AeroElectric-Archive.digest.vol-ir
May 13, 2009 - May 30, 2009
      >dropped the voltage.
      >         bob noffs
      >On Mon, May 11, 2009 at 8:31 PM, David L.
      >The little, cheap Harbor Freight "maintainers" work quite well.  I
      >have used several.  One key point however,  ...many of them come set
      >a tad too high in their fixed "float" voltage, to my thinking.  I
      >have seen them as high as 13.9 v.
      >The good news, is they can be adjusted to the float voltage that you
      >want.  The little controller box should have a back lid that is
      >lightly glued in place.  Carefully work a very narrow blade screw
      >driver or other tough, but thin device into the glued seam and work
      >it until the back pops off.  Inside is a small circuit board and
      >potentiometer.  It may have a spot of RTV on it. Work this
      >loose.  Turning the pot CW lowers to float voltage.  I like about
      >13.2 v.  Others may want a slightly different setting.  I usually
      >locate where the pot slotted screw adjust hole is located next to
      >the little case and drill a 3/16 hole.  That way, it can be adjusted
      >from the outside.  The little unit is quite stable after you get the
      >setting where you want it. David
         David's suggestions are worthy of consideration but
         he doesn't mention specific model numbers from
         H.F. I've tested several battery charger products
         from H.F. and found some that were not suited to our tasks.
         What we're looking for are devices that first
         "top off" a battery and then "drop to maintenance".
         This kind of behavior is illustrated in . . .
      http://www.aeroelectric.com/Pictures/Curves/schumacher_3.jpg
         This curve is from the Schumacher 1562 series chargers available
         from WalMart for about $20. There are dozens of other
         products that produce similar charge/maintenance profiles.
         This one  . . .
      http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=42292
         . . . does not.
         I found a pot inside to adjust the output voltage . . .
         but only ONE pot. It's a device suitable for maintaining
         an already charged battery (adjust it for 13.1 volts) but
         will not charge a battery.
         Based on its description and price, this device
      http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=99857
         shows more promise. Haven't had time to go get one and
         check it out but in the mean time, the Schumacher
         1562 is a sure bet
      http://aeroelectric.com/Pictures/Battery_Chargers/Schumacher_Chargers/1562.jpg
Date: May 13, 2009
Subject: Re: Connecting a battery charger to a 2 battery
system Good Afternoon Deems. Bob Nuckolls Suggested: "Active notification of low voltage (nice flashing light on panel) for each system is a good hedge against leaving the master switch on. Also, oil pressure switches can be used to control both an hour-meter (oil pressure up) and a low pressure light (engine stopped). Wiring a small buzzer in parallel with the light helps too once the engine is stopped." We have such an arrangement on our Piper Pawnee glider tow plane. Works great. I have also seen a strobe light hooked up in the same manner. Most of us tend to make a loving last glance at our pride and joy before we abandon the scene. It is hard to walk away with the strobes firing! Happy Skies Old Bob AKA Bob Siegfried Ancient Aviator 628 West 86th Street Downers Grove, IL 60516 630 985-8502 Stearman N3977A Brookeridge Air Park LL22 ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- **************Dell Mini Netbooks: Great deals starting at $299 after instant savings! ________________________________________________________________________________
Subject: Re: Modifying the Piper plug
Date: May 13, 2009
Thanks Bob, That is exactly what I needed. The link you posted in the "24 V system crowbar needed" thread had the diagram, but not the text. Thanks again. -------- Myron Nelson Mesa, AZ Emp completed, legacy build fuse in progress Read this topic online here: http://forums.matronics.com/viewtopic.php?p=243897#243897 ________________________________________________________________________________
Date: May 13, 2009
At 12:48 PM 5/13/2009, you wrote: > >Thanks Bob, > >That is exactly what I needed. > >The link you posted in the "24 V system crowbar needed" thread had >the diagram, but not the text. > >Thanks again. Okay, very good. Be advised that AEC is offering stand-alone crowbar ov modules. We've sorted through some fabrication enhancements and will put them in the catalog soon. In the mean time, you can order them by emailing me directly. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
From: "ROGER & JEAN CURTIS" <mrspudandcompany(at)verizon.net>
Date: May 13, 2009
Okay, very good. Be advised that AEC is offering stand-alone crowbar ov modules. We've sorted through some fabrication enhancements and will put them in the catalog soon. In the mean time, you can order them by emailing me directly. Bob . . . Bob, I will be needing 2 OV modules, one for my alternator circuit and one for ground power. Do you have pricing for your modules? Are they available both in kit and assembled form? Roger ________________________________________________________________________________
Subject: Is a pop rivet acceptable for a ground attachment?
Date: May 13, 2009
I am grounding a gizmotron (Dynon pitot heater controller) to a wing rib with a Fast-On Tab. I used a pop rivet to attach the Tab to the rib, but then it occurred to me this might not be acceptable. The Tab can rotate around the rivet, though not freely or loosely. I'm not concerned about the mechanical properties as much as the electrical. Maybe a tighter connection is required? Having been wrong about almost everything electrical in the past, I thought I'd post here and get a definitive answer. Ralph Finch Davis, CA RV-9A QB-SA ________________________________________________________________________________
Date: May 13, 2009
Subject: Re: Is a pop rivet acceptable for a ground attachment?
It will work for a while, though I could imagine it might get hot, and then maybe intermittent. It doesn't sound like it's a "gas tight" connection, so it's not the best we know how to do.. A machine screw and nut would be better I think. I'm sure someone with more direct experience will chime in. Matt- > > > I am grounding a gizmotron (Dynon pitot heater controller) to a wing rib > with a Fast-On Tab. I used a pop rivet to attach the Tab to the rib, but > then it occurred to me this might not be acceptable. The Tab can rotate > around the rivet, though not freely or loosely. I'm not concerned about > the > mechanical properties as much as the electrical. Maybe a tighter > connection > is required? > > Having been wrong about almost everything electrical in the past, I > thought > I'd post here and get a definitive answer. > > Ralph Finch > Davis, CA > RV-9A QB-SA > > ________________________________________________________________________________
Subject: RV-9 Wing Wire Routing
Date: May 13, 2009
I am wrapping up my RV-9 wings and am ready to route the wiring with the following components (right wing). Anyone have any advice on routing "pairing"? I have three wire runs available two adjacent to each other just rear of the wing spar and then a third in the wing trailing edge. 1- Dynon autopilot roll servo wiring set 2- Archer VOR/ILS co-ax cable (2 cables) Whiskey Victor 3 - strobe light 4 - LED position light 5 - HID landing light (wig-wag) thanks Russ Airey RV-9A Wrapping up Fuselage and Wing Construction ________________________________________________________________________________
Date: May 13, 2009
Subject: Re: RV-9 Wing Wire Routing
At 07:54 PM 5/13/2009, you wrote: > I am wrapping up my RV-9 wings and am ready to route the wiring > with the following components (right wing). Anyone have any advice > on routing "pairing"? I have three wire runs available two > adjacent to each other just rear of the wing spar and then a third > in the wing trailing edge. > >1- Dynon autopilot roll servo wiring set >2- Archer VOR/ILS co-ax cable (2 cables) >Whiskey Victor > 3 - strobe light > 4 - LED position light > 5 - HID landing light (wig-wag) Run them all together if you wish. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 13, 2009
At 06:18 PM 5/13/2009, you wrote: > >I am grounding a gizmotron (Dynon pitot heater controller) to a wing rib >with a Fast-On Tab. I used a pop rivet to attach the Tab to the rib, but >then it occurred to me this might not be acceptable. The Tab can rotate >around the rivet, though not freely or loosely. I'm not concerned about the >mechanical properties as much as the electrical. Maybe a tighter connection >is required? > >Having been wrong about almost everything electrical in the past, I thought >I'd post here and get a definitive answer.\ What you're looking for in bringing terminal and airplane together is a GAS TIGHT joint. This is between the terminal face that comes into contact with the aircraft's metallic surface. This usually means that you've applied enough force to DEFORM irregularities in the two surfaces and literally squash the materials together. This is the same process described in: http://www.aeroelectric.com/articles/CrimpTools/crimptools.html http://www.aeroelectric.com/articles/terminal.pdf If you want a local grounding joint that outlasts the rest of the airplane use 10-32 hardware to bring terminal and airplane together. Brighten up the terminal surface that touches the airplane. Brighten up the airplane that touches the terminal. SMOOTH! and SHINY! don't scuff it up with coarse abrasives. Make up the joint with the a washer between screw head (or nut) and the opposite side of the terminal. Use metal locknut (MS21042-L3) on the screw. "Icing on the cake" is to coat one of the mating electrical conduction surfaces with thin layer of silicone grease before mating. Torque to 20 in-lbs. THAT joint will not spin on the screw . . in fact, you should tear the wire grip off the terminal before the rest of it moves. If you pop-riveted a nav light ground, it would probably be okay but the higher you go in current through the joint the more important it is to get it gas tight. Short of soldering/welding the joint, what I've described is the best we know how to do. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 13, 2009
Thanks Matt and Bob. Once again you guys confirmed my suspicions that I have much to learn. RF ________________________________________________________________________________
Subject: Contactor and Crowbar Ratings
Date: May 14, 2009
Bob: I looked at the contactors made by Eaton that are 337 approved for Cessna Aircraft. Eaton P/N PW6041H215. rated for 28 volts continuous which is good for my 24 volt experimental aircraft. My question is about the crowbar circuit for overvoltage protection of the ground relay. The ones I see B&C and aeroelectric carry are rated at 12 VDC and 24 VDC. Shouldn't they be 15 VDC and 28 VDC to allow for battery charging thru the ground power port? If so, can the ones you sell be modified for this? Craig Read this topic online here: http://forums.matronics.com/viewtopic.php?p=243982#243982 ________________________________________________________________________________
Date: May 14, 2009
Subject: Of pop rivets and lock nuts . . .
Yesterday I offered a short list of simple ideas that went to the task of getting life-of-the-airplane joints between a wire and the airframe. Specifically, how to get a wire "grounded" in a way that it stays grounded. Discussions here on the List have considered the goals of achieving low resistance, high-longevity connection between two conductors in a variety contexts. Some tasks call for temporary or "service" connections between two wires. In this case, we look to the products offered by skilled designers and manufacturers of connectors. They spend a LOT of time figuring out the simple ideas that keep two mechanically independent pins in low resistance contact with each other in spite of moisture, vibration, temperature cycles, electron flow, etc., etc. These same designers have reasonable expectations that users of their products will understand that while we purchased their product for it's 'temporary' connection features, the user still has to make the 'permanent' connections between pins and wires. There are further considerations for supporting the joint adjacent to the transition between 'permanent' and 'flexible' segments of the assembly. When we purchase crimp tools appropriate to the well considered-components (like PIDG terminals) then much of the process sensitive actions are taken care of . . . as long as we follow instructions. We have a further interest in being able to evaluate the end-product of our labors. Did we use the right components/tools? Was the wire properly inserted? Was the crimp fully seated? etc. etc. Understanding and acknowledging the skill of folks who supply us with terminals, crimp tools, and connectors illuminates a need for the OBAM aircraft builder to consider his/her part in maintaining the overall strength of the chain . . . Emacs! No matter how 'good' the rest of the chain's links might be, inattention to detail at any point negates the integrity of the whole. Yesterday I offered a means by which a properly installed terminal can be electrically and mechanically attached to the airframe for the purpose of effecting a good ground connection. I suggested that a combination of 10-32 screw, washer and lock nut would apply mate-up forces would produce a very satisfactory joint in terms of performance and longevity. I suggested that a little silicone grease in the interface would be a further hedge against ingress of moisture. This was a best-we-know-how-to-do alternative to the use of the pop-rivet joint that raised a list member's curiosity as to potential loss of joint integrity. There is some value in expanding this discussion The driven rivet can be both electrically and mechanically robust. A #4 (.125) rivet set in a #30 (.128) hole swells up during the driving process to apply great pressure (tons per square inch) against the walls of the hole. Further, sheets of aluminum assembled with aluminum rivets offer no risk for effects of dissimilar metals in presence of moisture/oxygen for electrolytic corrosion. It's fair to say that an aluminum grounding tab for a rear mounted battery installed with 4-6 properly driven rivets has a life-of-the-airplane shot for performing as intended. The pop-rivet is a hollow fastener that also swells in the hole . . . and like it's driven cousin, applies some forces in tension that holds the parts together. But unless you use un-plated, aluminum pop-rivets, there are dissimilar metal issues (Yeah, you can get monel rivets too). Further, since the device is hollow, it cannot generate and maintain the mate-up forces offered by it's driven cousins. In the case that prompted this thread, the finished joint was loose enough to allow the mated up parts to move under ordinary manipulation with the fingers. One might deduce from this observation that attaching the battery ground tab with pop-rivets is problematic . . . even if the mounted bracket can't spin on the fastener. Yesterday, I suggested a 10-32 screw for the works- good-lasts-a-long-time joint. How much smaller can we go without serious degradation of the joint? For grounding of medium wires, say 14AWG or lighter, an 8-32 is probably fine. Grounding small wires (20-22AWG) can be tied down with 6-32 hardware. In all cases, bringing clean surfaces together with forces equal to the capabilities of the fastener is required. The use of all-metal lock washers makes the screw look more like a rivet. The addition of moisture ingress protection is also a useful ingredient in this recipe for success. This little dissertation is not intended to demean the lowly pop-rivet. Keep in mind that John Thorpe's very successful T-18 was assembled with "pulled" or "pop" rivets. See: http://tinyurl.com/pdhszb When use within their performance limits, the pop-rivet has a role to perform in many plays. However, making up lasts-a-long-time, gas-tight joints for airframe grounds just isn't one of them. Bob . . . ________________________________________________________________________________
Date: May 14, 2009
Subject: Re: Contactor and Crowbar Ratings
At 09:06 AM 5/14/2009, you wrote: > > >Bob: > >I looked at the contactors made by Eaton that are 337 approved for >Cessna Aircraft. Eaton P/N PW6041H215. When you can find these, get a grip on your wallet. While these are the cream of the crop for DC contactors, they're quite pricey. > . . . rated for 28 volts continuous which is good for my 24 volt > experimental aircraft. My question is about the crowbar circuit > for overvoltage protection of the ground relay. The ones I see B&C > and aeroelectric carry are rated at 12 VDC and 24 VDC. Shouldn't > they be 15 VDC and 28 VDC to allow for battery charging thru the > ground power port? If so, can the ones you sell be modified for this? No, generally speaking 12/14 and 24/28 are interchangeable with respect to functionality. The low-cost 12/24v RBM/Stancore/W-R and Cole-Hersee battery contactors offered by B&C and others are quite suited to our task. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 14, 2009
Ralph, I used an A5 pop for securing a ring lug to ground my tanks and there are a few hundred providing ground from the firewall back to the batteries without any problems. Perhaps a A5 would be better than an A4, but that's it. Larry McFarland 601HDS at www.macsmachine.com Ralph Finch wrote: > > I am grounding a gizmotron (Dynon pitot heater controller) to a wing rib > with a Fast-On Tab. I used a pop rivet to attach the Tab to the rib, but > then it occurred to me this might not be acceptable. The Tab can rotate > around the rivet, though not freely or loosely. I'm not concerned about the > mechanical properties as much as the electrical. Maybe a tighter connection > is required? > > Having been wrong about almost everything electrical in the past, I thought > I'd post here and get a definitive answer. > > Ralph Finch > Davis, CA > RV-9A QB-SA > > > ________________________________________________________________________________
Subject: Alternator excitation - suggested wiring?
Date: May 14, 2009
I have a question about wiring my alternator. My question is primarily about the excitation/ignition-on connection. I've found lots of articles about alternators, and info on this list. But most other articles talk about internally regulated versions. So far I can't quite get my head about the excitation question. I can surely experiment with the connections, and plan to do so this weekend. I'm just hoping to get a better understanding before diving in too deep with a running engine and spinning prop. My alternator has three connections, one for field, one for 12v excitation, and the B lead. I have the B&C LR3C regulator, overall electrical is a Z19. The alternator was built by a local high performance shop, after talking through the needs of my aircraft. Good bearings and grease, precise tolerances, etc. All those things Bob talks about in his book. The instructions that came with it say: "Alternator has isolated field wires. Either one can be the IGNITION ON 12 volt supply wire. The other to the FIELD CONNECTION on the regulator. The regulator case must be grounded. " So what I was planning to do is run a small wire from the B lead on the alternator to one of the alternator's connections, making it the IGNITION ON connection. Then connect the other tab to the Field connection on the regulator. That way when I turn on the Master Switch to middle position (batt) it sends 12 volts to the IGNITION ON connection. The hope being that is supplies the alternator with that 12 volt IGNITION ON voltage. I already know that turning the Master Switch to BATT position (or Alt) sends power all the way to the B lead. What I am not sure about is: do I need to keep that excitation/Ignition on voltage running all the time the engine is running (would it hurt anything if I did)? Or should it be shut off after the engine is started and alternator is producing power? My Master Switch is exactly as in the Z19, so it controls the on/off of the regulator already. It is this question of excitation that I am unclear about. Lots of articles talked about the need for an ignition on light as a mandatory component in making some alternators actually operate. Thanks in advance, Mike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=244022#244022 ________________________________________________________________________________
Date: May 14, 2009
Bob: Spoke with Bill at B&C. Their 24 volt crowbar trips at 32 VDC. That is OK. However, I am having difficulty finding a contactor for a 24 VDC application. The Stancor ones have a coil voltage of 24 VDC or 36 VDC. However, 28 VDC exceeds the coil voltage of the 24 VDC unit so it can't work. Also, their 36 VDC contactors will not work because of the coil voltage being too high to activate it. Bottom line is I need a contactor with a coil voltage rating of 28 VDC. Other than the Eaton unit (which you are correct is costly) I am running out of luck. Any ideas? Craig Read this topic online here: http://forums.matronics.com/viewtopic.php?p=244076#244076 ________________________________________________________________________________
Date: May 14, 2009
Subject: Re: Alternator excitation - suggested wiring?
>My alternator has three connections, one for field, one for 12v >excitation, and the B lead. I have the B&C LR3C regulator, overall >electrical is a Z19. The alternator was built by a local high >performance shop, after talking through the needs of my aircraft. >Good bearings and grease, precise tolerances, etc. All those things >Bob talks about in his book. The instructions that came with it say: > >"Alternator has isolated field wires. Either one can be the IGNITION >ON 12 volt supply wire. The other to the FIELD CONNECTION on the >regulator. The regulator case must be grounded. " > > Okay, the connections described are for > a "pull-down" regulator . . . typical of > the built in regulators. The LR3 is > a "pull-up" style device. This means > that one of your free field leads goes > to GROUND instead of 12v excitation. The > other field terminal connect to the FIELD > lead of the LR3. > >So what I was planning to do is run a small wire from the B lead on >the alternator to one of the alternator's connections, making it the >IGNITION ON connection. > > No, that's what you do for the "pull down" > regulator architecture. Take one field lead > to ground. > >Then connect the other tab to the Field connection on the regulator. > > Yes. > >That way when I turn on the Master Switch to middle position (batt) >it sends 12 volts to the IGNITION ON connection. The hope being >that is supplies the alternator with that 12 volt IGNITION ON voltage. > > Technically, once modified for legacy > functionality as an externally regulated > alternator, there is no more "IGN" terminal. > Just F1, F2, B and GND (case). > > >I already know that turning the Master Switch to BATT position (or >Alt) sends power all the way to the B lead. > > Yes . . . through your b-lead protection > device. ANL, MANL or other fat fuse. > >What I am not sure about is: do I need to keep that >excitation/Ignition on voltage running all the time the engine is >running (would it hurt anything if I did)? Or should it be shut off >after the engine is started and alternator is producing power? > > If wired per Z-19 (or any other Z-figure, the > DC PWR MASTER switch has control over the > alternator. > >My Master Switch is exactly as in the Z19, so it controls the on/off >of the regulator already. > > Then it controls the alternator too. If the > regulator is unpowered, the altenrator is OFF. > >It is this question of excitation that I am unclear about. Lots of >articles talked about the need for an ignition on light as a >mandatory component in making some alternators actually operate. > > This is only for some (in fact a few) alternators > with built in regulators. This feature no longer > applies to your situation. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 14, 2009
At 08:53 PM 5/14/2009, you wrote: > > >Bob: > >Spoke with Bill at B&C. Their 24 volt crowbar trips at 32 VDC. That is OK. Yes . . . the nominal trip range for 14v ov protection is 16.2 to 16.5 volts. 28v aircraft it's 32.4 to 33 volts. >However, I am having difficulty finding a contactor for a 24 VDC >application. The Stancor ones have a coil voltage of 24 VDC or 36 >VDC. However, 28 VDC exceeds the coil voltage of the 24 VDC unit so >it can't work. Also, their 36 VDC contactors will not work because >of the coil voltage being too high to activate it. Bottom line is I >need a contactor with a coil voltage rating of 28 VDC. Other than >the Eaton unit (which you are correct is costly) I am running out of >luck. Any ideas? I can tell you that the 70 series, continuous duty contactors have been used in 14 and 28 volt aircraft with good service histories. Yes, they run warm. But in airplanes, the ambient temperatures for most operating conditions are lower that max rated for 12v operation which tends to offset the effects of the extra heating. The 70-903 contactor has a resistance of 60 ohms operating at room temperature. If you're worried about it, you could put a 6 ohm, 1W resistor in series with the coil to "cool" it off by about 10% of applied voltage . . . but I think you're okay without it. These contactors have been around since about WWII. While they're not "Space Rated" contactors, they've proven to be of good value in a failure tolerant airplane. Even the $high$ contactors have bad days http://tinyurl.com/qmk6gm If you're loosing sleep over it, consider the these EV200 series contactors. They feature automatic coil current reduction after pull-in to reduce continuous power to keep the contactor energized. However, they're about 6X the price of the 70 series device and do generate some noise that has been a problem for a few builders. See: http://tinyurl.com/qazl8t Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 14, 2009
My alternator has three connections, one for field, one for 12v excitation, and the B lead. I have the B&C LR3C regulator, overall electrical is a Z19. The alternator was built by a local high performance shop, after talking through the needs of my aircraft. Good bearings and grease, precise tolerances, etc. All those things Bob talks about in his book. The instructions that came with it say: "Alternator has isolated field wires. Either one can be the IGNITION ON 12 volt supply wire. The other to the FIELD CONNECTION on the regulator. The regulator case must be grounded. " Okay, the connections described are for a "pull-down" regulator . . . typical of the built in regulators. The LR3 is a "pull-up" style device. This means that one of your free field leads goes to GROUND instead of 12v excitation. The other field terminal connect to the FIELD lead of the LR3. So what I was planning to do is run a small wire from the B lead on the alternator to one of the alternator's connections, making it the IGNITION ON connection. No, that's what you do for the "pull down" regulator architecture. Take one field lead to ground. Then connect the other tab to the Field connection on the regulator. Yes. That way when I turn on the Master Switch to middle position (batt) it sends 12 volts to the IGNITION ON connection. No, just the B-lead terminal. The field supply delivered through the regulator is still cold until you take the DC PWR MASTER all the way up. The hope being that is supplies the alternator with that 12 volt IGNITION ON voltage. Technically, once modified for legacy functionality as an externally regulated alternator, there is no more "IGN" terminal. Just F1, F2, B and GND (case). I already know that turning the Master Switch to BATT position (or Alt) sends power all the way to the B lead. Yes . . . through your b-lead protection device. ANL, MANL or other fat fuse. What I am not sure about is: do I need to keep that excitation /Ignition on voltage running all the time the engine is running (would it hurt anything if I did)? Or should it be shut off after the engine is started and alternator is producing power? If wired per Z-19 (or any other Z-figure, the DC PWR MASTER switch has control over the alternator. Start BATT only, once engine is running, bring alternator on line. Reverse process at ramp idle before parking the airplane. My Master Switch is exactly as in the Z19, so it controls the on/off of the regulator already. Then it controls the alternator too. If the regulator is unpowered, the alternator is OFF. It is this question of excitation that I am unclear about. Lots of articles talked about the need for an ignition on light as a mandatory component in making some alternators actually operate. This is only for some (in fact very few) alternators with built in regulators. This feature no longer applies to your situation. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
From: "Bob McCallum" <robert.mccallum2(at)sympatico.ca>
Date: May 14, 2009
As Bob N stated in his earlier reply 24 and 28 volt components are interchangeable. (They are the same thing from a practical/functional point of view) just as 12 and 14 volt components are. Items such as contactors, relays, motors, light bulbs etc are just not that voltage sensitive that they are affected by the normal swing of system voltages. Your 24 volt (nominal) system may experience actual measured voltages from a low of say 20 (maybe less) to a high of 28, 29 (maybe more) but all of the nominally rated 24 volt components will function just fine. It's like your house current at home. It may be 110,112, 115,120,125, 130 Volts or thereabouts if you actually measure it, but you don't use different toasters, washing machines, light switches etc for these different values. Standard 120 volt rated devices are close enough. Similarly 24 volt devices are fine for any voltage likely to be present in a 24 /28 volt aircraft. Another Bob Bob McC > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list- > server(at)matronics.com] On Behalf Of Craig Winkelmann > Sent: Thursday, May 14, 2009 9:54 PM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Re: Contactor and Crowbar Ratings > > > Bob: > > Spoke with Bill at B&C. Their 24 volt crowbar trips at 32 VDC. That is OK. > > However, I am having difficulty finding a contactor for a 24 VDC application. The > Stancor ones have a coil voltage of 24 VDC or 36 VDC. However, 28 VDC exceeds the coil > voltage of the 24 VDC unit so it can't work. Also, their 36 VDC contactors will not work > because of the coil voltage being too high to activate it. Bottom line is I need a > contactor with a coil voltage rating of 28 VDC. Other than the Eaton unit (which you are > correct is costly) I am running out of luck. Any ideas? > > Craig > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=244076#244076 > > > > > > > > _- > ===================================================== > ===== > _- > ===================================================== > ===== > _- > ===================================================== > ===== > _- > ===================================================== > ===== > > ________________________________________________________________________________
Date: May 14, 2009
I replaced two ground wires using pop rivets with solid driven rivets. Much tighter connection and it makes me feel better anyway. ________________________________________________________________________________
Date: May 15, 2009
Subject: Of pop rivets and locknuts . . .
