AeroElectric-Archive.digest.vol-iw
July 15, 2009 - July 31, 2009
      > After all the great info and advice I got on the fuses, I thought I
      > would try asking about contacters too  [Wink] .
      > The aircraft manufacturer, and the engine manual both give a wiring
      > diagram that does NOT include a master contacter. The battery
      > positive goes directly to a master switch, and then to the main bus.
      > This is the first time I have seen a configuration like this
      > (without the contacter).  What are the advantages, and disadvantages
      > of doing it this way?  My maximum current draw is around 10A, so
      > well within the continuous current range of a small toggle switch.
      > Thanks!
      > Justin
      > http://forums.matronics.com/viewtopic.php?p=253209#253209
Date: Jul 15, 2009
Subject: D.A.R question about fuse access
At 11:39 AM 7/15/2009, you wrote: >I wonder how a DAR would look upon Vertical Power. No fuses. You >have a control box in the panel that you can reset a "failed" >circuit, but that's it. There's no ability to "change fuses in flight". . . . but you can 'reset' a tripped circuit under software control. One of the BIG arguments for breakers over fuses was the ease of resetting and low risk for dropping a fuse holder's cap . . . Emacs! . . . not to mention relief from having to carry spare fuses. The advantages are inarguable. Over the past 20+ years we've developed various tools for fault current protection including remotely controlled circuit breakers and sundry electronic fault detection and reaction systems. The Eclipse 500 had no breakers in the cockpit but pilots had access to LOTS of breakers via flat screens and software. But getting back to simple ideas: Fuses/breakers/other are intended to protect the airframe from hard faults that put other systems if not the entire airframe at risk. Once that fault occurs, the system is out of business. It's a good idea to make the event known to the crew . . . but resetting is 99.99% never useful or a good idea. It was reported that repeated resets of the cabin heater breaker on an airplane carrying Ricky Nelson may have figured in the fire that brought the airplane down. The prudent rule for tripped breakers and fuses (that are sized to avoid nuisance trips) is leave them alone until on the ground. Should it be that said breaker powers something you really need . . . then so much for failure tolerance (or perhaps even the decision to launch). From my personal sense of elegant solutions, the idea that replacing a perfectly good 25 cent fuse with hardware that is larger, more expensive, higher parts count, and perhaps driven by software does not make the airplane cost less, assemble faster or perform better . . . nor is it a positive return on investment. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Subject: Re: D.A.R question about fuse access
Date: Jul 15, 2009
I can't reach any of my fuses in flight. I did this by design. I don't want to be tempted to fiddle with them. There isn't anything in my panel (VFR day/night) that will kill me if it fails, but fiddling with fuses when I should be flying the airplane can kill me. My DAR didn't ask. Some might. Just answer that there isn't any electrical circuit in your airplane that you can't LIVE without. If he/ she has a problem with that answer then make sure and warn your fellow builders about that DAR so that he/she may be avoided. Phil Birkelbach Houston RV7 - 727WB phil(at)petrasoft.net http://www.myrv7.com/ On Jul 15, 2009, at 2:19 PM, thomas sargent wrote: > > I'm confused by this thread. Are you telling me that the D.A.R. is > going to REQUIRE that my fuse block be accessible in flight? (Mine > isn't.) Or are you just telling me I need to have a rap prepared to > respond to the question. > > > -- > Tom Sargent > > ________________________________________________________________________________
Subject: Re: Contacter, or not?
Date: Jul 15, 2009
The battery is mounted around 12" from the starter, and 20" from the panel. All 'heavy' current wires are fairly short. I really like the idea of making it as simple as possible. Added complexity just means extra failure points. I will definitely go for a fusible link and a switch. Thanks for the info. Justin Read this topic online here: http://forums.matronics.com/viewtopic.php?p=253233#253233 ________________________________________________________________________________
Date: Jul 15, 2009
Tom, Absolutely not. You will find 100's of units with fuse blocks in very un-reachable positions. Do a little searching on Google. Remember, we are experimental - use poly fuses, fuse links or whatever you like. What folks are saying is that should any individual component be lost, be sure you can do without it (yes, Mr./Ms. DAR I can do without that). Period. Most prefer not trying to fix the broken thingy in flight, but rather get it down and tend to it on the ground. As Bob indicated failed items most often have nothing to do with the fuse/breaker. Stick and rudder folks know you really only need an airspeed indicator to get down safely in VFR. Make it a good one. Fuses are great and certainly reduce the owner's cost. I do like having breakers on my alternators to kill them if necessary. There again if the alternator breaker is popping for any reason than the occasional power surge, just leave it out and get down until fixed. Glenn From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Phil Birkelbach Sent: Wednesday, July 15, 2009 4:54 PM Subject: Re: AeroElectric-List: D.A.R question about fuse access I can't reach any of my fuses in flight. I did this by design. I don't want to be tempted to fiddle with them. There isn't anything in my panel (VFR day/night) that will kill me if it fails, but fiddling with fuses when I should be flying the airplane can kill me. My DAR didn't ask. Some might. Just answer that there isn't any electrical circuit in your airplane that you can't LIVE without. If he/she has a problem with that answer then make sure and warn your fellow builders about that DAR so that he/she may be avoided. Phil Birkelbach Houston RV7 - 727WB phil(at)petrasoft.net http://www.myrv7.com/ On Jul 15, 2009, at 2:19 PM, thomas sargent wrote: I'm confused by this thread. Are you telling me that the D.A.R. is going to REQUIRE that my fuse block be accessible in flight? (Mine isn't.) Or are you just telling me I need to have a rap prepared to respond to the question. -- Tom Sargent href="http://www.matronics.com/Navigator?AeroElectric-List">http://www. m atronics.com/Navigator?AeroElectric-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c o ntribution ________________________________________________________________________________
Date: Jul 15, 2009
Subject: Re: Automotive blade fuses?
Good Evening Sarge, Do we really need fuses of that low an amperage? Seems to me that what we need to protect are the wires. Unless you have awfully small diameter wires, five amp should be as small as you need. Five amp will protect a number twenty-two wire. That is as small as I ever use! Happy Skies, Old Bob In a message dated 7/15/2009 2:42:17 P.M. Central Daylight Time, sarg314(at)gmail.com writes: Autozone has them, but only in values used commonly in cars. For your plane you will need a lot of small values - 1 or 2 or 3 amps. I doubt you'll find those at autozone or checker. B&C Specialty has them. **************Can love help you live longer? Find out now. (http://personals.aol.com/articles/2009/02/18/longer-lives-through-relationships/?ncid=emlweu slove00000001) ________________________________________________________________________________
Date: Jul 15, 2009
Good Evening Glenn, My primary instructor kept the airspeed covered up most of the time. I learned to control airspeed via the sound and by the feel of the controls. Who needs an airspeed indicator? I may not be able to hold it dead on a specific number, but I can sure stay fast enough to avoid a stall and slow enough to get it stopped in a reasonable distance! Happy Skies, Old Bob In a message dated 7/15/2009 4:43:18 P.M. Central Daylight Time, longg(at)pjm.com writes: Stick and rudder folks know you really only need an airspeed indicator to get down safely in VFR. Make it a good one. **************Can love help you live longer? Find out now. (http://personals.aol.com/articles/2009/02/18/longer-lives-through-relationships/?ncid=emlweu slove00000001) ________________________________________________________________________________
Date: Jul 15, 2009
At 02:42 PM 7/15/2009, you wrote: > >After all the great info and advice I got on the fuses, I thought I >would try asking about contacters too [Wink] . > >The aircraft manufacturer, and the engine manual both give a wiring >diagram that does NOT include a master contacter. The battery >positive goes directly to a master switch, and then to the main bus. > >This is the first time I have seen a configuration like this >(without the contacter). What are the advantages, and disadvantages >of doing it this way? My maximum current draw is around 10A, so >well within the continuous current range of a small toggle switch. The legacy design goal for a battery master disconnect is to provide a means by which nearly all wiring in the airplane is 'cold' when the disconnect is open. If the battery is conveniently located then some form of manual switch can be considered. Perhaps like this? Emacs! Emacs! The next reason for a battery master disconnect is to provide a means by which the battery can be shut off if the starter contactor (solenoid) sticks. If the battery master cannot positioned conveniently for manual operation, then perhaps a contactor is indicated. These can be low power devices like the EV series devices from TYCO . . . but it's pretty easy to make an el-cheeso contactor emulate the low power characteristics of the TYCO device. Finally, a couple of guys on the list were working on versions of remotely controlled, manual switches like this: http://aeroelectric.com/Catalog/AEC/9042/9042-100.pdf In any case, there's two good reasons for a battery master disconnect. The style is up to you as is the choice for installing one. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jul 15, 2009
Well, yes, protecting the wire is the main task of the fuse. But If I have a device that I know should only use a fraction of an amp (my avionics cooling fan for example) and it starts drawing 2 amps, there's probably something seriously wrong with it. It will be toast long before the #22 wire (or a 5 amp fuse) ever burns up. The little thing could melt itself on 2 measly amps. So I put a 2 amp fuse on it. That still protects the wire and will keep the smoke level down in the cockpit. The fan is probably dead either way. On Wed, Jul 15, 2009 at 3:11 PM, wrote: > Good Evening Sarge, > > Do we really need fuses of that low an amperage? > > Seems to me that what we need to protect are the wires. Unless you have > awfully small diameter wires, five amp should be as small as you need. Five > amp will protect a number twenty-two wire. That is as small as I ever use! > > Happy Skies, > > Old Bob > > In a message dated 7/15/2009 2:42:17 P.M. Central Daylight Time, > sarg314(at)gmail.com writes: > > Autozone has them, but only in values used commonly in cars. For your > plane you will need a lot of small values - 1 or 2 or 3 amps. I doubt > you'll find those at autozone or checker. B&C Specialty has them. > > > ------------------------------ > > -- Tom Sargent ________________________________________________________________________________
Date: Jul 15, 2009
Bob, Your comments gave me another idea.. If you only have 12-14A to play with (little dynamo), and the airplane has a starter.. And your normal running power budget is a fairly high percentage of the output of the dynamo.. One could install a battery contactor (or starter relay) just for running the starter - in series with any starter/engine mounted relay/solenoid. Once the engine is running, the current draw from the monster contactor can be eliminated and you can drop back to a more power-frugal relay for driving the rest of the electronics on the airplane - a relay installed in parallel. I can't think of any downside. Regards, Matt- > At 02:42 PM 7/15/2009, you wrote: >> >> >>After all the great info and advice I got on the fuses, I thought I >>would try asking about contacters too [Wink] . >> >>The aircraft manufacturer, and the engine manual both give a wiring >>diagram that does NOT include a master contacter. The battery >>positive goes directly to a master switch, and then to the main bus. >> >>This is the first time I have seen a configuration like this >>(without the contacter). What are the advantages, and disadvantages >>of doing it this way? My maximum current draw is around 10A, so >>well within the continuous current range of a small toggle switch. > > The legacy design goal for a battery master > disconnect is to provide a means by which nearly > all wiring in the airplane is 'cold' when the > disconnect is open. If the battery is conveniently > located then some form of manual switch can be > considered. Perhaps like this? > > Emacs! > > Emacs! > > > The next reason for a battery master disconnect is > to provide a means by which the battery can be > shut off if the starter contactor (solenoid) > sticks. > > If the battery master cannot positioned conveniently > for manual operation, then perhaps a contactor is > indicated. These can be low power devices like the > EV series devices from TYCO . . . but it's pretty > easy to make an el-cheeso contactor emulate the > low power characteristics of the TYCO device. > > Finally, a couple of guys on the list were working > on versions of remotely controlled, manual switches > like this: > > http://aeroelectric.com/Catalog/AEC/9042/9042-100.pdf > > In any case, there's two good reasons for a battery > master disconnect. The style is up to you as is > the choice for installing one. > > > Bob . . . > > --------------------------------------- > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > --------------------------------------- > > ________________________________________________________________________________
Subject: glass fuses
Date: Jul 15, 2009
That is really what you should be using (is ATO blade type fuses) over the >glass fuses. From our experience, using glass fuses has many negatives and >they aren't something we'd really recommend for airplanes anymore. Bob> Absolutely! These have fragile internal connections at the ends of the fusible links . . . they also used large area, low pressure connections in their holders. Not gas-tight. Hi all: 1st time posting to this list. Years ago I owned a "75 Celica GT that had an electric fuel pump. The car kept quitting for no apparent reason (usually when my girlfriend drove it). Ended up my favorite auto mechanic found the fuse end cap was loose that fed the fuel pump. There is no way I would use glass fuses for anything in an aircraft. Regards Rick Lark Southampton, Ont RV10 #40956 ________________________________________________________________________________
Date: Jul 16, 2009
At 06:50 PM 7/15/2009, you wrote: > >Bob, > >Your comments gave me another idea.. If you only have 12-14A to play with >(little dynamo), and the airplane has a starter.. And your normal running >power budget is a fairly high percentage of the output of the dynamo.. >One could install a battery contactor (or starter relay) just for running >the starter - in series with any starter/engine mounted relay/solenoid. >Once the engine is running, the current draw from the monster contactor >can be eliminated and you can drop back to a more power-frugal relay for >driving the rest of the electronics on the airplane - a relay installed in >parallel. I can't think of any downside. That would work too. I'm thinking that for small airplanes, the manual battery switch makes the most sense. They're light and inexpensive. I've got a prototype contactor power manager on the bench but didn't get to finish evaluating it before I had to pull the plugs and start moving equipment and inventory. It would allow the builder to achieve low power operation with an el-cheeso contactor. Further, if the contactor needs replacing, you don't have to replace the associated electronics too . . . and vice versa Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jul 16, 2009
At 05:25 PM 7/15/2009, you wrote: >Good Evening Glenn, > >My primary instructor kept the airspeed covered up most of the time. >I learned to control airspeed via the sound and by the feel of the controls. > >Who needs an airspeed indicator? Only those not skilled in doing without them. When I checked out new renters in our 150's I used to demonstrate that "sticking the upper edge of the cowl on the horizon" got you an 80 mph climb. I further demonstrated that if the horizon is visible over the nose, you cannot be too slow. After that, paying attention to power settings pretty much covers the bases for not having an unhappy day in the pattern. I found this necessary/useful when new renters were transitioning to an uncontrolled field sharing a 5 mile radius with 5 other uncontrolled fields. It was a good idea to keep your eyes on the surrounding environment as opposed to sticking the needles on some finely tuned value for speeds and power. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jul 16, 2009
Subject: Re: glass fuses
At 09:06 PM 7/15/2009, you wrote: >That is really what you should be using (is ATO blade type fuses) over the > >glass fuses. From our experience, using glass fuses has many negatives and > >they aren't something we'd really recommend for airplanes anymore. > > Bob> Absolutely! These have fragile internal connections at > the ends of the fusible links . . . they also used large > area, low pressure connections in their holders. Not > gas-tight. > >Hi all: 1st time posting to this list. Welcome aboard sir! > >Years ago I owned a "75 Celica GT that had an electric fuel >pump. The car kept quitting for no apparent reason (usually when my >girlfriend drove it). Ended up my favorite auto mechanic found the >fuse end cap was loose that fed the fuel pump. There is no way I >would use glass fuses for anything in an aircraft. Hmmm . . . that too. I've seen those critters get 'unhooked' inside on several occasions myself. Those little two-legged plastic critters may look cheesy but they're the culmination of a century of lessons learned and recipes for success with very long field histories. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Subject: Solid State Relays
Date: Jul 16, 2009
Saw these http://www.futurlec.com/RelSS.shtml and for $20 they look like possible replacements for the common electro-mechanical relays that we now use. These are light, compact, and very reliable. But I don't know if there are gradations of MOSFETs or if they're just basic building blocks. The cost of these is about 1/8 of an almost identical Teledyne unit and I wonder if "you get what you pay for" is appropriate to apply here? Or is Teledyne just passing on the costs of marketing, regulatory environment, lawyers, pensions, etc? The only obvious downside that is evident from the data sheet is that the load capability starts falling off at about 60 deg C, so installation in an engine compartment is off the table without a blast tube and heatsink. One of these has a load spec of 240VAC @ 70A and another specs 100VDC @ 40A. I'd rather have more amperage capacity. Do solid state relays care whether the load is DC or AC? What think you all? John ________________________________________________________________________________
Date: Jul 16, 2009
Rich and others: Actually. Rick I ended up deciding there was ONE application for an in-line "glass" fuse. That is the always LIVE when the Master Switch is ON. I put my only in-line glass fuse immediately behind the top of the firewall. It's hard to replace - but the hot wire is only several inches long - with no chance to rub anything. Ernest Kells RV-9A ----- Original Message ----- From: Rick and Sandra Lark To: aeroelectric-list(at)matronics.com Sent: Wednesday, July 15, 2009 10:06 PM Subject: AeroElectric-List: glass fuses That is really what you should be using (is ATO blade type fuses) over the >glass fuses. From our experience, using glass fuses has many negatives and >they aren't something we'd really recommend for airplanes anymore. Bob> Absolutely! These have fragile internal connections at the ends of the fusible links . . . they also used large area, low pressure connections in their holders. Not gas-tight. Hi all: 1st time posting to this list. Years ago I owned a "75 Celica GT that had an electric fuel pump. The car kept quitting for no apparent reason (usually when my girlfriend drove it). Ended up my favorite auto mechanic found the fuse end cap was loose that fed the fuel pump. There is no way I would use glass fuses for anything in an aircraft. Regards Rick Lark Southampton, Ont RV10 #40956 ________________________________________________________________________________
Subject: Re: Solid State Relays
Date: Jul 16, 2009
OK, I should've gone to the archives BEFORE I posted this thread. But the objection 11/2 yrs ago was a voltage drop of 1.5 @ 12v. These claim .35v @30V. Did the earlier versions claim a similarly low V drop? I guess the only way to be sure is to buy one and test it. JB ________________________________________________________________________________
Date: Jul 16, 2009
Bob, Too funny! So true - I have had the same experience in the Pitts - you can feel when it's right. The Pitts will let you know when it's not. In a Lanciar, I find it behaves best when flown by the numbers. I should throw in a caveat of "the last standing instrument I'd enjoy having" Remember, flying is easy - the plane will always go where you point it, except when you are too slow. Don't do that. Have a great day. From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Thursday, July 16, 2009 11:16 AM Subject: Re: AeroElectric-List: D.A.R question about fuse access At 05:25 PM 7/15/2009, you wrote: Good Evening Glenn, My primary instructor kept the airspeed covered up most of the time. I learned to control airspeed via the sound and by the feel of the controls. Who needs an airspeed indicator? Only those not skilled in doing without them. When I checked out new renters in our 150's I used to demonstrate that "sticking the upper edge of the cowl on the horizon" got you an 80 mph climb. I further demonstrated that if the horizon is visible over the nose, you cannot be too slow. After that, paying attention to power settings pretty much covers the bases for not having an unhappy day in the pattern. I found this necessary/useful when new renters were transitioning to an uncontrolled field sharing a 5 mile radius with 5 other uncontrolled fields. It was a good idea to keep your eyes on the surrounding environment as opposed to sticking the needles on some finely tuned value for speeds and power. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jul 16, 2009
If I read the data correctly, it appears these relays are only rated at 3A continuous which even fairly small switches can handle. Not sure why you'd pick the relay over a switch unless you wanted to use a micro-micro switch to control something. Also, a few other issues: - It's rated for AC. Not sure how it will perform controlling a DC load. - The forward voltage drop seems like it might be large - up to 1.5V at peak current. Not only is that a bit of a performance hit, it will generate some heat. The app notes specify to provide adequate ventilation. - Don't know what behavior you might see if the load tried to drive the source - might not be bidirectional. Regards, Matt- > Saw these > http://www.futurlec.com/RelSS.shtml > and for $20 they look like possible replacements for the common > electro-mechanical relays that we now use. These are light, compact, and very reliable. But I don't know if there are gradations of MOSFETs or if they're just basic building blocks. The cost of these is about 1/8 of an almost identical Teledyne unit and I wonder if "you get what you pay for" > is appropriate to apply here? Or is Teledyne just passing on the costs of > marketing, regulatory environment, lawyers, pensions, etc? > > The only obvious downside that is evident from the data sheet is that the > load capability starts falling off at about 60 deg C, so installation in an engine compartment is off the table without a blast tube and heatsink. > > One of these has a load spec of 240VAC @ 70A and another specs 100VDC @ 40A. I'd rather have more amperage capacity. Do solid state relays care whether the load is DC or AC? > > What think you all? > > John > > ________________________________________________________________________________
Date: Jul 16, 2009
I think you may have looked at the wrong part. You have to go down to the bottom of the page to find the high amp rated DC units. That said, see my previous email. Dick Tasker Matt Prather wrote: > > If I read the data correctly, it appears these relays are only rated at 3A > continuous which even fairly small switches can handle. Not sure why > you'd pick the relay over a switch unless you wanted to use a micro-micro > switch to control something. > > Also, a few other issues: > > - It's rated for AC. Not sure how it will perform controlling a DC load. > - The forward voltage drop seems like it might be large - up to 1.5V at > peak current. Not only is that a bit of a performance hit, it will > generate some heat. The app notes specify to provide adequate > ventilation. > - Don't know what behavior you might see if the load tried to drive the > source - might not be bidirectional. > > > Regards, > > Matt- > ________________________________________________________________________________
Date: Jul 16, 2009
The 0.35V drop only applies to the low voltage assemblies which are not listed at Futurlec. They only show the 100V and 200V for sale and they have a much higher voltage drop at a lower current. The 30V versions look very attractive with the 0.007 milliohm on resistance at 50A. However, they say nothing about reverse voltage, so I would have to assume that these are only good for supplying power to a load and not good for use where there could be a reverse voltage on them - such as what would occur if you were trying to use two of these to switch two different batteries to a common load. Dick Tasker John Burnaby wrote: > OK, I should've gone to the archives BEFORE I posted this thread. > But the objection 11/2 yrs ago was a voltage drop of 1.5 @ 12v. These > claim .35v @30V. Did the earlier versions claim a similarly low V drop? > I guess the only way to be sure is to buy one and test it. > > JB ________________________________________________________________________________
Date: Jul 16, 2009
Robert L. Nuckolls, III wrote: > At 05:25 PM 7/15/2009, you wrote: >> Good Evening Glenn, >> >> My primary instructor kept the airspeed covered up most of the time. >> I learned to control airspeed via the sound and by the feel of the >> controls. >> >> Who needs an airspeed indicator? > > Only those not skilled in doing without them. When I > checked out new renters in our 150's I used to demonstrate > that "sticking the upper edge of the cowl on the > horizon" got you an 80 mph climb. I further demonstrated > that if the horizon is visible over the nose, you cannot > be too slow. After that, paying attention to power settings > pretty much covers the bases for not having an unhappy day > in the pattern. That instrument only works for people of the same height. It has to be recalibrated for some of us 8*) -- http://www.ernest.isa-geek.org ________________________________________________________________________________
From: "Bob McCallum" <robert.mccallum2(at)sympatico.ca>
Date: Jul 16, 2009
Ernest; Why an inline "glass" fuse???? The ATO style fuse is a much better choice with its one piece design, high pressure contacts etc. All the same reasons that the automotive world went blade style to replace the "old technology" "glass" fuses. No soldered end caps to come loose, no low pressure contacts to corrode and fail. ATO/ATC is a much more reliable choice. This holder is even waterproof. Good for 30A. http://tinyurl.com/l4eaae Similar holders are available for the Maxi series as well if you require higher ratings. Bob McC _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ernest Kells Sent: Thursday, July 16, 2009 12:04 PM Subject: Re: AeroElectric-List: glass fuses Rich and others: Actually. Rick I ended up deciding there was ONE application for an in-line "glass" fuse. That is the always LIVE when the Master Switch is ON. I put my only in-line glass fuse immediately behind the top of the firewall. It's hard to replace - but the hot wire is only several inches long - with no chance to rub anything. Ernest Kells RV-9A ----- Original Message ----- From: Rick and Sandra Lark <mailto:jrlark(at)bmts.com> Sent: Wednesday, July 15, 2009 10:06 PM Subject: AeroElectric-List: glass fuses That is really what you should be using (is ATO blade type fuses) over the >glass fuses. From our experience, using glass fuses has many negatives and >they aren't something we'd really recommend for airplanes anymore. Bob> Absolutely! These have fragile internal connections at the ends of the fusible links . . . they also used large area, low pressure connections in their holders. Not gas-tight. Hi all: 1st time posting to this list. Years ago I owned a "75 Celica GT that had an electric fuel pump. The car kept quitting for no apparent reason (usually when my girlfriend drove it). Ended up my favorite auto mechanic found the fuse end cap was loose that fed the fuel pump. There is no way I would use glass fuses for anything in an aircraft. Regards Rick Lark Southampton, Ont RV10 #40956 href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matro nics.com/Navigator?AeroElectric-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Jul 16, 2009
Subject: Situational awareness as an instrument of flight.
