AeroElectric-Archive.digest.vol-ii
December 18, 2008 - January 02, 2009
         successfully subscribed to a new list and then
         successfully un-subscribed from the same list.
         The system is working as advertised.
              ( . . .  a long habit of not thinking   )
              ( appearance of being right . . .       )
              (                  -Thomas Paine 1776-  )
Subject: Re: Dual Lightspeed Ignition modules
Date: Dec 18, 2008
Andrew, My two cents! I have personally seen more EMAG/PMAG failures then total electrical failure in single bus electrical systems (Z-11). Add a secondary battery (Z-19) and the statistics improve for a plasma system vs. EMAG/PMAG. Remember during a major electrical failure (for what ever reason) the Plasma systems only need, is a good battery for more flying time then the airplane will hold fuel. The EMAG/PMAG product has had more then it's fair share of field testing failures by the customer. A customer that didn't realize they were test subjects. Just my opinion viewed with actual 1st party data not 3rd! Mike Larkin -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Andrew Butler Sent: Thursday, December 18, 2008 5:57 AM Subject: Re: AeroElectric-List: Re: Dual Lightspeed Ignition modules Hi Jeff, I also plan on dual electronic ignition and my original design was practically identical to yours. This was when I was looking at Dual Plasma III Ignitions. Then I switched to dual P-MAGS. Reason? Simplicity and internal power. At this point I couldn't reason that the added complexity of the dual battery split bus was justified, and ended up removing the second battery from the design. Both the designs are attached, the dual alt, dual batt dating from April. The current design is more or less finished. Any takers of critiquing it for me? The originals are in Visio. If anyone wants a copy, let me know. Cheers, Andrew. ----- Original Message ----- From: "Jeff Page" <jpx(at)Qenesis.com> Sent: Wednesday, 17 December, 2008 3:44:53 PM GMT +00:00 GMT Britain, Ireland, Portugal Subject: AeroElectric-List: Re: Dual Lightspeed Ignition modules I plan dual electronic ignitions for my aircraft. I started with Z13/8. As much as I expect the designers have done significant things to ensure the ignitions work, in spite of nasty power events, I finally decided I wanted completely isolated electrical systems, so any problem, no matter how unlikely or unpredictable, could not prevent continued flight. So I added a few features from Z14. I didn't go all the way. My aux battery is very small, and driven by an SD-8 alternator. I did not join the batteries together for extra jolt when starting. I do have a small cross-feed relay that will allow the SD-8 to power the essential bus if the main alternator fails. The biggest thing I wrestled with, was how was my wife to know what switches to throw in the event of an alternator failure ? Together we came up with coloured lines joining the warning light and switches that are numbered. This low voltage light goes on, then flip these switches in this order. You can view my power diagram and the switch layout here: http://www.curtispriest.com/tundra/Electrical Jeff Page Dream Aircraft Tundra #10 > Speaking of Hall Effect stuff, I just purchased two LightSpeed III hall > effect ignition modules. The mfg says to connect the + side of the > controller through a pull-able breaker then directly to the battery > terminal. Ok, that covers their insurance folks if I crash. On the other > hand I am using Z-13 and was thinking of using the same scenario but > connecting them to the main battery bus using an ATC fuse and skipping > the breaker. I was never a proponent of having extra wires hanging off > the + side of the battery terminal. AS in Z-13 I will have a switch to > turn them on/off as necessary. > > Has anyone wired up two of these and which method did you use. > > Glenn -Matt Dralle, List Admin. - MS - 10/27/2008 7:57 AM 10/27/2008 7:57 AM ________________________________________________________________________________
Date: Dec 18, 2008
Glenn, The reason for wiring the Lightspeed Plasma systems directly to the battery is to prevent engine failure should you experience a bus failure (a bus short, over voltage, or heavy drain buy a runaway device. The object is that you could simply shut off all electric and continue to fly (powering the Lightspeed system directly from a battery). If you wire the Plasma system to the bus, you would become a glider in the event of an electrical problem. In my opinion the Lightspeed dual system requires two batters in the airplane period. Anything less will only serve to help you glider logbook. Mike Larkin -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Jeff Page Sent: Wednesday, December 17, 2008 8:45 AM Subject: AeroElectric-List: Re: Dual Lightspeed Ignition modules I plan dual electronic ignitions for my aircraft. I started with Z13/8. As much as I expect the designers have done significant things to ensure the ignitions work, in spite of nasty power events, I finally decided I wanted completely isolated electrical systems, so any problem, no matter how unlikely or unpredictable, could not prevent continued flight. So I added a few features from Z14. I didn't go all the way. My aux battery is very small, and driven by an SD-8 alternator. I did not join the batteries together for extra jolt when starting. I do have a small cross-feed relay that will allow the SD-8 to power the essential bus if the main alternator fails. The biggest thing I wrestled with, was how was my wife to know what switches to throw in the event of an alternator failure ? Together we came up with coloured lines joining the warning light and switches that are numbered. This low voltage light goes on, then flip these switches in this order. You can view my power diagram and the switch layout here: http://www.curtispriest.com/tundra/Electrical Jeff Page Dream Aircraft Tundra #10 > Speaking of Hall Effect stuff, I just purchased two LightSpeed III hall > effect ignition modules. The mfg says to connect the + side of the > controller through a pull-able breaker then directly to the battery > terminal. Ok, that covers their insurance folks if I crash. On the other > hand I am using Z-13 and was thinking of using the same scenario but > connecting them to the main battery bus using an ATC fuse and skipping > the breaker. I was never a proponent of having extra wires hanging off > the + side of the battery terminal. AS in Z-13 I will have a switch to > turn them on/off as necessary. > > Has anyone wired up two of these and which method did you use. > > Glenn 10/27/2008 7:57 AM 10/27/2008 7:57 AM ________________________________________________________________________________
Date: Dec 18, 2008
Subject: Dual Lightspeed Ignition modules
Mike, How many failures do you know about with the E-Mag, P-Mag ignitions? How many failures of magneto ignitions have occured in the same time? Other ignitions of various configurations. Fact vs: opinion is very important. Nothing is perfect. The main reason we all use dual ignitions is for safety. It also gives us better fuel burn. Jim ____________________________________________________________ Live the good life! Click now for great retirement planning assistance! http://thirdpartyoffers.juno.com/TGL2141/fc/PnY6rw1hgimeim0pl7I4CFc1o21Xu2lJFNyMywOmmFBAAdKspEJHz/ ________________________________________________________________________________
Subject: LED Nav lights: recommendation?
Date: Dec 18, 2008
Bob-- Sorry to bother you with this but: do you have a vendor or vendors of LED Navigation lights you can recommend or at least point out to me? Especially ones that would sell their lights without driver so I can use yours. Having a bit of trouble locating such a product. Thanks, Ralph Finch Davis, CA RV-9A QB ________________________________________________________________________________
Date: Dec 18, 2008
Subject: Re: LED Nav lights: recommendation?
Ralph Finch wrote: > > Bob-- > > Sorry to bother you with this but: do you have a vendor or vendors of LED > Navigation lights you can recommend or at least point out to me? Especially > ones that would sell their lights without driver so I can use yours. Having > a bit of trouble locating such a product. > > besthongkong.com ________________________________________________________________________________
Date: Dec 18, 2008
I have been using dual Lightspeed ign for about 300 hrs on my Glll with no problems. Jim Robinson Glll- N79R --- On Thu, 12/18/08, James H Nelson wrote: From: James H Nelson <rv9jim(at)juno.com> Subject: AeroElectric-List: Dual Lightspeed Ignition modules Date: Thursday, December 18, 2008, 12:23 PM Mike, How many failures do you know about with the E-Mag, P-Mag ignitions? How many failures of magneto ignitions have occured in the same time? Other ignitions of various configurations. Fact vs: opinion is very important. Nothing is perfect. The main reason we all use dual ignitions is for safety. It also gives us better fuel burn. Jim ____________________________________________________________ Live the good life! Click now for great retirement planning assistance! http://thirdpartyoffers.juno.com/TGL2141/fc/PnY6rw1hgimeim0pl7I4CFc1o21Xu2l JFNyMywOmmFBAAdKspEJHz/ ________________________________________________________________________________
Date: Dec 18, 2008
Subject: RE: Dual Lightspeed Ignition modules
At 12:06 PM 12/18/2008, you wrote: > >Glenn, > >The reason for wiring the Lightspeed Plasma systems directly to the >battery is to prevent engine failure should you experience a bus failure >(a bus short, over voltage, or heavy drain buy a runaway device. The >object is that you could simply shut off all electric and continue to >fly (powering the Lightspeed system directly from a battery). If you >wire the Plasma system to the bus, you would become a glider in the >event of an electrical problem. In my opinion the Lightspeed dual >system requires two batters in the airplane period. Anything less will >only serve to help you glider logbook. How do those feared risks occur? How do you get a shorted battery bus failure? How does connection directly to the battery protect against an overvoltage condition? What matter of "runaway device" can you imagine that brings the entire system to its knees? As long as we're in the free-ranging imagination mode, how about bursting batteries, open batteries, etc. etc. It's easy to hypothesize about all manner of failure but the acid test is the repeatable experiment. Get any combination of implements you choose and MAKE one of those events happen. If it can happen accidently, then you can make it happen. If it's exceedingly difficult or impossible to MAKE it happen, then concerns for accidental events go away. The physics of events do not change for random versus purposeful failures. Suppose your engine is also dependent upon electrically delivered fuel? The path to Nirvana is more than hooking certain accessories directly to the battery with some notion of fending off nargles. Failure Mode Effects Analysis is a science and exercise in logic that has served aviation (and others) very well for 100+ years. Making sure the electrically dependent engine is not left in dark has been discussed here on the list for over ten years. These discussions have included consideration of auxiliary batteries both manually and automatically controlled. http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z29-30K.pdf http://www.aeroelectric.com/articles/bat_iso2.pdf http://www.aeroelectric.com/Catalog/AEC/9005/9005-701B.pdf There are well considered rationale for dual accessories and power sources that do not concern themselves with the statistically improbable or physically impossible failure. These were the thought processes that went into crafting Z-19 for certain kinds of engines. http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z19m_1.pdf http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z19m_2.pdf Let us not get bogged down with concerns about why and how to tie multiple wires to the battery(+) post. There are tried and well tested ways to architecture and fabricate an electrical system that grow out of confidence of understanding as opposed to nostrums that arise out of fear. Bob . . . ________________________________________________________________________________
Date: Dec 18, 2008
At 01:31 PM 12/18/2008, you wrote: > >Bob-- > >Sorry to bother you with this but: do you have a vendor or vendors of LED >Navigation lights you can recommend or at least point out to me? Especially >ones that would sell their lights without driver so I can use yours. Having >a bit of trouble locating such a product. > >Thanks, > >Ralph Finch >Davis, CA No bother at all sir. I must confess that I'm ignorant of the most attractive products to this task. My interest in the power supplies arose from discussions that I think came to this List from the RV folks. Seems the barefoot power supplies were taking radios down. My only participation to this point has been to make these devices more user friendly for installation and system friendly with respect to noise. The idea is catching on . . . I presume based on availability of attractive lamps. I sent two pairs of LED drivers out of the country last week! If folks on the List are aware of suppliers for LED products suited to the task of fabricating nav lights, I'd be pleased to be made aware of them. I'll tie a list of recommendations to the last page of the document that I crafted for the power supplies. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
Date: Dec 18, 2008
I would agree..There have been a handful of failures, some of those were serious where the E/Pmag lost its timing reference. There were two reasons for this..One was where the firmware would see a false pressure spike and would then revert to its factory default timing..This was fixed a while ago and seems to have not re-occured. The other reason was because the magnet was shifting on the end of the shaft. There have been several fixes for this but I believe the lastest one has finally got it. The magnet is now silver soldered on the holder and the holder is keyed to the end of the shaft. Now of course this latest revision does not have that many hours on it so by default its unproven over the long term but it sure looks like a robust solution. I have over 300 hours on an E/Pmag combo and did have some early teething troubles. I know have the latest fixes and feel quite comfortable flying behind them. Frank -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of James H Nelson Sent: Thursday, December 18, 2008 11:23 AM Subject: AeroElectric-List: Dual Lightspeed Ignition modules --> Mike, How many failures do you know about with the E-Mag, P-Mag ignitions? How many failures of magneto ignitions have occured in the same time? Other ignitions of various configurations. Fact vs: opinion is very important. Nothing is perfect. The main reason we all use dual ignitions is for safety. It also gives us better fuel burn. Jim ____________________________________________________________ Live the good life! Click now for great retirement planning assistance! http://thirdpartyoffers.juno.com/TGL2141/fc/PnY6rw1hgimeim0pl7I4CFc1o21Xu2lJFNyMywOmmFBAAdKspEJHz/ ________________________________________________________________________________
Subject: Re: tried to unsub. can't. how do I?
Date: Dec 18, 2008
Subject: test #4 - I know I unsubbed and resubbed now!
Date: Dec 18, 2008
Date: Dec 18, 2008
FWIW dept. Marc Zeitlin documents the saga of his experiences, 2004 - 2008, with the product line. http://www.cozybuilders.org/Emagair_Warning/index.html Dale R. COZY MkIV #0497 Ch. 12 James H Nelson wrote: > > Mike, > How many failures do you know about with the E-Mag, P-Mag > ignitions? How many failures of magneto ignitions have occured in the > same time? Other ignitions of various configurations. Fact vs: opinion > is very important. Nothing is perfect. The main reason we all use dual > ignitions is for safety. It also gives us better fuel burn. > > Jim > ________________________________________________________________________________
Date: Dec 18, 2008
Subject: Re: test #4 - I know I unsubbed and resubbed now!
David M wrote: > David, Are you sending your messages as "attachments"? Either your mailer or the matronics mailer seems to be stripping off your content. Try setting up your mail handler to send "plain text" or "ASCII". Dale R. ________________________________________________________________________________
Date: Dec 19, 2008
Dale wrote >FWIW dept. > > Marc Zeitlin documents the saga of his experiences, 2004 - 2008, with the > product line. And then there is the silent majority that are happy with their PMAG. Yes some people have had problems, and there have been teething problems.I have had to send mine back for an update. But I haven't had any problems with mine. I only have 90 Hrs on them but many others have 100's of hours on theirs. Just to balance the argument. Chris Byrne ________________________________________________________________________________
Date: Dec 18, 2008
From: "Henry Trzeciakowski" <hammer408(at)comcast.net>
Subject: Re: Ignition Switch
Date: Dec 18, 2008
Bob: I just purchased an ACS Ignition Switch (A-510-2) [ Off-Right-Left-Both-Start] and was looking at their wiring instructions. I then downloaded your Z-26 diagram for Ignition Switch Options - Magento. Both wiring diagrams are basically identical with a few differences: Both diagrams jumper GRD &R for impulse coupling to Right Mag - shielded wire Both depict L to Left Mag - shielded wire Both depict B to Main Bus (7amp) Both diagram S to Starter Seleniod The differences are: ACS has shielded wire grounded at the right & left mag only, and the GRD terminal grounded at the grounding block or nearest structure. whereas your Z-26 have these wires shielded at both ends with the shield closest to the ignition switch wired to the GRD, but your GRD is NOT grounded to a grounding block or nearest structure.... ACS also says to use all shielded wire....I personally think that is overkill... So, would you recommend grounding at both ends of the shielding wire, but why not ground at the switch, or was this accidently omitted by you? Comments, suggestions appreciated. Henry ________________________________________________________________________________
Date: Dec 18, 2008
David - Do you have McAfee VirusScan on your computer? I've seen some reports that virus scanning on the outgoing messages can somehow cause the messages to appear to be blank. I have no idea why this would be so, or if this is fact or fiction. But, it may be worthwhile turning off any virus scanning for a test. Kevin Horton On 18-Dec-08, at 18:30 , David M wrote: > > ________________________________________________________________________________
Date: Dec 18, 2008
Still not working ----- Original Message ----- From: "David M" <ainut(at)hiwaay.net> Sent: Thursday, December 18, 2008 3:08 PM Subject: AeroElectric-List: test #4 - I know I unsubbed and resubbed now! > > > ________________________________________________________________________________
Date: Dec 18, 2008
Hi David, Looking at the message source I can see your text, but there is also some extra gunk in there that seems to be messing things up, and it looks like it is being generated on your computer. You might try disabling your AVG virus scanner, and then send another e-mail to see if that corrects the issue. The message header has a Content-Type "=======AVGMAIL-494ADD2F0000=======" info embedded in it, along with three other lines that also have "Content-Type" header information, including some embedded part way down the message, which does not look right to me. The only other idea is something is set incorrectly with the Microsoft Outlook Express program that you are using. If hiiway.net offers a web interface to your e-mail, you might try sending a message from that to bypass Outlook Express. You might also try another e-mail program such as Thunderbird. -Dj -- Dj Merrill - N1JOV Sportsman 2+2 Builder #7118 N421DJ KR-2 Builder N770DJ http://deej.net/sportsman/ http://deej.net/kr-2/ "Many things that are unexplainable happen during the construction of an airplane." --Dave Prizio, 30 Aug 2005 ________________________________________________________________________________
Subject: and my email is set to plain text!
Date: Dec 18, 2008
Subject: test 6, avg outgoing turned off
Date: Dec 18, 2008
test #6 ----- Original Message ----- From: "Kevin Horton" <khorton01(at)rogers.com> Sent: Thursday, December 18, 2008 6:13 PM Subject: Re: AeroElectric-List: test #4 - I know I unsubbed and resubbed now! > > > David - Do you have McAfee VirusScan on your computer? I've seen some > reports that virus scanning on the outgoing messages can somehow cause > the messages to appear to be blank. I have no idea why this would be > so, or if this is fact or fiction. But, it may be worthwhile turning > off any virus scanning for a test. > > Kevin Horton > > On 18-Dec-08, at 18:30 , David M wrote: > >> >> > > -------------------------------------------------------------------------------- Checked by AVG - http://www.avg.com 8:06 PM ________________________________________________________________________________
Date: Dec 18, 2008
Subject: Re: test 6, avg outgoing turned off
Ta Da! That did it. On Thu, Dec 18, 2008 at 6:55 PM, David M wrote: > > test #6 > > ________________________________________________________________________________
Date: Dec 18, 2008
Looks Good!! Happy Skies Old Bob AKA Bob Siegfried Ancient Aviator 628 West 86th Street Downers Grove, IL 60516 630 985-8502 Stearman N3977A Brookeridge Air Park LL22 In a message dated 12/18/2008 8:59:51 P.M. Central Standard Time, ainut(at)hiwaay.net writes: test #6 **************One site keeps you connected to all your email: AOL Mail, Gmail, and Yahoo Mail. Try it now. ________________________________________________________________________________
Date: Dec 18, 2008
Now that it's working what was the message? Better be good! HA HA Tim ----- Original Message ----- From: BobsV35B(at)aol.com To: aeroelectric-list(at)matronics.com Sent: Thursday, December 18, 2008 8:04 PM Subject: Re: AeroElectric-List: test 6, avg outgoing turned off Looks Good!! Happy Skies Old Bob AKA Bob Siegfried Ancient Aviator 628 West 86th Street Downers Grove, IL 60516 630 985-8502 Stearman N3977A Brookeridge Air Park LL22 In a message dated 12/18/2008 8:59:51 P.M. Central Standard Time, ainut(at)hiwaay.net writes: test #6 ------------------------------------------------------------------------- ----- One site keeps you connected to all your email: AOL Mail, Gmail, and Yah&ncid=emlcntaolcom00000025">Try it now. ________________________________________________________________________________
Date: Dec 18, 2008
Yay! It works now!!! David ----- Original Message ----- From: "David M" <ainut(at)hiwaay.net> Sent: Thursday, December 18, 2008 8:55 PM Subject: AeroElectric-List: test 6, avg outgoing turned off > > test #6 > > > ----- Original Message ----- > From: "Kevin Horton" <khorton01(at)rogers.com> > To: > Sent: Thursday, December 18, 2008 6:13 PM > Subject: Re: AeroElectric-List: test #4 - I know I unsubbed and resubbed > now! > > >> >> >> David - Do you have McAfee VirusScan on your computer? I've seen some >> reports that virus scanning on the outgoing messages can somehow cause >> the messages to appear to be blank. I have no idea why this would be >> so, or if this is fact or fiction. But, it may be worthwhile turning >> off any virus scanning for a test. >> >> Kevin Horton >> >> On 18-Dec-08, at 18:30 , David M wrote: >> >>> >>> >> >> >> >> >> > > > -------------------------------------------------------------------------------- > > > Checked by AVG - http://www.avg.com > 8:06 PM > > -------------------------------------------------------------------------------- Checked by AVG - http://www.avg.com 8:06 PM ________________________________________________________________________________
Subject: current sensors
Date: Dec 18, 2008
I'm going to use these in my OBAM 12v home made EFIS: Allegro ACS750xCA-100 Cheap, easy, and hopefully reliable. No moving parts. :) David ________________________________________________________________________________
Date: Dec 19, 2008
Hi Mike, Thanks for this. All two are welcome, as they help build a big picture of all sides of those coins. I am aware of the issues with the P-Mags (magnets and the like) and this is why I have decided to wire up for dual P-mags, but only install one. This will still give me most of the benefits of the e-ignition, while allowing me to rest easy with regards any gremlins that might exist. I'll let the Slick MAG do its thing and see how things are in a couple of years with regards replacing it............ Cheers, Andrew. ----- Original Message ----- From: "Mike" <mlas(at)cox.net> Sent: Thursday, 18 December, 2008 5:57:58 PM GMT +00:00 GMT Britain, Ireland, Portugal Subject: RE: AeroElectric-List: Re: Dual Lightspeed Ignition modules Andrew, My two cents! I have personally seen more EMAG/PMAG failures then total electrical failure in single bus electrical systems (Z-11). Add a secondary battery (Z-19) and the statistics improve for a plasma system vs. EMAG/PMAG. Remember during a major electrical failure (for what ever reason) the Plasma systems only need, is a good battery for more flying time then the airplane will hold fuel. The EMAG/PMAG product has had more then it's fair share of field testing failures by the customer. A customer that didn't realize they were test subjects. Just my opinion viewed with actual 1st party data not 3rd! Mike Larkin -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Andrew Butler Sent: Thursday, December 18, 2008 5:57 AM Subject: Re: AeroElectric-List: Re: Dual Lightspeed Ignition modules Hi Jeff, I also plan on dual electronic ignition and my original design was practically identical to yours. This was when I was looking at Dual Plasma III Ignitions. Then I switched to dual P-MAGS. Reason? Simplicity and internal power. At this point I couldn't reason that the added complexity of the dual battery split bus was justified, and ended up removing the second battery from the design. Both the designs are attached, the dual alt, dual batt dating from April. The current design is more or less finished. Any takers of critiquing it for me? The originals are in Visio. If anyone wants a copy, let me know. Cheers, Andrew. ----- Original Message ----- From: "Jeff Page" <jpx(at)Qenesis.com> Sent: Wednesday, 17 December, 2008 3:44:53 PM GMT +00:00 GMT Britain, Ireland, Portugal Subject: AeroElectric-List: Re: Dual Lightspeed Ignition modules I plan dual electronic ignitions for my aircraft. I started with Z13/8. As much as I expect the designers have done significant things to ensure the ignitions work, in spite of nasty power events, I finally decided I wanted completely isolated electrical systems, so any problem, no matter how unlikely or unpredictable, could not prevent continued flight. So I added a few features from Z14. I didn't go all the way. My aux battery is very small, and driven by an SD-8 alternator. I did not join the batteries together for extra jolt when starting. I do have a small cross-feed relay that will allow the SD-8 to power the essential bus if the main alternator fails. The biggest thing I wrestled with, was how was my wife to know what switches to throw in the event of an alternator failure ? Together we came up with coloured lines joining the warning light and switches that are numbered. This low voltage light goes on, then flip these switches in this order. You can view my power diagram and the switch layout here: http://www.curtispriest.com/tundra/Electrical Jeff Page Dream Aircraft Tundra #10 > Speaking of Hall Effect stuff, I just purchased two LightSpeed III hall > effect ignition modules. The mfg says to connect the + side of the > controller through a pull-able breaker then directly to the battery > terminal. Ok, that covers their insurance folks if I crash. On the other > hand I am using Z-13 and was thinking of using the same scenario but > connecting them to the main battery bus using an ATC fuse and skipping > the breaker. I was never a proponent of having extra wires hanging off > the + side of the battery terminal. AS in Z-13 I will have a switch to > turn them on/off as necessary. > > Has anyone wired up two of these and which method did you use. > > Glenn -Matt Dralle, List Admin. - MS - 10/27/2008 7:57 AM 10/27/2008 7:57 AM ________________________________________________________________________________
Date: Dec 19, 2008
How do those feared risks occur? How do you get a shorted battery bus failure? How does connection directly to the battery protect against an overvoltage condition? What matter of "runaway device" can you imagine that brings the entire system to its knees? As long as we're in the free-ranging imagination mode, how about bursting batteries, open batteries, etc. etc. Lets see, a tool across the bus, or direct short from a chafed wire, the loss of the ground bus on a composite airplane just to name a few. I have a story from a dark and stormy night where the air conditioner started to break down and started to draw over 150 amps and caused both Gen's to go off line and pull the volts down to about seven volts. The CB didn't trip, everything just went almost completely dark before we got the air conditioner off. Then we were able to restore power. The problem, if we couldn't shut the Air conditioner off or couldn't figure out the problem in time (if this airplane had a battery powered ignition system) the engine would have failed, where simply turning the bus off would have restored the engine or maybe even had enough voltage at the battery to keep the engine running. Oh, the airplane referenced was a certified airplane. It's easy to hypothesize about all manner of failure but the acid test is the repeatable experiment. Get any combination of implements you choose and MAKE one of those events happen. If it can happen accidently, then you can make it happen. If it's exceedingly difficult or impossible to MAKE it happen, then concerns for accidental events go away. The physics of events do not change for random versus purposeful failures. Bob, I sometime wonder if you fly or are around flying. This isn't a hypothesis; it's based on real people in real airplanes. The fact is that electrical systems fail with regularity, some worse then others. An engine failure on top of that in many cases is a near death experience. Loosing the engine is not the same as loosing the transponder. Why do we use vacuum or backup batteries to power important instrument systems? Don't you think the ignition system deserves the same respect? Suppose your engine is also dependent upon electrically delivered fuel? The path to Nirvana is more than hooking certain accessories directly to the battery with some notion of fending off nargles. Failure Mode Effects Analysis is a science and exercise in logic that has served aviation (and others) very well for 100+ years. It's not! In aviation failures that occur in the field are often not reported. Airplanes with electrical systems have been around for less the 100 years and electronic ignitions in aviation much less. We are all inventing new system designs that are not able to accept total failure of the total system. Making sure the electrically dependent engine is not left in dark has been discussed here on the list for over ten years. These discussions have included consideration of auxiliary batteries both manually and automatically controlled. Yes, but not everyone has been here for 10 years and most of the products and concepts haven't been either. Mike 10/27/2008 7:57 AM ________________________________________________________________________________
Date: Dec 19, 2008
I have had direct interaction with four EMAG/PMAG airplanes where the airplane was unflyable (loss of power in flight, or would not run on the ground). I have seen many more mag failures but I have not seen both fail at the same time making the airplane unflyable. I have also seen one failure on the Lightspeed system but never a dual failure. Some of the EMAG failures may have been isolatable in flight causing a single failure on a dual system vs. the dual failures that caused landing out or not running at all. Mike -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of James H Nelson Sent: Thursday, December 18, 2008 12:23 PM Subject: AeroElectric-List: Dual Lightspeed Ignition modules Mike, How many failures do you know about with the E-Mag, P-Mag ignitions? How many failures of magneto ignitions have occured in the same time? Other ignitions of various configurations. Fact vs: opinion is very important. Nothing is perfect. The main reason we all use dual ignitions is for safety. It also gives us better fuel burn. Jim ____________________________________________________________ Live the good life! Click now for great retirement planning assistance! http://thirdpartyoffers.juno.com/TGL2141/fc/PnY6rw1hgimeim0pl7I4CFc1o21X u2lJFNyMywOmmFBAAdKspEJHz/ 10/27/2008 7:57 AM 10/27/2008 7:57 AM ________________________________________________________________________________
Date: Dec 19, 2008
Subject: Re: RE: Dual Lightspeed Ignition modules
Mike wrote: > Making sure the electrically dependent engine is not > left in dark has been discussed here on the list for > over ten years. These discussions have included consideration > of auxiliary batteries both manually and automatically > controlled. > > Yes, but not everyone has been here for 10 years and most of the > products and concepts haven't been either. > > That statement shows a lot of insight, Mike. As the technology we use evolves, some things that were critical become secondary, and some things that were minor become critical. With respect to electrically dependent (ED) engines, I think we can boil all the concerns down to three things that the engine must have to keep running: air, fuel, and spark. A bulletproof system will have full redundancy across all three. Redundant air is generally provided by some sort of flapper valve or some such thingy to get around a clogged air filter, but the biggest problem with air is carb icing. This is one area where electronic injection shines. A significant portions of accidents occur when a carb ices up where the fuel is evaporated into the air. EI moves the evaporation location closer to the combustion location, where there is more heat to keep the ice from forming. Icing is still possible, just less so. Either way, methods for avoiding cutting off the air supply look the same for all types of engines. Redundant fuel is harder for ED engines. Fuel pumps are hard working devices that are reliable, but do not have infinite lifespan, and it depends on a lot of upstream stuff to work. A backup pump only backs up the pump. For it to be a true alternate system, you have to backup everything, up to and including the power generation source. Even with a second pump, I chose to go low tech and provide a gravity fed drip line to the air intake with a needle valve control. I would never be able to get the engine started with this on the ground...and I'd never want to. Control is slow and unresponsive, but it will get me to the nearest airport. It is meant as a backup to keep the fan turning in an emergency. This would work for any engine. Low wing aircraft would need a header tank higher than the engine. The vast majority of aircraft being built in garages today could stay straight and level for an hour with 5gal of fuel, and travel nearly 100 miles. At a time when everything is going that badly the only place you should be trying to get to is 'nearest'. High wing aircraft would be able to run the tanks dry with this method. The spark is also more difficult for ED. Airplane engines are designed with two independent, self contained spark producers. Each mag has a generator, a distributor and coil all in one tidy package. You just have to bolt them on and plug them in. Moving to ED generally means that you're breaking the generator and spark producer apart. Most designs have two spark producers, but combine the generators into one, and depend on the battery for backup. Again, this isn't really redundancy. My design calls for using two EDIS modules (self-contained electronic ignition controller used by Ford), and converting the old distributor to a generator. One EDIS module runs off ship's power. The other is powered by the tiny generator (less than 5 amps) that was once the distributor. If I lose ship's power, the secondary ignition will keep right on going. The two are completely independent. So Mike is correct. New products call for new thinking...but the thinking really goes back to the same basic principles. The engine must have air, spark and fuel. Backup systems must be able to deliver without depending on the primary system. It is best to assume that the primary system doesn't exist AT ALL when designing the backup. There's a lot of new under the sun....just it's not, really. ________________________________________________________________________________
Date: Dec 19, 2008
Mike and Bob, Thank you both for your input. I have emailed with Jeff P. and I've decided a second battery (even a small 4.5 ah job) would be a good idea as an independent source for keeping at least one ignition going even if I shut down the power completely and simply had to fly home with just the engine. Mike, as you indicated that is the reason Lightspeed likes it wired directly to the battery. Depending on a bus which is behind a solenoid is asking for trouble. Yes, I've replaced more than one solenoid on aircraft in the field and fortunately with mags there was no dependency. FYI, stealing a solenoid off the FBOs old pick-up truck works in airplanes too. Parts do fail, but only when you're flying - funny that. The Lightspeed draws little power and I only need 1-2 amps to find a landing spot. It may be that I install it inside the cabin and keep it charged just as a backup. A big part of the process is monitoring and recognizing when the system is acting up and when (and how) to shut it down - that's process. I have done enough flying in the dark to realize the importance of a backup something. Thanks to all for the diagrams and discussion. Glenn -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Mike Sent: Friday, December 19, 2008 8:01 AM Subject: RE: AeroElectric-List: RE: Dual Lightspeed Ignition modules How do those feared risks occur? How do you get a shorted battery bus failure? How does connection directly to the battery protect against an overvoltage condition? What matter of "runaway device" can you imagine that brings the entire system to its knees? As long as we're in the free-ranging imagination mode, how about bursting batteries, open batteries, etc. etc. Lets see, a tool across the bus, or direct short from a chafed wire, the loss of the ground bus on a composite airplane just to name a few. I have a story from a dark and stormy night where the air conditioner started to break down and started to draw over 150 amps and caused both Gen's to go off line and pull the volts down to about seven volts. The CB didn't trip, everything just went almost completely dark before we got the air conditioner off. Then we were able to restore power. The problem, if we couldn't shut the Air conditioner off or couldn't figure out the problem in time (if this airplane had a battery powered ignition system) the engine would have failed, where simply turning the bus off would have restored the engine or maybe even had enough voltage at the battery to keep the engine running. Oh, the airplane referenced was a certified airplane. It's easy to hypothesize about all manner of failure but the acid test is the repeatable experiment. Get any combination of implements you choose and MAKE one of those events happen. If it can happen accidently, then you can make it happen. If it's exceedingly difficult or impossible to MAKE it happen, then concerns for accidental events go away. The physics of events do not change for random versus purposeful failures. Bob, I sometime wonder if you fly or are around flying. This isn't a hypothesis; it's based on real people in real airplanes. The fact is that electrical systems fail with regularity, some worse then others. An engine failure on top of that in many cases is a near death experience. Loosing the engine is not the same as loosing the transponder. Why do we use vacuum or backup batteries to power important instrument systems? Don't you think the ignition system deserves the same respect? Suppose your engine is also dependent upon electrically delivered fuel? The path to Nirvana is more than hooking certain accessories directly to the battery with some notion of fending off nargles. Failure Mode Effects Analysis is a science and exercise in logic that has served aviation (and others) very well for 100+ years. It's not! In aviation failures that occur in the field are often not reported. Airplanes with electrical systems have been around for less the 100 years and electronic ignitions in aviation much less. We are all inventing new system designs that are not able to accept total failure of the total system. Making sure the electrically dependent engine is not left in dark has been discussed here on the list for over ten years. These discussions have included consideration of auxiliary batteries both manually and automatically controlled. Yes, but not everyone has been here for 10 years and most of the products and concepts haven't been either. Mike 10/27/2008 7:57 AM ________________________________________________________________________________