I replaced two ground wires using pop rivets with solid driven rivets. Much tighter connection and it makes me feel better anyway. Given that the new joints are 'tighter' is an obvious good thing. But be aware that a rivet is a fastener designed for shear loads. I.e., the shank swells in the hole thus capturing the two sheets radially. But the axial clamping forces are spread over a much smaller area than the nut, screw and washer process described earlier. Thus we have lower retention forces in torque. Further, aluminum rivets are softer than steel fasteners and more likely to loosen under temperature cycles and vibration over time. The gas-tightness of this joint over time is doubtful. We would never use a rivet (of any kind) for making up a life-of-the-airplane electrical connection to airframe in a TC aircraft. I'll refer the readers to Section 15 of AC43-13 http://www.aeroelectric.com/Reference_Docs/FAA/AC43.13-1B_Change1.pdf where one can become deeply immersed in the art of attaching electrical conductors to airframes. I hesitate to offer this reference because it tends to take something simple and make it complicated. But there is value in understanding the design goals along with some processes and materials to achieve them. In addition to the noise reduction benefits for the single-point ground system proposed in Z-15, the processes by which wires get attached to ground are already taken care of by using the fast-on terminals. But once you venture out of the forest-of-tabs ground block, then a rudimentary understanding of the design goals is useful. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 15, 2009
Bob, Thanks very much for that detailed explanation. That will help me plan this weekends activities. Mike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=244135#244135 ________________________________________________________________________________
Date: May 15, 2009
Thanks for the reply. When looking at the Stancor 70-903 data sheet it states the Max Safe Operating Range is 110% of nominal rated voltage. That gives me 26.4 volts. In a 24 volt system, the bus voltage often runs near 28 volts for the alternator to charge the battery. That is over the rating. Additionally, in the Stancor documentation for sizing a contactor, they specifically state a warning about using contactors rated at battery voltage when there is charging taking place. For 12 VDC systems, they make a 15 VDC contactor but have no such beast for a 24 vdc system. Also, Bob, take a look at the URLs in your last post. Some malware or something has changed the url to some odd url. Craig Read this topic online here: http://forums.matronics.com/viewtopic.php?p=244138#244138 ________________________________________________________________________________
Date: May 15, 2009
I didn't see anything about pop rivet grounds in AC43.13-1B-Change1 doc... See Section 15 Grounding and Bonding. I used several plate nut grounds similar to that shown in Tables 11-15 and 11-16 (see attached). Regards, Jay rgf(at)dcn.davis.ca.us wrote: > I am grounding a gizmotron (Dynon pitot heater controller) to a wing rib > with a Fast-On Tab. I used a pop rivet to attach the Tab to the rib, but > then it occurred to me this might not be acceptable. The Tab can rotate > around the rivet, though not freely or loosely. I'm not concerned about the > mechanical properties as much as the electrical. Maybe a tighter connection > is required? > > Having been wrong about almost everything electrical in the past, I thought > I'd post here and get a definitive answer. > > Ralph Finch > Davis, CA > RV-9A QB-SA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=244147#244147 Attachments: http://forums.matronics.com//files/grounds_756.pdf ________________________________________________________________________________
Date: May 15, 2009
OK, after much research, the Gigavac GX11CA it is. I spoke with one of their engineers and it is designed for 28 VDC continuous use. In addition, it is hermetically sealed as an added plus and it has built in spike suppression so it needs no external diodes. There are also models that have an extra contact for switching on an indicator light if wanted. Price is $113 each. So, more that Stancor, less than Kilovac and much less than CH. Thanks for all your help and direction! Craig Read this topic online here: http://forums.matronics.com/viewtopic.php?p=244164#244164 ________________________________________________________________________________
Subject: Marking Wires?
Date: May 15, 2009
I am looking for a way to mark my wires in my Zodiac 601XL. I am just finishing up the body and will begin engine installation soon. Can anyone suggest a method to print on shrink sleeving if possible? I have no idea what one would be called. I had heard there was a way to use a laser printer to do this in some way also. Any other ideas would be welcome. Don -------- Don Merritt- Laredo, Tx Apologies if I seem antagonistic. I believe in the freeflowing ideas and discussions between individuals for assistance in this thing we call life. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=244167#244167 ________________________________________________________________________________
Subject: Crowbar
Date: May 15, 2009
I received my Crowbar OV-14 module along with other parts for my external power project. Perhaps because of the importance of the task, or maybe because of the macho name "Crowbar" I kind of expected a big meaty device with attitude and tatoos. Something that would belong on a De Havilland that McGyver could use to save the world and then cook his dinner. Needless to say I was surprised at the scrawny little twirp that looked like it belonged in a Chinese model airplane. (just funnin' with ya Bob). Nevertheless, my whole life has been doing more with less, so I have 100% confidence in this dohicky, I just have a couple of questions. Is this thingy a one time protector? Does it give its life to an overvoltage and you snip it off like a foreskin and replace it? Or does it reset itself and endure forever? What is the best way to install it? Just wire it in and tie wrap it somewhere? Does anyone have a picture of a proper installation? Thanks in advance. -------- Myron Nelson Mesa, AZ Emp completed, legacy build fuse in progress Read this topic online here: http://forums.matronics.com/viewtopic.php?p=244172#244172 ________________________________________________________________________________
Subject: Re: Marking Wires?
Date: May 15, 2009
Don, I used a laser printer with Arial 7 point type, all caps to make labels.? I would have 4 lines, aligned one below the other.? I cut these labels out, rolled them around the wire, slipped clear tubing over the paper and heat shrunk it. I labeled both ends of each wire. I labeled the first end at the first terminal at my shop bench.? The other end would wait until I knew the wire length to the second terminal.? That was usually in the airplane, just before I installed the final terminal connector.? Experience tells me that adequate labeling is an absolute necessity. Jay Bannister -----Original Message----- From: mosquito56 <mosquito-56(at)hotmail.com> Sent: Fri, 15 May 2009 11:54 am Subject: AeroElectric-List: Marking Wires? I am looking for a way to mark my wires in my Zodiac 601XL. I am just finishing up the body and will begin engine installation soon. Can anyone suggest a method to print on shrink sleeving if possible? I have no idea what one would be called. I had heard there was a way to use a laser printer to do this in some way also. Any other ideas would be welcome. Don -------- Don Merritt- Laredo, Tx Apologies if I seem antagonistic. I believe in the freeflowing ideas and discussions between individuals for assistance in this thing we call life. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=244167#244167 ________________________________________________________________________ Email message sent from CompuServe - visit us today at http://www.cs.com ________________________________________________________________________________
Date: May 15, 2009
you can use a Kroy TubeMarker. It will print on shrink tubing. Look at alliedelec.com Dave-Westlake Village, CA ----- Original Message ----- From: "mosquito56" <mosquito-56(at)hotmail.com> Sent: Friday, May 15, 2009 9:54 AM Subject: AeroElectric-List: Marking Wires? > > > I am looking for a way to mark my wires in my Zodiac 601XL. I am just > finishing up the body and will begin engine installation soon. > > Can anyone suggest a method to print on shrink sleeving if possible? I > have no idea what one would be called. > I had heard there was a way to use a laser printer to do this in some way > also. > > Any other ideas would be welcome. > > Don > > -------- > Don Merritt- Laredo, Tx > Apologies if I seem antagonistic. > I believe in the freeflowing ideas and discussions between individuals > for assistance in this thing we call life. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=244167#244167 > > > ________________________________________________________________________________
Date: May 15, 2009
Hi Don, If you wanted a whole lot of labels with the same marking, I've used Merithian Products Corp. http://www.merithian.com/ For small quantities, printing on white heat shrink tubing with a fine point Sharpie a good job. Bob W. "mosquito56" wrote: > > I am looking for a way to mark my wires in my Zodiac 601XL. I am just finishing up the body and will begin engine installation soon. > > Can anyone suggest a method to print on shrink sleeving if possible? I have no idea what one would be called. > I had heard there was a way to use a laser printer to do this in some way also. > > Any other ideas would be welcome. > > Don > > -------- > Don Merritt- Laredo, Tx > Apologies if I seem antagonistic. > I believe in the freeflowing ideas and discussions between individuals for assistance in this thing we call life. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=244167#244167 > > > > > > > > > > -- N93BD - Rotary Powered BD-4 - http://www.bob-white.com 3.8 Hours Total Time and holding Cables for your rotary installation - http://roblinstores.com/ ________________________________________________________________________________
Date: May 15, 2009
Hi Don, After much frustrated wrapping and securing laser printed name tabs, I found wrapping the wire 180-degrees with packaging tape and placing the name tab between the extended adhesive ends, the loose protected name tab is easier to read than one coaxial with the wire. It's also much easier to do. Just don't go overboard on the marking if it's obvious what the wire's for. Larry McFarland 601HDS at www.macsmachine.com mosquito56 wrote: > > I am looking for a way to mark my wires in my Zodiac 601XL. I am just finishing up the body and will begin engine installation soon. > > Can anyone suggest a method to print on shrink sleeving if possible? I have no idea what one would be called. > I had heard there was a way to use a laser printer to do this in some way also. > > Any other ideas would be welcome. > > Don > > > ________________________________________________________________________________
Subject: Crowbar
Date: May 15, 2009
Myron Very well described, I mean the sensation you had. It was exactly the same I had when I received that CROWBAR OV-14 little black critter. Well, perhaps I couldn't have remembered what McGiver could do with it . :-) Carlos > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list- > server(at)matronics.com] On Behalf Of woxofswa > Sent: sexta-feira, 15 de Maio de 2009 18:22 > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Crowbar > > > I received my Crowbar OV-14 module along with other parts for my external power > project. > > Perhaps because of the importance of the task, or maybe because of the macho > name "Crowbar" I kind of expected a big meaty device with attitude and tatoos. > Something that would belong on a De Havilland that McGyver could use to save > the world and then cook his dinner. > > Needless to say I was surprised at the scrawny little twirp that looked like it > belonged in a Chinese model airplane. > > (just funnin' with ya Bob). > > Nevertheless, my whole life has been doing more with less, so I have 100% > confidence in this dohicky, I just have a couple of questions. > > Is this thingy a one time protector? Does it give its life to an overvoltage and you > snip it off like a foreskin and replace it? Or does it reset itself and endure forever? > > What is the best way to install it? Just wire it in and tie wrap it somewhere? > Does anyone have a picture of a proper installation? > > Thanks in advance. > > -------- > Myron Nelson > Mesa, AZ > Emp completed, legacy build fuse in progress ________________________________________________________________________________
Date: May 15, 2009
Subject: Re: Crowbar
The little pipsqueak should last a long time.. All it has to do is fault the 5A breaker and drag the field pin down (if it has an external regulator). I believe the SCR selected is up to repeated trips without any trauma. If I'm reading the specs correctly, it will handle 16A without problem (with proper cooling). Regards, Matt- > > I received my Crowbar OV-14 module along with other parts for my external > power project. > > Perhaps because of the importance of the task, or maybe because of the > macho name "Crowbar" I kind of expected a big meaty device with attitude > and tatoos. Something that would belong on a De Havilland that McGyver > could use to save the world and then cook his dinner. > > Needless to say I was surprised at the scrawny little twirp that looked > like it belonged in a Chinese model airplane. > > (just funnin' with ya Bob). > > Nevertheless, my whole life has been doing more with less, so I have 100% > confidence in this dohicky, I just have a couple of questions. > > Is this thingy a one time protector? Does it give its life to an > overvoltage and you snip it off like a foreskin and replace it? Or does > it reset itself and endure forever? > > What is the best way to install it? Just wire it in and tie wrap it > somewhere? > Does anyone have a picture of a proper installation? > > Thanks in advance. > > -------- > Myron Nelson > Mesa, AZ > Emp completed, legacy build fuse in progress > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=244172#244172 > > ________________________________________________________________________________
Date: May 15, 2009
Check Ebay for Kroy first. Bruce www.Glasair.org -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Dave Bowman Sent: Friday, May 15, 2009 1:37 PM Subject: Re: AeroElectric-List: Marking Wires? you can use a Kroy TubeMarker. It will print on shrink tubing. Look at alliedelec.com Dave-Westlake Village, CA ----- Original Message ----- From: "mosquito56" <mosquito-56(at)hotmail.com> Sent: Friday, May 15, 2009 9:54 AM Subject: AeroElectric-List: Marking Wires? > > > I am looking for a way to mark my wires in my Zodiac 601XL. I am just > finishing up the body and will begin engine installation soon. > > Can anyone suggest a method to print on shrink sleeving if possible? I > have no idea what one would be called. > I had heard there was a way to use a laser printer to do this in some way > also. > > Any other ideas would be welcome. > > Don > > -------- > Don Merritt- Laredo, Tx > Apologies if I seem antagonistic. > I believe in the freeflowing ideas and discussions between individuals > for assistance in this thing we call life. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=244167#244167 > > > ________________________________________________________________________________
Date: May 15, 2009
Thanks for the reply. When looking at the Stancor 70-903 data sheet it states the Max Safe Operating Range is 110% of nominal rated voltage. That gives me 26.4 volts. In a 24 volt system, the bus voltage often runs near 28 volts for the alternator to charge the battery. Actually 28.5 volts nominal . . . That is over the rating. Additionally, in the Stancor documentation for sizing a contactor, they specifically state a warning about using contactors rated at battery voltage when there is charging taking place. For 12 VDC systems, they make a 15 VDC contactor but have no such beast for a 24 vdc system. I've read the warning and I've observed the performance of these contactors in service since they went into the C-140 back in '46 or so. B&C and I have sold hundreds of these critters for the purpose of providing battery contactor, external power and cross-feed service for many moons . . . and found that they continue to offer satisfactory service in these applications. But if this idea stresses your sensibilities too much, there ARE several alternatives . . . One COULD also craft a after-pull-in power reduction module to emulate the performance of devices like the EV200. A 555 timer and a few jelly-beans would probably make it work. Also, Bob, take a look at the URLs in your last post. Some malware or something has changed the url to some odd url. Looked over my postings as they arrived here and didn't see anything out of the ordinary. Which URL you saw was hosed? Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 15, 2009
Subject: MX20 Vertical stripes - update
I was finally able to replicate the problem with the primary alternator, secondary alternator, and more importantly - running on battery power alone. Contacted Garmin and they suggested I send the unit in - they replaced the display head and it is on its way back to me. Ralph ________________________________________________________________________________
From: "Tom Barter" <kesleyelectric(at)chooseblue.coop>
Date: May 15, 2009
Don, I ended up buying a RhinoPro 5000, which I am very happy with. It will also print on heatshrink tubing. See link below. http://www.ecomofficesupplies.com/ProductInfo~productid~DYM15603.html# These folks have good service and very reasonable shipping for refill supplies. Just a quick plug here. Our EAA chapter, Chapter 94 in Mason City, IA, is sponsoring an Aero Electric Seminar on June 27-28. Refer to Bob's website for details. The hanger is a great facility located right off the taxiway for easy flying or driving. There will be a Saturday evening cookout, should be a great time. Hope to see some of you there. Tom Barter Kesley Electric, Inc. -----Original Message----- I am looking for a way to mark my wires in my Zodiac 601XL. I am just finishing up the body and will begin engine installation soon. Can anyone suggest a method to print on shrink sleeving if possible? I have no idea what one would be called. I had heard there was a way to use a laser printer to do this in some way also. Any other ideas would be welcome. Don -------- Don Merritt- Laredo, Tx Apologies if I seem antagonistic. I believe in the freeflowing ideas and discussions between individuals for assistance in this thing we call life. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=244167#244167 Checked by AVG - www.avg.com 06:16:00 ________________________________________________________________________________
Date: May 15, 2009
At 12:21 PM 5/15/2009, you wrote: > >I received my Crowbar OV-14 module along with other parts for my >external power project. > >Perhaps because of the importance of the task, or maybe because of >the macho name "Crowbar" I kind of expected a big meaty device with >attitude and tatoos. Something that would belong on a De Havilland >that McGyver could use to save the world and then cook his dinner. > >Needless to say I was surprised at the scrawny little twirp that >looked like it belonged in a Chinese model airplane. > >(just funnin' with ya Bob). > >Nevertheless, my whole life has been doing more with less, so I have >100% confidence in this dohicky, I just have a couple of questions. > >Is this thingy a one time protector? Does it give its life to an >overvoltage and you snip it off like a foreskin and replace it? Or >does it reset itself and endure forever? It's job is over less than 100 milliseconds after onset of an OV condition. It forces the 5A field supply breaker open. It will do this many times without breaking a sweat. >What is the best way to install it? Just wire it in and tie wrap it >somewhere? >Does anyone have a picture of a proper installation? Tie-wrap it to a wire bundle. It's okay to let the body hang on the leads. >Thanks in advance. I fussed over packaging for some time. I was looking for a process and materials that provided adequate protection while keeping costs low. When you have an assembled ECB this small Emacs! How's the best way to package it? Potting (full encapsulation) is messy, slow and makes the thing difficult to diagnose for field failures . . . impossible to repair. The double melting wall heat-shrink provides an envelope that can be put on in seconds, offers good shielding from contaminants. It can be cut away for repairs, field failure diagnosis or re-adjustment. Our next line of products will be offered in an enclosure like this: Emacs! I have hundreds of plastic boxes with pre-cut d-sub connector holes in the top. Cost of box and lid is under $2. While the box is glued shut, it's fast to assemble, easy to cut off, easy to replace after repairs are made, etc. I really considered reviving the CbOVM-14 in this housing but that would ADD the costs of enclosure and connector. Not consistent with my design and marketing goals. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
Date: May 15, 2009
Excellent, Sounds like it can't be an alternator noise problem then..I know whan I had painted steel alternator brackets (which produced high resistance ground path between the alt and the engine block) it played havoc with my GNS 430. Finally had the "duh" moment, changed the brackets and voila no more problems. Frank -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ralph E. Capen Sent: Friday, May 15, 2009 11:56 AM Subject: AeroElectric-List: MX20 Vertical stripes - update --> I was finally able to replicate the problem with the primary alternator, secondary alternator, and more importantly - running on battery power alone. Contacted Garmin and they suggested I send the unit in - they replaced the display head and it is on its way back to me. Ralph ________________________________________________________________________________
Subject: Re: Battery Charger as Ground Power
Date: May 15, 2009
Hi Bob, Perhaps you could help me understand what the words were that you saw in the advert that made you think HF item number 99857 might do the job (I understand you'd want to test it to confirm) versus very similar words in the ad for HF item number 42292 that you said definitely won't do the job. Both say they "maintain a full charge without over charging". Below is the description for 99857 from the HF web site * Three-stage fully automatic charging protects and prolongs battery life * Auto on/off trickle charging stage keeps 12 volt batteries fully charged without overcharging * Equipped with overload protection, short circuit protection, and reverse polarity protection for added safety * Also great for maintaining batteries while in storage * Has LED charge indicators * Includes a bracket for permanent mounting and here's the description for 42292 from the HF web site * Use on 12 volt batteries while in storage or during cold weather * Floating circuit maintains a full charge without overcharging * Automatic safety shutoff Is there any way the electron challenged such as myself could tell or do we just have to buy and test - or follow your recommendations. Am I being naive in believing manufacturers claims? Thanks for this and all your other explanations. Tony Babb -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Wednesday, May 13, 2009 7:14 AM Subject: Re: AeroElectric-List: Re: Battery Charger as Ground Power At 06:08 AM 5/12/2009, you wrote: i have 6 or 8 of these little chargers on all my toys. i have noticed on some some that the voltage was too low. i tried once to adjust the voltage but couldn't get anything to turn.i guess i will go back and try again to adjust the voltage on a couple that are too low. on the one that was too high i soldered a diode in line and dropped the voltage. bob noffs On Mon, May 11, 2009 at 8:31 PM, David L. wrote: The little, cheap Harbor Freight "maintainers" work quite well. I have used several. One key point however, ...many of them come set a tad too high in their fixed "float" voltage, to my thinking. I have seen them as high as 13.9 v. The good news, is they can be adjusted to the float voltage that you want. The little controller box should have a back lid that is lightly glued in place. Carefully work a very narrow blade screw driver or other tough, but thin device into the glued seam and work it until the back pops off. Inside is a small circuit board and potentiometer. It may have a spot of RTV on it. Work this loose. Turning the pot CW lowers to float voltage. I like about 13.2 v. Others may want a slightly different setting. I usually locate where the pot slotted screw adjust hole is located next to the little case and drill a 3/16 hole. That way, it can be adjusted from the outside. The little unit is quite stable after you get the setting where you want it. David David's suggestions are worthy of consideration but he doesn't mention specific model numbers from H.F. I've tested several battery charger products from H.F. and found some that were not suited to our tasks. What we're looking for are devices that first "top off" a battery and then "drop to maintenance". This kind of behavior is illustrated in . . . http://www.aeroelectric.com/Pictures/Curves/schumacher_3.jpg This curve is from the Schumacher 1562 series chargers available from WalMart for about $20. There are dozens of other products that produce similar charge/maintenance profiles. This one . . . http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=42292 . . . does not. I found a pot inside to adjust the output voltage . . . but only ONE pot. It's a device suitable for maintaining an already charged battery (adjust it for 13.1 volts) but will not charge a battery. Based on its description and price, this device http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=99857 shows more promise. Haven't had time to go get one and check it out but in the mean time, the Schumacher 1562 is a sure bet http://aeroelectric.com/Pictures/Battery_Chargers/Schumacher_Chargers/156 2.j pg Bob . . . ________________________________________________________________________________
Subject: Wire Sizes Help !!! Which Gauge to use ???
Date: May 15, 2009
I am wiring an airplane and need to know what gauge to use for a 10 amp circuit running about 10 feet of wire ? Also, what size wire should I use for the Molex Connectors I find on my Radio and Transponder ? Thanks, Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=244218#244218 ________________________________________________________________________________
Date: May 15, 2009
Subject: Re: Wire Sizes Help !!! Which Gauge to use ???
