AeroElectric-Archive.digest.vol-jx
December 09, 2010 - Present
      >> http://forums.matronics.com/viewtopic.php?p=322731#322731
Subject: Re: Odyssey type batteries require a special type
of charger?
Date: Dec 09, 2010
Yes, I hope I didn't imply that cheap wouldn't work, only that some of them may not perform correctly. That is easy to monitor when you start using a new charger. Bob Meyers Flight Testing Sonex N982SX Web Site Index http://N982SX.com On Dec 9, 2010, at 12:39 PM, bob noffs wrote: > fwiw, for several yrs i have had a schumacher [ mod 1362?] battery > tender connected to my 625. as far as i can tell it works as well as > when new. constant voltage regulation has n't been a problem. you > can pick them up new on ebay for $25. > bob noffs > > On Thu, Dec 9, 2010 at 12:18 PM, Bob Meyers > wrote: > > > > Not only is it not true, Odyssey doesn't claim it is true. Odyssey > makes a line of chargers that they will be happy to sell you, but > they also publish detailed specs that will let you evaluate the > suitability of any charger - of which most automotive chargers will > work just fine. > > Most significantly they warn about using any charger that exceeds > 15v. Since no charger should really do that, it is usually only the > cheapest, most poorly made chargers that you have to worry about. > > The above is the only thing that they warn can damage the battery. > The rest of their caveats talk about how best to achieve 100% SOC > and what you may may have to do depending on the charger you have. > > Bob Meyers > > Flight Testing Sonex N982SX Web Site Index http://N982SX.com > > > On Dec 9, 2010, at 7:37 AM, user9253 wrote: > > > > > This document by Eggenfellner > http://www.eggenfellneraircraft.com/Stuff-to-link-to/ESeriesInstallationGuide.pdf > says, > "Odyssey type batteries require a special type of charger. Never use > a regular automotive charger and especially never use a trickle > charger as these do not provide proper charge voltage or currents." > > This is not true is it? > Thanks, Joe > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=322731#322731 > > > he Annual List Fund Raiser. Click on > /" target="_blank">www.aeroelectric.com > omebuiltHELP www.homebuilthelp.com > http:/r generous support! > he Matronics List Features Navigator to browse > s.com/Navigator?AeroElectric-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List > ronics.com/" target="_blank">http://forums.matronics.com > ============= > > ________________________________________________________________________________
Date: Dec 09, 2010
of charger? At 10:48 AM 12/9/2010, you wrote: > > From ODYSSEY's site: > >http://www.odysseybattery.com/documents/US-ODY-OM-008_1010.pdf > >Also I note that the charges they sell use 3 sequential charge >currents. This may be of use in the Deep cycle application and of >course your alternator does not know if you have an ODYSSEY or a >Sears & Robuck battery. I cant imagine it would not get a complete >charge after a few hours with 14 VDC on it. >Tim Andres Right on. The Internet driven dispersal of floobydust about SVLA battery charging has been waxing and waning for at least ten years. Bottom line is that EVERY manufacturer of battery has good reason to recommend/discourage a battery charging philosophy . . . but for reasons that are usually not known to us and is probably irrelevant. The folks at the factory may have conducted many detailed studies with a goal of knowing (1) how their product performs and (2) how to make that performance stand a tad taller than the competition. As Tim noted, once you bolt the battery to your airplane, ALL bets for achieving the greatest possible service life are off. This is because the probability that any given battery is asked to perform in laboratory conditions is zero. The problem is further compounded when folks who sell batteries mix decades of ol' mechanics lore with ideas taken from the new supplier's 4-color brochures. Mix the 'right' ingredients and clouds of floobydust explode. There is no such thing as a modern "trickle" charger which is, by definition, a small but CONSTANT CURRENT charger. Trickle chargers are mildly abusive of a flooded battery ('cause you can put in more water) and poison to an SVLA battery ('cause you can't put in more water). Many small chargers (1/2 amp to perhaps 2 amps capability) are often mis-identified as "trickle chargers" based only on their electrical size. In fact, I'm aware of NO modern product at any price that does not go into some form of constant SUSTAINING voltage after spending some time at a bulk charge or TOP-OFF voltage. These are BATTERY MAINTAINERS. The least expensive device at WalMart are entirely suitable for charging/maintaining any brand/size of SVLA battery. http://www.aeroelectric.com/Pictures/Curves/Ideal_Recharge_Protocol.jpg How close do the market place chargers come to meeting the "ideal recharge protocol"? http://www.aeroelectric.com/Pictures/Curves/Battery_Minder_Recharge.pdf http://www.aeroelectric.com/Pictures/Curves/Battery_Tender_Recharge.pdf http://www.aeroelectric.com/Pictures/Curves/schumacher_2.jpg http://www.aeroelectric.com/Pictures/Curves/schumacher_3.jpg http://www.aeroelectric.com/Pictures/Curves/schumacher_4.jpg http://www.aeroelectric.com/Pictures/Curves/schumacher_5.jpg http://www.aeroelectric.com/Pictures/Curves/schumacher_6.jpg Not many. How much difference will it make in the demonstrated service life in YOUR airplane. Not much. Check out the offerings of Professor Battery (Isador Buchmann) at . . . http://batteryuniversity.com/learn Finally, exhortations for application or black- listing of any modern product as a battery charger need to be filtered integrity of the physics and/or relevance in your proposed application. As Tim noted, your alternator/regulator combo doesn't read Battery Digest. Bob . . . ________________________________________________________________________________
Date: Dec 09, 2010
Subject: Re: Avionics ground bus
At 09:55 AM 12/7/2010, you wrote: > > >Some parts on order for the first production batch will >be here tomorrow. I'm about 1/3 completed with the >instruction manual. I'll put it up on the website >catalog and order form tomorrow. I've got a pretty good first whack at the installation manual for the instrument panel ground bus. http://aeroelectric.com/Catalog/AEC/9031/IM9031-700A.pdf the first orders are shipping today. Bob . . . ________________________________________________________________________________
Subject: Re: G530 TX Issue
Date: Dec 09, 2010
Glen, You didn't say if it ever worked. From the symptoms you present it would appear to be the mic audio connection from the audio panel to the to the 530. Other com working says the mic and audio input is OK. The TX indicator and breaking squelch on the Hand Held Radio says the Mic Key and transmitter are working. You could have a defective Audio panel output or 530 Mic input but it is more likely a connection issue. Use a couple of pins crimped to a pair of stiff wires so you can probe the tray connectors and check continuity of both the Mic high and Mic Return lines. You will probably find A. A pin in the wrong place, B. A pin retracted from the connector, C. A bad crimp or D. A broken wire. I had a similar symptom on an RV-10 with a 430 it was A pin in the wrong position. If it ever worked then I would suspect B Good luck -------- Ralph & Laura Hoover RV7A N527LR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322796#322796 ________________________________________________________________________________
of charger?
Date: Dec 09, 2010
What kind of Alternator do you get that produces 3 sequential charge currents for the Odyssey? Well, I thought it was funny. Tim ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Sent: Thursday, December 09, 2010 12:02 PM Subject: Re: AeroElectric-List: Odyssey type batteries require a special type of charger? > > > At 10:48 AM 12/9/2010, you wrote: >> >> >> From ODYSSEY's site: >> >>http://www.odysseybattery.com/documents/US-ODY-OM-008_1010.pdf >> >>Also I note that the charges they sell use 3 sequential charge currents. >>This may be of use in the Deep cycle application and of course your >>alternator does not know if you have an ODYSSEY or a Sears & Robuck >>battery. I cant imagine it would not get a complete charge after a few >>hours with 14 VDC on it. >>Tim Andres > > Right on. The Internet driven dispersal of > floobydust about SVLA battery charging has been > waxing and waning for at least ten years. > > Bottom line is that EVERY manufacturer of battery > has good reason to recommend/discourage a battery > charging philosophy . . . but for reasons that > are usually not known to us and is probably > irrelevant. > > The folks at the factory may have conducted many > detailed studies with a goal of knowing (1) how > their product performs and (2) how to make that > performance stand a tad taller than the competition. > > As Tim noted, once you bolt the battery to your > airplane, ALL bets for achieving the greatest > possible service life are off. This is because > the probability that any given battery is asked > to perform in laboratory conditions is zero. > > The problem is further compounded when folks who > sell batteries mix decades of ol' mechanics lore > with ideas taken from the new supplier's 4-color > brochures. Mix the 'right' ingredients and clouds > of floobydust explode. > > There is no such thing as a modern "trickle" charger > which is, by definition, a small but CONSTANT > CURRENT charger. Trickle chargers are mildly abusive > of a flooded battery ('cause you can put in more > water) and poison to an SVLA battery ('cause you > can't put in more water). > > Many small chargers (1/2 amp to perhaps 2 amps > capability) are often mis-identified as "trickle > chargers" based only on their electrical size. > > In fact, I'm aware of NO modern product at any > price that does not go into some form of constant > SUSTAINING voltage after spending some time at > a bulk charge or TOP-OFF voltage. These are BATTERY > MAINTAINERS. The least expensive device at WalMart are > entirely suitable for charging/maintaining any > brand/size of SVLA battery. > > http://www.aeroelectric.com/Pictures/Curves/Ideal_Recharge_Protocol.jpg > > How close do the market place chargers come to meeting > the "ideal recharge protocol"? > > http://www.aeroelectric.com/Pictures/Curves/Battery_Minder_Recharge.pdf > > http://www.aeroelectric.com/Pictures/Curves/Battery_Tender_Recharge.pdf > > http://www.aeroelectric.com/Pictures/Curves/schumacher_2.jpg > > http://www.aeroelectric.com/Pictures/Curves/schumacher_3.jpg > > http://www.aeroelectric.com/Pictures/Curves/schumacher_4.jpg > > http://www.aeroelectric.com/Pictures/Curves/schumacher_5.jpg > > http://www.aeroelectric.com/Pictures/Curves/schumacher_6.jpg > > Not many. > > How much difference will it make in the demonstrated > service life in YOUR airplane. Not much. > > Check out the offerings of Professor Battery > (Isador Buchmann) at . . . > > http://batteryuniversity.com/learn > > Finally, exhortations for application or black- > listing of any modern product as a battery charger > need to be filtered integrity of the physics and/or > relevance in your proposed application. > > As Tim noted, your alternator/regulator combo > doesn't read Battery Digest. > > Bob . . . > > > ________________________________________________________________________________
Date: Dec 09, 2010
Hello Bob I order a grnd bus on your site and was expecting an email to complete the order with pay pal. No hurry but just wondering if I did not get the order complete Thanks Tim Andres Sent from my iPhone On Dec 9, 2010, at 2:46 PM, "Robert L. Nuckolls, III" wrote: > > At 09:55 AM 12/7/2010, you wrote: >> >> Some parts on order for the first production batch will >> be here tomorrow. I'm about 1/3 completed with the >> instruction manual. I'll put it up on the website >> catalog and order form tomorrow. > > I've got a pretty good first whack at the installation > manual for the instrument panel ground bus. > > http://aeroelectric.com/Catalog/AEC/9031/IM9031-700A.pdf > > the first orders are shipping today. > > > > Bob . . . > > > > ________________________________________________________________________________
Subject: Odyssey type batteries require a special type
of charger?
Date: Dec 10, 2010
Actually most chargers will reduce the amount of current being fed to the battery as the battery accepts charge. In effect as the battery accepts a charge it becomes a large resistor to the current feeding it. The only thing the three step charge does is lower the input requirements for the charger. This is why when you put a discharged battery on to charge it draws maximum current and when the battery is close to full charged the current is minimal. It is possible for chargers when they come to the end of a charge cycle to increase the voltage fed to the battery causing the battery to boil dry. Noel -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of F. Tim Yoder Sent: December 10, 2010 12:06 AM Subject: Re: AeroElectric-List: Odyssey type batteries require a special type of charger? What kind of Alternator do you get that produces 3 sequential charge currents for the Odyssey? Well, I thought it was funny. Tim ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Sent: Thursday, December 09, 2010 12:02 PM Subject: Re: AeroElectric-List: Odyssey type batteries require a special type of charger? > > > At 10:48 AM 12/9/2010, you wrote: >> >> >> From ODYSSEY's site: >> >>http://www.odysseybattery.com/documents/US-ODY-OM-008_1010.pdf >> >>Also I note that the charges they sell use 3 sequential charge currents. >>This may be of use in the Deep cycle application and of course your >>alternator does not know if you have an ODYSSEY or a Sears & Robuck >>battery. I cant imagine it would not get a complete charge after a few >>hours with 14 VDC on it. >>Tim Andres > > Right on. The Internet driven dispersal of > floobydust about SVLA battery charging has been > waxing and waning for at least ten years. > > Bottom line is that EVERY manufacturer of battery > has good reason to recommend/discourage a battery > charging philosophy . . . but for reasons that > are usually not known to us and is probably > irrelevant. > > The folks at the factory may have conducted many > detailed studies with a goal of knowing (1) how > their product performs and (2) how to make that > performance stand a tad taller than the competition. > > As Tim noted, once you bolt the battery to your > airplane, ALL bets for achieving the greatest > possible service life are off. This is because > the probability that any given battery is asked > to perform in laboratory conditions is zero. > > The problem is further compounded when folks who > sell batteries mix decades of ol' mechanics lore > with ideas taken from the new supplier's 4-color > brochures. Mix the 'right' ingredients and clouds > of floobydust explode. > > There is no such thing as a modern "trickle" charger > which is, by definition, a small but CONSTANT > CURRENT charger. Trickle chargers are mildly abusive > of a flooded battery ('cause you can put in more > water) and poison to an SVLA battery ('cause you > can't put in more water). > > Many small chargers (1/2 amp to perhaps 2 amps > capability) are often mis-identified as "trickle > chargers" based only on their electrical size. > > In fact, I'm aware of NO modern product at any > price that does not go into some form of constant > SUSTAINING voltage after spending some time at > a bulk charge or TOP-OFF voltage. These are BATTERY > MAINTAINERS. The least expensive device at WalMart are > entirely suitable for charging/maintaining any > brand/size of SVLA battery. > > http://www.aeroelectric.com/Pictures/Curves/Ideal_Recharge_Protocol.jpg > > How close do the market place chargers come to meeting > the "ideal recharge protocol"? > > http://www.aeroelectric.com/Pictures/Curves/Battery_Minder_Recharge.pdf > > http://www.aeroelectric.com/Pictures/Curves/Battery_Tender_Recharge.pdf > > http://www.aeroelectric.com/Pictures/Curves/schumacher_2.jpg > > http://www.aeroelectric.com/Pictures/Curves/schumacher_3.jpg > > http://www.aeroelectric.com/Pictures/Curves/schumacher_4.jpg > > http://www.aeroelectric.com/Pictures/Curves/schumacher_5.jpg > > http://www.aeroelectric.com/Pictures/Curves/schumacher_6.jpg > > Not many. > > How much difference will it make in the demonstrated > service life in YOUR airplane. Not much. > > Check out the offerings of Professor Battery > (Isador Buchmann) at . . . > > http://batteryuniversity.com/learn > > Finally, exhortations for application or black- > listing of any modern product as a battery charger > need to be filtered integrity of the physics and/or > relevance in your proposed application. > > As Tim noted, your alternator/regulator combo > doesn't read Battery Digest. > > Bob . . . > > > ________________________________________________________________________________
Date: Dec 10, 2010
of charger? At 09:35 PM 12/9/2010, you wrote: > > >What kind of Alternator do you get that produces 3 sequential charge >currents for the Odyssey? >Well, I thought it was funny. > >Tim Exactly. We considered launching into just such a protocol for the next generation alternator regulator. About 10 years ago I did a design study on a microprocessor based regulator that would produce a behavior not unlike the 'ideal SLVA battery recharge curve'. Having sized the task we then had to decide how to merchandise the thing. It was going to be about as expensive as an LR series regulator. Further, since the marketplace was moving decidedly toward the automotive alternators with built in regulators, selection of my new offering would demand other "inconveniences" be embraced to modify the alternator for external regulation. What could I tell the customer about the value for adding "the kitchen sink" to his suite of system accessories? It was decided that the economics of adding that expense to the cost of ownership for an OBAM aircraft was not justified. Selling the device would require the kinds of advertising you encounter for most other products and services . . . like "new and improved". The project was shelved. Bob . . . ________________________________________________________________________________
Date: Dec 10, 2010
of charger? Actually most chargers will reduce the amount of current being fed to the battery as the battery accepts charge. In effect as the battery accepts a charge it becomes a large resistor to the current feeding it. The only thing the three step charge does is lower the input requirements for the charger. The current demands on a constant voltage charger is a function of what the battery is presently accepting at that voltage. The only way the charger knows the battery is charged is to monitor recharge current versus time. When the recharge current has dropped below some target vale for some minimum period of time, the smart charger switches to the maintenance mode by dropping the output voltage to a value just above the battery's open circuit voltage. . . . just enough voltage to support the battery's internal leakage losses but not enough to produce unwelcome charging. Thus the battery is prevented from running itself down during a long term maintenance interval. This is why when you put a discharged battery on to charge it draws maximum current and when the battery is close to full charged the current is minimal. It is possible for chargers when they come to the end of a charge cycle to increase the voltage fed to the battery causing the battery to boil dry. This IS the salient feature of the so-called "trickle" chargers of yesteryear. They offer constant current outputs that are not programmed to terminate when the battery is charged. So even if the "trickle" is small, say 100 mA, subjecting a battery to a month of small but persistent "overcharge" is potentially terminal for an SVLA battery. Bob . . . ________________________________________________________________________________
Date: Dec 10, 2010
Ralph, Thanks for the tips. As far as I know it worked earlier this year. Since I've been building I've not really used it for talking, just listening. It also came back with a clean bill from a shop bench test. Of course that doesn't guarantee anything. I am using the Approach Stack bus so I'll check the connections and re-seat everything too. They made the cables. Someone else mentioned to check the case ground for continuity. Now that you mentioned Mic High, I think Approached used a blue wire to represent that pin. It was either High or Low that was supposed to go to ground? Glenn E. Long -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of hooverra Sent: Thursday, December 09, 2010 9:10 PM Subject: AeroElectric-List: Re: G530 TX Issue Glen, You didn't say if it ever worked. From the symptoms you present it would appear to be the mic audio connection from the audio panel to the to the 530. Other com working says the mic and audio input is OK. The TX indicator and breaking squelch on the Hand Held Radio says the Mic Key and transmitter are working. You could have a defective Audio panel output or 530 Mic input but it is more likely a connection issue. Use a couple of pins crimped to a pair of stiff wires so you can probe the tray connectors and check continuity of both the Mic high and Mic Return lines. You will probably find A. A pin in the wrong place, B. A pin retracted from the connector, C. A bad crimp or D. A broken wire. I had a similar symptom on an RV-10 with a 430 it was A pin in the wrong position. If it ever worked then I would suspect B Good luck -------- Ralph & Laura Hoover RV7A N527LR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322796#322796 ________________________________________________________________________________
Subject: RE: Intermittent Generator
Date: Dec 10, 2010
Hi Noel, Thanks, I'll check the F lead connection. I'm also guessing that it's sticking brushes. Unless I find some other cause, I'm planning to continue flying it until it fails again and then have the alternator repaired by a reputable shop. Thanks, Dennis From: "Noel Loveys" <noelloveys(at)yahoo.ca> Subject: RE: AeroElectric-List: RE: Intermittent Generator You may also want to check the point where the F lead attaches to the alternator. I'm still betting on sticky brushes. My experience is, that only happens when the brushes are well worn. Noel ________________________________________________________________________________
Date: Dec 10, 2010
Subject: Re: Intermittent Generator Problem
Any ideas what caused this? Since the first symptom was reduced output and a whine in the headset, I initially suspected failed diodes inside the alternator, but when it healed itself, I thought it might have been a brush problem inside the alternator. Could be a grounding issue too . . . After 15 minutes, whatever was causing poor brush contact went away? I'm grasping at straws here. I am so thankful for Bob's Z 13-8 architecture, which allowed me to continue the flight without breaking a sweat! Thanks, Bob! Let's replace the 'straws' with data. What kind of alternator/regulator combination are you flying? If an externally regulated alternator, consider adding a temporary instrumentation wire with 1000 ohm resistor as close as possible to to the alternator's field terminal best. See: http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z22K_23K.pdf Get some cheepy volt-ohmeter to monitor voltage at the cockpit end of the wire in flight. An analog meter is best suited for this. This would be a good choice: http://www.radioshack.com/product/index.jsp?productId=2103957 Tape the meter up where you can watch it. Note the readings when the system is operating normally/ abnormally. Review the topic of Alternator Fault Isolation in chapter 3 of the 'Connection. Bob . . . ________________________________________________________________________________
Date: Dec 10, 2010
Subject: Grounding Sensors
I solved this by installing a spring in the stack... so that the spring keeps the washer tight against the sensor body, and makes up for differences in pipe thread make-up. Paul On 12/9/2010 11:56 PM, AeroElectric-List Digest Server wrote: > If the brass fitting had NPT threads, trying to clamp a tabbed washer > between the fitting and the manifold is probably not a good idea. > Clamping force is required to maintain electrical contact/continuity > with the washer, fitting& sensor. NPT threads depend on taper& > interference fit to seal. Finding the perfect thickness of washer to > fill the gap between the manifold boss and the adapter shoulder while > maintaining the correct fit of the NPT threads without over- or > under-torquing might be challenging. ________________________________________________________________________________
of charger?
Date: Dec 10, 2010
Thanks Bob... Now I have to look up SVLA ;-) Noel The current demands on a constant voltage charger is a function of what the battery is presently accepting at that voltage. The only way the charger knows the battery is charged is to monitor recharge current versus time. When the recharge current has dropped below some target vale for some minimum period of time, the smart charger switches to the maintenance mode by dropping the output voltage to a value just above the battery's open circuit voltage. . . . just enough voltage to support the battery's internal leakage losses but not enough to produce unwelcome charging. Thus the battery is prevented from running itself down during a long term maintenance interval. This IS the salient feature of the so-called "trickle" chargers of yesteryear. They offer constant current outputs that are not programmed to terminate when the battery is charged. So even if the "trickle" is small, say 100 mA, subjecting a battery to a month of small but persistent "overcharge" is potentially terminal for an SVLA battery. Bob . . . ________________________________________________________________________________
Date: Dec 10, 2010
Subject: re: Special type of charger?
At 05:24 PM 12/10/2010, you wrote: > >Thanks Bob... > >Now I have to look up SVLA ;-) Sorry. Sealed Vented Lead-Acid, same as: Recombinant Gas (RG), starved electrolyte, and perhaps some names I've not discovered yet. They're often confused with and called "gell-cells" which they are not. They are also distinct from a class of "maintenance free" battery used in the automotive industry which is in fact a flooded and vented cell that you can't open up to replace water. But for the most part, any battery you pick up that weighs like a brick of lead encased in plastic is an SVLA/RG/SE battery. Bob . . . ________________________________________________________________________________
Date: Dec 10, 2010
Subject: Re: re: Special type of charger?
AGM, Absorbent Glass Mat, and I remember seeing SLA, Starved Lead Acid, somewhere, too. Merry Christmas Bob, you're better than Santa Claus. Gifts all year long, and no reindeer poop on the roof.:-} Rick Girard On Fri, Dec 10, 2010 at 9:03 PM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > nuckolls.bob(at)aeroelectric.com> > > At 05:24 PM 12/10/2010, you wrote: > >> noelloveys(at)yahoo.ca> >> >> Thanks Bob... >> >> Now I have to look up SVLA ;-) >> > > Sorry. > > Sealed Vented Lead-Acid, same as: Recombinant > Gas (RG), starved electrolyte, and perhaps > some names I've not discovered yet. > > They're often confused with and called "gell-cells" > which they are not. They are also distinct from > a class of "maintenance free" battery used in > the automotive industry which is in fact a flooded > and vented cell that you can't open up to replace > water. > > But for the most part, any battery you pick up > that weighs like a brick of lead encased in plastic > is an SVLA/RG/SE battery. > > > Bob . . . > > -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Date: Dec 11, 2010
Thanks Bob. I wasn't able to find anything on the web. Noel From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Richard Girard Sent: December 11, 2010 12:39 AM Subject: Re: AeroElectric-List: re: Special type of charger? AGM, Absorbent Glass Mat, and I remember seeing SLA, Starved Lead Acid, somewhere, too. Merry Christmas Bob, you're better than Santa Claus. Gifts all year long, and no reindeer poop on the roof.:-} Rick Girard On Fri, Dec 10, 2010 at 9:03 PM, Robert L. Nuckolls, III wrote: At 05:24 PM 12/10/2010, you wrote: Thanks Bob... Now I have to look up SVLA ;-) Sorry. Sealed Vented Lead-Acid, same as: Recombinant Gas (RG), starved electrolyte, and perhaps some names I've not discovered yet. They're often confused with and called "gell-cells" which they are not. They are also distinct from a class of "maintenance free" battery used in the automotive industry which is in fact a flooded and vented cell that you can't open up to replace water. But for the most part, any battery you pick up that weighs like a brick of lead encased in plastic is an SVLA/RG/SE battery. Bob . . . ========== om" target="_blank">www.aeroelectric.com ooks.com" target="_blank">www.buildersbooks.com et="_blank">www.homebuilthelp.com ="_blank">http://www.matronics.com/contribution le, List Admin. ========== -List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List ========== http://forums.matronics.com ========== -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Subject: ISO Amp help
Date: Dec 11, 2010
Well, my first attempt at the Isolation amp has fizzled. I've pretty well resigned myself to starting over from scratch, but I want to make sure I don't repeat the same mistakes again. Here's what I get: A lot of distortion when the amp is powered up. With no power, I can hear the radio softly through the headset. Power on the amp, it's all distortion. I removed all inputs from the amp -- radio, intercom, nav, etc, same thing. All it needs is power. The d-sub connector is mounted on the solder side, per the illustrations, so power is pin 8. I can't find any spots where solder might have jumped terminals to create a short. A mistake I did find was that I didn't understand the polarity aspects of the capacitors, and some were installed backwards. Once I figured that out, I removed them and reinstalled them in the correct orientation, but there has been no change to the distortion. Either the damage had already been done, or that mistake wasn't the problem. Any input would be appreciated. One bill of materials question: Parts 6 & 7, A24794, do not appear anywhere in the plans aside from the bill of materials. Is that the solder-in ic socket that was replaced by the new machined-pin socket (revision H), or have I missed something else here? Brooks RV-7 details details ________________________________________________________________________________
Date: Dec 11, 2010
Subject: Re: ISO Amp help
>One bill of materials question: Parts 6 & 7, A24794, do not appear >anywhere in the plans aside from the bill of materials. Is that the >solder-in ic socket that was replaced by the new machined-pin socket >(revision H), or have I missed something else here? No, those were optional and used under the amplifier chips. They weren't on the boards I photographed and as a result, did not get tied to the BOM tags. This kind of trouble shooting is very difficult to do by remote. If you're interested, mail the assembly to me. I can probably figure out what's going on in a few minutes. I'll share the process by which the discovery was made. Bob Nuckolls Bob 130 Medicine Lodge, KS 67104-0130 Bob . . . ________________________________________________________________________________
Date: Dec 12, 2010
Subject: Noise from Garmin 496
I posted a message a few days ago and haven't seen one response. Question is, has anyone else found that their Garmin handheld with 30A weather antenna produces a periodic type "hiss" noise in their radios? Marty ________________________________________________________________________________
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Date: Dec 12, 2010
Subject: Re: Noise from Garmin 496
I get kind of a da-da-da-shhhh (repeat endlessly) from my 696. If I disable the DC-IN it goes away. It's a pretty low level background noise that I can live with. I've tried all kinds of filters and alternate grounds with some relief but it's still noticeable. The noise is there whenever the 696 is plugged in, whether its powered on or not. I assume it has something to do with the battery being charged/monitored. Dave Saylor AirCrafters 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell On Sun, Dec 12, 2010 at 7:21 AM, Marty wrote: > I posted a message a few days ago and haven't seen one response. Question > is, has anyone else found that their Garmin handheld with 30A weather > antenna produces a periodic type "hiss" noise in their radios? > Marty > > ________________________________________________________________________________
Date: Dec 12, 2010
Subject: Teflon Wire - 7 strands vs. 19 stands
I found some surplus M16878/4BGB1 wire. I think it is 20 AWG wire with teflon insulation and coated copper conductors. It is made of 7 strands of wire. I know that newer wire is made of up 19 strands. Will the 7 strand wire "work" with crimp connections such as AMP FastOn and crimped D-sub pins? Thanks for any info, dave gribble ________________________________________________________________________________
Date: Dec 12, 2010
Subject: Re: Teflon Wire - 7 strands vs. 19 stands
It will be very much less flexible than 19 strand wire, and so may break in service. Peter On 12/12/2010 18:35, dave.gribble(at)mchsi.com wrote: > --> AeroElectric-List message posted by: dave.gribble(at)mchsi.com > > I found some surplus M16878/4BGB1 wire. I think it is 20 AWG wire with teflon insulation and coated copper conductors. It is made of 7 strands of wire. I know that newer wire is made of up 19 strands. Will the 7 strand wire "work" with crimp connections such as AMP FastOn and crimped D-sub pins? > > Thanks for any info, > > dave gribble > > ________________________________________________________________________________
Date: Dec 12, 2010
At 12:35 PM 12/12/2010, you wrote: > >I found some surplus M16878/4BGB1 wire. I think it is 20 AWG wire >with teflon insulation and coated copper conductors. It is made of >7 strands of wire. I know that newer wire is made of up 19 >strands. Will the 7 strand wire "work" with crimp connections such >as AMP FastOn and crimped D-sub pins? See attached file for description of M16878 wires. Yes, you have a Type E (600v thin teflon) wire that will be 20AWG silver coated 7 strand copper. Teflon was never real popular as an airframe wire. It's not very tough although the temperature ratings are great. 7-strand wire is not a really big deal. A quintrillion vehicles including airplanes have be wired with 7-strand wire . . . and we don't seem to be hearing about the lack of vibration resistant stranding. If you got this wire cheap and you're thinking about using a lot of it (it could probably substitute for 22AWG in most applications, then it's probably a cost effective thing to do with no significant increase in risks. Bob . . . ________________________________________________________________________________
From: Bob McCallum <robert.mccallum2(at)sympatico.ca>
Date: Dec 12, 2010
Dave; Yes, it will "work" with respect to being properly secured by the various terminals/connectors etc. However, 19 strand is considerably more flexible and consequently more vibration resistant than 7 strand. Both may perform satisfactorily in your application but if there is flexing involved (vibration?) the finer stranding will last longer and will impart lower loads on the devices to which it is attached. Gauge for gauge its fatigue resistance will be greater and mechanical forces transmitted less. This is the reason Bob recommends "welding cable" for fat wires due to its extremely fine stranding and hence greater flexibility. (Having said all that the fatigue resistance of the 7 strand may exceed the life of the airframe, but regardless the 19 strand will outlast it from an apples to apples fatigue standpoint) Bob McC > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list- > server(at)matronics.com] On Behalf Of dave.gribble(at)mchsi.com > Sent: Sunday, December 12, 2010 1:36 PM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Teflon Wire - 7 strands vs. 19 stands > > > I found some surplus M16878/4BGB1 wire. I think it is 20 AWG wire with teflon > insulation and coated copper conductors. It is made of 7 strands of wire. I know that > newer wire is made of up 19 strands. Will the 7 strand wire "work" with crimp > connections such as AMP FastOn and crimped D-sub pins? > > Thanks for any info, > > dave gribble > > _- > ==================================================== > ====== > _- > ==================================================== > ====== > _- > ==================================================== > ====== > _- > ==================================================== > ====== > > ________________________________________________________________________________
Date: Dec 12, 2010
Thanks Bob - great reply.. but I'm confused about why the 20AWG Teflon wire "could substitute for 22AWG in most applications" dave ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Sent: Sunday, December 12, 2010 3:30:21 PM GMT -06:00 US/Canada Central Subject: Re: AeroElectric-List: Teflon Wire - 7 strands vs. 19 stands At 12:35 PM 12/12/2010, you wrote: > >I found some surplus M16878/4BGB1 wire. I think it is 20 AWG wire >with teflon insulation and coated copper conductors. It is made of >7 strands of wire. I know that newer wire is made of up 19 >strands. Will the 7 strand wire "work" with crimp connections such >as AMP FastOn and crimped D-sub pins? See attached file for description of M16878 wires. Yes, you have a Type E (600v thin teflon) wire that will be 20AWG silver coated 7 strand copper. Teflon was never real popular as an airframe wire. It's not very tough although the temperature ratings are great. 7-strand wire is not a really big deal. A quintrillion vehicles including airplanes have be wired with 7-strand wire . . . and we don't seem to be hearing about the lack of vibration resistant stranding. If you got this wire cheap and you're thinking about using a lot of it (it could probably substitute for 22AWG in most applications, then it's probably a cost effective thing to do with no significant increase in risks. Bob . . . ________________________________________________________________________________
Date: Dec 12, 2010
I have a 496 with weather, mounted just above the comm radio. No hiss. Power is through the external cable to the main bus. Kevin ----- Original Message ----- From: Marty To: Aeroelectric-List Sent: Sunday, December 12, 2010 7:21 AM Subject: AeroElectric-List: Noise from Garmin 496 I posted a message a few days ago and haven't seen one response. Question is, has anyone else found that their Garmin handheld with 30A weather antenna produces a periodic type "hiss" noise in their radios? Marty ________________________________________________________________________________
Date: Dec 12, 2010
At 03:58 PM 12/12/2010, you wrote: > >Thanks Bob - great reply.. but I'm confused about why the 20AWG >Teflon wire "could substitute for 22AWG in most applications" If you have a drawing that calls out 22AWG, then you either go out and buy some 22AWG or you consider substituting 20AWG assuming you don't mind taking the hit on weight (very small) and the wire will fit into all the crimped pins. In terms of footage, 22AWG wire is the most popular size in most airplanes. We did try 24AWG in the Premier . . . I think the techs on the line are used to it now but there was a lot of fuss at the beginning. It's more difficult to work with. I think I suggested to this List many years ago that builders buy full spools of 20AWG wire (1000'). It's cheaper in large quantities and can be used wherever the drawings call for 22 or 20AWG. This one size MIGHT account for 90% of all your wiring footage in a small airplane and ease your procurement task. Bob . . . ________________________________________________________________________________
Subject: Computing a Resistor Value
Date: Dec 12, 2010
I want to install my AV80R GPS in my panel and wire the power lead to the bus without installing a clunky cigarette power socket on my panel. The GPS input voltage is 5V and it draws 1.5A (at least that's what the cigarette power lead says on it). My buss voltage is 13.5V, so how do I compute the resistor ohm's and watts needed for my power lead? I know enough about Ohm's law to be dangerous. Thanks. -------- Al Rice Skybolt 260 RV-9A Helping with my grandson's Piet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323122#323122 ________________________________________________________________________________
Date: Dec 12, 2010
From: "Richard E. Tasker" <retasker(at)optonline.net>
Subject: Re: Computing a Resistor Value
Just adding a resistor is probably not a good idea. A resistor drops a variable amount of voltage depending on the actual current consumption. Additionally, your bus voltage will vary from 12V or less when the alternator is off to as much as 14.2V when it is on. Unless the AV80R draws a constant current (unlikely) and can handle a relatively wide voltage input, you really do need to use the power cord or some other source of 5V. I couldn't find a manual to see what voltage it can handle, but given they sell adapters for 12/24VDC and for 110/220VAC, it is likely that it can use only a limited voltage (5V). The markings on the adapter almost surely refer to the adapter capacity, not the exact consumption of the AV80R. For educational purposes, assuming that the AV80R actually did take exactly 1.5A at 5V and your buss voltage was a constant 13.5V, you would calculate the resistor value as follows: The resistor would have to drop 13.5V minus 5V or 8.5V at 1.5A. Since V=I*R or R=V/I, then R = 8.5V/1.5A or 5.666 ohms which is close to a standard 5.6 ohm resistor. If we used that resistor we would actually get 8.4V drop which gives us 5.1V for the AV80R which would probably be close enough. The power dissipated in the resistor would be P=V*I or 8.4V*1.5A = 12.6W which would mean it would have to be a pretty large wirewound ceramic resistor that would get mighty hot. Of course, all this is based on the paragraph above this one, which is highly unlikely. You can either find a 12V to 5V power converter to include behind the panel or just use the optional cigarette lighter adapter provided by Honeywell. Dick Tasker AlRice wrote: > --> AeroElectric-List message posted by: "AlRice" > > I want to install my AV80R GPS in my panel and wire the power lead to the bus without installing a clunky cigarette power socket on my panel. The GPS input voltage is 5V and it draws 1.5A (at least that's what the cigarette power lead says on it). My buss voltage is 13.5V, so how do I compute the resistor ohm's and watts needed for my power lead? I know enough about Ohm's law to be dangerous. > Thanks. > > -------- > Al Rice > Skybolt 260 > RV-9A > Helping with my grandson's Piet > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=323122#323122 > > > -- Please Note: No trees were destroyed in the sending of this message. We do concede, however, that a significant number of electrons may have been temporarily inconvenienced. -- ________________________________________________________________________________
Date: Dec 13, 2010
Good Morning Al, I am sure you know more about Ohm's Law than I do, but why don't you consider using a Zener Diode? If you use a resistor, the voltage output will change as the load changes. I have no idea whether or not the load does change during operation of the AV80R but dropping resistors do not work well at all with a varying load. Happy Skies, Old Bob In a message dated 12/12/2010 8:05:24 P.M. Central Standard Time, Allen(at)allenrice.net writes: --> AeroElectric-List message posted by: "Al Rice" I want to install my AV 80 R GPS in my panel and wire the power lead to the bus without installing a clunky cigarette power socket on my panel. The GPS input voltage is 5 V and it draws 1.5A (at least that's what the cigarette power lead says on it). My buss voltage is 13.5V, so how do I compute the resistor ohm's and watts needed for my power lead? I know enough about Ohm's law to be dangerous. Thanks. -------- Al Rice Sky bolt 260 RV-9 A Helping with my grandson's Pi et ________________________________________________________________________________
Date: Dec 12, 2010
At 07:59 PM 12/12/2010, you wrote: > >I want to install my AV80R GPS in my panel and wire the power lead >to the bus without installing a clunky cigarette power socket on my >panel. The GPS input voltage is 5V and it draws 1.5A (at least >that's what the cigarette power lead says on it). My buss voltage >is 13.5V, so how do I compute the resistor ohm's and watts needed >for my power lead? I know enough about Ohm's law to be dangerous. And indeed, a total reliance on Ohm's law in this instance would be very hard if not dangerous to the GPS. You need to acquire the automotive power adapter suited for using/charging this product in the car . . . then adapt that same device to the airplane. I see that the advertising literature speaks of a USB/PC cable. Check the instruction manual to see if connection of the GPS to a powered up PC will also charge the battery. It may not . . . some USB ports on computers won't deliver 1.5A. If so, then there are dozens of "USB power adapters" designed to accept 14 volts from a vehicular power system and deliver the smooth, regulated 5v dc necessary for safe operation of the GPS. But accommodating the King automotive adapter cable in the airplane is THE 100% way to go. Bob . . . ________________________________________________________________________________
Date: Dec 13, 2010
Date: Dec 13, 2010
> The GPS input voltage is 5V and it draws 1.5A (at least that's what the >cigarette power lead says on it). My buss voltage is 13.5V=2C so how do I compute >the resistor ohm's and watts needed for my power lead?I know enough about >Ohm's law to be dangerous. > Thanks. > -------- > Al Rice Mornin' Al=2C When I first read your post=2C I didn't think the resistor was the way to go=2C either=2C same as Dick Tasker described. My thinking was you're asking quite a bit f rom just one resistor. My initial thought was "why not build a 5 volt circuit" (like this one)? http://www.tkk.fi/Misc/Electronics/circuits/psu_5v.html Recently=2C I asked this forum if they knew how I could turn my Ray Allen servo resistance output (0-5K ohms) into a visual LED indicator. Our buddy Joe Gores offere d the perfect suggestion of a circuit referenced from Mike Linse. Included in his suggestion was that really handy 5 volt circuit above=2C plus it is super easy to build. The circuit had a final voltage output of 4.96 volts=2C and when combined w ith the circuit Mike Linse talked about=2C the whole project worked exactly as I was hoping for. From the article's data points about this 5 volt circuit=2C it says it ma y be limited to only one amp=2C plus you should consider a heat sink. So I got to thinking..... .... Here's a question for for you guys that rearrange electrons for a living. ....could a guy build TWO of these 5 volt circuits=2C and combine the '5 volt output' in pa rallel? Mike Welch ________________________________________________________________________________
Date: Dec 13, 2010
Thanks for the advice everyone. I learned a lot with this thread. I guess I'll stick with the cigarette adapter and mount the socket behind the panel where I can't see the ugly thing. -------- Al Rice Skybolt 260 RV-9A Helping with my grandson's Piet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323176#323176 ________________________________________________________________________________
Date: Dec 13, 2010
Al, The rating on the 5 volt adaptor is what it is capable of, not necessarily what the GPS uses. There are options: 1. Like everyone is saying, using a resistor by itself is a bad idea. 2. A resistor and a 5 volt zener diode. Without knowing the current requirements of the GPS, it will be trial and error. 7 ohms, 10W would be a starting point. 3. You could build the 5v regulator circuit suggested by Mike Welch. A 7805 in a TO-220 case bolted to the airframe and using thermal conductive paste. 4. Take apart the OEM adaptor and solder wires to it and connect to the aircraft power. 5. Buy one of these: http://www.mouser.com/ProductDetail/Murata-Power-Solutions/78SRH-5-2-C/?qs=35WhQNrE6p2lJ6BniHrImQ%3d%3d Probably generates less heat than other options. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323181#323181 ________________________________________________________________________________
Subject: "Regulated" 12 v supply
Date: Dec 13, 2010
I have a video camera on my tailwheel so that I can see under the nose of my plane when taxiing. The camera calls for a "regulated" 12v, (+ or - 10%) power supply. Will a 12v inline zener diode do the job, or do I not understand how zeners work? Thanks, John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323192#323192 ________________________________________________________________________________
Date: Dec 13, 2010
Subject: Re: "Regulated" 12 v supply
At 12:20 PM 12/13/2010, you wrote: > >I have a video camera on my tailwheel so that I can see under the >nose of my plane when taxiing. The camera calls for a "regulated" >12v, (+ or - 10%) power supply. > >Will a 12v inline zener diode do the job, or do I not understand how >zeners work? A zener works like a "smart weight" on the end of a spring. Suppose you hung a kid's swing from the ceiling on a bungee cord and with nobody in the swing, it was 3' off the floor. For the kid's safety, you want them to enjoy the swing at an altitude of 12 +/- 1 inches off the floor. Suppose the heaviest 50# kid caused the swing to assume an altitude of 16" . . . you would need to ADD weight to achieve the desired altitude. Suppose further that the lightest 30# kid pulls the swing down to 24" off the floor. Obviously, still more weight needs to be added to achieve the 12" target. 24-16 The spring rate for this example is ------ = .40 inches/lb 50-30 So added weight need to lower the altitude with the 50# kid by 4 inches is 4/.4 or 10 pounds. Added weight for the 30# kid needs to lower the swing an additional 12 inches is 12/.4 or 30 pounds. Finally, you want the swing to hang at 12" for everyone to get into our out of the swing. This means that while the swing is completely unloaded, the greatest compensating weight would have to be applied and then adjusted downward quickly and smoothly as the passenger gets into or out of the swing. The study above says a total weight of 60 pounds will hold the empty swing at the right "altitude". Okay, our zener is a "smart weight". The bungee is replaced with a resistor (R). The range of swing customers have a "weight" of 30 to 50 millamperes. The target "swinging height" or Vout of 5 volts. Emacs! Obviously, we must hang from a ceiling greater than 5 volts . . . for the purposes of this study, let's call it a Vin of 12 volts. So we need a constant differential or "drop" of 7 volts in our resistor. Let's set up the resistor so that the swing is capable of carrying passengers just above the largest anticipated demand . . . 60 mA. 8V drop at 60 mA calls for a resistor of R = 8v/.06a = 133 ohms. Our "smart weight" is a zener diode operating at 5.1 volts above the floor. Further, with no passengers in the swing, the zener needs to dissipate a total power value of 5.1v x .06 amps = 300 milliwatts. So a 500 mW or larger zener will suffice. The resistor has a constant 8v drop across it at the .06A so it dissipates worst case: 8v x .06A = .48W I'd go for a 1W resistor to run cooler. Now, with the "smart weight" maintaining 5.1 volts off the floor, any load of 0 up to and including 0.06 amps can be connected across the zener with an expectation that the 5.1 volt value will be maintained. This example is probably in the neighborhood of a best case for using a zener supply. Total power being dumped in the components is maxed at 0.78W. If one were to design a similar architecture for a 1.5A supply, the wasted power goes up to 18 watts . . . really gets things hot unless provided with HEAVY heatsinks. The architecture of choice is to utilize one of the modern DC/DC converters that yield 90 plus percent efficiencies at all load levels. HOWEVER, it's not a free lunch. There can be terrible noise generators for adf and perhaps even VHF comm radios. So as a matter of normal practice, I ALWAYS close these critters up in metallic enclosures with input and output filters. You asked about a 12 volt source. Your input can be anything from 10 to 15 volts. So you need a buck-boost DC/DC converter that provides an output from a source that may be either above or below the output. How much current are we talking about? You might want to consider a set of alkaline cells and a toggle switch to turn the system on only when actively in use. I suspect a set of dedicated batteries would last a very long time. Bob . . . ________________________________________________________________________________
Date: Dec 14, 2010
Subject: 2010 List of Contributors
Dear Listers, The 2010 Matronics Email List and Forum Fund Raiser officially ended a couple of weeks ago and its time that I publish this year's List of Contributors. Its the people on this list that directly make the Email Lists and Forums possible. Their generous contributions keep the servers and Internet connection up and running. You can still show your support this year and pick up a great gift at the same time. The Contribution Web Site is fast, easy, and secure: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I also want to thank Bob, Jon, and Andy for their generous support through the supply of great gifts this year!! These guys have some great products and I encourage you to visit their respective web sites: Bob Nucklolls - AeroElectric - www.aeroelectric.com Jon Croke - HomebuiltHELP - www.homebuilthelp.com Andy Gold - The Builder's Bookstore - www.buildersbooks.com And finally, I'm proud to present The 2010 Fund Raiser List of Contributors: http://www.matronics.com/loc/2010.html Thanks again to everyone that made a Contribution this year!! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Dec 14, 2010
First thing you want to do is build a solid state voltage regulator for a 5V output.IK can't remember the number on the chip but they are available at Radio Scrap. The back of the package has a usable schematic. Noel -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of AlRice Sent: December 12, 2010 10:30 PM Subject: AeroElectric-List: Computing a Resistor Value I want to install my AV80R GPS in my panel and wire the power lead to the bus without installing a clunky cigarette power socket on my panel. The GPS input voltage is 5V and it draws 1.5A (at least that's what the cigarette power lead says on it). My buss voltage is 13.5V, so how do I compute the resistor ohm's and watts needed for my power lead? I know enough about Ohm's law to be dangerous. Thanks. -------- Al Rice Skybolt 260 RV-9A Helping with my grandson's Piet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323122#323122 ________________________________________________________________________________
Date: Dec 14, 2010
Thanks to Kevin K and Dave S for their replies. Seems like some installations may have noise and others not. I'll try disconnecting the power line next visit to the airport, but we're "frozen" in here in Nashville TN. If that works, I suspect there is some "output" from my 496 that is generating the noise. Pulling the power input line, which also has the power outputs will give some clues that it is in the 496 output side versus perhaps the weather antenna. My GPS output signal is split into three (max per Garmin) to feed my Dynon D10A, Electronic International Fuel Totalizer, and the third device escapes me right now, perhaps its the EI SuperClock. I also feed the output to Garmin's SL30 radio to feed the com and nav frequencies, and the warnings to my Garmin Audio Panel. Waiting now for warmer weather to go do some testing! Thanks again folks for your thoughts. Marty N826ME RV-6A ________________________________________________________________________________
Date: Dec 14, 2010
Only problem with that is resistors don't drop voltage unless they are set up in a voltage divider network. They only restrict current. Don't believe me? Ok.... Try this; take a convenient battery and measure the voltage across the terminals. Then connect any resistor to one terminal of the voltmeter and take another reading. Guess what both readings will be the same! Now to check the current flow. Connect a nice hefty resistor to one terminal of the battery and using a suitable ammeter measure the current through the resistor. Then add a resistor to one terminal of the ammeter and read again.... The second reading will be less than the first one indicating the resistor has actually dropped the current. If you are unsure of the resistor sizes to try use a battery tester and a resistor to do this experiment. If you want to build a voltage divider network with two resistors then that is another ball of wax. The problem with that is the network loads your buss the whole time it is active and it will load your buss. A solid state voltage regulator on the other hand will also load your buss but to a much less degree. Early model 45 field radios used a voltage divider network to give low power capability to the transmitters. It wasn't long before operators noticed the batteries didn't last jig time if the transmitter was operated on low power mode. Noel -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Richard E. Tasker Sent: December 13, 2010 1:11 AM Subject: Re: AeroElectric-List: Computing a Resistor Value Just adding a resistor is probably not a good idea. A resistor drops a variable amount of voltage depending on the actual current consumption. Additionally, your bus voltage will vary from 12V or less when the alternator is off to as much as 14.2V when it is on. Unless the AV80R draws a constant current (unlikely) and can handle a relatively wide voltage input, you really do need to use the power cord or some other source of 5V. I couldn't find a manual to see what voltage it can handle, but given they sell adapters for 12/24VDC and for 110/220VAC, it is likely that it can use only a limited voltage (5V). The markings on the adapter almost surely refer to the adapter capacity, not the exact consumption of the AV80R. For educational purposes, assuming that the AV80R actually did take exactly 1.5A at 5V and your buss voltage was a constant 13.5V, you would calculate the resistor value as follows: The resistor would have to drop 13.5V minus 5V or 8.5V at 1.5A. Since V=I*R or R=V/I, then R = 8.5V/1.5A or 5.666 ohms which is close to a standard 5.6 ohm resistor. If we used that resistor we would actually get 8.4V drop which gives us 5.1V for the AV80R which would probably be close enough. The power dissipated in the resistor would be P=V*I or 8.4V*1.5A = 12.6W which would mean it would have to be a pretty large wirewound ceramic resistor that would get mighty hot. Of course, all this is based on the paragraph above this one, which is highly unlikely. You can either find a 12V to 5V power converter to include behind the panel or just use the optional cigarette lighter adapter provided by Honeywell. Dick Tasker AlRice wrote: > --> AeroElectric-List message posted by: "AlRice" > > I want to install my AV80R GPS in my panel and wire the power lead to the bus without installing a clunky cigarette power socket on my panel. The GPS input voltage is 5V and it draws 1.5A (at least that's what the cigarette power lead says on it). My buss voltage is 13.5V, so how do I compute the resistor ohm's and watts needed for my power lead? I know enough about Ohm's law to be dangerous. > Thanks. > > -------- > Al Rice > Skybolt 260 > RV-9A > Helping with my grandson's Piet > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=323122#323122 > > > -- Please Note: No trees were destroyed in the sending of this message. We do concede, however, that a significant number of electrons may have been temporarily inconvenienced. -- ________________________________________________________________________________
Date: Dec 14, 2010
Easier than disconnecting the power line, does it make the noise after it is fully charged? Some consumer devices with Li+ batteries have a habit of hammering the power line with noise while charging. It sounds like you have a lot of possible ground paths for the Garmin. Any of these can cause the charging return current to take an unwanted, roundabout path back to the battery. Additionally, if your audio output is single-ended (Audio+ to signal, Audio- to ground) large (by comparison) power currents can cause the unit to 'float' a bit from ground potential. When the power current varies, the 'floats' are cyclical, and you could hear it as noise. Hope that helps! --Daniel On Tue, Dec 14, 2010 at 9:50 AM, Marty wrote: > Thanks to Kevin K and Dave S for their replies. Seems like some > installations may have noise and others not. I'll try disconnecting the > power line next visit to the airport, but we're "frozen" in here in > Nashville TN. If that works, I suspect there is some "output" from my 496 > that is generating the noise. Pulling the power input line, which also has > the power outputs will give some clues that it is in the 496 output side > versus perhaps the weather antenna. > My GPS output signal is split into three (max per Garmin) to feed my Dynon > D10A, Electronic International Fuel Totalizer, and the third device escapes > me right now, perhaps its the EI SuperClock. I also feed the output to > Garmin's SL30 radio to feed the com and nav frequencies, and the warnings to > my Garmin Audio Panel. > Waiting now for warmer weather to go do some testing! Thanks again folks > for your thoughts. > Marty N826MERV-6A > > -- Daniel Hooper ________________________________________________________________________________
Date: Dec 14, 2010
Yes... but another answer would be to us a circuit with more current capability. Or possibly using the 7805 to switch a power transistor. Noel From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Mike Welch Sent: December 13, 2010 10:39 AM Subject: RE: AeroElectric-List: Computing a Resistor Value > The GPS input voltage is 5V and it draws 1.5A (at least that's what the >cigarette power lead says on it). My buss voltage is 13.5V, so how do I compute >the resistor ohm's and watts needed for my power lead?I know enough about >Ohm's law to be dangerous. > Thanks. > -------- > Al Rice Mornin' Al, When I first read your post, I didn't think the resistor was the way to go, either, same as Dick Tasker described. My thinking was you're asking quite a bit from just one resistor. My initial thought was "why not build a 5 volt circuit" (like this one)? http://www.tkk.fi/Misc/Electronics/circuits/psu_5v.html Recently, I asked this forum if they knew how I could turn my Ray Allen servo resistance output (0-5K ohms) into a visual LED indicator. Our buddy Joe Gores offered the perfect suggestion of a circuit referenced from Mike Linse. Included in his suggestion was that really handy 5 volt circuit above, plus it is super easy to build. The circuit had a final voltage output of 4.96 volts, and when combined with the circuit Mike Linse talked about, the whole project worked exactly as I was hoping for. From the article's data points about this 5 volt circuit, it says it may be limited to only one amp, plus you should consider a heat sink. So I got to thinking......... Here's a question for for you guys that rearrange electrons for a living.....could a guy build TWO of these 5 volt circuits, and combine the '5 volt output' in parallel? Mike Welch ________________________________________________________________________________
Date: Dec 14, 2010
At 09:12 AM 12/14/2010, you wrote: > >First thing you want to do is build a solid state voltage regulator for a 5V >output.IK can't remember the number on the chip but they are available at >Radio Scrap. >The back of the package has a usable schematic. This is also an option. The 3-terminal regulators are factory calibrated step-down voltage control devices. http://www.fairchildsemi.com/ds/LM/LM7805.pdf Unlike the "smart weight" I described earlier, these are more like "smart valves". Instead of working in PARALLEL with the output load, these work in SERIES. They have a distinct advantage for optimizing power dissipation (waste heat). As we studied in the Zener example, loads on the input power supply are constant irrespective of load demanded by the powered-up device. This is the least efficient means by which step down voltage tasks can be managed but they are SIMPLE. So you use them only in the smallest of situations were waste energy is not a significant design concern. The series-pass 3-terminal regulators will draw power from the supply that is only a few microamps more than the load demanded by the load. They are also easily adjusted. I used to offer a line of panel light dimmers based on 3-terminal devices. http://www.aeroelectric.com/Catalog/AEC/9013/ Note that the larger the anticipated loads, the larger the device AND it's associated heatsink. Now, if you don't mind taking the hit in terms of size, weight and disspated power, this technology offers a simple, low noise and relatively inexpensive means for acquiring a very high-quality (meaning low noise) DC power source for devices needing 9 volts and less. This 9-volt limitation is due to the need for 'headroom' in the difference between input and output voltages. If you want the device to deliver, say 12 volts constant output, the INPUT cannot be lower than about 13.5 volts. A 9v design goal for output can be achieved for inputs down to about 10.5 volts. Bob . . . >Noel > >-----Original Message----- >From: owner-aeroelectric-list-server(at)matronics.com >[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of AlRice >Sent: December 12, 2010 10:30 PM >To: aeroelectric-list(at)matronics.com >Subject: AeroElectric-List: Computing a Resistor Value > > >I want to install my AV80R GPS in my panel and wire the power lead to the >bus without installing a clunky cigarette power socket on my panel. The GPS >input voltage is 5V and it draws 1.5A (at least that's what the cigarette >power lead says on it). My buss voltage is 13.5V, so how do I compute the >resistor ohm's and watts needed for my power lead? I know enough about >Ohm's law to be dangerous. >Thanks. > >-------- >Al Rice >Skybolt 260 >RV-9A >Helping with my grandson's Piet > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=323122#323122 > > >----- >No virus found in this message. >Checked by AVG - www.avg.com Bob . . . ________________________________________________________________________________
Date: Dec 14, 2010
Mornin' Al, When I first read your post, I didn't think the resistor was the way to go, either, same as Dick Tasker described. My thinking was you're asking quite a bit from just one resistor. My initial thought was "why not build a 5 volt circuit" (like this one)? http://www.tkk.fi/Misc/Electronics/circuits/psu_5v.html Recently, I asked this forum if they knew how I could turn my Ray Allen servo resistance output (0-5K ohms) into a visual LED indicator. Our buddy Joe Gores offered the perfect suggestion of a circuit referenced from Mike Linse. Included in his suggestion was that really handy 5 volt circuit above, plus it is super easy to build. The circuit had a final voltage output of 4.96 volts, and when combined with the circuit Mike Linse talked about, the whole project worked exactly as I was hoping for. From the article's data points about this 5 volt circuit, it says it may be limited to only one amp, plus you should consider a heat sink. So I got to thinking......... Here's a question for for you guys that rearrange electrons for a living.....could a guy build TWO of these 5 volt circuits, and combine the '5 volt output' in parallel? Sure . . . or go to a bigger device. The 3-terminal regulators come in a range of sizes. The smallest are Emacs! 6 x 4 mm on a side, solder right to the board, and as you might expect, cannot dissipate much power. They're good for 100-500 mA max . . . but if your needs are small . . . At the other end of the spectrum, you can buy these guys Emacs! Rated for 5A and MUST be on a hefty heatsink. Furhter, one can built arrays of transistors on even heftier heatsinks perhaps cooled with fans. Emacs! I think the last time I built up something like this it was to craft a finely adjustable 50A, 28v load bank. There were 10 fat transistors on a big chunk of aluminum cooled with a fan. This rig was good for 1400 watts of room warming dissipation all controlled by a little piece of plastic Emacs! and a 1/2" diameter potentiometer. The point to be made here is that the series-pass, smart regulator can be crafted in just about any size and output voltage within ratings limits for the devices. Bob . . . ________________________________________________________________________________
Date: Dec 14, 2010
Bob Did you include a bunch of photos that Yahoo didn't like?? Just a wondering Dick In a message dated 12/14/2010 11:44:25 A.M. Central Standard Time, nuckolls.bob(at)aeroelectric.com writes: Mornin' Al, When I first read your post, I didn't think the resistor was the way to go, either, same as Dick Tasker described. My thinking was you're asking quite a bit from just one resistor. My initial thought was "why not build a 5 volt circuit" (like this one)? _http://www.tkk.fi/Misc/Electronics/circuits/psu_5v.html _ (http://www.tkk.fi/Misc/Electronics/circuits/psu_5v.html) Recently, I asked this forum if they knew how I could turn my Ray Allen servo resistance output (0-5K ohms) into a visual LED indicator. Our buddy Joe Gores offered the perfect suggestion of a circuit referenced from Mike Linse. Included in his suggestion was that really handy 5 volt circuit above, plus it is super easy to build. The circuit had a final voltage output of 4.96 volts, and when combined with the circuit Mike Linse talked about, the whole project worked exactly as I was hoping for. >From the article's data points about this 5 volt circuit, it says it may be limited to only one amp, plus you should consider a heat sink. So I got to thinking......... Here's a question for for you guys that rearrange electrons for a living.....could a guy build TWO of these 5 volt circuits, and combine the '5 volt output' in parallel? Sure . . . or go to a bigger device. The 3-terminal regulators come in a range of sizes. The smallest are 6 x 4 mm on a side, solder right to the board, and as you might expect, cannot dissipate much power. They're good for 100-500 mA max . . . but if your needs are small . . . At the other end of the spectrum, you can buy these guys Rated for 5A and MUST be on a hefty heatsink. Furhter, one can built arrays of transistors on even heftier heatsinks perhaps cooled with fans. I think the last time I built up something like this it was to craft a finely adjustable 50A, 28v load bank. There were 10 fat transistors on a big chunk of aluminum cooled with a fan. This rig was good for 1400 watts of room warming dissipation all controlled by a little piece of plastic and a 1/2" diameter potentiometer. The point to be made here is that the series-pass, smart regulator can be crafted in just about any size and output voltage within ratings limits for the devices. Bob . . . ________________________________________________________________________________
Date: Dec 14, 2010
So, like I said, I chickened out and decided to use the car charger unit that came with the AV80R. I was able to pry the case apart and inside was a 1"x1" 12v-5v DC to DC power converter. I cut off the leads to the outside contacts and soldered on longer leads. For a case for the power converter, I simply used the existing one and routed the leads out the nose to a Molex plug. I'll secure the case behind the panel with an Adel clamp. Here is what it looks like. -------- Al Rice Skybolt 260 RV-9A Helping with my grandson's Piet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323386#323386 Attachments: http://forums.matronics.com//files/img_0001_533.jpg ________________________________________________________________________________
Date: Dec 14, 2010
At 11:50 AM 12/14/2010, you wrote: >Bob >Did you include a bunch of photos that Yahoo didn't like?? >Just a wondering >Dick > I guess I don't understand the question. Are you having trouble seeing the images? You echoed the posting back to me and they all appear as I originally sent them. Bob . . . ________________________________________________________________________________
Date: Dec 14, 2010
All I got was blanks where a photo was supposed to be aka Blanks Dick In a message dated 12/14/2010 9:35:34 P.M. Central Standard Time, nuckolls.bob(at)aeroelectric.com writes: At 11:50 AM 12/14/2010, you wrote: Bob Did you include a bunch of photos that Yahoo didn't like?? Just a wondering Dick I guess I don't understand the question. Are you having trouble seeing the images? You echoed the posting back to me and they all appear as I originally sent them. Bob . . . (http://www.aeroelectric.com/) (http://www.buildersbooks.com/) (http://www.homebuilthelp.com/) (http://www.matronics.com/contribution) (http://www.matronics.com/Navigator?AeroElectric-List) ________________________________________________________________________________
Date: Dec 15, 2010
Ok, Thanks, This is the only E-Mail this has happened on. So I'll try to access it thru the group site Thanks Dick In a message dated 12/14/2010 11:42:06 P.M. Central Standard Time, robert.mccallum2(at)sympatico.ca writes: Dick; All of the pictures in both Bob=99s original and your reply to him w orked fine for me. No blanks. Must have something to do with your computer settings. Bob McC DO NOT ARCHIVE ____________________________________ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of RGent12 24(at)aol.com Sent: Tuesday, December 14, 2010 11:44 PM Subject: Re: AeroElectric-List: Computing a Resistor Value All I got was blanks where a photo was supposed to be aka Blanks Dick In a message dated 12/14/2010 9:35:34 P.M. Central Standard Time, nuckolls.bob(at)aeroelectric.com writes: At 11:50 AM 12/14/2010, you wrote: Bob Did you include a bunch of photos that Yahoo didn't like?? Just a wondering Dick I guess I don't understand the question. Are you having trouble seeing the images? You echoed the posting back to me and they all appear as I originally sent them. Bob . . . tp://www.aeroelectric.com/">www.aeroelectric.com / href="http://www.buildersbooks.com/">www.buildersbooks.com http://www.homebuilthelp.com/">www.homebuilthelp.com p://www.matronics.com/contribution">http://www.matronics.com/contribution ist href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.ma tronics.com/Navigator?AeroElectric-List s.matronics.com/">http://forums.matronics.com -- Please Support Your Lists This Month -- (And Get Some AWESOME FREE Gifts!) November is the Annual List Fund Raiser. Click on this year's Terrific Free Incentive Gifts provided * AeroElectric _www.aeroelectric.com_ (http://www.aeroelectric.com/) * The Builder's Bookstore _www.buildersbooks.com_ (http://www.buildersbooks.com/) * HomebuiltHELP _www.homebuilthelp.com_ (http://www.homebuilthelp.com/) List Contribution Web Site: --> _http://www.matronics.com/contribution_ (http://www.matronics.com/contribution) Thank you for your generous support! -Matt Dralle, List Admin. - The AeroElectric-List Email Forum - --> _http://www.matronics.com/Navigator?AeroElectric-List_ (http://www.matronics.com/Navigator?AeroElectric-List) - MATRONICS WEB FORUMS - www.aeroelectric.com lp.com_ _http://www.matronics.com/contribution_ (http://www.matronics.com/contribut ion) ail Forum List Day _http://www.matronics.com/Navigator?AeroElectric-List_ ________________________________________________________________________________
Subject: pictures not showing up
Date: Dec 15, 2010
>All I got was blanks where a photo was supposed to be are Blanks. >Dick Dick=2C Bob's pictures showed fine for me=2C but I do know what you are referring to=2C though. My step-father sends me lots of 'patriotic=2C political=2C holidays=2C etc. emails that he forwards on to me. Some of them (maybe 10%) only have blank squares for pictures. I 'right click' on the picture=2C then choose "show picture". Sometimes =2C but not always=2C this works=2C and then the picture starts coming in. Hope this helps=2C Mike Welch ________________________________________________________________________________
Date: Dec 15, 2010
Daniel, Thanks for your thoughts. The 496 is mounted in the panel and the Li+ batteries are always being charged by ships power when running. I've never known the batteries not to be charged, but that is something to be experimented with. The Audio output may be single ended, I'll have to get the diagrams out to find out ( I do think they are single ended) but if the batteries are charged it would seem the charging currents would be small. I do have all devices in the panel going to a single point ground on the firewall. Marty ______ Subject: Re: AeroElectric-List: Noise from Garmin 496 From: Daniel Hooper <enginerdy(at)gmail.com> Easier than disconnecting the power line, does it make the noise after it is fully charged? Some consumer devices with Li+ batteries have a habit of hammering the power line with noise while charging. It sounds like you have a lot of possible ground paths for the Garmin. Any of these can cause the charging return current to take an unwanted, roundabout path back to the battery. Additionally, if your audio output is single-ended (Audio+ to signal, Audio- to ground) large (by comparison) power currents can cause the unit to 'float' a bit from ground potential. When the power current varies, the 'floats' are cyclical, and you could hear it as noise. Hope that helps! --Daniel On Tue, Dec 14, 2010 at 9:50 AM, Marty wrote: > Thanks to Kevin K and Dave S for their replies. Seems like some > installations may have noise and others not. I'll try disconnecting the > power line next visit to the airport, but we're "frozen" in here in > Nashville TN. If that works, I suspect there is some "output" from my 496 > that is generating the noise. Pulling the power input line, which also has > the power outputs will give some clues that it is in the 496 output side > versus perhaps the weather antenna. > My GPS output signal is split into three (max per Garmin) to feed my Dynon > D10A, Electronic International Fuel Totalizer, and the third device escapes > me right now, perhaps its the EI SuperClock. I also feed the output to > Garmin's SL30 radio to feed the com and nav frequencies, and the warnings to > my Garmin Audio Panel. > Waiting now for warmer weather to go do some testing! Thanks again folks > for your thoughts. > Marty N826MERV-6A > > -- Daniel Hooper ________________________________________________________________________________
Date: Dec 15, 2010
Bob, >From your analogy, I'm not sure if I should get a Johnny-Jump-Up or a DC/DC converter. :) > I suspect a set of dedicated batteries would > last a very long time. > The camera uses Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323448#323448 ________________________________________________________________________________
Date: Dec 15, 2010
Subject: Greatest OBAM aircraft achievement in history?
