AeroElectric-Archive.digest.vol-ja
September 17, 2009 - October 04, 2009
      installation.
      On the Continental, it is the only place that you will get an accurate flow, as
      they use a return line from the servo to the tank.
      Another thing that Flowscan recommends beside the lines being straight, is to mount
      the transducer with the wires pointing up.
      I have installed them with a 90 degree fitting on the out side and it has worked
      fine.
      Al
      http://forums.matronics.com/viewtopic.php?p=263498#263498
Date: Sep 17, 2009
Subject: Bus Voltage
In the comment below, Bob said that the bus (main?) should display 14+ volts. Mine displays 13.5 with the engine running, 60A Plane Power alternator on, and normal electrical loads of about 22-24 Amps. Initial Amp spike is up to 45 just after start as battery recharges, but volts average 13.5 with occasional spike to 13.7. Should the PP alternator be putting out more? Is it adjustable? Stan Sutterfield > Under what conditions? With the engine running and the > alternator supporting all the ship's electrical loads, > one would expect 14.2 to 14.6 volts on the bus. ________________________________________________________________________________
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
Date: Sep 17, 2009
Well PP sits at 13.7V continuously (as shown on the Dynon EMS..Then one day I measured the actual battery voltage and it was over 14V...So I took the highly technal path and chose to ignore it..:). But it is a curiosity I'd l ike to get to the bottom of one day. Frank ________________________________ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectr ic-list-server(at)matronics.com] On Behalf Of Speedy11(at)aol.com Sent: Thursday, September 17, 2009 8:28 AM Subject: AeroElectric-List: Bus Voltage In the comment below, Bob said that the bus (main?) should display 14+ volt s. Mine displays 13.5 with the engine running, 60A Plane Power alternator on, and normal electrical loads of about 22-24 Amps. Initial Amp spike is up to 45 just after start as battery recharges, but volts average 13.5 with occasional spike to 13.7. Should the PP alternator be putting out more? Is it adjustable? Stan Sutterfield > Under what conditions? With the engine running and the > alternator supporting all the ship's electrical loads, > one would expect 14.2 to 14.6 volts on the bus. ________________________________ ________________________________________________________________________________
Date: Sep 17, 2009
Subject: Re: Bus Voltage
At 10:27 AM 9/17/2009, you wrote: >In the comment below, Bob said that the bus (main?) should display >14+ volts. Mine displays 13.5 with the engine running, 60A Plane >Power alternator on, and normal electrical loads of about 22-24 >Amps. Initial Amp spike is up to 45 just after start as battery >recharges, but volts average 13.5 with occasional spike to 13.7. >Should the PP alternator be putting out more? Yes . . . and it MAY be . . . > Is it adjustable? I don't think so. Plane Power starts with a suitable IR alternator core and simply modifies it to bring the field supply lead to the outside world so that OV protection and pilot operated switches have ABSOLUTE, LOW-ENERGY control over alternator operations. Internal regulators for alternators are modern integrated circuits. Its EASY to trim their regulation set-points for the design goal value during manufacture. 14.2 to 14.6 volts has been the benchmark window for as long as I can remember. I'm not aware of any example of user adjustable, internal regulators. Let's eliminate potential sources of uncertainty. First, make sure that the voltmeter you're citing agrees with other voltmeters to within 0.1 volts. Check it against a Fluke instrument if you can. Know too that the regulator senses voltage at the b-lead terminal . . . so it's possible that system loads combined with system wiring resistance between b-lead and your voltmeter's sense point may be accounting for your observation. GROUND systems can contribute to a voltage drop too. Do a voltage measurement right at the b-lead terminal reference to the alternator's case ground. The alternator may be performing as advertised with the voltage being tossed off in installation errors. Check with Plane Power. Ask them what their design-goal set-point value is. Just because I've never seen a 13.8v regulator doesn't mean they don't exist. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Subject: mc3423 Overvoltage Crowbar Sensing Circuit
Date: Sep 17, 2009
Subject: Re: mc3423 Overvoltage Crowbar Sensing Circuit
Date: Sep 17, 2009
I don't know why my original message didn't get through but what I wrote was: Pending availability of AEC9004 has anyone looked at implementing the crowbar in the interim circuit with a mc3423? One chip, three resistors and an SCR, total cost approximately $4. Any catches I'm missing? best regards Peter Read this topic online here: http://forums.matronics.com/viewtopic.php?p=263551#263551 ________________________________________________________________________________
Date: Sep 17, 2009
At 12:11 PM 9/17/2009, you wrote: > >I don't know why my original message didn't get through but what I wrote was: > >Pending availability of AEC9004 has anyone looked at implementing the >crowbar in the interim circuit with a mc3423? >One chip, three resistors and an SCR, total cost approximately $4. Any >catches I'm missing? The AEC9004 is not an SCR based crow-bar protection module. The AEC9003 (AEC), OVM-14 (B&C), and CbOVM-14 (AEC) modules are still in production in one form or another . . . The 3423 is a well thought out device that would nicely emulate the functionality of the AEC/B&C crowbar OV protection modules. It features a constant current source charging a clamped dV/dT capacitor to set a "window" of tolerance for short duration transients. I did an implementation of the same configuration with dual comparators a few years after we offered the first OV crowbar design to Beech. The MC3423 came along some years later to offer a one-chip implementation of the idea. As long as our supply of trigger-diodes holds out, the design we offer will continue with the minimum-parts-count approach. It's a slick chip. However, I note that Digikey has no stock on the DIP8 package it and appears to offer the SOIC 8 package with only 11 pieces in stock at .93/ea each right now. Allied has DIP8 chips on hand at .71/ea. Other folks may have DIP8 packages on hand. If this chip is going the way that many others do, the alternatives will be to revisit the dual-comparator approach I cited earlier. I can supply a schematic for the design if anyone wants it. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Subject: One-Wire Alternator Conversion
Date: Sep 17, 2009
9/17/2009 Below web page posted for your information: http://www.eaa.org/experimenter/articles/2009-09_howto_alternator.asp 'OC' Says: "The best investment we can make is the effort to gather and understand knowledge." ________________________________________________________________________________
Date: Sep 17, 2009
I think this answers a question I had about PP alternators, which is are th e regulators linear like B&C?- I gather they are not but still wondering if it is really that important. Nobody seems to be having trouble with nois e from them.=0ATim Andres=0A=0A=0A=0A=0A________________________________=0A From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>=0ATo: aeroe lectric-list(at)matronics.com=0ASent: Thursday, September 17, 2009 9:04:43 AM =0ASubject: Re: AeroElectric-List: Bus Voltage=0A=0AAt 10:27 AM 9/17/2009, you wrote:=0A=0AIn the comment below, Bob said that the bus (main?) should display 14+ volts.- Mine displays 13.5 with the engine running, 60A Plane Power alternator on, and normal electrical loads of about 22-24 Amps.- I nitial Amp spike is up to 45 just after start as battery recharges, but vol ts average 13.5 with occasional spike to 13.7.=0A>Should the PP alternator be putting out more?=0A- Yes . . . and it MAY be . . .=0A=0A=0A- Is it adjustable?=0A- I don't think so. Plane Power starts with=0A- a suitabl e IR alternator core and simply=0A- modifies it to bring the field supply lead=0A- to the outside world so that OV protection=0A- and pilot oper ated switches have ABSOLUTE,=0A- LOW-ENERGY control over alternator opera tions.=0A=0A- Internal regulators for alternators are=0A- modern integr ated circuits. Its EASY to trim=0A- their regulation set-points for the d esign=0A- goal value during manufacture. 14.2 to 14.6=0A- volts has bee n the benchmark window for=0A- as long as I can remember. I'm not aware =0A- of any example of user adjustable, internal=0A- regulators.=0A=0A - Let's eliminate potential sources of uncertainty.=0A- First, make sur e that the voltmeter you're=0A- citing agrees with other voltmeters to wi thin=0A- 0.1 volts. Check it against a Fluke instrument=0A- if you can. Know too that the regulator senses=0A- voltage at the b-lead terminal . . . so it's=0A- possible that system loads combined with system=0A- wir ing resistance between b-lead and your voltmeter's=0A- sense point may be accounting for your observation.=0A- GROUND systems can contribute to a voltage drop=0A- too.=0A=0A- Do a voltage measurement right at the b-le ad=0A- terminal reference to the alternator's case=0A- ground. The alte rnator may be performing as=0A- advertised with the voltage being tossed off=0A- in installation errors.=0A=0A- Check with Plane Power. Ask them what their=0A- design-goal set-point value is. Just because=0A- I've n ever seen a 13.8v regulator doesn't mean=0A- they don't exist.=0A=0A=0A ------ Bob . . .=0A=0A------- ------------------- --------------------=0A------ ( . . .- a long habit of not th inking-- )=0A------ ( a thing wrong, gives it a superficial )=0A------ ( appearance of being right . . .------ )=0A------ (---------------- ---------------------- )=0A- ----- (----------------- -Thoma s Paine 1776-- )=0A------- -------------------------------- =================== ________________________________________________________________________________
Date: Sep 17, 2009
Plane power offers a number of different alternators, including PMA'd versions for certified aircraft, that clearly require the original external regulator. Their experimental versions are the internally regulated models. So you can have pretty much which flavor pleases you. Tim Andres wrote: > I think this answers a question I had about PP alternators, which is are > the regulators linear like B&C? I gather they are not but still > wondering if it is really that important. Nobody seems to be having > trouble with noise from them. > Tim Andres > > ------------------------------------------------------------------------ > *From:* "Robert L. Nuckolls, III" > *To:* aeroelectric-list(at)matronics.com > *Sent:* Thursday, September 17, 2009 9:04:43 AM > *Subject:* Re: AeroElectric-List: Bus Voltage > > At 10:27 AM 9/17/2009, you wrote: >> In the comment below, Bob said that the bus (main?) should display 14+ >> volts. Mine displays 13.5 with the engine running, 60A Plane Power >> alternator on, and normal electrical loads of about 22-24 Amps. >> Initial Amp spike is up to 45 just after start as battery recharges, >> but volts average 13.5 with occasional spike to 13.7. >> Should the PP alternator be putting out more? > > Yes . . . and it MAY be . . . > >> Is it adjustable? > > I don't think so. Plane Power starts with > a suitable IR alternator core and simply > modifies it to bring the field supply lead > to the outside world so that OV protection > and pilot operated switches have ABSOLUTE, > LOW-ENERGY control over alternator operations. > > Internal regulators for alternators are > modern integrated circuits. Its EASY to trim > their regulation set-points for the design > goal value during manufacture. 14.2 to 14.6 > volts has been the benchmark window for > as long as I can remember. I'm not aware > of any example of user adjustable, internal > regulators. > > Let's eliminate potential sources of uncertainty. > First, make sure that the voltmeter you're > citing agrees with other voltmeters to within > 0.1 volts. Check it against a Fluke instrument > if you can. Know too that the regulator senses > voltage at the b-lead terminal . . . so it's > possible that system loads combined with system > wiring resistance between b-lead and your voltmeter's > sense point may be accounting for your observation. > GROUND systems can contribute to a voltage drop > too. > > Do a voltage measurement right at the b-lead > terminal reference to the alternator's case > ground. The alternator may be performing as > advertised with the voltage being tossed off > in installation errors. > > Check with Plane Power. Ask them what their > design-goal set-point value is. Just because > I've never seen a 13.8v regulator doesn't mean > they don't exist. > > Bob . . . > > --------------------------------------- > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > --------------------------------------- > > *http://www.matronics.com/Navigator?AeroElectric-Li======== > ========== * > > * > > > * ________________________________________________________________________________
Date: Sep 17, 2009
Thanks but the question is are the PPregulators linear or switchers? ----- Original Message ---- From: Kelly McMullen <kellym(at)aviating.com> Sent: Thursday, September 17, 2009 4:56:16 PM Subject: Re: AeroElectric-List: Bus Voltage Plane power offers a number of different alternators, including PMA'd versions for certified aircraft, that clearly require the original external regulator. Their experimental versions are the internally regulated models. So you can have pretty much which flavor pleases you. Tim Andres wrote: > I think this answers a question I had about PP alternators, which is are the regulators linear like B&C? I gather they are not but still wondering if it is really that important. Nobody seems to be having trouble with noise from them. > Tim Andres > > ------------------------------------------------------------------------ > *From:* "Robert L. Nuckolls, III" > *To:* aeroelectric-list(at)matronics.com > *Sent:* Thursday, September 17, 2009 9:04:43 AM > *Subject:* Re: AeroElectric-List: Bus Voltage > > At 10:27 AM 9/17/2009, you wrote: >> In the comment below, Bob said that the bus (main?) should display 14+ volts. Mine displays 13.5 with the engine running, 60A Plane Power alternator on, and normal electrical loads of about 22-24 Amps. Initial Amp spike is up to 45 just after start as battery recharges, but volts average 13.5 with occasional spike to 13.7. >> Should the PP alternator be putting out more? > > Yes . . . and it MAY be . . . > >> Is it adjustable? > > I don't think so. Plane Power starts with > a suitable IR alternator core and simply > modifies it to bring the field supply lead > to the outside world so that OV protection > and pilot operated switches have ABSOLUTE, > LOW-ENERGY control over alternator operations. > > Internal regulators for alternators are > modern integrated circuits. Its EASY to trim > their regulation set-points for the design > goal value during manufacture. 14.2 to 14.6 > volts has been the benchmark window for > as long as I can remember. I'm not aware > of any example of user adjustable, internal > regulators. > > Let's eliminate potential sources of uncertainty. > First, make sure that the voltmeter you're > citing agrees with other voltmeters to within > 0.1 volts. Check it against a Fluke instrument > if you can. Know too that the regulator senses > voltage at the b-lead terminal . . . so it's > possible that system loads combined with system > wiring resistance between b-lead and your voltmeter's > sense point may be accounting for your observation. > GROUND systems can contribute to a voltage drop > too. > > Do a voltage measurement right at the b-lead > terminal reference to the alternator's case > ground. The alternator may be performing as > advertised with the voltage being tossed off > in installation errors. > > Check with Plane Power. Ask them what their > design-goal set-point value is. Just because > I've never seen a 13.8v regulator doesn't mean > they don't exist. > > Bob . . . > > --------------------------------------- > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > --------------------------------------- > > *http://www.matronics.com/Navigator?AeroElectric-Li======== ========== * > > * > > > * ________________________________________________________________________________
Date: Sep 17, 2009
At 07:49 PM 9/17/2009, you wrote: > >Thanks but the question is are the PP regulators linear or switchers? If they're internal, then they are duty-cycle switched. External can be either but linears are very rare. Probably less than 5% of the total market. As it turns out, all the excitement we had about 20 years ago for noise reduction by "going linear" was not well founded in physics. There's no reason for switchers . . . especially those that are built in . . . to be significant noise sources. Moral: don't shy away from switchers 'cause they're "quieter" . . . Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Subject: Re: KX-125 Installation Manual?
Date: Sep 18, 2009
Hi everybody. First post on Matronics forum :D I'm working on complete restoration of a long-EZ. The next step is the the wiring... I was unable to find the wiring diagram of the bendix King KX125. I will be very happy with the complete installation manual. Many thanks for your help. Overtorque Read this topic online here: http://forums.matronics.com/viewtopic.php?p=263704#263704 ________________________________________________________________________________
Date: Sep 18, 2009
With reference to the bus voltage discussion below: I have a B&C 55 amp alternator with a generic Ford regulator. The Ford regulator is bench adjustable and I had it set to 14.2 volts. My voltage sensing set up measures system voltage from the endurance bus and, under normal conditions, reads a steady 13.7 volts. Under normal (main bus) operation, the endurance bus gets its power via the main bus through a diode resulting in a measurable voltage drop. Switching to the endurance bus, power is provided directly to the endurance bus from the battery contactor and the voltage then reads a steady 14.2 volts. I can detect no change in avionics and instruments performance regardless of the bus used. In the situation cited below, system voltage may read low depending on where in the system the voltage is measured. Charlie Brame RV-6A N11CB San Anton -------------------------------------------------------- From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Subject: Re: AeroElectric-List: Bus Voltage At 10:27 AM 9/17/2009, you wrote: > In the comment below, Bob said that the bus (main?) should display > 14+ volts. Mine displays 13.5 with the engine running, 60A Plane > Power alternator on, and normal electrical loads of about 22-24 > Amps. Initial Amp spike is up to 45 just after start as battery > recharges, but volts average 13.5 with occasional spike to 13.7. > Should the PP alternator be putting out more? Yes . . . and it MAY be . . . > Is it adjustable? I don't think so. Plane Power starts with a suitable IR alternator core and simply modifies it to bring the field supply lead to the outside world so that OV protection and pilot operated switches have ABSOLUTE, LOW-ENERGY control over alternator operations. Internal regulators for alternators are modern integrated circuits. Its EASY to trim their regulation set-points for the design goal value during manufacture. 14.2 to 14.6 volts has been the benchmark window for as long as I can remember. I'm not aware of any example of user adjustable, internal regulators. Let's eliminate potential sources of uncertainty. First, make sure that the voltmeter you're citing agrees with other voltmeters to within 0.1 volts. Check it against a Fluke instrument if you can. Know too that the regulator senses voltage at the b-lead terminal . . . so it's possible that system loads combined with system wiring resistance between b-lead and your voltmeter's sense point may be accounting for your observation. GROUND systems can contribute to a voltage drop too. Do a voltage measurement right at the b-lead terminal reference to the alternator's case ground. The alternator may be performing as advertised with the voltage being tossed off in installation errors. Check with Plane Power. Ask them what their design-goal set-point value is. Just because I've never seen a 13.8v regulator doesn't mean they don't exist. Bob . . . ________________________________________________________________________________
Date: Sep 18, 2009
At 11:42 AM 9/18/2009, you wrote: > >Hi everybody. > >First post on Matronics forum :D >I'm working on complete restoration of a long-EZ. The next step is >the the wiring... I was unable to find the wiring diagram of the >bendix King KX125. I will be very happy with the complete installation manual. The only thing I have in my library is the pinout guide. See: http://www.aeroelectric.com/Installation_Data/KX125a.pdf Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Sep 18, 2009
Subject: Cleveland Wheels and Brakes
After listening to the praise for replacing the original Cleveland brakes with the Grove system for my Long EZ, I'm getting close to really needing them so finally decided to replace the Clevelands that I have. I now have some nice, shiny new Groves sitting here right now. They'll probably help a lot on the 3200 foot runway at Canandaigua when I get around to flying my Long EZ. So, I removed the Clevelands (that I've never used except as a stand for the Long EZ while I walked it around the hangar and my garage) and am selling the nearly new, never flown and never used over walking speed, Cleveland wheels and brakes. I wanted to offer it to the forums and groups I belong to first, before I put them on Barnstormers...and/or eBay...so I've put the pictures and all the information about them on my website: www.agelesswings.com/ClevelandWheelsAndBrakes.htm Have a look, and if you would like them, or know someone who does, send me an email...the web page and the pictures there should answer any question you may have. Harley Dixon Long EZ N28EZ (painting the belly of the fuselage) Hangar 29, Airport Canandaigua, NY ________________________________________________________________________________
Date: Sep 18, 2009
Thank you Bob, it is a first help, but not enough regarding my poor level in electricity. :D If someone has this doc... please, do not hesitate! Thanks Read this topic online here: http://forums.matronics.com/viewtopic.php?p=263716#263716 ________________________________________________________________________________
Date: Sep 18, 2009
Hi again, just received the documentation... Thank you all for your help! OT Read this topic online here: http://forums.matronics.com/viewtopic.php?p=263717#263717 ________________________________________________________________________________
Subject: Smart Start wire size
Date: Sep 18, 2009
I bought the Smart Start module from TCW and was just getting around to looking at the wire diagram and harness. All of the Aeroelectric diagrams show a 7 amp protected 20 AWG wire going to the start switch then on to the post on the start relay. The Smart Start module gets power from the main buss via 2 amp breaker or fuse and the wires in the entire harness are only 22 AWG. (http://tcwtech.com/Smartstart.htm) Wire diagram is at the link. So two wires connect to the start switch and go into the module and one wire goes to the small terminal on the start relay. Is the 22 AWG wire and 2 amp breaker too small. I can't see what determines wire size for this application. Since only 2 amps can flow into the module then the 22 AWG wire to the start relay is protected but what complication might there be with this setup. I guess I need to go back and read "the book" for the ump-teenth time! Thanks for any help. -------- Mike "Nemo" Elliott RV-8A QB (Fuselage) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=263752#263752 ________________________________________________________________________________
Subject: Z12 and IR Main Alt
Date: Sep 18, 2009
Without getting into the debate of IR vs Ext regulation, can a IR alternator be used in the Z12 system? Will the EXT regulator for the SD20 play nice with the IR of the main Alt? I have a buddy who has flown his RV8 for years, he is a EE major and loves the IR alternators. I respect his opinion and for cost sake I want to use the IR alternator, but I am designing my system with the Z12 diagram. My concern is will the SD20 regulator function properly with this, my guess is it will since it is just looking at the buss voltage to tell itself to start putting out power. Thanks for any help. -------- Mike "Nemo" Elliott RV-8A QB (Fuselage) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=263757#263757 ________________________________________________________________________________
Date: Sep 18, 2009
At 11:36 AM 9/18/2009, you wrote: >With reference to the bus voltage discussion below: > >I have a B&C 55 amp alternator with a generic Ford regulator. The >Ford regulator is bench adjustable and I had it set to 14.2 volts. >My voltage sensing set up measures system voltage from the endurance >bus and, under normal conditions, reads a steady 13.7 volts. Under >normal (main bus) operation, the endurance bus gets its power via >the main bus through a diode resulting in a measurable voltage drop. >Switching to the endurance bus, power is provided directly to the >endurance bus from the battery contactor and the voltage then reads >a steady 14.2 volts. I can detect no change in avionics and >instruments performance regardless of the bus used. Those readings are "as expected" and conform to design goals. >In the situation cited below, system voltage may read low depending >on where in the system the voltage is measured. Agreed. Once the energy leaves the alternator, the ONLY thing that can contribute to voltage drops is wire sizing versus loads on those wires . . . and (to a lesser extent) resistances that pile up in the sum-total of pressure joints. If the battery is measuring 14.2 to 14.6 then the alternator is doing it's job and the battery gets 100% topped off. Wire between the alternator and battery is always "fat" wires. After that, any unacceptable losses in available voltage MUST be from errors of design or installation. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Sep 18, 2009
At 01:44 PM 9/18/2009, you wrote: > >Hi again, just received the documentation... > >Thank you all for your help! What format? If it's a scanned .pdf file, I'd like to have a copy to add to the website library. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Subject: Re: Smart Start wire size
Date: Sep 18, 2009
The main current carrying wires for the smartstart module are the power input and the output to the contactor. The other wires to the start switch and interlock switch (if used) are signal level only. The start contactor will require a peak current of about 3.5 amps, this presents no issue for 22 awg wire as the voltage drop over 10-15 feet of wire at this current level is negligible. Since the start contactor operation is such a short duration and is not a continuous duty load the fusing may be reduced below that of the continuous rating. The SmartStart module itself can handle contactor currents of up to 10 amps peak. You may certainly raise the fuse rating if you wish to 5 amps without bumping into any issues as permitted by 43.13. However, we have found a 2 amp fuse is sufficient. Bob Newman TCW Technologies, LLC. www.tcwtech.com ----- Original Message ----- From: "rvg8tor" <rvg8tor(at)comcast.net> Sent: Friday, September 18, 2009 8:32 PM Subject: AeroElectric-List: Smart Start wire size > > I bought the Smart Start module from TCW and was just getting around to > looking at the wire diagram and harness. All of the Aeroelectric diagrams > show a 7 amp protected 20 AWG wire going to the start switch then on to > the post on the start relay. > > The Smart Start module gets power from the main buss via 2 amp breaker or > fuse and the wires in the entire harness are only 22 AWG. > (http://tcwtech.com/Smartstart.htm) Wire diagram is at the link. > > So two wires connect to the start switch and go into the module and one > wire goes to the small terminal on the start relay. Is the 22 AWG wire > and 2 amp breaker too small. I can't see what determines wire size for > this application. Since only 2 amps can flow into the module then the 22 > AWG wire to the start relay is protected but what complication might there > be with this setup. I guess I need to go back and read "the book" for the > ump-teenth time! Thanks for any help. > > -------- > Mike "Nemo" Elliott > RV-8A QB (Fuselage) > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=263752#263752 > > > ________________________________________________________________________________
Date: Sep 18, 2009
Subject: Re: Z12 and IR Main Alt
At 08:04 PM 9/18/2009, you wrote: > >Without getting into the debate of IR vs Ext regulation, can a IR >alternator be used in the Z12 system? Sure . . . > Will the EXT regulator for the SD20 play nice with the IR of the main Alt? They never have to play together. One works or the other works. Not both. > I have a buddy who has flown his RV8 for years, he is a EE major > and loves the IR alternators. I respect his opinion and for cost > sake I want to use the IR alternator, but I am designing my system > with the Z12 diagram. My concern is will the SD20 regulator > function properly with this, my guess is it will since it is just > looking at the buss voltage to tell itself to start putting out power. You are correct. But consider too that IF the reason your main alternator is down is due to an OV condition and there's no automatic and effective means for taking it off line . . . having a standby alternator may be a moot point. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Sep 18, 2009
Stan, A good test is to compare the bus voltage with light loads to the bus voltage with heavy loads. If there is a big difference, then there is a lot of resistance in the circuit, possibly from too small wire or from bad connections. Joe ________________________________________________________________________________
Subject: Not aviation related... Electronic though. :)
Date: Sep 18, 2009
From: "Jeffery J. Morgan" <jmorgan(at)compnetconcepts.com>
Bob, I am looking for some direction on how to build a battery pack that will help power my video camera longer. I am certain that I can find what I need but looking for some direction or guidance to get it right. I have a camcorder that uses a power pack that converts from wall outlet to a 9.6 volt 0.8a output. The symbol has a solid line on top and three dots on the bottom which I assume to me DC voltage. Currently the battery in the camera will last about 60-75 minutes and I would like to try to double that capacity. I was thinking that I should be able to pull together a battery holder of 4 D cell batteries and reduce the voltage and amperage to get what I would need. I am not correct in that thinking? Currently the camera has a lithium Ion battery that holds that charge. I appreciate any direction you can give. Thanks Jeff ________________________________________________________________________________
Subject: RE: Not aviation related... Electronic though. :)
Date: Sep 19, 2009
My apologies to the list. I didn't send that correctly... -----Original Message----- From: Jeffery J. Morgan Sent: Friday, September 18, 2009 11:53 PM Subject: Not aviation related... Electronic though. :) Bob, I am looking for some direction on how to build a battery pack that will help power my video camera longer. I am certain that I can find what I need but looking for some direction or guidance to get it right. I have a camcorder that uses a power pack that converts from wall outlet to a 9.6 volt 0.8a output. The symbol has a solid line on top and three dots on the bottom which I assume to me DC voltage. Currently the battery in the camera will last about 60-75 minutes and I would like to try to double that capacity. I was thinking that I should be able to pull together a battery holder of 4 D cell batteries and reduce the voltage and amperage to get what I would need. I am not correct in that thinking? Currently the camera has a lithium Ion battery that holds that charge. I appreciate any direction you can give. Thanks Jeff ________________________________________________________________________________
Date: Sep 19, 2009
Hi Bob Please, find attached the manual installation for KX125 (pdf ) Your site is very helpful! Thank you very much! Guillaume 2009/9/19 Robert L. Nuckolls, III > nuckolls.bob(at)aeroelectric.com> > > At 01:44 PM 9/18/2009, you wrote: > >> >> Hi again, just received the documentation... >> >> Thank you all for your help! >> > > What format? If it's a scanned .pdf file, I'd > like to have a copy to add to the website library. > > > Bob . . . > > --------------------------------------- > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > --------------------------------------- > > ________________________________________________________________________________
Date: Sep 19, 2009
Subject: Re: RE: Not aviation related... Electronic though.
