AeroElectric-Archive.digest.vol-it
June 09, 2009 - June 23, 2009
      > Frank George (Corvallis)
      > Sent: Tue 6/9/2009 5:47 PM
      > To: aeroelectric-list(at)matronics.com
      > Subject: RE: AeroElectric-List: Canopy Switch
      > (Corvallis)"
      > Personally I would use a buzzer from Radio shack instead of a light so
      > it works in bright sunlight.
      > Don't know if the Dynon will drive a buzzer or not but you might just
      > avoid the Dynon altogether and run the buzzer through the switch.
      > I'm assuming here you want a warning that you left your master
      > on?...if so you could wire the switch such the ground path goes thru
      > the master switch.
      > If you just want a canopy open switch (not sure what value it really
      > has?) then you can just wire a simple circuit thru the buzzer or light
      > your choice.
      > Either way there is not much point in going through the Dynon.
      > Frank
      > RV7a D100 and Ems10
      > I want to add a canopy (open) warning switch to my Lanciar Legacy.
      > I've got a Dynon 180 which handles all the high tech stuff but I need
      > the appropriate switch and vendor information from which to source it.
      > Naturally the switch should be low profile or recessed and perhaps be
      > adjustable in depth such that it could be adjusted to the canopy
      > tightness.
      > The premise of the Dynon is to alert via a contact light of a normally
      > closed or normally open item. Basically if it's grounded, it closes
      > the switch and allows the turns the light green.
      > If you have completed such an installation I'd be glad to hear of what
      > switch you used and related frustrations if any.
      > Thanks in ======================
      > href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.Same great content also available via the Web href="https://exc03wwp.corp.ds.pjm.com/f5-w-687474703a2f2f666f72756d732p;        - List Contribution Web bsp;                    -Matt Dralle, List href="http://www.matronics.com/contribution">http://www.matronics.com/c================
Subject: Burning up Van's Engine Instruments because?
Date: Jun 09, 2009
Saturday was hot and busy flying kids for COPA fun event. After 3 hours I started to taxi back and smelled smoke. On examination my Van's voltmeter melted inside the electronics, on the circuit board, between the power and the ground stud, had burned up melting the case. Today checked the voltage and found 12 volts (not running) and 14.2 volts (running) at the main bus that feeds instruments. Then found that the Oil Temp gauge was hot at same place and melting, and Manifold Pressure is very warm to touch. I searched and found no obvious loose grounds. Any suggestions about what would cause this? Where to look next? Sure appreciate any advice, expertice is distant here in Yukon. -------- Jake Read this topic online here: http://forums.matronics.com/viewtopic.php?p=247505#247505 ________________________________________________________________________________
Subject: Z12 questions
Date: Jun 10, 2009
Date: Tue=2C 9 Jun 2009 15:20:29 -0500 From: nuckolls.bob(at)aeroelectric.com Subject: Re: AeroElectric-List: Z12 questions > Yes=2C you can run both alternators together but >getting them to share proportionately is difficult >without special paralleling regulators. Bob=2C what exactly happens with architecture Z12 (with specifically one L R3 and one SB-1 regulator) if you keep turning on major loads (pitot=2C lan ding lights=2C etc) until the primary L40 alternator can no longer cope and the voltage sags. Will the SD20 come on and run concurrently. I presume it will... until some of the loads are shed..but from your comment above it may not be a happy event over time. Can you please elaborate on this. Is it possible that one or both of the alternators (or the regulators) could be damaged if both alternators are running concurrently in Z12. I'm trying to work out whether with Z12 I need to ensure that my primary al ternator is never pushed beyond its capacity (ie swap the L40 for an L60). Regards Bob Barrow _________________________________________________________________ POP access for Hotmail is here! Click here to find out more http://windowslive.ninemsn.com.au/article.aspx?id2246 ________________________________________________________________________________
Date: Jun 10, 2009
At 07:22 AM 6/10/2009, you wrote: > > >---------- > >Date: Tue, 9 Jun 2009 15:20:29 -0500 >To: aeroelectric-list(at)matronics.com >From: nuckolls.bob(at)aeroelectric.com >Subject: Re: AeroElectric-List: Z12 questions > > > > Yes, you can run both alternators together but > >getting them to share proportionately is difficult > >without special paralleling regulators. > > Bob, what exactly happens with architecture Z12 (with specifically > one LR3 and one SB-1 regulator) if you keep turning on major loads > (pitot, landing lights, etc) until the primary L40 alternator can > no longer cope and the voltage sags. Will the SD20 come on and run > concurrently. I presume it will... until some of the loads are > shed..but from your comment above it may not be a happy event over > time. Can you please elaborate on this. Is it possible that one or > both of the alternators (or the regulators) could be damaged if > both alternators are running concurrently in Z12. > >I'm trying to work out whether with Z12 I need to ensure that my >primary alternator is never pushed beyond its capacity (ie swap the >L40 for an L60). The "sharing" scenario you described is correct when the SD-20 is regulated by the SB-1 and the aux alternator setpoint is about 1 volt lower than the main alternator. As long as your main alternator is adequately cooled, there is no risk of damage to the main alternator. I was curious as to what kind of loads you are anticipating that would require over 30A of continuous engine driven power. For example, you wouldn't have any exterior lights on along with pitot heat. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 10, 2009
Subject: Re: problem in Bob's Wigwag.pdf circuit?
At 07:49 PM 6/9/2009, you wrote: >Hello - I am new to the list so please don't flame me for posting >this. I am designing my landing lights around the circuit on page 4 >of Bob's Wigwg.pdf. > >This is the circuit that uses the 4PDT switch, marked "4TL1-10 or >equal" I just ordered my switch today. My design goal of this >circuit is to have the switch function as OFF-WIGWAG-ON, with OFF in >the bottom position. > >In completing my design, I noticed in the Honeywell datasheet for >the 4TL1-10 switch (available at this link: ><http://www.datasheetarchive.com/4TL1-10-datasheet.html>http://www.datasheetarchive.com/4TL1-10-datasheet.html >) does not match the one in Bob's schematic. > >The problem is that for the -10 switch in the datasheet, there are >two poles (pins 8 & 11) that are open in the center condition. The >switch in Bob's circuit requires all poles to be active in all positions. > >After careful datasheet reading, I think that Bob's design will work >with a 4TL1-12 switch. It is supposedly the same circuitry as a -50 >(which looks right) and has no momentary positions. > >Can anyone confirm that I need to cancel my order for the -10 and >get a -12 instead? I'm hoping to find out quickly to avoid buying >the wrong switch. > >I did search the archive and found a single poster mentioning that >the circuit didn't work... maybe this was why? I just checked the data package for wig-wag options I published at: http://www.aeroelectric.com/PPS/Lighting/WigWag.pdf The single control switch option on page 4 calls out the 4TL1-12 switch. Where did you see a recommendation for the 4TL1-10? I note that this drawing was updated in January of 07. I don't recall now but perhaps this change was to correct the part number. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 10, 2009
Subject: Canopy Switch
Date: Jun 10, 2009
The RV-10 guys have the same issue and can have a really bad day if they launch without the doors being latched. I've got two friends with RV-10s that have switches that are triggered by the door pins. I can't give you part numbers but check the RV-10 sites. I think they are 3rd party and not Van's. Regards, Greg Young > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On > Behalf Of longg(at)pjm.com > Sent: Tuesday, June 09, 2009 4:23 PM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Canopy Switch > > > I want to add a canopy (open) warning switch to my Lanciar > Legacy. I've got a Dynon 180 which handles all the high tech > stuff but I need the appropriate switch and vendor > information from which to source it. > Naturally the switch should be low profile or recessed and > perhaps be adjustable in depth such that it could be adjusted > to the canopy tightness. > > The premise of the Dynon is to alert via a contact light of a > normally closed or normally open item. Basically if it's > grounded, it closes the switch and allows the turns the light green. > > If you have completed such an installation I'd be glad to > hear of what switch you used and related frustrations if any. > > > Thanks in advance, > Glenn ________________________________________________________________________________
Subject: Re: Z12 questions
Date: Jun 10, 2009
Bob, This raises a question that I know has been discussed before, but I could not find in the archives. I have a Plane Power 60A and a SD20. What are the pros and cons of using two LR3 's versus one LR3 and one SB-1? Thanks. Jim Berry RV10 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=247562#247562 ________________________________________________________________________________
Date: Jun 10, 2009
Subject: Circuit for "alternator emulator" for SEC-1223
Bob, Have you found (in your paper stack) the circuit for a battery backup module or "alternator emulator" used to convert SEC-1223 power supply for battery backup application? I want to run my avionics while the battery backup module is used between the SEC-1223 and the aircraft battery. My previous thread on Aerolectrics was about the problem of running my avionics with the SEC-1223 wired to the the aircraft battery. As I under stand this, there is a problem with the battery backfeeding the SEC-1223 and a problem with a discharged battery damaging the SEC-1223 by drawing too mu ch current. Would this simple circuit work? Input Negative (from SEC-1223)----------------------------Battery Negative-------------Load Negative (Avionics) Input Positive(from SEC-1223)----------!>------------------Battery Positive-------------Load Positive (Avionics) !> is a Schottky Diode to protect the Battery backfeeding the Power Supply. Unfortunately, this gives no protection to the power supply (over-current) AND too much charging current for my recombinant gas batte ry in the case of a discharged battery. The circuit also lowers the voltage to th e battery because of the diode forward voltage drop of 0.4 to 0.5 volt depe nding on the current draw, leaving 13.4 to 13.3 volts to the battery. My battery is a 34AHr Concorde CB35 RGXC. Recommended charging current woul d be 34 divided by 20 = 1.7 amps. Adding power resistors to the series circ uit to protect the power supply from providing too much current would only reduce the current to the battery and limit the voltage to the avionics from battery drawdown? 1. Recommended circuit to solve my problems? OR 2. Don't worry about a discharged battery if I know it is reasonably full y charged and just us the simple circuit above to protect the Battery backfeeding the Power Supply? Adequate forward voltage? Source and specs for the Shottky diode? OR 3. Just use the b-lead to the alternator as you recommended before? How to identify b-lead and attach which suitable connector so I can get to it easily on a regular basis? Run wire to my cowling cooling air outlet wit h which connector. OR Install a cigarette lighter outlet under my panel to energize the avionics master and leave the battery master switch off? Help! Don Schmiesing **************Dell Inspiron 15 Laptop: Now in 6 vibrant colors! Shop Dell =99s full line of laptops. =http:%2F%2Fad.doubleclick.net%2Fclk%3B215566094%3B3786435 8%3Bv) ________________________________________________________________________________
Date: Jun 10, 2009
Subject: Reverse flow in Shunt and Hall Effect
I have a HE device on the B lead from the Alternator to the main battery. It is oriented so that current is measured from the alternator to the mai n battery thus indicating the load imposed on the alternator. I have a shunt on the standby battery to measure current being used from the battery. If current flows in the opposite direction from the planned flow, does one get a negative amperage indication? Stan Sutterfield **************Dell Inspiron 15 Laptop: Now in 6 vibrant colors! Shop Dell =99s full line of laptops. =http:%2F%2Fad.doubleclick.net%2Fclk%3B215566094%3B3786435 8%3Bv) ________________________________________________________________________________
Date: Jun 10, 2009
Subject: IFR Certification
This may not be the ideal forum for asking this question, but I'll try it anyway. I want to certify my RV-8 for IFR flight. I know the FARs - I've looked at them. I have the Blue Mountain EFIS One as primary instrumentation. I have the Blue Mountain EFIS Lite as a backup. Both EFISs are on different electrical busses - the main and the standby. - which can be tied together, if needed. I asked a local avionics guy about doing a pitot-static and transponder check for IFR. He said I would have to install a separate altimeter and encoder in order to get IFR certification. The EFIS has a built-in encod er. Has anyone else encountered this obstacle? Stan Sutterfield **************Dell Inspiron 15 Laptop: Now in 6 vibrant colors! Shop Dell =99s full line of laptops. =http:%2F%2Fad.doubleclick.net%2Fclk%3B215566094%3B3786435 8%3Bv) ________________________________________________________________________________
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
Date: Jun 10, 2009
Nonsence!..He'll be telling you you need a vacuum pump next! I have a Dynon D100 that does the altitude encoding and there is certainly no requirement for a second altimeter. Go elsewhere.. Frank 7a IFR ________________________________ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectr ic-list-server(at)matronics.com] On Behalf Of Speedy11(at)aol.com Sent: Wednesday, June 10, 2009 10:21 AM Subject: AeroElectric-List: IFR Certification This may not be the ideal forum for asking this question, but I'll try it a nyway. I want to certify my RV-8 for IFR flight. I know the FARs - I've looked at them. I have the Blue Mountain EFIS One as primary instrumentation. I have the Blue Mountain EFIS Lite as a backup. Both EFISs are on different electrical busses - the main and the standby. - which can be tied together, if needed. I asked a local avionics guy about doing a pitot-static and transponder che ck for IFR. He said I would have to install a separate altimeter and encod er in order to get IFR certification. The EFIS has a built-in encoder. Has anyone else encountered this obstacle? Stan Sutterfield ________________________________ Dell Inspiron 15 Laptop: Now in 6 vibrant colors! Shop Dell's full line of redir=http:%2F%2Fad.doubleclick.net%2Fclk%3B215566094%3B37864358%3Bv> ________________________________________________________________________________
Date: Jun 10, 2009
Stan =93 Other folks have had similar issues. Some avionics shops demand TSOd equipment, then can=99t quote chapter and verse of the reg that requires it. The technician=99s task is to test the equipment as installed and verify that the data it puts out is accurate within limits, not to pass judgment on your choice of hardware. Find yourself another shop. Neal ------------------------ This may not be the ideal forum for asking this question, but I'll try it anyway. I want to certify my RV-8 for IFR flight. I know the FARs - I've looked at them. I have the Blue Mountain EFIS One as primary instrumentation. I have the Blue Mountain EFIS Lite as a backup. Both EFISs are on different electrical busses - the main and the standby. - which can be tied together, if needed. I asked a local avionics guy about doing a pitot-static and transponder check for IFR. He said I would have to install a separate altimeter and encoder in order to get IFR certification. The EFIS has a built-in encoder. Has anyone else encountered this obstacle? Stan Sutterfield ________________________________________________________________________________
Subject: Help witn Dynon 180 and RAC Parts
Date: Jun 10, 2009
Anyone have a wiring diagram for where they installed with a Dynon 180... 2 RAC trim servos, 1 RAC Flap Sensor, 1 five button RAC grip? -------- W.R. "Gig" Giacona 601XL Under Construction See my progress at www.peoamerica.net/N601WR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=247593#247593 ________________________________________________________________________________
Subject: Measuring voltage on aircraft and engine sensors?
Date: Jun 10, 2009
I am trying to connect my aircraft to a microcontroller and some adc's. Will a hall effect rpm sensor work on 5vdc? Are the oil temp and oil pressure sensors just pots? I am using a Jabiruu 3300. Thanx much Don Zodiac 601xl N601NV Soon beginning engine install. -------- Don Merritt- Laredo, Tx Apologies if I seem antagonistic. I believe in the freeflowing ideas and discussions between individuals for assistance in this thing we call life. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=247592#247592 ________________________________________________________________________________
Date: Jun 10, 2009
This is a rather common occurance by shops that are either uneducated or inexperienced with experimental aircraft. Sometimes it's also as a result of naiive FSDO people as well. Basically the information provided to you is completely false and not correct. The EFIS with it's encoder is just fine....so is it's altimeter - assuming both will pass an IFR check. We have our FAA Repair Station Certification and do a lot of said pitot static and/or transponder checks on both certified and experimentals. Should be no problem if you find the right people or right shop. Cheers, Stein -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Speedy11(at)aol.com Sent: Wednesday, June 10, 2009 12:21 PM To: aeroelectric-list(at)matronics.com Subject: AeroElectric-List: IFR Certification This may not be the ideal forum for asking this question, but I'll try it anyway. I want to certify my RV-8 for IFR flight. I know the FARs - I've looked at them. I have the Blue Mountain EFIS One as primary instrumentation. I have the Blue Mountain EFIS Lite as a backup. Both EFISs are on different electrical busses - the main and the standby. - which can be tied together, if needed. I asked a local avionics guy about doing a pitot-static and transponder check for IFR. He said I would have to install a separate altimeter and encoder in order to get IFR certification. The EFIS has a built-in encoder. Has anyone else encountered this obstacle? Stan Sutterfield ---------------------------------------------------------------------------- -- Dell Inspiron 15 Laptop: Now in 6 vibrant colors! Shop Dell's full line of laptops. ________________________________________________________________________________
Subject: Re: Canopy Switch
Date: Jun 10, 2009
I put a switch on the canopy latch of my RV-7. It indicates that the canopy is "closed and latched." I don't remember the part number of the switch but it was just a tiny little limit switch. it has worked well for 180 hours. Occasionally it even reminds me to close the canopy. :-) There are a couple of pictures here... http://www.myrv7.com/viewlog.php?year 05&month=2 Any switch that is a SPDT should work for what you want to do, I seriously doubt that the detection circuit carries more than a few milliamps. You just need to find one that fits the geometry. Phil On Jun 9, 2009, at 4:23 PM, wrote: > > I want to add a canopy (open) warning switch to my Lanciar Legacy. > I've > got a Dynon 180 which handles all the high tech stuff but I need the > appropriate switch and vendor information from which to source it. > Naturally the switch should be low profile or recessed and perhaps be > adjustable in depth such that it could be adjusted to the canopy > tightness. > > The premise of the Dynon is to alert via a contact light of a normally > closed or normally open item. Basically if it's grounded, it closes > the > switch and allows the turns the light green. > > If you have completed such an installation I'd be glad to hear of what > switch you used and related frustrations if any. > > > Thanks in advance, > Glenn > > ________________________________________________________________________________
Subject: Burning up Vans Engine Gauges - Part Two.
Date: Jun 10, 2009
Well I'm stumped....my simple RV8, basic analog instruments only, Nipon Denso 40 amp Alternator, Oddeysey battery, worked well for 200 hours. Saturday Volt Meter burned (resistor on circuit board overheated and melted case), then Oil Temperature gauge did same thing, now today while testing Manifold Pressure full of smoke. I have; -checked - no loose wires found ground or power. -Good Battery-engine-ground (heavy cable, short runs, tight connections.) -Good bus connections (one central ground bus located at firewall) -14.2 Volts on meter at gauges while running, but instruments overheat. -12+ volts on meter when engine stopped, instruments seem not to overheat. -Removed alternator and took to shop for evaluation....tested on stand and found good output and diodes. Anybody got a next step? Nice weather........need to fly George -------- Jake Read this topic online here: http://forums.matronics.com/viewtopic.php?p=247617#247617 ________________________________________________________________________________
Date: Jun 10, 2009
Subject: Re: Burning up Vans Engine Gauges - Part Two.
Interesting.. Can you see what in the instrument is fried? Is it a component connected to the V+ or from the signal/sensor (or something else)? I assume the 14.2V value is measured on the instrument supply (V+) terminal. Can you compare this with the voltage at the bus. Can you measure the voltage drop between the instrument (display) ground and the engine ground (with the engine running)? I understand that all of the connections appear solid. Have you done any recent maintenance or mods? Regards, Matt- > > > Well I'm stumped....my simple RV8, basic analog instruments only, Nipon > Denso 40 amp Alternator, Oddeysey battery, worked well for 200 hours. > > Saturday Volt Meter burned (resistor on circuit board overheated and > melted case), then Oil Temperature gauge did same thing, now today while > testing Manifold Pressure full of smoke. > > I have; > -checked - no loose wires found ground or power. > -Good Battery-engine-ground (heavy cable, short runs, tight connections.) > -Good bus connections (one central ground bus located at firewall) > -14.2 Volts on meter at gauges while running, but instruments overheat. > -12+ volts on meter when engine stopped, instruments seem not to overheat. > -Removed alternator and took to shop for evaluation....tested on stand and > found good output and diodes. > > > Anybody got a next step? Nice weather........need to fly > George > > -------- > Jake > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=247617#247617 > > ________________________________________________________________________________
Date: Jun 10, 2009
Subject: Re: Reverse flow in Shunt and Hall Effect
At 12:15 PM 6/10/2009, you wrote: >I have a HE device on the B lead from the Alternator to the main >battery. It is oriented so that current is measured from the >alternator to the main battery thus indicating the load imposed on >the alternator. > >I have a shunt on the standby battery to measure current being used >from the battery. > >If current flows in the opposite direction from the planned flow, >does one get a negative amperage indication? > >Stan Sutterfield Probably. But it's dependent upon the display software. I've never encountered a system that wouldn't show both +/- indications accurately but that doesn't mean they don't exist. Chances are your indicator will show a value for both charge and discharge currents just fine. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 10, 2009
The mechanism referred to in RV-10s is a simple magnetic reed switch arrangement. There is a magnet in each door pin and the reed switches mounted in the door frames. Bob RV-10 N442PM Read this topic online here: http://forums.matronics.com/viewtopic.php?p=247644#247644 ________________________________________________________________________________
Date: Jun 10, 2009
Yes.. Current going the opposite direction through the shunt will generate a negative voltage. The sensor connected to the shunt should interpret/display that as a negative current. One other thought is that a large discharge current is created by operating the engine starter which will generate a significant negative voltage across the shunt. If using a mechanical display it will slap the needle around pretty hard. Maybe not a big deal, but something to consider. One might install a normally-closed relay in the lead to the shunt which. Connect the controlling coil to the starter switch so that when the starter is engaged, the meter is disabled. I wouldn't think a digital display input would have any problems. If the shunt drops 50mV at full scale alternator output (not an unusual scheme). Alternator output might be 50A, and starter current might be 250A, so the shunt might drop 500mV (-0.5V) when operating the starter. Round numbers. Regards, Matt- > I have a HE device on the B lead from the Alternator to the main battery. > It is oriented so that current is measured from the alternator to the > main > battery thus indicating the load imposed on the alternator. > > I have a shunt on the standby battery to measure current being used from > the battery. > > If current flows in the opposite direction from the planned flow, does one > get a negative amperage indication? > > Stan Sutterfield > **************Dell Inspiron 15 Laptop: Now in 6 vibrant colors! Shop > Dells > full line of laptops. > =http:%2F%2Fad.doubleclick.net%2Fclk%3B215566094%3B3786435 > 8%3Bv) > ________________________________________________________________________________
Date: Jun 11, 2009
6/11/2009 Hello Stan, You wrote: "This may not be the ideal forum for asking this question, but I'll try it anyway." Actually, this is the ideal forum for asking this question. This topic has been hashed out extensively on the aeroelectric list. If you are interested in better understanding the situation go to the aeroelectric archives and search for "encoder approval". You will find many entries under this search phrase and there are other search phrases that will also generate past postings on this subject. To save you some time searching take a look at some of the postings in August , 2006 with the subject "encoder approval". You received some good advice in response to your posting copied below -- just go to another agency capable of performing the required 14 CFR 91.411 "IFR certification" tests and have them perform the tests and provide the paper work. You'll be joining hundreds of other amateur builders happily flying IFR with non TSO'd altitude encoders that have passed the required tests of 14 CFR 91.411. 'OC' Says: "The best investment we can make is the effort to gather and understand knowledge." PS: Stein Bruch wrote: " Basically the information provided to you is completely false and not correct." That is not entirely true. In defense of your local avionics guy he is taking the same position that FAA headquarters took on the altitude encoder -- that is, the altitude encoder must either be TSO'd or be tested in accordance with 14 CFR paragraph 91.217 (b). The tests that FAA headquarters described for compliance with 91.217 (b) are very elaborate and extensive. ================================================ From: Speedy11(at)aol.com Subject: AeroElectric-List: IFR Certification This may not be the ideal forum for asking this question, but I'll try it anyway. I want to certify my RV-8 for IFR flight. I know the FARs - I've looked at them. I have the Blue Mountain EFIS One as primary instrumentation. I have the Blue Mountain EFIS Lite as a backup. Both EFISs are on different electrical busses - the main and the standby. - which can be tied together, if needed. I asked a local avionics guy about doing a pitot-static and transponder check for IFR. He said I would have to install a separate altimeter and encoder in order to get IFR certification. The EFIS has a built-in encod er. Has anyone else encountered this obstacle? Stan Sutterfield ________________________________________________________________________________
Date: Jun 11, 2009
Matt and Bob, Thanks for your responses. You've confirmed my understanding of shunt an d HE functions. I'm using an Advanced Flt Systems AF-3400 and it reads both devices. I'v e had external power (regulated power supply) connected to one battery and I was getting negative amp indications. So, with the power supply connecte d to the battery and electrical consumers turned on, the shunt/HE will show a negative amperage. I'll be running the engine again in a few days and I'll check to make sur e amps are positive with normal alternator operation. Stan Yes.. Current going the opposite direction through the shunt will generate a negative voltage. The sensor connected to the shunt should interpret/display that as a negative current. **************Dell Deals: Don=99t miss huge summer savings on popula r laptops starting at $449. =http:%2F%2Fad.doubleclick.net%2Fclk%3B215566131%3B37864407%3B i) ________________________________________________________________________________
Date: Jun 11, 2009
Subject: Re: IFR Certification
Thanks for all the responses. I will use this guy to do the initial VFR certification because he will come to me rather than me having to take the airplane to him. Then maybe I'll just fly it to Stein's place and get him to do the IFR cert for me. : ) Stan Sutterfield This is a rather common occurance by shops that are either uneducated or inexperienced with experimental aircraft. Sometimes it's also as a resul t of naiive FSDO people as well. Basically the information provided to you is completely false and not correct. The EFIS with it's encoder is just fine....so is it's altimeter - assuming both will pass an IFR check. We have our FAA Repair Station Certification and do a lot of said pitot stat ic and/or transponder checks on both certified and experimentals. Should be no problem if you find the right people or right shop. **************Dell Deals: Don=99t miss huge summer savings on popula r laptops starting at $449. =http:%2F%2Fad.doubleclick.net%2Fclk%3B215566131%3B37864407%3B i) ________________________________________________________________________________
Date: Jun 11, 2009
Thanks to all for the suggestions. It sounds like the best solution is to find a switch that fits the geometry of my latch and work it from there (more fun there). I'm also checking on a pitot pressure switch or throttle up switch as a backup. Glenn -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of bcondrey Sent: Wednesday, June 10, 2009 10:53 PM Subject: AeroElectric-List: Re: Canopy Switch The mechanism referred to in RV-10s is a simple magnetic reed switch arrangement. There is a magnet in each door pin and the reed switches mounted in the door frames. Bob RV-10 N442PM Read this topic online here: http://forums.matronics.com/viewtopic.php?p=247644#247644 ________________________________________________________________________________
Date: Jun 11, 2009
Jake, What is the ambient temperature around your gauges? That could be a factor. The most likely cause of failure to a voltmeter is excessively high voltage. AC voltage applied to some instruments designed for DC could also cause damage. But you had the diodes checked out. And an AC component would be noticed in your headset. Since you are not having problems with other electrical devices on your airplane, it is unlikely that the aircraft electrical system is causing failure of your instruments unless there is something unique about the power being applied to the instruments. I suggest that you replace the analog voltmeter with a digital one. A high quality digital voltmeter should be immune to whatever your electrical system throws at it. If after flying with the new digital meter and observing the voltage, the other instruments can be replaced. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=247674#247674 ________________________________________________________________________________
Date: Jun 11, 2009
Subject: Re: Measuring voltage on aircraft and engine sensors?
