AeroElectric-Archive.digest.vol-jc
October 21, 2009 - November 20, 2009
Subject: Re: Bus bar wiring
At 09:49 AM 10/21/2009, you wrote: > >I am looking for opinions on my method for connecting wires to the >buses. The top two rows in the photo are my main buss >breakers. The big nut at the top is the 6 awg wire from the battery >relay, it is just the lug now. The short wire labeled P13 is how I >connect the top bus bar to the middle bar. This wire is only 8 awg, >I am not sure this is OK since the main feed is a 6 awg wire. I am >using 6 awg based Aeroelectric DWG, but I am guessing I could get >away with 8 awg, it is only about 3 feet from the contactor to the >bus. I will run wire from the 8 awg wire where you see it clamped, >to the diode on the black heat sink then to the bottom bus bar which >is my essential bus. 8AWG is fine for this task. But I want to remind my readers that ALL wire sizes cited on AEC drawings should be evaluated for your particular load analysis tempered by practical decisions. What you've got will be fine but the wire sizes, while illustrated in the ARCHITCTURE drawings may not be the optimum or practical size. >Please give me feedback and pointers, I want to know if I am on the >right track. This panel will sit by my right leg along the sloped >console of the RV-8A. I used a castle nut because for a temporary >install it is easier to work with. I am using a AN4 bolt because >that is the smallest size lug I could find for the 6 awg wire. McMaster-Carr has small quantities of your odd size terminal needs. A 6AWG terminal for #10 stud is catalog number 7113K365. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Oct 21, 2009
Bob, Thank you for the information. When you say 8 AWG is fine I assume you mean the short jumper to the middle bus. I was planning 6 AWG as the main power feed to the bus since I will have a 60 amp alternator. I was thinking I could get by with 8 AWG since my typical load from my load analysis is only 20-25 amps and only gets to 47 amps in a night IFR situation. My harness kit from Van's came with 8AWG for the supply to the bus but I was not sure I should use it since my plane has more electrical gadgets than the Van's basic electrical plan contains. Is my logic flawed going up to 6 AWG for my application, should I just use the 8 AWG since I should be under the 57 amp max for that size wire? Cheers -------- Mike "Nemo" Elliott RV-8A QB (Fuselage) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=268836#268836 ________________________________________________________________________________
Subject: Re: FLIR EVS (was XeVision HIDs)
Date: Oct 21, 2009
> Deer are ruthless in their attacks. I personally know 5 people who were > attacked by deer using a flanking attack method. In all these cases the > deer waited until the front of the vehicle had passed and then rammed > into the side of the vehicle. An attack that is impossible to counter. > > I will be using a pasture in front of my house eventually, and deer are > my biggest fear. They are impossible to predict. > > Raymond Julian Ray, It is apparent... We all need to eat more venison! Roger Upton, MA ________________________________________________________________________________
Subject: Re: RST-523 Marker Beacon Receiver Kit
Date: Oct 19, 2009
If anyone in the group has recently constructed this receiver, I've got a few questions. Please contact me off list. Thanks, Angier Ames N4ZQ ________________________________________________________________________________
Date: Oct 21, 2009
From: "Richard E. Tasker" <retasker(at)optonline.net>
Amen to that. They are like giant rats down here in NJ. Roger wrote: > > > >> Deer are ruthless in their attacks. I personally know 5 people who >> were attacked by deer using a flanking attack method. In all these >> cases the deer waited until the front of the vehicle had passed and >> then rammed into the side of the vehicle. An attack that is >> impossible to counter. >> >> I will be using a pasture in front of my house eventually, and deer >> are my biggest fear. They are impossible to predict. >> >> Raymond Julian > > Ray, > > It is apparent... We all need to eat more venison! > > Roger > Upton, MA > > -- Please Note: No trees were destroyed in the sending of this message. We do concede, however, that a significant number of electrons may have been temporarily inconvenienced. -- ________________________________________________________________________________
Subject: Re: Tachometer Generator Wiring
Date: Oct 21, 2009
Bob: One other item, the tach gen turns at half of the engine rpm. So, the signal from the tach gen would need to be fully rectified to make this work (for me to get enough pulses per revolution as 1 ppr is the lowest recognized by the EFIS system). If the tach gen signal is 20 VRMS as you mentioned, is there a simple rectifier circuit you'd recommend? This should finish the work on this tach issue. Thanks Bob, Craig Read this topic online here: http://forums.matronics.com/viewtopic.php?p=268882#268882 ________________________________________________________________________________
Subject: Lacing
Date: Oct 21, 2009
Bob: You mentioned Dacron lacing as a good alternative to high temp wire ties in the engine compartment. Is there a good place to get the material and where would I find a tutorial on how to lace? Craig Read this topic online here: http://forums.matronics.com/viewtopic.php?p=268883#268883 ________________________________________________________________________________
Subject: Data output from a Garmin 496
Date: Oct 21, 2009
My Garmin 496 and Electronics International Fuel Flow Gauge (FP5L) aren't on speaking terms! I'd like to talk to anyone who has successfully made these two work together. My Garmin is driving my TruTrac autopilot okay. The output line from the Garmin is split off to both instruments. I've checked the conductivity of the wiring from plug to plug and it's good. I would really like to hear from anyone using these same three instruments but if you just have the 496 talking to the FP5L that would help too. Thanks, Steve Hamer RV-6 Flying Apple Valley, Ca ________________________________________________________________________________
Subject: Lacing
Date: Oct 22, 2009
From: "George, Neal E Capt USAF ACC 605 TES/DOA" <Neal.George(at)hurlburt.af.mil>
Craig - Stein carries lacing: http://www.steinair.com/accessories.htm Sixth item down the page. And here's a link to Bob's shop notes on tying bundles: http://www.aeroelectric.com/articles/cable_lace/cable_lace.html neal ============= Bob: You mentioned Dacron lacing as a good alternative to high temp wire ties in the engine compartment. Is there a good place to get the material and where would I find a tutorial on how to lace? Craig ________________________________________________________________________________
From: "Bill Bradburry" <bbradburry(at)bellsouth.net>
Subject: Serial data output from a Garmin 430W to KMD150
Date: Oct 22, 2009
My KMD150 does not see the GPS output from the GNS430W. Does anyone have any input on how to convince these two to talk to one another? Bill B ________________________________________________________________________________
Date: Oct 22, 2009
Subject: Re: Lacing
At 11:33 PM 10/21/2009, you wrote: > > >Bob: > >You mentioned Dacron lacing as a good alternative to high temp wire >ties in the engine compartment. Is there a good place to get the >material and where would I find a tutorial on how to lace? I don't recommend a "running lace" for aircraft wiring. Spot ties used on the same frequency as you might use tie-wraps is preferred. See: http://www.aeroelectric.com/articles/cable_lace/cable_lace.html Aircraft Spruce, Steinair, and many electronic supply houses stock lacing tape. See: http://www.aeroelectric.com/Mfgr_Data/Misc/Lacing_Tape/ My favorite is the Type II, Size 3, Finish B but they're all suited to your task. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Oct 22, 2009
At 11:32 PM 10/21/2009, you wrote: > > >Bob: > >One other item, the tach gen turns at half of the engine rpm. So, >the signal from the tach gen would need to be fully rectified to >make this work (for me to get enough pulses per revolution as 1 ppr >is the lowest recognized by the EFIS system). > >If the tach gen signal is 20 VRMS as you mentioned, is there a >simple rectifier circuit you'd recommend? > >This should finish the work on this tach issue. I have no idea what your particular tach generator's operating specs are. My offering was based on the 3-phase, permanent magnet tach-generators that I was manufacturing/replacing 30 years ago. Folks often refer to their tach transducer as a "tach generator" when in fact, it may be any technology that converts shaft rotations to some periodic signal. The exact nature of that signal is driven by requirement for the companion instrument. The last tach transducer project I worked was for the Bonanza 2" instrument upgrade program where the instrument expected 8 pulses per rev at 12v. We mounted 8 magnets on a disk and spun them next to a hall sensor. But the device you're working with can be an probably is something entirely different. Do you have part numbers and a wiring diagram for the orignal system associated with your "tach generator"?\ Assuming that it IS an sine-wave, AC device, then you don't want to rectify it, you'll probably want to 'square' the signal with a simple over-driven amplifier. Didn't I suggest a circuit for this? Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Subject: p-lead signal conditioning or tach gen usage
Date: Oct 22, 2009
Bob: My application is a russian radial engine and I am trying to use the tach input of an EFIS system in the aircraft. The EFIS expects a nice square wave from a Hall Effect sensor. However, I cannot mount a Hall effect sensor on the Russian mags as there is no port to do so and even if there were, the threads would be metric pitch. The tach gen is a three phase AC generator. The connector on the tach gen is three pins so it is likely Y-wound and uses the case as neutral. According to specs on the engine, the tach gen turns at half of the engine rpm. What I see is the following: 1) I can use a single phase of the tach gen as you proposed but I will then only get one-half pulse per revolution of the engine since the gen turns at half the engine rpm. I was thinking of doing full wave rectification of the signal to get back to one pulse per revolution. 2) I could condition the p-lead signal and tell the EFIS that there are 4.5 pulses per revolution. However, I don't know how to condition the signal properly. This method would provide no engine RPM during a mag check but I'd be OK with that. We are putting a scope on one phase of the tach gen output and the p-leads tomorrow. I'll take a picture of the scope as this will help. Thanks, Craig PS - bought your book and it is excellent. Thanks for that and all your help to us with experimental aircraft! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=268923#268923 ________________________________________________________________________________
Date: Oct 22, 2009
Subject: Re: Serial data output from a Garmin 430W to KMD150
Bill, did you configure the 430 that it does output NMEA0183 format with the correct baudrate and also, that the KMD does look for that format with the same baudrate and that receive and transmit of the two units are crossed? You have 3 wires between the two right? Just as a starter br Werner Bill Bradburry wrote: > > My KMD150 does not see the GPS output from the GNS430W. Does anyone > have any input on how to convince these two to talk to one another? > > > > Bill B > > * * > * > > > * ________________________________________________________________________________
Date: Oct 22, 2009
Subject: Re: p-lead signal conditioning or tach gen usage
At 09:44 AM 10/22/2009, you wrote: > > >Bob: > >My application is a russian radial engine and I am trying to use the >tach input of an EFIS system in the aircraft. The EFIS expects a >nice square wave from a Hall Effect sensor. However, I cannot mount >a Hall effect sensor on the Russian mags as there is no port to do >so and even if there were, the threads would be metric pitch. > >The tach gen is a three phase AC generator. The connector on the >tach gen is three pins so it is likely Y-wound and uses the case as >neutral. According to specs on the engine, the tach gen turns at >half of the engine rpm. What I see is the following: > >1) I can use a single phase of the tach gen as you proposed but I >will then only get one-half pulse per revolution of the engine since >the gen turns at half the engine rpm. I was thinking of doing full >wave rectification of the signal to get back to one pulse per revolution. This may not be true. It depends on how many poles are in the rotor magnet and stator windings. I think the machines we were building had 4 poles. >2) I could condition the p-lead signal and tell the EFIS that there >are 4.5 pulses per revolution. However, I don't know how to >condition the signal properly. This method would provide no engine >RPM during a mag check but I'd be OK with that. > >We are putting a scope on one phase of the tach gen output and the >p-leads tomorrow. I'll take a picture of the scope as this will help. Okay. That's a good start. Also check continuity between any one signal lead and case . . . I suspect you'll find that there is no "neutral" connection. If you do a full-wave rectification of the 3-phase output, you will indeed get a ripple signature that is 3x the frequency of a single phase . . . but it drops to 5% pk-pk of average. Now you'll need to process that small signal that becomes even smaller at idle and perhaps run-up rpms. How hard is it to get your hands on another tach generator . . . it doesn't need to be compatible with your tach, only fit the engine. I can probably show you how to build a many-pulses hall (or perhaps a bunches of pulses electro- magnetic) transducer into the old tach generator case. >PS - bought your book and it is excellent. Thanks for that and all >your help to us with experimental aircraft! Thanks for the kind words. I'm pleased that you find the work useful! Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Oct 22, 2009
Bob: I think I know where you are going with the tach gen. We could tap the side of the case and put a hall effect on it to "watch" the rotor magnets go by. I suspect the stator windings would need to be removed. Am I on track? To answer your question, yes, I can get another tach gen for the engine with no problems. About $150 for a new one...a little less for a used one. The Hall Effect can be obtained fro Aircraft Spruce. I'll post pictures of the o-scope and also look at the terminal to case resistance to see if there is any connection. Craig Read this topic online here: http://forums.matronics.com/viewtopic.php?p=268972#268972 ________________________________________________________________________________
Date: Oct 22, 2009
The GNS430W only outputs "aviation". This is not on the list of what the KMD150 says it will read, however, I have been told by both Garmin and Honeywell tech support that the KMD will read it. So far, I have not been able to tell my KMD... :>) I was hoping that someone on the list had accomplished that.. Bill B -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Werner Schneider Sent: Thursday, October 22, 2009 10:58 AM Subject: Re: AeroElectric-List: Serial data output from a Garmin 430W to KMD150 --> Bill, did you configure the 430 that it does output NMEA0183 format with the correct baudrate and also, that the KMD does look for that format with the same baudrate and that receive and transmit of the two units are crossed? You have 3 wires between the two right? Just as a starter br Werner Bill Bradburry wrote: > > My KMD150 does not see the GPS output from the GNS430W. Does anyone > have any input on how to convince these two to talk to one another? > > > > Bill B > > * * > * > > > * ________________________________________________________________________________
Date: Oct 22, 2009
At 03:56 PM 10/22/2009, you wrote: > > >Bob: > >I think I know where you are going with the tach gen. We could tap >the side of the case and put a hall effect on it to "watch" the >rotor magnets go by. I suspect the stator windings would need to be >removed. Am I on track? Close. The first time I prototyped a hall-effect tach transducer, I salvaged the whole front end bell and shaft. Just enough hardware to grab the engine. Some time on the lathe produced a new, short rear end bell and ECB mount. Another lathe-cut part had 12 little rod-magnets pressed into it and positioned to fly past the hall device on the ECB. >To answer your question, yes, I can get another tach gen for the >engine with no problems. About $150 for a new one...a little less >for a used one. The Hall Effect can be obtained fro Aircraft Spruce. The hall device I'm considering is a little surface mounted device. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Subject: Re: Lacing
Date: Oct 22, 2009
Intersting as the avionics shop on my field said using wax covered lacing cord was not appropriate under the cowling. Comments? Craig Read this topic online here: http://forums.matronics.com/viewtopic.php?p=268985#268985 ________________________________________________________________________________
Date: Oct 22, 2009
Subject: Re: Lacing
At 06:29 PM 10/22/2009, you wrote: > > >Intersting as the avionics shop on my field said using wax covered >lacing cord was not appropriate under the cowling. Comments? The clove hitch methodology (I) leaves the knot in tension and would probably be more secure if not waxed. I've not had any knots come loose when you tie 'em up like (II) . . . http://aeroelectric.com/articles/cable_lace/cable_lace.html The knot serves only to provide a "lump" that stops the free ends from slipping though the noose- loop, there's little or no tension on the final knot. Actually, I think the waxed cord gets you a tighter knot because the string slides over itself easier during the tightening process. But all the listed tapes are better than nylon-tie wraps. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Oct 22, 2009
> If you do a full-wave rectification of the 3-phase > output, you will indeed get a ripple signature that > is 3x the frequency of a single phase . . . but it > drops to 5% pk-pk of average. Now you'll need to process > that small signal that becomes even smaller at idle and > perhaps run-up rpms. Bob, I was thinking of only rectifying one phase not all three. My thought was that the tach gen is rotating at half engine speed, I'd get another "peak" in the signal from one phase and essentially double the frequency. Craig Read this topic online here: http://forums.matronics.com/viewtopic.php?p=268999#268999 ________________________________________________________________________________
Date: Oct 22, 2009
> >Bob, I was thinking of only rectifying one phase not all three. My >thought was that the tach gen is rotating at half engine speed, I'd >get another "peak" in the signal from one phase and essentially >double the frequency. Hmmmm . . . yeah, that would work. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Oct 23, 2009
Interesting according to the specs from the KMD 150 it reads: External GPS, requires ARNAV R-30, BendixKing RS232 or RS422 (9600 baud), NMEA0183 (4800 or 9600 baud) or Northstar Proprietary data (1200 baud); WX-500 Stormscope sensor that sounds not like Aviation Format will work! Werner Bill Bradburry wrote: > > The GNS430W only outputs "aviation". This is not on the list of what the > KMD150 says it will read, however, I have been told by both Garmin and > Honeywell tech support that the KMD will read it. > > So far, I have not been able to tell my KMD... :>) I was hoping that > someone on the list had accomplished that.. > > Bill B > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Werner > Schneider > Sent: Thursday, October 22, 2009 10:58 AM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Serial data output from a Garmin 430W to > KMD150 > > --> > > Bill, > > did you configure the 430 that it does output NMEA0183 format with the > correct baudrate and also, that the KMD does look for that format with the > same baudrate and that receive and transmit of the two units are crossed? > You have 3 wires between the two right? > > Just as a starter > > br Werner > > Bill Bradburry wrote: > >> My KMD150 does not see the GPS output from the GNS430W. Does anyone >> have any input on how to convince these two to talk to one another? >> >> >> >> Bill B >> >> * * >> * >> >> >> * >> > > > ________________________________________________________________________________
Date: Oct 23, 2009
Hello Bill, just found on the 430 installation instruction: 4.6.1.1 you can set GPS COM Out1 port on data format 2 which is the northstar format Don't forget to check baudrate! Let me know if you need instructions how to set it. br Werner Werner Schneider wrote: > > > Interesting according to the specs from the KMD 150 it reads: > > > > > External GPS, requires ARNAV R-30, BendixKing RS232 or RS422 (9600 > baud), NMEA0183 (4800 or 9600 > baud) or Northstar Proprietary data (1200 baud); WX-500 Stormscope sensor > > that sounds not like Aviation Format will work! > > Werner > > Bill Bradburry wrote: >> >> >> The GNS430W only outputs "aviation". This is not on the list of what >> the >> KMD150 says it will read, however, I have been told by both Garmin and >> Honeywell tech support that the KMD will read it. >> >> So far, I have not been able to tell my KMD... :>) I was hoping that >> someone on the list had accomplished that.. >> >> Bill B >> -----Original Message----- >> From: owner-aeroelectric-list-server(at)matronics.com >> [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of >> Werner >> Schneider >> Sent: Thursday, October 22, 2009 10:58 AM >> To: aeroelectric-list(at)matronics.com >> Subject: Re: AeroElectric-List: Serial data output from a Garmin 430W to >> KMD150 >> >> >> >> Bill, >> >> did you configure the 430 that it does output NMEA0183 format with the >> correct baudrate and also, that the KMD does look for that format >> with the >> same baudrate and that receive and transmit of the two units are >> crossed? >> You have 3 wires between the two right? >> >> Just as a starter >> >> br Werner >> >> Bill Bradburry wrote: >> >>> My KMD150 does not see the GPS output from the GNS430W. Does >>> anyone have any input on how to convince these two to talk to one >>> another? >>> >>> >>> >>> Bill B >>> >>> * * >>> * >>> >>> >>> * >>> >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Subject: Need help with desicsion
Date: Oct 23, 2009
I am running a 60 amp alternator in my system and can't decide which way to go with the wire size to the main bus. #8 is good to 57 amps, my max continuous load is 45 amps. If I get right up to the 60 amp load for some reason this will exceed the wire limits, I will also have a 60 am ANL. Is the #8 wire a compromise or is it just fine, or should I go up to #6? I do have the #6 wire, so it is not a matter of saving $, just the weight, the only thing I would need is some lugs. I bought the #6 wire without really thinking this through. I want to do this the best way possible, not just what will work. So since materials are not the issue which way would you guys and gals go. Thanks for the help, am I over thinking this! Cheers -------- Mike "Nemo" Elliott RV-8A QB (Fuselage) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=269048#269048 ________________________________________________________________________________
Date: Oct 23, 2009
Werner, That may be it, but I will have to think through it because I have other things connected to the 430. Dynon 10A, Trutrack Digitrack II VSGV, etc. they require Aviation and different speeds. Bill B -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Werner Schneider Sent: Friday, October 23, 2009 6:31 AM Subject: Re: AeroElectric-List: Serial data output from a Garmin 430W to KMD150 --> Hello Bill, just found on the 430 installation instruction: 4.6.1.1 you can set GPS COM Out1 port on data format 2 which is the northstar format Don't forget to check baudrate! Let me know if you need instructions how to set it. br Werner Werner Schneider wrote: > > > Interesting according to the specs from the KMD 150 it reads: > > oadServlet?FileName=/static/brochures/pdf/kmd150.pdf> > > > External GPS, requires ARNAV R-30, BendixKing RS232 or RS422 (9600 > baud), NMEA0183 (4800 or 9600 > baud) or Northstar Proprietary data (1200 baud); WX-500 Stormscope > sensor > > that sounds not like Aviation Format will work! > > Werner > > Bill Bradburry wrote: >> >> >> The GNS430W only outputs "aviation". This is not on the list of what >> the KMD150 says it will read, however, I have been told by both >> Garmin and Honeywell tech support that the KMD will read it. >> >> So far, I have not been able to tell my KMD... :>) I was hoping >> that someone on the list had accomplished that.. >> >> Bill B >> -----Original Message----- >> From: owner-aeroelectric-list-server(at)matronics.com >> [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of >> Werner Schneider >> Sent: Thursday, October 22, 2009 10:58 AM >> To: aeroelectric-list(at)matronics.com >> Subject: Re: AeroElectric-List: Serial data output from a Garmin 430W >> to KMD150 >> >> >> >> Bill, >> >> did you configure the 430 that it does output NMEA0183 format with >> the correct baudrate and also, that the KMD does look for that format >> with the same baudrate and that receive and transmit of the two units >> are crossed? >> You have 3 wires between the two right? >> >> Just as a starter >> >> br Werner >> >> Bill Bradburry wrote: >> >>> My KMD150 does not see the GPS output from the GNS430W. Does >>> anyone have any input on how to convince these two to talk to one >>> another? >>> >>> >>> >>> Bill B >>> >>> * * >>> * >>> >>> >>> * >>> >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Oct 23, 2009
Subject: Re: Need help with desicsion
At 06:25 10/23/2009, you wrote: >I am running a 60 amp alternator in my system and can't decide which >way to go with the wire size to the main bus. #8 is good to 57 >amps, my max continuous load is 45 amps. If I get right up to the >60 amp load for some reason this will exceed the wire limits, I will >also have a 60 am ANL. > >Is the #8 wire a compromise or is it just fine, or should I go up to >#6? I do have the #6 wire, so it is not a matter of saving $, just >the weight, the only thing I would need is some lugs. I bought the >#6 wire without really thinking this through. I want to do this the >best way possible, not just what will work. So since materials are >not the issue which way would you guys and gals go. > >Thanks for the help, am I over thinking this! > >Cheers I'll wade into this only to suggest rather than just using the somewhat generic wire capacity tables, dig into Chapter 11 of AC43-13-1B and work it out with actual numbers. What will the IR (voltage) drop be for your proposed run length based on the load, resistance, temperature, altitude, bundling and such of your chosen cable. Is your calculated voltage drop acceptable? AC43-13 has a suggestion: b. Voltage Drop in Wires. The voltage drop in the main power wires from the generation source or the battery to the bus should not exceed 2 percent of the regulated voltage when the generator is carrying rated current or the battery is being discharged at the 5-minute rate. The tabulation shown in table 11-6 defines the maximum acceptable voltage drop in the load circuits between the bus and the utilization equipment ground. Ron Q. ________________________________________________________________________________
Date: Oct 23, 2009
Ron, Good point, I have done the voltage drop with the table in AC43 but have not done the further study of altitude and such. I will work though it, as far as voltage drop with the amps and the cable length #8 is the answer. Thank you for pointing this out. Mike [quote="rjquillin"]At 06:25 10/23/2009, you wrote: > I am running a 60 amp alternator in my system and can't decide which way to go with the wire size to the main bus. #8 is good to 57 amps, my max continuous load is 45 amps. If I get right up to the 60 amp load for some reason this will exceed the wire limits, I will also have a 60 am ANL. > > Is the #8 wire a compromise or is it just fine, or should I go up to #6? I do have the #6 wire, so it is not a matter of saving $, just the weight, the only thing I would need is some lugs. I bought the #6 wire without really thinking this through. I want to do this the best way possible, not just what will work. So since materials are not the issue which way would you guys and gals go. > > Thanks for the help, am I over thinking this! > > Cheers I'll wade into this only to suggest rather than just using the somewhat generic wire capacity tables, dig into Chapter 11 of AC43-13-1B and work it out with actual numbers. What will the IR (voltage) drop be for your proposed run length based on the load, resistance, temperature, altitude, bundling and such of your chosen cable. Is your calculated voltage drop acceptable? AC43-13 has a suggestion: b. Voltage Drop in Wires. The voltage drop in the main power wires from the generation source or the battery to the bus should not exceed 2 percent of the regulated voltage when the generator is carrying rated current or the battery is being discharged at the 5-minute rate. The tabulation shown in table 11-6 defines the maximum acceptable voltage drop in the load circuits between the bus and the utilization equipment ground. Ron Q. > [b] -------- Mike "Nemo" Elliott RV-8A QB (Fuselage) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=269073#269073 ________________________________________________________________________________
Date: Oct 23, 2009
Mike, I guess the question is are you feeling lucky or conservative? No, the wire won't melt down if you get to a 58 amp draw. Tefzel will run hot a long time before it deteriorates and dissolves the connector and destroys all your components. If you want to be safe and are not worried about the few extra ounces, use the #6. If you want to be a nerd you can buy a micro processor, program the imbedded code and attach it to a thermocouple sensor on the wire, thus monitor the temperature for a while. Who's got that much time? We gotta go fly. If the #8 suits your load pattern and length calculations, then use it. I think a common misconception is that if you have a 60 amp alternator, that the alternator is constantly trying to burn up your 10 amp load with 60 amps of pressure. The alternator works on demand, so it won't produce more than you need. Think of it as a throttle. If you demand more, you'll get more. You could put a 150 amp alternator on there and run a #8 wire to it. Just depends on demand and the design of your system. Remember, it's the voltage that kills you not the amperage. Remove the VARs and you've got nothing. Glenn -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of rvg8tor Sent: Friday, October 23, 2009 9:26 AM Subject: AeroElectric-List: Need help with desicsion I am running a 60 amp alternator in my system and can't decide which way to go with the wire size to the main bus. #8 is good to 57 amps, my max continuous load is 45 amps. If I get right up to the 60 amp load for some reason this will exceed the wire limits, I will also have a 60 am ANL. Is the #8 wire a compromise or is it just fine, or should I go up to #6? I do have the #6 wire, so it is not a matter of saving $, just the weight, the only thing I would need is some lugs. I bought the #6 wire without really thinking this through. I want to do this the best way possible, not just what will work. So since materials are not the issue which way would you guys and gals go. Thanks for the help, am I over thinking this! Cheers -------- Mike "Nemo" Elliott RV-8A QB (Fuselage) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=269048#269048 ________________________________________________________________________________
Date: Oct 23, 2009
usage At 08:59 PM 10/22/2009, you wrote: > > > >> >>Bob, I was thinking of only rectifying one phase not all three. My >>thought was that the tach gen is rotating at half engine speed, I'd >>get another "peak" in the signal from one phase and essentially >>double the frequency. > > Hmmmm . . . yeah, that would work. On further reflection, there's a simple collection of components that can be used to give you a 4x increase in frequency . . . assuming that your tach input is watching for EDGES of transition and doesn't care about symmetry. Your comparator looks at full-wave rectified output to give you a 2x square wave. You then add an exclusive- or gate and a resistor-capacitor to convert each edge of the 2x into 4 narrow pulses effectively doubling the total number of edges a second time. Let's see what your 'scope studies tell us. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Oct 23, 2009