Jeff, 4 D cells is 4.8 volts long term, you'll need twice that many to get 9.6. Why not go to one of the battery suppliers and see if there is a larger capacity unit that fits your camera and gives the use time you want. $time$ thing and no worries about charging, connecting, weight, etc. Rick Girard On Sat, Sep 19, 2009 at 1:08 AM, Jeffery J. Morgan < jmorgan(at)compnetconcepts.com> wrote: > jmorgan(at)compnetconcepts.com> > > My apologies to the list. I didn't send that correctly... > > > -----Original Message----- > From: Jeffery J. Morgan > Sent: Friday, September 18, 2009 11:53 PM > To: 'aeroelectric-list(at)matronics.com' > Subject: Not aviation related... Electronic though. :) > > Bob, > > I am looking for some direction on how to build a battery pack that will > help power my video camera longer. I am certain that I can find what I > need but looking for some direction or guidance to get it right. > > I have a camcorder that uses a power pack that converts from wall outlet > to a 9.6 volt 0.8a output. The symbol has a solid line on top and three > dots on the bottom which I assume to me DC voltage. > > Currently the battery in the camera will last about 60-75 minutes and I > would like to try to double that capacity. I was thinking that I should > be able to pull together a battery holder of 4 D cell batteries and > reduce the voltage and amperage to get what I would need. I am not > correct in that thinking? > > Currently the camera has a lithium Ion battery that holds that charge. > > I appreciate any direction you can give. > > Thanks > Jeff > > ________________________________________________________________________________
Date: Sep 19, 2009
Bob, Thanks for the explanation, I was going to email you over the weekend so you would have my message in you inbox on Monday, lucky for me you watch this forum. I was confused and could not figure out why the small wire would be OK as I stated AEC Z-diagrams all show 20 AWG with 7 amp protection. The Van's diagram calls out 18 AWG wire. I suppose they like the larger gage wire for its durability. -------- Mike "Nemo" Elliott RV-8A QB (Fuselage) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=263804#263804 ________________________________________________________________________________
Date: Sep 18, 2009
At 07:32 PM 9/18/2009, you wrote: > >I bought the Smart Start module from TCW and was just getting around >to looking at the wire diagram and harness. All of the Aeroelectric >diagrams show a 7 amp protected 20 AWG wire going to the start >switch then on to the post on the start relay. > >The Smart Start module gets power from the main buss via 2 amp >breaker or fuse and the wires in the entire harness are only 22 AWG. >(http://tcwtech.com/Smartstart.htm) Wire diagram is at the link. > >So two wires connect to the start switch and go into the module and >one wire goes to the small terminal on the start relay. Is the 22 >AWG wire and 2 amp breaker too small. I can't see what determines >wire size for this application. Since only 2 amps can flow into >the module then the 22 AWG wire to the start relay is protected but >what complication might there be with this setup. I guess I need to >go back and read "the book" for the ump-teenth time! Thanks for any help. Wire per the manufacturer's instructions . . . but write to them and ask what to do about it if the starter contactor draws 5A. Most intermittent duty contactors require about that much. Their instructions seem to allude to a potential for damage to their product if the thing is used to control a modern, engagement/contactor solenoid like B&C, Skytec or similar automotive adaptations. The question to ask them is whether or not they can handle a 5A contactor and a system powered via 7A breaker/fuse through 20 AWG wire on pins 7 and 9. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Sep 19, 2009
:) Jeff, Rick makes a good suggestion. But assuming that a more robust battery is not available, an external battery pack is an option. An array of 4 ni-cad cells comes across the starting line at about 1.25 volts per cell so an array of 8 would get you 10 volts. Alkaline cells start out a bit hotter at 1.5 volts per cell so you only need 7 cells to get 10.5 volts as a starting point. What the energy rating of your existing battery pak? The camera will be pretty tolerant of input voltage fed through it's external power jack. Unless the 'wall wart' power supply is internally REGULATED, then the 9.6v value is a nominal number and the camera will probably perform over a range of 8 to 12 volts or something like that. I used to run external 4-paks of d-alkalines on my Vivitar 283 flash guns. This gave me enough energy to do a 4-hour shoot without concerns for battery replacement. Further, the low impedance of the d-cells gave very fast recycle time on the flash gun, not unlike the recycle time I got with freshly charged ni-cads. The batty box hung off my belt and plugged into the flash-gun's external power jack through a coil-cord. For your application, you might consider an 8-pak of C-nicads like http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=SY123T-ND These offer 3,000 mAh of capacity. If you want more, there are some D-cells (harder to find) that will go up to 4,000 or more. These have solder tabs and will assemble into a pack that is MUCH more reliably connected than the spring-loaded battery boxes for individual cells. You could bring a lead-wire out at the center-tap. To charge this pack, a simple 120 vac line cord that feeds a series connection of 1N4007 diode and 7-15W light bulb will emulate a 40-100 mA constant current charter that takes awhile to recharge the cells but won't seriously over-charge them. Is this a portable application or running in a vehicle? You could craft a 9.6 v REGULATED adapter to run the camera from a vehicle's electrical system. Alternatively, you can go with a 7-pak of D-alkaline cells and throw them away when used up. This will offer MORE capacity than a rechargeable pak of the same size, somewhat less expensive to build. But after you've gone thorough 10-15 sets of alkaline cells, you've expended the cash for one set of ni-cads. Of course, you don't have the hassles of waiting for a ni-cad pack to recharge either. Your ultimate choice needs to fit design goals. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Subject: Re: Not aviation related... Electronic though. :)
Date: Sep 19, 2009
Instead of building, how about checking for bigger capacity batteries. I have used larger capacity batteries from eaglecool dot com for my JVC digital video recorders. They have worked well and the company has stood behind their warranties ok. On the other hand, I have built external battery packs for my camera flash equipment (Vivitar and Nikon) by using sealed gel cell off-the-shelf 6v batteries (4+ amphour)with custom built/modified (by me) power cables. But when you get into voltages like 7.2 or 9.6, etc. you could build external packs using "D" 1.2v rechargeable batteries in series as long as you can figure out a way to build/buy a power cable. -Ed- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=263838#263838 ________________________________________________________________________________
Date: Sep 19, 2009
Joe, Thanks for your comment. I have taken notice of the voltage during light and heaviest loads and it remains steady at 13.5. The light loading was about 3 Amps and heavy was about 32A (everything on). So, I'll take readings as Bob suggested and see what I find. Stan Stan, A good test is to compare the bus voltage with light loads to the bus voltage with heavy loads. If there is a big difference, then there is a lot of resistance in the circuit, possibly from too small wire or from bad connections. Joe ________________________________________________________________________________
Date: Sep 19, 2009
:) Robert L. Nuckolls, III wrote: > > > Jeff, > > Rick makes a good suggestion. But assuming that a more robust battery > is not available, an external battery pack is an option. An array of > 4 ni-cad cells comes across the starting line at about 1.25 volts per > cell so an array of 8 would get you 10 volts. Alkaline cells start out > a bit hotter at 1.5 volts per cell so you only need 7 cells to get 10.5 > volts as a starting point. > > What the energy rating of your existing battery pak? > > The camera will be pretty tolerant of input voltage fed through it's > external power jack. Unless the 'wall wart' power supply is internally > REGULATED, then the 9.6v value is a nominal number and the camera will > probably perform over a range of 8 to 12 volts or something like that. > > I used to run external 4-paks of d-alkalines on my Vivitar 283 flash > guns. > This gave me enough energy to do a 4-hour shoot without concerns > for battery replacement. Further, the low impedance of the d-cells > gave very > fast recycle time on the flash gun, not unlike the recycle time I got > with freshly charged ni-cads. The batty box hung off my belt and plugged > into the flash-gun's external power jack through a coil-cord. > > For your application, you might consider an 8-pak of C-nicads like > > http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=SY123T-ND > > > These offer 3,000 mAh of capacity. If you want more, there are some > D-cells (harder to find) that will go up to 4,000 or more. > > These have solder tabs and will assemble into a pack that is MUCH > more reliably connected than the spring-loaded battery boxes for > individual cells. You could bring a lead-wire out at the center-tap. > To charge this pack, a simple 120 vac line cord that feeds a series > connection of 1N4007 diode and 7-15W light bulb will emulate a 40-100 mA > constant current charter that takes awhile to recharge the cells but > won't seriously over-charge them. > > Is this a portable application or running in a vehicle? You could > craft a 9.6 v REGULATED adapter to run the camera from a vehicle's > electrical system. > > Alternatively, you can go with a 7-pak of D-alkaline cells and > throw them away when used up. This will offer MORE capacity than > a rechargeable pak of the same size, somewhat less expensive to > build. But after you've gone thorough 10-15 sets of alkaline cells, > you've expended the cash for one set of ni-cads. Of course, you don't > have > the hassles of waiting for a ni-cad pack to recharge either. Your > ultimate choice needs to fit design goals. > > > Bob . . . I like finding similar products from higher volume (ie: lower cost) markets. http://www.batteryjunction.com/9-6-pk.html Used something similar in an old handheld radio to replace dead nicads & had to pack most of the case with cardboard/foam to stabilize the smaller batteries. Also had about twice the capacity. Charlie Charlie ________________________________________________________________________________
Subject: strobe lights
Date: Sep 19, 2009
For anyone interested in this sort of thing=2C here is some information on test standards. http://physics.nist.gov/Divisions/Div844/facilities/photo/Flash/flash.html Deems Herring =0A _________________________________________________________________=0A Lauren found her dream laptop. Find the PC that=92s right for you.=0A http://www.microsoft.com/windows/choosepc/?ocid=ftp_val_wl_290 ________________________________________________________________________________
Date: Sep 19, 2009
Subject: Alternator mod article
Hi - I just wanted to make sure you saw the DIY alternator article, from one of the Quickie guys - Lynn French. I don't know if Lynn is on this, or not. http://www.eaa.org/experimenter/articles/2009-09_howto_alternator.asp Sam ________________________________________________________________________________
Subject: Alkaline vs. Lithium
Date: Sep 19, 2009
I was at my hangar taking alkaline batteries out of all of my battery powered tools. I had one Ray-O-Vac AA alkaline battery leaking, and I cleaned up the mess with baking soda. Most of the batteries were installed between 2002 and 2006 except for the digital torque wrench and digital airplane scale. Those batteries were relatively new. Some of these tools cost a lot of money, and I don't want to damage them. Therefore, I would like to get an opinion on whether I should migrate to lithium AA and 9V batteries. Is lithium technology safer than alkaline technology? I was at Home Depot today and saw two Duracell 9V lithium batteries in a pack for $7. That's $3.50 per battery, which brings it very close to the price of an alkaline battery. Even if it were X2 or X3, lithium batteries have a greater shelf life and higher energy density, so maybe they are cost effective at those greater prices. Has Bob or anyone else done a cost analysis on these two technologies to see how lithium stands against alkaline? I'd like to migrate to lithium just for its safety factor - if it doesn't leak or catch on fire in normal usage, but cost effectiveness would be a bonus. Simon Ramirez Copyright 2009 ________________________________________________________________________________
Date: Sep 19, 2009
My system on an RV-10 is very close to what you describe; a Plane Power 60 amp main IR alternator and a B&C 20 amp standby with B&C external linear regulator. System is wired very close to Z-12 and is working fine. Dick Sipp -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of rvg8tor Sent: Friday, September 18, 2009 9:04 PM Subject: AeroElectric-List: Z12 and IR Main Alt Without getting into the debate of IR vs Ext regulation, can a IR alternator be used in the Z12 system? Will the EXT regulator for the SD20 play nice with the IR of the main Alt? I have a buddy who has flown his RV8 for years, he is a EE major and loves the IR alternators. I respect his opinion and for cost sake I want to use the IR alternator, but I am designing my system with the Z12 diagram. My concern is will the SD20 regulator function properly with this, my guess is it will since it is just looking at the buss voltage to tell itself to start putting out power. Thanks for any help. -------- Mike "Nemo" Elliott RV-8A QB (Fuselage) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=263757#263757 ________________________________________________________________________________
Subject: Fixed connector on the Transponder Mounting Tray
Date: Sep 20, 2009
Where can I get the connector that fits onto the mounting tray [fixed onto the tray with a circlip] between the KT 76A transponder BNC and the aerial BNC connector [joins these two].Any part numbers???? Cheers Read this topic online here: http://forums.matronics.com/viewtopic.php?p=263931#263931 ________________________________________________________________________________
Subject: Kitplanes article on solar power
Date: Sep 20, 2009
Hi guys I am a Kitplanes subscriber, but I don't know my subscriber number, therefore I cannot access Kitplanes back issues. I will get my web access when I receive my next issue. Meanwhile, I need to consult one particular article, which is Jim Weir's article about solar power battery charging, which was published in the January 2007 Kitplanes issue. Can somebody of you who is (or was) a Kitplanes subscriber, please scan that article, or access the web at kitplanes.com and get the pdf, and send it to my email address. Thanks in advance Carlos Trigo Portugal RV-9A (90% done and 90% still to go) ________________________________________________________________________________
Subject: P-mag Internal Power Test
Date: Sep 20, 2009
I am getting my wiring started and have a question on how some of you with P-Mags wired your systems. There are two tests for th P-Mag as I understand things. One is just like a traditional magneto check, you turn off (ground the p-lead) and check for mag drop. The other check for a P-Mag is to turn off the 12v power to the P-Mag to check that the internal alternator keeps the magneto running. The check of the internal alternator does not seem like something that needs to be check each flight. I am considering just pulling the CB for each P-Mag to make this check rather than wiring a switch to serve this purpose. What have others done with regard to this, I don't want to use a switched breaker, I will just add the switch if it is required. My thinking is to just pull the breaker. We pull breaker on the B-767 at the end of each flight to turn some equipment off while the plane sits between flights, so I don't think there is an issue of waring out a breaker. Thanks for any pointers. -------- Mike "Nemo" Elliott RV-8A QB (Fuselage) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=263999#263999 ________________________________________________________________________________
From: "David & Elaine Lamphere" <dalamphere(at)comcast.net>
Subject: Re: P-mag Internal Power Test
Date: Sep 20, 2009
I used a normally-closed single-pole single-throw (momentarily opens against spring) switch in series with the PMag 12V circuit breaker. That said - it is YOUR plane and if YOU want it a certain way (and the inspector doesn't object) - that's your choice (and risk). :-) Got the switch from Mouser. Dave L. ----- Original Message ----- From: "rvg8tor" <rvg8tor(at)comcast.net> Sent: Sunday, September 20, 2009 4:45 PM Subject: AeroElectric-List: P-mag Internal Power Test > > I am getting my wiring started and have a question on how some of you > with P-Mags wired your systems. There are two tests for th P-Mag as I > understand things. One is just like a traditional magneto check, you turn > off (ground the p-lead) and check for mag drop. The other check for a > P-Mag is to turn off the 12v power to the P-Mag to check that the internal > alternator keeps the magneto running. The check of the internal > alternator does not seem like something that needs to be check each > flight. I am considering just pulling the CB for each P-Mag to make this > check rather than wiring a switch to serve this purpose. > > What have others done with regard to this, I don't want to use a switched > breaker, I will just add the switch if it is required. My thinking is to > just pull the breaker. We pull breaker on the B-767 at the end of each > flight to turn some equipment off while the plane sits between flights, so > I don't think there is an issue of waring out a breaker. Thanks for any > pointers. > > -------- > Mike "Nemo" Elliott > RV-8A QB (Fuselage) > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=263999#263999 > > > ________________________________________________________________________________
Date: Sep 20, 2009
Subject: Re: Alternator mod article
At 05:00 PM 9/19/2009, you wrote: >Hi - I just wanted to make sure you saw the DIY alternator article, >from one of the Quickie guys - Lynn French. I don't know if Lynn is >on this, or not. > ><http://www.eaa.org/experimenter/articles/2009-09_howto_alternator.asp>http://www.eaa.org/experimenter/articles/2009-09_howto_alternator.asp > >Sam Thanks for the heads-up on this Sam. I've archived it in a .pdf file and will mirror it to the website at the next update. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Sep 20, 2009
Subject: Re: Fixed connector on the Transponder Mounting Tray
At 02:01 AM 9/20/2009, you wrote: > >Where can I get the connector that fits onto the mounting tray >[fixed onto the tray with a circlip] between the KT 76A transponder >BNC and the aerial BNC connector [joins these two].Any part numbers???? Cheers This puppy has been around for many years. The tray side is a Ted 9-30-10. There's a number of them on Ebay right now. Emacs! Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Sep 20, 2009
At 02:01 AM 9/20/2009, you wrote: > >Where can I get the connector that fits onto the mounting tray >[fixed onto the tray with a >circlip] between the KT 76A transponder BNC and the aerial BNC >connector [joins these two] >.Any part numbers???? Cheers I forgot that I'd fielded this question some time back and posted pictures at: http://www.aeroelectric.com/Pictures/Connectors/Coax/ Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Sep 20, 2009
At 03:45 PM 9/20/2009, you wrote: > >I am getting my wiring started and have a question on how some of >you with P-Mags wired your systems. There are two tests for th >P-Mag as I understand things. One is just like a traditional >magneto check, you turn off (ground the p-lead) and check for mag >drop. The other check for a P-Mag is to turn off the 12v power to >the P-Mag to check that the internal alternator keeps the magneto >running. The check of the internal alternator does not seem like >something that needs to be check each flight. I am considering just >pulling the CB for each P-Mag to make this check rather than wiring >a switch to serve this purpose. > >What have others done with regard to this, I don't want to use a >switched breaker, I will just add the switch if it is required. My >thinking is to just pull the breaker. We pull breaker on the B-767 >at the end of each flight to turn some equipment off while the plane >sits between flights, so I don't think there is an issue of waring >out a breaker. Thanks for any pointers. What you've proposed is consistent with Emagair's recommendations. In fact, Figure Z13/8 was crafted with a similar philosophy. http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z13-8Q.pdf Note that with ship's power taken through a fuse from the main bus, the internal power source integrity can be verified occasionally by checking engine operations on the p-mag while the main bus is down. Easy to do under comfortable conditions and only occasionally. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Sep 20, 2009
nuckolls.bob(at)aeroelect wrote: > At 02:01 AM 9/20/2009, you wrote: > > > > > > > Where can I get the connector that fits onto the mounting tray > > [fixed onto the tray with a > > circlip] between the KT 76A transponder BNC and the aerial BNC > > connector [joins these two] > > > > > > > > .Any part numbers???? Cheers > > > > > > I forgot that I'd fielded this question > some time back and posted pictures at: > > http://www.aeroelectric.com/Pictures/Connectors/Coax/ > > > Bob . . . > > --------------------------------------- > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > --------------------------------------- How does a BNC connector hook up with these connectors, like the end on a TED aerial??? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264081#264081 ________________________________________________________________________________
Subject: KY97A wiring diagram and TERRA TRT250
Date: Sep 20, 2009
Good morning all, I noticed the power of the forum... and now, I need 2 others installation manuel: VHF KY97A Transponder TERRA TRT 250 Thank you very much if you can send theses docs OT Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264083#264083 ________________________________________________________________________________
Date: Sep 21, 2009
Hi Mike, Here is some additional info. I got from Emagair directly last year when researching the units. I personally have wired up according to Z13, with two switches for each unit, p-lead and power. I don't have CBs for the circuits, rather fuses. Regards, Andrew. ------------------------------------------------------------------------------------------------------------------- From: info(at)emagair.com [mailto:info(at)emagair.com] Sent: 09 May 2008 16:57 Subject: RE: Startup Checks Andrew: When an ignition is first powered up it has to wake up, load the operating code, track engine position, determine when the next spark even needs to happen, and finally trigger that spark event. If you power up while the engine is running all this has to happen very quickly. Since P models make their own power (as long as the engine is running), you cannot shut down the processor. You can turn both the p-lead and the 12 supply OFF and it will still be "awake" doing its business as usual, waiting to resume firing as soon as the p-lead is ungrounded. With E models, however, you can power them OFF when running, and the ignition (truly) will go dark - still no problem. Powering the E model OFF is not the issue. It's when you 1) power an E model ON (while the engine is running) and 2) with the p-lead ungrounded that you are asking it to instantaneously wake up and start firing as described above. The condition can be avoided (if encountered) by making sure the p-lead is grounded (OFF) before powering (12 volt) ON an E model ignition while the engine is running. Even so, if this happens, we aren't predicting disaster. It will probably resume operation just fine, but there is no reason to do it in the first place - that's all. I don't recall any customers (yet) in Ireland - congratulations, you'll be number 1. Kindest Regards, Brad Dement E-MAG Ignitions 2014 Greg Street Box 112 Azle, Texas 76020 (817) 444-5310 From: Butler, Andrew [mailto:andrew.butler(at)nuigalway.ie] Sent: Friday, May 09, 2008 10:29 AM Subject: RE: Startup Checks Thanks very much Brad. What is the logic behind not switching off power to an E-MAG while the engine is running? I am assuming that switching off power is okay, that it is switching power back on while the engine is turning that is the problem. What exactly is the event sequence associated with switching on power while the engine is turning that is problematic? Why is it problematic to turn power on while the P-MAG is live i.e ungrounded? I am not installing a rotary key switch, rather an individual power switch for each ignition. It appears that I will need a two position switch that allows me to control access to power and ground individually. Cheers, Andrew. RV71700 Galway, Ireland. From: info(at)emagair.com [mailto:info(at)emagair.com] Sent: 08 May 2008 17:07 Subject: RE: Startup Checks Hi Andrew: Thanks for considering us for your project. The ignition check for E-MAG ignitions is very similar to that of magnetos. You'll do your regular L/R (p-lead) check to make sure both ignitions operate. The only difference is that for each P model ignition you have installed (one or both) you'll add one additional sequence. While switched to the individual P model(s), simply turn OFF the 12 volt power that feeds that ignition for a few seconds to verify the engine continues to run. If the engine runs, the internal alternator is operating. If the engine quits, the alternator is not working. The engine speed should be 1000 rpm or greater when you do this check. There is no need to do this test with an E model as they don't have an alternator. The L/R test is a p-lead (ON/OFF) test applicable to both E and P models. The 12 power (ON/OFF) test is applicable to P models only, and we discourage doing it with E models, so the FAQ you refer to is not in conflict with the pre-flight ignition tests. The Installation and Operating Guide also has some recommendations on starting with our equipment - see Downloads page on our web site. Don't hesitate to call or drop us a note if you have any other questions. Kindest Regards, Brad Dement E-MAG Ignitions 2014 Greg Street Box 112 Azle, Texas 76020 (817) 444-5310 ------------------------------------------------------------------------------------------------------- ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Sent: Monday, 21 September, 2009 2:11:36 AM GMT +00:00 GMT Britain, Ireland, Portugal Subject: Re: AeroElectric-List: P-mag Internal Power Test At 03:45 PM 9/20/2009, you wrote: > >I am getting my wiring started and have a question on how some of >you with P-Mags wired your systems. There are two tests for th >P-Mag as I understand things. One is just like a traditional >magneto check, you turn off (ground the p-lead) and check for mag >drop. The other check for a P-Mag is to turn off the 12v power to >the P-Mag to check that the internal alternator keeps the magneto >running. The check of the internal alternator does not seem like >something that needs to be check each flight. I am considering just >pulling the CB for each P-Mag to make this check rather than wiring >a switch to serve this purpose. > >What have others done with regard to this, I don't want to use a >switched breaker, I will just add the switch if it is required. My >thinking is to just pull the breaker. We pull breaker on the B-767 >at the end of each flight to turn some equipment off while the plane >sits between flights, so I don't think there is an issue of waring >out a breaker. Thanks for any pointers. What you've proposed is consistent with Emagair's recommendations. In fact, Figure Z13/8 was crafted with a similar philosophy. http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z13-8Q.pdf Note that with ship's power taken through a fuse from the main bus, the internal power source integrity can be verified occasionally by checking engine operations on the p-mag while the main bus is down. Easy to do under comfortable conditions and only occasionally. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Subject: Flightcom headset
Date: Sep 21, 2009
--- MIME Errors - No Plain-Text Section Found --- A message with no text/plain MIME section was received. The entire body of the message was removed. Please resend the email using Plain Text formatting. HOTMAIL is notorious for only including an HTML section in their client's default configuration. If you're using HOTMAIL, please see your email application's settings and switch to a default mail option that uses "Plain Text". --- MIME Errors No Plain-Text Section Found --- ________________________________________________________________________________
Subject: Re: Kitplanes article on solar power
Date: Sep 21, 2009
Carlos, Try this link: http://www.kitplanes.com/issues/pdfs/0107-6566.pdf Jim Weir's website: http://www.rst-engr.com/rst/contact_us.html I will send an email to you with a scanned copy of the schematic. Joe Michigan USA ________________________________________________________________________________
Date: Sep 21, 2009
At 06:47 AM 9/21/2009, you wrote: > > >Hi Mike, > >Here is some additional info. I got from Emagair directly last year >when researching the units. I personally have wired up according to >Z13, with two switches for each unit, p-lead and power. I don't have >CBs for the circuits, rather fuses. > >Regards, Andrew. Thanks for that expansion Andrew. I had a similar dissertation from the guys at Emagair but couldn't lay my hands on it last night. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Subject: Dual Battery Dual Alternator Grounding
Date: Sep 21, 2009
I have two #2 AWG cables running from the back of my RV-10 to the firewall. My question is if I put in two batteries and two alternators, where do I ground each one. Van's plans show the grounding at the behind the baggage bulk head. Could both batteries be grounded there to a common ground? I intended to use the second cable as a ground from the battery to the firewall, but Van's shows it to be grounded to the battery box. Sorry if this has already been addressed dsyvert Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264118#264118 ________________________________________________________________________________
Date: Sep 21, 2009
Tray >How does a BNC connector hook up with these connectors, like the end >on a TED aerial??? > These connectors accept a prepared end of the antenna's feed-line coax. They are solder joints for both the center conductor and shield. If you want to break that feedline with a connector adjacent to the radio, then the segment that comes off the slip-connector is simply shortened to a pigtail of the desired length which is then terminated in a cable-female . . . http://www.aeroelectric.com/Pictures/Connectors/Coax/BNC_Cable_Female_2.jpg Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Sep 21, 2009
Subject: Re: Flightcom headset
At 07:58 AM 9/21/2009, you wrote: > > > >Not usual for me this kind of assistance. > >Thank you Becky and thank you Flightcom. > >A very good headset and an excellent service. > >Luigi Your observations agree with my own. The few times I've had occasion to communicate with Flightcom, their willingness to share has been exemplary . . . and I'm not even a customer! Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Sep 21, 2009
Subject: Re: Dual Battery Dual Alternator Grounding
At 09:20 AM 9/21/2009, you wrote: > >I have two #2 AWG cables running from the back of my RV-10 to the >firewall. My question is if I put in two batteries and two >alternators, where do I ground each one. Van's plans show the >grounding at the behind the baggage bulk head. Could both batteries >be grounded there to a common ground? I intended to use the second >cable as a ground from the battery to the firewall, but Van's shows >it to be grounded to the battery box. Independent grounds to structure will be consistent with design goals for elimination of single points of failure. See . . . http://aeroelectric.com/Pictures/Batteries/Battery_Install_OBrien_2.jpg do this for EACH battery. Also, 4AWG welding cable jumpers from battery(+) to contactor and battery(-) to ground are a good idea to minimize mechanical stress on terminals. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Sep 21, 2009
Subject: Re: Bus Voltage
Joe, I took careful notice of the bus voltage yesterday as I loaded up the bus and you've brought up a good point. At an 8 amp load, the bus voltage was 13.5. At 29 amps it dropped to 13.2 and stayed there until I reduced the load. So, I must have too small a wire from the alternator to the bus. I'll consider changing it. Thanks, Stan Sutterfield Joe, Thanks for your comment. I have taken notice of the voltage during light and heaviest loads and it remains steady at 13.5. The light loading was about 3 Amps and heavy was about 32A (everything on). So, I'll take readings as Bob suggested and see what I find. Stan Stan, A good test is to compare the bus voltage with light loads to the bus voltage with heavy loads. If there is a big difference, then there is a lot of resistance in the circuit, possibly from too small wire or from bad connections. Joe ________________________________________________________________________________
Date: Sep 21, 2009
Subject: Re: Van's gauges
At 12:46 PM 9/14/2009, you wrote: >In 420 house over three plus years a number of Van's gauges have >failed (fuel quantity, volts, amps, oil pressure). Now I must >install the third volt meter. I like the look of Van's gauges and >the fact that they match, but don't like the failure rate. What >have your experiences been? > >Pete in Clearwater >RV-6 - Reserve Grand Champion, S 'n F 2006 and other awards > >---------- Peter, Sorry to hear about this . . . I've got a Van's ammeter on the bench which I disassembled to look at. Hand- assembled, thru-hole components (not necessarily a 'bad' thing, especially in TC aviation!). However, the ammeter proved to be exceptionally vulnerable to radio-frequency fields (hand held). It's a line-item on my things-to-do list to see what sort of filter/shielding would reduce the effects to acceptable levels. My discovery raises a perplexing question . . . How much of the technology and design goals for the ammeter are common to the rest of the product line? Of course, my question only goes to system integration . . . a question which is moot if the critters have an unacceptable failure rate. Your question is the first I've heard of it. I'd be pleased to have updates from the rest of List membership. P.S. Sorry we didn't get together while attending to Dr. Dee at the convention last winter. It was an interesting and opportunity-packed event. I don't think we got out of the hotel more than a half dozen trips to local eateries! Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Sep 21, 2009
Subject: Re: Filter for Hand held devices
At 08:11 AM 9/14/2009, you wrote: > >I think that I do need one; I am using a cigarette lighter type connection >to power an Ipod power supply. When I connect this to the Ipod no noise is >heard, but when I connect the Ipod to the radio/ intercom system I >immediately get a high pitched noise in the earphones. Okay, 'high pitched' is not alternator noise. It MIGHT be an artifact of the dc/dc converter in your ipod power adapter. Try first to power the Ipod internally without the adapter. Does the noise go away? Try powering the adapter fromits own 12 battery pack NOT connected to the a/c in any way. A couple of el-cheeso 6v lantern batteries in series a good diagnostic supply. > I separated the >power and signal leads and the noise stayed. I moved the power supply of >the cigarette/ Ipod charger directly to the battery and the noise stayed. I >will still try a twisted pair on the power supply to the radio/intercom but >it seems to me that the noise is generated by the Ipod charger so I thought >that a filter might do the trick. Perhaps even a ferrite bead on the >positive in to the radio will work. > >The only other thing that I can think of is that the loop formed by the >plug->Ipod charger->Ipod audio out->radio/intercom is somehow causing the >problem; but how does one get rid of that loop- its intrinsic to the music >input? It's most likely to be a ground loop issue which will be re-enforced or denied by the above experiments. In any case, it's almost a certainty that filtering is not solution for root cause. We may have to incorporate an isolation transformer where audio from your Ipod goes to one winding and audio to the ship's system is taken from the other winding. See: http://www.radioshack.com/product/index.jsp?productId=2103994 Bob . . . ________________________________________________________________________________
Date: Sep 21, 2009
Just for information of those on the list, I recently had a faulty 12V charger on an AV8OR. The manufacturer willingly changed it. The symptoms were more your conventional white noise type static, like a very weak radio signal - there when charging the AV8OR, gone when not. It interfered with radio reception in the car and in the aircraft. I'm not proposing it as the cause of the IPOD problem below, just a useful data point. Faulty chargers do indeed seem capable of generating interference but not, in my case, a high pitched noise. Ian Brown Bromont, Quebec > >The only other thing that I can think of is that the loop formed by the > >plug->Ipod charger->Ipod audio out->radio/intercom is somehow causing the > >problem; but how does one get rid of that loop- its intrinsic to the music > >input? > > It's most likely to be a ground loop issue which will be > re-enforced or denied by the above experiments. > > In any case, it's almost a certainty that filtering > is not solution for root cause. > > We may have to incorporate an isolation transformer > where audio from your Ipod goes to one winding and > audio to the ship's system is taken from the other > winding. See: ________________________________________________________________________________
Date: Sep 21, 2009
Subject: Van's gauges
I also used Van's Gauges. I had trouble with the ammeter also. Never did get it to work quite right. It worked OK until you transmitted. The oil pressure gauge only worked when the engine oil was cold. After the temperature climbed to normal temps, the pressure would drop to 20 of 30 ps i, sometimes to 0. The rest of my Vans gauges (fuel quant, fuel pressure, tachometer, volt met er, manifold pressure) worked great after 300 hrs. John Danielson ________________________________ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectr ic-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Monday, September 21, 2009 2:08 PM Subject: Re: AeroElectric-List: Van's gauges At 12:46 PM 9/14/2009, you wrote: In 420 house over three plus years a number of Van's gauges have failed (fu el quantity, volts, amps, oil pressure). Now I must install the third volt meter. I like the look of Van's gauges and the fact that they match, but don't like the failure rate. What have your experiences been? Pete in Clearwater RV-6 - Reserve Grand Champion, S 'n F 2006 and other awards ________________________________ Peter, Sorry to hear about this . . . I've got a Van's ammeter on the bench which I disassembled to look at. Hand- assembled, thru-hole components (not necessarily a 'bad' thing, especially in TC aviation!). However, the ammeter proved to be exceptionally vulnerable to radio-frequency fields (hand held). It's a line-item on my things-to-do list to see what sort of filter/shielding would reduce the effects to acceptable levels. My discovery raises a perplexing question . . . How much of the technology and design goals for the ammeter are common to the rest of the product line? Of course, my question only goes to system integration . . . a question which is moot if the critters have an unacceptable failure rate. Your question is the first I've heard of it. I'd be pleased to have updates from the rest of List membership. P.S. Sorry we didn't get together while attending to Dr. Dee at the convention last winter. It was an interesting and opportunity-packed event. I don't think we got out of the hotel more than a half dozen trips to local eateries! Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Sep 21, 2009
Subject: Aerobatics and Instrument Damage
I have completed some excellent Unusual Attitude training in a Cap-10 which included loops, rolls and spins and will soon complete additional aerobatic training. Then I would like to try some of these aerobatics maneuvers in my RV-6. However, I am a little concern that the gyro tumbling and/or G forces of aerobatics may hurt my instruments. I have an AI, HSI and S-TEC autopilot all containing electric gyros and would hate to damage them. What has been your experience with aerobatics and instrument damage? Should I be concerned about this? Pete in Clearwater RV-6, Day/night IFR, Reserve Grand Champion S 'n F ________________________________________________________________________________
Date: Sep 21, 2009
Subject: Re: Aerobatics and Instrument Damage
Good Evening Peter, As Always, It All Depends! Your S-Tec uses the canted gyro in the Turn Coordinator for it's sensing device. That gyro will not be harmed by aerobatics. The attitude and heading gyros MAY be damaged! There are many different designs and your best bet is to check with the manufacturer of your instrumentation. Some of the newer instruments are suitable for aerobatic use. There were some fully aerobatic artificial horizons built about fifty years ago, but the pitch indication was just the opposite of what is standard today. There are a few older gyros that allow the gyros to be caged, but that is not a real good idea. It can keep the gyro from banging the stops, but the bearings will still incur abnormal wear. The best bet is to have a removable gyro panel to be used when not flying aerobatics. A few of the professional aerobatic pilots have made such a set up to save wear and tear during violent aerobatic flight. One more comment if you don't mind. The turn Coordinator (as is used by S-Tec for sensing) is an abominable instrument in that it never tells the truth. For use during aerobatics, I much prefer a standard old fashioned Turn needle combined with an inclinometer Ball. The classic needle and ball. It is the most reliable directional instrument you can buy and it can be used for spin recovery as well as unusual attitude recovery. A turn coordinator can provide confusing and counterproductive indications during a spin recovery. However, neither the T&B nor the TC will be damaged by doing such maneuvers. Many of the modern glass panels use solid state "gyros" that are not damaged by aerobatics, but some will lose proper sensing. Any help at all? Happy Skies, Old Bob AKA Bob Siegfried Downers Grove, Illinois LL22 Stearman N3977A In a message dated 9/21/2009 9:22:37 P.M. Central Daylight Time, PeterHunt1(at)aol.com writes: I have completed some excellent Unusual Attitude training in a Cap-10 which included loops, rolls and spins and will soon complete additional aerobatic training. Then I would like to try some of these aerobatics maneuvers in my RV-6. However, I am a little concern that the gyro tumbling and/or G forces of aerobatics may hurt my instruments. I have an AI, HSI and S-TEC autopilot all containing electric gyros and would hate to damage them. What has been your experience with aerobatics and instrument damage? Should I be concerned about this? Pete in Clearwater RV-6, Day/night IFR, Reserve Grand Champion S 'n F (http://www.matronics.com/Navigator?AeroElectric-List) (http://www.matronics.com/contribution) ________________________________________________________________________________
Date: Sep 21, 2009
At 04:18 PM 9/21/2009, you wrote: >Just for information of those on the list, I recently had a faulty >12V charger on an AV8OR. The manufacturer willingly changed >it. The symptoms were more your conventional white noise type >static, like a very weak radio signal - there when charging the >AV8OR, gone when not. It interfered with radio reception in the >car and in the aircraft. I'm not proposing it as the cause of the >IPOD problem below, just a useful data point. Faulty chargers do >indeed seem capable of generating interference but not, in my case, >a high pitched noise. The modern DC/DC converter technology has become smaller and more efficient as the components became available to operate at high and higher frequencies. The DC to DC converters that we used in the Cessna Nav/Com 300 in 1965 ran at about 1 Khz . . . and had relatively benign RF interference potential. That little nugget of electronics that exists in the cigar lighter plug on your ipod or cell phone charger probably operates at 1000 to 2000 times higher frequency. These guys are much more likely to become noise emitters in the AM radio band. I've had several devices that I had to throw away and substitute another brand. Bob . . . Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
From: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net>
Subject: Transmit problem on both comm radios.
