AeroElectric-Archive.digest.vol-iu
June 23, 2009 - July 02, 2009
      ended up being quite close to my pitch servo (approx. 4" below).  Should
      I be concerned about the strobe unit emitting noise that would in turn
      cause pulsations w/n the auto-pilot servo?
      The strobe power supply was installed early on without the pitch servo
      in mind.  Build and learn...
      I have routed no wiring yet.
      Thanks!
      Wade Roe
      EAA 557
      Aeronca 7AC flying
      RV-7 in process
Subject: First choice alternator decision
Date: Jun 23, 2009
Gentleman, This topic was touched on earlier but I'm still not sure which route is best regarding the primary alternator for my RV-7. I am interested in the best quality unit that will also coincide nicely with the AEC system designs (particulary Z-13/8). The options are as follows: --Plane Power 60A alternator with OV protection and internal regulation, or --B&C L-60 matched up with an LR3C-14. This will be an all electric IFR plane with one battery and SD-8 aux alternator. Any thoughts or comments would be appreciated. Thanks! Wade Roe EAA 557 Aeronca 7AC flying RV-7 in process ________________________________________________________________________________
Date: Jun 23, 2009
Subject: Re: Strobe Power Supply Location
At 08:58 AM 6/23/2009, you wrote: > > >I am building an RV-7 and my Whelen strobe power supply (HDACF) has >ended up being quite close to my pitch servo (approx. 4" below). Should >I be concerned about the strobe unit emitting noise that would in turn >cause pulsations w/n the auto-pilot servo? No >The strobe power supply was installed early on without the pitch servo >in mind. Build and learn... > >I have routed no wiring yet. There are no effects emanating from the strobe supply that put the servo system at risk. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 23, 2009
Subject: Re: Dual mags now...one Plasma II plus later
At 08:58 AM 6/23/2009, you wrote: > >My plan is to fly off several hours in the RV-7 using two Slick mags >before transitioning over to a one mag and Plasma II plus system. With >this in mind, what is the best way to spec-out and set-up the ignition >switches? I am referencing Z-13/8 AEC as the basis for my design. The >Z-13 diagram shows an s700-1-3 and a s700-2-10. Perhaps a s700-2-50 >would make more sense. A pair of S700-1-3 switches will do fine for both the pair of mags and for the final configuration. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 23, 2009
Subject: Re: First choice alternator decision
At 09:01 AM 6/23/2009, you wrote: > >Gentleman, > >This topic was touched on earlier but I'm still not sure which route is >best regarding the primary alternator for my RV-7. I am interested in >the best quality unit that will also coincide nicely with the AEC system >designs (particulary Z-13/8). The options are as follows: > > --Plane Power 60A alternator with OV protection and internal >regulation, or > > --B&C L-60 matched up with an LR3C-14. > >This will be an all electric IFR plane with one battery and SD-8 aux >alternator. > >Any thoughts or comments would be appreciated. Both products have good field histories and perform as advertised. Your choice. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Subject: Dual mags now...one Plasma II plus later
Date: Jun 23, 2009
Thanks for the input! Wade Roe SOUTHERN CARBIDE TECHNOLOGIES, INC. 7739 Unity Road M&D Industrial Park Tuscaloosa, AL 35401 205-248-6700 205-248-6372 fax -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Tuesday, June 23, 2009 10:33 AM Subject: Re: AeroElectric-List: Dual mags now...one Plasma II plus later At 08:58 AM 6/23/2009, you wrote: > >My plan is to fly off several hours in the RV-7 using two Slick mags >before transitioning over to a one mag and Plasma II plus system. With >this in mind, what is the best way to spec-out and set-up the ignition >switches? I am referencing Z-13/8 AEC as the basis for my design. The >Z-13 diagram shows an s700-1-3 and a s700-2-10. Perhaps a s700-2-50 >would make more sense. A pair of S700-1-3 switches will do fine for both the pair of mags and for the final configuration. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Subject: Strobe Power Supply Location
Date: Jun 23, 2009
Thank you Bob! Wade Roe SOUTHERN CARBIDE TECHNOLOGIES, INC. 7739 Unity Road M&D Industrial Park Tuscaloosa, AL 35401 205-248-6700 205-248-6372 fax -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Tuesday, June 23, 2009 10:31 AM Subject: Re: AeroElectric-List: Strobe Power Supply Location At 08:58 AM 6/23/2009, you wrote: > > >I am building an RV-7 and my Whelen strobe power supply (HDACF) has >ended up being quite close to my pitch servo (approx. 4" below). Should >I be concerned about the strobe unit emitting noise that would in turn >cause pulsations w/n the auto-pilot servo? No >The strobe power supply was installed early on without the pitch servo >in mind. Build and learn... > >I have routed no wiring yet. There are no effects emanating from the strobe supply that put the servo system at risk. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 23, 2009
Bob, I noticed in some of your drawings that there are panel mount breakers shown for the main alternator as well as the aux alternator. Is this preferred as compared to fuses? Obviously the breaker grants you at least an attempt to reset in flight... I am paralleling Z-13 with my design. Thanks! Wade Roe -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Tuesday, June 23, 2009 10:34 AM Subject: Re: AeroElectric-List: First choice alternator decision At 09:01 AM 6/23/2009, you wrote: > >Gentleman, > >This topic was touched on earlier but I'm still not sure which route is >best regarding the primary alternator for my RV-7. I am interested in >the best quality unit that will also coincide nicely with the AEC system >designs (particulary Z-13/8). The options are as follows: > > --Plane Power 60A alternator with OV protection and internal >regulation, or > > --B&C L-60 matched up with an LR3C-14. > >This will be an all electric IFR plane with one battery and SD-8 aux >alternator. > >Any thoughts or comments would be appreciated. Both products have good field histories and perform as advertised. Your choice. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 24, 2009
6/24/2009 Hello Wade, Will you have low voltage warning with the Plane Power installation? I would not be without a low voltage (battery not being charged) warning capability. 'OC' Says: "The best investment we can make is the effort to gather and understand knowledge." ============================================== From: "Wade Roe" <wroe1(at)dbtech.net> Subject: AeroElectric-List: First choice alternator decision Gentleman, This topic was touched on earlier but I'm still not sure which route is best regarding the primary alternator for my RV-7. I am interested in the best quality unit that will also coincide nicely with the AEC system designs (particulary Z-13/8). The options are as follows: --Plane Power 60A alternator with OV protection and internal regulation, or --B&C L-60 matched up with an LR3C-14. This will be an all electric IFR plane with one battery and SD-8 aux alternator. Any thoughts or comments would be appreciated. Thanks! Wade Roe EAA 557 Aeronca 7AC flying RV-7 in process ________________________________________________________________________________
Date: Jun 24, 2009
Thank you for the comments. The Plane Power unit has over voltage protection but no low voltage warning features. My plan would be to defer that task to the AEC9005-101 (low voltage monitor) that connects to the main buss per diagram Z-13 AEC. If main buss voltage drops I don't believe that there would be anything to blame other than the primary alternator. In this event, you get the bright yellow LV warning light on the panel and you're shutting down any unnecessary equipment to see if that will temporarily remedy the issue. My next move would be to bring up the aux alternator and e-buss...at least I think that would be the proper protocol. Wade Roe EAA 557 Aeronca 7AC flying RV-7 in process -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of bakerocb(at)cox.net Sent: Wednesday, June 24, 2009 6:37 AM Subject: AeroElectric-List: First choice alternator decision 6/24/2009 Hello Wade, Will you have low voltage warning with the Plane Power installation? I would not be without a low voltage (battery not being charged) warning capability. 'OC' Says: "The best investment we can make is the effort to gather and understand knowledge." ============================================== From: "Wade Roe" <wroe1(at)dbtech.net> Subject: AeroElectric-List: First choice alternator decision Gentleman, This topic was touched on earlier but I'm still not sure which route is best regarding the primary alternator for my RV-7. I am interested in the best quality unit that will also coincide nicely with the AEC system designs (particulary Z-13/8). The options are as follows: --Plane Power 60A alternator with OV protection and internal regulation, or --B&C L-60 matched up with an LR3C-14. This will be an all electric IFR plane with one battery and SD-8 aux alternator. Any thoughts or comments would be appreciated. Thanks! Wade Roe EAA 557 Aeronca 7AC flying RV-7 in process ________________________________________________________________________________
Date: Jun 24, 2009
Subject: Battery Proximity and mounting
Hi all, I am building an all-electric RV 8 with dual electronic ignition. I plan to use two P680 batteries. As I was sorting out where to put them, I had decided to strap them together and put them behind the firewall on the right. A building buddy asked the question, are they okay to be strapped together? Are there any failure modes where one might fail and take out the other out at the same time? I thought I would ask the same question to the list and/or Bob. I really like the "change one out every annual" approach described in the Aeroelectric book, which is why I am going with two identical batteries. The new and improved section on batteries does not describe explosion or melt-down as a likely failure of RG batteries so I had thought that mounting them together and in the inside of the plane would be okay. In retrospect, I can see that I should have built in the mounting system before I riveted on the front bottom skin. As is, I am still scratching my head about where exactly to put them and how to property secure them to the airframe. I am very open to suggestions. Regards, Michael Wynn RV 8 FWF San Ramon, CA **************Huge Savings on Popular Laptops only at Dell.com. Shop Now! %2F%2Fad.doubleclick.net%2Fclk%3B215910242%3B38350777%3Bf) ________________________________________________________________________________
Date: Jun 25, 2009
Subject: Re: Battery Proximity and mounting
At 01:14 PM 6/24/2009, you wrote: >Hi all, > >I am building an all-electric RV 8 with dual electronic ignition. I >plan to use two P680 batteries. As I was sorting out where to put >them, I had decided to strap them together and put them behind the >firewall on the right. > >A building buddy asked the question, are they okay to be strapped together? Yes > Are there any failure modes where one might fail and take out the > other out at the same time? No. > >I thought I would ask the same question to the list and/or Bob. I >really like the "change one out every annual" approach described in >the Aeroelectric book, which is why I am going with two identical >batteries. The new and improved section on batteries does not >describe explosion or melt-down as a likely failure of RG batteries >so I had thought that mounting them together and in the inside of >the plane would be okay. > >In retrospect, I can see that I should have built in the mounting >system before I riveted on the front bottom skin. As is, I am still >scratching my head about where exactly to put them and how to >property secure them to the airframe. I am very open to suggestions. Are you sure they want to go forward? A lot of my RV-8 builders had to put them in the tail for the purposes of satisfying CG limits. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Subject: Terminal N
Date: Jun 25, 2009
Hi there. I'm posting this on behalf of a reader of a newsletter I write. Any help you can give this gentleman would be appreciated: "Have fitted a Bosch externally regulated alternator which has terminals marked F, E, and N. I was advised that when the alternator is giving the correct output there should be 7V potertial at N which I have routed through a relay to extinguish an LED. When the engine is ticking over at 1000 revs the LED is flickering on and off but the battery shows 14 volts. Have I got the principle wrong? what is the purpose of terminal N? " -- Peter York -------- Bob Collins St. Paul, Minn. RV-7A - Running wires http://rvbuildershotline.com Day job: http://minnesota.publicradio.org/collections/special/columns/news_cut/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=249966#249966 ________________________________________________________________________________
Date: Jun 25, 2009
Bob: Could you expand further on your answer? Are there any failure modes or circumstances that would cause an RG battery to fail and drag down the entire system, including taking the alternator off-line? Thanks ----- Original Message ----- From: Robert L. Nuckolls, III To: aeroelectric-list(at)matronics.com Sent: Thursday, June 25, 2009 8:14 AM Subject: Re: AeroElectric-List: Battery Proximity and mounting At 01:14 PM 6/24/2009, you wrote: Hi all, I am building an all-electric RV 8 with dual electronic ignition. I plan to use two P680 batteries. As I was sorting out where to put them, I had decided to strap them together and put them behind the firewall on the right. A building buddy asked the question, are they okay to be strapped together? Yes Are there any failure modes where one might fail and take out the other out at the same time? No. I thought I would ask the same question to the list and/or Bob. I really like the "change one out every annual" approach described in the Aeroelectric book, which is why I am going with two identical batteries. The new and improved section on batteries does not describe explosion or melt-down as a likely failure of RG batteries so I had thought that mounting them together and in the inside of the plane would be okay. In retrospect, I can see that I should have built in the mounting system before I riveted on the front bottom skin. As is, I am still scratching my head about where exactly to put them and how to property secure them to the airframe. I am very open to suggestions. Are you sure they want to go forward? A lot of my RV-8 builders had to put them in the tail for the purposes of satisfying CG limits. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 25, 2009
Wade, I don't know which model of the PP alternator you have, but if you look at the diagrams for the 60 Amp model (_http://www.plane-power.com/images/99%20-%209900B.pdf_ (http://www.plane-power.com/images/99%20-%209900B.pdf) ) there is an option for an alternator out warning light. Would that suffice for a low voltage warning? Actually, should the alternator fail, the alternator out light should appear before the low voltage warning. Stan Sutterfield _www.rv-8a.net_ (http://www.rv-8a.net) Inspected, Ready to fly Thank you for the comments. The Plane Power unit has over voltage protection but no low voltage warning features. My plan would be to defer that task to the AEC9005-101 (low voltage monitor) that connects to the main buss per diagram Z-13 AEC. If main buss voltage drops I don't believe that there would be anything to blame other than the primary alternator. In this event, you get the bright yellow LV warning light on the panel and you're shutting down any unnecessary equipment to see if that will temporarily remedy the issue. My next move would be to bring up the aux alternator and e-buss...at least I think that would be the proper protocol. **************Make your summer sizzle with fast and easy recipes for the grill. (http://food.aol.com/grilling?ncid=emlcntusfood00000006) ________________________________________________________________________________
Date: Jun 25, 2009
Michael, I know other builders have mounted batteries side-by-side with no problems. Also, they are mounted that way in my golf cart with no problems. In my opinion, if you can leave a small airspace between them (say 1/4 to 1/2 inch) then I would do that. I mounted one P680 in the lower portion of the front baggage and one behind the aft baggage. I put the aft one there for W&B and it turns out that worked great because my 8A is within CG limits at all weights and configurations even with a 3 blade prop and IO-390. Actually I put everything as far aft as I could. Building a bracket for the front battery was challenging. You can see what I did at _http://www.rv-8a.net/2005.htm_ (http://www.rv-8a.net/2005.htm) and scroll down to 16 Dec 05 and at _http://www.rv-8a.net/2006.htm_ (http://www.rv-8a.net/2006.htm) - scroll down to 20 Mar 06 and more photos scattered throughout _http://www.rv-8a.net/2008.htm_ (http://www.rv-8a.net/2008.htm) . I bought the steel jackets for the batteries and made those an integral part of each bracket. Regards, Stan Sutterfield Inspected, ready to fly I am building an all-electric RV 8 with dual electronic ignition. I plan to use two P680 batteries. As I was sorting out where to put them, I had decided to strap them together and put them behind the firewall on the right. A building buddy asked the question, are they okay to be strapped together? Are there any failure modes where one might fail and take out the other out at the same time? I thought I would ask the same question to the list and/or Bob. I really like the "change one out every annual" approach described in the Aeroelectric book, which is why I am going with two identical batteries. The new and improved section on batteries does not describe explosion or melt-down as a likely failure of RG batteries so I had thought that mounting them together and in the inside of the plane would be okay. In retrospect, I can see that I should have built in the mounting system before I riveted on the front bottom skin. As is, I am still scratching my head about where exactly to put them and how to property secure them to the airframe. I am very open to suggestions. Regards, Michael Wynn **************Make your summer sizzle with fast and easy recipes for the grill. (http://food.aol.com/grilling?ncid=emlcntusfood00000006) ________________________________________________________________________________
Date: Jun 25, 2009
At 11:58 AM 6/25/2009, you wrote: >Bob: > >Could you expand further on your answer? Are there any failure >modes or circumstances that would cause an RG battery to fail and >drag down the entire system, including taking the alternator off-line? Back in the bad ol' days the lead-acid battery was prone to various forms of leaking, outgassing, and cells that shorted when the residue of flaking plates piled up too high. RG battery failures are very benign . . . the device simply stops storing and then giving back electrical energy. They don't short like the flooded battery. However, in defense of flooded cell devices: Had we bothered to maintain them by swapping out an otherwise working battery when its TESTED capacity dropped below design goals for battery only operations, the vast majority of unhappy experiences with this venerable technology could have been prevented. The short answer is that there are no failure modes that cause a battery to take a system down assuming that it is not abused. Most abuse situations arise from other system failures such as extended over voltage conditions: http://aeroelectric.com/Pictures/Batteries/Odyssey_OV/Odyssey_OV_1.jpg http://aeroelectric.com/Pictures/Batteries/Internal_Fire/Picture%20001.jpg Given that you've embraced the new-battery-per-year philosophy for battery maintenance and assuming you plan to incorporate active notification of low voltage and automatic mitigation of over-voltage conditions, any concerns for battery failure are unwarranted. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Subject: Magneto Switch Rating
Date: Jun 25, 2009
Bob, I am having difficulty finding the electrical specifications required for toggle switches used as Mag switches. There is both a withstanding voltage and a current carrying capability that needs to be met, and I have a need to use miniature toggle switches rated at 5A/120VAC/28VDC for this function. Help appreciated. Thanks, Vern ----- Original Message ----- From: Robert L. Nuckolls, III To: aeroelectric-list(at)matronics.com Sent: Thursday, June 25, 2009 12:06 PM Subject: Re: AeroElectric-List: Battery Proximity and mounting At 11:58 AM 6/25/2009, you wrote: Bob: Could you expand further on your answer? Are there any failure modes or circumstances that would cause an RG battery to fail and drag down the entire system, including taking the alternator off-line? Back in the bad ol' days the lead-acid battery was prone to various forms of leaking, outgassing, and cells that shorted when the residue of flaking plates piled up too high. RG battery failures are very benign . . . the device simply stops storing and then giving back electrical energy. They don't short like the flooded battery. However, in defense of flooded cell devices: Had we bothered to maintain them by swapping out an otherwise working battery when its TESTED capacity dropped below design goals for battery only operations, the vast majority of unhappy experiences with this venerable technology could have been prevented. The short answer is that there are no failure modes that cause a battery to take a system down assuming that it is not abused. Most abuse situations arise from other system failures such as extended over voltage conditions: http://aeroelectric.com/Pictures/Batteries/Odyssey_OV/Odyssey_OV_1.jpg http://aeroelectric.com/Pictures/Batteries/Internal_Fire/Picture%20001.jp g Given that you've embraced the new-battery-per-year philosophy for battery maintenance and assuming you plan to incorporate active notification of low voltage and automatic mitigation of over-voltage conditions, any concerns for battery failure are unwarranted. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 25, 2009
My vote is for Plane Power, for value and design. The internally regulated model is simpler and has EXTRA over voltage protection, that has satisfied even the most knowledgeable expert. If you MUST have external regulation, Plane Power has that as well. I have talked to them many times and Customer service is good. You can buy through Vans Aircraft (also good customer service). - Plane Power now also makes a FAA/PMA voltage regulator for $169, if you decide to go that way.- Very nice, compact and no doubt lighter than the V1200. - I have been recommending the Transpo V1200 "Voyager" for years which cost less than $100. It is made for Ford heavy duty applications. - The main complaint of stock internally regulated alternators in the past,-potential of Over Voltage. External regulators can have OV as well but they are easier to-add on EXTRA OV protection. The Plane Power units eliminates this worry and have added the same-EXTRA-OV protection that is preferred by the-experts. So there is no need to hang another BOX-on the fire wall and run more wires to an external regulator. That can all be internal with an-internal regulator making a cleaner-installation. - B&C is more expensive and has no internal regulator choice. Nothing wrong with B&C fine- product, good customer care and external regulation is fine. The voltage- regulator they sell for $225 is over priced. You can do better for less than 1/3rd the cost (Transpo V1200). - So which one? Can't lose but the tie breaker is the Plane power. - Cheers George - - - - >From: "Wade Roe" <wroe1(at)dbtech.net> >Subject: AeroElectric-List: First choice alternator decision > >Gentleman, > >This topic was touched on earlier but I'm still not sure which route is >best regarding the primary alternator for my RV-7.- I am interested in >the best quality unit that will also coincide nicely with the AEC system >designs (particulary Z-13/8).- The options are as follows: > >--Plane Power 60A alternator with OV protection and internal >regulation, or > >--B&C L-60 matched up with an LR3C-14. > >This will be an all electric IFR plane with one battery and SD-8 aux >alternator. > >Any thoughts or comments would be appreciated. > >Thanks! Wade Roe EAA 557 Aeronca 7AC flying RV-7 in process =0A=0A=0A ________________________________________________________________________________
Date: Jun 25, 2009
Thanks for the insight Stan. It's my opinion that the alternator out light would in fact suffice. I did not see this as an option on the unit available from Vans. It's also my understanding that alternators, especially those manufactured for aviation are very reliable. I'm not sure what the average life span is. At this point I'm mostly concerned about having the best, most reliable option. As we speak, I am doing a load analysis to determine if I even need a 60 amp alternator. Maybe I can get away with a 40 amp and shed 2.5 lb. and $200. Wade Roe SOUTHERN CARBIDE TECHNOLOGIES, INC. 7739 Unity Road M&D Industrial Park Tuscaloosa, AL 35401 205-248-6700 205-248-6372 fax -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Speedy11(at)aol.com Sent: Thursday, June 25, 2009 12:46 PM Subject: AeroElectric-List: Re: First choice alternator decision Wade, I don't know which model of the PP alternator you have, but if you look at the diagrams for the 60 Amp model (http://www.plane-power.com/images/99%20-%209900B.pdf) there is an option for an alternator out warning light. Would that suffice for a low voltage warning? Actually, should the alternator fail, the alternator out light should appear before the low voltage warning. Stan Sutterfield www.rv-8a.net Inspected, Ready to fly Thank you for the comments. The Plane Power unit has over voltage protection but no low voltage warning features. My plan would be to defer that task to the AEC9005-101 (low voltage monitor) that connects to the main buss per diagram Z-13 AEC. If main buss voltage drops I don't believe that there would be anything to blame other than the primary alternator. In this event, you get the bright yellow LV warning light on the panel and you're shutting down any unnecessary equipment to see if that will temporarily remedy the issue. My next move would be to bring up the aux alternator and e-buss...at least I think that would be the proper protocol. _____ Make your summer sizzle with fast and easy <http://food.aol.com/grilling?ncid=emlcntusfood00000006> recipes for the grill. ________________________________________________________________________________
Date: Jun 25, 2009
Thanks George for the comments and insight. I'll investigate the V1200. Wade Roe EAA 557 Aeronca 7AC flying RV-7 in process -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of gmcjetpilot(at)yahoo.com Sent: Thursday, June 25, 2009 4:04 PM Subject: AeroElectric-List: Re: First choice alternator decision My vote is for Plane Power, for value and design. The internally regulated model is simpler and has EXTRA over voltage protection, that has satisfied even the most knowledgeable expert. If you MUST have external regulation, Plane Power has that as well. I have talked to them many times and Customer service is good. You can buy through Vans Aircraft (also good customer service). Plane Power now also makes a FAA/PMA voltage regulator for $169, if you decide to go that way. Very nice, compact and no doubt lighter than the V1200. I have been recommending the Transpo V1200 "Voyager" for years which cost less than $100. It is made for Ford heavy duty applications. The main complaint of stock internally regulated alternators in the past, potential of Over Voltage. External regulators can have OV as well but they are easier to add on EXTRA OV protection. The Plane Power units eliminates this worry and have added the same EXTRA OV protection that is preferred by the experts. So there is no need to hang another BOX on the fire wall and run more wires to an external regulator. That can all be internal with an internal regulator making a cleaner installation. B&C is more expensive and has no internal regulator choice. Nothing wrong with B&C fine product, good customer care and external regulation is fine. The voltage regulator they sell for $225 is over priced. You can do better for less than 1/3rd the cost (Transpo V1200). So which one? Can't lose but the tie breaker is the Plane power. Cheers George >From: "Wade Roe" < <http://us.mc431.mail.yahoo.com/mc/compose?to=wroe1@dbtech.net> wroe1(at)dbtech.net> >Subject: AeroElectric-List: First choice alternator decision > >Gentleman, > >This topic was touched on earlier but I'm still not sure which route is >best regarding the primary alternator for my RV-7. I am interested in >the best quality unit that will also coincide nicely with the AEC system >designs (particulary Z-13/8). The options are as follows: > >--Plane Power 60A alternator with OV protection and internal >regulation, or > >--B&C L-60 matched up with an LR3C-14. > >This will be an all electric IFR plane with one battery and SD-8 aux >alternator. > >Any thoughts or comments would be appreciated. > >Thanks! Wade Roe EAA 557 Aeronca 7AC flying RV-7 in process ________________________________________________________________________________
Date: Jun 25, 2009
Bob,One of the links below (http://www.rv-8a.net/2005.htm) shows the Tempo marine or race car type battery switches being used in lieu of battery contractors. This seems like a very good idea, i.e. less cost, less weight and almost absolute reliability (assuming you don't loss the keys). Your comments? On Thu, Jun 25, 2009 at 13:02, wrote: > Michael, > I know other builders have mounted batteries side-by-side with no > problems. Also, they are mounted that way in my golf cart with no > problems. In my opinion, if you can leave a small airspace between them > (say 1/4 to 1/2 inch) then I would do that. > I mounted one P680 in the lower portion of the front baggage and one behind > the aft baggage. I put the aft one there for W&B and it turns out that > worked great because my 8A is within CG limits at all weights and > configurations even with a 3 blade prop and IO-390. Actually I put > everything as far aft as I could. > Building a bracket for the front battery was challenging. You can see what > I did at http://www.rv-8a.net/2005.htm and scroll down to 16 Dec 05 and at > http://www.rv-8a.net/2006.htm - scroll down to 20 Mar 06 and more photos > scattered throughout http://www.rv-8a.net/2008.htm. I bought the steel > jackets for the batteries and made those an integral part of each bracket. > Regards, > Stan Sutterfield > Inspected, ready to fly > > > I am building an all-electric RV 8 with dual electronic ignition. I plan > to use two P680 batteries. As I was sorting out where to put them, I had > decided to strap them together and put them behind the firewall on the > right. > > A building buddy asked the question, are they okay to be strapped > together? Are there any failure modes where one might fail and take out > the other > > out at the same time? > > I thought I would ask the same question to the list and/or Bob. I really > like the "change one out every annual" approach described in the > Aeroelectric book, which is why I am going with two identical batteries. > The > new and > improved section on batteries does not describe explosion or melt-down as > a likely failure of RG batteries so I had thought that mounting them > together and in the inside of the plane would be okay. > > In retrospect, I can see that I should have built in the mounting system > before I riveted on the front bottom skin. As is, I am still scratching > my > head about where exactly to put them and how to property secure them to > the > airframe. I am very open to suggestions. > > Regards, > > Michael Wynn > > > ------------------------------ > Make your summer sizzle with fast and easy recipes<http://food.aol.com/grilling?ncid=emlcntusfood00000006>for the grill. > > * > > * > > ________________________________________________________________________________
Date: Jun 25, 2009
Subject: Re: Alternator N-Terminal
At 10:49 AM 6/25/2009, you wrote: > > >Hi there. I'm posting this on behalf of a reader of a newsletter I >write. Any help you can give this gentleman would be appreciated: > >"Have fitted a Bosch externally regulated alternator which has >terminals marked F, E, and N. I was advised that when the >alternator is giving the correct output there should be 7V >potertial at N which I have routed through a relay to extinguish an >LED. When the engine is ticking over at 1000 revs the LED is >flickering on and off but the battery shows 14 volts. Have I got the >principle wrong? what is the purpose of terminal N? " To understand the answer to your question we need to go back about 42 years to when the first alternators (Ford derivatives) were being bolted to airplanes for the first time. The regulators were stock automotive, 2-relay, electro-mechanical devices shown in this figure . . . http://www.aeroelectric.com/Pictures/Regulators/Legacy_EM_Regulator_(Ford).pdf Terminal N is the center tap on a "Y-wound" stator. Yes, it has an output nominally 1/2 that of the B terminal. It was originally used to sense the fact that the alternator was being turned by an engine and was ready to produce power to the vehicle's systems. A field control relay was powered from the N terminal as shown in the attendant drawing. If the altenrator control switch was open, field excitation through the alternator fail light was zero. . . OR . . . if the alternator was not turning, then N-terminal voltage was zero. If the alternator is turning and the control switch is closed, then a small current (100 mA or so) places a small excitation current on the alternator's field terminal through the normally closed contacts of the v-reg relay. This causes the stator windings to produce voltage that is essentially unloaded (open circuit) until high enough to begin to conduct the diodes and deliver energy to the system. In this very lightly loaded state, the N-terminal voltage rises and energizes the field control relay. When the field relay closes, full bus voltage is available through a low impedance source and causes the alternator to wake up and power the ship's systems. If the engine is stopped, or a belt breaks, N-terminal volts goes to zero. Field control relay drops out removing a short across the ALT WARN lamp causing it to illuminate assuming that the control switch is still closed. This opens the high current loop for supplying alternator field current thus stopping internal generation of heat in the alternator and depleting the battery with no-value-added load of field current. I don't recall that Cessna ever used the N-terminal or field control relay for this purpose. We chose to apply bus voltage directly to the regulator's "S" terminal through the alternator control switch. In later years, the OV control module was placed in series with the field control relay as shown in . . . http://www.aeroelectric.com/Pictures/Schematics/Cessna_OVModule.gif Years later in the employ of Electro-Mech, I was designer of some rather crude voltage level sensors that watched the N-terminal voltage with the idea that it was good place to detect an alternator failure. We supplied these modules to Cessna and Beech. After working this industry for several years, I discovered that there were failure modes that would cripple the alternator's ability to power the system that COULD NOT BE DETECTED by watching the N-terminal. I recommended and developed a low-voltage warning module that was adopted by Beech. I don't recall if we ever sold any to Cessna. The short answer to your question: I recommend that you ignore the N-terminal of your alternator and install some form of active notification of low voltage set up to warn for any condition where bus voltage drops below 13.0 volts. This is one of several solutions to the low voltage warning task. http://www.aeroelectric.com/DIY/LV_Warn_Fab_and_Install.pdf Bob . . . ________________________________________________________________________________
Date: Jun 25, 2009
Bob: Thanks, that's good to hear. If I could take this one step further for the RG batteries: If there is a zero probability of battery failure (assuming it's not abused and maintenance benefits aside), strictly from the battery's contribution to system reliability, is there is any benefit gained from a dual battery as compared to single battery installation? Thanks ----- Original Message ----- From: Robert L. Nuckolls, III To: aeroelectric-list(at)matronics.com Sent: Thursday, June 25, 2009 12:06 PM Subject: Re: AeroElectric-List: Battery Proximity and mounting At 11:58 AM 6/25/2009, you wrote: Bob: Could you expand further on your answer? Are there any failure modes or circumstances that would cause an RG battery to fail and drag down the entire system, including taking the alternator off-line? Back in the bad ol' days the lead-acid battery was prone to various forms of leaking, outgassing, and cells that shorted when the residue of flaking plates piled up too high. RG battery failures are very benign . . . the device simply stops storing and then giving back electrical energy. They don't short like the flooded battery. However, in defense of flooded cell devices: Had we bothered to maintain them by swapping out an otherwise working battery when its TESTED capacity dropped below design goals for battery only operations, the vast majority of unhappy experiences with this venerable technology could have been prevented. The short answer is that there are no failure modes that cause a battery to take a system down assuming that it is not abused. Most abuse situations arise from other system failures such as extended over voltage conditions: http://aeroelectric.com/Pictures/Batteries/Odyssey_OV/Odyssey_OV_1.jpg http://aeroelectric.com/Pictures/Batteries/Internal_Fire/Picture%20001.jp g Given that you've embraced the new-battery-per-year philosophy for battery maintenance and assuming you plan to incorporate active notification of low voltage and automatic mitigation of over-voltage conditions, any concerns for battery failure are unwarranted. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 25, 2009