At 02:11 PM 6/10/2009, you wrote: > > >I am trying to connect my aircraft to a microcontroller and some adc's. > >Will a hall effect rpm sensor work on 5vdc? Get the data sheet for the sensor you plan to use. The HE devices I've used in the past to look at shaft rpms were quite happy with 5v supply. I suspect most are but the manufacturer's data sheet is the last word. >Are the oil temp and oil pressure sensors just pots? I presume you're building from scratch. Temperature and pressure sensors come in lots of flavors. I personally favor the use of thermocouples for all temperature measurements. These are most easily adapted to the 5v microprocessor world with thermocouple conditioning chips like the AD594 series. http://www.mne.psu.edu/sommer/me445/AD594_5_c.pdf But there are numerous other products using thermo-resistive sensors to choose from. The nice thing about thermocouples is that they're calibrated right off the roll of wire. Pressure transducers these days are usually amplified piezo-resistive device like . . . Emacs! These can be pretty pricey compared to the automotive devices that behave pretty much like a rheostat. Emacs! You can adapt about anything to your task when starting from a clean piece of paper. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 11, 2009
Don't if it was legal but I didn't do a VFR cert..I just labeled the Transp onder "Inooperative" and flew it to get the IFR cert done...Why pay twice i f you don't have to? Frank ________________________________ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectr ic-list-server(at)matronics.com] On Behalf Of Speedy11(at)aol.com Sent: Thursday, June 11, 2009 7:11 AM Subject: AeroElectric-List: Re: IFR Certification Thanks for all the responses. I will use this guy to do the initial VFR certification because he will com e to me rather than me having to take the airplane to him. Then maybe I'll just fly it to Stein's place and get him to do the IFR cert for me. : ) Stan Sutterfield This is a rather common occurance by shops that are either uneducated or inexperienced with experimental aircraft. Sometimes it's also as a result of naiive FSDO people as well. Basically the information provided to you i s completely false and not correct. The EFIS with it's encoder is just fine....so is it's altimeter - assuming both will pass an IFR check. We have our FAA Repair Station Certification and do a lot of said pitot static and/or transponder checks on both certified and experimentals. Should be n o problem if you find the right people or right shop. ________________________________ Dell Deals: Don't miss huge summer savings on popular laptops starting at $ r=http:%2F%2Fad.doubleclick.net%2Fclk%3B215566131%3B37864407%3Bi> ________________________________________________________________________________
Date: Jun 11, 2009
U3RhbiwNCg0KIA0KDQpUaGlzIGlzIHRoZSDigJxiaXJkcyBvZiBhIGZlYXRoZXIgdGhlb3J54oCd LiBTdGF5IGF3YXkgZnJvbSBmb2xrcyB0aGF0IGhhdmUgdGhlaXIgbWVudGFsIGludmVzdG1lbnQg dG9vIGRlZXAgaW4gdGhlIFBpcGVyIG1hbnVhbHMuIFRoZXkgcmVhbGx5IGRvIG1lYW4gd2VsbCBi dXTigKYNCg0KIA0KDQpHbGVubg0KDQogDQoNCiANCg0KIA0KDQpGcm9tOiBvd25lci1hZXJvZWxl Y3RyaWMtbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbSBbbWFpbHRvOm93bmVyLWFlcm9lbGVjdHJp Yy1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tXSBPbiBCZWhhbGYgT2YgU3BlZWR5MTFAYW9sLmNv bQ0KU2VudDogVGh1cnNkYXksIEp1bmUgMTEsIDIwMDkgMTA6MTEgQU0NClRvOiBhZXJvZWxlY3Ry aWMtbGlzdEBtYXRyb25pY3MuY29tDQpTdWJqZWN0OiBBZXJvRWxlY3RyaWMtTGlzdDogUmU6IElG UiBDZXJ0aWZpY2F0aW9uDQoNCiANCg0KVGhhbmtzIGZvciBhbGwgdGhlIHJlc3BvbnNlcy4NCg0K SSB3aWxsIHVzZSB0aGlzIGd1eSB0byBkbyB0aGUgaW5pdGlhbCBWRlIgY2VydGlmaWNhdGlvbiBi ZWNhdXNlIGhlIHdpbGwgY29tZSB0byBtZSByYXRoZXIgdGhhbiBtZSBoYXZpbmcgdG8gdGFrZSB0 aGUgYWlycGxhbmUgdG8gaGltLiAgVGhlbiBtYXliZSBJJ2xsIGp1c3QgZmx5IGl0IHRvIFN0ZWlu J3MgcGxhY2UgYW5kIGdldCBoaW0gdG8gZG8gdGhlIElGUiBjZXJ0IGZvciBtZS4gIDogKQ0KDQpT dGFuIFN1dHRlcmZpZWxkDQoNCiANCg0KCVRoaXMgaXMgYSByYXRoZXIgY29tbW9uIG9jY3VyYW5j ZSBieSBzaG9wcyB0aGF0IGFyZSBlaXRoZXIgdW5lZHVjYXRlZCBvcg0KCWluZXhwZXJpZW5jZWQg d2l0aCBleHBlcmltZW50YWwgYWlyY3JhZnQuICBTb21ldGltZXMgaXQncyBhbHNvIGFzIGEgcmVz dWx0DQoJb2YgbmFpaXZlIEZTRE8gcGVvcGxlIGFzIHdlbGwuICBCYXNpY2FsbHkgdGhlIGluZm9y bWF0aW9uIHByb3ZpZGVkIHRvIHlvdSBpcw0KCWNvbXBsZXRlbHkgZmFsc2UgYW5kIG5vdCBjb3Jy ZWN0LiAgVGhlIEVGSVMgd2l0aCBpdCdzIGVuY29kZXIgaXMganVzdA0KCWZpbmUuLi4uc28gaXMg aXQncyBhbHRpbWV0ZXIgLSBhc3N1bWluZyBib3RoIHdpbGwgcGFzcyBhbiBJRlIgY2hlY2suICBX ZQ0KCWhhdmUgb3VyIEZBQSBSZXBhaXIgU3RhdGlvbiBDZXJ0aWZpY2F0aW9uIGFuZCBkbyBhIGxv dCBvZiBzYWlkIHBpdG90IHN0YXRpYw0KCWFuZC9vciB0cmFuc3BvbmRlciBjaGVja3Mgb24gYm90 aCBjZXJ0aWZpZWQgYW5kIGV4cGVyaW1lbnRhbHMuICBTaG91bGQgYmUgbm8NCglwcm9ibGVtIGlm IHlvdSBmaW5kIHRoZSByaWdodCBwZW9wbGUgb3IgcmlnaHQgc2hvcC4NCg0KIA0KDQogDQoNCl9f X19fX19fX19fX19fX19fX19fX19fX19fX19fX19fDQoNCkRlbGwgRGVhbHM6IERvbid0IG1pc3Mg aHVnZSBzdW1tZXIgc2F2aW5ncyBvbiBwb3B1bGFyIGxhcHRvcHMgc3RhcnRpbmcgYXQgJDQ0OS4g PGh0dHA6Ly9wci5hdHdvbGEuY29tL3Byb21vY2xrLzEwMDEyNjU3NXgxMjIxNzcwMTg3eDEyMDE0 MjUxNTMvYW9sP3JlZGlyPWh0dHA6JTJGJTJGYWQuZG91YmxlY2xpY2submV0JTJGY2xrJTNCMjE1 NTY2MTMxJTNCMzc4NjQ0MDclM0JpPiANCg0KIA0KIA0KXy09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAgICAgICAgICAtIFRo ZSBBZXJvRWxlY3RyaWMtTGlzdCBFbWFpbCBGb3J1bSAtDQpfLT0gVXNlIHRoZSBNYXRyb25pY3Mg TGlzdCBGZWF0dXJlcyBOYXZpZ2F0b3IgdG8gYnJvd3NlDQpfLT0gdGhlIG1hbnkgTGlzdCB1dGls aXRpZXMgc3VjaCBhcyBMaXN0IFVuL1N1YnNjcmlwdGlvbiwNCl8tPSBBcmNoaXZlIFNlYXJjaCAm IERvd25sb2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwNCl8tPSBQaG90b3NoYXJlLCBhbmQg bXVjaCBtdWNoIG1vcmU6DQpfLT0NCl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20v TmF2aWdhdG9yP0Flcm9FbGVjdHJpYy1MaXN0DQpfLT0NCl8tPT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQpfLT0gICAgICAgICAgICAg ICAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0NCl8tPSBTYW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBh dmFpbGFibGUgdmlhIHRoZSBXZWIgRm9ydW1zIQ0KXy09DQpfLT0gICAtLT4gaHR0cDovL2ZvcnVt cy5tYXRyb25pY3MuY29tDQpfLT0NCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09DQpfLT0gICAgICAgICAgICAgLSBMaXN0IENvbnRy aWJ1dGlvbiBXZWIgU2l0ZSAtDQpfLT0gIFRoYW5rIHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBw b3J0IQ0KXy09ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgLU1hdHQgRHJhbGxlLCBMaXN0 IEFkbWluLg0KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24N Cl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09DQogDQo ________________________________________________________________________________
Date: Jun 11, 2009
Speedy11(at)aol.com wrote: > I'm using an Advanced Flt Systems AF-3400 and it reads both devices. > I've had external power (regulated power supply) connected to one > battery and I was getting negative amp indications. So, with the > power supply connected to the battery and electrical consumers turned > on, the shunt/HE will show a negative amperage. I am just starting the wiring on my AFS 3500 so I am probably confused, but I thought the shunt and Hall Effect were mutually exclusive. I plan to run both alternators (Z13/8) through the HE as shown on page 42 of the AF3500 System Manual V5.3. Am I missing something? John Morgensen RV9A - wiring ________________________________________________________________________________
Subject: Help with LCD Circuit Design - Altitude & Heading
Date: Jun 11, 2009
Hi, I am interested in building a simple, small, bright LCD display that can increment numbers with the twist of a knob. I would like to build a 4 digit and 3 digit versions, to represent pattern altitude and heading, respectively. Put it in a small enclosure and mount on my dash. Pattern altitude - knob changes in 100' increments Heading - knob changes in 10 degree increments. Would be nice to go from 0 to 360, then roll back over to zero (0). I know you knowledgeable electronics guys are thinking this is stone simple, but.... I'm a noob. I don't know which parts to mix and match to make this happen. And while having googled lots of stuff, I am still unsure how to pick the right parts to make this work. So if someone in the know could suggest the right combination of parts it would be most appreciated. Here is a commercial version that inspired my request here. But sweet jeeezus, at $400 that is just plain outrageous for what I bet cost maybe $50. http://www.p2inc.com/skybuddy.asp Thanks in advance! Mike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=247702#247702 ________________________________________________________________________________
Date: Jun 11, 2009
I'm wired for 13/8 and use the AFS3500's. I went with two shunts; one FWF for the main alt and another cabin-side for the SD-8. I had the main alt shunt reading negatively at first and only had to reverse the wires to the AFS unit. HTH Bret Smith RV-9A N16BL Blue Ridge, GA www.FlightInnovations.com ----- Original Message ----- From: John Morgensen To: aeroelectric-list(at)matronics.com ; Speedy11(at)aol.com Sent: Thursday, June 11, 2009 12:23 PM Subject: Re: AeroElectric-List: Re: Reverse flow in Shunt and Hall Effect Speedy11(at)aol.com wrote: I'm using an Advanced Flt Systems AF-3400 and it reads both devices. I've had external power (regulated power supply) connected to one battery and I was getting negative amp indications. So, with the power supply connected to the battery and electrical consumers turned on, the shunt/HE will show a negative amperage. I am just starting the wiring on my AFS 3500 so I am probably confused, but I thought the shunt and Hall Effect were mutually exclusive. I plan to run both alternators (Z13/8) through the HE as shown on page 42 of the AF3500 System Manual V5.3. Am I missing something? John Morgensen RV9A - wiring ________________________________________________________________________________
From: Etienne Phillips <etienne.phillips(at)gmail.com>
Subject: Re: Help with LCD Circuit Design - Altitude & Heading
Date: Jun 11, 2009
If I were looking at a similar project, I would consider using a microprocessor, 7-segment LED displays (or a backlit LCD for good sunlight readability), and two quadrature jogdials. It's not a simple solution though, and I'd be hesitant to encourage you to attempt this solution as a novice due to the combined software and hardware nature of the microprocessor... Total electronics cost (assuming you have all the required tools and a programmer) in the order of $15, then you'll need an enclosure of some sort. Maybe another $15-$20. Certainly do-able for waaaaay less than $400. Hope this inspires some other answers, hopefully with a simpler solution that would make a good project for a beginner :-) Etienne Very simple from a hardware perspective, and the code for the microprocessor is not too hard. However, I'm not a noob (BSc in Electrical Engineering ;-) ), and I have all the required tools on hand! On 11 Jun 2009, at 7:06 PM, mikef wrote: > > Hi, > > I am interested in building a simple, small, bright LCD display > that can increment numbers with the twist of a knob. I would like > to build a 4 digit and 3 digit versions, to represent pattern > altitude and heading, respectively. Put it in a small enclosure and > mount on my dash. > > Pattern altitude - knob changes in 100' increments > Heading - knob changes in 10 degree increments. Would be nice to go > from 0 to 360, then roll back over to zero (0). > > I know you knowledgeable electronics guys are thinking this is > stone simple, but.... I'm a noob. I don't know which parts to mix > and match to make this happen. And while having googled lots of > stuff, I am still unsure how to pick the right parts to make this > work. So if someone in the know could suggest the right combination > of parts it would be most appreciated. > > Here is a commercial version that inspired my request here. But > sweet jeeezus, at $400 that is just plain outrageous for what I bet > cost maybe $50. > > http://www.p2inc.com/skybuddy.asp > > Thanks in advance! > > Mike > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=247702#247702 > > ________________________________________________________________________________
Subject: GRETZ heated pitot tube
Date: Jun 11, 2009
Hi Guys Has anyone cut off the LEDs from the control unit (of the Gretz heated pitot tube product) and mounted it remotely, and then mounted the LEDs on their own wires to the panel - if so: how did you get on, any problems ??? Regards John (England - RV9a wings) ________________________________________________________________________________
Date: Jun 11, 2009
I'm confused on what you are attempting to accomplish. The LEDs aren't on the control unit, they are on a separate circuit board. This allows them to be remotely mounted. I would leave them on the board to add more strength to the mounting point for the LEDS. There is nothing magical about that circuit other than a resistor and LED. You should be able to reverse engineer the traces by looking at the board. Or you could just give Andrew at Angus Aviation a call. Just remember that he's fourteen hours ahead of us. From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of JOHN TIPTON Sent: Thursday, June 11, 2009 3:51 PM Subject: AeroElectric-List: GRETZ heated pitot tube Hi Guys Has anyone cut off the LEDs from the control unit (of the Gretz heated pitot tube product) and mounted it remotely, and then mounted the LEDs on their own wires to the panel - if so: how did you get on, any problems ??? Regards John (England - RV9a wings) ________________________________________________________________________________
Date: Jun 11, 2009
Etienne, Thanks for your note. It is educational. I'll keep the info in mind. Mike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=247727#247727 ________________________________________________________________________________
Date: Jun 11, 2009
At 12:06 PM 6/11/2009, you wrote: > >Hi, > >I am interested in building a simple, small, bright LCD display that >can increment numbers with the twist of a knob. I would like to >build a 4 digit and 3 digit versions, to represent pattern altitude >and heading, respectively. Put it in a small enclosure and mount on my dash. > >Pattern altitude - knob changes in 100' increments >Heading - knob changes in 10 degree increments. Would be nice to go >from 0 to 360, then roll back over to zero (0). > >I know you knowledgeable electronics guys are thinking this is stone >simple, but.... I'm a noob. I don't know which parts to mix and >match to make this happen. And while having googled lots of stuff, I >am still unsure how to pick the right parts to make this work. So if >someone in the know could suggest the right combination of parts it >would be most appreciated. > >Here is a commercial version that inspired my request here. But >sweet jeeezus, at $400 that is just plain outrageous for what I bet >cost maybe $50. If all you're wanting is a reminder why go electronic. Pure mechanical works too. See: http://tinyurl.com/mpjq8u In years past I've seen installations of thumbwheel switches mounted to allow dialing in a number to be prompted. No electronics required. What you're wanting to do would take quite a bit of time . . . that $400 price for a low volume product was probably not all that outrageous. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Subject: Re: GRETZ heated pitot tube
Date: Jun 11, 2009
Yes: I meant the separate circuit board: it does seem to be a lot of weight (relatively) to hang on the three LEDs John ----- Original Message ----- From: Bob Leffler To: aeroelectric-list(at)matronics.com Sent: Thursday, June 11, 2009 9:45 PM Subject: RE: AeroElectric-List: GRETZ heated pitot tube I'm confused on what you are attempting to accomplish. The LEDs aren't on the control unit, they are on a separate circuit board. This allows them to be remotely mounted. I would leave them on the board to add more strength to the mounting point for the LEDS. There is nothing magical about that circuit other than a resistor and LED. You should be able to reverse engineer the traces by looking at the board. Or you could just give Andrew at Angus Aviation a call. Just remember that he's fourteen hours ahead of us. From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of JOHN TIPTON Sent: Thursday, June 11, 2009 3:51 PM To: aeroelectric-list(at)matronics.com Subject: AeroElectric-List: GRETZ heated pitot tube Hi Guys Has anyone cut off the LEDs from the control unit (of the Gretz heated pitot tube product) and mounted it remotely, and then mounted the LEDs on their own wires to the panel - if so: how did you get on, any problems ??? Regards John (England - RV9a wings) http://www.matronics.com/Navigator?AeroElectric-Listhttp://forums.matroni cs.comhttp://www.matronics.com/contribution ________________________________________________________________________________
Date: Jun 11, 2009
John, I eliminated the Gretz LED's and mounting board altogether. Replaced them with 3 new LED's epoxied from the back of my panel, and wired without the mounting board. Works fine. Jim Berry RV10 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=247739#247739 ________________________________________________________________________________
Date: Jun 11, 2009
Recently had my Blue Mountain Sport (new install) calibrated and certified. Not an issue. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=247760#247760 ________________________________________________________________________________
Date: Jun 11, 2009
From: Mike Fontenot <mikef(at)apexconsultingservices.com>
Bob, That is a good idea. Thanks! Mike On Thu, Jun 11, 2009 at 3:32 PM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 12:06 PM 6/11/2009, you wrote: > > > Hi, > > I am interested in building a simple, small, bright LCD display that can > increment numbers with the twist of a knob. I would like to build a 4 digit > and 3 digit versions, to represent pattern altitude and heading, > respectively. Put it in a small enclosure and mount on my dash. > > Pattern altitude - knob changes in 100' increments > Heading - knob changes in 10 degree increments. Would be nice to go from 0 > to 360, then roll back over to zero (0). > > I know you knowledgeable electronics guys are thinking this is stone > simple, but.... I'm a noob. I don't know which parts to mix and match to > make this happen. And while having googled lots of stuff, I am still unsure > how to pick the right parts to make this work. So if someone in the know > could suggest the right combination of parts it would be most appreciated. > > Here is a commercial version that inspired my request here. But sweet > jeeezus, at $400 that is just plain outrageous for what I bet cost maybe > $50. > > > If all you're wanting is a reminder why go > electronic. Pure mechanical works too. See: > > * http://tinyurl.com/mpjq8u* > > In years past I've seen installations of thumbwheel > switches mounted to allow dialing in a number to > be prompted. No electronics required. > > What you're wanting to do would take quite a bit > of time . . . that $400 price for a low > volume product was probably not all that > outrageous. > > > Bob . . . > > --------------------------------------- > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > --------------------------------------- > > > * > > * > > -- Mike =============================== Mike Fontenot Apex Consulting & Services LLC Lakewood, Colorado 303 / 731-6645 mikef AT apexconsultingservices DOT com =============================== ________________________________________________________________________________
Date: Jun 11, 2009
mprather(at)spro.net wrote: > Interesting.. > > Can you see what in the instrument is fried? Is it a component connected > to the V+ or from the signal/sensor (or something else)? > > The resistor on +ve Voltage into instrument burned > > I assume the 14.2V value is measured on the instrument supply (V+) > terminal. Can you compare this with the voltage at the bus. > > Yes, was same. > > Can you measure the voltage drop between the instrument (display) ground > and the engine ground (with the engine running)? I understand that all of > the connections appear solid. > > I will do this. I think it was same. > > Have you done any recent maintenance or mods? > > No > > Thanks for taking time to answer.. > > Regards, > > Matt- > > > > > > > > > > Well I'm stumped....my simple RV8, basic analog instruments only, Nipon > > Denso 40 amp Alternator, Oddeysey battery, worked well for 200 hours. > > > > Saturday Volt Meter burned (resistor on circuit board overheated and > > melted case), then Oil Temperature gauge did same thing, now today while > > testing Manifold Pressure full of smoke. > > > > I have; > > -checked - no loose wires found ground or power. > > -Good Battery-engine-ground (heavy cable, short runs, tight connections.) > > -Good bus connections (one central ground bus located at firewall) > > -14.2 Volts on meter at gauges while running, but instruments overheat. > > -12+ volts on meter when engine stopped, instruments seem not to overheat. > > -Removed alternator and took to shop for evaluation....tested on stand and > > found good output and diodes. > > > > > > Anybody got a next step? Nice weather........need to fly > > George > > > > -------- > > Jake > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p 47617#247617 > > > > > > > > > > > > > > > > > > > > > > > > > > > -------- Jake Read this topic online here: http://forums.matronics.com/viewtopic.php?p=247770#247770 ________________________________________________________________________________
Date: Jun 11, 2009
Just an update ...thanks to those who answered; I have performed no modifications except annual inspection and wash. The instruments burn up the resistor on the +ve supply into the circuit board inside instruments. The 14.2 V is at instrument. Fooling around measuring power to ground at many places seems very consistent. The ambient temperature is not too high (especially compared to you guys in Southern US). On osciloscope today, we found .004 V AC in the alternator current. This seems pretty low to me? Nothing else currently having problems. Today we also removed the battery -ve cable cleaned it and put it to engine where we connected the cable to the firewall ground post. All cables are # 2 and about 18" long. I did notice the negative post on the battery moves just ever so slightly as I tightened the post back on, not very much just enough to notice. I also see the alternator is spinning at top of the rated RPM, but easily within the 10% the alternator shop taked of. Thanks again you guys. -------- Jake Read this topic online here: http://forums.matronics.com/viewtopic.php?p=247771#247771 ________________________________________________________________________________
Date: Jun 12, 2009
6/12/2009 Hello Frank, You wrote: "Why pay twice if you don't have to?" I agree. To determine if a flight without a transponder is legal go to 14 CFR 91.215. Also note that permission for a flight without a transponder can be obtained as described in 91.215 (d). 'OC' Says: "The best investment we can make is the effort to gather and understand knowledge." ==================================================== From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com> Subject: RE: AeroElectric-List: Re: IFR Certification Don't if it was legal but I didn't do a VFR cert..I just labeled the Transp onder "Inooperative" and flew it to get the IFR cert done...Why pay twice i f you don't have to? Frank ________________________________________________________________________________
Date: Jun 12, 2009
My BMA system has served as my encoder for my Mode C for 5 years in the NYC area. Islip Avionics had absolutely no issue with the certifications. If the boss at your local shop does not understand the regulations pertaining to OBAM aircraft, find another shop. Especially, since they would, if they finally elect to do the work, would take twice as long and charge twice as much! -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=247812#247812 ________________________________________________________________________________
Date: Jun 12, 2009
Just what I had in mind: but using some chrome bezels (which are available for LEDs) for easy replacement of the LEDs if needed Regards: John ----- Original Message ----- From: "Jim Berry" <jimberry(at)qwest.net> Sent: Thursday, June 11, 2009 11:53 PM Subject: AeroElectric-List: Re: GRETZ heated pitot tube > > John, > > I eliminated the Gretz LED's and mounting board altogether. Replaced them > with 3 new LED's epoxied from the back of my panel, and wired without the > mounting board. Works fine. > > Jim Berry > RV10 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=247739#247739 > > > ________________________________________________________________________________
Date: Jun 12, 2009
Hi John, When I received my 3500, I received only the Hall Effect sensor that I ordered extra. I have two power supplies and looking at the manual I figured that the both must go through the HE sensor (there are two wires in the photograph and there was no shunt in the box). Just to make sure I contacted AFS. They said that each power supply should be measured separately, and that the shunt was left out by mistake. They shipped it the same day. I installed the shunt for the main alt firewall forward (Z13/8), with the HE sensor for my SD-8 placed behind the panel just in front of the firewall. Haven't fired up the engine yet though. Andrew RV7, EI-EEO Galway, Ireland. ----- Original Message ----- From: "Bret Smith" <smithhb(at)tds.net> Sent: Thursday, 11 June, 2009 6:08:14 PM GMT +00:00 GMT Britain, Ireland, Portugal Subject: Re: AeroElectric-List: Re: Reverse flow in Shunt and Hall Effect I'm wired for 13/8 and use the AFS3500's. I went with two shunts; one FWF for the main alt and another cabin-side for the SD-8. I had the main alt shunt reading negatively at first and only had to reverse the wires to the AFS unit. HTH Bret Smith RV-9A N16BL Blue Ridge, GA www.FlightInnovations.com ----- Original Message ----- From: John Morgensen Sent: Thursday, June 11, 2009 12:23 PM Subject: Re: AeroElectric-List: Re: Reverse flow in Shunt and Hall Effect Speedy11(at)aol.com wrote: I'm using an Advanced Flt Systems AF-3400 and it reads both devices. I've had external power (regulated power supply) connected to one battery and I was getting negative amp indications. So, with the power supply connected to the battery and electrical consumers turned on, the shunt/HE will show a negative amperage. I am just starting the wiring on my AFS 3500 so I am probably confused, but I thought the shunt and Hall Effect were mutually exclusive. I plan to run both alternators (Z13/8) through the HE as shown on page 42 of the AF3500 System Manual V5.3. Am I missing something? John Morgensen RV9A - wiring href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Jun 13, 2009
6/13/2009 Hello Ira, You wrote: "If the boss at your local shop does not understand the regulations pertaining to OBAM aircraft, find another shop." I agree that finding another shop is the best way to resolve this situation. However outright condemnation of the boss for "not understand(ing) the regulations pertaining to OBAM aircraft" is not warranted. 1) The issue is not OBAM (amateur built experimental aircraft) versus standard type certificated aircraft. 2) 14 CFR 91.217 applies equally to both of those kinds of aircraft. 3) The fundamental issue relates to TSO'd versus non TSO'd altitude encoders. 4) Note that 91.217 applies to flight under VFR as well as flight under IFR. 5) Headquarters FAA is in agreement with the boss's position of not approving a non TSO'd altitude encoder unless the tests required by 14 CFR paragraph 91.217 (b) have been accomplished. 6) FAA Headquaters says that the tests required by 91.217 (b) are far more complex and demanding than the tests required by 91.411 and the associated appendicies of 14 CFR part 43. 7) Some people dispute FAA Headquarters position on this issue, but no one to date has adequately challenged them to change their position. 8) My current recommendations on this issue are: A) Understand the issues. (Hence this posting to you and fellow builders). B) Let sleeping dogs lie because if FAA Headquarers really tried to enforce their position it would cause chaos in the amateur built community because of the large number of non TSO'd altitude encoders already flying, being built into aircraft, and being manufactured. Please let me know if you have any questions. Thanks. 'OC' Says: "The best investment we can make is the effort to gather and understand knowledge." ============================================= Subject: AeroElectric-List: Re: IFR Certification From: "rampil" <ira.rampil(at)gmail.com> My BMA system has served as my encoder for my Mode C for 5 years in the NYC area. Islip Avionics had absolutely no issue with the certifications. If the boss at your local shop does not understand the regulations pertaining to OBAM aircraft, find another shop. Especially, since they would, if they finally elect to do the work, would take twice as long and charge twice as much! -------- Ira N224XS ________________________________________________________________________________
Date: Jun 13, 2009
The description you provided sounds like what would occur when a much higher than spec'ed voltage was applied to your engine instruments, not thousands of volts but hundreds (at extreme voltages most resistors would vaporize) and long enough for some heat to be transmitted to the plastic case. This does not sound like a ground problem since a poor ground would REDUCE the current through the resistor. Are these gauges lit? Is the light still ok? is it drive from the same bus or through some type of dimmer? Ira -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=247959#247959 ________________________________________________________________________________
Date: Jun 13, 2009
along those lines, cheap, simple, but unlighted- *Sort By* * Relevance*<http://sportys.com/pilotshop/pages/search.cfm?searc hword=reminder&field=myranking&sort=desc> *Price:* [Low-High]<http://sportys.com/pilotshop/pages/search.cfm?searchwor d=reminder&field=price&sort=asc> [High-Low]<http://sportys.com/pilotshop/pages/search.cfm?searchword=remin der&field=price&sort=desc> *Alphabetical:* [A-Z]<http://sportys.com/pilotshop/pages/search.cfm?searchword=reminder&f ield=producttitle&sort=asc> [Z-A]<http://sportys.com/pilotshop/pages/search.cfm?searchword=reminder&f ield=producttitle&sort=desc> *10 result(s) for reminder* <http://sportys.com/acb/showdetl.cfm?&did=19&product_id=1175> Altitude Reminder <http://sportys.com/acb/showdetl.cfm?&did=19&product_id=1175> This extremely simple but effective altitude reminder is great insurance against pilot error. Better than writing altitudes=97safer than trusting y..... 7035A - $11.95 <http://sportys.com/acb/showdetl.cfm?&did=19&product_id= 1175> http://sportys.com/acb/showdetl.cfm?&did=19&product_id=1175 ________________________________________________________________________________
Date: Jun 14, 2009
6/14/2009 Hello Ira, Thanks for your input. You wrote: 1) "For VFR into B, C airspace the BMA should be fine according to my reading of the regs." Note that the wording of 14 CFR 91.217 makes no distinction between the requirement for either a TSO'd altitude encoder (91.217 (c)) or a tested altitude encoder (91.217 (b)) for mode C operations (automatic pressure altitude reporting equipment) under IFR or VFR. Further, no class of airspace is excluded from the requirements of 91.217 by the wording therein. Can you cite some regulation that says otherwise? 2) "I treated my airframe to a brand new Sandia SAE5-35 TSO'd blind encoder." A valid solution. When people have attempted to get the assistance of EAA to change / clarify FAA Headquarter's position on this subject that is what EAA has recommended -- just install a TSO'd altitude encoder. 'OC' Says: "The best investment we can make is the effort to gather and understand knowledge." =============================================== Subject: Avionics-List: Re: IFR Certification From: "rampil" <ira.rampil(at)gmail.com> Actually I didn't condemn the boss, I simply referenced the boss as the key to the problem. I am familiar with the issues you raised which is why when finally got IFR certification for myself, I treated my airframe to a brand new Sandia SAE5-35 TSO'd blind encoder. For VFR into B, C airspace the BMA should be fine according to my reading of the regs. -------- Ira N224XS ________________________________________________________________________________
Subject: Z12 questions
Date: Jun 14, 2009
As others have suggested=2C it does seem like Z14 is my best option as I ha ve the L40 and SD20 already installed and I have 2 off LR3 regulators. Too much trouble and expense to go sending back things to B&C for exchange now from Australia. So I have purchased a second Odyssey AGM battery=2C in this case a PC310 wh ich is 7AH and weighs very little (2.7kg). Do you foresee of any problems with running the SD20 with the PC310 on the secondary bus. Cheers Bob Date: Wed=2C 10 Jun 2009 08:07:28 -0500 From: nuckolls.bob(at)aeroelectric.com Subject: RE: AeroElectric-List: Z12 questions At 07:22 AM 6/10/2009=2C you wrote: Date: Tue=2C 9 Jun 2009 15:20:29 -0500 From: nuckolls.bob(at)aeroelectric.com Subject: Re: AeroElectric-List: Z12 questions > Yes=2C you can run both alternators together but >getting them to share proportionately is difficult >without special paralleling regulators. Bob=2C what exactly happens with architecture Z12 (with specifically one L R3 and one SB-1 regulator) if you keep turning on major loads (pitot=2C lan ding lights=2C etc) until the primary L40 alternator can no longer cope and the voltage sags. Will the SD20 come on and run concurrently. I presume it will... until some of the loads are shed..but from your comment above it may not be a happy event over time. Can you please elaborate on this. Is it possible that one or both of the alternators (or the regulators) could be damaged if both alternators are running concurrently in Z12. I'm trying to work out whether with Z12 I need to ensure that my primary al ternator is never pushed beyond its capacity (ie swap the L40 for an L60). The "sharing" scenario you described is correct when the SD-20 is regulated by the SB-1 and the aux alternator setpoint is about 1 volt lower than the main alternator. As long as your main alternator is adequately cooled=2C there is no risk of damage to the main alternator. I was curious as to what kind of loads you are anticipating that would require over 30A of continuous engine driven power. For example=2C you wouldn't have any exterior lights on along with pitot heat. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong=2C gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- _________________________________________________________________ Looking for a new car this winter? Let us help with car news=2C reviews and more e%2Ecom%2Fcgi%2Dbin%2Fa%2Fci%5F450304%2Fet%5F2%2Fcg%5F801459%2Fpi%5F1004813 %2Fai%5F859641&_t=762955845&_r=tig_OCT07&_m=EXT ________________________________________________________________________________
Subject: Re: Z12 questions
Date: Jun 14, 2009
Jim, I am not Bob, but will offer a response based on my own study. In both the Z-12 and Z-14 architectures, your SB-20 can be connected to any and all electrical devices on the ship. In the event that you loose your big alternator, it is up to you to manage your electrical usage to keep your consumption within with your means (batteries + SB-20). In this scenario, the advantage of the SB-1 is that it can provide you with an indication that you are reaching the current capacity of the alternator with an indicator light. With the LR-3, you are going to have to monitor this with an ammeter or load meter. -------- rck Read this topic online here: http://forums.matronics.com/viewtopic.php?p=248033#248033 ________________________________________________________________________________
Date: Jun 14, 2009
Not positive what you are asking Bob but I'm approaching 300 hours with a 20 amp permanent magnet alternator and an 8AH battery as the second part of a Z-14 system. I run the strobes and a few things off that system and everything else off the other battery and 40 amp ND alternator. The voltage starts to sag a bit if you draw much more than 20 amps of course. The system works very well for my purposes. Both my batteries are 8AH and they auto parallel for cranking. That way I can still crank the electric dependent geared engine even if a battery is dead and the engine has stopped windmilling. Ken Bob Barrow wrote: > As others have suggested, it does seem like Z14 is my best option as I > have the L40 and SD20 already installed and I have 2 off LR3 regulators. > Too much trouble and expense to go sending back things to B&C for > exchange now from Australia. > > So I have purchased a second Odyssey AGM battery, in this case a PC310 > which is 7AH and weighs very little (2.7kg). > > Do you foresee of any problems with running the SD20 with the PC310 on > the secondary bus. > > Cheers Bob > ________________________________________________________________________________
Date: Jun 14, 2009
Subject: Is there a way to have part 14V and part 28V?