I was digging around in my mini-museum of vintage electronics looking for a part to photograph and ran across this item: Emacs! It was 24 years ago yesterday that the largest, heaviest, most fragile, aerodynamically unstable, and highest risk owner built and maintained aircraft departed Edwards for what is probably the greatest achievement in the history of OBAM aviation. I was privileged to be a part of this effort. B&C LR-1 regulators were in service during the close circuit shake-down. LR-2 regulators were installed for the Around the World Flight. I think their serial numbers were perhaps under 25. It has been a humbling thought that the folks in the Rutan Skunk Werks bolted our work-product to this high-risk airplane with no questions that I can recall about failure mode effects analysis, reliability studies, DO-160 testing, parts de-rating, post-production screening, mil-standard components, assembly personnel training and certification, quality assurance manuals, membership in the club of ISO elites, etc, etc . . . Had those regulators been crafted and delivered to modern notions of "aviation quality", they would have probably cost $25,000 each. The regulators we shipped were the same configuration of work product that went out the door to mounted on a LongEz and cost the guy $225. What's more, it was just a few weeks earlier that the LR-2 replaced LR-1 after we discovered some unhappy qualities in LR-1s. I believe that nobody was happier to see that airplane safely back on the ground as I. Something profound that happens to individuals who take on tasks like this. Had those regulators been $25,000 each and the mission had failed due to regulator failure, no doubt there would be plenty of places to hang blame. The post-mission de-briefing would assert some "system failure." When 4 or 5 folks hammered out parts in a Butler building in Bill's back yard, places to hang blame are limited. No system in which to hide. Very few folks in today's world are even aware of nor do they have an appreciation for what the Voyager program represented. It was conceived, built and completed a successful mission with the same top-to-bottom management philosophy that produced a host of airplanes that range from Blackbirds http://en.wikipedia.org/wiki/Skunk_Works http://en.wikipedia.org/wiki/Clarence_Johnson down to C-140s, Bonanza, PA-12, etc http://en.wikipedia.org/wiki/Beechcraft http://en.wikipedia.org/wiki/Cessna http://en.wikipedia.org/wiki/Piper_aircraft Voyager may have been the very last of such success stories. The last vestiges of this recipe for success has all but disappeared from institutionally produced aviation. But it hasn't completely expired. It's still happening in the shops and hangars of thousand of OBAM aircraft enthusiasts all over the world. Yeah, there's uncle Burt's space flight program . . . another example of how a capable, closely knit and bureaucracy free program can bring new recipes for success into the history of human achievements. Those achievements have little or no potential for "trickle_down" to the form of aviation that inspires us to design, build, maintain and fly products of our imagination just for the fun of it. Most individuals alive today have any concept of where all this began and how it evolved. If you told your next door neighbor that your RV parts were ordered from Walmart, there's a fair chance they'd believe it. When you show off your work-in-process . . . or you take anyone for a ride . . . see if you can plant some seeds of curiosity about the history and particularly the people who made it all happen. In particular, try to emphasize the fact the greatest things happened when unique individuals ignored those who were convinced, "that will never work." Bob . . . ________________________________________________________________________________
Subject: Battery Relay post too short
Date: Dec 15, 2010
On the out going post of the master relay I feed the start relay and the main bus feed. In the attached photo you can see with just the fat wire going to the start relay it takes up most of the room on the post. I know most of the Z-diagrams show both connected to the master relay. How do you guys get another lug on there? I could leave off the lock washer but then how do you keep it from coming loose? One guy told me I could remove the nut that snugs up against the relay, but to make sure the post does not turn, one could replace this with a shorter nut and get more room that way. Not sure I want to risk moving the internal part, might work for a while but this could cause unknown issues. More weight and parts but I guess I could connect the relay to a fat buss bar (maybe ANLs), then connect the start relay wire and the main bus feed wire to each. So please let me know how you others solved this issue. Thanks -------- Mike "Nemo" Elliott RV-8A QB (Fuselage) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323464#323464 Attachments: http://forums.matronics.com//files/battery_relay_post_135.jpg ________________________________________________________________________________
Subject: Vans RPM Transducer IE VTACHGEN 12
Date: Dec 15, 2010
... For a Lycoming IO-360 and a Dynon D180 the tach software setting is 4. I assume similar for other Dynon products. The Dynon has a left and right option. If you only have one VT, use the left wire. This setting jives perfectly with the Simpson display on my Plasma III. Be sure to smooth the crimp on the collar of the cable end going into the engine or it will catch on the casing and cause your RPM gauge to read like my old Ford Galaxy 500. After a lot of catching it will break. Glenn E. Long -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of longg(at)pjm.com Sent: Monday, September 27, 2010 10:37 AM Subject: RE: AeroElectric-List: Vans RPM Transducer IE VTACHGEN 12 Bob, I got their website from Van's, http://www.instrumentsales.com/ Vans could not give me any additional documentation. The website is rather limited. The way the Dynon doc reads is simply to set the pulses/revs to your particular equipment. I talked to Dynon and they admitted that this combination has been used before (and recommended because they don't sell an RPM transducer) but they do not document or support it directly. Yup, looks like a little experimenting is in order. I'll post my findings to Van's and the list as to make life a bit easier for others in the future. Thanks Glenn From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Friday, September 24, 2010 2:57 PM Subject: RE: AeroElectric-List: Vans RPM Transducer IE VTACHGEN 12 Seems like all the Van's folks use the EIS 4k, I'm using the Dynon 180 which is similar but different. What you're needing is the SCALE FACTOR for the transducer in pulses per revolution of the engine crankshaft. No doubt the setup instructions for the Dynon will tell you what calibration code or dip-switch setting to use for that particular transducer scale factor. Unless someone on the list has installed that combination of hardware items or incidental access to those two values you're going to have to do some legwork. Does the transducer have a brand and part number on it? Bob . . . ________________________________________________________________________________
From: "Bill Bradburry" <bbradburry(at)bellsouth.net>
Date: Dec 15, 2010
The nuts in that picture are reversed. The thicker nut should go on the outside. Bill B -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of rvg8tor Sent: Wednesday, December 15, 2010 3:15 PM Subject: AeroElectric-List: Battery Relay post too short On the out going post of the master relay I feed the start relay and the main bus feed. In the attached photo you can see with just the fat wire going to the start relay it takes up most of the room on the post. I know most of the Z-diagrams show both connected to the master relay. How do you guys get another lug on there? I could leave off the lock washer but then how do you keep it from coming loose? One guy told me I could remove the nut that snugs up against the relay, but to make sure the post does not turn, one could replace this with a shorter nut and get more room that way. Not sure I want to risk moving the internal part, might work for a while but this could cause unknown issues. More weight and parts but I guess I could connect the relay to a fat buss bar (maybe ANLs), then connect the start relay wire and the main bus feed wire to each. So please let me know how you others solved this issue. Thanks -------- Mike "Nemo" Elliott RV-8A QB (Fuselage) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323464#323464 Attachments: http://forums.matronics.com//files/battery_relay_post_135.jpg ________________________________________________________________________________
Subject: Re: Battery Relay post too short
Date: Dec 15, 2010
bbradburry(at)bellsouth.n wrote: > The nuts in that picture are reversed. The thicker nut should go on the > outside. > > Bill B > > -- Hmm, that is the way the relay shipped to me from Van's. Reversing the nut would not give me any more room on the post. -------- Mike "Nemo" Elliott RV-8A QB (Fuselage) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323476#323476 ________________________________________________________________________________
From: "Fisher Paul A." <FisherPaulA(at)johndeere.com>
Date: Dec 15, 2010
Cool souvenir Bob! I have a picture from an Oshkosh long ago of Burt Rutan sitting on the edge of his Defiant cockpit with his headset on taking note s. He was recording flight data from Voyager that was inbound to KOSH at t he time. You can't tell it from the picture, but soon after Voyager made a pass down the runway to the utter amazement of the crowd. Not as cool a s ouvenir as yours, but it is certainly a cherished memory of that beautiful plane. I agree this may have been the greatest, but I certainly hope it isn't the last OBAM achievement! Paul A. Fisher Q-200, N17PF RV-7A, N18PF From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectr ic-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Wednesday, December 15, 2010 12:43 Subject: AeroElectric-List: Greatest OBAM aircraft achievement in history? I was digging around in my mini-museum of vintage electronics looking for a part to photograph and ran across this item: It was 24 years ago yesterday that the largest, heaviest, most fragile, aer odynamically unstable, and highest risk owner built and maintained aircraft departed Edwards for what is probably the greatest achievement in the hist ory of OBAM aviation. I was privileged to be a part of this effort. B&C LR-1 regulators were in s ervice during the close circuit shake-down. LR-2 regulators were installed for the Around the World Flight. I think their serial numbers were perhaps under 25. It has been a humbling thought that the folks in the Rutan Skunk Werks bolted our work-product to this high-risk airplane with no questions that I can recall about failure mode effects analysis, reliability studies, DO-160 testing, parts de-rating, post-production screening, mil-standard c omponents, assembly personnel training and certification, quality assurance manuals, membership in the club of ISO elites, etc, etc . . . Had those regulators been crafted and delivered to modern notions of "aviat ion quality", they would have probably cost $25,000 each. The regulators we shipped were the same configuration of work product that went out the door to mounted on a LongEz and cost the guy $225. What's more, it was just a f ew weeks earlier that the LR-2 replaced LR-1 after we discovered some unhap py qualities in LR-1s. I believe that nobody was happier to see that airplane safely back on the g round as I. Something profound that happens to individuals who take on task s like this. Had those regulators been $25,000 each and the mission had fai led due to regulator failure, no doubt there would be plenty of places to h ang blame. The post-mission de-briefing would assert some "system failure." When 4 or 5 folks hammered out parts in a Butler building in Bill's back y ard, places to hang blame are limited. No system in which to hide. Very few folks in today's world are even aware of nor do they have an appre ciation for what the Voyager program represented. It was conceived, built a nd completed a successful mission with the same top-to-bottom management ph ilosophy that produced a host of airplanes that range from Blackbirds http://en.wikipedia.org/wiki/Skunk_Works http://en.wikipedia.org/wiki/Clarence_Johnson down to C-140s, Bonanza, PA-12, etc http://en.wikipedia.org/wiki/Beechcraft http://en.wikipedia.org/wiki/Cessna http://en.wikipedia.org/wiki/Piper_aircraft Voyager may have been the very last of such success stories. The last vesti ges of this recipe for success has all but disappeared from institutionally produced aviation. But it hasn't completely expired. It's still happening in the shops and hangars of thousand of OBAM aircraft enthusiasts all over the world. Yeah, there's uncle Burt's space flight program . . . another example of ho w a capable, closely knit and bureaucracy free program can bring new recipe s for success into the history of human achievements. Those achievements ha ve little or no potential for "trickle_down" to the form of aviation that i nspires us to design, build, maintain and fly products of our imagination j ust for the fun of it. Most individuals alive today have any concept of where all this began and h ow it evolved. If you told your next door neighbor that your RV parts were ordered from Walmart, there's a fair chance they'd believe it. When you sho w off your work-in-process . . . or you take anyone for a ride . . . see if you can plant some seeds of curiosity about the history and particularly t he people who made it all happen. In particular, try to emphasize the fact the greatest things happened when unique individuals ignored those who were convinced, "that will never work." Bob . . . ________________________________________________________________________________
Date: Dec 15, 2010
> bbradburry(at)bellsouth.n wrote: >> The nuts in that picture are reversed. The thicker nut should go on the >> outside. >> >> Bill B >> >> -- > > > Hmm, that is the way the relay shipped to me from Van's. Reversing the > nut would not give me any more room on the post. Yes it will, try it! Roger ________________________________________________________________________________
Date: Dec 15, 2010
At 04:40 PM 12/15/2010, you wrote: Cool souvenir Bob! I have a picture from an Oshkosh long ago of Burt Rutan sitting on the edge of his Defiant cockpit with his headset on taking notes. He was recording flight data from Voyager that was inbound to KOSH at the time. You can't tell it from the picture, but soon after Voyager made a pass down the runway to the utter amazement of the crowd. Not as cool a souvenir as yours, but it is certainly a cherished memory of that beautiful plane. I've never seen it fly. I was present at the 'official' roll-out party at Burt's Place. During a stroll down a really amazing flight line that I spotted the bones of the Beech Lightning languishing outside one of Burt's buildings. http://aeroelectric.com/Pictures/Misc/38P.jpg I think he got it as part of his "silver parachute" when he left Beech. Development testing of hardware for this airplane WOULD have put the first crowbar ov protection system on a TC aircraft. I agree this may have been the greatest, but I certainly hope it isn't the last OBAM achievement! Oh, certainly not the last. It would be interesting to talk to Burt, Mike, and all the original team to see what they see as possible OBAM aviation opportunities. Bob . . . ________________________________________________________________________________
Subject: RE: Intermittent Generator
Date: Dec 15, 2010
Hi Bob, Thanks for your reply about my one occurance of an intermittent alternator. I'll try your suggestions for troubleshooting. (By the way, it's an externally regulated 12 volt alternator with a B&C regulator.) Thanks, Dennis From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Subject: Re: AeroElectric-List: Intermittent Generator Problem Any ideas what caused this? Since the first symptom was reduced output and a whine in the headset, I initially suspected failed diodes inside the alternator, but when it healed itself, I thought it might have been a brush problem inside the alternator. Could be a grounding issue too . . . After 15 minutes, whatever was causing poor brush contact went away? I'm grasping at straws here. I am so thankful for Bob's Z 13-8 architecture, which allowed me to continue the flight without breaking a sweat! Thanks, Bob! Let's replace the 'straws' with data. What kind of alternator/regulator combination are you flying? If an externally regulated alternator, consider adding a temporary instrumentation wire with 1000 ohm resistor as close as possible to to the alternator's field terminal best. See: http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z22K_23K.pdf Get some cheepy volt-ohmeter to monitor voltage at the cockpit end of the wire in flight. An analog meter is best suited for this. This would be a good choice: http://www.radioshack.com/product/index.jsp?productId=2103957 Tape the meter up where you can watch it. Note the readings when the system is operating normally/ abnormally. Review the topic of Alternator Fault Isolation in chapter 3 of the 'Connection. Bob . . . ________________________________________________________________________________
Date: Dec 15, 2010
Two thin nuts would do it. Pax, Ed Holyoke On 12/15/2010 3:16 PM, Roger wrote: > > >> bbradburry(at)bellsouth.n wrote: >>> The nuts in that picture are reversed. The thicker nut should go on >>> the >>> outside. >>> >>> Bill B >>> >>> -- >> >> >> Hmm, that is the way the relay shipped to me from Van's. Reversing >> the nut would not give me any more room on the post. > > Yes it will, try it! > > Roger > > ________________________________________________________________________________
Date: Dec 16, 2010
> The following links and for that matter, the entire website is very interesting. The information and data clearly demonstrates how ineffective split lockwashers are and in some cases the bolt/joint is better WITHOUT the lockwasher. (Look at the graph). > http://www.boltscience.com/pages/vibloose.htm > http://www.boltscience.com/pages/hel...ingwashers.htm > AND the video..... > http://www.boltscience.com/pages/jun...ringwasher.htm > The above is a quote from Marty S. that was posted on VansAirforce. Split ring lock washers are not frequently used on aircraft because they do not always work. Nord-Lock washers are a much better choice. For the contactor post, you are better off using blue Loctite. Loctite will solve two problems: loosening and room for ring terminals. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323549#323549 ________________________________________________________________________________
Subject: Alternator Field Test Lead
Date: Dec 16, 2010
I'm trying to rig up the alternator field test lead recommended in note 8 of the "AeroElectric Connection." I have the resistor and the Radio Shack parts, but I'm not sure what goes into the Radio Shack 274-1573 plug. I need to mate the test leads from my muti-meter to that plug. What am I missing. a part number would help maybe. jb ________________________________________________________________________________
Subject: Unfamiliar Connector
Date: Dec 16, 2010
Does anyone know how to properly install this TED coaxial connector to the cable and the back of my King KT76A transponder? It looks like the cable comes into the connector at 90 deg and the center cable conductor gets soldered to the center pin. It also has a circlip and spring washer that looks like it is meant to retain the connector to the transponder case but there is no way to push the connector into the case far enough to slip the washer & circlip around the connector. This is my first transponder install. Thanks for the help. -------- Al Rice Skybolt 260 RV-9A Helping with my grandson's Piet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323577#323577 Attachments: http://forums.matronics.com//files/img_0001_194.jpg http://forums.matronics.com//files/tedconnector_198.jpg ________________________________________________________________________________
Subject:
Date: Dec 16, 2010
Folks; Been some discussion on pictures coming through. Bob N. just posted a picture. Here's what I see - be sure to see the Emacs! word. >From Bob: I was digging around in my mini-museum of vintage electronics looking for a part to photograph and ran across this item: Emacs! It was 24 years ago yesterday that the largest, heaviest, most fragile, aerodynamically unstable, and highest risk owner built and maintained aircraft departed Edwards for what is probably the greatest achievement in the history of OBAM aviation. This is what I always get unless someone sends an attachment. That's the only way I can see pictures. Don't have this problem on other groups - am I doing something wrong? Thanks In advance. -- Keith ________________________________________________________________________________
From: Bob McCallum <robert.mccallum2(at)sympatico.ca>
Subject: ectric-List:
Date: Dec 16, 2010
When I received this e-mail there was a photograph displayed where the word "emacs" is located. Have no idea what an "emacs" is but I see a photograph instead. I view my e-mails at work online and at home through Outlook and in both case the photos are always properly displayed so I don't think it h as anything to do with Matronics lists. Bob McC From: klburris(at)frontiernet.net Subject: AeroElectric-List: Date: Thu=2C 16 Dec 2010 11:42:45 -0700 Folks=3B Been some discussion on pictures coming through. Bob N. just posted a pictu re. Here's what I see - be sure to see the Emacs! word. From Bob: =93I was digging around in my mini-museum of vintage electronics looking for a part to photograph and ran across this item: Emacs! It was 24 years ago yesterday that the largest =2C heaviest=2C most fragile=2C aerodynamically unstable=2C and highe st risk owner built and maintained aircraft departed Edwards for what is probably the greatest achievement in the history of OBAM aviation .=94 This is what I always get unless someone sends an attachment.That's the on ly way I can see pictures. Don't have this problemon other groups - am I do ing something wrong? Thanks In advance. -- Keith /9j/4AAQSkZJRgABAgEASABIAAD/7QZAUGhvdG9zaG9wIDMuMAA4QklNA+0AAAAAABAASAAAAAEA AQBIAAAAAQABOEJJTQPzAAAAAAAIAAAAAAAAAAA4QklNBAoAAAAAAAEAADhCSU0nEAAAAAAACgAB AAAAAAAAAAI4QklNA/UAAAAAAEgAL2ZmAAEAbGZmAAYAAAAAAAEAL2ZmAAEAoZmaAAYAAAAAAAEA MgAAAAEAWgAAAAYAAAAAAAEANQAAAAEALQAAAAYAAAAAAAE4QklNA/gAAAAAAHAAAP////////// //////////////////8D6AAAAAD/////////////////////////////A+gAAAAA//////////// /////////////////wPoAAAAAP////////////////////////////8D6AAAOEJJTQQIAAAAAAAQ AAAAAQAAAkAAAAJAAAAAADhCSU0ECQAAAAAEzwAAAAEAAACAAAAAgAAAAYAAAMAAAAAEswAYAAH/ 2P/gABBKRklGAAECAQBIAEgAAP/+ACdGaWxlIHdyaXR0ZW4gYnkgQWRvYmUgUGhvdG9zaG9wqCA0 LjAA/+4ADkFkb2JlAGSAAAAAAf/bAIQADAgICAkIDAkJDBELCgsRFQ8MDA8VGBMTFRMTGBEMDAwM DAwRDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAENCwsNDg0QDg4QFA4ODhQUDg4ODhQRDAwM DAwREQwMDAwMDBEMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwM/8AAEQgAgACAAwEiAAIRAQMR Af/dAAQACP/EAT8AAAEFAQEBAQEBAAAAAAAAAAMAAQIEBQYHCAkKCwEAAQUBAQEBAQEAAAAAAAAA AQACAwQFBgcICQoLEAABBAEDAgQCBQcGCAUDDDMBAAIRAwQhEjEFQVFhEyJxgTIGFJGhsUIjJBVS wWIzNHKC0UMHJZJT8OHxY3M1FqKygyZEk1RkRcKjdDYX0lXiZfKzhMPTdePzRieUpIW0lcTU5PSl tcXV5fVWZnaGlqa2xtbm9jdHV2d3h5ent8fX5/cRAAICAQIEBAMEBQYHBwYFNQEAAhEDITESBEFR YXEiEwUygZEUobFCI8FS0fAzJGLhcoKSQ1MVY3M08SUGFqKygwcmNcLSRJNUoxdkRVU2dGXi8rOE w9N14/NGlKSFtJXE1OT0pbXF1eX1VmZ2hpamtsbW5vYnN0dXZ3eHl6e3x//aAAwDAQACEQMRAD8A 6/v5hJJLhPYlA/glwklMpKVolP3pp7p++iSldvNKR3+SRS8klK+SU+CRSSUrv5JSOEo7pT2SUpKN EpMeJSJSUr4pJdkvjykp/9Dr+QkJIShKQT8E9iUEvJJLVJStfmkPw8UvglOsH70lK+PCUd0hwl8U lK8kvhwEvNL4JKUSkEtOEklKjxS0S58vNIpKUlB+SUa6duUoSU//0evTd0/YjhL569k9iUUkktJ8 0lKSBKR5S5SUrRLVIeSY68d0lL9vimGif+KXkkpWiXhHzS4S1RUoifIJaBKdPJL4oKV5/elOmiXw SnXQpKf/0uv14SOqQ8PuSPMp7EpLulKRn5JKUkPvT88pu89+ySlJQAl/rCRjg/JJS3h+Cf8AIkkf E/gkpXKQ8kvuSmPJJStO6RSS/KkpXhPdJKfH5JJKf//T69LjQpf6yl+RPYlf6hLzSB/3JdklK8+3 glz/ABKSUapKVPilx/sSB8PklISUqNP70vxCRSSUrRJKI80vNJSu6RS5S0+SSlJcaH70pCUJKf/U 6/4JDwS+CXKexK+KRMJaz8Eo7JKV3SidTwkkQkpRPyS7pSEklK5SS8+6SSla8pJtDpx5J0lLaJz/ ALwl240SJhJSo1+HZL8qXmlqR8UlP//V67wP4JylH3pTrHfunsSkuPNL8vZLySUrlJNyU6SlJdpS Snx7d0lK158UvMfclyNO6XCSlHRIJfxSSUpIpJQkpQ1SS1kSkkp//9br5180pHZKUpjT8U9iVyUu 2iXxCWqSldvBJLTsUuP4pKV2SA/2Jo08E6SlTokEuNEklKmEkw5TwOUlK8kkvwKRSUqfx4TpkuNB 80lP/9kAOEJJTQQGAAAAAAAHAAMBAQABAQD//gAnRmlsZSB3cml0dGVuIGJ5IEFkb2JlIFBob3Rv c2hvcKggNC4wAP/uACFBZG9iZQBkAAAAAAEDABADAgMGAAAAAAAAAAAAAAAA/9sAhAAKBwcHCAcK CAgKDwoICg8SDQoKDRIUEBASEBAUEQwMDAwMDBEMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwM AQsMDBUTFSIYGCIUDg4OFBQODg4OFBEMDAwMDBERDAwMDAwMEQwMDAwMDAwMDAwMDAwMDAwMDAwM DAwMDAwMDAz/wgARCADIAMgDAREAAhEBAxEB/8QAfgABAQEBAAAAAAAAAAAAAAAAAAECBgEBAQEB AAAAAAAAAAAAAAAAAAECAxABAAICAwEBAQEAAAAAAAAAAQARECEgMDFBAkASEQACAgIDAAIDAQEB AQAAAAAAAREhMUEQUWFxgZGxwaEi0RISAQAAAAAAAAAAAAAAAAAAAJD/2gAMAwEBAhEDEQAAAO04 bikKQpAUCpAUgWyKigVIpAAi0iUJGqghQCpLRI1QkQpagiLUAtiWKZtsgBSAFJZcVpBbZIW1JAUk tsgKkUAVYlIKsRakBSLUliWkFtSSFKQUJFpKQQ1bItkgFlzVkWhDSySLQEUi2ySLbKQQKublLaRC iipAoJF0kUJGiAhVtSQi6QsQAFBEtsgUAlVGbLAaJUjVFkSyyLpIWWWRagWoIUiGrZIFIUEBSAAR aiFWWI1UgAW2SAsssKCUiipFJLbIWxLELbBJaKEhSQqxm2pVkNEEFIAqrIWJRKsikQ1UEC1JZZVi USrEKLEFhSBDVSBFWWFJZZYhS1IAW1IqRSQoEC1FJVJFJF0kqrJCwokCgKspIAWpIW1M22KkUhVS KlIIVFokW2CFiKKQFCS2xAAUgWpBVgKRFqRCikFIpEKC2wjNVEXVkEQq2ySLUW2SBRUS5soAgqgE isrtIW2QCLRcpYhVWSKCFAsSrZJSFBC0gpFIUEAWsy1FUzFAtSC25LCkiggi2S1FpIWFUhJdWQKC BAAUiKssKCWWJbYktslIUyUssspKQhq2TNagsSyxJpYWpKsSLUC25Z1LAUlJZZYUgssslosgKCFI hRZVkBf/2gAIAQIAAQUAIvB43Di8bhF6Hh84srh86Xh5wOZzewxVdD7wOm4YXsOIcXoHrM1Lx87L xeXFR5XHF4OFc71weB0OQzXI5PXUeV9dS49PvTeXIcnocXzqV03lOlw4Hk4vFYeF4ZXK++8Vyeyp XOudwjn501m8HH5kIPO8ByZXA4E+4cJ1+SuusXPnJ43yvJkzUqXfCs3moPVUeF8w7L4BisOK4h0P vQuXoWf/2gAIAQMAAQUAcMviS4RzeLyS4Rw8jqrorBmuFdd5DjWLw5cV1L0vReDvDFQxXKsuPMOa zfA51ip8hK76wOb43KzX8Liug51/EuayS+Rwrg9FcTsZceN8CXyqpfZXC+dxxfA7jFx7GEcGXB11 hyub4Xi+VcbxfKo8CVj5wDhWaycSLLwcXJkOgl8F5s8x8vi9t32LiulwcmGHi5vNcL5EOLxOFcDs qViv4nj/AP/aAAgBAQABBQB3KK1LQ9B1W2jF78XcQDTN17Bmr1CXvxdyitRN6nsps3EIaLl2hWKh GiVPJ+Xe0BlQExUPFZbELusUEFly9u4bKUZQMbpqqi1EE8w2zcQvSm4XGbt8giaxe/SmXEubC9XB uaJW2VcJ5DcLpLmiBu5VzUqEWNk1B2T6tRKgBNRqW3aSyNSyVPJphG5uqAra/wCf02Mrfsqi5Uqb H47hRPv6LN1shufKI3Wp4nhYlMZutT/NR8FuJA/UEZaT8q4tEblg6nylZRYjKouVLhcQs9+1Ladw dBSEux/WtRu0YVaNghY4ojsBuUXGfm5VwoKx7C4XL3Re58LiDA2rC6Ze/taKZQpo3PES/Z5HT+bp LGA0JPI7gVKqPjU3ZcQumWkvcqo6Ft+lrPmrqXoVjTEQuwhWKLUw3C61EH9O0d/arHsChuWQlaib u3CWWEYfkjUslVDzYlM+toanksSkbYT8iS9sWJZYRnsq5e/Y7n0bmgu1CCTxFtI7l7Z8hVexLnsq 5e7lkPPJWnR/ot3ELqaIm/I+/l3tAZThtKlXCowGts3gES7hNxahbAoqoeLqF2gwsX38ui2IkVq9 CsdzcJuVtdiP5GimDSgu7fal4qoeem4Lfj+q/RWoCYqXr40wuos/IxALt9gVKJtjcLpJRAl1Ny7H FXNxN6on27xtiteT6lyowtbh5RZdK4TdF1YXTU1VDNBdqEu4x9+XumJZu1pKW9Rj6TyAMaIaKKik fH8wd0T7dTUoi6LIeOzyXEZe7qaI1NRowWxodMNKtg0yy/Volq1csIOkYk8jcKnr+jXw1jTGKyiN 1qbsGUW0z75FpG0uErZH9UEaZdN3PIlxRh+ZqbcUWI4fV15LbTXgu9M3QrA38XXy0al0E+t2DVRQ dMfC1QzbZuOwNkbq2eRDNt//2gAIAQICBj8AHH//2gAIAQMCBj8AHH//2gAIAQEBBj8AgghaIm++ MV2SSTJ50KLfRBHRR72RtEQekkpnnQot9EEELQoO+M0j4zx5xmHonJ6Si8mInohueHV9jimS/sp/ BesnpKLIIxw+uJmOz9Mt4EnXF0U4fEiapHpD3xPHpZWeJIWuLJRk/hGOLvo9McTMwJf5x2UuJyie f0KL7P4XkvJ6hLb1x+idk9FZ0Xksqy983ronTJR/rI0ecOiiyrP0OWT+CGRvQuxlCT3sUX2eFuij 9HyOcOyPwVh5Ksh48P8A562y6XZCr1CTyubK5yfI4wfBR+xfoon/AAUWtkf6LtFYGlbREcJ9Hmyh w76KI2LTRP5Jgg+eK+yiUeo7PCinHFqCe+HBOiNEaPT50Mtyxfvj0rJKqMk6I+zwrGx9PBDJeRQf sgvHHR/Bel/klOUyfwf+jjOkTt6474slYZ6RsSX2JHheDw8If0Q8n9Ieez4ou+jMHnRCZ7zWGTsZ Z1xTzwl3sjmBp/SJxx0YJVsT70WRw5Vd8x3hkTZOyetmbRZGivxxiCMoTj5LVlkdEJiivSHxars9 I2eMnZ4uPMnjHcJHq4umXZSlH8JQp/wgcX4yH+Sl9kHpGzx8TscqCSVokh0fOSiUUdvUmBa4hokp Vxk9RD+nxOxyoFURxD/PMvAl2Qvsnok+T4IL2Or7HFMl/YiCETvjqD+kPPZaI09lE95RZGirIJeh PRZKeSxVMiQiMEZIMQxMzkuuOjJEkcQj1Ek5Jynoql4Rh8fI4/HGBw+LP6eHfhDtekdEJl6yekov JOxdmMcUy/s7POz9Dl4JOhrehVfRkjOy8E7RKsspfZZTh9nRK4/0fR1HDKV9FcRkrAv2OVSwyZ4n D4rPXGaIzGxXZDyhTkr74+clEorifwK/khZEiE4YkQSvtMkU/nifwLfZ/CcPZWNkTPpZGxLbIE5t E/k84Z/zsmP+iXo7TPT0iD+FOCBn/JLJMcOU0xtk/jh96PdlEL8EYKox9n7Q+lokrBB8kkZIwQqY qvZiyehzoS6O+ysc5Op4XWyNEFmIjfMqhmJ8I+hdbLxw7nwV42UZyekY7PETB8E6JWDw/pEEctYj RVwTEEjg8I/0hI92T3ji8HjIbvs9QlviFkTxGUdrYqzgsnKeD0vJi9lYITtlo8Z2tirOCycp4P/Z R0lGODlhWAI8ANX/AP+ZM/9mAMzMM8yZZsyZM8yZAMxmZsxmM8xmAMwzM8wzAMDAwJmZZpmZM5mZ AJlmZplmM5lmAJkzZpkzM5kzAJkAAGZmZmZmM2ZmAGYzZmYzM2YzAGYAADNmMzMzMzMzADMAMzMA AAAzAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH5BAEAAAsALAAAAABYAjwAQAb/wIVw SCwaj0hh4PFIOp/QqHRKrVqv2Kx2y+16v+CweEwum0foywVigajfl8ca/pbT7+/DW3Ph3+V2eG5q gYN0g2yGcXN4go11i42Kaol/jHSBj5qElpKQlI5rbXByk5aZoIqAj26ti6aIo5ibd6azqHCGhaGV kLakl7OQuG+TvcC2xJq/xYeyyHjKrJurnpygtZTPx6+0zZrVF2jjIw8Wn3cWTBQIEe7vFPEUEfPv CBQAEQjt7+788PLcVVDjp8+bZ3AQYrLlhg8Ec4P8nNNwTtsyQhDcVGT08BefBxAy1HkoxyHITBuv FdTkh9tBZmrU6crER6TBiARF0QIEgY+F/5VxWrWRkxKkzaBMbkLMeWHiRjbeWiqMCbMpSIJXKTKt 46cgVG/m0NGRuSfo0ZMl1yw1WFFkRTZAr+Ihm9PoSJAtHxQ82XCiTlpSbU3dRDfoR7nA1PYMJo5c uY2Z3ClwV4+eP3sFDhAgMJlfhQIQIhygHGHAAQcQEDgoEKEzhAMcPHyQTduDBtt9ftZdHHN34j6Z ThpkqjuhK4N4m/4ZJPzt1uFyVeVs8zYrZEZAMVX8KD0dJb3I4QA9lwHu2ONebxpK2dRPoOJMo5N6 OHw4fKrYwW0P+juhNveNDHVTI6U8F8d10aAnHkbYYGSOT/YVtF9SFdmhkYJl8bfGSu4xl/8hNPVF M+Ev9zVF33BHqRXJSISAZ5xjI1CS0VjK8VOAappBQAACN+pDwGjzyMPPPhEQUEADBOhjmT4QFOAA Ag2086MCDdA2Wx/ZSbighLbw0VUkBe01H04zqnEUhMD1Nx9HIDXU2yF2hBPUIKMANYlEH/knTV2I EaWWmCMZciFKX3V0UHvs8YdIm9NB5Z6LK87ZjJ104BnpOajkxRsc5ZW0XqSMUtKShoeGdc1ybJYJ IHQPTJCol2pykmhSzMXVS0etihVqnYds+aaJXCIFU3NlbQRhIDCW6ZZyBO3jgJEOVHbZBh54sMGS Qv4zWQRO3hNBBQG1piQ7EWww220f3Jb/Iazh5SRRWYGwe868+dFohwYnUlXdJBUlSlVaOBl3r3LH 9YZKvqSE6R95Mu53mCmY7hGqnrmYyOhiGnWF8Fz0OWRgWngZai+c0Sh8KMNrfKUcvh/fOrEwxYh8 FMqXZGfxgCEuwp0Gwp0aIr0Z7ZdOx4zd7LFVEEeq4h9fvtviXoloxW5GA/8l8tJwwIhcxia2YQgf tllZ22yWxUOP2RQoEBAFss02Gwjnnlvt3LLd5kFZHQ7MhFZIobS1Lk9h8ihFIZlYJicimXT4QXyv aHOpAXMVk152eZ0TfcXh+iuzoGjJUL2Q+ER54Rb6xlZHiszbuMqEgc6J6DwXbrlS7X13/2JKKVU1 yjmDpPg6sJXjlBSsJAXsVDH+TpMzRnyf5Ffvyv2E4E3Sf7N86HGM7paqKj7FRMEmzndsNkcjRqBB 45hRBAPg0iPEAxE0oP789Ndv//3456///vz37///SUAABABIwAIa8IAITKACF8hALozjPG6omvfM ZzA6EIBDlTHbt8xWHwEZDhcebNwiKBhBVASHQBiyWPIsJ8FifM87JnxhrxQDOg96DYQnQhOYfhVB VIEjhUNpC3/ugymfCI+CyjFhrBgUORtSbWgDQ5DT5mDCTaEFajXE3NB6aB8XIjFi/VFGcB7ShvTQ yYtJ89PmfMbErThxYzdji1h2yDkufv+sPh1ihNbCpJCMZLAy2+IWAiYQpMmww48EGECQ0sZIdvyR HkOiAJbYJZ4S5cQmebpA4jp4tZdEkW9f8hsp5pU67v2GkjpkUfZ8IsJDubEsmIzEURRBya0B6l/T 4ZvQ8BXFQiWnN8aCGSWHArEcImouHwpmLO0wy0oxZTyx64OH2MK3WEaOcI+YXVzw5sliFoib7VqJ NoV5R3dVg5X+CuavalKXN1WNMV9KneC+M53GkMOUvGuJGyZgowP4UzSaeUcBWHO2doRmH6n5xwEQ MBooNVQzBPjAB0BQm7pV65nDyaRBbGYrQRjxfO3Sl+26SC+OAcwvDQqm0NSExEjJSzn/ZwFngBwn w04sJJUMQoomBHS0be6skyxNhq+ip8k5SvNj30QdSF2oLE7lInm47OksHNKTnrmUpPj6is2CeDSB 4aymMMspObOTHO7sLkMkOccELEJDetIBRifMhZLo4QBujaZbTdoMAipgSEdSgDWrAU079hGks4kr AqFhB4/cpoEO3I1zH/XPwypEVOSoMa7nWQ4rF+KgioXIiJ5KzKrUEloVRS4aC1krG/GzOEiNJ3od jRykcFmfEi6oUllRRdAyGpPYGiisQVGt0lg7HBIRjSHfjMv0OHvaPLLsLii11JseJpZRnNZMJ5ot QTr2NZJdl5wgUS2hxJdEV/LmYHHS/y5ItNYKVIDxApB0wAF6IlG4VYts8shvP/hRDwy4zQMhuEA8 MJDfe0i0WtTKDThaGomUwIqyTIVKJgwlwhA2IylGxYgslJqzlk4YMYvJHVh/gynICM0uDgIZpD4s qK08UU/XmdVxOAwgyKw4FyBOZfGWWuI6eK8v6HhtcHLMCQq+d7htVAxOqEMKvUDmF8RQ43w2HJek nuSWbd0Q50gLkzIeZHR7SkTPRAie98LozGhOM5pD0I55VOAeQopHBdRM5zrb+c54zrOe98znPvv5 z4AOtKAHTehCG/rQiE60ohddvx0xoIGQjrSkJ03pSlu6gYt2zAcmkOlOe/rToA61qP9HTepSm/rU qDY0Lr4nPK4Zprx40MNW+DAPV7RiceiAyqywQeMhPm5lTC4uVjJCouGy2jfFSc6RE9S8jugmdrg+ la47sSjuXcWSwWicc4BDbDzwjLcJY5a2mQfrmRJOaBFpk1AtsutUtbp2zpznytLd7aXWIVTcgbey kXyoczeqgpjAt6/JvWwa+VvY3I72iqYtjEW5G9krkQZC0r1ex/yOdf6BgH7nilhnQoADbyBXkOC8 Nmp9Kaci1CeNGlTUjZy43vN5Z+PC0a8RztSU2FspHp9xcgUjT1UOlpFx0pmyhdyLZjrdecUUTpEJ ROTpdAQGmjoU7THvIXfaDHrRX0L/9DJV6HOKydSWJ3HSm183LS+ver4yl83e4Px3v1WvMQmCdaDf dnHB7iqNvD6SZv8yhxXRGjFRu4YITMCwS+oH2qK1UAoMwB0JJVc/xjV5J9EdfBqme8w1HyYZRtze ssrKrHlupj+0tCEis1mfUCuTOCkcJNtBabm/Ec14Xa47iemZGHPopjWRL/VLNDbSXJ8Mrcq+4A05 9pZzU7pVO+grg7fpvT/Hy9OKcfMK1lKTwT7iziHM+a3HSPFj38EOZyN7n1WHIFChNZ3ppCWIJY2S CCqtAaSmHod8fDwyM4AdXQbx+TUP/8AjXxMnCRIHXeEXTFARa4UgTcQdurA02bEN/5fTJrOTKOp3 Aa6CQvciKBEoTxnIbQjIeQeicCVWVVXRW5LCCYUyB9vECBiGcBhIFBv4CQ+4gt1wMvFyFS4iNSUo GPyWGIAHc980Ve/nVqLAd2NBg0WBDRKSRz34PLyjDUqYEN80g1shEkQYDPOygxHUc9cTKx5zNB5U Hk7VbYIHVKSBf+PCGs6iGYc3D0kSDwJUJKkhLhRAAAelAO3gT/4kABM1G20jiBdQLWJCdii4CRyW WbuxLMGRPGPWe5UCiTLydpGQfIdzQrYXCHjBYMN2dA2yb8TAHY4IDLD3XXJhhky1fNewiMYBL7ID Ko6zIp0IE7EDinNQCbfUER0SU//DEIFIZHVyRG0vc0r8UYvggFH+8h4gFTWGAWFFBi99x2DJAyvE I27xwXt9VyF7NDnPQREY0FB8+COZAT/usCMEUFhmExr6sA9JMlh5aCRNglipsSPUcl93owH62FjM Qkq+915kBnjL0V1NWDSXCBy21yCrUh4PkRc5YwFOt13+0XdapiEdMj6PUBKjwINfuH7rsmXJISfY 91x3ACgMyRv0QROn8iVF0RPqkEfQEWJBqDMb2WKuRE0YKD4Z6BWjqJFadQ0n6ZAqOYvMcUZDqYBb 0YFyYZK8eFuplBznFTByAUa48xx24I8SKYQI2XsQ0n6BU1yW4SzxyI4IIAAI8CP/bWZY26IAdcUa f8WO6sgar9EaAnSPF8VHdrQmkOIXUJiAyGEBDJgL1RZtMKmKN+OKKlVLRpeVl4A6KzVGsxhhGUlF KcgUgjIxLtGK0oQL8pRLMuY6o2I7P+kzPPghSjaZ1UN4GBaaSrZrDiF7vYOYxdJKivIcNsGDNkMf qPcyKnUJQfdsaBVhj6mXWeI4DamMb7BWkgiRUBec9vRA0QcH/sAON9IAd8gjo+EACkAA1tJm+PcP ghQB2nk2a0MZddhm/9UHHdA1xYiMGZmIy8AXzLKDu9eBj4BTrTg71LaZYXQpbsKRLHFOEplvsweL zWOK3sZy3uFz1Kafh1I4tjR7/3LCKwB6nwKaCrxyDcR0kdA4QudFKp9IgstIhVAWSszjiXSEnwfZ jCEJobI4XvnWUjmZIbpRgJmojczDjRaHZW/wJKdhD3kVARVFYAAxnYNlnvFwX9eiQe5wAPUQAoa4 jxcpoevBif94VSjZRTZIeMlHDKPJTE1JQ8+mO74HMuZBoAUnWTX5We7HHiypk1OYlOeDTf9mOw5J SwBZT6pkpsA5lTPpFBFkCmM2Ea72lNNUXO/0O7j4dH9XhNBRFkUJcJUUTp8Qfbv4S8i5p1vTp0a5 RtMFovFCdp3zQm+aLKN4k30gNm5DUbPBpEyqePTgX20zNtUCpf/FWPmIR+I3ev9pQZwep34lEoLQ dFQT+amLmX15GT5JyIqR+XPxFpO75VXuRH1A9WWm2TW4dmIg2lm1FXUyQo0J6ay3Ba0YF0KEKny0 IKw41pnEUa3CSEXE8R0txSHq93nBKJARh6/J6o0G4hJNY5yhanvv8jwbxS/M8ADtBycKRxC28QEm Ry0doAEbgDZrE4BC+gG2imD6iAG4YYhhky4fYJmWg0XkM41VcTXyqZDKQDXWV07j2iJSqTLCgQgS 81vAl2HDZStVg2Lfk1TSqKXZ010SCFwdJno5GnYcUbPLc7Or1bQBF7NP5rMYpbBWCXodNiNQIzqn t5lWZLUv2AmYcjUFaLNLCTn/ukAi9JkRGVAgLueSYQcB6UM/DBAuFKBx9PBol5a3eru3fNu3fvu3 XTC3dQu4hFu4hnu4iJu4/zMZTaC4jvu4kBu5kju5C8AAEdC4lJu5mru5nNu5SABq8ZBqoju6pFu6 pnu6qJu6qru6ePYBCcC6sBu7sju7tFu7tiu7Cjaa/VYzylp9A4IAU1sc9EqRaBezB3qtBCt6jpkh 4cqgLRoRvKNzK8O7suC7ilNULJclT5YnkcWhPvNaHlO24dYbYDhzLplOG7MSulmn1tuazGua5su9 vXu0VyVZlPkzcNRDfLSNSxm9BkKw7Eth7hsfV4cd/vuQOHM626W8Fvi+37i9/21qvB0KFOB7v4qj MqPFIc+ZBjwxMp/gW2pRRumIjfolLfPgAQ6qY93nM+wRsGWLGGYloSBmH0B1ZIlam7wkvqoUVmCl wgzGjJhlWccSprAnwzbpbfBBS9d6Fbv5wt1VxDZsPj4MZaXSHzITZBM5ZIIiETUsi1frgju2NbDo e8gEki0Dxp5HKjEcxUosYj9cxZIKsJ70E3QSQfSCLI7BDACyOBP7Ds/ERRCwATnBAWkZJBUASZC1 DJLojWD4kiA1RStsFUtcjO8bbRYmWp5EglZ4rYewyJKswa+wHtF0ftXKr2GITUMZFFhJWy8IyeDK yYL5kL1KwIdDxyNIxtnUvP+ueFul4E3l5MpdYgkQYoaWPHeXYFXtsa+S/FuxPB6zrKV7/CnQo6Ce Sggw0iF+MRTmY8KT1w/C9XF9cMiJJy2GxSMUsFJ0cZtO5iA783XWMQc5aYlmqsad7EwuohGbczDM Sq/4PM92QSep+DTujJJgJXtfu1lSd4zg4SctbJRf+SH6HM9nJ8b/PDnTvDcDnRfmA1XCIV11cZF7 M79FDFobnc+9ItHPwRxl1jes2Y9qojpzNKIxWjgAfdHrLCwaTdLyZDI7fEd8kLDruhXy9y1rWDaJ ZyQGkCSGR3mt4UiWwYcRwAGHrI+5c5q8tq28Bq4S3Fk0W2F2lyKo46V7omH/PViBM6uyY4eZWd2y 34CFSDOf68u7LIKiSrY6Y/3WMel3SYsVaX04NNtWn7cJIpQx7rzX4BbUISLW6Sq+ypYIsGCnGQZH v7K1hf3XaSJifr3Wq5jY2TR3KdKFHaE1YlccFgAk8DB5Tj1YO5IAkkEBB5AA2aIk7TAZtG0P7lB+ 85vQ5sfMSqPNj/0zJck42Ya9x5pKeeqnEza1MDTRwdtJbhq2FvHbPVe9s6h9U5ivUeRK7hXGngWG esLc4BadDX3L0vddaoLQ0XkXejqf50HJZEWj7mpM9yGMVU17vA3du71Rs/kvohzckApv35As5+M1 RT3UCKA21yJASn1IBUAB/xUwX3No1IasAGpDLguFWPfgCyp4dWdkUx1OkpRKVskKe2VNO9GVyD6I z8M2yjvRQ2PqQowwovAMCVQm47q4PKUZRrhXDFKBNwC8B0o8MCK+CC9OTx3ecJxDFH+9LAS6zDjO RdFLxSe+TtkHT0HuLspac5XKlSj+4+4CwNJ7jLVDknG9a+kVCSimfiUNCGA4PJVyzZnnHpBXD+KM Le+AJAXweKetAPPlZj/iT+lo2/xVWJ1heIeteUZrHJadhGl0U0YVTMj90HoZTK9ZJgI7kcfLrUzc 2Ysun7+GFDWqWbpCRlReEFpYgZFqKvrt2DDk6KSZXZin6Czn6ZD6PTyDov940aFosRsoJYqTzk2s LiK6Xc8rYsN27OPHSOlYk+uv7noGmUSucDFBS8r3GlTLAtQwzo6JN3nbkkgBpXh5CFAN/g4EkAA/ Qo+iUVcNkLG0oY8dkGA8jQ7tJmYcIwvbJnSSDJl07djHzRvA6kOrFa3hwEu55KkW4qAIqsBc+zhe VwpC0y9sUOItsuG7IRHEQB0drggN/xcET00GT6Lng1lvSjMCH5nZ4WxzsYn+fvGYF4GsePD8ovJY tjPVFTOUFbAF//Lw4YPOPImeRQtlgu36mVj79X8E0ABO6objIoBKElD1cJaPh/QEdZYQpQEH1rDq Yo2ZnCAPYnMwBe1Gi4H/CqIL//om142otz4sKhks0O46K8n152rPz5pkpWxd941sp2KYnYiiPCXc Yu/2zRpzcb8gz9xkwUdc5TfkHQbSfE80QgRV3EqSGrX3yJX23oD4783MPXPqklqV9wxMw1R6r+iV 4tsLGoAB/bBQmwEa8sfabnYPA8UtouGW9LAZ57gPDkUAhfhft8GPWHI5E6/wNBSoj93xI1k7O/lq AT8qkQXcmqcve3lvoAghX+GT07sNDJytWT51tfPZ8k39z1ChrMBCpkkvzQT5FqYbcUqT+Nz8AuyK WqE6DvOKZmKuchTz0wz/b38yxA0EkIvlUhwai8SLppgRFh+P5+WBNFaL/0wk0TLVJo/fLlZDZBIh ympZaB5Opdni1KidwJFpOlaehJBHAgUflPyqhJgwECIQHCIKIggaBiIYIyAgIygqIxQYHSAWIw4I KEQpDg46QxFCMTE+NDxklzqWmLSqupas4p4etL6u6obEjCD+6MCsjNDypHR5o5D4mJWY4tTqkpWX odyohZ64eakQia3Y5qx2L5DjmIWB5YwtmJ5yq6uZpe6v/eYkY3bkCrgr4uZIOWcuHpQq85j9cbeE 3EAqhRIiC0ds2jCL5rChc2evF0J38Drmo8avWjeAJzVao2YQCsJ+atIUKwnlIjExU5zBFCQIGUae RTS5GlUgFScEBAioQv+waZOlSgUceELgidFWTQVYMWpQaYOHWLyE4UJyb9k/Je3ernTXpsnauGG6 WOAjb+8Wn2ByEuwHz1u6uF+wOHloJIM1Jo1X7urS2ChDPXUwlgEDeaI0CIjXTmRLD0y7C401dKum GTMY0Kcl8uHc7HGvN7fTMfRYrnWYOaZt92kW+gzu00v2UQnd+a7mMs8tqm1GR/rL3lkOe1SsvLCG fckNZQFP0ts0YUWGBpKmS0uXSqIiOHAAtQCBRqSaUq061ZGlAqa6osoSBP7jpBINPphFrfMak0C5 83gZZyErYsJnpGQo426Ju2oSbJuBpgHvJJT+8os1fSSyTLgNcUORDJr/DiKELXkgyNDFLQgbriUp iAgRwrmy8eu7eXoMBwtfVtSsnRtZjBCkKFy6AhhtYlyIx3KuLFJKDSkUiB0uQYpHMqC49DE3hqZk J0WQqKzpSJMgRGO7Ddc0Lpn2fAsSzCiKS2+Egbgx0JIDGhHFAaYKGIACDjShwNH9CDTFAVU00WQq R98jcJSqZulAA1yC4SdK3fioDItkkqvwyoN0+0gPXfrqZ5jMWtUrosAOKSRF1pzbSQ+XbK3GiSzu XIegmJSLVaLzbC2OIi6xASqaLRDS9Vg8AjsJu23P86ULYBdrM9S3viiKp2xFyugjZdubdrqJrD3K VHGAG0JZudzQsxpd/3Ed6ZgXt+WHGLq6paPOgIazKCY/b6XzgkdMIcWBRTKxJIQPOFgEU0c1toqR /wBsVFBOIAjBrFk8uEVUEaERz6KWZ7Rolyghqu6Ixs7J5TMoP0r2YI+4gDM0ul7etZuQekYSpoFm Fq4Q1oJ+YjYqtPjDu5+pJeNLNTtLC951jW5ojZdb6rlp3nTaCcSDrhYxvCYLA3FZ0XYbLMfpvLvb bKEHJkhurb3ozO8rzniCi+qUmHoXhqmAp+ouKK74k0zM+iCERvUb2cBLOalAgao6MZCCk2OxhTfT UtJy6ZTslNU1vXaVw1bP5JLjs3VySZcLuJkd+witebGnX3+QGBa5OP/uOWTr6YDf7Q3gizOpoDaq vluzvoJP4ozUBrcm9uBT04Z4xvDhOXnByzlc790sGIPbYtCFvQ9UBzdNGHLh7z44LYzP+3Ywj1KO 4qhuXL5xUx+2Nzx/vQth5cjJj7KRLSi9xmm78lP7KKSQJXBiYgQ6VAQwcLKLmaVSGwOQxuBzCct5 wAMYoIAnOGYgFibIU7YoGN02co4JdWgc60tNy6yhN9XBJDDYKFvSiAaNNQgPiMsDIA8zYqUd8mYf FsIN/Zj2jQxqRGccMdwT2Sa49vQQaxhhmUnI0cUz8QZpR0CjBl+mJjhGqw9ZAmNNxle1tLGKjA6p 4xGpoY84ZmQ8tdv/ySGm5Trv8cRtAQxKMhj3DO6UCxIHCGGCSJegD2yghI7iSuYw5QEQJMhkmjyZ WTYwOrPQYgN1AKKznic72yVMlrCRyznUoMHeoY17fPDS2sDAs4hQBEnOcp9yfnbM7QXwPEKoYiOP gsu3MScPzkzX0phWKuWg4R+3zF4skZkcZaYNe8fY0//MgTwt7dB9lZnLJFkSpdn97hjddN44CwGR f43qIfwUFTHekiJEek9r35FZ2D7SLIF1hnFVwNlyeJEyWcyQdCz0QAkxB7pNTAWEoxSlJjFpSlOe 7AKz8EvP0McTZiHNiuaBqLGoNZrdLcNxHBmOWs5mpG82c6HUBNQU/x9Em5qgy00G4akylkgdv8Tk CyFxVu70Bg2jUqinX/wp2qCApzLojYzNgyVSneRONFhRGjs9l2okkhPOGEx/TLWp35qqIZwQgo1U DY5PmYed2Dnjh7fb3V2ggQhlKsFPghRTFj6VoIla9FNMEJknMYe5D4T0lBYtyyZXGQsWfjOIGfxn 0WDSEnfKJE1ElVIaEIPOwBrCrdQzJ0bkuc0AsiMOqGGTvYrVOMOFhDwp9a1sDRvECd3ETX795W+O A1NzZjGRMqutZ5S02vNZyF3cg61zIyNccn5mrsaFR9B0EhRhYM0hLVXtL4kLO+QRC6VC8hBW+TqM bhnruMPs69eM4LMn/e6Xv/v9AFciG+D+DpjABTbwgRGcYAUvmMENdvCDIRxhCU+YwhW28IUxnGEN b1gEsNhYRquyYRGPmMQlNvGJUZxiFa+YxS1O8AJgHGMZz5jGNbZxjCvxKAYswFEQuPGPgRxkIQ+Z yEU28pGRnGQlL5nJTXbyk6EcZSlPmcpVtvKVq0yVCsSYAlj28pfBHGYxj5nMZTbzmdGcZjUDmQGO 2vGa4RxnOc+ZznW2853xnOQgAAA7 ________________________________________________________________________________
Date: Dec 16, 2010
Subject: Re: Unfamiliar Connector
Page 12 of the SL70 manual shows what I believe you have described. The circlip was a real bugger to install. At first, I thought the coax connector wasn't in far enough. The problem as keeping the connector in there while putting the circlip on. Hope this helps a little bit.... -----Original Message----- >From: AlRice <Allen(at)allenrice.net> >Sent: Dec 16, 2010 12:59 PM >To: aeroelectric-list(at)matronics.com >Subject: AeroElectric-List: Unfamiliar Connector > > >Does anyone know how to properly install this TED coaxial connector to the cable and the back of my King KT76A transponder? It looks like the cable comes into the connector at 90 deg and the center cable conductor gets soldered to the center pin. It also has a circlip and spring washer that looks like it is meant to retain the connector to the transponder case but there is no way to push the connector into the case far enough to slip the washer & circlip around the connector. This is my first transponder install. > >Thanks for the help. > >-------- >Al Rice >Skybolt 260 >RV-9A >Helping with my grandson's Piet > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=323577#323577 > > >Attachments: > >http://forums.matronics.com//files/img_0001_194.jpg >http://forums.matronics.com//files/tedconnector_198.jpg > > ________________________________________________________________________________
Date: Dec 16, 2010
Good Afternoon Al, I probably should not comment because I do not know what the device is called or where to get it, but there is a long shaft device that will hold the washer and circlip while it is pushed onto the connector. Surely, some one will have better information. Happy Skies, Old Bob In a message dated 12/16/2010 12:06:31 P.M. Central Standard Time, Allen(at)allenrice.net writes: --> AeroElectric-List message posted by: "AlRice" Does anyone know how to properly install this TED coaxial connector to the cable and the back of my King KT76A transponder? It looks like the cable comes into the connector at 90 deg and the center cable conductor gets soldered to the center pin. It also has a circlip and spring washer that looks like it is meant to retain the connector to the transponder case but there is no way to push the connector into the case far enough to slip the washer & circlip around the connector. This is my first transponder install. Thanks for the help. -------- Al Rice Skybolt 260 RV-9A Helping with my grandson's Piet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323577#323577 Attachments: http://forums.matronics.com//files/img_0001_194.jpg http://forums.matronics.com//files/tedconnector_198.jpg ________________________________________________________________________________
Subject: LM3914 Bar Graph circuit question
Date: Dec 16, 2010
Hi guys=2C I have recently built the bar graph circuit suggested by Joe Gores. (Thi s circuit incorporates the LM7805 5 volt regulator=2C and works off the Ray A llen servo potentiometer) Anyway=2C I got the circuit built and it works great!!! It lights the LE Ds as I intended. In an unrelated circuit=3B I have a completely separate 5K ohm potentiometer that the engine uses fo r regulating fuel enrichment (via my manual adjustment). The 5K Pot is in pl ace of the stock coolant thermister. By substituting my own 5K Pot in place of the non-adjustable thermister=2C I can regulate the 'cold engine' (high resista nce) signal sent to the engine's ECU (computer)=2C thereby making the engine think the engine is st ill cold=2C and subsequently enriching the fuel/air mixture. This is a VERY common modification on the GEO/Suzuki auto website=2C for guys that installed turbo chargers (like mine). My question is=3B does anyone have a suggestion how I can use that LM391 4/LM7805 circuit with my 5K potentiometer...and NOT affect the ohm reading it would have normally sent to the ECU if the circuit wasn't there. (For information purposes=3B The 5K Pot has 3 tabs. When turning the kno b one direction=2C resistance between A & B goes from 0 to 5K=2C resistance from A to C goes from 5K to 0.) Mike Welch ________________________________________________________________________________
Subject: LM3914 Bar graph circuit question
Date: Dec 16, 2010
Hi guys=2C I have recently built the bar graph circuit suggested by Joe Gores. (Thi s circuit incorporates the LM7805 5 volt regulator=2C and works off the Ray A llen servo potentiometer) Anyway=2C I got the circuit built and it works great!!! It lights the LE Ds as I intended. In an unrelated circuit=3B I have a completely separate 5K ohm potentiometer that the engine uses fo r regulating fuel enrichment (via my manual adjustment). The 5K Pot is in pl ace of the stock coolant thermister. By substituting my own 5K Pot in place of the non-adjustable thermister=2C I can regulate the 'cold engine' (high resista nce) signal sent to the engine's ECU (computer)=2C thereby making the engine think the engine is st ill cold=2C and subsequently enriching the fuel/air mixture. This is a VERY common modification on the GEO/Suzuki auto website=2C for guys that installed turbo chargers (like mine). My question is=3B does anyone have a suggestion how I can use that LM391 4/LM7805 circuit with my 5K potentiometer...and NOT affect the ohm reading it would have normally sent to the ECU if the circuit wasn't there. (For information purposes=3B The 5K Pot has 3 tabs. When turning the kno b one direction=2C resistance between A & B goes from 0 to 5K=2C resistance from A to C goes from 5K to 0.) ________________________________________________________________________________
Date: Dec 16, 2010
A consideration about the "floating" 90 deg. coax tray connector.... When inserting the Transponder into its tray, be gentle. In the past, I have found that connector with one or more of its outside connector shield flanges broken off. These were in King KT76 and KT76A. Apparently, there was enough play in the floating connector and the tray clearances, to where a ham-handed avionics type, got an interference fit with the outside shield tang and snapped it off by forcing the unit fully into the tray. I am not sure what signal problems develop when one or more shielding tangs are snapped off. The units transmits a high powered pulse return and a broken shield path may screw things up a bit.... David ------------------------------------------------------------------------------------------------- ----- Original Message ----- From: "Ralph E. Capen" <recapen(at)earthlink.net> Sent: Thursday, December 16, 2010 11:26 AM Subject: Re: AeroElectric-List: Unfamiliar Connector > > Page 12 of the SL70 manual shows what I believe you have described. > > The circlip was a real bugger to install. At first, I thought the coax > connector wasn't in far enough. The problem as keeping the connector in > there while putting the circlip on. > > Hope this helps a little bit.... > > -----Original Message----- >>From: AlRice <Allen(at)allenrice.net> >>Sent: Dec 16, 2010 12:59 PM >>To: aeroelectric-list(at)matronics.com >>Subject: AeroElectric-List: Unfamiliar Connector >> >> >>Does anyone know how to properly install this TED coaxial connector to the >>cable and the back of my King KT76A transponder? It looks like the cable >>comes into the connector at 90 deg and the center cable conductor gets >>soldered to the center pin. It also has a circlip and spring washer that >>looks like it is meant to retain the connector to the transponder case but >>there is no way to push the connector into the case far enough to slip the >>washer & circlip around the connector. This is my first transponder >>install. >> >>Thanks for the help. >> >>-------- >>Al Rice >>Skybolt 260 >>RV-9A >>Helping with my grandson's Piet >> >> >> >> >>Read this topic online here: >> >>http://forums.matronics.com/viewtopic.php?p=323577#323577 >> >> >> >> >>Attachments: >> >>http://forums.matronics.com//files/img_0001_194.jpg >>http://forums.matronics.com//files/tedconnector_198.jpg >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Dec 16, 2010
Thanks everyone. Recapen's PDF had the other 1/2 of my question on page 15. I think I know what I'm doing now. -------- Al Rice Skybolt 260 RV-9A Helping with my grandson's Piet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323612#323612 ________________________________________________________________________________
Subject: (off topic) Aircraft Ground to the hangar floor when
parked
Date: Dec 17, 2010
ALL Sorry for the distractor... but I am on a quest for "Simple Science" FACTS to rebuff some "Hanger Talk" about grounding aircraft when parked. MOST military, some heavy maintenance bases , and a few General aviation facilities provide and use ground wires to the hangar floor when aircraft are parked. Why is that so??? The reasons I have gathered are: 1. "Grounds Out" static electricity when the aircraft is being polished (sounds reasonable) 2. "Grounds Out" the airplane if the hangar is struck by lightening (sounds like hanger talk) 3. Reduces Galvanic corrosion by dissimilar metals in the landing gear. ( sounds like hanger talk) 4. Provides path to ground in the event of a 220VAC Ground Power Unit being wired wrong and/or failure of the Green ground wire from the Mains supply (sounds reasonable). This has been witnessed by one our staff. 5. Reduces chances of damage to ESD components, for example, when removing Printed Circuit Cards from cages. (sounds reasonable) 6. Some Hanger Keepers insurance policies require it. (I have yet to see one...hanger talk) 7. And finally, the most common answer.... Because the Army told me to ground the airplane 30 years ago and I have been doing it ever since........(hanger talk accepted blindly with no supporting rationale) The accepted norms from several (Military) documents are: -------- WWW.toddheffley.com www.theinterconnectco.com for lighting products AV-TS.com for Jet Aircraft Test Equipment Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323646#323646 ________________________________________________________________________________
when parked
Date: Dec 17, 2010
If all aircraft in a hangar are bonded (grounded) to a common ground there is no chance of a spark occurring between aircraft and all static is immediately sent to ground. The AMO (Authorized Maintenance Organization - Canada) I worked for did in fact have a stipulation on the insurance requiring all aircraft on the premises be bonded to ground, even the ones tied down outside. I never actually saw the policy but I was told by the owner of the company such a stipulation was in effect. On one occasion the insurance company did send an inspector and he did check for grounds on all aircraft that may have fuel in them. Noel -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of toddheffley Sent: December 17, 2010 11:14 AM Subject: AeroElectric-List: (off topic) Aircraft Ground to the hangar floor when parked ALL Sorry for the distractor... but I am on a quest for "Simple Science" FACTS to rebuff some "Hanger Talk" about grounding aircraft when parked. MOST military, some heavy maintenance bases , and a few General aviation facilities provide and use ground wires to the hangar floor when aircraft are parked. Why is that so??? The reasons I have gathered are: 1. "Grounds Out" static electricity when the aircraft is being polished (sounds reasonable) 2. "Grounds Out" the airplane if the hangar is struck by lightening (sounds like hanger talk) 3. Reduces Galvanic corrosion by dissimilar metals in the landing gear. ( sounds like hanger talk) 4. Provides path to ground in the event of a 220VAC Ground Power Unit being wired wrong and/or failure of the Green ground wire from the Mains supply (sounds reasonable). This has been witnessed by one our staff. 5. Reduces chances of damage to ESD components, for example, when removing Printed Circuit Cards from cages. (sounds reasonable) 6. Some Hanger Keepers insurance policies require it. (I have yet to see one...hanger talk) 7. And finally, the most common answer.... Because the Army told me to ground the airplane 30 years ago and I have been doing it ever since........(hanger talk accepted blindly with no supporting rationale) The accepted norms from several (Military) documents are: -------- WWW.toddheffley.com www.theinterconnectco.com for lighting products AV-TS.com for Jet Aircraft Test Equipment Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323646#323646 ________________________________________________________________________________
Subject: Re: (off topic) Aircraft Ground to the hangar floor
when parked
Date: Dec 17, 2010
Tod, I'll take a shot at this. On hot,and particularly dry, days the fuel in the tanks will heat up and push the fumes out of the vent. The fumes, being heavier than air, will sink to the ground, asphalt, concrete or whatever. Should you rub against the plane or hit something that will make a spark there is a fair chance the spark will detonate the fume buildup on the ground. If the plane is grounded it will not contribute to a spark. I hope. Larry On Dec 17, 2010, at 9:43 AM, toddheffley wrote: > > ALL > > Sorry for the distractor... but I am on a quest for "Simple Science" FACTS to rebuff some "Hanger Talk" about grounding aircraft when parked. > > MOST military, some heavy maintenance bases , and a few General aviation facilities provide and use ground wires to the hangar floor when aircraft are parked. > > Why is that so??? ____________________________________________________________ Obama Urges Homeowners to Refinance If you owe under $729k you probably qualify for Obama's Refi Program http://thirdpartyoffers.juno.com/TGL3141/4d0b8e849612f7c19fcst01duc ________________________________________________________________________________
Date: Dec 17, 2010
Subject: Re:LM3914 Bar Graph circuit question
Hi Mike If you would like to ensure that there is no cross-effect between your bargraph measurement and the engine control circuit, you can use a dual potentiometer. This is like the potentiometer that you have, but it has two sections instead of one, and the two sections are operated by the same shaft. This approach gives you a signal for the bargraph that will track the mixture-control signal without an electrical connection between the two. To find a dual potentiometer at Digikey, enter "dual potentiometer" in the search box. Also check the "in stock" box. In the next screen you can find 5K linear potentiometers. The better-quality potentiometers are not exactly cheap... Mike Linse > > Hi guys, > > I have recently built the bar graph circuit suggested by Joe Gores. > (This > circuit incorporates the LM7805 5 volt regulator, and works off the Ray > Allen > servo potentiometer) > > Anyway, I got the circuit built and it works great!!! It lights the > LEDs as I intended. > > In an unrelated circuit; > I have a completely separate 5K ohm potentiometer that the engine uses > for > regulating fuel enrichment (via my manual adjustment). The 5K Pot is in > place > of the stock coolant thermister. By substituting my own 5K Pot in place > of the > non-adjustable thermister, I can regulate the 'cold engine' (high > resistance) signal sent to the > engine's ECU (computer), thereby making the engine think the engine is > still cold, > and subsequently enriching the fuel/air mixture. > This is a VERY common modification on the GEO/Suzuki auto website, for > guys that > installed turbo chargers (like mine). > > My question is; does anyone have a suggestion how I can use that > LM3914/LM7805 > circuit with my 5K potentiometer...and NOT affect the ohm reading it would > have normally > sent to the ECU if the circuit wasn't there. > > (For information purposes; The 5K Pot has 3 tabs. When turning the knob > one > direction, resistance between A & B goes from 0 to 5K, resistance from A > to C > goes from 5K to 0.) > > Mike Welch ________________________________________________________________________________
From: Etienne Phillips <etienne.phillips(at)gmail.com>
Date: Dec 17, 2010
Hi Mike(s) Another point to ponder is that there are two types of potentiometers - linear and logarithmic. The most common dual pots are logarithmic, as they're used as volume controls in audio systems, where the logarithmic change in volume produces a perceived linear fading. The chances are good that for your fuel system, you will require a linear response. To make sure, and to check what type the exiting pot is, with all power off move the wiper to the middle of its range and check the resistance between the middle and unconnected outer pin. If it's 2.5k, then it's a linear pot. If it's 1k or 4k then it's logarithmic. The bar-graph circuit will need a linear pot to be useful. If needed, you might be able to find a log-lin dual pot if you scratch around enough. Hope that helps! Etienne On 17 Dec 2010, at 9:30 PM, MikeRV6-A wrote: > > Hi Mike > > If you would like to ensure that there is no cross-effect between > your bargraph measurement and the engine control circuit, you > can use a dual potentiometer. This is like the potentiometer > that you have, but it has two sections instead of one, and the > two sections are operated by the same shaft. This approach gives > you a signal for the bargraph that will track the mixture-control > signal without an electrical connection between the two. > > To find a dual potentiometer at Digikey, enter "dual potentiometer" > in the search box. Also check the "in stock" box. In the next > screen you can find 5K linear potentiometers. The better-quality > potentiometers are not exactly cheap... > > Mike Linse > ________________________________________________________________________________
Date: Dec 15, 2010
At 02:15 PM 12/15/2010, you wrote: > >On the out going post of the master relay I feed the start relay and >the main bus feed. In the attached photo you can see with just the >fat wire going to the start relay it takes up most of the room on >the post. I know most of the Z-diagrams show both connected to the >master relay. How do you guys get another lug on there? I could >leave off the lock washer but then how do you keep it from coming loose? Lockwashers don't lock anything . . . especially when you've got the overhang moments of the fat wires. >One guy told me I could remove the nut that snugs up against the relay, NO, NO, NO . . . > but to make sure the post does not turn, one could replace this > with a shorter nut and get more room that way. Not sure I want to > risk moving the internal part, might work for a while but this > could cause unknown issues. Correct. >More weight and parts but I guess I could connect the relay to a fat >buss bar (maybe ANLs), then connect the start relay wire and the >main bus feed wire to each. Leave the lockwasher off. If you're confident of the final positioning of wires, use a mild thread-locker on the top nut. Otherwise wait until after your fly-off. But risks for loosening are very low. It would be really nice if they'd use a thin nut against the case. It's not a big participant in keeping things connected after all the nuts are on. But taking that nut off event to replace it is to risk mis-alignment of internal parts. http://www.aeroelectric.com/Pictures/Contactors/S701-1a.jpg In fact, it's REALLY a good idea to use a wrench on the bottom nut to counter act torque for final tightening of the top nut. Bob . . . ________________________________________________________________________________
Date: Dec 17, 2010
> you can use a dual potentiometer. > Mike Linse Hi Mike=2C Even though the dual potentiometer is fairly expensive=2C it sure does ac complish what I'm after in a simple=2C yet effective way. I think I'll head in this direction=2C and while I'm getting stuff from D igikey=2C I can round up another LM3914 and LM7805. Thanks for the suggestion=2C Mike. Also=2C Etienne=2C thanks for the poi nters on the differences between the two types of pots. Mike Welch ________________________________________________________________________________
Subject: Re: LM3914 Bar Graph circuit question
From: "nuckollsr" <bob.nuckolls(at)aeroelectric.com>
Date: Dec 17, 2010
I have a completely separate 5K ohm potentiometer that the engine uses for regulating fuel enrichment (via my manual adjustment). The 5K Pot is in place of the stock coolant thermister. By substituting my own 5K Pot in place of the non-adjustable thermister, I can regulate the 'cold engine' (high resistance) signal sent to the engine's ECU (computer), thereby making the engine think the engine is still cold, and subsequently enriching the fuel/air mixture. Mike, since the thermistor is a 2-wire device, your thermistor emulator potentiometer is NOT being used as a potentiometer . . . but as a simple adjustable rheostat (i.e. series resistor). From your post I presume you have an interest in having a light-up bar graph that represents the potentiometer position over full range of normal ops. I think this can be done but it's a bit 'fussier' than the trim-indicator task you've already mastered. How much of the pot's rotation is used for full range of operations? Is this a vernier adjustment that is used to trim engine performance during normal operations? Or is it a "set here for cold starting" and "set there for operation?" Do you have some min-max markings on the pot's knob. How many degrees of total potentiometer travel are represented by the min-max pot settings? The input impedance to the LM3914 is VERY high. The data sheet says bias current into pin 5 is 100 NANO amps max, 25 nA typical. This kind of 'load' will have no observable effect on the engine computer's perceptions of potentiometer position. I would guess that one end of the "adjustable thermistor" is wired to ground. The other goes to some current source within the ECU where voltage developed as an effect of that current is translated to some temperature value. I would also guess that the minimum voltage is not zero and the max voltage for normal operating range does not require full rotation of the pot. This means that your bar graph needs to be "differential". I.e. one led illuminated at the operational low but not zero volts and all led's lit at max volts (what ever that is). Can you get some measurements off an installed system for min-max volts to be converted into a graphical display? Bob . . ., Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323724#323724 ________________________________________________________________________________
Date: Dec 18, 2010
Hi Bob=2C What an incredibly astute understanding of the thermister's role. As far as I can gather=2C 99.99% of what you said is how I understood it=2C too. IIRC =2C the coolant temp sensor is one wire=2C depending on the body of it for ground. I agree the pot is being used basically a rheostat. I haven't started the engine yet with the new turbo installation. For lo w(ish) RPMs=2C the stock ECU is supposedly capable of proper A/F ratios up to 5 ps i. (with an unaltered coolant temperature sensor setup) I have a low-range pressure switch (2-7 psi) attached to the throttle body intake housing. On ce boost goes over 4.5 psi=2C it clicks over to the modified portion=2C allowing me to 'dial in' my own F/A ratio=2C from information displayed by the EGT=2C and A/F ratio =2C and boost gages. Since most airplane engine's run at extended periods of time at specific RPMs=2C I would also expect that the rheostat settings would be 'set it=2C and forg et it'. I have not fired up the engine yet. I am in the very final stages of hoo king up my overhead and front panel. In fact=2C today=2C I will be installing the overhead panel=2C and set the front panel into its premade brackets. All I do then is connec t the two DB15 wiring harnesses=2C and the two panels are done. Hook up the various sendo rs=2C and I ought to be able to hear some engine noises pretty soon. I can't really say how much of the rheostat's range would be needed. I'l l do some internet searching and see if there are any 'posted' voltage outputs. I wo uld suspect there is not=2C though. But=2C I'll look. I think what I need to do is A) get the electrical things finished B) s tart the engine and get the timing set correctly C) begin the anaysis part where I can fi nd out what the stock ECU can handle...and what I need to augment. Once I have a whole lot of data to know what I'm dealing with=2C then I t hink I can answer some of your well though-out questions. With your description of the complexities of the whole process=2C I think before I build any kind of LED indicator=2C I ought to get the engine going first=2C do so me testing=2C and THEN determine how best to display the rheostat's setting. Thanks for the help=2C Bob Mike Welch ________________________________________________________________________________
Date: Dec 18, 2010
Thanks everyone for the inputs, I will try the Loctite idea. Mike -------- Mike "Nemo" Elliott RV-8A QB (Fuselage) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323782#323782 ________________________________________________________________________________
Date: Dec 18, 2010
I have the same issue. I am planning to chuck the washer and outer nut for a NAS 21042 self locking small profile nut. That should leave room for two connections and self lock, but I need to order some to be sure. -------- "What is chiefly needed is skill rather than machinery." - Wilbur Wright, 1902 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323796#323796 ________________________________________________________________________________
From: Richard Reynolds <richardreynolds(at)cox.net>
Date: Dec 19, 2010
Be careful, I think Loctite comes in 3 grades. (You need to check!!) Red, Forever, 600F to break it loose. Blue, Not quite forever Green, Pipe sealant Richard Reynolds Norfolk VA RV-6A - N841RV On Dec 18, 2010, at 6:01 PM, rvg8tor wrote: > > Thanks everyone for the inputs, I will try the Loctite idea. > > Mike > > -------- > Mike "Nemo" Elliott > RV-8A QB (Fuselage) > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=323782#323782 > > > > > > > > > > ________________________________________________________________________________
Date: Dec 19, 2010
Richard and All... Good point! I used to run into this with the mechanics that I worked with. Grabbing the wrong one and wondering why they had to reapply it again the next day! Actually, there are almost 30 grades! Depending on cure rate, application and performance. There are 8 grades of threadlocker, depending on application screw/bolt size and removeability 7 grades of sealants, depending on app material and temperature. 4 grades of gasket material, depending on app temperature and cure rate. And, last but not least, 10 grades for retention! Depending on gap, app material, useage and temp. You can see them all (and their recommended applications) here: http://au.iloctite.com/en/loctite-products Harley ----------------------------------------------------------------- On 12/19/2010 6:43 AM, Richard Reynolds wrote: > --> AeroElectric-List message posted by: Richard Reynolds > > Be careful, I think Loctite comes in 3 grades. (You need to check!!) > > Red, Forever, 600F to break it loose. > Blue, Not quite forever > Green, Pipe sealant > > Richard Reynolds > Norfolk VA > RV-6A - N841RV > ________________________________________________________________________________
Date: Dec 19, 2010
I thought of a couple more options for setting the mixture control. A precision multi-turn potentiometer could be used with a knob having a numbered scale. This is the simplest solution with no other indicator required. Another option is to use a volt meter to monitor the control setting. A cheap Harbor Freight meter could be used, or a panel mount meter like this: http://www.murata-ps.com/data/meters/20lcd.pdf available at Mouser, part number 580-DMS-20LCD-1-5-C, $32. Or a double-throw switch could connect the voltage monitoring pin of the EFIS to either the aircraft electrical system or to the mixture control. I am not recommending one method over another. It is a matter of personal preference. If you get the plane flying first, then you might be having too much fun to spend time puttering with electronic projects. :-) Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323803#323803 ________________________________________________________________________________
Date: Dec 19, 2010
I believe that you have a series circuit of heavy wire between BATTERY to BATTERY RELAY to STARTER RELAY to STARTER. Electrically, there is NO difference between the output of the battery relay and the input of the starter relay. If the stud on your starter relay is slightly longer, simply move the extra cable over to the input side of the starter relay. The stud on your present BATTERY RELAY (master relay) seems abnormally short. If it were mine, I would probably just spring for another $25 relay from Aircraft Spruce (after asking them to confirm length). If you wish to use thin nuts, you can do so without damage by marking and closely observing a line placed on the stud tip with a felt tip pen to monitor any rotation. Double nut the stud at the tip and tighten, leaving small space between the double nuts and the inner (thick) nut. With a box wrench on the outer double nut, loosen the original inner nut next to the relay housing using an open end wrench WHILE WATCHING FOR ANY ROTATION by monitoring the ink line. There is no reason that the inner (stud locking) needs to be thick. In fact, a thin brass nut might help for electrical conductivity. I do not believe that the previously mentioned NAS 21042 nuts are available in coarse (NC) thread. A light grade of threadlocker might work, but sure as heck if you use it, the connection will have to be undone TOMORROW and now residue is imbedded in the threads. Upon disassembly when using threadlocker or locknuts, you are much more likely to cause stud rotation, even with the inner jam nut in place. In any case, mark the stud end with a felt tip pen. Lock washers dont work only because they need to be replaced with new every time they are removed. If you are in the field and must reuse lock washers, at least check to see that they are not flattened. Split ring lock washers eat hell out of everything they touch. My preference is for MS 353333 internal star lock washers with one AN960 light plain washer under the star (AC 43.13-1B, p 7-15). Besides, the star lock washers are thinner than split ring types. -------- Jerry King Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323808#323808 ________________________________________________________________________________
Subject: Infinity Stick Ordering And Wiring
Date: Dec 19, 2010
Go to infinity grip switch web site. Scroll down to "For how to wire your stick grips into your system " Click Here You will display a page of definition on possible stick grip functions. Print this page for reference. You will also see a Blue highlighted Stick Grip Order Form. Click on this. Print this page for reference. Then functions of the switches are fairly straightforward: Switch# 1 The Hat Switch is self explanatory. 2 Red PTT Your choice for switches 3, 4, 5, & 6 are: 1 Normally Open N.O. Push Button PB (8632) 2 Normally Closed N.C. Push Button PB (8632) 3 Push-on/Push-Off (8636) or ON/OFF Toggle (320) 4. ON/OFF/momentary ON Toggle or Spring Loaded to Center (ON)/OFF/(ON) (Use with Vertical Power) ________________________________________________________________________________
Date: Dec 19, 2010
> I thought of a couple more options for setting the mixture control. A pre cision multi-turn potentiometer could be used with a knob having a numbered scale. Hi Joe=2C This is exactly what I have already. I have a very high quality potentio meter (5K ohm=2C 10 turn=2C linear) with one of those numbered dials that look ju st like a "combination lock". The dial even has a little lever that locks the dial in place onto whatever setting it is turned to. The dial I got from Mouser is also a 10-turn unit=2C so whenever you rotate the dial from zero (at 0 ohms) all the way t o 10 (at 5K ohms)=2C it's reasonably close to indicating 1K ohms for every 2 tur ns. Here it is=3B (yes=2C the dial cost me more than $30)=3B http://www.mouser.com/ProductDetail/Honeywell-Clarostat/31612/?qs=sGAEpiM ZZMuiwDVLTMm01WUt3B34cWdtXy3YwOP582s%3d What I really would like=2C in addition to the numbered dial=2C would be a visual indicator=2C also. With Mike Pense's suggestion about using the dual pot a nd combining it with that LM3914 bar graph=2C this certainly get's the job don e!! > Another option is to use a volt meter to monitor the control setting. However=2C this suggestion of the digital number display (DVM) offers ano ther very good alternative to LEDs. I read the data sheet and I do like the ide a of a digital reading of the pot. Would I be able to use my present 5K potentiometer with this DVM=2C or wo uld I have to get one of those dual pots=2C like Mike Pense suggested? I reall y would like the reading to be simultaneous......that is=2C the ECU and I see the same reading at the same time=2C as opposed to switching back and forth by way of a DPDT=2C etc. switch. Could someone come up with a design for the DVM that reflect the pot's se tting=2C and whether or not this design would need a single or dual pot? Thanks for your help=2C Mike Welch ________________________________________________________________________________
Date: Dec 19, 2010
Mike, If you decide to use this voltmeter, http://www.murata-ps.com/data/meters/20lcd.pdf I do not think that it will be necessary to use a dual pot for isolation. The meter has an input impedance of 800K. When connected in parallel with a 5K pot, the resistance of the circuit will drop about 1 percent maximum (probably less). If it were necessary to measure an exact voltage, then a 1 percent error might be significant. But in this application, you are not looking for an exact voltage measurement, only the ability to repeatably set the voltage where the engine will run best. A voltmeter will certainly be more precise than a LED bar-graph. The first step is to measure the maximum voltage across the pot, then buy a meter with the correct part number for that voltage range. Connecting the meter to the aircraft is easy. Use a 7805 voltage regulator to power the meter pins 1 & 3, connect pins 7 & 8 together, and connect pins 11 & 12 to each side of the rheostat. If you want a decimal point, connect pin 3 to pin 4 or 5 or 6. I do not want to give Mike bad advice; so opposing views are welcome. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323851#323851 ________________________________________________________________________________
Date: Dec 20, 2010
At 04:55 PM 12/19/2010, you wrote: > >Mike, >If you decide to use this voltmeter, >http://www.murata-ps.com/data/meters/20lcd.pdf >I do not think that it will be necessary to use a dual pot for >isolation. The meter has an input impedance of 800K. The voltmeter is a good lick whether or not it's left in place permanently. The thermistor being "spoofed" has a temperature vs. resistance characteristic that probably going to yield some narrow range of readings for normal operating conditions. I'd guess replacing the thermistor with just a potentiometer will provide at best a very coarse adjustment and only a small percentage of the pot's travel will be used. It would be useful to have a voltmeter in place to quantify the adjustment rage for normal operations and then tailor some form of circuitry to emulate that range with large, high resolution rotation of the pot. A ten-turn pot is probably overkill but it's a very practical design goal to have normal ops settings to use 80 percent of the potentiometer's travel with say 10% head and foot-room at each end. Crafting the circuit is easy but we need data. How much current flows in the thermistor sense lead and what voltages exist across the thermistor a the extreme ends of the operating range? From the operating ergonomics perspective, it would be better for the final configuration not to have a voltmeter. If this is a mixture control then you probably have "feedback" for optimal settings already in terms of EGT, oxygen sensor, engine smoothness, rpm drops from peak, etc. etc. ADDING another instrument to be observed, perceived, pondered and reacted to is probably going the wrong direction . . . Bob . . . ________________________________________________________________________________
Date: Dec 20, 2010
> But in this application=2C you are not looking for an exact voltage measu rement=2C only the ability to repeatably set the voltage where the engine w ill run best. A voltmeter will certainly be more precise than a LED bar-gra ph. > The first step is to measure the maximum voltage across the pot=2C then b uy a meter with the correct part number for that voltage range. Connecting the meter to the aircraft is easy. Use a 7805 voltage regulator to power th e meter pins 1 & 3=2C connect pins 7 & 8 together=2C and connect pins 11 & 12 to each side of the rheostat. If you want a decimal point=2C connect pin 3 to pin 4 or 5 or 6. > I do not want to give Mike bad advice=3B so opposing views are welcome. > Joe Hi Joe=2C You are correct=2C I don't need to know a precise value of voltage=2C onl y a consistant one that I can duplicate fairly quickly. I would suspect there may be 3-4 maximum readings=2C i.e. take-off=2C climb-out=2C X-C fast cruise. I'd also guess most of the other RPM parameters would not even need any o f the "coolant temperature sensor mod" contributions. With the stock ECU able to handle up to approx. 5 PSI boost=2C the DVM is going to be ONLY high RPM/high engi ne power ranges=2C no CTS mod necessary. I don't understand what you mean when you say "first step measure max vol tage across the pot" and then buy the right meter. Do you mean=3B after it is i nstalled on the plane=2C and in operation=2C and the engine is taking a reading of the pot? This electrical expertise is above my experience level. One more quick question=3B I follow you with all the pin connections=2C except for the two pot connections (#11 ). Would these be hooked up in parallel with the CTS? Thanks a million=2C Mike Welch ________________________________________________________________________________
Date: Dec 20, 2010
> From the operating ergonomics perspective=2C it > would be better for the final configuration > not to have a voltmeter. If this is a mixture control > then you probably have "feedback" for optimal > settings already in terms of EGT=2C oxygen sensor=2C > engine smoothness=2C rpm drops from peak=2C etc. etc. > ADDING another instrument to be observed=2C perceived=2C > pondered and reacted to is probably going the > wrong direction . . . > > > > > Bob . . . Hi Bob=2C You do bring up a VERY valid point re: more complexities!! I do have a d igital EGT unit/gage w/ alarm function=2C a digital boost gage/w alarm=2C a wideband 02 sensor a nd digital gage. I hadn't thought about it before=2C but rather than rely on any additiona l stuff=2C maybe I should consider using the alarm functions to enrichen the A/F ratio? In a high demand power situation (high boost)=2C it is possible the EGT c ould register high temps (being too lean). Same thing goes for the boost gage. Supposedly an ything 5 psi and below is all automatically taken care of by the stock ECU. I think I should fire the engine up=2C do some measurements=2C and THEN f igure out which way to proceed. I am very close to being able to getting it running. The panels are in t he process of being installed=2C and then I just need a couple of days to complete the misc. wi ring and odds & ends. Here is a link to the EGT & Boost gages I have=3B http://www.auberins.com/index.php?main_page=product_info&cPath=5&produc ts_id=19&zenid=0aefca50e3651c54f87b3f3b7bf09f10 At his point=2C I think I need data before I should proceed. Thanks for your help=2C Mike Welch ________________________________________________________________________________
Date: Dec 20, 2010
> I don't understand what you mean when you say "first step measure max voltage across the pot" and then buy the right meter. The panel mount voltmeter that I suggested does not have a user selected voltage range like some hand-held meters. You have to buy the correct model number for the expected voltage range. If the voltage across the rheostat is 150mv, the 200mv model is the one to buy, not the 20volt model. Unless you have some documentation about the circuit parameters, it will be necessary to measure (with a portable meter) the voltage drop across the rheostat with the circuit in operation. Then buy a panel mount meter. You asked, " > I follow you with all the pin connections, except for the > two pot connections (#11 ). Would these be hooked up in parallel with the CTS?" I am not sure what you mean by CTS, but the meter input pins 11 & 12 would connect in parallel with the rheostat. I assume that you purchased a 5K pot because others have used it with success. If it turns out that the pot gives coarse adjustments that make fine tuning difficult, it might help to put a fixed resistor in parallel with the pot. Eventually when you get everything working to your satisfaction, and determine the optimum resistance values for takeoff, climb, and cruise, then fixed resistors and a selector switch could be substituted for the pot. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323910#323910 ________________________________________________________________________________
when parked
Date: Dec 20, 2010
This would explain all the exploding hangars all over the country...Geoff -------- Dual controls. Dynon 180. Icom 210 Garmin 296. Becker transponder. Sigtronics intercom. Electric flaperons. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323925#323925 ________________________________________________________________________________
Date: Dec 20, 2010
Subject: Re: moving batteries
Hi Bob You sent me a response to my question about relocating my batteries. >>>> I'd put the battery busses, and battery contactors adjacent to their respective batteries. Run a 2AWG ground forward for BOTH batteries and 4AWG feeders for each battery to the cross-feed contactor on the firewall.<<<< I have the battery contactores ,x feed contactor and starter contactor in a neat package on the firewall. What is the reason for moving the battery contactor back with the batteries behind the seat. There are some location problems I am trying to resolve. Jim James Robinson Glasair lll N79R Spanish Fork UT U77 ________________________________________________________________________________
Date: Dec 20, 2010
At 03:02 PM 12/20/2010, you wrote: >Hi Bob >You sent me a response to my question about relocating my batteries. > > >>>> I'd put the battery busses, and battery contactors > adjacent to their respective batteries. Run a 2AWG > ground forward for BOTH batteries and 4AWG feeders > for each battery to the cross-feed contactor on the > firewall.<<<< > >I have the battery contactores ,x feed contactor and starter >contactor in a neat package on the firewall. What is the reason for >moving the battery contactor back with the batteries behind the >seat. There are some location problems I am trying to resolve. Battery contactors and battery busses are classically located in close proximity to their respective batteries. Note the "*" symbol on the fat wires between batteries and battery busses in the z-figures. This says keep 'em short. This minimizes the lengths of always hot wires when the master switch is off. It's a crash safety thing. Bob . . . ________________________________________________________________________________
Subject: supplementing the A/F ratio
Date: Dec 20, 2010
Hi Bob N & Joe=2C You guys both appear to have a very good handle on the objective I'm trying to achieve. You also understand the coolant temperature sensor (CTS) pretty good=2C too=2C and likely how it instructs the ECU to enrich the A/F ratio due what it perceives as a 'cold engine'. Since I'm reasonably close to being able to fire the engine up=2C I think I need to see how things perform=2C get some measurements=2C pin down exactly what I'm up against and then ask for advice how to solve a more specific task. But=2C before I can get back to installing my pre-assembled instrument panel=2C I have to seal my storm cellar from leaks. Crap always seems to get in the way of having fun!! Thanks for your help=2C guys=2C I'll get back to you later on this subjec t with better information. Mike Welch ________________________________________________________________________________
Subject: Re: Battery Relay post too short
Date: Dec 20, 2010
I think it comes in three grades too... just have a look http://www.henkelna.com/cps/rde/xchg/henkel_us/hs.xsl/product-search-1554.ht m?¶m1=pageIndex%3D0|action%3Dsearch|y%3D0|x%3D0|applicationRedDotUID%3D0 00000026R|subsubapplicationRedDotUID%3D|advanced%3D|subapplicationRedDotUID% 3D00000002AD|brandRedDotUID%3D0000000389| For some of them you will need to have money... lots of money! Noel -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Richard Reynolds Sent: December 19, 2010 8:13 AM Subject: Re: AeroElectric-List: Re: Battery Relay post too short Be careful, I think Loctite comes in 3 grades. (You need to check!!) Red, Forever, 600F to break it loose. Blue, Not quite forever Green, Pipe sealant Richard Reynolds Norfolk VA RV-6A - N841RV On Dec 18, 2010, at 6:01 PM, rvg8tor wrote: > > Thanks everyone for the inputs, I will try the Loctite idea. > > Mike > > -------- > Mike "Nemo" Elliott > RV-8A QB (Fuselage) > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=323782#323782 > > > > > > > > > > ________________________________________________________________________________
Date: Dec 20, 2010
3 grades? According to that link you tried to send, it's 50! So others can see it, let's try it this way: http://tinyurl.com/24ujwsk Harley ----------------------------------------------------------------- On 12/20/2010 5:46 PM, Noel R.C. Loveys wrote: > --> AeroElectric-List message posted by: "Noel R.C. Loveys" > > I think it comes in three grades too... just have a look > http://www.henkelna.com/cps/rde/xchg/henkel_us/hs.xsl/product-search-1554.ht > m?¶m1=pageIndex%3D0|action%3Dsearch|y%3D0|x%3D0|applicationRedDotUID%3D0 > 00000026R|subsubapplicationRedDotUID%3D|advanced%3D|subapplicationRedDotUID% > 3D00000002AD|brandRedDotUID%3D0000000389| > > > For some of them you will need to have money... lots of money! > Noel > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Richard > Reynolds > Sent: December 19, 2010 8:13 AM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Re: Battery Relay post too short > > --> AeroElectric-List message posted by: Richard Reynolds > > > Be careful, I think Loctite comes in 3 grades. (You need to check!!) > > Red, Forever, 600F to break it loose. > Blue, Not quite forever > Green, Pipe sealant > > Richard Reynolds > Norfolk VA > RV-6A - N841RV > > > On Dec 18, 2010, at 6:01 PM, rvg8tor wrote: > >> --> AeroElectric-List message posted by: "rvg8tor" >> >> Thanks everyone for the inputs, I will try the Loctite idea. >> >> Mike >> >> -------- >> Mike"Nemo" Elliott >> RV-8A QB (Fuselage) >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=323782#323782 >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Dec 20, 2010
Subject: Belt & suspenders?
Any idea why Icom (& others I believe) would call for 2X18 awg wires for power and ground to their radio? The load is well under 10 amps and for the short 12" run to my Avionics/Ground bus it seems like "hyper safe" Thanks, Tim Andres ________________________________________________________________________________
Date: Dec 20, 2010
Thanks Harley Noel From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Harley Sent: December 20, 2010 7:28 PM Subject: Re: AeroElectric-List: Re: Battery Relay post too short 3 grades? According to that link you tried to send, it's 50! So others can see it, let's try it this way: http://tinyurl.com/24ujwsk Harley _____ On 12/20/2010 5:46 PM, Noel R.C. Loveys wrote: I think it comes in three grades too... just have a look http://www.henkelna.com/cps/rde/xchg/henkel_us/hs.xsl/product-search-1554.ht m?¶m1=pageIndex%3D0|action%3Dsearch|y%3D0|x%3D0|applicationRedDotUID%3D0 00000026R|subsubapplicationRedDotUID%3D|advanced%3D|subapplicationRedDotUID% 3D00000002AD|brandRedDotUID%3D0000000389| For some of them you will need to have money... lots of money! Noel -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Richard Reynolds Sent: December 19, 2010 8:13 AM Subject: Re: AeroElectric-List: Re: Battery Relay post too short Be careful, I think Loctite comes in 3 grades. (You need to check!!) Red, Forever, 600F to break it loose. Blue, Not quite forever Green, Pipe sealant Richard Reynolds Norfolk VA RV-6A - N841RV On Dec 18, 2010, at 6:01 PM, rvg8tor wrote: Thanks everyone for the inputs, I will try the Loctite idea. Mike -------- Mike "Nemo" Elliott RV-8A QB (Fuselage) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323782#323782 ________________________________________________________________________________
Date: Dec 20, 2010
Subject: Re: Belt & suspenders?
At 05:04 PM 12/20/2010, you wrote: > >Any idea why Icom (& others I believe) would call for 2X18 awg wires >for power and ground to their radio? The load is well under 10 amps >and for the short 12" run to my Avionics/Ground bus it seems like "hyper safe" Not all runs are under 12". They're looking for redundancy + low impedance connections. You can drop to 20AWG for the 12" runs but do put both in. I think they ask for dual power leads too? Bob . . . ________________________________________________________________________________
Date: Dec 21, 2010
Subject: 430W install kit
Can anyone shed some light on why Garmin supplies a molex connector & pins (#336-00029-00) in the 430W install kit? In table 3-4 of the install manual it list the molex pins they supply under the "Shield ground" column but I see no use for this connector. Thanks, Tim Andres ________________________________________________________________________________
Date: Dec 21, 2010
Subject: Re: 430W install kit
I saw that too. I'm going to use it to tie sheield to ground as needed. I'm planning on running the ARINC-429 and maybe the RS-232 signals via shielded twisted pair. ----- Original Message ----- From: "Tim Andres" <tim2542(at)sbcglobal.net> Sent: Tuesday, December 21, 2010 5:38:05 PM GMT -06:00 US/Canada Central Subject: AeroElectric-List: 430W install kit Can anyone shed some light on why Garmin supplies a molex connector & pins (#336-00029-00) in the 430W install kit? In table 3-4 of the install manual it list the molex pins they supply under the "Shield ground" column but I see no use for this connector. Thanks, Tim Andres ________________________________________________________________________________
Date: Dec 21, 2010
I figured some folks might install without a tray? Mine are still in the box awaiting a shop cleanout event. Allen Fulmer RV7 Panel with 430W finished, working on cowl N808AF reserved ________________________________________________________________________________
Date: Dec 21, 2010
Hey Allen Still down here in Miami workin for a livin. Zach Chase called a few days ago after getting an email from me. Nora and I will drive up to Stuart on the 31st to visit with him and get the cow l ready to ship home with some extra fiberglass stuff in the crate. any sug gestions on what I should order. Foam?? cloth=2C filler etc. I guess Zach c an tell me what I need to buy to glass in the naca scoops and ducts to the intercooler. Nora is out in San Diego now with our Son Skip and his wife Diane and t wo kids for Christmas. I will fly there on Thursday for a very brief 3 days off over Christmas=2C then Nora an I will return to Miami where we will li kely be until the end of Feb or mid-March. Hopefully I will earn enuf to st ay home all summer and work on the RV. I don't have any other distractions lined up yet for the summer except for helping the rentor a bit with the ha y operation. I do have to fix the hangar door as I had a hydraulic system a nd door structural failure just before I left. It slammed shut and is close d now with no counterweights on it and I don't know exactly how I am going to get it open to get the tractor back in to lift the heavy stuff. (door we ighs about 1400 lbs) re-design and install the hydraulic rams to open it I guess then remove and replace a door verticle support that bent.. bad engin eering on my part! llive and learn. another thousand dollar mistake. oh wel l. Thankfully the Lord takes care of fools. Have a very blessed Christmas celebration wih Joan. and maybe ATL family ? Bill & Nora > From: afulmer(at)charter.net > To: aeroelectric-list(at)matronics.com > Subject: RE: AeroElectric-List: 430W install kit > Date: Tue=2C 21 Dec 2010 18:22:14 -0600 > net> > > I figured some folks might install without a tray? Mine are still in the > box awaiting a shop cleanout event. > > Allen Fulmer > RV7 Panel with 430W finished=2C working on cowl > N808AF reserved > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Dec 21, 2010
Subject: Fwd: 430w
Received this from Bob Newman; -------- Original Message -------- Subject: 430w Date: Tue, 21 Dec 2010 19:24:47 -0500 From: Bob Newman <rnewman(at)lutron.com> The molex connector is a convenient landing point for all the shields and grounds that are in the various cables. You'll find a blade shaped landing spot formed in the casting of the backplate of the tray where the molex connector screws down and all the grounds are thus bonded to the chassis. You can post this reply, I just don't have access right now. Bob Newman ________________________________________________________________________________
Subject: Using a SD-20 Alternator on a Lycoming R-680
Date: Dec 21, 2010
Hello All, Dad and I are restoring a Stearman and would like to put a modern alternator and electrical system on it without going to the expense of a Jasco alternator. Our Stearman has the Lycoming R-680. Does anyone have any experience or suggestions doing this with a B&C SD-20 alternator? Any help and advice will be greatly appreciated. Thanks, Kent ________________________________________________________________________________
Date: Dec 22, 2010
Subject: Re: Using a SD-20 Alternator on a Lycoming R-680
At 11:31 PM 12/21/2010, you wrote: >Hello All, > >Dad and I are restoring a Stearman and would like to put a modern >alternator and electrical system on it without going to the expense >of a Jasco alternator. Our Stearman has the Lycoming R-680. Does >anyone have any experience or suggestions doing this with a B&C >SD-20 alternator? Any help and advice will be greatly appreciated. Does the engine have and AND20000 drive pad on it? Does it turn fast enough to stroke the SD20 to full output (4000 rpm). Is it stressed sufficiently for extracting the horsepower required to power the SD-20? Suggest you contact B&C at 316-283-8000 and discuss your design goals with them. Bob . . . ________________________________________________________________________________
Date: Dec 22, 2010
Hi Bob, Thanks for your response. The engine has the standard vacuum pump mounting pad which I think is the AND20000 you mentioned. We are researching the output speed of this drive. We have not thought about how this drive is stressed. That is an excellent point to consider. We will investigate this further along with calling B&C. Mostly, I am fishing to see if this has been done before with a radial engine in an attempt to keep from reinventing the wheel when we go for a field approval. Thanks again for your help. Best wishes for a Happy Holiday season!! Kent -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Wednesday, December 22, 2010 8:07 AM Subject: Re: AeroElectric-List: Using a SD-20 Alternator on a Lycoming R-680 At 11:31 PM 12/21/2010, you wrote: Hello All, Dad and I are restoring a Stearman and would like to put a modern alternator and electrical system on it without going to the expense of a Jasco alternator. Our Stearman has the Lycoming R-680. Does anyone have any experience or suggestions doing this with a B&C SD-20 alternator? Any help and advice will be greatly appreciated. Does the engine have and AND20000 drive pad on it? Does it turn fast enough to stroke the SD20 to full output (4000 rpm). Is it stressed sufficiently for extracting the horsepower required to power the SD-20? Suggest you contact B&C at 316-283-8000 and discuss your design goals with them. Bob . . . ________________________________________________________________________________
Date: Dec 22, 2010
At 07:56 PM 12/22/2010, you wrote: >Hi Bob, > >Thanks for your response. The engine has the standard vacuum pump >mounting pad which I think is the AND20000 you mentioned. We are >researching the output speed of this drive. We have not thought >about how this drive is stressed. That is an excellent point to >consider. We will investigate this further along with calling >B&C. Mostly, I am fishing to see if this has been done before with >a radial engine in an attempt to keep from reinventing the wheel >when we go for a field approval. Thanks again for your help. > If it has been done, I suspect that B&C has a high probability of knowing about it. Best wishes for a Happy Holiday season!! You too! Bob . . . ________________________________________________________________________________
Subject: Is this good practice?
Date: Dec 22, 2010
My Breaker panel will be hinged at the bottom, the idea being future maintenance, you just have to tip the panel out to get to the bus bars. In order to support the wire bundles I want to use a cushion clamp attached to the bus bar. I have a a tie for two rows of breakers that is held together with #8 screws, this is a convenient place for a cushion clamp. You can see the clamp in the photo. The clamp is totally cushioned, (WDG type) so the wires will not touch any metal, but there would be voltage running trough the metal part of the clamp. I wonder if this could cause problems? It would take more work but I can fashion a standoff attached to the panel to make the same support. Just wonder if the easy route will work. Thanks for the help -------- Mike "Nemo" Elliott RV-8A QB (Fuselage) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=324177#324177 ________________________________________________________________________________
Subject: test
Date: Dec 23, 2010
Subject: Garmin GTX 320
Date: Dec 23, 2010
Does anyone have a copy of the Installation Manual for the Garmin GTX 320 transponder. I cannot find one from the usual sources. Thanks. Mike G-CFMP Mono ________________________________________________________________________________
Date: Dec 23, 2010
Subject: Re: Is this good practice?