Date: Dec 19, 2008
At 07:01 AM 12/19/2008, you wrote: > > > How do those feared risks occur? > > How do you get a shorted battery bus failure? How does > connection directly to the battery protect against > an overvoltage condition? What matter of "runaway > device" can you imagine that brings the entire system > to its knees? As long as we're in the free-ranging > imagination mode, how about bursting batteries, > open batteries, etc. etc. > >Lets see, a tool across the bus, or direct short from a chafed wire, the >loss of the ground bus on a composite airplane just to name a few. . . . and are these all not manifestations of poor craftsmanship or maintenance? If we're going to add band-aids to any system that go to offsetting sub-standard behavior by someone who has touched the airplane . . . where does it end? >I have a story from a dark and stormy night where the air conditioner >started to break down and started to draw over 150 amps and caused both >Gen's to go off line and pull the volts down to about seven volts. The >CB didn't trip, everything just went almost completely dark before we >got the air conditioner off. Then we were able to restore power. The >problem, if we couldn't shut the Air conditioner off or couldn't figure >out the problem in time (if this airplane had a battery powered ignition >system) the engine would have failed, where simply turning the bus off >would have restored the engine or maybe even had enough voltage at the >battery to keep the engine running. Oh, the airplane referenced was a >certified airplane. . . . and what did you learn from this or any other story that would give you pause for evaluating your own project? Are there things that could or should have been done in the original design processes that would have prevented this incident? Suppose your RV doesn't even HAVE a piece-of-@#$@# air conditioner.What is the value of taking one incident where the designers/fabricators/maintainers/operators stubbed there collective toes and then levying new requirements on ALL airplanes that work-around the SYMPTOMS of that one case? >Bob, I sometime wonder if you fly or are around flying. This isn't a >hypothesis; it's based on real people in real airplanes. The fact is >that electrical systems fail with regularity, some worse then others. >An engine failure on top of that in many cases is a near death >experience. Loosing the engine is not the same as loosing the >transponder. Why do we use vacuum or backup batteries to power >important instrument systems? Don't you think the ignition system >deserves the same respect? My career in aviation began in 1955 when I helped an uncle install an MANUAL direction finder loop in his 170. He could put holes in the airplane but couldn't read a diagram or solder. I was 12 years old. I retired from Hawker-Beechcraft 18 months ago as the subject matter expert leader in electronics/electrical systems. I'm still contracting to that organization and several others who specialize in aviation design and production. I'm an 1000 hour private pilot with about that many additional hours as a test engineer on TC aircraft and 50 times that time as a designer, qualifier and troubleshooter of airborne systems. I'm now 66 years old and still in the business. >It's not! In aviation failures that occur in the field are often not >reported. Airplanes with electrical systems have been around for less >the 100 years and electronic ignitions in aviation much less. We are >all inventing new system designs that are not able to accept total >failure of the total system. Agreed. But just as fuel flow under all anticipated flight conditions was the big stumbling block for many a designer 70 years ago, we have a new challenge that isn't any different. Just as there's no excuse for total failure of fuel flow, there is NO EXCUSE for total failure of an electrical system. Yeah, it has happened which means there's a REASON but there is still no excuse. >Yes, but not everyone has been here for 10 years and most of the >products and concepts haven't been either. Just because it is new doesn't mean that the thought processes and fabrication techniques for airworthiness are any different than what has worked well for decades. Suppose we consider an RV with a piece of @#$@ air conditioner with a failure mode that sucks down the entire system? Of what value is it to tie one or both systems directly to the (+) battery post? Which is better, refine the A/C design or add weight, complexity, cost-of-ownership to offset the possibility that the A/C causes an unhappy day in the cockpit? On a related topic. Lots of folks are trying to figure out ways to integrate lithium-ion batteries into aircraft. It's no mean task. While the energy/weight radio of l-ion is seductive, it's sorta like figuring out a way to burn nitro-glycerine in your engine. Wow! What energy potential! Now, how do you integrate this potential into an existing, highly refined system in a way that does not increase risk? There are people who worry a lot about things they don't understand. There are people who are paid to worry a lot about things they presumably understand and use force of law to modify our behavior such that THEIR worries are mitigated . . . all in the name of 'safety'. http://www.hsegroup.com/hse/text/caffiene.htm http://aeroelectric.com/Pictures/Misc/Cowboy_after_OSHA.jpg My point about your posting was that it tended to reenforce the notion that there was a valid WORRY to be address without adding understanding. An understanding of design for failure-tolerance, craftsmanship, maintenance and operation such that worries go away. There are few suppliers to aviation that have a working knowledge of low-risk, light-weight, failure- tolerant system design. If we attached every worry-wart's product to the battery(+) post . . . it's easy to see where that idea leads! Bob . . . ________________________________________________________________________________
Subject: LED Position Lights
Date: Dec 19, 2008
This isn't an exact answer to your question about LED wingtip position lights, but it might be helpful. I'm using these LED wingtip position lights on my airplane: https://ssl.perfora.net/www.gs-air.com/sess/utn;jsessionid=15494c3e0b2a 590/shopdata/index.shopscript In addition to the red/green forward position light and the white aft position light, that both use LEDs, they also use a conventional strobe light. I talked with GS-Air the other day and they are close to finalizing a new wingtip position light that also uses LEDs for the "strobe" light. Best, Dennis Lancair Legacy, 225 hours ________________________________________________________________________________
Date: Dec 19, 2008
----- Original Message ----- From: Henry Trzeciakowski Sent: Thursday, December 18, 2008 7:09 PM Subject: AeroElectric-List: Re: Ignition Switch Bob: I just purchased an ACS Ignition Switch (A-510-2) [ Off-Right-Left-Both-Start] and was looking at their wiring instructions. I then downloaded your Z-26 diagram for Ignition Switch Options - Magento. Both wiring diagrams are basically identical with a few differences: Both diagrams jumper GRD &R for impulse coupling to Right Mag - shielded wire Both depict L to Left Mag - shielded wire Both depict B to Main Bus (7amp) Both diagram S to Starter Seleniod The differences are: ACS has shielded wire grounded at the right & left mag only, and the GRD terminal grounded at the grounding block or nearest structure. whereas your Z-26 have these wires shielded at both ends with the shield closest to the ignition switch wired to the GRD, but your GRD is NOT grounded to a grounding block or nearest structure.... ACS also says to use all shielded wire....I personally think that is overkill... So, would you recommend grounding at both ends of the shielding wire, but why not ground at the switch, or was this accidently omitted by you? Comments, suggestions appreciated. Henry ________________________________________________________________________________
Date: Dec 20, 2008
Subject: How do you hold a pull able breaker opened
Hi Guys I have a P+B pull able breaker I want to use as my E-Bus feed. I ordered a small clip from Spruce used for that purpose, but I guess it is for a Klixon breaker, it's too large in diameter and not wide enough for a P+B pull able breaker. Anyone have any suggestions? I cut a blue translucent piece of polyurethane fuel line to length, then slit it. It kinda works, but I have a suspicion someone has figured a better way. Thx. in advance Ron Parigoris ________________________________________________________________________________
Date: Dec 20, 2008
Subject: Re: How do you hold a pull able breaker opened
At 01:56 AM 12/20/2008, you wrote: > >Hi Guys > >I have a P+B pull able breaker I want to use as my E-Bus feed. > >I ordered a small clip from Spruce used for that purpose, but I guess it >is for a Klixon breaker, it's too large in diameter and not wide enough >for a P+B pull able breaker. > >Anyone have any suggestions? > >I cut a blue translucent piece of polyurethane fuel line to length, then >slit it. It kinda works, but I have a suspicion someone has figured a >better way. I'm having trouble visualizing your design goal. Are you talking about a "circuit breaker lock"? http://www.aircraftspruce.com/catalog/elpages/edmobreakerlocks.php I presume you're talking about the alternate feed path to the e-bus. What is the value in putting a breaker on the panel for this function as opposed to a switch? Do you plan to pre-flight check this path? Is there also wire protection on this path located right at the battery bus? Does not a little piece of plastic become a problematic cockpit accessory like loose fuses, AA batteries, pencils, pistachio shells and Hershey's kisses? Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Dec 20, 2008
At 11:41 PM 12/19/2008, you wrote: > >----- Original Message ----- >From: <mailto:hammer408(at)comcast.net>Henry Trzeciakowski >To: aeroelectric-list(at)matronics.com >Sent: Thursday, December 18, 2008 7:09 PM >Subject: AeroElectric-List: Re: Ignition Switch > >Bob: > >I just purchased an ACS Ignition Switch (A-510-2) [ >Off-Right-Left-Both-Start] and was looking at their wiring >instructions. I then downloaded your Z-26 diagram for Ignition >Switch Options - Magento. Both wiring diagrams are basically >identical with a few differences: > >Both diagrams jumper GRD &R for impulse coupling to Right Mag - shielded wire >Both depict L to Left Mag - shielded wire >Both depict B to Main Bus (7amp) >Both diagram S to Starter Seleniod > >The differences are: > >ACS has shielded wire grounded at the right & left mag only, and the >GRD terminal grounded at the grounding block or nearest structure. > >whereas your Z-26 have these wires shielded at both ends with the >shield closest to the ignition switch wired to the GRD, but your GRD >is NOT grounded to a grounding block or nearest structure.... > >ACS also says to use all shielded wire....I personally think that is >overkill... > >So, would you recommend grounding at both ends of the shielding >wire, but why not ground at the switch, or was this accidently omitted by you? > >Comments, suggestions appreciated. Yes, there are differences. I hope you will forgive me . . . I'm not trying to be obtuse but I just don't have the time at the moment to explain them. They've been discussed here on the List and you can probably find the exchanges in the matronics archives. It's a noise and ground loops issue. Bob . . . ________________________________________________________________________________
Date: Dec 20, 2008
Hi Bob Thx. for the reply. I am building a Europa monowheel with a electrical dependent Rotax 914. Battery is aft. I have a Flaming River battery contactor on the passenger headrest to be used as main battery contactor. I have panel laid out to my liking, and besides the fact that there is precious little panel space I do not like a cluttered panel with stuff that could be situated elsewhere. : http://www.europaowners.org/modules.php?set_albumName=album211&op=modload&name=gallery&file=index&include=view_album.php Thus it was my choice to make in and aft of passenger headrest an electrical center. Space is precious and the aft section of headrest mounted on the aluminium panel has 6 pullable circuit breakers and 3 circuit breaker/switches. : http://www.europaowners.org/modules.php?set_albumName=album261&op=modload&name=gallery&file=index&include=view_album.php Wire run from Battery switch to aft Bus is inches. Buss run to Shotky diode from battery switch is inches. Shotky Diode wire run to E-Buss alternate feed P+B pullable Breaker/Switch is inches. Aft buss, E-Buss and always hot buss are located on P+B Breakers/Breaker/Switches fabricated from .025" copper ~ 3/8" wide. Yes all wires are protected except for the short run from battery contactor. My always hot buss consists of only two things, pitch trim on a 1 amp pullable breaker and E-Buss alternate feed pullable breaker. It is the E-Buss alternate feed pullable breaker I wish to keep "pulled". I am afraid it could be accidental pushed in when flipping on and off 3 Breaker/Switches, which would kill my battery if I walked away from plane with it closed. My E-Buss consists of fuel pump #2, Rotax 914 TCU and Airmaster CS Propeller controller. The link included in your E-Mail from ACS is the exact breaker clip I have, but it is not designed for a P+B pullable breaker. The E-buss alternate feed is not something that will get much use, but if I need it, just smack the Flaming River main switch, push E-buss alternate feed and turn on pump #2. I don't like having stuff floating around cockpit, thus for this situation if I were to use my tube, would use a piece of Spectra to teather it. BTW Spectra is incredibly strong fishing line. Would be nice to have something like a sliding lock. I could invent something if i need to, but am hoping someone else figured out a reasonable solution. It just so happens my basement computer is on the light switch near the top of the steps. Got to be a pain when family would go upstairs and leave me in the dark, but worst they turned off computer. I fabricated a gizmo that lived on the switch plate attachment screw with just the right amount of "wiggulation" and it was put under switch so you couldn't turn it off without a bit of effort. Worked and still works great. Took me way over an hour to fabricate and get it tweaked. A few weeks later I saw essential the same thing in hardware store for under a buck. Anyway any ideas? Thx. Sincerely Ron Parigoris > I presume you're talking about the alternate feed path > to the e-bus. What is the value in putting a breaker on > the panel for this function as opposed to a switch? Do you > plan to pre-flight check this path? Is there also wire > protection on this path located right at the battery > bus? Does not a little piece of plastic become a problematic > cockpit accessory like loose fuses, AA batteries, pencils, > pistachio shells and Hershey's kisses? > > ________________________________________________________________________________
Date: Dec 20, 2008
At 03:25 PM 12/20/2008, you wrote: > >Hi Bob > >Thx. for the reply. > >I am building a Europa monowheel with a electrical dependent Rotax 914. >Battery is aft. I have a Flaming River battery contactor on the passenger >headrest to be used as main battery contactor. > >I have panel laid out to my liking, and besides the fact that there is >precious little panel space I do not like a cluttered panel with stuff >that could be situated elsewhere. : >http://www.europaowners.org/modules.php?set_albumName=album211&op=modload&name=gallery&file=index&include=view_album.php > >Thus it was my choice to make in and aft of passenger headrest an >electrical center. Space is precious and the aft section of headrest >mounted on the aluminium panel has 6 pullable circuit breakers and 3 >circuit breaker/switches. : >http://www.europaowners.org/modules.php?set_albumName=album261&op=modload&name=gallery&file=index&include=view_album.php > >Wire run from Battery switch to aft Bus is inches. Buss run to Shotky >diode from battery switch is inches. Shotky Diode wire run to E-Buss >alternate feed P+B pullable Breaker/Switch is inches. > >Aft buss, E-Buss and always hot buss are located on P+B >Breakers/Breaker/Switches fabricated from .025" copper ~ 3/8" wide. Yes >all wires are protected except for the short run from battery contactor. > >My always hot buss consists of only two things, pitch trim on a 1 amp >pullable breaker and E-Buss alternate feed pullable breaker. It is the >E-Buss alternate feed pullable breaker I wish to keep "pulled". I am >afraid it could be accidental pushed in when flipping on and off 3 >Breaker/Switches, which would kill my battery if I walked away from plane >with it closed. My E-Buss consists of fuel pump #2, Rotax 914 TCU and >Airmaster CS Propeller controller. > >The link included in your E-Mail from ACS is the exact breaker clip I >have, but it is not designed for a P+B pullable breaker. The E-buss >alternate feed is not something that will get much use, but if I need it, >just smack the Flaming River main switch, push E-buss alternate feed and >turn on pump #2. I don't like having stuff floating around cockpit, thus >for this situation if I were to use my tube, would use a piece of Spectra >to teather it. BTW Spectra is incredibly strong fishing line. > >Would be nice to have something like a sliding lock. > >I could invent something if i need to, but am hoping someone else figured >out a reasonable solution. > >It just so happens my basement computer is on the light switch near the >top of the steps. Got to be a pain when family would go upstairs and leave >me in the dark, but worst they turned off computer. I fabricated a gizmo >that lived on the switch plate attachment screw with just the right amount >of "wiggulation" and it was put under switch so you couldn't turn it off >without a bit of effort. Worked and still works great. Took me way over an >hour to fabricate and get it tweaked. A few weeks later I saw essential >the same thing in hardware store for under a buck. > >Anyway any ideas? What is the diameter of the cb button under the head? What is the gap (thickness of the clip)? Bob . . . ________________________________________________________________________________
Date: Dec 20, 2008
Hi Bob >>Anyway any ideas? > > What is the diameter of the cb button under the > head? What is the gap (thickness of the clip)? I just looked up spec sheet on W31 and they only provide head diameter which is .315". I will measure the length of head, and diameter and length of shaft (smaller diameter than head) and report back. Ron Parigoris ________________________________________________________________________________
Date: Dec 20, 2008
opened rparigor(at)SUFFOLK.LIB.NY.US wrote: > > Hi Bob > > >>> Anyway any ideas? >>> >> What is the diameter of the cb button under the >> head? What is the gap (thickness of the clip)? >> > > I just looked up spec sheet on W31 and they only provide head diameter > which is .315". > > I will measure the length of head, and diameter and length of shaft > (smaller diameter than head) and report back. > > Ron Parigoris > Why not just bend up a U shaped guard like you'd use to protect a toggle switch? Charlie ________________________________________________________________________________
Date: Dec 21, 2008
Hi Bob "> What is the diameter of the cb button under the > head? What is the gap (thickness of the clip)?>" The shaft sticking out of P+B pullable breaker has three tiers. Head is .312" diameter and .115" in length, and second tier below head is .250" in diameter and .200" in length, and third tier is .200" in diameter and .200"in length. Thus total shaft length sticking out measured from metal threaded portion to tipof head when pulled is .515" (.115" + .200" + .200"), with their threerespective diameters (head being the largest) .312", .250", .200". Ron Parigoris ________________________________________________________________________________
From: "Bill Schlatterer" <billschlatterer(at)sbcglobal.net>
Subject: Re: Ignition Switch - VAF Thread
Date: Dec 21, 2008
This thread pretty much covers it all on the starter switch and ground. Short story is that the GRD terminal on the 504 switch uses the shield on the P-Lead to get to the aircraft ground. Read this, should cover it for you. http://www.vansairforce.com/community/showthread.php?t=36272 <http://www.vansairforce.com/community/showthread.php?t=36272&highlight=Star ter+Switch> &highlight=Starter+Switch Hope this helps. Bill S 7a finishing _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Saturday, December 20, 2008 1:00 PM Subject: Re: Fw: AeroElectric-List: Re: Ignition Switch At 11:41 PM 12/19/2008, you wrote: ----- Original Message ----- From: Henry <mailto:hammer408(at)comcast.net> Trzeciakowski Sent: Thursday, December 18, 2008 7:09 PM Subject: AeroElectric-List: Re: Ignition Switch Bob: I just purchased an ACS Ignition Switch (A-510-2) [ Off-Right-Left-Both-Start] and was looking at their wiring instructions. I then downloaded your Z-26 diagram for Ignition Switch Options - Magento. Both wiring diagrams are basically identical with a few differences: Both diagrams jumper GRD &R for impulse coupling to Right Mag - shielded wire Both depict L to Left Mag - shielded wire Both depict B to Main Bus (7amp) Both diagram S to Starter Seleniod The differences are: ACS has shielded wire grounded at the right & left mag only, and the GRD terminal grounded at the grounding block or nearest structure. whereas your Z-26 have these wires shielded at both ends with the shield closest to the ignition switch wired to the GRD, but your GRD is NOT grounded to a grounding block or nearest structure.... ACS also says to use all shielded wire....I personally think that is overkill... So, would you recommend grounding at both ends of the shielding wire, but why not ground at the switch, or was this accidently omitted by you? Comments, suggestions appreciated. Yes, there are differences. I hope you will forgive me . . . I'm not trying to be obtuse but I just don't have the time at the moment to explain them. They've been discussed here on the List and you can probably find the exchanges in the matronics archives. It's a noise and ground loops issue. Bob . . . ________________________________________________________________________________
Date: Dec 21, 2008
Thanks Bill: This definitely answers my question.......I can now see the "light" regarding grounding the sheilded wire at both ends per Bob's Z-26......the link to the 2005 VAF Forum was excellent. The one thng I noticed was that they are using 18awg shieded and Bob's Z-26 uses 20 awg shielded....20 is what I have and plan on using unless 18 is better than 20 !! Thanks again Henry ----- Original Message ----- From: Bill Schlatterer To: aeroelectric-list(at)matronics.com Sent: Sunday, December 21, 2008 12:31 PM Subject: RE: Fw: AeroElectric-List: Re: Ignition Switch - VAF Thread This thread pretty much covers it all on the starter switch and ground. Short story is that the GRD terminal on the 504 switch uses the shield on the P-Lead to get to the aircraft ground. Read this, should cover it for you. http://www.vansairforce.com/community/showthread.php?t=36272&highlight= Starter+Switch Hope this helps. Bill S 7a finishing ------------------------------------------------------------------------- ----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Saturday, December 20, 2008 1:00 PM To: aeroelectric-list(at)matronics.com Subject: Re: Fw: AeroElectric-List: Re: Ignition Switch At 11:41 PM 12/19/2008, you wrote: ----- Original Message ----- From: Henry Trzeciakowski To: aeroelectric-list(at)matronics.com Sent: Thursday, December 18, 2008 7:09 PM Subject: AeroElectric-List: Re: Ignition Switch Bob: I just purchased an ACS Ignition Switch (A-510-2) [ Off-Right-Left-Both-Start] and was looking at their wiring instructions. I then downloaded your Z-26 diagram for Ignition Switch Options - Magento. Both wiring diagrams are basically identical with a few differences: Both diagrams jumper GRD &R for impulse coupling to Right Mag - shielded wire Both depict L to Left Mag - shielded wire Both depict B to Main Bus (7amp) Both diagram S to Starter Seleniod The differences are: ACS has shielded wire grounded at the right & left mag only, and the GRD terminal grounded at the grounding block or nearest structure. whereas your Z-26 have these wires shielded at both ends with the shield closest to the ignition switch wired to the GRD, but your GRD is NOT grounded to a grounding block or nearest structure.... ACS also says to use all shielded wire....I personally think that is overkill... So, would you recommend grounding at both ends of the shielding wire, but why not ground at the switch, or was this accidently omitted by you? Comments, suggestions appreciated. Yes, there are differences. I hope you will forgive me . . . I'm not trying to be obtuse but I just don't have the time at the moment to explain them. They've been discussed here on the List and you can probably find the exchanges in the matronics archives. It's a noise and ground loops issue. Bob . . . href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?AeroElectric-List">http://www. matronics.com/Navigator?AeroElectric-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Dec 21, 2008
At 08:08 PM 12/21/2008, you wrote: >Thanks Bill: > >This definitely answers my question.......I can now see the "light" >regarding grounding the sheilded wire at both ends per Bob's >Z-26......the link to the 2005 VAF Forum was excellent. The one >thng I noticed was that they are using 18awg shieded and Bob's Z-26 >uses 20 awg shielded....20 is what I have and plan on using unless >18 is better than 20 !! > >Thanks again Some TC aircraft designs specify 20AWG or larger to any accessories on the engine . . . it's some sort of robustness thing. I suppose 18AWG is more robust still. On canard pushers, there IS a voltage drop issue for the long run from start switch to the tail mounted starter contactor combined with low battery and cold temperatures. 20AWG is fine but if you have some scraps of 18 laying around waiting for useful duty on your airplane it would be fine too. The only wires that benefit from shielding are the p-leads and then only if wired as depicted in the z-figures. There again 20 is adequate but 18 is fine if you have it. Bob . . . ________________________________________________________________________________
Date: Dec 21, 2008
Probably a bit OTT have you looked at fitting a 'missile switch' cover MS25224-1 looks close enough to accomadate .5" of breaker shaft if you drill out the cover for clearance in the protected position. Perhaps a nicer way would be to recess the breaker so when pulled the button is level with the others. Ralph -------- Ralph - CH701 / 2200a Read this topic online here: http://forums.matronics.com/viewtopic.php?p=220474#220474 ________________________________________________________________________________
Date: Dec 21, 2008
Subject: DIY LED fixture data
A number of folks have sent me links to websites that either offer led lighting products or suppliers of individual LEDs that you may find suited to your task. Here's the list I have cmplied to date: http://www.firststarled.com/ http://www.duckworksmagazine.com/06/columns/guest/james.htm http://www.creativair.com/combo-navigation-light-kits-p-88.html http://www.amtonline.com/publication/article.jsp?pubId=1&id=1585 http://jmhledaircraftlights.blogspot.com/ http://www.eaa724.org/TechnicalStuff%20.html http://www.creativair.com/ http://www.killacycle.com/Lights.htm http://gsair.com/ http://www.luxeonstar.com/ http://www.periheliondesign.com/ledlights.htm http://www.vansairforce.com/community/showthread.php?t=24258 http://www.experimentalaircraft.info/articles/aircraft-lights-redbeacon.php http://stores.ebay.com/Light-of-Victory-Led-Store-lvehk http://stores.ebay.com/Emili223-Store http://stores.ebay.com.hk/auspiciouse http://stores.ebay.com/led-hk http://stores.ebay.com/cece718 http://stores.ebay.com.hk/electronicsdiy Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Dec 21, 2008
Subject: AEC 9051 Filtered LED Driver Circuit Question
This is probably a question for Bob . . . . I am in the process of building an LED driver that has 4 of the 3021-D-E-1000 Buck Pucks on the same board. I am attempting to parrot the filter design that Bob used for the AEC 9051 to quiet down the Buck Pucks but I have a couple of questions: 1. This board will use PWM (100 Hz) from a PIC to control the intensity of the LEDs attached to it. The Buck Pucks can be "flashed" at up to 10 kHz by toggling the control pin between 0 and 5V. I have tested this at 100 Hz and they work very well this way "bare". If I add the the filter network a-la the AEC 9051 to the LED+ and LED- lines, will it detrimentally affect the ability to toggle the output of the Buck Puck on and off at 100 Hz? I suspect that it won't but I'd like a second (more informed) opinion. 2. Each of the 4 Buck Pucks will have to have it's own filter network on LED+ and LED-. But I would really like to avoid having to replicate the filters 4 times for the VIN+ and VIN- lines. If I combined these into a single filter, would I need to change the inductance and capacitance values of the components? Inductance and capacitance values aside, it would seem that I would now have to have an inductor rated for at least 4A to feed the 4 Buck Pucks. Does that sound right? The problem there is that a 100uH inductor rated for 4A is physically pretty large and I'm really trying to keep the size of this thing down. Any other suggested solutions? Thanks! Dan Langhout ________________________________________________________________________________
From: "eddieedwards(at)mindspring.com" <eddieedwards(at)mindspring.com>
Subject: BOM for control cabinet for line #4
Date: Dec 22, 2008
Sarah, See attached a BOM for SMC items that Michael Stahl at Chewning and Wilmer requested. This is for a Control Cabinet on Line #4. Please let me know if there are any problems with part numbers or lead times. Thanks and have a great Holiday, Eddie eddieedwards(at)mindspring.com EarthLink Revolves Around You. ________________________________________________________________________________
Date: Dec 22, 2008
Subject: Re: AEC 9051 Filtered LED Driver Circuit Question
At 11:23 PM 12/21/2008, you wrote: > >This is probably a question for Bob . . . . > > I am in the process of building an LED driver that has 4 of > the 3021-D-E-1000 Buck Pucks on the same board. I am attempting to > parrot the filter design that Bob used for the AEC 9051 to quiet > down the Buck Pucks but I have a couple of questions: > >1. This board will use PWM (100 Hz) from a PIC to control the >intensity of the LEDs attached to it. The Buck Pucks can be >"flashed" at up to 10 kHz by toggling the control pin between 0 and >5V. I have tested this at 100 Hz and they work very well this way >"bare". If I add the the filter network a-la the AEC 9051 to the >LED+ and LED- lines, will it detrimentally affect the ability to >toggle the output of the Buck Puck on and off at 100 Hz? I suspect >that it won't but I'd like a second (more informed) opinion. No problem . . . >2. Each of the 4 Buck Pucks will have to have it's own filter >network on LED+ and LED-. But I would really like to avoid having >to replicate the filters 4 times for the VIN+ and VIN- lines. If I >combined these into a single filter, would I need to change the >inductance and capacitance values of the components? Inductance and >capacitance values aside, it would seem that I would now have to >have an inductor rated for at least 4A to feed the 4 Buck Pucks. Yes . . . > Does that sound right? The problem there is that a 100uH > inductor rated for 4A is physically pretty large and I'm really > trying to keep the size of this thing down. Any other suggested solutions? The values were WAGGED . . . I didn't have access to the DO160 lab at the time to refine the components. All we know now is that the components cited reduced observed interference to acceptable if not imperceptible levels. The filter may be overkill, or even less than suggested by DO160. There were no objective measurements made. I have some other test programs coming up that may give me an opportunity to check the AEC9051's real noise numbers. In the mean time, the values cited offer a good starting point for your own experiments. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Dec 22, 2008
Subject: Philosophy of Design - Endurance Bus
Robert L. Nuckolls, III wrote: > ... > I presume you're talking about the alternate feed path > to the e-bus. What is the value in putting a breaker on > the panel for this function as opposed to a switch? Do you > plan to pre-flight check this path? Is there also wire > protection on this path located right at the battery > bus? Bob, There are apparently some elements of the concept that I don't have a good handle on yet. Forgive me if it is already covered in AEC; but that's a big volume and I'm actually jumping a bit ahead in my build, so that I can do some of the ground-work while it's still convenient to do them in an early stage of the fuselage construction. I'm building a glass pusher (COZY) with an "alternative" engine. No mags. To my understanding - so far - the "endurance" bus has only the things on it that I ~must~ have to conclude my flight safely - albeit possibly truncated - in the event that my alternator fails. So, I'm having a problem understanding why one would want to switch access to that bus. To connect to a back-up supply of electrons? I'm planning to connect the bus supporting my bare essentials directly to the battery, then run a switched/fused connection to my "everything else" bus from that. To accomplish that, I'm running a "0" cable from the B+ terminal to my starter solenoid (about 18") and then a pair of #6 welding cables (+ & -) to the front of the airplane, and another #10 wire to the ECU which, at present, is only a few inches from the battery. Am I overlooking something important? Dale R. ________________________________________________________________________________
Subject: RE: Dual Lightspeed Ignition modules
Date: Dec 22, 2008
Ah, good point Bob. I think as long as aircraft and human nature exist, there is no end. One gets the impression that by introducing new technology we somehow lesson our faith in its reliability. I embrace new technology, but I don't want to have to build a triple-redundant system on the chance it may take a bow. The goal of simplicity with reliability should still be enforced. Glenn -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Friday, December 19, 2008 2:41 PM Subject: RE: AeroElectric-List: RE: Dual Lightspeed Ignition modules At 07:01 AM 12/19/2008, you wrote: > > > How do those feared risks occur? > > How do you get a shorted battery bus failure? How does > connection directly to the battery protect against > an overvoltage condition? What matter of "runaway > device" can you imagine that brings the entire system > to its knees? As long as we're in the free-ranging > imagination mode, how about bursting batteries, > open batteries, etc. etc. > >Lets see, a tool across the bus, or direct short from a chafed wire, the >loss of the ground bus on a composite airplane just to name a few. . . . and are these all not manifestations of poor craftsmanship or maintenance? If we're going to add band-aids to any system that go to offsetting sub-standard behavior by someone who has touched the airplane . . . where does it end? >I have a story from a dark and stormy night where the air conditioner >started to break down and started to draw over 150 amps and caused both >Gen's to go off line and pull the volts down to about seven volts. The >CB didn't trip, everything just went almost completely dark before we >got the air conditioner off. Then we were able to restore power. The >problem, if we couldn't shut the Air conditioner off or couldn't figure >out the problem in time (if this airplane had a battery powered ignition >system) the engine would have failed, where simply turning the bus off >would have restored the engine or maybe even had enough voltage at the >battery to keep the engine running. Oh, the airplane referenced was a >certified airplane. . . . and what did you learn from this or any other story that would give you pause for evaluating your own project? Are there things that could or should have been done in the original design processes that would have prevented this incident? Suppose your RV doesn't even HAVE a piece-of-@#$@# air conditioner.What is the value of taking one incident where the designers/fabricators/maintainers/operators stubbed there collective toes and then levying new requirements on ALL airplanes that work-around the SYMPTOMS of that one case? >Bob, I sometime wonder if you fly or are around flying. This isn't a >hypothesis; it's based on real people in real airplanes. The fact is >that electrical systems fail with regularity, some worse then others. >An engine failure on top of that in many cases is a near death >experience. Loosing the engine is not the same as loosing the >transponder. Why do we use vacuum or backup batteries to power >important instrument systems? Don't you think the ignition system >deserves the same respect? My career in aviation began in 1955 when I helped an uncle install an MANUAL direction finder loop in his 170. He could put holes in the airplane but couldn't read a diagram or solder. I was 12 years old. I retired from Hawker-Beechcraft 18 months ago as the subject matter expert leader in electronics/electrical systems. I'm still contracting to that organization and several others who specialize in aviation design and production. I'm an 1000 hour private pilot with about that many additional hours as a test engineer on TC aircraft and 50 times that time as a designer, qualifier and troubleshooter of airborne systems. I'm now 66 years old and still in the business. >It's not! In aviation failures that occur in the field are often not >reported. Airplanes with electrical systems have been around for less >the 100 years and electronic ignitions in aviation much less. We are >all inventing new system designs that are not able to accept total >failure of the total system. Agreed. But just as fuel flow under all anticipated flight conditions was the big stumbling block for many a designer 70 years ago, we have a new challenge that isn't any different. Just as there's no excuse for total failure of fuel flow, there is NO EXCUSE for total failure of an electrical system. Yeah, it has happened which means there's a REASON but there is still no excuse. >Yes, but not everyone has been here for 10 years and most of the >products and concepts haven't been either. Just because it is new doesn't mean that the thought processes and fabrication techniques for airworthiness are any different than what has worked well for decades. Suppose we consider an RV with a piece of @#$@ air conditioner with a failure mode that sucks down the entire system? Of what value is it to tie one or both systems directly to the (+) battery post? Which is better, refine the A/C design or add weight, complexity, cost-of-ownership to offset the possibility that the A/C causes an unhappy day in the cockpit? On a related topic. Lots of folks are trying to figure out ways to integrate lithium-ion batteries into aircraft. It's no mean task. While the energy/weight radio of l-ion is seductive, it's sorta like figuring out a way to burn nitro-glycerine in your engine. Wow! What energy potential! Now, how do you integrate this potential into an existing, highly refined system in a way that does not increase risk? There are people who worry a lot about things they don't understand. There are people who are paid to worry a lot about things they presumably understand and use force of law to modify our behavior such that THEIR worries are mitigated . . . all in the name of 'safety'. http://www.hsegroup.com/hse/text/caffiene.htm http://aeroelectric.com/Pictures/Misc/Cowboy_after_OSHA.jpg My point about your posting was that it tended to reenforce the notion that there was a valid WORRY to be address without adding understanding. An understanding of design for failure-tolerance, craftsmanship, maintenance and operation such that worries go away. There are few suppliers to aviation that have a working knowledge of low-risk, light-weight, failure- tolerant system design. If we attached every worry-wart's product to the battery(+) post . . . it's easy to see where that idea leads! Bob . . . ________________________________________________________________________________