You might try what format you can select on the other two com's maybe they can still do Aviation? You can easily try to hook up a PC with a terminal program (don't use the windows one, but e.g. terraterm) and see what you get out there, so you can choose on com 1 the northstar? Further on the Users Guide Page 44: Important Note for Garmin GPS Users Although Garmin products output the Bendix/King equivalent ARNAV R- 30 (RS232) data sentence format, when put into OBS Mode some Garmin GPS units stop sending flight plan data. In these circumstances your KMD 150 will display only the GPS position and track since it is not receiving flight plan data. In the case of DME arcs, turns and holds, some Garmin GPS units send the flight plan information as if there was no arc or curved flight path. Therefore the KMD 150 has no option but to connect the beginning and end waypoints of the arc or curve with a straight line. Under these circumstances the line on the KMD 150 MUST BE IGNORED. NMEA AND NORTHSTAR DATA If the host GPS is outputting NMEA data or Northstar M3 binary data, no flight plan information will be displayed on the KMD 150. The information appearing on the KMD 150 will be limited to present position, track and ground speed. Good luck Werner Bill Bradburry wrote: > > Werner, > That may be it, but I will have to think through it because I have other > things connected to the 430. Dynon 10A, Trutrack Digitrack II VSGV, etc. > they require Aviation and different speeds. > > Bill B > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Werner > Schneider > Sent: Friday, October 23, 2009 6:31 AM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Serial data output from a Garmin 430W to > KMD150 > > --> > > Hello Bill, > > just found on the 430 installation instruction: > > 4.6.1.1 you can set GPS COM Out1 port on data format 2 which is the > northstar format > > Don't forget to check baudrate! > > Let me know if you need instructions how to set it. > > br Werner > > Werner Schneider wrote: > >> >> >> Interesting according to the specs from the KMD 150 it reads: >> >> > oadServlet?FileName=/static/brochures/pdf/kmd150.pdf> >> >> >> External GPS, requires ARNAV R-30, BendixKing RS232 or RS422 (9600 >> baud), NMEA0183 (4800 or 9600 >> baud) or Northstar Proprietary data (1200 baud); WX-500 Stormscope >> sensor >> >> that sounds not like Aviation Format will work! >> >> Werner >> >> Bill Bradburry wrote: >> >>> >>> >>> The GNS430W only outputs "aviation". This is not on the list of what >>> the KMD150 says it will read, however, I have been told by both >>> Garmin and Honeywell tech support that the KMD will read it. >>> >>> So far, I have not been able to tell my KMD... :>) I was hoping >>> that someone on the list had accomplished that.. >>> >>> Bill B >>> -----Original Message----- >>> From: owner-aeroelectric-list-server(at)matronics.com >>> [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of >>> Werner Schneider >>> Sent: Thursday, October 22, 2009 10:58 AM >>> To: aeroelectric-list(at)matronics.com >>> Subject: Re: AeroElectric-List: Serial data output from a Garmin 430W >>> to KMD150 >>> >>> >>> >>> Bill, >>> >>> did you configure the 430 that it does output NMEA0183 format with >>> the correct baudrate and also, that the KMD does look for that format >>> with the same baudrate and that receive and transmit of the two units >>> are crossed? >>> You have 3 wires between the two right? >>> >>> Just as a starter >>> >>> br Werner >>> >>> Bill Bradburry wrote: >>> >>> >>>> My KMD150 does not see the GPS output from the GNS430W. Does >>>> anyone have any input on how to convince these two to talk to one >>>> another? >>>> >>>> >>>> >>>> Bill B >>>> >>>> * * >>>> * >>>> >>>> >>>> * >>>> >>>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> > > > ________________________________________________________________________________
Date: Oct 23, 2009
At 08:25 AM 10/23/2009, you wrote: > >I am running a 60 amp alternator in my system and can't decide which >way to go with the wire size to the main bus. #8 is good to 57 >amps, my max continuous load is 45 amps. If I get right up to the >60 amp load for some reason this will exceed the wire limits, I will >also have a 60 am ANL. > >Is the #8 wire a compromise or is it just fine, or should I go up to >#6? I do have the #6 wire, so it is not a matter of saving $, just >the weight, the only thing I would need is some lugs. I bought the >#6 wire without really thinking this through. I want to do this the >best way possible, not just what will work. So since materials are >not the issue which way would you guys and gals go. > >Thanks for the help, am I over thinking this! Assuming that you're alternator b-lead is 4' long, a 6AWG at 4 mOhms/Ft will drop 60 x .004 x 4 = .96 volts at full load. If your alternator is an externally regulated device then the regulator senses BUS voltage instead of B-terminal voltage and it will compensate for the voltage drop. However, if internally regulated, the bus will run about 1.0 volts low during full load operations. In practice, you'd never be able to realize that loading because loads on the alternator are a combination of system requirements + battery recharge currents. For a 14.2v setpoint, a 13.2v bus wouldn't significantly stimulate the battery to soak up the joules it would like to have if the bus were actually higher. If your alternator is externally regulated, then voltage drops in the b-lead only limit your minimum speed for full alternator output . . . which at take-off or cruise settings is not a limiting factor. The trends are moving toward internally regulated (b-lead sense) and small b-lead feeders COMBINED with all other wires between the alternator and battery can stack up voltage drops that will impact battery recharge performance. This is why the Z-figures generally show 4AWG or larger for b-lead feeders . . . and all other fat-wires. Having said that, unless your battery is seriously discharged, these simple-ideas in physics have little perceivable effect on your operations. Going to the wire tables is not particularly useful for fat-wire calculations since their recommendations are based on temperature rises that generally fall WELL BELOW that which the wire will tolerate in your airplane. The hard- hat consideration is for voltage drop under the worst case conditions. There are additional voltage drops to be considered for the full- up system. Know that automobiles tend to use fat-wires that are a lot smaller than the aviation community would find acceptable for meeting design goals. At the same time, except for a severely discharge battery, automobiles almost never encounter conditions that exploit the full capability of the alternator. I've often suggested that if it were my airplane and the batteries were up front, I'd craft all the fat-wire paths with 4AWG welding cable for reasons that are not readily revealed by praying over the wire table . . . Bob . . . ________________________________________________________________________________
Date: Oct 24, 2009
Subject: BNC and RG 174
Bob and all, Some time ago you published a page on connecting a regular (big) BNC connector to a skinny coax cable (RG 174 ?). To date I've been unable to retrieve the document. Could you point me in the right direction ? Thanks, Best regards, -- Gilles http://contrails.free.fr ________________________________________________________________________________
Date: Oct 24, 2009
Subject: Re: BNC and RG 174
At 05:34 AM 10/24/2009, you wrote: ><Gilles.Thesee@ac-grenoble.fr> > >Bob and all, > >Some time ago you published a page on connecting a regular (big) BNC >connector to a skinny coax cable (RG 174 ?). >To date I've been unable to retrieve the document. >Could you point me in the right direction ? I vaguely remember that . . . but I can't put my hands on the imagery in my picture files. There are several approaches but the general idea is to get the electrical connections made up by the usual crimp/solder techniques and the "pot" the small coax body into the too-large connector with epoxy or super-glue. I'd prepare the end of the RG-174 like . . . http://aeroelectric.com/articles/shldwire/shldwire.html Cut the center conductor back to leave about 1'4" insulation, strip end and crimp on the center pin. You may want to double-back the strands of 174 before inserting them into the pin to make sure you got plenty of copper in the wire-grip. Fold the shield-tail back as you push the pin into place in the connector body. Wrap the shield-tail over the end of the shield grip so you can slide the ferrule over it and crimp. Trim of excess shield tail. Now you can fill the cavity around the cable with epoxy. A slow-set variety is probably called for so that it says "runny" long enough to penetrate as far as possible into the open voids around the cable. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Oct 24, 2009
Subject: Invitation! Lower Slobovia Garden Club's Pumpkin Drop,
2009 You're cordially invited to the "Lower Slobovia Garden Club" 3rd annual Pumpkin Drop, starting at 11:00 AM on Saturday, November 7, 2009. Lunch will be served at noon, and pumpkin drop demos begin around 2:00 PM. Contact info for driving directions is on the attached flyer; nav info is at http://www.airnav.com/airport/MS71 Y'all come! Charlie & Tupper, for the Lower Slobovia Garden Club members ________________________________________________________________________________
Date: Oct 25, 2009
I believe you slipped a zero. 6 awg is 0.4 mOhms per foot so the voltage drop on 4 feet is just under 0.1 volts. An easy rule of thumb to remember is 10 awg wire is 1 milliohm per 1 foot, every three wire sizes doubles the resistance. (so 7 awg would be about 2 milliohms per foot.) -Bob Newman ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Sent: Friday, October 23, 2009 11:37 AM Subject: Re: AeroElectric-List: Need help with desicsion > > > At 08:25 AM 10/23/2009, you wrote: >> >>I am running a 60 amp alternator in my system and can't decide which way >>to go with the wire size to the main bus. #8 is good to 57 amps, my max >>continuous load is 45 amps. If I get right up to the 60 amp load for some >>reason this will exceed the wire limits, I will also have a 60 am ANL. >> >>Is the #8 wire a compromise or is it just fine, or should I go up to #6? >>I do have the #6 wire, so it is not a matter of saving $, just the weight, >>the only thing I would need is some lugs. I bought the #6 wire without >>really thinking this through. I want to do this the best way possible, >>not just what will work. So since materials are not the issue which way >>would you guys and gals go. >> >>Thanks for the help, am I over thinking this! > > Assuming that you're alternator b-lead is 4' long, > a 6AWG at 4 mOhms/Ft will drop 60 x .004 x 4 = .96 > volts at full load. If your alternator is an externally > regulated device then the regulator senses BUS voltage > instead of B-terminal voltage and it will compensate > for the voltage drop. However, if internally regulated, > the bus will run about 1.0 volts low during full load > operations. In practice, you'd never be able to realize > that loading because loads on the alternator are a > combination of system requirements + battery recharge > currents. For a 14.2v setpoint, a 13.2v bus wouldn't > significantly stimulate the battery to soak up the > joules it would like to have if the bus were actually > higher. > > If your alternator is externally regulated, then > voltage drops in the b-lead only limit your minimum > speed for full alternator output . . . which at > take-off or cruise settings is not a limiting > factor. > > The trends are moving toward internally > regulated (b-lead sense) and small b-lead feeders > COMBINED with all other wires between the alternator > and battery can stack up voltage drops that will > impact battery recharge performance. This is why > the Z-figures generally show 4AWG or larger for > b-lead feeders . . . and all other fat-wires. > > Having said that, unless your battery is seriously > discharged, these simple-ideas in physics have > little perceivable effect on your operations. > Going to the wire tables is not particularly > useful for fat-wire calculations since their > recommendations are based on temperature rises > that generally fall WELL BELOW that which the > wire will tolerate in your airplane. The hard- > hat consideration is for voltage drop under the > worst case conditions. There are additional > voltage drops to be considered for the full- > up system. > > Know that automobiles tend to use fat-wires that > are a lot smaller than the aviation community > would find acceptable for meeting design goals. > At the same time, except for a severely discharge > battery, automobiles almost never encounter conditions > that exploit the full capability of the > alternator. I've often suggested that if it > were my airplane and the batteries were up front, > I'd craft all the fat-wire paths with 4AWG welding > cable for reasons that are not readily revealed by > praying over the wire table . . . > > > Bob . . . > > > ________________________________________________________________________________
From: "ROGER & JEAN CURTIS" <mrspudandcompany(at)verizon.net>
Date: Oct 25, 2009
Bob N., I believe you slipped in the wrong direction. #7 AWG is larger than #10 AWG therefore the resistance should be less. Roger -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bob-tcw Sent: Sunday, October 25, 2009 7:13 PM Subject: Re: AeroElectric-List: Need help with desicsion I believe you slipped a zero. 6 awg is 0.4 mOhms per foot so the voltage drop on 4 feet is just under 0.1 volts. An easy rule of thumb to remember is 10 awg wire is 1 milliohm per 1 foot, every three wire sizes doubles the resistance. (so 7 awg would be about 2 milliohms per foot.) -Bob Newman ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Sent: Friday, October 23, 2009 11:37 AM Subject: Re: AeroElectric-List: Need help with desicsion > > > At 08:25 AM 10/23/2009, you wrote: >> >>I am running a 60 amp alternator in my system and can't decide which way >>to go with the wire size to the main bus. #8 is good to 57 amps, my max >>continuous load is 45 amps. If I get right up to the 60 amp load for some >>reason this will exceed the wire limits, I will also have a 60 am ANL. >> >>Is the #8 wire a compromise or is it just fine, or should I go up to #6? >>I do have the #6 wire, so it is not a matter of saving $, just the weight, >>the only thing I would need is some lugs. I bought the #6 wire without >>really thinking this through. I want to do this the best way possible, >>not just what will work. So since materials are not the issue which way >>would you guys and gals go. >> >>Thanks for the help, am I over thinking this! > > Assuming that you're alternator b-lead is 4' long, > a 6AWG at 4 mOhms/Ft will drop 60 x .004 x 4 = .96 > volts at full load. If your alternator is an externally > regulated device then the regulator senses BUS voltage > instead of B-terminal voltage and it will compensate > for the voltage drop. However, if internally regulated, > the bus will run about 1.0 volts low during full load > operations. In practice, you'd never be able to realize > that loading because loads on the alternator are a > combination of system requirements + battery recharge > currents. For a 14.2v setpoint, a 13.2v bus wouldn't > significantly stimulate the battery to soak up the > joules it would like to have if the bus were actually > higher. > > If your alternator is externally regulated, then > voltage drops in the b-lead only limit your minimum > speed for full alternator output . . . which at > take-off or cruise settings is not a limiting > factor. > > The trends are moving toward internally > regulated (b-lead sense) and small b-lead feeders > COMBINED with all other wires between the alternator > and battery can stack up voltage drops that will > impact battery recharge performance. This is why > the Z-figures generally show 4AWG or larger for > b-lead feeders . . . and all other fat-wires. > > Having said that, unless your battery is seriously > discharged, these simple-ideas in physics have > little perceivable effect on your operations. > Going to the wire tables is not particularly > useful for fat-wire calculations since their > recommendations are based on temperature rises > that generally fall WELL BELOW that which the > wire will tolerate in your airplane. The hard- > hat consideration is for voltage drop under the > worst case conditions. There are additional > voltage drops to be considered for the full- > up system. > > Know that automobiles tend to use fat-wires that > are a lot smaller than the aviation community > would find acceptable for meeting design goals. > At the same time, except for a severely discharge > battery, automobiles almost never encounter conditions > that exploit the full capability of the > alternator. I've often suggested that if it > were my airplane and the batteries were up front, > I'd craft all the fat-wire paths with 4AWG welding > cable for reasons that are not readily revealed by > praying over the wire table . . . > > > Bob . . . > > > ________________________________________________________________________________
Date: Oct 25, 2009
oops. I sure did. ,#7 awg would be 1/2 mohm..#13 is 2 mohms . my bad -Bob Newman ----- Original Message ----- From: "ROGER & JEAN CURTIS" <mrspudandcompany(at)verizon.net> Sent: Sunday, October 25, 2009 8:43 PM Subject: RE: AeroElectric-List: Need help with desicsion > > > Bob N., > > I believe you slipped in the wrong direction. #7 AWG is larger than #10 > AWG > therefore the resistance should be less. > > Roger > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bob-tcw > Sent: Sunday, October 25, 2009 7:13 PM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Need help with desicsion > > > I believe you slipped a zero. 6 awg is 0.4 mOhms per foot so the > voltage > drop on 4 feet is just under 0.1 volts. > > An easy rule of thumb to remember is 10 awg wire is 1 milliohm per 1 foot, > every three wire sizes doubles the resistance. (so 7 awg would be about 2 > milliohms per foot.) > > -Bob Newman > > > ----- Original Message ----- > From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> > To: > Sent: Friday, October 23, 2009 11:37 AM > Subject: Re: AeroElectric-List: Need help with desicsion > > >> >> >> At 08:25 AM 10/23/2009, you wrote: >>> >>>I am running a 60 amp alternator in my system and can't decide which way >>>to go with the wire size to the main bus. #8 is good to 57 amps, my max >>>continuous load is 45 amps. If I get right up to the 60 amp load for >>>some > >>>reason this will exceed the wire limits, I will also have a 60 am ANL. >>> >>>Is the #8 wire a compromise or is it just fine, or should I go up to #6? >>>I do have the #6 wire, so it is not a matter of saving $, just the >>>weight, > >>>the only thing I would need is some lugs. I bought the #6 wire without >>>really thinking this through. I want to do this the best way possible, >>>not just what will work. So since materials are not the issue which way >>>would you guys and gals go. >>> >>>Thanks for the help, am I over thinking this! >> >> Assuming that you're alternator b-lead is 4' long, >> a 6AWG at 4 mOhms/Ft will drop 60 x .004 x 4 = .96 >> volts at full load. If your alternator is an externally >> regulated device then the regulator senses BUS voltage >> instead of B-terminal voltage and it will compensate >> for the voltage drop. However, if internally regulated, >> the bus will run about 1.0 volts low during full load >> operations. In practice, you'd never be able to realize >> that loading because loads on the alternator are a >> combination of system requirements + battery recharge >> currents. For a 14.2v setpoint, a 13.2v bus wouldn't >> significantly stimulate the battery to soak up the >> joules it would like to have if the bus were actually >> higher. >> >> If your alternator is externally regulated, then >> voltage drops in the b-lead only limit your minimum >> speed for full alternator output . . . which at >> take-off or cruise settings is not a limiting >> factor. >> >> The trends are moving toward internally >> regulated (b-lead sense) and small b-lead feeders >> COMBINED with all other wires between the alternator >> and battery can stack up voltage drops that will >> impact battery recharge performance. This is why >> the Z-figures generally show 4AWG or larger for >> b-lead feeders . . . and all other fat-wires. >> >> Having said that, unless your battery is seriously >> discharged, these simple-ideas in physics have >> little perceivable effect on your operations. >> Going to the wire tables is not particularly >> useful for fat-wire calculations since their >> recommendations are based on temperature rises >> that generally fall WELL BELOW that which the >> wire will tolerate in your airplane. The hard- >> hat consideration is for voltage drop under the >> worst case conditions. There are additional >> voltage drops to be considered for the full- >> up system. >> >> Know that automobiles tend to use fat-wires that >> are a lot smaller than the aviation community >> would find acceptable for meeting design goals. >> At the same time, except for a severely discharge >> battery, automobiles almost never encounter conditions >> that exploit the full capability of the >> alternator. I've often suggested that if it >> were my airplane and the batteries were up front, >> I'd craft all the fat-wire paths with 4AWG welding >> cable for reasons that are not readily revealed by >> praying over the wire table . . . >> >> >> Bob . . . >> >> >> >> >> > > > ________________________________________________________________________________
From: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net>
Subject: Flakey UPS AT GPS/COM
Date: Oct 25, 2009
I know there are several folks out there who have UPS AT (now Garmin) Apollo GX-60/65, SL-30/40 avionics. I've followed the installation instructions very carefully but I'm still experiencing some issues that seem attributable to the connector pins on the unit occasionally not making good contact with the connector/sockets on the tray. My GX-65 has to have a pin grounded in order for the unit to NOT go into simulation mode. The wonderful consequence of this DUMB design decision is that unit has been entering SIM mode occasionally after I turn the avionics on. I can make it stop if I turn it off and joggle the radio in the tray a little and then turn the unit on again. I checked the connectors on the back of the tray and they are not loose and they are installed on the backside of the tray per the instructions. There don't seem to be any loose pins and none of the wires are loose, broken or otherwise unattached. I've installed the unit in the tray with the cam per instructions taking care not to over tighten but to make sure the cam is as tight as seems possible. I was also getting a COM radio failure on the same unit but the radio tested out fine, after jiggling the antenna connector on the back of the tray I stopped getting the failure but am wondering how long that will last. Question, is anyone else experiencing this? Is there a cure? Having to jiggle a $3000.00 piece of equipment back and forth in the tray to make it work is outrageous. Please advise! Bob is there any similarity in the connector pin world to the correlary that a switch will fail sooner if not used (due to the contacts not rubbing over each other and keeping corrosion at bay)? UPS AT uses DB-15 and DB-30 connectors with crimp on gold plated pins/sockets which I used with tefzel wire grounded to a forest of tabs. I have a 2 gauge tefzel wire from the tabs to the battery ground. Please advise. Thanks all.... Dean Psiropoulos N197DM RV-6A Tampa bay area ________________________________________________________________________________
Date: Oct 25, 2009
Dean, My Garmin 480 had the same problems. The solution was to push the unit in a little harder before the cam is turned. The units must seat all the way to work and the cam can't do that if the unit is not in far enough first. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of DEAN PSIROPOULOS Sent: Sunday, October 25, 2009 7:32 PM Subject: AeroElectric-List: Flakey UPS AT GPS/COM I know there are several folks out there who have UPS AT (now Garmin) Apollo GX-60/65, SL-30/40 avionics. I've followed the installation instructions very carefully but I'm still experiencing some issues that seem attributable to the connector pins on the unit occasionally not making good contact with the connector/sockets on the tray. My GX-65 has to have a pin grounded in order for the unit to NOT go into simulation mode. The wonderful consequence of this DUMB design decision is that unit has been entering SIM mode occasionally after I turn the avionics on. I can make it stop if I turn it off and joggle the radio in the tray a little and then turn the unit on again. I checked the connectors on the back of the tray and they are not loose and they are installed on the backside of the tray per the instructions. There don't seem to be any loose pins and none of the wires are loose, broken or otherwise unattached. I've installed the unit in the tray with the cam per instructions taking care not to over tighten but to make sure the cam is as tight as seems possible. I was also getting a COM radio failure on the same unit but the radio tested out fine, after jiggling the antenna connector on the back of the tray I stopped getting the failure but am wondering how long that will last. Question, is anyone else experiencing this? Is there a cure? Having to jiggle a $3000.00 piece of equipment back and forth in the tray to make it work is outrageous. Please advise! Bob is there any similarity in the connector pin world to the correlary that a switch will fail sooner if not used (due to the contacts not rubbing over each other and keeping corrosion at bay)? UPS AT uses DB-15 and DB-30 connectors with crimp on gold plated pins/sockets which I used with tefzel wire grounded to a forest of tabs. I have a 2 gauge tefzel wire from the tabs to the battery ground. Please advise. Thanks all.... Dean Psiropoulos N197DM RV-6A Tampa bay area ________________________________________________________________________________
Date: Oct 26, 2009
Subject: Confusing
Hey guys - I have a puzzling question for you. At least it's puzzling to me. I'm studying my downloaded engine monitor data and it appears that when I transmit on the radio that I get an amperage spike and a simultaneous voltage drop. That makes sense - but, at the same time my OAT readings drop several degrees F and then recover to normal after the transmission. The OAT probe is in a NACA duct on the bottom of the wing and it is exposed to the bent wire radio antenna. Is it possible that the signal from the radio antenna is affecting the OAT readings when the radio signal hits the OAT probe? Confused in Daytona Beach, Stan Sutterfield ________________________________________________________________________________
Date: Oct 26, 2009
Subject: wire bundle protection
What can be used as a flexible conduit when running wire bundles-along a tube and fabric airplane frame? -In auto circles they use corregated plastic tubing that is slit along on e side. The wire bundle can then be inserted inside. Is this material accep table? It seems more durable than the old style spiral wrap and also easier to apply to a wire bundle. - Thanks, Eric - in Michigan ----=0A=0A=0A ________________________________________________________________________________
Date: Oct 26, 2009
Dean, The other option you have is to remove the back-plate socket and plug it in directly. That worked for me. It just makes me reach a bit more to remove it for updating (SL 60). Glenn -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Don Sent: Sunday, October 25, 2009 11:40 PM Subject: RE: AeroElectric-List: Flakey UPS AT GPS/COM Dean, My Garmin 480 had the same problems. The solution was to push the unit in a little harder before the cam is turned. The units must seat all the way to work and the cam can't do that if the unit is not in far enough first. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of DEAN PSIROPOULOS Sent: Sunday, October 25, 2009 7:32 PM Subject: AeroElectric-List: Flakey UPS AT GPS/COM I know there are several folks out there who have UPS AT (now Garmin) Apollo GX-60/65, SL-30/40 avionics. I've followed the installation instructions very carefully but I'm still experiencing some issues that seem attributable to the connector pins on the unit occasionally not making good contact with the connector/sockets on the tray. My GX-65 has to have a pin grounded in order for the unit to NOT go into simulation mode. The wonderful consequence of this DUMB design decision is that unit has been entering SIM mode occasionally after I turn the avionics on. I can make it stop if I turn it off and joggle the radio in the tray a little and then turn the unit on again. I checked the connectors on the back of the tray and they are not loose and they are installed on the backside of the tray per the instructions. There don't seem to be any loose pins and none of the wires are loose, broken or otherwise unattached. I've installed the unit in the tray with the cam per instructions taking care not to over tighten but to make sure the cam is as tight as seems possible. I was also getting a COM radio failure on the same unit but the radio tested out fine, after jiggling the antenna connector on the back of the tray I stopped getting the failure but am wondering how long that will last. Question, is anyone else experiencing this? Is there a cure? Having to jiggle a $3000.00 piece of equipment back and forth in the tray to make it work is outrageous. Please advise! Bob is there any similarity in the connector pin world to the correlary that a switch will fail sooner if not used (due to the contacts not rubbing over each other and keeping corrosion at bay)? UPS AT uses DB-15 and DB-30 connectors with crimp on gold plated pins/sockets which I used with tefzel wire grounded to a forest of tabs. I have a 2 gauge tefzel wire from the tabs to the battery ground. Please advise. Thanks all.... Dean Psiropoulos N197DM RV-6A Tampa bay area ________________________________________________________________________________
Subject: Re: wire bundle protection
Date: Oct 26, 2009
I used lengths of shower curtain rod covers for the chase in my cozy project. They're covered by the arm rests though. Just another way to skin a cat. -- Remi ________________________________________________________________________________
Date: Oct 26, 2009
Eric, You can get a roll of half inch drip system tube at you local hardware store for a few bucks. It's light, flexible and easy to work with. Steve Hamer RV-6 Apple Valley, Ca ________________________________________________________________________________
Subject: Re: Continental IO-240: Alternator quit working, Coupling
Failed
Date: Oct 26, 2009
The past 254 hours have been great...until yesterday. My alternator coupling failed...AGAIN! I had purchased a rebuilt unit from Drake Air (as noted above in this thread). $450 versus $1,600 from TCM for a new one. Is there any reason this part should fail so soon? Oil, hours, temps, alternator load, how the load is applied, etc? I emailed Drake Air this morning and was inquiring as to why their part failed...prematurely...in my opinion! I have to pull my engine to remove the alternator. ...insult to injury! :? Again...I welcome input from the forum! Travis :) -------- Travis Rayner Mobile, AL Skystar Vixen, N-789DF Continental IO-240, Prince P-Tip Prop ADI-II Autopilot AnyWhereMap Navigation with weather Read this topic online here: http://forums.matronics.com/viewtopic.php?p=269543#269543 ________________________________________________________________________________
Date: Oct 26, 2009
Coupling Failed > >I emailed Drake Air this morning and was inquiring as to why their >part failed...prematurely...in my opinion! > >I have to pull my engine to remove the alternator. ...insult to injury! :? > >Again...I welcome input from the forum! In what manner did it fail? Was it the same failure mode as the first one? Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Oct 26, 2009
Subject: Re: Confusing
At 01:04 AM 10/26/2009, you wrote: >Hey guys - >I have a puzzling question for you. At least it's puzzling to me. >I'm studying my downloaded engine monitor data and it appears that >when I transmit on the radio that I get an amperage spike and a >simultaneous voltage drop. That makes sense - but, at the same time >my OAT readings drop several degrees F and then recover to normal >after the transmission. >The OAT probe is in a NACA duct on the bottom of the wing and it is >exposed to the bent wire radio antenna. >Is it possible that the signal from the radio antenna is affecting >the OAT readings when the radio signal hits the OAT probe? Sounds like a susceptibility problem with the instrumentation system. The offending stimulus (comm transmitter) gets into the instrumentation electronics via ship's wiring. Systems destined for installation in TC aircraft are tested for this effect and filters sufficient to the task are included inside the instrument enclosure. Try putting a dummy load on your antenna coax AT THE ANTENNA. See: http://aeroelectric.com/Pictures/Tools/RF_Antenna_Test_Tools/DummyLoad.jpg if the problem goes away with the dummy load attached, then you need to add filtering to the instrumentation system or see if moving the antenna further way does the job. If the problem does NOT go away, then you've got a shield ground open in the feedline between radio and antenna. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Oct 26, 2009
At 06:13 PM 10/25/2009, you wrote: > >I believe you slipped a zero. 6 awg is 0.4 mOhms per foot so the >voltage drop on 4 feet is just under 0.1 volts. Oops! Good eye. You're correct. >An easy rule of thumb to remember is 10 awg wire is 1 milliohm per 1 >foot, every three wire sizes doubles the resistance. (so 7 awg >would be about 2 milliohms per foot.) Yup, wrote about that in several places . . . but drop to 7 gets you 0.5 mOhm/ft and 6 awg would necessarily be lower. See: http://www.aeroelectric.com/articles/wiresize.pdf Thanks for the heads-up Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Oct 26, 2009
I love this stuff. http://cableorganizer.com/f6-wrap-around/ I got the fire retardant version. Really easy to use and looks really nice . IMAO. All the best, Christopher Barber Houston Velocity SE w/rotary 13B ________________________________ From: owner-aeroelectric-list-server(at)matronics.com [owner-aeroelectric-list -server(at)matronics.com] On Behalf Of Steve Hamer [s.hamer(at)verizon.net] Sent: Monday, October 26, 2009 2:52 PM Subject: Re: AeroElectric-List: wire bundle protection Eric, You can get a roll of half inch drip system tube at you local hardware stor e for a few bucks. It's light, flexible and easy to work with. Steve Hamer RV-6 Apple Valley, Ca ________________________________________________________________________________
Subject: Re: What is the type of this pin?
