AeroElectric-Archive.digest.vol-is
May 30, 2009 - June 09, 2009
      Also take a look at some of the other adapters available. You may want to
      put a normal airplane earphone sized jack on your instrument panel so that
      either your Walkman (with an adapter) or an airplane earphone set (without
      adapter) may be plugged in.
      'OC' Says: "The best investment we can make is the effort to gather and
      understand knowledge."
Subject: Stereo to Mono
From: "Don McIntosh" <don(at)contractorsnorthwest.com>
I want to install a plug in my panel to plug my stereo Walkman into but my intercom (PM1000 II) is mono. Can I just splice the Right and Left leads together to go into the intercom? Also the intercom pins are labeled "HI" and "LOW". Is this just the pin identification numbers? -------- Don McIntosh Kitfox Series 7 under construction Jabiru 3300 ________________________________________________________________________________
Subject: Must-Have Tool Tip
Date: May 30, 2009
5/30/2009 Hello Matt, Thanks for your tool tip. Here is another tip that you can distribute to the RV people if you will (I am not on their lists). Where ever possible abandon those abominable Phillips drive machine screws. Instead use Torx (six lobe) drive machine screws. Every builder who has done this has thanked me profusely for the suggestion. Torx drive inserts are readily available and with an electric cordless screw driver are very quick and effective -- vastly superior to Phillips drive. You can obtain Torx drive screws in a variety of sizes from Microfasteners. See here: http://www.microfasteners.com/catalog/products/SSCFCMXS.cfm (Note that these flat head screws have a true aviation use 100 degree countersink angle, not the common hardware store 82 degree countersink angle) and here: http://www.microfasteners.com/catalog/products/SSCSBXS.cfm 'OC' Says: "The best investment we can make is the effort to gather and understand knowledge." PS: Thanks again Matt for making the Matronics lists available to us -- they are of great value. ============================================= From: Matt Dralle <dralle(at)matronics.com> Subject: RV12-List: Must-Have Tool Tip... Dear Listers, I don't know, maybe everyone but me already knew about this little gem of a tool, but in case you missed it, I thought I share. If you don't have one of these, run - don't walk - down to your local Home Depot or Ace Hardware store and get one! All of those #8 screws in the RVs are a giant pain to work in and out and some are just impossible to get to. I've been using this little guy on the RV-8 project and can't image not having it now. The bendable shaft is really strong and you can bend the heck out of it without impacting the torque. Its about $13 at Home Depot which is a great deal considering how handy it is. Here's a link to it on the Ace Hardware web page. I also attached a picture of mine attached to my Dewalt electric screw driver. http://www.acehardware.com/sm-eazypower-flex-a-bit-plus-eazypower-flex-a-bit-plus--pi-2467822.html Best regards, Matt Dralle RV-8 #82880 N998RV ________________________________________________________________________________
Subject: Re: Engine mount as starter ground path
Date: May 30, 2009
Maybe Bob can address this point: Bill might be able to use the 8awg wire separately. If the battery is grounded to the airframe right next to itself, and the starter is grounded to the firewall, then the starter is taken care of. The forest of tabs is most likely common to that firewall ground mentioned above. These would be used for grounding avionics, etc. The 8awg wire he has already pulled (a long and difficult task in an RV-10) could be used for an "always hot bus". Attach it to the battery in back, and put a fuse block at the panel end. One wire instead of a handful of small ones. He can then pull out the small wires to be used elsewhere. He probably already has the fuse block for the hot bus next to the battery - just move it. No waste of 8awg wire. Just a suggestion, but I like it so much, I might do it myself. John -------- #40572 QB Fuselage, wings finished. Finish Kit started. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=246031#246031 ________________________________________________________________________________
Date: May 30, 2009
Subject: AECr12 goes to press . . .
The long promised reprint of the AeroElectric Connection, revision 12 went to press yesterday. The long delay was unfortunate but economically worthwhile. I've located a print shop that not only offered an attractive price but is reasonable driving distance away so that I can pick the order up and avoid freight charges on about 3,000 pounds of paper! I'm supposed to have proofs early next week and assuming no big gottchas are identified, books to ship about 3 weeks after that. We're printing 2000 books . . . twice that of our usual print-run. R13 should be another milestone in 'Connection history. I've purchased a suite of desktop publishing software and will being molding 20 years and 4 different word processor outputs into a single, cohesive, print-ready file. I'm planning on several new chapters in addition to complete review of all existing work. This issue is 304 pages, the next will probably be 335 or so. My thanks to those who helped me comb the worst of the errors out of the latest changes. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 30, 2009
At 10:06 AM 5/30/2009, you wrote: > > >Maybe Bob can address this point: > >Bill might be able to use the 8awg wire separately. If the battery >is grounded to the airframe right next to itself, and the starter is >grounded to the firewall, then the starter is taken care of. > >The forest of tabs is most likely common to that firewall ground >mentioned above. These would be used for grounding avionics, etc. > >The 8awg wire he has already pulled (a long and difficult task in an >RV-10) could be used for an "always hot bus". Attach it to the >battery in back, and put a fuse block at the panel end. Remotely mounting an always-hot bus is not recommended. Legacy crash safety conventions make this simply another remote bus that is worthy of a battery contactor . . . not ulike the robust e-bus feeder described in the Z-figures. > One wire instead of a handful of small ones. He can then pull out > the small wires to be used elsewhere. He probably already has the > fuse block for the hot bus next to the battery - just move it. No > waste of 8awg wire. Just a suggestion, but I like it so much, I > might do it myself. > >John I've been noodling through some recommendations for the rear-battery configuration of the RV10. I'm packed up to head out for M.L. right now so I don't have time to elaborate. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 30, 2009
From: "Paul Millner [OAK]" <paulmillner(at)compuserve.com>
Subject: Bonding for Fueling
>> how does one get lineboys trained that the engine exhaust pipe is a terrible place for ground wire Remember, it's not at all important to GROUND an aircraft for fueling. What *is* important is to BOND the aircraft to the fuel source, so that static charges created by the dielectric fluid called gasoline moving through the fueling equipment don't result in a spark at the nozzle. And... what Bob said about the size of the currents involved. Call it bonding, not grounding. Paul ________________________________________________________________________________
Subject: sky-tec starter wiring
Date: May 30, 2009
Sky-Tec advises against the use of a starter relay, while Bob K. advocates the use of one (for good reason, as I recall). I have a separate starter relay in my plane. A couple years ago the Sky-Tec website had an example schematic for hooking up one of their starters with a separate starter relay. I had a copy of that, but now I can't find it and they seem to have removed it from their website. I believe it showed a jumper between the large +12v terminal and the small terminal on the starter. Does any one have a copy of that schematic? Thanks, -- Tom Sargent, RV-6A, final assembly. ________________________________________________________________________________
Date: May 31, 2009
Subject: Re: 12V Power Socket
Thanks to all for the great replies. No worries now! Andrew. RV7 (firewall forward and wiring) EI-EEO (just received!) Galway, Ireland. ----- Original Message ----- From: "Greg Young" <gyoung@cs-sol.com> Sent: Thursday, 28 May, 2009 5:15:22 PM GMT +00:00 GMT Britain, Ireland, Portugal Subject: RE: AeroElectric-List: 12V Power Socket It depends on what you want to accomplish. If you wire it to the buss side of the master you can power your panel from it during the build. But if you wire it to the battery side of the master you can power accessories or trickle charge the battery without turning on the master. There are pluses & minuses both ways. Think it through and decide what's best for you. Regards, Greg Young > -----Original Message----- > ground. You should wire the scocket to powerthe panel with > out turning the master on. > I have mine that way so I can play with the panel with out > using the aircraft battery. I have a little cpmpressor / > battery unit that I take to the hanger and keeps the tires > up and lets me run my glass panel for setting up a trip etc. > > > ________________________________________________________________________________
Subject: Re: Bonding for Fueling
Date: May 31, 2009
Sorry I missed this thread: why is the exhaust pipe a bad place to connect the bonding cable to John ----- Original Message ----- From: "Paul Millner [OAK]" <paulmillner(at)compuserve.com> Sent: Sunday, May 31, 2009 3:25 AM Subject: AeroElectric-List: Bonding for Fueling > > > >> how does one get lineboys trained that the engine exhaust pipe is a > terrible place for ground wire > > Remember, it's not at all important to GROUND an aircraft for fueling. > What *is* important is to BOND the aircraft to the fuel source, so that > static charges created by the dielectric fluid called gasoline moving > through the fueling equipment don't result in a spark at the nozzle. > > And... what Bob said about the size of the currents involved. > > Call it bonding, not grounding. > > Paul > > > ________________________________________________________________________________
Subject: Garmin GA 56 GPS Antenna Aerial
Date: May 31, 2009
Hi Is it OK to use the Garmin GA 56 GPS Antenna Aerial as a permament fixture for the Garmin range of hand (although panel mounted-AirGizmo) held Garmin GPS Regards John ________________________________________________________________________________
From: "ROGER & JEAN CURTIS" <mrspudandcompany(at)verizon.net>
Date: May 31, 2009
Sorry I missed this thread: why is the exhaust pipe a bad place to connect the bonding cable to John IT'S NOT! Some listers, who don't understand, seem to feel that you need a low resistance path all the way from the fuel tank to the bonding point. In reality, the static charge is of high voltage and low energy, thus it will bleed off very quickly through a high impedance path, i.e. Through rusty exhaust connections etc. So, the exhaust pipe is a good bonding point. ________________________________________________________________________________
Subject: Lightweight Aux Battery?
Date: May 31, 2009
Does anyone have a good alternative lightweight Aux Battery? I'm looking for something 12V 10Ah capacity for emergency EFI powering. I've already got a "fat" airplane, so would like to keep the weight down if possible. Power requirements are calculated @ 8 amps. NiMH and LiFePO offer significant weight reduction at an increase in cost. I haven't found a good way to keep the battery's charged or a simple fall-over incase of main power failure. Any Ideas? Michael Read this topic online here: http://forums.matronics.com/viewtopic.php?p=246142#246142 ________________________________________________________________________________
Date: May 31, 2009
Try: http://www.skytecair.com/Wiring_Diag.htm -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of thomas sargent Sent: Saturday, May 30, 2009 10:46 PM Subject: AeroElectric-List: sky-tec starter wiring Sky-Tec advises against the use of a starter relay, while Bob K. advocates the use of one (for good reason, as I recall). I have a separate starter relay in my plane. A couple years ago the Sky-Tec website had an example schematic for hooking up one of their starters with a separate starter relay. I had a copy of that, but now I can't find it and they seem to have removed it from their website. I believe it showed a jumper between the large +12v terminal and the small terminal on the starter. Does any one have a copy of that schematic? Thanks, -- Tom Sargent, RV-6A, final assembly. ________________________________________________________________________________
Subject: Re: sky-tec starter wiring
Date: May 31, 2009
William: I followed the link back to sky-tec (yet again) and this time I found what I was looking for. Thanks for making me look again. Seems my current wiring set-up matches their "certified" diagram, tht is, the diagram for planes with a starter contactor. On May 31, 2009, at 9:40 AM, William Gill wrote: > > > > Try: http://www.skytecair.com/Wiring_Diag.htm > ________________________________________________________________________________
Subject: Rotax 912ULS voltage . . .
Date: May 31, 2009
Bob, Here is another twist in the strange continuing low voltage problem saga in my Rotax 912 / Figure Z16-designed electrical system. I purchased and installed a new Rotax voltage regulator (called a regulator/rectifier by Rotax), which provided identical low voltage results. Just as I was getting ready to return the "defective" regulator I accidently switched on the endurance bus and, what do you know, the voltage shot up from 12.9V to 13.8V (as measured through my Dynon glass cockpit and Lowrance GPS instruments). While still a little low, I can certainly live with 13.8V under normal working load since this should adequately charge my battery. Ok, so now it looks like there is something wrong in the Z16 electrical configuration. I'd rather not leave my endurance buss on all the time (although I don't think this would hurt anything??) so I would like to fix the issue. I suspect the problem is associated with the diode that attaches the two busses shown under "Note 12" on your Z16 diagram. Do you concur? Do you think I should change this diode, do further testing, or should I look elsewhere for the problem? The my diode came with a heatsink from B&C. If I need a new one, and you make them, I need one ASAP since I plan a 1000-mile trip next weekend. Thank you again for your help. Les Goldner 510-549-1622 -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Tuesday, May 26, 2009 3:46 PM Subject: AeroElectric-List: Rotax 912ULS voltage . . . At 12:38 AM 5/26/2009, you wrote: Thank you for the information Bob. I am trying to trouble shoot my low voltage problem to determine its cause (i.e.; the regulator, wiring, or the internal engine alternator) so I can take corrective action. There is nothing in the Rotax 912 manuals to assist in doing this. I checked the internal engine coil resistance reading and found it to be .7-ohms. The DC voltage at the regulator is the same previously reported (still under 13-volts). Finally I measured AC voltage coming from the coils. The voltage varied as follows: Idle (1900-RPM) was 12.8 volts 2500-RPM was 16.0 v 3000-RPM was 19.0 v 4000-RPM was 24.5 v cruse(5000-RPM)was not measured. Bob, Am I correct to think that the AC voltage looks adequate and the problem is likely a faulty Rotax voltage regulator? Thanks again for your help. If you have ANY voltage from the alternator's output winding at any speed, and the winding is not shorted to ground (very unlikely) then the alternator is fine. Rotax PM alternators are exceedingly simple, rugged and reliable. I'm not aware of any failures. The Ducati rectifier/regulator supplied with these engines is another matter. They are of marginal thermal design and sadly lacking in adjustability. Two conditions VERY easy to fix if anyone with responsibility for the product cared. Unfortunately, replacing it with an identical OEM R/R has a high probability of installing a similar problem right out of the box. I've heard that John Deere has a single phase, PM alternator regulator that is rated for up to 35 amps. Goto http://matronics.com/search Search the AeroElectric List for AM101406 and you'll get several hits by folks who discussed it some time back. Here are some after-market clones . . . http://www.watercraftstarter.com/Lawn%20Garden/Regulator%20Rectifier/?nocach e=1 http://www.amazon.com/Replacement-Voltage-Regulator-Deere-AM101406/dp/B00169 H3E0 I don't see a voltage adjustment mentioned or shown . . . unfortunate but perhaps understandable. Most of these regulators are used on small tractors and most users are not skilled in the use of such features. Wish I had my alternator drive stand running. Building a 'real' PM r/r for aircraft is not a big task . . . Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: May 31, 2009
At 10:46 PM 5/30/2009, you wrote: > >Sky-Tec advises against the use of a starter relay, while Bob K. >advocates the use of one (for good reason, as I recall). I have a >separate starter relay in my plane. A couple years ago the Sky-Tec >website had an example schematic for hooking up one of their starters >with a separate starter relay. I had a copy of that, but now I can't >find it and they seem to have removed it from their website. > >I believe it showed a jumper between the large +12v terminal and the >small terminal on the starter. Does any one have a copy of that >schematic? Not so long ago in a galaxy very close by, the first made-for-aircraft light weight starters were offered by B&C in Newton, KS. The crafters of design goals and system integrators of those products were cognizant of the extra-ordinary performance of the electrical control contactor/ pinion engagement solenoid . . . but at a price. See: http://www.aeroelectric.com/articles/strtctr.pdf The inductive, high engagement current of these devices was higher than any contemporary starter control switches were designed to handle. Indeed, a number of automobile starter switch contacts were ill-designed to stroke these little beasts. Further, part of the anticipated market for these starters included type certificated machines that were already fitted with intermittent duty, starter contactors. The marketing philosophy adopted for the B&C starters was to tie the solenoid coil terminal to the starter contactor's fat terminal as depicted in Figure 6 of the paper cited above. This philosophy mitigated the need for extra- husky starter switches -AND- offer a drop-in replacement for TC aircraft starters without modification of ship's wiring. Then came competing designs with permanent magnet motors. Attempts to wire these starters in the same manner produced a delayed retraction of the starter pinion gear after the start button was released. This was a byproduct of voltage GENERATED by the PM motors as they spun down. This "counter emf" held the pinion gear engaged for several seconds. The PM motor product designer's recommendation was to wire it just like in cars . . . but they either overlooked or ignored the inrush current demands described in the article cited above. The AEC work-around was to add a starter control "boost relay" as depicted in Figure Z-22 which isolates the panel mounted start switch from the extra-ordinary demands of the starter solenoid/contactor combination. See also Figures Z-22 notes on page Z-5 of http://aeroelectric.com/R12A/AppZ_12A3.pdf So. Your options are (1) wire per the manufacturer's instructions and select a starter control push-button or switch suited to the task (don't forget the arc-suppression diode) or (2) wire per Z-22. Bob . . . ________________________________________________________________________________
Date: May 31, 2009
Subject: Re: Lightweight Aux Battery?
At 09:37 AM 5/31/2009, you wrote: > >Does anyone have a good alternative lightweight Aux Battery? I'm >looking for something 12V 10Ah capacity for emergency EFI >powering. I've already got a "fat" airplane, so would like to keep >the weight down if possible. Power requirements are calculated @ 8 >amps. NiMH and LiFePO offer significant weight reduction at an >increase in cost. I haven't found a good way to keep the battery's >charged or a simple fall-over incase of main power failure. What engine are you using . . . and which (if any) Z-figure? Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Subject: Bendix 10-357210-1 Ignition switch
Date: May 31, 2009
Bought a rotary ignition switch and would like to know which terminal goes to what on a Jabiru 3300 engine.Terminals marked R,L LR,BO,Batt ,S and G. L= left mag,R= right mag G= ground.Don't know where to connect the rest [Bendix 10-357210-1 Ignition switch key OFF,L,R,Both and twist to start] Any help would be appreciated. Cheers T87 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=246250#246250 ________________________________________________________________________________
Date: Jun 01, 2009
Subject: Re: Stereo to Mono
I would not use a stereo to mono jack to go FROM stereo to MONO. It really is made for going from mono to drive a stereo headphone, split to drive both L & R channels. It is not designed to combine stereo to mono. - Whats the big deal? Shorting L & R of an amp can cause damage, even-an iP od. If the "Walkman" has a mono switch than its OK, but-iPods do not have mono switc hes. - If you don't have a MP3 player (iPod) get one. Walkman are last decades new s. If you don't have an iPod you can get 100's of hours of music on them with play ti me of 6 hours per charge. They are also small and light weight. - There are some threads on how to properly combine stereo and ground issues in this forum. Just use the search engine. The easy way is with capacitor and resis tor, which you can wire behind the panel. You would use a stereo 1/8" phone jack and t hen go from stereo to mono with the isolation Cap and Resistor. - Cheers George - - >From: <bakerocb(at)cox.net> >Subject: AeroElectric-List: Stereo to Mono > >5/30/2009 >Hello Don, You wrote: "I want to install a plug in my panel to plug my >stereo Walkman into but my intercom (PM1000 II) is mono." >Here is one way to solve that problem -- - >http://www.radioshack.com/product/index.jsp?productId=2102669 - >This adapter will put the output of a mono jack on your panel into both >sides of your stereo Walkman. - >Also take a look at some of the other adapters available. You may want to >put a normal airplane earphone sized jack on your instrument panel so that >either your Walkman (with an adapter) or an airplane earphone set (without >adapter) may be plugged in. > >======================== === >> >>Subject: AeroElectric-List: Stereo to Mono >>From: "Don McIntosh" <don(at)contractorsnorthwest.com> >> >>I want to install a plug in my panel to plug my stereo Walkman into but m y >>intercom (PM1000 II) is mono. Can I just splice the Right and Left leads together >>to go into the intercom? Also the intercom pins are labeled "HI" and "LOW ". >>Is this just the pin identification numbers? >>-------- >>Don McIntosh >>Kitfox Series 7 under construction >>Jabiru 3300 =0A=0A=0A ________________________________________________________________________________
Date: Jun 01, 2009
6/1/2009 Hello Thruster87, You wrote: "Bought a rotary ignition switch and would like to know ......" Another one of the advantages of using two toggle switches for this purpose instead of the unreliable rotary switch is to avoid fumbling around with the confusing wiring required. 'OC' Says: "The best investment we can make is the effort to gather and understand knowledge." ============================================== Subject: AeroElectric-List: Bendix 10-357210-1 Ignition switch From: "Thruster87" <alania(at)optusnet.com.au> Bought a rotary ignition switch and would like to know which terminal goes to what on a Jabiru 3300 engine.Terminals marked R,L LR,BO,Batt ,S and G. L= left mag,R= right mag G= ground.Don't know where to connect the rest [Bendix 10-357210-1 Ignition switch key OFF,L,R,Both and twist to start] Any help would be appreciated. Cheers T87 ________________________________________________________________________________
Date: Jun 01, 2009
Bob, The basis of my design is Z-14. Dual Odyssey 680 batteries aft with cross-feed contactor (using one for startup and one for avionics during starting-then switching avionics over to primary battery after running-both batteries available if necessary for starting)) but only one alternator (option to add second alternator later depending on upcoming plane power product). Diode inline allows alternator feed to one or both batteries. Batteries really both need to be aft due to engine weight considerations. So... is grounding both batteries at a common point aft in metal plane a viable solution? I note that you made reference to working on some info specific to the RV-10. That would be great. Thanks, Tom _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Thursday, May 28, 2009 9:02 PM Subject: RE: AeroElectric-List: Re: Engine mount as starter ground path At 07:34 PM 5/28/2009, you wrote: Thanks Bob. Sorry to beat a dead horse but I need one more clarification. Your response mentions =13if battery near firewall=14. The batteries are actually both in the aft area. Can the battery be locally grounded to airframe at site of battery (metal frame craft) with B&C tab forest on firewall for grounds and engine ground? Or is best solution still to run a 2awg ground wire up to firewall and proceed with grounding to tab forest as above? Thanks, Tom _____ You say "both batteries". Which Z-figure are you crafting? Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Jun 01, 2009
I have been following this thread with some interest as in been there done that. My Stratus Suburu setup required an automotive type switch, ignition, close for run. After a search for a compact simple switch I turned to one of my trusted sources, John Deere. Yes they had a compact ignition switch with starter function for a good price. Flash ahead a year or so, during my 40 hour test phase I was getting intermittent failures to engage especially when the engine was hot, you know you fly to the airport and then go to leave and it does want to start. Well I tracked it down to an excessive voltage drop across the switch. So off to the John Deere dealer for a new one. Talking to the dealer about my problem I found that they had the same problem on many of their tractors and John Deere had a fix. A nice tab mount relay suitable to mount on the starter that reduced the current load such that even the old switch works. I was able to make the entire change under the cowling by the starter and didn't have to get in to the instrument panel at all. John Deere come through again, after all that is where I get my oil filters. Tim Shankland thomas sargent wrote: > > > William: > I followed the link back to sky-tec (yet again) and this time I > found what I was looking for. Thanks for making me look again. > Seems my current wiring set-up matches their "certified" diagram, tht > is, the diagram for planes with a starter contactor. > > On May 31, 2009, at 9:40 AM, William Gill wrote: > >> >> >> Try: http://www.skytecair.com/Wiring_Diag.htm >> > > ________________________________________________________________________________
Date: Jun 01, 2009
At 07:40 AM 6/1/2009, you wrote: I have been following this thread with some interest as in been there done that. My Stratus Suburu setup required an automotive type switch, ignition, close for run. After a search for a compact simple switch I turned to one of my trusted sources, John Deere. Yes they had a compact ignition switch with starter function for a good price. Flash ahead a year or so, during my 40 hour test phase I was getting intermittent failures to engage especially when the engine was hot, you know you fly to the airport and then go to leave and it does want to start. Well I tracked it down to an excessive voltage drop across the switch. So off to the John Deere dealer for a new one. Talking to the dealer about my problem I found that they had the same problem on many of their tractors and John Deere had a fix. A nice tab mount relay suitable to mount on the starter that reduced the current load such that even the old switch works. My first encounter with the extra-ordinary demands of the modern two-step starter engagement solenoids was on one of my employees cars at Vidimation about 17 years ago. It was a Japanese car as I recall . . . it was experiencing intermittent responses to twisting the key switch to the START position. He pulled the switch in our shop and we discovered bare brass, sliding (read low pressure, slow moving) contacts for the start function were all burned up. The car had about 60K miles on it. A new switch fixed the problem . . . no doubt for perhaps another 60K miles? I'd didn't take time to dissect the physics behind the phenomenon then. But it looks like the "boost" relay fix has occurred to more than one individual seeking an alternative recipe for success. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
Date: Jun 01, 2009
This brings up an issue that has been beaten around a lot...Especially by myself in the past. On your Stratus you should have two ignition systems and I dearly hope you are not running the feed for both ignitions through that single key switch because the key switch is a single point of faiure. The two ignitions should be treated as totally separate entities, that means a separate fused circuit, separate swicthing and wiring..I.e no single component failing should stop the engine running. I know Cessna's use a separate two postion switch but the get away this because the switch is a fail safe device..i.e if continuity stops the engine continues to run...But even then I avoided this route on my current airplane. Cheers Frank Stratus 601 zenair RV7a -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Monday, June 01, 2009 6:30 AM Subject: Re: AeroElectric-List: sky-tec starter wiring --> At 07:40 AM 6/1/2009, you wrote: I have been following this thread with some interest as in been there ________________________________________________________________________________
Date: Jun 01, 2009
Frank, My electrical system consists of two batteries and two independent buses, A & B. All power connections are through center off single pole double throw switches. Thus I can run any part of my system on either bus of my choosing or all on one bus. The primary ignition circuit, which feeds the ignition switch goes through one of these switches, normally set to bus A. The secondary ignition, fuel pump and starter are all fed by single rocker switches. By the way I have a guard over the primary ignition rocker switch so as not to inadvertently turn if off during some switching. This allows me to start my plane like a car, turn on Bus A turn the key and your running. It also allows me to separate noisy devices like strobes on one bus and the radio on the other. I also have a relay that connects both batteries for starting. Tim Shankland Hinde, Frank George (Corvallis) wrote: > >This brings up an issue that has been beaten around a lot...Especially by myself in the past. > >On your Stratus you should have two ignition systems and I dearly hope you are not running the feed for both ignitions through that single key switch because the key switch is a single point of faiure. > >The two ignitions should be treated as totally separate entities, that means a separate fused circuit, separate swicthing and wiring..I.e no single component failing should stop the engine running. > >I know Cessna's use a separate two postion switch but the get away this because the switch is a fail safe device..i.e if continuity stops the engine continues to run...But even then I avoided this route on my current airplane. > >Cheers > >Frank >Stratus 601 zenair >RV7a > >-----Original Message----- >From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III >Sent: Monday, June 01, 2009 6:30 AM >To: aeroelectric-list(at)matronics.com >Subject: Re: AeroElectric-List: sky-tec starter wiring > >--> > >At 07:40 AM 6/1/2009, you wrote: > > >I have been following this thread with some interest as in been there > > > > ________________________________________________________________________________
Date: Jun 01, 2009
Bob, This will be on an existing Jabiru 3300 installation using the Z-20 wiring . -- Michael Crowder Read this topic online here: http://forums.matronics.com/viewtopic.php?p=246319#246319 ________________________________________________________________________________
Date: Jun 01, 2009
Subject: Re: Bendix 10-357210-1 Ignition switch
At 11:47 PM 5/31/2009, you wrote: > >Bought a rotary ignition switch and would like to know which >terminal goes to what on a Jabiru 3300 engine.Terminals marked R,L >LR,BO,Batt ,S and G. L= left mag,R= right mag G= ground.Don't know >where to connect the rest [Bendix 10-357210-1 Ignition switch key >OFF,L,R,Both and twist to start] Any help would be appreciated. Cheers T87 Unless you have a shower-of-sparks ignition system, you don't need BO. If the engine doesn't require starting on one ignition only, you don't use the LR terminal either. See Figure Z-26 at: http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z26K_27K.pdf Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Jun 01, 2009
nuckolls.bob(at)aeroelect wrote: > At 11:47 PM 5/31/2009, you wrote: > > > > > > > Bought a rotary ignition switch and would like to know which > > terminal goes to what on a Jabiru 3300 engine.Terminals marked R,L > > LR,BO,Batt ,S and G. L= left mag,R= right mag G= ground.Don't know > > where to connect the rest [Bendix 10-357210-1 Ignition switch key > > OFF,L,R,Both and twist to start] Any help would be appreciated. Cheers T87 > > Unless you have a shower-of-sparks ignition system, > > > > you don't need BO. If the engine doesn't require > starting on one ignition only, you don't use the LR > terminal either. > > > See Figure Z-26 at: > > http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z26K_27K.pdf > > > > Bob . . . > > ----------------------------------------) > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > ---------------------------------------- Much appreciated Cheers T87 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=246407#246407 ________________________________________________________________________________
Date: Jun 01, 2009
At 02:18 PM 5/31/2009, you wrote: ><lgold@quantum-associates.com> > >Bob, >Here is another twist in the strange continuing low voltage problem saga in >my Rotax 912 / Figure Z16-designed electrical system. >I purchased and installed a new Rotax voltage regulator (called a >regulator/rectifier by Rotax), which provided identical low voltage results. >Just as I was getting ready to return the "defective" regulator I accidently >switched on the endurance bus and, what do you know, the voltage shot up >from 12.9V to 13.8V (as measured through my Dynon glass cockpit and Lowrance >GPS instruments). While still a little low, I can certainly live with 13.8V >under normal working load since this should adequately charge my battery. >Ok, so now it looks like there is something wrong in the Z16 electrical >configuration. I'd rather not leave my endurance buss on all the time >(although I don't think this would hurt anything??) so I would like to fix >the issue. I suspect the problem is associated with the diode that attaches >the two busses shown under "Note 12" on your Z16 diagram. Do you concur? Do >you think I should change this diode, do further testing, or should I look >elsewhere for the problem? The my diode came with a heatsink from B&C. If I >need a new one, and you make them, I need one ASAP since I plan a 1000-mile >trip next weekend. Nothing needs "fixing". For the purposes of knowing your alternator's setpoint voltage, you're measuring the system voltage at the wrong place. Yes, the e-bus is KNOWN to run about 0.7 volts lower than the main bus and it doesn't matter. When a voltmeter is fed from the E-bus, it becomes something of an electrical fuel gage for battery-only operations. When you're down to 11.0 volts battery only, the battery is 95% used up. If you want to use this voltmeter to check the main bus . . . then you momentarily close the alternate feed switch as you've discovered. 13.8 is still pretty low for charging a battery but if you're going on a trip and will spend hours per flight cycle at cruise RPM then 13.8 will get you by. The system is working as designed. You can either mentally add the 0.7 volts of known diode-drop or do your low voltage and/or voltage display sensing from the main bus. Any LV Warning should ALWAYS be driven by the main bus when such systems are installed. I'd say you are good to go on your trip. Bob . . . ________________________________________________________________________________
Date: Jun 02, 2009
Subject: grounding to fuselage
In general I am opposed to running current thru the fuselage, but in the case of the white tail light, I am willing to make an exception. Is there any "approved" way of doing this so as to avoid causing corrosion due to the contact of dissimilar metals? Is a tin plated (it is tin isn't it?) ring terminal against bare aluminum going to cause a problem? Should it be covered/sprayed with something to protect it from moisture? Or is this just a bad idea under any circumstances? Thanks, -- Tom Sargent, RV-6A final assembly. ________________________________________________________________________________
Date: Jun 02, 2009
Subject: Re: grounding to fuselage
At 08:48 AM 6/2/2009, you wrote: >In general I am opposed to running current thru the fuselage, but in >the case of the white tail light, I am willing to make an >exception. Is there any "approved" way of doing this so as to avoid >causing corrosion due to the contact of dissimilar metals? > Is a tin plated (it is tin isn't it?) ring terminal against bare > aluminum going to cause a problem? Should it be covered/sprayed > with something to protect it from moisture? Or is this just a bad > idea under any circumstances? Local concerns for the attachment of wires to the airframe have been the topic of many pages of "how to" and "how not" to do. In the most hostile of environments, all the recommended processes and materials add longevity to the connection. Our airplanes are seldom operated in conditions that qualify as strenuous much less hostile. Design goals for local grounding/bonding speak to deleterious effects for failure to faithfully observe recipes for success but they seldom speak to the physics of the effects or relative risks. Keep in mind that for corrosion to occur, oxygen laden moisture must be present in the joint. Only then do the electrolytic effects of dissimilar metals in ionized solutions arise. Yes, the tin plating of copper terminals #1 task is an electrolytic "buffer" between copper and aluminum . . . but if you damage the tin layer in any way during assembly or maintenance of the joint, that barrier is breached and the original copper-aluminum couple is exposed. For all the fuss and froth about materials control, the very best prophylactic against corrosion call for making joints up with sufficient pressure to produce "gas-tightness" enhanced with a means by which future moisture ingress is retarded assuages 99.99% of your concerns. Join clean metals with robust, locking fasteners. Coat the metals with silicon grease before joining. And the joint will be fine for more than the lifetime of airplane. You can "drink from the fire hose" off grounding/bonding processes in section 15 of AC43-13 offers a rigorous study. There's nothing inherently evil about using the airframe to carry power system currents. Modern production aircraft made of aluminum have countless airframe grounds crafted with due diligence to the principals of gas-tightness and choice of materials. These function as desired for the lifetime of the airplane. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Jun 02, 2009
AC43.13-1B has an extensive discussion of aircraft bonding (grounding), including the proper procedure for connecting to the airframe and protection against corrosion. This document is available in .pdf format if you don't have a hardcopy. It's a bit large to email, so if you can find it online for download, that's good. If not, please let me know and I'll make other arrangements. Thanks, Vern Little www.vx-aviation.com ----- Original Message ----- From: thomas sargent To: aeroelectric-list(at)matronics.com Sent: Tuesday, June 02, 2009 6:48 AM Subject: AeroElectric-List: grounding to fuselage In general I am opposed to running current thru the fuselage, but in the case of the white tail light, I am willing to make an exception. Is there any "approved" way of doing this so as to avoid causing corrosion due to the contact of dissimilar metals? Is a tin plated (it is tin isn't it?) ring terminal against bare aluminum going to cause a problem? Should it be covered/sprayed with something to protect it from moisture? Or is this just a bad idea under any circumstances? Thanks, -- Tom Sargent, RV-6A final assembly. ________________________________________________________________________________
Date: Jun 02, 2009
At 10:50 AM 6/2/2009, you wrote: >AC43.13-1B has an extensive discussion of aircraft bonding >(grounding), including the proper procedure for connecting to the >airframe and protection against corrosion. > >This document is available in .pdf format if you don't have a >hardcopy. It's a bit large to email, so if you can find it online >for download, that's good. > >If not, please let me know and I'll make other arrangements. AC43-13 is available for download at: http://www.aeroelectric.com/Reference_Docs/FAA/ Bob . . . ----------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ----------------------------------------- ________________________________________________________________________________
Date: Jun 02, 2009
At 07:00 AM 6/1/2009, you wrote: >Bob, >The basis of my design is Z-14. Dual Odyssey 680 batteries aft with >cross-feed contactor (using one for startup and one for avionics >during starting-then switching avionics over to primary battery >after running-both batteries available if necessary for starting)) >but only one alternator (option to add second alternator later >depending on upcoming plane power product). okay >Diode inline allows alternator feed to one or both batteries. why diodes? close all the contactors and both batteries get charged by one alternator. > >Batteries really both need to be aft due to engine weight considerations. >So... is grounding both batteries at a common point aft in metal >plane a viable solution? Sure. Here's some exemplar battery grounds to airframe: http://aeroelectric.com/Pictures/Batteries/Battery_Install_OBrien_1.jpg http://aeroelectric.com/Pictures/Batteries/Battery_Install_OBrien_2.jpg http://aeroelectric.com/Pictures/Batteries/Battery_Install_OBrien_3.jpg >I note that you made reference to working on some info specific to >the RV-10. That would be great. Since the forest of tabs is on thin stainless (very poor conductor) it would be a good thing to put a 4 or 2AWG jumper from ground stud to similar structure as in photos above. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 02, 2009
At 01:26 PM 6/1/2009, you wrote: > >Bob, > >This will be on an existing Jabiru 3300 installation using the Z-20 wiring . Hmmm . . . what are the anticipated loads and duration for the aux battery? In other words, how does the aux battery fit into your recipe for plan-b success? Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 02, 2009
sonex293 wrote: > Power requirements are calculated @ 8 amps. This would include Fuel Pump, Injectors, and EFI Controller. I was looking for a one hour run time. -- Michael Read this topic online here: http://forums.matronics.com/viewtopic.php?p=246526#246526 ________________________________________________________________________________
Date: Jun 02, 2009
At 06:15 PM 6/2/2009, you wrote: > > >sonex293 wrote: > > Power requirements are calculated @ 8 amps. > > >This would include Fuel Pump, Injectors, and EFI Controller. I was >looking for a one hour run time. How big is your planned main battery and what feature of its selection and installation suggests that you can't get what you need out of the main battery? Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 02, 2009
I'm currently flying with a Odyssey PC625 battery, which has a 16Ah capacity. I'm also currently flying behind an engine/carb/magneto combo that has no fuel pumps, so even in the event of full electrical/battery failure the engine will keep running. By switching to an endurance buss my current draw with the new fuel injection system would be around 14-16 amps, I don't think the PC625 can provide 16amps for an hour in the case of charging problems. What do you think? -- Michael Read this topic online here: http://forums.matronics.com/viewtopic.php?p=246537#246537 ________________________________________________________________________________
Date: Jun 02, 2009
At 07:57 PM 6/2/2009, you wrote: > >I'm currently flying with a Odyssey PC625 battery, which has a 16Ah >capacity. > >I'm also currently flying behind an engine/carb/magneto combo that >has no fuel pumps, so even in the event of full electrical/battery >failure the engine will keep running. > >By switching to an endurance buss my current draw with the new fuel >injection system would be around 14-16 amps, I don't think the >PC625 can provide 16amps for an hour in the case of charging problems. > >What do you think? Hmmmm . . . how much STUFF have you shoe-horned into this neat little airplane that needs that much snort? Your alternator is probably a PM machine so if you've got a robust rectifier/regulator, loss of engine driven power is rare. But assuming you do need to go battery only, what situation do you anticipate that you cannot get from where you are to where you need to be using the ultimate battery-only comm/nav/ lighting system . . . http://aeroelectric.com/Pictures/Misc/Vacination_for_Dark_Panel_Syndrom.pdf Also, those numbers seem high for a small engine. Have you ever seen real energy numbers from somebody who has one of these systems flying? I hate to see you carry around any more weight than is REALLY useful. I've been pondering a li-ion battery/ automatic charter pack for OBAM aircraft. It will be the very lightest of batteries for all services other than engine cranking . . . i.e. AUX service. But it's weight, volume and price is not zero or even really attractive for airplanes like yours. I'd like to explore all the plan-A, plan-B options available to you before you start adding the $time$, $cost$, $weight$ of an additional or larger battery. Oh yeah, consider making your existing battery BIGGER before adding a second battery. But let's talk . . . Who sells your power plant package? Let's get some real running numbers from them. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 02, 2009
P.S. What's the driver for switching to the ECFI engine package? Does fuel efficiency go up so much that the additional complexity, power requirements and cost look like an attractive alternative? Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Subject: Jabiru 3300 starter
Date: Jun 02, 2009
I am helping a friend put together a power schematic for a Jabiru 3300.? I have seen several sample schematics that have both a starter solenoid and a starter contactor.? Is this really what is required and if so why ?? Is a starter contactor any different than a battery contactor? Jay Bannister ________________________________________________________________________ Email message sent from CompuServe - visit us today at http://www.cs.com ________________________________________________________________________________
Date: Jun 03, 2009
Subject: Re: Lightweight Aux =?UTF-8?Q?Battery=3F?
