AeroElectric-Archive.digest.vol-jp
June 27, 2010 - July 25, 2010
      =C2-
      Gordon Smith
Date: Jun 27, 2010
Subject: Re: LV Warn Light vs. Alternator Light
> >The first thought if this light comes on is that >the alternator is off line and not outputting to >the battery or aircraft bus systems. However this is not necessarily true. > >Can not there be a condition where the >alternator is puitting out its maximum >capacity but you are trying to use a total load >greater than that capacity. I think this would >eventually pull the battery and main bus voltage >down to a point where the LV warning light would turn on. Not if one has accomplished the customary load analysis. The legacy approach to sizing alternators to loads makes it impossible to overload the alternator. Now, if one PLANS to have more potential load than the alternator can carry, then an alternator loadmeter is indicated to assist the pilot in turning things on/off as needed to stay within the alternator's capabilities. >My thought was that maybe it would be >advantageous to have an additional indicator of >alternator function. Many regulators for both >field wound and/or permanent magnet alternators >have a light. But what does that light actually tell you? Those are in the same class as the alternator warning light on vehicles for 50+ years. They accurately indicate a broken wire, broken belt and some system failures but not all. An they're not a LV warning light. The stand-alone, active notification of LV is still the single most useful electrical system flight instrument. >On a schematic supplied by Jabiru for the J3300 >the stock supplied regulator for the permanent >magnet regulator system has a light >connection. It is identified as To Low >Voltage Warning Light. Is this just >redundant LV warning or does it actually >tell if the there is alternator output? Same as cited above. Not a 'real' lv warning system. Bob . . . ________________________________________________________________________________
From: "Valin & Allyson Thorn" <thorn(at)starflight.aero>
Subject: Re: Push Button "Speed Brakes"?
Date: Jun 27, 2010
Thanks Bob - looks like something along those lines would do the trick. These examples switch AC current with the DC control. I'm not sure if that matters or not. But, I figured relays that behave like this must be out there somewhere. Guess I need DPST bi-stable 24V DC relay. Valin From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bob McCallum Sent: Sunday, June 27, 2010 4:34 PM Subject: RE: AeroElectric-List: Re: Push Button "Speed Brakes"? Valin; The simplest circuit to accomplish your request would be to use your SPST push button to switch coil power to a bi-stable relay and use the relay contacts to switch the power to whatever load you wish. Each push of the button will toggle the relay. The second item on this page (part number RLY7742) is an example of a 12VDC 15 amp DPDT bi-stable relay. http://tinyurl.com/2ffvkur Bob McC _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Valin & Allyson Thorn Sent: Sunday, June 27, 2010 2:35 PM Subject: RE: AeroElectric-List: Re: Push Button "Speed Brakes"? Hi Bob and everyone, Thanks for the history of the Precise Flight Speedbrakes/Spoilers. Since they brand them "speed brakes" I've been using that term even though I know they are really spoilers. The accident scenario you described really brings to light how someone without a clear understanding of what they actually do could call for them at a bad time. ****** Big Clip********** Anyway, I appreciate and encourage the discussion about the best way to design all this with aircraft operations and human factors in mind. Even if I don't do it this way, I'd still like to know the best way to design a circuit to toggle back and forth between two poles with a push button switch. J Anyone have any advice on that question? Thanks, Valin ________________________________________________________________________________
Date: Jun 27, 2010
Thanks Robert -- that would be nice if I didn=99t already have a throttle quadrant that isn=99t very conducive to adding a switch to it See photo below. Valin throttle quadrant 2009.jpg From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert Sultzbach Sent: Sunday, June 27, 2010 4:31 PM Subject: Re: AeroElectric-List: Re: Push Button "Speed Brakes"? Hi Valin, I would suggest putting them on the throttle. That is where they were on military aircraft I flew. The beauty of having them there is it is extremely easy to develop a habit pattern of activating the spoilers to retract WHENEVER you ask for full power. There are thumb switches that have existed for these production aircraft so I would think they would be available. See if you can find pictures of military aircraft like the A-4 whose throttle had that setup. As the throttle is advanced the thumb pushes the thumb switch forward to retract the spoilers and vice versa when low thrust high drag is needed. Good luck. Sent from my iPhone On Jun 28, 2010, at 2:34, "Valin & Allyson Thorn" wrote: Hi Bob and everyone, Thanks for the history of the Precise Flight Speedbrakes/Spoilers. Since they brand them =9Cspeed brakes=9D I=99ve been using that term even though I know they are really spoilers. The accident scenario you described really brings to light how someone without a clear understanding of what they actually do could call for them at a bad time. I think they can be easily misunderstood since even spoilers can perform as speed brakes. I like to think of them as lift/drag ratio reducers. As you point out, an aircraft designer can go after bumping up the drag side or lowering the lift side to give the pilot more aircraft control when high on energy and wanting less altitude and/or airspeed. Even as spoilers they can act like speed brakes since when deployed, lowering lift, one can increase the wing angle of attack to keep the same lift (hold same altitude rate) while getting higher drag at the new higher AOA, slowing the airplane down Anyway, your accident example has convinced me to label them as spoilers and not speed brakes. The discussion has me reconsidering my decision to add the spoiler control to the joystick grips. But, let me summarize my rules for picking what=99s on the stick. 1. Actions required frequently 2. Functions needed while it=99s very inconvenient to remove hand from throttle 3. No functions that if accidentally activated would create a safety of flight issue So these are my basic criteria for selecting what=99s switches are on the joystick. Based on this, I=99ve tentatively made these assignments: For those who can=99t see the graphic, I have: Hat Switch: Pitch & Yaw Trim Trigger: Radio Transmit Lower Button: Alarm Mute Upper Right Button: Autopilot On/Off Toggle Upper Left Button: Spoilers Up/Down Toggle I did not put flaps or gear on the stick since one usually only activates them twice during a typical cross country flight and if they were to be accidentally deployed when flying too fast it would damage the aircraft =93 violating strategy rule 3 above. I=99m thinking having the spoilers on the stick is a good option because the Lancair Legacy is a very low drag airframe making them very useful for descents, the Legacy can be easily landed with them deployed, and there is no speed limit on their deployment. With this discussion ongoing I have heard from a Legacy flyer with a spoiler switch on his throttle control and that he wishes he had a guard on it because it has been accidentally activated a few times. The good news from his experiences is that he=99d even landed without realizing they were deployed and it was not an issue. I=99m also checking with another Legacy flyer who has the control on his joystick to see if it=99s been a problem for him or if he=99d do it again. >From earlier discussion with him he said he did it because the Mooney he used to fly had it that way and it was very convenient to toggle them when needed on descents. Anyway, I appreciate and encourage the discussion about the best way to design all this with aircraft operations and human factors in mind. Even if I don=99t do it this way, I=99d still like to know the best way to design a circuit to toggle back and forth between two poles with a push button switch J Anyone have any advice on that question? Thanks, Valin -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Saturday, June 26, 2010 11:45 PM Subject: AeroElectric-List: Re: Push Button "Speed Brakes"? At 08:24 PM 6/26/2010, you wrote: >I think it has to have a voltage applied at pin 7 continuously to >keep the speed brakes up. It's designed so that if the unit loses >power they fail to the retracted position. This is an excellent topic for discussions of failure mode effects analysis =AND= understand the simple-ideas behind the system design goals. A really important side note concerning the Precise Flight product is that it's not a "speed brake" in the aerodynamic sense of the phrase . . . A speed brake is a means by which aerodynamic DRAG is added to the mix of thrust-lift-mass-drag combination that dictates airframe behavior/performance. Drag can be and most often is added to the performance mix by throwing large surface areas out into the slipstream. I've participated in programs that crafted special actuators to extend large panels out of aft locations on the airplane where design goals called for an increase in the airframe's total drag component while having little or no effect on lift. Large air transport aircraft will lift rather large areas of aluminum from the top surface of the wing. In cruising flight, only the outboard panels will occasionally lift during roll control maneuvers. In this mode, the panels are SPOILERS that reduce lift on one wing at a time. Loss of lift augments rolling moment offered by the ailerons. However, during landing roll-out, one often sees every square foot of aluminum through out into the breeze with the obvious intent of making the whole machine a very draggy aerodynamic shape where flying efficiency is not important while slowing down is most important. The space shuttle has a bifurcated rudder that can be simultaneously extend both to the right and left of the vertical fin for the purpose of throwing out some aerodynamic drag. The Precise Flight product is the brainchild of on Bill Thompson who was chief of flight test at Cessna single engine division while I was a tech writer. Bill was directly responsible for introducing me to Ken Razak, former dean of engineering at Wichita State who became my second most revered mentor, business partner and friend with more than 40 years of collaboration on interesting things. But that's another story. Bill's product first evolved on the Cessna 210 and was later approved for installation on a host of TC aircraft. I was introduced to the device in Kerrville, TX by a Mooney test pilot and later on another Mooney by George Masey. It was then that I was given to understand that the Precise flight product is NOT A SPEED BRAKE. It's a SPOILER. Design goals for this device call for reducing lift on the wing while having very little effect on total drag. The artfully installed blades can be extended during a stabilized approach to offer a profound effect on rate of descent while having little effect on pitch angle or indicated airspeed. There are similar devices on the top of the wing in a Beechjet that offer augmentation of tiny ailerons for roll control in fight -OR- an increased rate of descent when fully extended on both sides. These also are NOT SPEED BRAKES. They might be extended during a roll out for the purpose of killing lift to increase weight on wheels and improve braking by the tires . . . but their effect as aerodynamic speed brakes is nil. The reason why this distinction is important has to do with proper and useful deployment of SPOILERS. I'm working an accident case where a pilot reports having extended his Precise Flight "speed brakes" a few seconds before an off-airport landing. He was under the mistaken understanding that they would help slow things down before an un-planned contact with the ground. In fact, the impact forces were probably GREATER than if he had not extended the SPOILERS at all. The net effect of extending the Precise Flight paddles on top of the wing was to INCREASE rate of descent to the ground. So after understanding what these things are designed to do for you, I'll suggest that its a really good thing to make sure that under no circumstances can they can extend when you don't want them to and that they can always be retracted when they're not needed . . . or their extension would increase risks of bent airplanes or broken people. When considering departures from the manufacture's instructions, make sure that you're not crafting a situation that increases risk of unintended extension or loss of pilot control for that extension. The system should probably include an easily accessed power switch. Removal of power from the system insures positive retraction irrespective of what other switch becomes stuck. Itty-bitty switches on stick-grips are not renowned for their robustness. Take care that your quest for convenience does not increase risks for un-intended consequences. Bob . . . to browse Un/Subscription, Browse, Chat, FAQ, more: http://www.matronics.com/Navigator?AeroElectric-List Web Forums! http://forums.matronics.com support! http://www.matronics.com/contribution ________________________________________________________________________________
Subject: Starter light
Date: Jun 27, 2010
Other builders tell me they wired in a light to indicate that the starter motor is 'doin its thang'. They value this because you can't hear a Lycoming starter working and if it continues running, due to welded contacts or some other problem in the circuit, something needs to be done about it. What I would really like is a light to indicate A) that the starter is available to be engaged OR B) is actually energized and working. It would switch off when the engine was running and the starter was no longer working. Such a light would come back on when the engine was cut off as long as the master is still on. This is pretty much how my car status lights work. I am still learning about electrics but would somebody more knowledgeable know; can a starter light be wired to this effect and how would it be done? I will be using the z13/8 architecture for my RV-9. -------- Loman O'Byrne RV-9 builder: Emp Done, Wings Done, Fuse underway Dublin, Ireland Read this topic online here: http://forums.matronics.com/viewtopic.php?p=302755#302755 ________________________________________________________________________________
From: "Bob McCallum" <robert.mccallum2(at)sympatico.ca>
Date: Jun 27, 2010
Valin; You're welcome. The 24V version would be part #RLY7443 4th item down on the link I sent previously. Also although they state these relays switch AC they work equally well on DC as the switching elements are mechanical micro switches. You can see this detail clearly if you view the photos on the linked page. Bob McC _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Valin & Allyson Thorn Sent: Sunday, June 27, 2010 7:21 PM Subject: RE: AeroElectric-List: Re: Push Button "Speed Brakes"? Thanks Bob - looks like something along those lines would do the trick. These examples switch AC current with the DC control. I'm not sure if that matters or not. But, I figured relays that behave like this must be out there somewhere. Guess I need DPST bi-stable 24V DC relay. Valin From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bob McCallum Sent: Sunday, June 27, 2010 4:34 PM Subject: RE: AeroElectric-List: Re: Push Button "Speed Brakes"? Valin; The simplest circuit to accomplish your request would be to use your SPST push button to switch coil power to a bi-stable relay and use the relay contacts to switch the power to whatever load you wish. Each push of the button will toggle the relay. The second item on this page (part number RLY7742) is an example of a 12VDC 15 amp DPDT bi-stable relay. http://tinyurl.com/2ffvkur Bob McC _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Valin & Allyson Thorn Sent: Sunday, June 27, 2010 2:35 PM Subject: RE: AeroElectric-List: Re: Push Button "Speed Brakes"? Hi Bob and everyone, Thanks for the history of the Precise Flight Speedbrakes/Spoilers. Since they brand them "speed brakes" I've been using that term even though I know they are really spoilers. The accident scenario you described really brings to light how someone without a clear understanding of what they actually do could call for them at a bad time. ****** Big Clip********** Anyway, I appreciate and encourage the discussion about the best way to design all this with aircraft operations and human factors in mind. Even if I don't do it this way, I'd still like to know the best way to design a circuit to toggle back and forth between two poles with a push button switch. :-) Anyone have any advice on that question? Thanks, Valin ________________________________________________________________________________
Date: Jun 27, 2010
Subject: Re: Starter light
At 08:26 PM 6/27/2010, you wrote: Other builders tell me they wired in a light to indicate that the starter motor is 'doin its thang'. They value this because you can't hear a Lycoming starter working and if it continues running, due to welded contacts or some other problem in the circuit, something needs to be done about it. What I would really like is a light to indicate A) that the starter is available to be engaged OR B) is actually energized and working. It would switch off when the engine was running and the starter was no longer working. Such a light would come back on when the engine was cut off as long as the master is still on. This is pretty much how my car status lights work. I am still learning about electrics but would somebody more knowledgeable know; can a starter light be wired to this effect and how would it be done? I will be using the Z13/8 architecture for my RV-9. A simple "starter energized" light is powered from the downstream side of the starter contactor. It's illuminated all times the contactor is closed either because your finger is on the button . . . or because it's stuck. See: http://www.aeroelectric.com/Pictures/Schematics/Starter_Engaged_Warning_Lt.pdf Do an archives search on "starter engaged" for a constellation of the problem and variables associated with the various starter technologies. Bob . . . ________________________________________________________________________________
Subject: Toggle Relay
Date: Jun 27, 2010
Gordon; See my reply to Valin re: the speed brakes thread, a couple of posts up the list. This bi-stable relay does what you are describing. The one I cited is a DPDT device rated 15 amps per contact. You could parallel the two contacts to approximate the 704's rating. The contacts won't precisely share the load but unless you are running at absolutely max rating they'll work well. If the switch ratings are a real concern, the supplied switches on this relay could be replaced with Omron V-15-1C5 switches which are rated at 15Amps 250VDC. Bob McC _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Gordon Smith Sent: Sunday, June 27, 2010 6:33 PM Subject: AeroElectric-List: Toggle Relay Is there a 12V. Relay device (SPST or SPDT) that can be toggled OFF/ON from a remote momentary SPST mini switch? It should remain in the off or on position until toggled again. I am looking for something in the class of a S704-1 regarding robustness and capacity. Gordon Smith ________________________________________________________________________________
Subject: Re: Voltmeter Needs Independent Power Supply
Date: Jun 28, 2010
It would almost certainly work fine to tie the grounds together and the +12 supply and the +measurement together. -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=302792#302792 ________________________________________________________________________________
Subject: Speedbrakes
Date: Jun 28, 2010
My Lancair Legacy has Precise Flight speedbrakes. But are they spoilers or speedbrakes? The primary purpose of a spoiler is to kill the lift on top of the wing. Typically, they are relatively long and narrow. Long to cover a significant portion of the wing and narrow because for the purpose of killing lift, they don't need to be very wide. The primary purpose of a speedbrake is to slow the airplane by acting as a flat plate drag device. The Precise Flight speedbrakes on a Legacy (and some other designs) are installed on the top of the wing. That makes them neither fish nor fowl. Since they are on top of the wing, they kill lift along the span of the wing equal to at least their width, and therefore, act as spoilers. However, their shape makes them inefficient as spoilers. Their flat plate area is nearly square (they are as tall as they are wide), which means for a spoiler, they are much taller than needed and cover too short of the span of the wing. So in that regard, they are speedbrakes. As a practical matter, Precise Flight speedbrakes are both spoilers and speedbrakes. We know that parasite drag increases as the square of airspeed. This means that at high airspeed, the effect of the speedbrakes on parasite drag is hugely more than at low speed. Deploying them at high speed generates a large amount of parasite drag. At low speed, the drag effect is relatively small while the spoiler effect is large. They act more like speedbrakes at high speed and more like spoilers at low speed. Since I typically only use mine at high speed to slow down, for me, they are speedbrakes. I don't normally use them at low speed because those stubby little wings need all the lift they can get when flying slowly. By the way, I rarely use my speedbrakes. I feel like deploying them is an admission that I used poor planning and am just wasting gas. However, there are times when it makes life so much easier. There are a few mountain airports I visit where for safety it's nice to come in high over a ridge and drop down quickly to pattern altitude before entering downwind. And there are times on IFR flights when approach control keeps me high until the last minute. Dennis ________________________________________________________________________________
Subject: Re: Audio system design
Date: Jun 28, 2010
yes, that's the one. 817.439.4645 -Jose Read this topic online here: http://forums.matronics.com/viewtopic.php?p=302854#302854 ________________________________________________________________________________
Subject: Ground Power and Aux Alt sharing OVM?
Date: Jun 28, 2010
I'm using Z13 in conjunction with Z31-B. Is there anything wrong about the aux alternator and the ground power jack sharing the same OVM? The only condition that I can think of where both systems would be in use simultaneously is a ground powered START on the aux alternator and that may not even be an issue unless the OVM tripped. The issue being what caused it, the GPU or the aux alt. If this passes group muster, how would I wire it? Thanks, John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=302859#302859 ________________________________________________________________________________
Date: Jun 29, 2010
Subject: New kid on the block . . .
Wonder if we'll see this guy at OSH this year . . . or perhaps he's been there before and I just didn't notice or hear of it. OSH is getting pretty BIG. http://www.terrafugia.com/ Bob . . . ________________________________________________________________________________
Subject: Re: New kid on the block . . .
Date: Jun 29, 2010
Bob, Terrafugia has been at the last two Airventures. I'm sure they'll be there this year as well. Though it will probably be a couple more years before you see one fly at Airventure. Bob Borger On Jun 29, 2010, at 8:22, Robert L. Nuckolls, III wrote: > > Wonder if we'll see this guy at OSH this year . . . > or perhaps he's been there before and I just didn't > notice or hear of it. OSH is getting pretty BIG. > > http://www.terrafugia.com/ > > > Bob . . . > > > > ________________________________________________________________________________
From: "ROGER & JEAN CURTIS" <mrspudandcompany(at)verizon.net>
Date: Jun 29, 2010
Wonder if we'll see this guy at OSH this year . . . or perhaps he's been there before and I just didn't notice or hear of it. OSH is getting pretty BIG. http://www.terrafugia.com/ Bob . . . This one has been around for a few years. Looks like the project is moving along quite well. Apparently they are getting very close to having a marketable item. My understanding is that they still have some work to make it roadable, accident safety, crumple zones, etc. but it has flown and I have seen it at Sun-n-Fun. Roger ________________________________________________________________________________
Subject: Panel punch
Date: Jun 29, 2010
Does anyone on the list have a 3 1/8" panel punch that you might be willing to loan out? I have a set of Greenly Punches but do not have one this large. I need to punch about 3 instrument holes in my panel and I feel the punch is the best way to go. The panel is light gauge aluminum, so will be very easy to punch. I have considered using a hole saw, but I have never been able to make a nice clean hole with this method. Any help would be appreciated. Roger Curtis Upton, MA ________________________________________________________________________________
Date: Jun 29, 2010
I have one you would be welcome to borrow. 3-1/8 on one side, 2-1/4 on the other. Kind of heavy but maybe one of those "if it fits it ships" USPS boxes wouldn't be too much. Allen Fulmer Alexander City, AL 35010 -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of ROGER & JEAN CURTIS Sent: Tuesday, June 29, 2010 5:31 PM Subject: AeroElectric-List: Panel punch Does anyone on the list have a 3 1/8" panel punch that you might be willing to loan out? I have a set of Greenly Punches but do not have one this large. I need to punch about 3 instrument holes in my panel and I feel the punch is the best way to go. The panel is light gauge aluminum, so will be very easy to punch. I have considered using a hole saw, but I have never been able to make a nice clean hole with this method. Any help would be appreciated. Roger Curtis Upton, MA ________________________________________________________________________________
From: "Richard Dudley" <rhdudley1(at)bellsouth.net>
Subject: Re: Panel punch
Date: Jun 29, 2010
Hi Roger, When I did my RV-6A panel some years ago, I rented a punch from Bob Avery for a nominal fee. It cut both the typical instruments sizes. Regards, Richard Dudley ----- Original Message ----- From: "ROGER & JEAN CURTIS" <mrspudandcompany(at)verizon.net> Sent: Tuesday, June 29, 2010 6:30 PM Subject: AeroElectric-List: Panel punch > > > Does anyone on the list have a 3 1/8" panel punch that you might be > willing > to loan out? I have a set of Greenly Punches but do not have one this > large. I need to punch about 3 instrument holes in my panel and I feel > the > punch is the best way to go. The panel is light gauge aluminum, so will > be > very easy to punch. I have considered using a hole saw, but I have never > been able to make a nice clean hole with this method. > > Any help would be appreciated. > > Roger Curtis > Upton, MA > > > ________________________________________________________________________________
Date: Jun 29, 2010
A technique I use for a cleaner hole when using a large hole saw is to drill the pilot hole first. Then put a standard drill bit into the hole saw reversed so that the flutes cannot work the pilot hole wider and wider. You may also use a scrap piece of steel rod (1/4" on my hole saw). The idea is to not enlarge the pilot hole as the larger part of the hole saw does it's thing. Of course clamp it tight and use a sharp hole saw for best results. Clean up with a high speed rotary deburing bit on a die grinder. Bevan -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of ROGER & JEAN CURTIS Sent: Tuesday, June 29, 2010 3:31 PM Subject: AeroElectric-List: Panel punch --> Does anyone on the list have a 3 1/8" panel punch that you might be willing to loan out? I have a set of Greenly Punches but do not have one this large. I need to punch about 3 instrument holes in my panel and I feel the punch is the best way to go. The panel is light gauge aluminum, so will be very easy to punch. I have considered using a hole saw, but I have never been able to make a nice clean hole with this method. Any help would be appreciated. Roger Curtis Upton, MA ________________________________________________________________________________
Date: Jun 30, 2010
i used a holesaw that i bought at ace. it worked perfect on my 1/16'' thick alum. i used one that mounted rigid on the center drill. more expensive ones that allowed substitution of sizes didnt work as well [i bought them too]. i cut my whole panel with 2 sized holes and each was perfect. buy one and try it on scrap first. bob noffs On Tue, Jun 29, 2010 at 5:30 PM, ROGER & JEAN CURTIS < mrspudandcompany(at)verizon.net> wrote: > mrspudandcompany(at)verizon.net> > > Does anyone on the list have a 3 1/8" panel punch that you might be willing > to loan out? I have a set of Greenly Punches but do not have one this > large. I need to punch about 3 instrument holes in my panel and I feel the > punch is the best way to go. The panel is light gauge aluminum, so will be > very easy to punch. I have considered using a hole saw, but I have never > been able to make a nice clean hole with this method. > > Any help would be appreciated. > > Roger Curtis > Upton, MA > > ________________________________________________________________________________
Subject: Panel Punch
Date: Jun 30, 2010
EAA has a great tutorial video on a clever way to use a hole saw to make nice holes in an instrument panel. http://www.eaa.org/video/homebuilders.html It's in the "General" tab, near the bottom of the list. Dennis ________________________________________________________________________________
Date: Jun 30, 2010
Thanks everyone for the helpful hints on punching instrument holes. My opinion is that the best method is using a punch of the correct size, however the EAA video, using a hole saw, appears to be a viable alternative. Again, thanks, Roger ________________________________________________________________________________
Date: Jun 30, 2010
Check out the video in the EAA's hints for homebuilders: http://www.eaa.org/video/homebuilders.html <http://www.eaa.org/video/homebuilders.html>There is one about using a hole saw for instrument panels, and if I remember correctly, he uses a piece of pre-drilled plywood above the aluminum to align and steady the saw. It's been a while since I watched it though. On Wed, Jun 30, 2010 at 6:19 AM, bob noffs wrote: > i used a holesaw that i bought at ace. it worked perfect on my 1/16'' thick > alum. i used one that mounted rigid on the center drill. more expensive ones > that allowed substitution of sizes didnt work as well [i bought them too]. i > cut my whole panel with 2 sized holes and each was perfect. buy one and try > it on scrap first. > bob noffs > > On Tue, Jun 29, 2010 at 5:30 PM, ROGER & JEAN CURTIS < > mrspudandcompany(at)verizon.net> wrote: > >> mrspudandcompany(at)verizon.net> >> >> Does anyone on the list have a 3 1/8" panel punch that you might be >> willing >> to loan out? I have a set of Greenly Punches but do not have one this >> large. I need to punch about 3 instrument holes in my panel and I feel >> the >> punch is the best way to go. The panel is light gauge aluminum, so will >> be >> very easy to punch. I have considered using a hole saw, but I have never >> been able to make a nice clean hole with this method. >> >> Any help would be appreciated. >> utilities such as List Un/Subscription, >> www.matronics.com/Navigator?AeroElectric-List" target="_blank"> >> http://www.matronics.com/Navigator?AeroElectric-List >> ronics.com/" target="_blank">http://forums.matronics.com >> Matt Dralle, List Admin. >> ==== >> >> >> >> > * > > * > > ________________________________________________________________________________
Subject: Speed Brakes/Spoilers
Date: Jun 30, 2010
Dennis, I sent this diatribe to the wrong address so here it comes now: One of us has it right (IMHO). The spoiler cancel switch should be on the throttle. The TriStar 500 was a whiz in cockpit design. There were four different kinds of spoilers on the wing. The first were big jobs inboard to plop the aircraft onto the tires on touchdown because you could round out, put only five of eight mainwheels on, catch a drift and touch brakes would blow out the tires on the runway - so the full weight was required to save tires - called GROUND SPOILERS. The second were roll augmenters and "speed brakes" in the air but accompanies the biggies when the touchdown was complete, the third types were outboard to balance fuel tank contents on an "active" wing (called 'direct Lift control' - don't ask) and I can't remember the 4th, but three of the four assisted in roll. The speed brakes could only be selected in air with no flap out - they were then effective brakes. So, you can call 'em speed brakes only if they operate to increase drag - that's how they are engineered into the wing. Just to complicate it, there were mixers which decided if your selection was (a) acceptable and (b) possible. The crux was on the throttles (3). The outer ones (1 & 3) had outside buttons in parallel, so were called GO AROUND buttons. If Cap'n was flying he used the No1 throttle button, if the F/O was doing it he had the No4 throttle button. When you wanted to abort the approach, you hollered "Go around", pushed the GA button on your side as you opened the throttles to GA power. The approach was made with some spoiler panels partially extended. The button [1] demanded a proper nose-up pitch, [2] cancelled the extended spoilers instantly which allowed the aircraft to 'leap' upward and [3] did a number of complicated things which made aborting an approach magic and instantaneous. No other a/c could do this and it meant (very early in the trade) approaching to 7 feet (wheel height) from the runway and not drop a foot farther - without ever seeing the ground. And 90% of the exercise was aerodynamic - a miracle. Let's hear it for partial spoilers. I suspect the throttle is the ideal place to cancel spoilers/speed brakes because you are probably going to want to increase speed or improve lift - and now. I have to close, I hear matron coming down the hall. Ferg ________________________________________________________________________________
From: "Bill Bradburry" <bbradburry(at)bellsouth.net>
Date: Jun 30, 2010
There was a major Delta crash at DFW a few years ago where the plane encountered wind shear on short final and touched down in a pasture prior to the airport. When the wheels touched, the spoilers automatically deployed and the pilot could not go around as a result. Major loss of life! Bill B _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Fergus Kyle Sent: Wednesday, June 30, 2010 3:31 PM Subject: AeroElectric-List: Speed Brakes/Spoilers Dennis, I sent this diatribe to the wrong address so here it comes now: One of us has it right (IMHO). The spoiler cancel switch should be on the throttle. The TriStar 500 was a whiz in cockpit design. There were four different kinds of spoilers on the wing. The first were big jobs inboard to plop the aircraft onto the tires on touchdown because you could round out, put only five of eight mainwheels on, catch a drift and touch brakes would blow out the tires on the runway - so the full weight was required to save tires - called GROUND SPOILERS. The second were roll augmenters and "speed brakes" in the air but accompanies the biggies when the touchdown was complete, the third types were outboard to balance fuel tank contents on an "active" wing (called 'direct Lift control' - don't ask) and I can't remember the 4th, but three of the four assisted in roll. The speed brakes could only be selected in air with no flap out - they were then effective brakes. So, you can call 'em speed brakes only if they operate to increase drag - that's how they are engineered into the wing. Just to complicate it, there were mixers which decided if your selection was (a) acceptable and (b) possible. The crux was on the throttles (3). The outer ones (1 & 3) had outside buttons in parallel, so were called GO AROUND buttons. If Cap'n was flying he used the No1 throttle button, if the F/O was doing it he had the No4 throttle button. When you wanted to abort the approach, you hollered "Go around", pushed the GA button on your side as you opened the throttles to GA power. The approach was made with some spoiler panels partially extended. The button [1] demanded a proper nose-up pitch, [2] cancelled the extended spoilers instantly which allowed the aircraft to 'leap' upward and [3] did a number of complicated things which made aborting an approach magic and instantaneous. No other a/c could do this and it meant (very early in the trade) approaching to 7 feet (wheel height) from the runway and not drop a foot farther - without ever seeing the ground. And 90% of the exercise was aerodynamic - a miracle. Let's hear it for partial spoilers. I suspect the throttle is the ideal place to cancel spoilers/speed brakes because you are probably going to want to increase speed or improve lift - and now. I have to close, I hear matron coming down the hall. Ferg ________________________________________________________________________________
Date: Jun 30, 2010
I think someone said that they would send you a punch. If not and you still need one, let me know. My panel is .090 and these die worked on it. You do have to squeeze, release, rotate, squeeze on this .090 thickness. It would really work like a breeze on a thinner panel. And you will need something to drill the center hole with. A step drill works best for that. Bill B _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Roger Sent: Wednesday, June 30, 2010 12:53 PM Subject: AeroElectric-List: Panel Punch Thanks everyone for the helpful hints on punching instrument holes. My opinion is that the best method is using a punch of the correct size, however the EAA video, using a hole saw, appears to be a viable alternative. Again, thanks, Roger ________________________________________________________________________________
Date: Jun 30, 2010
Subject: Re: Speed Brakes/Spoilers
Dear Sir.=0A=0A The crash of Delta 191 at DFW on 2 Aug 85 was not caused b y the spoilers deploying at touchdown. It was conjected by Monday morning qb's that had the spoilers deployed or not retracted at touchdown the aircr aft would have stayed on the ground where it touched down north of Texas st ate route 114. Therefore, it would not have hit the water tank at DFW. I recall that on the Tristar going to full throttle automatically retracted t he spoilers. So at full throttle during the windshear encounter, the spoil ers automatically retracted. Time has a way of making memories fuzzy so if anyone recollects differently please set me straight. Incidentally, from what I can tell, EVERY airliner extends spoilers at weight on wheels during landing. To go around, advance the throttles and retract the spoilers. W hat might be a point of confusion is thrust reverser deployment. After thr ust reverse is applied go arounds are generally forbidden by aircraft manuf acturers.=0A=0A=0A =0A=0ASent from my iPhone=0A=0AOn Jun 30, 2010, at 23:2 4, "Bill Bradburry" wrote:=0A=0AThere was a majo r Delta crash at DFW a few years ago where the plane encountered wind shear on short final and touched down in a pasture prior to the airport. When t he wheels touched, the spoilers automatically deployed and the pilot could not go around as a result. Major loss of life!=0A=0A =0A=0ABill B=0A=0A =0A=0AFrom: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aero electric-list-server(at)matronics.com] On Behalf Of Fergus Kyle=0ASent: Wednes day, June 30, 2010 3:31 PM=0ATo: 1AeroElectricLIST=0ASubject: AeroElectric- List: Speed Brakes/Spoilers=0A=0A =0A=0ADennis,=0A=0A I sent this di atribe to the wrong address so here it comes now:=0A=0AOne of us has it rig ht (IMHO). The spoiler cancel switch should be on the throttle. The TriStar 500 was a whiz in cockpit design. There were four different kinds of spoil ers on the wing.=0A=0AThe first were big jobs inboard to plop the aircraft onto the tires on touchdown because you could round out, put only five of e ight mainwheels on, catch a drift and touch brakes would blow out the tires on the runway =93 so the full weight was required to save tires =93 called GROUND SPOILERS. The second were roll augmenters and =9Cspeed brakes=9D in the air but accompanies the biggies when the to uchdown was complete, the third types were outboard to balance fuel tank co ntents on an =9Cactive=9D wing (called =98direct Lift con trol=99 =93 don=99t ask) and I can=99t remember the 4th, but three of the four assisted in roll. The speed brakes could only b e selected in air with no flap out =93 they were then effective brake s.=0A=0A So, you can call =98em speed brakes only if they oper ate to increase drag =93 that=99s how they are engineered into the wing. Just to complicate it, there were mixers which decided if your se lection was (a) acceptable and (b) possible.=0A=0A The crux was on t he throttles (3). The outer ones (1 & 3) had outside buttons in parallel, so were called GO AROUND buttons. If Cap=99n was flying he used the N o1 throttle button, if the F/O was doing it he had the No4 throttle button. When you wanted to abort the approach, you hollered =9CGo around =9D, pushed the GA button on your side as you opened the throttles to GA power. The approach was made with some spoiler panels partially extended. The button [1] demanded a proper nose-up pitch, [2] cancelled the extended spoilers instantly which allowed the aircraft to =98leap=99 up ward and [3] did a number of complicated things which made aborting an appr oach magic and instantaneous. No other a/c could do this and it meant (very early in the trade) approaching to 7 feet (wheel height) from the runway a nd not drop a foot farther =93 without ever seeing the ground. And 90 % of the exercise was aerodynamic =93 a miracle. Let=99s hear i t for partial spoilers.=0A=0A I suspect the throttle is the ideal place to cancel spoilers/speed brakes because you are probably going to want to increase s peed or improve lift =93 and now.=0A=0A I have to close, I hea r matron coming down the hall.=0A=0AFerg=0A=0A =0A =0Ahttp://www.matronics. com/Navigator?AeroElectric-List=0Ahttp://forums.matronics.com=0Ahttp://www. =========================0A =========================0A ========0A=0A=0A=0A=0A ________________________________________________________________________________
Subject: Re: AEC Modules
Date: Jul 01, 2010
Hi Bob, Is the paralysis resolving? I'm wondering when the 9004 and 9011 modules will be available. Thanks, Eric Schlanser W-10/Lycoming O320 with Z-13 and maybe Z-24 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=303264#303264 ________________________________________________________________________________
Date: Jul 01, 2010
There is one other technology for panel fabrication that some of you may wish to consider. Many fabricators of flat sheet products can take your CAD drawings and convert them directly into finished product. Some years ago I did this panel layout for a C-120 http://aeroelectric.com/Pictures/Misc/120PANEL.pdf I took a sheet of .125" aluminum and the .dxf file for the drawing to a local CNC shop and for just over $120 they cut me a panel that was accurate to better than .001" all around. Had I thought about it beforehand, I could have had lettering engraved directly into the panel. After having the panel anodized, the lettering can be filled with colored, stick-enamels of choice. I've built a number of devices for HBC, not the least of which was this recovery parachute controller: http://aeroelectric.com/Pictures/Misc/Recovery_Parachute_Controller_2.jpg In this case, I e-mailed the drawing to a California firm who cut me two engraved overlays with lettering, beveled edges and all thru holes. I think two placards were about $200. Very low cost software like TurboCAD will produce the necessary files for your panels, circuit breaker, and switch panel overlays. The end results can look quit professional. Bob . . . ________________________________________________________________________________
Subject: Battery tender
Date: Jul 01, 2010
I've got a BatteryTender Plus that has a float voltage of 12.7 volts. This is on both a new battery and the one that is being replaced. Is it time for a new Batterytender? Bill Glasair SIIS-FT ________________________________________________________________________________
Subject: Re: Rotax-B & C over voltage protection
Date: Jul 01, 2010
Bob, I finally got around to taking the OVM-14 you sent out of the package. I just want to double check that this is a hearty enough unit to drop the 30 amp breaker called for in the Rotax 912 schematics. There doesn't seem to be a separate field breaker called for. Do i maybe have to install it elsewhere? Thanks, Scott Read this topic online here: http://forums.matronics.com/viewtopic.php?p=303354#303354 ________________________________________________________________________________
Date: Jul 01, 2010
At 03:02 PM 7/1/2010, you wrote: > >Bob, > >I finally got around to taking the OVM-14 you sent out of the >package. I just want to double check that this is a hearty enough >unit to drop the 30 amp breaker called for in the Rotax 912 >schematics. There doesn't seem to be a separate field breaker called >for. Do i maybe have to install it elsewhere? Thanks, In no set of instructions is the OVM expected to open any breaker over 5A. Since the 912 schematics don't address ov protection of any type, you're stuck with installing as shown in . . . http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z16M.pdf Bob . . . ________________________________________________________________________________
Date: Jul 01, 2010
Subject: Re: Battery tender
At 11:26 AM 7/1/2010, you wrote: >I've got a BatteryTender Plus that has a float voltage of 12.7 >volts. This is on both a new battery and the one that is being >replaced. Is it time for a new Batterytender? Sounds like it . . . if you're sure the voltmeter is reading correctly . . . Bob . . . ________________________________________________________________________________
Date: Jul 02, 2010
Thanks Bob, yep, I checked it with 3 different meters and they all read the same. I just talked to Deltran and they confirmed that the Batterytender probably was ready for the big parts box in the sky. That'll teach me to let the thing fall off the wing...more than once . Bill ----- Original Message ----- From: Robert L. Nuckolls, III To: aeroelectric-list(at)matronics.com Sent: Thursday, July 01, 2010 11:03 PM Subject: Re: AeroElectric-List: Battery tender At 11:26 AM 7/1/2010, you wrote: I've got a BatteryTender Plus that has a float voltage of 12.7 volts. This is on both a new battery and the one that is being replaced. Is it time for a new Batterytender? Sounds like it . . . if you're sure the voltmeter is reading correctly . . . Bob . . . ------------------------------------------------------------------------- ----- Checked by AVG - www.avg.com 07/01/10 01:35:00 ________________________________________________________________________________
Subject: Re: ICOM A 210 matched with a Flightcom 403 intercom
From: "chris Sinfield" <chris_sinfield(at)yahoo.com.au>
Date: Jul 02, 2010
Alberto Thats the radio that I am installing in my plane as well. I also note it has aux inputs available for the MP3 and GPS warning. As I am a 2 seat Zodiac XL thats all I should need as its got a built in Intercom, thats one of its selling features. Friends with the radio love the intercom and say its great. Chris Sydney Australia Read this topic online here: http://forums.matronics.com/viewtopic.php?p=303521#303521 ________________________________________________________________________________
Subject: Over Voltage Module sharing?