Date: Dec 22, 2008
Subject: Re: Philosophy of Design - Endurance Bus
At 10:56 AM 12/22/2008, you wrote: > >Robert L. Nuckolls, III wrote: >>... >> I presume you're talking about the alternate feed path >> to the e-bus. What is the value in putting a breaker on >> the panel for this function as opposed to a switch? Do you >> plan to pre-flight check this path? Is there also wire >> protection on this path located right at the battery >> bus? > >Bob, > > There are apparently some elements of the concept that I >don't have a good handle on yet. Forgive me if it is already >covered in AEC; but that's a big volume and I'm actually >jumping a bit ahead in my build, so that I can do some of the >ground-work while it's still convenient to do them in an >early stage of the fuselage construction. > > I'm building a glass pusher (COZY) with an "alternative" >engine. No mags. > > To my understanding - so far - the "endurance" bus has only >the things on it that I ~must~ have to conclude my flight >safely - albeit possibly truncated - in the event that my >alternator fails. So, I'm having a problem understanding why >one would want to switch access to that bus. To connect to >a back-up supply of electrons? Not necessarily. The original concept for an E-bus was to support devices useful for en-route flight ops for the purpose of (1) bypassing the battery contactor and eliminating its parasitic (no value added) load and (2) powering up goodies useful for confident continued flight until airport of destination is in sight. > I'm planning to connect the bus supporting my bare >essentials directly to the battery, then run a switched/fused >connection to my "everything else" bus from that. To >accomplish that, I'm running a "0" cable from the B+ >terminal to my starter solenoid (about 18") and then a pair >of #6 welding cables (+ & -) to the front of the airplane, and >another #10 wire to the ECU which, at present, is only a few >inches from the battery. > > Am I overlooking something important? Dunno . . . the z-figures architectures are finely sorted for the purpose of minimizing failure modes, keeping transition from plan-a to plan-b. The grand notion was that loss of an alternator should not automatically turn into an emergency with an immediate landing on foreign tarmac. The premise of the e-bus stood on a 3-legged "stool" that says (a) equipment needed for x-hours of en-route flight can be exceedingly low energy, (b) it's easy to KNOW how long the ship's battery will support this energy requirement and (c) once you're cleared to land, the concrete ahead belongs to you and turning the master switch back ON to support more goodies adds no potential for hazard to the flight even if the battery folds before you get the wheels on the ground. Adding the SD-8 allows one to increase endurance loads up to and perhaps a bit over the ability of the SD-8 to deliver . . . while keeping the battery mostly (if not totally) reserved for descent and approach to landing. If shuffling the busses and re-sorting items feed by those accommodates alternative design goals, by all means. Just be aware not all changes are "golden" and may introduce failure mode effects that demand a new understanding on the part of the pilot. Bob . . . ________________________________________________________________________________
Date: Dec 22, 2008
Subject: Re:LED's
Gentlemen: I am not an electronics man, however I have been using LED's in our AOA systems for 14 years. Use caution and be aware just because the LED's come from the same supplier, they may NOT have the same intensity. They also have different dimming requirements for different colors. We have found that if using the Ultra-Bright LED's they must be individually paired (same colors and different) to insure they all dim the same. Not a big deal, but if you are looking for professional results best to take the extra time and compare them prior to soldering and saying darn I should have All except the Ultra bright by the same mfg. seem pretty good, but a large variance even in same order of 50 LED's ordered at same time. Elbie Mendenhall _www.riteangle.com_ (http://www.riteangle.com) **************One site keeps you connected to all your email: AOL Mail, Gmail, and Yahoo Mail. Try it now. ________________________________________________________________________________
From: "Henry Trzeciakowski" <hammer408(at)comcast.net>
Date: Dec 22, 2008
Thanks Bob: ----- Original Message ----- From: Robert L. Nuckolls, III To: aeroelectric-list(at)matronics.com Sent: Sunday, December 21, 2008 6:48 PM Subject: Re: Fw: AeroElectric-List: Re: Ignition Switch - VAF Thread At 08:08 PM 12/21/2008, you wrote: Thanks Bill: This definitely answers my question.......I can now see the "light" regarding grounding the sheilded wire at both ends per Bob's Z-26......the link to the 2005 VAF Forum was excellent. The one thng I noticed was that they are using 18awg shieded and Bob's Z-26 uses 20 awg shielded....20 is what I have and plan on using unless 18 is better than 20 !! Thanks again Some TC aircraft designs specify 20AWG or larger to any accessories on the engine . . . it's some sort of robustness thing. I suppose 18AWG is more robust still. On canard pushers, there IS a voltage drop issue for the long run from start switch to the tail mounted starter contactor combined with low battery and cold temperatures. 20AWG is fine but if you have some scraps of 18 laying around waiting for useful duty on your airplane it would be fine too. The only wires that benefit from shielding are the p-leads and then only if wired as depicted in the z-figures. There again 20 is adequate but 18 is fine if you have it. Bob . . . ________________________________________________________________________________
Date: Dec 22, 2008
> On a related topic. Lots of folks are trying to figure > out ways to integrate lithium-ion batteries into > aircraft. It's no mean task. While the energy/weight > radio of l-ion is seductive, it's sorta like figuring > out a way to burn nitro-glycerine in your engine. Wow! > What energy potential! Now, how do you integrate > this potential into an existing, highly refined system > in a way that does not increase risk? Oh good lord, li-poly batteries are awesome for *model* aviation. I hope the manufacturers you're alluding to are considering the "A123 Systems" type chemistry batteries (which will take abuse without emiting a napalm like lithium/cobalt fog). ________________________________________________________________________________
Date: Dec 22, 2008
Subject: Re: Li-Ion Batteries for aircraft
At 03:59 PM 12/22/2008, you wrote: > > > > On a related topic. Lots of folks are trying to figure > > out ways to integrate lithium-ion batteries into > > aircraft. It's no mean task. While the energy/weight > > radio of l-ion is seductive, it's sorta like figuring > > out a way to burn nitro-glycerine in your engine. Wow! > > What energy potential! Now, how do you integrate > > this potential into an existing, highly refined system > > in a way that does not increase risk? > >Oh good lord, li-poly batteries are awesome for *model* >aviation. I hope the manufacturers you're alluding to are >considering the "A123 Systems" type chemistry batteries (which >will take abuse without emiting a napalm like lithium/cobalt >fog). Everybody with a product has a dog in this hunt. I'm aware of at least three serious efforts by folks who understand batteries and their role in aviation . . . and perhaps a dozen more wannabes. A friend of mine made this anecdotal observation about batteries in the numerous crashes he investigated: He said that if the airplane didn't burn after impact, more often than not, the battery was pitched out and could be found in the weeds. If the airplane did burn, more often than not, the battery was still in the airplane. While an exceedingly unscientific observation, it plays homage to the high energy density of these devices along with their willingness to dump that energy to the outside world without regard to the fondest desires of those individuals close by. Li-Ion batteries have the potential for being several times worse than their lead-acid or ni-cad cousins when it comes to undesirable energy spills! Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Dec 22, 2008
Subject: Re:LED's
At 02:16 PM 12/22/2008, you wrote: > > >Gentlemen: > I am not an electronics man, however I have been using LED's in > our AOA systems for 14 years. Use caution and be aware just > because the LED's come from the same supplier, they may NOT have > the same intensity. They also have different dimming requirements > for different colors. We have found that if using the Ultra-Bright > LED's they must be individually paired (same colors and different) > to insure they all dim the same. Not a big deal, but if you are > looking for professional results best to take the extra time and > compare them prior to soldering and saying darn I should have All > except the Ultra bright by the same mfg. seem pretty good, but a > large variance even in same order of 50 LED's ordered at same time. >Elbie Mendenhall I've heard this before. A number of folks who supply sunlight viewable dead-front annunciators have mentioned a need for matching sets of leds for output to achieve uniform appearance across the panel. Bob . . . ________________________________________________________________________________
Date: Dec 22, 2008
Here is something from the archives. I think it followed a poll where Bill Dube was asking how many of us would be interested in a really good aircraft battery at a relatively high price: Sep 07, 2007 From: Bill Dube <William.P.Dube(at)noaa.gov> Subject: Re: A123 Systems Nano-phosphate technology and aircraft (was: KillaCycle on Dish Net Tonight) Whomever is designing the electronics doesn't have real experience with A123 Systems cells. They think they are dealing with conventional Li-Ion cells, and they are wrong. A123 Systems nano-phosphate cells are quite different than other Li-Ion cells. They will take a LOT of abuse. About the same amount as an AGM. It is straightforward to make a drop-in replacement for a 12 volt (or 24 volt) lead-acid battery using A123 Systems cells. The existing charging system will work just fine. (It must have the voltage set somewhere between 13.5 and 14.8 volts.) In an airplane, you would want a warning that alerted the pilot that the system was going over 14.8 volts and would make noise if the system was going over 15 volts. It would also be useful to know if the battery temperature was going over 80 Celsius. (You can go up to about 100 C without damage, but no higher or you risk venting the cells and damaging the plastic separator.) >>> Case study <<<< I have had a 3.5 lb A123 Systems battery running in my completely unmodified GMC van for the past 7 months. It snaps the engine over much better than the original 35 lb lead-acid battery. Let's talk about abuse. My wife left my van door unlocked and someone rifled my glove box and left it open with the light on. This killed the battery and it sat at ZERO VOLTS for over a week. I thought, "So much for THAT battery." I then decided to do what the typical consumer would do and I connected up the 3.5 lb completely dead battery to a fully-charged car battery with jumper cables. Hundreds of amps flowed and slightly warmed the cables. I waited a couple of minutes for the 3.5 lb battery voltage to come up, disconnected the jumper cables (the worst thing you could do) and cranked up the van. It started instantly. The alternator then gave the 3.5 lb battery ~100 amps until it came up to 13.4 volts and then tapered off. The BMS showed that all the cells were still in balance! This was five months ago. I haven't capacity-tested the battery, but I can't tell the difference in cranking performance. It was just as if nothing had happened. I even left it parked for 5 weeks while I was out of town and it cranked right up without a problem. If you were to torture a conventional Li-Ion battery like this, it would have burst into flames, or at least it would have just burst. I tell this story to folks with years of experience with conventional Li-Ion cells and they cringe when I get to the part about the jumper cables. :-) The A123 Systems cells will, indeed, "take the abuse". I have a very simplistic charge-balancing electronics (BMS) on my GMC van battery. Nothing fancy is needed. If you overcharge them grossly, they will vent a small amount of flammable vapor (like paint thinner.) If there is an ignition source, this vapor could catch fire. The cells can also burst if overcharged severely. That is the extent of the hazard this technology presents. Bill Dube' -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Michael Pereira Sent: Monday, December 22, 2008 1:59 PM Subject: Re: AeroElectric-List: RE: Dual Lightspeed Ignition modules > On a related topic. Lots of folks are trying to figure > out ways to integrate lithium-ion batteries into > aircraft. It's no mean task. While the energy/weight > radio of l-ion is seductive, it's sorta like figuring > out a way to burn nitro-glycerine in your engine. Wow! > What energy potential! Now, how do you integrate > this potential into an existing, highly refined system > in a way that does not increase risk? Oh good lord, li-poly batteries are awesome for *model* aviation. I hope the manufacturers you're alluding to are considering the "A123 Systems" type chemistry batteries (which will take abuse without emiting a napalm like lithium/cobalt fog). ________________________________________________________________________________
Date: Dec 23, 2008
Robert L. Nuckolls, III wrote: > > A friend of mine made this anecdotal observation about > batteries in the numerous crashes he investigated: He > said that if the airplane didn't burn after impact, more > often than not, the battery was pitched out and could > be found in the weeds. If the airplane did burn, more > often than not, the battery was still in the airplane. We're way off topic right now, but...huh? Are you saying that retaining the battery increases the chances of a fire? The takeaway being that the battery isn't our friend during/after an accident? ________________________________________________________________________________
Date: Dec 23, 2008
Unless someone comes up with a better idea, I think I have a stone simple and light solution for flagging and keeping my E-buss alternate breaker opened. See: http://www.europaowners.org/modules.php?set_albumName=album261&op=modload&name=gallery&file=index&include=view_album.php Picture #26 and #27 7-11 Slurpee straw! Ron Parigoris ________________________________________________________________________________
Subject: Anyone done Bob Nuckoll's CBA modifications?
Date: Dec 23, 2008
Hello all, After seeing a few units burn out unexpectedly (including one of mine), I've been doing an analysis of the West Mountain Radio CBA II. I was wondering if anyone here had done the MOSFET switch (from IRL2910 to IRFP2907) detailed in Bob Nuckoll's 4/10/05 analysis of the CBA II? Thanks! -------- John M. Owner CamLight Systems Read this topic online here: http://forums.matronics.com/viewtopic.php?p=220869#220869 ________________________________________________________________________________
Date: Dec 23, 2008
Subject: Re: Anyone done Bob Nuckoll's CBA modifications?
I have used the West Mountain unit a few times. No worries. I didn't know there was a mod. I bought mine about a year ago and have used it with an 11 ah battery and a few other smaller ones. I am getting ready to try it out with my new Oddessy 625. Maybe in a week, after the holiday. I have loaded the Ver 2 software, but have not tried it out. Sam Hoskins Murphysboro, IL www.samhoskins.blogspot.com On Tue, Dec 23, 2008 at 9:53 PM, CamLight wrote: > > Hello all, > After seeing a few units burn out unexpectedly (including one of mine), > I've been doing an analysis of the West Mountain Radio CBA II. I was > wondering if anyone here had done the MOSFET switch (from IRL2910 to > IRFP2907) detailed in Bob Nuckoll's 4/10/05 analysis of the CBA II? Thanks! > > -------- > John M. > Owner > CamLight Systems > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=220869#220869 > > ________________________________________________________________________________
Date: Dec 24, 2008
At 09:02 AM 12/23/2008, you wrote: > > >Robert L. Nuckolls, III wrote: >> >> A friend of mine made this anecdotal observation about >> batteries in the numerous crashes he investigated: He >> said that if the airplane didn't burn after impact, more >> often than not, the battery was pitched out and could >> be found in the weeds. If the airplane did burn, more >> often than not, the battery was still in the airplane. > >We're way off topic right now, but...huh? How so? The discussion was about the extra-ordinary capabilities of Li-Ion batteries that make their acceptance into aircraft problematic. While their energy/weight ratios and exceedingly low source impedance make them electrically attractive, they're also famous throughout the family of Li-Ion products for spectacular and unpleasant failure modes from within. Even after these batteries are blessed by those who know-more-about-airplanes-than-we-do, there are still considerations for system integration which includes crash safety. >Are you saying that retaining the battery increases the chances of a fire? Doesn't that stand to reason? Fires need ignition sources and aluminum is not hard-sparking material. Hot engines are not even particularly strong ignition sources . . . but a battery capable of thousands of amps of fault current could probably be demonstrated to light off magnesium castings under the right conditions. Lighting off fuel spills is easy. > The takeaway being that the battery isn't our friend during/after > an accident? Would you not share that conclusion with me? Except for the chance that you might sit in the wreck and use the battery to power your radios for the purpose of calling for help, of what practical value is it? Once the airframe is compromised to the extent that the battery is subject to high current discharges, it's easy to assume that fuel tanks are equally compromised. All things considered, if I were on short-final to the rocks, being able to eject the battery is not an unattractive idea. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Dec 24, 2008
Robert L. Nuckolls, III wrote: > The takeaway being that the battery isn't our friend during/after an > accident? > > Would you not share that conclusion with me? Except for > the chance that you might sit in the wreck and use the > battery to power your radios for the purpose of calling > for help, of what practical value is it? Once the airframe > is compromised to the extent that the battery is subject to > high current discharges, it's easy to assume that fuel > tanks are equally compromised. All things considered, if > I were on short-final to the rocks, being able to eject > the battery is not an unattractive idea. > Oh, I agree. It is just not something I've ever heard discussed, or even considered. Now I'm wondering if there are any designs that provide for an battery eject? Considering the logic behind your statement, the the crash investigator you referred to earlier, why aren't there more? ________________________________________________________________________________
Date: Dec 24, 2008
Robert L. Nuckolls, III wrote: > > > At 09:02 AM 12/23/2008, you wrote: >> >> >> Robert L. Nuckolls, III wrote: >>> >>> A friend of mine made this anecdotal observation about >>> batteries in the numerous crashes he investigated: He >>> said that if the airplane didn't burn after impact, more >>> often than not, the battery was pitched out and could >>> be found in the weeds. If the airplane did burn, more >>> often than not, the battery was still in the airplane. >> >> We're way off topic right now, but...huh? > > How so? The discussion was about the extra-ordinary > capabilities of Li-Ion batteries that make their > acceptance into aircraft problematic. While their > energy/weight ratios and exceedingly low source > impedance make them electrically attractive, they're > also famous throughout the family of Li-Ion products > for spectacular and unpleasant failure modes from > within. > > Even after these batteries are blessed by those who > know-more-about-airplanes-than-we-do, there are still > considerations for system integration which includes > crash safety. > >> Are you saying that retaining the battery increases the chances of a >> fire? > > Doesn't that stand to reason? Fires need ignition sources > and aluminum is not hard-sparking material. Hot engines are > not even particularly strong ignition sources . . . but > a battery capable of thousands of amps of fault current > could probably be demonstrated to light off magnesium castings > under the right conditions. Lighting off fuel spills is > easy. > >> The takeaway being that the battery isn't our friend during/after >> an accident? > > Would you not share that conclusion with me? Except for > the chance that you might sit in the wreck and use the > battery to power your radios for the purpose of calling > for help, of what practical value is it? Once the airframe > is compromised to the extent that the battery is subject to > high current discharges, it's easy to assume that fuel > tanks are equally compromised. All things considered, if > I were on short-final to the rocks, being able to eject > the battery is not an unattractive idea. > > > Bob . . . The 1st thing I thought about when reading the 'pitched battery=no fire' story is, wouldn't it be fairly simple to design a G-activated disconnect mounted directly to the battery? Basically the inverse of an ELT activator, to fail off instead of fail on. Something as simple as a spring- or mechanical fuse-loaded pivoting base for the battery that would allow the top to move forward, and bolt-on bullet or blade style connectors for the battery terminals that would face aft. With spring loaded insulators that would close if the connector halves separate, and the wires behind the battery and locked to structure, most any crash impact should try to move the battery forward, 'pulling the plugs' & allowing the insulators to close. This wouldn't be the simplest project for a homebuilder, but should be relatively easy for an R&D department. Also, having been in a car wreck where the battery moved against the frame & was burning through the steel, there might even be an opportunity to make some money if it's marketed to auto regulators (never get it adopted voluntarily, of course). Charlie ________________________________________________________________________________
Date: Dec 24, 2008
At 10:35 PM 12/23/2008, you wrote: >I have used the West Mountain unit a few times. No worries. I >didn't know there was a mod. I bought mine about a year ago and >have used it with an 11 ah battery and a few other smaller ones. I >am getting ready to try it out with my new Oddessy 625. Maybe in a >week, after the holiday. I have loaded the Ver 2 software, but have >not tried it out. > >Sam Hoskins >Murphysboro, IL ><http://www.samhoskins.blogspot.com>www.samhoskins.blogspot.com > > >On Tue, Dec 23, 2008 at 9:53 PM, CamLight ><jmuchow(at)camlight.com> wrote: ><jmuchow(at)camlight.com> > >Hello all, >After seeing a few units burn out unexpectedly (including one of >mine), I've been doing an analysis of the West Mountain Radio CBA >II. I was wondering if anyone here had done the MOSFET switch (from >IRL2910 to IRFP2907) detailed in Bob Nuckoll's 4/10/05 analysis of >the CBA II? Thanks! I own 2 of these devices. The first was damaged when I tried to do a 4a discharge on a 24v battery (well within the rated 100W power handling capability of the CBA II). After a determination that the active power load transistor had shorted, I jury-rigged a pair of FAT transistors onto an external heat sink and secured enough functionality to complete the task at hand. It was not intended to be a modification to upgrade the device. I subsequently purchased a second unit and I've been using both for a several years. I had some discussions with the head-shed at West Mountain Radio about the marginal design as demonstrated by my experience. The fellow seemed to believe I was the only one who was having any sort of problem and offered to repair mine under warranty. I'd chopped and hacked it so didn't feel like I was worthy of a warranty action. I ultimately replace the jury-rigged "fix" with a slightly more robust FET in the TO220 package. Both of my cap-meters have performed as advertised since on 12v or smaller batteries. I'm having trouble recalling how my "mod" got loose in the wild. I don't recall posting it to my website but I may have shared a picture and text with someone who has passed it along. Over the years, I've had several inquiries about my "mod" wherein I was unable to back-track the information trail. Suffice it to say that the CBA-II performs well and as advertised on 12-volt and smaller batteries and may well work on most batteries of higher voltage. It's my opinion that the TO-200 case power FET used as a load resistor is marginally applied to this product. If I were building a similar product, it would be more robust in this regard. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Dec 24, 2008
This is an interesting idea. It should be pretty simple in concept to design an on-impact disconnect for a rear-mounted battery in an RV. Just allow the battery to slide forward a few inches on impact, out of the slotted terminal connectors mounted rigid enough to not follow the battery. RV wings have an optional slotted mount at the leading edge to fuselage connection to allow the wings to shear off. Someone smarter than me could probably come up with a scheme for a firewall mounted (forward of the firewall) battery too. The battery would still be in the airplane, but not connected to any of the wiring. Terry Stalled RV-8A project (too many bright ideas; not enough consistent effort) Seattle -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ernest Christley Sent: Wednesday, December 24, 2008 5:56 AM Subject: Re: AeroElectric-List: Re: Li-Ion Batteries for aircraft Robert L. Nuckolls, III wrote: > The takeaway being that the battery isn't our friend during/after an > accident? > > Would you not share that conclusion with me? Except for > the chance that you might sit in the wreck and use the > battery to power your radios for the purpose of calling > for help, of what practical value is it? Once the airframe > is compromised to the extent that the battery is subject to > high current discharges, it's easy to assume that fuel > tanks are equally compromised. All things considered, if > I were on short-final to the rocks, being able to eject > the battery is not an unattractive idea. > Oh, I agree. It is just not something I've ever heard discussed, or even considered. Now I'm wondering if there are any designs that provide for an battery eject? Considering the logic behind your statement, the the crash investigator you referred to earlier, why aren't there more? ________________________________________________________________________________
From: "Christopher Barber" <CBarber(at)TexasAttorney.net>
Date: Dec 24, 2008
Ok, not a productive comment, however, this discussion has me playing with the thought of hearing: "Captain Picard, the matter/anti-matter containment is failing causing a reaction ark, she is about to blow!" "Geordie, eject the core....NOW!" Yeah, I am more of a NexGen guy then TOS. To show what a geek I can be, the "N" number on my Velocity is N17010. Other Trek geeks will understand that. Merry Christmas all. All the best, Chris Barber Houston ----- Original Message ----- From: "Terry Watson" <terry(at)tcwatson.com> Sent: Wednesday, December 24, 2008 11:58 AM Subject: RE: AeroElectric-List: Re: Li-Ion Batteries for aircraft > > > This is an interesting idea. It should be pretty simple in concept to > design > an on-impact disconnect for a rear-mounted battery in an RV. Just allow > the > battery to slide forward a few inches on impact, out of the slotted > terminal > connectors mounted rigid enough to not follow the battery. RV wings have > an > optional slotted mount at the leading edge to fuselage connection to allow > the wings to shear off. Someone smarter than me could probably come up > with > a scheme for a firewall mounted (forward of the firewall) battery too. The > battery would still be in the airplane, but not connected to any of the > wiring. > > Terry > Stalled RV-8A project (too many bright ideas; not enough consistent > effort) > Seattle > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ernest > Christley > Sent: Wednesday, December 24, 2008 5:56 AM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Re: Li-Ion Batteries for aircraft > > > > Robert L. Nuckolls, III wrote: >> The takeaway being that the battery isn't our friend during/after an >> accident? >> >> Would you not share that conclusion with me? Except for >> the chance that you might sit in the wreck and use the >> battery to power your radios for the purpose of calling >> for help, of what practical value is it? Once the airframe >> is compromised to the extent that the battery is subject to >> high current discharges, it's easy to assume that fuel >> tanks are equally compromised. All things considered, if >> I were on short-final to the rocks, being able to eject >> the battery is not an unattractive idea. >> > Oh, I agree. It is just not something I've ever heard discussed, or > even considered. Now I'm wondering if there are any designs that > provide for an battery eject? Considering the logic behind your > statement, the the crash investigator you referred to earlier, why > aren't there more? > > > ________________________________________________________________________________
Date: Dec 24, 2008
At 07:55 AM 12/24/2008, you wrote: > > >Robert L. Nuckolls, III wrote: >> The takeaway being that the battery isn't our friend >> during/after an accident? >> >> Would you not share that conclusion with me? Except for >> the chance that you might sit in the wreck and use the >> battery to power your radios for the purpose of calling >> for help, of what practical value is it? Once the airframe >> is compromised to the extent that the battery is subject to >> high current discharges, it's easy to assume that fuel >> tanks are equally compromised. All things considered, if >> I were on short-final to the rocks, being able to eject >> the battery is not an unattractive idea. >Oh, I agree. It is just not something I've ever heard discussed, or >even considered. Now I'm wondering if there are any designs that >provide for an battery eject? Considering the logic behind your >statement, the the crash investigator you referred to earlier, why >aren't there more? When I asked the scattered-pieces/smoking-hole crowd at RAC to search their memories and archives for accidents where an electrical failure figured into the chain of events leading up to damage to aircraft/crew. They couldn't come up with one.(*) At the same time, there were electrical issues that caused tense moments and unplanned completions of flight. Bottom line is that a well considered architecture, plan-A/ plan-B operating plan and reasonable training keeps even severe electrical failures from becoming a bad day in the cockpit. Given that OBAM aircraft are MUCH more forgiving than Barons and Jets, electrical failures in flight are even less risky. I don't think there was much interest in reducing the possibility of battery-induced, post-crash fire given that circumstances surrounding the cases where fire did occur were so severe that no useful difference in outcome would have been gained if the airplane had not caught fire. Bob . . . (*) I've personally worked only two accidents in 30+ years that probably started with an electrical failure. One involved a King Air over the Swiss Alps that disappeared from radar and radio contact . . . BEFORE traversing the peaks. The airplane crashed into said peaks COMING THE OTHER WAY. The prevailing theory was that the avionics master relay failed and took down all the good stuff. The pilot decided to return sometime after crossing the peaks and for some reason, descended too early. The other was loss of both alternators in a piston twin flying in ice. Pilot made successful approach to landing looking out the foul weather window. He lost directional control on the runway resulting in loss of airframe and all souls aboard. ________________________________________________________________________________
Date: Dec 24, 2008
nuckolls.bob(at)aeroelect wrote: > > I own 2 of these devices. The first was damaged > when I tried to do a 4a discharge on a 24v battery > (well within the rated 100W power handling capability > of the CBA II). After a determination that the > active power load transistor had shorted, I jury-rigged > a pair of FAT transistors onto an external heat > sink and secured enough functionality to complete the > task at hand. It was not intended to be a modification > to upgrade the device. I subsequently purchased a > second unit and I've been using both for a several > years. > > I had some discussions with the head-shed at > West Mountain Radio about the marginal design > as demonstrated by my experience. The fellow seemed > to believe I was the only one who was having any > sort of problem and offered to repair mine under > warranty. I'd chopped and hacked it so didn't feel > like I was worthy of a warranty action. I ultimately > replace the jury-rigged "fix" with a slightly > more robust FET in the TO220 package. Both of my > cap-meters have performed as advertised since > on 12v or smaller batteries. That's good news! I've heard of about 8 units that have blown their FETs and couple that also took out the driving op-amp and some resistor/capacitors too. I ended up using an Infineon IPP048N06L MOSFET for its great continuous rating for use as a load (DC plot line in the SOA graph). Seems that it's both the higher wattages and higher voltage batteries that can cause problems. Makes sense though. The first is due to temperature and the second due to hotspotting and thermal runaway. nuckolls.bob(at)aeroelect wrote: > > I'm having trouble recalling how my "mod" got > loose in the wild. I don't recall posting it to > my website but I may have shared a picture and > text with someone who has passed it along. Over > the years, I've had several inquiries about my > "mod" wherein I was unable to back-track the > information trail. Well, I can give you the trail I followed. :-) A friend had told me about seeing an analysis of the CBA but forgot where. A Goodle search led to an archive of a thread here on, IIRC, April 10, 2005. In that thread you provided a link to your analysis in the Articles section of your site. But the document was no longer there. This link though gave me the file name and my search led to an individual who had the document available from their site. I don't remember who. nuckolls.bob(at)aeroelect wrote: > > Suffice it to say that the CBA-II performs well > and as advertised on 12-volt and smaller batteries > and may well work on most batteries of higher voltage. > It's my opinion that the TO-200 case power FET used > as a load resistor is marginally applied to this > product. If I were building a similar product, > it would be more robust in this regard. > > Bob . . . > I completely agree. My analysis of two CBA's was pretty extensive (43 page document) and led me to conclude that it shouldn't be used at over 65W for long-term reliability and 86W to prevent the MOSFET from exceeding its max rated operating temperature. I also found out that the CBA's stock MOSFET isn't even rated for use as a load and was susceptible to hotspotting and thermal runaway (resulting in the MOSFET burning out) at well below the CBA's 100W rating when discharging at higher voltages. A MOSFET change, over to the IPP048N06L, and a fan change were the mods I made to bring the CBA's continuous power rating up to 106W at up to 48V without worrying about exceeding any of the MOSFET's specs. The extra fan also helped to keep the fuse and fuseholders from dropping out of the circuit board too when discharging at 30A or so. It happened more than once to me (and others) before we finally found ways to cool the circuit board and fuse. Very frustrating. :) -------- John M. Owner CamLight Systems Read this topic online here: http://forums.matronics.com/viewtopic.php?p=221015#221015 ________________________________________________________________________________
Date: Dec 25, 2008
I would consider a dual wire high current plug similar to one used on my snowplow main power lead. The plug supplies current to a motor similar to an engine starting motor which drives hydraulics to operate the plow. The plug is very robust and under very harsh operating conditions has never unplugged itself during plowing operations. The plug hangs freely between the front bumper of my truck and the plow. However, with a good tug the plug separates to disconnect the wires to remove the plow unit from my truck. This could be installed in the battery connection wires of the airplane and supported so as to disconnect in the event of excessive forward g forces. The contact pins are also recessed in plastic so after disconnect, there would be no chance of contact with other metal if the battery terminals were also covered. See 4b and 4c in the link below. http://www.rustrepair.com/snow_plow_parts/onlinecat.htm?r=ds&p=sn-boss-bs.elec Dave Leikam RV-10 #40496 N89DA (Reserved) Muskego, WI ----- Original Message ----- From: "Terry Watson" <terry(at)tcwatson.com> Sent: Wednesday, December 24, 2008 11:58 AM Subject: RE: AeroElectric-List: Re: Li-Ion Batteries for aircraft > > > This is an interesting idea. It should be pretty simple in concept to > design > an on-impact disconnect for a rear-mounted battery in an RV. Just allow > the > battery to slide forward a few inches on impact, out of the slotted > terminal > connectors mounted rigid enough to not follow the battery. RV wings have > an > optional slotted mount at the leading edge to fuselage connection to allow > the wings to shear off. Someone smarter than me could probably come up > with > a scheme for a firewall mounted (forward of the firewall) battery too. The > battery would still be in the airplane, but not connected to any of the > wiring. > > Terry > Stalled RV-8A project (too many bright ideas; not enough consistent > effort) > Seattle > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ernest > Christley > Sent: Wednesday, December 24, 2008 5:56 AM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Re: Li-Ion Batteries for aircraft > > > > Robert L. Nuckolls, III wrote: >> The takeaway being that the battery isn't our friend during/after an >> accident? >> >> Would you not share that conclusion with me? Except for >> the chance that you might sit in the wreck and use the >> battery to power your radios for the purpose of calling >> for help, of what practical value is it? Once the airframe >> is compromised to the extent that the battery is subject to >> high current discharges, it's easy to assume that fuel >> tanks are equally compromised. All things considered, if >> I were on short-final to the rocks, being able to eject >> the battery is not an unattractive idea. >> > Oh, I agree. It is just not something I've ever heard discussed, or > even considered. Now I'm wondering if there are any designs that > provide for an battery eject? Considering the logic behind your > statement, the the crash investigator you referred to earlier, why > aren't there more? > > > ________________________________________________________________________________
Date: Dec 25, 2008
Subject: Is this scheme valid to save weight, add flexibility
and reduce noise from fat wires?