Date: Sep 22, 2009
Hi all: Maybe you can help with my transmit problems. I have a UPS Aviation Technologies (now Garmin AT) radio stack with SL-30 Nav Comm, GX-65 GPS/Comm, SL-70 transponder and SL-10MS audio panel (actually a PS-6000 with UPS AT nameplate). I checked out everything according to the installation manuals while the airplane was sitting on the ramp and the engine NOT running. Now that I've been flying a lot, I'm getting a crackling in the sidetone and when I look at the "TX" light on the radio it's flickering as if someone were pulsing the press-to-talk switch 4-5 times per second, even though I'm holding the PTT down tight. This happens on both radios and people in the pattern say I'm breaking up and garbled. I've tried several things looking for a solution, they are: 1) Turn down the MIC gains on both radios (in steps, a little at a time, over several flights). In the end I had them turned down so much I couldn't get a side tone in the earphones and suspect no-one could hear me at all. 2) I tried a couple different headsets (inexpensive non ANR types, Sigtronics and Pilot Avionics units, both around 15 years old but well taken care of and worked just fine in the Cessnas I used to rent). No joy. 3) I tried both headsets with and without foam muffs over the microphones. No difference that I could tell with or without the muffs. 4) Placed ferrite beads over both coax lines running to the transmit antennas (about 3/4 of the way down to the antennas, don't have access to the base of the antennas right now, but will when I remove the floor panels for annual inspection). No help! 5) Shut off the field in my B&C LR-60 alternator (with external regulator) to operate on battery only. No change (I'm using forest of ground tabs ala AEC philosophy and I'm NOT getting alternator noise in the reception of either radio so I didn't expect this to help but it was easy to test). 6)Since I used fine (24 gauge 5 condutor MAC servo cable, no shielding) wire to take the PTT signal from the PTT on the control stick to the pilots mic jack, I thought maybe that was causing a problem so I tried using the passengers PTT (wired with 22 ga shielded tefzel) instead of the pilots. No change. 7) The audio panel has a built in fail-safe feature that routes the PTT and mic/earphone signals direct to the number 1 NAV/COM in the event of audio panel failure. I shut off the audio panel and tried that. The NAV/COMM TX light comes on but still flickers and is crackly so it's not that. I of course could not test the #2 radio this way but would expect it to be the same. Transmit antenna location is under the belly of the airplane (all metal RV-6A). Two Comant bent whips about 40 inches apart just aft of the wing spar. The GPS portion of the GX-60 and VOR/ILS portion of the SL-30 work just fine. Comm reception on both radios is loud and clear (at least I can hear people in the pattern even if I can't talk to them). When I originally ran through the installation checkout I left the settings on the radios at the factory recommended (transmit worked fine so I left the settings alone) and have been making changes to the Mic gains only. These are computer controlled radios so I'm wondering if I need to adjust any other parameters such as squelch (no pots to control squelch like the old days) after making the Mic gain adjustments. Could the two be somehow related through logic in the computer program that runs the radios? I'm really stumped, any suggestions? Any UPS AT radio stack users have this problem? How did you fix it? Should I run through the installation checkout with the engine running so as to have more noise impinging on the microphone while making adjustments? Don't like the idea of head down in the cockpit with engine running but I can tie down the airplane while doing the checks (I'm talking ground running here not trying to make adjustments in flight)! Thanks for the help. Dean Psiropoulos RV-6A N197DM Flying and tweeking. ________________________________________________________________________________
Date: Sep 22, 2009
Thanks Bob, That does make sense; I had isolated it to the dc/dc converter in the same manner that you suggest here- by powering the device internally. I knew that it wasn't alternator noise since I was running off the a/c battery only. I then found out that the same noise has presented itself on another installation that I did, so it couldn't be installation specific. There the owner simply let the Ipod charge up and then disconnected it from the system and played the music into the audio system using the Ipod internal battery. I'll try and get an isolation transformer here and see what effect that has; it is simply a transformer with a 1:1 winding ratio? Jay -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: 21 September 2009 10:35 PM Subject: RE: AeroElectric-List: Re: Filter for Hand held devices At 08:11 AM 9/14/2009, you wrote: > >I think that I do need one; I am using a cigarette lighter type connection >to power an Ipod power supply. When I connect this to the Ipod no noise is >heard, but when I connect the Ipod to the radio/ intercom system I >immediately get a high pitched noise in the earphones. Okay, 'high pitched' is not alternator noise. It MIGHT be an artifact of the dc/dc converter in your ipod power adapter. Try first to power the Ipod internally without the adapter. Does the noise go away? Try powering the adapter fromits own 12 battery pack NOT connected to the a/c in any way. A couple of el-cheeso 6v lantern batteries in series a good diagnostic supply. > I separated the >power and signal leads and the noise stayed. I moved the power supply of >the cigarette/ Ipod charger directly to the battery and the noise stayed. I >will still try a twisted pair on the power supply to the radio/intercom but >it seems to me that the noise is generated by the Ipod charger so I thought >that a filter might do the trick. Perhaps even a ferrite bead on the >positive in to the radio will work. > >The only other thing that I can think of is that the loop formed by the >plug->Ipod charger->Ipod audio out->radio/intercom is somehow causing the >problem; but how does one get rid of that loop- its intrinsic to the music >input? It's most likely to be a ground loop issue which will be re-enforced or denied by the above experiments. In any case, it's almost a certainty that filtering is not solution for root cause. We may have to incorporate an isolation transformer where audio from your Ipod goes to one winding and audio to the ship's system is taken from the other winding. See: http://www.radioshack.com/product/index.jsp?productId=2103994 Bob . . . ________________________________________________________________________________
Date: Sep 22, 2009
Duh.. scratch that question- its says exactly that on the Radio Shack page; just noticed now... I'll provide some feedback when I get the transformer -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Jay Hyde Sent: 22 September 2009 08:06 AM Subject: RE: AeroElectric-List: Re: Filter for Hand held devices Thanks Bob, That does make sense; I had isolated it to the dc/dc converter in the same manner that you suggest here- by powering the device internally. I knew that it wasn't alternator noise since I was running off the a/c battery only. I then found out that the same noise has presented itself on another installation that I did, so it couldn't be installation specific. There the owner simply let the Ipod charge up and then disconnected it from the system and played the music into the audio system using the Ipod internal battery. I'll try and get an isolation transformer here and see what effect that has; it is simply a transformer with a 1:1 winding ratio? Jay -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: 21 September 2009 10:35 PM Subject: RE: AeroElectric-List: Re: Filter for Hand held devices At 08:11 AM 9/14/2009, you wrote: > >I think that I do need one; I am using a cigarette lighter type connection >to power an Ipod power supply. When I connect this to the Ipod no noise is >heard, but when I connect the Ipod to the radio/ intercom system I >immediately get a high pitched noise in the earphones. Okay, 'high pitched' is not alternator noise. It MIGHT be an artifact of the dc/dc converter in your ipod power adapter. Try first to power the Ipod internally without the adapter. Does the noise go away? Try powering the adapter fromits own 12 battery pack NOT connected to the a/c in any way. A couple of el-cheeso 6v lantern batteries in series a good diagnostic supply. > I separated the >power and signal leads and the noise stayed. I moved the power supply of >the cigarette/ Ipod charger directly to the battery and the noise stayed. I >will still try a twisted pair on the power supply to the radio/intercom but >it seems to me that the noise is generated by the Ipod charger so I thought >that a filter might do the trick. Perhaps even a ferrite bead on the >positive in to the radio will work. > >The only other thing that I can think of is that the loop formed by the >plug->Ipod charger->Ipod audio out->radio/intercom is somehow causing the >problem; but how does one get rid of that loop- its intrinsic to the music >input? It's most likely to be a ground loop issue which will be re-enforced or denied by the above experiments. In any case, it's almost a certainty that filtering is not solution for root cause. We may have to incorporate an isolation transformer where audio from your Ipod goes to one winding and audio to the ship's system is taken from the other winding. See: http://www.radioshack.com/product/index.jsp?productId=2103994 Bob . . . ________________________________________________________________________________
Date: Sep 22, 2009
Subject: Shunt Readings
Bob or somebody - Please verify (or debunk) what I perceive is happening with the readings from my shunt. Background: RV-8A Two busses - main (operates everything normally) and standby (operates essentials if alt + main fail) One alternator, two batteries - one fore (main batt - main bus + engine start) & one aft (stby bus - no start) HE device on wire from alternator to main batt (HE device and main batt located aft of firewall) Shunt on standby batt located aft of rear baggage. Battery power is wired to shunt. Shunt is wired to contactor. Contactor is wired to standby bus. So, all electrons pass from battery through shunt to contactor to bus. When I turn on only standby batt contactor, the shunt load indicates about 2A (contactor resistance plus operation of engine monitor). After engine start and the alternator is carrying the load and the batts have recharged, I occasionally get a negative amp indication on the shunt (most of the time the shunt indicates 1 amp - probably contactor). Question: Can I assume that when the standby battery is being charged the shunt will indicate negative amps? If not, what might cause a negative load indication on the shunt? Thanks, Stan Sutterfield ________________________________________________________________________________
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
Date: Sep 22, 2009
Absolutely you should..Having said that the RV is a relatively gentle areob atic airplane. Then again you have an IFR airplane..You really need your in struments. One option is to plan an upgrade to a Dynon D100 and a trutrack A/P..These units are aerobatic proof..ask me how I know...:) Oh and the RV 7 will spin inverted..:) Frank ________________________________ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectr ic-list-server(at)matronics.com] On Behalf Of PeterHunt1(at)aol.com Sent: Monday, September 21, 2009 7:20 PM nics.com Subject: AeroElectric-List: Aerobatics and Instrument Damage I have completed some excellent Unusual Attitude training in a Cap-10 which included loops, rolls and spins and will soon complete additional aerobati c training. Then I would like to try some of these aerobatics maneuvers in my RV-6. However, I am a little concern that the gyro tumbling and/or G f orces of aerobatics may hurt my instruments. I have an AI, HSI and S-TEC a utopilot all containing electric gyros and would hate to damage them. What has been your experience with aerobatics and instrument damage? Should I be concerned about this? Pete in Clearwater RV-6, Day/night IFR, Reserve Grand Champion S 'n F ________________________________________________________________________________
Date: Sep 22, 2009
Subject: Re: Shunt Readings
> >Question: >Can I assume that when the standby battery is being charged the >shunt will indicate negative amps? >If not, what might cause a negative load indication on the shunt? Without seeing power distribution diagram, I can't be real sure that I have an accurate mental image of your system's configuration. However, some general rules apply to battery ammeters . . . Depending on polarity of connections to the current sensor (in this case it's not a 'shunt'), the polarity of current readings will indicate either a charge (bus voltage above 13v) or a discharge (bus voltage below 13v). Your narrative seems to indicate that your battery current display is positive sign when the battery is being discharged; alternator(s) off. It follows then that when the alternator(s) lift the bus voltage to nominal set points, the battery will be recharged and the sign of battery current will reverse . . . in this case be (-). Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Subject: Re: Smart Start wire size
Date: Sep 22, 2009
I received an email from Bob Newman at TCW, although they have had no issues with the system the discussion on this board made them double check the the fuse requirements and after consulting with some starter contact manufacturers they have upped the fuse requirement to a 5 amps. The on-line version of the manual is updated. It seems a 3 amp fuse would be fine but since the wire size will accommodate the 5 amp fuse they are making the change to 5 amps. -------- Mike "Nemo" Elliott RV-8A QB (Fuselage) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264423#264423 ________________________________________________________________________________
Subject: What size wire?
Date: Sep 22, 2009
Bare with me I am learning! My system will follow Z12, but it does not list a AWG for the connection form the battery relay to the main buss and from the main bus to the E-buss. Some of the drawings show a 6 AWG from the battery relay to the main bus, but the wire diagram from Van's calls out a 8 AWG. So this got me to thinking how do I determine the size wire that will go here. I understand wires sizing to individual components but how does one figure a wire feeding a bus? Do I take the numbers from my load analysis (only continuous loads) and use that to size the wire? Does the same theory apply for the wire connecting the main bus to the E-buss through the diode? Lastly due to panel space my main buss is going to be in two rows, how do I make the interconnection between the two, bolt a strip of buss bar material between the buss that holds the CBs. should I connect the two rows of breakers at both ends giving a redundant path to the second row. To be clear my main buss is 2 rows of breakers and the E-buss is one row, for 3 rows total. Thanks for the help. -------- Mike "Nemo" Elliott RV-8A QB (Fuselage) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264438#264438 ________________________________________________________________________________
Subject: 5V from aircraft power - best practice?
Date: Sep 23, 2009
Subject: Re: 5V from aircraft power - best practice?
Date: Sep 23, 2009
Can anyone tell me why my message sent from outlook are coming through blank? This one sent viam the web forum. Any message was: Hi all I'm building some PIC based circuits to provide some monitoring on my aircraft including interfacing a HMC6343 compass module (very expensive!) and wanted views on the best practice way to derive a clean 5V and 3.3V supply from the aircraft power. My current approach is as follows: 1 amp fuse - reverse polarity protection diodes - transorb and 4700uF capacitor across power/GND inside the diodes. Isolating DC-DC convertor (e.g TRACO TEL 3-2011) which gives 5V out from 10-30V in - MCP1700 low dropout linear regulator to get 3.3V from the 5V rail (very low power required at 3.3V). This is very much a one off so I'm not too worried about cost (especially compared to the compass module) but want something simple, secure, and reliable. Thanks Peter Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264465#264465 ________________________________________________________________________________
From: "tomcostanza" <Tom(at)CostanzaAndAssociates.com>
Date: Sep 23, 2009
I'm building an all electric RV and am also concerned about the gyros. Could the solution be as simple as installing a switch (or 2 switches ;-) )to power down the gyros when doing aerobatics? I agree it's better to take them out of the airplane, but that's not an option for me. Clear skies, -Tom -------- Clear Skies, Tom Costanza Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264470#264470 ________________________________________________________________________________
Date: Sep 23, 2009
Not a good idea for mechanical gyros, they might be damaged more if they do not spin then the other way round. Werner (all electric including instruments) tomcostanza wrote: > > I'm building an all electric RV and am also concerned about the gyros. Could the solution be as simple as installing a switch (or 2 switches ;-) )to power down the gyros when doing aerobatics? I agree it's better to take them out of the airplane, but that's not an option for me. > > Clear skies, > -Tom > > -------- > Clear Skies, > Tom Costanza > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=264470#264470 > > > ________________________________________________________________________________
Date: Sep 23, 2009
Good Morning Tom, Great Question! Wish I knew the answer. Once again, I think I would check with the manufacturer. However, as a point of reference, our answer fifty years ago when most gyros had a caging capability was to turn off the air before the flight and cage the gyros. That seemed to be a good solution at the time. The caging lifted the gyros off the stops, held them securely, and prevented banging of the gimbals. By shutting off the air, the gyroscopic forces were eliminated. Some of the instrument gurus of the day told us that the bearings and axles were still subjected to loads for which they were not designed. The good thing about those days was that we could buy high quality WWII surplus AN flight instruments at a fraction of their cost of manufacture. As I said earlier, the TC and T&B (S-Tec autopilots use a TC as a sensor.} can handle any and all aerobatics comfortably No problem there at all. They are not harmed by aerobatics, but Attitude and Directional Gyros can be. If you use a Bendix/King KG 102A compass system, aerobatics will damage it rapidly. My WAG for the electric Attitude and Directional Gyros is that if you turn them off before the flight so that the gyros are not spinning and restrain yourself to a maximum of two or three G smooth aerobatics (No snap maneuvers), the instruments will not be harmed. As Always, It All depends! Happy Skies, Old Bob AKA Bob Siegfried Downers Grove, IL LL22 Stearman N3977A In a message dated 9/23/2009 5:30:55 A.M. Central Daylight Time, Tom(at)CostanzaAndAssociates.com writes: --> AeroElectric-List message posted by: "tomcostanza" I'm building an all electric RV and am also concerned about the gyros. Could the solution be as simple as installing a switch (or 2 switches ;-) )to power down the gyros when doing aerobatics? I agree it's better to take them out of the airplane, but that's not an option for me. Clear skies, -Tom -------- Clear Skies, Tom Costanza Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264470#264470 ________________________________________________________________________________
Date: Sep 23, 2009
From: "David E. Nelson" <david.nelson(at)pobox.com>
Hi Peter, There was some recent discussion on this list regarding the 'blank emails' topic. I think the common problem was that AVG anti-virus was used. If you google for 'AVG anti-virus blank emails' you'll find various threads. Here are a couple of threads that may help you: http://www.zimbra.com/forums/zimbra-connector-outlook/7386-blank-email-body-anti-virus.html http://techrepublic.com.com/5208-23-0.html?forumID=101&threadID=272602&messageID=2581442 Regards, /\/elson On Wed, 23 Sep 2009, pmather wrote: > > Can anyone tell me why my message sent from outlook are coming through blank? This one sent viam the web forum. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=264465#264465 > ________________________________________________________________________________
Date: Sep 23, 2009
You need to select "Plain Text" as your default for sending messages. The mail you sent has some bad HTML code and it shows up as blank unless you select "Raw Source" (if your email program allows that.) Steve Thomas ________________________________________________________________________ On Sep 23, 2009, at 2:12 AM, pmather wrote: > > Can anyone tell me why my message sent from outlook are coming > through blank? This one sent viam the web forum. > > Any message was: > > Hi all > > I'm building some PIC based circuits to provide some monitoring on my > aircraft including interfacing a HMC6343 compass module (very > expensive!) > and wanted views on the best practice way to derive a clean 5V and > 3.3V > supply from the aircraft power. > > My current approach is as follows: > > 1 amp fuse - reverse polarity protection diodes - transorb and 4700uF > capacitor across power/GND inside the diodes. Isolating DC-DC > convertor (e.g > TRACO TEL 3-2011) which gives 5V out from 10-30V in - MCP1700 low > dropout > linear regulator to get 3.3V from the 5V rail (very low power > required at > 3.3V). > > This is very much a one off so I'm not too worried about cost > (especially > compared to the compass module) but want something simple, secure, and > reliable. > > Thanks > > Peter > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=264465#264465 > > ________________________________________________________________________________
Date: Sep 23, 2009
Steve, David Thanks for the info on the emails. I was already using plain text so it is clearly AVG that causes the problems. However, back to the real subject of the email? Best regards Peter Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264526#264526 ________________________________________________________________________________
Date: Sep 23, 2009
> >My current approach is as follows: > >1 amp fuse - reverse polarity protection diodes - transorb and 4700uF >capacitor across power/GND inside the diodes. Isolating DC-DC convertor (e.g >TRACO TEL 3-2011) which gives 5V out from 10-30V in - MCP1700 low dropout >linear regulator to get 3.3V from the 5V rail (very low power required at >3.3V). What you've proposed will be fine. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Sep 23, 2009
Subject: iPOD and Squeal
Bob wrote: Okay, 'high pitched' is not alternator noise. It MIGHT be an artifact of the dc/dc converter in your ipod power adapter. I have an identical issue with my SANSA mp3 player. When the screen backlight times out [user setting to 20 sec] the squeal stops. Apparently, the backlighting frequency is horrible for our ears. I pick this up over the plane audio, my car and stand alone ear buds. After 20 seconds, no squeal. Some units are set to remain lit if on external power, so the squeal never stops. Can the screen setting be changed on his iPOD to a shorter time? John in a Glasiar II FT ________________________________________________________________________________
Date: Sep 23, 2009
Subject: Re: What size wire?