At 15:12 5/15/2009, you wrote: >I am wiring an airplane and need to know what gauge to use for a 10 >amp circuit running about 10 feet of wire ? > >Also, what size wire should I use for the Molex Connectors I find on >my Radio and Transponder ? > >Thanks, > >Mike AC 43.13 is your friend, specifically chapter 11. If you don't want to purchase a copy, go here: http://rgl.faa.gov/ click on AC in the upper right then enter 43.13 in the resulting search window. First two hits. Minimum wire gauge for a 10A breaker or fuse is AWG-18. Beyond that you'll need to determine maximum acceptable voltage drop, calculate what the voltage drop for your chosen wire gauge is and then derate for bundle size, total capacity and altitude to ensure your chosen size is acceptable. At least that's what those of us in certified land need to do... Ron Q. ________________________________________________________________________________
Subject: High pitch whine from KLN90 GPS
Date: May 16, 2009
I recently installed a KLN90 GPS (I know its old, but it is better than my old loran) and it has a high pitch whine. I noticed the whine when I was wiring the gps on the bench, thinking I would not hear the noise in the plane-wrong. Would some kind of filter eliminate this or does it need to go to the shop ? I can hear the whine thru the headsets also and it gets annoying. Any ideas ? Thanks in advance, Gary Read this topic online here: http://forums.matronics.com/viewtopic.php?p=244264#244264 ________________________________________________________________________________
Subject: Re: EXP2BUS and non-functioning alternator
Date: May 16, 2009
I discovered that the IG lead to the alternator was only producing 12V when measured disconnected. As soon as a load was applied that went down to 1.5V. It turns out that some filings had got under the legs of an IRF4905 Mosfet and seemed to have shorted the pins. So, new question: Does anyone know how to test whether the cleaned up IRF4905 still works, and what the pinouts might be. There are three legs, but nothing I've read tells me what leg does what. Would I have to remove the IRF4905 from the board to test it's output? Thanks for your help so far, which got me to this point. Ian Read this topic online here: http://forums.matronics.com/viewtopic.php?p=244294#244294 ________________________________________________________________________________
Date: May 16, 2009
Bob, I wanted to update you. After getting a new alternator plug that has the connections I needed, I experimented and rewired the field and ground leads per your suggestions. WhaLa, alternator started outputting about 15 volts. Too high, but a few turns of the LR3C regulator screw has it now outputing 14.2 volts. And if I move the Master Switch to BATT position the alternator stops producing voltage. Like Hannibal Smith always said: 'I love it when a plan comes together'. I have a Z19 system, and here are the measured voltages from various instruments/locations: Digital meter directly on the main battery: 14.23 v Digital meter on the Z23 field wire to cockpit: 1.90 v Digital panel Voltmeter on Ebus: 14.10 v EM2 engine monitor connected to main bus: 14.44 v Is that Z23/field voltage what you might expect? Thanks again, Mike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=244296#244296 ________________________________________________________________________________
Date: May 17, 2009
Subject: Insulation on Welding Wire
All, I'm getting ready to buy my main battery cables and would like some advice on which insulation to choose.- I've read the discussions that say weldin g cable is good to use for its flexibility and durability, but should I be worried about the temperature range of the insulation?- The choices seem to be neoprene welding cable (good to 90C), thermoplastic rubber welding ca ble (good to 105C), PVC battery cable-(good to 80C), and-"SGX" battery cable (good to 125C).- Any ideas/insight into which of these is the most desirable?- The application is-a 24V system in a Velocity (batteries in the front, engine in the back).- Should I consider using some of the sti ffer battery cable for the run from the batteries to the firewall-mounted s tarter contactor and then welding cable from the contactor to the starter m otor? - Also, Waytek has some pretty good prices on these, but only sell in quantit ies greater than 100ft, does anyone know a good source that won't break the bank? - Thanks, Dan=0A=0A=0A ________________________________________________________________________________
Subject: Re: Insulation on Welding Wire
Date: May 17, 2009
Dan, I got my welding cable (~30') at Grainger for what I thought was a very reasonable price. Jay Bannister -----Original Message----- From: D Fritz <dfritzj(at)yahoo.com> Sent: Sun, 17 May 2009 11:11 am Subject: AeroElectric-List: Insulation on Welding Wire All, I'm getting ready to buy my main battery cables and would like some advice on which insulation to choose.? I've read the discussions that say welding cable is good to use for its flexibility and durability, but should I be worried about the temperature range of the insulation?? The choices seem to be neoprene welding cable (good to 90C), thermoplastic rubber welding cable (good to 105C), PVC battery cable?(good to 80C), and?"SGX" battery cable (good to 125C).? Any ideas/insight into which of these is the most desirable?? The application is?a 24V system in a Velocity (batteries in the front, engine in the back).? Should I consider using some of the stiffer battery cable for the run from the batteries to the firewall-mounted starter contactor and then welding cable from the contactor to the starter motor? ? Also, Waytek has some pretty good prices on these, but only sell in quantities greater than 100ft, does anyone know a good source that won't break the bank? ? Thanks, Dan ________________________________________________________________________ Email message sent from CompuServe - visit us today at http://www.cs.com ________________________________________________________________________________
Date: May 17, 2009
Hi Dan, I think welding wire is a better product for the heavy cable at the batteries. It's easy to join with silver solder and cupped ring ends. It's flexible and doesn't get brittle because of the fine wires. *January 15 *The order for cable terminals from Wicks came in so the battery contactor to starter was stripped, inserted and was crimped once. Flanges were filed off. Silver solder was added to join cable and terminal and shrink-wrap was added. After refastening it to the contactor, tie-ties reattached the cable to bus support structures through the plane. The instrument panel was removed to the worktable and switches were placed thru the switch template panel to keep them in order. Wires were revisited to shorten them, provide bundled protection, and minimize motion. see link: http://www.macsmachine.com/images/electrical/full/chargebatteryconnection.gif Larry McFarland 601HDS at www.macsmachine.com D Fritz wrote: > All, > I'm getting ready to buy my main battery cables and would like some > advice on which insulation to choose. I've read the discussions that > say welding cable is good to use for its flexibility and durability, > but should I be worried about the temperature range of the > insulation? The choices seem to be neoprene welding cable (good to > 90C), thermoplastic rubber welding cable (good to 105C), PVC battery > cable (good to 80C), and "SGX" battery cable (good to 125C). Any > ideas/insight into which of these is the most desirable? The > application is a 24V system in a Velocity (batteries in the front, > engine in the back). Should I consider using some of the stiffer > battery cable for the run from the batteries to the firewall-mounted > starter contactor and then welding cable from the contactor to the > starter motor? > > Also, Waytek has some pretty good prices on these, but only sell in > quantities greater than 100ft, does anyone know a good source that > won't break the bank? > > Thanks, > Dan > > ________________________________________________________________________________
Date: May 17, 2009
Bob: These urls Even the $high$ contactors have bad days http://tinyurl.com/qmk6gm If you're loosing sleep over it, consider the these EV200 series contactors. They feature automatic coil current reduction after pull-in to reduce continuous power to keep the contactor energized. However, they're about 6X the price of the 70 series device and do generate some noise that has been a problem for a few builders. See: http://tinyurl.com/qazl8t > Read this topic online here: http://forums.matronics.com/viewtopic.php?p=244422#244422 ________________________________________________________________________________
Date: May 17, 2009
Good Afternoon Don, I borrowed a WWII vintage, hand operated, electric wire marker and printed a label about every ten inches on every wire I used. It probably caused me to waste a few feet of wire as I tended to make each wire just a bit longer than needed, but it sure helps a lot during the assembly and for trouble shooting. Using any sort of shrink tube application darn near doubles the diameter of the small wires we tend to need. I tried that and did not care for the extra bulk at all. If I had a very sophisticated airplane to wire, I would watch E-Bay and buy my own wire marking machine! If it's good enough for Boeing and Beechcraft, it's good enough for me! Happy Skies Old Bob AKA Bob Siegfried Ancient Aviator 628 West 86th Street Downers Grove, IL 60516 630 985-8502 Stearman N3977A Brookeridge Air Park LL22 In a message dated 5/15/2009 11:57:50 A.M. Central Daylight Time, mosquito-56(at)hotmail.com writes: I am looking for a way to mark my wires in my Zodiac 601XL. I am just finishing up the body and will begin engine installation soon. Can anyone suggest a method to print on shrink sleeving if possible? I have no idea what one would be called. I had heard there was a way to use a laser printer to do this in some way also. Any other ideas would be welcome. Don **************A strong credit score is 700 or above. See Yours in Just 2 Easy Steps! bcd=Maystrongfooter51709NO115) ________________________________________________________________________________
Date: May 17, 2009
Subject: Contactor and Crowbar Ratings
At 04:42 PM 5/17/2009, you wrote: Bob: These urls Even the $high$ contactors have bad days http://tinyurl.com/qmk6gm . . . and this 6041 series contactor . . . in spite of its pedigree had a very bad day in a King Air about 20 years ago. If you're loosing sleep over it, consider the these EV200 series contactors. They feature automatic coil current reduction after pull-in to reduce continuous power to keep the contactor energized. However, they're about 6X the price of the 70 series device and do generate some noise that has been a problem for a few builders. See: http://tinyurl.com/qazl8t . . . and this is an exemplar 21st century design for a contactor along with a place to purchase the critter. These are "Tiny URL" contractions of the desired address. See: http://tinyurl.com Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 17, 2009
Bob, I wanted to update you. After getting a new alternator plug that has the connections I needed, I experimented and rewired the field and ground leads per your suggestions. WhaLa, alternator started outputting about 15 volts. Too high, but a few turns of the LR3C regulator screw has it now outputing 14.2 volts. And if I move the Master Switch to BATT position the alternator stops producing voltage. Like Hannibal Smith always said: 'I love it when a plan comes together'. I have a Z19 system, and here are the measured voltages from various instruments/locations: Digital meter directly on the main battery: 14.23 v Digital meter on the Z23 field wire to cockpit: 1.90 v Digital panel Voltmeter on Ebus: 14.10 v EM2 engine monitor connected to main bus: 14.44 v Is that Z23/field voltage what you might expect? Yes, depending on RPM and system loads, the field excitation to the alternator can be quite low. At low RPM and high loads, this reading will climb until it reaches at or slightly below bus voltage . . . this is were the alternator is maxed out. A very low reading says the alternator is carrying present loads without breaking a sweat. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 17, 2009
At 05:08 PM 5/16/2009, you wrote: > >I discovered that the IG lead to the alternator was only producing >12V when measured disconnected. As soon as a load was applied that >went down to 1.5V. It turns out that some filings had got under >the legs of an IRF4905 Mosfet and seemed to have shorted the pins. > >So, new question: Does anyone know how to test whether the cleaned >up IRF4905 still works, and what the pinouts might be. There are >three legs, but nothing I've read tells me what leg does what. See: http://www.irf.com/product-info/datasheets/data/irf4905s.pdf >Would I have to remove the IRF4905 from the board to test it's output? I wouldn't think so . . . but I'm mystified as to how an IRF4905 might be used to control an alternator. This is a really husky device. Far larger than necessary to effect control of the IG lead of an alternator. Do you have a schematic of the EXP2BUS product? I wasn't able to find anything useful on the website. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 17, 2009
Subject: Re: High pitch whine from KLN90 GPS
At 09:43 AM 5/16/2009, you wrote: > >I recently installed a KLN90 GPS (I know its old, but it is better >than my old loran) and it has a high pitch whine. I noticed the >whine when I was wiring the gps on the bench, thinking I would not >hear the noise in the plane-wrong. Would some kind of filter >eliminate this or does it need to go to the shop ? I can hear the >whine thru the headsets also and it gets annoying. Any ideas ? You need to deduce the propagation mode for the noise as described in chapter 16. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 17, 2009
From: Mike Fontenot <mikef(at)apexconsultingservices.com>
Bob, Thanks again for the information on regulators (pull up/pull down), and the way to wire it up. Sure feels good to have the system really working. This list is great! Mike On Sun, May 17, 2009 at 8:04 PM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > nuckolls.bob(at)aeroelectric.com> > > > Bob, > > > I wanted to update you. After getting a new alternator plug that has the > connections I needed, I experimented and rewired the field and ground leads > per your suggestions. > > > WhaLa, alternator started outputting about 15 volts. Too high, but a few > turns of the LR3C regulator screw has it now outputing 14.2 volts. And if I > move the Master Switch to BATT position the alternator stops producing > voltage. Like Hannibal Smith always said: 'I love it when a plan comes > together'. > > > I have a Z19 system, and here are the measured voltages from various > instruments/locations: > > Digital meter directly on the main battery: 14.23 v > Digital meter on the Z23 field wire to cockpit: 1.90 v > Digital panel Voltmeter on Ebus: 14.10 v > EM2 engine monitor connected to main bus: 14.44 v > > > Is that Z23/field voltage what you might expect? > > Yes, depending on RPM and system loads, the > field excitation to the alternator can be quite > low. At low RPM and high loads, this reading > will climb until it reaches at or slightly > below bus voltage . . . this is were the alternator > is maxed out. A very low reading says the alternator > is carrying present loads without breaking a > sweat. > > > Bob . . . > > ----------------------------------------) > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > ---------------------------------------- > > -- Mike =============================== Mike Fontenot Apex Consulting & Services LLC Lakewood, Colorado 303 / 731-6645 mikef AT apexconsultingservices DOT com =============================== ________________________________________________________________________________
Subject: Re: LR3 regulator Amperage indications
Date: May 18, 2009
Bob, I am now convinced that the variations were real. I inserted an ammeter into the field line, while the engine was stopped. Got a reading of 3.5 amps. Then took the plane out, fired it up with the ammeter in place, and when the alternator switch was turned on, the current went to 3.5 amps for a very short time, then dropped to zero. At that point, it stayed at zero, and the battery would not charge. Put plane back in hanger, and did some static measurements. Voltage from LR-3 to field circuit breaker ~4.5 volts Voltage at connector to alternator (black plug) ~4.5V Resistance to ground through the leads that field current plugs into varies (jumps around) and then often goes to open circuit. Could the slip rings be contaminated or not in contact? Comments? Bill Schertz KIS Cruiser #4045 N343BS Phase I testing ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Sent: Friday, May 08, 2009 3:31 PM Subject: Re: AeroElectric-List: LR3 regulator Amperage indications > > > At 10:33 AM 5/8/2009, you wrote: >>Bob, >>The heavy B lead comes off the B&C alternator, and passes through a sensor >>supplied by Blue Mountain avionics, which I believe is a Hall effect >>transducer, and then goes to the Batteries. The Voltage is measured at >>the Main buss. >> >>I am enclosing the output from the last flight showing the variations. > > Those traces are almost certainly plagued with data sampling > artifacts polluted by noise. There's no way that the "real" > numbers are that trashy. Have you explored the R/C filtering > I suggested? How many bits of resolution does the data > acquisition system offer? > > > Bob . . . > > ----------------------------------------) > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > ---------------------------------------- > > > ________________________________________________________________________________
Subject: 12 Volt .vs. 24 Volt
Date: May 18, 2009
I have a feeling that this subject has been discussed before, but I need help deciding on a voltage system for my Velocity. I intend a robust electrical system to support a high end IFR panel. The highest draw item will probably be an electric hydraulic pump which pulls about 30 amps at 12 volts. I know a 24 volt will save some weight in wiring because of the lower amperage. However, after reading Bob's response to a Blue Mountain article http://www.aeroelectric.com/articles/richter/response_1.pdf the weight saved appears minimal. I don't know for sure, but I have a feeling that the vast majority of OBAM airplanes are built around 12 volt systems. My question is, why do the likes of Cessna and Cirrus build their single engine airplanes with 24 volt systems? Thanks...Brooke ________________________________________________________________________________
Date: May 18, 2009
Similarity of construction. Bruce Glasair III (28v) www.Glasair.org -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Brooke Wolf Sent: Monday, May 18, 2009 9:40 AM Subject: AeroElectric-List: 12 Volt .vs. 24 Volt I have a feeling that this subject has been discussed before, but I need help deciding on a voltage system for my Velocity. I intend a robust electrical system to support a high end IFR panel. The highest draw item will probably be an electric hydraulic pump which pulls about 30 amps at 12 volts. I know a 24 volt will save some weight in wiring because of the lower amperage. However, after reading Bob's response to a Blue Mountain article http://www.aeroelectric.com/articles/richter/response_1.pdf the weight saved appears minimal. I don't know for sure, but I have a feeling that the vast majority of OBAM airplanes are built around 12 volt systems. My question is, why do the likes of Cessna and Cirrus build their single engine airplanes with 24 volt systems? Thanks...Brooke ________________________________________________________________________________
Date: May 18, 2009
> I have a feeling that this subject has been discussed before, but I need help deciding on a voltage system for my Velocity. I intend a robust electrical system to support a high end IFR panel. The highest draw item will probably be an electric hydraulic pump which pulls about 30 amps at 12 volts. I know a 24 volt will save some weight in wiring because of the lower amperage. However, after reading Bob's response to a Blue Mountain article http://www.aeroelectric.com/articles/richter/response_1.pdf the weight saved appears minimal. I don't know for sure, but I have a feeling that the vast majority of OBAM airplanes are built around 12 volt systems. My question is, why do the likes of Cessna and Cirrus build their single engine airplanes with 24 volt systems? Thanks...Brooke I wired a Velocity XL RG for a friend as a 12v system. Dual B&C alternators and Regulators. No issues for over four years and five hundred hours. Peter ________________________________________________________________________________
Date: May 18, 2009
Bob, I have the installation manual (attached) but it doesn't have a conventional circuit diagram. There is a logical layout in Figure 7, and a physical layout in Figure 3 (the IRF4905 is at J17) and a photo on the front page, which also shows it's location. There is evidence that the track leading from the Source pin on the IRF4905 has overheated, but I have yet to check it for continuity (meter is at the airport). Ian > > At 05:08 PM 5/16/2009, you wrote: > > > >I discovered that the IG lead to the alternator was only producing > >12V when measured disconnected. As soon as a load was applied that > >went down to 1.5V. It turns out that some filings had got under > >the legs of an IRF4905 Mosfet and seemed to have shorted the pins. > > > >So, new question: Does anyone know how to test whether the cleaned > >up IRF4905 still works, and what the pinouts might be. There are > >three legs, but nothing I've read tells me what leg does what. > > See: > > http://www.irf.com/product-info/datasheets/data/irf4905s.pdf > > > >Would I have to remove the IRF4905 from the board to test it's output? > > I wouldn't think so . . . but I'm mystified as to how > an IRF4905 might be used to control an alternator. This > is a really husky device. Far larger than necessary > to effect control of the IG lead of an alternator. Do > you have a schematic of the EXP2BUS product? I wasn't > able to find anything useful on the website. > > > Bob . . . > > ----------------------------------------) > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > ---------------------------------------- > > > > > > ________________________________________________________________________________
Subject: Re: 12 Volt .vs. 24 Volt
Date: May 18, 2009
Why 24 v. systems.... in the commercial world it is usually about costs and profits. Less copper used, less cost. David ----- Original Message ----- From: "Bruce Gray" <Bruce(at)Glasair.org> Sent: Monday, May 18, 2009 7:01 AM Subject: RE: AeroElectric-List: 12 Volt .vs. 24 Volt > > Similarity of construction. > > Bruce > Glasair III (28v) > www.Glasair.org > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of > Brooke Wolf > Sent: Monday, May 18, 2009 9:40 AM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: 12 Volt .vs. 24 Volt > > > I have a feeling that this subject has been discussed before, but I > need help deciding on a voltage system for my Velocity. I intend a > robust electrical system to support a high end IFR panel. The highest > draw item will probably be an electric hydraulic pump which pulls > about 30 amps at 12 volts. I know a 24 volt will save some weight in > wiring because of the lower amperage. However, after reading Bob's > response to a Blue Mountain article > > http://www.aeroelectric.com/articles/richter/response_1.pdf > > the weight saved appears minimal. I don't know for sure, but I have a > feeling that the vast majority of OBAM airplanes are built around 12 > volt systems. My question is, why do the likes of Cessna and Cirrus > build their single engine airplanes with 24 volt systems? > > Thanks...Brooke > > > ________________________________________________________________________________
From: "ROGER & JEAN CURTIS" <mrspudandcompany(at)verizon.net>
Date: May 18, 2009
Similarity of construction. (Please elaborate!) Bruce Glasair III (28v) www.Glasair.org I have a feeling that this subject has been discussed before, but I need help deciding on a voltage system for my Velocity. I intend a robust electrical system to support a high end IFR panel. The highest draw item will probably be an electric hydraulic pump which pulls about 30 amps at 12 volts. I know a 24 volt will save some weight in wiring because of the lower amperage. However, after reading Bob's response to a Blue Mountain article http://www.aeroelectric.com/articles/richter/response_1.pdf the weight saved appears minimal. I don't know for sure, but I have a feeling that the vast majority of OBAM airplanes are built around 12 volt systems. My question is, why do the likes of Cessna and Cirrus build their single engine airplanes with 24 volt systems? Thanks...Brooke ________________________________________________________________________________
Date: May 18, 2009
Subject: Speaking of W-R/RBM/Stancore Contactors . . .
FYI . . . I've become aware of a failure internal to a 3-terminal White-Rogers/RBM Controls contactor that shorted the coil stud to the contactor's floating conductor ring. This caused the contactor to "buzz" and ultimately burned the wire between the contactor and the battery master switch. Artifacts of arcing are visible in: http://aeroelectric.com/Pictures/Failures/W-R_RBM_3-Terminal_2s.jpg The solder lug that attaches to the coil wire is oriented UP toward the conductor ring and then formed over for clearance. At first blush, I would suspect that this solder lug was improperly assembled at the factory . . . it could have been laid over 90-degrees and still provided for coil lead termination with MUCH more clearance to the fat copper conductor ring. To understand the internal construction of this product I'll refer the readers to images at: http://www.aeroelectric.com/Pictures/Contactors/S701-1a.jpg http://www.aeroelectric.com/Pictures/Contactors/S701-1b.jpg http://www.aeroelectric.com/Pictures/Contactors/S701-1c.jpg http://www.aeroelectric.com/Pictures/Contactors/S701-1d.jpg http://www.aeroelectric.com/Pictures/Contactors/S701-1e.jpg http://www.aeroelectric.com/Pictures/Contactors/S701-1f.jpg These photos are for a later configuration of the 3 and 4- terminal contactors. The tiny coil wire is not even visible and ample clearances are maintained between coil terminal hardware and conductor ring by a molded nylon terminal housing. The 'Connection (and to the best of my knowledge B&C) has never sold contactors with the earlier terminal configuration. The failed contactor had a date code of 9515; 15th week of 1995). Every 4-terminal device I've torn down featured later configuration for coil terminals visible in photos above. It's also a fair bet that older versions of the contactor described in the failure analysis were assembled with more attention to detail for positioning the solder lug. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 18, 2009
At 10:44 AM 5/18/2009, you wrote: > >Why 24 v. systems.... in the commercial world it is usually about >costs and profits. Less copper used, less cost. >David > Close. When I went to work for Cessna in '64, we had 14v airplanes (150, 172) and 28v airplanes (182, 206, 210). When you need to run high-energy electro-whizzies you can get more WATTS of engine driven power from essentially the same WEIGHT of system if it's 28v. But as quantities of all airplanes sold dwindled, it was economically more efficient to simply install the same hardware in all aircraft. The alternators were the same size and weight, batteries could be sized to the task for total energy stored. Common landing lights, nav lights, strobe kits, etc made for fewer line items of electrical goodies in inventory and more wider applicability of fewer parts for field spares. It had nothing to do with any practical level of weight savings. We kinda like 14v stuff in the OBAM market: unlike the uniquely aircraft "pallet of paints" for 28V hardware, 14V automotive hardware is stocked in thousands of varieties and sources virtually everywhere on the planet. The "improved performance" and "lighter weight" canards are difficult to measure/prove without carefully detailed studies with slice-n-dice instrumentation. For us get-in-n-go airplane drivers, the 14 vs. 28 volt differences are not readily observable. So the big driver is simply cost of ownership in terms of $acquisition$ and $time$ to maintain. 14v has it hands down. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 18, 2009
Good Afternoon, Definitely NOT 'Lectric Bob here! I DO like twenty-four volt systems. I also agree that any weight saving is probably minimal on an overall basis, nevertheless, I do subscribe to the theory that ounces count. Twenty-four volts allows us to use lighter weight starters, alternators, wires, even relays. The trouble is that most twenty-four volt units weigh as much as their twelve volt counterparts. If you want to take full advantage of a twenty-four volt system you also have to use lighter components. If thirty amps at twelve volts will handle all of your aircraft requirements, all you need is fifteen amps with a twenty-four volt system. How many fifteen amp alternators do you see available? If you go ahead and use a thirty amp twenty-four volt alternator, you have not taken full advantage of the weight saving capabilities of the twenty-four volt regime. Cessna went to twenty-four volts for everything from the 152 on up many years ago. It was cheaper and lighter for the whole fleet and only having to deal with twenty-four volt components made inventory control a lot easier. Commonality of parts and all of the economies that breeds! If you want to be able to jump start your airplane form a twelve volt car, twenty-four volts may not be for you. Personally, If I ever have the feeling that I need a jump start for my airplane, I would also determine that I had made some sort of error in managing my flying machine. If I leave the master on and deplete the battery, I will pull the battery, have it properly serviced, and chalk the experience up to my own stupidity. (I have, unfortunately for me, had to do that more than once.) What I have NOT done, however, is jump start my airplane! If I need the battery at all, I want it to be fully charged and properly serviced before I fly. Happy Skies Old Bob AKA Bob Siegfried Ancient Aviator 628 West 86th Street Downers Grove, IL 60516 630 985-8502 Stearman N3977A Brookeridge Air Park LL22 In a message dated 5/18/2009 12:07:06 P.M. Central Daylight Time, mrspudandcompany(at)verizon.net writes: Similarity of construction. (Please elaborate!) Bruce Glasair III (28v) www.Glasair.org I have a feeling that this subject has been discussed before, but I need help deciding on a voltage system for my Velocity. I intend a robust electrical system to support a high end IFR panel. The highest draw item will probably be an electric hydraulic pump which pulls about 30 amps at 12 volts. I know a 24 volt will save some weight in wiring because of the lower amperage. However, after reading Bob's response to a Blue Mountain article http://www.aeroelectric.com/articles/richter/response_1.pdf the weight saved appears minimal. I don't know for sure, but I have a feeling that the vast majority of OBAM airplanes are built around 12 volt systems. My question is, why do the likes of Cessna and Cirrus build their single engine airplanes with 24 volt systems? Thanks...Brooke **************A Good Credit Score is 700 or Above. See Yours in Just 2 Easy Steps! =Mayfooter51809NO115) ________________________________________________________________________________
Date: May 18, 2009
And don't forget to add that you can save much more weight in the operation of your aircraft by going on a diet! Drop 10 to 15 pounds off your personal frame and it will make up for many many incremental weight saving devices in your airframe. Steve ________________________________________________________________________ On May 18, 2009, at 11:23 AM, Robert L. Nuckolls, III wrote: > The "improved performance" and "lighter weight" > canards are difficult to measure/prove without > carefully detailed studies with slice-n-dice > instrumentation. For us get-in-n-go airplane > drivers, the 14 vs. 28 volt differences are > not readily observable. So the big driver is > simply cost of ownership in terms of $acquisition$ > and $time$ to maintain. 14v has it hands down. > > > Bob . . . ________________________________________________________________________________
Date: May 18, 2009
Sorry, poor choice of words on my part. What I meant was "Commonality of Manufacturing". It easier for the factory to use one battery, one relay, one bulb, one starter, across the entire line than a mixed bag for each different aircraft. Where 28v has 14v beat is in delivery of power. I remember flying my 14v C177RG at night with everything, including all the lights turned on. When I reached for the gear lever and flipped it down, everything went dim! Just about every 14v RG airplane I've flown does that. Not the 28v ones, just the 14v. Power, when you need it, you need it! Bruce www.Glasair.org -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] Sent: Monday, May 18, 2009 10:58 AM Subject: RE: AeroElectric-List: 12 Volt .vs. 24 Volt Similarity of construction. (Please elaborate!) Bruce Glasair III (28v) www.Glasair.org I have a feeling that this subject has been discussed before, but I need help deciding on a voltage system for my Velocity. I intend a robust electrical system to support a high end IFR panel. The highest draw item will probably be an electric hydraulic pump which pulls about 30 amps at 12 volts. I know a 24 volt will save some weight in wiring because of the lower amperage. However, after reading Bob's response to a Blue Mountain article http://www.aeroelectric.com/articles/richter/response_1.pdf the weight saved appears minimal. I don't know for sure, but I have a feeling that the vast majority of OBAM airplanes are built around 12 volt systems. My question is, why do the likes of Cessna and Cirrus build their single engine airplanes with 24 volt systems? Thanks...Brooke ________________________________________________________________________________
Subject: Re: Modifying the Piper plug
Date: May 18, 2009
Bob, I am going to mount the receptacle close to the battery and run a #4awg right to the battery ground. As such, would the brass plate washer still be advised? Thanks for all your help. -------- Myron Nelson Mesa, AZ Emp completed, legacy build fuse in progress Read this topic online here: http://forums.matronics.com/viewtopic.php?p=244565#244565 ________________________________________________________________________________
From: "Rick Titsworth" <rtitsworth(at)mindspring.com>
Date: May 18, 2009
If you're thinking heated prop, Elec air conditioning, Elec cabin heat, heated seals, or other high-energy goodies, then a 24V system/alternator offers twice the "power" for roughly the same system weight as a 12v alternator. It's not the (potential) smaller wire savings that is significant/relevant, rather it's twice the available power from the same weight alternator, contactors, etc (i.e. the heavy items). This is also perhaps a consideration if you're planning on a small backup (B&C type) alternator. The 24v version again has twice the available "power" as the 12v (same weight/package) - i.e. more things you can drive on the E-bus. It used to be that 24V goodies were hard to come by. However, an evening with an aircraft spruce (or west marine) catalog will revel that many common items are now available 12v or 24v (14/28) for the same price. More over, most modern avionics items now operate over the entire 12-28 range. With some "shopping", perhaps the only items that needs converting down to 12v is the cigarette lighter port and Ray Allen trim tab servos. .02 -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Monday, May 18, 2009 2:24 PM Subject: Re: AeroElectric-List: 12 Volt .vs. 24 Volt At 10:44 AM 5/18/2009, you wrote: > >Why 24 v. systems.... in the commercial world it is usually about >costs and profits. Less copper used, less cost. >David > ________________________________________________________________________________