At 10:21 PM 12/22/2010, you wrote: My Breaker panel will be hinged at the bottom, the idea being future maintenance, you just have to tip the panel out to get to the bus bars. In order to support the wire bundles I want to use a cushion clamp attached to the bus bar. I have a a tie for two rows of breakers that is held together with #8 screws, this is a convenient place for a cushion clamp. You can see the clamp in the photo. Emacs! The clamp is totally cushioned, (WDG type) so the wires will not touch any metal, but there would be voltage running trough the metal part of the clamp. I wonder if this could cause problems? It would take more work but I can fashion a standoff attached to the panel to make the same support. Just wonder if the easy route will work. It's a bit un-orthodox as you've already guessed. You're using the terminal tabs on a row of circuit breakers for a task that is normally provided by some structurally robust support. Given the relatively light mass of just 4 wires, I wouldn't anticipate future difficulties. No doubt a TC cert team would ponder it with some distress but then, that's one reason we choose to reside in our parallel universe . . . right? I think it will be okay. Bob . . . ________________________________________________________________________________
Date: Dec 23, 2010
Subject: Re: Garmin GTX 320
If you're installing into a homebuilt, contact Garmin AT for a copy. This won't work for certified however. Ron Q. At 06:56 12/23/2010, you wrote: >Does anyone have a copy of the Installation Manual for the Garmin >GTX 320 transponder. I cannot find one from the usual sources. > >Thanks. > >Mike > >G-CFMP > >Mono ________________________________________________________________________________
From: "CHARLES T BECKER" <ctbecker(at)atlanticbb.net>
Date: Dec 23, 2010
"Mike Gamble" wrote: > Does anyone have a copy of the Installation Manual for >the Garmin GTX 320 > transponder. I cannot find one from the usual sources. > > Thanks. > > Mike > > G-CFMP > > Mono > > > > > JVBERi0xLjMNJeLjz9MNCjIxNyAwIG9iag08PCANL0xpbmVhcml6ZWQgMSANL08gMjIwIA0v SCBbIDExODggOTY0IF0gDS9MIDg0MDU4NCANL0UgMTUyMDI0IA0vTiAzNyANL1QgODM2MTI1 IA0+PiANZW5kb2JqDSAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICB4cmVmDTIxNyAzMCANMDAwMDAwMDAxNiAwMDAwMCBuDQowMDAwMDAwOTY5 IDAwMDAwIG4NCjAwMDAwMDEwNDcgMDAwMDAgbg0KMDAwMDAwMjE1MiAwMDAwMCBuDQowMDAw MDAyMzI2IDAwMDAwIG4NCjAwMDAwMDI2MDQgMDAwMDAgbg0KMDAwMDAwMjY0NSAwMDAwMCBu DQowMDAwMDAzMDQyIDAwMDAwIG4NCjAwMDAwMDMxMzkgMDAwMDAgbg0KMDAwMDAwMzM1NyAw MDAwMCBuDQowMDAwMDAzNDA3IDAwMDAwIG4NCjAwMDAwMDY0MDYgMDAwMDAgbg0KMDAwMDAw NzA0NSAwMDAwMCBuDQowMDAwMDA3MjYwIDAwMDAwIG4NCjAwMDAwMDc1OTUgMDAwMDAgbg0K MDAwMDAwNzgyMCAwMDAwMCBuDQowMDAwMDA3OTU4IDAwMDAwIG4NCjAwMDAwMDc5OTkgMDAw MDAgbg0KMDAwMDAxNjEwNSAwMDAwMCBuDQowMDAwMDI2NTQ3IDAwMDAwIG4NCjAwMDAwNjI4 NTIgMDAwMDAgbg0KMDAwMDA2MzA0NiAwMDAwMCBuDQowMDAwMDYzMTEwIDAwMDAwIG4NCjAw MDAwNjMyMDIgMDAwMDAgbg0KMDAwMDA2NDEyOCAwMDAwMCBuDQowMDAwMDY0MzM3IDAwMDAw IG4NCjAwMDAwNjUyNjMgMDAwMDAgbg0KMDAwMDE0NDc0NyAwMDAwMCBuDQowMDAwMDAxMTg4 IDAwMDAwIG4NCjAwMDAwMDIxMzAgMDAwMDAgbg0KdHJhaWxlcg08PA0vU2l6ZSAyNDcNL0lu Zm8gMjE2IDAgUiANL0VuY3J5cHQgMjE5IDAgUiANL1Jvb3QgMjE4IDAgUiANL1ByZXYgODM2 MTE0IA0vSURbPDY2NmRkNWM4NmMwYmU2MjQzNTdiNDM5MGE1M2RkZWViPjw2NjZkZDVjODZj MGJlNjI0MzU3YjQzOTBhNTNkZGVlYj5dDT4+DXN0YXJ0eHJlZg0wDSUlRU9GDSAgICANMjE4 IDAgb2JqDTw8IA0vVHlwZSAvQ2F0YWxvZyANL1BhZ2VzIDIxMiAwIFIgDS9QYWdlTGFiZWxz IDIxMCAwIFIgDT4+IA1lbmRvYmoNMjE5IDAgb2JqDTw8IA0vRmlsdGVyIC9TdGFuZGFyZCAN L1IgMiANL08gKHFccrxqMGSKFsCmKrO0+5/LXrdrRsd/SE8Ytrgx0ASJFCkNL1UgKGiQUdpj g0oV6Qhkpx/fDj18FKPRYJklQ5Qf+9gOo9glKQ0vUCAtNjAgDS9WIDEgDT4+IA1lbmRvYmoN MjQ1IDAgb2JqDTw8IC9TIDg2NSAvVCAxMDE5IC9MIDExMTEgL0ZpbHRlciAvRmxhdGVEZWNv ZGUgL0xlbmd0aCAyNDYgMCBSID4+IA1zdHJlYW0NCmnD0T43LgGCh40NDADsJgQD//vTylZR 9ddznEB2wXTJn0yo1Y53PpIomPckfbDbifoDXmJFjDzf0g2jInM0dc/aLRNd3Sd68pW52oKx YcaTolzTIWCwt+3BQKIZbdAzy/YL1lWE+MwJut8Zmwydzj4QC1zEyDOJ1WrqAhvEQSy9ZIhy JvN5t8+RodR4GD8ctVk1IAW8pKDfNeEkr1Iv7uiRmInuIl+5/lBC1naa4JkpPkCnNyuFBV1r qUL82QENOCJ6TB7zXaQYCgkQzVibXcqHxGnvRRPYnBPhInXkp1M4bBiQCEOvuTij5ohtJq+o czxZUN77cEiTbEG5zoKmLWdCxWRSFOYLeAUCJ07/e271EKONx4I9OAD4RuTgXsm+LljUIXGb 00BfWur1hqOHteZbRp0o/2x9NLc3QHaanOHgN3x39SEym2lN96UnY7r5yTYDNrkgeC/ZoGMd Lp3tOuMJ+Rf73mbGjT5Gea0e6i5zJo7xOCJb1n7/p12e90OywwOW5DzjJ+5o7Q2MnIKLV8Eh o6cu7WFaUWoZb6NzOEjM1MZmlXvtoNWoAalTokLwtlvf/YA1q254oxwQlO5e/TU9DzI+lZrd ibTWrYO0TSnlAWIJDBqZQbZD5IUmg6J6CQcbrDAZVV/NNP+Pfr8/t6gFi7vg4QBnPpJpqMw8 kZ33mur8J/OwrQ2eur7pBzLpUbzpiE6zw+TW6+OKvqZEQxT28HuX8vMrDSw27pJ8rTMXKj+g C1IEXRGdRlVZPuIhm6Qne8oEq5Re6nwdlI6atng8gXvuQdXXLKC0KGo0nCd6vUfajw8l8nu2 JE/K/F23PZO3qumq3kgKUyjErrjR8b9WVC7DA+9KxzsyTHMM2UaX8E69AWQgOF+SFATAXGzE rTT4z9D41UB+jabHEpebm4lvS2dcOnrncK+tTLhk/zfyNgKijYRsRCsM54EPHkTIazxaorUO EfSpuYMH51AeIXftH0piZTxmAj6fPOn3ZqMGSdpvK0hNJAfciRo0ht6R1VI7O9QH6iOjSiOu LOYNKSRLoF51SXRUQifLY39gSqqCd+Cjs23YyWqcN38vf3N5C2IrEfYHKHPDTc7MvXBI0D4e sK/mqK0KDWVuZHN0cmVhbQ1lbmRvYmoNMjQ2IDAgb2JqDTgzOSANZW5kb2JqDTIyMCAwIG9i ag08PCANL1R5cGUgL1BhZ2UgDS9QYXJlbnQgMjExIDAgUiANL1Jlc291cmNlcyAyMjEgMCBS IA0vQ29udGVudHMgMjI3IDAgUiANL1RodW1iIDE0NiAwIFIgDS9NZWRpYUJveCBbIDAgMCA2 MTIgNzkyIF0gDS9Dcm9wQm94IFsgMCAwIDYxMiA3OTIgXSANL1JvdGF0ZSAwIA0+PiANZW5k b2JqDTIyMSAwIG9iag08PCANL1Byb2NTZXQgWyAvUERGIC9UZXh0IC9JbWFnZUMgL0ltYWdl SSBdIA0vRm9udCA8PCAvVFQxMCAyMjMgMCBSIC9UVDExIDIyOCAwIFIgL1RUMTIgMjMwIDAg UiAvRzIgMjMyIDAgUiA+PiANL1hPYmplY3QgPDwgL0ltMSAyNDMgMCBSIC9JbTIgMjQ0IDAg UiA+PiANL0V4dEdTdGF0ZSA8PCAvR1MyIDIzOSAwIFIgPj4gDS9Db2xvclNwYWNlIDw8IC9D czcgMjI0IDAgUiAvQ3M4IDIyMiAwIFIgL0NzOSAyMzMgMCBSIC9DczEwIDIyNiAwIFIgPj4g DT4+IA1lbmRvYmoNMjIyIDAgb2JqDVsgDS9JQ0NCYXNlZCAyNDIgMCBSIA1dDWVuZG9iag0y MjMgMCBvYmoNPDwgDS9UeXBlIC9Gb250IA0vU3VidHlwZSAvVHJ1ZVR5cGUgDS9GaXJzdENo YXIgMzIgDS9MYXN0Q2hhciAxMTkgDS9XaWR0aHMgWyAyNzggMCAwIDAgMCAwIDAgMCAzMzMg MzMzIDAgMCAwIDAgMCAwIDU1NiAwIDU1NiA1NTYgMCAwIDAgMCAwIDAgMCANMCAwIDAgMCAw IDAgMCAwIDAgMCAwIDAgNzc4IDAgMCAwIDAgMCAwIDAgMCAwIDAgMCA2NjcgNjExIDAgMCAw IA02NjcgMCAwIDAgMCAwIDAgMCAwIDAgMCAwIDAgMCAwIDAgNjExIDAgMCAwIDAgMCA2MTEg NjExIDAgMCAwIDAgDTAgMCAwIDc3OCBdIA0vRW5jb2RpbmcgL1dpbkFuc2lFbmNvZGluZyAN L0Jhc2VGb250IC9JSUtBQlArQXJpYWwsQm9sZEl0YWxpYyANL0ZvbnREZXNjcmlwdG9yIDIy NSAwIFIgDT4+IA1lbmRvYmoNMjI0IDAgb2JqDVsgDS9MYWIgPDwgL1doaXRlUG9pbnQgWyAw Ljk2NDIgMSAwLjgyNDkxIF0gL1JhbmdlIFsgLTEyOCAxMjcgLTEyOCAxMjcgXSA+PiANDV0N ZW5kb2JqDTIyNSAwIG9iag08PCANL1R5cGUgL0ZvbnREZXNjcmlwdG9yIA0vQXNjZW50IDkw NSANL0NhcEhlaWdodCAwIA0vRGVzY2VudCAtMjExIA0vRmxhZ3MgMzIgDS9Gb250QkJveCBb IC01NjAgLTM3NiAxMTU3IDEwMzEgXSANL0ZvbnROYW1lIC9JSUtBQlArQXJpYWwsQm9sZEl0 YWxpYyANL0l0YWxpY0FuZ2xlIDAgDS9TdGVtViAwIA0vRm9udEZpbGUyIDIzNSAwIFIgDT4+ IA1lbmRvYmoNMjI2IDAgb2JqDVsgDS9JbmRleGVkIDIzMyAwIFIgMiAyMzggMCBSIA1dDWVu ZG9iag0yMjcgMCBvYmoNPDwgL0xlbmd0aCAyOTIyIC9GaWx0ZXIgL0ZsYXRlRGVjb2RlID4+ IA1zdHJlYW0NCuT9uTZYRtSlm2JUIJo7EwdP4xO5UWAi4Ds/SQbrKDZaKopw+1Ipdmf3b3pv FHQhr81sA7FO27IpOTMoqFbMXQhACyhUZk0ljfbXvJgPrwNugPkZrjtZKznWMMx405poA0K/ cTqDpwpVSlZ9DZlWGkSltbD6tbbNYZvncc6jvxHz0NBSK9xyLU88xO04EHKmgXMc4HPpcEDn xALwD63e4nszI9lrtUqmdd39XiuY/qaWRMmHfJkj2TeVLNrJTifPAFaiGApEm5WM59ECH6pi Td7KFfRzDblQwIXC2HDczCK8Vl3LXnADQmjag1cScushilB9Q3jdq+62qsXvsk21jK6yaRtI Ir79O1gwbWrXgtSuAA3v2it+b5puOXt9G1nhfQjUwpzz2AU9CxmvNQnYx6CHgI5bVmqxZY6v MVZ1dQXofkiGFc9vmq51HLKPHbZR5MF1Gu9ziChN6zvrtqJZsVAUYd/VbyqWZoKAF5vZc93X w6wykjLpxcHns9iUgP2yqxEkjmcixHPnhAxJUozXxDdoiJbnytADfFxS0JqJxSO45BL/c5bf N+Lxs1vIyxx76V3gUlcVI/AiyUrAkMxu6/S3/7or2vxXBiqSeNsASVYBgzj2QaSrj2rcAtNT xZ9xkWxIN7woF03LrhRyxs2B+R0aSPTU836mupP6kuNz4yrC1mZ9ZP9iEMhWW7Grdc/2Lddi msa9U6b35jSakR5yV1/meqLbmPZjs+5RJQ9Yu6Z+NBfgNRFRVCWVlKecXbrc86s11fzKLACS WJbzG/iwCJ2E4lFlTPmwKGlas5Qu3+KR9tw9R3HZzq/Qa0VsBDT2+oB8mUlClYrR+dxTOvku SWQopcLKkZVlj2bs/PQbQ3Olu0fcjwhMLEk6owbEgPXQ7EBY6Szxt0jdGAF7dG5WEX/7RcvR mqdIl7pz04CpMgv+0hOWHxaAn+djoNcj5atVH1S2oboxcGi6/30CMwNErP5arerVA+7knYW8 I17dUYlDI8X8qwpPNbRamRj6W9QMlgPkBwy9RZo+2suxWQM3q6Q+jxypHk2TlKd0T9qxedWK u9WLOongqnTGcvJNsGaaL1O40M9e5gk0HrtHn+HPCuv7MSubDHE/pdDfJZM8kBjjzHOknniq MTuPxDXCaNvzLsPF97eANo5Ab4V4+Ejr2gpDSv4L0SwrooW+3en5sERZT5nu32dZs7QNxXf6 hRy/KLRFyLaKZj4xrxK6WzvTrSub6lSjlIhr0Onf4lll+YMIFVDCz+SHrLJ/oEjdOc3HcLGU OVO7e3vNJfj8VTdf296RC7uWoectfpEZM5BQ3EyQ7ywi+shMw+0IrC+ZzF4jXg2cpDKoI+5V SgTjcOmOtn8BKUYrSn/Xavb766ehuRpEL9rEnpsDJnf0BIyxFlSiToqxaY7iO+iaWQ0CJW2q P2WYY3E4STlVqNSjXsajTEoPqGIMFjzs2ggFOXSJt7zuK2XzSA48kipU7xwFshiQvByTQGP1 CuqixrXz4rLV+tEhkWrSd7KvPN/g4aMmklnbV6i2tHFbncANdVMokAFd9rd9dU3v3jI6U3SD yKSWZChygbJoDQlmOXUvl+n5dGcnB1JEcIU5WuqB5uSXJ9VuQp0z62fgzi2Azly3n/giGZpy IafTi7wCDYH40sMiSjcVCg8eVbIxpntcY8qxpOIuD7bTaiWx+L8WYtY6KkPce/Yq8vT0DcLe pJbxezV1zt+otU642+la1091Fdw/eWDVLSIGG2ptcomB7jXql4GBOsW55vJfeD0PoaSx4edH uJULw7oeqwpmdR2xt60tluSyxdNEmOdHtgQFvBw7i6Zni+dGnEqodAYt5h9KaZgJqZIbq7Gj RJlSP7HfrMeN38BKt8s33MG4ywBnkPjo9VHCn7hFijMRF8GffcessV+6opgHuCTrPs5RjGpE 9EXfuzU9MTUNrVyD6fFnc8ye39jH8GmUicWsQXLA5GH8OosxUcyMxK6DkHqFcVpqDu3VwUbd TRr1npbPLmZMbbRrNSIBDxibBe9lWVMT3pJ28TAFLjwwpadR5FEmTHm2uCSQidjH2qLIzgLP +YZ+WrFLFhbSMNKW1hpsgRemNWejk+4fxEYqMnv/1Usb/xa0/l9Gfozzim1kNaJXdtQvvQqi YvYAh5OUAoRFy2iiocXg5m6ocfec5Ip/OIMKb/bdRWthAc2OpuaX7d0Iw6F+pSoIodovFq/t E/d+6LjwhpcLXkSyCRVh4VqDDjO9qtgVc8kh236N7K5vhmG0rKJtDe6cM3F4AjlFPYlUMVx9 6bjUCP2tDKTKmsD2KMg30JNOHjl/0PFrlgP2DrbAySuPPOhY2e4rEuO8ydT1gRfROGvwzlrN wuMfqk6IoydQNcPMn+V2b5wPNMXqSWQwUy/L4F0oVmIXTIZ1QAOtIwcEaPKZSeQ781ZsK/35 b9kQ2cXsuMYnOz4jT+zHeJOhw0lmdS1XiRj0RdRz7h45ywDZ76zwkw8xBHpki4k1PlDJh4Ms QJm1E1cpVgITy7FtTaQOru/CuCEHUi/K5VXTv9dBgAa2r69P3/SD0YlbkVhD3HEkqzqUIzOr cBa8GQT/FnhVg3glDQeIkSLGVg+IVIPdScB28hTTmiDY09PwedJHdv/zB9Ep+opIgRwGofpH pylxsotW7NmxtgPTsKhTtiA1zuNmcOOnQtOTI+9zRdYcBTWOoPSsOSBbVwSeDnR9nXy5Twr/ Uw0ku0/Rcmay9l+oQRAYVch/7Z1Eya9TSVxlFQEMRmZGrZhkbX7opiE8slwwlWx93J+8eTox HBpUePQDkO8hCqVh0EOwho7oN9XwMT39dKe4P19gQXwf7ZSAo/Wgh6+3nepil7j2irKuzIdT 0GDLqgJ8RkqyJw7UtOOD8dRuBXMOI3MJ0FLbKrBXNKIyiueQ4P6B+Pflt4FnyuOhXd12DAeg uQRGRpojWYI3stuIsbu25qjTJpJRLWLtSOBNtFTss59as1hvrCxJ9RBWiLo0PBnDOcQ6RYN1 EMmuk/RGzv2limCowXfEGXKk6PdyOOuES7dsBOh9/Mk8WaF/bour6rXYsAwG6WmI9OKvGpmi RlV/90/QaxJpKezHGd2D4vCRU+hoMXXH6lV9kD9OlXWQw3+iEMG+5KEhGZuo3gnWg7ccdbIT mcg2KSMJxFCppnBMfIhc1nezjej5dBbhK+OKi8rY2VHQc3rVYkWmOWTMJDaippxKiAUjmu8d +C5wkX4J6+3ngFUQT/KYF4QGdRtHpwtA0z7V2j1vtB5VmRYaYIzJ6kGQ2PePMRMAhV9RsRpb mRyUrQL3KwjO4CozjOqyuCbHsntOx/bKaqTg8CAxasE61rh9OnjJ2RnnTyLhI4hNxiQ0OMbG H4I1NklkzVgAVMIGHV7T8sIS5yvNmRtCaqeyB8+5eDhu7tsKh4nEZ61JMpNgWpMtk5UJv4Ju Vd3ClndbpMVpqOBagpYELWNqQ6C0a8MzqtB8H1pLVDaZQS0GxLqjJvcG0hJ8r+3h5akEncGu amHyetOaaO9QDCkJ+09Gl28rTlrlZZ7wbBPeGcudEvABfx4Q4n4+h327CRcN1DHvNyV0PCn0 maxLjKve+CvzXFviu3ZF2TckzyZRmvYHkVZ+fJlUJCcMcooGLA8IabpqcZzfOZbSF6psfTlV ZIKDG+QD9V2upoaqeW4jGxiUL0vSatX3WgNQBdVSDabOGEe+G2Zh8/9Nfx2/QH8+i1qMqV7t vH74G+tllZVM4L0IxGfDQOGVrE17sliRRBc0HqBzl8lWGXR5sjOsJRHrWRtNb88OfpXNCmQf KBxgNPUtwB4agvSoqpezKA2h7sbvjwggzdav2gAalmrR7M4YTaITgov9LdYI9eQ++u9w/pB1 efJdPMBUnFSW/E9ODs5CmQ1lbmRzdHJlYW0NZW5kb2JqDTIyOCAwIG9iag08PCANL1R5cGUg L0ZvbnQgDS9TdWJ0eXBlIC9UcnVlVHlwZSANL0ZpcnN0Q2hhciAzMiANL0xhc3RDaGFyIDE2 OSANL1dpZHRocyBbIDI1MCAwIDQwOCA1MDAgNTAwIDAgNzc4IDAgMzMzIDMzMyA1MDAgNTY0 IDI1MCAzMzMgMjUwIDI3OCA1MDAgNTAwIA01MDAgNTAwIDUwMCA1MDAgNTAwIDUwMCA1MDAg NTAwIDI3OCAyNzggMCAwIDAgMCAwIDcyMiA2NjcgNjY3IDcyMiANNjExIDU1NiA3MjIgNzIy IDMzMyAzODkgNzIyIDYxMSA4ODkgNzIyIDcyMiA1NTYgNzIyIDY2NyA1NTYgNjExIA03MjIg NzIyIDk0NCA3MjIgNzIyIDYxMSAzMzMgMCAzMzMgMCA1MDAgMCA0NDQgNTAwIDQ0NCA1MDAg NDQ0IDMzMyANNTAwIDUwMCAyNzggMjc4IDUwMCAyNzggNzc4IDUwMCA1MDAgNTAwIDUwMCAz MzMgMzg5IDI3OCA1MDAgNTAwIA03MjIgNTAwIDUwMCA0NDQgMCAwIDAgMCAwIDAgMCAwIDAg MCAwIDAgMCAwIDAgMCAwIDAgMCAwIDAgMCAzMzMgDTMzMyA0NDQgNDQ0IDAgMCAwIDAgMCAw IDAgMCAwIDAgMCAwIDAgMCAwIDAgMCAwIDAgMCA3NjAgXSANL0VuY29kaW5nIC9XaW5BbnNp RW5jb2RpbmcgDS9CYXNlRm9udCAvSUlLQ0xGK1RpbWVzTmV3Um9tYW4gDS9Gb250RGVzY3Jp cHRvciAyMjkgMCBSIA0+PiANZW5kb2JqDTIyOSAwIG9iag08PCANL1R5cGUgL0ZvbnREZXNj cmlwdG9yIA0vQXNjZW50IDg5MSANL0NhcEhlaWdodCAwIA0vRGVzY2VudCAtMjE2IA0vRmxh Z3MgMzIgDS9Gb250QkJveCBbIC01NjggLTMwNyAyMDI4IDEwMDcgXSANL0ZvbnROYW1lIC9J SUtDTEYrVGltZXNOZXdSb21hbiANL0l0YWxpY0FuZ2xlIDAgDS9TdGVtViAwIA0vRm9udEZp bGUyIDIzNiAwIFIgDT4+IA1lbmRvYmoNMjMwIDAgb2JqDTw8IA0vVHlwZSAvRm9udCANL1N1 YnR5cGUgL1RydWVUeXBlIA0vRmlyc3RDaGFyIDMyIA0vTGFzdENoYXIgODggDS9XaWR0aHMg WyAxNzYgMCAwIDAgMCAwIDAgMCAwIDAgMCAwIDAgMCAwIDM5NiA1MzYgMCA1MDIgNTMwIDAg MCAwIDAgMCAwIDAgMCANMCAwIDAgMCAwIDUwOCAwIDAgNTUzIDQxNiAwIDU1MSAwIDI4OCAw IDAgMzgwIDcxNyA1NDIgNTQ2IDUwMiAwIA01MzkgNTE3IDQ2MSA1NDcgMCAwIDQ4MiBdIA0v RW5jb2RpbmcgL1dpbkFuc2lFbmNvZGluZyANL0Jhc2VGb250IC9JSUtDTUsrSW1wYWN0IA0v Rm9udERlc2NyaXB0b3IgMjMxIDAgUiANPj4gDWVuZG9iag0yMzEgMCBvYmoNPDwgDS9UeXBl IC9Gb250RGVzY3JpcHRvciANL0FzY2VudCAxMDA4IA0vQ2FwSGVpZ2h0IDcxNCANL0Rlc2Nl bnQgLTIxMCANL0ZsYWdzIDMyIA0vRm9udEJCb3ggWyAtOTQgLTIwMyAxMDA2IDkzNiBdIA0v Rm9udE5hbWUgL0lJS0NNSytJbXBhY3QgDS9JdGFsaWNBbmdsZSAwIA0vU3RlbVYgMTc4IA0v WEhlaWdodCA1ODYgDS9Gb250RmlsZTIgMjM0IDAgUiANPj4gDWVuZG9iag0yMzIgMCBvYmoN PDwgDS9UeXBlIC9Gb250IA0vU3VidHlwZSAvVHlwZTAgDS9CYXNlRm9udCAvU3ltYm9sLUlk ZW50aXR5LUggDS9FbmNvZGluZyAvSWRlbnRpdHktSCANL0Rlc2NlbmRhbnRGb250cyBbIDI0 MSAwIFIgXSANPj4gDWVuZG9iag0yMzMgMCBvYmoNWyANL0lDQ0Jhc2VkIDI0MCAwIFIgDV0N ZW5kb2JqDTIzNCAwIG9iag08PCAvRmlsdGVyIC9GbGF0ZURlY29kZSAvTGVuZ3RoIDgwMTQg L0xlbmd0aDEgMTMxODAgPj4gDXN0cmVhbQ0KRy4yK/+GjW7hgsa3B2YHHp7aturc3WAtn9wL Mz0yhgZeDN9TM4eup3LNFdtkIRhuHinLDU9Knmwphlj3nk90HY9LZYMKClTb1e2ycn44MqL0 nbHbp37oFx5Hq8qU4Z/eQTHtodkJHzSD8HOuDhj1JI2aXhKrwmeWFwu5r5PvmP5+s91ei48E O+fTk1LYvljI/wSpJ3RV2hUNUeg8T/ktqbeZmczU1jvW59165Wu51FVavlJ0ufvEOxNgBxkm ja5nfsSywILh/Jko9nUcBotjB6ce42fxTpUNtlCtvPezan8wTzgeAM9sGYKqT5xD2W6gPZmc z+G8tWUmRHVOyyng94vtOyG/nJdB4ZFlNnuS8gFiMsPaRsPXi9eLouzpqI7X+iqiku7AIhXY WG5ITxZin8cFiYiXCISwuIejByPio3+BiJkai7Us3XOQvHKPlRxjiUd17ijxOU920c7StCdI OdKdMp44i/Yp/gkb1F1xwTte0B2B3BkVeY96RwCpH8uGy74ZuSdW6c5sEoXjNGjxdtPWpwuB ZVZRU8bv1v5PmXvsnpctM2qS/Hv3mn764F77XAe3vm9tnUnNPvZm8eSRybkQvXRhADotSeEz GA2FJlXYcd1i5qSbquyx9lz2uDNk8WjHOhsD0J0eGcYmhOEM3sFxTLy6DbkLEUoSPLOswES6 8mXplwR/3brQnv1C4E5rexXgB4xI4/CyhTvRB9zmkd2sDNC7IVu7ijbkf821CSsiMjfNwpPd vMCQ/+WMqT64QlpcX68R+G83z19tcK/MZRC/N6+6Bk+NriC9JXIIVOWylJsnvHKSnZFeL1MC bpyBIHS++H/jRxNxnAzntGvJscrEXQKwiLWobkDoqDTFwwey9AqJQJRzZTJzFmBZlIFyQLVS L/0dArmr8kp9+NAMK/sYkW18+GlbtEypdbllA8UkvgtYHovxGrQ22ZqpY7bA4mpBpUNhpC6Y +bRgTIPMiLwHD3Qgv5f8AANNccYGOKCzEL3b6dwqIPexpyhRwRHjlBFD+81pnpODhkXmHeUZ CdhHVvTDJRvlyjY5OzlpB+9Om2eqOAIPTPIhO5W0snPgNGE01Wj7eQb9S1xEyCQieY8Q8a7I qRdPOmkU/bCGxmT6LtLznLvg/p8Dja9oVqn28u1sa9hpaZKV8rwg2kd3mhLtaxf/gSz7eiiv ym1u8c/D7+EjY+05L5z5bU4COpXPQXBAxIHpdSwK0bPoWcmcvMujpmNFOjjzWZ+lfxGfjEzg wQhqIv6Arau44UDxrnqeJezN6XfOzNxuwSgqZWS/mnN/ntoCS5uBTHL/p09gyMNikpoTXP3I QK7JAWdj1KkCFVv7EPBWwULGLGIX9b+uU1cqfanHafit/w9bqCvNBVdRaE5hmL+5MpTE6J7Z I1IUglxCuQrI1eIF6B7W17KM+Wyhh8txMEe5dNRtqhl5IfsYXwFu1c67qkLb/Uehgpn/Trb+ JIXih5K87v6J0bYRPVZ1TtspBU7dB8oNlxRrq23xwJu3gFxuJ9hhMWJBA66McUQaNegPtZpM y6SUB0uJ1ITjBoEAseS/zZaDkYj6FiBmCF5jGtiX4iHMXvHTvx+abZvwZwFT3sBDHSx6VCwX SxJZy4X9gEgBzcJiKcjhtdNJkNPnpHiVl56E0LOGb/6+dhZX7KyUGCxqInwhJPJWKFMOrT2v Cabd7p4gwkNfRUnP9n+aL2zGWGJy5UTONGuo0dPWrDrAbU4n279cFMnT8qYiAJfW6P8Xtpvs 0iY38p7kS3Y+Y6hhrKZJ3ZVu2CWpr/0RycU3QHcDr0Ipz0kLZrY0zsLDam9T9lUG8AYW/MiR nUyFSaANG3nXk1GSSQNP3WyCb77CnIaVeMAAXoO+t25POqn2dy+AbHGpeLNefk2Or7DFmdIU qZHIUaxIqjeqGk0dQRSC7XDtZmLSaGuwreODGVrXqNmzBzO/gkWFjFmwEU2JKO4zB/ZnkEl0 KLuLHJd9h0n2tGRDdl1tIwKJxzkQwuyvMcHPCkKiD8CVBeiTPKKAFirwmZrko6j2Srmj10fk 8ibYlKP2lMS8+rbPwib6H1vj1Mvx5qbPzEujaLLQhzQR4ORrJlfelKzb++wjWuS4nYNyXka0 e3wdrmQVPSdMN1fNYhF4KW/Noc/IZlLAjbVbXhCkht2J2xtMKUDq1LFpSXcCi7tlgCDLo+k8 mpqJGJRKl1y8IkjBEJXswA2mkAUj6Z2AXMW531sa11DkgFAGMftFR15g42+yKl6HCeqaK7Qr 897ndO+19OAOrz25ZCaXnJx3jZyD03rG2RwnytjIyO0UX+dnya9yvVgLNBZhCEoBYcEvANtS 9ud6GbS8/aIuqAU0HOwp4in59bGyHBrZ8YwzX4h/lsVqic+Z/Ds1d2Qr1TPTVbN90J6v5wQP MzteSN5sJlmNymE+U+GxZ4cKFR9erefxVENgOQg4MU2V0r094RmAq+5gZ3NmafaR2zx929b2 XwgeHY4MLCpOjUYoiOTpBySr1kgI+1lfE28bPPrmXDAI+noRNZKifK7RvUpiqWjB9ZoyDE+p cRo9D1OD5/9xnkQRbPQwPUclS8BGdJ31wmrUxCOAX6A5kN0587vllzNkczfZsoOVybU6s0Er 4P30K0+HqZfceYFm5vA/TYqlF1DzKHvCp1Gl31b/0P5YYHsqRBe7dEODVwr/9ci5HLQTZ8A9 rb5qS6PTWZ1KXUCSd/VTwfMrFIQhCIdZ29a9LJiMXF5S1j3SHh8M6ypd7kRE5lHOtsvttXb9 9Evfj2uTbXjnzvGAr5UUG08b43kuVEqw3gm5kjkJRFI+MTxAHfJT8JylRBa7MYELhreMJl2D fRAh2qm6X3vdeDcQN+fsEliZu7gCzUoJDmszzvkgPqj3vmzZ99dYqy1FV6/vIasMXkQSIOJR FFyxZasq2JMhzOOT52nW4RoEL1F5Frh2FX5/fmTj6frn36ezcV/FXF88lve2h3zCIOT0pish hpgXeCMAnJ6BXZYlX722p8STzZQcIoC4Ysl5eSjyVL2Xa6JImYoQOLg+pxQxojJqHUxZ0TxS 2fFjvOUWuBATthDVg6qJugNar4TQWSZeKEQuFIS/lhhD3x3TBsa9TZeKWtPqpjmbGjVDHxiJ JDR2Xa80nqA0VxanlkC4d9XB57INz6QuIbg21cUjH8dhzR+kwaRU6xJkyNCcahaSMKxClQgm M5xlbiQDkTVBntFHsPOweQQgJOpgk/Y604qaHCyRN/D/1hgL9VnH6FFFf0DSh30TJssSNSSt YnQxdMQPl0sT8LXfYNcK6JcQqkzA49Svs/18YM4Sk6wN9AldyRF+3XNnHm/t5ae7A/DoMxn4 4bvyDEHyKWsE80Hi+WoG/7tsqHXuAwd9GXKjef5PlbNckIh+SnNKhrd6lSHEaWpAHLLDIIff Myw+JwyObYL3HnI0DZt9l4I5b6YYdxSnIZDOd2holm41b0uDfbHG5v+c9hwCzvCrWd3TW56s 0xTmhYq7UhUn4O21mcCXcl090CMRJOyWG/TeesCoaksgeGPo7+jgg8AEd0z0ptzkpHiUhR3k ayx1PcrRQDjVnuT0GzRr6kKBz1hgvA4l3Cu4PoiV7OJ+KRgysI6BhrpSkjOsIDiwV+xARXx4 LBy0wjr7lbYEwxSPmjMPt8vLZl6fCenWL7JihpzcLhJPinFBabJjHRuCiYu4zbwkFyeiPg86 5Bze74jaPDDj32ZpOOj4H2sdKyG3EI1obPhYXxKenS8pVnUjkWWvEC86mlGtup57nxbxixT3 IAKYMcB2lBp3eqfnVfQMcM7DNxWCn6dfhVoWE108lhqwwkPwD/ngP+8hwF+OH8SS1ZJfRHds dXX377Bb50JUUx1tSFrHvNlJ8wrRXNk9JOF3Sp1E8TArGWBf3XONtbdKQh3LDDR3DFC9S5If 8UJu534XCyPErf0NGEuT6qNB+XpVA35hH98MM2kdTQJk8nptm4LeCcbkxJY4B5th4HHU+uBp HW2UkRIYRHQOcTuPF4DGTMQ/zpIp3plvLHlEbA92Q8xxwxYpEH2Jnz+vDIvral8FCyKoZ/PN 9d9yN3YzUgCeWOQRlB/p13BQlZfBh62cwiGtTAZew8OJvmjA4MTQJ0hkldpxCNDChfv5HpC4 tYzEjQdGLw9JBpmahb3VQP9XhPmQB1bZPnpa919NUGDYAOj1UmLvxcvP0Yfjb4H66MKfyEY6 tt4FjJvPnCScDSE4eUFy8NpNIAti4t4aZJJNqUXJo/z4pK9pT5naI9WJKKZtgYTaSlzzzHDP CfYSaMbPL9W8XdipJWgbWO00D+mJSU4mdXUUDohnVnWnsP2wQyfQAgNllf+Ehos9Sub1TzG/ BVm+DiQgC8COq0QLt7vwLHY3UaSddoZXTRuJD7jVBp7CaBN7pfJWtBpJE8qdLOxcRqdTWOsn C/S5IvSnhycLUjnv4PF+xOOj5oVjCpETSPgt14p2LIaHTc5h4Vt96jVaNK5j7LLeLp+4FE9g s4QIpiCXzk4TjTN6PW44CX/kJ8NPme7FQAICpvLwnvrjKwa6RYhiDwiTavuIPwtmgnOVO+SA ykrv1VFouBe28YxjC5banXaLCVnKIjZlPY07W0AMvUxH0rnA1kI6GNrkq1crU7VqzYZ7318J NZeIpL3dZKYFfsgpCTxKLqAIj3ukl1u7FDrJijBds/5dw+lIgJYkGHzblqcxmQDlsbPwNHJt bsx8u6eqOlKN/I42p7HulJo3C3UK9to6dme1s0rVzcC9fZdMJ+Rsu/8Mgr8PHZ/i4y48kR5F EZ5BldYq91cKSI364EwEwrTuXJBEj1fby/9GZYmBw3oY5EKGpIHiihoqRuCHMJHiivmc5F3w +7FFFJRpZYyityWPrsTB/z5smCjhKcYhnjjVUqEKwdDdOdpzJHuanPjt7TruuiXPQlAIjRa3 bWiwMD9404kkOYeS7dFjbFGqqJ50VRxY1TEP/dx7x0S+awnb15+pjYbRyN+XzeoJx9XIjyjO dTpdMvd/F9EPWMyyhO9ht4rD6PjfYRF4cWhX9nVPXrVvrwRU36SPqWpWL2D67p/mczmkkHmN QWsVV0FZRLNlqwuS0IyyhUoFlomeYu6XS5azKG7h448FY9hIYH77rnk0SE/Pqjh5b8J6rUB4 PtbJ8oaknq2sAsS/DxvnISWUgQe8t/UAV5S0O8K+j5c/8Q1VSJ2g+5UGUdamq0hjNWftiUQd 4OV9b3WB8QyLYXEb8dLYrknp5PrZssLPI3vRK47Z23xIWPy29HZk7GR0BadFXZZyQFvuTSd1 9Dvmv1Yihc66ErbYAiTd1Er3D/y6VxNGNrCCd16/aYotDWTperFW+JCcB6a6yuQV4dSWo5in DYl2mMP+tHonqU+aP9nAgbKjJM2gXwNQ3UC99LxQYYN7KaDAIVgNMiQ4ZzcGbh3Bt47dBxfv V3VeBT1yg47jzqMwIErHZXiK8+oq0qPHkKwMGbpMpJEwjKBSaQFV9QSWpnJtOAnmW6SLtwq3 Y/wJVUbAUx3GkMTXo74aehEa0j6KJ46damPO/o6vBL56mRGJIg5UIxxj9ys4YDkBRLxzfFuk QjUFTboFrQH9YdJVawG5/UabN3bbCiaHei1SYYdcrYVYuWZWiVMa1W3xDHQDVoG1q9krXJ7c Os3BXUkp4f6mxukAn1h/27ALNXh0DrsU8EQdfZbYtdYYZ8IF/0CAszPByWcGqWg/+j1hGalP DbFKJnkHI3jQea+LX8nDFh0xMOUGP+UD9y10RLo4hRiXdPa4ydrlqvwOd+5D4Wt4YRVwEHeV joYPq424QHB0TxfYLjAuWDkXsSKqwkYzHJ2FI5aQCR9THz7lfeThhxODaOxSWa2foFm5KUMg zggIiH1vg/TLyqmmK/Vkwq1sbOAAZQIpZAa1cZLqCkYpOsWR4nVnsEihgHQDMNSqZEqbcCWO qZBy2EZDxeqYR/VJFvR9+ahYWaT+9PNMv4DAWXMzscm11gGIrO7/IrzPis1LE8oqkaSpB0el xyS+PIE2sxQfSNsnxVcSR4n+D4QC2dVfn2i2eL0biNK0/CS5T+cHzPVJzDzyYeEjoP4quN/A mQ1S/WMS6K8WXsNP41ojhPSMl3Y7/ds7gAXterPk94oUkJfl5xQCR/OAuOrBrqz7MUtB8tUK yOZU3ZcQF2BzdWsLI9HGpPzr4Ua8rPHmgOUzx4jFFYrStlhVgRH9aV55g4UinhxthXcegARY Ujnk5p6ICU9fdpZLTEMfGWWmH0G0zVf5J5XXkAmXxP5szkbdr3pC3iNOuHV8Out5RO3Nx9f+ 0LFqnoG55/s4Wf+eleWYqXTGYdR98Oqk+tAXaGSJqQoMCk/FW846N0oCZSWTgfCLtAF4zW1t 8eiGKueXsP5QHvei8Rseq6i5DxOBI99ITN6kqzwcIuSlf0nlN+RL4hS2QvNH1VY6B7CN0cEK /5WcXJTgZvHFcJmeHuNi2f9K1HLc4rs2sspiD6MI9uA9yNTDbM+KaPd4/0OnjIx9YvB6NfaS JOtdBxibL0LPHacY3iU5M5JzhOai+GkLtGjMjUWgRXt+GJhRdWAzfTiP87L5HRm6IXTVyelX lDovbF6Lke23YSs3zxNXRSs03kSV0HnOii/k/SCAqOshqoZ8rWG3rPgPN8Kpc/sV2vRE5kS1 roD7gAiDYBojN7B3iK6dY3ylluPA/AzRPzL2Nwc6h8/7u9dCCUVP47XKhPhRaVLw1B5o38Ue fM7LjfFSUNFNuaMvrXXfY5hTJh24Eq2ryOyjSOxiopwnfdlAieZH7cHccZk1/UxcKA1JJzdy 4aLh2xeCgJYrH9/mFOqj9AM7lDqkmbwvvz5CWlDYwCxPngjW+Q9C52V5nySGQayElxwGxDdt ogKgKwtHZYDjqWrXCfAV26q3iJE5Di4DqgX/AotCHq4jfzON2ysugU9mol7pOXCiTF2ZkQbO tgN/mjZi0wtZMZi/i4abE2+Pe65ErrK+Kz9ZRK71BxyGtU/InShb1Fbv8i3no+OqyXuYjwET gesXx8Yacg1gMng8uRyCMgJ3iLzewnTpeTznw0ZiTwSRO7vObkOqjcvm+XLvfFyjdkHVAAfu kCTcaX89o01ZChiQk3KzNdTQsxzN8VwMC/NF8j0JVxfzs5DQ2DJp0AMr8Me6QhH2XngbASqf QeNwUsIaoOAumIPRPryys8VwS8P4YthXBAbH7+5wgtDj5ixgod5dq4fKCIl5lhIDRyiSwkWC WNCVxByJtwJAkN6PSAFtYKfFBQNAD0iMxDyG7rg4iUHMBfwbr4FiQ8pHG2Rdh0Ldco6qTYri c0rx9OGKqDRhrfh/IA9lXJObxDLxwLDdZf2WtMdDU592wu2pbwl9s6FtAoTX6fXYNVDHPNaS Mj4lGZlPSV5kUqh1f/xmswhq7aesTYiYXOs9F8S5mDioDF5o8VyynkTIZburFfuu3CpyImbk oxDQb2zLmoej5NYmq6wZsxiZ/O1N3u1E0L6XLpufXf4lItQIHHBzrD7DGMOCyZqlJSpSymzc APQrZSJjl68uQ5eUi+S4+gucxWVn9XtrX0fLPIpNoUm3ftlfme91NvfLu5j1ey+wWYgQv2L1 YwWqXi+8voZKhNsNZSD0/5GawGCyqKhiTxSVyvpqXnimBGKYgoG9sItt2B9cy10TCqDo/Srs J+lH1J/1ba0zN1Mbl9RWlrBYJRInIRnM01oPWrXNguU14dDrl5uDE/Zg+arlcAH73qxp4O52 HXjS1UydzjM/EjMEFw7SBzokLBLJUiNpIfk6BHxKzAErrCiAC/cR2SBu0uXdSgPVO/nrPOgf XgU7GM+mP25dcwqNxNcUAC1/szEJxeU+6OJkbDjPvwYZsGNJDRDSY4BaRWPx44KqizdKnVQn oEN+pYAF+bEfAMZCfnkR7+OtJVVzoSbPSLOqIGDzHs20hJX/B0Jo0IRpSonqNvB31QLI5EmC g7/zkm7e6WMz3giqKlXzInk/zKL1K5pHmTLf9nEyuRoWs32gz2enVdYse+UiePPmXxl/HDOK Uj/0rR04KzV8Rfzv6MuhyJZ4FKZ3u1Yi1Kibez88NUKj/l0iUJ9cNWTmdAAAjdSzSiT1XzmR 4iTecfxbZhCZ2Tfe40D11k4b8zhEbToJL8IYz3XgqSm/+g1LlaX79II8Sfz70LsMRvKs7NVn ivI5pnc2W7uMmR5CNTQHJMib/NSk1A0P2F29trP9MpEnEkis2VpTO7hlItRkJqJlx1hVaQek I9l4SlGQHD5M6Lxk1jS0ijXAFnmbtaBnpy5ooRnmBiTJZ/DoyhoR2Pwu8GrtL6yj5MSHOTw5 ADkQwKj8CqWrED6H0NILBus1TniMrNovd6mRlLgkVuvJ+ukKDHaMqepTY6on1N/oxTnoZAhV K6tyB4hUmEdoduDW//9X6B+oL7ll6BPs0n0Qoqdq9SZwRSG3/tAgSkHP32NeUyNghWDGRJYg sgrVw2racURvedrEXSaXFx1nKgr1fkRg2/87Yarg6X+U+jJ0zH9Px6MOM7Z0wQNP4F6r5M1i YS2RDsjZ3j6Fc3NO80O0DEi9p6YwPKzH/FnBRU6A/aHhEGZP3z9oS+B3sHL2WkPQ7rp3UK8H VbK0mcJ87v3DJZVJVfR5Hse1f/jaRUM154VvCzFQPe4ysPVDj2RmDar5+0eeok2p9qAoZYVw XmApKljVWUs20CCld4DKUZ+1iNo7XepiZVL64SZtj3140In+KRVxa8PK0fb9FTyzj+4AbEvS RhcYxlJeyYhZIDXBELITQzxQp0bmoQ3dn8TGJUK/FxXEzZpI8RiNED2f5A19eqbVJod+j0jC 0Dx+vJR+C1841gT33kVSE6fEhIqo7xPeFnsiwtipWHKT1FCLxQiSLM+0zLhEpk5E6d7q7k63 vqa/PPUJrMLgXwY7k/gfI2dj4HM/s+BciqtV2Z9M/zwDAH3WToUFaMF3HUbReHa3rK5AqGc+ 1He0TNWLVOqE+1njwCeeYwI4kMEqSGprFoU6LKrEanOHOgwsv6mj0iO9vza70JKD6MKEY2Dc m25y0wNzp3NfwhrBjulxNuHxaGd45Lu1SwrF0VAhnePafUBXR9heWvUtB5JYJjwF7eU3LHBo Sn3Cpu036yYg3E+wGdQSKYlcXzbZiPkYesfK9U+tIC88P7DUu/N6Srt/xGsrS9y+twK6Jak7 m2LsAzKZuFbDH+GW8i1Dr0KY/r70QE/X/qpabCd4I+CNvitfGY1nI0NW5d3squIhckFkgAA2 Xiyt2melpqu4m9aUHMCCUeJrz7uwwqVD6kMCRd/OqRUjDivg9FQmt7qftMIqw9m1uLuKp48S s/lpVqQ75GvD+xg3OvwGz6+1dtAZjRMZf0YyRNDCU5UBrhBU5oradNc0ke0ns2WbLVcfqT4R U/UZYNx3artYmdT6b5E95BlfMD9YfFWbBRN3jimOdswipE5mUmAKtvAxLLu52wD6NB+e+Wff h/FHkBhcdrsd7fmSFVXTZsEzjtIaprRHB6N1qOLcEuhaCV5iubhCt33iLWJgE5x6YulgZyeb vEs4Wz63CFp5xZRBbFJ5DxtaXOQl6Nm3BwC8OltxMppZ587tUArQTkIlk9cNS5BE6coI8Lo3 yWwCuM1UJpXecONlb9wGPlh0IW1dbYjn3klte9OaGZ30UQjknCCIzcDZapzrQ+r/LKrXjnnN mmGxENr5YknTaZ4cdNMdm7bRs59ie0ZW0VtqBeqyOhEhsGH8PCMH4IronNQhC6xfXKQMRrK/ b1OHLRfAxBOsOqcjJjH5i7sS6ISe+Nmx//aMXz3Um2oDYJE8WmbgxL/N+HB9vWuS7l8zIWE9 As3z23dRw7IKLtn1yYSMFMOnDHlsDLTWiTRI/CtWQrqKgB38WMxTNO7X+6lWb9HRWJo7GSbh sLT65ny6CmQDTmw5//1hR+LiRRUI9W7ge7WFqzRi9JdxSKS19Vh+AmRZIdQa5KxyQWdd8sT5 i7eGdObW0h+qON/i648Zv6nJdA1M8h5B/RMy5SkJ6hIKKPXrVW8sFH5EwdRpbdG7GpiFjnSX a2dPyvwghkYP6EmWRyXzWvvikPSX/08y2t9jRGYs0ffgapZ7le7nCkfQ4SVyQtVCtGRB2xPm 7Eotp8QMbNHSLYjuu5PdAsdPNXbYc7+E32mPBSMsoFfOhFIsDvHyhNveAOlB53jmhYfmPdQH D9BptbrguB2il4aXVIPlsfBfbRSMjwlAIbpD8NFx1qZ3Ns4JOqMWN/tLHxvP+r8VqOV8CcTp mKajKDtKyzjwUCxv3aoBOVAT/jLOTHtr+7Tsyh7yc48o+rh/s/3jJONRHKswyj9i7sHsHZxr 00K0Ela1FXudtSkSwVIQTr00/GE7bSOSdOv/IskYrQ3kTWmLIt+Q7a3zwAbsIo0m1HzxCgaj 2njK2R3SOnp30pAV8oLHvizaqERIYom8NHkahFjusFEm9ig8Yh59zPUxLOPaMQZn62DBoZFP AgF3rkwrmPOmlNkg3A+aw38Q6yrRj326Fd/tsRjiBDL4/FNoZxzW6/LqZ69TRBCURoLcXwUo Z5T8JPYuudVtVWF7KvbMxwIjfoujqmYascvlcXuChOqmaUDABtHxXwvnyBo4RG/8pjzW8zdG oVRpQ0IBl2gqrQ9wkF1ELmMl52Jf1OmbWv1Mb6JOttNMKul5aYrYN68CsUKp4jDMDw1lbmRz dHJlYW0NZW5kb2JqDTIzNSAwIG9iag08PCAvRmlsdGVyIC9GbGF0ZURlY29kZSAvTGVuZ3Ro IDEwMzQ5IC9MZW5ndGgxIDE5NDUyID4+IA1zdHJlYW0NCiGQT7CS56lC6YkbRinUZ8cpNOhf Bwgt9gkWWt+N0/4kquEbM9W0o6WgnfZUNTRmOk9SPlzJcTF/j2JBaezWKDWthYEhTF7VvAFC j9GI6OwORuGbLyJc5pqWZTw/1/D3XHQiC4suzjVre/Df9fCxn26vwFNBHRlWyDJKtCQ6aSyu J+/aFGtFW7cCXTRdhXpffdU8s+cbFRptTqgeuWM82xAlzzHJo7LtqmzW6xuYq+SxBQIGvtQa nYdshjZ3RGr23WpTQMZd2olG0BkecRlE1B2oXZuWkjDmLCUPl/17IDz6NOkHR7V53/ALnJvX y+umN9WxjSFq26z/xIhjOX+OnqNfDFetAvZvy8EqJMAk4dueu1gML4vcli/2Wui1K1O5usor QgIDdp2v+FN0vbQ47pk8Q33PI1L6YEWiy/lh5q3mcI3JvIIwtJ1N9ARfPx3tfdK9QZU+7Xm2 UU7QGOgZ7YuXEX5KkAUNr+mwZydhD0wFn9kaNCQ7yWGVBv3geWQvNgpeXZ3a0mGFMNhuWI0y 7wAGDnhaA0MJyRFJpj1qOOCRUFrmtJp0JBMRUYBC4fAygwP9eSHb/fzOM8F29pk6hKetzRgo 7+R9l1cFXWGFA1EUvO7/S9xFP7xgkn1BIeinktc9ZU1LdLKZ0VcsRymHec9BKS0ULW0TQoP7 w4fB9GcWyG0aY85zBydI+frpm4QvCbgOEaOVKuY7xZPoejMsL42D0fhKTR3Qjt4osJKL5XYJ kY+lusLMpoiiIEmNegMq8q/nZlyoVmhj4d6/QAlcubMHXA2QiLse5a4NfSBIKMb17iW8K9zk gXQv0367fx5Gch1SzO3RdyvCQMVWoolWPmRskbAK8HWAfB1Vf4fwa5ZOhBaBH6yCYPSAEkiv Qj3cM24CNYIxt/6EjwpjXY8ahyp0Vv07xQDrDpytrSpHzqEtCPVV4hk4TjJXTh1A496mE3p/ zCcesZuaRW52rYckLk30gcgQOZNWyP+HqHrSB/QhoqNTHs4BA4rH3JeBFnsinorEqFX4PaDO 8zo8ZgjeFtQ5m239IR65ez1cMA/OyV+muWVt/QT2dQQXEy17jnYZHssv5KH+9QdwweWNtAqC 2dw6pIJt3B+m9Vvu6WuyTzP3p5rSbtPbHd5yHZZb6/FaUtRkyuX723PWPBTitKzMncB+wRDp A+dlWnsxza87sSgrKRub6bPQUBr9+/1pD4+r/NmbRL6jCLK+7B/V1UeD9yf5+ltSefoOR/JH W7CNkaVOD8dX8awwsCh3OjxoukFR3xxGwVP9d9W3/EKjjD/yjygrDEf0lQ7MFHGbG9zLMroB yFJAzZsLFq3WOYhzX98V/6guBXl+WYTXagI1ShIzwUMD+Wb1vqUD/fdM8MS5lR9uR8OGFsl8 kPYyyfO16QV6toLwsVVnlcAkdWRZbIs/0b7FTay4bCv7KEbwbK0uIW8wmbJk14HJFj/uHjXw 8FYQYtHDxxTyDWa315BoLfNosTWeb4WEOQZQ63oqQQw6bdJ2QbuQIcwMS4uX5DS/Ke1qUikN iTG0F28ggmAPmIa2DoglXHDX/AKUR7vnGwtzheTsZVSfBAbFydsfGBlARCe8khLJTKz0NNtd rMPnTWeVJcyZ39oUERewyPKORXl3+e1i9wqpdMXFcp8o08WId4ZnJVDoimo5ILPy/dxc2Vcl ieub2nLwnmTBBN7CDkierUnBR8Pivq9B7w+/7vP6hOppQSwzmHbPdDYaG0ZnmadZFGuVmrxT ve0msD0wdDaP6RAuyaQE2f9hSI27dTXt0bye00e5kxqHSKWTBfD5kdyuUFbU9W4Tm7w7xzAj 5wxoj8hRA9IRNAHGCZ8Q3ecDA8bBO4yhU7O6a14pbF+A1T9634G+HdhyX0wsHvhF95qLL0mI YlwRVjrI9KzwjtZuWv3I9dRwI6JQhGf8BsC6K5lrC83FgepjoZlp7oSE1MBjDmoqK/jSQMyo LF+JeFnydQYwzfE69EsPNz3hSqGnzjrrxw4icvvGkIzyRxz1Nl5PtxmW6NQ9wnVfsXg3Jhfn wn0/MdbMt91gOoy+trCGqS+GhW5/vAStSCyLw5P4d45Cyj2rH/NCHDCxx97Gelm1imziqR1g +ZaGQ34X/tRQb9MYRRYOGIIYozyMYQWTXyDw4UBhyKSI5o0QpruqbU3YImkkvG6vAv5wEHBR d6BFkqgg0Uqw7WhlKyAzxi5o3SNG9QypgZSupk1HUEgp70Sg8ptUjJaKE4n1y8SQCMnQPlLW 8mBZ7G9eRnP9coN1ZWOpwz3hXDZleSus0BoJg3Y9XsfFXFb6V+q9xZ0b3m/xvp9qQ6GTayHK UWt8GKlXNbUh28N0s//kuOkTB3tYoaYT7KQmWrF47iVkoGABpbx6+Et4myeu8Ud4P1YZkXlH 2UC6RIqnHjc7uEMcvxUlkZtZ20E+99WeviemBEyvJdK4RcBB808YSALlRhyF9hNgec4Mpe7w r/1vsvnhy/Fv1ZIhRf7+VjKBlURgZ3U+IP0MG5uZmf8h80i0QyitUV2aBP3rJLIh67r0eiN7 yrviAxJXsObPEWF3dPpxoZy2ZenfxHKjuhBQIK3g05LkVf1RhYf1pBIdGUH+LiK7QLrxHd/b 0JGkEGu4SLIW270IO+bhTgr6f4q8pghzUits95FuKd1HVHLUp8dnGnifPEg4yoh1t2egarC5 yK0cE6bcRbGxT7vSqLtqo8cPTwRAyPKB4x75l0PHOtIdohjFFhewfEiQHkmxp+RJFoQ208dQ LMIBRfWSdkGOtexu0ZOpoCPnGbeiK4lSSI3jwHkWCCa/tUZ4jGDBjXlJwP//oZv6QDzb/yvE SNVQvk8/0uh9HMZzmlhEOx1jNhEddVi1L2WVtFSugGfyzE57A82g5w4gX53eOR/WLFqiO7wX MdiF37NmssRzgR1nurwOhNcv4fBIR6z3eaWOk/r5FQ2twSIKukeNFmHkG1BwayRGHdL+jPpn cQNx5y2MI70BIenr560R6cUPIL6Dqs+wxtsHLVmZRogF5xSX8+h0rcLDUk9TBPVHQpcEF1uD OwiAuxAv8KsTxni3okHZKH2fLxor+xLrM07yyFZ6CxoUNuSs3/ec4oXQTWG5z7TfXHz3Cdw9 DrvwcLhqay4HDDqI0FIQeza5Gv/ZwmyLHNYPdM3u4OirS/tO9bhDPaIybWOFlH9WD12taZjC 1g9dOGLFJo5Q2tgNCI/e+cm8cbdKPUkJp/GvALP8hMjg95L+3su6zkVuausn54A+DEXV0nFh 8dhGwAPumK9xv7O1Wl4F7V/REBrupatBWelnexhqeHiGIu64Cmw+B6GeRNR7kBuyMkKL81yr 82bPl6ZY5GpRUobSBzaoT0j2l2H8KmTXDHEm4mOYCtdLOK+BbqFidJCnSa/9RWSL4ZUzO9ec cLgn8YLM4VAS1KlqrAPblROyWhfvku8B1CN5oNEHmRz3eEhslhpTdYeabhOnOps3AfMFGRju iHlAxBMr4RbrW+dgba2J0yoXwHiuoBXp/v3NNsxAhn6MOTTydtMkJCVSQudlUtHJgQ1WhSn7 kHOj2AuSwic/7YzoKHv2rnB+cqaHIqJg3Bb10SFW/Q0cSN/oQ4MH5zoBla1063HY9SCARVww H7RFEOUNaCzTPYVORrcHKiWrUMriOgHv9+s9yYRiuNMHWICe3vUYzhpQwfK6hO8/WmY/Dx4D wnHE97Q7bfXuyvuyHD7krSPUPoblcuTyi56ls7NvFgbKJfkFr5owWYBbrtuEDwYTfW5cw7oX IlAz5fW7SItIsIyan0J21nK8BHppnxHjaR/pUMgWLG8FT8AHzAGCwbcH4n8yukr7VqkVSq+h U1CfXsDJweeL6x4N3R35W/GN53hTvfVhIR9bpgvEhtwN6mbf+/tnb0Nufed7ZxBVtXR2Ychv Nry23GhlBx9hv8N4nXqX/Cy+WaGVCMYuVB4adjvM1MlF2u2Sz31ox+5DXJUeoiJXT5A6hWdG IzmO8yvGVV/ThfyyZu9sm0gYjZVsS+z+q3sm3tS2zGdyEopkVuNqa4sseBfnNrdR9e5YsekI ne+q6yJm45vYCiMYRyqawIrntvlS/NOBVxEUEqabvlSFdZmKyFe3FXzj2sjyde+waJe1iweW 6sOC29EkJBhnJ7ItB/PAExT15u6Zaqg1S3JdesTm8MaldDQ3rX+qYkOVCm0VUd1IsXgLZIbp uYgYA0qLQ+xaQUwxkFXAR3Jp4iEVVkDgAQDNRFEEE+wBute6dkLWG1YUu0Z84678nviGCAo5 kge0g3PmzCPpEw4a3LjgIN5i4F7cdadRaBHRRyCIkGEAfLwDIfZJucEvBoEWp5jT47S8mQGF U959BIYSb4p1tPNX8bivOY7/CSB1yaN1DraWexSjHgUK1boAQXgpp6DrIHuRfzr+ES8cgpnt 26GlP0AKsZhzKMjYTu3nLHBs6JhQjgvZp90wSFJq5rJVRFWQCkesVWeklrYTbjDUd/jC5zle IDNf0B3go8nrMkK5QizVnqvi3OlaRaNXh+46AElMNKQ5BXEyIUT+h+e3obJhsQYBz56iHPAK dqZGer9eYa17eqan9AvOQCgmPJ92ihATLcuo3zYe4swgqIg5AICGQjRv2YfWabBOuxg4mT5N OVS1b9oNZ49zx26ZhIBmNhAs/Yij1vmCGIh652aIEX+juaas/i5PVlK3an885hbsFoUwItlk XLwofKW42hHfQqe9iUl/LbMU/3vNQDz/LUoBnPIEMRfuKBTzKN81ZeFrEbiji2pYf3lLyxC2 s69B6AJneJndCg5nF+e+2qkq+ZZf2ObCg2aYmDpsGk0/yfyUYYQC9H94w0Yx7uQucbFoIr6O M5nalnypgDBOjFpR8HySeS6bcWZkYR4NSPWg19tk1mholwhI7J32r6Bk/e13kE/KRm0djM8K 4Oc2lAMrmg0TBqNF1gJvlCsfTh2hh0CSHjKaq9qrNfIN1i4jAv5j0S7wOjzzsH+ohcFOTfzB loj6qdkT74vfJnLydj2uTB1chloYVZ+5UhKk95dQ7W4K6kJyd03ic89VAUe/U8mystBpnuwa ZKAcO4neLOf00KadXBq90ksAnpEQ8A9yhzvaoktMVg/NAQ4iZF3WKSoDCm4SZsE8LIjcjbNx Z9iAW/evxWx5SNflyazOphzjacWXAim008ZW15OM+WsxUfGHxaRGxk6wnJ3ROCH1HgqwVNrF yVInN167fEcL5aUhKDr9LDKqdExNyM/Iil3/BBCVkhaAHon9z6REnRL3FgC/a/ESRxNHRlZB nM5CbCjVPPANUkWWycwLNO6739uIpnGpdxmwk3jtGt0+pj1LMzcHYaEqj+ZB/SWPhX63yk5y IHKgNAlYTvhJVlCiHGtUcJ4290a8l59s8rrfB16UXAylxVdgTOoKA8gcrESPTSX103RUeiO8 0UX6g/s6WB693f8Y6/wcTiOJ4F1F730ZTMeRdUnpkc6RaPhhqLYvZyzFB59+QbxFWjkPYuGn 1QvBgwjCWX3hZLIbFazGmeNvIbtjCvQvB/Zv/cv5BtwoTdZh+rDN4d0cxDm3lTT4eWl6GJkK JZnaJzEL+yF5CjHQRejLOwrcvYr3z2jPg5dcyVVMqQUeLqwQiG5IHvl82i/e5jcxTQlgExlc XKAGbPgXBO5Cc7XuLeKxy3bW+r4SaGd5p3PQNytwt0/L41fK6AtzAKZl6hqJKkL/qL2Nj0YZ XPvylGuheG5R+xaRuB+Y46YcbfJe/60Ejj+d7Ug3z9X2DfMDO7LrGpFYXpCi8WB6sKqFwlmE Co0+8fskfbaF3P84crW3g8rc+ISMuG2pVg5XMvmAayODGO44cgWXJYvpFnT1rZWt4UfTauHz M8dX9F8b6MnBbtRM6ZAphRKBP0oyiXGpCitwxtb0gOQj+9/7/XAgA/1hja5IHoaOKsC8+FMu lSQU2pW80605Lj/nSUPoTrV6UKzWAr6jhDaC+7e/+xXhDrh94Q14q3XwqCpkSgFQcKFlG50y xG5BVWUUCTxWe7FNPdATyqfk21cSWJvHtWiT33fH5e+46WUAMdKc+dXPz1H5cd5etNqttgO6 yGNxeZnY3Y1/EDgk6RPRGWg7c5uzKztmkjcQO3yCUjSr6rH0vGVMgFBwLHg3rullfp/2m74k K1h9bJIMzApdamFP1g2QhmvcoSfqKVMNedbXgCCEVad+a8wO5VT4A/c+ikhwoJ/GpQsYiGC1 GpEiHNn12IZvVNunDyH4hioivIw1IHO1NrcMVFlHlCI5qdnPWfiZ9LDUF29EPV6zZ9ZEE36A NHXzXn/nMZ50yEwovMvKr3kighlESnPUCW51FJopFCQcDKVMLDbbtjXoIZdmBKzvRsbgSPnA 6BOFdoyKZDUH7ZEWS/Hpk3li6tJHnfW1coDE4wUDqYKbImalawJT1+6WgyAgzPnJw2RVPxPk m4sbK360WsywDbwhuHhJgkif3g8y+tLn/oDIKq5dtJfxUZwKoxbuAzMNuRjvWKM1adxkhFLB dLjjvOUBV/7+Nc9krfn5QGsBmsXzGumGp70Z+NJqmS/dazVbDqLvVTKjxPb4W4fIvuUidDlD 4VN8+yifuDKtRX8GBOnz2HuD1xaMGsalXlfVUU9vHrdSjECXexue4D73cG4DpdSoFDRiOy2v YAkFxw18bCwJ1X7bjIkxAmGwRsBobFshRaylUfhpiGbnwrCr5ByGacS0z1LyYTs61brAeWLx ambmYfSwCSPHDT0k0UkShqRYc22oQYmLIMzgqLIjvN/cESAhLbP3MaZF1ctOlNdBHVesqpH8 w+sfqpdU0/cTdhimYPeaLqLi4o4X+CSZd6rd+FdeOiaBZSmw0iyrey4xLsv8PpXbOm8iNJaE N623vqnC44SiaaEVOg6DG6NJmoEfisBJLgvbrIuOaore/s8hT1NpkFhBsSMU5mnHyT7lWfYT Eo1e9Vb8TxDHgscX5kofpG7JW+JZhRYbr2w/mRIS2iu7pXr3XFna7Ku6Hp5WgIYsILdxHchN 3Pk3rf+kUmFDgHFuZu0EqDGV4Ehm0JqF0YaP8iuJfK4wHzycI703E7XtF1G/Eu1EpmLMt4lC Fi1GdCuYsDamLM/bZ9jcZy7FSfU2YVim1VxJaT3JVZsAW6RhJTAVLnC7fEkiqdzIVKcpfqv4 sF9igHJ4GD1mPSrggxbfqqudhFXjCXi2mEZ0F/m0FfiYv3zHb93bISrzBBtEJjIGFqm7IePS +/h9TRHatACyt+xlG+4SjJ7uZJl5P/jUJ2KfjJ0pzbzpuWKX5/L9k6iA4T83lcYH64xQMQx+ dqW735go9awz7yU+rNyhHBFJaOO/cGIiU/+T0+VxuJj1TswcXE8SM/uFxUPMiY3IbkHoCh1/ gCOcuUeqcxtVdBg+fwhIVqlOxVc16unCn2+GVWVjdWodv140nO/a2vq6xlvDzPJq+tr8+CXG OqRZqX/VhB3tJavmv4GoWLhpbFAGgQJgLBEoLqhRjAQwzyyAeaAii9eJO5Ww81rLzWj4p48z PP7nqjTLtJ4OV2+Ori3ref8pwQ1tR2IebWkjVPkwhudSP3LCsxCkjPklr3lH+kCpg+uoVNyC DUSRpytCxKw3c/zMfgxptseviUOf61N0QE7hN2wHTATtI56uxTrTuiFBOhCViT3oGvRVFJ+5 COki8gyUhNhXi8nfGgApTHKaahx/0AKM4JaHHvqHIVuYA9poIXekxaoBCibeMVMWi2z4vFUS m2OX7RhxX37VdefU5jKvTsd4F0edHpPco//tvddgRh03KkX3ZWW/0Se4yqCS2PiYQAp8QiKM KuECQqZMBRFN7nW4b8zmF965VDxcl7rtTaS+wiFgYf0gy3vPmwaG8jqeESbFKq9weG1hskuJ Xx25XzuX7GEbAl5W8QJy0vBoNM83/bar63Km7IOQc6vUVuCFtOX5jnX02m5SOi5Fiqh7XxTq 7PyEWjqNksCXaOO0cw26gtSovjCSAALGtzWkjKnkWzvjMM5OUkvr6BejJLjvOqiYxUAWTtFk eIsgj/wHEXcefQoBbEY+2ybkAJVHxZLyX58jgt3u1dYZlIqtjhWQ+9nRByLwN3qrfBuaINqD 4XWcGflPLBWJmYlc+U/gbBNrdxSliCmytXnkdpchYI17H9+FeEWDYnQtNjC1pqSFaiI3fxF3 bxS74yMv3qCrx2Lq/hSUTyb0bx7llj7LaWZ2pkghK3X2LtvmUoeBS2QDLnomyl9emb/FzsxD NfNPPjORXK52MhOOyDMFjVbAPB8lyn5PTWfbErkF6KfJIsWpigQmjjiiPTdbNM3et158fb7F o07cwIdlyYy07BQMyTAfATfklFsWHkQXgC798MMTI1ENvwtdVl/xOhmcITvW+PUPCnWdLUvf S4r/jMBpQ103hXwNtdnR1ZJ5YqSnyJWjE53MOv2DZOGu28tf08J91Egu1UvIxZhSzN58OwH4 KfazAgh/8PtvOKlFgfAuazioxIKvO4WV1tNlMtsFeU5G66fswdP44JER0wHvc9qjrKuUBZXd 9Z0qhNsVCKzGhEAR2Q1jnxm/8Iq7Z1StjZLRrvKOvygmnxdqHDji2fyfrU8zgwrBBj7v/gll th1GAvuDJetnHfx4GOBEI120P4xihC59MecVlmahilOZxQ+RTlvimE7MdjkqPn/ZR0OZitw5 pdvGU3ebmT2Q1Fjsz9L6I4yvQP0CFlyum84ZD9WxQQUrXQbrZgaoHgKyGIscPIWoD2xzxjsw d3JzCQMhJXKZSixYtgfRNt9M8zT1w/kU7u5A+Uo8RxUkCsAzjRZtf7AOZm1JOHtQs6p/7zNz 7dTM3XTprob+0kNsZAKKaRLres3667xFdhhwBYwCeATGhx/OjI9FJNOoBjJcDCRReOvikehg b6VGh9k36MW5ncO6TUb03ssgLuAMuiBXKwBSqQ7IFDrRpdhxwLHghlZzootHzXv6jR2f4psT +p9zMIrGN8DCfBozjgRhdyUslJqxkD2d5UR1katFaJIhPO87N8SOdxbsNZwxgpYNMXIqBzcd 5GOp7LqMKvaYB/OUmcr0KyVdoMJQZdHYZDgzkN1OSUFXME8XMFuFlLomYbjl/lg95X9QR/nt zfUdoSgPdjg+EaplYH+8iEzBkH2z6LCH7Gt6RmWa9Z7j0YkvpFqBJfErwz4UNoahgahYyBuL rWVOhiklf6+FcP+Q3MbeFEWWTUYomfTBz0QpPfvgc7K08YEAV4IanG0ykZTBBfCor7oU20gR RDmydxU/Tt6Qs6dzKwK3lvddpXYvUJHq1WdJYGQDJOVqS7d6aeEFBnIlX0he0LD4Xb3lubqN L8xdGVjPd8f6ygYzkqwNi5MpfZnuy1WyGiW3tqtTAV7HLAcsFMn+RTPhC1eVxWciLakKaZHo SaT3pMU2nn4zCHjcmHz4kbeMjWZsDz9+K/2PygxxqdX5GdDdN0LD38nGTsKDHbLcZNtEeus3 KIwyV+YTJlGGBGvTdQcwY/DRFudPs9VoMT0u1vbFQFzQ1kL6rYXA18/Xh9gAErGU6laGwTKs Cs3A68hA0fGZ4uI48vTzDV93EMje2BnO1foWAL27VUGtEZ2hzr9dQQaYxh7OrHBlxCWjGkzC 3/qpMaMqyfkS94tlqivqMhx2KOb7hbFr3RM8retgZNA354GlCOj3yvStSTr5hbWAnJrdBA3s KMDQVwsgel7yNmBTLB+bL0pvD8nq2niFyDmd9OkvuUG/WZCWIr4Gn2TwZPT7FkYUQjHukeyo LlMvDlUXmc5x2ZFmlE9bgx7QU8VQyOTQbHE6d8taPzXCHt/SObE7oHsKI9X9dUc8iGYwn/OV 0hknRCM9U0AuaQsAkNfnyAPs4Tt9e+n0/Ef8RK4bRYO9KmDhN17WSHMGrprsYmkmXq2wuB1N KjTNR5rxxmFAZiDezlTosophioFtqXXxrR0GVsBbQjYGJLxwzOxjHPMY3WMdI9QIgIp+R74V 87s3nJXs80+B1fpVEGJu+zd1fUh0UB3LzyMxIMZeIgcLOoH5USQlil2SW/v5IAIv0tbew/Wr DZ/RurvlYIQjIZ8P55GXAuLORefbjbcIl4oKX6AloOETIRRFXQpWxGhZJWUnXJUNkxHm0l2Q BOV64mOh74yYG88mHKI2GxpOVtlDofUN3WjVPGmbvKOYd/QfRBzVXWtCPUIZzFSFq+h16eui dzvGGpFaCE2a8mL6KQ2+B8YXSkNDdpu6YmHuM8+C1UQV/1m2itVgjk/D/a9ETnlAMmz/3PVt CkRJQdnSUQ1Cpzgs+scud+pNiOlKFF7zXoHDMWJoKjXi2lsTjoXfNIuC/+sniJEemTjRLq60 jv9LvQt4K9QUxGQeTmkewnHRzC08QQIc4f/pc79/4szhI9Ek2nDOQpZsQbn4ibMLKZpfWm6K 40XDC2r6ZDtigtc6ki5GvrlM8x+0Q47BKoNllRV+5u/bYozvhoy8VQFuvMWWHgYGMbZ69wQ1 443WyQSdOt6XGYfs0f2G/yomlVXs3RHmDv3IlvnmLBRbCblKrQPaSv/9rxxDIztAyy1EsOSt DxGKAqY93NYpzVcDZvdj8CHTXzci7f6kpJalReyRMQvMbnwoGOsEfmCbJzgIjBaDGxvWnTgv So4nLMx/5jiiO0651mG5KW1O9evaibowjJmrWmGw+Gp+RvQSoZY8fNFKjZEL+aF1ERa0wTXq o/NTTb//Gwiw2vmXVGjfH+p+4xhg/GlH8KTyRT/6puBKswSeDMkfC7p65TB8nvEToQWXEebI D+krUpbNiF9y1cJISVALEhp+gxLoy/+tek0E8/E9EbydDAgGaqCkehGasqg/awmIQPpez1Lo 2l/TFJgq0J3z7PEzMBWWwaa08dfypBMHz/bvOBJl+GK8q2owiUtnmhkK2SAypxUE5uOdkF8T oU3wFwXAWWEyLn6aH5u3FXnZ9LfbClcS/67A1CeheYwlVmZmHMcfwVCHsscIw+73D6VmurtQ 6X+Bj1FQP+okm7EIqyYWeP9zdem93hf+djQpAF5LeROgMAf/OhuALGicvYixzg9ycnrdsDVF r0kwj/VE7Q90XGmrbYynA4Uas59fppKejNbeDZDn3cJsIUShRd3rr8aRoVnU/qFqCE2FGkcR NhUnpMjTA0Y7v4oSG6Ic4mMIqIe/vI+/XXbeaYGz1ASXyGoduf/i/E8WCqxpVtm/HsIgE0+3 fXgieaoX/VzqyYM22XeQBJe9qb9P8SrKe0Bcr66qCSduUdQs2U62QMTLmmUCQ6YRK7pPytS2 EBwFUo6ZhNkBgtmnv9i3I3PunIhOA5w2vpBMNxUBNgf+7VDNe/WQcQYBRhDMCwpgXr/ba8Wi mFIwmOvxHkQWMVAMSwGy5mp+Do4CmT1fH0IpTp4YVZw422L2s1EJnept+YM+hWLxux9Q0htL 6lMwFXBM635NJ4AI3D2Z3FXK+FhzMi9YAnVHEYTpSZvpCtwOpJG9rlLmayywfHf9tf1OZjPP DwiXip2n+nZ53/khCbqo8A7HOwXsBSS1qO1sGa5Wo10bkZwSPxV3ebQIv+/RR0feLsgW86CI 7gFRRj2jx/h0qZeNjlaQOb70logdn+TKYssGLquDML79qDs+1sNbRyoN6rIBdeb6iNFxO/gd 5a3agox1Lm9J0tf4YqJPL2vvBefWQ7jL25ZJ7vx7VQ5wCK5x6AcvtvXerE0rKAxxqFFPA/5+ xCXe0BJcT4oEZubz1ptq0GikN8z/LlI6OrMMqDHLVWX0N8UZ21/xw40HOfDqFL98u0yUDjTf 8u1QjteMXZF146ffOC5rAqb1a25l9mce8WYcf+ML+XjD/0rInyg+uofKoS9hLLTjKqVzuWZG XWJjSpW56mDZnu6lhyz/949xCSF2dDvhDe5Ht4hybTAC1Hf8z61OGUUScn8TR/DqZoQ5Izas GbjJDmTeFMQFF5kvIcyAj019J2QNmGzt6ORyrjbhzEKmZspk3DDTlJA63iw3CtLPp2D/FprM u9QRo4Wpzr9rnY1KXUNJDHyk6wnSmhzeO/apRzb41WS9HNCLNaz305fsQPU0pjqJk5bK0yCh pqACW0SxeOpMZ8a8grHm6h285L6vAeGe20VMnnpljQ1Bif7iS/ixnb63nSMStjaPxxZ2qxiT I5H8vHnfPXCccMl+sCSRDboJKr6io2c6XnupFgMyDGO+CAg4fSQNRRXJQVtPBj2t/5a7YHP3 lUtwZW22gwEiPW0vGXp+1oPUFUYGtGVs2OXxVDwEj1YCAY5DjZzOk8BzFHj/eaWxGYZZvDmh hv0fz5aasP7j3vjeSyudXHIWXWCeujL6LKhl0d9YRIwGQKRDHYGndGHwSuv3sWWLu+K5fYer 8TRX8aliCEz/7GWsPIy/57amVfJFuqT0zwllgp+U8cO9WxUCldNpOUkUHeQzUzsDpXMybTsn 9OQN2zRL8cxE4ibOv8lL0fynREKVWI4phGI0GoTnFU5xlZQNhCTkQPsLSTke9i4LvOzBGyic VxxF/M4eCGzf64+osUr7SXNn+n2oqMJeFiaVQbNeaTgKaQsGKVk4QRduV001mVa3jadCs/LN QZk7TW8cn3C2icFOa2Qk9cB8RMAuiCDKQTFfyjcmQ8SSaaBYFRU37dW2K6EkfpTJot2YJ/nN pbA0OaPVBvHqNAtRSqoREDQzVOQ4KcGEHiEY6eum86JRNPWnouSdzmXNoA/NnPKcDQVKtWM0 raYMDFvSkd6sseupCIaTRZuLz4Vn1drwYrKicaSKlGZAPj5TwhZzOiTs3JlUgyhoXaumbION 7zbb812i3xd5d0osPuXwRV6ZhfYwkh7YWbOUA7ebArf206YtN6a3dt3kbamJRxwrWhd9uprh j/h1oOA9y/XmBjVOueEA7SlYFzFKPNCm6Zz8yhMyDxXOmhnr++zaqpvRlF4NlXu06Nv9tlyj FBcoARXn3JiEYqdS+co0364E9aLDB76lDNry0jP6/szAHPbhzD18kGSDH6opvaqK8qw1w2Kp 0QkpmynFBGfUlUou6lAuZ8hba0P2Ao/zB9U5XOCcwKp3rK2LX7olpyaXucO2fiHkMNkSAXXP R1sfX2pvKCieafooxvLJGiVzGym9iUfwKXEA/odPhCQt/30KlMk72d8XigB/IZS9PkNHe/qP ny0npXTpL+Nrh4Ac4Pxrqd3i71CjFrgSSlh729Hd6iU8NU1EBGKLCruL0Od2wwBA4SnEimfR N4eRCALK2LLYkv9UKk0nUWc7FcYspR6x/GRawOg3i9jPcBUYyIS0p4iGOUjnwKEXN3cXjKdV +4hMvvsX71vu5Ox5xNh8/F2kwXJgIYBWdoMKOzWlooa1b5KDLSGPYCyTzGLri5wUvkXX/Ko4 W8c32B4GJk/Lw3Ke18YLNsY57YRg/he7xUC3Lt7+wjfltb3SHYHfIFL3VuoA1366sCGFc+xM Qzarg8Q8x48x9jWckacWrPPa6ENygnM6WUST4jt0g8Sfvo3duuZruJAou4ceqTLzrkY2W/nR 7llV0+E/iTJUcBZqz/OxZvOensyP+U5snlxp3LyOWCgU4nogCjPel16mwzTqENkB4SaKqSvI 2kiIekimk0wHJalR+Zi47rY/KRBT2wVElK3iMy8roxcFmuHhqhVKcl03qe47TQ+I0AFx8r2p Z1kEEydVzG6XSFqe7XBuDUS5pFLuzh3QEdCJLUS3bMDjLY1WyzNSboA3RHXBZ9cP2pDCuYp5 TxXQTNugCXIHnlZbdKktTAX5tOorMdH5EvGYN+Rpn8Y3TudJ7cZm7SOKlglc71q9o64ftrJ6 Habdiu7WOdcQNmci+Ru+DWVuZHN0cmVhbQ1lbmRvYmoNMjM2IDAgb2JqDTw8IC9GaWx0ZXIg L0ZsYXRlRGVjb2RlIC9MZW5ndGggMzYyMTIgL0xlbmd0aDEgNTQ1MjAgPj4gDXN0cmVhbQ0K FlcmwRN2/05ld51idKxrS+9FS7d/3A9U22EMsKL5MX3SsGWYn9aZbNTSzxIqp7cBuNk4tT58 U7lZHqzfLAjgiVhRoGzS8jklkWiIp81h/FzU67tFAVYDipSCBj8NAQVOL3nFoc824nybx0U+ UbQmEl2XYwLdFMZ1AmhfchwkfDgsIr9bT3tUKf4rPJmbiXHcB80gZC4mEy5XsSZzo2s5B2o7 AV+tRK5FM4Ipd2JysEB7yODuI7IgDSMJYGaJWMzOyXj2HhNP/AhvkYpXHBaBfoqJ1GF3Tf1/ kLKnnso/utk//Zy4VsvUt+ykzbPaASrH6OTfjtbSfgJ2GGfkbdBuuiT/nVfQR1wS/H3Y/fsI BYa8YB9oo8aiqzUDf55UXSvB91k9eqP1umNrMUOtnhVQw8KV5n4VfNeLpkLCsszujnOm+iLo 1YjdEHgJUoYhtHl0nrbpQanekZw0lOiVAiYFEfdCptDLV1KsRJ4lyT+LKnqM4A0/hXvU/2/U y62vm8DVsTXe0yCGvmSm/laYCcjaKs1gBIT3JMViuwGBMoYH/MJF2OkJJ4XyOMc8ETlZ0Isu ILdQvjqBBHioNADPcVTd2m50RPHkNgiTOoAx5RYhRJGWROMQ8bjDhm8E5RjEHR3T7ZCwsumc t0o0GnP7bdLFk+uurLikxsG+fhyW/WDcdkvPwcSw91AGnHE+0ltgH/q3dwVk36Y3bgQXiwNu nGf+hMUu4zqc64KB/3qkz9fI8vvyFPDavOuKCLuZmWCn8bcfaXXhIXlidYrd5/UQGXp1mXoY 4/F0e59epPg6GIkBP1+toHW2IKrqZCP9FCg0FrFUn0jHe1IsVgoaqNMIDFyafkQiuRvDVWI/ kOOknmxj4e58B9oRPXs38V5DdScGFBmxXE2HDciEhnG56DsXcIEIzvbdCdKjr41CHRJBPtZE OHhNNFQtUBBQK5vF+UbSVjg2IWouLHQkI0U2KgeBrni+uhEw9FDfED3ewlteIKT9aUC7PP+r TfzVZ1GPdzjEZ6dZHrIhqBr5TAGu7m7NbGq3o7UihP3pJtaGKhc0xKhmk6buI9jIjWbdC2yV 3OmhlCZtTfwCS981aMGWHAVcdrVDZcEZayEWVurSk/xpnwwuB9JBQM1GwY206tay+EIhhJYV qP7l9SCR00MsJZA7czCPe6eFadDG38AW7/glPyW4wTWKnYeW9on/90ZEAuQ0Oq6LBBDKXMoU /XqSDUDcnCV26vz/W9XGtIKjqBkSZS6wCX6zYYTELJrG8tVVA0HdJQf0cy7Y60+Fa9sqv91d IDYFlI6liajFuzJLXilw+UeJdWk/WayrJWIbL+VyTCyTNtWaxdfGHl+rUyxIJtEmMqCIULCf gBjvPtpb0ZDarythXU7tkD1z0RPz55lFPnBNc076lOLlIlzc0CrDIT0P6YP3CU/G1e88ppLK ZsLp1+1iUmhbw4XJYY94CML68Fizy3aMiul19aBNMo6K4T1olG5ehv4lRdaAqhWGF285sro5 GaFc+OCeUx36Gmf93WYS1npCGAh7Df2aJy4WIHurQ253G2P4yk74l7LVKXHedFXHmxRI5nxQ OPofKJ7tk1D7UUkCEvHyJouX7z18hu6rRfyUNoX3BrCzZZcalYFZMkkCEmkePQ5s3m6D0OIN HGBd9bQOfEE8QB51Ixs6kTyjx+qdWSzi8arB3vEc+ibYwvwggpxyv6dvlVaqrXtYzqwpTLLp jOPAP7RZApzeTanNtLOgaBIJ6thM2V7ja2Jm10hXmR7EXrq04BCaPh16EdLe9jDb77pUd9Az DWjtyt2ftY8ZoRU4IDO05r7l+n5fecuA++bfJWOnK1ffGthsR8YuMTkquVoQ1JY8rOrE0VIh VJwx0c8MrkhfqsgQYJ9tyqTyRpTlo53qevftK19IhslZR25t6u61+2t0pXZeK1KpSWE1M16I 4bS8OXjTYNWgjptMFiuhF/Pwa/jA48NQfuU7QKAYwCNIpwW+V5d6j1Sx4KVwx74gt02z18No dWvjU1qj76tKyrGYbWNDx5D7qGUT3BAwJfqkVigCCvCA5lPTM5mbtv8qcDE7rossWRmtrbZX JgDEn/icwM3rLVHCxRdmzW5TTNanOGKeKxauGged/xbI1WCJ10oXFN5vJYhGYZ9KweBTPdc4 H707YChcpX8TCDG5JY8/t/I6w+IjUmMfqoPDQIXlcKyrNSTlz+v0xP38Iw7goYQtjvuuEzVg BOeR/oPowuWw1tfoPto3+ujrowzYg0RA6j54/OjImuKzy4ed0sWKfvtAelc2Zv3NGMe6oTMg zL98C+I0qdOWgrN/KpVjcI2Lm9pDlvs3fd142YMV9IQim4mXWbVixOH3HI3g3AzI5aopDNXn OZvvqE/gmOk2HLEgQRsbdghi+ucXfGBZq6p/cJMCOqlNU6RLGpmT0UALYVh0hkBzf3t+D7ZI pEbNAHflLiA+InzlhiZHyqYMrUZO9X0FPtePmGwTsEnk7sgqlzhXlKf6w5D4yNtkFT2GcDyp l2vQvBu6eC5avJ+KO3TUYWSqOzzlUVlYRfdk/40QbED1c2Reip3lMXx+xNdex6j2wZaGvblx Im1shkYdWuCgMoGjxLLGOD9N6RUzBvUaqSp3bG77+ZpwNt97uCWUMsLU87ai0/3LesCcBi20 DKZY4Gs5syyQEUrD8L6qNweomfoyRVwh4M7Ix2gwGKCfXtB5dcAD5EfPxnTkv75ATd8WgUQE SelEoAdxxLtbdDSV39B1C6+OTePimwvqrmVdpdXvGI7WMYYKFXK5Ad7EZGY8FRVTiKjrtsiE VKqc/1IYt3qQihXWBh+iR5dTyKjRdzE4MjU5E2AV+699/o5uFFcvAR9Y6feQjDbgA2xb/gt+ BO4GOlK4gcLTQOoOT4ytU77ZRsQjkLJN/LtqS87/cDFtWGMAJfGCtXvq2WOJvXXCLiuXh9Oy Hmcb0FfUKiJ35A5+/ogrNjgZGj3bUjQdPCUipYvD9a3NNtgbUOiPB84c09rDUU1iDI/6ErE6 SI5SaLTtFbINtPOW8BLulE0qaSKyHYZH2Vdn3ALVJ4eUXF7Hba0YPE0J0CBoJRSwavUtrWHx Zq3WL4+DZaseDBT7iyrejObtTejYxtHDgKBUPQDuRxxl3GWnjSAB+fHus1tab0mEUuTTeJwO V4rT3CPmy0GR3rGFyy9nASGMZEE2/MSSQBtXfYm3cxmMssaEZ3/LBJi4oeYnD+YYoiDRGDbG D22yNS8qyvfOJPBnpUAsb/snjiEnl7D9ydInDEHk7cvsCMRu5n58pRBjqbDKEb4eC0YEK9gp KQS2gdHFUSqq1Sfnf3Xi3bMLxerccd+XdRHQpniEsBkC3BlrQrLGSGe2C1Va+AWxPLqFQWtw 0N/D1rnnQs/UtFAeICVUufUbGuqOYjVx/LkP1KFzNedHwoc/lJAcYyCvjO9GNTp7d0UFSvfK RwQgV0Qn2AylNq+WrwFoG4HPQUZHds+RjnQeoib9HR9VH2w0eOgZpMHPLQm1MnddzeZve8/0 dcaTn9jPnt3y5ZNye6aSK60c+/g1L6kny5DhWMc+Kg3lXjeOH8NGjo6yj1OwureihWrYJHYO jqRH1Vvx3O/mah2U3aqGBbs5ibRAxnMSXHjzrwqfxtAIxZ2dNfNPjrc5dx8TlUD+FRYn5SBR c8XdW2Ba2POQMSKHrpKeGWl3VlHDbZenrLpClZ3FZKZL2VKa7BtUE8/T7wrmnkR/OANC0y03 BHgcMQujg92/3bxnCTRFxwuZtVmucp5JeHPbgr0TvmVtHOrL3d7gB8ksLj6oouhswup2lwJD 0Lqye/1ryl5z1s2MzrlODmmuIXtvE2ysw9S0xlVF9UHpy71QbCLvgt2CTgqaQXFG3+ayE0CT 3O4mvCw6+OzoUaTN6QaMHyfiFH1b0yhb4MpdX1Ik6HNaDeTG6TEf30j86XmBZPPlDBIbOvcP h0nnokjRwLVm2+YpbNjf5QPyl1wuQTsjHkO73iiJWN3TkIT6GHMJtmfhYCOY43tlHQc5sap0 nP8SQZdfOaaJN/W9bhYvk8zlPZZDL/Lb3FsW/EdDg0JnUwl8X1HEnYtp8VvcObvLJxIW/Nx9 V2XJygnGZjHyzmQI0MuUH18aAYdQ/LsDP9HSq8/Ch/IabyMebBNFF82VNnkqfsU6w+kDTtrx UXTrvPS5urQeOp0JSIs+Kn0nRuMLgNv1Rr/uq1sNamJ819rIWS0nMoQBGx4O00Wdznu01Ouq /6nrtnuzrn6ni8mIplggL1NGGW1H2B3qyO5oe3h4STC2T4f8sUB4aLmKqbfCLjJkcSJ7g0rF viqEL5WF2YzkhxU7biLXPklvQwsYKQPFav0TIkaHISuR/GVEhw6xvJwX9dibPLz6NiO1mDVF T7OTRD46A6j5mUk70+Q/JuEfEkSFcZH/M0NktDfYfzKTxQQCBcnCpZmAgkHnfyws0J4fttGu CzhQOpjelNnh1pozy4Q+od+Joi84NEkK5WV8mJ5w3UVhwY2Me/rfZYKL5IlbdOu1EvhjxqTy DSGGShLi18eHYGPjDMOTX79QiqL41db+4cOZvm5prcUPuYxihs5zjiIc8fT/PNjfK6LJE1zQ I1cu5Pe0xwiUOMg/0sDYaotwdvOdRHsSz+e7bzcElKhPdmPBg5sINzMXHabm8qpZ3XNZHZk5 kEpa9UTZ0D8NWPsRYXPszwgfV8bN3dqY3BdnLySPkD3lnK5Eu43nOygJ0GzUahWGKPsXigyF wn9Qy2SBmp800R3hgV+1MWubKpUGneLtQHczQ38yFxZK3klZf3utHtN0tdFmx0DE+NvT3JzD UeSeFZkfLKSq49MlNCRI1r9iap1APZKqZllxmm9852Wv4cNdoYD23AD/SmXRyM/ijbrgcj51 X0LIBTayljfhdAyfMWsdy/4F6+TQ6zE2oFEkr2JctHc8LUMEu+fFqS9YXE4tbgRKq2NkLYg8 9TTNLyt3Prxqo9urj5PLzrfsm902/Ws6I5qVqrjubW9HojEesFRKhbktMPh+6mnnOXp5pxbN kADAVQs8ng+G3Pc0zIDWtDT2/Z81FLjZwIvtswdjBOhGKMHm1K55EA4nowdOaqui1dKZ5BzL EqZA0JUA6I8aE1Czq26W7tLWF3Yf4LPpB2G2SGQOMj+4p9cGLI9S6pnjjaVccOwPv9G3Sm+A wwZCNGCWoHOp+CJY2dQ60tvN1zIOBd31XECeib3LU2WESFiXgFiWHx2fVGtXqtsdoCqRPxfu Z41I1rpOCVZknk6kwk5mgEAN1/bgyfj11y2ok0ha91V1EMX75Wo+mQvpic8mYynbTa25hAnb R/yMuiVnxbyv8RfsOcOkXMjeAcsRNQk9WgBbZfbdvL1rT2DJEwHp5hRmVnKCRnvkhhg21LSt 92hwwJClpEuFFNPnn9KZxo2/hZGXlXrgBf8bqY6+z/P05rkZ+5h74N5pmlDdcWb9NZmNAdJr 60WL74wvDmkUltQmgL0Gy8EpuJgTeqiDK6gzi0UvcYlqt5L+/WRal1j52qQw+QeNX5WKtFnv HJhoHqw7Rd6cD7hDMrm80Oj7/Jl/MI2FLpduJmmIhue4ifiiEj94eO0ETjw1Qx5ZfXX/Yain CS2zhVMDXDEgBRSbPWQu/rmpe3Cqg+2TK78kSLfSo6VBudvTfmlqSVbdfVRsKSZVDeqILvvW QUFnXbYaMo3dHMa9WhZ+JdImicqsihkx1J9b/7uNfKHEYpjqFy4U+zU6iPTSCneRPPMM14sM ihusi2YoT0EL+NvG812G+wco0JwYY+FryFWQaslwwNSMSwvxUSELG58vkUejSrN1mKU9wXvl ybYIi2vpuAh6fhexSGt5GVmJie7X+meqov537W5+09f1Zcxs4mbaipX283PQ2TyABrJs9R1a NjfFuBS85YBn55YS+YPVwGwq0QtRo4oKgjA1YmjuvNrzEWzecz2Vv97ntJGQgjTfUW8TNsjL Wlcud7nnFFcRO9YuEvOPmwkrK+CiiDu5FXdH40LsiD3FNGBLe3AYY42jrkyJcwto2ZDnsALl CNMPSLAqeysE/FwzIh6qMKosKH06eCtcGiX+q/EeuU8vaJeT9Kz7Bw4XpMcFkSlQhT03COEO lLbhmLHn6vEP7boOFYQWbikbY95vTmBAk1JOJjkr/mORKXk41ehrBtXmFvkNEp+CId+QPZrj P5Lg3e9063Nu/eJYWo16mFWMHSbWAB4A5CdoUd3J+hHKCZlEcITj+NEZPl0OoDd5v84um9gW pNE5c3zP+qSN6qSAobtV9K0bUBE49hFOEjkLv/rjdsFI7r7wC9m016+8ksOLS9Dh/PNWLEK/ pMxM4B0EjOjAHAdfftGzZkwTpKF7YCG10FTD+7w4iVtFBxjaUGKtxSWhmNRwdPTL2ZecffoZ MIHnSx55KjM0kfLJMI/CI9NvPcbiZvrJ+BxqZInST9x5WoQvaznBtcpW3T0SWFT3+zBlJfuY kGvz843Q1cD7ME9GQ5O1MWdwyOoWj0KT0eCAHavyrd8NcqMl3jU52wTIagyVSprkZo+/Jvee tnMgxfj9aNUMWygzyhfTN2OAor9vAEpxcyTbfMutrKdV0CEkoMwg9sbUcCCbEe10KgfMu778 27uB6mVwez+lD7WJV0QujWHmvtKwVr0GuK9MDGfrPpMYCI1d/gZHi4a8hq/ybiGAz3MP7DbN OgqutzIa1wyawu61UztoHSJ/5Te6+lE+f4F5gFlk+JecI8OksJ5ztUYRTyIoKENjEs7cgBRg 4oVfrlYgHntKzGMa1aeCtV2I+DshAEgieHEbrwny2MBShRo4s/mhHVV9fBK6LGooc7LGOVqe dL2kP8Pm0vutiED8UW6nFYpIkaU8Wpou15gxakUmz3bJCCvwMCGjaN+egsWl6+jAkeMWEb2E c60pb3sBPgRgite0+ie6GfPrCX6WM7vyxugVdeMXkGO+6ZafN08U8xaZM1Ox/Jn/1latOFwS EV6ClF+fllup6n/sarE+TFvdqaSUydByVAUb//2gdX3kH83AJjDZSKezmwr1l8xSX4AJRBEb fXEAU4iRSHHlwrU/e42uHfoTOvOVVB0EWLsBnCe+sHCQKGO34nDH4CqkQdPzPbg+yt99t5g0 Nf7r2baDOFGE19w1Obyp9VOCpqrAa5zzApfzJTxAolGEZd7PJaFHsk1LTNLwyn1PvDurdjh9 2TaxeCtilVrYuhpIvISFWUJtAqZ3EcqRwt+ij57sdlcKNLd9ch4NwofynBAYK+8U/hFk29ii UBO6yIit0XqI4ASMOGi+9TqmFAcseX8/xEDGZ+oTKzWkNhqnHUBfG0i3Crp+tGsBBhgoCEUm bW13eAyGJtZo80XC1Q2FAblEz7VvmTYRA5bCUt1EqB5HfOotfc7hkfH6MsxpBI4xp7JEUQgX a6C7Gm4ACthPfscqTWgOE86dRTrxHrvX0pjRlUelxcuI1v92hEqs8pLDKazgMgT+344S2/zd RF3zK2dCc/aAWPD5TQQgsT07E0ypGXG1Ii4YaG+p/pJkTSlZrzxu8+dvUtC+ucUDLmYaTpp3 4dP0tHT/72A38eVIToZ+Q5ZE0yjGlZhWFTjtx+3vVs/aEFLCbt6x8vKzEGIKxDbdCmIiIyIT eTEaMQ98WJ2i7z7svwaqNsZrJapUhKO9WFkvRRuuElyllOyAXwTebXAPPY7Q/4RWx6SJCXTC 79kUSu3i0TarzO1rMGUnSPuR424KL8k7Le5UCsiW5GmQihkF7IIph0z+OcWyvbSTM9vZ6w/z cqTml68VoLPFKVOlULo0OjvTcmqRazNDWBzm+amp8iH36ZI55wouPHit19YVnhUelFeUCcAb wYIhnjbrA2jRSjJSJhepLiC/YqSutjedAR2SHIdBghSbUUBUfSwA/JOade84/XJdsZHlTncw LlJmP9sjA8h3QuYpDyWksRrJQNZASJ45Z3xnon1xaJusfkHtQ28Smmz4q5HSCR7dd/jUvZp3 2wfvN3QzUdXPpbw8r48VtWoW9syw+3IHd6Pf/vGYQxX4XdEtuHdoTNQeoQWaBB1nAgycBn11 R2Yh5/AqTQlXvx2VO8aGrUpHvx++SNzf5G82xZWBO41x+gnzU5iUDRMgomFdwcDzX4jnVLrE Dy6CAb6gSzoXGDU1LFeRd8Npw+rWgVnbvuDh4NMLhpkag5ruAEuAWJfzawJXbtUYZj/u+SDC SGqNXv6xOqx0jVY1p38GmNHX+c9l8glwXb0fIW8mAtCgZT6tIsCUSJHSn7HU5aneDs552TYL ybmUXwgoGD8YCQ6YQ+o5mZneK6qjQjcVT4iKQc5pEgJ7RbpfRgbn4hU9c3VVzBjNmJjiEltN YoJYG1n9rVlpITNAqqeHSTNHQnxatejTD8lDOesUVfqQ0VJ/uXCdPPb9UBRpGcIGXrWmC8IV sANAZHZlP7uORy3Sj3duL2p3HrKrY7lCoteBLk25q8OIxEiUE/eB8L0z5P/YcBmVoCWb6lZA 2Un6+8VgPseGijmf+bWLaZvjsvpAlD/vD41NKCGnik5qtqKeNSGeRSn9HHKT7H7htNYYrQ5P g6qcgJFh19uYTZ9EGpV8C6Ph2RzN3ix0e4CXF69BsawLr1EPXafjDb2/cR2Vi12uS93Tb+yH gxA6B13Yr9mYPnWQuRmvSVENBWeQe5eCWJl7oiMcry7o9cNx7im2RRsFWc0lU7RlWuK/xeh6 JSXeZA9i4+puLa9DXYo3kB6RTHSqoJUKLLujW4xcIndyacP1WQT02St1QWWyAs3Ste46Nsyt mHBhbSj0EhRpF+ewtkIPIETg1TSuyjcm1zxqPleMebfNbkPa69gX3Yiuw66NoefX7KU4Q+WP KhMpMTEh+XU74Y8UD1Peu/e6rkLbaoc6GgAIYzqONy7sBxc/PctfnUg7yHokj0B3OvwZsjbf o3bpVDhZpm8qJy/sRk+d2OmOlLefF9vZ6Q4eDEh37BhTFGRpeeSY6zba2UHn2jVmRdzcbTLC nfTJIwRqEl+QG+85/q5Hti5rOelrik7XXB4x5lPwzSdIFgPcbYLkdgg0q/1MADKKkZluT1U+ cH9t7LM9GZK2xXd9tQ4wTybg4XZpMdN8iFyfmtL534HbP6cioa+/PLitjqWyNBRAhjjrq4Wm G0LqGttFiuOKF866n2EMxoh8+k5XHyIqAv1uXmZI1QrnHC0wzf8AhGOkuI5x6zXQxUUbWPmx f95aSwVXViNkEASuBqHQcxzJI7bPuQUX0bStG7F7/ir+Ybc8uRnEkOUXiWxbYE04X3W6wZiV /KW6y9yTG0a5OsFjmpSSk+2524bdc/x9zhMRlUy24rpVy9dLIbDhRKjqM6Qprm2jQ9VYf0hG 1f98RfpIwF4kD3eBZgtE1g8a8Q5JixAKbxJYLRDR3B8SrYIYKm+30HGN76KkMfIa+in6P/Fm pIztINt8jeB0JhrgUjQQ2VZIUDqp8dUgFRsCgB25O64X/VhJF7YmqMEK1OAEhTqcWGzh4Nii 3bMV/cEjIiIEW0ZEZi6RGCavcJniVay9QnpU+o9u4p1YjbZs1sJ+1F//eGcYLZ+OOvUoAitp OQVXvLtk3XhpRtptsBOy7oEbym+pt7O8qCCDmQISUqdnrRHbBFzI+/P5UMQCbxFfTuFRjGRr PbWjYPvnJULmyIKXCPTZ+E65HleRQEK1vtvbcmSrBh0Zw9hAkZEpSEohF5gQCMW3kaa4M/ap 6eNvQP8ZKygWqMDZMQ5hbYGi7C0wt0+q4jMRmUlAsP9Euc+pHXSRoWQbS4LNDczzEa8949Hs SKLa7fiXYt2Koy0uMRLQ1DpB+TBzY4+tZWj2tS3vXPPb7rtKpovUBB7Ll9RUHwQkBR+WjPZc /fHX9Ei4nFt/MwwhobCJfFQvKEOLq+HbGwD9erFFZitvHJX6FRUrW5ZglqESixUAnNe7lb+0 DhEGh5TLjgkFuiTy6mvutK7MCq6qEUAtNuOA6Hee4fmQbZmFlt384LIKSf77AJasr+RAzicZ BLOQCfZcrAeKlKOxJ4Ka+xQrYj8kLNO6K2+NTf4glS9+mgW4Z+SgqCIp0xHFqyUf8FypAE5B RWKCts1bTKiSJ2ZfTvE6QGDrmDiZwaXH/j58y4gfxShos2hRNZeIetCC0QUBqj5PbU7vX6lW DLX7WZ/lzYlTyhqL+z/yhw74HYuRl9RVABDTUsiAj4cOszDdNv1Z6dUujezjkIfnRxTlOukN aZjWbFzpAGgraXpbLC6ZBS5i0yUrrO14RXpNJwn6iTzIdVmpAn2HbRe2ZLIonT/uWAy8sm9c +9wKyXXhQx9FtgG42xd6BaYd5rirobzyXX1I+HrfbljU+/eceRMcIF8O5DDWSqLWR/8nBt+H KmJBepWYsDbk3myUBWVeO1AjzvKpb0ICpzcOO3G5IZ6lGHw5VcEL9jnYvmmJ1qxIMF+YWYQA pFQa834+/WA0L7c4xQ8YYis2XNo4hKRUGt2lqbSaZ7jQdVl+ClQO0mD1oSSAJHbCHTaZSGbb ifI/ijylalsybdPoQC7C5mYB4HwVSRE1mjD64WVxWN55xwxcxdQ4vR5HgAzV1fffEmHA9IH0 mZR6DRY7AeK+AYtMeAnjtTqnRRbOI8lDp+pz3F+aBfCAB421E0lx4QB8B9roJQ1nPTuXRTHG kY830IRjTpYstmssGYg3B+jC8Opw+1pzl5gcEocKdPXdA2R8jpwlfe70cD9gqgfY+kNN/oo9 8UkTxzM8c8MH7VY2+4dUFk8rLeq49LjJkMNvs5NRru0icRLDCCyR+43asjIUPda1IblupLS+ doQIcYXxMh9OiLLqvSZed0eWvjKRfJJPTQIgMA2bg3nUm7GNRINBggrNjSqn2aFprHejCi2s Sw50UDw3g264D45GhtjUxG3fIsxpdjRiQ/2pcqygOGIzETYJyFaY+iRs/ZI3WN2NrPSXb1Kf LtEwbyiUa+wFoLId0PxoX+vyTTVmOcXaIoEo0dBVqDjAL4zVL0CByR1sdb6DY8PrZDsRaLlw hlYRsKOO/8jdCMm6GFNFgrYFIW31dBSAr8KrGq3l3QQ1pjYIOkEKuJVN2W98vU8en4QDkhx8 UvTBKluUKiWJtDAUNCuLhLX1+1iS/Tjrq/bKVeblE2psmrkgwCriQFcIbm1hMJ1gKvoiEZfG kmIB+Yf6aR3HR7pz1MR/CSKUV9zA9yid3ic3by6EhWqOTVLzOzUPvuXGM2c318dPXHEJtccc MaLchmz63KP2o2Zo2eAFdWvLOmNIWFLCEvtNi/bHHGsgxe7BKvOmChh2Otajmu14dX5Igh/2 KHw+14tzTcxlj1NDttWV64c+a6zMjWwzQhtvSauNeZFq+v9erV6wZP/eDkOvHofdpQ56160F qWEjBEZAoxdVpWt821lanwPK+9DtI1lU0hot61VOgE9ibr3K9Y4/3M/HwLTGvvAp+jwa518f dvcv5/uDv3+Jm9T9Y7XyLzwoCrz2E6NNhHryAiZSdL/ybnd8n1muo7XyI8giEzg2dWs8Spec DDSBECzVMeHqrZHuRMQ5T9rP49+3NA7u9vXOSDL5g0ietVISQq93GGs/6tlPKSB7Cutt77B9 WHgBASuTyTwETHcwJThQgrAIFLUP0e/9y+ho+VRo2701bHEzIWYXZH5pAuFEBwugDXCReyfA sThZlkS9+ruXNNZiuYTVKfYRkRurRIaOotyA/JggSOokQPAXaxsaVDooT4SuWamndU86gMbo zq+9gQIar3wXqvCPwc9MRRfh67wEykutH6uLC0NgV7RXwoC0LnkXWstz3qs6rBFHcpO3Zy+Y oKwVJHb0hwuwfhf0kqRyBhAa/L7Wir6wU7EMdZjFAcYwjB7NKjfPN3CxgsBBVLxCv6RnZ+kD fph0rPd+rowAyAPvJZSC6a0UHBhoNadIx1Fbl1hHiccrx5L1hP0I9YGgYQ4/io9d4718F+1i 1YqPAk1nIqQr6884S5Jqw28daSWgHVmm8KR3qU2R/nzIPTJkEBQRkzDKmurXJ1uAtS05mmEG wZ0Y31YL0vPN/Pu3GKfsYWI5hZ8a7xY3c35W655MdK8FUxTCOQKEO5Qs4MKWVZd8oADaSjJT e+32AHq2d3A3ax0HUIqKhNp42jpKPVr8t3Sdkk9XmTGWbojFwH7o3aQjyVfSjCpbnCSN5cVn YsaeLIW9XEDBDRXpFYRtItScH1LZQu/GvPVWIwYN1kD8QCDL44ZhQJ4rYjiFDSgup4Pc8Mru gQlU5nU4jW4Ea2lynZ4seArTjh8MQbulQAoGDk2Ue0eapZiSNpV+33QsmoCbtHvlsr3Ly9Yi tndknB6B7If+ru/Sf1gAnq2qdZ7lgYJXOQ2H61x4PumQbfxLk6Bjcs8sLNU7lQPDeQq6LQFX uGn+XsC6aHpMRdbVB8qXfmsvGR2mc1e8yJ9C5+hacIBtCiuKX5QcemxdnvQMxgY//ntyXtKM ME0dtkaRwHgc0fIYO+7KOBDf8mxLbHCd8FxNjV+LH4xTH4nC+V8zCfMqC681ABhRIennmHLJ vy6eC3ATb6jq20wHQNNXzNMaW43mY61ObYQBrOPM+aAS2zikTYyZkTtW60d0KVSfdMtjVzTH M+HYvNkW7rnidao8F+e13pc2jbZe34yzudqxIqTSpJmwvfWgjqR6Zlxx6UN/LoFm26fagGaV TxPHGJZhaANmPz3WehggAl8NO61TMRkZ3o3dxsljvPZ65aZM0BC1wY3TkCT7gypQ5yMxZCho X1LIbFJX7mJeuumWKMs5iwpyCUKaMWlJ82NbmwiuuvXWjWsoePY7JTJzfEFirJzxBJr9PF1k pefzJidFSPt+v3EB/TdRmkE246nKtLd3zHZqQ/husZ/hGCWhgRN7R3r6a6zjyOig+jcziypb xPPoMi0UjkLP7iXz4fsdVq30I2dVPOm3MWMKyYMvoV1Qr3L8wW5+cbnS1jD+NyVBW+voTfbv HDB+NZfj8z5BAfeKHt5fSI3GQEI0xTPQmmBl6ysYcnnATtbTguVYVM5guU6PIWa0FUAE6FgC HAq8nLdcXs4chFcw5LF/arpq3ODx2Kd8lzD5CYdjm6KdNFXErLAIcoh+xgkQUU46N+zWnOMN JJA1FU45b2/7rUcLHdSFHz4W2G3gHhk/WQG3T0HKokrzeRmIw3fJ2dFT58ccctuqtwx9gCmm 5zYh1ZNgFDiPXdhbZPnLYKcXhLNUzPk1s9UkaTXqZBapTwOg7tvI6kik8r3LEGeHxF2ONLXs gB8mksw9u2LeICTmKHtYMI1QFbSle2HAOLsVEhs4LUff5amlxGWH5ZaCzKDqcCvVcKdiKq/4 iN2lvULyzpJYuO22uHrC6MaE38RM8DURRkdZbC/t6eOkX5l/OQmqxSsWJaKZCVlEPAcFsixn mDa4XQF0ah1VgtQXFombPOp1AkzKU5KcKZb9iY916t1QxQ4vSsRjBZogj/w7QkO/9foNU86V cB6cz1EsjFqDulE0vH8aC50rGebm/m47KeK1aooDWAAkWacRPgIScF/pif9ipCUmAcPXAiQQ lLY8mPTCUWOHO/MUxvqGpwJL1Z6RnWwhntcti11+Hy6VqMVhnXjSK6jadkXFY7psAkhdwoDj 4pCtLopzr4IHS6kHWStTYWSLV4p9O9H7u4baLTA5KPI1C7x+uPCnejmnuXXEQqI7MfGLIq6o uQnsYgUVvuYaz2oF9C8HrylvaGXUBlS+c7MBW2QaoNa1anaaD5t98p6CgguWzZfaOlX74jGE NZK2uOoDcqqmhMteLUl6CTzv5yZYpC8lOVedURXsZA34heyo6fGGDvS0vEtWlzHVV5MAgulU mt4Q8WnKVn8hs0yKXqUK0NexRP7zFlXQQXringwH9bbZagKyNYLAPuadcq4B48eJlLuY4p+S S6/7F/Bmb/vAvatG0Mj7eyEkXg45rIFWs59q72GsGJlMhGo4I5RoDLB8TKpY1G66Bqzbf5l2 9je54pC6s/vA/jeN1ulLWZtgDPlfXRsTXGrxbIm6JIpoE00yDY6ec8S+ntWf9I7LYjZIffFK /Dezu2nz49pja6y63ShzlWfrbtIeiThKdsHytgG2tTJGU+gHWv+agVfOl2T4jaMfqAt01zuD HXwKSpQpfw3Ld1pTWPGFT9YBkUqVhYQVHoHgB9Vc6Z3WOIKWvvGc6u20da+XC2SP1oXymWrV kMkolSfLdrLTISVrGVVzWGmNoN3TMSRBxE6nUIst0VEzoqmkiHeVhMxj9D/U6C7qA/1QGHUK eSkNw8QuUk9QWHraI5p38b6nM/JLc+tCjeZZeHCoDZbKFmeiikEBTD7B7+GgAxupeYjhxad/ 2p3ynzgBQm3OjnFPVeJ3EcFoU0Be7CYZGaF+zb4fW8JPN3YpSqqrbv0BhYa1gmI7vzgRF+FD 0agxp9qtx3VkI371kYcggOEgQeGXKb3SXNdLm2zKmJhxPFqN05vO8tBFJ+c1LkKdLvhuPgm0 pmWiDZbpGuoll16HcvKWUwBqZitXLH/snVSFNjFjJOS1w8HOfzVqQQnGCUjn9VOThSg6eP70 c6kjzQJaj+U3Wl4L4EKgAPVsm38lmbNszpzW/2vu5Pc68+XVDIwf1gtpdptPPrJ7Cfl8qVxe h7JLXtOJO4+Zp5udPxKPxemns5J6EhwxuEgAgr2AwHx1iMLNLK0iB9kNNqp9tfZTQIS1W45v zHD3Ah1aJyb2mHlP5qhM4IkX6GzOqpyBSqLBLtCPmNVZdPoCW99kvo6QMf5ojNIjqmor/UaO JC2rbOIQ0YqulLQe48aZoHP7uDUfYvlVvKWLT4leem37YNZN2jscwA1J83HEmIaImEqXIUzh Z8bCxrald35SvQkAgEjbEPtXegzdPv/MzsnXwbjCsV1Q9TlNfMMSkUS+SxxyUe31tHsw9328 uyf+UKN1izhHxQWFPlJpcGzSw/mL9jeDNSXIAvBvo1tZ2NnjjobYxjIy8E/XZ7xL/iUBZmPn llFNOORMgdE1vyF0PQBNSC0ZDPOFwHklNtxUgTgIzRNWQautV39KnJR3FLUcsbH0zTHH4WlT DJkx4L/KsOT+k7uZvYsk2XtzLFnrahz1CvC/a5tVnkvI99l85hRWVfq36UOYX7m8HXyD+eQg cPk9Zx0uggJLENqyYbyn23IFH/diPZs+tw2t+2m6NhHF9jDIok7m/AV4URFnyGQ23a99uWhE 5+B0i8l4HfRrx9+FLSh7lQSDvhvSf7gk0UsR5sc0C5JS6WsAUKOE9JptvOxFrgwv5oba1l4X 18mIIXsP7LZWMihQM1aU93evEIJtrDFx1Dr2Dm8GsUjz+bU1kfguRefPYv3bkveX9El8pvya lboW2jlVZjtDmmoiZ5t9FI1g6ZiayBnU0EEMmKqxR63zTMn2LHflx/Ys/AGZFHp4TY2Erg6/ 4KGKe/tUtihLfTWnB+qX7CBi1gcaqVJczGCxvpB4ngR4w+rm8+x2O9jWiDulwu3xmt0MXjgk MdxdjBNDKaNbkHfk1bu71XtOQSklgCoBLZUi1xuH8Ed4ntowr6/XzI9clcZoUs/q3E2QZEnG dXJ9VezZmziP1BfEAUd4TdJljOfHEiZriLGsGnVFsH0ObYbfB+ua30fPgyc0IryR5NV1Ysfc uUrOclFIYkqc6iSA2TR3/fLaf4Qc8H5AWz32pmxNpDZlzkKIf3pLDz6k5KiKYYLyqTLdCysF IzWtSv+zAxgC+1m/G4vKMSZOPOdtVVX2wh0KJSaHkuPNORRjxMqFpEptdQdOR7ycOkXf0CEl 7EdyDYMkMF3MH3d7SGF+l9H7IQlwpIzOd+jfeTMxEAQvRWiVPZfsbXaoMoj9hmP+TqQ3R3/m r9mrAHIVIG7PI+osYALBJsgks0TXNTJ61epYpzynEcoX5pUf9PGyCOdRAGf5enLYf4X7WLIL w8lJiVh90Xkf0r9hzhfJ9biFKecSswBbPFQTEVBgUj9F7OUMrWC1znoOBkKqc04ArcDBGER9 vlhfREzT1M+JndGZckC9u2+W6FGirwXDCfz7o0w+farzmY3KZCAIS4+TGExE52/4NCzbPgyV uDLIfaOJgrewJNbLPAxrIA4TxVGeZZVp31DNnmQDnE2TDDCZZo7w4kXXcL/UetRjc2f9f03R KgvZJga2TrMd0A0Teopuk28OO73BjAtMQoH8f0gxNRy8aPkBmi3Fak8uHb0PV2v3gAODZwj6 8AbhvdxC5L/CreGLMjh6PUe/cFoMzM+rOHkia10z3rA1De/kjU/0/eOcZeBhvEllqIrP2uRl PuK9v1dEdB7caG0f2qPtJm0JPv0A13ZjMPC5fK9Sj/VxLLgbBO8kh3Gf4dEyy2ee1XPGAX4b VO67u52WxMIG+gL7Y/Ypl295zOwXB7x2CQ7si9Hr3X96SjKBQ4niJcvny7AanEuT7/2h/jf3 HZMEWU+RnegZK9ESJg5HltGcA+GXgWPezrzpSnR2yTOTBzu33ANAM9wp/56PmlxPrPja46oU kLotmi9FjiNLGJprpUgtCCA937rgCbeUlvT+0KM/HHWhhS8noC2DKxDQac1KOnJ7vx6J4FpD PaAqR2i3g7s58A+a5NkKlqR8UgMi3qfeVdfJ9F9Tn0AKTvcprSv8OT38n3+nGNzf9IpIsIGM 0wEApP1/1HmJWhl5zkk/h/5Oz4hL3NfW5LGcOsZnOUGJ0kwpZ2h4HM2Ljhb4hNLke7yFcsDe KZ2fMZFnDQ5bTwAvN37J0GI20Hc/QXZfbw8MNi4PWCejLJK7x1pVeqJC+CCNmn/oBpnYdaV2 5asBN2D0SpmS6YkG38r0SjVtRU0ms0OOrfiBKgLQcLSiHJmA7jeBp6w7q7LLM2oJfr97q5E9 fY9ELYuah2mXT9eDou1UXofAAdtARjiB3/NYAaqmThdQvemGMKvvXEUnyBnnwtRk7nfQSWXw p6hJza78vNJJ+ZdfC2CghNDVr9Dfld2prMqPH7Djl7us60N3X4RUO2tUFtu8s3LeEbOYoKxV jtmRIV3Lqd1qqmrjE9gsH6+cnnjHJZ58t8iXArlyq0Jp/jhoolkeEDhK0SVLnBKSUaG7jXTJ +brY4j9rWE8MXLPWZ3HRw5tHQtLcDlfujBqZqUS38E6VZ1ejdaHMXvbZs3P5vxV90Tb4HtCB BZh6NRVijfMqGpfOafo9xyKH4vH6qkv5ZvKpGpEz1nZpWpMhX9LaMjbWMYd4UAVpru9ezkuS TsjDhVHo9MD29n8FZaEqvU3pmk4lmyXEOrLXOoDQiP5Jkn+Gp+ZT7NG9FkLkJFYxGn78udIh RWxhMhsrypjOlPSBCn0NWEBotb3v119AoLNG/f+xlFgdLx+RIQASL7RTvG2WOBr6i8HzPsR/ 2qGpsFcQuNO7quM9LkgSy6m7uFI5H20pk3iANUHDcD0eHpzyrtRqh6cEMD9ggxViGfmbqCgG ESDAM3j11fDv6EuZvgMtlZPEabIId0ZaXiGLG8lhoTnygcIkfdMV6u2EVtFIrpV8xr96plBE lVkpZ75MMK2RCq0k3hWMebxpnfes/IQSdqj5dOJX8KMyxWqmnkcTFtvx+WzlZMmHnlP4ydBV H2E96OBrFDKsYfrNCPRAGJlMkkv37I4EpuH9Sr3OfBkKwHaC+IcazsYZYff7VXrvPIhJwVF+ QhKTXwZCJHzOThuGhRh33VVidloHcickL/8UQ3ecTW93KAULrqM77unVTISY5OTpXcT73Tb4 s433TaH+aYSlB56s3yRDIgSWbtZX+itF7ptKok8WMJaHC5P1jREpaB7QQuXBcmE3eSaAM2EH 5upmOsQ81lDrMVFgRS61A77nUO7e23wVLvp7j6D5P7zJXUQY/M4HqCYrdGo76KDI8XYLLCaL rERq5P9dVj0QOD0AnJcIlpMWuTTSTFb+tsukaCnf/w2XiW9jCHk7pG1dteWzqIp/auRi3WuA bjpJK9wQwdTs7dbEZmttjIGNQlKnY2r8ZUGfKya13+EzcVoA6doOjN0k+ga0u9RCjecInAdk RhmlgN1aXySQPgUq5YiYs1UYV9evbYlj/qoHP1+V4YSRdqn59s8YcldjJF35CK27u0SqU7U8 ybgZzPV7KOpohFVuEQfE6iB8eWtyYOZjl57Knr47Uda2edUvxaLyuJayrdC9V63Mxf/XQEEN 7oOIGRrDKhKjcrnMLurPDUCloSzEna6MefdfH6Q61R6pKnyYHoTxk311MW9nWJCitI6yH+x/ 3jcrkU0p1UAJfblnr6z2lo7o3ii0CTau7rK+2dvlyKcuUbryJRFoVm8OUPFeJTUjUkaOBGYJ 2lkyOTmkPQVLAgDhwSRytJ86MUatq5IjACgsYbEJnKrdZdG1PMGy1myFEK+ICAqjCECAnDY8 UcGE7QWBPL38XtVz37H4FwEv62SkXPgw7ZGdyhuxSRkVJWC6cCoZ8ozUZihuWBWUOoNrdAsa bEAMdWMEF0pw/0u9wnkZq0rS+Is5CIm6INP2R/6M9Ryy4/hJZHvWvEsl16Ya6K7jz9QiEO6N HCz/s3QmvtrxyBE1/v5FC93BYvMRI4xVKMv6WjTSqIR1CewsYPpl3XU0NYIZ+n75G66tuN23 giYcLP1rkC+jKxV6gh+Lj7HhhtlujS1FMmGsSEHgXCUpnaxczBwA6lMzRiIIR+bYlc5Si2zV qfR70UN0zFyYZXc/s5YqmhdFRYFJv1MRnTwqMpHFfYwhl5I/iGCwHACLUGu6Wt6Qge3PqoFd 2Q9FQ+G5Q1vt0Yif8mNWch2OtG2jjvoItQlQ+ZguKlpfAl0w4ZFhqH4xugQF1oonOK8QJo1v Yl4n/QVDICED8tRqUktCoreE8KntT2Syd0CIo404ZW5j56Iter9kpVkB6Nyx6W8Z/30IaODU fGxhzgwobPI56Gls9rfjssnP6pzY8c0us4qpMs+ylJms853y7VAzpT7z07juNV2hbQHfEqht sYw7tM9bSf9CAmyMgvLr9p40pvHpAHrFcCoqug31HFtibyq6HeaoGTXfOAwBr/BPNahXSp1D PhvHbiyzqG3lBqE8n3nnKANSjOMHUiOaDS1wLC+anZoffeEVKf3hCf7Lmfkk5/0tdi8bzIqp m1ykZ3Kd78Wp36U/E0Br7P4LgfHRLNW4SMVtuwe4RvHN503m9o3wjXTSmDIuD8GK1ya6biVz blZQZmLWRK8Ix9CRrg2aR18qmY6Ba1aBF9bWg71PKzLXkciw5t3B53FSA1EZazYOUjZwIODX 5tHL+3H+W9iKA+w3RuPYritFGzmU7yykKbu4zFhcfXh3p9iQ33s+P/tP/fwnCFfo8dbQopAK 3SL7fK0vuXQdlsStAirdg9v13JcijkFL4HDHHcFm1CYorNXFoSMCTzU+qeYGo/bJ2xqWx9Ez 9Jk7szpXdy50+cAzVfY0vtJ1ZZQ/bUVv3IMqi+rBuOIfdBgEVdHeMtKvRCLaSAs9hD3o6owl 0yZSYJDfvnEWtyf9nlLcxTIf3xdqg3OJGQP9ZrC20BD3mAi68g2rvRdo9IyEpeOPjrDVrjeG 6iwTWBUSJ+GWGuW30PjqbtvApfnIeLI0QzVn7KRVYoMF7hh6A2f0YPRIpEOJL2q27Hjs8xRs vXStjfrsiuYCmzVpktWVIPpeXHH3CG63ORSWwvrohVxeXq5CDUmU1nJGMksrPnMnLHHa/mPQ xrC1jDbmBtJRi0Lb2Nv7EP7bjvIIIb6eDGDgS8P1x6r0LHLdlnX3F92y8ZgH713LsuBLSsY7 AAxGJGXpyi+C78NtIZLq9d+tJzdwlDE0TZwGP+vjtOUrmEx2ehe/UBvjm4r36vRNq3J3kbur oBMiZwp9wu4ojM4XOvJRep8zhG0dSAaLAbMeNM20fDzR2PWwooeA2JoqCbNdRVUtEG0VqPzC +cJNiQ5RDfuW3jYfeXuTuh4rKkYF9kI4NU3otyD5pl5Hq1bDahwnalHvR1QQtee3vL/F0+S0 ioRwm6J/ZVatatNH8cr6GmODeafdwH/nnASM1eDRRYP0mUZUAyS/w+zy0A2/v7apI7nN6Rb/ oAuVp7j7zpRRUB5DFXYyB3Hrg6PSGcqeh1bir8IwG7JujgkXuSbJi2ziywM2dMaHhUPW/M5F siPHM5LFvD1S7px2vI0r1ymAixn+Ixm772reOPhL47uzJrodyV/z/zjbCK10/hy14r1jToZT KqEEgNnMb0N1oSD6sdRpeJzV5hoIN8tSsS3bJMMepud2MuVy4NCDtyRhBc/f04m134EBQlmL 41VMVofqIjetUOlHMYjx+fSGTqTxjaOWvAJaCSB0skOo0TTchKVxptel8BAth268nLkCuFJP 4B7sNKvzhu9nHu5TqrRPzYuzV2WkAdjLK+R6GTkp0xRT1qr26YK2ujiTjboV2Lfo5vj5j+zV mss9AVOV9ZannVWJP3glKUA1ThEf7TPpcEU13khWM9KK9d+vkfdIPmrReBs/KFU27IJshSa4 29TrbfAkWxd35xImYrPcj+wo3WMcMk4bme3HhcYMVYkxo0dnt5x3otomp9PG4WvHlC2fobMp 12ijkMGOxV/vrBlLOf/vafmaqy+klll6R7LRjNaNr8Jp5EC1+4NFARkD0e7cKYbBDc4c4/gk qgQR/BgWPztYi2f39BD3ICH9s9sBqUpwYryEuJSxNQbHLme/lJVUDC8iYJXtZHTwLmM9IGO7 KPKaBQAPBsfRjP9gScNIX5FMKAywNChytL7yd5zbZFG/SLi8TtXElR36r1OAz1ol09bRy3ah aHhsUKy8vdx8RoNFZc4xLnqZ/sEFbbVAGm71s6J991CWgr+Lwi/Q/FcokrKAOQlfC2jaSdzx exnsdhgteywhPHXhvHt5VVoqN9HVjG0NS1kvdcf3A1fowVqku2dtg7kpwjz4i119dzYjdfoU RmIFW/dGnJ2qToWp10POMXIH7pr2FhyQTvahUfppK6uN59Ob0xBKwpa1ImdT0Y8W6XU8xvxN gNwhs5d0bl2RnpfvEAeiDRK139CsEIxPZASB8Dp96nX6U7qQOU1OesYIqwuH9eXS8QM1U9+d bEagzsZe+NxRtr7YG8/dX3FYqQU83OadSM75fNuySvVyCySHAwPZoizoS780xIkrXfa4IoGQ f/lCucl6lBqzDD8miI9iPozz1aocP0cXhKTodgS0SCa6C8oiTSTkBikW1PHzZv/IoUbpVFa8 kogSgkNVlDK8I9V9JqfRv5pcmloDnQv6KdCAiskVh80kYvz2CgiGYkJ3jqxKzlzuIKdv5AVN qwRrEZByN/EJ3cxdEL43Km1S/JPjZYYw685y/PstSStQKz+fOP+BfNayTq30BDA5R+R9miHd MDonMIkprSs5tIu6lTzntMeHsy5tcm3ge8vbI4Yz49wQUelol6BVXfYsHleC/UgjEmn/rXAG wgXcgvG3slLRu93mhYUkJ47Zxv7sDo/RyCJ6WC45em/c/cTGWrWdQVXPmJtgCf6dwgX57AWs ijJbckuz23adtJbNanQOfdzDqObb9MCDLUvNe2/ljGqgG+2pg2b428RBvNqS1MHVjZvCaVyE LHLx1URD3cgbVAEiIfVt75HSeLDbYuoe2hyOHfcsu2Sult3uuUCjlu4V7wMeTktOr2oB+buI YwDiIeSS/CHVlvDp+7DIMSI9BP4jRDiPELUSn0dIQNx7l+K36yhZ/Pbs+S/lPbwAV1Ag3sMC I3PVspJnM05dUT3MQP4TGrCbCoPmwb5sll4dvmEOjgxHSXw36RoBN+dfC8AEMV2ZmaPyUHW5 /Y3Xnl9uzS2XGaovnCyfabuRluCrd0ifBUM10j1ccQL/ZJBXtLLSROvaNvVgRA5GD+cAK+Xs IsroLJ2pSX5K7OUYgFs6kVwi5YT2OR/WMyp/3aBxRJCUiXxXEYjitSaFG17P3w1Cp+3DUd4x 45TQJ+PzrrBDx7a9yt+2ggNe2kUst/h/yBVfUHKIEJl0IE2gFxEQf/JiasTeA3XO3QOae05A +yjZRsIy/JP3w2e/qi0mk1boT1JxMOPYTGFwz90p0CvxbkfYEa/iT1JkmNYw5o53++zMjTuX sMkfPjjvLLZ8PWAN4Jj6DnyRVOGCKkqIBX38LEhLyhMJlNGgJNUy1aobKSh3XFA4D+3oyiHH jhlH0LkQZZ5nIy8wPvGeQ62f/kfvBU1A1G7r/cNFXLeAB9qWM/roJjyUtltyl6aNG4itWmcc 8JXrTrMslfUVYmH0bHNS9+bigenF6569qh7eOQ0X9c4+DkfwVnjOFqSybKSrJEf2nmExzhUm guUmi9hkuUH78rHKDITMYvytl8RZzCeZLSjFxvi20PvAClsIuJzZ1yjtDTlAvstAC2LI4+f9 XaxRMeLRVzkuHYk6jTCxUR/DKtT321TWrp7ryTxyRMv4k0/AkVIT7eNgPoFw5BOPd35pAicz u+JC8o3WpmyYCAfp/URwsJaHxISECGEbWb7Nb/dl+9gYoTugPuToSLhpvcl1MRQFTNw5v8WV mR0gP1NjTP55r1pfjK+H8iMXUsPz1HqDzp17dQrHE5UdVgBFPLq+XArsMhQtlXbLPR1EzqMD L3dgGL8n9AByikgsvzOEe10wIcmhudOQcRHG0qvo1mFVPWdJSomCfjgLwZ3Gynf7KAlB8YAc twcNz2k966fEZmKYqDTzSmA8yns7Wr306B20O9dracQaAtU6CXwXISE2T+phK/W61gWyKgsK qUiSqxtym7tFdTmGQB9uhxXD+p+blZaZmkYQJtc4nQ8M1oy9wh86IbEKJi5Q6ZVBCF0Ahees UwrUzDHKR1oOIUyiLQHObox1abJtSOhLpeFhc64rwEi3ZM9PS7RYTfLiNKCLrk4HM3RQ8l2w 8oGL9CEA0WF8bETjCntaOfOZTjTCh0ZhMBUzgUPo4X/+o0dhIc92TirqKPZS1j9jiNWYz7I1 iKJPNbT3jzFtDoMpB6rX0DlnF6DubPwTpU4esqN445b8OboGmx1s7iejln1kpXnvmIboVsNK zJaQEwIadS8t60gkmL5UFMDQpNpAWHeofuF8XhygDX3pa8oavMAprXxnJXaWUVj3TsTwR1qc SsXxmTEKp0wdMPqEUGzE8iW9e/zeMJpipythFoeTNXZWyvh9Ls6fzBxH264mjPi1GgpdVx68 w7GaJLJYue7mGcXtlu2pdPyBwiBCAUr5us5INjj1bkdTcq9u/FbdHXMiXUO0a73G6kuxaTi2 /tb0PKH0TPxrE+R+zS4s95+MKU+wMij6N/FTnWBvbwaRSPmVPV9S73BAwJdLN6uh2HeSh9FX QkA79fm2affYjyC6+miXTWc8zygBXBVGKdydEFCEC39R0qC+U9sbRWnbtl+mo6VeAxzTZFEq MXqX0rxWDdsvaEPyYsyV0t7hRdGrghOcqazws8GcYNxUDqDKyZpOpA8gt4gnHC9MA1oX3SJj CnqadvPHPPgISNn4SvDbZ2+Tz2Btwor2qEjTZlycepOef+RmDmJ/5k96/WJo34FSKuBai4DV ASnIykXoHt2HTpwLfD9uhK9Uz81zlJGC2jvaj9gR3/iouoj64R3BC4djYzv7P82OwCo9DEkJ PT1IqltLND7Fa7S7sR6tLGmtVQ3NtCHLQ/LxEal4vQKk86CM/pDLiNXtcmxMb3tMS3gIJcOz e51iZCnSlILxBH0znQeqHaGVDnXXDNrforGvlO7p/kwiZnDGfxJwpUijH86mineMJBejzRnB phmuSpXNwpa9wuVJ9e0Kk9OmR4QpR2eNnk1ffGq8eBH911HtHTuTsqOFdJxuyOre8Cb2YJJy gWlcKe4RzPmYD+TQxO4fB/Wf9nutCTtGjZ2ZzHm5qpbgDhTTKM0Mzqhcyt+Xn0OMly3saKPi pLU/z0BkQxYJ6dXdawr2aAvPKKqs3FLZpCZ8DlkuQuiYhDWO0vb/DQ8Rso9naXocv7g7CdOU XGIge34bW6kSmLToUmBOZsKuW0vYRmE9YJ7BpqktuUEyB4yeciOUmV3hWMucpidmo3TdTqSu SQEIOOxKRtii4VkJDDQNzTjdDGaS1ERDMXMspF0wvrQs/0dGyxmI0mfiF2ElnB2NQPYupCQs fMHYRuzd3IfiKA6951EZ7XNo7j66rjK29UGnzGkCgckiXkarO0WgBSBE84xKtxqHB9VrTYPU 5NxZIOjYqI1g4kmFKGCMtzTEX84LyxWHM3H9k4BlPzzuIaStiNr014pm64SZFiKF4Y2ez4En OnX00VlRHn6wT93B5/voGtYen6XwNvohhse/PWo0RouW2NY3S2zUVTc4RDRNhtYqj4EMY6pC vnnR9ZuOEp0ggGB1bxDZU16iXu6+k93IKgdSPbGfjoZLziVzH4yipMaKs7ovvZx+oN+nQP2k NlDVIcPk49P/ZJ7MOYS1oN/dK7goG4i0gh3FKJehm0ccmGD/HJUX2b6kHg4B76V4rVdF6/Z4 f+V2BPNWzUZQBH/uJsgD2f0mdwU7FhKjI7MPLqMnTrf2kLo6n2T86TaT9zPntMoX6r8AgUja vmf/l91UvyBrLzWo0UYkCi2YcY3/AGLkPQd59Z3wIzH2k6iFBDGh13iBPMWnniLN1oUhxN/y Vzd4GbKHlhOXo8jYQhMp10UY4eFXr/aCuLvDOe+IuQK1IEvJRfJ4P02LN1A4OL8+L+4/AOf8 GiQXTetyBp5wQUzPCZ13W1AEAVw93OBoTdnaa2X0rNMNDJrnfhn/t6xx1r/IUIx3wcLkFHbA evuReNGcMELGT3M3sXadzv4OIGyDIK58I0owSXHH2MSXwbrIxLVnfg7Cea7mVTUVRddhsSA5 r6Aic2i7tzwK985/FEKszj8gfr6We6y7m3u6OdhoGXZr1wR9yY5t4O2gkpBQIb4DBCLfdGBu J3P24soJgdXJQWSn/o0/QErx5o9hRFnn3Zx47uM7TNOkehylZC0iBPTxvUeF7tX+jEOOvuYz 6N0PorlcxAeAbkDSTRrrSaakyBGTKYgPV95g49XO/pxzG9UcFZ/yLFc5FXHLdrmWbsyp1MeB xkoT4ZiWUT6GCO8E80SzWHiMduWYCyO08xbatb3qAiixAFSSZPBV75pVCXteDMaj5aASmYZQ bLusdd7g+naewDHE1qOKkUPwm7n3RPZU5Rpf4xfPcg7icgP67DsUjHeQr4X2ELYonzdUHpZ/ ywfxnPDtZM2LeP2O0wxBcZUMkHQMGTKmalkTQ2u3qCo87bAygVW46tuaFhVDyguimguKns3j 3QCbxQVCC6OIkH5dXEZE54iO1SL11gq4+epb/XiGengsNPfu/p2TvI//FlA+EhNZjqVhXnc/ 2rgbxmDnbmHNGAInxh2rr2yy3FID/0uAUNt4qqVL4LzHMWoBgAkO/oluffY4SRFBZdTnoe8H dhl2ilhp3Rqrzs0zkK/UktTDHbBRmLufwT44GHEvW+m8JogIqOQPkaoN1ekoKkJ1kW9whuMC dlI82TysL2ryvoov6Lagmrnp6EljoxzxUKSw6nsU13VuarTUPoppSSVNpR0ax1TmRGrmDyfi gdVkTcX622hUwmxm8npjC1/I05Pv7zvOfvTm+IVLf7o4vGtmNWizTew5CEhQtEZAMKyD/+Cw rxI2o1tnsmuUM5HDgEDix7E/bFKk/6J+TgQbpUOWjrqeLT4zoTH0JWAsZbg9BsuHB8SEbUj1 WmwD9BllISg+yM+O8pXUZtLe3B4hDe0/CM6Wvl0tmumSbUWP0GVcfWLfvfpbLoOGF10n0M6S TRf3MXLUccFupyG1JPi9aBeXr1J0xEZBpgX40WegU0BcUHwQ+b4rUYMfcsrVZ2tqxxjYQSsL TZUPHAIZ3XwqIz0kw9td6XoVTVUm5i4sa15AhpAA30oOMXlzDBrFUa26THxUb7xTjKNadyfi ZAD41yAyOnzCGKZZBn5xjF+8/eQt/J6n1hkXe+V/9vH5IHI6b406xLBijnhBddEI6SFGem5v y/1yE8Jhmn19ZO9n0TJgfLBcfOJEKqQss3+8brOrL2elPiuWf1e+9AeSoCFfmISs2fQNSejP CvgVKYn8UaGThdJG+0McpvmEiNsdlEAULyHFPAHhb6tKNa/mUDkzOwdICjOcIPe71XUxAMRI dSFHV/Uhumi7ZS5swvAixOQX1/4PT/FVwvl3hP0wKt4kN0CXhjpa1pCCp0oBLj5A+ih/CibD Guzm0cssG6Z2BdCLvq8dAwINKoqJa3eawE1jRo3+i7vM+tCEUEKimNxI08kY7I6vSGCAO6kb eidsGX3d6ks1062Zt6K2pnDO49+4PHWn5Wb7xbmRgc1S8prrBD3OxPM4OACzD0trl+7dpl8e 3YbdwksiQuAZ665yaol+hdOhtaualM3F/w49ipSIdfPVdJ4XjaSpXUJsS44LPiGB5HEw4ItT olaqO/payB6Ce//MATbqnOmanFLHX/Rx3uxaFiF/kw8VzBQAt9Wjwsvz+PGErj+fp0/PJoQR Ip97Xg2GoWE/EaAXNqa7BRUM0ONVAAIfBFZmJ9pBKWBlpCDmMZ9HnBxvh+/1brEmJFF2oAPM AYXH/TLGYo+Qq7KuVwNnVq6lpV3e7R8NI2Neke3nrnSwezquwzGnGEd4bobag2ZnFf0ydHSQ X/yZ1i2fE6tH6Ce9+1bhw3UXuqPwOuz9yKMSAKk4sVXJt8UbdZFCiId4ry7CcsHC3aClhRbR GV6zhiXga3FR4oxe+7gKMtlT+pS1YybNF9OIHiIQFtGTthxGh5r1okIY8kA8AmVxAGaXCU2x Yj6Td7xp6tYzHWEpFiJGjPP+BVU9R7dEpUNakE6vSrMP/F/LMkUk/YVIgyB82JyROx92/MFF WivGbYxn9HdcYkaAjOQ5RqiNms20tGf+/wTLvpSt5UsVJcMp+Ea4aSYxwSTz2awPe/462YXB mozGMmXKs1jPtUe7eNzJdoQIitVSXt90OVDJxwtNFztd3X3J2E7yu9ZEpXUj9UgtuHach11Z YOxJGUfqxRNg7m6GPyq65lWmGWI/Hi2f207jR/CS0rENuj4sgPy7+UM6rtSG93/0tPrKr/57 mU03F6Cs0n/1zNx3b1VjFf68+Mr3pKOMIIHL7VyPJnRyYss3Ohpk338eovrtdI5FQi8lDU2N LE4Rg/HyzJMd8LoU41xD3X8Gzq/BgBLqAG+qWnmmKQz9mXe4LzWWd0lsO5V59QbZWXAmGI1L L1p5/7WJsnKiPavyY1zjlVrplvtcClH+RgnyjZnYyUZErRKTRKTtFITl/uA2D4qlP1S1ph5j 54f30ERbllSSgEpQHQHmCB7XdUu3E5RkFX2uqgabtE2XbFahx3Si+L3RO7Usay7NWfHh74Vq XgGIW92F9mvBvmKnWkDo9M4uo9QIdJCbo0UByPjs9IqEcuvUeAHmoy1BTMu15rE51/pzjlaj r6X+PU5INMFIbLONjKnfN85YMO76RYmHAV1b28qjMSPkQOu3nPFpSAjLO9M4YOFRcvLgLNbD UxzlPR2Z7SUy3J+JtVUICRsy3Ns8abZHSNw/3cGQTZaubiemh0Hbg30Kui+FDdMVQFrMIZXI M1iwd91a72+XBwsGQuUX2vYflzDFrB/1OB6uLvB8GLRFdBylC9eQlz94d8C2kWMqfHhmNr/p u1pb6ixe9GpsVqlG/dKbTfSwngG2V63AnSDGafy3gOTsndizawymtqLtXI9RixDzzX0u8x+l YdhrSPw0Xq1NBRWdBh2y1HlZZAWSeuBlH1FdSp62NOG4qG27CxIBGCXcpnMpAOMEvJLxDQxZ t7TU9/+uWtXLDuJtGqHA4lCFXXfPXO2Vf+XOfdnXKh9Tv8MA09TURDyv4cSC3R1rv4vsGFRI HJSeo5CZiK7sLORIhjOWCRDBPMgO7NM54L0gksu5QGXj5Tha0d8H6y9oy0SpeMOGPFA5MZGG nOoaLnliFHo57YPhpNgV4qmErBLdcwX/gZT4uUCv96dQAyQqTUkuNIbagyfkWBP54twyqVjG K6fLR81M4Gq6Wq3kCIJCfGae42IVOoAaMNrHeNXiPrvm8PZEvXkUUnQxUyLTBQbKx9GEBJaB nFROwiX4YBNYqYAJAEyheDCDLzaWRsJ1sYsWrroa7KuRNxnn2C0Ri0fpcU7Q4MTglrAB6vIC pF3V50NtcEs6ICKeLCcODsTq1/ksCCSEMIBPAldPLFcmSdJkgXC+eczTFrEFJBMwCfyNmiTv hh25MvVXZggVV+yAxw2TaQhLyjRELTo9z+qhEZJd35gBt8fjdqL3lFILJAnfzWOItx7xXQLT I77LKqk+5oSwkAYTxAivayTmm3gAeOE/ms42pC/IJ729lr64mMnNXhmO2e06AI4D4GWeXXXx Hwu5SzSMM6ebuOrlDjWNDMv8IVrlZA2whEH/xGGQ0hBlMnEwoQKxz8Lot4Sa3r/Cvpgg1Pk7 GvMnlsxJqZ9/scr9/nfUQ3+YCml+g7HJ/nIxdx5YFDppdZGWNtVsyDVvgY8FJhny1rm0vIQ7 lO7bpeUBSDnz4IMakyRz3hiqS4FZQk8d9xdgfkW8snQeQ2vqhn8kfGKVBuvZJpElRjPNZZ4b VPtT3Xc9ls937S/L5qq9vO0SifI5UyDNx339WJgBJcT6blU5/U4jY5Qsoqhh+9VTO3dWgHSp zs7UM9kr98fOzh6mNn4yCjwSKahxmT4EIRfVAeC5OvAkmboW61za0L5Is46xAXpc/Y0ExDg+ UYk7KasX39SiwEcRMc+Axrbv4UeuEbxVPm1PVMcj80gFr1hVMACleehdFg9QZlOZc06gfJok TKStxUI+j9NFEmJGoc1jK60MDqRnZ0WVt3YD2j1EmG0o6eYMWV9JTf8lTxvmN9avi5pZpz30 Jq7zr2yoo3cNySkcNwLdsXqCdYZtPPfoInp3HY2HdoHCMQt4VkwI5IZvAEyRAIpmkb2KY8dV VLz73shcdR3sE+RkmcrbOi886P5uZIeV8ihYEwzOpIMEiWeGVSOpKmREBiO71qEpwF791IUa ZZ/UelU2siPDB51IaskK8cWegyTPkQU8Jc4ovUBQd4jte4j5MUSGSGt9STcBSwEcu6ws8AWq sg9UjXd+hjeCsnEfzIYGKggRVaoovMCvpXeS8mfHUGRSw28aq1fEeNusxQDy2aenCTf11LWj pKYTlyoHXsByYoNISHnjqXgs8o1tckNHRtGJ0FwEJQjA3OlkS019jSSMXQ0AL+ZvVOt/Rhjh vtXDR3wjWfOGc6pCgBtHbd+ToYs8Y9sZOFngmLoboQjDME+fFZDGa7bbGew5l01P35VqOgWx CgzfK+SUob5Hs4Zlj7/AavOwJjglhJLJan0KSGPEl7fEA6QvLWsmHF+2TV531xm9A+MUv+ey mWSvz4ZrtRR/oD+F/U++7XociwzHRPSLpOBXZxwLbUunF2FXZuvPPMl9MUk0NC0S+MrLU7xK z4BCmatrCCyPHGx+F/P/17KJqa8vdEaQRhbxaoIG4d38X/ulWoHzCe0+4uIFIOMLjlLf5rUy tAqhHbgzb2dDlTB9tQBxm0AIva+ROThrH5bUvXr58CqFPGXvQpQDh9H/LwYDZpLYUmtV36E6 F1HKJd24AXSnXkOG8xzHBO8I31/zKk6+JvGIalSi+BIAi9fL63KqaqKl3ncsyX6dAd4YUK4W 0Knat3yOsMbMQdq13GrpPG6lGIwd0ktcfcksxYYtj46ffHPf4vlkrN0y0vy6qd0FFDUa2Sah cwVJgVJ09wGMgVbRBBR83EV1krVH4xK8ErCrDAWnz87EkfdJGXQuCfwtTC3PAyDlnOnQP+82 /hszNPhIVh2HL0iU3FLYnNxoHMpPxd5UwrP6KTGq/JHLcu+ffXtZecdI+kIqNrgbYgwuYSAa o3kSyqkiDTlkdExY/LQw4noDK/kBVvHYIxsoV0tzpVCW1hPiwXFRkX65CukxNqp0prMc+Zh0 6zjal3d9gLmvRIlhVPDgf2DGiL4jdxYZERZpXiDSCa1Ix3e7/cn4XKYePoDO6hIQMltYqYjw n3AJb1o8YkZlKhvSQ59yJK5P1mM+JgqMaDH4vN+lDEbfERse5yVPKlVjRSqcgIT//YwXiPyT xuaMAkVUjDTP112hbzz59czx9cmKY5ghHqHlUabBR93khfTKVW9fSTFICw8BTiYxhwaPZ3NH PbDdJsV9IsJFT3UgqqagvQfU2bbZ3hKDGyswk+X5IXoO9jN/PcxFFmYYfv5HYLgcRcJ4gcFa WnNkP164Qlc1ZzUKumcY2YNrxagMiQwuCMcpCdpvYk55yNZYyeCk1VEeqT+Mv9JlRkDtDrWL aTURqMIJYo+8OIqYqIlaZmAN/318aieNJ+0FEx1E1JW6H5XVDn47Bhr1eIIqd7HQCcadlGNI RWGc2U48K/0F8PYw2coKWzr2/HhzYy0//WmVOsvUTtlmPbrOz4uD2X/xeSfHzD9NzPScsz8v Z7zNFlMYBfxPQ7nGNMsfxSgdnJ8Bn3qk9l0B6HL6UuSNsUdz/Yc+vFD9O/hbycEnD/C32RXT DhlE+wQnUCvf7MI+qm4D0kutv+YfQTpAV+5llH7OieiGGlga4FYOBDPlA67hZspSQr3Aq7J2 iyE3mVuGIl5bMGZfVIE1FhjYnWry0SIhb6P9s5yhQjXJ6NS4YYn+hk8CeTSYM4k7JZRoCnZ+ jGMDmqWLW/7YyG+KjIjhc9UMnuJIRA9X8yNdAmKmYf3tDcrU0tXLtb1P0Gi2llXyUSfHhZHJ dELmWvDl9zgS6Ibcm2d/mLKaASoa8BxnfqUMugLcFbmszbU5YOthwSm9ei2TsHE3tCzyH2FA KIdHFnLEmDyhiPckmfHX85cHFi4fQGocDgtZGtItV7vknmVDcdZ75gB/y5Q9ZAXaNHfPPilz PuUrAtwIxv7GpcjrFGdS4FJWvSiqUgUtTb7R7o6unvX5zbEasx6pTigfeB5/2xF7swq874PX 5sm6v6jSliTNXNbcfuEDx5RYFHYVQ2vav1z9+w62IeT+wOclJAFeJcjsxoGMtE7kxw9/OLUO uxMogSh+/pbdinp6Ot5w8arz74ZjR1q7TPIvc502jR8KQrK0aQP6v3tPHlJT2KET5JxkrarM RcSAkhEMGndyZmClIpy7FPNVsbqx7JVMP34ILHFcXeAjKTw5uq9AWp86F7fvPFQjvfwEODTR dt3aN/uEfeLH6k5ZdBNYV3+zMyxKDjgHvCRsjEGLYAr+0KRhC0QssEtrtsmHHl9gN4mKShCM vQ/fXw+ccAPQNRMDFXuC35W8q5jqxaZkZ8yykJ/xMf6PGfG6I+omRxLlrpB7vNc3OMEU90JK /USqKQrnR03bN+uvA1JYFd6i8UHVJr2eCM64f+wmNFy63rtJ5abYuOMBiIA5rpU5go67AV71 O2z1zG67ruJ8XMdosdLoy5Zr1hKxUxsbKwYl37nITId40tw2l1zx1ypkt15lUz+GfIFmGMmM OukOzmXx0l2hlI8Cb5NY0zMo5f7f1s92eIc0lHu4evRASa9ZXhTxyCBHV1T4+w2VeBMl0ujT oxzjgBZqx5/etDnyXh7DNLPT0pAzaRtE26dzaGndtG/xrc5JrBim9HYvxAU/4jaJUsNY10yO U4c3imLDdGDJBGd7tjcW39l5txUGR19KPYT47qOQB3+q0+t4xkA0LynsMdqTrVtfgp0MSGdQ 7CkOJvXFp4Wa+WbiaeANOl8tEaZqNMSXIHP/Y+3Mp1DbpirZvG2SrLWS7SJu3/tDTztIEHuf vcMOB25ul94vVqFfr0cQrx1FT3CJOtu0xG9acL5LnWnWXbboZd//jf4MIzmOgW7Htx5/c0Rw zx6+U8EFB38jCd5xY+NdbvdY1A5ZBI4F9nkc1pKTCO2hKAy2D2qeSq4nfl7e1DhBg/Pt0pyr mMkKrDz9qOvIFc1pNcg6RRPcWvPxndKV3JOe29ZepCYEU87zMDf7hogOUeuHhuevwIF+Rl2Q JlZdSnw8U0ML7r5qr0QLU1CzroaRFSIueZW3XUef5Lfke/nmAjuFqmhnfedxN1uE8lCkzF6p 6zCBanaD9Z373cSBv2MQQx/BS+f7efPk04nqNcN/KJv2Sf0meg7dTzncxJ1dMKxsLC9NM5Df Bp28SBaphhmfuWjTTNgSEaLkWJd9T5PGlT6+zA8XQoTytlq0JIO6bb4klFnv6AgEBdrZVhB2 e4GUNo5k8Bl4g4frtq7zi1IH/LPnVwtawmtDLbhh0oTvh+ew3Vsq/m4nmZpR1czZU/K+AvKE KPOJoRZ4yQU+MnCh6w7EYgeYpnWOSGLWugEtKmdj+Hn2oF1sLh9GWx3td070vsVrqD4af2tj t5p7+naTdfZXY1o+wozxsTQXlMG1LwzVnLt4ib5qaUbIKXiRYEv4SjN74lYZ2yviXEbWcXrG Zj+QhfZsr4xjfEihNRe3EHQaogVfS2p+ip4EkG74xXZ2TGHfpJ20h5YsJJXWCxwyYBF9sYXq SZ7VLiWPJkp8m6TBN9hqAWoWbdybHjm5LB9IGs0N1baNVF5bCXNFQRnIN9vzGOnLP74cJM+v +3/0N1DgMfVx3ycmVlgX4oNQc3sbLdek5Tu+BvB5f5tKpK6PmEUbtrnti3eLKR4kyn5n8CWH NfVfNViBxRez/NUdnjh8JWRBsRRtKyAKQ67am+YQXjLhkVNf09zBwrZGvmcONxlj9DezW4r4 XuPgpmGGkmMJ+CRGPpFXlJeQwN2UUPEC61A6Huv3DuPfHE0WQP89eUmuLsi8xoP/CaDkuGtc XY0UD29fnhj/Ihjjx9w72zcUhW+5ipnSHArLZkU27xHhN5HsOQe+Bbd56KDOdRwNK/ROX4Ha 6C2rqHR+KZ16ZoMb7uUCWa2kYCy40gk8MiwFJPDWNx2lgb009WVptymf/3Y9nNLCmVWSSSg9 7dHP8XdiR7qeb6RFbNDpVuDm+B7KnsRoCbQn04FrxrgPKueewHf1nhnF1jF1Ybke3mYrR4iJ Lm9pH4ZCbmZIn82JCU0Qaxsqr+bleS3RwJAlPFns8u15WDbO8UYEcBy8gBS6tUUtBOSCbsIa TqfwO7EHJc5IOlJSfzS26dmZUQD53t0u04FshrLpsv/WX/C4hi5M9B5Ye6yN4bxahz8BzCUy 7zNG6nufsJ+408TLfhULvH+6gP+kOHQzIMpftQjjYR/ISk76IC+URi7bauRLzaxqfw46qs3B TQnnQ9xvNCKzZLcYchlWB41ETp1wgiE61BQ/JWSVJMYkdOU1bFep9SGIl4e8ycdctVcntjAY A+VrmKSNte9UlQtsz5IAkCcM03dxjNrm6m+RlaEKoR9Wv4UQ1h4IP2Y7GSfo/ahZDXyhBNZu uku6pT17D3gj6kMWF4WUHKWejjlxJ+YRNtMGyZlM7JwvJN9rdBtBiiv19OJukZszwc0hpwpJ oia0yuBx0nrxU7CwT3yf0ueBmqBVopnBu2aqsxvfyYaqUyL/jS5/E1mj4SVL1HubKr1Xg06A fwS4oe4zhhj7SQ/8/2npD/mep48/Y77BST2avvrveEeezd1otwstIRPLyAWVLyhtQGG8oA0y hPYDphmEEqTmXwS5k5c4yb+1sC2J7/UX4r8jytVCQuHagi/DGNJaymAyNpwi7mM6SECkm+mJ lgH1Jad9BT2j5mSIQHh4ov6tn5NsjBIK0njH6D1wLE875BM9Ad6QEN/m93bC1PDIeVTISXaC LgY2uGtKElrZfw5WJtB7RdpSNzhCECV+gPf5ss5WCjFaMnf6XaI6ox+R28hhWdw2yZxEnlr6 kFtzPKm9LJ8/QlDORwZ0ayyCmlizzBfWCT+fsGsU9lRBmGrWP11upKpHs4c/JQYG8BHD+ppx C1k9weUKZESSgWRZhbCHxMGBIsJZwhkNaZ8WJF8sPqABDwuyLB/bT0iAuclbdi4OrhAsrcUg cXBgPvFL2O5SR1lzTrkMQi/fJCt7X9LySml72nqB01xMiRvAsSD/YVISTV1sG5NH1X3oEZ4x nmyfLYDaafaz5dTok3S7Ofr/+HDoJSiOe8P/PimR7trO/G+9+ucUnWPtkaMWOSchnwT87Dos lshGTy5u0hcbY8OtAVMND6GXAHBODGmQiys5+NP4RS5u6QH0jNJNmbuYVYh9dyLwbSNd7Q3i Iq0IYyekISZpbLdUbjTWOdFVtjJqGamoEBUjXN+2NKDLz4JfrbxKAzm7lfGZAqDSVM9MlHFW CpNHabR2Ll78aeOJhDELPdyG63NGUxXBh5GNLbmZWGWOBMEuC6xQO0X5ysdEr7lHIrFv3J2E DOP29egZkLp6oMpiyp1A5EYFM3xCLrV7hw72BWaLy+T4oiFh4RmKWF51P0Vdof+zwQzMNVKf t9Wo3ZjjjMaHomisgfMcUYj5NdGMOWiMtLotdx/Dc0UW39O/HqpSFLR06zQJeHsyxZP6wthZ riKCFu/J/27qgiGKimlcLvGt8dNq1bXDbdgzNJ1Rjfk0Mx/IKJ6d/SXoSwmzuoW7hKmot1Xj nl9bxgeKEuc87m70PTQGPnkpi24B5+xsgsC4H+KpZZBTwDR0RgGmwhDAdJfnHcOxo/FqTz3i dgB7a4vWlmBv8YdnRhtbQpyXxPIy+tu3T7sqZNGAEmNGNSxifgpGy3GezvgB259eWcE6ERGA zRQ5NOIC+UcVZ3RGr+InV6JcmHI7cDNexT4CVTu/SJq+z6kgfULmFufydPtkT9s2EjYqPnpR V60/w+AGxFRy13pmQlZ2znSbTx1Ur4L7TdeW0tTTTB0Qt3OuSYquAcRtpf1gk3mhIs9uyJxd h3oMTJvCu84GoEBYAaS6cXWf7iT8TwM1I9FB6tx8JTJE3Lz4TCx6QlPewD4QYbzzAyGnLPfO 9goPkG8C/Z9NP6oITEF0DzkRhpKT1TsIv2KhIrfTazBJPKmAMf2p6hr89dV9kBqNsIii66sd S1547A6W+hOx7/irirqT86uUMAHsbuRQAzuTUhVuKKvQTkRnZ/aYNbj6H0spTQ8bih/K4ZLR lpOgbRiZ3iS8UrAHVmSOXpCcXMnFttfEFRAOI4Jrt7adpQgW5rU5ycjeDiWFnB2dUQLk06GX KXWGQrsEWQzpjBO8zce9jZF6XEm9U/X0t4gCKpLNJfweCqyha/5R9HCuHkuUnS8j0Qicv1Ya 5F60mutFB+FQoOK3SUYQ2S2ijDAASYgnpisx33B7Q1QNenDZbcMjWitS1DWlRqdsiJ9g13Xl meyP9ko6tkH1N1ohl/O+tiAb79g339ydpaRaZHe65vUJNOgRcS/+dRoopQ9WkHuioEQIs4U1 lVG96t/ikOmeO5YiMtANibVd0+ZryfAhKYqF5EFyLASEGXe1TwtQW19Hto4S+MK4vXgL0It1 FYIN4S8weFB8hImDgBXzzRc+KuZv5HTcVCps75HoZ6Xm2sSMY037rB7NaTnp1JC/C7I/pxVD HtqERZopyJD+ZJ2jIDNR8jxBMIdHxEauBGMfpCT1eK/lw4emPDBxumaaj/WEMy92Yg+CJXlz XLD4bqM4y5dB4YQhh84eyjp3Pye3X2L6zIZeEVa7skw9kHDM/nEqutXukHqQAs0I1hh1okfe 7XioCuTKh2b7jdQeLIWnVpQeExzkCt8+taVkYsQnEUWwfCaBoB1LUY6D+V1e7t3m/0CXaogz 4Yp5QY4hQg8lP9rtFy34o3aQFuaR+DSlmaB9Y/y+nsdDdXKq7/bMNJRAx9xO+4smdDHtGd5r Ul877q9zV4fipoUx9sGgSv4GEaDofYvlsf9PIxxkHaGbHgBbnO/YznVtx2NKdCODY2pUisfE enTXNW5RInCp7G/Et/+m0u8mcKI63RI7QcD15+mSmLZGxQVFWuEc06P7qYEpBNUTkmpSpQau xLihkFUZNsFj/ekVX5VgUdkTEbsYf+C/R5YfLhwo1UhuZfV49OQgbhFSNRYVHsa0IXygRgRY ZyYEdn5NkZOfO8I04RXWXwHA7iH5I/wn8C+ifXgNLALpPYLTm0Eqvy3TeSL+37br3JsWVkRz IaXGCDipGUFCkSy8TBd2cxvNAds7LBnTps3yZJLLr77yIztlgfIhWNO3LJkSeF837SylQLK9 W/O089HKErk4RVuxWKTolQ/D9omTm1nUKVu1rydkwjnp2RneHvHpsKcYiy29yr6JubHGlCjp kC4gUkeZ6ywrTECQPsQw45ZA+0UHPT+35NC5wMdyAAuj56AlabCnitTvPnWAAcZYxMrMWIIf 9yxejw7jtYwVVwRyp5Lh1UcLnSGRxhCOLS/h4uEcdeo3Qe4zjUmXlwbX6ZsS0o/OmulSZfxg usk4DFixU4ASUnGTAHlO4Bm6x6h52jiexfImmltWh8WdDadGmAPZ0yha39VpNCgufS36vHfj e7cNiXRMLXdpKwBCvP9wGDovxGuez/0m5lKamFS3AEkY+fb1AAjnnWU/cFzRUbomg2dNtyR9 Flc1hVLssCZo0GphYEI4/ywNUmLDaUhdXzd55Bq6WMeEERI2Cou9kHTctIvP/ITxffW4e9BY kvXgoFhFeIMs7gpg0x3eXK5Y5kcToNzS8SS2LN0TzNRhGG6+x/AP9Y1S9QlTJIZWqUBRRYq0 sxcgTTwDPfRr8KMIqhn3frCiL5UzednhzWFAgezZ9eFKJeXax1+iwhS6qDj2TBknogr0ZYGK bP5xV+akJEtfVkB1Iu5BFXHTQczgtIusCNMUG8JicPpzXSG6fA8Lr5tqsM8u7yKSQ1M3I23k E7X8xa+1zXH6OJ4UhWrkqSPASA2Z8a0Wcpx5qECww34sWrgJ11GArCNMqglyROjH6T8xDsD/ 5zwsvtpFI47VXBf1a7/a5NuQSoXIvP0d1h3vsZfrfCBW1zrs+LptzwHXNnDInJ/SxEcATI+C i0Vw5C+zVFc2ISUF0rd7C0ell+LXvRS2On/oW5SRHuOuo8RP23DFBsdF2+tgZsjL1qIhKe8m OeRBLOGpEAmig5i1087fDpZXuSqwEh9uMreRYU79/ThJE1u0ujxT2HnZFB1g6otlfATBdTbP QYKS9bNdg5+1v3gEw3oAhgN1h1fCV/LaQ7Bu/ktsLIezfaJZdDYwv1urFwvU4g/NwalKmNVk +8kt3Qp62aUW2c48m1IqIIkw6T0gYpFjjJ1IS9OPd7NPXX5XCcvM3RxrCgOj1PbMvmWReccv +aUjX5hfh/BL8vy2isuTKP+hOqYGeE9au6QLZLDgMm3tZNjXVgVGuCYM50QjJZ1DvnDEUGb5 V6nZR73sCulvrA+6qwKrANvEjx60K3+gBdF+c14fJW09TUC2RMF5f3HHJXSlHPnN14+onswP ewLDQB6x6A86EpMAW2uHmcELNWoFCQ8vuK86zpJX6vgK9EVgshtma0OgfVtXrzT5VdvK5f5t 6kW61spmLe/7gy3bPVRx/PE8jw4wZlew8vHA2JKpxu6Wf3ef+kOv/dRbbErPUGMwHUZN/+zD lyF0+JBFe+3wqcq03hkV/vSn1Lq35BDatyjkC4SAB3M7uaa1gioy031hU8Fj93+OCDPHDsjs 6OASBIQ3kp2B9V9r5V450ugBuxPoVZip3JeOU5xHZtt91I7XjIQz47bbmMmeXAfnP+vw56zH ocXIDOlK0ENVc7VeNd88AloquasEkNpuilQs03DGi6tFfjr8nEy7pqKoXnuurTJbAzgtlZWc uloVNFOpJz2ZjO00+aluw/UFiK4PB+s+LO9WKBNV7dzMemhQwYoGF0tzY+v+wJ4TRvymOlIB Qkcs268O2zKf9crvCIsdcYT5/kJvFA3KwHzPgqKC06ozDB7Uvvp5/T3PioWYaarQ+Gi35+2x uQJXTeKL26YpdNbOYNgRahTmsMawuflDUE60TFXs7pyariLZ23lz2FQaqV0Y1Z+MshulG/mn 1G/bsqg3mdKULWMDRZLsWWkX5b5DUxOkOhjt1Xq4EVMy97BfG1VLS02MkxawegASAEo/ZmNE XYWgkSD3q7ffQUV3Z6qdVADhi/+6NGDZLlYurE/yAYsCuNnUXxQ5xdWkFeUggvFs8ZdaIfRS 7a/rp0MrGG2DxuesIdrSDNxQYZw6ZjYYwlk0lPsf2qXdchs/ODK/FSxNfrIbpv8FqztRSF/p tG+N3cAoNLHzAg4ZF4tp0cgxagH3wpnoSOOrBdneornhSn8pacQfjP4FKcx5t8NWdCp01lWp zIVFGJV9gcazmesblKw6gAiqO9LgPwTsS9kdV1l9hmcwzkJoAUPr1/9qdZ14wQgVu0DnD265 2pD0z8eY4MS8986t6P9st309guP7tEWdhdjWEpSFfZPfwkpXdeD45QzYszqbiS2axSeL8zF9 ts5BtXhNX9xZDeFIKJBTv9akRriThM3SyfhYZ/EnSYrxpAZ0fYJndYp67f7T7ORgSyMnid1v 5bHuWvaJMPWJSYV09TI3jOs84f6u6C7teUKx4iF4oWrCJexu1LsqnRDzhxoq+njcWrzyf2BL YUzldxolpQtfhUW2O+TLkKs1PB3WWP9GNXGx71GLNfypdWc/YOZyRuwmDMU6OGIjKy5dMSGl lU/vxTZfmlAG95p+sDjd0eXgZUOs2y1NYAQxNZSbEBqok5qU6qsgAO7JBhfGghh27eiExN7t yvsf+qD0at8tUx+Y7fXrJHNXeXSLeY++4fM+dvlk79IHcT3gXWva4OHAB4wFku4zu7H4pR+R gxzZELhHpSPV7xTdj+VMmEiH3uRWm7XeDXavJZK5sZV1K+ivPsqsPlMAAAwbR1sclWwmDYjz to922ScAKfN+lZWeY2ARDuOle2xLn4qotQnFN3DwA03p973g63+p8O12UFiAmxCnCPC5xkbE EEGFl9VN6B+TYANuDOUsCz83zejUWwQ/tw1XhbVd9MBZu7dSDyFntZUJY9X8+jvaYm79GB8h FoLRwsz9J1gn6E7TBcGMeICMCRhXT5T2draHyB16cgxtWeSB1kRdB7qevv9CssnuZDjwlUKB VNOfc+PR4Igvu+SzLTOIIHTG9mHDWC+yZWzSbjLBdhQkAdICQqjt4BqSC58QOYAjVzzVRUFc aNmBRCdz9z7P0CJ67Kz1jMZtOI2VA7BYoR6pswn7/Dzf7Bt1CF7gXKv/XG8lx67YjSTvCvQE x8FmN5fOWBkGHJagYdTMrZEwoNgzAZccRwTiJK6tDlQ+W2P3n0X0GXL1nkQ+fQ3WJgczwpR0 yqmw29xd/H65jNfJRc8luJ3/Oho4nXH+Yg3y51c0K82ZjqWkU6QPMRo5kJMYf+vqJjImPNx+ 7iqXHZq1TD0Qeyba4kiOSc5Vuj4uhNxeu3qUHRMAulKGhs+uboiuZ/k4an8kysFfzbbPLtvu qsc+OViywXx8qW7c2cvTv+bhgTpnwCrLu8Q4YWgzlOGF5HZzX/UE69jcvAVy3mTASZuqlDEa mjIANzftVbQHsNR23xgyCl9EjpUCfNMCRLmgd8WenbUfVbj41MXnA3aL5okTASkMDLniFTEI M/NNSFxLDbRm8+nSxerbNi5+ky73tZP9YbvmwPKoF3SlBvO/NYFGQXltWg9S039LKqRygMny aCPEKCuAWY9XuUQWK7DxxM2pfPNL1P0qGlfR9p518p+3z1WBfs7UT21FNqgmX+wJBq1HRF+Y fffgG7n9NH1Qs6058EHI/ZzVT4Q5xEuzIB0Ivif6xn4yEdhUTH7zPY1QVUJeTyg5M/XZ+B0V W1PCGIm4Y8I0SQrGnFqxBuZmBnpdlleOLhRKFP+dgVIsE/4w3u6pHhaIEAZNDkZCm5CH4cEJ xtpYRw7N/7EF35W3xi5pGJe26bSRN8ew0lVvw/kn1S9wGkfzo4+8Cib78UcnQQc6JwmvNytY 81CLCEN8EWg4bJucDFuCfFsJ4Q1F9SdOocrHahU/3idfkIQVLnUyRYSBiwTJxo7sD2L33iGk Qck2VY770+yXmMYdGIWFvDr54mKCFmftYk+CmIizLPYGsTHHOsu/D1JSR/V4w1lbr8o7pPfo J6RFf1wjkvA8/MSu0W83Vns79w+y17vBqjgvTJuH9Ag7KTjsVIv7eVs++OgCbFFsGgFsRA3f nbLyl7aq+h74qbo00XxWIqzKLGvRUaUai/g1jHpDeQEbW0e7iAJ5kmBke+Ah5LtGYOt3soa1 gTvlls55zce/bR37mSnqFRT1CQmOEiFoMdh8CKlaMdeuGMn81l1NWTFCll3C+pFkFviXEBrT 6eVWWRA09rPRtTb0qIKUh63qM0fXGpo8CYUzWQSDD2DchDL8Wtz1bAopXSR8AzEk95FYDIOi v5Sgw+hA87JPB0bOXUfczXp8i1LNVvJRi1/gCXDerOBL038EYl5ZCMZWUVqdb8PJr0mVdKPv e6NowX0WcdIBur56XGi7lMIQ7i2pgijgCPSdDL97ejbugDz/xz/c7uiBUAsp7HB24NtDOtwG HJ3blkFhfB4VtTMRB4cqOQLDllhEJQnwH2Wp8RCVzRjYUso0yyhx3tLKTzebFQlkjriaTlns pwyk10iuMbhf/SoceZf9w5IJ+Bk9UjM9QYE3UnIBZHENLwlQdM1MBsbrI3NHMWnzas0Y0zmE l3vOgRc25bQqcAyOVDd9P7L57Vmrg+ApWOdabE4xW1A4KMZj9dRjBMKG8pb+fcQrTQsEaYip gsXT83YIrkROEgsndXYaP4ElNwJKdcSd8Z2QPyYZHkaIPZn9Uu1ABAWoVNE2rbtz8YgoCqnZ riQsfikqbOigBFD5DpS+oJayfqGFrUabXQtoNXxobnR+0417aTTbkjncVo4bjTd355Uf2jUC G4OzNNM0TZSfgr1A1HKeXfhcoYuzUpq0emuf/YnvpCQDfiLehnBExGeDIO7s/gYX8v4I9hP2 SeqOiScBqifYn6KKmKnyiVjunbYZy5Un6Mxck23GRuz0lHn6eXNofOfBUaRccMRk4Y3qHfvj ZW8sA0LXIoWtRLuaF+mg4qEFfz9aPisZpO/IUInQyKu8kG2Z3DRDC2La7siz7qD1Kq5hB3at M2+2YrrZbVRttZKVYZjfXO0kgXfQ3PYWk4J4f81AmUOpobyrqxXsO1kmvjRpj4/bo1XMfm2r uY2hRDeiQKQmEIk3pp0xh/HJz0YNKsyrzHRg3h7jmvRhEdYF6KsQ7OpR3gv37/lm+FnVNwNB RJy28deK7BoxTdUC+i/8qy5Cen4dFBLo6YGpj74a0DLr8sW/CWT9rXOz2x1n9dxJMDwGj9JV yXx9ncMdV+RAoNT5mz+BsB/YEfsJQT9hw76XS+qbpdRlOtCM/AhpM7YFs0oVfzPQwLMlGDK/ BCO01y/f8g6uszMIlsWH3w4dcT4QGqqcS4dSdxihxqMwXuwhMVZG4NGV4SXmW/c4jSJP7TSJ HbWBxiw3pyPZxyaQyzW7P9BdOKgV15S6dzCbOgNzBRlEg6jCmpk/tb6g1w9vmQL+ImrbWGd5 SxK0clKHkx6yCvUS9mj5gApEkTlDmpYygGLqJVtsE067p1nAdjqzJ/1HPtVMxpF2NfTNF2Sv 9cvLBoEQJgcguS8mKl4fmgJIzWPkchRohTDfoyst94UMSBRWOZvI7Ym/vlUybPx+qlWCzsRr aihLfq4CbqI2O/BYYMqdx5rs+mZtdHZSjB3tSHK0Utxoax7ofsDnT5Wd8GCXuMpHooT/x3Tn 8zERpkTQcIb6935Fkghef4zrm59cUsVC01idB6Hg6A5FixPXFTPOEvE+MR3ZckgMHhcM+b5z suJ/4I+25RC7LaxhTgrTHR+LC4Sv31pmM8YuI32K3U2knzRXL3EVXBDh2yiTaSy5tw1RV89z T8OodRGLZ2Npj2uwBv6ZM+A8bM4OlOZ3zOGFxxipokUQY1uFDppB/NZUeSLwsETy0CGUyJX8 UH8ujJWpan/I8bN5gW1eJIAnraK1SUTR/WLMFgbg3RRNxFngeBGRrOSnncQAfXKXaB4moKu0 PXc0gle8sb09onR2e7WBtqzNoirtANs/LSdVxe8zKmDZ/L8dPAUUGIufYlTHEXip83ejnn1w 0vsvmx4AOXIRDb+aXNWvrtOnEFU445kKaBBkbkOJLSaQXaKHntURvqdgfMtPZZDGlMdTUFME gdLfVdNVxNp87Aus0d1K4hAn3VklfbrA2NIFLVdpuPbbH/BnU/CBOxlBCv8QAm653YNL+7sz 5J4zX2JlASkKDKz9sCySh2PAH3t1INLAseyBjU/FikRxl+AmEv0oFeKWz9H14jRHYDvV0RC9 q0ejRcD0jMartL8n9UUBYrIFQIM3rt/tPWfLfEich3UNzAUMZuNxrUQjQMdz5G6knzg/Trav YoW5aPOLyIR5Xdk1w6PrGcg2H4+lDdyzrKU8gz2jFz07idmg6jOH6C8YsyzH2AFVckh5hwuf kSopGpQmnzkrB5bFZJznuLQNLtlyICsR5kJaG6dYHIEFuhokplv+c4HA2R0EhbU9aeamBKh3 M44QZqz5eMDB6lnLUJa7vpEjo+tghoyaz85z4K2v+74q0Mm6hs7eiDlXjmviKfbmXvZLZWi2 3LVF1qHnpu9jUkEM60AqU1jOcYRE4OGWkPh3ZipBAANoze6wB7jbDJpoXPhtWF3MB4i8LOkE XgRTNuCe7cYURp0RrqcZuGbvZvoBLPX1Ui0bkilZCJiChjafW3WDQcpkRHJqWP6AWDl7mYMz TOgVP0TFYAkPMsMV/G3mreqgsb39VTicBym5v5i/K2LuWkLd9TcxBxifDjWwHa/eZiswAmop A0daQmVEZkgEN5UybUAwV3bvHSPpHaWTfKDoChSEAHu8ok8s/ejY+ji6GRqAn8Z+LKiZwEAM kvku/I+GaO194MMiA0uTGly/YoisF7o7U62gvjaPgbI68C2118g2P8xdl3lAp9lV4zK5zkiJ Nerhy+w/5oZSdNcSYbHK6KZsbN2jsi40s0fwYmYB9iBHJ81FErwD3a2k6o0jyD6x/pgCgJM5 ioDiLGib94Sv/zVETvdvikAvKecXPmfBttHcgCE9HO6gLFYQub8j5qWq6QmnkrpGf9elKZ7P S2qYcldQ0Q6psOoU5mqBTweuoIas4qoDBo7cXl4IKK80c2TH9nk7yPiR2zgoUTTYuCxnvWYq N6XIs+SxUhRihc+/JSo0uKN0SWi22aHA8rIP+lEYCBvvXjgqydeqHOD4Vx+9C4oYt7geJvrq lzZtgggRUTZlfS58Ufpe/9iJqo5HsKCPkES7SVOdV7cBkxk+YTBDZkoEYQxU0tOSe21bgcND eP7XW+MomJ/E67H3oxJti2TAepxl4UE7nHU9H7UTmwe/13OMCb7AdbhLAJaFGyqC/a6dkJ4p lRiMi0iPGY6bY3twer05hyBgPHtjdM210W+W5DnPwhfTUCz0D9Pw9XwledsqODSzul5Czh0A rWXFDoKnucNjrAONgQmEsX/W839C6vSao2XwvE9xGQdtUNYr136Mb0XgH2tUhrn+HRkjJw8I yrf1NKkriERpi8oM6JzUbX2++dp8dBS2MLffb23rWAnLjWCjaAINN6jvKxwritehWaDUjLbP ooW6J/w8k6wdAwBdxLebQQJVf3kPs6A5wji3ASg/uKz3Rr7WGfRtsW1P1DMdiHH981IuoPd/ RTX98vYAQmTvbW+d+opXolLMoMLx4AeycrkRJaxXviEVvG7wBtYbxZ6OHM63jB+0+t732pKB TbQr7wilmuzhSxUYs0l6TBtq9YjmdVYMfupuK4Y4idIiuWrbGle5w9KHXQw0V0ITs+mOpUcK GZ5jHJ10T4ljcl1FYI/vU/P+DE7WcWxRgqrpOz6lwO4BeMiLxr2qluNtkg3jFea10lZygYwN G7HwdnTP5w3a2v+QllDuXW573taRAk1h9LvzAUUhGxvn5XrSu39wAHLjlQU5jULzJ9kcF/CR L3q31gqXQUG/BBfBIQ9E7H8SWvtGzOom7Xn0oF15Arxaerll0iiU8qDoE8/oT6SQFnTnbUtO SqrSF6wWCmACq9okY5vdLL9/KcbZlyHuQakMtWdoZ9WIO/H4M2Mv8+VDHv0XTR/D8iwOWE5c RqgAbDjoW+tojkewLIhRTX4QCAffvnYPS4CBTLm16VCxob3CUuRlbJtUZNe8IeFArzkrJ3Rn V5TICujMF5AjfYoCLE09FzFMPmksl/1ARc51jW5fqO4v8ckkzFbJuNUsC73a9HiMvuSXqfEC yw6fTonEIF21D8pxC7sgmM8/ZLsmBEeVqNxwGU9wCwcWdykETqy8sxeiwwAudhg04Iriq4+i rUwekRo2IrsZU4yfkjFZcV+h1/KJqNFCd5p5WmBfQVXZ2XgLt1NpRrcRVt/EsL7e8doVwoS8 XLV3Li0pXFryMP2FpDQi7X9OMP9CxwAvAXZtqpiNRtfTZJ7T//+ElcOw2zKLqWF0hX56rRgb gcczD3ikPPGN9hoWx09aLhxHENzBZBczUw0muRIZUZl5RTYedgmH0BdhA1oN+kIg6gw0DRKT UsfLxOn63TsN85CixDAk8z5dbgctch8KDkrdw35/fqcnX5OIn5INu5ZXg/7hlVJ0le22rmgo 9mxJczkNSOthKCs3yOx3MQ5YV2zmbP1VqZS2YIpuDZyFoE2sYMPgOLHPy7G1PsfnJzTi/IQY c/KEXmeVb4I1VuLiqXA7TutL5pVWGw06ZrwrV12I2giboOW0JtPM8/b1dkC8p9FjbNCEc8o7 rtIYgniMJ1GZoTO09p87viObg/Jq7XQ833yNnYJpM4ax0/b5F0fScL6+mB6HlH5wkVjjRCex YWL4+tDJRMXMjKoCGeeitL9ycK76j/l4p9GNrGmEs/I1Lji5xfsQpBcWGs1HdVF5r8JfmH5W 9Cp0YuD8eARNJ1ESulRy2nfKTHASbRZKK/v9iV1b/MxqhaOnQrtRDqRKojmBDL101i5levnx RHwh1AqhMmaVcoAsdVBLbcAZ7MP5wzfzkR6DFJ1dFOobFY2okTbb9d1iTg2ZviDG4PUcuowp zEAl8AugKYEV92dyfSrvmjnWMoOV52R11uUIR4pEV9dhs760gu5/XuxI1qfARdFQ2T0dESew leSMfW91/QlKuwK7qHZdXeuq3m8x4OevVRCcIvXhpYIDW1yicEG3Y/SGOmONKI608NCvLg8d vRWB1wJHuqLph5aIdSNjQDh129RRsZfk1wbN1/AhRvRNX131oGLPSQRYtNUslxbthpvW3EDz 5aXzM7Fh4Xb5vLrzIx+NmPIEiqjdY3dTFV+azJ2dzAA8YD0LDiz7fchPrde9GahhsBddo8Mz 0GwSkAHlrLHCC0baFIi3n2eKLG58HjlCayoVoNoHwwl069MTGO6alYOEI1rHoLQ/jf852kVd 3ZHPHm/JDeaMt/SzyKXI8X2SnJB7lz+eX3T2MePq0/itPitNKKgDAPdgymlComkhd9WtX/cU v0idkxyOMIlpfcz0nds4wzoHbCvwxN4yoFcupo3IPGXLhS5J2skRIZMQTxWNkMaVQcox4Wx+ uGxvGZgWmFXu9sP5a72ALmgr3AEBjc/gDhPgVKqH+tv0GOSxmkkXNJTrjYzJSs4tKELX9TAd jwuBOmYDFLqGNRP746jDfgGGqafjRP9LE7x4jXXTUco5WtQ9sJhDj/sOD/IeVUqgwlTN2iKN Rx2vhTSuVlDOCMaIs/ZUUAAL2ssMyEYCvY0Io3+O2qXHb5UIyT2Y4GutvHxAHlrZWGbAs0do DDtvsyHv3iAhP9KbwKJu7gr5ebYHD1BHhxYZQi+pNgGOfie4YMrTETPjpBrsV8OxwPtggQip /YGwAA2cBwJe00FrOP5c2tsG6rCQzkhj5gMyZbTgUg3ZJipcQ2yGtE8ND37SIBjGzBRzlO69 xTbySxeUDEzu3h9MhAlu7Gnf8/jwz3TeuvEpPsLebdNEXMPdGmdmAkwu34IA+/37uQPNFsaR tQBOoUqGKRhahnbEb/M4XhiMoPF1c9cOgs477wHGTn2D4+ejl4AUplPNWO3IAFuOV4+51ZtK oVIuxMl8LxzNTfgIwFEDMcIlSTr6uQVH0E5yWnTV78cyIvONxryzTmpfTM549lL8TJgempFV 0bBkBtMUROFL2XqyVAfzvxsplETRL4sDx/K45sUu2jMsdqiNZYKD2+ppS6tYTcsfF1wloP5p KHkKa48TJVUVdJWe++PggWo55WMUr5M8zNORhXocVAJhbhs6GcL59bg7QfLgLM0J7k2Bv6zw 78EwtsocO4sZ0foXAF83b2Pbfb0exnqNaYJMu9f/QervILtJT+HJEqgWr/w+Z2RInG8LAIz1 cV+UuygbBqe+63jjuAqcAALfki3/oA/EJ8ybIK45vnT7bAahBIXGXCclZnLjKUnIrl/DR5bN zqkKjeD+e6gZAIGpzp/MRVuD4rnF6+L5EXYNPgErMZzH4xeBfC/De0ZWVgcZhbiA+pNNvCMY 0yhrbLFLkXEr1MHiWKwXWF9tKYMstrWV2y3SPSQXoRAzAxLxKJve5Cpq1ghqsObVk7GvagAS CS4e1C9OVsWggGbWNsswhSYIlF1/x/IGln4oqtFKRWDsjjLmWtEwotvoRetPYhmOTDdvilJ+ kvnslwiLu/GoL+zvwl+9iN3fEooTLWWf6nbe8g/vkIRGX3ovpL6rO8gp1nEOl91Es8rV1HIf FZIxd0i20eMl7b0oe+zNAVS8SYRSFGkldIhmw9EQNy2bNmjpzzJ50gei/ybbJeNE6gDeOvLN kYw5BQmUN8H39wE7mQY+sg4IisRkaNKbBQn/vPUrNL1q+XPLt2XgP5F5xTFb9mlcJ+RqVIoa aSo/F4dqtPs2xQVuehzr8V3PHwD9Cp+VqONZ5Oq5NqUxs1BGRSiisg4vhOiNCE6hb/LgAZUU BoUPiPmS4kJOtQ++SfTJOiQe5S7BBXYhR8xMFNLsHfv4cWXO5kdXAFmdHc9x71Mo/YHoo5G6 pt1q7q3GG8Sqy97vNMJoagjxDliCwhhDwQ/6K8I3ADwJhfzseARHxKjz+tioeF00exi0oxWU pvKoXseKINqX4bGPEYytgD1iTmlmIZPDzZWPvzZT5AdJ8m4DuQV+4MX5ggNYnuLg/spFNppE B0Vql4GiCMGmMb0j620POij6vLTOfRUmlqbpzAjmEoJzNGPDpZv3AWIG0K/2YUnGBwvdYTpR YPx1ljaY1K791cXnXLxQPM3Njpz5m4IsIj3JqJoUIMZCxrk/6RYYJ9PKgihKXIleSPNeNvDB /saBf0HI60/oJVMLlbw0H2lppO+PiCoejkXkWjj/ZvgCP2j9ejwe3epYn3qMNRTtdwf17R93 oTuc0ZC2nyuq/eh9kqflv9nC7CPsU68kuQO1HnMrAIxDcxOZPllba7dyWCFST2st8Zv5ov3f P9qipj+e9aVeW/1YEXgvPDGqTDKyQfw/0TWQT/7ob5FI8P99OISKfmAAu7f3HddxlD2Xcc5a DcsBuwsynoqb4IXtg0nrGykvblZWAl00AvmTqwYkI1U0ISzbe8cMboGWLoQJ0yW9baMDD1bG rqNLunxRpRt2RuS3140J6vR04b6EKJ+bBPw6esPTDLuWqFlFWmZzU/zG1JMMDNWQ0TzIUzxu 4wlD5iDm2hRcDjTjEogmAPk1BLEY++m6b8GcvzNu0qLah8WgKsT21kGuQMG6TV4i2JhP+1VN ZUnS1/vHCy74JkU0rJ9CKfsn+oP/fjW957HgDkdutcbWfQNA0cyLkUKRvxLKwr2bRHsnkREz RreP5qDhMKJwuMaALVo20AJ0gpvSY5sm8OOkTK+GUj+7V0tMJgH4g3chSKAHfDupjbwTlsXt 5UMwzVXKG4dd5ZHLR0j2FSw3G6wJv7KiwUZRVcEoUEQNjatAi9N0rRJnBGvlK6kALioeJEGS 3YwaYCiXT6epRmX4smlyi186UjRpn77Vqqpina4cCIIVjXuXXPcrWmBa9UX8XQDRu9eV4+iA 2sg4jUzZ1wpIWaTAD7oPdz8n7UX1O3uEJnxBCGKmCmDNgsT6ZKDOhJ1SRCQwrdAu247sdJEI Km8nTpxncklAwWkzma+4+dcQ55ArhNohGaXEuzFiBtZY5s6Ee2K0AkmEeTxtt5gVvJT3mD6t g63C5Bxei7xaEeGF+Xpb1cc5WSGJKXyXLHxT97x+FCnp8hENuM5mTYGplifycDQRFd2dIx3I WlM1hOGzdcnjA+LU3dsKjjaBDaubhBTdWGkq6bB77UunHClfab/+fom7ClW2QD9Ip2Uk1RpA EKeT+cspofOoXeZ9xssoYu84LguS4a6n7vp1TmfKnEa0SBS76RFg4uJck40nnHbo+YSTb7+2 hmHuN3fiF6Qfs++QsjGs7ZFme9zx0PAYXKqyvTPnw6sxHXPNtdx0/OSgFlpnGtLOKBsGEpso Sgt0KwfVlZWywV4sVKz1bWw51k9wvn53aD0PA9fgF04NZW5kc3RyZWFtDWVuZG9iag0yMzcg MCBvYmoNPDwgDS9UeXBlIC9Gb250RGVzY3JpcHRvciANL0FzY2VudCA3NTIgDS9DYXBIZWln aHQgNzM3IA0vRGVzY2VudCAtMjcxIA0vRmxhZ3MgNiANL0ZvbnRCQm94IFsgMCAtMjIwIDEx MTMgMTAwNSBdIA0vRm9udE5hbWUgL1N5bWJvbCANL0l0YWxpY0FuZ2xlIDAgDS9TdGVtViA1 OCANL1hIZWlnaHQgNTUzIA0+PiANZW5kb2JqDTIzOCAwIG9iag08PCAvTGVuZ3RoIDEwID4+ IA1zdHJlYW0NCt9XTFi3G7SpHVQNZW5kc3RyZWFtDWVuZG9iag0yMzkgMCBvYmoNPDwgDS9U eXBlIC9FeHRHU3RhdGUgDS9TQSB0cnVlIA0vU00gMC4wMiANL0hUIC9EZWZhdWx0IA0vVFIy IC9EZWZhdWx0IA0+PiANZW5kb2JqDTI0MCAwIG9iag08PCAvTiAzIC9BbHRlcm5hdGUgL0Rl dmljZVJHQiAvTGVuZ3RoIDgyMyAvRmlsdGVyIC9GbGF0ZURlY29kZSA+PiANc3RyZWFtDQol 9AmMk/Xntn1+JRoWuqw0JXLc+DWjBqyy1tgvTJE89OM66xBxnS8ZwRdzuTRfGmiEO83DTndw WnqujFX3ZZBNysLv1v9O3rozJfKXeJVaqlZaFnB0TsVPqHE6sXwC3unA5UUZuq0N7lNjqzVq rYSErX+GikjkQ+PZcQTdlO0anHY6lP2w2icwA5s7EFs7OjzD47HR9v4B1xGhxdQuIim434iS w+408jJNq6HGh5W7u8VLFINW4L4Krc9tfTgj6WJDNmIoFGZOfxsOzhemzJtC5wdRxWue3aVM TSxcS7wRHyFwI+wHGzMH2Bm1VrzRafks2XG7UgAdtbPb1ZDX7gwW7RF6nT9HuFqSmf1lTPDD NBh6uIvKhcfaWs3sOeNF/99OFXpxeDhJL65hLr4jTPgH1DSq7mMqw/CTgV3dCdp7bMJBg8iy BHpUf7owh2t4571PYVbl8Gyfc46h3PBZwtmYV8hbsTobctYsrb0VWsiO29xlYOMpk8i7xrZT mdKkyGSlY8PhOm//xH12sHKdbiqe+wNZuPwemj9m7Y24MN57UdGR9q9lbjgOGTAeiQBc1AFA FYFUbVpJw0Q2Ln94KtemyPAIdR2g1ylU4oB3Qnd89woyrr6iazynbxVNYgrm78f4kyWfALom mSohEP3EIbtqZzXdv0rOiA5pvLiPpjmiseNQvyiVUQIdBuIvgr8F2oAceGkRlrSNf+MUlgJL QqcLg+sx7wZGsjaQbFrvgdz5j4tDd8NgGQ/ykfYAkNYLAQpysg4oWjRfFYhbEm76zP8646F8 /5ucxcjZPoGI7F5mopZo8vaATjMCZvvEyVKXGqH0WsDQkxeIWmNGvkZl+cfkWMoZysFlw4Kn Ppk0TNURsXEG1/FcuNVm4yri/wE7y4kGooEVhoQcR2Y9igKE9k2Y39zhTFQqkj2YBHynMTid BGZudzZDrv4pTEz8XErDuMdectyCq2fRKrgwMt4zNI9cZtCGkbNait9fUZzWVPlzorFjsV/i YTQM1dw5wTiai7qLrqrv3LOW1yScUQ/mUMFuM9HtcD4Ne4lqLli8T3uMtdZiVZKtyPUffnuW Ue8Vg7QUAxMs2chnDWVuZHN0cmVhbQ1lbmRvYmoNMjQxIDAgb2JqDTw8IA0vVHlwZSAvRm9u dCANL1N1YnR5cGUgL0NJREZvbnRUeXBlMiANL0Jhc2VGb250IC9TeW1ib2wgDS9Gb250RGVz Y3JpcHRvciAyMzcgMCBSIA0vQ0lEU3lzdGVtSW5mbyA8PCAvUmVnaXN0cnkgKCeRa7AxKS9P cmRlcmluZyAoL5FhvCDVHR0pL1N1cHBsZW1lbnQgMCA+PiANL0RXIDEwMDAgDS9XIFsgMTYz IFsgNzkwIF0gXSANPj4gDWVuZG9iag0yNDIgMCBvYmoNPDwgL04gMyAvQWx0ZXJuYXRlIC9E ZXZpY2VSR0IgL0xlbmd0aCA4MjMgL0ZpbHRlciAvRmxhdGVEZWNvZGUgPj4gDXN0cmVhbQ0K kf7mYxKEZdgpbhwKw1bIfE5LAYVUN4Zzhgy8ApqpRmuBRfdSFq1iXw+dxeYbxSWMihPcPp7u 1xbnfK1llqmYQ15uWZlKJQpcHnUt/lttTyLD/aqbKOokh7METRhCCExmkHarKz7e4Mpes5NH bWSbKr7usqC/woztlGVTIQsSjq+lZ5+JQbBJCFX//Q0XLMJgreur0+npd5aCgyagXWeBXcbq AC3lOH49M0/Xan7byyIMRLw8SrZ4c0ZWaORkj2By5IHT9iVmt3yZE/RtMlLMuxvpCD1QddP1 qNiMfmuYZebiRuQWiPEaE2kLWcmOqjUnIaoDTwzE0EBGFkVxzg3EIApXaIAwxyUYC0GjlKZA ctG3i50w/hQ87oQ0ffukY/SvxpwxJZ6HW55mh+Qc4IbDTde0kXFQdE0zz966YjkXGIqlT5At rkERBcl0LgAdvWI85G102dqRb0thLxHIfVXDS7b6xJt0XZ2Bqb+nm1pMStp71lCnxLcfxlpM iSlsbIp6i97XEEipgCEqKirPTSLarqF1k1ZGz3od9ur69qSnpVYlYmbWKW2ksLdN4NCbd8Of ezeJxzmibOD7Odcx5TzZzcQF0fdQhlN9voxMEMJTGzVXwrxHbBa44dBz4kbl3Vb6+tI5pXcu D6zFYf0fQ/mfp5bw00us5d00Z/a791uqfJmRGiReQnXa9a+JBghSLMjjC4tTj5/XXmJXH3+j kNUUyCCLVqAhgq4HHZS/+GB2QAVgYI2/qe5VFmWSXOxX3S+D7iN0MTDyw3xE36JVfBNOlJAG 7XHKX+gcUHnZajtMbYEraCA6huZYlrRvmcquOylazBnSgUjQm41FxPLU7+68yyA1QJ/2qJIA bLkFWD7VCMNk1RS20BsCVV1r/Np3jtn6pVSvxsNkGtA/P5dRXghtFGQ2DEbJoFb5jqkdadFr 6jcXLHyMu0diChDv41d6Z1vreSLaH6stSwP3JKxCOOTCKSUIl53Fakw96FbfNGTwrg4OvAlh xUO9N/PevIO5KGDhK7p7YJdxnguS72EGppNrji2QA7nWgEfrlWJ40nAXkn+j210PFKheEjHl H/l1+b244UEn3F0mVQ1lbmRzdHJlYW0NZW5kb2JqDTI0MyAwIG9iag08PCAvVHlwZSAvWE9i amVjdCAvU3VidHlwZSAvSW1hZ2UgL1dpZHRoIDEyMDAgL0hlaWdodCAzNzEgL0JpdHNQZXJD b21wb25lbnQgOCANL0NvbG9yU3BhY2UgMjIyIDAgUiAvTGVuZ3RoIDc5MzEyIC9GaWx0ZXIg L0RDVERlY29kZSA+PiANc3RyZWFtDQpevC0SpFU5Zq8N1IiVByMWkIZ/68zYF8MCaP7D9ZpN EpA6uzlpyBHQoKP1W4nJYG2sLAtkRo65/GkALqGKLSjet1U9h/HY1P0vTN7WyqgsUYG1yw4q 1XUBAeOOCo8HPhT3MB8pyK+0gtfhcProSAjc4/7QbG8UpCT1LZN3ethMNL4GTgKPZFpAPHyL k9HwnlOMrueWM1ZV+eljkeMgDbP+abQMRhK0BfauP01LDmbqi2tubIfQRfXyU+FTenJtRG6v rWhkMnQuIqMlgvPu07V7fomJXfcM+NAo++3nHoYy7KudUx4hNZsL4zMg4SKJWcL//ORf2x69 1NiDEQZ4RvJ+H26QTvT09WovWW+3w1h5ljTNNV9sdUHeHp74Efj1Xay2pmYxG3FVqk4eK9rL j6aKBB9J/WchRwalrrDEdhQvDT7mDxEsw9+acghZy2Po7ITrSU6MnE0EsoAT9pD91naOAEfr q5ijy96TcorSsL8+zYSz1zCcKuFDT8ry7X/rZknIduo4M1zT8/zCo5+BsDnKZ//sgqNA3Z+8 jasfE5vSqq+DlCYDxr8VRn5KurKOAm9NFYfSoWsNpXAEBXZOH3NdEJK1917v9KK2ddbweQ3u lSbVn80UxH+9QzqGe4XnsmbbMsFM96/4DB9l4S4o1QBWRljoGgc+v5VSDeRvxaC332+wuwJj As9y+CJWkRkTiiWSdoS7prFf+VRRnk3Kqq2HvclqvpIy0eaY1JrwB2bYIl2/J5yJ6XRzcRVY 0LhJd1Q5cVWxLXEyMmdmOb7cT+U/4/fM208WMPWR4+qwmfpyza9+KEvhUGYeEVBkrBZTIJJj hxm2tmnzvANTO36PAwlAoC2DalUfKNPnaJw8QrfAojME1c3pDPqlrSjy8fDa9HuqeP2T4Ky5 r5HcLy8xFv80ecYZ6gwgxX0Te4WiLV6PQZXf15v+cR9BPK/+V6H/Kp1c8/AvHUdYCR7tWMg/ BXf/eGsO/hNzVM85Xa/+ucAsB2/a6RA6cICxMmBrTE+TVRoLjB0hYVoJp7Wd9YFUxWMSSa2I jlmA5rMuDrVAwLp+Phqm6eQ1fwCi7XC7LF1s/Ufp/wIFzDnmdYvMDBg7FOuzO/kLZVGx/eWe eY6k5K6hUPRrzvS9n9ILvrLdraZoD7XG7sRHbvAoeW8p94JT10L6ddhfVTLg5KOuapDz8oY3 gaOvrD+S8iC0XLW9K1Vubn0NMMZdqGvw+G32ftpkag2ucYUv2Lk6I1Jd+EvDo0A2M4kEzk+S 3/C9rnShCit/k/eA7DnohvPlQje40sV2IXjfQMJIYN4y9Lh0OHaFq3te5qRf7k6uGLDHLyXB h+Zs8sZCzEhldvjLfg97RIWMrRX95sw95ju+KAFy3gz1pLtYTXVFusXTmHt8QOR7jpkCxkKF P8/ey8dMt8pz8VjZX6W8eFpOLZaWuCX6Tf/tSGux1q2JY+HTJ0n+4ARuBOvcR2PZy/+mJZb4 znkHwM/d33SJGR70sc2MpAdVwGrfXwPhLWJvZpHe/a8tED1mOVFQLLj21L7JqZRQEEwdxUu5 BMo003MbBySEqkrm7pF3oVjRPtLxPEjng/hGmV4c9jHXFxTriT7gfbOeKDegrP6eEWPiVHIp aaBGFiYUNiqR5ipfldR88bhc6nNE5f88WSZWDbFKsPvmBQR5txrrwg2PpnsmbVHI+ACwueet 0pynwDBVjO+3wVEXBDrF8aTMRuJ2/YjibWMXoa2tCPXxRqdYzOWZLKIvTySGivobBOdjSP6A QO9dYGghTX0ORHQa4GsBgf5/XjcSFe9StHnJKQXM30qrNu4LKGRvmtp/ohDxNeMUqopMha0D y+OGxNJnFtnslzynGjw0jVGGLK2l5FHtYcYI+TcC1LlLW9/P2iXF/ZpnDChCiq36Bd0fGN0+ 9ZaTugE35w70htV48OUWxzumLql5aSbg6Yx0M0qpUADdtia5aAY+3fL/EAenxbxQAUEChbh2 saihrMRo2FhAPxbtmkFALCo6ezD4wYUcDZ9S8OG3eSSKPIISV951GtMMGNMxdwC1hKeGEktX 6BpYWpJ7PL07ZvXGzn41ffWC2FAB23fhPRlnSqEVxM9llMTCBlmDyWuFwFDVmwokFbnUxdOs mm6rUe03MLsNwuO/FarQLvPPSTNPoBh9pM/al5gC4mpa19t1V3Fbwuu2fJHCiV9xONJz7HRy Pk1VbfeyuAA8UFomaJ0gEL4kAoWk+qWpLMTjuGxxngNJLqMhabzad7XRZzlggrnPOlbb/8XB 4Ux5kjmDRtBPHSqL+jukgWCAHDmI4lvPNzzs8QcZvbfc9tmNQNBJh1JqH1jXWi1Ye2Kray88 ijIA3vuj7o/ZDArQrI3PPiRETe+/mVDpEiTfha9Q2h29IDY1dZB0qgdat+YFABkygpDt6pmV 8YghQdPiiHwAIudf7+ViIvsU3BWiCdSqqLvz8v32o5cCFHYfqY6Zv6knMTOn1BOyLcUwGjud obxi7qOxmapf6jMnWcxw+00dNN/W7iKYef35VqS1MEjux+7nxiQhA2SQf+DIR/5Ng5vyxdAa s7uuydBhFLFuJL9Q+AkZqGtEvm2toT6vmepaPFkrWLNhzP8CwHoeOKcv6ZiKjwhQI7/matSw zRbb8Q7cvrLGmi5KoeCL7C21zAGRcJkALMYjdHFsXteveQ29Tvp/kkXGqg/QwKYEU6QuSo/M f7GLHhPlPmxkw4hZTa5bM8qRcOIoeg/FeDJjRfN8VYKrQJUkDlsMM7gxjqxEKVdNS2yG69Pq 1qEqfghW/4PfBo9Ugiw9GRuOcuIIYtqmLM40BHXQvX4Pk1G0+YmRH/nL+H87dfy0UKb3mstI dnoFUMnoF8dy/Z25hK22UwhJp1/RM11iW1nARsZMF9dy5OFga1hXzBAJMTilczwW0iNHWsmJ hhwu3lKNdsIz4mOQzf/nzaf4wSLbzIbL8KM1wDFtOh9Fg0TxT5FZPru5YGawmUlhK+hvuRd1 yLmPEg9j4IXPaxNsbqe9r/QsnCofgy3tMFjxaWTfrEbdirubqzlXX/oZsJyCORXbtSDQuCzn rDqa0rDhfL7agr4e5lmLPnL2tyk7IjSA/bNhSuuTZ5pP345c00QjWvHxtft/dVXg2KWAz+fz EKaNB0FS5Y5QFuak+sXDM/oYWxmYkpB4UkTu7o8aYA1Fy/fEL1ZXBFvDr+44eWaCos2NJ3qW XMSg15h10ncAf2MibhRT0H29tx3tZUn04EQn/NFzQaNiYZQraMl1oBOnVumjlNCG7SftbvKj NB6QSNFiTPypf43fxFk6wK4du3cwRb62Gihw41BFqyBYv6u+W2sVs/6eW9dGZ5oksk43+vo6 ei6MDz7p6jaBTthI3XagM9WJnEQ+gWsfGJbDtnWMnrW7+gLnXOgRFy8OjdOQUX0sjNR8H/AJ 9pTw2Vz0hQhp6rnWmQVPngzKE6oTbkTs8kj1ED0iK5uVtplD8xA5tcPDxkYjNAHidHimEIiX jJ0juKl4TBOxfTPrYYf43mHfTHbyWb7K5M3kEWdwQTpmM+CXTdft6IwHguFswNHU8nyT+1uO pJwKNFrr2SVRo67pRVSFtIZiYebhUTH5pRu0FcDRvtG61ELdFHMEXVlYB7XUxMZ+WsTTo3vg CzTC4izDopUC6BXNFBa4Ko4LyMJ0wxG+mx+c1VPbOY3T35CbU7f/nTxTnV7M4YkPG174MUwf PJlycTKn1kpJ24qX/3INseGU+u8ctTQvMhFwLzwwnfAa5G7rZOOsqlQZvRmkXabM8bVw12pG acQS+6JrHW9VORkNZ8dqrVAI4/4qV9fxoBvWGhM0m55MiFM0xTd3/J1AokaxJsMgzvIPJZxY uYV+HRIS9D8k35vqSW3GaKlOCoci4t847FxTKLt9jHHBevVgypBLHBOO27XJW5916NtqVd8L v32mEjtxiLW2lCSQsa7WsyCjybKqS4rt9hslB0KfyYmK/uvknt63nqy6HYmDC8tt7WoQv2jz JVp0HPxIJ3y+SydkIGIUj6QDZjnoxW6YOnexP4wHIicCget/o3p91HqVBWC01bqSf2iPccGJ FOSMn5iHuo57klJxEZF12zKPa08+k/mDFa63nG/W0Ol0MXYYmgwCxW4YbpYscmvXSoMj3POJ EC9DIm9CRG/0L6xpmr8kl6XJUu1Tt3lisBr+NITbXRfyxZZ3y+CySMrlav6lEG5j+NoBcf0B C+qAcnDNsHxA5ij43bVRtAlxw3D3dHia2e1MwwgPDoy3o3COb0OITBIMherriF0O2qIp/nbx JqmTdap7pqmm06LnZoN/cOOluBQCCsW6MJ1N5PyAFuLbkazb2T4jd2wXn/2pLQKXBE1fdw47 FohjDktord18kzZDLrctvXVPxnR8RxxLlVFcOhnQV6/R84Bv6A9ZKkBxmXE2c0mWuTn5rNca bvhvq2LU0I/uYS8y0A/cgdqEbUQyYw+zIH3VMcgfqzbBl2CaiLrCA2GGSRWOkSB8KHass+8A +WjkuKxHREZ5W4OLygcozhXw90qp0V7LsmZBRjcl4B3tIxCBgZAfexLlFq9qxpoMklB+/jGo 1XqbL8aXlF5FHNgB7kPz97NlpWr4srrA+qv94Q+/nGRG0wrfMsrXM3gUH94ebYJCDEBcOHQo pz4+6RzqU+lPttFmIoFa1r8xQEHSUnOTJCJQ/ilJ7bxzlJPopSGvJaTFzVRfbIIIo6xxVO0j VVmBHIXSYgbj4bYSEfCnqAkfRRrq77o5xqvPu1Km7ydaxvMy9VYF9ZYo8pKEqUD7/mH3z8IO P6WypocbEYpH9UlJWMzV4qP/2jnfWYjb0MkyZw7gD4UtHJVD+nd3sdMK+dsYLwSyJuoEXYoL jI9H9wwUkxwL2/qCIf0I2NvLHbah0ouqDjfAiqNUEGjNso/z3u71nHSZnp18NfuLhPMnJsVT AxP86T/fzorjbu2m13QoKwqfhvwL742dHuN8S/1lZCBqCaVZmx/YcNEfJHofEGs5PhIL6eoa mIx7KFME6vxSQ1AZ0SQLFwLD/R+3naH75uRi7PeCBO54pQA+ZT3H0B1sHQ6cFWQgQXZ4P3gq 6hMgJEb2lItr9XowSec0IJOAm7jpZgUopd3+LX4Gdvk62vr7AgkfMp6JdKft8y/njqCUHY59 LwOCZEF7IpePYUjnLXgVQ6s20/9wvh+GxMG6F6BKMCTcggs12EdlCYRbfzRO+xJg6bjOMNq7 DmTC2GM5XUQT/ny/HuSbFp8jdqMhbTxtU6jwDukJPLzUC02cjjBjwQWt6nH7a2NJaXLXDAVL SEkgQWu4pVv52w12WKy5iSATI1AW4MRY2VK5EO4pN3C0hlTtuSvQz0TXTvEuL8NfJZl8ykcK AKPlCBgF4wkwnv1rWL1ta7AD0kae9B9+kSRAxhaEixeYHrnV1DeUMJnKgmD7T4vMrYx4JdXJ P7hFD9nPiLtJZnCYLjS9zm+eQcbu5Ead0Vb2Jt3VIZ42q0lTm0OnZPuE/TpPQlyZkFS9WuGL 0xr67xYGw4aCcJV1VOoA+/pIXpGGk8ZsgGGTRHtSZM3+zlT2ZQuxPX3nPtg1ofL89MsBoI2Z MTdOnrLr9zw3iknR/3OTgesgRyi2KW3WfGbphG2KErW6C7CpH2N5Y0U063ZMAUsecU8N0OLo /BlkkLgeIWZVfF18Rr6nQ9g3aZvOQtNn7pU8hvhUqDlUqJoo9qWYAzSgTqYJtQtVSdyGcSk9 YTDmaW8PEikejAiHF+LWiiSNhxMA2dKQvZUQ7LuMywZ6qgpf+34IFYEEQ514F6zM+v0V49ro o6nYMOemZCOxM2nJBZNmLHWrF4+tAc1W2rCknMarP3oKAFyQNvLIsX2Uy9ggR+nUC9yFV6Ky I83b8mewkanOQIy2+Roq4+uxe48fkaLNJyiai6PCzHOsgGPjP0KJfIFIJm2mrMkFOwVEd8qt 2S3YKvjmzfp4XjyBW3ib9g1H9NTcE/8rWCGB4e2xnRg734bYxvVqXnbzSekvMcfxhnaV3Imr n4RBy+klfoF8NQqR5rFDp8BBWDJbxTevCx0mYFPxX/V56EAqRt6ZNXow+/qJ1bHVuECsoNPs dUsBwDux3fb3P1VTKgE1lEl3m8NWu1p2lu1FiEpJBI4jb13kijDKtfxdkS1HxWwl72+YVYH6 +/NtYxXJBCTYPJh5U/cCjZfsnRx2aO9AVTEwmvtcXRtLVWrxdA1P/J/BwV8iLXqqb2tY5q5U QZ8WGIOgpQOOzjM+oiOA2GLZvkqsOZI+DzR/1VUHfgk3nXcC+FxA6fqRnAL2gD/EAWuLmTUI 7/vvz1Fm43n/LHISVC5qbmAfGNKMgIVhBD09v3q0GmnNYOZoZ/b9loG7GPNBvh4Ga3oZKTZa zxcAByFjiEdeTh9rIWk98C2h9+e1sKgk04mZAC+8jb7MPWMWZAEOGfiWgjNv62/WxAGx0Nuz EdwN2bIuc71+Xkl0sD+TbBQZ4ZPWSUAy6NB5VzF7I4SoTi2L3p0ZjMAG2OehkwPEzuO4d1KP mE3OsTB4vgXz0TUpYdQY29GxSI0iMqCzWfrCSr6g+RdF93MZY1mrwRiR3mEreGGPCaJjWwcu x20IpWF9JGgmthXdRBD2pOAaGRRSjQRFowbgQ4F/t19px6Y6X/J31U+pPLfuBMCAVBtW34Ik vIsSNo7ZG7JHHaeGN7UPpnD1iW3LkJXzg+VUM3iiUT0fWNRRuaJHM/C1mgSfMuwSfEa5YJvA OE/XZHpyebfiYEdU5qzTaRz5CeL997OnGdAkjqc8E32Ec8T/j7V8Ip3PeojWewjedKLngpiQ Hh10uHNHbUXVE3LQz92v/olq0urElWLcw1X3pvUIOioiXxHpixKYSQIIGkGGhJZTKdLMGRoU A1VtS4s7kIS5DZSxN2Q2jdL/IiowO7tfYxQt3wPbdKnjUSirmuLyr8RfbOmF57MaUsW38TLS pDx2bFOc5aIA4YW6Nn3ZvIQlUX9v+yzBbtwrhq3lvyZDC09qEo6k/DQujCevm/4fjmnCI63i bkMPJqLiv+1HUCM9Ekoj9AtUd/FlROErpDUoTn9WbNiJex8B6mKHVPCVQ2x48XnaOls5CM6e CE+BalgOBOQYAKEsrj7vkMyBlfXHwG6U0d1FKBnYjx747V9tShmFBLEqV2byG919bdOVT50H VUZuDgoMXgKmjHgpM/9Yo24HJgFcQhs+ZI4VAVS6M+da3VHVpH77NMD4rJeqyZObgzvElQ4d k+tvqbM0ASpBwvd4wNzCtKsHo+bap1qKmwJ6g/0U7bkvlTA3R/WHCWis3v2M068TB+YmXwax ObZWIDr6qQU6sbrDPYp/eHAnEhjUv6qEiMcCiaKOKQ+PUhogItGvmhDeH+gkus9KR0qh6wlq DPPEvEXzJ08rO7lwvXEebexl4aJsMwM6s7vmI8b+cx7DuiRxAZMH/InLRfwuC+wR8iw01HxB v6EPM7WyQGE8IhuYaTtN9WkoTKGX0N99DnpAButDzfch4Rn+3rKHLxpWLPKffIs7acCHmlF5 n3qq36kyzdGxC6FsGLcsEdaBNP0w8aN45ffo9+t43D3lNajD6epuRL6Lxwb/OiEjUuTjWyZA WDytMfiynOB2ZdQpAcyYGsvKLxiuqkYvyVyid/m8zXsrOQAO90maNNBQmRJqp2nPW/kRoywI H+A23IYwVQcSDoqhQIcr5+BfypCXUEDazoRYIx6eD1oSvyOpgDzuvu/QOT5ntlIaYKlyThFo 6Xp+puCSVqvV2lSxXUtx7k1YWDHjslWeLkkHcN7K619wfOsBs7UsoJCQrsaTofBQISBC9NZa zvR6YwWa9I1mdxznnf+5bPSPY7lENE5gzXsJwPYYRBoQBXUgSWdKNV+5BHdz2U89sQEdCoiz VGAWEfPcz+fmKFxs6yyVd4bYZ1ClFZ5lm0QQReZdyD0kj4zCnKI/knVsR0Lcewu/JqGYp+a/ w5ezY1CTp3Oe4w7Uzuy2F+eJXcRbVzOwCB8i3gZEb9MxK9G/eLzBjnombhHjn/xHXpI2mp22 jeJRPsaXnx4z2wXrPJnIPAyNzYISj2CIy/9pXmbb8sArH8Th6nXHrsuWrxyaGYb/xxfcUn3l AdbfDug4Zo+qsK8HrfMHRqcqvcn2X6XzWUzjHGe2bvnHsW0gkIHYWIlcMQckyZJM5RDq84BF JC1SmIAAWj2MuHzp54sKFmdJmPD49rp4+QNaOvLzDby727zW2MwXj+us9X6Icyl8gaoFYlZG +4a02FijElNzfGw9toyexBT1ayFYiIsMezWKZoc8FfmUbmQd4WglPFXU5WWFJoDqXw/N9wt1 eUIII85/gJghRKUEF6Wd4JThDD5l/Fav+O/Vq7nLAVXlwu2oVYoNdNJ24UXhP8dqGb6i2/Q7 Kx9+zffNRzJl/YMThyX6BrWudz210emuenJ1Gi5b3+pr4oNyru9uNav+eRAYVxSPleQifWaY CBJ9gw1q3qNkvfNorTTwWUfb8CsIRYf2HbzJ16XzUfbY9kt0GuXwjvbOSAI+E/d9OVdXEMJq 2tOjV4LunoBxls8eQ8wyeDdKL3d7LcngwRwUxoC8Lj27Po9vVkpqwMFLrx7eXI3r83LnSF1t 8wRXgQfygEznGsFYqF49pFIaQzUlyyYYuRlGPx2CQlPyzwURMRj26Uc3a/cxgZ7HSahXjPMP 6y7024/ih81lsstSAKot82Yn702YtoXtAaSO9XM/4unTEb6bkKVH0L0BzibDU6RrrG600Nct ngZQcSDEt1T8XaAVnkjQrFz7cv23iUcGc5rLAzZnr7Nqskia+VCkj2O4WF/bKhe0Weecu3MQ reKrLU/aTYkCXHLhfom8QTpqUkJCBdLEPMuJ0mgjn+UpwBlQZSiSuzs5yfe8ZjgLuYK5bMv+ PH3iuqQcxn6YmN3PECtalePaRHW1d7Meedq/lAXtfykFX0dor99rly/fR3TZ5pnQl9WXKYjc aDkGn87ub0c0871FXkqmj0FVbay/CpzXNifOqdm+1CNemQPH9FkhY0tALXchuH1dycdUvnBY 6GE01i9HUmezE4VPQqPKORDtLPIs3Y7VPbv04o7NcwmLn4s9OyJIhSRpqNNd1rD1qDkmgZD5 TxeSusk1BYOh/hr583M8DVqzwv9Xqso5ParYlrb88sJrV83StS9Y9QyAfdCqtlTQHiLTpnqk Vs8I3jWSTDzrWtqhu8ciBrXDKzGR6+DQymHiw8dYiqKrq16fdiavS9QeEY05FupjCdemRzf5 z+sR9D5TGFKVt51D//ei1NMP2TN6R8AOoyFjkdt+u/PZe9RUeCVaM7rW521COVaRBn+jGsX4 0kbNDB5GmB4J171XrGQAvTnECqen2cBTuDcnFyUX3jpZSJIT/yQu6VLqv7sS8Pek3V8YDJ0S MwuT73agkipvbgoiFaa2MOLJhKA0WsR5Zv7gvvJO9vSrw+6iu10mKnsoWm9c6wVUGCpsJkyc PhWXFFqL89kn0ETsAwS2MKOTGYj2ZYGcmRWPGpVN4e1SpFHhBXA0p5yjxiUoeQJ0i5hbqv4a 92dIwe4ILtsQZuqIOEoel1Z/w+sgOiqeYGbt6eeN+OXgVtndOVyIvLvY4tEwjBhlZbJ18N4R A7vCYo4OQ3R9Gyiur8+1jAo8GPn5UGsw1XPLRVFDWUcgmKydM81xNB6tZG1wtdoysS2GOvs1 5lZhw1MyVPn5Oq+tzVXiL2iA5ucAF1dHw0gmsSrypQeiIsOJx+O5fNgB2W3Cw70EmkGo52Hw SrlYFFyf5ycsm90PiuGaqdvjvnGjwwbw39inW7Ym7DGq6X1Qwdc5DDlJYj/nQtE0HWbEEJSV VRI3qTWzxcynf5ceDAAezpBLWj7EKiyrY+5veqa5sPSUBo4Ta7dn+CKGDYscKIRLJP5fPRYL wzh4rU/vUeuEASfy40JSjfk4jnkE4WCyMNVSvGfvJg0fbnaqCH3oqtnvqP1Hm2z3l5340UBX lQE6xRl+zqBBdQsvCa1fyupBq+4pBIp88IpgiROUcNuOZiEQtHCuF+ILfzZyTWk0ybOVpfBz N+14oVQZ1fA1qN5scJw/f5wXSqNW5TBVEiS9LKNCihhAuTpzciJQ/cNhVpwetd3Cgvt8z5BI r/qqR7FsYV/yQqjR+LmAtQcTcHAgoB9c8QojqAtHOl1q0AA9wkHj+WdeRePnfedJTO6xmTN1 5flwUQePJyaE5ySyp7+1irL6VIS8byCiEB9zw/+3iH/bjLl58VUgXe4P+CIYmL5qrW/uLH4d dgxgH7dTrpvNbzS4SBSFqzcgBc/n4um8PI43t51oWzBCBS2MOo5GwEPOfuXE79MQtx6eqymK Wkh2DBgJjrQX82EyPspPeb0DEaDGZ8xoxwPc7x9Ope9sXBw5mPFiU71NRXawoHmNtuaMBcpv 7xE2pOU3fL3eRVOgn2ExRjOLlYzBe8fr7LOSYwuQATMkqDbS4ounCa3IT43HNUHie84v3qqj MQG08GKnq8w8xPQpIL29xNA16YC78SCAkD2PtDV8LPOTcAHDs5btlvo1iDMS69r6gLl0BA5s vp0hH7UFNkjZW7V6k7vj3Ve4flEMWuW3MydHyztnRIuGWjiefUSoGw1+DymOsFUNNcu2Lg71 A9UPAOmzaeNjmhJWgiM6ssRDtpxcw74hmbnDFkmOpkv/3On4PotgS9TntHaJvKFx6uamj3wD ruzv7HPr1F+SQC0jG4+bmwFrs8p0iPQIOqNHijBdP71dhvTXrEGLQkfEpSmvstgpubnZadKE NBcCN1xiNghoo1djBFmanzmYkHiyc77YCYUvMGbkUlx71pQFBkKwBYoBosboubcdKECC/nzG h0VyL8RKKLPDhU8BBVI2o+s8koapWvN1bxnFoK/aPH1JRS/rMPrWwFqeRY7Vo6KoTtcWkgc1 kwhy3zcG/OvVtHj/jRednvtvPmKdnqeebBOAu3VnrayBuAqobYxT5BBBQM2W70guX0PNfAWS Zf05cmwZCfyHBmcHI9s/UqiKRNekrxEXmY6SNjRQ8bF1SaBWQKg47jKGxgRqr8Up/BbGPaB/ JHAsPhuyXzpjnxVWX/c28lnaOlL/M81oaOUuwkLJzBHSUt3Qy0TsDagDxZYtcP0Bf+qd5ZiF 27GSWJPKcu6nZvPgiTF2cIqlyfPM1uvWJUiHCWcqyZYb0LdbrwevlfOxVho5E34h+6c9IX2L mGSDdJvLUwXF8KNmN5xeAnXyjnC26sXCwkvSJ1dBo4G8FhYoxpm68EkDEpcWoVOZE+FUuGSh 6FdjItD3Eio2Am295N3tQyv+YpPXDMfM1+YH+6NTaTViKsrB7WIlF77o1sgxgzcCHksF6MR5 XXkDjopvqsJvajgiKJCK/L5qycWhHdhrN08Fbnh3gd6RWpbRkTWPPV2vzPRucSREDuwVxBTb 4siEqr4Rws/9/MxKsIaoHU721Cm5MVleUKMgmcz7tJe3qOWTa1h8VmIhwX8nQs1dwsyiiwjd U14zvO5pMTxLvKpYYWL24LRXSuY0533V7qSTCdLMj55SuLgg0snmTCJzs6zgfn8yAllr7uHU ViVZ3cGcK7GJXLEdobsZ0gpX+2wWXthnAt7SEPczasKqjcJHUQeywxaSe0o89fIkoVNmnx9m QdvZ5+n8m6Oo1UGr3l5mA/1jQVYUdMTNYt+DP6fi2hQWNcIX1+Uss0UV31h4EdDbLRUH+1+9 zReYsygWLAO/yGDk/6fHhDXuv/M5oqfarB1mVnZ/NGi1CxTMma9fPP/LHHs5z9AFTGQwtjhu hdbmNsgH6TKA+oUOIHpEvKJVuo8g56cezEEYKZ6V8nc9HOlZv0A0GjGz0LDfh8V+l8jL/zPt gxn+KVN0AT/vIiSwFMU8Td4TFJ9zr53kLoaTwBW1EagoFs8x0efmDLCDXaCXDXj8bacOat6u gJ2qTJ2Q1nvYKapT4W11+bSPIHzeDOYEdRE1u/jmS33TnGubY+Eqgrr++QEFaIFAk+NdQ5bJ InZ7Om6jPXnNPVS4wGYNQ+cyMVSkP4uFcmK9TvibHCnTcActtCu6J7wdFcRWpFVWhz+COjb0 DB2RoXOzYTw+xskRVwjU8/0YKOieVQyoukFlLSozyoJHutVdP99KpgPvYw8tegtS7V20yz0n WsBi9uqp6iGh7sOZstyQe2lc3rR/5Mv+oCA0CMGQwt77dcyznTi3g41tW+1Xg5M+mMBUb4zc CMYTuEUWnmWS9kX3/qYUzeN7HCQi8eCVBY3EqUaC6Wzvd2IJWK/eoerMIbcuZEamYrouaBKx uOohlSaNDarkPheyAx+dxt0IW0ymnz7AkGZljYZkY2RHVNpY5SlP1nBHVAjfyzGlPRzTtnh9 fNdLVzjSccrEgUpm5furlbUjkhdPpPzOP0l88sQP59Yo6z2xSJW6KGNtv/fPcc1w6tGTQTYP QquDByh5WyuJO2KAr9C/Ttdkqm6iko9vKcs4L6R1qPkmq5UQN8REdiRuRVsF4aWK/4A73lME okbTzNBmdqdBSztLvvEip2CYO9wrbeVzdJs5uyS8Zm4anvkQH3eyk7UwP37Vnf3MHRyHSFxA autfzSo3+fyp6M2Sm9HPUiqUEMXcp3/tn/Ax3CLusfALIvChemcIJjat7IxzBeI5CnbIhmUW eJQy5j4c9aedR94t1EuOzGMwErxh3AV/nTW6wxdAF01+eF0Qs/EQJqXGiXqWAk48VbK4GyAE 7qUY9WD27puDSmwSdp31+PYZ6oAZMQqXrKMcHGlrShszyXNSKFDnrYBUqbFog8mudbioBkRb fcF264gIxtDCU53ImpwLdN5qTEyianekvDBAl/J6WmhF8hG1lKjC+eqTlvac4BxP+E46TT77 K3gLChYqHEV7isWSl7u6kv4Ts70jkhgrm78vKBevpDplh5vi/VT/4G7gfbpjOenh1enpq9HQ 1fLT7mJ0vq5WeiChTEwIOcvpC0pQgHd6lUHTjR3HkzM+aTNR6/bkc6SQzb1uczPqINhvAywG z5UF1LZdUh7vRyPxhM/JhXVRyf9vzf50HvJH6o5+eEI91CFeOyTVHI1EmWhVN14taoE6hqUD GB0FrFB0tHhE6SJmrMdnAg8K+F/e78dP7V56WDV1h58h/H4+TKnRBvzFLWSb/33jJri6uD78 6doQ07nownsWIDZP1IK+a3OY02o89t7zzAFEL4ALiae7Qmhkzf0PHl4bkn0YnzjHjgNv8JvV bzTTwzsOvbWy3RuPLAF/kUBXkOmSvGzafjtqKG666J8ahi0fIQP3k5AT6feFjHKtt82gH6zq Ph9kRJqTV+Y35X01FZpQWA6FmMR5zGzrZ6Etm+ab0Qy1eeiC5BIHXigQs2uAV40HDmuxtasz eQYvM/cGWwZv0wLkSQD6MNOzHeea11Fs3JWTZt5UqZNXEtzCIvOo4WtcZ+sQeNGfC1/sh1/x BC1sLxTQ4KdSYleozWishIAdCJiLyzILWeVkoAviMkcEEEuh8kTk+OH2PzNSyrqNy3nPvJ6C 1OU+Lbgj+Cfl5u9RvYBikE4OJnc4h6RvRkRvrb/IyLema9JnV3/K1lpY45mWbhl/R9dFybZc lsL1l9Etun4h3cO6P99CGGzRaXFIBsPQAdAPiAdy07Rh/PyihqfSKqDhNkKtMsgOx4vkANrU HCbUfsI0ckVXloztq68jm3bLNy6iMpIhv0YuhyLpFjFSMlwNYCatql/w5E7OyWhtTwwFafGW dzOPhMJPM2YYHPLQa9zRl1WU0+1wSPJdMOTBbk7Hggh5uD23EinE8c/fnKOo7n5us7yqH55I RHb/oZAvAbXEQXrBVFOLmCSmBgdGRrkkTTp7YXUAKhFtCZ7CwA5TdC64pDoRwDqryv+z0ic9 +vCGDeUsybz0v/lBrggg326coEstW0UbOcn759amZkq0dDYPk3kIDogJt/mFhEFJU20RFQ+r 49k2+/MEQzRezSrd50eWtizUQJQRpDxvgavnEnfI9hsfDmlnLHXyzJ5Sdt3yFcAZeLD8mPcQ IfNoloztINOenuFhJ2BofjNQvgGqKQP4sqVEipkzf67fvizhMyvfBguehJmhdCu0S4oPYet3 elDoDFmmk8w10s/Kh7ZArrOWhwAj0gcQnNN/WBMvkRZXo6M/UfVvSzKC2rstgm+X4gAnzKzR qFe7pFOalBXgNo5ObnMMnSedcfU1cayix0OgfOrlF/Wj3GXkQbYD3JCizQt1UOFLXHfMcIgW gl7hh+vpqGPFfxwX0HwwM7bVwCUAK3UGBDAsQ5nAlYg6lpckWZQHysZimAsXa/sVpIuHWtBj I5iyUUMyN3CtKsQi/aCKoSzPX/rbKnOhkVxy6Izas32xw0aRExyICVkSyFD7bZcll6YSAkqz kvpCY202B8f/jdDTyZbF4B3oQ3zNsnCW/qqw2PCm1fqT812v7HeLGYqkCrAGmQV4XAJpopFq 0xsLmLmO7MZWsw3Ejm1ajbk66zdxyEjs6P57z9giRq3p4oZVfgNATzR/h3XgHxJCtgU7qdqI FTom3nvMk4Lpgl31/d6cqP4vt18Bb7zAB4pWqkAuhp7qYb6SXy2wr6UpbHJ7nkxneL9X3H2E LynhKs1GPeuqqRVbP6WOJyIt+SrwdN0yemo8iMK+U7WHE7qxWFRos4AkYGB459KVc2WGWlZK 6yFGWZTGQd/HvW135ddFYGHMxmpffXQf8QlFSywycq+zugNUxzoIXMKEqDjbQzh+8mXXAPyw jDAC4SDdF5Eb+ov0qE8+eWfUaFiRdBIIOWCBLFWeMG/5gbbAjEaZ95abWEo+177nFJzGDH7l ErF/kCxQ81eopNybm3EdCK1/5TNXw6W4WI2lg2rTleJhsl07p071Hfo78UnmL/SHAdrOCaRh RE2l9YLZ3he6Rz4g8lv4S5dx8d0hsdLbIDb3ROoCRR+d48UAHOEKeDoZFvra5YLsR205uWEr RcSEf8ops64nbUFHkuhYrJOcGe6Dbvwh4pYNAOIHzggfEO5mZ8cY/+4GisQ88uRKk4MyuQLq YJeTObLK5VYoq5ZGXx1iEJYhqMqJ1T5fwOHVQN1CBlx8hLqmsx8ZG2U/Dfp8CvSQKmaru0wb XYiX2y8iwzUMBD+kEk3JXUKssfxnIfJebHaoyyakc0CSe2Fw0bn+X/3vMxlcE4b072uJR9pf ScXkbGQJUUSzdcPLZ51F09PndWcaLirpfvQjlLDofvgmqfzbt1+QjpmEKv2HWYNyj61H26st wpwMwmJmrBTtCewHUIyhaWBvnONKyA+2wT/mHUq+SxEZRziqQv1i7Vzg4UM57jtUlHPTMIiS 68fXYN2Rh4jIy/O7HSidw8O8AfuW/TsC02mVL1aI32tYTF9zyEYb9JoqGao1FCeF0F8tb4Lr bKsjPuqK+4lIHtd/JEwP4zR2upvd5F6BCHtxJ1ejmJrZHFaucdDFEl7ArNwJdNp54qmknejT kGFrAc6/UDYGHAgby6RAKmjtpV/vatv/3pIiNyKTAqF/OkpcEmjYjFxCDAag//dR3CBPb5yz V+/4cEH4XnYuML7/k6jL2RutvK/aoI6zQUreDZ0a+5SPG0R+qv446KL0c9WWt3f41PLJ+Rey wNQz4y8XAa04bxs0nJnpHTOZVeyMBBMbmTWN9S6VWnwetptzjio2eUQ2w9gRLGJfZaPl4MNw EUsuPCW6d1YK4UUKd4R/2KgcchasFkCg42LdNiZK86+HGV5OpiRMlOlES24B2paAIs81IirZ swuSCE7oAbE6XF3mFY7EKGHb1hm5sqA85+YzuQGR2H7L20dphjE0CM9T1tBW0YHyr8ypde4V 3eoYtPiYV79o0wfLmu/5PfhI4lhgpEwvqki/tJ1KREDrOttFtdCdLDE4Fx9SEXwOYKk5guPb THDUhd8sUJbeYmUm8I8nfiXrX2V/zfpHzPoYuV7w3eCb3Uuwmf6V81LUxHtOgRsGHPOnO91c iIuRXLLOM5yGIAczNzT74LvX6y29Wq0poS9+gw3Y2l4vs3QArV+EnJJw+CnBwtBDW9GTQZBu EgJS/zG+TDkYS+xOKuuY2pKIyihCk9+i2NoXQZWLEpzKrS6+zlgCmJV8or4rK/HQvEMtGC4t iKqzUZyOCERP6K/BthkJszIVt/U+4RBlQSgBlCRJWXAR2Zhk6xaOSQOiCTL6K60L8nIJ2Dsd i4JFdIOr7+kfTTPVyjbgZiGbA/uJArsZqwUNjeczvJpUV+0x6nzpz5U8T5HuPWpN4b7kKLA6 2ETkig0G/fyOU+niJnDE/x5EL6AMpyDYGaPOGNyGcUETd4cZukU0DIfS/IqmuSrel+cZr5Ff VoRF3B4FG0TwGs7s3o3Y6u2x/w87Q7wLMH9tdpKHRcG/DzUP4qEVvSxEDRBvzpSpeK0isGC4 bvuxrjoxNo0CiGx080KzZaaV79CcHvzMl5DcQMYcYhB4EJCWANr4qOcQvXuZgwOuv94hxmsC 10YgkDFjrFITp/UN6GB7spqkNceNWZLHFRVUK3RYKZybB9IlRqSgqej6pAFBZIEWrLjafBzX F7bmpEznbFTIBQVK3OBjIYkB7lp0ZFUbnf79usyoZfJACtcQt72y82vgu4ahj/0cle/+ZXTS HTSVdTC2NNen0PCFBeNz+5bWuc6cAfd9Tn/c0umLNj5X3UAjbF2NMbSRTEcHtXFNead1/fgX z+GXsHqHqD2wNnN84/3strCevGyAtOHSNtFGQqfVdoAB7etK3sxDJB5rkS2IZayNGVDlq7ta xqNH4Vi9/6CCrhg6A76qB9hFV/0oe4i9hikXbyOooUS0yO0MCLU38RQGfTqs5MO4BbVpoMAD XqMnYbcQaVMij5GnqW0ArWvbPKDN/MU/hJFWdKRlmDyvgarBZ8lPzJqEYL0vHL2lMqrxBlXm 4FWJAL6T5bDrZiJdcfimQEm+C71l0GpSGKSDIrHeOUpGpMih8HBKLjDeZzsKFRGb2tWPEC2R hcF9Q16eO9BFeGVk9SpNf3VsxD8qV/gX8TzDeo6Nzof5wu5HZTJoMbkoL11hmCFEhnUE/KVB qnnXwopN4ZKCRuztc63Ze1xU39ejJKpDeVTY6hqB6AtnT2cW4lH75MQH9U9EH/r4uz34GCZe ii53FOoSwguCPaEcU+r/n6JceG+Awe19xUrsBpd1l/l0+f0/TGcvjp4c8GULD5HQKeEIQXKe NzJIQOcyaIOY93TBWL2oZWN7K0sWe0t0Tsrd2acVNyhc1B7TXeRqdu+tprANtNBj1LpmYEX4 qccz67YnSX77UHKzAC+5LOZZb25b9mGVC/Mz9CR/VTQ2X4FSRa0ruD0SDg6vPaoex71ComIl SrTMeqg/9NdP0lYSt+zGnlN584PSu0UaizUE9Ou9Oo8tUqjR9FqBsM+GYSZ/diqNMDvqTwP5 kvEp/7SmdBqQCFGhoT1p0KkLIcPZITTGsbPT0bBfPgmLvKPsm+cGg17O+qprj66eDJd7Wps7 ySh0x0nmg2cCzg0cKtjIrsVpMzR9gQk3ia7/D6PMs0TCcW61TvnOB9R0nCyNmcXCnnFNY5le ZGmZi7JGUw59OoD3aJ0nIsxBTyoGrsykpMmXPqYfOWq8UILkkkcxdEgBIV1Ce3DrdwMCilqP I2UOWYp0ekotUklygZSlFz0AEJ78FVWfHSb7KiwV7xKgA9vuSu0hXd3HKBNPJiWSn4DkmMb+ XN17oxCVzn/ZId3ED/7pBCiVC2mg9S26+X04ubD0mgEHFpH0Onv2TqU0I3rqrJ7mlg7ia0q4 kGbcdkBtf5YJCA/qybBSl6Wv9onc/x3X467JusPkl3sMOASVF31lO8gHJ1cvxKN5GohWrYaJ GA9XGGJIREH/rP8npejSi2079Vnf7/Ld9I1NJISBg2cgqQsh3HehCeGFsbtTzJK2c1gyHlGQ vaUftqVRcoc+uN4kfeXTN7Dq8okIaylbFozLdd5lg6L2glgrxqeXaThkk9Oah/du+J3U+wY1 kRJsjoAo9Wq5J3NIaNWeS+sCBm2ZWz/H/jIPv5lQZmxVNe6fwX3nP+Bk/8L0Y0O0t0ggs6aC 2Rq31XCIsVf7XqiPTurlapOjdMgOINEkqQYnzDd0QVnyNcwojbzGEGgBXzYSxuHhvT+suwle kYyeKd3J8hKBE/mE5cRErdxZAFHZukQv5dAOsdKR/yHgwzqXOo48Su+uifISoESjceISQz35 Lnc9s45qYvSa2ReO4O0TaWf8tFGvWhSdxpds4QnQydK+ngABxr9RDutLFRnZKSA2C5TdzYNE EgLGx6WfQtBfiF6yzlOep8Ue6nISlEMd2SLZNCWbaXq2t7yx3nJwUQ47YooqMukYjmF+kxhY uA8+ewjUJsePfrSaiuCnZzZFizhj7qv1qtwuchDgxoo4ZzpvI/06Pa5yhkIPu3PTsRYCQ1aC uqs1DE9m15vRvJ7l9GD+vcphrBxoSwHFA4UCB75opE1IT+9xYhRkuWR6Cj5nj+zafmV0xsAC NLP4AtO+njn0p8tO+Z9j/ScDiNSflLfUalNtrDSPsKZApKXx801Mb/zUzA2nzkh1g5REwe2U b5WuhWphKYXagpscpyVtaceazNeaZseFqSiM2XwpR+5DIQstx9aAWrf57sB2dAhZG2QkUxFu Le3RFXYTWl3+VUhYN7apC+WrFepE4ggeHaS00JY5o2i9cDIBJvJ+/15tlT61Cbm4BpcAM1sA NiN1AZ9lFVADwtdmV9P54Ba19baqgKQRhNZNayS2cYVVD7rBv+2Bh1XP7RiacTz7y1XaqNa6 9C1uW2bOkV3v9eZxJvWM3vPaZ0T6EueNO6QjXw1MVpLUIoohOJvTus9ohF5oBXUGBomBuRzS Jjb2/Qrs6TIbhpib67vnN3ywGOrCAZA/RiC5BKzjqyLXaMoSyCs5uWIjHSiE9OFE3dKKwxRk /l3VP31l9V9i7r8hDRqyiIb/RTajeNOH1c5dd5FZThtmL5Bm4knK2sBKP25hYuQNjYIuLNKn REUfUwpuPGlgdtm9YX/fqrUOl/X5p+S/HzjKn8PsqMQWvlZbmtdd5XVbiXMiPWEt8oBJz/2E eZNUkIJncxmcnV9I4YpRuKWrrQyj+/EpiD1pQE4mQpEj+v9xZycEKiA174AxWBhXrpUVpUNi L5rn/KDCxPofSokRWAzQf3LIzOVgWAyK8QfdEry+F83OZdh8yObOVxrAq3vujhjsnD4P7Imr UVyCKjYuRO5/U4JpGTzdW6eDCHGWdJVoMe2PwppPfq+DdiiBxDrN8ImmfaNhLQKcM9TvgfvW 6SjEyAntRvZ824eAkretnDdy1/HO9CmxAEvuRSu+nYJ+R5d9OhUec2oQZEoCj/5CiNQzH9Uq rHSegRPgIY0FJKRewMDXy3OUPFMfBwTVonbx/RwYVySDlcDNOxvjvvo50P2LgwQpd00RocbR 7KSAiy9xkDdp2wf6cxCFZqi5mF5YbA7M9493ROEcyNHBKJWdi5q7kKXU5HV3nkaHnC0TW3qt mN8MxOyYz6k76YqNIpMbuQJ5cgXqkpE9muLodpZZtWtbDQbvjTsGeb4pAYQsAbNlpffJYNLH oJalEPdCoHU5ZhlDMmIumclz4YPMpq3IZVSqJGvx/M3AiQVY7CYqj12wnyCLTCzvDRjXLQuW Wve3Mg9QvinD35wwcBmWQL3uQ//7uc7ZKn4czhHhRA4xb8F5Jb1cGHW+UyBAyeVp6PXjQK8V w8ysvpPcOPu0sz+34kL4OSWa4GQTqHoilwtARPeYQYiIWM9ZrBplmi11jz1MDaH+oZ18pkU5 q0098uorP4Kbr0IP4XTPEsG2c3zPBSddnHLOLIa9v8In2VYQAkAEqtH8dD0ZUi2W7VQqIyCk O51q/8xv5iTXRIgR89vaNVANbudBGL9cO8Jjs6PvayrncJhHtsK/djZn6dgC4F34N7wF0HFM 6pwbcvtxY0jkWgSOJOHqppisbWVYsnZ5qxGHjmpVcRvyyZcj7w1nUubs7b7igFEszIb7XEax lGy7A/k71VaJhH0Ug41NbxUBOyFDkMyDTsS5g3ux/ToI0vmuA3oIwi5tONsNNSooyufVY6Uo esKEsjA/WveaLIWcslPXssJIOoX2KOklJxVmE5bjqHAZp9YcGX1OCQX8R/NmunCUPZZ9a9Vs l6W+ARneJEAjhAR3OQHDue8FY24akjAzrc0mgd2tZRUH9dS1r1hzWHrKb4tdtRgBUeqzGDzw YabRUeFD2fF4arFpTY8AWlCqDyZ7G7sNT0YrNmeCFyiOFsiE26T8xzpASgJ3l+5yFc4/dVB3 pOxmnWvwWq7wKx2KI+hdvrMUXcyRskTfEb/01F2c9knAHZLPCUQ6f/hv9tipIPlGgLY51SZW X5iSR+ElG4uqWtdKV+rSA2OMnKlhjoqV+3QmjFTPL8DtwdTfNkAEs+FmZK+GTObQdD5bxCgq KfMtT2iFtV95fW2En1DIPs46MPXQpkcSRunqwohY7ZXGFYoqbuhfF0bMTzYAMF5gzXW0V83k PqTeri9Ke8lKUx7XHXpqyhL/mJ5GIxULmEockf7gGvoMCbyJd2WnB9A8MGKvv4S05/4/9aoC ZWM6L3X3Sz4o8VajClLxJ5hH1vNNSpB2ybJS9rGwlzk6TS7v2V6Ndaxa3k4kK+BrCiXpUOx4 YleTdyHOEW2oCeaCunkFyLs4RsYwGieR2I5Jkdbdqr0NaPYOC6WsjgeyqyXJwXTdsk8mlG4U iXjNxWb7QOyRq6Ds9GYHlIIcYg0OZbh8WVDNQCoVL2/y1m70DtbAO4OzZhaWhSOvXiV0BZFJ Yg7sl4dALqV9v9PyrhdZwrHafxVnMXD6kp2n7qmjWFPQ/KwPArsdiBfKToD6f/JdHMFlGDiR HuIdvCxfDIYDVLltYXEr7NjXJoenS7ZYV0ydfL4/ix2teNNyeKG9ULb+y2HYf1TOw8sf1kma ZkVC3ux5hTtOb3h76XkZM1j5Q0syznUYczyNg/IfJdDnAcUquyT60Jggb47c7s/GZj492U0j oB9TcGA5A1wSgcVnTu5Zou0S8kLCsD4EbL3WLg2fs8WUxRz9xl5ekJOtIDLcIPlzgonV9KaD JGtfOwt5QRjbNqMN4gJ8ezSsXT22UV4VujNCYvGgjnu+pJWBCejtY8LoPkMoAjF8IRU6yzf+ 3nlAGXKrcRV3djmU0sy1KAICGbpewSXu/athrZlYeGrxy4366zsRn3xsiZuficdXzpIgFAjz Trz+w6Nl1rR+fgcliHaAnWzL1lN6cpn++Gfj8SPYNaNiy1Ip363r5R5URt5xG9bkutPSkSQn gRIwwiIvGI7gDniJoEsILV0DKbUkWnqpwZC/NDQorFB6IKsWxinNFpkQp4HQhpKtnp3qOLnF S756DoSW7DH1W+0AushC1zJ0OfTPjHOP3orJKk8hW1j5KkXiQjn4YBHF3NdjwTdEN3xUOoX6 V5GAbYjt0jd0ryGpvXXA6zlpJSEszCH1WI0OE3QelMxmZokQBy2By1rETTd0RI7FADZSDUXN dowq1/cl9NpzSD2xPiDmvBVQ9Ng3dK+clqiuduSRCxnBteeYvRv0+0AiT7LRTT/+4FRqTk3B DBeNqvhEcHPx5RGQHV+M8YmDlEQ4tZLOon0gGf/YiiBszX1L/EjshgHyuAINpLQmEUa7tQan veFriDsZUytTUKY7AftjhIDIxm8EWS+rxYZJfYFH1J5pmOkDtZ9dDUIOLoBej6+vjw6t+Iur 4Hy3auYqRosSO8b3JqJuLMlyqNmkLtADEGyDMIzx4lpsHHHN4oqeU2IpXmo/Jw0PhtFlEWns rNNwovfmrc8hLDGL4JFcx45LD0Ag8BZfGksZETdFWEPWPTmfraxlRRrz+F6dyh5sPt5oR4xh +jISwjbBmrevrLyQ3reo64fx1KKP6kBhiAa2rIc2NLsjo8APgTt9tO1Ic+8IEw2FOQh8u9ER w3qAPh53RCsCRXPMbie4DsEekMOuB2uiHLZfWj1289C73REPMuWUg5UgNBS/osGKv+hbozVf FkEEQp4c8TyN+Miw5uSK2EohMAFCB1vYBrP3IYNVg+1FiWspdtm5m9qH3kmeM9AjA9WLO/nd tHLewwSGLhZsYcX7BfkssmAM9HaAVfp3c2bt5PvnwbsJp1tpWWIp7ABsMSGV37cglQLY3cX8 +GfXF3hwm+7dhwjHgdivbW9L9AQxc+67c76p17SHiODn+/EZv7c4oVaAF7VymMUxlFBYpptY vilp34hgzRYzAyIEBRj+ZM3DQ0As8IAtR2rNJlguj52+u4+KRERJXlCcbMhK27SU9x64FoGC DXdBd8YZOMUjnoOyxF59k0AKqOZOK+FCSBTaamFK6RVIbXfvt+WaDg749V4Z4VgWe7oI2kQL hCcHszJ7lovG7ElwzYT2+aizrKz/NWUg4mK8Fe2P4ZA2zkHo25vOVRlQA8kOSYApUHS5KYTX r9hAEPb0AF7uou4/g3jWTZKCOwLPNe1NlzIzzQqgKNZ7R30oFXfB6jkSdkEy5j9hTyvj63u6 h8G9g93QbfX/TUCOsSsxCZ72TnQr82hckgScil/WeWafOZetnxrtkpW10dx19hvy2/YLoUIb 62PkCteCbVQcyYxwtlfGGT5+oZCGXL3+08BpIV0HkFA+avy+Y7xGh71r05aN0pZC2EWVfw3N D0a7UPX0Uupu7sDN1GWJ5A+4RsJ8upm4qz8m3QH8+DNZzKJj+b0ffFboYUOGvAsMGSu0oPQm nz1P5iFRMrh7EonUPcSdYvkp78Z1Jp1P+p17eDc0s7iMFbL9Ji6CF9RpwrsVRWEBjexoABHC 7o7uD1cQYrsaLEXjAIv9doNff5HYkpqA/cTehtShz6UUmnn+kEqFPHQKDNoiHRUqIjktWJyt 4Ao7UKCxeB8/VFTw8P0VeND3atda+H4mzcDx0qrk5RCNdttsI/m+nSaYAOGL49G3Ub4YdOIc wEAPMpowWdD70fE+T0E9tLoOvCjhBXn88J+MV+eo6tETUlEHS7J/f6YrTQramaWARXrVy3QM TBKpbAsDhKsW/xcvwLmx09/mp3ON4s5m0NXqaeFcObdtTM5YZmHEdnvY80qnlLxCSPAWyOY1 kME4nmDtC6uOIcgQFqGg8kaxqD8RXFG6dQ3QqZyuhed6cxSrInosW4mxCDj0PNITiE7IAX/j PEtMkKGYCAbhpS/PRYy7S5bo3173wPf8dut0iAMielDlwkC3/2uGtGwpmnmdwyAo9huYFcLO DrcaNnQDZnSrumkOu6Qw86ITk3YMN8cdJxDiEUekjsBKktQzIyWWzb4wYM/GVL0x0ikIOW49 w0QAobdbaGv+1RLRuIE4PRi0QdkF5Kv1Ypl0psOP2a6mri8HpEw1Sy/Uu2CwDu83C+zZh4uk j/+OV7jcYFswfZI4uNN2s0d8XwYTVacELGtHdSeYaKI4EV85coMkNF9iEbPTngRC4BTvCksy UsR36dzjMiQ1YlVwpn5mGU4GfNvh138OKId9Ze8KO2dfpy3WaXZBqVw4UeyYg72CvHgwdIGR MB57N3xzQk/AtICQU85RP3RNCPNVtaRxgGCpraU3i9D5ccgnhRo4P3z/ePRKrME9Oqrxw2Xq 30id6UE6oHuULmECN/y1DavhXqpx3WpNydR4ZEKFzt1QBS40kOuRTX9nEFLNoAZKmM6ef6jb T1ol7sATpcsuwXp/o3QkGM5tZmD0NonrGqUv6KPsp5IpPHcWs9hH3RWO/ZWrJRgJ9Fbgtu00 AokOVeoD24jE1nFNG4KJqOLE+k80+846AP1Yy+HnJ7+oVsBlfMrIEom6394ONGYh2O/RkRM4 gujqj0f7Jo6SL8NRWflslxt3f54OJYFvaaOf3ZWpLeYOZI03a7wMhGXe54qyqBmC6jxKpVWl WvjGF4grufVEIVAWld8JHv8wIpVPt8OCLjXgatTDd4QQ9INzFsL/XeUAwUmStHbl9yoUmsKq 1C5EW0OM/jGfQd0d/Ovl3B5ZWFd5ODeLlsclpVSyYe8Zm/ATjKC/b/ObInXM30OhxHbcZi2W FjVSfLIN/8ZPfFZarUtnepgty0o5Q6rEf/MZiw3o/yCLnV3Ij1sitkNkD8KK9LSTnNUv42/6 BDyUxbeMUe+PInEcrPOPS4COIE/Zpu2xEWQFJ0BKFDqmMbjYDrwpEhS1vIc3RTMfRDmeprYB yRUnQvFWUe1jK9bEbx08s4eb4rGfsOgCyH5ASBMrE2fpZyeCasvx/7yO+s1G1me+bc77MIJk fws8Z1ndLJxUd3annBhD9Llr/SerEZc0BBMjAnOLw/dCL5oAWJTpK1kyZ3xAzY3X/L9Z1Cba uNa47x+9lEUZFVnzrnWh6GHGsQkGIwsb4bVx9iZW9L2MLVA51zS1s67R/VqWfeIqGBi0PnOu RJGUmzhS7UqgbqnxC6borBCTHa+j+O6hIhlL94nR/HY5PtL32NcA2ugKB2jr1c25g1U5833m wkwNWEnwlqUY6gFjTJxckZO24s2JNsWjden/ER208d1YkIqKgdA+xH+zwJtvruBcMUhPlUBN 8ot5pTUpYb0qiod9SddMuJiUpzPJBBJ7srH04eiqppL5iI8NDGIoNwCS09R+MfWRKxI6s4UB AOMQZFpAVcjUbgOgFB3/yM9l28HidB9qFRFYDGmzL5wNesBvY3Hb8xONXo3lQRvZ0mTCnVRz qDkT4JMq64RF8vDu29Q+seH6b2PWGWyZim9uw/LjVngfHAl2WLz4ZaAw7OuCGJCpIrT4mIMq iAbT6CNlrz4VC217Rg6SYyXCWEe9YPQA2U3kCJqI7tYN6HvDwlY1rpMiqlGOFVOddefG9s6l TEYGwP1/CktE2N0MJqhtR/vhS+T2/OF9pnHGzSOrn05YN2fEFXs6sfqJf45Mg/n6tn0sfE/G pesTPl8TQScoxPpi/fb5d10MZl7KeynENFUJetrn5o3do3tNePVIHDfGBVemdRdY+V2PpN36 zWNoNQiILA7LTBhZbrsrhUrogl6MIt40lI+HeED5xkuHdGCIdA5hV7Gd9JxBu1Vy/CMzG09G Ev6lDIQDRXJpKpDNbtfTuKFHwCle2ULoBtUk2run85edJ0ufEbsAc5fOAPg++NewkbSJd4ry KHz+vZ26CJukWW3qwOUJd0QcIS1h7uXsCWZnVvD8Tuzz9w+ktbRMHHzios1OV3JO2XjQe6TA 6KiCY72Z2p+H2cTu+8fs3uOKOya1+ILmf5rHfXgqVWE/vYOTYwFlz1wdT10LEqOUBBz9AF0o h0pwgbxHu1g90fWuStzf59H7n8JtzJ/7WFzvbYJNcvQqu2Zcp1AqIp5WWnw11D+3mAGUJULC wuTZYsZbMXAiYSalWDG71GrhvwiaNVayS7+ErQZDXrYa+jLSPDxxGkF9Twl560V9mrqT6hZn WUUNWUFKuCvprM1yPm4m2u5QDQn9nAF28HvJf5dRKcrFWgffxjBaNWviyZ/HjNhqWdgI+JrI VnYP9nqE73g3oGkKrcufgetD88cG+9Y2ZFrHU03tLWuJPABozjZvtVVVnTdn841a5QawxlXG LSl0wXLP+1jf62PH1sFbkGl/TtjuDRxQRttTHrJWA7B50ch0z2tg4Wcw+G6G2q4pblwXBx81 1LNAoMhdC5B17mq/5j7MC1krTUUKdUgvul9QxfnMo34/l5vKS8KbRLUwCZL+8uSzjhweeLUC WIWLJ3uFmVYOjZ/d4o+NzYPLrfBOJiQXpMYAXIZ/HMzh97B/nKt4AToaMoplzdF2LtUvn9U3 0OOp0/afpyDymAM56kgHsMLm1Un8x7vcFl0NbwzGk4f574m7tJIDCiVBOeOAnyLq143a3gZp rxW9Fq+PTggh6iyLMMlnFr518ZOWHpUWTLaanMS1lca1aMtKVP0mHW4tJlZV6XdtdPsfwUbX GwanIxZH2+B9fcMGLzSid28aZsGOBQdQ4JldUN58HJedwtmtfSM9vQh3xCMZ5IL9YYHFenAu 6z13hOMsR8D0scHAYTQKjJiqOT5tlmnPNWXKwqm6UO0fYoKtEhy6YSkYtJFXv/x7Rvc0buDw FeEp2EjcLw7w7Dro3fgNKEx3ktp7AfU6eQ4WRLHg4f6Rca/IhYjTXN6S1ljdx1ZeDQ3jJBKS DeB7JxOoI5vCyTiUSYuwJKTA3b2O8tE94fbdcVyj107dawLTcowm9ETUeCXLdP+LHYVVS6AF +xeyHughbPDB/pBGhtGPcwT18AxKGzT2Tnlpwobq2FVq4IduJ7z/WDbu1a2xOUpjH3SQXUCC BE6vwXbNnUKpZY4u5+GuRrJrx2EHErTONWjB/fKfaoHxPDnq/vFA/uwB8hP7EG81x9aKpJWc UKn1dUFXML5EFktS2pjh92YZS/+5PLwBosgawn/O8iB+Ry9vKu3y6ENSUpw3mzUV/0ciNDX7 J4tNVQZFE5YSF10Oc0fK766ByUdYR0xOMrM2631j8aTQkaiOCCDx97ZrjcwaEp17KdpWXB+v sarLgvmLIpnGbghUKfV2VeWsEkxE6rRE+IHVfOdgbl678uI2Nui8GfeNUCKcW/H3PYJVsy5/ Us1tkgWx4WhY9ARZJYrEFBo0o2MRwf2dshoxjvtcL8YitLoYGI9CX8ktJEQ0hcMYzRJEYR6Z hycL87241SSCioFA1xsRdJ0kS/joC0p37VCmy+2qFXTuvRaeIkGRfylWRfSJFrYFRh8yb/ci hJ6H6xsms1HqCetNMrAumFr24/GhaLu0Sk5dv0oiXXpMEUcdSVQKUZCzMDcJMPIvB0Lj7g3G 3HU/IlZliSZwBGNjQgjG4R3LW97+HeKN6xNWxCdE6ZLhw+1c1Sc4gG5b2CsVtxWVb5EagjUz /08LF3aQUi3GeEpaOkPjWNzpAfZyla0KT/9pn0yV1uWWmctzN4qj4gjRKsefzapPsN1VYufn ubgxO7L0bssV8n0+J7Ir5Bt6sIEvAjNxAOUbKzbvY8i6sGNWp8MoO+B+7ZkAHTvZR5h2T3Zo 3e0vbMeqChmvD3IawZBBYR7jOjp8ARbbf4u8pCoMwbEvA83e3VdTT5+9ALV5Q5DE0m2Htg8I bh8RmA02tvizmcH99bQqPNhfGD0WDaVvSwMsE584bwOx/at/DBrNhYTIkbxJZq7LKdpG5W3N QtuG9MgJ9mdhNg+YFgrpKgcWTB7TtmajRl081EyEkB99RgqaV/sOlvQwFuzscj8nnmgjm/Ya As36af27dRFoxhW/5D+zoqWk+p2nVeq3/sYmhSlRf3Z+cxVRPlbv4g5izywEKvoZw8TH1ryj vCKbx80zM2DFEUht9+/hn/DOK4zC/fryKRQemRN3eQib2egEuXDRy5DHMt81oC+m2dlAUX3T levgj6RaCyDs4s4lIGMPMRRK1KcHRM5VAnC45JffXijIzD4vRd9TQg0FlxKYt/pMIFEzAvao Lc2xo8ALrxuKr59/uFJqZzwxRFA+xfDZtyhGR8uhSpSAnt9A8HTBHmAdi5tP/AXv/7/Hb5Ww tiGC9ab7GxbQVVAV2mVvhqn/LRaASnLhDPf5pl0CTKPXrBh33404Pxem4lqdA/eK7sGWvSnW /Y0GGuDr8v9fK06cNZLJkPfMIvgNqESuq65yIEUSpZ9YMQscgxq8oo8zWghXCDMJKb8fAZ4/ ere0w8umFeNdYxsO4rbECwHXBKyZ2a72nNgtYUsi/qzvYxkSfBVaeJXjXoJQLI8EsT9IwMnz hnzwI6q4pmPlHbweH4KvwfKkxIcqJnAglFetT0Etsj0/6aMpm6LOQDGpP7ZhrPV7aLxutmED yGYRjXL7EFDddCKqJQZUzioFdwmX4gm4UZZYHfKdTy8pNhkATkALVebdmn22e8r5CSOv780M 2JsOfTnfSB2SdADWq63dIowdyXppB0PaHiB1frbi2ap3VsZ+tEninJAINq+xCDK/JEnUAyKF zmNpB8QRBEq3mncjl1+CWu/QJjB4Ni87J3R3BB7BWChgKwguiALRjVjcwVULXwEOXAKqGWcx 