Date: Jul 02, 2010
Trying again. I'm using Z13 in conjunction with Z31-B. Is there anything wrong about the aux alternator and the ground power jack sharing the same OVM? The only condition that I can think of where both systems would be in use simultaneously is a ground powered START on the aux alternator and that may not even be an issue unless the OVM tripped. The issue being what caused it, the GPU or the aux alt. Is this doable? Unwise?, how would I wire it? Thanks, John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=303524#303524 ________________________________________________________________________________
Date: Jul 02, 2010
> I have one you would be welcome to borrow. 3-1/8 on one side, 2-1/4 on > the > other. Kind of heavy but maybe one of those "if it fits it ships" USPS > boxes wouldn't be too much. > > Allen Fulmer > Alexander City, AL 35010 Allen, I tried to contact you off line but did not get a response. I would like to take you up on your offer to let me borrow your punches. I will be happy to pay the Flat Rate USPS postage both ways. If you have changed you mind about loaning the punch, please let me know and I will make other arrangements. Thanks, Roger ________________________________________________________________________________
Date: Jul 02, 2010
Bill, ...before you trash the BT, take it apart. Unless, they have changed the assembly, it used to have 2 adjustable pots inside. You had to pick off a little silicon glue first. One pot set the max voltage charge level before it flipped state to the float voltage level. The second pot set the float voltage. That one should be about 13.2 - 13.4 volts. If you can make adjustments on your unit, make very tiny pot corrections and wait to see where the level settles out. I have seen brand new units not set correctly. You can also let us know if they pot the units now, or got rid of the pots..... David ----- Original Message ----- From: Bill Hibbing To: aeroelectric-list(at)matronics.com Sent: Friday, July 02, 2010 10:46 AM Subject: Re: AeroElectric-List: Battery tender Thanks Bob, yep, I checked it with 3 different meters and they all read the same. I just talked to Deltran and they confirmed that the Batterytender probably was ready for the big parts box in the sky. That'll teach me to let the thing fall off the wing...more than once . Bill ----- Original Message ----- From: Robert L. Nuckolls, III To: aeroelectric-list(at)matronics.com Sent: Thursday, July 01, 2010 11:03 PM Subject: Re: AeroElectric-List: Battery tender At 11:26 AM 7/1/2010, you wrote: I've got a BatteryTender Plus that has a float voltage of 12.7 volts. This is on both a new battery and the one that is being replaced. Is it time for a new Batterytender? Sounds like it . . . if you're sure the voltmeter is reading correctly . . . Bob . . . href="http://www.matronics.com/Navigator?AeroElectric-List">http://www. matronics.com/Navigator?AeroElectric-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ------------------------------------------------------------------------- --- - Release Date: 07/01/10 01:35:00 ________________________________________________________________________________
Date: Jul 02, 2010
Thanks David. I'll give it a try tomorrow if I get out to my hangar. This is an old unit...had it for about 7-8 years now. I ordered up a new so if this doesn't work I have a back up. Any idea on which pot is which? Bill ----- Original Message ----- From: David LLoyd To: aeroelectric-list(at)matronics.com Sent: Friday, July 02, 2010 8:29 PM Subject: Re: AeroElectric-List: Battery tender Bill, ...before you trash the BT, take it apart. Unless, they have changed the assembly, it used to have 2 adjustable pots inside. You had to pick off a little silicon glue first. One pot set the max voltage charge level before it flipped state to the float voltage level. The second pot set the float voltage. That one should be about 13.2 - 13.4 volts. If you can make adjustments on your unit, make very tiny pot corrections and wait to see where the level settles out. I have seen brand new units not set correctly. You can also let us know if they pot the units now, or got rid of the pots..... David ________________________________________________________________________________
Date: Jul 02, 2010
Bill, I knew you might ask me that question.....which pot.? My old notes are in the hangar and I can't get to it until the 6th as we are heading to WA in the morning....on 4 wheels not, 3. I'll try to find the notes, when I return. David ------------------------------------------------------------------------- ------- ----- Original Message ----- From: Bill Hibbing To: aeroelectric-list(at)matronics.com Sent: Friday, July 02, 2010 7:44 PM Subject: Re: AeroElectric-List: Battery tender Thanks David. I'll give it a try tomorrow if I get out to my hangar. This is an old unit...had it for about 7-8 years now. I ordered up a new so if this doesn't work I have a back up. Any idea on which pot is which? Bill ----- Original Message ----- From: David LLoyd To: aeroelectric-list(at)matronics.com Sent: Friday, July 02, 2010 8:29 PM Subject: Re: AeroElectric-List: Battery tender Bill, ...before you trash the BT, take it apart. Unless, they have changed the assembly, it used to have 2 adjustable pots inside. You had to pick off a little silicon glue first. One pot set the max voltage charge level before it flipped state to the float voltage level. The second pot set the float voltage. That one should be about 13.2 - 13.4 volts. If you can make adjustments on your unit, make very tiny pot corrections and wait to see where the level settles out. I have seen brand new units not set correctly. You can also let us know if they pot the units now, or got rid of the pots..... David ________________________________________________________________________________
Date: Jul 03, 2010
From: Iberplanes IGD - Alberto Martin <iberplanes(at)gmail.com>
Thanks Chris, I am also building a Zodiac, now I=B4m applying the upgrade. If you are in the Zenith Aero as a member, seach for iberplanes so we can contact each other on line. Thank you very much for your comments on the intercom, very useful. Take care, Alberto, Alberto Martin www.iberplanes.es Igualada - Barcelona - Spain ---------------------------------------------- Zodiac 601 XL Builder Serial: 6-7011 Tail Kit: Finished Wings: Not Started Fuselage: Started Engine: Jabiru 3300 Un ingles a Tom Lucero en la guerra de Malvinas: "=A1Piloto argentino mejor aqu=ED con nosotros en camilla. Muy peligroso arriba, en su avi=F3n!=97". Un pasaje del libro "Dios y Los Halcones" del Com. Pablo M. Carballo ________________________________________________________________________________
Subject: Switch Labeling
Date: Jul 03, 2010
Hi! I got my panel figured out, but the actual labeling layout has made me think I need to change some things. I originally had planned on having a row of toggle switches about as close together as they'd comfortably go, which is ~0.9" I believe. Here is a rough schematic of how I was planning it originally. At this stage there are no labels, i.e. the text is just to identify items in the computer image. -------- Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=303606#303606 Attachments: http://forums.matronics.com//files/dans_panel_for_labels_to_scale_original_147.pdf ________________________________________________________________________________
Subject: Re: Switch Labeling
Date: Jul 03, 2010
I found that I'd have a hard time putting the actual labels on for the two 2-10 off-on-on switches, assuming I want to have the center positions labeled. So I figured I could eliminate the 'EFIS alarm' light and move the two offending switches over almost an inch. This would allow me to apply the labels to the center positions. This 'EFIS alarm' is programmable and as far as I understand it could come on as a secondary alarm to the screen alarm for any or all alarms. So I'd have the screen flashing at me as well as this light. There is also an audio alarm that can be programmed to come on through the headphones whenever any or all screen alarms come on. Seems I could rely on just the screen and audio alarms, safely ditching the extra light alarm. This is for a Sonex, which has a 30 degree tilted main panel and a 1.5" vertical subpanel. The EFIS is an MGL Enigma, which barely fits. The bold black text in this diagram is the exact size the labels might be. Font is Myriad Bold 11.47, fwiw. I thought I'd put in 12, but must have messed it up somehow. Also forgot to remove the 'primer' text on the red knob. I've printed out a full size version and it seems to be easily readable. The only difference is my panel would be Rustoleum Hammered Black and the labels white, so the contrast should be about the same. I just got Decal Pro to make these. Once applied, I've got some clear matte to spray over the top to protect them and cut down on the sorta glossy hammered finish. The only info I've gotten about labeling is from browsing pics of people's panels on the web. So please let me know if you you have any suggestions. Thanks! -------- Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=303608#303608 Attachments: http://forums.matronics.com//files/dans_panel_for_labels_to_scale_switches_spread_209.pdf ________________________________________________________________________________
Date: Jul 04, 2010
At 12:46 PM 7/2/2010, you wrote: >Thanks Bob, yep, I checked it with 3 different meters and they all >read the same. I just talked to Deltran and they confirmed that the >Batterytender probably was ready for the big parts box in the >sky. That'll teach me to let the thing fall off the wing...more than once . Hmmm . . . Dave has suggested exploring a diddling-of-the-pots. It that doesn't revive the ol' feller, consider a Schumacher 1562 series device from WalMart. About 1/2 the price if you have to have the BT shipped in . . . and about twice the snort (0.8 versus 1.5 amps). Bob . . . ________________________________________________________________________________
Date: Jul 04, 2010
At 08:35 AM 7/1/2010, you wrote: > >Hi Bob, > Is the paralysis resolving? I'm wondering when the 9004 and 9011 > modules will be available. >Thanks, >Eric Schlanser >W-10/Lycoming O320 with Z-13 and maybe Z-24 I did some more think-work on them while on the round trip to Denver. Got the packaging decisions resolved. I'll do a board layout on the 9004 Monday and get some proof-of-concept parts built for my software guy to play with. Should be within the next 60 cays. By the way, I'll be looking for "Beta testers" for the 9004. I'll provide a ship set of 9004 parts to someone who is already flying regularly if they'll install the parts and give me feedback on installation/operational/performance issues. Email me directly. The 9011 design is done. I just need to inventory up on parts and show the kids how to assemble and test them. We'll do both programs together. Bob . . . ________________________________________________________________________________
Subject: AEC-9011
Date: Jul 04, 2010
Bob; On page 4 of the document found here http://www.aeroelectric.com/Catalog/AEC/9011/9011-700-1C.pdf at bottom of the page, the connections are shown for the various pins in the D9P connector. Pin 6 is used twice. Typo I would imagine?? Same issue in this drawing http://www.aeroelectric.com/Catalog/AEC/9011/9011_PM_OV-LV.pdf Bob McC ________________________________________________________________________________
Date: Jul 04, 2010
I'm a bit embarrassed, but at least I caught my mistake. I had designed my instrument panel last summer, and in the fall I added a boost pump to the fuel system. When I resumed the instrument panel project a few days ago, I had forgotten all about adding the boost pump. So I've added a 2-3 switch for this in my design. Below is one possible solution doing it this way, which keeps the center position labeling format by still having the 2-10 switches separated from the others. I've simply moved both the 'push start' button and 'starter engaged' up and the mag switches over. -------- Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=303708#303708 Attachments: http://forums.matronics.com//files/dans_panel_for_labels_to_scale_starter_above_116.pdf ________________________________________________________________________________
Date: Jul 04, 2010
Another option is to put the fuel pump switch in the space between the 2-10 switches and 2-3 switches. The labeling is more cluttered and confusing, but it allows the starter button to stay in the same row. I also switched the ALT/BAT main power switch with the EFIS PWR switch. I'd prolly do this in the previous layout, but just didn't catch it before posting. So the start sequence would be flip the ALT/BAT switch (up). I think the ALT WARN light would come on in either center or up positions, since the alternator is offline. I'll have to double check how I'd wired it. I have the Jabiru voltage regulator and have the green (LV) wire available for this. As I understand it, this would be the lead to connect to the ALT WARN light. Next would be the EFIS PWR to center. If the EFIS powers up, I know my EFIS backup battery is working. Flipping it to the up position would bring the main battery online to the EFIS, which is needed to charge the backup. The fuel pump, left and right mag switches would be turned on in order. The primer cable needs to be pulled open for a few seconds when cold starting. I have a Rotec TBI and doing this opens the diaphragm to allow more fuel to flow. I imagine if this is done when the fuel pump has been turned on, it wouldn't need to stay open as long as with the pump off. I'll figure out later whether it's better if the primer is pulled before or after the fuel pump is turned on. With my non-pilot eyes, it seems the the layout with the gap between the 2-10 switches and the others is simpler. The center positions for both switches are easier to read. And the gap in the row of switches separates the switches a little more making it easier to find things. For example, suppose I've reached altitude and turned off the boost pump when my mechanical pump fails. It would be easier to locate the fuel pump switch as the left most switch of three, compared to the middle one of five. -------- Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=303713#303713 ________________________________________________________________________________
From: "michael harris" <bearhawk390(at)clearwire.net>
Subject: newbie
Date: Jul 05, 2010
greetings all, I just finished reading the aero connection wow! THANK YOU BOB for all your efforts, although extremely informative it opens up a whole new list of questions, and before I ask those questions I wanted to be sure iam posting them in the right place. ________________________________________________________________________________
Date: Jun 28, 2010
Subject: Re: Ground Power and Aux Alt sharing OVM?
At 12:49 PM 6/28/2010, you wrote: > >I'm using Z13 in conjunction with Z31-B. Is there anything wrong >about the aux alternator and the ground power jack sharing the same >OVM? The only condition that I can think of where both systems would >be in use simultaneously is a ground powered START on the aux >alternator and that may not even be an issue unless the OVM tripped. >The issue being what caused it, the GPU or the aux alt. > >If this passes group muster, how would I wire it? Can't think of a practical way to do it. Bob . . . ________________________________________________________________________________
Date: Jul 05, 2010
Subject: Re: newbie
At 08:25 AM 7/5/2010, you wrote: >greetings all, > I just finished reading the aero connection wow! THANK YOU BOB > for all your efforts, although extremely informative it opens up a > whole new list of questions, and before I ask those questions I > wanted to be sure iam posting them in the right place. Absolutely. The AeroElectric-List is a community supported classroom where the only expectations for participation are a civil demeanor and a quest for improving upon the best we know how to do. There are about 1800 folk who find value in watching what transpires here on the List. The sum total of personal experience of implementing recipes for success by our participants must be measured in centuries. I attended a family gathering in Denver this past weekend. One of the topics of discussion amongst those of us once or presently employed in the technical professions was the steady decline of technical expertise and skill in virtually every institution of which any had personal experience. For all the ISO, EPA, OSHA, FAA, etc. etc. directives for success, virtually no such institutions seemed aware of the means by which tribal knowledge is passed to those who follow. Until we can do the Vulcan mind-meld and pass all understanding by mere touch, one-on-one mentorship will have to suffice . . . and it has . . . for thousands of years. You are indeed in the right place my friend. Welcome aboard! Bob . . . ________________________________________________________________________________
Date: Jul 05, 2010
Subject: Re: AEC-9011
At 12:23 PM 7/4/2010, you wrote: >Bob; > >On page 4 of the document found here ><http://www.aeroelectric.com/Catalog/AEC/9011/9011-700-1C.pdf>http://www.aeroelectric.com/Catalog/AEC/9011/9011-700-1C.pdf >at bottom of the page, the connections are shown for the various >pins in the D9P connector. Pin 6 is used twice. Typo I would >imagine?? Same issue in this drawing ><http://www.aeroelectric.com/Catalog/AEC/9011/9011_PM_OV-LV.pdf>http://www.aeroelectric.com/Catalog/AEC/9011/9011_PM_OV-LV.pdf > > >Bob McC Yes, those are preliminary documents and I appreciate the heads-up. Bob . . . ________________________________________________________________________________
Subject: Headset and mic shield question
Date: Jul 05, 2010
My 2 place Europa has a PS audio panel. I need to route shielded headset and mic wires out the port side of instrument module through a D-sub connector. Curiosity question, what would happen if the shields were connected at the D-sub? Thx. Ron Parigoris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=303808#303808 ________________________________________________________________________________
Date: Jul 05, 2010
Subject: Re: Headset and mic shield question
At 11:55 AM 7/5/2010, you wrote: > > >My 2 place Europa has a PS audio panel. I need to route shielded >headset and mic wires out the port side of instrument module through >a D-sub connector. > >Curiosity question, what would happen if the shields were connected >at the D-sub? What does the PS installation instructions say about shielding? It should describe their recommendations for terminating the shields. Do they use the shields a part of the signal paths (i.e. grounds) or are they simply shields over an array of wires? It makes a difference and they should tell you exactly how to do it. For example, on page 1.10 of http://www.aeroelectric.com/Catalog/AEC/9009/9009-700L.pdf you can see examples of shield-only and shield-plus-signal connections for shielded wires. Bob . . . ________________________________________________________________________________
From: Robert Dufresne <robertdufresne(at)videotron.ca>
Subject: AEC-9011
Date: Jul 05, 2010
Hi, Where can I find the meaning of the symbols 3, P2, A1, S8, K10, 5, L4, L6, 7 in hexagonal boxes on page 4 of document 9011-700-1C.pdf. Robert D. De : owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] De la part de Robert L. Nuckolls, III Envoy=E9 : 5 juillet 2010 10:04 =C0 : aeroelectric-list(at)matronics.com Objet : Re: AeroElectric-List: AEC-9011 At 12:23 PM 7/4/2010, you wrote: Bob; On page 4 of the document found here http://www.aeroelectric.com/Catalog/AEC/9011/9011-700-1C.pdf at bottom of the page, the connections are shown for the various pins in the D9P connector. Pin 6 is used twice. Typo I would imagine?? Same issue in this drawing http://www.aeroelectric.com/Catalog/AEC/9011/9011_PM_OV-LV.pdf Bob McC Yes, those are preliminary documents and I appreciate the heads-up. Bob . . . ________________________________________________________________________________
Date: Jul 05, 2010
Subject: AEC-9011
At 02:06 PM 7/5/2010, you wrote: >Hi, > >Where can I find the meaning of the symbols 3, P2, A1, S8, K10, 5, >L4, L6, 7 in hexagonal boxes on page 4 of document 9011-700-1C.pdf. > That's a preliminary document intended only to describe the spirit-and-intent of the new product. When the design is finalized, the document will be updated to look like this one http://www.aeroelectric.com/Catalog/AEC/9005/LV_Warn_Fab_and_Install.pdf where a spread-sheet of reference designators and the materials call-outs will be fully expanded like on page 3. Bob . . . ________________________________________________________________________________
Subject: Microphone levels
Date: Jul 05, 2010
Bob, Would you expect that the microphone output level from a standard Aviation headset to be similar/ or even the same as a standard handheld audio microphone as used with a professional sound board? I don't own an audio meter but just need to be close for a non-aircraft related project. Bevan Rv7A Implementing Z13/8 ________________________________________________________________________________
Date: Jul 05, 2010
Hi Bob I have a PS Engineering PMA 4000. See: Page #21: http://www.ps-engineering.com/docs/PMA4000_IM.pdf Each 2 or 3 conductor cable has the shield connected to a different pin on the 25 pinb P1 Bottom Unit Connector. If pin 1, 2 , 6 and 7 were to touch each other at my D-sub connector, what trouble (if any) might that cause? Thx. Ron Parigoris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=303825#303825 ________________________________________________________________________________
Date: Jul 05, 2010
Subject: Re: Microphone levels
At 03:04 PM 7/5/2010, you wrote: > > Bob, > >Would you expect that the microphone output level from a standard Aviation >headset to be similar/ or even the same as a standard handheld audio >microphone as used with a professional sound board? No. Aircraft microphones are victim to legacy compatibility standards that emulate the original carbon granule microphones (like those in telephones through the 70s). http://en.wikipedia.org/wiki/Carbon_microphone The audio output is not only very high (as much as 1 vrms) it is generated with a power supply delivered by the transmitter. Hence, most aircraft microphones have active electronics so that modern TINY voltage microphones can dress up like a carbon mic. > I don't own an audio >meter but just need to be close for a non-aircraft related project. Sound boards are generally set up to accept 100 mV pk-pk (30 mV rms) output from dynamic mics delivered on twisted pairs. Bob . . . ________________________________________________________________________________
Date: Jul 05, 2010
Subject: stray RF
Hi Bob I have recently developed a problem when I transmit my VSI and other features on my Cheltons goes crazy. I have added a engine monitor EI MVP-50 recently. Is there a way to isolate the cause. This is a recent occurance No prior problem for 350 hrs James Robinson Glasair lll N79R Spanish Fork UT U77 ________________________________ ________________________________________________________________________________
Date: Jul 05, 2010
Thanks Bob, exactly what I'm looking for. Bevan -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Monday, July 05, 2010 3:26 PM Subject: Re: AeroElectric-List: Microphone levels --> At 03:04 PM 7/5/2010, you wrote: >--> > > Bob, > >Would you expect that the microphone output level from a standard >Aviation headset to be similar/ or even the same as a standard handheld >audio microphone as used with a professional sound board? No. Aircraft microphones are victim to legacy compatibility standards that emulate the original carbon granule microphones (like those in telephones through the 70s). http://en.wikipedia.org/wiki/Carbon_microphone The audio output is not only very high (as much as 1 vrms) it is generated with a power supply delivered by the transmitter. Hence, most aircraft microphones have active electronics so that modern TINY voltage microphones can dress up like a carbon mic. > I don't own an audio >meter but just need to be close for a non-aircraft related project. Sound boards are generally set up to accept 100 mV pk-pk (30 mV rms) output from dynamic mics delivered on twisted pairs. Bob . . . ________________________________________________________________________________
Date: Jul 06, 2010
Subject: Matronics.com access?
Is anyone having trouble accessing http://matronics.com Bob . . . ________________________________________________________________________________
Date: Jul 06, 2010
Subject: Re: stray RF
At 11:18 PM 7/5/2010, you wrote: >Hi Bob >I have recently developed a problem when I transmit my VSI and other >features on my Cheltons goes crazy. I have added a engine monitor >EI MVP-50 recently. Is there a way to isolate the cause. This is a >recent occurance No prior problem for 350 hrs A high-probability possibility is that a feed line shield has become detached at one end or the other on your comm antenna. A simple inspection may suffice. An organized troubleshooting effort suggest you dummy load the transceiver at the back of the tray with a device like this: http://aeroelectric.com/Pictures/Tools/RF_Antenna_Test_Tools/DummyLoad.jpg See if the problem goes away. If so, then move the dummy load to the other end of the feedline. You'll need a male-male adapter, a t-connector can be used too. Try again to see if the problem goes away or is still there. If the problem does not manifest with either dummy load experiment, then it's likely that something has changed in system conditions for the Cheltons. But I'm betting it's a feed line problem. Bob . . . ________________________________________________________________________________
Date: Jul 06, 2010
Subject: Re: Matronics.com access?