Merry Christmas and happy holidays to all. Have a mini break. I have an aft battery on my Europa XS with Rotax 914. Wires run parallel with radio antennas for ~ 5 or so feet. I have main battery switch in passenger headrest. Initial plan was to use #4 Tefzel wire with short pieces of #6 welding cable at battery attachment (for flexability) and at battery switch attachment (to more easily negotiate routing). I was going to turn butt connectors out of 101 copper with precise holes for #4 and #6 wires with a cross drilled hole slight outboard of each wire to allow me to add solder. Just a note that #6 welding cable has a slight larger OD compared to #4 Tefzel. I don't have space for the diameter of #4 copper plated aluminium wire. I was happy with above plan >>>>>>>>> until got to thinking >>>>>>>>>> Might be better off using two paralleled #8 Tefzel wires instead of one #4???? Could twist 2 sets of #8 together (each twist pos + neg) which could help out with potential noise on my paralleled run with RG400 antennas. #8 would be flexable enough to negate need for welding cable. Two paralleled wires in one respect add redundancy of connection. Two paralleled #8 wires are lighter than one #4. Cons: Need more terminations, but even with more terminations still lighter than #4 / #6 combo. Twisting pos + neg perhaps could somehow create more of a hazard of them shorting together compared to pos and neg #4 sitting side by side. There is a slight amount more resistance of two #8s compared to one #4. I don't think this will be too much of a problem with lower compression and slight less displacement of Rotax 914 compared to Rotax 912S. I also have heavy duty starter that in fact draws less amps compared to old style starter?? OK Is this scheme valid to save weight, add flexibility and reduce noise from fat wires? Anyone know of a source to obtain #8 wire with silver plating (would help out slightly with lower resistance)? Ron P. ________________________________________________________________________________
Date: Dec 25, 2008
[/quote] The 1st thing I thought about when reading the 'pitched battery=no fire' story is, wouldn't it be fairly simple to design a G-activated disconnect mounted directly to the battery? Charlie[/quote] Delphi has already done this... it's a pyrotechnically activated battery cutoff switch. See http://delphi.com/manufacturers/auto/ee/eec/bdsd/ In the cars they're installed in, the airbag module triggers it. However, since we don't typically have airbag triggers on board, we could use the standard Ford fuel pump cutoff switch that Ford's been using since the mid-80's (it's a g-activated switch). Heinrich Gerhardt RV-6, flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=221100#221100 ________________________________________________________________________________
Date: Dec 25, 2008
Subject: Re: Is this scheme valid to save weight, add
flexibility and reduce noise from fat wires? At 07:56 AM 12/25/2008, you wrote: > >Merry Christmas and happy holidays to all. > >Have a mini break. > >I have an aft battery on my Europa XS with Rotax 914. Wires run parallel >with radio antennas for ~ 5 or so feet. I have main battery switch in >passenger headrest. > >Initial plan was to use #4 Tefzel wire with short pieces of #6 welding >cable at battery attachment (for flexability) and at battery switch >attachment (to more easily negotiate routing). I was going to turn butt >connectors out of 101 copper with precise holes for #4 and #6 wires with a >cross drilled hole slight outboard of each wire to allow me to add solder. >Just a note that #6 welding cable has a slight larger OD compared to #4 >Tefzel. I don't have space for the diameter of #4 copper plated aluminium >wire. That would work but is pretty labor intensive. Lapped, soldered and heat-shrink would work too and is quick. >I was happy with above plan >>>>>>>>> until got to thinking >>>>>>>>>> > >Might be better off using two paralleled #8 Tefzel wires instead of one >#4???? > >Could twist 2 sets of #8 together (each twist pos + neg) which could help >out with potential noise on my paralleled run with RG400 antennas. > >#8 would be flexable enough to negate need for welding cable. "better off", "flexible enough", "potential noise" are all non-quantified . . . and don't offer a lucid image of your design goals. >Two paralleled wires in one respect add redundancy of connection. > >Two paralleled #8 wires are lighter than one #4. But smaller in cross-section than one #4. >Cons: > >Need more terminations, but even with more terminations still lighter than >#4 / #6 combo. > >Twisting pos + neg perhaps could somehow create more of a hazard of them >shorting together compared to pos and neg #4 sitting side by side. > >There is a slight amount more resistance of two #8s compared to one #4. I >don't think this will be too much of a problem with lower compression and >slight less displacement of Rotax 914 compared to Rotax 912S. I also have >heavy duty starter that in fact draws less amps compared to old style >starter?? Exactly how much weight are you "saving" and how much $time$ are you investing in the goal. You've added joints to the system that wouldn't have to be there with a contiguous run of 4awg welding cable. Have you calculated the delta-weight for the proposed architectures? >OK >Is this scheme valid to save weight, add flexibility and reduce noise from >fat wires? Don't worry about noise from these wires into antenna systems or feedlines. Twising is not necessary either. Just run them tightly parallel with string ties every 6" or so. >Anyone know of a source to obtain #8 wire with silver plating (would help >out slightly with lower resistance)? Silver plated wire comes on Teflon insulated conductors. More expensive, less robust and so small an improvement as to not be noticed. I'd still like to see how much weight you expect to save with any alternatives to single strands of 4AWG. How long are these runs of wire? Bob . . . ________________________________________________________________________________
Subject: AGM Battery Charger
Date: Dec 25, 2008
Is a special charger needed for AGM batteries such as the Odyssey? At www.odyessy.com <http://www.odyessy.com/> they recommend two types, but I'm wondering why something like a Schumacher http://store.schumachermart.com/se-1010-2.html won't work just as well. ________________________________________________________________________________
Subject: Re: AGM Battery Charger
Date: Dec 25, 2008
odysseybatteries.com ----- Original Message ----- From: Mike Creek To: aeroelectric-list(at)matronics.com Sent: Thursday, December 25, 2008 3:16 PM Subject: AeroElectric-List: AGM Battery Charger Is a special charger needed for AGM batteries such as the Odyssey? At www.odyessy.com they recommend two types, but I'm wondering why something like a Schumacher http://store.schumachermart.com/se-1010-2.html won't work just as well. ________________________________________________________________________________
Date: Dec 25, 2008
Ron: If you need the capacity of #4 wire for the starter, 2 #8 wires have much less capacity than 1 #4. Two #7 wires are very close to the same capacity, but I'm not sure of #7AWG availability. I would recommend staying with the first plan, using #4 cable. Radio interference would be from the alternator charging, but it's at a much lower ampere rating and would produce much less EMI than when starting the engine. Also, invest in the highest quality cable for the antenna. If interference even exists after that, then use filters to clean that up. Phil On Dec 25, 2008, at 5:56 AM, rparigor(at)SUFFOLK.LIB.NY.US wrote: > > Merry Christmas and happy holidays to all. > > Have a mini break. > > I have an aft battery on my Europa XS with Rotax 914. Wires run > parallel > with radio antennas for ~ 5 or so feet. I have main battery switch in > passenger headrest. > > Initial plan was to use #4 Tefzel wire with short pieces of #6 welding > cable at battery attachment (for flexability) and at battery switch > attachment (to more easily negotiate routing). I was going to turn > butt > connectors out of 101 copper with precise holes for #4 and #6 wires > with a > cross drilled hole slight outboard of each wire to allow me to add > solder. > Just a note that #6 welding cable has a slight larger OD compared > to #4 > Tefzel. I don't have space for the diameter of #4 copper plated > aluminium > wire. > > I was happy with above plan >>>>>>>>> until got to thinking >>>>>>>>>> > > Might be better off using two paralleled #8 Tefzel wires instead of > one > #4???? > > Could twist 2 sets of #8 together (each twist pos + neg) which > could help > out with potential noise on my paralleled run with RG400 antennas. > > #8 would be flexable enough to negate need for welding cable. > > Two paralleled wires in one respect add redundancy of connection. > > Two paralleled #8 wires are lighter than one #4. > > > Cons: > > Need more terminations, but even with more terminations still > lighter than > #4 / #6 combo. > > Twisting pos + neg perhaps could somehow create more of a hazard of > them > shorting together compared to pos and neg #4 sitting side by side. > > There is a slight amount more resistance of two #8s compared to one > #4. I > don't think this will be too much of a problem with lower > compression and > slight less displacement of Rotax 914 compared to Rotax 912S. I > also have > heavy duty starter that in fact draws less amps compared to old style > starter?? > > OK > Is this scheme valid to save weight, add flexibility and reduce > noise from > fat wires? > > Anyone know of a source to obtain #8 wire with silver plating > (would help > out slightly with lower resistance)? > > Ron P. > > ________________________________________________________________________________
Date: Dec 26, 2008
Hi Bob Thx. for the reply My mission is to electrically connect my aft battery to the upfront 914 supplying it sufficient amperage and voltage, while being able to fit wires neatly under door sill/fuse seam and allow routing required to connect to battery switch (tight bends). Old style starter amp draw is stated at I think 60 amps, I have new style that is a bit less. If I can save some weight in the process that is a bonus. Just a quick calculation of one #4 compared to two #8s for 5 meters of wire would be a savings of a little over a half pound with two #8s. The larger the diameter of wires, the harder it will be to route under door sill and allow for door centering pin receptacle to help keep door from bulging. #4 Tefzel wire is .310" in diameter #6 EPDM jacket 259 strand is .332" diameter (#4 406 strand .380") #6 Chlorinated Polyethylene 660 strand is .370" diameter (#4 1045 strand .420") It's true I could lap solder #6 welding wire to #4 Tefzel, but my interior cover/conduit for wires would need to be larger to accommodate, and the laps would be in an already tight area. Butt soldering #4 Tefzel to #6 welding would approx. be the same diameter. I am not sure of the weight of welding cable compared to Tefzel, but I would think it heavier. I have a Hobart TRT 250 TIG welder. The ground wire I suspect is EPDM jacketed. It has cracks and splits and in general the jacketing is in bad health. True it sees a lot of UV and for a TIG ground strap that is fine. Are you be happy with using EPDM jacketed welding cable for the full run to and from engine to aft battery knowing if it smokes, a dozen feet is in the cockpit (aeroplane is fiberglass)? How about only 1 foot? Same question with Chlorinated Polyethylene jacketed welding cable: Are you be happy with using Chlorinated Polyethylene jacketed welding cable for the full run to and from engine to aft battery knowing if it smokes, a dozen feet is in the cockpit (aeroplane is fiberglass)? How about only 1 foot? Knowing I need flexibility for routing at battery switch, want the smallest diameter that is feasible, be able to provide reasonable voltage and cranking amps, not take unreasonable risks of breathing noxious fumes if wires smoke, not have much risk that aging wire insulation will crack and split and be the instigator of smoke and loss of electron flow and be of a reasonable weight. What would be your two favorite choices: ****#4 Tefzel with #6 EPDM jacketed butt soldered battery and battery switch ends? ****#4 Tefzel with #6 Chlorinated Polyethylene jacketed butt soldered battery and battery switch ends? ****All #4 EPDM jacketed wire? ****All #4 Chlorinated Polyethylene jacketed wire? ****Two paralleled #8 Tefzel wire that doesn't need twisting? Thx. Ron Parigoris ________________________________________________________________________________
Subject: Z-14 extrapolation
Date: Dec 26, 2008
Pardon my sophmoric ignorance on this question (sophmore = wise fool) but I have installed my Z-14 system in my Velocity with a Mazda Rotary. I am using two standard/stock alternators for this engine rated at 80 amps each. The Z drawing uses two 40 amp alternators and mostly 20 awg wire. Do I need to increase the wire size to perhaps 10 awg for my larger alternators? This is becoming an issue as after finally seeming to get my system to "work" mostly properly after having my EE friend come out and figure out some basic switch functioning that I missed I am having my two Bat circuit breakers trip whenever the engine is running and the crossover toggle is in the NON crossover mode. My friend, Blain (who formed and owns the company who supplies air conditioner units for smaller airplanes such as Cirus, Moody, Columbia/Cessna and now developing for the EXP market, namely Velocity) is very versed in electrics but was unable to stick around once this issue came up. He had already spent the day helping me get things right and had a family to tend to for the holidays. He did suggest that I may need to change the 5 amp CB to 7.5 but cautioned to find out more before going too much further by simply adding higer CB's ect. Back to my problem. As mentioned, when in the "crossover mode", ie both alternators acting together the CB's do NOT trip. However, when I put the toggle in the center position (from down) having the systems act indipendently, both trip. It happens only when the engine is running thus the alternator, well, alternating...so to speak. I did change to the 7.5 amp CB's but when I tested it tonight, they both tripped as well. My thought is since I used the 20 awg wire as in the Z drawing, but am using higher output alternators that my system is not up to the task and that I may need to beef things up with larger wire. Again, pardon my ingonrance...even though the fog lifts a bit every day. So, thoughts, concerns, insight???? All is appreciated. Thank you. All the best, Chris Barber Houston www.LoneStarVelocity.com ________________________________________________________________________________
Date: Dec 26, 2008
Subject: Re: Is this scheme valid to save weight, add flexibility
From: "Brian R. Wood" <brianrobertwood(at)gmail.com>
Speaking of smokng wires, one time when I was working on a certificated airplane, I inadvertantly shorted a #22 compass light wire. Almost immediately the cabin was filled with black acrid smoke. I was almost overcome. I ran out to the hangar door to get some fresh air. I still marvel at how much nasty material just 6 inches of tiny wire can create. I think the safest course is to avoid any smoking wires, either one foot or twelve feet, I think either one would probably kill you. Brian > Same question with Chlorinated Polyethylene jacketed welding cable: > Are you be happy with using Chlorinated Polyethylene jacketed welding > cable for the full run to and from engine to aft battery knowing if it > smokes, a dozen feet is in the cockpit (aeroplane is fiberglass)? How > about only 1 foot? > -- Brian R. Wood JH Manutencao Anapolis. Goias, Brazil ________________________________________________________________________________
Date: Dec 26, 2008
Subject: Re: Z-14 extrapolation
At 03:45 AM 12/26/2008, you wrote: > > >Pardon my sophmoric ignorance on this question (sophmore = wise >fool) but I have installed my Z-14 system in my Velocity with a >Mazda Rotary. I am using two standard/stock alternators for this >engine rated at 80 amps each. The Z drawing uses two 40 amp >alternators and mostly 20 awg wire. Do I need to increase the wire >size to perhaps 10 awg for my larger alternators? This is becoming >an issue as after finally seeming to get my system to "work" mostly >properly after having my EE friend come out and figure out some >basic switch functioning that I missed I am having my two Bat >circuit breakers trip whenever the engine is running and the >crossover toggle is in the NON crossover mode. The Z-figures are to illustrate architectures and are not intended to drive alternator size, wire sizes, fuse/breaker sizes. Nor are they intended to drive the selection of what devices are fed from which bus. >My friend, Blain (who formed and owns the company who supplies air >conditioner units for smaller airplanes such as Cirus, Moody, >Columbia/Cessna and now developing for the EXP market, namely >Velocity) is very versed in electrics but was unable to stick around >once this issue came up. He had already spent the day helping me >get things right and had a family to tend to for the holidays. He >did suggest that I may need to change the 5 amp CB to 7.5 but >cautioned to find out more before going too much further by simply >adding higer CB's ect. The very FIRST thing you do in crafting an electrical system is make a list of every device that needs DC power to function and you decide what that device's position is in the hierarchy of necessity. If it's functionality is highly desirable for comfortable completion of flight, then you have TWO of those devices fed from separate power sources. Design goals for achieving comfortable termination of flight after some component failure are outlined in Chapter 17 of the 'Connection. Next you select an architecture that mitigates the effect on outcome of flight for having lost one of the devices. Unless you plan on boring long holes in the most marginal kinds of weather AND you're planning on full-up capability of flight in IMC on both sides of the panel, it's not clear that the features offered by Z-14 is really all that useful to you. However, if you're already a long way down that path, so be it. Have you conducted a load analysis on your proposed system and filled out forms like: http://www.aeroelectric.com/PPS/Load_Analysis/Blank_Form.pdf Fill out one sheet for each bus in your proposed design with the goal of deducing what your electrical system load are for each flight condition AND insuring separate power sources for systems that back each other up. Or you can take advantage of the load analysis exercises conducted by a number of List members and offered in Excel spread sheets. You can download those for study or modification to your needs in this director from my website: http://www.aeroelectric.com/PPS/Load_Analysis After ALL the electrico-whizzies in your airplane have been identified, quantified and assigned functionality, then you pick fuse/breakers and wire sizes to accomModate the needs of each system. >Back to my problem. As mentioned, when in the "crossover mode", ie >both alternators acting together the CB's do NOT trip. However, >when I put the toggle in the center position (from down) having the >systems act indipendently, both trip. It happens only when the >engine is running thus the alternator, well, alternating...so to >speak. I did change to the 7.5 amp CB's but when I tested it >tonight, they both tripped as well. My thought is since I used the >20 awg wire as in the Z drawing, but am using higher output >alternators that my system is not up to the task and that I may need >to beef things up with larger wire. Again, pardon my >ingonrance...even though the fog lifts a bit every day. > >So, thoughts, concerns, insight???? All is appreciated. There are no positions of switches in Z-14 or any other Z-figure that would cause a breaker to trip. The cross-feed contactor is there to (1) PERMIT running both sides from one alternator should one alternator become inoperable and (2) using both batteries to crank the engine. But if the crossfeed is closed during normal operations, no untoward behaviors should be expected. One alternator (with the higher voltage setting) will hog the load but no breakers will pop. I'm not sure of the 20AWG wire reference. Wires this small are used in power distribution and control downstream of the appropriately sized fuse or breaker. The wire is selected to meet requirements for carrying current in that particular task and the PROTECTED by the appropriate size fuse or breaker. If you've strung a lot of 20AWG wire into your airplane without having evaluated each of those wires with respect to their current carrying function, then you've not conducted the load analysis exercise suggested above. Bob . . . ________________________________________________________________________________
Date: Dec 26, 2008
add flexibility and reduce noise from fat wires? At 11:16 PM 12/25/2008, you wrote: > >Hi Bob Thx. for the reply > >My mission is to electrically connect my aft battery to the upfront 914 >supplying it sufficient amperage and voltage, while being able to fit >wires neatly under door sill/fuse seam and allow routing required to >connect to battery switch (tight bends). > >Old style starter amp draw is stated at I think 60 amps, I have new style >that is a bit less. > >If I can save some weight in the process that is a bonus. > >Just a quick calculation of one #4 compared to two #8s for 5 meters of >wire would be a savings of a little over a half pound with two #8s. > >The larger the diameter of wires, the harder it will be to route under >door sill and allow for door centering pin receptacle to help keep door >from bulging. > >#4 Tefzel wire is .310" in diameter > >#6 EPDM jacket 259 strand is .332" diameter (#4 406 strand .380") > >#6 Chlorinated Polyethylene 660 strand is .370" diameter (#4 1045 strand >.420") > >It's true I could lap solder #6 welding wire to #4 Tefzel, but my interior >cover/conduit for wires would need to be larger to accommodate, and the >laps would be in an already tight area. Butt soldering #4 Tefzel to #6 >welding would approx. be the same diameter. > >I am not sure of the weight of welding cable compared to Tefzel, but I >would think it heavier. > >I have a Hobart TRT 250 TIG welder. The ground wire I suspect is EPDM >jacketed. It has cracks and splits and in general the jacketing is in bad >health. True it sees a lot of UV and for a TIG ground strap that is fine. > >Are you be happy with using EPDM jacketed welding cable for the full run >to and from engine to aft battery knowing if it smokes, a dozen feet is in >the cockpit (aeroplane is fiberglass)? How about only 1 foot? > >Same question with Chlorinated Polyethylene jacketed welding cable: >Are you be happy with using Chlorinated Polyethylene jacketed welding >cable for the full run to and from engine to aft battery knowing if it >smokes, a dozen feet is in the cockpit (aeroplane is fiberglass)? How >about only 1 foot? > >Knowing I need flexibility for routing at battery switch, want the >smallest diameter that is feasible, be able to provide reasonable voltage >and cranking amps, not take unreasonable risks of breathing noxious fumes >if wires smoke, not have much risk that aging wire insulation will crack >and split and be the instigator of smoke and loss of electron flow and be >of a reasonable weight. > >What would be your two favorite choices: > >****#4 Tefzel with #6 EPDM jacketed butt soldered battery and battery >switch ends? > >****#4 Tefzel with #6 Chlorinated Polyethylene jacketed butt soldered >battery and battery switch ends? > >****All #4 EPDM jacketed wire? > >****All #4 Chlorinated Polyethylene jacketed wire? > >****Two paralleled #8 Tefzel wire that doesn't need twisting? To use terms like "reasonable weight" and "this wire is heavier than that wire" without quantifying the overall weight savings. I think I'd run 4AWG welding cable throughout. The delta-weights are trivial and the effort to run multiple twisted, spliced, variable gage wires has a poor return on investment and looks pretty chopped and hacked when you're done. I've never understood the thought process that suggests smoke from one kind of insulation is preferable to smoke form another kind of insulation. When you get the first whiff of ANY smoke, all switches are OFF ASAP. I can't speak to your experience with cracked insulation on welding cable. The stuff I've been buying around here for years looks like this: http://aeroelectric.com/Pictures/Wire/4AWG_Welding_Cable_1.jpg I'm not sure of the chemical makeup of the two layers but it's a sure bet they're selected for robustness as insulation on wires that lay on gravel roads and get run over by dump-trucks. The fat wires in your airplane are not subject to great abuse by liquids, mashing, pulling, etc. They're easily observed during annual inspection for degraded performance such as cracks. The risks for using this stuff is exceedingly low, the benefit for low cost, flexibility, and ease of installation is significant. The idea that you're going to save a few ounces at most on total installed weight may be intellectually pleasing but probably won't produce practical benefits later. Bob . . . ________________________________________________________________________________
Date: Dec 26, 2008
At 04:16 PM 12/25/2008, you wrote: >Is a special charger needed for AGM batteries such as the Odyssey? >At <http://www.odyessy.com/>www.odyessy.com they recommend two >types, but I'm wondering why something like a Schumacher ><http://store.schumachermart.com/se-1010-2.html>http://store.schumachermart.com/se-1010-2.html >won't work just as well. ALL battery technologies benefit from the use of "smart" battery chargers that offer charge, top-off and maintenance cycles. The charger you cited doesn't cite this feature. A really nice, low cost Schumacher product sold at Wallmart is the 1562 series critters cited in http://www.aeroelectric.com/articles/Batteries/Multiple_Battery_Myths_A.pdf and illustrated here: http://aeroelectric.com/Pictures/Battery_Chargers/Schumacher_Chargers/1562.jpg Schumacher makes a range of smart chargers identifiable by the word "maintainer" in their descriptions. These include the SC600, SC1000, SC1200, etc. The idea that one should finely tune a plug-in-the-wall battery charger to the brand/technology of the battery is not supported by the way we charge batteries in our vehicles and expect years of service life. Consider also a variety of small battery charger/maintainers like: http://aeroelectric.com/Pictures/Battery_Chargers/Battery_Minder/ http://aeroelectric.com/Pictures/Battery_Chargers/Battery_Tender_Jr/Battery_Tender-Junior.jpeg Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Dec 26, 2008
Date: Dec 26, 2008
>Well, I can give you the trail I followed. :-) >A friend had told me about seeing an analysis of the CBA but forgot >where. A Goodle search led to an archive of a thread here on, IIRC, >April 10, 2005. In that thread you provided a link to your analysis >in the Articles section of your site. But the document was no longer >there. This link though gave me the file name and my search led to >an individual who had the document available from their site. I >don't remember who. Okay, I found it. I don't know why it was taken off the website. It's still on the CDRom image of the website as it existed some months ago. I've put the article back up at: http://www.aeroelectric.com/articles/WestMountain_CBAII.pdf >I completely agree. My analysis of two CBA's was pretty extensive >(43 page document) and led me to conclude that it shouldn't be used >at over 65W for long-term reliability and 86W to prevent the MOSFET >from exceeding its max rated operating temperature. I also found out >that the CBA's stock MOSFET isn't even rated for use as a load and >was susceptible to hotspotting and thermal runaway (resulting in the >MOSFET burning out) at well below the CBA's 100W rating when >discharging at higher voltages. > >A MOSFET change, over to the IPP048N06L, and a fan change were the >mods I made to bring the CBA's continuous power rating up to 106W at >up to 48V without worrying about exceeding any of the MOSFET's >specs. The extra fan also helped to keep the fuse and fuseholders >from dropping out of the circuit board too when discharging at 30A >or so. It happened more than once to me (and others) before we >finally found ways to cool the circuit board and fuse. Very frustrating. :) I had some extensive conversation with WMR. First with regard to the FET failure and a second attempt to discover the communication protocols on the USB connection that controls the CBA-II and then gets reported data back. I offered to craft an engineer's version of battery test software that would provide watt-seconds instead of amp-hours displays, conduct battery impedance tests, etc. I even told him I would share the software for him to use as I saw fit. He said similar plans were already in work in his facilities and he declined to share any information. The new software was 3 years in the making and still falls short of what I would like to do with his product. Further, the software reads the serial number of the specific CBA II and you have to purchase separate registered copies of the software to use each CBA II. I have three computers and two CBA II that I would like to use in interchangeable combinations but I'm not going to buy a second software package when it still doesn't do the things I would like to do and offered to him for free. Bob . . . ________________________________________________________________________________
Date: Dec 26, 2008
and reduce noise from fat wires? Same question with Chlorinated Polyethylene jacketed welding cable: Are you be happy with using Chlorinated Polyethylene jacketed welding cable for the full run to and from engine to aft battery knowing if it smokes, a dozen feet is in the cockpit (aeroplane is fiberglass)? How about only 1 foot? >Speaking of smokng wires, one time when I was working on a certificated >airplane, I inadvertantly shorted a #22 compass light wire. Almost >immediately the cabin was filled with black acrid smoke. I was almost >overcome. I ran out to the hangar door to get some fresh air. I still >marvel at how much nasty material just 6 inches of tiny wire can create. > >I think the safest course is to avoid any smoking wires, either one foot >or twelve feet, I think either one would probably kill you. Without a doubt, the smoking of wires with insulation of any pedigree produces a most disagreeable atmosphere. But at the same time, let's made a distinction between small wires that are ROUTINELY protected and fat wires that are not. Small wires are very likely to smoke when driven by high current sources. FAT wires are generally few in number, installed with special care and more likely to burn away the faulting intrusion than to burn and become an emitter of smoke. Small wire protection is generally takes the form of breakers or fuses (I prefer fuses cause they're light, cheap, fast and take up minimum panel space on airplane). Had the #22 wire cite above been thoughtfully protected, the outcome of the experience would have been much less exciting. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Dec 26, 2008
Yep, you are right about that. Small wire=high-resistance=heat which leads to smoke. How hot would a run of #4 get if it were shorted out (batt+ to ground)? Would it smoke the insulation? Brian in Brazil escreveu: >> I think the safest course is to avoid any smoking wires, either one foot >> or twelve feet, I think either one would probably kill you. > > Without a doubt, the smoking of wires with insulation > of any pedigree produces a most disagreeable atmosphere. > But at the same time, let's made a distinction between small > wires that are ROUTINELY protected and fat wires that are > not. Small wires are very likely to smoke when driven by > high current sources. FAT wires are generally few in number, > installed with special care and more likely to burn away the > faulting intrusion than to burn and become an emitter of smoke. > Small wire protection is generally takes the form of breakers or > fuses (I prefer fuses cause they're light, cheap, fast > and take up minimum panel space on airplane). Had the #22 wire > cite above been thoughtfully protected, the outcome of the > experience would have been much less exciting. > > > Bob . . . > > ----------------------------------------) > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > ---------------------------------------- > > -- Brian R. Wood JH Manutencao Anapolis. Goias, Brazil ________________________________________________________________________________
and
Date: Dec 26, 2008
brianrobertwood(at)gmail. wrote: > Yep, you are right about that. Small wire=high-resistance=heat which leads > to smoke. How hot would a run of #4 get if it were shorted out (batt+ to > ground)? Would it smoke the insulation? > > Brian in Brazil > > Brian R. Wood > JH Manutencao > Anapolis. Goias, Brazil I've run 300A through #4 synthetic rubber insulated welding cable (105 degrees-C rated) for several minutes without the insulation smoking or failing. It did get VERY hot though. :) A lot depends on the insulation. PVC is often rated at 85-degrees C. and will smoke a lot sooner than 400 degree-C rated fiberglass insulation. The "fusing current" level, at which the copper will melt and the wire acts like a fuse, is around 800A. -------- John M. Owner CamLight Systems Read this topic online here: http://forums.matronics.com/viewtopic.php?p=221284#221284 ________________________________________________________________________________
Subject: Re: Anyone done Bob Nuckoll's CBA modifications?
Date: Dec 26, 2008
nuckolls.bob(at)aeroelect wrote: > > Okay, I found it. I don't know why it was taken off the > website. It's still on the CDRom image of the website > as it existed some months ago. I've put the article back > up at: > > http://www.aeroelectric.com/articles/WestMountain_CBAII.pdf > I had tried to contact you via e-mail last month regarding my analysis. Some of my test results and recommendations differ from yours and I wanted to ask if you might be interested in discussing them? nuckolls.bob(at)aeroelect wrote: > > I had some extensive conversation with WMR. First > with regard to the FET failure and a second attempt to > discover the communication protocols on the USB > connection that controls the CBA-II and then gets > reported data back. > > I offered to craft an engineer's version of battery > test software that would provide watt-seconds instead > of amp-hours displays, conduct battery impedance tests, > etc. I even told him I would share the software for > him to use as I saw fit. He said similar plans were > already in work in his facilities and he declined > to share any information. > > The new software was 3 years in the making and still > falls short of what I would like to do with his product. > Further, the software reads the serial number of the > specific CBA II and you have to purchase separate > registered copies of the software to use each CBA II. > I have three computers and two CBA II that I would like > to use in interchangeable combinations but I'm not going > to buy a second software package when it still doesn't > do the things I would like to do and offered to him for > free. > > Bob . . . Sigh...you're not the only one frustrated with WMR's policies! The requirement to assign the software to a particular CBA II is maddening. And within a day or two after its release, a couple of us over at the RC Group forums found several obvious bugs in their version 2 software. Our biggest frustrations now? They've had at least 6 releases of the beta and "final" version 2 software since 10/28 and none of them have listed the changes from the previous release. Arggghhh! -------- John M. Owner CamLight Systems Read this topic online here: http://forums.matronics.com/viewtopic.php?p=221287#221287 ________________________________________________________________________________
Date: Dec 26, 2008
add flexibility and reduce noise from fat wires? Hi Ron, I have been up and down this pole with my Europa.- I ended up running- the + # 4 welding cable in the duct under the window sill and the - # 4 cab le through the wheel tunnel.- The battery and contactor are in close prox imity under the baggage bay. With all that said, I can remember when I purchased the cable (25' if I rem ember) thinking how much the darn stuff weighed.- I haven't done the comp arisons, but it would be worth seeing if there was a worthwhile saving usin g CCA cable that Eric sells.- For the sake of calculation, I think that I ultimately used about 22' of welding cable.- The only downside is that i t does have a larger diameter than # 4 welding cable. Cheers,- Paul --- On Thu, 12/25/08, rparigor(at)SUFFOLK.LIB.NY.US wrote: From: rparigor(at)SUFFOLK.LIB.NY.US <rparigor(at)SUFFOLK.LIB.NY.US> Subject: Re: AeroElectric-List: Is this scheme valid to save weight, add flexibility and reduce noise from fat wires? Date: Thursday, December 25, 2008, 11:16 PM Hi Bob Thx. for the reply My mission is to electrically connect my aft battery to the upfront 914 supplying it sufficient amperage and voltage, while being able to fit wires neatly under door sill/fuse seam and allow routing required to connect to battery switch (tight bends). Old style starter amp draw is stated at I think 60 amps, I have new style that is a bit less. If I can save some weight in the process that is a bonus. Just a quick calculation of one #4 compared to two #8s for 5 meters of wire would be a savings of a little over a half pound with two #8s. The larger the diameter of wires, the harder it will be to route under door sill and allow for door centering pin receptacle to help keep door from bulging. #4 Tefzel wire is .310" in diameter #6 EPDM jacket 259 strand is .332" diameter (#4 406 strand .380") #6 Chlorinated Polyethylene 660 strand is .370" diameter (#4 1045 strand .420") It's true I could lap solder #6 welding wire to #4 Tefzel, but my interior cover/conduit for wires would need to be larger to accommodate, and the laps would be in an already tight area. Butt soldering #4 Tefzel to #6 welding would approx. be the same diameter. I am not sure of the weight of welding cable compared to Tefzel, but I would think it heavier. I have a Hobart TRT 250 TIG welder. The ground wire I suspect is EPDM jacketed. It has cracks and splits and in general the jacketing is in bad health. True it sees a lot of UV and for a TIG ground strap that is fine. Are you be happy with using EPDM jacketed welding cable for the full run to and from engine to aft battery knowing if it smokes, a dozen feet is in the cockpit (aeroplane is fiberglass)? How about only 1 foot? Same question with Chlorinated Polyethylene jacketed welding cable: Are you be happy with using Chlorinated Polyethylene jacketed welding cable for the full run to and from engine to aft battery knowing if it smokes, a dozen feet is in the cockpit (aeroplane is fiberglass)? How about only 1 foot? Knowing I need flexibility for routing at battery switch, want the smallest diameter that is feasible, be able to provide reasonable voltage and cranking amps, not take unreasonable risks of breathing noxious fumes if wires smoke, not have much risk that aging wire insulation will crack and split and be the instigator of smoke and loss of electron flow and be of a reasonable weight. What would be your two favorite choices: ****#4 Tefzel with #6 EPDM jacketed butt soldered battery and battery switch ends? ****#4 Tefzel with #6 Chlorinated Polyethylene jacketed butt soldered battery and battery switch ends? ****All #4 EPDM jacketed wire? ****All #4 Chlorinated Polyethylene jacketed wire? ****Two paralleled #8 Tefzel wire that doesn't need twisting? Thx. Ron Parigoris =0A=0A=0A ________________________________________________________________________________
Date: Dec 27, 2008
At 07:40 PM 12/26/2008, you wrote: > > >nuckolls.bob(at)aeroelect wrote: > > > > Okay, I found it. I don't know why it was taken off the > > website. It's still on the CDRom image of the website > > as it existed some months ago. I've put the article back > > up at: > > > > http://www.aeroelectric.com/articles/WestMountain_CBAII.pdf > > > >I had tried to contact you via e-mail last month regarding my >analysis. Some of my test results and recommendations differ from >yours and I wanted to ask if you might be interested in discussing them? Yes, I recall that. I must have been 'snowed' at the time and the List comes first. We could discuss it here on the List . . . >Sigh...you're not the only one frustrated with WMR's policies! The >requirement to assign the software to a particular CBA II is >maddening. And within a day or two after its release, a couple of >us over at the RC Group forums found several obvious bugs in their >version 2 software. > >Our biggest frustrations now? They've had at least 6 releases of >the beta and "final" version 2 software since 10/28 and none of them >have listed the changes from the previous release. Arggghhh! That's unfortunate. I know there are a lot of folks out there with time, talent and resources willing to help him refine the product. Push comes to shove, we could do our own. I've got PIC's with USB engines that I've integrated into some proposed projects for TC aircraft. A retired programmer from NCR/Symbios/LSI lives right behind me (my father in law). He's been doing some other projects for me and would be please to have this one. Our hammer-n-tongs version need not be pretty, only utilitarian. I think I'd opt for a board that could drive any practical number of power FETS. The user could scale his/her version to the desired task. The only variable in the software would be to insert a shunt constant for current interpretation. The battery tester itself is stone simple. The sexy part is the application that manages it. John went out and bought VBasic.net a few months ago but we've not had occasion to use it yet. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Dec 27, 2008
flexibility and At 07:23 PM 12/26/2008, you wrote: > > >brianrobertwood(at)gmail. wrote: > > Yep, you are right about that. Small wire=high-resistance=heat > which leads > > to smoke. How hot would a run of #4 get if it were shorted out (batt+ to > > ground)? Would it smoke the insulation? Wires are generally really hard to "smoke". This piece of 22AWG wire . . . http://aeroelectric.com/Pictures/Wire/22AWG_20A.pdf . . . had been running at 20 AMPS until the temperature stabilized at 112C. Tefzel is good to 150C. So we're not even pushing the wire all that hard YET. Of course we "derate" wires for effects of bundling, hi temperature environments, and voltage drop. But the point is that a 22AWG wire we normally limit to a 5 amp circuit feeder is much more robust with respect to fault tolerance than the 5A de-rating suggests. >I've run 300A through #4 synthetic rubber insulated welding cable >(105 degrees-C rated) for several minutes without the insulation >smoking or failing. It did get VERY hot though. :) > >A lot depends on the insulation. PVC is often rated at 85-degrees >C. and will smoke a lot sooner than 400 degree-C rated fiberglass >insulation. The "fusing current" level, at which the copper will >melt and the wire acts like a fuse, is around 800A. Which supports the 22 AWG experiment described above. Folks worry a lot about "smoking" wires but simple attention to fuses and circuit breakers for small wires and careful attention to routing and support for fat wires is all it takes to drive the probability of smoke down to the very small numbers. With respect to relative weights, my data books say 4AWG Tefzel (22759/16) is 157 pounds per 1000/ft or .16 pounds per foot. A 4" chunk of 4AWG welding cable I have laying around comes in at 24gm or 72gm per foot which is still .16 pounds. So if you substitute the style cable I have here (one layer synthetic rubber) for the 22759/16, there is no weight penalty. Other brands/styles of welding cable may not be 1:1 but they're not going to be far off. Bottom line is that any weight differences to be exploited with exotic combinations of other sizes and subsequent splices has a poor if not zero return on investment for $time$ expended. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
From: "Henry Trzeciakowski" <hammer408(at)comcast.net>
Subject: Re: D-Sub Pins
Date: Dec 27, 2008
Bob: Looking thru your archives, I see that one can use D-Sub's are wiring connections: I.E. - joining 2 wires together, rather than use butt splices, solder seal, etc.... So my question is: 1- Rather than soldering my Mic & Phone jack wires directly to my jack outlets, can I solder leads, then use D-Sub pins to join to the leads to the amin wires? 2- Can I also use these D-Subs for splicing shielded wire: 22 awg wire? I can see al lot of uses for these D-subs, amazing !!! Henry ________________________________________________________________________________
Date: Dec 27, 2008
nuckolls.bob(at)aeroelect wrote: > > Yes, I recall that. I must have been 'snowed' at the > time and the List comes first. We could discuss it here > on the List . . . No problem, I understand. :) In another thread I'll post a link to the analysis and a couple of things I'd love to discuss. nuckolls.bob(at)aeroelect wrote: > > That's unfortunate. I know there are a lot of > folks out there with time, talent and resources > willing to help him refine the product. Push > comes to shove, we could do our own. > > I've got PIC's with USB engines that I've integrated > into some proposed projects for TC aircraft. A > retired programmer from NCR/Symbios/LSI lives right > behind me (my father in law). He's been doing > some other projects for me and would be please > to have this one. > > Our hammer-n-tongs version need not be pretty, > only utilitarian. I think I'd opt for a board > that could drive any practical number of power > FETS. The user could scale his/her version > to the desired task. The only variable in the > software would be to insert a shunt constant > for current interpretation. > > The battery tester itself is stone simple. > The sexy part is the application that manages > it. John went out and bought VBasic.net a few > months ago but we've not had occasion to use > it yet. > > Bob . . . I think that's an idea worth exploring! I've developed a 500W (400W continuous) electronic load that can be used to extend the capabilities of any analyzer or discharger (http://www.rcgroups.com/forums/showthread.php?t=938266) but there's a real need for "host" software and a load in the power range of the CBA, perhaps 100W-200W. This would be perfect for most DIY'ers and could easily be paralleled for higher power handling. The software would have to be very graphics-capable as the plotting and graphing features would be extremely important. I'd love to see it not require a huge installation just to run. But, the options may be limited. The CBA software has a nice light footprint though. An executable, help file, settings file, three DLLs for USB comms and forms handling. It may have some registry keys or other files in public directories but it doesn't seem to require the NET framework. MileHighWings' eFlightWatt logger had a single executable file that did everything, no installation needed. Something like this for an open source tester would be terrific. -------- John M. Owner CamLight Systems Read this topic online here: http://forums.matronics.com/viewtopic.php?p=221437#221437 ________________________________________________________________________________
Date: Dec 27, 2008
Subject: Anything wrong with using a plier style crimper?