I have the opportunity to get some flight instruments from an acquaintance that is upgrading. The problem is they are all 28V. is there a way to have a part 28V and part 14V panel? Rodney Hall ________________________________________________________________________________
Subject: Re: Is there a way to have part 14V and part 28V?
Date: Jun 14, 2009
Rodney, Many small 14 to 28 v. converters are available for that purpose. Example.... when Garmin first came out with their 430 Navigator, their marketing plan was to capture most\all of the new aircraft OEM market. Great way to knock off King dominance. That meant they were designed for 28 v. In an older 14 v. aircraft you had to have an approved converter installed along with the 430. Garmin was smart enough to just have such an "approved unit. That is the way my C185D was done to get an early 430 installed as my main GPS Navigator. In homebuilts, the converter does not have to have the mass of paperwork approvals required and you should be able to find a good one for 1/10th what I was forced to pay. David Just make sure ----- Original Message ----- From: <r.r.hall(at)cox.net> Sent: Sunday, June 14, 2009 3:17 PM Subject: AeroElectric-List: Is there a way to have part 14V and part 28V? > > I have the opportunity to get some flight instruments from an acquaintance > that is upgrading. The problem is they are all 28V. is there a way to have > a part 28V and part 14V panel? > > Rodney Hall > > > ________________________________________________________________________________
Date: Jun 14, 2009
Sure, I recently did it for my Navion's engine conversion. I got a 14v to 28v converter to feed a 28v bus just for the engine instruments. I had to use a holy watered part. Even for a relatively small power rating (~5a was all I needed) it was big, heavy and not cheap. But if it's worth it to you it's not a big deal. Regards, Greg Young > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On > Behalf Of r.r.hall(at)cox.net > Sent: Sunday, June 14, 2009 5:17 PM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Is there a way to have part 14V > and part 28V? > > > I have the opportunity to get some flight instruments from an > acquaintance that is upgrading. The problem is they are all > 28V. is there a way to have a part 28V and part 14V panel? > > Rodney Hall > ________________________________________________________________________________
Date: Jun 15, 2009
At 08:29 AM 6/14/2009, you wrote: >As others have suggested, it does seem like Z14 is my best option as >I have the L40 and SD20 already installed and I have 2 off LR3 >regulators. Too much trouble and expense to go sending back things >to B&C for exchange now from Australia. > >So I have purchased a second Odyssey AGM battery, in this case a >PC310 which is 7AH and weighs very little (2.7kg). > >Do you foresee of any problems with running the SD20 with the PC310 >on the secondary bus. > >Cheers Bob No problems at all. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Subject: Re: Crowbar
Date: Jun 15, 2009
I am finishing up the installation of my external power receptacle. Just to be totally sure, please verify that the orange lead from the OVM14 is the positive lead and goes on the left terminal of the smaller posts on the contactor? Thanks in advance. -------- Myron Nelson Mesa, AZ Emp completed, legacy build fuse in progress Read this topic online here: http://forums.matronics.com/viewtopic.php?p=248300#248300 ________________________________________________________________________________
Date: Jun 15, 2009
IRA Thanks for reply....gauges are lit, but I kept the power and grounds for them completely separate so I could eliminate them if problems developed. (I hate cabin lighting in a VFR ship.) Tomorrow I will check lights dimmers and grounds as you suggest. Today I find that when I transmit on VHF the manifold pressure drops to "zero", then returns when PTT released. I recall it has done that before...tomorrow I will see if something is wrong there. (Radio has separate power and ground bus too....mabe PPP ?) Thanks again.....appreciate any and all suggestions! Jake -------- Jake Read this topic online here: http://forums.matronics.com/viewtopic.php?p=248373#248373 ________________________________________________________________________________
Date: Jun 16, 2009
At 02:24 PM 6/15/2009, you wrote: > >I am finishing up the installation of my external power receptacle. > >Just to be totally sure, please verify that the orange lead from the >OVM14 is the positive lead and goes on the left terminal of the >smaller posts on the contactor? Yes, the non-black lead is (+). The exact color was changed to identify mod levels in the construction. Don't know about the "left" terminal. The (+) lead of the crowbar module goes to the (+) supply termnial of the contactor . . . the black lead goes to the terminal that is connected to the ground power control breaker. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 16, 2009
Subject: New from Harbor Freight
I received a flyer from Harbor Freight yesterday, and one of the items in it was a new "borescope" that was priced down from $139 (on their website) to $99.99 in the local stores. So, knowing that I would need one soon to exam the inside of my fuel tanks when I get the holes for the fuel filler assembly cut (and who knows what other little holes I'd have to inspect), I went down and bought it. I bought it...it was much better than I expected, and a lot more solid than other Harbor Freight items I bought in the past. The first thing I noticed was that it was very well packaged in a semi-rigid plastic container. I'll use that to store it in. I think it has a lot of neat features (in addition to the price), so I thought I'd pass it on to you people in case you are looking for a tool to examine those hard to view places as well. The camera/light source head is 5/8 inch in diameter...the flexible shaft is 3 feet long. The camera, flex shaft and mounting head on the handle are attached with o-rings and are claimed to be water proof. The whole thing (including the monitor) has a nice solid feel to it and appears to be pretty rugged. Not the usual thin plastic like the Chinese stuff often is. The length of the camera head before it starts to be bendable may be a problem for some applications though, as even though the camera and it's fitting itself is only a little less than 3 inches in length, it needs 4-1/2 inches of clearance straight in to get a full bend in the flexible shaft. An application like this would be a good place to use the 45 degree mirror attachment that comes with it that I mention below. The monitor/display is in color, has adjustable brightness (in addition to the LED light source brightness adjustments), contrast and orientation (rotates the image in four steps) and can be removed easily from the handle and remoted as it uses a wireless connection to the camera. It also has a video output. It's cable has a standard RCA connector on the end so you can input it to any device that will accept a composite video input for recording or viewing on a larger screen. The camera and LEDs runs on 4 AA batteries in the handle, and the monitor has a rechargeable lithium ion battery. It comes with the charger as well. It has three attachments that fit over the camera head ...a mirror, a magnet and a pick. So you can hunt down and move or pick up things you find in those deep dark holes. It uses super bright LEDs for the camera's light source, and the light level is adjustable through a trigger on the handle. The camera does pretty good in low light as well...I was viewing items in my house this morning without using the LEDs. You can see it online here: www.harborfreight.com/cpi/ctaf/displayitem.taf?function=Search And the manual is here: www.harborfreight.com/manuals/66000-66999/66550.pdf Harley Dixon Long EZ N28EZ Canandaigua, NY ________________________________________________________________________________
Date: Jun 16, 2009
Subject: Re: New from Harbor Freight
Oops...I broke the link! Here's the link to the borescope itself...remember, it was only $99.99 in the store here in Henrietta. www.harborfreight.com/cpi/ctaf/displayitem.taf?itemnumber=66550&Submit=Go The manual's link was OK... Harley ------------------------------------------------------------------------ Harley wrote: > I received a flyer from Harbor Freight yesterday, and one of the items > in it was a new "borescope" that was priced down from $139 (on their > website) to $99.99 in the local stores. > > So, knowing that I would need one soon to exam the inside of my fuel > tanks when I get the holes for the fuel filler assembly cut (and who > knows what other little holes I'd have to inspect), I went down and > bought it. > > I bought it...it was much better than I expected, and a lot more solid > than other Harbor Freight items I bought in the past. The first thing > I noticed was that it was very well packaged in a semi-rigid plastic > container. I'll use that to store it in. > > I think it has a lot of neat features (in addition to the price), so I > thought I'd pass it on to you people in case you are looking for a > tool to examine those hard to view places as well. > > The camera/light source head is 5/8 inch in diameter...the flexible > shaft is 3 feet long. The camera, flex shaft and mounting head on the > handle are attached with o-rings and are claimed to be water proof. > The whole thing (including the monitor) has a nice solid feel to it > and appears to be pretty rugged. Not the usual thin plastic like the > Chinese stuff often is. > > The length of the camera head before it starts to be bendable may be a > problem for some applications though, as even though the camera and > it's fitting itself is only a little less than 3 inches in length, it > needs 4-1/2 inches of clearance straight in to get a full bend in the > flexible shaft. An application like this would be a good place to use > the 45 degree mirror attachment that comes with it that I mention below. > > The monitor/display is in color, has adjustable brightness (in > addition to the LED light source brightness adjustments), contrast and > orientation (rotates the image in four steps) and can be removed > easily from the handle and remoted as it uses a wireless connection to > the camera. It also has a video output. It's cable has a standard > RCA connector on the end so you can input it to any device that will > accept a composite video input for recording or viewing on a larger > screen. > > The camera and LEDs runs on 4 AA batteries in the handle, and the > monitor has a rechargeable lithium ion battery. It comes with the > charger as well. It has three attachments that fit over the camera > head ...a mirror, a magnet and a pick. So you can hunt down and move > or pick up things you find in those deep dark holes. > > It uses super bright LEDs for the camera's light source, and the light > level is adjustable through a trigger on the handle. The camera does > pretty good in low light as well...I was viewing items in my house > this morning without using the LEDs. > > You can see it online here: > www.harborfreight.com/cpi/ctaf/displayitem.taf?function=Search > > And the manual is here: > www.harborfreight.com/manuals/66000-66999/66550.pdf > > Harley Dixon > Long EZ N28EZ > Canandaigua, NY* > * ________________________________________________________________________________
Subject: Tyco Breakers
Date: Jun 16, 2009
Does anyone have any experience with the Tyco Rocker type switch/breaker? They are specified in the Digi-Key PTM as "secondary breakers", which must be backed up by a branch circuit breaker or fuse http://dkc1.digikey.com/us/en/tod/TycoElectronicsPB/CircuitBreakers_NoAud io/ CircuitBreakers_NoAudio.html. This would seem to defeat the purpose of having the breaker in the first place. What am I missing? Ken Howell Glenwood, MD RV-7 Fuselage ________________________________________________________________________________
Date: Jun 16, 2009
Harley, when I try to order the item it comes up at $139.95 that is the regular price, but the sale price does not come up. Is the item still on sale? Jim streit Harley wrote: > > Oops...I broke the link! > > Here's the link to the borescope itself...remember, it was only $99.99 > in the store here in Henrietta. > > www.harborfreight.com/cpi/ctaf/displayitem.taf?itemnumber=66550&Submit=Go > > The manual's link was OK... > > Harley > ------------------------------------------------------------------------ > Harley wrote: >> I received a flyer from Harbor Freight yesterday, and one of the >> items in it was a new "borescope" that was priced down from $139 (on >> their website) to $99.99 in the local stores. ________________________________________________________________________________
Date: Jun 16, 2009
I mentioned the price difference in the last email. It was $99.99 in the store...$139 on the website...note at the bottom of the listing on the website, it says: "Prices on our website may or may not be current prices in our stores" I first saw it for the $99.99 price in a flyer that Harbor Freight sent two days ago. Harley ------------------------------------------------------------------------ Jim Streit wrote: > Harley, when I try to order the item it comes up at $139.95 that is > the regular price, but the sale price does not come up. Is the item > still on sale? > > Jim streit > > > Harley wrote: >> >> >> Oops...I broke the link! >> >> Here's the link to the borescope itself...remember, it was only >> $99.99 in the store here in Henrietta. >> >> www.harborfreight.com/cpi/ctaf/displayitem.taf?itemnumber=66550&Submit=Go >> >> >> The manual's link was OK... >> >> Harley >> ------------------------------------------------------------------------ >> Harley wrote: >>> I received a flyer from Harbor Freight yesterday, and one of the >>> items in it was a new "borescope" that was priced down from $139 (on >>> their website) to $99.99 in the local stores. > > * > > > * ________________________________________________________________________________
Date: Jun 16, 2009
At 01:03 PM 6/16/2009, you wrote: >I mentioned the price difference in the last email. > >It was $99.99 in the store...$139 on the website...note at the >bottom of the listing on the website, it says: "Prices on our >website may or may not be current prices in our stores" A gentleman at the local HF store explained that their merchandising is handled through three somewhat exclusive channels. The catalog sales, website sales and storefront sales are different pipes and may have differences in prices and products offered. On occasion, I've been to the local store with a catalog in hand where the catalog price was lower than the store price . . . they readily offered the product at the lower price. But sale prices in the stores are not tightly tied to the catalog or website offerings. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 16, 2009
Robert L. Nuckolls, III wrote: > At 01:03 PM 6/16/2009, you wrote: >> I mentioned the price difference in the last email. >> >> It was $99.99 in the store...$139 on the website...note at the bottom >> of the listing on the website, it says: "Prices on our website may or >> may not be current prices in our stores" > > A gentleman at the local HF store explained that > their merchandising is handled through three > somewhat exclusive channels. The catalog sales, > website sales and storefront sales are different > pipes and may have differences in prices and > products offered. > > On occasion, I've been to the local store with > a catalog in hand where the catalog price was > lower than the store price . . . they readily > offered the product at the lower price. But > sale prices in the stores are not tightly tied > to the catalog or website offerings. > > Bob . . . > A gentleman in another forum I belong to mentioned that Ridgid has the same thing...so... A search for "color inspection cameras" comes up with several different brand names, and ALL of them are identical. Looks like this is one of those cases where China makes it and sells it to everyone who wants to market one, putting their own brand name on them. The prices for this unit vary from as high as $450 for the 4UCAM model, to Harbor Freight's $99. The average appears to be around $250. Dollars to donuts, Harbor Freight is getting them from the same company that is making them for Ridgid. http://tinyurl.com/mw5yug http://tinyurl.com/nskvv5 Also one of the accessories available for it is a 9.5 mm camera to replace the 17mm one that comes with it (the camera and flexible cable plug into the same hand unit). That size WILL fit in a spark plug hole! It also says that the smaller camera has a shorter focal distance for closer and smaller work. http://tinyurl.com/makor3 I'll bet that it fits the HF model perfectly! Know I now why the unit felt so substantial and "un-Harbor Freight-Like" when I opened up the package! It was probably designed for Ridgid! Now if we can only get HF to sell that smaller camera accessory...if they ever do, it'll prolly be for $9.99 or so! Harley ________________________________________________________________________________
Date: Jun 16, 2009
Harley, Could you cut/paste the coupon (if it was a coupon sale) or the flier? I searched my HF emails and couldn't find the item, but if I had a coupon/flier, the local store would honor it. Thanks, Don -----Original Message----- From: owner-aeroelectric-list-server=40matronics.com =5Bmailto:owner-aeroelectric-list-server=40matronics.com=5D On Behalf Of Harley Sent: Tuesday, June 16, 2009 5:14 PM Subject: Re: AeroElectric-List: New from Harbor Freight Robert L. Nuckolls, III wrote: At 01:03 PM 6/16/2009, you wrote: I mentioned the price difference in the last email. It was =2499.99 in the store...=24139 on the website...note at the bottom of the listing on the website, it says: =22Prices on our website may or may not be current prices in our stores=22 A gentleman at the local HF store explained that their merchandising is handled through three somewhat exclusive channels. The catalog sales, website sales and storefront sales are different pipes and may have differences in prices and products offered. On occasion, I've been to the local store with a catalog in hand where the catalog price was lower than the store price . . . they readily offered the product at the lower price. But sale prices in the stores are not tightly tied to the catalog or website offerings. Bob . . . A gentleman in another forum I belong to mentioned that Ridgid has the same thing...so... A search for =22color inspection cameras=22 comes up with several different brand names, and ALL of them are identical. Looks like this is one of those cases where China makes it and sells it to everyone who wants to market one, putting their own brand name on them. The prices for this unit vary from as high as =24450 for the 4UCAM model, to Harbor Freight's =2499. The average appears to be around =24250. Dollars to donuts, Harbor Freight is getting them from the same company that is making them for Ridgid. http://tinyurl.com/mw5yug http://tinyurl.com/nskvv5 Also one of the accessories available for it is a 9.5 mm camera to replace the 17mm one that comes with it (the camera and flexible cable plug into the same hand unit). That size WILL fit in a spark plug hole=21 It also says that the smaller camera has a shorter focal distance for closer and smaller work. http://tinyurl.com/makor3 I'll bet that it fits the HF model perfectly=21 Know I now why the unit felt so substantial and =22un-Harbor Freight-Like=22 when I opened up the package=21 It was probably designed for Ridgid=21 Now if we can only get HF to sell that smaller camera accessory...if they ever do, it'll prolly be for =249.99 or so=21 Harley ____________________________________________________________ FREE 3D EARTH SCREENSAVER - Watch the Earth right on your desktop=21 Check it out at http://www.inbox.com/earth ________________________________________________________________________________
Date: Jun 16, 2009
>>but if I had a coupon/flier, the local store would honor it.<< Yep, they are great that way! I've done that myself in the past. However, it wasn't a coupon sale...it was in the Fourth of July flier...you may not have received it yet! I just got mine yesterday. The price in the store scanned as $99.99, so it was in their computer as that price...no coupon or flier needed. However... I took the flier with me in case they didn't have the current price, and ran into another gentleman who was trying to convince the cashier that he saw the price of ANOTHER item for less but he didn't have the flier with him. So, I gave him mine! So, sorry, I don't have it (but neither did the store yet...the store manager here said that they usually get the fliers that are mailed to the customers a few days after the customers get them.) If you don't get one by Monday next week, or your local store doesn't have it by then, let me know and I'll see if I can dig one up locally. HF is only about 5 minutes from me here. BTW...in further research, I discovered that that inspection camera is a Ridgid, and is last year's model that is being sold by the manufacturer in China under a bunch of other brand names now that Ridgid's is a bit different (use the same camera head and cable for both, though.) Harley ------------------------------------------------------------------------ Don Curry wrote: > > Harley, > > Could you cut/paste the coupon (if it was a coupon sale) or the > flier? I searched my HF emails and couldn't find the item, but if I > had a coupon/flier, the local store would honor it. Thanks, Don > > > > > > > > -----Original Message----- > *From:* owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of > *Harley > *Sent:* Tuesday, June 16, 2009 5:14 PM > *To:* aeroelectric-list(at)matronics.com > *Subject:* Re: AeroElectric-List: New from Harbor Freight > > > > > Robert L. Nuckolls, III wrote: > > At 01:03 PM 6/16/2009, you wrote: > > I mentioned the price difference in the last email. > > It was $99.99 in the store...$139 on the website...note at the bottom > of the listing on the website, it says: "Prices on our website may or > may not be current prices in our stores" > > > A gentleman at the local HF store explained that > their merchandising is handled through three > somewhat exclusive channels. The catalog sales, > website sales and storefront sales are different > pipes and may have differences in prices and > products offered. > > On occasion, I've been to the local store with > a catalog in hand where the catalog price was > lower than the store price . . . they readily > offered the product at the lower price. But > sale prices in the stores are not tightly tied > to the catalog or website offerings. > > > Bob . . . > > A gentleman in another forum I belong to mentioned that Ridgid has the > same thing...so... > > A search for "color inspection cameras" comes up with several > different brand names, and ALL of them are identical. Looks like this > is one of those cases where China makes it and sells it to everyone > who wants to market one, putting their own brand name on them. The > prices for this unit vary from as high as $450 for the 4UCAM model, to > Harbor Freight's $99. The average appears to be around $250. Dollars > to donuts, Harbor Freight is getting them from the same company that > is making them for Ridgid. > > http://tinyurl.com/mw5yug > http://tinyurl.com/nskvv5 > > Also one of the accessories available for it is a 9.5 mm camera to > replace the 17mm one that comes with it (the camera and flexible cable > plug into the same hand unit). That size WILL fit in a spark plug > hole! It also says that the smaller camera has a shorter focal > distance for closer and smaller work. > http://tinyurl.com/makor3 > > I'll bet that it fits the HF model perfectly! Know I now why the unit > felt so substantial and "un-Harbor Freight-Like" when I opened up the > package! It was probably designed for Ridgid! > > Now if we can only get HF to sell that smaller camera accessory...if > they ever do, it'll prolly be for $9.99 or so! > > Harley > > * * > * * > ** > ** > ** > ** > ** > ** > ** > *http://www.matronics.com/contribution* > * * > ------------------------------------------------------------------------ > 3D Earth Screensaver Preview <http://www.inbox.com/earth> > *Free 3D Earth Screensaver* > Watch the Earth right on your desktop! Check it out at > www.inbox.com/earth <http://www.inbox.com/earth> > * > > > * ________________________________________________________________________________
Subject: pitot heat wire gauge
Date: Jun 16, 2009
Can anyone offer an appropriate wire size to prewire for pitot heat, probably the Dynon unit? Thanks in advance. -------- Myron Nelson Mesa, AZ Emp completed, legacy build fuse in progress Read this topic online here: http://forums.matronics.com/viewtopic.php?p=248548#248548 ________________________________________________________________________________
Date: Jun 16, 2009
How long was the price good for? Steve Thomas ________________________________________________________________________ On Jun 16, 2009, at 3:00 PM, Don Curry wrote: > Harley, > Could you cut/paste the coupon (if it was a coupon sale) or the > flier? I searched my HF emails and couldn=92t find the item, but if I > had a coupon/flier, the local store would honor it. Thanks, Don > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com > ] On Behalf Of Harley > Sent: Tuesday, June 16, 2009 5:14 PM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: New from Harbor Freight > > > Robert L. Nuckolls, III wrote: > At 01:03 PM 6/16/2009, you wrote: > > I mentioned the price difference in the last email. > > It was $99.99 in the store...$139 on the website...note at the > bottom of the listing on the website, it says: "Prices on our > website may or may not be current prices in our stores" > > A gentleman at the local HF store explained that > their merchandising is handled through three > somewhat exclusive channels. The catalog sales, > website sales and storefront sales are different > pipes and may have differences in prices and > products offered. > > On occasion, I've been to the local store with > a catalog in hand where the catalog price was > lower than the store price . . . they readily > offered the product at the lower price. But > sale prices in the stores are not tightly tied > to the catalog or website offerings. > > > Bob . . . > > A gentleman in another forum I belong to mentioned that Ridgid has > the same thing...so... > > A search for "color inspection cameras" comes up with several > different brand names, and ALL of them are identical. Looks like > this is one of those cases where China makes it and sells it to > everyone who wants to market one, putting their own brand name on > them. The prices for this unit vary from as high as $450 for the > 4UCAM model, to Harbor Freight's $99. The average appears to be > around $250. Dollars to donuts, Harbor Freight is getting them from > the same company that is making them for Ridgid. > > http://tinyurl.com/mw5yug > http://tinyurl.com/nskvv5 > > Also one of the accessories available for it is a 9.5 mm camera to > replace the 17mm one that comes with it (the camera and flexible > cable plug into the same hand unit). That size WILL fit in a spark > plug hole! It also says that the smaller camera has a shorter focal > distance for closer and smaller work. > http://tinyurl.com/makor3 > > I'll bet that it fits the HF model perfectly! Know I now why the > unit felt so substantial and "un-Harbor Freight-Like" when I opened > up the package! It was probably designed for Ridgid! > > Now if we can only get HF to sell that smaller camera accessory...if > they ever do, it'll prolly be for $9.99 or so! > > Harley > > > http://www.matronics.com/contribution > > > Free 3D Earth Screensaver > Watch the Earth right on your desktop! Check it out at www.inbox.com/earth > > ________________________________________________________________________________
From: "kuffel(at)cyberport.net" <kuffel(at)cyberport.net>
Subject: Re: Tyco Breakers
Date: Jun 16, 2009
Ken, << Does anyone have any experience with the Tyco Rocker type switch/breaker? I used the Tyco/Airpax/(now)Sensata/Snapak style rocker circuit breaker/switches as primary power control in my homebuilt in the mid-90s. Gave excellent service, not one failure. I'm using the same style in the Sportsman I'm currently building. The specific type is R11-1-[amperage]-G06EV. They are Hydraulic-Magnetic type, not thermal. You can find all the specifications at airpax.sensata.com. Bob Nuckolls does not approve of this arrangement. But this type is specified as usable in life-critical medical devices which, together with my personal experience, is good enough for me. Tom Kuffel, AL7AU ________________________________________________________________________________
Date: Jun 16, 2009
Looks like I'd better get that flier back if these questions keep coming up! >>How long was the price good for?<< Not sure how long, it was in the Fourth of July flier, so I would guess that it was good until at least the Fourth of July! But, in the past, I've taken in old fliers with old prices on them (a few weeks old, not years! ) and they have honored them. Harley ------------------------------------------------------------------------ Steve Thomas wrote: > How long was the price good for? > > Steve Thomas > ________________________________________________________________________ > > > On Jun 16, 2009, at 3:00 PM, Don Curry wrote: > >> Harley, >> Could you cut/paste the coupon (if it was a coupon sale) or the >> flier? I searched my HF emails and couldnt find the item, but if I >> had a coupon/flier, the local store would honor it. Thanks, Don >> >> >> >> >> >> >> -----Original Message----- >> *From:* owner-aeroelectric-list-server(at)matronics.com >> [mailto:owner-aeroelectric-list-server(at)matronics.com] *On >> Behalf Of *Harley >> *Sent:* Tuesday, June 16, 2009 5:14 PM >> *To:* aeroelectric-list(at)matronics.com >> >> *Subject:* Re: AeroElectric-List: New from Harbor Freight >> >> >> >> >> >> Robert L. Nuckolls, III wrote: >> At 01:03 PM 6/16/2009, you wrote: >> >> I mentioned the price difference in the last email. >> >> It was $99.99 in the store...$139 on the website...note at the bottom >> of the listing on the website, it says: "Prices on our website may or >> may not be current prices in our stores" >> >> A gentleman at the local HF store explained that >> their merchandising is handled through three >> somewhat exclusive channels. The catalog sales, >> website sales and storefront sales are different >> pipes and may have differences in prices and >> products offered. >> >> On occasion, I've been to the local store with >> a catalog in hand where the catalog price was >> lower than the store price . . . they readily >> offered the product at the lower price. But >> sale prices in the stores are not tightly tied >> to the catalog or website offerings. >> >> >> Bob . . . >> >> A gentleman in another forum I belong to mentioned that Ridgid has >> the same thing...so... >> >> A search for "color inspection cameras" comes up with several >> different brand names, and ALL of them are identical. Looks like >> this is one of those cases where China makes it and sells it to >> everyone who wants to market one, putting their own brand name on >> them. The prices for this unit vary from as high as $450 for the >> 4UCAM model, to Harbor Freight's $99. The average appears to be >> around $250. Dollars to donuts, Harbor Freight is getting them from >> the same company that is making them for Ridgid. >> >> http://tinyurl.com/mw5yug >> http://tinyurl.com/nskvv5 >> >> Also one of the accessories available for it is a 9.5 mm camera to >> replace the 17mm one that comes with it (the camera and flexible >> cable plug into the same hand unit). That size WILL fit in a spark >> plug hole! It also says that the smaller camera has a shorter focal >> distance for closer and smaller work. >> http://tinyurl.com/makor3 >> >> I'll bet that it fits the HF model perfectly! Know I now why the >> unit felt so substantial and "un-Harbor Freight-Like" when I opened >> up the package! It was probably designed for Ridgid! >> >> Now if we can only get HF to sell that smaller camera accessory...if >> they ever do, it'll prolly be for $9.99 or so! >> >> Harley >> * * >> * * >> ** >> ** >> ** >> ** >> ** >> ** >> ** >> *http://www.matronics.com/contribution* >> * * >> ------------------------------------------------------------------------ >> 3D Earth Screensaver Preview <http://www.inbox.com/earth> >> *Free 3D Earth Screensaver* >> Watch the Earth right on your desktop! Check it out >> at www.inbox.com/earth <http://www.inbox.com/earth> >> * >> >> href="http://www.matronics.com/Navigator?AeroElectric-List" style="color: blue; text-decoration: underline; ">http://www.matronics.com/Navigator?AeroElectric-List >> blue; text-decoration: underline; ">http://forums.matronics.com >> style="color: blue; text-decoration: underline; ">http://www.matronics.com/contribution >> >> * >> > > * > > > * ________________________________________________________________________________
Date: Jun 16, 2009
Subject: Re: pitot heat wire gauge
At 05:18 PM 6/16/2009, you wrote: > >Can anyone offer an appropriate wire size to prewire for pitot heat, >probably the Dynon unit? > >Thanks in advance. Most 14v pitot heaters use 9-11A of continuous running load (150W). Their inrush current is high and protracted. I'd go with a 20A fuse/ breaker and 14AWG wire. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 16, 2009
At 05:50 PM 6/16/2009, you wrote: >Looks like I'd better get that flier back if these questions keep coming up! > > >>How long was the price good for?<< > >Not sure how long, it was in the Fourth of July flier, so I would >guess that it was good until at least the Fourth of July! But, in >the past, I've taken in old fliers with old prices on them (a few >weeks old, not years! ) and they have honored them. Yeah. They've been very consumer friendly here too. Had a 2.5Kw generator still in a box that I wanted to trade in for a 6Kw machine. I'd had it almost three years. He looked in the computer and found that it was still stocked in their system so he took it back and gave me full credit toward the larger machine. On the few occasions I've had quality issues (like un-sticky sticky-stuff on sanding disks, they swapped out and/or refunded even if I didn't have the receipt. What they may lack in quality of some items, they more than compensated for it in customer service. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 16, 2009
At 06:01 PM 6/16/2009, you wrote: > > > >Ken, > ><< Does anyone have any experience with the Tyco Rocker type >switch/breaker? > >I used the Tyco/Airpax/(now)Sensata/Snapak style rocker >circuit breaker/switches as primary power control in my >homebuilt in the mid-90s. Gave excellent service, not one >failure. I'm using the same style in the Sportsman I'm >currently building. The specific type is >R11-1-[amperage]-G06EV. They are Hydraulic-Magnetic type, >not thermal. You can find all the specifications at >airpax.sensata.com. Bob Nuckolls does not approve of this >arrangement. There's a BIG difference between approval and recommendation. I DON'T disapprove anything. I DO make recommendations based on cost of ownership and using parts in a manner that does put a mission at risk should a part fail. >But this type is specified as usable in >life-critical medical devices which, together with my >personal experience, is good enough for me. These are indeed Cadillac breaker/switches . . . with a price to match. But if your system design goals include achievement of failure tolerant design then the $extra$ cost only buys you a style of device and adds nothing to system reliability for the airplane. I've not seen this class of breaker used anywhere on a TC aircraft of any size or price. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 16, 2009
At 12:08 PM 6/16/2009, you wrote: >Does anyone have any experience with the Tyco Rocker type switch/breaker? > >They are specified in the Digi-Key PTM as "secondary breakers", >which must be backed up by a branch circuit breaker or fuse ><http://dkc1.digikey.com/us/en/tod/TycoElectronicsPB/CircuitBreakers_NoAudio/CircuitBreakers_NoAudio.html>http://dkc1.digikey.com/us/en/tod/TycoElectronicsPB/CircuitBreakers_NoAudio/CircuitBreakers_NoAudio.html. > >This would seem to defeat the purpose of having the breaker in the >first place. What am I missing? Beats me. This is the first time I've seen that terminology used in describing the application of circuit protection. Did some searching and found this tid-bit . . . Emacs! This was excerpted from a book on wiring design for large AC power distribution systems. I don't think this applies to our 14/28V DC systems in light aircraft. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 16, 2009
Subject: Unique aviation video . . .