At 09:26 AM 7/6/2010, you wrote: > > >Is anyone having trouble accessing http://matronics.com > I think the servers were down for a period of time since midnight last night but they seem to be up now. All is right with the world . . . Bob . . . ________________________________________________________________________________
Date: Jul 06, 2010
Bob, Yup, it was down for a while but seems to be back up now. Bob Borger On Jul 6, 2010, at 9:26, Robert L. Nuckolls, III wrote: > > Is anyone having trouble accessing http://matronics.com > > > > > Bob . . . > > > > ________________________________________________________________________________
Date: Jul 06, 2010
Is anyone having trouble accessing http://matronics.com Bob . . . Seems to be OK for me Roger ________________________________________________________________________________
Date: Jul 06, 2010
Thanks Bob!!!! James Robinson Glasair lll N79R Spanish Fork UT U77 ________________________________ From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Sent: Tue, July 6, 2010 10:45:17 AM Subject: Re: AeroElectric-List: stray RF At 11:18 PM 7/5/2010, you wrote: > Hi Bob > I have recently developed a problem when I transmit my VSI and other features >on my Cheltons goes crazy. I have added a engine monitor EI MVP-50 recently. >Is there a way to isolate the cause. This is a recent occurance No prior >problem for 350 hrs A high-probability possibility is that a feed line shield has become detached at one end or the other on your comm antenna. A simple inspection may suffice. An organized troubleshooting effort suggest you dummy load the transceiver at the back of the tray with a device like this: http://aeroelectric.com/Pictures/Tools/RF_Antenna_Test_Tools/DummyLoad.jpg See if the problem goes away. If so, then move the dummy load to the other end of the feedline. You'll need a male-male adapter, a t-connector can be used too. Try again to see if the problem goes away or is still there. If the problem does not manifest with either dummy load experiment, then it's likely that something has changed in system conditions for the Cheltons. But I'm betting it's a feed line problem. Bob . . . ________________________________________________________________________________
Subject: Heat Sink necessary?
Date: Jul 06, 2010
Using a 25a bridge rectifier for dual power sources for EFI. The injectors might pull 10a, worst case. For normal ops, 6a. Is heat sinking necessary for the rectifer? Thanks, J Read this topic online here: http://forums.matronics.com/viewtopic.php?p=303922#303922 ________________________________________________________________________________
Subject: Z-31B Ground Power Contactor Diode
Date: Jul 06, 2010
In Z-31B, I'm using a continuous duty contactor with one coil post, like the one shown in the diagram and labled"Existing Battery Contactor", for a Grd. Pwr. Contactor. I'm unsure about where to place and how to orient the diode for a GP jack when using the CD contactor. Thanks for any help, J Read this topic online here: http://forums.matronics.com/viewtopic.php?p=303931#303931 ________________________________________________________________________________
Date: Jul 06, 2010
Jon, You are mixing supply and demand (but that's ok). Normally it is suggested a heat sink be used for a sink load of 20A or more. Since your hardware is bigger than your load you could try it without. If it is continuous load you may want to monitor the rectifier temperature to be sure you're in limits. The manufacturer should publish that. If you're at all concerned about temperature, just add a heat sink. If the heat sink sets you back wait till you see the price at the gas pump. Wow! The poor man's option is to mount it on a piece phenolic block which you'll find does little for heat dissipation but is virtually indestructible should your diode take to glowing in flight. You can cut some grooves in the top of the block to allow air to travel underneath the rectifier. You can also buy one of those computer fans and a frame for about a $1.00 to point in the general direction. I have a variety pack of those stick on thermometers that lets one visualize surface temps. Could be handy for something like this. Most of this is much more fuss than just installing the heat sink. Hey, what kind of injectors pull 10A? I suppose you mean the ignition module. Enjoy, Glenn E. Long -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of jonlaury Sent: Tuesday, July 06, 2010 2:08 PM Subject: AeroElectric-List: Heat Sink necessary? Using a 25a bridge rectifier for dual power sources for EFI. The injectors might pull 10a, worst case. For normal ops, 6a. Is heat sinking necessary for the rectifer? Thanks, J Read this topic online here: http://forums.matronics.com/viewtopic.php?p=303922#303922 ________________________________________________________________________________
Date: Jul 06, 2010
Subject: Re: HLMP-2685 multi-LEDs off LR3C
Bob, Just to feed back to you and anyone on the list who might fancy using the HLMP-2685 as a snazzy LED alt. warn. light for the LR3C regulator, I'd like to report the following: It works quite well putting the 8 LEDs of the HLMP in two parallel banks of 4 resistors in series, i.e. four LEDs on one side, in series, put in parallel with the other four LEDs on the other side, those also put in series. I put a current-limiting resistor of 440 ohms works well. In fact, it was two 220 ohm resistors in series, but then I don't have much of a resistor selection... This arrangement seems to check out okay, and looks to be about the right brightness. I might tweak it a little bit at some point. When the warning light is "off", I can't discern any light from the HLMP, and indeed on the bench I can discern no light from it at 6.0V. For day time it looks good, though it might also be too bright for night time use. FWIW! Thanks for your guidance on this matter. James On Sun, Apr 11, 2010 at 12:28 PM, James Kilford wrote: > Bob, > > That's great, thank you. It gives me a good place from which to experiment. > > James > > On Thu, Apr 8, 2010 at 2:04 PM, Robert L. Nuckolls, III > wrote: >> >> >> >>> >>> >>> http://parts.digikey.com/1/parts/681506-led-lt-bar-hi-eff-red-8led-dip-hlmp2685.html >>> >>> I'd like to hook one of these to the LR3C regulator instead of the >>> supplied filament lamp, so that it can go into the annunciator panel >>> too. >>> >>> I've been trying to trace a schematic of Bob's, which I'm sure I've >>> seen, of how to use an LED instead of a filament lamp with the LR3C, >>> as a starting point. I can't find it, and the resistor values would >>> be different in any case, so can anyone throw any light on to how to >>> use one of these 8-LED devices with the LR3C? >> >> The schematic I published is at: >> >> http://aeroelectric.com/Pictures/Schematics/LR3_LV_Led_1.jpg >> >> Your application will take some experimentation. >> You can try paralleling all the LEDs and seeing how >> well you can excite the array and still have uniform >> illumination. You may find that you need to treat >> them as separate LEDs. >> >> Just be aware that LR3 lamp driver is never completely >> "OFF". The off current is too low to get any light >> from a bulb but it will cause an LED to glow at a >> reduced intensity. Hence the paralleling resistor to >> get the LED to mimic a lamp more closely. >> >> Bob . . . >> >> ________________________________________________________________________________
Date: Jul 06, 2010
No problem from here no not archive On Tue, Jul 6, 2010 at 10:26 AM, Robert L. Nuckolls, III wrote: > > > Is anyone having trouble accessing http://matronics.com > > > Bob . . . > > ________________________________________________________________________________
Date: Jul 06, 2010
Bob, My interface circuit which brings a line level output through an impedance matching transformer to the mic input of the aircraft radio may need to go through a capacitor to block the DC bias voltage coming from the radio from getting to the output of the matching transformer. Do you agree with this method and can you recommend a value for this cap? Bevan -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Monday, July 05, 2010 3:26 PM Subject: Re: AeroElectric-List: Microphone levels --> At 03:04 PM 7/5/2010, you wrote: >--> > > Bob, > >Would you expect that the microphone output level from a standard >Aviation headset to be similar/ or even the same as a standard handheld >audio microphone as used with a professional sound board? No. Aircraft microphones are victim to legacy compatibility standards that emulate the original carbon granule microphones (like those in telephones through the 70s). http://en.wikipedia.org/wiki/Carbon_microphone The audio output is not only very high (as much as 1 vrms) it is generated with a power supply delivered by the transmitter. Hence, most aircraft microphones have active electronics so that modern TINY voltage microphones can dress up like a carbon mic. > I don't own an audio >meter but just need to be close for a non-aircraft related project. Sound boards are generally set up to accept 100 mV pk-pk (30 mV rms) output from dynamic mics delivered on twisted pairs. Bob . . . ________________________________________________________________________________
Date: Jul 06, 2010
Subject: Re: Heat Sink necessary?
At 01:07 PM 7/6/2010, you wrote: > >Using a 25a bridge rectifier for dual power sources for EFI. The >injectors might pull 10a, worst case. For normal ops, 6a. >Is heat sinking necessary for the rectifer? yes . . . but simply mounting it to a metallic surface on the airplane will be sufficient. 10A on any one leg of the device will dissipate about 7 watts of heat that is easily managed by most metal surface mounting situations. Doing in-situ temperature measurements on the molded bridge rectifier is VERY difficult. There's no thermally integral metal surface available for sampling. You'd need to bury a tiny-wire thermocouple in the mounting under the rectifier assembly. You can measure the temperature of the sheet metal directly opposite the rectifier and make some assumptions about thermal resistance of the mounting . . . but it's more fuss than you'd probably want to experience. 10A doesn't present much of a challenge to a device with a metal heat-sink interface. Use a little 'heat sink' grease under it when mounting. http://www.radioshack.com/product/index.jsp?productId=2102858 Bob . . . ________________________________________________________________________________
Date: Jul 06, 2010
Subject: Re: Z-31B Ground Power Contactor Diode
At 01:39 PM 7/6/2010, you wrote: > >In Z-31B, I'm using a continuous duty contactor with one coil post, >like the one shown in the diagram and labled"Existing Battery >Contactor", for a Grd. Pwr. Contactor. > >I'm unsure about where to place and how to orient the diode for a GP >jack when using the CD contactor. The banded end of the diode connects to the "BAT" terminal of the contactor which in turn faces incoming power from the ground power connector. The other end of the diode goes to the small coil terminal which is switched to ground to energize the contactor and bring ground power onto the bus. Bob . . . ________________________________________________________________________________
Date: Jul 06, 2010
At 02:58 PM 7/6/2010, you wrote: > >Bob, > >My interface circuit which brings a line level output through an impedance >matching transformer to the mic input of the aircraft radio may need to go >through a capacitor to block the DC bias voltage coming from the radio from >getting to the output of the matching transformer. Do you agree with this >method and can you recommend a value for this cap? Some experimentation is probably called for. You need to find a resistor value that becomes a 'dummy microphone'. The resistor probably wants to have 2-3 volts dropped across it while the transmitter is 'talking'. Then make sure the effective output impedance and signal level of your transmit audio source can drive the necessary signal into this load . . . 3 v pk-pk is probably a good upper bound to strive for. Then pick a capacitor who's reactance at say 100Hz is about 1/10 that of the sum of dummy load resistor + source output impedance. Bob . . . ________________________________________________________________________________
Date: Jul 06, 2010
At 14:36 7/6/2010, you wrote: >signal level of your transmit audio source can > drive the necessary signal into this load . . . > 3 v pk-pk is probably a good upper bound to > strive for. Without grabbing my scope, 3Vpp --sounds-- a bit hot for a mic input. Is that value a typo? Ron Q. ________________________________________________________________________________
Date: Jul 06, 2010
At 04:46 PM 7/6/2010, you wrote: >At 14:36 7/6/2010, you wrote: >>signal level of your transmit audio source can >> drive the necessary signal into this load . . . >> 3 v pk-pk is probably a good upper bound to >> strive for. > >Without grabbing my scope, 3Vpp --sounds-- a bit hot for a mic input. Nope. That's what can come out of an aircraft microphone the emulates the legacy carbon mic. Of course, REAL carbon microphones are exceedingly rare in service now. Just for grins, put your scope on the mic line of a headset and see what kinds of signals can be seen there. They may have migrated down over the years . . . Bob . . . ________________________________________________________________________________
Date: Jul 06, 2010
At 04:46 PM 7/6/2010, you wrote: >At 14:36 7/6/2010, you wrote: >>signal level of your transmit audio source can >> drive the necessary signal into this load . . . >> 3 v pk-pk is probably a good upper bound to >> strive for. > >Without grabbing my scope, 3Vpp --sounds-- a bit hot for a mic input. Nope. That's what can come out of an aircraft microphone the emulates the legacy carbon mic. Of course, REAL carbon microphones are exceedingly rare in service now. Just for grins, put your scope on the mic line of a headset and see what kinds of signals can be seen there. They may have migrated down over the years . . . P.s. Just checked some links as follows: http://www.capitalavionics.com/tip_0909.asp http://tinyurl.com/24g4wjf and a number of others that 'specd' aircraft mics for sensitivity, current draw, bias voltage but failed to call out the output voltage present when those specs are being satisfied. I think it was DO170 that talks industry specifics. I did see an anecdotal reference to 100-500 mv which would translate to 300-1500 mv pk-pk. Same ball park. We used to design for 3v pk-pk to have zero risk of clipping . . . at least in THAT part of the circuit! Bob . . . ________________________________________________________________________________
Date: Jul 07, 2010
Glen and Bob, Thanks. I used a .063 alum washer for a stand-off from my composite structure which allows air to the metal backside of the rectifier. I will add a larger surface area piece of alum w/recommended grease. The injectors are 55#/hr and my 6 cyl engine, with a bsfc of .55 lbs./hr/hp, will have a max fuel consumption of 132 lbs/hr so these injectors will only see a 40% duty cycle. At 75% they draw 9W each or 54 W, so my normal ops should draw about 2.5 amps. So my initial guess of 6a is too high. The 10 amp circuit recommended by the EFI mfgr is to cover all the bases including low voltage and higher power than my engine makes. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=304047#304047 ________________________________________________________________________________
Date: Jul 07, 2010
At 11:29 AM 7/7/2010, you wrote: > >Glen and Bob, Thanks. > >I used a .063 alum washer for a stand-off from my composite >structure which allows air to the metal backside of the rectifier. I >will add a larger surface area piece of alum w/recommended grease. Okay, recommend something on the order of 10 square inches of .062 aluminum. If you wanted to make it "tighter" on real-estate, you could bend the edges up so that the diode still sits on a flat spot, but the overall width is reduced. >The injectors are 55#/hr and my 6 cyl engine, with a bsfc of .55 >lbs./hr/hp, will have a max fuel consumption of 132 lbs/hr so these >injectors will only see a 40% duty cycle. At 75% they draw 9W each >or 54 W, so my normal ops should draw about 2.5 amps. So my initial >guess of 6a is too high. The 10 amp circuit recommended by the EFI >mfgr is to cover all the bases including low voltage and higher >power than my engine makes. Hmmmm . . . maybe you don't need to do anything with the diode. Wait until you're able to run the engine and take some measurements of your own. It sounds like it might be just fine with zero-heat sink. Bob . . . ________________________________________________________________________________
Date: Jul 07, 2010
Subject: Re: Lithium Battery Option
As far as I know, the granddaddy of all-lithium battery uses is the Tesla =0ARoadster.- Of course, they run the entire car on the battery, so it's a very =0Adifferent beast.- I do know, though, that they get their batte ries made by =0APanasonic.- Given that, I'd say it's a very good bet that Panasonic makes the =0Abest lithium batteries available.- Cost is not a huge issue for a $110K car, so =0Athey weren't scrimping.=0A=0AMay be worth looking into.- You might be able to assemble your own from =0APanasonic parts.- Hey, we're experimentals, right?=0A-=0ADoug Ilg=0AGrumman Tiger N74818, College Park-Airport (KCGS), Maryland=0AChallenger II LSS LW (N6 41LG-reserved)-- kit underway at Laurel Suburban (W18)=0A ________________________________________________________________________________
Date: Jul 07, 2010
A while back Bill Dube mentioned he was offering a A-123 cell battery for aircraft use. Ron P. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=304079#304079 ________________________________________________________________________________
Subject: Dynon D10A sound
Date: Jul 07, 2010
I have a Dynon D10A with a homemade AOA and PS PMA4000 audio panel with unswitched audio inputs. For those who have tried, is it worth it hooking up D10A audio to audio panel? Thx. Ron Parigoris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=304080#304080 ________________________________________________________________________________
Date: Jul 07, 2010
Subject: Re: Dynon D10A sound
If you have an AoA which works yes, it gives you a nice alert! br Wrener On 07.07.2010 22:16, rparigoris wrote: > --> AeroElectric-List message posted by: "rparigoris" > > I have a Dynon D10A with a homemade AOA and PS PMA4000 audio panel with unswitched audio inputs. > > For those who have tried, is it worth it hooking up D10A audio to audio panel? > > Thx. > Ron Parigoris > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=304080#304080 > > ________________________________________________________________________________
Date: Jul 07, 2010
Yep, it's a bit pricey... http://www.motorauthority.com/blog/1039902_porsches-1700-starter-battery-option-for-boxster-spyder-911-gt3 -------- Bill Settle RV-8 Fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=304092#304092 ________________________________________________________________________________
Subject: Re: Panel punch
Date: Jul 07, 2010
> Does anyone on the list have a 3 1/8" panel punch that you might be > willing > to loan out? I have a set of Greenly Punches but do not have one this > large. I need to punch about 3 instrument holes in my panel and I feel > the > punch is the best way to go. The panel is light gauge aluminum, so will > be > very easy to punch. I have considered using a hole saw, but I have never > been able to make a nice clean hole with this method. > > Any help would be appreciated. > > Roger Curtis > Upton, MA > I have one you would be welcome to borrow. 3-1/8 on one side, 2-1/4 on > the > other. Kind of heavy but maybe one of those "if it fits it ships" USPS > boxes wouldn't be too much. > > Allen Fulmer > Alexander City, AL 35010 Allen, Thank you for the loan of your punch. I can't immagine, short of setting the panel up on a milling machine, making instrument holes as nice, smooth, round, easy, and precisely placed, as can be accomplished with the simple punch. This is what it is all about, "Builders helping Builders" Great forum! Roger ________________________________________________________________________________
Date: Jul 07, 2010
=0AIf my math is right, that works out to $77.00/pound. Not quite up to th e rumored $100,000/pound that Formula 1 is willing to pay but still out of my budget.... :-(=0A =0AJon=0A=0A-----Original Message-----=0AFrom: "N38CW " =0ASent: Wednesday, July 7, 2010 3:47pm=0ATo: a eroelectric-list(at)matronics.com=0ASubject: AeroElectric-List: Re: Lithium Ba tle@bellsouth.net>=0A=0AYep, it's a bit pricey...=0A=0Ahttp://www.motorauth ority.com/blog/1039902_porsches-1700-starter-battery-option-for-boxster-spy der-911-gt3=0A=0A--------=0ABill Settle=0ARV-8 Fuselage=0A=0A=0A=0A=0ARead this topic online here:=0A=0Ahttp://forums.matronics.com/viewtopic.php?p= =========0A=0A=0A=0A ________________________________________________________________________________
Date: Jul 07, 2010
"If you have an AoA which works yes, it gives you a nice alert!" Thx. Werner Ron Parigoris ________________________________________________________________________________
Date: Jul 07, 2010
It is sometimes good to imagine what can go wrong. Generally high impedance injectors run around 12 ohms resistance. If one or more injector driver fails on, the engine will likely keep running unless subsequently a fuse pops or a diode fails due to the extra current. I'd consider making sure the diode had some heat sinking and was capable of feeding all six injectors at 100% duty cycle which is likely 7+ amps at 14+ volts. Ken Robert L. Nuckolls, III wrote: > > > At 11:29 AM 7/7/2010, you wrote: >> >> >> Glen and Bob, Thanks. >> >> I used a .063 alum washer for a stand-off from my composite structure >> which allows air to the metal backside of the rectifier. I will add a >> larger surface area piece of alum w/recommended grease. > > Okay, recommend something on the order of 10 square inches > of .062 aluminum. If you wanted to make it "tighter" on > real-estate, you could bend the edges up so that the > diode still sits on a flat spot, but the overall width > is reduced. > >> The injectors are 55#/hr and my 6 cyl engine, with a bsfc of .55 >> lbs./hr/hp, will have a max fuel consumption of 132 lbs/hr so these >> injectors will only see a 40% duty cycle. At 75% they draw 9W each or >> 54 W, so my normal ops should draw about 2.5 amps. So my initial >> guess of 6a is too high. The 10 amp circuit recommended by the EFI >> mfgr is to cover all the bases including low voltage and higher power >> than my engine makes. > > Hmmmm . . . maybe you don't need to do anything with > the diode. Wait until you're able to run the engine > and take some measurements of your own. It sounds > like it might be just fine with zero-heat sink. > > > Bob . . . > ________________________________________________________________________________
Date: Jul 07, 2010
At 05:47 PM 7/7/2010, you wrote: > >It is sometimes good to imagine what can go wrong. Generally high >impedance injectors run around 12 ohms resistance. If one or more >injector driver fails on, the engine will likely keep running unless >subsequently a fuse pops or a diode fails due to the extra current. >I'd consider making sure the diode had some heat sinking and was >capable of feeding all six injectors at 100% duty cycle which is >likely 7+ amps at 14+ volts. Would that not be a multiple failure scenario? . . . and would the engine run with 5 of the 6 injectors turned on hard? Bob . . . ________________________________________________________________________________
Date: Jul 08, 2010
Normally injectors are sized such that full on only represents about 30% extra fuel over full power. (sized primarily to give better idle control) So yes in most cases an engine will run at aircraft cruise power or higher with all injectors locked full on. I would consider one or more locked on injectors a single failure. Older ecu's batch fire injectors and share drivers. But yes you'd need to go into ecu and wiring specifics to determine whether a single failure could lock more than one injector on. 100% extra fuel (twice normal flow) on my subaru makes the exhaust system quite hot but does not stop the engine. Rare but injectors do occasionally fail on. A minor concern admittedly. Similarly for multiple coil ignitions. Rare but I've seen single coils short out internally and draw continuous current. I'm just suggesting that some headroom or safety margin in the sizing and fusing of such circuits is a good idea and that would include any diodes. Ken Robert L. Nuckolls, III wrote: > > > At 05:47 PM 7/7/2010, you wrote: >> >> It is sometimes good to imagine what can go wrong. Generally high >> impedance injectors run around 12 ohms resistance. If one or more >> injector driver fails on, the engine will likely keep running unless >> subsequently a fuse pops or a diode fails due to the extra current. >> I'd consider making sure the diode had some heat sinking and was >> capable of feeding all six injectors at 100% duty cycle which is >> likely 7+ amps at 14+ volts. > > Would that not be a multiple failure scenario? . . . > and would the engine run with 5 of the 6 injectors > turned on hard? > > Bob . . . > ________________________________________________________________________________
Date: Jul 08, 2010
I love it - Porsche throws in a lead acid battery just in case it gets a bit chilly for the lithium. At 13 pounds it's not a huge savings on the RG jobs. Glenn -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Jon Finley Sent: Wednesday, July 07, 2010 6:28 PM Subject: RE: AeroElectric-List: Re: Lithium Battery Option If my math is right, that works out to $77.00/pound. Not quite up to the rumored $100,000/pound that Formula 1 is willing to pay but still out of my budget.... :-( Jon -----Original Message----- From: "N38CW" <billsettle(at)bellsouth.net> Sent: Wednesday, July 7, 2010 3:47pm Subject: AeroElectric-List: Re: Lithium Battery Option Yep, it's a bit pricey... http://www.motorauthority.com/blog/1039902_porsches-1700-starter-battery-option-for-boxster-spyder-911-gt3 -------- Bill Settle RV-8 Fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p======== ________________________________________________________________________________
Date: Jul 08, 2010
Ken, Thank you for your illumination of some issues surrounding EFI. The Simple Digital Systems EFI is the one I'm using. Your comments have explained why SDS said that I might want to consider using a 15 amp circuit. It never made sense to me until I read your comments about sizing for all 6 injectors locking on (100% duty cycle). The bridge diode that I'm using is rated for 25a @ 200v so there seems to be sufficient headroom. My injectors are low impedance type and SDS supplies a 3 x 4 x 1/8" aluminum piece with 3 gold anodized resistors??(I'm guessing) that have fins radiating around them. Installation instructions say this piece can get "quite hot at higher duty cycles". It seems that the SDS EFI 'wants' to have high impedance injectors. Are there advantages to a high impedance architecture? John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=304179#304179 ________________________________________________________________________________
Date: Jul 08, 2010
John Port injectors are usually high impedance and they are by far the most common injector. They simplify control issues and drive circuits and are the only ones that I've played with. Suitable mosfet (transistor) switches are very cheap and don't have large heat sinking requirements. I allow just over 1 millisec opening delay for mine when calculating and the 90 volt spike when I turn them off is not much of a problem. Large injectors for throttle body injection or very high power engines are more likely to be low impedance. Larger injectors need more energy to activate them. I have not used them but they are not uncommon in the aftermarket. Low impedance ones will open faster I believe but you typically throttle back the current to a hold open value. That likely extends life but it also lets them close faster. The higher current and higher voltage spikes of low impedance injectors complicates things. Your power resistors would be there to reduce the hold open current. There are other methods like pulse width modulation, flyback circuits, etc. There are hardware and software methods of accomplishing all this but it is simpler with the high impedance (lower current) injectors. I'm pleased if I helped a bit. SDS does good work and they likely have better explanations of this on their extensive website so definitely follow their recommendations. Ken jonlaury wrote: > > > Ken, Thank you for your illumination of some issues surrounding EFI. > The Simple Digital Systems EFI is the one I'm using. Your comments > have explained why SDS said that I might want to consider using a 15 > amp circuit. It never made sense to me until I read your comments > about sizing for all 6 injectors locking on (100% duty cycle). The > bridge diode that I'm using is rated for 25a @ 200v so there seems to > be sufficient headroom. My injectors are low impedance type and SDS > supplies a 3 x 4 x 1/8" aluminum piece with 3 gold anodized > resistors??(I'm guessing) that have fins radiating around them. > Installation instructions say this piece can get "quite hot at higher > duty cycles". It seems that the SDS EFI 'wants' to have high > impedance injectors. Are there advantages to a high impedance > architecture? > > John > ________________________________________________________________________________
Subject: Quick splice connectors?
Date: Jul 08, 2010
I've begun wiring, and have always hated cutting a good wire to splice into it. I've found no reference to the quick splices in any of the aircraft parts catalogs, so before giving up, and cutting the ignition CDI wires to connect the kill switches (That alone feels all sorts of wrong to me..), I thought I'd ask the question: Has anyone used a splice such as http://www.wiringproducts.com/contents/en-us/d266.html in their wiring? Thanks, -Jack Austin, TX Avid Catalina (getting there..) ________________________________________________________________________________
Date: Jul 08, 2010
Subject: Re: Quick splice connectors?
>I thought I'd ask the question: Has anyone used a splice >such as http://www.wiringproducts.com/contents/en-us/d266.html >in their wiring? Keep in mind that the design goal for bringing two wires together is "gas tightness". I.e. give the joining the same environmental resistance to effects of moisture and oxygen as if they were one piece of metal. Detailed discussions of these goals and some of the recipes for achieving them are discussed at: http://aeroelectric.com/articles/rules/review.html http://aeroelectric.com/articles/Solder_Lap_Splicing/Solder_Lap_Splices.html http://aeroelectric.com/articles/terminal.pdf The splices you've cited are not crafted to these design goals. I've seen those used on aircraft that traveled to various air shows . . . but the question to be asked is not "have you used them?" but "what studies have shown them to be of the same caliber as legacy products and processes that have been proven to be essentially zero risk?" Bob . . . ________________________________________________________________________________
From: "Bob McCallum" <robert.mccallum2(at)sympatico.ca>
Date: Jul 08, 2010
Jack; Absolutely not! These were developed, I believe, as a "quick'n'dirty", temporary connection in the automotive industry for such applications as a one time trailer hook-up for say a rental trailer. Personal (bad) experience is that they are unreliable and in a very short time the nice one piece original wire will corrode through where this so called "splice" damaged the insulation. I wouldn't use them for anything let alone on an aircraft. They certainly don't provide the nice solid "gas tight" joint that the properly crimped PIDG terminals provide. Where and how would you propose to use such a connection? I don't follow the reference to having to cut the CDI wires. The power supply to a CDI ignition, I would have thought, would involve a supply wire and a ground wire just like any other accessory. No?? If they need to be "spliced" then a proper PIDG splice is the way to go. See http://tinyurl.com/2575j6g or http://tinyurl.com/27zackn Now all of this is my personal opinion and others may differ, but for what it may be worth, there you have it. Bob McC > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list- > server(at)matronics.com] On Behalf Of Jack L Bell > Sent: Thursday, July 08, 2010 5:08 PM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Quick splice connectors? > > > > > I've begun wiring, and have always hated cutting a good wire > to splice into it. I've found no reference to the quick > splices in any of the aircraft parts catalogs, so before > giving up, and cutting the ignition CDI wires to connect > the kill switches (That alone feels all sorts of wrong to me..), > I thought I'd ask the question: Has anyone used a splice > such as http://www.wiringproducts.com/contents/en-us/d266.html > in their wiring? > > Thanks, > > -Jack > Austin, TX > Avid Catalina (getting there..) > > _- > ==================================================== > ====== > _- > ==================================================== > ====== > _- > ==================================================== > ====== > _- > ==================================================== > ====== > > ________________________________________________________________________________
Date: Jul 08, 2010
> Absolutely not! > > These were developed=2C I believe=2C as a "quick'n'dirty"=2C temporary co nnection > in the automotive industry for such applications as a one time trailer > hook-up for say a rental trailer. > Bob McC Jack=2C I was going to respond to your question regarding the splices you asked a bout=2C but then I read Bob McC's email. He said essentially the same thin g I was going top say. These splices are what the (U-Haul=2C Ryder=2C etc) trailer hook-up guys grab=2C to keep from doing a proper splicing job. Th ey're quick=2C they corrode=2C and they're virtually useless on anything of long term dependability. I've used them=2C but NEVER on an airplane. Basically=2C they're junk. My opinion.... Mike Welch _________________________________________________________________ Hotmail is redefining busy with tools for the New Busy. Get more from your inbox. http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:O N:WL:en-US:WM_HMP:042010_2 ________________________________________________________________________________
Date: Jul 08, 2010
>Keep in mind that the design goal for bringing >two wires together is "gas tightness". I.e. >give the joining the same environmental resistance >to effects of moisture and oxygen as if they were one >piece of metal. Detailed discussions of these goals >and some of the recipes for achieving them are >discussed at: That whole concept of gas tightness is what led me down the path of those connectors: I figured leaving the wire intact in the first place was better than cutting, then rejoining the wire. I'd looked at the mechanical support from the better connectors, and didn't see any disadvantage there, but had not considered the galvanic reaction from dissimilar metals. That might be a problem in an amphibian. The entire plan was to follow the whole theory of the kill switch in the first place- if it fails, the engine keeps running. I'll go down a modified solder-lap approach. I'm *much* more comfortable with solder joints than crimp joints, and will support them with a double heat-shrink cover. (Lead exposure? What might a few years of soldering circuit boards by hand add in the way of exposure? I figure that's why I'm always on a diet..) Thanks again, Jack ________________________________________________________________________________
Date: Jul 08, 2010
Jack : They use those splices at the U-haul trailer place. They will screw up your trailer wiring in about one year they are junk. I would never put anything like that in my plane. I would trim the insulator back real careful and solder the wire you want to connect then use some of that plastic stuff coat in and cover it with shrink wrap. STeve Not a wiring expert Steven W. Harmon 2446 E. 3800 N. Filer Idaho 83328 "Lovin Life in Idaho" Where Being poor on a farm beats being rich in the city ----- Original Message ----- From: "Jack L Bell" <jack(at)comconn.com> Sent: Thursday, July 08, 2010 3:08 PM Subject: AeroElectric-List: Quick splice connectors? > > > > I've begun wiring, and have always hated cutting a good wire > to splice into it. I've found no reference to the quick > splices in any of the aircraft parts catalogs, so before > giving up, and cutting the ignition CDI wires to connect > the kill switches (That alone feels all sorts of wrong to me..), > I thought I'd ask the question: Has anyone used a splice > such as http://www.wiringproducts.com/contents/en-us/d266.html > in their wiring? > > Thanks, > > -Jack > Austin, TX > Avid Catalina (getting there..) > > > ________________________________________________________________________________
Date: Jul 09, 2010
>I'll go down a modified solder-lap approach. I'm *much* >more comfortable with solder joints than crimp joints, >and will support them with a double heat-shrink cover. >(Lead exposure? What might a few years of soldering circuit >boards by hand add in the way of exposure? I figure that's >why I'm always on a diet..) The "exposure" is nil. There are some folks who believe that the mere proximity of a toxin opens a channel of ethereal osmosis that drives up risk. It's healthy for them not to study potential toxicity of every substance in our daily lives . . . the American Psychological Association would have to name a new phobia . . . or perhaps they already have. I've been soldering various items together for over 50 years. I have a lifetime stock of 63/37 solder in many forms and intend to use it until the lead finally kills me . . . or my heart does. My money is not on the lead. Bob . . . ________________________________________________________________________________
Date: Jul 09, 2010
Subject: Re: Long and short hot feeders
Reviewing the Z-14 diagram, there is no fuse protection from the panel switch turning on or off the main battery contactor. In my airplane with a battery in back, this means a 7 foot always hot lead. Should I be concerned? ________________________________________________________________________________
Date: Jul 09, 2010
N38CW wrote: > > Yep, it's a bit pricey... > > http://www.motorauthority.com/blog/1039902_porsches-1700-starter-battery-option-for-boxster-spyder-911-gt3 Perhaps something like this: http://elitepowersolutions.com/products/product_info.php?cPath=16&products_id=74 It might not have enough urge, though. --Rick ________________________________________________________________________________
Subject: Circuit protection
Date: Jul 09, 2010
I have my electrical plan in the final draft and will post it here soon. But first I have a few questions. I will have breakers for a few items, the ignition, fuel pump, landing brake, nose lift, alternator field and pitch trim. 1. I am using a Plane Power alternator with the integrated over-volt protection. I see no need for a breaker in this case, why not use a fuse? 2. The nose lift (EZ type A/C) requires unswitched power to the lift and a 10A CB in the panel. This will be a long run and needs protection back at the Bat Bus also. I plan to use a fusible link for this. I also need unswitched power for the ignition (1 mag, 1 EI) and clock power. I thought I would pull the unswitched lead forward with a fusible link at the bat bus, then branch out to the nose lift, EI, and clock power. Something tells me there is a problem with this. I can't put my finger on it other than I can hear Bob saying a bat bus is at the battery. The EI probably needs a dedicated circuit. But if the feeder was protected/sized to 15 amps, and knowing the lift only draws heavy loads when the A/C is on the ground I thought it should be ok. Thoughts? 3. The rest of the breakers on the panel will be fed from the E bus and some from the Main bus, both of which are some 30"' away. At what point (length) do I need to protect those feeder circuits using fuses or fusible links? Thanks in advance, Tim Andres ________________________________________________________________________________
Subject: Z-19 RB ground?