Re: Battery Proximity and mounting From: James Quinn <jquinn3(at)gmail.com> Bob, One of the links below (<http://www.rv-8a.net/2005.htm>http://www.rv-8a.net/2005.htm) shows the Tempo marine or race car type battery switches being used in lieu of battery contractors. This seems like a very good idea, i.e. less cost, less weight and almost absolute reliability (assuming you don't loss the keys). Your comments? A number of airplanes (including type certified) have used battery switches in lieu of contactors. A TriPacer I used to fly had manual battery switch AND a high current, manually operated starter switch. No contactors at all. So there's nothing particularly unusual about the idea. A decision to substitute manual switches for contactors needs to meet design goals for convenient accessibility under all flight conditions: Both normal and those which anticipate un-intended arrivals with the earth. Recall that the battery switch is designed make the ship's wiring max-cold when off. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 25, 2009
I think if you read the response, he is not saying that there is a zero probability of battery failure, just essentially a zero probability of a failure that will also bring down the whole system. I.e. the battery could fail so that it no longer can supply current, but this failure would have no effect on the rest of the system if you still had a second battery. Obviously, if you have only one battery and it stops supplying current that you need then you have a problem. Dick Flagstone(at)cox.net wrote: > Bob: > > Thanks, that's good to hear. If I could take this one step further > for the RG batteries: > > If there is a zero probability of battery failure (assuming it's not > abused and maintenance benefits aside), strictly from the battery's > contribution to system reliability, is there is any benefit gained > from a dual battery as compared to single battery installation? > > Thanks > > > ----- Original Message ----- > *From:* Robert L. Nuckolls, III > > *To:* aeroelectric-list(at)matronics.com > > *Sent:* Thursday, June 25, 2009 12:06 PM > *Subject:* Re: AeroElectric-List: Battery Proximity and mounting > > At 11:58 AM 6/25/2009, you wrote: >> Bob: >> >> Could you expand further on your answer? Are there any failure >> modes or circumstances that would cause an RG battery to fail and >> drag down the entire system, including taking the alternator >> off-line? > > Back in the bad ol' days the lead-acid battery > was prone to various forms of leaking, outgassing, > and cells that shorted when the residue of flaking > plates piled up too high. > > RG battery failures are very benign . . . the device > simply stops storing and then giving back electrical > energy. They don't short like the flooded battery. > However, in defense of flooded cell devices: Had we > bothered to maintain them by swapping out an otherwise > working battery when its TESTED capacity dropped > below design goals for battery only operations, > the vast majority of unhappy experiences with this > venerable technology could have been prevented. > > The short answer is that there are no failure modes > that cause a battery to take a system down assuming > that it is not abused. Most abuse situations arise > from other system failures such as extended over > voltage conditions: > > http://aeroelectric.com/Pictures/Batteries/Odyssey_OV/Odyssey_OV_1.jpg > > > http://aeroelectric.com/Pictures/Batteries/Internal_Fire/Picture%20001.jpg > > > Given that you've embraced the new-battery-per-year > philosophy for battery maintenance and assuming you > plan to incorporate active notification of low voltage > and automatic mitigation of over-voltage conditions, > any concerns for battery failure are unwarranted. > > Bob . . . > > --------------------------------------- > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > --------------------------------------- > > * > > href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > * > > * > > > * ________________________________________________________________________________
Date: Jun 25, 2009
From: "Wade Roe" <wroe1(at)dbtech.net> Subject: RE: AeroElectric-List: Re: First choice alternator decision Date: Thu, 25 Jun 2009 16:22:13 -0500 Thanks for the insight Stan. It's my opinion that the alternator out light would in fact suffice. I did not see this as an option on the unit available from Vans. It's also my understanding that alternators, especially those manufactured for aviation are very reliable. I'm not sure what the average life span is. At this point I'm mostly concerned about having the best, most reliable option. Your electrical SYSTEM can offer satisfactory 'reliability' in spite of individual components failure. This is the cornerstone of failure tolerant design. It's far more useful to design and fabricate with a foregone conclusion that any part can and will at some time fail in flight. Further, price of a component is not necessarily directly related to expected service life. Based on anecdotal observation, most failures of an alternator installation are unrelated to the physical alternator. The only mechanical wearing parts of an alternator are bearings-and- brushes-on-slip-rings. There are thermal service-life- limiting stresses that influence diodes, integrated circuits, bond-wire joints, etc. Generally speaking, it's not difficult to fabricate a belt driven alternator with a service life that equals that of the engine. But poor choice of attach hardware, wiring supports can be equally crippling of alternator performance. The purpose of this little dissertation is to suggest that much of what's reported as an "alternator problem" has nothing to do with the design or fabricating processes in the alternator itself. Given that absolute "quality" in terms of service life cannot be absolutely predicted, I'll suggest it's more useful to use what ever combination of products is most attractive for price, weight, ease of installation while mitigating reliability worries with crafty failure tolerant design. Understand that the "alternator out" light feature of an internally regulated alternator is operated from the same slab of silicon as the voltage regulator. See: http://aeroelectric.com/Mfgr_Data/Semiconductors/MC33092A_Block_Diagram.pdf This drawing is a somewhat dated (but I think exemplar) architecture for an internally regulated alternator. Note that the lamp circuit is driven from the integrated circuit chip. The ability of this lamp to annunciate ALL forms of alternator failure is not known. Further, since the warning functions share hardware and space with controlling functions, it does not conform with design goals for most aircraft systems that call for separation of control and failure monitoring/annunciation. Observance of those design goals calls for active notification of low voltage that is independent of the alternator and it's regulator. This concept is common to many TC aircraft and is suggested by illustration throughout the Z-figures. Bob . . . ________________________________________________________________________________
Date: Jun 25, 2009
At 05:19 PM 6/25/2009, you wrote: Bob: Thanks, that's good to hear. If I could take this one step further for the RG batteries: If there is a zero probability of battery failure (assuming it's not abused and maintenance benefits aside), strictly from the battery's contribution to system reliability, is there is any benefit gained from a dual battery as compared to single battery installation? The reasons for dual batteries are few and specific. Z-14 calls for dual batteries because you have dual systems. If you have one alternator and an electrically dependent engine, then Z-19 suggests a means by which an alternator failure can be responded to by having engine and instruments supported by separate batteries while operating in the endurance mode. We've also discussed appliances not designed to live in the real world of airplanes and require support of a battery that is independent of the cranking battery. I neglected ask why you were considering two batteries. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 25, 2009
Bob: Are any of those reasons for Z-14 as a result of the design and performance of the RG batteries by themselves, or are they the result of other potential failures extraneous to the batteries? If any of the reasons are a result of the batteries, what are they and what are the probabilities of them happening? Another group member stated that "the battery could fail so that it can no longer supply current". He may be correct that I misunderstood your previous answer. I would consider that within the scope of my previous question, in that it seems to me that if a battery were to suddenly be unable to supply current, it would be the result of some sort of internal failure. If that in fact can happen, what are the circumstances that would cause that, and what are the probabilities of it happening? I intend to use to use two batteries for the maintenance benefits you outline in your book and for the additional cranking power. Right now I'm just trying to get a clear understanding of the RG battery's reliability and performance limitations. Thanks ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Sent: Thursday, June 25, 2009 4:51 PM Subject: Re: AeroElectric-List: Battery Proximity and mounting > > > > At 05:19 PM 6/25/2009, you wrote: > Bob: > > Thanks, that's good to hear. If I could take this one step further for > the RG batteries: > > If there is a zero probability of battery failure (assuming it's not > abused and maintenance benefits aside), strictly from the battery's > contribution to system reliability, is there is any benefit gained from a > dual battery as compared to single battery installation? > > The reasons for dual batteries are few and specific. > Z-14 calls for dual batteries because you have dual > systems. If you have one alternator and an electrically > dependent engine, then Z-19 suggests a means by which > an alternator failure can be responded to by having > engine and instruments supported by separate batteries > while operating in the endurance mode. > > We've also discussed appliances not designed to live > in the real world of airplanes and require support > of a battery that is independent of the cranking > battery. > > I neglected ask why you were considering two batteries. > > Bob . . . > > --------------------------------------- > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > --------------------------------------- > > > ________________________________________________________________________________
Date: Jun 25, 2009
First off, thank you all for the replies and the group think. My main reason for two batteries is the dual electronic ignition. Claus at Lightspeed strongly suggests a back-up battery if you are completely electrically dependent. I have read the Aeroelectric book through several times. I suppose that I may be in overkill mode, but I have a main and back-up alternator (B&C 60 Amp and 20 amp). While I have not yet done the wiring or really completed the drawings, I was thinking strongly of a Vertical Power VP 100 around a system that is basically a Z12 with a second battery. The VP will not really support a Z14 style architecture. If I am going to have a second battery per the ignition system's manufacturers recommendation, it seems reasonable to use identical batteries and plan a yearly rotation. Is this complete overkill? Adding a cross feed connector gives you the opportunity to have additional cranking power in case of starting difficulties. Thoughts? Michael Wynn RV 8 San Ramon In a message dated 6/25/2009 4:56:55 P.M. Pacific Daylight Time, nuckolls.bob(at)aeroelectric.com writes: --> AeroElectric-List message posted by: "Robert L. Nuckolls, III" At 05:19 PM 6/25/2009, you wrote: Bob: Thanks, that's good to hear. If I could take this one step further for the RG batteries: If there is a zero probability of battery failure (assuming it's not abused and maintenance benefits aside), strictly from the battery's contribution to system reliability, is there is any benefit gained from a dual battery as compared to single battery installation? The reasons for dual batteries are few and specific. Z-14 calls for dual batteries because you have dual systems. If you have one alternator and an electrically dependent engine, then Z-19 suggests a means by which an alternator failure can be responded to by having engine and instruments supported by separate batteries while operating in the endurance mode. We've also discussed appliances not designed to live in the real world of airplanes and require support of a battery that is independent of the cranking battery. I neglected ask why you were considering two batteries. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- **************Shop Popular Dell Laptops now starting at $349! bleclick.net%2Fclk%3B215910283%3B38350812%3Ba) ________________________________________________________________________________
Date: Jun 25, 2009
Yup, but you'll need to turn one of the switches over when you want to use it to switch the ei. The mag switch closes to turn the mag off, but the ei switch will close to turn on. You want the "up" position to be on. Pax, Ed Holyoke Robert L. Nuckolls, III wrote: > > > At 08:58 AM 6/23/2009, you wrote: >> >> My plan is to fly off several hours in the RV-7 using two Slick mags >> before transitioning over to a one mag and Plasma II plus system. With >> this in mind, what is the best way to spec-out and set-up the ignition >> switches? I am referencing Z-13/8 AEC as the basis for my design. The >> Z-13 diagram shows an s700-1-3 and a s700-2-10. Perhaps a s700-2-50 >> would make more sense. > > A pair of S700-1-3 switches will do fine for both the pair > of mags and for the final configuration. > > > Bob . . . > > --------------------------------------- > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > --------------------------------------- > > ________________________________________________________________________________
Date: Jun 25, 2009
At 07:59 PM 6/25/2009, you wrote: > >Bob: > >Are any of those reasons for Z-14 as a result of the design and >performance of the RG batteries by themselves, or are they the >result of other potential failures extraneous to the batteries? If >any of the reasons are a result of the batteries, what are they and >what are the probabilities of them happening? Z-14 is the "mother of all electrical systems" intended to address the design goals for probably less than 1% of the OBAM aircraft fleet. This would be the Lancair or Glasair with fully redundant IFR panels on both pilot seats wherein the aircraft's missions often include two rated pilots and a high percentage of flight in IMC. Batteries swapped out when their battery-only endurance capabilities drop below 2+ hours are still cranking and engine nicely . . . and a battery this capable is exceedingly unlikely to go south on you en route to aunt Martha's. For my purposes and for the purposes of the majority of the OBAM fleet, Z-13/8 with a battery maintenance program offers SYSTEM reliability that is head and shoulders above the majority of TC fleet up to and including some twin turbine powered aircraft. >Another group member stated that "the battery could fail so that it >can no longer supply current". He may be correct that I >misunderstood your previous answer. I would consider that within >the scope of my previous question, in that it seems to me that if a >battery were to suddenly be unable to supply current, it would be >the result of some sort of internal failure. If that in fact can >happen, what are the circumstances that would cause that, and what >are the probabilities of it happening? Can't put a number on "probability" and if I could, it probably wouldn't be significant to you. The point about battery technology and service life is that hundreds of thousands of airplanes have launched into IFR with a single generator and single flooded battery with a high probability of a now-sweat termination of the flight. The demonstrated level of system reliability was such that many pilots exploited the capability with little concern for system failure. The majority of accidents were (and still are) seeded by poor judgement and/or conditions beyond control of the pilot that were not related to system reliability. Now we can easily install two engine driven power sources to charge a well maintained, very user-friendly RG battery. A combination that reduces risks of power starvation to still lower numbers. If you're willing to jump in a rented C182 and launch into the grey with equipment certificated 30 years ago, then getting into your RV fitted with Z-13/8 + RG battery has to be more comfortable yet. Bottom line is that with either airplane, your risk for experiencing an unhappy day in the cockpit has more to do with what's between your ears than with what's under the cowl. >I intend to use to use two batteries for the maintenance benefits >you outline in your book and for the additional cranking power. Dual batteries are indicated only for those special conditions I cited earlier. If you don't have those configurations . . . dual batteries are only a cost, volume and weight burden on your project. >Right now I'm just trying to get a clear understanding of the RG >battery's reliability and performance limitations. If all you want is more cranking power, install ONE bigger battery. But cranking power of RG batteries is so much better than their flooded counterparts that we're installing systems like Z-13/8 with a small fraction of the hardware weight in a 1975 Cessna 182. Unless you have operational features that encourage dual batteries, please consider installing a single 17 to 18 a.h. RG battery. You can always up-size later. But consider leaving 16 pounds of hardware on the ground until you KNOW you need it. 16 extra pounds of baggage or fuel is USEFUL . . . 16 unnecessary pounds of battery is . . . well . . . you know. I'm betting you'll never need it. Bob . . . ________________________________________________________________________________
Date: Jun 25, 2009
At 09:29 PM 6/25/2009, you wrote: First off, thank you all for the replies and the group think. My main reason for two batteries is the dual electronic ignition. Claus at Lightspeed strongly suggests a back-up battery if you are completely electrically dependent. I have read the Aeroelectric book through several times. I suppose that I may be in overkill mode, but I have a main and back-up alternator (B&C 60 Amp and 20 amp). While I have not yet done the wiring or really completed the drawings, I was thinking strongly of a Vertical Power VP 100 around a system that is basically a Z12 with a second battery. The VP will not really support a Z14 style architecture. If I am going to have a second battery per the ignition system's manufacturers recommendation, it seems reasonable to use identical batteries and plan a yearly rotation. Is this complete overkill? Adding a cross feed connector gives you the opportunity to have additional cranking power in case of starting difficulties. Don't know about "complete" overkill . . . but it's in the 90th percentile. Z-13/8 and one battery with EACH ignition enjoying it's own fuse on the battery bus is a very rational approach. Keep in mind that your engine will run fine on ONE ignition. In fact, If you find yourself running from the e-bus on either Z-11 or Z-13/8, I'd shut off one of the two ignition systems and use the power for something more useful. I'm working an accident case right now where the owner/pilot got wrapped around the "reliability axle" and designed a dual ignition power distribution system guaranteed to fail both ignitions . . . and it did. Save your money for an extra GPS or perhaps dual wing-levelers. Z-13/8 will keep them all humming at much less cost and weight in your airplane . . . and easier to install too. Better yet, the extra dollars buys stuff that ADDS value to the airplane. Bob . . . ________________________________________________________________________________
Date: Jun 25, 2009
Subject: Re: Dual mags now...one Plasma II plus later
At 11:58 PM 6/25/2009, you wrote: > >Yup, but you'll need to turn one of the switches over when you want >to use it to switch the ei. The mag switch closes to turn the mag >off, but the ei switch will close to turn on. You want the "up" >position to be on. No, the 1-3 switches are single pole, two position switches. They function for either breaking power to an electronic ignition -OR- grounding a magneto by simply moving a wire to the opposite terminal. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 26, 2009
Subject: Complex aircraft NTSB report
All, I found this link on the rotary engine news group. It's a thorough NTSB report about a complex engine/electrical installation that the builder/pilot was unwilling and unprepared to finish correctly. http://www.ntsb.gov/ntsb/brief2.asp?ev_id 071120X01821&ntsbno=NYC08FA023&akey=1 Sam ________________________________________________________________________________
Date: Jun 26, 2009
Bob, In the "Battery Proximity and mounting" thread speaking of Z-14 you say: Z-14 is the "mother of all electrical systems" intended to address the design goals for probably less than 1% of the OBAM aircraft fleet. This would be the Lancair or Glasair with fully redundant IFR panels on both pilot seats wherein the aircraft's missions often include two rated pilots and a high percentage of flight in IMC. ... Z-13/8 will keep them all humming at much less cost and weight in your airplane . . . and easier to install too. In the "First choice alternator decision" thread you say: The purpose of this little dissertation is to suggest that much of what's reported as an "alternator problem" has nothing to do with the design or fabricating processes in the alternator itself. I have decided on Z-14 to support my electrically dependant engine because of your second statement! I'm not concerned with battery failure, I'm concerned with my ability to assemble a set of components, few as they are, that will not fail in any circumstance. The Z-14 design is more reliable than Z-13/8 by a significant margin because all of us do not have your capability to assemble the compenents. Two battery ground connections and two battery plus connections are a great sleeping aid to me. I'm using smaller batteries so the weight penalty is only a few pounds. Regards, Bob Lee N52BL KR2 Suwanee, GA USA 92% done only 67% to go! ________________________________________________________________________________
Date: Jun 26, 2009
Subject: Re: First choice alternator decision
In hindsight, I, too, should have given more consideration to the 40 A unit. As I was building, my thought was that more power was better. While that is basically true, during my building process, new technology low power replacements for traditionally high power gadgets became available - such as HIDs for incandescent landing lights, LEDs for position, taxi (landing?) lights and interior lights, low power EFIS and engine monitors. As a result, my power needs are dramatically less than what the alternator can produce. I guess the PP 60A will just be loafing. Stan Sutterfield As we speak, I am doing a load analysis to determine if I even need a 60 amp alternator. Maybe I can get away with a 40 amp and shed 2.5 lb. and $200. **************Make your summer sizzle with fast and easy recipes for the grill. (http://food.aol.com/grilling?ncid=emlcntusfood00000006) ________________________________________________________________________________
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
Date: Jun 26, 2009
Hmm..Yes the PP 60A would be hard pressed to find any real work to do..But then its a very small lightweight unit so I don't see that it matters. Is t here a 40A unit with the same reliability and shutdown features that is 2.5 lb less than the Plane power? Frank ________________________________ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectr ic-list-server(at)matronics.com] On Behalf Of Speedy11(at)aol.com Sent: Friday, June 26, 2009 7:04 AM Subject: AeroElectric-List: Re: First choice alternator decision In hindsight, I, too, should have given more consideration to the 40 A unit . As I was building, my thought was that more power was better. While tha t is basically true, during my building process, new technology low power r eplacements for traditionally high power gadgets became available - such as HIDs for incandescent landing lights, LEDs for position, taxi (landing?) l ights and interior lights, low power EFIS and engine monitors. As a result , my power needs are dramatically less than what the alternator can produce . I guess the PP 60A will just be loafing. Stan Sutterfield As we speak, I am doing a load analysis to determine if I even need a 60 amp alternator. Maybe I can get away with a 40 amp and shed 2.5 lb. and $200. ________________________________ Make your summer sizzle with fast and easy recipes<http://food.aol.com/gril ling?ncid=emlcntusfood00000006> for the grill. ________________________________________________________________________________
Date: Jun 26, 2009
I have decided on Z-14 to support my electrically dependant engine because of your second statement! I'm not concerned with battery failure, I'm concerned with my ability to assemble a set of components, few as they are, that will not fail in any circumstance. NASA cant even do this. Why do you burden yourself with this goal? The Z-14 design is more reliable than Z-13/8 by a significant margin because all of us do not have your capability to assemble the components. Two battery ground connections and two battery plus connections are a great sleeping aid to me. I'm using smaller batteries so the weight penalty is only a few pounds. Z-14? In a KR2? Can we talk about this some more? "Reliability" is generally a measure of component failure rates. Any component taken by itself can be analyzed for the purpose of predicting a failure rate usually expressed in "failures per quantity of service hours". For disciplines that require exceedingly high reliability rates we call out tested and perhaps even screened parts. These have demonstrated failure rates even if those numbers are deduced only in the lab. System reliability is another matter entirely. The poor pilot's definition of a reliable system is that which "never causes one to break a sweat." Systems that occasionally experience a component failure can still be very reliable. This is true when the operator doesn't find it necessary to do more than have the failure repaired before the next flight. This is what keeps FBO's in business. None of has enough money to craft a system with established reliability components. Any of us can craft a sweat-free system from hardware store components by application of simple design goals. System reliability is strongly affected by assembly process which is in turn influenced by worker skill and knowledge. You've expressed some concerns for your own skill levels. May I suggest that a minimalist failure-tolerant system skillfully assembled is far better than layers of redundancy assembled with poorly conceived motives or lack of understanding. If your concerns for understanding are properly founded, I'll suggest that assembling Z-14 with poor skills is NOT more reliable than Z-13/8 assembled with nominal skills. If you were assembling this airplane on a deserted island with corked bottles as your only communications mode, your worries about understanding would be justified. However, you are a member of a society of fellow travelers with a huge skill-set and world wide verbal and visual communications network with nearly instant functionality. As a member of this List for the past 6 years or so, your lack of confidence for getting it all put together right the first time is curious. I'd be pleased to know how we fell short of addressing your need for input. I'll encourage you to stand back, take a deep breath and join us in a discussion of your design goals and a plan for getting them implemented with a minimum of cost weight and complexity. It would be a shame to burden a KR-2 with many pounds of hardware that steals payload and hampers performance. This is particularly true if the added burdens are no more than a band-aid on your perceptions of understanding. Understanding is what the AeroElectric-List is all about. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 26, 2009
Subject: Re: Magneto Switch Rating
At 03:47 PM 6/25/2009, you wrote: >Bob, I am having difficulty finding the electrical specifications >required for toggle switches used as Mag switches. > >There is both a withstanding voltage and a current carrying >capability that needs to be met, and I have a need to use miniature >toggle switches rated at 5A/120VAC/28VDC for this function. > >Help appreciated. > >Thanks, Vern Hmmm . . . I've never seen a rating requirement for mag switches. Can you give me a link or send me a copy? I've seen a host of switch styles used as magneto switches where it was very unlikely that the installer was cognizant of any recommendations/requirements. I was thinking that this airplane . . . http://aeroelectric.com/Pictures/Switches/miniswitches.jpg had miniature mag switches too but they don't show in the picture. I'm not aware of any successful application of miniature toggles for magnetos. Some years ago I had an inquiry about using a miniature rocker switch. http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=SW322-ND I suggested that the builder hook the two sides of a two-pole switch in series to effectively double the gap for open contacts (mag operating). I think he did this and I've not heard back. I'll suggest the same thing for what ever switch you plan to try. Go with double-pole switch an use contacts in series to short the mag in the OFF condition. I'm 99% sure that you'll find this approach satisfactory. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 26, 2009
Subject: Re: Complex aircraft NTSB report
At 06:50 AM 6/26/2009, you wrote: >All, > >I found this link on the rotary engine news group. It's a thorough >NTSB report about a complex engine/electrical installation that the >builder/pilot was unwilling and unprepared to finish correctly. > ><http://www.ntsb.gov/ntsb/brief2.asp?ev_id 071120X01821&ntsbno=NYC08FA023&akey=1>http://www.ntsb.gov/ntsb/brief2.asp?ev_id 071120X01821&ntsbno=NYC08FA023&akey=1 I've had several private links to this posting. Very sad. It's an unfortunate fact of the human condition that rational thought processes and understanding of simple-ideas can be so terribly diminished by hazardous behaviors. Let us strive to watch out for each other. Don't be afraid to speak up when we perceive that somebody's project is not going forward with the best goals and processes we know how to do. Its far better to risk getting some builder pissed off at you than to be thinking "I SHOULD have told you so" while reading the NTSB report. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 26, 2009
Absolutely..This was so sad and many of us on the Vans airforce forum kinda saw it coming. I get slammed almost daily for my choice to use electric fuel pumps with no mechanical backup from folks who are not engineers and don't understand my system. You know what, I would rather recieve a thousand emails of uninformed disse nt for the potential of seeing one nugget of information that is maybe a fl aw in my system. None of us are so well informed that we can't learn something. The accident airplane had a an Eggenfelner subaru conversion installed I be lieve. Cheers Frank ________________________________ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectr ic-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Friday, June 26, 2009 10:17 AM Subject: Re: AeroElectric-List: Complex aircraft NTSB report At 06:50 AM 6/26/2009, you wrote: All, I found this link on the rotary engine news group. It's a thorough NTSB re port about a complex engine/electrical installation that the builder/pilot was unwilling and unprepared to finish correctly. http://www.ntsb.gov/ntsb/brief2.asp?ev_id 071120X01821&ntsbno=NYC08FA 023&akey=1 I've had several private links to this posting. Very sad. It's an unfortunate fact of the human condition that rational thought processes and understanding of simple-ideas can be so terribly diminished by hazardous behaviors. ________________________________________________________________________________
Subject: Re: Battery Proximity and mounting
Date: Jun 26, 2009
Bob: A complete non answer. Lot of words...no relevance. On page 17-11 (rev11) you state that "RG battery reliability and performance supplemented with good preventative maintenance drives probability of gross battery failure to zero" You don't say "near zero", "close to zero", "approaching zero", or any such thing. To claim anything has a zero probability of failure is a pretty bold statement to make. Further, judging from the general tone of your writing style, there's as much a chance of that statement being rhetoric as anything else. When I first read your book a couple years ago, I tried to get some clarification from you on that statement. At first, when I asked directly, you simply didn't address the question. I gave up on that approach. Since then, whenever other group members have touched on the issue, I have attempted, by asking questions in different ways, to get you to explain further the meaning of your statement. In response to the inquiries (mine and others) on this subject, you either: 1. Don't answer. 2. Provide theoretical fluffery 3. Answer questions that aren't asked 4. Introduce extraneous issues 5. Claim its beyond understanding At first, I thought I was close to getting some answers this time, but as before, the answers degraded into one or more of the above categories. I really don't understand why you can't give a full and complete explanation of what you mean by "gross battery failure" and "zero probability" in some meaningful and understandable way. After all, its your statement, you should be able to substantiate it. But, that's apparently not the case. I've noticed that you seem to follow that pattern on a few other issues as well. Anyway, I'm tired of trying to coax an explanation out of you so I won't bring up it up again. I'll just assume the statement was the result of your writing style and not to be taken literally. In any regard, I don't need the information now, and when I do, I'll get it from other sources. Thanks ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Sent: Thursday, June 25, 2009 9:21 PM Subject: Re: AeroElectric-List: Battery Proximity and mounting > > > At 07:59 PM 6/25/2009, you wrote: >> >>Bob: >> >>Are any of those reasons for Z-14 as a result of the design and >>performance of the RG batteries by themselves, or are they the result of >>other potential failures extraneous to the batteries? If any of the >>reasons are a result of the batteries, what are they and what are the >>probabilities of them happening? > > Z-14 is the "mother of all electrical systems" intended > to address the design goals for probably less than 1% > of the OBAM aircraft fleet. This would be the Lancair > or Glasair with fully redundant IFR panels on both > pilot seats wherein the aircraft's missions often > include two rated pilots and a high percentage of > flight in IMC. > > Batteries swapped out when their battery-only endurance > capabilities drop below 2+ hours are still cranking > and engine nicely . . . and a battery this capable is > exceedingly unlikely to go south on you en route to > aunt Martha's. > > For my purposes and for the purposes of the majority > of the OBAM fleet, Z-13/8 with a battery maintenance > program offers SYSTEM reliability that is head and > shoulders above the majority of TC fleet up to and > including some twin turbine powered aircraft. > >>Another group member stated that "the battery could fail so that it can no >>longer supply current". He may be correct that I misunderstood your >>previous answer. I would consider that within the scope of my previous >>question, in that it seems to me that if a battery were to suddenly be >>unable to supply current, it would be the result of some sort of internal >>failure. If that in fact can happen, what are the circumstances that >>would cause that, and what are the probabilities of it happening? > > Can't put a number on "probability" and if I > could, it probably wouldn't be significant to > you. The point about battery technology and > service life is that hundreds of thousands of > airplanes have launched into IFR with a single generator > and single flooded battery with a high probability > of a now-sweat termination of the flight. The > demonstrated level of system reliability was such > that many pilots exploited the capability with > little concern for system failure. The majority > of accidents were (and still are) seeded by > poor judgement and/or conditions beyond > control of the pilot that were not related > to system reliability. > > Now we can easily install two engine driven > power sources to charge a well maintained, > very user-friendly RG battery. A combination > that reduces risks of power starvation to > still lower numbers. > > If you're willing to jump in a rented C182 > and launch into the grey with equipment > certificated 30 years ago, then getting into > your RV fitted with Z-13/8 + RG battery has to > be more comfortable yet. Bottom line is that with > either airplane, your risk for experiencing > an unhappy day in the cockpit has more to > do with what's between your ears than with > what's under the cowl. > >>I intend to use to use two batteries for the maintenance benefits you >>outline in your book and for the additional cranking power. > > Dual batteries are indicated only for those special > conditions I cited earlier. If you don't have those > configurations . . . dual batteries are only a cost, > volume and weight burden on your project. > >>Right now I'm just trying to get a clear understanding of the RG battery's >>reliability and performance limitations. > > If all you want is more cranking power, install ONE > bigger battery. But cranking power of RG batteries > is so much better than their flooded counterparts > that we're installing systems like Z-13/8 with a small > fraction of the hardware weight in a 1975 Cessna > 182. Unless you have operational features that > encourage dual batteries, please consider installing > a single 17 to 18 a.h. RG battery. You can always > up-size later. But consider leaving 16 pounds of > hardware on the ground until you KNOW you need it. > 16 extra pounds of baggage or fuel is USEFUL . . . 16 > unnecessary pounds of battery is . . . well . . . > you know. > > I'm betting you'll never need it. > > Bob . . . > > > ________________________________________________________________________________
Date: Jun 26, 2009
See: http://www.verticalpower.com/forums/showthread.php?t=37 -------- Marc Ausman http://www.verticalpower.com RV-7 IO-390 Flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=250211#250211 ________________________________________________________________________________
Subject: Battery Proximity and mounting
Date: Jun 26, 2009