At 09:41 PM 9/22/2009, you wrote: > >Bare with me I am learning! My system will follow Z12, but it does >not list a AWG for the connection form the battery relay to the main >buss and from the main bus to the E-buss. Some of the drawings show >a 6 AWG from the battery relay to the main bus, but the wire diagram >from Van's calls out a 8 AWG. So this got me to thinking how do I >determine the size wire that will go here. I understand wires >sizing to individual components but how does one figure a wire feeding a bus? As a general rule, fat wires that do not carry starter currents are picked to carry alternator currents. Many builders using 4AWG fat wires for battery installations near the engine simply use 4AWG for the altenrator b-lead and main bus too. But if your alternator is 60A or smaller, 6AWG is fine for these two slots. Size the main-bus/e-bus jumper according to e-bus loads. Same philosophy for the e-bus alternate feed path from the battery bus. >Lastly due to panel space my main buss is going to be in two rows, >how do I make the interconnection between the two, bolt a strip of >buss bar material between the buss that holds the CBs. should I >connect the two rows of breakers at both ends giving a redundant >path to the second row. To be clear my main buss is 2 rows of >breakers and the E-buss is one row, for 3 rows total. Thanks for the help. Here's how Beech does it . . . http://aeroelectric.com/Pictures/Breakers/Breaker_Panel_Busing_2.jpg http://aeroelectric.com/Pictures/Breakers/Breaker_Panel_Busing_1.jpg http://aeroelectric.com/Pictures/Breakers/Breaker_Panel_Busing_0.jpg Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Sep 23, 2009
Subject: Re: strobe lights
At 12:48 PM 9/19/2009, you wrote: >For anyone interested in this sort of thing, here is some >information on test standards. ><http://physics.nist.gov/Divisions/Div844/facilities/photo/Flash/flash.html>http://physics.nist.gov/Divisions/Div844/facilities/photo/Flash/flash.html thank you sir. I've downloaded to my reference library Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Subject: Re: Ground Loop posibilities
Date: Sep 24, 2009
In my Lancair, I have two Odessey batteries and the - terminals are wired as follows: 1. 4ga cable from A bat to B bat and from there to starter ground. 2. 10ga cable from A Bat to B Bat and from there to ground buss forward of the panel. This ground buss is electrically isolated from the rest of the airframe as it is mounted on glass. I can demonstrate continuity between the ground buss and any point on the instrument panel and avionics stack as well as any of the control cables which penetrate the firewall and attach to the engine. This would seem to be made possible by the ground path from the batteries directly to the starter ground point. From a ground loop point of view, is this anything to be concerned about? Given all the cables which attach to the engine and pass through the firewall to the panel, I don't see how it would be possible to isolate the starter ground cable path to the panel. Maybe this is a non issue and I should just get on with building. All comments appreciated. :-) Angier Ames N4ZQ ________________________________________________________________________________
Date: Sep 24, 2009
Subject: Welding cable
Date: Sep 24, 2009
My van's kit came with MS 2 awg cable for big wires, but the stuff is too stiff for my application, I have very short runs from my battery to the contactor. I know welding cable can be used, a friend found some "200 amp inverter cable" at Harbor Freight that he is using in his airplane. Does anyone know if this is the same stuff as welding cable. The connections I want to use this flexible cable for are all behind the firewall, I will use the mil spec stuff to run power forward to the starter. Thanks for any help with this. -------- Mike "Nemo" Elliott RV-8A QB (Fuselage) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264699#264699 ________________________________________________________________________________
Date: Sep 24, 2009
Subject: Re: Welding cable
I don't know about the Harbor Freight stuff, but when I was looking for welding cable, I did find a variety of quality in insulation. Some had an inner jacket, which I took to be a better quality, and some had not. Sam www.samhoskins.blogspot.com On Thu, Sep 24, 2009 at 10:19 AM, rvg8tor wrote: > > My van's kit came with MS 2 awg cable for big wires, but the stuff is too > stiff for my application, I have very short runs from my battery to the > contactor. I know welding cable can be used, a friend found some "200 amp > inverter cable" at Harbor Freight that he is using in his airplane. Does > anyone know if this is the same stuff as welding cable. The connections I > want to use this flexible cable for are all behind the firewall, I will use > the mil spec stuff to run power forward to the starter. Thanks for any help > with this. > > -------- > Mike "Nemo" Elliott > RV-8A QB (Fuselage) > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=264699#264699 > > ________________________________________________________________________________
Date: Sep 24, 2009
At 10:19 AM 9/24/2009, you wrote: > >My van's kit came with MS 2 awg cable for big wires, but the stuff >is too stiff for my application, I have very short runs from my >battery to the contactor. I know welding cable can be used, a >friend found some "200 amp inverter cable" at Harbor Freight that he >is using in his airplane. Does anyone know if this is the same >stuff as welding cable. The connections I want to use this flexible >cable for are all behind the firewall, I will use the mil spec stuff >to run power forward to the starter. Thanks for any help with this. No good way to know details of this product. Welding cable is really inexpensive. Pick up what you need at a local welding supply store. Also, 2AWG is REALLY oversized for an RV with battery on the firewall. If it were my airplane, 4AWG welding cable would be used for all fat wires that carry starter current. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Subject: Diode numbers
Date: Sep 24, 2009
I have an electronic supply store in my town so I went out to get the diodes that go on the battery and start relays. I asked for the 1N5400, after looking up in a book the guy gave me an NTE-5800. Near as I can tell from looking on-line they are the same type of diode. Is there anything quality wiser or otherwise I should be aware of when buying these things? They only cost .38 each, so after ring terminals and some heat shrink I might have a buck into them, not bad. -------- Mike "Nemo" Elliott RV-8A QB (Fuselage) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264814#264814 ________________________________________________________________________________
Date: Sep 24, 2009
At 11:51 AM 9/24/2009, you wrote: >I don't know about the Harbor Freight stuff, but when I was looking >for welding cable, I did find a variety of quality in >insulation. Some had an inner jacket, which I took to be a better >quality, and some had not. > >Sam Thanks for reminding me of that Sam. A guy at a welding store told me that the two-layer cable lasted longer in the field. Little nicks in the outer jacket tended to propagate cracks through to the strands when the cable was flexed/ stretched. By making it two layers, the gap was a "crack stopper" while the inner layer maintained environmental integrity. http://aeroelectric.com/Pictures/Wire/4AWG_Welding_Cable_1.jpg It seems a logical explanation. Of course, the cables in our airplanes don't get stretched across gravel drives and run over by dump-trucks. The Anchor brand welding cable illustrated above has an HDPM outer jacket which is revered for its flexibility and toughness. Here's an excerpt from a wire catalog describing this insulation. Emacs! Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Sep 24, 2009
I found my local welding shop and bought some 4 AWG. Man this stuff is flexible, I can't believe I was trying to wrestle with the mill spec stuff for those short runs. It is not the double insulated stuff you showed in the picture but it seem tough. it is labeled as "Heavy Duty Welding cable 600V -50 degrees C to 105 degrees C. I will use a crimp on ring terminal, I have the tool from ACS for this but should I solder the end before crimping, there are a lot of fine wires in this cable. I will have to check the AEC Bible, I seem to remember reading something on this subject. -------- Mike "Nemo" Elliott RV-8A QB (Fuselage) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264836#264836 ________________________________________________________________________________
Subject: Mounting BATT/START Relays
Date: Sep 25, 2009
My battery will be just aft of the firewall so the battery relay will be mounted on the aft side of the firewall, the start relay will be just opposite on the forward side of the firewall. I see some who install plate nuts to mount these relays individually, 4 nuts + 4 bolts+4 holes in the firewall. The holes on the two relays work out so that one could just use 2 bolts and two normal nuts (not anchor nuts) and mount the two relays through common holes in the firewall. The only drawback I can see is that if one or the other needs to be replaced then both you can't remove one without disturbing the other, this does not seem like a big deal to me as they are fairly long lasting devices. Can anyone see why my idea is a bad one? I though of heat transfer from the hot side of the firewall, but bolts into nut plates would do that to some degree, and all of the relays could be mounted forward of the firewall like many factory airplanes have them. -------- Mike "Nemo" Elliott RV-8A QB (Fuselage) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264914#264914 ________________________________________________________________________________
Date: Sep 24, 2009
Subject: Re: Diode numbers
At 05:29 PM 9/24/2009, you wrote: > >I have an electronic supply store in my town so I went out to get >the diodes that go on the battery and start relays. I asked for the >1N5400, after looking up in a book the guy gave me an >NTE-5800. Near as I can tell from looking on-line they are the same >type of diode. Is there anything quality wiser or otherwise I >should be aware of when buying these things? They only cost .38 >each, so after ring terminals and some heat shrink I might have a >buck into them, not bad. Of thousands of diode part numbers on the shelves, the vast majority of the industry's needs can be met by perhaps a few hundred . . . maybe less. The spike catcher diodes don't even wake up from a sound sleep when hit by the energy from your contactor's magnetic field collapse. I LIKE the 5400 series devices because they're MECHANICALLY friendly for installation. Much smaller diodes would be electrically adequate but these dudes (and the NTE-5800 cousins) are most adequate to the task. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Sep 25, 2009
Mike, Maybe a small thing, but I would crimp "before" I'd solder. Soldering just seals the deal. Glenn -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of rvg8tor Sent: Thursday, September 24, 2009 8:42 PM Subject: AeroElectric-List: Re: Welding cable I found my local welding shop and bought some 4 AWG. Man this stuff is flexible, I can't believe I was trying to wrestle with the mill spec stuff for those short runs. It is not the double insulated stuff you showed in the picture but it seem tough. it is labeled as "Heavy Duty Welding cable 600V -50 degrees C to 105 degrees C. I will use a crimp on ring terminal, I have the tool from ACS for this but should I solder the end before crimping, there are a lot of fine wires in this cable. I will have to check the AEC Bible, I seem to remember reading something on this subject. -------- Mike "Nemo" Elliott RV-8A QB (Fuselage) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264836#264836 ________________________________________________________________________________
Date: Sep 25, 2009
At 07:41 PM 9/24/2009, you wrote: > >I found my local welding shop and bought some 4 AWG. Man this stuff >is flexible, I can't believe I was trying to wrestle with the mill >spec stuff for those short runs. NICE to work with . . . > It is not the double insulated stuff you showed in the picture but > it seem tough. it is labeled as "Heavy Duty Welding cable 600V -50 > degrees C to 105 degrees C. Yup, it will be just fine . . . > I will use a crimp on ring terminal, I have the tool from ACS for > this but should I solder the end before crimping, there are a lot > of fine wires in this cable. I will have to check the AEC Bible, I > seem to remember reading something on this subject. If your crimp tool produces the proper crush, then crimping is as good as solder. The two processes are essentially interchangeable. If you solder at all, then crimping adds no value. http://www.aeroelectric.com/articles/big_term.pdf Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Subject: Why have a switch on ALT Field?
Date: Sep 25, 2009
I am brain storming here while I work on my electrical system design (Z12). I wonder why there is a switch for the Alt Field. From my reading on the forums internally regulated alternators get their life shortened if one turns them on under load, (they should be on before start until after start to get the most life out of the alternator). The B&C alternator is externally regulated and can handle the switching under load. But operationally there is no reason to switch the alternator on and off, if you have an abnormal situation and need to turn the alternator off you can do that just as easily with a circuit breaker as you can with a switch. So why not leave the switch out of the loop and wire the alternator field directly to circuit breaker so it is always on, in case of alternator problem, pull circuit breaker. On less switch a few ounces and dollars saved. So, am I missing something obvious here? I have posted this on VAF, but thought since this forum is more on point I should post it here. -------- Mike "Nemo" Elliott RV-8A QB (Fuselage) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264938#264938 ________________________________________________________________________________
Date: Sep 25, 2009
Subject: Re: Mounting BATT/START Relays
>The holes on the two relays work out so that one could just use 2 >bolts and two normal nuts (not anchor nuts) and mount the two relays >through common holes in the firewall. > The only drawback I can see is that if one or the other needs to > be replaced then both you can't remove one without disturbing the > other, this does not seem like a big deal to me as they are fairly > long lasting devices. Can anyone see why my idea is a bad one? The TC aircraft guys do things like this all the time . . . > I though of heat transfer from the hot side of the firewall, but > bolts into nut plates would do that to some degree, and all of the > relays could be mounted forward of the firewall like many factory > airplanes have them. ??? not sure of the rationale here. The battery relay should be as close to the battery as practical and certainly positioned so that the battery(+) lead doesn't penetrate the firewall before reaching the relay's fat terminal. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Sep 25, 2009
Subject: Re: Why have a switch on ALT Field?
At 10:22 AM 9/25/2009, you wrote: I am brain storming here while I work on my electrical system design (Z12). I wonder why there is a switch for the Alt Field. From my reading on the forums internally regulated alternators get their life shortened if one turns them on under load, (they should be on before start until after start to get the most life out of the alternator). Bob Nuckolls replies: An urban (or perhaps hangar) legend. I've been working with alternators and generators for 40+ years. There is no basis in physics to support the legend. In fact, it has always been a design goal of every TC aircraft electrical system to offer any time, any conditions, positive ON/OFF control of alternators and/or generators without concern for degradation of performance or damage to equipment. The B&C alternator is externally regulated and can handle the switching under load. As can ALL other skillfully designed alternators. One of the foundations upon which the hangar-myth was built had to do with alternators ostensibly wired per Z-24 . . . http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z24-Interim.pdf . . . and apparently switched off (B-lead broken) while the alternator was under load. This started a hysterical kerfuffle about "turning alternators on or off under load". Numerous authors have posited the same hypothesis before. However, the special case presented by a b-lead disconnect contactor energized efforts by the in-experienced and un-informed to stoke the fires anew and stir the pot of misunderstanding. I enjoyed a two-day tour of a LARGE scale alternator remanufacturing operation about a year ago. Details of this visit can be discovered at: http://aeroelectric.com/R12A/03_Alternator_12A1.pdf During that visit I witnessed a demonstration of a full load, max rpm, hot-alternator b-lead disconnect that liberated kilojoules of energy in the ensuing arc . . . 5 times in a row. The flash of fire was so great that it was impossible to photograph or record on video. Their chief engineer asserted that all of their reman products (2800+ line items) were tested to the same design goals. These alternators were demonstrably immune from self-induced load dump damage. But operationally there is no reason to switch the alternator on and off, if you have an abnormal situation and need to turn the alternator off you can do that just as easily with a circuit breaker as you can with a switch. Suppose you have two alternators like Z-12 or Z-13? Is it not useful to test the two alternators independently of each other irrespective of all other conditions? Suppose you have smoke in the cockpit? How about an unruly regulator? Our brothers in the TC aircraft world have adopted any-time, any-conditions, ON/OFF control as a design goal. So why not leave the switch out of the loop and wire the alternator field directly to circuit breaker so it is always on, in case of alternator problem, pull circuit breaker. On less switch a few ounces and dollars saved. So, am I missing something obvious here? Perhaps not obvious . . . but certainly not 'secret'. Any student of contact physics for things like relays, switches and CIRCUIT BREAKERS will understand that depending on a breaker like . . . http://aeroelectric.com/Pictures/Breakers/Klixon_1.jpg . . . to open the 100 volts plus, b-lead of a runaway alternator is quite likely to experience a hundreds-of- kilojoules arc in the gap of relatively slow moving contacts that are guaranteed to produce a lot of smoke in the cockpit. BREAKERS are not intended to serve as commanding manual control devices. Breakers for aircraft are designed to break faults of several thousand amps at 32 VOLTS or less. See paragraph 4.7.14 of . . . http://www.aeroelectric.com/Reference_Docs/Mil-Specs/5809G.pdf Since the first generators (and then alternators) went aboard an airplane, the pilot has been offered positive control of those electrical energy sources by breaking the FIELD lead. At no time did anyone consider the main power output feeder protection to be a control device. In fact, b-lead protection on TC aircraft isn't even on the panel . . . http://aeroelectric.com/Pictures/Wiring_Technique/A36_Firewall_A.jpg I have posted this on VAF, but thought since this forum is more on point I should post it here. Please post this reply to VAF. Thanks! Bob . . . ________________________________________________________________________________
Date: Sep 25, 2009
Bob, Thank you for the explanation, this really helps me understand the design better. I did post your reply on the VAF for all to read. I think this will add to everyones education. So if I understand what your post, the gist is that there is potential for excess voltage in some situations as to make a CB fail if used to cut the field to the alternator. I have heard others say CBs are not meant to be switches, but at my airline we routinely pull CB on certain items while the airplane sits between flights for several hours. Things like the radar, TCAS, VSI indicator. This use of the CB as a switch happens several times a day for each aircraft. It this an accepted practice since these are low voltage items. You have given me the data i was looking for, I now understand why the switch is needed, it is due to potential high loads. -------- Mike "Nemo" Elliott RV-8A QB (Fuselage) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=265058#265058 ________________________________________________________________________________
Date: Sep 26, 2009
9/26/2009 Hello Mike and Bob, The recent exchange of postings between the two of you on the subject of "Why have a switch on ALT Field?" has left me a bit baffled. Mike, your question dealt with shutting down an alternator by removing the electrical source to its FIELD. Figure Z 12 was the starting point for your question and presumably dealt with externally regulated alternators, but then you threw in the red herring of shutting down internally regulated alternators. Bob, your answer appeared to deal extensively with shutting down an internally regulated alternator by opening the B LEAD such as in Figure Z 24.. Mike, your response below indicated that you believed, as a result of Bob's posting, that there was a huge amount of electricity flowing through the wire to the alternator FIELD circuit in an externally regulated alternator and that therefore a switch rather than a circuit breaker would be needed to open that circuit. "You have given me the data i was looking for, I now understand why the switch is needed, it is due to potential high loads." It is my understanding that: 1) The alternator FIELD wire in an externally regulated alternator only carries a few amps of electricity. 2) Opening this FIELD wire with either a CB or a switch while electricity is flowing through this wire generates no huge electrical flow interruption issue. 3) The alternator B LEAD (in either an internally regulated or externally regulated alternator) can carry a significant amount of electricity and interrupting this flow through the B LEAD by opening the B LEAD brings up the issues that Bob dealt with extensively in his response. Mike if you will check some of the Z diagrams (Z 9 as well as Z 12 for example) you will see that there is both a CB and a switch that can interrupt the electrical flow to the alternator FIELD of an externally regulated alternator. And this is good. The CB provides the traditional protection to that wiring and the switch makes it possible to turn on / off the alternator FIELD as desired with no great concern regarding interrupting huge amperage flow. My airplane has both a CB and a switch (as do the Z figures) and the externally regulated alternator FIELD gets turned off by the switch during every engine shut down procedure while the engine is still running. Shortly after the alternator is turned off by the FIELD switch the low voltage light begins to flash telling me that that warning indication is working. I then turn on my essential bus** and then turn off the battery master and the radio master (yes I have one ##) to ensure that my Garmin 430W and my transponder continue to operate off the battery which is now feeding the avionics essential bus. The Garmin 430W and the transponder are essential for me to return to my home field inside the Washington DC SFRA. Please let me know if I have confused or clarified the issue raised by Mike's original question. 'OC' Says: "The best investment we can make is the effort to gather and understand knowledge." **PS: Yes I am aware that there are means of causing this to happen automatically with a diode, but the guy who wired my panel did not do it that way and I have been living very happily with what he provided because I understand the system. ##PS: Again this was given to me (after I paid big money to have the panel built), but I have access to the avionics that I need via an essential avionics bus so I have been living very happily with what he provided because I understand the system. ================================================ Subject: AeroElectric-List: Re: Why have a switch on ALT Field? From: "rvg8tor" <rvg8tor(at)comcast.net> Bob, Thank you for the explanation, this really helps me understand the design better. I did post your reply on the VAF for all to read. I think this will add to everyones education. So if I understand what your post, the gist is that there is potential for excess voltage in some situations as to make a CB fail if used to cut the field to the alternator. I have heard others say CBs are not meant to be switches, but at my airline we routinely pull CB on certain items while the airplane sits between flights for several hours. Things like the radar, TCAS, VSI indicator. This use of the CB as a switch happens several times a day for each aircraft. It this an accepted practice since these are low voltage items. You have given me the data i was looking for, I now understand why the switch is needed, it is due to potential high loads. -------- Mike "Nemo" Elliott RV-8A QB (Fuselage) ________________________________________________________________________________
Date: Sep 26, 2009
Where can you find the anchor brand cable? Any weblinks/supply you can point to. Thanks Chris RV-10 From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Thursday, September 24, 2009 3:54 PM Subject: Re: AeroElectric-List: Welding cable At 11:51 AM 9/24/2009, you wrote: I don't know about the Harbor Freight stuff, but when I was looking for welding cable, I did find a variety of quality in insulation. Some had an inner jacket, which I took to be a better quality, and some had not. Sam Thanks for reminding me of that Sam. A guy at a welding store told me that the two-layer cable lasted longer in the field. Little nicks in the outer jacket tended to propagate cracks through to the strands when the cable was flexed/ stretched. By making it two layers, the gap was a "crack stopper" while the inner layer maintained environmental integrity. http://aeroelectric.com/Pictures/Wire/4AWG_Welding_Cable_1.jpg It seems a logical explanation. Of course, the cables in our airplanes don't get stretched across gravel drives and run over by dump-trucks. The Anchor brand welding cable illustrated above has an HDPM outer jacket which is revered for its flexibility and toughness. Here's an excerpt from a wire catalog describing this insulation. Emacs! Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Sep 26, 2009
At 08:47 PM 9/25/2009, you wrote: Bob, Thank you for the explanation, this really helps me understand the design better. I did post your reply on the VAF for all to read. I think this will add to everyone's education. So if I understand what your post, the gist is that there is potential for excess voltage in some situations as to make a CB fail if used to cut the field to the alternator. That's not the bottom line . . . We should start with some design goals in mind. For all of my career in TC and OBAM aircraft, I've embraced and designed systems that meet traditional goals for any time, any conditions, On-0ff control of the engine driven power source(s). I have heard others say CBs are not meant to be switches, but at my airline we routinely pull CB on certain items while the airplane sits between flights for several hours. Things like the radar, TCAS, VSI indicator. This use of the CB as a switch happens several times a day for each aircraft. It this an accepted practice since these are low voltage items. This isn't about using breakers as switches, it's about meeting the design goal cited above. The b-lead breaker on an alternator COULD be used to disconnect the alternator assuming (A) the alternator is under control [producing 14 or so volts] and (B) the breaker is on the panel and pullable [many TC aircraft have push-only breakers]. The classical control philosophy for engine driven power sources has been a SWITCH in reach of the crew that offers control over the field excitation . . . always a low current, easy-to-manage task. This task COULD be managed by flipping a switch -OR- pulling the field supply breaker . . . it's your choice. There are other legacy design goals . . . like automatic and absolute control of the alternator in case of a failed regulator in an OV runaway condition. Figure Z-24 is but one of several recipes for success. When Z-24 was combined with alternators NOT designed and tested to withstand their own load-dumps that some builders experienced alternator failures immediately after turning them off while under load. You have given me the data I was looking for, I now understand why the switch is needed, it is due to potential high loads. No . . . its about dependance on pulling of a b-lead breaker for the purpose of taking a runaway alternator off line. This is a shaky design goal due to the fact that a failed alternator can deliver 100-200 volts in a runaway condition. Attempting to do this reliably with a 32-volt rated, pullable breaker would very likely fail the breaker. Further, pulling a b-lead breaker to mitigate an ov condition puts human perception, decision, reaction delays into the shutdown event. That's never been embraced by the TC aircraft world that I'm aware of. The issues before us are (1) design goals for control (2) design goals for automatic millisecond- fast mitigation of an OV event. You can pull a field breaker for (1) if you wish . . . but NOT a b-lead breaker for (2). Bob . . . ________________________________________________________________________________
Date: Sep 26, 2009
At 09:45 AM 9/26/2009, you wrote: >Where can you find the anchor brand cable? Any weblinks/supply you >can point to. >Thanks >Chris >RV-10 A local welding supply store will offer Anchor or a suitable equivalent. Some mention was made of a "200A inverter cable" from Harbor Freight. While these wires will probably have enough finely stranded copper for the task, the question to be asked deals with temperature characteristics and ruggedness of the INSULATION. Welding cable produced to an ATSM specification (as are most if not all American products) will do the job for you . . . I searched for Anchor outlets but without success after 20 minutes or so . . . however, the storefront where I purchased the pictured sample was offering Anchor brand cable at the time I bought it. That was several years ago. Shop around locally first . . . Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Sep 26, 2009
My design goal is a system that is simple as possible but still meets capacity and redundancy goals (glass IFR bird). Thankfully I found Z12 and this design suits my need. My assumption not mentioned by me so far, is that I will have an alternator that will have a controllable filed with OV protection, be that with internal or external regulation. I never thought of controlling the alternator with the "B" lead. So just looking at the Z12 diagram I pondered whether I needed the switch for the alternator field, I was looking for way to simplify where I could. My CB panel will all be in easy reach by my right leg, the CB layout has 4 breakers at the end of two rows to make then stand out from the rest, I also plan to have them with colored collars, this would make finding them in the dark easy. Two at the end of the top row are for the primary and standby alternator fields. Two at the end of the next row control 12V power to the L/R P-mags respectfully. Also the two rows are not the same length, this also allows for identification in the dark. Top row is shorter, last two breakers are MAIN ALT then STBY ALT, easy to remember easy to find. I know a toggle switch will be faster to actuate than finding a breaker but not by much. So would elimination of the switch change the design goal of Z12, would I not still have a controllable engine driven power source? I guess from what I have read so far the answer is no. Even though the switch will be used very little, it is still required? -------- Mike "Nemo" Elliott RV-8A QB (Fuselage) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=265125#265125 ________________________________________________________________________________
Date: Sep 26, 2009
OK, now here's one more vote for "confused". I thought the circuit breaker was supposed to be rated at the output amperage of the alternator because it's that current that one wants to limit. My 40A circuit breaker would do nothing for me on the alternator field circuit. As I understand it, the switch is on the alternator field low-current 12V line (called IGN on my alternator) and the circuit breaker protects the output side (B lead). Mine is wired this way because it made sense. Ian Brown, RV-9A, Bromont, QC > > 9/26/2009 > > Hello Mike and Bob, The recent exchange of postings between the two of you > on the subject of "Why have a switch on ALT Field?" has left me a bit > baffled. > > Mike, your question dealt with shutting down an alternator by removing the > electrical source to its FIELD. Figure Z 12 was the starting point for your > question and presumably dealt with externally regulated alternators, but > then you threw in the red herring of shutting down internally regulated > alternators. > > Bob, your answer appeared to deal extensively with shutting down an > internally regulated alternator by opening the B LEAD such as in Figure Z > 24.. > > Mike, your response below indicated that you believed, as a result of Bob's > posting, that there was a huge amount of electricity flowing through the > wire to the alternator FIELD circuit in an externally regulated alternator > and that therefore a switch rather than a circuit breaker would be needed to > open that circuit. > > "You have given me the data i was looking for, I now understand why the > switch is > needed, it is due to potential high loads." > > It is my understanding that: > > 1) The alternator FIELD wire in an externally regulated alternator only > carries a few amps of electricity. > > 2) Opening this FIELD wire with either a CB or a switch while electricity is > flowing through this wire generates no huge electrical flow interruption > issue. > > 3) The alternator B LEAD (in either an internally regulated or externally > regulated alternator) can carry a significant amount of electricity and > interrupting this flow through the B LEAD by opening the B LEAD brings up > the issues that Bob dealt with extensively in his response. > > Mike if you will check some of the Z diagrams (Z 9 as well as Z 12 for > example) you will see that there is both a CB and a switch that can > interrupt the electrical flow to the alternator FIELD of an externally > regulated alternator. And this is good. The CB provides the traditional > protection to that wiring and the switch makes it possible to turn on / off > the alternator FIELD as desired with no great concern regarding interrupting > huge amperage flow. > > My airplane has both a CB and a switch (as do the Z figures) and the > externally regulated alternator FIELD gets turned off by the switch during > every engine shut down procedure while the engine is still running. Shortly > after the alternator is turned off by the FIELD switch the low voltage light > begins to flash telling me that that warning indication is working. I then > turn on my essential bus** and then turn off the battery master and the > radio master (yes I have one ##) to ensure that my Garmin 430W and my > transponder continue to operate off the battery which is now feeding the > avionics essential bus. The Garmin 430W and the transponder are essential > for me to return to my home field inside the Washington DC SFRA. > > Please let me know if I have confused or clarified the issue raised by > Mike's original question. > > 'OC' Says: "The best investment we can make is the effort to gather and > understand knowledge." > > > **PS: Yes I am aware that there are means of causing this to happen > automatically with a diode, but the guy who wired my panel did not do it > that way and I have been living very happily with what he provided because I > understand the system. > > ##PS: Again this was given to me (after I paid big money to have the panel > built), but I have access to the avionics that I need via an essential > avionics bus so I have been living very happily with what he provided > because I understand the system. > > ================================================ > > > Subject: AeroElectric-List: Re: Why have a switch on ALT Field? > From: "rvg8tor" <rvg8tor(at)comcast.net> > > > Bob, > > Thank you for the explanation, this really helps me understand the design > better. > I did post your reply on the VAF for all to read. I think this will add to > everyones education. > > So if I understand what your post, the gist is that there is potential for > excess > voltage in some situations as to make a CB fail if used to cut the field to > the alternator. I have heard others say CBs are not meant to be switches, > but > at my airline we routinely pull CB on certain items while the airplane sits > between flights for several hours. Things like the radar, TCAS, VSI > indicator. > This use of the CB as a switch happens several times a day for each > aircraft. > It this an accepted practice since these are low voltage items. > > You have given me the data i was looking for, I now understand why the > switch is > needed, it is due to potential high loads. > > -------- > Mike "Nemo" Elliott > RV-8A QB (Fuselage) > > > > > ________________________________________________________________________________