Hi Michael What sort of upgrade do you have planned for your 3300? Enquiring minds, thinking likewise, would like to know? All the best. Peter Eedy Waiex 109 - 50% there. Newcastle. NSW. Australia. > > > sonex293 wrote: >> Power requirements are calculated @ 8 amps. > > > This would include Fuel Pump, Injectors, and EFI Controller. I was looking > for a one hour run time. > > -- > Michael ________________________________________________________________________________
Date: Jun 03, 2009
I suppose you could "get away with it" to use the airframe for grounding. But remember that the "ground" connection does EXACTLY the same thing as the positive conductor but backwards. Wiring a tail light might be fine, but wiring the ground on a MAC/RAC trim box will almost certainly cause a noisy bar graph indicator, and the desire to keep down the loop resistance can be frustrated, and change with age. If you just can't stop yourself, then at least don't use the airframe or tubes as a high current ground for engine starting. A customer of mine has an automobile built of steel. It has a battery in the trunk and requires an additional ground conductor--or the engine won't start. Hmmmm....... "When facing a decision, ask yourself: what would I do if I wasn't afraid?" Russ Reeves -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=246583#246583 ________________________________________________________________________________
Date: Jun 03, 2009
At 07:54 AM 6/3/2009, you wrote: > >I suppose you could "get away with it" to use the airframe for >grounding. But remember that the "ground" connection does EXACTLY >the same thing as the positive conductor but backwards. > >Wiring a tail light might be fine, but wiring the ground on a >MAC/RAC trim box will almost certainly cause a noisy bar graph >indicator, and the desire to keep down the loop resistance can be >frustrated, and change with age. If you just can't stop yourself, >then at least don't use the airframe or tubes as a high current >ground for engine starting. > >A customer of mine has an automobile built of steel. It has a >battery in the trunk and requires an additional ground conductor--or >the engine won't start. Hmmmm....... All of which goes to the system integration task of deducing which devices are potential antagonists (can be grounded about anywhere) and potential victims (demand attention to wiring to avoid ground loop injection of noise). It's not a matter of "getting away with it". This phraseology suggests an air of uncertainty or risk for using the airframe as a ground. When accomplished with a bit of study and understanding, then there is no uncertainty, no risk and no wishful thinking for "getting away with" anything. >"When facing a decision, ask yourself: what would I do if I wasn't afraid?" Perhaps the better question is: "What do I need to understand to mitigate my unfounded fear?" Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 03, 2009
From: Mike Fontenot <mikef(at)apexconsultingservices.com>
Maybe it should be "ungrounded fear"..... On Wed, Jun 3, 2009 at 7:30 AM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > nuckolls.bob(at)aeroelectric.com> > > At 07:54 AM 6/3/2009, you wrote: > >> emjones(at)charter.net> >> >> I suppose you could "get away with it" to use the airframe for grounding. >> But remember that the "ground" connection does EXACTLY the same thing as the >> positive conductor but backwards. >> >> Wiring a tail light might be fine, but wiring the ground on a MAC/RAC trim >> box will almost certainly cause a noisy bar graph indicator, and the desire >> to keep down the loop resistance can be frustrated, and change with age. If >> you just can't stop yourself, then at least don't use the airframe or tubes >> as a high current ground for engine starting. >> >> A customer of mine has an automobile built of steel. It has a battery in >> the trunk and requires an additional ground conductor--or the engine won't >> start. Hmmmm....... >> > > All of which goes to the system integration task > of deducing which devices are potential antagonists > (can be grounded about anywhere) and potential victims > (demand attention to wiring to avoid ground loop injection > of noise). > > It's not a matter of "getting away with it". This > phraseology suggests an air of uncertainty or risk > for using the airframe as a ground. When accomplished > with a bit of study and understanding, then there is no > uncertainty, no risk and no wishful thinking for > "getting away with" anything. > > "When facing a decision, ask yourself: what would I do if I wasn't >> afraid?" >> > > Perhaps the better question is: "What do I need to understand to > mitigate my unfounded fear?" > > > Bob . . . > > --------------------------------------- > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > --------------------------------------- > > -- Mike =============================== Mike Fontenot Apex Consulting & Services LLC Lakewood, Colorado 303 / 731-6645 mikef AT apexconsultingservices DOT com =============================== ________________________________________________________________________________
Date: Jun 03, 2009
Bob, I went back and looked at my existing battery, the Odyssey PC625. From the MFG datasheets the battery can provide 13.6 Amps for one hour. After recalculating my load with non-essentials turned off, I 'm currently at 5.4 amps and with the addition of the EFI system would bring the current requirements to 13.1 Amps. So,with my current system I could run for about 1 hour, which was my datapoint. I guess my main concern was the even of a battery failure and/or PM Alternator failure. Based on you're comments, it sounds like a vary rare occurrence. I've been unhappy with the fuel delivery methods of the AeroCarb which I'm currently using and the Bing. Both can be setup to operate "OK", but nether can setup to operate great across the entire power spectrum. There is also the reason of just wanting to do it from a technical standpoint. So it looks like I may not need the complexities of the AUX battery. -- Michael Read this topic online here: http://forums.matronics.com/viewtopic.php?p=246610#246610 ________________________________________________________________________________
Date: Jun 03, 2009
>From the items you quoted, I guess you've guessed I'm looking at EFI. There is already someone in your neck of the woods that has done this modification and has indicated he is very pleased with the outcome. -- Michael Peter Eedy wrote: > Hi Michael > What sort of upgrade do you have planned for your 3300? > Enquiring minds, thinking likewise, would like to know? > All the best. > Read this topic online here: http://forums.matronics.com/viewtopic.php?p=246611#246611 ________________________________________________________________________________
Date: Jun 03, 2009
Mike, If it's an option, keep the same battery and add a second alternator. True, you could go with a bigger battery, but my engine is bigger than yours and the 680 works fine. A second alt is easy (unless mounting is a problem), more reliable than batteries (many will argue that one, but my auto store always sells more batteries than alternators mmmm...) and adds less weight. Better to be up there with 2 alternators than two batteries worth diddle. You do need enough juice to keep the alternator excited and that varies with the brand. I've got two alternators, one battery, dual EI and plenty of reliability. If I shut the alternators off, my machine runs for almost an hour on the 680 with dual EI before falling out of the sky (tested on ground only). This is a very old argument and everyone has their own opinion about his/her mission. The fact that we are all still here talking about it, lends itself to the idea that either solution is viable and reliable as long as you respect the limitation of each. Glenn -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of sonex293 Sent: Wednesday, June 03, 2009 11:50 AM Subject: [Probable SPAM] AeroElectric-List: Re: Lightweight Aux Battery? >From the items you quoted, I guess you've guessed I'm looking at EFI. There is already someone in your neck of the woods that has done this modification and has indicated he is very pleased with the outcome. -- Michael Peter Eedy wrote: > Hi Michael > What sort of upgrade do you have planned for your 3300? > Enquiring minds, thinking likewise, would like to know? > All the best. > Read this topic online here: http://forums.matronics.com/viewtopic.php?p=246611#246611 ________________________________________________________________________________
Subject: Essential Incident - Almost (Long)
Date: Jun 03, 2009
It was suggested by one of the aeroelectric list members, Sam Hoskins, that the following report of an incident I had on a recent trip be posted to the AeroElectric list for obvious reasons - once you read it. I have an all-electric Rv-6A with over 10 years and close to 500 hours on it. I based the electrical system roughly one of Bob's excellent designs. It initially had one alternator and two batteries, but removed the second battery approx 5 years ago - but, I did make one modification to the design that I almost had cause to regret. So needless to say, but I will, responsibility for design and incident is totally mine. But, to get on with the tale One the way to Texas I had an incident that ended up in with me and aircraft making a 7 mile engine-out glide into Craig Field (Selma, Alabama). NO! It was not fault of the engine or even the subsystems. But, the complete answer is not provided until after my litany of the conditions and symptoms - can you figure it out? I took off on Thursday (28 May 2009) AM from North Carolina planning on stopping in Mississippi to join up with two friends. After spending the night there, we all three would then head for Texas. But, the weather (as you are aware) has been laying over the southeast for days with rain and more rain - but I launched into it anyway as past Atlanta, GA things were forecast to improve.. Other than dodging lines of clouds and a bit of scud running, but not much, I landed at Alexandria City to the southwest of Atlanta, GA to take on fuel. I then climbed back in and fire it up and took off. I noticed that during climb-out the engine would occasionally miss and thought the fuel might have had a bit of water in it, but was not really concerned. So I fly on for approx another 45 minutes and had just passed Selma, Alabama and old Craig Air Force base, and turned west toward Mississippi, when more symptoms began to occur. It started to act like a case of SAG (fouled spark plugs) where the rpm will drop a bit - not dangerous - just nerve racking. But, shortly things began to go beyond the SAG symptoms, so I though I might have an injector problem (like one sticking open or not opening at all). Since our injectors are in pairs, I tried turning one pair off figuring if things got better, then that pair might have a bad injector. So I turned off one pair and sure enough the symptoms abated a bit (more on this later) so I figured I had a bad injector in that pair. To be certain I turned this "bad" pair back on and turn off the "good" pair expecting the symptoms to really get bad as I would now be running on only the "bad" pair - much to my surprise when I turned off the "good" pair - the symptoms also abated. So that indicated it was not an injector problem - but what? About this time, I decided to turn the aircraft back around toward Craig Field and dodging clouds headed back with the engine progressively getting worst. It appeared to be a fuel problem (and while that is ultimately the subsystem affected - it was not the root cause). The fuel pressure was ranging from zero to 80 psi, other electrical things were also misbehaving. I check the voltmeter thinking perhaps the alternator had died - but it showed 14 volts. So back to the fuel system. Finally, the engine just stops with the prop standing still - like a hood ornament, I'm at around 4500-5000 MSL at this point having lost some altitude dodging a cloud (good old GPS just kept pointing to Craig Field). At that time I am 6-7 miles out from Craig Field at 4500 msl with a stopped prop, a crippled seat cushion and a dry mouth. Yes, I've been there before, but I don't think you ever get "use" to it. I recalled thinking -". things just can't get worst." when they very shortly and suddenly - did. I keyed the radio and made a call to Craig Field at 4 miles on the GPS but before I could get their reply, I heard a "CLANK" (without the engine running you can hear things like that) like a relay springing open (it was) and the entire panel goes dead!!!! No radio, no engine instruments, not even a stinking LED was lit - only the battery powered GPS. Can you spell "total electrical failure?" Talk about a lonely feeling - amazing how comforting having lights on and radio - you could almost convince yourself this was just a practice engine-out landing, but not when the panel goes dark. No engine gauges, no radio, nada! Well not being one inclined to panic (but I seriously considered it for a moment {:>)), I continued toward Craig field - I mean like there were lots of other alternatives. Well Once again I found myself in the "fortunate position" of being too high, too much altitude. So I put in 40 degs of flaps to steepen my rate of descent. But, then I decided this time that rather than do the 360 I had done on a previous Incident to lose "excessive" altitude, I would try to glide - a more or less - regular traffic pattern. However, I neglected to remember to retract the flaps. So I found myself on the downwind around mid-field at pattern altitude (which felt normal) until I suddenly realized that you CAN NOT maintain that pattern altitude without an engine!!! (and particularly with 40 deg of flaps deployed - flaps and trim are manual) Duh! I knew I could never make it to the far end of the runway before turning base (toward the runway) and I was losing altitude at the rate of 400-500 fpm, so I started my turn immediately. To make matters a bit worst - I had been paralleling the runway on the downwind leg a bit too close in - must have been the comforting feeling of being close to safety. This position naturally required a tighter turn and as I turned I saw I was likely to overshoot the runway and land in the grass. So I though I need to steepen this turn further (Yep! COFFIN CORNER was calling), but fortunately glanced at my airspeed indicator - to see it only registering 80 MPH and my rate of descent (normally 400-500 feet per minute) up to over 1000 feet per minute. The seat cushion suddenly vanished from this universe. But the REAL danger in this situation, as you all know, is your airspeed gets low, you are in a steep bank which greatly raises the stall speed - meaning at 80 mph you are close to a stall in a steep turn while your are not in straight and level. So I immediately straighten out of the turn - the little voice saying "better to land in the grass than get their concrete runway all messed up". So the immediate danger of a stall was adverted, but I was still pointed toward the ground with a sink rate twice as high as normal (and I've manage a few hard landings even with a normal sink rate). Fortunately, the runway was now under my nose rather than grass. The hardest thing to do when you are sinking at a 1000 fpm a couple hundred feet above the ground (with your nose already pointed at the ground) is to push the stick forward steeping the dive even more. But, I manage to do that and picked enough air speed and energy to flair to a nice touch down - not even a bump. I've always been amazed at what total concentration does to improve you landing {:>). Rolled to the end of the runway and had energy to roll off onto the taxiway. Got out, check under the aircraft for any evidence of leaks and started pulling the aircraft toward the far -off - hangar which had an airplane parked in front of it. A nice looking young woman comes riding a bicycle out to meet me. Hopped off and holding out her hand said "Hi I'm Angie, looks like we'll be spending time together" - so things were starting to look up {:>) So pulled the aircraft in to the hangar where the mechanic came over and ask what the problem was. Well, I looked at the volt meter and it said the battery was dead. Mechanic put on a battery charger and announced "Yep! The battery is dead". So we both concluded that the alternator must have failed and not being able to replenish the drain on the battery by all the electrical systems such as fuel pumps, injectors, ignition coils, etc had drained the battery. However, there were a few problems with the analysis of a failed alternator. First, the low voltage warning light never came on to warn of an alternator problem, 2nd I never notice the voltmeter showing anything other than what it should for alternator voltage - like around 14 volts. While checking the voltage after the Mechanic had charged the battery, I noticed down below that the "essential bus" switch was in the battery rather than the alternator position, so flicked it back to the alternator position figuring I must have accidentally kicked it while getting to some stuff in the baggage compartment of my RV-6A. It was getting late and being a bit tired not to mention stressed, I needed to get a rental car and a motel for the night. Did that, eat dinner and went to bed after sitting down and drawing out a problem tree with the entire major elements of the electrical system. So next morning I show up at the hangar early and met Ben, the mechanic, the battery had received a charge of only 45 minutes the evening before, So I suggested we charged it for another hour and try to start the aircraft. Ben suggested a real stress test of the battery and NOT charge it anymore. Made sense, so we rolled the aircraft out of the hangar. I hopped in, threw a half dozen switches and punched the starter button. The engine started on the first prop blade rotation - so the battery was clearly OK. The engine is humming like a top. So I looked over at the voltmeter expecting it to show only around 12.8 volts instead of the 14 volts a functioning alternator would produce. Much to both my and Ben's surprise the alternator voltage read 14 volts. We loaded the alternator by turning on the both l00 watt landing lights, all fuel pumps, the pitot heat, etc. The alternator voltage only drops perhaps 0.4 volts clearly indicating the alternator could carry the load and was OK. So here I am - battery is OK, alternator is OK - engine is purring normally, so clearly this was all a figment of my deteriorating brain cells. I loaded up the aircraft and launched to do a few circuits of the airport - I did so and all was operating normally and so I radio them I was head onward to Texas. While flying (with my only functional eyeball on the voltmeter), my mind could not let go of the problem and finally the light bulb came on. The essential bus switch had (for my entire 10 + years of flying)always been in the alternator position. The purpose of this switch is, of course, to isolate the battery from the alternator should the alternator fail - to prevent an alternator problem from draining the battery. So in event of an alternator problem, you move the switch from alternator to battery. Its call the essential bus because you only have the essential things drawing from the battery so you wont' drain it as quickly. The idea is to give you time (generally around 30 minutes) to find a safe place to land in case of alternator failure. Well, at some point I had either (not paying attention) turned the switch to battery thinking I was turning the voltmeter switch to battery(more on that below) - or accidentally had move the switch from alternator to battery without noticing it by kicking it, etc. However, it was sort of protected in its position from accidental activation. It must have happened during refueling - as I got approx 45 minutes down the road on the battery after take off before quality battery time started to deteriorate. As the battery voltage fell due to the load (and no alternator link to replenish it), electrical things (mainly computers first) started acting up until they could not longer run the engine. The injectors would not open fully, etc. Then as the voltage level further decreased, the master relay which the battery held closed and which connected the (fully functional) alternator to the rest of the electrical system - opened up and removed ALL power from the electrical system. So no radio, no gauges, etc. Oh, another little factor that may have contributed, the voltmeter has a tiny toggle switch by it marked ALT BAT1 BAT2 for checking alternator battery 1 and battery 2 (which I no longer fly with) voltages. Down below It a couple of inches and off to the right is the essential bus normal size toggle switch - also marked ALT BAT1 BAT1. I normally never touch it and don't even think about it. But I could have reached for the voltmeter toggle thinking to check my battery voltage (which I do as a regular thing) and perhaps distracted by something reached a bit further down and instead moved the essential bus switch from Alternator to Battery causing this entire event. I know that I did not consciously do it. So it is either accidental or absence minded activation - either way ends with the same results {:>) Now it became clear why it didn't matter which pair of fuel injectors I turned off - turning off either pair improved the situation because it slightly reduced the electrical load by a few amps - and the engine ran slightly better for a few moments. The same thing had happened when turning off one of the EFI fuel pumps - but what threw me was the alternator voltage continued to be normal during this. After I knew the cause (switch in wrong position), I decided the problem was fixed so no reason to return to NC, and I just continued on to Texas. I know some of you may think that removing my second battery was a mistake - but, consider this, having another battery could have meant I would have been much further from a suitable airfield before they both went south. On the other hand, it might have caused me to at least think to throw the essential bus switch to the second battery and have the Light bulb come on. Who really knows. But, I have in mind a simply addition to my electrical circuit that should help in the future. I do want to state that this time when the problems started I DID switch fuel tanks - but naturally it had no effect because this time it turned out, it was not a fuel problem - not the root cause at least. So what are the lessons learned: 1. Put EVERY critical switch on your before-takeoff Check list 2. Perhaps put a guard around such critical switches to force conscious activation 3. Don't (hard not to) get overly focused on what you think is the problem - consider other possibilities. I thought it was a fuel problem (I even switched fuel tanks this time) - it turned out to be electrical in its root cause. 4. While the fuel pressure was jumping all over the place and the EGT was erratic and engine surging strongly indicating a fuel problem - the ultimate cause was electrical. Once the voltage got below a certain point the EC2 computer was still trying to pull the injectors open, but with the voltage so low it could not do it properly. 5. When the battery voltage dropped below a certain point, the master relay released and removed the alternator from the electrical system and the panel went dark - even though the alternator was still working 6. Immediately turn to the nearest airfield when serious problems occur - THEN work on fixing them. I only delayed for perhaps 2-3 minutes, but that could have made a difference. 7. Watch out for Coffin Corner turn when turning base to final - airspeed really bleeds off fast with no engine pulling you along (and especially with flaps deployed!) 8. IF you change your mind about landing approach type - remember to reconfigure your aircraft for the last decision - I had left my flaps deployed when I should have remembered to retracted them. Did that help prevent a Coffin Corner stall and spin or would it have put me closer to it? 9. You must increase airspeed over the wing to get the sufficient energy to over come a high sink rate. Pulling back on the stick when the ground is staring you in the face is the natural reaction - but, pushing forward to lower the nose is the correct action - providing of course you have sufficient altitude! 10. Battery life - I had a two year old 680 odyssey battery which I maintain a trickle charge on whenever I'm not flying. With two EFI fuel pumps, boost pump, injectors, coils, EC2 and radio and just having started the engine before take off - this battery lasted 55 minutes. Well, the last 5 minutes were not quality battery time. So in my case, 30 minutes appears to be a very realistic battery life. In fact, had I turned off one EFI pump and the boost pump would have gained a few more miles. But, if I had recognized the need to turn them off at that time (I normally turn them off at cruise altitude), then I would have known how to "fix" the problem. 11. I've decided to add a Schokkty diode between my essential bus and the alternator - so that as long as the alternator is producing sufficient voltage, then the battery will be getting some charge to replace the drain. I've also decided to make that switch position a check-list item. So what it boils down to - if I had recognized early on that it was an electrical problem and not focused so much on the fuel system, I may have noticed the essential bus switch in the wrong position. Force yourself to examine other possible causes (easy to say - harder to do). NEVER, NEVER forget that flying the airplane is the first and only priority in this type of situation NEVER, NEVER forget that saving your butt is the ultimately end-all priority. When I decided that landing on the grass was preferable to putting a hole in their concrete - I may have made a life-saving decision. So that's my story and I'm sticking to it. Fly safe, guys!! Ed Ed Anderson Rv-6A N494BW Rotary Powered Matthews, NC eanderson(at)carolina.rr.com <http://www.andersonee.com> http://www.andersonee.com <http://www.dmack.net/mazda/index.html> http://www.dmack.net/mazda/index.html http://www.flyrotary.com/ <http://members.cox.net/rogersda/rotary/configs.htm> http://members.cox.net/rogersda/rotary/configs.htm#N494BW <http://www.dmack.net/mazda/index.html> ________________________________________________________________________________
Date: Jun 03, 2009
Subject: Re: Essential Incident - Almost (Long)
Ed - great story. Just out of curiosity, where is the essential bus switch located? Is it plainly in your field of vision or do you have to turn your head to see it? Cockpit ergonomics are a huge challenge. Sam Hoskins www.samhoskins.blogspot.com On Wed, Jun 3, 2009 at 2:53 PM, Ed Anderson wrot e: > It was suggested by one of the aeroelectric list members, Sam Hoskins, > that the following report of an incident I had on a recent trip be poste d > to the AeroElectric list for obvious reasons ' once you read it. > > > I have an all-electric Rv-6A with over 10 years and close to 500 hours o n > it. I based the electrical system roughly one of Bob=92s excellent desig ns. > It initially had one alternator and two batteries, but removed the secon d > battery approx 5 years ago ' but, I did make one modification to the d esign > that I almost had cause to regret. > > > So needless to say, but I will, responsibility for design and incident is > totally mine. > > > But, to get on with the tale > > > One the way to Texas I had an incident that ended up in with me and > aircraft making a 7 mile engine-out glide into Craig Field (Selma, > Alabama). NO! It was not fault of the engine or even the subsystems. B ut, > the complete answer is not provided until after my litany of the conditio ns > and symptoms ' can you figure it out? > > > I took off on Thursday (28 May 2009) AM from North Carolina planning on > stopping in Mississippi to join up with two friends. After spending the > night there, we all three would then head for Texas. But, the weather (a s > you are aware) has been laying over the southeast for days with rain and > more rain ' but I launched into it anyway as past Atlanta, GA things we re > forecast to improve.. > > > Other than dodging lines of clouds and a bit of scud running, but not muc h, > I landed at Alexandria City to the southwest of Atlanta, GA to take on > fuel. I then climbed back in and fire it up and took off. > > > I noticed that during climb-out the engine would occasionally miss and > thought the fuel might have had a bit of water in it, but was not really > concerned. So I fly on for approx another 45 minutes and had just passed > Selma, Alabama and old Craig Air Force base, and turned west toward > Mississippi, when more symptoms began to occur. > > > It started to act like a case of SAG (fouled spark plugs) where the rpm > will drop a bit ' not dangerous - just nerve racking. But, shortly thi ngs > began to go beyond the SAG symptoms, so I though I might have an injector > problem (like one sticking open or not opening at all). Since our inject ors > are in pairs, I tried turning one pair off figuring if things got better , > then that pair might have a bad injector. > > > So I turned off one pair and sure enough the symptoms abated a bit (more on > this later) so I figured I had a bad injector in that pair. To be certai n I > turned this =93bad=94 pair back on and turn off the =93good=94 pair expec ting the > symptoms to really get bad as I would now be running on only the =93bad =94 pair > ' much to my surprise when I turned off the =93good=94 pair ' the sym ptoms also > abated. So that indicated it was not an injector problem ' but what? > > > About this time, I decided to turn the aircraft back around toward Craig > Field and dodging clouds headed back with the engine progressively gettin g > worst. It appeared to be a fuel problem (and while that is ultimately the > subsystem affected - it was not the root cause). The fuel pressure was > ranging from zero to 80 psi, other electrical things were also misbehavin g. > I check the voltmeter thinking perhaps the alternator had died ' but it > showed 14 volts. So back to the fuel system. > > > Finally, the engine just stops with the prop standing still - like a ho od > ornament, I=92m at around 4500-5000 MSL at this point having lost some > altitude dodging a cloud (good old GPS just kept pointing to Craig Field) . > At that time I am 6-7 miles out from Craig Field at 4500 msl with a stopp ed > prop, a crippled seat cushion and a dry mouth. Yes, I=92ve been there be fore, > but I don=92t think you ever get =93use=94 to it. I recalled thinking '=93=85 things > just can=92t get worst=85=94 when they very shortly and suddenly - did. > > > I keyed the radio and made a call to Craig Field at 4 miles on the GPS bu t > before I could get their reply, I heard a =93CLANK=94 (without the engine > running you can hear things like that) like a relay springing open (it w as) > and the entire panel goes dead!!!! No radio, no engine instruments, not > even a stinking LED was lit ' only the battery powered GPS. Can you sp ell > =93total electrical failure?=94 Talk about a lonely feeling ' amazing how > comforting having lights on and radio ' you could almost convince yours elf > this was just a practice engine-out landing, but not when the panel goes > dark. No engine gauges, no radio, nada! > > > Well not being one inclined to panic (but I seriously considered it for a > moment {:>)), I continued toward Craig field ' I mean like there were l ots > of other alternatives. Well Once again I found myself in the =93fortunat e > position=94 of being too high, too much altitude. So I put in 40 degs of flaps > to steepen my rate of descent. But, then I decided this time that rather > than do the 360 I had done on a previous Incident to lose =93excessive=94 > altitude, I would try to glide - a more or less - regular traffic pattern . > > > However, I neglected to remember to retract the flaps. So I found myself > on the downwind around mid-field at pattern altitude (which felt normal) > until I suddenly realized that you CAN NOT maintain that pattern altitude > without an engine!!! (and particularly with 40 deg of flaps deployed ' > flaps and trim are manual) Duh! > > > I knew I could never make it to the far end of the runway before turning > base (toward the runway) and I was losing altitude at the rate of 400-500 > fpm, so I started my turn immediately. To make matters a bit worst - I had > been paralleling the runway on the downwind leg a bit too close in ' mu st > have been the comforting feeling of being close to safety. This position > naturally required a tighter turn and as I turned I saw I was likely to > overshoot the runway and land in the grass. So I though I need to steepe n > this turn further (Yep! COFFIN CORNER was calling), but fortunately glan ced > at my airspeed indicator - to see it only registering 80 MPH and my rate of > descent (normally 400-500 feet per minute) up to over 1000 feet per minut e. > The seat cushion suddenly vanished from this universe. > > > But the REAL danger in this situation, as you all know, is your airspee d > gets low, you are in a steep bank which greatly raises the stall speed - > meaning at 80 mph you are close to a stall in a steep turn while your are > not in straight and level. So I immediately straighten out of the turn ' > the little voice saying =93better to land in the grass than get their con crete > runway all messed up=94. So the immediate danger of a stall was adverted , but > I was still pointed toward the ground with a sink rate twice as high as > normal (and I=92ve manage a few hard landings even with a normal sink rat e). > Fortunately, the runway was now under my nose rather than grass. > > > The hardest thing to do when you are sinking at a 1000 fpm a couple hundr ed > feet above the ground (with your nose already pointed at the ground) is t o > push the stick forward steeping the dive even more. But, I manage to do > that and picked enough air speed and energy to flair to a nice touch down ' > not even a bump. I=92ve always been amazed at what total concentration d oes > to improve you landing {:>). > > > Rolled to the end of the runway and had energy to roll off onto the > taxiway. Got out, check under the aircraft for any evidence of leaks an d > started pulling the aircraft toward the far 'off ' hangar which had a n > airplane parked in front of it. A nice looking young woman comes riding a > bicycle out to meet me. Hopped off and holding out her hand said =93Hi I =92m > Angie, looks like we=92ll be spending time together=94 ' so things were starting > to look up {:>) > > > So pulled the aircraft in to the hangar where the mechanic came over and > ask what the problem was. Well, I looked at the volt meter and it said t he > battery was dead. Mechanic put on a battery charger and announced =93Yep! The > battery is dead=94. So we both concluded that the alternator must have f ailed > and not being able to replenish the drain on the battery by all the > electrical systems such as fuel pumps, injectors, ignition coils, etc had > drained the battery. > > > However, there were a few problems with the analysis of a failed > alternator. First, the low voltage warning light never came on to warn o f > an alternator problem, 2nd I never notice the voltmeter showing anything > other than what it should for alternator voltage ' like around 14 volts . > While checking the voltage after the Mechanic had charged the battery, I > noticed down below that the =93essential bus=94 switch was in the battery rather > than the alternator position, so flicked it back to the alternator positi on > figuring I must have accidentally kicked it while getting to some stuff i n > the baggage compartment of my RV-6A. > > > It was getting late and being a bit tired not to mention stressed, I need ed > to get a rental car and a motel for the night. Did that, eat dinner and > went to bed after sitting down and drawing out a problem tree with the > entire major elements of the electrical system. > > > So next morning I show up at the hangar early and met Ben, the mechanic, > the battery had received a charge of only 45 minutes the evening before, So > I suggested we charged it for another hour and try to start the aircraft. > Ben suggested a real stress test of the battery and NOT charge it anymore . > Made sense, so we rolled the aircraft out of the hangar. I hopped in, th rew > a half dozen switches and punched the starter button. The engine started on > the first prop blade rotation ' so the battery was clearly OK. The engi ne is > humming like a top. So I looked over at the voltmeter expecting it to > show only around 12.8 volts instead of the 14 volts a functioning alterna tor > would produce. Much to both my and Ben=92s surprise the alternator volt age > read 14 volts. We loaded the alternator by turning on the both l00 watt > landing lights, all fuel pumps, the pitot heat, etc. The alternator volt age > only drops perhaps 0.4 volts clearly indicating the alternator could carr y > the load and was OK. > > > So here I am ' battery is OK, alternator is OK ' engine is purring > normally, so clearly this was all a figment of my deteriorating brain > cells. I loaded up the aircraft and launched to do a few circuits of the > airport ' I did so and all was operating normally and so I radio them I was > head onward to Texas. While flying (with my only functional eyeball on t he > voltmeter), my mind could not let go of the problem and finally the light > bulb came on. > > > The essential bus switch had (for my entire 10 + years of flying)always > been in the alternator position. The purpose of this switch is, of cours e, > to isolate the battery from the alternator should the alternator fail - to > prevent an alternator problem from draining the battery. So in event of an > alternator problem, you move the switch from alternator to battery. Its > call the essential bus because you only have the essential things drawing > from the battery so you wont=92 drain it as quickly. The idea is to give you > time (generally around 30 minutes) to find a safe place to land in case o f > alternator failure. > > > Well, at some point I had either (not paying attention) turned the switch > to battery thinking I was turning the voltmeter switch to battery(more on > that below) - or accidentally had move the switch from alternator to > battery without noticing it by kicking it, etc. However, it was sort of > protected in its position from accidental activation. It must have happen ed > during refueling ' as I got approx 45 minutes down the road on the batt ery > after take off before quality battery time started to deteriorate. As th e > battery voltage fell due to the load (and no alternator link to replenish > it), electrical things (mainly computers first) started acting up until t hey > could not longer run the engine. The injectors would not open fully, etc. > Then as the voltage level further decreased, the master relay which the > battery held closed and which connected the (fully functional) alternator to > the rest of the electrical system - opened up and removed ALL power from the > electrical system. So no radio, no gauges, etc. > > > Oh, another little factor that may have contributed, the voltmeter has a > tiny toggle switch by it marked ALT BAT1 BAT2 for checking alternator > battery 1 and battery 2 (which I no longer fly with) voltages. Down belo w > It a couple of inches and off to the right is the essential bus normal si ze > toggle switch ' also marked ALT BAT1 BAT1. I normally never touch it a nd > don=92t even think about it. But I could have reached for the voltmeter > toggle thinking to check my battery voltage (which I do as a regular thin g) > and perhaps distracted by something reached a bit further down and instea d > moved the essential bus switch from Alternator to Battery causing this > entire event. I know that I did not consciously do it. So it is either > accidental or absence minded activation - either way ends with the same > results {:>) > > > Now it became clear why it didn=92t matter which pair of fuel injectors I > turned off ' turning off either pair improved the situation because it > slightly reduced the electrical load by a few amps ' and the engine ran > slightly better for a few moments. The same thing had happened when turn ing > off one of the EFI fuel pumps ' but what threw me was the alternator vo ltage > continued to be normal during this. > > > After I knew the cause (switch in wrong position), I decided the problem > was fixed so no reason to return to NC, and I just continued on to Texas. > > > I know some of you may think that removing my second battery was a mistak e > ' but, consider this, having another battery could have meant I would h ave > been much further from a suitable airfield before they both went south. On > the other hand, it might have caused me to at least think to throw the > essential bus switch to the second battery and have the Light bulb come o n. > Who really knows. But, I have in mind a simply addition to my electrical > circuit that should help in the future. > > > I do want to state that this time when the problems started I DID switch > fuel tanks ' but naturally it had no effect because this time it turned out, > it was not a fuel problem ' not the root cause at least. > > > So what are the lessons learned: > > > 1. Put EVERY critical switch on your before-takeoff Check list > 2. Perhaps put a guard around such critical switches to force consciou s > activation > 3. Don=92t (hard not to) get overly focused on what you think is the > problem ' consider other possibilities. I thought it was a fuel pro blem (I > even switched fuel tanks this time) ' it turned out to be electrical in its > root cause. > 4. While the fuel pressure was jumping all over the place and the EGT > was erratic and engine surging strongly indicating a fuel problem ' the > ultimate cause was electrical. Once the voltage got below a certain p oint > the EC2 computer was still trying to pull the injectors open, but wit h the > voltage so low it could not do it properly. > 5. When the battery voltage dropped below a certain point, the master > relay released and removed the alternator from the electrical system a nd the > panel went dark ' even though the alternator was still working > 6. Immediately turn to the nearest airfield when serious problems occu r > - THEN work on fixing them. I only delayed for perhaps 2-3 minutes, b ut > that could have made a difference. > 7. Watch out for *Coffin Corner* turn when turning base to final ' > airspeed really bleeds off fast with no engine pulling you along (and > especially with flaps deployed!) > 8. IF you change your mind about landing approach type - remember to > reconfigure your aircraft for the last decision ' I had left my flap s > deployed when I should have remembered to retracted them. Did that he lp > prevent a Coffin Corner stall and spin or would it have put me closer to it? > 9. You must increase airspeed over the wing to get the sufficient > energy to over come a high sink rate. Pulling back on the stick when the > ground is staring you in the face is the natural reaction ' but, pus hing > forward to lower the nose is the correct action ' providing of cours e you > have sufficient altitude! > 10. Battery life ' I had a two year old 680 odyssey battery which I > maintain a trickle charge on whenever I=92m not flying. With two EFI fuel > pumps, boost pump, injectors, coils, EC2 and radio and just having sta rted > the engine before take off ' this battery lasted 55 minutes. Well, the last > 5 minutes were not quality battery time. So in my case, 30 minutes ap pears > to be a very realistic battery life. In fact, had I turned off one EF I pump > and the boost pump would have gained a few more miles. But, if I had > recognized the need to turn them off at that time (I normally turn the m off > at cruise altitude), then I would have known how to =93fix=94 the prob lem. > 11. I=92ve decided to add a Schokkty diode between my essential bus an d > the alternator ' so that as long as the alternator is producing suff icient > voltage, then the battery will be getting some charge to replace the d rain. > I=92ve also decided to make that switch position a check-list item. > > > So what it boils down to ' if I had recognized early on that it was an > electrical problem and not focused so much on the fuel system, I may have > noticed the essential bus switch in the wrong position. Force yourself t o > examine other possible causes (easy to say ' harder to do). > > > NEVER, NEVER forget that flying the airplane is the first and only priori ty > in this type of situation > > > NEVER, NEVER forget that saving your butt is the ultimately end-all > priority. When I decided that landing on the grass was preferable to > putting a hole in their concrete ' I may have made a life-saving decis ion. > > > So that=92s my story and I=92m sticking to it. > > > Fly safe, guys!! > > > Ed > > Ed Anderson > > Rv-6A N494BW Rotary Powered > > Matthews, NC > > eanderson(at)carolina.rr.com > > http://www.andersonee.com > > http://www.dmack.net/mazda/index.html > > http://www.flyrotary.com/ > > http://members.cox.net/rogersda/rotary/configs.htm#N494BW cox.net/rogersda/rotary/configs.htm> > > <http://www.dmack.net/mazda/index.html> > > > * > =========== =========== =========== =========== > * > > ________________________________________________________________________________