Date: May 18, 2009
Subject: 12 Volt vs. 24 Volt
At 08:06 PM 5/18/2009, you wrote: If you're thinking heated prop, Elec air conditioning, Elec cabin heat, heated seals, or other high-energy goodies, then a 24V system/alternator offers twice the "power" for roughly the same system weight as a 12v alternator. It's not the (potential) smaller wire savings that is significant/relevant, rather it's twice the available power from the same weight alternator, contactors, etc (i.e. the heavy items). Which reminds me of advice I've offered in years past but worth repeating again: The first task for crafting your electrical system is to craft a load analysis. If your maximum cruising load is expected to exceed 1000 watts, then PERHAPS a 28v system is called for. In the past 20 years, I've been directly involved in crafting only two 28v OBAM aircraft. One was a LongEz where the owner wanted to fly a lot in the northern climes. A 100 amp, 28v alternator was included to over about 200 watts of energy to run the airplane . . . and 2,000 watts for toe heaters! The other was a Lancair IV with electrically driven air conditioning. But even this system pretty low duty cycle. For all the weight, cost and complexity of an air conditioner, it operates an average of 30 minutes per flight cycle in hot weather. The rest of the time, it was dead weight. The 14/28 debate really isn't a debate if you need the energy. But with continuing advances in LED lighting, LCD under glass instruments, etc the energy required to run the vast majority of the OBAM fleet has been going down. It's a rare airplane that needs more than 500 watts (40A at 14v) continuous running loads. Up to twice that load is easily carried by modern automotive alternators. There are a lot of cars coming off the line these days with 100+ amp alternators on them. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 18, 2009
At 07:58 PM 5/18/2009, you wrote: > >Bob, > >I am going to mount the receptacle close to the battery and run a >#4awg right to the battery ground. As such, would the brass plate >washer still be advised? Some kind of backing plate is called for. You need the structural benefits of the backing plate to double up the skin and improve conductivity of the pot-metal jack-housing to cranking currents. But if you want to make it out of aluminum, that's okay too . . . in fact probably better. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 18, 2009
Subject: Re: 12 Volt vs. 24 Volt
As more and varied low current draw devices become available, do you see PV in the equation? On Mon, May 18, 2009 at 7:23 PM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > nuckolls.bob(at)aeroelectric.com> > > At 08:06 PM 5/18/2009, you wrote: > rtitsworth(at)mindspring.com> > > If you're thinking heated prop, Elec air conditioning, Elec cabin heat, > heated seals, or other high-energy goodies, then a 24V system/alternator > offers twice the "power" for roughly the same system weight as a 12v > alternator. It's not the (potential) smaller wire savings that is > significant/relevant, rather it's twice the available power from the same > weight alternator, contactors, etc (i.e. the heavy items). > > Which reminds me of advice I've offered in > years past but worth repeating again: The > first task for crafting your electrical system > is to craft a load analysis. If your maximum > cruising load is expected to exceed 1000 watts, > then PERHAPS a 28v system is called for. > > In the past 20 years, I've been directly > involved in crafting only two 28v OBAM > aircraft. One was a LongEz where the owner > wanted to fly a lot in the northern climes. > A 100 amp, 28v alternator was included to > over about 200 watts of energy to run the > airplane . . . and 2,000 watts for toe > heaters! > > The other was a Lancair IV with electrically > driven air conditioning. But even this system > pretty low duty cycle. For all the weight, cost > and complexity of an air conditioner, it operates > an average of 30 minutes per flight cycle in > hot weather. The rest of the time, it was dead > weight. > > The 14/28 debate really isn't a debate if you > need the energy. But with continuing advances > in LED lighting, LCD under glass instruments, > etc the energy required to run the vast majority > of the OBAM fleet has been going down. It's a > rare airplane that needs more than 500 watts > (40A at 14v) continuous running loads. Up to > twice that load is easily carried by modern > automotive alternators. There are a lot of > cars coming off the line these days with 100+ > amp alternators on them. > > > Bob . . . > > ----------------------------------------) > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > ---------------------------------------- > > ________________________________________________________________________________
Date: May 19, 2009
Subject: Re: Contactor and Crowbar Ratings
Bob,Why would the Tyco EV200 create noise in some applications and how could this problem be mitigated? On Sun, May 17, 2009 at 16:42, Craig Winkelmann wrote: > capav8r(at)gmail.com> > > Bob: > > These urls > > Even the $high$ contactors have bad days > > http://tinyurl.com/qmk6gm > > If you're loosing sleep over it, consider the > these EV200 series contactors. They feature > automatic coil current reduction after pull-in > to reduce continuous power to keep the contactor > energized. However, they're about 6X the price > of the 70 series device and do generate some > noise that has been a problem for a few builders. > See: > > http://tinyurl.com/qazl8t > > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=244422#244422 > > ________________________________________________________________________________
Date: May 19, 2009
Thanks to everybody for their comments. It is much easier to make informed decisions when armed with the insight that this group provides. Thanks to Bob and everybody else for making this possible! Brooke ________________________________________________________________________________
Date: May 19, 2009
Okay, very good. Be advised that AEC is offering stand-alone crowbar ov modules. We've sorted through some fabrication enhancements and will put them in the catalog soon. In the mean time, you can order them by emailing me directly. Bob . . . Bob, I will be needing 2 OV modules, one for my alternator circuit and one for ground power. Do you have pricing for your modules? Are they available both in kit and assembled form? Roger ________________________________________________________________________________
Date: May 19, 2009
At 03:33 AM 5/19/2009, you wrote: >Bob, >Why would the Tyco EV200 create noise in some applications and how >could this problem be mitigated? "Noise" by definition is the artifact of rapidly changing current flow that propagates from some antagonist to some victim. This is described in more detail in the book. Sometimes the 'noise' is an intentional byproduct of a useful radiation. For example, you radiate strong signals from your comm and transponder antennas to achieve a useful purpose. In some cases, the stronger the radiation, the better. However, this radio frequency energy can become a nuisance too. Its sorta like being pleased that your wheat fields are benefiting from a good rain shower but the holes in your roof are a source of concern. The EV200 (and similar devices) use an transistor that's turned on with varying duty cycle to reduce current in the contactor coil after pull-in is achieved. The speed of the switching device, the amount of current it carries, the area of its "antennas", the frequency of operation and the artifacts of current modulation flowing out on the wires are all ingredients that go into a recipe for problems. The stuff that gets outside the product needs to be evaluated for potential nuisance if not hazard. This is part of what DO-160/Mil-STD-704 is about. In the case of the EV200, the occasional OBAM aircraft builder has heard the duty cycle switching of the EV200's control electronics as a "buzz" in their audio system. I've not been able to put my hands on one of these problems to deduce the magnitude of potential noise or track down the specific propagation path. However, it's a pretty fair bet that poor grounding techniques are the probable cause. I wouldn't shy away from an EV200 installation based on a reported noise issue. I've never found a noise problem I couldn't fix. I've found problems that the customer decided not to fix because it involved $millions$ of design changes to an airframe. But in our airplanes, the risk of noise is low, the cost of the solution is not great. In response to our List discussion late last week on the ratings for the lowly el-cheeso contactors, I've begun a design for a contactor power management module. This device will be assembled much like the over voltage modules . . . quasi-potted in double walled heat shrink. It's easy to add this device to an el-cheeso contactor and achieve improved electrical performance that emulates the EV200. At the same time, it separates control electronics from the contactor. If the contactor ever requires replacing, then you don't need to buy new electronics. Similarly, if the electronics craps, you don't toss out a perfectly good contactor. See: http://www.aeroelectric.com/Catalog/AEC/9024/9024-700-1P1.pdf I have an upcoming opportunity to get into the EMC lab with a customer's product for DO-160 conducted emissions testing. I'm planning to piggy-back a couple of my projects into the same testing session. If my software guru can get me some exemplar chips for the 9024, I can do an EMC look-see to confirm my confidence in its OBAM aircraft friendly demeanor. This module will drastically reduce the temperature rise on the RBM/W-R/Stancore contactors. This not only reduces energy required to keep the critter closed, it honors the manufacturer's ratings limits for use in systems with bus voltages high enough to charge batteries. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 19, 2009
At 10:32 PM 5/18/2009, you wrote: > >As more and varied low current draw devices become available, do you >see PV in the equation? Photovoltaic? Not soon. The power/weight ratio for PV generators is not attractive, yet. Yeah, there are some demonstration projects out there. http://www.greenjobs.com/Public/IndustryNews/inews04432.htm . . . but if you're anything like me, flying at night and on cloudy days is not an option I'd want to give up. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
From: Valin & Allyson Thorn <thorn(at)starflight.aero>
Date: May 19, 2009
Thanks, Allyson On May 18, 2009, at 9:23 PM, "Robert L. Nuckolls, III" wrote: > > > > At 08:06 PM 5/18/2009, you wrote: > > > > If you're thinking heated prop, Elec air conditioning, Elec cabin > heat, > heated seals, or other high-energy goodies, then a 24V system/ > alternator > offers twice the "power" for roughly the same system weight as a 12v > alternator. It's not the (potential) smaller wire savings that is > significant/relevant, rather it's twice the available power from the > same > weight alternator, contactors, etc (i.e. the heavy items). > > Which reminds me of advice I've offered in > years past but worth repeating again: The > first task for crafting your electrical system > is to craft a load analysis. If your maximum > cruising load is expected to exceed 1000 watts, > then PERHAPS a 28v system is called for. > > In the past 20 years, I've been directly > involved in crafting only two 28v OBAM > aircraft. One was a LongEz where the owner > wanted to fly a lot in the northern climes. > A 100 amp, 28v alternator was included to > over about 200 watts of energy to run the > airplane . . . and 2,000 watts for toe > heaters! > > The other was a Lancair IV with electrically > driven air conditioning. But even this system > pretty low duty cycle. For all the weight, cost > and complexity of an air conditioner, it operates > an average of 30 minutes per flight cycle in > hot weather. The rest of the time, it was dead > weight. > > The 14/28 debate really isn't a debate if you > need the energy. But with continuing advances > in LED lighting, LCD under glass instruments, > etc the energy required to run the vast majority > of the OBAM fleet has been going down. It's a > rare airplane that needs more than 500 watts > (40A at 14v) continuous running loads. Up to > twice that load is easily carried by modern > automotive alternators. There are a lot of > cars coming off the line these days with 100+ > amp alternators on them. > > > Bob . . . > > ----------------------------------------) > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > ---------------------------------------- > > ________________________________________________________________________________
Date: May 19, 2009
Thanks for the replies Larry and Jay.- Has anyone else got any input on t he material of the insulation?- Particularly, would I be buying into exce ssive risk using the "Thermoplastic Rubber" insulated welding wire that's r ated at 80C or do I need to consider going to the 105C or 125C rated materi als?- I don't intend to have an electrical fire, but I like to plan for t he worst and hope for the best... - Da =0A=0A=0A ________________________________________________________________________________
Date: May 19, 2009
At 10:39 AM 5/19/2009, you wrote: >Thanks for the replies Larry and Jay. Has anyone else got any input >on the material of the insulation? Particularly, would I be buying >into excessive risk using the "Thermoplastic Rubber" insulated >welding wire that's rated at 80C or do I need to consider going to >the 105C or 125C rated materials? I don't intend to have an >electrical fire, but I like to plan for the worst and hope for the best... Don't loose any sleep over it. You're not going to start an electrical fire by heating a fat wire. Welding cable is just fine. It's inexpensive and a joy to work with. Wires that burn are the itty-bitty fellers that should have fuses and/or breakers protecting them. Now, the insulation on your wires might CONTRIBUTE to a fuel fed fire but this is exceedingly rare . . . and if you've got a gasoline or oil fed fire going, adding a few ounces of insulation is the least of your worries. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 19, 2009
Subject: EV200 noise
At 03:33 AM 5/19/2009, you wrote: >Bob, >Why would the Tyco EV200 create noise in some applications and how >could this problem be mitigated? "Noise" by definition is the artifact of rapidly changing current flow that propagates from some antagonist to some victim. This is described in more detail in the book. Sometimes the 'noise' is an intentional byproduct of a useful radiation. For example, you radiate strong signals from your comm and transponder antennas to achieve a useful purpose. In some cases, the stronger the radiation, the better. However, this radio frequency energy can become a nuisance too. Its sorta like being pleased that your wheat fields are benefiting from a good rain shower but the holes in your roof are a source of concern. The EV200 (and similar devices) use an transistor that's turned on with varying duty cycle to reduce current in the contactor coil after pull-in is achieved. The speed of the switching device, the amount of current it carries, the area of its "antennas", the frequency of operation and the artifacts of current modulation flowing out on the wires are all ingredients that go into a recipe for problems. The stuff that gets outside the product needs to be evaluated for potential nuisance if not hazard. This is part of what DO-160/Mil-STD-704 is about. In the case of the EV200, the occasional OBAM aircraft builder has heard the duty cycle switching of the EV200's control electronics as a "buzz" in their audio system. I've not been able to put my hands on one of these problems to deduce the magnitude of potential noise or track down the specific propagation path. However, it's a pretty fair bet that poor grounding techniques are the probable cause. I wouldn't shy away from an EV200 installation based on a reported noise issue. I've never found a noise problem I couldn't fix. I've found problems that the customer decided not to fix because it involved $millions$ of design changes to an airframe. But in our airplanes, the risk of noise is low, the cost of the solution is not great. In response to our List discussion late last week on the ratings for the lowly el-cheeso contactors, I've begun a design for a contactor power management module. This device will be assembled much like the over voltage modules . . . quasi-potted in double walled heat shrink. It's easy to add this device to an el-cheeso contactor and achieve improved electrical performance that emulates the EV200. At the same time, it separates control electronics from the contactor. If the contactor ever requires replacing, then you don't need to buy new electronics. Similarly, if the electronics craps, you don't toss out a perfectly good contactor. See: http://www.aeroelectric.com/Catalog/AEC/9024/9024-700-1P1.pdf I have an upcoming opportunity to get into the EMC lab with a customer's product for DO-160 conducted emissions testing. I'm planning to piggy-back a couple of my projects into the same testing session. If my software guru can get me some exemplar chips for the 9024, I can do an EMC look-see to confirm my confidence in its OBAM aircraft friendly demeanor. This module will drastically reduce the temperature rise on the RBM/W-R/Stancore contactors. This not only reduces energy required to keep the critter closed, it honors the manufacturer's ratings limits for use in systems with bus voltages high enough to charge batteries. Bob . . . ________________________________________________________________________________
Date: May 19, 2009
Considering welding wire is subjected to temporary flame, molten hot metal and much abuse, I'd think it's an ideal product to carry the heavy currents you'll be running thru it. The insulation doesn't want to burn unless you've a really hot one going. By then, I doubt you'd want to be there either. I'd rate the risk as very low for welding cable insulation. Larry McFarland 601HDS at www.macsmachine.com D Fritz wrote: > Thanks for the replies Larry and Jay. Has anyone else got any input > on the material of the insulation? Particularly, would I be buying > into excessive risk using the "Thermoplastic Rubber" insulated welding > wire that's rated at 80C or do I need to consider going to the 105C or > 125C rated materials? I don't intend to have an electrical fire, but > I like to plan for the worst and hope for the best... > > Da > ________________________________________________________________________________
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
Date: May 19, 2009
Yes and think of the abuse welding cable takes on the industrial job site or ship yard..I never seen a welding cable sparking to ground in 25 years of construction! Frank At 10:39 AM 5/19/2009, you wrote: >Thanks for the replies Larry and Jay. Has anyone else got any input on >the material of the insulation? Particularly, would I be buying into >excessive risk using the "Thermoplastic Rubber" insulated welding wire >that's rated at 80C or do I need to consider going to the 105C or 125C >rated materials? I don't intend to have an electrical fire, but I like >to plan for the worst and hope for the best... Don't loose any sleep over it. You're not going to start an electrical fire by heating a fat wire. Welding cable is just fine. It's inexpensive and a joy to work with. Wires that burn are the itty-bitty fellers that should have fuses and/or breakers protecting them. Now, the insulation on your wires might CONTRIBUTE to a fuel fed fire but this is exceedingly rare . . . and if you've got a gasoline or oil fed fire going, adding a few ounces of insulation is the least of your worries. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Subject: Marking Wires?
Date: May 19, 2009
I did exactly what Jay described here. For some of the smaller wire runs (20-22AWG) I actually used 2 pieces of heat shrink. The first I would shrink on to give the wire some girth, then I would slip on my label and shrink on another piece to hold the label in place. It is working great so far. Scott R. Shook RV-7A (Building) N696JS (Reserved) _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of jaybannist(at)cs.com Sent: Friday, May 15, 2009 10:26 Subject: Re: AeroElectric-List: Marking Wires? Don, I used a laser printer with Arial 7 point type, all caps to make labels. I would have 4 lines, aligned one below the other. I cut these labels out, rolled them around the wire, slipped clear tubing over the paper and heat shrunk it. I labeled both ends of each wire. I labeled the first end at the first terminal at my shop bench. The other end would wait until I knew the wire length to the second terminal. That was usually in the airplane, just before I installed the final terminal connector. Experience tells me that adequate labeling is an absolute necessity. Jay Bannister -----Original Message----- From: mosquito56 <mosquito-56(at)hotmail.com> Sent: Fri, 15 May 2009 11:54 am Subject: AeroElectric-List: Marking Wires? I am looking for a way to mark my wires in my Zodiac 601XL. I am just finishing up the body and will begin engine installation soon. Can anyone suggest a method to print on shrink sleeving if possible? I have no idea what one would be called. I had heard there was a way to use a laser printer to do this in some way also. Any other ideas would be welcome. Don -------- Don Merritt- Laredo, Tx Apologies if I seem antagonistic. I believe in the freeflowing ideas and discussions between individuals for assistance in this thing we call life. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=244167#244167 _____ size=2 width="100%" align=center> Email message sent from CompuServe - visit us today at http://www.cs.com ________________________________________________________________________________
Date: May 19, 2009
Having had very recent experience of this, just remember that the really neat, shrunk on labels can be fiendishly difficult to read when you're upside down, under the panel, on the tarmac. There is something to be said for larger labels, or even a coded system and a lookup table. Ian Brown Flight testing RV-9A > I did exactly what Jay described here. For some of the smaller wire > runs (20-22AWG) I actually used 2 pieces of heat shrink. The first I > would shrink on to give the wire some girth, then I would slip on my > label and shrink on another piece to hold the label in place. It is > working great so far. > > > Scott R. Shook > RV-7A (Building) > N696JS (Reserved) > > > > ______________________________________________________________________ > From:owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of > jaybannist(at)cs.com > Sent: Friday, May 15, 2009 10:26 > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Marking Wires? > > > > > Don, > > I used a laser printer with Arial 7 point type, all caps to make > labels. I would have 4 lines, aligned one below the other. I cut > these labels out, rolled them around the wire, slipped clear tubing > over the paper and heat shrunk it. I labeled both ends of each wire. I > labeled the first end at the first terminal at my shop bench. The > other end would wait until I knew the wire length to the second > terminal. That was usually in the airplane, just before I installed > the final terminal connector. Experience tells me that adequate > labeling is an absolute necessity. > > Jay Bannister > > > > > > > > > -----Original Message----- > From: mosquito56 <mosquito-56(at)hotmail.com> > To: aeroelectric-list(at)matronics.com > Sent: Fri, 15 May 2009 11:54 am > Subject: AeroElectric-List: Marking Wires? > > > > > > > > > I am looking for a way to mark my wires in my Zodiac 601XL. I am just finishing > > > > up the body and will begin engine installation soon. > > > > > > > > Can anyone suggest a method to print on shrink sleeving if possible? I have no > > > > idea what one would be called. > > > > I had heard there was a way to use a laser printer to do this in some way also. > > > > > > > > > > > > Any other ideas would be welcome. > > > > > > > > Don > > > > > > > > -------- > > > > Don Merritt- Laredo, Tx > > > > Apologies if I seem antagonistic. > > > > I believe in the freeflowing ideas and discussions between individuals for > > > > assistance in this thing we call life. > > > > > > > > > > > > > > > > > > > > Read this topic online here: > > > > > > > > http://forums.matronics.com/viewtopic.php?p=244167#244167 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > size=2 width="100%" align=center> > Email message sent from CompuServe - visit us today at > http://www.cs.com > > > > > http://www.matronics.com/Navigator?AeroElectric-List > http://forums.matronics.com > http://www.matronics.com/contribution > > > > ________________________________________________________________________________
Date: May 19, 2009
A simple and low cost way to mark wires is to use wire number markers (1/4=94 x 1 =BC=94) lengthwise on each end of the wire and then put heat shrink over it. The only down side is that you have to keep a chart showing what each wire number is for. See: http://cableorganizer.com/wire-marker/#features Joe R From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Scott R. Shook Sent: Tuesday, May 19, 2009 10:27 AM Subject: RE: AeroElectric-List: Marking Wires? I did exactly what Jay described here. For some of the smaller wire runs (20-22AWG) I actually used 2 pieces of heat shrink. The first I would shrink on to give the wire some girth, then I would slip on my label and shrink on another piece to hold the label in place. It is working great so far. Scott R. Shook RV-7A (Building) N696JS (Reserved) _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of jaybannist(at)cs.com Sent: Friday, May 15, 2009 10:26 Subject: Re: AeroElectric-List: Marking Wires? Don, I used a laser printer with Arial 7 point type, all caps to make labels. I would have 4 lines, aligned one below the other. I cut these labels out, rolled them around the wire, slipped clear tubing over the paper and heat shrunk it. I labeled both ends of each wire. I labeled the first end at the first terminal at my shop bench. The other end would wait until I knew the wire length to the second terminal. That was usually in the airplane, just before I installed the final terminal connector. Experience tells me that adequate labeling is an absolute necessity. Jay Bannister -----Original Message----- From: mosquito56 <mosquito-56(at)hotmail.com> Sent: Fri, 15 May 2009 11:54 am Subject: AeroElectric-List: Marking Wires? I am looking for a way to mark my wires in my Zodiac 601XL. I am just finishing up the body and will begin engine installation soon. Can anyone suggest a method to print on shrink sleeving if possible? I have no idea what one would be called. I had heard there was a way to use a laser printer to do this in some way also. Any other ideas would be welcome. Don -------- Don Merritt- Laredo, Tx Apologies if I seem antagonistic. I believe in the freeflowing ideas and discussions between individuals for assistance in this thing we call life. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=244167#244167
Email message sent from CompuServe - visit us today at http://www.cs.com http://www.matronics.com/Navigator?AeroElectric-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Date: May 19, 2009
Subject: Re: Marking Wires?
Good Afternoon Ian, I find that one of the advantages to marking directly on the wires such as the big boys do is that if I can't read the label in one spot, there is a good chance I will be able to read it within a foot or two of the termination point. Happy Skies Old Bob AKA Bob Siegfried Ancient Aviator 628 West 86th Street Downers Grove, IL 60516 630 985-8502 Stearman N3977A Brookeridge Air Park LL22 In a message dated 5/19/2009 12:20:34 P.M. Central Daylight Time, ixb(at)videotron.ca writes: Having had very recent experience of this, just remember that the really neat, shrunk on labels can be fiendishly difficult to read when you're upside down, under the panel, on the tarmac. There is something to be said for larger labels, or even a coded system and a lookup table. Ian Brown **************An Excellent Credit Score is 750. See Yours in Just 2 Easy Steps! Excfooter51609NO62) ________________________________________________________________________________
Date: May 19, 2009
At 12:29 PM 5/19/2009, you wrote: >A simple and low cost way to mark wires is to >use wire number markers (1/4 x 1 ) lengthwise >on each end of the wire and then put heat shrink >over it. The only down side is that you have to >keep a chart showing what each wire number is for. Before you spend a lot of $time$ putting numbers on individual wires, think through the expected return on investment. While the wires are waiting to be tied off, a masking tape flag with a sharpie notation of where it goes will get you done. Now, what is the likelihood that you'll benefit from the existence of ANY single wire marking at some time in the future? When you're working with 3" wire bundles of hundreds of wires, yeah . . . but the future maintenance value of individual wire marking is of limited value in a single engine airplane. But if you must . . . B&C still sells the clear heat-shrink kit I used to offer for marking wires like this: http://aeroelectric.com/Pictures/Wiring_Technique/Wire_Marking.jpg You can print columns of labels in 6pt type on full sheets of label material. Pull of the backing sheet, paste to a plastic cutting board. Use x-acto knife to cut out label of interest and attach to wire with clear shrink. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 19, 2009
From: Bill Mauledriver Watson <MauleDriver(at)nc.rr.com>
Subject: Re: Is a pop rivet acceptable for a ground attachment?
Bob detailed out the acceptable practice documented in AC43.13-1b part 11-190. I kept a copy of that page handy as I wired up my first few grounds. (sorry if someone already said this, I'm catching up on email) Bill "back from some r&r" Watson RV10 Ralph Finch wrote: > > I am grounding a gizmotron (Dynon pitot heater controller) to a wing rib > with a Fast-On Tab. I used a pop rivet to attach the Tab to the rib, but > then it occurred to me this might not be acceptable. The Tab can rotate > around the rivet, though not freely or loosely. I'm not concerned about the > mechanical properties as much as the electrical. Maybe a tighter connection > is required? > > Having been wrong about almost everything electrical in the past, I thought > I'd post here and get a definitive answer. > > Ralph Finch > Davis, CA > RV-9A QB-SA > > > ________________________________________________________________________________
Date: May 20, 2009
Jay's think alike- I did the same as Jay Bannister except that I used a sharpie to write onto strips of white plastic that I had cut from a square shaped milk container. The surface of the plastic is slightly rough so that you can easily write on it. The advantage for me was that I didn't have to jump between the PC and the shop. The plastic was about 0.6mm thick and I cut it into strips about 4mm high. This also meant that it was often bigger than the wire which allowed you (with a bit of a tug) to slide the label and clear shrink up and down the wire to where you wanted it as the plastic slightly held the heat shrink off the wire except at the ends. Of course you have to be able to print neatly... Jay Hyde > ----- Original Message ----- > From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> > To: aeroelectric-list(at)matronics.com > Subject: RE: AeroElectric-List: Marking Wires? > Date: Tue, 19 May 2009 12:46:09 -0500 > > > > > At 12:29 PM 5/19/2009, you wrote: > > A simple and low cost way to mark wires is to use wire number markers (1/4 > > x 1 ) lengthwise on each end of the wire and then put heat shrink over it. > > The only down side is that you have to keep a chart showing what each wire > > number is for. > > Before you spend a lot of $time$ putting numbers > on individual wires, think through the expected return > on investment. While the wires are waiting to be tied > off, a masking tape flag with a sharpie notation of > where it goes will get you done. > > Now, what is the likelihood that you'll benefit from > the existence of ANY single wire marking at some > time in the future? When you're working with 3" > wire bundles of hundreds of wires, yeah . . . but > the future maintenance value of individual wire marking > is of limited value in a single engine airplane. But > if you must . . . > > B&C still sells the clear heat-shrink kit I used > to offer for marking wires like this: > > http://aeroelectric.com/Pictures/Wiring_Technique/Wire_Marking.jpg > > You can print columns of labels in 6pt type on > full sheets of label material. Pull of the backing > sheet, paste to a plastic cutting board. Use x-acto > knife to cut out label of interest and attach to > wire with clear shrink. > > > > Bob . . . > > ----------------------------------------) > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > ---------------------------------------- > > > > > ________________________________________________________________________________
Date: May 20, 2009
From: Michael Hilderbrand <m_hilderbrand(at)sbcglobal.net>
Subject: alternator relay connection
Hi everyone, =0A=0ALooking at Z-20 for the Jab 3300 engine, I notice off th e alternator relay the "COM" wire goes to the Starter Contactor.--On my plane I -also have a Batt Contactor.-Is there a-reason I-cannot or should not-connect the COM wire to-the-Batt Contactor instead?-I a m assuming if connected to the starter contactor (like on Z-20) that the- current would still flow-through the-Batt Contactor (for a lack of bett er term - going "up stream") to charge the battery?- =0A-=0AThanks! =0A Michael Hilderbrand=0ADerby, Kansas=0AHttp://www.kansasflying.com ________________________________________________________________________________
Date: May 20, 2009
Subject: Re: alternator relay connection
At 08:46 AM 5/20/2009, you wrote: >Hi everyone, > >Looking at Z-20 for the Jab 3300 engine, I notice off the alternator >relay the "COM" wire goes to the Starter Contactor. On my plane >I also have a Batt Contactor. Is there a reason I cannot or should >not connect the COM wire to the Batt Contactor instead? I am >assuming if connected to the starter contactor (like on Z-20) that >the current would still flow through the Batt Contactor (for a lack >of better term - going "up stream") to charge the battery? Wires are roadways for electrons. You can move intersections between roadways such that the electrons can still get from here to there. If you have a battery contactor on a system with a small alternator, you might want to consider a low-energy contactor like the EV200 we discussed earlier this week . . . or add the Contator Power Manager I spoke of earlier this week. This decision can wait however . . . get everything working first and then think about decorations on the cake. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Subject: Rotax 912ULS Voltage
Date: May 20, 2009
I am a sport pilot and don't fly at night, but took my Zenith 701 /Rotax 912ULS up a few evenings ago just to see how hard it would be to land in the dark. No problem landing, but with all the extra night time stuff on (strobes, 55watt landing light, & cabin lights) plus my normal stuff (intercom, 2GPS's, Dynon 180, ICOM radio, transponder, and intercom) the voltage went down to 11.9 at 3500-rpm and 12.3V at my 4900-rpm cruse. The blinding low voltage light (from aeroelectric's Z16 diagram, which I used for my aircraft) came on for the first time and gave me a scare. My question; is this low voltage situation normal or do I have voltage regulation issues? Without the extra load during daylight flight my voltage runs about 12.9-13.0 V and my battery holds a 12.8V charge. I don't have an extra alternator and just use the internal Rotax coils for power. One guy already told me that what I am getting is the norm with the extra stuff on, and that the Rotax voltage regulator heats up a lot and should not be expected to last very long. Are these things true? Thanks for your advice. Les ________________________________________________________________________________