>> Only those not skilled in doing without them. When I >> checked out new renters in our 150's I used to demonstrate >> that "sticking the upper edge of the cowl on the >> horizon" got you an 80 mph climb. I further demonstrated >> that if the horizon is visible over the nose, you cannot >> be too slow. After that, paying attention to power settings >> pretty much covers the bases for not having an unhappy day >> in the pattern. >That instrument only works for people of the same height. It has to >be recalibrated for some of us 8*) Yeah . . . that's why I was happy the thing averaged 80 . . . Short guys IAS was a little slower, taller guys were a little faster but rate of climb wasn't enough different to worry about. Bottom line was that it kept the guy's eyeballs out of the cockpit in the airport traffic area. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jul 17, 2009
Subject: Re: Situational awareness as an instrument of flight
redux >>> . . . . I further demonstrated >>> that if the horizon is visible over the nose, you cannot >>> be too slow. After that, paying attention to power settings >>> pretty much covers the bases for not having an unhappy day >>> in the pattern. >>That instrument only works for people of the same height. It has >>to be recalibrated for some of us 8*) > > Yeah . . . that's why I was happy the thing averaged > 80 . . . > > Short guys IAS was a little slower, Got that backwards! Must have been too much hauling furniture in the 100+ heat for two days! Obviously, if the individual is shorter then for any given deck angle, his response would be to LOWER the nose to bring it back into alignment with the horizon, i.e. IAS will he HIGHER for the same gross weight, and power setting. Had hard time getting to sleep last night thinking about it and discovering my brain-f#@t . . . Probably need to avoid heavy thinking for a few days. We got Dr. Dee's office spaces 90% moved (probably 1000 pounds of books and another 500 pounds of filing cabinets. I'm trying whole-house wi-fi to avoid stringing lots of cat-5 cable. After an arm wrestling match with "Network Magic" I tossed it out and studied the semi-lame instructions for the router. Got it to come up nicely with the MAC address filtering mode for security so the ground has been prepared for expanding the network to the house and shop. When Dad built this house, I strung hundreds of feet of of twin-lead antenna and twisted-pair phone lines around. Today, none of those wires are in use. A single strand of glass comes to the back of the house to deliver telephone, high speed Internet, and soon to be TV. Both Internet and telephone are hardwired from the fiber modem to network nodes that move all data around the house over spread- spectrum radio. My Dad would be fascinated with all that is changing with the house he built in 4 years of "spare" time 44 years ago. Bob . . . ________________________________________________________________________________
Date: Jul 17, 2009
Subject: Re: Bluetooth headsets was Situational awareness as
an instrument of flight redux Bob et al... Since we are quickly moving to a wireless world... I haven't seen wireless aircraft headsets. This seems like an ideal application for the technology. Is anyone making such a device? Chris Stone RV-8 Oregon > I'm trying whole-house wi-fi to avoid > stringing lots of cat-5 cable. After an > arm wrestling match with "Network Magic" > I tossed it out and studied the semi-lame > instructions for the router. Got it to > come up nicely with the MAC address filtering > mode for security so the ground has been > prepared for expanding the network to the > house and shop. >> > Bob . . . > > ________________________________________________________________________________
Date: Jul 17, 2009
Ernest, you are definitely a geek. Why not try an electric engine? -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ernest Christley Sent: Thursday, July 16, 2009 2:53 PM Subject: Re: AeroElectric-List: D.A.R question about fuse access Robert L. Nuckolls, III wrote: > At 05:25 PM 7/15/2009, you wrote: >> Good Evening Glenn, >> >> My primary instructor kept the airspeed covered up most of the time. >> I learned to control airspeed via the sound and by the feel of the >> controls. >> >> Who needs an airspeed indicator? > > Only those not skilled in doing without them. When I > checked out new renters in our 150's I used to demonstrate > that "sticking the upper edge of the cowl on the > horizon" got you an 80 mph climb. I further demonstrated > that if the horizon is visible over the nose, you cannot > be too slow. After that, paying attention to power settings > pretty much covers the bases for not having an unhappy day > in the pattern. That instrument only works for people of the same height. It has to be recalibrated for some of us 8*) -- http://www.ernest.isa-geek.org ________________________________________________________________________________
Date: Jul 17, 2009
Subject: Fuseblock drawings
Is there a .dwg file of the fuseblocks, besides the isometric view? I am looking for a 2-D version that I can use to label for easy I.D. of the fuse size, and the wire that attaches to it. Thanks. Sam Hoskins www.samhoskins.blogspot.com ________________________________________________________________________________
Date: Jul 17, 2009
Subject: Re: offtopic: the goodie of todays communication
world At 08:40 AM 7/17/2009, you wrote: > >Hello Bob, > >off topic as not aircraft related. > >Bob, you can go even a step further, my Audio setup consists of >several Logitech boxes (squeezebox receiver, boom, duett ><http://www.logitechsqueezebox.com/products/overview.html>) Interesting! I'll check it out. Thanks! Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jul 17, 2009
as an instrument of flight redux At 08:41 AM 7/17/2009, you wrote: > >Bob et al... > >Since we are quickly moving to a wireless world... >I haven't seen wireless aircraft headsets. >This seems like an ideal application for the technology. You got that right. I'm thinking I saw an article on a DIY OBAM aircraft wireless headset project but don't recall where. Getting one 'approved' to go into an airplane might be another matter. But totally wireless would be a real breath of fresh air in the cockpit of most airplanes. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Subject: Re: Fuseblock drawings
Date: Jul 17, 2009
Sam, Here is a dwg file and a pdf drawing of the 8-fuse block that is in my airplane. Jay Bannister -----Original Message----- From: Sam Hoskins <sam.hoskins(at)gmail.com> Sent: Fri, Jul 17, 2009 1:49 pm Subject: AeroElectric-List: Fuseblock drawings Is there a .dwg file of the fuseblocks, besides the isometric view?? I am looking for a 2-D version that I can use to label for easy I.D. of the fuse size, and the wire that attaches to it. Thanks. Sam Hoskins www.samhoskins.blogspot.com ________________________________________________________________________ Email message sent from CompuServe - visit us today at http://www.cs.com ________________________________________________________________________________
Date: Jul 17, 2009
Great, Jay! Saved me a bunch of time! Sam On Fri, Jul 17, 2009 at 3:12 PM, wrote: > Sam, > > Here is a dwg file and a pdf drawing of the 8-fuse block that is in my > airplane. > > Jay Bannister > > > -----Original Message----- > From: Sam Hoskins <sam.hoskins(at)gmail.com> > To: Aerolectric List > Sent: Fri, Jul 17, 2009 1:49 pm > Subject: AeroElectric-List: Fuseblock drawings > > Is there a .dwg file of the fuseblocks, besides the isometric view? I am > looking for a 2-D version that I can use to label for easy I.D. of the fuse > size, and the wire that attaches to it. > > Thanks. > > Sam Hoskins > www.samhoskins.blogspot.com > > > * > > > * > > ------------------------------ > Email message sent from CompuServe - visit us today at http://www.cs.com > ________________________________________________________________________________
Subject: Re: Exp Bus
Date: Jul 17, 2009
Can I use the Exp Bus as a device (35-60 Amp Fuse) on the Main Power Distribution Bus (Z11). Do I need to put a diode between the two buses and what kind? I have an Exp Bus and would like to find out if I can use it on the Main Bus. Just wondering if this is doable. John Szantho RV9A jszantho(at)gmail.com ________________________________________________________________________________
Date: Jul 17, 2009
Here are the two sizes that I use in AutoCAD ver14 dwg format. If you need them in another format, let me know. Dick Tasker Sam Hoskins wrote: > Is there a .dwg file of the fuseblocks, besides the isometric view? I > am looking for a 2-D version that I can use to label for easy I.D. of > the fuse size, and the wire that attaches to it. > > Thanks. > > Sam Hoskins > www.samhoskins.blogspot.com <http://www.samhoskins.blogspot.com> ________________________________________________________________________________
Date: Jul 17, 2009
Bob: Please reread my post. I said that I have only ONE glass fuse - all others are ATO fuses - with fuse busses. I stated that there is only ONE case whereby the glass fuse is justified - in my opinion. I still believe it - and I have given away my in-line fuse holders and all of the glass fuses. Ernest Kells Ernest; Why an inline "glass" fuse???? The ATO style fuse is a much better choice with its one piece design, high pressure contacts etc. All the same reasons that the automotive world went blade style to replace the "old technology" "glass" fuses. No soldered end caps to come loose, no low pressure contacts to corrode and fail. ATO/ATC is a much more reliable choice. This holder is even waterproof. Good for 30A. http://tinyurl.com/l4eaae Similar holders are available for the Maxi series as well if you require higher ratings. Bob McC ------------------------------------------------------------------------- ----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ernest Kells Sent: Thursday, July 16, 2009 12:04 PM To: aeroelectric-list(at)matronics.com Subject: Re: AeroElectric-List: glass fuses Rich and others: Actually. Rick I ended up deciding there was ONE application for an in-line "glass" fuse. That is the always LIVE when the Master Switch is ON. I put my only in-line glass fuse immediately behind the top of the firewall. It's hard to replace - but the hot wire is only several inches long - with no chance to rub anything. Ernest Kells RV-9A ________________________________________________________________________________
Date: Jul 17, 2009
longg(at)pjm.com wrote: > > Ernest, you are definitely a geek. Why not try an electric engine? > -Weight. -Power availability. -Range. Technology is improving, but it isn't there.....yet. -- http://www.ernest.isa-geek.org ________________________________________________________________________________
Date: Jul 17, 2009
Ernest; I did originally read your post carefully and still wonder why you would retain the "ONE" glass fuse. Why not use an ATO here as well?? That was the point of my post, not that you didn't use ATO for all others, just why retain the single glass one when you are obviously aware of the superiority of the ATO style? Is the justification that it's already there and hard to replace?? Thus the most difficult to access fuse is also the least reliable and most likely to fail?? Not meaning to be critical, just not understanding the logic. Bob McC _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ernest Kells Sent: Friday, July 17, 2009 6:45 PM Subject: Re: AeroElectric-List: glass fuses Bob: Please reread my post. I said that I have only ONE glass fuse - all others are ATO fuses - with fuse busses. I stated that there is only ONE case whereby the glass fuse is justified - in my opinion. I still believe it - and I have given away my in-line fuse holders and all of the glass fuses. Ernest Kells Ernest; Why an inline "glass" fuse???? The ATO style fuse is a much better choice with its one piece design, high pressure contacts etc. All the same reasons that the automotive world went blade style to replace the "old technology" "glass" fuses. No soldered end caps to come loose, no low pressure contacts to corrode and fail. ATO/ATC is a much more reliable choice. This holder is even waterproof. Good for 30A. http://tinyurl.com/l4eaae Similar holders are available for the Maxi series as well if you require higher ratings. Bob McC _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ernest Kells Sent: Thursday, July 16, 2009 12:04 PM Subject: Re: AeroElectric-List: glass fuses Rich and others: Actually. Rick I ended up deciding there was ONE application for an in-line "glass" fuse. That is the always LIVE when the Master Switch is ON. I put my only in-line glass fuse immediately behind the top of the firewall. It's hard to replace - but the hot wire is only several inches long - with no chance to rub anything. Ernest Kells RV-9A ________________________________________________________________________________
Subject: Fat feed confusion
Date: Jul 18, 2009
I note in a June post that Bob Nuckolls said that "fat feed" wires (6 AWG o r larger) do not need a fuse or current limiter. I understand the logic beh ind that. However I note in the Nuckolls Z14 architecture that the wire between the C rossfeed Contactor and the Auxiliary Bus is 10 AWG and has no protection. Why is this an exception to the rule. _________________________________________________________________ Get the latest news=2C goss and sport Make ninemsn your homepage! http://windowslive.ninemsn.com.au/article.aspx?id=813730 ________________________________________________________________________________
Subject: Bluetooth headsets was Situational awareness
Date: Jul 17, 2009
The Navy helicopter world has been toying around with wireless com. For instance long chords used by crew chiefs when standing out front during start up or walking back and forth in the cabin (MH-53E) have proven to be a safety hazard when trying to egress during ditching. The main issues with going wireless in the Navy is making it a secure communication channel and also making sure the crew is not heard by another crew during formation flight or on the flight line. I am sure OBAM needs would not be as great and it would be more doable. -Chris RV-10 #40072 -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Friday, July 17, 2009 3:19 PM Subject: Re: AeroElectric-List: Bluetooth headsets was Situational awareness as an instrument of flight redux At 08:41 AM 7/17/2009, you wrote: > >Bob et al... > >Since we are quickly moving to a wireless world... >I haven't seen wireless aircraft headsets. >This seems like an ideal application for the technology. You got that right. I'm thinking I saw an article on a DIY OBAM aircraft wireless headset project but don't recall where. Getting one 'approved' to go into an airplane might be another matter. But totally wireless would be a real breath of fresh air in the cockpit of most airplanes. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Subject: Bluetooth headsets was Situational awareness as
Date: Jul 17, 2009
In case you are interested I found this on google. -Chris RV-10 http://www.multispectral.com/pdf/MSSI161103b.pdf -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Chris Stone Sent: Friday, July 17, 2009 9:42 AM Subject: Re: AeroElectric-List: Bluetooth headsets was Situational awareness as an instrument of flight redux Bob et al... Since we are quickly moving to a wireless world... I haven't seen wireless aircraft headsets. This seems like an ideal application for the technology. Is anyone making such a device? Chris Stone RV-8 Oregon > I'm trying whole-house wi-fi to avoid > stringing lots of cat-5 cable. After an > arm wrestling match with "Network Magic" > I tossed it out and studied the semi-lame > instructions for the router. Got it to > come up nicely with the MAC address filtering > mode for security so the ground has been > prepared for expanding the network to the > house and shop. >> > Bob . . . > > ________________________________________________________________________________
Date: Jul 17, 2009
I haven't had a chance to read it yet but the issue of "QST" that arrived today had an article about setting up a blue tooth type connection to amateur transceivers. Might be something to look into. Bill Glasair >> >>Since we are quickly moving to a wireless world... >>I haven't seen wireless aircraft headsets. >>This seems like an ideal application for the technology. > > You got that right. I'm thinking I saw an article > on a DIY OBAM aircraft wireless headset project but don't > recall where. Getting one 'approved' to go into an airplane > might be another matter. But totally wireless would be > a real breath of fresh air in the cockpit of most > airplanes. > > > Bob . . . > > --------------------------------------- > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > --------------------------------------- > > -------------------------------------------------------------------------------- Checked by AVG - www.avg.com 18:00:00 ________________________________________________________________________________
From: "William Slaughter" <william_slaughter(at)att.net>
Date: Jul 18, 2009
A 10 AWG wire is smaller than a 6 AWG, not larger. In wire gauge notation a low number is a big wire, a higher number is a smaller wire. William Slaughter From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bob Barrow Sent: Friday, July 17, 2009 10:03 PM Subject: AeroElectric-List: Fat feed confusion I note in a June post that Bob Nuckolls said that "fat feed" wires (6 AWG or larger) do not need a fuse or current limiter. I understand the logic behind that. However I note in the Nuckolls Z14 architecture that the wire between the Crossfeed Contactor and the Auxiliary Bus is 10 AWG and has no protection. Why is this an exception to the rule. _____ Make ninemsn your homepage! Get <http://windowslive.ninemsn.com.au/article.aspx?id=813730> the latest news, goss and sport ________________________________________________________________________________
Date: Jul 18, 2009
Thank you, Dick. I can modify them to suit. Sam On Fri, Jul 17, 2009 at 4:59 PM, Richard Tasker wrote: > Here are the two sizes that I use in AutoCAD ver14 dwg format. > > If you need them in another format, let me know. > > Dick Tasker > > Sam Hoskins wrote: > >> Is there a .dwg file of the fuseblocks, besides the isometric view? I am >> looking for a 2-D version that I can use to label for easy I.D. of the fuse >> size, and the wire that attaches to it. >> >> Thanks. >> >> Sam Hoskins >> www.samhoskins.blogspot.com <http://www.samhoskins.blogspot.com> >> > ________________________________________________________________________________
Date: Jul 18, 2009
Subject: Re: Fat feed confusion
william, since 10 ga is smaller than 6ga that is why the question ''why no protection''. bob noffs On Sat, Jul 18, 2009 at 6:32 AM, William Slaughter < william_slaughter(at)att.net> wrote: > A 10 AWG wire is smaller than a 6 AWG, not larger. In wire gauge > notation a low number is a big wire, a higher number is a smaller wire. > > > William Slaughter > > > *From:* owner-aeroelectric-list-server(at)matronics.com [mailto: > owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of *Bob Barrow > *Sent:* Friday, July 17, 2009 10:03 PM > *To:* aeroelectric-list(at)matronics.com > *Subject:* AeroElectric-List: Fat feed confusion > > > I note in a June post that Bob Nuckolls said that "fat feed" wires (6 AWG > or larger) do not need a fuse or current limiter. I understand the logic > behind that. > > However I note in the Nuckolls Z14 architecture that the wire between the > Crossfeed Contactor and the Auxiliary Bus is 10 AWG and has no protection. > > Why is this an exception to the rule. > ------------------------------ > > Make ninemsn your homepage! Get the latest news, goss and sport<http://windowslive.ninemsn.com.au/article.aspx?id=813730> > > * * > > * * > > ** > > ** > > ** > > ** > > ** > > ** > > *http://www.matronics.com/Navigator?AeroElectric-List* > > ** > > ** > > ** > > *http://forums.matronics.com* > > ** > > ** > > ** > > ** > > *http://www.matronics.com/contribution* > > ** > > * * > > * > > * > > ________________________________________________________________________________
Subject: Fuel Flow - Hoskins FT 101 Fuel Flow not working
Date: Jul 18, 2009
Hoskins FT 101 Fuel Flow not working: 1. Lights stay on - all zeros 2. Unplugging connector in rear gets it working for a while, then it goes to #1 state again. 3. Resetting by doing #2 does not carry forward any fuel used between resets. 4. If reset it every time it goes to state #1, it will accumulate all the fuel used while working. Only missing that used while in state #1. Since it always shows some power applied, I do not think this is an intermittent power problem. Since it accumulates, I do not think this is a problem in the wire going to the battery for residual power to retain accumulated fuel. The transducer has three wires to it, maybe one of them is the problem. Since doing #2 always fixes it, maybe the problem is in or near this plug? Any ideas help?? Wiring diagram is available at http://www.instrumenttech.com/productsupport.shtml Look in the POH for the FT101A. It shows the plug pin diagram. Although I have a 101 the only difference I can tell, is that the type reading - gallons, pounds, etc. - is user resetable vice manufacturer set. Thanks for your ideas. Need to fix it tomorrow - Sunday 7/19/09 Roger -------- Thanks for the help. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=253624#253624 Attachments: http://forums.matronics.com//files/ft_101a_fuelflow_poh_160.pdf ________________________________________________________________________________
Date: Jul 18, 2009
Subject: Fuselinks & breakers
Bob, in several of your Z drawings, you show a fuselink in series with a breaker. For instance, Z-18. You also have a fuselink and a breaker separated only by a relay in Z-18RB. What is the rationale behind this seemingly redundant layout? Thanks Sam Hoskins (Not related to Hoskins fuel systems) ________________________________________________________________________________
Date: Jul 18, 2009
redux Bob, Don't rely on MAC address filtering for security. It is very easy to defeat. Sniffers show the MAC addresses in use and most wireless network interface cards allow you to change the MAC address. Don't use WEP either. Only WPA encryption is (reasonably) secure. Mark Sonex 713 ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Sent: Friday, July 17, 2009 8:49:10 AM GMT -05:00 US/Canada Eastern Subject: Re: AeroElectric-List: Situational awareness as an instrument of flight redux >>> . . . . I further demonstrated >>> that if the horizon is visible over the nose, you cannot >>> be too slow. After that, paying attention to power settings >>> pretty much covers the bases for not having an unhappy day >>> in the pattern. >>That instrument only works for people of the same height. It has >>to be recalibrated for some of us 8*) > > Yeah . . . that's why I was happy the thing averaged > 80 . . . > > Short guys IAS was a little slower, Got that backwards! Must have been too much hauling furniture in the 100+ heat for two days! Obviously, if the individual is shorter then for any given deck angle, his response would be to LOWER the nose to bring it back into alignment with the horizon, i.e. IAS will he HIGHER for the same gross weight, and power setting. Had hard time getting to sleep last night thinking about it and discovering my brain-f#@t . . . Probably need to avoid heavy thinking for a few days. We got Dr. Dee's office spaces 90% moved (probably 1000 pounds of books and another 500 pounds of filing cabinets. I'm trying whole-house wi-fi to avoid stringing lots of cat-5 cable. After an arm wrestling match with "Network Magic" I tossed it out and studied the semi-lame instructions for the router. Got it to come up nicely with the MAC address filtering mode for security so the ground has been prepared for expanding the network to the house and shop. When Dad built this house, I strung hundreds of feet of of twin-lead antenna and twisted-pair phone lines around. Today, none of those wires are in use. A single strand of glass comes to the back of the house to deliver telephone, high speed Internet, and soon to be TV. Both Internet and telephone are hardwired from the fiber modem to network nodes that move all data around the house over spread- spectrum radio. My Dad would be fascinated with all that is changing with the house he built in 4 years of "spare" time 44 years ago. Bob . . . ________________________________________________________________________________
Date: Jul 18, 2009
Subject: Re: Grounding question
Robert L. Nuckolls, III a crit : > > The short answer is, I recommend you stay with the architecture > described in Z-16. > Bob, Thank you for your response. Sorry for answering late, but I've been with no Internet connection for several weeks. Thanks again, Best regards, -- Gilles http://contrails.free.fr ________________________________________________________________________________
Date: Jul 18, 2009
Bob: I understand our differences. I am using Bob's system, using fuse blocks. My system is completely installed using his approach. I use four of his B & C fuse blocks (10 sockets each). It's great. However, the "live" circuit for the Ignition is an exception. It requires "close" circuit protection. I did not want to run the hot circuit to a fuse block near the instrument panel. Any change could be problematic. What if I removed the instrument panel??? I just wanted NUTTIN affecting this hot circuit. I looked at the in-line fuse holder installed very close to the battery as a conservitive situation. I think that it is totally safe. I don't know anything safer (I am electronics challenged). Ernest; I did originally read your post carefully and still wonder why you would retain the "ONE" glass fuse. Why not use an ATO here as well?? That was the point of my post, not that you didn't use ATO for all others, just why retain the single glass one when you are obviously aware of the superiority of the ATO style? Is the justification that it's already there and hard to replace?? Thus the most difficult to access fuse is also the least reliable and most likely to fail?? Not meaning to be critical, just not understanding the logic. Bob McC ------------------------------------------------------------------------- ----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ernest Kells Bob: Please reread my post. I said that I have only ONE glass fuse - all others are ATO fuses - with fuse busses. I stated that there is only ONE case whereby the glass fuse is justified - in my opinion. I still believe it - and I have given away my in-line fuse holders and all of the glass fuses. Ernest Kells Ernest; Why an inline "glass" fuse???? The ATO style fuse is a much better choice with its one piece design, high pressure contacts etc. All the same reasons that the automotive world went blade style to replace the "old technology" "glass" fuses. No soldered end caps to come loose, no low pressure contacts to corrode and fail. ATO/ATC is a much more reliable choice. This holder is even waterproof. Good for 30A. http://tinyurl.com/l4eaae Similar holders are available for the Maxi series as well if you require higher ratings. Bob McC ------------------------------------------------------------------------- --- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ernest Kells Sent: Thursday, July 16, 2009 12:04 PM To: aeroelectric-list(at)matronics.com Subject: Re: AeroElectric-List: glass fuses Rich and others: Actually. Rick I ended up deciding there was ONE application for an in-line "glass" fuse. That is the always LIVE when the Master Switch is ON. I put my only in-line glass fuse immediately behind the top of the firewall. It's hard to replace - but the hot wire is only several inches long - with no chance to rub anything. Ernest Kells RV-9A - The AeroElectric-List Email Forum ---> http://www.matronics.com/Navigator?AeroElectric-List - MATRONICS WEB FORUMS - - List Contribution Web Site - -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Jul 18, 2009
I think you guys are missing each others point. You could have your inline fuse "inline" anywhere you want it and still use an ATO. They make inline ATO holders. http://tinyurl.com/lcvcjq HTH, Tim Andres _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ernest Kells Sent: Saturday, July 18, 2009 6:12 PM Subject: Re: AeroElectric-List: glass fuses Bob: I understand our differences. I am using Bob's system, using fuse blocks. My system is completely installed using his approach. I use four of his B & C fuse blocks (10 sockets each). It's great. However, the "live" circuit for the Ignition is an exception. It requires "close" circuit protection. I did not want to run the hot circuit to a fuse block near the instrument panel. Any change could be problematic. What if I removed the instrument panel??? I just wanted NUTTIN affecting this hot circuit. I looked at the in-line fuse holder installed very close to the battery as a conservitive situation. I think that it is totally safe. I don't know anything safer (I am electronics challenged). Ernest;I did originally read your post carefully and still wonder why you would retain the "ONE" glass fuse. Why not use an ATO here as well?? That was the point of my post, not that you didn't use ATO for all others, just why retain the single glass one when you are obviously aware of the superiority of the ATO style? Is the justification that it's already there and hard to replace?? Thus the most difficult to access fuse is also the least reliable and most likely to fail?? Not meaning to be critical, just not understanding the logic. Bob McC _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ernest Kells Bob: Please reread my post. I said that I have only ONE glass fuse - all others are ATO fuses - with fuse busses. I stated that there is only ONE case whereby the glass fuse is justified - in my opinion. I still believe it - and I have given away my in-line fuse holders and all of the glass fuses. Ernest Kells Ernest; Why an inline "glass" fuse???? The ATO style fuse is a much better choice with its one piece design, high pressure contacts etc. All the same reasons that the automotive world went blade style to replace the "old technology" "glass" fuses. No soldered end caps to come loose, no low pressure contacts to corrode and fail. ATO/ATC is a much more reliable choice. This holder is even waterproof. Good for 30A. http://tinyurl.com/l4eaae Similar holders are available for the Maxi series as well if you require higher ratings. Bob McC _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ernest Kells Sent: Thursday, July 16, 2009 12:04 PM Subject: Re: AeroElectric-List: glass fuses Rich and others: Actually. Rick I ended up deciding there was ONE application for an in-line "glass" fuse. That is the always LIVE when the Master Switch is ON. I put my only in-line glass fuse immediately behind the top of the firewall. It's hard to replace - but the hot wire is only several inches long - with no chance to rub anything. Ernest Kells RV-9A - The AeroElectric-List Email Forum - <>--> http://www.matronics.com/Navigator?AeroElectric-List - MATRONICS WEB FORUMS - - List Contribution Web Site - -Matt Dralle, List Admin. href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matro nics.com/Navigator?AeroElectric-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c 270.13.19/2245 - Release Date: 07/18/09 05:57:00 ________________________________________________________________________________
Date: Jul 18, 2009
Subject:
X-mailer: Pegasus Mail for Windows (4.41) X-SpamReason %%SpamReason%%: http://www.michigan.gov/aero/0,1607,7-145-14493-29639--,00.html Jim Baker 580.788.2779 405. 426.5377 cell Elmore City, OK ________________________________________________________________________________
Subject: Re: Icom A-210 intercom
Date: Jul 18, 2009
Just installed the icom 210a as per the diagram Bob posted earlier.It receives just fine but the mics are dead.Using 2 x Ray Allen grips [601xl Y grips] with the PTT switches and 2 place phone and mic wired in parallel.Should pin 10 be grounded via a switch for the intercom to work as well???? Thank you Read this topic online here: http://forums.matronics.com/viewtopic.php?p=253689#253689 ________________________________________________________________________________
Date: Jul 19, 2009
Subject: Re: Fuselinks & breakers
At 12:15 PM 7/18/2009, you wrote: >Bob, in several of your Z drawings, you show a fuselink in series >with a breaker. For instance, Z-18. You also have a fuselink and a >breaker separated only by a relay in Z-18RB. > >What is the rationale behind this seemingly redundant layout? Fusible links are not to be confused or even placed in the same class as breakers and the run-o-the-mill plastic fuses. Not all that is offered as a "circuit protective device" has the same design goals. Fuses are VERY FAST acting devices compared to thermal breakers. Fusible links and the ANN/ANL "current limiters" are VERY SLOW compared to the breakers and slower still compared to fuses. In the cases you cited, the protective device upstream of a crowbar ov protection system needs to be pilot re-setable . . . but when combined with remotely mounted fuse blocks, a "extension" of the main bus bar up to the field breaker, the legacy design goals call for some form of protection for the extended bus that drives the one and only breaker. However, it must be MUCH more robust protection than the breaker itself. I.e., feeders protected with ANL limiters or fusible links. Fusible links and current limiters are SPECIAL, robust forms of circuit protection which are NOT interchangeable with fuses and breakers on distribution feeders. They are recommended for use only in situations described in the Z-figures. I had a builder some years ago share his wiring diagram with me concerning some other issues wherein he had scattered a number of fusible links around the system. Your car has one, maybe two fusible links. All other circuit protection is breakers, fuses or polyfuses specifically tailored to the protection task. Before you do anything with links or limiters, let's talk about it here on the list before you do it. Further, the short answer to your question is that the buss extension up to the breakers cited is classically protected by some extra-robust device at the feeder end. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jul 19, 2009
Subject: D.A.R question about fuse access
> >The nice thing about having internal batteries within the EFIS is that >nothing changes while you scurry to either change the fuse or land and >repair - even for the AP. If I couldn't isolate the problem by replacing >the fuse - I'd just land. Kind-o-like the ole' circuit breaker theory - >if it blows once you reset it. If it blows twice, you leave it. But what is the likelihood that replacing a properly sized, popped fuse will restore any system to functionality? If it's anticipated that the wing leveler's services will ever be critical to comfortable termination of flight, then is not as essential as radio navigation or cockpit lighting? Perhaps dual wing levelers are in order? I'd bet that a BIG chunk of the accidents due to poor pilot visibility and/or workload distractions for single-pilot IFR would have been averted electrons had the stick. I'll suggest that most IFR capable airframes would be better outfitted for ventures into poor visibility if there were NO displays on the panel and dual, heading-slaved wing levelers installed. The wing levelers are probably lighter and more reliable than a suite of panel mounted gyros and more capable than pilot's trying to manage an airplane interleaved with other distractions/ duties in the cockpit . . . including the distraction of fiddling with fuses -OR- breakers. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jul 19, 2009
Subject: Re: D.A.R question about fuse access
Good Evening Bob, I agree with your evaluation, but back when Mooney tried it, most pilots didn't care for it. You would regularly find the interrupt button taped down thus deactivating the system. I feel certain that some method could be made to work and still be acceptable to the average pilot, but no one has, as yet, figured out that method. Had JFK jr just let his autopilot fly his airplane, we would probably have a light plane pilot high in our government hierarchy by now. 'Tis a quandary indeed! Happy Skies, Old Bob AKA Bob Siegfried LL22 Stearman N3977A In a message dated 7/19/2009 12:53:57 P.M. Central Daylight Time, nuckolls.bob(at)aeroelectric.com writes: Perhaps dual wing levelers are in order? I'd bet that a BIG chunk of the accidents due to poor pilot visibility and/or workload distractions for single-pilot IFR would have been averted electrons had the stick. I'll suggest that most IFR capable airframes would be better outfitted for ventures into poor visibility if there were NO displays on the panel and dual, heading-slaved wing levelers installed. The wing levelers are probably lighter and more reliable than a suite of panel mounted gyros and more capable than pilot's trying to manage an airplane interleaved with other distractions/ duties in the cockpit . . . including the distraction of fiddling with fuses -OR- breakers. **************Can love help you live longer? Find out now. (http://personals.aol.c om/articles/2009/02/18/longer-lives-through-relationships/?ncid=emlweuslove00000001) ________________________________________________________________________________
Date: Jul 19, 2009
Subject: p and retard leads
From: Jeff Peterson <jeffreyb.peterson(at)gmail.com>
I have an engine with bendix shower of sparks magnetos. The mags have number S4LN-200 and S4LN-204. I need 2 ea. p-leads and 1 ea. retard lead to hook this up. I dont know whether I need the hex nut or round nut connector, nor where I can get same. -- Jeff Peterson ________________________________________________________________________________