Date: Jun 03, 2009
Great writeup Ed. Thanks for sharing it with the list. Regards, Matt- > It was suggested by one of the aeroelectric list members, Sam Hoskins, > that > the following report of an incident I had on a recent trip be posted to > the > AeroElectric list for obvious reasons - once you read it. > > > I have an all-electric Rv-6A with over 10 years and close to 500 hours on > it. I based the electrical system roughly one of Bob's excellent designs. > It initially had one alternator and two batteries, but removed the second > battery approx 5 years ago - but, I did make one modification to the > design > that I almost had cause to regret. > > > So needless to say, but I will, responsibility for design and incident > is > totally mine. > > > But, to get on with the tale > > > One the way to Texas I had an incident that ended up in with me and > aircraft > making a 7 mile engine-out glide into Craig Field (Selma, Alabama). NO! > It > was not fault of the engine or even the subsystems. But, the complete > answer is not provided until after my litany of the conditions and > symptoms > - can you figure it out? > > > I took off on Thursday (28 May 2009) AM from North Carolina planning on > stopping in Mississippi to join up with two friends. After spending the > night there, we all three would then head for Texas. But, the weather (as > you are aware) has been laying over the southeast for days with rain and > more rain - but I launched into it anyway as past Atlanta, GA things were > forecast to improve.. > > > Other than dodging lines of clouds and a bit of scud running, but not > much, > I landed at Alexandria City to the southwest of Atlanta, GA to take on > fuel. > I then climbed back in and fire it up and took off. > > > I noticed that during climb-out the engine would occasionally miss and > thought the fuel might have had a bit of water in it, but was not really > concerned. So I fly on for approx another 45 minutes and had just passed > Selma, Alabama and old Craig Air Force base, and turned west toward > Mississippi, when more symptoms began to occur. > > > It started to act like a case of SAG (fouled spark plugs) where the rpm > will > drop a bit - not dangerous - just nerve racking. But, shortly things > began > to go beyond the SAG symptoms, so I though I might have an injector > problem > (like one sticking open or not opening at all). Since our injectors are > in > pairs, I tried turning one pair off figuring if things got better, then > that pair might have a bad injector. > > > So I turned off one pair and sure enough the symptoms abated a bit (more > on > this later) so I figured I had a bad injector in that pair. To be certain > I > turned this "bad" pair back on and turn off the "good" pair expecting the > symptoms to really get bad as I would now be running on only the "bad" > pair > - much to my surprise when I turned off the "good" pair - the symptoms > also > abated. So that indicated it was not an injector problem - but what? > > > About this time, I decided to turn the aircraft back around toward Craig > Field and dodging clouds headed back with the engine progressively getting > worst. It appeared to be a fuel problem (and while that is ultimately the > subsystem affected - it was not the root cause). The fuel pressure was > ranging from zero to 80 psi, other electrical things were also > misbehaving. > I check the voltmeter thinking perhaps the alternator had died - but it > showed 14 volts. So back to the fuel system. > > > Finally, the engine just stops with the prop standing still - like a > hood > ornament, I'm at around 4500-5000 MSL at this point having lost some > altitude dodging a cloud (good old GPS just kept pointing to Craig Field). > At that time I am 6-7 miles out from Craig Field at 4500 msl with a > stopped > prop, a crippled seat cushion and a dry mouth. Yes, I've been there > before, > but I don't think you ever get "use" to it. I recalled thinking -". > things > just can't get worst." when they very shortly and suddenly - did. > > > I keyed the radio and made a call to Craig Field at 4 miles on the GPS but > before I could get their reply, I heard a "CLANK" (without the engine > running you can hear things like that) like a relay springing open (it > was) > and the entire panel goes dead!!!! No radio, no engine instruments, not > even a stinking LED was lit - only the battery powered GPS. Can you spell > "total electrical failure?" Talk about a lonely feeling - amazing how > comforting having lights on and radio - you could almost convince yourself > this was just a practice engine-out landing, but not when the panel goes > dark. No engine gauges, no radio, nada! > > > Well not being one inclined to panic (but I seriously considered it for a > moment {:>)), I continued toward Craig field - I mean like there were lots > of other alternatives. Well Once again I found myself in the "fortunate > position" of being too high, too much altitude. So I put in 40 degs of > flaps > to steepen my rate of descent. But, then I decided this time that rather > than do the 360 I had done on a previous Incident to lose "excessive" > altitude, I would try to glide - a more or less - regular traffic pattern. > > > However, I neglected to remember to retract the flaps. So I found myself > on > the downwind around mid-field at pattern altitude (which felt normal) > until > I suddenly realized that you CAN NOT maintain that pattern altitude > without > an engine!!! (and particularly with 40 deg of flaps deployed - flaps and > trim are manual) Duh! > > > I knew I could never make it to the far end of the runway before turning > base (toward the runway) and I was losing altitude at the rate of 400-500 > fpm, so I started my turn immediately. To make matters a bit worst - I > had > been paralleling the runway on the downwind leg a bit too close in - must > have been the comforting feeling of being close to safety. This position > naturally required a tighter turn and as I turned I saw I was likely to > overshoot the runway and land in the grass. So I though I need to steepen > this turn further (Yep! COFFIN CORNER was calling), but fortunately > glanced > at my airspeed indicator - to see it only registering 80 MPH and my rate > of > descent (normally 400-500 feet per minute) up to over 1000 feet per > minute. > The seat cushion suddenly vanished from this universe. > > > But the REAL danger in this situation, as you all know, is your airspeed > gets low, you are in a steep bank which greatly raises the stall speed - > meaning at 80 mph you are close to a stall in a steep turn while your are > not in straight and level. So I immediately straighten out of the turn - > the little voice saying "better to land in the grass than get their > concrete > runway all messed up". So the immediate danger of a stall was adverted, > but > I was still pointed toward the ground with a sink rate twice as high as > normal (and I've manage a few hard landings even with a normal sink rate). > Fortunately, the runway was now under my nose rather than grass. > > > The hardest thing to do when you are sinking at a 1000 fpm a couple > hundred > feet above the ground (with your nose already pointed at the ground) is to > push the stick forward steeping the dive even more. But, I manage to do > that and picked enough air speed and energy to flair to a nice touch down > - > not even a bump. I've always been amazed at what total concentration does > to improve you landing {:>). > > > Rolled to the end of the runway and had energy to roll off onto the > taxiway. > Got out, check under the aircraft for any evidence of leaks and started > pulling the aircraft toward the far -off - hangar which had an airplane > parked in front of it. A nice looking young woman comes riding a bicycle > out to meet me. Hopped off and holding out her hand said "Hi I'm Angie, > looks like we'll be spending time together" - so things were starting to > look up {:>) > > > So pulled the aircraft in to the hangar where the mechanic came over and > ask > what the problem was. Well, I looked at the volt meter and it said the > battery was dead. Mechanic put on a battery charger and announced "Yep! > The > battery is dead". So we both concluded that the alternator must have > failed > and not being able to replenish the drain on the battery by all the > electrical systems such as fuel pumps, injectors, ignition coils, etc had > drained the battery. > > > However, there were a few problems with the analysis of a failed > alternator. > First, the low voltage warning light never came on to warn of an > alternator > problem, 2nd I never notice the voltmeter showing anything other than what > it should for alternator voltage - like around 14 volts. While checking > the > voltage after the Mechanic had charged the battery, I noticed down below > that the "essential bus" switch was in the battery rather than the > alternator position, so flicked it back to the alternator position > figuring > I must have accidentally kicked it while getting to some stuff in the > baggage compartment of my RV-6A. > > > It was getting late and being a bit tired not to mention stressed, I > needed > to get a rental car and a motel for the night. Did that, eat dinner and > went to bed after sitting down and drawing out a problem tree with the > entire major elements of the electrical system. > > > So next morning I show up at the hangar early and met Ben, the mechanic, > the > battery had received a charge of only 45 minutes the evening before, So I > suggested we charged it for another hour and try to start the aircraft. > Ben > suggested a real stress test of the battery and NOT charge it anymore. > Made > sense, so we rolled the aircraft out of the hangar. I hopped in, threw a > half dozen switches and punched the starter button. The engine started on > the first prop blade rotation - so the battery was clearly OK. The engine > is > humming like a top. So I looked over at the voltmeter expecting it to > show only around 12.8 volts instead of the 14 volts a functioning > alternator > would produce. Much to both my and Ben's surprise the alternator voltage > read 14 volts. We loaded the alternator by turning on the both l00 watt > landing lights, all fuel pumps, the pitot heat, etc. The alternator > voltage > only drops perhaps 0.4 volts clearly indicating the alternator could carry > the load and was OK. > > > So here I am - battery is OK, alternator is OK - engine is purring > normally, > so clearly this was all a figment of my deteriorating brain cells. I > loaded > up the aircraft and launched to do a few circuits of the airport - I did > so > and all was operating normally and so I radio them I was head onward to > Texas. While flying (with my only functional eyeball on the voltmeter), > my > mind could not let go of the problem and finally the light bulb came on. > > > The essential bus switch had (for my entire 10 + years of flying)always > been > in the alternator position. The purpose of this switch is, of course, to > isolate the battery from the alternator should the alternator fail - to > prevent an alternator problem from draining the battery. So in event of > an > alternator problem, you move the switch from alternator to battery. Its > call the essential bus because you only have the essential things drawing > from the battery so you wont' drain it as quickly. The idea is to give > you > time (generally around 30 minutes) to find a safe place to land in case of > alternator failure. > > > Well, at some point I had either (not paying attention) turned the switch > to > battery thinking I was turning the voltmeter switch to battery(more on > that > below) - or accidentally had move the switch from alternator to battery > without noticing it by kicking it, etc. However, it was sort of protected > in its position from accidental activation. It must have happened during > refueling - as I got approx 45 minutes down the road on the battery after > take off before quality battery time started to deteriorate. As the > battery > voltage fell due to the load (and no alternator link to replenish it), > electrical things (mainly computers first) started acting up until they > could not longer run the engine. The injectors would not open fully, etc. > Then as the voltage level further decreased, the master relay which the > battery held closed and which connected the (fully functional) alternator > to > the rest of the electrical system - opened up and removed ALL power from > the > electrical system. So no radio, no gauges, etc. > > > Oh, another little factor that may have contributed, the voltmeter has a > tiny toggle switch by it marked ALT BAT1 BAT2 for checking alternator > battery 1 and battery 2 (which I no longer fly with) voltages. Down below > It a couple of inches and off to the right is the essential bus normal > size > toggle switch - also marked ALT BAT1 BAT1. I normally never touch it and > don't even think about it. But I could have reached for the voltmeter > toggle thinking to check my battery voltage (which I do as a regular > thing) > and perhaps distracted by something reached a bit further down and instead > moved the essential bus switch from Alternator to Battery causing this > entire event. I know that I did not consciously do it. So it is either > accidental or absence minded activation - either way ends with the same > results {:>) > > > Now it became clear why it didn't matter which pair of fuel injectors I > turned off - turning off either pair improved the situation because it > slightly reduced the electrical load by a few amps - and the engine ran > slightly better for a few moments. The same thing had happened when > turning > off one of the EFI fuel pumps - but what threw me was the alternator > voltage > continued to be normal during this. > > > After I knew the cause (switch in wrong position), I decided the problem > was > fixed so no reason to return to NC, and I just continued on to Texas. > > > I know some of you may think that removing my second battery was a mistake > - > but, consider this, having another battery could have meant I would have > been much further from a suitable airfield before they both went south. > On > the other hand, it might have caused me to at least think to throw the > essential bus switch to the second battery and have the Light bulb come > on. > Who really knows. But, I have in mind a simply addition to my electrical > circuit that should help in the future. > > > I do want to state that this time when the problems started I DID switch > fuel tanks - but naturally it had no effect because this time it turned > out, > it was not a fuel problem - not the root cause at least. > > > So what are the lessons learned: > > > 1. Put EVERY critical switch on your before-takeoff Check list > 2. Perhaps put a guard around such critical switches to force conscious > activation > 3. Don't (hard not to) get overly focused on what you think is the > problem - consider other possibilities. I thought it was a fuel problem > (I > even switched fuel tanks this time) - it turned out to be electrical in > its > root cause. > 4. While the fuel pressure was jumping all over the place and the EGT > was erratic and engine surging strongly indicating a fuel problem - the > ultimate cause was electrical. Once the voltage got below a certain point > the EC2 computer was still trying to pull the injectors open, but with > the > voltage so low it could not do it properly. > 5. When the battery voltage dropped below a certain point, the master > relay released and removed the alternator from the electrical system and > the > panel went dark - even though the alternator was still working > 6. Immediately turn to the nearest airfield when serious problems occur > - THEN work on fixing them. I only delayed for perhaps 2-3 minutes, but > that could have made a difference. > 7. Watch out for Coffin Corner turn when turning base to final - > airspeed really bleeds off fast with no engine pulling you along (and > especially with flaps deployed!) > 8. IF you change your mind about landing approach type - remember to > reconfigure your aircraft for the last decision - I had left my flaps > deployed when I should have remembered to retracted them. Did that help > prevent a Coffin Corner stall and spin or would it have put me closer to > it? > > 9. You must increase airspeed over the wing to get the sufficient > energy to over come a high sink rate. Pulling back on the stick when the > ground is staring you in the face is the natural reaction - but, pushing > forward to lower the nose is the correct action - providing of course you > have sufficient altitude! > 10. Battery life - I had a two year old 680 odyssey battery which I > maintain a trickle charge on whenever I'm not flying. With two EFI fuel > pumps, boost pump, injectors, coils, EC2 and radio and just having started > the engine before take off - this battery lasted 55 minutes. Well, the > last > 5 minutes were not quality battery time. So in my case, 30 minutes > appears > to be a very realistic battery life. In fact, had I turned off one EFI > pump > and the boost pump would have gained a few more miles. But, if I had > recognized the need to turn them off at that time (I normally turn them > off > at cruise altitude), then I would have known how to "fix" the problem. > 11. I've decided to add a Schokkty diode between my essential bus and > the alternator - so that as long as the alternator is producing sufficient > voltage, then the battery will be getting some charge to replace the > drain. > I've also decided to make that switch position a check-list item. > > > So what it boils down to - if I had recognized early on that it was an > electrical problem and not focused so much on the fuel system, I may have > noticed the essential bus switch in the wrong position. Force yourself to > examine other possible causes (easy to say - harder to do). > > > NEVER, NEVER forget that flying the airplane is the first and only > priority > in this type of situation > > > NEVER, NEVER forget that saving your butt is the ultimately end-all > priority. When I decided that landing on the grass was preferable to > putting a hole in their concrete - I may have made a life-saving > decision. > > > So that's my story and I'm sticking to it. > > > Fly safe, guys!! > > > Ed > > Ed Anderson > > Rv-6A N494BW Rotary Powered > > Matthews, NC > > eanderson(at)carolina.rr.com > > <http://www.andersonee.com> http://www.andersonee.com > > <http://www.dmack.net/mazda/index.html> > http://www.dmack.net/mazda/index.html > > http://www.flyrotary.com/ > > <http://members.cox.net/rogersda/rotary/configs.htm> > http://members.cox.net/rogersda/rotary/configs.htm#N494BW > > <http://www.dmack.net/mazda/index.html> > > ________________________________________________________________________________
Date: Jun 03, 2009
Ed, Congrats for keeping your cool, and flying the airplane to a safe landing. And thanks for sharing the story, so we can all learn from your incident. I fully agree that checklists are important. If your electrical system design assumes that the electrical system will be in a particular configuration for flight, then you need a checklist that ensures this is true. And you need to religiously do every step on that checklist before take-off. It is also useful to have well thought out checklists for engine failure, engine rough running, etc. For example, a well thought rough running engine checklist would include all steps necessary to check voltage on whatever bus(s) your engine needs. One thing that puzzles me about your electrical system design - it seems that your engine needs power from the Essential Bus. But it seems like your active low voltage warning is looking at some other bus. Why not hook the low voltage warning up the the one bus that is really important - i.e. the Essential Bus? Kevin Horton On 3-Jun-09, at 15:53 , Ed Anderson wrote: > It was suggested by one of the aeroelectric list members, Sam > Hoskins, that the following report of an incident I had on a recent > trip be posted to the AeroElectric list for obvious reasons once > you read it. > > I have an all-electric Rv-6A with over 10 years and close to 500 > hours on it. I based the electrical system roughly one of Bobs > excellent designs. It initially had one alternator and two > batteries, but removed the second battery approx 5 years ago but, > I did make one modification to the design that I almost had cause > to regret. > > So needless to say, but I will, responsibility for design and > incident is totally mine. > > But, to get on with the tale > > > One the way to Texas I had an incident that ended up in with me and > aircraft making a 7 mile engine-out glide into Craig Field (Selma, > Alabama). NO! It was not fault of the engine or even the > subsystems. But, the complete answer is not provided until after my > litany of the conditions and symptoms can you figure it out? > > I took off on Thursday (28 May 2009) AM from North Carolina planning > on stopping in Mississippi to join up with two friends. After > spending the night there, we all three would then head for Texas. > But, the weather (as you are aware) has been laying over the > southeast for days with rain and more rain but I launched into it > anyway as past Atlanta, GA things were forecast to improve.. > > Other than dodging lines of clouds and a bit of scud running, but > not much, I landed at Alexandria City to the southwest of Atlanta, > GA to take on fuel. I then climbed back in and fire it up and took > off. > > I noticed that during climb-out the engine would occasionally miss > and thought the fuel might have had a bit of water in it, but was > not really concerned. So I fly on for approx another 45 minutes and > had just passed Selma, Alabama and old Craig Air Force base, and > turned west toward Mississippi, when more symptoms began to occur. > > It started to act like a case of SAG (fouled spark plugs) where the > rpm will drop a bit not dangerous - just nerve racking. But, > shortly things began to go beyond the SAG symptoms, so I though I > might have an injector problem (like one sticking open or not > opening at all). Since our injectors are in pairs, I tried turning > one pair off figuring if things got better, then that pair might > have a bad injector. > > So I turned off one pair and sure enough the symptoms abated a bit > (more on this later) so I figured I had a bad injector in that > pair. To be certain I turned this bad pair back on and turn off > the good pair expecting the symptoms to really get bad as I would > now be running on only the bad pair much to my surprise when I > turned off the good pair the symptoms also abated. So that > indicated it was not an injector problem but what? > > About this time, I decided to turn the aircraft back around toward > Craig Field and dodging clouds headed back with the engine > progressively getting worst. It appeared to be a fuel problem (and > while that is ultimately the subsystem affected - it was not the > root cause). The fuel pressure was ranging from zero to 80 psi, > other electrical things were also misbehaving. I check the > voltmeter thinking perhaps the alternator had died but it showed > 14 volts. So back to the fuel system. > > Finally, the engine just stops with the prop standing still - like > a hood ornament, Im at around 4500-5000 MSL at this point having > lost some altitude dodging a cloud (good old GPS just kept pointing > to Craig Field). At that time I am 6-7 miles out from Craig Field > at 4500 msl with a stopped prop, a crippled seat cushion and a dry > mouth. Yes, Ive been there before, but I dont think you ever get > use to it. I recalled thinking things just cant get > worst when they very shortly and suddenly - did. > > I keyed the radio and made a call to Craig Field at 4 miles on the > GPS but before I could get their reply, I heard a CLANK (without > the engine running you can hear things like that) like a relay > springing open (it was) and the entire panel goes dead!!!! No > radio, no engine instruments, not even a stinking LED was lit only > the battery powered GPS. Can you spell total electrical failure? > Talk about a lonely feeling amazing how comforting having lights > on and radio you could almost convince yourself this was just a > practice engine-out landing, but not when the panel goes dark. No > engine gauges, no radio, nada! > > Well not being one inclined to panic (but I seriously considered it > for a moment {:>)), I continued toward Craig field I mean like > there were lots of other alternatives. Well Once again I found > myself in the fortunate position of being too high, too much > altitude. So I put in 40 degs of flaps to steepen my rate of > descent. But, then I decided this time that rather than do the 360 I > had done on a previous Incident to lose excessive altitude, I > would try to glide - a more or less - regular traffic pattern. > > However, I neglected to remember to retract the flaps. So I found > myself on the downwind around mid-field at pattern altitude (which > felt normal) until I suddenly realized that you CAN NOT maintain > that pattern altitude without an engine!!! (and particularly with > 40 deg of flaps deployed flaps and trim are manual) Duh! > > I knew I could never make it to the far end of the runway before > turning base (toward the runway) and I was losing altitude at the > rate of 400-500 fpm, so I started my turn immediately. To make > matters a bit worst - I had been paralleling the runway on the > downwind leg a bit too close in must have been the comforting > feeling of being close to safety. This position naturally required > a tighter turn and as I turned I saw I was likely to overshoot the > runway and land in the grass. So I though I need to steepen this > turn further (Yep! COFFIN CORNER was calling), but fortunately > glanced at my airspeed indicator - to see it only registering 80 MPH > and my rate of descent (normally 400-500 feet per minute) up to over > 1000 feet per minute. The seat cushion suddenly vanished from this > universe. > > But the REAL danger in this situation, as you all know, is your > airspeed gets low, you are in a steep bank which greatly raises the > stall speed - meaning at 80 mph you are close to a stall in a steep > turn while your are not in straight and level. So I immediately > straighten out of the turn the little voice saying better to land > in the grass than get their concrete runway all messed up. So the > immediate danger of a stall was adverted, but I was still pointed > toward the ground with a sink rate twice as high as normal (and Ive > manage a few hard landings even with a normal sink rate). > Fortunately, the runway was now under my nose rather than grass. > > The hardest thing to do when you are sinking at a 1000 fpm a couple > hundred feet above the ground (with your nose already pointed at the > ground) is to push the stick forward steeping the dive even more. > But, I manage to do that and picked enough air speed and energy to > flair to a nice touch down not even a bump. Ive always been > amazed at what total concentration does to improve you landing {:>). > > Rolled to the end of the runway and had energy to roll off onto the > taxiway. Got out, check under the aircraft for any evidence of > leaks and started pulling the aircraft toward the far off hangar > which had an airplane parked in front of it. A nice looking young > woman comes riding a bicycle out to meet me. Hopped off and holding > out her hand said Hi Im Angie, looks like well be spending time > together so things were starting to look up {:>) > > So pulled the aircraft in to the hangar where the mechanic came over > and ask what the problem was. Well, I looked at the volt meter and > it said the battery was dead. Mechanic put on a battery charger and > announced Yep! The battery is dead. So we both concluded that the > alternator must have failed and not being able to replenish the > drain on the battery by all the electrical systems such as fuel > pumps, injectors, ignition coils, etc had drained the battery. > > However, there were a few problems with the analysis of a failed > alternator. First, the low voltage warning light never came on to > warn of an alternator problem, 2nd I never notice the voltmeter > showing anything other than what it should for alternator voltage > like around 14 volts. While checking the voltage after the Mechanic > had charged the battery, I noticed down below that the essential > bus switch was in the battery rather than the alternator position, > so flicked it back to the alternator position figuring I must have > accidentally kicked it while getting to some stuff in the baggage > compartment of my RV-6A. > > It was getting late and being a bit tired not to mention stressed, I > needed to get a rental car and a motel for the night. Did that, eat > dinner and went to bed after sitting down and drawing out a problem > tree with the entire major elements of the electrical system. > > So next morning I show up at the hangar early and met Ben, the > mechanic, the battery had received a charge of only 45 minutes the > evening before, So I suggested we charged it for another hour and > try to start the aircraft. Ben suggested a real stress test of the > battery and NOT charge it anymore. Made sense, so we rolled the > aircraft out of the hangar. I hopped in, threw a half dozen > switches and punched the starter button. The engine started on the > first prop blade rotation so the battery was clearly OK. The > engine is humming like a top. So I looked over at the voltmeter > expecting it to show only around 12.8 volts instead of the 14 volts > a functioning alternator would produce. Much to both my and Bens > surprise the alternator voltage read 14 volts. We loaded the > alternator by turning on the both l00 watt landing lights, all fuel > pumps, the pitot heat, etc. The alternator voltage only drops > perhaps 0.4 volts clearly indicating the alternator could carry the > load and was OK. > > So here I am battery is OK, alternator is OK engine is purring > normally, so clearly this was all a figment of my deteriorating > brain cells. I loaded up the aircraft and launched to do a few > circuits of the airport I did so and all was operating normally > and so I radio them I was head onward to Texas. While flying (with > my only functional eyeball on the voltmeter), my mind could not let > go of the problem and finally the light bulb came on. > > The essential bus switch had (for my entire 10 + years of > flying)always been in the alternator position. The purpose of this > switch is, of course, to isolate the battery from the alternator > should the alternator fail - to prevent an alternator problem from > draining the battery. So in event of an alternator problem, you > move the switch from alternator to battery. Its call the essential > bus because you only have the essential things drawing from the > battery so you wont drain it as quickly. The idea is to give you > time (generally around 30 minutes) to find a safe place to land in > case of alternator failure. > > > Well, at some point I had either (not paying attention) turned the > switch to battery thinking I was turning the voltmeter switch to > battery(more on that below) - or accidentally had move the switch > from alternator to battery without noticing it by kicking it, etc. > However, it was sort of protected in its position from accidental > activation. It must have happened during refueling as I got approx > 45 minutes down the road on the battery after take off before > quality battery time started to deteriorate. As the battery voltage > fell due to the load (and no alternator link to replenish it), > electrical things (mainly computers first) started acting up until > they could not longer run the engine. The injectors would not open > fully, etc. Then as the voltage level further decreased, the master > relay which the battery held closed and which connected the (fully > functional) alternator to the rest of the electrical system - opened > up and removed ALL power from the electrical system. So no radio, > no gauges, etc. > > Oh, another little factor that may have contributed, the voltmeter > has a tiny toggle switch by it marked ALT BAT1 BAT2 for checking > alternator battery 1 and battery 2 (which I no longer fly with) > voltages. Down below It a couple of inches and off to the right is > the essential bus normal size toggle switch also marked ALT BAT1 > BAT1. I normally never touch it and dont even think about it. But > I could have reached for the voltmeter toggle thinking to check my > battery voltage (which I do as a regular thing) and perhaps > distracted by something reached a bit further down and instead moved > the essential bus switch from Alternator to Battery causing this > entire event. I know that I did not consciously do it. So it is > either accidental or absence minded activation - either way ends > with the same results {:>) > > > Now it became clear why it didnt matter which pair of fuel > injectors I turned off turning off either pair improved the > situation because it slightly reduced the electrical load by a few > amps and the engine ran slightly better for a few moments. The > same thing had happened when turning off one of the EFI fuel pumps > but what threw me was the alternator voltage continued to be normal > during this. > > After I knew the cause (switch in wrong position), I decided the > problem was fixed so no reason to return to NC, and I just continued > on to Texas. > > I know some of you may think that removing my second battery was a > mistake but, consider this, having another battery could have > meant I would have been much further from a suitable airfield before > they both went south. On the other hand, it might have caused me to > at least think to throw the essential bus switch to the second > battery and have the Light bulb come on. Who really knows. But, I > have in mind a simply addition to my electrical circuit that should > help in the future. > > > I do want to state that this time when the problems started I DID > switch fuel tanks but naturally it had no effect because this time > it turned out, it was not a fuel problem not the root cause at > least. > > So what are the lessons learned: > > Put EVERY critical switch on your before-takeoff Check list > Perhaps put a guard around such critical switches to force > conscious activation > Dont (hard not to) get overly focused on what you think is the > problem consider other possibilities. I thought it was a fuel > problem (I even switched fuel tanks this time) it turned out to be > electrical in its root cause. > While the fuel pressure was jumping all over the place and the > EGT was erratic and engine surging strongly indicating a fuel > problem the ultimate cause was electrical. Once the voltage got > below a certain point the EC2 computer was still trying to pull the > injectors open, but with the voltage so low it could not do it > properly. > When the battery voltage dropped below a certain point, the > master relay released and removed the alternator from the electrical > system and the panel went dark even though the alternator was > still working > Immediately turn to the nearest airfield when serious problems > occur - THEN work on fixing them. I only delayed for perhaps 2-3 > minutes, but that could have made a difference. > Watch out for Coffin Corner turn when turning base to final > airspeed really bleeds off fast with no engine pulling you along > (and especially with flaps deployed!) > IF you change your mind about landing approach type - remember to > reconfigure your aircraft for the last decision I had left my > flaps deployed when I should have remembered to retracted them. Did > that help prevent a Coffin Corner stall and spin or would it have > put me closer to it? > You must increase airspeed over the wing to get the sufficient > energy to over come a high sink rate. Pulling back on the stick > when the ground is staring you in the face is the natural reaction > but, pushing forward to lower the nose is the correct action > providing of course you have sufficient altitude! > Battery life I had a two year old 680 odyssey battery which I > maintain a trickle charge on whenever Im not flying. With two EFI > fuel pumps, boost pump, injectors, coils, EC2 and radio and just > having started the engine before take off this battery lasted 55 > minutes. Well, the last 5 minutes were not quality battery time. > So in my case, 30 minutes appears to be a very realistic battery > life. In fact, had I turned off one EFI pump and the boost pump > would have gained a few more miles. But, if I had recognized the > need to turn them off at that time (I normally turn them off at > cruise altitude), then I would have known how to fix the problem. > Ive decided to add a Schokkty diode between my essential bus and > the alternator so that as long as the alternator is producing > sufficient voltage, then the battery will be getting some charge to > replace the drain. Ive also decided to make that switch position a > check-list item. > > So what it boils down to if I had recognized early on that it was > an electrical problem and not focused so much on the fuel system, I > may have noticed the essential bus switch in the wrong position. > Force yourself to examine other possible causes (easy to say > harder to do). > > NEVER, NEVER forget that flying the airplane is the first and only > priority in this type of situation > > NEVER, NEVER forget that saving your butt is the ultimately end-all > priority. When I decided that landing on the grass was preferable > to putting a hole in their concrete I may have made a life-saving > decision. > > So thats my story and Im sticking to it. > > Fly safe, guys!! > > Ed > Ed Anderson > > ________________________________________________________________________________