Date: May 20, 2009
Subject: Re: Rotax 912ULS Voltage
At 01:08 PM 5/20/2009, you wrote: ><lgold@quantum-associates.com> > >I am a sport pilot and don't fly at night, but took my Zenith 701 /Rotax >912ULS up a few evenings ago just to see how hard it would be to land in the >dark. No problem landing, but with all the extra night time stuff on >(strobes, 55watt landing light, & cabin lights) plus my normal stuff >(intercom, 2GPS's, Dynon 180, ICOM radio, transponder, and intercom) the >voltage went down to 11.9 at 3500-rpm and 12.3V at my 4900-rpm cruse. The >blinding low voltage light (from aeroelectric's Z16 diagram, which I used >for my aircraft) came on for the first time and gave me a scare. >My question; is this low voltage situation normal or do I have voltage >regulation issues? If the low votlage light is on (bus less than 13.0 volts) then the alternator is not producing sufficient energy to carry all of the ship's loads AND maintain a battery. >Without the extra load during daylight flight my voltage runs about >12.9-13.0 V and my battery holds a 12.8V charge. This is TOO LOW. No load and engine running should produce a bus voltage of 14.0 MINIMUM, 14.2 to 14.4 is better. With a 13.0V set-point, your alternator is not replenishing the energy used to get the engine started. It's also maintaining your battery in a very low state of charge, probably less than 50% of capacity. > I don't have an extra >alternator and just use the internal Rotax coils for power. One guy already >told me that what I am getting is the norm with the extra stuff on, and that >the Rotax voltage regulator heats up a lot and should not be expected to >last very long. Are these things true? Not quite. That voltage level is too low. You need to add up the real current draw for all accessories that might be on at the same time. These cannot exceed the rating of the alternator (assuming the battery is charged) for the operating RPM . . . Emacs! . . . and should not be more than 75% of that rating if you want the alternator to replenish energy removed before cruising flight RPMs are achieved. The stock rectifier/regulator is marginal for the way we use them. I wish they were a bit more robust. It would add very little to the cost of the product. John Deere has some single phase rectifier/regulators rated in the 30A class. It would be interesting to see how well these might substitute for the stock regulator. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 20, 2009
Hi Bob, Could you please help me with a low voltage problem that I am having in my RV7. Voltage indicators on the Dynon and engine monitor both show fluctuations between 12.5V and 11.5V while in flight. This is something that just started during the last few flights, I have 300h on the airplane with this being the first problem. I have had the ND 60A internally regulated alternator form Vans in the shop and it checked out fine, I also have put in a new battery with no improvements. Airplane wired as per Z11 with an added electronic ignition on the top side Thanks for any suggestions you may have Franz ________________________________________________________________________________
Date: May 20, 2009
Subject: Alternator Failure
At 05:16 PM 5/20/2009, you wrote: >Hi Bob, >Could you please help me with a low voltage problem that I am having >in my RV7. Voltage indicators on the Dynon and engine monitor both >show fluctuations between 12.5V and 11.5V while in flight. These are the voltages you can expect from a battery that is NOT benefiting from support by the alternator. > This is something that just started during the last few flights, I > have 300h on the airplane with this being the first problem. I have > had the ND 60A internally regulated alternator form Vans in the > shop and it checked out fine. If the alternator is okay, then it's deprived of an ON/OFF command that controls it . . . or is otherwise disconnected from the system. With the engine not running but with battery and alternator switches ON, you should measure some voltage close to the battery output at all wires attached to the alternator. If no/low voltage at the b-lead terminal, perhaps your b-lead fuse or current limiter is open. If no/low voltage to the control terminal, then there is a failure in the wiring between that terminal and the bus. > I also have put in a new battery with no improvements. Airplane > wired as per Z11 with an added electronic ignition on the top side I wouldn't expect a battery to fix this. The alternator is definitely not being allowed to do its job for some reason. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 20, 2009
Subject: Re: Alternator Failure
Thanks for your prompt reply, I will investigate further Franz On 20/05/09 3:55 PM, "Robert L. Nuckolls, III" wrote: > > > At 05:16 PM 5/20/2009, you wrote: >> Hi Bob, >> Could you please help me with a low voltage problem that I am having >> in my RV7. Voltage indicators on the Dynon and engine monitor both >> show fluctuations between 12.5V and 11.5V while in flight. > > These are the voltages you can expect from a battery > that is NOT benefiting from support by the alternator. > >> This is something that just started during the last few flights, I >> have 300h on the airplane with this being the first problem. I have >> had the ND 60A internally regulated alternator form Vans in the >> shop and it checked out fine. > > If the alternator is okay, then it's deprived of > an ON/OFF command that controls it . . . or is > otherwise disconnected from the system. > > With the engine not running but with battery and > alternator switches ON, you should measure some > voltage close to the battery output at all wires > attached to the alternator. If no/low voltage at > the b-lead terminal, perhaps your b-lead fuse or > current limiter is open. If no/low voltage to > the control terminal, then there is a failure in > the wiring between that terminal and the bus. > > >> I also have put in a new battery with no improvements. Airplane >> wired as per Z11 with an added electronic ignition on the top side > > > I wouldn't expect a battery to fix this. The alternator > is definitely not being allowed to do its job > for some reason. > > > > Bob . . . > > ----------------------------------------) > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > ---------------------------------------- > > > > > > ________________________________________________________________________________
Subject: Re: New to electronics
Date: May 21, 2009
Although I have some low level electrical knowledge, I am still wandering around in the dark. I am waiting for Vans to ship the rest of my kit so I am taking advantage of the down time to determine my electrical requirements and design the system. I have downloaded a couple of spreadsheets that seem to calculate the power requirements for many system and avionic components. So I am developing a list of the things I want and their respective power requirements. To my questions: 1. There seems to be some discussion as to the BUS system used. For those that have build their own, how did that workout for you. What "gotchas" would you warn me about? 2. If you could give one piece of advice, what would that be? 3. Other than determine what I feel I need for systems and their respective power requirements, any suggests on getting started? I hope to order the 12th edition of The AreoElectric Connection. I am sure it will be very useful in answering many of my questions. Thanks for your time Scott Ahrens ________________________________________________________________________________
Subject: RE: Welding Cable source
Date: May 21, 2009
Try www.weldingsupply.com Just received 100' #2 welding cable at around 50% of Grainger and others price including shipping. Very fast shipping Bob Mitchell Lancair 320 ________________________________________________________________________________
Date: May 21, 2009
Subject: Re: Insulation on Welding Wire
Thank you all for the responses on this, I feel a lot better about welding wire now. - Dan=0A=0A=0A ________________________________________________________________________________
Date: May 22, 2009
Subject: New to electronics
At 09:34 PM 5/21/2009, you wrote: Although I have some low level electrical knowledge, I am still wandering around in the dark. I am waiting for Vans to ship the rest of my kit so I am taking advantage of the down time to determine my electrical requirements and design the system. I have downloaded a couple of spreadsheets that seem to calculate the power requirements for many system and avionic components. So I am developing a list of the things I want and their respective power requirements. To my questions: 1. There seems to be some discussion as to the BUS system used. For those that have build their own, how did that workout for you. What "gotchas" would you warn me about? I'm aware of no potential for "gotchas". We've been flying single engine airplanes with one battery, one generator/alternator, and a main bus (added the avionics bus about 1965), for about 80 years. Hollywood notions of how airplanes work aside, electrical system failures are exceedingly low order causes for accidents. The POTENTIAL for an increase in electrically induced accident has been rising as engines have become more electrically dependent . . . and instrument panels have shed their vacuum driven flight instruments. But this increase in risk is EASILY offset by (1) taking advantage of the open vacuum pump drive pad and (2) OBAM aircraft users improved understanding of what it takes to craft and maintain a very low risk electrical system. 2. If you could give one piece of advice, what would that be? Don't order Vans electrical system kit. Certainly study all the options. Download this portion of the 'Connection. http://aeroelectric.com/R12A/AppZ_12A3.pdf Note that NONE of the exemplar architectures speak to specific airplanes. There ARE variations on a theme based on engines. So as you cruise through the drawings, you'll find that your choices are narrowed to Z-10/8 through Z-14. These architectures offer some options for crafting Plan A (everything working) and Plan-B (something broke). The differences between these drawings are designed to accommodate a range of design goals, equipment compliments and missions for your aircraft. I can tell you now that Z-13/8 is probably suited to 95% of the OBAM aircraft in existence. It's a step-wise evolution of the systems flying in a very high percentage of certified S.E. aircraft with Z-12 coming up strong as the TC version of Z-13/8. For lowest cost, lightest weight, and exceedingly high reliability, Z-13/8 is my personal choice and it has been installed in hundreds of OBAM aircraft with great reports of user satisfaction. To my knowledge, the first such system to fly was in a father and son RV-8 project built in CT about 10 years ago. Since that time, I've had numerous reports of no-sweat failure events that were made so by (1) pilot understanding of how the system works. (2) well maintained battery. (3) Failure tolerant design where no single failure brings down so much hardware that continued flight becomes a sweaty-palms affair. While Z-14 can and has been installed in RVs, it's a heavy, expensive over-kill. Z-14 was crafted to address the rather rare OBAM project that flies high, fast, and through less than comfortable weather. Preferably with two pilots and IFR capability from either seat wherein there is a separate electrical system to accommodate each system. This is what SHOULD be flying in King Airs and Beechjets . . . but isn't. 3. Other than determine what I feel I need for systems and their respective power requirements, any suggests on getting started? If you've taken the time to list all your anticipated electro-whizzies and shuffle the loads into various phases of flight (we call this load analysis) then you've already accomplished that which most builders skip over. They just bolt on a 60A alternator and keep truck'n. This is fine as long as Plan-A is in operation. If the alternator clocks out early, having a calculated Plan-B implemented by the second engine driven power source combined with a well maintained battery is your ticket to comfortable termination of flight at the airport of intended destination. I hope to order the 12th edition of The AreoElectric Connection. I am sure it will be very useful in answering many of my questions. The paper version of R12 is starved for cash. As soon as I scrape together a couple more $grand$ I'll get it off to the printer. A big start can be achieved from the down-loadable chapter I cited above. The second most valuable resource is the community of aviation enthusiasts who frequent this List. Stay on board and let us help you with this 24/7/365 service from lots of folks who have been there, done that. Bob . . . ________________________________________________________________________________
Subject: Re: Welding Cable source
Date: May 22, 2009
I just had an inquiry from a guy who has a racing car with 34' battery cable. I am selling him 34' of Super-2-CCA (equivalent to about AWG 1.5 that will save him 3 ounces per foot. Not a bad investment if you really want to win. It is really easy to show that hauling extra pounds around in the sky is a poor use of money. See this great little article: aeroelectric.com/articles/economics_of_weight_reduction.html You can get Super-2-CCA from SteinAir.com or Super-4-CCA from PerihelionDesign.com. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=244968#244968 ________________________________________________________________________________
Date: May 22, 2009
Subject: Comm 2 volume Very low
My Com2 Garmin SL40 which is connected through a Garmin 340 audio panel produces only a fraction of the volume, that the Com1 SL 30 does. I've been through the manuals looking for a clue as to where to begin. The audio panel states that the volume is controlled by the volume control on the radios. The Comm2 Vol is at max level. Anybody got suggestions on where to look? THANKS Deems Davis ________________________________________________________________________________
Subject: EV200s on Ebay
Date: May 22, 2009
Someone is offering EV200 contactors on Ebay for far less than the usual retail price. Search for EV200 I am not affiliated with the listing and have no additional information. Cheers, -------- rck Read this topic online here: http://forums.matronics.com/viewtopic.php?p=245034#245034 ________________________________________________________________________________
Date: May 22, 2009
Deems, I had the OPPOSITE problem but the solution may be the key for you... See below. "For some reason the SL40 com is much louder through the intercom when transmitting than the GNS430W com even with the volume turned down as low as possible." You can tell him that's "bad" setting in SL-40 for the side tone. It should be set to "000" - by going into setup mode then jumping through a few settings until side tone setting is encountered. When set to 000, the side tone volume will "follow" whatever volume is on the volume knob. Currently it's set to some value other than 000 (most likely 128) and that's why it's not following volume knob at all.. (all this is in the manual J). Fixed that on Thane's plane just the other day.. he had exact same thing going on.. HTH Bret Smith RV-9A N16BL Blue Ridge, Ga www.FlightInnovations.com -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Deems Davis Sent: Friday, May 22, 2009 7:39 PM Subject: AeroElectric-List: Comm 2 volume Very low --> My Com2 Garmin SL40 which is connected through a Garmin 340 audio panel produces only a fraction of the volume, that the Com1 SL 30 does. I've been through the manuals looking for a clue as to where to begin. The audio panel states that the volume is controlled by the volume control on the radios. The Comm2 Vol is at max level. Anybody got suggestions on where to look? THANKS Deems Davis ________________________________________________________________________________
Date: May 23, 2009
Thank you Bob for the sound advice. And thank you to all the folks who emailed me directly. I will download the diagrams and start digesting all this new information. Scott ________________________________________________________________________________
Date: May 23, 2009
Subject: Re: Comm 2 volume Very low
Bret, Thanks for the suggestion I stopped by the hangar this afternoon, and made the changes to the 'sidetone' on the SL40 Unfortunately there was no difference in the Volume level through the audio panel. Does anyone think this might/could be related to antenna/coax? I'm trying to eliminate the easier things, as getting to the connectors and pins is going to be some serious access challenge. Deems Bret Smith wrote: > > Deems, > > I had the OPPOSITE problem but the solution may be the key for you... See > below. > > "For some reason the SL40 com is much louder through the intercom when > transmitting than the GNS430W com even with the volume turned down as low as > possible." > > > You can tell him that's "bad" setting in SL-40 for the side tone. It should > be set to "000" - by going into setup mode then jumping through a few > settings until side tone setting is encountered. When set to 000, the side > tone volume will "follow" whatever volume is on the volume knob. Currently > it's set to some value other than 000 (most likely 128) and that's why it's > not following volume knob at all.. (all this is in the manual J). Fixed > that on Thane's plane just the other day.. he had exact same thing going > on.. > > ________________________________________________________________________________
Date: May 23, 2009
Subject: Source for the colied cord used on yoke type aircraft
Good evening all. Wishing all VETS a good weekend and may we always remember those who have flown on before us. Am looking for a source of coiled cord. Does anyone know of one? I have looked at McMaster-Carr and they have some but I don't know one type from the other. My mechanic says get the stuff that doesn't have the shiny outside jacket, it breaks down too fast. I have googled and came up with some others, there again I don't which type to get. Would like to have at least 24 guage or larger due to ease of working with the larger guages (i.e. 28 guage is a pain) Thanks Barry ________________________________________________________________________________
Date: May 23, 2009
Subject: Re: Source for the colied cord used on yoke type
aircraft At 09:24 PM 5/23/2009, you wrote: >Good evening all. Wishing all VETS a good weekend and may we always >remember those who have flown on before us. > >Am looking for a source of coiled cord. Does anyone know of one? > >I have looked at McMaster-Carr and they have some but I don't know >one type from the other. My mechanic says get the stuff that >doesn't have the shiny outside jacket, it breaks down too fast. I >have googled and came up with some others, there again I don't which >type to get. > >Would like to have at least 24 guage or larger due to ease of >working with the larger guages (i.e. 28 guage is a pain) How many conductors do you need and how long? Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 24, 2009
aircraft Looking for 2 conductor, 6 inches long for each piece. 2 pieces needed now, but if good source, would get several for my mechanic. Thanks Bob. Barry ________________________________ From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Sent: Saturday, May 23, 2009 11:40:52 PM Subject: Re: AeroElectric-List: Source for the colied cord used on yoke type aircraft At 09:24 PM 5/23/2009, you wrote: > Good evening all. Wishing all VETS a good weekend and may we always remember those who have flown on before us. > > Am looking for a source of coiled cord. Does anyone know of one? > > I have looked at McMaster-Carr and they have some but I don't know one type from the other. My mechanic says get the stuff that doesn't have the shiny outside jacket, it breaks down too fast. I have googled and came up with some others, there again I don't which type to get. > > Would like to have at least 24 guage or larger due to ease of working with the larger guages (i.e. 28 guage is a pain) How many conductors do you need and how long? Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 24, 2009
Subject: Source for the coiled cord used on yoke type aircraft
At 07:43 AM 5/24/2009, you wrote: >Looking for 2 conductor, 6 inches long for each piece. 2 pieces >needed now, but if good source, would get several for my mechanic. Thanks Bob. Coiled cord is not something you find as a "by the foot" bulk item. Coiled cords are custom made with wires, of specified insulation color and material, a diameter, coiled length, uncoiled length, and usually some straight segments at each end. I've had occasion to order such items several times over the years. Coiled cords in the wild are prolific. The electrical/ electronic products world is fond of them and they're readily available as new or surplus. Try e-bay and search on coiled cord . . . you'll get a hundred plus hits. Your mechanic is correct, the "shiny" stuff tends to be pretty cheesy plastic. However, the matt finish are generally some form of more robust rubber. Getting the wire size is problematic. Many small signal applications (usually audio) don't need much copper to do the job . . . on occasion you'll find coil cords wired with copper foil wound around a string core . . . nearly impossible to make connections. Coiled power adapter cords for cell phones flash guns, dash mounted GPS receivers, etc. tend to be heavier conductors made from real wire. Every coiled cord has two conductors, some will have more. I think many of the personality modules for upscale cigar lighter adapters "talk back" on one or more wires to the electronics in the plug. These are more expensive . . . like $25 or so . . . http://www.radioshack.com/product/index.jsp?productId=3336570 . . . but you might be able to get two cords from cannibalizing the one device. Somewhere in my skunk werks boxes I have some 2-conductor coiled cords I bought off E-bay many moons ago. Things are somewhat scrambled right now with the move but I'll dig around and see what I can find. In any case, there are dozens of opportunities out there to be explored. Start with R-S, Best Buy, WalMart electronics, etc. Of course, when you cut a stock cord, only one end will have the desired straight section, the cut end will be coiled . . . but I'm sure you can deal with that. I'll let you know about what I find in the junk box. Bob . . . ________________________________________________________________________________
Subject: Coiled Cord
Date: May 24, 2009
Greetings, I needed a coiled cord and went to a local thrift store. Rummaging through a box of miscellaneous stuff in the "electronics section," there were dozens of devices with coiled cords attached. I bought four different devices, each with a coiled cord attached to it. I don't remember what they were originally connected to; I think one had a cigar lighter power plug on one end and I think another one was a cell phone battery charger. I think all four of them, combined, cost two dollars. I took them home and cut off whatever was connected to one end and examined the cut end to see how many wires were in the cable and how big they were. Of the four I brought home, one was perfect, another would have been adequate, and the other two either didn't have enough wires or they were too tiny for my application. It turned out great, cost almost nothing, and kept something out of the landfill. Plus a charity got a couple of bucks. Good luck, Dennis ________________________________________________________________________________
Subject: Military style external power receptacle question
Date: May 24, 2009
Looking at Bob's wiring diagram in Appendix Z, 31A, for a military style external power receptacle, what is the function of the smaller third pin? Just guessing by the schematic it's hot power, just like the middle pin. Inquiring minds want to know........ John -------- #40572 QB Fuselage, wings finished. Finish Kit started. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=245177#245177 ________________________________________________________________________________
Date: May 24, 2009
Subject: Re: Military style external power receptacle question
Hi John, More or less. You have to supply power to the third pin to close the ground power contactor. If you had such a connector, you could still wire it up like the Piper ground power jack and just ignore the third pin. Bob W. "johngoodman" wrote: > > Looking at Bob's wiring diagram in Appendix Z, 31A, for a military style external power receptacle, what is the function of the smaller third pin? Just guessing by the schematic it's hot power, just like the middle pin. > Inquiring minds want to know........ > > John > > -------- > #40572 QB Fuselage, wings finished. Finish Kit started. > N711JG reserved > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=245177#245177 > > > > > > > > > > -- N93BD - Rotary Powered BD-4 - http://www.bob-white.com 3.8 Hours Total Time and holding Cables for your rotary installation - http://roblinstores.com/ ________________________________________________________________________________
Date: May 24, 2009
It's a sense pin and it is hot, the same as the center pin. Without the plug, it is not connected to the center pin. It can be used as the drawing shows, to separate the source of power activating the contactor from what is flowing through the contactor. This allows you a way to take action on this pin going hot. In the case of Z31A, that drawing shows polarity and overvoltage sensing being done from that pin. Bob Meyers Building Sonex 982SX Web Site Index http://meyersfamily.org/Sonex982.html On May 24, 2009, at 4:15 PM, johngoodman wrote: > > > > Looking at Bob's wiring diagram in Appendix Z, 31A, for a military > style external power receptacle, what is the function of the smaller > third pin? Just guessing by the schematic it's hot power, just like > the middle pin. > Inquiring minds want to know........ > > John > > -------- > #40572 QB Fuselage, wings finished. Finish Kit started. > N711JG reserved > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=245177#245177 > > ________________________________________________________________________________
Date: May 24, 2009
Thanks for the response. I assume that the military and airlines use the pin for the same thing. John -------- #40572 QB Fuselage, wings finished. Finish Kit started. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=245185#245185 ________________________________________________________________________________
Date: May 25, 2009
At 04:15 PM 5/24/2009, you wrote: > > >Looking at Bob's wiring diagram in Appendix Z, 31A, for a military >style external power receptacle, what is the function of the smaller >third pin? Just guessing by the schematic it's hot power, just like >the middle pin. >Inquiring minds want to know........ It's a pretty subtle thing . . . not obvious without some attention to the little details. The third pin is much shorter than the other two fat pins. This means that as you push the socket onto the pins, the two fat ones are electrically engaged before the third pin mates and current flows. Similarly, assume you're pulling the plug out of a ground power connector that is loaded. The third pin breaks first and de-energizes the system before the fat pins break. In some applications, this connector can be loaded to hundreds of amp at 28V. That kind of power makes for long hot sparks during a slow make/break operation. The pins of the connector are not designed to work like a contactor and are subject to damage if not made or broken "cold". Using the third pin to control the ground power contactor prevents damage to the connector from a hot make or break of the main power pins. Finally, the smaller size of the third pin provides "polarization" for the mated connector halves. If on tried to plug it in backwards the differences in sizes prevents any form of engagement from taking place. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Subject: Re: Solar & Wind Power
Date: May 25, 2009
This forum may not be the appropriate place to discuss alternative energy sources as they might apply to an aircraft hangar to be built in a location far removed from the energy grid. I'm hoping that one of you may have experience in this area and reply on this forum or contact me directly. Thanks, Angier Ames ________________________________________________________________________________
Date: May 25, 2009
Angier M. Ames wrote: > > > This forum may not be the appropriate place to discuss alternative > energy sources as they might apply to an aircraft hangar to be built > in a location far removed from the energy grid. I'm hoping that one of > you may have experience in this area and reply on this forum or > contact me directly. > > Thanks, > > Angier Ames A friend has put 5 kw of 'thin film' solar panels on the roof of his hangar in S Florida. He is 'on grid' and the grid interface feeds any excess power into the grid & the power company has to buy the power (at wholesale rates, of course). If you're totally off-grid, you'd almost certainly need storage (batteries) & an inverter, which raises cost considerably. Actual power demands obviously matter, too. Do you need to run serious power tools (big air compressor, welder, etc), or just light the hangar & run small power tools? If you have access to newsgroups, try alt.energy.homepower or alt.solar.thermal. Charlie ________________________________________________________________________________
Date: May 25, 2009
Bob, Thanks! John -------- #40572 QB Fuselage, wings finished. Finish Kit started. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=245293#245293 ________________________________________________________________________________
Subject: Battery Capacity Tester
Date: May 25, 2009
5/25/2009 Hello Fellow Listers, There has been some interest in the past on how to test the capacity of one's aircraft battery. Here is a new piece of equipment available from Concorde for this purpose. http://www.concordebattery.com/accessories.php?id OC ________________________________________________________________________________
Date: May 25, 2009
Subject: Re: LR3 regulator Amperage indications
At 06:12 AM 5/18/2009, you wrote: > >Bob, >I am now convinced that the variations were real. I inserted an >ammeter into the field line, while the engine was stopped. Got a >reading of 3.5 amps. Then took the plane out, fired it up with the >ammeter in place, and when the alternator switch was turned on, the >current went to 3.5 amps for a very short time, then dropped to >zero. At that point, it stayed at zero, and the battery would not charge. > >Put plane back in hanger, and did some static measurements. > >Voltage from LR-3 to field circuit breaker ~4.5 volts This voltage comes FROM your battery via the contactor, main bus, alternator field breaker and switch. When you made these measurements, was the battery charged at all? Or was it down to 4.5 volts? >Voltage at connector to alternator (black plug) ~4.5V >Resistance to ground through the leads that field current plugs into >varies (jumps around) and then often goes to open circuit. > >Could the slip rings be contaminated or not in contact? This is a possibility. You need to deduce the reason for such low voltage readings. Put a charger/maintainer on your battery and make sure it's 100% before you continue the investigation. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 25, 2009
Subject: Re: Battery Capacity Tester
For $1300 I would want to have a requirement to test more than one or two batteries every year! http://www.aircraftspruce.com/catalog/elpages/bc5000.php I think maybe Bob's tester would prove more than adequate for the average OBAM user. http://www.aeroelectric.com/articles/battest.pdf Just my opinion, Bob W. wrote: > > 5/25/2009 > > Hello Fellow Listers, There has been some interest in the past on how to > test the capacity of one's aircraft battery. Here is a new piece of > equipment available from Concorde for this purpose. > > http://www.concordebattery.com/accessories.php?id > > OC > > > > > -- N93BD - Rotary Powered BD-4 - http://www.bob-white.com 3.8 Hours Total Time and holding Cables for your rotary installation - http://roblinstores.com/ ________________________________________________________________________________
Date: May 25, 2009
Bob, an update -- The Battery, alternator, and LR3C are fine, the symptoms below are attributed to operator induced problems. 1. Apparently when hooking up for the test, I caused a short that blew the fuse to the alternator field. That is the reason for the battery not charging. 2. I talked to B&C, and downloaded there diagnostic check sheet. This led to the discovery of the blown fuse. 3. I have installed an old fashioned 50mv/60A shunt in the B lead, and hooked it up to a DVM. Alternator working fine, hash on recorded output must be as you originally surmised, the result of noise. I have not yet tried to filter the noise, now that I know the output is stable, I can ignore the chart until I have time to fix it. Thanks for your help/input. Bill Schertz KIS Cruiser #4045 N343BS Phase I testing ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Sent: Monday, May 25, 2009 3:26 PM Subject: Re: AeroElectric-List: LR3 regulator Amperage indications > > > At 06:12 AM 5/18/2009, you wrote: >> >> >>Bob, >>I am now convinced that the variations were real. I inserted an ammeter >>into the field line, while the engine was stopped. Got a reading of 3.5 >>amps. Then took the plane out, fired it up with the ammeter in place, and >>when the alternator switch was turned on, the current went to 3.5 amps for >>a very short time, then dropped to zero. At that point, it stayed at >>zero, and the battery would not charge. >> >>Put plane back in hanger, and did some static measurements. >> >>Voltage from LR-3 to field circuit breaker ~4.5 volts > > This voltage comes FROM your battery via the contactor, > main bus, alternator field breaker and switch. When > you made these measurements, was the battery charged > at all? Or was it down to 4.5 volts? > >>Voltage at connector to alternator (black plug) ~4.5V > > >>Resistance to ground through the leads that field current plugs into >>varies (jumps around) and then often goes to open circuit. >> >>Could the slip rings be contaminated or not in contact? > > This is a possibility. You need to deduce the > reason for such low voltage readings. Put > a charger/maintainer on your battery and make > sure it's 100% before you continue the investigation. > > > Bob . . . > > ----------------------------------------) > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > ---------------------------------------- > > > ________________________________________________________________________________
Date: May 25, 2009
Hi Bob, Just letting you know that after some trouble shooting I found the culprit of my problems, a loose connection that I overlooked many times, all is working as it should again Thanks Franz On 20/05/09 3:55 PM, "Robert L. Nuckolls, III" wrote: > > > At 05:16 PM 5/20/2009, you wrote: >> Hi Bob, >> Could you please help me with a low voltage problem that I am having >> in my RV7. Voltage indicators on the Dynon and engine monitor both >> show fluctuations between 12.5V and 11.5V while in flight. > > These are the voltages you can expect from a battery > that is NOT benefiting from support by the alternator. > >> This is something that just started during the last few flights, I >> have 300h on the airplane with this being the first problem. I have >> had the ND 60A internally regulated alternator form Vans in the >> shop and it checked out fine. > > If the alternator is okay, then it's deprived of > an ON/OFF command that controls it . . . or is > otherwise disconnected from the system. > > With the engine not running but with battery and > alternator switches ON, you should measure some > voltage close to the battery output at all wires > attached to the alternator. If no/low voltage at > the b-lead terminal, perhaps your b-lead fuse or > current limiter is open. If no/low voltage to > the control terminal, then there is a failure in > the wiring between that terminal and the bus. > > >> I also have put in a new battery with no improvements. Airplane >> wired as per Z11 with an added electronic ignition on the top side > > > I wouldn't expect a battery to fix this. The alternator > is definitely not being allowed to do its job > for some reason. > > > > Bob . . . > > ----------------------------------------) > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > ---------------------------------------- > > > > > > ________________________________________________________________________________
Date: May 25, 2009
Date: May 25, 2009
Not sure if this is relevant to your situation, but I just had a similar experience with the EXPBUS output to the alternator. The IRF4905 MOSFET that was controlling the 12V to the alternator was measuring 12V with no load, but when connected to the alternator dropped to a low voltage. Replacing that device on the EXPBUS resolved my problem, as of today. ;-) The ammeter output was totally confusing during this time, in that it was indicating 2A, but may have actually been indicating no charging current at all. The battery was certainly discharging with minimal loads. If the LR3 "solid state" components include a similar device to the IRF4905 it seems it's not so simple as just measuring the voltage at the output, since it seems to drop as soon as a load is applied if faulty. Good luck, Ian Brown Bromont Quebec Finally getting back to flying tomorrow! > > At 06:12 AM 5/18/2009, you wrote: > > > >Bob, > >I am now convinced that the variations were real. I inserted an > >ammeter into the field line, while the engine was stopped. Got a > >reading of 3.5 amps. Then took the plane out, fired it up with the > >ammeter in place, and when the alternator switch was turned on, the > >current went to 3.5 amps for a very short time, then dropped to > >zero. At that point, it stayed at zero, and the battery would not charge. > > > >Put plane back in hanger, and did some static measurements. > > > >Voltage from LR-3 to field circuit breaker ~4.5 volts > > This voltage comes FROM your battery via the contactor, > main bus, alternator field breaker and switch. When > you made these measurements, was the battery charged > at all? Or was it down to 4.5 volts? > > >Voltage at connector to alternator (black plug) ~4.5V > > > >Resistance to ground through the leads that field current plugs into > >varies (jumps around) and then often goes to open circuit. > > > >Could the slip rings be contaminated or not in contact? > > This is a possibility. You need to deduce the > reason for such low voltage readings. Put > a charger/maintainer on your battery and make > sure it's 100% before you continue the investigation. > > > > Bob . . . > > ----------------------------------------) > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > ---------------------------------------- > > > > > > ________________________________________________________________________________
Date: May 25, 2009
From: "Paul Millner [OAK]" <paulmillner(at)compuserve.com>
Subject: Ground Power Receptacle - 3 pin
>> I assume that the military and airlines use the pin for the same thing. In the 70's, Cessna used that small third pin, hotted up by the external power source, to both close the ground power contactor, connecting the external power source to the bus, *and* to energize an avionics relay, which disconnected the avionics bus from the main bus. The relay coil was diode or'd with the starter contactor coil circuit... so turning the key to start *also* disconnected the avionics bus. Where it gets exciting is when the diode from the starter contactor fails as a short.. then, connecting ground power causes the prop to start spinning, Youza! Paul ________________________________________________________________________________
Date: May 25, 2009
Thank you for the information Bob. I am trying to trouble shoot my low voltage problem to determine its cause (i.e.; the regulator, wiring, or the internal engine alternator) so I can take corrective action. There is nothing in the Rotax 912 manuals to assist in doing this. I checked the internal engine coil resistance reading and found it to be .7-ohms. The DC voltage at the regulator is the same previously reported (still under 13-volts). Finally I measured AC voltage coming from the coils. The voltage varied as follows: Idle (1900-RPM) was 12.8 volts 2500-RPM was 16.0 v 3000-RPM was 19.0 v 4000-RPM was 24.5 v cruse(5000-RPM)was not measured. Bob, Am I correct to think that the AC voltage looks adequate and the problem is likely a faulty Rotax voltage regulator? Thanks again for your help. Regards, Les From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Wednesday, May 20, 2009 11:54 AM Subject: Re: AeroElectric-List: Rotax 912ULS Voltage At 01:08 PM 5/20/2009, you wrote: <lgold@quantum-associates.com> I am a sport pilot and don't fly at night, but took my Zenith 701 /Rotax 912ULS up a few evenings ago just to see how hard it would be to land in the dark. No problem landing, but with all the extra night time stuff on (strobes, 55watt landing light, & cabin lights) plus my normal stuff (intercom, 2GPS's, Dynon 180, ICOM radio, transponder, and intercom) the voltage went down to 11.9 at 3500-rpm and 12.3V at my 4900-rpm cruse. The blinding low voltage light (from aeroelectric's Z16 diagram, which I used for my aircraft) came on for the first time and gave me a scare. My question; is this low voltage situation normal or do I have voltage regulation issues? If the low votlage light is on (bus less than 13.0 volts) then the alternator is not producing sufficient energy to carry all of the ship's loads AND maintain a battery. Without the extra load during daylight flight my voltage runs about 12.9-13.0 V and my battery holds a 12.8V charge. This is TOO LOW. No load and engine running should produce a bus voltage of 14.0 MINIMUM, 14.2 to 14.4 is better. With a 13.0V set-point, your alternator is not replenishing the energy used to get the engine started. It's also maintaining your battery in a very low state of charge, probably less than 50% of capacity. I don't have an extra alternator and just use the internal Rotax coils for power. One guy already told me that what I am getting is the norm with the extra stuff on, and that the Rotax voltage regulator heats up a lot and should not be expected to last very long. Are these things true? Not quite. That voltage level is too low. You need to add up the real current draw for all accessories that might be on at the same time. These cannot exceed the rating of the alternator (assuming the battery is charged) for the operating RPM . . . Emacs! . . . and should not be more than 75% of that rating if you want the alternator to replenish energy removed before cruising flight RPMs are achieved. The stock rectifier/regulator is marginal for the way we use them. I wish they were a bit more robust. It would add very little to the cost of the product. John Deere has some single phase rectifier/regulators rated in the 30A class. It would be interesting to see how well these might substitute for the stock regulator. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 26, 2009
Besides, there is nothing that encourages wild speculation as knowing nothing about it...and a few beers. Instead, google "Home Power" magazine online (and print). They have everything and lots of archives. The internet is a wealth of information on the subject. "The problem with the world is that only the intelligent people want to be smarter, and only the good people want to improve." - Eolake Stobblehouse -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=245377#245377 ________________________________________________________________________________
Date: May 26, 2009
Subject: Engine mount as starter ground path
Does anyone have some scientific information (beyond the practical description in the Connection) that I can use to convince someone that running the engine ground strap to the engine mount is a poor choice ? Thanks ! Jeff Page Dream Aircraft Tundra #10 ________________________________________________________________________________
Date: May 26, 2009
Totally separate but possibly dead on. My 1978 Ford pickup suffered catastrophic electrolysis of the cab floorboards and the entire bed (years 28-31). The Tailgate was replaced with an Electro-Hydraulic 1,000 pound Tommy Lift. The lift motor used high current capacity welding cable with neoprene shielding for the Positive. NO GROUND. Just the mounting to the bed of the truck and the frame rails. All of a sudden over the last several years, the truck began rapid corrosion (Really Rapid - Decomposition). My conclusion. Stray electrons looking for the primary path to ground - found their path without the aid of the missing ground. My action - Never again! use a structural mount in hopes of taking a path of less effort during installation. Provide an adequate ground from the battery or generator source. Listen to Bob. Semi-monocoque construction makes it even more valid. YMMV. John Cox Now for the experts. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Jeff Page Sent: Tuesday, May 26, 2009 8:14 AM Subject: AeroElectric-List: Engine mount as starter ground path Does anyone have some scientific information (beyond the practical description in the Connection) that I can use to convince someone that running the engine ground strap to the engine mount is a poor choice ? Thanks ! Jeff Page Dream Aircraft Tundra #10 ________________________________________________________________________________
Date: May 26, 2009
How about the scientific principle of rubber engine mounts being a poor conductor of electricity? That would go for the cadmium plating on the bolts themselves. Not a perfect conductor. Scientifically engine mounting bolts will corrode over time, get oily and generally loose what connectivity they have. Under Ohm's law the addition of the engine mount changes sub R in the equation reducing the conductance value of the material. If he works out the equation using the combined values conductivity will be less. After he is done scratching his head, he'll recognize why it's done this way. See: http://en.wikipedia.org/wiki/Electrical_conductance If he is trying to save $3.00 on the cost of the additional 5" of cable required to anchor it to the engine, there is little argument on his side. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Jeff Page Sent: Tuesday, May 26, 2009 11:14 AM Subject: AeroElectric-List: Engine mount as starter ground path Does anyone have some scientific information (beyond the practical description in the Connection) that I can use to convince someone that running the engine ground strap to the engine mount is a poor choice ? Thanks ! Jeff Page Dream Aircraft Tundra #10 ________________________________________________________________________________
Subject: Re: Crowbar
Date: May 26, 2009
Bob, I'm following the Z-31A schematic for a military style ground power jack, and I'm ordering parts. I've found everything except for the OVM-14 Crowbar O.V. Module. I called B&C sales and they referred me to a part number 504-1 , which is something for an alternator with a lot of pieces. How do I get just the OVM-14? John -------- #40572 QB Fuselage, wings finished. Finish Kit started. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=245430#245430 ________________________________________________________________________________
Date: May 26, 2009
At 02:25 PM 5/26/2009, you wrote: > > >Bob, >I'm following the Z-31A schematic for a military style ground power >jack, and I'm ordering parts. I've found everything except for the >OVM-14 Crowbar O.V. Module. I called B&C sales and they referred me >to a part number 504-1 , which is something for an alternator with a >lot of pieces. How do I get just the OVM-14? They're in production in our shop now. I don't have them on the catalog yet. Fill out an order at: https://matronics.com/aeroelectric/Catalog/AECcatalog.html and put "1ea CbOVM-14 @ $25.00" in the comments box. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 26, 2009
Subject: Re: Engine mount as starter ground path
At 10:14 AM 5/26/2009, you wrote: > >Does anyone have some scientific information (beyond the practical >description in the Connection) that I can use to convince someone that >running the engine ground strap to the engine mount is a poor choice ? > >Thanks ! The shortest, lowest resistance and minimum parts count path in any high current conduction path is the road to Ground System Nirvana. See: http://www.aeroelectric.com/articles/grnding.pdf Engine mounts are steel assembled with steel hardware. The joints between mounts and other components of the airframe are not treated for the purpose of electrical "bonding". The engine mount is intended to hold the engine on the airplane and was not designed or installed to be a part of the electrical system. Note that Figure Z-15 and Chapter 5 of the 'Connection speak to and illustrate a notion that engines are best tied to the single point fire-wall ground block with a single-flexible- fatwire. To avoid having the firewall sheet participate in a PARALLEL ground path (read ground loop) any bonding jumpers across the engine mounts are best removed. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 26, 2009
Given such a ground path, how does one get lineboys trained that the engine exhaust pipe is a terrible place for ground wire, that the fuel tanks are in the wings, and something like a bare spot on wing tiedown has a much shorter ground path? I always wonder how static charge is supposed to make it from the fuel tank through the airframe to the engine and down the rusty, carboned up exhaust pipe, usually with a swivel or slip joint or two to that ground wire, without significant resistance. Robert L. Nuckolls, III wrote: > > > At 10:14 AM 5/26/2009, you wrote: >> >> Does anyone have some scientific information (beyond the practical >> description in the Connection) that I can use to convince someone that >> running the engine ground strap to the engine mount is a poor choice ? >> >> Thanks ! > > The shortest, lowest resistance and minimum parts count path > in any high current conduction path is the road to Ground > System Nirvana. See: > > http://www.aeroelectric.com/articles/grnding.pdf > > Engine mounts are steel assembled with steel > hardware. The joints between mounts and other > components of the airframe are not treated for > the purpose of electrical "bonding". The engine > mount is intended to hold the engine on the > airplane and was not designed or installed to > be a part of the electrical system. > > Note that Figure Z-15 and Chapter 5 of the > 'Connection speak to and illustrate a notion > that engines are best tied to the single point > fire-wall ground block with a single-flexible- > fatwire. To avoid having the firewall sheet > participate in a PARALLEL ground path (read > ground loop) any bonding jumpers across the > engine mounts are best removed. > > > Bob . . . > > ________________________________________________________________________________
From: "Vaughn Teegarden" <europaul260i(at)bvunet.net>
Date: May 26, 2009
How about some anecdotal evidence. I had a Cadillac 4.9 liter V8 installed in my Pontiac Fiero. Since it weighted 15 pounds more than the V6 that was in there, I had the battery moved from the rear engine compartment to just on top of the front axle. My voltmeter would not show over 13.5 volts even when the battery was weak and would drop below 12 volts if I ran the AC and lights at the same time. I would also have intermittent problems starting the car when it was hot. The battery was grounded to the frame and the engine was also grounded to the frame. A 9 foot #2 wire went from the positive terminal to the starter. After putting on a new starter the engine would not start hot the very first time I drove it somewhere. I put a 9 foot #2 wire from the negative side of the battery to the one of the mounting studs of the starter and now no more starting problems. The voltmeter shows 14.5 volts on start-up and after a brief drop when turning on the lights and AC, it shows 13.5 volts. The ground is important. I only wish it hadn't taken me 2 years to figure it out. Vaughn Teegarden ----- Original Message ----- From: "Jeff Page" <jpx(at)Qenesis.com> Sent: Tuesday, May 26, 2009 11:14 Subject: AeroElectric-List: Engine mount as starter ground path > > Does anyone have some scientific information (beyond the practical > description in the Connection) that I can use to convince someone that > running the engine ground strap to the engine mount is a poor choice ? > > Thanks ! > > Jeff Page > Dream Aircraft Tundra #10 > > > ________________________________________________________________________________
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
Date: May 26, 2009
Just be thankful your ground path didn't go thru your crank bearings..You would have figured itout a lot sooner though..:) Frank RV 7a and a tractor where the battery negative goes directly to the starter as well! -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Vaughn Teegarden Sent: Tuesday, May 26, 2009 2:22 PM Subject: Re: AeroElectric-List: Engine mount as starter ground path --> How about some anecdotal evidence. I had a Cadillac 4.9 liter V8 installed in my Pontiac Fiero. Since it weighted 15 pounds more than the V6 that was in there, I had the battery moved from the rear engine compartment to just on top of the front axle. My voltmeter would not show over 13.5 volts even when the battery was weak and would drop below 12 volts if I ran the AC and lights at the same time. I would also have intermittent problems starting the car when it was hot. The battery was grounded to the frame and the engine was also grounded to the frame. A 9 foot #2 wire went from the positive terminal to the starter. After putting on a new starter the engine would not start hot the very first time I drove it somewhere. I put a 9 foot #2 wire from the negative side of the battery to the one of the mounting studs of the starter and now no more starting problems. The voltmeter shows 14.5 volts on start-up and after a brief drop when turning on the lights and AC, it shows 13.5 volts. The ground is important. I only wish it hadn't taken me 2 years to figure it out. Vaughn Teegarden ________________________________________________________________________________
Date: May 26, 2009
Subject: Rotax 912ULS voltage . . .
At 12:38 AM 5/26/2009, you wrote: Thank you for the information Bob. I am trying to trouble shoot my low voltage problem to determine its cause (i.e.; the regulator, wiring, or the internal engine alternator) so I can take corrective action. There is nothing in the Rotax 912 manuals to assist in doing this. I checked the internal engine coil resistance reading and found it to be .7-ohms. The DC voltage at the regulator is the same previously reported (still under 13-volts). Finally I measured AC voltage coming from the coils. The voltage varied as follows: Idle (1900-RPM) was 12.8 volts 2500-RPM was 16.0 v 3000-RPM was 19.0 v 4000-RPM was 24.5 v cruse(5000-RPM)was not measured. Bob, Am I correct to think that the AC voltage looks adequate and the problem is likely a faulty Rotax voltage regulator? Thanks again for your help. If you have ANY voltage from the alternator's output winding at any speed, and the winding is not shorted to ground (very unlikely) then the alternator is fine. Rotax PM alternators are exceedingly simple, rugged and reliable. I'm not aware of any failures. The Ducati rectifier/regulator supplied with these engines is another matter. They are of marginal thermal design and sadly lacking in adjustability. Two conditions VERY easy to fix if anyone with responsibility for the product cared. Unfortunately, replacing it with an identical OEM R/R has a high probability of installing a similar problem right out of the box. I've heard that John Deere has a single phase, PM alternator regulator that is rated for up to 35 amps. Goto http://matronics.com/search Search the AeroElectric List for AM101406 and you'll get several hits by folks who discussed it some time back. Here are some after-market clones . . . http://www.watercraftstarter.com/Lawn%20Garden/Regulator%20Rectifier/?nocache=1 http://www.amazon.com/Replacement-Voltage-Regulator-Deere-AM101406/dp/B00169H3E0 I don't see a voltage adjustment mentioned or shown . . . unfortunate but perhaps understandable. Most of these regulators are used on small tractors and most users are not skilled in the use of such features. Wish I had my alternator drive stand running. Building a 'real' PM r/r for aircraft is not a big task . . . Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 26, 2009
At 04:21 PM 5/26/2009, you wrote: >Given such a ground path, how does one get lineboys trained that the >engine exhaust pipe is a terrible place for ground wire, that the >fuel tanks are in the wings, and something like a bare spot on wing >tiedown has a much shorter ground path? I always wonder how static >charge is supposed to make it from the fuel tank through the >airframe to the engine and down the rusty, carboned up exhaust pipe, >usually with a swivel or slip joint or two to that ground wire, >without significant resistance. The line boy's ground lead is not intended to carry more than micro-amps of current . . . and then for only enough time to equalize the STATIC charge on the airplane with the STATIC charge on the fuel truck. Given the proliferation of composite aircraft it's not a bad bet for fuel truck operators to use the exhaust pipe . . . it's metallic and definitely connected to the crankcase through other metallic parts. Now, it's entirely possible that a metallic tank resides in a composite wing and is plumbed up with some modern synthetic tubing . . . it's a tiny bit of a crap-shoot. Bottom line is that the rusty, gunked up piece of pipe is not a bad choice. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 26, 2009
Subject: Re: Ground Power Receptacle - 3 pin
At 10:13 PM 5/25/2009, you wrote: > > > >> I assume that the military and airlines use the pin for the same thing. > >In the 70's, Cessna used that small third pin, hotted up by the >external power source, to both close the ground power contactor, >connecting the external power source to the bus, *and* to energize >an avionics relay, which disconnected the avionics bus from the main >bus. The relay coil was diode or'd with the starter contactor coil >circuit... so turning the key to start *also* disconnected the avionics bus. > >Where it gets exciting is when the diode from the starter contactor >fails as a short.. then, connecting ground power causes the prop to >start spinning, Youza! Yeah . . . I remember that setup. We sure thought it was a good idea . . . at the time . . . Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 26, 2009
At 04:31 PM 5/25/2009, you wrote: > > >Hi Bob, >Just letting you know that after some trouble shooting I found the culprit >of my problems, a loose connection that I overlooked many times, all is >working as it should again >Thanks >Franz Very good sir. Keep the dirty side down and the pointy end forward! Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 26, 2009
At 06:09 PM 5/25/2009, you wrote: > >Not sure if this is relevant to your situation, but I just had a similar >experience with the EXPBUS output to the alternator. The IRF4905 MOSFET >that was controlling the 12V to the alternator was measuring 12V with no >load, but when connected to the alternator dropped to a low voltage. >Replacing that device on the EXPBUS resolved my problem, as of >today. ;-) > >The ammeter output was totally confusing during this time, in that it >was indicating 2A, but may have actually been indicating no charging >current at all. The battery was certainly discharging with minimal >loads. > >If the LR3 "solid state" components include a similar device to the >IRF4905 it seems it's not so simple as just measuring the voltage at the >output, since it seems to drop as soon as a load is applied if faulty. Not exactly . . . The mosfet in the EXP bus appears to be used as a ON/OFF switch in the feature labeled OV CUTOFF. It should be turned on hard at all times when not OV-tripped so as to not upset regulator performance downstream. Emacs! The LR3 does have a series control device used as part of the voltage regulator system. The LR3 also features its own ov protection that would NOT be compatible with an EXP BUS installation. Bill cited a voltage reading on the order of 4.5 volts on the wire between circuit breaker and the field terminal of the LR3 . . . this would cause the LR3 output to be similarly depressed. There's either something "unhooked" between the field supply breaker and the field power terminal of the LR3 . . . or the battery is REALLY soggy. Bob. . . ________________________________________________________________________________
Date: May 26, 2009
At 03:50 PM 5/25/2009, you wrote: > >Bob, an update -- The Battery, alternator, and LR3C are fine, the >symptoms below are attributed to operator induced problems. > >1. Apparently when hooking up for the test, I caused a short that >blew the fuse to the alternator field. That is the reason for the >battery not charging. > >2. I talked to B&C, and downloaded there diagnostic check sheet. >This led to the discovery of the blown fuse. > >3. I have installed an old fashioned 50mv/60A shunt in the B lead, >and hooked it up to a DVM. Alternator working fine, hash on recorded >output must be as you originally surmised, the result of noise. > >I have not yet tried to filter the noise, now that I know the output >is stable, I can ignore the chart until I have time to fix it. > >Thanks for your help/input. Aha! funny thing about those pesky electrons. The alchemists have been trying to teach them how to jump gaps for centuries . . . no joy. If you have an LR3, it should have no fuses in the field supply lead, only a 5A breaker and perhaps a fusible link as illustrated in Z14. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 26, 2009
Subject: ARC R-402A Pin Out
I have an aircraft with an MX-300 radio and an ARC R-402A marker beacon rec eiver. There is an unlabeled-mystery switch in the panel that leads to th e marker beacon receiver. Anyone know what this switch is for, and is a pin out diagram available? - Thanks, Mike=0A=0A=0A ________________________________________________________________________________
Date: May 26, 2009
From: Bill Mauledriver Watson <MauleDriver(at)nc.rr.com>
The Z-14 I've put into my RV10 follows the best practices as described in the Connection with one oversight.... I have the 2 sided forest of tabs on the firewall but I only have an AWG 8 cable running to it from the rear batteries instead of an AWG2 fat wire. And it's too late to swap it out without significant re-work. The isssue is how to get the engine adequately grounded for the start. I remember this same situation being discussed recently on either the RV10 or AeroConnection list but I'd like to get some more input regarding my choices as I see it. Choice1: Run a flat fat wire (AWG 2 equivalent) from the forest of tabs lug to the engine and keep the engine mount out of the circuit. Here I'm depending on the AWG 8 cable and the firewall to provide and adequate ground for starting. I feel that I do have a solidly grounded airframe and it is a metal fuselage. Choice2: Ground the engine to the mount per Van's wiring diagram - 2 straps from the mount to the engine and relying on the 6 mount bolts to provide what they're not designed to provide. Here I'm trusting that the steel engine mount will work as a working part of my electrical system - clearly this is what the Connection is steering me away from. Choice3: Do both 1 and 2 which gives me a better chance of an adequate ground than either choice alone gives me, but I run the risk of ground loops. (what is the potential impact of ground loops in the starter circuit? Does this introduce potential ground loop problems to systems connected to the forest of tabs?) Bob, thanks for covering the same ground over and over! Bill "enjoying panel wiring and fiberglassing at the same time" Watson RV10 40605 Robert L. Nuckolls, III wrote: > > > At 10:14 AM 5/26/2009, you wrote: >> >> Does anyone have some scientific information (beyond the practical >> description in the Connection) that I can use to convince someone that >> running the engine ground strap to the engine mount is a poor choice ? >> >> Thanks ! > > The shortest, lowest resistance and minimum parts count path > in any high current conduction path is the road to Ground > System Nirvana. See: > > http://www.aeroelectric.com/articles/grnding.pdf > ________________________________________________________________________________
Date: May 26, 2009
Hi Bill. I was out at Aurora today and once last week. Both times I remembered your plane was out there but had forgotten to contact you to see if you would be around. I'm flying again out of Gauntlet Warbirds at least once a week. I'll be there next Monday if the weather is good. If you'd like to show off your plane, I would be delighted to see it. How often are you around out there? Take care, good to see your making progress with the issue you posted. Bob Meyers Building Sonex 982SX Web Site Index http://meyersfamily.org/Sonex982.html On May 25, 2009, at 3:50 PM, Bill Schertz wrote: > > > > Bob, an update -- The Battery, alternator, and LR3C are fine, the > symptoms below are attributed to operator induced problems. > > 1. Apparently when hooking up for the test, I caused a short that > blew the fuse to the alternator field. That is the reason for the > battery not charging. > > 2. I talked to B&C, and downloaded there diagnostic check sheet. > This led to the discovery of the blown fuse. > > 3. I have installed an old fashioned 50mv/60A shunt in the B lead, > and hooked it up to a DVM. Alternator working fine, hash on recorded > output must be as you originally surmised, the result of noise. > > I have not yet tried to filter the noise, now that I know the output > is stable, I can ignore the chart until I have time to fix it. > > Thanks for your help/input. > > Bill Schertz > KIS Cruiser #4045 > N343BS > Phase I testing > ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com > > > To: > Sent: Monday, May 25, 2009 3:26 PM > Subject: Re: AeroElectric-List: LR3 regulator Amperage indications > > >> > >> >> At 06:12 AM 5/18/2009, you wrote: >>> > >>> >>> Bob, >>> I am now convinced that the variations were real. I inserted an >>> ammeter into the field line, while the engine was stopped. Got a >>> reading of 3.5 amps. Then took the plane out, fired it up with the >>> ammeter in place, and when the alternator switch was turned on, >>> the current went to 3.5 amps for a very short time, then dropped >>> to zero. At that point, it stayed at zero, and the battery would >>> not charge. >>> >>> Put plane back in hanger, and did some static measurements. >>> >>> Voltage from LR-3 to field circuit breaker ~4.5 volts >> >> This voltage comes FROM your battery via the contactor, >> main bus, alternator field breaker and switch. When >> you made these measurements, was the battery charged >> at all? Or was it down to 4.5 volts? >> >>> Voltage at connector to alternator (black plug) ~4.5V >> >> >>> Resistance to ground through the leads that field current plugs >>> into varies (jumps around) and then often goes to open circuit. >>> >>> Could the slip rings be contaminated or not in contact? >> >> This is a possibility. You need to deduce the >> reason for such low voltage readings. Put >> a charger/maintainer on your battery and make >> sure it's 100% before you continue the investigation. >> >> >> >> Bob . . . >> >> ----------------------------------------) >> ( . . . a long habit of not thinking ) >> ( a thing wrong, gives it a superficial ) >> ( appearance of being right . . . ) >> ( ) >> ( -Thomas Paine 1776- ) >> ---------------------------------------- >> >> >> >> >> >> > > ________________________________________________________________________________
Date: May 26, 2009
Subject: Re: ARC R-402A Pin Out
Is the switch MB sensitivity? Matt- > I have an aircraft with an MX-300 radio and an ARC R-402A marker beacon > receiver. There is an unlabeledmystery switch in the panel that leads to > the marker beacon receiver. Anyone know what this switch is for, and is a > pin out diagram available? > > Thanks, Mike > > ________________________________________________________________________________
Date: May 26, 2009
t 08:47 PM 5/26/2009, you wrote: The Z-14 I've put into my RV10 follows the best practices as described in the Connection with one oversight.... I have the 2 sided forest of tabs on the firewall but I only have an AWG 8 cable running to it from the rear batteries instead of an AWG2 fat wire. And it's too late to swap it out without significant re-work. Is this the ONLY ground for the rear-mounted batteries? 8AWG is waaayyyy too small. Pull it out and ground the battery(ies) locally to the airframe. http://aeroelectric.com/Pictures/Batteries/Battery_Install_OBrien_1.jpg http://aeroelectric.com/Pictures/Batteries/Battery_Install_OBrien_2.jpg http://aeroelectric.com/Pictures/Grounding/Local_Battery_Grounds_1.jpg The isssue is how to get the engine adequately grounded for the start. I remember this same situation being discussed recently on either the RV10 or AeroConnection list but I'd like to get some more input regarding my choices as I see it. Choice1: Run a flat fat wire (AWG 2 equivalent) from the forest of tabs lug to the engine and keep the engine mount out of the circuit. This is a given . . . no matter what the rest of the ground system looks like. Here I'm depending on the AWG 8 cable and the firewall to provide and adequate ground for starting. I feel that I do have a solidly grounded airframe and it is a metal fuselage. I'm not sure from your description where the ends of the 8AWG wire are tied. This size of wire is too small for any significant starter performance. Choice2: Ground the engine to the mount per Van's wiring diagram - 2 straps from the mount to the engine and relying on the 6 mount bolts to provide what they're not designed to provide. Here I'm trusting that the steel engine mount will work as a working part of my electrical system - clearly this is what the Connection is steering me away from. It's been done before. Leave it alone. Choice3: Do both 1 and 2 which gives me a better chance of an adequate ground than either choice alone gives me, but I run the risk of ground loops. (what is the potential impact of ground loops in the starter circuit? Does this introduce potential ground loop problems to systems connected to the forest of tabs?) Do them both and ground the batteries to the airframe. The 8AWG wire can be cut loose and pulled out. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 27, 2009
At 11:35 PM 5/26/2009, you wrote: > > >t 08:47 PM 5/26/2009, you wrote: > > >The Z-14 I've put into my RV10 follows the best practices as >described in the Connection with one oversight.... I have the 2 >sided forest of tabs on the firewall but I only have an AWG 8 >cable running to it from the rear batteries instead of an AWG2 fat >wire. And it's too late to swap it out without significant re-work. Bill, re-reading my posting from last night I'm not sure I conveyed a clear image of my recommendations. In a nutshell: Add local grounds to airframe for the batteries if you don't already have them. Add crankcase to firewall ground stud for engine. Leave jumpers across the engine mount biscuits. You can cut the 8AWG wire out if you wish and if it is practical. It adds only weight and offers no significant electrical function. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Subject: KX-125 Installation Manual?
Date: May 27, 2009
Ladies/Gents: I'm in the process of wiring up a KX-125 Nav/Com into my Zenith 701 panel. Would anyone happen to have an installation manual for this radio? I've got the connector pinouts, but still more questions than answers about what gets connected where. Thanks... John Flavin Olathe, KS Zenith CH701 still 80% and holding... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=245534#245534 ________________________________________________________________________________
Date: May 27, 2009
From: "Johnson, Phillip (EXP)" <phillip.johnson(at)lmco.com>
Subject: RE: AeroElectric-List Digest: 21 Msgs - 05/26/09
Bob, I read your message and went to your web link indicated below and I can't accept that it is a good design. The problem that I see is that your design does not create a single ground reference. Ideally you want the engine block to be the ground reference with all currents flowing through it. To this end you need to connect the battery -ve to the crankcase and then make all grounds connect, either directly or indirectly, to the crankcase as well. In doing this there will be no ground potential differences to upset the instrumentation. If we look at schematic given in http://www.aeroelectric.com/articles/grnding.pdf there is no alternator shown but we all know that the alternator ground is connected to the crankcase so all the current that the alternator generates must pass through the engine block and then on to the battery through the interconnections given in your circuit. If I now connect an instrument such as an engine monitor to the instrument panel and ground it as indicated in the diagram the ground voltage that the engine monitor uses will be different to the ground reference seen by the sensor located on the engine in particular when high currents are being sourced from the alternator. Such a configuration will cause erroneous readings unless a differential arrangement is utilised. In addition to the grounding issues related to the instrumentation it is likely that, at some point, someone will make some ground connections to the engine block and some to the instrumentation ground. Somewhere , we are all human, the two will interconnect (yes you could/should check for all of these but people don't in particular when the owner is not the builder). All will be well when the system is new but as the aircraft ages and maybe the aircraft is sold to a new owner the ground between the engine and instrumentation/firewall ground will be left off (maybe after an annual inspection or maintenance session) or degraded through loose connection. The pilot now tries to start the engine and all of the current tries to flow through this instrumentation ground. This causes a melt down of the wiring and a potential ground fire and risk to those expensive electronics. It is my opinion, and I believe that the automotive industry also adopts this philosophy, that you connect the battery ground to the crankcase and then strap the engine to the airframe/car body and system ground so that the high current grounds pass only through the engine. Charging ground currents, which can be extremely high, also only pass through the engine block thereby preventing erroneous instrumentation and potential fire risk. OK I've now started to run and get my flame suit on. Regards to all Phillip Johnson ________________________________ Message 7 _____________________________________ From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Subject: Re: AeroElectric-List: Engine mount as starter ground path At 10:14 AM 5/26/2009, you wrote: > >Does anyone have some scientific information (beyond the practical >description in the Connection) that I can use to convince someone that >running the engine ground strap to the engine mount is a poor choice ? > >Thanks ! The shortest, lowest resistance and minimum parts count path in any high current conduction path is the road to Ground System Nirvana. See: http://www.aeroelectric.com/articles/grnding.pdf Engine mounts are steel assembled with steel hardware. The joints between mounts and other components of the airframe are not treated for the purpose of electrical "bonding". The engine mount is intended to hold the engine on the airplane and was not designed or installed to be a part of the electrical system. Note that Figure Z-15 and Chapter 5 of the 'Connection speak to and illustrate a notion that engines are best tied to the single point fire-wall ground block with a single-flexible- fatwire. To avoid having the firewall sheet participate in a PARALLEL ground path (read ground loop) any bonding jumpers across the engine mounts are best removed. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 27, 2009
Subject: SEC-1223 Power Supply --Question re isolating diode
and charge limiting resistor Bob, On reading a recent thread on Aerolectrics, I ordered the SEC-1223 Power Supply from Universal Radio to power my avionics on the ground with direct connection to my aircraft battery as a battery backup. Question: The supplied manual gives a warning: "These units are power supplies and not battery chargers. Do not connect these units directly to a battery. Battery charging and battery charging may be undertaken only when the battery is connected through suitable external isolating diodes and charge limiting resistor. The isolating diode will ensure that the battery does not back power the power supply.. When the battery is deeply discharged, it will initially draw a very large charging current and thus, will force the power supply into current limit mode for prolonged periods. This is harmful for the power supply. The charge limiting resistor will limit the charging current, thereby, ensuring that the maximum charging current is well below the current limit value of the power supply. It is recommended that optional battery backup module BBM-1225 may be used to convert SEC-1223 for battery backup application." Looks simple enough to make my own module? Could you recommend a circuit with diagram and give your two cents regarding the warning? Don Schmiesing **************Dinner Made Easy Newsletter - Simple Meal Ideas for Your Family. Sign Up Now! 3Fhttp:%2F%2Frecipes.dinnermadeeasy.com%2F%3FESRC%3D622) ________________________________________________________________________________
Date: May 27, 2009
Subject: Re: KX-125 Installation Manual?
Sent by PM br Werner jf3sb wrote: > > Ladies/Gents: > > I'm in the process of wiring up a KX-125 Nav/Com into my Zenith 701 panel. Would anyone happen to have an installation manual for this radio? I've got the connector pinouts, but still more questions than answers about what gets connected where. > > Thanks... > > John Flavin > Olathe, KS > Zenith CH701 still 80% and holding... > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=245534#245534 > > > ________________________________________________________________________________
Date: May 27, 2009
Subject: Grounding philosophy
At 09:05 AM 5/27/2009, you wrote: Bob, I read your message and went to your web link indicated below and I can't accept that it is a good design. The problem that I see is that your design does not create a single ground reference. Yes it does. The architectures discussed in Figure Z-15 and other writings suggeste the stud at the forest of tabs on the firewall is the central point ground for the aircraft. Ideally you want the engine block to be the ground reference with all currents flowing through it. To this end you need to connect the battery -ve to the crankcase and then make all grounds connect, either directly or indirectly, to the crankcase as well. In doing this there will be no ground potential differences to upset the instrumentation. Instrumentation is a special case where grounded automotive sensors are at risk for suffering ground loop interference. This has been discussed at length in various writings. If the problem presents itself (usually manifest by a shift in instrumentation readings in response to alternator loads), then the "ground" leads for panel mounted instruments need to be extended to the crankcase. However, if one has a very low resistance net between he crankcase and the firewall ground stud . . . then the "problem" may be reduced to insignificant if not completely unobservable. The pilot now tries to start the engine and all of the current tries to flow through this instrumentation ground. This causes a melt down of the wiring and a potential ground fire and risk to those expensive electronics. Again, discussed in past publications and postings . . . "Smoking ground returns" is easily avoided by not closing the returns. Common occurrences include the risk of instrumentation grounds for instruments not designed to live in the real world of aircraft. Another common risk happens when builders attached p-lead shields to crankcase at one end and airframe at the other end. All of my drawings illustrate technique for avoiding that loop as well. It is my opinion, and I believe that the automotive industry also adopts this philosophy, that you connect the battery ground to the crankcase and then strap the engine to the airframe/car body and system ground so that the high current grounds pass only through the engine. Charging ground currents, which can be extremely high, also only pass through the engine block thereby preventing erroneous instrumentation and potential fire risk. Batteries go to crankcases in cars because the battery always sits right next to the engine. The automotive industry has adopted the same philosophy as every other industry for minimizing the numbers of joints, fasteners and pieces of wire in the fat-wire conduction paths. Now, if one had a battery on the forward side of the firewall then there is no electrical reason NOT to ground the battery right to the crankcase. There are mechanical reasons not to . . . we've already established the value of a 2AWG equivalent jumper from crankcase to ground stud. This same stud becomes a practical spot to ground a battery as well . . . and the 2AWG bonding strap makes sure that voltage differences between the crankcase and the ground stud are insignificantly small. If the battery is aft of the firewall, then the most practical battery ground is the firewall ground stud . . . or to the airframe on an all metal airplane. OK I've now started to run and get my flame suit on. Zero risk from me sir . . . Bob . . . ________________________________________________________________________________
Date: May 27, 2009
At 09:18 AM 5/27/2009, you wrote: Bob, On reading a recent thread on Aerolectrics, I ordered the SEC-1223 Power Supply from Universal Radio to power my avionics on the ground with direct connection to my aircraft battery as a battery backup. Question: The supplied manual gives a warning: "These units are power supplies and not battery chargers. Do not connect these units directly to a battery. Battery charging and battery charging may be undertaken only when the battery is connected through suitable external isolating diodes and charge limiting resistor. The isolating diode will ensure that the battery does not back power the power supply.. When the battery is deeply discharged, it will initially draw a very large charging current and thus, will force the power supply into current limit mode for prolonged periods. This is harmful for the power supply. The charge limiting resistor will limit the charging current, thereby, ensuring that the maximum charging current is well below the current limit value of the power supply. It is recommended that optional battery backup module BBM-1225 may be used to convert SEC-1223 for battery backup application." Looks simple enough to make my own module? Could you recommend a circuit with diagram and give your two cents regarding the warning? Yes. I have a drawing in the pile of things to do that shows how to convert the SEC-1223 (or a similar power supply) to an "alternator emulator". The warnings from Samlex about using the stand-alone power supply as a battery charger are well taken. Any time I've used these supplies to power up the airplane in the shop, the power supply was used as a battery emulator. I'll see if I can dig out those drawings and publish them along with the explanatory text. In the mean time, just use the power supply to energize the system (tied to the alternator b-lead?) but leaving the battery master switch OFF. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 27, 2009
Subject: Re: Grounding philosophy
> > snip > > Batteries go to crankcases in cars because the battery > always sits right next to the engine. The automotive > industry has adopted the same philosophy as every other snip Just to be contrarian, our family has owned two different cars with the battery in the trunk (rear) and the engine in the front - both foreign jobs.. :) The manufacturer claims they did it for better weight distribution. I can't recall whether the batteries were locally grounded, or if they had a dedicated ground wire running to the front. > > Bob . . . > Matt- ________________________________________________________________________________
Date: May 27, 2009
It's crystal clear now! Thanks Robert L. Nuckolls, III wrote: > > > At 11:35 PM 5/26/2009, you wrote: >> >> >> t 08:47 PM 5/26/2009, you wrote: >> >> >> The Z-14 I've put into my RV10 follows the best practices as >> described in the Connection with one oversight.... I have the 2 sided >> forest of tabs on the firewall but I only have an AWG 8 cable >> running to it from the rear batteries instead of an AWG2 fat wire. >> And it's too late to swap it out without significant re-work. > > Bill, re-reading my posting from last night I'm not > sure I conveyed a clear image of my recommendations. > In a nutshell: > > Add local grounds to airframe for the batteries if > you don't already have them. > > Add crankcase to firewall ground stud for engine. > > Leave jumpers across the engine mount biscuits. > > You can cut the 8AWG wire out if you wish and > if it is practical. It adds only weight and > offers no significant electrical function. > > > Bob . . . > > ----------------------------------------) > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > ---------------------------------------- > > ________________________________________________________________________________
From: "Bill Bradburry" <bbradburry(at)bellsouth.net>
Subject: DynaFocal engine mount ring
Date: May 27, 2009
Not exactly electric, but airplane related... I have an engine mount ring for sale.. I am using an alternative engine, so I don't need this ring. AC Spruce sells it for $180 plus shipping. I will sell mine for $125 plus shipping. It is a Type 1 Dynafocal with 2.75 cups. Bill B ________________________________________________________________________________
Date: May 27, 2009
Static is usually described as high voltage and little to no current. That means those nasty electrons are really juiced up...like a 2 year old loaded with chocolate cake, etc. They can jump tall buildings, and wide gaps, etc. A hopped up electron does not need a good conductor to move and be a nuisance. Rusty or otherwise not well connected pipes, etc. work just fine. So connecting a static grounding line to an exhaust pipe should work just fine to dump most, if not all, of the electrons to ground. Most of my Cessna wing is bare aluminum. As an extra precaution, I lightly touch the fuel nozzle to the wing surface before I even take the fuel caps off. That also relieves any final electrons off the table before fueling. Also, as the fuel flows, I make sure the nozzle is touching the metal filler neck. In dry climates especially, flowing fuel will also generate some static. With the nozzle grounded against the filler metal that takes care of those speedy critters also. David ----- Original Message ----- From: Kelly McMullen To: aeroelectric-list(at)matronics.com Sent: Tuesday, May 26, 2009 2:21 PM Subject: Re: AeroElectric-List: Engine mount as starter ground path Given such a ground path, how does one get lineboys trained that the engine exhaust pipe is a terrible place for ground wire, that the fuel tanks are in the wings, and something like a bare spot on wing tiedown has a much shorter ground path? I always wonder how static charge is supposed to make it from the fuel tank through the airframe to the engine and down the rusty, carboned up exhaust pipe, usually with a swivel or slip joint or two to that ground wire, without significant resistance. Robert L. Nuckolls, III wrote: At 10:14 AM 5/26/2009, you wrote: Does anyone have some scientific information (beyond the practical description in the Connection) that I can use to convince someone that running the engine ground strap to the engine mount is a poor choice ? Thanks ! The shortest, lowest resistance and minimum parts count path in any high current conduction path is the road to Ground System Nirvana. See: http://www.aeroelectric.com/articles/grnding.pdf Engine mounts are steel assembled with steel hardware. The joints between mounts and other components of the airframe are not treated for the purpose of electrical "bonding". The engine mount is intended to hold the engine on the airplane and was not designed or installed to be a part of the electrical system. Note that Figure Z-15 and Chapter 5 of the 'Connection speak to and illustrate a notion that engines are best tied to the single point fire-wall ground block with a single-flexible- fatwire. To avoid having the firewall sheet participate in a PARALLEL ground path (read ground loop) any bonding jumpers across the engine mounts are best removed. Bob . . . ________________________________________________________________________________
Subject: Alternator with built-in regulator
Date: May 27, 2009
I am building an RV-7 and have purchased a stock alternator from Vans (in firewall forward kit). I understand this unit to have a built-in regulator. I hope to use the B&C LR3C-14. Being new to aircraft electronics...will this create an issue or is there something that I'm missing? Wade Roe SOUTHERN CARBIDE TECHNOLOGIES, INC. 7739 Unity Road M&D Industrial Park Tuscaloosa, AL 35401 205-248-6700 205-248-6372 fax ________________________________________________________________________________
Date: May 27, 2009
If the regulator is built in it means exactly that..No external regulator will be required or indeed desired... Did you get the Plane Power 60A alternator or the rebuilt Honda unit I think it is. The Plane Power is the finest internally regulated alternator there is and Van's has the best prices on them. If you are building an electrically dependant airplane or an IFR bird then this is the unit you should have. Frank -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Wade Roe Sent: Wednesday, May 27, 2009 1:00 PM Subject: AeroElectric-List: Alternator with built-in regulator I am building an RV-7 and have purchased a stock alternator from Vans (in firewall forward kit). I understand this unit to have a built-in regulator. I hope to use the B&C LR3C-14. Being new to aircraft electronics...will this create an issue or is there something that I'm missing? Wade Roe SOUTHERN CARBIDE TECHNOLOGIES, INC. 7739 Unity Road M&D Industrial Park Tuscaloosa, AL 35401 205-248-6700 205-248-6372 fax ________________________________________________________________________________
Date: May 27, 2009
Subject: State of the art - then and now
I'm in possession of several issues of the Electrical Experimenter circa 1916. This hobbyist/amateur/semi- professional publication offered a newsstand source for both understanding and state of the art news in a range of technologies. I'm using one of these magazines as reference for a science history presentation I'm doing. I've scanned it for sharing and thought I would post it for those having an interest in such things. See: http://tinyurl.com/ofbj3c It's interesting to see the depth and scope of interests illustrated on these pages. It's also interesting to see a level of hucksterism and quackery not unlike that which pours forth in today's video and print media! See pdf pages 7, 25, 62 (violet rays), 65 (Pandiculator). But the casually discriminating eye can easily identify and appreciate the good stuff of which there is plenty. Hope you enjoy browsing this piece of technological history. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 27, 2009
The alternator from Vans is a reconditioned Japanese automobile unit (Honda?) that came with the firewall forward kit. I figured the B&C linear regulator to be a superior/cleaner product than that on the alternator. The plane will be IFR and all electric. Wade Roe -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Hinde, Frank George (Corvallis) Sent: Wednesday, May 27, 2009 3:37 PM Subject: RE: AeroElectric-List: Alternator with built-in regulator (Corvallis)" If the regulator is built in it means exactly that..No external regulator will be required or indeed desired... Did you get the Plane Power 60A alternator or the rebuilt Honda unit I think it is. The Plane Power is the finest internally regulated alternator there is and Van's has the best prices on them. If you are building an electrically dependant airplane or an IFR bird then this is the unit you should have. Frank -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Wade Roe Sent: Wednesday, May 27, 2009 1:00 PM Subject: AeroElectric-List: Alternator with built-in regulator I am building an RV-7 and have purchased a stock alternator from Vans (in firewall forward kit). I understand this unit to have a built-in regulator. I hope to use the B&C LR3C-14. Being new to aircraft electronics...will this create an issue or is there something that I'm missing? Wade Roe SOUTHERN CARBIDE TECHNOLOGIES, INC. 7739 Unity Road M&D Industrial Park Tuscaloosa, AL 35401 205-248-6700 205-248-6372 fax ________________________________________________________________________________
Date: May 27, 2009
Subject: Re: Alternator with built-in regulator
At 02:59 PM 5/27/2009, you wrote: > >I am building an RV-7 and have purchased a stock alternator from Vans >(in firewall forward kit). I understand this unit to have a built-in >regulator. I hope to use the B&C LR3C-14. Being new to aircraft >electronics...will this create an issue or is there something that I'm >missing? Do you have a copy of the 'Connection? It speaks to the various configurations for internally/externally regulated alternators. The updated chapter on alternators is posted at: http://aeroelectric.com/R12A/03_Alternator_12A1.pdf Most single engine airplanes fly with externally regulated alternators for reasons offered in the chapter cited above. But either configuration can be adapted to aircraft. If you have a Plane Power unit from Van's, know that it has been successfully integrated into aircraft while meeting design goals for ON/OFF, any time, any conditions control. Further, it's fitted with over-voltage management. You won't need an LR-3 for this alternator. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 27, 2009
At 01:00 PM 5/27/2009, you wrote: >The discussion about engine mounts as ground points has generated a >question. The "When is a Good Ground Not?" article shows 2AWG wire >for the high current paths as do the Z-15 diagrams demonstrating >various grounding architectures. > >The Z-13/8 diagram I was planning my electrical system around shows >4AWG wires for these same high current paths. All my "fat wires" >will be under 3 feet since my RG battery, starter and battery >contactors, 40A alternator, and firewall ground block will all be on >or close to the firewall. I thought I had read somewhere in the >"AeroElectric Connection" that 4AWG was fine as long as all the fat >wires were 3 feet or less, but now I can't find it. > >Could someone confirm that 4AWG welding cable is acceptable for the >high current wires when these wires are all located on the hot side >of the firewall, wired per Z-13/8 and each under three feet in length? The drawings published on our website and publications are intended to illustrate architectures. Exact sizing of circuit protection, wires, batteries, alternators, etc. are up to the builder based on a host of considerations. Your recollection is accurate in that if the battery, starter and alternator are all within short distances of each other (3' or so) then 4AWG is adequate to the task of managing fat-wire duties. When engine and batteries are remotely located from each other (rear mounted batteries in RV-8, canard pushers) will benefit from something bigger like 2AWG battery cables. Really extreme cases like some some winged watercraft, parallel 2AWG or 0AWG is often used. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 27, 2009
In that case send that alternator back to Vans and exchange it for the plane power unit...Trying to use the B&C regulator (which it was not designed for) is a bit like putting lipstick on a pig..Its still a pig! I futzed with a rebuilt alternator for a while and had a couple of scary moments in IMC..then I changed to the Plane power and its been faultless ever since. They come with a wonderful reputation. No electrical noise, just fit (with the supplied brackets) and forget it. On An all electric IFR airplane the alternator is not the place to be making shortcuts!!!..The extra couple of hundred bucks is WELL spent. Frank RV7a..all electric IFR including 2* EI's and the fuel pumps! -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Wade Roe Sent: Wednesday, May 27, 2009 2:20 PM Subject: RE: AeroElectric-List: Alternator with built-in regulator The alternator from Vans is a reconditioned Japanese automobile unit (Honda?) that came with the firewall forward kit. I figured the B&C linear regulator to be a superior/cleaner product than that on the alternator. The plane will be IFR and all electric. Wade Roe ________________________________________________________________________________
Date: May 27, 2009
> > >The plane will be IFR and all electric. > >Wade Roe > Wade, would it be a fair assumption then that a second alternator will go onto the vacuum pump pad? Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 27, 2009
Subject: Military_Humor_Miss_America_1.jpg (JPEG Image, 490x442
pixels) http://www.allmilitary.com/i/Image/Military_Humor_Miss_America_1.jpg ________________________________________________________________________________
Date: May 28, 2009
Subject: 12V Power Socket
Hello, I am wiring up a 12V (cigarette lighter) power socket into my panel. Can anyone tell me the convention for the +ve and -terminals on these things? Thanks, Andrew. ________________________________________________________________________________
Date: May 28, 2009
Bob, My first post to this site. I'm working on an rv-10. I thought I understood the grounding once you gave the below explanation to Bill W. One and two are clear. I read #3 as putting a jumper across an individual mount t0 both sides of a single biscuit. In a later post, you advise "any bonding jumpers across the engine mounts are best removed" to avoid parallel grounds. Equally, the Connection speaks of a single point ground at firewall. Is this a contradiction or does it refer to not having jumpers between two completely separate mounts? Thanks, Tom Hanaway Boynton Beach, FL Robert L. Nuckolls, III wrote: > > > > At 11:35 PM 5/26/2009, you wrote: >> > >> >> t 08:47 PM 5/26/2009, you wrote: >> > >> >> The Z-14 I've put into my RV10 follows the best practices as >> described in the Connection with one oversight.... I have the 2 sided >> forest of tabs on the firewall but I only have an AWG 8 cable >> running to it from the rear batteries instead of an AWG2 fat wire. >> And it's too late to swap it out without significant re-work. > > Bill, re-reading my posting from last night I'm not > sure I conveyed a clear image of my recommendations. > In a nutshell: > > Add local grounds to airframe for the batteries if > you don't already have them. > > Add crankcase to firewall ground stud for engine. > > Leave jumpers across the engine mount biscuits. > > You can cut the 8AWG wire out if you wish and > if it is practical. It adds only weight and > offers no significant electrical function. > > > Bob . . . > > ----------------------------------------) > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) ________________________________________________________________________________
Date: May 28, 2009
From: "jay(at)horriblehyde.com" <jay(at)horriblehyde.com>
Subject: Re: 12V Power Socket
The positive is the centre post and negative the outer shell. Jay -----Original Message----- From: "Andrew Butler" [andrewbutler(at)ireland.com] Date: 05/28/2009 04:04 PM Subject: Re: AeroElectric-List: 12V Power Socket Hello, I am wiring up a 12V (cigarette lighter) power socket into my panel. Can anyone tell me the convention for the +ve and -terminals on these things? Thanks, Andrew. ________________________________________________________________________________
Date: May 28, 2009
Positive is the center (spring loaded plunger on the plug), ground is the shell (two flat connectors along the side of the plug). Rick On Thu, May 28, 2009 at 7:45 AM, Andrew Butler wrote: > andrewbutler(at)ireland.com> > > Hello, > > I am wiring up a 12V (cigarette lighter) power socket into my panel. > > Can anyone tell me the convention for the +ve and -terminals on these > things? > > Thanks, > > Andrew. > > ________________________________________________________________________________
Date: May 28, 2009
Roger that. I plan to use the B&C 8 amp alternator or the 20 amp as backup. Wade Roe IPhone message On May 27, 2009, at 10:38 PM, "Robert L. Nuckolls, III" wrote: > > > > >> >> >> The plane will be IFR and all electric. >> >> Wade Roe >> > > Wade, would it be a fair assumption then that > a second alternator will go onto the vacuum > pump pad? > > > Bob . . . > > ----------------------------------------) > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > ---------------------------------------- > > ________________________________________________________________________________
Date: May 28, 2009
Andrew, The usual center is positive and the shell goest to ground. You should wire the scocket to powerthe panel with out turning the master on. I have mine that way so I can play with the panel with out using the aircraft battery. I have a little cpmpressor / battery unit that I take to the hanger and keeps the tires up and lets me run my glass panel for setting up a trip etc. Jim ____________________________________________________________ Compete with the big boys. Click here to find products to benefit your business. http://thirdpartyoffers.juno.com/TGL2141/fc/BLSrjpTI97zF6gFxJRmQXuZsZBzUiPEnqkuoiaMthATKQtsww5EJAaYCWxa/ ________________________________________________________________________________
Date: May 28, 2009
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Subject: At 09:05 AM 5/27/2009, you wrote: Bob, >I read your message and went to your web link indicated below and I >can't accept that it is a good design. The problem that I see is that >your design does not create a single ground reference. >Yes it does. The architectures discussed in Figure Z-15 and >other writings suggeste the stud at the forest of tabs on the >firewall is the central point ground for the aircraft. So Ground point number one is the "forest of tabs" and ground point number two is the engine crankcase when the alternator, starter motor, and most engine sensors make their ground. I.e. there is not a single point ground. In an ideal world where #2 gauge wires and interconnections have zero resistance but, as you point out in your document, this is not the case. >>Ideally you want >>the engine block to be the ground reference with all currents flowing >>through it. To this end you need to connect the battery -ve to the >>crankcase and then make all grounds connect, either directly or >>indirectly, to the crankcase as well. In doing this there will be no >>ground potential differences to upset the instrumentation. >Instrumentation is a special case where grounded automotive >sensors are at risk for suffering ground loop interference. >This has been discussed at length in various writings. If the >problem presents itself (usually manifest by a shift in >instrumentation readings in response to alternator loads), >then the "ground" leads for panel mounted instruments need >to be extended to the crankcase. However, if one has a very >low resistance net between he crankcase and the firewall >ground stud . . . then the "problem" may be reduced to >insignificant if not completely unobservable. They should not have to be a special case if wired correctly. When everything references the crankcase there is no special case. The problem is that when the installation is done all the connections are clean and the installer usually knows what he is doing. A few years down the road an unknowledgeable person does not prepare the electrical bonding surface as well as he should and then problems start happening when current starts to flow through the circuit. Using the philosophy that I have given, these problems are reduced significantly, which in my opinion makes for a better design. >>The pilot now tries to start the engine and all of >>the current tries to flow through this instrumentation ground. This >>causes a melt down of the wiring and a potential ground fire and risk to >>those expensive electronics. >Again, discussed in past publications and postings . . . >"Smoking ground returns" is easily avoided by not closing >the returns. Common occurrences include the risk of >instrumentation grounds for instruments not designed >to live in the real world of aircraft. Another common >risk happens when builders attached p-lead shields to >crankcase at one end and airframe at the other end. >All of my drawings illustrate technique for avoiding >that loop as well. Again, "Smoking ground returns" are avoided if you use my design solution. >>It is my opinion, and I believe that the automotive industry also adopts >>this philosophy, that you connect the battery ground to the crankcase >>and then strap the engine to the airframe/car body and system ground so >>that the high current grounds pass only through the engine. Charging >>ground currents, which can be extremely high, also only pass through the >>engine block thereby preventing erroneous instrumentation and potential >>fire risk. >Batteries go to crankcases in cars because the battery >always sits right next to the engine. In the old days the battery ground went straight to the bodywork and then there was an engine strap in a different location which coupled the body to the engine. I'm not sure when the change occurred but I would guess that it occurred somewhere soon after the first electronic systems were implemented. I changed the battery on my neighbours Audi a couple of years ago and that had the battery under the rear seats. The ground lead did not go straight to the body but I can't be sure that it went all the way to the front either. I surmise that if it did not go directly to the body it would probably make the full journey to the engine. >The automotive >industry has adopted the same philosophy as every other >industry for minimizing the numbers of joints, fasteners >and pieces of wire in the fat-wire conduction paths. Agreed >Now, if one had a battery on the forward side of >the firewall then there is no electrical reason >NOT to ground the battery right to the crankcase. >There are mechanical reasons not to . . . we've >already established the value of a 2AWG equivalent >jumper from crankcase to ground stud. This same stud >becomes a practical spot to ground a battery as >well . . . and the 2AWG bonding strap makes sure >that voltage differences between the crankcase >and the ground stud are insignificantly small. I have a Cozy MK IV with the battery on the cockpit side of the firewall. I have approximately two feet of cable connecting the -ve to crankcase ground so length cant be an issue. The issue is that there are two additional connections and a couple of feet of #2 cable separating the engine ground from the "forest of tabs". Using the numbers from your paper this gives 1.3 mohm of resistance. Assuming you have an alternator sourcing say 40 amps you now have 50 mV ground difference which is also rectified AC i.e. noise. Now as you have said it is difficult to get better than 0.5miliohm per connection and with time and sloppy maintenance the number grows to something that is unacceptable. All this just because the ground reference was not defined appropriately. >If the battery is aft of the firewall, then the >most practical battery ground is the firewall >ground stud . . . or to the airframe on an all >metal airplane. OK I have a plastic aeroplane so airframe is not an option but I still feel the firewall is a bad choice. >>OK I've now started to run and get my flame suit on. >Zero risk from me sir . . . Bob . . . ________________________________________________________________________________