Date: Jul 09, 2010
I am building an all wood electrically dependent aircraft and the plan is to use, essentially, the Z-19 RB wiring scheme. What are the thoughts on the ground wire? It will be a "Fat wire" going from tail section to the firewall. It is a single wire, and single point of failure! Should I install this single ground wire making sure it is done with the utmost care, and say these cables never fail and forget about it, except for regular inspections to insure its integrity, or should I add a parallel ground, somehow, to keep my electrically dependent engine purring?? Thoughts, suggestions, please?? Roger ________________________________________________________________________________
Date: Jul 09, 2010
At 10:13 AM 7/9/2010, you wrote: >Reviewing the Z-14 diagram, there is no fuse protection from the >panel switch turning on or off the main battery contactor. In my >airplane with a battery in back, this means a 7 foot always hot >lead. Should I be concerned? What's the failure mode? If that wire gets shorted to ground, what happens? If that wire gets shorted to the battery, what happens? Are their any failure modes you can deduce that would cause a hazardous level of current to flow in that wire? Bob . . . ________________________________________________________________________________
Date: Jul 09, 2010
At 10:13 AM 7/9/2010, you wrote: Reviewing the Z-14 diagram, there is no fuse protection from the panel switch turning on or off the main battery contactor. In my airplane with a battery in back, this means a 7 foot always hot lead. Should I be concerned? What's the failure mode? If that wire gets shorted to ground, what happens? If that wire gets shorted to the battery, what happens? Are their any failure modes you can deduce that would cause a hazardous level of current to flow in that wire? Bob . . . This may be a low probability, but what if the coil in the contactor were to short? Roger ________________________________________________________________________________
Date: Jul 09, 2010
Subject: Re: Circuit protection
At 11:10 AM 7/9/2010, you wrote: >I have my electrical plan in the final draft and will post it here >soon. But first I have a few questions. I will have breakers for a >few items, the ignition, fuel pump, landing brake, nose lift, >alternator field and pitch trim. > > * I am using a Plane Power alternator with the integrated > over-volt protection. I see no need for a breaker in this case, why > not use a fuse? Because it's a crowbar ov protection system that MIGHT nuisance trip for conditions as yet undiscovered. > * The nose lift (EZ type A/C) requires unswitched power to the > lift and a 10A CB in the panel. This will be a long run and needs > protection back at the Bat Bus also. I plan to use a fusible link for this. Please don't use fusible links for any other application than those illustrated in the Z-figures. Your gear motor circuit would be happier with a breaker. Where is the battery located in the airplane? > * I also need unswitched power for the ignition (1 mag, 1 EI) > and clock power. I thought I would pull the unswitched lead forward > with a fusible link at the bat bus, then branch out to the nose > lift, EI, and clock power. Something tells me there is a problem > with this. I can't put my finger on it other than I can hear Bob > saying a bat bus is at the battery. The EI probably needs a > dedicated circuit. But if the feeder was protected/sized to 15 > amps, and knowing the lift only draws heavy loads when the A/C is > on the ground I thought it should be ok. Thoughts? How about a fuse for each battery bus feed system in a fuse holder mounted right at the battery contactor? > * The rest of the breakers on the panel will be fed from the E > bus and some from the Main bus, both of which are some 30"' away. > At what point (length) do I need to protect those feeder circuits > using fuses or fusible links? Not sure what the 30" refers to. The E-bus and main busses are separated by 30"? Bob . . . ________________________________________________________________________________
Date: Jul 09, 2010
> > > This may be a low probability, but what if the coil in the > contactor were to short? The wire in the contactor opens up. It's small gage wire total enclosed in a metal container. Bob . . . ________________________________________________________________________________
Date: Jul 09, 2010
Subject: Re: Z-19 RB ground?
At 01:01 PM 7/9/2010, you wrote: > > >I am building an all wood electrically dependent aircraft and the >plan is to use, essentially, the Z-19 RB wiring scheme. What are >the thoughts on the ground wire? It will be a "Fat wire" going from >tail section to the firewall. It is a single wire, and single point >of failure! Should I install this single ground wire making sure it >is done with the utmost care, and say these cables never fail and >forget about it, except for regular inspections to insure its >integrity, or should I add a parallel ground, somehow, to keep my >electrically dependent engine purring?? Fat wires are generally considered as robust as prop bolts and wing struts. Of course, weak links come in choice of hardware and installation technique. However, using 5/16" or larger hardware torqued to recommended values and reasonable care in installing terminals will cover you nicely. Bob . . . ________________________________________________________________________________
Date: Jul 09, 2010
_____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Friday, July 09, 2010 5:18 PM Subject: Re: AeroElectric-List: Circuit protection At 11:10 AM 7/9/2010, you wrote: I have my electrical plan in the final draft and will post it here soon. But first I have a few questions. I will have breakers for a few items, the ignition, fuel pump, landing brake, nose lift, alternator field and pitch trim. 1. I am using a Plane Power alternator with the integrated over-volt protection. I see no need for a breaker in this case, why not use a fuse? Because it's a crowbar ov protection system that MIGHT nuisance trip for conditions as yet undiscovered. OK, that makes sense. 1. The nose lift (EZ type A/C) requires unswitched power to the lift and a 10A CB in the panel. This will be a long run and needs protection back at the Bat Bus also. I plan to use a fusible link for this. Please don't use fusible links for any other application than those illustrated in the Z-figures. Your gear motor circuit would be happier with a breaker. Where is the battery located in the airplane? On the main spar, perhaps 8' away. 1. I also need unswitched power for the ignition (1 mag, 1 EI) and clock power. I thought I would pull the unswitched lead forward with a fusible link at the bat bus, then branch out to the nose lift, EI, and clock power. Something tells me there is a problem with this. I can't put my finger on it other than I can hear Bob saying a bat bus is at the battery. The EI probably needs a dedicated circuit. But if the feeder was protected/sized to 15 amps, and knowing the lift only draws heavy loads when the A/C is on the ground I thought it should be ok. Thoughts? How about a fuse for each battery bus feed system in a fuse holder mounted right at the battery contactor? I can do that, I was trying to eliminate a couple of wires. 1. The rest of the breakers on the panel will be fed from the E bus and some from the Main bus, both of which are some 30"' away. At what point (length) do I need to protect those feeder circuits using fuses or fusible links? Not sure what the 30" refers to. The E-bus and main busses are separated by 30"? The CB's on the panel are 30" away from the Main & Ebus, where they feed from. So I need to protect those feeds as they go to the CB's right? Thanks, Tim Bob . . . Checked by AVG - www.avg.com 11:36:00 ________________________________________________________________________________
Date: Jul 09, 2010
> > >The CB's on the panel are 30" away from the Main & Ebus, where they >feed from. So I need to protect those feeds as they go to the CB's right? >Thanks, Tim The definition of a BUS is where the breakers and/or fuse holders all come together. For example, http://aeroelectric.com/Pictures/Wiring_Technique/bus_bars_1.jpg All of those straps or "bars" between the breakers IS one kind of bus or another. In other words, where ever your breakers/fuses live is where the bus lives be it the E-bus, main bus, battery bus, etc. There are no "feeders" between a bus and the protection that taps that bus. Bob . . . ________________________________________________________________________________
Date: Jul 10, 2010
DCS317, > this means a 7 foot always hot lead. Should I be concerned? > No. Every time the master switch is turned on, it shorts this wire to ground. If this wire is accidentally shorted to ground, the main contactor coil restricts the current flow. The contactor will energize and you will lose the ability to shut it off. The danger of fire or smoke is minimal. If installed with secure terminations and care to prevent mechanical damage, then there should be no problem. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=304388#304388 ________________________________________________________________________________
Date: Jul 05, 2010
At 03:16 PM 7/5/2010, you wrote: > > >Hi Bob > >I have a PS Engineering PMA 4000. >See: >Page #21: >http://www.ps-engineering.com/docs/PMA4000_IM.pdf > >Each 2 or 3 conductor cable has the shield connected to a different >pin on the 25 pinb P1 Bottom Unit Connector. > >If pin 1, 2 , 6 and 7 were to touch each other at my D-sub >connector, what trouble (if any) might that cause? None. All their shields are open at the far end, i.e. only shields and not part of the audio path. "audio LO" connections in virtually all such systems is a common signal ground. Bob . . . ________________________________________________________________________________
Subject: Deceptive Voltage?
Date: Jul 11, 2010
7/11/2010 Hello Bob Nuckolls and other Electrical Gurus, Suppose you ran your battery down by spinning your first time to be started O-540 Lycoming engine with the starter in order to preoil the engine in your nearly finished RV-10. And maybe you did some other things that ran the battery down. Then you connected your small amperage output battery charger to the battery and you attempted to start the Shower of Sparks equipped engine without success. The engine was cranked OK, but the starting vibrator just was not putting out. A check of the system voltage in appropriate points with a separate volt meter while cranking the engine showed 13 plus volts. Is it possible that the voltage being seen was in fact the voltage being put out by the battery charger as it attempted to recharge the run down battery, but the amperage being put out by the run down battery and battery charger together just was not enough current flow to run the starting vibrator as well as crank the engine? 'OC' Baker Says: "The best investment we can make is the time and effort to gather and understand knowledge." ________________________________________________________________________________
Subject: Another battery maintainer/charger question
Date: Jul 11, 2010
This subject is off topic of building/running airplanes, but it is still an interesting (to me, anyways) question/subject. One of my hobbies that gets in the way of aircraft building is my long time ham radio interests. I recently obtained a new RV/Marine deep cycle battery to provide emergency 12vdc power for my vhf/uhf station and hf station on low power. I bought a nice battery box to put the thing in (a rather heavy battery -- "105 Ahr"). Mounted a small dc-to-ac inverter on the lid along with some 12vdc outlets and also a new Schumacher SE-1-12s (1.5 amp) maintainer/charger. Everything works fairly well except for two troubling things: 1. the maintainer/charger is very loud, even in the maintainer mode -- actually louder than my other two regular 6/2 amp and 10/2 amp battery chargers. 2. the "float" voltage that is maintained is at 12.96 vdc as measured by two different digital (fluke brand) volt meters. Seems a little bit low when reading the other posts here. So... Bob and the other electron experts: is there a relatively (physically) small maintainer/charger that doesn't always sound like a loud battery charger (oxymoron???) when in the maintainer mode, and is the float voltage high enough? Thanks, -Ed- NX6ED Read this topic online here: http://forums.matronics.com/viewtopic.php?p=304520#304520 ________________________________________________________________________________
Date: Jul 11, 2010
Ed - My little Schumacher 1562 1.5-amp charger/maintainer is silent - at least, if it makes any noise, I've never noticed it, even in the wee hours with the house & shop quiet. Neal N8ZG -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of edleg Everything works fairly well except for two troubling things: 1. the maintainer/charger is very loud, even in the maintainer mode -- actually louder than my other two regular 6/2 amp and 10/2 amp battery chargers. 2. the "float" voltage that is maintained is at 12.96 vdc as measured by two different digital (fluke brand) volt meters. Seems a little bit low when reading the other posts here. So... Bob and the other electron experts: is there a relatively (physically) small maintainer/charger that doesn't always sound like a loud battery charger (oxymoron???) when in the maintainer mode, and is the float voltage high enough? Thanks, -Ed- NX6ED ________________________________________________________________________________
Date: Jul 12, 2010
Subject: Re: Deceptive Voltage?
At 05:36 PM 7/11/2010, you wrote: 7/11/2010 Hello Bob Nuckolls and other Electrical Gurus, Suppose you ran your battery down by spinning your first time to be started O-540 Lycoming engine with the starter in order to preoil the engine in your nearly finished RV-10. And maybe you did some other things that ran the battery down. Then you connected your small amperage output battery charger to the battery and you attempted to start the Shower of Sparks equipped engine without success. The engine was cranked OK, but the starting vibrator just was not putting out. A check of the system voltage in appropriate points with a separate volt meter while cranking the engine showed 13 plus volts. This number appears bogus. A battery is incapable of delivering energy at more than about 12.5 volts lightly loaded . . . a few amps. Given that most batteries offer an internal resistance on the order of .007 to .010 ohms, a 200A starter draw would be expected to drop the battery terminal voltage by perhaps 2 volts. So a terminal voltage of 10.5 or lower is expected. Is it possible that the voltage being seen was in fact the voltage being put out by the battery charger as it attempted to recharge the run down battery, but the amperage being put out by the run down battery and battery charger together just was not enough current flow to run the starting vibrator as well as crank the engine? No, if the engine cranked at some speed you would EXPECT to start it, then the battery is fine. The shower-of-sparks system is designed to do two things: (1) increased intensity of the sparking energy by offering a repeating train of battery-supported sparks and (2) DELAYING the delivery of ANY sparks until just after TDC such that potential for kickback is eliminated. If your engine cranks but doesn't start, the battery is fine and the SOS system is suspect. This article might be of value in your quest for making all things right with the world: http://www.aeroelectric.com/articles/Shower-of-Sparks/ShowerOfSparks.pdf Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Go ahead, make my day . . . > < show me where I'm wrong. > ================================ ________________________________________________________________________________
Date: Jul 12, 2010
Subject: Engine ground
When connecting a ground to the engine - I am wondering if braided bonding straps and flexible wire (aka welding wire) are equally applicable? I am also wondering how much slack is appropriate regards length. For example if I measure 15" from firewall stud to engine stud - how much e xtra length should used to allow for engine movement? John ________________________________________________________________________________
Subject: Re: Another battery maintainer/charger question
Date: Jul 12, 2010
Ed, The little maintainer should be dead silent. I suspect the step down transformer inside the unit is bad. I would try to return it to the store for an exchange or send it back to the manuf. They should be good about replacing it. The float voltage should be approx. 13.1 to 13.4 volts. There are probably internal adjustments "if" you can pop the case. However, if the transformer is faulty/vibrates at 60/120 Hz. then it needs to be swapped with a good one. David _________________________________________________________ ----- Original Message ----- From: "Neal George" <n8zg(at)att.net> Sent: Sunday, July 11, 2010 5:13 PM Subject: RE: AeroElectric-List: Another battery maintainer/charger question > > Ed - > My little Schumacher 1562 1.5-amp charger/maintainer is silent - at least, > if it makes any noise, I've never noticed it, even in the wee hours with > the > house & shop quiet. > > Neal > N8ZG > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of edleg > > Everything works fairly well except for two troubling things: > 1. the maintainer/charger is very loud, even in the maintainer mode -- > actually louder than my other two regular 6/2 amp and 10/2 amp battery > chargers. > 2. the "float" voltage that is maintained is at 12.96 vdc as measured by > two > different digital (fluke brand) volt meters. Seems a little bit low when > reading the other posts here. > > So... Bob and the other electron experts: is there a relatively > (physically) > small maintainer/charger that doesn't always sound like a loud battery > charger (oxymoron???) when in the maintainer mode, and is the float > voltage > high enough? > > Thanks, > > -Ed- > NX6ED > > > ________________________________________________________________________________
Subject: OSH '10 Options
Date: Jul 12, 2010
I am again offering B&B style beds in the classic brick Oshkosh house that I rent each year for EAA members. The house comes with central air for those hot or humid nights, newly remodeled kitchen, big screen HDTV (with video input for your daily shots), fresh towels, cold beer and toiletry service. I will transport campers each day To/From Airventure 2010. Available from Saturday, July 24th through Sunday, August for $250 per occupant = nine nights and days. Send me an email with your phone number and I will promptly call back to secure your First class accomodations. It is way beyond camping on the field in a tent or staying in a Dorm at the UW-OSH. John Cox johnwcox at pacificnw.com ________________________________________________________________________________
Date: Jul 12, 2010
Subject: Re: Engine ground
At 10:31 AM 7/12/2010, you wrote: >When connecting a ground to the engine I am >wondering if braided bonding straps and flexible >wire (aka welding wire) are equally applicable? yes > >I am also wondering how much slack is appropriate regards length. enough slack that there is no tension and/or sharp bends adjacent to end terminals. > >For example if I measure 15 from firewall stud >to engine stud how much extra length should >used to allow for engine movement? It isn't the enginge that moves a lot, it's the nice floppy wire that moves. Add a couple or three inches and don't ask wire to change directions sharply next to the ends. Bob . . . ________________________________________________________________________________
Date: Jul 12, 2010
Subject: Microair 760 bench test fixture
I've placed a Microair 760 bench test fixture up on Ebay as item number 150466479723 This can be used to operate your radio on the bench out of the airplane . . . or in the airplane independently of ship's wiring. Handy diagnostic/ test tool for this radio. If you have an xcom 760 radio, this test fixture can be easily adapted to operate that radio by re-arranging some wires in the connector. Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Go ahead, make my day . . . > < show me where I'm wrong. > ================================ ________________________________________________________________________________
Subject: Re: ANL current limiter location on rear battery installations
From: "tomcostanza" <Tom(at)CostanzaAndAssociates.com>
Date: Jul 13, 2010
Bob, With respect to: > Small aircraft do not get circuit protection in > the battery feeders to the starter and distribution > busses. Why does the battery feeder to the distribution buss not get protected? Thanks, -Tom -------- Clear Skies, Tom Costanza Read this topic online here: http://forums.matronics.com/viewtopic.php?p=304645#304645 ________________________________________________________________________________
Date: Jul 13, 2010
7/13/2010 Hello Again Bob Nuckolls, Thank you for the prompt response copied below, but my specific electrical theory question about the battery charger output voltage possibly masking the battery's output voltage capability was not answered. In response to the statement: "...... a separate volt meter while cranking the engine showed 13 plus volts." You wrote: "This number appears bogus. A battery is incapable of delivering energy at more than about 12.5 volts.........." But what about the battery charger that is connected to the system, turned on, and providing a higher than normal battery output voltage in its attempt to recharge the battery while the engine was being cranked and the volt meter readings were taken? My electrical theory question is: "Could that battery charger output voltage be affecting the reading obtained by the separate volt meter and indicate that the battery is more capable than it really is in putting out amperage?" Thank you. 'OC' Baker Says: "The best investment we can make is the time and effort to gather and understand knowledge." PS: Thank you also for writing and passing on the link to the article about Shower of Sparks. http://www.aeroelectric.com/articles/Shower-of-Sparks/ShowerOfSparks.pdf I will pass that along to the RV-10 builder and his helpers. ========================================================== From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Subject: Re: AeroElectric-List: Deceptive Voltage? At 05:36 PM 7/11/2010, you wrote: 7/11/2010 Hello Bob Nuckolls and other Electrical Gurus, Suppose you ran your battery down by spinning your first time to be started O-540 Lycoming engine with the starter in order to preoil the engine in your nearly finished RV-10. And maybe you did some other things that ran the battery down. Then you connected your small amperage output battery charger to the battery and you attempted to start the Shower of Sparks equipped engine without success. The engine was cranked OK, but the starting vibrator just was not putting out. A check of the system voltage in appropriate points with a separate volt meter while cranking the engine showed 13 plus volts. This number appears bogus. A battery is incapable of delivering energy at more than about 12.5 volts lightly loaded . . . a few amps. Given that most batteries offer an internal resistance on the order of .007 to .010 ohms, a 200A starter draw would be expected to drop the battery terminal voltage by perhaps 2 volts. So a terminal voltage of 10.5 or lower is expected. Is it possible that the voltage being seen was in fact the voltage being put out by the battery charger as it attempted to recharge the run down battery, but the amperage being put out by the run down battery and battery charger together just was not enough current flow to run the starting vibrator as well as crank the engine? No, if the engine cranked at some speed you would EXPECT to start it, then the battery is fine. The shower-of-sparks system is designed to do two things: (1) increased intensity of the sparking energy by offering a repeating train of battery-supported sparks and (2) DELAYING the delivery of ANY sparks until just after TDC such that potential for kickback is eliminated. If your engine cranks but doesn't start, the battery is fine and the SOS system is suspect. This article might be of value in your quest for making all things right with the world: http://www.aeroelectric.com/articles/Shower-of-Sparks/ShowerOfSparks.pdf Bob . . . ________________________________________________________________________________
Date: Jul 13, 2010
OC The thing is the battery voltage during cranking is the highest possible voltage in the system during cranking. The charger voltage must be pulled down to the same value unless you are measuring near the charger and there is is high resistance between where you are measuring the voltage and the battery. That would mean you have a second wiring issue. So Bob really did answer the question. The 13 volt reading is bogus/wrong/not related to you shower of sparks problem and is meaningless/impossible unless you have the above mentioned second issue or a large (100 amp ?) charger. Hope that helps a bit. The answer to your electrical theory question is "No" BTW I do enjoy your posts. Ken bakerocb(at)cox.net wrote: > > 7/13/2010 > > Hello Again Bob Nuckolls, Thank you for the prompt response copied > below, but my specific electrical theory question about the battery > charger output voltage possibly masking the battery's output voltage > capability was not answered. > > In response to the statement: "...... a separate volt meter while > cranking the engine showed 13 plus volts." > > You wrote: "This number appears bogus. A battery is incapable of > delivering energy at more than about 12.5 volts.........." > > But what about the battery charger that is connected to the system, > turned on, and providing a higher than normal battery output voltage in > its attempt to recharge the battery while the engine was being cranked > and the volt meter readings were taken? > > My electrical theory question is: "Could that battery charger output > voltage be affecting the reading obtained by the separate volt meter and > indicate that the battery is more capable than it really is in putting > out amperage?" Thank you. > > 'OC' Baker Says: "The best investment we can make is the time and effort > to gather and understand knowledge." > > PS: Thank you also for writing and passing on the link to the article > about Shower of Sparks. > > http://www.aeroelectric.com/articles/Shower-of-Sparks/ShowerOfSparks.pdf > > I will pass that along to the RV-10 builder and his helpers. > > ========================================================== > > From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> > Subject: Re: AeroElectric-List: Deceptive Voltage? > > > > At 05:36 PM 7/11/2010, you wrote: > > 7/11/2010 > > Hello Bob Nuckolls and other Electrical Gurus, > > Suppose you ran your battery down by spinning your first time to be > started O-540 Lycoming engine with the starter in order to preoil the > engine in your nearly finished RV-10. And maybe you did some other > things that ran the battery down. > > Then you connected your small amperage output battery charger to the > battery and you attempted to start the Shower of Sparks equipped > engine without success. The engine was cranked OK, but the starting > vibrator just was not putting out. > > A check of the system voltage in appropriate points with a separate > volt meter while cranking the engine showed 13 plus volts. > > This number appears bogus. A battery is incapable > of delivering energy at more than about 12.5 volts > lightly loaded . . . a few amps. Given that most > batteries offer an internal resistance on the order > of .007 to .010 ohms, a 200A starter draw would be > expected to drop the battery terminal voltage by > perhaps 2 volts. So a terminal voltage of 10.5 or > lower is expected. > > > Is it possible that the voltage being seen was in fact the voltage > being put out by the battery charger as it attempted to recharge the > run down battery, but the amperage being put out by the run down > battery and battery charger together just was not enough current flow > to run the starting vibrator as well as crank the engine? > > No, if the engine cranked at some speed you would > EXPECT to start it, then the battery is fine. The > shower-of-sparks system is designed to do two things: > (1) increased intensity of the sparking energy by > offering a repeating train of battery-supported > sparks and (2) DELAYING the delivery of ANY sparks > until just after TDC such that potential for kickback > is eliminated. > > If your engine cranks but doesn't start, the battery > is fine and the SOS system is suspect. This article might > be of value in your quest for making all things right > with the world: > > http://www.aeroelectric.com/articles/Shower-of-Sparks/ShowerOfSparks.pdf > > > Bob . . . > ________________________________________________________________________________
From: "nuckollsr" <bob.nuckolls(at)aeroelectric.com>
Date: Jul 13, 2010
> But what about the battery charger that is connected to the system, turned on, and providing a higher than normal battery output voltage in its attempt to recharge the battery while the engine was being cranked and the volt meter readings were taken? > > My electrical theory question is: "Could that battery charger output voltage be affecting the reading obtained by the separate volt meter and indicate that the battery is more capable than it really is in putting out amperage?" My apologies, I did miss that one. A battery charger is simply another energy source. It has characteristics common to all energy sources in terms of potential power, open circuit voltage, ability to deliver current (internal impedance), noise, etc. A charge may be considered equivalent to a noisy battery (because its got artifacts of internal electronics noise and/or rectified ac mains) with a high internal impedance. The charger can produce no more output current than its designers provided. Unless the charger is specifically designed for cranking engines . . . see: http://tinyurl.com/385snfg then the effects of an operating charger on system voltage while cranking is insignificant. It's not unlike paralleling a 60A alternator with an SD-8 alternator. As long as you don't draw more than 8-10A, and SD-8 with a HIGHER regulation setpoint might happily assume all the load and boost the voltage high enough to cause the larger alternator to simply relax. But as soon as the demand (in this case a cranking motor) exceeds the load carrying capabilities of the source with the higher setpoint (in this case a charger), the voltage sags to the point where the battery is willing and able to shoulder some load . . . in this case, about 12.5 volts or lower. So the short answer is, unless were talking about a boss-hogg charger that is capable of supporting engine cranking loads at 13.0 volts (I don't think such a critter exists), then the cited reading raises some questions as to measurement technique, quality of the instrument, etc. I would not dispute what the individuals observed but I will suggest that the reported readings raise more questions than they answer and beg some explanation that will come from data we do not yet have. I will suggest that the voltmeter be tested against another instrument believed to be good. They should agree to within a 0.2 volts or so at 13v. Then connect the voltmeter right at the battery terminals to watch the battery's ability to pick up the cranking loads. Do the test with the charger connected, then repeat with the charger disconnected. I suspect that voltage readings while cranking under the two conditions will be under 12.5 volts and not significantly different from each other. Bob . . . Read this topic online here: http://forums.matronics.com/viewtopic.php?p=304665#304665 ________________________________________________________________________________
Date: Jul 13, 2010
installations At 05:53 AM 7/13/2010, you wrote: > > >Bob, > >With respect to: > > > > Small aircraft do not get circuit protection in > > the battery feeders to the starter and distribution > > busses. > > >Why does the battery feeder to the distribution buss not get protected? Because fat wires in dc electrical systems are exceedingly hard to burn, hence there is no value added in attempting to protect them. The legacy design goals for DC systems in most vehicles don't call for adding circuit protection to wires until they become so small compared to the potential energy sources (1000+ amps from a hard faulted battery) that wiring protection is called for. A fat wire in an airplane that's allowed to hat-dance up to a chunk of airframe will probably burn a hole in the airframe without opening the upstream circuit protection. I've seen a 8AWG wire protected with 40A breaker burn an elevator cable in two without so much as generating bad smells, blinking the lights or popping a breaker. Hence design goals and installation that suggest extra attention to the insulation and support of fat wires combined with a crew-controlled shut-off right at the battery i.e. battery contactor. Bob . . . ________________________________________________________________________________
Subject: LV warn light snafu?