Date: Sep 26, 2009
At 06:53 AM 9/26/2009, you wrote: Please let me know if I have confused or clarified the issue raised by Mike's original question. Your words appear to paint a clear understanding . . . The problem with this (and many threads of similar discussion in the past) is the stirring of a LOT of simple-ideas (facts) into one pot of ill-conceived stew (no definition of design goals) and stirred over a hot fire ("don't do that or you're gonna die") with the unbridled enthusiasm (mis-interpretation of words). 'OC' Says: "The best investment we can make is the effort to gather and understand knowledge." Yup, you got that right. I notice that my response to Mike's follow-up hasn't passed through the server yet . . . but I hope it proves to be a useful clarification of how we . . . (1) start with design goals . . . (2) then craft an architecture that addresses design goals while . . . (3) eliminating single points of failure for extra ordinarily useful electro-whizzies as revealed by skillfully conducted FMEA. (4) Study and understand the specs for ingredients that go into recipes for success. (5) Select style, quality and a minimized quantity of components that go into the proposed recipe. (6) Verify that the recipe meets design goals. (7) Analyze subsequent failures to deduce root cause. Wear out? Mis-application? Robustness? Quality? Error of stating or conformance to design goals? Other? Answers to these questions may prompt a program review that goes all the way back to step (1). When one makes a career of this process, you eventually discover that it's a Mobius Loop which strives for archiving a host of lessons-learned while improving upon the best we know how to do. This is the essence of good design engineering as I've come to understand it. Its interesting but frustrating that there are so many pitfalls that put the 7-step process at risk. We're fortunate that until recently, loss of the entire electrical system was unlikely to force an airplane down. Now that we've embraced performance advantages of modern electronics to control engines, there's a pressing need to craft an architecture with particular attention to step (3). This is relatively easy to do if the seven steps are dutifully observed . . . but it's easy to be distracted from the process if excited rhetoric borne out of misunderstanding dominates the tenor of the discussion. So while we "gather and understand knowledge" (become designers) we must be ready to calmly defuse excitement with lucid explanation of simple-ideas and how they become ingredients that go into recipes for success (become teachers). Bob . . . ________________________________________________________________________________
Date: Sep 26, 2009
I was at my local True-Value hardware store, this morning, and they had the 4AWG inner jacketed stuff. I didn't look for the brand name, though. Sam On Sat, Sep 26, 2009 at 12:13 PM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > nuckolls.bob(at)aeroelectric.com> > > At 09:45 AM 9/26/2009, you wrote: > >> Where can you find the anchor brand cable? Any weblinks/supply you can >> point to. >> Thanks >> Chris >> RV-10 >> > > A local welding supply store will offer Anchor or > a suitable equivalent. Some mention was made of > a "200A inverter cable" from Harbor Freight. While > these wires will probably have enough finely stranded > copper for the task, the question to be asked deals > with temperature characteristics and ruggedness of > the INSULATION. Welding cable produced to an ATSM > specification (as are most if not all American > products) will do the job for you . . . > > I searched for Anchor outlets but without success > after 20 minutes or so . . . however, the storefront > where I purchased the pictured sample was offering > Anchor brand cable at the time I bought it. That > was several years ago. > > Shop around locally first . . . > > > Bob . . . > > --------------------------------------- > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > --------------------------------------- > > ________________________________________________________________________________
Date: Sep 26, 2009
Hi Bob, West Marine carries ANCOR brand battery cable. I don't know if it's any good. Just another piece of intel to muck things up. Hal Benjamin RV4 Long Island, NY ----- Original Message ----- From: "Robert L. Nuckolls, III" Date: Saturday, September 26, 2009 1:35 pm Subject: RE: AeroElectric-List: Welding cable > III" > > At 09:45 AM 9/26/2009, you wrote: > >Where can you find the anchor brand cable? Any weblinks/supply > you > >can point to. > >Thanks > >Chris > >RV-10 > > A local welding supply store will offer Anchor or > a suitable equivalent. Some mention was made of > a "200A inverter cable" from Harbor Freight. While > these wires will probably have enough finely stranded > copper for the task, the question to be asked deals > with temperature characteristics and ruggedness of > the INSULATION. Welding cable produced to an ATSM > specification (as are most if not all American > products) will do the job for you . . . > > I searched for Anchor outlets but without success > after 20 minutes or so . . . however, the storefront > where I purchased the pictured sample was offering > Anchor brand cable at the time I bought it. That > was several years ago. > > Shop around locally first . . . > > > Bob . . . > > --------------------------------------- > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > --------------------------------------- > > > > > > > ________________________________________________________________________________
Date: Sep 26, 2009
Subject: Hired wire-slingers
>>##PS: Again this was given to me (after I paid big money to have the panel >>built), but I have access to the avionics that I need via an essential >>avionics bus so I have been living very happily with what he provided >>because I understand the system. The task of selecting a panel builder is two-fold. Unfortunately, features that drive most buy-decisions are appearance (craftsmanship), and experience (built a lot of panels). The the seven-step process I described earlier goes to the MOST important component of the buy-decision process . . . and is seldom offered by some of the most skilled builders. This is why the most successful airplane companies had good engineers that teamed with equally good craftsmen that were both free to continuously improve upon the best we know how to do. I always had a excellent relationship with the folks in the factory. I hold their skills in high regard . . . I've worked on those lines too. But corporate management is moving from self-serving entrepreneurs to stockholder-serving bankers. Product quality and capability is being wrenched from the control of designers and craftsmen and replaced with process and control dictates (ISO, FAR, EPA, etc). The result is predictable and inevitable. The best we know how to do is no longer represented by the folks who understood and built airplanes most of us learned to fly in. The best we know how to do is now in your basements and garages. Fortunately, there are many skilled craftsmen from the TC aircraft world who are supporting OBAM aircraft . . . but their skills and understanding as designers are carry-overs from their experience in the TC aircraft world. Great amounts of money CAN buy great amounts of mediocre work product. This is avoided when a team of artful designers AND craftsmen filter the activity through the Seven Steps. You are all program managers now . . . managers who have to design, craft, do make-buy decisions and ultimately climb into and fly the work product. While "caveat emptor" was mostly applied to the exchange of real estate, it's no less applicable here. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Sep 26, 2009
9/26/2009 Hello Mike, You wrote: "........ this does not seem like a big deal to me as they are fairly long lasting devices."** I began my real plane aviation career as a US Navy airplane mechanic some 59 years ago. Since then I have spent thousands of hours working on airplanes, acquired an A&P rating, a Master's Degree in Aeronautical Engineering, built my own airplane, and flown several thousand hours. I had plenty of opportunity during that time to confront many maintainability issues. These issues come in many different forms, but one of the most important ones is accessibility -- if you can't access a part you can't fix it, adjust it, or replace it. It is very easy in the early stages of building a homebuilt to significantly underestimate the effort that will be required to access a part when the airplane is completed. I want you to envision your airplane completed and someone someday attempting to remove and replace one of the contactors which is held in place by through bolts also holding the other contactor in place on the other side of the firewall. It will require a wrench simultaneously on both the bolt head and the bolt nut. This means that two people will be required. One of those persons must dive down under the instrument panel -- not always an easy task (take it from an old man). What frequently happens when building the airplane is that one is able to use both hands on the part being worked on. When diving down under the instrument panel sometimes only one hand can reach the part. Realize also that some fairly heavy guage wires must be disconnected. Then on reinstall both contactors must be in alignment for the holding bolts to go through and wires must be reconnected. Mounting the contactors with anchor nuts can turn this into a one man job and reduce the time and effort significantly. 'OC' Says: "The best investment we can make is the effort to gather and understand knowledge." **PS: I am aware locally of three that have failed just in the last few years. ============================================= Subject: AeroElectric-List: Mounting BATT/START Relays From: "rvg8tor" <rvg8tor(at)comcast.net> My battery will be just aft of the firewall so the battery relay will be mounted on the aft side of the firewall, the start relay will be just opposite on the forward side of the firewall. I see some who install plate nuts to mount these relays individually, 4 nuts + 4 bolts+4 holes in the firewall. The holes on the two relays work out so that one could just use 2 bolts and two normal nuts (not anchor nuts) and mount the two relays through common holes in the firewall. The only drawback I can see is that if one or the other needs to be replaced then both you can't remove one without disturbing the other, this does not seem like a big deal to me as they are fairly long lasting devices. Can anyone see why my idea is a bad one? I though of heat transfer from the hot side of the firewall, but bolts into nut plates would do that to some degree, and all of the relays could be mounted forward of the firewall like many factory airplanes have them. -------- Mike "Nemo" Elliott RV-8A QB (Fuselage) ________________________________________________________________________________
Date: Sep 26, 2009
At 01:00 PM 9/26/2009, you wrote: >Hi Bob, > >West Marine carries ANCOR brand battery cable. I don't know if it's >any good. Just another piece of intel to muck things up. > Thanks for the heads-up. I checked a portion of their offerings at: http://tinyurl.com/ycmabhn It's not clear to me that this is the same "Anchor" cable company. The material illustrated has tinned conductors while welding cable does not. Further, their prices (before shipping I presume) are pretty breathtaking. Higher than 22759 stuff from Aircraft Spruce! It seems that 'Anchor' is an exceedingly popular name for various brands/businesses. Makes it difficult to find 'the one' . . . Here's one good hit http://tinyurl.com/ydjdlr2 assuming you can use 500' of 4awg. This stuff is about $1.50/ft before shipping. This is how your welding supply store would buy it and sell it for $2.25/ft or so . . . It appears that the folks we're looking for offer a huge selection of electric and wire-welding parts and tools of which welding cable is only a small fraction of their catalog. Given this penetration into the welding supplies market, it's quite likely that local stores will know all about them. If anyone finds the mother website for Anchor brand welding products, I'd appreciate hearing about it. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Sep 26, 2009
BAKEROCB, All very good points. I do try to look at future maintenance when I am building my airplane. One of the reasons I am putting my battery just aft of the firewall is I will have easy access to it via the front baggage area for charging or jumping if it goes dead, it is also a more hospitable environment for the battery. I can get to both sides of the bolts holding the relays because the front baggage door gives access. The only limiting factor I have now made for myself is if the battery relay is the only thing I needed to replace then I would not have to remove the cowl if I had used nut plates. My thought at this point is I can always go that route in the future, for now I like the fact that I have two less holes in the firewall. See my log for pictures of the completed installation, done yesterday. http://www.mykitlog.com/users/display_log.php?user=rvg8tor&project=403&category=0&log=88927&row=1 -------- Mike "Nemo" Elliott RV-8A QB (Fuselage) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=265145#265145 ________________________________________________________________________________
Date: Sep 26, 2009
Well I guess you see why I asked, I spent some time googling and didn't find much whioch actually called out the epdm insulation. Guess I should have mentioned that. I did find this place and I sent an email to ask what brand it is they carry, hopefully they will respond Monday and I'll report back. Its finding that EPDM insulation that seems tricky, I had some stuff locally but it had a paper inner liner and I didn't find the outer stuff to be very tough, it seemed easy to nick and penetrate. http://www.wesbellwireandcable.com/Welding.html -Chris RV-10 From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Saturday, September 26, 2009 3:20 PM Subject: Re: RE: AeroElectric-List: Welding cable At 01:00 PM 9/26/2009, you wrote: Hi Bob, West Marine carries ANCOR brand battery cable. I don't know if it's any good. Just another piece of intel to muck things up. Thanks for the heads-up. I checked a portion of their offerings at: http://tinyurl.com/ycmabhn It's not clear to me that this is the same "Anchor" cable company. The material illustrated has tinned conductors while welding cable does not. Further, their prices (before shipping I presume) are pretty breathtaking. Higher than 22759 stuff from Aircraft Spruce! It seems that 'Anchor' is an exceedingly popular name for various brands/businesses. Makes it difficult to find 'the one' . . . Here's one good hit http://tinyurl.com/ydjdlr2 assuming you can use 500' of 4awg. This stuff is about $1.50/ft before shipping. This is how your welding supply store would buy it and sell it for $2.25/ft or so . . . It appears that the folks we're looking for offer a huge selection of electric and wire-welding parts and tools of which welding cable is only a small fraction of their catalog. Given this penetration into the welding supplies market, it's quite likely that local stores will know all about them. If anyone finds the mother website for Anchor brand welding products, I'd appreciate hearing about it. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Sep 27, 2009
Bob, I know you are trying to help but, this last post does not seem to help me, it actually confuses me. I respect your experience but I am not trying to design an electrical system from scratch, much like I did not design my RV-8A from scratch. I picked a plane from a good designer (Van's). While building I study the plans and try to understand how the parts relate to be a better builder, if I have a question I call builder assistance and I ask questions on the forum. When it came to the electrical system, I went with a design from an expert in the field, in studying the design I asked a simple question, 'why is the alternator field switch needed". There have been a lot of words written, much of which my little brain doesn'tunderstand how it relates to the very simple question. The possible answers I was expecting were: 1. It has always been done that way 2. It doesn't matter the non-switch method will work but has these limitations (fill in the blanks) 3. You need the switch because if you don't have one it will cause XYZ. Some of what you wrote I get but I really just need the simple short answer, not a run down on design philosophy. Since you designed the systems I thought of all people you could provide the best explanation. I thank you for attempting to answer my questions, if nothing else you have convinced me not to deviate from the Z diagram. I can't say that I understand fully why the alternator field switch is a requirement other than to provide a convenient way to turn off the field. I look forward to the simple answer if there is one. -------- Mike "Nemo" Elliott RV-8A QB (Fuselage) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=265184#265184 ________________________________________________________________________________
Date: Sep 27, 2009
Hi there Mike, Perhaps I can shed a bit of light on your questions. The switch is used as it switches a smaller current than would be required on the B-lead; thus you can use a switch and not a contactor. By switching off the field you have effectively switched off the alternator in its entirety, not just its output. Now its just a spinning mechanical device. If you switch the output (B lead) then you have a live spinning device and if the fault is inside the alternator then you're still feeding it... Utilising the field to switch the alternator also allows you to fit in overvoltage protection that will quickly detect and clear any overvoltage fault that would fry all your avionics leaving you with a damaged alternator AND no instruments (electrically powered ones in any case); whereas, if the overvoltage fault is detected and cleared you can still run the instruments on the battery. If you have an internally regulated alternator then you need to switch the output by using a contactor close to the alternator, because you cannot access the field winding wire. Protecting the alternator by using a panel mounted CB means that you lead a fat wire into the cockpit to the breaker in your panel, which in turn means that there is a long bit of fat wire that is unprotected- that long bit from the alternator to the CB. Personally I don't like that. If you use a contactor that is close to the source (alternator or battery) then the only unprotected bit of fat wire is that bit between the source and the contactor. A short bit of fat wire is unlikely to fault, or has a higher reliability because it is short and mechanically robust. The closer a contactor is to the voltage source the better your chances of removing the power source from a fault. Jay -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of rvg8tor Sent: 27 September 2009 09:15 AM Subject: AeroElectric-List: Re: Why have a switch on ALT Field? Bob, I know you are trying to help but, this last post does not seem to help me, it actually confuses me. I respect your experience but I am not trying to design an electrical system from scratch, much like I did not design my RV-8A from scratch. I picked a plane from a good designer (Van's). While building I study the plans and try to understand how the parts relate to be a better builder, if I have a question I call builder assistance and I ask questions on the forum. When it came to the electrical system, I went with a design from an expert in the field, in studying the design I asked a simple question, 'why is the alternator field switch needed". There have been a lot of words written, much of which my little brain doesn'tunderstand how it relates to the very simple question. The possible answers I was expecting were: 1. It has always been done that way 2. It doesn't matter the non-switch method will work but has these limitations (fill in the blanks) 3. You need the switch because if you don't have one it will cause XYZ. Some of what you wrote I get but I really just need the simple short answer, not a run down on design philosophy. Since you designed the systems I thought of all people you could provide the best explanation. I thank you for attempting to answer my questions, if nothing else you have convinced me not to deviate from the Z diagram. I can't say that I understand fully why the alternator field switch is a requirement other than to provide a convenient way to turn off the field. I look forward to the simple answer if there is one. -------- Mike "Nemo" Elliott RV-8A QB (Fuselage) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=265184#265184 ________________________________________________________________________________
Date: Sep 27, 2009
Mike, Here is a response without embellishment. You need the alternator field switch because there is no alternator field breaker in Z-12. A fuse is used instead. You could substitute a breaker for the fuse and use it instead of a switch, but I wouldn't because: 1. You will be switching the field on and off at least once on every flight and a normal breaker is not designed to be a robust switch. 2. You could use a "switch-breaker", but I have heard so many stories about these having short life spans (at least the reasonably priced ones) that I would not put one in my aircraft. 3. I don't think you will save any money or weight using a breaker instead of the more reliable switch and fuse. Regards -------- rck Read this topic online here: http://forums.matronics.com/viewtopic.php?p=265200#265200 ________________________________________________________________________________
Date: Sep 27, 2009
9/27/209 Hello Ian, Thanks for reading my post and responding. Please let me make an attempt at reducing your confusion. You wrote: 1) "As I understand it, the switch is on the alternator field low-current 12V line (called IGN on my alternator) ........" Can you both turn ON (activate) and turn OFF (deactivate) your alternator's electrical output with this alternator field switch?** This is generally considered a desireable design goal. There are some internally regulated alternators that, once activated, draw their field current from inside the alternator and it is not possible to deactivate those alternator's electrical output by turning OFF an external field switch. While this subject has been hotly debated several times on the aeroelectric list it is generally considered that the feature of not being able to shut down the alternator's electrical output with an external field switch is an undesirable design goal. 2) "..........the circuit breaker protects the output side (B lead)." The primary purpose of a CB or fuse in the B lead is to protect the wiring in the B lead. This wiring normally goes from the positive terminal of the battery to a main battery contactor and then onto the B output terminal of the alternator. If this wiring should encounter a short to ground the BATTERY could dump a huge amount of amperage into the wiring and cause a fire. Therefore the primary purpose of the CB or fuse in the B lead wiring is to protect the wiring from BATTERY electrical output. But since there are alternators that could "run away" and not be shut down by a switch in the circuit providing electricity to the alternator's field some people who have those kinds of alternators look upon the CB in the B lead as a means of cutting off the excess electrical flow from the alternator. Depending upon the manual pulling of a circuit breaker in the B lead as the only means of terminating an over voltage situation or a "run away" alternator is generally not considered a desirable design goal. Does this help? 'OC' Says: "The best investment we can make is the effort to gather and understand knowledge." **PS: I'd be interested in knowing how your alternator field switch does work and if you have an externally or internally regulated alternator? ====================================================== Subject: Re: AeroElectric-List: Why have a switch on ALT Field? From: Ian <ixb(at)videotron.ca> OK, now here's one more vote for "confused". I thought the circuit breaker was supposed to be rated at the output amperage of the alternator because it's that current that one wants to limit. My 40A circuit breaker would do nothing for me on the alternator field circuit. As I understand it, the switch is on the alternator field low-current 12V line (called IGN on my alternator) and the circuit breaker protects the output side (B lead). Mine is wired this way because it made sense. Ian Brown, RV-9A, Bromont, QC ________________________________________________________________________________
Date: Sep 27, 2009
Subject: Welding cable
At 06:22 PM 9/26/2009, you wrote: >Well I guess you see why I asked, I spent some time googling and >didn't find much whioch actually called out the epdm >insulation. Guess I should have mentioned that. I did find >this place and I sent an email to ask what brand it is they carry, >hopefully they will respond Monday and I'll report back. Its >finding that EPDM insulation that seems tricky, I had some stuff >locally but it had a paper inner liner and I didn't find the outer >stuff to be very tough, it seemed easy to nick and penetrate. I looked at some wire in the junk box that I think came from an installation kit for an automotive super-sound system. The insulation was decidedly plastic looking (shiny) and also had a paper liner. > > ><http://www.wesbellwireandcable.com/Welding.html>http://www.wesbellwireandcable.com/Welding.html Hey, good find on the web-source! Looks like their prices are really good too. As you can see from their offerings, there are MANY different kinds of insulation . . . EPDM is not the magic material, just one of many that would be suitable. I didn't intend that one zero in on EDPM in that manner. The fact that a reel of wire (or a catalog page) cites EDPM says that you KNOW what's being offered. That reel of shiny stuff with unknown and/or questionable insulation material MIGHT be okay. Without identification or other qualification data like materials or temperature ratings, it's good to move on and consider other sources. Looks like the WesBell folks are an excellent source of wire suitable for use as fat wires in your airplane. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Sep 27, 2009
Subject: While on the topic of alternators
I've had a number of private e-mails on the alternator field switch thing. I want to thank those who have joined the discussion with lucid and accurate offerings of their own. I recalled an article that was sent to me about spring time of last year where the author attempted to explain the simple-ideas upon which the battery/alternator power system works in our airplanes. Seems that many folks on the 'net were citing this article as a valuable reference. http://www.aeroelectric.com/articles/Know_Your_Charging_System.pdf Those who are interested in expanding their understanding of what alternators do (and don't do) are encouraged to review this piece wherein I've endeavored to screen out the 'chunks' of misinformation. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Sep 27, 2009
This is the way I understand it. Please correct me if I am wrong. The alternator output current does not need to be limited by a circuit breaker because the alternator output is self-limiting. If one were to add more loads to a fully loaded alternator, the voltage would drop, thus limiting the current automatically. It is not desired to unnecessarily run the alternator B lead into the cockpit. The B-lead circuit breaker is not necessary, and adds weight, cost and complexity. The purpose of an ANL fuse on the alternator output is not to protect the alternator or to prevent it from producing more than its rated current. The purpose of the ANL fuse is to protect the wires between the battery and alternator from 400+ amps of battery current in the event that the alternator shorts out, most likely from shorted diodes. In the event that an over-voltage condition occurs (due to a faulty regulator), an over-voltage module will short out the supply voltage that goes to the alternator field. If that happens, an alternator-field circuit breaker will trip, thus protecting the wires from excessive current resulting from this short circuit. Joe ________________________________________________________________________________
Date: Sep 27, 2009
rckol wrote: > > > 1. You will be switching the field on and off at least once on every flight and a normal breaker is not designed to be a robust switch. Why?? Is there a need to turn the alternator on/off separate from the master if it is functioning correctly? > 2. You could use a "switch-breaker", but I have heard so many stories about these having short life spans (at least the reasonably priced ones) that I would not put one in my aircraft. The Klixon switch breakers in my Mooney are almost all OEM from 45 years/6000 hours ago. A couple have been replaced from springs getting weak. ________________________________________________________________________________
Date: Sep 27, 2009
Jay, Thank you so much. Spelling out what may be obvious or intuitive to experienced hands is a great assistance to us neophyte electron herders. Tony Velocity SEFG 62% done, 78% to go www.alejandra.net/velocity -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Jay Hyde Sent: Sunday, September 27, 2009 3:04 AM Subject: RE: AeroElectric-List: Re: Why have a switch on ALT Field? --> Hi there Mike, Perhaps I can shed a bit of light on your questions. The switch is used as it switches a smaller current than would be required on the B-lead; thus you can use a switch and not a contactor. By switching off the field you have effectively switched off the alternator in its entirety, not just its output. Now its just a spinning mechanical device. If you switch the output (B lead) then you have a live spinning device and if the fault is inside the alternator then you're still feeding it... Utilising the field to switch the alternator also allows you to fit in overvoltage protection that will quickly detect and clear any overvoltage fault that would fry all your avionics leaving you with a damaged alternator AND no instruments (electrically powered ones in any case); whereas, if the overvoltage fault is detected and cleared you can still run the instruments on the battery. If you have an internally regulated alternator then you need to switch the output by using a contactor close to the alternator, because you cannot access the field winding wire. Protecting the alternator by using a panel mounted CB means that you lead a fat wire into the cockpit to the breaker in your panel, which in turn means that there is a long bit of fat wire that is unprotected- that long bit from the alternator to the CB. Personally I don't like that. If you use a contactor that is close to the source (alternator or battery) then the only unprotected bit of fat wire is that bit between the source and the contactor. A short bit of fat wire is unlikely to fault, or has a higher reliability because it is short and mechanically robust. The closer a contactor is to the voltage source the better your chances of removing the power source from a fault. Jay -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of rvg8tor Sent: 27 September 2009 09:15 AM Subject: AeroElectric-List: Re: Why have a switch on ALT Field? Bob, I know you are trying to help but, this last post does not seem to help me, it actually confuses me. I respect your experience but I am not trying to design an electrical system from scratch, much like I did not design my RV-8A from scratch. I picked a plane from a good designer (Van's). While building I study the plans and try to understand how the parts relate to be a better builder, if I have a question I call builder assistance and I ask questions on the forum. When it came to the electrical system, I went with a design from an expert in the field, in studying the design I asked a simple question, 'why is the alternator field switch needed". There have been a lot of words written, much of which my little brain doesn'tunderstand how it relates to the very simple question. The possible answers I was expecting were: 1. It has always been done that way 2. It doesn't matter the non-switch method will work but has these limitations (fill in the blanks) 3. You need the switch because if you don't have one it will cause XYZ. Some of what you wrote I get but I really just need the simple short answer, not a run down on design philosophy. Since you designed the systems I thought of all people you could provide the best explanation. I thank you for attempting to answer my questions, if nothing else you have convinced me not to deviate from the Z diagram. I can't say that I understand fully why the alternator field switch is a requirement other than to provide a convenient way to turn off the field. I look forward to the simple answer if there is one. -------- Mike "Nemo" Elliott RV-8A QB (Fuselage) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=265184#265184 ________________________________________________________________________________
Date: Sep 27, 2009
At 09:58 AM 9/27/2009, you wrote: >This is the way I understand it. Please correct me if I am wrong. > > The alternator output current does not need to be limited by a > circuit breaker because the alternator output is self-limiting. correct > If one were to add more loads to a fully loaded alternator, the > voltage would drop, thus limiting the current automatically. yes > It is not desired to unnecessarily run the alternator B lead into > the cockpit. yes > The B-lead circuit breaker is not necessary, and adds weight, > cost and complexity. > The purpose of an ANL fuse on the alternator output is not to > protect the alternator or to prevent it from producing more than > its rated current. The purpose of the ANL fuse is to protect the > wires between the battery and alternator from 400+ amps of battery > current in the event that the alternator shorts out, most likely > from shorted diodes. Yup . . . > In the event that an over-voltage condition occurs (due to a > faulty regulator), an over-voltage module will short out the supply > voltage that goes to the alternator field. If that happens, an > alternator-field circuit breaker will trip, thus protecting the > wires from excessive current resulting from this short circuit. Yes . . . this is a property unique to the crowbar philosophy for opening the alternator's field supply after an ov condition is detected. There are other designs that do not open the field supply breaker . . . and can be considered as a potential player in your design goals. The reason that Z-figures featuring crowbar ov protection -AND- fuseblocks have a field supply breaker is to accommodate the crowbar ov control philosophy. If non-crowbar shutdown products are considered, then one could easily supply alternator field through one of the fuses and leave the circuit breaker out. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Sep 27, 2009
Subject: Re: Why have a switch on ALT Field?
Why?? Is there a need to turn the alternator on/off separate from the master if it is functioning correctly? Depends on your architecture. Does the MASTER control the alternator too? Is the MASTER a progressive transfer two-pole switch or classic "split rocker". Then indeed, the alternator field breaker may never need to be touched. But if the MASTER is a simple two-pole switch that controls alternator and battery at the same time, then you could use the field breaker to shut the alternator down for battery-only ground-ops. 2. The Klixon switch breakers in my Mooney are almost all OEM from 45 years/6000 hours ago. A couple have been replaced from springs getting weak. But the Potter-Brumfield W31 style breakers installed in many other airplanes for about the same length of time have been identified has having a safety of flight failure mode that is prompting an AD to replace about 80,000 of the critters. Not all switch breakers are alike. All are much more expensive than the fuse/switch architecture featured in the Z-figures. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Subject: Why have a switch on ALT Field?