Bob, After reading your response to my wanting two batteries I again took a look at my design. To be more accurate, I have a hybrid version with Z-14 as the power distribution section (alternator, dynamo, and batteries) and Z-13 implimentation of the main and essential buses. The main bus is on the battery bus supported by the 40A alternator and and the essential bus is supported by your recomended Shack bridge rectifier fed from both battery buses. There is also a backup essential bus power switch from the second batery bus. My reason for redundant power distribution is that there can be some unforseen failure modes (vibration, fatigue, materiel defect, or assembly error) that would percipitate sweat on my part with hours of fuel in the tank no fuel being pumped to the engine or spark in the ignition. There have been a couple of pilots responding to this thread indicating that they have flown successfully for hundreds of hours on the primary system and subsequently decided that the second battery is not needed. In hind sight I could agree with them on Z13/20. For now I'll carry the extra insurance as it doesn't add much weight or complexity and it gets the best parts of both designs as it applies to my design goals. Regards, Bob Lee N52BL KR2 Suwanee, GA USA 92% done only 67% to go! ________________________________________________________________________________
Date: Jun 26, 2009
At 12:46 PM 6/26/2009, you wrote: > >Bob: > >A complete non answer. Lot of words...no relevance. > >On page 17-11 (rev11) you state that "RG battery reliability and >performance supplemented with good preventative maintenance drives >probability of gross battery failure to zero" > >You don't say "near zero", "close to zero", "approaching zero", or >any such thing. To claim anything has a zero probability of failure >is a pretty bold statement to make. Further, judging from the >general tone of your writing style, there's as much a chance >of that statement being rhetoric as anything else. Gross battery failures are functions of two things. Design or manufacturing defect -OR- abuse of the battery that places stresses on it that are outside design limits. Modern RG batteries are assembled on highly mechanized processes and demonstrate thousands to millions of units of field service history per year. Very few instances of design or manufacturing defect go un-corrected. This leaves abuse which cannot be predicted or quantified. I'll go fix that statement to read "very close to zero". >When I first read your book a couple years ago, I tried to get some >clarification from you on that statement. At first, when I asked >directly, you simply didn't address the question. I gave up on that >approach. Since then, whenever other group members have touched on >the issue, I have attempted, by asking questions in different ways, >to get you to explain further the meaning of your statement. In >response to the inquiries (mine and others) on this subject, you either: > 1. Don't answer. > 2. Provide theoretical fluffery > 3. Answer questions that aren't asked > 4. Introduce extraneous issues > 5. Claim its beyond understanding > >At first, I thought I was close to getting some answers this time, >but as before, the answers degraded into one or more of the above >categories. I really don't understand why you can't give a full and >complete explanation of what you mean by "gross battery failure" and >"zero probability" in some meaningful and understandable way. After >all, its your statement, you should be able to substantiate >it. But, that's apparently not the case. I've noticed that you seem >to follow that pattern on a few other issues as well. Anyway, I'm >tired of trying to coax an explanation out of you so I won't bring >up it up again. I'll just assume the statement was the result of >your writing style and not to be taken literally. In any regard, I >don't need the information now, and when I do, I'll get it from other sources. You wrote: "I intend to use to use two batteries for the maintenance benefits you outline in your book and for the additional cranking power." I recommended that you explore the need/value for "more cranking power" with a follow-up that many, many airplanes are flying with single 17 a.h. batteries and enjoy satisfactory cranking performance. You also said: "Right now I'm just trying to get a clear understanding of the RG battery's reliability and performance limitations." To the second statement it was my intention to suggest that battery "reliability" given in terms of failures per flight hour is not possible. Nobody has done the studies nor have the candidate manufacturers implemented statistical process controls intended to sustain advertised reliability numbers. It was not my intent to be mysterious or condescending. I'm only saying that credible "reliability" numbers don't exist. But assuming they did. Let us hypothesize that a flooded 24 a.h. Rebatt has a 453 failures per million flight hours and a 24 a.h. Odyssey was 305 failures per million flight hours . . . how would you use that data? Suppose I said that you have a 1 in 103 probability of ending a flight due to a battery failure? Of what use is that number? And how many mud-throwing fights can we start by debating how that number was calculated? First we need to define and separate "failure" from "end-of- life." The vast majority of batteries in ALL vehicles are replaced because they are at end-of-life as demonstrated by a failure to crank the engine. Would you call that a "failure" in aircraft system reliability parlance? In aircraft parlance, a battery that fails to crank an engine is probably months past end-of-life established by battery-only endurance design goals. Consider this same conversation going on about tires. How could anyone make recommendations for reliability of any particular tire without defining weight of aircraft, pilot skills, runway surfaces, landing speeds, etc. etc. A crummy tire can last a long time under the right circumstances . . . a top-of-the-line tire can be abused and used up with some dispatch. What do you wish I would have told you? Are you looking for brand recommendations. Service recommendations? Charging recommendations? ALL of the above can have a profound effect on service life of ANY battery. I can only suggest the universal recipe for success calls for . . . Monitoring the performance of any brand or style of battery and replacing it when it falls below some standard of performance THAT YOU ADOPT. Replacement is based on failure to store and deliver energy needed for YOUR battery only endurance mode. This is what we do in biz-jets. None of those batteries have published reliability numbers. In the fleet, a few folks get 3-4 years of service. A few folks get less than 2 years. Most fall someplace in between. An exceedingly small number of the total experience unanticipated gross failure. How would you have me describe "reliability" of those batteries? For me to offer reliability opinions without also stating design, operating and maintenance goals for the battery would be without foundation. I'm sorry about your disappointment but I hope it's clear that your question cannot be simply answered. If you discover "another source" that offers satisfying answers, please share that information with us. Bob . . . ________________________________________________________________________________
Date: Jun 26, 2009
I wrote about this yesterday on Letters From Flyover Country. Please keep in mind also that this was the NTSB factual report. It is not the probable cause report, although I think we can figure out what's coming. As I was reading the report, I was reminded of two articles. One was the Kitplanes article (folks who know me know which one I'm talking about), where the author wrote that people should just get their plane in the air. Period. And the other was a thread on VAF a couple of weeks ago basically goading those people who are deviating from planes and taking forever, to just hurry up and get in the air. What we have here appears to be a concession of safety for the fastest way into the air. This is a good reminder that a slow builder, a careful builder, a builder whose first goal is not to get in the air as soon as possible, is not someone to criticize or ridicule, it's someone to emulate. -------- Bob Collins St. Paul, Minn. RV-7A - Running wires http://rvbuildershotline.com Day job: http://minnesota.publicradio.org/collections/special/columns/news_cut/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=250234#250234 ________________________________________________________________________________
Date: Jun 26, 2009
Robert L. Nuckolls, III wrote: > At 06:50 AM 6/26/2009, you wrote: >> All, >> >> I found this link on the rotary engine news group. It's a thorough >> NTSB report about a complex engine/electrical installation that the >> builder/pilot was unwilling and unprepared to finish correctly. >> >> http://www.ntsb.gov/ntsb/brief2.asp?ev_id 071120X01821&ntsbno=NYC08FA023&akey=1 >> <http://www.ntsb.gov/ntsb/brief2.asp?ev_id 071120X01821&ntsbno=NYC08FA023&akey=1> > > > I've had several private links to this posting. > Very sad. It's an unfortunate fact of the human > condition that rational thought processes and > understanding of simple-ideas can be so terribly > diminished by hazardous behaviors. > Let's not let simple ideas get lost in our sympathy for the pilot in this accident. Most of this report is superfluous fluff with little bearing on what could have caused the accident. In fact, there is no statement of what caused the accident that could be blamed on the lack of a rational thought processes on the part of the builder. Most of the report was dedicated to pointing out how the high-end EFIS was not calibrated. At no point was the lack of calibration cited as a contributing factor to the accident. The man was flying day VFR. The instrument was superfluous for the mission. The fact that the pilot was not familiar with the instrument's operation was superfluous to the report. The fact that the instrument was in the plane at all was superfluous to the report. How could anything displayed on an uncalibrated EFIS translate into a plane taking a 35 to 60 degree nosedive during a day VFR flight? Most of the remainder of the report was equally superfluous. The first flight occurred on July 12. The accident occurred on November 2. The fact that clecoes held the cowling on for the first flight was superfluous to the accident report. It might have been germane if an accident had occurred with the clecoes still in use, but that was not the case. The fact that the propeller was under manual control vs some sort of electronics is superfluous. Are there not many examples of airplanes flying just fine with manual control? And I hear that there are a few flying with no pitch control at all. There is some information that the pilot was having issues with coordinating the engine power with the propeller pitch controls. But that does not translate to taking a 35 to 60 degree nose dive into terra firma. I can't even translate it to a situation where the pilot would not be able to maintain altitude. It might translate to an inability to maintain smooth level flight, but there is a wide gulf between smooth level flight and a dirt bath. The report pointed out that the rudder trim was attached with duct tape. The key word is "attached". How did a *rudder* trim that was *attached* contribute to a 60 degree nosedive? How does an *attached* rudder trim even make it difficult to maintain altitude? An aileron trim tab rod had been broken and poorly repaired. Was the weak attachment cause of an accident, or more superfluous data? The report makes hay of the pilots lack of high performance training. He was flying the plane for nearly 4 months before the accident. I would imagine that high performance training would cover issues like severe P factors and overspeeding the airplane. Is "maintaining altitude" taught exclusively in high performance trainging now? If not, why is the lack of such training an issue? The report details the pilots rush to get to Oshkosh, and the pilots willingness to falsify records in order to meet legal requirements. How did any of that contribute to an accident that occurred months later? There were some wires not connected. So? Did any of them contribute to the inability to maintain altitude? I have several wires in my project that are slated for future upgrades. It's much easier to run them now than when everything is closed up. They are not connected to anything. If something really bad happens to me, those wires will have nothing to do with it, but will "unconnected cables" be cited in the report anyway? I suggest reading the report again...but cross out all the superfluous lines that obviously have nothing at all to do with the accident. Cross out the parts that point out "He didn't follow the rules. He was a BAAAAD man." It'll be a much shorter report. The pilot of N289DT may very well be a prime candidate for a Darwin Award, but we can't know that from reading this report. All I can tell is that the investigator was much more concerned with pointing out how the pilot was not following procedure than about what occurred. -- http://www.ernest.isa-geek.org ________________________________________________________________________________
Date: Jun 26, 2009
At 02:01 PM 6/26/2009, you wrote: > >Bob, > >After reading your response to my wanting two batteries I again took a look >at my design. To be more accurate, I have a hybrid version with Z-14 as the >power distribution section (alternator, dynamo, and batteries) and Z-13 >implimentation of the main and essential buses. The main bus is on the >battery bus supported by the 40A alternator and and the essential bus is >supported by your recomended Shack bridge rectifier fed from both battery >buses. There is also a backup essential bus power switch from the second >batery bus. Okay. The term "hybrid" raise questions. The Z-figures are stand-alone, recipes for success that have passed muster for some analysis of failure modes and matched to missions. Mixing/matching between Z-figures should be evaluated for new failure modes. Can you sketch your power distribution and scan it for sharing with he group? >My reason for redundant power distribution is that there can be some >unforseen failure modes (vibration, fatigue, materiel defect, or assembly >error) that would percipitate sweat on my part with hours of fuel in the >tank no fuel being pumped to the engine or spark in the ignition. My sense is that your failure analysis may have been too broad with respect to kinds and numbers of failures. Many of my readers have stacked multiple failures onto a single flight cycle. This is so rare that part 23 aircraft don't even consider multiple failures for certification, part 25 airplanes consider it and ask the builder to show better one in ten to the minus 6 probability in a single system. But the neat thing is that completely independent systems need not be nearly so failure resistant because their failures do not "stack". You only need to show a 1 x 10^-6 probability for failure in any single flight cycle. MUCH easier. >There have been a couple of pilots responding to this thread indicating that >they have flown successfully for hundreds of hours on the primary system and >subsequently decided that the second battery is not needed. In hind sight I >could agree with them on Z13/20. For now I'll carry the extra insurance as >it doesn't add much weight or complexity and it gets the best parts of both >designs as it applies to my design goals. Have you done a load analysis on minimum energy requirements for sustained flight? Exactly how many watt-seconds of energy per flight hour are needed to run your engine? What engine are you using? Let's look at your hybridization and ponder the effects. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 26, 2009
At 03:16 PM 6/26/2009, you wrote: Let's not let simple ideas get lost in our sympathy for the pilot in this accident. Most of this report is superfluous fluff with little bearing on what could have caused the accident. In fact, there is no statement of what caused the accident that could be blamed on the lack of a rational thought processes on the part of the builder. Most of the report was dedicated to pointing out how the high-end EFIS was not calibrated. At no point was the lack of calibration cited as a contributing factor to the accident. The man was flying day VFR. The instrument was superfluous for the mission. The fact that the pilot was not familiar with the instrument's operation was superfluous to the report. The fact that the instrument was in the plane at all was superfluous to the report. How could anything displayed on an uncalibrated EFIS translate into a plane taking a 35 to 60 degree nosedive during a day VFR flight? To be sure, the first documents generated by any well crafted investigation are "factual reports". I've done many and was soundly admonished by my boss for inserting anything that smacked of analysis, supposition or opinion. In fact, we always dictated field notes, had them typed, and then judiciously edited them to offer only factual information. The tapes were then destroyed after the field investigator compared his tapes with the finished document. Most of the remainder of the report was equally superfluous . . . I suggest reading the report again...but cross out all the superfluous lines that obviously have nothing at all to do with the accident. Cross out the parts that point out "He didn't follow the rules. He was a BAAAAD man." It'll be a much shorter report. The pilot of N289DT may very well be a prime candidate for a Darwin Award, but we can't know that from reading this report. All I can tell is that the investigator was much more concerned with pointing out how the pilot was not following procedure than about what occurred. Points well taken. Everything that is factual should be in there and evaluated for significance by others who are detached from the natural emotions that arise from investigation. Digging through bent aluminum and archiving of written records is a task that should never be mixed with attempts to assign significance and deduce cause/effect. The NTSB Blue Ribbon Report will be produced later and screened for significance by less-invested minds. The report suggests some risky attitudes on the part of the builder but the exact cause of engine failure is pure physics. We can only grieve for his attitudes but learning can happen only if we understand the physics. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 26, 2009
At 01:26 PM 6/26/2009, you wrote: > >See: http://www.verticalpower.com/forums/showthread.php?t=37 Marc, Thanks for sharing this. I'd not looked at the scope trace on a mag p-lead in many years. I thought the voltage was more on the order of 300v but that might be across the points of the distributor rotor in my 283 Chevy! Too long ago . . . Your data confirms that my suggestion to Vern offers a robust solution to his design goal. Busted 100 degrees down there yet? Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 26, 2009
As another poster pointed out, this report is "Factual", not "Probably Cause". I imagine that the investigator made an effort to find out as much as he could about the airplane and pilot and this report is the culmination of this search. I believe that's a reasonably common method for investigating crashes. Another way to interpret the report is that it is documenting the fact that there were many things that could have caused the pilot to get distracted from the cardinal "Aviate, Navigate, then Communicate." If I were investigating an airplane crash I would be interested in listing all discrepancies from "normal" practice as any such deviations could cause the crash. This report does not find or imply blame for the crash. Matt- > > > Robert L. Nuckolls, III wrote: >> At 06:50 AM 6/26/2009, you wrote: >>> All, >>> >>> I found this link on the rotary engine news group. It's a thorough >>> NTSB report about a complex engine/electrical installation that the >>> builder/pilot was unwilling and unprepared to finish correctly. >>> >>> http://www.ntsb.gov/ntsb/brief2.asp?ev_id 071120X01821&ntsbno=NYC08FA023&akey=1 >>> <http://www.ntsb.gov/ntsb/brief2.asp?ev_id 071120X01821&ntsbno=NYC08FA023&akey=1> >> >> >> I've had several private links to this posting. >> Very sad. It's an unfortunate fact of the human >> condition that rational thought processes and >> understanding of simple-ideas can be so terribly >> diminished by hazardous behaviors. >> > Let's not let simple ideas get lost in our sympathy for the pilot in > this accident. Most of this report is superfluous fluff with little > bearing on what could have caused the accident. In fact, there is no > statement of what caused the accident that could be blamed on the lack > of a rational thought processes on the part of the builder. > > Most of the report was dedicated to pointing out how the high-end EFIS > was not calibrated. At no point was the lack of calibration cited as a > contributing factor to the accident. The man was flying day VFR. The > instrument was superfluous for the mission. The fact that the pilot was > not familiar with the instrument's operation was superfluous to the > report. The fact that the instrument was in the plane at all was > superfluous to the report. How could anything displayed on an > uncalibrated EFIS translate into a plane taking a 35 to 60 degree > nosedive during a day VFR flight? > > Most of the remainder of the report was equally superfluous. The first > flight occurred on July 12. The accident occurred on November 2. The > fact that clecoes held the cowling on for the first flight was > superfluous to the accident report. It might have been germane if an > accident had occurred with the clecoes still in use, but that was not > the case. > > The fact that the propeller was under manual control vs some sort of > electronics is superfluous. Are there not many examples of airplanes > flying just fine with manual control? And I hear that there are a few > flying with no pitch control at all. There is some information that the > pilot was having issues with coordinating the engine power with the > propeller pitch controls. But that does not translate to taking a 35 to > 60 degree nose dive into terra firma. I can't even translate it to a > situation where the pilot would not be able to maintain altitude. It > might translate to an inability to maintain smooth level flight, but > there is a wide gulf between smooth level flight and a dirt bath. > > The report pointed out that the rudder trim was attached with duct > tape. The key word is "attached". How did a *rudder* trim that was > *attached* contribute to a 60 degree nosedive? How does an *attached* > rudder trim even make it difficult to maintain altitude? An aileron > trim tab rod had been broken and poorly repaired. Was the weak > attachment cause of an accident, or more superfluous data? > > The report makes hay of the pilots lack of high performance training. > He was flying the plane for nearly 4 months before the accident. I > would imagine that high performance training would cover issues like > severe P factors and overspeeding the airplane. Is "maintaining > altitude" taught exclusively in high performance trainging now? If not, > why is the lack of such training an issue? The report details the > pilots rush to get to Oshkosh, and the pilots willingness to falsify > records in order to meet legal requirements. How did any of that > contribute to an accident that occurred months later? > > There were some wires not connected. So? Did any of them contribute to > the inability to maintain altitude? I have several wires in my project > that are slated for future upgrades. It's much easier to run them now > than when everything is closed up. They are not connected to anything. > If something really bad happens to me, those wires will have nothing to > do with it, but will "unconnected cables" be cited in the report anyway? > > I suggest reading the report again...but cross out all the superfluous > lines that obviously have nothing at all to do with the accident. Cross > out the parts that point out "He didn't follow the rules. He was a > BAAAAD man." It'll be a much shorter report. The pilot of N289DT may > very well be a prime candidate for a Darwin Award, but we can't know > that from reading this report. All I can tell is that the investigator > was much more concerned with pointing out how the pilot was not > following procedure than about what occurred. > > -- > > http://www.ernest.isa-geek.org > > ________________________________________________________________________________
Date: Jun 26, 2009
Wow, it's as if you and I read two different accounts of this unfortunate accident. I came away with the distinct impression that the builder/pilot was both careless and impatient, and utterly indifferent to the FAA regulations governing pilots and amateur built airplanes. Here we have a novice pilot (221.4 hours logged) flying a complex, high performance aircraft without logging the required training. I'll agree with you that it is possible that the pilot had sufficient experience by the time of the crash that he should have been able to find an instructor that would provide the necessary logbook endorsement to fly the airplane, but the fact remains there was no such endorsement, so no flights up to and including the accident flight were legal. There were many indications in the NTSB report of violations and just plain bad judgment. Let's look at them in the same order that they are mentioned in the report. The blade retention nuts were also found tightened approximately 1/4 inch tighter than the index marks scribed on the hub. This however, did not appear to affect the pitch rotation friction. A minor error but indicative (when taken with many other similar factors) of careless assembly and an urge to get the airplane finished on a tight schedule. Examination of the propeller controller revealed that it was not the propeller controller that was manufactured by the propeller manufacturer. Another minor discrepancy that is also indicative of that urge to get flying. Sure, he could just fly as if it was a fixed pitch prop and avoid the workload associated with manually adjusting pitch, but the report seems to suggest that was not the case. It gets worse. .examination of the flight control system revealed that, the outboard ends of the ailerons had been filled with foam and then fiberglass had been used to seal in the foam. A trim tab for the rudder was discovered to be attached with duct tape. The lock nuts which were used on the rod ends for the pitch control system could be spun by hand and were not tightened against the rod ends, and were found on the threaded portion of the rods approximately 1/4 inch away from what would be their normal seated positions. The right trim tab rod on the elevator was connected to its rod end by two threads and was shorter than the trim tab rod for the left trim tab. It displayed evidence that the end of the trim tab rod at one time had broken off, and then had been re-inserted into the rod end, as the rest of the threaded portion was not present. I can't see how to interpret that paragraph other than the builder had what I would charitably call "a relaxed attitude" toward quality workmanship. This isn't sloppy upholstery or paint here, this is flight safety related. Multiple wires showed no evidence of having being connected prior to impact. Examination of the cableing (sic) connected to the electrical system's contactor relays, revealed that a cable was not secured to its corresponding terminal on the contact or relay. More of that "relaxed attitude." Examination of the pilot's logbook revealed no evidence of the training required by the FAA for operation of an airplane with an engine of more than 200 horsepower. The accident flight was in violation of the FARs and so were all previous flights. Examination of the airplane's maintenance logbook revealed that on July 10, 2007, the FAA issued a special airworthiness certificate allowing operation of the airplane. Seven days later, on July 17, 2007, the pilot certified in the maintenance logbook that the prescribed 40 hours of test flying required by the FAA had been completed however, no record of separate entries for each of the test flights was discovered. The pilot also certified on that date that the airplane was controllable throughout its normal range of speeds and maneuvers, and that it had no hazardous characteristics or design flaws and that it was safe for operation. The pilot additionally certified that he had demonstrated by flight test, the operating data for the airplane and the weight and balance data. Anyone who believes that the 40 hour test program was actually completed in seven days probably also has seen Bigfoot and the Loch Ness Monster, and believes in both Santa Claus and the Easter Bunny. Pardon my skepticism, but I don't think he did it, and I also think he admitted as much when he was quoted (later in the report) saying "That's not what the logbooks say" at OSH when one other builder stated to the pilot that "There's no way you could have completed your fly off yet." Later in the NTSB report it says that "On July 13, 2007 the pilot emailed an RV builders group that he . had 39 hours and 20 minutes left to fly off." making it even less believable that the remaining time was actually flown in 4 more days. Not only did he not fly the test flights but he faked the weight and balance at least once (either in the log or in reporting to the FAA). Review of the FAA airworthiness records also revealed that the weight and balance data supplied to the FAA differed from the weight and balance information in the airplane's maintenance logbook. These differences included differing centers of gravity and a difference in empty weight. And to support my contention that he was rushing things a bit the report says. According to friends and other builders, the pilot was impatient with the time it was taking to do everything, and he was pushing to get the airplane assembled and flying in time for the Experimental Aircraft Association (EAA) convention at Wittman Regional Airport, (OSH) Oshkosh, Wisconsin. This resulted in the pilot doing such things as requesting the instrument panel builder to send the panel "as quickly as possible," and traveling to the engine builder's facility to pick up the engine instead of waiting for shipment. There's nothing wrong with using "will call" instead of waiting for a shipment but this is not the only instance of being in too much of a hurry to get the project finished. On July 14, 2007, the pilot and the engine builder departed 4G1 for X50. The last time I checked Florida was not "within an area around 4G1, and I doubt that the engine builder was a required crew member, further indicative of the pilot's disregard for the FARs. With only four days since the issuance of the special airworthiness certificate (call that 96 hours on the clock) is it virtually impossible that the flight was legal. Had the Phase 1 tests been completed as required the pilot should not have needed this exchange. On November 1, 2007, the day before the accident, the pilot once again emailed his friend asking: "What speeds do you carry on base and final when at max load? I am taking the family on our first trip and I am being paranoid but this is the first time I have taken more than 1 passenger. So just doing due diligence." Due diligence, indeed! have not seen any indication in the NTSB report of any due diligence. Best regards, Rob Housman Irvine, CA Europa XS Tri-Gear A070 Airframe complete -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ernest Christley Sent: Friday, June 26, 2009 1:17 PM Subject: Re: AeroElectric-List: Complex aircraft NTSB report Robert L. Nuckolls, III wrote: > At 06:50 AM 6/26/2009, you wrote: >> All, >> >> I found this link on the rotary engine news group. It's a thorough >> NTSB report about a complex engine/electrical installation that the >> builder/pilot was unwilling and unprepared to finish correctly. >> >> http://www.ntsb.gov/ntsb/brief2.asp?ev_id 071120X01821&ntsbno=NYC08FA023&a key=1 >> <http://www.ntsb.gov/ntsb/brief2.asp?ev_id 071120X01821&ntsbno=NYC08FA023& akey=1> > > > I've had several private links to this posting. > Very sad. It's an unfortunate fact of the human > condition that rational thought processes and > understanding of simple-ideas can be so terribly > diminished by hazardous behaviors. > Let's not let simple ideas get lost in our sympathy for the pilot in this accident. Most of this report is superfluous fluff with little bearing on what could have caused the accident. In fact, there is no statement of what caused the accident that could be blamed on the lack of a rational thought processes on the part of the builder. Most of the report was dedicated to pointing out how the high-end EFIS was not calibrated. At no point was the lack of calibration cited as a contributing factor to the accident. The man was flying day VFR. The instrument was superfluous for the mission. The fact that the pilot was not familiar with the instrument's operation was superfluous to the report. The fact that the instrument was in the plane at all was superfluous to the report. How could anything displayed on an uncalibrated EFIS translate into a plane taking a 35 to 60 degree nosedive during a day VFR flight? Most of the remainder of the report was equally superfluous. The first flight occurred on July 12. The accident occurred on November 2. The fact that clecoes held the cowling on for the first flight was superfluous to the accident report. It might have been germane if an accident had occurred with the clecoes still in use, but that was not the case. The fact that the propeller was under manual control vs some sort of electronics is superfluous. Are there not many examples of airplanes flying just fine with manual control? And I hear that there are a few flying with no pitch control at all. There is some information that the pilot was having issues with coordinating the engine power with the propeller pitch controls. But that does not translate to taking a 35 to 60 degree nose dive into terra firma. I can't even translate it to a situation where the pilot would not be able to maintain altitude. It might translate to an inability to maintain smooth level flight, but there is a wide gulf between smooth level flight and a dirt bath. The report pointed out that the rudder trim was attached with duct tape. The key word is "attached". How did a *rudder* trim that was *attached* contribute to a 60 degree nosedive? How does an *attached* rudder trim even make it difficult to maintain altitude? An aileron trim tab rod had been broken and poorly repaired. Was the weak attachment cause of an accident, or more superfluous data? The report makes hay of the pilots lack of high performance training. He was flying the plane for nearly 4 months before the accident. I would imagine that high performance training would cover issues like severe P factors and overspeeding the airplane. Is "maintaining altitude" taught exclusively in high performance trainging now? If not, why is the lack of such training an issue? The report details the pilots rush to get to Oshkosh, and the pilots willingness to falsify records in order to meet legal requirements. How did any of that contribute to an accident that occurred months later? There were some wires not connected. So? Did any of them contribute to the inability to maintain altitude? I have several wires in my project that are slated for future upgrades. It's much easier to run them now than when everything is closed up. They are not connected to anything. If something really bad happens to me, those wires will have nothing to do with it, but will "unconnected cables" be cited in the report anyway? I suggest reading the report again...but cross out all the superfluous lines that obviously have nothing at all to do with the accident. Cross out the parts that point out "He didn't follow the rules. He was a BAAAAD man." It'll be a much shorter report. The pilot of N289DT may very well be a prime candidate for a Darwin Award, but we can't know that from reading this report. All I can tell is that the investigator was much more concerned with pointing out how the pilot was not following procedure than about what occurred. -- http://www.ernest.isa-geek.org ________________________________________________________________________________
Date: Jun 26, 2009
As I build my RV, I also tend to want to have the rod end bearing jam nuts torqued down. Oh, and if a threaded rod breaks, I'll probably replace it rather than just stick it in with the broken part absent. The problem with many of us who knew Dan is that he was a good guy. A really nice guy. I certainly would want to look again at the DAR who signed off and I feel bad for the friends mentioned in the report who clearly tried to tell him a few things and I'm guessing they're kicking themselves for not being a little more direct. One tragedy WAS averted here. I believe Dan had planned to put his family in this plane later that day and fly to Boston. Let's be careful as we discuss this not to get too insulting toward Dan while learning from his death. It's a very difficult close-to-home story for those of us in the RV community. ________________________________________________________________________________
Date: Jun 26, 2009
Lectric Bob asked: Have you done a load analysis on minimum energy requirements for sustained flight? Exactly how many watt-seconds of energy per flight hour are needed to run your engine? Don't have watt-seconds/flight-hour but there is a spread sheet with amps required in various flight modes. Here's a link to my electrical system design documentation. http://kr.flyboybob.com/web_pages/kr2/electrical%20and%20instrument/electric al.htm At the bottom of the page there are links to the wiring diagrams. Regards, Bob Lee N52BL KR2 Suwanee, GA USA 92% done only 67% to go! ________________________________________________________________________________
Subject: 12 vs. 24 volt system
Date: Jun 26, 2009
I am in the process of buying an engine. I am told by TCM, that the FADEC is only available in 24V and they are not supporting a 12V system. I have designed my aircraft for 12V, however other than some lights and my Hydraulic pump motor and pressurization outflow valve, everything else will work on 12/32V. Is there an easy way to convert the 24V to 12V for the hydraulic pump and outflow valve? The heavy user is the Hydraulic motor, calling for a 12V/50A fused supply. Any thoughts on doing a 24-12V high amp conversion would be appreciated. Giff Marr LIV-P 75% ________________________________________________________________________________
Date: Jun 26, 2009
Subject: Splicing into D-sub wires.