I rounded up some ratcheting style crimping tools from airport folk and a homebuilderfor crimping Red crimp on connectors from Stein (fast on and ring). Got hold of a Paladin tool with several sets of dies, and some no name non adjustable tool. The die sets for the Paladine: ****Part number said for insulated terminals and had 3 colored dots including red ****There was a set of dies with no part number but fit tool (perhaps from Stein??) and looked like for insulated terminals And a few others, one for uninsulated terminals and other First off no matter what the adjustment, if using 22 gauge wire, even with the dies completely bottomed, could not get as much a grip as i would like. I could semi make it better by splicing more wire and doubling it over to better fill hole. Problem was it still did not crimp wire terrific and the portion that was to crimp on the insulation for strain relief was too far away (too wide a die?) where it was only partially catching the metal in the terminals. All the terminals from Stein and Terminal Town and Mcmaster (double metal) appeared to be too short for tool. I tried all the dies I had and combinations. Not great success with theno name tool with fixed dies and is non adjustable. I could get an OK crimp, probably will work and with heat shrink support will probably be OK, but insulation was not captured properly and if i sliced open the crimp on the wire, you could see it is not as compact as would be nice. Then I pulled out an old and rusty Whitaker WC2850 tool, looks like a pair of pliers with several dies on it. After some practice I can make what I think is a very nice crimp, far better than what I could do withthe other tools. *First I stripped twice what I need and double up tail to go into terminal *Then crimp with RARB dieabout 1/16" from the edge of terminal *Then use a part of tool called "A" which is kind of a half cylinder (feel here is important) and put a dimple on top of terminalwhere I just crimped. I tried to over crimp this step and if I go crazy where terminal in stead of being straight begins to bend, I can tear wire when pulled very hard because wire is mashed too much. I am pretty confident can repeat this dimple consistently.When I sliced practice terminals apart had a very compacted crimp without strands being deformed/mashed. Without dimple, crimp is acceptable in my mind for automobiles only, and places easy to get at with no moisture present. *Then use RARB to crimp wire insulation about 1/16" from edge, no hurting of insulation at all and wire is held pretty good. Anyone see any problems crimping like I describe? i could have stripped and crimped a dozen terminals in time it took me to write this. Ron Parigoris ________________________________________________________________________________
Subject: CBA II Thermal Analysis - Does the CBA run too hot?
Date: Dec 28, 2008
Hello all, After hearing of several of them burning out, I did an analysis of two West Mountain Radio CBA II's and have written it up: http://www.camlight.com/techinfo/CamLight_Systems_CBA_II_Thermal_Analysis.pdf Bob wrote up a really great analysis back in 2005 (which is still being passed around) but a couple of my conclusions differ from those Bob made so I wanted to post here to discuss them. Those conclusions are: - The MOSFETs in the CBA and the 10x Amplifier are not rated for use as a load and are subject to failure at levels significantly below the CBA's 100W rating. This includes the IRFP2907. - Paralleling switching MOSFETs is very, very problematic and each should be driven by its own local control loop. - Due to overheating, the CBA should not be used at a level above 65W for long term reliability. Never exceed 86W to prevent failure of the MOSFET. - Discharging packs at above 20V (and perhaps even lower) significantly increases the risk of the CBA burning out, at almost any power level. A fun note... After reading Bob's analysis a couple of times, I suddenly noticed that he uses the exact same graphics to represent/model the thermal resistances of a MOSFET that I've always used. Important? No. But it was fun to realize why it was such easy reading for me. :-) -------- John M. Owner CamLight Systems Read this topic online here: http://forums.matronics.com/viewtopic.php?p=221447#221447 ________________________________________________________________________________
Date: Dec 28, 2008
Subject: Re: Anything wrong with using a plier style crimper?
At 10:38 PM 12/27/2008, you wrote: >I rounded up some ratcheting style crimping tools from airport folk >and a homebuilder for crimping Red crimp on connectors from Stein >(fast on and ring). > >Got hold of a Paladin tool with several sets of dies, and some no >name non adjustable tool. > >The die sets for the Paladine: >****Part number said for insulated terminals and had 3 colored dots >including red >****There was a set of dies with no part number but fit tool >(perhaps from Stein??) and looked like for insulated terminals >And a few others, one for uninsulated terminals and other > >First off no matter what the adjustment, if using 22 gauge wire, >even with the dies completely bottomed, could not get as much a grip >as i would like. I could semi make it better by splicing more wire >and doubling it over to better fill hole. Problem was it still did >not crimp wire terrific and the portion that was to crimp on the >insulation for strain relief was too far away (too wide a die?) >where it was only partially catching the metal in the terminals. All >the terminals from Stein and Terminal Town and Mcmaster (double >metal) appeared to be too short for tool. I tried all the dies I had >and combinations. Not great success with the no name tool with fixed >dies and is non adjustable. > >I could get an OK crimp, probably will work and with heat shrink >support will probably be OK, but insulation was not captured >properly and if i sliced open the crimp on the wire, you could see >it is not as compact as would be nice. > >Then I pulled out an old and rusty Whitaker WC2850 tool, looks like >a pair of pliers with several dies on it. > >After some practice I can make what I think is a very nice crimp, >far better than what I could do with the other tools. > >*First I stripped twice what I need and double up tail to go into terminal >*Then crimp with RARB die about 1/16" from the edge of terminal >*Then use a part of tool called "A" which is kind of a half cylinder >(feel here is important) and put a dimple on top of terminal where I >just crimped. I tried to over crimp this step and if I go crazy >where terminal in stead of being straight begins to bend, I can tear >wire when pulled very hard because wire is mashed too much. I am >pretty confident can repeat this dimple consistently. When I sliced >practice terminals apart had a very compacted crimp without strands >being deformed/mashed. Without dimple, crimp is acceptable in my >mind for automobiles only, and places easy to get at with no moisture present. >*Then use RARB to crimp wire insulation about 1/16" from edge, no >hurting of insulation at all and wire is held pretty good. > >Anyone see any problems crimping like I describe? i could have >stripped and crimped a dozen terminals in time it took me to write this. > >Ron Parigoris The physics for making a gas-tight connection between wire and terminal is process-sensitive. The "ideal" crimped junction puts sufficient force on the terminal to close the cross-section of terminal and wire copper just to the point that the terminal and wire strands become one piece of metal. Too little mash, and voids in the joint allow oxygen laden moisture to enter raising risk of failure due to corrosion. Too much mash and strength of the strands is weakened by reduction of cross-section thus raising risk of failure under tension/vibration. See: http://aeroelectric.com/articles/CrimpTools/crimptools.html Dimple-crimps are for terminals going onto solid wire only. See "Solistrand" terminals and tooling from AMP. You will note that all crimp tools suggested and/or evaluated in our writing are free of "dimple" punches. The PIDG style terminal is best applied with uniform pressure offered by smooth bore dies. Of secondary concern is molding of the wire-grip to the conductor just outside the joint. The terminal may have too little volume in the closed condition for the amount of plastic in the terminal's wire support insulation. See: http://aeroelectric.com/Pictures/Terminals/JST_Samples_2.jpg These terminals were electrically okay when installed with our favorite tools . . . but did not become part of our inventory because we had no tools that would do a professional looking installation. Ron, it's not possible to encourage or discourage use of the tools you've cited without making a first-hand evaluation of their performance under the guide-lines discussed in the article above and these additional pieces found on my website . . . http://aeroelectric.com/articles/faston3.pdf http://aeroelectric.com/articles/terminal.pdf Finally, on the subject of wire-joining, I'll remind readers of this article published some years back in Sport Aviation. The author didn't have a clue about simple-ideas for the processes in which he claimed considerable knowledged and skill. http://aeroelectric.com/articles/rules/review.html Bob . . . ________________________________________________________________________________
Date: Dec 28, 2008
At 06:55 PM 12/27/2008, you wrote: > > >Bob: > >Looking thru your archives, I see that one can use D-Sub's are wiring >connections: I.E. - joining 2 wires together, rather than use butt splices, >solder seal, etc.... >So my question is: > >1- Rather than soldering my Mic & Phone jack wires directly to my jack >outlets, can I solder leads, then use D-Sub pins to join to the leads to the >amin wires? If you wish. What is the advantage? You've increased parts count and total numbers of joints. Are these jacks likely to be removed and replaced as part of a maintenance activity? If you need to break a wire bundle during routine maintenance then it's best to use a complete mated pair of d-sub connectors as opposed to individual pin-pairs under heatshrink. >2- Can I also use these D-Subs for splicing shielded wire: 22 awg wire? > >I can see al lot of uses for these D-subs, amazing !!! They ARE a legacy technology with features that can address design-goals that are peripheral to or sub-sets of the original ideas. But as a general rule we try to MINIMIZE parts count and $time$ to install wires for best reliability and lowest cost of ownership. Splicing of wires is best made with permanent joining technologies (crimp/solder) unless there is an over-riding interest in future maintenance activities made simple by the use of de-mateable splices whether grouped as connectors or individual pins. Keep in mind too that the single pin-pairs under heat-shrink are VERY vulnerable to de-mating under tension. Use this technique with careful attention to support of strands either side of the splice to prevent tugging on the joint. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Dec 28, 2008
Subject: Re: CBA-II Battery Tester modifications/improvements?
> >I think that's an idea worth exploring! >I've developed a 500W (400W continuous) electronic load that can be >used to extend the capabilities of any analyzer or discharger >(http://www.rcgroups.com/forums/showthread.php?t=938266) but there's >a real need for "host" software and a load in the power range of the >CBA, perhaps 100W-200W. This would be perfect for most DIY'ers and >could easily be paralleled for higher power handling. > >The software would have to be very graphics-capable as the plotting >and graphing features would be extremely important. I'd love to see >it not require a huge installation just to run. But, the options >may be limited. I'm not so sure about the graphics. Yes, they do make for an effective display of data . . . and comparison of similar batteries . . . http://aeroelectric.com/articles/AA_Bat_Test.pdf The data for this article was taken with a one-sample-per-second data acquisition module that produces columnar data easily imported into graphics applications like autocad and excel. For the purpose of writing articles, the graphics offered by WestMountainRadio are pretty . . . http://www.aeroelectric.com/Pictures/Curves/9vBatteryTests.jpg but from an engineering perspective, a numerical value for energy delivered under the prescribed test conditions is quite sufficient. The results of dynamic tests for evaluating battery source impedance could be offered out as numerical values. I did a flight test program for Raytheon a few years back where the Weeder Technology modules proved quite useful. http://www.weedtech.com/ http://aeroelectric.com/Pictures/Tools/Test_Equipment/Data_Acquisition/Weedtech_DAS_2.jpg As a first pass for crafting a more robust version of the CBA-II, a Weeder analog input module for $69 and an analog output module for $99 would offer 95% of the hardware to implement the task. Very simple programs in any language of choice could be crafted to orchestrate the testing, gathering of data values and presentation of end-point results with no graphics capabilities at all. One could also store individual data points on the hard drive in a format easily imported to Excel. >The CBA software has a nice light footprint though. An executable, >help file, settings file, three DLLs for USB comms and forms >handling. It may have some registry keys or other files in public >directories but it doesn't seem to require the NET >framework. MileHighWings' eFlightWatt logger had a single >executable file that did everything, no installation >needed. Something like this for an open source tester would be terrific. Sure. And I wouldn't discourage any interested parties from turning their vision into really nifty applications by exercising their programming skills. From the hands-on engineering perspective, my personal needs for battery testing can be easily addressed with more rudimentary software. In fact, I still keep 20 year old copies of Turbo-Basic that outputs compiled .exe files for talking/listening to the Weeder modules. I have a supply of these guys on the shelf from various programs over the years. They still offer the hammer-n-nails approach to crafting a quick and useful test-setup. Bob . . . ________________________________________________________________________________
Subject: Twisted Wires vs. Parallel
Date: Dec 28, 2008
We often see instructions to twist the positive and negative wires together to reduce noise problems. Instructions from B&C for their voltage regulator even specified the number of twists per inch. But I'm wondering about the physics. From studying the 'Connection, it seems that paralleling the positive and negative wires tightly together would have the same effect as twisting them together. Is twisting the wires together recommended because it is a convenient way to keep the wires in close contact? Or is there something about the nature of the electromagnetic fields that makes twisting more effective? Thanks, Dennis Legacy, 220 hours, mostly twisted positive and negative wires ________________________________________________________________________________
Subject: Re: Twisted Wires vs. Parallel
Date: Dec 28, 2008
Twisting reduces the wiring's susceptibility to interference due to the way it can cancel out certain external signals by reducing the wire's loop area (which reduces its degree of coupling to the interference). It also reduces crosstalk between nearby pairs of wire, but you need different twist rates for each pair to minimize coupling between them. What I'm not sure of is the difference in effectiveness between pairs carrying single-ended signals (signal and ground) vs. differential signals (signal+ and signal-. used in telecomm and computer equipment). -------- John M. Owner CamLight Systems Read this topic online here: http://forums.matronics.com/viewtopic.php?p=221507#221507 ________________________________________________________________________________
Date: Dec 28, 2008
>We often see instructions to twist the positive and negative wires >together to reduce noise problems. Instructions from B&C for their >voltage regulator even specified the number of twists per inch. > >But I'm wondering about the physics. From studying the 'Connection, >it seems that paralleling the positive and negative wires tightly >together would have the same effect as twisting them together. Is >twisting the wires together recommended because it is a convenient >way to keep the wires in close contact? Or is there something about >the nature of the electromagnetic fields that makes twisting more effective? A single conductor in relatively "free" space has some behaviors of an antenna. I.e, it can radiate as well as gather some portion of any electro-magnetic energy in the vicinity. When electrons move relative to some local point one can measure both an electric (electro-static) force as well as a magnetic (electro-magnetic) force as a result of that motion. For example, a beam of electrons shot from the rear of a cathode ray tube toward a screen can be deflected or pointed because we can exploit EITHER the electro-static or electro-magnetic properties of a moving stream of electrons. It matters not whether those electrons move through a conductor or through a vacuum. In a CRT television display http://aeroelectric.com/Pictures/Misc/Electro-Magnetic_Deflection.jpg electro-magnets on the neck of the tube were used to control direction of the electron beam to produce spots of light over the surface of the screen. In an oscilloscope, electro-static deflection . . . . http://aeroelectric.com/Pictures/Misc/Electro-Static_Deflection.jpg . . . was preferred for its much higher frequency response. Not only can electron streams be magnetically and statically influenced as described above, they exert their own, similar influences. Suppose we start with a circular loop of wire say 10' in diameter. This is an excellent example of a loop antenna with an ability to efficiently radiate or intercept energy at some frequency. Now, let's squash the loop in one dimension. As it moves toward an elliptical shape, the AREA of the loop goes down and the radiation/reception efficiency goes down. The obvious end point happens when the area approaches zero and the circle becomes a parallel pair of wires. It's intuitively obvious that electrons flowing in one wire are exactly balanced by opposite direction flow in the opposite wire thus cancelling their individual electro-magnetic and electro-static effects . . . mostly. At higher frequencies it can be shown that parallel lines do not exactly cancel mutual magnetic effects because of the non-zero distance between their centers. Here it becomes valuable to twist the two conductors such that what ever leakage exists perpendicular to the conductors tends to be washed out by the reverse polarity of effects longitudinally displaced 1/2 twist away. Another very effective technique is to use shielded wire. Use the center conductor for the outbound electron flow and the shield for the inbound flow. Here the two fields ARE centered on each other and cancel each other exactly. In the case of the compass light wire, the goal is to null the magnetic field around a wire that MUST be positioned in close proximity to the system most vulnerable to interference from variable and stray magnetic fields. Some manufacturers twisted their outbound and return wires. Others ran the wire up a small i.d. copper tube to make inbound/outbound paths. Similarly, shielded wire would be equally effective in this regard. Twisting the B&C Alternator wires was done at my suggestion back when plastic and glass canard pushers were king. The effects of poorly managed inbound/outbound conductor pairs had some profound effects on compass as well as audio systems. But again, this practice IS NOT generally recommended for ALL inbound/outbound pairs in an airplane. Like my oft repeated admonition for "follow the manufacturer's instructions" for shielding practices, the same advice applies to things like twisting for PM alternator installations in plastic airplanes and compass lights. Twisting makes a wire bundle more bulky and more $time$ consuming to fabricate and install. Bob . . . ________________________________________________________________________________
Date: Dec 28, 2008
At 04:41 PM 12/28/2008, you wrote: > >Twisting reduces the wiring's susceptibility to interference due to >the way it can cancel out certain external signals by reducing the >wire's loop area (which reduces its degree of coupling to the >interference). It also reduces crosstalk between nearby pairs of >wire, but you need different twist rates for each pair to minimize >coupling between them. > >What I'm not sure of is the difference in effectiveness between >pairs carrying single-ended signals (signal and ground) vs. >differential signals (signal+ and signal-. used in telecomm and >computer equipment). Paralleled or twisted conductors get you benefit only when they carry equal magnitude and opposite polarity signals. This is why RS232 single-ended data was quickly replaced by RS422 twisted pairs under shields for the greatest noise immunity. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Dec 28, 2008
Dennis, There is no difference electrically between two wires that are kept at the same distance in parallel and two wires that are twisted together to stay parallel. The reason they are twisted together is that it is the simplest way to keep them in parallel while the cable (a combination of wires, shields, insulation, etc.) bends and distorts. When an RS-422 transmitter generates a signal, it has two circuits that drive the twisted wire pair. One circuit sources current, while the other circuit sinks current. When a differential twist wire pair carries two currents from the transmitter to the receiver, they travel from the source driver to the load (a termination resistor next to the receiver), then back to the current sink. Along each wire, the current generates an electromagnetic field defined by the right hand rule, where the direction of the field is per the direction of the hand's fingers when the thumb is pointing toward the direction of current flow. Since the current in one wire is traveling opposite the current in the other wire, the fields oppose each other and ideally cancel each other out. They also ideally cause no noise to be radiated. Perhaps the greatest benefit of RS-422 and differential signaling is immunity from external noise in the receiver. RS-422 receivers are built to reject "common-mode noise, which is noise that is of the same amplitude on both the + and - terminals of the receiver. This is where the twisted wire pair comes in. It connects to the receiver's + and - terminals and brings in both the real signal and common-mode noise. While the twisted-wire pair is shielded, some noise will leak in, but the electromagnetic and electrostatic fields will cut across wires at the same amplitude, because the wires are so close together. Thus, the noise's amplitude will appear at the receiver's + and - terminals equally and will be rejected by the receiver, since it is designed to reject common-mode noise. As an example, the AM26LV32 is a commonly used differential line 3.3V receiver. It has a common mode input voltage range from -0.3 to 5.5V and will reject any voltage that appears on both terminals in this range. The voltages on its terminals must have a delta of greater than 0.2V for it to change its outputs. You probably have to be involved in the measurement of real world signals and problems to appreciate just how good the AM26LV32 works to reject common-mode noise. One of the things that I haven't mentioned is that the termination resistor not only serves to terminate the twisted wire pair's characteristic impedance but also provides a low impedance to prevent electrostatic and electromagnetic fields from developing high voltages in twisted wire pairs. So to reiterate, there is nothing magical about twisted wire pairs other than they keep the wires in close proximity to each other and that's it. Everything else I said above is just fluff! :) Simon Ramirez Copyright 2008 From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Dennis Johnson Sent: Sunday, December 28, 2008 12:29 PM Subject: AeroElectric-List: Twisted Wires vs. Parallel We often see instructions to twist the positive and negative wires together to reduce noise problems. Instructions from B&C for their voltage regulator even specified the number of twists per inch. But I'm wondering about the physics. From studying the 'Connection, it seems that paralleling the positive and negative wires tightly together would have the same effect as twisting them together. Is twisting the wires together recommended because it is a convenient way to keep the wires in close contact? Or is there something about the nature of the electromagnetic fields that makes twisting more effective? Thanks, Dennis Legacy, 220 hours, mostly twisted positive and negative wires ________________________________________________________________________________
Subject: Pitts S1 Wiring Diagram
Date: Dec 29, 2008
Hi all.. been trawling through all the posting history on this list looking for some help with what layout and equipment set make sense in the tight engine compartment of a Pitts S1. Sorry if any of this is repeat/old stuff, but it's all new to me. Thanks also to Bob who has given me many hours of enjoyment trying to get to grips with his manual, and Z figures. I started on Z13/8 and pulled out the 2nd big alternator in favor of a single small SD-8 one, and have gone from there. A Pitts should be rather simple, I would have thought. This is a VFR short-hop plane 99% of the time, doing aerobatics I had a good look at the aerobatic wiring diagram from B&C... so I had assumed I could get by on a SD-8 alternator as only electrical generation source. I have a Icom A200, Narco Xpdr, Encoder and the usual engine instruments (EGT, CHT, OILT, OILP, FUELP) so thought I could get away it. Um, ok, also a Fuel boost pump (only during starting) and smoke pump (couple of minutes a flight)... I also would like to run a AV80R GPS as well, if possible. Now I'm wondering about the SD-8... and if not, well, then the SD-20. I can add up all the Amp loads on each thing, but I'm not sure how much under/over capacity I need to run everything? Is there a general rule of thumb? My other question is whether there is enough space behind the engine for the vacuum mounted SD-8 - considering I'm planning dual PMAGS, and have an inverted OIL kit right there in the same place. A friend building an S1 that I talk to a lot as opted for the PlanePower 60Amp unit that is belt driven up front to free up some space, as he reckoned it was too tight. Would love a second opinion from someone with an S1. Most S1's flying out there are 20, 30 years old, even older, and I'm hoping someone can help me take advantage of the new technology advances to build a simple, clean and lightweight electrical system. Thanks to anyone who can help. ________________________________________________________________________________
Date: Dec 29, 2008
Hello Stuart, I have an S1 with an SD-8, standard slick mags and an inverted oil system. It is tight but doable. Cheers, John -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Stuart Mackereth Sent: Monday, 29 December 2008 4:53 PM Subject: AeroElectric-List: Pitts S1 Wiring Diagram --> Hi all.. been trawling through all the posting history on this list looking for some help with what layout and equipment set make sense in the tight engine compartment of a Pitts S1. Sorry if any of this is repeat/old stuff, but it's all new to me. Thanks also to Bob who has given me many hours of enjoyment trying to get to grips with his manual, and Z figures. I started on Z13/8 and pulled out the 2nd big alternator in favor of a single small SD-8 one, and have gone from there. A Pitts should be rather simple, I would have thought. This is a VFR short-hop plane 99% of the time, doing aerobatics I had a good look at the aerobatic wiring diagram from B&C... so I had assumed I could get by on a SD-8 alternator as only electrical generation source. I have a Icom A200, Narco Xpdr, Encoder and the usual engine instruments (EGT, CHT, OILT, OILP, FUELP) so thought I could get away it. Um, ok, also a Fuel boost pump (only during starting) and smoke pump (couple of minutes a flight)... I also would like to run a AV80R GPS as well, if possible. Now I'm wondering about the SD-8... and if not, well, then the SD-20. I can add up all the Amp loads on each thing, but I'm not sure how much under/over capacity I need to run everything? Is there a general rule of thumb? My other question is whether there is enough space behind the engine for the vacuum mounted SD-8 - considering I'm planning dual PMAGS, and have an inverted OIL kit right there in the same place. A friend building an S1 that I talk to a lot as opted for the PlanePower 60Amp unit that is belt driven up front to free up some space, as he reckoned it was too tight. Would love a second opinion from someone with an S1. Most S1's flying out there are 20, 30 years old, even older, and I'm hoping someone can help me take advantage of the new technology advances to build a simple, clean and lightweight electrical system. Thanks to anyone who can help. ________________________________________________________________________________
Date: Dec 29, 2008
Great, thanks John. What line up do you run - VHF, XPDR, GPS, etc? Don't suppose you have a picture of the back for me to have a look at? Sorry, but now you got me started ;-) -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of John Cleary Sent: Monday, 29 December 2008 7:40 p.m. Subject: RE: AeroElectric-List: Pitts S1 Wiring Diagram --> Hello Stuart, I have an S1 with an SD-8, standard slick mags and an inverted oil system. It is tight but doable. Cheers, John -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Stuart Mackereth Sent: Monday, 29 December 2008 4:53 PM Subject: AeroElectric-List: Pitts S1 Wiring Diagram --> Hi all.. been trawling through all the posting history on this list looking for some help with what layout and equipment set make sense in the tight engine compartment of a Pitts S1. Sorry if any of this is repeat/old stuff, but it's all new to me. Thanks also to Bob who has given me many hours of enjoyment trying to get to grips with his manual, and Z figures. I started on Z13/8 and pulled out the 2nd big alternator in favor of a single small SD-8 one, and have gone from there. A Pitts should be rather simple, I would have thought. This is a VFR short-hop plane 99% of the time, doing aerobatics I had a good look at the aerobatic wiring diagram from B&C... so I had assumed I could get by on a SD-8 alternator as only electrical generation source. I have a Icom A200, Narco Xpdr, Encoder and the usual engine instruments (EGT, CHT, OILT, OILP, FUELP) so thought I could get away it. Um, ok, also a Fuel boost pump (only during starting) and smoke pump (couple of minutes a flight)... I also would like to run a AV80R GPS as well, if possible. Now I'm wondering about the SD-8... and if not, well, then the SD-20. I can add up all the Amp loads on each thing, but I'm not sure how much under/over capacity I need to run everything? Is there a general rule of thumb? My other question is whether there is enough space behind the engine for the vacuum mounted SD-8 - considering I'm planning dual PMAGS, and have an inverted OIL kit right there in the same place. A friend building an S1 that I talk to a lot as opted for the PlanePower 60Amp unit that is belt driven up front to free up some space, as he reckoned it was too tight. Would love a second opinion from someone with an S1. Most S1's flying out there are 20, 30 years old, even older, and I'm hoping someone can help me take advantage of the new technology advances to build a simple, clean and lightweight electrical system. Thanks to anyone who can help. Checked by AVG - http://www.avg.com 2:23 p.m. ________________________________________________________________________________
Date: Dec 28, 2008
nuckolls.bob(at)aeroelect wrote: > I'm not so sure about the graphics. Yes, they do make for an > effective display of data . . . and comparison of similar > batteries . . . > > http://aeroelectric.com/articles/AA_Bat_Test.pdf > > The data for this article was taken with a one-sample-per-second > data acquisition module that produces columnar data easily > imported into graphics applications like autocad and excel. > For the purpose of writing articles, the graphics offered by > WestMountainRadio are pretty . . . > > http://www.aeroelectric.com/Pictures/Curves/9vBatteryTests.jpg > > but from an engineering perspective, a numerical value for > energy delivered under the prescribed test conditions is > quite sufficient. The results of dynamic tests for evaluating > battery source impedance could be offered out as numerical > values. As someone involved heavily in engineering, I agree. But you'll find a lot of very strong opposition to devices that only output numerical values for later importing and graphing or for use in creating a table. These all take extra work to do and is considered a total PITA by those who don't revel in the numbers the way we do. In my opinion, the success of the CBA is in its software (and its price, of course). It allows for very, very easy and no-work testing and comparison of different cells. There are other devices out there that allow for exporting to Excel or other saving of data, but they aren't nearly as popular. As a first step, just storing the data for import into Excel is OK. Even for taking and creating tables with. But, it would be nice to see a growth path possible for the software to include on-screen graphing/plotting. There are many constant-current load circuits out there but they're not being built and used by very many people, I think the right software is what would make the difference. nuckolls.bob(at)aeroelect wrote: > > I did a flight test program for Raytheon a few years > back where the Weeder Technology modules proved quite > useful. > > http://www.weedtech.com/ > > http://aeroelectric.com/Pictures/Tools/Test_Equipment/Data_Acquisition/Weedtech_DAS_2.jpg > > As a first pass for crafting a more robust version of > the CBA-II, a Weeder analog input module for $69 and > an analog output module for $99 would offer 95% of > the hardware to implement the task. Very simple programs > in any language of choice could be crafted to orchestrate > the testing, gathering of data values and presentation > of end-point results with no graphics capabilities > at all. > > One could also store individual data points on the > hard drive in a format easily imported to Excel. > Those are nice units! I've been using the USB-6008 DAQ unit from National Instruments (http://sine.ni.com/nips/cds/view/p/lang/en/nid/14604) for various projects, which is competitively priced. It includes driver and basic logging software too. I'd have to check closer to make sure it can support what the project might need but it's worth checking out IMHO. Another option is one you alluded to earlier, a PIC. That would result in a very small and inexpensive unit to control the load with and acquire and upload the data from. Someone would have to develop and test the firmware though. There's still a decent amount of hardware left to work out though...PCB design and selection of the MOSFETs, op-amps, resistor/capacitors, voltage regulators, microprocessor, connectors, heat sink, fan, etc., for the load itself. nuckolls.bob(at)aeroelect wrote: > > Sure. And I wouldn't discourage any interested parties > from turning their vision into really nifty applications > by exercising their programming skills. From the hands-on > engineering perspective, my personal needs for battery > testing can be easily addressed with more rudimentary > software. > > In fact, I still keep 20 year old copies of > Turbo-Basic that outputs compiled .exe files > for talking/listening to the Weeder modules. > I have a supply of these guys on the shelf from > various programs over the years. They still > offer the hammer-n-nails approach to crafting > > a quick and useful test-setup. > > Bob . . . I remember Turbo-Basic. You're right, a very useful software package! :) I think you bring up a very good point. There will be two groups of users for this load. The ones who just need the raw data outputted in the simplest way possible and those who want it displayed in graphical form to allow for the quickest way to see what they need to see. -------- John M. Owner CamLight Systems Read this topic online here: http://forums.matronics.com/viewtopic.php?p=221572#221572 ________________________________________________________________________________
Date: Dec 28, 2008
simon(at)synchdes.com wrote: > There is no difference electrically between two wires that are kept at the same distance in parallel and two wires that are twisted together to stay parallel. The reason they are twisted together is that it is the simplest way to keep them in parallel while the cable (a combination of wires, shields, insulation, etc.) bends and distorts. But don't pairs in untwisted pair cabling suffer from more crosstalk and susceptibility to interference than in twisted-pair cabling? And, IIRC, can't you do a longer run with twisted-pair than with untwisted-pair cable? -------- John M. Owner CamLight Systems Read this topic online here: http://forums.matronics.com/viewtopic.php?p=221573#221573 ________________________________________________________________________________
Date: Dec 29, 2008
I think this paragraph from Bob N. earlier this week bears on this discussion. =============================================== At higher frequencies it can be shown that parallel lines do not exactly cancel mutual magnetic effects because of the non-zero distance between their centers. Here it becomes valuable to twist the two conductors such that what ever leakage exists perpendicular to the conductors tends to be washed out by the reverse polarity of effects longitudinally displaced 1/2 twist away. ================================================ Raymond Julian Kettle River, MN "Hope for the best, but prepare for the worst." ----- Original Message ----- From: "S. Ramirez" <simon(at)synchdes.com> Sent: Sunday, December 28, 2008 9:16 PM Subject: RE: AeroElectric-List: Twisted Wires vs. Parallel > Dennis, > > > There is no difference electrically between two wires that are kept at the > same distance in parallel and two wires that are twisted together to stay > parallel. The reason they are twisted together is that it is the simplest > way to keep them in parallel while the cable (a combination of wires, > shields, insulation, etc.) bends and distorts. > > > When an RS-422 transmitter generates a signal, it has two circuits that > drive the twisted wire pair. One circuit sources current, while the other > circuit sinks current. When a differential twist wire pair carries two > currents from the transmitter to the receiver, they travel from the source > driver to the load (a termination resistor next to the receiver), then > back > to the current sink. Along each wire, the current generates an > electromagnetic field defined by the right hand rule, where the direction > of > the field is per the direction of the hand's fingers when the thumb is > pointing toward the direction of current flow. Since the current in one > wire is traveling opposite the current in the other wire, the fields > oppose > each other and ideally cancel each other out. They also ideally cause no > noise to be radiated. > > > Perhaps the greatest benefit of RS-422 and differential signaling is > immunity from external noise in the receiver. RS-422 receivers are built > to > reject "common-mode noise, which is noise that is of the same amplitude on > both the + and - terminals of the receiver. This is where the twisted > wire > pair comes in. It connects to the receiver's + and - terminals and brings > in both the real signal and common-mode noise. While the twisted-wire > pair > is shielded, some noise will leak in, but the electromagnetic and > electrostatic fields will cut across wires at the same amplitude, because > the wires are so close together. Thus, the noise's amplitude will appear > at > the receiver's + and - terminals equally and will be rejected by the > receiver, since it is designed to reject common-mode noise. As an > example, > the AM26LV32 is a commonly used differential line 3.3V receiver. It has a > common mode input voltage range from -0.3 to 5.5V and will reject any > voltage that appears on both terminals in this range. The voltages on its > terminals must have a delta of greater than 0.2V for it to change its > outputs. You probably have to be involved in the measurement of real > world > signals and problems to appreciate just how good the AM26LV32 works to > reject common-mode noise. One of the things that I haven't mentioned is > that the termination resistor not only serves to terminate the twisted > wire > pair's characteristic impedance but also provides a low impedance to > prevent > electrostatic and electromagnetic fields from developing high voltages in > twisted wire pairs. > > > So to reiterate, there is nothing magical about twisted wire pairs other > than they keep the wires in close proximity to each other and that's it. > Everything else I said above is just fluff! :) > > > Simon Ramirez > > Copyright 2008 > > > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Dennis > Johnson > Sent: Sunday, December 28, 2008 12:29 PM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Twisted Wires vs. Parallel > > > We often see instructions to twist the positive and negative wires > together > to reduce noise problems. Instructions from B&C for their voltage > regulator > even specified the number of twists per inch. > > > But I'm wondering about the physics. From studying the 'Connection, it > seems that paralleling the positive and negative wires tightly together > would have the same effect as twisting them together. Is twisting the > wires > together recommended because it is a convenient way to keep the wires in > close contact? Or is there something about the nature of the > electromagnetic fields that makes twisting more effective? > > > Thanks, > > Dennis > > Legacy, 220 hours, mostly twisted positive and negative wires > > -------------------------------------------------------------------------------- Checked by AVG - http://www.avg.com 9:40 AM ________________________________________________________________________________