Date: Jul 19, 2009
Subject:
At 06:06 PM 7/19/2009, you wrote: >Good Evening Bob, > >I agree with your evaluation, but back when Mooney tried it, most >pilots didn't care for it. You would regularly find the interrupt >button taped down thus deactivating the system. I feel certain that >some method could be made to work and still be acceptable to the >average pilot, but no one has, as yet, figured out that method. Yeah . . . PC (positive control) by Brittain as I recall. A totally pneumatic wing leveler that operated directly though valves at the back of the turn-coordinator driving "tomato juice can" servos. A truly elegant design for its time. Just found that the system is still offered at: http://www.brittainautopilots.com/ I liked it. You couldn't hurt it by direct over-ride while engaged. No servos to smoke, no clutches to burn, no engagement solenoids to burn out. This was TSO-C3a hardware which tells us how far back that goes. I did a little white paper for Cessna way back when that suggested large diaphragm pneumatic force cartridges operated by pitot/static delta-P and permanently rigged to ailerons. A simple reed valve system driven from a turn-coordinator would drive a simple set of electronics that consumed less than 1 watt of total power. Three moving parts, no lubrication issues, etc. etc. But they were the proud owners of ARC who was already offering a line of autopilots that plagued with every failure mode that such devices might offer . . . > >Had JFK jr just let his autopilot fly his airplane, we would >probably have a light plane pilot high in our government hierarchy by now. Hmmm . . . you can lead a horse to water. . . All we can do as teachers/designers/suppliers is offer well considered advice backed by a history of recipes for success. Dr. Dee speaks of a human condition known as "cognitive dissonance" http://en.wikipedia.org/wiki/Cognitive_dissonance which we've all observed first hand: "I KNOW that smoking is bad for me . . . but I (like/need/want) to do it". We've all observed a pilot's worst ever day in the cockpit that appeared to rise from a dead-short-between-the-headphones. It's called the "bell curve". For the very best among us, there MUST be individuals who balance out the other end of the curve. > >'Tis a quandary indeed! Let us continue to strive for position on the upper slope of that curve . . . Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jul 19, 2009
Subject: Re: p and retard leads
I have those mags on my Mooney. The P-leads take one size round connector, the retard lead is a different size, so you can't mix them up. Jeff Peterson wrote: > I have an engine with bendix shower of sparks magnetos. > The mags have number S4LN-200 and S4LN-204. > > I need 2 ea. p-leads and 1 ea. retard lead to hook this up. > > > I dont know whether I need the hex nut or round nut connector, > nor where I can get same. > > -- > Jeff Peterson > > * > > > * ________________________________________________________________________________
From: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net>
Subject: Air conditioning stuff for sale
Date: Jul 20, 2009
Don't know if any of you are contemplating an air conditioning system in your airplane or have an old R-12 system in your airplane (or car) that needs fixing but I may have what you need. Since I no longer own a vehicle that uses R-12 refrigerant I have seven 12 ounce cans available for sale at $35 dollars apiece (a repair shop now charges upwards of $100 a pound for R-12, if they can locate some). I also have an R-12 manifold gauge set (used to monitor the high and low pressures in an R-12 system while filling) and a tap for the R-12 cans ($35.00 for both of these). Let me know if you need any of these or, buy the whole ball of wax for $250.00. Dean Psiropoulos RV-6A N197DM Prop removed for radiographic inspection. ________________________________________________________________________________
Subject: The weak link
Date: Jul 20, 2009
Bob Nuckolls said, "Perhaps dual wing levelers are in order? I'd bet that a BIG chunk of the accidents due to poor pilot visibility and/or workload distractions for single-pilot IFR would have been averted (if) electrons had the stick. I'll suggest that most IFR capable airframes would be better outfitted for ventures into poor visibility if there were NO displays on the panel and dual, heading-slaved wing levelers installed. The wing levelers are probably lighter and more reliable than a suite of panel mounted gyros and more capable than pilot's trying to manage an airplane . . . .." I agree wholeheartedly. Flying IFR, if we can trust our lives to electronics to take information from sensors and display that information, then why can't we trust electronics to actually operate the controls? The human being is the weak link in the system. Have you ever noticed the control movements when the autopilot is on, compared to when a human is in control? Some planes have dual EFISs. I suggest that it would be better to have dual autopilots with dual servos. The recreational IFR pilot is better off monitoring the system as a whole, watching for component failure, making sure that the altitude and heading are correct, handling radio communications, looking for traffic, and etc. Joe Gores ________________________________________________________________________________
Date: Jul 20, 2009
Subject: Re:
Good Morning 'Lectric Bob, Interesting thoughts from Doctor Dee. It brings me to question if my strong advocacy of the T&B over the TC might be some evidence of my personal conditioning. It also leads me to think that maybe I am right in my feelings and that the quandary we find ourselves in when we get confused about which way is up is caused by that lack of consistency in our perceptions Sooo .... I have already added another thing for me to worry about! Not sure where you were working at the time or how close you were to automatic flight, but I bet you know about how Beech competed with Mooney's PC. Beech installed a Century I (The folks who made it were called Edo Aire Mitchell at the time) Wing Leveler and my memory is that they called it the Constant Copilot. The main difference was that Beech provided an ON/OFF switch so the pilot could choose to use it or not. My recollection is that Piper offered a similar unit, but I do not recall who made it for them or what they called it. Back to the Constant Copilot. If the switch was left on, the wing leveler worked full time just like the Mooney PC. It could be easily over ridden without causing any damage to the unit and it was made inoperative by pressing an interrupter switch on the control wheel. Take your thumb off the switch button and the leveler took over. We always told our customers to use it regularly. Almost nobody did! Just a bit more musing if you don't mind. Back when autopilots were first being introduced in air carrier use, one of the first things we were taught to do when any flight attitude problem was encountered was to turn OFF the autopilot. The thought was that any deviation from normal was most likely caused by an autopilot failure. When we flew into turbulence, we were also told to turn off the autopilot. That attitude certainly did not encourage us to rely on the autopilot when things started to get dicey. Maybe we need to train pilots to use and trust the autopilot from the very first time they ever get in the airplane? That is almost how the Airbus pilots are trained today! For fully automatic landings, we initially used three autopilots and a comparator circuit that told us to execute a miss if any one of those three autopilots felt that things are not going well. Seems as if there is something worthwhile in that fully automatic flight regime, but the issues are not easily solved. Happy Skies, Old Bob PS My current transportation steed is a 1978 V35B and I still keep the Century I Constant Copilot in good working order. The early ones shared a roll servo with the regular autopilot and that was how mine was set up when I bought it. A few years ago I changed the primary autopilot. The new one has it's own roll servo so my airplane now has two roll autopilots available. If I hit the interrupter button, both are turned off. When I let go of the button, the Century One will come back on line but the primary one stays off. The only problem is that I can't use both at the same time because they will fight with each other! Not sophisticated enough to use the same inputs and do the comparison bit. In a message dated 7/19/2009 10:39:26 P.M. Central Daylight Time, nuckolls.bob(at)aeroelectric.com writes: At 06:06 PM 7/19/2009, you wrote: Good Evening Bob, I agree with your evaluation, but back when Mooney tried it, most pilots didn't care for it. You would regularly find the interrupt button taped down thus deactivating the system. I feel certain that some method could be made to work and still be acceptable to the average pilot, but no one has, as yet, figured out that method. Yeah . . . PC (positive control) by Brittain as I recall. A totally pneumatic wing leveler that operated directly though valves at the back of the turn-coordinator driving "tomato juice can" servos. A truly elegant design for its time. Just found that the system is still offered at: _http://www.brittainautopilots.com/ _ (http://www.brittainautopilots.com/) I liked it. You couldn't hurt it by direct over-ride while engaged. No servos to smoke, no clutches to burn, no engagement solenoids to burn out. This was TSO-C3a hardware which tells us how far back that goes. I did a little white paper for Cessna way back when that suggested large diaphragm pneumatic force cartridges operated by pitot/static delta-P and permanently rigged to ailerons. A simple reed valve system driven from a turn-coordinator would drive a simple set of electronics that consumed less than 1 watt of total power. Three moving parts, no lubrication issues, etc. etc. But they were the proud owners of ARC who was already offering a line of autopilots that plagued with every failure mode that such devices might offer . . . Had JFK jr just let his autopilot fly his airplane, we would probably have a light plane pilot high in our government hierarchy by now. Hmmm . . . you can lead a horse to water. . . All we can do as teachers/designers/suppliers is offer well considered advice backed by a history of recipes for success. Dr. Dee speaks of a human condition known as "cognitive dissonance" _http://en.wikipedia.org/wiki/Cognitive_dissonance_ (http://en.wikipedia.org/wiki/Cognitive_dissonance) which we've all observed first hand: "I KNOW that smoking is bad for me . . . but I (like/need/want) to do it". We've all observed a pilot's worst ever day in the cockpit that appeared to rise from a dead-short-between-the-headphones. It's called the "bell curve". For the very best among us, there MUST be individuals who balance out the other end of the curve. 'Tis a quandary indeed! Let us continue to strive for position on the upper slope of that curve . . . Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- (http://www.matronics.com/Navigator?AeroElectric-List) (http://www.matronics.com/contribution) **************What's for dinner tonight? Find quick and easy dinner ideas for any occasion. (http://food.aol.com/dinner-tonight?ncid=emlcntusfood00000009) ________________________________________________________________________________
From: "nuckollsr" <bob.nuckolls(at)aeroelectric.com>
Date: Jul 20, 2009
Sharp eye! I think that's a typo. To qualify as a "fat feeder" with inherent resistance to ground-fault-burning of wire/insulation, the current carrying ability of the wire compared with highest hypothesized fault needs to be pretty high. While the 10AWG buss feeder is adequate to the task of servicing electro-whizzies that load the 20A alternator, it's also small enough to be at risk for burning the length of the wire along with the attendant risk of smoke in the cockpit, etc. We have two choices here to slide this feeder under the umbrella of legacy design goals: (a) add a fusible link to the feed-end of this wire (6" of 14 AWG would be fine) or (b) increase the 10AWG feeder to at least a 6AWG. Since we're already wired with lots of 4AWG, that would be good too. Actually, there's a third option. We bought the Delrin stock from which we can fabricate mounting blocks for the minature robust, ANL style fuses. See http://aeroelectric.com/Pictures/Fuses/Fuses/ABI_fuses.jpg http://aeroelectric.com/Pictures/Fuses/Fuses/megafuse250.gif http://www.knukonceptz.com/productMaster.cfm?category=Mini-ANL%20Fuse# We're going to stock one of these fuse topologies and offer a mounting block to to with it. But these can be fabricated locally from the right nuts, washers, screws, and block of Delrin or cloth filled phenolic. While on the subject of fuses, check out this little treatis I found on the 'net. Nicely done . . . http://www.bcae1.com/fuses.htm Note the author's caveat concerning the quality levels of glass cartridge fuses. Bob . . . Read this topic online here: http://forums.matronics.com/viewtopic.php?p=253876#253876 ________________________________________________________________________________
Date: Jul 20, 2009
When we put a high amp alternator in the truck we used a fuse with holder to protect against alt internal failure. Same kind should work fine for the batt feeder as recommended by Littelfuse? http://www.littelfuse.com/part/0298175.html No need to fabricate a holder. Pretty common in my truck world. Use it in-line or bolt it to the structure. Very low tech and functional. PW ========= At 08:05 AM 7/20/2009, you wrote: > > >Sharp eye! I think that's a typo. To qualify as a "fat feeder" with >inherent resistance to ground-fault-burning of wire/insulation, the >current carrying ability of the wire compared with highest >hypothesized fault needs to be pretty high. While the 10AWG buss >feeder is adequate to the task of servicing electro-whizzies that >load the 20A alternator, it's also small enough to be at risk for >burning the length of the wire along with the attendant risk of >smoke in the cockpit, etc. > >We have two choices here to slide this feeder under the umbrella of >legacy design goals: (a) add a fusible link to the feed-end of this >wire (6" of 14 AWG would be fine) or (b) increase the 10AWG feeder >to at least a 6AWG. Since we're already wired with lots of 4AWG, >that would be good too. > >Actually, there's a third option. We bought the Delrin stock from >which we can fabricate mounting blocks for the minature robust, ANL >style fuses. See > >http://aeroelectric.com/Pictures/Fuses/Fuses/ABI_fuses.jpg > >http://aeroelectric.com/Pictures/Fuses/Fuses/megafuse250.gif > >http://www.knukonceptz.com/productMaster.cfm?category=Mini-ANL%20Fuse# > >We're going to stock one of these fuse topologies and offer a >mounting block to to with it. But these can be fabricated locally >from the right nuts, washers, screws, and block of Delrin or cloth >filled phenolic. > >While on the subject of fuses, check out this little treatis I found >on the 'net. Nicely done . . . > >http://www.bcae1.com/fuses.htm > >Note the author's caveat concerning the quality levels of glass >cartridge fuses. > >Bob . . . > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=253876#253876 > > ________________________________________________________________________________
Date: Jul 20, 2009
Subject: Autopilots vs. "The Right Stuff"
At 09:04 AM 7/20/2009, you wrote: Good Morning 'Lectric Bob, Interesting thoughts from Doctor Dee. It brings me to question if my strong advocacy of the T&B over the TC might be some evidence of my personal conditioning. It also leads me to think that maybe I am right in my feelings and that the quandary we find ourselves in when we get confused about which way is up is caused by that lack of consistency in our perceptions Sooo .... I have already added another thing for me to worry about! The debate for visual display of yaw rate and apparent center of the earth (gravity) as a flight instrument is only slightly related to the task of providing a practical automatic flight control system. For a simple yaw damper to work, it needs only numerical knowledge of turning rate about the yaw axis. However, given that the process of turning the airplane to a new heading BEGINS with a change in roll followed by a change in yaw rate. Doing the job smoothly with a single rate sensor required some knowledge of both roll (to anticipate a heading change) and yaw (to quantify the rate of change after the turn was established). While the T&B may well be best suited to recovering from an upset condition, the TC is best suited for avoiding that upset in the first place. I.e, Brittain could not have achieved the design goal without a carefully considered "pollution" of TB data. Not sure where you were working at the time or how close you were to automatic flight, but I bet you know about how Beech competed with Mooney's PC. Only vaguely. I'll have to ask some of the grey-beards if they recall the system. I guess I could get on the computer and check service parts catalogs. I think Beech listed their A/P hardware in those books. Beech installed a Century I (The folks who made it were called Edo Aire Mitchell at the time) Wing Leveler and my memory is that they called it the Constant Copilot. The main difference was that Beech provided an ON/OFF switch so the pilot could choose to use it or not. My recollection is that Piper offered a similar unit, but I do not recall who made it for them or what they called it. I believe Piper had the Brittian system too but featured a valve in the vacuum supply line to shut if off if wanted. I think that valve was added to the Mooneys later. Back to the Constant Copilot. If the switch was left on, the wing leveler worked full time just like the Mooney PC. It could be easily over ridden without causing any damage to the unit and it was made inoperative by pressing an interrupter switch on the control wheel. Take your thumb off the switch button and the leveler took over. We always told our customers to use it regularly. Almost nobody did! Yeah, the "Right Stuff" syndrome. I guess it depends on what you use the airplane for and how you assess risk for the situations in which you fly. I enjoy flying. I enjoyed honing my under-the-hood skills. But when it was necessary to competently and smoothly manage a transition though IMC, I've never been adverse to calling up what ever support was available to reduce both sweat and risk. I've run the traps with some fellow techo-wiennies here in Wichita for a roll servo that contains a dedicated GPS receiver, canted roll/yaw rate sensor and a micro-controller that will "hold that GPS track" to plus/minus 1 degree. Controls would be limited to an on/off switch and bi-directional track increment buttons. Click one for each degree of track change. Hold button for standard rate turn. The servo would have a serial port that accepts commands for "new track to make good". The same line outputs system status. As a single installation, you install a servo, hook up an antenna, hook up 14v and you're done. As a dual installation, there would be a "arbitrator box" that compares data to and from the pair of wing levelers with data from a panel mounted GPS and raises a warning flag if one of the systems mis-behaves. Each system is powered from a separate source. It's my belief that such a system would allow a pilot to comfortably enter a controlled airspace environment and comply with all ATC instructions with great precision, low risk and very low sweat factor . . . and never have to touch the stick. E.g. cluttering the panel with attitude displays would add nothing to the design goal. Bill of materials for the full-up system is under $200. All I need is a 36 hour day and a relaxation of other duties! Bob. . . ________________________________________________________________________________
Date: Jul 20, 2009
At 10:36 AM 7/20/2009, you wrote: > >When we put a high amp alternator in the truck we used a fuse with >holder to protect against alt internal failure. Same kind should >work fine for the batt feeder as recommended by Littelfuse? >http://www.littelfuse.com/part/0298175.html No need to fabricate a >holder. Pretty common in my truck world. >Use it in-line or bolt it to the structure. Very low tech and functional. Yup, that's a righteous product. It's a miniaturize version of the 70 year old ANN/ANL series devices. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jul 20, 2009
Subject: Re: Autopilots vs. "The Right Stuff"
Good Afternoon 'Lectric Bob, I totally agree with you that the canted gyro works better for a wing leveler than does a T&B, but I do NOT feel it works well with we human pilots. Too much conflict with our semi circular canal sensors. But I have expanded on that thought here many times in the past. I would love to see something new and modern that would replace the T&B and the TC. Your thought on using a sequential GPS position seems to me to have considerable merit. Happy Skies, Old Bob LL22 Piper Pacer N2858P In a message dated 7/20/2009 2:37:45 P.M. Central Daylight Time, nuckolls.bob(at)aeroelectric.com writes: Bill of materials for the full-up system is under $200. All I need is a 36 hour day and a relaxation of other duties! Bob. . . **************What's for dinner tonight? Find quick and easy dinner ideas for any occasion. (http://food.aol.com/dinner-tonight?ncid=emlcntusfood00000009) ________________________________________________________________________________
Date: Jul 20, 2009
Modern autopilots are remarkably better performers than their elder parents.. The P3 Orion had an autopilot which had a component with a limited operating life.. Crews would often hand fly en route to and from their station in order to improve the odds that the autopilot would work during a critical period. My only personal experience with autopilots is in late 70's Archers which I think had a rebadged Century III. They do the job (track a nav source), but sloppily. They tend to wander heading a fair amount and if the rudder trim isn't spot-on they can see-saw back and forth. In a flight regime with low indicated airspeed (climb or high altitude cruise) the increased adverse yaw makes the ride somewhat unpleasant and is kind of distracting. Especially in an airplane with fairly strong roll-yaw coupling. If that were the state of the art for autopilots, I'd be much less excited about having one. My impression is that the modern autopilots are much, much better. Although, I did get a ride in the right seat of a PC12.. At cruise (in the low FL's) in smooth air the airplane tended to slowly vary altitude +/-100ft from the programmed value. Seemed a bit odd in a brand new (30TTSN) multi-million dollar machine. Probably just needed a bit of tuning. Finally, pilots need to train like they fly, and fly like they train. Pilots need to let George fly enough so that they have confidence in "his" abilities. Regards, Matt- > > > At 09:04 AM 7/20/2009, you wrote: > Good Morning 'Lectric Bob, > > Interesting thoughts from Doctor Dee. > > It brings me to question if my strong advocacy of the T&B over the TC > might be some evidence of my personal conditioning. > > It also leads me to think that maybe I am right in my feelings and > that the quandary we find ourselves in when we get confused about > which way is up is caused by that lack of consistency in our perceptions > > Sooo .... I have already added another thing for me to worry about! > > The debate for visual display of yaw rate and > apparent center of the earth (gravity) as > a flight instrument is only slightly related to snip ________________________________________________________________________________
Date: Jul 20, 2009
We have something better than T&B or TC. It's call glass panels with pictorial displays that the mind doesn't have to do much to interpret Strong visual information . James Robinson Glasair lll N79R Spanish Fork UT U77 ________________________________ From: "BobsV35B(at)aol.com" <BobsV35B(at)aol.com> Sent: Monday, July 20, 2009 2:17:26 PM Subject: Re: AeroElectric-List: Autopilots vs. "The Right Stuff" Good Afternoon 'Lectric Bob, I totally agree with you that the canted gyro works better for a wing leveler than does a T&B, but I do NOT feel it works well with we human pilots. Too much conflict with our semi circular canal sensors. But I have expanded on that thought here many times in the past. I would love to see something new and modern that would replace the T&B and the TC. Your thought on using a sequential GPS position seems to me to have considerable merit. Happy Skies, Old Bob LL22 Piper Pacer N2858P In a message dated 7/20/2009 2:37:45 P.M. Central Daylight Time, nuckolls.bob(at)aeroelectric.com writes: Bill of materials for the full-up system is under > $200. All I need is a 36 hour day and a relaxation > of other duties! > > Bob. . . > > ________________________________ What's for dinner tonight? Find quick and easy dinner ideas for any occasion. ________________________________________________________________________________
Date: Jul 20, 2009
Good Evening James, I sure hope something works out along that line, but suitable reliability and usability has not yet been demonstrated. Glass is also way out of my price range at the present time. The TC and T&B have been fairly economical in the past, though the prices have skyrocketed in the last couple of years. Do you figure on two glass units to provide back up or are you willing to go with a single source of information? I kinda like Jim Younkin's instrument for experimental aircraft. We who fly certified antiques are not allowed to use Jim's stuff. Happy Skies, Old Bob In a message dated 7/20/2009 4:26:37 P.M. Central Daylight Time, jbr79r(at)yahoo.com writes: We have something better than T&B or TC. It's call glass panels with pictorial displays that the mind doesn't have to do much to interpret Strong visual information . James Robinson Glasair lll N79R Spanish Fork UT U77 **************An Excellent Credit Score is 750. See Yours in Just 2 Easy Steps! yExcfooterNO62) ________________________________________________________________________________
Date: Jul 20, 2009
Hi Jim, It's been proven time and time again that you're better off using a backup system that uses a different method of operation when your panel goes dark. Bruce www.Glasair.org -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of James Robinson Sent: Monday, July 20, 2009 5:05 PM Subject: Re: AeroElectric-List: Autopilots vs. "The Right Stuff" We have something better than T&B or TC. It's call glass panels with pictorial displays that the mind doesn't have to do much to interpret Strong visual information . James Robinson Glasair lll N79R Spanish Fork UT U77 _____ From: "BobsV35B(at)aol.com" <BobsV35B(at)aol.com> Sent: Monday, July 20, 2009 2:17:26 PM Subject: Re: AeroElectric-List: Autopilots vs. "The Right Stuff" Good Afternoon 'Lectric Bob, I totally agree with you that the canted gyro works better for a wing leveler than does a T&B, but I do NOT feel it works well with we human pilots. Too much conflict with our semi circular canal sensors. But I have expanded on that thought here many times in the past. I would love to see something new and modern that would replace the T&B and the TC. Your thought on using a sequential GPS position seems to me to have considerable merit. Happy Skies, Old Bob LL22 Piper Pacer N2858P In a message dated 7/20/2009 2:37:45 P.M. Central Daylight Time, nuckolls.bob(at)aeroelectric.com writes: Bill of materials for the full-up system is under $200. All I need is a 36 hour day and a relaxation of other duties! Bob. . . _____ What's for dinner tonight? Find quick and easy dinner ideas <http://food.aol.com/dinner-tonight?ncid=emlcntusfood00000009> for any occasion. ________________________________________________________________________________
Date: Jul 20, 2009
From: Dennis Golden <dgolden@golden-consulting.com>
Subject: Re: glass fuses
Tim Andres wrote: > I think you guys are missing each others point. You could have your > inline fuse inline anywhere you want it and still use an ATO. They > make inline ATO holders. *http://tinyurl.com/lcvcjq* I'd like to add that I have had (on my 1976 GMC Motorhome) 2 circuits that were added during the 90's or early 20's fail. Both using inline glass fuse holders (one under the dash and another behind the remote generator control panel). In both cases, the fuse holder actually failed dropping the fuses out of the holder. Just another data point and maybe the fuse holders were inferior quality to what you plan to use, but I wouldn't do it. Dennis -- Dennis Golden Golden Consulting Services, Inc. ________________________________________________________________________________
Date: Jul 20, 2009
I have the trutrak auto pilot and it has been very dependable. Also the support has be very good. I fly with 2 screen Cheltons with some round gauges as backup and a AOA. I am all electric with a 2 alternator setup. It definitely ups the ante however James Robinson Glasair lll N79R Spanish Fork UT U77 ________________________________ From: "BobsV35B(at)aol.com" <BobsV35B(at)aol.com> Sent: Monday, July 20, 2009 5:15:07 PM Subject: Re: AeroElectric-List: Autopilots vs. "The Right Stuff" Good Evening James, I sure hope something works out along that line, but suitable reliability and usability has not yet been demonstrated. Glass is also way out of my price range at the present time. The TC and T&B have been fairly economical in the past, though the prices have skyrocketed in the last couple of years. Do you figure on two glass units to provide back up or are you willing to go with a single source of information? I kinda like Jim Younkin's instrument for experimental aircraft. We who fly certified antiques are not allowed to use Jim's stuff. Happy Skies, Old Bob In a message dated 7/20/2009 4:26:37 P.M. Central Daylight Time, jbr79r(at)yahoo.com writes: We have something better than T&B or TC. It's call glass panels with pictorial displays that the mind doesn't have to do much to interpret Strong visual information . > > James Robinson >Glasair lll N79R >Spanish Fork UT U77 ________________________________ An Excellent21323041x1201367261/aol?redir=http://www.freecreditreport.com/pm/default.aspx?sc=668072%26hmpgID=62%26bcd=JulyExcfooterNO62>See Yours in Just 2 Easy Steps! ________________________________________________________________________________
Date: Jul 20, 2009
I have backup round gauges and auto pilot and AOA to help me out=0A=0A Jame s Robinson=0AGlasair lll N79R=0ASpanish Fork UT U77=0A=0A=0A=0A=0A_______ _________________________=0AFrom: Bruce Gray <Bruce(at)Glasair.org>=0ATo: aero electric-list(at)matronics.com=0ASent: Monday, July 20, 2009 5:32:14 PM=0ASubj ect: RE: AeroElectric-List: Autopilots vs. "The Right Stuff"=0A=0A =0AHi Ji m,=0A =0AIt=99s=0Abeen proven time and time again that you=99re better off using a backup=0Asystem that uses a different method of operati on when your panel goes dark.=0A =0ABruce=0Awww.Glasair.org =0A-----Origina l Message-----=0AFrom: owner-aeroelectric-list-server(at)matronics.com=0A[mail to:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of James Robinso n=0ASent: Monday, July 20, 2009 5:05=0APM=0ATo: aeroelectric-list@matronics .com=0ASubject: Re: AeroElectric-List:=0AAutopilots vs. "The Right Stuff" =0A =0AWe have something better than T&B or TC. =0AIt's call glass panels w ith pictorial displays that the mind doesn't have to do=0Amuch to interpret Strong visual information .=0A =0AJames Robinson=0AGlasair lll N79R=0ASpa nish Fork UT U77=0A =0A =0A=0A________________________________=0A =0AFrom:" BobsV35B(at)aol.com" =0ATo: aeroelectric-list(at)matronics.com =0ASent: Monday, July 20, 2009=0A2:17:26 PM=0ASubject: Re: AeroElectric-Lis t:=0AAutopilots vs. "The Right Stuff"=0A=0A=0A=0AGood=0AAfternoon 'Lectric Bob,=0A =0AI=0Atotally agree with you that the canted gyro works better for a wing leveler=0Athan does a T&B, but I do NOT feel it works well with we human pilots. Too=0Amuch conflict with our semi circular canal sensors. But I have expanded on that=0Athought here many times in the past.=0A =0AI wou ld=0A love to see something new and modern that would replace the T&B and =0Athe TC. Your thought on using a sequential GPS position seems to me to h ave=0Aconsiderable merit.=0A =0AHappy=0ASkies,=0A =0AOld Bob=0ALL22=0APiper =0APacer N2858P=0A =0AIn a=0Amessage dated 7/20/2009 2:37:45 P.M. Central Daylight Time,=0Anuckolls.bob(at)aeroelectric.com writes:=0ABill of materials for=0A>the full-up system is under=0A>> $200. All I need is a 36 hour d ay and a relaxation=0A>> of other duties!=0A>=0A>> Bob. . .=0A=0A=0A =0A=0A________________________________=0A =0AWhat's=0Afor dinner tonight? F ind quick and easy dinner ideas for any occasion.=0A =0A =0A - T he AeroElectric-List Email Forum -=0A --> http://www.matronics.com/Naviga tor?AeroElectric-List=0A - MATRONICS WEB FORUMS -=0A --> ht tp://forums.matronics.com=0A - List Contribution Web Site -=0A Thank you for your generous support!=0A -Matt Dralle, List Admin.=0A --> http://www.matronics.com/contribution=0A =0A ==================== ________________________________________________________________________________
Date: Jul 20, 2009
At 03:17 PM 7/20/2009, you wrote: >Good Afternoon 'Lectric Bob, > >I totally agree with you that the canted gyro works better for a >wing leveler than does a T&B, but I do NOT feel it works well with >we human pilots. Too much conflict with our semi circular canal >sensors. But I have expanded on that thought here many times in the past. > >I would love to see something new and modern that would replace the >T&B and the TC. Your thought on using a sequential GPS position >seems to me to have considerable merit. Stabilization and control of the airframe is still based on interpretation of rotational rate values. The sensors are now all solid state as opposed to spinning up a rotor on bearings. The rate sensors have become so commonplace that simple versions are offered to augment pilot controls for flying model r/c helicopters . . . and they're just a few dollars. http://tinyurl.com/lcuqkc Two more technologies have come forward to make the job easier and better. GPS and microprocessors. Our first autopilot for the MQM-107 http://www.designation-systems.net/dusrm/m-107.html was totally analog. 741 op amps and fists full of transistors. The next autopilot was a TI 9900 processor. All of a sudden, our calculating ability combined with differentiation (anticipation) made this bird fly even better yet. We never got to put GPS on this bird but it went into other products. http://tinyurl.com/lhwmnp The availability of ground track nav data opened the horizons for auto flight AND auto navigation. The thing that would be pretty cool with the products I described is access to the serial data ports. The stand-alone device would nicely steer an airplane. But anyone handy with byte thrashing could craft an auto-navigation application in the portable number cruncher of their choice. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jul 20, 2009
I recall hearing that the solid state sensors (gyros) had a problem with drift. Is this still an issue? Raymond Julian Kettle River, MN "Hope for the best, but prepare for the worst" Robert L. Nuckolls, III wrote: > At 03:17 PM 7/20/2009, you wrote: >> Good Afternoon 'Lectric Bob, >> >> I totally agree with you that the canted gyro works better for a wing >> leveler than does a T&B, but I do NOT feel it works well with we human >> pilots. Too much conflict with our semi circular canal sensors. But I >> have expanded on that thought here many times in the past. >> >> I would love to see something new and modern that would replace the >> T&B and the TC. Your thought on using a sequential GPS position seems >> to me to have considerable merit. > > Stabilization and control of the airframe is > still based on interpretation of rotational > rate values. The sensors are now all solid > state as opposed to spinning up a rotor > on bearings. The rate sensors have become > so commonplace that simple versions are offered > to augment pilot controls for flying model > r/c helicopters . . . and they're just a > few dollars. > > * http://tinyurl.com/lcuqkc* > > Two more technologies have come forward to make > the job easier and better. GPS and microprocessors. > > Our first autopilot for the MQM-107 > > http://www.designation-systems.net/dusrm/m-107.html > > was totally analog. 741 op amps and fists full of > transistors. The next autopilot was a TI 9900 > processor. All of a sudden, our calculating > ability combined with differentiation (anticipation) > made this bird fly even better yet. > > We never got to put GPS on this bird but it went > into other products. > > * http://tinyurl.com/lhwmnp* > > The availability of ground track nav data opened > the horizons for auto flight AND auto navigation. > > The thing that would be pretty cool with the products > I described is access to the serial data ports. > The stand-alone device would nicely steer an > airplane. But anyone handy with byte thrashing > could craft an auto-navigation application in the > portable number cruncher of their choice. > > Bob . . . > > --------------------------------------- > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > --------------------------------------- > > * > > > * ________________________________________________________________________________
Date: Jul 20, 2009
Is this ok for a Circuit diagram for a 2 place, 2 x ptt no external intercom ?????? Cheers Read this topic online here: http://forums.matronics.com/viewtopic.php?p=254063#254063 Attachments: http://forums.matronics.com//files/icom_a210_835.pdf ________________________________________________________________________________
Date: Jul 21, 2009