See: http://tinyurl.com/3x76dd Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 16, 2009
According to the Dynon manual, "The maximum draw of the heated pitot controller/probe is 10 amps." which is a bit less than the typical heated pitot. They recommend at least a #14 wire for a 10'-16' run. You can download the manual from their web site. -------- rck Read this topic online here: http://forums.matronics.com/viewtopic.php?p=248609#248609 ________________________________________________________________________________
Subject: Re: noisy tach signal
Date: Jun 16, 2009
I have been unable to solve this problem so far and am considering a different tach sensor or even buying / installing a stand-alone tach as I'm getting frustrated in trying to get the IK-2000 engine monitor tach to work with the factory recommended sensor. If anyone has any suggestions on what I'm missing in making this work, any input is appreciated. Here's where I'm at right now: 1. I cut the Hall effect sensor factory harness as short as I could for installing connectors and used a 3-wire shielded cable from there to aft of the firewall to connect the Hall effect sensor power, signal, and ground wires. I soldered a short ground wire to the shield at the sensor end of the cable and grounded it via ring terminal at the same mag location that I grounded the p-lead shield. No improvement - in fact, probably worse than without the shielded cable. 2. I moved the Hall effect sensor from the right mag to the left mag to see if the same noise issue was observed and to see if the problem moved with the sensor to the other mag. The problem DID move to the other mag and was identical in performance (or lack thereof). So the Hall effect sensor gives good rpm indication on the IK-2000 as long as the mag it is installed in is NOT operating. As soon as I move the p-lead switch to "On" for the mag the sensor is installed on, the tach signal becomes unusable. At low rpm (below about 2000 rpm), the signal usually reads as if no signal is being recieved (reads 20 or 30 rpm, same as when IK-2000 energized with engine off). At high power settings, the tach indication bounces between reading correct to being 100 to 300 rpm low and the number changes frequently even with constant actual engine rpm. One interesting note is that the tach reading is more accurate, i.e. less noise, when the engine is first started and run from being cold (ambient temp). On initial (cold) startup, I start getting good tach indication at about 1200 to 1500 rpm, allowing normal runup and takeoff, and at cruise power settings everything looks good with the tach. After shutdown and subsequent restart following initial flight of the day, I don't get a good, or even close, reading until power goes above about 2000 rpm. After warmup in flight, tach indication is jumpy and reads low even at 2200 to 2300 rpm power settings. At any time, I can get a solid and apparently accurate tach reading by securing the mag that has the Hall effect sensor installed (I make the "apparently accurate" statement based on past operating conditions: throttle position, sound, and airspeed/fuel flow performance data, and the fact that the reading goes back to steady, solid reading vice jumping around, and the idle readings are where they should/have been). 3. As mentioned below, I tried installing 0.1 uF capacitor between signal/gnd with no improvement. Same for installing 0.1 uF b/w +5V and gnd. Whatever noise is being induced is driving the tach signal to point of no pulses detected when the mag with sensor installed is operating. I can't physically seperate the sensor line from the mag or the p-lead any more than I already have. Has anybody had success with the Westach Hall effect sensor installed in a Slick mag? Anybody using this combination with an IK-Technologies engine monitor? If so on either, did you encounter any noise issues that had to be overcome? Any advice/help is appreciated. Thanks, Chris RV-6A, N731CK ----- Original Message ----- From: "Chris Hand" <chris_hand(at)comcast.net> Sent: Wednesday, June 03, 2009 11:54 PM Subject: AeroElectric-List: noisy tach signal > > > I'm having a lot of trouble getting a good tach reading on my IK-2000 > engine monitor using a Hall effect sensor on a Slick mag and am looking > for > suggestions on what to try next. I've tried multiple different wiring > routings and tried 0.1 uF capacitor between signal lead and ground as well > as between +5V power lead and ground, with no success (problem actually > got worse when I added the caps so I took them back out). > > History is that I initially had dual P-mag setup with tach sensor reading > off right P-mag. Tach worked fine in that configuration. At about 26 > hours > total time I replaced the left P-mag with an impulse coupled Slick mag, > still taking tach signal off right side P-mag. In that configuration I > had > noise issues causing problems with the tach reading at power settings > below about 1800 rpm (engine / prop combo is O-360, fixed pitch > Sensenich). The > issue only showed up on throttling back when in flight; didn't see it on > the ground except after landing when I had the problem in flight. Those > tach problems were resolved by tying the Slick mag p-lead up a little > further away from the tach sensor leads (although they were already > seperated by at least 6 or 8 inches at closest approach). > > This past weekend I changed out the right side P-mag for non-impulse > coupled Slick mag and installed a Hall effect sensor in the mag vent hole > for > feeding the IK-2000 tach sensor lines. This was the sensor suggested by > IK-Technologies. Ground testing shows good tach readings only at rpms > above about 1000-1200 rpm but after 10 or 15 minutes of flight time it > starts reading low and erratic at power settings below about 2000 rpm, > becoming completely unusable at approach and idle power settings. If I > secure the right mag at any time (ground or in-flight testing), the tach > reading is steady and appears accurate. So the noise is being introduced > by the right mag when it is operating, but with the mag not firing, the > sensor > installed on that mag works great. > > I am using the factory supplied sensor wiring harness, which uses twisted > pair wiring with none of the leads being shielded. I had extra lengths in > this harness when I installed it so have the extra length coiled up under > the forward top skin. For lack of any other ideas, I'm thinking about > removing the factory harness and building a new one using 3-wire shielded > cable for the tach sensor lines. > > Has anybody else on the list run into tach signal noise issues when using > standard mags with Hall effect sensor? Any suggestions on what else I can > do to fix this? (aside from going to a different sensor type or > stand-alone tachometer) > > Thanks in advance for any suggestions! > > Chris > RV-6A, N731CK, 55 hrs > > > ________________________________________________________________________________
Subject: What size hook up wire for the radio/Ptt switching
etc??
Date: Jun 16, 2009
Noticed on a Icom 210A rear plug that they used different color wires of approx 24 or 26 awg. Does anyone have a part number or the place to get this type of wire as Aircraft spruce only has limited colors.Cheers Read this topic online here: http://forums.matronics.com/viewtopic.php?p=248644#248644 ________________________________________________________________________________
Subject: Re: What size hook up wire for the radio/Ptt switching
etc??
Date: Jun 17, 2009
http://www.steinair.com/wire.htm ----- Original Message ----- From: "Thruster87" <alania(at)optusnet.com.au> Sent: Wednesday, June 17, 2009 7:49 AM Subject: AeroElectric-List: What size hook up wire for the radio/Ptt switching etc?? > > > Noticed on a Icom 210A rear plug that they used different color wires of > approx 24 or 26 awg. Does anyone have a part number or the place to get > this type of wire as Aircraft spruce only has limited colors.Cheers > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=248644#248644 > > > ________________________________________________________________________________
Subject: Nav Comm Antenna
Date: Jun 17, 2009
I searched the archives but to no success. How far should belly mounted Comm and VOR antennas be spaced apart? Randy R. ________________________________________________________________________________
etc??
Date: Jun 17, 2009
B & C Specialty Products - http://www.bandc.biz/index.asp Bob Borger Europa Kit #A221 N914XL, XS Mono, Intercooled 914, Airmaster C/S http://www.europaowners.org/N914XL Aircraft Flying! 3705 Lynchburg Dr. Corinth, TX 76208 Home: 940-497-2123 Cel: 817-992-1117 On Jun 17, 2009, at 1:49, Thruster87 wrote: > > > > Noticed on a Icom 210A rear plug that they used different color > wires of approx 24 or 26 awg. Does anyone have a part number or the > place to get this type of wire as Aircraft spruce only has limited > colors.Cheers > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=248644#248644 > > ________________________________________________________________________________
Date: Jun 17, 2009
It appears that they are referring to the primary and secondary windings of the transformer, and not in the sense of a "backup". In a nutshell, here's the way I interpret the Tyco spec: You can use our circuit breakers to protect a circuit, but you must also use another circuit breaker or fuse to protect the same circuit. Does that make sense? Ken -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Tuesday, June 16, 2009 9:12 PM Subject: Re: AeroElectric-List: Tyco Breakers At 12:08 PM 6/16/2009, you wrote: Does anyone have any experience with the Tyco Rocker type switch/breaker? They are specified in the Digi-Key PTM as "secondary breakers", which must be backed up by a branch circuit breaker or fuse http://dkc1.digikey.com/us/en/tod/TycoElectronicsPB/CircuitBreakers_NoAud io/ CircuitBreakers_NoAudio.html . This would seem to defeat the purpose of having the breaker in the first place. What am I missing? Beats me. This is the first time I've seen that terminology used in describing the application of circuit protection. Did some searching and found this tid-bit . . . Emacs! This was excerpted from a book on wiring design for large AC power distribution systems. I don't think this applies to our 14/28V DC systems in light aircraft. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 17, 2009
Subject: Re: Unique aviation video . . .
Saw a longer story about high tension wire repairs some time ago on one of the cable/satellite channels...Discovery maybe? Went into details on all the tools and equipment needed and why. Was very interesting! And entertaining! And, like the guy in this video...I'm afraid of the same three things he is...heights (and I too fly), electricity (and I too built a career around it) and women (but unlike him, I'm no longer married! ) Harley ------------------------------------------------------------------------ Robert L. Nuckolls, III wrote: > See: > > * http://tinyurl.com/3x76dd* > > Bob . . .** > ________________________________________________________________________________
Date: Jun 17, 2009
etc?? Interesting replies to your post. Checking the web sites, B&C has one color of 24 awg, Stein has none, and Aircraft Spruce has 6 listed. :) Those are all fine companies, but I would suggest that you use 22 awg wire for the extension you are building or whatever. It's easier to work with, won't weigh significantly more, and more readily available in different colors. Bob W. "Thruster87" wrote: > > Noticed on a Icom 210A rear plug that they used different color wires of approx 24 or 26 awg. Does anyone have a part number or the place to get this type of wire as Aircraft spruce only has limited colors.Cheers > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=248644#248644 > > > > > > > > > > -- N93BD - Rotary Powered BD-4 - http://www.bob-white.com 3.8 Hours Total Time and holding Cables for your rotary installation - http://roblinstores.com/ ________________________________________________________________________________
Date: Jun 17, 2009
At 07:11 AM 6/17/2009, you wrote: >It appears that they are referring to the primary and secondary >windings of the transformer, and not in the sense of a "backup". > >In a nutshell, here's the way I interpret the Tyco spec: You can use >our circuit breakers to protect a circuit, but you must also use >another circuit breaker or fuse to protect the same circuit. Does >that make sense? Not in a small footprint DC power distribution system typical of a vehicle. You can use these breakers like any other breaker in crafting your project. The primary/secondary thing is unique to AC systems where transformers are used for changing voltage levels or offering isolation between sides of a system. Clearly we don't do this in little airplanes. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 17, 2009
Subject: Re: Nav Comm Antenna
At 05:36 AM 6/17/2009, you wrote: >I searched the archives but to no success. How far should belly >mounted Comm and VOR antennas be spaced apart? Randy R. As far as practical without getting silly. What kind of VOR antenna do you have that mounts on the belly? Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Subject: Burning Vans Engine Gauges - Part 3
Date: Jun 17, 2009
Thanks so far to those with advice! It was frustrating to watch the engine gauges overheat and melt while watching 14.2 Volts show on multimeter at gauge. Right now, I turn master on and all gauges light up, but after I start some gauges drop off and fail to power up unless I cycle the Master. Is this from low voltage do you suppose? -I plan to replace all damaged gauges (Volt, Oil Temp, Manifold) -I will replace alternator (currently a Nippon Denso internally regulated with standard pulley) despite it testing OK. -Should I add over-voltage separately? -Should I switch instrument power to eliminate them being on line during start? Thanks for ideas...Jake -------- Jake Read this topic online here: http://forums.matronics.com/viewtopic.php?p=248712#248712 ________________________________________________________________________________
Date: Jun 17, 2009
I think you're looking in the wrong place. You're drawing to many amps through the instruments. Hook up an ammeter to the instrument ground and measure the draw when you start the engine and while running. Bruce www.Glasair.org -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of JakeTheBosun Sent: Wednesday, June 17, 2009 12:07 PM Subject: AeroElectric-List: Burning Vans Engine Gauges - Part 3 Thanks so far to those with advice! It was frustrating to watch the engine gauges overheat and melt while watching 14.2 Volts show on multimeter at gauge. Right now, I turn master on and all gauges light up, but after I start some gauges drop off and fail to power up unless I cycle the Master. Is this from low voltage do you suppose? -I plan to replace all damaged gauges (Volt, Oil Temp, Manifold) -I will replace alternator (currently a Nippon Denso internally regulated with standard pulley) despite it testing OK. -Should I add over-voltage separately? -Should I switch instrument power to eliminate them being on line during start? Thanks for ideas...Jake -------- Jake Read this topic online here: http://forums.matronics.com/viewtopic.php?p=248712#248712 ________________________________________________________________________________
Subject: Re: Burning Vans Engine Gauges - Part 3
Date: Jun 17, 2009
Thanks Bruce...(will do this tomorrow - child-minding today). I have a trend ammeter beside voltmeter....it shows nothing alarming but it might not reflect instrument situation. The instruments are fused at 3 amps...but that is at the buss and I think you are suggesting something different is happening. -------- Jake Read this topic online here: http://forums.matronics.com/viewtopic.php?p=248718#248718 ________________________________________________________________________________
From: "ROGER & JEAN CURTIS" <mrspudandcompany(at)verizon.net>
Subject: FW: Inspection camera
Date: Jun 17, 2009
Just got my HF flier today. The sale is good until July 6. See attachment! Roger ________________________________________________________________________________
Date: Jun 17, 2009
etc?? At 01:49 AM 6/17/2009, you wrote: > >Noticed on a Icom 210A rear plug that they used different color >wires of approx 24 or 26 awg. Does anyone have a part number or the >place to get this type of wire as Aircraft spruce only has limited >colors.Cheers Some years ago I did a data package for wiring the A200. I just looked up the installation info for the A210 and it appears that Icom for all their technical skills have learned little about airplanes . . . the installation manuals leave a lot to be desired. Here's my impression of the A210. It appears they've added a 15 pin D-sub connector that parallels connections in the 30-pin Molex connector. The connector can be used in simple installations like a line truck or FBO base station. As near as I can tell, all other wiring on the Molex connector for the A210 are the same as for the A200. I've updated the drawings I did for the A200 and published at: http://www.aeroelectric.com/Installation_Data/Icom_A200-210_Wiring_D.pdf I think you'll find these more helpful than the factory installation manual. I'll further suggest you use all white, 22AWG wire for connecting this radio. The thing is very simple and taking time to purchase a few feet of colored wire is not a good return on investment. Use masking tape tags on the free ends of wires to tell you where that end goes when the installation is complete. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 17, 2009
At 01:41 AM 6/17/2009, you wrote: > >I have been unable to solve this problem so far and am considering a >different tach sensor or even buying / installing a stand-alone tach >as I'm getting frustrated in trying to get the IK-2000 engine >monitor tach to work with the factory recommended sensor. If anyone >has any suggestions on what I'm missing in making this work, any >input is appreciated. > >Here's where I'm at right now: > >1. I cut the Hall effect sensor factory harness as short as I could >for installing connectors and used a 3-wire shielded cable from >there to aft of the firewall to connect the Hall effect sensor >power, signal, and ground wires. I soldered a short ground wire to >the shield at the sensor end of the cable and grounded it via ring >terminal at the same mag location that I grounded the p-lead >shield. No improvement - in fact, probably worse than without the >shielded cable. Clearly your hall sensor is responding to "ringing" in the magnetic circuit associated with the points- opening event of the magneto. Have you used a 'scope to see what's showing up on the tach signal when the magneto is operating? The tach signal is quite low in frequency so some form of low-pass filter and/or other signal conditioning is indicated. Unfortunately, the expected signal from a hard switching hall effect sensor is already full of high frequency components (cause it's square). Rolling this off to get rid of the ringing spikes will probably require re-squaring the signal after low-pass to get tach input happy. In the past, I've use phase locked loops to grab the desired suite of low frequency components that basically ignores the spikes. What is the sensor brand and part number? Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 17, 2009
Can somebody please explain why is it advertised "Wireless Inspection Camera" and it comes with "3 ft flexible extended tube" ? Carlos _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of ROGER & JEAN CURTIS Sent: quarta-feira, 17 de Junho de 2009 17:53 Subject: AeroElectric-List: FW: Inspection camera Just got my HF flier today. The sale is good until July 6. See attachment! Roger ________________________________________________________________________________
Subject: Inspection camera
Date: Jun 17, 2009
Can somebody please explain why is it advertised "Wireless Inspection Camera" and it comes with "3 ft flexible extended tube" ? Is the "wireless" referring to the (battery) power only? Carlos _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of ROGER & JEAN CURTIS Sent: quarta-feira, 17 de Junho de 2009 17:53 Subject: AeroElectric-List: FW: Inspection camera Just got my HF flier today. The sale is good until July 6. See attachment! Roger ________________________________________________________________________________
Date: Jun 17, 2009
Thanks Bob. I don't have access to an o-scope so haven't been able to look at the signal. The only filtering I've tried is the simple wiring of a 0.1 uF cap from signal lead to ground. My other efforts at solving the problem have been trying various wiring routing changes and then changing the sensor leads to shielded cable. The sensor is a Westach Model 720-14R Hall effect sensor that screws into the Slick mag vent hole over the rotating magnets. Westach has been very responsive in trying to help solve the issue but no luck so far. They are going to send me a sensor that is driven off the mechanical drive (model 303DH2T) and I'll see if that works better, but they tell me the setup I have has worked for many others and I'm not sure what in my setup could be causing the problem. I haven't heard back from IK-Tech yet. Chris > > > > > Clearly your hall sensor is responding to "ringing" > in the magnetic circuit associated with the points- > opening event of the magneto. Have you used a 'scope > to see what's showing up on the tach signal when > the magneto is operating? The tach signal is quite > low in frequency so some form of low-pass filter > and/or other signal conditioning is indicated. > Unfortunately, the expected signal from a hard > switching hall effect sensor is already full of > high frequency components (cause it's square). > Rolling this off to get rid of the ringing spikes > will probably require re-squaring the signal after > low-pass to get tach input happy. > > In the past, I've use phase locked loops to grab > the desired suite of low frequency components that > basically ignores the spikes. What is the sensor > brand and part number? > > > Bob . . . ________________________________________________________________________________
etc??