Date: Oct 27, 2009
Hi everybody, I found the name of my contact: Amphenol AIRLB.... Fortunatly I met a guy familiar with this type of contact. Thank you very much for all input Overtorque Read this topic online here: http://forums.matronics.com/viewtopic.php?p=269622#269622 ________________________________________________________________________________
Subject: Alternator quit working, Coupling
Date: Oct 27, 2009
10/27/2009 Hello Travis, You wrote: 1) "My alternator coupling failed...AGAIN!" Bummer -- I feel a bit guilty because I steered you in the direction of Drake back in November 2006. The history of your alternator couplings is not clear to me: a) Your original TCM factory provided coupling that came with your engine failed after how many hours? b) You sent the original failed coupling off to Drake and they refurbished it. How many hours did you get on this refurbished coupling before it failed? 2) "I emailed Drake Air this morning and was inquiring as to why their part failed...prematurely...in my opinion!" In addition to this query to Drake (from whom you may not get a completely unbiased answer) I would call TCM Technical Services (1-888-826-5465) and ask some questions: a) What is the expected service hours life of their elastomeric coupling? b) What factors could shorten that service life? c) Do they have any info from the field on the durability of Drake's coupling versus TCM's coupling? d) Who makes the TCM coupling? You can see where this is heading. It may turn out that a $1,600 TCM coupling is a more cost effective item than a $450 Drake refurbished coupling. The durability of the Drake refurbished coupling would be dependent upon: A) The quality of the elastomeric material used, and B) The quality of the workmanship in casting / assembling the coupling. Can you recall how the original TCM coupling failed? Was it a shearing of the elastomeric or was it a separation of the elastomeric from the metal parts? Similarly, how did the Drake refurbished coupling fail? Was it a shearing of the elastomeric or was it a separation of the elastomeic from the metal parts? Regardless of which coupling source you decide to use you may want to apply the torque test to it before you install it. The torque test is described in the TCM SB95-3B. Good luck and please keep us informed. 'OC' Says: "The best investment we can make is the effort to gather and understand knowledge." PS: I am flying a KIS TR-1 with a TCM IO-240 B9B engine with a Prince P tip prop. 263 hours tach time with the engine above 1,500 RPM. With my new wheel pants I can get 140 knots indicated airspeed. ========================================================== Subject: AeroElectric-List: Re: Continental IO-240: Alternator quit working, Coupling Failed From: "FlyboyTR" <flyboytr(at)bellsouth.net> The past 254 hours have been great...until yesterday. My alternator coupling failed...AGAIN! I had purchased a rebuilt unit from Drake Air (as noted above in this thread). $450 versus $1,600 from TCM for a new one. Is there any reason this part should fail so soon? Oil, hours, temps, alternator load, how the load is applied, etc? I emailed Drake Air this morning and was inquiring as to why their part failed...prematurely...in my opinion! I have to pull my engine to remove the alternator. ...insult to injury! :? Again...I welcome input from the forum! Travis :) -------- Travis Rayner Mobile, AL Skystar Vixen, N-789DF Continental IO-240, Prince P-Tip Prop ADI-II Autopilot AnyWhereMap Navigation with weather Read this topic online here: http://forums.matronics.com/viewtopic.php?p=269543#269543 ________________________________________________________________________________
Subject: Re: Flakey UPS AT GPS/COM
Date: Oct 27, 2009
Is that ground signal the only intermittent you have? You might rework that one pin to wire joint on the back side of the connector. Does pulling the unit straight forward break the connection? It might be a faulty pin or poorly captured one in the connector body. -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=269635#269635 ________________________________________________________________________________
Subject: What makes diode get warm
Date: Oct 27, 2009
I have the B&C diode on the heat sink (smaller one). I was bench testing things to make sure the flow was correct, I just took the breaker panel and hooked up power to the main bus then the E-bus. The diode did not heat up at all, the flow was in the correct direction. I hooked up power to the E-bus and the diode did prevent current to the main bus, the main would only read 0.4 volts which I assume is normal. With this set up the diode again did not heat up. I then hooked up one of the 50W MR16 landing light bulbs to a CB thinking maybe I needed a load, again the diode did not heat up. So what make the diode heat up, is it more load on the system or is it when there is power going to both buses, as when you have the master on and the E-bus alternate feed on at the same time. With both buses getting power the diode is getting power from both sides. I hear you can fly around this way but not sure I will, my plan now is the have my E-bus alternate feed under a guarded switch that stay off when guarded. When the E-bus gets power from the main via the diode there is a slight voltage drop, the the E-bus alternate feed was on the flow from the battery to the E-bus would win out and supply the E-bus since the voltage from the main is lower. So would this meeting of currents be what heats up the diode? As far as flying around with the E-bus alternate feed on I don't see the need with my system I have a standby alternator. Once I am using standby power then I might consider turning the alternate feed on for automatic switching in case the standby alternator then quit. Thank for the help. Cheer Mike -------- Mike "Nemo" Elliott RV-8A QB (Fuselage) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=269670#269670 ________________________________________________________________________________
Subject: Bending male tabs on diode
Date: Oct 27, 2009
My diode is mounted on my CB panel which is by my right leg. When I hooked up the blade connectors they stick out just enough that the radius of wire touches the fuselage. I bent over the tabs with some duck bill pliers, the diode arrived with one tab slightly bent so I knew they are fairly easy to bend. The thing bench tests fine, other than heat shrinking the connector since they are closer to the sides of the diode is there anything wrong with doing this? Picture attached for illustration. -------- Mike "Nemo" Elliott RV-8A QB (Fuselage) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=269674#269674 ________________________________________________________________________________
Date: Oct 27, 2009
Subject: Re: What makes diode get warm
rvg8tor wrote: > > I have the B&C diode on the heat sink (smaller one). I was bench testing things to make sure the flow was correct, I just took the breaker panel and hooked up power to the main bus then the E-bus. The diode did not heat up at all, the flow was in the correct direction. I hooked up power to the E-bus and the diode did prevent current to the main bus, the main would only read 0.4 volts which I assume is normal. With this set up the diode again did not heat up. I then hooked up one of the 50W MR16 landing light bulbs to a CB thinking maybe I needed a load, again the diode did not heat up. > > So what make the diode heat up, is it more load on the system or is it when there is power going to both buses, as when you have the master on and the E-bus alternate feed on at the same time. With both buses getting power the diode is getting power from both sides. I hear you can fly around this way but not sure I will, my plan now is the have my E-bus alternate feed under a guarded switch that stay off when guarded. When the E-bus gets power from the main via the diode there is a slight voltage drop, the the E-bus alternate feed was on the flow from the battery to the E-bus would win out and supply the E-bus since the voltage from the main is lower. So would this meeting of currents be what heats up the diode? As far as flying around with the E-bus alternate feed on I don't see the need with my system I have a standby alternator. Once I am using standby power then I might consider turning the alternate feed on for automatic switching in case the standby alternator th! > en quit. Thank for the help. > > Cheer > Mike > > -------- Bob will probably provide a better answer, but the quick & dirty is that it's called a 'semi-conductor' because it's not a pure conductor. There's some resistance even with the electrons flowing 'forward', and it will heat up due to the work being done pushing them through this resistance, just like a wire heats up with a lot of current flowing through it. With more electrons flowing (more current), more heat. Charlie ________________________________________________________________________________
Date: Oct 27, 2009
Mike, If you have a second alternator, and using B&C's regulators, you really don't need the E buss. Peter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of rvg8tor Sent: Tuesday, October 27, 2009 2:06 PM Subject: AeroElectric-List: What makes diode get warm I have the B&C diode on the heat sink (smaller one). I was bench testing things to make sure the flow was correct, I just took the breaker panel and hooked up power to the main bus then the E-bus. The diode did not heat up at all, the flow was in the correct direction. I hooked up power to the E-bus and the diode did prevent current to the main bus, the main would only read 0.4 volts which I assume is normal. With this set up the diode again did not heat up. I then hooked up one of the 50W MR16 landing light bulbs to a CB thinking maybe I needed a load, again the diode did not heat up. So what make the diode heat up, is it more load on the system or is it when there is power going to both buses, as when you have the master on and the E-bus alternate feed on at the same time. With both buses getting power the diode is getting power from both sides. I hear you can fly around this way but not sure I will, my plan now is the have my E-bus alternate feed under a guarded switch that stay off when guarded. When the E-bus gets power from the main via the diode there is a slight voltage drop, the the E-bus alternate feed was on the flow from the battery to the E-bus would win out and supply the E-bus since the voltage from the main is lower. So would this meeting of currents be what heats up the diode? As far as flying around with the E-bus alternate feed on I don't see the need with my system I have a standby alternator. Once I am using standby power then I might consider turning the alternate feed on for automatic switching in case the standby alternator th! en quit. Thank for the help. Cheer Mike -------- Mike "Nemo" Elliott RV-8A QB (Fuselage) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=269670#269670 ________________________________________________________________________________
Date: Oct 27, 2009
> > > rvg8tor wrote: >> >> I have the B&C diode on the heat sink (smaller one). I was bench >> testing things to make sure the flow was correct, I just took the >> breaker panel and hooked up power to the main bus then the E-bus. The >> diode did not heat up at all, the flow was in the correct direction. I >> hooked up power to the E-bus and the diode did prevent current to the >> main bus, the main would only read 0.4 volts which I assume is normal. >> With this set up the diode again did not heat up. I then hooked up one >> of the 50W MR16 landing light bulbs to a CB thinking maybe I needed a >> load, again the diode did not heat up. >> >> So what make the diode heat up, is it more load on the system or is it >> when there is power going to both buses, as when you have the master on >> and the E-bus alternate feed on at the same time. With both buses >> getting power the diode is getting power from both sides. I hear you >> can fly around this way but not sure I will, my plan now is the have my >> E-bus alternate feed under a guarded switch that stay off when guarded. >> When the E-bus gets power from the main via the diode there is a slight >> voltage drop, the the E-bus alternate feed was on the flow from the >> battery to the E-bus would win out and supply the E-bus since the >> voltage from the main is lower. So would this meeting of currents be >> what heats up the diode? As far as flying around with the E-bus >> alternate feed on I don't see the need with my system I have a standby >> alternator. Once I am using standby power then I might consider turning >> the alternate feed on for automatic switching in case the standby >> alternator ! > th! >> en quit. Thank for the help. >> >> Cheer >> Mike >> >> -------- > Bob will probably provide a better answer, but the quick & dirty is > that it's called a 'semi-conductor' because it's not a pure conductor. > There's some resistance even with the electrons flowing 'forward', and > it will heat up due to the work being done pushing them through this > resistance, just like a wire heats up with a lot of current flowing > through it. With more electrons flowing (more current), more heat. > > Charlie > Right. The ebus diode will run hottest when the ebus is powered through it. To observe this, the ebus alternate feed switch needs to be open, and power (battery) directly to the main bus. At this point, any loads on the ebus will pull current through the diode and cause it to heat up. Regards, Matt- ________________________________________________________________________________
Subject: Re: Transponder antenna location
Date: Oct 27, 2009
I plan to position my transponder antenna (GTX330) just behind the firewall on the left, next to the fuel vent line (RV9A). This location is about 34" from the back of the transponder. Do you guys see any problems with this location, if you do where would you place the antenna. The whip-style COM antenna will be located behind the pilots seat. Also do you know of a good wiring diagram between the SL30 and the GMA340 audio box. Thanks for any help. John ________________________________________________________________________________
Date: Oct 27, 2009
John: As a rule of thumb an antenna wants a ground plane around it that is infinite. In practice it should be at least (roughly) a wave long or so i n all directions. The more the better. What I mean is that the antenna might have a more radially uniform pattern if it was not right at the edge of the floor skin, immediately behind the firewall. That gives it an asymmetric ground plane and will distort the antenna pattern. I put mine closer to th e gear weldment (on a 6A) so that it was under the seat skins. I kept it abou t 1 wavelength away from the steel (=conductive) landing gear. (at 1GHz 1 w ave is about a foot - your xponder antenna is 1/4 wave). I haven't run the thing yet, so I can't tell you that it works well there, just that it should work better there than at the forward edge of things. In practice it might not matter much. Still, I thought it better not to tempt fate. Antenna design is a black art. On Tue, Oct 27, 2009 at 1:33 PM, John B Szantho wrote: > I plan to position my transponder antenna (GTX330) just behind the > firewall on the left, next to the fuel vent line (RV9A). This location is > about 34=9D from the back of the transponder. Do you guys see any p roblems > with this location, if you do where would you place the antenna. The > whip-style COM antenna will be located behind the pilots seat. Also do yo u > know of a good wiring diagram between the SL30 and the GMA340 audio box. > Thanks for any help. > > John > > * > =========== =========== =========== =========== > * > > -- Tom Sargent ________________________________________________________________________________
Date: Oct 28, 2009
- - Which Z diagram would it look like without the E buss? - Eric From: "plaurence" <peterlaurence6(at)gmail.com> Subject: RE: AeroElectric-List: What makes diode get warm Mike, If you have a second alternator, and using B&C's regulators, you really don't need the E buss. Peter //mail.yahoo.com ________________________________________________________________________________
Date: Oct 28, 2009
At 01:06 PM 10/27/2009, you wrote: > >I have the B&C diode on the heat sink (smaller one). I was bench >testing things to make sure the flow was correct, I just took the >breaker panel and hooked up power to the main bus then the >E-bus. The diode did not heat up at all, the flow was in the >correct direction. I hooked up power to the E-bus and the diode did >prevent current to the main bus, the main would only read 0.4 volts >which I assume is normal. With this set up the diode again did not >heat up. I then hooked up one of the 50W MR16 landing light bulbs >to a CB thinking maybe I needed a load, again the diode did not heat up. Perhaps it did . . . just not enough for you to perceive it by feeling. Was your e-bus alternate feed switch OPEN during the test. If so, then the normal feed path diode would have been carrying all the e-bus loads and it would warm up. Why a diode on a heat-sink? How large are your anticipated e-bus loads? The diode-bridge rectifier mounted on a metal airframe surface is good for 10+ amps. Schottky diodes are a bit better yet. I've tested this guy to 20A http://aeroelectric.com/Catalog/AEC/9001/IM9001-700A.pdf when mounted on a surface .062" thick with no additional heat sinking. >So what make the diode heat up, is it more load on the system or is >it when there is power going to both buses, as when you have the >master on and the E-bus alternate feed on at the same time. If the alternate feedpath switch is closed, then the normal feed-path is bypassed and the diode will carry no current . . . nor will it warm up. >With both buses getting power the diode is getting power from both >sides. I hear you can fly around this way but not sure I will, my >plan now is the have my E-bus alternate feed under a guarded switch >that stay off when guarded. When the E-bus gets power from the main >via the diode there is a slight voltage drop . . . and is the time when it dissipates a few watts of power and will warm up. The degree of temperature rise depends on mass and configuration of the heat sink. > . . . the the E-bus alternate feed was on the flow from the > battery to the E-bus would win out and supply the E-bus since the > voltage from the main is lower. . . . The main bus voltage isn't 'lower' but a voltage drop in the normal feed path becomes insignificant when the alternate feed path bypasses the diode. > So would this meeting of currents be what heats up the diode? As > far as flying around with the E-bus alternate feed on I don't see > the need with my system I have a standby alternator. How about being able to fire up the comm radio for ATIS and clearance delivery before starting the engine? THIS is the time that the alternate feed path is also tested. > Once I am using standby power then I might consider turning the > alternate feed on for automatic switching in case the standby > alternator then quit. Thank for the help. The purpose of the alternate feed path switch is to allow battery only operations without having a battery contactor closed. You didn't mention which, if any of the Z-figures you based your system. If you're running Z-12, then having the switch "pre-closed" offers no degree of automation. I'll suggest you do a site search on "e-bus" at aeroelectric.com and review the conversation about how the e-bus came into being and what it's all about. There's about 30 hits that should offer some insight. Over the past 15 or so years, folks have tended to overload the e-bus and/or lost track of the e-bus design goals. It may well be that your design goals are served by not having an e-bus. It's a strong probability that your normal feed-path diode assembly is oversized. Bob . . . ________________________________________________________________________________
Date: Oct 29, 2009
Bob N. When I looked at the B&C website for my diode the install instructions for the diode said for an E-bus drawing more than 3 amps to mount the diode on a heat sink, my E-bus will draw 9 amps. So I bought he diode already mounted to the heat sink, I did not think about the fact that just mounting it to the metal panel would provide some heat sink capability. I have read many posts with regard to E-bus design, my goal was not to fly to my destination if I was battery only but to be able to fly to suitable field, not necessarily the closest field and land to make repairs. In all honesty I think I may never see battery only when I consider the probability of losing both main and standby alternators. I like the insurance of the standby alternator when I consider IFR operations, this is my main reason for adding this to this and hence my adoption of Z-12. Thanks again for the help you provide it is much appreciated, I have been learning a lot. -------- Mike "Nemo" Elliott RV-8A QB (Fuselage) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=269970#269970 ________________________________________________________________________________
Date: Oct 29, 2009
At 10:00 AM 10/29/2009, you wrote: > >Bob N. > >When I looked at the B&C website for my diode the install >instructions for the diode said for an E-bus drawing more than 3 >amps to mount the diode on a heat sink, my E-bus will draw 9 >amps. So I bought he diode already mounted to the heat sink, I did >not think about the fact that just mounting it to the metal panel >would provide some heat sink capability. > >I have read many posts with regard to E-bus design, my goal was not >to fly to my destination if I was battery only but to be able to fly >to suitable field, not necessarily the closest field and land to >make repairs. In all honesty I think I may never see battery only >when I consider the probability of losing both main and standby >alternators. I like the insurance of the standby alternator when I >consider IFR operations, this is my main reason for adding this to >this and hence my adoption of Z-12. > >Thanks again for the help you provide it is much appreciated, I have >been learning a lot. Then leave the e-bus out. There are thousands of Bonanzas, and large Piper/Cessna singles wired like Z-12. This pre-supposes that you're not interested in the pre-flight power up of a comm radio before starting the engine. Z-12 Works good, lasts a long time. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Subject: Crimpmaster for insulated, non-insulated, and open
barrel
Date: Oct 30, 2009
Hi! I crimped my first wire last night. I have a Crimpaster with a 30-579 die set in it. I hadn't realized that this set is specifically made for insulated terminals. Put the terminal in so it is sticking out of the side with the red, blue, and yellow sizes stamped on it. Squeeze until the ratchet releases, and I have two crimps with one pull, one crimp for the wire and the other for the insulator. Ideal tech support verified this is the correct way, but they didn't know if this die for insulated terminals could be used for uninsulated terminals, also. It looks like the crimp bay for the insulation would be narrower than that for the wire. This means when using it for a non-insulated terminal, the closest crimp to the terminal end ('1st crimp') would be good, but the '2nd crimp' using the insulation bay would smash it too much. Doesn't seem like it would work. I forgot to ask about open barrel terminal crimping with this tool. I've got a few of those, but haven't tried any crimping yet. Ideal lists part #30-586 for a 'non-insulated open barrel' die and 30-580 for 22-8 AWG non-insulated terminals. Would these work? Seems like I would have been better off just getting a crimper that makes one crimp at a time. Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=270137#270137 ________________________________________________________________________________
Subject: BNC to RG400 connections
Date: Oct 30, 2009
I'm ready to run the coax in the RV-7 now. Does anyone have any helpful comments regarding attaching BNC connectors to RG400 or similar. I have heard that crimp-on connectors are not desired compared to solder...is this bum info? Also, what tools are recommended for stripping/crimping coax? Thanks! Wade Roe EAA 557 RV-7 in progress Aeronca Champ flying ________________________________________________________________________________
Subject: For Sale Samsung I8000 Omnia II $,Apple iPhone 3GS
32GB $210
Date: Oct 30, 2009
BAUERTRANC LIMITED ,We specializes in the distributions of Mobile phones , Laptops , Games , Mobile accessories e.t.c. Our objective is to develop long-term relationships with our customers. To do so, we continuously provide our existing customers new products, advanced designs, and patented innovations so that they can stay on the top of their markets. We offer a 10days return policy , and offer a secure payment method . We shipout worldwide through Professional and reliable courier company e.g FEDEX EXPRESS , DHL and UPS within 48hrs of contract sealed . Customers never experience what is called Breach of contract since our operation. Fidelity guarantee our service , our product are 100% international waranty and guarantee . Contact us today for your order at our marketing We look forward in placing your Order with Us and giving you the most competent services as we are Using this Medium to Look For Buyers Of Various Electronics Product we Stock. ORDER INFORMATION : Minimum Order : 1-10 units Shipping Method : FedEx and UPS. Delivery Time : 2-3days Delivery To Your Door Step. Our phones are imported from Finland,Hungary and Singapore; they are factory sealed with original packets with complete accessory, e.g. charger, extra battery and software c d. The phones are sim free and it's never lock to any network, specification: (europeans/usa-specifications) general network gsm 900/gsm 1800/gsm 1900 platform - tri band (gsm900 + 1800 + 1900 MHz: country of manufactured origin: Finland,Hungary and Singapore. 1. Complete accessories(Well packed and sealed in original company box) 2. Unlocked / sim free. 3. Brand new (original manufacturer) box - no copies 4. All phones have English language as default 5. All material (software, manual) - car chargers - home chargers - usb data cables -holsters/belt clips - wireless headsets(bluetooth) -leather and non-leather carrying cases - batteries. If you are interested, forward your questions and inquires to us via email your order and shipping details. we give 1 year warranty for every product sold out to our costumers, our product are company class 1 tested and approved by global standard organization of wireless industries, Brand new merchandise with complete accessories, extra charger and battery. Shipping fees : Free shipping for bulk purchase : FedEx, DHL or UPS Delivery Time : 2 days maximum. Nokia: Nokia 6760 slide$220 Nokia Surge -$215 Nokia N98$200 Nokia N85$190 Nokia N96 16GB $175 Nokia E90 $155 Nokia N97 $195 Nokia N79 $175 Nokia E72 $190 Nokia E71 $180 Nokia E75 $185 Nokia 8800 Sapphire Arte $205 Nokia N93i $125 Nokia 8600 Luna $145 Nokia 5530 XpressMusic $190 Nokia 5800 XPress Music-$185 T-Mobile Sidekick: T-Mobile Sidekick LX 2008$135 T-Mobile Sidekick LX 2009$140 T-Mobile Sidekick LX $105 T-Mobile Shadow $120 T-Mobile G1 $130 T-Mobile Sidekick 3 $100 Juicy Couture Sidekick 2 $80 Apple iPhone: Apple iPhone 3GS 32GB- $210 Apple iPhone 3GS 16GB- $200 Apple iPhone 4GB $100 Apple iPhone 8GB $120 Apple iPhone 16GB $130 Apple iPhone 3G 8GB $140 Apple iPhone 3G 16GB $150 Palm Pre Sprint $220 BlackBerry: BlackBerry Tour 9630 $195 Blackberry Curve 8900 $170 Blackberry Storm 9500 $140 Blackberry Storm 9530 $155 Blackberry Pearl Flip 8220 $105 Blackberry Bold 9000 $135 Blackberry Curve 8320 $125 HTC: HTC Snap $200 HTC Hero -$200 HTC Touch Pro $155 HTC Touch Diamond 2 $200 HTC Touch Diamond $140 HTC Touch Cruise $140 HTC Touch Pro2 $200 HTC Touch Dual $130 HTC Dream $195 HTC Touch Cruise 09 $215 HTC MAX 4G $200 HTC Touch HD $165 HTC Touch 3G $155 HTC Touch Viva $145 HTC S740 $155 Samsung: Samsung I8000 Omnia II $220 Samsung B7320 OmniaPRO $200 Samsung B7300 Omnia LITE$190 Samsung i8910 Omnia HD -$170 Samsung i900 Omnia 16GB $165 Samsung Omnia 8GB -$160 Samsung S8000 Jet Samsung T929 Memoir $195 Samsung T919 Behold $185 Samsung Giorgio Armani P520 $135 Samsung U900 Soul $160 Samsung G800 $155 Samsung F490 $145 Eten: Acer Tempo DX900 -$190 Eten glofiish X610 $135 Eten glofiish V900 $235 Eten glofiish X900 $185 Eten glofiish DX900 $165 Eten glofiish M810 $155 Eten glofiish X650 $145 Eten glofiish M800 $160 Sony Ericsson: Sony Ericsson XPERIA X2 $200 Sony Ericsson Satio --$200 Sony Ericsson Idou$190 Sony Ericsson C510 $185 Sony Ericsson P1 $125 Sony Ericsson W995 -$190 Sony Ericsson C905 $145 Sony Ericsson W960 $130 Sony Ericsson G900 $150 Sony Ericsson XPERIA X1 $175 Sony Ericsson C902 $130 Sony Ericsson W902 $145 LG Phones LG GW550 $205 LG Incite$200 LG GD910$195 LG KS500-$190 LG KF900 Prada$195 LG KC780-$200 LG KP500 Cookie$215 LG KC910 Renoir$210 LG KB770$200 LG CB630 Invision$200 LG KS360-$190 Video Games Console: Playstation: Sony PSP Slim Giga Bundle $105 Sony PlayStation 3 80GB Motorstorm Pack $155 Sony Playstation 3 60GB $140 Sony PlayStation 3 40GB $125 Microsoft Xbox: Xbox 360 Arcade Console $115 Xbox 360 Pro 60GB Console $145 Xbox 360 Elite 120GB Console $165 Nintendo: Nintendo DS Lite $70 Nintendo Wii Console $125 APPLE IPODS: Apple iPod 60GB (Video) New $150usd Apple iPod 30GB (Video) New $140usd Apple ipod 80 GB $140usd Apple iPod U2 SE 20 GB $120usd Apple iPod Photo 60 GB $120usd Apple iPod Mini 6 GB $100usd Apple iPod 20 GB $100usd Apple iPod Photo 30 GB $110usd Apple iPod Nano 4GB New! $90usd Apple iPod Nano 2GB New! $80usd Apple iPod Shuffle 1 GB $80usd Apple iPod Mini 4 GB $70usd Apple iPod Shuffle 512 MB $60usd APPLE LAPTOPS Apple Macbook Air.$600 Apple MacBook (MA700LL/A) Mac Notebook$500usd Apple MacBook Pro (MA611LL/A) Notebook$500usd Apple MacBook (MA254LL/A) Mac Notebook$450usd Apple iBook G3 (M7698LL/A) Mac Notebook..$400usd Apple MacBook Pro (MA609LL/A) Notebook$550usd Apple MacBook Pro (MA600LLA) Notebook$500usd Apple MacBook Pro (MA610LL/A) Notebook$450usd Apple Macbook Pro (885909119400) Notebook..$445usd Company Contact Details: Company Details BAUERTRANC LIMITED Registered #.05218652 Email: bauertra(at)upjs.com Name: Michael Beckwith Read this topic online here: http://forums.matronics.com/viewtopic.php?p=270148#270148 ________________________________________________________________________________
Date: Oct 30, 2009
From: Bill Mauledriver Watson <MauleDriver(at)nc.rr.com>
Subject: Re: BNC to RG400 connections
I just finished doing a set of these per Bob's pics and articles on his site. For example: http://aeroelectric.com/articles/bnccrimp.pdf (I think that is pre-RG400 cable) Recommend that you search around on his site under strippers (3 blades) and crimpers for coax. Then you'll have some more specific questions. Wade Roe wrote: > > I'm ready to run the coax in the RV-7 now. Does anyone have any helpful > comments regarding attaching BNC connectors to RG400 or similar. I have > heard that crimp-on connectors are not desired compared to solder...is > this bum info? > > Also, what tools are recommended for stripping/crimping coax? > > Thanks! > > > Wade Roe > > EAA 557 > RV-7 in progress > Aeronca Champ flying > > > ________________________________________________________________________________
Date: Oct 30, 2009
Crimping works fine if it is done well. When I bought my RG-400 connectors from B and C they provide a diagram showing what dimensions to strip the sheath, shielding and central conductor to. I think I used an Ideal crimper which was about $30. I've talked to the tower and tested the ELT so far. Haven't flown yet, though. On Fri, Oct 30, 2009 at 11:45 AM, Wade Roe wrote: > > I'm ready to run the coax in the RV-7 now. Does anyone have any helpful > comments regarding attaching BNC connectors to RG400 or similar. I have > heard that crimp-on connectors are not desired compared to solder...is > this bum info? > > Also, what tools are recommended for stripping/crimping coax? > > Thanks! > > > Wade Roe > > EAA 557 > RV-7 in progress > Aeronca Champ flying > > -- Tom Sargent ________________________________________________________________________________
Date: Oct 30, 2009
Crimping works fine if it is done well. I work at a large observatory and we build a lot of electronic stuff here with lots of coaxes. All our BNC's are crimped. When I bought my RG-400 connectors from B and C they provided a diagram showing what dimensions to strip the sheath, shielding and central conductor to. I think I used an Ideal crimper which was about $30. I've talked to the tower and tested the ELT so far and it all seems to work. Haven't flown yet, though. On Fri, Oct 30, 2009 at 11:45 AM, Wade Roe wrote: > > I'm ready to run the coax in the RV-7 now. Does anyone have any helpful > comments regarding attaching BNC connectors to RG400 or similar. I have > heard that crimp-on connectors are not desired compared to solder...is > this bum info? > > Also, what tools are recommended for stripping/crimping coax? > > Thanks! > Wade Roe > > EAA 557 > RV-7 in progress > Aeronca Champ flying > -- Tom Sargent ________________________________________________________________________________
Date: Oct 30, 2009
At 01:45 PM 10/30/2009, you wrote: > >I'm ready to run the coax in the RV-7 now. Does anyone have any helpful >comments regarding attaching BNC connectors to RG400 or similar. I have >heard that crimp-on connectors are not desired compared to solder...is >this bum info? > >Also, what tools are recommended for stripping/crimping coax? Crimping the right connector with the right tool is the preferred process. NOBODY solders them any more if it can be avoided. See: http://www.aeroelectric.com/articles/coaxconn/coaxconn.html http://www.aeroelectric.com/articles/Coax_Stripper/coaxstrip.html You can get tools like this http://www.aeroelectric.com/Pictures/Tools/Crimp_Tools/rct-2.jpg from http://bandc.biz http://steinair.com/tools.htm You need a .213" hex die and a .068" square die in the tool for installing the connectors illustrated and offered on their websites. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Oct 30, 2009
Subject: Re: Crimpmaster for insulated, non-insulated, and
open barrel At 12:58 PM 10/30/2009, you wrote: > >Hi! > >I crimped my first wire last night. I have a Crimpaster with a >30-579 die set in it. I hadn't realized that this set is >specifically made for insulated terminals. Put the terminal in so it >is sticking out of the side with the red, blue, and yellow sizes >stamped on it. Squeeze until the ratchet releases, and I have two >crimps with one pull, one crimp for the wire and the other for the insulator. > >Ideal tech support verified this is the correct way, but they didn't >know if this die for insulated terminals could be used for >uninsulated terminals, also. It looks like the crimp bay for the >insulation would be narrower than that for the wire. This means when >using it for a non-insulated terminal, the closest crimp to the >terminal end ('1st crimp') would be good, but the '2nd crimp' using >the insulation bay would smash it too much. Doesn't seem like it would work. > >I forgot to ask about open barrel terminal crimping with this tool. >I've got a few of those, but haven't tried any crimping yet. > >Ideal lists part #30-586 for a 'non-insulated open barrel' die and >30-580 for 22-8 AWG non-insulated terminals. Would these work? Seems >like I would have been better off just getting a crimper that makes >one crimp at a time. EACH tool's die needs to be tailored to EACH terminal's crimping requirements. No single tool installs insulated, uninsulated, and open-barrel terminals. See various illustrated articles on http://aeroelectric.com . . . Uninsulated terminals are recommended ONLY for fat wires where you'll want to ADD insulation support with beefy heatshink after crimping or soldering the terminal. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Oct 30, 2009
Subject: Re: BNC and RG 174
At 05:34 AM 10/24/2009, you wrote: ><Gilles.Thesee@ac-grenoble.fr> > >Bob and all, > >Some time ago you published a page on connecting a regular (big) BNC >connector to a skinny coax cable (RG 174 ?). >To date I've been unable to retrieve the document. >Could you point me in the right direction ? I found the article that speaks to adding BNC connectors to the ends of smaller diameter wires. It's at: http://www.aeroelectric.com/articles/RG58/RG58.html Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Oct 30, 2009
Hi, Me Laracroft, The diode will heat when the ebus is powered through it. To observe this, the ebus alternate feed switch needs to be open, and power (battery) directly to the main bus. so I am agree with Mike. -------- R4games Read this topic online here: http://forums.matronics.com/viewtopic.php?p=270206#270206 ________________________________________________________________________________
Subject: Re: Crimpmaster for insulated, non-insulated, and open
barrel
Date: Oct 31, 2009
Thanks, Bob :-) I would have used insulated terminals, but they don't make faston insulated terminals for 8AWG. I already have the wire, so need to go with what they make, uninsulated open barrel faston receptacles with separate ears for wire and insulation. I've seen the open barrel crimpers with butt-cheek pockets, but I don't have very many of these connections, so I'm thinking I could use my cheapo GB crimper. It only goes down to 10awg, but since it's not a cycling crimper, it might work. Or I could bend the tabs over individually using a pair of pliers. Another issue I have is figuring out which end goes where with the Crimpaster for PIDG terminals. The left side of the tool have dies shaped like flying saucers and are coded with numbers and colors for size. The right side ones are more elliptical. The right side also is a little narrower than the left. So the terminal sticks out the left side and the wire goes in from the right? -------- Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=270247#270247 Attachments: http://forums.matronics.com//files/gb_cheapo_crimper_836.jpg http://forums.matronics.com//files/crimpmaster_right_side_270.jpg http://forums.matronics.com//files/crimpmaster_left_side_383.jpg ________________________________________________________________________________