Bob - do you have a comic book about splicing a second 20 AWG wire into the wire(s) heading into a D-sub connector? I looked through the articles at http://www.aeroelectric.com/articles.html, but didn't find exactly what I was trying to accomplish. I have a 37 pin connector which is plugged into a device. I want to tap into 5 of those wires to connect to another gizmo, and figured you already have a razzle-dazzle way to accomplish it. Thanks. Sam Hoskins Murphysboro, IL www.samhoskins.blogspot.com ________________________________________________________________________________
Date: Jun 26, 2009
Bob, Marc, thanks for the info. Odd that in all the years, I've never seen a rating until Marc's reference. Seems to be lost in the folklore. Vern ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Sent: Friday, June 26, 2009 3:08 PM Subject: Re: AeroElectric-List: Re: Magneto Switch Rating > > > At 01:26 PM 6/26/2009, you wrote: >> >> >>See: http://www.verticalpower.com/forums/showthread.php?t=37 > > Marc, > > Thanks for sharing this. I'd not looked at the scope > trace on a mag p-lead in many years. I thought the voltage > was more on the order of 300v but that might be > across the points of the distributor rotor in my > 283 Chevy! Too long ago . . . > > Your data confirms that my suggestion to Vern offers > a robust solution to his design goal. > > Busted 100 degrees down there yet? > > > Bob . . . > > --------------------------------------- > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > --------------------------------------- > > > ________________________________________________________________________________
Date: Jun 26, 2009
At 09:28 PM 6/26/2009, you wrote: > > >Bob, Marc, thanks for the info. > >Odd that in all the years, I've never seen a rating until Marc's >reference. Seems to be lost in the folklore. It probably has to do with the fact that about any switch you pick up at the hardware store is adequate to the task. The voltages are not much higher than peak AC waveform on 120 vac and the current is very nominal. Not a big deal electrically. The J-3 I used to fly had those little ball-end handles common to the front panel of grandpa's radio and grandma's electric fan. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 26, 2009
Subject: Re: 12 vs. 24 volt system
At 06:41 PM 6/26/2009, you wrote: > > >I am in the process of buying an engine. I am told by TCM, that the FADEC is >only available in 24V and they are not supporting a 12V system. I have >designed my aircraft for 12V, however other than some lights and my >Hydraulic pump motor and pressurization outflow valve, everything else will >work on 12/32V. Is there an easy way to convert the 24V to 12V for the >hydraulic pump and outflow valve? The heavy user is the Hydraulic motor, >calling for a 12V/50A fused supply. Any thoughts on doing a 24-12V high amp >conversion would be appreciated. Dual voltage band-aids are seldom very elegant. Suggest you go fully 24v. The pump motor is easy to swap out. How much current does the outflow valve use. If on the order of 1A or less, a simple series down-regulator is not too ugly. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 26, 2009
Agreed, very troubling for the RV-10 community that suffered this and 2 weather related fatals in the same year. I don't see any facts in the report relating to the electronic ignition for the Subaru engine, and its power source, but it certainly makes one wonder if the crash was initiated by loss of electrons to fire plugs and produce power, followed by power off attempt at landing that unfortunately was not successful. The mention of numerous unterminated wires does lead to head scratching. KM RV 10 #40866 Bob Collins wrote: > As I build my RV, I also tend to want to have the rod end bearing jam > nuts torqued down. Oh, and if a threaded rod breaks, I'll probably > replace it rather than just stick it in with the broken part absent. > > The problem with many of us who knew Dan is that he was a good guy. A > really nice guy. > > I certainly would want to look again at the DAR who signed off and I > feel bad for the friends mentioned in the report who clearly tried to > tell him a few things and I'm guessing they're kicking themselves for > not being a little more direct. > > One tragedy WAS averted here. I believe Dan had planned to put his > family in this plane later that day and fly to Boston. > > Let's be careful as we discuss this not to get too insulting toward Dan > while learning from his death. It's a very difficult close-to-home story > for those of us in the RV community. > > * > > > * ________________________________________________________________________________
Subject: COAXIAL CABLES recommendations
Date: Jun 26, 2009
Any recommendations for which coax can be used to wire the radio and the transponder ???? RG 400 - Standard cable for radio installations. Double shielded stranded conductor, MIL-DTL-17 spec. Approved for certified aircraft. PN 11-09202 $2.75 ($3.55AUD) RG 142 - Low loss coax cable for GPS, TPX, and DME installations. Double shielded solid conductor, MIL-C-17 spec. Approved for certified aircraft. PN 11-00043 $2.95 ($3.80AUD) RG 58A/U - Standard cable for experimental avionics installations. Single shielded stranded conductor, jacket type PVC. For experimental aircraft only. PN 11-03920 $0.46 ($0.59AUD) RG 58C/U - Standard cable for experimental avionics installations. Single shielded stranded conductor, jacket type Non-PVC. For experimental aircraft only. PN 11-04258 $0.46 ($0.59AUD) Thanks Read this topic online here: http://forums.matronics.com/viewtopic.php?p=250288#250288 ________________________________________________________________________________
Date: Jun 26, 2009
Subject: Re: Dual mags now...one Plasma II plus later
I get it. I was thinking of the 1-2 swiches. Pax, Ed Holyoke Robert L. Nuckolls, III wrote: > > > At 11:58 PM 6/25/2009, you wrote: >> >> >> Yup, but you'll need to turn one of the switches over when you want >> to use it to switch the ei. The mag switch closes to turn the mag >> off, but the ei switch will close to turn on. You want the "up" >> position to be on. > > No, the 1-3 switches are single pole, two position switches. > They function for either breaking power to an electronic > ignition -OR- grounding a magneto by simply moving a wire > to the opposite terminal. > > > Bob . . . > > --------------------------------------- > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > --------------------------------------- > > ________________________________________________________________________________
Subject: Re: COAXIAL CABLES recommendations
Date: Jun 27, 2009
I used RG58A/U for my radios and VOR. Same stuff that is on my 65 Cherokee that has been working for 40 years. I used the RG 400 for the GPS antenna. The reason for the 58 was cost savings. If you check ebay you can find RG 400 for $1.00 per foot. At that price, I would have used it for everything. Floyd Wilkes Zodiac 601XL ----- Original Message ----- From: "Thruster87" <alania(at)optusnet.com.au> Sent: Saturday, June 27, 2009 12:51 AM Subject: AeroElectric-List: COAXIAL CABLES recommendations > > > Any recommendations for which coax can be used to wire the radio and the > transponder ???? > RG 400 - Standard cable for radio installations. Double shielded stranded > conductor, MIL-DTL-17 spec. Approved for certified aircraft. > PN 11-09202 $2.75 ($3.55AUD) > > > RG 142 - Low loss coax cable for GPS, TPX, and DME installations. Double > shielded solid conductor, MIL-C-17 spec. Approved for certified aircraft. > PN 11-00043 $2.95 ($3.80AUD) > > > RG 58A/U - Standard cable for experimental avionics installations. Single > shielded stranded conductor, jacket type ?" PVC. For experimental > aircraft only. > PN 11-03920 $0.46 ($0.59AUD) > > > RG 58C/U - Standard cable for experimental avionics installations. Single > shielded stranded conductor, jacket type ?" Non-PVC. For experimental > aircraft only. > PN 11-04258 $0.46 ($0.59AUD) Thanks > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=250288#250288 > > > ________________________________________________________________________________
Date: Jun 27, 2009
Well I am just spitballing here but If I had to put forth a theory it would be that the propellor and power problem are what finally did him in. If he had to manually adjust the propellor pitch every time he changed power I think he could have easily either gotten distracted by it and stopped flying the airplane or messed up the settings and lost thrust even though the engine was running. Just my 2 cents. I would have found that plane very hard to fly in that condition. Can't trust the instruments so look outside, reduce power then change prop pitch, shut off alarm, look outside again, oops to low add power reset prop pitch, shut off alarm, etc. I think it would have been easy for him to get distracted or mess up the power or prop setting. Bottom line is if it ain't working right fix it before you fly. ---- Kelly McMullen wrote: > > Agreed, very troubling for the RV-10 community that suffered this and 2 > weather related fatals in the same year. I don't see any facts in the > report relating to the electronic ignition for the Subaru engine, and > its power source, but it certainly makes one wonder if the crash was > initiated by loss of electrons to fire plugs and produce power, followed > by power off attempt at landing that unfortunately was not successful. > The mention of numerous unterminated wires does lead to head scratching. > KM > RV 10 #40866 > > Bob Collins wrote: > > As I build my RV, I also tend to want to have the rod end bearing jam > > nuts torqued down. Oh, and if a threaded rod breaks, I'll probably > > replace it rather than just stick it in with the broken part absent. > > > > The problem with many of us who knew Dan is that he was a good guy. A > > really nice guy. > > > > I certainly would want to look again at the DAR who signed off and I > > feel bad for the friends mentioned in the report who clearly tried to > > tell him a few things and I'm guessing they're kicking themselves for > > not being a little more direct. > > > > One tragedy WAS averted here. I believe Dan had planned to put his > > family in this plane later that day and fly to Boston. > > > > Let's be careful as we discuss this not to get too insulting toward Dan > > while learning from his death. It's a very difficult close-to-home story > > for those of us in the RV community. > > > > * > > > > > > * > > > > ________________________________________________________________________________
Date: Jun 27, 2009
Subject: Re: Complex aircraft NTSB report
I believe Ernest is correct. The report does indicate a pattern of behavior that may have contributed to the accident. Stan Sutterfield I suggest reading the report again...but cross out all the superfluous lines that obviously have nothing at all to do with the accident. Cross out the parts that point out "He didn't follow the rules. He was a BAAAAD man." It'll be a much shorter report. The pilot of N289DT may very well be a prime candidate for a Darwin Award, but we can't know that from reading this report. All I can tell is that the investigator was much more concerned with pointing out how the pilot was not following procedure than about what occurred. **************Make your summer sizzle with fast and easy recipes for the grill. (http://food.aol.com/grilling?ncid=emlcntusfood00000006) ________________________________________________________________________________
Date: Jun 27, 2009
Hi all, This has been a very enlightening thread for me. I am persuaded that a single battery, dual alternator is probably quite sufficient for my mission envelope and will save me a good #20 over using the second battery. This is not the forum to argue the battery position in an RV 8. There are several long discussions on the VAF forum. The up side of the rear position is the weight and balance advantage, as RV 8's tend to be nose heavy. The down side is an additional six to eight foot run of #2 welding cable, its associated weight, resistance and potential for chaffing. I will have to give that a little more thought. Thank you all for your insights and off-line diagrams. Regards, Michael Wynn RV 8 FWF San Ramon, CA **************An Excellent Credit Score is 750. See Yours in Just 2 Easy Steps! eExcfooterNO62) ________________________________________________________________________________
Date: Jun 27, 2009
Subject: Re: Battery Proximity and mounting
At 08:18 AM 6/27/2009, you wrote: >Looks like we have another a**hole that refuses to include his >name. Could he be ashamed of it? >I got a nasty note from him off the forum for my comments on the forum. >Wonder what up with him? Gently my friend. This is after all a classroom with a broad spectrum of attendee needs and skill sets. The value of what we do here is not increased by prejudicial words. Let us strive to be teachers with a goal of working to everyone's satisfaction. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 27, 2009
At 07:51 AM 6/27/2009, you wrote: Well I am just spitballing here but If I had to put forth a theory it would be that the propellor and power problem are what finally did him in. If he had to manually adjust the propellor pitch every time he changed power I think he could have easily either gotten distracted by it and stopped flying the airplane or messed up the settings and lost thrust even though the engine was running. Just my 2 cents. I would have found that plane very hard to fly in that condition. Can't trust the instruments so look outside, reduce power then change prop pitch, shut off alarm, look outside again, oops to low add power reset prop pitch, shut off alarm, etc. I think it would have been easy for him to get distracted or mess up the power or prop setting. Bottom line is if it ain't working right fix it before you fly. There have been numerous electrically driven prop pitch adjustment mechanisms that were not automatic. The earliest I recall was on a 50's vintage Bonanza. These are treated for all practical purposes as a fixed pitch prop that can be changed in flight. Keep in mind that the engine will keep the craft airborne at ANY prop pitch setting. The value in being able to adjust it is obvious for optimizing climb vs. cruise performance . . . but departures from optimum settings do not automatically present hazards beyond that of distracting a pilot that doesn't understand how it works. If we indulge in useful speculation I'll suggest that items in the factual report are particularly significant. Namely the probability that wires that SHOULD have been managing power around the recently moved batteries were not properly terminated. Given that the engine was electrically dependent, the idea that wires were coming loose at the battery is not pleasant to contemplate. Once the engine is dead, the pilot is faced with a whole new task that exceedingly few are well trained to achieve . . . walk away from the impending arrival with the earth. Pilot's attitudes and other errors not withstanding, the manner in which the last few seconds of this story unfolded tells the tale. I'm told that the terrain was relatively flat farm land and that major damage to the airframe occurred when it contacted a raised roadbed at right angles. All these things suggest a host of poor actions on the part of a neophyte pilot who was tasked with making good decisions under the worst of circumstances. As dark-n-stormy night stories go, this one is rich with factual data. At the same time, it's particularly sad because the root cause that started this unhappy chain of events probably did not involve an error of design or failure of a component. It seems likely that attention to ordinary details of good craftsmanship and pilotage set the stage for this play. It's no different than finding the engine suddenly silent because one neglected to take on predictable and necessary fuel before flight. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 27, 2009
At 06:20 AM 6/27/2009, you wrote: > >I used RG58A/U for my radios and VOR. Same stuff that is on my 65 >Cherokee that has been working for 40 years. > >I used the RG 400 for the GPS antenna. > >The reason for the 58 was cost savings. If you check ebay you can >find RG 400 for $1.00 per foot. At that price, I would have used it >for everything. > >Floyd Wilkes >Zodiac 601XL Good thought. RG58 is pvc and polyethylene for insulation . . . the best we knew how to do in WWII. RG-400 and cousins are modern, high temperature materials and double shielded to boot. The best we know how to do in 2009. It's a plugs, points and coil versus electronic ignition kind of decision. Both will function as advertised. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 27, 2009
At 09:49 AM 6/27/2009, you wrote: >Hi all, > >This has been a very enlightening thread for me. I am persuaded >that a single battery, dual alternator is probably quite sufficient >for my mission envelope and will save me a good #20 over using the >second battery. > >This is not the forum to argue the battery position in an RV >8. There are several long discussions on the VAF forum. The up >side of the rear position is the weight and balance advantage, as RV >8's tend to be nose heavy. The down side is an additional six to >eight foot run of #2 welding cable, its associated weight, >resistance and potential for chaffing. I will have to give that a >little more thought. > >Thank you all for your insights and off-line diagrams. Batteries have been the classical mitigator of wight and balance issues since day-one. Of all major weight contributors, the batteries have always been the easiest to relocate. I'll suggest that concerns for wire weight and installation requirements take a very distant back seat to the airplane's handling qualities. Batteries have been carried around in the tail of airplanes in tens of thousands of airplanes. When I started at Cessna, I think all of our batteries were in the tail. Doing a good job of installing the wire is a trivial task. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 27, 2009
---- "Robert L. Nuckolls wrote: > > >> There have been numerous electrically driven prop > pitch adjustment mechanisms that were not automatic. > The earliest I recall was on a 50's vintage Bonanza. > These are treated for all practical purposes as a > fixed pitch prop that can be changed in flight. Keep > in mind that the engine will keep the craft airborne > at ANY prop pitch setting. The value in being able to > adjust it is obvious for optimizing climb vs. cruise > performance . . . but departures from optimum settings > do not automatically present hazards beyond that > of distracting a pilot that doesn't understand how > it works. > > If we indulge in useful speculation I'll suggest > that items in the factual report are particularly > significant. Namely the probability that wires > that SHOULD have been managing power around the > recently moved batteries were not properly > terminated. Given that the engine was electrically > dependent, the idea that wires were coming loose > at the battery is not pleasant to contemplate. > Another good possibility Bob. If as the story says, he crimped the battery terminals with a pair of pliers the connections could very well have come loose. My point was that he had a constant speed prop apparently and was trying to adjust it with each change in power setting which, along with everything else, could have overloaded him especially if he was having intermitent electrical problems from a loose battery wire. I have to agree with poor craftsmanship and a seeming passion for working around problems instead of fixing them seems the culprit. A strong lesson we should all take to heart. Another lesson here is that if you have a friend, acquaintance or fellow pilot with a problem help them to get it fixed and don't let them think it is okay to fly with these kinds of issues. The days of duct tape and bailing wire fixes are long gone. Rodney ________________________________________________________________________________
Subject: NTSB RV10 Accident Report
Date: Jun 27, 2009
This is forwarded from the Lancair mailing list without comment, except that there are a couple hundred lessons in here. Bob Mitchell L-320 For a number of reasons I track some of the RV websites and data. You may want to read the accident report from Dan Lloyd's accident last November, because it has so many lessons for all of us. He had an RV10 with an early turbocharged Eggenfellner Subaru H-6 engine. This really was a bad case of "Get -to-Oshkosh-itis", and some of the mistakes made are pretty scary. I am listing it because I suspect that we could all learn from it. By all accounts, Dan was regarded as a a pretty sound person, which makes it even more applicable to our community. You can read the report at http://www.ntsb.gov/ntsb/brief2.asp?ev_id 071120X01821 <http://www.ntsb.gov/ntsb/brief2.asp?ev_id 071120X01821&ntsbno=NYC08FA023& akey=1> &ntsbno=NYC08FA023&akey=1 ________________________________________________________________________________
Date: Jun 27, 2009
Subject: Unterminated wires (was: Complex aircraft NTSB report)
Whether unterminated wires were problematic would be dependent on the circumstances. On a new plane, I wouldn't be surprised to find wires with unstripped ends, tied off to the side awaiting some as-yet un-purchased option. Now if the loose ends (literally) were stripped and showed signs of having been previously connected to something - that could be worrisome. My $0.25 ($.02 adjusted for 40 years of government theft through "inflation") Dale R. COZY MkIV #0497 Ch. 13 Mesa, AZ Kelly McMullen wrote: > > > Agreed, very troubling for the RV-10 community that suffered this and > 2 weather related fatals in the same year. I don't see any facts in > the report relating to the electronic ignition for the Subaru engine, > and its power source, but it certainly makes one wonder if the crash > was initiated by loss of electrons to fire plugs and produce power, > followed by power off attempt at landing that unfortunately was not > successful. The mention of numerous unterminated wires does lead to > head scratching. > KM > RV 10 #40866 ________________________________________________________________________________
Date: Jun 27, 2009
>I have to agree with poor craftsmanship and a seeming passion for >working around problems instead of fixing them seems the culprit. A >strong lesson we should all take to heart. Another lesson here is >that if you have a friend, acquaintance or fellow pilot with a >problem help them to get it fixed and don't let them think it is >okay to fly with these kinds of issues. The days of duct tape and >bailing wire fixes are long gone. > >Rodney Well put sir. I'll suggest that the mission is core to the purposes of all the Lists. They can be the repository and offeror of proven recipes for success as well as a filter for combining simple-ideas into new recipes. This isn't just a brother's keeper issue. When somebody makes a spectacular and newsworthy exit in any (but particularly an OBAM) aircraft, public and regulatory perceptions will paint us all with the same brush dipped into the words of ignorant and ratings- motivated vendors of the morning rags and disseminators of the evening news. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 27, 2009
Subject: Re: Unterminated wires
At 05:36 PM 6/27/2009, you wrote: Whether unterminated wires were problematic would be dependent on the circumstances. On a new plane, I wouldn't be surprised to find wires with unstripped ends, tied off to the side awaiting some as-yet un-purchased option. Now if the loose ends (literally) were stripped and showed signs of having been previously connected to something - that could be worrisome. The report speaks specifically to several wires not mated to terminals on the contactor. That the battery and contactor had been recently moved but without benefit of crimp tools. "Channel Locks" were used to install terminals. A hardware store torch and solder could have provided secure if temporary connections. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Subject: Complex aircraft NTSB report
Date: Jun 27, 2009
I finally read the NTSB report. As usual, these accidents are years in the making. Not sure what lesson(s) apply to us here..idiots with more money than brains are everywhere, including the highest levels of Wall Street and banking ;). This quote by the owner/pilot is classic: ". just doing due diligence." We sure are good at self-deception. Ralph RV-9A QB SA From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Sam Hoskins Sent: Friday, June 26, 2009 4:51 AM Subject: AeroElectric-List: Complex aircraft NTSB report All, I found this link on the rotary engine news group. It's a thorough NTSB report about a complex engine/electrical installation that the builder/pilot was unwilling and unprepared to finish correctly. http://www.ntsb.gov/ntsb/brief2.asp?ev_id 071120X01821 <http://www.ntsb.gov/ntsb/brief2.asp?ev_id 071120X01821&ntsbno=NYC08FA023& akey=1> &ntsbno=NYC08FA023&akey=1 Sam ________________________________________________________________________________
Date: Jun 28, 2009
To All: I recently made statements in a post under this subject that was critical of Bob's responsiveness to an issue. The statements were based on my recollections of posts over the past two years. Bob was kind enought to continue the discussion with me off-group. In preparation for that discussion, I reveiwed my posts on the issue and could not find support for the statements I made. I would like to retract those statements and make an appology to Bob and the group for making them. Mark ________________________________________________________________________________
Date: Jun 28, 2009
Subject: Splicing at D-subs.
I didn't hear back on this one, so here it is again: Bob - do you have a comic book about splicing a second 20 AWG wire into the wire(s) heading into a D-sub connector? I looked through the articles at http://www.aeroelectric.com/articles.html, but didn't find exactly what I was trying to accomplish. I have a 37 pin connector which is plugged into a device. I want to tap into 5 of those wires to connect to another gizmo, and figured you already have a razzle-dazzle way to accomplish it. Thanks. Sam Hoskins Murphysboro, IL www.samhoskins.blogspot.com ________________________________________________________________________________
Date: Jun 28, 2009
Date: Jun 28, 2009
Subject: Re: Splicing of 2 or 3 conductor shielded cable
Date: Jun 28, 2009
I am relocating the comm and mic jacks in my Lancair to a position behind the pilot/co-pilot seatback and so the comm and mic cables need to be lengthened. Any suggestions here for what would be the best method for splicing additional length to these cables and also maintaining the integrity of the shields? Thanks ________________________________________________________________________________
Date: Jun 28, 2009
Subject: Re: Splicing at D-subs.
Sam Hoskins wrote: > I didn't hear back on this one, so here it is again: > > Bob - do you have a comic book about splicing a second 20 AWG wire > into the > wire(s) heading into a D-sub connector? I looked through the articles at > http://www.aeroelectric.com/articles.html, but didn't find exactly what I > was trying to accomplish. > > I have a 37 pin connector which is plugged into a device. I want to tap > into 5 of those wires to connect to another gizmo, and figured you already > have a razzle-dazzle way to accomplish it. > > Thanks. > > Sam Hoskins > Murphysboro, IL > > www.samhoskins.blogspot.com <http://www.samhoskins.blogspot.com> Hi Sam, There's a comic book somewhere on the aeroelectric site showing how to feed power *in* to multiple pins on a subD connector. You can just reverse the technique to feed multiple outs. Bring one lead out of the subD for a few inches. At that point, use an in-line (butt) splice with your subD lead in one end and your 2 destination leads in the other. Of course, this assumes that you have researched the signal quality implications of splitting the signals. Charlie ________________________________________________________________________________
From: "Bill Bradburry" <bbradburry(at)bellsouth.net>
Date: Jun 28, 2009
Sam, Is this what you were looking for? http://www.aeroelectric.com/articles/pigtail/pigtail.html Bill B _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Sam Hoskins Sent: Sunday, June 28, 2009 8:11 AM Subject: AeroElectric-List: Splicing at D-subs. I didn't hear back on this one, so here it is again: Bob - do you have a comic book about splicing a second 20 AWG wire into the wire(s) heading into a D-sub connector? I looked through the articles at http://www.aeroelectric.com/articles.html, but didn't find exactly what I was trying to accomplish. I have a 37 pin connector which is plugged into a device. I want to tap into 5 of those wires to connect to another gizmo, and figured you already have a razzle-dazzle way to accomplish it. Thanks. Sam Hoskins Murphysboro, IL <http://www.samhoskins.blogspot.com> www.samhoskins.blogspot.com ________________________________________________________________________________
Date: Jun 28, 2009
6/28/2009 The NTSB Report NYC08FA023 contains the following statement: "14 CFR Part 21.93 requires that any major changes that are made to an airplane require inspection by the FAA prior to further flight." This statement does not apply to the amateur built experimental airplane being reported upon in this accident report. Instead it applies to aircraft with changes in type design. Actions required when changes are made to an amateur built experimental aircraft are described in the Operating Limitations for that specific aircraft. 'OC' Says: "The best investment we can make is the effort to gather and understand knowledge." ________________________________________________________________________________
Date: Jun 28, 2009
No - I saw that one and it's for shields. I was looking for something similar for single conductor wire. It's no big deal. I was just looking for one of Bob's elegant soultions. Thanks. Sam On Sun, Jun 28, 2009 at 8:43 AM, Bill Bradburry wrote: > Sam, > > Is this what you were looking for? > > > http://www.aeroelectric.com/articles/pigtail/pigtail.html > > > Bill B > > > ------------------------------ > > *From:* owner-aeroelectric-list-server(at)matronics.com [mailto: > owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of *Sam Hoskins > *Sent:* Sunday, June 28, 2009 8:11 AM > *To:* AeroElectric-List(at)matronics.com > *Subject:* AeroElectric-List: Splicing at D-subs. > > I didn't hear back on this one, so here it is again: > > Bob - do you have a comic book about splicing a second 20 AWG wire into the > wire(s) heading into a D-sub connector? I looked through the articles at > http://www.aeroelectric.com/articles.html, but didn't find exactly what I > was trying to accomplish. > > I have a 37 pin connector which is plugged into a device. I want to tap > into 5 of those wires to connect to another gizmo, and figured you already > have a razzle-dazzle way to accomplish it. > > Thanks. > > Sam Hoskins > Murphysboro, IL > > www.samhoskins.blogspot.com > > * * > > * * > > ** > > ** > > ** > > *http://www.matronics.com/Navigator?AeroElectric-List* > > ** > > ** > > *http://forums.matronics.com* > > ** > > ** > > *http://www.matronics.com/contribution* > > * * > > * > > * > > ________________________________________________________________________________
Date: Jun 28, 2009
At 09:07 AM 6/28/2009, you wrote: 6/28/2009 The NTSB Report NYC08FA023 contains the following statement: "14 CFR Part 21.93 requires that any major changes that are made to an airplane require inspection by the FAA prior to further flight." This statement does not apply to the amateur built experimental airplane being reported upon in this accident report. Instead it applies to aircraft with changes in type design. Actions required when changes are made to an amateur built experimental aircraft are described in the Operating Limitations for that specific aircraft. Thanks for responding to this Bob. It rang some alarm bells when I first read it but had not yet taken time to research it. I would offer to add the following: Just because some legacy or regulatory mandate "does not apply" to the OBAM aircraft endeavor does not automatically tag it useless or unworthy of consideration. I have many moons of experience working inside the rubber padded room that is bounded by lots of rules . . . some of which were crafted and later administered by folks who didn't understand the discipline in which we work. At the same time, MOST of the rules stand on foundations crafted of simple-ideas of physics, logic and/or historical experience. In the case of 21.93, when one takes hammer and saw to the airplane, it doesn't hurt and may be very helpful to seek the advice of any who can offer mentorship. Clearly, the subject of this unhappy thread did not avail himself of the volumes of data and guidance freely offered from hundred of sources. It was his choice, decision and risk. Fortunately, the other seats were un occupied when the risks tagged him on the shoulder. If the community of OBAM aircraft builders can claim any common fraternal goal, it should go much deeper than the sharing goggles, helmet and white scarf experiences of flying. It includes the task of RISK REDUCTION. Our machines are beautiful, exciting, and offer a potential for great utility. But they are exceedingly unforgiving of those who do not embrace a necessity of responsible conduct supported by skill and understanding. Fly comfortably my friends . . . Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
From: "Bob McCallum" <robert.mccallum2(at)sympatico.ca>
Date: Jun 28, 2009
Sam; Same process works. Just bring an inch or so of the wire from the pin out of the connector, splice on your two leads, heat shrink the assembly, just as shown in this "comic book" for shields and carry on. The second wire instead of looping back into the connector as shown here, simply goes to your second device. Either the solder technique or the solder sleeve method are neat and compact. Bob McC _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Sam Hoskins Sent: Sunday, June 28, 2009 10:03 AM Subject: Re: AeroElectric-List: Splicing at D-subs. No - I saw that one and it's for shields. I was looking for something similar for single conductor wire. It's no big deal. I was just looking for one of Bob's elegant soultions. Thanks. Sam On Sun, Jun 28, 2009 at 8:43 AM, Bill Bradburry wrote: Sam, Is this what you were looking for? http://www.aeroelectric.com/articles/pigtail/pigtail.html Bill B _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Sam Hoskins Sent: Sunday, June 28, 2009 8:11 AM Subject: AeroElectric-List: Splicing at D-subs. I didn't hear back on this one, so here it is again: Bob - do you have a comic book about splicing a second 20 AWG wire into the wire(s) heading into a D-sub connector? I looked through the articles at http://www.aeroelectric.com/articles.html, but didn't find exactly what I was trying to accomplish. I have a 37 pin connector which is plugged into a device. I want to tap into 5 of those wires to connect to another gizmo, and figured you already have a razzle-dazzle way to accomplish it. Thanks. Sam Hoskins Murphysboro, IL <http://www.samhoskins.blogspot.com> www.samhoskins.blogspot.com http://www.matronics.com/Navigator?AeroElectric-List http://forums.matronics.com http://www.matronics.com/contribution ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List a>http://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jun 28, 2009