Date: Jun 17, 2009
Isn't the net wonderful, this is why I really enjoy these forums. Thank you again for all your responses. Cheers Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=248790#248790 ________________________________________________________________________________
Subject: Re: FW: Inspection camera
Date: Jun 17, 2009
Roger, It would be nice if you scanned the sale page to also include the "date" that it is good. That way folks that do not get the ad can take your scanned copy, with current date, and hustle down to HF and purchase one. I do not know if all HF outlets carry the same sales. But, they would probably honor a sale print out. David ------------------------------------------------------------------------- ------- ----- Original Message ----- From: ROGER & JEAN CURTIS To: aeroelectric-list(at)matronics.com Sent: Wednesday, June 17, 2009 9:53 AM Subject: AeroElectric-List: FW: Inspection camera Just got my HF flier today. The sale is good until July 6. See attachment! Roger ________________________________________________________________________________
Date: Jun 17, 2009
It's battery powered. Older boroscopes needed to be plugged in to drive their hi intensity lights. Regards, Greg Young _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Carlos Trigo Sent: Wednesday, June 17, 2009 3:52 PM Subject: RE: AeroElectric-List: FW: Inspection camera Can somebody please explain why is it advertised "Wireless Inspection Camera" and it comes with "3 ft flexible extended tube" ? Carlos ________________________________________________________________________________
Subject: Re: Inspection camera
Date: Jun 17, 2009
Can somebody please explain why is it advertised "Wireless Inspection Camera" and it comes with "3 ft flexible extended tube" ? Is the "wireless" referring to the (battery) power only? Carlos This is an excerpt from a previous posting by Harley: The monitor/display is in color, has adjustable brightness (in > addition to the LED light source brightness adjustments), contrast and > orientation (rotates the image in four steps) and can be removed > easily from the handle and remoted as it uses a wireless connection to > the camera. It also has a video output. It's cable has a standard > RCA connector on the end so you can input it to any device that will > accept a composite video input for recording or viewing on a larger > screen. Roger ________________________________________________________________________________
Date: Jun 17, 2009
The extended tube is to get the camera located on the end of the tube where it is you want to see something - inside a cylinder or other semi-remote / inaccessible place. The "wireless" refers to the fact that you don't need an AC extension cord for power. Additionally, the "wireless" refers to the fact that the LCD monitor can be separated from the camera assembly so you can place the monitor somewhere it can be conveniently viewed while manipulating the camera probe. Pretty cool for $99! Dick Carlos Trig wrote: > > Can somebody please explain why is it advertised Wireless Inspection > Camera and it comes with 3 ft flexible extended tube ? > > Is the wireless referring to the (battery) power only? > > Carlos > ________________________________________________________________________________
Subject: New from Harbor Freight
Date: Jun 17, 2009
Harley said: "The first thing I noticed was that it was very well packaged in a semi-rigid plastic container. I'll use that to store it in." I got my HF sale paper today and hurried down to the store to pick up one of these little gems. When I got there, I was surprised to see the thing in a foam-filled cardboard box. No plastic container. What are other folks finding: plastic containers or cardboard boxes? Don -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Harley Sent: Tuesday, June 16, 2009 12:32 PM Subject: AeroElectric-List: New from Harbor Freight I received a flyer from Harbor Freight yesterday, and one of the items in it was a new "borescope" that was priced down from $139 (on their website) to $99.99 in the local stores. So, knowing that I would need one soon to exam the inside of my fuel tanks when I get the holes for the fuel filler assembly cut (and who knows what other little holes I'd have to inspect), I went down and bought it. I bought it...it was much better than I expected, and a lot more solid than other Harbor Freight items I bought in the past. The first thing I noticed was that it was very well packaged in a semi-rigid plastic container. I'll use that to store it in. I think it has a lot of neat features (in addition to the price), so I thought I'd pass it on to you people in case you are looking for a tool to examine those hard to view places as well. The camera/light source head is 5/8 inch in diameter...the flexible shaft is 3 feet long. The camera, flex shaft and mounting head on the handle are attached with o-rings and are claimed to be water proof. The whole thing (including the monitor) has a nice solid feel to it and appears to be pretty rugged. Not the usual thin plastic like the Chinese stuff often is. The length of the camera head before it starts to be bendable may be a problem for some applications though, as even though the camera and it's fitting itself is only a little less than 3 inches in length, it needs 4-1/2 inches of clearance straight in to get a full bend in the flexible shaft. An application like this would be a good place to use the 45 degree mirror attachment that comes with it that I mention below. The monitor/display is in color, has adjustable brightness (in addition to the LED light source brightness adjustments), contrast and orientation (rotates the image in four steps) and can be removed easily from the handle and remoted as it uses a wireless connection to the camera. It also has a video output. It's cable has a standard RCA connector on the end so you can input it to any device that will accept a composite video input for recording or viewing on a larger screen. The camera and LEDs runs on 4 AA batteries in the handle, and the monitor has a rechargeable lithium ion battery. It comes with the charger as well. It has three attachments that fit over the camera head ...a mirror, a magnet and a pick. So you can hunt down and move or pick up things you find in those deep dark holes. It uses super bright LEDs for the camera's light source, and the light level is adjustable through a trigger on the handle. The camera does pretty good in low light as well...I was viewing items in my house this morning without using the LEDs. You can see it online here: www.harborfreight.com/cpi/ctaf/displayitem.taf?function=Search And the manual is here: www.harborfreight.com/manuals/66000-66999/66550.pdf Harley Dixon Long EZ N28EZ Canandaigua, NY ________________________________________________________________________________
Date: Jun 17, 2009
Carlos...the monitor slides off and can be viewed without being attached to the handle. No wires. It takes awhile to get used to the fact that to work, the monitor POWER has to be on (I assume that turns on the receiver), the HANDLE has to be on (the transmitter as well as the camera and the light) AND the monitor display has to be turned on. Maybe that's why they permanently mounted the monitor in later models...without the transmitter and receiver, only need one switch to do it all! I played with it last night and took the monitor two rooms away from the camera and still had a picture...have no idea how far it can be removed (the instructions say it can be used "in close proximity" to the handle...) but a couple of rooms away allows you to have the monitor close to a tape recorder or computer if you want to save the video you are looking at without having the recording unit in the garage or near the work being examined (it comes with a cable to output the image for recording or storing.) I saw a big advantage to being able to disconnect the monitor when I was playing around last night. When you are moving the camera by either the flexible cable or the handle, it's a big help to have the monitor standing still in front of you while you maneuver the camera. It looks like the newer models that Ridgid is still selling under their own name, no longer have that option. Harley ------------------------------------------------------------------------ Carlos Trigo wrote: > > Can somebody please explain why is it advertised "Wireless Inspection > Camera" and it comes with "3 ft flexible extended tube" ? > > Is the "wireless" referring to the (battery) power only? > > > > Carlos > > > > ------------------------------------------------------------------------ > > *From:* owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of > *ROGER & JEAN CURTIS > *Sent:* quarta-feira, 17 de Junho de 2009 17:53 > *To:* aeroelectric-list(at)matronics.com > *Subject:* AeroElectric-List: FW: Inspection camera > > > > > > Just got my HF flier today. The sale is good until July 6. See > attachment! > > > > Roger > > * > * ________________________________________________________________________________
Date: Jun 17, 2009
Subject: Re: New from Harbor Freight
As I said, Don...the foam is semi-ridgid (oops, I mean rigid )...Makes a great permanent storage box for it. It isn't a blown plastic container like some tools have, with a latching lid, but it is thick walled, and protective enough to store it in. Originally, I was going to say "foam" but I didn't want anyone to think that it was that fragile styrofoam that is often used to pack around elctronics. The foam that the camera is packed with has a waxy feel to it...very sturdy. Harley ------------------------------------------------------------------------ Don Curry wrote: > > Harley said: "The first thing I noticed was that it was very well > packaged in a semi-rigid plastic container. I'll use that to store it in." > > > > I got my HF sale paper today and hurried down to the store to pick up > one of these little gems. When I got there, I was surprised to see > the thing in a foam-filled cardboard box. No plastic container. What > are other folks finding: plastic containers or cardboard boxes? > > Don > > > > > > > > -----Original Message----- > *From:* owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of > *Harley > *Sent:* Tuesday, June 16, 2009 12:32 PM > *To:* undisclosed-recipients: > *Subject:* AeroElectric-List: New from Harbor Freight > > > > I received a flyer from Harbor Freight yesterday, and one of the items > in it was a new "borescope" that was priced down from $139 (on their > website) to $99.99 in the local stores. > > So, knowing that I would need one soon to exam the inside of my fuel > tanks when I get the holes for the fuel filler assembly cut (and who > knows what other little holes I'd have to inspect), I went down and > bought it. > > I bought it...it was much better than I expected, and a lot more solid > than other Harbor Freight items I bought in the past. The first thing > I noticed was that it was very well packaged in a semi-rigid plastic > container. I'll use that to store it in. > > I think it has a lot of neat features (in addition to the price), so I > thought I'd pass it on to you people in case you are looking for a > tool to examine those hard to view places as well. > > The camera/light source head is 5/8 inch in diameter...the flexible > shaft is 3 feet long. The camera, flex shaft and mounting head on the > handle are attached with o-rings and are claimed to be water proof. > The whole thing (including the monitor) has a nice solid feel to it > and appears to be pretty rugged. Not the usual thin plastic like the > Chinese stuff often is. > > The length of the camera head before it starts to be bendable may be a > problem for some applications though, as even though the camera and > it's fitting itself is only a little less than 3 inches in length, it > needs 4-1/2 inches of clearance straight in to get a full bend in the > flexible shaft. An application like this would be a good place to use > the 45 degree mirror attachment that comes with it that I mention below. > > The monitor/display is in color, has adjustable brightness (in > addition to the LED light source brightness adjustments), contrast and > orientation (rotates the image in four steps) and can be removed > easily from the handle and remoted as it uses a wireless connection to > the camera. It also has a video output. It's cable has a standard > RCA connector on the end so you can input it to any device that will > accept a composite video input for recording or viewing on a larger > screen. > > The camera and LEDs runs on 4 AA batteries in the handle, and the > monitor has a rechargeable lithium ion battery. It comes with the > charger as well. It has three attachments that fit over the camera > head ...a mirror, a magnet and a pick. So you can hunt down and move > or pick up things you find in those deep dark holes. > > It uses super bright LEDs for the camera's light source, and the light > level is adjustable through a trigger on the handle. The camera does > pretty good in low light as well...I was viewing items in my house > this morning without using the LEDs. > > You can see it online here: > www.harborfreight.com/cpi/ctaf/displayitem.taf?function=Search > <http://www.harborfreight.com/cpi/ctaf/displayitem.taf?function=Search> > > And the manual is here: > www.harborfreight.com/manuals/66000-66999/66550.pdf > <http://www.harborfreight.com/manuals/66000-66999/66550.pdf> > > Harley Dixon > Long EZ N28EZ > Canandaigua, NY > > * * > * * > ** > ** > ** > ** > ** > ** > ** > *http://www.matronics.com/contribution* > * * > * > > > * ________________________________________________________________________________
Date: Jun 17, 2009
Harley Thanks for the complete explanation. It really looks cool. and not expensive I wish there were Harbour Freight shops in Europe. Carlos _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Harley Sent: quarta-feira, 17 de Junho de 2009 23:21 Subject: Re: FW: AeroElectric-List: Inspection camera Carlos...the monitor slides off and can be viewed without being attached to the handle. No wires. It takes awhile to get used to the fact that to work, the monitor POWER has to be on (I assume that turns on the receiver), the HANDLE has to be on (the transmitter as well as the camera and the light) AND the monitor display has to be turned on. Maybe that's why they permanently mounted the monitor in later models...without the transmitter and receiver, only need one switch to do it all! I played with it last night and took the monitor two rooms away from the camera and still had a picture...have no idea how far it can be removed (the instructions say it can be used "in close proximity" to the handle...) but a couple of rooms away allows you to have the monitor close to a tape recorder or computer if you want to save the video you are looking at without having the recording unit in the garage or near the work being examined (it comes with a cable to output the image for recording or storing.) I saw a big advantage to being able to disconnect the monitor when I was playing around last night. When you are moving the camera by either the flexible cable or the handle, it's a big help to have the monitor standing still in front of you while you maneuver the camera. It looks like the newer models that Ridgid is still selling under their own name, no longer have that option. Harley _____ Carlos Trigo wrote: Can somebody please explain why is it advertised "Wireless Inspection Camera" and it comes with "3 ft flexible extended tube" ? Is the "wireless" referring to the (battery) power only? Carlos ________________________________________________________________________________
Date: Jun 17, 2009
David, There is no "sale end date" listed on the page where this ad appears. This is a widely published flyer which is most likely known by all retail stores. Just print the scanned ad. They will accept it. Roger ----- Original Message ----- From: David LLoyd To: aeroelectric-list(at)matronics.com Sent: Wednesday, June 17, 2009 5:56 PM Subject: Re: AeroElectric-List: FW: Inspection camera Roger, It would be nice if you scanned the sale page to also include the "date" that it is good. That way folks that do not get the ad can take your scanned copy, with current date, and hustle down to HF and purchase one. I do not know if all HF outlets carry the same sales. But, they would probably honor a sale print out. David ------------------------------------------------------------------------- ----- ----- Original Message ----- From: ROGER & JEAN CURTIS To: aeroelectric-list(at)matronics.com Sent: Wednesday, June 17, 2009 9:53 AM Subject: AeroElectric-List: FW: Inspection camera Just got my HF flier today. The sale is good until July 6. See attachment! Roger ________________________________________________________________________________
Date: Jun 17, 2009
FWIW I saw Harleys post yesterday and went to my local Harbor Freight Store (Margate FL) Iwent up to the counter and asked for the $99 wireless inspection camera item #66550. The clerk got 1 off the shelf, rang it up at $99.95+tax and I was out the door. No coupon or anything. And yes, it works great..... Don Curry wrote: > > Harley, > > Could you cut/paste the coupon (if it was a coupon sale) or the > flier? I searched my HF emails and couldn't find the item, but if I > had a coupon/flier, the local store would honor it. Thanks, Don > > > > > > > > -----Original Message----- > *From:* owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of > *Harley > *Sent:* Tuesday, June 16, 2009 5:14 PM > *To:* aeroelectric-list(at)matronics.com > *Subject:* Re: AeroElectric-List: New from Harbor Freight > > > > > Robert L. Nuckolls, III wrote: > > At 01:03 PM 6/16/2009, you wrote: > > I mentioned the price difference in the last email. > > It was $99.99 in the store...$139 on the website...note at the bottom > of the listing on the website, it says: "Prices on our website may or > may not be current prices in our stores" > > > A gentleman at the local HF store explained that > their merchandising is handled through three > somewhat exclusive channels. The catalog sales, > website sales and storefront sales are different > pipes and may have differences in prices and > products offered. > > On occasion, I've been to the local store with > a catalog in hand where > > Harley > > * * > * * > ** > ** > ** > ** > ** > ** > ** > *http://www.matronics.com/contribution* > * * > ------------------------------------------------------------------------ > 3D Earth Screensaver Preview <http://www.inbox.com/earth> > *Free 3D Earth Screensaver* > Watch the Earth right on your desktop! Check it out at > www.inbox.com/earth <http://www.inbox.com/earth> > * > > * ________________________________________________________________________________
Date: Jun 17, 2009
From: "Richard E. Tasker" <retasker(at)optonline.net>
This is not a coupon that you have to have to get the price. It is just an entry in the flyer. Just go to the store and ask for it. I would assume that all stores have the same price on this item. Unfortunately, you do have to go to a store to get one - no web discount. :-( Dick Tasker David LLoyd wrote: > Roger, > It would be nice if you scanned the sale page to also include the > "date" that it is good. That way folks that do not get the ad can > take your scanned copy, with current date, and hustle down to HF and > purchase one. I do not know if all HF outlets carry the same sales. > But, they would probably honor a sale print out. > David > ------------------------------------------------------------------------ -- Please Note: No trees were destroyed in the sending of this message. We do concede, however, that a significant number of electrons may have been temporarily inconvenienced. -- ________________________________________________________________________________
Date: Jun 17, 2009
On 6/17/2009 10:10 PM, Richard E. Tasker wrote: > you do have to go to a store to get one - no web discount. :-( And no store near me... :-( -Dj ________________________________________________________________________________
Date: Jun 17, 2009
It uses batteries. Ergo --- no power cord! Happy Skies, Old Bob In a message dated 6/17/2009 3:57:20 P.M. Central Daylight Time, trigo(at)mail.telepac.pt writes: Can somebody please explain why is it advertised =9CWireless Inspec tion Camera=9D and it comes with =9C3 ft flexible extended tube =9D ? Carlos **************Dell Days of Deals! June 15-24 - A New Deal Everyday! =http:%2F%2F ad.doubleclick.net%2Fclk%3B215692145%3B38015538%3Bh) ________________________________________________________________________________
Date: Jun 17, 2009
I suppose, depending on one's definition of "near", there are stores near me - but the closest is at least an hours drive. :-( With the price of gas today, I might as well buy online and pay the extra $40. Well, probably not quite, but including time, gas, etc.... Dick Dj Merrill wrote: > > On 6/17/2009 10:10 PM, Richard E. Tasker wrote: > >> you do have to go to a store to get one - no web discount. :-( >> > > And no store near me... :-( > > -Dj -- Please Note: No trees were destroyed in the sending of this message. We do concede, however, that a significant number of electrons may have been temporarily inconvenienced. -- ________________________________________________________________________________
Date: Jun 17, 2009
Thanks,,,,, ----- Original Message ----- From: Roger To: aeroelectric-list(at)matronics.com Sent: Wednesday, June 17, 2009 4:09 PM Subject: Re: AeroElectric-List: FW: Inspection camera David, There is no "sale end date" listed on the page where this ad appears. This is a widely published flyer which is most likely known by all retail stores. Just print the scanned ad. They will accept it. Roger ----- Original Message ----- From: David LLoyd To: aeroelectric-list(at)matronics.com Sent: Wednesday, June 17, 2009 5:56 PM Subject: Re: AeroElectric-List: FW: Inspection camera Roger, It would be nice if you scanned the sale page to also include the "date" that it is good. That way folks that do not get the ad can take your scanned copy, with current date, and hustle down to HF and purchase one. I do not know if all HF outlets carry the same sales. But, they would probably honor a sale print out. David ------------------------------------------------------------------------- --- ----- Original Message ----- From: ROGER & JEAN CURTIS To: aeroelectric-list(at)matronics.com Sent: Wednesday, June 17, 2009 9:53 AM Subject: AeroElectric-List: FW: Inspection camera Just got my HF flier today. The sale is good until July 6. See attachment! Roger ________________________________________________________________________________
Date: Jun 18, 2009
You can get the Milwaukee brand of the same inspection camera from Amazon.com for $97.62 with free shipping. (p/n 2300-20) There are 2 versions; this is the AA powered model, a Lithium ion powered model is $200+ John Ciolino David LLoyd wrote: > Thanks,,,,, > > ----- Original Message ----- > *From:* Roger > *To:* aeroelectric-list(at)matronics.com > > *Sent:* Wednesday, June 17, 2009 4:09 PM > *Subject:* Re: AeroElectric-List: FW: Inspection camera > > David, > > There is no "sale end date" listed on the page where this ad > appears. This is a widely published flyer which is most likely > known by all retail stores. > > Just print the scanned ad. They will accept it. > > Roger > > ----- Original Message ----- > *From:* David LLoyd > *To:* aeroelectric-list(at)matronics.com > > *Sent:* Wednesday, June 17, 2009 5:56 PM > *Subject:* Re: AeroElectric-List: FW: Inspection camera > > Roger, > It would be nice if you scanned the sale page to also include > the "date" that it is good. That way folks that do not get > the ad can take your scanned copy, with current date, and > hustle down to HF and purchase one. I do not know if all HF > outlets carry the same sales. But, they would probably honor > a sale print out. > David > ------------------------------------------------------------------------ > > ----- Original Message ----- > *From:* ROGER & JEAN CURTIS > > *To:* aeroelectric-list(at)matronics.com > > *Sent:* Wednesday, June 17, 2009 9:53 AM > *Subject:* AeroElectric-List: FW: Inspection camera > > > > Just got my HF flier today. The sale is good until July > 6. See attachment! > > > > Roger > > * > * > > * > > href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > * > > * > > > * ________________________________________________________________________________
Date: Jun 18, 2009
John... Not quite the same thing...the reviews of the Milwaukee unit are not as good as for the Ridgid one...biggest complaints with this Milwaukee unit is the large camera head (3/4"...a bit bigger than the HF model) and the difficulty of watching the screen while trying to maneuver the camera head...solved with the HF unit by removing the monitor from the handle. There were some complaints about cracks in the plastic case as well. Also, it doesn't have the ability to record the image, or flip or reverse the image without moving the camera. Also, the handy little tools that come with the HF unit are definitely a plus...a hook, a magnet and a mirror that attach to the camera head. Cheap to add to it, but quite a good idea! So far, I've found the HF unit to be VERY substantial and well built. Last night, I was playing with it, and recorded a quick look around my computer room...inputting the image into the video capture device I have on the 'puter. You can see the results here: www.youtube.com/watch?v=iMcqqQNIg50&feature=channel_page Harley ------------------------------------------------------------------------ John Ciolino wrote: > You can get the Milwaukee brand of the same inspection camera from > Amazon.com for $97.62 with free shipping. (p/n 2300-20) There are 2 > versions; this is the AA powered model, a Lithium ion powered model is > $200+ > > John Ciolino > > David LLoyd wrote: >> Thanks,,,,, >> >> ----- Original Message ----- >> *From:* Roger >> *To:* aeroelectric-list(at)matronics.com >> >> *Sent:* Wednesday, June 17, 2009 4:09 PM >> *Subject:* Re: AeroElectric-List: FW: Inspection camera >> >> David, >> >> There is no "sale end date" listed on the page where this ad >> appears. This is a widely published flyer which is most likely >> known by all retail stores. >> >> Just print the scanned ad. They will accept it. >> >> Roger >> >> ----- Original Message ----- >> *From:* David LLoyd >> *To:* aeroelectric-list(at)matronics.com >> >> *Sent:* Wednesday, June 17, 2009 5:56 PM >> *Subject:* Re: AeroElectric-List: FW: Inspection camera >> >> Roger, >> It would be nice if you scanned the sale page to also include >> the "date" that it is good. That way folks that do not get >> the ad can take your scanned copy, with current date, and >> hustle down to HF and purchase one. I do not know if all HF >> outlets carry the same sales. But, they would probably honor >> a sale print out. >> David >> ------------------------------------------------------------------------ >> >> ----- Original Message ----- >> *From:* ROGER & JEAN CURTIS >> >> *To:* aeroelectric-list(at)matronics.com >> >> *Sent:* Wednesday, June 17, 2009 9:53 AM >> *Subject:* AeroElectric-List: FW: Inspection camera >> >> >> >> Just got my HF flier today. The sale is good until July >> 6. See attachment! >> >> >> >> Roger >> >> * >> * >> >> * >> >> href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List >> href="http://forums.matronics.com">http://forums.matronics.com >> href="http://www.matronics.com/contribution">http://www.matronics.com/c >> * >> >> * >> >> href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List >> href="http://forums.matronics.com">http://forums.matronics.com >> href="http://www.matronics.com/contribution">http://www.matronics.com/contribution >> >> * > * > > > * ________________________________________________________________________________
From: "kuffel(at)cyberport.net" <kuffel(at)cyberport.net>
Subject: Re: Tyco Breakers
Date: Jun 18, 2009
Question was: << experience with the Tyco Rocker type switch/breaker? >> I replied: << I used the Tyco/Airpax/(now)Sensata/Snapak style rocker circuit breaker/switches R11-1-[amperage]-G06EV. .. airpax.sensata.com. Bob Nuckolls does not approve of this arrangement. >> Bob Nuckolls replied: <> Felt Bob would take umbrage at the phrase the moment I pressed the send button. Okay, replace "does not approve of" with "discourages use of". Semantics anywhere but in a government bureaucracy. << These are indeed Cadillac breaker/switches . . . with a price to match. >> Just went and looked. Airpax style R11-1-[amp] are available under $15. This is half the AS&S price of the Tyco thermal circuit breakers used in type certified aircraft. << But if your system design goals include achievement of failure tolerant design then the $extra$ cost only buys you a style of device and adds nothing to system reliability for the airplane.>> Here, Bob and I have disagreed before. To me, the probable reliability of this life rated switch/circuit breaker and two connections is not automatically worse than the switch, wire across the panel to a circuit breaker array and 4 connections setup typical of most aircraft. As I said, my experience has been good, I'm confident in the reliability of the device, I like the simplified wiring and also like the reduced panel usage. << I've not seen this class of breaker used anywhere on a TC aircraft of any size or price. >> Which is one of the reasons we build experimental aircraft, so we can use stuff the TC world doesn't. Tom Kuffel ________________________________________________________________________________
Date: Jun 18, 2009
At 04:12 PM 6/17/2009, you wrote: > >Thanks Bob. I don't have access to an o-scope so haven't been able >to look at the signal. The only filtering I've tried is the simple >wiring of a 0.1 uF cap from signal lead to ground. My other efforts >at solving the problem have been trying various wiring routing >changes and then changing the sensor leads to shielded cable. > >The sensor is a Westach Model 720-14R Hall effect sensor that screws >into the Slick mag vent hole over the rotating magnets. Westach has >been very responsive in trying to help solve the issue but no luck >so far. They are going to send me a sensor that is driven off the >mechanical drive (model 303DH2T) and I'll see if that works better, >but they tell me the setup I have has worked for many others and I'm >not sure what in my setup could be causing the problem. I haven't >heard back from IK-Tech yet. Hmmm . . . see if the IK-Tech will share a sketch of a schematic for the first two stages of tach signal conditioning. The manner in which bias levels are established for any "squaring" or level sensing circuits can have a profound effect on noise sensitivity. The schematics (need parts values too) + 'scope trace will permit a simple-ideas analysis of the symptoms. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 18, 2009
You can get the Milwaukee brand of the same inspection camera from Amazon.com for $97.62 with free shipping. (p/n 2300-20) There are 2 versions; this is the AA powered model, a Lithium ion powered model is $200+ John Ciolino They appear to be quite different from the HF unit! Does anyone have a comparison for us?? Roger ________________________________________________________________________________
Date: Jun 18, 2009
Another day, more testing of this neat little camera! This morning (a very rainy, wet morning here...good day to play inside! ), I set it up in my "computer room" (a converted bedroom on the west most end of my house), disconnected the monitor and walked around the house. I had a steady image until I got about 25 feet away, in the hall to my kitchen, but even then, never totally lost the image in the house. Went out into my attached garage (~60 feet from the camera) and also down into the cellar. What did happen was that I would start getting a couple of regular horizontal flash-like lines as the signal became weaker...never bothered the readability of the image though. The only time I lost the image altogether was when I went out into my front yard. But it returned immediately if I backed up a couple of feet. What this all means for me, is that I can set the monitor up to record to the computer in the computer room, and check out things just about anywhere in my house, including the garage and cellar. Of course things may change when I start moving the camera instead of the monitor! Found another similar device online that uses a separate monitor, and can be recorded directly into the monitor. The V-Snake ( www.privatebrandtools.com/wireless.htm ). But the base unit (without the record function) is $500, and the recording option adds another $400 to the price. Harley ------------------------------------------------------------------------ Carlos...the monitor slides off and can be viewed without being attached to the handle. No wires. It takes awhile to get used to the fact that to work, the monitor POWER has to be on (I assume that turns on the receiver), the HANDLE has to be on (the transmitter as well as the camera and the light) AND the monitor display has to be turned on. Maybe that's why they permanently mounted the monitor in later models...without the transmitter and receiver, only need one switch to do it all! I played with it last night and took the monitor two rooms away from the camera and still had a picture...have no idea how far it can be removed (the instructions say it can be used "in close proximity" to the handle...) but a couple of rooms away allows you to have the monitor close to a tape recorder or computer if you want to save the video you are looking at without having the recording unit in the garage or near the work being examined (it comes with a cable to output the image for recording or storing.) I saw a big advantage to being able to disconnect the monitor when I was playing around last night. When you are moving the camera by either the flexible cable or the handle, it's a big help to have the monitor standing still in front of you while you maneuver the camera. It looks like the newer models that Ridgid is still selling under their own name, no longer have that option. Harley ------------------------------------------------------------------------ Carlos Trigo wrote: > > Can somebody please explain why is it advertised "Wireless Inspection > Camera" and it comes with "3 ft flexible extended tube" ? > > Is the "wireless" referring to the (battery) power only? > > > > Carlos > * * ________________________________________________________________________________
Date: Jun 18, 2009
Subject: Homemade handheld antenna
Bob, Just got through mounting my A-22 handheld in my trike. Now I'm wondering about a better antenna than the rubber ducky that it came with. Calculated length for a 1/4 wave centered on 127Mhz is 23.25". I'm thinking of nothing more than a piece of 1/16" SS welding wire shoved into a BNC connector. Any input by radio heads will be greatly appreciated. Thanks, Rick ________________________________________________________________________________
Date: Jun 18, 2009
Harley, You tested it for long lens photo views it seems. How is the lens when you want to look at something up very close? ...say 1 -3 inches away. Does it have a manually adjusted lens,,? David ----- Original Message ----- From: Harley To: aeroelectric-list(at)matronics.com Sent: Thursday, June 18, 2009 5:23 AM Subject: AeroElectric-List: Inspection camera Another day, more testing of this neat little camera! This morning (a very rainy, wet morning here...good day to play inside! ), I set it up in my "computer room" (a converted bedroom on the west most end of my house), disconnected the monitor and walked around the house. I had a steady image until I got about 25 feet away, in the hall to my kitchen, but even then, never totally lost the image in the house. Went out into my attached garage (~60 feet from the camera) and also down into the cellar. What did happen was that I would start getting a couple of regular horizontal flash-like lines as the signal became weaker...never bothered the readability of the image though. The only time I lost the image altogether was when I went out into my front yard. But it returned immediately if I backed up a couple of feet. What this all means for me, is that I can set the monitor up to record to the computer in the computer room, and check out things just about anywhere in my house, including the garage and cellar. Of course things may change when I start moving the camera instead of the monitor! Found another similar device online that uses a separate monitor, and can be recorded directly into the monitor. The V-Snake ( www.privatebrandtools.com/wireless.htm ). But the base unit (without the record function) is $500, and the recording option adds another $400 to the price. Harley ------------------------------------------------------------------------- ----- Carlos...the monitor slides off and can be viewed without being attached to the handle. No wires. It takes awhile to get used to the fact that to work, the monitor POWER has to be on (I assume that turns on the receiver), the HANDLE has to be on (the transmitter as well as the camera and the light) AND the monitor display has to be turned on. Maybe that's why they permanently mounted the monitor in later models...without the transmitter and receiver, only need one switch to do it all! I played with it last night and took the monitor two rooms away from the camera and still had a picture...have no idea how far it can be removed (the instructions say it can be used "in close proximity" to the handle...) but a couple of rooms away allows you to have the monitor close to a tape recorder or computer if you want to save the video you are looking at without having the recording unit in the garage or near the work being examined (it comes with a cable to output the image for recording or storing.) I saw a big advantage to being able to disconnect the monitor when I was playing around last night. When you are moving the camera by either the flexible cable or the handle, it's a big help to have the monitor standing still in front of you while you maneuver the camera. It looks like the newer models that Ridgid is still selling under their own name, no longer have that option. Harley ------------------------------------------------------------------------- ----- Carlos Trigo wrote: Can somebody please explain why is it advertised "Wireless Inspection Camera" and it comes with "3 ft flexible extended tube" ? Is the "wireless" referring to the (battery) power only? Carlos ________________________________________________________________________________