0ZQ7YBmYhOFuAWGsxESHsW1ldR+Q43CmsUvPpBzdU7vKFtgxioqAyXl02gt5qa05D2SjRvGY YmeMz8tXYZTgzxSesY07QDJ2IFp3uLcGEXPrRtRKkIogRxuFCQl5WBm5dzk8SOaMp7M6LgRc Ss9m8zobRZi12Ht1vzxNWaJ1nfERfq2/1fR4uBkCgqhqtduk1+xl01ogpXaD3Qvg1bg1t8xe QneN1Ta7lWWNFJEGzXJ5xPXocmdVyAUNFJSEh+bzJRPQ7MDTv6yHXWj0WQ3KWQALEA15IsIl LIRa0nvzsHzvrSos4/YYgmlPrjWnc3O/zHVzD8DV3sIv/uBjqIIdLhb/5ak3nDPZlQfWxjp4 Tiah6LWIMoULt51Ko2srG8OJ1a5CrnWSQnUH/qnW6mUk+GJ5HIr5Uo3oW596SgHqUTGHTD9h D9Lcbw9kI0Hjz8qrvBGiLV5AaV8/6NNIx8eZouUXxYrl21s+B+m5Z4dhI+ck78CEhWgk/dOd bw+fPEJJ5mt71fi9RjsXOB7/6uAcK1WGvaK1UHevk4el7V6cUaBEIi/1MdQtzUMwZD+oVGgk NQBvPKifgRw542FX5Hglha/eC0A2utodR2FpoqVzrfzVfa3m9z4jGehE0v8GZOWHBIPlk34C UpSACZUX76lyuR5rGioN0vyLDvnCfUg38OB98BMTdn1dPalVbG59GOu36v7bk+tbodp+jLSv NvcTMgt7GJgtgI/TkSDpe/Z7eO+P9U1sg/hOkFl2Eg5+Dpuctd2KrxXMjKtzgI/N0MQqYBFW te8b0z7HZ0J+mqbrw92FHu6wod5Zh5oJVclw6bTRH+IeFJyR/cPIt+EzsEYRckRBPEP3JPxU /udWw5xbiURH1kERCPT+LC52+dln8LMDDBCCC7OtF9CEDBcT1GoOWdb8Hs90hl4aYZU0KdYw KpsljN8+sruwaSFzOufEoEPmfu0pklglRFlKlHgYZpM83a1O27hIUH8oAImP5AZhLDgJvuq7 Wovj56tdePZEqq0D5lUt/CoYI/f3V/S2NPxhDwIFHxOHeR4GR9rbFaHSZ0kiefYqt4E4NoLD 8ZCH7A50Z5y7ijTKYPIjOHQnc9L+uV40PP0Z7tFWhwccHVA0Om4K26b7l56qZ5TVLzRcNSgv G++WicQVNIGDlajVdKRaXXuodSk6JC/vQn38oK3L7lB/cZ4S1sG/xCQljFY2YwkA2KfDn3dP 242GDVvXuy2fmpA9d/X2wAZgqD5hS+FcCdL/TZ1qLYBPbukYcW4lEzif//FuT0tJ6n9UA30w T3D+Bd6ToUG8y8UBOY328q+rbzJjMiX+aGQzrX6nJghYPJBRhIuRy/DAJz21VQ1178gwKU5H kJzh+wpVgx8JgI8sn66XQU0nCWtRMe20ej7RJHdCyvWVoeLspmpKNn739vuj15lZHSEbW199 IoV7+bt/kaumX1H5SFi3Bh1Yf/3MlSTxt3GPdZaEh4QwDjnWljDvzonUMTOn77/faZCVHKB1 RsiUPzDF6Dh+YXrwbv2ZiuA9RJP+qK1fqSIyFWooEPNQBpauKJWjSvT4TYyBo6Z4+jtfyg4Z OBoQLyfZ2h/rWEZRUuiKzw88WD1qGhEdgb2eZsMCLgiMM4AIDiRqTqRZe0w6zrS/LgHobhm+ VnhfF5QLDhq5p8JjPXnebN8HoYVsATkiiSfdGRT1Ooxxp8LeC3mifQI8ebvWDlhOErivXdo/ fR0f4HXkRB57opxbPxvLA6aSXvVV/y/ikixEitJDcsvm2Z54mfSy/DYtsA+kn1tckL41HPI7 GtyRSaW2y1hZmh7hOv41xzh3G3+4LJgJyyjj+Bd97kXHUlD5Ket2Bm5W1oyoKWtyuPI19oFb I3zJOzCYgrumNEqPUEmWZaGrX8JBfcAhU13xenFcxzYhowAZty+6bR2YCmpxBTXbeVsYzKt/ wWEclOFjoI9vYOJO6bfc32mrcJ4G8TrJJnGOoRE4cNV3vaky3Ip9+lBd8gI1ui/9hROGqQ7s 6T35O+jITKZOxOhUtQ0r2IEiYljcpIci1M7oiH7eO5B61ReioDsY9ikdEYqQCioNVUHqESUK xgtDeUU2+VoKRQLl4i07SKIWAVrpoouldoy3B1BCpIbN6Hnr8HOe9dizc0bM4GgZQzoiGIN2 Cv/ba8QEEEtxsRUyfcHhK3oWA20EKUEum5cKUvY6sgkNkeJ+To16ZeQOIDzrZTSRPa2JWcIZ 1rlMMKm26RMQM4sV7o7/eqLydiUlyYRjiSGKHiWJzjgIbM7s5MBrydrm2gat+mdFUXIuZnnZ xXue4P3RPUW9w+fAt2WKQaIXUjOnzRw5H1AoFolIqQR8uIBZhotjzpKiTVp1Sqp8GI//JJtU Ku/9r1GSyg1sbwac0J94GpMINRDab/BisOtQJlEItNxXfO3EarzY6MNb37htwJzxemZmfgM5 Kqv9j9G3fa3dA8nMaDQwaInO0LhB86QpIXdqoTOVfaoqdcu5J1boarIl64zQDiKp78C7Bhgq V0yZD7PDeOqbaoiukSIP1cAELVcpnWhq9pJc6+9iaQEZ67WCWFJcfdSqKCZI185dXe7I9KMx D+85yksYpG0Ooh5iGduqzKfuqXx2sOjlvxhA0u7ldd++s8OH60OY9R0jT3IzX6nEAuvLuLoS etHUAJAd+2JBX0k4E/TRT/BnirwxJNzimxcGt4VZHaUNnJPoWAfVpiBuJs/LdAyiFjiKu7Gi tVsinq824SM/3F+ZrHtDmEnQMlSYt5v4vpuHrpuplkTh5L1A7W0EZ1zAeGR37Fo7Vv5oDXKz tHyDCHf2QrjY9WeTCuC5CTqEgcgDN2ofI1rk0TcKKbelMZ041D8qtNfa+8L1DLTuctrMz4iW nmMCSbinUqxsBWpnCwRuqH3k1XAUcKZLGZzOh8yF4vhIthIiw1pKMC/YsCnRiKVpa7+XEnC9 97wV/Y3XjMeK+rW3Jl54EWCFvO3rJlxay69ric90F+sQeVN324UN+15MjUMjfJHNbkLy7By7 QdfPW8nsVa7tjjl9NEm0S45r9u3ZVDFs0Ylcd6ZQHaYsvCVtOY+zOfagg1+KSVzLWNGt8B1t 5E3Xs6u6V1tDsIo6P4iltJ1mE+BStBSyznEI8lkCsC03KOvL34/VS8xNM6dj/dnRaQbZM1Z7 1YTu0aSN5vZa1xdtKUzaOrJagyAHGW/Ps4HSe+6b0xnptL6zYgK4MvXkHxCfbK+gLLcBUlxD r4TqTCLoGlkcU6oiUrrBX67Lp0CcHHYOJFQd9NX5PnUcAE+BuWmqRUznL7fEcdq3k5ml7f7C GJf9YQhK870xPJQ350tjOCZ/1DOvH4Myq9lFAzLLHhLNr61LJd7boNOJVt4IY8z46Nr+4lsL hOcHZ1SMkS/3hI0vV7hBXzSvT4cL2+Z67+pUvrkEeDsx4Jyxe//oREBhnQLA8TRmlpqd5I5P TRTaw+Q9ylZDTZ3lLhq/Q104rcRPkfDvYl0WqZKAVKm6uIjC9a42rlNegW8dktEIJWsVkKir e03fjuingNOljXcoP5mldLxVWnyEkKUNK5QFjQEekWOnZF4vWKhz9o1AF3SzDcxvFAsMMAPX SSmzwsx1RF80v+v5LTvsCdkDpXIn2wpXH6H6tC6gcdiECdFumntZ0kRXpeeD5hv2ukbDlDsx uP07+TSUyGt5Z/U+7m8RhoPWIk2TIq2t5dHBrDkDZifM7w8MdxpcK42SBRyThocVZzvQ3ecy 4YhyXRyZ+s/yLMigCKQv967RJVBd8TCWgh89/EKf7O9+CQl3s35uKEIaa60A5CVzJv+P72i1 nExzgcAY9TR0WwAqe3iQzkpcbjjaCzEr3EL/RH/hCKelbqiL+cKUNee2RW/zUAZM6GBXItvt ogqa8YDfBlgU3OhQoSmesaRUMXJO1dhcgxpyP4IVAPR2TrVzMzO1YFRzr3118vdhd7Hfw9CZ De5QbL6STuuqZy20U51PBMJGPEW7AA1I4TVRnirIIjQW/cc7GJmXje9P96pdBGswtbV/b2VL np5QvnEw2ZDaWjyay7ivRp+EbmtqpuH8PfwBf+kmxvvvoYuvhkGdYAqMQdag009vel3Y2pqZ 4q+REqBqKepcRiIjdx1Qglwyq/IIMD7btSY7dVjoepHLI9+bi/DjaDeCrH5CZ8U8iIkFHpiC nxirUmiOPy5K0Ez8eNzdAqFhhc9YOLZrmB6s/mCXr21KW88B7SK1BffHmpWabw767PbmuunZ pGxEQEaGFHeEavUmYNrxfxlSpHE0DKrb6KmPZNuEhT4XlcnVsAK1Pvyd04SUWdr4s0jdnNPu uRkZpl34XGddosCRatDVESL90tlDtFM00xoF25JCP+O5B76Y3fEeMwsty9K/hPIWp+DZJxz7 1wuFAsQgsNYlklD3nap8FeP749uBHqBj2H1n7p2S3T3ipbfN4HndhSRwdTL3F08+VePUMmcc byM2VZrjd5s2FdPoN2UuodTOX8DsUSH8fAoODScdylUKq+hSSePdPQtg4O9Ag4chYgMdLwYi tZmk2q9FOd0WxRidXcU6saW5AAzRXVmZdRFScVpo415QRrlar/fGkbsYos+e29wDHhXCKH+2 hUdsuwfRH5Do8oXEfW9Y7vy/N8aqiSqTyF57aMswz6on5OLsE0G1Xab081D5gvr6nVaUJ6rc 9UKZklSq/fAyz0rmHedPXCVIHcwBl5jDXZxmujwELuwtu0P/g/RF0+HrZgT82VNNfEdYUnq2 7SIkoKcj9iwW4VkUTYa/gETyRE7/mWNMvCOV8y3ZIN0wMy25H8Bpf279CVssWdFukYQXvDAN 0jUhlt19D5HLOeahSPn/lZNAvdL3ITu0mqsUrP+9PMjpThC/7xzGosn2SEt2UdGQttosglHp 37jXfJftAubhaCySd3w7Of7M1bJQynd97gBzMEIC5okXiDS4Il+VeCpvhnoq9H3Ksdvq8YpQ IOzw7Hs1z8HF7VNRhqgMXdmZHcLvSWvTi09FBHf7Lrd8C8tGsJtv61rpBPzhxtOoImTYbitj Qoodc4pgZlzCZrjo/V1qtjS0KYFeL9iq7iNQYLg/OKupPKCNDuZCel+zAxnkqYUdyhBe4LJZ 5EnlDm+LJCoU8Oyki7H7DTB4vJXhOtmKU/kdAIOlvqFZpuDmp9SdgIjV49Vr0yhtR4AkPW42 SbWaeeKM7ptH1L0xVryVAY6GCANZdhSM7RzR0ikW2WdqPpdaVjxI//8hcq7ns1M19ZKeRMr4 1XKpGXRLNAj+NBv+dSQ1CXKHzGomVOj4h4RRs5GddhnhRGueDcGDrKLL0IP5mR7OXYw1g61M FEyNcymSfFuZ7Fi/qFAz0x3lZqOAwIx0f4HN8s/dRyzgkCHsKy7BzAtRefTpcoppWKAohaHn zZ1+5MJsI05XKGcnk+jtseity8qiMZCbGgGrfb5k0hePwj4JXpW1YAqYE25ECDplF6MM44yD qCOQod7J0vXmcK2zq/fFts4B8wekTMQD6mS4aFy/eMy46r5B7ubaNefHjKz8swiwS7O0r8K6 epypz2Hid6Vp1QTgDEPvawEmfgnk6yvSgl8MTZg3jHzH+cl/suyy8ATDUupNb+k9Zq1RcbX1 Ngemqr613PYekmOqubxm0lc/g71OOrdUlxnBp9D6cs5SNFODwOrKdvsT9s2wJdkpcO4DflvS 7/roUrQEhhfenTP61qgqB33GR9Zi5MrIqwl4qYyYpf2Ejs2ck3gYFChaYC5U7uBdLlttRXVR 0udF3HAplhgmB/y6f9a6+vOCppf/SUh5jaT39bFYmdmuvSkHA765jcmquP3A7sGPutCD6yw/ R3Ep395zjr5s50+fN58dJ54JZoQHgop8ouRRkBqcT+kk7MtUzxpPxwMXJ2vcn/x6c2YPGLCh xxyUQhKOn2Yih5VUnADWbq8rA+LS087aNht23Du4TCMnoO5aYHqy6gBsT5aPoQPR6mjeozPg V5OKJ3Ji6Px1h0u7fhgL73Jbh6yAgbvQkuR3mDKMqvAt/gJtWaUbRQcfRSUVVpW7qoWDtdxj bPW3C8rHJDIlynI9wO8u1wkd6IiIfPenBvMKYKT2Kp31UHoIiAXsPUvoL2O3tBTgej5al7VJ CiFoZL5FDWFPDrwYPfMVzriMePgPqfoWNLRwG38Vh0We7JmHhg/f66px7kXS5CRsUmzr++aa TgjITeTRkHQXy8WDGySbC3wQIPYsgP+XjPVs3DXVJu6tdLenVyG3Ya9P3IkQ40iUE9SpZphk VuZudF8+iQRXsTF6NWBGXWBmwIEhOA1nNnQlt3I8NCYczAUg68InYwQZDSmp4p2SMeKea4Ao JGXHygiijnr7P1Kh33MkLPTyKIex6nWwGZbti264RSfeieLP9m6oVICPNlYY0MAFJf2I7Nfh emCco/xkchGMI3W8cq0ZZvJ3j1/MHq/bdwZaiXoxsOIAgIea16au0LTxiblRy8uPJbyW5A3P VgcrOPpuE0iKzB8W0sZ/zVYuuX9R8NT9hDv57ba7mbJ+cjhzTNdf5Jt4yyzhzfCRZZQDy1Mv OLI06us+cHkf40p6uZTBikVgwRhHDPkNv2OCkQCQDsHgSFsIafbJsfdRg08Xrt6hgMXKs/4i WlBrMAnzxEjz8krxBgUP3MhuZtg5Wc2WUL8ORfWD9d8l5y03YLuFYFk9U5bhcXxwgjYhSiL6 yMgTkCrsc9AlT2pIp8ao0UigikuqwURsaWeMlFymJ0Qj55Yra1zvVd9BpeYOFLmv8Qu/Fzng Fcm+tZoPNFnx5T2uzW4CzvN+G03LPZlJFFBDiDnWJ34li2vM8DfEVrr5wt5Mh6KS2OLBq3k0 jzEZ8x7lrAXlCoT49C523eJOC7j35Gar1PaBmi5FbMa5OJYcZiJa+m9Sahiz6RZaYqEMHeXj uG3oDEuunTNQAHW+ElgAdN5qfWarP39p/Pfe5d+ZCRn+t4x8hoTl/cTSC66OL3Ga1ww9yX+A +GDhBHE8sQSyrLEQRW6abS1Mt9Wm43wiX+35IG6Hh+sUIzkZePXNfxenaRiwHqjgVTIGODB/ qcav03yBxFj5xkgMToFAU4JXzjfImjjw/twPIVH62CqTA/8SwhPMGvWfpkN95PESAInccBxD KLvnQCj12MR02oolLQne+OPuZasT/jfV52mKm34SPPlyF4iDuiDWnwOzgSQmJtOhzrIYx7/S kSrKKpdeuIkbPuOChpZWNvsQAo+QuHnZ6jsW50qvhBaRccV+5wDmNTvnD1IVfw5fmbF4+cCX UOJuB6IM+Nkk3yTywyn6hLPhZT4tKeJ22OL/QUBPVs5zxHEnFSQpKV5e6F4jbrx/vVhd934B 1d94o2x5JgIMaiBT++K7EUTTBUFkDiMD23WnhN9ZZb310uC5LGtZwzvKeBFe/olmDv6c1mm0 UNYUMT6Iu8G23zK96ZldyELMZBdIuRk1ImEHHa43XAeJee6/GTtWAl8A8Kc5b8yEPXHOo1B8 Imhpeh/czATQKB2hRj4/WS4WxwPoDZMoZRLz0yO8FZt1m6R5Oguoc4wNXzfifb4HJ/aGHgrU rNOaYc+ee6oglYfhDTEZZ6Lv5xf7kIggH4lIRlbL9CAof+uBsRaQTD4BN5DGUh3wEUsh6eio vOSb1bXUDgwB7pbVpCTsD48doGt67y2Pm7L8TuOBn5rvowqaEY8mKcw2nFRymNkr4mvQi9oW ++on2qAlUxmInLSlXCRVEkacl2xXGFO4TWiIMb+aLfn3Rel94jAguZWWTFcSI/oV5Q1e8Ib5 iz8mE/u8rmFisgpthcZ/UoYdmvKJWsFhAYGFnZO0BwGcnbx1/nkFVjltLR5yQ1mgBlt3/+Ym FiHAm3B89vKtaDMDhbGJRQYAtH9z+y9QUxLVwNHykB6DqMXvqTkIuSH2BTZdeqNJ/mSmnQ4e CTK8F0cEPNJd1qpfbwbye/MUqhCaYVjNuZ5DnMK356pFS1VopBw5oyIcrjbattvCtROECne7 WiH9Rj6+oS6azRtBZsK3W/9N443YGsAK2PG8p20htzDSKeSvVpuM9K98xfJYRUOOFotio/1t 1MwH1E3G07YFAwJwoHo8SBwL6wyQXiSpvtvNKSbxjA8BwVppvZt1zT0SDfi230Mgcb2/79Xn zbdkK1rR7cleJhyMYoiGgSJV53yQ/gnsqBaoSdZ+s80TLnICJcsMFdw0i3IX/1z9fw0TAE3c eP0vJpt9VmON9UyKeiV2NziY7xmd86BZNeDC6yMYft8uKKmFrMLUWI0kTYqaM6QwSORM1Yv2 HDy9cCbx7FE4rV6yZX1ZYMIOUTp8NaTJRUMadFl9L4Smf3kDikCFiMdEnV4x4Fcxc9bmrtle palqFhagYOOOG2OBcLI9pWTTs4wVxnFQsZj3LaE7eU585O+cFTTLi3Fu1eMwjPQ90Mnmfvu2 T07iIyD36Tl4SwWWmWPZ3JE3pt6GVfcpiZkW2x+RwAkrGeBbDLyfeplV7+ma7DTHTj6ezhGO yiswVYJWuU5SH25d589lhTxcDI9NBrpmb4CXWXRX94ts/jvq+jNZbUZ4holKIYELbBVwI70l qXxT7kraVeeVQAvTitPXb7UmAeHtVfxUvSBAt+QH0IxgKtWvjEiT530Xd8r9KF3pcXOPQk6v XQ53ws77Zof3pSEBDbBhrVFsxoRTvd34i/7R0XF838AioyWGpXIfAXQ2f9bnkSMHTX+q9sM4 vietIiqjPlIwgWIID8mc8/ytxZT98mp7SpVqyKjGYj+9VTrlH9n2SdcRnKFpnbT6EjpoPDdu ZBV/sjI+3jDZuwzaaVnK0cFBRC5CT1YqLTAtAhEIucJbCnBE6WRo/ITl7Tvzlq7Zoxbuj34Y UhHzrmyXm48T8qeAZsOrWi70jOI6SKh0k2m9fMq1Gv9Mf8uZpP63VM8Exg4kexr6FmjvH540 eCuY5Ll3PHV8z4jrpicDofGKlHNY4YYOs+jO+3K0P0Wm+Oo8XoXRxUM3crSikNQFZqA1uImZ SR/6hPTMuamHpMAU1bkVR3N4Hp9+8CC8dZWOg7NozIODWXGfdbOehI0YWyzmuYVhFfmNixQL 6QF5v0qOnHi5wgHCImkrjqnL/B5KZMuH3o1K7XP95FOukfIrjJfBTA6KrbEuTa/2Vqgpg5To yEKTRh1jchDb9FW+wx+pHozw4ABfTxDK9AJ9exvW7q7wmHgPUmZzjzeiNmZXwZ+Te2tLTTv/ r8Kwc5HY0kgqFRBqGeUk3SYnGoxUChU9Gf9+nHvHdRsT6YciesbwdSxTFyz9GDICxKF1Xk99 RI0xmCcnYSBnUOCdkhBtqW4jaPrJC5RX9BJ4QvaZGvqlVH5dlgJ/fqEtvUgsl3yUp6PuM/78 vvzFiKdD196p8MJSvSAq9khlqCbG9BLbnWvRkIHYCI+Y+vrZxScGPttxYMOP4MHJXkivkOWW RHSjWhI5j1Dnfcr9g9MUcvB2QYEVNah68BKoaTHHAZyQhLJjdUp0Sqi5jqwy2Wn1tYBlLZSQ 0+DI6AEQ3yxrYDjLIpooF1R+euY0fXOblTF+cD7bwM10Wc0P9lFr9bLp5tlz70szrKEKTogY hgCzlEv6dNJlXgSJSbQOLXfNd8xl+K81ecnyTG1kD9W9eKPJRUyBDrSy7RLZ7QnHY8U+6Nyy QR5UUAB0Jud6XPgWdqTCR16hIY+Vmb5IacrdT0jejPSxj4GkOzQHSkl+B4Z7xdR/attVE4ZG nm+TfZo/UfhxdiPkAotYD8ymDgI5wVb2cRHZUFvYQJRJgMzh8AUlkYMJedhhBXOC8GLpcOgW FZRFWEma+SB5Ig+/RDIhy/bAF6whkw89pBB6i4Hu65anS1hzH0ZECjRAQGqQ6AnW3q2JWJy+ CEPELJ6SljwlqUekDezhbSC63qtyv99H808aAt2+Q3wWdxdeA4wY63+Qv4NhZUX5CRwKvoJ1 5qgntQS0qxdCJNQYmpsgdxzNyAw59fhqXhgFUb2hyccjDSleK2O4Qb6f8fN80IkUiyuVAMUI 29YE+L+RfcMZ4QnyEoFjx0XteyHTsPonxdmq+dtZhlh2QPSp+h1gt+DxB6rg24Nr/4Ud/wrs 1Jbc9vPpVUZ6f5QPvp6NgxiNk8Vl510jnhFU2xOuPAn3MvI8I+qSezXcXSyDODmdBeMtY9I1 Fd38CUxewTRoje12DgMnvCJ8QSqmh7y5+jcnhmCcH/PRrj5yc1WJcCI7xOhzJEL3M3sVwWFQ 8wrcgGKeHsCYfmHjVGJ3Od56itDwJ5/fs5RP57SRBmHS9d4XhC/Zf//98Bhg92YQhkjYqPN+ 9190g/XWq0WkcUNXKzsQMqlT4VMh0XpvgE2fXj4iXQtKsP+edg6VkQDjEi1msSHuITdWWrjm AZY8BS713crB2YEINe/JdR9FDzmHUrWnsIjeEjmL3LuryBwuEiiJNJVjjdj6nNcTS6hNMDb2 KK6phuY7w66X6LM8+0rfQjUUhfwMnuLxCyV0MBfjvlQ+EFjIweL2vlq+co+gWqCMRUsiKn/q Bzeb+HwDCNU2ThAe2SzyY2pmwh3zUa2qA8PDBfXz6zFeduZxRVAoFzXf2ABrZJKF4gu69yi7 DxTY9LIZs/DJlsQ+E0pkNaEFLNTdwFRIFSZGJWn6nORQzaeJc44eVdYlI+WvcMkblWq2NtDX yYIdPJZZMN2LkCwx7ke29N/fN3snUvcmGIJKp6Um9T1x8wSxxTUHznalI+Gzi67ocWRt50GR XtoLz0jThB/bYnxg4NbxddlgmSaTTu99znVS+EHYsGPRDTBe4OGnPMptumVXdM5Hi0Plp19S 5GgQssi985r36zfHoCac/ERfD6qOWE8C9YIn4OgrQgULD8GrZ/SvzHNPUnXs3o1P3AxqwjcL vURFDc6hyU4hxo2B6f5ILOI+gDSYLXw1ki1Kkp3x3YSK0miJPeVQAJuXfFXd/2MA1rHXVfze Ojq3tANd74yTrWFbqojChLCm0GsnrV/c1RzdgFfrYWtg1njtshN1h7b5JTrqplH5qp2177HB kCpd3FJPShkrhTNjLL5iMgJs3oXzl8OYDjrXwMafa3zcV4FHPdctixDUFOrEYsBIlMAqS4i5 iasOgdfIX/ZoEwe+F5wW2kx6VCAJrIkoJHrawsLsrPhoOGUHXDMR/WKWbukI1C2sHffkjPK9 OC2EJwUT8dQacwKXCAwHeg5Vo4RaEnVYOORlZZg97Y44U02kyaCdQkfMBn1csZvOc0ttf4oI gUaJhxOUClVucgaINjNvDvGMRBzXqeWgHmnvU1wcSCcbaO0nv5K9k8oSBnDuNA7oYxKVIVnz /E9VK5iQC5MNZtB2dbt+qgxaowuwtBKDpgzhwigIQx9/d3HPogYPRj3yiese8GFxOW9pUELn 8hvwQUs4vC7Q5gLA07s/KY9Mf8Kda24rBoCb9K8Gt5ew2DvQ/Op7E1Zdl6C4iSufNWxDhAPJ UaX0KgLN5BTKISPI3/gChRFFMT9AiPyUmaxitAUYIQqLwbASk743vFxfZ/o4AyfnqdtNZmSY AeCodlK4o2qle8BXgNIMjekNqI2byIQ0JvAOiNx5xC409g9DaVsiu4f8IQwQNi5lvaJcL4D/ dEmWqUfQ3FIE3UO2FBA5HCEuhsOxhOhlaj3uDHkxZhNHLHqWGHkNb8y3txIK1cAaOQzX3rsk fT2sHH7mx/F/9VqBIj/sCYLvkZuob0Q+B1ohH63l5hpwywyTrdpJ5VvyAfHfMyzF03990r7g cTSIHCOLsxpgtELhyZ1bu7IoO3U0f6BbaW12eESgFVzh7WiWdNyUSmn0rywglSnJ8+EUmrN2 u3PPbbi028AQIIY8zYZdu9hbQ6XkmGDeOTBpcHYH1VpKgbJOt7N7yExmUARmcoOQLi0HigRH SvF04ue4pUhtjcnqXSoBydMh+UWJMe7nRNZxAYmMKV/PSuF5ycKc5B9dZx/hwCVyCybApLaW j3AuYfPZ/X1lnrz4i3WvXHXn+xsIbPHhA9tbS0e5Uv98nvVtzzSwqbzs5YvyB8+ZUddS70fM rksdKhLtDvBHgReBrjMhnFMUuavwNGrJP2GEK0VqASUQF8Ani2rXeOarSwJH8I9YFCM4wpbi EVQ3RSh6q94RzzBrkjhnU6070/Eg0QxAH9kWDVfmxa1gwfJBPnqB4lGcZmMK8L1fgHh06YS1 Nl0rra4xICY9AHF1k23uGZ7HRZ9UE85LsGerqCIPAo6/OawGTlV00wbeuVbBJxclwi4tTDjr aFqAPNz4GhuJSid+DHJyowXbzbu3Q6qsIxfrwruqt6S8a0DfVFDRAGV288RR8qRSHtTFBXFF 21WtofTtpfNbUZJZy61M5HY8dBDT5QISGuvXZeWg5nAnv18HGF6KXzYsAvWqcYiqiFnLUo0/ 2jS/5Cb3SO1IVygOnyMaJOmHhJUoi0NlJFqhvpN9VsNbNd5pxHDuAXWWwptrHgI2EEQRmeeU Eqp0+qPoWhcbvcQbkco5N0AmxtZRRIaovRkn65hzRIJoTLUAGxSgTbFfnUp01rTPYHzml5to ltDkK7sXUjip9c23zYJfdH2zzuyQ7FHw8g/GE4Jp7wnychKyAUFrvWt1cB/tiHgT/LV3YCNm vailPhjhJScYM/L6zgLXbeEiSdAsc+f6YYF30YeFG8YICRsrJpSwXzQhQklSybkRw/irc6HA KvpRjz5BqSgJscDBOg7Vip7g5AZvp9zj1B6RN/WUk9HCpRexeQmn47mmD97e2YklPA+nuUYd UHyztaWfsLZY4go2cXHSIfjhIWFE04jAUD1GjGmPeuMP1QBiK3FA/3np0WE+/dDvtbgN6And otvPiRdo/D3EcP/PIILmIyOiV6OGXzI/DVJ/hthfz/Efl6ya7+9YnxTo1fcRLAQtx+AR08vb 9lCKQpkRi591pMTsMliHJ7bOFJoh/E+1a7cYsQwxIB4lIbSkFkRQPEDZUt9zwBOcBhtZXyeT 5jPMJCvHPepugG0uKx48EqWNbyAAqkGSL/gNTZV99qPiWGWWsBY0+MYUtoiRzmB7JSTXFDoc 2FtAOiygVkTNSjYePRMXgOEXUp/vKUyuUOgvQ1WO5tPdnVSgnykxfO4cxJdJolgxM9Zrro/H wbYhcUCSEWDxvlCe3SOozbCxzrR5y4P3gk/aSU3KomLOr6UDaq+C1QaqX9nhXUReP9tgKsOF u/aEBff/Tcbwhuy2ArQoSbEM9ACo2X2Zq+kltYPWTyXaP8NezxrBp0Jv7kVLFBbF0uOe7nD9 NfO3Hr1ApszmBERjM3R2tRfieAKnHAIKijTnsTWu7L1ti7IC/7NqJXk4K1A2ef/XWw6aPLxa hY1ziAZHfibW4Q0kron2/sPU/Wjs3Wofh+Ia36mLPeamYyNPhp2/wQvmCOxDh+iAULbQotAr XU+f9ny0CXE7BUpmUl7ynwwkFSpBeJPVybnFW2B3F6rN6P2DmfiEhcMfICf58Jy8SUcxZ0m2 mR7T8Uyci6sW7douUMHR9Tc57nQ/aBCLHw9xR0h9533w0cB648VCCjP9ISDfZ0PJNbYiVYIQ I1iTXQOejWQu7+7vHaclj1g7HdJU5s6OpgtF9Ld8dqdNScMkye3eixCf91XFMin5nbT5HJiQ s6YKQUmyjHWQfooD2JmEmkcnC1iZTlUf8V7hn+jMq7pmol7V6F0mk/Gp0dgxmbXtlVJkz6/t s7awg++NgaWQF7OqlfFKXtFLxbDqZbFQFcfKeLDLiTQnLPfzXuIZfX9BA1NrMh3Rw3TkpLA2 CuLyaKfkGCqRjLqXBvsxcySb8NpOP70h3QfNt4zPnrjPraCLOSsSvt6/s+4uiPzIuT5ydYm8 FUegXAiCB5g29vxg3pbDEE8I9+560pcFzj50YdOh4kLqz5NNxaHbLqPDeCIxQ0AmUkRAIvbd lLD8uEuqxHCbyspmNwGFiFk4hPzsu2v7Zw7s4dyWW24fOn7u8awn5lixyk7OPRkS/Y7nqNPq rK9QYB8IOQg4/4xBR6xSgDrLvmTKrtYF88P1DslMQRWvn6rA+Qc2mcemGYKj2t9H8I9ANx6R vwSw27nC4xiRbkAVuwS13yIyWsqpB4vddP551PQyAn2/mch4qU+Lcka3L8f9B7EuFE0Bj0Mq 8tdi74GuFwMQ4pbPqg5yuN1PxQoic/C2TvkmaiRUjeDZNp2Qf6P8dx43X1f11L90yNGQwgmV Iu9VVMsR6McO7SVaIPVFjHoQhIc7Yicx4pGlxsmS//XR0hsFl6Qso5MKdNR6KyXnogLMKcB8 k9xWN1mXRMFqL+9WnXvkon5xkNsIELW5z/ZAST2FuYPusMxBP9UlXAN0ACWmjKy7iXrWBeQ4 OT83vC0uKaOBdzRm6sf6uK70e70WrFGzJVxqu7bnLZz+2+LmghvgSdMPKG07mwvs71sQxf0K Hxh8HTEGvr1IvBhZ/pckOOcmbmx2/g5QSgk1fIhvLdxNCZvCuaxmUFfrTzPcz+69RVCTGf2G NyrBzKaG7lKhDHBqQ4Wy8CdO4v4aJVpd5t0eDWxQ+EiGTddk6l7FuC+l94VX+4o8p4ltjeBR JE2wK6ZO9+S6+aMhqc0chN5v4blJYqTw+XFp4fOkAC6moIq98Agx9iomufilBo1exBwFLXyw J4yHJLYOMI7fUmDahZCSDrHE/U4cxG/HuXgzNov1XVW+PiSjlvMQI5OvuzsxwLen0Zeb78gU vgtxrywO8RBoBDxpz0QmwCwMMiAczxyYZ4B9//BADqHrAmDuvL4QW1Vb5yFlM9TTClw+/M28 +QPGzIEC4IHJKcKbBImYrLJDFaGvHjMA00VSnxOgnWbmUD9RUQADqsSh01xUqRygUYRaUGwg cPXliz22pU+HvVR5jw5ktZZ5rf3Su8b5aOMNw4C+3LTGaIs6UaDk5eYyEYCeKg1Spk5Pa2s7 GapVyH8Y+VpIrEsgEQ58Wg4bKFA1hgS+/wiRnEvaJ3AKVCKnwYYncgErEiHfkGYXRM7/FrJV lvAwIuDnch10w+Xidru1DQzCxMeC7gJkYNxZ7CZnsZYCVy3xyMFLlrUzeFa/eTTDTXTDeo/V dHabRwHsKB+4ziQqsSiKimCNZ37ebr7GZWo61Fl+uHegEfPHE+e6xIf5mZeEVXKKP1RijwQn 8Vr+q7YdwgGUJRwkspKi9hmh1svoc+uZu+9O9OiDDWhAjqzxg+I5vAFQM5rBkJrsJqI8MGTI 3oq9zedoIuUtAbDQOzStlrrlY693fOM0vZ7U/Uf+fYiftyvd9Xeb043pIx8b03r+859ySoBN K4WoifAvFHFs69fMY7UCB+qWuWDUfqlduf4Msp/4Uhn+ut8tYrXL/saprU0L8rgSKq01/s/u pu7kTQmL8qs4wKMt2Ncfd7xcZgXsxe6p3b4J00BT/Hm2+J0HTwNkV7WBCEIIBT3X5sXVVkKE dh/B29djvjEK2AuWOlMRjkThEl8dRNfslweBScj+FA3n6AqWzYW/td5gQvYcyqg4IWzDy4fo WzCy8FwIPllXBH3Ioe+uAIdgY2BDEez1RZ+JzupfcXJWsXoIDfrc0jd1c46QMxRAzPoCFcNT uMK+n/LtLWIw1kBjFAibLX4AQw3+MmtO+DJ/A5gqQm1SqX9j5T+2Lw4L80yER0BJYpoibONS WAdXnh+ESiuEhiSzjsrbBYOcJtTObLAYoE4qcVto/C5zcpcwPdgPAE9utozYcnQSWiEPZVpX 2vSSUoobFYA01TSihiMK9MNK13ouyatX9tdX++5oIfH6zNhdGKshJteudOKnUuFF4NSMcHZm 79bdh1WsOBXkAiiglxqG3wHYEMYLs6vWIGa33Ib8s/DcqpNbL/vEq11YpPHzhoUer0N+6WWL jDAZw2gehSZf+Z74zYBWjjqyd5vowkuViB1/1CLVj/TkmUBlWFKTdM2i+3R9JCLS5ogUYLsl MrPghhw0jWjZ3nWRdLKfr3CM/21mhj56WDm9+8AByZvjKw9+Mw+lCYZVe69SQNLxdzvDoVbX RDhZ0UiJ6IoVurQX+03xoRE/fGCOkRI0u0783NooPw4WEnP16lLl2xRC9h1wLUdt+1dCJJF+ gAEnye+quJPmGEM6uKEzDWcf9erlllS6ib79Op2xIkbw/sD7JDsI+sDhAHYPt5u4VT6lVw8M 3wOvIaRW+Wfe2zciswXuIdAbzMGR99nkNhbf3aZE1OYPM/26qUFIQmRm3j2Y3WFxoO61pvZL yNaAj23P9eAJrDHYJ/zHuJ8M3qsuTQcJdzJdfHaZXf7gAg2DlosARpcMlwAc6WL1VpuvG5jI y1q6icFrnZboR89vIkaq3jETdnqZ11PZ2eLJ93ovoF/fvcoudSaYWM/qFblTf0aC6RdL2OhX VJ8QL1/At2KZhHF2p+of7VdeEHpZAsaqdxHDhZxnWyFgo+j3fjxkGN24MWprrJnkQa27ZZvK Duh0bnFQxwHAoHfxpRvYhqdTM45jpEFqqTUCSxTw5b2GTsfNz2TZ/LlRdZmY3cJmX5X07jO+ 6nvJ/01GwnTlDQYyJUN/2MsOVvezxnGylkR0NRlFQeE/AWbBfvP1S5yJgF952V9hS405SgG+ QZrA+B6MunqckH0GzibdVRyFfRNzrMj4rywskb44jqX8XzW648PQLfixri//x0bm2n6DSA7Z x6u7xs1GHHM3J2O6WfiLLjP5HvS+mv/cKZS1Ri2UI+6xciLBxEWAmNs4J89fxxg0ESnXB5HM yo/F4WX94ffHJYXofRwAkMhfFashAwyRBs402LdYtHqIPMM85A7zaJka/su4TQ8VirIu7NOY fP8s+gFnWMJ/VbYMoewI8oFxz+1OiXUjTFz0f7wJCFDqZBJhuc3HWGpeFx1T+gSUPTPAEvTV wtpj7z96MWlyLQX/vCq9bfRFyMoArc0EFC/LtEUA8Y/zqaMkm3/kg2QmFyuRCYUPOVd9sE77 AUaYDuw5QBQBORc7JqwEIgJu5ihAW4q2pIcU3GdjQlZnoLJ6l47Ea6dLs3M1R0BJ6rEQj7+L iULATfRbroiGemECkEOVatcybz9bLKIQL5YzGRLKV7NwfuGLRcLAYtx4bAOmHbINUoYprDhl 88huNeOlCy2RXC0NAFyEno2ryYWGWpCjEkP5zSDrde09uXmnlcDY4uV4AL5Pym2gF+yq0zRt WGQwwFejP52Jc7xKU0RFSWP6gSV5lMfi4RuzDC24wJi3NaC/NAkVnPlNO47T0Dcm/1k5a7TL 3yJIPNwRmtHFELCERwlqOB+V9I46cvBBOPzL76fn6a30espc2PBr5F+T40tgbqdUYLa9we6W q2FbjQTQzbyp1Yb+KMLUveEmd1R+ygyF1gnz1QRCFnkaV5qGpAIU6J293ardCj3mj9civJqH VGJ9QG3oGcKS83r8afIYPI7qp3Zv+ycPvMzDuL2ydYtxaBTbS9gEanT7SsWO61vDG4CYsio+ /yR2lEKvJizeZTYY72vGyOXIlcySYorKPtsONaeDsKiQCuT/KZU62cXpUEEsWfVm0D73ZJ1U k4TT3HNBWV85akVe3sDo9byj3ztmbB+yaWjzdy1p03zf/8uzn/T4KF9PTd487MJhk2Z2ezzl 5xhgNH9udqZvberZcVDCiKgtdwAdOKSL4sozPo4dE+B1zSk5tbcbD0kTUag6Y4tJokTdLn39 qqfoN5+dtwTb1c149GWOZIYB0kxbIf5G65BGjD6K/d/kAFM1rmzNyCm2iyov05yGdVeGt45b h6uXshXiGtNG10UFvj+Wo03LmNI54aegEWU1FT2P3ZrGpBiWUcfzDN+qPEdp9doXZzjhdBNf I2yOKWfuUDS9am68ZctfccjmDIufgLE9OtOBurHI0cvKRFJyzInQtQth1N3MjbmF4rOzA+7Y kplzez5SsHjP80E08HUfw+SGt26eTtVolcS8CK8DwGT+7cuSLEw4y0nfWL1uQwIzR4JLaXHm j3AdQv3bJN6YQeDhoTeOh/Ju8UOWQPALKhQGOB5zWFj2avqEcuJ//Ukmyg3MmgPKk6zv1GmJ 3VEi8FCx1nTEgcDEBkQxuCnrowWeZXvObd718qeEY/4CM/MKUeDsowTWECM4UjCbdYlLaso/ ZnmVKWurgSTkicxiotRcms6FUwFnmT5cbJwRfzOKYMI9SFh5l3fWAaxhHcD+n2c0KW/ZLNWW C5+fRN6SAFmPDF+USj0NmrZr1dvSPJknigPcpVRdNXsR3jEFKGYX5J7YjAe9NmMVTbh3HgCp /c+itPsnxnsxDM9GKmw0wE+d+lcNrZ+xmhBd8qzdGDj5GmUSkmb7FRmb/Ty2biy3CIugYVvq yse6o5+v0rdTQAIMvFDmZKroP1+tmL1xspM8IJzKBVzNmXdcuXJgJ+CHYPW49kQusu9iCrQC NUlEE4undN7e1e+/2y5HKist/KHh5MrVc+eU/8D77zm/dnvHkpY0dh00K6OXCsysT8WabqCz fYj1KFf/VXp4vVxaVtTJ5rhzeyPX8jO+rVQp4EEFkAgty8auAE9JBxkGWqzq52qzhPApyAZP mOaOb1IIC1V4PrYXEx2kwZgtcBfqK1y+m9PhCizMDT/FGbkADOydPl/Vku/Hxv53boJn18xa 3NzBWl0Ww6c/cS0BPH/acNFuEhhxcM6fHtQGwmnjrmsY3CZ8oG0/0PrI60FfUde6ZNpYRf3T J4jCaFejJ2/yrORdwmtGlpoMGngK5STDWfRfiIpUN84bAlnAMMVPAfSIumwRqcdBHp3SKwUK gROSqKfogC6Va2Txq0+42wDIiXOvF4R2zyCkjG0CX18K42atdaRhStOPOhzLV0G5WrMijqRh axwMdYSqF9Y7cVGuXFOSR/awnrcvlkpEVX1re3raBiZ0rxydZrNGwX78w7BjfG0EsoQatZ2A OeNWQVyswH7pEYBUO0Mgrww+VtaBkXQ4fI/IP6xJlg1zY1WQORQXS/kGDBupjbosuiBFj12z TZw9T3PI+hrKDwt02cPU19LTrOTZNduuZwP7uNGBJiRkPhma6KsMnBjYHfqokyER23yw/phv 6ZMfligx3w28by8QiCJzJZdRAK4171/z0Nqx3RTgg1qkHF45kd/XKCYTIgW9c55a5nwGWmVi 3O45gEgLDhP/TdQq3eOKB+dGtiIAZnvA0gtEnOJ9jamfaW60osCORIB60jCgmLIj0ep4NVku fUAzSIKR6i6RKDw1x4FpBKBfolHvBV9GXsiNLcOf6FH7RNdNed7FrHhEmtM5tKJhq/oY9Fbf IzPPvYGrBqNUQjprvqI8DHbtj37Ks6eskM1uZNN/u0FXQsM7SkXI2ZRCVJaRkfA9nPzqoHva T/xMaJ6zkESO95NKp+iur2TlMVwDyYUcg7rBPwPzp2MlkpShERE4nZ4QMaEvLV42VOH/FzgH hxK0BYuAv989sAZ256+Zf7Zaenx+mAqj0q9rnfPyZo8FEo8VgDDIV3crAaiN4otC7v5+Kf3l 6GAWGpSVwtPeiJ0H977oRTVDoXektmpMc2SrnjF3n7c/M49QLRCnMGWm0jsE2HOvy0cj7FRH 7lfD1TOlQ7KgfAgHinqm5Ru7zbKHtUfEDaraAt5AL05qoDrrakfKDtfJXqrKvvHE007KPdOl 7v1Rk+KZ8IglMjEqVelSsg3IUjwqAWhk2E9xiYkluRqrU/QpcXCbEe5xyPEnVMovEt34gy8I YSxau9i8IxVOR2I/8IwZ/4KVuPhxpfK8qpzOoqXZPXqc14ktabK6QT/zBLcauHjCCGZd4JMe lTYfGsFUNt0lhBbt5elAR3ypEltNMLOmRyxcZ9B71LqnZcBTnH0KX39+u2NUPD5kAEXo52QC ujYOKnWeATBhVaDHp8XKfRZs6sJSGN5nhKK2DlgzfH35qhsRkQ4FKA9ivvKmVTNqUBaEqeBm 0dMJfltPs52WqVSHPzrinvAgLgT2C9h7BBU6woTK5I7Jhh9/V+yjmVV3ybQ7bFLWt6UHuYKq dr1WBEsDnJTGpexTlOqZNsjdn+u7LeolbRyo1+VN4MOYtvVDyqusUv2YPj5+T6Bi5w2c/xT2 VyAEcOo6sMSpOSo2wQfXR0PejCR6Eejzk1ccRFScaOFLYHibPvAkSjDCFEIe7JUnau2LrT6o mTuYCZyqneuaC90WwoVjH+SGM2rbWVOzJjfzafXjzKEIwh14f0flekll6ppDCwDZ+LoYIZ6Y Lx/tGloT/vhHoAe1AyT3wZ/jm1wb7lBRNZYxsEcJH+2pTg7ZpJ1aacqtVUnX26tH3sllFT/5 JBq4QNthqgWznmBamzIoPqrf87niupwo77BFoTrgsiLI4UdpyhE9yXd8U+5SOUobR301iz/C h5vpEAuNTLrs9h2JcRFahZg1PrFUsRth+SUDBnInAuvzaQgtbtonaskqPVPqkCvunvCZxbfr AER0oOS4zHhzPZqTII7uwgd+w9ulpukKrO65ZPXFNrwcsoxhO2+WEIOybRHwx91jLSuJdXZl To3XG+R9zKlac2rcKiTpMojmKzHSlPg7zE9ZRImjb5TS1AP03D4OoqwFStuiV9WrZhShpx7R ELtZEjIkBDibzuxnbKrR3QE/4FUg0O+3XN/5ATfjWB6uaXChT9ppioyDBg3tHyrkGmqp6jME bl7sR/p74fOFcRlCtCxToEE0TIv7riI6aF+TOnfo3Zhd3Kbpm+Kvp4qzoJjNRcNcYUhxXfxG lFH3RSVZdOJxpW5OdqW4Zzt5FtE1zHAcYDgYPkuywYxX02y9rjd/4SvP40hCB3xCIzQjsVJV vxC1WsyJ6jKu5mna/z/sYA6pucJ/Z13b1XxrFL18pIfj+6h8DLgWwhsVoK8XnVnh00KMaF/L 8Xyltab07Dnx79TcWi9n/um+uWlVs7bjtSDiD05FVmBos6a+AMLrFAZBcw/DQuqD4c3exYAT XqvG/FT6Z8MOpIF6g+fBF5neaU23+OzMArd49fgnl+zYlBxuVNAuauuaLSMm76b34mJjQ9vu ZWumcFuLuMwUMSN1AMFq/YJhDpWpDX97FO+I5PJS5nk5NnvsyzR+TBoS8wx8YM/eQnbSi3A3 Il5NW00TzfmxYcjr5Vm0q/MJC9WT+4ID52R2bo62oUK/MBKQcpQu3LCrzFMxnZPmOqh+hypi pa+cFaDM1UFYRmv6GccQLPgjrd/4oITn2P/o+xpxvr8Ygv08uGQ7tFD6poWBAtskxV9QEeqs TOExtIuyN5hwAXP3f+c4TDX6M7DJY9m19vp7jROry+8SPIKMyKdDVZIBdhCQNV7MAEl8houU CAxB/rSIagxBoJZn3DucL7i3RU8OUKNRUIwE8YrErIZCcblPT0jdSzN1lAm+pS2sip2Nj31P HJ4uYszcGAutqiU/yH0+zRlODP3bKiTX+EBhmTE6tCRbe4oMObIsu0/yBse1HizRgxBxnFe2 LasfZuSHKAwoRyHxq8LRibwLi/Eo+ThMWSnk3TChqOWdkNfhyueZWdD/UOd6SV0yGfw+Rre4 njKpUj3id/Q81Xrok2Xgq4Its8x1gk+g4kbMFIYud31hp2Hq2AqpsAkpsdVfB7ZZHTsUZny3 PEVibJh8oGIVniTsPfKxY/aMDkWOQxnWqfv5OsGSAWckUm/8VaCO54NlbabyL5ADS7JqblgQ m9mHKvcY8LO+H3blbhZTFig9Y4q1yA+MrLFFBpn48dCj6fyfeF2/SksX7OLFijN2mCD17By0 mtDSS81qEzqPEcQosbtcuUHjS0/RNoRKAPhoqBGzZ/H1Ut0XbtqByHuiiM8HJMn9aY1qsrD7 ZvFYCjk3xQHJgcHpNrHXrgK32e2owEGm3iq6HlpoH1oOtuS2pwVfuX//LghkUGaArovEzkpS vim/auwIVula2wRcFUJ6jsuYYWzslB19nmV3YTmr7lo/AHpWJk8G2lBoBX5bk03SKooqwHOh ANKur0G3X7z/2cwdyOKQ6VHD/Z9j5qrCpXzsCNLg/slyeTvAz6al8sI76syLNF2zAR6ttcHx 4nlwdK8J1rL26LKFUy1vQBR0K4W5RNy3TlLGkKF4zYdIyJteHh0/qdxfPJf4p//rknujfFG6 AQHr/b5op+MW9H7mf7aDqoBu6fTpL/Ir/WMcKxhwQMEEZCDdbuYDzGByeKQImIhzrXk+mU6/ HBASyjDVDtI6H1AOm0YiEvFEAVf8iuEuIuKlXN3EEA7L73JFcgDO1SXjRG1dtHtSEfR2u+c9 5nh/EOaULQ7QZsB5yY+tn1qxaI/MRhjW5dw1dPjc43eMorJapE8UnIbCqvXAopEc50tFb6e6 MIbUkksPYRnJ2pYW9OOgTn7ARtcsUX/JCQeST/GBf5fyld3HfyvAsyZi4HhIxovDDOhZwkjJ SFO8L+gTKq4BrnOD5nqBOuariMFsU3nSTGbGzxu62oqJf/v58i2ekfAHvfbZc+AL0CVnw87N DPDEmRxtILSHMy8oDjm1CfApp4TL9wC2t+FTefbwQxX5xHKOVghsaSrMy5j4f5gHh8wVlirY xoo3IWdH6pT0vjn+lXhiJ2vJvy3eTcUhb4MGpucsDRWKmxFzWumBYxlARHe/Ul2zWTd8z5Qv BdzvnKXHC7GBs35j1XmH2LdtVY2N5XYCwOdp9kqUoOg5G+X/xTZYiPLO1DzebkRzIbVCK+RY w1WbTpQSSTGqnUJHAVe8zV2IXKZQ6yEDMvswZXGY8J+jNSTxhnsyJem9EreRw943zwFjfqSR VezcepQJ3ZreBdW4RuO5pG7ACWVblJVg/6dxvDKCWMKoEgi/7nGAs8o3ptVMwYA+tghtgl1i Dnn3t4sN8uPad9J4BCNdc8XUnJuZIe9SLBk631E6i9xGBTJrQZNGEGb9IiXKx694RPwrJ1YH 6NnApr06R8xBgNZd4lMqXzHVS3pE8hdrkruwlZvS2QuIyqhyoCmjKVqM/bfgpJCLhWg41tWl vbFIOL3BH5tib3I8q1aKh0qIB4Lg0i+OPtgxGQiy9Wm1lvDzyoVyjdBl1HDOMC+Utl5GrmKd Vw8aa8dxUoyk8fwLaF7L2poZAsZ75IDDb16L6UptvpvIsKaAU0Dvv153QVEAJvnc6ZFbfeyj v16olKA7mz/6elVcNTONQTGoy6T1aWfM888HWbL1aJvC50xEGI00GgNaTkC/peeeR/JtUvI5 5TpX/So4VNiYPT7Tq4h1/ixxIfmJkJeevQyhiQgGXAQsW/feHmIi7DfOpFnW/fIcIY/es0XO D+o7LT75jQ7DsPJ9aDDeiJP2H4x6jNhYQp5s+gpNx/u9xm7jgTEsKdrm2R2evxPvhjISwC49 0CvA8Ac0qnAJfHPLH39TxiM5ha5ijQM8iauuO5cp9CCoTJ7fwh52ezFO4+suQR41slEzuYx0 BPlmjaW0tPVXQWpPj0eSKgwdqtN2m+jb7kNssG40n9Uj1q38c2okXfyTuXwU3z2t89aff8VN Dy0RdMoJfrCrTKwCl0ROouRRzLDfzFpjxkavDusZZoSaL+O+15+V7QUfxjsfSUcN7m9DseSM 5Wa72yzxY4iRxnstyIwutY7w9AseoRFUjYoJziESXGeYkYBiDBsPINgY3rm5iXHBfRjfE5Wt 5rexRi+4RBMd7XY5gC1d2cPvJyVgwonmGovlXXrP9b0wdo1YUjsym/mv+7J0jsVrGDxGTr8i Yc7Cs7gesw46KCal8x3YSrqNkKPvD1na8/0+cxxpAc1Ff9K+Z7s0hmYU2jySQ/BXVZAE8yDO EyD6ldQu5ivJdyTcXmtPa9yJUl96nDE6BH/vvO88WR+CQ8uwwKw0stFbByIg1TpWGywLbW6O 7EVKOZV7pqilphvI4Dxd/ukeh/IyRM9Wc4HwQvXB7C4j9xM7FGppZdOZ+j4chpA/qU4klr4B obKq3ylO9LAgInvEFDHRUUFDbRI1TRmPxC7TXaZFpXIGggKWFMbomUbIYhJ+GnI4XgRvzwdl KjkMqO2MsLXiyegFOWxlAwEqmW6VTsxiDCGeWvOu7rYNSmILlyu5x5No1W+Z2KA8AwjxWPeX cIU5zY4lh0jfEdCJ48KT2tZBKCY4a12t0499F3jZuv21jE7sghsX89GuLO9GdkLiXFnJ7UeG /T8kDcUje0Nqlv55yTJsHe3VYZ2efbcvd55yGeSBdfaNhAMGJP2Pucx9aPEdMzt7VDXMOceY PphghUJ9jkH9A6U8WkJ3iUw5PvCzVJB0gz5Z+Es9REORv1EmwCjRpxJ4wgo/cEsbSMyLzf/g 4tJnh3V/HgkpkBocX1qW8YjeXN8MygdeWkM7tx+R4e1GJ+vogaQb3jH1t5wc3aHGOk4dfGTW lkzdJ99ZyVr4r/rEE8dg1g3MmShAFU8pPLXWDP/wl50s6axnMOE3L54IKtxbfvlJ89KXOc0c BQmZbL/TdrznZQgIvti0IWM/VBCioe7o7egYeq6VoVIeXaKLjtEOrXoXsYTWq1cZsU/LLNZ5 ApsJ44onj+CmGu2TfncBjo9ic7cqrEbjMrkRuTwQkxW2WOexyDMOwLtHR/4YqoYSb197DhSY u1kq7hR0LIcv+I5YwtUSe3/A9hZBzOLZhgogiCyLKAoenaFegjKOZ7jL5SXJ7KCwQICcHj0B 6Mxk5Xvk7u7J+urMRuD8JgljU6SesutZP008jeoQX01ci2ff03tRi0ZYbzY/U8RCO9Ah6pRr sC1C5kem8AcB84dud4s/epjFm8VB62JdvWziEDPeKKumZFphf8Ns2xPh8UvHaPOReUkscgmu Dp0dUaO1mW5fCur7ylKhbP3jEBJ/r+5OlqptpjUJu8Q+VpUImjKYwohze5wQckCl0hMvzZb4 n5LTUGCnUrQIqDlI6AdUN4Al0Ers0lZDQ35PpX4KzUJG2jYr/WdTo4g+bGkJ1fnurLBXlFS+ XCQIddPzhERdOeLJTbgEg6jHMWE+l6l1kUo67RWd9dOFX0xf34/D/lo4s+wTYffsIUydqLkn htqI+OyqmoblaV/bhFIaKOv+qbpNL5mgIkHQOw2K/LpLebiwnR+a2wbnJ2nUWIKcRJTMhVwY kPR/pVRWS+zFZdGTrMOxw703ESUWt2D5SkN0fIHvpsJNh3KEcNGy6L/Vdy/nWCWLqgeDRkot T8AWRtySC7Wamcn0i1nAT61+iMX1h5zNIh+PoPG2O0istg2oLIlIfqug6AwCjBRNA/HdQgU8 +YlvQ7Dr9zJGZXtytmAALM6C/HFX/cGrBWUjoEHxUx5Pjitps2HufpKHLnXeVoVSHb08mE5z Kpa6NOUheulFPHJQNfcjCx6+ykKyqugdqniB7SbtsrXlZ51naZrN7BsyO8Uz+29yYcf2Eyl3 i6Lu+Do7DNkh0Doxftyf+A4LItl3lHwafaM/1YMPRyzmOuCUTLKI3SanlbTCm4QQ+24yPtYk PqZBQ+Ek3Zceg/cFVReeND7c+8ASWLgiYj1On3cgeeQv8IDeAPslLPo6UEExUDt7IPPGtJya RIiNYaIHT2D9l8i4LIHwEzaTw53vkcxXdYAqN2irM3HVPhqVaW+CDnF/Bt6I2OK6JACvbXx0 AakItbosbwBo1N1sTEhdEsUzqU6/llznQlC/zk8ZKsCKW62anzWAixj+JKiTS7mQlubgJZmb /VXi7G2eLcMRhsxkegezjMfKq9Jmva+W88tDPmShpJDmG3ieWtLulF7RjzV6510J3WOrLe8M TgdHxifGkRF5/zWDC1kuGa0P44Ml60FL+SqKMylq7mFJmGN1SqlXfvgaf2uMKvQUxiFAJ63Z qpeCPHPGM5mkHekn2pzRLBCmfH1+FeblNpwPC58B4aRJSxzT0wnvtMKU/PnY9ZqsqoFHNqB9 /bK7bdOp+eVHeB07g+n41+44kwVE6f1yzmmkqaCSZ0xNgdwYJ82jV8l36dty5cifV9iGMewh QImmpazz9a5DD+SRREXEot4XXgWZd3mf+jgqxRhw5RqzKYc9i675Eg9MZwEqkveB3/XvNf4k aK/uhEvho5Dkyl9lwqfpMySOgl18Ow5d7LfNGVPtkb8vCpP6C1Y7Yw9B6yuj2nm/fcaCmdYl YIFEPhMGQMBGMyPV/aGsQBqQux/45veDjUJMNs38btdFQxvSPoQmkiz+Dx+DFfpjmCRFm4DP a0tXuAJT62aJoZop/epWUtMZZRcGTX5IqfhkBxdVofTsGEV7ezGWQ5JYl6L9mH1dy4ayA47p dcrUKmGPxxKYnhrySQ5EzqvzF/9DhegxRBU0KV2VfM3ZHHIZYhAPnbPfGTg+uy7GJN6eSGOf nJ8wDbddCD3eyjr4VuqJLJuk94fzZYDXxjAuo7WaDu5a8TxPA2d/4f4GDZlmNuNhfBs1x6VX TNfQTWVEhuwuCvno98FC5OEPwQUe7GSevd1ODmQ40FURJZrlOWc1ZZ/KU6Vl3syTn3a2Xaj5 WC/jN/FtEAr14b0yDTdkqZ8IOzZ4hh505RzC2NJ9g7Gjd+7CRm/oFS77hx48WVejs0Uf+zfL 4D7d+rDLion2gBrCUw1/PeLvjSlnQRjfBy5gNpOwssHy9c59mMZXKDt/nJQ/r3jahzk5rW8K OB2/eu/Q4tpvzXPGBCeis49Bq0g5HYQF6hZa7OMTGWHIbNPy2t9PjteQeLmehrWwYbmlNMMG ARrpe94QJcp387uR/x+686fQes8NkBmmUEhOVU92JB+QUie2bv+000yQHmDrKGnZZA2W1JE6 oSvyQe2f7Lubi3FFCJTTFWqrGEVQ9unQfTR53EMM5zlC1v6qmSiqncuwnUHKeRdAxtWEb2nY +y68ZrV/q33VEn4FWfM8cpa7IDnt3l3F+nSw7R9R8wLGwWmnNLoRjSQk9xkrK5iIbN+28z6F wuFodxhjYfEvBzqxVkDJEun+FHFfGUhK3MOD1RfNwiIRaRp1CgI7MKg1duaM40E/59930qNs oBs2lNFMjEi9LrJnVNqqzfefEUhaWxzrH5PIPoNGGBjzCUE6y+/XMzrvr4Am6TcJTnZu+rNa OyglmL2YWFcBLFyD3Vz7gb0pgPwjeCDA7WxtUKoXNmhb2hoWkS/sSJRQW83E+p6vbfhFe70z lhxzk8ffF+fZ29QxJwAS4YWSqVSrqfR6PwHSPmn0uOQ/zlU2p50ZMHVMJtBAZAzRsEMY03zv QS2Lt+sAZ9fRIaZwO0giLOfeUoirgHiz5XmMKfcvqepb03I6DA5pJGjhOtdin1yN46dx3YSU nM52NtQF/PxxMSrUcC8kDhYjKdFd/+AJypngvYczI9IJdzBsSX9otS1D8JD8YeEtiuC+A/zi V54lfQ1r2cIhFdVXKczLzhqGi/7DVKJsrScX+gGC4ao/7VZN/nWxpvSt2jAHv90FqytyJS7B SnedQr+AByg2jBBLf5BFtBWr47yOPfCtDxtaNPlp/z670cN8s0bL9QvUdHi4O8kqi3y5Zb5b aP1eqrL1ECubIX8ZwWkfObk4Tu/ip8nhSJIF9kXDPvo/gJ/Sthrw65Ub1PYmRpWejpy4B4/H ABtNWoeJxhL7fSd5TkZDLzODD5JdHC0pG0OmCnFX7RAzWx1Ufrmh6FLM0KKx15jDhhnWNcYv 7VtcTU09ABvGzRnULlS1wtGfQiSfICXORmu6gVUJ5WhtkUZ0obRSAistr7eBUzlrGbg+OKJV yx3hKHq8DkpFCry4L9O83k8Dk0v/PvDFSWR8ayrvwl61q65hDQE8839SbePMfKll92OowM0r qwVbWL5SeMbfdyuOabLKmo/e83EU+5bbrWtnhmk/qofU8jH7xYOIe5cROEHgFM5YWRcWXi2w i3alk2iY6PO1KyGwW3n/sekvGfxuAuhoZQljBUV+/nGq8Qoac0mvSygeWtaNaCRtcHR5Z6X2 sA08Hpz71e77grjFy74EYrweqCGwgN7N1bSRO+v9EvoZ8n43eifjMnbhGHSL8hxsCa6KnOLf 7CA29xLBtOIm7PUO1DCbT3HQTWLMpOBXKdm7/5MX3XAodRDxD+aWpYqHYPdXVpSFm30kfkQT TXRSQTOkAJSEb1yCT/u3SoZ9kddKFOCAVygsgLGS8cHPVozpH2TW0AqpoFFD47VM3fHnN3ge fm7sODxuul/AeBOamXM4DUS3mgGDMMuIQrof2SLM4g9Wt56ucL4m3kWL66uddEWD3taaLu9c VHaaxa3Bs4N2n7CdoAb2h9ancVOb82HpBE/BldZ1E+hPu066XbUtQbN9FLplfKBB3SgARQBN tBuT2ApaUsCuJT+8AP6HTnVM7rdVmtPe9uL+6NwMAPsyRjP6xZG86BqO2qwMGiwTuGA/LtOd qGqowdLSlaNOY2mULyPZif3i0uVeQq1oE6cQeCTuXd4uSJyVQS55gocj9+lviR4sMRsMmhkB Frh/eUWHsi0CMUDjsl/FtM1X+Y9178V3B45dkpQy+cenUblfZdDsye2pWFN+jnTC4TvfptOZ n6GIUvfyClsLamEbYdPtOX7onxUb762g0FBxUWrEkwyy/JuZ2UgcNpWopxVBnkeNwtpC4iOw UMuzhUzUeBWcbB454DCyYMQSAqaJbETFOuJ3/AK959w2q49ZgZBXTYS1Ck753Y9sxL2Xkbpm a8lLK6DDfhT9I/gl2pnXAOCMrGZbCZhbuN68gMzpQTmyxZXPzUd5323WK2PivAo+NJ03AtPt zd9Cdc6a+qIYxjDduxE2YMv/OqgblmjazQeVG9WeeB7rZ8C2Q+9pYys5KJUc2rvgCcEdOTeW n9ynM8TFilrxcg6AC5ORS23Vq/blFSQ0Xl2Ng0O6tTWWsn+V08GVSYLMthStzDMxQD+dNzKW a8zkKAK1m94iA1o+nN1VXeQ/JUtU4FecsNzmFAD7OrofC7l2f+M1EXGvY2J9tfuQTCw2qhyG 5rPAw0iiJl1wyDx37NxBY4N+Z9LXoBDgCjJ7Xn59e2a6svbUNNoXmr/rYpenua2lYmnttbmo O+JBF4MHpk4/DYZMtqCbzrck6TxTOJp4oQVSXzCLBCgbe1r42hC0c4Rw5NUThp3Ny/V5WqLh pciiDcKBeole3M3ywVlK7jP8clq1WsxQ9wn5nuyxxhHP3N7Mz16ZbaophsD3O3P+qEVPRaRb iurU9Jn0eqJl6pdBqueAWwVRCVi7BscKsZGyqmJKP26Y4A2aaQw72NH8a9kSofAwJeb7zYDP OU8yNouaf+b0jn4qtvR3/7adrX9U2IbcAMz97TCBlLZxcFdrCP3Vxf7sQhDxcuOgLimlGah2 VZx3PMfl87IAZxYs/9W/nyXhTL54aZ8uTBJhWFnf5kY66OEJjl7RRNVzEhs6gr3oYwislR6b CiPDQilp0MKH+ovjpcEu/Kfx7HPwvq+O3uyrqKZ+cE64B9WqCRQnk+lUDEQmg1TBmLH6BvMV Tid/Byp7qrOBQb2A6mJxALh09BP4SsSzXx+zu+P6DmyfmJv3iCO+sLs7phN8xobfOmthev5F ATwIudOoBFqlvjgB4S+qtUqMgdR/fHvD+UsKNp5WIUNONrAYwOt0ZAf87W+EIlsBCKtW3go6 sjPm/vTuAKP4YkvWu4RMR3iJY/bnLy+pTPipMzRL6bOaBWQXyIwArxU6O6aHHUEQ7PckYoEA req+Qh84FPB2OfX65pmhPdbHU86HPqNaTKzNOClWhsnr8sN8pPZ2H80EogYBjuJwkn8Yjeny 9vlHkuLRj0GicwlFTygqpsprxcj8lDz7DOHuHnSgUGACO3lJeryiudh2rLFpuV4wt5zinDpl 7/yVdi1zfj24eE1QtY1O5gsKsr1BmB3rz3WZZ6CUliKXyNfdSPnE/4zE5oYgEhlvo7co7pbY JW8zYOawBDRxkjeSdUhkzn+ZKPHRSZPCpp0KPmtjRbY5UaEdwDwDYAHsFBkwz3+KxzbYFH3d FpuvX64NUIUnvM0BCwX7lTOAI8AWqfM8PAtc9o/4QQoSwcKhn0Rc1kBLTOu+bQIkhQDx6C3L 9Sithu+UEeRCeNUWe5HzDaPgYR/ezByhH/JYDloN18q5yrpwY4NHBxEh6hWgy0rdXZYcVwRC g/AnBhfHfkJWYmvghGp0yQW0/5JWT9EFG6a4+WiKddsc2xKz+2MRJKbB7lF0UimpLYEs6duC /JQzxo710ay2ILf5h2gGS9Xg3qwo+z68hpjxbd+HCroFJIJB2tkLOSxstY6/3+BJHCG+4Yr6 3YU+VQejliAb7719OHwJaNkaNzTqcadh2RIb/5kSVtH9pLX/DZKDeL3vKXiiNX4lY5/S4pmv B2FpGCHzSEe7ovTRv7IZo/5KE726Hb/1wLfj0/K+i1aCEUzVet34UNqHDLzCGXDfu3eqDcvY 1U92z4C/qwQjVLH+c7Zd/oUaGxsUGs8F8RTc+kaOGzoR3bkB1gSQw4RUKpIqTgVCF0/jNZ2T YNLCaeLW9gwOjMk9ztwID17U9ordRcvNc/9A8rpCpXnM4IdfPo2Smsr8tG7ro6GgAk8UZmSa hIq7aXZ7bVbOJQHdXJzN2Gu1Pc35hVWA6q2wmUduJOwXg8POkG93CiR7ABbMPEc869Mn9kzF 1CpwKY4XI7AiMITk+v88VU9/6BEidwOoqr2nTs1xGPJXRACkhFcZ2kDVIJR78P2aTRPtqwK2 UasOHRjW1bDhj+tcsapF0x5cO04oJ6LGHbEj/AxXAwIOq+Ow/AM0VN3c2W9WQy/wjvNWUroH SUS2HYTXyq6oYzxt5N7WJqvVZAOillg0+LSA8t9HHNkJdIoXxTDbDk4u+09EY5AP9kGsLsb6 Jwcls/5BZ2zMgvAP7RVU+bAMtVJwFdGcEs/4qtKjSPsT3kML+WFdnNmqkw3PFrGtbmtbSZd1 dnIRqBK3r/bGgWftGBy1XBh0UAsnis8DS61rfMz3NQ/Y6dbn3V5kIV5C4rdRoRz5f+K1mXn1 ZIrvjOzai9eU3L0ApxQVK/I6eZzaSIEu4hSSzWCtR/ePnbz5OneGi0y9u/oRr8iOyIVXPrq8 ys2TL0wF+osik0sWfDL29ttu3DHMw4iWL6k9IsrsfmU34VP7hE2XLYIKYWZb9e5gx/rpcCZB YOSzsHwGE0d7Q/36cCy69UMj8uVikUkLM7FwosFdEstw/Inqo0fTHd3hdq8ngNrw7a0zxFRJ ssAVl5PMg56tcEAcjn52JaF18c2Nc/Z9wtpYYQ0DpnyND8B5rkuZ/aeD2kRCKYmC1yyZYXFu BbFBnIMEIxhcSPggAx/b7+cYEvUzyBcUbiLTeZQNqP7dDXIRMQ5j2lFTGmh9SBrFEwMgfiBr jA0BTDlM7jj0y/rB9QmTFjF6BdCw3+1fEU4LmPvi3QzVEoiF+iCechPyVd7WN8IpZSwMTqSg xd811fBHa4wyjAXBDDSzhYnjUCmVMbZdFSNhvWBoIXXDBGq9AJXy/NWim0j/Y568lVd9a/7o 3hPnZVJvy0wF62ojwSCyqYQnY5hd11tLplPD7y6DzTPRrqzkKsH/wGDLmyyK/PV9xONPx5Fn Z3x/mFgZbnskCiIV9Vzn2jW71ww+l06nB4EqU41Io/8/lErMIyDcMalP4B6VoyCcV6CDli4R JHwAQQ2XR7fty1Mzl1IREE96EE83UhVaiqu+btZsMpzvKGDQcgp8tlXqe6rFneMBJjwMO+/H yQzzGN9lGp4ewYc8+lTURFxbHn5D6+sRPhvpJas7hiT6yDrdUVCqKoK3DvXPsIaVFJVGazfA yAL3i6zN/lLeEoXAshtPxT1ZtDGd+CfQrIDl+bsFNE+fpbsm2rq7AHQbdCfGv2RX+PkEjnko wZTfo4Mog8RxqdlQ2yof2czmifxL95G2SiPAhQD1xXy3HZ4n0uYdmx5ptJO61jC5ti41ZECC 4OyNaMtPGUFT6IiCKo1z1BPPX0JmmW1EmeloXSgRSj5qUVNvv0FhDkzaM7BXagwAm1UsXQqC gcch++GwICzxLMpxK4IiHpoRqET/gUIOYhoyUUVt2q5CX6+fVF4n2ujOewQEYFvlQxIu48/a j6ITD6zTay144+aNgSjFGY46NGLPNCESe9ocWrCVymLlrgZaycVdkljha3IHW3ixk/TrJztg iBQ7u3Y9msZpul3i4tvOhx+9xQynlaMXF8LQsgR2RuEMd5JY/vyXHRoefzvS2c09TAxaOOIB aIyOhonf/yHooGN6bKG4+xaRWBo4BVdYb7E05D9Ly8vNLXXyPzJT8Npcchz1aaQE5HWAoP7A 1w6rmBlgYFO7NnQImM4bAvM3Y65y+h0e555JUVbLEnaJXul/tp7inMX61YYDgp5DWBJhyRaf YJdRvZWBZSRDAzZJtXCQ8nvyNTIcXoCQlH705zOU2iY8a4UzmUjOuVA2Apdbl/KWaz5Q3tBJ pKkMuQ/+gi2nX/3V9duGhTGfy0M9ffWaF9/AvoUdXO83lD+snJEs7twMbALuFBN8sGdfqHsK xYfz7bK5FqmkAl1sXD7jLiE3oL3ysjvG4T54rJe/bkjy9b7qmRgEhB0mUQ0/8GILVype9jzW omD7Gcd7vf7BtcnZJ3CiU8SmfJpJ4yAp3Qv4YVkbKg1YbpJoYoedymguao1nDJch4TSvc/oA VzQOczP87IzTDQ9/a9yVrMkKyNyaRTCyl6ALlV6EXJ9ZjmZUkhbPiJSPPsWuWbo8nx5asBwe yWaCAaGfoZX+V+VlwJtG1rmDEd3GEkMJQlgUBlhJwQytiQstH5xQck2ru2GPgCvjLWaEFO9C w42AEh+qOwGqG2A3LhZOKS+exLxfrSc+uIXe9PYRIrg0ZpEfF0kV6LBdVQj+ucwBebeIJP9E 6Tno27weXjgc8qSWzIcM+xKrJ7odZvybDugHSWsYnLsTMDaYF+pqGNV1zC9rh6Xf36lKgNhf x5AoCevlhTpCnRTDn+ns4oDSPy6VXTAgyKw4S6Ckq4Hojh6rI33yPQzTQ3xFfrXGV1fcSxVY Pppmqq1rVCrE6Ubb7Hyd+yk06FCE00b6ea9dTTdv+sVhDPHcz92pIkqJoTTFAy8SNEe0i+rN Fub74ewhrcsxYF1y6awC5cWxvFsd0OTLfsbl1uEq1+V5zpwlJ3wxvqtrDUWVSfmC7s2iZAtN kKrhCdgqQSX14+qpAydLDe/Q3jwusp71+VeR1wwLe2X4srrhCNP5BTt5nPDBvBXWMISac1ua ushlWEsOGtFebSRZkzP7OsNxwVT63nTuH09L67+8Ec9xliI55eEfgemQiwX/9wVSUwXfLwFt PoiDrSSxbCtJJ3lj1l3x5ibA1dAePIhwFgndVOaynW/ESNUftZmk/+oZ5yQr1gjHNQdK81Ij yJKaaNY4zn9xUXq2ShrefG2bu884gUlkpG0wThhEjokVanM6xOFD0y8orKEHt75z0Kvb1bJG Y0VQeO8aFiUAw/C5nXR1Xr7bkZKyzhY3Aaijwz8ijHsklYFGAZz1fc/3nGwSk5nReSAtTEiJ T2M1vFGsOemf2luMn6ayTZKrXSzd4rIw9c8ml6YDR9cxHpPaLFj+h1R+QzvR8cegUu5uvfTC dxuonHiYq15+vu2YrDwtQZ4AVj31i0iLQ7BKsGfBz7tTT66b4YSaOx5Lb4SrHf4wtEBWc6p8 4lKrtWt/mTK6ZrWcCGmK/1lWpYytP6OE1x0pW00BhoSBljSICWPg5STD0YRQA/ahYxfIIjxT mbcn9KtEtnRFkhSQhcurF8A2cyLoKe96fUD2unxRSgEI92JcE6ttVLKRGO+mDml/LRSEQlZa zD5fEPQ9jhxUQ4AyMDw0YQq4Vs+kBlpqjQP+8AP8rjHSVNvQGTYXAS9buy9kWllD8Pijue5t JmBHD6h4TWqVA+Plj9O01IhrKX/xH8a/ex2DiBopLuIrPNnWYfdtAMxvO6Ustn6MJIxDYAgX o9yof12H5kUEwm6uLJedYoAUAR3Z6Y1TfPC81EfFaPJmsmUT0wIYgioXZzQy8HSzln64Ga7T 4rBe/smHwG1Zc1jDbylcRWMZjadJ5Cig5QJtLZvJPsHTKhRbDSkyP/UZo3qjhDiFqFdNJ7EM xaYBqdyzu/KKqO2QkKay6ZOMcUvz7iOoi6ZgiNvkRCnaam1QdVG/1hQF/eH/oT8byI8TRLzW FZFBBHDguj3kmC7mKBlc7gq+MMSvTwV4XoAo31Oup89j2ErzA7guxDnFYajuGVwxSNCjdzvN OIldC1uMlXE+gHcSF0KiPvum7jopwTrjRfPuq5sAV9FYqH75CS1To9ixadKkJv0ap02gYZaN l2bQo/ARCTG8z1TLR0WX5o3hl88GohXL6B8AtOIqquZHfIWsI0HP4KqRNLLZJl7U8J09tV7d StH2V3W6O9dAeictkr9/8aaxlIxJzWOJ8t0FMObdb8IDZKMbx/SV0VwWvUyQ6Vj1lGGEt6yJ mH4Tdn6BKqWt6Yj2KGGMfEKUL5kz0VMiFJ51qfrZnbFNe0ck+C5Cgsdf2StQ+ANw7BOSzbBw mHN9lBNmK9ijf1bdsFEVNfB3lDsEQh/fgqFykZMwPD8QsXgpjOECZ2FeXs9SM7SRm88x3HC7 DXq3g8mibrA1FKi0usqCyTHQMmU7KMFAeL8vGrQJIK/6Y+Ln4Jrx6e4g+4OhyccZGei+ROlj 1MQMhHZreGgyyKJ6IOtF2BQzSe1G6cKkvpbwKScVJJhqFbH5TBK71t50fUiN/f6Yt/X4a6rL ms0YtOsDR8QJwq2m8SdM2sJNFKb7Xdo4Lx7fjHhNR7/VznQThNYsZ1Q44w5HXy4rGHrmau6v IgwlFK1T01PYg/vZD3vz9AQGZYBFkEG6aFzP8mw5Gbo5ixpAK3V03AUz6Ce/mUBR2+imkTgE e51YOqxHhvxIVUD/cQyU7+WOcmrl0K2jwgKLrHvZk0+1btD/L6t4flApwhzQYwiiT8WlsYpG R/Cn2kCe1VrYpPVCFpOUY4f+S+/kZt3DM4+u3qIuyEEOFxMgnQyWPbWSKK88Xu6z5CSLBHNT dIs4EH2t2c+RqFlI2DI7AKTxQrTF9IbDCA2qTTtGYB09x8HioswUBqhx+4ePc5X0wMr2eJr3 ro9WtHfPYEf50BYzGLgBM6jyUWRI3W6OPeAJO/Dhbzudnj33+aJDBrV53g7lXYYoNe9vTMyS hm0frRX8vPpE8C0KOUH1HDEpgrFuZbOj3EfCpgujD/+J0o3h3Msgk6l7FPz3a/LWTI7uQBHn zG+8TGeJksxNK9TdgAogePXcgbMVY8YihYSlPYb5o8h05WA9M0beBLrMJOS6rVTroxrp5w8z JDgUszBMBJtuJzMl/fyaTvfnmqt0cxCvCMFs0c7Q9Z/fBIMBVO4YQm5nhZ+rVxOmf+w6+R7k HW9VJNSNf+Pf3F6nLBFv7hHN4dg/x0vdwunU/d9cfQ9x6oSAlMa87hFn+7FA8rqzm2QKSF11 XclnhjmSxO9hliqWxg0YZZ9dlkHSRLEc+OCAkXkGN8REV60pCEmzXS8WiqHuLIG6UBbBOG3T 51+wyFQBrPnoFsGkPTn3GhOUaGMBWuyIn6oFhTg0ALy9XcUC5ecZMlwVh0WPl7Sl60KFAEKE kQgLLa1QlHW7YQLgO67GG4nEVNsVj3XoVNq2niEWYLtLY3TDZ+IXyEKQJpVBRagy6vbeuYNf wIioXNlz545Lag9P1KfsWf/Bm7VzGYJLNapACtsMLai1IftwxwlqWTTtdmtBPlWEbM1gk1Zi gZkz8wDaz2xGRoTiQW/Q4pg70cpqbdIIShjna7WehWAEo/QZrlWpcSTPK5Y5gbsJ5R1M/I+i lVCtH9jFTCzR6iDKA3cD8yo8L7aUvSJv9wKu7GQUyeyhi1Tf7Eqx8k6az8OR5xE45ljf0Jh4 nQU3G0ywJAAT/rrx012a8+8lJQ70pLZ8P34FSLShvcVbwgnPDw5Khb7BGtYPO8WgEzIO1kMr MEUZwQ2VH9fFCUavii99h2Qa4Szn48QloW529GRs8j+Q/lshzK0C+lgtCv9QBtoCd2PuLSzk ZzShidLD3BQ82yk81r+Y+H56jbu26/oEVDtyw2zw5OQtFCzt82KxRgx7C6d9NyYQl58IOUT8 lEk2LXMsoI8J4mSXydG7zSIEW3cOJRmAVLJAvdP9i07NFMqekzlMfduWLHqu6LFLIbxRj9oR eEAWIaSREiFJdm3wUfAgyJhAbPAYiH9t4ivDSQFDiru/jCCIw9hmqDa3HqONpgOHNtqpMXli PrgNa29EoRlAtPqCE+LgLYRWxtkAcmHpfdeMKLnKmG5arOn00NvzjZnE38hqqiGIvDeB4R8u s6oMEaWqPgjyUQO5AoH53Gr/vrQBDfXpu4EdHCcf4NLlreHBe01KmRkrKjP6kV4iwo7yYIPp 859TYTvj2wFXYLRhr0MV9j+shZ+abx7OaqBWWA4anIb1dLD1goOmMYOS4PVtr7RJqNHF4jvm y6dLAHLpy7o/l04+G+V2iJ0NqkwXh22ctAvWxFa13SWPOU80YqaJKP8U+Qo2eDAeQnZITyS8 SDqJ1hieX6NjU2rs30kZF4U+rDJALYJilw1k2fQt4Su2U4YdhcN0U/EPAdrYb6yOK8k7o6YZ f8Ze3bD12fuMRvTuVQtAmyMz/9oesQh0ZKw8DxSkxfpFL24grc4EiqiimSAE9P3oi96uEQbS ScUv9fD5PHnO5as/gIyfJB/V479w6+xUtS0WqTR7HAzwEWIuozwTS/LogAB9hFq4p0evzYMf yRewR1i9B0w2aQtbpKiRXstLEKbIHTDCfvVz37Tz7+JXqQu/dfISHgFJ/WMZcde6fTZktrOS DxtH47Jxoq2YTn0WOxMeUAX5/V4VkpY5xL+Da9B9fFRmUAzyYvScT5nW4/sVwmtPeOr07Wy8 87H/5wI8s/q1FufNwSZzngRpVE/xg5CWq2kBM15WhhmheBXGHDIhkCJzBoRowN01q2saKTp/ pmblUO90IXWEqHHgqru+jP33NNN3N/hY97fMLtCgeICVTD2UA31QdxM/g+oj7IpYx4JYO7Bw t5erIDSLeuaIO4rQAE7nWBq53xFnyfL5yNd71SChFy0VWBuGDG7AXvzoMkt0iC9etr/WhvBO ORagxwvgXOpwquW/OAl8KqK57rsJdFYDhULn01WjsuKaPxmWw2/spm1UeVQvpAsC54HqIhyA OAGXeSBX/vV8bHw/Z52bv9zPLotawVK4zBd11Q2lyJ5CkHv/jlprjuD4br/v7a/XYajAZjJs tHWju67aTNZhuPErZ9GFE+ZQqwH9R+jR5Cyicn71cZUlld9+UyV1oJXXV9oCYS8oWZSvUmqf 7h2oqhN7NuZxjo+tnEK3B6atjfFOWFagHqI0rxj3wyhlnw1Nhk5XYHRwwQcJxmOZDFXHICe+ HUqwrjFdqpkPbM+/OhL3swJ9SslD1XqZVrJjZNYB3AC5h8pzZ7uFA+Z2favgI+YX/3V7OcFI cB9wMqkEecJy32q4l9RQiERNM4mABRZsm6izuJu2f4t6TMRgiy555RPN5SOJdSyo27Ct3j9i mYilfEfMB/Up0o9xZyJpcnChECJC2jiqr00pFQ35P/XSCvz6GX519+wXhzqemdq4zqhgaqIl Sg59iL8CX3WDMXX6Ljp900ccNJQ/qVkQ0stJWflxDjDqmfLEOgLEEzkDpFC3zaAipTj0WKQg YhHb9Aj5RkKRnb7daWeQhIk5Ohg8oG2HxRA0jF8maG0RJ2evyRdVoJPBO3t0L6ksYZs8nXXB IMy3kUKurZ/0KiG+uAw5Cfq8xgL4zD30KH4VSXry3PRJRddfvn69US5q0Z1j2YmXEBhQY/2+ mVRIOb3DDU9kIu74Fxa/9gO8nx6RqJU+NbW5XC3Ox8VaALSB8O752SR9nQ5qb//jlwm9nW0h 0VlkkimE0cBfbd69zDykYcj5+eUPPOAMw1ZyV/1Ss7gLhDPOH3tCDdThGfnOFMmyWaa5KZuX fkgTFRaAE5KlohraAdD+1bnfBwz7t1VWcYr8Ex4xqf6csNUsPO6PB/wnYwhLJZmV98HjDEwK NsYJJbbVPbzQE1S8ATT8nUS7GOZxXafndUZSPugbiH8T4gthSDFkYBL/1xfW2wuIzn+8wpdx XADo0LLfQcMM8FqSxB1vJBVbYdL1B3crQVmbu2mzpRZAXBKvi9lP5kESA+M/x0s6rBnTICeq BFlgQ7W2WsQOchTbDTF1+XDfSR2iSCer5c+BE+9fJp1XEs5G9Qg5UQJiBF78HKCd8RbzAno4 Whpd2FeogW1brHU5YZKi0v0eRfLKBTjFDgT4txUmNcgf0xO0QfZlJFD3r/F9m+yIyqg3o2+z rLTxnhXg9GhUMOl5zR7muv72ampf3i33KJSWMdw9jCek2fm1LWTFU9IEFEjcFZiv2jLWeC76 xoAcNVwftV4KlT6IIj5BbZz/XeQk+78r3Oihdr386DRVb47PXPIBZyQyEPLT9LLv7FSvAUXx tcVYW76Ay2ULAviVJZZHwPApgSx6pYuq3yUebqribTvj4ZRyu9k4Z5wS0rgNB5aXkdkVbdhy dNoH36qhPoZwHNOTy/BKmubjQR47TEO4aoSv2ovs+dOsvqNVrXu4KbsSONTSEpt07/Cm6t1L DebDR5TxDH4veTLL7gehRN1rhpHqwCUBIkHgipeookwODOkRP/Oa20lGdtKBbetC0t+wqcuJ l3/tUa46jzLBLy+73CCpS+bJjM0/7bKL/Z1/b0hP7Xe7vlzl0Ebt+0k2DJuQF3aCf+Z6Wobq vaZAn/OK1ge/6069hRTuvUR7OsrG5PAcRhbmFjjQwlfYvfCgyH9PkrfXd2kKPRx5ZbR2rb62 g5354O5eFsN7tqrsc7W+IdkQPW1u9W0DiuAG7TExlpXht+BUXQUkI3fj20z9bGbuCnFuK2Oi mpY6VI+z3UuLEwKYtILUU+7XbaM4E2iwTntwKwIxqOIdK0rzGbCX5XwTj+eyzneEERH/09r8 urfcwmCW0Gs7y3BoL/5c9PswGn/gHtRVdZyG2kdSU6SYpeNdZqjo+pI/cs2M48swlxZUxzPV L+S36Vgo+Cj70rpGSKfjzSZZpl13xE9gxqZTM7+G5pp3+zypVeX8YHHFi09IulrDwkoSgPxC ldJ23roMQlPl+5Brb1UIq8CBA3/f5jet9lIhfxgfa3PZJyVIsWRR0DR5LxjMMJ2KjeiS5csa