Date: Jul 13, 2010
I powered up my electrical system for the first time a couple days ago. No smoke. Yeah! I have a Jabiru 3300 with their provided voltage regulator of some Japanese make, I believe. The master switch is a sequential on (off, bat, bat + alt) wired as shown in the attached schematic. I used Bobs Z-16 and Z-21 as the basis for my system. >From what I can tell, all but the LV warning light seems to work as I expected. I wired the green voltage regulator wire to a panel mounted LED like shown in the Jab manual on page 23 and 24. At first, I left the two alternator output leads disconnected. When I turned on the master to the middle 'bat' position, the LV warn LED came on nice and bright. I figured this was normal, since the alternator is disconnected both by the master switch and also by the two alt output leads being disconnected. But when I flipped the master fully up to bat + alt, the light went out. I thought it would have stayed on, since the alternator output leads are still disconnected. So I connected the alternator output leads with jumpers, one to the COM terminal on the alternator disconnect relay and the other to the LTBLU wire of the voltage regulator. This time, when I turned the master to the first 'bat' position, there was nothing. No light. Likewise in the 'bat + alt' position. Nada. And with the master switch in the bat only position, disconnecting either of the alternator output leads caused the red LED LV warn light to come on again. But as before, it went out when the master switch is flipped to add the alternator. I also noticed that when the LED LV warn light was on and then the master switched off, it took several seconds for the light to fade and eventually go out. But when the light went by switching the master from 'bat' to 'bat + alt', the light went out immediately. I know the regulator is connected to a filter capacitor, so I assume the battery charges up the capacitor when the master is on 'bat' and the charge bleeds out through the LED LV warn light when the battery is disconnected. You can download a PDF file I've attached or look at the smaller file inline below. Most of the stuff is native Adobe, so there's much higher resolution available. And it's in color! Otherwise, there's no difference. -------- Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=304692#304692 Attachments: http://forums.matronics.com//files/dans_electrical_schematic_643.jpg http://forums.matronics.com//files/dans_electrical_schematic_112.pdf ________________________________________________________________________________
Subject: 200G wiring with OVR
Date: Jul 13, 2010
Bob, We are installing a B&C 200G PM alternator along with B&C's regulator and OVR. I was planing on copying the layout for the SD-8 in Z-10/8.( just that part since this is the only alternator for our simple Continental O-200 installation). The 200G alternator is rated for about 12 amps. Can I stay with the 15 amp in-line fuse or should I increase it to 20 amps? I am connecting the in-line fuse at the starter contactor since my battery is behind the seat and the battery contactor is behind the seat. Why the differences between Z-13/ 8 and Z-10/8 for the SD-8 wiring? 1) Z-13 has 20AWG fuse link instead of the 15amp in-line fuse at the battery contactor 2) Z-13 has diodes on the S704-1 relay 3) Z13 has resistor across the capacitor 4) Z13 has bridge rectifier (?)and resistor to a LCL off of the alternator. What is that for? What does LCL stand for? Should I incorporate these in my installation? 5) Not sure how to tie-in a Low-Voltage indicator light in with either option. Suggestions 6) I am installing a battery buss( fuse block) next to my main buss (fuse block) under the panel The feed for the battery buss is a 10 awg wire from the battery behind the seat to the panel. I was not planing on protecting that wire with a in-line fuse. Should I? It will be routed with the + & - fat wires . I would rather keep the two busses together. Other option would be to put the battery buss behind the seat and than I would have to run more wires toward the panel for , clock, aux power, cabin lights etc. but they are all fused . Thanks for your help. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=304710#304710 ________________________________________________________________________________
Subject: Re: LV warn light snafu?
Date: Jul 13, 2010
Well, I think I found the problem. There will be an inline fuse between the COM lead of the alternator disconnect relay and the RDAC for a tach signal. I have the end into the COM lead just fine, but the other end was touching the firewall, effectively grounding it. Once I took care of that, the LV light came on exactly how I expected it to, both in 'bat only' as well as in the 'bat + alt' positions. In troubleshooting this, I started checking out numbers with my Fluke 83 VOM. The wires and switches showed resistances of 0.2 to 0.4. The resistance across the alt relay coil was 91 ohms. Voltage drops across the 3 reversing diodes were all a little over 0.5V. There was no continuity across the crowbar OVM. I should have connected the alternator output leads again before declaring a success. I'll do that when I get out in the shop again. And finally, assuming I've got the LV warn light problem fixed, is there anything I can do to test the electrical system? -------- Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=304731#304731 ________________________________________________________________________________
Date: Jul 14, 2010
Thanks for that Bob. As often is the case, at least with me, the answer to one question leads to more questions. > Because fat wires in dc electrical systems are > exceedingly hard to burn, hence there is no > value added in attempting to protect them. When you say "protect them", I'm not sure what you mean. Not knowing any better, I might want to protect things near the high current path, or the battery itself, from melting. Your thoughts? > Hence design goals and installation that suggest extra > attention to the insulation and support of fat wires combined > with a crew-controlled shut-off right at the battery > i.e. battery contactor. Got it. But again, another question, this time about the wire supplying the main battery buss, for example in Z-11. This is neither fused, nor does it go through the contactor. So it isn't shut-off-able. What's the worst case if this shorts to ground. Will the wire just burn through as if it were a fuseable link? What if someone used a heavier wire, anticipating a more robust e-bus? Please pardon my ignorance, and thanks so much for your patience. -------- Clear Skies, Tom Costanza Read this topic online here: http://forums.matronics.com/viewtopic.php?p=304740#304740 ________________________________________________________________________________
Date: Jul 14, 2010
installations Bob; this question is similar to what I was asking a few days ago but I'm n ot =0Asure we were on the same page, probably my fault. For example the Z8 I'm using =0Adoes not show any protection device between the main bus and t he contactor,-in =0Amy case that is a 7'~8' run from the rear mounted bat tery to the Instrument =0Apanel where the main bus-is located.- The E b us is protected-from both ends with =0Afuses in your drawing and I unders tand why but do not understand why there is no =0Aprotection on the-feede r to the main bus/fuse block=0AThanks, Tim Andres=0A=0A=0A=0A=0A___________ _____________________=0AFrom: tomcostanza <Tom(at)CostanzaAndAssociates.com> =0ATo: aeroelectric-list(at)matronics.com=0ASent: Wed, July 14, 2010 3:50:05 A M=0ASubject: AeroElectric-List: Re: ANL current limiter location on rear ba stanza" =0A=0A=0AThanks for that Bob.- As often is the case, at least with me, the answer to one =0Aquestion leads to more questions.=0A=0A=0A> Because fat wires in dc electrical systems are =0A> exceedingly hard to burn, hence there is no =0A> value added in attemp ting to protect them.=0A=0A=0AWhen you say "protect them", I'm not sure wha t you mean.- Not knowing any =0Abetter, I might want to protect things ne ar the high current path, or the =0Abattery itself, from melting.- Your t houghts?=0A=0A=0A> Hence design goals and installation that suggest extra =0A> attention to the insulation and support of fat wires combined =0A> wit h a crew-controlled shut-off right at the battery =0A> i.e. battery contact or. =0A=0A=0AGot it.- But again, another question, this time about the wi re supplying the =0Amain battery buss, for example in Z-11.- This is neit her fused, nor does it go =0Athrough the contactor.- So it isn't shut-off -able.- What's the worst case if =0Athis shorts to ground.- Will the wi re just burn through as if it were a fuseable =0Alink?- What if someone u sed a heavier wire, anticipating a more robust e-bus?=0A=0APlease pardon my ignorance, and thanks so much for your patience.=0A=0A--------=0AClear Ski es,=0ATom Costanza=0A=0A=0A=0A=0ARead this topic online here:=0A=0Ahttp://f orums.matronics.com/viewtopic.php?p=304740#304740=0A=0A=0A=0A=0A=0A=0A=0A ================ ________________________________________________________________________________
Date: Jul 14, 2010
installations At 05:50 AM 7/14/2010, you wrote: Thanks for that Bob. As often is the case, at least with me, the answer to one question leads to more questions. BN: Because fat wires in dc electrical systems are exceedingly hard to burn, hence there is no value added in attempting to protect them. When you say "protect them", I'm not sure what you mean. Not knowing any better, I might want to protect things near the high current path, or the battery itself, from melting. Your thoughts? The idea of adding "protection" to any wire goes toward risk reduction. Risk of expense for making easily avoided repairs, risk of experiencing a hazardous condition. When a wire is strung through the innards of a type certificated airplane, there's a standard waltz tune played called "Failure Mode Effects Analysis" or FMEA for short. This exercise considers all the potentials for increased risk and the return on investment for adding "protection" or risk reduction. The fat wires in the engine cranking path and major bus feeders were deduced to first be capable of very high reliability. Further, when installed with good materials and practice, they were very low risks to the airframe even if insulation integrity was lost. Finally, history has demonstrated that when insulation integrity of fat wires is lost, it's likely that the fault condition will be relatively "soft" . . . i.e. it will arc a lot over time releasing a lot of total energy . . . but at current levels too low to open the traditional protective devices. Hence the part 23 rule: ------------ Sec. 23.1357 Circuit protective devices. (a) Protective devices, such as fuses or circuit breakers, must be installed in all electrical circuits other than-- (1) Main circuits of starter motors used during starting only; and (2) Circuits in which no hazard is presented by their omission. ------------ It was just such a fault that is believed to have brought down Swissair Flt 111 by setting some combustible insulation on fire after some not-designed-for-prime-time- insulation cracked and precipitated a "soft" arcing event. Rather than rewire thousands of airplanes with parsecs of better wire, the Dispensers of Great Wisdom decided that a new form of breaker was called for. Hence all our friends at Klixon, Eaton, et. als. rushed off to the lab to build little microprocessor based digital signal detectors into the breakers and train them to "listen" for soft faults. Now, if you'd like to protect your ship's battery wire for such events, I'm sure that somebody makes the breaker for the job . . . but it will be big, heavy, expensive, and probably run the lifetime of your airplane never being called upon to trip. > Hence design goals and installation that suggest extra > attention to the insulation and support of fat wires combined > with a crew-controlled shut-off right at the battery > i.e. battery contactor. Got it. But again, another question, this time about the wire supplying the main battery buss, for example in Z-11. This is neither fused, nor does it go through the contactor. So it isn't shut-off-able. What's the worst case if this shorts to ground. Will the wire just burn through as if it were a fuseable link? What if someone used a heavier wire, anticipating a more robust e-bus? Check the definition of an E-Bus. Just how "robust" do you anticipate? See http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z32K.pdf for recommendations concerning e-bus feeders FUSED at greater than say 10A. In other words, if your e-bus alternate feed path gets too big, then a crew-controlled, mini-contactor is called for. The battery bus is another critter. Since battery busses are located AT the battery, their feeders are short. See that (*) on the battery bus feeder wires? So yes, if that wire sees a fault hard enough to smoke it, the rule 23.1357(a)(2) suggests no hazard is presented if the wire is short because smoke-risk is low and the event will be short lived due to small gage of wire. At the same time, we want that path to be very robust (low parts count and well installed) so that reliability is high. Please pardon my ignorance, and thanks so much for your patience. TA: Bob; this question is similar to what I was asking a few days ago but I'm not sure we were on the same page, probably my fault. For example the Z8 I'm using does not show any protection device between the main bus and the contactor, in my case that is a 7'~8' run from the rear mounted battery to the Instrument panel where the main bus is located. The E bus is protected from both ends with fuses in your drawing and I understand why but do not understand why there is no protection on the feeder to the main bus/fuse block BN: Because that should be a "fat" wire well installed. This same pathway falls under the FAR23 category cited above. Legacy design goals have supported the notion for many decades and hundreds of thousands of airplanes. You won't find this pathway fuse or breaker protected in any type certificated SE aircraft on a par with your grandpa's C-170. The e-bus alternate feed wire is longer, smaller gage and capable of being fault-powered from either end. Further, we don't want a fault on the alternate feed path wire to open both the alternate and normal feed paths. Hence NO protection in the normal path and SHORT wires there too. Bob . . . ________________________________________________________________________________
Date: Jul 14, 2010
>I should have connected the alternator output leads again before >declaring a success. I'll do that when I get out in the shop again. Sounds like you've done a righteous job of chasing the bugs out . . . >And finally, assuming I've got the LV warn light problem fixed, is >there anything I can do to test the electrical system? Sounds like the next step is an engine-run with the alternator delivering power. Bob . . . ________________________________________________________________________________
Date: Jul 14, 2010
Subject: ANL Alternator Fuse Substitution
Bob Is it advisable to substitute a MaxiFuse for the ANL Alternator Fuse? The MaxiFuse can be wired in-line with the alternator wire such that it's clamped along with the alternator 8AWG wire as it routes along the engine mount- versus mounting the ANL fuse holder on the firewall which is not as desirable. Is it possible to size the MaxiFuse to provide the same level of nuisance tripping immunity, and 8AWG alternator wire protection, as the ANL fuse would? I'm using the 40A B&C alternator. Sam Ray ________________________________________________________________________________
Date: Jul 14, 2010
Subject: Re: ANL Alternator Fuse Substitution
At 06:29 PM 7/14/2010, you wrote: Bob Is it advisable to substitute a MaxiFuse for the ANL Alternator Fuse? The MaxiFuse can be wired in-line with the alternator wire such that it's clamped along with the alternator 8AWG wire as it routes along the engine mount- versus mounting the ANL fuse holder on the firewall which is not as desirable. Is it possible to size the MaxiFuse to provide the same level of nuisance tripping immunity, and 8AWG alternator wire protection, as the ANL fuse would? I'm using the 40A B&C alternator. Absolutely. Of course, the ANL current limiters are exceedingly robust. One NEVER nuisance trips a current limiter. However, the lowly fuse like the MAXI series can be sized to stay in place on a 40A alternator. You'd want to de-rate about 25% based on the absolute max that a cold alternator can produce. Let's call it 50A. So the MAX70 would do be optimal. But if that's hard to find, a 60A or and 80A would be okay too Bob . . . ________________________________________________________________________________
Date: Jul 15, 2010
From: "Lapsley R. and Sandra E. Caldwell" <lrsecaldwell(at)earthlink.net>
Subject: RV12 Wire lists
I am disappointed that Van's refuses to provide wire lists for RV12 harnesses and the RV12 Control panel connectors. It will make it very difficult to do maintenance. Has anybody developed wire lists for the RV12. Roger ________________________________________________________________________________
Date: Jul 15, 2010
Thanks, Bob :-) It was a big relief for sure to figure that out. It'll be at least a few months before engine startup. My goal is to get it in the air next year. I do have another electrical question that I'll post on a different thread, though. -------- Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=304884#304884 ________________________________________________________________________________
Subject: Facet Boost Pump Fuses
Date: Jul 15, 2010
Hi! I'm wondering what size fuse to use for my Facet 40104 boost pump. I talked to somebody in their engineering department and he said 3 is recommended. I told him I'd heard of a couple people blowing 3A fuses in a 40105. They replaced it with a 5A and had no further problems. For some reason Facet is stingy with documentation. They list 20 or more pumps and give only their psi and gph ranges individually, then lump them all together and say they draw an average of 1.6A. The 04 I have is the smallest, with the 05 only slightly bigger. http://www.facet-purolator.com/index.php?option=com_content&task=category§ionid=7&id=16&Itemid=31 I asked if putting a 5A in would work. The Facet dude said it probably would work, but it'd increase the chance of wrecking the coil, but wouldn't get hot enough to start a fire. I have 15-20' round trip of 20awg wire going to it, so I know a 5A fuse would protect the wire. I plan on using this as a boost pump for my mechanical, turning it on before startup, check the pressure, then some seconds later crank the engine. It would then be turned off at altitude and back on for landing. The boost pump is near the bottom of the cowl, ~1' below the mechanical pump. They are in series with no recirculation, so it would be pumping with no flow until cranking. The fuses I'm thinking of are the fast ATO/ATC style. I could go with slower 3AG fuses, if there is a any advantage in doing this. I assume that if the Facet is pumping against a closed valve a couple feet downstream it would in a few seconds reach its max current draw. I haven't heard of anyone wrecking their boost pump, just a few that blew 3A fuses. I'm waiting for Facet to return my emailed questions. I also could bench test this pump with my VOM and see what the current draw really is. Suggestions? -------- Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=304897#304897 ________________________________________________________________________________
From: "Gordon Smith" <gordonrsmith921(at)yahoo.com>
Subject: Z Figure Inconsistencies
Date: Jul 15, 2010
I think the following questions relate to the current string with the subject: "ANL current limiter location on rear battery Installations." I think that item number 1. below relates to Bob's answer in the above string where he comments: "The e-bus alternate feed wire is longer, smaller gage and capable of being fault-powered from either end." And item number 2. below relates to an inconsistency with Bob's answer in the above string where he comments: "Further, we don't want a fault on the alternate feed path wire to open both the alternate and normal feed paths. Hence NO protection in the normal path and SHORT wires there too." RESEND - Originally sent on 21 June & 24 June when Bob N. was tied up with his monster garage sale. I find some inconsistencies regarding E-Bus feeds and I can't understand the physics that might drive the decision for these differences. Or are they just items that need to be updated in the future? 1. The wire from the E-Bus Alternate Feed Switch (or relay) to the E-Bus: In most cases this wire connects to the E-Bus directly at the bolt, with no protection between the E-Bus bolt and the other end. In two cases it is different. In Z10-8 it connects at the E-Bus through a fuse on the E-Bus. In Z13-8 it connects to the E-Bus bolt through a Fuselink at the bolt. It seems to me that this wire will likely be more than 6 inches (especially when coming from a panel mounted switch). It seems to me that this wire should be protected at the E-Bus when the E-Bus is hot from the Main Bus Feed and the E-Bus Alternate Feed is open. However, I don't know which is the favored method (Fuse or Fuselink). 2. The wire from the Main Bus to the E-Bus main feed Diode: In all cases except one this wire comes directly from the Main Bus Bolt to the Diode, with no protection (in most cases it is marked to be less than 6 inches). In the Z19 figures, this wire comes from the Main Bus through a fuse on the Main Bus and then to the main feed Diode. Is this because it is assumed that this wire will likely be longer than 6 inches? If the E-Bus and Main Bus could be close to each other and the Diode could this wire be as in the other Z figures? Gordon Smith ________________________________________________________________________________
Subject: Panel Accessible breaker for Mission Critical Item
Date: Jul 15, 2010
Goal: to determine if there is added value in being able to reset a breaker for a mission critical item. Assumptions: I have plenty of fuse busses in my airplane (don't sell me on the fuse vs. breaker crap) and only a couple of breakers. I'm not worried about one more $20 breaker. Problem: My aircraft, Lancair Legacy is not designed to land without flaps; not even just for fun. If you do you put yourself in a situation of a high speed landing with no visibility over the nose. Flaps fix that problem in that they provide the option of being able to modify the wing cord such that you can see a bit of the runway during landing. So, all is well when the flap motor has electrons. No, there is no Piper J bar on a Legacy. Electric only and no emergency dump option. The only option is to find a long runway and fly it in. My question: Am I at negative odds using a fuse which I might have to fish for if my flaps go out during flight or do I replace that option with a breaker on the panel? Thanks, Glenn ________________________________________________________________________________
Subject: ANL Fuse holder
Date: Jul 15, 2010
While ANL current limiters are currently at the top of this list, thought I'd relate my experience with the holders of these devices. If you are considering the inexpensive, clear acrylic torpedo-shape holders, DON'T. The design uses a screw to pinch the fat wire in the supplied metal wire end/ANL end. Once the ANL device is in place and your wire ends are clamped down (I elected to solder mine), you screw the two plastic end pieces to the body and end up with an enclosed, transparent housing. Sounds good, looks good, but the wire terminal anti-rotation device failed on both ends on two units and the ANL fuse broke. These units are OK for the auto stereo systems they're designed for, but totally inadequate for holding on to a wire that's being thrashed about by an engine on a dynafocal mount. I ended up using scrap 1/8" fiberglass lamination and two AN screws/nuts to make an easy simple, small, light, strong and cheap homegrown replacement. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=304907#304907 ________________________________________________________________________________
Date: Jul 15, 2010
Subject: Re: Panel Accessible breaker for Mission Critical
Item What is your plan to deal with failure of the flap motor? Why wouldn't the same plan be appropriate to deal with an open flap motor CB? -- Kevin Horton Ottawa, Canada On Thu, Jul 15, 2010 at 11:14, wrote: > > Goal: to determine if there is added value in being able to reset a > breaker for a mission critical item. > > Assumptions: I have plenty of fuse busses in my airplane (don't sell me > on the fuse vs. breaker crap) and only a couple of breakers. I'm not > worried about one more $20 breaker. > > Problem: My aircraft, Lancair Legacy is not designed to land without > flaps; not even just for fun. If you do you put yourself in a situation > of a high speed landing with no visibility over the nose. Flaps fix that > problem in that they provide the option of being able to modify the wing > cord such that you can see a bit of the runway during landing. So, all > is well when the flap motor has electrons. > > No, there is no Piper J bar on a Legacy. Electric only and no emergency > dump option. The only option is to find a long runway and fly it in. > > My question: Am I at negative odds using a fuse which I might have to > fish for if my flaps go out during flight or do I replace that option > with a breaker on the panel? > > Thanks, > > Glenn > > ________________________________________________________________________________
Item
Date: Jul 15, 2010
The plan is as I defined below. Find a long runway. If I have a CB I get at least one chance to reset. Is it worth one chance? Glenn E. Long -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Kevin Horton Sent: Thursday, July 15, 2010 12:23 PM Subject: Re: AeroElectric-List: Panel Accessible breaker for Mission Critical Item What is your plan to deal with failure of the flap motor? Why wouldn't the same plan be appropriate to deal with an open flap motor CB? -- Kevin Horton Ottawa, Canada On Thu, Jul 15, 2010 at 11:14, wrote: > > Goal: to determine if there is added value in being able to reset a > breaker for a mission critical item. > > Assumptions: I have plenty of fuse busses in my airplane (don't sell me > on the fuse vs. breaker crap) and only a couple of breakers. I'm not > worried about one more $20 breaker. > > Problem: My aircraft, Lancair Legacy is not designed to land without > flaps; not even just for fun. If you do you put yourself in a situation > of a high speed landing with no visibility over the nose. Flaps fix that > problem in that they provide the option of being able to modify the wing > cord such that you can see a bit of the runway during landing. So, all > is well when the flap motor has electrons. > > No, there is no Piper J bar on a Legacy. Electric only and no emergency > dump option. The only option is to find a long runway and fly it in. > > My question: Am I at negative odds using a fuse which I might have to > fish for if my flaps go out during flight or do I replace that option > with a breaker on the panel? > > Thanks, > > Glenn > > ________________________________________________________________________________
Item
Date: Jul 15, 2010
And further to that =2C how or why would either a fuse or breaker open such that resetting would get the flaps working. If the fuse or breaker opens t hen likely the flap motor or its wiring has failed causing the protective d evice to operate and therefore resetting isn't going to restore flap functi onality anyway. Protective devices normally only operate for just cause=2C and if you don't repair the root cause resetting the device accomplishes no thing other than an additional trip. Bob McC > From: khorton01(at)rogers.com > Date: Thu=2C 15 Jul 2010 12:23:06 -0400 > Subject: Re: AeroElectric-List: Panel Accessible breaker for Mission Crit ical Item > To: aeroelectric-list(at)matronics.com > om> > > What is your plan to deal with failure of the flap motor? Why > wouldn't the same plan be appropriate to deal with an open flap motor > CB? > > -- > Kevin Horton > Ottawa=2C Canada > > > > On Thu=2C Jul 15=2C 2010 at 11:14=2C wrote: > > > > Goal: to determine if there is added value in being able to reset a > > breaker for a mission critical item. > > > > Assumptions: I have plenty of fuse busses in my airplane (don't sell me > > on the fuse vs. breaker crap) and only a couple of breakers. I'm not > > worried about one more $20 breaker. > > > > Problem: My aircraft=2C Lancair Legacy is not designed to land without > > flaps=3B not even just for fun. If you do you put yourself in a situati on > > of a high speed landing with no visibility over the nose. Flaps fix tha t > > problem in that they provide the option of being able to modify the win g > > cord such that you can see a bit of the runway during landing. So=2C al l > > is well when the flap motor has electrons. > > > > No=2C there is no Piper J bar on a Legacy. Electric only and no emergen cy > > dump option. The only option is to find a long runway and fly it in. > > > > My question: Am I at negative odds using a fuse which I might have to > > fish for if my flaps go out during flight or do I replace that option > > with a breaker on the panel? > > > > Thanks=2C > > > > Glenn > > > > > > > > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Jul 15, 2010
Subject:
http://compulider.com.br/about.php ________________________________________________________________________________
Item
Date: Jul 15, 2010
Thanks, Ok, so we're all in agreement that either resetting a breaker or replacing a fuse on flaps in flight is completely futile? And were quite sure no one in history has recovered from a popped breaker on a flap motor? That makes my decision easy. Glenn E. Long -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of robert.mccallum2(at)sympatico.ca Sent: Thursday, July 15, 2010 1:11 PM Subject: RE: AeroElectric-List: Panel Accessible breaker for Mission Critical Item And further to that , how or why would either a fuse or breaker open such that resetting would get the flaps working. If the fuse or breaker opens then likely the flap motor or its wiring has failed causing the protective device to operate and therefore resetting isn't going to restore flap functionality anyway. Protective devices normally only operate for just cause, and if you don't repair the root cause resetting the device accomplishes nothing other than an additional trip. Bob McC > From: khorton01(at)rogers.com > Date: Thu, 15 Jul 2010 12:23:06 -0400 > Subject: Re: AeroElectric-List: Panel Accessible breaker for Mission > Critical Item > To: aeroelectric-list(at)matronics.com > > --> > > What is your plan to deal with failure of the flap motor? Why wouldn't > the same plan be appropriate to deal with an open flap motor CB? > > -- > Kevin Horton > Ottawa, Canada > > > > On Thu, Jul 15, 2010 at 11:14, wrote: > > > > Goal: to determine if there is added value in being able to reset a > > breaker for a mission critical item. > > > > Assumptions: I have plenty of fuse busses in my airplane (don't sell > > me on the fuse vs. breaker crap) and only a couple of breakers. I'm > > not worried about one more $20 breaker. > > > > Problem: My aircraft, Lancair Legacy is not designed to land without > > flaps; not even just for fun. If you do you put yourself in a > > situation of a high speed landing with no visibility over the nose. > > Flaps fix that problem in that they provide the option of being able > > to modify the wing cord such that you can see a bit of the runway > > during landing. So, all is well when the flap motor has electrons. > > > > No, there is no Piper J bar on a Legacy. Electric only and no > > emergency dump option. The only option is to find a long runway and fly it in. > > > > My question: Am I at negative odds using a fuse which I might have > > to fish for if my flaps go out during flight or do I replace that > > option with a breaker on the panel? > > > > Thanks, > > > > Glenn > > > > > > > > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Item
Date: Jul 15, 2010
To muddy the waters, I have reset the landing gear breaker on a twin comanche, which tripped because the wrong lube in the system had gotten cold and stiff, thus working the motor a bit too hard. You are the only one who can make the decision. On Jul 15, 2010, at 14:23, wrote: > > Thanks, > > Ok, so we're all in agreement that either resetting a breaker or > replacing a fuse on flaps in flight is completely futile? And were quite > sure no one in history has recovered from a popped breaker on a flap > motor? > > That makes my decision easy. > > Glenn E. Long > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of > robert.mccallum2(at)sympatico.ca > Sent: Thursday, July 15, 2010 1:11 PM > To: aeroelectric-list(at)matronics.com > Subject: RE: AeroElectric-List: Panel Accessible breaker for Mission > Critical Item > > > And further to that , how or why would either a fuse or breaker open > such that resetting would get the flaps working. If the fuse or breaker > opens then likely the flap motor or its wiring has failed causing the > protective device to operate and therefore resetting isn't going to > restore flap functionality anyway. Protective devices normally only > operate for just cause, and if you don't repair the root cause resetting > the device accomplishes nothing other than an additional trip. > > > > Bob McC > >> From: khorton01(at)rogers.com >> Date: Thu, 15 Jul 2010 12:23:06 -0400 >> Subject: Re: AeroElectric-List: Panel Accessible breaker for Mission >> Critical Item >> To: aeroelectric-list(at)matronics.com >> >> --> >> >> What is your plan to deal with failure of the flap motor? Why wouldn't > >> the same plan be appropriate to deal with an open flap motor CB? >> >> -- >> Kevin Horton >> Ottawa, Canada >> >> >> >> On Thu, Jul 15, 2010 at 11:14, wrote: >>> >>> Goal: to determine if there is added value in being able to reset a >>> breaker for a mission critical item. >>> >>> Assumptions: I have plenty of fuse busses in my airplane (don't sell > >>> me on the fuse vs. breaker crap) and only a couple of breakers. I'm >>> not worried about one more $20 breaker. >>> >>> Problem: My aircraft, Lancair Legacy is not designed to land without > >>> flaps; not even just for fun. If you do you put yourself in a >>> situation of a high speed landing with no visibility over the nose. >>> Flaps fix that problem in that they provide the option of being able > >>> to modify the wing cord such that you can see a bit of the runway >>> during landing. So, all is well when the flap motor has electrons. >>> >>> No, there is no Piper J bar on a Legacy. Electric only and no >>> emergency dump option. The only option is to find a long runway and > fly it in. >>> >>> My question: Am I at negative odds using a fuse which I might have >>> to fish for if my flaps go out during flight or do I replace that >>> option with a breaker on the panel? >>> >>> Thanks, >>> >>> Glenn >>> >>> >>> >>> >>> >>> >> >> > =========== > =========== > =========== > =========== >> >> >> > > > > > > ________________________________________________________________________________
Date: Jul 15, 2010