Date: Jun 18, 2009
No, the lens doesn't have an adjustable focus...but, if you'll notice the keyboard in my video, I was within a couple of inches of the keys at one point and it was still fairly clear. www.youtube.com/watch?v=iMcqqQNIg50. Ridgid has a 9mm camera and flexible cable (this one is 17mm diameter) accessory that should fit this unit that is supposed to have a closer focal range. That may be an option as well. Harley ------------------------------------------------------------------------ David LLoyd wrote: > Harley, > You tested it for long lens photo views it seems. How is the lens > when you want to look at something up very close? ...say 1 -3 inches > away. Does it have a manually adjusted lens,,? > David > > ----- Original Message ----- > *From:* Harley > *To:* aeroelectric-list(at)matronics.com > > *Sent:* Thursday, June 18, 2009 5:23 AM > *Subject:* AeroElectric-List: Inspection camera > > Another day, more testing of this neat little camera! This > morning (a very rainy, wet morning here...good day to play inside! > ), I set it up in my "computer room" (a converted bedroom on > the west most end of my house), disconnected the monitor and > walked around the house. > > I had a steady image until I got about 25 feet away, in the hall > to my kitchen, but even then, never totally lost the image in the > house. Went out into my attached garage (~60 feet from the > camera) and also down into the cellar. > > What did happen was that I would start getting a couple of regular > horizontal flash-like lines as the signal became weaker...never > bothered the readability of the image though. The only time I > lost the image altogether was when I went out into my front yard. > But it returned immediately if I backed up a couple of feet. > > What this all means for me, is that I can set the monitor up to > record to the computer in the computer room, and check out things > just about anywhere in my house, including the garage and cellar. > Of course things may change when I start moving the camera instead > of the monitor! > > Found another similar device online that uses a separate monitor, > and can be recorded directly into the monitor. The V-Snake ( > www.privatebrandtools.com/wireless.htm ). But the base unit > (without the record function) is $500, and the recording option > adds another $400 to the price. > > Harley > ------------------------------------------------------------------------ > > Carlos...the monitor slides off and can be viewed without being > attached to the handle. No wires. It takes awhile to get used to > the fact that to work, the monitor POWER has to be on (I assume > that turns on the receiver), the HANDLE has to be on (the > transmitter as well as the camera and the light) AND the monitor > display has to be turned on. > > Maybe that's why they permanently mounted the monitor in later > models...without the transmitter and receiver, only need one > switch to do it all! > > I played with it last night and took the monitor two rooms away > from the camera and still had a picture...have no idea how far it > can be removed (the instructions say it can be used "in close > proximity" to the handle...) but a couple of rooms away allows you > to have the monitor close to a tape recorder or computer if you > want to save the video you are looking at without having the > recording unit in the garage or near the work being examined (it > comes with a cable to output the image for recording or storing.) > > I saw a big advantage to being able to disconnect the monitor when > I was playing around last night. When you are moving the camera by > either the flexible cable or the handle, it's a big help to have > the monitor standing still in front of you while you maneuver the > camera. > > It looks like the newer models that Ridgid is still selling under > their own name, no longer have that option. > > Harley > ------------------------------------------------------------------------ > > Carlos Trigo wrote: >> >> Can somebody please explain why is it advertised "Wireless >> Inspection Camera" and it comes with "3 ft flexible extended tube" ? >> >> Is the "wireless" referring to the (battery) power only? >> >> Carlos >> > * > * > > * > > href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > * > > * > > > * ________________________________________________________________________________
Date: Jun 18, 2009
From: "George, Neal E Capt USAF ACC 605 TES/DOA" <Neal.George(at)hurlburt.af.mil>
Rick - That will work, but I'd suggest a piece of music wire rather than stainless. Music wire will accept solder, so you can solder the wire to the BNC center pin for a better electrical connection (then pot it with epoxy for strain-relief). You'll also be happier if you put a tight 180-deg bend or small loop in the end (also soldered) to mitigate scratches, snags and gouged eyes. Neal ================= Bob, Just got through mounting my A-22 handheld in my trike. Now I'm wondering about a better antenna than the rubber ducky that it came with. Calculated length for a 1/4 wave centered on 127Mhz is 23.25". I'm thinking of nothing more than a piece of 1/16" SS welding wire shoved into a BNC connector. Any input by radio heads will be greatly appreciated. Thanks, Rick ________________________________________________________________________________
Date: Jun 18, 2009
Thanks Harley... I had previously missed your YouTube link. For me is key to have close up to look for bracket cracks and other mechanical failure areas that are nearly inaccessible for inspection. David ----- Original Message ----- From: Harley To: aeroelectric-list(at)matronics.com Sent: Thursday, June 18, 2009 9:21 AM Subject: Re: AeroElectric-List: Inspection camera No, the lens doesn't have an adjustable focus...but, if you'll notice the keyboard in my video, I was within a couple of inches of the keys at one point and it was still fairly clear. www.youtube.com/watch?v=iMcqqQNIg50. Ridgid has a 9mm camera and flexible cable (this one is 17mm diameter) accessory that should fit this unit that is supposed to have a closer focal range. That may be an option as well. Harley ------------------------------------------------------------------------- ----- David LLoyd wrote: Harley, You tested it for long lens photo views it seems. How is the lens when you want to look at something up very close? ...say 1 -3 inches away. Does it have a manually adjusted lens,,? David ----- Original Message ----- From: Harley To: aeroelectric-list(at)matronics.com Sent: Thursday, June 18, 2009 5:23 AM Subject: AeroElectric-List: Inspection camera Another day, more testing of this neat little camera! This morning (a very rainy, wet morning here...good day to play inside! ), I set it up in my "computer room" (a converted bedroom on the west most end of my house), disconnected the monitor and walked around the house. I had a steady image until I got about 25 feet away, in the hall to my kitchen, but even then, never totally lost the image in the house. Went out into my attached garage (~60 feet from the camera) and also down into the cellar. What did happen was that I would start getting a couple of regular horizontal flash-like lines as the signal became weaker...never bothered the readability of the image though. The only time I lost the image altogether was when I went out into my front yard. But it returned immediately if I backed up a couple of feet. What this all means for me, is that I can set the monitor up to record to the computer in the computer room, and check out things just about anywhere in my house, including the garage and cellar. Of course things may change when I start moving the camera instead of the monitor! Found another similar device online that uses a separate monitor, and can be recorded directly into the monitor. The V-Snake ( www.privatebrandtools.com/wireless.htm ). But the base unit (without the record function) is $500, and the recording option adds another $400 to the price. Harley ------------------------------------------------------------------------- - Carlos...the monitor slides off and can be viewed without being attached to the handle. No wires. It takes awhile to get used to the fact that to work, the monitor POWER has to be on (I assume that turns on the receiver), the HANDLE has to be on (the transmitter as well as the camera and the light) AND the monitor display has to be turned on. Maybe that's why they permanently mounted the monitor in later models...without the transmitter and receiver, only need one switch to do it all! I played with it last night and took the monitor two rooms away from the camera and still had a picture...have no idea how far it can be removed (the instructions say it can be used "in close proximity" to the handle...) but a couple of rooms away allows you to have the monitor close to a tape recorder or computer if you want to save the video you are looking at without having the recording unit in the garage or near the work being examined (it comes with a cable to output the image for recording or storing.) I saw a big advantage to being able to disconnect the monitor when I was playing around last night. When you are moving the camera by either the flexible cable or the handle, it's a big help to have the monitor standing still in front of you while you maneuver the camera. It looks like the newer models that Ridgid is still selling under their own name, no longer have that option. Harley ------------------------------------------------------------------------- - Carlos Trigo wrote: Can somebody please explain why is it advertised "Wireless Inspection Camera" and it comes with "3 ft flexible extended tube" ? Is the "wireless" referring to the (battery) power only? Carlos href="http://www.matronics.com/Navigator?AeroElectric-List">http://www. matronics.com/Navigator?AeroElectric-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?AeroElectric-List">http://www. matronics.com/Navigator?AeroElectric-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ontribution ________________________________________________________________________________
Date: Jun 18, 2009
Subject: Re: Homemade handheld antenna
Hi Rick, I just got finished with antenna tuning on all my vhf radios. Made a big difference. Like you I use lengths for my common freq. If you go to the Ham radio store they will sell you a VHF Whip antenna for a hand held. It will make a huge difference. Mine is ~16.7" long. They have adapters for the different connectors as required. I have not used the rubber ducky since I got the whip antenna. Obviously the one I bought was not tuned for 127 but the swr is just fine across a large range of freqs. Maybe they will have a 22 or 23' one? BTW, Correct length for 127 is 22.1" for 1/4 wave per my calcs. Cut yours 23" an then re-cut for best swr. Paul ========= At 08:58 AM 6/18/2009, Rick wrote: >Bob, Just got through mounting my A-22 handheld in my trike. Now I'm >wondering about a better antenna than the rubber ducky that it came >with. Calculated length for a 1/4 wave centered on 127Mhz is 23.25". >I'm thinking of nothing more than a piece of 1/16" SS welding wire >shoved into a BNC connector. Any input by radio heads will be >greatly appreciated. > >Thanks, >Rick ________________________________________________________________________________
Date: Jun 18, 2009
Date: Jun 18, 2009
Date: Jun 18, 2009
Date: Jun 18, 2009
I mounted an antennae on my( Antares ) trike using a 1/4 wave whip on the wing keel tube and ran the coax down the vertical mast with a BNC adapter on my VXA-700 and it works fine. It is a bit directional though and the next time I will mount it in on the bottom of the pod and put at least a six inch diameter metal disk around the antennae mount. RS Rob Stapleton, Photojournalist Anchorage, AK KL2AN Skype:rob.stapleton.jr -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of George, Neal E Capt USAF ACC 605 TES/DOA Sent: Thursday, June 18, 2009 8:40 AM Subject: RE: AeroElectric-List: Homemade handheld antenna Rick - That will work, but I'd suggest a piece of music wire rather than stainless. Music wire will accept solder, so you can solder the wire to the BNC center pin for a better electrical connection (then pot it with epoxy for strain-relief). You'll also be happier if you put a tight 180-deg bend or small loop in the end (also soldered) to mitigate scratches, snags and gouged eyes. Neal ================= Bob, Just got through mounting my A-22 handheld in my trike. Now I'm wondering about a better antenna than the rubber ducky that it came with. Calculated length for a 1/4 wave centered on 127Mhz is 23.25". I'm thinking of nothing more than a piece of 1/16" SS welding wire shoved into a BNC connector. Any input by radio heads will be greatly appreciated. Thanks, Rick ________________________________________________________________________________
Date: Jun 18, 2009
Date: Jun 18, 2009
Good Afternoon Harley and All, Went to Harbor Freight this morning and picked up my unit. I also learned something that many of you may already know. When you receive a Harbor Freight Sale flyer, the ones that need a coupon to get th e lower price are the ones that have a barcode included in the ad. If you do not have the flyer with you, they generally have the flyer available in the store, but you will NOT get the sale price unless they can a scan the barc ode on the advertisement. The little monitor and camera did not have a barcode so you would get that price without any effort on your part. However, I did pick up a few other items that were cheaper by having the coupons available to be scanned. Happy Skies, Old Bob Stearman N3977A Brookeridge Airpark LL22 In a message dated 6/18/2009 7:26:42 A.M. Central Daylight Time, harley(at)agelesswings.com writes: Another day, more testing of this neat little camera! This morning (a very rainy, wet morning here...good day to play inside! ), I set it up in my "computer room" (a converted bedroom on the west most end of my house), disconnected the monitor and walked around the house. I had a steady image until I got about 25 feet away, in the hall to my kitchen, but even then, never totally lost the image in the house. Went out into my attached garage (~60 feet from the camera) and also down into the cellar. What did happen was that I would start getting a couple of regular horizontal flash-like lines as the signal became weaker...never bothered the readability of the image though. The only time I lost the image altogeth er was when I went out into my front yard. But it returned immediately if I back ed up a couple of feet. What this all means for me, is that I can set the monitor up to record to the computer in the computer room, and check out things just about anywhe re in my house, including the garage and cellar. Of course things may chang e when I start moving the camera instead of the monitor! Found another similar device online that uses a separate monitor, and can be recorded directly into the monitor. The V-Snake ( _www.privatebrandtools.com/wireless.htm_ (http://www.privatebrandtools.com /wireless.htm) ). But the base unit (without the record function) is $500, and the recordin g option adds another $400 to the price. Harley ____________________________________ Carlos...the monitor slides off and can be viewed without being attached to the handle. No wires. It takes awhile to get used to the fact that to work, the monitor POWER has to be on (I assume that turns on the receiver ), the HANDLE has to be on (the transmitter as well as the camera and the light) AND the monitor display has to be turned on. Maybe that's why they permanently mounted the monitor in later models...without the transmitter and receiver, only need one switch to do it all! I played with it last night and took the monitor two rooms away from the camera and still had a picture...have no idea how far it can be removed (the instructions say it can be used "in close proximity" to the handle...) bu t a couple of rooms away allows you to have the monitor close to a tape recorder or computer if you want to save the video you are looking at wit hout having the recording unit in the garage or near the work being examined (it comes with a cable to output the image for recording or storing.) I saw a big advantage to being able to disconnect the monitor when I was playing around last night. When you are moving the camera by either the flexible cable or the handle, it's a big help to have the monitor standin g still in front of you while you maneuver the camera. It looks like the newer models that Ridgid is still selling under their own name, no longer have that option. Harley ____________________________________ Carlos Trigo wrote: Can somebody please explain why is it advertised =9CWireless Inspec tion Camera=9D and it comes with =9C3 ft flexible extended tube =9D ? Is the =9Cwireless=9D referring to the (battery) power only? Carlos ======================== ============ (http://www.matronics.com/Navigator?AeroElectric-List) ======================== ============ ======================== ============ (http://www.matronics.com/contribution) ======================== ============ **************Dell Days of Deals! June 15-24 - A New Deal Everyday! =http:%2F%2F ad.doubleclick.net%2Fclk%3B215692163%3B38015526%3Be) ________________________________________________________________________________
Date: Jun 18, 2009
I have opened the (4) e-mails you have posted in the last couple of hours about the inspection camera and there is nothing to read. Is it just me as all the other posts open OK? -----Original Message----- From: David M. <ainut(at)hiwaay.net> Sent: Thu, Jun 18, 2009 1:09 pm Subject: Re: AeroElectric-List: Inspection camera ________________________________________________________________________________
Date: Jun 18, 2009
If your mail reader has an option to "view message source" or something similar, you can see David's messages. I have the same problem with my mail reader on a few messages. I'm not sure what causes the problem, except that the un-viewable message is some sort of html format but it comes into my mail reader as plain text. My grandfather would have said, "it's one of those modern inconveniences". Bob W. Here is the fourth message David posted as viewed from source: Content-Type: text/html; charset=ISO-8859-1 Content-Transfer-Encoding: 7bit I have a little concern about using the clamp-on attachments.  The mirror is an absolute must when checking in the cylinders for just that purpose - checking the valves.  However, I am worried about the mirror coming off while still inside the cylinder.  That will be a major pain...  Does it seem sturdy enough to you guys?  You don't think it will come off?
David M.
wrbyars(at)aol.com wrote: > > > > > I have opened the (4) e-mails you have posted in the last couple of hours about the inspection camera and there is nothing to read. Is it just me as all the other posts open OK? > > > > > -----Original Message----- > From: David M. <ainut(at)hiwaay.net> > To: aeroelectric-list(at)matronics.com > Sent: Thu, Jun 18, 2009 1:09 pm > Subject: Re: AeroElectric-List: Inspection camera > > -- N93BD - Rotary Powered BD-4 - http://www.bob-white.com 3.8 Hours Total Time and holding Cables for your rotary installation - http://roblinstores.com/ ________________________________________________________________________________
Date: Jun 18, 2009
On 06/18/2009 03:15 PM, wrbyars(at)aol.com wrote: > > *I have opened the (4) e-mails you have posted in the last couple of > hours about the inspection camera and there is nothing to read. Is it > just me as all the other posts open OK? > * > > -----Original Message----- > From: David M. <ainut(at)hiwaay.net> From reading the e-mail headers from David's message, it looks like David is using the AVG mail virus scanner, which has known problems in sending out e-mails that other e-mail clients cannot read. It is showing up blank on my system, too. David, you may wish to consider removing the AVG virus scanner, and use another virus scanner instead, or disable AVG from scanning outgoing e-mails if that is possible. fyi -Dj ________________________________________________________________________________
Date: Jun 18, 2009
Nope...not just you...David's posts have been coming through empty here as well...the blank space below David's header (as seen below) is just what I've been receiving as well. David...since I started this thread, why don't you email me directly and we'll try to see what is going on... harley(at)agelesswings.com Harley ------------------------------------------------------------------------ wrbyars(at)aol.com wrote: > > *I have opened the (4) e-mails you have posted in the last couple of > hours about the inspection camera and there is nothing to read. Is it > just me as all the other posts open OK? > * > > -----Original Message----- > From: David M. <ainut(at)hiwaay.net> > To: aeroelectric-list(at)matronics.com > Sent: Thu, Jun 18, 2009 1:09 pm > Subject: Re: AeroElectric-List: Inspection camera > > > Dell Days of Deals! June 15-24 - A New Deal Everyday! > * > * ________________________________________________________________________________
Date: Jun 18, 2009
Subject: Re: Inspection camera
They were blank to me also. Raymond Julian Kettle River, MN. "Hope for the best, but prepare for the worst" wrbyars(at)aol.com wrote: > > *I have opened the (4) e-mails you have posted in the last couple of > hours about the inspection camera and there is nothing to read. Is it > just me as all the other posts open OK? > * > > -----Original Message----- > From: David M. <ainut(at)hiwaay.net> > To: aeroelectric-list(at)matronics.com > Sent: Thu, Jun 18, 2009 1:09 pm > Subject: Re: AeroElectric-List: Inspection camera > > > > > > Dell Days of Deals! June 15-24 - A New Deal Everyday! > > * > > > * ________________________________________________________________________________
Date: Jun 18, 2009
The thought that too.. But I messed around and found that if I select "View Message Details" on my webmail page I can see the text of David's messages. Matt- > > > I have opened the (4) e-mails you have posted in the last couple of hours > about the inspection camera and there is nothing to read. Is it just me > as all the other posts open OK? > > > -----Original Message----- > From: David M. <ainut(at)hiwaay.net> > To: aeroelectric-list(at)matronics.com > Sent: Thu, Jun 18, 2009 1:09 pm > Subject: Re: AeroElectric-List: Inspection camera > > ________________________________________________________________________________
Date: Jun 18, 2009
It is not just you. I too do not see anything. Dick Tasker wrbyars(at)aol.com wrote: > > *I have opened the (4) e-mails you have posted in the last couple of > hours about the inspection camera and there is nothing to read. Is it > just me as all the other posts open OK? > * > > -----Original Message----- > From: David M. <ainut(at)hiwaay.net> > To: aeroelectric-list(at)matronics.com > Sent: Thu, Jun 18, 2009 1:09 pm > Subject: Re: AeroElectric-List: Inspection camera > * > * ________________________________________________________________________________
Date: Jun 18, 2009
>>However, I did pick up a few other items that were cheaper<< I have that problem as well, Old Bob...I can't go into Harbor Freight without picking up something more than I was looking for...even if it's nothing but another box of nitrile gloves! Speaking of which...one of our list members sent me a private email this morning...he wants one of those cameras but was in an area where there is no Harbor Freight (Portugal! ). so I went to another local HF (the one here in Henrietta was out of them) and bought one for him (he said that he had access to an adapter for the US voltage and also didn't care if it was NTSC monitor). Just sent it off to him. While there, I was telling the manager what I was going to do with it, and he offered to sell me the other two he had left in stock as well! I bought them! So! I have two more for sale, if any of you are not near a Harbor Freight, want one of these fine Harbor Freight Wireless Inspection Cameras and are thinking about getting one of these from their website, I'll sell you one for their price of $99.99 plus tax ($8) and shipping...it'll still be less than the online price for it (the order to Portugal with shipping came in almost $10 less than the online price!) Let me know... If I don't sell them, I'm not out anything(except for the gas money for the 35 mile round trip...but I like to drive anyway!), as HF will always take them back, so don't feel you have to.. Harley ------------------------------------------------------------------------ BobsV35B(at)aol.com wrote: > Good Afternoon Harley and All, > > Went to Harbor Freight this morning and picked up my unit. > > I also learned something that many of you may already know. When you > receive a Harbor Freight Sale flyer, the ones that need a coupon to > get the lower price are the ones that have a barcode included in the > ad. If you do not have the flyer with you, they generally have the > flyer available in the store, but you will NOT get the sale price > unless they can a scan the barcode on the advertisement. > > The little monitor and camera did not have a barcode so you would get > that price without any effort on your part. However, I did pick up a > few other items that were cheaper by having the coupons available to > be scanned. > > Happy Skies, > > Old Bob > Stearman N3977A > Brookeridge Airpark > LL22 > * > * ________________________________________________________________________________
Date: Jun 18, 2009
Now that we know what David said: "I have a little concern about using the clamp-on attachments. The mirror is an absolute must when checking in the cylinders for just that purpose - checking the valves. However, I am worried about the mirror coming off while still inside the cylinder. That will be a major pain... Does it seem sturdy enough to you guys? You don't think it will come off?" First, the mirror is very securely mounted to the shaft it's on. It is mounted with a loop at the end of the shaft so that it would have to be rotated over 270 degrees on the mount to even loosen it. And the shaft is then mounted through the locking collar that goes around the camera with a couple of bends in it...one is back on itself so that a pull in either direction will actually tighten it in the clamp. Last the clamp has a latching feature on it, so when mounted to the camera, it surrounds an indent in the camera body and is no larger diameter than the camera, and locked in place. I found it's a bit difficult to remove once mounted! Now, in the event that it DOES come off (and I can't see how), you can simply use the magnet or the hook to retrieve it! Harley ________________________________________________________________________________
Date: Jun 18, 2009
I don't think AVG's the problem...I'm using it too...have for years...as well as just about everyone I know locally. We've never had a problem with sending emails. Harley ------------------------------------------------------------------------ > From reading the e-mail headers from David's message, it looks like > David is using the AVG mail virus scanner, which has known problems in > sending out e-mails that other e-mail clients cannot read. It is > showing up blank on my system, too. > > David, you may wish to consider removing the AVG virus scanner, and > use another virus scanner instead, or disable AVG from scanning outgoing > e-mails if that is possible. > > fyi > > -Dj > > > ________________________________________________________________________________
Subject: Inspection camera
Date: Jun 18, 2009
I got mine this morning, too. I took a quick look to see if HF had a plastic box the foam padding would fit in, but I didn't have enough time to do a thorough search. From what I could tell, one of the compartmentalized plastic boxes seemed just about perfect except for the handle. I suspect the scope items could be reconfigured in the foam for a nice fit, but I couldn't tell for sure. Anybody find a good plastic storage box for it yet? Don -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of BobsV35B(at)aol.com Sent: Thursday, June 18, 2009 2:18 PM Subject: Re: AeroElectric-List: Inspection camera Good Afternoon Harley and All, Went to Harbor Freight this morning and picked up my unit. I also learned something that many of you may already know. When you receive a Harbor Freight Sale flyer, the ones that need a coupon to get the lower price are the ones that have a barcode included in the ad. If you do not have the flyer with you, they generally have the flyer available in the store, but you will NOT get the sale price unless they can a scan the barcode on the advertisement. The little monitor and camera did not have a barcode so you would get that price without any effort on your part. However, I did pick up a few other items that were cheaper by having the coupons available to be scanned. Happy Skies, Old Bob Stearman N3977A Brookeridge Airpark LL22 In a message dated 6/18/2009 7:26:42 A.M. Central Daylight Time, harley(at)agelesswings.com writes: Another day, more testing of this neat little camera! This morning (a very rainy, wet morning here...good day to play inside! ), I set it up in my "computer room" (a converted bedroom on the west most end of my house), disconnected the monitor and walked around the house. I had a steady image until I got about 25 feet away, in the hall to my kitchen, but even then, never totally lost the image in the house. Went out into my attached garage (~60 feet from the camera) and also down into the cellar. What did happen was that I would start getting a couple of regular horizontal flash-like lines as the signal became weaker...never bothered the readability of the image though. The only time I lost the image altogether was when I went out into my front yard. But it returned immediately if I backed up a couple of feet. What this all means for me, is that I can set the monitor up to record to the computer in the computer room, and check out things just about anywhere in my house, including the garage and cellar. Of course things may change when I start moving the camera instead of the monitor! Found another similar device online that uses a separate monitor, and can be recorded directly into the monitor. The V-Snake ( www.privatebrandtools.com/wireless.htm ). But the base unit (without the record function) is $500, and the recording option adds another $400 to the price. Harley _____ Carlos...the monitor slides off and can be viewed without being attached to the handle. No wires. It takes awhile to get used to the fact that to work, the monitor POWER has to be on (I assume that turns on the receiver), the HANDLE has to be on (the transmitter as well as the camera and the light) AND the monitor display has to be turned on. Maybe that's why they permanently mounted the monitor in later models...without the transmitter and receiver, only need one switch to do it all! I played with it last night and took the monitor two rooms away from the camera and still had a picture...have no idea how far it can be removed (the instructions say it can be used "in close proximity" to the handle...) but a couple of rooms away allows you to have the monitor close to a tape recorder or computer if you want to save the video you are looking at without having the recording unit in the garage or near the work being examined (it comes with a cable to output the image for recording or storing.) I saw a big advantage to being able to disconnect the monitor when I was playing around last night. When you are moving the camera by either the flexible cable or the handle, it's a big help to have the monitor standing still in front of you while you maneuver the camera. It looks like the newer models that Ridgid is still selling under their own name, no longer have that option. Harley _____ Carlos Trigo wrote: Can somebody please explain why is it advertised "Wireless Inspection Camera" and it comes with "3 ft flexible extended tube" ? Is the "wireless" referring to the (battery) power only? Carlos List href="http://www.matronics.com/Navigator?AeroElectric-List">http://www. matro nics.com/Navigator?AeroElectric-List ms.matronics.com/">http://forums.matronics.com tp://www.matronics.com/contribution">http://www.matronics.com/contributio n _____ Dell Days of Deals! June 15-24 - A New Deal Everyday! ________________________________________________________________________________
Date: Jun 18, 2009
On 06/18/2009 04:13 PM, Harley wrote: > I don't think AVG's the problem...I'm using it too...have for > years...as well as just about everyone I know locally. We've never > had a problem with sending emails. > We've had several problems with AVG and e-mail (I work in computing support at a local College). Disabling AVG has fixed it every time, so far. I can't say that every version of AVG has a problem, but most definitely some do. -Dj -- Dj Merrill - N1JOV Glastar Sportsman 2+2 Builder #7118 N421DJ http://deej.net/sportsman/ "Many things that are unexplainable happen during the construction of an airplane." --Dave Prizio, 30 Aug 2005 ________________________________________________________________________________
Subject: iNSPECTION CAMERA
Date: Jun 18, 2009
I've been thinking about a device such as this for some time and want to thank all of you who have and are contributing to the thread. This is certianly a good price and I intend to get one in a couple of days if my Tulsa store has any; which a lot of times they don't have what is advertized because of POOR, or lack of, management. I was curious about the apparent lack of focus for close ups and wondered if the camera could be replaced with a better quality? I get catalogs from suppliers of security equipment that has all sizes of these little cameras and they are relatively inexpensive. Maybe one of you fellas with the proper skills could look into this and also check the spec's on the RIGID brand accessories smaller camera, or whomever, and see what it's capabilities are. ________________________________________________________________________________
Date: Jun 18, 2009
Nothing came through. ----- Original Message ----- From: wrbyars(at)aol.com To: aeroelectric-list(at)matronics.com Sent: Thursday, June 18, 2009 12:15 PM Subject: Re: AeroElectric-List: Inspection camera I have opened the (4) e-mails you have posted in the last couple of hours about the inspection camera and there is nothing to read. Is it just me as all the other posts open OK? -----Original Message----- From: David M. <ainut(at)hiwaay.net> To: aeroelectric-list(at)matronics.com Sent: Thu, Jun 18, 2009 1:09 pm Subject: Re: AeroElectric-List: Inspection camera Dell Days of Deals! June 15-24 - A New Deal Everyday! ________________________________________________________________________________
Date: Jun 18, 2009
This thread got me curious as to what other borescopes in the $100-$150 price range were available. Here=99s a list of a few. I don=99t know squat about any of them. http://tinyurl.com/n4sgbo http://tinyurl.com/m5kscj Dental camera, seems to offer serious detail viewing http://tinyurl.com/nsegl4 fiber optic, no light, no power reqd http://tinyurl.com/me83ut powered by USB port http://tinyurl.com/mqu9vk http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber-833 Another HF borescope$300 http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=91565 HF again, $200 ________________________________________________________________________________
Subject: Shower of Sparks Help
Date: Jun 18, 2009
Hi Bob I wired my RV6A (I think) according to your Shower of Sparks info I found on the Internet. I did this quite awhile ago, and just got around to a planned first start today. In doing some preliminary checking with the plugs out before the start, it appears I have both mags producing sparks in the start mode. The mags, vibrator and ignition switch all came out of the same aircraft (R22), thus I know they were compatible at one time. Is there something obvious I should check that may be causing this problem? Can continuity of the wires be checked while still attached to the swithch? Thanks in advance. John Crate ----- Original Message ----- From: Robert L. Nuckolls, III To: aeroelectric-list(at)matronics.com Sent: Tuesday, June 16, 2009 9:12 PM Subject: [Bulk] Re: AeroElectric-List: Tyco Breakers At 12:08 PM 6/16/2009, you wrote: Does anyone have any experience with the Tyco Rocker type switch/breaker? They are specified in the Digi-Key PTM as "secondary breakers", which must be backed up by a branch circuit breaker or fuse http://dkc1.digikey.com/us/en/tod/TycoElectronicsPB/CircuitBreakers_NoAud io/CircuitBreakers_NoAudio.html . This would seem to defeat the purpose of having the breaker in the first place. What am I missing? Beats me. This is the first time I've seen that terminology used in describing the application of circuit protection. Did some searching and found this tid-bit . . . This was excerpted from a book on wiring design for large AC power distribution systems. I don't think this applies to our 14/28V DC systems in light aircraft. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 18, 2009
Date: Jun 18, 2009