Date: Sep 28, 2009
9/28/2009 Hello Again Mike, You wrote: "I look forward to the simple answer if there is one." Let's try this -- How do you intend to simulate or check the continued functioning of essential for flight avionics items when you are airborne and have a non functioning alternator because: the field wire broke,** the belt broke, or whatever? Here is my answer: At the end of each flight while the engine is still running I turn off the alternator by means of its field switch and ensure that: A) The essential for flight avionics items (Garmin 430W and transponder) can still function off an essential bus. (These items needed to return to my home field inside the Washington DC SFRA.) B) My low voltage warning system (a flashing light) is still functioning. Discussion: 1) Why not perform check A above at the beginning of each flight before the engine is started and the alternator is not yet putting out current? Because: a) I do not have my Garmin 430W and transponder turned on prior to or during engine start, and b) I don't want to put the electrical burden of the Garmin 430W and transponder on the battery before engine start. 2) Why not perform check B above at the beginning of each flight before the engine is started and the alternator is not yet putting out current? That check is indeed accomplished as soon as the master battery contactor is closed at the beginning of the flight. The B check at the end of the flight is a duplication of the before flight B check and is just a system design fall out in order to perform check A. 3) Why not just use pulling the alternator field CB as a means of turning off the alternator at the end of each flight? I have not priced the cost differential between replacing my fancy, internally illuminated, rocker activated, alternator field switch and the alternator field CB, but I do know this: a) The switch is designed to be switched on and off thousands of times, the CB is not, and b) It will be much easier for me to replace the switch than the CB. So please let me know what you decide regarding whether or not you will install the alternator field switch and what were the deciding factors in that decision. Thanks. 'OC' Says: "The best investment we can make is the effort to gather and understand knowledge." **PS: This happened to a friend of mine in his Beech Sierra just a few months ago. He has no low voltage warning system other than looking at an aftermarket automotive gadget voltmeter plugged into his cigarette lighter -- not very visible. His first real warning was when his VHF comm began to not work properly because the battery was becoming depleted. Soon he had no electronic nav functions either. He was on an IFR flight plan, but in VMC. He spotted a little podunk airport and landed. A mechanic at the airport quickly diagnosed the problem, repaired the wire, and my friend was on his way shortly. But what if he has been in IMC? What if he had not spotted podunk airport? What if there was no repair person or facility at podunk airport? Using your word "convenient" do you think that he would have had a convenient termination of that flight? ==================================================== Subject: AeroElectric-List: Re: Why have a switch on ALT Field? From: "rvg8tor" <rvg8tor(at)comcast.net> Bob, I know you are trying to help but, this last post does not seem to help me, it actually confuses me. I respect your experience but I am not trying to design an electrical system from scratch, much like I did not design my RV-8A from scratch. I picked a plane from a good designer (Van's). While building I study the plans and try to understand how the parts relate to be a better builder, if I have a question I call builder assistance and I ask questions on the forum. When it came to the electrical system, I went with a design from an expert in the field, in studying the design I asked a simple question, 'why is the alternator field switch needed". There have been a lot of words written, much of which my little brain doesn'tunderstand how it relates to the very simple question. The possible answers I was expecting were: 1. It has always been done that way 2. It doesn't matter the non-switch method will work but has these limitations (fill in the blanks) 3. You need the switch because if you don't have one it will cause XYZ. Some of what you wrote I get but I really just need the simple short answer, not a run down on design philosophy. Since you designed the systems I thought of all people you could provide the best explanation. I thank you for attempting to answer my questions, if nothing else you have convinced me not to deviate from the Z diagram. I can't say that I understand fully why the alternator field switch is a requirement other than to provide a convenient way to turn off the field. I look forward to the simple answer if there is one. -------- Mike "Nemo" Elliott RV-8A QB (Fuselage) ________________________________________________________________________________
Subject: Re: Welding cable
From: "tomcostanza" <Tom(at)CostanzaAndAssociates.com>
Date: Sep 28, 2009
Here's another data point: http://www.cableyard.com/catalog/index.php?cPath=21&osCsid=0cc7974ccdf864c041a7cdd5357e601a -------- Clear Skies, Tom Costanza Read this topic online here: http://forums.matronics.com/viewtopic.php?p=265302#265302 ________________________________________________________________________________
Date: Sep 28, 2009
> >When it came to the electrical system, I went with a design from an >expert in the >field, in studying the design I asked a simple question, >'why is the alternator field switch needed". There have been a lot >of words written, >much of which my little brain doesn'tunderstand how it relates to the very >simple question. I'm sorry if my words are too much for you. When I wear my teacher-hat, the answers I offer are intended to lead to understanding of the foundation upon which the answer is based. It's my belief that once understanding is achieved, the student then becomes a teacher on the same discussion. Perhaps I presume too much . . . that everyone here on the List is as enthusiastic about understanding as I . . . > The possible answers I was expecting were: > >1. It has always been done that way Okay, with my expert-hat on, that answer works for me. Fly comfortably my friend . . . Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Sep 28, 2009
At 08:56 AM 9/28/2009, you wrote: > > >Here's another data point: > >http://www.cableyard.com/catalog/index.php?cPath=21&osCsid=0cc7974ccdf864c041a7cdd5357e601a Another score from the 3-point line . . . thanks! Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Sep 28, 2009
McMaster-Carr supplies welding cable in two insulation types at a reasonable price... http://www.mcmaster.com/#welding-cable/=3tsvkp Chris Stone RV-* >>Where can you find the anchor brand cable? Any weblinks/supply you >>can point to. >>Thanks >>Chris >>RV-10 > > ________________________________________________________________________________
Date: Sep 28, 2009
From: "George, Neal E Capt USAF ACC 605 TES/DOA" <Neal.George(at)hurlburt.af.mil>
I'm sorry if my words are too much for you. When I wear my teacher-hat, the answers I offer are intended to lead to understanding of the foundation upon which the answer is based. It's my belief that once understanding is achieved, the student then becomes a teacher on the same discussion. Perhaps I presume too much . . . that everyone here on the List is as enthusiastic about understanding as I . . . Keep at it Bob - I generally need to be told more than once. As for the presentation style, I learn more than electron herding here. Too many of us can barely speak, much less write... neal ________________________________________________________________________________
Date: Sep 28, 2009
At 09:36 AM 9/28/2009, you wrote: > >McMaster-Carr supplies welding cable in two insulation types at a >reasonable price... > >http://www.mcmaster.com/#welding-cable/=3tsvkp Thanks! I should have thought about those guys. I'm thinking about adding a page to the website too link to the hot prospects . . . Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Sep 28, 2009
> I'm sorry if my words are too much for you. > When I wear my teacher-hat, the answers > I offer are intended to lead to understanding of > the foundation upon which the answer is based. > It's my belief that once understanding is > achieved, the student then becomes a teacher > on the same discussion. Perhaps I presume too > much . . . that everyone here on the List is > as enthusiastic about understanding as I . . . Don't stop, Bob...that's the way I always try to explain things, figuring that most people don't believe me or want to know the reason why and need a more detailed explanation or an understanding for themselves...that was from my working days as well, when I had to train the mechanics after I had installed one of the new automated systems. Of course they all usually fall asleep ... Harley ________________________________________________________________________________
Date: Sep 28, 2009
> > I'm thinking about adding a page to the > website too link to the hot prospects . . . Broke down and did it. See: http://aeroelectric.com/Sources.html . . . as readers discover additional web sources for other unique materials or tools that belong on this list are encouraged to let me know about them. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Sep 28, 2009
Bob N. Please to not take my request for a simpler answer the wrong way, I am enthusiastic about learning, I was just not getting it. When I was asked about teaching as in instructor pilot in the Air Force, I always said what made a good instructor was being able to give the same information many different ways until the student got it. We all learn different ways and at a different pace. My email to you was meant to communicate that I was not getting it, please tell me a different way. In radio jargon "I did not copy say again". To everyone on this thread, my knowledge of how the alternator and regulator and field work has increased ten fold and that is what my ultimate goal was, I never want to stop learning. I will put in the field switch after all is said and done for the following reasons not in any particular priority. 1. CBs don't' make good switches 2. Convenience 3. There might be something I did not get and don't want to add a switch later 4. It had always been done that way [Laughing] Thank you again to all who posted I hope I am not the only one who gained from this thread. -------- Mike "Nemo" Elliott RV-8A QB (Fuselage) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=265358#265358 ________________________________________________________________________________
Date: Sep 28, 2009
Ditto on that Bob!! I always go to McMaster and just as quickly forget I did. -Chris -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Monday, September 28, 2009 12:54 PM Subject: RE: AeroElectric-List: Welding cable At 09:36 AM 9/28/2009, you wrote: > >McMaster-Carr supplies welding cable in two insulation types at a >reasonable price... > >http://www.mcmaster.com/#welding-cable/=3tsvkp Thanks! I should have thought about those guys. I'm thinking about adding a page to the website too link to the hot prospects . . . Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Sep 28, 2009
Subject: Welding cable, cabbages and kings
At 06:28 PM 9/28/2009, you wrote: > >Ditto on that Bob!! I always go to McMaster and just as quickly forget I >did. Just too many things for the ol' gray matter to keep a grip on . . . but gee, McMaster-Carr? I used to mail order from their 2+ inch thick mail order catalog over 30 years ago. If they didn't have it in that catalog you probably didn't need it! I may be renewing an old acquaintance with them. Out here in cow and buzzard country, everything is 100 miles away . . . well not quite. We've got one of those 10,000 sq ft Ace hardware stores in Pratt that is VERY well stocked. They're only 30 miles away but with prices that are pretty breathtaking. Would you believe $4.75 for a 2-foot piece of valve stem packing? I need to find that stash of bee's wax and graphite! But if you gotta have it today, it's possible. The stores here in M.L. are quite adequate to routine needs and they too are willing to get stuff in on "Wednesday's truck". At the same time, I've got at least two dozen projects on the to-do list at all times. If one needs to pause while necessary goodies come in the mail, or UPS there are always plenty of alternatives to keep the moment productive. It certainly changes the way you think about things. Projects I was accustomed to finishing in a few hours after spool-up might take several days here if I don't have everything needed in 'inventory'. In some ways I think it's a good thing. You get to consider design goals and processes on a wider horizon and more relaxed imperative. Folks you work for are seldom upset if you have to order in materials. It's a much more relaxed but no less certain way of orchestrating one's priorities. Overnight UPS out of Digikey works well to M.L. too and at no greater expense than to Wichita Total hands-on time for a project isn't much longer but the challenge to craft expedient alternatives is greater. Dad's shop was loaded with little jigs, fixtures, mysterious bits and pieces that had to have been the product of his expanded creative horizons. I'm really enjoying the walk in his shoes. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Sep 28, 2009
> >To everyone on this thread, my knowledge of how the alternator and >regulator and field work has increased ten fold and that is what my >ultimate goal was, I never want to stop learning. Great! >I will put in the field switch after all is said and done for the >following reasons not in any particular priority. > >1. CBs don't' make good switches >2. Convenience >3. There might be something I did not get and don't want to add a >switch later >4. It had always been done that way [Laughing] All those things are true so even if the explanations offered seem arcane, the benefits for having the switch will be secured. >Thank you again to all who posted I hope I am not the only one who >gained from this thread. At last count, subscribers to this List numbered over 1800. If you look at the posting stats on Matronics, this list is one of the busiest on Matt's service. I have to believe the goals for sharing are being realized. Thank you for participating. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Sep 29, 2009
Bob... You've a great idea... Electronics: http://www.mouser.com/ Chris Stone RV-8 -----Original Message----- >From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> >Sent: Sep 28, 2009 1:47 PM >To: aeroelectric-list(at)matronics.com >Subject: RE: AeroElectric-List: Welding cable > > >> >> I'm thinking about adding a page to the >> website too link to the hot prospects . . . > > Broke down and did it. See: > >http://aeroelectric.com/Sources.html > > . . . as readers discover additional web > sources for other unique materials or tools > that belong on this list are encouraged to > let me know about them. > > > Bob . . . > > --------------------------------------- > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > --------------------------------------- > > ________________________________________________________________________________
Date: Sep 29, 2009
At 08:23 AM 9/29/2009, you wrote: > >Bob... > >You've a great idea... > >Electronics: > >http://www.mouser.com/ got it. thanks. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Sep 29, 2009
To all: I have some Carol #2 welding cable in stock. I also have some #4 black tin coated extraflex. the marking on the cable : 4 AWG AWM 10070 105C 600V E42481 VW-1 CSA AWM I A/B 105C 600V FT1 LL59358. I also have green with the same specs. This Material is in my stockroom and we currently do not have requirements. I can sell this material for a dollar a foot. Contact me off list if you are interested. Regards Ron Raby www.advanceddesign.com ronr(at)advanceddesign.com ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Sent: Tuesday, September 29, 2009 9:41 AM Subject: RE: AeroElectric-List: Welding cable > > > At 08:23 AM 9/29/2009, you wrote: >> >> >>Bob... >> >>You've a great idea... >> >>Electronics: >> >>http://www.mouser.com/ > > got it. thanks. > > > Bob . . . > > --------------------------------------- > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > --------------------------------------- > > > ________________________________________________________________________________
Date: Sep 29, 2009
Subject: Re: Mounting BATT/START Relays
Mike, How about using a piece of 'all thread rod' through the firewall with a nut on each side of the firewall to secure it, then mount the contactors with another nut. Now either contactor can be removed from one side without disturbing the other. My .02 On Sat, Sep 26, 2009 at 12:02 PM, wrote: > > 9/26/2009 > > Hello Mike, You wrote: "........ this does not seem like a big deal to me > as they are fairly long lasting devices."** > > > John McMahon Lancair Super ES, S/N 170, N9637M (Reserved) ________________________________________________________________________________
Date: Sep 29, 2009
Bob For your Sources of Tools and Materials page, a good wire source, both 22759 and welding cable (red and black), we used Wiremasters and got excellent prices on all our wire and service was excellent. Our contact person was Deb Sullivan. http://www.wiremasters.net/ John McMahon Lancair Super ES, S/N 170, N9637M (Reserved) ________________________________________________________________________________
Date: Sep 29, 2009
At 12:34 PM 9/29/2009, you wrote: >Bob > >For your Sources of Tools and Materials page, a good wire source, >both 22759 and welding cable (red and black), we used Wiremasters >and got excellent prices on all our wire and service was excellent. >Our contact person was Deb Sullivan. Good hit. It's been added to the page . . . Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Subject: Visio?
Date: Sep 29, 2009
Has anyone tried using Visio to draw their schematic? It looks like it will work but I'm not finding much in the way of automotive symbols i.e. solenoids relays etc. Can anyone recommend a free or cheap program for this? Thanks, Tim Andres ________________________________________________________________________________
Subject: Re: Visio?
Date: Sep 29, 2009
Hi Tim. Go here: www.vx-aviation.com and follow the link near the top of the page for the free schematic software, library and design example from my RV-9A. Doesn't have everything but it's very easy to create symbols on the fly. Thanks, Vern Little -------------------------------------------------- From: "Tim Andres" <tim2542(at)sbcglobal.net> Sent: Tuesday, September 29, 2009 9:37 PM Subject: AeroElectric-List: Visio? > > > > Has anyone tried using Visio to draw their schematic? It looks like it > will > work but I'm not finding much in the way of automotive symbols i.e. > solenoids relays etc. > Can anyone recommend a free or cheap program for this? > Thanks, Tim Andres > > > ________________________________________________________________________________
Subject: Visio?
Date: Sep 30, 2009
I have used Visio a lot and re-drawn many of the symbols- I can let you have my 'library page' if you'd like. I use Visio a lot so I found it pretty useful to draw the schematics as well. Jay -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Tim Andres Sent: 30 September 2009 06:38 AM Subject: AeroElectric-List: Visio? Has anyone tried using Visio to draw their schematic? It looks like it will work but I'm not finding much in the way of automotive symbols i.e. solenoids relays etc. Can anyone recommend a free or cheap program for this? Thanks, Tim Andres ________________________________________________________________________________
Subject: Re: Visio?
Date: Sep 30, 2009
jay(at)horriblehyde.com wrote: > I have used Visio a lot and re-drawn many of the symbols- I can let you have > my 'library page' if you'd like. > > I use Visio a lot so I found it pretty useful to draw the schematics as > well. > > Jay > > -- If you are able to make available your library of Visio symbols that would be appreciated. I have a Visio one off aircraft symbols that I got of the net that I am happy to share (the file extension .VSS is not permitted for attachments) - contact to email. Regards Peter Armstrong Auckland, New Zealand Building a French carbon fibre plane MCR-4S "www.dynaero.com" Read this topic online here: http://forums.matronics.com/viewtopic.php?p=265679#265679 ________________________________________________________________________________
Subject: Re: Visio?
Date: Sep 30, 2009
Hi there Peter, I have sent what I have to you via your email address; you can also convert the dwg files that Bob supplies, although I find that using them after conversion is not easy. If anyone else wants what I have (not much..) then mail me directly. Jay -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of pestar Sent: 30 September 2009 10:09 AM Subject: AeroElectric-List: Re: Visio? jay(at)horriblehyde.com wrote: > I have used Visio a lot and re-drawn many of the symbols- I can let you have > my 'library page' if you'd like. > > I use Visio a lot so I found it pretty useful to draw the schematics as > well. > > Jay > > -- If you are able to make available your library of Visio symbols that would be appreciated. I have a Visio one off aircraft symbols that I got of the net that I am happy to share (the file extension .VSS is not permitted for attachments) - contact to email. Regards Peter Armstrong Auckland, New Zealand Building a French carbon fibre plane MCR-4S "www.dynaero.com" Read this topic online here: http://forums.matronics.com/viewtopic.php?p=265679#265679 ________________________________________________________________________________
Date: Sep 30, 2009
Subject: Re: Visio?
Hi Tim, Here's mine, all done in Visio......... I started off by importing Bob's CAD drawings and then converting them. I then went about "cleaning" up the less than perfect result and saving the individual components as "groups". After that, drag and drop and copy and paste works a charm in Visio. Would you like a copy of the source? Andrew. ----- Original Message ----- From: "Tim Andres" <tim2542(at)sbcglobal.net> Sent: Wednesday, 30 September, 2009 05:37:41 GMT +00:00 GMT Britain, Ireland, Portugal Subject: AeroElectric-List: Visio? Has anyone tried using Visio to draw their schematic? It looks like it will work but I'm not finding much in the way of automotive symbols i.e. solenoids relays etc. Can anyone recommend a free or cheap program for this? Thanks, Tim Andres ________________________________________________________________________________
Date: Sep 30, 2009
From: Bill Mauledriver Watson <MauleDriver(at)nc.rr.com>
Subject: Re: Visio?
I'm using that product too and like it a lot. A belated Thanks Vern! If anyone installs it and wants a sample, I'd be glad to share my schematics. (but you have to have the SCH tool installed to view it) Bill Vern Little wrote: > > > Hi Tim. > Go here: www.vx-aviation.com and follow the link near the top of the > page for the free schematic software, library and design example from > my RV-9A. Doesn't have everything but it's very easy to create symbols > on the fly. > > Thanks, > Vern Little > > -------------------------------------------------- > From: "Tim Andres" <tim2542(at)sbcglobal.net> > Sent: Tuesday, September 29, 2009 9:37 PM > To: > Subject: AeroElectric-List: Visio? > >> >> >> >> Has anyone tried using Visio to draw their schematic? It looks like >> it will >> work but I'm not finding much in the way of automotive symbols i.e. >> solenoids relays etc. >> Can anyone recommend a free or cheap program for this? >> Thanks, Tim Andres >> >> >> >> >> > > ________________________________________________________________________________
Subject: Re: Visio?
From: Michael W Stewart <mike.stewart(at)us.ibm.com>
Date: Sep 30, 2009
My drawings all in visio here. http://mstewart.net/super8/visio/S8Panelandwiringr1.vsd or if you want to peruse the html version on a browser here. http://mstewart.net/super8/visio/n687msvisio_files.htm I keep the html version up so when Im on the raod with a problem, I can access all my connector pin outs and things. Enjoy, Mike From: "pestar" <peter(at)reivernet.com> To: aeroelectric-list(at)matronics.com Date: 09/30/2009 04:38 AM Subject: AeroElectric-List: Re: Visio? Sent by: owner-aeroelectric-list-server(at)matronics.com jay(at)horriblehyde.com wrote: > I have used Visio a lot and re-drawn many of the symbols- I can let y ou have > my 'library page' if you'd like. > > I use Visio a lot so I found it pretty useful to draw the schematics as > well. > > Jay > > -- If you are able to make available your library of Visio symbols that wo uld be appreciated. I have a Visio one off aircraft symbols that I got of the net that I am happy to share (the file extension .VSS is not permitted for attachments) - contact to email. Regards Peter Armstrong Auckland, New Zealand Building a French carbon fibre plane MCR-4S "www.dynaero.com" Read this topic online here: http://forums.matronics.com/viewtopic.php?p=265679#265679 ======================== ============ ======================== ============ ======================== ============ ======================== ============ ________________________________________________________________________________
Date: Sep 30, 2009
Subject: Re: Inspection camera
On 07/08/2009 07:37 AM, Harley wrote: > I think I did mention that in one of the emails I sent. In response > to other concerns over the camera's diameter being too large to fit in > a spark plug hole, I also mentioned that there is a 9 mm camera and > extension available for the Ridgid unit, that might fit the HF one. I > believe that smaller camera version was listed as having a shorter > focal length. Here is the 9.5mm camera for $107: <http://www.reliablepaper.com/Imager_Head_and_Cable_p/632-30068.htm> You can also get the Rigid inspection camera unit here for $85, which I think is the same thing as the HF unit: <http://www.reliablepaper.com/SeeSnake_Micro_Inspection_Camera_p/632-31133.htm> They also have a $49 version. I'm not sure what the differences are: <http://www.reliablepaper.com/SeeSnake_Micro_Inspection_Camera_p/632-31128.htm> fyi -Dj -- Dj Merrill - N1JOV Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Grumman Yankee Driver N9870L - http://deej.net/yankee/ ________________________________________________________________________________
Date: Sep 30, 2009
They look identical to the borescope I bought from Harbor Freight a few months ago. Excellent tool. Has a solid, firm feel to it, too. One ad mentioned a 30 foot extension? Where can I find one of those? Oh, the one I have allows the video head to be removed from the handheld and can be moved some feet away from where the actual tool is working, allowing others to see. David M. Dj Merrill wrote: > > On 07/08/2009 07:37 AM, Harley wrote: >> I think I did mention that in one of the emails I sent. In response >> to other concerns over the camera's diameter being too large to fit in >> a spark plug hole, I also mentioned that there is a 9 mm camera and >> extension available for the Ridgid unit, that might fit the HF one. I >> believe that smaller camera version was listed as having a shorter >> focal length. > > Here is the 9.5mm camera for $107: > <http://www.reliablepaper.com/Imager_Head_and_Cable_p/632-30068.htm> > > You can also get the Rigid inspection camera unit here for $85, > which I think is the same thing as the HF unit: > <http://www.reliablepaper.com/SeeSnake_Micro_Inspection_Camera_p/632-31133.htm> > > They also have a $49 version. I'm not sure what the differences are: > <http://www.reliablepaper.com/SeeSnake_Micro_Inspection_Camera_p/632-31128.htm> > > fyi > > -Dj > > > > ------------------------------------------------------------------------ > > > Checked by AVG - www.avg.com > ________________________________________________________________________________
Date: Sep 30, 2009
DJ, It appears that the $49 "version" isn't a less expensive camera but a 3' extension cable for the $85 camera unit. I'm considering ordering the basic camera and the 9.5mm camera head. Looks very interesting. Bob Borger Europa XS, Rotax 914, Airmaster C/S prop On Wednesday, September 30, 2009, at 09:38AM, "Dj Merrill" wrote: > >On 07/08/2009 07:37 AM, Harley wrote: >> I think I did mention that in one of the emails I sent. In response >> to other concerns over the camera's diameter being too large to fit in >> a spark plug hole, I also mentioned that there is a 9 mm camera and >> extension available for the Ridgid unit, that might fit the HF one. I >> believe that smaller camera version was listed as having a shorter >> focal length. > > Here is the 9.5mm camera for $107: ><http://www.reliablepaper.com/Imager_Head_and_Cable_p/632-30068.htm> > > You can also get the Rigid inspection camera unit here for $85, >which I think is the same thing as the HF unit: ><http://www.reliablepaper.com/SeeSnake_Micro_Inspection_Camera_p/632-31133.htm> > > They also have a $49 version. I'm not sure what the differences are: ><http://www.reliablepaper.com/SeeSnake_Micro_Inspection_Camera_p/632-31128.htm> > >fyi > >-Dj > >-- >Dj Merrill - N1JOV >Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ >Grumman Yankee Driver N9870L - http://deej.net/yankee/ > > ________________________________________________________________________________
Date: Sep 30, 2009
Ok, the difference between the $49 and $85 versions appears to be the length of the cable. The $49 is 3 feet while the $85 is 6 feet, according to the ads. Mine is 3 feet from HF. Heckuva bargain at $49. David M. Dj Merrill wrote: > > On 07/08/2009 07:37 AM, Harley wrote: >> I think I did mention that in one of the emails I sent. In response >> to other concerns over the camera's diameter being too large to fit in >> a spark plug hole, I also mentioned that there is a 9 mm camera and >> extension available for the Ridgid unit, that might fit the HF one. I >> believe that smaller camera version was listed as having a shorter >> focal length. > > Here is the 9.5mm camera for $107: > <http://www.reliablepaper.com/Imager_Head_and_Cable_p/632-30068.htm> > > You can also get the Rigid inspection camera unit here for $85, > which I think is the same thing as the HF unit: > <http://www.reliablepaper.com/SeeSnake_Micro_Inspection_Camera_p/632-31133.htm> > > They also have a $49 version. I'm not sure what the differences are: > <http://www.reliablepaper.com/SeeSnake_Micro_Inspection_Camera_p/632-31128.htm> > > fyi > > -Dj > > > > ------------------------------------------------------------------------ > > > Checked by AVG - www.avg.com > ________________________________________________________________________________
Date: Sep 30, 2009
DJ (and others)... Be careful that you know what you order from the website you linked below. Cjeck out the next page: www.reliablepaper.com/Ridgid_SeeSnake_micro_Inspection_Camera_s/6295.htm It looks like they used a stock picture of the entire camera set for not only the camera head, but each of the accessory options except the 9mm camera. If that's true, then even if you get the camera, you will still have to buy the cable and the accessory kit separately...the $49 version appears to be JUST the 3 foot cable extension. When you get done buying everything you need, it'll be a bit more than the HF unit which is $139 right now, but goes on "sale" regularly for $99.. Having said that, the major difference between the Rigid unit and the Harbor Freight one, is that the HF unit has a REMOVABLE screen that is wireless. I was able to remove the screen, plug it in to my computer, then walk out to the garage while recording what it was seeing into my computer (it doesn't come with the software to do that, just an video cable...I already had an video to digital converter and the software). I tried using the HF unit with the screen attached several times, but even for simple inspections, it was easier to detach it so I could manipulate the camera without having to stand on my head to see the screen. Harley Dixon ------------------------------------------------------------------------ Dj Merrill wrote: > > On 07/08/2009 07:37 AM, Harley wrote: > >> I think I did mention that in one of the emails I sent. In response >> to other concerns over the camera's diameter being too large to fit in >> a spark plug hole, I also mentioned that there is a 9 mm camera and >> extension available for the Ridgid unit, that might fit the HF one. I >> believe that smaller camera version was listed as having a shorter >> focal length. >> > > Here is the 9.5mm camera for $107: > <http://www.reliablepaper.com/Imager_Head_and_Cable_p/632-30068.htm> > > You can also get the Rigid inspection camera unit here for $85, > which I think is the same thing as the HF unit: > <http://www.reliablepaper.com/SeeSnake_Micro_Inspection_Camera_p/632-31133.htm> > > They also have a $49 version. I'm not sure what the differences are: > <http://www.reliablepaper.com/SeeSnake_Micro_Inspection_Camera_p/632-31128.htm> > > fyi > > -Dj > > ________________________________________________________________________________
Date: Sep 30, 2009
On 09/30/2009 11:45 AM, Harley wrote: > DJ (and others)... > > Be careful that you know what you order from the website you linked > below. > Cjeck out the next page: > www.reliablepaper.com/Ridgid_SeeSnake_micro_Inspection_Camera_s/6295.htm > Thanks! I didn't catch that. Looks like the camera unit itself is $76 at: <http://www.reliablepaper.com/SeeSnake_Micro_Inspection_Camera_p/632-26663.htm> plus the 9.5mm camera and cable for $107 at: <http://www.reliablepaper.com/Imager_Head_and_Cable_p/632-30068.htm> so it would cost around $183 in total for the smaller camera. It is not clear whether you would also have to buy the accessory pack (mirrors) separately for $17 at: <http://www.reliablepaper.com/Hook_Magnet_and_Mirror_Attachment_Accessory_Pack_p/632-26668.htm> -Dj -- Dj Merrill - N1JOV Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Grumman Yankee Driver N9870L - http://deej.net/yankee/ ________________________________________________________________________________
Date: Sep 30, 2009
didn't someone get an inspection camers from harbor frt.? how did it work out? bob noffs On Wed, Sep 30, 2009 at 1:20 PM, Dj Merrill wrote: > > On 09/30/2009 11:45 AM, Harley wrote: > > DJ (and others)... > > > > Be careful that you know what you order from the website you linked > > below. > > Cjeck out the next page: > > www.reliablepaper.com/Ridgid_SeeSnake_micro_Inspection_Camera_s/6295.htm > > > > Thanks! I didn't catch that. > > Looks like the camera unit itself is $76 at: > < > http://www.reliablepaper.com/SeeSnake_Micro_Inspection_Camera_p/632-26663.htm > > > > plus the 9.5mm camera and cable for $107 at: > <http://www.reliablepaper.com/Imager_Head_and_Cable_p/632-30068.htm> > > so it would cost around $183 in total for the smaller camera. > > It is not clear whether you would also have to buy the accessory pack > (mirrors) separately for $17 at: > < > http://www.reliablepaper.com/Hook_Magnet_and_Mirror_Attachment_Accessory_Pack_p/632-26668.htm > > > > -Dj > > > -- > > Dj Merrill - N1JOV > Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ > Grumman Yankee Driver N9870L - http://deej.net/yankee/ > > ________________________________________________________________________________
Date: Sep 30, 2009
bob noffs wrote: > didn't someone get an inspection camers from harbor frt.? how did it > work out? > bob noffs Yep, Bob...a whole bunch of us did. You must have missed my previous email today on this topic, as I mentioned a couple of uses I've put it to. In addition to those (including recording the inspections directly into my computer), I used it to repair a pocket door (like the doors on Star Trek...slide into the wall) at a friends house that had jumped the track INSIDE the pocket. I used the camera to look in along the top edge of the door from the end and see which side it jumped off on, and what was needed to get it back on the track...also used it to watch what I was doing as I maneuvered it back on track. Without a camera like that, she would have had to tear out the trim molding and then cut a hole in the wall behind it just to see what the problem was, and then probably cut another hole to adjust it. As far as my Long EZ, so far, I've checked the hell hole to find tools and small parts I've dropped in there...inspected the inside of the strakes, both from inside the fuselage, and through the holes in the strake used to tighten the wing mounting bolts, and just today found some washers I had dropped into the nose when installing the electric nose lift (the fuselage is currently upside down ...I used the magnet to pick up the washers once I saw them lying between the nose block and the forward edge of the back battery bulkhead ). When I get the holes cut for the fuel tank filler, I'll be using it to examine the inside of the tanks. It can also electrically flip and/or rotate the image on the screen. Don't know if the others do that. The HF camera has been worth every penny! You just have to remember that with the camera it comes with, if you want a sharp focus, then what you are viewing should be further away than 4 inches...that smaller 9mm camera is advertised to have a shorter focal range if you want to see something close, and pay the extra money for it. As I mentioned earlier, the best part is being able to remove the screen...then you don't have to twist around in weird positions to try to look at it as you move the camera handle. Harley ------------------------------------------------------------------------ ________________________________________________________________________________
Date: Sep 30, 2009
I got one. Works great! I like it. David M. bob noffs wrote: > didn't someone get an inspection camers from harbor frt.? how did it > work out? > bob noffs > > On Wed, Sep 30, 2009 at 1:20 PM, Dj Merrill > wrote: > > > > > On 09/30/2009 11:45 AM, Harley wrote: > > DJ (and others)... > > > > Be careful that you know what you order from the website you linked > > below. > > Cjeck out the next page: > > > www.reliablepaper.com/Ridgid_SeeSnake_micro_Inspection_Camera_s/6295.htm > <http://www.reliablepaper.com/Ridgid_SeeSnake_micro_Inspection_Camera_s/6295.htm> > > > > Thanks! I didn't catch that. > > Looks like the camera unit itself is $76 at: > <http://www.reliablepaper.com/SeeSnake_Micro_Inspection_Camera_p/632-26663.htm> > > plus the 9.5mm camera and cable for $107 at: > <http://www.reliablepaper.com/Imager_Head_and_Cable_p/632-30068.htm> > > so it would cost around $183 in total for the smaller camera. > > It is not clear whether you would also have to buy the accessory pack > (mirrors) separately for $17 at: > <http://www.reliablepaper.com/Hook_Magnet_and_Mirror_Attachment_Accessory_Pack_p/632-26668.htm> > > -Dj > > > -- > > Dj Merrill - N1JOV > Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ > Grumman Yankee Driver N9870L - http://deej.net/yankee/ > =========== > rch & Download, 7-Day Browse, Chat, FAQ, > ="http://www.matronics.com/Navigator?AeroElectric-List" > target="_blank"======== > http://forums.mle, List Admin. > ==== > > > > <http://forums.matronics.com/> > > > <http://forums.matronics.com/> > > * > > > * > > > ------------------------------------------------------------------------ > > > Checked by AVG - www.avg.com > ________________________________________________________________________________
Date: Sep 30, 2009
One of my best uses is looking inside the cylinders, via the spark plug openings. David M. Harley wrote: > bob noffs wrote: >> didn't someone get an inspection camers from harbor frt.? how did it >> work out? >> bob noffs > Yep, Bob...a whole bunch of us did. > > You must have missed my previous email today on this topic, as I > mentioned a couple of uses I've put it to. > > In addition to those (including recording the inspections directly into > my computer), I used it to repair a pocket door (like the doors on Star > Trek...slide into the wall) at a friends house that had jumped the track > INSIDE the pocket. I used the camera to look in along the top edge of > the door from the end and see which side it jumped off on, and what was > needed to get it back on the track...also used it to watch what I was > doing as I maneuvered it back on track. Without a camera like that, she > would have had to tear out the trim molding and then cut a hole in the > wall behind it just to see what the problem was, and then probably cut > another hole to adjust it. > > As far as my Long EZ, so far, I've checked the hell hole to find tools ><<>> ________________________________________________________________________________
From: "ROGER & JEAN CURTIS" <mrspudandcompany(at)verizon.net>
Subject: Inspection camera
Date: Sep 30, 2009
One of my best uses is looking inside the cylinders, via the spark plug openings. David M. Is it small enough to enter a spark plug hole? Roger ________________________________________________________________________________
Date: Sep 30, 2009
And with the HF model you can focus inside the cylinder okay with a 4" or so minimum focus distance? Can you look back at the valves? And what does it look like the wireless range might be? I think someone said it came with a cable to allow you to record the video on the computer. Have you tried this? Thanks, Allen Fulmer RV7 wiring -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of David M Sent: Wednesday, September 30, 2009 8:02 PM Subject: Re: AeroElectric-List: Inspection camera One of my best uses is looking inside the cylinders, via the spark plug openings. David M. ________________________________________________________________________________
Date: Sep 30, 2009
Subject: "Spiked" Radio
Greetings Bob et al., On another list someone posted that he "spiked" his radio when he inadvertently turned his master switch off and immediately turned it back on. He did not say what the engine rpm was at when this happened. He said the radio was protected only by a circuit breaker that did not open. The radio required service which included the replacement of a resistor. He also said he planned on adding a fuse to the radio circuit. I don't understand how the stated actions would result in the damage cited. Any insight would be appreciated. Regards, Frank ________________________________________________________________________________
Date: Sep 30, 2009
Subject: Work in process . . .
Like the 'Connection, the website is always "in process". I've been working on a new index for the posted articles and slowly coming out broken/missing links . . . time permitting. I've activated the new index at: http://aeroelectric.com/articles.html . . . a heads-up on any detected errors would be welcome. It's still got a way to go but I think the new organization will make it much easier to browse the work product for topics of interest. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Sep 30, 2009
Subject: Basic Electrical Architecture for review...