> > http://tinyurl.com/lcuqkc > The cheap ones like the above don't work that well (although it will still make the tail human controllable during helicopter aerobatics). The quality futaba products aren't that cheap. The difference between the quality and cheaper products are how much drift in yaw they allow under normal circumstances and how that effect varies based on input voltage variance and temperature variance and how well the gyro deals with vibration. The expensive ones perform better in other ways that matter in a rc helicopter but aren't needed in a wing leveler environment (which would be levels of magnitude less demanding). If i'm not mistaken Futaba actually produces their own sensors which implies to me that signal conditioning commercial off the shelf sensors must not be easy in demanding situations. Then again you talk about gps input so with proper software you could continually calibrate what signal from the gyro means "zero yaw" (or any other yaw rate). The thing is if you're going to do that it might just be as easy to buy a quality gps chipset and calculate for bank angle based on ground speed and turning radius (like the Garmin 396 and later do on their instrument page). Without the gps input or alternately a 3-axis compass input it would be difficult to not have the autopilot (using whatever sensors are in the cheaper rc heli gyros) continually command a very slow (yet highly annoying) turn. c'ya, Michael ________________________________________________________________________________
Date: Jul 21, 2009
Good Morning Michael, Great information for an old guy like me that is still struggling with Ohms Law! May I interject a few thoughts though? This new technology is certain to provide us with excellent autopilots and situational awareness instrumentation. The advancements in technology are mind boggling. Anything we purchase becomes obsolete before the ink is dry on the check. That is all to the good and I love to see it happening. Back to the world of application. The first time Wilbur, Orville or Glenn had difficulty establishing their reference to the natural horizon, folks realized that some instrumentation would be required to allow safe flight when visibility was reduced. The principles of the gyroscope were well understood and it was not long before various adaptations were applied to aircraft control. At the same time, the Wrights and other pioneers realized that there was benefit to building aerodynamic stability into their flying machines. As an aside, the Wrights had initially thought that the machine needed to be built with almost neutral stability in order for it to be controllable. The reason they never rebuilt the original Wright Flyer, but went on to another design is because their flights on December 17, 1903 taught them that the Flyer was not stable enough for practical flight. By the end of World War One, the concept of making the airplane dynamically stable and using a gyroscope to tell the pilot he/she was turning was well established. Monster ship's gyroscopes were too expensive and too heavy for practical airborne use, but a simple gyroscope hooked to some sort of an indicator that could tell the pilot the craft was turning was light weight and cheap enough that it became common equipment. Most of those units used a needle of some sort to tell the pilot what was happening. Many of the ones developed by European interests had the needle hinged at the top. Most that were developed on our side of the pond had the needle hinged at the bottom. By using the Turn needle to keep any turning force to a minimum and by learning the idiosyncrasies of Magnetic Compass precession during turns, it became practical to fly in cloud. Not easy, but doable. By the end of WW I the shape of future instrumentation was quite evident. They had learned that if you stop the turn, you will survive! Since coordinated flight was found to be advantageous, a simple inclinometer was added to the flight panel to display the degree of coordination being used. By the beginning of WWII, most turn instruments had that ball included within the same instrument case. Gyroscopes that showed an artificial horizon were developed, but they tended to be very heavy, very expensive, very delicate and not at all reliable if their mechanical limitations were exceeded. During the late twenties and early thirties, instrument flight became a practical endeavor. The Turn and Bank was the main thing used to allow the pilots to perceive a turning moment and the built in stability of the aircraft was such that it was relatively easy to evaluate the pitch and speed of the aircraft by the response of the airspeed indicator and the altimeter. Thus we had Needle, Ball, and Airspeed IFR flight. By the time WWII came along, the artificial horizons had gotten cheap enough and light enough such that they were fitted to most airliners and many larger military aircraft. Sure made for easier and smoother flight operations. Notice that, thus far, we were still relying primarily on a human being to supply the motion need to position the controls? Efforts had been made to build machinery that would perform that function, but was not yet well developed. Since this dissertation is getting way too long for an avionics list, fast forward to today. We now have almost unlimited calculating capability and there seems to be no reason why the human even needs to be involved other than as a mechanism to monitor what the electrons are doing. Given sufficient computing power, there is no doubt in my mind that it is relatively easy to make a machine that has a lower failure rate than do we mere humans. So, I guess the question is, how much do we want humans to be involved? Happy Skies, Old Bob LL22 Stearman N3977A In a message dated 7/21/2009 3:28:15 A.M. Central Daylight Time, mjpereira68(at)gmail.com writes: Then again you talk about gps input so with proper software you could continually calibrate what signal from the gyro means "zero yaw" (or any other yaw rate). The thing is if you're going to do that it might just be as easy to buy a quality gps chipset and calculate for bank angle based on ground speed and turning radius (like the Garmin 396 and later do on their instrument page). Without the gps input or alternately a 3-axis compass input it would be difficult to not have the autopilot (using whatever sensors are in the cheaper rc heli gyros) continually command a very slow (yet highly annoying) turn. c'ya, Michael **************What's for dinner tonight? Find quick and easy dinner ideas for any occasion. (http://food.aol.com/dinner-tonight?ncid=emlcntusfood00000009) ________________________________________________________________________________
Date: Jul 21, 2009
At 03:05 AM 7/21/2009, you wrote: > > > > > > http://tinyurl.com/lcuqkc > > > >The cheap ones like the above don't work that well (although it will >still make the tail human controllable during helicopter aerobatics). The citation of this particular part was not intended to suggest suitability to any task, only to illustrate the advancements in micro-electronics for the sensing of physical phenomena. Certainly there are moderately priced, solid state rate sensors that may be better suited to the task of crafting a flight augmentation system for a manned aircraft. But even the best sensors have offset gain and temperature coefficient errors that must be considered as part of the overall error budget. The neat thing about teaming these devices with micro-controllers is the ability to compare sensor outputs with other, more stable data sources and deduce those errors for the purposes of reducing/eliminating their effects. For example, we could take the least expensive of rate sensors combined with a GPS receiver and artfully crafted software that would allow the autopilot to go through some gentle maneuvers, compare expected GPS data with real data and calculate new offset and gain values for the as-installed rate sensor. Tailoring an autopilot to a specific airframe and its installation is a tedious and exacting process. However, for the simple heading-hold wing leveler, a freshly installed system could be placed in a temporary calibration mode and flown at altitude while allowing the autopilot to wiggle the controls and deduce appropriate gain and offset values for ALL of the as-installed hardware. Once the calibration sequence is completed, a switch is moved from the CAL to the FLY position and the processor stores all the new values for operation. If the el-cheeso rate sensor exhibits some degree of long term drift, the CAL process can be repeated at the owner's convenience to trim up system performance at any time. Further, cross checking against GPS data, allows small values of drift to be deduced on-the-fly and accounted for. FAA rules for software qualification would make such conveniences very difficult in a TC aircraft. As I suggested in an earlier post, the availability and capability of inexpensive GPS engines, micro-controllers and low-cost rate sensors is head-and-shoulders above those components which were the best we knew how to do 30 years ago. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jul 21, 2009
At 10:58 PM 7/20/2009, you wrote: > >I recall hearing that the solid state sensors (gyros) had a problem >with drift. Is this still an issue? You betcha! But it's slow and can be accommodated in software. See companion posting. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jul 21, 2009
Subject: Re: Air conditioning stuff for sale
Hi Dean, I'll pass on the R12, apparently, it's pretty difficult to get through the 49th Parallel Wall and I don't have a use for it right now. Thanks for thinking of me, anything else you have? Doug >>> DEAN PSIROPOULOS 07/19/09 9:22 PM >>> Don't know if any of you are contemplating an air conditioning system in your airplane or have an old R-12 system in your airplane (or car) that needs fixing but I may have what you need. Since I no longer own a vehicle that uses R-12 refrigerant I have seven 12 ounce cans available for sale at $35 dollars apiece (a repair shop now charges upwards of $100 a pound for R-12, if they can locate some). I also have an R-12 manifold gauge set (used to monitor the high and low pressures in an R-12 system while filling) and a tap for the R-12 cans ($35.00 for both of these). Let me know if you need any of these or, buy the whole ball of wax for $250.00. Dean Psiropoulos RV-6A N197DM Prop removed for radiographic inspection. ________________________________________________________________________________
Date: Jul 21, 2009
On Tue, Jul 21, 2009 at 6:21 AM, Robert L. Nuckolls, III wrote: > > > At 03:05 AM 7/21/2009, you wrote: >> >> >> >> > >> > http://tinyurl.com/lcuqkc >> > >> >> The cheap ones like the above don't work that well (although it will >> still make the tail human controllable during helicopter aerobatics). > > The citation of this particular part was not intended to > suggest suitability to any task, only to illustrate the > advancements in micro-electronics for the sensing of physical > phenomena. Certainly there are moderately priced, solid state > rate sensors that may be better suited to the task of > crafting a flight augmentation system for a manned aircraft. > > But even the best sensors have offset gain and temperature > coefficient errors that must be considered as part of the > overall error budget. The neat thing about teaming these devices > with micro-controllers is the ability to compare sensor outputs > with other, more stable data sources and deduce those errors > for the purposes of reducing/eliminating their effects. > > For example, we could take the least expensive of > rate sensors combined with a GPS receiver and artfully > crafted software that would allow the autopilot to go through > some gentle maneuvers, compare expected GPS data with real > data and calculate new offset and gain values for the > as-installed rate sensor. Tailoring an autopilot > to a specific airframe and its installation is a tedious > and exacting process. However, for the simple heading-hold > wing leveler, a freshly installed system could be placed in > a temporary calibration mode and flown at altitude while > allowing the autopilot to wiggle the controls and deduce > appropriate gain and offset values for ALL of the as-installed > hardware. Once the calibration sequence is completed, a > switch is moved from the CAL to the FLY position and the > processor stores all the new values for operation. Oh i agree with everything you've said. I think you'd have to manage without a specific calibration routine however, it's something that would have to run constantly (and that's assuming the quality gyro/rate sensor). > > If the el-cheeso rate sensor exhibits some degree of > long term drift, the CAL process can be repeated at > the owner's convenience to trim up system performance > at any time. Further, cross checking against GPS data, > allows small values of drift to be deduced on-the-fly > and accounted for. FAA rules for software qualification > would make such conveniences very difficult in a TC aircraft. The thing with the cheesy sensors as applied to the rc heli gyros is the drift varies from minute to minute requiring constant trim adjustments to the tail channel so it'll sit (relatively) still while the stick is at neutral. Now, the problem could be more related to crummy software than the sensor itself. No way to know in this kind of black box situation what components are generating what percentage of the total error. Whatever the case is with the cheesy gyros, futaba has it nailed with their more expensive stuff. Their tech is probably good enough for the cockpit (at least in general aviation). The drift errors are small, that has to make writing the calibration software easier. They probably aren't crazy enough to license it to that market considering the market size/liability issues though. > As I suggested in an earlier post, the availability > and capability of inexpensive GPS engines, micro-controllers > and low-cost rate sensors is head-and-shoulders above > those components which were the best we knew how to do > 30 years ago. So i'm curious. I've read a bit about 3-axis electronic compasses (basically the 3d allows the device to automatically compensate for magnetic tilt errors). If these devices are accurate enough and update fast enough, could one of these alone drive a simple wing leveler ? ie. change in heading divided by time equals rate of turn, etc. Well actually, I guess it would act nuts if you were operating close enough to one of the magnetic poles, nevermind. lol. c'ya, Michael ________________________________________________________________________________
Date: Jul 21, 2009
> >Oh i agree with everything you've said. I think you'd have to manage >without a specific calibration routine however, it's something that >would have to run constantly (and that's assuming the quality >gyro/rate sensor). Sure, with the GPS engine data we can resolve slow, short term drifts and compensate on-the-fly. The larger calibration corrections would probably be a one-time thing that would wash out initial offset, gains and mechanism transfer functions. >The thing with the cheesy sensors as applied to the rc heli gyros is >the drift varies from minute to minute requiring constant trim >adjustments to the tail channel so it'll sit (relatively) still while >the stick is at neutral. Now, the problem could be more related to >crummy software than the sensor itself. No way to know in this kind of >black box situation what components are generating what percentage of >the total error. We would probably not choose to get THAT cheesy. There's a host of rate sensors offered by the micro-machined chip manufacturers with very useable drift characteristics. >Whatever the case is with the cheesy gyros, futaba has it nailed with >their more expensive stuff. Their tech is probably good enough for >the cockpit (at least in general aviation). The drift errors are >small, that has to make writing the calibration software easier. They >probably aren't crazy enough to license it to that market considering >the market size/liability issues though. Wouldn't seek a "license" . . . there are plenty of commercial, off-the-shelf devices to choose from that have no more liability for airplanes falling out of the sky than do the nail manufacturer's have to shoulder for houses falling down. > > As I suggested in an earlier post, the availability > > and capability of inexpensive GPS engines, micro-controllers > > and low-cost rate sensors is head-and-shoulders above > > those components which were the best we knew how to do > > 30 years ago. > >So i'm curious. I've read a bit about 3-axis electronic compasses >(basically the 3d allows the device to automatically compensate for >magnetic tilt errors). If these devices are accurate enough and update >fast enough, could one of these alone drive a simple wing leveler ? >ie. change in heading divided by time equals rate of turn, etc. Well >actually, I guess it would act nuts if you were operating close enough >to one of the magnetic poles, nevermind. lol. They're interesting devices and we looked at them several times at the Beech/RAC Targets division. Problem is that there are 3 conditions of orientation where these devices fall out of bed. That's when any one of the three axes are exactly aligned with earth magnetic flux lines. Under that condition, the other two axes see the same data no matter how the device is rotated about that axis. While these may be transient conditions, they offered enough risk to operation of the fully aerobatic target that we rejected their incorporation into the product. It may be that one could use them with more confidence where the design goal is not to recover from an unusual attitude but to keep from getting into an unusual attitude. Bob . . . ________________________________________________________________________________
Date: Jul 21, 2009
Bob, Great review...... Dave ----- Original Message ----- From: BobsV35B(at)aol.com To: aeroelectric-list(at)matronics.com Sent: Tuesday, July 21, 2009 6:12 AM Subject: Re: AeroElectric-List: Autopilots vs. "The Right Stuff" Good Morning Michael, Great information for an old guy like me that is still struggling with Ohms Law! May I interject a few thoughts though? This new technology is certain to provide us with excellent autopilots and situational awareness instrumentation. The advancements in technology are mind boggling. Anything we purchase becomes obsolete before the ink is dry on the check. That is all to the good and I love to see it happening. Back to the world of application. The first time Wilbur, Orville or Glenn had difficulty establishing their reference to the natural horizon, folks realized that some instrumentation would be required to allow safe flight when visibility was reduced. The principles of the gyroscope were well understood and it was not long before various adaptations were applied to aircraft control. At the same time, the Wrights and other pioneers realized that there was benefit to building aerodynamic stability into their flying machines. As an aside, the Wrights had initially thought that the machine needed to be built with almost neutral stability in order for it to be controllable. The reason they never rebuilt the original Wright Flyer, but went on to another design is because their flights on December 17, 1903 taught them that the Flyer was not stable enough for practical flight. By the end of World War One, the concept of making the airplane dynamically stable and using a gyroscope to tell the pilot he/she was turning was well established. Monster ship's gyroscopes were too expensive and too heavy for practical airborne use, but a simple gyroscope hooked to some sort of an indicator that could tell the pilot the craft was turning was light weight and cheap enough that it became common equipment. Most of those units used a needle of some sort to tell the pilot what was happening. Many of the ones developed by European interests had the needle hinged at the top. Most that were developed on our side of the pond had the needle hinged at the bottom. By using the Turn needle to keep any turning force to a minimum and by learning the idiosyncrasies of Magnetic Compass precession during turns, it became practical to fly in cloud. Not easy, but doable. By the end of WW I the shape of future instrumentation was quite evident. They had learned that if you stop the turn, you will survive! Since coordinated flight was found to be advantageous, a simple inclinometer was added to the flight panel to display the degree of coordination being used. By the beginning of WWII, most turn instruments had that ball included within the same instrument case. Gyroscopes that showed an artificial horizon were developed, but they tended to be very heavy, very expensive, very delicate and not at all reliable if their mechanical limitations were exceeded. During the late twenties and early thirties, instrument flight became a practical endeavor. The Turn and Bank was the main thing used to allow the pilots to perceive a turning moment and the built in stability of the aircraft was such that it was relatively easy to evaluate the pitch and speed of the aircraft by the response of the airspeed indicator and the altimeter. Thus we had Needle, Ball, and Airspeed IFR flight. By the time WWII came along, the artificial horizons had gotten cheap enough and light enough such that they were fitted to most airliners and many larger military aircraft. Sure made for easier and smoother flight operations. Notice that, thus far, we were still relying primarily on a human being to supply the motion need to position the controls? Efforts had been made to build machinery that would perform that function, but was not yet well developed. Since this dissertation is getting way too long for an avionics list, fast forward to today. We now have almost unlimited calculating capability and there seems to be no reason why the human even needs to be involved other than as a mechanism to monitor what the electrons are doing. Given sufficient computing power, there is no doubt in my mind that it is relatively easy to make a machine that has a lower failure rate than do we mere humans. So, I guess the question is, how much do we want humans to be involved? Happy Skies, Old Bob LL22 Stearman N3977A In a message dated 7/21/2009 3:28:15 A.M. Central Daylight Time, mjpereira68(at)gmail.com writes: Then again you talk about gps input so with proper software you could continually calibrate what signal from the gyro means "zero yaw" (or any other yaw rate). The thing is if you're going to do that it might just be as easy to buy a quality gps chipset and calculate for bank angle based on ground speed and turning radius (like the Garmin 396 and later do on their instrument page). Without the gps input or alternately a 3-axis compass input it would be difficult to not have the autopilot (using whatever sensors are in the cheaper rc heli gyros) continually command a very slow (yet highly annoying) turn. c'ya, Michael ------------------------------------------------------------------------- ----- What's for dinner tonight? Find quick and easy dinner ideas for any occasion. ________________________________________________________________________________
Date: Jul 21, 2009
Yes, with the wondrous capabilities and reliability of today's computer controlled machines, be assured that nothing can go wrong...go wrong...go wrong....go........ I seem to recall reading about several accidents caused by the erroneous actions of computer controlled servo systems; actions that couldn't be detected nor corrected by the pilots.? Admittedly, these were the result of faulty assumptions being built into the computer's database by humans.? I guess it comes down to "who (or what) do you trust?" Jay -----Original Message----- From: David LLoyd <skywagon(at)charter.net> Sent: Tue, Jul 21, 2009 10:27 am Subject: Re: AeroElectric-List: Autopilots vs. "The Right Stuff" Bob, ? Great review...... Dave ----- Original Message ----- From: BobsV35B(at)aol.com Sent: Tuesday, July 21, 2009 6:12 AM Subject: Re: AeroElectric-List: Autopilots vs. "The Right Stuff" Good Morning Michael, ? Great information for an old guy like me that is still struggling with Ohms Law! ? May I interject a few thoughts though? ? This new technology is certain to provide us with excellent autopilots and situational awareness instrumentation. The advancements in technology are mind boggling. Anything we purchase becomes obsolete before the ink is dry on the check. ? That is all to the good and I love to see it happening. ? Back to the world of application. ? The first time Wilbur, Orville or Glenn had difficulty establishing their reference to the natural horizon, folks realized that some instrumentation would be required to allow safe flight when visibility was reduced. ? The principles of the gyroscope were well understood and it was not long before various adaptations were applied to aircraft control. ? At the same time, the Wrights and other pioneers realized that there was benefit to building aerodynamic stability into their flying machines. As an aside, the Wrights had initially thought that the machine needed to be built with almost neutral stability in order for it to be controllable. The reason they never rebuilt the original Wright Flyer, but went on to another design is because their flights on December 17, 1903 taught them that the Flyer was not stable enough for practical flight. ? By the end of World War One, the concept of making the airplane dynamically stable and using a gyroscope to tell the pilot he/she was turning was well established. Monster ship's gyroscopes were too expensive and too heavy for practical airborne use, but a simple gyroscope hooked to some sort of an indicator that could tell the pilot the craft was turning was light weight and cheap enough that it became common equipment.? Most of those units used a needle of some sort to tell the pilot what was happening. Many of the ones developed by European interests had the needle hinged at the top. Most that were developed on our side of the pond had the needle hinged at the bottom. ? By using the Turn needle to keep any turning force to a minimum and by learning the idiosyncrasies of Magnetic Compass precession during turns, it became practical to fly in cloud. Not easy, but doable. ? By the end of? WW I the shape of future instrumentation was quite evident. ? They had learned that if you stop the turn, you will survive! ? Since coordinated flight was found to be advantageous, a simple inclinometer was added to the flight panel to display the degree of coordination being used. By the beginning of WWII, most turn instruments had that ball included within the same instrument case. ? Gyroscopes that showed an artificial horizon were developed, but they tended to be very heavy, very expensive, very delicate and not at all reliable if their mechanical limitations were exceeded. ? During the late twenties and early thirties, instrument flight became a practical endeavor. The Turn and Bank was the main thing used to allow the pilots to perceive a turning moment and the built in stability of the aircraft was such that it was relatively easy to evaluate the pitch and speed of the aircraft by the response of the airspeed indicator and the altimeter. ? Thus?we had Needle, Ball, and Airspeed IFR flight. ? By the time WWII came along, the artificial horizons had gotten cheap enough and light enough such that they were fitted to most airliners and many larger military aircraft. Sure made for easier and smoother flight operations. ? Notice that, thus far, we were still relying primarily on a human being to supply the motion need to position the controls? ? Efforts had been made to build machinery that would perform that function, but was not yet well developed. ? Since this dissertation is getting way too long for an avionics list, fast forward to today. ? We now have almost unlimited calculating capability and there seems to be no reason why the human even needs to be involved other than as a?mechanism to monitor what the electrons are doing. Given sufficient computing power, there is no doubt in my mind that it is relatively easy to make a machine that has a lower failure rate than do we mere humans. ? So, I guess the question is, how much do we want humans to be involved? ? Happy Skies, ? Old Bob LL22 Stearman N3977A ? In a message dated 7/21/2009 3:28:15 A.M. Central Daylight Time, mjpereira68(at)gmail.com writes: Then again you talk about gps input so with proper software you could continually calibrate what signal from the gyro means "zero yaw" (or any other yaw rate).? The thing is if you're going to do that it might just be as easy to buy a quality gps chipset and calculate for bank angle based on ground speed and turning radius (like the Garmin 396 and later do on their instrument page).? Without the gps input or alternately a? 3-axis compass input it would be difficult to not have the autopilot (using whatever sensors are in the cheaper rc heli gyros) continually command a very slow (yet highly annoying) turn. c'ya, Michael What's for dinner tonight? Find quick and easy dinner ideas for any occasion. href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________ Email message sent from CompuServe - visit us today at http://www.cs.com ________________________________________________________________________________
Subject: Wild flights... 22 hr trip in an LSA over the Atlantic...
Date: Jul 21, 2009
Hey there all, I posted something similar to what I will write now but it does not seem to have come through. Two mates of mine will attempt (and hopefully complete) a flight across the Atlantic, from Conakry, Guinea to Belem, Brazil tomorrow evening. They are flying an aircraft called the 'Sling' that they designed and built here in South Africa; to be sold as a light sport kit. The aircraft is a low wing 2 seater with a 912 Rotax engine and is specially modified so that the whole leading edge of each wing is a fuel tank (divided into 6 tanks), carrying 450 litres of fuel. Tomorrow evening their flight will use 440 litres.. Its going to be a narrow thing. The aircraft has a modified Z-16 diagram that I used from Bob's (thank you!) lists/diagrams. In the aircraft there are 2 MGL Voyagers, a stormscope, transponder, Garmin SL30 Nav/ Comm radio, auto pilots, and bits and pieces including a satellite linked GPS tracker so that we can follow their progress. This last Saturday they took off from near Johannesburg here in South Africa and flew non-stop for 20 hours to reach Sao Tome off the west African coast, just south of Nigeria. I was with them when James, one of the pilots, filed an unbelievable flight plan for an LSA aircraft. He had to repeat and confirm the distances and aircraft type several times- and explain this to the disbelieving official at the other end. If you're curious and would like to see more have a look at http://www.airplanefactory.co.za/world/default.asp You will be able to track their flight across the Atlantic tomorrow if all goes well, and for those of you going to Oshkosh, they'll be there. Bob, I've read your arguments and as an electrical engineer they made a lot of sense; I used your suggestions and designs in this aircraft and so far it has worked well and I am sure that it will continue to do so. Here's hoping that my mates make it across the pond! Jay from South Africa ________________________________________________________________________________
Subject: Re: Electrical stuff for sale.
Date: Jul 21, 2009
Hi Dean, I am wondering if the Rocky Mountain Instrument - Micro Encoder (Unassembled Kit), fits std 3 1/8 inch instrument hole, displays airspeed, altitude, VSI, OAT, Altitude alerting, misc warnings. Half the price of new at $450.00 still available? Is it the low speed or standard speed microencoder? I am interested in buying this from you. Thank you, Aaron. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=254201#254201 ________________________________________________________________________________
Date: Jul 21, 2009
Subject: Re: The weak link
On Mon, Jul 20, 2009 at 6:25 AM, Joe wrote: > Bob Nuckolls said, "Perhaps dual wing levelers are in order? I'd bet that a > BIG > chunk of the accidents due to poor pilot visibility and/or > workload distractions for single-pilot IFR would have been > averted (if) electrons had the stick. I'll suggest that most > IFR capable airframes would be better outfitted for ventures > into poor visibility if there were NO displays on the panel > and dual, heading-slaved wing levelers installed. The wing > levelers are probably lighter and more reliable than a suite > of panel mounted gyros and more capable than pilot's trying > to manage an airplane . . . .." > > I agree wholeheartedly. Flying IFR, if we can trust our lives to > electronics to take information from sensors and display that information, > then why can't we trust electronics to actually operate the controls? The > human being is the weak link in the system. Have you ever noticed the > control movements when the autopilot is on, compared to when a human is in > control? Some planes have dual EFISs. I suggest that it would be better to > have dual autopilots with dual servos. The recreational IFR pilot is better > off monitoring the system as a whole, watching for component failure, making > sure that the altitude and heading are correct, handling radio > communications, looking for traffic, and etc. > Joe Gores Joe, Having software manage your flight controls doesn't eliminate the human "weak link" it just moves it from the pilot (who's own butt is on the line) and transfers it to computer programmers, the vast majority of which only understand a small part of the total program on large projects (which is unavoidable). They have the privilege of not being in the aircraft when their products fail (unless they're working for a major aircraft manufacturer and suffer an incredible case being in the wrong place at the wrong time). Don't cast me as a luddite, I have a ton of IT experience. And honestly all that experience makes me appreciate the concept of having a hunk of spinning iron as a backup. In fact, since efis is dependant on electricity, It'd be nice if that spinning gyro was based on vacuum (or an electrically driven one with it's own internal battery that *only* drives the motor). c'ya, Michael > > ________________________________________________________________________________
Date: Jul 21, 2009
Subject: transorbs
Howdy folks, In my work we use 30v transorbs similar the ones that have been discussed on this list for years. We use them to limit relay contact arcing when switching inductive loads such as mag locks and electric strikes. We have hundreds in the field and until yesterday I would have said they never go bad - but yesterday I had a service call and sure enough a transorb had shorted. In our applications the coil currents range from 125ma to maybe an amp or so. I don't know why it failed, maybe a manufacturing defect, but the point becomes that they CAN fail. So I'm thinking, if I have one of these things across the coil on my master contactor and it shorts - bad things happen. Not only would I loose electric power but the un-fused master switch wiring would be overloaded. I'm thinking maybe a 30v transorb across the master switch - not the contactor coil may be a better choice if you are going to use them at all. It would still protect the switch, it would still allow about 15v reverse voltage to collapse the field in the coil (12v system - use a 45v transorb in a 24v system) and in a failure mode you would just be unable to shut off the power. Anyway, I just wanted to bring attention to an admittedly remote failure mode and a possible re-configuration that would have a much more favorable result if a failure did occur. Joel ________________________________________________________________________________
Date: Jul 21, 2009
> > snip >> communications, looking for traffic, and etc. >> Joe Gores > > Joe, > > Having software manage your flight controls doesn't eliminate the > human "weak link" it just moves it from the pilot (who's own butt is > on the line) and transfers it to computer programmers, the vast > majority of which only understand a small part of the total program on > large projects (which is unavoidable). They have the privilege of not > being in the aircraft when their products fail (unless they're > working for a major aircraft manufacturer and suffer an incredible > case being in the wrong place at the wrong time). > > Don't cast me as a luddite, I have a ton of IT experience. And > honestly all that experience makes me appreciate the concept of having > a hunk of spinning iron as a backup. In fact, since efis is dependant > on electricity, It'd be nice if that spinning gyro was based on vacuum > (or an electrically driven one with it's own internal battery that > *only* drives the motor). > > c'ya, > Michael > One benefit the computer programmer has is the opportunity to ponder bad things happening while sitting at a desk (on the ground), drinking a favored beverage. On the other hand, the pilot gets to ponder these bad things while riding through said bad things (which are often quite distracting). Sometimes the pilot doesn't make the right decision and doesn't get to take another shot at it. The computer programmer can (with the help of peers) consider all sorts of malfunctions. One other thought.. The act of using GPS data to correct for roll/yaw gyro drift is a far cry (much simpler task) from the tasks currently being accomplished by the current crop of EFISs. Simpler tasks mean simpler code, and a much easier device to debug. What amounts to be a single axis autopilot could be done in very few lines of code. Matt- ________________________________________________________________________________
Date: Jul 21, 2009
Subject: Re: transorbs