Subject: Reading Potentiometer Values
Date: May 28, 2009
I have a handful of potentiometers at home and I want to verify the ohms rating of each. What is the best/easiest or cheapest way to determine their rating? The only real equipment I have is a simple DC tester with ohms values. I will be using one to control the audio volume between my D180 & GMA340. Thanks, Glenn ________________________________________________________________________________
Date: May 28, 2009
Absolutely, if you think about it for just a second, these things are no different than a standard light bulb socket. Touch the center contact and you'll light up; touch the ring and your still here. When people used to smoke everyone knew the center contact had to touch to make the heat and the cool ground was the outside. After too many cigarettes you got stinky fingers and the contact would begin to fail and loose heat thus becoming less of a conductor between the center and the shell. If the shell were a on the + side of the ship, your 63 Chevy's steel panel would still be smoking. Glenn From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Richard Girard Sent: Thursday, May 28, 2009 9:44 AM Subject: Re: AeroElectric-List: 12V Power Socket Positive is the center (spring loaded plunger on the plug), ground is the shell (two flat connectors along the side of the plug). Rick On Thu, May 28, 2009 at 7:45 AM, Andrew Butler wrote: Hello, I am wiring up a 12V (cigarette lighter) power socket into my panel. Can anyone tell me the convention for the +ve and -terminals on these things? Thanks, Andrew. -List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List http://forums.matronics.com le, List Admin. ="_blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: May 28, 2009
One caveat on P & P alts. The one I had came with what I'll call a cheap Molex connector for the field wire etc. I replaced it with sold wiring after it vibrated and sheared itself off for the second time. I now use and internal job and have not had any issues. It's all about the core quality. Alternators are one of the biggest scams in automotive history. They cost about $10.00 to rebuild and the vendors charge you an arm and a leg. As Frank mentioned, start with a good core and stick with it. I'm using one off a Porsche and it works like a champ. Glenn -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Hinde, Frank George (Corvallis) Sent: Wednesday, May 27, 2009 5:45 PM Subject: RE: AeroElectric-List: Alternator with built-in regulator (Corvallis)" In that case send that alternator back to Vans and exchange it for the plane power unit...Trying to use the B&C regulator (which it was not designed for) is a bit like putting lipstick on a pig..Its still a pig! I futzed with a rebuilt alternator for a while and had a couple of scary moments in IMC..then I changed to the Plane power and its been faultless ever since. They come with a wonderful reputation. No electrical noise, just fit (with the supplied brackets) and forget it. On An all electric IFR airplane the alternator is not the place to be making shortcuts!!!..The extra couple of hundred bucks is WELL spent. Frank RV7a..all electric IFR including 2* EI's and the fuel pumps! -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Wade Roe Sent: Wednesday, May 27, 2009 2:20 PM Subject: RE: AeroElectric-List: Alternator with built-in regulator The alternator from Vans is a reconditioned Japanese automobile unit (Honda?) that came with the firewall forward kit. I figured the B&C linear regulator to be a superior/cleaner product than that on the alternator. The plane will be IFR and all electric. Wade Roe ________________________________________________________________________________
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
Date: May 28, 2009
Me too..I found that the SD8 was adequate and remember I run electric fuel pumps..One of them MUST be running or I become a glider. I have a GNS 430W, transponder etc etc and found that with sensible load management the SD8 would maintian the battery volts at 12..Not enough to charge the battery but it would keep up with the load. Frank -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Wade Roe Sent: Thursday, May 28, 2009 6:52 AM Subject: Re: AeroElectric-List: Alternator with built-in regulator Roger that. I plan to use the B&C 8 amp alternator or the 20 amp as backup. Wade Roe IPhone message ________________________________________________________________________________
Date: May 28, 2009
Subject: Re: State of the art - then and now
Great stuff Bob! "The more things change the more they stay the same." Thanks for sharing... C. Stone I'm in possession of several issues of the Electrical Experimenter circa 1916. This hobbyist/amateur/semi- professional publication offered a newsstand source for both understanding and state of the art news in a range of technologies. I'm using one of these magazines as reference for a science history presentation I'm doing. I've scanned it for sharing and thought I would post it for those having an interest in such things. See: http://tinyurl.com/ofbj3c It's interesting to see the depth and scope of interests illustrated on these pages. It's also interesting to see a level of hucksterism and quackery not unlike that which pours forth in today's video and print media! See pdf pages 7, 25, 62 (violet rays), 65 (Pandiculator). But the casually discriminating eye can easily identify and appreciate the good stuff of which there is plenty. Hope you enjoy browsing this piece of technological history. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 28, 2009
Subject: Re: Reading Potentiometer Values
Hi Glenn, It sounds like you have what you need. Measure the resistance (ohms) between the two outside pins. That will tell you what the resistance of the pot is. There is another consideration when selecting a pot. There linear and "audio" taper pots. A linear pot will change resistance linearly with pot rotation. Turn it half way between CCW and CW will give a reading of 1/2 the total resistance. An audio taper will change exponentially. Rotating half way between CCW and CW will result in a lower resistance between the center pin and the CCW pin and a higher resistance between the center pin and the CW pin. The audio taper is probably the best choice for your application. Also, there should be some markings on the pot that will tell you what value the pot is. Picking up a couple of random pots from by work bench, one is marked "200 (ohm) LIN" which is pretty straightforward to decode. the other is marked "A100K" which clearly indicates it is a 100 kohm pot, and I would guess the "A" means audio taper but I would have to check. (There are pots that aren't configured quite as described, but it should work for most run of the mill pots.) Bob W. wrote: > > I have a handful of potentiometers at home and I want to verify the ohms > rating of each. What is the best/easiest or cheapest way to determine > their rating? The only real equipment I have is a simple DC tester with > ohms values. I will be using one to control the audio volume between my > D180 & GMA340. > > Thanks, > Glenn > > > > > -- N93BD - Rotary Powered BD-4 - http://www.bob-white.com 3.8 Hours Total Time and holding Cables for your rotary installation - http://roblinstores.com/ ________________________________________________________________________________
Date: May 28, 2009
It depends on what you want to accomplish. If you wire it to the buss side of the master you can power your panel from it during the build. But if you wire it to the battery side of the master you can power accessories or trickle charge the battery without turning on the master. There are pluses & minuses both ways. Think it through and decide what's best for you. Regards, Greg Young > -----Original Message----- > ground. You should wire the scocket to powerthe panel with > out turning the master on. > I have mine that way so I can play with the panel with out > using the aircraft battery. I have a little cpmpressor / > battery unit that I take to the hanger and keeps the tires > up and lets me run my glass panel for setting up a trip etc. > > > ________________________________________________________________________________
Date: May 28, 2009
Subject: Grey code output to multiple devices
Folks, I have a Narco AR 850 grey code altitude reporter. I would like to connect it to two devices (GPS and transponder) instead of just the transponder. The serial port on the GPS is being used for something else and it has grey code lines also. Both the GPS and transponder have diode suppression in the grey code lines in order to prevent an off unit from dropping the signal to low. What say ye.....can I do this - or will smoke escape....? Thanks, Ralph Capen ________________________________________________________________________________
Date: May 28, 2009
Excellent, Thanks Bob. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bob White Sent: Thursday, May 28, 2009 12:00 PM Subject: Re: AeroElectric-List: Reading Potentiometer Values Hi Glenn, It sounds like you have what you need. Measure the resistance (ohms) between the two outside pins. That will tell you what the resistance of the pot is. There is another consideration when selecting a pot. There linear and "audio" taper pots. A linear pot will change resistance linearly with pot rotation. Turn it half way between CCW and CW will give a reading of 1/2 the total resistance. An audio taper will change exponentially. Rotating half way between CCW and CW will result in a lower resistance between the center pin and the CCW pin and a higher resistance between the center pin and the CW pin. The audio taper is probably the best choice for your application. Also, there should be some markings on the pot that will tell you what value the pot is. Picking up a couple of random pots from by work bench, one is marked "200 (ohm) LIN" which is pretty straightforward to decode. the other is marked "A100K" which clearly indicates it is a 100 kohm pot, and I would guess the "A" means audio taper but I would have to check. (There are pots that aren't configured quite as described, but it should work for most run of the mill pots.) Bob W. wrote: > > I have a handful of potentiometers at home and I want to verify the ohms > rating of each. What is the best/easiest or cheapest way to determine > their rating? The only real equipment I have is a simple DC tester with > ohms values. I will be using one to control the audio volume between my > D180 & GMA340. > > Thanks, > Glenn > > > > > -- N93BD - Rotary Powered BD-4 - http://www.bob-white.com 3.8 Hours Total Time and holding Cables for your rotary installation - http://roblinstores.com/ ________________________________________________________________________________
Date: May 28, 2009
At 09:23 AM 5/28/2009, you wrote: > >I have a handful of potentiometers at home and I want to verify the ohms >rating of each. What is the best/easiest or cheapest way to determine >their rating? The only real equipment I have is a simple DC tester with >ohms values. I will be using one to control the audio volume between my >D180 & GMA340. For simple volume control duties, simply knowing the resistance value is sufficient. Further, it's unlikely that the exact value is critical. Potentiometers with values ranging from 500 to perhaps as high as 10000 ohms would work for you. It's an easy experiment and zero risk to the rest of your system. Digital multi-meters are inexpensive. Harbor Freight has one that seems to be perpetually on sale for under $5. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 28, 2009
At 08:51 AM 5/28/2009, you wrote: > >Roger that. I plan to use the B&C 8 amp alternator or the 20 amp as >backup. Most builders find the SD-8 to be adquate to the task. Consider Figure Z-13/8. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 28, 2009
So Ground point number one is the "forest of tabs" and ground point number two is the engine crankcase when the alternator, starter motor, and most engine sensors make their ground. I.e. there is not a single point ground. In an ideal world where #2 gauge wires and interconnections have zero resistance but, as you point out in your document, this is not the case. Let's not get wrapped around the axle for defining "single point ground". The better term is perhaps a central ground point from which the rest of the ground system radiates. Now, there can be and often is further spreading from nodes remote from the central ground. One example is the crankcase from which numerous grounded sensors find a reference. See Figure Z-15 (three sheets). Risks of system performance degrading due to currents circulating in the ground system are reduced if not eliminated by first avoiding multiple grounds within any single system that are not co-located. In the case of engine instruments with grounded sensors, taking the ground returns for panel mounted instruments back to the crankcase makes the crankcase a "single point ground" for that suite of instruments. Figure Z-15 speaks to a variety of grounding options for accessories located all over the airplane. None of those illustrations suggests that ALL grounds be brought to a single-point be it the crankcase or forest of tabs. What those drawing DO illustrate is making a distinction between potential noise victims, noise antagonists and breaking the ground loop coupling mode. They should not have to be a special case if wired correctly. When everything references the crankcase there is no special case. The problem is that when the installation is done all the connections are clean and the installer usually knows what he is doing. A few years down the road an unknowledgeable person does not prepare the electrical bonding surface as well as he should and then problems start happening when current starts to flow through the circuit. Using the philosophy that I have given, these problems are reduced significantly, which in my opinion makes for a better design. Define "wired correctly". In the TC aviation world we're very much aware of the problems associated with engine sensors conforming to legacy automotive conventions of grounding to the block. In the 1957 Chevy, the grounded oil pressure "sender" is "wired correctly". In a 1995 Beechjet, this product would not be considered for a host of reasons not the least of which is "incorrect wiring" for design goals imposed on the project. But if my boss says "Put this 1957 oil pressure gage in that airplane" I can get 'er done with zero risk of degraded performance induced by poor grounding decisions. Again, "Smoking ground returns" are avoided if you use my design solution. I'm not suggesting that there is but one solution for avoiding smoking grounds or ground loop induced noise. If you choose to use the crankcase as your "single point ground" . . . is it your intention to take all the ground wires from ship's electro-whizzies to the crankcase? That could make for a really big bundle of wires through the firewall. If you grounded EVERYTHING to the crankcase, would you still ground the p-lead shields at both ends? >Batteries go to crankcases in cars because the battery >always sits right next to the engine. In the old days the battery ground went straight to the bodywork and then there was an engine strap in a different location which coupled the body to the engine. I'm not sure when the change occurred but I would guess that it occurred somewhere soon after the first electronic systems were implemented. I changed the battery on my neighbours Audi a couple of years ago and that had the battery under the rear seats. The ground lead did not go straight to the body but I can't be sure that it went all the way to the front either. I surmise that if it did not go directly to the body it would probably make the full journey to the engine. Which is anecdotal to what we're discussing here. Exactly how you achieve low resistance, minimum parts count, no-loop architecture for grounds in your airplane has many recipes for success as long as the components are assembled with understanding. But let us take care that we don't confuse 1800+ readers of this List with some notion that the crankcase is the touchstone of grounds . . . this simply isn't so. I have a Cozy MK IV with the battery on the cockpit side of the firewall. I have approximately two feet of cable connecting the -ve to crankcase ground so length cant be an issue. The issue is that there are two additional connections and a couple of feet of #2 cable separating the engine ground from the "forest of tabs". Using the numbers from your paper this gives 1.3 mohm of resistance. Assuming you have an alternator sourcing say 40 amps you now have 50 mV ground difference which is also rectified AC i.e. noise. Now as you have said it is difficult to get better than 0.5miliohm per connection and with time and sloppy maintenance the number grows to something that is unacceptable. All this just because the ground reference was not defined appropriately. I think you're sifting the sand here. There is NO electrical system for any vehicle that is not plagued with beeps, burps, hums, spikes and assorted perturbations of voltage a LOT bigger than your hypothesis. In the TC aircraft world we KNOW that those noises exist and we design to live with them. See: http://www.aeroelectric.com/articles/DO-160.pdf The voltage levels you hypothesize are of no significance if potentially vulnerable systems don't see them because ground loops have been eliminated. Making sure the loops don't exist is easy if you understand your system integration task. It matters not whether the system follows legacy automotive design goals or modern aviation design goals. BOTH technologies can be successfully integrated into the OBAM aircraft. >If the battery is aft of the firewall, then the >most practical battery ground is the firewall >ground stud . . . or to the airframe on an all >metal airplane. OK I have a plastic aeroplane so airframe is not an option but I still feel the firewall is a bad choice. A "bad choice" only if you allow ground loops to exist without evaluating their potential for influencing system performance. Please wire in any manner that gives you comfort. All I'm offering is a constellation of options based on many recipes for success. Virtually ALL of those recipes call for elimination of ground loops that offer a potential for problems. NONE of those recipes treats any location or component of the ground system as the Nirvana of grounds. The forest-of-tabs offers a level of convenience for the majority of system grounds for devices both sides of the firewall. Having this device be 'central' to the ship's ground system makes sense . . . especially if the engine sensors are "wired correctly" in observance of modern aircraft design goals. But even if they are not, the third sheet of Z15 suggests how the 1950's design goals can be accommodated in a 2009 RV. Bob . . . ________________________________________________________________________________
Date: May 28, 2009
Subject: Re: Engine mount as starter ground path
At 07:58 AM 5/28/2009, you wrote: >Bob, > >My first post to this site. I'm working on an rv-10. I thought I >understood the grounding once you gave the below explanation to Bill W. > >One and two are clear. I read #3 as putting a jumper across an >individual mount t0 both sides of a single biscuit. In a later >post, you advise "any bonding jumpers across the engine mounts are >best removed" to avoid parallel grounds. Equally, the Connection >speaks of a single point ground at firewall. Is this a contradiction >or does it refer to not having jumpers between two completely separate mounts? No, I was referencing a project-in-process where an already too-small 8AWG battery(-) wire was installed. Upsizing that wire was not an attractive option. The work-around involved the used of jumper straps around the shock mount biscuits and local battery grounds. Now, if you're starting from scratch and your battery is located near the firewall, that posting was not applicable to you. Use NO JUMPERS on the engine mount biscuits. Wire as suggested in chapter 5 and Figure Z-15. Welcome to the List! Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 28, 2009
Thanks Bob. Sorry to beat a dead horse but I need one more clarification. Your response mentions "if battery near firewall". The batteries are actually both in the aft area. Can the battery be locally grounded to airframe at site of battery (metal frame craft) with B&C tab forest on firewall for grounds and engine ground? Or is best solution still to run a 2awg ground wire up to firewall and proceed with grounding to tab forest as above? Thanks, Tom _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Thursday, May 28, 2009 5:10 PM Subject: Re: AeroElectric-List: Re: Engine mount as starter ground path At 07:58 AM 5/28/2009, you wrote: Bob, My first post to this site. I=12m working on an rv-10. I thought I understood the grounding once you gave the below explanation to Bill W. One and two are clear. I read #3 as putting a jumper across an individual mount t0 both sides of a single biscuit. In a later post, you advise =13any bonding jumpers across the engine mounts are best removed=14 to avoid parallel grounds. Equally, the Connection speaks of a single point ground at firewall. Is this a contradiction or does it refer to not having jumpers between two completely separate mounts? No, I was referencing a project-in-process where an already too-small 8AWG battery(-) wire was installed. Upsizing that wire was not an attractive option. The work-around involved the used of jumper straps around the shock mount biscuits and local battery grounds. Now, if you're starting from scratch and your battery is located near the firewall, that posting was not applicable to you. Use NO JUMPERS on the engine mount biscuits. Wire as suggested in chapter 5 and Figure Z-15. Welcome to the List! Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 28, 2009
At 07:34 PM 5/28/2009, you wrote: >Thanks Bob. >Sorry to beat a dead horse but I need one more clarification. Your >response mentions "if battery near firewall". The batteries are >actually both in the aft area. Can the battery be locally grounded >to airframe at site of battery (metal frame craft) with B&C tab >forest on firewall for grounds and engine ground? > >Or is best solution still to run a 2awg ground wire up to firewall >and proceed with grounding to tab forest as above? > >Thanks, >Tom > >---------- You say "both batteries". Which Z-figure are you crafting? Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 28, 2009
The RV-10 by necessity and design has the battery(s) located in the tailcone to partly offset the weight of the IO-540 up front. Given that the structure from the battery location to the firewall is all riveted aluminum in the lower half of the fuselage there likely is a solid ground path. Running a fat wire to parallel that ground path, or to replace it doesn't appear to be all that good an option. Kelly Robert L. Nuckolls, III wrote: > > No, I was referencing a project-in-process where an > already too-small 8AWG battery(-) wire was installed. > Upsizing that wire was not an attractive option. > The work-around involved the used of jumper straps > around the shock mount biscuits and local battery grounds. > > Now, if you're starting from scratch and your > battery is located near the firewall, that > posting was not applicable to you. Use NO > JUMPERS on the engine mount biscuits. Wire > as suggested in chapter 5 and Figure Z-15. > > ________________________________________________________________________________
From: "iconoclast" <chris@pilot-flight-instruction.com>
Date: May 28, 2009
If it's not too much trouble, can you please PM me the KX 125 manual also? I'm adding a second com and need to patch into the harness for my 125. Thanks, Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=245836#245836 ________________________________________________________________________________
Date: May 29, 2009
done iconoclast wrote: > > If it's not too much trouble, can you please PM me the KX 125 manual also? I'm adding a second com and need to patch into the harness for my 125. > > Thanks, > > Chris > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=245836#245836 > > > ________________________________________________________________________________
Subject: Stereo to Mono
From: "Don McIntosh" <don(at)contractorsnorthwest.com>
Date: May 29, 2009
I want to install a plug in my panel to plug my stereo Walkman into but my intercom (PM1000 II) is mono. Can I just splice the Right and Left leads together to go into the intercom? Also the intercom pins are labeled "HI" and "LOW". Is this just the pin identification numbers? -------- Don McIntosh Kitfox Series 7 under construction Jabiru 3300 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=245926#245926 ________________________________________________________________________________
Date: May 29, 2009
Subject: Re: Stereo to Mono
At 12:58 PM 5/29/2009, you wrote: > > >I want to install a plug in my panel to plug my stereo Walkman into >but my intercom (PM1000 II) is mono. Can I just splice the Right and >Left leads together to go into the intercom? Also the intercom pins >are labeled "HI" and "LOW". Is this just the pin identification numbers? Put a 100 ohm, 1/4w resistor in series with the two stereo output before bringing them together at the "HI" input terminal. The "LOW" terminal is ground. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 29, 2009
Bob, Thanks for the answer. OK, so behind the panel, where do you mount these resistors, or are they just soldered in-line with heat shrink over them?BTW I am in process of reading your book. -------- Don McIntosh Kitfox Series 7 under construction Jabiru 3300 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=245963#245963 ________________________________________________________________________________
Date: May 29, 2009
At 05:08 PM 5/29/2009, you wrote: > > >Bob, >Thanks for the answer. OK, so behind the panel, where do you mount >these resistors, or are they just soldered in-line with heat shrink over them? Given the relatively low priority for comfortable terminaion of flight, I think I'd build them into the wire bundle and heat shrink 'em. See: http://aeroelectric.com/articles/Homeless/Homeless_Components.htm >BTW I am in process of reading your book. Great! If you have any questions, post them here on the List. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Subject: Under-Glareshield GPS/WAAS Antenna
Date: May 29, 2009
5/29/2009 Hello Fellow Listers, A while back there was a thread initiated by a question on where to best mount a GPS WAAS antenna. Below is a copy of an FAA SPECIAL AIRWORTHINESS INFORMATION BULLETIN that relates to tlhis subject. A couple of comments: 1) 3MT Dual LockT is 3M's version of a Velcro like product. http://www.andybaird.com/travels/gertie/superlock.htm 2) My GNS 430W antenna mounted on an aluminum shelf under the fiberglass fuselage shell forward of the windshield on my KIS TR-1 has given excellent service. The antenna is mounted with machine screws. 'OC' Says: "The best investment we can make is the effort to gather and understand knowledge." ========================================================== 1 FAA Aircraft Certification Service SPECIAL AIRWORTHINESS INFORMATION BULLETIN SUBJ: Navigation: Cirrus Aircraft Under-Glareshield GPS/WAAS Antenna SAIB: CE-09-32 Mount Date: May 29, 2009 This is information only. Recommendations aren't mandatory. Introduction This Special Airworthiness Information Bulletin is being issued to alert owners and installers to an airworthiness concern regarding under-glareshield mounted antennas that may cause loss of Global Positioning System/Wide-Area Augmentation System (GPS/WAAS) navigation service on Cirrus Design Corporation (Cirrus) Models SR20 and SR22 airplanes. This Special Airworthiness Information Bulletin applies to all Cirrus aircraft with GPS/WAAS antennas installed using the original under-glareshield mounting location when replacing the non-WAAS GPS antenna. The airworthiness concern is not an unsafe condition that would warrant airworthiness directive (AD) action under Title 14 of the Code of Federal Regulations (14 CFR) Part 39. Background Cirrus originally incorporated an internal mounting location under the aircraft glareshield for non- WAAS GPS antennas on the Models SR20 and SR22 airplanes as part of the aircraft type design. These antennas were secured using the 3MT Dual LockT Reclosable Fastener SJ3552 (Type 170) engaged to 3MT Dual LockT Reclosable Fastener SJ3551 (Type 400). This method to secure the antennas was evaluated during the type certification process and found satisfactory. To upgrade the non-WAAS GPS equipment to GPS/WAAS capability requires new antennas that may be installed in the same location using the same fastener method as the non-WAAS antennas. There are two potential issues for GPS/WAAS service associated with the under-glareshield mounting location and fastener method: 1) robustness of the antenna mounting method; and 2) Localizer Performance with Vertical Guidance (LPV) service interruption due to signal loss from airframe shadowing. Both issues affect service availability and may ultimately result in loss of GPS/WAAS navigation capability. Loss of GPS/WAAS navigation capability requires the operator to rely on other on-board navigation equipment that may not have area navigation or LPV capability. Antenna Mounting Robustness Two service difficulty reports (S8Y2008F00000 and 2007FA0000554) indicate the possibility for antennas secured using the 3MT Dual LockT fastener system to detach, which would result in loss of navigation. A detached antenna will not have an adequate field of view to receive satellite signals resulting in loss of GPS/WAAS navigation. Airframe Shadowing Cirrus airplanes use composite construction, which, unlike metal aircraft, is essentially transparent to radio signals. There is always concern that metal components such as engines, instrument panels, or embedded metal mesh for lightening protection can affect GPS/WAAS signal reception for internally mounted antennas. Antenna location, even on composite aircraft, can have an affect on GPS/WAAS 2 signal availability due to signal shadowing and/or attenuation effects. Shadowing and attenuation are more critical during LPV operations due to the more stringent requirements receivers must meet. The current receiver and antenna performance standards use a conservative estimate for intra-system noise environment and antenna gain patterns that provides significant signal margin. However, the margin available today will gradually decrease as new systems, signals, and satellites come on-line over the next decade. This decrease could potentially cause decreased LPV availability or loss of GPS/WAAS navigation on Cirrus aircraft with antennas mounted under the glareshield. Recommendations We recommend that owners and operators of Cirrus Models SR20 and SR22 airplanes using the under-glareshield location for GPS/WAAS antennas relocate the antennas to upper fuselage external locations following Cirrus Optional Service Bulletins SB 2X-34-23 R1 (for aircraft without a primary flight display) or SB 2X-34-24 R1 (for aircraft with a primary flight display). Relocating the antennas according to the Optional Service Bulletins provides a more robust antenna mounting; and assures maximum GPS/WAAS signal reception for optimum service availability when performing LPV instrument approaches. To obtain copies of Cirrus Optional Service Bulletins SB 2X-34-23 R1 or SB 2X-34-24 R1, contact Cirrus Design Corporation, 4515 Taylor Circle Duluth, MN 5581-1548 or visit their website at www.cirruslink.com/mycirrus/servicepubs.aspx. For Further Information Contact Kevin J. Bridges, General Engineer, AIR-130; phone: (202) 385-4627; fax: (202) 385-4651; e-mail: kevin.bridges(at)faa.gov. ________________________________________________________________________________
Date: May 29, 2009
At 06:24 PM 5/29/2009, you wrote: > >Bob, > > Just a quick question. It the resistor to lower the > voltage at the intercom or is it related to what the CD player > output sees? Or something completely different. If it is to lower > the voltage, should the voltage be in the same range as the other > inputs to the intercom? The resistors are a crude "audio mixer" that gives you a mono-average of right and left channels. It also isolates the right and left audio amplifiers from each other so that diverse audio signal levels in the two channels don't cause the two amplifiers to arm-wrestle. The resistors can be lower . . . say the same as for MP3 player headphones . . . 33 ohms. But you probably won't hear much loss of signal that cannot be compensated for by turning up the volume on the audio device. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 30, 2009
5/30/2009 Hello Don, You wrote: "I want to install a plug in my panel to plug my stereo Walkman into but my intercom (PM1000 II) is mono." Here is one way to solve that problem -- http://www.radioshack.com/product/index.jsp?productId=2102669 This adapter will put the output of a mono jack on your panel into both sides of your stereo Walkman.
May 13, 2009 - May 30, 2009
AeroElectric-Archive.digest.vol-ir