Subject: Essential Incident - Almost (Long)
Date: Jun 03, 2009
Sam, its just about on the centerline of the panel but down on the bottom. So its actually outside my line of vision looking straight ahead. My voltmeter and its toggle selector is above it approx 3-4" and slightly to the left of it. Both are within reach without stretching. As I mentioned the essential bus switch has been in the alternator position for the past 10 years of flying and never moved since initial testing back then. Should have had it on my pre-takeoff check list and will. Ed Ed Anderson Rv-6A N494BW Rotary Powered Matthews, NC eanderson(at)carolina.rr.com <http://www.andersonee.com> http://www.andersonee.com <http://www.dmack.net/mazda/index.html> http://www.dmack.net/mazda/index.html http://www.flyrotary.com/ <http://members.cox.net/rogersda/rotary/configs.htm> http://members.cox.net/rogersda/rotary/configs.htm#N494BW http://www.rotaryaviation.com/Rotorhead%20Truth.htm <http://www.dmack.net/mazda/index.html> _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Sam Hoskins Sent: Wednesday, June 03, 2009 4:12 PM Subject: Re: AeroElectric-List: Essential Incident - Almost (Long) Ed - great story. Just out of curiosity, where is the essential bus switch located? Is it plainly in your field of vision or do you have to turn your head to see it? Cockpit ergonomics are a huge challenge. Sam Hoskins www.samhoskins.blogspot.com On Wed, Jun 3, 2009 at 2:53 PM, Ed Anderson wrote: It was suggested by one of the aeroelectric list members, Sam Hoskins, that the following report of an incident I had on a recent trip be posted to the AeroElectric list for obvious reasons - once you read it. I have an all-electric Rv-6A with over 10 years and close to 500 hours on it. I based the electrical system roughly one of Bob's excellent designs. It initially had one alternator and two batteries, but removed the second battery approx 5 years ago - but, I did make one modification to the design that I almost had cause to regret. So needless to say, but I will, responsibility for design and incident is totally mine. But, to get on with the tale One the way to Texas I had an incident that ended up in with me and aircraft making a 7 mile engine-out glide into Craig Field (Selma, Alabama). NO! It was not fault of the engine or even the subsystems. But, the complete answer is not provided until after my litany of the conditions and symptoms - can you figure it out? I took off on Thursday (28 May 2009) AM from North Carolina planning on stopping in Mississippi to join up with two friends. After spending the night there, we all three would then head for Texas. But, the weather (as you are aware) has been laying over the southeast for days with rain and more rain - but I launched into it anyway as past Atlanta, GA things were forecast to improve.. Other than dodging lines of clouds and a bit of scud running, but not much, I landed at Alexandria City to the southwest of Atlanta, GA to take on fuel. I then climbed back in and fire it up and took off. I noticed that during climb-out the engine would occasionally miss and thought the fuel might have had a bit of water in it, but was not really concerned. So I fly on for approx another 45 minutes and had just passed Selma, Alabama and old Craig Air Force base, and turned west toward Mississippi, when more symptoms began to occur. It started to act like a case of SAG (fouled spark plugs) where the rpm will drop a bit - not dangerous - just nerve racking. But, shortly things began to go beyond the SAG symptoms, so I though I might have an injector problem (like one sticking open or not opening at all). Since our injectors are in pairs, I tried turning one pair off figuring if things got better, then that pair might have a bad injector. So I turned off one pair and sure enough the symptoms abated a bit (more on this later) so I figured I had a bad injector in that pair. To be certain I turned this "bad" pair back on and turn off the "good" pair expecting the symptoms to really get bad as I would now be running on only the "bad" pair - much to my surprise when I turned off the "good" pair - the symptoms also abated. So that indicated it was not an injector problem - but what? About this time, I decided to turn the aircraft back around toward Craig Field and dodging clouds headed back with the engine progressively getting worst. It appeared to be a fuel problem (and while that is ultimately the subsystem affected - it was not the root cause). The fuel pressure was ranging from zero to 80 psi, other electrical things were also misbehaving. I check the voltmeter thinking perhaps the alternator had died - but it showed 14 volts. So back to the fuel system. Finally, the engine just stops with the prop standing still - like a hood ornament, I'm at around 4500-5000 MSL at this point having lost some altitude dodging a cloud (good old GPS just kept pointing to Craig Field). At that time I am 6-7 miles out from Craig Field at 4500 msl with a stopped prop, a crippled seat cushion and a dry mouth. Yes, I've been there before, but I don't think you ever get "use" to it. I recalled thinking -". things just can't get worst." when they very shortly and suddenly - did. I keyed the radio and made a call to Craig Field at 4 miles on the GPS but before I could get their reply, I heard a "CLANK" (without the engine running you can hear things like that) like a relay springing open (it was) and the entire panel goes dead!!!! No radio, no engine instruments, not even a stinking LED was lit - only the battery powered GPS. Can you spell "total electrical failure?" Talk about a lonely feeling - amazing how comforting having lights on and radio - you could almost convince yourself this was just a practice engine-out landing, but not when the panel goes dark. No engine gauges, no radio, nada! Well not being one inclined to panic (but I seriously considered it for a moment {:>)), I continued toward Craig field - I mean like there were lots of other alternatives. Well Once again I found myself in the "fortunate position" of being too high, too much altitude. So I put in 40 degs of flaps to steepen my rate of descent. But, then I decided this time that rather than do the 360 I had done on a previous Incident to lose "excessive" altitude, I would try to glide - a more or less - regular traffic pattern. However, I neglected to remember to retract the flaps. So I found myself on the downwind around mid-field at pattern altitude (which felt normal) until I suddenly realized that you CAN NOT maintain that pattern altitude without an engine!!! (and particularly with 40 deg of flaps deployed - flaps and trim are manual) Duh! I knew I could never make it to the far end of the runway before turning base (toward the runway) and I was losing altitude at the rate of 400-500 fpm, so I started my turn immediately. To make matters a bit worst - I had been paralleling the runway on the downwind leg a bit too close in - must have been the comforting feeling of being close to safety. This position naturally required a tighter turn and as I turned I saw I was likely to overshoot the runway and land in the grass. So I though I need to steepen this turn further (Yep! COFFIN CORNER was calling), but fortunately glanced at my airspeed indicator - to see it only registering 80 MPH and my rate of descent (normally 400-500 feet per minute) up to over 1000 feet per minute. The seat cushion suddenly vanished from this universe. But the REAL danger in this situation, as you all know, is your airspeed gets low, you are in a steep bank which greatly raises the stall speed - meaning at 80 mph you are close to a stall in a steep turn while your are not in straight and level. So I immediately straighten out of the turn - the little voice saying "better to land in the grass than get their concrete runway all messed up". So the immediate danger of a stall was adverted, but I was still pointed toward the ground with a sink rate twice as high as normal (and I've manage a few hard landings even with a normal sink rate). Fortunately, the runway was now under my nose rather than grass. The hardest thing to do when you are sinking at a 1000 fpm a couple hundred feet above the ground (with your nose already pointed at the ground) is to push the stick forward steeping the dive even more. But, I manage to do that and picked enough air speed and energy to flair to a nice touch down - not even a bump. I've always been amazed at what total concentration does to improve you landing {:>). Rolled to the end of the runway and had energy to roll off onto the taxiway. Got out, check under the aircraft for any evidence of leaks and started pulling the aircraft toward the far -off - hangar which had an airplane parked in front of it. A nice looking young woman comes riding a bicycle out to meet me. Hopped off and holding out her hand said "Hi I'm Angie, looks like we'll be spending time together" - so things were starting to look up {:>) So pulled the aircraft in to the hangar where the mechanic came over and ask what the problem was. Well, I looked at the volt meter and it said the battery was dead. Mechanic put on a battery charger and announced "Yep! The battery is dead". So we both concluded that the alternator must have failed and not being able to replenish the drain on the battery by all the electrical systems such as fuel pumps, injectors, ignition coils, etc had drained the battery. However, there were a few problems with the analysis of a failed alternator. First, the low voltage warning light never came on to warn of an alternator problem, 2nd I never notice the voltmeter showing anything other than what it should for alternator voltage - like around 14 volts. While checking the voltage after the Mechanic had charged the battery, I noticed down below that the "essential bus" switch was in the battery rather than the alternator position, so flicked it back to the alternator position figuring I must have accidentally kicked it while getting to some stuff in the baggage compartment of my RV-6A. It was getting late and being a bit tired not to mention stressed, I needed to get a rental car and a motel for the night. Did that, eat dinner and went to bed after sitting down and drawing out a problem tree with the entire major elements of the electrical system. So next morning I show up at the hangar early and met Ben, the mechanic, the battery had received a charge of only 45 minutes the evening before, So I suggested we charged it for another hour and try to start the aircraft. Ben suggested a real stress test of the battery and NOT charge it anymore. Made sense, so we rolled the aircraft out of the hangar. I hopped in, threw a half dozen switches and punched the starter button. The engine started on the first prop blade rotation - so the battery was clearly OK. The engine is humming like a top. So I looked over at the voltmeter expecting it to show only around 12.8 volts instead of the 14 volts a functioning alternator would produce. Much to both my and Ben's surprise the alternator voltage read 14 volts. We loaded the alternator by turning on the both l00 watt landing lights, all fuel pumps, the pitot heat, etc. The alternator voltage only drops perhaps 0.4 volts clearly indicating the alternator could carry the load and was OK. So here I am - battery is OK, alternator is OK - engine is purring normally, so clearly this was all a figment of my deteriorating brain cells. I loaded up the aircraft and launched to do a few circuits of the airport - I did so and all was operating normally and so I radio them I was head onward to Texas. While flying (with my only functional eyeball on the voltmeter), my mind could not let go of the problem and finally the light bulb came on. The essential bus switch had (for my entire 10 + years of flying)always been in the alternator position. The purpose of this switch is, of course, to isolate the battery from the alternator should the alternator fail - to prevent an alternator problem from draining the battery. So in event of an alternator problem, you move the switch from alternator to battery. Its call the essential bus because you only have the essential things drawing from the battery so you wont' drain it as quickly. The idea is to give you time (generally around 30 minutes) to find a safe place to land in case of alternator failure. Well, at some point I had either (not paying attention) turned the switch to battery thinking I was turning the voltmeter switch to battery(more on that below) - or accidentally had move the switch from alternator to battery without noticing it by kicking it, etc. However, it was sort of protected in its position from accidental activation. It must have happened during refueling - as I got approx 45 minutes down the road on the battery after take off before quality battery time started to deteriorate. As the battery voltage fell due to the load (and no alternator link to replenish it), electrical things (mainly computers first) started acting up until they could not longer run the engine. The injectors would not open fully, etc. Then as the voltage level further decreased, the master relay which the battery held closed and which connected the (fully functional) alternator to the rest of the electrical system - opened up and removed ALL power from the electrical system. So no radio, no gauges, etc. Oh, another little factor that may have contributed, the voltmeter has a tiny toggle switch by it marked ALT BAT1 BAT2 for checking alternator battery 1 and battery 2 (which I no longer fly with) voltages. Down below It a couple of inches and off to the right is the essential bus normal size toggle switch - also marked ALT BAT1 BAT1. I normally never touch it and don't even think about it. But I could have reached for the voltmeter toggle thinking to check my battery voltage (which I do as a regular thing) and perhaps distracted by something reached a bit further down and instead moved the essential bus switch from Alternator to Battery causing this entire event. I know that I did not consciously do it. So it is either accidental or absence minded activation - either way ends with the same results {:>) Now it became clear why it didn't matter which pair of fuel injectors I turned off - turning off either pair improved the situation because it slightly reduced the electrical load by a few amps - and the engine ran slightly better for a few moments. The same thing had happened when turning off one of the EFI fuel pumps - but what threw me was the alternator voltage continued to be normal during this. After I knew the cause (switch in wrong position), I decided the problem was fixed so no reason to return to NC, and I just continued on to Texas. I know some of you may think that removing my second battery was a mistake - but, consider this, having another battery could have meant I would have been much further from a suitable airfield before they both went south. On the other hand, it might have caused me to at least think to throw the essential bus switch to the second battery and have the Light bulb come on. Who really knows. But, I have in mind a simply addition to my electrical circuit that should help in the future. I do want to state that this time when the problems started I DID switch fuel tanks - but naturally it had no effect because this time it turned out, it was not a fuel problem - not the root cause at least. So what are the lessons learned: 1. Put EVERY critical switch on your before-takeoff Check list 2. Perhaps put a guard around such critical switches to force conscious activation 3. Don't (hard not to) get overly focused on what you think is the problem - consider other possibilities. I thought it was a fuel problem (I even switched fuel tanks this time) - it turned out to be electrical in its root cause. 4. While the fuel pressure was jumping all over the place and the EGT was erratic and engine surging strongly indicating a fuel problem - the ultimate cause was electrical. Once the voltage got below a certain point the EC2 computer was still trying to pull the injectors open, but with the voltage so low it could not do it properly. 5. When the battery voltage dropped below a certain point, the master relay released and removed the alternator from the electrical system and the panel went dark - even though the alternator was still working 6. Immediately turn to the nearest airfield when serious problems occur - THEN work on fixing them. I only delayed for perhaps 2-3 minutes, but that could have made a difference. 7. Watch out for Coffin Corner turn when turning base to final - airspeed really bleeds off fast with no engine pulling you along (and especially with flaps deployed!) 8. IF you change your mind about landing approach type - remember to reconfigure your aircraft for the last decision - I had left my flaps deployed when I should have remembered to retracted them. Did that help prevent a Coffin Corner stall and spin or would it have put me closer to it? 9. You must increase airspeed over the wing to get the sufficient energy to over come a high sink rate. Pulling back on the stick when the ground is staring you in the face is the natural reaction - but, pushing forward to lower the nose is the correct action - providing of course you have sufficient altitude! 10. Battery life - I had a two year old 680 odyssey battery which I maintain a trickle charge on whenever I'm not flying. With two EFI fuel pumps, boost pump, injectors, coils, EC2 and radio and just having started the engine before take off - this battery lasted 55 minutes. Well, the last 5 minutes were not quality battery time. So in my case, 30 minutes appears to be a very realistic battery life. In fact, had I turned off one EFI pump and the boost pump would have gained a few more miles. But, if I had recognized the need to turn them off at that time (I normally turn them off at cruise altitude), then I would have known how to "fix" the problem. 11. I've decided to add a Schokkty diode between my essential bus and the alternator - so that as long as the alternator is producing sufficient voltage, then the battery will be getting some charge to replace the drain. I've also decided to make that switch position a check-list item. So what it boils down to - if I had recognized early on that it was an electrical problem and not focused so much on the fuel system, I may have noticed the essential bus switch in the wrong position. Force yourself to examine other possible causes (easy to say - harder to do). NEVER, NEVER forget that flying the airplane is the first and only priority in this type of situation NEVER, NEVER forget that saving your butt is the ultimately end-all priority. When I decided that landing on the grass was preferable to putting a hole in their concrete - I may have made a life-saving decision. So that's my story and I'm sticking to it. Fly safe, guys!! Ed Ed Anderson Rv-6A N494BW Rotary Powered Matthews, NC eanderson(at)carolina.rr.com <http://www.andersonee.com> http://www.andersonee.com <http://www.dmack.net/mazda/index.html> http://www.dmack.net/mazda/index.html http://www.flyrotary.com/ <http://members.cox.net/rogersda/rotary/configs.htm> http://members.cox.net/rogersda/rotary/configs.htm#N494BW <http://www.dmack.net/mazda/index.html> ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution __________ Information from ESET NOD32 Antivirus, version of virus signature database 3267 (20080714) __________ The message was checked by ESET NOD32 Antivirus. ________________________________________________________________________________
Date: Jun 03, 2009
Thanks, Matt Ed Anderson Rv-6A N494BW Rotary Powered Matthews, NC eanderson(at)carolina.rr.com http://www.andersonee.com http://www.dmack.net/mazda/index.html http://www.flyrotary.com/ http://members.cox.net/rogersda/rotary/configs.htm#N494BW http://www.rotaryaviation.com/Rotorhead%20Truth.htm -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Matt Prather Sent: Wednesday, June 03, 2009 4:40 PM Subject: Re: AeroElectric-List: Essential Incident - Almost (Long) Great writeup Ed. Thanks for sharing it with the list. Regards, Matt- > It was suggested by one of the aeroelectric list members, Sam Hoskins, > that > the following report of an incident I had on a recent trip be posted to > the > AeroElectric list for obvious reasons - once you read it. > > > I have an all-electric Rv-6A with over 10 years and close to 500 hours on > it. I based the electrical system roughly one of Bob's excellent designs. > It initially had one alternator and two batteries, but removed the second > battery approx 5 years ago - but, I did make one modification to the > design > that I almost had cause to regret. > > > So needless to say, but I will, responsibility for design and incident > is > totally mine. > > > But, to get on with the tale > > > One the way to Texas I had an incident that ended up in with me and > aircraft > making a 7 mile engine-out glide into Craig Field (Selma, Alabama). NO! > It > was not fault of the engine or even the subsystems. But, the complete > answer is not provided until after my litany of the conditions and > symptoms > - can you figure it out? > > > I took off on Thursday (28 May 2009) AM from North Carolina planning on > stopping in Mississippi to join up with two friends. After spending the > night there, we all three would then head for Texas. But, the weather (as > you are aware) has been laying over the southeast for days with rain and > more rain - but I launched into it anyway as past Atlanta, GA things were > forecast to improve.. > > > Other than dodging lines of clouds and a bit of scud running, but not > much, > I landed at Alexandria City to the southwest of Atlanta, GA to take on > fuel. > I then climbed back in and fire it up and took off. > > > I noticed that during climb-out the engine would occasionally miss and > thought the fuel might have had a bit of water in it, but was not really > concerned. So I fly on for approx another 45 minutes and had just passed > Selma, Alabama and old Craig Air Force base, and turned west toward > Mississippi, when more symptoms began to occur. > > > It started to act like a case of SAG (fouled spark plugs) where the rpm > will > drop a bit - not dangerous - just nerve racking. But, shortly things > began > to go beyond the SAG symptoms, so I though I might have an injector > problem > (like one sticking open or not opening at all). Since our injectors are > in > pairs, I tried turning one pair off figuring if things got better, then > that pair might have a bad injector. > > > So I turned off one pair and sure enough the symptoms abated a bit (more > on > this later) so I figured I had a bad injector in that pair. To be certain > I > turned this "bad" pair back on and turn off the "good" pair expecting the > symptoms to really get bad as I would now be running on only the "bad" > pair > - much to my surprise when I turned off the "good" pair - the symptoms > also > abated. So that indicated it was not an injector problem - but what? > > > About this time, I decided to turn the aircraft back around toward Craig > Field and dodging clouds headed back with the engine progressively getting > worst. It appeared to be a fuel problem (and while that is ultimately the > subsystem affected - it was not the root cause). The fuel pressure was > ranging from zero to 80 psi, other electrical things were also > misbehaving. > I check the voltmeter thinking perhaps the alternator had died - but it > showed 14 volts. So back to the fuel system. > > > Finally, the engine just stops with the prop standing still - like a > hood > ornament, I'm at around 4500-5000 MSL at this point having lost some > altitude dodging a cloud (good old GPS just kept pointing to Craig Field). > At that time I am 6-7 miles out from Craig Field at 4500 msl with a > stopped > prop, a crippled seat cushion and a dry mouth. Yes, I've been there > before, > but I don't think you ever get "use" to it. I recalled thinking -". > things > just can't get worst." when they very shortly and suddenly - did. > > > I keyed the radio and made a call to Craig Field at 4 miles on the GPS but > before I could get their reply, I heard a "CLANK" (without the engine > running you can hear things like that) like a relay springing open (it > was) > and the entire panel goes dead!!!! No radio, no engine instruments, not > even a stinking LED was lit - only the battery powered GPS. Can you spell > "total electrical failure?" Talk about a lonely feeling - amazing how > comforting having lights on and radio - you could almost convince yourself > this was just a practice engine-out landing, but not when the panel goes > dark. No engine gauges, no radio, nada! > > > Well not being one inclined to panic (but I seriously considered it for a > moment {:>)), I continued toward Craig field - I mean like there were lots > of other alternatives. Well Once again I found myself in the "fortunate > position" of being too high, too much altitude. So I put in 40 degs of > flaps > to steepen my rate of descent. But, then I decided this time that rather > than do the 360 I had done on a previous Incident to lose "excessive" > altitude, I would try to glide - a more or less - regular traffic pattern. > > > However, I neglected to remember to retract the flaps. So I found myself > on > the downwind around mid-field at pattern altitude (which felt normal) > until > I suddenly realized that you CAN NOT maintain that pattern altitude > without > an engine!!! (and particularly with 40 deg of flaps deployed - flaps and > trim are manual) Duh! > > > I knew I could never make it to the far end of the runway before turning > base (toward the runway) and I was losing altitude at the rate of 400-500 > fpm, so I started my turn immediately. To make matters a bit worst - I > had > been paralleling the runway on the downwind leg a bit too close in - must > have been the comforting feeling of being close to safety. This position > naturally required a tighter turn and as I turned I saw I was likely to > overshoot the runway and land in the grass. So I though I need to steepen > this turn further (Yep! COFFIN CORNER was calling), but fortunately > glanced > at my airspeed indicator - to see it only registering 80 MPH and my rate > of > descent (normally 400-500 feet per minute) up to over 1000 feet per > minute. > The seat cushion suddenly vanished from this universe. > > > But the REAL danger in this situation, as you all know, is your airspeed > gets low, you are in a steep bank which greatly raises the stall speed - > meaning at 80 mph you are close to a stall in a steep turn while your are > not in straight and level. So I immediately straighten out of the turn - > the little voice saying "better to land in the grass than get their > concrete > runway all messed up". So the immediate danger of a stall was adverted, > but > I was still pointed toward the ground with a sink rate twice as high as > normal (and I've manage a few hard landings even with a normal sink rate). > Fortunately, the runway was now under my nose rather than grass. > > > The hardest thing to do when you are sinking at a 1000 fpm a couple > hundred > feet above the ground (with your nose already pointed at the ground) is to > push the stick forward steeping the dive even more. But, I manage to do > that and picked enough air speed and energy to flair to a nice touch down > - > not even a bump. I've always been amazed at what total concentration does > to improve you landing {:>). > > > Rolled to the end of the runway and had energy to roll off onto the > taxiway. > Got out, check under the aircraft for any evidence of leaks and started > pulling the aircraft toward the far -off - hangar which had an airplane > parked in front of it. A nice looking young woman comes riding a bicycle > out to meet me. Hopped off and holding out her hand said "Hi I'm Angie, > looks like we'll be spending time together" - so things were starting to > look up {:>) > > > So pulled the aircraft in to the hangar where the mechanic came over and > ask > what the problem was. Well, I looked at the volt meter and it said the > battery was dead. Mechanic put on a battery charger and announced "Yep! > The > battery is dead". So we both concluded that the alternator must have > failed > and not being able to replenish the drain on the battery by all the > electrical systems such as fuel pumps, injectors, ignition coils, etc had > drained the battery. > > > However, there were a few problems with the analysis of a failed > alternator. > First, the low voltage warning light never came on to warn of an > alternator > problem, 2nd I never notice the voltmeter showing anything other than what > it should for alternator voltage - like around 14 volts. While checking > the > voltage after the Mechanic had charged the battery, I noticed down below > that the "essential bus" switch was in the battery rather than the > alternator position, so flicked it back to the alternator position > figuring > I must have accidentally kicked it while getting to some stuff in the > baggage compartment of my RV-6A. > > > It was getting late and being a bit tired not to mention stressed, I > needed > to get a rental car and a motel for the night. Did that, eat dinner and > went to bed after sitting down and drawing out a problem tree with the > entire major elements of the electrical system. > > > So next morning I show up at the hangar early and met Ben, the mechanic, > the > battery had received a charge of only 45 minutes the evening before, So I > suggested we charged it for another hour and try to start the aircraft. > Ben > suggested a real stress test of the battery and NOT charge it anymore. > Made > sense, so we rolled the aircraft out of the hangar. I hopped in, threw a > half dozen switches and punched the starter button. The engine started on > the first prop blade rotation - so the battery was clearly OK. The engine > is > humming like a top. So I looked over at the voltmeter expecting it to > show only around 12.8 volts instead of the 14 volts a functioning > alternator > would produce. Much to both my and Ben's surprise the alternator voltage > read 14 volts. We loaded the alternator by turning on the both l00 watt > landing lights, all fuel pumps, the pitot heat, etc. The alternator > voltage > only drops perhaps 0.4 volts clearly indicating the alternator could carry > the load and was OK. > > > So here I am - battery is OK, alternator is OK - engine is purring > normally, > so clearly this was all a figment of my deteriorating brain cells. I > loaded > up the aircraft and launched to do a few circuits of the airport - I did > so > and all was operating normally and so I radio them I was head onward to > Texas. While flying (with my only functional eyeball on the voltmeter), > my > mind could not let go of the problem and finally the light bulb came on. > > > The essential bus switch had (for my entire 10 + years of flying)always > been > in the alternator position. The purpose of this switch is, of course, to > isolate the battery from the alternator should the alternator fail - to > prevent an alternator problem from draining the battery. So in event of > an > alternator problem, you move the switch from alternator to battery. Its > call the essential bus because you only have the essential things drawing > from the battery so you wont' drain it as quickly. The idea is to give > you > time (generally around 30 minutes) to find a safe place to land in case of > alternator failure. > > > Well, at some point I had either (not paying attention) turned the switch > to > battery thinking I was turning the voltmeter switch to battery(more on > that > below) - or accidentally had move the switch from alternator to battery > without noticing it by kicking it, etc. However, it was sort of protected > in its position from accidental activation. It must have happened during > refueling - as I got approx 45 minutes down the road on the battery after > take off before quality battery time started to deteriorate. As the > battery > voltage fell due to the load (and no alternator link to replenish it), > electrical things (mainly computers first) started acting up until they > could not longer run the engine. The injectors would not open fully, etc. > Then as the voltage level further decreased, the master relay which the > battery held closed and which connected the (fully functional) alternator > to > the rest of the electrical system - opened up and removed ALL power from > the > electrical system. So no radio, no gauges, etc. > > > Oh, another little factor that may have contributed, the voltmeter has a > tiny toggle switch by it marked ALT BAT1 BAT2 for checking alternator > battery 1 and battery 2 (which I no longer fly with) voltages. Down below > It a couple of inches and off to the right is the essential bus normal > size > toggle switch - also marked ALT BAT1 BAT1. I normally never touch it and > don't even think about it. But I could have reached for the voltmeter > toggle thinking to check my battery voltage (which I do as a regular > thing) > and perhaps distracted by something reached a bit further down and instead > moved the essential bus switch from Alternator to Battery causing this > entire event. I know that I did not consciously do it. So it is either > accidental or absence minded activation - either way ends with the same > results {:>) > > > Now it became clear why it didn't matter which pair of fuel injectors I > turned off - turning off either pair improved the situation because it > slightly reduced the electrical load by a few amps - and the engine ran > slightly better for a few moments. The same thing had happened when > turning > off one of the EFI fuel pumps - but what threw me was the alternator > voltage > continued to be normal during this. > > > After I knew the cause (switch in wrong position), I decided the problem > was > fixed so no reason to return to NC, and I just continued on to Texas. > > > I know some of you may think that removing my second battery was a mistake > - > but, consider this, having another battery could have meant I would have > been much further from a suitable airfield before they both went south. > On > the other hand, it might have caused me to at least think to throw the > essential bus switch to the second battery and have the Light bulb come > on. > Who really knows. But, I have in mind a simply addition to my electrical > circuit that should help in the future. > > > I do want to state that this time when the problems started I DID switch > fuel tanks - but naturally it had no effect because this time it turned > out, > it was not a fuel problem - not the root cause at least. > > > So what are the lessons learned: > > > 1. Put EVERY critical switch on your before-takeoff Check list > 2. Perhaps put a guard around such critical switches to force conscious > activation > 3. Don't (hard not to) get overly focused on what you think is the > problem - consider other possibilities. I thought it was a fuel problem > (I > even switched fuel tanks this time) - it turned out to be electrical in > its > root cause. > 4. While the fuel pressure was jumping all over the place and the EGT > was erratic and engine surging strongly indicating a fuel problem - the > ultimate cause was electrical. Once the voltage got below a certain point > the EC2 computer was still trying to pull the injectors open, but with > the > voltage so low it could not do it properly. > 5. When the battery voltage dropped below a certain point, the master > relay released and removed the alternator from the electrical system and > the > panel went dark - even though the alternator was still working > 6. Immediately turn to the nearest airfield when serious problems occur > - THEN work on fixing them. I only delayed for perhaps 2-3 minutes, but > that could have made a difference. > 7. Watch out for Coffin Corner turn when turning base to final - > airspeed really bleeds off fast with no engine pulling you along (and > especially with flaps deployed!) > 8. IF you change your mind about landing approach type - remember to > reconfigure your aircraft for the last decision - I had left my flaps > deployed when I should have remembered to retracted them. Did that help > prevent a Coffin Corner stall and spin or would it have put me closer to > it? > > 9. You must increase airspeed over the wing to get the sufficient > energy to over come a high sink rate. Pulling back on the stick when the > ground is staring you in the face is the natural reaction - but, pushing > forward to lower the nose is the correct action - providing of course you > have sufficient altitude! > 10. Battery life - I had a two year old 680 odyssey battery which I > maintain a trickle charge on whenever I'm not flying. With two EFI fuel > pumps, boost pump, injectors, coils, EC2 and radio and just having started > the engine before take off - this battery lasted 55 minutes. Well, the > last > 5 minutes were not quality battery time. So in my case, 30 minutes > appears > to be a very realistic battery life. In fact, had I turned off one EFI > pump > and the boost pump would have gained a few more miles. But, if I had > recognized the need to turn them off at that time (I normally turn them > off > at cruise altitude), then I would have known how to "fix" the problem. > 11. I've decided to add a Schokkty diode between my essential bus and > the alternator - so that as long as the alternator is producing sufficient > voltage, then the battery will be getting some charge to replace the > drain. > I've also decided to make that switch position a check-list item. > > > So what it boils down to - if I had recognized early on that it was an > electrical problem and not focused so much on the fuel system, I may have > noticed the essential bus switch in the wrong position. Force yourself to > examine other possible causes (easy to say - harder to do). > > > NEVER, NEVER forget that flying the airplane is the first and only > priority > in this type of situation > > > NEVER, NEVER forget that saving your butt is the ultimately end-all > priority. When I decided that landing on the grass was preferable to > putting a hole in their concrete - I may have made a life-saving > decision. > > > So that's my story and I'm sticking to it. > > > Fly safe, guys!! > > > Ed > > Ed Anderson > > Rv-6A N494BW Rotary Powered > > Matthews, NC > > eanderson(at)carolina.rr.com > > <http://www.andersonee.com> http://www.andersonee.com > > <http://www.dmack.net/mazda/index.html> > http://www.dmack.net/mazda/index.html > > http://www.flyrotary.com/ > > <http://members.cox.net/rogersda/rotary/configs.htm> > http://members.cox.net/rogersda/rotary/configs.htm#N494BW > > <http://www.dmack.net/mazda/index.html> > > __________ Information from ESET NOD32 Antivirus, version of virus signature database 3267 (20080714) __________ The message was checked by ESET NOD32 Antivirus. ________________________________________________________________________________
Date: Jun 03, 2009