Interesting. I could imagine that Bob might like to look at the shorted device - if it's still around. I wonder what short circuit current such a transorb might support before itself becoming a fuse (going open circuit).. If the switch and wiring can handle it, this may not be a terribly serious issue. A bit smokey perhaps... Matt- > Howdy folks, > In my work we use 30v transorbs similar the ones that have been discussed > on > this list for years. We use them to limit relay contact arcing when > switching inductive loads such as mag locks and electric strikes. We have > hundreds in the field and until yesterday I would have said they never go > bad - but yesterday I had a service call and sure enough a transorb had > shorted. In our applications the coil currents range from 125ma to maybe > an > amp or so. I don't know why it failed, maybe a manufacturing defect, but > the point becomes that they CAN fail. > > So I'm thinking, if I have one of these things across the coil on my > master > contactor and it shorts - bad things happen. Not only would I loose > electric power but the un-fused master switch wiring would be overloaded. > I'm thinking maybe a 30v transorb across the master switch - not the > contactor coil may be a better choice if you are going to use them at all. > It would still protect the switch, it would still allow about 15v reverse > voltage to collapse the field in the coil (12v system - use a 45v transorb > in a 24v system) and in a failure mode you would just be unable to shut > off > the power. > > Anyway, I just wanted to bring attention to an admittedly remote failure > mode and a possible re-configuration that would have a much more favorable > result if a failure did occur. > > Joel > ________________________________________________________________________________
Date: Jul 21, 2009
BobsV35B(at)aol.com wrote: > Good Morning Michael, > > Great information for an old guy like me that is still struggling with Ohms > Law! > > May I interject a few thoughts though? > > This new technology is certain to provide us with excellent autopilots and > situational awareness instrumentation. The advancements in technology are > mind boggling. Anything we purchase becomes obsolete before the ink is dry > on the check. > > You still write checks? Don't you know that technology have made them obsolete? 8*) > > So, I guess the question is, how much do we want humans to be involved? > I didn't get a pilot's license so that a machine could fly me around. 8*) -- http://www.ernest.isa-geek.org ________________________________________________________________________________
Date: Jul 21, 2009
Good Evening Ernest, May I take it from that statement that you prefer a Boeing over an Airbus? I repeat: The question is, how much do we want humans to be involved? Happy Skies, Old Bob In a message dated 7/21/2009 8:16:03 P.M. Central Daylight Time, echristley(at)nc.rr.com writes: I didn't get a pilot's license so that a machine could fly me around. 8*) **************What's for dinner tonight? Find quick and easy dinner ideas for any occasion. (http://food.aol.com/dinner-tonight?ncid=emlcntusfood00000009) ________________________________________________________________________________
Date: Jul 21, 2009
Yes I still have it and I'd be happy to send it to Bob if he wants to take a look. It's in heat shrink with lead wires sticking out. I haven't molested it yet - just checked it with a meter. A transorb is basicaly two zeners back to back and one in this is shorted. It measures a standard diode drop one way and open the other. Joel On Tue, Jul 21, 2009 at 8:39 PM, Matt Prather wrote: > > > > Interesting. > > I could imagine that Bob might like to look at the shorted device - if > it's still around. > > I wonder what short circuit current such a transorb might support before > itself becoming a fuse (going open circuit).. If the switch and wiring > can handle it, this may not be a terribly serious issue. A bit smokey > perhaps... > > > Matt- > > > Howdy folks, > > In my work we use 30v transorbs similar the ones that have been discussed > > on > > this list for years. We use them to limit relay contact arcing when > > switching inductive loads such as mag locks and electric strikes. We > have > > hundreds in the field and until yesterday I would have said they never go > > bad - but yesterday I had a service call and sure enough a transorb had > > shorted. In our applications the coil currents range from 125ma to maybe > > an > > amp or so. I don't know why it failed, maybe a manufacturing defect, but > > the point becomes that they CAN fail. > > > > So I'm thinking, if I have one of these things across the coil on my > > master > > contactor and it shorts - bad things happen. Not only would I loose > > electric power but the un-fused master switch wiring would be overloaded. > > I'm thinking maybe a 30v transorb across the master switch - not the > > contactor coil may be a better choice if you are going to use them at > all. > > It would still protect the switch, it would still allow about 15v reverse > > voltage to collapse the field in the coil (12v system - use a 45v > transorb > > in a 24v system) and in a failure mode you would just be unable to shut > > off > > the power. > > > > Anyway, I just wanted to bring attention to an admittedly remote failure > > mode and a possible re-configuration that would have a much more > favorable > > result if a failure did occur. > > > > Joel > > > > ________________________________________________________________________________
Date: Jul 22, 2009
Hey there all, I posted something similar to what I will write now but it does not seem to have come through. Two mates of mine will attempt (and hopefully complete) a flight across the Atlantic, from Conakry, Guinea to Belem, Brazil this evening. They are flying an aircraft called the Sling that they designed and built here in South Africa; to be sold as a light sport kit. The aircraft is a low wing 2 seater with a 912 Rotax engine and is specially modified so that the whole leading edge of each wing is a fuel tank (divided into 6 tanks), carrying 450 litres of fuel. This evening their flight will use 440 litres. Its going to be a narrow thing. The aircraft has a modified Z-16 diagram that I used from Bobs (thank you!) lists/diagrams. In the aircraft there are 2 MGL Voyagers, a stormscope, transponder, Garmin SL30 Nav/ Comm radio, auto pilots, and bits and pieces including a satellite linked GPS tracker so that we can follow their progress. This last Saturday they took off from near Johannesburg here in South Africa and flew non-stop for 20 hours to reach Sao Tome off the west African coast, just south of Nigeria. I was with them when James, one of the pilots, filed an unbelievable flight plan for an LSA aircraft. He had to repeat and confirm the distances and aircraft type several times- and explain this to the disbelieving official at the other end. If youre curious and would like to see more have a look at http://www.airplanefactory.co.za/world/default.asp You will be able to track their flight across the Atlantic tomorrow if all goes well, and for those of you going to Oshkosh, theyll be there. Bob, Ive read your arguments and as an electrical engineer they made a lot of sense; I used your suggestions and designs in this aircraft and so far it has worked well and I am sure that it will continue to do so. Heres hoping that my mates make it across the pond! Jay from South Africa ________________________________________________________________________________
Date: Jul 22, 2009
Subject: differences in fuses versus circuit breakers
Hi Bob, For the 12v/24v DC circuits typically used in our aircraft, is there any difference in the rating one would select if using a fuse versus a circuit breaker? In other words, a hypothetical example, if one arrived at a value of 15 amps to protect a wire, would a 15 amp fuse be interchangeable with a 15 amp circuit breaker for protecting the wire? I ask for two reasons - in a discussion on another mailing list, someone has said that fuses and circuit breakers of the same rated value are not interchangeable, and AC43.13-1B table 11-3 on page 11-15 in Section 4 shows a 15 amp CB or a 10 amp fuse to protect a 16 gauge copper wire (picture attached). If there is a difference, do you know and can you explain in simple terms why? Thanks, -Dj -- Dj Merrill - N1JOV Glastar Sportsman 2+2 Builder #7118 N421DJ http://deej.net/sportsman/ "Many things that are unexplainable happen during the construction of an airplane." --Dave Prizio, 30 Aug 2005 ________________________________________________________________________________
Subject: EV200
Date: Jul 22, 2009
It appears the EV200 is a good master relay...anyone know why it should not be used as a starter relay...also...? Al Read this topic online here: http://forums.matronics.com/viewtopic.php?p=254326#254326 ________________________________________________________________________________
From: "nuckollsr" <bob.nuckolls(at)aeroelectric.com>
Date: Jul 22, 2009
Yes I still have it and I'd be happy to send it to Bob if he wants to take a look. It's in heat shrink with lead wires sticking out. I haven't molested it yet - just checked it with a meter. A transorb is basicaly two zeners back to back and one in this is shorted. It measures a standard diode drop one way and open the other. Yes, I'd like to look at it. Please send to Bob Nuckolls, P.O. Box 130, Medicine Lodge, KS 67104-0130. Bob . . . Read this topic online here: http://forums.matronics.com/viewtopic.php?p=254333#254333 ________________________________________________________________________________
Date: Jul 22, 2009
Subject: Re: EV200
At 11:31 AM 7/22/2009, you wrote: > >It appears the EV200 is a good master relay...anyone know why it >should not be used as a starter relay...also...? To what advantage? This is a contactor that operates for a few seconds per flight cycle. The el-cheeso parts have performed well and demonstrated good value. The EV200 may function well too . . . but what's the expected return on investment for the more expensive purchase? Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jul 22, 2009
Subject: Re: differences in fuses versus circuit breakers
At 10:06 AM 7/22/2009, you wrote: >Hi Bob, > For the 12v/24v DC circuits typically used in our aircraft, is there >any difference in the rating one would select if using a fuse versus a >circuit breaker? In other words, a hypothetical example, if one arrived >at a value of 15 amps to protect a wire, would a 15 amp fuse be >interchangeable with a 15 amp circuit breaker for protecting the wire? This is a classic example of how AC43.13 offers advice that is not explained and makes no sense based on the physics. For example, AC43.13 says their table applies to fuses per Mil-F-15160. Here . . . http://www.dscc.dla.mil/Programs/MilSpec/ListDocs.asp?BasicDoc=MIL-PRF-15160 we see that the general spec covers a couple dozen types of fast acting fuses (1 hour trip at 135%, seconds to few minutes at 200%). The spec called out is constellation of FORM/FIT/FUNCTION specs for a variety of fuses. Now we go look at Mil-C-5806G . . . http://www.aeroelectric.com/Reference_Docs/Circuit_Breaker/Mil-C-5806G.pdf This is a QUALIFICATION TEST spec for circuit breakers of unspecified performance. The poor sap who takes AC43.13 table 11-13, and the specifications called out (gee the talked about Mil-W-5088 wire too!) will be pretty much in the dark as to how a considered selection can be made. MOST readers will simply check to see that the sales brochure for each part under consideration simply cites these specs . . . without a clue as to how the part performs to design goals. > I ask for two reasons - in a discussion on another mailing list, >someone has said that fuses and circuit breakers of the same rated value >are not interchangeable, and AC43.13-1B table 11-3 on page 11-15 in >Section 4 shows a 15 amp CB or a 10 amp fuse to protect a 16 gauge >copper wire (picture attached). For our purposes, breakers and fuses are size-for-size interchangeable. The table cited from AC43.13 is but one of many examples of poor and/or senseless advice. Please consider running section 11 through the shredder and come here to the AeroElectric List for advice based on experience and proven recipes for success. The article at http://www.aeroelectric.com/articles/wiresize.pdf speaks to the practical aspects of wire sizing and selection of circuit protection. For the airplanes we're building, it DOESN'T need to be complicated. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Subject: Re: EV200
Date: Jul 22, 2009
If I could get the parts cheap enough, the benefit for me, with two planes, would be interchangeability...or just having one spare on the shelf. Thanks for the initial lead, it looks like a great relay, but like you say, can be pricey...I think I can get them at a little over $40. Cheers, Al Read this topic online here: http://forums.matronics.com/viewtopic.php?p=254422#254422 ________________________________________________________________________________
Date: Jul 22, 2009
From: "Richard E. Tasker" <retasker(at)optonline.net>
Subject: Re: EV200
Uuuh... Because a much cheaper and perfectly adequate solution is available - the normal el-cheapo starter relay. The only reason I can see for ever using the EV200 is that it uses less current when it is energized which might be justifiable for the master relay. But for the starter relay - how long would it be on when starting - 2-5 seconds? Save the money and spend it on gas... My $0.02 Dick Tasker al38kit wrote: > > It appears the EV200 is a good master relay...anyone know why it should not be used as a starter relay...also...? > > Al ________________________________________________________________________________
Date: Jul 22, 2009
On 7/22/2009 7:25 PM, Robert L. Nuckolls, III wrote: > For our purposes, breakers and fuses are size-for-size interchangeable. Thanks! :-) -Dj ________________________________________________________________________________
Date: Jul 22, 2009
Subject: Re: Autopilots vs. "The Right Stuff"
At 11:21 AM 7/21/2009, you wrote: >Yes, with the wondrous capabilities and reliability of today's >computer controlled machines, be assured that nothing can go >wrong...go wrong...go wrong....go........ > >I seem to recall reading about several accidents caused by the >erroneous actions of computer controlled servo systems; actions that >couldn't be detected nor corrected by the pilots. Admittedly, these >were the result of faulty assumptions being built into the >computer's database by humans. I guess it comes down to "who (or >what) do you trust?" Or designing for failure tolerance. Accidents that follow servo system failures are generally situations where the pilot did not have his/her hand on the stick while too close to the ground. I've had a/p systems hiccup . . . and it's never pleasant. I wouldn't shoot a coupled approach without having a hand on the wheel and a thumb on the disconnect switch. You need to unhook the autopilot to land so you can be ready to punch it off when you break out and/or punch it off when and if it strays. I worked a FMEA on a Baron accident where the pilot was in a climb and punched altitude hold as he approached his assigned level. The autopilot immediately grabbed pitch and held the desired altitude. At the same time, it started driving trim to take force out of the pitch servo. Unfortunately, the down-pitch relay stuck and continued to trim down while the a/p servo worked to keep pitch level. When the pitch servo ran out of authority, the aircraft nosed down. The pilot was then aware of a problem. He correctly deduced a difficulty in the automatic flight control system and punched the a/p disconnect button. The pitch servo relaxed and the airplane was now trimmed nearly full nose down trim. Forces on the wheel needed to keep the airplane level would have been high. He was so busy trying to fly the airplane that he probably didn't notice the trim situation. This was a smoking hole event where all of the wreckage ended up in a single divot. In years since we've installed pitch authority limiters in servos (no reason for the a/p to be more capable than a robust pilot), trim in motion annunciation signals, and software based monitors that watch for diverging forces. The accident was a simple, analog, single channel autopilot that had a connection to the standard factory electric trim. The a/p had no way to spot the stuck relay but was capable of standing off the effects of divergent forces until they were too large for the pilot to physically handle when he told the autopilot to buzz off. Microprocessors, highly integrated flight control systems, and lessons-learned have largely eliminated such events. The forces and rates in a stepper motor implemented wing leveler can never over-stress a pilot or an airframe. Bob . . . ________________________________________________________________________________
Date: Jul 23, 2009
At 07:10 PM 7/21/2009, you wrote: > > > >One benefit the computer programmer has is the opportunity to ponder bad >things happening while sitting at a desk (on the ground), drinking a >favored beverage. On the other hand, the pilot gets to ponder these bad >things while riding through said bad things (which are often quite >distracting). Sometimes the pilot doesn't make the right decision and >doesn't get to take another shot at it. The computer programmer can (with >the help of peers) consider all sorts of malfunctions. > >One other thought.. The act of using GPS data to correct for roll/yaw >gyro drift is a far cry (much simpler task) from the tasks currently being >accomplished by the current crop of EFISs. Simpler tasks mean simpler >code, and a much easier device to debug. What amounts to be a single axis >autopilot could be done in very few lines of code. Absolutely! This is why the design goals I suggested for the GPS aided wing leveler has the gps receiver built in along with the rate sensors. No wiring other than to power it up, hook up an antenna and pushbuttons. If a valid gps signal isn't present, the system won't drive. If 14v isn't present, it won't drive. Software has but one task only . . . hold gps course of the moment which is modified by simple push-button commands -or- offered by external flight planning accessory over the serial bus. VERY simple code in a one-chip microprocessor. total parts count is very low . . . i.e. failure rates driven by complexity go way down. If you push all the fancy maneuvering software and hardware out to a plug-n-play device like a palm- computer, then the guy who keeps the airplane right side up and pointed the right direction is not distracted nor are his design goals plagued with CPU "business". Let somebody else with equally constrained design goals write the software that does the fancy steering . . . but in a device that can be unplugged or turned off without influencing the performance of the wing-leveler. This distributed processing, minimalist hardware approach offers an opportunity for a small, light, low cost end product, and reduces probability of high-risk software. A dual wing-leveler package has two control gps receivers cross-checked with data from a third panel mounted receiver. Probability for an system failure to endure unattended by the pilot is low and plan-a/plan-b tolerance to failure is high. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jul 23, 2009
At 06:23 PM 7/21/2009, you wrote: >Howdy folks, >In my work we use 30v transorbs similar the ones that have been >discussed on this list for years. We use them to limit relay >contact arcing when switching inductive loads such as mag locks and >electric strikes. We have hundreds in the field and until yesterday >I would have said they never go bad - but yesterday I had a service >call and sure enough a transorb had shorted. In our applications >the coil currents range from 125ma to maybe an amp or so. I don't >know why it failed, maybe a manufacturing defect, but the point >becomes that they CAN fail. The transorb is indeed a specialized zener. In the zener conduction mode, the potential for dissipating a deleterious level of heat is much higher than for a diode rectifier. The energy available from a magnetic field collapse is quite low and measured in millijoules. Certainly a low risk stress to any power semiconductor. The ability of the electrical system to deliver energy to the transorb in a voltage transient condition is many times higher. >So I'm thinking, if I have one of these things across the coil on my >master contactor and it shorts - bad things happen. Not only would >I loose electric power but the un-fused master switch wiring would >be overloaded. I'm thinking maybe a 30v transorb across the master >switch - not the contactor coil may be a better choice if you are >going to use them at all. It would still protect the switch, it >would still allow about 15v reverse voltage to collapse the field in >the coil (12v system - use a 45v transorb in a 24v system) and in a >failure mode you would just be unable to shut off the power. But there are OTHER, equally likely failure modes that can take the battery contactor out of service. That's what the e-bus alternate feed path is all about. The optimum location for transient suppression is at the contactor coil terminals. Do I correctly deduce from your posting that your contactor coils are protected by a single transorb? If so, then it has to be wired as shown in -A- below. Emacs! In this configuration, the device HAS to be biased in the zener conduction mode polarity while coiled power IS APPLIED. When the switch opens, the top of the coil swings negative . . . and the transorb is now biased in the diode conduction mode. This configuration doesn't take advantage of the transorb's voltage limiting function as a specialized zener. In other words, your transorb functionality in the coil release mode is the same as for the simple diodes described in: http://www.aeroelectric.com/articles/spikecatcher.pdf The proper application of uni-polar transorbs or zeners for SPIKE mitigation is to place them in series with a plain vanilla rectifier as shown in -B-. In this case, power that energizes the coil is blocked by the diode, but the strong negative swing at switch opening time is carried through the diode to the transorb that conducts like a ZENER to limit the excursion to more attractive levels (and allows the contactor to release faster). See: If the contactor release time (15mS versus 60 mS) is critical the use of transorbs as shown in -B- is indicated . . . -OR- you can use a single, bi-directional device to keep the wiring complexity down and eliminate device polarity concerns. If your transorbs are implemented as in -A- then they've offered no more functionality than the simple rectifier diode would offer. If contactor release time is critical, then changing to -B- or changing to bi-directional devices is called for. See: http://www.aeroelectric.com/Pictures/Curves/Cole-Hersee_with_Diode.gif http://www.aeroelectric.com/Pictures/Curves/Cole-Hersee_without_Diode.gif http://www.aeroelectric.com/Pictures/Curves/CH_w_2x18v_Transorbs.gif http://www.aeroelectric.com/Pictures/Curves/CH_w_120_Ohm.gif http://www.aeroelectric.com/Pictures/Curves/CH_w_1n5400.gif >Anyway, I just wanted to bring attention to an admittedly remote >failure mode and a possible re-configuration that would have a much >more favorable result if a failure did occur. Failures of the plain-vanilla diode are unknown to me. They're simply never electrically stressed in a manner that puts them at risk for failure. Similarly, Transorbs wired as shown in -B- cannot be impressed with system transients because they're isolated by the series diode. I'll suggest that there's more to your failure experience than what you've related in your posting. Bob . . . ________________________________________________________________________________
Date: Jul 21, 2009
Subject: Voltage Drop / amp ?????
Date: Jul 23, 2009
I have wired my RV7A with the 13/8 revision L. I did modify it to include t he LR3C Alternator controller in place of genric Ford Regulator and the AEC 9005-101 Low Voltage Module. In looking at the 13/8 revision Q there is an addition of a S704-1 / diode combo added to the Main Battery Bus / Enduranc e Bus / Endurance Bus Switch. I also have noted that a AEC9001 Schottky Dio de can be used in place of a bridge diode. As I notded in a previous email. 1. When the master switch is closed the vo ltage showes around 10.8 volts with rock solid amps indication on the Dynon D-120 EMS. When the endurance switch is closed the Voltage moves up to 12. 8 or 12.9 and the amps meter begins to fluctuate. Open the Master Switch th us having the load go to only the endurance bus side the voltage maintains at 12.8 to 12.9 volts and the amps still fluctuates. This situation happens with or with out the engine running. The battery maintains charge. Since I sent the last email I have learned that the bridge diode will cause a drop in voltage. (Even this 62 year old guy can learn stuff....) =2C but I would have though it would cause the endurance voltage to be less on the endurance bus side not the main bus side with the master switch closed.??? ???? Now the questions. 1. Why the addition of the S204-1 / diode combo added at the endurance bus switch and will it be of value in my configuration to ad ded it. 2. Would it be of value to added the Schottly in place of the bridg e diode. I would think yes if the voltage drop is less and thus give a more accurate voltage reading. 3. Why the higher voltage drop on the Main Bus a s compared to the Endurance Bus? 4. Whay the conflicting amp reading betwee n the Main vs Endurance Bus. Thanks in advance for any help in this matter Frank @ 1L8 ...RV7A... Phase 1 underway _________________________________________________________________ Windows Live=99 Hotmail=AE: Celebrate the moment with your favorite sports pics. Check it out. http://www.windowslive.com/Online/Hotmail/Campaign/QuickAdd?ocid=TXT_TAGL M_WL_QA_HM_sports_photos_072009&cat=sports ________________________________________________________________________________
Subject: Re: Wild flights... 22 hr trip in an LSA over the Atlantic...
Date: Jul 23, 2009
They made it to Brazil. -------- rck Read this topic online here: http://forums.matronics.com/viewtopic.php?p=254508#254508 ________________________________________________________________________________
Atlantic...
Date: Jul 23, 2009
Yeah- its been a very anxious and scary time for all of us. I think that they have made aviation history doing it. After Oshkosh there is still a big journey awaiting them. They're already heroes here in SA and we are planning a huge party when they arrive. If you've been following the website you'll have seen the desperation, anxiety and elation the trip has caused. I trust that y'all ;-) will give them a great reception at Oshkosh! ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Jay Hyde HH Enterprises Aircraft Manufacture, Engineering and Flying jay(at)horriblehyde.com Mobile phone: 083 300 8675 International: +27 83 300 8675 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of rckol Sent: 23 July 2009 10:10 PM Subject: AeroElectric-List: Re: Wild flights... 22 hr trip in an LSA over the Atlantic... They made it to Brazil. -------- rck Read this topic online here: http://forums.matronics.com/viewtopic.php?p=254508#254508 ________________________________________________________________________________
Atlantic...
Date: Jul 23, 2009
Tell 'em CONGRATULATIONS! And thanks for letting us know. Hope they have a safe trip the rest of the way to Oshkosh. Bob Taylor ----- Original Message ----- From: "rckol" <rckol(at)kaehlers.com> Sent: Thursday, July 23, 2009 4:09 PM Subject: AeroElectric-List: Re: Wild flights... 22 hr trip in an LSA over the Atlantic... > > They made it to Brazil. > > -------- > rck > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=254508#254508 > > > ________________________________________________________________________________
Atlantic...
Date: Jul 23, 2009
If you go to their website (http://www.airplanefactory.co.za/world/default.asp) you can leave them a message yourself :-) - they'd really appreciate it ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Jay Hyde HH Enterprises Aircraft Manufacture, Engineering and Flying jay(at)horriblehyde.com Mobile phone: 083 300 8675 International: +27 83 300 8675 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert D. Taylor Sent: 23 July 2009 10:38 PM Subject: Re: AeroElectric-List: Re: Wild flights... 22 hr trip in an LSA over the Atlantic... Tell 'em CONGRATULATIONS! And thanks for letting us know. Hope they have a safe trip the rest of the way to Oshkosh. Bob Taylor ----- Original Message ----- From: "rckol" <rckol(at)kaehlers.com> Sent: Thursday, July 23, 2009 4:09 PM Subject: AeroElectric-List: Re: Wild flights... 22 hr trip in an LSA over the Atlantic... > > They made it to Brazil. > > -------- > rck > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=254508#254508 > > > ________________________________________________________________________________
Subject: Re: EV200
Date: Jul 23, 2009
(some repost here...) I have railed against these Type-70 contactors for years. But they are almost obsolete. Most electronics distributors have dropped them from their lines. Problems-- 1) Low Temperature rating. Only 122F max. You could land at Furnace Creek in Death Valley in May and take off in October. Maybe. This is primarily due to the Nylon innards. This is a drop-dead reason to avoid the part. 2) Not sealed. Not dust proof, or fuel proof. 3) Low interrupt capacity. 4) High hold current---16 ohm coil. Almost one amp. 5) Low hold force. The specifications call for specific orientation. 2G rating? 6) Wildly wrong for B&C to use coil suppression diodes on these. This causes short lifetimes on the B&C parts. 7) Not designed to open against voltages above 36 volts. (So forget the B-lead applications) See: www.stancor.com There are better ways to go. Omron's line of automotive contactors (CHEAP) and Kilovac's EV200 series, Blue Sea 9012, Gigavac's GX-11. Expensive but preferred. Can you use them? Sure. Should you use them?....not on my bird, Bubela. Better yet, avoid all contactors and use manual switches if you can. "Facts do not cease to exist because they are ignored." ---Aldous Huxley -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=254518#254518 ________________________________________________________________________________
Atlantic...
Date: Jul 24, 2009
Hey there everyone, My apologies for the multiple posts on this; my webmail service and email server was arbitrarily placing mails into a junk folder that was not accessed by the POP3 download so I was not seeing any replies and was getting very frustrated! For your interest here is a bit from a post that I made on another forum. Thanks to all of you who have sent messages of congratulations! ****************** I was also most pleased to hear that the storm scope worked well- the antenna for that (very complex with a whole bunch of individually screened twisted pairs in an overall screened cable) was wired one bitterly cold evening at 3am in the Springs hanger as the guys bashed and moved the airframe around getting the wings installed! The aircraft has an unusual fitting as well- a hooter; this was Mikes idea which he thought might help to scare birds away when flying low level near the coast. That was wired up that same evening a couple of hours earlier - Mike was under the aircraft on his back and the guys were trying to manoeuvre the wing into its slot (extra layers of paint was making this difficult and they had to keep removing it and sand paint away...). Without thinking I switched the DC Master on and pressed the hooter button. Mike must have been concentrating fiercely because he shot out and up from under the aircraft yelling 'yah, yah, yaaaah!' He had got one heck of a fright. It provided a laugh and a slight warm up for all of us. :lol: ***************** ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Jay Hyde HH Enterprises Aircraft Manufacture, Engineering and Flying jay(at)horriblehyde.com Mobile phone: 083 300 8675 International: +27 83 300 8675 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Jay Hyde Sent: 23 July 2009 10:56 PM Subject: RE: AeroElectric-List: Re: Wild flights... 22 hr trip in an LSA over the Atlantic... If you go to their website (http://www.airplanefactory.co.za/world/default.asp) you can leave them a message yourself :-) - they'd really appreciate it ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Jay Hyde HH Enterprises Aircraft Manufacture, Engineering and Flying jay(at)horriblehyde.com Mobile phone: 083 300 8675 International: +27 83 300 8675 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert D. Taylor Sent: 23 July 2009 10:38 PM Subject: Re: AeroElectric-List: Re: Wild flights... 22 hr trip in an LSA over the Atlantic... Tell 'em CONGRATULATIONS! And thanks for letting us know. Hope they have a safe trip the rest of the way to Oshkosh. Bob Taylor ----- Original Message ----- From: "rckol" <rckol(at)kaehlers.com> Sent: Thursday, July 23, 2009 4:09 PM Subject: AeroElectric-List: Re: Wild flights... 22 hr trip in an LSA over the Atlantic... > > They made it to Brazil. > > -------- > rck > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=254508#254508 > > > ________________________________________________________________________________
Date: Jul 24, 2009
Atla... Good Morning Jay, Just wanted to thank you for letting us know about this project. I did attempt to send a message to your friends, but I don't think it worked. My lack of computer skills became evident as I attempted to work my way through the process. In any case, I will be looking for them at Oshkosh. Happy Skies, Old Bob Pacer N2858P In a message dated 7/24/2009 4:58:10 A.M. Central Daylight Time, jay(at)horriblehyde.com writes: --> AeroElectric-List message posted by: "Jay Hyde" Hey there everyone, My apologies for the multiple posts on this; my webmail service and email server was arbitrarily placing mails into a junk folder that was not accessed by the POP3 download so I was not seeing any replies and was getting very frustrated! For your interest here is a bit from a post that I made on another forum. Thanks to all of you who have sent messages of congratulations! ****************** I was also most pleased to hear that the storm scope worked well- the antenna for that (very complex with a whole bunch of individually screened twisted pairs in an overall screened cable) was wired one bitterly cold evening at 3am in the Springs hanger as the guys bashed and moved the airframe around getting the wings installed! The aircraft has an unusual fitting as well- a hooter; this was Mikes idea which he thought might help to scare birds away when flying low level near the coast. That was wired up that same evening a couple of hours earlier - Mike was under the aircraft on his back and the guys were trying to manoeuvre the wing into its slot (extra layers of paint was making this difficult and they had to keep removing it and sand paint away...). Without thinking I switched the DC Master on and pressed the hooter button. Mike must have been concentrating fiercely because he shot out and up from under the aircraft yelling 'yah, yah, yaaaah!' He had got one heck of a fright. It provided a laugh and a slight warm up for all of us. :lol: ***************** ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Jay Hyde HH Enterprises Aircraft Manufacture, Engineering and Flying jay(at)horriblehyde.com Mobile phone: 083 300 8675 International: +27 83 300 8675 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Jay Hyde Sent: 23 July 2009 10:56 PM Subject: RE: AeroElectric-List: Re: Wild flights... 22 hr trip in an LSA over the Atlantic... --> AeroElectric-List message posted by: "Jay Hyde" If you go to their website (http://www.airplanefactory.co.za/world/default.asp) you can leave them a message yourself :-) - they'd really appreciate it ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Jay Hyde HH Enterprises Aircraft Manufacture, Engineering and Flying jay(at)horriblehyde.com Mobile phone: 083 300 8675 International: +27 83 300 8675 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert D. Taylor Sent: 23 July 2009 10:38 PM Subject: Re: AeroElectric-List: Re: Wild flights... 22 hr trip in an LSA over the Atlantic... --> AeroElectric-List message posted by: "Robert D. Taylor" Tell 'em CONGRATULATIONS! And thanks for letting us know. Hope they have a safe trip the rest of the way to Oshkosh. Bob Taylor ----- Original Message ----- From: "rckol" <rckol(at)kaehlers.com> Sent: Thursday, July 23, 2009 4:09 PM Subject: AeroElectric-List: Re: Wild flights... 22 hr trip in an LSA over the Atlantic... > --> AeroElectric-List message posted by: "rckol" > > They made it to Brazil. > > -------- > rck > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=254508#254508 > > > **************An Excellent Credit Score is 750. See Yours in Just 2 Easy Steps! yExcfooterNO62) ________________________________________________________________________________
Date: Jul 23, 2009