Test 2: Ok, html is explicitly off and scanning outgoing messages is off in AVG. David Dj Merrill wrote: > > On 06/18/2009 03:15 PM, wrbyars(at)aol.com wrote: >> *I have opened the (4) e-mails you have posted in the last couple of >> hours about the inspection camera and there is nothing to read. Is it >> just me as all the other posts open OK? >> * >> >> -----Original Message----- >> From: David M. <ainut(at)hiwaay.net> > > From reading the e-mail headers from David's message, it looks like > David is using the AVG mail virus scanner, which has known problems in > sending out e-mails that other e-mail clients cannot read. It is > showing up blank on my system, too. > > David, you may wish to consider removing the AVG virus scanner, and > use another virus scanner instead, or disable AVG from scanning outgoing > e-mails if that is possible. > > fyi > > ________________________________________________________________________________
Date: Jun 18, 2009
Subject: Re: Inspection camera: now, test 3
Date: Jun 18, 2009
Hi David, This last one came through just fine. Test 1 had the same problem. I suspect turning html off probably fixed the problem. Email used to be a plain text world. :) Was there anything different in test 1? Bob W. "David M." wrote: > > Test 2: > > Ok, html is explicitly off and scanning outgoing messages is off in AVG. > > David > > > > Dj Merrill wrote: > > > > On 06/18/2009 03:15 PM, wrbyars(at)aol.com wrote: > >> *I have opened the (4) e-mails you have posted in the last couple of > >> hours about the inspection camera and there is nothing to read. Is it > >> just me as all the other posts open OK? > >> * > >> > >> -----Original Message----- > >> From: David M. <ainut(at)hiwaay.net> > > > > From reading the e-mail headers from David's message, it looks like > > David is using the AVG mail virus scanner, which has known problems in > > sending out e-mails that other e-mail clients cannot read. It is > > showing up blank on my system, too. > > > > David, you may wish to consider removing the AVG virus scanner, and > > use another virus scanner instead, or disable AVG from scanning outgoing > > e-mails if that is possible. > > > > fyi > > > > > > > > -- N93BD - Rotary Powered BD-4 - http://www.bob-white.com 3.8 Hours Total Time and holding Cables for your rotary installation - http://roblinstores.com/ ________________________________________________________________________________
Date: Jun 18, 2009
Maybe not. The problem is back. What you did for Test 2 worked OK. Must be that AVG thing. Bob W. "David M." wrote: > > > -- N93BD - Rotary Powered BD-4 - http://www.bob-white.com 3.8 Hours Total Time and holding Cables for your rotary installation - http://roblinstores.com/ ________________________________________________________________________________
Date: Jun 18, 2009
Follow up. After looking at the source for test 2 and test 3, the difference seems to be this line: Content-Type: multipart/mixed; boundary="=======AVGMAIL-4DD03951=======" Also in test 3, these two lines: Content-Type: text/plain; charset=ISO-8859-1; format=flowed Content-Transfer-Encoding: 7bit are located just before the actual message. In test 2, those two lines were just after the Subject line and ahead of three other header fields, so it seems AVG is reordering some thing before sending the message on. Bob W. Bob White <bob@bob-white.com> wrote: > > Maybe not. The problem is back. What you did for Test 2 worked OK. > > Must be that AVG thing. > > Bob W. > > > "David M." wrote: > > > > > > > > > -- N93BD - Rotary Powered BD-4 - http://www.bob-white.com 3.8 Hours Total Time and holding Cables for your rotary installation - http://roblinstores.com/
--=======AVGMAIL-4DD03951=======-- ________________________________________________________________________________
Date: Jun 18, 2009
3 avg outgoing checking off, html on. David David M. wrote: > > > ------------------------------------------------------------------------ > > > Checked by AVG - www.avg.com > ________________________________________________________________________________
Date: Jun 18, 2009
Subject: Re: Shower of Sparks Help
John, I'm not Bob, but are the mags both equipped with retard breaker points as indicated by two connections on each mag? Are they Slick mags? What are their part numbers? On most installations there will be different part numbers with one (usually the left) being the retard breaker mag. If they came off of a Helicopter engine (R22?)they might be using dual retard breaker mags, which would provide TDC sparks from both mags during start and then both reverting to normal (25 degree?advance) when the start switch is released from the start position. This should be good in the sense that easier starts would be expected because both sets of plugs would be firing throughout the start up process. Jim McCulley ============================================================================= John wrote: > Hi Bob > > I wired my RV6A (I think) according to your Shower of Sparks info I > found on the Internet. I did this quite awhile ago, and just got around > to a planned first start today. In doing some preliminary checking with > the plugs out before the start, it appears I have both mags producing > sparks in the start mode. The mags, vibrator and ignition switch all > came out of the same aircraft (R22), thus I know they were compatible at > one time. > > Is there something obvious I should check that may be causing this problem? > Can continuity of the wires be checked while still attached to the swithch? > > Thanks in advance. > > John Crate > > ----- Original Message ----- > *From:* Robert L. Nuckolls, III > *To:* aeroelectric-list(at)matronics.com > > *Sent:* Tuesday, June 16, 2009 9:12 PM > *Subject:* [Bulk] Re: AeroElectric-List: Tyco Breakers > > At 12:08 PM 6/16/2009, you wrote: >> Does anyone have any experience with the Tyco Rocker type >> switch/breaker? >> >> They are specified in the Digi-Key PTM as "secondary breakers", >> which must be backed up by a branch circuit breaker or fuse >> http://dkc1.digikey.com/us/en/tod/TycoElectronicsPB/CircuitBreakers_NoAudio/CircuitBreakers_NoAudio.html >> . >> >> This would seem to defeat the purpose of having the breaker in the >> first place. What am I missing? > > Beats me. This is the first time I've seen that > terminology used in describing the application > of circuit protection. Did some searching and found > this tid-bit . . . > > Emacs! > > > This was excerpted from a book on wiring > design for large AC power distribution systems. > I don't think this applies to our 14/28V DC > systems in light aircraft. > > Bob . . . > > --------------------------------------- > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > --------------------------------------- > ________________________________________________________________________________
Date: Jun 18, 2009
On 6/18/2009 8:38 PM, Bob White wrote: > fields, so it seems AVG is reordering some thing before sending the > message on. Bob, That is exactly the problem. AVG re-orders the header information for the e-mail message, causing a lot of e-mail clients to incorrectly parse the resulting message that is sent, resulting in a "blank" display instead of the proper body text. Turning off AVG scanning of outbound e-mail (both HTML and text) solves the problem for us. Unfortunately, we believe that some AVG updates turn the outbound e-mail scanning back on again... *sigh* -Dj -- Dj Merrill - N1JOV Sportsman 2+2 Builder #7118 N421DJ http://deej.net/sportsman/ "Many things that are unexplainable happen during the construction of an airplane." --Dave Prizio, 30 Aug 2005 ________________________________________________________________________________
Date: Jun 18, 2009
Subject: Re: noisy tach signal
Date: Jun 18, 2009
At 05:50 PM 6/18/2009, you wrote: >Hi Bob > >I wired my RV6A (I think) according to your Shower of Sparks info I >found on the Internet. I did this quite awhile ago, and just got >around to a planned first start today. In doing some preliminary >checking with the plugs out before the start, it appears I have both >mags producing sparks in the start mode. The mags, vibrator and >ignition switch all came out of the same aircraft (R22), thus I know >they were compatible at one time. Here's a link to an article I did some years ago on SOS systems . . . never quite got around to polishing it up it but it's essentially complete. http://www.aeroelectric.com/articles/Shower-of-Sparks/ShowerOfSparks.pdf Only one mag with a second set of retard points is hooked to the vibrator. The second mag is prevented from operating by inclusion of the GRD to R jumper shown in the first of the two wiring diagrams. If both mags are "active" then perhaps the jumper is not in place. How do you know that both mags are active? Are you getting vibrator enhanced sparks from both devices? They should not be sharing any connections with the vibrator unless it's specifically designed to handle a PAIR of dual breaker mags. Can you point me to the information you used to do the wiring? Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 18, 2009
> >Felt Bob would take umbrage at the phrase the moment I >pressed the send button. Okay, replace "does not approve >of" with "discourages use of". Semantics anywhere but in a >government bureaucracy. You put words in my mouth still . . . my offering of simple ideas for the use of switch breakers pointed out that fact that switch breakers force the builder to fabricate a distribution bus on the panel . . . not unlike the breaker panels typical of TC aircraft even today. If one is favorably impressed with fuse blocks, then the fabrication of bus bars is already accomplished with a purchased part . . . and can be mounted remotely from the panel. If one has fuse blocks, then the only panel real estate devoted to control/protection are the necessary switches. All protected circuits not requiring switches require no panel space. If one chooses to use a combination of switch/breakers and circuit/breakers, then the real estate budget is affected. I prefer and RECOMMEND the low real estate, low labor, low cost approach but I would not discourage anyone from wiring their airplane any way they wish that does not introduce hazardous failure modes. Certainly choices of breakers, switch- breakers and/or fuses do not offer great risks. > ><< These are indeed Cadillac breaker/switches . . . with >a price to match. >> > >Just went and looked. Airpax style R11-1-[amp] are >available under $15. This is half the AS&S price of the >Tyco thermal circuit breakers used in type certified >aircraft. The breakers in common to TC aircraft are mil-spec devices with price tags commensurate with their pedigree. There are other commercial/ industrial breakers to be had for less money . . . the Airpax line you cited is but one. > < But if your system design goals >include achievement of failure tolerant design >then the $extra$ cost only buys you a style >of device and adds nothing to system reliability >for the airplane.>> > >Here, Bob and I have disagreed before. To me, the probable >reliability of this life rated switch/circuit breaker and >two connections is not automatically worse than the switch, >wire across the panel to a circuit breaker array and 4 >connections setup typical of most aircraft. Breakers that assuage concerns for aircraft designers have terminal bosses compatible with bus bars that tie multiple devices together. Like . . . Emacs! The R11 has fast-on tabs that do not lend themselves to direct connection to bus bars. Emacs! > As I said, my >experience has been good, I'm confident in the reliability >of the device, I like the simplified wiring and also like >the reduced panel usage. As to absolute reliability, the numbers are inversely proportional to parts count and without a doubt, the breaker/switch is more complex than the plain switch. Reliability is inarguable. Bonanza and Baron owners are presently saddled with some parts-count issues in the utilization of this breaker/switch . . . Emacs! It's a sure bet that they're wishing we'd not strayed from the simple breaker-panel, switch- panel architecture common to most other airplanes. This albatross involves about 80,000 fielded breaker/switches. But had you chosen fuse blocks and rocker switches with fast-on tabs, you would be no greater parts count than using toggle switches with fast-on tabs. Further, you would not have to wrestle with the bus-bar connection issues presented by fast-on tabs. > ><< I've not seen this class of breaker used >anywhere on a TC aircraft of any size or >price. >> > >Which is one of the reasons we build experimental aircraft, >so we can use stuff the TC world doesn't. Absolutely! An if you're pleased with the outcome of your choices, I'm pleased for you. But kindly refrain from mis-representing my mission here on the List. When I offer a particular recipe for success, it's supported by an analysis of design goals that I'm willing to share and explain. There are certainly other recipes that have met the builder's design goals . . . yours included. Bob . . . ________________________________________________________________________________
Date: Jun 18, 2009
At 09:58 AM 6/18/2009, you wrote: >Bob, Just got through mounting my A-22 handheld in my trike. Now I'm >wondering about a better antenna than the rubber ducky that it came >with. Calculated length for a 1/4 wave centered on 127Mhz is 23.25". >I'm thinking of nothing more than a piece of 1/16" SS welding wire >shoved into a BNC connector. Any input by radio heads will be >greatly appreciated. > >Thanks, >Rick Rick, how are you sir! Long time no speak! How well "exposed" is the rubber duck? Unless your mounting situation masks the antenna with nearby conductive structure, I don't think you would benefit much from a more optimized antenna. Your mission profile just doesn't call for getting weather reports from an RCO that 100 miles out on the horizon. Have you encountered communications issues that you thought might be improved by a better antenna? Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 18, 2009
Subject: re: Tyco Breakers (Image corrected)
Date: Jun 18, 2009
We've been missed by all the big storms again this spring and I count that a long way toward things being pretty good.I'm expanding my mission profile by taking the trike to its first towered airport for the chapter 980 Fly In at IDP this Saturday. Rather than having to call ahead, I added a power tap (21st century cigarette lighter receptacle) to the panel and a bracket from the forward mast to attach the A-22. The radio stands atop the panel and the rubber ducky, or any other antenna for that matter, stands vertically above the wind screen. There's no structure exactly parallel to the antenna, although the forward mast (a 1 1/4" aluminum tube) is about two inches from the antenna base and this distance gradually increases.As I was out in the hangar this evening my eyes fell on a disused telescoping antenna from an ELT. Its BNC connector mates right up to the radio and gives me a "tunable" length. What the heck, the price was certainly right. Thanks to all who responded. Great help just a few keyboard clicks away. Rick On Thu, Jun 18, 2009 at 10:04 PM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > nuckolls.bob(at)aeroelectric.com> > > At 09:58 AM 6/18/2009, you wrote: > >> Bob, Just got through mounting my A-22 handheld in my trike. Now I'm >> wondering about a better antenna than the rubber ducky that it came with. >> Calculated length for a 1/4 wave centered on 127Mhz is 23.25". I'm thinking >> of nothing more than a piece of 1/16" SS welding wire shoved into a BNC >> connector. Any input by radio heads will be greatly appreciated. >> >> Thanks, >> Rick >> > > Rick, how are you sir! Long time no speak! > How well "exposed" is the rubber duck? Unless > your mounting situation masks the antenna with > nearby conductive structure, I don't think you > would benefit much from a more optimized antenna. > Your mission profile just doesn't call for getting > weather reports from an RCO that 100 miles out > on the horizon. > > Have you encountered communications issues that > you thought might be improved by a better antenna? > > > Bob . . . > > --------------------------------------- > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > --------------------------------------- > > ________________________________________________________________________________
Date: Jun 19, 2009
Bob The link you referenced below is the one I used to wire my SOS system (Key Switch Controlled). The GRD to R jumper was checked and is in place. The way that I know both mags are active is that, as a test before first start, I pulled a plug wired to each mag and cranked the starter to check for spark. . I don't know whether the vibrator was working at the time. Is there a way to check the keyed ignition switch to make sure it is working properly? Could a faulty shield connection on the Right Mag at either the switch or mag terminal cause the problem? Thanks John ----- Original Message ----- From: Robert L. Nuckolls, III To: aeroelectric-list(at)matronics.com Sent: Thursday, June 18, 2009 10:00 PM Subject: Re: AeroElectric-List: Shower of Sparks Help At 05:50 PM 6/18/2009, you wrote: Hi Bob I wired my RV6A (I think) according to your Shower of Sparks info I found on the Internet. I did this quite awhile ago, and just got around to a planned first start today. In doing some preliminary checking with the plugs out before the start, it appears I have both mags producing sparks in the start mode. The mags, vibrator and ignition switch all came out of the same aircraft (R22), thus I know they were compatible at one time. Here's a link to an article I did some years ago on SOS systems . . . never quite got around to polishing it up it but it's essentially complete. http://www.aeroelectric.com/articles/Shower-of-Sparks/ShowerOfSparks.pdf Only one mag with a second set of retard points is hooked to the vibrator. The second mag is prevented from operating by inclusion of the GRD to R jumper shown in the first of the two wiring diagrams. If both mags are "active" then perhaps the jumper is not in place. How do you know that both mags are active? Are you getting vibrator enhanced sparks from both devices? They should not be sharing any connections with the vibrator unless it's specifically designed to handle a PAIR of dual breaker mags. Can you point me to the information you used to do the wiring? Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 18, 2009
If you have an A&P handy, he should be able to sort it out. You should have two P leads to the left mag, only one to the right. Make sure when key switch is off, mags are in fact grounded, before going further. TC aircraft with the SOS system use a push to start Bendix switch(pricey at $280)which operates the vibrator when turned to start, and only activates the starter relay when pushed toward dash. That allows checking for pulsing signal on retard breaker P lead. If the mags are both firing when starter is activated, right mag P lead isn't grounded. John wrote: > > > Bob > > The link you referenced below is the one I used to wire my SOS system > (Key Switch Controlled). The GRD to R jumper was checked and is in > place. The way that I know both mags are active is that, as a test > before first start, I pulled a plug wired to each mag and cranked the > starter to check for spark. . I don't know whether the vibrator was > working at the time. > > Is there a way to check the keyed ignition switch to make sure it is > working properly? Could a faulty shield connection on the Right Mag at > either the switch or mag terminal cause the problem? > > Thanks > > John > > > > > > > > > ----- Original Message ----- > > *From:* Robert L. Nuckolls, III > *To:* aeroelectric-list(at)matronics.com > > *Sent:* Thursday, June 18, 2009 10:00 PM > *Subject:* Re: AeroElectric-List: Shower of Sparks Help > > At 05:50 PM 6/18/2009, you wrote: >> Hi Bob >> >> I wired my RV6A (I think) according to your Shower of Sparks info >> I found on the Internet. I did this quite awhile ago, and just >> got around to a planned first start today. In doing some >> preliminary checking with the plugs out before the start, it >> appears I have both mags producing sparks in the start mode. The >> mags, vibrator and ignition switch all came out of the same >> aircraft (R22), thus I know they were compatible at one time. > > Here's a link to an article I did some years > ago on SOS systems . . . never quite got around > to polishing it up it but it's essentially complete. > > http://www.aeroelectric.com/articles/Shower-of-Sparks/ShowerOfSparks.pdf > > Only one mag with a second set of retard > points is hooked to the vibrator. The second > mag is prevented from operating by inclusion > of the GRD to R jumper shown in the first > of the two wiring diagrams. If both mags are > "active" then perhaps the jumper is not in > place. > > How do you know that both mags are active? > Are you getting vibrator enhanced sparks from > both devices? They should not be sharing any > connections with the vibrator unless it's > specifically designed to handle a PAIR of > dual breaker mags. > > Can you point me to the information you used > to do the wiring? > > Bob . . . > > --------------------------------------- > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > --------------------------------------- > > * > > href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > * > > * > > > * ________________________________________________________________________________
Date: Jun 19, 2009
Subject: Wire Protection Question
I am rebuilding the "Fat Wire" portion of my purchased RV-6A, moving the battery and contactors to the engine side of the firewall. Fig Z-11 does not show any protection on the 6AWG wire going from the Battery Contactor to supply the Main Power Distribution Bus. In my case, I am using a 12AWG wire, which passes through the firewall. Seems to me this wire needs protection of some sort, such as a fusible link, or an in-line fuse on the engine side of the firewall. Looking for suggestions/recommendations, thanks! Pete Hunt ________________________________________________________________________________
Date: Jun 19, 2009
Bob, My apologies for missing part of you question last night. My primary concern with the rubber ducky was its performance at low altitudes (200 to 500 feet) where I normally fly. Rick On Thu, Jun 18, 2009 at 10:04 PM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > nuckolls.bob(at)aeroelectric.com> > > At 09:58 AM 6/18/2009, you wrote: > >> Bob, Just got through mounting my A-22 handheld in my trike. Now I'm >> wondering about a better antenna than the rubber ducky that it came with. >> Calculated length for a 1/4 wave centered on 127Mhz is 23.25". I'm thinking >> of nothing more than a piece of 1/16" SS welding wire shoved into a BNC >> connector. Any input by radio heads will be greatly appreciated. >> >> Thanks, >> Rick >> > > Rick, how are you sir! Long time no speak! > How well "exposed" is the rubber duck? Unless > your mounting situation masks the antenna with > nearby conductive structure, I don't think you > would benefit much from a more optimized antenna. > Your mission profile just doesn't call for getting > weather reports from an RCO that 100 miles out > on the horizon. > > Have you encountered communications issues that > you thought might be improved by a better antenna? > > > Bob . . . > > --------------------------------------- > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > --------------------------------------- > > ________________________________________________________________________________
Date: Jun 19, 2009
Subject: Just a test
=======AVGMAIL-32A90303=======-- ________________________________________________________________________________
Date: Jun 19, 2009
Subject: Re: Wire Protection Question
At 02:31 AM 6/19/2009, you wrote: > >I am rebuilding the "Fat Wire" portion of my purchased RV-6A, moving >the battery and contactors to the engine side of the firewall. >Fig Z-11 does not show any protection on the 6AWG wire going from >the Battery Contactor to supply the Main Power Distribution Bus. In >my case, I am using a 12AWG wire, which passes through the firewall. >Seems to me this wire needs protection of some sort, such as a >fusible link, or an in-line fuse on the engine side of the firewall. > >Looking for suggestions/recommendations, thanks! A 12AWG wire is probably too small to be a bus feeder. When wiring with truly "fat" wires (6AWG or larger) they're not at high risk for burning due to shorts or overloads. Take a look at the wiring diagrams for any single engine TC aircraft and you'll find that few if any will incorporate fuses or current limiters in these pathways. This philosophy is echoed in the FARS . . . Sec. 23.1357 Circuit protective devices. (a) Protective devices, such as fuses or circuit breakers, must be installed in all electrical circuits other than-- (1) Main circuits of starter motors used during starting only; and (2) Circuits in which no hazard is presented by their omission. (b) A protective device for a circuit essential to flight safety may not be used to protect any other circuit. (c) Each resettable circuit protective device ("trip free" device in which the tripping mechanism cannot be overridden by the operating control) must be designed so that-- (1) A manual operation is required to restore service after tripping; and (2) If an overload or circuit fault exists, the device will open the circuit regardless of the position of the operating control. (d) If the ability to reset a circuit breaker or replace a fuse is essential to safety in flight, that circuit breaker or fuse must be so located and identified that it can be readily reset or replaced in flight. (e) For fuses identified as replaceable in flight-- (1) There must be one spare of each rating or 50 percent spare fuses of each rating, whichever is greater; and (2) The spare fuse(s) must be readily accessible to any required pilot. In particular, paragraph 12.1357(a)(2) applies here. Faulted robust wires generally arc to ground and burn their faults clear. Further, they're easily installed with attention to mechanical details such that faults to ground are as probable as loosing one's propeller due to bolt failure. The Z-figures are crafted with this philosophy in mind supported by a confidence in nearly 100 years of field history. I'll suggest that none of your fat wires should be smaller than 6AWG and that protection beyond what is illustrated in the Z-figures is no-value-added weight, cost and complexity. Bob . . . ________________________________________________________________________________
Date: Jun 19, 2009
At 05:05 AM 6/19/2009, you wrote: >Bob, My apologies for missing part of you question last night. My >primary concern with the rubber ducky was its performance at low >altitudes (200 to 500 feet) where I normally fly. Understand. Given that your radio horizon is so close compared to most airplanes, I'm doubtful that improving antenna efficiency over that of the rubber-duck will yield any improved "range". In fact, depending on how well the radio noise is controlled from your ignition system, you might want to keep the antenna as far from the engine as practical. It's an easy test. Rig a temporary antenna in your remote location of choice. We could do some extreme range testing with the two antennas to see if the extra effort has a return on investment. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 19, 2009
Subject: Re: Just a test
Well, that settles that! For the message copied below () I turned on my outgoing email scanner in AVG...and, voila! You couldn't see it! So, AVG is the problem! And, oh, yeah...I turned it back off! Harley ------------------------------------------------------------------------ Harley wrote: > =======AVGMAIL-32A90303=======-- > > > ________________________________________________________________________________
Date: Jun 19, 2009
The interesting thing is that I sent the same message to two other accounts that I have (agelesswings and Frontiernet), and in both of those, it came through fine??? So something in Aeroelectric might be "interacting" with it. Harley ------------------------------------------------------------------------ Harley wrote: > Well, that settles that! For the message copied below () I turned > on my outgoing email scanner in AVG...and, voila! You couldn't see it! > > So, AVG is the problem! And, oh, yeah...I turned it back off! > > Harley > ------------------------------------------------------------------------ > > Harley wrote: >> =======AVGMAIL-32A90303=======-- >> >> >> > * > > > * ________________________________________________________________________________
Date: Jun 19, 2009
At 11:45 PM 6/18/2009, you wrote: > > >Bob > >The link you referenced below is the one I used to wire my SOS >system (Key Switch Controlled). The GRD to R jumper was checked and >is in place. The way that I know both mags are active is that, as a >test before first start, I pulled a plug wired to each mag and >cranked the starter to check for spark. . I don't know whether the >vibrator was working at the time. What kind of spark did you get? A magneto is capable of delivering but a single spark per ignition even. If the shower of sparks vibrator system is working, the left magneto should be delivering a continuous stream of sparks during engine cranking. Should should also be able to hear the vibrator "buzzing". If the key switch is bad, then the mags are NEVER being shut off . . . not a good thing. Be sure your shield grounds are properly and robustly wired as shown. It could be that you're not getting the right mag grounded because the shield is improperly terminated at one end or both ends. > > >Is there a way to check the keyed ignition switch to make sure it is >working properly? Could a faulty shield connection on the Right Mag >at either the switch or mag terminal cause the problem? Sure. Leave the master switch off. Disconnect the p-lead from the R mag and put an ohmmeter between center conductor and shield. Turn the key switch and watch ohmmeter. You should read less than 1 ohm in all key switch positions except "R" and "BOTH". In particular, you're interested in seeing the R mag get shorted in the START position which is what the jumper does for you. If this doesn't happen, then the switch is probably bad . . . but check the shield grounds first. Check out this shield termination process if you've not already seen it. http://aeroelectric.com/articles/shldwire/shldwire.html I believe these key switches can be disassembled, cleaned and lubricated. An alternative is to use toggle switches as shown in the third diagram. Much less expensive and easier to maintain. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 19, 2009
On 6/19/2009 10:09 AM, Harley wrote: > The interesting thing is that I sent the same message to two other > accounts that I have (agelesswings and Frontiernet), and in both of > those, it came through fine??? > > So something in Aeroelectric might be "interacting" with it. Hi Harley, I've seen this happen with other mailing lists (non-Matronics), as well as direct person to person. Sometimes the messages go through fine, sometimes they don't. It has to do with the way that AVG modifies the mail headers, which sometimes are okay, and more often are not. AVG obviously has a bug in their software that they have not tracked down yet. FWIW, while scanning incoming e-mail has definite merits for protecting your computer, scanning outgoing e-mail has little value, so there really is no significant harm in turning that function off. -Dj -- Dj Merrill - N1JOV Sportsman 2+2 Builder #7118 N421DJ http://deej.net/sportsman/ "Many things that are unexplainable happen during the construction of an airplane." --Dave Prizio, 30 Aug 2005 ________________________________________________________________________________
Date: Jun 19, 2009
Dj Merrill wrote: > > On 6/19/2009 10:09 AM, Harley wrote: > >> The interesting thing is that I sent the same message to two other >> accounts that I have (agelesswings and Frontiernet), and in both of >> those, it came through fine??? >> >> So something in Aeroelectric might be "interacting" with it. >> > > Hi Harley, > I've seen this happen with other mailing lists (non-Matronics), as well > as direct person to person. Sometimes the messages go through fine, > sometimes they don't. It has to do with the way that AVG modifies the > mail headers, which sometimes are okay, and more often are not. AVG > obviously has a bug in their software that they have not tracked down yet. > > FWIW, while scanning incoming e-mail has definite merits for protecting > your computer, scanning outgoing e-mail has little value, so there > really is no significant harm in turning that function off. > Yeah...I thought the same thing...guess that's why I turned it off in the first place, then promptly forgot about it! H. > -Dj > > ________________________________________________________________________________
Subject: RE: Borescopes and sparkplug holes
Date: Jun 19, 2009
The camera just starts into a plug hole and binds. I bet one could slightly shave the camera dia to get it in just fine. I don't yet have the unit charged or AA's on hand, so I don't know how good a view of the piston and valves you can get from the plug hole or with the mirror. glen matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
From: "Bill Bradburry" <bbradburry(at)bellsouth.net>
Date: Jun 19, 2009
Wouldn't it would be great if you could get it all the way in there and get it stuck! :>) -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of glen matejcek Sent: Friday, June 19, 2009 12:18 PM Subject: AeroElectric-List: RE: Borescopes and sparkplug holes --> The camera just starts into a plug hole and binds. I bet one could slightly shave the camera dia to get it in just fine. I don't yet have the unit charged or AA's on hand, so I don't know how good a view of the piston and valves you can get from the plug hole or with the mirror. glen matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Date: Jun 19, 2009
If your email client has the capability, you can select "View Message Raw Source" (that is what my Mac Mail program calls it) and you will be able to read the blank messages. The problem is a mis-formed HTML tag at the beginning of the message. By reading the raw source, you can pick out the message OK from the HTML tags, which are all present. Steve Thomas ________________________________________________________________________ On Jun 19, 2009, at 9:17 AM, Harley wrote: > > > Dj Merrill wrote: >> >> >> On 6/19/2009 10:09 AM, Harley wrote: >> >>> The interesting thing is that I sent the same message to two other >>> accounts that I have (agelesswings and Frontiernet), and in both of >>> those, it came through fine??? >>> >>> So something in Aeroelectric might be "interacting" with it. >>> >> >> Hi Harley, >> I've seen this happen with other mailing lists (non-Matronics), as >> well >> as direct person to person. Sometimes the messages go through fine, >> sometimes they don't. It has to do with the way that AVG modifies >> the >> mail headers, which sometimes are okay, and more often are not. AVG >> obviously has a bug in their software that they have not tracked >> down yet. >> >> FWIW, while scanning incoming e-mail has definite merits for >> protecting >> your computer, scanning outgoing e-mail has little value, so there >> really is no significant harm in turning that function off. >> > Yeah...I thought the same thing...guess that's why I turned it off > in the first place, then promptly forgot about it! > > H. >> -Dj >> >> > > ________________________________________________________________________________
Date: Jun 19, 2009
Subject: Re: RE: Borescopes and sparkplug holes
Quoting glen matejcek : > > > The camera just starts into a plug hole and binds. I bet one could > slightly shave the camera dia to get it in just fine. I don't yet have the > unit charged or AA's on hand, so I don't know how good a view of the piston > and valves you can get from the plug hole or with the mirror. > > glen matejcek > aerobubba(at)earthlink.net Can those experienced in close inspection of cylinders and corrosion comment on the potential of this dental camera? http://tinyurl.com/m5kscj It would seem to offer detailed, closeup, remote inspection, but never having used any borescope I don't trust my own judgment. Ralph Finch Davis, CA USA ---------------------------------------------------------------- This message was sent using IMP, the Internet Messaging Program. ________________________________________________________________________________
Date: Jun 19, 2009
This seems to be a week of internet problems. I cannot use tinyurl successfully on this or any other link in a message. Can I ask that you post the raw link instead of going through the Netherlands? John Morgensen Ralph Finch wrote: > > Can those experienced in close inspection of cylinders and corrosion > comment on > the potential of this dental camera? http://tinyurl.com/m5kscj It > would seem > to offer detailed, closeup, remote inspection, but never having used any > borescope I don't trust my own judgment. > > Ralph Finch > Davis, CA USA ________________________________________________________________________________
Date: Jun 19, 2009