Greetings all, I've attached an electrical architecture (in Bob's drawing style) for your review. It's for the Longeze I'm restoring. I'm doing the restoration in multiple stages. Although it had ~1000 Hrs. on it when I obtained it, it's been grounded since I received it. The attached architecture is intended to be more robust and fault tolerant than what was there (which I'm sure it is...) and certainly not worse in that regard than a TC aircraft (though not as good as a design with an essential bus). Down the road a bit, I intend to replace the vacuum system and associated instruments with electric, plus a backup alternator and an architecture with an essential bus. I would appreciate comments on the architecture and, specifically, on any unmitigated faults (especially those that would not be acceptable in a TC aircraft). The aircraft is VFR only. Thanks in advance, Steve Stearns Boulder/Longmont, Colorado CSA,EAA,IAC,AOPA,PE,ARRL,BARC (but ignorant none-the-less) Restoring (since 1/07): N45FC O235 Longeze Cothern/Friling CF1 (~1000 Hrs) Flying (since 9/86): N43732 A65 Taylorcraft BC12D ________________________________________________________________________________
Date: Sep 30, 2009
THeoretically you could look at the valves with the mirror but I haven't done that. As to range, I've had it contact stuff and it was almost in focus. Range for the wireless part is a few feet inside the house if there's a wall between you and maybe 25 or 30 feet outside. So range varies. It does have a video out port so getting it into a computer is a snap. David M. Allen Fulmer wrote: > > And with the HF model you can focus inside the cylinder okay with a 4" or so > minimum focus distance? > > Can you look back at the valves? > > And what does it look like the wireless range might be? > > I think someone said it came with a cable to allow you to record the video > on the computer. Have you tried this? > > Thanks, > > Allen Fulmer > RV7 wiring > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of David M > Sent: Wednesday, September 30, 2009 8:02 PM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Inspection camera > > > One of my best uses is looking inside the cylinders, via the spark plug > openings. > > David M. > > > > > > > > > > ------------------------------------------------------------------------ > > > Checked by AVG - www.avg.com > ________________________________________________________________________________
From: Ben Cunningham <bencunninghamiii(at)gmail.com>
Subject: Wiring the LR3C-14 Warning light
Date: Oct 01, 2009
> I recently purchased the LR3C-14 for my RV7. > > My panel was constructed by Aerotronics and I have added a diagram > below of the schematic for my annunciator lights. > > I have done a sketch below of how I would like to wire the LR3, with > terminal 5 feeding the light through plug P-1-0, and terminal 3 > reading buss voltage downstream of the 2 amp breaker. Since the > light was wired through a test switch, I wanted to run this setup by > you to see if it looked OK to you. Thanks, Ben ________________________________________________________________________________
Subject: Visio?
Date: Oct 01, 2009
Nice and complete Andrew! -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Andrew Butler Sent: 30 September 2009 10:47 AM Subject: Re: AeroElectric-List: Visio? Hi Tim, Here's mine, all done in Visio......... I started off by importing Bob's CAD drawings and then converting them. I then went about "cleaning" up the less than perfect result and saving the individual components as "groups". After that, drag and drop and copy and paste works a charm in Visio. Would you like a copy of the source? Andrew. ----- Original Message ----- From: "Tim Andres" <tim2542(at)sbcglobal.net> Sent: Wednesday, 30 September, 2009 05:37:41 GMT +00:00 GMT Britain, Ireland, Portugal Subject: AeroElectric-List: Visio? Has anyone tried using Visio to draw their schematic? It looks like it will work but I'm not finding much in the way of automotive symbols i.e. solenoids relays etc. Can anyone recommend a free or cheap program for this? Thanks, Tim Andres ________________________________________________________________________________
Subject: Re: "Spiked" Radio
Date: Sep 30, 2009
Frank, You don't specify the type of aircraft and radio which can make a big difference. If the guy is considering adding a fuse then that suggests to me its a homebuilt aircraft, raising the question of just how much care has been taken to configure everything to best practice for the mission desired. Some radios designed for the Ultralight / LSA markets are not TSO'd and not necessarily able to withstand the conditions of electrical immunity spelled out in DOD-160 or better. In a proper installation with an adequate electrical system any TSO'd radio should be OK with the conditions described. I would not expect a properly sized CB to trip and definitely not hold my breath for a fuse do do anything. I have owned a 1961 Cessna or 12 years and my CH701 for the last five, these have been equipped with the same KY97a radio and I have never turned the radio off before starting the plane or any of that stuff that basically wears out the switches and volume controls. I can't think of a better way to test a radio than the O-200 with the pull starter! But I've seen a high proportion of the newer radios with warnings about requiring an avionics master switch, large capacitor ( a problem in itself because that will render the CB / fusing inadequate) and these are the radios that seem to scramble their insides on a regular basis. Not sure if that gives any insight into whats happened if it was my plane I'd be retaining the CBs not adding fuses - the fact you can attempt to replace them inflight is a danger in itself. Ralph -------- Ralph - CH701 / 2200a Read this topic online here: http://forums.matronics.com/viewtopic.php?p=265815#265815 ________________________________________________________________________________
Date: Oct 01, 2009
Allen Fulmer wrote: > And with the HF model you can focus inside the cylinder okay with a 4" or so > minimum focus distance? > > Can you look back at the valves? > > And what does it look like the wireless range might be? > > I think someone said it came with a cable to allow you to record the video > on the computer. Have you tried this? > > Thanks, > > Allen Fulmer > RV7 wiring > What is the actual Diameter of the camera.Can't seem to find this dimension anywhere on HF site or product info pdf.Will it fit in the 10mm spark plug hole like the Jabiru 3300 Cheers > -- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=265824#265824 ________________________________________________________________________________
Date: Oct 01, 2009
I'd like to add something to David's replies... The camera head as supplied is too big to fit into the spark plug hole...but just a touch too big. I didn't think of inserting the mirror into the spark plug hole with the camera still outside...a possibility. I just checked the mirror size, and it is only a very little bit smaller than the camera...not sure that it would fit either. The smaller, 9mm camera mentioned from another supplier may work, IF you want to spend the extra $100 AND IF it works with the HF camera...haven't heard from anyone on that yet, and haven't needed to try it myself. As far as the wireless range, the first day I had the HF camera (read that while the batteries were still fresh ), I detached the display from the camera head, connected the supplied video cable into my computer's converter's analog video input plug, and started recording the image using the Pinnacle Video capture program that came with the video/digital converter. I then walked the camera through the house, and outside to try to determine the range. The computer is located in the west end bedroom (now a "computer" room ) of my house, and I was able to go into the middle of the garage attached to the east end of my house (~40 feet away..through two rooms and down a 20 foot hall) before I lost the signal, and outside about halfway down the front yard (also about 40 feet). Just tried it again...same original batteries that I first installed in it. Interesting results. I put the camera on my desk here in the computer room and turned it on, then walked the display away until I lost the signal. The camera remained inside, here on my desk. I got as far as the garage door (about 35 feet away) inside the house...but when I took it outside, I was able to go across the street into the neighbor's yard before the display shut down (it goes black when it can't receive a signal)...about 90 feet...with the camera inside my house! I did have to rotate to get the best signal, a bit like locating a cell phone signal, but the image was still very readable when I locked it in while in Tom's front yard...and it's a dreary rainy day here. Except for the handle color, the hard case and a couple of the accessories, this unit is identical to the HF one: www.nteinc.com/wic There is a video describing it (actually, a narrated slide show). Looks to me like a lot of companies are seeing the advantage of this camera and putting their own brand on it. If you google "wireless inspection camera" you'll get dozens of different brand labels on the same unit. But so far, from my search, HF is the lowest cost...especially when it's on sale for $99 (it may be on sale at the store as it was here, even though it didn't show a sale online). And, I, for one, am pleased with it. Harley ------------------------------------------------------------------------ David M wrote: > > THeoretically you could look at the valves with the mirror but I > haven't done that. > As to range, I've had it contact stuff and it was almost in focus. > Range for the wireless part is a few feet inside the house if there's > a wall between you and maybe 25 or 30 feet outside. So range varies. > It does have a video out port so getting it into a computer is a snap. > > David M. > > > Allen Fulmer wrote: >> >> >> And with the HF model you can focus inside the cylinder okay with a >> 4" or so >> minimum focus distance? >> >> Can you look back at the valves? >> >> And what does it look like the wireless range might be? >> >> I think someone said it came with a cable to allow you to record the >> video >> on the computer. Have you tried this? >> >> Thanks, >> >> Allen Fulmer >> RV7 wiring >> >> >> One of my best uses is looking inside the cylinders, via the spark >> plug openings. >> >> David M. >> ------------------------------------------------------------------------ > ________________________________________________________________________________
Date: Oct 01, 2009
Subject: inspection camera
harley, thanks for the info on your camera, bob noffs ________________________________________________________________________________
Subject: Re: Basic Electrical Architecture for review...
Date: Oct 01, 2009
Steve, Yes, the 20 amp fuse should be replaced. A 22awg fuselink will work. Since your plane does not have a starter, you could use a relay instead of a contactor, perhaps one like this: http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=255-1830-ND A relay weighs less and will not use as much power. You could buy two relays, one to replace the battery contactor and one to remotely control power to the essential bus, thus having the ability to isolate all electrical power on the engine side of the firewall. Depending on how your main power bus is constructed, you might be able to cut it in half and then connect the two halves with a diode, thus making an essential bus. It would be relatively easy to add a switch and wire to complete the essential bus circuit. Dual alternators are not necessary for a VFR plane unless the engine is electrically dependent and you fly long distances over hostile terrain. Putting a diode between the load side of the battery contactor and main power bus along with a circuit breaker from the battery to the bus defeats the purpose of having a contactor, which is the ability to shut off electrical power at the battery without bringing a large always-hot wire into the cockpit. Yes, the ANL fuse protects the battery and wire against alternator short circuits. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=265890#265890 ________________________________________________________________________________
Subject: Visio?
Date: Oct 01, 2009
Bill, To make Visio drawings viewable by everyone save them as .jpg files (Save as, and then scroll nearly to the bottom of the menu). Peter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bill Mauledriver Watson Sent: 30 September 2009 13:55 Subject: Re: AeroElectric-List: Visio? I'm using that product too and like it a lot. A belated Thanks Vern! If anyone installs it and wants a sample, I'd be glad to share my schematics. (but you have to have the SCH tool installed to view it) Bill Vern Little wrote: > > > Hi Tim. > Go here: www.vx-aviation.com and follow the link near the top of the > page for the free schematic software, library and design example from > my RV-9A. Doesn't have everything but it's very easy to create symbols > on the fly. > > Thanks, > Vern Little > > -------------------------------------------------- > From: "Tim Andres" <tim2542(at)sbcglobal.net> > Sent: Tuesday, September 29, 2009 9:37 PM > To: > Subject: AeroElectric-List: Visio? > >> >> >> >> Has anyone tried using Visio to draw their schematic? It looks like >> it will >> work but I'm not finding much in the way of automotive symbols i.e. >> solenoids relays etc. >> Can anyone recommend a free or cheap program for this? >> Thanks, Tim Andres >> >> >> >> >> > > ________________________________________________________________________________
Subject: Re: Mason City, Iowa Aero-Electric seminar
Date: Oct 01, 2009
Is this still on...? Just wanted to make sure before I make travel/hotel plans. Thanks, Patrick -------- Patrick XL/650/Corvair N63PZ (reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=265899#265899 ________________________________________________________________________________
From: "Kesley Electric" <kesleyelectric(at)iowatelecom.net>
Date: Oct 01, 2009
Hi Patrick, I spoke with Bob Nuckolls this morning. Unfortunately, there were not enough people registered to meet the minimum. Bob will be e-mailing those who registered with the announcement sometime today. I'm really disappointed that the response was not enough to meet the minimum class size, as I was really looking forward to the class and the interaction with other builders. No reschedule date has been set at this time. Regards, Tom Barter kesleyelectric(at)iowatelecom.net -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of PatrickW Sent: Thursday, October 01, 2009 2:27 PM Subject: AeroElectric-List: Re: Mason City, Iowa Aero-Electric seminar Is this still on...? Just wanted to make sure before I make travel/hotel plans. Thanks, Patrick -------- Patrick XL/650/Corvair N63PZ (reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=265899#265899 Checked by AVG - www.avg.com 06:34:00 ________________________________________________________________________________
Date: Oct 01, 2009
At 12:16 AM 10/1/2009, you wrote: > >Frank, > You don't specify the type of aircraft and radio which can > make a big difference. If the guy is considering adding a fuse then > that suggests to me its a homebuilt aircraft, raising the question > of just how much care has been taken to configure everything to > best practice for the mission desired. > > >Not sure if that gives any insight into whats happened if it was my >plane I'd be retaining the CBs not adding fuses - the fact you can >attempt to replace them inflight is a danger in itself. Good answer sir. Couldn't have said it better myself . . . Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Subject: Odyssey PC310 battery pairings
Date: Oct 01, 2009
I am planning to use a small PC310 as a primary battery in a system designed for 1 battery in a VFR only Rotax powered aircraft. Is it possible to parallel a larger PC680 for occasions when I would want to extend my reserve capacity time? Or should I plan to only use a second PC310 for such an application? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=265999#265999 ________________________________________________________________________________
Date: Oct 02, 2009
Subject: Re: Odyssey PC310 battery pairings
At 12:44 AM 10/2/2009, you wrote: > >I am planning to use a small PC310 as a primary battery in a system >designed for 1 battery in a VFR only Rotax powered aircraft. Is it >possible to parallel a larger PC680 for occasions when I would want >to extend my >reserve capacity time? Or should I plan to only use a second PC310 >for such an application? See: http://www.aeroelectric.com/articles/Batteries/Multiple_Battery_Myths_A.pdf It's okay to parallel batteries of two different sizes and/or station in their service life. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Oct 02, 2009
Subject: The HF Inspection camera again
Once more, that little HF inspection camera has proved it's worth... When I tried to turn the heat on in my car a few days ago, the heater temperature couldn't be controlled. In fact, all I got was cold outside air. Googling online I found a couple of checks to determine the reason...turns out it was a loose soldered connection on the temperature control card...found it by using a programmed troubleshooting check I found the instructions for online. Not mentioned in any Mazda literature...including the shop manual! Hold in the radio "On" button, and push the radio "Scan Up" button at the same time! It then displays the temperature control setting in the radio display! Rotating the control showed no change from 0. But I digress... Had to remove the radio to get to that card, and in the process, lost the radio's side mounting bolt down behind the dashboard, and behind the center console and inside the edge of it's carpet. Where I could not get my head to see it, let alone my hand to retrieve it... After this weeks discussion, I immediately thought of the HF inspection camera. It located the bolt within seconds, and then mounting the magnet probe on the camera retrieved it as well! Re-soldered the loose connections on the card (all three of them on the temperature control potentiometer) and now the RX8 is toasty warm again! Oh, and the programmed check displays 0 to 16 as I rotate the control! Harley ________________________________________________________________________________
Date: Oct 02, 2009
>The camera head as supplied is too big to fit into the spark plug >hole...but just a touch too big. On my unit, I found the body of the camera to just match the plug hole dia. However, there was a raised arrow cast on the side of the side of the body that caused interference. After a little judicial use of a single edged razor the arrow is now flush, yet discernable, and the camera now fits into the hole. glen matejcek aerobubba(at)earthlink.ne ________________________________________________________________________________
Date: Oct 02, 2009
When I checked it on my Lycoming O235, the camera did fit inside the beginning of the spark plug hole, but the threads in the hole got in the way from there on in...removing that little bit of plastic may have helped, but I didn't do it figuring that I wouldn't be able to see anything anyway since the camera would be pointing toward the crankcase and not the valves and I wouldn't be able to bend the camera in the short radius needed to look at the valves if it did get inside. Maybe the smaller 9mm camera may be able to do that... Harley ------------------------------------------------------------------------ glen matejcek wrote: > > > >> The camera head as supplied is too big to fit into the spark plug >> hole...but just a touch too big. >> > > On my unit, I found the body of the camera to just match the plug hole dia. > However, there was a raised arrow cast on the side of the side of the body > that caused interference. After a little judicial use of a single edged > razor the arrow is now flush, yet discernable, and the camera now fits into > the hole. > > glen matejcek > aerobubba(at)earthlink.ne > > > ________________________________________________________________________________
Date: Oct 02, 2009
At 09:57 PM 9/30/2009, you wrote: >Greetings all, > >I've attached an electrical architecture (in Bob's drawing style) >for your review. It's for the Longeze I'm restoring. I'm doing the >restoration in multiple stages. Although it had ~1000 Hrs. on it >when I obtained it, it's been grounded since I received it. The >attached architecture is intended to be more robust and fault >tolerant than what was there (which I'm sure it is...) and certainly >not worse in that regard than a TC aircraft (though not as good as a >design with an essential bus). > >Down the road a bit, I intend to replace the vacuum system and >associated instruments with electric, plus a backup alternator and >an architecture with an essential bus. > >I would appreciate comments on the architecture and, specifically, >on any unmitigated faults (especially those that would not be >acceptable in a TC aircraft). > >The aircraft is VFR only. > >Thanks in advance, You appear to have a generic distribution system and questions that go to departures from recommendations offered in the Z-figures. What was it about Z-11 as depicted at: http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z11M.pdf or features depicted in other z-figures that prompted the changes in direction? Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Oct 02, 2009
From: Marvin Haught <handainc(at)madisoncounty.net>
Bob - I'm a lurker on this site, but am in progress on a Pa22-20 project (certified). How difficult would it be to use Z-11 in a certified aircraft and get a 337 for that purpose? Has anyone done that recently? Looks perfect for the project. M. Haught Robert L. Nuckolls, III wrote: > > > At 09:57 PM 9/30/2009, you wrote: >> Greetings all, >> >> I've attached an electrical architecture (in Bob's drawing style) for >> your review. It's for the Longeze I'm restoring. I'm doing the >> restoration in multiple stages. Although it had ~1000 Hrs. on it >> when I obtained it, it's been grounded since I received it. The >> attached architecture is intended to be more robust and fault >> tolerant than what was there (which I'm sure it is...) and certainly >> not worse in that regard than a TC aircraft (though not as good as a >> design with an essential bus). >> >> Down the road a bit, I intend to replace the vacuum system and >> associated instruments with electric, plus a backup alternator and an >> architecture with an essential bus. >> >> I would appreciate comments on the architecture and, specifically, on >> any unmitigated faults (especially those that would not be acceptable >> in a TC aircraft). >> >> The aircraft is VFR only. >> >> Thanks in advance, > > You appear to have a generic distribution system > and questions that go to departures from recommendations > offered in the Z-figures. > > What was it about Z-11 as depicted at: > > http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z11M.pdf > > or features depicted in other z-figures that > prompted the changes in direction? > > > Bob . . . > > --------------------------------------- > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > --------------------------------------- > > ________________________________________________________________________________
Date: Oct 02, 2009
Subject: Re: Watons's RV-10 power distribution
At 03:00 PM 10/1/2009, you wrote: >Some confusion here perhaps. I'm not using Visio - rather I'm using >the ExpressSCH product that Vern has linked to at his site. It does >have a bitmap export function which I just tried and attached the results. >Looks like that works ok. You need fusible links upstream of your ov crowbar breakers, NOT pluggable fuses in the fuse blocks. You're missing a diode at the cross-feed contactor. Where are your batteries mounted? 2AWG is too big for forward mounted batteries. Suggest 4AWG. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Subject: Z-16 Alternator disconnect
Date: Oct 02, 2009
I'm working off Z-16. Rev M. I have the Cessna type split master. For the sake of argument, if I were to eliminate the Alternator OV disconnect relay, then would I simply interrupt one of the yellow alt wires with my master in order to take the Alternator off-line? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=266085#266085 ________________________________________________________________________________
Subject: What is the type of this pin?
Date: Oct 02, 2009
Hi All, who will be able to tell me what is the type of this connector? I found it in a switch coming from a military aircraft. In order to give a new life to the switch, I need to buy some pins....but I know nothing about it. Thank you for your help Overtorque. PS: On the first pic, it is millimeter.... (http://img42.imageshack.us/i/dsc00979fq.jpg/) (http://g.imageshack.us/img42/dsc00979fq.jpg/1/) (http://img245.imageshack.us/i/p1010327g.jpg/) (http://g.imageshack.us/img245/p1010327g.jpg/1/) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=266089#266089 ________________________________________________________________________________
Date: Oct 02, 2009
Subject: Re: What is the type of this pin?
Wasn't able to get any of the images to load to see what you are referring to. Tried going directly to the site too with no joy. If it came from a military aircraft, there's a milspec for it and you should be able to get replacements using the milspec number.....the trick then is determining what the milspec is..... -----Original Message----- >From: Overtorque <lezbnd(at)gmail.com> >Sent: Oct 2, 2009 1:42 PM >To: aeroelectric-list(at)matronics.com >Subject: AeroElectric-List: What is the type of this pin? > > >Hi All, > >who will be able to tell me what is the type of this connector? I found it in a switch coming from a military aircraft. In order to give a new life to the switch, I need to buy some pins....but I know nothing about it. > >Thank you for your help > >Overtorque. > >PS: On the first pic, it is millimeter.... > > (http://img42.imageshack.us/i/dsc00979fq.jpg/) (http://g.imageshack.us/img42/dsc00979fq.jpg/1/) > > (http://img245.imageshack.us/i/p1010327g.jpg/) (http://g.imageshack.us/img245/p1010327g.jpg/1/) > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=266089#266089 > > ________________________________________________________________________________
Date: Oct 02, 2009
Bob, thanks for giving this a review. I've responded below: Robert L. Nuckolls, III wrote: > > > You need fusible links upstream of your ov crowbar > breakers, NOT pluggable fuses in the fuse blocks. My thinking was the fuse is just protecting the wire to the pullable breaker. The wire is 16AWG and the fuse a 15amp. Then the breaker is a 5amp. But I think what you are telling me is that the fuse could defeat the whole purpose of having the pullable breaker. And that either a fusible link is needed to protect the wire or a direct connection to the buss. Is that correct? > > You're missing a diode at the cross-feed contactor. Yes, drawing fixed. > > Where are your batteries mounted? 2AWG is too big > for forward mounted batteries. Suggest 4AWG. It's an RV10 with both batteries in the rear. So I used 2AWG for the run to the starter and for the interbattery connections. The other battery has a (previously unmarked) 8AWG wire for the other run to the front. My analysis suggested that the 8AWG is enough for the 20amp Alt side of the circuit even in a crossfeed situation. Thanks again Bill "finishing up the panel wiring" Watson ________________________________________________________________________________
Date: Oct 02, 2009
Good Afternoon Overtorque, I thought I would have an answer for you. It looks very much like the pins used by Beechcraft to feed the ground and power to their wedge type internal instrument lights. They are on the ends which plug into group receptacles on the back of the panel. I have some somewhere, but can't find them or the Beech part number. Been trying for the last hour or so. The bad thing is that they cost about ten bucks apiece when purchased from Beechcraft. If I find the ones I have or can locate the Beech Part Number, I will post it here. Meanwhile, maybe this will jog someone else's memory. 'Lectric Bob, do you remember them during your time at Beech? Happy Skies, Old Bob In a message dated 10/2/2009 12:45:18 P.M. Central Daylight Time, lezbnd(at)gmail.com writes: http://img42.imageshack.us/i/dsc00979fq.jpg/) (http://g.imageshack.us/img42/dsc00979fq.jpg/1/) ________________________________________________________________________________
Date: Oct 02, 2009
At 10:17 AM 10/2/2009, you wrote: > > >Bob - > >I'm a lurker on this site, but am in progress on a Pa22-20 project >(certified). How difficult would it be to use Z-11 in a certified >aircraft and get a 337 for that purpose? Has anyone done that >recently? Looks perfect for the project. >M. Haught I have often fantasized about taking a nice ol' rag-wing piper and updating the electrical system with something like Z-13/8, all new lightweight hardware and an RG battery. I'm aware of no projects flying where one has successfully run the gauntlet for permission to do a good thing to an ageing aircraft. Several folks have proposed such upgrades and have received tentative blessings on things like the forest of tabs ground bus and fuse blocks. But those systems have yet to be completed and signed off for flight. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Oct 02, 2009
At 12:42 PM 10/2/2009, you wrote: > >Hi All, > >who will be able to tell me what is the type of this connector? I >found it in a switch coming from a military aircraft. In order to >give a new life to the switch, I need to buy some pins....but I know >nothing about it. > >Thank you for your help A number of high-end manufacturers of switches (and relays, etc) are offering very robust, environmentally sealed devices that are electrically terminated IWTS (integrated wire termination system) by means of built-in sockets having female pins. The idea is not new. Patent 3717838 was issued in 1973 on this topic. There are no doubt earlier documents. An exemplar product line is illustrated starting on page A27 of http://tinyurl.com/ya22ub8 I did a search of IWTS in this pdf file and found a couple of switch lines offering that feature. I believe there are probably few sizes and styles of pins used across these product lines . . . but pins, extraction tools and installation tools are unique to the pins. I've not personally put my hands on any of these but we used a goodly number at Hawker-Beech. I didn't see any references to mating pin numbers in the EATON catalog. I did see a reference to M39029/1-101 pins for 20AWG wire for THAT particular part. You'll need to check your existing pins against the dimensions of similar pins (OR) get the part number of your switch and see what its catalog listing calls out for the mating pin. These wont be easy to find in small quantities but if you identify a part number, you can try Aircraft and Commercial Enterprises in Derby KS. They might have and be willing to supply you a small quantity of pins. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Oct 03, 2009
>My thinking was the fuse is just protecting the wire to the pullable >breaker. The wire is 16AWG and the fuse a 15amp. Then the breaker >is a 5amp. But I think what you are telling me is that the fuse >could defeat the whole purpose of having the pullable breaker. And >that either a fusible link is needed to protect the wire or a direct >connection to the buss. Is that correct? Fuses are so much faster than breakers that you may pop a 15A fuse trying to open a 5A breaker. There's a reason for the fusible link depicted in the Z-figures. >It's an RV10 with both batteries in the rear. So I used 2AWG for >the run to the starter and for the interbattery connections. The >other battery has a (previously unmarked) 8AWG wire for the other >run to the front. >My analysis suggested that the 8AWG is enough for the 20amp Alt side >of the circuit even in a crossfeed situation. Do you intend to load the aux battery for cranking? If batteries are in the rear, then contactors are in the rear and crossfeed contactor is on firewall to give you a fat-terminal, power distribution point at the cross-feed contactor. Use 4AWG welding cable off each battery terminal to contactors and ground. 2AWG for run forward to the starter contactor. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Oct 02, 2009
Hi all, Thank you very much for these input.... I made myself the extraction tool. I have to leave for the WE. Monday, I will take accurate size of the connector and the brand (if I can find it) of the switch. I wish a nice nice WE to all Overtorque Read this topic online here: http://forums.matronics.com/viewtopic.php?p=266215#266215 ________________________________________________________________________________
Subject: Z-14 alternator wire guage??
Date: Oct 03, 2009
I have the latest revision of Z14 (REV N 7/14/09) which shows that the Main Alternator (40 amp) has a 4 AWG B-lead. BUT the Aux Alternator (also 40 am p) has a 10 AWG B-lead. Is there any possible logic in this discrepancy. My calculations indicate that for a standard Lycoming set-up with main alte rnator at the front of the engine and the aux alternator on the rear of the engine 10 AWG should be more than enough for the B-leads for both=2C provi ding the battery is FWF. Am I missing something here. =0A _________________________________________________________________=0A Use Messenger in your Hotmail inbox Find out how here=0A http://windowslive.ninemsn.com.au/article.aspx?id=823454 ________________________________________________________________________________
Date: Oct 03, 2009
Subject: Re: Z-16 Alternator disconnect
At 12:21 PM 10/2/2009, you wrote: > >I'm working off Z-16. Rev M. I have the Cessna type split master. >For the sake of argument, if I were to eliminate the Alternator OV >disconnect relay, then would I simply interrupt one of the yellow >alt wires with my master in order to take the Alternator off-line? Yes, if you wanted to load the switch that heavily. You wouldn't have OV protection either. Recommend you keep the relay. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Oct 03, 2009
Subject: Re: Z-14 alternator wire guage??