I have wired my RV7A with the 13/8 revision L. I did modify it to include the LR3C Alternator controller in place of genric Ford Regulator and the AEC9005-101 Low Voltage Module. In looking at the 13/8 revision Q there is an addition of a S704-1 / diode combo added to the Main Battery Bus / Endurance Bus / Endurance Bus Switch. I also have noted that a AEC9001 Schottky Diode can be used in place of a bridge diode. As I noted in a previous email. 1. When the master switch is closed the voltage shoes around 10.8 volts with rock solid amps indication on the Dynon D-120 EMS. From this I deduce that your Dynon is measuring the e-bus voltage. Indeed, with master switch ON and alternator not running, the main bus would normally be a about 12.5 volts. An expected 0.7 volt drop in normal feed diode produces an e-bus voltage on the order of 11.8 volts. When the endurance switch is closed the Voltage moves up to 12.8 or 12.9 and the amps meter begins to fluctuate. Open the Master Switch thus having the load go to only the endurance bus side the voltage maintains at 12.8 to 12.9 volts and the amps still fluctuates. Okay, with the alternator OFF the battery-only voltage would be expected to fall in this range. When you say the amps "fluctuates" what's the max-min numbers displayed? This situation happens with or without the engine running. The battery maintains charge. With the engine running, do you turn the alternator ON to see if it elevates the bus to the nominal 14.2 to 14.6 volts? Since I sent the last email I have learned that the bridge diode will cause a drop in voltage. (Even this 62 year old guy can learn stuff....), but I would have though it would cause the endurance voltage to be less on the endurance bus side not the main bus side with the master switch closed.??????? Then the Dynon is NOT monitoring the e-bus? If you close the e-bus alternate feed switch and the Dynon display goes UP, then it appears that the Dynon is on the e-bus. Now the questions. 1. Why the addition of the S204-1/diode combo added at the endurance bus switch and will it be of value in my configuration to added it? Don't know what an S204-1 device is . . . and don't know why ANY diode would be wired to the e-bus alternate feed switch. 2. Would it be of value to added the Schottly in place of the bridge diode? Slightly . . . but from the readings you cite it's not clear that the Dynon is connected to the Main bus . . . hence SOME degree of bus votlage suppression would be expected. I would think yes if the voltage drop is less and thus give a more accurate voltage reading. The voltmeter is already ACCURATE. It's showing the votlage at where ever it's attached. I'm guessing the e-bus. So all other things being normal and functioning to design goals, the readings are expected and normal. 3. Why the higher voltage drop on the Main Bus as compared to the Endurance Bus? With engine not running and alternator OFF . . . Get out a voltmeter and connect the (-) lead to the battery (-) or to airframe ground. With master switch ON, E-bus alternate feed switch OFF, measure and record main and e-bus voltages. Turn E-Bus alternate feed switch ON and repeat the measurements. Leave B-Bus switch ON turn master switch OFF and repeat the measurements. With engine running and alternator ON . . . With master switch ON, E-bus alternate feed switch OFF, measure and record main and e-bus voltages. Turn E-Bus alternate feed switch ON and repeat the measurements. Leave B-Bus switch ON turn master switch OFF and repeat the measurements. 4. Why the conflicting amp reading between the Main vs Endurance Bus. I don't know WHAT your amp reading means nor how big the fluctuations are. These are digital instruments with quantitization errors that may well display some tiny wobble in readings even when the actual value is steady. Are the strobes running? This would cause an explain a jumpy ammeter reading. Thanks in advance for any help in this matter We need DATA under various configurations in order to deduce the whether the system is wired as designed and whether or not the components are functioning as expected. Bob . . . ________________________________________________________________________________
Date: Jul 24, 2009
Thanks Bob for the info. My next trip to the airport will begin the process of trouble shooting as you suggest. In regards to this part of the email I made a typo.. Now the questions. 1. Why the addition of the S204-1/diode combo( should ha ve been S704-1 / diode combo) added at the endurance bus switch and will it be of value in my configuration to add it? Don't know what an S204-1 device is . . . and don't know why ANY diode would be wired to the e-bus alternate feed switch. > Date: Thu=2C 23 Jul 2009 13:39:00 -0500 > To: aeroelectric-list(at)matronics.com > From: nuckolls.bob(at)aeroelectric.com > Subject: RE: AeroElectric-List: Voltage Drop / amp ????? > kolls.bob(at)aeroelectric.com> > > I have wired my RV7A with the 13/8 revision L. I did modify it to > include the LR3C > Alternator controller in place of genric Ford Regulator and the AEC9005-1 01 Low > Voltage Module. In looking at the 13/8 revision Q there is an > addition of a S704-1 / > diode combo added to the Main Battery Bus / Endurance Bus / Endurance > Bus Switch. > I also have noted that a AEC9001 Schottky Diode can be used in place > of a bridge diode. > > As I noted in a previous email. 1. When the master switch is closed the v oltage > shoes around 10.8 volts with rock solid amps indication on the Dynon D-12 0 EMS. > > From this I deduce that your Dynon is measuring the e-bus voltage. > Indeed=2C with master switch ON and alternator not running=2C the main > bus would normally be a about 12.5 volts. An expected 0.7 volt drop > in normal feed diode produces an e-bus voltage on the order of > 11.8 volts. > > When the endurance switch is closed the Voltage moves up to 12.8 or 12.9 and > the amps meter begins to fluctuate. Open the Master Switch thus having th e > load go to only the endurance bus side the voltage maintains at 12.8 > to 12.9 volts > and the amps still fluctuates. > > Okay=2C with the alternator OFF the battery-only voltage would > be expected to fall in this range. When you say the amps > "fluctuates" what's the max-min numbers displayed? > > This situation happens with or without the engine running. The > battery maintains charge. > > With the engine running=2C do you turn the alternator ON to > see if it elevates the bus to the nominal 14.2 to 14.6 volts? > > Since I sent the last email I have learned that the bridge diode will > cause a drop in voltage. (Even this 62 year old guy can learn stuff....) =2C > but I would have though it would cause the endurance voltage to be > less on the endurance bus side not the main bus side with the master > switch closed.??????? > > Then the Dynon is NOT monitoring the e-bus? If you close the > e-bus alternate feed switch and the Dynon display goes UP=2C > then it appears that the Dynon is on the e-bus. > > Now the questions. 1. Why the addition of the S204-1/diode combo added at > the endurance bus switch and will it be of value in my configuration to a dded > it? > > Don't know what an S204-1 device is . . . and don't know why > ANY diode would be wired to the e-bus alternate feed switch. > > 2. Would it be of value to added the Schottly in place of the bridge diod e? > > Slightly . . . but from the readings you cite it's not clear > that the Dynon is connected to the Main bus . . . hence SOME > degree of bus votlage suppression would be expected. > > I would think yes if the voltage drop is less and thus give a more accura te > voltage reading. > > The voltmeter is already ACCURATE. It's showing the votlage > at where ever it's attached. I'm guessing the e-bus. So all other > things being normal and functioning to design goals=2C the readings > are expected and normal. > > 3. Why the higher voltage drop on the Main Bus as compared to the > Endurance Bus? > > With engine not running and alternator OFF . . . > > Get out a voltmeter and connect the (-) lead to the battery (-) > or to airframe ground. With master switch ON=2C E-bus alternate > feed switch OFF=2C measure and record main and e-bus voltages. > Turn E-Bus alternate feed switch ON and repeat the measurements. > Leave B-Bus switch ON turn master switch OFF and repeat the > measurements. > > With engine running and alternator ON . . . > > With master switch ON=2C E-bus alternate feed switch OFF=2C > measure and record main and e-bus voltages. Turn E-Bus alternate > feed switch ON and repeat the measurements. Leave B-Bus switch > ON turn master switch OFF and repeat the measurements. > > 4. Why the conflicting amp reading between the Main vs Endurance Bus. > > I don't know WHAT your amp reading means nor how big the > fluctuations are. These are digital instruments with quantitization > errors that may well display some tiny wobble in readings even when > the actual value is steady. Are the strobes running? This would > cause an explain a jumpy ammeter reading. > > Thanks in advance for any help in this matter > > We need DATA under various configurations in order to deduce > the whether the system is wired as designed and whether or > not the components are functioning as expected. > > Bob . . . > > =========== =========== =========== =========== > > > _________________________________________________________________ Windows Live=99 Hotmail=AE: Search=2C add=2C and share the web=92s latest s ports videos. Check it out. http://www.windowslive.com/Online/Hotmail/Campaign/QuickAdd?ocid=TXT_TAGL M_WL_QA_HM_sports_videos_072009&cat=sports ________________________________________________________________________________
Date: Jul 24, 2009
Subject: Re: EV200
At 04:03 PM 7/23/2009, you wrote: > >(some repost here...) I have railed against these Type-70 contactors >for years. But they are almost obsolete. Most electronics >distributors have dropped them from their lines. Really? Who used to carry them that doesn't any more. My preferred sources are still offering them. I think the Cole-Hersey guys are still cranking out their equivalent parts in volume. I think these are the devices that Van's offers. >Problems-- > >1) Low Temperature rating. Only 122F max. You could land at Furnace >Creek in Death Valley in May and take off in October. Maybe. This is >primarily due to the Nylon innards. This is a drop-dead reason to >avoid the part. And hundreds of thousands of el-cheeso contactors have been used in airplanes for decades and for some reason, they never seem to have bubbled up high enough on the "problems list" to have been replaced. The max temperature ratings for cited for the purpose of meeting specified design goals over a products service lifetime. The 122F max does not mean that the critter goes into destructive meltdown at 123, 153 or even 200F. We've had numerous discussions on the List concerning ratings vs. limits vs. service life, on a host of products. The physics of the matter haven't changed. That 122F figure is not a drop-dead reason for doing anything. It's a reason to consider the product's suitability to task using a combination of understanding what the ratings mean -AND- demonstrated field history. >2) Not sealed. Not dust proof, or fuel proof. No, not hermetically sealed. But those cans are steel and the caps are swaged on with hydraulics or some form of rolling press. I've opened dozens (not easy to do) for various reasons and have yet to discover a spec of dust. And how many contactors are expected function as advertised while sloshed with fuel? The venerable Cutler- Hammer 6041 series contactors have been around since the late 30's and are less "sealed" or "fuel proof" than the el-cheeso RPM/W-H/Stancor devices. Yet they are still in current production on many of the Hawker-Beech products. What part would you recommend that HBC consider for upgrading their choice of contactors? I'd be pleased to forward your recommendations to their VP of Engineering. >3) Low interrupt capacity. And what current levels do you propose to interrupt? A battery contactor opens just before shutdown of the airplane when it's parked. How much current does the contactor carry under these conditions? If the service life at full rated current is in the tens of thousands of operations, how much will it go up if you only open it during shutdown of the airplane? 10 Amps? Gee, that's a killer. >4) High hold current---16 ohm coil. Almost one amp. Yes . . . it's "higher" than the EV200, but not nearly one amp. See: http://www.aeroelectric.com/Pictures/Contactors/Battery_Contactor_Temps_2.jpg http://www.aeroelectric.com/Pictures/Contactors/Battery_Contactor_Temps_1.jpg >5) Low hold force. The specifications call for specific orientation. >2G rating? I've not seen that. Please cite the page and paragraph where this is offered. I've done linear g-loading tests on these contactors and was unable to open them at the limits of my centrifuge . . . 10+ G >6) Wildly wrong for B&C to use coil suppression diodes on these. >This causes short lifetimes on the B&C parts. Absolute BS. I've demonstrated many times that the assessment that you and others have offered on the diode suppression issue is without foundation in the simple ideas and physics behind the design and incorporation of these devices. You guys read specs, and then demonstrate your lack of understanding by posting a "doom-n-gloom of the day" article that does NOT demonstrate or explain where I'm wrong. >7) Not designed to open against voltages above 36 volts. (So forget >the B-lead applications) For normal operations, the b-lead contactor is not subjected to more than 36 volts. When operated as recommended, the service life on an el-cheeso contactor in the b-lead is not at risk. However, during an OV runaway, you damn betcha the contactor is expected to open at more than 36 volts . . . and why should we care? If the OV protection system does it's job . . . and just assuming that a couple of high-energy opening events for the contactor is going to trash it . . . do I care? >See: www.stancor.com > >There are better ways to go. Omron's line of automotive contactors (CHEAP) Which OMRON part would you recommend? > and Kilovac's EV200 series, Blue Sea 9012, Gigavac's GX-11. > Expensive but preferred. > >Can you use them? Sure. Should you use them?....not on my bird, Bubela. Your choice are your own and I wouldn't dream of attempting to dissuade you from exercising the right to make them and enjoy the consequences therefrom. But your participation here on the List needs to offer more than your opinions based on poor interpretation of spec sheets, understanding of design goals and knowledge of demonstrated recipes for success. >Better yet, avoid all contactors and use manual switches if you can. > >"Facts do not cease to exist because they are ignored." ABSOLUTELY! . . . so why do you continue to ignore that which I have offered on this topic for years? Make my day, show me where I'm wrong. Bob . . . ________________________________________________________________________________
Date: Jul 24, 2009
At 10:51 AM 7/24/2009, you wrote: >Thanks Bob for the info. My next trip to the airport will begin the >process of trouble shooting as you suggest. > >In regards to this part of the email I made a typo.. > >Now the questions. 1. Why the addition of the S204-1/diode combo( >should have been S704-1 / diode combo) added at >the endurance bus switch and will it be of value in my configuration to add >it? Okay. The normal e-bus feed path diode shown on Figure Z-11 . . . http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z11M.pdf shows an isolation diode between the main bus and the endurance bus. The purpose of this device is to PREVENT the main bus from being powered up from the E-bus during battery-only operations. If you're subscribing to the design goals described for the endurance bus, then this diode is necessary. Do I deduce correctly that this diode is not presently a part of your current configuration? Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jul 24, 2009
>From the discussion, I still haven't seen evidence that either alternator is putting anything on either bus - the voltage reported doesn't correspond with them charging - I think that's what I was saying before. Maybe they are charging, but no values have been reported that would indicate as such. It doesn't sound like you have a design or component selection problem - I think you have all of the right pieces, but maybe not all of the connections are exactly like they should be. I don't think adding a diode here or there is going to make any difference. I suppose it is possible that ended up with a diode some place there shouldn't be - but that means it wasn't put together according to one of the Z-diagrams. >From my experience debugging problems like this, it always helps to have an extra set of eyes (hopefully with a brain behind them) to which I explain how the system is supposed to work. I'll take the wiring diagram (do you have one?) and point to each item on it and then to each item in the real system. Then I point to each wire (connection) on the diagram and then point to each wire in the system. Sometimes I'll even grab each wire and tug on it a little to make sure I can tell where it's routed. Often (the) problem(s) will become apparent well short of going through the whole process. If I uncover something I don't understand I'll make notes about that (sometimes just writing it down helps figure it out), and then find someone I can explain my question to - even if they probably won't have an answer. I'm interested in seeing values for each of Bob's queries. I suspect the solution to the problem may become apparent to you while taking the data. Regards, Matt- > At 10:51 AM 7/24/2009, you wrote: >>Thanks Bob for the info. My next trip to the airport will begin the >>process of trouble shooting as you suggest. >> >>In regards to this part of the email I made a typo.. >> >>Now the questions. 1. Why the addition of the S204-1/diode combo( >>should have been S704-1 / diode combo) added at >>the endurance bus switch and will it be of value in my configuration to >> add >>it? > > > Okay. The normal e-bus feed path diode shown on Figure > Z-11 . . . > > http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z11M.pdf > > > shows an isolation diode between the main bus and > the endurance bus. The purpose of this device is > to PREVENT the main bus from being powered up > from the E-bus during battery-only operations. > > If you're subscribing to the design goals described > for the endurance bus, then this diode is necessary. > Do I deduce correctly that this diode is not presently > a part of your current configuration? > > > Bob . . . > > --------------------------------------- > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > --------------------------------------- > > ________________________________________________________________________________
Subject: ZU-TAF: Belem To U.S. Virgin Islands Has Launched
Date: Jul 24, 2009
I see that Mark and James of ZU-TAF fame have launched from Belem, Brasil and are headed to the U.S. Virgin Islands. These two guys and their airplane are incredible! I'm observing their flight path and their present location on Google Earth per Jay Hyde's earlier posting/weblink, which I'm including below. Thanks, Jay! http://www.airplanefactory.co.za/world/default.asp Simon Ramirez Copyright 2009 ________________________________________________________________________________
From: "Bill Bradburry" <bbradburry(at)bellsouth.net>
Launched
Date: Jul 24, 2009
I watched them as they crossed the Atlantic..21 hours! I think they are nuts! They needed 440 liters of gas to make the crossing. They were carrying 450 liters! B2 _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of S. Ramirez Sent: Friday, July 24, 2009 7:19 PM Subject: [Bulk] AeroElectric-List: ZU-TAF: Belem To U.S. Virgin Islands Has Launched I see that Mark and James of ZU-TAF fame have launched from Belem, Brasil and are headed to the U.S. Virgin Islands. These two guys and their airplane are incredible! I'm observing their flight path and their present location on Google Earth per Jay Hyde's earlier posting/weblink, which I'm including below. Thanks, Jay! http://www.airplanefactory.co.za/world/default.asp Simon Ramirez Copyright 2009 ________________________________________________________________________________
Subject: Re: Icom A-210 intercom
Date: Jul 24, 2009
Icom A210 receiving and transmitting just fine but the bloody intercom won't co-operate at all.I must be missing something in the menu setup so any help would be appreciated. Cheers Read this topic online here: http://forums.matronics.com/viewtopic.php?p=254649#254649 ________________________________________________________________________________
Date: Jul 25, 2009
Subject: Voltage Drops/Amps, Cabbages and Kings
At 06:16 PM 7/24/2009, you wrote: > > >From my experience debugging problems like this, it always helps to have >an extra set of eyes (hopefully with a brain behind them) to which I >explain how the system is supposed to work. This is a CORE COMPONENT of every successful skunk-werks venture. While privileged to be an employee of the targets business unit at Beech/RAC/HBC, every time a program or portion of a program wan in trouble, a meeting was called. In some organizations, such meetings are uncomfortable events entered with foreboding. The mind-set of many folks walking in was to figure out ways to avoid blame. If one leaves with less stress, it's probably because they were not found at fault and some other poor sap was taking the hit. My leaders and colleagues both understood recipes for success demonstrated many times in the past by the likes of Kettering, Johnson, Kay, Beech, Lear, et. als. They understood that it's a rare mind that can grasp the totality of a program and that the intellectual whole is greater than the sum of its parts. Meetings at the Beech targets unit were always something to be welcomed . . . anyone walking in with a problem walked out with new insight, additional support, a map for future learning. Everyone walked out with a sense of accomplishment. This isn't about, positions of hierarchy or competition. It's about the joy of finding things out (being a good student) and then sharing that understanding with others (being a good teacher). We were all diligent students of the ideas demonstrated by participants of the original Skunk Works. I suggest that we would do well to bring the same goals to the activity here on the List. Our skunk-werks isn't a single facility, it's thousands of facilities scattered all over the planet. We're not working one momentous task to be delivered in 180 days, we have thousands of projects that will take years. But the task is the same. Produce machines that perform to design goals operated by pilots who understand how those goals were selected, achieved and maintained. Meetings at the Matronics List Servers should always be something to be welcomed . . . anyone posting a problem or sharing an idea should look forward to achieving new insight, additional support for a problem, and map for future learning. It would be well if everyone who takes the time to participate or simply observe happenings on the Lists walk away with a sense of accomplishment. Our teachers were not carving a place in history for themselves, they were striving to share their understanding with as many folks as possible. They knew that the more times good ideas and recipes for success are shared, the more valuable they become. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jul 25, 2009
At 10:50 PM 7/24/2009, you wrote: > >Icom A210 receiving and transmitting just fine but the bloody >intercom won't co-operate at all.I must be missing something in the >menu setup so any help would be appreciated. Cheers Can you describe your observations of symptoms? "Won't cooperate" as a symptom does not bring ideas to mind. The intercom function of most of the small radios is a "hot mic" activated by a push to talk button that simply engages the transmitter's side tone (listen to yourself) feature. Hence no squelch adjustment for voice activated opening of the signal channel . . . and no separate volume control for intercom versus receiver. This is an exceedingly minimalist (but very robust) approach to an intercom function. However, it is nothing like that which is found in most airplanes. Perhaps it's working as intended but you're expecting something different? Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Launched
Date: Jul 25, 2009
I see on Google Earth that they've landed at H.S. Truman airport in the U.S. Virgin Islands. Never mind what happened crossing the Atlantic. That's ancient history! :) Simon Ramirez Copyright 2009 From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bill Bradburry Sent: Friday, July 24, 2009 8:52 PM Subject: RE: [Bulk] AeroElectric-List: ZU-TAF: Belem To U.S. Virgin Islands Has Launched I watched them as they crossed the Atlantic..21 hours! I think they are nuts! They needed 440 liters of gas to make the crossing. They were carrying 450 liters! B2 _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of S. Ramirez Sent: Friday, July 24, 2009 7:19 PM Subject: [Bulk] AeroElectric-List: ZU-TAF: Belem To U.S. Virgin Islands Has Launched I see that Mark and James of ZU-TAF fame have launched from Belem, Brasil and are headed to the U.S. Virgin Islands. These two guys and their airplane are incredible! I'm observing their flight path and their present location on Google Earth per Jay Hyde's earlier posting/weblink, which I'm including below. Thanks, Jay! http://www.airplanefactory.co.za/world/default.asp Simon Ramirez Copyright 2009 ________________________________________________________________________________
Date: Jul 25, 2009
Here is the installation diagram and operating manual http://www.icomamerica.com/en/products/avionics/panelmount/a210/default.aspx On Sat, Jul 25, 2009 at 8:48 AM, Robert L. Nuckolls, III< nuckolls.bob(at)aeroelectric.com> wrote: > > > At 10:50 PM 7/24/2009, you wrote: >> >> >> >> Icom A210 receiving and transmitting just fine but the bloody intercom >> won't co-operate at all.I must be missing something in the menu setup so any >> help would be appreciated. Cheers > > Can you describe your observations of symptoms? > "Won't cooperate" as a symptom does not bring ideas > to mind. > > The intercom function of most of the small radios > is a "hot mic" activated by a push to talk button > that simply engages the transmitter's side tone > (listen to yourself) feature. Hence no squelch > adjustment for voice activated opening of the > signal channel . . . and no separate volume control > for intercom versus receiver. This is an exceedingly > minimalist (but very robust) approach to an intercom > function. However, it is nothing like that which is found > in most airplanes. Perhaps it's working as intended > but you're expecting something different? > > > Bob . . . > > --------------------------------------- > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > --------------------------------------- > > ________________________________________________________________________________
Date: Jul 25, 2009
At 09:09 AM 7/25/2009, you wrote: >Here is the installation diagram and operating manual ><http://www.icomamerica.com/en/products/avionics/panelmount/a210/default.aspx>http://www.icomamerica.com/en/products/avionics/panelmount/a210/default.aspx > Aha! This is more to this little critter than I realized. I might have expected this from Icom. I'll have to study up. Thanks for the heads-up. In the mean time "Thruster87" might we know your name along with a better description of the problems you're having? Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Subject: RE: Lee KR-2 System Architecture
Date: Jul 25, 2009
Lectric Bob, You said: <> Are you still praying, or did you decide to exercise my design of using z14 for the engine (electrionic ignition, fuel pumps alternators and batteries) and z13 (main bus and e-bus) for everything else? Regards, Bob Lee N52BL KR2 Suwanee, GA USA 92% done only 67% to go! ________________________________________________________________________________
Date: Jul 25, 2009
Hi Bob,I was expecting it to just activate [intercom] without a separate button,so one just speaks and the other person hears you.Pressing the PTT it transmits OK and the passenger can also hear what you say and both can hear just fine the incoming calls.I have not tried connecting the intercom switch to pin 10 Intercom IN and joining to pin 9 PTT + as I understand it,it should not require this switch to operate as a VOX intercom. Cheers Alan [610xl builder almost ready to start taxi run testing] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=254719#254719 ________________________________________________________________________________
Date: Jul 25, 2009
At 03:59 PM 7/25/2009, you wrote: > >Lectric Bob, > >You said: > >< for a few days . . .>> > >Are you still praying, or did you decide to exercise my design of using z14 >for the engine (electrionic ignition, fuel pumps alternators and batteries) >and z13 (main bus and e-bus) for everything else? I've got a plan. The kids are down for the weekend and my grandson is looking for a lot of grandpa-time. But I'll do a system for Corvair engines. It will become Z-9. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jul 27, 2009
Subject: Crossfeed
I have an all electric plane and have attempted to emulate Z19-RB. Both batteries are the same size, but I am intending on starting on the main battery only. My alternator-out load analysis shows around 17 amps to keep it in the air, though I think I can drop that to 10. The "keep the engine running" components may run off either bus, but the endurance bus is just connected to the main. Could I install a crossfeed switch between the main and engine batteries, without a contactor? It would allow me to use the engine battery for the endurance bus, to supplement the main battery. That would also allow me to simultaneously charge both batteries without engaging the engine battery contactor. I'll try and attach a pdf. BTW, after a year and a half, I am somewhat back in the air, though many bugs remain. Sam www.samhoskins.blogspot.com ________________________________________________________________________________
Date: Jul 27, 2009
At 05:00 PM 7/25/2009, you wrote: > >Hi Bob,I was expecting it to just activate [intercom] without a >separate button,so one just speaks and the other person hears >you.Pressing the PTT it transmits OK and the passenger can also hear >what you say and both can hear just fine the incoming calls.I have >not tried connecting the intercom switch to pin 10 Intercom IN and >joining to pin 9 PTT + as I understand it,it should not require >this switch to operate as a VOX intercom. Cheers Alan [610xl builder >almost ready to start taxi run testing] After reading through the available installation data on the Icom IC-A210 I've discovered that the 210 is a head-n-shoulders upgrade from the 200. Most noteworthy are extensive audio management features with functions and gains set by software using a front panel menu system. Another interesting feature is what appears to be rear connector plate options. The stock input/output connector plate works with the same Molex wires-to- ecb style of harnes connector . . . same as the A200. The A210 install kit comes with an "MB-113" adapter module to convert the legacy molex connnector interface Emacs! To the more robust Dsub 15 connector. Emacs! If we look at the A210 installation data . . . http://tinyurl.com/nxw5jm . . . we see that half of the 30 wires available in the Molex pin-out are available in Dsub pinout and in different combinations. For example, only 2 of the 6 power/gnd connections are available in the Dsub. The Molex doesn't offer the RS232 GPS interface option. The Molex connection offers 3 aux audio inputs, the Dsub offers only one. Certainly, the Dsub pinouts offer enough features to accomplish a perfectly useful installation in an airplane. Getting back to the intercom issue, we see that there's a raft of menu driven audio performance setup features. Further, pin 10 (intercom enable) in the Molex connector does not appear on the Dsub connector. Admittedly, with out a schematic of the MB-113 adapter, we don't know if Molex 10 is simply ignored or is tied to ground by the adapter. Further, functionality of the intercom ground to activate connection is not explained. It's illustrated in the Molex wiring as a useful thing to attache to an intercom PTT button, but in the user's manual . . . http://tinyurl.com/nsvye4 the use of this push button is not explained. However, on the description of panel controls we see that item (1) DUAL SWITCH has a time-based function (hold for 2+ seconds) to turn the intercom function ON or OFF. It would be nice if the manuals were more complete in this regard. I'll keep an eye open for the service manual on this radio. Schematics are VERY useful in figuring out how things work. Does anyone on the List have an A210 installed and working who can help Alan sort through this radio's intercom functionality? Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jul 27, 2009
I have installed one of these (A210) in conjunction with a PM1000II intercom (from PS-Engineering) on a 4 seater aircraft where there I need more than 2 intercom stations. It was a bit of nightmare; I couldn't get the two systems working- the headphones worked fine but the mic circuits wouldn't work properly (I am still busy with that project). Recently I had to install the PM1000II on the Sling (that little aircraft that is making its way between the Virgin Islands and Florida as I write!) where it interfaced to a Garmin SL30 nav/ comm radio. This time I called PS themselves and checked up on a few things. One of the things that I discovered was that one must not put an 'aux PTT' in the same way that they call for 'aux mic and phone jacks'. I have yet to test the A210/ PM1000 system after removing this item but I can tell you that the SL30/ PM1000 combination worked just fine when I left the 'aux PTT' out- so perhaps that's one of the problems? As a matter of interest, PS Eng told me that the PTT's are hard wired through so that, even if (in the unlikely event of failure, ladies and gentleman.) there is a failure with PM1000 the PTT's will still work. Jay ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Jay Hyde HH Enterprises Aircraft Manufacture, Engineering and Flying jay(at)horriblehyde.com Mobile phone: 083 300 8675 International: +27 83 300 8675 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: 27 July 2009 06:06 PM Subject: Re: AeroElectric-List: Re: Icom A-210 intercom At 05:00 PM 7/25/2009, you wrote: Hi Bob,I was expecting it to just activate [intercom] without a separate button,so one just speaks and the other person hears you.Pressing the PTT it transmits OK and the passenger can also hear what you say and both can hear just fine the incoming calls.I have not tried connecting the intercom switch to pin 10 Intercom IN and joining to pin 9 PTT + as I understand it,it should not require this switch to operate as a VOX intercom. Cheers Alan [610xl builder almost ready to start taxi run testing] After reading through the available installation data on the Icom IC-A210 I've discovered that the 210 is a head-n-shoulders upgrade from the 200. Most noteworthy are extensive audio management features with functions and gains set by software using a front panel menu system. Another interesting feature is what appears to be rear connector plate options. The stock input/output connector plate works with the same Molex wires-to- ecb style of harnes connector . . . same as the A200. The A210 install kit comes with an "MB-113" adapter module to convert the legacy molex connnector interface Emacs! To the more robust Dsub 15 connector. Emacs! If we look at the A210 installation data . . . http://tinyurl.com/nxw5jm . . . we see that half of the 30 wires available in the Molex pin-out are available in Dsub pinout and in different combinations. For example, only 2 of the 6 power/gnd connections are available in the Dsub. The Molex doesn't offer the RS232 GPS interface option. The Molex connection offers 3 aux audio inputs, the Dsub offers only one. Certainly, the Dsub pinouts offer enough features to accomplish a perfectly useful installation in an airplane. Getting back to the intercom issue, we see that there's a raft of menu driven audio performance setup features. Further, pin 10 (intercom enable) in the Molex connector does not appear on the Dsub connector. Admittedly, with out a schematic of the MB-113 adapter, we don't know if Molex 10 is simply ignored or is tied to ground by the adapter. Further, functionality of the intercom ground to activate connection is not explained. It's illustrated in the Molex wiring as a useful thing to attache to an intercom PTT button, but in the user's manual . . . http://tinyurl.com/nsvye4 the use of this push button is not explained. However, on the description of panel controls we see that item (1) DUAL SWITCH has a time-based function (hold for 2+ seconds) to turn the intercom function ON or OFF. It would be nice if the manuals were more complete in this regard. I'll keep an eye open for the service manual on this radio. Schematics are VERY useful in figuring out how things work. Does anyone on the List have an A210 installed and working who can help Alan sort through this radio's intercom functionality? Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Subject: Icom 200
Date: Jul 27, 2009
--- MIME Errors - No Plain-Text Section Found --- A message with no text/plain MIME section was received. The entire body of the message was removed. Please resend the email using Plain Text formatting. HOTMAIL is notorious for only including an HTML section in their client's default configuration. If you're using HOTMAIL, please see your email application's settings and switch to a default mail option that uses "Plain Text". --- MIME Errors No Plain-Text Section Found --- ________________________________________________________________________________
Subject: Icom 200
Date: Jul 28, 2009
Date: Jul 27, 2009
I did the 2 second push on the Dual button and the screen shows the ics as on and still no go.Spoke to Icom techi with whom we went thru the menu but still no go . Might look at putting a intercom in. Cheers Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=254978#254978 ________________________________________________________________________________
Subject: That magic moment when everything comes together.....