Thanks Kevin Could not agree with your points more. Yes, I have a pre-takeoff check list which I do use - however, as you point out - if an item is not on it that is critical to safe flight, then it is certainly incomplete. I do not have an in-flight emergency check list, but will certainly give that some serious thought - it would be helpful if it just isolated whether the problem was the fuel system, electrical system and their subsystems. Another good suggestion Ah, good analysis, Kevin. You are correct, my low voltage light is hooked to my alternator circuit and not the essential bus. The logic (if there was any) was that if the alternator started to fail then the warning light would warn me before I started to drain the battery. However, in this case, the alternator was continuing to produce 14 V so naturally the low voltage light never came on. So again, I agree on all the points you made. Just goes to show you how even things designed to make it safer can do the opposite under certain conditions. Clearly, there are a few things that I need to change {:>) Ed Ed Anderson Rv-6A N494BW Rotary Powered Matthews, NC eanderson(at)carolina.rr.com http://www.andersonee.com http://www.dmack.net/mazda/index.html http://www.flyrotary.com/ http://members.cox.net/rogersda/rotary/configs.htm#N494BW http://www.rotaryaviation.com/Rotorhead%20Truth.htm -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Kevin Horton Sent: Wednesday, June 03, 2009 5:02 PM Subject: Re: AeroElectric-List: Essential Incident - Almost (Long) Ed, Congrats for keeping your cool, and flying the airplane to a safe landing. And thanks for sharing the story, so we can all learn from your incident. I fully agree that checklists are important. If your electrical system design assumes that the electrical system will be in a particular configuration for flight, then you need a checklist that ensures this is true. And you need to religiously do every step on that checklist before take-off. It is also useful to have well thought out checklists for engine failure, engine rough running, etc. For example, a well thought rough running engine checklist would include all steps necessary to check voltage on whatever bus(s) your engine needs. One thing that puzzles me about your electrical system design - it seems that your engine needs power from the Essential Bus. But it seems like your active low voltage warning is looking at some other bus. Why not hook the low voltage warning up the the one bus that is really important - i.e. the Essential Bus? Kevin Horton On 3-Jun-09, at 15:53 , Ed Anderson wrote: > It was suggested by one of the aeroelectric list members, Sam > Hoskins, that the following report of an incident I had on a recent > trip be posted to the AeroElectric list for obvious reasons - once > you read it. > > I have an all-electric Rv-6A with over 10 years and close to 500 > hours on it. I based the electrical system roughly one of Bob's > excellent designs. It initially had one alternator and two > batteries, but removed the second battery approx 5 years ago - but, > I did make one modification to the design that I almost had cause > to regret. > > So needless to say, but I will, responsibility for design and > incident is totally mine. > > But, to get on with the tale > > > One the way to Texas I had an incident that ended up in with me and > aircraft making a 7 mile engine-out glide into Craig Field (Selma, > Alabama). NO! It was not fault of the engine or even the > subsystems. But, the complete answer is not provided until after my > litany of the conditions and symptoms - can you figure it out? > > I took off on Thursday (28 May 2009) AM from North Carolina planning > on stopping in Mississippi to join up with two friends. After > spending the night there, we all three would then head for Texas. > But, the weather (as you are aware) has been laying over the > southeast for days with rain and more rain - but I launched into it > anyway as past Atlanta, GA things were forecast to improve.. > > Other than dodging lines of clouds and a bit of scud running, but > not much, I landed at Alexandria City to the southwest of Atlanta, > GA to take on fuel. I then climbed back in and fire it up and took > off. > > I noticed that during climb-out the engine would occasionally miss > and thought the fuel might have had a bit of water in it, but was > not really concerned. So I fly on for approx another 45 minutes and > had just passed Selma, Alabama and old Craig Air Force base, and > turned west toward Mississippi, when more symptoms began to occur. > > It started to act like a case of SAG (fouled spark plugs) where the > rpm will drop a bit - not dangerous - just nerve racking. But, > shortly things began to go beyond the SAG symptoms, so I though I > might have an injector problem (like one sticking open or not > opening at all). Since our injectors are in pairs, I tried turning > one pair off figuring if things got better, then that pair might > have a bad injector. > > So I turned off one pair and sure enough the symptoms abated a bit > (more on this later) so I figured I had a bad injector in that > pair. To be certain I turned this "bad" pair back on and turn off > the "good" pair expecting the symptoms to really get bad as I would > now be running on only the "bad" pair - much to my surprise when I > turned off the "good" pair - the symptoms also abated. So that > indicated it was not an injector problem - but what? > > About this time, I decided to turn the aircraft back around toward > Craig Field and dodging clouds headed back with the engine > progressively getting worst. It appeared to be a fuel problem (and > while that is ultimately the subsystem affected - it was not the > root cause). The fuel pressure was ranging from zero to 80 psi, > other electrical things were also misbehaving. I check the > voltmeter thinking perhaps the alternator had died - but it showed > 14 volts. So back to the fuel system. > > Finally, the engine just stops with the prop standing still - like > a hood ornament, I'm at around 4500-5000 MSL at this point having > lost some altitude dodging a cloud (good old GPS just kept pointing > to Craig Field). At that time I am 6-7 miles out from Craig Field > at 4500 msl with a stopped prop, a crippled seat cushion and a dry > mouth. Yes, I've been there before, but I don't think you ever get > "use" to it. I recalled thinking -". things just can't get > worst." when they very shortly and suddenly - did. > > I keyed the radio and made a call to Craig Field at 4 miles on the > GPS but before I could get their reply, I heard a "CLANK" (without > the engine running you can hear things like that) like a relay > springing open (it was) and the entire panel goes dead!!!! No > radio, no engine instruments, not even a stinking LED was lit - only > the battery powered GPS. Can you spell "total electrical failure?" > Talk about a lonely feeling - amazing how comforting having lights > on and radio - you could almost convince yourself this was just a > practice engine-out landing, but not when the panel goes dark. No > engine gauges, no radio, nada! > > Well not being one inclined to panic (but I seriously considered it > for a moment {:>)), I continued toward Craig field - I mean like > there were lots of other alternatives. Well Once again I found > myself in the "fortunate position" of being too high, too much > altitude. So I put in 40 degs of flaps to steepen my rate of > descent. But, then I decided this time that rather than do the 360 I > had done on a previous Incident to lose "excessive" altitude, I > would try to glide - a more or less - regular traffic pattern. > > However, I neglected to remember to retract the flaps. So I found > myself on the downwind around mid-field at pattern altitude (which > felt normal) until I suddenly realized that you CAN NOT maintain > that pattern altitude without an engine!!! (and particularly with > 40 deg of flaps deployed - flaps and trim are manual) Duh! > > I knew I could never make it to the far end of the runway before > turning base (toward the runway) and I was losing altitude at the > rate of 400-500 fpm, so I started my turn immediately. To make > matters a bit worst - I had been paralleling the runway on the > downwind leg a bit too close in - must have been the comforting > feeling of being close to safety. This position naturally required > a tighter turn and as I turned I saw I was likely to overshoot the > runway and land in the grass. So I though I need to steepen this > turn further (Yep! COFFIN CORNER was calling), but fortunately > glanced at my airspeed indicator - to see it only registering 80 MPH > and my rate of descent (normally 400-500 feet per minute) up to over > 1000 feet per minute. The seat cushion suddenly vanished from this > universe. > > But the REAL danger in this situation, as you all know, is your > airspeed gets low, you are in a steep bank which greatly raises the > stall speed - meaning at 80 mph you are close to a stall in a steep > turn while your are not in straight and level. So I immediately > straighten out of the turn - the little voice saying "better to land > in the grass than get their concrete runway all messed up". So the > immediate danger of a stall was adverted, but I was still pointed > toward the ground with a sink rate twice as high as normal (and I've > manage a few hard landings even with a normal sink rate). > Fortunately, the runway was now under my nose rather than grass. > > The hardest thing to do when you are sinking at a 1000 fpm a couple > hundred feet above the ground (with your nose already pointed at the > ground) is to push the stick forward steeping the dive even more. > But, I manage to do that and picked enough air speed and energy to > flair to a nice touch down - not even a bump. I've always been > amazed at what total concentration does to improve you landing {:>). > > Rolled to the end of the runway and had energy to roll off onto the > taxiway. Got out, check under the aircraft for any evidence of > leaks and started pulling the aircraft toward the far -off - hangar > which had an airplane parked in front of it. A nice looking young > woman comes riding a bicycle out to meet me. Hopped off and holding > out her hand said "Hi I'm Angie, looks like we'll be spending time > together" - so things were starting to look up {:>) > > So pulled the aircraft in to the hangar where the mechanic came over > and ask what the problem was. Well, I looked at the volt meter and > it said the battery was dead. Mechanic put on a battery charger and > announced "Yep! The battery is dead". So we both concluded that the > alternator must have failed and not being able to replenish the > drain on the battery by all the electrical systems such as fuel > pumps, injectors, ignition coils, etc had drained the battery. > > However, there were a few problems with the analysis of a failed > alternator. First, the low voltage warning light never came on to > warn of an alternator problem, 2nd I never notice the voltmeter > showing anything other than what it should for alternator voltage - > like around 14 volts. While checking the voltage after the Mechanic > had charged the battery, I noticed down below that the "essential > bus" switch was in the battery rather than the alternator position, > so flicked it back to the alternator position figuring I must have > accidentally kicked it while getting to some stuff in the baggage > compartment of my RV-6A. > > It was getting late and being a bit tired not to mention stressed, I > needed to get a rental car and a motel for the night. Did that, eat > dinner and went to bed after sitting down and drawing out a problem > tree with the entire major elements of the electrical system. > > So next morning I show up at the hangar early and met Ben, the > mechanic, the battery had received a charge of only 45 minutes the > evening before, So I suggested we charged it for another hour and > try to start the aircraft. Ben suggested a real stress test of the > battery and NOT charge it anymore. Made sense, so we rolled the > aircraft out of the hangar. I hopped in, threw a half dozen > switches and punched the starter button. The engine started on the > first prop blade rotation - so the battery was clearly OK. The > engine is humming like a top. So I looked over at the voltmeter > expecting it to show only around 12.8 volts instead of the 14 volts > a functioning alternator would produce. Much to both my and Ben's > surprise the alternator voltage read 14 volts. We loaded the > alternator by turning on the both l00 watt landing lights, all fuel > pumps, the pitot heat, etc. The alternator voltage only drops > perhaps 0.4 volts clearly indicating the alternator could carry the > load and was OK. > > So here I am - battery is OK, alternator is OK - engine is purring > normally, so clearly this was all a figment of my deteriorating > brain cells. I loaded up the aircraft and launched to do a few > circuits of the airport - I did so and all was operating normally > and so I radio them I was head onward to Texas. While flying (with > my only functional eyeball on the voltmeter), my mind could not let > go of the problem and finally the light bulb came on. > > The essential bus switch had (for my entire 10 + years of > flying)always been in the alternator position. The purpose of this > switch is, of course, to isolate the battery from the alternator > should the alternator fail - to prevent an alternator problem from > draining the battery. So in event of an alternator problem, you > move the switch from alternator to battery. Its call the essential > bus because you only have the essential things drawing from the > battery so you wont' drain it as quickly. The idea is to give you > time (generally around 30 minutes) to find a safe place to land in > case of alternator failure. > > > Well, at some point I had either (not paying attention) turned the > switch to battery thinking I was turning the voltmeter switch to > battery(more on that below) - or accidentally had move the switch > from alternator to battery without noticing it by kicking it, etc. > However, it was sort of protected in its position from accidental > activation. It must have happened during refueling - as I got approx > 45 minutes down the road on the battery after take off before > quality battery time started to deteriorate. As the battery voltage > fell due to the load (and no alternator link to replenish it), > electrical things (mainly computers first) started acting up until > they could not longer run the engine. The injectors would not open > fully, etc. Then as the voltage level further decreased, the master > relay which the battery held closed and which connected the (fully > functional) alternator to the rest of the electrical system - opened > up and removed ALL power from the electrical system. So no radio, > no gauges, etc. > > Oh, another little factor that may have contributed, the voltmeter > has a tiny toggle switch by it marked ALT BAT1 BAT2 for checking > alternator battery 1 and battery 2 (which I no longer fly with) > voltages. Down below It a couple of inches and off to the right is > the essential bus normal size toggle switch - also marked ALT BAT1 > BAT1. I normally never touch it and don't even think about it. But > I could have reached for the voltmeter toggle thinking to check my > battery voltage (which I do as a regular thing) and perhaps > distracted by something reached a bit further down and instead moved > the essential bus switch from Alternator to Battery causing this > entire event. I know that I did not consciously do it. So it is > either accidental or absence minded activation - either way ends > with the same results {:>) > > > Now it became clear why it didn't matter which pair of fuel > injectors I turned off - turning off either pair improved the > situation because it slightly reduced the electrical load by a few > amps - and the engine ran slightly better for a few moments. The > same thing had happened when turning off one of the EFI fuel pumps - > but what threw me was the alternator voltage continued to be normal > during this. > > After I knew the cause (switch in wrong position), I decided the > problem was fixed so no reason to return to NC, and I just continued > on to Texas. > > I know some of you may think that removing my second battery was a > mistake - but, consider this, having another battery could have > meant I would have been much further from a suitable airfield before > they both went south. On the other hand, it might have caused me to > at least think to throw the essential bus switch to the second > battery and have the Light bulb come on. Who really knows. But, I > have in mind a simply addition to my electrical circuit that should > help in the future. > > > I do want to state that this time when the problems started I DID > switch fuel tanks - but naturally it had no effect because this time > it turned out, it was not a fuel problem - not the root cause at > least. > > So what are the lessons learned: > > . Put EVERY critical switch on your before-takeoff Check list > . Perhaps put a guard around such critical switches to force > conscious activation > . Don't (hard not to) get overly focused on what you think is the > problem - consider other possibilities. I thought it was a fuel > problem (I even switched fuel tanks this time) - it turned out to be > electrical in its root cause. > . While the fuel pressure was jumping all over the place and the > EGT was erratic and engine surging strongly indicating a fuel > problem - the ultimate cause was electrical. Once the voltage got > below a certain point the EC2 computer was still trying to pull the > injectors open, but with the voltage so low it could not do it > properly. > . When the battery voltage dropped below a certain point, the > master relay released and removed the alternator from the electrical > system and the panel went dark - even though the alternator was > still working > . Immediately turn to the nearest airfield when serious problems > occur - THEN work on fixing them. I only delayed for perhaps 2-3 > minutes, but that could have made a difference. > . Watch out for Coffin Corner turn when turning base to final - > airspeed really bleeds off fast with no engine pulling you along > (and especially with flaps deployed!) > . IF you change your mind about landing approach type - remember to > reconfigure your aircraft for the last decision - I had left my > flaps deployed when I should have remembered to retracted them. Did > that help prevent a Coffin Corner stall and spin or would it have > put me closer to it? > . You must increase airspeed over the wing to get the sufficient > energy to over come a high sink rate. Pulling back on the stick > when the ground is staring you in the face is the natural reaction - > but, pushing forward to lower the nose is the correct action - > providing of course you have sufficient altitude! > . Battery life - I had a two year old 680 odyssey battery which I > maintain a trickle charge on whenever I'm not flying. With two EFI > fuel pumps, boost pump, injectors, coils, EC2 and radio and just > having started the engine before take off - this battery lasted 55 > minutes. Well, the last 5 minutes were not quality battery time. > So in my case, 30 minutes appears to be a very realistic battery > life. In fact, had I turned off one EFI pump and the boost pump > would have gained a few more miles. But, if I had recognized the > need to turn them off at that time (I normally turn them off at > cruise altitude), then I would have known how to "fix" the problem. > . I've decided to add a Schokkty diode between my essential bus and > the alternator - so that as long as the alternator is producing > sufficient voltage, then the battery will be getting some charge to > replace the drain. I've also decided to make that switch position a > check-list item. > > So what it boils down to - if I had recognized early on that it was > an electrical problem and not focused so much on the fuel system, I > may have noticed the essential bus switch in the wrong position. > Force yourself to examine other possible causes (easy to say - > harder to do). > > NEVER, NEVER forget that flying the airplane is the first and only > priority in this type of situation > > NEVER, NEVER forget that saving your butt is the ultimately end-all > priority. When I decided that landing on the grass was preferable > to putting a hole in their concrete - I may have made a life-saving > decision. > > So that's my story and I'm sticking to it. > > Fly safe, guys!! > > Ed > Ed Anderson > > __________ Information from ESET NOD32 Antivirus, version of virus signature database 3267 (20080714) __________ The message was checked by ESET NOD32 Antivirus. ________________________________________________________________________________
From: "Bill Schlatterer" <billschlatterer(at)sbcglobal.net>
Subject: Essential Incident - Almost (Long)
Date: Jun 03, 2009
Ed, just curious,... How is it that your essential switch disconnects the main bus? Usually, they power the essential bus but you have to shut off the Main bus (I think) manually as a safety feature. When you heard the CLANK which you said was the main bus relay disconnecting, that would have been caused by the absolute drain of the battery. BUT, with the master relay still engaged, the alternator should have still been charging the battery? (even with the E-Bus switch thrown,... I think? If your essential completely reroutes the current from the alternator around the battery, then what takes up the load with the single battery off line? Is that what the second battery (removed) was supposed to do? Just wondering how it works? Thanks Bill S 7a finishing / Z13/8 and other stuff -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ed Anderson Sent: Wednesday, June 03, 2009 7:51 PM Subject: RE: AeroElectric-List: Essential Incident - Almost (Long) --> Thanks Kevin Could not agree with your points more. Yes, I have a pre-takeoff check list which I do use - however, as you point out - if an item is not on it that is critical to safe flight, then it is certainly incomplete. I do not have an in-flight emergency check list, but will certainly give that some serious thought - it would be helpful if it just isolated whether the problem was the fuel system, electrical system and their subsystems. Another good suggestion Ah, good analysis, Kevin. You are correct, my low voltage light is hooked to my alternator circuit and not the essential bus. The logic (if there was any) was that if the alternator started to fail then the warning light would warn me before I started to drain the battery. However, in this case, the alternator was continuing to produce 14 V so naturally the low voltage light never came on. So again, I agree on all the points you made. Just goes to show you how even things designed to make it safer can do the opposite under certain conditions. Clearly, there are a few things that I need to change {:>) Ed Ed Anderson Rv-6A N494BW Rotary Powered Matthews, NC eanderson(at)carolina.rr.com http://www.andersonee.com http://www.dmack.net/mazda/index.html http://www.flyrotary.com/ http://members.cox.net/rogersda/rotary/configs.htm#N494BW http://www.rotaryaviation.com/Rotorhead%20Truth.htm -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Kevin Horton Sent: Wednesday, June 03, 2009 5:02 PM Subject: Re: AeroElectric-List: Essential Incident - Almost (Long) --> Ed, Congrats for keeping your cool, and flying the airplane to a safe landing. And thanks for sharing the story, so we can all learn from your incident. I fully agree that checklists are important. If your electrical system design assumes that the electrical system will be in a particular configuration for flight, then you need a checklist that ensures this is true. And you need to religiously do every step on that checklist before take-off. It is also useful to have well thought out checklists for engine failure, engine rough running, etc. For example, a well thought rough running engine checklist would include all steps necessary to check voltage on whatever bus(s) your engine needs. One thing that puzzles me about your electrical system design - it seems that your engine needs power from the Essential Bus. But it seems like your active low voltage warning is looking at some other bus. Why not hook the low voltage warning up the the one bus that is really important - i.e. the Essential Bus? Kevin Horton On 3-Jun-09, at 15:53 , Ed Anderson wrote: > It was suggested by one of the aeroelectric list members, Sam Hoskins, > that the following report of an incident I had on a recent trip be > posted to the AeroElectric list for obvious reasons - once you read > it. > > I have an all-electric Rv-6A with over 10 years and close to 500 > hours on it. I based the electrical system roughly one of Bob's > excellent designs. It initially had one alternator and two > batteries, but removed the second battery approx 5 years ago - but, I > did make one modification to the design that I almost had cause to > regret. > > So needless to say, but I will, responsibility for design and > incident is totally mine. > > But, to get on with the tale > > > One the way to Texas I had an incident that ended up in with me and > aircraft making a 7 mile engine-out glide into Craig Field (Selma, > Alabama). NO! It was not fault of the engine or even the subsystems. > But, the complete answer is not provided until after my litany of the > conditions and symptoms - can you figure it out? > > I took off on Thursday (28 May 2009) AM from North Carolina planning > on stopping in Mississippi to join up with two friends. After > spending the night there, we all three would then head for Texas. > But, the weather (as you are aware) has been laying over the southeast > for days with rain and more rain - but I launched into it anyway as > past Atlanta, GA things were forecast to improve.. > > Other than dodging lines of clouds and a bit of scud running, but not > much, I landed at Alexandria City to the southwest of Atlanta, GA to > take on fuel. I then climbed back in and fire it up and took off. > > I noticed that during climb-out the engine would occasionally miss and > thought the fuel might have had a bit of water in it, but was not > really concerned. So I fly on for approx another 45 minutes and had > just passed Selma, Alabama and old Craig Air Force base, and turned > west toward Mississippi, when more symptoms began to occur. > > It started to act like a case of SAG (fouled spark plugs) where the > rpm will drop a bit - not dangerous - just nerve racking. But, > shortly things began to go beyond the SAG symptoms, so I though I > might have an injector problem (like one sticking open or not opening > at all). Since our injectors are in pairs, I tried turning one pair > off figuring if things got better, then that pair might have a bad > injector. > > So I turned off one pair and sure enough the symptoms abated a bit > (more on this later) so I figured I had a bad injector in that pair. > To be certain I turned this "bad" pair back on and turn off the "good" > pair expecting the symptoms to really get bad as I would now be > running on only the "bad" pair - much to my surprise when I turned off > the "good" pair - the symptoms also abated. So that indicated it was > not an injector problem - but what? > > About this time, I decided to turn the aircraft back around toward > Craig Field and dodging clouds headed back with the engine > progressively getting worst. It appeared to be a fuel problem (and > while that is ultimately the subsystem affected - it was not the root > cause). The fuel pressure was ranging from zero to 80 psi, other > electrical things were also misbehaving. I check the voltmeter > thinking perhaps the alternator had died - but it showed > 14 volts. So back to the fuel system. > > Finally, the engine just stops with the prop standing still - like a > hood ornament, I'm at around 4500-5000 MSL at this point having lost > some altitude dodging a cloud (good old GPS just kept pointing to > Craig Field). At that time I am 6-7 miles out from Craig Field at > 4500 msl with a stopped prop, a crippled seat cushion and a dry mouth. > Yes, I've been there before, but I don't think you ever get "use" to > it. I recalled thinking -". things just can't get > worst." when they very shortly and suddenly - did. > > I keyed the radio and made a call to Craig Field at 4 miles on the GPS > but before I could get their reply, I heard a "CLANK" (without the > engine running you can hear things like that) like a relay > springing open (it was) and the entire panel goes dead!!!! No > radio, no engine instruments, not even a stinking LED was lit - only > the battery powered GPS. Can you spell "total electrical failure?" > Talk about a lonely feeling - amazing how comforting having lights on > and radio - you could almost convince yourself this was just a > practice engine-out landing, but not when the panel goes dark. No > engine gauges, no radio, nada! > > Well not being one inclined to panic (but I seriously considered it > for a moment {:>)), I continued toward Craig field - I mean like there > were lots of other alternatives. Well Once again I found myself in > the "fortunate position" of being too high, too much altitude. So I > put in 40 degs of flaps to steepen my rate of descent. But, then I > decided this time that rather than do the 360 I had done on a previous > Incident to lose "excessive" altitude, I would try to glide - a more > or less - regular traffic pattern. > > However, I neglected to remember to retract the flaps. So I found > myself on the downwind around mid-field at pattern altitude (which > felt normal) until I suddenly realized that you CAN NOT maintain that > pattern altitude without an engine!!! (and particularly with 40 deg > of flaps deployed - flaps and trim are manual) Duh! > > I knew I could never make it to the far end of the runway before > turning base (toward the runway) and I was losing altitude at the > rate of 400-500 fpm, so I started my turn immediately. To make > matters a bit worst - I had been paralleling the runway on the > downwind leg a bit too close in - must have been the comforting > feeling of being close to safety. This position naturally required a > tighter turn and as I turned I saw I was likely to overshoot the > runway and land in the grass. So I though I need to steepen this turn > further (Yep! COFFIN CORNER was calling), but fortunately glanced at > my airspeed indicator - to see it only registering 80 MPH and my rate > of descent (normally 400-500 feet per minute) up to over 1000 feet per > minute. The seat cushion suddenly vanished from this universe. > > But the REAL danger in this situation, as you all know, is your > airspeed gets low, you are in a steep bank which greatly raises the > stall speed - meaning at 80 mph you are close to a stall in a steep > turn while your are not in straight and level. So I immediately > straighten out of the turn - the little voice saying "better to land > in the grass than get their concrete runway all messed up". So the > immediate danger of a stall was adverted, but I was still pointed > toward the ground with a sink rate twice as high as normal (and I've > manage a few hard landings even with a normal sink rate). > Fortunately, the runway was now under my nose rather than grass. > > The hardest thing to do when you are sinking at a 1000 fpm a couple > hundred feet above the ground (with your nose already pointed at the > ground) is to push the stick forward steeping the dive even more. > But, I manage to do that and picked enough air speed and energy to > flair to a nice touch down - not even a bump. I've always been amazed > at what total concentration does to improve you landing {:>). > > Rolled to the end of the runway and had energy to roll off onto the > taxiway. Got out, check under the aircraft for any evidence of > leaks and started pulling the aircraft toward the far -off - hangar > which had an airplane parked in front of it. A nice looking young > woman comes riding a bicycle out to meet me. Hopped off and holding > out her hand said "Hi I'm Angie, looks like we'll be spending time > together" - so things were starting to look up {:>) > > So pulled the aircraft in to the hangar where the mechanic came over > and ask what the problem was. Well, I looked at the volt meter and it > said the battery was dead. Mechanic put on a battery charger and > announced "Yep! The battery is dead". So we both concluded that the > alternator must have failed and not being able to replenish the drain > on the battery by all the electrical systems such as fuel pumps, > injectors, ignition coils, etc had drained the battery. > > However, there were a few problems with the analysis of a failed > alternator. First, the low voltage warning light never came on to > warn of an alternator problem, 2nd I never notice the voltmeter > showing anything other than what it should for alternator voltage - > like around 14 volts. While checking the voltage after the Mechanic > had charged the battery, I noticed down below that the "essential bus" > switch was in the battery rather than the alternator position, so > flicked it back to the alternator position figuring I must have > accidentally kicked it while getting to some stuff in the baggage > compartment of my RV-6A. > > It was getting late and being a bit tired not to mention stressed, I > needed to get a rental car and a motel for the night. Did that, eat > dinner and went to bed after sitting down and drawing out a problem > tree with the entire major elements of the electrical system. > > So next morning I show up at the hangar early and met Ben, the > mechanic, the battery had received a charge of only 45 minutes the > evening before, So I suggested we charged it for another hour and try > to start the aircraft. Ben suggested a real stress test of the > battery and NOT charge it anymore. Made sense, so we rolled the > aircraft out of the hangar. I hopped in, threw a half dozen switches > and punched the starter button. The engine started on the first prop > blade rotation - so the battery was clearly OK. The > engine is humming like a top. So I looked over at the voltmeter > expecting it to show only around 12.8 volts instead of the 14 volts a > functioning alternator would produce. Much to both my and Ben's > surprise the alternator voltage read 14 volts. We loaded the > alternator by turning on the both l00 watt landing lights, all fuel > pumps, the pitot heat, etc. The alternator voltage only drops perhaps > 0.4 volts clearly indicating the alternator could carry the load and > was OK. > > So here I am - battery is OK, alternator is OK - engine is purring > normally, so clearly this was all a figment of my deteriorating brain > cells. I loaded up the aircraft and launched to do a few circuits of > the airport - I did so and all was operating normally and so I radio > them I was head onward to Texas. While flying (with my only > functional eyeball on the voltmeter), my mind could not let go of the > problem and finally the light bulb came on. > > The essential bus switch had (for my entire 10 + years of > flying)always been in the alternator position. The purpose of this > switch is, of course, to isolate the battery from the alternator > should the alternator fail - to prevent an alternator problem from > draining the battery. So in event of an alternator problem, you move > the switch from alternator to battery. Its call the essential bus > because you only have the essential things drawing from the battery so > you wont' drain it as quickly. The idea is to give you time > (generally around 30 minutes) to find a safe place to land in case of > alternator failure. > > > Well, at some point I had either (not paying attention) turned the > switch to battery thinking I was turning the voltmeter switch to > battery(more on that below) - or accidentally had move the switch > from alternator to battery without noticing it by kicking it, etc. > However, it was sort of protected in its position from accidental > activation. It must have happened during refueling - as I got approx > 45 minutes down the road on the battery after take off before quality > battery time started to deteriorate. As the battery voltage fell due > to the load (and no alternator link to replenish it), electrical > things (mainly computers first) started acting up until they could not > longer run the engine. The injectors would not open fully, etc. Then > as the voltage level further decreased, the master relay which the > battery held closed and which connected the (fully > functional) alternator to the rest of the electrical system - opened > up and removed ALL power from the electrical system. So no radio, no > gauges, etc. > > Oh, another little factor that may have contributed, the voltmeter > has a tiny toggle switch by it marked ALT BAT1 BAT2 for checking > alternator battery 1 and battery 2 (which I no longer fly with) > voltages. Down below It a couple of inches and off to the right is > the essential bus normal size toggle switch - also marked ALT BAT1 > BAT1. I normally never touch it and don't even think about it. But I > could have reached for the voltmeter toggle thinking to check my > battery voltage (which I do as a regular thing) and perhaps distracted > by something reached a bit further down and instead moved the > essential bus switch from Alternator to Battery causing this entire > event. I know that I did not consciously do it. So it is either > accidental or absence minded activation - either way ends with the > same results {:>) > > > Now it became clear why it didn't matter which pair of fuel injectors > I turned off - turning off either pair improved the situation because > it slightly reduced the electrical load by a few amps - and the engine > ran slightly better for a few moments. The same thing had happened > when turning off one of the EFI fuel pumps - but what threw me was the > alternator voltage continued to be normal during this. > > After I knew the cause (switch in wrong position), I decided the > problem was fixed so no reason to return to NC, and I just continued > on to Texas. > > I know some of you may think that removing my second battery was a > mistake - but, consider this, having another battery could have meant > I would have been much further from a suitable airfield before they > both went south. On the other hand, it might have caused me to at > least think to throw the essential bus switch to the second battery > and have the Light bulb come on. Who really knows. But, I have in > mind a simply addition to my electrical circuit that should help in > the future. > > > I do want to state that this time when the problems started I DID > switch fuel tanks - but naturally it had no effect because this time > it turned out, it was not a fuel problem - not the root cause at > least. > > So what are the lessons learned: > > . Put EVERY critical switch on your before-takeoff Check list > . Perhaps put a guard around such critical switches to force > conscious activation > . Don't (hard not to) get overly focused on what you think is the > problem - consider other possibilities. I thought it was a fuel > problem (I even switched fuel tanks this time) - it turned out to be > electrical in its root cause. > . While the fuel pressure was jumping all over the place and the EGT > was erratic and engine surging strongly indicating a fuel problem - > the ultimate cause was electrical. Once the voltage got below a > certain point the EC2 computer was still trying to pull the injectors > open, but with the voltage so low it could not do it properly. > . When the battery voltage dropped below a certain point, the master > relay released and removed the alternator from the electrical system > and the panel went dark - even though the alternator was still working > . Immediately turn to the nearest airfield when serious problems > occur - THEN work on fixing them. I only delayed for perhaps 2-3 > minutes, but that could have made a difference. > . Watch out for Coffin Corner turn when turning base to final - > airspeed really bleeds off fast with no engine pulling you along (and > especially with flaps deployed!) > . IF you change your mind about landing approach type - remember to > reconfigure your aircraft for the last decision - I had left my flaps > deployed when I should have remembered to retracted them. Did that > help prevent a Coffin Corner stall and spin or would it have put me > closer to it? > . You must increase airspeed over the wing to get the sufficient > energy to over come a high sink rate. Pulling back on the stick when > the ground is staring you in the face is the natural reaction - but, > pushing forward to lower the nose is the correct action - providing of > course you have sufficient altitude! > . Battery life - I had a two year old 680 odyssey battery which I > maintain a trickle charge on whenever I'm not flying. With two EFI > fuel pumps, boost pump, injectors, coils, EC2 and radio and just > having started the engine before take off - this battery lasted 55 > minutes. Well, the last 5 minutes were not quality battery time. > So in my case, 30 minutes appears to be a very realistic battery life. > In fact, had I turned off one EFI pump and the boost pump would have > gained a few more miles. But, if I had recognized the need to turn > them off at that time (I normally turn them off at cruise altitude), > then I would have known how to "fix" the problem. > . I've decided to add a Schokkty diode between my essential bus and > the alternator - so that as long as the alternator is producing > sufficient voltage, then the battery will be getting some charge to > replace the drain. I've also decided to make that switch position a > check-list item. > > So what it boils down to - if I had recognized early on that it was > an electrical problem and not focused so much on the fuel system, I > may have noticed the essential bus switch in the wrong position. > Force yourself to examine other possible causes (easy to say - harder > to do). > > NEVER, NEVER forget that flying the airplane is the first and only > priority in this type of situation > > NEVER, NEVER forget that saving your butt is the ultimately end-all > priority. When I decided that landing on the grass was preferable to > putting a hole in their concrete - I may have made a life-saving > decision. > > So that's my story and I'm sticking to it. > > Fly safe, guys!! > > Ed > Ed Anderson > > __________ Information from ESET NOD32 Antivirus, version of virus signature database 3267 (20080714) __________ The message was checked by ESET NOD32 Antivirus. ________________________________________________________________________________
From: Etienne Phillips <etienne.phillips(at)gmail.com>
Subject: Re: Essential Incident - Almost (Long)
Date: Jun 04, 2009
Hi Ed Aren't you glad you weren't flying at night! :-) A diagram of your electrical system as it was would help us understand what you did, and why its design caused the failure... Of particular interest is why switching on the e-bus disconnected the alternator. I also can't seem to make out why when the main bus still had power from the alternator, the contactor died when the e-bus voltage dropped. It may prompt Bob to suggest a better solution to what you're planning :-D Not pointing fingers here, I just can't visualise how it's all hooked up! Thanks Etienne On 03 Jun 2009, at 9:53 PM, Ed Anderson wrote: > It was suggested by one of the aeroelectric list members, Sam > Hoskins, that the following report of an incident I had on a > recent trip be posted to the AeroElectric list for obvious reasons > ' once you read it. > > I have an all-electric Rv-6A with over 10 years and close to 500 > hours on it. I based the electrical system roughly one of Bob=92s > excellent designs. It initially had one alternator and two > batteries, but removed the second battery approx 5 years ago ' but, > I did make one modification to the design that I almost had cause > to regret. > > So needless to say, but I will, responsibility for design and > incident is totally mine. > > But, to get on with the tale > > > One the way to Texas I had an incident that ended up in with me and > aircraft making a 7 mile engine-out glide into Craig Field (Selma, > Alabama). NO! It was not fault of the engine or even the > subsystems. But, the complete answer is not provided until after > my litany of the conditions and symptoms ' can you figure it out? > > > Fly safe, guys!! > > Ed ________________________________________________________________________________