Subject: Re: KIS-List: Aircraft electric question
Date: Oct 31, 2009
10/31/2009 Hello Al, You wrote: "When wiring for the systems that are controlled by switches in the cockpit such as lighting, flaps, pitot heat, do you run the full amperage through the 20A switches or should the switches trip relays to handle the larger current?" If the switch is capable enough to handle the load it is simpler, and with less parts count, to control the items directly with the switch. So you start out with the switch rating and the current draw (including surge) of the item to be controlled. If you reach the point where the switch rating is inadequate then it is time to start thinking in terms of relays. Of course the wire guage and circuit protection device (fuses or circuit breakers) must also be appropriately sized. I know that there is a tendency among builders to shy away from the electrical aspects of the building for a long time. It has been my experience that once a builder gets his feet wet in this arena he almost invariable realizes that this electrical stuff is fun, educational, and very satisfying to work with. If you don't already have a copy of Bob Nuckoll's book "The Aeroelectrical Connection", -- see here: https://matronics.com/aeroelectric/Catalog/pub/pub.html#P-Book you should buy one or borrow one locally. You may rebel at first look and say that this is far more than I need to know or want to know about this subject -- fair enough, then treat it as reference material. It is not a cook book per se, but that book plus the folks on the matronics aeroelectric-list will do more towards keeping your electrical system on track than any two other sources in the world. I am going to shoot this over to the folks on the aeroelectric-list and see how they react. 'OC' Says: "The best investment we can make is the effort to gather and understand knowledge." PS: Please let me display one personal bias here. There are various magic electrical boxes available commercially. The fundamental theme seems to run along the line of "if you buy our box then all of your electrical problems will be solved and you don't really need to learn anything or do anything except just connect it up." Frequently the customers who go that route wind up concluding that the magic box does not do exactly what they want it to and they fish around for some sort of modification. ================================================ ----- Original Message ----- From: "Alfred Rosa" <76papa(at)dishmail.net> Sent: Saturday, October 31, 2009 3:39 PM Subject: KIS-List: Aircraft electric question > --> KIS-List message posted by: Alfred Rosa <76papa(at)dishmail.net> > > I know I could go to aeroelectric with this but they tend to talk too > technical for me. My question is simple and maybe even stupid: When > wiring for the systems that are controlled by switches in the cockpit > such as lighting, flaps, pitot heat, do you run the full amperage > through the 20A switches or should the switches trip relays to handle the > larger current? > Not that I'm doing the wiring now but it's something I've wondered about > for a long time. > > Al ________________________________________________________________________________
Date: Oct 31, 2009
and open barrel At 12:54 PM 10/31/2009, you wrote: > >Thanks, Bob :-) > >I would have used insulated terminals, but they don't make faston >insulated terminals for 8AWG. 8AWG is too large for fast-on. I don't recommend this technology for anything larger than 12AWG/20A in airplanes. The largest fuse/wire combo I'd recommend on a fuse-block is 15Amps/14AWG. This is a de-rating thing to accommodate the aircraft environs. > I already have the wire, so need to go with what they make, > uninsulated open barrel faston receptacles with separate ears for > wire and insulation. I've seen the open barrel crimpers with > butt-cheek pockets, but I don't have very many of these > connections, so I'm thinking I could use my cheapo GB crimper. It > only goes down to 10awg, but since it's not a cycling crimper, it > might work. Or I could bend the tabs over individually using a > pair of pliers. Where are you needing to put an 8AWG to a fast-on tab? 8AWG implies loads upwards of 40A. I'd stay in threaded fastener and ring terminal world for this much current. >Another issue I have is figuring out which end goes where with the >Crimpaster for PIDG terminals. The left side of the tool have dies >shaped like flying saucers and are coded with numbers and colors for >size. The right side ones are more elliptical. The right side also >is a little narrower than the left. So the terminal sticks out the >left side and the wire goes in from the right? This is explained in the last panel of: http://www.aeroelectric.com/articles/CrimpTools/crimptools.html Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
barrel
Date: Oct 31, 2009
> Where are you needing to put an 8AWG to a fast-on tab? 8AWG > implies loads upwards of 40A. Sonex plans show using 8AWG for the power distribution circuit. I have a Jabiru 3300 that puts out between 13A and 20A, depending on which set of their numbers you use. The two alternator leads end in female fastons. Can't see the gauge, but they're a little bigger compared to a piece of 12awg wire with insulation when held next to it. The voltage regulator has 6 wires, all with faston terminals. The size of these wires are also covered, but they look to be about the same size as my 12AWG wire. So I'm thinking it would be best to get 12AWG for this circuit and use fastons. It would be ~3' between the filter capacitor and my main bus, both of which have posts. Would 10AWG be better for this section? > This is explained in the last panel of: > > http://www.aeroelectric.com/articles/CrimpTools/crimptools.html I saw this in that article: As a general rule, tools with unsymetrical dies will have a smaller, closed-die cross section on the wire grip side. which sounds like it would apply to the Crimpmaster. -------- Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=270282#270282 ________________________________________________________________________________
Subject: Battery Contactor Coil Wiring
Date: Oct 31, 2009
Hi! I've got a Tyco EV200 battery contactor. In addition to the two high current posts, it has two small wires labelled coil positive and coil negative. The Z diagrams show just one wire between the switch and battery contactor. In my case, seems like this would be the coil positive. So where would the coil negative wire be connected? -------- Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=270293#270293 Attachments: http://forums.matronics.com//files/tyco_ev200_battery_contactor_wiring_664.pdf ________________________________________________________________________________
Date: Oct 31, 2009
It probably drives a light to tell you that the contactor is closed. This can be helpful to prevent starter damage. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of messydeer Sent: Saturday, October 31, 2009 6:50 PM Subject: AeroElectric-List: Battery Contactor Coil Wiring Hi! I've got a Tyco EV200 battery contactor. In addition to the two high current posts, it has two small wires labelled coil positive and coil negative. The Z diagrams show just one wire between the switch and battery contactor. In my case, seems like this would be the coil positive. So where would the coil negative wire be connected? -------- Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=270293#270293 Attachments: http://forums.matronics.com//files/tyco_ev200_battery_contactor_wiring_664.p df ________________________________________________________________________________
Date: Oct 31, 2009
Subject: Re: Battery Contactor Coil Wiring
Hi Dan, Take a look at how the switch is wired. Most likely it connects the wire to the contactor to ground. In this case, the red wire can be connected directly to the large terminal that goes to the battery. Connect the black wire to the lead to the switch. You don't need the diode when using the EV200. If the switch connects the wire on the contactor to a bus (12V), then the black wire would be connected to ground. Bob W. "messydeer" wrote: > > Hi! > > I've got a Tyco EV200 battery contactor. In addition to the two high current posts, it has two small wires labelled coil positive and coil negative. The Z diagrams show just one wire between the switch and battery contactor. In my case, seems like this would be the coil positive. So where would the coil negative wire be connected? > > -------- > Dan > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=270293#270293 > > > > > Attachments: > > http://forums.matronics.com//files/tyco_ev200_battery_contactor_wiring_664.pdf > > > > > > > -- N93BD - Rotary Powered BD-4 - http://www.bob-white.com Now Rotary Powered Alpine http://www.youtube.com/watch?v=FwceNc2ydN8 Cables for your rotary installation - http://roblinstores.com/ ________________________________________________________________________________
Date: Oct 31, 2009
Thanks, but this is a battery contactor. Seems like what you're saying might work for starter contactor, or am I missing something? -------- Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=270306#270306 ________________________________________________________________________________
Date: Oct 31, 2009
You are not missing anything, I mis read the post. Sorry -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of messydeer Sent: Saturday, October 31, 2009 7:31 PM Subject: AeroElectric-List: Re: Battery Contactor Coil Wiring Thanks, but this is a battery contactor. Seems like what you're saying might work for starter contactor, or am I missing something? -------- Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=270306#270306 ________________________________________________________________________________
Date: Nov 01, 2009
Subject: PLEASE READ - Matronics Email List Fund Raiser During
November! Dear Listers, Each November I hold a PBS-like fund raiser to support the continued operation and upgrade of the List services at Matronics. It's solely through the Contributions of List members that these Matronics Lists are possible. There is NO advertising to support the Lists. You might have noticed the conspicuous lack of flashing banners and annoying pop-ups on the Matronics Email List email messages and web site pages such as the Matronics List Forums ( http://forums.matronics.com ), the List Wiki ( http://wiki.matronics.com), or other related pages such as the List Search Engine ( http://www.matronics.com/search ), the List Browser ( http://www.matronics.com/listbrowse ), etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisements. During the month of November I will be sending out List messages every couple of days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages. The Fund Raiser is only financial support mechanism I have to pay all of the bills associated with running these lists. Your personal Contribution counts! Once again, this year I've got a terrific line up of free gifts to go along with the various Contribution levels. Most all of these gifts have been provided by some of the vary members and vendors that you'll find on Matronics Lists and have been either donated or provided at substantially discounted rates. This year, these generous people include Bob Nuckolls of the AeroElectric Connection (http://www.aeroelectric.com/), Andy Gold of the Builder's Bookstore (http://www.buildersbooks.com/), and Jon Croke of HomebuiltHELP (http://www.homebuilthelp.com/). These are extremely generous guys and I encourage you to visit their respective web sites. Each one offers a unique and very useful aviation-related product line. I would like publicly to thank Bob, Andy, and Jon for their generous support of the Lists again this year!! You can make your List Contribution using any one of three secure methods this year including using a credit card, PayPal, or by personal check. All three methods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure site below: http://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 01, 2009
Hi Dan, Connect the positive coil wire to the big terminal on the EV200 that goes to the battery. Connect the negative coil wire to the master switch. When turned on, the master switch will connect the negative coil wire to ground. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=270411#270411 ________________________________________________________________________________
Subject: Relays etc
Date: Nov 01, 2009
Al, First of all, I heartily endorse OCBaker's remarks about the AeroConnection book, as I think do most of us. Second, as a short cut to some thinking, I made a habit of checking with how the auto industry wired things - you know if they had a device too rich in current to switch alone, they used relays and the same principle applies. I have never (well once) had to change a car relay since 1948 (and it was corroded) so I guess my aircraft device (homebuilt) could stand it. Bosch relays seem very reliable. Just an idea, Ferg Europa A064 wiring wiring wiring ________________________________________________________________________________
Date: Nov 01, 2009
Thanks, guys :-) 2 here and 1 by private email makes the score 3-0 for doing this. So I'll crimp a ring onto the red wire and hang it on the positive post of the contactor and splice the black wire to my master switch. There must be a reason they didn't wire the positive coil lead internally to the post. This is the only contactor I've dealt with. Are they all like this? -------- Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=270440#270440 ________________________________________________________________________________
From: "Bob McCallum" <robert.mccallum2(at)sympatico.ca>
Date: Nov 01, 2009
Dan; No not all relays or contactors are wired like this. They are all wired, however, to serve whatever applications they are designed for. If you purchase a contactor intended for aircraft master relay use then chances are it will be wired with the internal jumper. The EV200 you're referring to is not a battery contactor per se but a generic device used in tens of thousands of different applications and wired in many different ways. Use as an aircraft master relay is an infinitesimally small percentage of their total sales and therefore the design will not take that into account because it would limit some of the other applications for which it is used. You have to understand how to wire a device such as this (or any other) for the way your application uses it, which is what others have explained. Positive to battery, negative through switch to ground. The rationale is explained in "the book". Following this list, asking questions, and reading "the book" will soon result in a good understanding of the not so mysterious mysteries behind the functioning of many things electrical. There are other ways of wiring this relay to function in your application by the way, but the "standard accepted aircraft practice" is as described by the three responses you refer to. Good luck on the road to understanding. This is a great place to learn. P.S. don't forget to support Matt's efforts via his annual fundraiser. Bob McC > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric- > list-server(at)matronics.com] On Behalf Of messydeer > Sent: Sunday, November 01, 2009 10:38 AM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Re: Battery Contactor Coil Wiring > > > Thanks, guys :-) > > 2 here and 1 by private email makes the score 3-0 for doing this. So I'll crimp a > ring onto the red wire and hang it on the positive post of the contactor and splice > the black wire to my master switch. > > There must be a reason they didn't wire the positive coil lead internally to the > post. This is the only contactor I've dealt with. Are they all like this? > > -------- > Dan ________________________________________________________________________________
Date: Nov 01, 2009
Subject: magnetometer location
I'm using 2 EFIS units and could connect both to the same magnetometer but wanted to have backup. Is there any problem mounting them next to each other side by side. Will they interfere or cross talk with each other? ________________________________________________________________________________
Date: Nov 01, 2009
and open barrel At 05:47 PM 10/31/2009, you wrote: > > > > Where are you needing to put an 8AWG to a fast-on tab? 8AWG > > implies loads upwards of 40A. > > >Sonex plans show using 8AWG for the power distribution circuit. I >have a Jabiru 3300 that puts out between 13A and 20A, depending on >which set of their numbers you use. > >The two alternator leads end in female fastons. Can't see the gauge, >but they're a little bigger compared to a piece of 12awg wire with >insulation when held next to it. > >The voltage regulator has 6 wires, all with faston terminals. The >size of these wires are also covered, but they look to be about the >same size as my 12AWG wire. > >So I'm thinking it would be best to get 12AWG for this circuit and >use fastons. It would be ~3' between the filter capacitor and my >main bus, both of which have posts. Would 10AWG be better for this section? 20A is handled nicely on 12AWG wire which will fit into a yellow PIDG faston. >As a general rule, tools with unsymetrical dies will have a smaller, >closed-die cross section on the wire grip side. > >which sounds like it would apply to the Crimpmaster. Correct Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Nov 01, 2009
Subject: Re: magnetometer location
At 11:59 AM 11/1/2009, you wrote: > >I'm using 2 EFIS units and could connect both to the same >magnetometer but wanted to have backup. Is there any problem >mounting them next to each other side by side. Will they interfere >or cross talk with each other? magnetometers don't interfere with each other but their measurement accuracy can be polluted with stray fields from current in wires and nearby magnetic materials. At Beech we used to mount these things out in the wing but located about 12" away from wiring to the tip. Your strobe wiring is magnetically compatible since all outbound electrons are balanced by inbound electrons in the same bundle. Note that the shield on the strobe wire has nothing to do with the magnetics. The nav light wiring could run close to the magnetometers if it were a twisted pair that takes outbound and inbound electrons past any point closer than say 12" to the magnetometer. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Nov 01, 2009
Robert L. Nuckolls, III a crit : > > > At 05:34 AM 10/24/2009, you wrote: > > I found the article that speaks to adding BNC > connectors to the ends of smaller diameter wires. > It's at: > > http://www.aeroelectric.com/articles/RG58/RG58.html Bob, Thanks for retrieving the article. Best regards, -- Gilles http://contrails.free.fr ________________________________________________________________________________
Subject: Re: p-lead signal conditioning or tach gen usage
Date: Nov 01, 2009
Bob: Put a scope on the tach gen output. The situation is the signal from the tach gen goes to a 5.1 V zener diode, then to a comparator against a reference voltage to generate a square wave. Attached is the picture of the waveform at low rpm (approx 800). Note the spikes in the wave. Also, the voltage is near the zener voltage so the zener never gets driven into breakdown so that is why the unit has a flakey rpm reading at low rpm. So, would the waveform squaring circuit you posted in an earlier post work to square this waveform? If so, I have 28 VDC available in the aircraft. I'd need to use a 28-5 V converter chip to get the 5 VDC on the collector as you drew it. Any suggestions for this? Craig Read this topic online here: http://forums.matronics.com/viewtopic.php?p=270501#270501 Attachments: http://forums.matronics.com//files/tach_gen_800_rpm_143.jpg ________________________________________________________________________________
Date: Nov 01, 2009
Bob: Forgot to mention that at full RPM (2400) the tach gen signal is a bit more than 40 v peak to peak. Craig Read this topic online here: http://forums.matronics.com/viewtopic.php?p=270508#270508 ________________________________________________________________________________
Date: Nov 01, 2009
Subject: Re: Relays etc
Second, as a short cut to some thinking, I made a habit of checking with how the auto industry wired things - you know if they had a device too rich in current to switch alone, they used relays and the same principle applies. I have never (well once) had to change a car relay since 1948 (and it was corroded) so I guess my aircraft device (homebuilt) could stand it. Bosch relays seem very reliable. Just an idea, An astute and accurate observation my friend. As a rule, relays are considered to be some of the least reliable devices in terms of failures per flight hour. Indeed compared to transistors, capacitors and such, they are way down on the totem pole. So when you're working on a 200 ton ATC aircraft with miles of wiring and tons of electro-whizzies that get exercised 15 hrs a day for weeks at a time, one minimizes the numbers of relays and picks them carefully. Down-time on these aircraft is measured in thousands of dollars per day. In the automotive world, the cost of ownership and magnitude of risk due to failure is much lower than for complex aircraft. Light airplanes are certainly higher risk but failure tolerant design can buffer that risk. Hence, relays need not be avoided where they make sense. One doesn't want to put an ugly-beefy toggle switch in right next to an ordinary 7 - 10A device just to accommodate some heavier load. Relay buffering is a good thing to consider . . . solid state relays even better. Fortunately for us, only things like pitot heat (30A inrush), large landing lights (30-50A inrush) and perhaps hydraulic pump motors (100A inrush) are devices that give pause for extra attention. Relays like this . . . http://tinyurl.com/yhrqnkz are designed and tested to survive under the hood of an automobile. There are other examples in the same family of products. They're made on totally automated machines and are reasonably priced. Once the system demands push much above 7A or offer extra-ordinary inrush loads, a relay may be an ingredient that fits your recipe for success quite well. Having said that, let's talk about any particular situation where you think the relay is a potential solution to a design goal. I about dropped my teeth when I saw this picture the first time: http://aeroelectric.com/Pictures/Relays/TooManyRelays.jpg . . . and these were part of an electrically dependent engine's ignition, fuel and controls system! "One is good" does not morph into "21 is better." Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Nov 01, 2009
Try this site for a better price ie $2.49 ea _https://www.surpluscenter.com/item.asp?UID 09110121075049&catname=&qty=1& item=11-2275_ (https://www.surpluscenter.com/item.asp?UID 09110121075049&catname=&qty=1&item=11-2275) They have lots of other goodies also Dick In a message dated 11/1/2009 4:44:00 P.M. Pacific Standard Time, nuckolls.bob(at)aeroelectric.com writes: Second, as a short cut to some thinking, I made a habit of checking with how the auto industry wired things - you know if they had a device too rich in current to switch alone, they used relays and the same principle applies. I have never (well once) had to change a car relay since 1948 (and it was corroded) so I guess my aircraft device (homebuilt) could stand it. Bosch relays seem very reliable. Just an idea, An astute and accurate observation my friend. As a rule, relays are considered to be some of the least reliable devices in terms of failures per flight hour. Indeed compared to transistors, capacitors and such, they are way down on the totem pole. So when you're working on a 200 ton ATC aircraft with miles of wiring and tons of electro-whizzies that get exercised 15 hrs a day for weeks at a time, one minimizes the numbers of relays and picks them carefully. Down-time on these aircraft is measured in thousands of dollars per day. In the automotive world, the cost of ownership and magnitude of risk due to failure is much lower than for complex aircraft. Light airplanes are certainly higher risk but failure tolerant design can buffer that risk. Hence, relays need not be avoided where they make sense. One doesn't want to put an ugly-beefy toggle switch in right next to an ordinary 7 - 10A device just to accommodate some heavier load. Relay buffering is a good thing to consider . . . solid state relays even better. Fortunately for us, only things like pitot heat (30A inrush), large landing lights (30-50A inrush) and perhaps hydraulic pump motors (100A inrush) are devices that give pause for extra attention. Relays like this . . . _http://tinyurl.com/yhrqnkz_ (http://tinyurl.com/yhrqnkz) are designed and tested to survive under the hood of an automobile. There are other examples in the same family of products. They're made on totally automated machines and are reasonably priced. Once the system demands push much above 7A or offer extra-ordinary inrush loads, a relay may be an ingredient that fits your recipe for success quite well. Having said that, let's talk about any particular situation where you think the relay is a potential solution to a design goal. I about dropped my teeth when I saw this picture the first time: _http://aeroelectric.com/Pictures/Relays/TooManyRelays.jpg _ (http://aeroelectric.com/Pictures/Relays/TooManyRelays.jpg) . . . and these were part of an electrically dependent engine's ignition, fuel and controls system! "One is good" does not morph into "21 is better." Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- (http://www.aeroelectric.com/) (http://www.buildersbooks.com/) (http://www.homebuilthelp.com/) (http://www.matronics.com/contribution) (http://www.matronics.com/Navigator?AeroElectric-List) ________________________________________________________________________________
Date: Nov 01, 2009
Dick, Thanks for the web link..... David ----- Original Message ----- From: RGent1224(at)aol.com To: aeroelectric-list(at)matronics.com Sent: Sunday, November 01, 2009 7:10 PM Subject: Re: AeroElectric-List: Relays etc Try this site for a better price ie $2.49 ea https://www.surpluscenter.com/item.asp?UID 09110121075049&catname=& qty=1&item=11-2275 They have lots of other goodies also Dick In a message dated 11/1/2009 4:44:00 P.M. Pacific Standard Time, nuckolls.bob(at)aeroelectric.com writes: Second, as a short cut to some thinking, I made a habit of checking with how the auto industry wired things - you know if they had a device too rich in current to switch alone, they used relays and the same principle applies. I have never (well once) had to change a car relay since 1948 (and it was corroded) so I guess my aircraft device (homebuilt) could stand it. Bosch relays seem very reliable. Just an idea, An astute and accurate observation my friend. As a rule, relays are considered to be some of the least reliable devices in terms of failures per flight hour. Indeed compared to transistors, capacitors and such, they are way down on the totem pole. So when you're working on a 200 ton ATC aircraft with miles of wiring and tons of electro-whizzies that get exercised 15 hrs a day for weeks at a time, one minimizes the numbers of relays and picks them carefully. Down-time on these aircraft is measured in thousands of dollars per day. In the automotive world, the cost of ownership and magnitude of risk due to failure is much lower than for complex aircraft. Light airplanes are certainly higher risk but failure tolerant design can buffer that risk. Hence, relays need not be avoided where they make sense. One doesn't want to put an ugly-beefy toggle switch in right next to an ordinary 7 - 10A device just to accommodate some heavier load. Relay buffering is a good thing to consider . . . solid state relays even better. Fortunately for us, only things like pitot heat (30A inrush), large landing lights (30-50A inrush) and perhaps hydraulic pump motors (100A inrush) are devices that give pause for extra attention. Relays like this . . . http://tinyurl.com/yhrqnkz are designed and tested to survive under the hood of an automobile. There are other examples in the same family of products. They're made on totally automated machines and are reasonably priced. Once the system demands push much above 7A or offer extra-ordinary inrush loads, a relay may be an ingredient that fits your recipe for success quite well. Having said that, let's talk about any particular situation where you think the relay is a potential solution to a design goal. I about dropped my teeth when I saw this picture the first time: http://aeroelectric.com/Pictures/Relays/TooManyRelays.jpg . . . and these were part of an electrically dependent engine's ignition, fuel and controls system! "One is good" does not morph into "21 is better." Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ttp://www.aeroelectric.com/">www.aeroelectric.com m/ href="http://www.buildersbooks.com/">www.buildersbooks.com "http://www.homebuilthelp.com/">www.homebuilthelp.com tp://www.matronics.com/contribution">http://www.matronics.com/contributio n List href="http://www.matronics.com/Navigator?AeroElectric-List">http://www. matronics.com/Navigator?AeroElectric-List ms.matronics.com/">http://forums.matronics.com ________________________________________________________________________________
Date: Nov 02, 2009
At 04:59 PM 11/1/2009, you wrote: > > >Bob: > >Put a scope on the tach gen output. The situation is the signal >from the tach gen goes to a 5.1 V zener diode, then to a comparator >against a reference voltage to generate a square wave. > >Attached is the picture of the waveform at low rpm (approx >800). Note the spikes in the wave. Also, the voltage is near the >zener voltage so the zener never gets driven into breakdown so that >is why the unit has a flakey rpm reading at low >rpm. Agreed. >So, would the waveform squaring circuit you posted in an earlier >post work to square this waveform? If so, I have 28 VDC available >in the aircraft. I'd need to use a 28-5 V converter chip to get the >5 VDC on the collector as you drew it. Any suggestions for this? I don't recall exactly what I sent you earlier but this is probably similar. Emacs! This squaring circuit has a +0.6v threshold. Since your 80mS, 5v trashy square wave goes above and below ground, this will square it up nicely. The diode keeps the negative excursions at high RPM from going exceeding the zener breakdown threshold for the NPN device. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Nov 02, 2009
Judson, I recently mounted two of the Dynon type next to each other behind the panel. The dealer said you "might" get away with it. Way too much interference with stuff. they were way off. I then set them on the top of the panel just to see the difference - wow, right on! ok, get them out of the panel and over to the wings or maybe behind the seat. to keep them separate I mounted them in the stub wing area on each side of the Legacy. you must be very careful they are mounted at the same angle as the unit. Put them where they won't get wet and where you have access to get at them for maintenance. It's all about maintenance. I find they are sensitive to everything, e.g. spars, landing gear, pliers in your pocket etc. Get or make an extension cable (easy) and give them their own space. You'll enjoy the better accuracy. Glenn -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Judson Porter Sent: Sunday, November 01, 2009 12:59 PM Subject: AeroElectric-List: magnetometer location I'm using 2 EFIS units and could connect both to the same magnetometer but wanted to have backup. Is there any problem mounting them next to each other side by side. Will they interfere or cross talk with each other? ________________________________________________________________________________
Date: Nov 02, 2009
David No Problem that's what we're here for Dick In a message dated 11/1/2009 9:38:32 P.M. Pacific Standard Time, skywagon(at)charter.net writes: Dick, Thanks for the web link..... David ----- Original Message ----- From: _RGent1224(at)aol.com_ (mailto:RGent1224(at)aol.com) (mailto:aeroelectric-list(at)matronics.com) Sent: Sunday, November 01, 2009 7:10 PM Subject: Re: AeroElectric-List: Relays etc Try this site for a better price ie $2.49 ea _https://www.surpluscenter.com/item.asp?UID 09110121075049&catname=&qty=1& item=11-2275_ (https://www.surpluscenter.com/item.asp?UID 09110121075049&catname=&qty=1&item=11-2275) They have lots of other goodies also Dick In a message dated 11/1/2009 4:44:00 P.M. Pacific Standard Time, _nuckolls.bob(at)aeroelectric.com_ (mailto:nuckolls.bob(at)aeroelectric.com) writes: Second, as a short cut to some thinking, I made a habit of checking with how the auto industry wired things - you know if they had a device too rich in current to switch alone, they used relays and the same principle applies. I have never (well once) had to change a car relay since 1948 (and it was corroded) so I guess my aircraft device (homebuilt) could stand it. Bosch relays seem very reliable. Just an idea, An astute and accurate observation my friend. As a rule, relays are considered to be some of the least reliable devices in terms of failures per flight hour. Indeed compared to transistors, capacitors and such, they are way down on the totem pole. So when you're working on a 200 ton ATC aircraft with miles of wiring and tons of electro-whizzies that get exercised 15 hrs a day for weeks at a time, one minimizes the numbers of relays and picks them carefully. Down-time on these aircraft is measured in thousands of dollars per day. In the automotive world, the cost of ownership and magnitude of risk due to failure is much lower than for complex aircraft. Light airplanes are certainly higher risk but failure tolerant design can buffer that risk. Hence, relays need not be avoided where they make sense. One doesn't want to put an ugly-beefy toggle switch in right next to an ordinary 7 - 10A device just to accommodate some heavier load. Relay buffering is a good thing to consider . . . solid state relays even better. Fortunately for us, only things like pitot heat (30A inrush), large landing lights (30-50A inrush) and perhaps hydraulic pump motors (100A inrush) are devices that give pause for extra attention. Relays like this . . . _http://tinyurl.com/yhrqnkz_ (http://tinyurl.com/yhrqnkz) are designed and tested to survive under the hood of an automobile. There are other examples in the same family of products. They're made on totally automated machines and are reasonably priced. Once the system demands push much above 7A or offer extra-ordinary inrush loads, a relay may be an ingredient that fits your recipe for success quite well. Having said that, let's talk about any particular situation where you think the relay is a potential solution to a design goal. I about dropped my teeth when I saw this picture the first time: _http://aeroelectric.com/Pictures/Relays/TooManyRelays.jpg _ (http://aeroelectric.com/Pictures/Relays/TooManyRelays.jpg) . . . and these were part of an electrically dependent engine's ignition, fuel and controls system! "One is good" does not morph into "21 is better." Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ttp://www.aeroelectric.com/">www.aeroelectric.com m/ href="http://www.buildersbooks.com/">www.buildersbooks.com "http://www.homebuilthelp.com/">www.homebuilthelp.com tp://www.matronics.com/contribution">http://www.matronics.com/contribution List href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics. com/Navigator?AeroElectric-List ms.matronics.com/">http://forums.matronics.com href="http://www.aeroelectric.com">www.aeroelectric.com href="http://www.buildersbooks.com">www.buildersbooks.com href="http://www.homebuilthelp.com">www.homebuilthelp.com href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator? AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List href="http://forums.matronics.com">http://forums.matronics.com (http://www.aeroelectric.com/) (http://www.buildersbooks.com/) (http://www.homebuilthelp.com/) (http://www.matronics.com/contribution) (http://www.matronics.com/Navigator?AeroElectric-List) ________________________________________________________________________________
Date: Nov 02, 2009
Bob: I can eliminate the comparator circuit if I get the output of the squaring circuit to 5 VDC (TTL level). My thought is to use a Texas Instrument UA7805 Positive Voltage Regulator and connect it to an available 12VDC source in the aircraft. This should give me a stable 5.0 voltage source. At 5.0 VDC, the prior squaring circuit diagram used a 4.7K resistor on the collector to limit the current when the transistor is off. This should square off the signal and provide a TTL level input to the EFIS system in the aircraft. I can build this on a breadboard and test it in the lab and use a variable speed power drill to rotate the tach gen. If the above sounds reasonable, I'm off to order the parts from DigiKey. Thanks for all the help and advice. Craig Craig Read this topic online here: http://forums.matronics.com/viewtopic.php?p=270633#270633 ________________________________________________________________________________
Date: Nov 02, 2009
Subject: GPS multiple feeds - how many?