Date: Dec 29, 2008
Stuart, I run a VHF, a smoke pump and a Garmin 296 plugged into a cigarette lighter outlet for power if required. All the rest are steam gauges, and the fuel pump is manual. Since most my trips are short aerobatics trips, the biggest consumer is the starter motor, and the SD-8 is more than adequate to keep the battery charged even if I do a series of 10 to 12 minute sorties. On longer trips the SD-8 has much longer to catch up, and it has never been an issue. This system, apart from the 296, has been in satisfactory operation since the early 80s. Sorry, no photos of that area, but the next 100 hourly is due late January, and if you still want photos then, I am more than happy to snap a few and send them off line to you. Cheers, John -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Stuart Mackereth Sent: Monday, 29 December 2008 6:03 PM Subject: RE: AeroElectric-List: Pitts S1 Wiring Diagram --> Great, thanks John. What line up do you run - VHF, XPDR, GPS, etc? Don't suppose you have a picture of the back for me to have a look at? Sorry, but now you got me started ;-) -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of John Cleary Sent: Monday, 29 December 2008 7:40 p.m. Subject: RE: AeroElectric-List: Pitts S1 Wiring Diagram --> Hello Stuart, I have an S1 with an SD-8, standard slick mags and an inverted oil system. It is tight but doable. Cheers, John -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Stuart Mackereth Sent: Monday, 29 December 2008 4:53 PM Subject: AeroElectric-List: Pitts S1 Wiring Diagram --> Hi all.. been trawling through all the posting history on this list looking for some help with what layout and equipment set make sense in the tight engine compartment of a Pitts S1. Sorry if any of this is repeat/old stuff, but it's all new to me. Thanks also to Bob who has given me many hours of enjoyment trying to get to grips with his manual, and Z figures. I started on Z13/8 and pulled out the 2nd big alternator in favor of a single small SD-8 one, and have gone from there. A Pitts should be rather simple, I would have thought. This is a VFR short-hop plane 99% of the time, doing aerobatics I had a good look at the aerobatic wiring diagram from B&C... so I had assumed I could get by on a SD-8 alternator as only electrical generation source. I have a Icom A200, Narco Xpdr, Encoder and the usual engine instruments (EGT, CHT, OILT, OILP, FUELP) so thought I could get away it. Um, ok, also a Fuel boost pump (only during starting) and smoke pump (couple of minutes a flight)... I also would like to run a AV80R GPS as well, if possible. Now I'm wondering about the SD-8... and if not, well, then the SD-20. I can add up all the Amp loads on each thing, but I'm not sure how much under/over capacity I need to run everything? Is there a general rule of thumb? My other question is whether there is enough space behind the engine for the vacuum mounted SD-8 - considering I'm planning dual PMAGS, and have an inverted OIL kit right there in the same place. A friend building an S1 that I talk to a lot as opted for the PlanePower 60Amp unit that is belt driven up front to free up some space, as he reckoned it was too tight. Would love a second opinion from someone with an S1. Most S1's flying out there are 20, 30 years old, even older, and I'm hoping someone can help me take advantage of the new technology advances to build a simple, clean and lightweight electrical system. Thanks to anyone who can help. Checked by AVG - http://www.avg.com 2:23 p.m. ________________________________________________________________________________
From: "Eric Tiethoff (HCCNet)" <j.e.tiethoff(at)hccnet.nl>
Date: Dec 29, 2008
When wiring a tube amplifier it is common practice to twist the filament lines to the tubes. Reason is that they are AC fed with a relative high amperages (6,3 volt and 2 or 3 amp). The rest of the wiring is or signal or DC. When the filament lines are NOT twisted they introduce humm (50 or 60 Hz) in the system. Since in an aircraftsystem there is no AC feed (except the output of the alternator field tot the regulator) the only usance is to keep the lines together. -------------------------------------------------- From: "raymondj" <raymondj(at)frontiernet.net> Sent: Monday, December 29, 2008 9:09 AM Subject: Re: AeroElectric-List: Twisted Wires vs. Parallel > > > I think this paragraph from Bob N. earlier this week bears on this > discussion. > > =============================================== > At higher frequencies it can be shown that parallel > lines do not exactly cancel mutual magnetic effects > because of the non-zero distance between their centers. > Here it becomes valuable to twist the two conductors > such that what ever leakage exists perpendicular > to the conductors tends to be washed out by the reverse > polarity of effects longitudinally displaced 1/2 twist > away. > ================================================ > > Raymond Julian > Kettle River, MN > > "Hope for the best, > but prepare for the worst." > > ----- Original Message ----- > From: "S. Ramirez" <simon(at)synchdes.com> > To: > Sent: Sunday, December 28, 2008 9:16 PM > Subject: RE: AeroElectric-List: Twisted Wires vs. Parallel > > >> Dennis, >> >> >> >> There is no difference electrically between two wires that are kept at >> the >> same distance in parallel and two wires that are twisted together to stay >> parallel. The reason they are twisted together is that it is the >> simplest >> way to keep them in parallel while the cable (a combination of wires, >> shields, insulation, etc.) bends and distorts. >> >> >> >> When an RS-422 transmitter generates a signal, it has two circuits that >> drive the twisted wire pair. One circuit sources current, while the >> other >> circuit sinks current. When a differential twist wire pair carries two >> currents from the transmitter to the receiver, they travel from the >> source >> driver to the load (a termination resistor next to the receiver), then >> back >> to the current sink. Along each wire, the current generates an >> electromagnetic field defined by the right hand rule, where the direction >> of >> the field is per the direction of the hand's fingers when the thumb is >> pointing toward the direction of current flow. Since the current in one >> wire is traveling opposite the current in the other wire, the fields >> oppose >> each other and ideally cancel each other out. They also ideally cause no >> noise to be radiated. >> >> >> >> Perhaps the greatest benefit of RS-422 and differential signaling is >> immunity from external noise in the receiver. RS-422 receivers are built >> to >> reject "common-mode noise, which is noise that is of the same amplitude >> on >> both the + and - terminals of the receiver. This is where the twisted >> wire >> pair comes in. It connects to the receiver's + and - terminals and >> brings >> in both the real signal and common-mode noise. While the twisted-wire >> pair >> is shielded, some noise will leak in, but the electromagnetic and >> electrostatic fields will cut across wires at the same amplitude, because >> the wires are so close together. Thus, the noise's amplitude will appear >> at >> the receiver's + and - terminals equally and will be rejected by the >> receiver, since it is designed to reject common-mode noise. As an >> example, >> the AM26LV32 is a commonly used differential line 3.3V receiver. It has >> a >> common mode input voltage range from -0.3 to 5.5V and will reject any >> voltage that appears on both terminals in this range. The voltages on >> its >> terminals must have a delta of greater than 0.2V for it to change its >> outputs. You probably have to be involved in the measurement of real >> world >> signals and problems to appreciate just how good the AM26LV32 works to >> reject common-mode noise. One of the things that I haven't mentioned is >> that the termination resistor not only serves to terminate the twisted >> wire >> pair's characteristic impedance but also provides a low impedance to >> prevent >> electrostatic and electromagnetic fields from developing high voltages in >> twisted wire pairs. >> >> >> >> So to reiterate, there is nothing magical about twisted wire pairs other >> than they keep the wires in close proximity to each other and that's it. >> Everything else I said above is just fluff! :) >> >> >> >> Simon Ramirez >> >> Copyright 2008 >> >> >> >> >> >> >> >> From: owner-aeroelectric-list-server(at)matronics.com >> [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Dennis >> Johnson >> Sent: Sunday, December 28, 2008 12:29 PM >> To: aeroelectric-list(at)matronics.com >> Subject: AeroElectric-List: Twisted Wires vs. Parallel >> >> >> >> We often see instructions to twist the positive and negative wires >> together >> to reduce noise problems. Instructions from B&C for their voltage >> regulator >> even specified the number of twists per inch. >> >> >> >> But I'm wondering about the physics. From studying the 'Connection, it >> seems that paralleling the positive and negative wires tightly together >> would have the same effect as twisting them together. Is twisting the >> wires >> together recommended because it is a convenient way to keep the wires in >> close contact? Or is there something about the nature of the >> electromagnetic fields that makes twisting more effective? >> >> >> >> Thanks, >> >> Dennis >> >> Legacy, 220 hours, mostly twisted positive and negative wires >> >> >> >> > > > -------------------------------------------------------------------------------- > > > Checked by AVG - http://www.avg.com > 9:40 AM > > > ________________________________________________________________________________
Date: Dec 29, 2008
Subject: SD-8 Relay Questions
All, I am in the process of making my drawings a reality and unpacked the SD-8 and its accompanying S-704. I have my S-704 wired up like in Z-13/8 and Z-32. From the diagrams it looks like power is supplied to the relay coil using an external wire attached from one end of the COIL to COM. Am I reading the diagram correctly? Does anyone have any pictures like those that show how S-704 DIODEs are inserted? Also, does it matter which way round YEL/BLK leads of the OVM-14 module are connected to the coil (the instructions that come with the SD-8 appear to show the opposite way round to that depicted in SD-13). Thanks for your help, Andrew Butler, Wiring RV71700 Galway, Ireland. ________________________________________________________________________________
Date: Dec 29, 2008
Subject: CBA-II Battery Tester modifications/improvements?
> > but from an engineering perspective, a numerical value for > > energy delivered under the prescribed test conditions is > > quite sufficient. The results of dynamic tests for evaluating > > battery source impedance could be offered out as numerical > > values. > >As someone involved heavily in engineering, I agree. >But you'll find a lot of very strong opposition to devices that only >output numerical values for later importing and graphing or for use >in creating a table. These all take extra work to do and is >considered a total PITA by those who don't revel in the numbers the way we do. > >In my opinion, the success of the CBA is in its software (and its >price, of course). It allows for very, very easy and no-work >testing and comparison of different cells. There are other devices >out there that allow for exporting to Excel or other saving of data, >but they aren't nearly as popular. > >As a first step, just storing the data for import into Excel is >OK. Even for taking and creating tables with. But, it would be >nice to see a growth path possible for the software to include >on-screen graphing/plotting. There are many constant-current load >circuits out there but they're not being built and used by very many >people, I think the right software is what would make the difference. I bought the devices when they offered a high return on investment for answering some questions about battery performance between brands and battery condition for insuring performance in a $high$ instrumentation job. Looking at all the data files in my CBA output folder I see that I've conducted perhaps 100 battery cap-checks on various devices. Even when I was doing cross brand comparisons, graphical display of data was useful only for helping my readers understand . . . it was of no value in deducing the results of the tests, i.e. total energy delivered under a particular test condition. I guess I'm not clear as to your design and market goals. If it's your desire to fabricate large quantities of a product to compete with the CBA-II then "window dressing" will be important. If you're goal is to offer a sort of DIY work-around for the CBA-II's shortcomings to be shared with some cognizant individuals, then the super-graphics features become problematic for return on investment. >Another option is one you alluded to earlier, a PIC. That would >result in a very small and inexpensive unit to control the load with >and acquire and upload the data from. Someone would have to develop >and test the firmware though. > >There's still a decent amount of hardware left to work out >though...PCB design and selection of the MOSFETs, op-amps, >resistor/capacitors, voltage regulators, microprocessor, connectors, >heat sink, fan, etc., for the load itself. Yes . . . if you're looking to optimize a product and marketing effort. I would estimate 30-40 hrs to work up a documentation package for hardware. Firmware in the PIC would take 10-20 hrs. The PC based application could take as long or longer than the hardware and firmware combined. So if your goals are to compete with the CBA-II in their sandbox, you're looking at a development program with a market value on the order of $10K before you manufacture and sell a single device. >I think you bring up a very good point. There will be two groups of >users for this load. The ones who just need the raw data outputted >in the simplest way possible and those who want it displayed in >graphical form to allow for the quickest way to see what they need to see. I'm not sure what a graph tells me that a number in an output box doesn't tell me. In fact, the way the early CBA-II software outputs graphics, one has to get out a pencil and straight edge to drop the cut-off crossing to the baseline and then visually do a linear interpolation to arrive at a number. The upscale version of the software give you the "box score" and the graph . . . what does the graph tell anyone that the box score does not? My disappointments with the CBA-II application is that it offers only constant-current discharge testing which doesn't emulate very many real life situations. After all the work has been done to achieve their present software package, it's a relatively simple addition to offer constant-resistance and constant- power discharge protocols with some dynamic internal impedance measurements thrown in for "frosting on the cake". Of course there's still the issue of marginal thermal performance and selection of load devices. No doubt West Mountain Radio has made a significant market penetration and their product offers a lot of bang for the buck. I own two of them! If you're considering development of a competing product, will the features you and I find useful convince future buyers of battery analyzers to pay more dollars for the offerings of the new kid on the block? More importantly, do potential sales for the super-whizzy product bode well for return on investment? Bob . . . ________________________________________________________________________________
Subject: Re: D-Sub Pins
Date: Dec 29, 2008
Henry, I too use them for various connection points, especially those that may need to be separated at some point. They are indeed handy. Rather than get into some fancy connector I butt the male/female pins together, shrink wrap the whole mess - done. Make sure your shrink wrap is well done so they don't pull apart. If you need to take them apart use a p blade or other against the connector to remove the shrink wrap. Don't touch the wire with the knife. If you have a connection that needs to come apart regularly, just go to RS and get two 9/15 pin connectors to join the two. You will need two 4/40 bolt/nuts to keep the DB connectors together. Use a bit of lock-tite or epoxy on bolts to keep them from separating. The only thing you need to obey are the amperage limits on the pins. The rest is up to your imagination. If you're always in a hurry like me, get your stuff from L-com. Great prices, incredible service (get your own rep if you like) and very fast shipping. I get most stuff within a day or two of ordering. They will also make any custom cable you need. http://www.l-com.com/ Glenn -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Henry Trzeciakowski Sent: Saturday, December 27, 2008 7:56 PM Subject: AeroElectric-List: Re: D-Sub Pins Bob: Looking thru your archives, I see that one can use D-Sub's are wiring connections: I.E. - joining 2 wires together, rather than use butt splices, solder seal, etc.... So my question is: 1- Rather than soldering my Mic & Phone jack wires directly to my jack outlets, can I solder leads, then use D-Sub pins to join to the leads to the amin wires? 2- Can I also use these D-Subs for splicing shielded wire: 22 awg wire? I can see al lot of uses for these D-subs, amazing !!! Henry ________________________________________________________________________________
Date: Dec 29, 2008
Please how do I remove this email from receiving informative notes like the ones below? thanks Steven Lynn Global Business Services IBM Americas Cell: 425-280-4404 Fax: 360-851-2211 sglynn(at)us.ibm.com "raymondj" To Sent by: owner-aeroelectri cc c-list-server@mat ronics.com Subj ect Re: AeroElectric-List: Twisted Wires vs. Parallel 12/29/2008 12:09 AM Please respond to aeroelectric-list @matronics.com I think this paragraph from Bob N. earlier this week bears on this discussion. ======================== ======================== At higher frequencies it can be shown that parallel lines do not exactly cancel mutual magnetic effects because of the non-zero distance between their centers. Here it becomes valuable to twist the two conductors such that what ever leakage exists perpendicular to the conductors tends to be washed out by the reverse polarity of effects longitudinally displaced 1/2 twist away. ======================== ======================== Raymond Julian Kettle River, MN "Hope for the best, but prepare for the worst." ----- Original Message ----- From: "S. Ramirez" <simon(at)synchdes.com> Sent: Sunday, December 28, 2008 9:16 PM Subject: RE: AeroElectric-List: Twisted Wires vs. Parallel > Dennis, > > > There is no difference electrically between two wires that are kept a t the > same distance in parallel and two wires that are twisted together to stay > parallel. The reason they are twisted together is that it is the simplest > way to keep them in parallel while the cable (a combination of wires, > shields, insulation, etc.) bends and distorts. > > > When an RS-422 transmitter generates a signal, it has two circuits th at > drive the twisted wire pair. One circuit sources current, while the other > circuit sinks current. When a differential twist wire pair carries t wo > currents from the transmitter to the receiver, they travel from the source > driver to the load (a termination resistor next to the receiver), the n > back > to the current sink. Along each wire, the current generates an > electromagnetic field defined by the right hand rule, where the direc tion > of > the field is per the direction of the hand's fingers when the thumb i s > pointing toward the direction of current flow. Since the current in one > wire is traveling opposite the current in the other wire, the fields > oppose > each other and ideally cancel each other out. They also ideally caus e no > noise to be radiated. > > > Perhaps the greatest benefit of RS-422 and differential signaling is > immunity from external noise in the receiver. RS-422 receivers are b uilt > to > reject "common-mode noise, which is noise that is of the same amplitu de on > both the + and - terminals of the receiver. This is where the twiste d > wire > pair comes in. It connects to the receiver's + and - terminals and brings > in both the real signal and common-mode noise. While the twisted-wir e > pair > is shielded, some noise will leak in, but the electromagnetic and > electrostatic fields will cut across wires at the same amplitude, bec ause > the wires are so close together. Thus, the noise's amplitude will ap pear > at > the receiver's + and - terminals equally and will be rejected by the > receiver, since it is designed to reject common-mode noise. As an > example, > the AM26LV32 is a commonly used differential line 3.3V receiver. It has a > common mode input voltage range from -0.3 to 5.5V and will reject any > voltage that appears on both terminals in this range. The voltages o n its > terminals must have a delta of greater than 0.2V for it to change its > outputs. You probably have to be involved in the measurement of real > world > signals and problems to appreciate just how good the AM26LV32 works t o > reject common-mode noise. One of the things that I haven't mentioned is > that the termination resistor not only serves to terminate the twiste d > wire > pair's characteristic impedance but also provides a low impedance to > prevent > electrostatic and electromagnetic fields from developing high voltage s in > twisted wire pairs. > > > So to reiterate, there is nothing magical about twisted wire pairs ot her > than they keep the wires in close proximity to each other and that's it. > Everything else I said above is just fluff! :) > > > Simon Ramirez > > Copyright 2008 > > > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of De nnis > Johnson > Sent: Sunday, December 28, 2008 12:29 PM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Twisted Wires vs. Parallel > > > We often see instructions to twist the positive and negative wires > together > to reduce noise problems. Instructions from B&C for their voltage > regulator > even specified the number of twists per inch. > > > But I'm wondering about the physics. From studying the 'Connection, it > seems that paralleling the positive and negative wires tightly togeth er > would have the same effect as twisting them together. Is twisting th e > wires > together recommended because it is a convenient way to keep the wires in > close contact? Or is there something about the nature of the > electromagnetic fields that makes twisting more effective? > > > Thanks, > > Dennis > > Legacy, 220 hours, mostly twisted positive and negative wires > > ----------------------------------------------------------------------- --------- Checked by AVG - http://www.avg.com 9:40 AM ======================== ============ ======================== ============ ======================== ============ ======================== ============ ________________________________________________________________________________
Date: Dec 29, 2008
nuckolls.bob(at)aeroelect wrote: > I bought the devices when they offered a high > return on investment for answering some questions > about battery performance between brands and > battery condition for insuring performance in a > $high$ instrumentation job. Looking at all the > data files in my CBA output folder I see that I've > conducted perhaps 100 battery cap-checks on various > devices. > > Even when I was doing cross brand comparisons, > graphical display of data was useful only for helping > my readers understand . . . it was of no value in > deducing the results of the tests, i.e. total energy > delivered under a particular test condition. > > I guess I'm not clear as to your design and market > goals. If it's your desire to fabricate large > quantities of a product to compete with the CBA-II > then "window dressing" will be important. If you're > goal is to offer a sort of DIY work-around for > the CBA-II's shortcomings to be shared with some > cognizant individuals, then the super-graphics > features become problematic for return on investment. > You mention it three times in your post so I want to be clear, I'm not interested in designing a product to compete with the CBA. I create high-power loads for dischargers/cyclers/analyzers/testers. I don't want the ultra price-sensitive "low" end of the market. But, if this project moved forward, I would offer to lay out a PCB that others could use for building the load. If enough people were interested, I'd have a batch of boards run and offer them at my cost. Each person involved would contribute to the project where they can, and for me, it's the hardware. I'm just bringing up other thoughts about the possible feature set for a very good DIY project. You want just raw data and feel it offers the most and that graphics offer little, if nothing, compared to box-scored raw data. But many users of battery analyzers disagree. I have to keep going back to the CBA and its popularity. A lot of people don't care what the actual number is. They can look at a graph of a test involving several cells or packs and see instantly which lasted the longest, or had the highest voltage-under-load, for that test. Whether the "best-performing" battery had a capacity of 10.02Ah or 10.10Ah, they wouldn't care. Which battery that they can afford (or physically fit, etc,) came out on "top". No need to check or compare actual numbers. But, we should definitely have just a raw data-capture and store program. In fact, it should be the first thing developed as it's the easiest to do. But I feel strongly that we shouldn't design out the ability of someone to do a more graphics-oriented package. It makes the project more desirable for more people and that's important to help draw other designers and developers to the project. This results in better, less expensive designs for those who want to DIY the hardware, and easier to use and fuller-featured software. Hopefully not with useless bloat but with great stuff like various discharge modes, IR measurement, etc. Never at the expense of a really good, very basic, data capture hardware design and software program. Just as other options for an open-source project that should encourage anyone to contribute to. Whether we'd ever use that hardware or software or not. nuckolls.bob(at)aeroelect wrote: > > Yes . . . if you're looking to optimize a > product and marketing effort. I would estimate > 30-40 hrs to work up a documentation package > for hardware. Firmware in the PIC would take > 10-20 hrs. The PC based application could take > as long or longer than the hardware and firmware > combined. So if your goals are to compete with > the CBA-II in their sandbox, you're looking at > a development program with a market value on > the order of $10K before you manufacture and > sell a single device. > No marketing effort, no product development. This is an open-source DIY project. You mentioned the use of a PIC earlier and I was alluding to that. If that's no longer an idea you're interested in seeing possibly be used for this DIY project, then the Weeder modules (or other equivalent) are a quicker way to get going. You also mentioned a friend who might possibly, maybe, be interested in taking on the PC software development. No $10K to develop something great that everyone could use. As a open-source project, anyone who wants to contribute, can. Whether its integrating existing I/O boards, creating an integrated PIC board, writing data storage PC software or creating a full-blown graphics package (which will certainly do the raw data storage), I think there's room for someone who wants to do any of the above. We'd all just use the software/hardware that best matched our needs and wants. nuckolls.bob(at)aeroelect wrote: > > I'm not sure what a graph tells me that a number > in an output box doesn't tell me. In fact, the way > the early CBA-II software outputs graphics, one has > to get out a pencil and straight edge to drop the cut-off > crossing to the baseline and then visually do a > linear interpolation to arrive at a number. The > upscale version of the software give you the "box > score" and the graph . . . what does the graph tell > anyone that the box score does not? > > My disappointments with the CBA-II application is that > it offers only constant-current discharge testing > which doesn't emulate very many real life situations. > After all the work has been done to achieve their > present software package, it's a relatively simple > addition to offer constant-resistance and constant- > power discharge protocols with some dynamic internal > impedance measurements thrown in for "frosting on > the cake". Of course there's still the issue of > marginal thermal performance and selection of load > devices. > > No doubt West Mountain Radio has made a significant > market penetration and their product offers a lot > of bang for the buck. I own two of them! If you're > considering development of a competing product, will > the features you and I find useful convince future > buyers of battery analyzers to pay more dollars for > the offerings of the new kid on the block? More > importantly, do potential sales for the super-whizzy > product bode well for return on investment? > > Bob . . . A graph doesn't tell you anything a number doesn't. But, the right graph can make understanding various numbers, groups of numbers, and their relationships, easier to understand. Edward Tufte's books so wonderfully illustrate that. What's great about this project is that everyone can get exactly what they want. One person can create a bare-bones, tiny-footprint, data uploading and storage program. Another person can create a graphics-analysis package to show tons of data in easy to read graphs. One person could develop hardware that integrated existing products, another could create a custom PIC board. I think a really important part of al of this would be to create a set of standards for comms between the PC software and the boards, and for a data storage format. This would allow for easy "black-box" development of both the hardware and the software. Either could have any set of features but all would be compatible with each other. I agree with you on the lack of discharge profiles for the CBA. They do have a constant-power discharge option in the Pro software now though. It would be nice to see constant-current, constant-power, and constant-resistance "modes" in the open-source hardware/software. Also nice would be allowing the user to be able to create or select a "profile" for discharging. Whether it's just a burst of current for a while every minute, or a complex profile to recreate a "real world" usage scenario, I think it would offer a lot. And the IR measurements feature is a great idea. There are so many "standards" and methods for measuring IR that it would be great to see the hardware/software eventually support a user-created IR test (timing, current, etc.). We're starting to get into the meat of this...good stuff. :) -------- John M. Owner CamLight Systems Read this topic online here: http://forums.matronics.com/viewtopic.php?p=221696#221696 ________________________________________________________________________________
Subject: Re: Twisted Wires vs. Parallel
Date: Dec 29, 2008
Yes and yes, John. Untwisted pair cables suffer from more crosstalk and are more susceptible to interference because during their run, they tend to be farther apart in places than their twisted pair counterparts. Per my earlier post, when an electromagnetic or electrostatic field crosses their path and induces a current or voltage into them, it will be a different in each wire because they are at different relative distances from the source wire, which is probably running parallel but not necessarily. Then the common-mode receiver will not be able to reject this noise as effectively as if the noise at its two terminals were more "equal." Also, if a differential transmitter is generating + and - currents through the two non-twisted wires, they will not cancel each other out as effectively as their twisted wire counterparts, because they will be farther apart in places, and their electromagnetic fields will not be mutually inductively coupled into each other as well along the wires' runs. Furthermore, it is easier to maintain characteristic impedances more accurately when the wires are twisted together and their distances apart are more accurately maintained. By providing a termination resistor at the receiving end of the twisted wire pair, reflections are more carefully controlled, if not cancelled. For this reason and for the reasons cited above, longer runs are possible with twisted wire pairs than with untwisted wire pairs. BTW, the same theory that applies to keeping the distances equal between wires in twisted wire pairs also is used in printed circuit boards to propagate signals along traces. There the traces are geometrically controlled so that their widths and distances from each other and from other traces, ground and power planes are maintained, as well as the separation material, to do a much better job than wires in cables, especially in Gigabit applications. Simon Ramirez Copyright 2008 -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of CamLight Sent: Monday, December 29, 2008 2:34 AM Subject: AeroElectric-List: Re: Twisted Wires vs. Parallel simon(at)synchdes.com wrote: > There is no difference electrically between two wires that are kept at the same distance in parallel and two wires that are twisted together to stay parallel. The reason they are twisted together is that it is the simplest way to keep them in parallel while the cable (a combination of wires, shields, insulation, etc.) bends and distorts. But don't pairs in untwisted pair cabling suffer from more crosstalk and susceptibility to interference than in twisted-pair cabling? And, IIRC, can't you do a longer run with twisted-pair than with untwisted-pair cable? -------- John M. Owner CamLight Systems ________________________________________________________________________________
Date: Dec 30, 2008
Subject: Brass is not a very good conductor
Figured would share with the group at just how poor a conductor brass is. According to: http://www.kp44.org/ftp/ElectricalConductivityOfMaterials.php Brass only has ~ 28% the conductivity of copper. (They don't get as specific as alloy types) I need to somehow wire my port headrest (negative) to my starboard headrest. Shortest distance is direct between headrests but using a traditional wire will be unsightly and make for harder interior install. It needs to carry enough current to allow an occasional jump start. Since Ace hardware sells .032" thick brass 1" wide (alloy 260), I was going to use that and trim it to .75" wide until I researched just how poor a conductor brass is. Could double the thickness and double the width, but that would make for more weight and harder interior install. Anyway, going to use .75" wide by .032" thick copper alloy 110 and glass it in place with one thin layer of 3/4 oz model aeroplane cloth. Ron Parigoris ________________________________________________________________________________
Subject: EI Altitude Clock Mod
Date: Dec 30, 2008
Ok all you electronics warriors out there, here's a good one: Electronics International designed and markets a pretty nifty-looking aircraft clock called the ASC-5A. One of the nifty things about it is that it is more than just a clock - it's also an altitude alerter. Put in your MDA and your speed-based approach time, and you'll get an LED indication on the face of the instrument telling you that you have arrived either at your altitude or your time. It even has an external-warning capability that, when paired with a tone or voice generator, can send alerts to your headset. But here's the rub: it only has ONE external-warning wire, so regardless of whether it is a timer alert or an altitude alert, it goes out over this one wire (and in the same way, probably as a ground). As a result, when your headset alert sounds on a VOR approach, you must obtain additional input (i.e., you need to look at the face of the clock or your altimeter) to determine whether it is because you have reached the MDA and you need to level off or because you have exhausted your time and need to execute a missed approach. So, internally the unit can differentiate between altitude events and timer events because it lights different LEDs on the face of the instrument for these different events, but EI didn't extend that basic capability to the external-warning feature sticking out the back of the instrument. What were they thinking? At this point, it seems like a simple matter to tap into the light circuits that activate the LEDs on the front of the instrument, extend some wires from those taps out the back, hook up a tone or voice generator, and receive separate signals in your headset for time and altitude alerts. But I don't want to open mine up without first getting some feedback. Ok, I soldered once and it didn't turn out well, so I'm reluctant to tear into my ~$500 instrument without lots of encouragement (I've learned that things that begin with, "Honey, watch this!" often don't turn out well. . .)! Any thoughts? Thanks, Don ________________________________________________________________________________
Date: Dec 30, 2008
Subject: EI SC-5 clock doc error
The previous post inspired me to share this recent discovery. The EI SC-5 clock includes a non-resettable total engine time counter, essentially a Hobbes function. The manual says that in a 12V system, the ORANGE wire should be connected via an N.O. oil pressure switch to provide +12V on closure, when oil pressure develops, which will start the engine timer. This is a little tricky with the B&P oil presure switch, where the N.O. contact is normally grounded -- I even set up a little relay to power the wire that way -- but don't bother. Contrary to the manual, any time the RED +12V main supply wire is hot, the engine timer runs, regardless of what's is or isn't happening on the ORANGE wire. For example, if you're running the panel on ground power, perhaps for training or maintenance, or just entering a flight plan into the GPS before engine start, the engine timer will be ticking up, even though the engine isn't running. (The clock is supposed to be wired to a main bus or e-bus, so it's going to be ON when most anything on the panel is on.) Incidentally, the manual also says that in a 12V system, the BROWN wire should _not_ be connected to anything. After considerable consultation with EI, it was confirmed that the ORANGE wire is at best superfluous to the engine timer function (or any function as far as I could determine) and the BROWN wire is what must be used to control the engine timer. The BROWN wire should be grounded when the engine is OFF, i.e., wired through a N.C. contact on a B&C pressure switch, in parallel with the oil pressure warning light. When the BROWN wire's connection to ground is broken, on engine start, the engine timer begins. So, what the manual says to do doesn't work, and what the manual says not to do is what you have to do to make it work. I suggested to EI that they should at least fix the manual, but they did not indicate any eagerness to do so. Hopefully, this work around will be useful others. Otherwise, it's a nice clock. Ron ________________________________________________________________________________