Date: Jul 28, 2009
Just wanted to post and say that my X-Air Hanuman (French microlight 79II) finally flew this weekend. I adopted Bob's Z-20 for the Jabiru installation and apart from wiring the mags the wrong way round (I'm still learning!) everything else works perfectly. I just wanted to say a big thank you to Bob and everyone else on this list - I REALLY couldn't have done it without all of your considerable expertise and willingness to help a rookie. A short, but very sweet video is here.... http://www.youtube.com/watch?v=BTSv4sqDxdQ Ian Read this topic online here: http://forums.matronics.com/viewtopic.php?p=255001#255001 ________________________________________________________________________________
Subject: ROCHESTER FUEL LEVEL INDICATOR WIRING
Date: Jul 28, 2009
The indicator has 3 posts on the back marked SEN, middle not marked and IGN which goes to which.Didn't want to fry anything. Cheers Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=255035#255035 ________________________________________________________________________________
Subject: Switch Failures
Date: Jul 28, 2009
Approximately 100 hours ago, I replaced all of my Carling toggle switches with Honeywell/Microswitch switches in my RV-9A. I had experienced multiple failures with the Carling switches in the first 150 hours due to loose terminals and overheating leading to charred terminals and wiring. There is a long thread on this topic, including some failure analysis by Bob. At this point, I have had no additional switch failures after switching to the Honeywell switches. At the time, Bob postulated that the lack of decoupling loops in the wiring may have contributed. I was not so sure, so I made no other changes other than replacing the switches. While not conclusive, I would say the root cause of failure was the loose riveted terminals on the Carling Switches. The lack of decoupling loops in the wiring may have contributed, but it appears that a higher quality switch is an effective solution. I had two failures on the Strobe circuit, one on the Landing light circuit and one on the progressive-transfer Master Switch in the first 150 hours with the Carling Switches. So, if anyone thinks that this is just a characteristic of our OBAM aircraft being built with "substandard" components, look at this: ====================== FAA Issues Airworthiness Bulletin For Cessna GA Aircraft Tue, 28 Jul '09 SAIB Affects 100, 200, 300 Series Cessna Aircraft The FAA has issued a Special Airworthiness Information Bulletin (SAIB) to advise pilots and owners of an airworthiness concern on mandatory replacement intervals of Cessna Landing Light, Beacon Light, and Taxi Light switches on Cessna 100, 200, and 300 series airplanes, specified in Cessna service bulletins MEB09-3 and SEB09-6 dated May 11, 2009. Cessna 100, 200, and 300 series airplanes utilize switches in the Landing Light, Beacon Light, and Taxi Light circuits that have been reported failing in the field causing overheating and smoke in the cockpit. There have been reports of burned insulation on the wiring terminals to the switch. On at least one occasion, there was a small fire in the cockpit. The failure in these applications can be attributed to contact erosion leading to irregular arcing and eventual failure of the switch. The contact erosion has been shown to occur after approximately 4,000 cycles of operation. Cessna service bulletins SEB09-6 and MEB09-3, initial release, dated May 11, 2009, specify the following: .An inspection to determine time-in-service for the switches. .Replacement of switches that have been in service for four or more years with the month and year of the installation written on the new replacement switch. .The month and year of the initial installation written on switches that have been in service for less than four years. The FAA recommends that owners, operators, and maintenance technicians act on the above-referenced service bulletins within the next 400 hours of operation, 12 months, or the next annual inspection, whichever comes first. ====== Vern Little Vx Aviation ----- Original Message ----- From: "Thruster87" <alania(at)optusnet.com.au> Sent: Monday, July 27, 2009 11:05 PM Subject: AeroElectric-List: Re: Icom A-210 intercom > > > I did the 2 second push on the Dual button and the screen shows the ics as > on and still no go.Spoke to Icom techi with whom we went thru the menu but > still no go . Might look at putting a intercom in. Cheers Alan > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=254978#254978 > > > ________________________________________________________________________________
From: "David & Elaine Lamphere" <dalamphere(at)comcast.net>
Subject: No Sidetone
Date: Jul 29, 2009
I have an interesting problem with my newly installed King KX125. While everything seems to be working correctly and I am clearly received when I transmit, there is no sidetone during transmission (I do not hear myself in the head set). I have eliminated the intercom completely, using an older handheld mike and phones only - same symptoms - rx clear, tx clear, no sidetone. Could it be that I have not installed some jumper not shown?? Or is there a pot somewhere I need to tweek? I have attached the section of the schematic that pertains to this. I do not have any connections to pin 501-16 nor do I have a switch on the mike jack as shown. The applicable notes refer to switching 100-H to 501-16 and opening up 100-8 to prevent your audio from being transmitted. Any clues or hints as to what I have missed doing?? ________________________________________________________________________________
Date: Jul 29, 2009
Subject: Re: Switch Failures
Vern Can you post the product number for the Honeywell switches? Peter On Wed, Jul 29, 2009 at 1:22 AM, Vern Little wrote: > rv-9a-online(at)telus.net> > > Approximately 100 hours ago, I replaced all of my Carling toggle switches > with Honeywell/Microswitch switches in my RV-9A. I had experienced > multiple failures with the Carling switches in the first 150 hours due to > loose terminals and overheating leading to charred terminals and wiring. > There is a long thread on this topic, including some failure analysis by > Bob. > > At this point, I have had no additional switch failures after switching to > the Honeywell switches. At the time, Bob postulated that the lack of > decoupling loops in the wiring may have contributed. I was not so sure, so > I made no other changes other than replacing the switches. > > While not conclusive, I would say the root cause of failure was the loose > riveted terminals on the Carling Switches. The lack of decoupling loops in > the wiring may have contributed, but it appears that a higher quality switch > is an effective solution. > > I had two failures on the Strobe circuit, one on the Landing light circuit > and one on the progressive-transfer Master Switch in the first 150 hours > with the Carling Switches. > > So, if anyone thinks that this is just a characteristic of our OBAM > aircraft being built with "substandard" components, look at this: > > ====================== > > FAA Issues Airworthiness Bulletin For Cessna GA Aircraft > Tue, 28 Jul '09 > > SAIB Affects 100, 200, 300 Series Cessna Aircraft > The FAA has issued a Special Airworthiness Information Bulletin (SAIB) to > advise pilots and owners of an airworthiness concern on mandatory > replacement intervals of Cessna Landing Light, Beacon Light, and Taxi Light > switches on Cessna 100, 200, and 300 series airplanes, specified in Cessna > service bulletins MEB09-3 and SEB09-6 dated May 11, 2009. > > Cessna 100, 200, and 300 series airplanes utilize switches in the Landing > Light, Beacon Light, and Taxi Light circuits that have been reported failing > in the field causing overheating and smoke in the cockpit. There have been > reports of burned insulation on the wiring terminals to the switch. On at > least one occasion, there was a small fire in the cockpit. The failure in > these applications can be attributed to contact erosion leading to irregular > arcing and eventual failure of the switch. The contact erosion has been > shown to occur after approximately 4,000 cycles of operation. > > Cessna service bulletins SEB09-6 and MEB09-3, initial release, dated May > 11, 2009, specify the following: > > .An inspection to determine time-in-service for the switches. > .Replacement of switches that have been in service for four or more years > with the month and year of the installation written on the new replacement > switch. > .The month and year of the initial installation written on switches that > have been in service for less than four years. > The FAA recommends that owners, operators, and maintenance technicians act > on the above-referenced service bulletins within the next 400 hours of > operation, 12 months, or the next annual inspection, whichever comes first. > > ====== > Vern Little > Vx Aviation > > > ----- Original Message ----- From: "Thruster87" <alania(at)optusnet.com.au> > To: > Sent: Monday, July 27, 2009 11:05 PM > Subject: AeroElectric-List: Re: Icom A-210 intercom > > >> alania(at)optusnet.com.au> >> >> I did the 2 second push on the Dual button and the screen shows the ics as >> on and still no go.Spoke to Icom techi with whom we went thru the menu but >> still no go . Might look at putting a intercom in. Cheers Alan >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=254978#254978 >> >> >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
From: "nuckollsr" <bob.nuckolls(at)aeroelectric.com>
Date: Jul 29, 2009
"The failure in these applications can be attributed to contact erosion leading to irregular arcing and eventual failure of the switch. The contact erosion has been shown to occur after approximately 4,000 cycles of operation." I'm away from my office for a couple of days. I'll have a more extensive response when I get back "to the hills". It would be interesting/enlightening to see the failed switches. For all of the Carling failures I examined, there was no evidence of contact erosion. In fact, all failure examples displayed evidence of heating effects that began away from the contacts . . . most notably at the riveted joins for the fast-on tabs. It would also be interesting to know how the problem aircraft were flown. I've flown dozens of Cessna aircraft fitted with switches where the factory original switches were 40+ years old. I also recall testing the the lab at Cessna East (single engine) on the Carling rocker switches were tens of thousands of cycles were impressed on the switches before they were deemed suited to the task. I suspect that root cause for this rash of failures is yet to be deduced and understood. Action taken by the regulators was predictable. Write an $AD$ that demands replacing a $2 switch with the one that's been re-labeled with Cessna's $Standard-Part$ number. I don't know if any of the gray-beards are still working out there. I'll have to call around and see what I can discover. Bob . . . Read this topic online here: http://forums.matronics.com/viewtopic.php?p=255100#255100 ________________________________________________________________________________
Date: Jul 29, 2009
Subject: Re: AeroElectric-List Digest: 6 Msgs - 07/27/09
Can someone enlighten me what the word "Emacs" means? J=FCrgen Amtmann On Mon, Jul 27, 2009 at 11:55 PM, AeroElectric-List Digest Server < aeroelectric-list(at)matronics.com> wrote: > * > > ======================== > Online Versions of Today's List Digest Archive > ======================== > > Today's complete AeroElectric-List Digest can also be found in either of > the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the AeroElectric-List Digest and can be viewed with a generic text > editor > such as Notepad or with a web browser. > > HTML Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html& Chapter 09-07-27&Archive=AeroElectric > > Text Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&C hapter 09-07-27&Archive=AeroElectric > > > ======================== ======================= > EMail Version of Today's List Digest Archive > ======================== ======================= > > > ---------------------------------------------------------- > AeroElectric-List Digest Archive > --- > Total Messages Posted Mon 07/27/09: 6 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 08:56 AM - Crossfeed (Sam Hoskins) > 2. 09:07 AM - Re: Re: Icom A-210 intercom (Robert L. Nuckolls, III) > 3. 09:59 AM - Re: Re: Icom A-210 intercom (Jay Hyde) > 4. 01:27 PM - Icom 200 (luigit(at)freemail.it) > 5. 10:23 PM - Icom 200 (luigit(at)freemail.it) > 6. 11:07 PM - Re: Icom A-210 intercom (Thruster87) > > > ________________________________ Message 1 > _____________________________________ > > > Subject: AeroElectric-List: Crossfeed > From: Sam Hoskins <sam.hoskins(at)gmail.com> > > I have an all electric plane and have attempted to emulate Z19-RB. > > Both batteries are the same size, but I am intending on starting on the > main > battery only. My alternator-out load analysis shows around 17 amps to ke ep > it in the air, though I think I can drop that to 10. > > The "keep the engine running" components may run off either bus, but the > endurance bus is just connected to the main. > > Could I install a crossfeed switch between the main and engine batteries, > without a contactor? It would allow me to use the engine battery for the > endurance bus, to supplement the main battery. That would also allow me to > simultaneously charge both batteries without engaging the engine battery > contactor. > > I'll try and attach a pdf. > > BTW, after a year and a half, I am somewhat back in the air, though many > bugs remain. > > Sam > www.samhoskins.blogspot.com > > ________________________________ Message 2 > _____________________________________ > > > From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> > Subject: Re: AeroElectric-List: Re: Icom A-210 intercom > > At 05:00 PM 7/25/2009, you wrote: > > > >Hi Bob,I was expecting it to just activate [intercom] without a > >separate button,so one just speaks and the other person hears > >you.Pressing the PTT it transmits OK and the passenger can also hear > >what you say and both can hear just fine the incoming calls.I have > >not tried connecting the intercom switch to pin 10 Intercom IN and > >joining to pin 9 PTT + as I understand it,it should not require > >this switch to operate as a VOX intercom. Cheers Alan [610xl builder > >almost ready to start taxi run testing] > > After reading through the available installation data > on the Icom IC-A210 I've discovered that the 210 is > a head-n-shoulders upgrade from the 200. Most noteworthy > are extensive audio management features with functions > and gains set by software using a front panel menu > system. > > Another interesting feature is what appears to be > rear connector plate options. The stock input/output > connector plate works with the same Molex wires-to- > ecb style of harnes connector . . . same as the A200. > The A210 install kit comes with an "MB-113" adapter > module to convert the legacy molex connnector interface > > Emacs! > > > To the more robust Dsub 15 connector. > Emacs! > > > If we look at the A210 installation data . . . > > http://tinyurl.com/nxw5jm > > . . . we see that half of the 30 wires available > in the Molex pin-out are available in Dsub > pinout and in different combinations. For example, > only 2 of the 6 power/gnd connections are available > in the Dsub. The Molex doesn't offer the RS232 > GPS interface option. The Molex connection offers > 3 aux audio inputs, the Dsub offers only one. > > Certainly, the Dsub pinouts offer enough > features to accomplish a perfectly useful installation > in an airplane. > > Getting back to the intercom issue, we see that > there's a raft of menu driven audio performance > setup features. Further, pin 10 (intercom enable) > in the Molex connector does not appear on the > Dsub connector. Admittedly, with out a schematic > of the MB-113 adapter, we don't know if Molex 10 > is simply ignored or is tied to ground by the > adapter. Further, functionality of the intercom > ground to activate connection is not explained. It's > illustrated in the Molex wiring as a useful thing > to attache to an intercom PTT button, but in the > user's manual . . . > > http://tinyurl.com/nsvye4 > > the use of this push button is not explained. However, > on the description of panel controls we see that > item (1) DUAL SWITCH has a time-based function > (hold for 2+ seconds) to turn the intercom function > ON or OFF. > > It would be nice if the manuals were more complete in > this regard. I'll keep an eye open for the service > manual on this radio. Schematics are VERY useful in > figuring out how things work. Does anyone on the List > have an A210 installed and working who can help Alan > sort through this radio's intercom functionality? > > > Bob . . . > > --------------------------------------- > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > --------------------------------------- > > > ________________________________ Message 3 > _____________________________________ > > > From: "Jay Hyde" <jay(at)horriblehyde.com> > Subject: RE: AeroElectric-List: Re: Icom A-210 intercom > > I have installed one of these (A210) in conjunction with a PM1000II > intercom > (from PS-Engineering) on a 4 seater aircraft where there I need more than 2 > intercom stations. It was a bit of nightmare; I couldn't get the two > systems working- the headphones worked fine but the mic circuits wouldn't > work properly (I am still busy with that project). Recently I had to > install the PM1000II on the Sling (that little aircraft that is making it s > way between the Virgin Islands and Florida as I write!) where it interfac ed > to a Garmin SL30 nav/ comm radio. > > > This time I called PS themselves and checked up on a few things. One of > the > things that I discovered was that one must not put an 'aux PTT' in the sa me > way that they call for 'aux mic and phone jacks'. I have yet to test the > A210/ PM1000 system after removing this item but I can tell you that the > SL30/ PM1000 combination worked just fine when I left the 'aux PTT' out- so > perhaps that's one of the problems? > > > As a matter of interest, PS Eng told me that the PTT's are hard wired > through so that, even if (in the unlikely event of failure, ladies and > gentleman.) there is a failure with PM1000 the PTT's will still work. > > > Jay > > > ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ > > Jay Hyde > > HH Enterprises > > Aircraft Manufacture, Engineering and Flying > > jay(at)horriblehyde.com > > Mobile phone: 083 300 8675 > > International: +27 83 300 8675 > > ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ > > _____ > > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert > L. > Nuckolls, III > Sent: 27 July 2009 06:06 PM > Subject: Re: AeroElectric-List: Re: Icom A-210 intercom > > > At 05:00 PM 7/25/2009, you wrote: > > > > > Hi Bob,I was expecting it to just activate [intercom] without a separate > button,so one just speaks and the other person hears you.Pressing the PTT > it > transmits OK and the passenger can also hear what you say and both can he ar > just fine the incoming calls.I have not tried connecting the intercom > switch > to pin 10 Intercom IN and joining to pin 9 PTT + as I understand it,it > should not require this switch to operate as a VOX intercom. Cheers Alan > [610xl builder almost ready to start taxi run testing] > > > After reading through the available installation data > on the Icom IC-A210 I've discovered that the 210 is > a head-n-shoulders upgrade from the 200. Most noteworthy > are extensive audio management features with functions > and gains set by software using a front panel menu > system. > > Another interesting feature is what appears to be > rear connector plate options. The stock input/output > connector plate works with the same Molex wires-to- > ecb style of harnes connector . . . same as the A200. > The A210 install kit comes with an "MB-113" adapter > module to convert the legacy molex connnector interface > > Emacs! > > > To the more robust Dsub 15 connector. > Emacs! > > If we look at the A210 installation data . . . > > http://tinyurl.com/nxw5jm > > . . . we see that half of the 30 wires available > in the Molex pin-out are available in Dsub > pinout and in different combinations. For example, > only 2 of the 6 power/gnd connections are available > in the Dsub. The Molex doesn't offer the RS232 > GPS interface option. The Molex connection offers > 3 aux audio inputs, the Dsub offers only one. > > Certainly, the Dsub pinouts offer enough > features to accomplish a perfectly useful installation > in an airplane. > > Getting back to the intercom issue, we see that > there's a raft of menu driven audio performance > setup features. Further, pin 10 (intercom enable) > in the Molex connector does not appear on the > Dsub connector. Admittedly, with out a schematic > of the MB-113 adapter, we don't know if Molex 10 > is simply ignored or is tied to ground by the > adapter. Further, functionality of the intercom > ground to activate connection is not explained. It's > illustrated in the Molex wiring as a useful thing > to attache to an intercom PTT button, but in the > user's manual . . . > > http://tinyurl.com/nsvye4 > > the use of this push button is not explained. However, > on the description of panel controls we see that > item (1) DUAL SWITCH has a time-based function > (hold for 2+ seconds) to turn the intercom function > ON or OFF. > > It would be nice if the manuals were more complete in > this regard. I'll keep an eye open for the service > manual on this radio. Schematics are VERY useful in > figuring out how things work. Does anyone on the List > have an A210 installed and working who can help Alan > sort through this radio's intercom functionality? > > > Bob . . . > > --------------------------------------- > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > --------------------------------------- > > > ________________________________ Message 4 > _____________________________________ > > > From: luigit(at)freemail.it > Subject: AeroElectric-List: Icom 200 > > --- MIME Errors - No Plain-Text Section Found --- > > A message with no text/plain MIME section was received. > The entire body of the message was removed. Please > resend the email using Plain Text formatting. > > HOTMAIL is notorious for only including an HTML section > in their client's default configuration. If you're using > HOTMAIL, please see your email application's settings > and switch to a default mail option that uses "Plain Text". > > --- MIME Errors No Plain-Text Section Found --- > > > ________________________________ Message 5 > _____________________________________ > > > From: luigit(at)freemail.it > Subject: AeroElectric-List: Icom 200 > > --- MIME Errors - No Plain-Text Section Found --- > > A message with no text/plain MIME section was received. > The entire body of the message was removed. Please > resend the email using Plain Text formatting. > > HOTMAIL is notorious for only including an HTML section > in their client's default configuration. If you're using > HOTMAIL, please see your email application's settings > and switch to a default mail option that uses "Plain Text". > > --- MIME Errors No Plain-Text Section Found --- > > > ________________________________ Message 6 > _____________________________________ > > > Subject: AeroElectric-List: Re: Icom A-210 intercom > From: "Thruster87" <alania(at)optusnet.com.au> > > > I did the 2 second push on the Dual button and the screen shows the ics a s > on and > still no go.Spoke to Icom techi with whom we went thru the menu but still > no > go . Might look at putting a intercom in. Cheers Alan > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=254978#254978 > > =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Jul 29, 2009
On 07/29/2009 11:56 AM, Janet Amtmann wrote: > Can someone enlighten me what the word "Emacs" means? http://www.gnu.org/software/emacs/ "GNU Emacs is an extensible, customizable text editorand more." fyi -Dj -- Dj Merrill - N1JOV Glastar Sportsman 2+2 Builder #7118 N421DJ http://deej.net/sportsman/ "Many things that are unexplainable happen during the construction of an airplane." --Dave Prizio, 30 Aug 2005 ________________________________________________________________________________
Date: Jul 29, 2009
On Wed Jul 29 11:56:59 2009, Janet Amtmann wrote : >Can someone enlighten me what the word "Emacs" means? Emacs is the name of a very popular (in some circles) text editor. It was authored in 1976 by Richard Stallman, initially together with Guy L. Steele, Jr. It is most often found on Unix/Linux type systems, but has been ported to other environments as well. For more information that most non-geeks would care to know about Emacs see the following URLs : http://en.wikipedia.org/wiki/Emacs http://www.gnu.org/software/emacs/ Why Bob's posts seem to regularly include the "Emacs!" exclaimation is a mystery I've long puzzled over. -- Dwight ________________________________________________________________________________
Date: Jul 29, 2009
Great question! I've been meaning to ask Bob about that for a while.. To me, emacs is a text editing program originally used on computers running Unix OS.. I use it at work. I wonder if Bob edits his email using emacs and maybe these sneak into his messages. Sometimes it seems like links he intends to post get sub'ed with "Emacs!". If it's not Bob, maybe it's Dralle.. Matt- > Can someone enlighten me what the word "Emacs" means? > Jrgen Amtmann > > On Mon, Jul 27, 2009 at 11:55 PM, AeroElectric-List Digest Server < > aeroelectric-list(at)matronics.com> wrote: > >> * >> >> ======================== >> Online Versions of Today's List Digest Archive >> ======================== >> >> Today's complete AeroElectric-List Digest can also be found in either of >> the >> two Web Links listed below. The .html file includes the Digest >> formatted >> in HTML for viewing with a web browser and features Hyperlinked Indexes >> and Message Navigation. The .txt file includes the plain ASCII version >> of the AeroElectric-List Digest and can be viewed with a generic text >> editor >> such as Notepad or with a web browser. >> >> HTML Version: >> >> >> http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 09-07-27&Archive=AeroElectric >> >> Text Version: >> >> >> http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 09-07-27&Archive=AeroElectric >> >> >> =============================================== >> EMail Version of Today's List Digest Archive >> =============================================== >> >> >> ---------------------------------------------------------- >> AeroElectric-List Digest Archive >> --- >> Total Messages Posted Mon 07/27/09: 6 >> ---------------------------------------------------------- >> >> >> Today's Message Index: >> ---------------------- >> >> 1. 08:56 AM - Crossfeed (Sam Hoskins) >> 2. 09:07 AM - Re: Re: Icom A-210 intercom (Robert L. Nuckolls, III) >> 3. 09:59 AM - Re: Re: Icom A-210 intercom (Jay Hyde) >> 4. 01:27 PM - Icom 200 (luigit(at)freemail.it) >> 5. 10:23 PM - Icom 200 (luigit(at)freemail.it) >> 6. 11:07 PM - Re: Icom A-210 intercom (Thruster87) >> >> >> >> ________________________________ Message 1 >> _____________________________________ >> >> >> Subject: AeroElectric-List: Crossfeed >> From: Sam Hoskins <sam.hoskins(at)gmail.com> >> >> I have an all electric plane and have attempted to emulate Z19-RB. >> >> Both batteries are the same size, but I am intending on starting on the >> main >> battery only. My alternator-out load analysis shows around 17 amps to >> keep >> it in the air, though I think I can drop that to 10. >> >> The "keep the engine running" components may run off either bus, but the >> endurance bus is just connected to the main. >> >> Could I install a crossfeed switch between the main and engine >> batteries, >> without a contactor? It would allow me to use the engine battery for >> the >> endurance bus, to supplement the main battery. That would also allow me >> to >> simultaneously charge both batteries without engaging the engine battery >> contactor. >> >> I'll try and attach a pdf. >> >> BTW, after a year and a half, I am somewhat back in the air, though many >> bugs remain. >> >> Sam >> www.samhoskins.blogspot.com >> >> ________________________________ Message 2 >> _____________________________________ >> >> >> From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> >> Subject: Re: AeroElectric-List: Re: Icom A-210 intercom >> >> At 05:00 PM 7/25/2009, you wrote: >> > >> >Hi Bob,I was expecting it to just activate [intercom] without a >> >separate button,so one just speaks and the other person hears >> >you.Pressing the PTT it transmits OK and the passenger can also hear >> >what you say and both can hear just fine the incoming calls.I have >> >not tried connecting the intercom switch to pin 10 Intercom IN and >> >joining to pin 9 PTT + as I understand it,it should not require >> >this switch to operate as a VOX intercom. Cheers Alan [610xl builder >> >almost ready to start taxi run testing] >> >> After reading through the available installation data >> on the Icom IC-A210 I've discovered that the 210 is >> a head-n-shoulders upgrade from the 200. Most noteworthy >> are extensive audio management features with functions >> and gains set by software using a front panel menu >> system. >> >> Another interesting feature is what appears to be >> rear connector plate options. The stock input/output >> connector plate works with the same Molex wires-to- >> ecb style of harnes connector . . . same as the A200. >> The A210 install kit comes with an "MB-113" adapter >> module to convert the legacy molex connnector interface >> >> Emacs! >> >> snip ________________________________________________________________________________
Subject: RE: what is Emacs
Date: Jul 29, 2009
Emacs is a text editor. Well, that=92s like saying the Airbus A380 is an airplane. Anyway it=92s more used in the Linux/Unix world, though versions exist for windows. Ralph Finch Davis CA From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Janet Amtmann Sent: Wednesday, July 29, 2009 8:57 AM Subject: AeroElectric-List: Re: AeroElectric-List Digest: 6 Msgs - 07/27/09 Can someone enlighten me what the word "Emacs" means? J=FCrgen Amtmann ________________________________________________________________________________
Date: Jul 29, 2009
Why Bob's posts seem to regularly include the "Emacs!" exclaimation is a mystery I've long puzzled over. Beats me. I wasn't even aware of it until it popped up on the List just now . . . and I see it on the webmail access to the forums. When I get back to the Gyp Hills, I'll search my ingoing and outgoing archives to see if it shows up. Bob . . . Read this topic online here: http://forums.matronics.com/viewtopic.php?p=255137#255137 ________________________________________________________________________________
Date: Jul 29, 2009
On 07/29/2009 04:07 PM, nuckollsr wrote: > Beats me. I wasn't even aware of it until it popped up > on the List just now Ah, and here I was hoping you were a closet Emacs fan... :-) -Dj ________________________________________________________________________________
Subject: Z-20: Fuse Links, Master Switch, Alt OV Disc. and OVM
Date: Jul 29, 2009
Hello :-) First, thanks to Bob his dedication to helping build dependable electronic systems for homebuilts. I am building a Sonex powered by a Jabiru 3300. I've read through the book and have some questions below. Unless noted otherwise, I am referring directly to your Z-20 diagram. 18awg and 16awg Fuse Link to Starter Contactor On Z-20, connecting to the starter contactor is a 14awg wire from the Alt OV disconnect relay that has an 18awg fuse link inline with it. Although it meets the criterion of being 2 steps smaller than the 14awg, it also say to contact Bob about making them any bigger than with a 22awg line (protececting 18awg). Same issue occurs above this in the diagram with a 16awg fuse link called out to protect the 12awg master power line. Are these fuse links of a different type? On the diagram, it says to refer to Note 4, which doesn't shed any light on this issue. DC Master Power Switch (S1) "Up" (keyway) position: As I understand it, the 2-10 switch is a 3-position dpdt switch. The top position (oriented according to the diagram) would connect terminal 2 to 1, connecting the main power distribution bus to the battery via a starter contactor terminal. At the same time, terminal 5 would connect to 4, where it connects both to the crowbar OVM and the alternator OV disconnect relay, and if then eventually, if all is well in the world, to the PM alternator. This would be the 'normal' position for regular flying, right? "Center" position: Toggling the switch to the center position would still connect terminal 2 to 1 (I had originally thought it made it open), and terminal 5 goes to 6, disconnecting the OVM and cutting power to the alt OV disconnect relay. The alt OV disconnect magnetic field collapses, causing the NO switch to move to the NC position. Moving the toggle to the center position manually takes the alternator offline. "Down" (opposite) position: Moving this switch to the down (opposite) position disconnects terminal 2, cutting off the connection to the battery. And terminal 5 is the same as the 'center' position, disconnecting the alternator. ALT 5A Fuse: Current will flow through the 22awg wire between terminals 2 and 5 only when the switch is in the "Up" (keyway) position, i.e. both the alternator and battery are online. The fuse will blow when more than 5A passes through it, caused by an overvoltage condition. But if there is an OV condition, wouldn't the crowbar OVM take the alternator offline? Is this just redundancy, or am I missing something? Maybe so when the OV condition returns to normal it will keep the alternator permanently offline, instead of going off and on and off, etc, caused by the crowbar OVM cycling off and on? Crowbar OVM In Z-20, the crowbar OVM is shown sharing terminal 4 of the master power switch with the line to the alternator. For me, the crowbar OVM is a black box. All I need to understand is what the 'net' function of it is. When it senses a voltage above a certain value, does it allow a current path to be completed through it to the panel ground? If so, then there would be no current going to the alt OV disconnect relay, which would then take the alternator offline. Is that how it works? Alternator OV Disconnect Relay Am I right in assuming that in the normal engine operation with the power master switch in the 'up' position, the power is applied through the switch to the alternator OV disconnect relay, whose magnetic field then pulls down the alt OV switch from the N.C. position to the N.O. position? That had me confused at first, cuz I figured 'normal' operation is when both the alternator and battery are connected. I think I can interpret 'Normally Open, Normally Closed' as being the 'unenergized' switch position, right? Dynamo, aka PM Alternator Z-20 shows just two wire coming off the alternator. One connects to the voltage regulator at terminal 3, the other at terminal 1. There is also a tach signal wire spliced into the terminal 1 wire. So both of these wires are carrying current generated by the alternator to the voltage regulator? If so, why have two leads instead of one, and shouldn't there be a ground someplace? Capacitor Is the capicitor after the regulator for filtering out noise to the radio? I know of someone who wired according to Z-20, but left out the capacitor. I'm not sure why. Cheers, Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=255162#255162 ________________________________________________________________________________
Date: Jul 30, 2009
Subject: Re: RE: what is Emacs
Uggh, emacs vs vi discussions turn out worse than downwind turn discussions. On Wed, Jul 29, 2009 at 10:31 AM, Ralph Finch wrote: > Emacs is a text editor. Well, thats like saying the Airbus A380 is an > airplane. Anyway its more used in the Linux/Unix world, though versions > exist for windows. > > > Ralph Finch > > Davis CA > > > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Janet > Amtmann > Sent: Wednesday, July 29, 2009 8:57 AM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Re: AeroElectric-List Digest: 6 Msgs - 07/27/09 > > > Can someone enlighten me what the word "Emacs" means? > > > Jrgen Amtmann > > ________________________________________________________________________________
Subject: "Emacs!"
Date: Jul 30, 2009
7/30/2009 Hello Bob Nuckolls, You wrote: " I'll search my ingoing and outgoing archives to see if it shows up." Thank you for your effort to resolve this mystery / aggravation. I had assumed that it was some failing of my computer arrangement that deprived me of what information you were trying to convey. Emacs! usually appeared when you were attempting to place a link to some information. Here is an example extracted from your July 23, 2009 posting on transorbs, message # 46078 in the archives: " Do I correctly deduce from your posting that your contactor coils are protected by a single transorb? If so, then it has to be wired as shown in -A- below. Emacs! In this configuration, the device HAS to be biased in the zener conduction mode polarity while coiled power IS APPLIED." You can see that there was no way to access the intended information. Many thanks for your help on this matter. 'OC' Says: "The best investment we can make is the effort to gather and understand knowledge." ============================================== Subject: AeroElectric-List: Re: AeroElectric-List Digest: 6 Msgs - 07/27/09 From: "nuckollsr" <bob.nuckolls(at)aeroelectric.com> Why Bob's posts seem to regularly include the "Emacs!" exclaimation is a mystery I've long puzzled over. Beats me. I wasn't even aware of it until it popped up on the List just now . . . and I see it on the webmail access to the forums. When I get back to the Gyp Hills, I'll search my ingoing and outgoing archives to see if it shows up. Bob . . . ________________________________________________________________________________
Subject: Z-31A question
Date: Jul 30, 2009
Bob, Z-31A is for a Military Style Ground Power Jack. I understand the diode and OVM-14 on the Ground Power Contactor, but is the diode/jumper necessary on the Existing Battery Contactor? Also, when do you think you will be filling existing orders for OVM-14s? John -------- #40572 QB Fuselage, wings finished. Finish Kit progressing. Engine & Panel delivery soon. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=255222#255222 ________________________________________________________________________________
Date: Jul 30, 2009
On 07/30/2009 12:00 PM, halbenjamin(at)optonline.net wrote: > The REAL question is what primer should be used on emacs? Here is one: <http://www.csm.uwe.ac.uk/~lrlang/java_html/emacsref.html> *wink* -Dj ________________________________________________________________________________
Date: Jul 30, 2009
Subject: Re: Z-20: Fuse Links, Master Switch, Alt OV Disc.
and OVM Too many questions at once makes it daunting for one guy to tackle quickly Dan. I'll take a go at the second part of your post. Maybe someone more familiar with Z-20 will answer the first part. If not, post the questions again that you still have. Yes on the crowbar operation. The black box is very quick. But in addition, the crowbar black box will trip the Circuit breaker to keep the power off. Resetting the breaker will reset the circuit. Alternator OV disconnect. With no power to the relay the alternator is disconnected. Energizing the relay connects the alternator. The NC and NO terminology has a history in electronics where normal means the condition when the coil is not energized. No reference to airplane operation. Dynamo aka PM alternator. These units generate AC power not DC so they need the two wires. The regulator also rectifies the AC into DC and then regulates the DC output voltage. Capacitor. Yes it will help filter noise. It also may assist the stable generation of power if the battery fails or is disconnected. In my machine I do not have the ability to disconnect the PM voltage regulator from the battery and I do not have a capacitor and it all works just fine. Ken > Crowbar OVM > > In Z-20, the crowbar OVM is shown sharing terminal 4 of the master > power switch with the line to the alternator. For me, the crowbar OVM > is a black box. All I need to understand is what the 'net' function > of it is. When it senses a voltage above a certain value, does it > allow a current path to be completed through it to the panel ground? > If so, then there would be no current going to the alt OV disconnect > relay, which would then take the alternator offline. Is that how it > works? > > Alternator OV Disconnect Relay > > Am I right in assuming that in the normal engine operation with the > power master switch in the 'up' position, the power is applied > through the switch to the alternator OV disconnect relay, whose > magnetic field then pulls down the alt OV switch from the N.C. > position to the N.O. position? That had me confused at first, cuz I > figured 'normal' operation is when both the alternator and battery > are connected. I think I can interpret 'Normally Open, Normally > Closed' as being the 'unenergized' switch position, right? > > Dynamo, aka PM Alternator > > Z-20 shows just two wire coming off the alternator. One connects to > the voltage regulator at terminal 3, the other at terminal 1. There > is also a tach signal wire spliced into the terminal 1 wire. So both > of these wires are carrying current generated by the alternator to > the voltage regulator? If so, why have two leads instead of one, and > shouldn't there be a ground someplace? > > Capacitor > > Is the capicitor after the regulator for filtering out noise to the > radio? I know of someone who wired according to Z-20, but left out > the capacitor. I'm not sure why. > > Cheers, Dan > > ________________________________________________________________________________
Subject: Garmin GNS 530 Internal Battery
Date: Jul 30, 2009
It's time to change the internal battery on my GNS 530. Does anyone have any documentation on... 1. How to find the battery? 2. What is required to remove and replace? Thanks, Glenn ________________________________________________________________________________
Subject: Re: Z-20: Fuse Links, Master Switch, Alt OV Disc. and
OVM
Date: Jul 30, 2009
Thanks, Ken :-) I'll post another topic with the any questions I still have in a few days. Chopping the topic up into smaller pieces is a good suggestion. Cheers, Dan -------- Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=255289#255289 ________________________________________________________________________________
Date: Jul 28, 2009
Subject: Re: That magic moment when everything comes together.....