Sam, While I was looking I also found the one that Charlie is talking about here. You just use 6" pigtails and crimp them together as Charlie describes. Bill B -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Charlie England Sent: Sunday, June 28, 2009 9:38 AM Subject: Re: AeroElectric-List: Splicing at D-subs. --> Sam Hoskins wrote: > I didn't hear back on this one, so here it is again: > > Bob - do you have a comic book about splicing a second 20 AWG wire > into the > wire(s) heading into a D-sub connector? I looked through the articles > at http://www.aeroelectric.com/articles.html, but didn't find exactly > what I was trying to accomplish. > > I have a 37 pin connector which is plugged into a device. I want to > tap into 5 of those wires to connect to another gizmo, and figured you > already have a razzle-dazzle way to accomplish it. > > Thanks. > > Sam Hoskins > Murphysboro, IL > > www.samhoskins.blogspot.com <http://www.samhoskins.blogspot.com> Hi Sam, There's a comic book somewhere on the aeroelectric site showing how to feed power *in* to multiple pins on a subD connector. You can just reverse the technique to feed multiple outs. Bring one lead out of the subD for a few inches. At that point, use an in-line (butt) splice with your subD lead in one end and your 2 destination leads in the other. Of course, this assumes that you have researched the signal quality implications of splitting the signals. Charlie ________________________________________________________________________________
Date: Jun 28, 2009
At 09:03 AM 6/28/2009, you wrote: >No - I saw that one and it's for shields. I was looking for >something similar for single conductor wire. > >It's no big deal. I was just looking for one of Bob's elegant soultions. Sorry for the long delay in responding . . . I wish there were an "elegant" solution. Obviously the D-Sub pin is limited to the insertion of but a single 20AWG wire. The task is to tap into a few conductors in a manner that does not result in the wire bundle taking on that "rabbit satisfied snake" appearance. The lowest volume approach I can deduce is to bare a short segment (1/4 to 3/8 inch) of strands on wire to be tapped a couple of inches from the end . . . Emacs! Wrap the branch strands around the open gap, solder and heat shrink. Then install the d-sub pin. Emacs! You probably want to have the spice occur outside the back-shell of the connector. Stagger their positions so that they don't "bulk up" a lump in one place on the harness. Are you committed to 20AWG wire throughout? 22AWG does this hat-dance a little better. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 28, 2009
There's a comic book somewhere on the aeroelectric site showing how to feed power *in* to multiple pins on a subD connector. You can just reverse the technique to feed multiple outs. Bring one lead out of the subD for a few inches. At that point, use an in-line (butt) splice with your subD lead in one end and your 2 destination leads in the other. Of course, this assumes that you have researched the signal quality implications of splitting the signals. Charlie --------------------- I think you're referring to the suggestion for paralleling pins in a d-sub to achieve higher current ratings for conductors in the connector. This technique was used on a super-sonic target project I worked on some years ago and is illustrated here: http://www.aeroelectric.com/Pictures/Wiring_Technique/Paralleled_DSub_Pins.pdf Sam is looking for a way to add a "wye-intersection" into one of the connectors for carrying the same current of to another location in the system. I've illustrated a suggestion to this task in another posting. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 28, 2009
I'm building an RV. I leave my hangar door open (I don't understand why people don't want visitors, really.) When expert builders stop by -- as they often do -- I encourage them to look at the project and holler if they see something that doesn't look right or could be improved (although I do joke that my hangar rules or "no looking closer than from 1 foot!"(g)). I've been building since 2001 and, yes, I'm a slow builder, but when I was growing up, my family called me the "Scotch tape kid," because I took the shortest route to fix any problem -- tape. If the airplane project has taught me anything at all, "take your time, do it right, and kick the people who make fun of how long it's taking out of the hangar" are the most important. I fear we're preaching to the choir here, however. People who read AeroElectric Connection or hang out here on the list, already have a preference for quality and good workmanship. Bob Collins St. Paul, MN. Letters From Flyover Country http://rvnewsletter.blogspot.com -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Sunday, June 28, 2009 10:01 AM Subject: Re: AeroElectric-List: Complex aircraft NTSB report --> At 09:07 AM 6/28/2009, you wrote: 6/28/2009 The NTSB Report NYC08FA023 contains the following statement: "14 CFR Part 21.93 requires that any major changes that are made to an airplane require inspection by the FAA prior to further flight." This statement does not apply to the amateur built experimental airplane being reported upon in this accident report. Instead it applies to aircraft with changes in type design. Actions required when changes are made to an amateur built experimental aircraft are described in the Operating Limitations for that specific aircraft. Thanks for responding to this Bob. It rang some alarm bells when I first read it but had not yet taken time to research it. ________________________________________________________________________________
Date: Jun 28, 2009
At 02:03 AM 6/28/2009, you wrote: >To All: > >I recently made statements in a post under this subject that was >critical of Bob's responsiveness to an issue. The statements were >based on my recollections of posts over the past two years. Bob was >kind enought to continue the discussion with me off-group. In >preparation for that discussion, I reveiwed my posts on the issue >and could not find support for the statements I made. I would like >to retract those statements and make an appology to Bob and the >group for making them. > >Mark Thank you sir. No problem . . . and let's not dwell on it. We are all friends here. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 28, 2009
As an additional data point, Garmin has a D-sub crimp and poke contact P/N 336-00023-00 for standard density connectors that accommodated an 18AWG wire. Ron Q. At 08:25 6/28/2009, you wrote: > Sorry for the long delay in responding . . . I > wish there were an "elegant" solution. Obviously > the D-Sub pin is limited to the insertion of but > a single 20AWG wire. The task is to tap > into a few conductors in a manner that does not > result in the wire bundle taking on that > "rabbit satisfied snake" appearance. ________________________________________________________________________________
Date: Jun 28, 2009
At 08:19 AM 6/28/2009, you wrote: > >I am relocating the comm and mic jacks in my Lancair to a position >behind the pilot/co-pilot seatback and so the comm and mic cables need >to be lengthened. Any suggestions here for what would be the best >method for splicing additional length to these cables and also >maintaining the integrity of the shields? Strip back 3 inches or so of outer insulation on cables to be spliced. Pull conductors out of the shield as shown in , , , http://aeroelectric.com/articles/shldwire/shldwire.html Lap splice the individual strands as shown here . . . http://www.aeroelectric.com/articles/Solder_Lap_Splicing/Solder_Lap_Splices.html Actually, you don't even need to "bulk up" the joint by wrapping the strands, you can simply lay them parallel and solder as shown on page 84 of . . . http://www.aeroelectric.com/Reference_Docs/NASA/NASA-STD-8739p4c4.pdf Once the individual strands are joined and insulated, overlap the braid pigtails a half inch or so and lap solder them too. No individual insulation is called for on this final joint. Put a piece of heat-shrink over the finished splice. Shielding of these wires has a vanishingly small benefit for noise mitigation on these wires. Don't worry about loss of shielding integrity at the joint. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 28, 2009
At 10:56 AM 6/28/2009, you wrote: >As an additional data point, Garmin has a D-sub crimp and poke >contact P/N 336-00023-00 for standard density connectors that >accommodated an 18AWG wire. I've heard of those but never had an opportunity to use them. I'm sure there are other "nifty" solutions out there. I'll try to get my hands on some and look 'em over. I think I've heard of similar products from yesteryear. A larger diameter crimp/solder cup adapter would be quite elegant. Unfortunately, these devices seldom find their way into the Digikey or Radio Shack catalogs at attractive prices. Shade tree technicians are oft obliged to resort to processes adapted from the materials at hand. An as one can see from a study of the NASA handbook cited earlier, even the Big Guys have adopted some techniques we Poor Guys can duplicate. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 28, 2009
Subject: NASA docs
While searching the reference documents archives I'm reminded of this collection of NASA documents found on the 'net. I've compiled a library of useful publications and posted them to my website at: http://www.aeroelectric.com/Reference_Docs/NASA/ I'll invite any with an interest in the processes cited to add these documents to their library. In particular, check out the 1963 NASA wiring handbook that one of your fellow readers forwarded to me some months ago. This book was published two years after I got out of high school! It's an interesting adventure back in time but still rich in solid, simple-ideas. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 28, 2009
Thanks all - got it!. Now, off to the airport... Sam On Sun, Jun 28, 2009 at 10:25 AM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 09:03 AM 6/28/2009, you wrote: > > No - I saw that one and it's for shields. I was looking for something > similar for single conductor wire. > > It's no big deal. I was just looking for one of Bob's elegant soultions. > > > Sorry for the long delay in responding . . . I > wish there were an "elegant" solution. Obviously > the D-Sub pin is limited to the insertion of but > a single 20AWG wire. The task is to tap > into a few conductors in a manner that does not > result in the wire bundle taking on that > "rabbit satisfied snake" appearance. > > The lowest volume approach I can deduce is > to bare a short segment (1/4 to 3/8 inch) > of strands on wire to be tapped a couple > of inches from the end . . . > > > [image: Emacs!] > > Wrap the branch strands around the open gap, solder > and heat shrink. Then install the d-sub pin. > > [image: Emacs!] > > You probably want to have the spice occur outside > the back-shell of the connector. Stagger their > positions so that they don't "bulk up" a lump > in one place on the harness. > > Are you committed to 20AWG wire throughout? > 22AWG does this hat-dance a little better. > > > Bob . . . > > --------------------------------------- > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > --------------------------------------- > > ________________________________________________________________________________
Date: Jun 28, 2009
Subject: First Flight
My Appreciation to Bob and others on this list who helped me better understand electricity and its application to aircraft systems. The invaluable information I obtained on this forum was implemented into my RV-8A and my airplane flew for the first time today. The electrical system performed as expected and will continue to do so far into the future. Most of the info I got on this forum was not available elsewhere - or, at least, not without great difficulty. Thanks! Stan Sutterfield RV-8A N884P - Flying **************Make your summer sizzle with fast and easy recipes for the grill. (http://food.aol.com/grilling?ncid=emlcntusfood00000006) ________________________________________________________________________________
Date: Jun 28, 2009
Ha - I thought I was being gentle. My apology. Actually, I got an off forum email from him (his name is Mark) and we apologized to one another. Stan >Looks like we have another a**hole that refuses to include his >name. Could he be ashamed of it? >I got a nasty note from him off the forum for my comments on the forum. >Wonder what up with him? Gently my friend. This is after all a classroom with a broad spectrum of attendee needs and skill sets. The value of what we do here is not increased by prejudicial words. Let us strive to be teachers with a goal of working to everyone's satisfaction. Bob . . . **************Make your summer sizzle with fast and easy recipes for the grill. (http://food.aol.com/grilling?ncid=emlcntusfood00000006) ________________________________________________________________________________
Date: Jun 28, 2009
Subject: Re: First Flight
Congratulations Franz On 28/06/09 10:07 AM, "Speedy11(at)aol.com" wrote: > My Appreciation to Bob and others on this list who helped me better understand > electricity and its application to aircraft systems. The invaluable > information I obtained on this forum was implemented into my RV-8A and my > airplane flew for the first time today. The electrical system performed as > expected and will continue to do so far into the future. > Most of the info I got on this forum was not available elsewhere - or, at > least, not without great difficulty. > Thanks! > Stan Sutterfield > RV-8A N884P - Flying > > > Make your summer sizzle with fast and easy recipes > <http://food.aol.com/grilling?ncid=emlcntusfood00000006> for the grill. > > > > ________________________________________________________________________________
Date: Jun 28, 2009
Subject: Re: NASA docs
Bob, The current editions I teach from... http://www.hq.nasa.gov/office/codeq/doctree/87391.htm http://www.hq.nasa.gov/office/codeq/doctree/87392.htm http://www.hq.nasa.gov/office/codeq/doctree/87393.htm http://www.hq.nasa.gov/office/codeq/doctree/87394.htm Ron Q. At 09:44 6/28/2009, you wrote: >From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> > > > >While searching the reference documents archives I'm >reminded of this collection of NASA documents found on >the 'net. I've compiled a library of useful publications >and posted them to my website at: > >http://www.aeroelectric.com/Reference_Docs/NASA/ > > >I'll invite any with an interest in the processes >cited to add these documents to their library. In >particular, check out the 1963 NASA wiring handbook >that one of your fellow readers forwarded to me >some months ago. This book was published two years >after I got out of high school! It's an interesting >adventure back in time but still rich in solid, >simple-ideas. > > > Bob . . . ________________________________________________________________________________
Date: Jun 28, 2009
Congrats Stan! Now comes the fun part! Be careful during Phase 1. Bret Smith RV-9A N16BL Blue Ridge, Ga www.FlightInnovations.com <http://www.flightinnovations.com/> _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Speedy11(at)aol.com Sent: Sunday, June 28, 2009 1:08 PM Subject: AeroElectric-List: First Flight My Appreciation to Bob and others on this list who helped me better understand electricity and its application to aircraft systems. The invaluable information I obtained on this forum was implemented into my RV-8A and my airplane flew for the first time today. The electrical system performed as expected and will continue to do so far into the future. Most of the info I got on this forum was not available elsewhere - or, at least, not without great difficulty. Thanks! Stan Sutterfield RV-8A N884P - Flying _____ Make your summer sizzle with fast and easy <http://food.aol.com/grilling?ncid=emlcntusfood00000006> recipes for the grill. ________________________________________________________________________________
Subject: TCW product update: SmartStart
Date: Jun 28, 2009
Fellow RV builders, Just a quick update regarding our SmartStart product. We have added a new option for use with our SmartStart anti-theft and safety starting module. We now are offering SmartStart with an optional airspeed switch that allows for in-flight restarting without having to re-arm the system. The airspeed switch (ASW-2) is available as an add-on for those who have already installed a SmartStart module. We are also making the system available as package which includes the SmartStart module, wiring harness and an airspeed switch. All the details are available on our web site: www.tcwtech.com The product instruction sheet has been updated and is avialable for downloading from our web site. Thanks, Bob Newman TCW Technologies, LLC. ________________________________________________________________________________
Date: Jun 28, 2009
At 12:48 PM 6/28/2009, you wrote: >Bob, > >The current editions I teach from... > >http://www.hq.nasa.gov/office/codeq/doctree/87391.htm >http://www.hq.nasa.gov/office/codeq/doctree/87392.htm >http://www.hq.nasa.gov/office/codeq/doctree/87393.htm >http://www.hq.nasa.gov/office/codeq/doctree/87394.htm > >Ron Q. Thanks! I'll update my library as well as the website posting. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 28, 2009
At 12:07 PM 6/28/2009, you wrote: >My Appreciation to Bob and others on this list who helped me better >understand electricity and its application to aircraft systems. The >invaluable information I obtained on this forum was implemented into >my RV-8A and my airplane flew for the first time today. The >electrical system performed as expected and will continue to do so >far into the future. >Most of the info I got on this forum was not available elsewhere - >or, at least, not without great difficulty. >Thanks! >Stan Sutterfield >RV-8A N884P - Flying Outstanding! Post some pictures! Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
From: "Gordon Smith" <gordonrsmith921(at)yahoo.com>
Subject: Internally Regulated Alternator Control
Date: Jun 28, 2009
I have followed posts to the list regarding internally regulated alternators and it appears to me that all are not the same regarding regulator functions and connections. I am considering the use of an Eggenfellner E6.0 Subaru Auto conversion. The electrical system architecture will basically be Z-19. The Egg is supplied with an internally regulated alternator and their installation manual shows the following: ALTERNATOR CONNECTIONS - 4 1. B+ Lead Out - Large connection to Starter & Main Battery Contactor. 2. Fault - Goes to ground in case of alternator failure. For use of "idiot light". I suppose this could be used as a low voltage warning but I would opt for an active and separate warning system that could also control my aux battery contactor. 3. Sense - This is a short jumper to the B+ output terminal; I assume for voltage info to the internal regulator. (I also assume that sense and enable connections could be jumpered together and fed from the panel alternator master switch through the 5A CB controlled by the OV module.) 4. Enable - Clip From manual below: "5A Alternator Enable. To enable your alternator to produce charging current, this wire must be connected to a power source. This power source can be switched by the Master Switch or a subservient "Alternator" switch. People have come to know this function as an "alternator field", however that is a term that has lingered on from years ago. It is actually just an enable signal going to a solid-state voltage regulator inside the alternator. It knows only ON or OFF, not specific voltages in between. If you wish to have the ability to manually turn on and off the alternator, a switch should be provided. However, beware that turning an alternator on and off under heavy load can dramatically shorten the life of the alternator and cause substantial spikes and surges. If used, this switch should be left in the ON position, except when the alternator actually needs to be taken offline for some reason. For simplicity, this wire can simply be switched by the Master Switch or the Ignition Switch." End clip from manual. I would take this to indicate that the alternator can be shut down using this enable circuit, by switching off the 12V+ that goes to it. And therefore the Z-24 (&/or Z-24A) circuitry including the Alternator OV Disconnect Contactor would not have to be used. However, I believe that I have read on this list that these enable circuits will cause the alternator to power up when power is applied, but won't necessarily shut the alternator down when power is removed. Now I am confused. Is it possible/likely that the internally regulated alternator that Egg supplies will operate off and on through this "Enable" terminal; and all that one would need for OV protection (the manual does not say that the internal alternator regulator contains any circuitry for OV protection) is to add an OV module and 5A resettable CB in this circuit? Gordon Smith ________________________________________________________________________________
Date: Jun 28, 2009
Gongrats Stan! Which is more fun, T-38 or RV-8A? In my mind's eye.....a tough choice! Congratulations again! Brooke On Jun 28, 2009, at 1:07 PM, Speedy11(at)aol.com wrote: > My Appreciation to Bob and others on this list who helped me better > understand electricity and its application to aircraft systems. The > invaluable information I obtained on this forum was implemented into > my RV-8A and my airplane flew for the first time today. The > electrical system performed as expected and will continue to do so > far into the future. > Most of the info I got on this forum was not available elsewhere - > or, at least, not without great difficulty. > Thanks! > Stan Sutterfield > RV-8A N884P - Flying > > Make your summer sizzle with fast and easy recipes for the grill. > > ________________________________________________________________________________
Date: Jun 28, 2009
Subject: Re: Internally Regulated Alternator Control
At 03:28 PM 6/28/2009, you wrote: I have followed posts to the list regarding internally regulated alternators and it appears to me that all are not the same regarding regulator functions and connections. I am considering the use of an Eggenfellner E6.0 Subaru Auto conversion. The electrical system architecture will basically be Z-19. The Egg is supplied with an internally regulated alternator and their installation manual shows the following: ALTERNATOR CONNECTIONS - 4 1. B+ Lead Out Large connection to Starter & Main Battery Contactor. Yes . . . 2. Fault Goes to ground in case of alternator failure. For use of idiot light. I suppose this could be used as a low voltage warning but I would opt for an active and separate warning system that could also control my aux battery contactor. This was discussed earlier this week. The built-in alternator failure light does not comport with legacy design goals for separate and independent monitoring and warning of low voltage. The AEC9005 is discontinued but Eric Jones has a clone. We'll have a new replacement in the form of the AEC9011 later this year. Either approach will satisfy the legacy design goals for low voltage monitor and control. 3. Sense This is a short jumper to the B+ output terminal; I assume for voltage info to the internal regulator. (I also assume that sense and enable connections could be jumpered together and fed from the panel alternator master switch through the 5A CB controlled by the OV module.) Don't know. Does the alternator have a brand and part number on it? 4. Enable Clip From manual below: 5A Alternator Enable. To enable your alternator to produce charging current, this wire must be connected to a power source. This power source can be switched by the Master Switch or a subservient Alternator switch. People have come to know this function as an alternator field, however that is a term that has lingered on from years ago. It is actually just an enable signal going to a solid-state voltage regulator inside the alternator. It knows only ON or OFF, not specific voltages in between. This is characteristic of ALL internally regulated alternators. I.e. there are no stock provisions for absolute control over the field supply source. This is why both B&C and Plane Power opt for their own modifications of stock alternators to provide this functionality. If you wish to have the ability to manually turn on and off the alternator, a switch should be provided. However, beware that turning an alternator on and off under heavy load can dramatically shorten the life of the alternator and cause substantial spikes and surges. If used, this switch should be left in the ON position, except when the alternator actually needs to be taken off line for some reason. For simplicity, this wire can simply be switched by the Master Switch or the Ignition Switch. Almost . . . Under the legacy design goals for alternator control, turning the field supply line on and off while a battery is on line offers no particular risk to the alternator or the ship's electro-whizzies. Further, it's a design goal of any quality supplier of alternators that their product be able to withstand b-lead disconnects (load dumps) under hot, full load, high rpm conditions. So adding Z-24 style OV protection to the internally regulated alternator presents no operational hazard for two reasons . . . (1) there is no normal operating condition where turning an alternator OFF under heavy load using Z-24 is called for . . . but a quality alternator would not be at risk anyhow. (2) Z-24 style protection can be depended upon to do it's intended job should the admittedly rare OV event occur. I would take this to indicate that the alternator can be shut down using this enable circuit, by switching off the 12V+ that goes to it. And therefore the Z-24 (&/or Z-24A) circuitry including the Alternator OV Disconnect Contactor would not have to be used. Assuming the electronics of the internal regulator is functioning as designed, then external control by means of the little wire at the back is possible and predictable. But if the electronics fails (which is the definition of an OV event) then all bets are off. Legacy design goals call for separate and independent control over the alternator during an OV event . . . this is what drove the design philosophy for Z-24. Alternatively, you can modify your alternator to adopt the control philosophy adopted by Plane Power. However, I believe that I have read on this list that these enable circuits will cause the alternator to power up when power is applied, but wont necessarily shut the alternator down when power is removed. As far as anyone KNOWS, the control lead will always exert any time, ON/OFF control . . . as long as the internal electronics are intact. Further, exercising this control at any time under any conditions is not a risky thing to do as long as the battery is on line. This design goal is satisfied when you utilize the progressive transfer DC PWR MASTER switch architecture described in the Z-figures. Now I am confused. Is it possible/likely that the internally regulated alternator that Egg supplies will operate off and on through this Enable terminal; and all that one would need for OV protection (the manual does not say that the internal alternator regulator contains any circuitry for OV protection) is to add an OV module and 5A resettable CB in this circuit? If it were my airplane, I would add OV protection in the form of either Plane Power style modification or Z-24 interim to be replaced by the Z-24 final solution at a later time. Bob . . . ________________________________________________________________________________
Date: Jun 28, 2009
Congratulations, Stan! All the work come to fruition. Regards, Michael Wynn RV 8 FWF San Ramon, CA In a message dated 6/28/2009 10:14:31 A.M. Pacific Daylight Time, Speedy11(at)aol.com writes: My Appreciation to Bob and others on this list who helped me better understand electricity and its application to aircraft systems. The invaluable information I obtained on this forum was implemented into my RV-8A and my airplane flew for the first time today. The electrical system performed as expected and will continue to do so far into the future. Most of the info I got on this forum was not available elsewhere - or, at least, not without great difficulty. Thanks! Stan Sutterfield RV-8A N884P - Flying ____________________________________ Make your summer sizzle with _fast and easy recipes_ (http://food.aol.com/grilling?ncid=emlcntusfood00000006) for the grill. (http://www.matronics.com/Navigator?AeroElectric-List) (http://www.matronics.com/contribution) **************An Excellent Credit Score is 750. See Yours in Just 2 Easy Steps! eExcfooterNO62) ________________________________________________________________________________
Date: Jun 29, 2009
Subject: Noise Problem
Hello All, I hooked up my first headset yesterday. I have multiple audio sources mixed using an AMX-2A mixer from Vx Aviation feeding into a Flightcom 403 intercom. My 496 GPS told me when I turned off the power, my Traffic Watch that it was online and my EFIS told me voltage was low. My SL30 radio transmitted too, strength 5 and no noise! What a thrill the radio worked out of the box and all that spaghetti was actually functional! One caveat. I could hear the inner workings of my AFS 3500 EFIS. Can anyone help me with identifying the usual suspects that may assist me in tracking down and eliminating the source of the noise? Best regards, Andrew Butler, RV7 EI-EEO Galway, Ireland. ________________________________________________________________________________
Subject: =?us-ascii?Q?Electric_dependent_Engine_-_Pucker_Factor=3F?
Date: Jun 29, 2009
I have been following the posts on this list for a year or so and 'Lectric Bob's writings for maybe 10 years. This has led to my understanding of failure tolerant design, so that if any part fails (as any part can and will) you go to plan"B" with out needing to raise a sweat. Not considered as possible failures in this case are such things as prop bolts, wing struts, connecting rods and the like. I am considering the use of an Eggenfellner E6.0 Subaru Auto conversion. The electrical system architecture will basically be Z-19. There are electrical system designs that are very failure tolerant even for electrically dependent engines. And there are more and more of these electrically dependent engines being used all the time. But usually you have 2 fuel pumps, 2 electrical paths to the fuel injection/electronic ignition, etc. The Egg has 1 ECU (Engine Control Unit) computer. Without it functioning the fan out front does not rotate. It is a computer whose heart is a microprocessor. Is a microprocessor in the same league as a prop bolt for reliability? This is a single point of failure regardless of how many electrical feed paths are designed to feed it. What is the reliability of a microprocessor; does it approach a zero failure rate similar to a prop bolt or an RG battery? What is the answer for this? Simply accept it and increase the pucker factor? Also, I think that I have seen Bob mention that he might be publishing a Z-19 modification, specific to the Egg requirements and also some potential pre-flight checklist recommendations for Z-19 and perhaps other designs, Has this been done and I have missed it? ________________________________________________________________________________
Subject: Head Set Jacks Location
Date: Jun 29, 2009
6/29/2009 Hello Angier, You wrote: "..... behind the pilot/co-pilot seatback ......" Congratulations. After decades of flying many different types of aircraft with many different locations for the head set jacks I came to the conclusion that locating the jacks behind the pilot and copilot seats was the best solution. I built my airplane that way and it has worked great. When the pilot's jacks are behind the copilot's seat and the copilot's jacks are behind the pilot's seat it makes it possible to both see and manipulate the plugs while seated and strapped into your seat. I have used this benefit many times. Also the plugs are not banging into your knees while plugged into the instrument panel and the wires are not dangling across your lap. 'OC' Says: "The best investment we can make is the effort to gather and understand knowledge." ===================================== From: "Angier M. Ames" <N4ZQ(at)comcast.net> Subject: AeroElectric-List: Re: Splicing of 2 or 3 conductor shielded cable I am relocating the comm and mic jacks in my Lancair to a position behind the pilot/co-pilot seatback and so the comm and mic cables need to be lengthened. Any suggestions here for what would be the best method for splicing additional length to these cables and also maintaining the integrity of the shields? Thanks ________________________________________________________________________________
Subject: Electric dependent Engine - Pucker Factor?
Date: Jun 29, 2009
Hi Gordon, Been flying with my all-electric rotary for over 10 years I originally used an aftermarket HALTECH F3 unit (single CPU, but did have a mixture control) ' it failed after 2 =BD years ' fortunately while doing a run-up on the ground. I have since flow with a dual CPU EFI system and while I firmly believe a microchip (if operated within its intended environment is about as safe and reliable as anything can be), I feel more comfortable, knowing at the flick of a switch I have a back up. The backup does reduce the pucker factor -even thought I=92ve never had to use it. So probably does not answer your question, but just wanted to share real-world experience with you. Ed Ed Anderson Rv-6A N494BW Rotary Powered Matthews, NC eanderson(at)carolina.rr.com <http://www.andersonee.com> http://www.andersonee.com <http://www.dmack.net/mazda/index.html> http://www.dmack.net/mazda/index.html http://www.flyrotary.com/ <http://members.cox.net/rogersda/rotary/configs.htm> http://members.cox.net/rogersda/rotary/configs.htm#N494BW http://www.rotaryaviation.com/Rotorhead%20Truth.htm <http://www.dmack.net/mazda/index.html> _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Gordon Smith Sent: Monday, June 29, 2009 5:55 AM Subject: AeroElectric-List: Electric dependent Engine - Pucker Factor? I have been following the posts on this list for a year or so and =91Lectric Bob=92s writings for maybe 10 years. This has led to my understanding of failure tolerant design, so that if any part fails (as any part can and will) you go to plan=94B=94 with out needing to raise a sweat. Not considered as possible failures in this case are such things as prop bolts, wing struts, connecting rods and the like. I am considering the use of an Eggenfellner E6.0 Subaru Auto conversion. The electrical system architecture will basically be Z-19. There are electrical system designs that are very failure tolerant even for electrically dependent engines. And there are more and more of these electrically dependent engines being used all the time. But usually you have 2 fuel pumps, 2 electrical paths to the fuel injection/electronic ignition, etc. The Egg has 1 ECU (Engine Control Unit) computer. Without it functioning the fan out front does not rotate. It is a computer whose heart is a microprocessor. Is a microprocessor in the same league as a prop bolt for reliability? This is a single point of failure regardless of how many electrical feed paths are designed to feed it. What is the reliability of a microprocessor; does it approach a zero failure rate similar to a prop bolt or an RG battery? What is the answer for this? Simply accept it and increase the pucker factor? Also, I think that I have seen Bob mention that he might be publishing a Z-19 modification, specific to the Egg requirements and also some potential pre-flight checklist recommendations for Z-19 and perhaps other designs, Has this been done and I have missed it? __________ Information from ESET NOD32 Antivirus, version of virus signature database 3267 (20080714) __________ The message was checked by ESET NOD32 Antivirus. _____ ________________________________________________________________________________
Date: Jun 29, 2009
Subject: Re: Electric dependent Engine - Pucker Factor?