Item FWIW Could attempting to deploy flaps at too high a speed result in an overload resulting in a blown CB? Could attempting to deploy flaps with an ice buildup result in an overload resulting in a blown CB? Could there be any other conditions (bird's nest, or ????) that might be cleared during flight or by multiple attempts to deploy flaps? I'm in favor of a resettable CB. Raymond Julian Kettle River, MN. On 07/15/2010 01:23 PM, longg(at)pjm.com wrote: > --> AeroElectric-List message posted by: > > Thanks, > > Ok, so we're all in agreement that either resetting a breaker or > replacing a fuse on flaps in flight is completely futile? And were quite > sure no one in history has recovered from a popped breaker on a flap > motor? > > That makes my decision easy. > > Glenn E. Long > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of > robert.mccallum2(at)sympatico.ca > Sent: Thursday, July 15, 2010 1:11 PM > To: aeroelectric-list(at)matronics.com > Subject: RE: AeroElectric-List: Panel Accessible breaker for Mission > Critical Item > > > And further to that , how or why would either a fuse or breaker open > such that resetting would get the flaps working. If the fuse or breaker > opens then likely the flap motor or its wiring has failed causing the > protective device to operate and therefore resetting isn't going to > restore flap functionality anyway. Protective devices normally only > operate for just cause, and if you don't repair the root cause resetting > the device accomplishes nothing other than an additional trip. > > > Bob McC > >> From: khorton01(at)rogers.com >> Date: Thu, 15 Jul 2010 12:23:06 -0400 >> Subject: Re: AeroElectric-List: Panel Accessible breaker for Mission >> Critical Item >> To: aeroelectric-list(at)matronics.com >> >> --> AeroElectric-List message posted by: Kevin Horton >> --> >> >> What is your plan to deal with failure of the flap motor? Why wouldn't > >> the same plan be appropriate to deal with an open flap motor CB? >> >> -- >> Kevin Horton >> Ottawa, Canada >> >> >> >> On Thu, Jul 15, 2010 at 11:14, wrote: >>> --> AeroElectric-List message posted by: >>> >>> Goal: to determine if there is added value in being able to reset a >>> breaker for a mission critical item. >>> >>> Assumptions: I have plenty of fuse busses in my airplane (don't sell > >>> me on the fuse vs. breaker crap) and only a couple of breakers. I'm >>> not worried about one more $20 breaker. >>> >>> Problem: My aircraft, Lancair Legacy is not designed to land without > >>> flaps; not even just for fun. If you do you put yourself in a >>> situation of a high speed landing with no visibility over the nose. >>> Flaps fix that problem in that they provide the option of being able > >>> to modify the wing cord such that you can see a bit of the runway >>> during landing. So, all is well when the flap motor has electrons. >>> >>> No, there is no Piper J bar on a Legacy. Electric only and no >>> emergency dump option. The only option is to find a long runway and > fly it in. >>> >>> My question: Am I at negative odds using a fuse which I might have >>> to fish for if my flaps go out during flight or do I replace that >>> option with a breaker on the panel? >>> >>> Thanks, >>> >>> Glenn >>> >>> >>> >>> >>> >>> >> >> > =========== > =========== > =========== > =========== >> >> >> > > > ________________________________________________________________________________
Item
Date: Jul 15, 2010
Thanks All, Yes, I tend to agree - there must be some value (and a lot of memorable stories) in being able to reset flaps at least once. Sure, if a problem exists, or I see smoke - forget it, but for all the reasons mentioned it's worth $20. Glenn E. Long -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of ray Sent: Thursday, July 15, 2010 3:11 PM Subject: Re: AeroElectric-List: Panel Accessible breaker for Mission Critical Item FWIW Could attempting to deploy flaps at too high a speed result in an overload resulting in a blown CB? Could attempting to deploy flaps with an ice buildup result in an overload resulting in a blown CB? Could there be any other conditions (bird's nest, or ????) that might be cleared during flight or by multiple attempts to deploy flaps? I'm in favor of a resettable CB. Raymond Julian Kettle River, MN. On 07/15/2010 01:23 PM, longg(at)pjm.com wrote: > --> AeroElectric-List message posted by: > > Thanks, > > Ok, so we're all in agreement that either resetting a breaker or > replacing a fuse on flaps in flight is completely futile? And were quite > sure no one in history has recovered from a popped breaker on a flap > motor? > > That makes my decision easy. > > Glenn E. Long > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of > robert.mccallum2(at)sympatico.ca > Sent: Thursday, July 15, 2010 1:11 PM > To: aeroelectric-list(at)matronics.com > Subject: RE: AeroElectric-List: Panel Accessible breaker for Mission > Critical Item > > > And further to that , how or why would either a fuse or breaker open > such that resetting would get the flaps working. If the fuse or breaker > opens then likely the flap motor or its wiring has failed causing the > protective device to operate and therefore resetting isn't going to > restore flap functionality anyway. Protective devices normally only > operate for just cause, and if you don't repair the root cause resetting > the device accomplishes nothing other than an additional trip. > > > Bob McC > >> From: khorton01(at)rogers.com >> Date: Thu, 15 Jul 2010 12:23:06 -0400 >> Subject: Re: AeroElectric-List: Panel Accessible breaker for Mission >> Critical Item >> To: aeroelectric-list(at)matronics.com >> >> --> AeroElectric-List message posted by: Kevin Horton >> --> >> >> What is your plan to deal with failure of the flap motor? Why wouldn't > >> the same plan be appropriate to deal with an open flap motor CB? >> >> -- >> Kevin Horton >> Ottawa, Canada >> >> >> >> On Thu, Jul 15, 2010 at 11:14, wrote: >>> --> AeroElectric-List message posted by: >>> >>> Goal: to determine if there is added value in being able to reset a >>> breaker for a mission critical item. >>> >>> Assumptions: I have plenty of fuse busses in my airplane (don't sell > >>> me on the fuse vs. breaker crap) and only a couple of breakers. I'm >>> not worried about one more $20 breaker. >>> >>> Problem: My aircraft, Lancair Legacy is not designed to land without > >>> flaps; not even just for fun. If you do you put yourself in a >>> situation of a high speed landing with no visibility over the nose. >>> Flaps fix that problem in that they provide the option of being able > >>> to modify the wing cord such that you can see a bit of the runway >>> during landing. So, all is well when the flap motor has electrons. >>> >>> No, there is no Piper J bar on a Legacy. Electric only and no >>> emergency dump option. The only option is to find a long runway and > fly it in. >>> >>> My question: Am I at negative odds using a fuse which I might have >>> to fish for if my flaps go out during flight or do I replace that >>> option with a breaker on the panel? >>> >>> Thanks, >>> >>> Glenn >>> >>> >>> >>> >>> >>> >> >> > =========== > =========== > =========== > =========== >> >> >> > > > ________________________________________________________________________________
Date: Jul 15, 2010
From: Bill Mauledriver Watson <MauleDriver(at)nc.rr.com>
Item I have chosen to mainly use fuses on my (non-flying) RV10 with a Z-14. I do have 4 breakers in no particular order: #1 & #2 for 2 LRC3 regulators #3 for the autopilot which I consider a quick dis-connect switch #4 for the flaps I don't think a no-flap landing in '10 is a big deal but I came up with the same scenarios (high speed deployment, ice) which 'could' blow the circuit protection and justify a reset. My fuses are on two panels in the right seat leg well wall. I've been flying my Maule for over 10 years and 1300+ hours and never had a breaker pop. My thinking goes something like, "it probably won't happen in my lifetime, if it does on a CAVU day, land it and don't risk a fire, if does happen on a dark and stormy, use the backups to land it since you have like 3 layers of them" But I'm not flying it yet Bill "Polyurethaning" Watson Durham, NC ray wrote: > > FWIW > > Could attempting to deploy flaps at too high a speed result in an > overload resulting in a blown CB? > > Could attempting to deploy flaps with an ice buildup result in an > overload resulting in a blown CB? > > Could there be any other conditions (bird's nest, or ????) that might > be cleared during flight or by multiple attempts to deploy flaps? > > I'm in favor of a resettable CB. > > Raymond Julian > Kettle River, MN. > > On 07/15/2010 01:23 PM, longg(at)pjm.com wrote: >> --> AeroElectric-List message posted by: >> >> Thanks, >> >> Ok, so we're all in agreement that either resetting a breaker or >> replacing a fuse on flaps in flight is completely futile? And were quite >> sure no one in history has recovered from a popped breaker on a flap >> motor? >> >> That makes my decision easy. >> >> Glenn E. Long >> >> >> -----Original Message----- >> From: owner-aeroelectric-list-server(at)matronics.com >> [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of >> robert.mccallum2(at)sympatico.ca >> Sent: Thursday, July 15, 2010 1:11 PM >> To: aeroelectric-list(at)matronics.com >> Subject: RE: AeroElectric-List: Panel Accessible breaker for Mission >> Critical Item >> >> >> And further to that , how or why would either a fuse or breaker open >> such that resetting would get the flaps working. If the fuse or breaker >> opens then likely the flap motor or its wiring has failed causing the >> protective device to operate and therefore resetting isn't going to >> restore flap functionality anyway. Protective devices normally only >> operate for just cause, and if you don't repair the root cause resetting >> the device accomplishes nothing other than an additional trip. >> >> >> >> Bob McC >> >>> From: khorton01(at)rogers.com >>> Date: Thu, 15 Jul 2010 12:23:06 -0400 >>> Subject: Re: AeroElectric-List: Panel Accessible breaker for Mission >>> Critical Item >>> To: aeroelectric-list(at)matronics.com >>> >>> --> AeroElectric-List message posted by: Kevin Horton >>> --> >>> >>> What is your plan to deal with failure of the flap motor? Why wouldn't >> >>> the same plan be appropriate to deal with an open flap motor CB? >>> >>> -- >>> Kevin Horton >>> Ottawa, Canada >>> >>> >>> >>> On Thu, Jul 15, 2010 at 11:14, wrote: >>>> --> AeroElectric-List message posted by: >>>> >>>> Goal: to determine if there is added value in being able to reset a >>>> breaker for a mission critical item. >>>> >>>> Assumptions: I have plenty of fuse busses in my airplane (don't sell >> >>>> me on the fuse vs. breaker crap) and only a couple of breakers. I'm >>>> not worried about one more $20 breaker. >>>> >>>> Problem: My aircraft, Lancair Legacy is not designed to land without >> >>>> flaps; not even just for fun. If you do you put yourself in a >>>> situation of a high speed landing with no visibility over the nose. >>>> Flaps fix that problem in that they provide the option of being able >> >>>> to modify the wing cord such that you can see a bit of the runway >>>> during landing. So, all is well when the flap motor has electrons. >>>> >>>> No, there is no Piper J bar on a Legacy. Electric only and no >>>> emergency dump option. The only option is to find a long runway and >> fly it in. >>>> >>>> My question: Am I at negative odds using a fuse which I might have >>>> to fish for if my flaps go out during flight or do I replace that >>>> option with a breaker on the panel? >>>> >>>> Thanks, >>>> >>>> Glenn >>>> >>>> >>>> >>>> >>>> >>>> >>> >>> >> =========== >> =========== >> =========== >> =========== >>> >>> >>> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Jul 15, 2010
Item
Hi All, The one thing to consider is the fact that there is no harm done in landing with the flaps retracted. Therefore I see very little value in having the ability to reset the breaker or change the fuse if the flaps don't extend. Now of course we can look at the scenario where the flaps are extended already and the breaker or fuse blew during a full extension or when trying to retract. This would most likely be in a case during a go around in which case all hands are busy to fly the airplane anyway and the PIC should not distract himself with other things . Franz RV7A-450h On 15/07/10 12:30 PM, "longg(at)pjm.com" wrote: > > Thanks All, > > Yes, I tend to agree - there must be some value (and a lot of memorable > stories) in being able to reset flaps at least once. Sure, if a problem > exists, or I see smoke - forget it, but for all the reasons mentioned > it's worth $20. > > Glenn E. Long > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of ray > Sent: Thursday, July 15, 2010 3:11 PM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Panel Accessible breaker for Mission > Critical Item > > > FWIW > > Could attempting to deploy flaps at too high a speed result in an > overload resulting in a blown CB? > > Could attempting to deploy flaps with an ice buildup result in an > overload resulting in a blown CB? > > Could there be any other conditions (bird's nest, or ????) that might be > > cleared during flight or by multiple attempts to deploy flaps? > > I'm in favor of a resettable CB. > > Raymond Julian > Kettle River, MN. > > On 07/15/2010 01:23 PM, longg(at)pjm.com wrote: >> --> AeroElectric-List message posted by: >> >> Thanks, >> >> Ok, so we're all in agreement that either resetting a breaker or >> replacing a fuse on flaps in flight is completely futile? And were > quite >> sure no one in history has recovered from a popped breaker on a flap >> motor? >> >> That makes my decision easy. >> >> Glenn E. Long >> >> >> -----Original Message----- >> From: owner-aeroelectric-list-server(at)matronics.com >> [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of >> robert.mccallum2(at)sympatico.ca >> Sent: Thursday, July 15, 2010 1:11 PM >> To: aeroelectric-list(at)matronics.com >> Subject: RE: AeroElectric-List: Panel Accessible breaker for Mission >> Critical Item >> >> >> And further to that , how or why would either a fuse or breaker open >> such that resetting would get the flaps working. If the fuse or > breaker >> opens then likely the flap motor or its wiring has failed causing the >> protective device to operate and therefore resetting isn't going to >> restore flap functionality anyway. Protective devices normally only >> operate for just cause, and if you don't repair the root cause > resetting >> the device accomplishes nothing other than an additional trip. >> >> >> >> Bob McC >> >>> From: khorton01(at)rogers.com >>> Date: Thu, 15 Jul 2010 12:23:06 -0400 >>> Subject: Re: AeroElectric-List: Panel Accessible breaker for Mission >>> Critical Item >>> To: aeroelectric-list(at)matronics.com >>> >>> --> AeroElectric-List message posted by: Kevin Horton >>> --> >>> >>> What is your plan to deal with failure of the flap motor? Why > wouldn't >> >>> the same plan be appropriate to deal with an open flap motor CB? >>> >>> -- >>> Kevin Horton >>> Ottawa, Canada >>> >>> >>> >>> On Thu, Jul 15, 2010 at 11:14, wrote: >>>> --> AeroElectric-List message posted by: >>>> >>>> Goal: to determine if there is added value in being able to reset a >>>> breaker for a mission critical item. >>>> >>>> Assumptions: I have plenty of fuse busses in my airplane (don't sell >> >>>> me on the fuse vs. breaker crap) and only a couple of breakers. I'm >>>> not worried about one more $20 breaker. >>>> >>>> Problem: My aircraft, Lancair Legacy is not designed to land without >> >>>> flaps; not even just for fun. If you do you put yourself in a >>>> situation of a high speed landing with no visibility over the nose. >>>> Flaps fix that problem in that they provide the option of being able >> >>>> to modify the wing cord such that you can see a bit of the runway >>>> during landing. So, all is well when the flap motor has electrons. >>>> >>>> No, there is no Piper J bar on a Legacy. Electric only and no >>>> emergency dump option. The only option is to find a long runway and >> fly it in. >>>> >>>> My question: Am I at negative odds using a fuse which I might have >>>> to fish for if my flaps go out during flight or do I replace that >>>> option with a breaker on the panel? >>>> >>>> Thanks, >>>> >>>> Glenn >>>> >>>> >>>> >>>> >>>> >>>> >>> >>> >> =========== >> =========== >> =========== >> =========== >>> >>> >>> >> >> >> >> >> >> >> > > > > > > > > > Franz Fux Director of Operations Last Frontier Heliskiing Ltd. Bell 2 Lodge P.O. Box 1237 Vernon, BC, V1T 6N6 CANADA Office Contact T: (250) 558-7980 F: (250) 558-7981 Lodge Contact T: (250) 275-4770 F: (250) 275-4912 http://www.bell2lodge.com --- LAST FRONTIER Heliskiing www.lastfrontierheli.com --- And for some of the best Steelhead Fishing in the world at Bell 2 Lodge www.steelhead-fishing.net ________________________________________________________________________________
Item
Date: Jul 15, 2010
I am also building a Legacy and I feel that there may be a possibility that the motor could be overloaded - more particularly with the landing gear which is hydraulic. Here the motor drives a hydraulic pack and I think that one may get an overload which could be due to a bit of dirt in the fluid or something like that. One reset may (?) allow this to be cleared and you can try again. Of course you also have the option, when needing to lower the gear, of a dump valve that allows the gear to swing free and down. It seems to me that flap loss in a Legacy can be a big deal so one reset should be allowed. The guy I am building for is an airline pilot and he wants to see breakers. After much persuasion I managed to convert him to the fuse options but threw in a bone with it; flaps and gear could have breakers. My philosophy is that if it is possible to overload the circuit, such as with a motor, then a CB is permissible. If it is a non-varying load, such as a light, no reset. Jay -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Franz Fux Sent: 15 July 2010 10:05 PM Subject: Re: AeroElectric-List: Panel Accessible breaker for Mission Critical Item Hi All, The one thing to consider is the fact that there is no harm done in landing with the flaps retracted. Therefore I see very little value in having the ability to reset the breaker or change the fuse if the flaps don't extend. Now of course we can look at the scenario where the flaps are extended already and the breaker or fuse blew during a full extension or when trying to retract. This would most likely be in a case during a go around in which case all hands are busy to fly the airplane anyway and the PIC should not distract himself with other things . Franz RV7A-450h On 15/07/10 12:30 PM, "longg(at)pjm.com" wrote: > > Thanks All, > > Yes, I tend to agree - there must be some value (and a lot of memorable > stories) in being able to reset flaps at least once. Sure, if a problem > exists, or I see smoke - forget it, but for all the reasons mentioned > it's worth $20. > > Glenn E. Long > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of ray > Sent: Thursday, July 15, 2010 3:11 PM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Panel Accessible breaker for Mission > Critical Item > > > FWIW > > Could attempting to deploy flaps at too high a speed result in an > overload resulting in a blown CB? > > Could attempting to deploy flaps with an ice buildup result in an > overload resulting in a blown CB? > > Could there be any other conditions (bird's nest, or ????) that might be > > cleared during flight or by multiple attempts to deploy flaps? > > I'm in favor of a resettable CB. > > Raymond Julian > Kettle River, MN. > > On 07/15/2010 01:23 PM, longg(at)pjm.com wrote: >> --> AeroElectric-List message posted by: >> >> Thanks, >> >> Ok, so we're all in agreement that either resetting a breaker or >> replacing a fuse on flaps in flight is completely futile? And were > quite >> sure no one in history has recovered from a popped breaker on a flap >> motor? >> >> That makes my decision easy. >> >> Glenn E. Long >> >> >> -----Original Message----- >> From: owner-aeroelectric-list-server(at)matronics.com >> [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of >> robert.mccallum2(at)sympatico.ca >> Sent: Thursday, July 15, 2010 1:11 PM >> To: aeroelectric-list(at)matronics.com >> Subject: RE: AeroElectric-List: Panel Accessible breaker for Mission >> Critical Item >> >> >> And further to that , how or why would either a fuse or breaker open >> such that resetting would get the flaps working. If the fuse or > breaker >> opens then likely the flap motor or its wiring has failed causing the >> protective device to operate and therefore resetting isn't going to >> restore flap functionality anyway. Protective devices normally only >> operate for just cause, and if you don't repair the root cause > resetting >> the device accomplishes nothing other than an additional trip. >> >> >> >> Bob McC >> >>> From: khorton01(at)rogers.com >>> Date: Thu, 15 Jul 2010 12:23:06 -0400 >>> Subject: Re: AeroElectric-List: Panel Accessible breaker for Mission >>> Critical Item >>> To: aeroelectric-list(at)matronics.com >>> >>> --> AeroElectric-List message posted by: Kevin Horton >>> --> >>> >>> What is your plan to deal with failure of the flap motor? Why > wouldn't >> >>> the same plan be appropriate to deal with an open flap motor CB? >>> >>> -- >>> Kevin Horton >>> Ottawa, Canada >>> >>> >>> >>> On Thu, Jul 15, 2010 at 11:14, wrote: >>>> --> AeroElectric-List message posted by: >>>> >>>> Goal: to determine if there is added value in being able to reset a >>>> breaker for a mission critical item. >>>> >>>> Assumptions: I have plenty of fuse busses in my airplane (don't sell >> >>>> me on the fuse vs. breaker crap) and only a couple of breakers. I'm >>>> not worried about one more $20 breaker. >>>> >>>> Problem: My aircraft, Lancair Legacy is not designed to land without >> >>>> flaps; not even just for fun. If you do you put yourself in a >>>> situation of a high speed landing with no visibility over the nose. >>>> Flaps fix that problem in that they provide the option of being able >> >>>> to modify the wing cord such that you can see a bit of the runway >>>> during landing. So, all is well when the flap motor has electrons. >>>> >>>> No, there is no Piper J bar on a Legacy. Electric only and no >>>> emergency dump option. The only option is to find a long runway and >> fly it in. >>>> >>>> My question: Am I at negative odds using a fuse which I might have >>>> to fish for if my flaps go out during flight or do I replace that >>>> option with a breaker on the panel? >>>> >>>> Thanks, >>>> >>>> Glenn >>>> >>>> >>>> >>>> >>>> >>>> >>> >>> >> =========== >> =========== >> =========== >> =========== >>> >>> >>> >> >> >> >> >> >> >> > > > > > > > > > Franz Fux Director of Operations Last Frontier Heliskiing Ltd. Bell 2 Lodge P.O. Box 1237 Vernon, BC, V1T 6N6 CANADA Office Contact T: (250) 558-7980 F: (250) 558-7981 Lodge Contact T: (250) 275-4770 F: (250) 275-4912 http://www.bell2lodge.com --- LAST FRONTIER Heliskiing www.lastfrontierheli.com --- And for some of the best Steelhead Fishing in the world at Bell 2 Lodge www.steelhead-fishing.net ________________________________________________________________________________
Date: Jul 15, 2010
Subject: Re: Facet Boost Pump Fuses
At 09:36 AM 7/15/2010, you wrote: > >Hi! > > >I asked if putting a 5A in would work. The Facet dude said it >probably would work, but it'd increase the chance of wrecking the >coil, but wouldn't get hot enough to start a fire. That is . . . shall we say . . . no . . . I'll be civil. First, supply fuse (at least in an airplane) is never intended to protect devices . . . only wiring. >I have 15-20' round trip of 20awg wire going to it, so I know a 5A >fuse would protect the wire. I plan on using this as a boost pump >for my mechanical, turning it on before startup, check the >pressure, then some seconds later crank the engine. It would then be >turned off at altitude and back on for landing. The boost pump is >near the bottom of the cowl, ~1' below the mechanical pump. They are >in series with no recirculation, so it would be pumping with no flow >until cranking. If it's 20AWG, put a 7A fuse in an don't loose any sleep over it. Having too robust a feeder protection cannot put anything inside the pump at risk. >The fuses I'm thinking of are the fast ATO/ATC style. I could go >with slower 3AG fuses, if there is a any advantage in doing this. I >assume that if the Facet is pumping against a closed valve a couple >feet downstream it would in a few seconds reach its max current >draw. I haven't heard of anyone wrecking their boost pump, just a >few that blew 3A fuses. > >I'm waiting for Facet to return my emailed questions. I also could >bench test this pump with my VOM and see what the current draw really is. We had a thread on this topic some months ago. The current draw by solenoid pumps is pulsed. I cited a number of patents that go back to the 50s or earlier. The first devices had mechanical contacts that pulsed the coil when the fuel pumping piston approached end of stroke thus pulling the piston back against a spring for another stroke. The energy consumption of these pumps WAS somewhat dependent in fuel flow. You could hear the stroke-rate go up as flow increased. Modern pumps are all solid state, no switches and simply pulse the coil so many times per minute irrespective of flow rate. If the flow is high, the piston strokes long in the bore. If the flow is low, the piston barely moves with each pulsed and tends to stay in the max compressed end of the stroke. Trying to get any sort of current measurement on on of these things by watching a meter is meaningless. It will be all over the place. A true ENERGY measurement must be made with some RMS type ammeter having a very long time constant . . . or a fast data acquisition system that will secure a sufficiently verbose data stream to do bit-wise integration of current values. I've got that on my list of things to do . . . in fact, there's a Facet pump on my bench loaned to me by a generous Lister for that purpose. I tried to get real engineering data from Facet on several occasions with no success. I'm doubtful that anyone there even understood the question. Nonetheless, the have been building a really slick, trouble-free product for a very long time. You don't have to know how it all works to serve great hamburgers, fries and a shake . . . just follow directions. It's the ISO way. Bob . . . ________________________________________________________________________________
Item
Date: Jul 15, 2010
It happens in flight Can't reset the breaker or replace the fuse you know this application has but one remedy install a mechanical AOA and learn how to use it Always be proficient in no flap landings to a point where it will not be a big deal to do it. Practice it four or five times a month to maintain the proficiency Now chew my a__ for saying this Dick -----Original Message----- From: ray <raymondj(at)frontiernet.net> Sent: Thu, Jul 15, 2010 12:10 pm Subject: Re: AeroElectric-List: Panel Accessible breaker for Mission Criti cal Item FWIW Could attempting to deploy flaps at too high a speed result in an overload resulting in a blown CB? Could attempting to deploy flaps with an ice buildup result in an overload resulting in a blown CB? Could there be any other conditions (bird's nest, or ????) that might be cleared during flight or by multiple attempts to deploy flaps? I'm in favor of a resettable CB. Raymond Julian Kettle River, MN. On 07/15/2010 01:23 PM, longg(at)pjm.com wrote: > > Thanks, > > Ok, so we're all in agreement that either resetting a breaker or > replacing a fuse on flaps in flight is completely futile? And were quite > sure no one in history has recovered from a popped breaker on a flap > motor? > > That makes my decision easy. > > Glenn E. Long > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of > robert.mccallum2(at)sympatico.ca > Sent: Thursday, July 15, 2010 1:11 PM > To: aeroelectric-list(at)matronics.com > Subject: RE: AeroElectric-List: Panel Accessible breaker for Mission > Critical Item > > > And further to that , how or why would either a fuse or breaker open > such that resetting would get the flaps working. If the fuse or breaker > opens then likely the flap motor or its wiring has failed causing the > protective device to operate and therefore resetting isn't going to > restore flap functionality anyway. Protective devices normally only > operate for just cause, and if you don't repair the root cause resetting > the device accomplishes nothing other than an additional trip. > > > > Bob McC > >> From: khorton01(at)rogers.com >> Date: Thu, 15 Jul 2010 12:23:06 -0400 >> Subject: Re: AeroElectric-List: Panel Accessible breaker for Mission >> Critical Item >> To: aeroelectric-list(at)matronics.com >> >> --> >> >> What is your plan to deal with failure of the flap motor? Why wouldn't > >> the same plan be appropriate to deal with an open flap motor CB? >> >> -- >> Kevin Horton >> Ottawa, Canada >> >> >> >> On Thu, Jul 15, 2010 at 11:14, wrote: >>> >>> Goal: to determine if there is added value in being able to reset a >>> breaker for a mission critical item. >>> >>> Assumptions: I have plenty of fuse busses in my airplane (don't sell > >>> me on the fuse vs. breaker crap) and only a couple of breakers. I'm >>> not worried about one more $20 breaker. >>> >>> Problem: My aircraft, Lancair Legacy is not designed to land without > >>> flaps; not even just for fun. If you do you put yourself in a >>> situation of a high speed landing with no visibility over the nose. >>> Flaps fix that problem in that they provide the option of being able > >>> to modify the wing cord such that you can see a bit of the runway >>> during landing. So, all is well when the flap motor has electrons. >>> >>> No, there is no Piper J bar on a Legacy. Electric only and no >>> emergency dump option. The only option is to find a long runway and > fly it in. >>> >>> My question: Am I at negative odds using a fuse which I might have >>> to fish for if my flaps go out during flight or do I replace that >>> option with a breaker on the panel? >>> >>> Thanks, >>> >>> Glenn >>> >>> >>> >>> >>> >>> >> >> > ============ > ============ > ============ > ============ >> >> >> > > > > > > > ======================== ============ ======================== ============ ======================== ============ ======================== ============ ________________________________________________________________________________
Subject: Re: Panel Accessible breaker for Mission Critical Item
Date: Jul 15, 2010
[quote="raymondj(at)frontiernet.n"Could there be any other conditions (bird's nest, or ????) that might be cleared during flight or by multiple attempts to deploy flaps? I'm in favor of a resettable CB. [/quote] Sure, some conditions could be cleared by multiple attempts to reset CBs. If the CB has popped for a good reason, multiple attempts to reset it could start an electrical fire (witness the Air Canada DC-9 accident in Cincinatii many years ago, where multiple CB reset attempts started an in-flight fire which killed many people). I'd rather do a zero flaps landing than do multiple CB resets and risk an in-flight fire. If a zero flap landing is more risky than an in-flight fire, then there is a problem somewhere. Kevin Horton -------- Kevin Horton RV-8 Ottawa, Canada http://www.kilohotel.com/rv8 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=305011#305011 ________________________________________________________________________________
Date: Jul 15, 2010
> -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On > Behalf Of Robert L. Nuckolls, III > Sent: Thursday, July 15, 2010 2:40 PM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Facet Boost Pump Fuses > > --> > > At 09:36 AM 7/15/2010, you wrote: > >--> > > > >Hi! > > > > > >I asked if putting a 5A in would work. The Facet dude said > it probably > >would work, but it'd increase the chance of wrecking the coil, but > >wouldn't get hot enough to start a fire. > > That is . . . shall we say . . . no . . . I'll be civil. > First, supply fuse (at least in an airplane) is never > intended to protect devices . . . only wiring. > > > >I have 15-20' round trip of 20awg wire going to it, so I > know a 5A fuse > >would protect the wire. I plan on using this as a boost pump for my > >mechanical, turning it on before startup, check the pressure, then > >some seconds later crank the engine. It would then be turned off at > >altitude and back on for landing. The boost pump is near the > bottom of > >the cowl, ~1' below the mechanical pump. They are in series with no > >recirculation, so it would be pumping with no flow until cranking. > > If it's 20AWG, put a 7A fuse in an don't loose > any sleep over it. Having too robust a feeder > protection cannot put anything inside the pump > at risk. > Would this reasoning not lead to running "really" robust feeders/fuses, and then a fuel pump (or other device) with and internal problem that is generating a lot of heat (fire/smoke)? I agree that we're not trying to 'save/protect' the pump, rather trying to prevent smokeing wires, but a smokeing load can be a big problem, too. -john- ________________________________________________________________________________
Date: Jul 15, 2010
Item >My philosophy is that if it is possible to overload the circuit, such as >with a motor, then a CB is permissible. It is POSSIBLE that any circuit in the airplane can become overloaded. It's also possible that any circuit in the airplane can become simply inoperable. I would presume that worrisome things like landing gear have some means for extension that are not dependent on power . . .is this not the case in your airplane? > If it is a non-varying load, such as a light, no reset ????? what's non-varying have to do with it? If its a system/device that's exceptionally useful in reducing risk for comfortable termination of flight, then it's customary to have a plan-B for dealing with the loss of that system. If it's "critical", then you better have a back up for total loss of that system irrespective off root cause. To limit the failure studies to nuisance tripping of a breaker leaves a lot of rocks un-turned. Bob . . . ________________________________________________________________________________
Subject: Ducati regulator question
Date: Jul 16, 2010
I am building an RV-12. Because I am registering as E-LSA, I must build it EXACTLY according to plans using the pre-assembled wiring harness and control board, essentially a plug and play system. The schematic may be viewed here: http://www.vansaircraft.com/pdf/revisions/RV-12/User_Manuals/MM-R1.pdf on page 173 of the 185 page of the Adobe document. My question concerns the 22awg wire that connects the main bus to the "C" terminal of the Ducati voltage regulator. First of all, there is no fuse protection for this 3-foot wire that passes through the firewall. One half of the master switch is in series with this wire. I thought the "C" terminal was for voltage sensing. It seems that it is being used as an ON-OFF control for the regulator on the RV-12. If terminal "C" really is a voltage-sense input, then it would seem that if the master switch were shut off while the engine was running, that the regulator would see a low input (0 volts) and put out a higher voltage, resulting in an over-voltage situation. Another concern is the 22,000f 25vdc capacitor on the control board which is on the cabin side of the firewall. If the regulator fails and can not be shut off, an over-voltage situation could smoke the capacitor with no way to shut the power off to it. So here are my questions: Does terminal "C" of the Ducati regulator act as an ON-OFF control? If the regulator fails and allows over-voltage, will opening input to terminal "C" shut off the regulator output? Thanks, Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=305065#305065 ________________________________________________________________________________
Subject: Vertex VXA700 information needed
Date: Jul 16, 2010
I am trying to hook up a Vertex VXA700 handheld as a second Com to my PS Engineering PSA4000 audio panel. Here is link to owners manual (1.01MB): http://www.vertexstandard.com/indexVS.cfm?cmd=DisplayProducts&ProdCatID 4&encProdID=CDA841ED5B9711A5833A60A9115F5EDE&DivisionID=2&isArchived=1 As per manual on page 65 I have a CT-96 headset cable. The problem is I want the audio panel to allow the Pilot and Co-Pilot PTT to transmit on Com 2 (Vertex) when I select Com 2. Does anyone have a schematic how to wire the CT-96 headset cable to accomplish this task? I do have as shown on page 65 the external PTT switch. This is not a simple device that goes in series with the mic jack and pulls PTT wire to ground. It has two switches that I believe could be replicated with a relay that has the coil powered and could look for ground through the PTT pin of Com 2 on the PMA 4000. I think when the external PTT switch/es are pushed, it disables the handhelds internal mic while connecting to the mic on headset. Vertex was not of much assistance. They sent over a Service manual and a diagram of CT-96, which have errors. When I asked another question that would have solved my issue, Vertex said they don't make the external PTT and couldn't help me any further. Thx. Ron Parigoris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=305075#305075 ________________________________________________________________________________
Subject: RE: Panel Accessible breaker for Mission Critical Item
Date: Jul 16, 2010