oi+UDHb0uSP1YIzdbz4knHEz6PIKm22XThjYKL3TWOVM0hc/rBfWyO0DORFZnxoPSn2DLjhx wLkDCM9aLLJU7RKTGxyFpPaif1e/teuKPrci7kdoAhte4kZ+ganKvJOYFB7YL92N8TJWlakV Kwq77/IoGIEB6JeaQjReO9ppXBu0bu8J9hlXlunFC4pvue8tGbLaGCxGlAO0M9zmrAvUdLi4 yHx6AtEblhclgoqreHFZ5lb1P+fKLzugKIvfM/hqhqid8rfWPerApXFfKOb56q3Cg2NECPIN CkSsK4xVCpZDIlmvWbqs8zMTFGdGTk+DNpV78R1ucfU/y6VfErAF4ouB1lWKKx9PLxc2//6k a1mgVqo2DFiOXxOSdKZCyF0v0yAS6z++qD6oXbIpQs2ExDVYTVn9abidqxIU5BVK6tNB+GZ0 dbnAOnSkaIbjjjXY0XlOWK5hUo0mvVgbi0zEIwKUE1fRRCox1RmTndi3utlOCk6bqQsfcIYo 1UOzq/5AGZTE/b3BSdelgwhuxwL3UVamkEn0wEaiELOidmx6PGxsucoo2J9CZCi8GcJ3K9x6 mepqnetQhKVk2xsytSwPL+ZhIGp6ZmhjR3/vi9qOufkqS0yVhKipfMMf4pvpYtjPdDz4zUz0 ViBchuFgeS+qyrK7T1UOoYIdBrYGlulAogUgOkLYv2Ebmys2EmeuodvRBvKT/uA8bb6RUtAl /Ya3BhI/JXpEcatxze6XXlrhhftnEyepEDZ5bVBUEkJqmOQ3rx14gTIJF0iPlIl1nKa0cCVY +RE9EkPSAKZ+B8ak5euTgXbF94W8CdLC1Y0jEcJhqNCSdPefgcaNmgg9LgNJ5wJ/E78QCnHH cB4Fy+rFRnDOwQxVjbm3FR6vmSa2tI6I+EZdLB0jHShvfLmAAaSvDG1iuNu/Wy9ZVEo8LCHL irdbrXeLqUg0PfFqM4jmfyshAfJBLwmzHe5d/fKWPj315pcNsS7EZXaU8fIJ8JJ+2wJ+JLPy 0VynyQEP51Np2A718nm1lg2rWskZB8g7NZGimn9r6bRJkpMULKSPOwITbC4+FiDX8jGABliX a9AilvKFugN+adAx+Aw1fim4X3lZLM1uvIiJJjtNStl055CRf+NgPsYGESQzK6RfoJx9Y5eo At758ygeoaWnJjO3Y4GbFY9fyofV+RXdr66aXQkiVNPdgtYLlx340ExZWRf6es9q5lrODpHB /BDhrImmS+2VaO4/KhPecmAL/GCswGThLDeAGy3D2D6/qD+4n2sx8tXlL6yrRDP0aomF1xw7 n99R/dbkksYMsqf3nZmwekMOH85sorQts5Ml2B1tYk0DUtrKV8FNxMQ5/ZliC5UDSc8/uqV2 Urv9y8hnbWL7baOr9k/+H8MupgTdxwXNUjjQk3qtbdjN0zqC+Ll9O2ItYkDHUiAxLCsnCA1i iifEadB9sw6Ea+44IeizhiLe15kmDoMJL3/1qfZqLKwBn4di3SEMUu5UViu8c1at80/hxPP4 jMeUtaAV5TjACUdWSfKIMpT4dSX+70+fnF8xOThso6gbB91uaIjt8nijJ0sveiYTUtE0JF9J bzQh5+MfvqqER49XAaLSiQuVDPYROUxrp1LPps3rVjYQSTnjBd2x//mgCTo1m45689aMV6Ks 3kjgvAav9nGXpbUGkk69GSj4jhLbXLR2Hib2QuBLf0mTePQWw9Xogp9hX1/2Ff7rIbLG6TkA Tc33S8ayIYtUU/OLZqghUJytMoeUCjUB13oaLutvl5L23rYL4FBW2l5GDIXtoKCcQgMWmWE+ gStw04HntD01h9+4uj98h9QJ5ogOK4CTmJ78RlLMdKeif/HKVPLTs6Csh/N9C4VM02uGP1L3 bYoAYZkr3oqnDTkkMdoVcD+6UqSmXoXnALBMinoMo6Mh0Jg0G8qQlpq5AeLJqstCQSf79BpO FObReLymGyREJGPO8oM3HiEW6Mja9I3QPGvInK2W+QHVToP+E/DgpH2E5G2VgvRrHwby6TCa DUfr7Qg7UEhMwbDxAfpXPCFydzU48hH3CIeukBT5wNIMF03qFmzcvdVsh+VQu9Umcl/Saci8 krxWUNfpIPV8ybOXwSiQZPaiUoujF3HCvmEhrdq/URhpS0RQLOjvzmTpG2+/CUap5Nl3YLar nP7SNDKEaeLHF96L8XMD8UqkNpS9meB+7OFBNdqUxy0fthT1y/LxFfPhtVgLlxOFBcwxdxFb AWDZZSuc+C5QKG/uimzKrvtU05ZWzHApz+CoZ0+V85Bo6evG5u6qPXr7eGeE/j/4A9UyT815 lNCCRKdxbBjpkJdsikiIqDZTusLJJ4SRHWY7/779VcImK+y/TQ8349Br3EaNSd0Jm5hjC0Je ERUL131ZQ6A57fxZBs/zdxhpDCAEeLTuINMZydN0iomSSauF6rADFC8C0wnb+5s37f/n0+Ww MUY0nXgcbv0eoAErrkEUvIMv2Wh8jBK9/zbzdDptM7tOmG/rzm44LYqs6Ze/wZzErsCcI615 XVu3gLqrc7b3ssXsxEbrmEJpDyeIV2PYCBf6O0snxBOpRcjq0EaRAWr6cA/Dp3rRyvs4BZf1 RLm9LI0FxM2L2riVQ01Trb1Bb+yYZgWpPyoPtlz61AR4SyiVDjiqlvIvMNLECLAjLXBg517c HDv5QMej6FZL+ac8G7OdaQLA2q8YjCERLavD+Kj8sZoPtn+IqqZf6Mw8ltwLMfgmaVZ4qoji nnktZJXOyPkXVUzv4YrLuCh4g+O+zoQDtfM8tTu0ykYKencMku9XoekLM40/5wyhxiOqJGm5 EgcziUO81Dys1PaWbKPJ1ViVN/LKhRgSqf1OSta/jeVPzKZliI5M81uYTjMYQ1cHhDhLnXmi pQK6PeDPgFB2LQofK2I77ivx8h6iC0QvJFPBosJxwdHmJ8mC89Yvtht6+0UmwFQROojKlFAv Jw55jxrn6Dz/AaVycdd8n1h5kZYkIjrsgQma/1RZqLGTbjQMM+L++uEnOUGwZacHZAUXUIvw l+/lr5PSbWl0b2WTNz71Y+bBSrwQfeK7/8Z0tpXRx7q9+bSdSRgYnT8Vux8q1KM9nMxzVI5Y EJG7Y16/RkpKrjL0Vt6JWizxBhsj8T1Dsq3o3kaCEywTv3fY7zCpsg53VzwVDSQ1hq2ymYni 0xUpHkWrrgqsUEc60ywIEN3RWmT9Tu9EzcfiPAVXjYZpyR54HO+78PG2CaUlp94tWOzgHEEq SnBECSA1a+FV5aJ/L5tXFgbCMxi/WBXID60RNoHxI6wxXIIfgpPAgUJwGboNNc1ICOncPPxk 18ofsliGJGg9nTuc46zADUNvLl2hFW6bHL+gVDgOa3GbsTZv/bvbNfUzslMw8wsHfbF9exk/ 0f45ORuniWgpCIcSxorwTt5erAJLoUEIiwTQKa3K4V9l13EylZ5Mc/zI7+J1ZTRhRBw/PIP1 n8EDHaEXM03ueTvqSNn/7QANC1lE25Z90yk4pIXSp47EcjLXkYRMS2q2uuxT2QH0VBNFtTNF XmsCWtsE3yfKwVik2CFadyitM/qt+Uu7CHaKuUtFjHmDY8ZUCx4DSf2dU2Dw9chI+XVERUqX L0j1b3CE47Q4pMz2ghGs+UomTsdyGHUI5WdW8D7AAO6rUwQTA5v9cSARvX4E6Zi2RPjfjIJE Zq03r9bmfW8VEbryTNJJdR9bKCcyhUGv7POcSxIxsaZTM9EhdC6uDDPxX86JU2hmAz0A7VbJ bT3DGlCWY1mq359Odm0HT7qlrzYnPahSbwWdjdiZFsSXHHjsm+AE3e6ZEbNCKTAybqWWBL0k Q7fhDseaK2BUM81e54k4hZak0j/My9eobOBYUv3v5LcAF7jSJ51WwSPLzi3pakvuVqdsLDhk RWYoRX1+Qjjsi06S+NNcjsfBvS2Cr2+0Vf7/Dw/UTmWN3T0VYTE9o6Da5s9YuU0OLfPouwSn 1kSv9n47Dek7kipsXDEaJ+fOugHFZweLEPSb8CTMF26qafEBAYw4BOsKvcz5nD8sI6r97a/2 p2dBfQywExu7NK50i1OXhNVUzDsj2h8yDCsDCKxMbzC2Zgbl+iEv4+7RYmzkW+SG+JcSWS9/ ck8WFnqgO7/hHx6LUMqckKdnEfuo9vUXgJD1nnjj0iwkBPBL2ysVv5mBSymNM8pLMnNYMrZZ DketavgbXbc6AphFa6hDCC3DQCbQPyLxnOEIQFNLMaoLpLg9mU1+iZ7h+uLyIwsKe/pzC0vX 1UWloQNNKp82/jqguQ59/YvGgupC3jQyFL0zWFLJ1zsgBhlq0E7HS2baBtSCyPvbP2FALevm E1NCvp4Lk2K///LpiMxo2Aw0Y1tcJe0n0OBztffFZI0bM+uBtRD3a+TDs33UiEFgowu/Snom acjo1QZmPJ1+1Bi7lBluUOhn6R8lhCSa1FtvmnwrgksCV5gc/RFpyho+PVco3ed5/rdI4x9m BN/wHanu0rCMzHlbE5WCqUTuxTbhFnFVlzJcl+GJMLXgHqw7ddjRC6GtLQjTIbHTY8wLgueM CoRINKcAHkyjL1sexqpNQUkZoI9D9p27J2x4X0ebxzimdqEgfnfk8Vn5JK3jaOOq2Ok9mb4Q BsTUZEtARBe3Vu+21hs9T7yUlcZlQS/UN3VnGudAhvhD8baF2OigNU9eqb4YNGbdyl8A0Mmc PwQ/5h2Zba4hLHIX4NDNUWJFavH4osJyHdLQWEUBYNo6raiYH2AQQXRCtpdYN+dQI+I3L+HG XjBQ/gDdMDk+U5Hlqavuj2Q2yM9lAB35HHu3+3MaeoCxq1CCVMDFwJ+kFu9TA54LZIJjVbrS Q3Stoia0HxFRFpf9QbZLKdWigFL7zk1CtKweEl8/1LLy10FLdZCZ9FeauAvXheydbI2SYYJF 53bNUI0jpe+px26Cg/Zq9x/BxItGEf0D4XYCj85MAHyWx2fMZFVClF9ZnF0GyrSy6gTLQHdt DAFj9ba+xOOLSDddP7W4fBSoi91AjIWDMPJKlAqupUNhYbKnoDjDnrcSsaiVMTMgelxJeWQ4 BiOft5nZKtCO9nR0i5u0AMfYb2d55Zo9pnU+Cphy/fLHHFO2FSzt1sEB3PtHTGh/qpkyOsGE KTLpOkDainaCt/Yyx7ARFSawXOifhn8v0luAdWneTeZoDN1We/zT9RH0HLU09EvJ4liLekiz hj77Xyedz6ZSOOQyfSBuwbBwZVrGVtdQEulU4IoM5NM2opBWKmHBSFi6IzCHPX4QBeRbOz0D yciGLyVmXAjTi+ht3qOJlOfBpJlrj1C/4+v6bCrMrzjeRfFd6B43ujTTSmUxfmU640D0B8AC J9syJjPrd9D9bJ/VE1xXYP+rlQCXz3AFtFOrHW+OQs2063h5KkP71jX9qo/JPul6EtpWLedS 3L82vzfN8X8MVByoklJqc7VLqu79+Fgxlbub1enjLw+EdehSZyTSsahz1xOglZ7SZtBAqA2k Zn+iNmZfvsPoLhBPOHDJpGhhR5rRBY5m04HCaVestjtaMwmAzFGK5ar2elbYg9RNkM9mYSRo pY8+lgTTPWtCW7SrO3yLF7D+0rPM+ksnGYPiu6M27OM2FtDjKyA1zcAF0T7hZMD654wRpWtU okHE7IUDbk0ny7VQZaalPZJf5mkiOi4fbRbdRvANhsx+g9FwY4wkyBXj51XTQnPJzBnG9Eh2 AOOSrL6rOq5DCx2uxzpe+EHrc0y/Nn48E2Jz3M0Pi//UQTk0nMkpsV0MUw8zh3GlzVqE6NsC 3rF9PhIlClU9+h9OSkP5PQM73iJwysk/OSJX4f6Og90vzNBaordhTIrc2Fcr++KBUSPlVoba vH1tLCOe1dT9YT3vjWRXCn162u5xnGg8aFE/9jW4fDwMA/c26mPU+YxhJ0f37CYruRIqa7LK 5lf3E/SvHPEfxqwfGl5ZNlJu1GudrGMcE47PBphq8tjbXPYK10k5s4x+0y6CDfTXMeA6arRs w9mAJE3dFu+VarMxUaaSGC2vVab0HeGF2wSEuTb4Pg99hEiMv8jZkOGJNs/+2Se1p6M7mUTt OADOrIZodoF6MSq/CPiLnun/AXqfKt92eLIWsq4Tau47cREE3X+Awy9qRtljoXiC/hTKp4/n WPZurwCE9TEo1cu6HpRtEvBeIoq1ogEg0Sockcy53j7Z2lkM9n05BjTWeuLg2yMtkxyLBs9g R9ErSA0oX30aRVmB1ehNoVHbld59Kak9KPUlrI4Rhv9iKO9dG+Z/khfVkzTbuhBsnycC3SEa JRS3yI3SlyiPzcdabI8XN9lvEBNvQ24ArVeVcKme35KTQLqpu1nTaxzYZNNpQho2pg9QMLMq zYpEE/TNpfEljOpqEWZEWx7T4z/XCt6hHOmGOQ4YFuNSyLD11pd5iIsQ4nEoP5phq3L80xfh 8K+0gfh4a9m1UY64QVXrmfVQC+d9e/2VPWbggca+MlnCiusaNmA7G/eu09yTP36QycbPqDbc pUd8h0iP+VnnnDhGu2xGH0mZ1Agk3+hZ3oAiJNdXcTeJewAaSKOXUd1zXaVLbpV+pUuxE+t9 2mK8YNeqI7VyaAfE5q6LjYTarPjdaDGdhPKGfFyC37FWkyy+xK9m26u1yErKtEMi/WTdSjZQ xYQSSwfQRDySzPPjdTZrKBWqlH/p8SWhnjYI49JoKTj1O345by+hAV2Es/jBDvpA922HZcYP XfsAzob5CVHjEbpOyB2DjQ6sg5AVUy0A2LB6AuWpb1C/VzQOiJik4c/KHAz/DJE1r9iZChaw Vvc0jnsmYffa9oam/9Ehbfcf9gypExWuROgpRxaUUn6rYaZfLNap2Yp8chI57QR5MtUnY7Pt EugLUCPDEIZk+w7b83RaVLp/ezMgcvxgxsxlp44q6nKVt1+CbmzIvIffWY3G73jDGH2k7g0g PimH1n+XEdDDg9ScKJdB5kwWMc9Ik2dwwonl2khnHsb/pNW3KYNowNGcavoyvzSrE8Kwt26e HiUoUzqL2KvmQ+AEYEAVbJkTrhV0aNURu2+D4oTS56Iipky3NibHHMWfRBcemuIMso1+oJAG vqlEtqrKI55oCFYnfhvCW3wo/JNB2om3ChMoz3XkAfgynbB4XwgU5oRewW2AFQh+Nd7dULCi L7NiaP782y5LdjPg3Smil5uZwE9nkmb/uDEl6p2f7p6QKm0HRJ2Q77a980jPr9tDC2roblQh JSER/Bo8/TkRMKCGQ7hmy1i6Osf3N+8ENEPreXG+JavbdP+0flrgrVMDTuNQtz74iX4omQqW e3e5n2dkty8gzqwj6GWoq0sc0L2cReGXKqmSfMjpyy+IB97rUA9i2FaDdFhfjaOYMmhoxu73 C1jwomwLLS9lCJln93CKI/u7uTADi2zwONq7n74KIEio2TIUnTRzS48fnOv31PqlSvDLg8u1 YuVpGmM8v5XKFAL5QWAxlEw3fJ9P5ZCqgunOOtUx4cnd/TM7K6ja/p1f+NV+Mp9EaQ9fHVHZ aBe4MEYjs2I4LEMpFqLM5h2+dVqfgd29ZR0zxxI+caDylBpui49N6S84BNtoQd+4XYfjQsQk AQv5QRzZubJpD9jsikEiJe2XE47oBa1TGjnLveuAf2OQmX65j8wz8VAUrspFHx6Fm9EGXITl aGPhyeuiLVddDU/wkLCroEfxBVxwzfsuRe6GMrT6FMJkiRiRZ+54It1yArYG+lOY3sgbWSf0 VQ6fsf8ibLqGQvepOD9iHXWiWUlDwOnlJt7DI3YcoupGqDiGDGumdB60SKy886NmwmtuBDWb F83nVo2h8Erl9xXC+USxR46o5IvjUYio44KCyuUz3DgrI4yltIhLSpmp4AM6GcLQDU/6mRlG yPVci94Jc2IJJyCUvh2DU2ShfpCyuY/Y+dZ5+l935TMjLyILB2N++QpB2h3CFvQVQx2KpMtZ YUb6ALrTv4M65WeaiGfdzmQuHpsGykLMl9c+APNygkHoFlJAGoaYA91dSwQkGLg9nFAt2j4n eXBQfK25x9wcu6E+QcPk2ICIF+dWiSbX/20QXY02x06wP9J2EFKSp0ARKshThLPNugh2w99v NQGrcPkyUkjKnRFK75qNbWhLypo103DvRo4k03NQR7g8Lxc/H6VUkFy5T+4GjdI2+JNICpTG fVLyYFq8SoP0axpZ0vPMRouToIEGeccroCtzxgmnJrP0S2RhvVwL8JIvKki9rw6jYk5psJOL CkAXQAwHGq690+JNgW9yfkk4TYU8NDfopl/t050w5xzeWPPmuEUC1hUC1Of64ooxDTD0H+JP GrLDNOpCilimax1uVenC+LeWaq/9fX4upngYhOgSO/9WaGszPpPKQtXuMz9ewE9C3ObZD9Pc PHVLmxfsfnGopJtjHR8CfjUTXSfJzuegOshDRaLewoMflKHDbPE0FTmLenqA5kYyOAjgTLJU eTixv9856SiHVjLrYOcXU5YP9b/rXAe2FAszQi84PBYOrQGLMVL0cUh0LTgiw2lHXYaABZDS PXB/Edkhb93LmRi0IE1mwAOb7SI9xegDkxcmG1WCTEgqHZ4R2+pkRMhU1oLQUZdTGc8GP0bv JEB8lhJ/YB324X1tdtJF2NIA+4T/eMoyOWsRjFKIErRR99UvO5/j/cshmpBvK8pqQVoivvkB AlSCgx2p5xJ6GQujcJ1Wt3wi8jXxBND7CTa7PBSDgYQW8TSUBTUfm+gFXlwEYVrtLhXNDcJB xetC6x2Pb4JT8fG+uZHz7IVFBla1vlgSVFoGpftA6ybhPXYy9nTZNIwMDVi5u8nSW/bY9wtz v+BA95cT8zfd+seTzeaOaEAqltmyM05thAeqGDmZs4vVxaFqMLR8xRdelUhpenrK6pn+y55W 5OpL2Y7I0awM7IvFE1UE/Gm5hzdR0vV5bsGgRu5PKq1Jcl3RTWrHDP7FJxqOc6Q11A7T6TBB UXyBdJw/DWOjkvIxb7xYYB71YLgnCVrvHeTYulzguMnetcQIOxMxoErr6AYt2jHYT2rsa8wB liORJ3UkCzkdNtxv+z5KEYbl4ZhmPzjvc911er2xeuSv02uO/y3jwTi+qXlbgAqQrCZ24Wg6 KlNf0KRQLVgGrpsrAeJSXsejQTwvX8WxnMYuZ8mwT2xo0Vrhqf1Ijc5cC5ZBwt54f2JT2/6u VIlIvFG0on/YHOc8u3Vmj9cdlRDsqNODaCfspDYZkTD6oK0l+YR2srewqCH5n3LQKYKrnAfY V8gEh1Jr13fWhAAk22U2i7oCjt4ASDfio3WMa/DrbiDVad//LNi4ev1Bn/o8+owoMmGMBvoT SXT9J5RDM43XN40ByXoNVAB9e1zu9v6biRa0LdvQC9Z1XQsOOZzbitkzOl4/8s/9SybyX+g6 DgZGBRsdJNnB8SOSB6NnyadaWbn70AfHdV9TYMSzlKuWYQK5+YgznFQPiR9jDz645uHhFG4w vshijMa+b/YiEbmiGl9K+pIuDgw0ikLaCa3GWrLlPi2SapOE7jPC7evbIo2742AMwght/l3M RjLcpdZ38KlbahaZ/LA1zOyaV602CIG+FI+ucs1D2v1b+h65iUxOPhrj4IUYYnuGHJhDrdCL PNzZDe5ImWjiC4lIXGG2MbGa2uSyMgfyXuyjcX5RMa74R0nRjMSLiXgYwZJfnCi102FziS4/ mJQkRKpj4kT64Erju/VbZmeGFy8QaX9M6j2LuCawPLKcrXTUc9Fiy8e46gdz03P8ei1BHpb+ +CsAe87GOCumtuaRLPIGPEoSA7ePbVsU0yPwTxuVwjHLMv5BFhn05+X7rVKtzkWgNN4zPKLd ErMq0DKcgk2J9pk04hC7ILUWuPZGiBEUPhfbtEcluZeSE8CG2TUbnfR4pHJItfHRL9fCOi0F Zc7EOmQB5Um08DxqoCuR6pj2CK3MuqwtS7lxCQSGPb7lU1YluJugTxmtX/5xJ29jRHbxzxET cuch2UuZXEJa1VnMHQiacDQ21Py0e0LCO7fV173yF1eZT8KQRn39wDRugRZ34u8lZ+pgu1hu 43uvPexK74OArT0sJUpt2QU3+jleDTCJI/E4sz+H6EbpnzKAE5JQo2t/slOJx9HcQ6AxkmCu pbKIoLrUxL4/zobY17bpjG4g2Y0DpZHoWB3f50I+xqUd3codksOIsAZN+J/8wJ8FpMoSd2r0 D7Nov5R5cCOl8H+dNa5VRYZfHooPgA6FAdbKzGPsXbPx5veHIyQD7n6YGQz/gV/Awt9h7TLx OZwwtMzK5jWBF90kcdngHHoJP66oJM8aEF1OTOLJBdC0fq1k+dhj0MEH4iM559K/O35lS4D+ cKyS7b6V/y4p0f99rONNpnHeNmNF48tdc2/82iAWdFeqrtTxmhVwiiFunddxRDRIrS3Q7CcK 9eWQT8x8mwf0FoHXb7bj5v8uWIT05cd9yq51Mun4gLc9nBztfPmDjO36Lbr8JrMy3imtZuhg DQIHIDnL36hyvlMrdOttSSHFN+MZBjNUjjhUQap7pJ3ygJgHTc2Ep59URZaMdQ9KtiFeqJYQ l0tjm3Iomkc69z6wV0mS6hG44DT3vSWkSoYhPTJNeDxfJxDZUhD77NCCIDO5RVuoJ/k+tASW 1/toV38HPBzGKtsvTllrWnypyq6QDeKaE+wET0/nCMhm3EIW6C8jJB3688xNrPXi4OmA5qsx jLhRhD9OcMtQIrZMlMSd4wE/JSwSiO0YkE9bWc62uLaG9hJM0CeMtdED34XIOW/9ySmiBHeA YGf+uUl5y/fUHg8FicCoYARh6hfMLVo9voy3STm/N5Otx48gD2PEKgQEwj34h0cT/rBTA+pu 09Us/0QcqmlLAvgti5rN8F5YHzPCQwm0udVXfx4VdVOUyPGdnAEkE1MGNb8nPEXwxyruipOE fq0JeZkh+HhkxCehtEARNRvNUPgbzdNm50zjfAEzgEzMD8wfvp57Ay316v9twM6rm75/Pbuf pX0Mh38QbJAMC1UbBhF3LHAY/Jxw10HIlsjJYPTvqjAubWle0fx1nuci3O0xMeohaRYvxRFW MSdwQtFro1IcAzKPr9HvQT8YlxuOu9X4yRZW1BtKZOptIDhgDj1EWU+GBXxbNFIrJpcOpRUn YrmN484BUf1+6iKPEAKtQfH8v9DcXmyZCVu9hFEUk4x/4F3NjQfs3r97PuZhGwBkgtcOBvoq IObF0Lm/D3t4fmuSZhAq64f6ZegSWjPMU4ZxcBCKGsOgTCEyq70Nyv0t6pkiz3gKCsPcYeBO i2DO8jhJc8neBpXJIPHO8HdhxIB8zN5QW7zUWDo1smVm4SVl2QpadT83BN9Jamwt9wr/hOi9 h8QhwuQiV7hlb8hKryvRJFIIZQyajNkR+CdLDAi7TzZMveUGTOr/S/6EekxOAw00xRNUcHRe 3qEtmHl02A45Oa/YpN3wL+7FIvifhCFTn4u7mf8dvIw0YPvTP2Vk/j7OAQ8AnDNbSCCYgKo2 M3r/zKVlO0Bje6Iy0/3QHSxHR92MKDgbUj1zNa6C+dXuUZP95mLFaA/iAe3UHkj6eV2caS6x FoWNPE+eHR+h2PV1dn1KGHtuDZXASDQbYGJ6pvR6wqvl2dROrA1D0t0wiJVryJuLIbgFzCSe Vavgh4n3iw/7wV9AhXrjUiz+gLQl5F5rvdvqhSknzP2eKxz2vGINo1wVYQUGSyl7T8yZ0gIE EA08IVuEzn2IKvnnks5dD+8HzNorVbkQfdz8zS5JZZVz0NgAHbk87ffM1lleUWxI6ctr3mOD yVKBxDPzhsznkOL2tOGlck4Dy4uslFCxr5j3992NLrHGA4eHomYxkBfqOrcoA33OvWADN2WM ZYdv6Tjjbvbivi7+/zvMKrX0v5lO42JlJfx/tuFbJr/9DfgmI5vvHVUrscIz4XvscU2rDdQb C2/Q4frvHey+ZyqMe+y8WxiDP+pz4u8C9pgfzF/LTg4rlAeoyRzJIhAWZDMGAWpg8HdKZGP2 JlAx+ciu3GDuPP0tjrl1zImzSdM24H5D3Ga8b5NMKfhY1e5M/MJgtUCQ5H4X0U8s54pvQmh7 Xkp6wL9go1nykZaFJNUhWyI5g8udJqrJaBdjFonZ2a7Y0FxaNKI4vts9vDiYa5EBB3mP35zg P0xwT5JhQY/T6ECEty3UhY/It4huAdMRuc+0Lmv0ghzu3bRE+FAxUNJuIHOFKxukvgCxZhPD YRaWvKXIJMWkq9JQ4JkDn5eU8/bAzWiKc07pyHF+3NcSViUxBGq8pL5kb7BomwNLM6/f7K9v ctX0lJF4n2pFEMffz8qg5GiHn4ypxmJ9KvF0h5D4TsQeapCaJmGFRvW6CEHT4R/GJbJr9Nia gjACuTlGi1X8MECUQpRUcrjtAbSQJIjbFq8ublMH003xxBfUWQO0/ksMnIL3rjSuT+1CL4Bk P2z9oSGR4V+8NE7jBP4jNSj39CO0aX8WMN6CKLR3AP7DlgCbBGWAerlRXnmi6b2zj8ql0+31 YvzHtTBFGRp+TaV/f7TKQ6D5r7oqY2uRUw4jyYDe0dCd54Wmu6sqjDSbe6OWa7meImj5jp2f 6fhKLeyjSbsgAQH8notlcZhi8cEFrrmJjeupGz+YXJE8u8tFlW3j+7pyb1j1JvuTJdTvdJxK xAeW0t7fPNFcXmS9cqK6x1Mo2svk/CJJpV5HaRjY7OiOI8+9v2j5yxQwN4fjF433rwET5e4T XE708SGp/jkk02VkWkg/TgAVRjG7Yrj5AWw7HpizUL4J6EoMzqhFl+GYiIpKKmAOlYYBkw3W QXttfgiuydHVaZ8dZfUThsCe4LyMUGJc80wILS1WHb4EZfusBgk3KWidfK7K/MzF+oaxOW5+ MH+18TdkIQ93RiNLKng6JrmQwOaCVLtjyT5A2xPstdVJjsQ/C5s3e4P1TXRwmFsTRMywWlkl TdweSA/E7tnTGUpm6eRdXSzvGxdvsmZKOHhFP1FhUETOTv18yv7C9u/c+ijKheLGYbF4XvM3 0myDjJ5rJHNGpDDuCrBBhem35AYaLeR1Sny5kR4QXLD+0rGOlLmOjO+fxGuiBAZlDKYVXYCJ npup0qp2dc2nBuWniJvEzjqnlQ37QuyMylsrE+QvSfmkcjWT6iOG2HNhCAFTMYYnjdYGxcgY wabRHY41vsHeBwQMU6nHY+yMX0s7RaiUHXGaNyLpmh/ZsB6xsL46xVKG1gz6uJBDEaz4VZe0 XeekYjkUWMA6dFJTH3x8UFb9l3lFRg8QBw7ULHYkbIL2IhIfbycAr9WZ4x6quXRccjdU4Qh7 Fxd6UvsJh2gKubgd4lDDghpVPJ9382cST1NOIs2zlyY7Sa1b9OQkfTpwmAXCJ6JqLBLNj2UY KvTT0JvG45MzK8twQwGBJFgNth2/fNyyGtPXKlzTz20g0j+lI30bDuX5nRGWzgk6P6X5SdBa hGhRTdXsRnAbQaJjFdmLnAoR91o/uXY5LrcUKbfrIW+IAi7euRvtYGpA/pZSV2Yx455USG0b oOCdKDhJ/IfVCt50BYHVP4GB3FuGzp5+y59e7yxZXo1YosMUpBaIb5jD0uuEKUZFtduGnmNi vsEyIYlcMo8EPcIE6TQj29pb1a3D+vZOxK9e/Cr+MFtZredn/7U3FpS/wLCXU/wVvk8qMSmt NQ2MnWczmRCyYGwlPwDpdLy4PMpGJnlisG8jj1b1zCzET1hBFfQSsnj4XUikbrd0dPkeEpkg Z4cQsx5iazZbqz4PR2vkdFxI3uPWjT5JkPlaSIRcozyzWa6k9B3H8R/yZ9njDLLMSaF36QeS w8cbLQOhi+TqaQnoh19ntM5zWYL4tXbfMjfiy1IllaKxNwun08JdQTI80iOrdL98bz1ofLjN Zfw01ubawHUEyIoqMMC8thtntVS6gIRY+tcKqlcn6sDcJh9mSYvccYgTWnBV3jDaAU4TY9S8 YTXGu/SFLwlW73mpwQw4twzLwtxAZyWV9tLA9GUU32lLkRKCOiG8xLVrc2jCM2qNzoy6sUHf 66Aec2GjfvUXKUQBnW12+iaFb72cUJSw1zRjWb/ptZgPPhoUAKy2jAQRO4tdvctaTKkoSNn4 xYmlr1kRZpmRV02qxyRBSAsPGgSqpledKWvjuPV3Zx2v1LKxbXUj7e2GcEgVH/4ccCWMzDFy uxE0nATBCvvSVxGlvFveug+JBkxQ1B9eCzHO9EzF+/tVnjPh4ajja3+tJA1lxutueq3lPeTa qK5Rk5w0mu+NwJo54yZrlqBL4NxktoHYcGZA9onhk1Ib3dFsKKi3Bm5rKyyAlWbxysKDxxFN TyU3p7To6+OJLp+uEeo93DC4xux0jOdgFZWbM+wyUr4dmzIUZrRQGH1GZEHDsGM8BfOZwljf M+RkhobkRIL9fEKmJLpHHWnNh/RbVGmRQ9TgkXL7uZ/wG+i3CinINK5WFxt8dCJYhkJIpIum sjvLrz9FaNYmudkWw6bBCKrFPWeQiz7/z4gUePN/4ihITFNzZH8mhjpaO1PIhAzszW1cbaMR eTxbl7SSS4UPeHq3R7ujqLSXSfUs2HXoLuX3+SaKtz+BJfBFon8PV/hnI3czvFdiDGLKXbVV LHcCze+TNj/dlBuOvPhkII/87GD34EWOaLBPp5cm3eSp9PZhfQL0eoAu6cRVQPjbx60ySX2q frgyjzwaw26Fv8i5jjSyuS1pM+767jkvCzPmyTBb6uWx4Oyxxspux2sbYw4YUwTaCBE+Cuih LI2XL8fRf7EvhPoZ9s5uxQTFDJCDtWHhZp33j54UTd3mAgmYlEhIKRv9rTp0JhXfUh5HHDxm cpYP+ES9dKcFj3Mk4n1qTt2mCo4z3gsHDjymv+MRJ7hU9bFGnxThmrw8HsRQFIQbgaUaF/em z9T+U6glvq2IAB6rDXlrc6ms57ZuZTe+wUXIj53djhJoHgAIA77rQeIhYXYmhyW8UN83Fv14 iOphj/mRZRdTJQS3eZPP9X/oKolcXOsVBwSax+HqdEqIVWjIei7KumwsKtLaNHyMaaiJHZpl XKfhS03HrDe4MTqxmUk+yY/TrcEb4gCQjC9iKI4Theq+9lA/dSBjVZR8C8RR0QEo7HihQERz 1IzmFJjkyIJ+kHfyx/tDNMzYBOLYaaZox4PjfQE2oqbUan2R3M3NHeV5fujipC9alOaVhdsl Q7asdGbdj6NlDrLARYLy1bUxanPIBLb8EPGZlC6M/JrIxwbHAUi8fhxGcTJRQNAWMPu5XTIT Hp9QZ/O6OCJr0mjMMgqBl7rdTzmcqOJARw+xKsCot961c4ioW7JvZg8UrF/fA+nQT0vA3/ty Ar4N4j3EsLcfUd35GTBEKLxnDBfAYbBG4khkCxVsKJc5ib44/MC3FmWDsiwaXnYFkou5F7Fg PPCRRNeFev4cb4/BXrTmHVUofyfsZ5X67yf17WzUGNOEPZmtJxvuZW2oyOSZRVcitvenbVsI 4XIHu2W3O0G8FkWqVUmu7IAf04ai97pGU77WWpZsSa33bXruG6HKnMNO/2pDWhHDk4WGbg17 gmONDOciOG1pz3T8uE1GsZfikSAY1CunvliqXpUaK+1Ugp1E0SVOszHZTuSiDlQQtdiHH/bE BRYMMgLwezsacT8eNBgIYOfXsXszgwUumv7gYViqJnYgrOb4hODVeuPGJ3mnY0Hqm6Z4bxjj iYUOrK1TYtjBqOYJf+jcWc60yVaN2Hm2mH7JIvxx7HS5b80utIY4Ip6SPBX1lWOf+PLWOFHF RJeACTiISUPgDx46tYXVkLJr/FLeOkJ8gJFSUwFa3VRMy9YgUdO4kCyhCTxkAUwfpI8eZD6r PTOKKrecEfsXhhaTFSixyYioT0+N+UPNFNjZVqd3/aQgKJc/msNmDrPOoNDnGC/ssYM+uWzl Lijvw3ZJFGkFkI1mUURMGW0gdTwN4QEd5iuK1ikewNUqpOomgdHICIVyuukeqzcJyl7E3lSk lGUcQrAuT6ufkml/c9Bew5pB7YTqg+ROYoQuNBSEdPv0GKxxQJEOjC4+wJ4XdcqYo782EC5+ eeWHrbrbFvVqSp2YUpcsKy9X8QRAjqn4AOK3NGXYJaG4wkcEvx1PIRl2ZLuo6WmtK15+3EnS H4Qs+KiDqOp9J28JJFys3OVOcWtz4qwEeMgtRDahQXn6fIYzQnQtvw8NIntADN1RoIPnJyTX RlCyAc0O5CUoINNhqwzNjrN1LMkaM0Yc4+GLS0Gs+mgTwS2AwuLwvwsNnFpk5bLx4MAVpSx/ ILT4ty1M2q66n6JqR4QwL+XdOpJjju8Eo8tqXPV5ZCuzY2LYQctIvZrsYb5EBDPDcwkePaNJ xKUamnkIIf7BpnMmn67dJT3J38n55Ocevx1rve6c5weviR/2AmN/ldMHSZfdWVnCyp9PMQf2 l9LLfeJOnjj0AFs3v3HingxuMfdODcl2n9IeRT2IYAoBeHHt0CHNC2GmoQIMil6YHwhcCX4l vMQFMQIQPC9A2+CNmgh/KYc2oXUbM70kKCaNtR5gh0bUgma+HsuTVrvlRGoxtHIEShFJkg/X 5AnHzNhVpN0TlYIvlwXD4gXtFlBMYbDsZXDaya6Ya1S1ek7qk1U82yq2VDH6aiVDhR5zPrJ7 7Asgi4zQTJSaTy0jdvnGnZFj/GEJG6v1IuY+jDS6Cjjsbe1BVQn00VxAHECTovPYTTzLl4ng w1b58NWzBzZI1gsPkKD1OFTUF2NxcoTe6W9+8k2ExL6yy32mhWDgPbKzho5F3BMpNCrKOJm0 h84/kzzsDhWwLVd/BHV8h1XIrNRGYCoR6soe2mgt0s4TxsnlktvDb7pEb0hmizr0rmPxZ3nW 7HafdY6y4IVFYszjBJ5CmRh+x2M0Ir1r8ex9VFtu3nf2/LVsr6M7DufzNIYCgnmYxFBFsw1P 6IIS4jPHMuHJ/6DTbthaNNOXfPQljtl6oNflRdSHJVN12o9pl2flTcD38wsA0rpYinsOe04M LzM6uoU5lSy3E6gAJGyPCRUAxCNeI1HriC/piOOOSicQZaR9tMwsJaClTRBE8DLTmflwR8z+ F7kUmYcTMfdfb03Vi9SN0ObSaSz0+1LJiKkjBLOGjjHKP0GKMtyrZoC+rvPBedSW4Smv902k QLLiqy6Mslcoz9bdhDgafJvbC0P+Jcq7KeI58dFRQQDTG/o8pODbWStAjfkTZlwhb4Ibs9So IYb1djgI0NmJNTeCKtSJC6A/Z+sNnjCpRBOOnuHgdS3IlnoRp3fgfXkGCha5X8D/bO8v4IFy U3qGsFdjrkRnCbiOGHGxsz4mxn4xTpETxltN0bKzj/Qk5UHcOXQiZX598zbbV7m3BPU5lsJ1 YLkFY7g166dcojkSJwO8eKQuegqeQGyMOt1moH/NJlumeBG8RuiZ+0jAcIHT7mglAI29eX1P c7hLS5/+cq0E2LZKaNTuwM5Ie7q6swYdV97v70ZJ79/9cFphSbDm2e7fx1RNTDEOq4P5HAoX lV/8kqU8kshv+XmlcneAtfZpkQDh83QcHlNn8YsCOWIjTOJeRqvbDk9xs3rJF08NuD4dfy/3 RyLOmytGGkBUVXH2I8ipP/rlbo2wMKZUG1+KAi7zfqvcTJMGr9A2DX8qnfcFmxtn4CD1VxOe 0WD0iIEUbSVlTm34jn4HI8OHh5Q4mAm9fl0EBXnq4tf4FGusizvpuaw4jkWh12hmLw3uun5X /cEdF9MWD4OGleec+0peiTl2HjcjGOdyk4T9onw54SIO0El/+2fL9K6vziA9WKq6od8vDv7o xt2lW6UP2uaGwjuulOML9UFhuIl1cTToCxFQG1Ts5RxjYVWMWvkmHbI+/s/JwSW4g96oZo9V Q1qFGyrHDLAGcH1/Mo6GjJk+aMQcvtHAwtzQyGnYFRPUOhv7i37O+x6wnMgFBTrjjqEpXrA8 qd9+4owdlW2p3rXPCAYNlX/KmlKAbM2mdU/XiiDShj3+yb2/EI1UrSQKpcWSCFg+vvtgnDXQ mTSfy1QG5blahed4gDOYXi71LqiTwG90s4TYwAb+vaspIhJr8vmbQo1dXBvTBuP0+m1+ISSR l+an5RAxlyQoM8rMLtSi+twuk8IDLdVZJufgwzhvi3FffKgbXqOyUeBa/ZkfDl3uLp2NOwGM tWTXTEZINnym/4CTEwxjEUbb/lg8dwBSf4Cs3xrSZ0E9D3ohy5gaHjR0sJhoa/Wzko0mpZBN Qs5cqh0YNNmhE2NOZrI5T+MskqGflKBVyxcyXV8sQq4LWRPT6KqPz8DGSig/GUnBrv9TTmKF wDtv8v2cNqLYyy8d/lw5qODDEfgwr5Ips/8jxryvIlgs8zXIQEY0HCVp3kNg2Z0/wu91oNs7 SOm653fP1DvmvdL68UlrSfI/T3B3+rnU9WHlfDu2cYQlDzymDrYa9yoNI9hE7JET36JG7By2 R3aHZEduY2N03jINj0xoS0872qY6nepUvFHins39uQNXEdc1Pr+HLkYFMjog6k/mlnZAJmVz o9UwkzbR/Ap8m7KksGQ0uPLoHXIQSqop8HK6gh3npx2ZFl3yhbNK9su3y12CMvGjO+R3e/x7 kQScjDs5Gj7S6lZMlWWZDrFF2ZuZVVXo5R4mgaFcYOnqcpFh7ZKeFYniJTwB+f/nWW+dOPZH bHNQ3PnLfvea7DWM6KJSjOeyr+hEn3ztMkLLkOyh/KRs/t28uh3FLtcea67dfF246tQz+uGz u1YpTD4f0WzaAErMJJWAIQ5v9Rm49+AlyVwqYCW9Z1T8plTd0zCe8LuGTZkxVO+3xJi9M0HV t5u8e+YtMBP5c3QGeCWVqE12alGHvgozcTDdsiQGdiWzkWoFM9anYtgsmbduAWyzCiZ23dpE Qkc0wba/cbJtnWf0AyYrql4rEp8LxlIvf5Ok634aDnPzggtu1wa4rl4hArDErCrx3omdGUzp nLNqpWz5awk88PcyA513J3K2RzUqjpOHNIMwQ/Qe6uZAH2k5fZWJ/2ZyIHdVWrE6wsi8+0yL iR7IF7MzmSuWSA95RWBIStu/XNf4BI4pqtAuHk9H3uaPDCiPXJ384FM2IGXuK9EIST1NrCxn fhUsoUzKGHtCJBQpQ5l40unT8v8yoS2uVCfQKLsHJwd32irXuNVc3Vz/zasRwFP5zjV8tXzE e+C+A3EuDlZma25+md+jh23ax8L355G0h7EIkfpcySPItJ63fXLCkPRwLURZlRdg64rZTTz9 NnTEPoMNhjiAvDxUMn4JGNZpaNY3TmGfXe4CfY/Ywrhtv+oZTq9xr5qUB3rALgS1CEHtjpJC fpcUIceRDuFTJrg1NnV3VJkJFOh0afIVHlsYzowsMCdifyICoOYF5xH8rQhc1O5lR4CXVckZ KpbRudQF5xJX2Eque1mAYjPN73H1JD5SU/GscIqINr/lIHnkDidrJ90WeiOVhWVGz4sNEBxg cMdM8wIaM6Vfeku6jExFiWN0YNjy2mlHKXBkiGFM1gjTzEBpg8CgJp3IZRKCxvJlYR/SjOBd UZ5FXHc01hCmKF9GmKIfz9uB850qfW7RXxalglQ5mHLtdgpYfHQKxlNlHu+E43y7O7yiziAg 7KFAqcU3Eg6CxjC91MlR+ssTXxh4IJauljvxNDw4BV5yxUBNdgnFrXSJxdvj1ljZ6OU/Jhzb ZBRgOYkhyubmIOG6P8EcncOD1gXP+/UNRpSdB80swplTIKIDYv/P46g7XrlqT0laXyd8JvCR 3iFnZb45NksqmR1K+j9NN3KyYxkikVjv5lti0udqgrO+eGMtUp1s68cZWcfRxbCg8bdS6lwL Ov3jHOsDkgpePOQijhYH3WW+pmJuc+xCIP4CLGacsgv3h1IgN1AkYqqOKPMqsx1FVkENWwww OuXcahiWjE3DD98C++PH6ZrcFQeYnJvgGSAroEOFkktn8LAD62S178zo8mELS7EPnf7+WssW vLtY5RKwOMrLmh5CRoN7DNMgd04HsPJOyI8QBnt/AA/1h9L4iDJyAK9xG1KMMD6kr2AjEZ+Z /Tkw4PbpkPMdl5bCcF53ic3V60Oek/vjMnEgw52GIr/g+fGsfSyl1UWMFSYQ9+P0OTQW4PFD XlEWQ3fP/oBPyyzVaZC/wchbkrcaeUYnJL/ns9SIt4y4IfF2B+ssGaEbGvZpS5VBZLYtPVzP qYfRAfZj5GFO50h6JQJXbco8ZdWTjqu0bttR0wGjKrQWRzTxigpmuetDUGexEbFuoOj+xpBY sFYOS4hax397JDSvv7Q7wQHTuuEMRXYPho1S469axod0tO3E5eP5BwF5EWsGzXvc52wthv5I woGrXE44gNhUxPtLPrA5x/OiNRuTVwamJliR1/UO8SN4F2VI/V5exHV/RlwaofPubUH9TZme 1hymT0Ea1t3brGLtsrDIXAeE8h49pQ4ufVi2K/AdSPNFQxTMOuk/Qwnlyz67T2R279tjQ7Hi zQZiC6uTKW5I23dMqvFY59YY2mqLXl5XtLtWpTsIMwA3gQEYxA6DstSAaAAP0H947He2R/0L xvLw6JIOwtGYfzC5T/Xdj6yW4GhKP95lWeAv8zg/q2J/KEkQsFT+f0Anf78mT3BNrGtBiCXV 9457MLhHvhOhPnwuRCycZ1HCPs/rf/vNeqLbxhoUA1SnmUQCXodyidIETIA5RefRY+oCO8Y4 8vlrrtkdDLY34V6S753mJp7fLPk8r0L0+pyybvNLS2GFyfxDsBNhMIaKho2tvq19kdfokJFz uxzszYMkuKWPWirtfR5u4EKecgw+FS+4jQDSu3ZfBacbqu4kpiXf76Aql6uMIVJOm2/Nr4H2 zIPkDT748oPpfQeOkDQjpeWUGtlT9LznffgiDzoA8T9uI+j/5IQgwQXsofHi4Yp2c21UWcBT 7qQO1ZqC9rXgoU+zQ8+B5Y6jj+aD+1dXp3x0lWi/r6qxBP078+s4MxDdTvAB0v1veubiU5FU DX6CON3c6NEDICn46tKIQQ/zMVbaJn8OUOv1fFBsAp4RlwZnkKTWTFCil3oRikxc+1kp1yjN MWt8b/C8h7p70xsnTUM1o+RnHQfIQbMTIe0pEznOcrBY/ZxIxuj2iemy4hL1lROq2mum2L9m zYAXaC8vsAAQAnlAp8iVH9R6H5E/5XhlYNCTxQbpoGpzPGhA5UIc6vqM8zvq/BPcDi0nfxNf XCzP5y0sTJsIE6svPdQIxXfce/QwKVvmmen4XCU3o78b6h/mY7z7TnatYJ+LnTh0NtuUdpy8 dweKBOSz0UmEaNBb3agLIFOg31gHQFg92ywyXaoq+8YW98Xeqbu4HQz31plP/kT8mNDG1BHA T9YlsJVeOGdSyE+VvGdsxWOZPei/6CwYor991D+kgn2Xckq8f+IHd+uTyJ518HAddydVz230 pxXGFNoQrvF27D7ynU5PthuMVC1mWm+41Fa6SSiJpYGtn+ViYdHtI3KOBjhWETiHUAQvGXJT W01W241T24D0oafb/+IXyHsip8ehbddK5BG3LqdKLcjuMd7tGwOlOp/EQgZW56ufhHQiR8KA 4mstjqFz94I3Fv4itt5eJjrxN3cS3kotturjySLlu+mpXZUL8CNQeQevfVMUGFhwgvOUCQt9 uu/c8ChqNaKPW0RTdwc/3vd7Ka5HxohwKXcCBEE2eQ3vn5657AWhyh6jNkqcq7amposkkqVz Z4dKHABaXJoNdt5r6e1ZN6VYLN0ctirPIddMUommCmJ/7xxVbjJD+E18iHgy95/FVzJM4lFi Xg2Ig3mniwwikUH7UkPrsWyRjWrhTPowPBk99PZkIf5cwdQUJMmdamtBh2UWTEh/zViHbu6d PlJiprfxVX75OfUXB3Bua+MRy9TO6X/bPBRlVqpZGulsb6ZA65f+9IuQc4r4ScTPTG+rYMk1 VzW7y5fHqbuJPXzL3pk1WIx8joLiha6aFtSEY/uhZ5FW7Eekq071Oh6SHNtAk6FmpC22Baky NrXudGdt4w4YAk/Lvf9Zw0PdK0SVF9L7sZtGkh5S0NSSzPNtsm/mCZfssrVY2LgahNFJJhRB YcpaVQXYyRlySjqi9koSPXnbVhygC62mp22it+CIcybynVoTLQnYa7TQORLwEOEHSIVc3/St PmrP1NsUWJptuFsqFA6IXTbJcKg4DSoXo+ud7CP1dnPlJwzN7ndzMqwTwmYj0k3HVnsxG4AH tANfkThZNqA2yXFYidVJGi9PgpaoaH61jOW2o4SSVO+uM9ILBbzdZcu/xVhzTR9nkcmX5gfU f1iWSTO7x+9hbHJw5DZmCF9hra7IL+fN56ghpzimN/OsILVt0m53L6fWHCoAWrwLdffu1fGk oDCgFud5mFqVurAm20idJ+OMhIdkVdT0zyVniBC7uTPseE/oXJ+gglHpzgZPwVuHIaYa8zlS VFFtZ8VEAbf5nmYhniPc19/pYwFt1pMc8SnoLceNpW/dXRCI0gPKOLM00yfoT+KLDJ5rGKxd TVK/c25Lk4Yw7dwWhZs6enVkopfzSYwmXu1Jc9lDCKFkYTInUpyle1C9KLm/SoerjnaJYZZh Jlw3XoyolmMULDH5lHq4cXWu0KV4ci/DVXGpCrG6A35eH7afwg9tSbXS76aSwETdBaIVp8/F T4Eie6GEGmBpQidzLvDRQC8F6U16wOTSAXaE+taI+/h32lWnKdcapb9KQF2sOlkXXViChZuN kev62e14yrFDz5ETjzdfQTaIy9DOTKhcA7A9PeWXjANpOhWYY7KJhGZ2WIO2PzV2HPoY5a3L pEJBIVoaBREeGj25EWRwslDqbWxADUMoXtWRQqgdrZeT9Z4jwB+ykLGmcLlt95kKctpbc5ix E4UA6oLwFOxwFHixHdPVnH9Sc2ksLGpCo8lXYfFwcfqlJBiba53fnSj6Vhf+UHnI5S0tpYj4 t5U8mdFpo85jEolnfCWDgUNf1E2Vkrw1gU1f66AZMGNO7TtrVwpdi9ptCPFnZzKmfP5cEsLG 7MPJENYUmr3if70RSvGN7QpeJcsH9klf53ggVUg+CxrcpzfUyIuv9zuxNDV0Vtq2BBuXu/Y4 JSqz4LsfSOqI/oz4gf8CHlDff/qPGrO2klvwCXzO4xM51XNWDKn2xCjfA/zmPjjGjUejwW+j wHGoPii47IvipT+FQPLYzxx2ilFZT5x8UwbWgYbkhTMXQ6VZ4zHc6OaFEN6AnGVcjbG9yLvy oEb8qVKJ9j7B7ZADB7ZTbNR4LY2ARUfO23ftNSI6wg6XSujEX4Szlw2H/i5U662kMc7uAGpN +etvOP/97BXDRq5FDZt2LieWaqVKfOiApY8iANhFt1b/hLCKkgQq64INeAbIMea8DobLVZcI wwOSsBebm2Ket+SUVKt6jUSV2cEqty3MLrCFgbhhSOuK6XFxRGsBFNpwbveO0MonKeuQdYi8 8mqI3lqwd5N+sbRjSaRB1DOGq3UXBihMF8leYAII5716UDoh1ykBC9mnTYVDXsLZZ/A5EMEL MsdOLMl0GRna7abz8lMnx16ZzdsVQtEuTk0Ysk0goYi9IYC5heXyhsVuUuwDLGixiLTEsQOZ 95gI/sd0WCrjB/hvAtHD9ryUkuJrZQ80bfBrZ9fkFBj3vKzkSM/qUmU7Mdc76lOu1N5UEv4Y XC1EG79B5AJcqLVq+OOPNBoNqiFjM/F2TkUUMXvlnKWNY3qYcLDHf3RQrU/SfDB/7sXPkOy6 PfaaPxFQjmy3ApReUe3PmRzOl6t2CVef0JMezRd+jMl7iM80dbk36wMv60gIchkondJymZGE E1YdYgj/5YJNPlgyznEgo8Af5AcIXz3IjD05+ua+RVjXwez6mMxgcGmOK40uoVuOrS5MTnlM JMSbvph26VZm0z8fUD86OwPsifxFTrxnV6fC5BBw+PuxRIFHbBoiRZYgLqCYd47INnRhd4Lx kGtTJS4Mou98HgmIPpbNwxZJQl+JAsfXm9YSZ4cbTAV5prKxh4zcoZO8JCwV3iEQ7sdgOaCP ZAhiSOKMGIVmmeGTSnWAGW2kah4qmMO9rPETzdykvlaia6+tECpftF+lq8mR9OhER4CfYdb1 2/57Wx44GbV/DHuNmdSk6tBn/utNAKbp7TfxBlwSxpascxgov9ewgukUxnAMrqoOJLru0+Mc mP7jR7lN9N9I06njuSbeYtTsPXmPr5vEX7G3ysgih6pHJNIiQzQDo8YEo7bSk8x2wQNyouZE DqUbwaWPSZ5unob0eKLLQub4kTpiMVJOfrXNEVKg928FWMtl/rH5zFmL7s1nS6BAg1quZKlC v2Pj1pJQTEx5l+f68Y2Ine7xdmVdLCTRj+oNXIquc47oTVcXugUHTc5eGAQ6WkJqE1Cg/ak9 syE6dpQ8myTXF1gK3OPmzkr/aKOLFFpb+QhT77ymM3y4eVD2TGU8jZGLKbdzQs60+Q+AriCO 7bVCKpf82ZrfmnIDVVktxbzqNvnSLXsI3nHYo3B0WEyfz4iFQZK04O3eL8FLKWubpFcpXc1d O3A6FoAexsg8hHehtTbKTKkERXWeOr4F+i+cOtf2iRE/WNtKWlBHXybGPbxk6pWM/BHXeH19 1nJYxz6+KkU0XRoCwKQ7U78BTToZ9FmD7kZ/URdQ00yoc3R2/xMSYC6TXrstRwk05noFY+77 rosHMCHBDqCmyoEyrtKT/ZiDxJkLaB7BSFPZv/lGOW5GAVpp2Em2IZMyX7zrhw5mu24x3d2X uBS5CefLKq+rhWfli9gYzQUwMvWeIUTeDqyBuUX06RngNyNZWmGItOK/nzPdGyYaU8DlT4Sm qvkEAI4ptt2WToY+kLiN6gHv/KAxaHTUiWe0Vhs87UjXO3Wg34jJ7j59ggbFmxSB3BRrPOKz RJNAYfAhB5PouNPesZUqppUtPrcSePFnrhgeG8GnYmGxL8gLdDmG2dNoEjH9LIcY/+GJxNPV JqbjXa6N+57wzi+thOMG/dKVBNuDYg4jVjfCmV77dC7hwdHqUm0hOyGuyJ89+vaeXF0ab0m9 rA0gIIzeUUBos8jAXrgeLNWTw04U9Ey8kbm1tAM4NfMk87Tvu43jn1PtgsHfhgJ7DKb/drc4 nyzh0yXs+Gy0BsGHgVKBmWo94Mt8Xi5t9Umps0hfBhON1MJfeKZOCZx43agrC9i4ryAIM92S 1Y4tbf6Z0O55vmY4ugF3X39tW07Cl+VeR+ZWp1MhpSonXb1GOdcaWmgB/3RgKu9MImIWGR9z zv+NDEI884cz/j1vYhuXDVUB8nTp0qEV7srKw9gHMf+Cs6+xndZYKbSdb2ogGJi7C7I0JG4i olOliBegfCx6zaHKvkVDZ4gXWZtDIDARksIfnp/Ses8Jy81VxaRjnIjPpf5XoHT5Eu7z1EFt VVMFkg1FeyG7p3HGH+fdCLhQdI9EwgpQkq2BVz/PqCK5/BW3rLqUh4fwOtJU0UeujkTO101N AeogPJvLngBHWKI751LMFChUSQvgJ8GJe+SygtpBUf8grVgqQof4VV95E2z51u/d2UuVo0fL adjPlHY//dS04kLX1DWSeX2euU5jYuYVdRd6hx6Tvl2Pr+li5xPc2jbdWsgT4u65MV4whZwU 3cb1AkglHP4WolhbH7Sc0QBx7vtoKVVCx1n+hj05MxI2aiaOXfIVXL9odanGWCmqybtrvrqs JFTbvVBrxbnJZFqXhfz6LLW2qdf32FBE6visA+mukXIRrt8sLYPi32SlZ/0/h5tLj0SJdgro eQ9+RKmH1fyKPFK5bU8jraOvCdbIHXPpLzCZgOsL0yEqNH+v0y1orcdBTjU4cVGAnvcBIzXG SXVHdMyr7IC2+juqW3BNsVFuPVGWkDOT87vx5WYDVfUVFGQ03y1Rtnsx3QMRYuQKUsyMmr1y nk/bHsmzenBwHSNhuCHRTd6l7XDB8y3dSuenaugSi4ck3C5Pg8a5sMpItbN8NjtDu/UeTteD cTkS9ujkYGH3Ss//Uq4uGlPvaoVHtasa7n4MrNTTYSUKr3D9fDELnA1KANLlKv/ClQCvMkhI 1TQtwWnrYs+CCRK7dN9oKQiqXl3wsda7cgZNIpAepVsWo+z6IAEMieLmwc013z68CUcylVri rIZ16QbQMFg6rpyUzcjXkgtY2/MZDTTJTPBZCQc91WSgV+2iCOyexYdBA4Q8ZNYpgUjo42BD hZEUyMs4jKjuTz9LK+TJDNgJR4CZaXu/l1NwrAmk0oXVotu0ZdctAOyTIcZ05XKvHcwG5Ai0 U23hwujLupMFyUBtZgAbYsKwU+hlCgzsmhyWO4mZ1mbasoQGbMol+qQEAnqjxwDPZmJqxeyu ebKLD8QTKgTU3dOZ6t/yn0pI9YlglJI180TWqDNOFm8u/ELbNC2Ujl5vaOlMaV8nIg/zD/cx aOL652WmcVC5Yv6sXYPzpQ60qPOOl+NhMKnY1DhH/O8+uzzJKCfl/DoN7K6v7K0HLULBhJ/U a110IBXBRCcbg2pWMOHeEKwCxT3h3Yzjbq7GcMjY4RZgqBUP5zsL1btN8Bimq2oYcVE4UFBr Y2uIQO+pr0tzwxQ8urtaOlOyNwW302LgUPi4Lq97mv5EXBPVc9C4SQeK2FRZkN45LzQ/LNM7 XoGqiRbypW0MVxPmXZIgydMCjAhFGuem+qYR+rDyEYQaIcqXyG5kgg2NqruwyjHKpP4gDwsj p6h7MjtwkvQSwls15AU9pn2bgvJoKxj0J7r1ljrtZO85MfCMRfKFRA0a5z6cv+OmJSId/kpJ R1elhsQHiYU7f91+TKKz1eP0gbBI5dqodgC6tp/dzdGawYX6kybGScT6sa7MuFCtcyoM/qne dCWBKctlhvtTmjqzTzmbxVnG7uzqikb9cFEYx9E396SbeiCqrOTppOTkaDtWi7uyzOREVqSM QWrLmd1ygR/c2wOiLHsA/sUKoHdr0OJjTZVNVrZHjCYR5qWvVhOeJToFmG67p19oit1Kc7WS 1gSLQ6OKk7clI6W+2//UM4arb4cqK1C0zo2yWbvr2zRObqGMkwtvrXjOuWPKGDS6tpJzbgdB Byiks+vjilKf0x0SRyk6X05ySgWrgSKWi2VKZIaVTQxKGRmoVqoNFCUPoswGq9t2wJ2wFny4 k0RlAr7Y0qSvoiU+qKGN/gDylUPVmwfTiE0NdUztc3r6Fx8DicqyTDRA/8WysY+6thlvdELM oe99P+ecyeHwK9fj8f0CxvyLEu1XgUfueHI3iy2b9pMEVHPcB1O5j8Y1nuPovJz7p/A/1Hp9 y7SAQE4q3bP8YKqu8xFqF9oQKaW9D4kYnjGYT51ZOp4IcbgXPk2IRTQifMfj5JcYmPnZEwsM +rhFO93dFHN0Phu1Pl8eQxes363Xg3NVLARtvVRAuiYwqPk/46nKGfMQ+MJFmR+MfvUEVZoM zC0aeDRYMywkWgi8U+cIZo6y9S4o9YuUaP4fQcYzQ+6Bl3HSUvztFkpDflq4KTTIi3gT3Lem JTmo2vBWOXTCV2f3gHXfZcppvlcCi5i4LbgW4aD5w8FMFb+4rSbNJfa1JCcrmlf8Uj8Zq6aN VKat+73GMTa4o2PoXFJWcumLcovxMwBy1IBDmpV0KNNX0mE1uDg4HINBpHLvbpUvckqxM/kN 22aPzvB7TLAg52GILii//8Hi3T1U4GpPpfsrKgB9VdNnWL9x/kplmaX8qiYKmyDeR2Kx38L9 gCj5nsDI4b6mV7dYJnWUkpFE16qUhwiwyBYx+z9FdQM2LmCjdMsqt0oLkp4cV3e3i1P+NQDy 8CFD6nf7/kO7/ZT3T+QVVztUv3dl5OkK/X2pt5dhWvE/EpR7JgENVxQ/E1H5ktppAVkZ7HjN Wz49IjW7hLQk+cIGnPmQdJE0NDtyM6PuwKogR5z4NYgwie6/uxZxM/fRZfXFXOEgg8VOtpmL CemBbO2meg8N/kGa6I2gyEj6SEfATSRRzBuzw8tLK4FKkQ4h9Ty3OZaZgjOt2Q9gUb6qEM2s DiMh9KOYM39sKP0YxV2zF8VRsygIS97NmehkjwPSZf2x8kdGpM27M2uCeQv0dEIhfzRZGo+m CeF2zUteAxTNcxxJ260e5w4Ry9RZtV/XGxKMoEgbYUMob1RbIE/0TWdbiEzo7r3MTJ3/tLrN d909aXh0glpDMy1u7MK8vzVev9uyKXVbkBgxTgdmNJ7CuayPQW23sGofkh3AKLZGQiX/DQx5 WyOoOIfTSGWEg30BKK4ehMQgKZYzOIRlsnrUTGM9t8LTHutNrvKYxPw/aM/7nRb5wfoxgg53 fFsvg/yeUUrx28tv7FyeaRJmnwI6ZjPyYlFW5iS4aFhXwl7dh97Js9AsdMIiPUYiUckxVlo+ 4MzHXNfHs4JoL3HtvohsDVLD0oYCqpstW0cZZC8UB2jGCCxyM0J2UCb9fSUsQsEjGizW+Uqk i6ewuCZxbvEIT+wjTeafRE6wJ9/Mi4e6iexg0Sxe3u/lqL4VQig2LNPLvQRt8mCyTNlkSP4u z/PN+DOee8Ncy0U6w1sOC8kJvjgDZZ57P0d1Kfc/3U6TYZv/29sLmcWYWTRBDprsRD+VrSft +gOc8uFSSsRsAKWHx4YCVWe9A0QOpm7OErIbz8POEZkdnGqVZ8DKm9hSUiGO92Zhoct1jNa6 ihwNkTPLNGekfvHubcSTNr7P6Py2Irhxpm7cdLPH4Eqv864WAdOcnMloxkniqjaHOBnFrD51 9Nj/Mfou46QMdvxweqDm938Pl3NDUlMIjVdwMxt/OzZRmds7/Km5Nwwm3JPnbUyh7hZZ+QoX phhOzfH+nXplLucSokEzTN2dD0Ln/F85fzxwTvu05UJkZh145u9v4ZWmOkqpU7G4rkurVzq2 5Xoo4PvPI/rb+1fiCEo8B4fpfgff4CaTwy27qF7ZpSVpaB3QapbBRV6Ww04fpH8AyHJIoLMe UnkXNbaN4xW9NzyWTKnxSRZlAojCdvnpqhIs8iRUpliQ4+j7SV+xkZpmeZdyVy3/NFVRwEZL COQGSlSdAX8+Sd2ASgfWzG1jkCSuhNwPk2U/Vi/+lkOXurNgvZA1UaZqCI7kD+Bcq9twBJf0 bUn1mmzMyR+VjBXBQhZnGN1ns6yZF4A2u5Rdw+0JMPvS98sf4PxT1dQc62iJdEQKzzYoU4KV Eo++jeL/p2Jb+oGeynj1lSR+GHD38xRpznITl3JEyOo8WUe+vWMVpZ3BA9Ds+f43jW4WZ1Y2 Pl7GIoxbTiNqEfnA636Ew95M3OnDB3QXZ5R7rQEWm/BgUEbBSz4rarQVY73bBNFmJMF2Cb/i /q6//XMO2j0iNddo22vA/qZZBSquJgtOI7BGeesu/ttB9ZuOTsc4mzkMBgW6LN7VKjZLp+rk IY4cDoam7gNblRjPuAQiZ68WXH3+wgySydLJvYoZFp02Y52bqFB34oThclIjafEKMRojF/Te QomUu1oIoGCP8fRfE0O/gAoUsZxW73xaTJy9N8hj8jHWk/OB/n5joMtyJd7Ftkw0rhjhC5oZ mstcCIte1U632GZdgSvMNxOXBG2HQvmaN/MA0rRNmWc8rsseykMznAeEfdpDA+iPvaHH5zH6 m2StPnki8i9lG103DIHJ75S8KzdQmrsjHFIbyfYb9FZWLJhagmSGtopC0BMiRD+qxsYXrlgM TFznEEmCq6l7Mnl0gVdY5LBUi4p8ChoKvJxaJ0wrRU0zaB/0yrbI66IooXV6YPt4Bu8xoIp7 uQUOVDlpBxJJXAA3Vq/iHdJQ+msO3X0anNTbqkqbO6J2eyNnth6zM0z41u+k448N6BSIFJJB yyiMYG06syNM/gs5HQY9w8RLMufJGpoFl0AzFxnqxmTW8KcFFit6ocdmwujjt/HifM28ZVuf M5sP8dx+2qDkEZhi4mw+h6jJ2F+qXRiiWdR+godHsyYty9RiI+3JxATmmPw182fecJblmgBj K9GLdb3cfi2JftvaHit8KDyw6sPxekdd9QLz/YdEV9CFUhVlz0WFtJGUzz2yOkQSQS49jL5c Cr/89ssYbCF0wUeN6mQF9hGCfDuGuOPRRAnPp4cgoG+zC0xhVv73bJLAgckSeJwAA6bO8x65 RK69Bjju9Xr/QL4yUbeqLLbNJqkO78of88kADVt06l+EwaoXKTnssgsZIQ+8n5T1P+NEDgbh maH4CtCqgsvw519NM8Sz0pTvlOiwR++8Ug6f4qDJpYl52ojtNXXaIb44seOcPkinSTm5CUIo AQG5fDZjbuiXt31vs2Q1mEnj6sNgZDUgd62Znhw5Z45bDkLlBTWBiZ51FjRqyDh+hHx45hCf RwJngS0FAhr29J65eqFKZQx5iCZAOH2trlaThsUbF2Ec7TNYlCFbRGNt9L9Xzj6N/EWEQjkV 5Q6Otc4rqfqDADAWHHSioOW4StUjmp/GY+0Z1Jgi/M6C01faD/eFccVKhw/8qjI+EUIRRtEv JgI6eiqUOusyUCzV3jFyYgYdQijXiL/B6gdvfo7volA87fI9ETzVp6LtljODN0GKTrq6JBq8 nrsWT7pTDviSrv2apwQ+L6jOhhBlH5nwAnRN0+yWeGiyALokDl+244Q5krdJotXUQSJ7oMl0 jfUwANj1mBlq3rIrv7pWX01bNthiG1psupQ/iW53K17z5nMr/Nr3cg7JQVY2NuGT52v/LbA5 IaC5aAnB2pqt4FyI/pgm3d8cF4QnoLqXMJ7DS9pdYHpJ8PcvwdVLl8yeSBSxOciBWL6q/ckh 0UeRpxVsQzn7rs1bY1C1d+nqOQuYlYaUrXqWOeafiNUOjf8Bz8do53LT29+Fu/9K35mgt1zO FeBq9caYXUSS/AJH46fVYrXe1LUp7oq56P4dt/v6D6Wo2DCxl2XucbCzhkfswAv2UwLOLbHv p+yRegYRgxnV1GaNYtJA4o2Zo3jb6wo0KHH4f28lgq3yjdBCXa5JOpYgClSBQzSRRAxsoj/C 6nO03JCyueWX3fCg519o0cBrImHxPc4rIGNESB2hVEGXmXy6dLZdAw1VbS4EhRvhL9JVhBIu MZ7vemCA8b/ViamE7iXle5I6NzMHiZ/XSSo1lUuzANdTUslazUmYidwjjIITbF6n0LiOqlvr ywL9+jDcZlsStEoXPLCYGU8mbGmiZLTs2raKitO+OigIxGumam6v5XCxzmJ6FWP7jTfdYiEf bGEyrHkWzvgl5vrbbRHzYZhj54UdsXVuzx/KCofvD0mVu82MnAA0Qmln6EIQA8mczPsrCnQb nzFr3K1XSmu8lxfciOvS2kLBvvS4P0wSCR2y8tOUAQlp7jgUAFWmIJIRLrLudwG4O5mj50Ue FgU6EsKa2KyKGt2Vc6AEvukvpvDOuGR7jZWFTmtyu9CAAsIIspQ3OzZJCWZpcHk2g/fv8x4L xuJjG4giiAC0tO4lTJS7Myp2DLDrAP4OahTLOJMBUsfF2nJ9wn8NwBTdOZT68Kqqrb2YWr/m 7/TFuWas55DUFdnRZUNw4PyuUU2xhMKOJ5icLTVEcW39sAUAdXc1m+ZDRNuNKqaGDATcD9l0 st8pywa+RRtEH8lCzxFdYymLbziX6wDQgFMfNLFbnUoXI1uGV7iXkvy7QtMev3p2lF7zwAbb L5Fwlz3qbaICfD9PIFfQ7dMJTZvuj1/MsIcgH+PFU076l6cbaD/F7J7oM+uMhF6Blpu7CySY /MP1V/wAHlDGaDOHghe6lYHQoyINTXs65lLDOqNEoHfJ1PHgtfTos872kKQK27n0/TES48TA AFUMD83ZtvtAneQTE9tJyHTgRdXluZJecfgsnkpTa41hkVxGN0NX6dTmeCktceDldGvuz1uR PROZOGGsBvgUf5+Cd+oexzr9FeFd33kxrJSN4HfICp6B/UMVGinugUkh9z7SGS/SBFqXmGqY IWGjx5Xx8c08LsN/JC+zhnY016SZh5k1x/SJU/VA9/QSW1Z4m4fZgP0LsgjcvPe0O5PLc5Ak 0s/MP0NFWRXH+qWTEvWLQA983ZemXmIN50XNGHy5/L7n1HfZgwTuR/Ms0MJCGdI1/1rajh6t XbFyzsd4cNe/6uikSC0bspkqlsarZoHjS5O93ncvcKZmaF3UErIZnJR6aonf/4NkT/OcQRwN NdjuoM81nu2t/eNnpisgbA1UNkn4FXuVHHLYWvhrxb3SBMb+Mraai7ma8vExGgZ6yjyPs2MJ r6yHRodf7C4C4B1D8/3k5FkdoX5eXXBxVTocWY03I1a0t+RYgP6jWupvn3vEenVbNtmbqJV4 dounFJXP4cWybehFN7Mk5NAlGtVOXVr0JPdq9I5BxWS9D9F28lnixJHfdYbmJT/09G6RLSYO YFvvUrsnPIYXd6djbUpUYoY4mXCln1CFfQaPxlUopXw2TgFMbWyZQcGp7QOGtgy9XWaQDP8a WOMhQh67LDrEzfyLfue8LGFyun0itwg/z40Y5HmQmkZ+ULoOHrvrOLu/A1r2mIt8/SKCLdwS 32YDS+MP+jSjqhcB+9jiZZO1MyioxAb7KbU+x676Xql2tXhrtWTPSIzdQdvp6ciuytLpMLDW Mkn2NWHB4O1RqfU1fmnDcR/ykMul1kO9GsZ+FbjufPdyDggLLjoo2ZYSzAHW9PFKeRDf7RpR n5KbnN2CIkzAALDKqXmR+Pjwefl/oN70oPD+/afBZJyIDf6stNl+DnzEvCpSr48dWWOx1ojE xvJ2v7R4POVjRJhm7BGM34trNZqxC5ISoscVnkRXfe1h8bqw6f1As+sW0fDuqQChwv74I9+2 CowJRsBgj8VdS6Q9MlLIM2yq4ljHuEH5U+4Kf45Qkpmx30Yq3TnRwD2qL2AbBzYl36QE5BWj RTXwK2am6R2RzEe1rRdUm+KhdbKgonhI5aGVVJ9bEoD26eXi1PD0tWzOUwHNCcxz3Br0XQg/ o6Atw8zBwUQ7ANJmRkjpv3q51w+ZVnTkmIO3L0stCAk7YoZqWaSMDBscnIFmpEtdbK5EqOwH DsLlkiwa+3qE6c7Mll6QIZhd1jn+NogyLQNHOGMf2vy4/sEVSznSTntzB5iRI5aU1/OdsPnW ZkulPfPm0xiNCEzKfexELeOZ+0aw00Hcn8ropPLSfYpi8drtUNfXKdHzbqyZvFtF9o77Zc5F d10njGsA82n8KhSbxAisayroccKKKS9he6daV6pkUVVUks+gEC3Du7ZZo0C8nhVpaw8pMRR1 Iw8Q6o/kUMY9SuQ2EwGJ1lBhO2pF9YMV5DZMIO4TxAOPpmyg8iFcCjTtiv+K2U4JJUSF4CyP gijowTle/kI0XDFIsTMqlu28Cq2Mt0/ymg3iCwE39Apszg0+cXNmPkLs3lvalXUlCFbzDyiH lYhwz5mUYvqvIl/uSBpKsReZDGURIaOFFd5xNY/5EBZ5M9IlRfLkmLh3E56SL+qednyRFJTk 14T58rLzZWr/9kFHfLqF9nIBmm1ABSGQ6FJwRefi9G93vZIzaEuHGE07BmJMRHSoZmO4ApOD O/+YmgUOS0UIZG3H1RINJ+JIsJa7wRStvEEG77ynAKcVvHVktNioIQz22kFfodm7NEmBaqv0 +ZWVFjDonmrfaDVGAgunHjpQ31H4M+B1iON+c31HPQuCazHcB2Gxdyxvww/z3HMuSgQxmeiS KEinpvdcHqYAyt7z5HtL3gQ4yABiY0/LdALHi/EYE0BZCiS7LaQlgBXB1sMw/BT4bFIqYwk0 oVZDpk9kKH1AaMmCEFurYy1s+yhkjnUTtHuAuHCy8SdYVg6zW817BrE6/p9TB8BZ4qHv9dOG dM5xQLf4sPwdDrN7X1vvlEcg/l2kq6hzgb3W6hvFa/hUGCOW1163dhj+foxHJCaaJlAQs+lQ 8AVk2g0FdpBMiBeNte3C8hWWAgJTHRuLFHpLu6VXxRrbqI/04YDBEQjatQoz02Jl5/llEgjb qJE+zVCHnAMYhJ7eTzm5tFqOADAwKg62gKGfeT//H8/IDw7QlfIBTzIQNjT5Bogr8/tbFNgN j1NJ46D/dkKpxTI7nIGPp64Ne1VVYPFoMy4ceyuVucfK1VX+VcSn+qjS5l1hrftnnT3FQfpl Wdwhibrzrgm32mp2pn0jOjYA0lqVuLtasWtPSxjRd43pL8hGx7W8LMVJYcd/wYKYh//6sYBa VDonNraMZifvSZUNEZO921Ag2H0ib9btIrns3q9gv9yrYKVCWhWrSWto1e6hV28Hczz0Bjif mjKQOneu0O+5+/j7dHHyY5/HGs7+dpL2s2egR0oM69GQRAlEfbKPLifJUJuiPPaqmFboQQaS 5jjZ6W1NBbVQLBH6CitQ0fiX+YgaU2VIhrkPaSlNI9TKgkGEssxzkSff+zvBTafbC0w58axn nR8L8uJxgPwe5N3sgv2EHPx00qZNvIVRrqSuvnnXlTz77z4sBkQIIsxbu2WvkJecNIFmntO9 XMuYhwIXMsDkpL86NQAhtneGBxADnXeJdjzIQLLBfvKHfkAUd5BfhjOWN6sxZzHVrpsgv1hW VXRYdNwfeWNSNaHVGJt9kUekO4CBUL7RoUmH2iA25AOmsWzDCffpeMQFQKD2nMGh+nq+jXuS AgkEJECmUUJ8lyDH39Brjg6sa9CexAXg7bAKik9Iuy/Nu21P7wpJ3Eu5iosnOPpv0NolTFqE /+9115Tl2gfx4oGJYzKIUDgmtR9h767wkG54HUiT1ibADDCbPYjmixJn96SsVXYUdLuWhECb 04rjZoGa3OCmQKWIah1tKNC8zSgX/bEJYomZ8/DUkt7TUwsM6eoaC0OY/TtgNv3nxBcNUF9g p0txb9QoDvfGSiyRO837jdqd/lJ3Lx8T/ostbxCdVOzitTOZHa5rxCkCWM/u/kGTJvKGkMbT UGRokiVk9f0j2ktCdyVNQS5xU72U2grj2A8UYj5nu5jgudYblbwOUORu6L9uCqUZy566XKV/ n7lIp5XIRG55bUK3kM/deLhnciU4lRplBUF7tphMkxCEqzZ6Qcvo3uy6VlELaCR9SO1+3F8Y 1SynXdjUgr4Gh0/TTUkZyHQPaZcF/F6ACt+dcKIsazNMrSfkqiuaQ6ymqjWm3tZ0DSKclRuh z50lG/qPniIrVzp0kRL5phJGugRkHTbtHtSKwwYo3T7UH/vJYOvKSpZVBxcbUQT5Ca4KnxSV abSy1vIaCqECOoEwDpqOWzH7lWlYBWm1GSTsd2cMuRZ6SMGVgJDmSqTW7WOrN6Y3UUE0extb NMaPPMjyZFgKdColVXvoQ2n6BzNLoml+aW8gTJNh1TyZ0oAieTyd2xS6TaZyCILSHIX98n32 ls5MN08so251BUBRjzh9eryXym07Pah08jQgkow1AOhRgHLFvXEj9HnvjxoDZUFOt+RNRm9i MD90x2RaNpYPdkqjQU6YGrhjxwcweaEy+ZctDO1Y7QRaGD0NwyjOh5sLc0558/wEcj0lPmgT AqKLRChpRMPGDyibw6Mbs6tgX/Io3J9PvOYa2RA5bUS/q94hjsrH+gcXUUW22hsDHD/6dyt8 lGDHClBA+SJ6qS5qXNVy1wArTv4S2XQkNoCwDxIhbOWh7bHB2m1ifxEx13QjWzi5OXE4JTX+ L+/aMwsi/mHtk+0GrifHgsAiKNzLGYnrfEo6GcXVIKeNfj1OsfZUQAw4dBVvi4DzDQT7fNEl V4EPgoWFUrXlw77E2fvv3SkTtIPyRoTalZSjd08iYQUnKvr+3gpXqTveAoivjk6B7Z/2r5fj NOhkBIZeugrUCjBQAEgsr+0IYtuZBzMyPo9APGuMy4zDHk62N0Ac69gkEp18GSBTfurg98WV EXHOZkcrtbqTPNbQPwL5ARMhpDbuzJoL6OWh7tQAlT1jfO2auWmG9vSglGPOY475aK5YEiGx bKuoDHjxOpN1jQEL36HpI/azx1NRVF3SjktNDbhC6MUmksnzOeVjQQUT34csNOiKdeDB9zHG ULlO0cNdBC0Rm+GtiTlwFXLXRcsFwKvvGj/5cKEKTeIVeMA8ciihDC+sFBbGCFrXz5ZZJHkK VKLzYzR+WML0QWW6wzxVKxwSlWnnWhiT84K8WDagRhO3vr55An2+1ksVKK6unwKx3BQxWtrj odR3N7uIHQwM/30bNyQ9mlEt+jFzGbfaxTkq9UvL/qi95LyWGlTdR71+iGjyelu3A5CERGsO ZqT30GzADie9N4ZY2YTvjn2p11IJXMQdOObaTe9nbIo6pEQ0tNMPkvP1YfI90zGrsTKK3d6y V6++wS3izz40xpdzP2ekyZTBFhi2oGilCGCbvhKaTKghulx552nRCrrfbpWyAS6B+7EJ0VMp hQ6N44WHA+cIMboaGUM6UsiLKJ8A2gzJyvf3EVixhA/XI5a8VntQfKCSfMA96eujEY6CDKrJ ka9IEdJNoyYr5g/yD5MTGkXTAxNjli+AEkG+hoStJ0T1L5lu5KArnGnAnM/bjPOciCMsMcy4 0bq/LqKkBtrf9RermFdpm4ep53lmGA6+Cms75jXEhlVeLuoVJFTfgZTy5S+61Q/3Aka2cm1q R5qeMSIlNv3qp8i/IhscLNvswDu2YogcQtEDCsfC53yedn30jeQNkMP0nxyv4soo8E/c4tOT 5sE8k6wa+lNWsGfmVyfcs9sMbAho24Mp52QXxvPe7Xq8irvlcXmPt8h3J9GWAcSml1wIji5K Fu/1IXXMmOyiNcOaKWG8WfWHJiIr/UDnmOCUVV2QTzG72v+C9AiCfmQYIsHKWqTz1VnXCg3M /PAjy1ij3hDqHAaWD+4T8FaDY5lKgnWaSqhZH1DRUbjb40wqTnIDpkhsfdoCLMRxtzImAyK6 ZCKF7U+pKugO+AnMNDFHK5htlH26sspiSF3W3EfY0i6Km4z7Irx7Z6Q/a4RiuIBK2HCYsj+y Bh/mKUdt7676lPfYGFXzxaIOMSIugZkeIiTzsQOs0HNQICo0pnN/D7LxwYX1OlyqAqXeMgKZ 9P0qyypanZdGJGPeKjcQ3dgWH/oLg8RZuhZG15b7lmPsUb4TwbcnU5gaCz3D6/VnD0QonE7e K0CPV52tuqLNASvD1VY56evsGeHo1flP5m/uJ6vFoLOlqEw1hbA+1AQtWmnnlj8DnFOmwaL2 iX9vHVT9Bl2tj7q4QYjiul5XlxwSGlTm+VAttuu8JY75cpMpeK/I5MgtQM3zYI40W5GQH8Go BDGEgRrj1xawO/MhBZVKPItiz48WIu/PoJQUIq5nTYpqsbY0RTu4usKPIvndfdMCIpWEjIe2 IlB2KtbnpjrsUYzaJMwPx923duq5KAa0qGayw1/0lG6P0eM2SeCci+6XCS0eySYv8UV7HZRP WT8nSisUoLiR8MgoAcI5ozuyBQoghxFdMRtQK5bcvrzO+UVP2/+DkP/OexA708bquCIFVvte dhmjYbOf1Z33HwtEp3Ri41oqjCi1Kp3ulDnEOLgaQSAycymcx+mtnHx0iCb5AqlMY43+/iWP AeZKga2l5VAsxV+HOrUp9kveUC3Zj+BEi1j7edo/Dk24nv07+1mlpIZbIsKbxa2JroI9wNwt upKH9IspMcokPRsVSKgZx9U/1o/TbV0o7+TVYLEvCxjgIEZ6onLSYOodrYWlO4rMs7boTxoF 8i6DIU9w3NYmTF2OLtbuP2nuWPcCnvctTdgjnBTYG1Z4koBWD+D7E8wZKT/cqQgOZT7t76uj ME+dRIyKVugLMdLNf73K/LiqDjMLl5bzKIR0l1POXE+SnZoxJc/5VfpMvgcrv7WN1F0QTYof f5I6tLPo5g8mCveKUs02LB9pEqL7ZqzIHLL0RKZiuhLLVEW1J4jERBgx/d1GIUarx4pKLOzL PtldFKQEW5OkhfzSBYDEu4I/U/6Tt6UC6M/ZgmmxY9/mYjgh34SsU4frFi0nC2nXLaXnYKj5 WOr1KsNlqE0A5ncCsZ0VnJKrcU7K4CgQUexKA9svAT0veuITbDpwHTw0HbocVSMQ5TAZfF7b CgLAv0fyn5+EzAUZKggAxjnU48vWPWdFPRgObYF8H5Pevz1PSC1MfjjLu17jTBSuSX98kZMH pF6TEcN8VU32N1cva6pQAcffjov8OZ8TG/aHLKkRByicBVzM4UziI9LI+nSNkFFHPyRyWyog 8mO+Ww6b0ZwqrcwER15lOwAnw6dHxepmVL+xuTaGRrZD0cxTTFS0J490vee+tqh9nK6Wol3e rxhzZiTFH6WLnFVlYu007llbZPFfqsFrdPSSA2XdeWbJfUrquOv+pf8RDV+QYrfSpDXV3WEu DHh6PBNgKnODOb1NwXcMnDuf52cYm71+VgdkXcZs7qKlrvRbEgZIVUGeYHWFuPfkTjj8iZKf /FcJcIv2hpfmQXNAs+ffCv+WD8Nrz2RjEhg90fDV8hsSzx54SM1oVNlhhjl+OKFDYC7G4fR+ sR/NGgMQgw8mLiTjpac96jfqSCkedp6NoUzkpUM46Au6s96UqHv4TdTQYKURBp0GLDS9yaSS ibsoPrIhp1ZQjl0vPhNNELFSEvAscFoAOG3+NgD+uyjhldX1CuEs1F8R2fhgCYVMo5YaQx0Y gPxmSpTwg68vANsmXaNQvx24gmGJP6QAkICYSu541In2Hquqng7fsTn0OFtwnZruxyBIDwln luZ23fol8zmzpoGNbQ4RU4DFiF0nRAT7YKzvjon4BIok7T4n197zUw3qJiTSnVbsmbWpaxJo BzBTx/g1+YSw4WxtJU6pmCD9bGLSMgcnoK2UbIA3IqzDLAs8u6zyq/k0k5K5JOAKAxg3miCH H4ESlqzmXJg7Z8Ifbf4+LI01blOPj73vOCxoNPNnFYbblHkgz4cFljsspQGF1SdWp22hsPzZ 3N9IzJnxSs+wrhzR+uGrfqb0DbGBYMbAxj93mvS5fWX/nyLTSKWf8NNWhBe1ltOYUQQ7bDI3 e6yxw71AQRjvDWVuZHN0cmVhbQ1lbmRvYmoNMjQ0IDAgb2JqDTw8IC9UeXBlIC9YT2JqZWN0 IC9TdWJ0eXBlIC9JbWFnZSAvV2lkdGggNzYyIC9IZWlnaHQgNzM3IC9CaXRzUGVyQ29tcG9u ZW50IDggDS9Db2xvclNwYWNlIDIyNiAwIFIgL0xlbmd0aCA2OTM3IC9GaWx0ZXIgL0ZsYXRl RGVjb2RlID4+IA1zdHJlYW0NChpw4bPuV2CIaQdGYH1fzzLf6fCfP8UpmdXf02JBelJyoQh0 QTbZda/1LRhNYSWsOLl7qbywrE5FSmQFnMDpoUs/MKpiT1Gqd3A/B43wnn2/WApXo5sYV0BF