Gordon. Tracy Crook has his EC3 fuel injection/ignition controller and he may have a version that will work for you. The EC3 has two independent controllers mounted on a single board in a single box. Here is the link: http://www.rotaryaviation.com/eficont.html Tracy is out of town through the end of July, but his business partner, Laura, is providing some support while he's gone. Regards, Sam Hoskins On Mon, Jun 29, 2009 at 4:55 AM, Gordon Smith wr ote: > I have been following the posts on this list for a year or so and > =91Lectric Bob=92s writings for maybe 10 years. This has led to my > understanding of failure tolerant design, so that if any part fails (as a ny > part can and will) you go to plan=94B=94 with out needing to raise a swea t. Not > considered as possible failures in this case are such things as prop bolt s, > wing struts, connecting rods and the like. > > > I am considering the use of an Eggenfellner E6.0 Subaru Auto conversion. > The electrical system architecture will basically be Z-19. > > > There are electrical system designs that are very failure tolerant even f or > electrically dependent engines. And there are more and more of these > electrically dependent engines being used all the time. But usually you > have 2 fuel pumps, 2 electrical paths to the fuel injection/electronic > ignition, etc. > > > The Egg has *1 *ECU (Engine Control Unit) computer. Without it > functioning the fan out front does not rotate. It is a computer whose he art > is a microprocessor. > > Is a microprocessor in the same league as a prop bolt for reliability? > > > This is a single point of failure regardless of how many electrical feed > paths are designed to feed it. What is the reliability of a microprocess or; > does it approach a zero failure rate similar to a prop bolt or an RG > battery? > > > What is the answer for this? Simply accept it and increase the pucker > factor? > > > Also, I think that I have seen Bob mention that he might be publishing a > Z-19 modification, specific to the Egg requirements and also some potenti al > pre-flight checklist recommendations for Z-19 and perhaps other designs, > Has this been done and I have missed it? > > > * > =========== =========== =========== =========== > * > > ________________________________________________________________________________
Date: Jun 29, 2009
At 04:55 AM 6/29/2009, you wrote: >I have been following the posts on this list for a year or so and >'Lectric Bob's writings for maybe 10 years. This has led to my >understanding of failure tolerant design, so that if any part fails >(as any part can and will) you go to plan"B" with out needing to >raise a sweat. Not considered as possible failures in this case are >such things as prop bolts, wing struts, connecting rods and the like. > >I am considering the use of an Eggenfellner E6.0 Subaru Auto >conversion. The electrical system architecture will basically be Z-19. > >There are electrical system designs that are very failure tolerant >even for electrically dependent engines. And there are more and >more of these electrically dependent engines being used all the >time. But usually you have 2 fuel pumps, 2 electrical paths to the >fuel injection/electronic ignition, etc. > >The Egg has 1 ECU (Engine Control Unit) computer. Without it >functioning the fan out front does not rotate. It is a computer >whose heart is a microprocessor. >Is a microprocessor in the same league as a prop bolt for reliability? Probably not . . . but they CAN be pretty good. How's that for a non-quantified answer? Reliability is an oft discussed topic here on the List. When we speak of reliability in the military or TC aircraft world, the discussion necessarily includes a study of failure rates for individual components (taken from a handbook written by folks who purport to know such things). The last reliability study I witnessed in my career involved the mathematical analysis of all the pieces and parts that went into the fabrication of a super-sonic target we were building for the Navy . . . http://www.ordnance.org/aqm37c.htm We expended perhaps 1000 man-hours compiling the data and publishing a report. I don't recall now what the numbers were. I don't put much credence in such activities. They are exercises in bureaucratic process that make bureaucrats happy . . .. and they paid us for it! Bottom line is that most such systems, if they are crafted with legacy products by skilled workers and screened for defects at time of manufacture will perform as advertised with low risk of failure. There's that non-quantified "low" thing again. But suppose Eggenfellner spent $100,000 and produced a detailed reliability study of the system as installed per his instructions posted at: http://www.eggenfellneraircraft.com/electrical.htm Suppose further that he offered a number of 1.6 failures per million flight hours. How would you use that number? If you have competing suppliers and the other guy says his gizmo has only 0.8 failures per million flight hours, would you pay double the cost to get double the "reliability"? Further, the past week's discussion on a Subaru powered RV-10 crash vividly illustrates that a system with 1 failure per trillion flight hours isn't worth beans if you don't craft power sources with similarly impressive numbers. > >What is the answer for this? Simply accept it and increase the pucker factor? Being a diligent observer of demonstrated service history is a good place to start. I've been chastised soundly on this List for suggesting that my observations of B&C's return products was not a proper expression of "reliability". I was able to offer from first hand experience that with thousands of devices in service, his return rates were on the order of 1-2 units per month for repair of user induced damage. I observed no returns for failure of the product. Not being inclined to spend $100,000 on a formal reliability study, I suggested that those observations were encouraging . . . especially since we knew how to produce failure tolerant systems that did not depend on a functioning alternator for comfortable termination of flight. > >Also, I think that I have seen Bob mention that he might be >publishing a Z-19 modification, specific to the Egg requirements and >also some potential pre-flight checklist recommendations for Z-19 >and perhaps other designs, Has this been done and I have missed it? Some years ago I had some discussion with Eggenfellner about a product-specific Z-figure. I don't remember details of the conversation now except that the idea was not received with enough enthusiasm for the project to move forward. The Eggenfellner website gives us lip-service for a resource on technique but includes a statement, "Avoid being lured into thinking that you can create your own alternative to the EXPBUS and save time and money." I've studied the EXPBUS (and similar products) and written about them extensively. It's easy to demonstrate that they DO NOT save money. You can search aeroelectric.com for those discussions. At the same time, Eggenfellner's instructions are painstakingly crafted and well illustrated. I have no first hand knowledge as to how many of these systems are flying nor do I know the history of field service problems. Queries to the various Lists have to be your most useful places to put a dipstick into tribal knowledge. But be aware that while dark-n-stormy night stories abound in aviation, few tellers of such stories understand the simple ideas nor do they always have access to the facts of reported failures. While there are things in the Eggenfellner design I would not embrace, it's his kitchen, his recipe for success, and his reputation on the line. If you want to go the Z-19 route, then let's talk about it here on the list and tap the grey matter and experience of the membership. So what ever stories you uncover, bring them to the AeroElectric List for the assistance of many minds who are skilled at sifting significance out of the noise. Given the demonstrated service history of automotive engine controllers (in environments much more stressful than under your cowl) I'll suggest that concerns for the hardware are probably not well founded. These pieces of hardware perform long and hard for thousands of hours over the lifetime of the vehicle. It is more likely that your unhappy day in the cockpit will arise from failure to exercise due diligence in the crafting or maintaining your electrical system . . . or still more likely from venturing into a flight situation beyond the abilities of you or your airplane. There are plenty of nice ol' Lycomings out there with a huge history of demonstrated performance that doesn't seem to discourage many of our ranks from launching into the blue behind them. Bottom line is that the risks are never zero. We can only do our best to mitigate those risks to acceptable levels. If you're really worried about it . . . then don't do it. A worried pilot with a good system is probably at greater risk than a skilled and thoughtful pilot with a mediocre system. Your likelihood of walking away from an unplanned arrival with the earth has little to do with reliability numbers and a lot to do with how you approach duties as pilot, designer and maintainer of the airplane. This fact has been demonstrated countless times throughout the history of aviation. This is why accident rates for OBAM aircraft are pretty much in step with accident rates in TC aircraft. Both sets of pilots run off the same runways, fly into the same mountains, run the same batteries to destruction . . . or fail to tighten the same oil drain plug. Bob . . . ________________________________________________________________________________
Date: Jun 29, 2009
Subject: Re: Noise Problem
At 03:52 AM 6/29/2009, you wrote: > > >Hello All, > >I hooked up my first headset yesterday. I have multiple audio >sources mixed using an AMX-2A mixer from Vx Aviation feeding into a >Flightcom 403 intercom. My 496 GPS told me when I turned off the >power, my Traffic Watch that it was online and my EFIS told me >voltage was low. My SL30 radio transmitted too, strength 5 and no >noise! What a thrill the radio worked out of the box and all that >spaghetti was actually functional! > >One caveat. I could hear the inner workings of my AFS 3500 EFIS. Can >anyone help me with identifying the usual suspects that may assist >me in tracking down and eliminating the source of the noise? Do you have a copy of the 'Connection? There's an extensive chapter on noise mitigation that offers a good start for your investigation Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 29, 2009
Subject: RE: Lee KR-2 System Architecture
At 05:51 PM 6/26/2009, you wrote: > >Lectric Bob asked: > > Have you done a load analysis on minimum > energy requirements for sustained flight? Exactly > how many watt-seconds of energy per flight hour are > needed to run your engine? > >Don't have watt-seconds/flight-hour but there is a spread sheet with amps >required in various flight modes. Here's a link to my electrical system >design documentation. > >http://kr.flyboybob.com/web_pages/kr2/electrical%20and%20instrument/electrical.htm >At the bottom of the page there are links to the wiring diagrams. Okay, I've got you drawing. Let me pray over it for a few days . . . Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 29, 2009
On 6/29/2009 11:26 AM, Robert L. Nuckolls, III wrote: > But suppose Eggenfellner spent $100,000 and > produced a detailed reliability study of the > system as installed per his instructions > posted at: > > http://www.eggenfellneraircraft.com/electrical.htm Just fyi, those are an older set of wiring instructions for the Eggenfellner package. The latest instructions can be found at <http://www.eggenfellneraircraft.com/ESeriesInstallationGuide.pdf> starting on page 45 with other references for the package at <http://www.eggenfellneraircraft.com/iindex.htm> > The Eggenfellner website gives us lip-service > for a resource on technique but includes a > statement, "Avoid being lured into thinking that > you can create your own alternative to the EXPBUS > and save time and money." Please note that the current wiring instructions are quite different from the old, and do not include the EXPBUS. Refer to page 51 for a schematic. fyi -Dj -- Dj Merrill - N1JOV Sportsman 2+2 Builder #7118 N421DJ http://deej.net/sportsman/ "Many things that are unexplainable happen during the construction of an airplane." --Dave Prizio, 30 Aug 2005 ________________________________________________________________________________
Date: Jun 29, 2009
At 10:52 AM 6/29/2009, you wrote: > > Just fyi, those are an older set of wiring instructions for the >Eggenfellner package. The latest instructions can be found at > ><http://www.eggenfellneraircraft.com/ESeriesInstallationGuide.pdf> > >starting on page 45 with other references for the package at ><http://www.eggenfellneraircraft.com/iindex.htm> Interesting! Thank you. At first blush, it looks like a lower parts count, 'leaner' architecture. I'll look it over in more detail later. Appreciate the heads-up . . . Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 29, 2009
Dr. Bob, I also have a noise problem. I do indeed have a copy of the "Connection" and have what you might have described as a "Really off the wall problem". I wonder if you or any of your "listeners" would have a clue. My RV-9A has a Garmin GNX300 XL GPS/Com, a Narco AT165 transponder, a Dynon EFIS D10A, and a Rocky Mountain enging micromonitor. The comms are routed through a Flightcomm 403. The power distribution is through an EXP2BUS. In flight I get an irregular clankety-clank noise in both headsets that sounds like someone whacking a rudder cable against the fuselage but it's electrical. When I remove the headset and listen to the cabin noise, all I hear is a louder engine noise. It's all about the same pitch, but almost sounds almost like some form of sparking or discharging. There is no whining or other noise, and this seems to only happen when the engine in running (i.e. most of the time). The sound reduces when I turn down the volume, and goes away when I "isolate" the pilot from the passenger on the Flightcomm 403 with the "ICS/Isolate" switch. This is such a unique noise I just wondered if anyone else had heard it or heard of it. Thanks in advance for any of your wisdom. Ian Brown, Bromont Quebec > > At 03:52 AM 6/29/2009, you wrote: > > > > > >Hello All, > > > >I hooked up my first headset yesterday. I have multiple audio > >sources mixed using an AMX-2A mixer from Vx Aviation feeding into a > >Flightcom 403 intercom. My 496 GPS told me when I turned off the > >power, my Traffic Watch that it was online and my EFIS told me > >voltage was low. My SL30 radio transmitted too, strength 5 and no > >noise! What a thrill the radio worked out of the box and all that > >spaghetti was actually functional! > > > >One caveat. I could hear the inner workings of my AFS 3500 EFIS. Can > >anyone help me with identifying the usual suspects that may assist > >me in tracking down and eliminating the source of the noise? > > Do you have a copy of the 'Connection? There's > an extensive chapter on noise mitigation that offers a > good start for your investigation > > > Bob . . . > > --------------------------------------- > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > --------------------------------------- > > > > > > ________________________________________________________________________________
Subject: Battery failure
From: "tomcostanza" <Tom(at)CostanzaAndAssociates.com>
Date: Jun 29, 2009
I have read a lot on this forum about alternator failures and e-busses and backup alternators. Is it possible that the battery can fail in a way that short circuits the bus, causing a total power failure? If so, is there sufficient probably that I should design around that? My RV will be equipped for light IFR, and I'll have an e-bus with sufficient reserve to fly for an hour after an alternator failure. I may add a 2nd alternator at some point, but for now, just a single battery/alternator. -------- Clear Skies, Tom Costanza Read this topic online here: http://forums.matronics.com/viewtopic.php?p=250646#250646 ________________________________________________________________________________
Subject: Time to Battery Exhaustion: RE: Lee KR-2 System Architecture
Date: Jun 29, 2009
Having had some recent real-world experience with battery exhaustion, I though some of you might be interested in actual flight duration with all systems on - until the battery voltage dropped below that necessary to run crucial flight systems. Without going into the "why it happened - switch in wrong place, deficient design" as that has already been posted to this forum, rather this is the following systems I had on during the period of battery-only powered flight: 1. Engine started from battery (naturally) after refueling - no recharging after start - due to switch in wrong position. 2. Two 50 watt Landing lights ON (my normal practice for take off and landing) 3. Two High pressure EFI fuel pumps (probably drawing 4-5 amps each) 4. One 6 psi boost pump 5. 4 electronic fuel injectors 6. 2 ignition modules 7. 1 radio 8. 1 transponder 9. 1 Gps 10. 1 Strobe light on I took off with a 1 1/2 year old PC 680 Odyssey battery (which as I mentioned above did not get alternator recharge after engine start - so was somewhat depleted). I took off and flew for 45 minutes before (dropping battery voltage) started to manifest itself in undesirable and very noticeable ways. Approx 50 minutes after take off I found the engine would no longer run - prop stopped. Approx 54 minutes after take off while in engine-out glide to Craig Field, Selma, Al. The master relay (held closed by battery voltage) gave up and removed the alternator and therefore all power from the system. Dead panel, dead engine - rather lonely. Did get one radio call off before panel went dead. No - low battery voltage will not show up if your voltmeter and low voltage warning LED happens to be on the alternator circuit and the battery is disconnected from the alternator - which is one of the reasons I had problem convincing myself it was anything other than a fuel problem - but, it was solely electrical, inadvertently (you don't think I did it on purpose do you?) induced by the pilot and supported by a design deficiency - no isolation diode between battery and alternator only a switch(which ended up in the wrong position). Next morning, once switch was placed in the proper position (connecting battery to alternator) a test flight was made and all checked out and I continued on to Texas. Flew back with no incident. However, I doubt the battery would do as well a second time as the voltage had dropped to 6 volts by the time I checked on the ground. From what I understand is that once a battery undergoes that degree of discharge, its capacity is less than it was. The battery is rated at 17 AH, don't know how much the engine start drained but at 400 amp for say 5 second for engine start = 0.55 amp-hour leaving theoretically 16.45 amp hour in the battery. Flew for 45 minutes before the dropping voltage started undesirable things happening so 45/60 = .75 hour of battery powered flight. That theoretically would indicate a 16.45/.75 = 21 amp/hour load. Clearly lots of estimation here but that load (with two 50 watt landing lights on) does not seem unreasonable to me. YMMV But all things considered - the battery did a credible job of lasting as long as it did. Just wanted to post a real world example of battery power duration. Lessons learned - stick in the isolation diode so battery will get alternator juice regardless of essential bus switch position - Put check of Essential bus switch on emergency as well as regular check list - Don't fixate on what you "THINK" the problem is, check both fuel and electrical Ed Anderson Rv-6A N494BW Rotary Powered Matthews, NC eanderson(at)carolina.rr.com http://www.andersonee.com http://www.dmack.net/mazda/index.html http://www.flyrotary.com/ http://members.cox.net/rogersda/rotary/configs.htm#N494BW http://www.rotaryaviation.com/Rotorhead%20Truth.htm __________ Information from ESET NOD32 Antivirus, version of virus signature database 3267 (20080714) __________ The message was checked by ESET NOD32 Antivirus. ________________________________________________________________________________
Date: Jun 29, 2009
As reliable as ecu's are, solid state electronics and wiring often don't give much warning before failing. So I opted for Z-14 with a second independent engine control system running off the second electrical system. At 300 hours I too have never needed it. It is handy for troubleshooting as well as pucker minimization. In the past, a manual backup valve to feed fuel into the intake manifold was mentioned. Another thought would be a switch (and diodes) to ground all the injectors low side. On an installation with separate backup ignition, positive voltage supply to the injectors, and positive fuel pump control, that will keep the engine running as long as the throttle is kept at near a cruise setting or higher, even after a total EFI system electronic failure. Certainly simpler, if less elegant in operation, than my second ecu system. A robust exhaust system would be in order and of course the challenge of implementing it without reducing primary system reliability. Ken Gordon Smith wrote: > I have been following the posts on this list for a year or so and > Lectric Bobs writings for maybe 10 years. This has led to my > understanding of failure tolerant design, so that if any part fails (as > any part can and will) you go to planB with out needing to raise a > sweat. Not considered as possible failures in this case are such things > as prop bolts, wing struts, connecting rods and the like. > ________________________________________________________________________________
Date: Jun 29, 2009
I have a noise in the Flightcomm 403 intercom that I would describe as a snare drum. It goes away when the squelch is adjusted. John Ian wrote: > > Dr. Bob, > I also have a noise problem. I do indeed have a copy of the > "Connection" and have what you might have described as a "Really off the > wall problem". I wonder if you or any of your "listeners" would have a > clue. > > My RV-9A has a Garmin GNX300 XL GPS/Com, a Narco AT165 transponder, a > Dynon EFIS D10A, and a Rocky Mountain enging micromonitor. The comms > are routed through a Flightcomm 403. The power distribution is through > an EXP2BUS. > > In flight I get an irregular clankety-clank noise in both headsets that > sounds like someone whacking a rudder cable against the fuselage but > it's electrical. When I remove the headset and listen to the cabin > noise, all I hear is a louder engine noise. > ________________________________________________________________________________
Date: Jun 29, 2009
Subject: Re: Battery failure
At 01:39 PM 6/29/2009, you wrote: > > >I have read a lot on this forum about alternator failures and >e-busses and backup alternators. Is it possible that the battery >can fail in a way that short circuits the bus, causing a total power failure? No. We used to see the occasional shorted cell in flooded batteries. This could cause a 12 volt battery to become a 10 volt battery. Remaining good cells then suffered overcharging. RG batteries don't do this. > If so, is there sufficient probably that I should design around that? No >My RV will be equipped for light IFR, and I'll have an e-bus with >sufficient reserve to fly for an hour after an alternator >failure. I may add a 2nd alternator at some point, but for now, >just a single battery/alternator. Start out with Z-11 which is easily morphed to Z-13/8 at a later time. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 29, 2009
AeroElectric-List message posted by: What I have read on this list is that yes, batteries fail, but historically dead shorts are rare and worries are few. Thus, large ANL protection (200 amp) between battery and contactor are deemed unnecessary. Correct. If current limiters are found in battery circuits, they are to protect WIRES from the fault currents that can flow (1000+ amps) when a battery becomes the SOURCE driving a HARD FAULT. I have discussed this same topic recently with my mechanics. They have indicated heat is a real danger of Mr. Battery. Extreme amounts of it can and will cause dead shorts internally (I've yet to experience one). Thus, if I am to keep Mr. Battery on the firewall I am ill advised to protect it with shielding, venting and ANL fuse to keep it from going poof. RG batteries contain a relatively small amount of moisture compared to the flooded cells of yesteryear. When an RG battery is deliberately abused by either hard fault or overcharge, the manufacturer is well advised to design cases to withstand over-pressures (typically 2 PSI) whereupon the vent valves open and the battery goes "sssssss" not "boom". I used to have running conversations with the Navy's battery test facilities in Crane Indiana where EVERY battery in Navy inventory and many other batteries were test for worst case outcomes in horrible failure modes. Our friends at Concorde were routinely subject to Crane's House of Battery Horrors to verify their suitability to task in military programs. It's an easy and not terribly expensive thing to try for yourself. Hook 3 golf cart 6v batteries in series and hook 17 a.h. RG in parallel with it. Thermocouple the battery, watch the current as the 18v source "cooks" the 12v battery. Test #2 calls for throwing a dead short across the same fully charged battery and tracking temperatures and currents. Early on in the history of all batteries, there were some spectacular outcomes for these tests. However, given the ubiquitous presence of the SVLA battery in everything from video cameras to toys to airplanes to submarines, the family of suppliers have pretty much all become righteous citizens. When you see fuses in series with batteries, it's to protect external things from the energy the batteries contain . . . not vice versa. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 29, 2009
Subject: Re: Time to Battery Exhaustion
Having had some recent real-world experience with battery exhaustion, I though some of you might be interested in actual flight duration with all systems on - until the battery voltage dropped below that necessary to run crucial flight systems. Next morning, once switch was placed in the proper position (connecting battery to alternator) a test flight was made and all checked out and I continued on to Texas. Flew back with no incident. However, I doubt the battery would do as well a second time as the voltage had dropped to 6 volts by the time I checked on the ground. From what I understand is that once a battery undergoes that degree of discharge, its capacity is less than it was. This is why the Z-figures and other writings in the 'Connection suggest ACTIVE NOTIFICATION OF LOW VOLTAGE on the main bus. When you turn the battery master on before cranking the engine, that light is an irritating feature on the panel and remains so until the alternator comes on to boost the bus above 13.0 volts. The battery is rated at 17 AH, don't know how much the engine start drained but at 400 amp for say 5 second for engine start = 0.55 amp-hour leaving theoretically 16.45 amp hour in the battery. Flew for 45 minutes before the dropping voltage started undesirable things happening so 45/60 = .75 hour of battery powered flight. That theoretically would indicate a 16.45/.75 = 21 amp/hour load. Clearly lots of estimation here but that load (with two 50 watt landing lights on) does not seem unreasonable to me. See . . . http://www.aeroelectric.com/Pictures/Curves/17AH_12V_Capacity_vs_Load.gif The typical 17 a.h. battery being discharged in 40 minutes when presented with a 17A load. This yields a useful capacity on the order of 17 x 0.7 or 12 ampere hours. But all things considered - the battery did a credible job of lasting as long as it did. Just wanted to post a real world example of battery power duration. Lessons learned - stick in the isolation diode so battery will get alternator juice regardless of essential bus switch position. Without seeing your power distribution diagram, I'm not sure what the "isolation diode" is about. Active and irritating notification of low voltage becomes a expected event that cannot missed or ignored. I requires no training and/or checklist activity for making sure things are up and running before flight. Bob . . . ________________________________________________________________________________
Date: Jun 30, 2009
Hi Bob, The "isolation diode" was a poor choice of words for the schokkty battery feed diode between alternator power and the essential bus battery circuit. If I had installed that diode 10 years ago (per your design) then having the switch in the wrong position wouldn't have affected the ability of the battery to get alternator voltage. The problem with my "low voltage warning" indicator (both LED and Voltmeter) was they were on the alternator circuit and NOT the battery. Since the alternator was working fine and continued to produce power (until the dropping battery voltage opened the master relay), these two devices never indicated low voltage. IF I had thought to switch the voltmeter to the battery then I would likely have noticed the decreasing battery voltage. Thanks for the battery drain curve, appears my system does not have as much current drain as I had estimated. Also looks like the powered required for starting did not much affect the duration. Ed Ed Anderson Rv-6A N494BW Rotary Powered Matthews, NC eanderson(at)carolina.rr.com http://www.andersonee.com http://www.dmack.net/mazda/index.html http://www.flyrotary.com/ http://members.cox.net/rogersda/rotary/configs.htm#N494BW http://www.rotaryaviation.com/Rotorhead%20Truth.htm -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Tuesday, June 30, 2009 12:20 AM Subject: AeroElectric-List: Re: Time to Battery Exhaustion Having had some recent real-world experience with battery exhaustion, I though some of you might be interested in actual flight duration with all systems on - until the battery voltage dropped below that necessary to run crucial flight systems. Next morning, once switch was placed in the proper position (connecting battery to alternator) a test flight was made and all checked out and I continued on to Texas. Flew back with no incident. However, I doubt the battery would do as well a second time as the voltage had dropped to 6 volts by the time I checked on the ground. From what I understand is that once a battery undergoes that degree of discharge, its capacity is less than it was. This is why the Z-figures and other writings in the 'Connection suggest ACTIVE NOTIFICATION OF LOW VOLTAGE on the main bus. When you turn the battery master on before cranking the engine, that light is an irritating feature on the panel and remains so until the alternator comes on to boost the bus above 13.0 volts. The battery is rated at 17 AH, don't know how much the engine start drained but at 400 amp for say 5 second for engine start = 0.55 amp-hour leaving theoretically 16.45 amp hour in the battery. Flew for 45 minutes before the dropping voltage started undesirable things happening so 45/60 = .75 hour of battery powered flight. That theoretically would indicate a 16.45/.75 = 21 amp/hour load. Clearly lots of estimation here but that load (with two 50 watt landing lights on) does not seem unreasonable to me. See . . . http://www.aeroelectric.com/Pictures/Curves/17AH_12V_Capacity_vs_Load.gif The typical 17 a.h. battery being discharged in 40 minutes when presented with a 17A load. This yields a useful capacity on the order of 17 x 0.7 or 12 ampere hours. But all things considered - the battery did a credible job of lasting as long as it did. Just wanted to post a real world example of battery power duration. Lessons learned - stick in the isolation diode so battery will get alternator juice regardless of essential bus switch position. Without seeing your power distribution diagram, I'm not sure what the "isolation diode" is about. Active and irritating notification of low voltage becomes a expected event that cannot missed or ignored. I requires no training and/or checklist activity for making sure things are up and running before flight. Bob . . . __________ Information from ESET NOD32 Antivirus, version of virus signature database 3267 (20080714) __________ The message was checked by ESET NOD32 Antivirus. __________ Information from ESET NOD32 Antivirus, version of virus signature database 3267 (20080714) __________ The message was checked by ESET NOD32 Antivirus. ________________________________________________________________________________
Date: Jun 30, 2009
> >It's all about the same pitch, but almost sounds almost like some form >of sparking or discharging. > >There is no whining or other noise, and this seems to only happen when >the engine in running (i.e. most of the time). The sound reduces when I >turn down the volume, and goes away when I "isolate" the pilot from the >passenger on the Flightcomm 403 with the "ICS/Isolate" switch. > >This is such a unique noise I just wondered if anyone else had heard it >or heard of it. > >Thanks in advance for any of your wisdom. What is the repetition rate for the noise. How many times per minute. Its it a regular rate or random? Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 30, 2009
At 07:09 AM 6/30/2009, you wrote: > > >Hi Bob, > >The "isolation diode" was a poor choice of words for the schokkty battery >feed diode between alternator power and the essential bus battery circuit. >If I had installed that diode 10 years ago (per your design) then having the >switch in the wrong position wouldn't have affected the ability of the >battery to get alternator voltage. I'm still not getting a mental image of how you had it wired. How does the existence or lack of the diode affect connection between battery and alternator? >The problem with my "low voltage warning" indicator (both LED and Voltmeter) >was they were on the alternator circuit and NOT the battery. Since the >alternator was working fine and continued to produce power (until the >dropping battery voltage opened the master relay), these two devices never >indicated low voltage. IF I had thought to switch the voltmeter to the >battery then I would likely have noticed the decreasing battery voltage. So have (or are you planning) you movee the low voltage sensing point in your system? Could you sketch and scan the distribution system and share with us? Normally, alternator has no way NOT to charge the battery if the engine is running -AND- both the alternator and battery control circuits are closed. I'm having trouble visualizing how "both were functioning" but the alternator was still not connected to the battery. >Thanks for the battery drain curve, appears my system does not have as much >current drain as I had estimated. Also looks like the powered required for >starting did not much affect the duration. While starters take a lot of POWER it is for just a few seconds. The total ENERGY is quite low. Even in large aircraft, the percentage of battery energy used to start is a small fraction of the total. In this start current curve we took off a Beechjet . . . http://www.aeroelectric.com/Pictures/Curves/turbine_start_a.jpg . . . it takes about 20 seconds for cranking current to taper from 800A to 300A and another 7 seconds to go to zero. Yet this 44 a.h. battery is tapped for only 5 to 6 percent of total stored energy. In piston singles where the engine starts readily, it's about half that total. You mentioned in the earlier post that you thought you might have seriously whacked the battery's ability to store energy when you allowed it to be so severely depleted. This is generally no big deal. Brand new batteries subjected to a series of 90% depletion cycles will slowly drop in capacity with each cycle. Most RG batteries are good for several hundred deep-cycles before they lose 20% of their capacity. Emacs! Here's an exemplar cycle-life performance curve for a lithium battery . . . lead-acid curves are similar they just don't go out to those really big numbers. But a single deep discharge of your battery followed by a recharging activity does not seriously affect future performance. Now, leaving the master switch on and leaving the battery discharged for a couple of weeks is another matter . . . Bob . . . ________________________________________________________________________________
Date: Jun 30, 2009