I've been flying my Lancair Legacy for over three years and 350 hours. I do not agree with your characterization of a no flap landing in a Legacy. I wouldn't fly it if I thought it was unsafe to land without flaps. You're right that you need a higher landing speed and a longer runway, but at least where I fly, there are a dozen suitable runways within my normal fuel reserve. The last time I did a no flap landing, for practice, was on a 6,000' runway at sea level and I don't think I used more than half the runway. But it is something that needs to be practiced because you're right that it's much easier with flaps than without. There are plenty of single points of failure in the flap system and the fuse or circuit breaker is only one of them. I'd recommend a comfortable Plan B if any of them caused a flap system failure. By the way, I have a 7 amp ATO/ATC fuse protecting my wing flap circuit. During construction, I installed a 5 amp fuse based on measurements of the flap motor's current draw. However, once I started flying, I found that I could sometimes blow the fuse if I instantly reversed the flap direction. For example, let's say I'm on the ground running the before takeoff checklist and lowering the flaps to 10 degrees. I overshoot a little and immediately move the flap lever to the up position to get back to 10 degrees. That immediate reversal of flap movement sometimes blew the 5 amp fuse. I replaced it with a 7 amp fuse and have not had a problem since; about three years and over 300 hours. Another poster expressed concern about circuit protection for the landing gear. That's near the bottom of my worries, because the backup gear extension system relies on gravity and proper installation and lubrication of the landing gear system. I practice the alternate landing gear extension from time to time and perhaps that's why I'm so comfortable with it. My hydraulic pump is protected by a 40 amp ANL current limiter, which I don't believe the pump could possibly blow, absent some failure that would disable the system anyway. Dennis ________________________________________________________________________________
Date: Jul 16, 2010
begin SPECULATION While it may have a "sense" function, it is probably the power source for the internal electronics. Without the source, the internal electronics won't startup, and the regulator will remain dormant. end SPECULATION This configuration, with a motorcycle regulator, was used on the early Jabiru engines and in that application powering the regulator without having the engine running would burn out the regulator and the alternator. -john- > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On > Behalf Of user9253 > Sent: Friday, July 16, 2010 8:31 AM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Ducati regulator question > > --> > > I am building an RV-12. Because I am registering as E-LSA, I > must build it EXACTLY according to plans using the > pre-assembled wiring harness and control board, essentially a > plug and play system. The schematic may be viewed here: > http://www.vansaircraft.com/pdf/revisions/RV-12/User_Manuals/M > M-R1.pdf on page 173 of the 185 page of the Adobe document. > My question concerns the 22awg wire that connects the main > bus to the "C" terminal of the Ducati voltage regulator. > First of all, there is no fuse protection for this 3-foot > wire that passes through the firewall. One half of the > master switch is in series with this wire. I thought the "C" > terminal was for voltage sensing. It seems that it is being > used as an ON-OFF control for the regulator on the RV-12. If > terminal "C" really is a voltage-sense input, then it would > seem that if the master switch were shut off while the engine > was running, that the regulator would see a low input (0 > volts) and put out a higher voltage, resulting in an > over-voltage situation. Another concern is the 22,000f > 25vdc capacitor on the control board which is on the cabin > side of the firewall. If the regulator fails and can not be > shut off, an over-voltage situation could smoke the capacitor > with no way to shut the power off to it. So here are my questions: > Does terminal "C" of the Ducati regulator act as an ON-OFF control? > If the regulator fails and allows over-voltage, will opening > input to terminal "C" shut off the regulator output? > Thanks, > Joe > > -------- > Joe Gores > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=305065#305065 > > > > > > > > Photoshare, and much much more: > > > > ________________________________________________________________________________
Date: Jul 16, 2010
Thanks, Bob :-) Nice to get some background on how the pump works. Facet told me in an email 5A would be fine, I see from Table 11-3 of AC43.13-1B a 5A fuse would work, and you say 7A is peachy. So I'm happy and will think no more about this issue. -------- Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=305105#305105 Attachments: http://forums.matronics.com//files/dc_wire_and_circuit_protector_chart_784.jpg ________________________________________________________________________________
Date: Jul 16, 2010
At 01:35 PM 7/16/2010, you wrote: > >begin SPECULATION >While it may have a "sense" function, it is probably the power source for >the internal electronics. >Without the source, the internal electronics won't startup, and the >regulator will remain dormant. >end SPECULATION Seems reasonable. Here's a schematic someone sent me of what was believed to be at least one version of a Ducati PM alternator rectifier/regulators. It's typical of many other diagrams I've seen: http://aeroelectric.com/Pictures/Regulators/regul_912.jpg The "C" lead is indeed a voltage sense lead. Further, it powers the regulation + SCR control circuits. >This configuration, with a motorcycle regulator, was used on the early >Jabiru engines and in that application powering the regulator without having >the engine running would burn out the regulator and the alternator. > While this lead exercises ON/OFF control of the R/R, it's not in a position to do serious harm if left powered while the engine is not running. It's worst risk is that over a long period of time, it might run a battery down with what amounts to perhaps tens of milliamps of steady current draw. > > I am building an RV-12. Because I am registering as E-LSA, I > > must build it EXACTLY according to plans using the > > pre-assembled wiring harness and control board, essentially a > > plug and play system. The schematic may be viewed here: > >http://tinyurl.com/2d4b9j8 > > on page 173 of the 185 page of the Adobe document. > > My question concerns the 22awg wire that connects the main > > bus to the "C" terminal of the Ducati voltage regulator. > > First of all, there is no fuse protection for this 3-foot > > wire that passes through the firewall. Yes . . . this is not in agreement with legacy esign goals for aircraft . . . > > One half of the > > master switch is in series with this wire. I thought the "C" > > terminal was for voltage sensing. It seems that it is being > > used as an ON-OFF control for the regulator on the RV-12. If > > terminal "C" really is a voltage-sense input, then it would > > seem that if the master switch were shut off while the engine > > was running, that the regulator would see a low input (0 > > volts) and put out a higher voltage, resulting in an > > over-voltage situation. You'd be correct if this were not ALSO a power supply wire for the R/R . . . > Another concern is the 22,000=C2=B5f > > 25vdc capacitor on the control board which is on the cabin > > side of the firewall. If the regulator fails and can not be > > shut off, an over-voltage situation could smoke the capacitor > > with no way to shut the power off to it. Also correct . . . > > here are my questions: > > Does terminal "C" of the Ducati regulator act as an ON-OFF control? Yes > > If the regulator fails and allows over-voltage, will opening > > input to terminal "C" shut off the regulator output? Very probably. Further, given that the output capability for the Rotax (and all PM) alternator is relatively low, the voltage is not going to climb precipitously . . . If you had an ACTIVE NOTIFICATION of high voltage, this would probably suffice to offer timely crew notification. Alternatively, you could add active OV protection like that illustrated in http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z16M.pdf I would further suggest, active notification of low voltage is a good thing too. Finally, a 3A fuse in series with the "C" lead would be in conformity with legacy design goals. Bob . . . ________________________________________________________________________________
Date: Jul 16, 2010
Subject: Facet Boost Pump Fuses
> If it's 20AWG, put a 7A fuse in an don't loose > any sleep over it. Having too robust a feeder > protection cannot put anything inside the pump > at risk. > Would this reasoning not lead to running "really" robust feeders/fuses, and then a fuel pump (or other device) with and internal problem that is generating a lot of heat (fire/smoke)? I agree that we're not trying to 'save/protect' the pump, rather trying to prevent smoking wires, but a smoking load can be a big problem, too. Most devices we use in our airplanes are considered not flight worthy if they exhibit any failure mode that becomes a hazard source for combustion . . . emitting smoke is frowned upon too. The "really robust" feeders was more rhetorical than anything else . . . after all, with a fuse block, one has the option of selecting the optimal fuse for each application . . . and easily changing it if later circumstances suggest it's a good idea. Specifically, with the FACET being a low energy device totally enclosed in a metal box. The risks are nil . . . Emacs! Although I seem to recall that G. Richter suggested that the entire airplane could be configured with an array of one-size-fits-all, self-resetting PTC polyswitches soldered to a nifty etched circuit board product he offered. But when it's so easy to achieve the elegant solution, why not do it? Bob . . . ________________________________________________________________________________
Subject: Electrical Noise Prevention
Date: Jul 16, 2010
Hi! I'm finishing up my electrical wiring and am wondering about noise. I'm not sure what types there are, nor do I know all the sources. I have heard the alternator and the transmitting radio can cause problems. Also heard that anything with a pulsing signal could also be a source. I have a 3 or 4 100-150 Mhz ferrite RF suppressors from MGL http://www.mglavionics.com/EMI_suppressor_for_VHF_frequencies.pdf. It sounds like MGL recommends putting them on any output from the radio, but not the antenna. I've heard that twisting the feeder line to the noise maker with it's ground coming back from the device (or having the wires next to each other) will help cancel out EMF generated noise. My schematic is posted in another thread: http://www.matronics.com/forums/viewtopic.php?t=72713. The two alternator leads are about 1' long and are wrapped together until one separates to go to the regulator and the other to the alt disconnect relay, which is right next to the regulator. The regulator output wire goes ~6" to a 10k micro (10 mili?) F 50V filter capacitor. I forgot to label the left and right mag wires, which are dangling out the bottom center of the pic. The engine instruments will be 6 cht's, 6 egt's, fuel pressure sender, fuel flow sensor, OT, OP, carb temp, and tach. All these will plug into the RDAC above the battery. A shielded data cable goes from there back to the EFIS. All the wires go through the firewall in either of two firewall penetations, then join together going to the right side, then back to the instrument panel and into a wire wrap along a light channel 'tray' along the bottom of the instrument panel. The pic shows the panel rotated 90 degrees in the open position. Most of the wires hanging loose are grounds. They'll be bundled together in the final installation, and if needed, close to the panel feed wires already wrapped. Besides the mag wires (which are shielded), the only wire with pusling would be the boost pump. The radio (which may be a handheld) and strobe/nav/pos lights are not in. I know strobes are notorious noise makers. I have the shielded cable installed already in the wings. How does this look to you? Thanks again for taking your time helping me :-) -------- Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=305153#305153 Attachments: http://forums.matronics.com//files/cabin_wiring_labeled_836.jpg http://forums.matronics.com//files/firewall_electrical_components_labeled_828.jpg ________________________________________________________________________________
Subject: Re: Ducati regulator question
Date: Jul 17, 2010
Bob & John, Thanks for replying. You answered my questions. Now I have a better understanding of the Ducati regulator. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=305164#305164 ________________________________________________________________________________
Date: Jul 17, 2010
Subject: Re: Electrical Noise Prevention
At 11:20 PM 7/16/2010, you wrote: > >Hi! > >I'm finishing up my electrical wiring and am wondering about noise. >I'm not sure what types there are, nor do I know all the sources. I >have heard the alternator and the transmitting radio can cause >problems. Also heard that anything with a pulsing signal could also >be a source. >How does this look to you? Thanks again for taking your time helping me :-) Suppliers of product to the TC aircraft world are encouraged if not commanded to worship at that altars of the gods of blissful system integration. Catechisms for these orders are documented in RTCA DO-160, Mil-Std-810, Mil-Std-704 just to name the most prevalent. By the time the system integrator is tasked with finding a place to bolt it in and wire it up to make it work, 99.99% of concerns for unhappy experience are already addressed. Even when the hardware has not been admitted to the social A-List for the aviation community, the risks for noise issues are relatively low. A single point ground for all the instrument panel mounted goodies and paying attention to the manufacturer's installation instructions goes a long way to crafting a noise free future. Ferrite beads are found useful only when the original designer of a potential noise antagonist/victim didn't do their homework. To assume that they would be useful before you've identified a real noise issue is probably not a good use of time . . . Fly the airplane first . . . the ferrites can probably be willed to the neighbor kid as slingshot ammo. Bob . . . >-------- >Dan > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=305153#305153 > > >Attachments: > >http://forums.matronics.com//files/cabin_wiring_labeled_836.jpg >http://forums.matronics.com//files/firewall_electrical_components_labeled_828.jpg > > >Checked by AVG - www.avg.com >07/17/10 01:35:00 Bob . . . ________________________________________________________________________________
Date: Jul 18, 2010
Thanks, Bob :-) -------- Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=305278#305278 ________________________________________________________________________________
Date: Jul 18, 2010
At 11:20 PM 7/16/2010, you wrote: > >How does this look to you? Thanks again for taking your time helping me :-) > > >http://forums.matronics.com//files/cabin_wiring_labeled_836.jpg In this picture you show a "main bus" . . . what is this? Normally, the main bus is a contiguous connection by means of unbroken bar or strip to the power feed side of an array of breakers or fuses. I.e., this component is already in existence inside a fuse block . . . or is fabricated and configured like the bus bars in this photo: http://aeroelectric.com/Pictures/Breakers/Breaker_Panel_Busing_1.jpg You also show a panel ground that appears to be on the side of the fuselage. Is this a floating tie point for the collection of all ground wires off the panel mounted accessories? In the various z-figures, I suggest a gathering of the grounds on what's called a "panel" or "avionics ground bus". This is intended to offer a single point ground for a fist full of wires and centrally located to the serviced accessories (on the panel itself). Further, it is NOT grounded to the panel structure . . . but serves as a handy way to extend lots of grounds to the fire wall ground in fewer wires. For a panel ground, you'd need something like: http://aeroelectric.com/Pictures/Grounding/Avionics_Bus_3.jpg and wired like: http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z13-8Q.pdf where I show 5 strands of 20AWG running from the panel ground to the fire wall ground. This provides redundant, low resistance connection (roughly 2 mOhms/Ft equal to 13AWG) between the two busses. The 5 strands and panel ground provides a much handier way to deal with grounds on the panel mounted accessories. Bob . . . ________________________________________________________________________________
Date: Jul 18, 2010
> In this picture you show a "main bus" . . . what is this? This is a fuse block fed by a 10awg line from the battery contactor. I had incorrectly called it a 'bus'. Now I know better. > You also show a panel ground that appears to be on > the side of the fuselage. Is this a floating tie point > for the collection of all ground wires off the panel mounted > accessories? The panel ground is made of a section of 'forest of tabs'. I took one 48 tab forest and cut it into 3 pieces. One is on the hot side of the firewall and is connected to another section on the cool side via a 5/16" SS bolt. I forget the exact numbers, but when I measured the resistance of the SS, it was only slightly higher than brass. I chose SS because of its higher melting point. A 10awg ground goes from the inside firewall ground to another section of tab forest for the panel ground. The panel ground is on the outside (lower side) of the cover to the main fuse block a few inches from the side of the fuselage. The cover will be piano hinged to the underside of the glareshield. In the pics, the glareshield is removed, so I've used a bent piece of metal to put the blocks in about the same position. Next step is to wrap all the wires together in a spiral wrap starting from where teh bundle enters the tray on the right side of the fuselage. Feeders and grounds will branch off where shown. -------- Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=305327#305327 Attachments: http://forums.matronics.com//files/ground_blocks_951.jpg ________________________________________________________________________________
Date: Jul 18, 2010
Subject: To balun or not to balun, that IS the question
> >Comments/Questions: I'm installing new VOR antenna and cable and >have a balun question. I see and have studied the balun on your >page, >http://www.matronics.com/aeroelectric/articles/BALUN/Balun_Fabrication.html. > >However the connection arrangement for the old cable arrangement is >the same as in in AC 43.13-2B, Pg 29 >http://www.faa.gov/documentLibrary/media/Advisory_Circular/AC%2043.13-2B.pdf >. It shows the center conductor NOT attached to an antenna pole. > >I plan to use a Garmin SL30 radio. Which balun connection is >best? (and hopefully why?!) I haven't been able to find anything >to support either arrangement, so maybe they're functionally equivalent??? There are a variety of ways to fabricate a balun and some are preferred depending on the impedance matching task (1:1 vs 4:1). The balun shown in 43-13 is one way to do it but I selected the device I published because it was easier to build. One has to be cautious of 43-13 data. For example, on pages 28 and 29 they make references to "airframe ground" . . . on p28, they suggest 4 connections to the airframe. From a radio frequency performance these grounds are not necessary/helpful. On a type certificated airplane one is not allowed to placard the airplane thusly: WARNING: THIS AIRCRAFT IS NOT QUALIFIED TO WITHSTAND DIRECT LIGHTNING STRIKES OF ANY MAGNITUDE. FLIGHT INTO OR IN VICINITY OF CONVECTIVE WEATHER OFFERS SUBSTANTIAL RISK OF HAZARD FROM LIGHTNING AND OTHER UGLY FORCES. ONE IS STRONGLY ADVISED TO REDUCE RISK BY MAINTAINING COMFORTABLE SPACING FROM SUCH CONDITIONS. So, the dedicated acolyte to all things FAR will feel compelled to add "airframe grounds" to things that stick out in the breeze on plastic airplanes. This is irrespective of the fact that at least couple dozen paragraphs describing "Lightning Quality Grounds" is necessary to assist the reader in crafting effective connections for such purposes. In any case, either balun is a 1:1 line impedance transformer so it's your choice. Don't worry about the "airframe ground" . . . unless you enjoy the excitement of Mother Nature's roller coaster rides. Bob . . . ________________________________________________________________________________
Date: Jul 18, 2010
Hi Bob and thanks for the help. I am trying to understand your comment re: grounds below. Why is the 5X20 AWG better than a single large wire? And why separate panel and avionics grounds? In my case I had planned either a DB 25 or forest of tabs approach on the front of the (glass) panel with all local ground needs tied in there, then a suitable ground run back to the battery. With a rear mounted battery do you then recommend the 5X20AWG run all the way to the back? For reference I am building an all electric COZY. Thanks, Tim Andres I suggest a gathering of the grounds on what's called a "panel" or "avionics ground bus". This is intended to offer a single point ground for a fist full of wires and centrally located to the serviced accessories (on the panel itself). Further, it is NOT grounded to the panel structure . . . but serves as a handy way to extend lots of grounds to the fire wall ground in fewer wires. For a panel ground, you'd need something like: http://aeroelectric.com/Pictures/Grounding/Avionics_Bus_3.jpg and wired like: http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z13-8Q.pdf where I show 5 strands of 20AWG running from the panel ground to the fire wall ground. This provides redundant, low resistance connection (roughly 2 mOhms/Ft equal to 13AWG) between the two busses. The 5 strands and panel ground provides a much handier way to deal with grounds on the panel mounted accessories. Bob . . . ________________________________________________________________________________
Subject: Avionics Dimmer
Date: Jul 18, 2010
I have discovered the PWM Dimmer I have will not work on at least some of my Garmin equipment. Instead I think I will just use the built in sensing circuits that is available for this purpose. The equipment in question is the GNS 430W, GTX 327, PSA 5000EX and Icom A210. Along with GRT HS displays. I have read elsewhere that the Garmin stuff is fine using the auto dimming, Anyone have experience with this for or against this decision? Thanks, Tim Andres ________________________________________________________________________________
Date: Jul 19, 2010
> 5 strands of 20AWG running from the panel ground > to the fire wall ground. Good question, Tim. I had missed that point. I have a single 10awg wire going from my panel ground to the firewall, not 5 smaller ones. I used 10awg for my main feeder, so chose the same size for the ground. -------- Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=305427#305427 ________________________________________________________________________________
Subject: Lightning
Date: Jul 19, 2010
....just a quick note on personal experience. In the past 50 years or so, I (my aircraft) have been struck three times ' thrice too much. The first was in Vampire fighter on descent to landing at about 20,000 feet in dense cloud. Fortunately I was head-down when the light erupted. There was an instantaneous =92bang=92 followed by a howl which dropped in audio frequency when I abruptly reduced power to slow. On the ground, a service panel had been blown off ( fuselage was molded wood construction). Time two was DC-9 enroute the south over S Carolina, in cloud at 31,000.. Bolt of lightning came almost horizontal from passing within about five miles of a thunderhead (on radar). I saw it out of corner of my eye coming in from F/O=92s window. Big bang, no hole found, but followed by cabin crew who must know what happened, thus setting off the passengers. Time three was on final at Heathrow, when unforecasted Cb struck left side at rudder pedal level. No system fault found but a neat =BD=94 buttonhole-style blown through the alu skin. L-1011s are tough. As a slow learner I determined never to pass within 15 miles of a thunderhead, except 25 miles when at the freezing level and never had another attack. FWIW. Cheers, Ferg ________________________________________________________________________________
Date: Jul 19, 2010
At 08:25 PM 7/18/2010, you wrote: > >Hi Bob and thanks for the help. >I am trying to understand your comment re: grounds below. Why is the 5X20 >AWG better than a single large wire? Single wire is single point of failure . . . although it can also be argued that 5 parallel paths offers the POTENTIAL for an undetected, latent failure. Further, at higher frequencies, multiple parallel strands are lower impedance connection than a single strand (or one thin, wide strap would be good too). The most compelling reason was to offer a high probability for installation success . . . the D-sub connector accepts 20AWG wires. Going with a single, larger conductor leaves it up to the installer to fabricate the joint between the ground wire and the avionics ground bus. The short answer is "no single reason . . . but several significant reasons". But those reasons are rooted in the features of a D-sub based ground bus. Other configurations change the selection of ingredients that go into YOUR recipe for success. >And why separate panel and avionics grounds? Sorry about the vague vernacular. For the purposes of this discussion, let's use Figure Z15, View B and move the battery from the nose back to the rear spar and ground it to the firewall ground stud. An avionics ground is on the panel sheet and intended to bring small power/signal wires to a common ground. The "panel" ground is captive to the airplane and would take care of grounding airframe accessories not generally associated with music, bells, lights and pointers. > In my case I had planned either a DB 25 or forest of tabs approach >on the front of the (glass) panel with all local ground needs tied in there, >then a suitable ground run back to the battery. With a rear mounted battery >do you then recommend the 5X20AWG run all the way to the back? The 5x20 configuration presumes a tractor airplane with a forest-of-tabs on one or both sides of firewall. >For reference I am building an all electric COZY. Okay, where are your panel equipment power distribution busses located? How about doing a sketch on where the power and ground busses are located along with a list of loads on each bus. Bob . . . ________________________________________________________________________________
Date: Jul 19, 2010
At 08:45 AM 7/19/2010, you wrote: > > > > 5 strands of 20AWG running from the panel ground > > to the fire wall ground. > > >Good question, Tim. > >I had missed that point. I have a single 10awg wire going from my >panel ground to the firewall, not 5 smaller ones. I used 10awg for >my main feeder, so chose the same size for the ground. Since you're not using a d-sub avionics ground, leave the 10AWG in place. Bob . . . ________________________________________________________________________________
Subject: Redundant Power switching
Date: Jul 19, 2010
If I bring separate bus power legs to a DPST to feed a single load, is the current shared (i.e. halved) on the two poles/switches? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=305471#305471 ________________________________________________________________________________
Subject: Panel Accessible breaker for Mission Critical
Item
Date: Jul 19, 2010
AOA's are great and I agree with the need. They should be careful calibrated and even then while helpful, don't bet the bank on them. Per my original email if you fly a Lancair there is no such thing as a proficient no flaps landing. It's simply risky. Certainly it can be done in an emergency. Take whatever precaution you need to ensure the flaps are working or as I indicated earlier, find a long runway. Glenn E. Long -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of rgent1224(at)aol.com Sent: Thursday, July 15, 2010 6:12 PM Subject: Re: AeroElectric-List: Panel Accessible breaker for Mission Critical Item It happens in flight Can't reset the breaker or replace the fuse you know this application has but one remedy install a mechanical AOA and learn how to use it Always be proficient in no flap landings to a point where it will not be a big deal to do it. Practice it four or five times a month to maintain the proficiency Now chew my a__ for saying this Dick -----Original Message----- From: ray <raymondj(at)frontiernet.net> Sent: Thu, Jul 15, 2010 12:10 pm Subject: Re: AeroElectric-List: Panel Accessible breaker for Mission Critical Item FWIW Could attempting to deploy flaps at too high a speed result in an overload resulting in a blown CB? Could attempting to deploy flaps with an ice buildup result in an overload resulting in a blown CB? Could there be any other conditions (bird's nest, or ????) that might be cleared during flight or by multiple attempts to deploy flaps? I'm in favor of a resettable CB. Raymond Julian Kettle River, MN. On 07/15/2010 01:23 PM, longg(at)pjm.com wrote: > > Thanks, > > Ok, so we're all in agreement that either resetting a breaker or > replacing a fuse on flaps in flight is completely futile? And were > quite sure no one in history has recovered from a popped breaker on a > flap motor? > > That makes my decision easy. > > Glenn E. Long > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of > robert.mccallum2(at)sympatico.ca > Sent: Thursday, July 15, 2010 1:11 PM > To: aeroelectric-list(at)matronics.com > Subject: RE: AeroElectric-List: Panel Accessible breaker for Mission > Critical Item > > > And further to that , how or why would either a fuse or breaker open > such that resetting would get the flaps working. If the fuse or > breaker opens then likely the flap motor or its wiring has failed > causing the protective device to operate and therefore resetting isn't > going to restore flap functionality anyway. Protective devices > normally only operate for just cause, and if you don't repair the root > cause resetting the device accomplishes nothing other than an additional trip. > > > > Bob McC > >> From: khorton01(at)rogers.com >> Date: Thu, 15 Jul 2010 12:23:06 -0400 >> Subject: Re: AeroElectric-List: Panel Accessible breaker for Mission >> Critical Item >> To: aeroelectric-list(at)matronics.com >> >> --> >> >> What is your plan to deal with failure of the flap motor? Why >> wouldn't > >> the same plan be appropriate to deal with an open flap motor CB? >> >> -- >> Kevin Horton >> Ottawa, Canada >> >> >> >> On Thu, Jul 15, 2010 at 11:14, wrote: >>> >>> Goal: to determine if there is added value in being able to reset a >>> breaker for a mission critical item. >>> >>> Assumptions: I have plenty of fuse busses in my airplane (don't sell > >>> me on the fuse vs. breaker crap) and only a couple of breakers. I'm >>> not worried about one more $20 breaker. >>> >>> Problem: My aircraft, Lancair Legacy is not designed to land without > >>> flaps; not even just for fun. If you do you put yourself in a >>> situation of a high speed landing with no visibility over the nose. >>> Flaps fix that problem in that they provide the option of being able > >>> to modify the wing cord such that you can see a bit of the runway >>> during landing. So, all is well when the flap motor has electrons. >>> >>> No, there is no Piper J bar on a Legacy. Electric only and no >>> emergency dump option. The only option is to find a long runway and > fly it in. >>> >>> My question: Am I at negative odds using a fuse which I might have >>> to fish for if my flaps go out during flight or do I replace that >>> option with a breaker on the panel? >>> >>> Thanks, >>> >>> Glenn >>> >>> >>> >>> >>> >>> >> >> > =========== > =========== > =========== > =========== >> >> >> > > > > > > > ==================================== ==================================== ==================================== ==================================== ________________________________________________________________________________
Date: Jul 19, 2010
Thanks Bob! That makes sense especially when using the D sub. In my case the fuse blocks will probably be under the Right seat, about a 30" run up to the avionics and various switches. I'm looking into using a swing down panel to hold the fuse blocks under the panel, but it looks complicated. There will be 5 breakers in the panel as well. The ground bus will be in front of the panel in an undetermined location but close to the avionics stack. I'm still working on the drawing and will post it soon. >For reference I am building an all electric COZY. Okay, where are your panel equipment power distribution busses located? How about doing a sketch on where the power and ground busses are located along with a list of loads on each bus. Bob . . . ________________________________________________________________________________
Date: Jul 19, 2010
From: "Richard E. Tasker" <retasker(at)optonline.net>
Subject: Re: Redundant Power switching
Shared, yes. Halved, not likely. How much of the load each pole of the switch provides depends on the resistance in each leg. Furthermore, if you are trying to get by with a switch that is not rated per pole for your total load you will be overloading it. It is very unlikely that both poles will switch simultaneously so there will be momentary full loads on one of the poles. Depending on how many times you plan to operate the switch and what the load is you may have a problem. If you are doing it with a properly rated switch to provide a redundant source of power, you have just created a single point of failure - the switch. My $0.02. Dick Tasker jonlaury wrote: > --> AeroElectric-List message posted by: "jonlaury" > > If I bring separate bus power legs to a DPST to feed a single load, is the current shared (i.e. halved) on the two poles/switches? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=305471#305471 > > > -- Please Note: No trees were destroyed in the sending of this message. We do concede, however, that a significant number of electrons may have been temporarily inconvenienced. -- ________________________________________________________________________________
Date: Jul 19, 2010
Either leg of the switch has the ampacity of the overcurrent protection device rating available, when either or the sum of both legs reach that value, the overcurrent device will trip. It is still the sum of the total load that will trip the breaker, not how you divide it downstream of the overcurrent protection. On Mon, Jul 19, 2010 at 12:54 PM, jonlaury wrote: > > If I bring separate bus power legs to a DPST to feed a single load, is the > current shared (i.e. halved) on the two poles/switches? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=305471#305471 > > ________________________________________________________________________________
Date: Jul 20, 2010
Dick and Joe, thanks for your input. Dick, I will have two switches. The plan is to use the DPST to switch legs of 6-7A and 2A. One switch is a Honeywell AML 34, rated at 125v/15a @ 60% power factor. The back-up is a Honeywell AML 31, 125v/10a @ 60% In a similar chart for another switch, Honeywell specifies "Resistive", along with % power factor so I'm assuming that the %power factor is for inductive loads. The 6-7 A load is for electronic fuel injectors which I believe are solenoids and hence, inductive loads. Joe, I didn't quite follow how the loads on the switch legs are additive. Each pole/switch is separate from the other in the switch and are fed from fuses on separate buses. J Read this topic online here: http://forums.matronics.com/viewtopic.php?p=305605#305605 ________________________________________________________________________________
Subject: Electrical System Schematic Review
Date: Jul 20, 2010
I would appreciate anyone's comments on my electrical schematic. I'm unsure about the placement of the over voltage module for the Ground Power jack. I used a single post continuous duty contactor which I had and it necessitated some changes in Bob's Z-31 drawing. Thanks John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=305607#305607 Attachments: http://forums.matronics.com//files/z13_8q_mine_155.pdf ________________________________________________________________________________
Date: Jul 20, 2010
Subject: Re: Electrical System Schematic Review
For some reason I can only see page two of the PDF - cutting off some portion to the left of the main battery bus on your schematic. Page one is blank. Dick Tasker jonlaury wrote: > --> AeroElectric-List message posted by: "jonlaury" > > I would appreciate anyone's comments on my electrical schematic. > I'm unsure about the placement of the over voltage module for the Ground Power jack. I used a single post continuous duty contactor which I had and it necessitated some changes in Bob's Z-31 drawing. > > Thanks > John > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=305607#305607 > > > Attachments: > > http://forums.matronics.com//files/z13_8q_mine_155.pdf > > > ________________________________________________________________________________