This may look terrible: http://cgi.ebay.com/NEW-HOME-USE-DENTAL-INTRA-ORAL-CAMERA-USB-Connection_W0QQitemZ370206256373QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item5632032cf5&_trksid=p3286.c0.m14&_trkparms=65%3A15|66%3A2|39%3A1|240%3A1318|301%3A1|293%3A1|294%3A50#ebayphotohosting If it's broken, you can cut each little piece of the URL from this message into the address window and it should work. I had to chuckle about "130,000,0" Mega pixels.. Below, it does state a more reasonable 1.3 Mega pixels. Matt- > > > This seems to be a week of internet problems. I cannot use tinyurl > successfully on this or any other link in a message. Can I ask that you > post the raw link instead of going through the Netherlands? > > John Morgensen > > Ralph Finch wrote: >> >> Can those experienced in close inspection of cylinders and corrosion >> comment on >> the potential of this dental camera? http://tinyurl.com/m5kscj It >> would seem >> to offer detailed, closeup, remote inspection, but never having used any >> borescope I don't trust my own judgment. >> >> Ralph Finch >> Davis, CA USA > > ________________________________________________________________________________
Date: Jun 19, 2009
At 06:52 6/19/2009, you wrote: >To: aeroelectric-list(at)matronics.com >Subject: Re: AeroElectric-List: Wire Protection Question > >At 02:31 AM 6/19/2009, you wrote: >> > > A 12AWG wire is probably too small to be > a bus feeder. When wiring with truly "fat" > wires (6AWG or larger) they're not at high > risk for burning due to shorts or overloads. > Take a look at the wiring diagrams for any > single engine TC aircraft and you'll find > that few if any will incorporate fuses or > current limiters in these pathways. This > philosophy is echoed in the FARS . . . > > >Sec. 23.1357 Circuit protective devices. > >(a) Protective devices, such as fuses or circuit breakers, must be >installed in all electrical circuits other than-- >(1) Main circuits of starter motors used during starting only; and >(2) Circuits in which no hazard is presented by their omission. Bob, Trying to turn this into a learning/understanding moment, the above leaves me a bit puzzled as to exactly when the omission of a protective device would be considered to pose no hazard. Say one has an AWG-6 feeder connected to the switched side of the master relay and the conductor or a terminal faults to airframe. Alternator current would be limited by the alternator breaker, good; but battery current would only be limited by conductor, termination, device and internal battery resistances. At first estimate this would seem to be capable of generating a current well above the safe capacity of the AWG-6. While my scope of knowledge is limited to but a small spectrum of TC's aircraft, all have had some form of protection on large gauge feeders. Specifically, for a PA-46-350, the only unprotected unswitched circuit is termed the battery bus and supplies lights, clock and ground clearance com. This topic is of particular interest to me as we are currently working on electrical system modifications for a Bellanca BL-17 and found the local, SAN, FSDO and inspectors have conflicting thoughts with what you have stated. Appreciate any additional insight you may be able to provide. Thanks Ron Q. ________________________________________________________________________________
Date: Jun 19, 2009
Ralph, you might have to be the guinea pig and let us know how it works out. It doesn't look practical to me but I have very little experience with borescopes in general. Ralph Finch wrote: > > > Quoting glen matejcek : > >> >> >> The camera just starts into a plug hole and binds. I bet one could >> slightly shave the camera dia to get it in just fine. I don't yet >> have the >> unit charged or AA's on hand, so I don't know how good a view of the >> piston >> and valves you can get from the plug hole or with the mirror. >> >> glen matejcek >> aerobubba(at)earthlink.net > > Can those experienced in close inspection of cylinders and corrosion > comment on > the potential of this dental camera? http://tinyurl.com/m5kscj It > would seem > to offer detailed, closeup, remote inspection, but never having used any > borescope I don't trust my own judgment. > > Ralph Finch > Davis, CA USA > > ---------------------------------------------------------------- > This message was sent using IMP, the Internet Messaging Program. > > > ------------------------------------------------------------------------ > > > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Jun 19, 2009
BTW, There are other places to buy similar cameras: http://foxtor.com/product_info.php?products_id=1432 I searched on Google for "dental oral usb camera". Matt- > > > This seems to be a week of internet problems. I cannot use tinyurl > successfully on this or any other link in a message. Can I ask that you > post the raw link instead of going through the Netherlands? > > John Morgensen > > Ralph Finch wrote: >> >> Can those experienced in close inspection of cylinders and corrosion >> comment on >> the potential of this dental camera? http://tinyurl.com/m5kscj It >> would seem >> to offer detailed, closeup, remote inspection, but never having used any >> borescope I don't trust my own judgment. >> >> Ralph Finch >> Davis, CA USA > > ________________________________________________________________________________
Date: Jun 19, 2009
Maybe an even better one(?): http://www.armatexx.eu/consumerelectronics/product_info.php?info=p2407_Tubular-Inspection-Camera---USB-Wand-Digital-Camera-with-Lights.html I searched for "usb inspection camera -microscope" Matt- > > > This seems to be a week of internet problems. I cannot use tinyurl > successfully on this or any other link in a message. Can I ask that you > post the raw link instead of going through the Netherlands? > > John Morgensen > > Ralph Finch wrote: >> >> Can those experienced in close inspection of cylinders and corrosion >> comment on >> the potential of this dental camera? http://tinyurl.com/m5kscj It >> would seem >> to offer detailed, closeup, remote inspection, but never having used any >> borescope I don't trust my own judgment. >> >> Ralph Finch >> Davis, CA USA > > ________________________________________________________________________________
Subject: Re: Borescopes and sparkplug holes
Date: Jun 19, 2009
When doing cylinder wall inspections using a boroscope it's best to look at the wall at 90deg.Spark plug holes may not be in the center of the cylinder it is nice to have a flexible probe / pivoting mirror /camera view at least 90deg to probe shaft as this allows you to see the valves. Cheers Read this topic online here: http://forums.matronics.com/viewtopic.php?p=249163#249163 ________________________________________________________________________________
Date: Jun 19, 2009
That's partly why the before-mentioned dental usb camera seemed it might work: it's mounted at a right angle to the probe, fairly high magnification, made for close work...and cheap. Another one with 4 million pixels is at http://tinyurl.com/mcvhw8 $159 including shipping from China. Connect to a $400 laptop and you've got a nice inspection device. Our manufacturing doesn't have a chance. http://cgi.ebay.com/4-0MEGA-PIXELS-DENTAL-INTRA-ORAL-CAMERA-USB-CONNECTION_W 0QQitemZ320385953075QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item4a987dad3 3&_trksid=p4634.m332.l1262 -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Thruster87 Sent: Friday, June 19, 2009 3:19 PM Subject: AeroElectric-List: Re: Borescopes and sparkplug holes When doing cylinder wall inspections using a boroscope it's best to look at the wall at 90deg.Spark plug holes may not be in the center of the cylinder it is nice to have a flexible probe / pivoting mirror /camera view at least 90deg to probe shaft as this allows you to see the valves. Cheers Read this topic online here: http://forums.matronics.com/viewtopic.php?p=249163#249163 ________________________________________________________________________________
Date: Jun 19, 2009
Did you miss this paragraph in Bob's message. > In particular, paragraph 12.1357(a)(2) applies here. Faulted robust wires generally arc to ground and burn their faults clear. Further, they're easily installed with attention to mechanical details such that faults to ground are as probable as loosing one's propeller due to bolt failure. > Robust mounting keeps that arcing end from moving so it burns the fault clear. You just end up with a hole were the fault was. Bob Meyers Building Sonex 982SX Web Site Index http://meyersfamily.org/Sonex982.html On Jun 19, 2009, at 3:53 PM, Ron Quillin wrote: > At 06:52 6/19/2009, you wrote: >> To: aeroelectric-list(at)matronics.com >> Subject: Re: AeroElectric-List: Wire Protection Question >> >> At 02:31 AM 6/19/2009, you wrote: >>> > >>> >> >> A 12AWG wire is probably too small to be >> a bus feeder. When wiring with truly "fat" >> wires (6AWG or larger) they're not at high >> risk for burning due to shorts or overloads. >> Take a look at the wiring diagrams for any >> single engine TC aircraft and you'll find >> that few if any will incorporate fuses or >> current limiters in these pathways. This >> philosophy is echoed in the FARS . . . >> >> >> Sec. 23.1357 Circuit protective devices. >> >> (a) Protective devices, such as fuses or circuit breakers, must be >> installed in all electrical circuits other than-- >> (1) Main circuits of starter motors used during starting only; and >> (2) Circuits in which no hazard is presented by their omission. > > Bob, > Trying to turn this into a learning/understanding moment, the above > leaves me a bit puzzled as to exactly when the omission of a > protective device would be considered to pose no hazard. Say one > has an AWG-6 feeder connected to the switched side of the master > relay and the conductor or a terminal faults to airframe. > Alternator current would be limited by the alternator breaker, good; > but battery current would only be limited by conductor, termination, > device and internal battery resistances. At first estimate this > would seem to be capable of generating a current well above the safe > capacity of the AWG-6. > > While my scope of knowledge is limited to but a small spectrum of > TC's aircraft, all have had some form of protection on large gauge > feeders. Specifically, for a PA-46-350, the only unprotected > unswitched circuit is termed the battery bus and supplies lights, > clock and ground clearance com. > > This topic is of particular interest to me as we are currently > working on electrical system modifications for a Bellanca BL-17 and > found the local, SAN, FSDO and inspectors have conflicting thoughts > with what you have stated. > > Appreciate any additional insight you may be able to provide. > > Thanks > Ron Q. > > ________________________________________________________________________________
Date: Jun 19, 2009
Thanks again Bob for sharing your expertise... I'll confirm that the vibrator is working and troubleshoot the system as suggested, but before I do, could you please help me with a couple more questions I have about the SOS system? With reference to the wire between the LR terminal on the switch and the retard breaker on the left mag, is this suppose to be a shielded wire with the shield running to GND the same as the L & R p-lead? If not, what would be the consequences of using a shielded wire with the shield running to the switch ground. I know I used shielded wire for the retard breaker, but can't recall if I ran the shield to ground. I haven't had a chance to pull the switch yet to check. Regards, John ----- Original Message ----- From: Robert L. Nuckolls, III To: aeroelectric-list(at)matronics.com Sent: Friday, June 19, 2009 10:15 AM Subject: Re: Fw: AeroElectric-List: Shower of Sparks Help At 11:45 PM 6/18/2009, you wrote: Bob The link you referenced below is the one I used to wire my SOS system (Key Switch Controlled). The GRD to R jumper was checked and is in place. The way that I know both mags are active is that, as a test before first start, I pulled a plug wired to each mag and cranked the starter to check for spark. . I don't know whether the vibrator was working at the time. What kind of spark did you get? A magneto is capable of delivering but a single spark per ignition even. If the shower of sparks vibrator system is working, the left magneto should be delivering a continuous stream of sparks during engine cranking. Should should also be able to hear the vibrator "buzzing". If the key switch is bad, then the mags are NEVER being shut off . . . not a good thing. Be sure your shield grounds are properly and robustly wired as shown. It could be that you're not getting the right mag grounded because the shield is improperly terminated at one end or both ends. Is there a way to check the keyed ignition switch to make sure it is working properly? Could a faulty shield connection on the Right Mag at either the switch or mag terminal cause the problem? Sure. Leave the master switch off. Disconnect the p-lead from the R mag and put an ohmmeter between center conductor and shield. Turn the key switch and watch ohmmeter. You should read less than 1 ohm in all key switch positions except "R" and "BOTH". In particular, you're interested in seeing the R mag get shorted in the START position which is what the jumper does for you. If this doesn't happen, then the switch is probably bad . . . but check the shield grounds first. Check out this shield termination process if you've not already seen it. http://aeroelectric.com/articles/shldwire/shldwire.html I believe these key switches can be disassembled, cleaned and lubricated. An alternative is to use toggle switches as shown in the third diagram. Much less expensive and easier to maintain. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Subject: Antenna and Balun dimensions
Date: Jun 19, 2009
http://www.aeroelectric.com/articles/BALUN/Balun_Fabrication.html Saw the dimensions for this VOR antenna on the website. What would the dimensions for a COM's antenna be and would I also use a balun Thanks Mike ________________________________________________________________________________
From: "kuffel(at)cyberport.net" <kuffel(at)cyberport.net>
Subject: Re: Tyco Breakers
Date: Jun 19, 2009
Bob Nuckolls said: << switch breakers force the builder to fabricate a distribution bus on the panel . . . not unlike the breaker panels typical of TC aircraft even today. >> << Breakers that assuage concerns for aircraft designers have terminal bosses compatible with bus bars that tie multiple devices together. >> Which is exactly what I did with my previous amateur built aircraft using these breakers, connected all the breakers together with one buss bar connected directly to the terminals. << If one is favorably impressed with fuse blocks, >> But I am not, which is the source of our differing approach. My friend, the rich man's chief pilot, has just spent a large part of the last seven years fighting with the maker of their new model $47 million private jet over the fact they wanted to make all the fuses totally inaccessible in flight. Manufacturer lost the argument. Same principle applies to single pilot small aircraft with the automobile style fuse block. All I'm saying is if you are among those of us who are uncomfortable without access to our circuit protection devices, the Snapak magnetic-hydraulic R11-1 style circuit breaker/switch rated for use in life critical medical devices (albeit not mil-spec) is a viable, lower cost, simpler and possibly more reliable alternative to the TC common practice of acres of breakers way over there and switches way over here. Tom Kuffel ________________________________________________________________________________
Date: Jun 20, 2009
Subject: Re: Antenna and Balun dimensions
At 12:09 AM 6/20/2009, you wrote: ><http://www.aeroelectric.com/articles/BALUN/Balun_Fabrication.html>http://www.aeroelectric.com/articles/BALUN/Balun_Fabrication.html > > >Saw the dimensions for this VOR antenna on the website. What would >the dimensions for a COM's antenna be and would I also use a balun Is your comm antenna a vertical half wave dipole? How do you get this much vertical disposition of the elements on a small aircraft? The dimensions would simply be reduced by about 10% to favor the comm band. 23" would be fine. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 20, 2009
>Bob, >Trying to turn this into a learning/understanding moment, the above >leaves me a bit puzzled as to exactly when the omission of a >protective device would be considered to pose no hazard. Say one >has an AWG-6 feeder connected to the switched side of the master >relay and the conductor or a terminal faults to >airframe. Alternator current would be limited by the alternator >breaker, good; but battery current would only be limited by >conductor, termination, device and internal battery resistances. At >first estimate this would seem to be capable of generating a current >well above the safe capacity of the AWG-6. > >While my scope of knowledge is limited to but a small spectrum of >TC's aircraft, all have had some form of protection on large gauge >feeders. Specifically, for a PA-46-350, the only unprotected >unswitched circuit is termed the battery bus and supplies lights, >clock and ground clearance com. > >This topic is of particular interest to me as we are currently >working on electrical system modifications for a Bellanca BL-17 and >found the local, SAN, FSDO and inspectors have conflicting thoughts >with what you have stated. > >Appreciate any additional insight you may be able to provide. The style of "protection" one might add to fat wires in an array of battery/bus/cranking feeders are like the ANL "current limiters" found in the power distribution systems of many larger aircraft. http://aeroelectric.com/Pictures/Fuses/Fuses/ANL-ANN_Current_Limiter.jpg Fusing characteristics for these puppies are shown here . . . http://aeroelectric.com/Mfgr_Data/Fuses_and_Current_Limiters/Bussman/ANL_Specs.pdf Suppose you decided to put an ANL200 in the battery feeder for your project. Note in the fusing plots above the ANL200 will carry 300A without breathing hard. Now, what kind of fault can you imagine that ties your feeders down so firmly to the airframe that you'd expect battery fault currents of 1000+ amps to flow? You're going to rub off some insulation and have some low pressure, flying fault that arcs a lot and intermittently draws hundreds of amps . . . but is unlikely to open the ANL limiter. In facdt, you'll find that the copper is barely damaged compared to adjacent aluminum that simply burns clear without even warming up your feed wire. Have your skeptics research the wiring diagrams for the host of S.E. aircraft produced in the hundreds of thousands for nearly 100 years and they'll note a not so curious absence of fuses/breakers in the fat wire feeders . . . These wires seldom get faulted and when they do, the event is so benign that the current protection doesn't operate before arcing burns the fault clear. It's a lot of careful design and hard work to bring two conductors together to be an efficient conductor of hundreds of amps. It just doesn't happen accidently. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 20, 2009
>All I'm saying is if you are among those of us who are >uncomfortable without access to our circuit protection >devices, the Snapak magnetic-hydraulic R11-1 style circuit >breaker/switch rated for use in life critical medical >devices (albeit not mil-spec) is a viable, lower cost, >simpler and possibly more reliable alternative to the TC >common practice of acres of breakers way over there and >switches way over here. To each his own. Fly comfortably sir! Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 20, 2009
At 10:38 PM 6/19/2009, you wrote: >Thanks again Bob for sharing your expertise... My pleasure sir. >I'll confirm that the vibrator is working and troubleshoot the >system as suggested, but before I do, could you please help me with >a couple more questions I have about the SOS system? With >reference to the wire between the LR terminal on the switch and the >retard breaker on the left mag, is this suppose to be a shielded >wire with the shield running to GND the same as the L & R >p-lead? If not, what would be the consequences of using a shielded >wire with the shield running to the switch ground. I know I used >shielded wire for the retard breaker, but can't recall if I ran the >shield to ground. I haven't had a chance to pull the switch yet to check. This lead is 'hot' only while cranking the engine and doesn't represent a potential noise source after the engine is running. I've seen systems where the designer shielded all the wires but most will leave this one un-shielded. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 20, 2009
This doesn't answer your post directly but you might find it interesting: http://www.vansairforce.com/community/showthread.php?t=42872 -------- Marc Ausman http://www.verticalpower.com RV-7 IO-390 Flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=249232#249232 ________________________________________________________________________________
Date: Jun 20, 2009
>First, thank you for your response to my original question. If I am >following your logic: A fat wire, if shorted to airframe >ground, will burn away the nearby aluminum ground fault very >quickly, and thereby eliminate the immediate problem. > >If that is so, then the next question would seem to be: Why protect >the relatively short B-Lead that goes to-from the alternator, as it >can be easily physically protected in a similar manner to the bus feed wire. Because the fault risk there is not to the wire itself but for the potential of diodes shorting in the alternator. This failure would probably burn wires in the alternator. That's probably the least "useful" of the fat-wire feeder fuses. Probability of diodes shorting in modern alternators is exceedingly low. That fuse or breaker can probably be eliminated with little risk. Cars have never used this fuse. Early cars burned some wires . . . later ones added fusible links in the system to limit the amount of wire that needed to be replaced after a "burn". >And a second question: Why use an AWG-6 wire to supply a main bus >that only has a 20 amp max load? Because to qualify as a fat-feeder with little use for protection, the wire needs to be more robust than the fault site conductors that would put it at risk. We protect the little guys because flying faults will often burn them . . . a distribution fat-wire unworthy of protection needs to be in the robust class. I've never seen any rules of thumb but my sense is that wires in the 10 to 6AWG range are in a grey area and I'd probably fuse them. A short 6AWG or larger bus feeder is probably good to go without specific protection other than extra attention to support and isolation from potentially hazardous mechanical damage. >Struggling to understand in a few weeks what you have learned in an >entire career!!!!............ No hurry my friend. We've got all the time you need. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 20, 2009
[quote] But I am not, which is the source of our differing approach. My friend, the rich man's chief pilot, has just spent a large part of the last seven years fighting with the maker of their new model $47 million private jet over the fact they wanted to make all the fuses totally inaccessible in flight. Manufacturer lost the argument. Same principle applies to single pilot small aircraft with the automobile style fuse block. Tom Kuffel[/quote] Tom, I spend my life with private Jets. I've never seen fuses in the cockpit, only circuit breakers. Any fuses or current limiters in transport category aircraft, and there are hundreds, are always located where the crew can't touch them, along with many of the breakers they don't want the pilot to have access to. You just don't want some stupid pilot starting a fire playing with them. The rule that has always been pounded into my head is to accept the loss and fly the plane, not try and fix it. That's how L-1011's end up in the swamp while pilots are trying to change gear indicator bulbs. The only aircraft I'm aware of that has few, but not no, breakers in the cockpit is Bombardier's Global Express. It does, however, have remote breakers controlled by screens in the cockpit. It saves a huge amount of weight running wires all the way from the hell hole to the cockpit and back. Also the usability for the crew goes way up. They can see all systems effected when a breaker is popped and can isolate a bus at will. Also, if one pops you get a message. That being said, no manufacturer is going to change his Type Certificated product based on the whims of some ego-centric pilot. Funny, but the buyer of that $47M aircraft is sitting in the back. That's the ones the manufacturer's listen to and not the hired hands up front. Trust me on that one. Cockpits and panel layout of all new aircraft are now part of the certificate and short of adding a third something cannot be altered without a big STC project. I'd be interested in knowing what aircraft model you are talking about. Cheers, Don Read this topic online here: http://forums.matronics.com/viewtopic.php?p=249246#249246 ________________________________________________________________________________
Date: Jun 20, 2009
Marc, VERY COOL! Thanks! Bob Borger Europa Kit #A221 N914XL, XS Mono, Intercooled 914, Airmaster C/S http://www.europaowners.org/N914XL Aircraft Flying! 3705 Lynchburg Dr. Corinth, TX 76208 Home: 940-497-2123 Cel: 817-992-1117 On Jun 20, 2009, at 11:58, marcausman wrote: > > > > This doesn't answer your post directly but you might find it > interesting: http://www.vansairforce.com/community/showthread.php?t=42872 > > -------- > Marc Ausman > http://www.verticalpower.com > RV-7 IO-390 Flying > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=249232#249232 > > ________________________________________________________________________________
Subject: Re: noisy tach signal
Date: Jun 21, 2009
Thanks Bob, fortunately it appears there was a simple solution that will avoid troubleshooting efforts at the circuit level.....it appears the 720-14R hall effect sender I had installed was defective as I replaced it with a new one this evening and after a ground run and short test flight, everything seems to be working normally now. Westach has been very good about helping me with this issue on getting their sender to work with the IK unit and they sent me several sender types to try, including a new replacement for what I was using. Excellent customer service and tech support from Westach. I didn't get to the point of using the other sender options they sent as the first thing I did was try the straight replacement for what I had. So my lesson learned is that yes, sometimes a brand new sensor/sender can be bad right out of the box. What I don't understand is how a defective hall effect sender would cause indications of noise issues when the mag it's installed in is running but work normally when that mag is secured.....but I've got a working tach now, so I'm happy! Chris > > > > Hmmm . . . see if the IK-Tech will share a sketch > of a schematic for the first two stages of tach > signal conditioning. The manner in which bias levels > are established for any "squaring" or level sensing > circuits can have a profound effect on noise sensitivity. > The schematics (need parts values too) + 'scope trace > will permit a simple-ideas analysis of the symptoms. > > > Bob . . . ________________________________________________________________________________
Subject: antenna mounting
Date: Jun 21, 2009
I am looking for ideas on mounting a antenna for a hand held VHF radio on a steel tube fabric covered airplane. The original idea was to just use the short supplied antenna but it has been suggested that I could get better range with a mounted antenna. Because of the original plan there wasn't any type of ground plane installed and adding one may be difficult. The plane is a Warner Sportster (new version of the Spacewalker II), it is a low wing two place tandem open cockpit fuselage. There is a wood turtledeck that runs from the aft cockpit to the tail. About the best place would probably be on the belly but the ground plane would probably have to be on top of the tubing (because of stringers) with some type of spacer the length of the tube diameter to get the antenna base to the fabric. I am guessing that a antenna mounted inside the tube fuselage would be a mute point. Any thoughts on this? Thanks Read this topic online here: http://forums.matronics.com/viewtopic.php?p=249344#249344 ________________________________________________________________________________
Date: Jun 21, 2009
At 02:13 PM 6/20/2009, you wrote: > >[quote] >But I am not, which is the source of our differing approach. > My friend, the rich man's chief pilot, has just spent a >large part of the last seven years fighting with the maker >of their new model $47 million private jet over the fact >they wanted to make all the fuses totally inaccessible in >flight. Manufacturer lost the argument. Same principle >applies to single pilot small aircraft with the automobile >style fuse block. > >Tom Kuffel[/quote] > > >Tom, > >I spend my life with private Jets. I've never seen fuses in the >cockpit, only circuit breakers. Any fuses or current limiters in >transport category aircraft, and there are hundreds, are always >located where the crew can't touch them, along with many of the >breakers they don't want the pilot to have access to. You just >don't want some stupid pilot starting a fire playing with them. The >rule that has always been pounded into my head is to accept the loss >and fly the plane, not try and fix it. That's how L-1011's end up >in the swamp while pilots are trying to change gear indicator bulbs. Exactly. It's with this design goal in mind that we strive for failure tolerant design. I.e., loss of any single system should not put a mission at risk for bent airplanes -OR- people. Better yet, very low risk for even breaking a sweat. To be sure, there are things we cannot make failure tolerant. Wing struts, prop bolts, connecting rods, etc. At the same time, we design those components with some notion of robustness under normal use. Somehow, it's easy to allow certain electro-whizzies to take up residence in our "can't survive without it" basket of thought. Hence, we worry about them a lot and tend to get wrapped around a "push-the-breaker- and-HOPE-it-will-stay on" mentality. But as I pointed out some 15 years ago . . . http://www.aeroelectric.com/articles/fuseorcb.html and elaborated upon it further 4 years later . . . http://www.aeroelectric.com/articles/fusvbkr2.html . . . there are MANY ways an electro-whizzy can wander into the weeds WITHOUT opening it's supply circuit protection. Considering this inarguable fact, it seems prudent to design one's electrical system such that every device truly necessary for comfortable termination of flight have an independent backup . . . a Plan-B. Once the design goal is achieved, then it matters not what form the circuit protection takes nor does it matter where that protection is located. If one has plenty of panel space, low expectations for overall electrical system reliability (day vfr, fair weather flying) then covering the panel with acres-of-breakers-and-switches may be satisfying as a style statement . . . but adds nothing to system reliability while adding burden to empty weight, cockpit complexity, time to install and cost of ownership. The only aircraft I'm aware of that has few, but not no, breakers in the cockpit is Bombardier's Global Express. It does, however, have remote breakers controlled by screens in the cockpit. It saves a huge amount of weight running wires all the way from the hell hole to the cockpit and back. Also the usability for the crew goes way up. They can see all systems effected when a breaker is popped and can isolate a bus at will. Also, if one pops you get a message. Yeah, I think Eclipse did this too. Bob . . . ________________________________________________________________________________
Date: Jun 21, 2009
Subject: Re: antenna mounting
At 09:04 AM 6/21/2009, you wrote: > >I am looking for ideas on mounting a antenna for a hand held VHF >radio on a steel tube fabric covered airplane. > >The original idea was to just use the short supplied antenna but it >has been suggested that I could get better range with a mounted antenna. A belly mounted antenna (either full size or a 'rubber duck') will perform better than the antenna installed on the hand-held. >Because of the original plan there wasn't any type of ground plane >installed and adding one may be difficult. Not a big problem. If you can get a mounting bracket against the skin to support the antenna that is also well connected to tubular structure, then performance will not be appreciably enhance with a 'proper' ground plane. Try mounting a bulkhead mounted, BNC cable-connector http://www.aeroelectric.com/Pictures/Connectors/Coax/BNC_Bulkhead_Female.jpg on the bracket and just move the radio mounted rubber-duck to this location. I think you'll find the performance to be very close to an idealized antenna installation. I am guessing that a antenna mounted inside the tube fuselage would be a mute point. Correct. Radiation through the fabric from inside the structure is pretty lame. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 21, 2009
At 02:32 AM 6/21/2009, you wrote: > >Thanks Bob, fortunately it appears there was a simple solution that >will avoid troubleshooting efforts at the circuit level.....it >appears the 720-14R hall effect sender I had installed was defective >as I replaced it with a new one this evening and after a ground run >and short test flight, everything seems to be working normally now. Great! It would have been interesting to see if a 'scope investigation would have revealed the problem too . . . but I'm pleased to hear that you can move on to more important things! Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 21, 2009
Thanks Bob, That sounds easy enough to do. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=249434#249434 ________________________________________________________________________________
Date: Jun 22, 2009
Subject: EGT instrument test
>Comments/Questions: Pete at Westach tells me that if I can apply a >3.5mv current to the EGT, that it should read 1500f on the >meter. Do you know where to get something that I can apply such an >electric voltage. They have a chart for all the different voltages >and resulting readings, on their web site. 3.5 mV is a bit low for 1500F . . . I think it's more like 35.0 mV. See: http://www.omega.com/temperature/Z/pdf/z218-220.pdf "Applying voltage" to a thermocouple readout is but a gross test of functionality. Significant errors can be introduced unless the voltage is applied with consideration for "parasitic thermocouple junctions". See: http://www.aeroelectric.com/articles/excerpt.pdf Assuming that you're interested in doing a gross functionality test at 34mV, then you can craft this little test rig. Emacs! A couple of easily acquired resistors from Radio Shack and a AA battery holder. http://www.radioshack.com/product/index.jsp?productId 62247 http://www.radioshack.com/product/index.jsp?productId 62338 http://www.radioshack.com/product/index.jsp?productId=2994588 wired as shown will get you a voltage in the right ball park. If all the errors are accounted for, your instrument will read 1504F, but if it's off by as much as 50 degrees, I wouldn't worry about it. An accurate calibration test of the instrument will require more attention to details. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Subject: Re: Burning Vans Engine Gauges - Part 3
Date: Jun 22, 2009
Well I spent some time with the ammeter, with and without engine running. There appeared to be no overheating. There is less than an amp at the instrument buss. There is less than 4 amps overall at the alternator once it recovers from start. I even tried banging on the alternator while it was running. All the grounds and connections have been checked. ....all I am left with is the assumption that the alternator ran away....cooked the resistors in the gauges, and they finished melting when it was producing within limits. Also I think that the "starting" draw down is not good. I plan to change the alternator and instruments. I wonder if anyone has suggestion about isloating instruments during start cycle? Thanks! -------- Jake Read this topic online here: http://forums.matronics.com/viewtopic.php?p=249534#249534 ________________________________________________________________________________
Date: Jun 22, 2009
At 11:19 AM 6/22/2009, you wrote: > > >Well I spent some time with the ammeter, with and without engine >running. There appeared to be no overheating. There is less than an >amp at the instrument buss. There is less than 4 amps overall at >the alternator once it recovers from start. I even tried banging on >the alternator while it was running. All the grounds and connections >have been checked. > >....all I am left with is the assumption that the alternator ran >away....cooked the resistors in the gauges, and they finished >melting when it was producing within limits. Also I think that the >"starting" draw down is not good. > >I plan to change the alternator and instruments. I wonder if anyone >has suggestion about isloating instruments during start cycle? What alternator/regulator combination are you using? Do you have any form of OV protection? Any OV event that is even slightly hazardous to aircraft electro-whizzies is easily managed by appropriate protection. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Subject: Dual mags now...one Plasma II plus later
Date: Jun 23, 2009
My plan is to fly off several hours in the RV-7 using two Slick mags before transitioning over to a one mag and Plasma II plus system. With this in mind, what is the best way to spec-out and set-up the ignition switches? I am referencing Z-13/8 AEC as the basis for my design. The Z-13 diagram shows an s700-1-3 and a s700-2-10. Perhaps a s700-2-50 would make more sense. Thanks, Wade Roe EAA 557 Aeronca 7AC flying RV-7 in process ________________________________________________________________________________
Subject: Strobe Power Supply Location
Date: Jun 23, 2009
I am building an RV-7 and my Whelen strobe power supply (HDACF) has
June 09, 2009 - June 23, 2009
AeroElectric-Archive.digest.vol-it