At 12:50 AM 10/3/2009, you wrote: >I have the latest revision of Z14 (REV N 7/14/09) which shows that >the Main Alternator (40 amp) has a 4 AWG B-lead. BUT the Aux >Alternator (also 40 amp) has a 10 AWG B-lead. > >Is there any possible logic in this discrepancy. No, there were some artifacts of cut-n-paste that didn't get combed out before the drawing was last published. They've been corrected. The latest drawing can be downloaded from the website. > >My calculations indicate that for a standard Lycoming set-up with >main alternator at the front of the engine and the aux alternator on >the rear of the engine 10 AWG should be more than enough for the >B-leads for both, providing the battery is FWF. > >Am I missing something here. I recommend 4AWG for all fat wires just because you need to buy enough of it to take care of battery/ starter wiring. It's just handy to use the same gage for all fat wires. I'd leave the Main alternator at 4AWG and wire the Aux alternator for 20A as shown on the corrected drawing. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Subject: Pitot Wiring Connectors
Date: Oct 03, 2009
Curious if anyone had a solution for a connector problem. I sent off my Velocity's sharkfin pitot for plating and when it came back, the two wires to the heating elements were missing. The two wires had female pin connectors which mate to the two male pins of the heating elements. The female connector slides right over the male pins. By memory, the pins are approx. 2-3/32nd inch in diameter and approximately 1/2" long. I've seen similar pins on some other pitots, but have not been able to find the connectors that I can attach termials ends to to hook up to the plane wiring. Anybody know of a source for female pin connectors that might work? Chuck Jensen ________________________________________________________________________________
Date: Oct 03, 2009
Subject: Appendix Z
Change 4 to Appendix Z has been published to correct some errors. Figure Z-9 for Corvair Engines was developed in cooperation with William Wynne and several of his customers. That figure has been added to the suite of architecture drawings. http://aeroelectric.com/R12A/AppZ_12A4.pdf Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Oct 03, 2009
Subject: Re: Pitot Wiring Connectors
At 11:16 AM 10/3/2009, you wrote: >Curious if anyone had a solution for a connector problem. I sent >off my Velocity's sharkfin pitot for plating and when it came back, >the two wires to the heating elements were missing. The two wires >had female pin connectors which mate to the two male pins of the >heating elements. The female connector slides right over the male >pins. By memory, the pins are approx. 2-3/32nd inch in diameter and >approximately 1/2" long. I've seen similar pins on some other >pitots, but have not been able to find the connectors that I can >attach termials ends to to hook up to the plane wiring. > >Anybody know of a source for female pin connectors that might work? I've never seen a heated pitot tube that did not mate the AN3113-1 connector. That doesn't mean that yours is the same format . . . but I suspect it is. The AN3115-1 is a pricey dude. ACS get about $60 for it . . . http://www.aircraftspruce.com/catalog/inpages/heatedptubes2.php . . . and offer it under their own part number. Others on the 'net get as much as $100 for it. I've contemplated building these and even have a set of drawings and a slitting saw to do the cross-cuts in the receptacles. See . . . http://www.aeroelectric.com/Pictures/Connectors/AN3115_Pitot_Tube_Heater/ I built one set of pins way back when and they would probably have worked well. After looking at the hassles of tooling up a housing and considering just how many connectors I might sell . . . well, let's just say the blush was off the rose. If it were my airplane, I would solder pigtails onto the extended pins and install my own connectors on the ends of the pigtails. Say "power pole" style connector like those used on B&C PM alternators? Bob . . . ________________________________________________________________________________
Date: Oct 03, 2009
Say "power pole" style connector like those used on B&C PM alternators? Bob, I've done a quick search for "power pole". Can you supply a link to a supplier? Bevan RV7A wiring ________________________________________________________________________________
Date: Oct 03, 2009
Bob, Thanks for the link. Yes, it looks like that connector would fit, though it is different than what was on the pitot initiatlly, which worked fine, but was apparently 'home made'. The photos show the original connectors on the old pitot in which the element had gone bad. The connectors just 'pop off'. The old pitot wassilver-soldered and servicing was 'not possible', but I had the good fortune to find a like Kolhsman pitot on ebay for $15; find of the decade, which I sent off to have plated, but then the connecting wires became lost. If I'm unable to find the bare connectors, perhaps I'll have to dig down into the green moldy stuff and cough up for the one shown in your link. Chuck Jensen -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Robert L. Nuckolls, III Sent: Saturday, October 03, 2009 1:44 PM Subject: Re: AeroElectric-List: Pitot Wiring Connectors At 11:16 AM 10/3/2009, you wrote: >Curious if anyone had a solution for a connector problem. I sent >off my Velocity's sharkfin pitot for plating and when it came back, >the two wires to the heating elements were missing. The two wires >had female pin connectors which mate to the two male pins of the >heating elements. The female connector slides right over the male >pins. By memory, the pins are approx. 2-3/32nd inch in diameter and >approximately 1/2" long. I've seen similar pins on some other >pitots, but have not been able to find the connectors that I can >attach termials ends to to hook up to the plane wiring. > >Anybody know of a source for female pin connectors that might work? I've never seen a heated pitot tube that did not mate the AN3113-1 connector. That doesn't mean that yours is the same format . . . but I suspect it is. The AN3115-1 is a pricey dude. ACS get about $60 for it . . . http://www.aircraftspruce.com/catalog/inpages/heatedptubes2.php . . . and offer it under their own part number. Others on the 'net get as much as $100 for it. I've contemplated building these and even have a set of drawings and a slitting saw to do the cross-cuts in the receptacles. See . . . http://www.aeroelectric.com/Pictures/Connectors/AN3115_Pitot_Tube_Heater/ I built one set of pins way back when and they would probably have worked well. After looking at the hassles of tooling up a housing and considering just how many connectors I might sell . . . well, let's just say the blush was off the rose. If it were my airplane, I would solder pigtails onto the extended pins and install my own connectors on the ends of the pigtails. Say "power pole" style connector like those used on B&C PM alternators? Bob . . . ________________________________________________________________________________
Date: Oct 03, 2009
> I recently purchased the LR3C-14 voltage Reg. for my RV7. > > My panel was constructed by Aerotronics and I have added a diagram > below of their schematic for my annunciator light circuit. > > I have added a sketch below of how I would like to wire the LR3, > with terminal 5 feeding the low voltage light through plug P-1-0/6, > and terminal 3 reading buss voltage downstream of the 2 amp breaker. > Since the light would be wired through a test switch, I wanted to > run this setup by everyone to see if it looked OK. Thanks, Ben ________________________________________________________________________________
Date: Oct 03, 2009
Bevan - Follow this link and find a table of Anderson PowerPole connectors at the bottom right of page 79... http://www.hamradio.com/web/newcat/hrocat5.pdf neal -----Original Message----- Say "power pole" style connector like those used on B&C PM alternators? Bob, I've done a quick search for "power pole". Can you supply a link to a supplier? Bevan RV7A wiring ________________________________________________________________________________
Date: Oct 03, 2009
Hi Chuck, I may have a pitot connector that I don't need any longer. It will be Monday before I can check to see what condition it's in. If it's OK and will work for you, you are welcome to it. Bob W. "Chuck Jensen" wrote: > Bob, > > Thanks for the link. Yes, it looks like that connector would fit, though it is different than what was on the pitot initiatlly, which worked fine, but was apparently 'home made'. The photos show the original connectors on the old pitot in which the element had gone bad. The connectors just 'pop off'. > > The old pitot wassilver-soldered and servicing was 'not possible', but I had the good fortune to find a like Kolhsman pitot on ebay for $15; find of the decade, which I sent off to have plated, but then the connecting wires became lost. > > If I'm unable to find the bare connectors, perhaps I'll have to dig down into the green moldy stuff and cough up for the one shown in your link. > > Chuck Jensen > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Robert > L. Nuckolls, III > Sent: Saturday, October 03, 2009 1:44 PM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Pitot Wiring Connectors > > > > At 11:16 AM 10/3/2009, you wrote: > >Curious if anyone had a solution for a connector problem. I sent > >off my Velocity's sharkfin pitot for plating and when it came back, > >the two wires to the heating elements were missing. The two wires > >had female pin connectors which mate to the two male pins of the > >heating elements. The female connector slides right over the male > >pins. By memory, the pins are approx. 2-3/32nd inch in diameter and > >approximately 1/2" long. I've seen similar pins on some other > >pitots, but have not been able to find the connectors that I can > >attach termials ends to to hook up to the plane wiring. > > > >Anybody know of a source for female pin connectors that might work? > > I've never seen a heated pitot tube that did not mate > the AN3113-1 connector. That doesn't mean that yours is > the same format . . . but I suspect it is. > > The AN3115-1 is a pricey dude. ACS get about $60 for > it . . . > > http://www.aircraftspruce.com/catalog/inpages/heatedptubes2.php > > . . . and offer it under their own part number. > > Others on the 'net get as much as $100 for it. I've > contemplated building these and even have a set of > drawings and a slitting saw to do the cross-cuts in > the receptacles. See . . . > > http://www.aeroelectric.com/Pictures/Connectors/AN3115_Pitot_Tube_Heater/ > > > I built one set of pins way back when and they > would probably have worked well. After looking > at the hassles of tooling up a housing and considering > just how many connectors I might sell . . . well, let's > just say the blush was off the rose. > > If it were my airplane, I would solder pigtails onto > the extended pins and install my own connectors on the > ends of the pigtails. Say "power pole" style connector > like those used on B&C PM alternators? > > Bob . . . > > > > > > -- N93BD - Rotary Powered BD-4 - http://www.bob-white.com 3.8 Hours Total Time and holding Cables for your rotary installation - http://roblinstores.com/ ________________________________________________________________________________
Date: Oct 03, 2009
Bob - Sent this earlier but did not get a reply. Thought I would send it again. M. Haught Bob - I'm a lurker on this site, but am in progress on a Pa22-20 project (certified). How difficult would it be to use Z-11 in a certified aircraft and get a 337 for that purpose? Has anyone done that recently? Looks perfect for the project. M. Haught Robert L. Nuckolls, III wrote: > > > At 09:57 PM 9/30/2009, you wrote: >> Greetings all, >> >> I've attached an electrical architecture (in Bob's drawing style) for >> your review. It's for the Longeze I'm restoring. I'm doing the >> restoration in multiple stages. Although it had ~1000 Hrs. on it >> when I obtained it, it's been grounded since I received it. The >> attached architecture is intended to be more robust and fault >> tolerant than what was there (which I'm sure it is...) and certainly >> not worse in that regard than a TC aircraft (though not as good as a >> design with an essential bus). >> >> Down the road a bit, I intend to replace the vacuum system and >> associated instruments with electric, plus a backup alternator and an >> architecture with an essential bus. >> >> I would appreciate comments on the architecture and, specifically, on >> any unmitigated faults (especially those that would not be acceptable >> in a TC aircraft). >> >> The aircraft is VFR only. >> >> Thanks in advance, > > You appear to have a generic distribution system > and questions that go to departures from recommendations > offered in the Z-figures. > > What was it about Z-11 as depicted at: > > http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z11M.pdf > > or features depicted in other z-figures that > prompted the changes in direction? > > > Bob . . . > > --------------------------------------- > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > --------------------------------------- > > ________________________________________________________________________________
Date: Oct 03, 2009
Hi, bob, See what you have. I checked Neals suggestion and had seen if in a couple other searches. It appears to be a tension loaded flat blade that is designed to mate up with another flat blade. With both blades tensioned, the pressure is enough to form a good connection between them. A blade to pin connection might work, but that's certainly not the way it was intended. Let me know and if works, we enter some high level negotiations for it. lol Chuck Jensen Diversified Technologies 2680 Westcott Blvd Knoxville, TN 37931 Phn: 865-539-9000 x100 Cell: 865-406-9001 Fax: 865-539-9001 cjensen(at)dts9000.com -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Bob White Sent: Saturday, October 03, 2009 5:34 PM Subject: Re: AeroElectric-List: Pitot Wiring Connectors Hi Chuck, I may have a pitot connector that I don't need any longer. It will be Monday before I can check to see what condition it's in. If it's OK and will work for you, you are welcome to it. Bob W. "Chuck Jensen" wrote: > Bob, > > Thanks for the link. Yes, it looks like that connector would fit, though it is different than what was on the pitot initiatlly, which worked fine, but was apparently 'home made'. The photos show the original connectors on the old pitot in which the element had gone bad. The connectors just 'pop off'. > > The old pitot wassilver-soldered and servicing was 'not possible', but I had the good fortune to find a like Kolhsman pitot on ebay for $15; find of the decade, which I sent off to have plated, but then the connecting wires became lost. > > If I'm unable to find the bare connectors, perhaps I'll have to dig down into the green moldy stuff and cough up for the one shown in your link. > > Chuck Jensen > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Robert > L. Nuckolls, III > Sent: Saturday, October 03, 2009 1:44 PM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Pitot Wiring Connectors > > > > At 11:16 AM 10/3/2009, you wrote: > >Curious if anyone had a solution for a connector problem. I sent > >off my Velocity's sharkfin pitot for plating and when it came back, > >the two wires to the heating elements were missing. The two wires > >had female pin connectors which mate to the two male pins of the > >heating elements. The female connector slides right over the male > >pins. By memory, the pins are approx. 2-3/32nd inch in diameter and > >approximately 1/2" long. I've seen similar pins on some other > >pitots, but have not been able to find the connectors that I can > >attach termials ends to to hook up to the plane wiring. > > > >Anybody know of a source for female pin connectors that might work? > > I've never seen a heated pitot tube that did not mate > the AN3113-1 connector. That doesn't mean that yours is > the same format . . . but I suspect it is. > > The AN3115-1 is a pricey dude. ACS get about $60 for > it . . . > > http://www.aircraftspruce.com/catalog/inpages/heatedptubes2.php > > . . . and offer it under their own part number. > > Others on the 'net get as much as $100 for it. I've > contemplated building these and even have a set of > drawings and a slitting saw to do the cross-cuts in > the receptacles. See . . . > > http://www.aeroelectric.com/Pictures/Connectors/AN3115_Pitot_Tube_Heater/ > > > I built one set of pins way back when and they > would probably have worked well. After looking > at the hassles of tooling up a housing and considering > just how many connectors I might sell . . . well, let's > just say the blush was off the rose. > > If it were my airplane, I would solder pigtails onto > the extended pins and install my own connectors on the > ends of the pigtails. Say "power pole" style connector > like those used on B&C PM alternators? > > Bob . . . > > > > > > -- N93BD - Rotary Powered BD-4 - http://www.bob-white.com 3.8 Hours Total Time and holding Cables for your rotary installation - http://roblinstores.com/ ________________________________________________________________________________
Date: Oct 03, 2009
Subject: 24V Heated Pitot
I have a chromed AN 5812-1 14V heated pitot tube from Aero Instrument Co. and need the exact equivalent in a 12V model. Anyone care to trade? Anticipating some responses that lead to thread drift: I don't want to change the heating element. And yes, it gets hot on 12V but not hot enough to suit me. I rather just swap with someone who has a 12V model and a 24V airplane. Thanks, Joe Independence, OR http://www.mail2600.com/position ________________________________________________________________________________
Date: Oct 04, 2009
Hi Bob, Thanks for taking a look at my architecture drawing. As to why it differs from the recommendations in the Z-figures. Good question. I hope my answers are as good (I have no inherent desire to be "different"). The project at hand is the "repair" of a LongEZ that already has 1000 hrs on it by the previous owners (mostly by the original builder). My objective is to return the aircraft to what I consider flight-worthy shape. "Return" might not be the right word here as there were many details (electrical and otherwise) on the aircraft that have never been in what I would consider (by my standards today) flight worthy, though they may have been by some standards 30 years ago... And then put a year or two of flying on it (day VFR) while I become opinionated about what I want in it and what I don't. Then, the next project will be to add the enhancements I think are appropriate. I'm expecting the desired enhancements to include night & IFR support, eliminate the vacuum system etc. This project description flows down to the electrical subsystem as the constraint to keep it as simple as possible to meet the objective (and, specifically, avoid the temptation to grow the scope of the project). One other bit of background that may be relevant to my particular choices: Almost all of my flying since my license (1988) is in my no-electrical system Taylorcraft. For day VFR missions, a total electrical system failure, as long as the failure didn't make fire or smoke, would not give me sweaty palms. I would, however, be mindful of the loss of ignition redundancy and might choose to shorten the leg... Note: All of my explanations below (many), are intended solely as explanation and not a "defense". Although I believe I have thought everything through, I might have missed stuff and I could easily have misunderstood why some things were the way they were. PLEASE feel free to express any disagreement. I am seeking out things that I still need to fix. Given the above, this is what I did relative to Z11 and why: - Removed the starter and associated support. (As I also removed it from the aircraft. I saved the parts as I might want to reinstall it (more appropriately wired) later. - Removed the primer (As I also removed it from the aircraft. This might also be added back later in a more appropriately wired and plumbed manner) - Replaced the ignition switches with SPST as part of the removal of the starter support features. If/when I re-install the starter I intend to revisit the latest recommendations regarding connections here and anticipate I will be replacing these with the progress transfers as shown in Z11. - Rearranged the ground buses to match a pusher configuration rather than the tractor configuration. - Redefined the avionics ground bus to be an audio ground bus. My Nav/Com uses a differential audio path allowing separate audio/power grounds. All the avionics power grounds, with the exception of the low-power intercom return, terminate at the PNL Gnd bus. All audio grounds (including the intercom power ground) terminate at the Audio Gnd bus. - Reduced the number of connections tying the PNL ground to the Audio ground as it no longer carries any significant current. - Replaced the regulator shown on Z11 with the one existent on the aircraft. - Added a stand alone low-voltage indicator as the existent regulator (to my knowledge) does not support the feature. - Replaced the ANL with one sized to the existent alternator. - Replaced the shunt with one sized to match the existent Ampmeter. - Used a 20Amp blade fuse instead of a fuse-link for the regulator power for reasons that are lost to history. I will be using the fuse-link rather than 20A fuse approach. (I suspect that, back when I did this, the recommendation for a fuse-link wasn't as obvious but who knows... My book is years old.) - Combined the endurance bus and main battery bus as the only items on the main bus that have significant load are the position, landing, and strobe lights and, if I end up with a (currently not shown) backup path for the bus feed, the check list will list specific loads to drop (e.g. turn off these lights) before enabling the backup power path. - Removed the bus alternate feed as I haven't (yet) justified it as a worthy exception to the project guidelines (repair, not enhance as this stage). - Removed the Battery Bus as I have nothing that would attach to it. - Adjusted wire gauges as seemed appropriate for my actual loads. - I put each engine instrument on it's own fuse as I couldn't think of a good enough reason not to. It would have been the only exception to the one-fuse-per-end device approach. - I changed the "6 inches or less" to "24 inches or less" (turns out to be about 18 inches at the longest) due to the LongEZ's configuration constraints. The battery is in the nose. The contactor, shunt and ANL current limiter (with the regulator mounted on the closest fuselage side) are all mounted on the canard bulkhead (about as close as you can get them to the battery but the required wire length is still longer than 6 inches) and the fuse panel is on the right fuselage side between the canard bulkhead and the panel. This is also about as close as you can get it but is still requires wire lengths longer than 6 inches. Fortunately, with a non-metal airframe, it's a little easier to ensure appropriate protection for these runs. - I changed the fuse values to match either that recommended by the manufacturer of the end device, or, if not stated, to an appropriate value less than or equal to that required to protect the wire. Let me know if I missed any changes. It occurs to me now that the cleanest way to add an alternate power path (I don't like the approach I pondered on the schematic) may be to (conceptually, relative to Z11) move everything except the regulator power path from the main bus to the endurance bus (thus the main bus effectively becomes the output contact on the contactor). And then replace the battery bus and the alternate feed switch with a fuse-link to a panel mounted breaker switch. (Ideally a fuse link appropriate for 7-10 Amps, assuming such a thing exists) My justification for the breaker switch in this application that I want this resettable in flight given that I will be required to manually load shed (i.e. turn off the lights) and, if I neglect the check list and leave the lights on, I want to have a reasonable recovery option. I'm also still seriously considering leaving the alternate feed path off until I revisit the electrical system during the "enhancement" project to follow in a couple of years. For my current project, I think the alternate feeds greatest value is, in the event of a contactor failure, allowing my to keep my redundant source of ignition (but it also allows me to keep my primary nav/com etc. which is also nice :-) All comments welcome but I am particularly interested in discussion of failure mode for which I don't have appropriate fault tolerance. Thanks in advance, Steve Stearns Boulder/Longmont, Colorado CSA,EAA,IAC,AOPA,PE,ARRL,BARC (but ignorant none-the-less) Restoring (since 1/07): N45FC O235 Longeze Cothern/Friling CF1 (~1000 Hrs) Flying (since 9/86): N43732 A65 Taylorcraft BC12D ________________________________________________________________________________
Date: Oct 04, 2009
Subject: Re: 24V Heated Pitot
At 09:46 PM 10/3/2009, you wrote: >I have a chromed AN 5812-1 14V heated pitot tube from Aero >Instrument Co. and need the exact equivalent in a 12V model. Anyone >care to trade? > >Anticipating some responses that lead to thread drift: I don't want >to change the heating element. It's physically impossible to retrofit these devices. The heating elements are stainless tubes about 12-15" long with spiral wound segments tailored to deliver specific amounts of heat to various portions of the tube assembly. Emacs! Here you can see the heater tube as it loops twice through the labyrinth chamber and around the nose piece. I had to cut the tube apart just to SEE the heater . . . replacing it as a maintenance operation is not an option. > And yes, it gets hot on 12V but not hot enough to suit me. I > rather just swap with someone who has a 12V model and a 24V airplane. What defines "hot enough to suit"? Know that the crafting of a practical heated pitot tube involves a careful study of ice accretion characteristics under worst case conditions. The goal is to prevent liquid ice (super-cooled water droplets) from becoming solid ice on contact . . . this requires MUCH more energy than that required to maintain the surface at above freezing temperatures. As I alluded earlier, it's also not a function of simply installing a heater . . . the heater is a long, linear, un-even liberator of heat crafted to the task. Here's some data I took on an identical pitot tube in flight (clear air). http://www.aeroelectric.com/Pictures/Curves/Pitot_tube_temps_at_altitude.pdf The upper curve shows that while RAT was sometimes below -35C, the pitot tube was over 100C in cruising flight at 41K feet. An THIS was on a tube that was being studied for potentially deficient ability to avoid freezing under some conditions. Heated pitot tubes have been installed on tens of thousands of light aircraft not certified for flight into know icing conditions. I wouldn't discourage anyone from adding this feature to their airplane . . . it just MIGHT save your bacon one day. But know too that the icing conditions that would render your airspeed (and perhaps static instruments) useless are similarly destructive of the airplane's ability to fly. But then, it might be interesting to know how high you are and how fast you're going down . . . Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Oct 04, 2009
At 04:47 PM 10/3/2009, you wrote: > > >Bob - Sent this earlier but did not get a reply. Thought I would >send it again. I found my reply in the out-box. Here it is again: ------------------------------------------------------------- At 10:17 AM 10/2/2009, you wrote: > > >Bob - > >I'm a lurker on this site, but am in progress on a Pa22-20 project >(certified). How difficult would it be to use Z-11 in a certified >aircraft and get a 337 for that purpose? Has anyone done that >recently? Looks perfect for the project. >M. Haught I have often fantasized about taking a nice ol' rag-wing piper and updating the electrical system with something like Z-13/8, all new lightweight hardware and an RG battery. I'm aware of no projects flying where one has successfully run the gauntlet for permission to do a good thing to an ageing aircraft. Several folks have proposed such upgrades and have received tentative blessings on things like the forest of tabs ground bus and fuse blocks. But those systems have yet to be completed and signed off for flight. Bob . . . ________________________________________________________________________________
Date: Oct 04, 2009
Joe, As Bob said: "The goal is to prevent liquid ice (super-cooled water droplets) from becoming solid ice on contact . . . this requires MUCH more energy than that required to maintain the surface at above freezing temperatures. As I alluded earlier, it's also not a function of simply installing a heater . . . the heater is a long, linear, un-even liberator of heat crafted to the task." >From a qualitative perspective, it takes very little pitot heat to keep the pitot clear of rime and clear icing that we occassionally bump into at the altitudes that most GA flies. If we accidently run into SCD icing, we'll likely have far bigger and faster problems, long before the pitot heating is overcome by the super-cooled droplets. But, as always, each should do that that gives the greatest level of comfort. Chuck -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Joe Dubner Sent: Saturday, October 03, 2009 10:47 PM Subject: AeroElectric-List: 24V Heated Pitot I have a chromed AN 5812-1 14V heated pitot tube from Aero Instrument Co. and need the exact equivalent in a 12V model. Anyone care to trade? Anticipating some responses that lead to thread drift: I don't want to change the heating element. And yes, it gets hot on 12V but not hot enough to suit me. I rather just swap with someone who has a 12V model and a 24V airplane. Thanks, Joe Independence, OR http://www.mail2600.com/position ________________________________________________________________________________
Date: Oct 04, 2009
Well, I was afraid that was what you would say, as I had no seen any discussion of such a project while I have been on here. I guess I'm stuck with the original. Looking at my fuselage, the wiring harness is intact and actually, all of the wiring looks really good with no frayed covering or corrosion on the attachment points. But it will not support much in the way of avionics, etc. Thanks, Bob - M. Haught Robert L. Nuckolls, III wrote: > > > At 04:47 PM 10/3/2009, you wrote: >> >> >> Bob - Sent this earlier but did not get a reply. Thought I would >> send it again. > > I found my reply in the out-box. Here it is again: > ------------------------------------------------------------- > At 10:17 AM 10/2/2009, you wrote: >> >> >> Bob - >> >> I'm a lurker on this site, but am in progress on a Pa22-20 project >> (certified). How difficult would it be to use Z-11 in a certified >> aircraft and get a 337 for that purpose? Has anyone done that >> recently? Looks perfect for the project. >> M. Haught > > I have often fantasized about taking a nice > ol' rag-wing piper and updating the electrical > system with something like Z-13/8, all > new lightweight hardware and an RG battery. > > I'm aware of no projects flying where one > has successfully run the gauntlet for > permission to do a good thing to an ageing > aircraft. Several folks have proposed such > upgrades and have received tentative blessings > on things like the forest of tabs ground bus > and fuse blocks. But those systems have yet > to be completed and signed off for flight. > > > Bob . . . > > ________________________________________________________________________________
Date: Oct 04, 2009
From: Bill Mauledriver Watson <MauleDriver(at)nc.rr.com>
Robert L. Nuckolls, III wrote: > >> My thinking was the fuse is just protecting the wire to the pullable >> breaker. The wire is 16AWG and the fuse a 15amp. Then the breaker >> is a 5amp. But I think what you are telling me is that the fuse >> could defeat the whole purpose of having the pullable breaker. And >> that either a fusible link is needed to protect the wire or a direct >> connection to the buss. Is that correct? > Fuses are so much faster than breakers that > you may pop a 15A fuse trying to open a 5A > breaker. There's a reason for the fusible > link depicted in the Z-figures. I must be back level on my printed out Z figs. The one I have has that circuit connected directly to buss but in either case I get the point. I'm going to add 2 fusible links (22AWG based) to the circuit and take the power directly from the power feeds. >> It's an RV10 with both batteries in the rear. So I used 2AWG for the >> run to the starter and for the interbattery connections. The other >> battery has a (previously unmarked) 8AWG wire for the other run to >> the front. >> My analysis suggested that the 8AWG is enough for the 20amp Alt side >> of the circuit even in a crossfeed situation. > > Do you intend to load the aux battery for cranking? > If batteries are in the rear, then contactors are > in the rear and crossfeed contactor is on firewall > to give you a fat-terminal, power distribution point > at the cross-feed contactor. > > Use 4AWG welding cable off each battery terminal > to contactors and ground. 2AWG for run forward to > the starter contactor. > I did this a little different. I have all 3 contactors back with the batteries. Then a 2AWG running forward for the starter circuit and fuse board 1 with the majority of the load. Then a 8AWG line running forward to the other fuse board. The batteries are twin PC680s (pic attached). I can crank with both batteries or with 1. The plan is to generally just use 1. All of this was done over a year ago so it's all installed at this point. - Why a Z14? In the end, I fell for the simple symmetry of the whole thing over an E-bus solution. A bit irrational with some extra cost but it's working for me so far. It is an all electric a/c with my dream IFR panel (3 GRTs, G430w). No electronic ignition though. One of the things I found myself doing when IFR in my Maule, is sitting on the ramp getting a clearance, programming the G300XL, and more recently watching the Nexrad on the G396. For example, a year after Katrina I was sitting at the GA New Orlean's airport waiting to get past a line of buildups. The FBO was operational but their weather terminal was down so I spent 2 or 3 hours running out to the Maule checking the 396 for a hole and otherwise figuring out when and how to escape. I started to worry about having enough juice to start (I've never figured out what kind of time I would have in such a situation). Then when things opened up a bit, I shut everything down because I was keeping to the practice of not starting with the avionics online. Then I had to load a plan and wait for the 396 to get it's Nexrad back. All the time trying not to rush to get thru the hole. Since then based on your writings, I've started turning on my Maule avionics stack when needed, and keeping it on when starting. No problems ever encountered of course. But the doc for the GRTs suggest that it might reduce the life of the screeens if this is done frequently, so... Two things I wanted to have with my Z14. 1) I wanted the ability to run most of my stack without worrying about having enough energy for the start. I've always found that time spent on the ground prepping for an IFR flight, especially a single pilot departure into IMC, can be the most valuable in the flight. 2) I wanted to feel totally comfortable running the stack during the start - given the manufacturer's warning and a lifetime of perhaps worrying about something I didn't need to. An un-rushed, guilt-free panel setup before the start is a very nice thing to have. And then I have this dual electric system that can put 2 batteries on the starter if ever needed and can backup just about any electrical failure without much concern. And I don't think I can get too much weight back there in the battery compartment - the RV10 seems to benefit from it. Thanks for the review and the resources. Bill "this thing is going to fly in 2010" Watson > > Bob . . . > > --------------------------------------- > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > --------------------------------------- > > ________________________________________________________________________________
Date: Oct 04, 2009
Subject: Re: Basic Electrical Architecture for review...
Good Afternoon Marvin, I would never qualify as an expert on electrical systems, but I did recently make a few changes which I feel are improvements to our 1955 PA-22-20. I replaced every piece of wiring that could be reached without cutting the aircraft's fabric covering with nice new Tefzel wiring of the appropriate gauge. I replaced all of the original Circuit Breakers and most switches with new production substitutes. I removed the original CB panel and replaced it with a hunk of angle aluminum that extends left to right all the way across the bottom of the instrument panel. I also made new busses for all switches and CBs. 'Lectric Bob won't care for this next item, but I did add a radio master switch to feed an electronics buss. I performed all functions in accordance with AC 43.13-1B citing appropriate paragraphs for documentation of suitability. All work was noted on a 337 and filed with the FAA. No local approval required as AC43.13-1B provides adequate documentation for an IA to determine whether or not the installation is in conformance with those provisions. Our Pacer is now a very nice full WAAS equipped IFR platform! Any help at all? Happy Skies, Old Bob In a message dated 10/4/2009 3:55:58 P.M. Central Daylight Time, handainc(at)madisoncounty.net writes: --> AeroElectric-List message posted by: Marvin Haught Well, I was afraid that was what you would say, as I had no seen any discussion of such a project while I have been on here. I guess I'm stuck with the original. Looking at my fuselage, the wiring harness is intact and actually, all of the wiring looks really good with no frayed covering or corrosion on the attachment points. But it will not support much in the way of avionics, etc. Thanks, Bob - M. Haught ________________________________________________________________________________
Date: Oct 04, 2009
At 11:28 AM 10/4/2009, you wrote: > >Hi Bob, > >Thanks for taking a look at my architecture drawing. As to why it >differs from the recommendations in the Z-figures. Good >question. I hope my answers are as good (I have no inherent desire >to be "different").
September 17, 2009 - October 04, 2009
AeroElectric-Archive.digest.vol-ja