Subject: noisy tach signal
Date: Jun 03, 2009
I'm having a lot of trouble getting a good tach reading on my IK-2000 engine monitor using a Hall effect sensor on a Slick mag and am looking for suggestions on what to try next. I've tried multiple different wiring routings and tried 0.1 uF capacitor between signal lead and ground as well as between +5V power lead and ground, with no success (problem actually got worse when I added the caps so I took them back out). History is that I initially had dual P-mag setup with tach sensor reading off right P-mag. Tach worked fine in that configuration. At about 26 hours total time I replaced the left P-mag with an impulse coupled Slick mag, still taking tach signal off right side P-mag. In that configuration I had noise issues causing problems with the tach reading at power settings below about 1800 rpm (engine / prop combo is O-360, fixed pitch Sensenich). The issue only showed up on throttling back when in flight; didn't see it on the ground except after landing when I had the problem in flight. Those tach problems were resolved by tying the Slick mag p-lead up a little further away from the tach sensor leads (although they were already seperated by at least 6 or 8 inches at closest approach). This past weekend I changed out the right side P-mag for non-impulse coupled Slick mag and installed a Hall effect sensor in the mag vent hole for feeding the IK-2000 tach sensor lines. This was the sensor suggested by IK-Technologies. Ground testing shows good tach readings only at rpms above about 1000-1200 rpm but after 10 or 15 minutes of flight time it starts reading low and erratic at power settings below about 2000 rpm, becoming completely unusable at approach and idle power settings. If I secure the right mag at any time (ground or in-flight testing), the tach reading is steady and appears accurate. So the noise is being introduced by the right mag when it is operating, but with the mag not firing, the sensor installed on that mag works great. I am using the factory supplied sensor wiring harness, which uses twisted pair wiring with none of the leads being shielded. I had extra lengths in this harness when I installed it so have the extra length coiled up under the forward top skin. For lack of any other ideas, I'm thinking about removing the factory harness and building a new one using 3-wire shielded cable for the tach sensor lines. Has anybody else on the list run into tach signal noise issues when using standard mags with Hall effect sensor? Any suggestions on what else I can do to fix this? (aside from going to a different sensor type or stand-alone tachometer) Thanks in advance for any suggestions! Chris RV-6A, N731CK, 55 hrs ________________________________________________________________________________
Date: Jun 04, 2009
Subject: Re: Stereo to Mono
bakerocb(at)cox.net wrote: > > 5/30/2009 > > Hello Don, You wrote: "I want to install a plug in my panel to plug my > stereo Walkman into but my intercom (PM1000 II) is mono." > > Here is one way to solve that problem -- > > http://www.radioshack.com/product/index.jsp?productId=2102669 > > This adapter will put the output of a mono jack on your panel into both > sides of your stereo Walkman. > Greetings... I'm a bit confused on this subject after reading this thread and similar threads in other lists. I have the same objective: plug my iPod into my Xcom 760's audio in. The Xcom's documentation says to use a 3.5mm mono jack in combination with a stereo-to-mono adapter plug. My thought was to eliminate the adapter plug by simply jumping the left/right channel pins on the jack itself, and this does indeed give [seemingly] good results with both channels clearly heard. But lately I've read that this may damage the iPod, and I should be using resistors/capacitors and/or the adaptor, as though the adaptor had some components built into it's small, moulded little case. I'm relatively sure that this adaptor plug is doing nothing but physically joining the left and right channels from the stereo plug into a single tip on the mono plug, and is in no way electronically 'magic'. Not wanting to damage my iPod, I'd be interested to know the science behind all the posts saying 'don't do it' (wire the left and right together), use the adaptor plug. Thanks! -- Regards, J. Sonex C-FJNJ +-------------------------------------------------------------+ | J. Davis, M.Sc. | (computer science) | | *NIX consulting, SysAdmin | email: jd at lawsonimaging.ca | +-------------------------------------------------------------+ and now... Deep Thought #39, by Jack Handy Probably the earliest flyswatters were nothing more than some sort of striking surface attached to the end of a long stick. ________________________________________________________________________________
From: Michael W Stewart <mike.stewart(at)us.ibm.com>
Date: Jun 04, 2009
R3JlYXQgR3JlYXQgc3RvcnkgRWQuIFRoYW5rIHlvdSBmb3Igc2hhcmluZy4NCg0KT24gdGhlIGNo ZWNrbGlzdCB0aGluZywgT25lIHRoaW5nIEkgZGlkIHdhcyBzdGFydCB3aXRoIHRoZSBwcmVtaXNl IHRoYXQgYW55DQppZGlvdCBzaG91bGQgYmUgYWJsZSB0byBqdW1wIGluIG15IGFpcnBsYW5lIGFu ZCBmbHkgaXQuIFRoaXMgY2FuIGJlIGEgdGFsbA0Kb3JkZXIgYXMgc29tZSBvZiBteSBmbHlpbmcg YnVkZGllcyBhcmUgZXZlbiBiaWdnZXIgaWRpb3RzIHRoYW4gbWUuDQoNClRvIHRlc3QgbXkgY2hl Y2sgbGlzdHMsIEkgbGV0IHNldmVyYWwgcGlsb3RzIGp1bXAgaW4gbXkgcGxhbmUgYW5kIHRha2Ug aXQNCmZvciBhIHJpZGUuIE5lZWRsZXNzIHRvIHNheSwgbXkgY2hlY2sgbGlzdCwgYW5kIGNvY2tw aXQgbm9tZW5jbGF0dXJlLCB3ZW50DQp0aHJvdWdoIHF1aXRlIGEgZmV3IGFkZGl0aW9ucywgYW5k IHZlcnkgZ29vZCBvbmVzLiBGcm9tIHRoZSBtb21lbnQgdGhleQ0KY2xpbWIgaW4sIHRoZWlyIGZh Y2VzIGNvbnRvcnQgYW5kIHRoZXkgZmlzaCBhbmQgZmluZCwgYXNraW5nIHF1ZXN0aW9ucyB0aGF0 DQpwb2ludGVkIHRvIGlzc3Vlcy4gSW4gdGhlIGhlYXQgb2YgYmF0dGxlLCB5b3UgZG9udCB3YW50 IHRvIGhhdmUgdG8gcmVtZW1iZXINCmhvdyB0aGluZ3Mvc3lzdGVtcyB3b3JrLCB0aGlzIHN3aXRj aCB0byB0aGF0IHBvc2l0aW9ucyBmb3IgdGhpcyB0aGluZyB0bw0KaGFwcGVuIGV0Yy4uIFRyeWlu ZyB0byBtYWtlIHRoZSBhY3Rpdml0aWVzIGlkaW90IHByb29mIGlzIGltcG9ydGFudCB0byBtZSwN CmNhdXNlIEkgY2FuIHR1cm4gaW50byBhIHJlYWwgaWRpb3Qgb2Z0ZW4sIGVzcGVjaWFsbHkgd2hl biB0aGluZ3MgZ28gYXdyeSwNCm15IGlkaW90IGZhY3RvciBpbmNyZWFzZXMgZHJhbWF0aWNhbGx5 LiBJIGhhdmUgaGFkIG1hbnkgb3Bwb3J0dW5pdGllcyB0bw0KcHJvdmUgdGhpcyB0byBteXNlbGYg b3ZlciBteSB0aG91c2FuZHMgb2YgUlYgZmx5aW5nIGhvdXJzLg0KDQpXaGlsZSB0aGlzIHRlY2hu aXF1ZSBtYXkgbm90IGhhdmUgaWRlbnRpZmllZCB0aGlzIGl0ZW0sIGl0IG1pZ2h0IGlkZW50aWZ5 DQpvdGhlcnMuIEV2ZXJ5IHF1ZXN0aW9uIGZyb20gYW5vdGhlciBwaWxvdCB3aG8gaGFzIHRvIGdl dCBpbiBpdCBhbmQgZ2V0IGFpcg0KYm9ybiwgbWVhbnMgc29tZSBjb21wbGV4aXR5IG9yIGFyZWEg b2YgY29uZnVzaW9uIHRoYXQgaXMgYSBjYW5kaWRhdGUgZm9yDQphZGRyZXNzaW5nLg0KDQpBbHNv IHNpbmNlIEkgcmVseSBvbiBteSBlbGVjdHJpY2FsIHN5c3RlbSBoZWF2aWx5KHRvbyBtdWNoIGdl ZSB3aGl6IHN0dWZmKSwNCndoZW4gSW0gemlwcGluZyBhbG9uZyBmcm9tIEEgdG8gQiwgSSBmYWls IHRoaW5ncyBqdXN0IHRvIHZlcmlmeSBleHBlY3RlZA0KYmVoYXZpb3IuIFVzdWFsbHkgaXRzIGp1 c3QgZW50ZXJ0YWlubWVudCBmb3IgbWUgb24gbXkgY3Jvc3MgY291bnRyaWVzLCBidXQNCm1vc3Rs eSBpcyB2ZXJpZmllcyB0aGUgZmFpbCBvdmVycyB3b3JrIGFzIGRlc2lnbmVkLiBUaGlua2luZyBv ZiBmYWlsdXJlDQptb2RlcyBjYW4gb2NjdXB5IHRob3NlIG11bmRhbmUgY3Jvc3MgY291bnRyaWVz IGFzIHdlbGwuDQoNCkp1c3QgYSBmZXcgdGhvdWdodHMgZm9yIHlvdSBhbmQgdGhhbmtzIGZvciB0 aGUgZ3JlYXQgd3JpdGUgdXAgRWQuDQpCZXN0LA0KTWlrZSwNCg0KDQoNCg0KICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgIA0KICBGcm9tOiAgICAgICAiRWQgQW5kZXJzb24iIDxlYW5kZXJzb25AY2Fyb2xpbmEucnIu Y29tPiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgIA0KICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIA0KICBUbzogICAgICAgICA8 YWVyb2VsZWN0cmljLWxpc3RAbWF0cm9uaWNzLmNvbT4gICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg IA0KICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgIA0KICBEYXRlOiAgICAgICAwNi8wMy8yMDA5IDA0OjMwIFBNICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIA0KICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIA0K ICBTdWJqZWN0OiAgICBBZXJvRWxlY3RyaWMtTGlzdDogRXNzZW50aWFsIEluY2lkZW50IC0gQWxt b3N0IChMb25nKSAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgIA0KICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIA0KICBTZW50IGJ5OiAgICBvd25lci1h ZXJvZWxlY3RyaWMtbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbSAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIA0KICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgIA0KDQoNCg0KDQoNCkl0IHdhcyBzdWdnZXN0ZWQgYnkgb25lIG9mIHRoZSBh ZXJvZWxlY3RyaWMgbGlzdCBtZW1iZXJzLCBTYW0gSG9za2lucywNCnRoYXQgdGhlIGZvbGxvd2lu ZyByZXBvcnQgb2YgYW4gaW5jaWRlbnQgSSBoYWQgb24gYSByZWNlbnQgdHJpcCBiZSBwb3N0ZWQN CnRvIHRoZSBBZXJvRWxlY3RyaWMgbGlzdCBmb3Igb2J2aW91cyByZWFzb25zIOKAkyBvbmNlIHlv dSByZWFkIGl0Lg0KDQogSSBoYXZlIGFuIGFsbC1lbGVjdHJpYyBSdi02QSB3aXRoIG92ZXIgMTAg eWVhcnMgYW5kIGNsb3NlIHRvIDUwMCBob3VycyBvbg0KaXQuICBJIGJhc2VkIHRoZSBlbGVjdHJp Y2FsIHN5c3RlbSByb3VnaGx5IG9uZSBvZiBCb2LigJlzIGV4Y2VsbGVudCBkZXNpZ25zLg0KSXQg aW5pdGlhbGx5IGhhZCBvbmUgYWx0ZXJuYXRvciBhbmQgdHdvIGJhdHRlcmllcywgYnV0IHJlbW92 ZWQgdGhlIHNlY29uZA0KYmF0dGVyeSBhcHByb3ggNSB5ZWFycyBhZ28g4oCTIGJ1dCwgSSBkaWQg bWFrZSBvbmUgbW9kaWZpY2F0aW9uIHRvIHRoZQ0KZGVzaWduIHRoYXQgSSBhbG1vc3QgaGFkIGNh dXNlIHRvIHJlZ3JldC4NCg0KIFNvIG5lZWRsZXNzIHRvIHNheSwgYnV0IEkgd2lsbCwgIHJlc3Bv bnNpYmlsaXR5IGZvciBkZXNpZ24gYW5kIGluY2lkZW50IGlzDQp0b3RhbGx5IG1pbmUuDQoNCkJ1 dCwgdG8gZ2V0IG9uIHdpdGggdGhlIHRhbGUNCg0KDQpPbmUgdGhlIHdheSB0byBUZXhhcyBJIGhh ZCBhbiBpbmNpZGVudCB0aGF0IGVuZGVkIHVwIGluIHdpdGggbWUgYW5kDQphaXJjcmFmdCBtYWtp bmcgYSA3IG1pbGUgZW5naW5lLW91dCBnbGlkZSBpbnRvIENyYWlnIEZpZWxkIChTZWxtYSwNCkFs YWJhbWEpLiAgTk8hICBJdCB3YXMgbm90IGZhdWx0IG9mIHRoZSBlbmdpbmUgb3IgZXZlbiB0aGUg c3Vic3lzdGVtcy4NCkJ1dCwgdGhlIGNvbXBsZXRlIGFuc3dlciBpcyBub3QgcHJvdmlkZWQgdW50 aWwgYWZ0ZXIgbXkgbGl0YW55IG9mIHRoZQ0KY29uZGl0aW9ucyBhbmQgc3ltcHRvbXMg4oCTIGNh biB5b3UgZmlndXJlIGl0IG91dD8NCg0KSSB0b29rIG9mZiBvbiBUaHVyc2RheSAoMjggTWF5IDIw MDkpIEFNIGZyb20gTm9ydGggQ2Fyb2xpbmEgcGxhbm5pbmcgb24NCnN0b3BwaW5nIGluIE1pc3Np c3NpcHBpIHRvIGpvaW4gdXAgd2l0aCB0d28gZnJpZW5kcy4gIEFmdGVyIHNwZW5kaW5nIHRoZQ0K bmlnaHQgdGhlcmUsIHdlIGFsbCB0aHJlZSB3b3VsZCB0aGVuIGhlYWQgZm9yIFRleGFzLiAgQnV0 LCB0aGUgd2VhdGhlciAoYXMNCnlvdSBhcmUgYXdhcmUpIGhhcyBiZWVuIGxheWluZyBvdmVyIHRo ZSBzb3V0aGVhc3QgZm9yIGRheXMgd2l0aCByYWluIGFuZA0KbW9yZSByYWluIOKAkyBidXQgSSBs YXVuY2hlZCBpbnRvIGl0IGFueXdheSBhcyBwYXN0IEF0bGFudGEsIEdBIHRoaW5ncyB3ZXJlDQpm b3JlY2FzdCB0byBpbXByb3ZlLi4NCg0KT3RoZXIgdGhhbiBkb2RnaW5nIGxpbmVzIG9mIGNsb3Vk cyBhbmQgYSBiaXQgb2Ygc2N1ZCBydW5uaW5nLCBidXQgbm90IG11Y2gsDQpJIGxhbmRlZCBhdCBB bGV4YW5kcmlhIENpdHkgdG8gdGhlIHNvdXRod2VzdCBvZiBBdGxhbnRhLCBHQSB0byB0YWtlIG9u DQpmdWVsLiAgSSB0aGVuIGNsaW1iZWQgYmFjayBpbiBhbmQgZmlyZSBpdCB1cCBhbmQgdG9vayBv ZmYuDQoNCkkgbm90aWNlZCB0aGF0IGR1cmluZyBjbGltYi1vdXQgdGhlIGVuZ2luZSB3b3VsZCBv Y2Nhc2lvbmFsbHkgbWlzcyBhbmQNCnRob3VnaHQgdGhlIGZ1ZWwgbWlnaHQgaGF2ZSBoYWQgYSBi aXQgb2Ygd2F0ZXIgaW4gaXQsIGJ1dCB3YXMgbm90IHJlYWxseQ0KY29uY2VybmVkLiAgU28gSSBm bHkgb24gZm9yIGFwcHJveCBhbm90aGVyIDQ1IG1pbnV0ZXMgYW5kIGhhZCBqdXN0IHBhc3NlZA0K U2VsbWEsIEFsYWJhbWEgYW5kIG9sZCBDcmFpZyBBaXIgRm9yY2UgYmFzZSwgYW5kIHR1cm5lZCB3 ZXN0IHRvd2FyZA0KTWlzc2lzc2lwcGksIHdoZW4gbW9yZSBzeW1wdG9tcyBiZWdhbiB0byBvY2N1 ci4NCg0KSXQgc3RhcnRlZCB0byBhY3QgbGlrZSBhIGNhc2Ugb2YgU0FHIChmb3VsZWQgc3Bhcmsg cGx1Z3MpIHdoZXJlIHRoZSBycG0NCndpbGwgZHJvcCBhIGJpdCDigJMgbm90IGRhbmdlcm91cyAt IGp1c3QgbmVydmUgcmFja2luZy4gIEJ1dCwgc2hvcnRseSB0aGluZ3MNCmJlZ2FuIHRvIGdvIGJl eW9uZCB0aGUgU0FHIHN5bXB0b21zLCBzbyBJIHRob3VnaCBJIG1pZ2h0IGhhdmUgYW4gaW5qZWN0 b3INCnByb2JsZW0gKGxpa2Ugb25lIHN0aWNraW5nIG9wZW4gb3Igbm90IG9wZW5pbmcgYXQgYWxs KS4gIFNpbmNlIG91cg0KaW5qZWN0b3JzIGFyZSBpbiBwYWlycywgSSB0cmllZCB0dXJuaW5nIG9u ZSBwYWlyIG9mZiAgZmlndXJpbmcgaWYgdGhpbmdzDQpnb3QgYmV0dGVyLCB0aGVuIHRoYXQgcGFp ciBtaWdodCBoYXZlIGEgYmFkIGluamVjdG9yLg0KDQpTbyBJIHR1cm5lZCBvZmYgb25lIHBhaXIg YW5kIHN1cmUgZW5vdWdoIHRoZSBzeW1wdG9tcyBhYmF0ZWQgYSBiaXQgKG1vcmUgb24NCnRoaXMg bGF0ZXIpIHNvIEkgZmlndXJlZCBJIGhhZCBhIGJhZCBpbmplY3RvciBpbiB0aGF0IHBhaXIuICBU byBiZSBjZXJ0YWluDQpJIHR1cm5lZCB0aGlzIOKAnGJhZOKAnSBwYWlyIGJhY2sgb24gYW5kIHR1 cm4gb2ZmIHRoZSDigJxnb29k4oCdIHBhaXIgZXhwZWN0aW5nIHRoZQ0Kc3ltcHRvbXMgdG8gcmVh bGx5IGdldCBiYWQgYXMgSSB3b3VsZCBub3cgYmUgcnVubmluZyBvbiBvbmx5IHRoZSDigJxiYWTi gJ0gcGFpcg0K4oCTIG11Y2ggdG8gbXkgc3VycHJpc2Ugd2hlbiBJIHR1cm5lZCBvZmYgdGhlIOKA nGdvb2TigJ0gcGFpciDigJMgdGhlIHN5bXB0b21zIGFsc28NCmFiYXRlZC4gIFNvIHRoYXQgaW5k aWNhdGVkIGl0IHdhcyBub3QgYW4gaW5qZWN0b3IgcHJvYmxlbSDigJMgYnV0IHdoYXQ/DQoNCkFi b3V0IHRoaXMgdGltZSwgSSBkZWNpZGVkIHRvIHR1cm4gdGhlIGFpcmNyYWZ0IGJhY2sgYXJvdW5k IHRvd2FyZCBDcmFpZw0KRmllbGQgYW5kIGRvZGdpbmcgY2xvdWRzIGhlYWRlZCBiYWNrIHdpdGgg dGhlIGVuZ2luZSBwcm9ncmVzc2l2ZWx5IGdldHRpbmcNCndvcnN0LiBJdCBhcHBlYXJlZCB0byBi ZSBhIGZ1ZWwgcHJvYmxlbSAoYW5kIHdoaWxlIHRoYXQgaXMgdWx0aW1hdGVseSB0aGUNCnN1YnN5 c3RlbSBhZmZlY3RlZCAtIGl0IHdhcyBub3QgdGhlIHJvb3QgY2F1c2UpLiAgVGhlIGZ1ZWwgcHJl c3N1cmUgd2FzDQpyYW5naW5nIGZyb20gemVybyB0byA4MCBwc2ksIG90aGVyIGVsZWN0cmljYWwg dGhpbmdzIHdlcmUgYWxzbyBtaXNiZWhhdmluZy4NCkkgY2hlY2sgdGhlIHZvbHRtZXRlciB0aGlu a2luZyBwZXJoYXBzIHRoZSBhbHRlcm5hdG9yIGhhZCBkaWVkIOKAkyBidXQgaXQNCnNob3dlZCAx NCB2b2x0cy4gIFNvIGJhY2sgdG8gdGhlIGZ1ZWwgc3lzdGVtLg0KDQogIEZpbmFsbHksIHRoZSBl bmdpbmUganVzdCBzdG9wcyB3aXRoIHRoZSBwcm9wIHN0YW5kaW5nIHN0aWxsIC0gbGlrZSBhIGhv b2QNCm9ybmFtZW50LCBJ4oCZbSBhdCBhcm91bmQgNDUwMC01MDAwIE1TTCBhdCB0aGlzIHBvaW50 IGhhdmluZyBsb3N0IHNvbWUNCmFsdGl0dWRlIGRvZGdpbmcgYSBjbG91ZCAoZ29vZCBvbGQgR1BT IGp1c3Qga2VwdCBwb2ludGluZyB0byBDcmFpZyBGaWVsZCkuDQpBdCB0aGF0IHRpbWUgSSBhbSA2 LTcgbWlsZXMgb3V0IGZyb20gQ3JhaWcgRmllbGQgYXQgNDUwMCBtc2wgd2l0aCBhIHN0b3BwZWQN CnByb3AsIGEgY3JpcHBsZWQgc2VhdCBjdXNoaW9uIGFuZCBhIGRyeSBtb3V0aC4gIFllcywgSeKA mXZlIGJlZW4gdGhlcmUNCmJlZm9yZSwgYnV0IEkgZG9u4oCZdCB0aGluayB5b3UgZXZlciBnZXQg 4oCcdXNl4oCdIHRvIGl0LiAgSSByZWNhbGxlZCB0aGlua2luZw0K4oCT4oCc4oCmIHRoaW5ncyBq dXN0IGNhbuKAmXQgZ2V0IHdvcnN04oCm4oCdICAgd2hlbiB0aGV5IHZlcnkgc2hvcnRseSBhbmQg c3VkZGVubHkgLQ0KZGlkLg0KDQpJIGtleWVkIHRoZSByYWRpbyBhbmQgbWFkZSBhIGNhbGwgdG8g Q3JhaWcgRmllbGQgYXQgNCBtaWxlcyBvbiB0aGUgR1BTIGJ1dA0KYmVmb3JlIEkgY291bGQgZ2V0 IHRoZWlyIHJlcGx5LCBJIGhlYXJkIGEg4oCcQ0xBTkvigJ0gKHdpdGhvdXQgdGhlIGVuZ2luZQ0K cnVubmluZyB5b3UgY2FuIGhlYXIgdGhpbmdzIGxpa2UgdGhhdCkgIGxpa2UgYSByZWxheSBzcHJp bmdpbmcgb3BlbiAoaXQNCndhcykgYW5kIHRoZSBlbnRpcmUgcGFuZWwgZ29lcyBkZWFkISEhISAg IE5vIHJhZGlvLCBubyBlbmdpbmUgaW5zdHJ1bWVudHMsDQpub3QgZXZlbiBhIHN0aW5raW5nIExF RCB3YXMgbGl0IOKAkyBvbmx5IHRoZSBiYXR0ZXJ5IHBvd2VyZWQgR1BTLiAgQ2FuIHlvdQ0Kc3Bl bGwg4oCcdG90YWwgZWxlY3RyaWNhbCBmYWlsdXJlP+KAnSAgVGFsayBhYm91dCBhIGxvbmVseSBm ZWVsaW5nIOKAkyBhbWF6aW5nDQpob3cgY29tZm9ydGluZyBoYXZpbmcgbGlnaHRzIG9uIGFuZCBy YWRpbyDigJMgeW91IGNvdWxkIGFsbW9zdCBjb252aW5jZQ0KeW91cnNlbGYgdGhpcyB3YXMganVz dCBhIHByYWN0aWNlIGVuZ2luZS1vdXQgbGFuZGluZywgYnV0IG5vdCB3aGVuIHRoZQ0KcGFuZWwg Z29lcyBkYXJrLiBObyBlbmdpbmUgZ2F1Z2VzLCBubyByYWRpbywgbmFkYSENCg0KV2VsbCBub3Qg YmVpbmcgb25lIGluY2xpbmVkIHRvIHBhbmljIChidXQgSSBzZXJpb3VzbHkgY29uc2lkZXJlZCBp dCBmb3IgYQ0KbW9tZW50IHs6PikpLCBJIGNvbnRpbnVlZCB0b3dhcmQgQ3JhaWcgZmllbGQg4oCT IEkgbWVhbiBsaWtlIHRoZXJlIHdlcmUgbG90cw0Kb2Ygb3RoZXIgYWx0ZXJuYXRpdmVzLiAgV2Vs bCBPbmNlIGFnYWluIEkgZm91bmQgbXlzZWxmIGluIHRoZSDigJxmb3J0dW5hdGUNCnBvc2l0aW9u 4oCdIG9mIGJlaW5nIHRvbyBoaWdoLCB0b28gbXVjaCBhbHRpdHVkZS4gU28gSSBwdXQgaW4gNDAg ZGVncyBvZg0KZmxhcHMgdG8gc3RlZXBlbiBteSByYXRlIG9mIGRlc2NlbnQuIEJ1dCwgdGhlbiBJ IGRlY2lkZWQgdGhpcyB0aW1lIHRoYXQNCnJhdGhlciB0aGFuIGRvIHRoZSAzNjAgSSBoYWQgZG9u ZSBvbiBhIHByZXZpb3VzIEluY2lkZW50IHRvIGxvc2UNCuKAnGV4Y2Vzc2l2ZeKAnSBhbHRpdHVk ZSwgSSB3b3VsZCB0cnkgdG8gZ2xpZGUgLSBhIG1vcmUgb3IgbGVzcyAtIHJlZ3VsYXINCnRyYWZm aWMgcGF0dGVybi4NCg0KSG93ZXZlciwgSSBuZWdsZWN0ZWQgdG8gcmVtZW1iZXIgdG8gcmV0cmFj dCB0aGUgZmxhcHMuICBTbyBJIGZvdW5kIG15c2VsZg0Kb24gdGhlIGRvd253aW5kIGFyb3VuZCBt aWQtZmllbGQgYXQgcGF0dGVybiBhbHRpdHVkZSAod2hpY2ggZmVsdCBub3JtYWwpDQp1bnRpbCBJ IHN1ZGRlbmx5IHJlYWxpemVkIHRoYXQgeW91IENBTiBOT1QgbWFpbnRhaW4gdGhhdCBwYXR0ZXJu IGFsdGl0dWRlDQp3aXRob3V0IGFuIGVuZ2luZSEhISAgKGFuZCBwYXJ0aWN1bGFybHkgd2l0aCA0 MCBkZWcgb2YgZmxhcHMgZGVwbG95ZWQg4oCTDQpmbGFwcyBhbmQgdHJpbSBhcmUgbWFudWFsKSBE dWghDQoNCkkga25ldyBJIGNvdWxkIG5ldmVyIG1ha2UgaXQgdG8gdGhlIGZhciBlbmQgb2YgdGhl IHJ1bndheSBiZWZvcmUgdHVybmluZw0KYmFzZSAodG93YXJkIHRoZSBydW53YXkpIGFuZCBJIHdh cyBsb3NpbmcgYWx0aXR1ZGUgYXQgdGhlIHJhdGUgb2YgNDAwLTUwMA0KZnBtLCBzbyBJIHN0YXJ0 ZWQgbXkgdHVybiBpbW1lZGlhdGVseS4gICBUbyBtYWtlIG1hdHRlcnMgYSBiaXQgd29yc3QgLSBJ DQpoYWQgYmVlbiBwYXJhbGxlbGluZyB0aGUgcnVud2F5IG9uIHRoZSBkb3dud2luZCBsZWcgYSBi aXQgdG9vIGNsb3NlIGluIOKAkw0KbXVzdCBoYXZlIGJlZW4gdGhlIGNvbWZvcnRpbmcgZmVlbGlu ZyBvZiBiZWluZyBjbG9zZSB0byBzYWZldHkuICBUaGlzDQpwb3NpdGlvbiBuYXR1cmFsbHkgcmVx dWlyZWQgYSB0aWdodGVyIHR1cm4gYW5kIGFzIEkgdHVybmVkIEkgc2F3IEkgd2FzDQpsaWtlbHkg dG8gb3ZlcnNob290ICB0aGUgcnVud2F5IGFuZCBsYW5kIGluIHRoZSBncmFzcy4gU28gSSB0aG91 Z2ggSSBuZWVkDQp0byBzdGVlcGVuIHRoaXMgdHVybiBmdXJ0aGVyIChZZXAhICBDT0ZGSU4gQ09S TkVSIHdhcyBjYWxsaW5nKSwgYnV0DQpmb3J0dW5hdGVseSBnbGFuY2VkIGF0IG15IGFpcnNwZWVk IGluZGljYXRvciAtIHRvIHNlZSBpdCBvbmx5IHJlZ2lzdGVyaW5nDQo4MCBNUEggYW5kIG15IHJh dGUgb2YgZGVzY2VudCAobm9ybWFsbHkgNDAwLTUwMCBmZWV0IHBlciBtaW51dGUpIHVwIHRvIG92 ZXINCjEwMDAgZmVldCBwZXIgbWludXRlLiBUaGUgc2VhdCBjdXNoaW9uIHN1ZGRlbmx5IHZhbmlz aGVkIGZyb20gdGhpcw0KdW5pdmVyc2UuDQoNCiAgQnV0IHRoZSBSRUFMIGRhbmdlciBpbiB0aGlz IHNpdHVhdGlvbiwgYXMgeW91IGFsbCBrbm93LCBpcyB5b3VyIGFpcnNwZWVkDQpnZXRzIGxvdywg eW91IGFyZSBpbiBhIHN0ZWVwIGJhbmsgd2hpY2ggZ3JlYXRseSByYWlzZXMgdGhlIHN0YWxsIHNw ZWVkICAtDQptZWFuaW5nIGF0IDgwIG1waCB5b3UgYXJlIGNsb3NlIHRvIGEgc3RhbGwgaW4gYSBz dGVlcCB0dXJuIHdoaWxlIHlvdXIgYXJlDQpub3QgaW4gc3RyYWlnaHQgYW5kIGxldmVsLiAgU28g SSBpbW1lZGlhdGVseSBzdHJhaWdodGVuIG91dCBvZiB0aGUgdHVybiDigJMNCnRoZSBsaXR0bGUg dm9pY2Ugc2F5aW5nIOKAnGJldHRlciB0byBsYW5kIGluIHRoZSBncmFzcyB0aGFuIGdldCB0aGVp cg0KY29uY3JldGUgcnVud2F5IGFsbCBtZXNzZWQgdXDigJ0uICBTbyB0aGUgaW1tZWRpYXRlIGRh bmdlciBvZiBhIHN0YWxsIHdhcw0KYWR2ZXJ0ZWQsIGJ1dCBJIHdhcyBzdGlsbCBwb2ludGVkIHRv d2FyZCB0aGUgZ3JvdW5kIHdpdGggYSBzaW5rIHJhdGUgdHdpY2UNCmFzIGhpZ2ggYXMgbm9ybWFs IChhbmQgSeKAmXZlIG1hbmFnZSBhIGZldyBoYXJkIGxhbmRpbmdzIGV2ZW4gd2l0aCBhIG5vcm1h bA0Kc2luayByYXRlKS4gIEZvcnR1bmF0ZWx5LCB0aGUgcnVud2F5IHdhcyBub3cgdW5kZXIgbXkg bm9zZSByYXRoZXIgdGhhbg0KZ3Jhc3MuDQoNClRoZSBoYXJkZXN0IHRoaW5nIHRvIGRvIHdoZW4g eW91IGFyZSBzaW5raW5nIGF0IGEgMTAwMCBmcG0gYSBjb3VwbGUgaHVuZHJlZA0KZmVldCBhYm92 ZSB0aGUgZ3JvdW5kICh3aXRoIHlvdXIgbm9zZSBhbHJlYWR5IHBvaW50ZWQgYXQgdGhlIGdyb3Vu ZCkgaXMgdG8NCnB1c2ggdGhlIHN0aWNrIGZvcndhcmQgc3RlZXBpbmcgdGhlIGRpdmUgZXZlbiBt b3JlLiAgQnV0LCBJIG1hbmFnZSB0byBkbw0KdGhhdCBhbmQgcGlja2VkIGVub3VnaCBhaXIgc3Bl ZWQgYW5kIGVuZXJneSB0byBmbGFpciB0byBhIG5pY2UgdG91Y2ggZG93biDigJMNCm5vdCBldmVu IGEgYnVtcC4gIEnigJl2ZSBhbHdheXMgYmVlbiBhbWF6ZWQgYXQgd2hhdCB0b3RhbCBjb25jZW50 cmF0aW9uIGRvZXMNCnRvIGltcHJvdmUgeW91IGxhbmRpbmcgezo+KS4NCg0KUm9sbGVkIHRvIHRo ZSBlbmQgb2YgdGhlIHJ1bndheSBhbmQgaGFkIGVuZXJneSB0byByb2xsIG9mZiBvbnRvIHRoZQ0K dGF4aXdheS4gICBHb3Qgb3V0LCBjaGVjayB1bmRlciB0aGUgYWlyY3JhZnQgZm9yIGFueSBldmlk ZW5jZSBvZiBsZWFrcyBhbmQNCnN0YXJ0ZWQgcHVsbGluZyB0aGUgYWlyY3JhZnQgdG93YXJkIHRo ZSBmYXIg4oCTb2ZmIOKAkyBoYW5nYXIgd2hpY2ggaGFkIGFuDQphaXJwbGFuZSBwYXJrZWQgaW4g ZnJvbnQgb2YgaXQuICBBIG5pY2UgbG9va2luZyB5b3VuZyB3b21hbiBjb21lcyByaWRpbmcgYQ0K YmljeWNsZSBvdXQgdG8gbWVldCBtZS4gIEhvcHBlZCBvZmYgYW5kIGhvbGRpbmcgb3V0IGhlciBo YW5kIHNhaWQg4oCcSGkgSeKAmW0NCkFuZ2llLCBsb29rcyBsaWtlIHdl4oCZbGwgYmUgc3BlbmRp bmcgdGltZSB0b2dldGhlcuKAnSDigJMgc28gdGhpbmdzIHdlcmUNCnN0YXJ0aW5nIHRvIGxvb2sg dXAgezo+KQ0KDQpTbyBwdWxsZWQgdGhlIGFpcmNyYWZ0IGluIHRvIHRoZSBoYW5nYXIgd2hlcmUg dGhlIG1lY2hhbmljIGNhbWUgb3ZlciBhbmQNCmFzayB3aGF0IHRoZSBwcm9ibGVtIHdhcy4gIFdl bGwsIEkgbG9va2VkIGF0IHRoZSB2b2x0IG1ldGVyIGFuZCBpdCBzYWlkIHRoZQ0KYmF0dGVyeSB3 YXMgZGVhZC4gTWVjaGFuaWMgcHV0IG9uIGEgYmF0dGVyeSBjaGFyZ2VyIGFuZCBhbm5vdW5jZWQg 4oCcWWVwISBUaGUNCmJhdHRlcnkgaXMgZGVhZOKAnS4gIFNvIHdlIGJvdGggY29uY2x1ZGVkIHRo YXQgdGhlIGFsdGVybmF0b3IgbXVzdCBoYXZlDQpmYWlsZWQgYW5kIG5vdCBiZWluZyBhYmxlIHRv IHJlcGxlbmlzaCB0aGUgZHJhaW4gb24gdGhlIGJhdHRlcnkgYnkgYWxsIHRoZQ0KZWxlY3RyaWNh bCBzeXN0ZW1zIHN1Y2ggYXMgZnVlbCBwdW1wcywgaW5qZWN0b3JzLCBpZ25pdGlvbiBjb2lscywg ZXRjIGhhZA0KZHJhaW5lZCB0aGUgYmF0dGVyeS4NCg0KSG93ZXZlciwgdGhlcmUgd2VyZSBhIGZl dyBwcm9ibGVtcyB3aXRoIHRoZSBhbmFseXNpcyBvZiBhIGZhaWxlZA0KYWx0ZXJuYXRvci4gIEZp cnN0LCB0aGUgbG93IHZvbHRhZ2Ugd2FybmluZyBsaWdodCBuZXZlciBjYW1lIG9uIHRvIHdhcm4g b2YNCmFuIGFsdGVybmF0b3IgcHJvYmxlbSwgMm5kIEkgbmV2ZXIgbm90aWNlIHRoZSB2b2x0bWV0 ZXIgc2hvd2luZyBhbnl0aGluZw0Kb3RoZXIgdGhhbiB3aGF0IGl0IHNob3VsZCBmb3IgYWx0ZXJu YXRvciB2b2x0YWdlIOKAkyBsaWtlIGFyb3VuZCAxNCB2b2x0cy4NCldoaWxlIGNoZWNraW5nIHRo ZSB2b2x0YWdlIGFmdGVyIHRoZSBNZWNoYW5pYyBoYWQgY2hhcmdlZCB0aGUgYmF0dGVyeSwgSQ0K bm90aWNlZCBkb3duIGJlbG93IHRoYXQgdGhlIOKAnGVzc2VudGlhbCBidXPigJ0gc3dpdGNoIHdh cyBpbiB0aGUgYmF0dGVyeQ0KcmF0aGVyIHRoYW4gdGhlIGFsdGVybmF0b3IgcG9zaXRpb24sIHNv IGZsaWNrZWQgaXQgYmFjayB0byB0aGUgYWx0ZXJuYXRvcg0KcG9zaXRpb24gZmlndXJpbmcgSSBt dXN0IGhhdmUgYWNjaWRlbnRhbGx5IGtpY2tlZCBpdCB3aGlsZSBnZXR0aW5nIHRvIHNvbWUNCnN0 dWZmIGluIHRoZSBiYWdnYWdlIGNvbXBhcnRtZW50IG9mIG15IFJWLTZBLg0KDQpJdCB3YXMgZ2V0 dGluZyBsYXRlIGFuZCBiZWluZyBhIGJpdCB0aXJlZCBub3QgdG8gbWVudGlvbiBzdHJlc3NlZCwg SSBuZWVkZWQNCnRvIGdldCBhIHJlbnRhbCBjYXIgYW5kIGEgbW90ZWwgZm9yIHRoZSBuaWdodC4g IERpZCB0aGF0LCBlYXQgZGlubmVyIGFuZA0Kd2VudCB0byBiZWQgYWZ0ZXIgc2l0dGluZyBkb3du IGFuZCBkcmF3aW5nIG91dCBhIHByb2JsZW0gdHJlZSB3aXRoIHRoZQ0KZW50aXJlIG1ham9yIGVs ZW1lbnRzIG9mIHRoZSBlbGVjdHJpY2FsIHN5c3RlbS4NCg0KU28gbmV4dCBtb3JuaW5nIEkgc2hv dyB1cCBhdCB0aGUgaGFuZ2FyIGVhcmx5IGFuZCBtZXQgQmVuLCB0aGUgbWVjaGFuaWMsDQp0aGUg YmF0dGVyeSBoYWQgcmVjZWl2ZWQgYSBjaGFyZ2Ugb2Ygb25seSA0NSBtaW51dGVzIHRoZSBldmVu aW5nIGJlZm9yZSwgU28NCkkgc3VnZ2VzdGVkIHdlIGNoYXJnZWQgaXQgZm9yIGFub3RoZXIgaG91 ciBhbmQgdHJ5IHRvIHN0YXJ0IHRoZSBhaXJjcmFmdC4NCkJlbiBzdWdnZXN0ZWQgYSByZWFsIHN0 cmVzcyB0ZXN0IG9mIHRoZSBiYXR0ZXJ5IGFuZCBOT1QgY2hhcmdlIGl0IGFueW1vcmUuDQpNYWRl IHNlbnNlLCBzbyB3ZSByb2xsZWQgdGhlIGFpcmNyYWZ0IG91dCBvZiB0aGUgaGFuZ2FyLiAgSSBo b3BwZWQgaW4sDQp0aHJldyBhIGhhbGYgZG96ZW4gc3dpdGNoZXMgYW5kIHB1bmNoZWQgdGhlIHN0 YXJ0ZXIgYnV0dG9uLiAgVGhlIGVuZ2luZQ0Kc3RhcnRlZCBvbiB0aGUgZmlyc3QgcHJvcCBibGFk ZSByb3RhdGlvbiDigJMgc28gdGhlIGJhdHRlcnkgd2FzIGNsZWFybHkgT0suDQpUaGUgZW5naW5l IGlzIGh1bW1pbmcgbGlrZSBhIHRvcC4gICAgU28gSSBsb29rZWQgb3ZlciBhdCB0aGUgdm9sdG1l dGVyDQpleHBlY3RpbmcgaXQgdG8gc2hvdyBvbmx5IGFyb3VuZCAxMi44IHZvbHRzIGluc3RlYWQg b2YgdGhlIDE0IHZvbHRzIGENCmZ1bmN0aW9uaW5nIGFsdGVybmF0b3Igd291bGQgcHJvZHVjZS4g IE11Y2ggdG8gYm90aCAgbXkgYW5kIEJlbuKAmXMgc3VycHJpc2UNCnRoZSBhbHRlcm5hdG9yIHZv bHRhZ2UgcmVhZCAxNCB2b2x0cy4gIFdlIGxvYWRlZCB0aGUgYWx0ZXJuYXRvciBieSB0dXJuaW5n DQpvbiB0aGUgYm90aCBsMDAgd2F0dCBsYW5kaW5nIGxpZ2h0cywgYWxsIGZ1ZWwgcHVtcHMsIHRo ZSBwaXRvdCBoZWF0LCBldGMuDQpUaGUgYWx0ZXJuYXRvciB2b2x0YWdlIG9ubHkgZHJvcHMgcGVy aGFwcyAwLjQgdm9sdHMgY2xlYXJseSBpbmRpY2F0aW5nIHRoZQ0KYWx0ZXJuYXRvciBjb3VsZCBj YXJyeSB0aGUgbG9hZCBhbmQgd2FzIE9LLg0KDQpTbyBoZXJlIEkgYW0g4oCTIGJhdHRlcnkgaXMg T0ssIGFsdGVybmF0b3IgaXMgT0sg4oCTIGVuZ2luZSBpcyBwdXJyaW5nDQpub3JtYWxseSwgc28g Y2xlYXJseSB0aGlzIHdhcyBhbGwgYSBmaWdtZW50IG9mIG15IGRldGVyaW9yYXRpbmcgYnJhaW4N CmNlbGxzLiAgSSBsb2FkZWQgdXAgdGhlIGFpcmNyYWZ0IGFuZCBsYXVuY2hlZCB0byBkbyBhIGZl dyBjaXJjdWl0cyBvZiB0aGUNCmFpcnBvcnQg4oCTIEkgZGlkIHNvIGFuZCBhbGwgd2FzIG9wZXJh dGluZyBub3JtYWxseSBhbmQgc28gSSByYWRpbyB0aGVtIEkgd2FzDQpoZWFkIG9ud2FyZCB0byBU ZXhhcy4gIFdoaWxlIGZseWluZyAod2l0aCBteSBvbmx5IGZ1bmN0aW9uYWwgZXllYmFsbCBvbiB0 aGUNCnZvbHRtZXRlciksIG15IG1pbmQgY291bGQgbm90IGxldCBnbyBvZiB0aGUgcHJvYmxlbSBh bmQgZmluYWxseSB0aGUgbGlnaHQNCmJ1bGIgY2FtZSBvbi4NCg0KVGhlIGVzc2VudGlhbCBidXMg c3dpdGNoIGhhZCAoZm9yIG15IGVudGlyZSAxMCArIHllYXJzIG9mIGZseWluZylhbHdheXMNCmJl ZW4gaW4gdGhlIGFsdGVybmF0b3IgcG9zaXRpb24uICBUaGUgcHVycG9zZSBvZiB0aGlzIHN3aXRj aCBpcywgb2YgY291cnNlLA0KdG8gaXNvbGF0ZSB0aGUgYmF0dGVyeSBmcm9tIHRoZSBhbHRlcm5h dG9yIHNob3VsZCB0aGUgYWx0ZXJuYXRvciBmYWlsIC0gdG8NCnByZXZlbnQgYW4gYWx0ZXJuYXRv ciBwcm9ibGVtIGZyb20gZHJhaW5pbmcgdGhlIGJhdHRlcnkuICBTbyBpbiBldmVudCBvZiBhbg0K YWx0ZXJuYXRvciBwcm9ibGVtLCB5b3UgbW92ZSB0aGUgc3dpdGNoIGZyb20gYWx0ZXJuYXRvciB0 byBiYXR0ZXJ5LiAgSXRzDQpjYWxsIHRoZSBlc3NlbnRpYWwgYnVzIGJlY2F1c2UgeW91IG9ubHkg aGF2ZSB0aGUgZXNzZW50aWFsIHRoaW5ncyBkcmF3aW5nDQpmcm9tIHRoZSBiYXR0ZXJ5IHNvIHlv dSB3b2504oCZIGRyYWluIGl0IGFzIHF1aWNrbHkuICBUaGUgaWRlYSBpcyB0byBnaXZlIHlvdQ0K dGltZSAoZ2VuZXJhbGx5IGFyb3VuZCAzMCBtaW51dGVzKSB0byBmaW5kIGEgc2FmZSBwbGFjZSB0 byBsYW5kIGluIGNhc2Ugb2YNCmFsdGVybmF0b3IgZmFpbHVyZS4NCg0KDQpXZWxsLCBhdCBzb21l IHBvaW50IEkgaGFkIGVpdGhlciAobm90IHBheWluZyBhdHRlbnRpb24pIHR1cm5lZCB0aGUgc3dp dGNoDQp0byBiYXR0ZXJ5IHRoaW5raW5nIEkgd2FzIHR1cm5pbmcgdGhlIHZvbHRtZXRlciBzd2l0 Y2ggdG8gYmF0dGVyeShtb3JlIG9uDQp0aGF0IGJlbG93KSAgLSBvciBhY2NpZGVudGFsbHkgaGFk IG1vdmUgdGhlIHN3aXRjaCBmcm9tIGFsdGVybmF0b3IgdG8NCmJhdHRlcnkgd2l0aG91dCBub3Rp Y2luZyBpdCBieSBraWNraW5nIGl0LCBldGMuICBIb3dldmVyLCBpdCB3YXMgc29ydCBvZg0KcHJv dGVjdGVkIGluIGl0cyBwb3NpdGlvbiBmcm9tIGFjY2lkZW50YWwgYWN0aXZhdGlvbi4gSXQgbXVz dCBoYXZlIGhhcHBlbmVkDQpkdXJpbmcgcmVmdWVsaW5nIOKAkyBhcyBJIGdvdCBhcHByb3ggNDUg bWludXRlcyBkb3duIHRoZSByb2FkIG9uIHRoZSBiYXR0ZXJ5DQphZnRlciB0YWtlIG9mZiBiZWZv cmUgcXVhbGl0eSBiYXR0ZXJ5IHRpbWUgc3RhcnRlZCB0byBkZXRlcmlvcmF0ZS4gIEFzIHRoZQ0K YmF0dGVyeSB2b2x0YWdlIGZlbGwgZHVlIHRvIHRoZSBsb2FkIChhbmQgbm8gYWx0ZXJuYXRvciBs aW5rIHRvIHJlcGxlbmlzaA0KaXQpLCBlbGVjdHJpY2FsIHRoaW5ncyAobWFpbmx5IGNvbXB1dGVy cyBmaXJzdCkgc3RhcnRlZCBhY3RpbmcgdXAgdW50aWwNCnRoZXkgY291bGQgbm90IGxvbmdlciBy dW4gdGhlIGVuZ2luZS4gVGhlIGluamVjdG9ycyB3b3VsZCBub3Qgb3BlbiBmdWxseSwNCmV0Yy4g IFRoZW4gYXMgdGhlIHZvbHRhZ2UgbGV2ZWwgZnVydGhlciBkZWNyZWFzZWQsIHRoZSBtYXN0ZXIg cmVsYXkgd2hpY2gNCnRoZSBiYXR0ZXJ5IGhlbGQgY2xvc2VkIGFuZCB3aGljaCBjb25uZWN0ZWQg dGhlIChmdWxseSBmdW5jdGlvbmFsKQ0KYWx0ZXJuYXRvciB0byB0aGUgcmVzdCBvZiB0aGUgZWxl Y3RyaWNhbCBzeXN0ZW0gLSBvcGVuZWQgdXAgYW5kIHJlbW92ZWQgQUxMDQpwb3dlciBmcm9tIHRo ZSBlbGVjdHJpY2FsIHN5c3RlbS4gIFNvIG5vIHJhZGlvLCBubyBnYXVnZXMsIGV0Yy4NCg0KIE9o LCBhbm90aGVyIGxpdHRsZSBmYWN0b3IgdGhhdCBtYXkgaGF2ZSBjb250cmlidXRlZCwgdGhlIHZv bHRtZXRlciBoYXMgYQ0KdGlueSB0b2dnbGUgc3dpdGNoIGJ5IGl0IG1hcmtlZCBBTFQgQkFUMSBC QVQyIGZvciBjaGVja2luZyBhbHRlcm5hdG9yDQpiYXR0ZXJ5IDEgYW5kIGJhdHRlcnkgMiAod2hp Y2ggSSBubyBsb25nZXIgZmx5IHdpdGgpIHZvbHRhZ2VzLiAgRG93biBiZWxvdw0KSXQgYSBjb3Vw bGUgb2YgaW5jaGVzIGFuZCBvZmYgdG8gdGhlIHJpZ2h0IGlzIHRoZSBlc3NlbnRpYWwgYnVzIG5v cm1hbCBzaXplDQp0b2dnbGUgc3dpdGNoIOKAkyBhbHNvIG1hcmtlZCBBTFQgQkFUMSBCQVQxLiAg SSBub3JtYWxseSBuZXZlciB0b3VjaCBpdCBhbmQNCmRvbuKAmXQgZXZlbiB0aGluayBhYm91dCBp dC4gIEJ1dCBJIGNvdWxkIGhhdmUgcmVhY2hlZCBmb3IgdGhlIHZvbHRtZXRlcg0KdG9nZ2xlIHRo aW5raW5nIHRvIGNoZWNrIG15IGJhdHRlcnkgdm9sdGFnZSAod2hpY2ggSSBkbyBhcyBhIHJlZ3Vs YXIgdGhpbmcpDQphbmQgcGVyaGFwcyBkaXN0cmFjdGVkIGJ5IHNvbWV0aGluZyByZWFjaGVkIGEg Yml0IGZ1cnRoZXIgZG93biBhbmQgaW5zdGVhZA0KbW92ZWQgdGhlIGVzc2VudGlhbCBidXMgc3dp dGNoIGZyb20gQWx0ZXJuYXRvciB0byBCYXR0ZXJ5IGNhdXNpbmcgdGhpcw0KZW50aXJlIGV2ZW50 LiAgSSBrbm93IHRoYXQgSSBkaWQgbm90IGNvbnNjaW91c2x5IGRvIGl0LiAgU28gaXQgaXMgZWl0 aGVyDQphY2NpZGVudGFsIG9yIGFic2VuY2UgbWluZGVkIGFjdGl2YXRpb24gLSBlaXRoZXIgd2F5 IGVuZHMgd2l0aCB0aGUgc2FtZQ0KcmVzdWx0cyB7Oj4pDQoNCg0KTm93IGl0IGJlY2FtZSBjbGVh ciB3aHkgaXQgZGlkbuKAmXQgbWF0dGVyIHdoaWNoIHBhaXIgb2YgZnVlbCBpbmplY3RvcnMgSQ0K dHVybmVkIG9mZiDigJMgdHVybmluZyBvZmYgZWl0aGVyIHBhaXIgaW1wcm92ZWQgdGhlIHNpdHVh dGlvbiBiZWNhdXNlIGl0DQpzbGlnaHRseSByZWR1Y2VkIHRoZSBlbGVjdHJpY2FsIGxvYWQgYnkg YSBmZXcgYW1wcyDigJMgYW5kIHRoZSBlbmdpbmUgcmFuDQpzbGlnaHRseSBiZXR0ZXIgZm9yIGEg ZmV3IG1vbWVudHMuICBUaGUgc2FtZSB0aGluZyBoYWQgaGFwcGVuZWQgd2hlbg0KdHVybmluZyBv ZmYgb25lIG9mIHRoZSBFRkkgZnVlbCBwdW1wcyDigJMgYnV0IHdoYXQgdGhyZXcgbWUgd2FzIHRo ZQ0KYWx0ZXJuYXRvciB2b2x0YWdlIGNvbnRpbnVlZCB0byBiZSBub3JtYWwgZHVyaW5nIHRoaXMu DQoNCkFmdGVyIEkga25ldyB0aGUgY2F1c2UgKHN3aXRjaCBpbiB3cm9uZyBwb3NpdGlvbiksIEkg ZGVjaWRlZCB0aGUgcHJvYmxlbQ0Kd2FzIGZpeGVkIHNvIG5vIHJlYXNvbiB0byByZXR1cm4gdG8g TkMsIGFuZCBJIGp1c3QgY29udGludWVkIG9uIHRvIFRleGFzLg0KDQpJIGtub3cgc29tZSBvZiB5 b3UgbWF5IHRoaW5rIHRoYXQgcmVtb3ZpbmcgbXkgc2Vjb25kIGJhdHRlcnkgd2FzIGEgbWlzdGFr ZQ0K4oCTIGJ1dCwgY29uc2lkZXIgdGhpcywgaGF2aW5nIGFub3RoZXIgYmF0dGVyeSBjb3VsZCBo YXZlIG1lYW50IEkgd291bGQgaGF2ZQ0KYmVlbiBtdWNoIGZ1cnRoZXIgZnJvbSBhIHN1aXRhYmxl IGFpcmZpZWxkIGJlZm9yZSB0aGV5IGJvdGggd2VudCBzb3V0aC4gIE9uDQp0aGUgb3RoZXIgaGFu ZCwgaXQgbWlnaHQgaGF2ZSBjYXVzZWQgbWUgdG8gYXQgbGVhc3QgdGhpbmsgdG8gdGhyb3cgdGhl DQplc3NlbnRpYWwgYnVzIHN3aXRjaCB0byB0aGUgc2Vjb25kIGJhdHRlcnkgYW5kIGhhdmUgdGhl IExpZ2h0IGJ1bGIgY29tZSBvbi4NCldobyByZWFsbHkga25vd3MuICBCdXQsIEkgaGF2ZSBpbiBt aW5kIGEgc2ltcGx5IGFkZGl0aW9uIHRvIG15IGVsZWN0cmljYWwNCmNpcmN1aXQgdGhhdCBzaG91 bGQgaGVscCBpbiB0aGUgZnV0dXJlLg0KDQoNCkkgZG8gd2FudCB0byBzdGF0ZSB0aGF0IHRoaXMg dGltZSB3aGVuIHRoZSBwcm9ibGVtcyBzdGFydGVkIEkgRElEIHN3aXRjaA0KZnVlbCB0YW5rcyDi gJMgYnV0IG5hdHVyYWxseSBpdCBoYWQgbm8gZWZmZWN0IGJlY2F1c2UgdGhpcyB0aW1lIGl0IHR1 cm5lZA0Kb3V0LCBpdCB3YXMgbm90IGEgZnVlbCBwcm9ibGVtIOKAkyBub3QgdGhlIHJvb3QgY2F1 c2UgYXQgbGVhc3QuDQoNClNvIHdoYXQgYXJlIHRoZSBsZXNzb25zIGxlYXJuZWQ6DQoNCiAgIDEu IFB1dCBFVkVSWSBjcml0aWNhbCBzd2l0Y2ggb24geW91ciBiZWZvcmUtdGFrZW9mZiBDaGVjayBs aXN0DQogICAyLiBQZXJoYXBzIHB1dCBhIGd1YXJkIGFyb3VuZCBzdWNoIGNyaXRpY2FsIHN3aXRj aGVzIHRvIGZvcmNlIGNvbnNjaW91cw0KICAgICAgYWN0aXZhdGlvbg0KICAgMy4gRG9u4oCZdCAo aGFyZCBub3QgdG8pIGdldCBvdmVybHkgZm9jdXNlZCBvbiB3aGF0IHlvdSB0aGluayBpcyB0aGUN CiAgICAgIHByb2JsZW0g4oCTIGNvbnNpZGVyIG90aGVyIHBvc3NpYmlsaXRpZXMuICBJIHRob3Vn aHQgaXQgd2FzIGEgZnVlbA0KICAgICAgcHJvYmxlbSAoSSBldmVuIHN3aXRjaGVkIGZ1ZWwgdGFu a3MgdGhpcyB0aW1lKSDigJMgaXQgdHVybmVkIG91dCB0byBiZQ0KICAgICAgZWxlY3RyaWNhbCBp biBpdHMgcm9vdCBjYXVzZS4NCiAgIDQuIFdoaWxlIHRoZSBmdWVsIHByZXNzdXJlIHdhcyBqdW1w aW5nIGFsbCBvdmVyIHRoZSBwbGFjZSBhbmQgdGhlIEVHVA0KICAgICAgd2FzIGVycmF0aWMgYW5k IGVuZ2luZSBzdXJnaW5nIHN0cm9uZ2x5IGluZGljYXRpbmcgYSBmdWVsIHByb2JsZW0g4oCTDQog ICAgICB0aGUgdWx0aW1hdGUgY2F1c2Ugd2FzIGVsZWN0cmljYWwuICBPbmNlIHRoZSB2b2x0YWdl IGdvdCBiZWxvdyBhDQogICAgICBjZXJ0YWluIHBvaW50IHRoZSBFQzIgY29tcHV0ZXIgIHdhcyBz dGlsbCB0cnlpbmcgdG8gcHVsbCB0aGUNCiAgICAgIGluamVjdG9ycyBvcGVuLCBidXQgd2l0aCB0 aGUgdm9sdGFnZSBzbyBsb3cgaXQgY291bGQgbm90IGRvIGl0DQogICAgICBwcm9wZXJseS4NCiAg IDUuIFdoZW4gdGhlIGJhdHRlcnkgdm9sdGFnZSBkcm9wcGVkIGJlbG93IGEgY2VydGFpbiBwb2lu dCwgdGhlIG1hc3Rlcg0KICAgICAgcmVsYXkgcmVsZWFzZWQgYW5kIHJlbW92ZWQgdGhlIGFsdGVy bmF0b3IgZnJvbSB0aGUgZWxlY3RyaWNhbCBzeXN0ZW0NCiAgICAgIGFuZCB0aGUgcGFuZWwgd2Vu dCBkYXJrIOKAkyBldmVuIHRob3VnaCB0aGUgYWx0ZXJuYXRvciB3YXMgc3RpbGwNCiAgICAgIHdv cmtpbmcNCiAgIDYuIEltbWVkaWF0ZWx5IHR1cm4gdG8gdGhlIG5lYXJlc3QgYWlyZmllbGQgd2hl biBzZXJpb3VzIHByb2JsZW1zIG9jY3VyDQogICAgICAtIFRIRU4gd29yayBvbiBmaXhpbmcgdGhl bS4gIEkgb25seSBkZWxheWVkIGZvciBwZXJoYXBzIDItMyBtaW51dGVzLA0KICAgICAgYnV0IHRo YXQgY291bGQgaGF2ZSBtYWRlIGEgZGlmZmVyZW5jZS4NCiAgIDcuIFdhdGNoIG91dCBmb3IgQ29m ZmluIENvcm5lciB0dXJuIHdoZW4gdHVybmluZyBiYXNlIHRvIGZpbmFsIOKAkw0KICAgICAgYWly c3BlZWQgcmVhbGx5IGJsZWVkcyBvZmYgZmFzdCB3aXRoIG5vIGVuZ2luZSBwdWxsaW5nIHlvdSBh bG9uZyAoYW5kDQogICAgICBlc3BlY2lhbGx5IHdpdGggZmxhcHMgZGVwbG95ZWQhKQ0KICAgOC4g SUYgeW91IGNoYW5nZSB5b3VyIG1pbmQgYWJvdXQgbGFuZGluZyBhcHByb2FjaCB0eXBlIC0gcmVt ZW1iZXIgdG8NCiAgICAgIHJlY29uZmlndXJlIHlvdXIgYWlyY3JhZnQgZm9yIHRoZSBsYXN0IGRl Y2lzaW9uIOKAkyBJIGhhZCBsZWZ0IG15IGZsYXBzDQogICAgICBkZXBsb3llZCB3aGVuIEkgc2hv dWxkIGhhdmUgcmVtZW1iZXJlZCB0byByZXRyYWN0ZWQgdGhlbS4gIERpZCB0aGF0DQogICAgICBo ZWxwIHByZXZlbnQgYSBDb2ZmaW4gQ29ybmVyIHN0YWxsIGFuZCBzcGluIG9yIHdvdWxkIGl0IGhh dmUgcHV0IG1lDQogICAgICBjbG9zZXIgdG8gaXQ/DQogICA5LiBZb3UgbXVzdCBpbmNyZWFzZSBh aXJzcGVlZCBvdmVyIHRoZSB3aW5nIHRvIGdldCB0aGUgc3VmZmljaWVudCBlbmVyZ3kNCiAgICAg IHRvIG92ZXIgY29tZSBhIGhpZ2ggc2luayByYXRlLiAgUHVsbGluZyBiYWNrIG9uIHRoZSBzdGlj ayB3aGVuIHRoZQ0KICAgICAgZ3JvdW5kIGlzIHN0YXJpbmcgeW91IGluIHRoZSBmYWNlIGlzIHRo ZSBuYXR1cmFsIHJlYWN0aW9uIOKAkyBidXQsDQogICAgICBwdXNoaW5nIGZvcndhcmQgdG8gbG93 ZXIgdGhlIG5vc2UgaXMgdGhlIGNvcnJlY3QgYWN0aW9uIOKAkyBwcm92aWRpbmcNCiAgICAgIG9m IGNvdXJzZSB5b3UgaGF2ZSBzdWZmaWNpZW50IGFsdGl0dWRlIQ0KICAgMTAuICAgICAgQmF0dGVy eSBsaWZlIOKAkyBJIGhhZCBhIHR3byB5ZWFyIG9sZCA2ODAgb2R5c3NleSBiYXR0ZXJ5IHdoaWNo IEkNCiAgICAgIG1haW50YWluIGEgdHJpY2tsZSBjaGFyZ2Ugb24gd2hlbmV2ZXIgSeKAmW0gbm90 IGZseWluZy4gIFdpdGggdHdvIEVGSQ0KICAgICAgZnVlbCBwdW1wcywgYm9vc3QgcHVtcCwgaW5q ZWN0b3JzLCBjb2lscywgRUMyIGFuZCByYWRpbyBhbmQganVzdA0KICAgICAgaGF2aW5nIHN0YXJ0 ZWQgdGhlIGVuZ2luZSBiZWZvcmUgdGFrZSBvZmYg4oCTIHRoaXMgYmF0dGVyeSBsYXN0ZWQgNTUN CiAgICAgIG1pbnV0ZXMuICBXZWxsLCB0aGUgbGFzdCA1IG1pbnV0ZXMgd2VyZSBub3QgcXVhbGl0 eSBiYXR0ZXJ5IHRpbWUuICBTbw0KICAgICAgaW4gbXkgY2FzZSwgMzAgbWludXRlcyBhcHBlYXJz IHRvIGJlIGEgdmVyeSByZWFsaXN0aWMgYmF0dGVyeSBsaWZlLg0KICAgICAgSW4gZmFjdCwgaGFk IEkgdHVybmVkIG9mZiBvbmUgRUZJIHB1bXAgYW5kIHRoZSBib29zdCBwdW1wIHdvdWxkIGhhdmUN CiAgICAgIGdhaW5lZCBhIGZldyBtb3JlIG1pbGVzLiAgQnV0LCBpZiBJIGhhZCByZWNvZ25pemVk IHRoZSBuZWVkIHRvIHR1cm4NCiAgICAgIHRoZW0gb2ZmIGF0IHRoYXQgdGltZSAoSSBub3JtYWxs eSB0dXJuIHRoZW0gb2ZmIGF0IGNydWlzZSBhbHRpdHVkZSksDQogICAgICB0aGVuIEkgd291bGQg aGF2ZSBrbm93biBob3cgdG8g4oCcZml44oCdIHRoZSBwcm9ibGVtLg0KICAgMTEuICAgICAgSeKA mXZlIGRlY2lkZWQgdG8gYWRkIGEgU2Nob2trdHkgZGlvZGUgYmV0d2VlbiBteSBlc3NlbnRpYWwg YnVzDQogICAgICBhbmQgdGhlIGFsdGVybmF0b3Ig4oCTIHNvIHRoYXQgYXMgbG9uZyBhcyB0aGUg YWx0ZXJuYXRvciBpcyBwcm9kdWNpbmcNCiAgICAgIHN1ZmZpY2llbnQgdm9sdGFnZSwgdGhlbiB0 aGUgYmF0dGVyeSB3aWxsIGJlIGdldHRpbmcgc29tZSBjaGFyZ2UgdG8NCiAgICAgIHJlcGxhY2Ug dGhlIGRyYWluLiAgSeKAmXZlIGFsc28gZGVjaWRlZCB0byBtYWtlIHRoYXQgc3dpdGNoIHBvc2l0 aW9uIGENCiAgICAgIGNoZWNrLWxpc3QgaXRlbS4NCg0KIFNvIHdoYXQgaXQgYm9pbHMgZG93biB0 byDigJMgaWYgSSBoYWQgcmVjb2duaXplZCBlYXJseSBvbiB0aGF0IGl0IHdhcyBhbg0KZWxlY3Ry aWNhbCBwcm9ibGVtIGFuZCBub3QgZm9jdXNlZCBzbyBtdWNoIG9uIHRoZSBmdWVsIHN5c3RlbSwg SSBtYXkgaGF2ZQ0Kbm90aWNlZCB0aGUgZXNzZW50aWFsIGJ1cyBzd2l0Y2ggaW4gdGhlIHdyb25n IHBvc2l0aW9uLiAgRm9yY2UgeW91cnNlbGYgdG8NCmV4YW1pbmUgb3RoZXIgcG9zc2libGUgY2F1 c2VzIChlYXN5IHRvIHNheSDigJMgaGFyZGVyIHRvIGRvKS4NCg0KTkVWRVIsIE5FVkVSIGZvcmdl dCB0aGF0IGZseWluZyB0aGUgYWlycGxhbmUgaXMgdGhlIGZpcnN0IGFuZCBvbmx5IHByaW9yaXR5 DQppbiB0aGlzIHR5cGUgb2Ygc2l0dWF0aW9uDQoNCk5FVkVSLCBORVZFUiBmb3JnZXQgdGhhdCBz YXZpbmcgeW91ciBidXR0IGlzIHRoZSB1bHRpbWF0ZWx5IGVuZC1hbGwNCnByaW9yaXR5LiAgV2hl biBJIGRlY2lkZWQgdGhhdCBsYW5kaW5nIG9uIHRoZSBncmFzcyB3YXMgcHJlZmVyYWJsZSB0bw0K cHV0dGluZyBhIGhvbGUgaW4gdGhlaXIgY29uY3JldGUg4oCTIEkgIG1heSBoYXZlIG1hZGUgYSBs aWZlLXNhdmluZyBkZWNpc2lvbi4NCg0KU28gdGhhdOKAmXMgbXkgc3RvcnkgYW5kIEnigJltIHN0 aWNraW5nIHRvIGl0Lg0KDQpGbHkgc2FmZSwgZ3V5cyEhDQoNCkVkDQoNCg0KRWQgQW5kZXJzb24N Cg0KDQpSdi02QSBONDk0QlcgUm90YXJ5IFBvd2VyZWQNCg0KDQpNYXR0aGV3cywgTkMNCg0KDQpl YW5kZXJzb25AY2Fyb2xpbmEucnIuY29tDQoNCg0KaHR0cDovL3d3dy5hbmRlcnNvbmVlLmNvbS4N Cg0KDQpodHRwOi8vd3d3LmRtYWNrLm5ldC9tYXpkYS9pbmRleC5odG1sDQoNCg0KaHR0cDovL3d3 dy5mbHlyb3RhcnkuY29tLw0KDQoNCmh0dHA6Ly9tZW1iZXJzLmNveC5uZXQvcm9nZXJzZGEvcm90 YXJ5L2NvbmZpZ3MuaHRtI040OTRCVw0KDQoNCg0KDQoNCg0KDQoNCl8tPT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQpfLT0gICAgICAg ICAgLSBUaGUgQWVyb0VsZWN0cmljLUxpc3QgRW1haWwgRm9ydW0gLQ0KXy09IFVzZSB0aGUgTWF0 cm9uaWNzIExpc3QgRmVhdHVyZXMgTmF2aWdhdG9yIHRvIGJyb3dzZQ0KXy09IHRoZSBtYW55IExp c3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sDQpfLT0gQXJjaGl2ZSBT ZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0LCBGQVEsDQpfLT0gUGhvdG9zaGFy ZSwgYW5kIG11Y2ggbXVjaCBtb3JlOg0KXy09DQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25p Y3MuY29tL05hdmlnYXRvcj9BZXJvRWxlY3RyaWMtTGlzdA0KXy09DQpfLT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KXy09ICAgICAg ICAgICAgICAgLSBNQVRST05JQ1MgV0VCIEZPUlVNUyAtDQpfLT0gU2FtZSBncmVhdCBjb250ZW50 IGFsc28gYXZhaWxhYmxlIHZpYSB0aGUgV2ViIEZvcnVtcyENCl8tPQ0KXy09ICAgLS0+IGh0dHA6 Ly9mb3J1bXMubWF0cm9uaWNzLmNvbS4NCl8tPQ0KXy09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAgICAgICAgICAgICAtIExp c3QgQ29udHJpYnV0aW9uIFdlYiBTaXRlIC0NCl8tPSAgVGhhbmsgeW91IGZvciB5b3VyIGdlbmVy b3VzIHN1cHBvcnQhDQpfLT0gICAgICAgICAgICAgICAgICAgICAgICAgICAgICAtTWF0dCBEcmFs bGUsIExpc3QgQWRtaW4uDQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRy aWJ1dGlvbg0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT0NCg0KDQoNCg0KDQoNCg= ________________________________________________________________________________
Subject: Re: [Probable SPAM] Re: Lightweight Aux Battery?
Date: Jun 04, 2009
Thanks for your input Glenn. -- Michael Read this topic online here: http://forums.matronics.com/viewtopic.php?p=246752#246752 ________________________________________________________________________________
Date: Jun 04, 2009
Ed, Great story - thanks for sharing. Thanks also for your insight into the problem, analysis, and solutions. Stan Sutterfield **************Limited Time Offers: Save big on popular laptops at Dell %2Fad.doubleclick.net%2Fclk%3B215221161%3B37268813%3By) ________________________________________________________________________________
Subject: Kitfox IV - Jabiru 2200 - Icom IC-A210 Reciving noise
From: "EdgePerformance" <post(at)edgeperformance.no>
Date: Jun 04, 2009
Hi, I`m new to this forum, but I really hope someone can help me out. I have just completed my Jabiru 2200 turbo rebuilding on my Kitfox IV. Then I mounted my new Icom IC-A210 transceiver along with a new instrument panel and new wiring. I send crystal clear messages and receive perfectly on ground with engine of. But as soon as I start my engine I get either ignition noise or alternator noise. The sound adjusts in harmony with the throttle settingrpm. I have changed spark wires, used shielded tefzel wires on all avionics and ignition kill switches. Used shielded wires on headset and microphone jacks, ptt etc. I have also shielded the AC current wires from the alternator or stator plate if you like. And still there is no sign to reduce in headset noise. This happens no matter if the transponder, GPS, instruments etc is ON or OFF. Also what i noticed is when transmitting a message I bearly hear myself in the headset, though the intergrated intercom works well. Hope anyone has experience either with the Icom IC-A210 and noise or the jabiru engine in kitfox IV ? Great full for all tips and help ! -------- Kitfox IV w\ Jabiru 2200 Turbo\Aerocarb Read this topic online here: http://forums.matronics.com/viewtopic.php?p=246794#246794 ________________________________________________________________________________
Date: Jun 04, 2009
Subject: Re: Kitfox IV - Jabiru 2200 - Icom IC-A210 Reciving
noise !?
Hello -----, I think it's important to identify whether the source of the noise is ignition or alternator.. It looks like that engine has dual transistorized magnetos. Does your installation allow for defeating one of those systems while the engine is running? If so, you might notice a decrease in the noise by turning off one or the other system while the engine is running. Also, is it possible to disable the alternator while the engine is running? After you find the source of the noise, you'll need to identify the method of coupling that noise into the audio system. Conducted or radiated? This might get you pointed in the right direction.. Regards, Matt- > > > Hi, > > I`m new to this forum, but I really hope someone can help me out. > > I have just completed my Jabiru 2200 turbo rebuilding on my Kitfox IV. > Then I mounted my new Icom IC-A210 transceiver along with a new instrument > panel and new wiring. > > I send crystal clear messages and receive perfectly on ground with engine > of. But as soon as I start my engine I get either ignition noise or > alternator noise. The sound adjusts in harmony with the throttle > settingrpm. > > I have changed spark wires, used shielded tefzel wires on all avionics and > ignition kill switches. Used shielded wires on headset and microphone > jacks, ptt etc. I have also shielded the AC current wires from the > alternator or stator plate if you like. And still there is no sign to > reduce in headset noise. > > This happens no matter if the transponder, GPS, instruments etc is ON or > OFF. > > Also what i noticed is when transmitting a message I bearly hear myself in > the headset, though the intergrated intercom works well. > > Hope anyone has experience either with the Icom IC-A210 and noise or the > jabiru engine in kitfox IV ? > > Great full for all tips and help ! > > -------- > Kitfox IV w\ Jabiru 2200 Turbo\Aerocarb > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=246794#246794 > > ________________________________________________________________________________
noise
Date: Jun 04, 2009
Hi, Do you mean if i have one ignition switch for each coil ? I have tried to turn off one and one coil but that does`t reduce any noise. I`ll try charging my battery full and take a quick flight with the alternator wires off. At last I will try to add an extra battery and only connect the radio to it. -------- Kitfox IV w\ Jabiru 2200 Turbo\Aerocarb Read this topic online here: http://forums.matronics.com/viewtopic.php?p=246808#246808 ________________________________________________________________________________
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
Date: Jun 04, 2009
noise I was about to suggest that..I.e if you connect the radio directly to an isolated battery and the noise is still there than clearly it is airborne transmitted..If it goes away its probably coming thru the power/ground wires Frank -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of EdgePerformance Sent: Thursday, June 04, 2009 11:29 AM Subject: AeroElectric-List: Re: Kitfox IV - Jabiru 2200 - Icom IC-A210 Reciving noise --> Hi, Do you mean if i have one ignition switch for each coil ? I have tried to turn off one and one coil but that does`t reduce any noise. I`ll try charging my battery full and take a quick flight with the alternator wires off. At last I will try to add an extra battery and only connect the radio to it. -------- Kitfox IV w\ Jabiru 2200 Turbo\Aerocarb Read this topic online here: http://forums.matronics.com/viewtopic.php?p=246808#246808 ________________________________________________________________________________
noise
Date: Jun 04, 2009
I will give it a try tomorrow. But I cant figure what I have done wrong. Radio is connected right to the battery, all wires out of the molex connector are shielded, jacks to headsets are isolated with plastic washers through the front panel, have a grounded 50x45cm ground plate inside the body with the antenna screwed right in the center of the plate with the coaxial cable shield grounded straight to the ground plate. Heres a really simple sketch of how I have wired my antenna. -------- Kitfox IV w\ Jabiru 2200 Turbo\Aerocarb Read this topic online here: http://forums.matronics.com/viewtopic.php?p=246820#246820 Attachments: http://forums.matronics.com//files/antenna_ground_plate_163.jpg ________________________________________________________________________________
noise !?