Date: Dec 30, 2008
In electronics all things are possible, Don (well, almost {:>)). The feasibility of doing what you suggest is certainly conceptually simple; however, it depends quite a bit on what format the electronics have taken. If there are isolated wires running from a board to a couple of LED holders then that would probably be fairly simply provided you take care not to overload load the LED circuit. I would put in some sort of isolation barrier - such as an Ops amp - perhaps an Ops amp circuit with a tone generator designed in. However, if the LED's are an integrated part of a printed circuit board - then while still conceptually feasible, you need someone who knows how to modify a board (probably with surface mount components) - a person with the right skills and experience could do it - but, where do you find him? I certainly would hesitate to let just anyone wearing a hat with a lightening bolt through it tackle it. If you can do it without damage to the unit, you might open it up and take a peek. If it looks like wires to the LEDs, then you might consider proceeding further - if it looks like the LED's are an integrated part of a print circuit board, I think I would just button it back up. I agree with you that one would have thought the designer/manufacture would have considered the advantages of a dual audio alarm. Good luck Ed Ed Anderson Rv-6A N494BW Rotary Powered Matthews, NC eanderson(at)carolina.rr.com <http://www.andersonee.com/> http://www.andersonee.com <http://members.cox.net/rogersda/rotary/configs.htm> http://members.cox.net/rogersda/rotary/configs.htm#N494BW <http://www.dmack.net/mazda/index.html> http://www.dmack.net/mazda/index.html _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Don Curry Sent: Tuesday, December 30, 2008 3:45 PM Subject: AeroElectric-List: EI Altitude Clock Mod Ok all you electronics warriors out there, here's a good one: Electronics International designed and markets a pretty nifty-looking aircraft clock called the ASC-5A. One of the nifty things about it is that it is more than just a clock - it's also an altitude alerter. Put in your MDA and your speed-based approach time, and you'll get an LED indication on the face of the instrument telling you that you have arrived either at your altitude or your time. It even has an external-warning capability that, when paired with a tone or voice generator, can send alerts to your headset. But here's the rub: it only has ONE external-warning wire, so regardless of whether it is a timer alert or an altitude alert, it goes out over this one wire (and in the same way, probably as a ground). As a result, when your headset alert sounds on a VOR approach, you must obtain additional input (i.e., you need to look at the face of the clock or your altimeter) to determine whether it is because you have reached the MDA and you need to level off or because you have exhausted your time and need to execute a missed approach. So, internally the unit can differentiate between altitude events and timer events because it lights different LEDs on the face of the instrument for these different events, but EI didn't extend that basic capability to the external-warning feature sticking out the back of the instrument. What were they thinking? At this point, it seems like a simple matter to tap into the light circuits that activate the LEDs on the front of the instrument, extend some wires from those taps out the back, hook up a tone or voice generator, and receive separate signals in your headset for time and altitude alerts. But I don't want to open mine up without first getting some feedback. Ok, I soldered once and it didn't turn out well, so I'm reluctant to tear into my ~$500 instrument without lots of encouragement (I've learned that things that begin with, "Honey, watch this!" often don't turn out well. . .)! Any thoughts? Thanks, Don __________ Information from ESET NOD32 Antivirus, version of virus signature database 3267 (20080714) __________ The message was checked by ESET NOD32 Antivirus. ________________________________________________________________________________
Date: Dec 31, 2008
Subject: Re: Brass is not a very good conductor
Date: Dec 30, 2008
Ron, there has been some discussion on this in the past, and there were questions about sourcing copper bus bar material. Van's Aircraft sells bass strips for this purpose, or you can flatten a copper pipe and use it. I replaced the brass buss-bars on my RV-9A prior to completion after doing a voltage drop analysis through the system. Probably would not make a significant difference, but if you have a choice, use copper. Vern Little Vx Aviation www.vx-aviation.com ----- Original Message ----- From: <rparigor(at)SUFFOLK.LIB.NY.US> Sent: Tuesday, December 30, 2008 12:09 PM Subject: AeroElectric-List: Brass is not a very good conductor Figured would share with the group at just how poor a conductor brass is. According to: http://www.kp44.org/ftp/ElectricalConductivityOfMaterials.php Brass only has ~ 28% the conductivity of copper. (They don't get as specific as alloy types) I need to somehow wire my port headrest (negative) to my starboard headrest. Shortest distance is direct between headrests but using a traditional wire will be unsightly and make for harder interior install. It needs to carry enough current to allow an occasional jump start. Since Ace hardware sells .032" thick brass 1" wide (alloy 260), I was going to use that and trim it to .75" wide until I researched just how poor a conductor brass is. Could double the thickness and double the width, but that would make for more weight and harder interior install. Anyway, going to use .75" wide by .032" thick copper alloy 110 and glass it in place with one thin layer of 3/4 oz model aeroplane cloth. Ron Parigoris ________________________________________________________________________________
Date: Dec 30, 2008
THANK YOU. I AM INSTALLING THAT SAME CLOCK AS WE SPEAK. MUCH APPRECIATED! JIM BOWEN Date: Tue=2C 30 Dec 2008 13:28:13 -0800From: rshannon(at)CRUZCOM.COMTo: aeroel ectric-list(at)matronics.comSubject: AeroElectric-List: EI SC-5 clock doc erro rThe previous post inspired me to share this recent discovery.The EI SC-5 c lock includes a non-resettable total engine time counter=2C essentially a H obbes function. The manual says that in a 12V system=2C the ORANGE wire sho uld be connected via an N.O. oil pressure switch to provide +12V on closure =2C when oil pressure develops=2C which will start the engine timer. This i s a little tricky with the B&P oil presure switch=2C where the N.O. contact is normally grounded -- I even set up a little relay to power the wire tha t way -- but don't bother. Contrary to the manual=2C any time the RED +12V main supply wire is hot=2C the engine timer runs=2C regardless of what's is or isn't happening on the ORANGE wire. For example=2C if you're running th e panel on ground power=2C perhaps for training or maintenance=2C or just e ntering a flight plan into the GPS before engine start=2C the engine timer will be ticking up=2C even though the engine isn't running. (The clock is s upposed to be wired to a main bus or e-bus=2C so it's going to be ON when m ost anything on the panel is on.) Incidentally=2C the manual also says that in a 12V system=2C the BROWN wire should _not_ be connected to anything.Af ter considerable consultation with EI=2C it was confirmed that the ORANGE w ire is at best superfluous to the engine timer function (or any function as far as I could determine) and the BROWN wire is what must be used to contr ol the engine timer. The BROWN wire should be grounded when the engine is O FF=2C i.e.=2C wired through a N.C. contact on a B&C pressure switch=2C in p arallel with the oil pressure warning light. When the BROWN wire's connecti on to ground is broken=2C on engine start=2C the engine timer begins.So=2C what the manual says to do doesn't work=2C and what the manual says not to do is what you have to do to make it work. I suggested to EI that they shou ld at least fix the manual=2C but they did not indicate any eagerness to do so. Hopefully=2C this work around will be useful others.Otherwise=2C it's a nice clock.Ron ________________________________________________________________________________
Date: Dec 30, 2008
Don, I looked at the ASC-5A Operating Instructions and saw a picture of its front panel. I am willing to bet that all of those LEDs, the LCD and the switches are connected directly to a printed circuit board. You can verify this for us by opening the unit and looking at it. Obviously, you do this at your own risk. Regardless of whether they are connected by wire or printed circuit board, you can connect to these LEDs by wire. All you have to do is solder wires to the solder points. I'd suggest that you have this done by a person known as an "assembler" in the electronics world. I've seen too many engineers who think they know how to solder, only to destroy a board by applying too much heat, too little heat, too much solder, not cleaning flux off the board, etc. A poor solder job usually results in a failure in our vibration environment. Typically, an LED will be turned on by a driver going low at its cathode. This causes it to sink current through the LED. The LED's anode is connected to the voltage source through a current limiting resistor. When the LED is turned off, the driver will be in the tri-state mode, thus causing only leakage current to flow through the LED. Therefore, when turned on, the LED's cathode will be low, and when turned off, the LED's cathode will be high. What "low" and "high" is depends on the driver and voltage source used. Since a low most likely is the active state (you can verify this), it is not good enough by itself to generate a tone. This means that you will use it as a gating signal to generate such a tone. Someone earlier suggested that you will have to use op amps to isolate these two signals so that they don't interfere with the LEDs' operation. I would suggest keeping it in the digital world and using an appropriate driver that also has a high input impedance. In either case, you are now faced with bringing out one or two ground wire(s) with these two wires and running all wires to wherever you are taking them to, because you will need a reference ground where you are going. I will suggest that you write me directly after you find out what's inside your ASC-5A if you are really serious about this project. There are several details that need to be known to find the best course of action, and only the owner can determine these details. Simon Ramirez Copyright 2008 From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Don Curry Sent: Tuesday, December 30, 2008 3:45 PM Subject: AeroElectric-List: EI Altitude Clock Mod Ok all you electronics warriors out there, here's a good one: Electronics International designed and markets a pretty nifty-looking aircraft clock called the ASC-5A. One of the nifty things about it is that it is more than just a clock - it's also an altitude alerter. Put in your MDA and your speed-based approach time, and you'll get an LED indication on the face of the instrument telling you that you have arrived either at your altitude or your time. It even has an external-warning capability that, when paired with a tone or voice generator, can send alerts to your headset. But here's the rub: it only has ONE external-warning wire, so regardless of whether it is a timer alert or an altitude alert, it goes out over this one wire (and in the same way, probably as a ground). As a result, when your headset alert sounds on a VOR approach, you must obtain additional input (i.e., you need to look at the face of the clock or your altimeter) to determine whether it is because you have reached the MDA and you need to level off or because you have exhausted your time and need to execute a missed approach. So, internally the unit can differentiate between altitude events and timer events because it lights different LEDs on the face of the instrument for these different events, but EI didn't extend that basic capability to the external-warning feature sticking out the back of the instrument. What were they thinking? At this point, it seems like a simple matter to tap into the light circuits that activate the LEDs on the front of the instrument, extend some wires from those taps out the back, hook up a tone or voice generator, and receive separate signals in your headset for time and altitude alerts. But I don't want to open mine up without first getting some feedback. Ok, I soldered once and it didn't turn out well, so I'm reluctant to tear into my ~$500 instrument without lots of encouragement (I've learned that things that begin with, "Honey, watch this!" often don't turn out well. . .)! Any thoughts? Thanks, Don ________________________________________________________________________________
Date: Dec 30, 2008
Same here. I've got one on the bench waiting on a convenient time to install. Good and very timely info. Thanks. Regards, Greg Young _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of JAMES BOWEN Sent: Tuesday, December 30, 2008 7:41 PM Subject: RE: AeroElectric-List: EI SC-5 clock doc error THANK YOU. I AM INSTALLING THAT SAME CLOCK AS WE SPEAK. MUCH APPRECIATED! JIM BOWEN _____ Date: Tue, 30 Dec 2008 13:28:13 -0800 From: rshannon(at)CRUZCOM.COM Subject: AeroElectric-List: EI SC-5 clock doc error The previous post inspired me to share this recent discovery. The EI SC-5 clock includes a non-resettable total engine time counter, essentially a Hobbes function. The manual says that in a 12V system, the ORANGE wire should be connected via an N.O. oil pressure switch to provide +12V on closure, when oil pressure develops, which will start the engine timer. This is a little tricky with the B&P oil presure switch, where the N.O. contact is normally grounded -- I even set up a little relay to power the wire that way -- but don't bother. Contrary to the manual, any time the RED +12V main supply wire is hot, the engine timer runs, regardless of what's is or isn't happening on the ORANGE wire. For example, if you're running the panel on ground power, perhaps for training or maintenance, or just entering a flight plan into the GPS before engine start, the engine timer will be ticking up, even though the engine isn't running. (The clock is supposed to be wired to a main bus or e-bus, so it's going to be ON when most anything on the panel is on.) Incidentally, the manual also says that in a 12V system, the BROWN wire should _not_ be connected to anything. After considerable consultation with EI, it was confirmed that the ORANGE wire is at best superfluous to the engine timer function (or any function as far as I could determine) and the BROWN wire is what must be used to control the engine timer. The BROWN wire should be grounded when the engine is OFF, i.e., wired through a N.C. contact on a B&C pressure switch, in parallel with the oil pressure warning light. When the BROWN wire's connection to ground is broken, on engine start, the engine timer begins. So, what the manual says to do doesn't work, and what the manual says not to do is what you have to do to make it work. I suggested to EI that they should at least fix the manual, but they did not indicate any eagerness to do so. Hopefully, this work around will be useful others. Otherwise, it's a nice clock. Ron ________________________________________________________________________________
Date: Dec 31, 2008
Subject: Power Supply - Anode/Cathode
Hello, I have no clue how to determine which is which. Can someone help? I have an electronic meter. I bought a low rate power supply some time back to use to power non polarity sensitive flap motors and the like. I cut off the attached 12V socket connector and attached crocodile clips. I didn't take note which wire was anode or cathode. Now I want to use it to power some of my avionics for testing etc. They are polarity sensitive. Thanks, Andrew. ________________________________________________________________________________
Date: Dec 31, 2008
Subject: Re: Power Supply - Anode/Cathode
Andrew, I hope I'm understanding what you are asking. To review: you have a power supply that has unmarked terminals, and you have a digital multi-meter or maybe just a DVM. You want to know how to determine - with the meter - the polarity of your power supply? Your meter should have a black probe and a red probe. With the red probe's lead plugged into the Volt/Ohm jack and the black probe's lead plugged into the "COMmon" jack, and the range set to, say, 50vDC, attach your power supply's alligator clamps to your probes. If the reading is negative, then your probes are cross-wired, so the clip on the black probe is the B+. If the reading is not negative, then the leads are connected correctly and the clip on the red lead is the B+. Have some red electrical tape handy to mark your power supply's B+ lead. Replace, when convenient, with red heat shrink. HTH, Dale R COZY MkIV #0497 Mesa, AZ Andrew Butler wrote: > Hello, > > I have no clue how to determine which is which. Can someone help? I > have an electronic meter. > > I bought a low rate power supply some time back to use to power non > polarity sensitive flap motors and the like. I cut off the attached > 12V socket connector and attached crocodile clips. I didn't take note > which wire was anode or cathode. > > Now I want to use it to power some of my avionics for testing etc. > They are polarity sensitive. > > Thanks, ________________________________________________________________________________
Date: Dec 31, 2008
Andrew, If I understand your question correctly, the answer is an easy one.? Use a mulitmeter.? If you have the wrong polarity, it will peg negative.? If you have it right, it will show 12V. Jay in Dallas -----Original Message----- From: Andrew Butler <andrewbutler(at)ireland.com> Sent: Wed, 31 Dec 2008 4:49 am Subject: AeroElectric-List: Power Supply - Anode/Cathode Hello, I have no clue how to determine which is which. Can someone help? I have an electronic meter. I bought a low rate power supply some time back to use to power non polarity sensitive flap motors and the like. I cut off the attached 12V socket connector and attached crocodile clips. I didn't take note which wire was anode or cathode. Now I want to use it to power some of my avionics for testing etc. They are polarity sensitive. Thanks, Andrew. ________________________________________________________________________ Email message sent from CompuServe - visit us today at http://www.cs.com ________________________________________________________________________________
Subject: Audio noise revisited
Date: Dec 31, 2008
To noise specialists I just concluded the installation of my Intercom, and although I took all the recommended measures to avoid ground loops and noise in general, I'm still hearing 2 whines, which after some time (many hours . :-)) of investigation, I think I identified the causes. One is the Air/Fuel Ratio Monitor, because when I disconnect its ground wire, the most high-frequency whine disappears. Which kind of filter (resistor, capacitor, diode, any other) can I install to eliminate this noise? And should I put it in the power(+) red wire or the ground(-) black wire, or is it indifferent? The other whine is from the COMM Radio (Garmin SL-30), because when I switch it off, the whine disappears. How shall I eliminate this noise? Thanks in advance Carlos ________________________________________________________________________________
Date: Dec 31, 2008
McMaster-Carr (http://www.mcmaster.com/) has copper bar that you can order from them. I wanted a piece of 1/8" thick 1/2" wide bar, and found it as part number 8964K291. The downside? It was 3 feet long and cost $13. *sigh* As you might guess, I have quite a bit left if anyone wants to buy some off of me. :) On the other hand, it made for a really nice/neat/attractive set of connections between my master and starter contactors, as well as to my ammeter shunt. -- Dwight On Tue Dec 30 20:28:49 2008, Vern Little wrote : > >Ron, there has been some discussion on this in the past, and there were >questions about sourcing copper bus bar material. > >Van's Aircraft sells bass strips for this purpose, or you can flatten a >copper pipe and use it. > >I replaced the brass buss-bars on my RV-9A prior to completion after doing a >voltage drop analysis through the system. > >Probably would not make a significant difference, but if you have a choice, >use copper. > >Vern Little >Vx Aviation >www.vx-aviation.com >----- Original Message ----- >From: <rparigor(at)SUFFOLK.LIB.NY.US> >To: >Sent: Tuesday, December 30, 2008 12:09 PM >Subject: AeroElectric-List: Brass is not a very good conductor > > >Figured would share with the group at just how poor a conductor brass is. > >According to: >http://www.kp44.org/ftp/ElectricalConductivityOfMaterials.php > >Brass only has ~ 28% the conductivity of copper. (They don't get as >specific as alloy types) > >I need to somehow wire my port headrest (negative) to my starboard >headrest. Shortest distance is direct between headrests but using a >traditional wire will be unsightly and make for harder interior install. >It needs to carry enough current to allow an occasional jump start. > >Since Ace hardware sells .032" thick brass 1" wide (alloy 260), I was >going to use that and trim it to .75" wide until I researched just how >poor a conductor brass is. Could double the thickness and double the >width, but that would make for more weight and harder interior install. > >Anyway, going to use .75" wide by .032" thick copper alloy 110 and glass >it in place with one thin layer of 3/4 oz model aeroplane cloth. > >Ron Parigoris > > ________________________________________________________________________________
Date: Dec 31, 2008
At 04:49 AM 12/31/2008, you wrote: >Hello, > >I have no clue how to determine which is which. Can someone help? I >have an electronic meter. > >I bought a low rate power supply some time back to use to power non >polarity sensitive flap motors and the like. I cut off the attached >12V socket connector and attached crocodile clips. I didn't take >note which wire was anode or cathode. > >Now I want to use it to power some of my avionics for testing etc. >They are polarity sensitive. Generally, the terms anode and cathode are used when referring to vacuum tubes, and chemical systems such as plating baths, batteries and dissimilar metals on boats. The source connections from a battery or power supply are more commonly referred to as (+) and (-) source connections. Most multi-meters don't identify their leads as (+) or (-) connections. For example: http://aeroelectric.com/Pictures/Tools/Test_Equipment/tenma1.jpg This instrument has a COMmmon jack with a black ring around it suggesting the black lead be plugged in here. There are two jacks for the red lead. One dedicated to high current measurements (20A full scale) and the other marked Volts-Ohms-mA for voltage, resistance and low current measurements. The instrument will indicate positive readings when the red lead is positive. Conversely, when the red lead is negative, the reading on the instrument will be preceded by a (-) sign. Not all instruments are set up exactly the same way . . . it's useful to study the manual that comes with it and then do some experimental measurements on your car, with a battery and light bulbs on the bench, etc. Become familiar with the instruments unique characteristics. Therefore, when set up as described above, probing the output leads for your power supply will no doubt produce a voltage reading . . . with polarity sign indicating which of the two test leads is positive. Your question suggests that you're just getting your feet wet in this electronic stuff. May I suggest a number of supplemental sources of information on the simple-ideas from which this craft is built? I recommend you acquire a copy of Electonics Fundamentals by T. Floyd. Don't get a new one. In fact get the cheapest one you can. The older editions are VERY reasonable. See: http://tinyurl.com/94g8gb Also, take a look at the first five books of a Navy electronics course that I've posted at my website. http://www.aeroelectric.com/Reference_Docs/Navy_Electroinics_Manuals/ Finally, keep talking with us here on the List. You'll be hard pressed to find a more willing and able bunch of folks to help you out. Bob . . . ________________________________________________________________________________
Date: Dec 31, 2008
From: "David E. Nelson" <david.nelson(at)pobox.com>
As an alternative, you can order P/N 8964K5 (1/8 x 3/4 x 12 copper bar) from McMaster for $7.33 + S&H. If you're in the Austin, TX area, stop by or call Westbrook Metals (NE Austin) as they sell copper bar. Price for 1/8 x 3/4 is a little less than $5/ft but they get you with a $5 cutting fee (and no, you're not allowed to cut it - I asked). ;( If you're lucky, you might find a scrap piece. Just another choice, :) /\/elson ~~ Lately my memory seems to be like a steel trap .... without any spring. ~~ On Wed, 31 Dec 2008, Dwight Frye wrote: > > McMaster-Carr (http://www.mcmaster.com/) has copper bar that you can order > from them. I wanted a piece of 1/8" thick 1/2" wide bar, and found it as > part number 8964K291. The downside? It was 3 feet long and cost $13. *sigh* > > As you might guess, I have quite a bit left if anyone wants to buy some off > of me. :) On the other hand, it made for a really nice/neat/attractive > set of connections between my master and starter contactors, as well as to > my ammeter shunt. > > -- Dwight > > On Tue Dec 30 20:28:49 2008, Vern Little wrote : >> >> Ron, there has been some discussion on this in the past, and there were >> questions about sourcing copper bus bar material. >> >> Van's Aircraft sells bass strips for this purpose, or you can flatten a >> copper pipe and use it. >> >> I replaced the brass buss-bars on my RV-9A prior to completion after doing a >> voltage drop analysis through the system. >> >> Probably would not make a significant difference, but if you have a choice, >> use copper. >> >> Vern Little >> Vx Aviation >> www.vx-aviation.com >> ----- Original Message ----- >> From: <rparigor(at)SUFFOLK.LIB.NY.US> >> To: >> Sent: Tuesday, December 30, 2008 12:09 PM >> Subject: AeroElectric-List: Brass is not a very good conductor >> >> >> >> >> Figured would share with the group at just how poor a conductor brass is. >> >> According to: >> http://www.kp44.org/ftp/ElectricalConductivityOfMaterials.php >> >> Brass only has ~ 28% the conductivity of copper. (They don't get as >> specific as alloy types) >> >> I need to somehow wire my port headrest (negative) to my starboard >> headrest. Shortest distance is direct between headrests but using a >> traditional wire will be unsightly and make for harder interior install. >> It needs to carry enough current to allow an occasional jump start. >> >> Since Ace hardware sells .032" thick brass 1" wide (alloy 260), I was >> going to use that and trim it to .75" wide until I researched just how >> poor a conductor brass is. Could double the thickness and double the >> width, but that would make for more weight and harder interior install. >> >> Anyway, going to use .75" wide by .032" thick copper alloy 110 and glass >> it in place with one thin layer of 3/4 oz model aeroplane cloth. >> >> Ron Parigoris >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
From: "Henry Trzeciakowski" <hammer408(at)comcast.net>
Subject: Re: Hour Meter/Oil Pressure Wiring
Date: Dec 31, 2008
Bob: I'm in a bit of a quandry regarding wiring my Hobbs Meter, Oil Pressure Switch and Low Oil Pressure Warning light !! I've printed out the Drawings from B & C and found one of your drawings regarding this wiring, however, before I went to order my transducer from B&C, I checked with Advanced Flight Systems to make sure that B&C's Oil Pressure transducer would work with the AFS 4500 EFIS / Engine monitor.......the answer was NO....I had to purchase theirs. They told me that their transducer had a single terminal (for their signal wire) that connects to their wiring harness: NOT a 3 terminal arrangement (S-I-P) configuration like B&C's.... SO, can you give me some suggestions on how I can wire my Hour Meter, Oil Pressure Warning Light given that there is only 1 terminal ?? Any help or suggestions appreciated. Henry ________________________________________________________________________________
Date: Dec 31, 2008
Henry, I'm not Bob, I didn't stay at a Holiday Inn express last night - but here's what I did... I purchased a manifold that allows me to connect two senders and an oil pressure hose all together....one of the senders was for the AFS 3400 EM, the other sender is for the B&C dual-throw switch unit that allows for my Oil pressure idiot light and my hobbs meter (through a relay that starts my engine timer and the hobbs at the same time). I've had my engine running so I know it works correctly. Ralph RV6A N822AR @ N06 - getting refresher training next weekend - then first flight -----Original Message----- >From: Henry Trzeciakowski <hammer408(at)comcast.net> >Sent: Dec 31, 2008 4:06 PM >To: aeroelectric-list(at)matronics.com >Subject: AeroElectric-List: Re: Hour Meter/Oil Pressure Wiring > >Bob: > >I'm in a bit of a quandry regarding wiring my Hobbs Meter, Oil Pressure Switch and Low Oil Pressure Warning light !! I've printed out the Drawings from B & C and found one of your drawings regarding this wiring, however, before I went to order my transducer from B&C, I checked with Advanced Flight Systems to make sure that B&C's Oil Pressure transducer would work with the AFS 4500 EFIS / Engine monitor.......the answer was NO....I had to purchase theirs. > >They told me that their transducer had a single terminal (for their signal wire) that connects to their wiring harness: NOT a 3 terminal arrangement (S-I-P) configuration like B&C's.... > >SO, can you give me some suggestions on how I can wire my Hour Meter, Oil Pressure Warning Light given that there is only 1 terminal ?? > >Any help or suggestions appreciated. > >Henry ________________________________________________________________________________
Date: Dec 31, 2008
Ralph: What type of manifold and where did you purchase it.....Area you talking about the Manifold, I think it's the VA-168 that Van's sells? I already have this installed on my firewall..... ----- Original Message ----- From: "Ralph E. Capen" <recapen(at)earthlink.net> Sent: Wednesday, December 31, 2008 10:33 AM Subject: Re: AeroElectric-List: Re: Hour Meter/Oil Pressure Wiring > > Henry, > > I'm not Bob, I didn't stay at a Holiday Inn express last night - but here's what I did... > > I purchased a manifold that allows me to connect two senders and an oil pressure hose all together....one of the senders was for the AFS 3400 EM, the other sender is for the B&C dual-throw switch unit that allows for my Oil pressure idiot light and my hobbs meter (through a relay that starts my engine timer and the hobbs at the same time). I've had my engine running so I know it works correctly. > > Ralph > RV6A N822AR @ N06 - getting refresher training next weekend - then first flight > > -----Original Message----- > >From: Henry Trzeciakowski <hammer408(at)comcast.net> > >Sent: Dec 31, 2008 4:06 PM > >To: aeroelectric-list(at)matronics.com > >Subject: AeroElectric-List: Re: Hour Meter/Oil Pressure Wiring > > > >Bob: > > > >I'm in a bit of a quandry regarding wiring my Hobbs Meter, Oil Pressure Switch and Low Oil Pressure Warning light !! I've printed out the Drawings from B & C and found one of your drawings regarding this wiring, however, before I went to order my transducer from B&C, I checked with Advanced Flight Systems to make sure that B&C's Oil Pressure transducer would work with the AFS 4500 EFIS / Engine monitor.......the answer was NO....I had to purchase theirs. > > > >They told me that their transducer had a single terminal (for their signal wire) that connects to their wiring harness: NOT a 3 terminal arrangement (S-I-P) configuration like B&C's.... > > > >SO, can you give me some suggestions on how I can wire my Hour Meter, Oil Pressure Warning Light given that there is only 1 terminal ?? > > > >Any help or suggestions appreciated. > > > >Henry > > ________________________________________________________________________________
Date: Dec 31, 2008
That sounds like the item...has three stubs on it, each with holes drilled on three sides. I had to put a spacer between the firewall and the manifold in order for all of the senders to fit. I have some pictures I'll send you...... -----Original Message----- >From: Henry Trzeciakowski <hammer408(at)comcast.net> >Sent: Dec 31, 2008 5:37 PM >To: aeroelectric-list(at)matronics.com >Subject: Re: AeroElectric-List: Re: Hour Meter/Oil Pressure Wiring > > >Ralph: > >What type of manifold and where did you purchase it.....Area you talking >about the Manifold, I think it's the VA-168 that Van's sells? I already >have this installed on my firewall..... > > >----- Original Message ----- >From: "Ralph E. Capen" <recapen(at)earthlink.net> >To: >Sent: Wednesday, December 31, 2008 10:33 AM >Subject: Re: AeroElectric-List: Re: Hour Meter/Oil Pressure Wiring > > > >> >> Henry, >> >> I'm not Bob, I didn't stay at a Holiday Inn express last night - but >here's what I did... >> >> I purchased a manifold that allows me to connect two senders and an oil >pressure hose all together....one of the senders was for the AFS 3400 EM, >the other sender is for the B&C dual-throw switch unit that allows for my >Oil pressure idiot light and my hobbs meter (through a relay that starts my >engine timer and the hobbs at the same time). I've had my engine running so >I know it works correctly. >> >> Ralph >> RV6A N822AR @ N06 - getting refresher training next weekend - then first >flight >> >> -----Original Message----- >> >From: Henry Trzeciakowski <hammer408(at)comcast.net> >> >Sent: Dec 31, 2008 4:06 PM >> >To: aeroelectric-list(at)matronics.com >> >Subject: AeroElectric-List: Re: Hour Meter/Oil Pressure Wiring >> > >> >Bob: >> > >> >I'm in a bit of a quandry regarding wiring my Hobbs Meter, Oil Pressure >Switch and Low Oil Pressure Warning light !! I've printed out the Drawings >from B & C and found one of your drawings regarding this wiring, however, >before I went to order my transducer from B&C, I checked with Advanced >Flight Systems to make sure that B&C's Oil Pressure transducer would work >with the AFS 4500 EFIS / Engine monitor.......the answer was NO....I had to >purchase theirs. >> > >> >They told me that their transducer had a single terminal (for their >signal wire) that connects to their wiring harness: NOT a 3 terminal >arrangement (S-I-P) configuration like B&C's.... >> > >> >SO, can you give me some suggestions on how I can wire my Hour Meter, Oil >Pressure Warning Light given that there is only 1 terminal ?? >> > >> >Any help or suggestions appreciated. >> > >> >Henry >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Dec 31, 2008
Subject: Re: Audio noise revisited
At 09:03 AM 12/31/2008, you wrote: >To noise specialists > >I just concluded the installation of my >Intercom, and although I took all the >recommended measures to avoid ground loops and >noise in general, I'm still hearing 2 whines, >which after some time (many hours =85 J) of >investigation, I think I identified the causes. > >One is the Air/Fuel Ratio Monitor, because when >I disconnect its ground wire, the most high-frequency whine disappears. >Which kind of filter (resistor, capacitor, >diode, any other) can I install to eliminate this noise? >And should I put it in the power(+) red wire or >the ground(-) black wire, or is it indifferent? > >The other whine is from the COMM Radio (Garmin >SL-30), because when I switch it off, the whine disappears. >How shall I eliminate this noise? Have you tried running the intercom from a separate battery? Rather than attack two noise sources, perhaps it's easier to attack the noise propagation path for one victim. The fact that you're hearing noise from TWO sources is a strong suggestion that the victim is the "sub standard" appliance with respect to tolerating noises that are known to exist on the bus. See if the intercom cleans up with its own separate power source . . . What is the input voltage range for normal operation of your intercom? Bob . . . ----------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ----------------------------------------- ________________________________________________________________________________
Date: Dec 31, 2008
Hi Bob My Intercom is the Flightcom 403. Its power requirement (per the manual) is 12-28V 0,16Amp. My next step would be exactly powering it from a separate battery, but I still didn't do it, 'cause I had no battery available - will do it next year :-)(tomorrow) If it cleans up working from a separate power source, how should I proceed? Thanks Carlos _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: quarta-feira, 31 de Dezembro de 2008 20:04 Subject: Re: AeroElectric-List: Audio noise revisited At 09:03 AM 12/31/2008, you wrote: To noise specialists I just concluded the installation of my Intercom, and although I took all the recommended measures to avoid ground loops and noise in general, I'm still hearing 2 whines, which after some time (many hours . :-)) of investigation, I think I identified the causes. One is the Air/Fuel Ratio Monitor, because when I disconnect its ground wire, the most high-frequency whine disappears. Which kind of filter (resistor, capacitor, diode, any other) can I install to eliminate this noise? And should I put it in the power(+) red wire or the ground(-) black wire, or is it indifferent? The other whine is from the COMM Radio (Garmin SL-30), because when I switch it off, the whine disappears. How shall I eliminate this noise? Have you tried running the intercom from a separate battery? Rather than attack two noise sources, perhaps it's easier to attack the noise propagation path for one victim. The fact that you're hearing noise from TWO sources is a strong suggestion that the victim is the "sub standard" appliance with respect to tolerating noises that are known to exist on the bus. See if the intercom cleans up with its own separate power source . . . What is the input voltage range for normal operation of your intercom? Bob . . . ----------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ----------------------------------------- ________________________________________________________________________________
Date: Dec 31, 2008
At 02:36 PM 12/31/2008, you wrote: >Hi Bob > >My Intercom is the Flightcom 403. Its power requirement (per the >manual) is 12-28V 0,16Amp. > >My next step would be exactly powering it from a separate battery, >but I still didn't do it, 'cause I had no battery available - will >do it next year J(tomorrow) >If it cleans up working from a separate power source, how should I proceed? Consider some form of filter for the +12V input to the intercom. I have one I can send you to try. See: http://www.aeroelectric.com/Catalog/AEC/9006/9006_1.jpg You can choose from either a horizontal or vertical connector position. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Subject: Always Hot Battery Bus
Date: Dec 31, 2008
I'm wiring my rv-8 using bob nuckolls simple vfr day night wiring diagram. Provisions are for a always hot battery bus. He indicates the length of wire should be six inches or less. However I would like to mount this fuse block next to the main bus which is one bulkhead forward of the instrument panel requiring a 5 foot length of wire. Should I fuse protect this wire with in-line fuse or maybe a current limiter. I'm planning on one electronic ignition and one conventional magneto. Thanks Tim -------- Tim Pethel RV-8A Wiring Fuse Read this topic online here: http://forums.matronics.com/viewtopic.php?p=222041#222041 ________________________________________________________________________________
Date: Dec 31, 2008
Subject: Re: CBA-II Battery Tester modifications/improvements?