I am building an RV-10, and beginning to assemble and wire a panel. My main GPS is a Garmin 396. I need it to feed my GRT EFIS, a Tru-Trak autopilot, and a 406 MHz ELT. Will I have any problems with impedance matching, or signal degradation if all 3 are fed from the GPS directly? I don't know the input impedances of any of these fed boxes, or what sort of power the Garmin can generate on its RS-232 feed. I read the 2007 post about using a DB25 connector to facilitate the multiple connections, but wonder if one needs a buffer or amplifier of any sort to handle 3 outputs from one. Phil in IL ________________________________________________________________________________
Subject: Re: GPS multiple feeds - how many?
Date: Nov 02, 2009
My Garmin 395, and now a 496, drives a Trutrak autopilot, Argus 5000, and automatic position reporting transmitter perfectly well, without any consideration of impedance compatibility. Consultation with Garmin tech support had indicated that these portable GPS units are expected to drive three devices without degradation of signal. and I can confirm that. I tied together the five pins of a DB9 connector as a "NMEA-bus", and it works well. Kenneth Melvin, N669TJ, RV-9A On Nov 2, 2009, at 7:38 PM, Phil White wrote: > > > > I am building an RV-10, and beginning to assemble and wire a panel. > My main GPS is a Garmin 396. I need it to feed my GRT EFIS, a Tru- > Trak autopilot, and a 406 MHz ELT. Will I have any problems with > impedance matching, or signal degradation if all 3 are fed from the > GPS directly? I don't know the input impedances of any of these fed > boxes, or what sort of power the Garmin can generate on its RS-232 > feed. > I read the 2007 post about using a DB25 connector to facilitate > the multiple connections, but wonder if one needs a buffer or > amplifier of any sort to handle 3 outputs from one. > Phil in IL > > ________________________________________________________________________________
Date: Nov 03, 2009
Subject: November List Fund Raiser
A couple of years ago I implemented an automatic "squelch button" of sorts for the Fund Raiser messages. Here's how it works... As soon as a List member makes a Contribution through the Matronics Fund Raiser web site, he or she will instantly cease to receive these Fund Raiser messages for the rest of the month! Its just that simple. Don't you wish PBS worked that way! :-) I really do appreciate each and every one of your individual Contributions to support the Lists. It is your support that enables me to upgrade the hardware and software that are required to run a List Site such as this one. It also goes to pay for the commercial-grade Internet connection and to pay the huge electric bill to keep the computer gear running and the air conditioner powered on. I run all of the Matronics Email List and Forums sites here locally which allows me to control and monitor every aspect of the system for the utmost in reliably and performance. Your personal Contribution matters because, when combined with other Listers such as yourself, it pays the bills to keep this site up and running. I accept exactly ZERO advertising dollars for the Matronics Lists sites. I can't stand the pop-up ads and all other commercials that are so prevalent on the Internet these days and I particularly don't want to have it on my Email List sites. If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email Lists, please make a Contribution to keep it that way!! http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator [Note that there are certain circumstances where you might still see a Contribution related message. For example, if someone replies to one of the messages, when using the List Browse feature, or when accessing List message via the Forum. The system keys on the given email address and since most of these are anonymous public access methods, there is no simple way to filter them.] ________________________________________________________________________________
From: "gordonrsmith921(at)yahoo.com" <gordonrsmith921(at)yahoo.com>
Date: Nov 03, 2009
Att'n: 'Lectric Bob: You mentioned ". . . solid state relays even better." I recall some time ago that you mentioned that you might design, build, market solid state relays. Is that still a possibility for the future? Gordon smith Read this topic online here: http://forums.matronics.com/viewtopic.php?p=270760#270760 ________________________________________________________________________________
Date: Nov 03, 2009
I have a 396 (not in the '10) and all those other components but I can't answer your question. It occurs to me that a cost effective solution may be to simply add a $150 external GPS from GRT. It can drive at least the EFIS and the AP. And it would be permanently mounted like the EFIS and TT though I'm sure you are planning to 'permanently' mount the 396. Bill "just finishing up the panel and going back to fiberglass" Watson RV10 40605 Phil White wrote: > > I am building an RV-10, and beginning to assemble and wire a panel. > My main GPS is a Garmin 396. I need it to feed my GRT EFIS, a > Tru-Trak autopilot, and a 406 MHz ELT. Will I have any problems with > impedance matching, or signal degradation if all 3 are fed from the > GPS directly? I don't know the input impedances of any of these fed > boxes, or what sort of power the Garmin can generate on its RS-232 feed. > I read the 2007 post about using a DB25 connector to facilitate the > multiple connections, but wonder if one needs a buffer or amplifier of > any sort to handle 3 outputs from one. > Phil in IL > > ________________________________________________________________________________
Date: Nov 03, 2009
At 04:18 PM 11/2/2009, you wrote: > > >Bob: > >I can eliminate the comparator circuit if I get the output of the >squaring circuit to 5 VDC (TTL level). My thought is to use a Texas >Instrument UA7805 Positive Voltage Regulator and connect it to an >available 12VDC source in the aircraft. This should give me a >stable 5.0 voltage source. At 5.0 VDC, the prior squaring circuit >diagram used a 4.7K resistor on the collector to limit the current >when the transistor is off. This should square off the signal and >provide a TTL level input to the EFIS system in the aircraft. > >I can build this on a breadboard and test it in the lab and use a >variable speed power drill to rotate the tach gen. > >If the above sounds reasonable, I'm off to order the parts from >DigiKey. Thanks for all the help and advice. Okay, how about this? Emacs! How "square" does the signal need to be? If you're driving the "off the shelf" input to some tachometer originally designed to attach to a p-lead or some other transducer, the tach should take care of its own "squaring" internally. It may be that all you need is to "clean" up the waveform to eliminate bumps and warts on transitions that can be interpreted as "extra edges". Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Nov 03, 2009
At 07:12 AM 11/3/2009, you wrote: > > >Att'n: 'Lectric Bob: >You mentioned ". . . solid state relays even better." >I recall some time ago that you mentioned that you might design, >build, market solid state relays. Is that still a possibility for the future? >Gordon smith Absolutely. That design is done and tooled. At the moment, I don't have a production facility free. We're still knee deep in house remodeling and shuffling of furniture between four locations. The goal now is to have the kids in my Wichita house over the Thanksgiving week. Give them a few weeks to get "settled in" and I'll be training them to take over the AeroElectric Connection production and order fulfillment. That will let me spend 100% of my time on development of about a dozen new products. Here's the preliminary data on a solid state relay. http://www.aeroelectric.com/Catalog/AEC/9030/ Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Nov 03, 2009
From: "David E. Nelson" <david.nelson(at)pobox.com>
Subject: What is the SD-8's regulator doing when not being used
Hi Bob, With the plane in a cruise configuration and 'Aux Alt' switch 'Off', is the regulator sinking all the power that the SD-8 is producing? Thanks, /\/elson ~~ Lately my memory seems to be like a steel trap .... without any spring. ~~ ________________________________________________________________________________
From: Etienne Phillips <etienne.phillips(at)gmail.com>
Subject: Re: What is the SD-8's regulator doing when not being
used
Date: Nov 03, 2009
Hi /\/elson Since there's no current flowing through the regulator, my guess is that it's not doing anything... Converting the open-circuit voltage of the SD-8 to 13.8V (or whatever yours is set to) doesn't dissipate any energy until the current starts to flow. Etienne On 03 Nov 2009, at 7:40 PM, David E. Nelson wrote: > > > > > Hi Bob, > > With the plane in a cruise configuration and 'Aux Alt' switch 'Off', > is the regulator sinking all the power that the SD-8 is producing? > > Thanks, > /\/elson > > ~~ Lately my memory seems to be like a steel trap .... without any > spring. ~~ > > ________________________________________________________________________________
Date: Nov 03, 2009
used At 12:29 PM 11/3/2009, you wrote: > > >Hi /\/elson > >Since there's no current flowing through the regulator, my guess is >that it's not doing anything... Converting the open-circuit voltage of >the SD-8 to 13.8V (or whatever yours is set to) doesn't dissipate any >energy until the current starts to flow. > >Etienne Correct. Bob . . . --------------------------------------- ( It's MATRONICS FUND RAISER MONTH! ) ( Do your part to keep this marvelous ) ( tool sharp and available to all our ) ( brothers in the OBAM aviation ) ( community. ) --------------------------------------- ________________________________________________________________________________
Date: Nov 03, 2009
used Thank you. /\/elson On Tue, 3 Nov 2009, Robert L. Nuckolls, III wrote: > > > At 12:29 PM 11/3/2009, you wrote: >> >> >> Hi /\/elson >> >> Since there's no current flowing through the regulator, my guess is >> that it's not doing anything... Converting the open-circuit voltage of >> the SD-8 to 13.8V (or whatever yours is set to) doesn't dissipate any >> energy until the current starts to flow. >> >> Etienne > > Correct. > > > Bob . . . > > --------------------------------------- > ( It's MATRONICS FUND RAISER MONTH! ) > ( Do your part to keep this marvelous ) > ( tool sharp and available to all our ) > ( brothers in the OBAM aviation ) > ( community. ) > --------------------------------------- > > ________________________________________________________________________________
Date: Nov 03, 2009
Bob: In that case, I'll just run the output into the comparator circuit as the signal input to the comparator goes to this: signal in O------- | > | O---------O------> to comparator | | > --- 50K | | | gnd gnd Read this topic online here: http://forums.matronics.com/viewtopic.php?p=270874#270874 ________________________________________________________________________________
Date: Nov 03, 2009
Bob: Well that got messed up when it posted! Basically, signal in goes to a voltage divider of 1K resistor and 50K resistor with a 5.1V Zener in parallel with the 50K resistor. The output goes to the comparator. Output of the comparator goes to the EFIS as a TTL level signal. Craig Read this topic online here: http://forums.matronics.com/viewtopic.php?p=270875#270875 ________________________________________________________________________________
Subject: Jabiru regulator wiring and 2nd ground
Date: Nov 03, 2009
Hi! I am mounting my filter capacitor and alt disconnect relay on the cool side of the firewall. Voltage regulator and battery would be FWF. One alternator lead would go through the firewall to the COM terminal of the alt disconnect relay. From the regulator, one ltblu wire, the red wire, and the yel wire would go through the firewall to the filter capacitor. From the filter capacitor, there would be one wire come back through the firewall to the starter contactor. This is how I'd planned it a few months ago. The only changes were to downsize the wires. But today, I ran across the following on the US Jabiru website: We suggest keeping the red and yellow wires ahead of the firewall. We run them directly but separately to the battery. This differs from how I have it, since my red and yellow wires are not kept fwf. And they are not run directly to the battery, but go first to the filter capacitor, starter contactor, battery contactor and then to the battery. Is there any problem doing it how I have it? I also noticed in the Z drawings with the Jabiru regulator, Bob shows two grounds, one from the black wire and another drawn between the voltage regulator box to the firewall. I'm wondering if this ground drawing should be deleted. The voltage regulator metal case certainly contacts the firewall, fwiw. -------- Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=270882#270882 Attachments: http://forums.matronics.com//files/dans_jab_3300_alternator_and_regulator_wiring_505.pdf ________________________________________________________________________________
Subject: MaxPulse and MaxDim
Date: Nov 04, 2009
Hey list members. Just thought I would let you all know that we completed our installation of the MaxPulse and MaxDim units in our 150, 4 months ago now. These things run cool and are a dream to install. These correct so many problems we encounter as aircraft owners. Like replacing the rheostats or the big dual dimmer that costs $1200 from Cessna. Yikes. You can see these at www.maxpulsemaxdim.com . I see another member is gathering a group together for a special buy on the MaxDim, I think I will join in that effort for our other Cub. Mark Eagle River, Alaska ________________________________________________________________________________
Subject: Re: What is the type of this pin?
Date: Nov 04, 2009
Hi Overtorque I read your post. In your post u show one pin it is push to on pin. It use in the some electronics component. The function of this pin is to set and reset circuit. -------- r4 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=270910#270910 ________________________________________________________________________________
Date: Nov 04, 2009
Yeah, but . . . If you study the dynamics of the circuit with the transistor, it's "active" window is only a few hundred millivolts wide defined by the signal level where the transistor first starts to conduct until it is saturated. Only "glitches" that exist within that widow are transferred through . . . with gain. A straight divider/zener network has an active window of about 5 volts but no gain. None the less, the "filtering" feature we're looking for is degraded. I'm not saying that it won't work . . . give it a try. But you may find that the little extra gain and tightening of the window to be useful and easy to do. By the way, since your signal of interest goes below ground, the bottom resistor in the schematic you propose is probably not necessary. Bob . . . --------------------------------------- ( It's MATRONICS FUND RAISER MONTH! ) ( Do your part to keep this marvelous ) ( tool sharp and available to all our ) ( brothers in the OBAM aviation ) ( community. ) --------------------------------------- ________________________________________________________________________________
Date: Nov 04, 2009
At 08:19 PM 11/3/2009, you wrote: > > >Bob: > >Well that got messed up when it posted! Basically, signal in goes >to a voltage divider of 1K resistor and 50K resistor with a 5.1V >Zener in parallel with the 50K resistor. The output goes to the >comparator. Output of the comparator goes to the EFIS as a TTL level signal. OH . . . you mean there are other electro-whizzies posed between our pre-conditioning circuit and the input to your EFIS? I thought we were talking about the whole thing. Perhaps you need to sketch the whole system for me, I've been seeing it through a gray matter "knothole". Bob . . . --------------------------------------- ( It's MATRONICS FUND RAISER MONTH! ) ( Do your part to keep this marvelous ) ( tool sharp and available to all our ) ( brothers in the OBAM aviation ) ( community. ) --------------------------------------- ________________________________________________________________________________
Date: Nov 04, 2009
Subject: Re: Jabiru regulator wiring and 2nd ground
At 08:54 PM 11/3/2009, you wrote: > >Hi! > >I am mounting my filter capacitor and alt disconnect relay on the >cool side of the firewall. Voltage regulator and battery would be >FWF. One alternator lead would go through the firewall to the COM >terminal of the alt disconnect relay. From the regulator, one ltblu >wire, the red wire, and the yel wire would go through the firewall >to the filter capacitor. From the filter capacitor, there would be >one wire come back through the firewall to the starter contactor. >This is how I'd planned it a few months ago. The only changes were >to downsize the wires. > >But today, I ran across the following on the US Jabiru website: > >We suggest keeping the red and yellow wires ahead of the >firewall. We run them directly but separately to the battery. > >This differs from how I have it, since my red and yellow wires are >not kept fwf. And they are not run directly to the battery, but go >first to the filter capacitor, starter contactor, battery contactor >and then to the battery. Is there any problem doing it how I have it? > > >I also noticed in the Z drawings with the Jabiru regulator, Bob >shows two grounds, one from the black wire and another drawn between >the voltage regulator box to the firewall. I'm wondering if this >ground drawing should be deleted. It depends on the specific regulators . . . some regulators require an electrical case ground for proper function so I always show it . . . if the critter is mounted to your conductive firewall, then it IS grounded whether electrically necessary or not. > The voltage regulator metal case certainly contacts the firewall, fwiw. Yes . . . that's what that symbol is about. You're mixing multiple recipes for success together with predicable consternation. There's no good reason to have just the relay and filter capacitor on the cockpit side of the firewall. Good practice calls for minimizing firewall penetrations. If it were my airplane, I'd put all the alternator stuff forward of the firewall and bring a minimum of power distribution and control wires through to the cockpit. Bob . . . --------------------------------------- ( It's MATRONICS FUND RAISER MONTH! ) ( Do your part to keep this marvelous ) ( tool sharp and available to all our ) ( brothers in the OBAM aviation ) ( community. ) --------------------------------------- ________________________________________________________________________________
Date: Nov 04, 2009
> You're mixing multiple recipes for success together > with predicable consternation. There's no good reason to > have just the relay and filter capacitor on the > cockpit side of the firewall. Good practice calls > for minimizing firewall penetrations. > > If it were my airplane, I'd put all the alternator > stuff forward of the firewall and bring a > minimum of power distribution and control wires > through to the cockpit. I could certainly do that. The main reason I planned on putting them in the cabin was because that's where the documentation for the relay and capacitor said to put them. "Regulator and capacitor should be mounted in a cool place and should be mounted on the cockpit side of the firewall" The diagram shows the battery, alt disconnect relay, capacitor and voltage regulator behind the firewall. Of these, only the battery has a fixed position fwf in a Sonex. I had planned to put the regulator fwf mainly because that's where Jabiru has it. As it's drawn now in my schematic, I have 5 wires going through the firewall between the regulator, relay, and capacitor. Moving the regulator into the cabin would cut that down to 3: the 2 alternator leads and the single wire from the capacitor to the starter contactor. Or I could mount all of these components fwf, which would eliminate all the firewall penetrations shown and add just the 22awg alt relay coil wire going fwf. It sounds like this latter way is how you would do it, which means less firewall penetrations would trump having these components in the cooler cabin. -------- Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=270967#270967 Attachments: http://forums.matronics.com//files/504_500_rev_f_498.pdf ________________________________________________________________________________
Date: Nov 04, 2009
> > >It sounds like this latter way is how you would do it, which means >less firewall penetrations would trump having these components in >the cooler cabin. Virtually everybody would like to have their pride-n-joy products mounted in the most benign location possible aboard the airplane . . . lower risk. At the same time, except for direct radiation from hot exhaust stacks, the environment under the cowl isn't all that bad either. The capacitor and relay are rated for temperatures greater than what's expected under the cowl . . . so make the installation clean and simple as opposed to "cooler". Bob . . . --------------------------------------- ( It's MATRONICS FUND RAISER MONTH! ) ( Do your part to keep this marvelous ) ( tool sharp and available to all our ) ( brothers in the OBAM aviation ) ( community. ) --------------------------------------- ________________________________________________________________________________
Date: Nov 04, 2009
Thanks, Bob :-) -------- Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=271065#271065 ________________________________________________________________________________
Date: Nov 05, 2009
Subject: Reminder
Dear Listers, Just a quick reminder that November is the annual List Fund Raiser. The Matronics Lists are 100% member supported and all of the operational costs are provided for my your Contributions during this time of the year. Your personal Contribution makes a difference and keeps all of the Matronics Email Lists and Forums completely ad-free. Please make your Contribution today to keep these services up and running! http://www.matronics.com/contribution Thank you in advance! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 05, 2009
Bob wrote "That will let me spend 100% of my time on development of about a dozen new products. Here's the preliminary data on a solid state relay." Might one of these products be the small, light, low cost, wing leveler discussed as part of "The Right Stuff" and "The Weak Link" in July 2009? Gordon smith Read this topic online here: http://forums.matronics.com/viewtopic.php?p=271175#271175 ________________________________________________________________________________
Date: Nov 05, 2009
At 08:08 AM 11/5/2009, you wrote: > > >Bob wrote >"That will let me spend 100% of my time on development >of about a dozen new products. Here's the preliminary >data on a solid state relay." > >Might one of these products be the small, light, low cost, wing >leveler discussed as part of "The Right Stuff" and "The Weak Link" >in July 2009? That's on the list but necessarily rather far down. The up-front development $time$ is significant. The manufacture calls for a significant quantity of out- sourced materials. Further, there ARE already very capable suppliers of similar products on the market. A noteworthy supplier is "Mr. Autopilot" in the person of Jim Younkin. I could not pick a more worthy competitor. I'll need access to a flight test airframe too. I've considered buying or leasing something with a prop and wings on it for that purpose. In any case, I still think it's a righteous project with a lot of potential. I need to make sure that any investment WE make (my kids are being groomed to take over AEC business interests) has a high probability for return on investment. In the mean time . . . Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Nov 05, 2009
Subject: Avionics cooling fan revisited
-In researching the Aeroelectric-list archives for cooling fans, I-foun d several interesting posts. - -I-copied and pasted-the-post below-from 2003. When I followed- Bob's link to the fan at MPJA.com,-it was no longer there.-The one Bob recommended- (60 cfm and 2 amps)seems like too much when compared to TSO' d fans like the Cyclone-21 (21-cfm and 0.19 amp) or Ameriking (26-cfm -and-0.6 amp). If Bob is reading, what would you suggest today? - Is there a specific alternative fan that would be appropriate to cool the t wo radios in my OBAM plane besides the-T$O's fans made for certified plan es? Or how to house the suggested computer fans? Have such computer fans-been used successfully notwithstanding Bob's doub ts as to their suitability? - Thanks for the list, Eric Schlanser-- - - Match: #83 Message: #15485 Date: Dec 08, 2003 From: "Robert L. Nuckolls, III" Subject: Re: cooling fans, ONE DOLLAR > >There's been some talk about cooling fans, and people have mentioned 8-12 >bucks (I think).- No need to spend that much: > >$1 each:- http://store.yahoo.com/nexfan03/evcafan80bl.html > >Or, for quieter, ball bearing, $4.99 each: >http://store.yahoo.com/directron/uc001btc.html >http://store.yahoo.com/directron/80l1a.html -- Air movers for avionics need characteristics -- conducive to moving air against quite a bit -- of back pressure. The relatively small diameter -- hoses are probably too much for a computer cooling -- fan that almost never has to move air though -- tiny spaces. -- Most of the avionics cooling fans I've seen -- used centrifugal blowers or vane axial blowers. -- If I were going to hammer something together -- for avionics cooling, I'd start with a product -- like -- http://www.mpja.com/productview.asp?product=14495+FN -- This critter draws 2A and is rated at 60 cfm -- (at no pressure). You could build a plenum onto -- its output snoot for attaching cooling hoses. -- Bob . . . =0A=0A=0A ________________________________________________________________________________
Date: Nov 05, 2009
Eric, I just perused the site and went to the fans directory. apparently technology is moving forward. there are a number of adaptable 12/24 volt blowers (look like leaf blowers) that draw < 1 amp and are reasonably priced too. You don't get much for a dollar today, but I saw some from $5-10. Glenn From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Eric Schlanser Sent: Thursday, November 05, 2009 11:41 AM Subject: AeroElectric-List: Avionics cooling fan revisited In researching the Aeroelectric-list archives for cooling fans, I found several interesting posts. I copied and pasted the post below from 2003. When I followed Bob's link to the fan at MPJA.com, it was no longer there. The one Bob recommended (60 cfm and 2 amps)seems like too much when compared to TSO'd fans like the Cyclone-21 (21 cfm and 0.19 amp) or Ameriking (26 cfm and 0.6 amp). If Bob is reading, what would you suggest today? Is there a specific alternative fan that would be appropriate to cool the two radios in my OBAM plane besides the T$O's fans made for certified planes? Or how to house the suggested computer fans? Have such computer fans been used successfully notwithstanding Bob's doubts as to their suitability? Thanks for the list, Eric Schlanser Match: #83 Message: #15485 Date: Dec 08, 2003 From: "Robert L. Nuckolls, III" Subject: Re: cooling fans, ONE DOLLAR <http://www.matronics.com/searching/getmsg_script.cgi?INDEX=24759583?KE Y S=cooling_fan?LISTNAME=AeroElectric?HITNUMBER=83?SERIAL=064059231 52?SHOW BUTTONS=NO> > >There's been some talk about cooling fans, and people have mentioned 8-12 >bucks (I think). No need to spend that much: > >$1 each: http://store.yahoo.com/nexfan03/evcafan80bl.html > >Or, for quieter, ball bearing, $4.99 each: >http://store.yahoo.com/directron/uc001btc.html >http://store.yahoo.com/directron/80l1a.html Air movers for avionics need characteristics conducive to moving air against quite a bit of back pressure. The relatively small diameter hoses are probably too much for a computer cooling fan that almost never has to move air though tiny spaces. Most of the avionics cooling fans I've seen used centrifugal blowers or vane axial blowers. If I were going to hammer something together for avionics cooling, I'd start with a product like http://www.mpja.com/productview.asp?product=14495+FN This critter draws 2A and is rated at 60 cfm (at no pressure). You could build a plenum onto its output snoot for attaching cooling hoses. Bob . . . ________________________________________________________________________________
Date: Nov 05, 2009
Bob: Here is the circuit that is the current interface between the tach gen and the EFIS tach input. It was originally designed to interface a Hall sensor with a 10 V p-p input. The 50K resistor in parallel with the zener was to provide a current path (so I am told) should a p-lead be used instead of the Hall sensor. My thought was to put the circuit you have proposed in the location as shown in the attached document (I could not scan to a .jpg and the .bmp was way too big). Thanks, Craig Read this topic online here: http://forums.matronics.com/viewtopic.php?p=271250#271250 Attachments: http://forums.matronics.com//files/tach_interface_146.doc ________________________________________________________________________________
Date: Nov 05, 2009
At 03:38 PM 11/5/2009, you wrote: > > >Bob: > >Here is the circuit that is the current interface between the tach >gen and the EFIS tach input. It was originally designed to >interface a Hall sensor with a 10 V p-p input. The 50K resistor in >parallel with the zener was to provide a current path (so I am told) >should a p-lead be used instead of the Hall sensor. > >My thought was to put the circuit you have proposed in the location >as shown in the attached document (I could not scan to a .jpg and >the .bmp was way too big). Okay. I think your 'trash' is coming from artifacts on the wave-form that are a result of the combination of the two phases of a 3-phase generator. These seem to reside some millivolts away from ground . . . so your results are bound to improve if you move your comparator's decision-point as close to ground as possible. Try the simple transistor-zener circuit without the comparator. The transistor's "decision point" is in the .5 to .7 volt range as a function of Vbe characteristics of b-e junction. Bob . . . --------------------------------------- ( It's MATRONICS FUND RAISER MONTH! ) ( Do your part to keep this marvelous ) ( tool sharp and available to all our ) ( brothers in the OBAM aviation ) ( community. ) --------------------------------------- ________________________________________________________________________________
Subject: Jabiru Magneto Wiring
Date: Nov 05, 2009
Hello! The Jabiru manual doesn't say much about the mag wiring. On each of my coils, there is a 1/4" faston tab. I have 20awg shielded wire for each ignition. I've read through the Book and understand when the mags are ungrounded, they are hot. Flipping the mag switch off completes the ground ground and kills the mag. I've attached a doc that shows what I understand and what I don't. Quotes are from Bob's book in Note 3 of the Z appendix, I believe: 1. "Attach the shield to one and only one switch terminal at the cockpit end..." How do I do this? I can strip off the outer insulation and expose the braided shield. For a 20awg wire, using a 16awg stripper is about right. That's about as far as my brain will take me. Seems like I would splice the outer braid to a wire, and connect that wire via faston to terminal #2 of the switch. Another faston would go on the inner wire and connect to terminal #3. I just don't know how. 2. "Attach the shield to engine ground at the magneto end." The drawing shows shield going to one spot on the ignition and the inner wire going to another. I have just the faston tab of the coil. How is this done? -------- Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=271275#271275 Attachments: http://forums.matronics.com//files/dans_magneto_wiring_141.pdf ________________________________________________________________________________
Subject: Re: Jabiru Magneto Wiring
Date: Nov 05, 2009
I also just read this searching through the Yahoo Jab group: "...at the switch end, you should connect both L and R shield grounds together (but not to anything else but the switch), for redundancy, in case of a break in one of the ground leads, you can still shut off the engine. This should not cause a ground loop/noise problem..." -------- Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=271277#271277 ________________________________________________________________________________
Date: Nov 06, 2009
At 06:48 PM 11/5/2009, you wrote: > >Hello! > >The Jabiru manual doesn't say much about the mag wiring. On each of >my coils, there is a 1/4" faston tab. I have 20awg shielded wire for >each ignition. I've read through the Book and understand when the >mags are ungrounded, they are hot. Flipping the mag switch off >completes the ground ground and kills the mag. > >I've attached a doc that shows what I understand and what I don't. >Quotes are from Bob's book in Note 3 of the Z appendix, I believe: > >1. "Attach the shield to one and only one switch terminal at the >cockpit end..." > >How do I do this? I can strip off the outer insulation and expose >the braided shield. For a 20awg wire, using a 16awg stripper is >about right. That's about as far as my brain will take me. Seems >like I would splice the outer braid to a wire, and connect that wire >via faston to terminal #2 of the switch. Another faston would go on >the inner wire and connect to terminal #3. I just don't know how. > >2. "Attach the shield to engine ground at the magneto end." > >The drawing shows shield going to one spot on the ignition and the >inner wire going to another. I have just the faston tab of the coil. >How is this done? See: http://aeroelectric.com/articles/shldwire/shldwire.html Put faston female on engine end of center conductor and install on magneto coil tab. Put ring terminal on engine end shield and take to crankcase ground via mounting bolt (on ignition coil?). If necessary, slice onto the shield to extend to nearest practical mounting bolt. NOTE "mounting bolt" means some fastener that holds detail parts and/or accessories on the engine. This does not mean any bolt with a critical torque value for the maintenance of structural integrity. I once had a guy remove a head-bolt to "ground" some wire to his engine! Attach other end of shielded wire to switch. Prepare ends the same way. Install fast-on or ring terminals as appropriate. Connect so that the wire and shield are connected to each other when the ignition switch is closed (OFF). Bob . . . --------------------------------------- ( It's MATRONICS FUND RAISER MONTH! ) ( Do your part to keep this marvelous ) ( tool sharp and available to all our ) ( brothers in the OBAM aviation ) ( community. ) --------------------------------------- ________________________________________________________________________________
Subject: MaxPulse warm-up and pulse rates suitability for HID
Date: Nov 06, 2009
http://forum.matronics.com/viewtopic.php?t=62495 Read the 2nd 1/2 of this thread. -------- LED still has a long way to go to compete with HID as a landing light. This is true in terms of total lumens and reach (distance). Read this topic online here: http://forums.matronics.com/viewtopic.php?p=271374#271374 ________________________________________________________________________________
Date: Nov 06, 2009
Thanks, for running down that article, Bob. Not sure how I missed it. Nice, easy to understand article. -------- Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=271393#271393 ________________________________________________________________________________
Date: Nov 06, 2009
At 06:56 PM 11/5/2009, you wrote: > >I also just read this searching through the Yahoo Jab group: > >"...at the switch end, >you should connect both L and R shield grounds together (but not to >anything else but the switch), for redundancy, in case of a break in >one of the ground leads, you can still shut off the engine. This >should not cause a ground loop/noise problem..." This refers to the O-L-R-B-S key-switch and is not applicable to the use of toggles and push-button. Bob . . . --------------------------------------- ( It's MATRONICS FUND RAISER MONTH! ) ( Do your part to keep this marvelous ) ( tool sharp and available to all our ) ( brothers in the OBAM aviation ) ( community. ) --------------------------------------- ________________________________________________________________________________
Date: Nov 07, 2009
Subject: Please Make A Contribution To Support Your Lists
Dear Listers, There is no advertising income to support the Matronics Email Lists and Forums. The operation is supported 100% by your personal Contributions during the November Fund Raiser. Please make your Contribution today to support the continued operation and upgrade of these services. You can pick up a really nice gift for making your Contribution too! You may use a Credit Card or Paypal at the Matronics Contribution Site here: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle PO Box 347 Livermore, CA 94551-0347 Thank you in advance for your generous support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 07, 2009