Date: Jun 04, 2009
Here is a simple sketch of my ground plate and antenna wiring. -------- Kitfox IV w\ Jabiru 2200 Turbo\Aerocarb Read this topic online here: http://forums.matronics.com/viewtopic.php?p=246821#246821 Attachments: http://forums.matronics.com//files/antenna_ground_plate_191.jpg ________________________________________________________________________________
Date: Jun 04, 2009
Reciving noise
Just goes to show you that "shielding everything" isn't a magic bullet. It's not clear to me from your description that the noise is present when the radio is receiving as well as transmitting. Other ideas: - Does disconnecting the antenna mitigate received noise? - Have you verified that you don't have a "hot mag" by turning off both ignitions while the engine is running - the engine should quit. (Maybe this is normally how you stop the engine - I don't know if your fuel delivery system allows "idle-cutoff"...) Additionally, if the noise is from the ignition system (which I am now doubting), turning both of the switches off should douse the electrical noise as well. Regards, Matt- > > > I will give it a try tomorrow. But I cant figure what I have done wrong. Radio is connected right to the battery, all wires out of the molex connector are shielded, jacks to headsets are isolated with plastic washers through the front panel, have a grounded 50x45cm ground plate inside the body with the antenna screwed right in the center of the plate > with the coaxial cable shield grounded straight to the ground plate. > > Heres a really simple sketch of how I have wired my antenna. > > -------- > Kitfox IV w\ Jabiru 2200 Turbo\Aerocarb > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=246820#246820 > > > Attachments: > > http://forums.matronics.com//files/antenna_ground_plate_163.jpg > > ________________________________________________________________________________
n
Date: Jun 04, 2009
Hi, i have the aerocarb so normally i use idle-cutoff but both magnetic coils are new and they work fine. Ignition cutoff work great on both cold and hot engine no matter what throttle setting. What do you mean by antenna mitigate ? My English aren't that great. (Poor Norwegian). I tried to turn off both ignition switches in flight and the engine didn't get to stop completely before the transmission was over, but I could clearly hear the noise frequency becoming lower. But that could also be both alternator and ignition I believe. I really hope I can figure this out soon so that I can go out and fly my new build jabiru 2200 turbo kitfox IV. -------- Kitfox IV w\ Jabiru 2200 Turbo\Aerocarb Read this topic online here: http://forums.matronics.com/viewtopic.php?p=246830#246830 ________________________________________________________________________________
noise
Date: Jun 04, 2009
Are the plastic washers the type with a raised bit that goes through the hole? They generally come with the jack connectors. Otherwise the ground side of the plug can ground through the side of the hole. Ian Brown Bromont Quebec > > I will give it a try tomorrow. But I cant figure what I have done wrong. Radio is connected right to the battery, all wires out of the molex connector are shielded, jacks to headsets are isolated with plastic washers through the front panel, have a grounded 50x45cm ground plate inside the body with the antenna screwed right in the center of the plate with the coaxial cable shield grounded straight to the ground plate. > > Heres a really simple sketch of how I have wired my antenna. > > -------- > Kitfox IV w\ Jabiru 2200 Turbo\Aerocarb > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=246820#246820 > > > > > Attachments: > > http://forums.matronics.com//files/antenna_ground_plate_163.jpg > > > > > > > ________________________________________________________________________________
Subject: Fwd: Jabiru 3300 starter
Date: Jun 04, 2009
Just wondering - Did anyone see this post ? -----Original Message----- From: jaybannist(at)cs.com Sent: Tue, 2 Jun 2009 7:37 pm Subject: Jabiru 3300 starter I am helping a friend put together a power schematic for a Jabiru 3300.? I have seen several sample schematics that have both a starter solenoid and a starter contactor.? Is this really what is required and if so why ?? Is a starter contactor any different than a battery contactor? Jay Bannister Email message sent from CompuServe - visit us today at http://www.cs.com ________________________________________________________________________ Email message sent from CompuServe - visit us today at http://www.cs.com ________________________________________________________________________________
Date: Jun 04, 2009
Subject: Re: Fwd: Jabiru 3300 starter
Yes but it has been discussed before and we all hoped someone else would answer... ;) A conventional battery contactor draws almost 1 amp and can be on continuously. A starter contactor is quicker acting, draws more like 4 amps, and is intermittant duty. ie it will overheat and fail if energized continuously. Your call on whether you need a starter contactor as well as a starter solenoid. Is there any chance that both are required for your warranty? I did not use a starter contactor on my subaru but I can kill a stuck on starter by killing a "battery" contactor on my bird. Solenoids on starters do occasionally but rarely stick on but the same is true for starter contactors. I judge the risk quite low for an automotive type starter solenoid and a glance at the voltage after start up confirms disengagement. Ken jaybannist(at)cs.com wrote: > Just wondering - Did anyone see this post ? > > > -----Original Message----- > From: jaybannist(at)cs.com > To: aeroelectric-list(at)matronics.com > Sent: Tue, 2 Jun 2009 7:37 pm > Subject: Jabiru 3300 starter > > I am helping a friend put together a power schematic for a Jabiru 3300. > I have seen several sample schematics that have both a starter solenoid > and a starter contactor. Is this really what is required and if so why > ? Is a starter contactor any different than a battery contactor? > > Jay Bannister > ------------------------------------------------------------------------ > E ________________________________________________________________________________
Date: Jun 04, 2009
Ken, Thanks for the reply.? Because I have a Corvair engine, in the past, I have not looked at posts dealing specifically with Jabiru systems.? I think my confusion comes from the fact that the starter solenoid on my engine is tied to the started and there is no starter contactor.? I think from looking at the latest Jabiru wiring diagram, one or the other is required, but not both.? I'm just not sure what is included in the Jabiru FWF package. Thanks again - Jay -----Original Message----- From: Ken <klehman(at)albedo.net> ? Yes but it has been discussed before and we all hoped someone else would answer... ;)? ? A conventional battery contactor draws almost 1 amp and can be on continuously. A starter contactor is quicker acting, draws more like 4 amps, and is intermittant duty. ie it will overheat and fail if energized continuously.? ? Your call on whether you need a starter contactor as well as a starter solenoid. Is there any chance that both are required for your warranty? I did not use a starter contactor on my subaru but I can kill a stuck on starter by killing a "battery" contactor on my bird. Solenoids on starters do occasionally but rarely stick on but the same is true for starter contactors. I judge the risk quite low for an automotive type starter solenoid and a glance at the voltage after start up confirms disengagement.? ? Ken? ________________________________________________________________________ Email message sent from CompuServe - visit us today at http://www.cs.com ________________________________________________________________________________
Subject: Essential Incident - Almost (Long)
Date: Jun 04, 2009
Hi Bill, Perhaps a bit clear explanation of my circuit. When I move my essential bus switch from ALT (alternator) to BAT1 (battery1), it removes the link between battery and alternator. However, the master relay still closed by the battery voltage, so this provides a path for the alternator to continue to feed the rest of the (none essential systems - such as landing lights, strobe light, transponder, etc). When the battery voltage dropped low enough it was unable to hold the master relay closed - which opened removing alternator voltage from the rest of the system. By that time, the battery was too low to support the essential systems such as my engine and to include the radio. When the battery is disconnected from the alternator, there is no noticeable variation in my alternator voltage indicating that the none-essential subsystems apparently provide sufficient load stability. That's my best analysis of the system. Ed Ed Anderson Rv-6A N494BW Rotary Powered Matthews, NC eanderson(at)carolina.rr.com http://www.andersonee.com http://www.dmack.net/mazda/index.html http://www.flyrotary.com/ http://members.cox.net/rogersda/rotary/configs.htm#N494BW http://www.rotaryaviation.com/Rotorhead%20Truth.htm -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bill Schlatterer Sent: Wednesday, June 03, 2009 10:00 PM Subject: RE: AeroElectric-List: Essential Incident - Almost (Long) Ed, just curious,... How is it that your essential switch disconnects the main bus? Usually, they power the essential bus but you have to shut off the Main bus (I think) manually as a safety feature. When you heard the CLANK which you said was the main bus relay disconnecting, that would have been caused by the absolute drain of the battery. BUT, with the master relay still engaged, the alternator should have still been charging the battery? (even with the E-Bus switch thrown,... I think? If your essential completely reroutes the current from the alternator around the battery, then what takes up the load with the single battery off line? Is that what the second battery (removed) was supposed to do? Just wondering how it works? Thanks Bill S 7a finishing / Z13/8 and other stuff -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ed Anderson Sent: Wednesday, June 03, 2009 7:51 PM Subject: RE: AeroElectric-List: Essential Incident - Almost (Long) --> Thanks Kevin Could not agree with your points more. Yes, I have a pre-takeoff check list which I do use - however, as you point out - if an item is not on it that is critical to safe flight, then it is certainly incomplete. I do not have an in-flight emergency check list, but will certainly give that some serious thought - it would be helpful if it just isolated whether the problem was the fuel system, electrical system and their subsystems. Another good suggestion Ah, good analysis, Kevin. You are correct, my low voltage light is hooked to my alternator circuit and not the essential bus. The logic (if there was any) was that if the alternator started to fail then the warning light would warn me before I started to drain the battery. However, in this case, the alternator was continuing to produce 14 V so naturally the low voltage light never came on. So again, I agree on all the points you made. Just goes to show you how even things designed to make it safer can do the opposite under certain conditions. Clearly, there are a few things that I need to change {:>) Ed Ed Anderson Rv-6A N494BW Rotary Powered Matthews, NC eanderson(at)carolina.rr.com http://www.andersonee.com http://www.dmack.net/mazda/index.html http://www.flyrotary.com/ http://members.cox.net/rogersda/rotary/configs.htm#N494BW http://www.rotaryaviation.com/Rotorhead%20Truth.htm -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Kevin Horton Sent: Wednesday, June 03, 2009 5:02 PM Subject: Re: AeroElectric-List: Essential Incident - Almost (Long) --> Ed, Congrats for keeping your cool, and flying the airplane to a safe landing. And thanks for sharing the story, so we can all learn from your incident. I fully agree that checklists are important. If your electrical system design assumes that the electrical system will be in a particular configuration for flight, then you need a checklist that ensures this is true. And you need to religiously do every step on that checklist before take-off. It is also useful to have well thought out checklists for engine failure, engine rough running, etc. For example, a well thought rough running engine checklist would include all steps necessary to check voltage on whatever bus(s) your engine needs. One thing that puzzles me about your electrical system design - it seems that your engine needs power from the Essential Bus. But it seems like your active low voltage warning is looking at some other bus. Why not hook the low voltage warning up the the one bus that is really important - i.e. the Essential Bus? Kevin Horton On 3-Jun-09, at 15:53 , Ed Anderson wrote: > It was suggested by one of the aeroelectric list members, Sam Hoskins, > that the following report of an incident I had on a recent trip be > posted to the AeroElectric list for obvious reasons - once you read > it. > > I have an all-electric Rv-6A with over 10 years and close to 500 > hours on it. I based the electrical system roughly one of Bob's > excellent designs. It initially had one alternator and two > batteries, but removed the second battery approx 5 years ago - but, I > did make one modification to the design that I almost had cause to > regret. > > So needless to say, but I will, responsibility for design and > incident is totally mine. > > But, to get on with the tale > > > One the way to Texas I had an incident that ended up in with me and > aircraft making a 7 mile engine-out glide into Craig Field (Selma, > Alabama). NO! It was not fault of the engine or even the subsystems. > But, the complete answer is not provided until after my litany of the > conditions and symptoms - can you figure it out? > > I took off on Thursday (28 May 2009) AM from North Carolina planning > on stopping in Mississippi to join up with two friends. After > spending the night there, we all three would then head for Texas. > But, the weather (as you are aware) has been laying over the southeast > for days with rain and more rain - but I launched into it anyway as > past Atlanta, GA things were forecast to improve.. > > Other than dodging lines of clouds and a bit of scud running, but not > much, I landed at Alexandria City to the southwest of Atlanta, GA to > take on fuel. I then climbed back in and fire it up and took off. > > I noticed that during climb-out the engine would occasionally miss and > thought the fuel might have had a bit of water in it, but was not > really concerned. So I fly on for approx another 45 minutes and had > just passed Selma, Alabama and old Craig Air Force base, and turned > west toward Mississippi, when more symptoms began to occur. > > It started to act like a case of SAG (fouled spark plugs) where the > rpm will drop a bit - not dangerous - just nerve racking. But, > shortly things began to go beyond the SAG symptoms, so I though I > might have an injector problem (like one sticking open or not opening > at all). Since our injectors are in pairs, I tried turning one pair > off figuring if things got better, then that pair might have a bad > injector. > > So I turned off one pair and sure enough the symptoms abated a bit > (more on this later) so I figured I had a bad injector in that pair. > To be certain I turned this "bad" pair back on and turn off the "good" > pair expecting the symptoms to really get bad as I would now be > running on only the "bad" pair - much to my surprise when I turned off > the "good" pair - the symptoms also abated. So that indicated it was > not an injector problem - but what? > > About this time, I decided to turn the aircraft back around toward > Craig Field and dodging clouds headed back with the engine > progressively getting worst. It appeared to be a fuel problem (and > while that is ultimately the subsystem affected - it was not the root > cause). The fuel pressure was ranging from zero to 80 psi, other > electrical things were also misbehaving. I check the voltmeter > thinking perhaps the alternator had died - but it showed > 14 volts. So back to the fuel system. > > Finally, the engine just stops with the prop standing still - like a > hood ornament, I'm at around 4500-5000 MSL at this point having lost > some altitude dodging a cloud (good old GPS just kept pointing to > Craig Field). At that time I am 6-7 miles out from Craig Field at > 4500 msl with a stopped prop, a crippled seat cushion and a dry mouth. > Yes, I've been there before, but I don't think you ever get "use" to > it. I recalled thinking -". things just can't get > worst." when they very shortly and suddenly - did. > > I keyed the radio and made a call to Craig Field at 4 miles on the GPS > but before I could get their reply, I heard a "CLANK" (without the > engine running you can hear things like that) like a relay > springing open (it was) and the entire panel goes dead!!!! No > radio, no engine instruments, not even a stinking LED was lit - only > the battery powered GPS. Can you spell "total electrical failure?" > Talk about a lonely feeling - amazing how comforting having lights on > and radio - you could almost convince yourself this was just a > practice engine-out landing, but not when the panel goes dark. No > engine gauges, no radio, nada! > > Well not being one inclined to panic (but I seriously considered it > for a moment {:>)), I continued toward Craig field - I mean like there > were lots of other alternatives. Well Once again I found myself in > the "fortunate position" of being too high, too much altitude. So I > put in 40 degs of flaps to steepen my rate of descent. But, then I > decided this time that rather than do the 360 I had done on a previous > Incident to lose "excessive" altitude, I would try to glide - a more > or less - regular traffic pattern. > > However, I neglected to remember to retract the flaps. So I found > myself on the downwind around mid-field at pattern altitude (which > felt normal) until I suddenly realized that you CAN NOT maintain that > pattern altitude without an engine!!! (and particularly with 40 deg > of flaps deployed - flaps and trim are manual) Duh! > > I knew I could never make it to the far end of the runway before > turning base (toward the runway) and I was losing altitude at the > rate of 400-500 fpm, so I started my turn immediately. To make > matters a bit worst - I had been paralleling the runway on the > downwind leg a bit too close in - must have been the comforting > feeling of being close to safety. This position naturally required a > tighter turn and as I turned I saw I was likely to overshoot the > runway and land in the grass. So I though I need to steepen this turn > further (Yep! COFFIN CORNER was calling), but fortunately glanced at > my airspeed indicator - to see it only registering 80 MPH and my rate > of descent (normally 400-500 feet per minute) up to over 1000 feet per > minute. The seat cushion suddenly vanished from this universe. > > But the REAL danger in this situation, as you all know, is your > airspeed gets low, you are in a steep bank which greatly raises the > stall speed - meaning at 80 mph you are close to a stall in a steep > turn while your are not in straight and level. So I immediately > straighten out of the turn - the little voice saying "better to land > in the grass than get their concrete runway all messed up". So the > immediate danger of a stall was adverted, but I was still pointed > toward the ground with a sink rate twice as high as normal (and I've > manage a few hard landings even with a normal sink rate). > Fortunately, the runway was now under my nose rather than grass. > > The hardest thing to do when you are sinking at a 1000 fpm a couple > hundred feet above the ground (with your nose already pointed at the > ground) is to push the stick forward steeping the dive even more. > But, I manage to do that and picked enough air speed and energy to > flair to a nice touch down - not even a bump. I've always been amazed > at what total concentration does to improve you landing {:>). > > Rolled to the end of the runway and had energy to roll off onto the > taxiway. Got out, check under the aircraft for any evidence of > leaks and started pulling the aircraft toward the far -off - hangar > which had an airplane parked in front of it. A nice looking young > woman comes riding a bicycle out to meet me. Hopped off and holding > out her hand said "Hi I'm Angie, looks like we'll be spending time > together" - so things were starting to look up {:>) > > So pulled the aircraft in to the hangar where the mechanic came over > and ask what the problem was. Well, I looked at the volt meter and it > said the battery was dead. Mechanic put on a battery charger and > announced "Yep! The battery is dead". So we both concluded that the > alternator must have failed and not being able to replenish the drain > on the battery by all the electrical systems such as fuel pumps, > injectors, ignition coils, etc had drained the battery. > > However, there were a few problems with the analysis of a failed > alternator. First, the low voltage warning light never came on to > warn of an alternator problem, 2nd I never notice the voltmeter > showing anything other than what it should for alternator voltage - > like around 14 volts. While checking the voltage after the Mechanic > had charged the battery, I noticed down below that the "essential bus" > switch was in the battery rather than the alternator position, so > flicked it back to the alternator position figuring I must have > accidentally kicked it while getting to some stuff in the baggage > compartment of my RV-6A. > > It was getting late and being a bit tired not to mention stressed, I > needed to get a rental car and a motel for the night. Did that, eat > dinner and went to bed after sitting down and drawing out a problem > tree with the entire major elements of the electrical system. > > So next morning I show up at the hangar early and met Ben, the > mechanic, the battery had received a charge of only 45 minutes the > evening before, So I suggested we charged it for another hour and try > to start the aircraft. Ben suggested a real stress test of the > battery and NOT charge it anymore. Made sense, so we rolled the > aircraft out of the hangar. I hopped in, threw a half dozen switches > and punched the starter button. The engine started on the first prop > blade rotation - so the battery was clearly OK. The > engine is humming like a top. So I looked over at the voltmeter > expecting it to show only around 12.8 volts instead of the 14 volts a > functioning alternator would produce. Much to both my and Ben's > surprise the alternator voltage read 14 volts. We loaded the > alternator by turning on the both l00 watt landing lights, all fuel > pumps, the pitot heat, etc. The alternator voltage only drops perhaps > 0.4 volts clearly indicating the alternator could carry the load and > was OK. > > So here I am - battery is OK, alternator is OK - engine is purring > normally, so clearly this was all a figment of my deteriorating brain > cells. I loaded up the aircraft and launched to do a few circuits of > the airport - I did so and all was operating normally and so I radio > them I was head onward to Texas. While flying (with my only > functional eyeball on the voltmeter), my mind could not let go of the > problem and finally the light bulb came on. > > The essential bus switch had (for my entire 10 + years of > flying)always been in the alternator position. The purpose of this > switch is, of course, to isolate the battery from the alternator > should the alternator fail - to prevent an alternator problem from > draining the battery. So in event of an alternator problem, you move > the switch from alternator to battery. Its call the essential bus > because you only have the essential things drawing from the battery so > you wont' drain it as quickly. The idea is to give you time > (generally around 30 minutes) to find a safe place to land in case of > alternator failure. > > > Well, at some point I had either (not paying attention) turned the > switch to battery thinking I was turning the voltmeter switch to > battery(more on that below) - or accidentally had move the switch > from alternator to battery without noticing it by kicking it, etc. > However, it was sort of protected in its position from accidental > activation. It must have happened during refueling - as I got approx > 45 minutes down the road on the battery after take off before quality > battery time started to deteriorate. As the battery voltage fell due > to the load (and no alternator link to replenish it), electrical > things (mainly computers first) started acting up until they could not > longer run the engine. The injectors would not open fully, etc. Then > as the voltage level further decreased, the master relay which the > battery held closed and which connected the (fully > functional) alternator to the rest of the electrical system - opened > up and removed ALL power from the electrical system. So no radio, no > gauges, etc. > > Oh, another little factor that may have contributed, the voltmeter > has a tiny toggle switch by it marked ALT BAT1 BAT2 for checking > alternator battery 1 and battery 2 (which I no longer fly with) > voltages. Down below It a couple of inches and off to the right is > the essential bus normal size toggle switch - also marked ALT BAT1 > BAT1. I normally never touch it and don't even think about it. But I > could have reached for the voltmeter toggle thinking to check my > battery voltage (which I do as a regular thing) and perhaps distracted > by something reached a bit further down and instead moved the > essential bus switch from Alternator to Battery causing this entire > event. I know that I did not consciously do it. So it is either > accidental or absence minded activation - either way ends with the > same results {:>) > > > Now it became clear why it didn't matter which pair of fuel injectors > I turned off - turning off either pair improved the situation because > it slightly reduced the electrical load by a few amps - and the engine > ran slightly better for a few moments. The same thing had happened > when turning off one of the EFI fuel pumps - but what threw me was the > alternator voltage continued to be normal during this. > > After I knew the cause (switch in wrong position), I decided the > problem was fixed so no reason to return to NC, and I just continued > on to Texas. > > I know some of you may think that removing my second battery was a > mistake - but, consider this, having another battery could have meant > I would have been much further from a suitable airfield before they > both went south. On the other hand, it might have caused me to at > least think to throw the essential bus switch to the second battery > and have the Light bulb come on. Who really knows. But, I have in > mind a simply addition to my electrical circuit that should help in > the future. > > > I do want to state that this time when the problems started I DID > switch fuel tanks - but naturally it had no effect because this time > it turned out, it was not a fuel problem - not the root cause at > least. > > So what are the lessons learned: > > . Put EVERY critical switch on your before-takeoff Check list > . Perhaps put a guard around such critical switches to force > conscious activation > . Don't (hard not to) get overly focused on what you think is the > problem - consider other possibilities. I thought it was a fuel > problem (I even switched fuel tanks this time) - it turned out to be > electrical in its root cause. > . While the fuel pressure was jumping all over the place and the EGT > was erratic and engine surging strongly indicating a fuel problem - > the ultimate cause was electrical. Once the voltage got below a > certain point the EC2 computer was still trying to pull the injectors > open, but with the voltage so low it could not do it properly. > . When the battery voltage dropped below a certain point, the master > relay released and removed the alternator from the electrical system > and the panel went dark - even though the alternator was still working > . Immediately turn to the nearest airfield when serious problems > occur - THEN work on fixing them. I only delayed for perhaps 2-3 > minutes, but that could have made a difference. > . Watch out for Coffin Corner turn when turning base to final - > airspeed really bleeds off fast with no engine pulling you along (and > especially with flaps deployed!) > . IF you change your mind about landing approach type - remember to > reconfigure your aircraft for the last decision - I had left my flaps > deployed when I should have remembered to retracted them. Did that > help prevent a Coffin Corner stall and spin or would it have put me > closer to it? > . You must increase airspeed over the wing to get the sufficient > energy to over come a high sink rate. Pulling back on the stick when > the ground is staring you in the face is the natural reaction - but, > pushing forward to lower the nose is the correct action - providing of > course you have sufficient altitude! > . Battery life - I had a two year old 680 odyssey battery which I > maintain a trickle charge on whenever I'm not flying. With two EFI > fuel pumps, boost pump, injectors, coils, EC2 and radio and just > having started the engine before take off - this battery lasted 55 > minutes. Well, the last 5 minutes were not quality battery time. > So in my case, 30 minutes appears to be a very realistic battery life. > In fact, had I turned off one EFI pump and the boost pump would have > gained a few more miles. But, if I had recognized the need to turn > them off at that time (I normally turn them off at cruise altitude), > then I would have known how to "fix" the problem. > . I've decided to add a Schokkty diode between my essential bus and > the alternator - so that as long as the alternator is producing > sufficient voltage, then the battery will be getting some charge to > replace the drain. I've also decided to make that switch position a > check-list item. > > So what it boils down to - if I had recognized early on that it was > an electrical problem and not focused so much on the fuel system, I > may have noticed the essential bus switch in the wrong position. > Force yourself to examine other possible causes (easy to say - harder > to do). > > NEVER, NEVER forget that flying the airplane is the first and only > priority in this type of situation > > NEVER, NEVER forget that saving your butt is the ultimately end-all > priority. When I decided that landing on the grass was preferable to > putting a hole in their concrete - I may have made a life-saving > decision. > > So that's my story and I'm sticking to it. > > Fly safe, guys!! > > Ed > Ed Anderson > > __________ Information from ESET NOD32 Antivirus, version of virus signature database 3267 (20080714) __________ The message was checked by ESET NOD32 Antivirus. __________ Information from ESET NOD32 Antivirus, version of virus signature database 3267 (20080714) __________ The message was checked by ESET NOD32 Antivirus. ________________________________________________________________________________
Date: Jun 04, 2009
Hi Etienne, No one can point finger at me better than myself. As I indicated the modifications to Bob's excellent design and resulting incident rest strictly with me - no getting around that (even if I tried). As best I can recall from over 10 years ago, I decided I did not want the voltage drop caused by a isolation diode (as you might imagine I am reconsidering that decision). So when I move my essential bus switch from Alternator to Battery, the battery is completely disconnected from alternator circuit. At the same time the battery voltage is what is holding my master relay closed so that the alternator feeds the electrical system. Normally (at least for the past 10 years and 450 + hours) has worked as I had envisioned. But, never having an alternator failure, I never had reason to move the switch from the Alternator position. In this case, the switch was moved to battery which isolated the battery from the alternator completely - This was of course unintentional, but all the same resulted in exhaustion of the battery while I still had a perfectly good alternator functioning. Needless to say, that requires me to reconsider my design. The simplest fix appears to be to put the isolation diode between alternator and battery essential bus. Ed Ed Anderson Rv-6A N494BW Rotary Powered Matthews, NC eanderson(at)carolina.rr.com <http://www.andersonee.com> http://www.andersonee.com <http://www.dmack.net/mazda/index.html> http://www.dmack.net/mazda/index.html http://www.flyrotary.com/ <http://members.cox.net/rogersda/rotary/configs.htm> http://members.cox.net/rogersda/rotary/configs.htm#N494BW http://www.rotaryaviation.com/Rotorhead%20Truth.htm <http://www.dmack.net/mazda/index.html> _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Etienne Phillips Sent: Thursday, June 04, 2009 1:55 AM Subject: Re: AeroElectric-List: Essential Incident - Almost (Long) Hi Ed Aren't you glad you weren't flying at night! :-) A diagram of your electrical system as it was would help us understand what you did, and why its design caused the failure... Of particular interest is why switching on the e-bus disconnected the alternator. I also can't seem to make out why when the main bus still had power from the alternator, the contactor died when the e-bus voltage dropped. It may prompt Bob to suggest a better solution to what you're planning :-D Not pointing fingers here, I just can't visualise how it's all hooked up! Thanks Etienne On 03 Jun 2009, at 9:53 PM, Ed Anderson wrote: It was suggested by one of the aeroelectric list members, Sam Hoskins, that the following report of an incident I had on a recent trip be posted to the AeroElectric list for obvious reasons - once you read it. I have an all-electric Rv-6A with over 10 years and close to 500 hours on it. I based the electrical system roughly one of Bob's excellent designs. It initially had one alternator and two batteries, but removed the second battery approx 5 years ago - but, I did make one modification to the design that I almost had cause to regret. So needless to say, but I will, responsibility for design and incident is totally mine. But, to get on with the tale One the way to Texas I had an incident that ended up in with me and aircraft making a 7 mile engine-out glide into Craig Field (Selma, Alabama). NO! It was not fault of the engine or even the subsystems. But, the complete answer is not provided until after my litany of the conditions and symptoms - can you figure it out? Fly safe, guys!! Ed __________ Information from ESET NOD32 Antivirus, version of virus signature database 3267 (20080714) __________ The message was checked by ESET NOD32 Antivirus. ________________________________________________________________________________
Subject: Re: Stereo to Mono
Date: Jun 04, 2009
Actually, I use a Sony Walkman in my RV-6A that has something on the order of 400+ songs right now with plenty of storage room to spare for more songs, videos, photos, etc. Weighs a few ounces, plugs into my intercom, didn't cost much, and works great. It's a Sony Walkman digital media player - smaller physical size than the i-pods my kids prefer and does all I want for the RV. Although once upon a time I did have one of the Walkman units you are talking about, Sony has rehashed the name with current technology.....not sure which era Don's Walkman is from. Chris ----- Original Message ----- From: gmcjetpilot(at)yahoo.com To: aeroelectric-list(at)matronics.com ; don(at)contractorsnorthwest.com Sent: Monday, June 01, 2009 3:00 AM Subject: AeroElectric-List: Re: Stereo to Mono I would not use a stereo to mono jack to go FROM stereo to MONO. It really is made for going from mono to drive a stereo headphone, split to drive both L & R channels. It is not designed to combine stereo to mono. Whats the big deal? Shorting L & R of an amp can cause damage, even an iPod. If the "Walkman" has a mono switch than its OK, but iPods do not have mono switches. If you don't have a MP3 player (iPod) get one. Walkman are last decades news. If you don't have an iPod you can get 100's of hours of music on them with play time of 6 hours per charge. They are also small and light weight. There are some threads on how to properly combine stereo and ground issues in this forum. Just use the search engine. The easy way is with capacitor and resistor, which you can wire behind the panel. You would use a stereo 1/8" phone jack and then go from stereo to mono with the isolation Cap and Resistor. Cheers George >From: <bakerocb(at)cox.net> >Subject: AeroElectric-List: Stereo to Mono > >5/30/2009 >Hello Don, You wrote: "I want to install a plug in my panel to plug my >stereo Walkman into but my intercom (PM1000 II) is mono." >Here is one way to solve that problem -- >http://www.radioshack.com/product/index.jsp?productId=2102669 >This adapter will put the output of a mono jack on your panel into both >sides of your stereo Walkman. >Also take a look at some of the other adapters available. You may want to >put a normal airplane earphone sized jack on your instrument panel so that >either your Walkman (with an adapter) or an airplane earphone set (without >adapter) may be plugged in. > >======================== === >> >>Subject: AeroElectric-List: Stereo to Mono >>From: "Don McIntosh" <don(at)contractorsnorthwest.com> >> >>I want to install a plug in my panel to plug my stereo Walkman into but my >>intercom (PM1000 II) is mono. Can I just splice the Right and Left leads together >>to go into the intercom? Also the intercom pins are labeled "HI" and "LOW". >>Is this just the pin identification numbers? >>-------- >>Don McIntosh >>Kitfox Series 7 under construction >>Jabiru 3300 ________________________________________________________________________________
noise
Date: Jun 05, 2009
Hi, Will that cause receiving noise only, and only with the engine off ? ianxbrown wrote: > Are the plastic washers the type with a raised bit that goes through the > hole? They generally come with the jack connectors. Otherwise the > ground side of the plug can ground through the side of the hole. > > Ian Brown > Bromont > Quebec > > > > > > > > I will give it a try tomorrow. But I cant figure what I have done wrong. Radio is connected right to the battery, all wires out of the molex connector are shielded, jacks to headsets are isolated with plastic washers through the front panel, have a grounded 50x45cm ground plate inside the body with the antenna screwed right in the center of the plate with the coaxial cable shield grounded straight to the ground plate. > > > > Heres a really simple sketch of how I have wired my antenna. > > > > -------- > > Kitfox IV w Jabiru 2200 TurboAerocarb > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p 46820#246820 > > > > > > > > > > Attachments: > > > > http://forums.matronics.com//files/antenna_ground_plate_163.jpg > > > > > > > > > > > > > > > > > > > -------- Kitfox IV w\ Jabiru 2200 Turbo\Aerocarb Read this topic online here: http://forums.matronics.com/viewtopic.php?p=246925#246925 ________________________________________________________________________________
Date: Jun 05, 2009
Subject: Re: Essential Incident - Almost (Long)
A related discussion FWIW: I still think that the electrically dependent engine and especially with internal regulated alternators, may be better served by connecting the alternator to the battery side of a battery contactor. Even more so if you have a separate OV contactor or if you run small batteries. I've done that on both alternators of my Z-14 system. Separate guarded switches control the OV contactors. In a smoke situation I want to kill everything not required by the engine but if the smoke stops I still want the option of keeping the alternator. I don't want to risk load dumping my internally regulated alternator if I don't have to. I run very small 8AH batteries but interestingly one of them lost almost all of its capacity very quickly last winter. The second one still cranked the engine fairly well so it was not obvious. It did not seem to go open circuit as it would still supply a 5 amp load for 2 or 3 minutes. De-sulphating pulses made no improvement. My voltmeters and OV sensing are off the battery busses since they run the engine. Ken Ed Anderson wrote: > > Hi Bill, > > Perhaps a bit clear explanation of my circuit. When I move my essential bus ________________________________________________________________________________
Date: Jun 05, 2009
>>Sony Walkman in my RV-6A that has something on the order of 400+ songs right now with plenty of storage room to spare for more songs, videos, photos, etc.<< You mean those tapes I use in my Walkman have been replaced by something better? Actually I am very happy with the HP pocket computer that came with my newest upgrade to Anywhere Map. It fits in my pocket when not in it's vehicle mount, it has wireless internet (I did replace the Microsoft browser with "Opera", however), MP3 player, Bluetooth, built in GPS antenna, Tom-Tom for ground navigation, and, of course, AnywhereMap. Not to mention the games that I loaded into it that I can play while waiting in the doctor's waiting rooms! It does have an output socket for earphones and I have an adapter for the 1/8" socket to a 1/4" plug to just plug in to the appropriate socket in my intercom. But haven't gotten around to connecting it to my intercom yet, since I don't even have an electrical system in my plane yet! Hopefully before this year is out.... Harley ------------------------------------------------------------------------ Chris Hand wrote: > decades news. If you > play time of 6 hours > > > > Actually, I use a Sony Walkman in my RV-6A that has something on the > order of 400+ songs right now with plenty of storage room to spare for > more songs, videos, photos, etc. Weighs a few ounces, plugs into my > intercom, didn't cost much, and works great. It's a Sony Walkman > digital media player - smaller physical size than the i-pods my kids > prefer and does all I want for the RV. Although once upon a time I > did have one of the Walkman units you are talking about, Sony has > rehashed the name with current technology.....not sure which era Don's > Walkman is from. > > Chris > > > ----- Original Message ----- > *From:* gmcjetpilot(at)yahoo.com > *To:* aeroelectric-list(at)matronics.com > ; > don(at)contractorsnorthwest.com > *Sent:* Monday, June 01, 2009 3:00 AM > *Subject:* AeroElectric-List: Re: Stereo to Mono > > I would not use a stereo to mono jack to go FROM stereo to MONO. > It really is made > for going from mono to drive a stereo headphone, split to drive > both L & R channels. > It is not designed to combine stereo to mono. > > Whats the big deal? Shorting L & R of an amp can cause damage, > even an iPod. If the > "Walkman" has a mono switch than its OK, but iPods do not have > mono switches. > > If you don't have a MP3 player (iPod) get one. Walkman are last > decades news. If you > don't have an iPod you can get 100's of hours of music on them > with play time of 6 hours > per charge. They are also small and light weight. > > There are some threads on how to properly combine stereo and > ground issues in this > forum. Just use the search engine. The easy way is with capacitor > and resistor, which > you can wire behind the panel. You would use a stereo 1/8" phone > jack and then > go from stereo to mono with the isolation Cap and Resistor. > > Cheers George > > > >From: <bakerocb(at)cox.net <mailto:bakerocb(at)cox.net>> > >Subject: AeroElectric-List: Stereo to Mono > > > >5/30/2009 > >Hello Don, You wrote: "I want to install a plug in my panel to > plug my > >stereo Walkman into but my intercom (PM1000 II) is mono." > >Here is one way to solve that problem -- > > >http://www.radioshack.com/product/index.jsp?productId=2102669 > > >This adapter will put the output of a mono jack on your panel > into both > >sides of your stereo Walkman. > > >Also take a look at some of the other adapters available. You may > want to > >put a normal airplane earphone sized jack on your instrument > panel so that > >either your Walkman (with an adapter) or an airplane earphone set > (without > >adapter) may be plugged in. > > > >=========================== > >> > >>Subject: AeroElectric-List: Stereo to Mono > >>From: "Don McIntosh" <don(at)contractorsnorthwest.com > > > >> > >>I want to install a plug in my panel to plug my stereo Walkman > into but my > >>intercom (PM1000 II) is mono. Can I just splice the Right and > Left leads together > >>to go into the intercom? Also the intercom pins are labeled "HI" > and "LOW". > >>Is this just the pin identification numbers? > >>-------- > >>Don McIntosh > >>Kitfox Series 7 under construction > >>Jabiru 3300 > > > * > > href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > * > > * > > > * ________________________________________________________________________________
Subject: Re: Essential Incident - Almost (Long)Essential Incident
- Almost (Long)
Date: Jun 05, 2009
Ed, It is hard to improve on Bob Nuckolls wiring diagrams. His schematics have evolved and have been proven over time and have been scrutinized by many eyes. His essential bus is fed via two paths: a diode and a switch. If one path fails, there is a backup. Your intention of putting the diode back in is a good idea. The voltage drop across a diode is not a concern because the alternator is putting out more than enough voltage. If the alternator fails and you turn on the E-Bus alternate feed switch, the diode is no longer part of the circuit. So in either case, alternator working or not, the voltage drop across the diode is not a concern. Putting another switch (E-Bus alt feed) between the battery and alternator introduces another failure point. That extra switch is not needed because there is already a master switch to shut off the battery and alternator circuits. Not only does the master switch shut off non-essential electrical loads, it also shuts off the main battery contactor, another non-essential load. I assume that your E-Bus alternate feed switch is a double pole switch because it controls two things: the E-Bus and battery-to-main-bus circuit. If that switch fails, both electrical paths to the E-Bus could be lost. If you post your electrical schematic on AeroElectric, others can offer suggestions for improvement. Joe ________________________________________________________________________________
Date: Jun 05, 2009
Subject: RE: Essential Incident
At 08:22 PM 6/4/2009, you wrote: > > >Hi Bill, > >Perhaps a bit clear explanation of my circuit. When I move my essential bus >switch from ALT (alternator) to BAT1 (battery1), it removes the link between >battery and alternator. However, the master relay still closed by the >battery voltage, so this provides a path for the alternator to continue to >feed the rest of the (none essential systems - such as landing lights, >strobe light, transponder, etc). Ed, could you send me a copy of your architecture? It seems that it might benefit from a failure mode effects analysis. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Subject: Essential Incident - Almost (Long)Essential Incident
- Almost (Long)
Date: Jun 05, 2009
I have to agree, Joe. What 10 years ago seemed like a reasonable idea and design- proved 10 years later to be in need of some changes - without doubt. While this incident was undoubtedly pilot induced - it pointed out some limitations that I had not factored in. Fortunately, I get the chance to make some changes. Yes, in hindsight, I agree - the voltage drop across the diode is a minor factor in the scheme of things. However, the Alternator/ battery switch will stay in the circuit - because even diodes can fail. If the switch fails then hopefully the diode will keep the battery replenished. Should the diode fail then the switch provides a circuit for keeping battery alive. I will also revise the circuit so the Master relay is not solely dependent on battery voltage. Back 10 years ago, it seemed to me that alternator failure was the highest probability. After 10+ years of flying without either alternator or battery failure - I am content with the basic design (after aforementioned changes are made that is {:>)) Ed Ed Anderson Rv-6A N494BW Rotary Powered Matthews, NC eanderson(at)carolina.rr.com <http://www.andersonee.com> http://www.andersonee.com <http://www.dmack.net/mazda/index.html> http://www.dmack.net/mazda/index.html http://www.flyrotary.com/ <http://members.cox.net/rogersda/rotary/configs.htm> http://members.cox.net/rogersda/rotary/configs.htm#N494BW http://www.rotaryaviation.com/Rotorhead%20Truth.htm <http://www.dmack.net/mazda/index.html> _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Joe Sent: Friday, June 05, 2009 9:23 AM Subject: Re: AeroElectric-List: Essential Incident - Almost (Long)Essential Incident - Almost (Long) Ed, It is hard to improve on Bob Nuckolls wiring diagrams. His schematics have evolved and have been proven over time and have been scrutinized by many eyes. His essential bus is fed via two paths: a diode and a switch. If one path fails, there is a backup. Your intention of putting the diode back in is a good idea. The voltage drop across a diode is not a concern because the alternator is putting out more than enough voltage. If the alternator fails and you turn on the E-Bus alternate feed switch, the diode is no longer part of the circuit. So in either case, alternator working or not, the voltage drop across the diode is not a concern. Putting another switch (E-Bus alt feed) between the battery and alternator introduces another failure point. That extra switch is not needed because there is already a master switch to shut off the battery and alternator circuits. Not only does the master switch shut off non-essential electrical loads, it also shuts off the main battery contactor, another non-essential load. I assume that your E-Bus alternate feed switch is a double pole switch because it controls two things: the E-Bus and battery-to-main-bus circuit. If that switch fails, both electrical paths to the E-Bus could be lost. If you post your electrical schematic on AeroElectric, others can offer suggestions for improvement. Joe __________ Information from ESET NOD32 Antivirus, version of virus signature database 3267 (20080714) __________ The message was checked by ESET NOD32 Antivirus. ________________________________________________________________________________
Date: Jun 05, 2009
Subject: E-bus design goals
At 08:30 PM 6/4/2009, you wrote: >Hi Etienne, > >As best I can recall from over 10 years ago, I decided I did not >want the voltage drop caused by a isolation diode . . . > Yeah, that bit of physics seems to bug some folks . . . but more than necessary or useful. Keep in mind that when the worst happens (alternator quits) the battery delivers energy at 12.5 down to about 11.0 volts. All our electro-whizzies are designed to either produce useful performance over this voltage range else they are NOT suitable for installation in airplanes. When the e-bus is being powered from the main bus via the back-feed isolation diode, the main bus runs at 14.2 to 14.6 volts. A 0.7 to 0.8 volt drop in the diode depresses the e-bus to a minimum of 13.4 volts - a value that is about 1.0 volt HIGHER than delivered by a battery alone. The voltage drop may be reduced by utilization of a Schottky rectifier . . . http://en.wikipedia.org/wiki/Schottky_diode . . . if the builder is willing to give up the cost and convenience of installation for the silicon diode bridge rectifier described in my writings: http://aeroelectric.com/Pictures/Misc/s401-25.jpg Several products crafted for the OBAM aircraft market speak to a design goal for lower voltage drop . . . http://aeroelectric.com/Catalog/AEC/9001/IM9001-700A.pdf http://www.periheliondesign.com/powerschottkydiodes.htm The latter product offers the lower voltage drop characteristic of the Schottky junction diode however, the application schematic shown in the link above is not the correct implementation of the e-bus philosophy described in the 'Connection. See: http://aeroelectric.com/R12A/AppZ_12A3.pdf All this makes a mountain out of a mole hill. When used as illustrated in the Z-figures, the voltage drop offered by either silicon junction or Schottky devices has no operational significance for achieving the original design goals that gave rise to the e-bus about 15 years ago. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 05, 2009
Basically starter contactors are used in addition to the solenoid on the st arter purely to avoid having a permanently hot big fat wire from the batter y to the engine..In the extrordinarilly low risk event that the wire should break and start flailing around under the cowling the consequences are lik ely to be catastrophic..read fire or at least a boiled battery. Low likelyhood/high catastrophy events are hard to quantify in terms of how much protection to add. In the "real" airplane world they went with the ad ditional contactor..Automotive they didn't. Personally I'm comfortable either way...My current RV has a starter contact or mainly cus it was in box..:) Frank ________________________________ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectr ic-list-server(at)matronics.com] On Behalf Of jaybannist(at)cs.com Sent: Thursday, June 04, 2009 4:35 PM Subject: Re: AeroElectric-List: Fwd: Jabiru 3300 starter Ken, Thanks for the reply. Because I have a Corvair engine, in the past, I have not looked at posts dealing specifically with Jabiru systems. I think my confusion comes from the fact that the starter solenoid on my engine is tie d to the started and there is no starter contactor. I think from looking a t the latest Jabiru wiring diagram, one or the other is required, but not b oth. I'm just not sure what is included in the Jabiru FWF package. Thanks again - Jay -----Original Message----- From: Ken <klehman(at)albedo.net> hman(at)albedo.net>> Yes but it has been discussed before and we all hoped someone else would an swer... ;) A conventional battery contactor draws almost 1 amp and can be on continuou sly. A starter contactor is quicker acting, draws more like 4 amps, and is intermittant duty. ie it will overheat and fail if energized continuously. Your call on whether you need a starter contactor as well as a starter sole noid. Is there any chance that both are required for your warranty? I did n ot use a starter contactor on my subaru but I can kill a stuck on starter b y killing a "battery" contactor on my bird. Solenoids on starters do occasi onally but rarely stick on but the same is true for starter contactors. I j udge the risk quite low for an automotive type starter solenoid and a glanc e at the voltage after start up confirms disengagement. Ken ________________________________ Email message sent from CompuServe - visit us today at http://www.cs.com ________________________________________________________________________________
Date: Jun 05, 2009
Is it possible to have both the E-Bus switch and the Master ON at the same time? Wouldn't this power the ebus stuff at full voltage? -Ben Westfall ________________________________________________________________________________
Date: Jun 05, 2009
Subject: Re: Kitfox IV - Jabiru 2200 - Icom IC-A210
Reciving n
Hello EdgePerformance, I'm just suggesting some basic trouble shooting methods. One of those methods is to disable possible antagonists - things that might be creating noise - while still being able to operate the victim. This can help to identify which system is the source of the noise. In turn: - Disable the ignition - Disable the alternator To verify that I understand clearly, you simultaneously turned off both ignitions - causing the engine to stop running, but the prop windmilled the engine for a short time? And the noise was still present, though the frequency was winding down? I would expect that if the ignition were the source of the problem, turning the ignition off would instantly stop the generation of the noise, even as the engine continued to windmill. Assuming this suggests to me that the source of the noise is in the charging system. Can you turn off the alternator while the engine runs? Another way of attacking the problem is to identify how the noise is getting into the victim. - Running the radio from a battery can help identify if noise is getting in through power/ground - Disconnecting the antenna (from the back of the radio) can identify if the noise is coming through the VHF/RF section of the radio More questions: - Do you have a separate audio panel or intercom? Can you disable it? - Does the noise present itself while on the ground (with the engine running)? This would make the debug process easier.. - Is it possible the noise is audio in nature, only (not electrical)? Maybe a mic issue? Disconnect the mic plug from the audio system? On some Permanent Magnet alternator systems, it is recommended that a bypass capacitor be installed at the output of the regulator. A cap with a value of 10kuF with at least a 40V rating would be adequate. I apologize if it seems I'm repeating myself.. I just want to make sure my non-existent Norwegian isn't causing a communication problem. :) Regards, Matt- > > > Hi, > > i have the aerocarb so normally i use idle-cutoff but both magnetic coils > are new and they work fine. Ignition cutoff work great on both cold and hot engine no matter what throttle setting. > > What do you mean by antenna mitigate ? My English aren't that great. (Poor > Norwegian). > > I tried to turn off both ignition switches in flight and the engine didn't > get to stop completely before the transmission was over, but I could clearly hear the noise frequency becoming lower. But that could also be both alternator and ignition I believe. > > I really hope I can figure this out soon so that I can go out and fly my new build jabiru 2200 turbo kitfox IV. > > -------- > Kitfox IV w\ Jabiru 2200 Turbo\Aerocarb > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=246830#246830 > > ________________________________________________________________________________
Date: Jun 05, 2009
Subject: Re: E-bus design goals
From: Mike Fontenot <mikef(at)apexconsultingservices.com>
SW4gdGhlIFoxOSAod2hhdCBJIGRpZCkgdGhlIERpb2RlIGJldHdlZW4gdGhlIE1haW4gUG93ZXIg YnVzIGFuZCB0aGUgRUJ1cwpwcmV2ZW50cyB0aGF0LgoKT24gRnJpLCBKdW4gNSwgMjAwOSBhdCAx MDozMyBBTSwgQmVuIFdlc3RmYWxsIDxydjEwQHNpbmtyYXRlLmNvbT4gd3JvdGU6Cgo+ICBJcyBp dCBwb3NzaWJsZSB0byBoYXZlIGJvdGggdGhlIEUtQnVzIHN3aXRjaCBhbmQgdGhlIE1hc3RlciBP TiBhdCB0aGUKPiBzYW1lIHRpbWU/ICBXb3VsZG6SdCB0aGlzIHBvd2VyIHRoZSBlYnVzIHN0dWZm IGF0IGZ1bGwgdm9sdGFnZT8KPgo+Cj4KPiAtQmVuIFdlc3RmYWxsCj4KPgo+Cj4KPiBfX19fX19f X19fIEluZm9ybWF0aW9uIGZyb20gRVNFVCBOT0QzMiBBbnRpdmlydXMsIHZlcnNpb24gb2Ygdmly dXMKPiBzaWduYXR1cmUgZGF0YWJhc2UgNDEzNCAoMjAwOTA2MDUpIF9fX19fX19fX18KPgo+IFRo ZSBtZXNzYWdlIHdhcyBjaGVja2VkIGJ5IEVTRVQgTk9EMzIgQW50aXZpcnVzLgo+Cj4gKiBfLT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PSBfLT0gLSBUaGUKPiBBZXJvRWxlY3RyaWMtTGlzdCBFbWFpbCBGb3J1bSAtIF8tPSBVc2UgdGhl IE1hdHJvbmljcyBMaXN0IEZlYXR1cmVzCj4gTmF2aWdhdG9yIHRvIGJyb3dzZSBfLT0gdGhlIG1h bnkgTGlzdCB1dGlsaXRpZXMgc3VjaCBhcyBMaXN0Cj4gVW4vU3Vic2NyaXB0aW9uLCBfLT0gQXJj aGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0LCBGQVEsIF8tPQo+IFBo b3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZTogXy09IF8tPSAtLT4gKioKPiBodHRwOi8vd3d3 Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP0Flcm9FbGVjdHJpYy1MaXN0IF8tPQo+IF8tPT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09IF8t PSAtCj4gTUFUUk9OSUNTIFdFQiBGT1JVTVMgLSBfLT0gU2FtZSBncmVhdCBjb250ZW50IGFsc28g YXZhaWxhYmxlIHZpYSB0aGUgV2ViCj4gRm9ydW1zISBfLT0gXy09IC0tPiBodHRwOi8vZm9ydW1z Lm1hdHJvbmljcy5jb20gXy09Cj4gXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT0gXy09IC0gTGlzdAo+IENvbnRyaWJ1dGlvbiBXZWIg U2l0ZSAtIF8tPSBUaGFuayB5b3UgZm9yIHlvdXIgZ2VuZXJvdXMgc3VwcG9ydCEgXy09IC1NYXR0 Cj4gRHJhbGxlLCBMaXN0IEFkbWluLiBfLT0gLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9j b250cmlidXRpb25fLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PQo+ICoKPgoKCgotLSAKTWlrZQoKPT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT0KTWlrZSBGb250ZW5vdApBcGV4IENvbnN1bHRpbmcgJiBTZXJ2aWNlcyBMTEMK TGFrZXdvb2QsIENvbG9yYWRvCjMwMyAvIDczMS02NjQ1Cm1pa2VmIEFUIGFwZXhjb25zdWx0aW5n c2VydmljZXMgRE9UIGNvbQo9PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQo ________________________________________________________________________________
Subject: Re: Kitfox IV - Jabiru 2200 - Icom IC-A210 Reciving
n
From: "EdgePerformance" <post(at)edgeperformance.no>
Date: Jun 05, 2009
Hi Matt, Thanks alot for all suggestions. Yes I believe it may be alternator noise as the prop did windmill for a few second while I was receiving a transmission. I have fully charged my battery now, and will try to take a landing circuit with the alternator wires disconnected. I use the integrated intercom in my Icom IC-A210 transceiver witch works exceptionally great. The intercom and transmissions are crystall clear. The noise does exist on ground, but it seems to affect the radio noise even more as in flight. I will try out all suggestions tomorrow and come back with a test resault. I have also got hold on a new RA-Miller com antenna I will try as well as a completly isolated battery. Thanks again, Thomas intercom(at)spro.net wrote: > Hello EdgePerformance, > > I'm just suggesting some basic trouble shooting methods. One of those > methods is to disable possible antagonists - things that might be creating > noise - while still being able to operate the victim. This can help to > identify which system is the source of the noise. In turn: > > - Disable the ignition > - Disable the alternator > > To verify that I understand clearly, you simultaneously turned off both > ignitions - causing the engine to stop running, but the prop windmilled > the engine for a short time? And the noise was still present, though the > frequency was winding down? I would expect that if the ignition were the > source of the problem, turning the ignition off would instantly stop the > generation of the noise, even as the engine continued to windmill. > Assuming this suggests to me that the source of the noise is in the > charging system. > > Can you turn off the alternator while the engine runs? > > Another way of attacking the problem is to identify how the noise is > getting into the victim. > > - Running the radio from a battery can help identify if noise is getting > in through power/ground > - Disconnecting the antenna (from the back of the radio) can identify if > the noise is coming through the VHF/RF section of the radio > > More questions: > > - Do you have a separate audio panel or intercom? Can you disable it? > > - Does the noise present itself while on the ground (with the engine > running)? This would make the debug process easier.. > > - Is it possible the noise is audio in nature, only (not electrical)? > Maybe a mic issue? Disconnect the mic plug from the audio system? > > On some Permanent Magnet alternator systems, it is recommended that a > bypass capacitor be installed at the output of the regulator. A cap with > a value of 10kuF with at least a 40V rating would be adequate. > > I apologize if it seems I'm repeating myself.. I just want to make sure > my non-existent Norwegian isn't causing a communication problem. :) > > > Regards, > > Matt- > > > > > > > > > > Hi, > > > > i have the aerocarb so normally i use idle-cutoff but both magnetic > > coils > > > > > > are new and they work fine. Ignition cutoff work great on both cold and > > hot engine no matter what throttle setting. > > > > > > > > What do you mean by antenna mitigate ? My English aren't that great. > > (Poor > > > > > > Norwegian). > > > > I tried to turn off both ignition switches in flight and the engine > > didn't > > > > > > get to stop completely before the transmission was over, but I could > > clearly hear the noise frequency becoming lower. But that could also be > > > > both alternator and ignition I believe. > > > > > I really hope I can figure this out soon so that I can go out and fly my > > new build jabiru 2200 turbo kitfox IV. > > > > > > > > -------- > > Kitfox IV w Jabiru 2200 TurboAerocarb > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p 46830#246830 > > > > > > > > > > > > > > > > > > > > > > > > > > > -------- Kitfox IV w\ Jabiru 2200 Turbo\Aerocarb Read this topic online here: http://forums.matronics.com/viewtopic.php?p=247001#247001 ________________________________________________________________________________
Date: Jun 05, 2009
Ed, Wouldn't isolating the battery from the alternator stop the alternator from generating power? Or do you have a permanent magnet alternator? Or was the alternator originally switched to the auxiliary, now non-existent battery to keep feeding your e-bus? Lenny Read this topic online here: http://forums.matronics.com/viewtopic.php?p=247043#247043 ________________________________________________________________________________
Date: Jun 06, 2009
Hi Lenny, I have an auto alternator with internal regulator. The alternator ONLY needs battery voltage to get started - once its producing voltage it uses its own voltage to keep its field coils energized and magnetized. In fact, I can pull the alternator field coil circuit breaker once the engine is running and it has no effect on the alternator. Yes, you do need the battery to jump start /bootstrap the alternator to producing voltage. Now with the typical aircraft alternator, it's a bit different story. They normally have an external regulator which permits you to remove voltage from the alternator field coil and in this case, if you pull the CB and remove voltage from the field coil it will stop producing voltage. But, once again you only need the battery to get it started. At least that is my understanding of the major difference between auto and aircraft alternators. Ed Ed Anderson Rv-6A N494BW Rotary Powered Matthews, NC eanderson(at)carolina.rr.com http://www.andersonee.com http://www.dmack.net/mazda/index.html http://www.flyrotary.com/ http://members.cox.net/rogersda/rotary/configs.htm#N494BW http://www.rotaryaviation.com/Rotorhead%20Truth.htm -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Lenny Iszak Sent: Friday, June 05, 2009 10:45 PM Subject: AeroElectric-List: Re: Essential Incident - Almost (Long) Ed, Wouldn't isolating the battery from the alternator stop the alternator from generating power? Or do you have a permanent magnet alternator? Or was the alternator originally switched to the auxiliary, now non-existent battery to keep feeding your e-bus? Lenny Read this topic online here: http://forums.matronics.com/viewtopic.php?p=247043#247043 __________ Information from ESET NOD32 Antivirus, version of virus signature database 3267 (20080714) __________ The message was checked by ESET NOD32 Antivirus. __________ Information from ESET NOD32 Antivirus, version of virus signature database 3267 (20080714) __________ The message was checked by ESET NOD32 Antivirus. ________________________________________________________________________________
From: "nuckollsr" <bob.nuckolls(at)aeroelectric.com>
Date: Jun 06, 2009
There are no risks to electro-whizzies for operating the airplane with the e-bus alternate feed switch ON. However, you need to pre flight test the two power paths for operation. The original operating protocols suggested closing the e-bus alternate feed switch to power up the comm radio to get the ATIS and/or clearance delivery. This presumes, of course that your departure field has such services. If not, then closing this switch momentarily before doing anything else proves availability of this power path. The e-bus alternate feed switch would be off after closing the battery contactor and during engine start. After engine start, the e-bus should be verified energized via the normal feed path diode thus proving that power path. Re-closing the e-bus alternate feed switch later for the purpose of "getting the e-bus voltage up" offers no risk to the system or equipment. Be sure to add "E-bus alternate feed switch - OFF" to the post-flight check list. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=247068#247068 ________________________________________________________________________________
Date: Jun 06, 2009
Does anyone know if the 1/8-inch phone jack audio output on a Garmin 396 is stereo or monaural? I plan to route this output into the monaural input of the intercom. If the Garmin output is stereo, I can do the two-resistor mixer that was mentioned previously in this thread. Roger Cole 1946 Cessna 140, flying Murphy Elite #709, working on fuselage rcole927(at)earthlink.net On Jun 5, 2009, at 12:40 AM, Chris Hand wrote: > decades news. If you > with play time of 6 hours > > > > Actually, I use a Sony Walkman in my RV-6A that has something on > the order of 400+ songs right now with plenty of storage room to > spare for more songs, videos, photos, etc. Weighs a few ounces, > plugs into my intercom, didn't cost much, and works great. It's a > Sony Walkman digital media player - smaller physical size than the > i-pods my kids prefer and does all I want for the RV. Although > once upon a time I did have one of the Walkman units you are > talking about, Sony has rehashed the name with current > technology.....not sure which era Don's Walkman is from. > > Chris > > ----- Original Message ----- > From: gmcjetpilot(at)yahoo.com > To: aeroelectric-list(at)matronics.com ; don(at)contractorsnorthwest.com > Sent: Monday, June 01, 2009 3:00 AM > Subject: AeroElectric-List: Re: Stereo to Mono > > I would not use a stereo to mono jack to go FROM stereo to MONO. It > really is made > for going from mono to drive a stereo headphone, split to drive > both L & R channels. > It is not designed to combine stereo to mono. > > Whats the big deal? Shorting L & R of an amp can cause damage, even > an iPod. If the > "Walkman" has a mono switch than its OK, but iPods do not have mono > switches. > > If you don't have a MP3 player (iPod) get one. Walkman are last > decades news. If you > don't have an iPod you can get 100's of hours of music on them with > play time of 6 hours > per charge. They are also small and light weight. > > There are some threads on how to properly combine stereo and ground > issues in this > forum. Just use the search engine. The easy way is with capacitor > and resistor, which > you can wire behind the panel. You would use a stereo 1/8" phone > jack and then > go from stereo to mono with the isolation Cap and Resistor. > > Cheers George > > > >From: <bakerocb(at)cox.net> > >Subject: AeroElectric-List: Stereo to Mono > > > >5/30/2009 > >Hello Don, You wrote: "I want to install a plug in my panel to > plug my > >stereo Walkman into but my intercom (PM1000 II) is mono." > >Here is one way to solve that problem -- > > >http://www.radioshack.com/product/index.jsp?productId=2102669 > > >This adapter will put the output of a mono jack on your panel into > both > >sides of your stereo Walkman. > > >Also take a look at some of the other adapters available. You may > want to > >put a normal airplane earphone sized jack on your instrument panel > so that > >either your Walkman (with an adapter) or an airplane earphone set > (without > >adapter) may be plugged in. > > > >=========================== > >> > >>Subject: AeroElectric-List: Stereo to Mono > >>From: "Don McIntosh" <don(at)contractorsnorthwest.com> > >> > >>I want to install a plug in my panel to plug my stereo Walkman > into but my > >>intercom (PM1000 II) is mono. Can I just splice the Right and > Left leads together > >>to go into the intercom? Also the intercom pins are labeled "HI" > and "LOW". > >>Is this just the pin identification numbers? > >>-------- > >>Don McIntosh > >>Kitfox Series 7 under construction > >>Jabiru 3300 > > href="http://www.matronics.com/Navigator?AeroElectric-List">http:// > www.matronics.com/Navigator?AeroElectric-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http:// > www.matronics.com/c > > ________________________________________________________________________________
Subject: xponder ant mounting
Date: Jun 06, 2009
Since I already installed a reinforcement plate into the floor of my tailcone to mount my ground power receptacle, is there any reason that I can't mount my transponder antenna into the same plate an inch or two from the piper plug receptacle? Thanks in advance. I am loathe to drill holes into my skin without checking first. -------- Myron Nelson Mesa, AZ Emp completed, legacy build fuse in progress Read this topic online here: http://forums.matronics.com/viewtopic.php?p=247103#247103 ________________________________________________________________________________
Date: Jun 06, 2009
I think I have a similar problem in a spam can. There is a 1/8 plug coming out of the intercom that I can plug into a Garmin 496. The results are audible but poor. XM radio is barely audible but verbal warnings from the 496 are much clearer. Could it be that I need a 1/8 mono to stereo adapter or is additional wiring required? Can I measure the resistance of the adapter to determine if it contains more than a solid connection? John Morgensen Roger Cole wrote: > Does anyone know if the 1/8-inch phone jack audio output on a Garmin > 396 is stereo or monaural? I plan to route this output into the > monaural input of the intercom. If the Garmin output is stereo, I can > do the two-resistor mixer that was mentioned previously in this thread. > > Roger Cole > 1946 Cessna 140, flying > Murphy Elite #709, working on fuselage > rcole927(at)earthlink.net > ________________________________________________________________________________
Subject: Wiring is done but SL-30 comm won't transmit
Date: Jun 06, 2009
I used the bottom half of the Z-13 or I guess the Z-11 drawings. Finally turned on the Master Switch. The good news all the smoke stayed in the wires and the fuses didn't blow. The radio receives loud and clear. The only problem is when I hit the PTT on the SL-30 all I get is a loud squeal, thank goodness ground control didn't know where it was coming from, where do I start looking, using the old look for the simple fixes first? I have the CH stick grips with the PTT in the trigger portion. I'm sure that I'm not the first that has experienced this problem but couldn't find anything in the archives so would appreciate any helpful suggestions. Jim Thorne RV-7A CHD Getting close ________________________________________________________________________________
Subject: Cessna 150F Landing/Taxi light switch.