Ok, Bob, here is a crude sketch of the essential elements ALT B Lead ------------------- Aircraft Bus---------------------------------------------------- None Essential Load | | | | | | Switch Diode (not installed at time of incident) Essential Bus Load ---------------------------- |---------- | | | Battery The alternator B lead feeds the aircraft main bus. The switch is designed to be closed during normal operation permitting the alternator to charge/ recharge the battery - in this incident it became open - therefore no alternator voltage to charge battery. The diode would have permitted the alternator to charge the battery (regardless of switch position) IF I had installed it back 10 years ago. The idea back then was that if the alternator failed, I could remove the battery and essential load from that circuit by opening the switch. The diode (if I had installed it) would have prevent the very problem I encountered - that of the battery being exhausted because it could get no voltage from the alternator due to the inadvertently opened switch. Why a diode and a switch - well, diodes can fail, switches can fail - unlikely both would at the same time. - In reality, I have never moved the switch from the Alternator connection position in 10 years of flying - until, of course, this incident. The idea of having the low voltage warning LED tied to the alternator circuit was that it would give first notice (before the battery started to drain) if there was a problem with alternator. The volt meter has a toggle switch so I can monitor either alternator or battery voltage. Unfortunately, I had it set to alternator and therefore it didn't register the deteriorating battery voltage. Of course, if the switch in question is ON then alternator and battery voltage will read the same - so to check the battery voltage solely, I would need to open the Switch removing the alternator temporarily from feeding the battery. This all seemed reasonable 10 years ago, less so since the incident - as you might imagine. Providing this so others may avoid my mistakes - certainly not trying to defend what in hindsight are obvious {:>) deficiencies in my design. Ed Ed Anderson Rv-6A N494BW Rotary Powered Matthews, NC eanderson(at)carolina.rr.com <http://www.andersonee.com> http://www.andersonee.com <http://www.dmack.net/mazda/index.html> http://www.dmack.net/mazda/index.html http://www.flyrotary.com/ <http://members.cox.net/rogersda/rotary/configs.htm> http://members.cox.net/rogersda/rotary/configs.htm#N494BW http://www.rotaryaviation.com/Rotorhead%20Truth.htm <http://www.dmack.net/mazda/index.html> _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Tuesday, June 30, 2009 10:12 AM Subject: RE: AeroElectric-List: Re: Time to Battery Exhaustion At 07:09 AM 6/30/2009, you wrote: Hi Bob, The "isolation diode" was a poor choice of words for the schokkty battery feed diode between alternator power and the essential bus battery circuit. If I had installed that diode 10 years ago (per your design) then having the switch in the wrong position wouldn't have affected the ability of the battery to get alternator voltage. I'm still not getting a mental image of how you had it wired. How does the existence or lack of the diode affect connection between battery and alternator? The problem with my "low voltage warning" indicator (both LED and Voltmeter) was they were on the alternator circuit and NOT the battery. Since the alternator was working fine and continued to produce power (until the dropping battery voltage opened the master relay), these two devices never indicated low voltage. IF I had thought to switch the voltmeter to the battery then I would likely have noticed the decreasing battery voltage. So have (or are you planning) you movee the low voltage sensing point in your system? Could you sketch and scan the distribution system and share with us? Normally, alternator has no way NOT to charge the battery if the engine is running -AND- both the alternator and battery control circuits are closed. I'm having trouble visualizing how "both were functioning" but the alternator was still not connected to the battery. Thanks for the battery drain curve, appears my system does not have as much current drain as I had estimated. Also looks like the powered required for starting did not much affect the duration. While starters take a lot of POWER it is for just a few seconds. The total ENERGY is quite low. Even in large aircraft, the percentage of battery energy used to start is a small fraction of the total. In this start current curve we took off a Beechjet . . . http://www.aeroelectric.com/Pictures/Curves/turbine_start_a.jpg . . . it takes about 20 seconds for cranking current to taper from 800A to 300A and another 7 seconds to go to zero. Yet this 44 a.h. battery is tapped for only 5 to 6 percent of total stored energy. In piston singles where the engine starts readily, it's about half that total. You mentioned in the earlier post that you thought you might have seriously whacked the battery's ability to store energy when you allowed it to be so severely depleted. This is generally no big deal. Brand new batteries subjected to a series of 90% depletion cycles will slowly drop in capacity with each cycle. Most RG batteries are good for several hundred deep-cycles before they lose 20% of their capacity. Emacs! Here's an exemplar cycle-life performance curve for a lithium battery . . . lead-acid curves are similar they just don't go out to those really big numbers. But a single deep discharge of your battery followed by a recharging activity does not seriously affect future performance. Now, leaving the master switch on and leaving the battery discharged for a couple of weeks is another matter . . . Bob . . . __________ Information from ESET NOD32 Antivirus, version of virus signature database 3267 (20080714) __________ The message was checked by ESET NOD32 Antivirus. __________ Information from ESET NOD32 Antivirus, version of virus signature database 3267 (20080714) __________ The message was checked by ESET NOD32 Antivirus. ________________________________________________________________________________
Date: Jun 30, 2009
It's pretty random. It's about the pitch of metal on metal. It almost sounds like someone is working in a workshop, throwing bits of scrap aluminum around. Completely random, but of the order of about one a second - certainly not a regular vibration type noise. Bursts of two or three and then silence for a couple of seconds. Apparently someone else has the same exact noise with the same behaviour on the Flightcom 403 in intercom mode. He described is as a bit like a snare drum which give you a feel for the pitch. It reduces with the squelch too. I've also emailed Flightcom for help. Regards, Ian Brown > > > > > >It's all about the same pitch, but almost sounds almost like some form > >of sparking or discharging. > > > >There is no whining or other noise, and this seems to only happen when > >the engine in running (i.e. most of the time). The sound reduces when I > >turn down the volume, and goes away when I "isolate" the pilot from the > >passenger on the Flightcomm 403 with the "ICS/Isolate" switch. > > > >This is such a unique noise I just wondered if anyone else had heard it > >or heard of it. > > > >Thanks in advance for any of your wisdom. > > What is the repetition rate for the noise. How many > times per minute. Its it a regular rate or random? > > > Bob . . . > > --------------------------------------- > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > --------------------------------------- > > > > > > ________________________________________________________________________________
Date: Jun 30, 2009
Subject: AEC 9005-101 Low Voltage Monitor module not found
Bob, I am trying to-build a Z-11 wiring scheme for now with eventual upgrade t o dual batteries and alternators. - The AEC-Z-11 figure shows a generic Ford regulator and the AEC 9005-101 L ow Voltage Monitor Module. However, the Appendix Z notes-for the Z-11 fig ure-advises that-"it features the B&C alternator control sytem (regulat or, OV protection and LV warning in a single product)". - I ran a search on the list and on the AEC website for the AEC 9005-101 LVMM , but failed to find any reference for it.-Have the-AEC 9005-101 LVMM a nd generic Ford regulator been phased out in favor-of the-comparatively costly-LR-3 B&C alternator control system? - Thanks for your help, Eric Schlanser=0A=0A=0A ________________________________________________________________________________
Date: Jun 30, 2009
=0AThank you Ed,=0A =0AI have learned a number of things due to your willin gness to share your experience and system configuration.=0A =0AJon Finley =0AN314JF - Q2 - Subaru EJ-22=0A[http://www.finleyweb.net/Q2Subaru.aspx] ht tp://www.finleyweb.net/Q2Subaru.aspx=0A=0A=0A-----Original Message-----=0AF rom: "Ed Anderson" =0ASent: Tuesday, June 30, 20 09 9:02am=0ATo: aeroelectric-list(at)matronics.com=0ASubject: FW: AeroElectric -List: Re: Time to Battery Exhaustion=0A=0A=0A=0A =0AOk, Bob, here is a c rude sketch of the essential elements=0A =0A =0A ALT B Lead ------------ ------- Aircraft Bus---------------------------------------------------- No ne Essential Load=0A | | =0A | |=0A | |=0A Switch Diod e (not installed at time of incident)=0A Essential Bus Load -- -------------------------- |---------- |=0A | |=0A Battery=0A =0AThe alt ernator B lead feeds the aircraft main bus. The switch is designed to be c losed during normal operation permitting the alternator to charge/ recharge the battery =93 in this incident it became open =93 therefore no alternator voltage to charge battery. The diode would have permitted th e alternator to charge the battery (regardless of switch position) IF I had installed it back 10 years ago. The idea back then was that if the altern ator failed, I could remove the battery and essential load from that circui t by opening the switch. The diode (if I had installed it) would have prev ent the very problem I encountered =93 that of the battery being exha usted because it could get no voltage from the alternator due to the inadve rtently opened switch. Why a diode and a switch =93 well, diodes can fail, switches can fail =93 unlikely both would at the same time. =93 In reality, I have never moved the switch from the Alternator con nection position in 10 years of flying =93 until, of course, this inc ident.=0A =0AThe idea of having the low voltage warning LED tied to the alt ernator circuit was that it would give first notice (before the battery st arted to drain) if there was a problem with alternator. The volt meter has a toggle switch so I can monitor either alternator or battery voltage. U nfortunately, I had it set to alternator and therefore it didn=99t re gister the deteriorating battery voltage. Of course, if the switch in quest ion is ON then alternator and battery voltage will read the same =93 so to check the battery voltage solely, I would need to open the Switch rem oving the alternator temporarily from feeding the battery. =0A =0AThis al l seemed reasonable 10 years ago, less so since the incident - as you might imagine. Providing this so others may avoid my mistakes =93 certain ly not trying to defend what in hindsight are obvious {:>) deficiencies in my design.=0A =0A =0AEd=0A=0AEd Anderson=0ARv-6A N494BW Rotary Powered=0AMa tthews, NC=0Aeanderson@carolina.rr.com=0A[http://www.andersonee.com/] http: //www.andersonee.com=0A[http://www.dmack.net/mazda/index.html] http://www.d mack.net/mazda/index.html=0A[http://www.flyrotary.com/] http://www.flyrotar y.com/=0A[http://members.cox.net/rogersda/rotary/configs.htm] http://member s.cox.net/rogersda/rotary/configs.htm#N494BW=0A[http://www.rotaryaviation.c om/Rotorhead%20Truth.htm] http://www.rotaryaviation.com/Rotorhead%20Truth.h tm[http://www.dmack.net/mazda/index.html] =0A=0A=0AFrom: owner-aeroelectric -list-server(at)matronics.com [mailto:owner-aeroelectric-list-server@matronics .com] On Behalf Of Robert L. Nuckolls, III=0ASent: Tuesday, June 30, 2009 1 0:12 AM=0ATo: aeroelectric-list(at)matronics.com=0ASubject: RE: AeroElectric-L ist: Re: Time to Battery Exhaustion=0A =0AAt 07:09 AM 6/30/2009, you wrote: na.rr.com>=0A=0AHi Bob,=0A=0AThe "isolation diode" was a poor choice of wor ds for the schokkty battery=0Afeed diode between alternator power and the e ssential bus battery circuit.=0AIf I had installed that diode 10 years ago (per your design) then having the=0Aswitch in the wrong position wouldn't h ave affected the ability of the=0Abattery to get alternator voltage.=0A=0A I'm still not getting a mental image of=0A how you had it wired. How d oes the=0A existence or lack of the diode affect=0A connection between battery and alternator?=0A=0A=0A=0AThe problem with my "low voltage warning " indicator (both LED and Voltmeter)=0Awas they were on the alternator circ uit and NOT the battery. Since the=0Aalternator was working fine and conti nued to produce power (until the=0Adropping battery voltage opened the mast er relay), these two devices never=0Aindicated low voltage. IF I had though t to switch the voltmeter to the=0Abattery then I would likely have noticed the decreasing battery voltage.=0A=0A=0A So have (or are you planning) y ou movee the low=0A voltage sensing point in your system?=0A=0A Could y ou sketch and scan the distribution=0A system and share with us? Normally , alternator=0A has no way NOT to charge the battery if the=0A engine i s running -AND- both the alternator=0A and battery control circuits are c losed. I'm=0A having trouble visualizing how "both were =0A functioning " but the alternator was still not=0A connected to the battery.=0A=0A=0A =0AThanks for the battery drain curve, appears my system does not have as m uch=0Acurrent drain as I had estimated. Also looks like the powered requir ed for=0Astarting did not much affect the duration.=0A=0A While starters take a lot of POWER it is for=0A just a few seconds. The total ENERGY is quite=0A low. Even in large aircraft, the percentage of=0A battery ener gy used to start is a small fraction=0A of the total. In this start curre nt curve we=0A took off a Beechjet . . .=0A=0A[http://www.aeroelectric.co m/Pictures/Curves/turbine_start_a.jpg] http://www.aeroelectric.com/Pictures /Curves/turbine_start_a.jpg=0A=0A . . . it takes about 20 seconds for cra nking=0A current to taper from 800A to 300A and another=0A 7 seconds to go to zero. Yet this 44 a.h. battery=0A is tapped for only 5 to 6 percen t of total=0A stored energy. In piston singles where the engine=0A star ts readily, it's about half that total.=0A=0A You mentioned in the earlie r post that you thought=0A you might have seriously whacked the battery's =0A ability to store energy when you allowed it to be=0A so severely de pleted. This is generally no big=0A deal. =0A=0A Brand new batteries s ubjected to a series of 90%=0A depletion cycles will slowly drop in capac ity with=0A each cycle. Most RG batteries are good for several=0A hundr ed deep-cycles before they lose 20% of their=0A capacity.=0A=0A=0A=0A Here's an exemplar cycle-life performance curve for a=0A lithium bat tery . . . lead-acid curves are similar=0A they just don't go out to t hose really big numbers.=0A But a single deep discharge of your batter y followed=0A by a recharging activity does not seriously affect=0A future performance.=0A=0A Now, leaving the master switch on and lea ving the=0A battery discharged for a couple of weeks is another=0A matter . . .=0A=0A=0A Bob . . .=0A=0A=0A__________ Information from E SET NOD32 Antivirus, version of virus signature database 3267 (20080714) __ ________=0A=0AThe message was checked by ESET NOD32 Antivirus.=0A=0A=0A=0A =0A__________ Information from ESET NOD32 Antivirus, version of virus signa ture database 3267 (20080714) __________=0A=0AThe message was checked by ES ET NOD32 Antivirus.=0A=0A=0A=0A=0A__________ Information from ESET NOD32 An tivirus, version of virus signature database 3267 (20080714) __________=0A =0AThe message was checked by ESET NOD32 Antivirus.=0A=0A ________________________________________________________________________________
Date: Jun 30, 2009
Subject: Re: AEC 9005-101 Low Voltage Monitor module not found
At 11:09 AM 6/30/2009, you wrote: >Bob, >I am trying to build a Z-11 wiring scheme for now with eventual >upgrade to dual batteries and alternators. > >The AEC Z-11 figure shows a generic Ford regulator and the AEC >9005-101 Low Voltage Monitor Module. However, the Appendix Z notes >for the Z-11 figure advises that "it features the B&C alternator >control sytem (regulator, OV protection and LV warning in a single product)". > >I ran a search on the list and on the AEC website for the AEC >9005-101 LVMM, but failed to find any reference for it. Have the AEC >9005-101 LVMM and generic Ford regulator been phased out in favor of >the comparatively costly LR-3 B&C alternator control system? That particular product has been discontinued at the 'Connection and will be replaced with the http://www.aeroelectric.com/Catalog/AEC/9011/9011-700-1C.pdf This is a multi-tasking product that can be used for any combination of following monitoring/control: Low volts annunciation on Bus Low volts annunciation on Aux Overvolts shutdown and annunciation on Bus If you need something sooner you can consider the LVWarn/ABMM module from http://periheliondesign.com/lvwaabm.htm or you can craft your own from the original AEC design as described at: http://www.aeroelectric.com/DIY/LV_Warn_Fab_and_Install.pdf and built on ExpressPCB artwork supplied at: http://www.aeroelectric.com/DIY/9005-301-1C_Fab.pcb The AEC9011 will be available later this year. I'm teaching my kids how to assemble and program these critters. They'll be in production as soon as I can get moved out of this house and the kids get moved in. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jun 30, 2009
At 10:37 AM 6/30/2009, you wrote: > >It's pretty random. It's about the pitch of metal on metal. It almost >sounds like someone is working in a workshop, throwing bits of scrap >aluminum around. Completely random, but of the order of about one a >second - certainly not a regular vibration type noise. Bursts of two or >three and then silence for a couple of seconds. Apparently someone else >has the same exact noise with the same behaviour on the Flightcom 403 in >intercom mode. He described is as a bit like a snare drum which give >you a feel for the pitch. It reduces with the squelch too. Hmmm . . . beats me. Were the problem in my shop, I'd have to break out the 'scope and signal tracer and start poking around the innards of things. Bob . . . ________________________________________________________________________________
Date: Jun 30, 2009
At 10:02 AM 6/30/2009, you wrote: > >Ok, Bob, here is a crude sketch of the essential elements > > > ALT B Lead ------------------- Aircraft > Bus---------------------------------------------------- None Essential Load > >| | > >| | > >| | > >Switch Diode (not installed at time of incident) > Essential Bus Load ---------------------------- |---------- | > >| | > >Battery > >The alternator B lead feeds the aircraft main >bus. The switch is designed to be closed during >normal operation permitting the alternator to >charge/ recharge the battery ' in this incident >it became open ' therefore no alternator voltage >to charge battery. The diode would have >permitted the alternator to charge the battery >(regardless of switch position) IF I had >installed it back 10 years ago. The idea back >then was that if the alternator failed, I could >remove the battery and essential load from that >circuit by opening the switch. The diode (if I >had installed it) would have prevent the very >problem I encountered ' that of the battery >being exhausted because it could get no voltage >from the alternator due to the inadvertently >opened switch. Why a diode and a switch ' well, >diodes can fail, switches can fail ' unlikely >both would at the same time. ' In reality, I >have never moved the switch from the Alternator >connection position in 10 years of flying ' until, of course, this incident. Understand. Know that there are a host of reasons why Z-11 is crafted the way it's illustrated in the 'Connection. This is a step-up from the legacy power distribution common to 99.9% of all single-engine aircraft ever flown. The design goals call for main bus, battery and alternator to be firmly in connection with each other. The purpose of the endurance bus isolation diode is to prevent back-feeding power from the e-bus while the e-bus alternate feed switch is supplying power directly from the battery. The diode has no function with respect to the relationship between alternator and battery. > >The idea of having the low voltage warning LED >tied to the alternator circuit was that it >would give first notice (before the battery >started to drain) if there was a problem with >alternator. The volt meter has a toggle switch >so I can monitor either alternator or battery >voltage. Unfortunately, I had it set to >alternator and therefore it didn=92t register the >deteriorating battery voltage. Of course, if the >switch in question is ON then alternator and >battery voltage will read the same ' so to check >the battery voltage solely, I would need to open >the Switch removing the alternator temporarily from feeding the battery. > >This all seemed reasonable 10 years ago, less so >since the incident - as you might >imagine. Providing this so others may avoid my >mistakes ' certainly not trying to defend what >in hindsight are obvious {:>) deficiencies in my design. Understand. Suggest you re-configure to Z-11 as soon as practical if you you haven't already . . . Bob . . . ________________________________________________________________________________
Date: Jun 30, 2009
Subject: Battery facts and myths redux . . .
Since this topic seems to be simmering again on the list, I thought it would be useful to share an excerpt from another conversation concerning battery characteristics and performance: >It is my understanding that a battery can fail in only one of three >ways (modes): > 1. An internal short circuit that results in a direct closed > path from the (+) to the (-) terminals. Never happens. Single cells might short thus reducing a 12v battery to a 10v battery. This causes the system to respond by overcharging what it perceives is a seriously discharged 12v battery. Failure of other cells due to overcharging is the secondary effect. > 2. An internal open circuit that results in no path between the > (+) and (-) terminals. Yes . . . but very rare. Usually due to manufacturing defect. > 3. An internal resistence (I beleive this is correct) that > results in the inability of the battery to provide power/accept a > charge, but not 1 and 2. All power sources have internal resistance. This is inherent in any "non-perfect" device. The resistance may be quite low (typically 10 milliohms for a small 12v RG battery) but rises with time as cell-stes in the battery begin to die off. A battery that is ready to be replaced due to loss of capacity might expect to see a 30-40%% increase or so in internal resistance. Still capable of cranking an engine but not capable of meeting endurance mode requirements. This would not be classed as a failure but an end of life event. >Open Circuit (#2): >A. For two batteries: It would not affect the second parallel >battery. The only effect on the system would be to reduce capacity >by the failed battery's contribution. Yes. >B. For a single battery: The effect on the system would be the >same as no battery. If the alternator were running, power would >continue to be provided subject to the conditions that would take >the alternator off line, at which time no power would be >provided. Otherwise no power would be provided. Yes. >Internal Resistance (#3): >A. For two batteries: It would not effect the second parallel >battery. The effect on the system would be to reduce capacity by >the failed battery's contribution, in some proportion to the >increase in resistance. In other words, the failed battery would >not drain energy from the second battery. Yes. >B. For a single battery: The effect on the system would be to >reduce capacity in some proportion to the increase in >resistence. At some point the capacity would be reduced to below >that necessary to keep the alternator on line, at which time no >power would be provided. Demonstrated internal resistance would/should never be allowed to degrade to a "no power" condition. This is a service life issue that should be addressed as a preventative maintenance program on the airplane. >Short Circuit (#3): > A. For two batteries: It would cause an immediate drain on the > second parallel battery. Yes. >With no means to isolate the failed battery it would cause a failure >of the two battery system. The OK battery would not be at risk but its stored energy would combine with alternator output to overcharge the 10v battery. >If the alternator were running, and the failed battery system were >not isolated, the drain on the whole system would excede the >alternator capacity and the whole system would fail. No, the alternator MIGHT go into current limited operation at the 10V level but in a matter of minutes, overcharged cells in the failed battery would outgas, their internal resistance would rise and the failure would essentially isolate itself over time. This presumes of course that the battery has a demonstrated ability to go into passive failure under severe overcharge conditions. Batteries qualified for military and aircraft use are subjected to such tests in the lab. It's likely that even a commercial off the shelf product would be similarly disposed to go quietly off into the sunset. >If the failed battery system were isolated, it would have the same >effect as no battery except that it is probable that the alternator >would be off line due to reduced system voltage at the time of >isolation and the whole system would be failed. No. As long as the bus voltage stays above one volt or so, the alternator never "quits". In the shorted cell case, there's no reason to expect bus voltage to drop below 10-11 volts while being feed by the alternator. If the battery is well behaved in the shorted cell scenario, then I would expect the low voltage condition to last perhaps 30 minutes before the failed battery unhooks itself. >B. For a single battery: It would have the same effect as A. for >the failure of the two battery system. For a single battery, single shorted cell, the system voltage would depress to 11 or so volts and the combined output of alternator and battery would go to work boiling of the liquid in the remaining good cells. Passive disconnect followed by return to normal bus voltage would be expected. >III. Detection (assuming a system volt meter and alternator load meter) > >Opern Circuit (#2) and Internal Resistance (#3): >A. For two batteries: At start up, it might be detectable as >reduced or insufficinet cranking capactiy. In flight, it would not >be detectable as long as the alternator was functioning and loads >were below the alternator capacity. If loads exceeded alternator >capacity, it might be detectable by a greater than expected drop in >system voltage in relation to load. If the alternator failed, it >would be detectable by a greater than expected drop in system >voltage in relation to load. If the alternator is on line, bus is supported at the setpoint votlage and low voltage warning would be dark. If the alternator goes off line, then the bus would still fall to the expected 12.5 or so volts and decay from there depending on load. The low voltage warning light would be ON but you would obviously not have access to the expected capacity of both batteries. This would take some time to discover when expected endurance performance falls short by about 1/2. >B. For a single battery: At start up it would be detecable as zero >or insufficient cranking capacity. In flight, basically the same as >A except that the drop in system voltage would be more severe and >detectable, and with the alternator failed, the there woul be no >power under #2. > >It that understanding correct?? Essentially >Short Circuit (#1): >A. For one and two batteries: It would be detectable as an immediate >drop in system voltage and if not isolated immediately, failure of >the whole system. Even if isolated immediately, it is probable >that the whole system would be failed due to the initial >drop in system voltage taking the alternator off line. No, a shorted cell doesn't take the whole system down. There would be a momentary drop in voltage probably annunciated by low voltage warning and paired with alternator loadmeter showing a maxed out machine. But as the still functioning cells are cooked off, voltage would rise and the alternator output would drop back to the value demanded by system loads. Probability of cell shorting is exceedingly low because the typical RG battery has physical barriers of porous plastic and/or glass mat fiber between plates . . . Emacs! Emacs! Emacs! As you can see in these views on a Concorde RG battery, alternate plates are completely bagged in fiberglas and plastic. No shorted cells in this product. All of these hypothetical failures presume that an alternator is sufficiently cooled to tolerate current limited operation for a period of time. They also presume benign response to overcharging that is demanded of batteries qualified to aviation and military service. Bob . . . ________________________________________________________________________________
Date: Jun 30, 2009
You're welcome, Jon That's the entire intention - to share my screw-ups, so that other's won't make the same ones - advance the state of the art - make a new one {:>). Ed Ed Anderson Rv-6A N494BW Rotary Powered Matthews, NC eanderson(at)carolina.rr.com <http://www.andersonee.com> http://www.andersonee.com <http://www.dmack.net/mazda/index.html> http://www.dmack.net/mazda/index.html http://www.flyrotary.com/ <http://members.cox.net/rogersda/rotary/configs.htm> http://members.cox.net/rogersda/rotary/configs.htm#N494BW http://www.rotaryaviation.com/Rotorhead%20Truth.htm <http://www.dmack.net/mazda/index.html> _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of jon(at)finleyweb.net Sent: Tuesday, June 30, 2009 1:00 PM Subject: RE: FW: AeroElectric-List: Re: Time to Battery Exhaustion Thank you Ed, I have learned a number of things due to your willingness to share your experience and system configuration. Jon Finley N314JF - Q2 - Subaru EJ-22 http://www.finleyweb.net/Q2Subaru.aspx ________________________________________________________________________________
Date: Jun 30, 2009
Subject: Re: Noise Problem
Maybe it would only serve novelty purposes, but it would be interesting to me to be able to hear these various sounds. Has anyone tried to record anything like this? Share it on the web? Regards, Matt- > > > At 10:37 AM 6/30/2009, you wrote: >> >>It's pretty random. It's about the pitch of metal on metal. It almost >>sounds like someone is working in a workshop, throwing bits of scrap >>aluminum around. Completely random, but of the order of about one a >>second - certainly not a regular vibration type noise. Bursts of two or >>three and then silence for a couple of seconds. Apparently someone else >>has the same exact noise with the same behaviour on the Flightcom 403 in >>intercom mode. He described is as a bit like a snare drum which give >>you a feel for the pitch. It reduces with the squelch too. > > Hmmm . . . beats me. Were the problem in my shop, I'd > have to break out the 'scope and signal tracer and start > poking around the innards of things. > > Bob . . . > > ________________________________________________________________________________
Subject: Race timing help
Date: Jun 30, 2009
I just participated in a type club speed event (without lawyers we'd call it a race) and the time keeping got unbelievably screwed up for such a small group (18 planes). Even though there are classes and staggered starts we got folks crossing the finish tip to tip at pattern altitude. Suffice to say that human errors on both the pilots and timers parts caused a lot of grief. Sooo... what kind of technology is out there to assist? All we really need is start and finish times for each plane. It could be plane based, ground based or a combo but it needs to be affordable for 20-30 planes to use and able to deliver the results quickly, e.g. a download and analysis of everyone's 396/496 bread crumb trail probably won't do. I was kinda thinking of giant barcodes under the wing and a 10 KW scanner at the finish point;-) Hopefully someone knows of something simpler, cheaper and more elegant. What's available? Thanks, Greg Young ________________________________________________________________________________
Subject: Re: Race timing help
Date: Jun 30, 2009
Many of us in the SARL (www.sportairrace.org) purchased low cost GPS data loggers to analyze our own performance. It records at 1sec (programmable) resolution, Lat, Long, Speed, and Alt for about 5hrs, more at lower res. The data can then be uploaded into Google Earth and viewed. It is very easy to mark the crossing of start/finish lines, turn points, etc. From that, you can derive your TRUE course timing - much more accurately than a human centric process. Eventually, the races will be timed off of these units instead of human timers and turn point observers. http://www.globalsat.com.tw/eng/product_detail_00000090.htm This is the one I use, many others are out there. Be sure the one you choose has the ability to output or export to .GPX format. This is the "standard" GPS data format that is expected by most data formatting sites and programs. I also use http://www.gpsvisualizer.com/ to colorize my track by speed, add a semi-transparent wall connected to the ground, and other things. Very neat stuff. It sure lets you know if you blow a turn or wander in altitude/heading. My closest competitor and I share our data and superimpose our tracks on GoogleEarth to see how each others performance compared. At less than $100...this things are golden in my book! James Redmon Berkut #013/Race 13 www.berkut13.com 2007 SARL Silver National Champion ----- Original Message ----- From: Greg Young To: aeroelectric-list(at)matronics.com Sent: Tuesday, June 30, 2009 9:54 PM Subject: AeroElectric-List: Race timing help I just participated in a type club speed event (without lawyers we'd call it a race) and the time keeping got unbelievably screwed up for such a small group (18 planes). Even though there are classes and staggered starts we got folks crossing the finish tip to tip at pattern altitude. Suffice to say that human errors on both the pilots and timers parts caused a lot of grief. Sooo... what kind of technology is out there to assist? All we really need is start and finish times for each plane. It could be plane based, ground based or a combo but it needs to be affordable for 20-30 planes to use and able to deliver the results quickly, e.g. a download and analysis of everyone's 396/496 bread crumb trail probably won't do. I was kinda thinking of giant barcodes under the wing and a 10 KW scanner at the finish point;-) Hopefully someone knows of something simpler, cheaper and more elegant. What's available? Thanks, Greg Young ________________________________________________________________________________
Date: Jul 01, 2009
Subject: self weighing our planes
Does anyone have experience with strain gauges? I envision strain gauges somewhere on each of the 3 "legs" of the plane, calibrated initially at the empty weight of the plane and then again at full fuel, oil, and etc. What that would give us is a constant readout or our plane's weight, esp on takeoff. One could argue that landing weight could be inferred as well while still in the air. This should help immensely with the (uncommon) problems of taking off too heavy or (gasp) CG being out of range. I want to try this on my plane but I have no experience with strain gauges. I'm thinking of mounting them where the legs meet the fuselage for the mains, and maybe at the movable joint on the front (mine is a trike.) Any ideas? David M. ________________________________________________________________________________
Date: Jul 01, 2009
Subject: Audio panel for nav audio
Hi Bob and all, A buddy asked for help in installing his Garmin SL30. I'll need some clarification about nav audio. Do we actually need an audio panel in order to hear the nav audio input through the phones ? Sorry if this has been asked before, but my home internet connection has been down for weeks. Thanks in advance, Gilles http://contrails.free.fr ________________________________________________________________________________
Date: Jul 01, 2009
Subject: Re: self weighing our planes
Good Morning David, Strain gauges do have a lot of capability. For some reason, every time a proposal is made to use them for a control function, various calibration issues arise. It will be interesting to see what the brainy guys on the list come up with. The idea of having an instantaneous check of weight has been toyed with for many years. Not sure how long ago it started. However, my first exposure was just after WWII when tricycle landing gear became common on air carrier aircraft. Since everyone of the then popular tricycle landing geared airliners used air/oil hydraulic struts on their landing gear, the obvious answer was to measure the change in strut pressure as the aircraft was being loaded. The first objection came from those who mentioned air loads. We can't even get a good static weighing of an airplane unless the weighing is being conducted in a closed hangar. Even ceiling fans must be shut off because those have been known to affect a precise weighing. Once an engine is started, additional varying loads would be applied that mess up the weight numbers. If all those variables are considered, do we really want something that will tell us we are ten pounds too heavy? Or maybe that our CG is two tenths of an inch aft of where it should be? For safety, I think we would all like to have that information, but only if it was absolutely guaranteed to be accurate and repeatable information. I wish you well in your endeavor and hope that the problems can be solved, but the powers that be have elected to study the situation quite a bit more before using it in commercial aviation. Let us know how it works for you. Happy Skies, Old Bob Downers Grove IL LL22 Stearman N3977A In a message dated 7/1/2009 6:37:05 A.M. Central Daylight Time, ainut(at)hiwaay.net writes: --> AeroElectric-List message posted by: "David M." Does anyone have experience with strain gauges? I envision strain gauges somewhere on each of the 3 "legs" of the plane, calibrated initially at the empty weight of the plane and then again at full fuel, oil, and etc. What that would give us is a constant readout or our plane's weight, esp on takeoff. One could argue that landing weight could be inferred as well while still in the air. This should help immensely with the (uncommon) problems of taking off too heavy or (gasp) CG being out of range. I want to try this on my plane but I have no experience with strain gauges. I'm thinking of mounting them where the legs meet the fuselage for the mains, and maybe at the movable joint on the front (mine is a trike.) Any ideas? David M. **************Make your summer sizzle with fast and easy recipes for the grill. (http://food.aol.com/grilling?ncid=emlcntusfood00000005) ________________________________________________________________________________
Subject: LED Headlamps
Date: Jul 01, 2009
A customer of mine is buying LED Headlamps from Truck-Lite. They make these for the military and come in 12V and 28V. Direct replacement for Par56, H6014 and H6024 lamps. Expensive...$309.99 each. See: http://www.levineautoparts.com/ledheadlights.html I have no experience with them, but this is where the world will go when the price drops. And other sizes and forms will dominate no doubt. "Inventor: A person who makes an ingenious arrangement of wheels, levers and springs, and believes it civilization." --Ambrose Bierce -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=250932#250932 ________________________________________________________________________________
Date: Jul 01, 2009
I think that some airliners have tried onboard systems, but the shortcoming is that it is hard to build a system that is sensitive enough to keep the accuracy where you would want it but yet strong enough to survive the stresses of landings. Most big planes have instead moved in the direction of math calculations with average weights instead. Those calculations have a lot of room for error, and yet someone must have decided at some point that they were still more accurate than strain gauges. Maybe with a small plane and feather fingertips for the landings, you could make it work! -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of David M. Sent: Wednesday, July 01, 2009 7:32 AM Subject: AeroElectric-List: self weighing our planes Does anyone have experience with strain gauges? I envision strain gauges somewhere on each of the 3 "legs" of the plane, calibrated initially at the empty weight of the plane and then again at full fuel, oil, and etc. What that would give us is a constant readout or our plane's weight, esp on takeoff. One could argue that landing weight could be inferred as well while still in the air. This should help immensely with the (uncommon) problems of taking off too heavy or (gasp) CG being out of range. I want to try this on my plane but I have no experience with strain gauges. I'm thinking of mounting them where the legs meet the fuselage for the mains, and maybe at the movable joint on the front (mine is a trike.) Any ideas? David M. ________________________________________________________________________________
Date: Jul 01, 2009
From: "David E. Nelson" <david.nelson(at)pobox.com>
Subject: Re: Help with LCD Circuit Design - Altitude & Heading