Bob: I have assumes that the windings are Y-wound and not delta. The connector for the unit only has three pins and they are labeled a, b, and c. I am assuming by your comment that we are using two phases that we have picked up the signal improperly from the tach gen itself. However, when we tried to get a signal from one pin with the case as ground reference, we had no signal at all. Craig Read this topic online here: http://forums.matronics.com/viewtopic.php?p=271542#271542 ________________________________________________________________________________
Date: Nov 07, 2009
At 06:57 AM 11/7/2009, you wrote: > > >Bob: > >I have assumes that the windings are Y-wound and not delta. The >connector for the unit only has three pins and they are labeled a, b, and c. > >I am assuming by your comment that we are using two phases that we >have picked up the signal improperly from the tach gen >itself. However, when we tried to get a signal from one pin with >the case as ground reference, we had no signal at all. Understand . . . and it's what I would have expected. So there's no "improper" connection, only a "less than ideal" connection. The design goal is to craft a squaring circuit that has the narrowest window of uncertainty that is centered in the area of the waveform least likely to be problematic. What are the specs for signal input to your engine monitor? Does the square wave need to be of any particular "sqareness" i.e. rate of change or simply "clean" and free of extraneous changes in direction. If I were designing such an instrument, I'd be interested only in a clean representation of period be it a sine wave, pulse, trapezoid, etc . . . all I'm doing is counting transitions from highest to lowest voltage. I'd do all of my "squaring" internally to accommodate the needs of the electronics. So I'm betting that if you get a clean 5v signal of any shape . . . the electronics will be happy. Bob . . . --------------------------------------- ( It's MATRONICS FUND RAISER MONTH! ) ( Do your part to keep this marvelous ) ( tool sharp and available to all our ) ( brothers in the OBAM aviation ) ( community. ) --------------------------------------- ________________________________________________________________________________
Subject: Re: Garmin GNS 530 Internal Battery
Date: Nov 07, 2009
Did you ever find a source for this information? I'm looking for the same thing. Thanks. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=271555#271555 ________________________________________________________________________________
Subject: Re: p-lead signal conditioning or tach gen usage
Date: Nov 08, 2009
I wanted to repost a circuit that I built for an Aeroelectric lister for his problem of interfacing two different tach generators with one tachometer. This is a simple divide by two and signal conditioner that might prove useful in these, or related efforts. I have PCBs for this and can build up one for little money. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=271690#271690 Attachments: http://forums.matronics.com//files/tacho_divider_141.jpg http://forums.matronics.com//files/tachodividerschematic_108.jpg ________________________________________________________________________________
Date: Nov 08, 2009
Subject: Re: wire size
Hello Bob I have a wire size question. I use your 2 bat 2 alt all electric configuation for my Glasair. I use circuit breakers on a panel on the right side of the panel. The problem is that the person that helped me wire the airplane ran #4 wire from the firewall pass through and attached to the breaker panel. These are very stiff ( not welding cable) and put stress on the connections to the breakers. I would like to terminate the 2 #4 wires on the sidewall on 2 separate studs and from each of these two studs run 2 #10 wire (about 6 to 10 inches)to each end of the strap connecting the hot side of the breakers on each of the two circuits. I hope this is clear. My question is; would 2 #10 wire be sufficient to replace for a short run the #4 wires? Jim James Robinson Glasair lll N79R Spanish Fork UT U77 ________________________________ ________________________________________________________________________________
Date: Nov 08, 2009
At 02:09 PM 11/8/2009, you wrote: >Hello Bob >I have a wire size question. I use your 2 bat 2 alt all electric >configuation for my Glasair. I use circuit breakers on a panel on >the right side of the panel. The problem is that the person that >helped me wire the airplane ran #4 wire from the firewall pass >through and attached to the breaker panel. These are very stiff ( >not welding cable) and put stress on the connections to the >breakers. I would like to terminate the 2 #4 wires on the sidewall >on 2 separate studs and from each of these two studs run 2 #10 wire >(about 6 to 10 inches)to each end of the strap connecting the hot >side of the breakers on each of the two circuits. I hope this is >clear. My question is; would 2 #10 wire be sufficient to replace >for a short run the #4 wires? I'd really rather you didn't have all this "hardware" in the system. How about replacing the 4AWG tefzel with a 6AWG welding cable which will be MUCH easier to work with and entirely adequate for alternator outputs of 60A. I'm presuming that your alternator is no larger than this. Alternatively, a single chunk of 4AWG welding cable would be MUCH preferred. Bob . . . --------------------------------------- ( It's MATRONICS FUND RAISER MONTH! ) ( Do your part to keep this marvelous ) ( tool sharp and available to all our ) ( brothers in the OBAM aviation ) ( community. ) --------------------------------------- ________________________________________________________________________________
Date: Nov 08, 2009
Hi Bob Your solution is OK and doable. I just worry about the weight of the wire on the copper tie strip on the breakers. I could figure a support for the much more flexible wire. I am running a pad mount 20 amp and a belt driven 40 amp alternators. Can you make up the wires with ends if I provide the length and connector sizes? Jim James Robinson Glasair lll N79R Spanish Fork UT U77 ________________________________ From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Sent: Sun, November 8, 2009 3:43:57 PM Subject: Re: AeroElectric-List: wire size At 02:09 PM 11/8/2009, you wrote: > Hello Bob > I have a wire size question. I use your 2 bat 2 alt all electric configuation for my Glasair. I use circuit breakers on a panel on the right side of the panel. The problem is that the person that helped me wire the airplane ran #4 wire from the firewall pass through and attached to the breaker panel. These are very stiff ( not welding cable) and put stress on the connections to the breakers. I would like to terminate the 2 #4 wires on the sidewall on 2 separate studs and from each of these two studs run 2 #10 wire (about 6 to 10 inches)to each end of the strap connecting the hot side of the breakers on each of the two circuits. I hope this is clear. My question is; would 2 #10 wire be sufficient to replace for a short run the #4 wires? I'd really rather you didn't have all this "hardware" in the system. How about replacing the 4AWG tefzel with a 6AWG welding cable which will be MUCH easier to work with and entirely adequate for alternator outputs of 60A. I'm presuming that your alternator is no larger than this. Alternatively, a single chunk of 4AWG welding cable would be MUCH preferred. Bob . . . --------------------------------------- ( It's MATRONICS FUND RAISER MONTH! ) ( Do your part to keep this marvelous ) ( tool sharp and available to all our ) ( brothers in the OBAM aviation ) ( community. ) --------------------------------------- ________________________________________________________________________________
Date: Nov 08, 2009
If you walk into your local welding supply shop & tell 'em you need x feet of #6 and y crimp-on lugs for the wire with z stud size, then ask if they know anyone who might rent you a crimper, odds are good that someone at the counter will go get a crimper out of stock & do it for you on the spot. Charlie James Robinson wrote: > Hi Bob > Your solution is OK and doable. I just worry about the weight of the > wire on the copper tie strip on the breakers. I could figure a > support for the much more flexible wire. > I am running a pad mount 20 amp and a belt driven 40 amp alternators. > Can you make up the wires with ends if I provide the length and > connector sizes? > Jim > James Robinson > Glasair lll N79R > Spanish Fork UT U77 > > > ------------------------------------------------------------------------ > *From:* "Robert L. Nuckolls, III" > *To:* aeroelectric-list(at)matronics.com > *Sent:* Sun, November 8, 2009 3:43:57 PM > *Subject:* Re: AeroElectric-List: wire size > > > > > At 02:09 PM 11/8/2009, you wrote: > > Hello Bob > > I have a wire size question. I use your 2 bat 2 alt all electric > configuation for my Glasair. I use circuit breakers on a panel on the > right side of the panel. The problem is that the person that helped > me wire the airplane ran #4 wire from the firewall pass through and > attached to the breaker panel. These are very stiff ( not welding > cable) and put stress on the connections to the breakers. I would > like to terminate the 2 #4 wires on the sidewall on 2 separate studs > and from each of these two studs run 2 #10 wire (about 6 to 10 > inches)to each end of the strap connecting the hot side of the > breakers on each of the two circuits. I hope this is clear. My > question is; would 2 #10 wire be sufficient to replace for a short run > the #4 wires? > > I'd really rather you didn't have all this "hardware" > in the system. How about replacing the 4AWG tefzel with > a 6AWG welding cable which will be MUCH easier to work > with and entirely adequate for alternator outputs of > 60A. I'm presuming that your alternator is no larger > than this. Alternatively, a single chunk of 4AWG welding > cable would be MUCH preferred. > > > Bob . . . ________________________________________________________________________________
Date: Nov 08, 2009
Thanks Charlie I have a welding shop around the corner. I'll check with them. Jim James Robinson Glasair lll N79R Spanish Fork UT U77 ________________________________ From: Charlie England <ceengland(at)bellsouth.net> Sent: Sun, November 8, 2009 4:50:56 PM Subject: Re: AeroElectric-List: wire size If you walk into your local welding supply shop & tell 'em you need x feet of #6 and y crimp-on lugs for the wire with z stud size, then ask if they know anyone who might rent you a crimper, odds are good that someone at the counter will go get a crimper out of stock & do it for you on the spot. Charlie James Robinson wrote: > Hi Bob > Your solution is OK and doable. I just worry about the weight of the wire on the copper tie strip on the breakers. I could figure a support for the much more flexible wire. > I am running a pad mount 20 amp and a belt driven 40 amp alternators. Can you make up the wires with ends if I provide the length and connector sizes? > Jim > James Robinson > Glasair lll N79R > Spanish Fork UT U77 > > > ------------------------------------------------------------------------ > *From:* "Robert L. Nuckolls, III" > *To:* aeroelectric-list(at)matronics.com > *Sent:* Sun, November 8, 2009 3:43:57 PM > *Subject:* Re: AeroElectric-List: wire size > > > At 02:09 PM 11/8/2009, you wrote: > > Hello Bob > > I have a wire size question. I use your 2 bat 2 alt all electric configuation for my Glasair. I use circuit breakers on a panel on the right side of the panel. The problem is that the person that helped me wire the airplane ran #4 wire from the firewall pass through and attached to the breaker panel. These are very stiff ( not welding cable) and put stress on the connections to the breakers. I would like to terminate the 2 #4 wires on the sidewall on 2 separate studs and from each of these two studs run 2 #10 wire (about 6 to 10 inches)to each end of the strap connecting the hot side of the breakers on each of the two circuits. I hope this is clear. My question is; would 2 #10 wire be sufficient to replace for a short run the #4 wires? > > I'd really rather you didn't have all this "hardware" > in the system. How about replacing the 4AWG tefzel with > a 6AWG welding cable which will be MUCH easier to work > with and entirely adequate for alternator outputs of > 60A. I'm presuming that your alternator is no larger > than this. Alternatively, a single chunk of 4AWG welding > cable would be MUCH preferred. > > > Bob . . . ________________________________________________________________________________
Subject: Failure Detection and Annunciation question
Date: Nov 08, 2009
Bob, Was reviewing your article: http://www.aeroelectric.com/articles/Failure_Detection_and_Annunciation.pdf I want to annunciate the failure of a 12v scavenge pump to draw current. You mention such a circuit being used on a heated pitot but I was wondering if it mattered if the load was a pump motor? Full load would be approximately 5 amps and it needs to be running whenever the engine is running. I figured the LED would come on whenever I put power to the ECU and Ignition and would quickly go out if the scavenge pump was pulling power as it should. Thus, even if I "forgot" to flip the switch for the scavenge pump, the LED would illuminate until I did AND the pump was pulling power. Any problem with a motor as opposed to a resistance load? Any other things I should consider? Thanks. Allen Fulmer RV7 Eggenfellner Turbo normalized 6 cyl. Finishing up the wiring ________________________________________________________________________________
Date: Nov 09, 2009
Subject: Fund Raiser List of Contributors - Please Make A Contribution
Today! Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take a moment and assure that your name is on that List of Contributors (LOC)? As a number of members have pointed out over the years, the List seems at least - if not a whole lot more - valuable as a building/flying/recreating/entertainment tool as your typical magazine subscription! Please take minute and assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics PO Box 347 Livermore CA 94551-0347 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Was wire size, now crimping heavy wires
Date: Nov 09, 2009
I would add to Charlie's experience that when I went through this process, the guy in my local welding shop said he'd do my crimps for $10, or he'd sell me a crimping die for the same price. It's a self gauging device you can put on a bench or set on the floor and whack a couple times with a good sized hammer. (Actually, you can gauge the crimps by ear as well or better than by sight). Natch, I bought the die and have made a dozen crimps with it and loaned it out to a couple of my cohorts as well. It's definitely one of the more cost effective tool investments I've ever made. A couple thoughts on technique: When set properly, the crimp is gas tight. Needless to say, the individual strands of wire can't slide over each other and you might as well have a solid copper bar in the crimp zone. This makes the cable significantly less flexible adjacent to the crimp, transitioning back to quite flexible a couple inches out from the terminal barrel. If you need to make any sharp bends near the end of the installed cable, it would be beneficial to have another set of hands to pre-bend the cable as the crimp is being made. The other thing is that since welding cable is not tinned like the Tefzel is, after making the crimp I tinned the cut end of the cable for corrosion proofing. Of course, I put heat shrink on the cable-barrel juncture as well. FYI, YMMV, etc, etc... glen matejcek aerobubba(at)earthlink.net > Subject: Re: AeroElectric-List: wire size > > > If you walk into your local welding supply shop & tell 'em you need x > feet of #6 and y crimp-on lugs for the wire with z stud size, then ask > if they know anyone who might rent you a crimper, odds are good that > someone at the counter will go get a crimper out of stock & do it for > you on the spot. > > Charlie > > > James Robinson wrote: > > Hi Bob > > Your solution is OK and doable. I just worry about the weight of the > > wire on the copper tie strip on the breakers. I could figure a > > support for the much more flexible wire. > > I am running a pad mount 20 amp and a belt driven 40 amp alternators. > > Can you make up the wires with ends if I provide the length and > > connector sizes? > > Jim > > James Robinson > > Glasair lll N79R > > Spanish Fork UT U77 > > > > ________________________________________________________________________________
Date: Nov 09, 2009
No, I just dove in and replaced the battery. If you are well organized when you disassemble thing, you'll have not trouble. I've got a few pictures on my website and I can send you a few more on request. It appears intimidating at first, but in reality many of the boards used are rather old school, using typical connectors and screws to fasten them. If the 530 were re-designed with new technology, it would weigh half as much, have better resolution and fewer contraptions inside. I'm guessing with all the new products coming out from Garmin, the 430 and 530 will eventually fall unsupported. For now , they are a great unit. Once you get down to the battery you have a choice. You can trim the tabs and buy a tab type battery or break looks the tabs from the battery and re-solder a new battery in its place. The batteries are easily sourced and cost < $10. I think Garmin charges $800.00 to replace a $10.00 battery, so you have a choice. Glenn -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of joburke Sent: Saturday, November 07, 2009 10:32 AM Subject: AeroElectric-List: Re: Garmin GNS 530 Internal Battery Did you ever find a source for this information? I'm looking for the same thing. Thanks. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=271555#271555 ________________________________________________________________________________
Date: Nov 09, 2009
Subject: Re: Was wire size, now crimping heavy wires
At 03:56 11/9/2009, you wrote: >I would add to Charlie's experience that when I went through this process, >the guy in my local welding shop said he'd do my crimps for $10, or he'd >sell me a crimping die for the same price. It's a self gauging device you >can put on a bench or set on the floor and whack a couple times with a good >sized hammer. (Actually, you can gauge the crimps by ear as well or better >than by sight). Natch, I bought the die and have made a dozen crimps with >it and loaned it out to a couple of my cohorts as well. It's definitely >one of the more cost effective tool investments I've ever made. > > > >FYI, YMMV, etc, etc... > >glen matejcek >aerobubba(at)earthlink.net Not as inexpensive as the $10 pound-on-it crimper, but... These occasionally go on sale at HF for under $50, and with a 20% off coupon on top of that, for <$40 a very nice tool that crimps from AWG-12 to 00 cables. http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=66150 Emacs! ________________________________________________________________________________
Date: Nov 09, 2009
If you go to Ebay and enter "hammer crimper" there are a bunch of them for little money. I have a hammer crimper and it works like a charm. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=271948#271948 ________________________________________________________________________________
Date: Nov 09, 2009
I have one of these. It works great for crimping some large wire gauges - 8 tons of force, hex crimp, etc. However, the dies that are supplied with it are completely marked incorrectly - at least for the type of terminals we typically use in aviation. The range is on the small size in reality and most of the dies are not usable. It will, however, crimp standard #4, #6 and #8AWG wire terminals using the dies marked "00" (biggest), "0", and "2" respectfully. It might do #10, but I didn't have any around to try. So, it's cheap..and it works...just don't expect a correct die set. James Redmon Berkut #013/Race 13 www.berkut13.com ----- Original Message ----- From: Ron Quillin To: aeroelectric-list(at)matronics.com Sent: Monday, November 09, 2009 8:38 AM Subject: Re: AeroElectric-List: Was wire size, now crimping heavy wires Not as inexpensive as the $10 pound-on-it crimper, but... These occasionally go on sale at HF for under $50, and with a 20% off coupon on top of that, for <$40 a very nice tool that crimps from AWG-12 to 00 cables. http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=66150 ________________________________________________________________________________
Date: Nov 09, 2009
Thanks everyone for the great response!!! James Robinson Glasair lll N79R Spanish Fork UT U77 ________________________________ From: "berkut13(at)berkut13.com" <berkut13(at)berkut13.com> Sent: Mon, November 9, 2009 3:09:25 PM Subject: Re: AeroElectric-List: Was wire size, now crimping heavy wires I have one of these. It works great for crimping some large wire gauges - 8 tons of force, hex crimp, etc. However, the dies that are supplied with it are completely marked incorrectly - at least for the type of terminals we typically use in aviation. The range is on the small size in reality and most of the dies are not usable. It will, however, crimp standard #4, #6 and #8AWG wire terminals using the dies marked "00" (biggest), "0", and "2" respectfully. It might do #10, but I didn't have any around to try. So, it's cheap..and it works...just don't expect a correct die set. James Redmon Berkut #013/Race 13 www.berkut13.com ----- Original Message ----- >From: Ron Quillin >To: aeroelectric-list(at)matronics.com >Sent: Monday, November 09, 2009 8:38 > AM >Subject: Re: AeroElectric-List: Was wire > size, now crimping heavy wires > >Not as inexpensive as the $10 pound-on-it crimper, > but... >These occasionally go on sale at HF for under $50, and with a 20% > off coupon on top of that, for <$40 a very nice tool that crimps from > AWG-12 to 00 cables. > >http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=66150 > > > > ________________________________________________________________________________
Date: Nov 09, 2009
At 15:09 11/9/2009, you wrote: >The range is on the small size in reality and most of the dies are not usable. > >So, it's cheap..and it works...just don't expect a correct die set. And here I just thought they were marked in metric units A bit of labor with a die grinder does wonders. I don't recall exactly where I got dimensions from, perhaps AMP, but they can be made to work quite well. Ron Q. ________________________________________________________________________________
Date: Nov 09, 2009
Subject: Re: EFIS Article
At 10:48 AM 11/9/2009, you wrote: >Hello Bob, > >Sometime ago there was a conversation on the >AeroElectric List about how to choose an EFIS >for an experimental airplane, and talked about >the kind of questions that might be appropriate >to ask a supplier. I think I sent you a very >early copy of an article I was writing. In the >end it ended up as three articles which have now >been published in the UK. The first described >what an EFIS is and what makes a good one. The >second looked at the responses from five EFIS >makers (and included Blue Mountain who it seems >is no longer in business). The third looked at >some of the operation factors to be considered >when flying behind a glass screen. > >I have uploaded the articles as PDFs ' see the >bottom 3 links on this page ><http://www.glosterairparts.co.uk/building.htm>http://www.glosterairparts.c o.uk/building.htm. > >They are available as Word files if required. I >would be interested in your comments and perhaps >the best way to roll them out to the Aeroelectric community. > >Best Regards, Peter Pengilly Peter, I've read through your offerings an to the techno-wiennie with some flying experience . . . they read well and logically. I've posted them at: http://aeroelectric.com/articles.html#Instrumentation I'll invite our brothers here stateside to look them over and craft any assessment they might like to offer. I'd be pleased to add these articles to the too small number of guest authors on the AeroElectric.com website. Bob . . . --------------------------------------- ( It's MATRONICS FUND RAISER MONTH! ) ( Do your part to keep this marvelous ) ( tool sharp and available to all our ) ( brothers in the OBAM aviation ) ( community. ) --------------------------------------- ________________________________________________________________________________
Date: Nov 09, 2009
Subject: Re: EFIS Articles (Mis quoted Link)
Peter, I've read through your offerings and to the techno-wiennie with some flying experience . . . they read well and logically. I've posted them at (CORRECTED LINK) . . . http://aeroelectric.com/articles.html#EFIS_Systems I'll invite our brothers here stateside to look them over and craft any assessment they might like to offer. I'd be pleased to add these articles to the too small number of guest authors on the AeroElectric.com website. Bob . . . --------------------------------------- ( It's MATRONICS FUND RAISER MONTH! ) ( Do your part to keep this marvelous ) ( tool sharp and available to all our ) ( brothers in the OBAM aviation ) ( community. ) --------------------------------------- Bob . . . --------------------------------------- ( It's MATRONICS FUND RAISER MONTH! ) ( Do your part to keep this marvelous ) ( tool sharp and available to all our ) ( brothers in the OBAM aviation ) ( community. ) --------------------------------------- ________________________________________________________________________________
Date: Nov 10, 2009
Probably the best in depth and most welll researched article I have read on comparison of systems available. Although a bit outdated re: one of the Mfgrs. Well done Peter -------- Milt Read this topic online here: http://forums.matronics.com/viewtopic.php?p=272067#272067 ________________________________________________________________________________
Date: Nov 10, 2009
Good ole' Harbor Freight. What would we do without that 500 billion dollar trade deficit. I bought a pair from Stein (also imported) which doesn't require a shaving kit full of dies, but does cost a few extra bucks. Convenience worth the money. See their tools page. Glenn From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of berkut13(at)berkut13.com Sent: Monday, November 09, 2009 6:09 PM Subject: Re: AeroElectric-List: Was wire size, now crimping heavy wires I have one of these. It works great for crimping some large wire gauges - 8 tons of force, hex crimp, etc. However, the dies that are supplied with it are completely marked incorrectly - at least for the type of terminals we typically use in aviation. The range is on the small size in reality and most of the dies are not usable. It will, however, crimp standard #4, #6 and #8AWG wire terminals using the dies marked "00" (biggest), "0", and "2" respectfully. It might do #10, but I didn't have any around to try. So, it's cheap..and it works...just don't expect a correct die set. James Redmon Berkut #013/Race 13 www.berkut13.com ----- Original Message ----- From: Ron Quillin <mailto:rjquillin(at)gmail.com> To: aeroelectric-list(at)matronics.com Sent: Monday, November 09, 2009 8:38 AM Subject: Re: AeroElectric-List: Was wire size, now crimping heavy wires Not as inexpensive as the $10 pound-on-it crimper, but... These occasionally go on sale at HF for under $50, and with a 20% off coupon on top of that, for <$40 a very nice tool that crimps from AWG-12 to 00 cables. http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=66150 ________________________________________________________________________________
Date: Nov 10, 2009
Indeed. I wonder if it's coincidence that Dynon have since started using GPS augmentation to help with lost airspeed data? Either way, it's good for everyone to have a clear, unbiased comparison. Thanks Etienne On 10 Nov 2009, at 3:46 PM, n395v wrote: > > > > Probably the best in depth and most welll researched article I have > read on comparison of systems available. Although a bit outdated > re: one of the Mfgrs. Well done Peter > > -------- > Milt > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=272067#272067 > > ________________________________________________________________________________
Subject: Preferred Method for Redundant Power Sources to Single
Input
Date: Nov 10, 2009
Bob, I am curious as to what your preferred method is for providing redundant power sources to devices that only have a single power input. One thought was that you could use one half of a bridge rectifier diode with fast-on tabs to provide a simple way to provide dual inputs and handle the diode backfeed protection. The only problem with that is the forward voltage drop can be significant. I noticed it is 1.7V on a Radio Shack piece that I looked at. I called B&C and they did not know (?) what the forward voltage drop was on their product (I am guessing it might be the same). I like the simplicity of the bridge if the drop wasn't so significant. Do you tend to prefer axial diodes or some other solution? Thanks, Scott Read this topic online here: http://forums.matronics.com/viewtopic.php?p=272117#272117 ________________________________________________________________________________
Date: Nov 11, 2009
Subject: List Fund Raiser
Dear Listers, Just a reminder that November is the Matronics Email List Fund Raiser month. There are some very nice incentive gifts to choose from as well! Please make your Contribution today: http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Re: Preferred Method for Redundant Power Sources to
Single Input
From: "nuckollsr" <bob.nuckolls(at)aeroelectric.com>
Date: Nov 12, 2009
When flight critical devices with a single input power connection are powered from more than one source, there are not many choices. You can use manually or automatically operated "switches" to route energy from the various sources to the electrically needy accessory . . . Manual switches are pretty obvious . . . a toggle switch transfer from NORM to ALTERNATE power source will do. Alternatively, one might install a relay that is held closed and controlled with some voltage sensing device that drops the coil and effects a transfer without pilot intervention. In the Z-Figure below . . . http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z19-RBA1.pdf http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z19-RBA2.pdf . . . I've illustrated a manually operated selection of power sources that MINIMIZES common points of failure for the two power paths that source a single load. This drawing should not be interpreted as a recommended architecture for all situations; it's only illustrative of ONE recipe for success in meeting design goals for the systems that inspired the drawing. I show a pair of diodes that are used IN THIS CASE to prevent the back-feed of power from a working to a non-working system in the even the pilot positions switches incorrectly. Obviously, a pair of diodes could be used WITHOUT switches to provide an either/or energy path from two, always-on sources. The recipe for your particular design goals may differ from that which is shown here. Power distribution diodes come in two common flavors: Silicon Junction and Schottky Junction devices. The former is used in 99% of all power steering and rectification tasks. The later has a slight advantage in that voltage drop across the conducting junction is lower and a disadvantage of being more expensive and available in fewer user-friendly package styles. The Maximum voltage drop ratings for any given device are stated for conditions of highest peak current sometimes stacked on top of the worst case for operating temperature. Its quite misleading because you're interested in average voltage drop under NORMAL conditions. Take a peek at this data sheet for a 2A, 40V rated Schottky device: http://tinyurl.com/ygbolwb Note on Figure 1 we see a plot of typical forward voltage drop characteristics. At 2A the critter nominally tosses off 0.5 volts. Now check out: http://tinyurl.com/y9y7fc7 In figure 1 of this data sheet we see a similarly rated standard junction device tosses off about .95 volts for the same conditions for a difference of about .5 volts. But for reasons I've cited many times in the past, I like the modular molded bridge rectifier blocks with fast-on tabs. They're cheap. They mount right to the airframe with no need for additional heat-sinking in most cases. Finally, they're internally insulated electrically from their mounting surfaces. Check out this data sheet: http://tinyurl.com/yzmpjbk In figure 5 we see that depending on the internal temperature of the device, we can expect voltage drops on the order of 0.6 to 0.7 at the same 2A loads. Further, the mono-block bridge with fast-on tabs offers a very robust, easy to wire, minimum risk for installation error solution for diode steering of energy around the ship's electrical system. The typical voltage drops experienced do not produce an observable degradation of performance. My preference for this class of diode has little to do with electrical performance . . . the little beasties are 25A plus rated devices and quite robust electrically for the way we use them. I judge them preferred for low cost, wide availability, mechanical convenience and minimum parts count. Bob . . . Read this topic online here: http://forums.matronics.com/viewtopic.php?p=272463#272463 ________________________________________________________________________________
Date: Nov 12, 2009
Subject: FOR SALE RV6A
FOR SALE RV6A This one is for sale because I am 74 and cant get my medical renewed. This plane is complete except for upholstery. And a D-10. It has an alternative engine in it that develops over 200 hp. $27,000 with engine $22,000 without. It has a Navaid device AP-1. wing leveler. Electric Flaps Both wing tips have strobes along with the regular lights. Wings have wig wags. Apollo GX65 Flaps are electric Tiedown rings. Lift Reserve Indicator. Lets you know when you are close to a stall. Military style portable flood. Can adjust to a spot. Can adjust to red or white light. Pilot stick has military style grip. With several switches that run trim. lights, mike etc. Wing tips are finished. Vertical tips are finished. Stabilizer tips are finished. Rudder tips are finished top and bottom. The instrument panel is upgraded to a fiberglass panel with two sub panels tilted toward pilot. Wings are finished with finished tips with all lights including strobes and landing lights. More than 1,000 invested in assembly. About $15,000 invested in firewall forward which is not for sale. Call Cecil at 805 402-5308 or e-mail at (cecilth(at)juno.com) for questions or to arrange to see in Ventura County, Southern California. ____________________________________________________________ Free College Information Connect to the online college that best fits your needs. http://thirdpartyoffers.juno.com/TGL2141/c?cp=NhNcxlOSOJV3HMi82aVsEAAAJ1CgTD6yWnN9nTOcXhzb7nn5AAQAAAAFAAAAAA4tAj8AAAMlAAAAAAAAAAAAAAAAAAJWaQAAAAA ________________________________________________________________________________
Subject: Re: FOR SALE RV6A
Date: Nov 12, 2009
What engine is in it? ------Original Message------ From: cecilth(at)juno.com Sender: owner-aeroelectric-list-server(at)matronics.com ReplyTo: aeroelectric-list(at)matronics.com Subject: AeroElectric-List: FOR SALE RV6A Sent: Nov 12, 2009 2:32 PM FOR SALE RV6A This one is for sale because I am 74 and cant get my medical renewed. This plane is complete except for upholstery. And a D-10. It has an alternative engine in it that develops over 200 hp. $27,000 with engine $22,000 without. It has a Navaid device AP-1. wing leveler. Electric Flaps Both wing tips have strobes along with the regular lights. Wings have wig wags. Apollo GX65 Flaps are electric Tiedown rings. Lift Reserve Indicator. Lets you know when you are close to a stall. Military style portable flood. Can adjust to a spot. Can adjust to red or white light. Pilot stick has military style grip. With several switches that run trim. lights, mike etc. Wing tips are finished. Vertical tips are finished. Stabilizer tips are finished. Rudder tips are finished top and bottom. The instrument panel is upgraded to a fiberglass panel with two sub panels tilted toward pilot. Wings are finished with finished tips with all lights including strobes and landing lights. More than 1,000 invested in assembly. About $15,000 invested in firewall forward which is not for sale. Call Cecil at 805 402-5308 or e-mail at (cecilth(at)juno.com) for questions or to arrange to see in Ventura County, Southern California. ____________________________________________________________ Free College Information Connect to the online college that best fits your needs. http://thirdpartyoffers.juno.com/TGL2141/c?cp=NhNcxlOSOJV3HMi82aVsEAAAJ1CgTD6yWnN9nTOcXhzb7nn5AAQAAAAFAAAAAA4tAj8AAAMlAAAAAAAAAAAAAAAAAAJWaQAAAAA Sent from my Verizon Wireless BlackBerry ________________________________________________________________________________
Date: Nov 12, 2009
Date: Nov 13, 2009
Subject: Some Very Nice Comments...