At 03:44 PM 12/29/2008, you wrote: > > > > >You mention it three times in your post so I want to be clear, I'm >not interested in designing a product to compete with the CBA. I >create high-power loads for >dischargers/cyclers/analyzers/testers. I don't want the ultra >price-sensitive "low" end of the market. But, if this project moved >forward, I would offer to lay out a PCB that others could use for >building the load. If enough people were interested, I'd have a >batch of boards run and offer them at my cost. Each person involved >would contribute to the project where they can, and for me, it's the hardware. Hmmm . . . understand. >I'm just bringing up other thoughts about the possible feature set >for a very good DIY project. You want just raw data and feel it >offers the most and that graphics offer little, if nothing, compared >to box-scored raw data. But many users of battery analyzers >disagree. I have to keep going back to the CBA and its popularity. >A lot of people don't care what the actual number is. They can look >at a graph of a test involving several cells or packs and see >instantly which lasted the longest, or had the highest >voltage-under-load, for that test. Whether the "best-performing" >battery had a capacity of 10.02Ah or 10.10Ah, they wouldn't >care. Which battery that they can afford (or physically fit, etc,) >came out on "top". No need to check or compare actual numbers. agreed . . . >No marketing effort, no product development. This is an open-source >DIY project. You mentioned the use of a PIC earlier and I was >alluding to that. If that's no longer an idea you're interested in >seeing possibly be used for this DIY project, then the Weeder >modules (or other equivalent) are a quicker way to get going. You >also mentioned a friend who might possibly, maybe, be interested in >taking on the PC software development. No $10K to develop something >great that everyone could use. I wasn't suggesting that anyone would have to cough up $10K . . . just putting some perspective on the market value potential for returns on the effort. . . it helps sort priorities. >A graph doesn't tell you anything a number doesn't. But, the right >graph can make understanding various numbers, groups of numbers, and >their relationships, easier to understand. Edward Tufte's books so >wonderfully illustrate that. > >What's great about this project is that everyone can get exactly >what they want. One person can create a bare-bones, tiny-footprint, >data uploading and storage program. Another person can create a >graphics-analysis package to show tons of data in easy to read >graphs. One person could develop hardware that integrated existing >products, another could create a custom PIC board. The Weeder modules (or something similar) could be used to implement a host of battery tests without laying out a single board. An analog output board could drive a load-FET array of any size. An analog input board could watch battery voltage and the output from some handy current sensor. Perhaps one of these http://www.amploc.com/PRO%20Series.pdf So with a few grafted on components to the two Weeder modules, you'd be ready to tackle the application software in any language of choice. >I think a really important part of al of this would be to create a >set of standards for comms between the PC software and the boards, >and for a data storage format. This would allow for easy >"black-box" development of both the hardware and the >software. Either could have any set of features but all would be >compatible with each other. EVERYONE can read column or comma delimited data files. I think I'd split the software task into two areas. (a) test management and data storage with box-score readouts and (b) data presentation package with graphics abilities, perhaps some averaging of multiple data on same batteries, graphics, etc. >And the IR measurements feature is a great idea. There are so many >"standards" and methods for measuring IR that it would be great to >see the hardware/software eventually support a user-created IR test >(timing, current, etc.). Well, I've got the modules in a bin out in the shop. I've also got the core software needed to wake up and talk to the modules. I'm going to be out of town all next week but I'll dig up the hardware when I get back and see if it can be stroked back to life. It's been a couple of years since I had this stuff working. Bob . . . ________________________________________________________________________________
Date: Dec 31, 2008
Subject: Re: Always Hot Battery Bus
At 03:48 PM 12/31/2008, you wrote: > > >I'm wiring my rv-8 using bob nuckolls simple vfr day night wiring >diagram. Provisions are for a always hot battery bus. He indicates >the length of wire should be six inches or less. However I would >like to mount this fuse block next to the main bus which is one >bulkhead forward of the instrument panel requiring a 5 foot length >of wire. Should I fuse protect this wire with in-line fuse or maybe >a current limiter. I'm planning on one electronic ignition and one >conventional magneto. Thanks Tim The 6" rule including the maximum size of fuse (7A) for the hot-battery bus is a convention adopted for post crash fire risk reduction. It's not possible to offer advice based on any analysis of your proposed changes. If you mount it that far away from the battery, you've got an always hot feeder rated for considerable current capability. This is not done in the certified world. I would recommend you leave the battery bus fuse block co-located with the battery contactor and run individual feeders from fuses of no more than 7A from that location. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Dec 31, 2008
So, bringing this down to earth for the rest of us... If I want to do annual capacity checking of my $25 ah battery$, in an aircraft that requires 15-20 amps to stay afloat, will the CBA II give me the information I need? Say, if I run it at 65W to save the device? Or would it be better to find an analyzer that ran at 200+ watts? BTW, Happy New Year! Sam Hoskins www.samhoskins.blogspot.com On Sun, Dec 28, 2008 at 9:11 AM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > nuckolls.bob(at)aeroelectric.com> > > >> I think that's an idea worth exploring! >> I've developed a 500W (400W continuous) electronic load that can be used >> to extend the capabilities of any analyzer or discharger ( >> http://www.rcgroups.com/forums/showthread.php?t=938266) but there's a >> real need for "host" software and a load in the power range of the CBA, >> perhaps 100W-200W. This would be perfect for most DIY'ers and could easily >> be paralleled for higher power handling. >> >> The software would have to be very graphics-capable as the plotting and >> graphing features would be extremely important. I'd love to see it not >> require a huge installation just to run. But, the options may be limited. >> > > I'm not so sure about the graphics. Yes, they do make for an > effective display of data . . . and comparison of similar > batteries . . . > > http://aeroelectric.com/articles/AA_Bat_Test.pdf > > The data for this article was taken with a one-sample-per-second > data acquisition module that produces columnar data easily > imported into graphics applications like autocad and excel. > For the purpose of writing articles, the graphics offered by > WestMountainRadio are pretty . . . > > http://www.aeroelectric.com/Pictures/Curves/9vBatteryTests.jpg > > but from an engineering perspective, a numerical value for > energy delivered under the prescribed test conditions is > quite sufficient. The results of dynamic tests for evaluating > battery source impedance could be offered out as numerical > values. > > I did a flight test program for Raytheon a few years > back where the Weeder Technology modules proved quite > useful. > > http://www.weedtech.com/ > > > http://aeroelectric.com/Pictures/Tools/Test_Equipment/Data_Acquisition/Weedtech_DAS_2.jpg > > As a first pass for crafting a more robust version of > the CBA-II, a Weeder analog input module for $69 and > an analog output module for $99 would offer 95% of > the hardware to implement the task. Very simple programs > in any language of choice could be crafted to orchestrate > the testing, gathering of data values and presentation > of end-point results with no graphics capabilities > at all. > > One could also store individual data points on the > hard drive in a format easily imported to Excel. > > The CBA software has a nice light footprint though. An executable, help >> file, settings file, three DLLs for USB comms and forms handling. It may >> have some registry keys or other files in public directories but it doesn't >> seem to require the NET framework. MileHighWings' eFlightWatt logger had a >> single executable file that did everything, no installation needed. >> Something like this for an open source tester would be terrific. >> > > Sure. And I wouldn't discourage any interested parties > from turning their vision into really nifty applications > by exercising their programming skills. From the hands-on > engineering perspective, my personal needs for battery > testing can be easily addressed with more rudimentary > software. > > In fact, I still keep 20 year old copies of > Turbo-Basic that outputs compiled .exe files > for talking/listening to the Weeder modules. > I have a supply of these guys on the shelf from > various programs over the years. They still > offer the hammer-n-nails approach to crafting > a quick and useful test-setup. > > Bob . . . > > ________________________________________________________________________________
Date: Dec 31, 2008
Long hot wires bother me as well. However in the world of off road truck racing there is no room for a battery located near the panel or engine. We frequently use 10'+ #2 always hot unprotected leads from 2 big AH batteries located in the back where the weight does some good. Its very rare to have any issues after a major crash that involves shorted battery leads. You better believe the leads are carefully routed and protected. Typically protected with the convoluted split plastic stuff. Sure it burns but it is good for abrasion protection and cheap. The best lead wire is welding wire with double elastomer insulation. Pretty durable. I cannot source the stuff for you all but a day of shopping at the weld & battery shops will turn up a good product. I use a west marine source 4 position switch to turn the power off if need be and for storage to reduce the drain from all the parasite electronics. Yes the switch is where the driver can reach it and it is a long ways from the batts. The bottom line is there are many more high risk things in a plane or a race truck to be concerned about than a long hot batt lead. Regards, Paul =============== At 03:39 PM 12/31/2008, you wrote: > > >At 03:48 PM 12/31/2008, you wrote: >> >> >>I'm wiring my rv-8 using bob nuckolls simple vfr day night wiring >>diagram. Provisions are for a always hot battery bus. He >>indicates the length of wire should be six inches or less. However >>I would like to mount this fuse block next to the main bus which is >>one bulkhead forward of the instrument panel requiring a 5 foot >>length of wire. Should I fuse protect this wire with in-line fuse >>or maybe a current limiter. I'm planning on one electronic >>ignition and one conventional magneto. Thanks Tim > > The 6" rule including the maximum size of fuse (7A) > for the hot-battery bus is a convention adopted for > post crash fire risk reduction. It's not possible > to offer advice based on any analysis of your > proposed changes. If you mount it that far away > from the battery, you've got an always hot feeder > rated for considerable current capability. This > is not done in the certified world. I would > recommend you leave the battery bus fuse block > co-located with the battery contactor and > run individual feeders from fuses of no more > than 7A from that location. > > > Bob . . . > > --------------------------------------- > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > --------------------------------------- > > ________________________________________________________________________________
Date: Dec 31, 2008
nuckolls.bob(at)aeroelect wrote: > > I wasn't suggesting that anyone would have to > cough up $10K . . . just putting some perspective > on the market value potential for returns on the > effort. . . it helps sort priorities. > Ahh...agreed. nuckolls.bob(at)aeroelect wrote: > > The Weeder modules (or something similar) could be > used to implement a host of battery tests without > laying out a single board. An analog output board > could drive a load-FET array of any size. An analog > input board could watch battery voltage and the output > from some handy current sensor. Perhaps one of these > > http://www.amploc.com/PRO%20Series.pdf > > So with a few grafted on components to the two > Weeder modules, you'd be ready to tackle the > application software in any language of choice. > I have some samples of the 25A version of that and the 100A versions of the Allegro sensors: http://www.allegromicro.com/en/Products/Part_Numbers/0755/index.asp I'd be happy to cobble up a small board to output to your Weeders. nuckolls.bob(at)aeroelect wrote: > > EVERYONE can read column or comma delimited data > files. I think I'd split the software task into two > areas. (a) test management and data storage with > box-score readouts and (b) data presentation package > with graphics abilities, perhaps some averaging of > multiple data on same batteries, graphics, etc. > Agreed! nuckolls.bob(at)aeroelect wrote: > > Well, I've got the modules in a bin out in the > shop. I've also got the core software needed to > wake up and talk to the modules. I'm going to > be out of town all next week but I'll dig up > the hardware when I get back and see if it > can be stroked back to life. It's been a couple > of years since I had this stuff working. > > Bob . . . Sounds terrific. In the mean time, I'll dig out the current sensors I have and look into working up a simple interface to the Weeders. If you already have something that will work well, no problem. I also have some assorted MOSFETs, heat sinks and op-amps around to put together a basic load to use for testing to concept. We can talk more when you're back. My best wishes for a Healthy & Happy New Year to everyone! -------- John M. Owner CamLight Systems Read this topic online here: http://forums.matronics.com/viewtopic.php?p=222088#222088 ________________________________________________________________________________
Date: Jan 01, 2009
Very good. Thanks all. Andrew. ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Sent: Wednesday, 31 December, 2008 3:58:05 PM GMT +00:00 GMT Britain, Ireland, Portugal Subject: Re: AeroElectric-List: Power Supply - Anode/Cathode At 04:49 AM 12/31/2008, you wrote: Hello, I have no clue how to determine which is which. Can someone help? I have an electronic meter. I bought a low rate power supply some time back to use to power non polarity sensitive flap motors and the like. I cut off the attached 12V socket connector and attached crocodile clips. I didn't take note which wire was anode or cathode. Now I want to use it to power some of my avionics for testing etc. They are polarity sensitive. Generally, the terms anode and cathode are used when referring to vacuum tubes, and chemical systems such as plating baths, batteries and dissimilar metals on boats. The source connections from a battery or power supply are more commonly referred to as (+) and (-) source connections. Most multi-meters don't identify their leads as (+) or (-) connections. For example: http://aeroelectric.com/Pictures/Tools/Test_Equipment/tenma1.jpg This instrument has a COMmmon jack with a black ring around it suggesting the black lead be plugged in here. There are two jacks for the red lead. One dedicated to high current measurements (20A full scale) and the other marked Volts-Ohms-mA for voltage, resistance and low current measurements. The instrument will indicate positive readings when the red lead is positive. Conversely, when the red lead is negative, the reading on the instrument will be preceded by a (-) sign. Not all instruments are set up exactly the same way . . . it's useful to study the manual that comes with it and then do some experimental measurements on your car, with a battery and light bulbs on the bench, etc. Become familiar with the instruments unique characteristics. Therefore, when set up as described above, probing the output leads for your power supply will no doubt produce a voltage reading . . . with polarity sign indicating which of the two test leads is positive. Your question suggests that you're just getting your feet wet in this electronic stuff. May I suggest a number of supplemental sources of information on the simple-ideas from which this craft is built? I recommend you acquire a copy of Electonics Fundamentals by T. Floyd. Don't get a new one. In fact get the cheapest one you can. The older editions are VERY reasonable. See: http://tinyurl.com/94g8gb Also, take a look at the first five books of a Navy electronics course that I've posted at my website. http://www.aeroelectric.com/Reference_Docs/Navy_Electroinics_Manuals/ Finally, keep talking with us here on the List. You'll be hard pressed to find a more willing and able bunch of folks to help you out. Bob . . . ________________________________________________________________________________
Subject: updating electrical system
Date: Jan 01, 2009
I posted this under the avionics list but I meant to post it here so I pasted it below. Hello My business partner and I own an aircraft maintenance company. We are working towards the restoration side of the trade and would like to feature updated avionics and electrical systems as an option to original equipment. We have our company 1956 Tripacer that we are using as a learning tool and advertisement. The plane is down to the bare frame and I am starting the planning process for the electrical system. We are looking for ideas on updating the electrical system. we plan on all new wiring, single point ground, and possibly EFIS or a variation. The generator is coming off and an alternator is going on. We would like to replace the original nav light/dimmer combination switch and possibly re-design the aux fuel transfer system which is a pull cable with a switch (pull the knob - the cable opens the fuel valve and the switch turns on the pump). Parts for these older planes are getting harder to find and are quite expensive, this is our reason for wanting to update the systems plus technology has given us better products to work with. This isn't an experimental plane so we will have to do paperwork on everything we do. I would appreciate your thoughts and comments Gary Read this topic online here: http://forums.matronics.com/viewtopic.php?p=222223#222223 ________________________________________________________________________________
Date: Jan 01, 2009
Subject: Re: updating electrical system
At 01:43 PM 1/1/2009, you wrote: > >I posted this under the avionics list but I meant to post it here so >I pasted it below. > >Hello >My business partner and I own an aircraft maintenance company. We >are working towards the restoration side of the trade and would like >to feature updated avionics and electrical systems as an option to >original equipment. > >We have our company 1956 Tripacer that we are using as a learning >tool and advertisement. The plane is down to the bare frame and I am >starting the planning process for the electrical system. > >We are looking for ideas on updating the electrical system. we plan >on all new wiring, single point ground, and possibly EFIS or a >variation. The generator is coming off and an alternator is going on. > >We would like to replace the original nav light/dimmer combination >switch and possibly re-design the aux fuel transfer system which is >a pull cable with a switch (pull the knob - the cable opens the fuel >valve and the switch turns on the pump). > >Parts for these older planes are getting harder to find and are >quite expensive, this is our reason for wanting to update the >systems plus technology has given us better products to work with. > >This isn't an experimental plane so we will have to do paperwork on >everything we do. > >I would appreciate your thoughts and comments > >Gary I was working with a gentleman a few years ago on exactly the same project: Nice ol' Tripacer pulled down to the bare structure and refurbished for cover, flight controls, engine and cabin appointments. We planned a Figure Z-13/8 electrical system architectured here: http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z13-8Q.pdf The idea was to totally update the electrical/avionics systems. Fuel transfer to be managed with check valves/ electrically controlled pumps. Virtually none of the original equipment items were retained in favor of present day, catalog items. The goal was to craft the mother of all 337's to describe and qualify the changes without resorting to an STC. After about 6 months work on the project he was transfered. Never heard from him after he moved. I still think it's a worthwhile project for breathing new life into a very utilitarian machine. Successful completion would offer FAA approved benchmarks for similar efforts on other aircraft. We can talk about this if you like. Bob . . . ________________________________________________________________________________
Date: Jan 01, 2009
Bob That is kind of what I had in mind, I am just not sure how to get there quite yet. I would be glad to talk with you and welcome your help. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=222289#222289 ________________________________________________________________________________
Date: Jan 01, 2009
Subject: Follow-up on Carling switch failures . . .
A few weeks ago a discussion here on the List explored a "rash" of failures in Carling switches sold by a number of sources including B&C as their S700 series devices. The earliest manifestations of failure produced obvious effects of heating including discolored metal parts, deformed metal parts, loose rivets, charred housings etc. The most convincing hypothesis generated from these conditions centered on loss of conduction followed by increased resistance, increased heating, etc., etc. Sometime later in the discussions, we added the idea that root cause for these failures might be a mechanical loosening of the joints at locations (3) and (8) in the following sketch . . . http://tinyurl.com/8cm52v This loosening would be the byproduct of bending moments on the tabs by too-tight bundling of wires behind the switches. If these tabs are not favored with 'slack' leadwires, effects of weight and vibration of the whole bundle can be impressed on these joints. A postmortem on the first such failure was conducted back in the spring of 2006 and produced this document. http://tinyurl.com/2a2qqp Over the past few months, I've received about a half dozen failed switches. Most showed effects of heating as shown in the article cited above. However, TWO of the recently acquired failures showed NO effects of heating. They did have loose rivets that caused the switch to become intermittent . . . but circumstances did not produce subsequent heating. Based on this new information, I'm ready to hang my hat on the hypothesis I offered some months ago namely: The rash of failures experienced are most likely caused by inappropriate wire dress behind the switch that FIRST causes loosening of riveted joints. This condition MAY be followed by overheating events so spectacular as to divert attention away from the loose rivet. I can now comfortably suggest that failures we've seen (and perceived as a sudden up-tick in frequency) have been happening in these products for years. Further, the smoked switches were not a failure on the part of the manufacturer to meet electrical specifications nor upon users for failure to respect those ratings. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Subject: EI SC-5 clock doc error question
Date: Jan 01, 2009
Hi Ron. I was finishing the install on the SC-5 tonight. I ran the brown wi re in parallel with the oil low pressure light through the NC side of the p ressure switch. Just to clarify=2C what did you end up doing with the orang e wire since you said it was superfluous to the engine timer? Just leave it unconnected and tie it off? I appreciate your input=2C thanks in advance. Jim B Date: Tue=2C 30 Dec 2008 13:28:13 -0800From: rshannon(at)CRUZCOM.COMTo: aeroel ectric-list(at)matronics.comSubject: AeroElectric-List: EI SC-5 clock doc erro rThe previous post inspired me to share this recent discovery.The EI SC-5 c lock includes a non-resettable total engine time counter=2C essentially a H obbes function. The manual says that in a 12V system=2C the ORANGE wire sho uld be connected via an N.O. oil pressure switch to provide +12V on closure =2C when oil pressure develops=2C which will start the engine timer. This i s a little tricky with the B&P oil presure switch=2C where the N.O. contact is normally grounded -- I even set up a little relay to power the wire tha t way -- but don't bother. Contrary to the manual=2C any time the RED +12V main supply wire is hot=2C the engine timer runs=2C regardless of what's is or isn't happening on the ORANGE wire. For example=2C if you're running th e panel on ground power=2C perhaps for training or maintenance=2C or just e ntering a flight plan into the GPS before engine start=2C the engine timer will be ticking up=2C even though the engine isn't running. (The clock is s upposed to be wired to a main bus or e-bus=2C so it's going to be ON when m ost anything on the panel is on.) Incidentally=2C the manual also says that in a 12V system=2C the BROWN wire should _not_ be connected to anything.Af ter considerable consultation with EI=2C it was confirmed that the ORANGE w ire is at best superfluous to the engine timer function (or any function as far as I could determine) and the BROWN wire is what must be used to contr ol the engine timer. The BROWN wire should be grounded when the engine is O FF=2C i.e.=2C wired through a N.C. contact on a B&C pressure switch=2C in p arallel with the oil pressure warning light. When the BROWN wire's connecti on to ground is broken=2C on engine start=2C the engine timer begins.So=2C what the manual says to do doesn't work=2C and what the manual says not to do is what you have to do to make it work. I suggested to EI that they shou ld at least fix the manual=2C but they did not indicate any eagerness to do so. Hopefully=2C this work around will be useful others.Otherwise=2C it's a nice clock.Ron ________________________________________________________________________________
Date: Jan 02, 2009
Subject: New RWS EFI/Electcronic Ignition group
A couple of us have started a brand new, self-help, Yahoo! group, centered around Real World Solutions' electronic controllers<http://www.rotaryaviation.com/eficont.html>. This would be specific to this brand only. If you have a RWS EC1, EC2, or EC3 controller, or are planning on installing one in the future, please sig n up and get involved. Tracy Crook has been invited, but has not yet signed up. We are hoping. It's called EC3_RWS =B7 Friends of RWS EFI Ignition Controllers. Sign up here: Group home page: http://groups.yahoo.com/group/EC3_RWS Group email address: EC3_RWS(at)yahoogroups.com Best Wishes, Sam Hoskins Murphysboro, IL ________________________________________________________________________________
Date: Jan 02, 2009
Bob Did you get my offline email? Carlos _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: quarta-feira, 31 de Dezembro de 2008 21:43 Subject: RE: AeroElectric-List: Audio noise revisited At 02:36 PM 12/31/2008, you wrote: Hi Bob My Intercom is the Flightcom 403. Its power requirement (per the manual) is 12-28V 0,16Amp. My next step would be exactly powering it from a separate battery, but I still didn=12t do it, =11cause I had no battery available - will do it next year :-) (tomorrow) If it cleans up working from a separate power source, how should I proceed? Consider some form of filter for the +12V input to the intercom. I have one I can send you to try. See: http://www.aeroelectric.com/Catalog/AEC/9006/9006_1.jpg You can choose from either a horizontal or vertical connector position. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jan 02, 2009
Subject: Re: New RWS EFI/Electcronic Ignition group
At 06:19 AM 1/2/2009, you wrote: >A couple of us have started a brand new, >self-help, Yahoo! group, centered around ><http://www.rotaryaviation.com/eficont.html>Real >World Solutions' electronic controllers. This >would be specific to this brand only. If you >have a RWS EC1, EC2, or EC3 controller, or are >planning on installing one in the future, please sign up and get involved. > >Tracy Crook has been invited, but has not yet signed up. We are hoping. > >It's called > >EC3_RWS =B7 Friends of RWS EFI Ignition Controllers. > >Sign up here: > >Group home page: ><http://groups.yahoo.com/group/EC3_RWS>http://groups.yahoo.com/group/EC3_RW S >Group email address: EC3_RWS(at)yahoogroups.com > >Best Wishes, > >Sam Hoskins >Murphysboro, IL My congratulations and commentdations for your efforts sir. Hava you considered asking Matt for a List-server slot on Matronics? Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Jan 02, 2009
At 07:57 AM 1/1/2009, you wrote: >Good morning Bob > >Thanks for your offer, I accept it and I prefer the vertical connector. > >Please ship it (Global Priority Mail) to > >CARLOS TRIGO >Rua dos Cravos, 424 >2750-225 CASCAIS >PORTUGAL > >Tell me if I have to pay you something and how. > >Regards >Carlos > > We need to do the stand-alone battery test to make sure the offending noise is coming in through the power supply. If the noise is coming in through another path, then a power filter wont help. You can use a couple of 6v volt lantern batteries in series. Do your stores carry these? Emacs! It doesn't need to be alkaline. The venerable old carbon-zinc versions (cheapest) would suffice for this task. Bob. . . ________________________________________________________________________________
Date: Jan 02, 2009
Robert L. Nuckolls, III wrote: > At 06:19 AM 1/2/2009, you wrote: >> A couple of us have started a brand new, self-help, Yahoo! group, >> centered around Real World Solutions' electronic controllers >> <http://www.rotaryaviation.com/eficont.html>. This would be specific >> to this brand only. If you have a RWS EC1, EC2, or EC3 controller, >> or are planning on installing one in the future, please sign up and >> get involved. >> >> Tracy Crook has been invited, but has not yet signed up. We are hoping. >> >> It's called >> >> EC3_RWS Friends of RWS EFI Ignition Controllers. >> >> Sign up here: >> >> Group home page: http://groups.yahoo.com/group/EC3_RWS >> Group email address: EC3_RWS(at)yahoogroups.com >> >> >> Best Wishes, >> >> Sam Hoskins >> Murphysboro, IL > > My congratulations and commentdations for your efforts > sir. Hava you considered asking Matt for a List-server > slot on Matronics? > > Bob . . . > I'd 2nd that idea; I find the yahoo groups a royal pain in the backside. Charlie ________________________________________________________________________________
Date: Jan 02, 2009
thanks Bob. I am most familiar with the administrative portions of the Yahoo groups, so it was the easiest FOR ME to create it. We're up to 7 members, so far. Sam On Fri, Jan 2, 2009 at 8:23 AM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 06:19 AM 1/2/2009, you wrote: > > A couple of us have started a brand new, self-help, Yahoo! group, centere d > around Real World Solutions' electronic controllers<http://www.rotaryavia tion.com/eficont.html>. > This would be specific to this brand only. If you have a RWS EC1, EC2, o r > EC3 controller, or are planning on installing one in the future, please s ign > up and get involved. > > Tracy Crook has been invited, but has not yet signed up. We are hoping. > > It's called > > EC3_RWS =B7 Friends of RWS EFI Ignition Controllers. > > Sign up here: > > Group home page: http://groups.yahoo.com/group/EC3_RWS > Group email address: EC3_RWS(at)yahoogroups.com > > Best Wishes, > > Sam Hoskins > Murphysboro, IL > > > My congratulations and commentdations for your efforts > sir. Hava you considered asking Matt for a List-server > slot on Matronics? > > Bob . . . > > ----------------------------------------) > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > ---------------------------------------- > > > * > =========== =========== =========== =========== > * > > ________________________________________________________________________________
Date: Jan 02, 2009
Subject: GPS Serial Data to Garmin GTX-327 Transponder
Listers, I've tried sending two different sources of NMEA 0183 data at 4800/9600/19200/38400/57600 baud rates to my Garmin GTX-327 on both serial input ports 1 (db25 Pin 2) and port 2 (db25 pin 19), and configured for "GPS" input. But I don't get anything on the GTX-327 serial input test display. I have been successful at getting AirData Z-format from the GRT EFIS at 9600 baud into either of the GTX-327 serial ports, so the ports are good. The NMEA 0183 data registers correctly on other devices reading it so the GPS serial output seem fine. The GTX-327 just won't seem to see the GPS data for some reason. Am I doing something wrong? Has anyone else tried this successfully? Thanks! Matt Dralle RV-8 #82880 N998RV ________________________________________________________________________________
Date: Jan 02, 2009
Bob, FWIW I have the LML, the Yahoo ES group and the AeroElectric list all sent to my Google gmail account, where they are sent to their own folder labels. They then are all in the same place, in the same format and easy to search in the same way. Works great for me... ________________________________________________________________________________
From: "Christopher Barber" <CBarber(at)TexasAttorney.net>
Subject: Z-14 v Z-14Fadec question
Date: Jan 02, 2009
Last week I asked about C/B's tripping in the NON crossover mode and received a thoughtful answer. Thanks. Due to my growing but limited knowledge in this area it took a EE buddy of mine to figure out I had the crossover switch wired in a "mirrored" manner on my switch. Now, no more C/B tripping AND my alternators are charging properly. So, my initial calculations seemed to be ok as to wires etc....just not my translation as to switch connections. Ahhhhhh, non-the-less, it now feels nice. Now, I have a general question regarding the Z-14 schemes. For the crossover switch, up is to engage the starter with both batteries, center is non-crossover, normal mode with batteries working to power their bus independently and down is both batteries working together on both busses......If I understand correctly. So, in the Z-14 Fadec scheme, the start button engages the starter, then one position on the switch is independent alt to each bus and the other switch to have the systems work together? Or, is on position Off and the other switch position engaging both alternators to work together? If it is the second scenario, does that mean the two systems ALWAYS work together? If so, is there any reason not to have both systems always working together in the standard Z-14 scheme. I assume the FADEC label is since it is always engaged there is no pilot intervention. Just looking for a better understanding. Thanks. All the best, Chris Barber Houston Velocity SE with all electric Mazda 13b rotary ________________________________________________________________________________
Date: Jan 02, 2009
Ok, I sneaked out the 12V battery of my house alarm and did the test. I powered the Intercom from that separate battery but the noises are still there. I suppose, as you say, that a filter on the Intercom power wire won't solve my problem. Regarding the A/F Ratio Monitor, I am pretty sure it makes one of the whines, so I have to put back the power filter that it used to have (the filter has gone west some time ago, way before installing the Intercom, and I took it away, to restore power to the Monitor, not knowing about the noise it causes). I believe that will eliminate that noise. The remaining problem now is coming from the COMM Radio. That other whine comes on and off whenever I turn the radio on and off. I even tried powering the radio from a separate battery and no joy. Should I put the filter on the Radio's power line? What do you suggest? Carlos _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: sexta-feira, 2 de Janeiro de 2009 14:25 Subject: RE: AeroElectric-List: Audio noise revisited At 07:57 AM 1/1/2009, you wrote: We need to do the stand-alone battery test to make sure the offending noise is coming in through the power supply. If the noise is coming in through another path, then a power filter wont help. You can use a couple of 6v volt lantern batteries in series. Do your stores carry these? It doesn't need to be alkaline. The venerable old carbon-zinc versions (cheapest) would suffice for this task. Bob. . . ________________________________________________________________________________
Subject: Follow-up on Carling switch failures. . .
Date: Jan 02, 2009
Bob, While I can't disagree with your findings, if I remember the discussion correctly, most of the failed B&C S700 switches were on strobe systems. I think I kicked off the recent discussion with a failed switch on my strobe system. I have several other B&C S700 series switches, all are wired similar to the strobe switch, and none of them have failed or showed signs of heat stress. Why should the switches on a strobe system be more failure prone? Charlie Brame RV 6A N11CB San Antonio ---------------------------------------------------------------------------- > From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> > Subject: AeroElectric-List: Follow-up on Carling switch failures . . . > > A few weeks ago a discussion here on the List explored > a "rash" of failures in Carling switches sold by a number > of sources including B&C as their S700 series devices. --------------------------------snip------------------------------ > > > I can now comfortably suggest that failures we've > seen (and perceived as a sudden up-tick in frequency) > have been happening in these products for years. Further, > the smoked switches were not a failure on the part of the > manufacturer to meet electrical specifications nor > upon users for failure to respect those ratings. > > Bob . . . > > ----------------------------------------) > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > ---------------------------------------- > ________________________________________________________________________________
Subject: Re: Follow-up on Carling switch failures. . .
Date: Jan 02, 2009
Bob's working hypothesis is that vibration is loosening the rivets on the Carling switches. High current switches (strobe supplies, landing lights) then exhibit overtemperature, increased resistance and thermal runaway. Strobe supplies are probably the worst load in the aircraft because they are effectively constant-power devices: as the input voltage decreases, the current increases to compensate. This would be bad news if the switch is resistive. I've had two strobe switch failures, one landing light switch (actually a wig-wag) failure, and one master switch failure (loose rivet but no charred terminals). I have also received brand-new Carling switches with loose terminals. As an experiment, I replaced several Carling switches with Honeywell switches and have been running them, monitoring for failures. I proposed about 100 hours of testing before any conclusions could be made. This will probably take several more months. I have check them in the interim, with no problems. If the experiment shows failure of the Honeywell switches, then the problem may be attributed to my installation. If the experiment does not show failure of the Honeywell switches, then the problem may be attributed to the Carling switches sensitivity to vibration. Bob has concluded that the Carling switches are fine, but should have vibration decoupling loops to minimize vibration stresses on the terminals. Good advice no matter who's switches are installed. Unfortunately, I don't agree that the problem is that my (our) installations are incorrect. Rather, I believe that the problem is that the Carling switches are unusually sensitive to vibration. In my next project, I am planning to use different switches, plus decoupling loops. In addition, strobe and landing light loads will be isolated with automotive relays which are generally more robust. Vern Little ----- Original Message ----- From: Charles Brame To: AeroElectric List Sent: Friday, January 02, 2009 4:42 PM Subject: AeroElectric-List: Follow-up on Carling switch failures. . . Bob, While I can't disagree with your findings, if I remember the discussion correctly, most of the failed B&C S700 switches were on strobe systems. I think I kicked off the recent discussion with a failed switch on my strobe system. I have several other B&C S700 series switches, all are wired similar to the strobe switch, and none of them have failed or showed signs of heat stress. Why should the switches on a strobe system be more failure prone? Charlie Brame RV 6A N11CB San Antonio ------------------------------------------------------------------------- --- From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Subject: AeroElectric-List: Follow-up on Carling switch failures . . . A few weeks ago a discussion here on the List explored a "rash" of failures in Carling switches sold by a number of sources including B&C as their S700 series devices.
December 18, 2008 - January 02, 2009
AeroElectric-Archive.digest.vol-ii