Date: Jun 06, 2009
I have a very basic question. The switch in question burnt out so I obtained a replacement. For the life of me I can't figure out which wire goes where. I have three wires, power and feeds to the Landing and Taxi lights. The switch has four connectors marked H,R,A, B. The case is marked 600 and is a pull switch with two positions. Can anyone help? I am aware it is not RV related. When I'm not flying my RV4 I have the Cessna to take pictures etc. SSD ________________________________________________________________________________
Subject: Re: Wiring is done but SL-30 comm won't transmit
Date: Jun 06, 2009
Jim, I had the same thing and it turned out to be a shorted antenna cable. Disconnect the cable at both ends and use an ohm meter to determine if the center connector is shorted to the ground. In my case, one of the BNC connectors was shorted. Hope this helps. Floyd Wilkes 601XL ----- Original Message ----- From: Jim Thorne To: aeroelectric-list(at)matronics.com Sent: Saturday, June 06, 2009 5:55 PM Subject: AeroElectric-List: Wiring is done but SL-30 comm won't transmit I used the bottom half of the Z-13 or I guess the Z-11 drawings. Finally turned on the Master Switch. The good news all the smoke stayed in the wires and the fuses didn't blow. The radio receives loud and clear. The only problem is when I hit the PTT on the SL-30 all I get is a loud squeal, thank goodness ground control didn't know where it was coming from, where do I start looking, using the old look for the simple fixes first? I have the CH stick grips with the PTT in the trigger portion. I'm sure that I'm not the first that has experienced this problem but couldn't find anything in the archives so would appreciate any helpful suggestions. Jim Thorne RV-7A CHD Getting close ________________________________________________________________________________
Date: Jun 06, 2009
When you hit the trigger, does the SL30 TX light go on - indicating that the mic was keyed? ----- Original Message ----- From: Jim Thorne To: aeroelectric-list(at)matronics.com Sent: Saturday, June 06, 2009 6:55 PM Subject: AeroElectric-List: Wiring is done but SL-30 comm won't transmit I used the bottom half of the Z-13 or I guess the Z-11 drawings. Finally turned on the Master Switch. The good news all the smoke stayed in the wires and the fuses didn't blow. The radio receives loud and clear. The only problem is when I hit the PTT on the SL-30 all I get is a loud squeal, thank goodness ground control didn't know where it was coming from, where do I start looking, using the old look for the simple fixes first? I have the CH stick grips with the PTT in the trigger portion. I'm sure that I'm not the first that has experienced this problem but couldn't find anything in the archives so would appreciate any helpful suggestions. Jim Thorne RV-7A CHD Getting close ________________________________________________________________________________
Date: Jun 06, 2009
The Garmin 396 owner's manual makes reference to connecting stereo headphones to the audio jack on the 396 (p114). I plug my 396 into my car stereo's aux port all the time. I'm pretty sure I get stereo signals from it. Regards, Matt- > I think I have a similar problem in a spam can. There is a 1/8 plug > coming out of the intercom that I can plug into a Garmin 496. The > results are audible but poor. XM radio is barely audible but verbal > warnings from the 496 are much clearer. Could it be that I need a 1/8 > mono to stereo adapter or is additional wiring required? > > Can I measure the resistance of the adapter to determine if it contains > more than a solid connection? > > John Morgensen > > Roger Cole wrote: >> Does anyone know if the 1/8-inch phone jack audio output on a Garmin >> 396 is stereo or monaural? I plan to route this output into the >> monaural input of the intercom. If the Garmin output is stereo, I can >> do the two-resistor mixer that was mentioned previously in this thread. >> >> Roger Cole >> 1946 Cessna 140, flying >> Murphy Elite #709, working on fuselage >> rcole927(at)earthlink.net >> > > ________________________________________________________________________________
Subject: RF interference fix?
Date: Jun 07, 2009
>From first flight, the GRT EFIS and EIS on my RV have indicated momenta ry, anomalously high fuel pressure readings, typically just before take-off and also when entering and in the pattern. Stewed over that for over a yea r before asking myself the question - how does the system KNOW Im going t o takeoff or land? Asking that question led me to the only possible answ er: it knows because I get on comm and announce it! A couple of weeks ago I confirmed this - every comm transmission resulted in a sharp rise in fu el pressure. Yesterday I took it a step further, seeking to determine wha t the propogation mode was, and reasoned it was either RF interference or some sort of magnetic coupling associated with the increased power requirements during comm transmissions. The easy test was to get out m y battery operated handheld transceiver and transmit from inside the cock pit with the engine running and the EFIS/EIS powered up, so I did that firs t. Bingo - a similar increase in the fuel pressure reading, although to a lesser degree than with ship's comm. Also noticed a lot of noise on my handheld when receiving from inside the cockpit - noise that isnt noticeable on ship's comm, nor on the handheld normally.So, now Im feel ing pretty high and mighty with my diagnostic skills, but the problem still remains - where do I go from here to fix this? thanks erich This e-mail and any attachments contain URS Corporation confidential information that may be proprietary or privileged. If you receive this message in error or are not the intended recipient, you should not reta in, distribute, disclose or use any of this information and you should dest roy the e-mail and any attachments or copies. ________________________________________________________________________________
Date: Jun 07, 2009
Subject: Re: Cessna 150F Landing/Taxi light switch.
At 06:24 PM 6/6/2009, you wrote: >I have a very basic question. The switch in question burnt out so I >obtained a replacement. For the life of me I can't figure out which >wire goes where. I have three wires, power and feeds to the Landing >and Taxi lights. The switch has four connectors marked H,R,A, >B. The case is marked 600 and is a pull switch with two positions. >Can anyone help? I am aware it is not RV related. When I'm not >flying my RV4 I have the Cessna to take pictures etc. >SSD It has been a VERY long time since I've seen these switches installed on the Cessnas but if it's a 4-terminal switch I suspect that an ohmmeter test will show that with the switch has no connections with the handle all the way in. With the handle pulled to the first notch, I think the pair of terminals furthest from the panel will be connected to each other. This pair is the taxi light circuit. With the handle all the way out, the pair of terminals closest to the panel will be connected to turn on the landing light. In this position, the taxi light will be out. Here's an exemplar 4-terminal push-pull switch from Cole-Hersee Emacs! Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 08, 2009
At 11:27 AM 6/7/2009, you wrote: From first flight, the GRT EFIS and EIS on my RV have indicated momentary, anomalously high fuel pressure readings, typically just before take-off and also when entering and in the pattern. Stewed over that for over a year before asking myself the question - how does the system KNOW Im going to takeoff or land? Asking that question led me to the only possible answer: it knows because I get on comm and announce it! A couple of weeks ago I confirmed this - every comm transmission resulted in a sharp rise in fuel pressure. Yesterday I took it a step further, seeking to determine what the propogation mode was, and reasoned it was either RF interference or some sort of magnetic coupling associated with the increased power requirements during comm transmissions. The easy test was to get out my battery operated handheld transceiver and transmit from inside the cockpit with the engine running and the EFIS/EIS powered up, so I did that first. Bingo - a similar increase in the fuel pressure reading, although to a lesser degree than with ship's comm. This is not an uncommon problem with products offered to the OBAM aircraft community. In the TC aircraft world, we have to demonstrate immunity from commonly encountered radio frquency stresses in the lab during qualification tests. Some of the instruments offere by Van's have demonstrated sensitivity to VHF comm signals from ship's transmitters. Talk to GRT first. They have certainly encountered this before. They know their product better than anyone else and should be able to recommend some filtering . . . probably compoents added at the connector where the pressure transducer wires come into the indicator. Don't be surprised that there isn't a fix either. These issues are realtively easy to fix during prouduct development and qualification . . . but MUCH more difficult later. Also noticed a lot of noise on my handheld when receiving from inside the cockpit - noise that isnt noticeable on ship's comm, nor on the handheld normally.So, now Im feeling pretty high and mighty with my diagnostic skills, but the problem still remains - where do I go from here to fix this? Igntion noise? The best way to enhance the performance of a hand held transceiver is to provide connections to the ship's regulator comm antenna. I used to recommend a coiled loop of coax within reach of pilot in the cockpit that could be opened with a pair of in-line connectors. http://www.aeroelectric.com/Pictures/Connectors/Coax/BNC_Cable_Female_1.jpg http://www.aeroelectric.com/Pictures/Connectors/Coax/BNC_Cable_Male.jpg Put the cable-male on the feeder that goes to the the antenna and leave enough slack in it to allow connection to the hand-held. A pair of right-angle coax adapers http://www.aeroelectric.com/Pictures/Connectors/Coax/BNC_Rt-Angle_Adapt_2.jpg can be used to do a small radius 180 degree turn in the coax so that it will lay against the back of the hand-held and exit downward. Bob . . . Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 08, 2009
Subject: Re: RF interference fix?
At 06:31 AM 6/8/2009, you wrote: > > >At 11:27 AM 6/7/2009, you wrote: > The easy test was to get out my battery operated handheld > transceiver and transmit from inside the cockpit with the engine > running and the EFIS/EIS powered up, so I did that first. Bingo - > a similar increase in the fuel pressure reading, although to a > lesser degree than with ship's comm. P.S. You may find it more practical to live with it. After one understands how the problem manifests itself then it may be easier to just let it go. I've had several customers who've elected to not pursue a best-we-know- how-to-do fix when the $time$ associated with the fix was going to be pretty high. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 08, 2009
Subject: Stero to Mono
At 06:40 AM 6/4/2009, you wrote: Greetings... I'm a bit confused on this subject after reading this thread and similar threads in other lists. I have the same objective: plug my iPod into my Xcom 760's audio in. The Xcom's documentation says to use a 3.5mm mono jack in combination with a stereo-to-mono adapter plug. My thought was to eliminate the adapter plug by simply jumping the left/right channel pins on the jack itself, and this does indeed give [seemingly] good results with both channels clearly heard. But lately I've read that this may damage the iPod, and I should be using resistors/capacitors and/or the adaptor, as though the adaptor had some components built into it's small, moulded little case. I'm relatively sure that this adaptor plug is doing nothing but physically joining the left and right channels from the stereo plug into a single tip on the mono plug, and is in no way electronically 'magic'. Not wanting to damage my iPod, I'd be interested to know the science behind all the posts saying 'don't do it' (wire the left and right together), use the adaptor plug. Thanks! The roots of this thread go back a few years. The first adaptation I recall of a common commercial stereo music product into an OBAM aircraft was for a builder wanting to adapt a compact automotive AM/FM radio to his airplane. In fact, he had pulled a non-working ADF and was plugging the hold with the automotive receiver. He missed the ADF's ability to turn the AM radio stations. This was before car radios featured low-level audio output/input jacks. The only outputs were intended to deliver WATTS of energy to speakers. Voltage levels at the speaker output of such radios were much higher than necessary to service the headphone level inputs to intercom systems in tens of milliwatts. The task then had several considerations. The output stages of the radio were designed to deliver energy to low resistance loads (4 ohm speakers). If not similarly loaded in this new application, audio quality at low output levels might suffer (cross-over distortion). So the first thing we did was "load" the radio with some handy but relatively low value resistor . . . 10 ohms, 1 watt was common. After that, the too-high output voltage needed to be attenuated to levels appropriate to headphone input levels at the intercom. At the same time, the right-left stereo signals needed to be mixed in a manner that provided a summation of the two signals, not a conflict. By conflict, I mean that simultaneous positive and negative going transients in program material do not cause large currents to circulate between the right and left amplifier output stages. The risk for damage to the system is low. The strongest effect for these circulating currents is distortion of the audio. It's common practice to first reduce the potential for circulating currents between the two outputs by artificially raising their output impedances (series resistors) and then setting the system losses with a downstream load (parallel resistor) to set volume. In this example http://aeroelectric.com/Pictures/Schematics/WalkmanAdapter.gif only mixing resistors are called for but if the signals from the audio source proved too strong, a resistor on the order of 10 to 100 ohms could be paralleled with the output to bring the level down to size. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 08, 2009
Subject: Re: Stero to Mono
Robert L. Nuckolls, III wrote: > > The roots of this thread go back a few years. The > first adaptation I recall of a common commercial > stereo music product into an OBAM aircraft was for > a builder wanting to adapt a compact automotive > AM/FM radio to his airplane. In fact, he had pulled > a non-working ADF and was plugging the hold with the > automotive receiver. He missed the ADF's ability to > turn the AM radio stations. > ---------------snip ------------- Thanks so much for this inclusive explanation, Bob. In my particular case, though, I *think* it's safe to assume that the modern Xcom 760 radio is designed with iPod/CD player input in mind, and that any attenuation/gain/amplification is done on the radio's c.b. The fact that the manufacturer states to simply use a 3.5mm mono jack along with a stereo-to-mono adapter plug from the iPod headphone out, enforces this assumption, in my mind. My question, really, is if shorting the ring and tip pins on a stereo jack installed on my panel is the electrical equivalent of using the adapter plug. Which begs the question: do those adapter plugs contain any sort of electronic components at all? Since the price of these critters ranges from $1.00 at the Dollar store to $9.95 at the Source (Canadian Radio Shack, gold plated), perhaps the high-end ones do, but I doubt it. The sound is good the way I've got it (jack pins connected), hearing both channels mixed, good volume. Just don't want to put my little iTouch at risk, as some have implied I may be doing... Thanks, again! -- Regards, J. Sonex C-FJNJ, Jab 3300, Prince P-Tip http://cleco.ca +-------------------------------------------------------------+ | J. Davis, M.Sc. | (computer science) | | *NIX consulting, SysAdmin | email: jd at lawsonimaging.ca | +-------------------------------------------------------------+ and now... Deep Thought #35, by Jack Handy When you go in for a job interview, I think a good thing to ask is if they ever press charges. ________________________________________________________________________________
Date: Jun 08, 2009
>Thanks so much for this inclusive explanation, Bob. In my particular >case, though, I *think* it's safe to assume that the modern Xcom 760 >radio is designed with iPod/CD player input in mind, and that any >attenuation/gain/amplification is done on the radio's c.b. The fact >that the manufacturer states to simply use a 3.5mm mono jack along >with a stereo-to-mono adapter plug from the iPod headphone out, >enforces this assumption, in my mind. Yes, we're talking headphone levels for signal strength in both the aviation and the pocket entertainment world. These voltage levels are on in the ballpark with votlages that are exchanged between component systems on their line-in/out jacks. >My question, really, is if shorting the ring and tip pins on a >stereo jack installed on my panel is the electrical equivalent of >using the adapter plug. Which begs the question: do those adapter >plugs contain any sort of electronic components at all? Since the >price of these critters ranges from $1.00 at the Dollar store to >$9.95 at the Source (Canadian Radio Shack, gold plated), perhaps the >high-end ones do, but I doubt it. The sound is good the way I've got >it (jack pins connected), hearing both channels mixed, good volume. >Just don't want to put my little iTouch at risk, as some have >implied I may be doing... The only way to see if there are components included inside the adapter is to research it from outside with test equipment. I suspect they have none. Modern integrated circuits are quite tolerant of "circulating currents" so if you're satisfied with the audio quality then no further action is necessary. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 08, 2009
Subject: Re: xponder ant mounting
At 01:55 PM 6/6/2009, you wrote: > >Since I already installed a reinforcement plate into the floor of my >tailcone to mount my ground power receptacle, is there any reason >that I can't mount my transponder antenna into the same plate an >inch or two from the piper plug receptacle? > >Thanks in advance. I am loathe to drill holes into my skin without >checking first. I see no structural problems with it . . . One usually mounts the xponder antenna on the belly centerline. I presume your ground power jack structure is off to one side. I doubt that an off-center antenna location is any big deal. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 08, 2009
Thanks for the response Bob. I have called GRT - they did not seem to be familiar with this problem. I am also a follower of the Vans Air Force list and multiple posts there have turned up only one other individual with similar fuel pressure symptoms, and I wasnt ever able to confirm that h is problem was RF related. This all seems strange to me as there are many RVs with similar equipment (SL-40 comm, GRT EFIS/EIS) and wiring (Z-13/8) t hat have my problem. Anyway, GRT suggested a ferrite filter , which I trie d without success. Looks like I may just have to live with this issue. Good to know that the noise I hear on my handheld will likely disappear by connecting it to ships antenna. I have a small device that allows switching between two radios on a single antenna, but have not yet hook ed it up - on my to do list. thanks again Erich ________________________________________________________________________________
Subject: Z12 questions
Date: Jun 09, 2009
I already have a B&C 40 amp alternator and a B&C SD20 aux alternator instal led on my Lycoming. I also have 2 B&C LR3 regulators. Now I'm contemplatin g swapping one of the LR3 regs for a SB-1 and using architecture Z12. I'm p lanning on an IFR ship for long distance international flights. These are my questions: 1. Is the battery contactor on Z12 a single point of failure that will take out both of my alternators and leave me with only battery power. If so is there a mod to Z12 that gets around this. 2. Under certain extreme power use configurations I may marginally exceed t he capacity of the 40 amp main alternator. If the capacity of the 40 amp al ternator is exceeded and the bus voltage sags will the 20 amp aux alternato r switch on automatically (when regulated by the SB-1 regulator) and run co ncurrently with the 40 amp main alternator to effectively provide 60 amps o f useable current. Regards Bob Barrow RV7A _________________________________________________________________ View photos of singles in your area Click Here http://dating.ninemsn.com.au/search/search.aspx?exec=go&tp=q&gc=2&tr =1&lage=18&uage=55&cl=14&sl=0&dist=50&po=1&do=2&trackingid =1046138&r2s=1&_t=773166090&_r=WLM_EndText ________________________________________________________________________________
Date: Jun 09, 2009
Bob et al... While on the subject of xponder antennae... I am helping with wiring of a Kitfox (rag & tube) and we need to mount a xponder antenna. IIRC the antenna requires a ground plane 12 inches in diameter. Is this correct? The xponder frequencys are 1030 and 1090Mhz which is a wavelength of about 291mm and 275mm or about 12 and 11 inches. I would think I would tune for the lower freq as the higher would be inclusive. A 12 inch diameter aluminum plate with the antenna monted in the center is my plan... please feel free to educate me further! Thanks... Chris Stone Newberg, OR Rv's 'n' Kitfox's -----Original Message----- >From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> >Sent: Jun 8, 2009 10:26 AM >To: aeroelectric-list(at)matronics.com >Subject: Re: AeroElectric-List: xponder ant mounting > > >At 01:55 PM 6/6/2009, you wrote: >> >>Since I already installed a reinforcement plate into the floor of my >>tailcone to mount my ground power receptacle, is there any reason >>that I can't mount my transponder antenna into the same plate an >>inch or two from the piper plug receptacle? >> >>Thanks in advance. I am loathe to drill holes into my skin without >>checking first. > > I see no structural problems with it . . . > > One usually mounts the xponder antenna > on the belly centerline. I presume your > ground power jack structure is off to one > side. I doubt that an off-center antenna > location is any big deal. > > > Bob . . . > > --------------------------------------- > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > --------------------------------------- > > ________________________________________________________________________________
Subject: Re: Z12 questions
Date: Jun 09, 2009
I would consider keeping the LR3 and use Z-14. It would address both of your concerns. You would need another battery though. -------- rck Read this topic online here: http://forums.matronics.com/viewtopic.php?p=247431#247431 ________________________________________________________________________________
Date: Jun 09, 2009
From: "John F. Herminghaus" <catignano(at)tele2.it>
Subject: Ground planes
What is the acceptable/recommended resistance from a transponder antenna to its ground plane. Have built your low ohm meter, so can measure in milliohms. Regards, John Herminghaus ________________________________________________________________________________
Date: Jun 09, 2009
In my last post I said: "This all seems strange to me as there are man y RVs with similar equipment(SL-40 comm, GRT EFIS/EIS)and wiring(Z-13/8)t hat have my problem." Meant to say "....that DONT have my problem". Makes more sense that way eh? Got a private email from a List follower inquiring about the 'device' referenced in my earlier post - it allows use of a handheld comm on the main ships antenna for emergency use. Bob reviewed this product some t ime ago and seemed to think it was satisfactory. Here is a link to it http://www.edmo.com/index.php?module=products&func=display&prod_id= 19280&cat_id You will likely want to also get a patch cord to allow you to hook up y our headset to the handheld to make it easier to hear/transmit erich ________________________________________________________________________________
Date: Jun 09, 2009
At 10:11 AM 6/9/2009, you wrote: > >I would consider keeping the LR3 and use Z-14. It would address >both of your concerns. You would need another battery though. > >-------- >rck Good answer. Z12 is a dual alternator enhancement of Z12 that emulates the SD20 standby alternator offered as STC on LOTS of TC aircraft. I'll suggest that Z-13/8 is the elegant solution for cost/weight/performance/reliability/simplicity. If you're going to hang an SD20 on a fresh design, then Z-14 is the better if not a bit heavier choice. You can go to the smallest of engine cranking batteries because of Z-14's ability to parallel them during cranking. Alternatively, battery contactor failure is pretty rare . . . and you have the e-bus alternate feed to back it up. You could consider a premium low-power contactor and probably be just fine with Z-12 and and SD-20/LR3 combination. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 09, 2009
At 08:00 AM 6/9/2009, you wrote: >I already have a B&C 40 amp alternator and a B&C SD20 aux alternator >installed on my Lycoming. I also have 2 B&C LR3 regulators. Now I'm >contemplating swapping one of the LR3 regs for a SB-1 and using >architecture Z12. I'm planning on an IFR ship for long distance >international flights. > >These are my questions: > >1. Is the battery contactor on Z12 a single point of failure that >will take out both of my alternators and leave me with only battery >power. If so is there a mod to Z12 that gets around this. > >2. Under certain extreme power use configurations I may marginally >exceed the capacity of the 40 amp main alternator. If the capacity >of the 40 amp alternator is exceeded and the bus voltage sags will >the 20 amp aux alternator switch on automatically (when regulated by >the SB-1 regulator) and run concurrently with the 40 amp main >alternator to effectively provide 60 amps of useable current. Yes, you can run both alternators together but getting them to share proportionately is difficult without special paralleling regulators. What situation demands more than 40A? Alternatively, consider Z-14 and split the loads between the two alternators. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Subject: Canopy Switch
Date: Jun 09, 2009
I want to add a canopy (open) warning switch to my Lanciar Legacy. I've got a Dynon 180 which handles all the high tech stuff but I need the appropriate switch and vendor information from which to source it. Naturally the switch should be low profile or recessed and perhaps be adjustable in depth such that it could be adjusted to the canopy tightness. The premise of the Dynon is to alert via a contact light of a normally closed or normally open item. Basically if it's grounded, it closes the switch and allows the turns the light green. If you have completed such an installation I'd be glad to hear of what switch you used and related frustrations if any. Thanks in advance, Glenn ________________________________________________________________________________
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
Date: Jun 09, 2009
Personally I would use a buzzer from Radio shack instead of a light so it works in bright sunlight. Don't know if the Dynon will drive a buzzer or not but you might just avoid the Dynon altogether and run the buzzer through the switch. I'm assuming here you want a warning that you left your master on?...if so you could wire the switch such the ground path goes thru the master switch. If you just want a canopy open switch (not sure what value it really has?) then you can just wire a simple circuit thru the buzzer or light your choice. Either way there is not much point in going through the Dynon. Frank RV7a D100 and Ems10 I want to add a canopy (open) warning switch to my Lanciar Legacy. I've got a Dynon 180 which handles all the high tech stuff but I need the appropriate switch and vendor information from which to source it. Naturally the switch should be low profile or recessed and perhaps be adjustable in depth such that it could be adjusted to the canopy tightness. The premise of the Dynon is to alert via a contact light of a normally closed or normally open item. Basically if it's grounded, it closes the switch and allows the turns the light green. If you have completed such an installation I'd be glad to hear of what switch you used and related frustrations if any. Thanks in advance, Glenn ________________________________________________________________________________
Date: Jun 09, 2009
Subject: Re: Ground planes
At 10:23 AM 6/9/2009, you wrote: > > >What is the acceptable/recommended resistance from a transponder >antenna to its ground plane. Have built your low ohm meter, so can >measure in milliohms. If you pay attention to cleanliness and pressure on the mounting hardware surfaces that make contact . . . see: http://aeroelectric.com/Pictures/Antenna/Comm_Antenna_Installation.gif This shows a comm antenna with a base attached with screws. If you're mounting a blade transponder antenna the same rules apply. If you're mounting one of these things . . . http://aeroelectric.com/Pictures/Antenna/Transponder_1.jpg then all of the "grounding" happens under the nut (not the best place but the outside flange holds the gasket). The internal tooth lockwasher under the nut "bites" into the ship's inner skin for ground. In any case, it's unlikely that you'll measure anything significant with the low-resistance ohmmeter. A bonding meter measures in fractions of micro-ohms. Bottom line is that 99.999% of all antennas installed with reasonable care for cleanliness and pressure at the critical joints are going to be just fine. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 09, 2009
At 10:57 AM 6/9/2009, you wrote: >In my last post I said: "This all seems strange to me as there are >many RVs with similar equipment(SL-40 comm, GRT EFIS/EIS)and wiring(Z-13/8)that >have my problem." Meant to say "....that DONT have my >problem". Makes more sense that way eh? > >Got a private email from a List follower inquiring about the >'device' referenced in my earlier post - it allows use of a handheld >comm on the main ships antenna for emergency use. Bob reviewed this >product some time ago and seemed to think it was satisfactory. Here >is a link to it > ><http://www.edmo.com/index.php?module=products&func=display&prod_id=19280&cat_id>http://www.edmo.com/index.php?module=products&func=display&prod_id=19280&cat_id > >You will likely want to also get a patch cord to allow you to hook >up your headset to the handheld to make it easier to hear/transmit I really don't like those things . . . they use a miniature phone jack that looks like #2 in the view below. Emacs! It features a normally closed switch strut to provide "feed through" of antenna connection to the panel mounted comm. This "switch" is low pressure, exposed to atmosphere and not terribly reliable. If the thing gives you problems, the intermittent will be with the panel mounted radio. I would prefer/recommend breaking into a coil bit of slack in your regular comm antenna coax. You shouldn't have to do this very often which offsets the inconvenience. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 09, 2009
At 08:40 AM 6/9/2009, you wrote: Bob et al... While on the subject of xponder antennae... I am helping with wiring of a Kitfox (rag & tube) and we need to mount a xponder antenna. IIRC the antenna requires a ground plane 12 inches in diameter. Is this correct? The xponder frequencys are 1030 and 1090Mhz which is a wavelength of about 291mm and 275mm or about 12 and 11 inches. I would think I would tune for the lower freq as the higher would be inclusive. A 12 inch diameter aluminum plate with the antenna monted in the center is my plan... please feel free to educate me further! The "ideal" ground plane has a radius equal to the height of the antenna. I.e., about 2.6" for a transponder. Anything bigger, such as the 12" diameter is not a "tuned" ground plane in which case make it any size you wish. Anything bigger than the 2.6" radius is not going to significantly alter performance. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Subject: problem in Bob's Wigwag.pdf circuit?
Date: Jun 09, 2009
Hello - I am new to the list so please don't flame me for posting this. I am designing my landing lights around the circuit on page 4 of Bob's Wigwg.pdf. This is the circuit that uses the 4PDT switch, marked "4TL1-10 or equal" I just ordered my switch today. My design goal of this circuit is to have the switch function as OFF-WIGWAG-ON, with OFF in the bottom position. In completing my design, I noticed in the Honeywell datasheet for the 4TL1-10 switch (available at this link: http://www.datasheetarchive.com/4TL1-10-datasheet.html ) does not match the one in Bob's schematic. The problem is that for the -10 switch in the datasheet, there are two poles (pins 8 & 11) that are open in the center condition. The switch in Bob's circuit requires all poles to be active in all positions. After careful datasheet reading, I think that Bob's design will work with a 4TL1-12 switch. It is supposedly the same circuitry as a -50 (which looks right) and has no momentary positions. Can anyone confirm that I need to cancel my order for the -10 and get a -12 instead? I'm hoping to find out quickly to avoid buying the wrong switch. I did search the archive and found a single poster mentioning that the circuit didn't work... maybe this was why? Thanks for any info, dave ________________________________________________________________________________
Date: Jun 09, 2009
Frank, Thanks for your ideas. No, actually I want what I asked for, a canopy alert light, not a "I forgot the master" warning light. The Dynon has some great contact display features that allow one to connect gear down, canopy open type things. When I'm ready to launch I'm looking strait at the EFIS and should see a big red light. You are correct, the sun can be a factor, but in PA where I live, rarely so. The probability of forgetting the canopy on a sunny day in PA is probably much less than forgetting it on an overcast day. The buzzer is a great idea, but does one really want the buzzer in your ears anytime the master is on and you are running around in sweat with the canopy in tilt position? I will stick to trying to find the right switch for mounting on the canopy jam. Glenn ________________________________ From: owner-aeroelectric-list-server(at)matronics.com on behalf of Hinde, Frank George (Corvallis) Sent: Tue 6/9/2009 5:47 PM Subject: RE: AeroElectric-List: Canopy Switch (Corvallis)" Personally I would use a buzzer from Radio shack instead of a light so it works in bright sunlight. Don't know if the Dynon will drive a buzzer or not but you might just avoid the Dynon altogether and run the buzzer through the switch. I'm assuming here you want a warning that you left your master on?...if so you could wire the switch such the ground path goes thru the master switch. If you just want a canopy open switch (not sure what value it really has?) then you can just wire a simple circuit thru the buzzer or light your choice. Either way there is not much point in going through the Dynon. Frank RV7a D100 and Ems10 I want to add a canopy (open) warning switch to my Lanciar Legacy. I've got a Dynon 180 which handles all the high tech stuff but I need the appropriate switch and vendor information from which to source it. Naturally the switch should be low profile or recessed and perhaps be adjustable in depth such that it could be adjusted to the canopy tightness. The premise of the Dynon is to alert via a contact light of a normally closed or normally open item. Basically if it's grounded, it closes the switch and allows the turns the light green. If you have completed such an installation I'd be glad to hear of what switch you used and related frustrations if any. Thanks in advance, Glenn ________________________________________________________________________________
Date: Jun 09, 2009
Glenn, if you think the buzzer is a good idea but have the concern you mentioned, just install a second switch on the throttle. If the canopy is open and the throttle is opened more than enough for taxi..you get the idea. Tim Andres _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of longg(at)pjm.com Sent: Tuesday, June 09, 2009 6:50 PM Subject: RE: AeroElectric-List: Canopy Switch Frank, Thanks for your ideas. No, actually I want what I asked for, a canopy alert light, not a "I forgot the master" warning light. The Dynon has some great contact display features that allow one to connect gear down, canopy open type things. When I'm ready to launch I'm looking strait at the EFIS and should see a big red light. You are correct, the sun can be a factor, but in PA where I live, rarely so. The probability of forgetting the canopy on a sunny day in PA is probably much less than forgetting it on an overcast day. The buzzer is a great idea, but does one really want the buzzer in your ears anytime the master is on and you are running around in sweat with the canopy in tilt position? I will stick to trying to find the right switch for mounting on the canopy jam. Glenn _____ From: owner-aeroelectric-list-server(at)matronics.com on behalf of Hinde, Frank George (Corvallis) Sent: Tue 6/9/2009 5:47 PM Subject: RE: AeroElectric-List: Canopy Switch Personally I would use a buzzer from Radio shack instead of a light so it works in bright sunlight. Don't know if the Dynon will drive a buzzer or not but you might just avoid the Dynon altogether and run the buzzer through the switch. I'm assuming here you want a warning that you left your master on?...if so you could wire the switch such the ground path goes thru the master switch. If you just want a canopy open switch (not sure what value it really has?) then you can just wire a simple circuit thru the buzzer or light your choice. Either way there is not much point in going through the Dynon. Frank RV7a D100 and Ems10 I want to add a canopy (open) warning switch to my Lanciar Legacy. I've got a Dynon 180 which handles all the high tech stuff but I need the appropriate switch and vendor information from which to source it. Naturally the switch should be low profile or recessed and perhaps be adjustable in depth such that it could be adjusted to the canopy tightness. The premise of the Dynon is to alert via a contact light of a normally closed or normally open item. Basically if it's grounded, it closes the switch and allows the turns the light green. If you have completed such an installation I'd be glad to hear of what switch you used and related frustrations if any. Thanks in ====================== href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.Same great content also available via the Web href="https://exc03wwp.corp.ds.pjm.com/f5-w-687474703a2f2f666f72756d732p; - List Contribution Web bsp; -Matt Dralle, List href="http://www.matronics.com/contribution">http://www.matronics.com/c==== =========== 05:53:00 ________________________________________________________________________________
Date: Jun 09, 2009
Simple switches that can be either normally open or normally closed are those that are used on housing security systems. GE makes a line of pressure operated switches like that, that fit into window frames. An appropriate choice might depend on the area where you intend to mount the switch, and the how small it needs to be. Ian Brown Bromont Quebec > Frank, > > Thanks for your ideas. No, actually I want what I asked for, a canopy > alert light, not a "I forgot the master" warning light. The Dynon has > some great contact display features that allow one to connect gear > down, canopy open type things. When I'm ready to launch I'm looking > strait at the EFIS and should see a big red light. You are correct, > the sun can be a factor, but in PA where I live, rarely so. The > probability of forgetting the canopy on a sunny day in PA is probably > much less than forgetting it on an overcast day. > > The buzzer is a great idea, but does one really want the buzzer in > your ears anytime the master is on and you are running around > in sweat with the canopy in tilt position? > > I will stick to trying to find the right switch for mounting on the > canopy jam. > > > Glenn > > > ______________________________________________________________________ > From: owner-aeroelectric-list-server(at)matronics.com on behalf of Hinde,
May 30, 2009 - June 09, 2009
AeroElectric-Archive.digest.vol-is