Dear Listers, I've been getting some really nice comments from Listers along with their List Support Contributions. I've shared some of them below. Please read them over and see what your fellow Listers think of the Lists and Forums. Please make a Contribution today to support the continued upgrade and operation of these services. There are lots of sweet gifts available, so browse the extensive selection and pickup a nice item along with your qualifying Contribution. http://www.matronics.com/contribution Thank you in advance for your generous support! It is very much appreciated! Best regards, Matt Dralle Matronics Email List Administrator ----------- What Listers Are Saying About The Lists ----------- Few things in life bring more usefulness than the List. This is worth every penny! Stephen T. I have enjoyed the list for way too many years, but continue to get closer to flying my project with the help of listers. C.L. Thanks for this List. It's been a great source of encouragement and information. Arden A. Great service! Gerald T. It's always interesting reading the lists and I've gotten some good help from the issues and answers there. Steve T. Been a member of the List for 12 years. Keep up the good work. John H. Great Site! Harry M. Great source of information... Martin H. Thanks for providing this great service! Jeff P. I continue to get and give information through these lists. Ralph C. This is a wonderful resource! Warren H. This is what inernet was meant for, sharing information and experience. Michael W. Thanks for making such a good list! Fred D. Thanks for running a great service! Michael F. I really appreciate it. Dan H. Thanks for the great service. Michael L. Thanks for maintaining this great resource. John C. Your sites have been a great resourses and an introduction to many competent aircraft designers and fabricators. Jon M. Thanks for all that you do to maintain the Matronics forums and for the personal help that you have been to me in answering my questions regarding the use of the forums. William B. [The List] helped me get flying, fly off my test hours and make my systems better. Ralph C. The Universe is a better place because of you. Eric J. ________________________________________________________________________________
Subject: Features
Date: Nov 13, 2009
Read E-Books and more... Features: - Same size as an original DS game cartridge - Built-in PassMe (NO need for any boot cart/passcard etc.) - Uses microSD memory card (Trans Flash) as storage. - Boot clean dump images (downloadable from internet) - Very simple to use: drag and drop files to the microSD card and play - Standard FAT system support - Supports different speeds of micro SD cards - Supports HC memory cards - Upgradable Firmware ( OS / Bios / Kernel ) - Touch screen control and robust skinning support - No battery needed, back up the save file directly into the microSD card - Auto detect the save type and automatically generate saver file - Homebrew support , IO lib available on launch - Supports WiFi, DS rumble pack and DS browser. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=272644#272644 ________________________________________________________________________________
Single Input
From: "gordonrsmith921(at)yahoo.com" <gordonrsmith921(at)yahoo.com>
Date: Nov 13, 2009
Bob wrote: Obviously, a pair of diodes could be used WITHOUT switches to provide an either/or energy path from two, always-on sources. In this case when the two always-on sources differ by a volt or two, for whatever reason, Do the sources provide power proportionally to their voltage or will it be a 100% feed from the highest voltage source? Gordon Smith Read this topic online here: http://forums.matronics.com/viewtopic.php?p=272667#272667 ________________________________________________________________________________
Date: Nov 13, 2009
to Single Input At 07:09 AM 11/13/2009, you wrote: > > >Bob wrote: >Obviously, a pair of diodes could be used WITHOUT switches to >provide an either/or energy path from two, always-on sources. > >In this case when the two always-on sources differ by a volt or two, >for whatever reason, Do the sources provide power proportionally to >their voltage or will it be a 100% feed from the highest voltage source? Great question. The highest voltage source will assume most if not all the total downstream load. The design goal for use of diodes in this manner is not to spread and share the load between two sources but to insure that the loads are supplied with energy irrespective of the condition for either source. I'm working an accident case where a couple of systems were combined downstream of a pair of diodes without modifying upstream protection to accommodate the SUM OF BOTH LOADS on EITHER energy source. This was but one design error that stacked on top of several others to bring an airplane full of folks to an unplanned arrival with the earth. The little things DO matter. Bob . . . --------------------------------------- ( It's MATRONICS FUND RAISER MONTH! ) ( Do your part to keep this marvelous ) ( tool sharp and available to all our ) ( brothers in the OBAM aviation ) ( community. ) --------------------------------------- ________________________________________________________________________________
Date: Nov 14, 2009
Bob, Was reviewing your article: <http://www.aeroelectric.com/articles/Failure_Detection_and_Annunciation.pdf>http://www.aeroelectric.com/articles/Failure_Detection_and_Annunciation.pdf Alan, sorry for the delay on this. I'm fielding input from the List on three different computers which scatters my to-answer list over three in-boxes. I have to scan the forum archives from time to time to make sure I don't have any dangling conversations! I want to annunciate the failure of a 12v scavenge pump to draw current. You mention such a circuit being used on a heated pitot but I was wondering if it mattered if the load was a pump motor? Full load would be approximately 5 amps and it needs to be running whenever the engine is running. I figured the LED would come on whenever I put power to the ECU and Ignition and would quickly go out if the scavenge pump was pulling power as it should. Thus, even if I "forgot" to flip the switch for the scavenge pump, the LED would illuminate until I did AND the pump was pulling power. Sounds like a plan Any problem with a motor as opposed to a resistance load? Any other things I should consider? There are many ways to deduce whether or not an accessory is drawing the expected current (and therefore assumed functional). Since your pump has a 100% duty cycle, perhaps it would be better to rig the annunciation such that you have a warning light which speaks to the pump NOT running. It's a human factors thing that an undesirable condition be annunciated by turning a light ON as opposed to watching to make sure a light doesn't turn OFF. The reed-switch current relay I illustrated in that article has been incorporated by the thousands in all manner of monitored systems for many years. A friend of mine has been manufacturing those sensors in a wide variety of current detection levels for decades. I would not discourage you from crafting a similar device . . . but they DO require a bit of tinkering on the bench to make sure that the reed is going to be closed when it's supposed to . . . Further, keep in mind that the warning light side of the sensor system needs to be powered from some source OTHER than power that runs the motor. You don't want a failure warning light to be dark just because the supply fuse/breaker is open. Further, you'll want to have a pre-flight test item that checks the light for operation by turning the pump switch OFF. Emacs! Power to the light doesn't need "protection" with fuse or breaker if you mount the resistor close to the bus-tap . . . the resistor's current limiting qualities protects the wiring. A 1K resistor can be installed in the source wire like . . . http://www.aeroelectric.com/articles/Homeless/Homeless_Components.htm Build your relay so that it pulls in with anything over 2A or so. http://jameco.com sells reed capsules. Bob . . . --------------------------------------- ( It's MATRONICS FUND RAISER MONTH! ) ( Do your part to keep this marvelous ) ( tool sharp and available to all our ) ( brothers in the OBAM aviation ) ( community. ) --------------------------------------- ________________________________________________________________________________
Subject: Solid Wire for Ground
Date: Nov 14, 2009
Hello! I didn't have any Tefzel stranded 10awg for the ground wire for about a 3' run from my panel ground to my firwall ground. The little bit of soldering I've done so far has been sorta fun, so I figured I'd use a piece of solid 10awg wire I had laying around (non-Tefzel). Into a noninsulated 8awg ring, I put this solid wire in plus a tiny piece of 12awg stranded wire to bulk up the space. Crimped it down good in a couple places, then soldered. Although the thicker wires took a bit longer to heat up, it eventually got there. I figure if it's a ground wire, it won't heat up and be a primary source of fire, poisoning me with the plastic coating. The other concern I have is the solid wire. I know it's susceptible to cracking if it's bent back and forth a few times in a tight radius. That's not the case here, as I'm using maybe 1" radius corners. Would this be okay to use just for the ground wire with no tight bends? -------- Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=272881#272881 ________________________________________________________________________________
Date: Nov 15, 2009
Subject: Re: Solid Wire for Ground
On 11/15/2009 1:51 AM, messydeer wrote: > I figure if it's a ground wire, it won't heat up and be a primary source of fire, poisoning me with the plastic coating. Hi Dan, Since there is just as much current flowing through the ground wire as the positive wire, it is possible for it to heat up as well. -Dj -- Dj Merrill - N1JOV Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Grumman Yankee Driver N9870L - http://deej.net/yankee/ ________________________________________________________________________________
Date: Nov 15, 2009
At 12:51 AM 11/15/2009, you wrote: > >Hello! > >I didn't have any Tefzel stranded 10awg for the ground wire for >about a 3' run from my panel ground to my firwall ground. The little >bit of soldering I've done so far has been sorta fun, so I figured >I'd use a piece of solid 10awg wire I had laying around >(non-Tefzel). Into a noninsulated 8awg ring, I put this solid wire >in plus a tiny piece of 12awg stranded wire to bulk up the space. >Crimped it down good in a couple places, then soldered. Although the >thicker wires took a bit longer to heat up, it eventually got there. > >I figure if it's a ground wire, it won't heat up and be a primary >source of fire, poisoning me with the plastic coating. The other >concern I have is the solid wire. I know it's susceptible to >cracking if it's bent back and forth a few times in a tight radius. >That's not the case here, as I'm using maybe 1" radius corners. >Would this be okay to use just for the ground wire with no tight bends? Use of solid wire is contrary to accepted practice in all manner of vehicle. It's recommended for stationary applications only. Where is your panel ground bus located? Is it mounted on or close to some panel support structure that is not subject to periodic removal from the airplane? Bob . . . --------------------------------------- ( It's MATRONICS FUND RAISER MONTH! ) ( Do your part to keep this marvelous ) ( tool sharp and available to all our ) ( brothers in the OBAM aviation ) ( community. ) --------------------------------------- ________________________________________________________________________________
Date: Nov 15, 2009
Thanks, guys :-) Sounds like I'll get some stranded wire for this. My panel ground is located on the under side of the permanantly mounted glare shield. It's a few inches away from the main buss block, whose piano hinge sections can be seen in the pic. Regarding the panel ground buss, I have used a section of the B&C forest of tabs. It would be convenient to rivet the brass block to the glare shield and use one of the tabs to connect to the firewall. Would using a faston for 10awg wire here be okay, or would it be better to solder it, or both? I'd rather not have an ugly bolt head on top of the glare shield. If I solder without the female faston, would I just drill a hole in one of the tabs big enough for the bare wire to go through and solder it like that? If soldering isn't as good as a ring to bolt connection, I'd prolly make a little standoff bracket for the panel ground. -------- Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=272920#272920 Attachments: http://forums.matronics.com//files/subpanel_progress2_207.jpg http://forums.matronics.com//files/ground_buss_and_cig_lighter_184.jpg ________________________________________________________________________________
Date: Nov 16, 2009
Subject: Contributions Down By 21%...
Dear Listers, As of today, contributions to the Matronics List Fund Raiser are lagging behind last year at this time by 21%. I have a fund raiser each year simply to cover my operating costs for the Lists. I *do not* accept any advertising income to support the Lists and rely solely on the contributions of members to keep the expenses paid. I run all of my own servers and they are housed here locally, and the Internet connection is a commercial-grade, T1 connection with public address space. I also maintain a full backup system that does nightly backups of all List-related data so that in the event of a server crash or worse, all of the Lists and the many years of List archive data could be restored onto a new server in a matter of hours. All of this costs a fair amount of money, not to mention a significant amount of my personal time as well. I have a Fund Raiser each year to cover these costs and I ask that members that feel they receive a benefit from my investments, make a modest contribution each year to support the continued operation and upgrade of these services. If you enjoy the Lists, please make a contribution today. I also offer some incentive gifts for larger contribution levels. At the Contribution Web Wite, you can use a credit card, Paypal, or personal check to show your support for the continuation of these services: http://www.matronics.com/contribution Thank you for your support! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Re: MaxPulse and MaxDim
Date: Nov 16, 2009
This is a good time to have another MaxDim and MaxPulse "Group Buy". Wholesale prices on Seaton Engineering products are being raised substantially on December 1. I set up a "Group Buy" almost a year ago for U.S. List members only, so here we go again... If you're looking for the most sophisticated panel dimmer for your project, the MaxDim is it. If you're looking for a sophisticated landing light controller for your project, check out the MaxPulse. So, through November 29, 2009 order as many as you want at samcoaviation.com and receive an $8 rebate off the posted price when you add the note "Aeroelectric List Group Buy" during check out. Rebates will be applied to your PayPal account after the order is placed because I have to do this manually. $3.35 shipping (+ sales tax in CA), but multiple unit orders will ship together and receive a shipping discount, too (added to rebate). These dimmers are unparalleled in performance... NO heat, NO separate, bulky control unit. NO heatsink. Amazing 350W power control in a 1.25" diameter unit. This is a best-of-breed product. Mooney has specified these for all their new planes! (STC and PMA) 5-35VDC, 12.5Amps and less than 1 ounce! Hook up power, ground, and lights (3 connections), 2 mounting holes to drill, and you're done. The 2 units in my Cessna have been installed for over a year, and still perform flawlessly. See the specs at samcoaviation.com Prices are already better than most dealers, plus now you get an additional $8 off each unit until Nov 29, 2009. Thanks, Phil RV7, Cessna 177 On Nov 4, 2009, at 1:32 AM, cherokee wrote: > Hey list members. Just thought I would let you all know that we > completed our installation of the MaxPulse and MaxDim units in our > 150, 4 months ago now. These things run cool and are a dream to > install. These correct so many problems we encounter as aircraft > owners. Like replacing the rheostats or the big dual dimmer that > costs $1200 from Cessna. Yikes. > You can see these at www.maxpulsemaxdim.com . > > I see another member is gathering a group together for a special buy > on the MaxDim, I think I will join in that effort for our other Cub. > > Mark > Eagle River, Alaska ________________________________________________________________________________
Date: Nov 16, 2009
Subject: Fuel pump control
I just came across a notation I made quite a while ago, after noticing a neat idea, probably on this list. It utilizes a low pressure switch to provide an "automatic" mode to the electric fuel boost pump, so that if the engine driven pump failed, the electric one would be powered up. This seemed like a great idea at the time. It would likely mean an engine hiccup, followed by the fuel pump on LED illuminating - much better than the pilot conjecturing the engine failure is due to fuel starvation and manually turning on the pump (would be a checklist item). However, looking at the schematic as I drew it, as soon as the electric pump provided sufficient pressure, the low pressure switch would open and the pump would shut off, and then back on, and then off. Ooops :-( Is it worth fabricating a little latching circuit to provide this automatic operation, or better to keep things simple ? I don't do hard IFR, and manually turning on the fuel pump switch in most circumstances would be sufficient to avoid an unpleasant landing. Thoughts ? Jeff Page Dream Aircraft Tundra #10 ________________________________________________________________________________
Date: Nov 16, 2009
Subject: Re: Fuel pump control
Instead of a pressure switch, how about a flow switch on the input side of the mechanical pump... Harley ------------------------------------------------------------------------ Jeff Page wrote: > > I just came across a notation I made quite a while ago, after noticing > a neat idea, probably on this list. > > It utilizes a low pressure switch to provide an "automatic" mode to > the electric fuel boost pump, so that if the engine driven pump > failed, the electric one would be powered up. > > This seemed like a great idea at the time. It would likely mean an > engine hiccup, followed by the fuel pump on LED illuminating - much > better than the pilot conjecturing the engine failure is due to fuel > starvation and manually turning on the pump (would be a checklist item). > > However, looking at the schematic as I drew it, as soon as the > electric pump provided sufficient pressure, the low pressure switch > would open and the pump would shut off, and then back on, and then > off. Ooops :-( > > Is it worth fabricating a little latching circuit to provide this > automatic operation, or better to keep things simple ? > > I don't do hard IFR, and manually turning on the fuel pump switch in > most circumstances would be sufficient to avoid an unpleasant landing. > > Thoughts ? > > Jeff Page > Dream Aircraft Tundra #10 > > ________________________________________________________________________________
Date: Nov 16, 2009
Hi Jeff, Another option would be to put a one way valve in the output of the engine driven pump. T the two lines together after the valve. I think some of the electric pumps provide a one way flow, but if not, you would need one there also to prevent the mechanical pump from bypassing the engine. I seem to recall a Faucet pump I had would flow backwards sometimes depending on where it stopped when it was turned off. Bob W. "Jeff Page" wrote: > > I just came across a notation I made quite a while ago, after noticing > a neat idea, probably on this list. > > It utilizes a low pressure switch to provide an "automatic" mode to > the electric fuel boost pump, so that if the engine driven pump > failed, the electric one would be powered up. > > This seemed like a great idea at the time. It would likely mean an > engine hiccup, followed by the fuel pump on LED illuminating - much > better than the pilot conjecturing the engine failure is due to fuel > starvation and manually turning on the pump (would be a checklist item). > > However, looking at the schematic as I drew it, as soon as the > electric pump provided sufficient pressure, the low pressure switch > would open and the pump would shut off, and then back on, and then > off. Ooops :-( > > Is it worth fabricating a little latching circuit to provide this > automatic operation, or better to keep things simple ? > > I don't do hard IFR, and manually turning on the fuel pump switch in > most circumstances would be sufficient to avoid an unpleasant landing. > > Thoughts ? > > Jeff Page > Dream Aircraft Tundra #10 > > > > > -- N93BD - Rotary Powered BD-4 - http://www.bob-white.com Now Rotary Powered Alpine http://www.youtube.com/watch?v=FwceNc2ydN8 Cables for your rotary installation - http://roblinstores.com/ ________________________________________________________________________________
Date: Nov 16, 2009
I thought perehileon design had a circuit for doing this, but in looking at there web site, I couldn't find it. Eric Jones monitors the list -- Eric? Bill Schertz ----- Original Message ----- From: "Harley" <harley(at)AgelessWings.com> Sent: Monday, November 16, 2009 11:30:35 AM GMT -06:00 US/Canada Central Subject: Re: AeroElectric-List: Fuel pump control Instead of a pressure switch, how about a flow switch on the input side of the mechanical pump... Harley Jeff Page wrote: I just came across a notation I made quite a while ago, after noticing a ne at idea, probably on this list. It utilizes a low pressure switch to provide an "automatic" mode to the ele ctric fuel boost pump, so that if the engine driven pump failed, the electr ic one would be powered up. This seemed like a great idea at the time.=C2- It would likely mean an en gine hiccup, followed by the fuel pump on LED illuminating - much better th an the pilot conjecturing the engine failure is due to fuel starvation and manually turning on the pump (would be a checklist item). However, looking at the schematic as I drew it, as soon as the electric pum p provided sufficient pressure, the low pressure switch would open and the pump would shut off, and then back on, and then off.=C2- Ooops :-( Is it worth fabricating a little latching circuit to provide this automatic operation, or better to keep things simple ? I don't do hard IFR, and manually turning on the fuel pump switch in most c ircumstances would be sufficient to avoid an unpleasant landing. Thoughts ? Jeff Page Dream Aircraft Tundra #10 ________________________________________________________________________________
Date: Nov 16, 2009
It is pretty simple to do this if you use a fuel pump and relay coil that require the same voltage. Use a pressure sensor to control the relay. Connect the relay output to the fuel pump AND to the relay coil (input). That way when the fuel pump comes on (due to a low pressure signal), the relay locks itself on, regardless of the state of the pressure sensor. To turn the pump off, you would have a momentary switch in the circuit that would break the connection to the relay coil. This used to be called a "seal-in" circuit for industrial controls. Steve Ruse > Jeff Page wrote: > > > I just came across a notation I made quite a while ago, after > noticing a neat idea, probably on this list. > > It utilizes a low pressure switch to provide an "automatic" mode to > the electric fuel boost pump, so that if the engine driven pump > failed, the electric one would be powered up. > > This seemed like a great idea at the time. It would likely mean an > engine hiccup, followed by the fuel pump on LED illuminating - much > better than the pilot conjecturing the engine failure is due to fuel > starvation and manually turning on the pump (would be a checklist > item). > > However, looking at the schematic as I drew it, as soon as the > electric pump provided sufficient pressure, the low pressure switch > would open and the pump would shut off, and then back on, and then > off. Ooops :-( > > Is it worth fabricating a little latching circuit to provide this > automatic operation, or better to keep things simple ? > > I don't do hard IFR, and manually turning on the fuel pump switch in > most circumstances would be sufficient to avoid an unpleasant > landing. > > Thoughts ? > > Jeff Page > Dream Aircraft Tundra #10 > > ________________________________________________________________________________
Date: Nov 16, 2009
Jeff, << low pressure switch to provide an "automatic" mode to the electric fuel boost pump, so that if the engine driven pump failed, the electric one would be powered up. ... It would likely mean an engine hiccup, followed by the fuel pump on LED illuminating - as soon as the electric pump provided sufficient pressure, the low pressure switch would open and the pump would shut off, and then back on, and then off. Ooops :-( >> My circuit published in the May 2008 issue of Kitplanes magazine will do what you describe including switch conditioning and relay driving. It is a simple programmable timer. Set it to run for say 4 minutes. This gives you plenty of time to notice the LED and turn on the manual pump switch. You would need some blocking diodes for the manual switch and a cockpit accessible fuse/circuit breaker to be able to override a stuck-on failure. With the system you describe there should not be an engine hiccup. When the fuel pressure starts to drop there is still a bowl's worth of fuel in the carburetor. The pressure switch should turn on the pump and refill the carb long before the bowl is depleted. Email me off list and I'll send you a revised schematic for this function. Tom ________________________________________________________________________________
Date: Nov 16, 2009
Subject: Please review my electrical system (Deviation of Z-13)
List, I've been working on the wiring diagram for my airplane (electric panel, IFR, plane power internally regulated main alt and a SD-8 backup). So I've been reading though Bob's book and am familiar with the Z-13 wiring diagram, however there are a two things about it that I don't like: 1. It is possible to turn on both alternators at once. It is my understanding that you don't want to have both alternators online at once and I don't want the pilot to be able to cause damage by not using the correct switches. 2. Alternate feed switches. Feed switches seem cumbersome since it requires the pilot to know something about the electrical system. I think I have a new wiring diagram that addresses these things, but I want to run it past this list and perhaps Bob so that others can help me find the problems. Here is how it works: The avionics bus is treated like the endurance bus since the avionics are the only things I care about if my alternator fails (I have mags and a mechanical fuel pump.) When the master switch is on, the battery pulls the battery contactor which brings the main alternator and battery into the system. Should something happen to the main alternator the battery will continue to power the system unless I switch the ALT switch to AUX. When the alternator switch is on AUX it takes out the main alt and powers up the SD-8 wired up with the self exciting hack. This will allow my aux alternator to power the avionics bus (when the Avionics master is on AUX) but will keep my master contactor and battery separate from the rest of the system. In the event that I want to charge my main battery I can turn the master switch off which will then allow me to charge my battery should I desire to try and bring the main alternator back after a dead battery. In order to clear up any confusion here are the basic switches, settings, and mode of operation: Master: on, Alt: main, Avionics: main; Normal operation running on the main alternator and battery. Master on, Alt: Aux, Avionics: Main; Aux alternator is online and master alternator is offline, battery is powering everything. Master on, Alt: Aux, Avionics: Aux; Aux alternator is powering avionics, main alternator is offline, and battery is powering everything except avionics. Master off, Alt: Main, Avionics: main; Nothing is powered up. Master off, Alt: aux, Avionics: main; Avionics are off, Aux alternator is online and is charging the battery. Master Off, Alt: aux, Avoinics: aux; Avionics are on aux alternator, aux alternator is online and is charging the battery. Perhaps it would be more intuitive if I name the switches like this: Battery: On | Off (Aux Charge) Alternator : MAIN | AUX Avionics: MAIN | OFF | AUX This setup reduces the panel down to 3 switches and gives the operator good control over the system, allows for the battery to be isolated or charged from the aux alternator, and gives a way for non critical devices to run off the battery. If this doesn't look sane to you please post some feedback. Any help I can get is greatly appreciated. Thanks, schu ________________________________________________________________________________
Date: Nov 17, 2009
Subject: Re: Please review my electrical system (Deviation
of Z-13) ________________________________________________________________________________
Date: Nov 17, 2009
The RV-12 has a mechanical fuel pump on the engine and an electrical fuel pump near the fuel tank. The electric fuel pump runs continuously whenever the master switch is on. There is no discrete switch for the electric fuel pump. The pre-flight check is to turn on the master switch and observe the fuel pressure to be sure the electric pump is working. Then start the engine and watch for an increase in fuel pressure to be sure that the mechanical fuel pump is also working. Yes, it wastes electricity and wears out the electric fuel pump. On the other hand, most automotive fuel pumps last the life of the vehicle. Airplanes are used a lot less then cars. I would not expect the electric fuel pump in the RV-12 to wear out soon. The big advantage of wiring the electric fuel pump to run continuously is that it helps to prevent mismanagement of the fuel system, a major cause of accidents. The RV-12 fuel system does not have a fuel selector valve because there is only one fuel tank. There is no mixture control. The only thing for the pilot to mismanage is the emergency fuel shut-off valve handle that is located on the floor. The handle must be pulled up to shut off. The simpler the system is, the less chance for malfunction or error. Joe ________________________________________________________________________________
Date: Nov 17, 2009
of Z-13) I investigated this earlier and this is what I found: 1. No harm is done with both alternators online. The theory that there is a problem stems from twin engine systems with elaborate schemes to deal with 2 alternators. I am using Z-13/8 and there are only 3 switches: Main: (off)- (battery contactor)-(battery+main alternator) Aux feed: (off)-(on) Aux Alt: (off)-(on) The endurance bus can be powered by: Battery only Battery + Main Alternator Battery + Aux Alternator Aux Alternator only The Aux Feed provides a path that does not include the battery contactor. Hope this helps, John Morgensen Grumman AA1B 150hp - For Sale RV4 - Flying RV9A - wiring Matthew Schumacher wrote: > List, > > I've been working on the wiring diagram for my airplane (electric panel, > IFR, plane power internally regulated main alt and a SD-8 backup). So > I've been reading though Bob's book and am familiar with the Z-13 wiring > diagram, however there are a two things about it that I don't like: > > 1. It is possible to turn on both alternators at once. It is my > understanding that you don't want to have both alternators online at > once and I don't want the pilot to be able to cause damage by not using > the correct switches. > > 2. Alternate feed switches. Feed switches seem cumbersome since it > requires the pilot to know something about the electrical system. > > I think I have a new wiring diagram that addresses these things, but I > want to run it past this list and perhaps Bob so that others can help me > find the problems. > > Here is how it works: > > The avionics bus is treated like the endurance bus since the avionics > are the only things I care about if my alternator fails (I have mags and > a mechanical fuel pump.) When the master switch is on, the battery > pulls the battery contactor which brings the main alternator and battery > into the system. Should something happen to the main alternator the > battery will continue to power the system unless I switch the ALT switch > to AUX. When the alternator switch is on AUX it takes out the main alt > and powers up the SD-8 wired up with the self exciting hack. This will > allow my aux alternator to power the avionics bus (when the Avionics > master is on AUX) but will keep my master contactor and battery separate > from the rest of the system. In the event that I want to charge my main > battery I can turn the master switch off which will then allow me to > charge my battery should I desire to try and bring the main alternator > back after a dead battery. > > In order to clear up any confusion here are the basic switches, > settings, and mode of operation: > > Master: on, Alt: main, Avionics: main; Normal operation running on the > main alternator and battery. > > Master on, Alt: Aux, Avionics: Main; Aux alternator is online and master > alternator is offline, battery is powering everything. > > Master on, Alt: Aux, Avionics: Aux; Aux alternator is powering avionics, > main alternator is offline, and battery is powering everything except > avionics. > > Master off, Alt: Main, Avionics: main; Nothing is powered up. > > Master off, Alt: aux, Avionics: main; Avionics are off, Aux alternator > is online and is charging the battery. > > Master Off, Alt: aux, Avoinics: aux; Avionics are on aux alternator, aux > alternator is online and is charging the battery. > > Perhaps it would be more intuitive if I name the switches like this: > > Battery: On | Off (Aux Charge) > Alternator : MAIN | AUX > Avionics: MAIN | OFF | AUX > > This setup reduces the panel down to 3 switches and gives the operator > good control over the system, allows for the battery to be isolated or > charged from the aux alternator, and gives a way for non critical > devices to run off the battery. > > If this doesn't look sane to you please post some feedback. Any help I > can get is greatly appreciated. > > Thanks, > schu > > ________________________________________________________________________________
Subject: Re: Please review my electrical system (Deviation of
Z-13)
Date: Nov 17, 2009
Schu, It is easier for me to visualize a circuit by looking at an electrical schematic rather than reading about it. If I understand correctly, you intend to have one switch control two alternators. It seems like a single point of failure. What happens when the switch fails? Switches probably fail about as often as alternators. It is my understanding that it will not hurt to have two alternators on line at once. Power will be drawn from the one with the highest voltage. Bob will correct me if I am wrong. Having one switch for the avionics is also a single failure point. In Z-13/8, inadvertently turning on both the master switch and the E-Bus Alternate feed switch will not hurt anything. The Endurance Bus will draw from the highest voltage source. After engine shut down, it is important to remember to shut off both the master switch and the E-Bus Alternate Feed switch. Keeping the electrical controls simple is a worthwhile goal. Having options in case of a failure is another worthwhile goal. Aircraft design is a matter of compromises. It is hard to improve on Bob's designs. They have been scrutinized by many and have evolved over the years. Joe ________________________________________________________________________________