At 11:02 AM 7/28/2009, you wrote: > >- I REALLY couldn't have done it without all of your > considerable expertise and willingness to help a rookie. Yeah . . . you would have got there . . . but perhaps with less confidence in your finished product. Well done sir. Be sure to let your friends know what goes on here at the AeroElectric- List. Helping out EVERYBODY is what we do. >A short, but very sweet video is here.... > >http://www.youtube.com/watch?v=BTSv4sqDxdQ Wayyyy cool! Send us some more video/pix when they don't get in the way of business. Fly comfortably. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jul 31, 2009
Subject: Re: Z-31A question
At 09:59 AM 7/30/2009, you wrote: > > >Bob, >Z-31A is for a Military Style Ground Power Jack. I understand the >diode and OVM-14 on the Ground Power Contactor, but is the >diode/jumper necessary on the Existing Battery Contactor? Yes. The jumper turns the 4-terminal contactor into a 3-terminal contactor. The diode or other transient trapper across the coil is always a good idea too. >Also, when do you think you will be filling existing orders for OVM-14s? Our shops look like a train-wreck right now. I cleared some space on a table yesterday and put a bunch of OVM-14s together and filled all existing orders. Also put a few on the shelf. If you had one on order, you should have received the e-mail notices from the credit card company and a packing list from the 'Connection. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Subject: Re: No Sidetone
Date: Jul 31, 2009
Just a follow-up.. The problem turned out to be the sidetone adjustment pot was turned all the way down by some previous owner (or the factory). This is accessable through a hole labeled "sidetone" in the radio case (covered by a small aluminum tape dot). Being careful to ground myself before touching, I turned it to halfway. Upon re-insttalling and trying it out, I could hear myself clearly when transmitting. While there were no repsonses about this post, I think someone else might benefit from what I found. Dave L. ----- Original Message ----- From: "David & Elaine Lamphere" <dalamphere(at)comcast.net> Sent: Wednesday, July 29, 2009 9:17 AM Subject: AeroElectric-List: No Sidetone >I have an interesting problem with my newly installed King KX125. > > While everything seems to be working correctly and I am clearly received > when I transmit, there is no sidetone during transmission (I do not hear > myself in the head set). I have eliminated the intercom completely, using > an > older handheld mike and phones only - same symptoms - rx clear, tx clear, > no > sidetone. Could it be that I have not installed some jumper not shown?? Or > is there a pot somewhere I need to tweek? > > I have attached the section of the schematic that pertains to this. > > I do not have any connections to pin 501-16 nor do I have a switch on the > mike jack as shown. > > The applicable notes refer to switching 100-H to 501-16 and opening up > 100-8 > to prevent your audio from being transmitted. > > Any clues or hints as to what I have missed doing?? > ________________________________________________________________________________
Date: Jul 31, 2009
Bob, While on the subject of switches, what's up with the AD on Beechcraft switches? My local FBO has 3 or 4 Bonanzas and a couple of Barons in the shop to replace all the switches on the panels. They told me the switches were about $130 each (cost!!!!) plus several hours labor to install. I cannot imagine charging that much for a switch. Jerry Isler RV4 N455J ________________________________________________________________________________
OVM
Date: Jul 31, 2009
> 18awg and 16awg Fuse Link to Starter Contactor > > On Z-20, connecting to the starter contactor is a 14awg wire from the Alt OV disconnect relay that has an 18awg fuse link inline with it. Although it meets the criterion of being 2 steps smaller than the 14awg, it also say to contact Bob about making them any bigger than with a 22awg line (protececting 18awg). Same issue occurs above this in the diagram with a 16awg fuse link called out to protect the 12awg master power line. > > Are these fuse links of a different type? On the diagram, it says to refer to Note 4, which doesn't shed any light on this issue. Also, B & C sells FLK-2 Fusible Link Kit, 20-16 AWG, but in their instructions, they likewise say use this method for 20 and 18 awg, no larger? http://www.bandc.biz/pdfs/Fuselink.pdf Another Way to Skin a Cat Instead of using a fusible link, it looks like an inline fuse with a fuse holder could be used: http://forums.matronics.com/viewtopic.php?t=34954 In this post, Bob says to use MAXI fuses instead of ATC fuses to protect the alternator. I'm guessing this was either because ATC didn't offer them in a large enough size, or because the MAXI line was more dependable for this application. The ATC spec page http://www.aeroelectric.com/Mfgr_Data/Fuses_and_Current_Limiters/Bussman/ATC_Specs.pdf shows a 25A fuse (the size Bob said would work for a 20A alternator, I believe) and a holder that would work up to 24A continuous. The MAXI spec page http://www.aeroelectric.com/Mfgr_Data/Fuses_and_Current_Limiters/Bussman/MAXI_Specs.pdf shows only 20A and 30A without a 25A fuse. So how should I protect my 20A Jabiru PM alternator? Fusible link, 25A ATC fuse and holder, or 30A MAXI fuse and holder? > DC Master Power Switch (S1) Bob answered my questions about this in 2007: http://forums.matronics.com/viewtopic.php?t=21238 Thanks, Dan -------- Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=255386#255386 ________________________________________________________________________________
Date: Jul 31, 2009
and OVM At 07:41 PM 7/29/2009, you wrote: Hello :-) First, thanks to Bob his dedication to helping build dependable electronic systems for homebuilts. I am building a Sonex powered by a Jabiru 3300. I've read through the book and have some questions below. Unless noted otherwise, I am referring directly to your Z-20 diagram. 18awg and 16awg Fuse Link to Starter Contactor On Z-20, connecting to the starter contactor is a 14awg wire from the Alt OV disconnect relay that has an 18awg fuse link inline with it. Although it meets the criterion of being 2 steps smaller than the 14awg, it also say to contact Bob about making them any bigger than with a 22awg line (protececting 18awg). Same issue occurs above this in the diagram with a 16awg fuse link called out to protect the 12awg master power line. Fusible links called out in the Z-figures have been evaluated for appropriate application of this protection philosophy. Use in OTHER places should be discussed before proceeding. Consider that fusible links fall in the same protection category as ROBUST device (ANL, MANL, etc. current limiters). Are these fuse links of a different type? On the diagram, it says to refer to Note 4, which doesn't shed any light on this issue. No, a fusible link can be crafted from wire that is 4AWG or more wire steps SMALLER than the wire being protected. Note that fusible links called upon to do their job will burn. The legacy design goal for TC aircraft (and I presume automobiles) is that in the rare but stressful situation that might open that protection, the designer installs them such that damage to adjacent wires is minimized (fiberglas sleeving over wire) and what ever smoke is expected will be minimized (keep link on the order of 6" and out of the cockpit). DC Master Power Switch (S1) "Up" (keyway) position: As I understand it, the 2-10 switch is a 3-position dpdt switch. The top position (oriented according to the diagram) would connect terminal 2 to 1, connecting the main power distribution bus to the battery via a starter contactor terminal. At the same time, terminal 5 would connect to 4, where it connects both to the crowbar OVM and the alternator OV disconnect relay, and if then eventually, if all is well in the world, to the PM alternator. This would be the 'normal' position for regular flying, right? Down is all power OFF. Mid position is intended to bring the battery only on line. The up position adds the engine driven power source. Full up (both sources on) is the normal position for flight. "Center" position: Toggling the switch to the center position would still connect terminal 2 to 1 (I had originally thought it made it open), and terminal 5 goes to 6, disconnecting the OVM and cutting power to the alt OV disconnect relay. The alt OV disconnect magnetic field collapses, causing the NO switch to move to the NC position. Moving the toggle to the center position manually takes the alternator offline. yes "Down" (opposite) position: Moving this switch to the down (opposite) position disconnects terminal 2, cutting off the connection to the battery. And terminal 5 is the same as the 'center' position, disconnecting the alternator. yes. this is explained in the section on switches where the functionality of progressive transfer switches is discussed. ALT 5A Fuse: Current will flow through the 22awg wire between terminals 2 and 5 only when the switch is in the "Up" (keyway) position, i.e. both the alternator and battery are online. The fuse will blow when more than 5A passes through it, caused by an overvoltage condition. OV conditions DO NOT increase current demands expected to open ANY STYLE of circuit protection. Fuses and breakers protect wires. OV conditions are managed by millisecond-fast detection devices specific to the task of taking an alternator off line. But if there is an OV condition, wouldn't the crowbar OVM take the alternator offline? Is this just redundancy, or am I missing something? Maybe so when the OV condition returns to normal it will keep the alternator permanently offline, instead of going off and on and off, etc, caused by the crowbar OVM cycling off and on? Yes, ALL ov protection devices qualified for aviation are latching. I.e., when an ov condition is detected, the alternator shuts down and stays down. Keep in mind that the condition immediately following an OV trip is a LOW VOLTS situation that should cause your LV warning system to become active. Crowbar OVM In Z-20, the crowbar OVM is shown sharing terminal 4 of the master power switch with the line to the alternator. For me, the crowbar OVM is a black box. All I need to understand is what the 'net' function of it is. When it senses a voltage above a certain value, does it allow a current path to be completed through it to the panel ground? If so, then there would be no current going to the alt OV disconnect relay, which would then take the alternator offline. Is that how it works? Yup, it opens the UPSTREAM circuit protection (in this case a circuit breaker) thus latching the alternator OFF. Alternator OV Disconnect Relay Am I right in assuming that in the normal engine operation with the power master switch in the 'up' position, the power is applied through the switch to the alternator OV disconnect relay, whose magnetic field then pulls down the alt OV switch from the N.C. position to the N.O. position? That had me confused at first, cuz I figured 'normal' operation is when both the alternator and battery are connected. I think I can interpret 'Normally Open, Normally Closed' as being the 'unenergized' switch position, right? Yes, this is a vernacular common to relay-speak since about day-one. Further, you may find the "COM", "NO" and "NC" nomenclature molded into the plastic housing of the relay. See . . . http://aeroelectric.com/Pictures/Relays/Plastic_Relay_2.jpg Dynamo, aka PM Alternator Z-20 shows just two wire coming off the alternator. One connects to the voltage regulator at terminal 3, the other at terminal 1. There is also a tach signal wire spliced into the terminal 1 wire. So both of these wires are carrying current generated by the alternator to the voltage regulator? If so, why have two leads instead of one, and shouldn't there be a ground someplace? The Dynamo is an AC power generating device that needs both leads brought out to a rectifier/regulator for conversion and management. The classic "alternator" has the rectifiers built in and usually take power (-) to case ground thus eliminating the need for one of the power output wires. Capacitor Is the capicitor after the regulator for filtering out noise to the radio? I know of someone who wired according to Z-20, but left out the capacitor. I'm not sure why. The capacitor reduces alternator noise an enhances alternator stability during battery-off operations (contactor failed). If left off, you're not likely to notice the difference for 99.9% of your operations. Bob . . . ________________________________________________________________________________
Date: Jul 31, 2009
and OVM At 12:09 PM 7/31/2009, you wrote: > > > > 18awg and 16awg Fuse Link to Starter Contactor > > > > On Z-20, connecting to the starter contactor is a 14awg wire from > the Alt OV disconnect relay that has an 18awg fuse link inline with > it. Although it meets the criterion of being 2 steps smaller than > the 14awg, it also say to contact Bob about making them any bigger > than with a 22awg line (protececting 18awg). Same issue occurs > above this in the diagram with a 16awg fuse link called out to > protect the 12awg master power line. > > > > Are these fuse links of a different type? On the diagram, it says > to refer to Note 4, which doesn't shed any light on this issue. > > >Also, B & C sells FLK-2 Fusible Link Kit, 20-16 AWG, but in their >instructions, they likewise say use this method for 20 and 18 awg, no larger? > >http://www.bandc.biz/pdfs/Fuselink.pdf > >Another Way to Skin a Cat > >Instead of using a fusible link, it looks like an inline fuse with a >fuse holder could be used: >http://forums.matronics.com/viewtopic.php?t=34954 In this post, Bob >says to use MAXI fuses instead of ATC fuses to protect the >alternator. I'm guessing this was either because ATC didn't offer >them in a large enough size, or because the MAXI line was more >dependable for this application. > >The ATC spec page >http://www.aeroelectric.com/Mfgr_Data/Fuses_and_Current_Limiters/Bussman/ATC_Specs.pdf >shows a 25A fuse (the size Bob said would work for a 20A alternator, >I believe) and a holder that would work up to 24A continuous. > >The MAXI spec page >http://www.aeroelectric.com/Mfgr_Data/Fuses_and_Current_Limiters/Bussman/MAXI_Specs.pdf >shows only 20A and 30A without a 25A fuse. > >So how should I protect my 20A Jabiru PM alternator? Fusible link, >25A ATC fuse and holder, or 30A MAXI fuse and holder? Any way you wish. All of the processes you mentioned are suited for PROTECTING THE WIRE between the bus and the alternator's rectifier/regulator. The Z-20 data is but one recipe for success that will perform as advertised. There are many variations on a theme for protection of wires which are interchangeable if exercised with understanding about how the ingredient substitution is expected to perform. The plastic fuses would be fine too. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jul 31, 2009
At 11:13 AM 7/31/2009, you wrote: > > >Bob, > >While on the subject of switches, what's up with the AD on >Beechcraft switches? My local FBO has 3 or 4 Bonanzas and a couple >of Barons in the shop to replace all the switches on the panels. >They told me the switches were about $130 each (cost!!!!) plus >several hours labor to install. I cannot imagine charging that much >for a switch. Gee . . . ONLY $130? It has to be because the volume in sales is up. While I was still at HBC, I seem to recall a price of $175 each. The device in question is a breaker-switch . . . http://aeroelectric.com/Pictures/Breakers/W31_3.jpg . . . where robustness of the braided copper jumper wire is not meeting design goals. If the "added insulator" is not present, jumper failure causes load current to flow through the contact-spreading spring. IF the switch is used in a high current application (prop de-ice, pitot heat) then the spring smokes and folks get upset. Problem is similar to the AD being discussed on the Cessna switches. The Bonanzas and Barons total about 80,000 switches in the field. The Cessna situation is probably much larger. This is a great example of what happens when one discovers a failure to meet design goals in a legacy product with huge numbers. The only folks upset about it are the aircraft owners. The FBO can sympathize but he cannot do anything practical. Cessna and Beech can't do anything practical either. First, it's unlikely that they have anyone on their staff that truly understands root causes for the problems. Second, practical fixes require properly approved kits with staggering costs and time-to-market issues driven by bureaucracy and corporate policy/procedure albatrosses. So, what's the easy fix? AD the critters, spread the costs around the fleet owners. But make sure the work is accomplished only by qualified technicians at FBO standard rates. The type certificated light airplane market is sinking ever lower in the FAA/ISO tarpits. While at Cessna in 1965 or so, we broke 10,000 airplanes per year production. It's never been that high since and the trends are going down. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
Date: Jul 31, 2009
Buy one switch then search heavan and earth to find the supplier and buy direct from them..then hand them to the A&P..Got to be worth a shot..Gee! Frank...Thankfully experimental! Bob, While on the subject of switches, what's up with the AD on Beechcraft switches? My local FBO has 3 or 4 Bonanzas and a couple of Barons in the shop to replace all the switches on the panels. They told me the switches were about $130 each (cost!!!!) plus several hours labor to install. I cannot imagine charging that much for a switch. Jerry Isler RV4 N455J ________________________________________________________________________________
Subject: AEC9011
Date: Jul 31, 2009
Thanks, Bob, for answering my questions on the other thread :-) Sifting through the forum archives, I see you have mentioned a replacement for the AEC9005-101 LV monitor module, http://aeroelectric.com/Catalog/AEC/9011/9011-700-1C.pdf ,which shows the new product. When will the 9011 become available? Looks like it would replace the S704-1 alternator disconnect and AEC9005-101 LV monitor module. The alternator disconnect portion of the drawing shows a slightly different alternator disconnect, the AEC9011-110-1. It says 'arc suppression' and has a resistor and capacitor added. What are the pros and cons of these pieces? If I then wanted to leave of the resistor and capacitor, could I simply modify the 9011? Thanks, Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=255399#255399 ________________________________________________________________________________
Date: Jul 31, 2009
Subject: Re: ROCHESTER FUEL LEVEL INDICATOR WIRING
At 05:28 PM 7/28/2009, you wrote: > >The indicator has 3 posts on the back marked SEN, middle not marked >and IGN which goes to which.Didn't want to fry anything. Cheers Alan Best guess is that IGN goes to your fuel gages breaker/fuse. SEN goes to the tank sender. The unmarked goes to ground. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jul 31, 2009
Subject: Re: Crossfeed
At 10:32 AM 7/27/2009, you wrote: >I have an all electric plane and have attempted to emulate Z19-RB. > >Both batteries are the same size, but I am intending on starting on >the main battery only. My alternator-out load analysis shows around >17 amps to keep it in the air, though I think I can drop that to 10. Okay, what are your design goals for battery only endurance? >The "keep the engine running" components may run off either bus, but >the endurance bus is just connected to the main. > >Could I install a crossfeed switch between the main and engine >batteries, without a contactor? Obviously, yes. But 30A always hot wires to a panel mounted switch? You're stacking lots of switches and options together that PRESUMES you'll be making good and useful decisions when things aren't going right. You also appear to be stacking multiple failures onto a single tank full of gas. > It would allow me to use the engine battery for the endurance > bus, to supplement the main battery. That would also allow me to > simultaneously charge both batteries without engaging the engine > battery contactor. Hmmmm . . . the whole idea behind Z-19 was to partition duties for the two batteries batteries of known condition. If there's rationale for paralleling them, perhaps one larger battery is more appropriate? With respect to hangar maintenance for dual batteries, how about dual battery maintainers? Give each their own accessory plug to a wire off the battery bus protected with a 5A fuse?? If you're worried about having total battery energy available for any and all duties aboard the aircraft, what's the failure mode that prompts the design goal? >I'll try and attach a pdf. Nice job on the drawing . . . >BTW, after a year and a half, I am somewhat back in the air, though >many bugs remain. Yup, it's no different in the development of TC aircraft. Hopefully we slay all the dragons during pre-cert flight testing and shepherding the first dozen or so airplanes down the line. The NICE thing about dead-dragons in the factory is that the outcome benefits lots of future airplanes. Your website for sharing your own hunting successes is a good and useful thing . . . Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jul 31, 2009
Got confirmation on the order. Thanks! John -------- #40572 QB Fuselage, wings finished. Finish Kit progressing. Engine & Panel delivery soon. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=255426#255426 ________________________________________________________________________________
Date: Jul 31, 2009
Subject: Re: AEC9011
At 02:00 PM 7/31/2009, you wrote: > >Thanks, Bob, for answering my questions on the other thread :-) > >Sifting through the forum archives, I see you have mentioned a >replacement for the AEC9005-101 LV monitor module, >http://aeroelectric.com/Catalog/AEC/9011/9011-700-1C.pdf ,which >shows the new product. When will the 9011 become available? As soon as I get my kids schooled in the art of soldering specs of fly-#$@@ onto ECB's. The design is done and I've had a couple of prototypes flying for the past 6 months or so. When do you absolutely need it? >Looks like it would replace the S704-1 alternator disconnect and >AEC9005-101 LV monitor module. The alternator disconnect portion of >the drawing shows a slightly different alternator disconnect, the >AEC9011-110-1. No, only the AEC9005 LV warning. It COULD be used for OV management of either generators -OR- alternators with external regulators. The present modus operandi for the 9011 calls for ENERGIZING the relay to shut the alternator/generator down. For your application, we need to ENERGIZE the relay to bring the alternator ON and de-energize it to kill the alternator. I guess I could do a patch to the software to make it do that. That would allow the single device to do both OV and LV monitoring/control on your small PM alternator. > It says 'arc suppression' and has a resistor and capacitor added. > What are the pros and cons of these pieces? If I then wanted to > leave of the resistor and capacitor, could I simply modify the 9011? Those are components added to the generator field disconnect relay when and if the OV management relay connects to a very inductive load (alternator or generator field). For the application we're talking about, you wouldn't need the arc suppression. Let me think about this a bit and see what it would take to offer a different dash number for the 9011. Alternatively, I could make the existing version energize the relay for generator turn-on . . . that would let me offer one product into yet another application. That's and attractive. I'll think about it. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jul 31, 2009
> When do you absolutely need it? Absolutely...hmm...lemme say possibly as early as 2 months, probably between 3 and 4 months, maybe as long as 6-8 months. If I knew the dimensions, connections, etc. I could prolly leave space for it and do a little retro fitting, if my project stepped into the fast lane. > No, only the AEC9005 LV warning. It COULD be used for > OV management of either generators -OR- alternators > with external regulators. I won't have any aux battery, so if I outfitted it today I would need only an LV warning light and not the rest of the options currently available. > For your application, > we need to ENERGIZE the relay to bring the alternator > ON and de-energize it to kill the alternator. I guess > I could do a patch to the software to make it do that. > That would allow the single device to do both OV and > LV monitoring/control on your small PM alternator. And this device wouldn't need the arc suppression devices for my use, just like you'd said before, right? That would be nice. Then it would replace the PM alternator disconnect. It could use the panel display from the 9011 prototype, showing something like lights for OV, LV, aux bat LV (wouldn't be wired in my case), and OV test? -------- Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=255446#255446 ________________________________________________________________________________
Subject: Re: Switch Failures
Date: Jul 31, 2009
The cost isn't that high - I paid only $98-$105 each for my six switch / breakers. Its the miracle of certified aviation. BTW - there was a vendor at Oshkosh who claims that the new switches are also defective (with a somewhat different failure mode - the breakage of the braided wire inside). He claimed to have "just yesterday" received a PMA for his replacement switch/breaker. It was only $130.... taking orders but not yet available. :) ----- Original Message ----- From: "Jerry Isler" <jlisler(at)windstream.net> Sent: Friday, July 31, 2009 11:13 AM Subject: Re: AeroElectric-List: Re: Switch Failures > > > Bob, > > While on the subject of switches, what's up with the AD on Beechcraft > switches? My local FBO has 3 or 4 Bonanzas and a couple of Barons in the > shop to replace all the switches on the panels. They told me the switches > were about $130 each (cost!!!!) plus several hours labor to install. I > cannot imagine charging that much for a switch. > > Jerry Isler > RV4 N455J > > > ________________________________________________________________________________
Date: Jul 31, 2009
Subject: Re: "Emacs!"
At 08:39 AM 7/30/2009, you wrote: > >I just checked my archives, and the first Emacs showed up in a message >January 2, 2009. Your observation that it is in the place Bob intended >a picture or drawing to show up is accurate. However, the intended >picture was included in my emails as an attachment which shows up at >the bottom of the message. I can also look at the html format of those >messages, and I see a box in the appropriate location with "Emacs!" >inside the box. Looking at the html source, I find this: Gee, you guys put up with this for long time before rattling my cage . . . don't worry about getting "bit", my rabies shots are current. I sent myself some e-mails between matronics accounts with embedded images and they came through as expected. However, "embedded" appears not to mean that they are truly merged with the text . . . rather, they're stored in some sub-directory called "embedded". My email application also has a directory called "attached" . . . and at first blush, they appear quite similar. If I erase the "embedded" images from the directory, lo-and- behold, the html interpreter blocks out a space for that image and labels it with "Emacs!". Further, references to the embedded images at the bottom of the message calles out a file name and puts a big red X through it to indicate that it cannot be found. I don't know how the html text and images are handled through the list server . . . or stored in the forums archives. But it would appear that once the image becomes detached from it's companion text, the Emacs! thing pops up. There's quite a number of postings that loose some flavor when the images went away. I wonder if sending them as attachments is any more stable. OTOH, I could go back to archiving on my website and linking to the images. But it IS much less convenient. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jul 31, 2009
Subject: testing
Emacs! this is a test Emacs! This is another test done! Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jul 31, 2009
At 08:08 PM 7/31/2009, you wrote: > > >The cost isn't that high - I paid only $98-$105 each for my six >switch / breakers. Its the miracle of certified aviation. > >BTW - there was a vendor at Oshkosh who claims that the new switches >are also defective (with a somewhat different failure mode - the >breakage of the braided wire inside). That was the ORIGINAL failure with a secondary event (smoking spring) caused by current flowing through the spring between the contact strut and the frame. The "FIX" didn't stop the wire from breaking, it only kept the secondary event from occurring. So instead of getting a broken wire followed by smoke, you only get a dead accessory. Now, I suppose the next shoe to drop will insist that some light or warning be included. Yeah, put a paragraph in the flight manual asking the pilot to keep an eye on the ammeter lest a broken wire sneak past without notice . . . but at least we don't put smoke in the cockpit. > He claimed to have "just yesterday" received a PMA for his > replacement switch/breaker. It was only $130.... taking orders > but not yet available. :) Do you have his contact data? Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jul 31, 2009
At 07:40 PM 7/31/2009, you wrote: > > > > When do you absolutely need it? > > >Absolutely...hmm...lemme say possibly as early as 2 months, probably >between 3 and 4 months, maybe as long as 6-8 months. If I knew the >dimensions, connections, etc. I could prolly leave space for it and >do a little retro fitting, if my project stepped into the fast lane. the dimensions are given in http://www.aeroelectric.com/Catalog/AEC/9011/9011-700-1C.pdf and the mating connector is a 9 pin, female d-sub. The only thing that MIGHT change is wiring to the relay such that the relay's N.O. contacts are used to control the alternator as opposed to the N.C. contacts as shown now. I've decided to leave the alternator/generator version as shown . . . for several reasons. There will be a PM alternator version -10/14V AND -11/28v that drops out the relay for alternator OV condition. This will merge nicely with all the existing PM alternator Z-figures. Your installation would not have the OV warn light and optionally, you can leave off the aux battery warn light too. So all you'll have is the OV test/reset switch and the LV warning light. > > No, only the AEC9005 LV warning. It COULD be used for > > OV management of either generators -OR- alternators > > with external regulators. > > >I won't have any aux battery, so if I outfitted it today I would >need only an LV warning light and not the rest of the options >currently available. The 'extras' come standard and are used or not used as your particular design goals dictate. Once the basic circuitry and packaging is taken care of, adding the extra features is about 5% of the total cost of the product. >And this device wouldn't need the arc suppression devices for my >use, just like you'd said before, right? That would be nice. Then it >would replace the PM alternator disconnect. It could use the panel >display from the 9011 prototype, showing something like lights for >OV, LV, aux bat LV (wouldn't be wired in my case), and OV test? I haven't decided whether or not to offer a placard. Like you've already noted, the needs of each builder can generate a lot of different placard combinations. I think we'll offer LED indicators, miniature switches, control module and the 704-1 style relay. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Jul 31, 2009
Hi Bob, I suspect the attachment method will be more likely to give good results as compared to embedding the images. Even lowly text only email clients can usually handle attachments in some way. Bob W. "Robert L. Nuckolls, III" wrote: > > At 08:39 AM 7/30/2009, you wrote: > > > >I just checked my archives, and the first Emacs showed up in a message > >January 2, 2009. Your observation that it is in the place Bob intended > >a picture or drawing to show up is accurate. However, the intended > >picture was included in my emails as an attachment which shows up at > >the bottom of the message. I can also look at the html format of those > >messages, and I see a box in the appropriate location with "Emacs!" > >inside the box. Looking at the html source, I find this: > > Gee, you guys put up with this for long time before > rattling my cage . . . don't worry about getting "bit", > my rabies shots are current. > > I sent myself some e-mails between matronics accounts > with embedded images and they came through as expected. > However, "embedded" appears not to mean that they are > truly merged with the text . . . rather, they're stored > in some sub-directory called "embedded". My email application > also has a directory called "attached" . . . and at first > blush, they appear quite similar. > > If I erase the "embedded" images from the directory, lo-and- > behold, the html interpreter blocks out a space for that > image and labels it with "Emacs!". Further, references to > the embedded images at the bottom of the message calles > out a file name and puts a big red X through it to indicate > that it cannot be found. > > I don't know how the html text and images are handled through > the list server . . . or stored in the forums archives. But > it would appear that once the image becomes detached from > it's companion text, the Emacs! thing pops up. > > There's quite a number of postings that loose some flavor > when the images went away. I wonder if sending them as > attachments is any more stable. OTOH, I could go back to > archiving on my website and linking to the images. But > it IS much less convenient. > > > Bob . . . > > --------------------------------------- > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > --------------------------------------- > > > > > > -- N93BD - Rotary Powered BD-4 - http://www.bob-white.com 3.8 Hours Total Time and holding Cables for your rotary installation - http://roblinstores.com/ ________________________________________________________________________________
Date: Jul 31, 2009
His handout reads: "MAJOR PROBLEM! If you install the NEW Beech Circuit Breaker for the AD, be prepared for smoke, sparks, or fire in the cockpit. THE Braided Wire BREAKS..." You can read the rest of it with photos here: http://www.williamsairpower.com/pdf/switches.pdf Contact info as requested: Daniel J. Williams
July 15, 2009 - July 31, 2009
AeroElectric-Archive.digest.vol-iw