Hi Mike, You might look into the "Arduino". >From a learning perspective, this looks to be pretty easy to get started (ie relatively low entry cost and easy access to h/w) and has lots of potential to go crazy (in a good way, of course ;). The integrated development environment (IDE) is open-source and works under Linux, Windows, and MacOS X. Some links: http://www.arduino.cc http://www.arduino.cc/en/Guide/HomePage - Getting Started http://www.arduino.cc/playground/ http://www.arduino.cc/playground/Code/LCD - LCD Specific writings... I don't have experience in this area, but thought I'd pass it on in the spirit of the original inquiry. Good luck, /\/elson ~~ Lately my memory seems to be like a steel trap .... without any spring. ~~ ________________________________________________________________________________
Date: Jul 01, 2009
Or http://www.nerdkits.com/. Nice "noob starter" manual comes with the kit. On Jul 1, 2009, at 10:32 AM, David E. Nelson wrote: > > > > > Hi Mike, > > You might look into the "Arduino". > >> From a learning perspective, this looks to be pretty easy to get >> started (ie > relatively low entry cost and easy access to h/w) and has lots of > potential to go crazy (in a good way, of course ;). The integrated > development environment (IDE) is open-source and works under Linux, > Windows, and MacOS X. > > Some links: > > http://www.arduino.cc > http://www.arduino.cc/en/Guide/HomePage - Getting Started > http://www.arduino.cc/playground/ > http://www.arduino.cc/playground/Code/LCD - LCD Specific writings... > > I don't have experience in this area, but thought I'd pass it on in > the spirit of the original inquiry. > > Good luck, > /\/elson > > > ~~ Lately my memory seems to be like a steel trap .... without any > spring. ~~ > > ________________________________________________________________________________
Date: Jul 01, 2009
On 1 Jul 2009, at 07:32, David M. wrote: > > Does anyone have experience with strain gauges? I envision strain > gauges somewhere on each of the 3 "legs" of the plane, calibrated > initially at the empty weight of the plane and then again at full > fuel, oil, and etc. What that would give us is a constant readout > or our plane's weight, esp on takeoff. One could argue that landing > weight could be inferred as well while still in the air. This > should help immensely with the (uncommon) problems of taking off too > heavy or (gasp) CG being out of range. > I want to try this on my plane but I have no experience with strain > gauges. I'm thinking of mounting them where the legs meet the > fuselage for the mains, and maybe at the movable joint on the front > (mine is a trike.) > Any ideas? One big problem will be that as you add weight, and the gear flexes, the bottom end of the gear legs need to move outwards. If you are stopped, the friction between the tires and the ground prevent the bottom ends of the gear legs from spreading apart. Once you start to move, and the wheels roll, the wheels will spread apart a bit to allow the gear legs to take up their new natural position. So, once the aircraft is loaded, you won't get a repeatable measurement until the aircraft rolls a few feet. If while the aircraft is rolling, a tire comes upon a piece of ground that is not even from side to side, that will tend to make the wheel roll a bit to the left or right of its natural position, which will affect the strain on the upper end of the gear leg, changing the strain gauge output. There is no harm in conducting the experiment, but I'm not optimistic that you would be able to get acceptable accuracy in the real world. I'll be amazed if you get accuracy better than 100 lb. Please keep up posted. This is an interesting project. -- Kevin Horton (Grounded) RV-8 (Flight Test Phase) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: Jul 01, 2009
Heading
From: Mike Fontenot <mikef(at)apexconsultingservices.com>
Thanks Guys, I have so far gone with the simple Push Wheel switch that Bob K suggested. I got the parts from Digikey for about $50 for 7 pushwheels, end caps, and a simple black enclosure. I mounted it up in a four button/altitude and three button/heading configuration. Simple and easy to mount. I'll try to post a photo over the holiday weekend. Thanks, Mike On Wed, Jul 1, 2009 at 10:35 AM, Sean Stephens wrote: > sean(at)stephensville.com> > > Or http://www.nerdkits.com/. Nice "noob starter" manual comes with the > kit. > > > On Jul 1, 2009, at 10:32 AM, David E. Nelson wrote: > >> david.nelson(at)pobox.com> >> >> >> Hi Mike, >> >> You might look into the "Arduino". >> >> From a learning perspective, this looks to be pretty easy to get started >>> (ie >>> >> relatively low entry cost and easy access to h/w) and has lots of >> potential to go crazy (in a good way, of course ;). The integrated >> development environment (IDE) is open-source and works under Linux, Windows, >> and MacOS X. >> >> Some links: >> >> http://www.arduino.cc >> http://www.arduino.cc/en/Guide/HomePage - Getting Started >> http://www.arduino.cc/playground/ >> http://www.arduino.cc/playground/Code/LCD - LCD Specific writings... >> >> I don't have experience in this area, but thought I'd pass it on in the >> spirit of the original inquiry. >> >> Good luck, >> /\/elson >> >> >> ~~ Lately my memory seems to be like a steel trap .... without any >> spring. ~~ >> >> >> >> >> >> > > -- Mike =============================== Mike Fontenot Apex Consulting & Services LLC Lakewood, Colorado 303 / 731-6645 mikef AT apexconsultingservices DOT com =============================== ________________________________________________________________________________
Date: Jul 01, 2009
From: Buckaroo Banzai <ornerycuss2001(at)yahoo.com>
Subject: Re: Audio panel for nav audio
Gilles, The nav audio is available from the SL-30 without an audio panel.- You ca n also access the menus to adjust the volume of the nav audio relative to t he volume of the com audio.- I have my nav volume set at 80 percent so th at I always hear the com audio over the nav audio.- I've been flying the airplane with this arrangement for 5 years. Greg --- On Wed, 7/1/09, Gilles.Thesee@ac-grenoble.fr wrote: From: Gilles.Thesee@ac-grenoble.fr <Gilles.Thesee@ac-grenoble.fr> Subject: AeroElectric-List: Audio panel for nav audio Date: Wednesday, July 1, 2009, 7:38 AM Hi Bob and all, A buddy asked for help in installing his Garmin SL30. I'll need some clarification about nav audio. Do we actually need an audio panel in order to hear the nav audio input through the phones ? Sorry if this has been asked before, but my home internet connection has be en down for weeks. Thanks in advance, Gilles http://contrails.free.fr le, List Admin. =0A=0A=0A ________________________________________________________________________________
From: "Mike Humphrey" <mike109g6(at)insideconnect.net>
Date: Jul 01, 2009
James, Where can you buy one? Thanks, Mike H ----- Original Message ----- From: berkut13(at)berkut13.com To: aeroelectric-list(at)matronics.com Sent: Wednesday, July 01, 2009 2:49 AM Subject: Re: AeroElectric-List: Race timing help Many of us in the SARL (www.sportairrace.org) purchased low cost GPS data loggers to analyze our own performance. It records at 1sec (programmable) resolution, Lat, Long, Speed, and Alt for about 5hrs, more at lower res. The data can then be uploaded into Google Earth and viewed. It is very easy to mark the crossing of start/finish lines, turn points, etc. From that, you can derive your TRUE course timing - much more accurately than a human centric process. Eventually, the races will be timed off of these units instead of human timers and turn point observers. http://www.globalsat.com.tw/eng/product_detail_00000090.htm This is the one I use, many others are out there. Be sure the one you choose has the ability to output or export to .GPX format. This is the "standard" GPS data format that is expected by most data formatting sites and programs. I also use http://www.gpsvisualizer.com/ to colorize my track by speed, add a semi-transparent wall connected to the ground, and other things. Very neat stuff. It sure lets you know if you blow a turn or wander in altitude/heading. My closest competitor and I share our data and superimpose our tracks on GoogleEarth to see how each others performance compared. At less than $100...this things are golden in my book! James Redmon Berkut #013/Race 13 www.berkut13.com 2007 SARL Silver National Champion ----- Original Message ----- From: Greg Young To: aeroelectric-list(at)matronics.com Sent: Tuesday, June 30, 2009 9:54 PM Subject: AeroElectric-List: Race timing help I just participated in a type club speed event (without lawyers we'd call it a race) and the time keeping got unbelievably screwed up for such a small group (18 planes). Even though there are classes and staggered starts we got folks crossing the finish tip to tip at pattern altitude. Suffice to say that human errors on both the pilots and timers parts caused a lot of grief. Sooo... what kind of technology is out there to assist? All we really need is start and finish times for each plane. It could be plane based, ground based or a combo but it needs to be affordable for 20-30 planes to use and able to deliver the results quickly, e.g. a download and analysis of everyone's 396/496 bread crumb trail probably won't do. I was kinda thinking of giant barcodes under the wing and a 10 KW scanner at the finish point;-) Hopefully someone knows of something simpler, cheaper and more elegant. What's available? Thanks, Greg Young ________________________________________________________________________________
Date: Jul 01, 2009
> >One big problem will be that as you add weight, and the gear flexes, >the bottom end of the gear legs need to move outwards. If you are >stopped, the friction between the tires and the ground prevent the >bottom ends of the gear legs from spreading apart. Once you start to >move, and the wheels roll, the wheels will spread apart a bit to allow >the gear legs to take up their new natural position. So, once the >aircraft is loaded, you won't get a repeatable measurement until the >aircraft rolls a few feet. If while the aircraft is rolling, a tire >comes upon a piece of ground that is not even from side to side, that >will tend to make the wheel roll a bit to the left or right of its >natural position, which will affect the strain on the upper end of the >gear leg, changing the strain gauge output. > >There is no harm in conducting the experiment, but I'm not optimistic >that you would be able to get acceptable accuracy in the real world. >I'll be amazed if you get accuracy better than 100 lb. Aha! I'd not thought of that one. Thanks Ken. Got my feet wet in strain gages about 38 years ago when we fiddled with adding a patient weighing feature to the Mobilizer hospital patient transporter for which I was developing the electrics. http://aeroelectric.com/Pictures/Misc/Mobilizer_3s.jpg The task using electronics available at the time was a challenge! The feature didn't get incorporated until years after the project was sold off and I note that the brochure doesn't mention it now. http://tinyurl.com/mtt42o Here's what we wrestled with back then . . . and you have to look forward to today. Strain gages measure stretching or compression on the surface. It's expressed in MICROINCHES per INCH of dimensional variation as the material is stressed. There's an excellent historical on perceptions and measurement of force at: http://www.omega.com/Literature/Transactions/volume3/history.html The full scale value of signal from a strain gage is very small. Typically, a strain-gage bridge stretched (or compressed) to near limits and excited with 10 volt will give you an output between 5 and 20 millivolts. The materials from which your landing gear is constructed will determine how much strain the gage sees . . . but in landing gears (designed for robustness) it's hard to get large values of strain on robust articles! It's more likely that you would get useful data if you could incorporate off-the-shelf, ruggedized load cells into your gear system. http://www.daytronic.com/products/trans/t-loadcells.htm Pretty ugly . . . no? Hence the signal you need to slice up into 1000-2000 parts for accurately resolving weights can get pretty small to begin with. As Ken mentioned, getting the geometry right for accurately sensing the true gravity component of load on the gear is daunting. Measuring pressure in an oleo strut seems most promising. We do this kind of thing in the lab all the time . . . and on flight test aircraft. But I can tell you that of ALL the measurements we do on test airframes, strain gages are the most problematic either for bonding, wiring, amplifying signals to useful levels, etc. Even if you whipped the instrumentation design, then there's a matter of robustness in the work-a-day environment. Accurate resolution of weight-on-wheels in service has been considered on a lot of projects big and small. They may be doing it well on something like the A380 or B787 . . . but if my boss handed me a project like that today, I'd seriously consider advancing my retirement date! It's NOT easy or everyone would be doing it. Bob . . . ________________________________________________________________________________
Date: Jul 01, 2009
Greg - Take a look here - "Timing the Race" http://www.sportairrace.org/id141.html Sam On Tue, Jun 30, 2009 at 11:54 PM, Greg Young <gyoung@cs-sol.com> wrote: > I just participated in a type club speed event (without lawyers we'd call > it a race) and the time keeping got unbelievably screwed up for such a small > group (18 planes). Even though there are classes and staggered starts we got > folks crossing the finish tip to tip at pattern altitude. Suffice to say > that human errors on both the pilots and timers parts caused a lot of grief. > Sooo... what kind of technology is out there to assist? All we really need > is start and finish times for each plane. It could be plane based, ground > based or a combo but it needs to be affordable for 20-30 planes to use and > able to deliver the results quickly, e.g. a download and analysis of > everyone's 396/496 bread crumb trail probably won't do. I was kinda thinking > of giant barcodes under the wing and a 10 KW scanner at the finish point;-) > Hopefully someone knows of something simpler, cheaper and more elegant. > What's available? > > Thanks, > Greg Young > > * > > * > > ________________________________________________________________________________
Subject: RE: self weighing our planes
Date: Jul 02, 2009
IIRC, the Airbus A-320 family of aircraft weigh themselves. Right after takeoff, and for the reasons cited previously... ________________________________________________________________________________
Subject: Forum Search Problem & RSS Feed Question
Date: Jul 02, 2009
Just finished reading AEC and new to forum, building RV-7. I have 2 questions related to forum administration: 1. Why is it that when I search the archives on a particular topic, and I view one of the threads that came up in the search, I cannot return to the "search results" page by pressing "back" in my browser? Instead I get a "web page expired" and have to repeat the search - every time! Truly a pain. I do not have this problem on other forums, just matronics. 2. Is there a way yo get an RSS feed from this forum to my home page? Thanks, -------- Highest Regards, Noah Forden RV-7A Rhode Island Read this topic online here: http://forums.matronics.com/viewtopic.php?p=251102#251102 ________________________________________________________________________________
Date: Jul 02, 2009
Subject: Re: RE: self weighing our planes
OK, my turn...we used strain gauges in the processing tanks when I worked for a living (pharmaceutical company). It was my idea to incorporate them, and it became my responsibility to calibrate and see that they were properly maintained. For example, when the 5,000 gallon processors were full of product being manufactured, even a fork truck driving by in an aisle outside the room would change the readings...the act of mixing the product would change the readings...even trying to massage the information we were getting from the gauges through computers only worked when everything was still...running water or other liquids into the process could only be accurately measured after the fluids had stopped sloshing around. So, how can strain gauges ever work in a plane while it is moving (as someone earlier wished for...to determine LANDING WEIGHT for example!) Once the plane is in the air, the load is off the legs...the strain is gone...at least the strain from the craft's weight. And while flying, even if there was a method to transfer the measured load from the legs to the wings, that would change constantly with attitude and g forces. The only way I can see the airbus weighing themselves right after take off is a differential between the reading on the ground motionless, and when flying level...after that, I would think that any "weight" reading would be interpolated from fuel burn rate and not an actual weight. Harley ------------------------------------------------------------------------ glen matejcek wrote: > > IIRC, the Airbus A-320 family of aircraft weigh themselves. Right after > takeoff, and for the reasons cited previously... > > > ________________________________________________________________________________
Date: Jul 02, 2009
Subject: Living without an audio panel
I know this has been discussed before, please excuse, I am still confused . My intercom will accept one monaural input. I want to simply "twist" all the low level audio outputs together from the various boxes to the intercom (then solder or crimp). This will make the volume control on the box and its on-off switch the control for that unit. What do I put in line between the intercom input and each box? resistor, diode, snapjack, or do I need a small isolation amplifier? On switching the comm, I assume I need a 4pdt (on-on) to switch=== ==-mic, ptt, indicator light, and audio low so I don't get confused which comm I am listening to while transmitting? Or is there a simple way to maybe add a resistor to the switch so that the non-transmitting comm is still on but with a reduced output? Thank you, Skip Simpson **************Dell Summer Savings: Cool Deals on Popular Laptops =93 Shop Now! =http:%2F%2Faltfarm.mediaplex.com%2Fad%2Fck%2F12309%2D81939%2D1629%2D1) ________________________________________________________________________________
Date: Jul 02, 2009
On 2 Jul 2009, at 08:29, glen matejcek wrote: > > > > IIRC, the Airbus A-320 family of aircraft weigh themselves. Right > after > takeoff, and for the reasons cited previously... I've done flight testing on most of the Airbus family, and this is the first I've ever heard of this. The fly-by-wire Airbus aircraft do have a backup CG calculation that uses airspeed, weight and stabilizer angle. This serves to crosscheck the CG that is calculated from the crew entered values of zero fuel weight and CG. Maybe this is what you were thinking of. -- Kevin Horton (Grounded) RV-8 (Flight Test Phase) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: Jul 02, 2009
Subject: Re: Forum Search Problem & RSS Feed Question
At 07:54 AM 7/2/2009, you wrote: > >Just finished reading AEC and new to forum, building RV-7. I have 2 >questions related to forum administration: > >1. Why is it that when I search the archives on a particular topic, >and I view one of the threads that came up in the search, I cannot >return to the "search results" page by pressing "back" in my >browser? Instead I get a "web page expired" and have to repeat the >search - every time! Truly a pain. I do not have this problem on >other forums, just matronics. Hmmm . . . could be a browser thing. I'm using Firefox and when I select an item from the search results page, it opens that selection in a new tab. I can go back to the previous tab at any time and make further selections. Tried it with IE8 and got a good search results page but when I selected an item for viewing, it opened a new window and went into interminable "waiting for matronics.com" annunciation . Gave up after a couple of minutes. >2. Is there a way yo get an RSS feed from this forum to my home page? Don't think Matt has offered this feature. You'll need to rattle his cage on that one. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jul 02, 2009
At 07:29 AM 7/2/2009, you wrote: > > >IIRC, the Airbus A-320 family of aircraft weigh themselves. Right after >takeoff, and for the reasons cited previously... Hmmmm . . . that perhaps answers some questions about maintain strain gage calibration that accounts for creep in offsets. Waiting until after t.o to display weight gets them a "zero weight" value off the gear stress sensors that becomes a new baseline for the next weighing action. But that does beg the question as to what's the value of knowing that you're over-gross/out-of-CG AFTER takeoff? Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jul 02, 2009
On 2 Jul 2009, at 08:54, Noah wrote: > > Just finished reading AEC and new to forum, building RV-7. I have 2 > questions related to forum administration: > > 1. Why is it that when I search the archives on a particular topic, > and I view one of the threads that came up in the search, I cannot > return to the "search results" page by pressing "back" in my > browser? Instead I get a "web page expired" and have to repeat the > search - every time! Truly a pain. I do not have this problem on > other forums, just matronics. Most web browsers allow you to open a link in a new window or tab, keeping the original window available. Then when you close the window for the new link, the old window with the search results is still there. The exact way to do this varies from browser to browser, and operating system to operating system. For many browsers in many operating systems you would press and hold the Ctrl key, then click the link. -- Kevin Horton (Grounded) RV-8 (Flight Test Phase) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: Jul 02, 2009
Good Morning aerobubba, Any of us can do the same if we wish to go to the trouble of getting highl y accurate calibration of all factors involved. For any specific weight and any specific angle of attack there will be just one speed at which the aircraft will leave the ground. If we note that speed and adjust for all the other pertinent factors we will have the weight. I have used that technique to some degree when flying the DC-8 in a charte r operation. I found that if my weight really was what the paperwork said it was and I initiated rotation when the book said I should, the DC-8 would leave the surface at a nine degree nose up attitude. When I started to fi nd airplanes in the charter operation that didn't do what I expected, I bega n to evaluate each takeoff very carefully. If I rotated to nine degrees and it did not fly, I held the nine degrees until it did lift off. I would then add two thousand pounds to whatever my weight manifest said for each knot above the normal lift off speed that I attained by holding the nine degrees. If I then added that extra weight to my performance calculations, all became normal. As an example, if the lift off speed was ten knots higher than had been calculated I would be twenty thousand pounds heavier than the paperwork showed. By using that new weight to establish climb and cruise numbers, the airplane would deliver the performance required. Hopefully, modern techni ques for gathering the data for weight manifests have improved drastically in the thirty-five plus years since I flew those charters, but it worked well for me! Happy Skies, Old Bob Downers Grove, IL LL22 Stearman N3977A In a message dated 7/2/2009 7:44:03 A.M. Central Daylight Time, aerobubba(at)earthlink.net writes: --> AeroElectric-List message posted by: "glen matejcek" IIRC, the Airbus A-320 family of aircraft weigh themselves. Right after takeoff, and for the reasons cited previously... ======================== =========== ======================== =========== ======================== =========== ======================== =========== **************Dell Summer Savings: Cool Deals on Popular Laptops =93 Shop Now! =http:%2F%2Faltfarm.mediaplex.com%2Fad%2Fck%2F12309%2D81939%2D1629%2D1) ________________________________________________________________________________
Date: Jul 02, 2009
>For example, when the 5,000 gallon processors were full of product >being manufactured, even a fork truck driving by in an aisle outside >the room would change the readings...the act of mixing the product >would change the readings...even trying to massage the information >we were getting from the gauges through computers only worked when >everything was still...running water or other liquids into the >process could only be accurately measured after the fluids had >stopped sloshing around. Yeah. I recall an associate once describing strain gage technology akin to working with tweezers under a microscope during an earthquake. It's truly an exercise in sifting grains of sugar from the rock salt. The artful application of strain gages has been enhanced by advances in software analysis of noise-laden micro-signals. Computers made a huge improvement in accuracy and resolution of slow moving data but if you're wanting to measure vibration or other rapidly changing data over long periods of time, it's a whole new ball game. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jul 02, 2009
U2tpcCwNCg0KIA0KDQpEaWQgeW91IHJlYWxpemUgeW91IGNhbiBidXkgYSBQaWxvdCBicmFuZCAy LTQgcGxhY2UgaW50ZXJjb20gc3RhcnRpbmcgYXQgJDExNS4wMD8gV2h5IGJvdGhlcj8gSnVzdCBm b3IgZnVuPyANCg0KIA0KDQpHbGVubg0KDQogDQoNCkZyb206IG93bmVyLWFlcm9lbGVjdHJpYy1s aXN0LXNlcnZlckBtYXRyb25pY3MuY29tIFttYWlsdG86b3duZXItYWVyb2VsZWN0cmljLWxpc3Qt c2VydmVyQG1hdHJvbmljcy5jb21dIE9uIEJlaGFsZiBPZiBDYXJkaW5hbE5TQkBhb2wuY29tDQpT ZW50OiBUaHVyc2RheSwgSnVseSAwMiwgMjAwOSA5OjI4IEFNDQpUbzogYWVyb2VsZWN0cmljLWxp c3RAbWF0cm9uaWNzLmNvbQ0KU3ViamVjdDogQWVyb0VsZWN0cmljLUxpc3Q6IExpdmluZyB3aXRo b3V0IGFuIGF1ZGlvIHBhbmVsDQoNCiANCg0KSSBrbm93IHRoaXMgaGFzIGJlZW4gZGlzY3Vzc2Vk IGJlZm9yZSwgcGxlYXNlIGV4Y3VzZSwgSSBhbSBzdGlsbCBjb25mdXNlZC4NCg0KIA0KDQpNeSBp bnRlcmNvbSB3aWxsIGFjY2VwdCBvbmUgbW9uYXVyYWwgaW5wdXQuDQoNCiANCg0KSSB3YW50IHRv IHNpbXBseSAidHdpc3QiIGFsbCB0aGUgbG93IGxldmVsIGF1ZGlvIG91dHB1dHMgdG9nZXRoZXIg ZnJvbSB0aGUgdmFyaW91cyBib3hlcyB0byB0aGUgaW50ZXJjb20gKHRoZW4gc29sZGVyIG9yIGNy aW1wKS4gIFRoaXMgd2lsbCBtYWtlIHRoZSB2b2x1bWUgY29udHJvbCBvbiB0aGUgYm94IGFuZCBp dHMgb24tb2ZmIHN3aXRjaCB0aGUgY29udHJvbCBmb3IgdGhhdCB1bml0Lg0KDQogDQoNCldoYXQg ZG8gSSBwdXQgaW4gbGluZSBiZXR3ZWVuIHRoZSBpbnRlcmNvbSBpbnB1dCBhbmQgZWFjaCBib3g/ ICByZXNpc3RvciwgZGlvZGUsIHNuYXBqYWNrLCBvciBkbyBJIG5lZWQgYSBzbWFsbCBpc29sYXRp b24gYW1wbGlmaWVyPw0KDQogDQoNCk9uIHN3aXRjaGluZyB0aGUgY29tbSwgSSBhc3N1bWUgSSBu ZWVkIGEgNHBkdCAob24tb24pIHRvIHN3aXRjaD09PT09LW1pYywgcHR0LCBpbmRpY2F0b3IgbGln aHQsIGFuZCBhdWRpbyBsb3cgc28gSSBkb24ndCBnZXQgY29uZnVzZWQgd2hpY2ggY29tbSBJIGFt IGxpc3RlbmluZyB0byB3aGlsZSB0cmFuc21pdHRpbmc/DQoNCiANCg0KT3IgaXMgdGhlcmUgYSBz aW1wbGUgd2F5IHRvIG1heWJlIGFkZCBhIHJlc2lzdG9yIHRvIHRoZSBzd2l0Y2ggc28gdGhhdCB0 aGUgbm9uLXRyYW5zbWl0dGluZyBjb21tIGlzIHN0aWxsIG9uIGJ1dCB3aXRoIGEgcmVkdWNlZCBv dXRwdXQ/DQoNCiANCg0KVGhhbmsgeW91LCBTa2lwIFNpbXBzb24NCg0KIA0KDQpfX19fX19fX19f X19fX19fX19fX19fX19fX19fX19fXw0KDQpEZWxsIFN1bW1lciBTYXZpbmdzOiBDb29sIERlYWxz IG9uIFBvcHVsYXIgTGFwdG9wcyAtIFNob3AgTm93ISA8aHR0cDovL3ByLmF0d29sYS5jb20vcHJv bW9jbGsvMTAwMTI2NTc1eDEyMjI2OTY5MjR4MTIwMTQ2ODM0OC9hb2w/cmVkaXI9aHR0cDolMkYl MkZhbHRmYXJtLm1lZGlhcGxleC5jb20lMkZhZCUyRmNrJTJGMTIzMDklMkQ4MTkzOSUyRDE2Mjkl MkQxPiANCg0KIA0KIA0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT0NCl8tPSAgICAgICAgICAtIFRoZSBBZXJvRWxlY3RyaWMtTGlz dCBFbWFpbCBGb3J1bSAtDQpfLT0gVXNlIHRoZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJlcyBOYXZp Z2F0b3IgdG8gYnJvd3NlDQpfLT0gdGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMgc3VjaCBhcyBMaXN0 IFVuL1N1YnNjcmlwdGlvbiwNCl8tPSBBcmNoaXZlIFNlYXJjaCAmIERvd25sb2FkLCA3LURheSBC cm93c2UsIENoYXQsIEZBUSwNCl8tPSBQaG90b3NoYXJlLCBhbmQgbXVjaCBtdWNoIG1vcmU6DQpf LT0NCl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP0Flcm9FbGVj dHJpYy1MaXN0DQpfLT0NCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09DQpfLT0gICAgICAgICAgICAgICAtIE1BVFJPTklDUyBXRUIg Rk9SVU1TIC0NCl8tPSBTYW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFibGUgdmlhIHRoZSBX ZWIgRm9ydW1zIQ0KXy09DQpfLT0gICAtLT4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tDQpf LT0NCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09DQpfLT0gICAgICAgICAgICAgLSBMaXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAt DQpfLT0gIFRoYW5rIHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQ0KXy09ICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgLU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLg0KXy09ICAgLS0+ IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24NCl8tPT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQogDQo ________________________________________________________________________________
Date: Jul 02, 2009
>> >> Just finished reading AEC and new to forum, building RV-7. I have 2 >> questions related to forum administration: >> >> 1. Why is it that when I search the archives on a particular topic, >> and I view one of the threads that came up in the search, I cannot >> return to the "search results" page by pressing "back" in my >> browser? Instead I get a "web page expired" and have to repeat the >> search - every time! Truly a pain. I do not have this problem on >> other forums, just matronics. > > Most web browsers allow you to open a link in a new window or tab, > keeping the original window available. Then when you close the window > for the new link, the old window with the search results is still > there. The exact way to do this varies from browser to browser, and > operating system to operating system. For many browsers in many > operating systems you would press and hold the Ctrl key, then click > the link. > > -- > Kevin Horton (Grounded) > RV-8 (Flight Test Phase) > Ottawa, Canada > http://www.kilohotel.com/rv8 With Firefix, just right click the link and select "Open in a new Window" or "Open in a new Tab". However, when I write something for my website, I include "Target=blank" in the html code for any links so that ANY browser using it will open a new window or tab without being asked or ordered to. IMHO, all web authors using html should do this to prevent just the problem that's mentioned above. Harley ________________________________________________________________________________
Date: Jul 02, 2009
Subject: Re: Living without an audio panel
At 08:28 AM 7/2/2009, you wrote: >I know this has been discussed before, please excuse, I am still confused. > >My intercom will accept one monaural input. > >I want to simply "twist" all the low level audio outputs together >from the various boxes to the intercom (then solder or crimp). This >will make the volume control on the box and its on-off switch the >control for that unit. > >What do I put in line between the intercom input and each >box? resistor, diode, snapjack, or do I need a small isolation amplifier? Try series resistors as passive mixing devices. This will take some fiddling but it may get you by. This is described in figure 18-4 and associated text of the 'Connection. Alternatively, consider a small mixing (audio iso) amplifier. An exemplar DIY project is offered at http://www.aeroelectric.com/DIY/Audio_Isolation_Amplifier.pdf there's a number of off-the-self products out there too. Somebody announced their new offerings here on the List a few weeks ago. I've had a number of requests for the ECB to build an amplifier from scratch. I'm putting the bare ECB back on the website catalog in a few minutes. > >On switching the comm, I assume I need a 4pdt (on-on) to >switch=====-mic, ptt, indicator light, and audio low so I don't get >confused which comm I am listening to while transmitting? > >Or is there a simple way to maybe add a resistor to the switch so >that the non-transmitting comm is still on but with a reduced output? I don't know if that's available even in the super-whizzy audio panels. It can be done but certainly calls for a lot of development effort. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jul 02, 2009
Perhaps knowing something about the weight and CG in case you need to make a landing, especially an emergency landing? JR ----- Original Message ---- From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Sent: Thursday, July 2, 2009 7:19:08 AM Subject: Re: AeroElectric-List: RE: self weighing our planes At 07:29 AM 7/2/2009, you wrote: > > IIRC, the Airbus A-320 family of aircraft weigh themselves. Right after > takeoff, and for the reasons cited previously... Hmmmm . . . that perhaps answers some questions about maintain strain gage calibration that accounts for creep in offsets. Waiting until after t.o to display weight gets them a "zero weight" value off the gear stress sensors that becomes a new baseline for the next weighing action. But that does beg the question as to what's the value of knowing that you're over-gross/out-of-CG AFTER takeoff? Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jul 02, 2009
At 10:12 AM 7/2/2009, you wrote: > > > >Perhaps knowing something about the weight and CG in case you need >to make a landing, especially an emergency landing? JR > But is it not an FAA mandate (and a damned good idea) that the pilot know that weight and balance limits have been checked BEFORE takeoff? Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jul 02, 2009
Good Morning Bob, It has to do with something like: "The best laid plans of mice and men ------ " Happy Skies, Old Bob In a message dated 7/2/2009 10:22:05 A.M. Central Daylight Time, nuckolls.bob(at)aeroelectric.com writes: --> AeroElectric-List message posted by: "Robert L. Nuckolls, III" At 10:12 AM 7/2/2009, you wrote: > > > >Perhaps knowing something about the weight and CG in case you need >to make a landing, especially an emergency landing? JR > But is it not an FAA mandate (and a damned good idea) that the pilot know that weight and balance limits have been checked BEFORE takeoff? Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ======================== =========== ======================== =========== ======================== =========== ======================== =========== **************Dell Summer Savings: Cool Deals on Popular Laptops =93 Shop Now! =http:%2F%2Faltfarm.mediaplex.com%2Fad%2Fck%2F12309%2D81939%2D1629%2D1) ________________________________________________________________________________
Date: Jul 02, 2009
Thanks for the responses guys. Bob, just curious why you started a new thread rather than respond to my original post, keeping this discussion all in one thread? Kevin, I'm using IE-7, and you suggest a reasonable workaround by opening a new tab. Sometimes, however, opening a new tab can take up to 30 seconds do display anything. In any event, I'm still not clear why I can do this without issue on other forums (VAF for instance) and why it's different here. Perhaps Matt can fix this. Google Chrome also does not exhibit this behavior. Another feature I like on some other forums is that from the home page or search results page, you can "hover over" the thread title to read the first couple of sentences of the first post. VERY handy to see if it's something worth reading without taking the time to click in, wait, read, and click back out. It's all about reducing mouse clicks, you know! -------- Highest Regards, Noah Forden RV-7A Rhode Island Read this topic online here: http://forums.matronics.com/viewtopic.php?p=251165#251165 ________________________________________________________________________________
Date: Jul 02, 2009
Subject: AeroElectric-List: Re: Forum Search Problem & RSS Feed Question From: "Noah" <sgninc(at)cox.net> Thanks for the responses guys. Bob, just curious why you started a new thread rather than respond to my original post, keeping this discussion all in one thread? Don't think I did. This is a reply to the original from my trash bin just as it came to me about 8:00 this morning ------------------------- At 07:54 AM 7/2/2009, you wrote: > >Just finished reading AEC and new to forum, building RV-7. I have 2 >questions related to forum administration: > >1. Why is it that when I search the archives on a particular topic, >and I view one of the threads that came up in the search, I cannot >return to the "search results" page by pressing "back" in my >browser? Instead I get a "web page expired" and have to repeat the >search - every time! Truly a pain. I do not have this problem on >other forums, just matronics. > >2. Is there a way yo get an RSS feed from this forum to my home page? > >Thanks, > >---------------------- Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jul 02, 2009
Kevin Horton wrote: > > > One big problem will be that as you add weight, and the gear flexes, > the bottom end of the gear legs need to move outwards. If you are > stopped, the friction between the tires and the ground prevent the > bottom ends of the gear legs from spreading apart. Once you start to > move, and the wheels roll, the wheels will spread apart a bit to allow > the gear legs to take up their new natural position. So, once the > aircraft is loaded, you won't get a repeatable measurement until the > aircraft rolls a few feet. If while the aircraft is rolling, a tire > comes upon a piece of ground that is not even from side to side, that > will tend to make the wheel roll a bit to the left or right of its > natural position, which will affect the strain on the upper end of the > gear leg, changing the strain gauge output. > > There is no harm in conducting the experiment, but I'm not optimistic > that you would be able to get acceptable accuracy in the real world. > I'll be amazed if you get accuracy better than 100 lb. > I'd expect that what you'd get is a readout that bounced around. The question is, does it bounce around the middle of your W&B range, or is it bouncing around one of the extremes? If you use it for a sanity check, it could be a useful tool. No one really needs the weight to within a 1/4 oz anyway, just whether the wife was lying about how many shoes she was taking. If you're trying to use it to get an exact W&B, I'd say you were fooling yourself. BTW, Kevin. If I were within 100lbs of gross or 1/2" of my CG limit, I'd be reweighing stuff and re-doing my calculation a couple more times with extra care anyway 8*) -- http://www.ernest.isa-geek.org ________________________________________________________________________________
From: "Gordon Smith" <gordonrsmith921(at)yahoo.com>
Subject: AEC Products - Future Z Revisions?
Date: Jul 02, 2009
Given: Electrically Dependent Engine Internally Regulated Alternator Z-19 + Z-24 AEC 9005 Discontinued AEC 9004 & AEC 9011 to be available at a later date. Question: How to best accomplish OV/LV Control with Automatic Aux Battery Contactor Control? My thoughts: AEC 9011 doesn't appear to have an output capable of the Aux Battery Contactor Automatic control, and therefore might not be appropriate in this example as an alternate replacement for the AEC 9005. It appears that the #1 terminal of the AEC 9004 might be used to not only control the Alternator OV Disconnect Contactor but also to offer automatic control of the Aux Battery Contactor. Or would something such as the LVWAABM by Eric Jones have to be employed in addition to the AEC 9004? Gordon Smith
June 23, 2009 - July 02, 2009
AeroElectric-Archive.digest.vol-iu