Date: Nov 17, 2009
Thanks for everyone's replys. The following is exactly the trick I was hoping for ! Jeff Page Dream Aircraft Tundra #10 > From: Steve Ruse <steve(at)wotelectronics.com> > Subject: Re: AeroElectric-List: Fuel pump control >> > It is pretty simple to do this if you use a fuel pump and relay coil > that require the same voltage. Use a pressure sensor to control the > relay. Connect the relay output to the fuel pump AND to the relay > coil (input). That way when the fuel pump comes on (due to a low > pressure signal), the relay locks itself on, regardless of the state > of the pressure sensor. To turn the pump off, you would have a > momentary switch in the circuit that would break the connection to the > relay coil. This used to be called a "seal-in" circuit for industrial > controls. > > Steve Ruse ________________________________________________________________________________
Subject: EFIS backup battery switch wiring
Date: Nov 17, 2009
Hello :-) I have an MGL Enigma EFIS and will put in a backup battery. In regular operation, both the main and backup battery are to be wired to the EFIS. The Enigma automatically switches to backup when it senses a main battery low voltage. I was thinking of maybe some wiring of a 2-10 that would do the following: Down position: main buss to EFIS. Middle position: backup battery to EFIS (for backup battery check) Up position: both batteries to EFIS. Or maybe just a two position switch, one position would be for both batteries, the other just to the backup. The backup check position could be a momentary on, I suppose, that just takes the main battery offline. Hold it in this position and see if the EFIS still works, then release. -------- Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=273305#273305 ________________________________________________________________________________
Subject: Re: EFIS backup battery switch wiring
Date: Nov 17, 2009
Well, I got one possibility figured out using a 2-10. Figure attached. -------- Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=273310#273310 Attachments: http://forums.matronics.com//files/enigma_efis_backup_switch_wiring_with_2_10_162.pdf ________________________________________________________________________________
Date: Nov 17, 2009
With one switch you are putting all your eggs (and faith) in a single point of failure. What use is having emergency backup power if you can not use it if the only switch is broken? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=273314#273314 ________________________________________________________________________________
Z-13)
Date: Nov 17, 2009
Oops my mistake, there was no schematic in the daily digest that is emailed to me. Now I see it on the online forum. Most aircraft have the battery contactor and starter contactor wired in series so that the starter can be shut off in case it welds shut. There is no way to disconnect the main alternator from the battery. Moving the alternator wire to the other side of the battery contactor will fix both issues. Will the avionics momentarily lose power when the avionics master switch is operated? Do the master switch and alternator switch have a center off position? There needs to be a way to kill power in case of smoke in the cockpit. Most pilots are familiar with switches being off when in the down position. Switches that accomplish your goals are available that are off when down. The 22mfd capacitor should be 22,000mfd. There is a hot wire from the battery to master switch terminal 5. If it starts smoking inside of the cockpit, there is no way to shut it off. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=273318#273318 ________________________________________________________________________________
Date: Nov 17, 2009
Dan, Turn the master on, turn the EFIS on . Turn the master off. If EFIS remains on the systemn works. Don VS RV7 flying ---- messydeer wrote: > > Well, I got one possibility figured out using a 2-10. Figure attached. > > -------- > Dan > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=273310#273310 > > > > > Attachments: > > http://forums.matronics.com//files/enigma_efis_backup_switch_wiring_with_2_10_162.pdf > > > > > > > ________________________________________________________________________________
Date: Nov 17, 2009
of Z-13) At 08:52 AM 11/17/2009, you wrote: > >I investigated this earlier and this is what I found: > >1. No harm is done with both alternators online. The theory that >there is a problem stems from twin engine systems with elaborate >schemes to deal with 2 alternators. Correct . . . and the "problem" was that light twins fitted with alternators were plagued with inability to make two alternators PARALLEL . . . i.e. share total loads. I've developed several approaches to alternator paralleling. Quite frankly, if you have TWO alternators capable of carrying most if not all of total system loads, then Z-14 and NO paralleling is the better way to go. But the system is not placed at risk by having two alternators on at the same time. Unless they are calibrated to within millivolts of each other, the device with the higher set-point "hogs" the load until it reaches its output limit. The bus voltage then sags until the alternator with the lower setpoint picks up the difference. Bob . . . --------------------------------------- ( It's MATRONICS FUND RAISER MONTH! ) ( Do your part to keep this marvelous ) ( tool sharp and available to all our ) ( brothers in the OBAM aviation ) ( community. ) --------------------------------------- ________________________________________________________________________________
Date: Nov 17, 2009
Turns out I had the wiring to the EFIS wrong. There are separate terminals for the backup and main power inputs, so I've redrawn it. It looks like if I forgot to turn off the EFIS switch, my backup battery would run dead. But I suppose I otta notice that my screen is still powered up. I would think that would be pretty obvious. -------- Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=273325#273325 Attachments: http://forums.matronics.com//files/enigma_efis_backup_switch_wiring_with_2_10_150.pdf ________________________________________________________________________________
Date: Nov 17, 2009
>I have an MGL Enigma EFIS and will put in a backup battery. In >regular operation, both the main and backup battery are to be wired >to the EFIS. The Enigma automatically switches to backup when it >senses a main battery low voltage. > >I was thinking of maybe some wiring of a 2-10 that would do the >following . . . What does the manufacturer of the EFIS system recommend? Bob . . . --------------------------------------- ( It's MATRONICS FUND RAISER MONTH! ) ( Do your part to keep this marvelous ) ( tool sharp and available to all our ) ( brothers in the OBAM aviation ) ( community. ) --------------------------------------- ________________________________________________________________________________
Date: Nov 17, 2009
Thanks, Bob. >From the manual: "...One power switch for the main incoming 12 or 24 V feed (switch in positive supply lead), another for the backup battery. In flight, both switches would be on allowing the charging of the backup battery. Preflight check would involve switching main power on, then battery power on. Check of battery power would involve switching main power off and verifying that Enigma continues to operate. Voltage on the backup battery should be measured by means of the backup voltage readouts which can be placed on any display..." Imaged referred to attached. -------- Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=273357#273357 Attachments: http://forums.matronics.com//files/mgl_enigma_odyssey_installation_198.bmp ________________________________________________________________________________
Date: Nov 17, 2009
In simple terms... if the backup battery is not on its own switch it won't charge. Two switches is simple. Trying to find a special switch to do all things at once leaves you with a non-common fix if it fails away from your home airport..... Two switches lets you troubleshoot power problems, and lets the EFIS be powered fully during a voltage drop, like during an engine start. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=273386#273386 ________________________________________________________________________________
Date: Nov 17, 2009
Thanks, E., for bringing up the issue of single point of failure. Hadn't thought about that, which makes me ask some questions about DPDT vs SPST switches. Looking at the schematic of a DPDT switch it looks like there are two circuits, an upper and a lower. Their terminals are separate but contained in the same housing. They also use the same lever and the mechanism the lever connects to that makes and brakes the contacts. If the only way a switch failed was through these shared components, then a DPDT would have the same reliability as a SPST, so there would be a single point of failure. And if DPDT's never failed at these shared components, then having one DPDT would be just as reliable as having two SPST's, and there wouldn't be a single point of failure. I'm sure the truth lies somewhere between these two extremes. If it turns out that a DPDT has 90% of the reliabilty as two SPST's, I might stick with just one DPDT. If it has only 20% of the reliabilty of two SPST's, I might consider going with two switches. -------- Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=273392#273392 ________________________________________________________________________________
Date: Nov 17, 2009
From: "Richard E. Tasker" <retasker(at)optonline.net>
The issue is not so much about what the relative reliability is. The issue is that if the DPDT switch fails you may not be able to connect to either source of electrons. If one of the SPST switches fails, you always have the other one. Dick Tasker messydeer wrote: > > Thanks, E., for bringing up the issue of single point of failure. Hadn't thought about that, which makes me ask some questions about DPDT vs SPST switches. > > Looking at the schematic of a DPDT switch it looks like there are two circuits, an upper and a lower. Their terminals are separate but contained in the same housing. They also use the same lever and the mechanism the lever connects to that makes and brakes the contacts. > > If the only way a switch failed was through these shared components, then a DPDT would have the same reliability as a SPST, so there would be a single point of failure. > > And if DPDT's never failed at these shared components, then having one DPDT would be just as reliable as having two SPST's, and there wouldn't be a single point of failure. > > I'm sure the truth lies somewhere between these two extremes. If it turns out that a DPDT has 90% of the reliabilty as two SPST's, I might stick with just one DPDT. If it has only 20% of the reliabilty of two SPST's, I might consider going with two switches. > > -------- > Dan > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=273392#273392 > > > ________________________________________________________________________________
Date: Nov 17, 2009
What are the consequences of failure of both poles in that switch, given how you will operate the aircraft (day/night and VFR/IFR) and the backups you have installed? If you are certain that you will be able to safely get the aircraft on the ground with an acceptable workload, then the potential single point failure is acceptable. Kevin Horton Sent from my iPod On 2009-11-17, at 10:36 PM, "messydeer" wrote: > > > > Thanks, E., for bringing up the issue of single point of failure. > Hadn't thought about that, which makes me ask some questions about > DPDT vs SPST switches. > > Looking at the schematic of a DPDT switch it looks like there are > two circuits, an upper and a lower. Their terminals are separate but > contained in the same housing. They also use the same lever and the > mechanism the lever connects to that makes and brakes the contacts. > > If the only way a switch failed was through these shared components, > then a DPDT would have the same reliability as a SPST, so there > would be a single point of failure. > > And if DPDT's never failed at these shared components, then having > one DPDT would be just as reliable as having two SPST's, and there > wouldn't be a single point of failure. > > I'm sure the truth lies somewhere between these two extremes. If it > turns out that a DPDT has 90% of the reliabilty as two SPST's, I > might stick with just one DPDT. If it has only 20% of the reliabilty > of two SPST's, I might consider going with two switches. > > -------- > Dan > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=273392#273392 > > ________________________________________________________________________________
Date: Nov 18, 2009
There is one quite important thing to note, no matter how one wires the switches (I used two DPST switches in the Sling - one for the power to the Enigmas and one to the backup batteries)- that is that the backups will not charge unless the voltage to them is sufficiently high. Obvious of course, but where this becomes a problem is if you have a diode between your main bus and the e-bus. You get a 0.7v drop across it and then there are some voltage drops inside the Enigma and the backup batt gets a voltage of between 12.5 -13v. To solve this we now run the aircraft with the e-bus alt feed permanently on, which boosts the e-bus voltage back up sufficiently to charge the backup battery. Jay -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Kevin Horton Sent: 18 November 2009 06:43 AM Subject: Re: AeroElectric-List: Re: EFIS backup battery switch wiring What are the consequences of failure of both poles in that switch, given how you will operate the aircraft (day/night and VFR/IFR) and the backups you have installed? If you are certain that you will be able to safely get the aircraft on the ground with an acceptable workload, then the potential single point failure is acceptable. Kevin Horton Sent from my iPod On 2009-11-17, at 10:36 PM, "messydeer" wrote: > > > > Thanks, E., for bringing up the issue of single point of failure. > Hadn't thought about that, which makes me ask some questions about > DPDT vs SPST switches. > > Looking at the schematic of a DPDT switch it looks like there are > two circuits, an upper and a lower. Their terminals are separate but > contained in the same housing. They also use the same lever and the > mechanism the lever connects to that makes and brakes the contacts. > > If the only way a switch failed was through these shared components, > then a DPDT would have the same reliability as a SPST, so there > would be a single point of failure. > > And if DPDT's never failed at these shared components, then having > one DPDT would be just as reliable as having two SPST's, and there > wouldn't be a single point of failure. > > I'm sure the truth lies somewhere between these two extremes. If it > turns out that a DPDT has 90% of the reliabilty as two SPST's, I > might stick with just one DPDT. If it has only 20% of the reliabilty > of two SPST's, I might consider going with two switches. > > -------- > Dan > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=273392#273392 > > ________________________________________________________________________________
Date: Nov 18, 2009
Subject: What's My Contribution Used For?
Dear Listers, Some have asked, "What's my Contribution used for?" and that's a good question. Here are just a few examples of what your direct List support enables. It provides for the very expensive, commercial-grade T1 Internet connection used on the List insuring maximum performance and minimal contention when accessing List services. It pays for the regular system hardware and software upgrades enabling the highest performance possible for services such as the Archive Search Engine, List Browser, and Forums. It pays for narly 20 years (yeah, I really said *20* years) worth of online archive data available for instant random search and access. And, it offsets the many hours spent writing, developing, and maintaining the custom applications that power this List Service such as the List Browse, Search Engine, Forums, and Wiki. But most importantly, your List Contribution enables a forum where you and your peers can communicate freely in an environment that is free from moderation, censorship, advertising, commercialism, SPAM, and computer viruses. How many places on the Internet can you make all those statements these days? It is YOUR CONTRIBUTION that directly enables these many aspects of these valuable List services. Please support it today with your List Contribution. Its one of the best investments you can make in your Sport... List Contribution Web Site: http://www.matronics.com/contribution Thank you for your support! Matt Dralle Email List Administrator ________________________________________________________________________________
Date: Nov 18, 2009
When crafting your project's electrical system architecture it would be helpful to be aware of the marketplace for to which avionics suppliers deliver most of their products. 99.9% of all light aircraft built feature an architecture that has not changed materially in 40+ years when the avionics bus and master switch was added to protect transistors from will-o'-the-wisp spikes. Those same aircraft are largely owned and operated by individuals who know little if any more about their airplanes than they do about their cars. Further, even if they knew and understood a great deal about them, they would not be permitted by regulation to make any meaningful improvements upon them. Phrases like "failure tolerance", "meeting design goals", and "artful preventative maintenance for maintenance of system reliability" might just as well be spoken in Swahili. Now we have the starry-eyed entrepreneur who tailors a product for best-fit into spam-can/ FAA-trained aviation. Not only is the product marketed and sold as the greatest accessory since sliced bread, it may include a suite of "back up" features designed to ward of a host of failures uncomfortable to contemplate. Internal back up batteries are popular. Keep in mind that internal batteries MIGHT make sense in the spam-can/FAA-trained world of flight . . . but we're OBAM aviation. We can craft power sources that are exceedingly robust. In fact so robust that flight-critical systems are more likely to become unavailable due to internal failure than for lack of ship's power. Staying true to our design goals for failure tolerance: If your are PLANNING for any accessory to be critical to comfortable completion of flight, then your plan-B for failure of that device needs to go BEYOND any need for ship's power. If you have a system like Z-13/8 (and assuming further that you exercise due diligence for battery maintenance) then the probability of the E-bus ever becoming un-powered in flight is on the same order as prop bolt failure. At the same time, probability of some flight critical system going down for for reasons OTHER than power failure is decidedly higher. With that reasoning in mind I'll suggest that fussing over the optimum back-up battery installation for any accessory is a distraction from the real task of crafting a failure tolerant system. If it were my airplane, I'd go for Z-13/8, ditch the internal back-up batteries and figure out how I'm going to comfortably deal with a failure of the LEDs that light up the screen or a rate sensor that goes south, etc. etc. Bob . . . --------------------------------------- ( It's MATRONICS FUND RAISER MONTH! ) ( Do your part to keep this marvelous ) ( tool sharp and available to all our ) ( brothers in the OBAM aviation ) ( community. ) --------------------------------------- ________________________________________________________________________________
Subject: Need advice on Z16 5amp circuit breaker
Date: Nov 18, 2009
Ref Z16 schematic. There is a 5 amp circuit breaker on the wire from the main bus to the S700-2-10 Master. Can I use an in line 5 amp fuse. I would appreciate the advice. Thanks.....Geoff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=273560#273560 ________________________________________________________________________________
Date: Nov 18, 2009
Subject: Re: Need advice on Z16 5amp circuit breaker
At 12:20 PM 11/18/2009, you wrote: > >Ref Z16 schematic. There is a 5 amp circuit breaker on the wire from >the main bus to the S700-2-10 Master. Can I use an in line 5 amp >fuse. I would appreciate the advice. Thanks.....Geoff You're apparently unaware of why the breaker is even there . . . The Z-figures are intended to display various ARCHITECTURES, not recommended wiring diagrams and bills-of-materials. In the case of Z-16, it shows the use of fuseblocks in combination with a CROWBAR over voltage protection system. A panel re-setable breaker is one of the installation requirements for a crowbar ov protection system. So when combining with fuseblocks, the solitary breaker illustrated is part of the system integration task. Now, if your choice of power distribution protection is breakers instead of fuses then the 5A breaker would be right on the bus and labeled ALT FIELD. If you're going to use some form of field disconnect ov protection system, then yes, the 5A breaker could be a fuse . . . but not an in-line . . . it would be one of many fuses on the main bus. The simple answer to your question depends on the combination of components you're planning to use. In all cases, an in-line fuse is not a recommended substitute in any case. If you're using fuse blocks AND have crowbar ov protection, then you need the breaker as suggested. Bob . . . --------------------------------------- ( It's MATRONICS FUND RAISER MONTH! ) ( Do your part to keep this marvelous ) ( tool sharp and available to all our ) ( brothers in the OBAM aviation ) ( community. ) --------------------------------------- ________________________________________________________________________________
Date: Nov 18, 2009
Subject: Matronics Fund Raiser
The month is half-gone and Matt's receipts are running about 20% behind last year . . . while the costs of maintaining his system have, no doubt, gone up. If you haven't already contributed to this worthy cause, please do so. $5 will barely buy a lunch at McD's. There are 1800+ folks subscribing to this List alone . . . . a $5 donation from each of us would make sure that this magnificent system stays healthy. It just takes a few minutes to insure continuance of a system that supports tens of thousands of person-hours per year in volunteer effort. Bob . . . --------------------------------------- ( It's MATRONICS FUND RAISER MONTH! ) ( Do your part to keep this marvelous ) ( tool sharp and available to all our ) ( brothers in the OBAM aviation ) ( community. ) --------------------------------------- ________________________________________________________________________________
Date: Nov 18, 2009
Bob, Questions about the field breaker are a relatively common. I know you cover the reasoning for the breaker in the discussion about over voltage protection but it seems there ends up being a disconnect when people look at the Z diagrams. I kind of suspect that many more people look at the Z diagrams (seeking a wiring diagram/recipe) than read all parts of the Aeroelectric connection book, so some may miss the part about crowbars, etc. I see that you have a descriptive note (18) regarding the crowbar module.. Maybe it would help people if there were an additional note next to the field breaker that said something about this being part of the crowbar OV circuit functionality - maybe refer to your discussion about controlling alternators. I realize you don't mind answering the same question multiple times (in the interest of educating an ever changing classroom), but this could be a place where a tiny amount of additional documentation speeds the whole process. Regards, Matt- > > > At 12:20 PM 11/18/2009, you wrote: >> >> >>Ref Z16 schematic. There is a 5 amp circuit breaker on the wire from >>the main bus to the S700-2-10 Master. Can I use an in line 5 amp >>fuse. I would appreciate the advice. Thanks.....Geoff > > You're apparently unaware of why the breaker is even there . . . > > The Z-figures are intended to display various ARCHITECTURES, > not recommended wiring diagrams and bills-of-materials. In > the case of Z-16, it shows the use of fuseblocks in combination > with a CROWBAR over voltage protection system. A panel re-setable > breaker is one of the installation requirements for a crowbar > ov protection system. So when combining with fuseblocks, the > solitary breaker illustrated is part of the system integration > task. > > Now, if your choice of power distribution protection is > breakers instead of fuses then the 5A breaker would be > right on the bus and labeled ALT FIELD. If you're > going to use some form of field disconnect ov protection > system, then yes, the 5A breaker could be a fuse . . . but > not an in-line . . . it would be one of many fuses on the > main bus. > > The simple answer to your question depends on the > combination of components you're planning to use. In > all cases, an in-line fuse is not a recommended > substitute in any case. If you're using fuse blocks > AND have crowbar ov protection, then you need the breaker > as suggested. > > > Bob . . . > > --------------------------------------- > ( It's MATRONICS FUND RAISER MONTH! ) > ( Do your part to keep this marvelous ) > ( tool sharp and available to all our ) > ( brothers in the OBAM aviation ) > ( community. ) > --------------------------------------- > > ________________________________________________________________________________
Date: Nov 18, 2009
Thanks for the info Bob. Correct. I did not know why it is there......Geoff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=273584#273584 ________________________________________________________________________________
Date: Nov 19, 2009
At 11:20 AM 11/15/2009, you wrote: > >Thanks, guys :-) > >Sounds like I'll get some stranded wire for this. My panel ground is >located on the under side of the permanantly mounted glare shield. >It's a few inches away from the main buss block, whose piano hinge >sections can be seen in the pic. > >Regarding the panel ground buss, I have used a section of the B&C >forest of tabs. It would be convenient to rivet the brass block to >the glare shield and use one of the tabs to connect to the firewall. >Would using a faston for 10awg wire here be okay, or would it be >better to solder it, or both? I'd rather not have an ugly bolt head >on top of the glare shield. > >If I solder without the female faston, would I just drill a hole in >one of the tabs big enough for the bare wire to go through and >solder it like that? > >If soldering isn't as good as a ring to bolt connection, I'd prolly >make a little standoff bracket for the panel ground. The common point ground for stuff mounted on the instrument panel generally needs a LOT of places to attach ground wires. Further, these are seldom larger wires than 20AWG. This is why the D-Sub ground connector was proposed. http://aeroelectric.com/Pictures/Grounding/AVG_RA.jpg http://aeroelectric.com/Pictures/Grounding/Avionics_Bus_3.jpg This technique is much more compact than the forest-of-tabs product . . . and is best located on the panel - centrally located to the majority of devices requiring ground attachments. You can fabricate your own ground connector using techniques illustrated here http://aeroelectric.com/Pictures/Grounding/Minibus1.jpg http://aeroelectric.com/Pictures/Grounding/Minibus2.jpg This example was produced to offer a means by which lots of instrument lights could be connected to a single dimmer. Obviously, if used only as a single point ground, you don't need two-circuits on the connector. Solder TWO 12AWG grounds to the row of pins and terminate each 12AWG on it's own tab at the forest-of-tabs block on the firewall. Bob . . . ________________________________________________________________________________
Date: Nov 19, 2009
Thanks, Bob :-) I will only have 8 or 10 wires to ground in the panel. The section of tab forest for the panel ground has 20 tabs. I may need to get D-Sub tools, supplies, and skills for installing my not-yet-bought radio, but that's down the road a bit. Even if I had the stuff for it, it would only save me a little space, which surprisingly isn't much of an issue in this particular case. My ground blocks consist of one 48 tab ground block from B&C cut into three sections. 12 tabs are on the forward side of the firewall, 16 tabs on the rear side with a bolt and rivet connecting the two blocks. That leaves a 20 tab section available for the panel ground buss. There's actually no individual grounds going to the rear side of the firewall, just the single wire from the panel ground block. I can't think of anything in the future that I would add that I couldn't ground to the glare shield mounted panel ground buss. So could I eliminate the rear firewall block completely, and just connect the panel ground block wire to the big bolt through the firewall? Since I have 10awg to the main buss, I understand I need a 10awg ground. I would like to know how soldering this ground wire to a drilled out faston tab of the panel ground forest might work, or if it's better to use a #10 bolt and ring. -------- Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=273743#273743 ________________________________________________________________________________
Date: Nov 19, 2009
> >Since I have 10awg to the main buss, I understand I need a 10awg >ground. I would like to know how soldering this ground wire to a >drilled out faston tab of the panel ground forest might work, or if >it's better to use a #10 bolt and ring. Ring terminal and bolt. Bob . . . --------------------------------------- ( It's MATRONICS FUND RAISER MONTH! ) ( Do your part to keep this marvelous ) ( tool sharp and available to all our ) ( brothers in the OBAM aviation ) ( community. ) --------------------------------------- ________________________________________________________________________________
Subject: Crowbar Circuit
Date: Nov 19, 2009
If anyone is interested I've posted a circuit and veroboard layout for a tested and working crowbar circuit based on the MC3423 chip on the blog for my Wittman Tailwind build. Total parts cost around $5. http://tailwindbuild.blogspot.com/2009/11/15th-november-2009-overvoltage-crowbar.html Click on the pics/diagrams to enlarge The variable resistor allows the crowbar voltage to be set as required and compensates for differences in the internal reference voltage on the MC3423. Best regards Peter ________________________________________________________________________________
Date: Nov 19, 2009
Subject: [Fwd: How Pumpkin Pies are made]
Date: Nov 20, 2009
Subject: Just A Few Days Left; Still Trailing Last Year...
Dear Listers, There are just a few more days left of this year's List Fund Raiser! Response has been very good, but still well behind last year. If you've been waiting until the last minute to make your contribution and maybe even pick up a great gift, now might be good time to show your support! Please remember that there isn't any sort of commercial advertising on the Lists and the *only* means of keeping these Lists running is through your Contributions during this Fund Raiser. Please make a Contribution today! http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 20, 2009
Subject: Re: Crowbar Circuit
At 12:35 PM 11/19/2009, you wrote: > >If anyone is interested I've posted a circuit and veroboard layout >for a tested and working crowbar circuit based on the MC3423 chip on >the blog for my Wittman Tailwind build. Total parts cost around $5. > >http://tailwindbuild.blogspot.com/2009/11/15th-november-2009-overvoltage-crowbar.html > >Click on the pics/diagrams to enlarge > >The variable resistor allows the crowbar voltage to be set as >required and compensates for differences in the internal reference >voltage on the MC3423. Some thoughts based on lessons-learned: You need to select the trip time delay capacitor for something on the order of 50-100 milliseconds. Further, depending on how "twitchy" the SCR is, you may experience nuisance triggers of the SCR due to very low energy but fast rise-time noises on the bus. These are effectively dealt with by tying a 10 ohm resistor from SCR gate to ground (which may mean a commensurate increase in gate drive requirements from the MC3423). Bob . . . --------------------------------------- ( It's MATRONICS FUND RAISER MONTH! ) ( Do your part to keep this marvelous ) ( tool sharp and available to all our ) ( brothers in the OBAM aviation ) ( community. ) --------------------------------------- ________________________________________________________________________________
Subject: Dan's Switches
Date: Nov 20, 2009
Hello! I've done a fair amount of crimping and a little soldering while wiring my instrument panel mockup, and have a few questions. Maybe posting one or two pics per post will work. This is for my Jabiru 3300 Sonex with a standard ~30 degree tilted panel. I've put a piano hinge along the bottom and top with a few nutplates to go on the side. The tank and glareshield are removed. Tank has roughly the same cross section as the panel face, starts about a foot in front of the panel to the firewall. -------- Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=274009#274009 Attachments: http://forums.matronics.com//files/panel_front_112.jpg ________________________________________________________________________________
Subject: Re: Dan's Switches
Date: Nov 20, 2009
This pic is from the left side looking right, with the panel tilted forward. Some have had interference problems with the top of the Enigma hitting the glare shield, but mine just fits. At the top of the pic you can see the cover for the main buss. It's mocked up to fit on the underside of the glare shield. Taking out the top hinge pin will let it swing down for easier access. On the bottom side of the cover I've mounted a section of ground tabs. -------- Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=274011#274011 Attachments: http://forums.matronics.com//files/panel_pivoted_119.jpg ________________________________________________________________________________
Date: Nov 20, 2009
This is with the panel in the closed position. The channel that the lower piano hinge attaches to is 025 with either 1/2" or 3/4" flanges. Some of the longer wires, like the blue one in the foreground, can be tucked away from the flange. There are a few shorter wires that need to have a zip tie pull them up and away, or maybe ben up the switch terminals. The 3rd switch back is a good example. It has a white and red wire resting on the flange. In the foreground is my security switch for the starter button, mentioned in earlier posts. -------- Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=274017#274017 Attachments:
October 21, 2009 - November 20, 2009
AeroElectric-Archive.digest.vol-jc