Subject: Looking for a do-hicky thingy
Date: Jul 20, 2010
I'm having trouble getting a reading from Klaus's Plasma III box (RPM pulse) to my Dynon. Either Klaus or Dynon is telling me fish stories. I'm looking for a gadget that fits as a pass through to a DB15 connector and has stubs or leads off the side so it would allow me to test values passing through DB15 the connector. This sounds reasonable but I have no idea if such things exist? Any ideas on where I might find something like this? If they do exist, what are they called? Thanks, Glenn ________________________________________________________________________________
Date: Jul 20, 2010
I know what happened. I'll put it up again. J Read this topic online here: http://forums.matronics.com/viewtopic.php?p=305615#305615 ________________________________________________________________________________
Subject: Re: Looking for a do-hicky thingy
Date: Jul 20, 2010
How about a jumper cable where you crimp two wires to each pin. Then you could take the extra wires out to a test plug. Regards Ron Raby ----- Original Message ----- From: longg(at)pjm.com To: aeroelectric-list(at)matronics.com Sent: Tuesday, July 20, 2010 2:46 PM Subject: AeroElectric-List: Looking for a do-hicky thingy I'm having trouble getting a reading from Klaus's Plasma III box (RPM pulse) to my Dynon. Either Klaus or Dynon is telling me fish stories. I'm looking for a gadget that fits as a pass through to a DB15 connector and has stubs or leads off the side so it would allow me to test values passing through DB15 the connector. This sounds reasonable but I have no idea if such things exist? Any ideas on where I might find something like this? If they do exist, what are they called? Thanks, Glenn ________________________________________________________________________________
Date: Jul 20, 2010
The fancy version, for those with more $$$ than time http://www.breakoutboxes.com/ At 11:46 7/20/2010, you wrote: >I'm looking for a gadget that fits as a pass through to a DB15 >connector and has stubs or leads off the side so it would allow me >to test values passing through DB15 the connector. > > This sounds reasonable but I have no idea if such things exist? > > Any ideas on where I might find something like this? > > If they do exist, what are they called? ________________________________________________________________________________
Subject: Corrected Electrical Schematic for Review
Date: Jul 20, 2010
The complete schematic is on page 1. Disregard page 2. There's some glitch in my TurboCad v. 11 that makes a truncated page 2 when saving files as .pdf John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=305620#305620 Attachments: http://forums.matronics.com//files/z13_8q_mine_186.pdf ________________________________________________________________________________
Date: Jul 20, 2010
On 7/20/2010 1:46 PM, longg(at)pjm.com wrote: > > Im having trouble getting a reading from Klauss Plasma III box (RPM > pulse) to my Dynon. Either Klaus or Dynon is telling me fish stories. > > Im looking for a gadget that fits as a pass through to a DB15 > connector and has stubs or leads off the side so it would allow me to > test values passing through DB15 the connector. > > This sounds reasonable but I have no idea if such things exist? > > Any ideas on where I might find something like this? > > If they do exist, what are they called? > > Thanks, > > Glenn > Google 'inline db15 breakout connector'. 1st one I hit on was: http://www.winfordeng.com/products/brk15mf.php If you do a bit more digging (try Black Box), you can probably find one that is just 3 dB connectors back to back to side, allowing insertion in-line with existing cables/chassis and giving you probe access on the 3rd connector Charlie ________________________________________________________________________________
Date: Jul 20, 2010
Thanks Ron, Yeah, that's a pain 'cause Klaus has those wires shrunk in there tighter than you know what... Today I learned something from one of our subscribers. It's called a Break Out Box. http://device-connect.com/product/hdbreakout/hdbreakout.php Glenn E. Long -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ron Raby Sent: Tuesday, July 20, 2010 3:03 PM Subject: Re: AeroElectric-List: Looking for a do-hicky thingy How about a jumper cable where you crimp two wires to each pin. Then you could take the extra wires out to a test plug. Regards Ron Raby ----- Original Message ----- From: longg(at)pjm.com To: aeroelectric-list(at)matronics.com Sent: Tuesday, July 20, 2010 2:46 PM Subject: AeroElectric-List: Looking for a do-hicky thingy I'm having trouble getting a reading from Klaus's Plasma III box (RPM pulse) to my Dynon. Either Klaus or Dynon is telling me fish stories. I'm looking for a gadget that fits as a pass through to a DB15 connector and has stubs or leads off the side so it would allow me to test values passing through DB15 the connector. This sounds reasonable but I have no idea if such things exist? Any ideas on where I might find something like this? If they do exist, what are they called? Thanks, Glenn ________________________________________________________________________________
Date: Jul 20, 2010
http://www.winfordeng.com/products/brk15mf.php http://www.bipom.com/products/us/3376564.html (which seems to be the same as above) These used to be readily available for troubleshooting RS232 cables but I cannot seem to find any but those above. As someone else mentioned, you can make your own with either solder or crimp DB15 connectors by just including a second wire connected to each DB15 interconnect wire. Dick Tasker longg(at)pjm.com wrote: > > I'm having trouble getting a reading from Klaus's Plasma III box (RPM > pulse) to my Dynon. Either Klaus or Dynon is telling me fish stories. > > I'm looking for a gadget that fits as a pass through to a DB15 > connector and has stubs or leads off the side so it would allow me to > test values passing through DB15 the connector. > > This sounds reasonable but I have no idea if such things exist? > > Any ideas on where I might find something like this? > > If they do exist, what are they called? > > Thanks, > > Glenn > > * > > > * ________________________________________________________________________________
Subject: test
Date: Jul 20, 2010
test ________________________________________________________________________________
Subject: Re: test
Date: Jul 20, 2010
OK ----- Original Message ----- From: Steve Hamer To: aeroelectric-list(at)matronics.com Sent: Tuesday, July 20, 2010 2:43 PM Subject: AeroElectric-List: test test ________________________________________________________________________________
Date: Jul 20, 2010
> Since you're not using a d-sub avionics ground, leave > the 10AWG in place. > Goodie! Another person told me they'd expect noise if the P-leads are in the same bundle to the panel. That's how I've got them. But I don't have any audio system hooked up yet. Those wires would cross the P-leads or at a right angle. -------- Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=305689#305689 ________________________________________________________________________________
Date: Jul 20, 2010
At 02:33 PM 7/20/2010, you wrote: > >Thanks Ron, > >Yeah, that's a pain 'cause Klaus has those wires shrunk in there tighter >than you know what... > >Today I learned something from one of our subscribers. It's called a >Break Out Box. Yeah, I've got a fist full of those that have proven handy in my business for over 50 years. When you're working with low current D-sub signals, here's a little trick . . . http://aeroelectric.com/Pictures/Tools/Test_Equipment/Quck_n_Dirty_Breakout.jpg A piece of ribbon cable and some munch-on connectors can be assemble in a variety of useful combinations. A M-F patch cable of appropriate length can be 'enhanced' with a female connector either between the ends . . . or on a "flying tail". Last time I built one of these was to look at some signals on a black-box buried about 3' away from anyplace I could get access to in flight. I took a 4' piece of ribbon cable and munched the M-F pair on one end about 4" apart. On the other end, I put a female connector to serve as an array of tiny "pin jacks" where ir proved easy to eavesdrop on what was happening at the other end of the cable. If I were in better shape for being unpacked and sorted out, I could send you the break-out adapter shown in the picture. If you can't get ribbon cable and connectors locally, a friend of mine in Wichita could assemble one for you from inventory (Lloyd's Electronics) and mail it to you. The whole thing goes together in about 5 minutes for about five dollars. Bob . . . ________________________________________________________________________________
Date: Jul 21, 2010
The crowbar over-voltage module needs to be in parallel with contactor coil, not in series as drawn. The way that it is now and in the event of an over-voltage condition, even if the module shorts out, the circuit breaker will not trip because the contactor coil will limit the current. Another way to look at is, if the over-voltage module is replaced with a solid piece of wire, the contactor will still function and the circuit breaker will not trip. Also, the diode needs to be in series with the contactor coil to prevent reverse polarity damage from the ground power. See Bob's drawing Z-31B. Joe http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z31K.pdf -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=305725#305725 ________________________________________________________________________________
Date: Jul 21, 2010
> If I bring separate bus power legs to a DPST to feed a single load, is the current shared (i.e. halved) on the two poles/switches? The simple answer to your question is, no, not necessarily. I agree with the other posts above. The problem is that it is not clear exactly how the circuit is wired and what is trying to be accomplished. If you can post an electrical drawing of your circuit, it will be helpful. Do not be too concerned about switch ratings as long as they are in the ballpark. If a switch handles 10 percent more current than its rating, that does not mean that it will be destroyed. Its life will be shortened but that might not matter. Supposing that the life of a switch is rated at 10,000 cycles and due to higher than rated current, it only lasts for 5,000 cycles. It will still last as long as the airplane. Now I am not saying that switch ratings should be ignored. But a switch will not blow up if slightly overloaded. I would use a switch with the proper rating if available. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=305742#305742 ________________________________________________________________________________
Date: Jul 21, 2010
Subject: 9024 Development status
The ECB layout has been checked against the schematic and we'll order proof-of-concept boards tonight. The package of choice turned out to be a 15-pin, d-sub connector shell. The board assembly solders right to the pins of the connector and the shell snaps over the assembly. Emacs! The draft software description is done. My software guy says he can comb it out for me over the next few days. Depending on parts selection and installed software, this particular design can become perhaps a dozen different products. First release of the 9024 will offer a quad function device. The user will select the desired function with jumpers in the mating connector. This allows the owner/operator to stock one spare device for up to four different applications on the airplane This one will be fun to put together. It's got up to 25 components soldered to two sides of a .8" x 1.1" board! Progress is happening . . . Bob . . . ________________________________________________________________________________
Date: Jul 21, 2010
After review by a group member, he pointed out that my alt#2 B lead was always hot because it was connected to the upstream side of the battery contactor. As it 's a relatively long fat wire, he suggested a separate contactor for it. As I was figuring where to install it, I thought that the ground power contactor is doing nothing most of its life and could serve as the #2 alt B lead contactor as well. I'd be grateful if any of you could take a look at the attached to see if I'm neglecting something. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=305867#305867 Attachments: http://forums.matronics.com//files/z13_8q_mine_w_40a_contactor_126.pdf ________________________________________________________________________________
Subject: Z-32 Question
Date: Jul 21, 2010
If the feed wire from the main batt bus to the relay is protected by the 10a fuse, why is it marked " * " ? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=305869#305869 ________________________________________________________________________________
Date: Jul 21, 2010
Subject: Re: Z-32 Question
At 08:17 PM 7/21/2010, you wrote: > >If the feed wire from the main batt bus to the relay is protected by >the 10a fuse, why is it marked " * " ? > Because the 10A (or larger) fuse exceeds the legacy rule-of-thumb for protection size of long, always hot feeders. Hence the alternate feed source "mini- contactor" and a short feeder between that contactor and the battery bus. Bob . . . ________________________________________________________________________________
Date: Jul 21, 2010
Subject: Re: Corrected Electrical Schematic for Review
At 08:14 PM 7/21/2010, you wrote: > >After review by a group member, he pointed out that my alt#2 B lead >was always hot because it was connected to the upstream side of the >battery contactor. As it 's a relatively long fat wire, he suggested >a separate contactor for it. > >As I was figuring where to install it, I thought that the ground >power contactor is doing nothing most of its life and could serve as >the #2 alt B lead contactor as well. > >I'd be grateful if any of you could take a look at the attached to >see if I'm neglecting something. You could do that but the contactor needs to be a 4-terminal device wired with three diodes like a cross-feed contactor in Z-14. The way you have it wired now, the contactor may not be assured a power source for closing it if the alternator doesn't self-excite. Better that coil power is assured with the appropriate array of diodes. Also, you need to fix the ov protection on this contactor per remarks offered earlier. Bob . . . ________________________________________________________________________________
Date: Jul 22, 2010
Bob, OK, got it. But now that begs the question of why there is a fusible link between the Ebus and Alt Feed Switch in Z-13/8 and not one in Z-32 between the contactor and Ebus? Also, would you comment on my attached schematic (disregard pg 2)? In particular your thoughts on using the GP contactor as a contactor for Alt # 2. Is there a prohibition of having both alternators online simultaneously? Thank you, John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=305962#305962 Attachments: http://forums.matronics.com//files/z13_8q_mine_w_40a_contactor_111.pdf ________________________________________________________________________________
Date: Jul 22, 2010
Bob, I missed your response to "Corrected Electrical Schematic" so disregard that part of my last post on this subject. Thanks, J Read this topic online here: http://forums.matronics.com/viewtopic.php?p=305963#305963 ________________________________________________________________________________
Date: Jul 22, 2010
Joe G, My question was rendered moot by going with two DPST switches, one leg of which powers the EFI ECU and the other, the Injectors, per Dick Tasker's suggestion to eliminate the single point of failure. I was being kind of myopic wondering if a DPST providing dual power sources to a single load would see 1/2 the load on each leg. Thanks, John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=305968#305968 ________________________________________________________________________________
Date: Jul 22, 2010
user9253 wrote: > ... > Also, the diode needs to be in series with the contactor coil to prevent reverse polarity damage from the ground power. See Bob's drawing Z-31B. > Joe > http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z31K.pdf Joe, I'm doing a separate post of my schematic revisions, titled ...RevA, B, etc. Made the correction re the OVM. Re Diodes Because I'm using a continuous duty contactor with one 8-32 coil post, as drawn, I asked about placement and orientation. Bob N responded " The banded end of the diode connects to the "BAT" terminal of the contactor which in turn faces incoming power from the ground power connector." I thought that my schematic complied with Bob's suggestion??? Is the second diode on the wire to the switch breaker superfluous once the contactor diode is oriented/located properly? Thanks, John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=305977#305977 ________________________________________________________________________________
Date: Jul 22, 2010
nuckolls.bob(at)aeroelect wrote: > At 08:14 PM 7/21/2010, you wrote: > > > > > > > You could do that but the contactor needs to be a 4-terminal > device wired with three diodes like a cross-feed contactor > in Z-14. The way you have it wired now, the contactor may > not be assured a power source for closing it if the alternator > doesn't self-excite. Better that coil power is assured with > the appropriate array of diodes. > > Also, you need to fix the ov protection on this contactor > per remarks offered earlier. > Bob . . . Bob, Got the OVM where it's supposed to go. See post "Electrical Schematic for Review, Rev.A" I'm not sure what you mean by "self excite". The Ebus Alt Feed Switch provides power to the field. If the alternator starts outputting voltage, doesn't the B lead provide power to the coil of the contactor, closing it?. And if the alternator isn't making any power, does it matter if the contactor closes or not?? John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=305981#305981 ________________________________________________________________________________
Subject: Electrical System Schematic Review Rev A
Date: Jul 22, 2010
Most current revision Read this topic online here: http://forums.matronics.com/viewtopic.php?p=305982#305982 Attachments: http://forums.matronics.com//files/z13_8q_mine_w_40a_contactor_reva_110.pdf ________________________________________________________________________________
Date: Jul 22, 2010
> Is the second diode on the wire to the switch breaker superfluous once the contactor diode is oriented/located properly? John, Your GROUND POWER / ALT 2 contactor circuit is looking good now. As for the diode, the one below the contactor going to the GND PWR 2 amp breaker, it is wired correctly and will protect against reverse polarity from an exterior battery. The other diode on the right side of the contactor does not serve any useful purpose that I can see. It does not hurt anything, except that it is an unnecessary failure point. If this diode was intended as a coil arc suppression diode, it is connected to the wrong contactor terminal. It should have been connected where the O.V. module is now. Not to worry about that, just get rid of that unnecessary diode because the O.V. module guards against voltage spikes. I agree that as long as the battery is not dead and the E-BUS ALT FEED switch is turned on, then the AUX Alternator should work and energize the contactor coil. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=305994#305994 ________________________________________________________________________________
Date: Jul 23, 2010
Joe, thanks. The correction is on Rev. B that I'll post this morning. I have one other question and then I think I've got this knocked. >From the Ebus alt feed contactor to the Ebus, there is a fusible link called for. My Ebus is fused at 30a at the battery bus and will run at about 20-24 amps and I'm using an 8AWG wire to keep temps down so the fuse link would be a 12AWG. I think that I will put a 40a at the batt bus for the 8AWG protection and to give some head room for the Ebus. Would it be a better design to use a 30a ANL current limiter in place of the 12AWG Fuselink? John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306095#306095 ________________________________________________________________________________
Date: Jul 23, 2010
At 11:29 AM 7/23/2010, you wrote: > >Joe, thanks. > >The correction is on Rev. B that I'll post this morning. > >I have one other question and then I think I've got this knocked. > > >From the Ebus alt feed contactor to the Ebus, there is a fusible > link called for. My Ebus is fused at 30a at the battery bus and > will run at about 20-24 amps and I'm using an 8AWG wire to keep > temps down so the fuse link would be a 12AWG. I think that I will > put a 40a at the batt bus for the 8AWG protection and to give some > head room for the Ebus. Would it be a better design to use a 30a > ANL current limiter in place of the 12AWG Fuselink? I thing the concept for an E-bus has run off into the weeds. The original idea for the e-bus was to craft a plan-b that offered an option for a system that would take you comfortably to airport of intended destination . . . battery only. When vacuum pumps started dropping like flies, we reasoned that e-bus loads could take a jump by supplementing a battery with an 8A engine driven power source. Even then, sizing of continuous operating loads during an alternator failure event was still LIMITED. A modicum of planning was necessary to craft the optimal plan-b. Your aux alternator is large enough to run all normal operating loads of 99% of all OBAM aircraft flying. Hence, the notion of segmenting electrical loads into "normal" and "endurance" camps for the purpose optimizing battery-only operations is curious. With a 40A aux alternator one is inclined to run a battery until it croaks . . . If you're not running a battery maintenance program designed to maintain some required reserve capacity, then the whole idea of an e-bus is moot. Further, the notion of battery-only operations for a electrically dependent engine under the best of conditions is a scenario most system designers would rather not contemplate. I'll suggest you stand back and review the big picture. Consider something like Figure Z-12 and no e-bus. This is how hundreds of TC aircraft are configured to integrate robust alternators into the electrical system. Before you get deeply distracted with the details of what fuse or diode goes where, you need to Work through anticipated failure modes and see first how ARCHITECTURE mitigates those failures. Keep in mind that crafting a preventative maintenance plan unique to your needs marches hand-in-hand with architecture and sizing of hardware. I think you'll find that a Z-12 basis for your proposed system is simpler, easier to operate, and better suited to an airplane with an electrically dependent engine. Bob . . . ________________________________________________________________________________
Date: Jul 23, 2010
> Would it be a better design to use a 30a ANL current limiter in place of the 12AWG Fuselink? Short answer is no. The long answer is that I agree with Bob that the electrical system is much more heavy duty than most airplanes. If you are sure that you need this redundancy for IFR over hostile terrain or whatever, then this is what I would do. Get rid of the fuse at the battery bus and mount the E-Bus relay as close to the battery as possible and use a 14awg wire (fuselink) between the battery bus and the relay. Put a 30amp ANL at the relay in series with 10awg to the E-bus. I am not saying that this is the right way to do it, just the way that I would do it. Your way will work too. Keep in mind that it will difficult to blow a 40amp ANL fuse or even a 30 amp for that matter. Use double insulation where the wire passes though the firewall or bulkheads and take care with the installation and a fuse will never blow, nor will there be smoke. I am heading for OSH. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306116#306116 ________________________________________________________________________________
Date: Jul 24, 2010
Bob and Joe, OK, I got kind of buried in the details and my goal became to build an absolutely bullet- proof redundant electrical system rather than one that is practical for my purposes. Also at work was a lack of confidence in my understanding of electrical theory and principle and a visceral notion that electricity is a mysterious, unpredictable serpent , so to compensate for that and to gain a level of comfort, I chose to just overbuild its cage. After both of your responses and re-reading the purpose of Ebus, I see that somewhere along the development of my system, I came to view the Main bus as something that might fail and misconceived the Ebus as a back up. After discussion offline with a Glasair III builder (using Z-12) and Bobs suggestion to stand back and review the big picture I can now reason that the MB has switches and fuses for every circuit and that my apprehension that, despite proper construction, it could crash altogether is simply unsupportable. With the above in mind, Z-12 now seems elegantly appropriate for my needs and I will eliminate the Ebus altogether, per Bobs suggestion. The one feature of my drawn architecture that deviates from Z-12 is the SB Alt B lead landing on the battery side of the MB contactor. I perceive that this will allow me to use the Generic Ford Regulator over the B&C SB-1 and eliminate the MB contactor as a single point of failure in the charging circuit. I seem to remember Bob recommending a mechanical lock out of the SB alt, if not using the SB-1?? Z-12 w- SB ALT contactor is attached. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306153#306153 Attachments: http://forums.matronics.com//files/z12_w_sb_alt_contactor_208.pdf ________________________________________________________________________________
Date: Jul 24, 2010
At 01:37 PM 7/24/2010, you wrote: > >Bob and Joe, > >OK, I got kind of buried in the details and my >goal became to build an absolutely bullet- proof >redundant electrical system rather than one that is practical for my purposes. I hope you don't feel that this has been a "wasted" exercise. The elegant solution is like a fine wine. Not only are the choices of simple-ideas large and varied, the time that it takes to hypothesize, assemble and consider the results doesn't happen like magic. In fact, one must be wary of new designs offered by anyone in any discipline until that caution is displaced by understanding. I'm going into production on the 9024 series devices after perhaps a year of mulling over the options . . . and I've been doing this for a long time. The B&C starter was over 6 years in development. I can probably recall many more examples of how the roots of many products run deep in man-years of preparation. >With the above in mind, Z-12 now seems elegantly >appropriate for my needs and I will eliminate >the Ebus altogether, per Bobs suggestion. The >one feature of my drawn architecture that >deviates from Z-12 is the SB Alt B lead landing >on the battery side of the MB contactor. I >perceive that this will allow me to use the >Generic Ford Regulator over the B&C SB-1 and >eliminate the MB contactor as a single point of >failure in the charging circuit. I seem to >remember Bob recommending a mechanical lock out >of the SB alt, if not using the SB-1?? Not sure where that might have come from. Note that Z-12 as published is illustrative and demonstrative of a minimalist approach to adding robust aux alternators to a TC aircraft. Note that unlike the rest of the z-figures, Z-12 shows breakers on the bus as opposed to fuse blocks. A Z-12 for new design where crowbar ov protection is proposed might lean toward fuse blocks but take both B-leads to fat wires under the cowl through current limiters. Of course, the field supply leads still need breakers . . . run a 20 pair of 18AWG feeders protected with 22AWG fusible links to their respective alternator control switches. This might be a Z11-1/2 where you simply add a second alternator that needs only one more switch (field supply) on the panel. Eliminate the e-bus. Run ALL electrically dependent engine loads from the battery bus. In further "stirring of simple-ideas" I note that another feature of the e-bus is a plan-b for dealing with a battery contactor failure. These are rare and can probably become still more rare if fitted with power a management module to reduce operating temperature. Even so, we could consider tying your aux alternator b-lead to the battery side of the contactor with a Schottky diode to isolate the always-hot, fat wire between battery and alternator. In this case, you'd also need to power the aux alternator field from the battery bus. This variant would cover the failed-contactor scenario. Let me ponder this some more. Take a whack at implementing this using your current CAD skills. By the way, good work with the CAD drawings. I'm pretty certain that we're boiling the options down toward the essence of an elegant solution. The 40A aux alternator offers a Z-12 like architecture that accommodates more demanding engine support loads. Bob . . . >Z-12 w- SB ALT contactor is attached. > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=306153#306153 > > >Attachments: > >http://forums.matronics.com//files/z12_w_sb_alt_contactor_208.pdf > > >Checked by AVG - www.avg.com >- Release Date: 07/24/10 01:36:00 Bob . . . ________________________________________________________________________________
Subject: Low Voltage Warning Light
Date: Jul 24, 2010
Bob, I am using an LR3 voltage regulator and a B&C 60 A alternator. Is it acceptable to change out the supplied warning light for a red 12 volt led? It would be in my direct line of sight so I do not think the lack of blinking would be an issue. That is if the blinking is a function of the light and not the regulator. Please let me know if there would be problems with using an led and if it would blink. TIA Don VS ________________________________________________________________________________
Date: Jul 25, 2010
Subject: New Engine Monitor on eBay
Morning, Everyone... Last night I listed my never used or even powered up, still in the original packing, engine monitor (EMS) for sale on eBay. I'm replacing it because a friend sold me a unit that has the EMS AND the EFIS combined instead of just the EMS as this IK Technology unit has. This was for my Lycoming O_235, but will work for any 4 cylinder engine. This AIM-1 model is now selling for $1499. I have no minimum and no reserve (well, I guess the minimum is the current bid! ), so someone is going to get a real deal! For ALL the details and several pictures, just search eBay for the item number 350375561835 , or search eBay for IK Tech (so far, mine is the only item listed with that name). Harley Dixon Long EZ N28EZ Canandaigua, NY ________________________________________________________________________________
Date: Jul 25, 2010
Jon: Your solutions appear similar to my system, and the Schematic is beautiful! I see there are many Notes referred to on the schematic. Are the notes available? (I'm still under construction, and don't have your documentation skills.) Phil RV10 w/Mazda 20B electrically dependent engine installed ________________________________________________________ Bob and Joe, "snip" With the above in mind, Z-12 now seems elegantly appropriate for my needs and I will eliminate the Ebus altogether, per Bobs suggestion. The one feature of my drawn architecture that deviates from Z-12 is the SB Alt B lead landing on the battery side of the MB contactor. I perceive that this will allow me to use the Generic Ford Regulator over the B&C SB-1 and eliminate the MB contactor as a single point of failure in the charging circuit. I seem to remember Bob recommending a mechanical lock out of the SB alt, if not using the SB-1?? Z-12 w- SB ALT contactor is attached. ________________________________________________________________________________
Date: Jul 25, 2010
Subject: Re: Low Voltage Warning Light
At 10:11 PM 7/24/2010, you wrote: > >Bob, >I am using an LR3 voltage regulator and a B&C 60 A alternator. Is it >acceptable to change out the supplied warning light for a red 12 volt led? Yes, but the circuitry in the LR3 was designed to drive incandescent bulbs. You'll need to add some resistors to the LED circuit such that the LED mimics the bulb. See: http://aeroelectric.com/Pictures/Schematics/LR3_LV_Led_1.jpg >It would be in my direct line of sight so I do not think the lack of >blinking would be an issue. That is if the blinking is a function of the >light and not the regulator. Please let me know if there would be problems >with using an led and if it would blink/ The flasher is built into the LR3. Bob . . . ________________________________________________________________________________
Date: Jul 25, 2010
At 06:23 AM 7/25/2010, you wrote: > >Jon: Your solutions appear similar to my system, and the >Schematic is beautiful! I see there are many Notes referred to on >the schematic. Are the notes available? (I'm still under >construction, and don't have your documentation skills.) > >Phil Jon was willing and able to exploit the CAD drawings published at: http://www.aeroelectric.com/PPS/ACAD_Architecture_Dwgs/ and repeated as ordinary .pdf drawings at: http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/ I might remind List members who were referred to the AeroElectric-List from other associations that there is an AeroElectric website at http://aeroelectric.com/ with some 500 Megabytes of articles, photos, and drawings including a complete compilation of sample system architectures extracted from the back of the book . . . http://aeroelectric.com/R12A/AppZ_12A4.pdf Bob . . . ________________________________________________________________________________
Date: Jul 25, 2010
[/quote] I hope you don't feel that this has been a "wasted" exercise. Not at all. In the course of building my plane, I have spent hours, weeks, years even, in developing ideas that ended up in the trash. But they are just the steps that I had to take to get to where I am. > > .... > A Z-12 for new design where > crowbar ov protection is proposed might lean toward fuse blocks > but take both B-leads to fat wires under the cowl through > current limiters. Of course, the field supply leads still need > breakers . . . run a 20 pair of 18AWG feeders protected with > 22AWG fusible links to their respective alternator control switches. > > Done in my schematic > > This might be a Z11-1/2 where you simply add a second alternator > that needs only one more switch (field supply) on the panel. > Eliminate the e-bus. Run ALL electrically dependent engine > loads from the battery bus. > > Knee jerk reaction is the all-eggs-in-one-basket apprehension. Granted the failure modes of the battery/bus seem awfully remote, but what harm is there in having an essential engine complement on the main bus so that it can run from a self-excited alternator with the Main contactor open? > > In further "stirring of simple-ideas" I note that another > feature of the e-bus is a plan-b for dealing with a > battery contactor failure. These are rare and can > probably become still more rare if fitted with > power a management module to reduce operating temperature. > Even so, we could consider tying your aux alternator b-lead > to the battery side of the contactor with a Schottky diode > to isolate the always-hot, fat wire between battery and > alternator. In this case, you'd also need to power the > aux alternator field from the battery bus. This variant > would cover the failed-contactor scenario. > > In my system this seems like a moot exercise because of the redundant SB Alt/GP contactor. But for a system that isn't installing a GPJ, the Schottky variant on the B lead is a nice solution. > > Let me ponder this some more. Take a whack at implementing > this using your current CAD skills. By the way, good work > with the CAD drawings. > > Thanks and here's a " Z11.5" Draft > > I'm pretty certain that we're boiling the options down > toward the essence of an elegant solution. The > 40A aux alternator offers a Z-12 like architecture > that accommodates more demanding engine support > loads. > > Bob . . . > > > > > > Z-12 w- SB ALT contactor is attached. > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=306153#306153 > > > > > > > > > > Attachments: > > > > http://forums.matronics.com//files/z12_w_sb_alt_contactor_208.pdf
June 27, 2010 - July 25, 2010
AeroElectric-Archive.digest.vol-jp