LLZUltlmpeQX2a+Jat1s5HcKjU382zDHCgySUyt32ZwAsWPm1BVw0GCyXCgQ7ajmnSPro/mD xmvJu+vKv2waNGzlz9S2fd89/IB0Dwh3gJmkX7cV8o7tf1/gyvSdg+XkIuoJtlZUdzZ/dqGP Oc1Y4fdB+USslnJ1cTMLY1PAWk7s4MP+S6/+a0NAS6ZezgGHVpTasPPmDr7YAPy+6oTi06iO dTMgi8f2Lm8RMf1yjYnsSG5Tc5V7XiC1M0jKBZoOuB99EVq6CtckC0KOe8a29WCK5g5x9bxB dz05lxCSEoP2hhbCA/x8dI/EI3+pLD/geXPyhq8pthuDCnVCZN2+Z3rhAkW1JP2LBN0udahO n9r0MY8BzIdYlLvD0CsdTcAEvyc4fhPwmk3N9ikv4yAgJG/O9+O77QjtpWwPfn/2AEltvfN8 GUY7Iu+v/TlW7Om9Q4FG+/U30Gzve10dtLZ13flRwzhuP6c24ov6xFjTQTdRSOZbFRtfw/S0 EfZL8G6oqNxj3bcDR82wnv5ORyvmP+h/jvb8bGhGWI0b0JFBQ+RnhLNP8Fq4bGwxPJ2afPW2 bF0pUCBESk1N/fFBOzcaBXpDHia9mlFxndrTuchoCZDwO7Vge5tIBIGElpEIt5vTurwgPaN5 qHtqg5I4oUxnjXfhZhxTBEwM2YdiSKMydrITpGZt47etWCyQEJggBGKQe9A0/hzRmqFRhqiX asqJw0i973bMsqbwaW+bI05t/k+Dc95POXBnKczzNb6shMVdjRFL+9pPw2mckU2tWocWnwNf frJ6Vli896L4Zaf9ZbQTP91/8MEftMvC8EdIgPQFggfQkXG6ZMBe+7giDcBbSOPA58lw546V klU+Pd1iivZMWin1OOdH0AS6hEEtJuE7j3n/Bm08j7Rzxh3m8vTa52M8nkR7tUr+royZahku mqnbXzzr2ov3xoyEV3fHKaSb6QaGMjh2gHaa2vsFnAF/PlP/Ux8AR/4hs+no2icwwaDb1dyU wNu7m0propxppWn3rih9iJdN4TutUoW/R/lWpvevpesP7tzH57WgPgH+h0cQ0UrT1kXnJjbr CvCNIx1+ZMzBjuJuywpIXn/DWXXrx5tSiMG3w2SHxj2rU1K0F0KkhRlNt45sep4uLP6Ndrlf xEr2xg551pLf30UIUU+r6sl4MlLkXGGbPjcHYTd8Vg0sU2qqobPw+mAm0K5tkZgt+TU6/lQL KB7s9TilsTEm9g198zYBhGHof9YVMMclerIP2MJXfjnQtkYKeQEOywiQuaUPYq4k9iDNqsQB UPVMkwJ+AXko0MZvYeD9v+W/lRvEGGq/kab/e/3MumFCa9flsYR07ZO7jani/aRodx/zenMO pVyLGnbYtmEvClQ1stK6dtRCQji/XQNWNDOPvqanZr3d6JQ+ReZ3EPU7c2JqSwDENd1ZF5o/ BVgGs+TWEVdQ2xB2l3msEe+63GlTtbrkP3v5xMxdI8ODM7N7uoHSP568YjqY3/U1zZlztLpv eDvw6oS6YgMGjOuN9IVvMSV4RL5SvRATs9OGYoRxzB+p/0paI0bKgfqgmHWXXWtujvNSdLIz fA4W5S1CpnQqE1O0h9q+PRTvK1LYVxIpoWuFZCqNFps3lLeLFTXL05LMPqoUZg/5k1FddmHb ugjT9qrLWUiYQYIFqRQTGy2jkV6/GcxxkgA3Dcm3JjT6ljOdPEY5JV3Wb0jUFyrIovqFdu0H yzTWT3M4BbRjiLo6JmreSuz5gMEo9RhgRcpqXL0jDZkcFdgtYKInI0sIMOKt3E23G9tSjaO7 gvyG4NdLoDOEiygYLyYAb+bglXkSnYNzsRjNe6chQem1Xa8njjKI6TzZkE0fPIASCzzH/bd1 ooXxx15M16jBo9r1Prmt5zwIkCC1hX+rFJqrcQHg2kIkqGulR4KRsagn2Hrn28mJqKi7NCnf UfbkXpzBEUdjCp4TDImgCOMZFpsGAsKWlfhp51bvN9Uq4/X4nUlEsPXJ5z7rpxoVtGd0jOqz 5fp7mFo1gCFsoIyrqRTdvR4E4+Hfk8qJAbWsDfYcYRMchL+h5znoKCuVdwUakuakIN+HLq3/ 3Kui9IdAwSrO/0HIt/zCA6kQi7SQfrzcqXPJ2fY8LGdsgbkdy1VT/5pPBIzICLeis/0cfB/+ b2qydiWELbcSHKg17vPdQKONNFfLFuX5Z0fCw33LM4ILlxVxjQ68qLxt4Da9T+cpllPBd+Rb Z8dQEuSx2ed5sYbyZahpLLwcOe4BJgXwPaunVelTzBW0dnEldAYKZ8IeAOrZoV9Kelam1It1 FnMy9jSygybCGVhBFGFb0ylEkvmru05ErrfPMnZl2YVHhYcGkvqa/psjNWfi3nIzPpiLg8MC 9qgP/tK/89r2dEnVzKT2iFiyr/uxI5nGKmJb9Q7zyIqpSBege+edSfKrGovJCWGXw8pbJhDp bRRe88n4r7m9xtKXIuLefj7clNMJcwMoxK/L9D1fizWkALCemmTEOjJAMKyof/fEvhYFX2nZ XYAzFV7pu/1Mrq74VB/0i0vUE15ZuLtrJw9ynUY8LvVAFYQN2PDbKkJT1W4fJKDmWhl39j33 SImtb2ZyjFm3GTHwtZlNNACFvahHILYYolCWzhj8yCtITDkd1M54z9Xxplf2mvW9S3JOtP2A VkKrRruMKkdyWg6qPljTx4V26IN8etQ8s0pAV97cyFUMhKpw45WuIJzA3RRy1gQGm29Cdvkv YcHCH3QtK5A8nqjB9j24ggkeAiQqzxAatIw2QYYt2e3Cr6oyLwyQJ+BDjNfRfQNkWlXQU1nU PwEDc2e9aonzTcUhFIODGF5wGakLME2lvgqHYiQ73w5NIHhSt/NTWFUMyiYqQTwTsk7G8xgg ztNTo2JEpQL175rh6DqR2GgOZpOEBIZbm85jLct9PtvmbI162B5Eof5xuSLECvO8kE7693ZU FizMnTZ+HOHfrQh/eBo+PmJ4MW1eAWxGm2+M1wSpIa0cI7UOvYHDH4VJet8EM2RhLhfKVqK/ IcfOdvmlUFrB9SxIOk3D5y6hieyAsUK68gnyn+eM3jkr0sg1E6gsSdgMtlUbJaCTa298hDMV udNqJ393PQN8cdIhdmnYnCV/7+qY2dNWD8gGcrUXnE30sB2FShAkbZxd8eeRwhbvNuoiLPJu bG7TGEqG9yJTHp3LiWulzRMuGnH5MV9ifrJAmkpsZyqgZDqstUUl54OF6PB6aog5kQpudCkL YaMHGf+F3HeznWvMQ79qb72z3jmLYlpSFqFcZy7O1gHY6pdPYuUFm/Nn2HmxaZk/OBQK15fN 0GQt6vFdRra4tKl2D4ZFr6UXiAoybhtl2sKEXhQc/kFtmg9L03bXloM+X8PsSJcVUB97uds3 gtjUIeCKZeWk6urmbHWdkJI2niRo1iFH3wohop+nm04LXMr1Yx3nvCE1cA6zfAo0YmxypGOP Ea3rwndalz09wyVJrrY0YbcQexmY+OkXRYbvuNaJco4dVCtGDoqcbAiVP30NltGkLi3ATdWa ggeL2o0xrbEPiJ+wyXINJfLvo86qeYNQGT1OylDGnZ+8FAhCs1+Apzejqa9kmQBi+67D5g7g cPrsVMAETIIwbo4+nIBTxTPgSInFN+u850j5gHiLKkitfUoujguqlE/GpFMYl76XrIICEZlb PoD97oMnaGPH29zCIkPpC9ICQ3gMIkvbmCvbVj2uCov0Bkbgisrubhp17H/xwZFRQwaJltyJ fLfE0Wnea2NZFz+F4v5Ml7zP02yYgw8jrJpIi78rq7awGewP5ryIVeInJ381mzA3RnaDR4NP Hwbjrk+ZhMtyspMZ8kRCZGCPTJHsp/fszG1Zrrg02RLCE7VqDWQPy5UmpCCHDNNVrGHNAAOI OCdQSiMxYa1KGnDhR8+cwZr4dXuuaNP+l+SwrDTXIu/6Kqi/Kis8pvdtk1gIqM1euyV/mc/u kdktwy6ysAAJlMU7sATTWSFTozJ4596+RAFzvhqGzy7BEwyGp0BP5BojhNdH1vBU/gYAuVJC uSVmtBJ/0I3vxESNRWuJeFvxGIjnoGxigtEmen6+abPS55I4bimcWcK95S3Q/MmtFTligXVc 6PX2Z4/RUCZ9znZ3i6s16zFlwx64M4DIgKJv0e0EdAvs9PrRvjWveq6hpa5mCcatk957JMnw 80z7mKuVFsmn9SmwJRpOzTB5J+rnhCastkBjy0i+R0D1oSe0Irh0SXqxPADAi41HGQhyPv3M LYnxvhMF8kHttacOOSeaMwhfNmfgYFkNJ+axOGfnd4cje1ce+gs1/RZmCOsp2g543/xGhcgB fhvXsEbCNcVBYvoHYB0LTcns7FAEzvL76Qzcgrnoz02xIXzP1+yTvNKtttcIG51XdzjcTYsK 8Z2/6OHwHt0W9C4990+3q29jOuqKxz/1WOiokcGH8EFyScnso/gs+hgK/6WtuYIvYx5VLcj6 xSu5ozIBzfTP+z48CKEu1gTKoEYGFqSEAo6meGks8HcOAdkH19i5Tj/Ng3C3IED8lofdy/Qg CzfVVBbOg0Gf6A+Het0oFyvO00T8BoOn2fUiePntYkUv1OAVK1sUqfrnB6EjSoMueP9ulm78 Mly/Z6/9SSBMSGyAbDy5eJGCIQWFdkDSa3qnPHq6TNrmrWnUJmv4ER1Z0liAJFsULGuKfZBr +RKAj1acIMF3gqUaoNFPdI4S7BTkAOyjYf6BfRk7NtekGikZExuaod3ddUO3sPVXGgcLeGPI h+YzkF/aQId2O/vP0KX0d/UCj5ZN+JvBQ8yKTMdmmxkOQQ1JDP8A1hTGwIHWx0CSl0Vx7lKt AIVKaYJ2cv2q3NlTbnxOU1flcoAkhhWC6paStCs8O2XZAhIEFnuqxjs0brjUIrEloKsYG202 az9VI0m2BxIMBd0NLd+qxFIQf0yfntCQpBlEMSMg86cLsZqj34uqn20i0ISv2I3OaIBP88aa 6LsrBVf+yVGNuB+aXwT/dCu++UboFV7VQiYXSOw7eKC8aAu6L0wMrdyk2zbKUWZ8zIhQPNBx X1Mwf2IRJGXwTXbLW1iPZc62hwhZpS9EvOCHlRKVhKA3W6FZffYVfwI6K50F3HbdOYZr2BK7 avJmciehx4JvWK9DRvHVXckv+2F9FjZhKQuW/09JJMbQM+VoW+e3AjLyFRTee0mlWLFzPPc3 BVcWG86w0UWaZ9gYG7PNH5/ydiPX4Hha7PwT96xfd0X2jkLcoTRa+HN95J6NpgDoTwjiqQdF 63Yf9GkGsUJe0jzrFwKq0xmB/HUeCvhdISq7xsH02JB9WyLdmJBDrFqN9bXkma0pcuLrdpC7 5wQ8rlugvxdz5wVRJ3QLZAAbRF4EzzkO8CFR8wNObuz+XpJzOz3vjz8fZQCNJTYGUZJzy7zW 1sZ68eciWYzm+QkXrwGfUFvE9US5DW/0hno6CKqTtKWtRed+d213PW9iU0lyvY9ok8RYMCMu pBoWxLsw+rF2nFkYhgp7mUqjcmUJJTpP/G4uUuXW4MerD+hcQgIZnaQJcZVo9SrvJtQGlRiN pS/OPl1lYtjR5JMohAhLlUCpbo4D11kIYJc5shaJIQiKdd9oHtfdXjTFnNQGMDMcuYQV4it6 fCnd8/0VJm8keNz1lqta1AQ9heN9s0oiqV7CP1FjFYDIj/joXELVGKrXdhZpzFM94kc1v7dj xtKw+yTr/9RqJFWj4omsapKj/sAK5vA7cWzhgOTYVbIq4KUgZugKNlrfZ9ZamA0d/B+sOzz8 4o7KbEcwcoZXNRwsbWF9HjdAaSBMyniJZI7POa5YRsQsHKeLb/CtucZvvdPCSbLQHcqO37Fz pxm/V5/2QVDYYb0w1S6IZPlRgGtCtZFgXlkedFO+hAadsOPxFxbOAkma92N23bpWyz+fsoUN H0yWCJNkzXQH2n2+BHAvyC1BOx3OI6xCCdIC/SZxdTUwyZAeWbgVKT7F/Xm/gyjbbojATYDM MVJVuhXhcNNN8SMlEwBhgYDYC7s3F2i92cBz/wzcNSb/2q65nmzx0UWCuO8yPowwFG2Zuw48 VTchehuLGtRioTOSv0i9Kzx9c3AlVKHOIw+gRxprCVgWyFLyRFYXHMUrvaStLp2lfrK70jfm WvB4xMFJXFSHgn8785HoC8SJTKFgH7+Ws2JuOf77s6Rm2PFDfX4OqzCxtA3Ph36mYial5s09 Obc5ahTVTku7O3MZ1O56HVPsv9ixvmVEvyQMOhQZjKE89gBG6C9jgyD/IO7hvX2kp5Qcr8Db RhpYou6Xy6wZ6qd4COtq3aqjQgJ+W2LZOVmJdO0Gs0ntpAj8R3m7iJvtDb0k8pCjvoLgOHHW N4WR0x9hnGAzMa4ZI2ir1yt4vxlg79LZzke3WSMz2nIYqL8mN9ifxmt+SA8JddIkTvgkrZqn O+P4u5SNWzy2o5bix53c0Przm4siz4Keb85sYPmYh3n2CHqjwcBKUr/yELY9tkcRjqz1dRGV BKE+lOs6g8+eRrhrurDyu0mCTpdTlln7uL3ELE5bCOg0uOcT0gkC7F21BiEqeHnngdB6ybs8 2cuhCfGgl320QjT9jJDlmk+m5mb3Rn9L8p3IcAiuMYeREUSd4vsFn7td8Ih0N0Wj5XgBTT+M tTl5G+0tXLugfgvGX06uQhUAThy6edGgDzfZH4dbQy56Wkus4BJo3eQnhv50PZJegK1XyvD0 bmYg1I0Zpts75UQGjl1lSqUFbX9QeTz4Ddkel85TKyNHNTw4dDtErv2fqaObFFsBnbnUTVHd 3r2wW4NZUUsKtxGVHuRkbIdKE44f30zwpdoRjr3HV0RvVLs776hwfuQSNKu4EKvFyQZ6+6oS ft1/uQS1KpOxSR6j7ZHhdP+wPlSjaBYhu7c0CGpXr5DOeiH0SrHb5eLktlsWuzV9HqUWrMG1 t16n3hgBl2nwc3r08TTH1CvjhKLO1D7gzM+PMSLNSbAfhVJAJ/RnZdVtpj6QrUKe4SU342cu GJ1j8oqBOAgVrO8mN5/FhrFpt7oku4i/PE4XMiNpO2GcKGasLHsVnbA28mcPBeXtiFRFj+zT h3H21Z8uIE1bPbbyD9amcll0Bi5wobH66x8QDCYr5VxlJAlk+nUzWsRslkX9+N7WS+4YYesp tYD34aDPXuFPrCIVTsDYDyTkZffbqnmn2MbMIVu0rkDAVKVMbAVST6jaqU0K3tjelk6pwJr9 LR97mVGhmgHVe/iXozmpAKnxlv5WZDGg/nMFrQWc5J7BlxOGEKa0m3Btijz8oEVaAmR21Whj mYc5QEIjaiNTaVxFgwLV1sT+TuWhACiySN+gRZa20eOMUNtfNM8+2WghwGl8HB1KAWiD0Ttk fE1G7AgM04G6Aka/NzdU88oq15wFahqK6BqBlyNdNLdIrD9MWsY/Bu9mV82lKwgaFXsHlgmd PMUMuf8zA/op8P48tYfyPEiA7YemtqZWQQyJHvpKCV8r7lJV5fg+j3iGpZfF4hqnzMH/OZm3 XYXZWt9RUPwk0R+PZF7oHcaJHmPKJhoMMq0EfhnzAf01FGkJ862xeIh+l2uPyYZdgXbsJChM 2obqx2erY4RIxxClYmEPniZFlQf9UhNH+9ifD/0V9ymWiuug0y3N/uuCrTCluoT21BxMzMS7 1bfAkAGZWXNanbkcjLHaheuRAmcC/986dUED/+bQOnBqyHTkZXVhnhRWvwTd9J6VJLcCHSMM sqvxPGJXViHR6PoWoZcvS2wEzFjBRnnH1S1/GAvj2iwNOPwuE+mSlk9vsufl9lvcAI82dUpf sbUpG3ZlcSws7HFJ62GSUIv/ngMsqfsM5CDRfcn3EfEKa9UI/dwdyXGtMrkESYmxbDd+CLui ZIB9W2goFq6l0dQjfzDrZ0wtNR4FZLKXO6hdGZZX375kFg96Qcwh2D8vz4HFUUI0OrINmn7k Kw8qnxKYWRn+mgQs2UiU9qeH1DNF/gRzZEwQaIuURYoZ3t/Ng99j1sEVX5VdkuWg+jDfNedS ceW5/FDCq6F8sJBJr6/tZr7xS/tBKFVEm082s+rdSZLB9xvfBshjI3+BtpbcSGx3VIR5h5mK kbP1M77NifteRQrt5l7l8FFpMk5rxvJ4NkjnSrrka5ThjOEwQ+i3pCDqGYYCgkS+VlSe8sy6 AOLK1/AGeB0qduWpoBgV6orXsrtBjOihkvUIgz4BvCFJkvPXh+gs2iV4SA63XfbF+F+1Nl50 ybBgs0XvbxiQmAPHwbxIRDSEuGGLORM2ZQK9PX7VDi7kLdjESyuJSVTRuKdBwPAouJn4N0c/ 1O+YR8EzVBd/nxHRoqgVg2Q0R+qNvVJFTTVFmbRzcpVioAEAsfybf/5pxnWIUbbEGg6cimMy x09o9IZkh+FlqKtC2Il0Sv5QM1ZZgvljVRjbE7ls3aCouNGgkNICNZeOxr0bSTsxPsP1Jbka RxEapB2DVjWY1P+HNoKEf/N7VyR4+xaVVQmmzUdpk3hkcE+VnOhPsOSpWU1uC2YGz4bZf/FA o1WE+qQ80gHjZh7V1fbJOfeMTtM7FBaUvloyBzIlfAUF2EWtJcnKUF+xf6TYQOcRykXQVqdn Sd8IsI7QCufrC+Bem1LW66Oh7ad1UF60NCtac5bRJ56wR9TleBdtt1IPbuH2kjCJmuFZD5RW 99zoAJKjeoAanunlsHICYs/9XGtYip6nIk6VJkfnJUkeXeUUdIqSEYbt5+KDrFSICQlrqSAs 7dxgl48wHzX2h71x2xLiN4GVwx8DvEABSx5cZbYycWWMalTV5sYbM2J3eINYGU7a1kDQWyt0 RDtBK33I4zET3soQXZeYovCt4mznDYiZ4Ra9RdzNROgNQyKgtCBgFvjGIRwcZWiBD5Ibxe/9 p8muRZ1r0K/O0IEm7ckDSrcyJicugPQppJrpg/w1KGvpFUGPttcetaa5k/2+H4k97t+bCqAE S4grTeFxrz7xlsHa/klRqqbv4upYrzEDudXhb93MKeaQ1DjRVEEqjUbp8deXBpAtHm6Z8Wf9 M3rqXCh3L86R4kOvHoyxi0gTEkdC/YNL8WDqqm/1MPT0Kb8cuJ2T7Ep9Ccm8pS/l1DrVZIg1 TFisMjEDjEKwFuLZt5A1I1X24k/+gswIK8Z36SuWv4vgJWsgW46UigfO3pgNZW5kc3RyZWFt DWVuZG9iag0xIDAgb2JqDTw8IA0vVHlwZSAvUGFnZSANL1BhcmVudCAyMTEgMCBSIA0vUmVz b3VyY2VzIDIgMCBSIA0vQ29udGVudHMgMyAwIFIgDS9UaHVtYiAxNDggMCBSIA0vTWVkaWFC b3ggWyAwIDAgNjEyIDc5MiBdIA0vQ3JvcEJveCBbIDAgMCA2MTIgNzkyIF0gDS9Sb3RhdGUg MCANPj4gDWVuZG9iag0yIDAgb2JqDTw8IA0vUHJvY1NldCBbIC9QREYgL1RleHQgXSANL0Zv bnQgPDwgL1RUMTEgMjI4IDAgUiAvVFQxMyAxMTQgMCBSIC9UVDE0IDExNSAwIFIgPj4gDS9F eHRHU3RhdGUgPDwgL0dTMiAyMzkgMCBSID4+IA0vQ29sb3JTcGFjZSA8PCAvQ3M4IDIyMiAw IFIgPj4gDT4+IA1lbmRvYmoNMyAwIG9iag08PCAvTGVuZ3RoIDI3NzIgL0ZpbHRlciAvRmxh dGVEZWNvZGUgPj4gDXN0cmVhbQ0KAfA/c/AA5F3MRsoDzxL0JloOj6knox7el/juX71KJsYT oUg6AgY9lwCmBI69j5w+PR49kCbZNeTt5c0I8fxvoW74D/y72/koKvrkXEY+ezgvIOz3QCDb WTwiESrSoLwV82RzWX5mr7tsr26t5QFklKOwIZf0cTAaZo02YD+WYkV5JNRdGvRIwI8TnUXy zS81jDWg2bMfy6UL/PErKnZt1jLtiUQpTxPu6jflg771lNzC7WM5q3PbrPlK4eAjdVpbOuNF O4EoDWD5YL1miYEbBKVVWmEZXPD7x0ilrZ8QyG8hHhYLZhjIJypxUh0YQl4jGEvSmikl/izJ r+82FbSvLbnyCwV7/dNkNWmoLkl97GFniTgDrfDnBjdbjm3qFIYLBNOGDabtfoGQmi59rUrK NskBQwuSkn8w/7jcWCtbp+sqK5A0ziW69Nio2wxyeDckwZl5AE8zHL626qiEBBGKZat8H8rl +ZWil1Ov9sGytb5sdfGEuQdRpbxwDiiKY29avXRAK+ycxDpBvHWBx59SuCD8PiHUAmCJvZrr HcSyFAXAvrNzn7/JdFspTOSGZkHNO2WNZRkElsi7CKaBJLVd1nhgKOpobBhXicXwhWKeUEjc RKWR9FrPxfkY9kH4hWspYq/6zzrgoniDGvK2Wp1/0GlsetmC6/ATGCuuzNroPJkIQ7V6qw3R LjXjTuV/bnYd2fjZqfT6KYySYqHnJAmc7md6MYzldzOzvybjTjLaHLCZQ/DzYC3C0kMbj2n8 R1iniwEm5CHzq02JvxOeL2bGl+bK8o/yfg9Kfns4xu5ZmnKGEpzpnGEt7MLgeQ9oYmT6WeGz IwcBFRonrvEnDFDq1Bg+cWrHTFHFOsmQduMB0MNbcDK6/HQIMnlsqAKkjdGSrwmZ+0sY/r4X mHJRYUiJKEaPzMVcAwGCJbAbS9o9fgG0YCiNmkxAgCvGJJ9ZZB8/wwW3/CEnJmySV0xt8lX1 XMUHQaaycIcL2ELtnRlbiRMIQdRSkeW1FIhkTJS8SZXKf4kjtBMTsOwGGZfUjqwFofBu2vfR p2xraoxWk5xlluqo3Ps1o6xiAIxzN6xpxIwu1P51iXEZif3qf5+JwDrH09f5XDLeGmZcKPh6 +EYVe1pvTt0oz02u4KfDDTDEjHMGxPZQnhC1qty2r03Me0UtyUgbbyum2PSLKuKlDbp8SSey 1iXBTE4/nrs+AoYo4OPU9rYo9dSUy1tspX+jBcFVDvphTTjd6zXwSKaKhjQSFUC1oWrlLOUe N53UmndiwxsqDWDurrrEO/Vu7djGjE8NoqtqwX6Vo9UTk3f0Y/d6IddGKcjosHTWrhBcPQf3 Yag9HUhPL2rWzdqUCM9H1QhMxqwBJyR57QsPvMBWovgKaaKvm7gHpCJsoTBnKYX9kCOyNxxy y/4WQ/CqB7ujMSAodWD89KmFJPorlXOKn6q7FEFieYze2hNFlb19OAah4qBFetRd55vK4TD1 hEVjn6pcRZ52CIsBYEuvsi53TjnfCXG15xvz2qm/DFOlu28/1nR7rRpmnx2DfrahaFdABrj8 Vh8ZrLDoc9kwSCSb56aboYcTVehCRsoX/+iDTncOJTJ8eIfbWxZfcrAZMfI2mirvOKHJ5sup HN07l/SfB1W4IwmmQK7lNvuMa3p+yeKrLgcG6MtmDuC/p5Xy2HDf0JV+uz75LvvCvwFwh5Ej /uZ/c+vvP/e03ooX3gvscuak4FRjV7JouyXOlDPun45d8/1qL3ZwEydU+OfS8SZry1gCkc4h DsLtT6M1WSVCBDd3LjYaGV8KgXEaPzM1OeeOZdAAsJflndCMKLP8C2GDWoblp1AMNtCA4MhG lZJbY7l3XKhoLihpDysV6MrH7FmfnEFQ0bYlWz2GWpRde9ubYdmhNB3f7IzbsR4PMuJMvJ0W jLZft7w8v9Qh3jEAOpH8hEoUHyvy6FonvBsWiVI5jvOtHyHm4YB1pKZ/oddRdjgiMgiYz6cc 9UTVx7gE2NcoonnRRmb5Xrr20W6AB5krZ837ltwKhNVSPIk+XgD+lwf5q+Vf6RB9OnEnkvGp R4dpJ56yW/F+KEMz7kqC9vnssYANMSVMA4HJPAXHF0VBurbspbO46bV2OEK24HpVinmBM3Mf gAVFdEZMkj7sHvXoQPF1RKdsR8OE5Jc155A3Vd3xiGTa3pETbG6Q3Ra5lRRXwdVGmM1Zmyht O78D7/Wi7O+R+LrEpoJaCz3nkqt9XXzSaOuCF6e+7k2zePoH2SztERn4BWyL65kM0AJ2wSW8 2xDHK7r5FQTZyWyxHC7wiT6A9U5OA7a6ls9GMNrqVcEII1Vm3E0kx8YlF+qaWSpMj232ctEY coTpNyD3wj0FUKPihU/ilrQX/qH7/LY6micuNbtEn7iVz4KT8LRK3VzUm4Qu392PGsoN1/3L 3Sem+4JRcQkP8L9gVWxZe1rMDsaGG8NscqjMLnrS7VbtjQrrBN8vMDYra7vmwOU+PXl8HiW7 ilctSTQtXkeNeEU/5hPIwrA5E8/6KMfdBC9ZdXbvHMiT6PEudB4h5uWP5krF0xbAQaAVRnkF rFmt8adBAfSQC3wnATKlSHFuJ/dvsfNvrWfy9c4iiZcyR7ftPFcTmZqgLpnXECImhGf3bQfG HMPVqn2huhKm8AYUVEaSMOAtC9+E139iVqhxJH6nvWNZB6PUn/u5WPFpCe/kF6S9xaphC4Os aPzSEBlegA/OIcEWD3UwSTvTSlVJcE+irQ2E5zhbsQ9QSmK3R0Wqj0lMWsSvJJ3jO0QBtOJd dSaPGzlRxIGwnjSXuht5+xfqMFXpnjala/6Sf7revpbBsA6177x8n+cEWxs7maWSPOYVRbMc iDjYCEv1yRnk2jhbCfFBlK96XqMhZTIPxeo+b50MJn/bGsnpTZ6pw/6EaCFN2n5zLNK3GGv7 OP2AS5jdAj4wJaDBLVskcmg8Q4yTf0MFTemLsOymzI/2uRr1e8imcBPG2hzx5KOhogDt9x/U lbOzqmSrRN4EdMgA9hvSQC2DHycS61RCdbjd/NW/3JfrqGD482KC6d4fmXL2WaqsXzlrXk/L 6Yy3d2X73a1ULd/ZokmqS9vPH4DpEZxsfQtAbJiD6emXlO2HvL4tsLS+Zv9q8O/s0IB6j4o6 4X4rxDJ16yPBCNSAAjbc4BDih5ublN/vijakdVNLI411xYh8u6nQeX6I5HZjU5k+S+yzWOWx y1f4wtUNnEkd1kJG20MifkPmIEH70vKIdh1JFa/WCNqTUy0oeMEq7vOlkBSd/CkM9TY3bFNL 5gScdrPlkrnVe/ThC78Sba695KAiKoEcd4P/SRZsQbCDT/ggybNsurQTx0sLogQ1QCzhhRXr gdlJrYVNuOxRbehojzDWfG+6mgbSVjAmH0j45BAVUofnC+GdRIn+tD6XjIbl9keNc0cFkMp5 0CAJFh02qZmDnGOvenwFwTMw0IYFSWdJYtWXsUPktsM0bTqAfgM1Oh+DSneGvrrP2BfY7sE8 rmesUlDyOGGmN7nFvqbYhx5WmBLzEyuCWylbG8h3SJnSvAcL6KYC0KlbT5cKUq/UXnhDMX/Y xIECbHZ+Y1723J658l6x99GnFBW3EPuhCx8LQtMkgE+sAH2MWl9AzJY0dHv8skzcwccOgsUj G1n4dwFLslJjQW0yctFpf3Kqe0J5ub8OAPy9U75n+XasRiuRRy+pDWVuZHN0cmVhbQ1lbmRv YmoNNCAwIG9iag08PCANL1R5cGUgL1BhZ2UgDS9QYXJlbnQgMjExIDAgUiANL1Jlc291cmNl cyA1IDAgUiANL0NvbnRlbnRzIDYgMCBSIA0vVGh1bWIgMTUwIDAgUiANL01lZGlhQm94IFsg MCAwIDYxMiA3OTIgXSANL0Nyb3BCb3ggWyAwIDAgNjEyIDc5MiBdIA0vUm90YXRlIDAgDT4+ IA1lbmRvYmoNNSAwIG9iag08PCANL1Byb2NTZXQgWyAvUERGIC9UZXh0IF0gDS9Gb250IDw8 IC9UVDExIDIyOCAwIFIgL1RUMTMgMTE0IDAgUiA+PiANL0V4dEdTdGF0ZSA8PCAvR1MyIDIz OSAwIFIgPj4gDS9Db2xvclNwYWNlIDw8IC9DczggMjIyIDAgUiA+PiANPj4gDWVuZG9iag02 IDAgb2JqDTw8IC9MZW5ndGggMjI1MiAvRmlsdGVyIC9GbGF0ZURlY29kZSA+PiANc3RyZWFt DQqz2ib2xtPk0OlK/yfTNKa8UXq2Wn6mcbs5ny6N0sDPphYvA3NP++PhapdcDqE/yN+TBldN Wd4XXw3ozDsEAJvJLjI4HcxUdEROtkKUpvnUTBf2NEFPHvMWaMh76C1jBSkeUFGSwNcSEwrQ 5rWbX62fdJFg+LIB9ho+FKeb7Zmd0xt4WKe3iRmAtBh9/x32C08u2aO1bzEcQTQXnVdqEAi8 pWIhF3Ckni2HEjoJHsp30VTHDBO3IFspfZuj7O5b9Ugx9zrZCl6eBoRL1d2qSuLmQZ8HAGBj 6K4UZUDCasGyN0L1vaxdi4nUi5KAXzDWBIMKzaHzShSQF2mm89+qrp8imdcLUIHu1I625eCk ZPOupbuTdzvnOPjjY0W+7xSk4vUr8CzAppwBvbIhbv3OLgaMmq1fdepi1MSsPs0t98rUrB3u GNBDJWFmbXHzk7Ui733xNKcNUWmSIsaG2cq1yfIGa8PydBm25ml/NobePvMgu43oWPlh33Qd rkRRorZioJ7yrBq6tRKl2iVy8ufPd14WOvYuDaKIGJwmybyJcpnpB8zUV9FUtPUb1pzYObg9 H64sSKPzOaT+i6kbz91FG9t9fkDrKa5TxdhjqdbkGhUsSVXYId7XDYZWDPftk3J5rL5pHt4t rPS76zyOXV34Q9pIXswMhCUy/Zj2N1t9uaCls6+xZzzsppvfCdDdADcc6LKjQdzKZRj92EQJ 4LaG5AAXk3xm3QVCkPAzZLJW6zudObu7L6LeX/QlQm0/8ZILRJXklhg9Z67kigZmGzhftbcJ j00V98z5+jA09m5Mjesvbkza59dRjXzFIeIPmr+nfoakrbUdMsQY86RtCtOn5yYvkKj7Lbnl nC9cILGxHZ9zWc2jh2j4WUgLQDUXJwYLo9odpQoS9F6R+egw5ftH81Y+NxpgYbHfYpbrUfwt BkVkvEDAK996kBJbV+WlpTUyySu37mveygcYJwWgKVbmIqGm7rwhlRDnPhlF8l6WoBZhbLXa xJMA88iN0M+kyHGf2pi48yoSVMPJBliPcc1mQQpDamhS8NqxVmmYB57LB2zESnSit3nksxoY jXYmLZij0s0D9T8XMYIg+6c2S39M5xsvwkm0ElNbF7ccErX+NbTsoe1xasxw+VuRhO2HPUfP 8e4k4Gi2Y6MsCoYzK9c26pD9nvKLcYCs24Z6UHtjWLPAW43AxJHryFTuutPVtsjTFC7WWYH8 0b6hcFuPSoM16EahLtp2oCy6yQ9j5/ue3rgUzarObXOsnoWlVGe/uiXx8X6CJ7IyJpZzNTMX FPyTuMqtCmwuS8S9PeRSUDhL7hP246kKQSoc/JdASOEYQSjZNZBGtcTSGmrjmFzoZV8eGq7i O6PfFTutC3ga9scWB11k4DSfIkm6EBwGhBvMsW6+3K5mky4VCk3Nbl7W1dfBAGvkA9ikGYaZ 37dbFkzIKDSbYY9+6zs6sLRPjcSGSc0WHLVH+e9HUO2AiyNgrx1n23ovqOCeS4ww+04hEUs7 PEyOs0FE9Ur3c9fUOqHFODkKK2hOWs3A1+7cauwfbe1ssWegqZTtFvHdubZYWG2qR9fjQE2P s6r5krq02Yjw0Iy4dv33IgPFkP865IUIBLf5u0ELuUrVLDB1Wrkfgrbpo+3CHpl1AxlrY2ID aOtLZMeBfrKvmZH5oRx82pMUDq2AwA4RPuYkKOpypZ2MlLpYeynOx9NnNmpUW05kts9qalHm tMbGMIFXiQacMYpqV1oQ+piSHv4isMgrfRknJ/AGyPPpYxZi5GgWbir7/IlzEslfXNGOv3Dq 7uHo3ruoeY+CCCBKFQQdBcv1v0U02EdxnDM3WbfPm05ejlJELonyb9VEvihQn6to148EAeVm kYXMuNMk1aGbZykRDPGDdqZgL73+89JjAQcY0gd9ZLY/04rhJSpTUJZA+57F9AtOtAVAEKko wY3c2S4NBAtLdKgMYYmysWtOHANfUAzk+JTrjSg7WwByJvCmYl5k+IYs8Ps7LCBbQ6ybhhSo cvzMadLVxEr30vF04V388HHNgDDWoXypO3kK5zJtYrSkNc7zQqznPU8L2EaiuNRG+PIVyjCp YcE4/FT+vPgAD/lcJ30cSJ0eoF9QdtinIx26uSFkFPlQ+oyzbfg0SRUimWUb6fnpGek6Hap/ t7JgPwruqxL2TxEKvJo0CBT0pdN6Gx8RFblpaSJcspmyBTw3xw3fDQYkRrEJhFA/8o0nsN48 nTEOevBUud0AemDFhmmoPRA6t4LR0sX+Sq/EgWOD/DiJHx0gB/kKwFpZbZ6VWI2GQt5Pl4Xm MwhId+8mf7pqIPcE2E2/jH2xdrnG4z4mJXauMLG1bNINZ6TP0DPTVTC450JSLzKKtS5MxYEA ekmBwyTd1CrlXn2XSWo0DbMi1MpLQ+etBuaz2VAuA/5NAQ2bVV2spMk4iyn9Fr8feiCWUwf5 1gQ7aKp7MeiDv708aUFfYbTpeDypVyBvq8XYgwUddKNIfJZq/Dn4ctC/0+j41Q0HSNzl3aDn IAT6QTkJhjs59RJJ7cKDJCezjF+hfAEVLSRPu7TD6E0J0mZIieJKfsdzxkdRO4k8UogpDU0r CJZ8olJ2x3dJNovHfytcC1AT5GtC2xyuX7A+4t/yjUXco0TZGeJr785ogl5jEY7eXHStgW0a nU5W20b84BRu0tZqkJioe8oVSxj3UJ7oGzDar1MDY1TUF5zYkIBweR0RBLhQcV8t1FoRqhOF vz+Ty5RnJfbije/t1rAcAXu/IjSXZVNM3md/clKAtlyFZkZrpVm+tG3RFjKmWj2yt2kW5/Vi 66hMtuRaB+FcdZBMgwuyHW35MZls45LEiMepYmKpK1sa9vZDuuMWLpmW4b7goTwMyqx/YQSw 2L9sNCczItngAAAtoWSxFfJXsosQ9qXyMrdFXUbs/Sw7l2mi0WhLIRkKXs7U0j88faM+mSiM SiqdUXKFPaunaTcHtkH3db+epvIw1hgt0RPHoouYu4m3Mq4z5MNpew1lbmRzdHJlYW0NZW5k b2JqDTcgMCBvYmoNPDwgDS9UeXBlIC9QYWdlIA0vUGFyZW50IDIxMSAwIFIgDS9SZXNvdXJj ZXMgOCAwIFIgDS9Db250ZW50cyA5IDAgUiANL1RodW1iIDE1MiAwIFIgDS9NZWRpYUJveCBb IDAgMCA2MTIgNzkyIF0gDS9Dcm9wQm94IFsgMCAwIDYxMiA3OTIgXSANL1JvdGF0ZSAwIA0+ PiANZW5kb2JqDTggMCBvYmoNPDwgDS9Qcm9jU2V0IFsgL1BERiAvVGV4dCBdIA0vRm9udCA8 PCAvVFQxMSAyMjggMCBSIC9UVDEzIDExNCAwIFIgPj4gDS9FeHRHU3RhdGUgPDwgL0dTMiAy MzkgMCBSID4+IA0vQ29sb3JTcGFjZSA8PCAvQ3M4IDIyMiAwIFIgPj4gDT4+IA1lbmRvYmoN OSAwIG9iag08PCAvTGVuZ3RoIDE0OTkgL0ZpbHRlciAvRmxhdGVEZWNvZGUgPj4gDXN0cmVh bQ0KIZpVzKS41uKIMZljpCLG/LLfSqY7q9EPKKw7gE2285qIfbpCtYXcBpMyeGC6ZZW1fdNR 1RtaU1RJhB6n8eYr66jSJDs3gAJoWKESJPO+qW8dHciyb9tN8pYYEBjrRl9XDfOxOz65jMz8 c8UDcm57bGxgT1xb7J1A6ywFh1WXpRhGFH1b1DQ3zqU5n3j6bHJ+Jrwtp80R6aaJQSl3e6y6 Jgm741/eezhqiVxx41ptH3N6iPTljpIjVQ8hjnmEqku+TPreVZO+992I2uDN+YhaMCNfMGWn 6LprKgde1jiG53RKQd1bNo5dJu3mSRkTsOckazffJe826jXU6NGRCFQpJEiL1Dx7XOcPJ/Ob E26DS2NNKa93KxprLhW7N3lK9Dv8KECCMVjw8ytKO2LgcF+HKNlDlDthpjDPkqwe+JovrL3Q 0HNo2Xfh/2wyxx8g5qtrsAPhiQe/J8X2exsL6GgfxenU9ZCRlZ/QEXsDXWUF+lJzZfS3Yk+b pH90B44vk4GJRPCbLArzen2xAVCrlV/0QCc8z4EVmtM85ap4G3BaG5Gdb+y9mvcLGm5jmjpT 0elbh8bKaYNj/8MkpY4tzP4rfXp8UfHKKKAmG9+CSxTWjw2PsFwmQAYexmYKV5MvOSSAxQKF N725acnV/e3nwys0MgcpXYqBZxbT8i0wHDeKCv+QIc8PKACJ8I92fC35OvkDyDWDaGUqTtZg xal7CoxRu4XghyloKj1NNzS/7bXaKPIwvW9X/KKbYOxWbkUzTVuMHqhSm9VHhF/hNudsfA1S krb1DPEob77vy3wyUt4VQkQeF3juH8rHE9FSK/8u/mK46bpFnCL4ik3Xhz6wl1tnr0GeucUp PGcENyXJy1Eht7UrHPrELsXDzOS2cM6mJvEVjZqM8Xq2cvmngMmcEkffMFiBqn+HFD2nnRzH 8yyDWVJ+DP6t8IwcSNI3ldf4lbV1yvb03JOSxcVpMwiPlP9nctj6VSEizrQKofna+dcMN6bY XC3bLHm9R+8tOoV12Y4gLl4BqnTsYgXsV/VluyQZC9YVG8U/GcnMf5UjHY7m2zC9AjHG/QK8 tQ8hFlRLpHktmO+TjN3XyQjosOqvSn8McLaYphbp72YCKE2QXikSm0SWyVdtNwoX9CAEaSG6 4kYoIspaHPeW+LxgMTo9OlafUnOOFY/A13URXJoGPu1qLr0fvG+wR8wonHDHg9SFCF3FKi7V gpj84L9g5tzg8R7qgCHQQr3o92oj+bAIAaAbdWKhAr2bX3+zROwDa0Z9P0M5IrJKuxHKsMkN By6nreM1FKWQn0YDfk/FlZ9KbchrVPMT5JEdntk+fgvMwQObzZZVe5T/GuWCPAk2M/kpqQz/ Sr+wwjxahiz/0oMQnrUm0hDrmFAJ7CutWTxS/4+RVz9shVFJjy2CTj3BrN3N1uLffO4sZpht mN4Hq20UKwQkUOnvqhTPLI6DyOHW4Q3WdH7tJ942KbU0ZysvKKLTaZotRFeRkfXmTpK4Rm5u rn7aVDizokvkUBQYIMgO+wTJWraVaTZpKl5+BkeegAEphJuTTAx+vhVdlga2q3WrTeBsrH5H owUdkBz0+fwAZS4xaER4vvVKQICcph5LyqO8qqUhXYGn65/l2CuUB2AIjwedO6bVFcsnF8qX wtHRLgPll3hygfVImvnQpa1XyAAccbaj138si+KMqIUgqEmFflYm3XARWUmGJMB3W6CyesSj 6ox0iyWsvVQ5TT1QMfvxHCxhtDKceoVFnFxvEHXyeou9H/6ncQf1wPiWZkGhTq3F4ONoM6RU gRFcdyPd+ft+1u/erl3urdkGgIgxwo33xlMkDsXJdMW9o5JW5Rfh80c8QXV6JsviUWfx08n5 xmReUwqgLz5kSQqoKu2gvTcdTx708t5SQFi3FZjoPJxggRaUcoXzyw48zjoNCtkfjff/vNYx 46BMTMpTxgW51JlPUZmqBb/g/C8eM0AEYqcv90qFoPAcEw2qudRz8xdT4joNZW5kc3RyZWFt DWVuZG9iag0xMCAwIG9iag08PCANL1R5cGUgL1BhZ2UgDS9QYXJlbnQgMjExIDAgUiANL1Jl c291cmNlcyAxMSAwIFIgDS9Db250ZW50cyAxMiAwIFIgDS9UaHVtYiAxNTQgMCBSIA0vTWVk aWFCb3ggWyAwIDAgNjEyIDc5MiBdIA0vQ3JvcEJveCBbIDAgMCA2MTIgNzkyIF0gDS9Sb3Rh dGUgMCANPj4gDWVuZG9iag0xMSAwIG9iag08PCANL1Byb2NTZXQgWyAvUERGIC9UZXh0IF0g DS9Gb250IDw8IC9GMTQgMTE2IDAgUiAvRjE2IDExNyAwIFIgL1RUMTEgMjI4IDAgUiAvVFQx NCAxMTUgMCBSIC9UVDE1IDExOCAwIFIgPj4gDS9FeHRHU3RhdGUgPDwgL0dTMiAyMzkgMCBS ID4+IA0vQ29sb3JTcGFjZSA8PCAvQ3M4IDIyMiAwIFIgPj4gDT4+IA1lbmRvYmoNMTIgMCBv YmoNPDwgL0xlbmd0aCAzMzMxIC9GaWx0ZXIgL0ZsYXRlRGVjb2RlID4+IA1zdHJlYW0NCrRf CFbliKwOUsbHqlkQY62I1XDgQ5E3m/QuoV6qhvYPVhH2WE3X1UcD18qjDPzdAjxj7xvDo6ed a47No5YajjS5tZf9cWHmy1lKsnEfXprhcgWD0dPOxQUneb665eL8mr/Ym6aDKdqKGjX1YHW0 nIPcxCqyzVV9a2rtaWr5vnnxAzhl2IasIXPxDgmmwGaFsJzJ+Pc99tsp9JRrhPvO8CWzjTRS h4ngx63Xc69NMPip1KPd/PdTV5AABF6Jw1dQWsfYheDgTHuSi4NexAH/YDnoUXZlewRxzrMr Issiz7F9LvBb2H5QXTNA5EQ84B6o21JD2J15h5UQgGgl9wzsW3fyU6m9mNPGlbhRkkP3y+Tx /WIrcdcVVQA9oPdamxzQ99XuoMvDqZYIhVJ5jberxUjiQWW3caW4+c77PbiyCFYJrbQvg/K+ TPzsnZwwK7AP4rB9jsb/UPcKVBuqIhruaNK1lMSTUiehGtn3pl/AkF/H2U18dZVF3SGJdHw0 Y+MR0FGvEalCcYi9FCsmZlr/jE2PBQ7TOZBIi1nKgrA7AiN45fCAvCNxxmuwxWNOaEdkRNK1 XL9/IwvEhiJVMNKsajkAUklkgrvWuzUM3Jb3EuKOe/9X3kVn/tpLmDCcf8r7xqisGZ7+KHcO iXInk8xNWDjYWK7zxLTSlv2lnUXa1/IbKDqs2mGFB0WDZIdwXlUzyqCyX4+hEnbePh/pQ14c rPooF0SNdH+gDEciplhsa4tIvYPq1cA1Z9JMY9exC9Vasi5nd/kdQnUyWn3PGIVTRWgRtyNM Y2BqYpUx/rIbAaYZ/SFrqutgylGBttp1XdReHx6iHCqL/cP3IFPgtK5CR0pfbKaR/u7EKs0x tBaClT4XBplrZiVdZG8Nus/HmyRF8bdr1N+x8Hgi7JSQ8tNhRecgUYlYoBDnH/01cv2Np+GG vDhZI7dAxHZVOJKiWticqc//E6NgLIowerkffXShOeN2wgehJ+JuS74Meh6PJDD11wyLsTny FZvd81wUDWqWXp8AYSvT8kuM1eOkCZrg31PYbemEvhMcRytzE309RH7SWoFbOSXraAkj8mvB s8qOwmohIxIa5ESnOflifc3qQvVOz0EXstwFkA7oMbOS7Ko5cPUcWy/CJEp6DzaAB94pd3uT NTVjRU2yGDVab5HhoRohfR3dWOIAbBLlgYxhIwL5CgOFw3JB9zx9yF4X+o45NYeUI11ozDMd DbRxeVdmt4haCqBK13upa0Z5z25OETNgNJrFNuKgEfmqDa+U8Cwd4KzQEXRp6ijqxDJLr/co 1kA/sm1H/Kbj9Rz5N9nkmqhHYo2wGNHRYXjH23KkE9Sbv4JtPakwkbzDbI0F/tzHXG2Bati6 EiWmYGGv6uNd9TtYWsrM57Irnr2prY9LLclKHc9cZGK2UCfZooKu68PHjeXXPzU/bnWgiq+9 Nmgf/Bjc+cEwIJ/FvVgBy2i7jnAenjLqfmsCKHr8XxhLURwUExbEM3SFNb9ZtARFhx2iQyCq g5otfVePojh3YJWwxrJ1R72BrWh0QZaLCZR/pS/BlnzlHs6mWo1bBG5Qf7Fsps5MqeWJKGZP BFcunHQsXGi3QuDdW6nT0G3QL/Ikrbel4OPJVSluc+wmD1Rn2+jRNvscGDUWrOQ1k7wNe1Tm NR44T8TK35cX+Uc7z6ofFbg/jr93imD+aL/CkNM5ROmnaks8elaQAHbgKw26TYTF4B150fuz zQvsbPGGByej23zT4Em5E8TD9jDa/mm/zsLu2ew7GMKm3C2AFQBHamNJj6Ob3tkpRchvRXkm BsE95wiz/cfkWRxwUR0i1NUvRbzT7DZBT/SAh/09kytdAu+vRDlITXJ7FvNYYDw1YX6SI5NH DsTqTdDpgzDp2rhJYFe5sUsjCz5mBtHkB4ycf3S0djcOiLfZQCNUk2hnv2o82wozadafVc/1 p2xl5ZAm5L1m54DcLnkPGAX3A2HfKbfmCgieZjDsjbEVFq/oty0bIEnUCL+1HsDucMuawleI DU6ehDGoKbhUuYl1gvd8J2xUg9NQmvbsLkaI97CFRIlyGFUV/bI7HmZrncgF/gCcqRJwX0mn 2+YCBbCMVFA6cBDBq/cYhiHtbfJXBVdha+b87Lo85a/Aq7tn6cTcTuFSr+on9Az+L5ctCncF Uvfsb/vQRRByFPk26KDJ/oYYyZPOwrV6/rWU8GW+Dou6aehnK3/0M2rLY/Vj5SdziNsOlqTE NVcKDCYR5SrXQoQZQP5SLVjOxVInv7zLub0cylcY1G3VWSQD+8Uo2JrT/GpoPOAgBz9TfXsF bKYdIVzLjwyr2JSR+XVA67IoyUCKYi+tRomJTigQM+ad6i9yZkTlJBnqD/gClttyAwlYNFc4 MoxtDuVUrKW6jqmYsITbnvMxpl6PgRkJycKF2tctj11I+8Q6Kt2q8ZeD5FbR8XfCmjiDgW5v l3obK3mbpotI6JvVS5s6hnLzPnJxjBIo1o+y1Rwf0OBS+fH4KW/ih1yP0F5/b4AxY+Ai4YQw G7uiysd1kRFyfQgU5vMIx8xQw3Bar7s+nTUz0w6XhoE1aW4bnFB/Q/7+h464sbhRmeoCAJRU rb8ux4tX8rzPM09TAGWeOPqYX3JunMJgEk4XE3OGOjtVIR0ssjMCZ+jrb2sUz/WOw1JDgdrH jWkUE2WR1gYSp+TZf+dVNXKxRfITlpK0NDaifXoX48+0IlPGreZ0rK3bKPVWB8XW+iQzijRy z0yvFVPi9Y7ERKDHxCA0Dgl9AmQlFpWvKaMMKK4n0m8FkPk2rQGkZ2fadDkBaV2MgL16OPhS nvnuO/JRBsan3F7aXkeziRbU39vd3joqovm5rKeP8t0Tt61McowRnPrZi6jM67DA8yX7FpYq ecQOl5HUrc908noWvKCr9N8NQLIl3iUR6OXBfM/Ig7fxUnqwpu5jGnU0MSxEYK39H9rJlTL5 xn267eZX8pSVLpm63hlBVbRcX9lVy0qGif3ktcvncDIht8QkQfkid3B8OHvDQZGC25ZxGipK FJfi0VxuckMWATukK7P3bt/v1vxXR1l6qUE6cn6u4+NUzqT0/qJtFpEtyrFaEak2ancaJP58 AgVWdgJl6Fcdnz+QYjrHeVgeGG1raaYrXNabofjIhW5iMqLpU4gysdPZCesThgiG7M+P4VVP QH9FY0aik3GwUOGg2zEeGxRDOh5e25gajfaJr8ikD+KG9BFESzfp64GDpK+dL2nw1j8tIaLs l/ekgjW5+24I3PcQl7s7urdUwoims1d7j0udgaZh5sLBXHW5OspxlKExIvA8QSRzLC3qppC8 N6Dr51bL1Vjtka2GehIOmv1znEBlxTtrCvCC6NB8z+ESoNfTwEaHH7UUdd4wAHBcoTw0SjwS IR17Kh2EoEfg6CXk6xjPY4bmzxEeCI7rhkHXUDo1dr/KGArsCyJ8jGGFWD6pIN3k/3JCOo0i 0HmXn/ZGeg10Q29jJ9fhi0oizbbLdS7pZ66oGTcTUN9GyrfSa31jqVwF6WkqBAsRNCjHo74a j9VU+ZSHd66XAfeI+DaBWp91bznxBDwSkfRXKx7TnHAOGD26hl7BO6yyl7RtYYBjv2qG3Kwh +TB2lCmqFDU/s8h8tC0BdgLpMvkOIvSP5kjgqGw1ABMWGgKqyLAMJkvNEYD1/D7ar5DWpm3k KqLhYuvaPprWmdCXrNQPMC+pVucBJp643qq+D5wqoPXsaP1Y9tB3IqGvsFw/FIRcA25GcLdi xZIkgTmJyqLlt7OUmhYm29Pei0n6slte8FDMX2BLpEp+b1ZdO0FlvhsgqUQ/WeBu+RGgVI5w ofZcNW5bQKzR0Bujp47Nleo12Am1Tc6CLkVfl0s5yfmmS+goKz7JYUSSPAGAXYax80dWznnk V1ZM+qDjLn7w7nZEwbWoSwhNGzkzacG+iXyzuihiwUGnqR56ehjyLKvTUcaaWtSVbeSMpV2s fWk3CIqYwJlWEvU5QPXsV+I2SMxgPINIHAbAVTOnUqwLGZkmteOiSjFK+axOyyRfQfWHD+7J E7Gwu8bg/YLW5SPf5HzpX5oUYzD6iROLpIdmxQgaIg7RN/oje8LYd5tfLlNcmd00kVuKiIH8 9Qfnu12j/2q97nW6LPCEHA9N1vTqAi0DaXOrOJodvddk+QBzSkiUnec77m5cRkhDb0KQl/GP 88sbdQ51b/DPA6Pep8Kqd3V4VpLyzOMNdi8zCD8vSjKVCQC16ylGGpyY6DqfOZPfvTUp3W5M 4q+93yoIHKt8LQXlZYIDAS4DD/gjVxzBBgaQH8zxlOYXMPPVRcS9W1vGPP69l9a+IHDXIbzr qKBTjlWqc5NUqASmQI4SabfX7yNB9L/zL0xSByDYZtvsRnpBWXYcdqKuorYrMphaYCHfK7AF fCIIzI3mxXf89/BZogjZ07D097QsHJ1HtxjAoJFXJ6NDhIENZW5kc3RyZWFtDWVuZG9iag0x MyAwIG9iag08PCANL1R5cGUgL1BhZ2UgDS9QYXJlbnQgMjExIDAgUiANL1Jlc291cmNlcyAx NCAwIFIgDS9Db250ZW50cyAxNSAwIFIgDS9UaHVtYiAxNTYgMCBSIA0vTWVkaWFCb3ggWyAw IDAgNjEyIDc5MiBdIA0vQ3JvcEJveCBbIDAgMCA2MTIgNzkyIF0gDS9Sb3RhdGUgMCANPj4g DWVuZG9iag0xNCAwIG9iag08PCANL1Byb2NTZXQgWyAvUERGIC9UZXh0IF0gDS9Gb250IDw8 IC9GMTYgMTE3IDAgUiAvVFQxMSAyMjggMCBSIC9UVDE0IDExNSAwIFIgL1RUMTUgMTE4IDAg UiAvVFQxNiAxMTkgMCBSID4+IA0vRXh0R1N0YXRlIDw8IC9HUzIgMjM5IDAgUiA+PiANL0Nv bG9yU3BhY2UgPDwgL0NzOCAyMjIgMCBSID4+IA0+PiANZW5kb2JqDTE1IDAgb2JqDTw8IC9M ZW5ndGggMTk0NSAvRmlsdGVyIC9GbGF0ZURlY29kZSA+PiANc3RyZWFtDQpsxrp16hY2hqet FfigbHr6iPXY9Kx0vAlTNUg4DtQduEw9HfbgQ8o/eq/Phv2KKuyapIaGQyocuhCWFENdehAf MWZV+BMGxywJ85vdjl6J76nzN4PPn8Zm6dyIFAcQ1uPELFLlO+PR3XFi2RX2SynzzsSHHpTO D3tNyMVo055qqfbSLTpVPmjx7yNcMU9jXnKyBQ79TEyPscblkf60wqYs7eyJjjmBHEwpEWOP 6V6+QXcEMOokNhSzxZ+K7UITZqZtunGNplnOq6/ew/zz/zo5DQt8eqcDhsdE2qt+lIgpb0vB e9/8kuKK+6xc6p8AHwxpMkpn9Gs5WV5R3sasL4cmvLv7y31un6hDqr50B9+tJr9Ht+PrdntT xrse6kUhRgCj8cMdX5msNEY3My9dVh/Ni8F4RhVHf7BMZJAK5eBpWeul2Y6A11oDF9zZxaq9 0sG9s36r50c7E2Ppv25IAj7DEo/owYDrqPqFVJWHeHvZIgz9D8FMkJSYVWBxFVmAQOzDAHQ3 Od3mi9LeoLk4E7j9P4MjBp7IGl5nRsxYe/9+PNFlYrqGW1M3SWMBPX3LpuTXHrIDgAirPiR7 fQw5RC7G5oADW0/rayUsM7Ayr9hDtkCTMKdMNgjOsdh2egNi9Ve2L0lfrXt5jclH/70wmqQQ I8cEDgZnDwTYR3aSREv4j/gwZmoE64GQWGpJBVkQzsRYzLcKWCxsaiGQMIIYCNAr/SQ9mhi+ qOWuOJe8xfQfbuFN9BMnocW2hJ4+UG2mCEkTSgPKBnLLH7/dZtpZv9gGUweVDEA+nQDQ160j /LiODEAtJWZjG/ekHT56t7P88cMnA67U5xAoqPEltGGUaj16PYHhRvJTldV0pK4zb9iznGmF iX7G/6oIv0Rd6wM4sFf/Ma39KxcUT2dazPnBf5GjdSFg7c1DB8ntQXvTgVW1dgDCQ8sQoffK UBY6JhpCzhMnyy8fXL26j6eKdVrZvazxDLd8pxkQLRNrMpcBiPa5rxIfeZbHgzHAZZtR1JMZ RsWQ4bby+zwMCfzYIhAhS1UNF15Y3XIMfFgnRB/XpClINmHXHYsdKaFOMt9nEquzrp0e4RyG m/rj72Nh7zPkWiYwkD5fVhY/030sCxUAn9DsEQE9g3tKT0Lc+bmLXFVv1KSd50mFb6DuX7RI 4Kq1axVPeRRj7U+qgB+I4t5RZfyBFKU3DfNm3H7Iuzc5v5deo7z5s5/9FxUbXOEMpvUsp/Ab 6o9c0ZKUXPFPPps4v1sykr8TWo/iDra78375ktycQquQuoERWsRRxSUO4hVAAc4qmTh04VkU etD/385YBXFQz975cIHMN9oQWXSSHQNomCn6kGVlROx+4QfPO8XkbxHF5kw7rQdwX0KdpxvX VkRi2223s4E1XSIJPiouh4b7l/l5UzZxj0e5jSkigjBtzzuFSlImrneCU+J7JTqfLjCyYkNo Cgcq5t2aEwXqbA6ifTNqiODiEg1+pxmEh7ppQ2u4uT3WGyIQlLPubX8Xuk8vt1MYfhjXIQ/c f7dErVr3eDIek3UBpPKV6n5UlwwMGI+31x37n/PxmCUjVxHjnk/QeYW2YHdhN4X6WETVFJRd BAlmitI47AaIakHjSCGY5iOduCcDh205ptxYkQbz5OU8ZkDrW0tZQw4KymC/RxX+5J8Mc3q8 nENfSG3p8/B1A13uz5CHxfg2GV2ruDkFIYUWXn+9BAUYumQz4XMqpFJ/kHy2exN2w7C7iNLk d/CGbH+ezSoAxC+kRe9XP4h/XVmXDmpTNldqG7XK4YoX9WF1hwGyp6eK/p0vJoVaBB0RBn7a eXuW2VJHPTv/zqIwbzGzHFUZrcugzDuykwp3F3OHFPxb4QsyDDH+QpFVGVNsHnFqu4ZMJC9l kc4b8m7hoYV3qPSjB/jriyhLjoV8r2c41GliPwnu7JrEAQzn5kr1qqJbrhIL4dHv+2pcycHE XRQiX928KJDcmGytt5OR5GL+vpJ+4ODlmmb2Ub9I9X7+2wxUTdMFrRc023XG0hUxFvm58WMI vZNMh1m+8QRFiMEfoTtc3W4MxKzOUN6kvhz93hFJVzLbB3idw/FHHjS6X7AovZCBitCjQXjh 451WY9WNZeh9TtFJ9I2vIQcM7Xu2MVUoZslhXHxt4XM/kjOnS8roQ86D/8VbxJ/klNTXqHU5 NMhHMxZ0HIgDlWkHp6Lb6tdty4CBHU6lWyAoAmvV45i2sLnccCCgLtOjlCgsKcivJA6SVlMQ +kVJQYZp2mUOdaKm+svbVjaxylcAN6pbLWoOIkockjm0Nft6BWOwz2Q+AyiVZcY9/DEQKc0h WpDvO4hB0wIMjgztS3UHktEA3t2PqfVGgwZv8RHiGlHY6ynJEczOhSB4a+qwYJu49h1avRVO 0LbMPn5BXvW0mXgbJqUvXG+30kLw3RdFuxmPlQwrMGD2SxPJyt91sb6CpgDS/BrrlL56PMlX ZfilgoY0LmyFuiAo51EUjaDDhrjSn8OGXr1YCcbizuSFuu7bJNtU5P3baWNIBaWQr2eg+16Q pop5xqzbp/PdC2u3gOknLkpYWz6d5v18f/7UfAuu1r07w7iXNEBLx/4NBkquDWVuZHN0cmVh bQ1lbmRvYmoNMTYgMCBvYmoNPDwgDS9UeXBlIC9QYWdlIA0vUGFyZW50IDIxMSAwIFIgDS9S ZXNvdXJjZXMgMTcgMCBSIA0vQ29udGVudHMgMTggMCBSIA0vVGh1bWIgMTU4IDAgUiANL01l ZGlhQm94IFsgMCAwIDYxMiA3OTIgXSANL0Nyb3BCb3ggWyAwIDAgNjEyIDc5MiBdIA0vUm90 YXRlIDAgDT4+IA1lbmRvYmoNMTcgMCBvYmoNPDwgDS9Qcm9jU2V0IFsgL1BERiAvVGV4dCBd IA0vRm9udCA8PCAvRjE0IDExNiAwIFIgL0YxNiAxMTcgMCBSIC9UVDExIDIyOCAwIFIgL1RU MTMgMTE0IDAgUiAvVFQxNCAxMTUgMCBSIA0vVFQxNSAxMTggMCBSID4+IA0vRXh0R1N0YXRl IDw8IC9HUzIgMjM5IDAgUiA+PiANL0NvbG9yU3BhY2UgPDwgL0NzOCAyMjIgMCBSID4+IA0+ PiANZW5kb2JqDTE4IDAgb2JqDTw8IC9MZW5ndGggMjkzOSAvRmlsdGVyIC9GbGF0ZURlY29k ZSA+PiANc3RyZWFtDQqsMd+No8+ABE384tGl8uqo4LWbDRiHnqiRuKCLWOmNDUbXGi89a//Q KRNxUNYWGP9Ky3ythZn/YYQVRdd6FCjhglSqFPEP9rTzBP8L1l99YKd+LXW4LFe5peUXVHCa aq/eAMkTuhY+JfksICb/haaoFP54e22Wm6Cjzg6L5Ww3aBDmB4mEYWknMSJZmd6pnb1Uftur /xlfDQhlQGHeArwWvBq+xznUanUiyPEmar84byMVNYQQ04yL7aLfu6bsuEARrPnf0tVbVdZF 0fh28rDci6f4B3hblwQPgi4gkwQS7geMFRSHEh+E8IFckx4jL9p8rZx1IIc2Un5V+kZUFlVC gJ9ELjvA/VL+cbC/hSyPeBlIRgUC1zamgzCygKz8g3neAQ/A74UNRZVoiwimJZR9DPdM2nhQ E0ljeUw+r1ZzUvApXy1kcSk2fDlecb0Lv99qYpKPI3/t/x0AUbkAGmwZ9pw4mfjeUbP2fUV4 CnaC4V4TUD3VHraMxUr0yucHwqnL1jGgbuV05BojO+zSR1g31Q+3pCKZE0byqXzVdv12YMu5 47qJs/ErZznA69K8dZQe4PqUus33OvipQS+BafB9VLthiaDBnIk9OI1PFPj7RGKo1ploJkxT fvrxwjJRSGbmbzSfRDFrD9I74Otd8FTDmW4rNcg/SaEDzUMXlH2qkEh9K7JM31TggMDefs14 Ef5t+rSyHqh1ZBHwyUkpkskqRSnycRnY6fY+pXX9ixiS/jRBykITKSkmM+b3VbQHOpoj01DC 6YsLTw0LwOlhpXcNgXwt1SMalplLkH5bWOeaSQaI/6u+U2W97v8fx+RcLSGSPRUILXdkjaud SEu+1G3yZ27uMyxT6a4ROm1DDNQ1raiMmG1r7P3x4jeAavlgT53489pIcTY8YZ3c38yC2RS7 f6POeoHfhx/UpYBxuktF79877A3zvuO8woC3FE9H/HkMSF0skCEd8b0WOngaUHmBIeqBhbAE P1mgQkTC7mMo4GpQSHIrlHOp/jlFIWEs/LUwrd5HFVYx2tCZETCzs+qVAv9ZM3ezSVPoCl2g PKPrDW0hfTpsdGAnzIqwa4Q3MNwBxiBYGv1UAAqkCdJ14VX/DtChSiG9wFwmdZkCxcoOfgGN ItwWuGrWKKkTlLfohTdGWg/xEDjlvwDlfeHAZVAr7+E4DsbK8/dR6txSelKP1FtjuWiFITm6 PlokIseAPaHVcZ+yJiSkwh9oDW3inVN1XldoqL2XzN4rbl+LHm1b8v+xsqnlxNfKFuZ/+Hno HlVxENJxHOOqfZ2CnUB9s1xXu70GcCqOnJiLcFmQPijUT6PQJuDYqGeMNEKnsz5rrnEX1nKy I5wb6MopGDHLTVBr6rqVvHiOHCxpB9VDL4kidezLNwiuTlczMmsmqvuvGhhFV3xpBdjkt849 RS1vjETTvG9sonu7PxNLwVgB5SCIWSew2glEWAS75/nPyLbBDp16TJ3OhfKTCbXTZSeYX8bP ulvxxYBx3YpxoSDYbR+jvSnxSQwJPoSDORFaeTjv8NFJHTrMfiKp/Xw+c+p6U7rAxEz032Rb scooU6IOq0TVX0I2TYRLVtJbHxHSXbG25u9QFnHDeEf/V/N5KWu4SRerwM4/zJNJzyZtIdt8 0eRs7E1O+CWS7tSaznmJtnxiDUuGMFgiMn11tx8rUdKaZ1ofLEINx3M8uNRutuqFBsiXlQFx tN8pnz7TxvU9AW4PX5Zfx22uN4DL08fz8trub+oRxyST+l4tnWK93ZFK45tISKjZp8d1AVc0 8KopuJQCaTc2ovuMu590rqwNBlkSJdr/uCGZHRe4GtzoT5ihKamqLHb0YAnQp9kmnGtSGct/ q/8/0l2LnhFVDsPxXiy14FeUTqQsRpWP1Cc0+Jxs2dWSK1/cyBJkwy6w/Sv/u8KRIOgogj5m qdOsk4mGjmPkJNpPIYLRzHw5ByzaMK8qbiT3TQpImQ5BSj2m3xj/3HSSuXEvOhCJ7V2Dputs Y9hf9zv1aVeioeKPU0Ht7nq0oNbz5oK0iYpabqsZhdXzziZGr3bqN3tj6w7kFvNpduyONgdG WxNpV+9hCfmJjWeAGR/e6huIq8IPSdsnVeFTzXPSnIrASZywwNgO7TzZtj7zDIc7S0gj6dLq BrLATQe/4zRhnuaz1BOVh+4/GgY2deNPmfrJwTLRCdRTc6XDUYdNOoiDtGVh1eFA4EAEQFEQ 9f5UrJUTpFTZudloqkQh856PXnoUMkmUsj2gy5AGWLav4nqWxsmu15ANCukmfua3U4AYsUVn 0qc55Go9nC5d8T0jG9Q3rE+f6uCIW5YZJq0mZ/qix2ketbLXsV79zX1bK4qaN+oHiBPHXra2 +jzQCSNVW6hKHPDx2yUVrsYjJtdN8ZTjZ7KgN6goa5COqpIAOX5ayRv8jNahXljU9tm6mTGB iucEs8gusGEGme1JaB/UlRCauAH/9uVsQxZjC53M3iofYVwseTHNTfhKMCun6uiPHBqsFXxk JOF+EwY7DrQE71Kz1lFZh7uVlGRT0IraZAr/rtL3AmjKdmVsgvOMxOjoVOXjUuUIDy/FD/Dl 8bf0Qx1z6xOD4F6yljeGUmgPG72PljFzv5xma4CXM/NdA4lMI85wa+Vf0yNfcCA7pADrtXNK WpwYWu8A4FA8lug0YGBu4Dqj9JKEAoKDWj0bTMtjnbOVvqgdgxTFIuQqMktIL10C00Otsycv CLjZM2LIs+p5TOjP1/WdKQ7U7EXueH2Qm3iXtvPQIpLaMQBnJkJr1CKjY5g1Ek6ao9fAzBav FayZNiMBNreWLMFlOlVfa/9NQcs6h/V3QCkU3iCd4BFX9Pom471wv7/PaP2yZeXO31BxVuA7 mGvKH/GSEbuRRnfsXXHqJ8u2Gb9XbIKP7kC1q8UCC9WwP/eCWSgf0Aji6BuIzzm2AXrVApZQ 4oyX4EHdw/PJPmUgGVb0Z8do319EVvsCB4ZkFhsCT6c188z2Eyt4LSoAfq4Gohw2Jltid8DS x5mc1qn6s78HbsoMYPBpmvkP2PGApbVnoe4F962lujWqkn/sSaWvsSTj0aDB6RZPYNb6QMPq g6uQXfNAmlj7GoR9p5ujzjdzoiIoK3dxVLlGv4UZLbqYz0uES8voLH6zGJKygVnHT7R7G132 FSrmW7OPhBfbIR//Yiq1pNss0+alcKjhM2FAg6a6qboI3m8CW+mXV/Dw8tFQ7VUWdj45w6WD oYUeaQYjpVglvcOUAspu3Tqs5l65++ZOo/yI8z6gCVJbAtLn7x0dN9aXzsBjqr8lqwuY/vIv zvZewe/LXjJI2lbAuDAOovnXTumfKEXk+TYrsdUgjCryGE50ua5WG2QzedzffidA2nbWIpEe 9lG6t9vnwB36OyEaB0FuMHIUPlWIKSFpK6rsvkBcwEe4wmsUHlH3bLXEzCJ/lAuzc9JDgT/x g8ityvscwf6sdFFVQJO2/OI+Z1Z968RCpwCcuam9aksQzcEtE8L1tgGCCKKYCs/EBlhb8a+0 M8G8CKWOrDUlsK5yfezcYUllf58tnEuk+k4vTxnDPcKK2b8FaS2z/TYycxA+MjEI5jWtvrus vb7mkZnKw9uc+iMNw0yNwuumst4JbS8wpGtwRyhlYb1FexSrq6vjlvNGIoXcTcFLEW5EFqUu Bho0VFNCEyuAHQvPLpnT71CxxfLASlkZKtK1lr+c9btpBXf2cqhqsBGabdTJizmykAJMwp2+ FBWKO/anpun9bHU78IKsdsbeFJywp9mePgviAqUa3izRaaz3znrM96Rgjrfv1LuA0OG+Iw7a 93nJr3q+ZMAngZkiu2B6E6VYXDAIAOBwwqbj78IOSpi38sDYpQEhmkMAQ91jcr05i36ibjJP c04MKuCsT4kv18kX2oZJjhawx0EEfXo0AnfoXItTjymCUwd1QA1lbmRzdHJlYW0NZW5kb2Jq DTE5IDAgb2JqDTw8IA0vVHlwZSAvUGFnZSANL1BhcmVudCAyMTEgMCBSIA0vUmVzb3VyY2Vz IDIwIDAgUiANL0NvbnRlbnRzIDIxIDAgUiANL1RodW1iIDE2MCAwIFIgDS9NZWRpYUJveCBb IDAgMCA2MTIgNzkyIF0gDS9Dcm9wQm94IFsgMCAwIDYxMiA3OTIgXSANL1JvdGF0ZSAwIA0+ PiANZW5kb2JqDTIwIDAgb2JqDTw8IA0vUHJvY1NldCBbIC9QREYgL1RleHQgXSANL0ZvbnQg PDwgL0YxNiAxMTcgMCBSIC9UVDExIDIyOCAwIFIgPj4gDS9FeHRHU3RhdGUgPDwgL0dTMiAy MzkgMCBSID4+IA0vQ29sb3JTcGFjZSA8PCAvQ3M4IDIyMiAwIFIgPj4gDT4+IA1lbmRvYmoN MjEgMCBvYmoNPDwgL0xlbmd0aCAyMDQ2IC9GaWx0ZXIgL0ZsYXRlRGVjb2RlID4+IA1zdHJl YW0NCqIpdhBIUtcWGv5TDEeZqQ1DKBM6HDq9ZMBj5FlwZjOYgyGQIpuxnykLmmGfgYsPqTOC IBmCAymJNyjWNBx4HT52KtFPfWY7vOH+QCqmnmeix7fYDEyA6il1UCmgq6Je2r0Jp8vJ/Mrz b43rxokO9OOxmzQUYFev16OWxD65XA3bNuXccxQpCzSl2nyBbwVYcMXrb7ggxORiQEryJrzy Lv7NOkakZPR390m4KjCVPBQuIivYJQgqAizg9nKlcT1W0hrgkNsfc+UAdIUFx3DC3YIO/3eK trwcz0W1VxHzeMf9lzE5Bu6HvWJ5CoBalfcbP+qiII+6kKCL+RIcloWBNNmvS63Nx+kLRE3m bY5bLRGlPdzS4mqay3PbOJ9uCfVKIL2iZm1B+mJ79SMo6UBOYW80c6wJv259MYwDTSbTmCM3 lu52fsodwJ4Dfvi33cZFYQnmhi+wC4GHPJRSLm/laIof0s0fDeJsF3W/ERC1y0XvzEHoMQE8 ywLLONan10tWu0wj9f2Qc0wCrQplma2HXjxfJ7WYkDPrzR0y4ECMUQWdEWoMMxjQaT7/jiHp pTDrfPUoXqbTdBsPh7yFzBhm60hgnB2UiWU5GllnJo1kvD6KZ0xRovPrVhhvT2/sdf0Ym7q/ k0qiLfNihf9ZjI7xgVmeCw0LTJxMXJ2X3FZb2IUNYZLPDjFCegykE2VIOGUfOXGfmUssG2rc LQ60uCjdMEc16/PhCkBIxy6+7ip/6g35GHpj/eB+XlOmr6jwPdf5DZgq+8D1YkLpIjSRlSs/ rc+9wbnW52OTSqV26KEmTV6ZoxoeT3QcnUckcHJPNPU1pd7X4EZcdWsmuhBoEL68Juti0HMB ol27UjfPWVlmFmI1wvKIr/fLZNFsWGcS31ToYhLuD4XWTADtoVenxFbRYOAh0yuSAj4o/4Lo rt3ufCdEZI7KWUaZ9z6ou67usdajkMSQV9rxXAirQP1OMfCblImLt+kLt9pfj03Vyu2wtafQ I+sP872Zsc/kGvdReqhHL/edP2HW0nPVyXTeYfa2lLI4Ynrx1ulx4hcgl6AMEwaLbAaXHAHV AUZmZKd91ATSMGDGE/BZTJPat/ozKSAXcD5s0fXqGRg8v4uBY0jRoxbqd40MFnQisWitx7xV w+qagmppt6r4GY1QmdYgMN+QcQmUvfvH2X6Lna4PIFnz5ZlX18Wa1YDLKep5A2Ym4PgMx0B3 UWFukKyt0IvfOy9eWkaEVSbSF+BTZxma7i/vewbgWeeie/HkmlSxAGLBqD5/wQoWmy6mqVd3 GwPs8eOSqSNjaznIKRI2JaIDxy018U1POygbqcA8V8c8nI9GQ6wM7SCgoU9UXY1Slp1BYt4M 8+a3WWKA6xqsjkzystQL5MotJu68HnFkY0LgHWHjtZFHOGXTAtyQ9LXBh5ltxvLfByjsmqSG 2SJrNHrW0QMruqxUpy0hL+Ii/kNxvpCoBRw4T2AXv7jyZ4159JbNY7ZXlyUsuq5xBf4IUI/k xdx+J+XfuikdRX66UPs0hfP4oUdP7mdwogqqsyi++iXGyaimvw8RgeLrDN2rK2ytd1AGqoz2 keXJ1augbZvCSaP0W89c0glZ00IJ+tQpbWbZkKCJrn/YbU0yrOk4UBDG4+fexQi5rMCEREm/ T3VnnOH0orCcjzAjb1k5UNtk0dlrI+6zx8QVnBgbYdg0JdZhYFdefjEwauq7JteD2GJieyWa XHior7IXSacPz/DhH1UayHCds1ivJu9X8L6Pxx43aCSDeZLUu1SCEsftYCSabNAZRjRUtGUj YzSxQFbLVoFDzXlfR1o61pN2isLkKO3x46+Wm+tF3Z8f+f16vaFh54FltMyPKlGTgKGJ8sRl AzNq/DgIR/QPiGUqSJWY2tMMDjRlu7llRDYafxC2yeDE9JRzmuhcVK6gpltaYYHruYj1mueP +8dHCEyTGaMSE7SdV4pSz7jdkA/sTJDxQcZn0jQclVvTE6xyZUtpuSeWG5vvCxdxsA0oez97 pGDDJ6DCC96VAY1xXBl9lPTsEguEHOe+FQYsV5/mBH/JFQk7F/Mp0Y0Xh7H5q54tgbBklgp6 vV7b5sUC8svlbPwtu4qHDz2C43VNmUMhnBvrXZ/YcLnRff2oNy/3uZA+8swxHTiKAQEt//xM aJOgtU/op/V+2wPhEFRt0IA0a/+SXwZw3ZQdirmNtVOHPc2/XIblSbbiU52jDclosPvpoYvv vgloeXGoRzsTlNijHmaeLsH0xi6jIUn+lgCCkHRCQ43hrVj5vai0BrBvou4K5jo9+RJixmKW vW3+YHJAiCmnVrlWwGToZUtcRiJM7G8pi27/wK9ZqolQjNc17NQZnCUZyi/tSOHqwq6BbBI4 voS64b1UmiGcWBRdj0ym7hArdvByLWwBsRHdykmm4N7uylpcml50dy4MPjBe/vZ+XpLf7105 cVbEsHsS27wDN4nyZiEogKUm0Cch+BsS9okJjLuCKC73nFYNwE3Z0x+t6QYP90v4LYlcnwUU IHV6Tcmu/9yRh34JUCBujuIXeH6C4WN+2Y7FrxRxtfyYfYDtGtgBr5FIiO93EI/nD9O/4FEk y49FqMiyrFHTz4IdDJyndp46Hm6e92ZPWAJ14AiTlhVC5iYSOW1KttBcbuxMOCRma/2wrkdR 8SiY1zO5O+lXNWsmZ5VJUEX7TWLETrbHTWkKtHFPNC04kbw/o+UoyIdLkySw1vJFAvjTgA1l bmRzdHJlYW0NZW5kb2JqDTIyIDAgb2JqDTw8IA0vVHlwZSAvUGFnZSANL1BhcmVudCAyMTEg MCBSIA0vUmVzb3VyY2VzIDIzIDAgUiANL0NvbnRlbnRzIDI0IDAgUiANL1RodW1iIDE2MiAw IFIgDS9NZWRpYUJveCBbIDAgMCA2MTIgNzkyIF0gDS9Dcm9wQm94IFsgMCAwIDYxMiA3OTIg XSANL1JvdGF0ZSAwIA0+PiANZW5kb2JqDTIzIDAgb2JqDTw8IA0vUHJvY1NldCBbIC9QREYg L1RleHQgXSANL0ZvbnQgPDwgL0YxNiAxMTcgMCBSIC9UVDExIDIyOCAwIFIgL1RUMTMgMTE0 IDAgUiA+PiANL0V4dEdTdGF0ZSA8PCAvR1MyIDIzOSAwIFIgPj4gDS9Db2xvclNwYWNlIDw8 IC9DczggMjIyIDAgUiA+PiANPj4gDWVuZG9iag0yNCAwIG9iag08PCAvTGVuZ3RoIDI0MTYg L0ZpbHRlciAvRmxhdGVEZWNvZGUgPj4gDXN0cmVhbQ0Kla80AU1rwPyBAaFcw8YcP1ksxnyp AnVaZ0iIcTWxFbXualc4PoU3Ok5MK9VTm109tTede2In8b4VR+TefS9voRMOYvjIb7wRhQkv wgUfHO+UoXmOXcatkI+FFWOyRrNi68SHwx+Zg+6LgG/DWusfRzO3pkzgBt/RWo7nZIBH0X/G FLyBOjg5fYF+QocTI/ocCZEmB+6qju0602A5YlMQd0Wxezx24e65BYLb+NaagvdnCzpLa2mR tih9aba+jq0ZM3irIMlIHipnqopc9t5TqTaQXkFprcb4d09Xih13zdcAFDVXECgrN8ywqP/r qaOFJ1NABbFTX+17HKdbj6QrZnOu4j1K0apdCVPAFTmgIHGzwPa8Swkw1aKruHinG8BQGvhy MSDnLwbYE5WCNR6xmJ/+wS6SjMWUVyt8ASfKBAiBEVkOv/NQJ5ef1blvDfoyWxs/u1arJjap 3AUqdNrJQaZ/I91hrfboH0mOXoEXukomyQVTbW5seyNUIWuJptMxkn0enGf/lq8FTyhv00Qn ngmN1oHQuOxGYZEFNPT8slaKqYOEMRz+ItxD9i71Pv+VmbiwgXM/kSCEwkKj32qZnK/nfNKO z46UjXbb0v34kZhRqT5H9vQoit0uAKwjabknXp4drH4RbzjjjapqIqS1fn1LdDT9CTy4x8j7 xptgWwfIkDyFZ8ivsP/dVHzkepGixWmXuew3QZuROOaB5JAbG8BL6aWSm5BzgP40unemnqi8 czEy3YgNlYyOKNKjDgnmMFJr11TXpaZ3zBJvfUWHLx/pP0WYQQeAa+Cu+wQzboqYnQrEDM9u DCJFFx7Q21O4Hg6BSfvNbpZPPLZAwSGySZylpf/O97GVKiGphptODRRtp78C2DiEgP1RQ3Qu BjetE4eL6Qthl+AksRR9b7T/7JzN8cgHmkfNuCFfzAWvmDPqpZ3IybbsOltXJGn91tFjVveT G7JihyMEKckEIZlVfKuw/JibivRkAT2REswCoGaTZmP/ncJJG2TruTqeteBKW2uY4GaVkXDL bav1K4xNwn+8QMcW3ffBENt2/YPcmYHAcIi58DwN9bWYPCP5k9bIUw0lgrcG42CdPJmIfoq0 RxLTJ5JJtX7WPfnXgYinI0HMj8P3eHt4a472TRHVrxHeHxfziMxT7Zym1SO7GO4J8LMbKkW+ Rg2kCdbrHEo/UVjG83x9LSFwtItiKSM6CraxjWt47Pj8vnHotGnkXGll8GN9QFuRQ8z90k3s osk7d2xb84bOXlL2tWoQS8Kminxlk6gPuxbwpJBQIBUVrZDK/CZkHGmV4q3f8FWtc4XxLqmT oUtZ8xB4HIfONNYmebozAlqooyI5Jkr8bBDoFN3kA9gCsfVezBhdjnSReDmj/5X+KI+nKtJF JJUcKsQ78Zu1VjCXIgkwvRkWiKqgM83IxxGA81DeDA/yJHIUDGnSoQsEKO5Tc3OUr8+HMht+ Rs5liToQCTm6EW1nPHpVa/LfMrMzjWwNlcm+dBzduRa6EbJkwlg69yHf5W2K8pN1k5IxEBeU QSPveuLrDLLdqSUFWWXCJSKTfM0GdIl9pWw7lOenSqulb0cVUlQzUNxOfbAZXF3XlKJcqIUu rMvT0V7JUOpnoJZOOMo/J/S10nnJdAnQ+pKKfJnbhfSi5UFcP91iudPwhBr6ezIwLD5iOsN8 4VgrKVa/3KqkhWRPTD6JEPOulP6KJI3xAA8n6hFiBGQgarZeipHOFzpwGA0b+Oou9zvxkHBT A2S2iSRemM6nB2PN2ncFtFgoN+6d8yc6pw3O1yfewSm88J3lPNgn4toO0jeYXEYR2qrK7fix qz2kD5H8GV8gJKvFk1+LIxj0+pq2BHMiYcCPoqv4lNdNI5rkKd7Xkjlha9pC71O+Yfbpi9B9 V6Z0+smMvLTrZakqIVpniL86UT5vk2ErFT7N0G0MK20tO8LIww0CnB8iSHS6nJDm/39vddst VJ/fuNIflZexI12zDy/OxF/68XWwjFvJgbf5mA41/9n8j14xN3AA52P1hkmk8mLl/5H5IN7e q/QEOuDJ7kwCXcQsbuSVPNncP1z9gBpd94c40k+DfEqqHXCtIG5Elf+4/0rajTEB0nTq3nJm /E3JnnlWTBHw0O64aMGCSiST5FKooIT/ayJ1qS33mtxrf6tx76+I9j6PDy+Z6gHpSVWmoFUh gxWr48fp30kOh930ukQ17lx3Hybkd4N4qj2naLgMwJBmPEO1E7MqdVt71UYLFOzNdDbvb8ku i9h1s4+U96lJtAq4MOHlMbKLd1bkizcmttL5Q0hlFLJnPgA5JOzdwAqxzHHTov3Iu6ups3n+ Fk7rw+qI2OwjJuO75WAvqTDztji7t+5/t0gNy5i8cLmMDL2eerUbJV46ci+7qEZvHTDW9dDY PpRF28KfCt1sqAoVmj/KQGqjLDFD/yCKHoZ3OQmZ4f/38zQrU365+5gLllg3TgSOo9bS/ABZ 8VWpDGPE8hYxVQbfWOp09xNqoVISmSflS0Zp8e6mFo1MjccWwUlWAL4LFtFH3/n2P/rIVarH 0XfRZV0Lz5vO40gbW23xZtXDbgRTDXuj9gauUf7dMk55aNo3eIwIqnhTxO4ZZo29ZqXW3SO+ 9Ir+eOTUIty9Nnj1nwUbtcrOvNJDsBP0ZxVkgs+CalNpVIntPjEigZOHlrjUaYmm58qrt8HG jGPPVsPTo7iKnsSMMnsZs8wwwzIJ/ZdFVREQO7Cx4UQiDY3o7Uu8W1fq2KrwDuAXAFEIjGDU sGxRNMvK2Mv3mQAuuWOV6SW75iXB6PiLL/n6bzDUuuu5TIF0ubN/oyq/vRI/f9LwuvNwJljy odGbFjzTXwcE5DIzxgXtyBE3rRqccz4A8zReeTU9TnnYt1/wMnxWXdhdFOMKrqCh1M+CGbHb BR3aiMBMCWk8g+I4Fi9+brIGkscaepHWsnMJBHDw0Y0U3CDsA5sBt3HF1G2gilJKZYjKkCrR Otdm80qBTX2GPaVL6JtdHbjpqeLsy3jCSZYoc28ZsxeA0N90t0Qo9H1PnNenr4HNxmTGw6+T Ze3ButSs34L2S+FAPyWFzSH4QBMHqkPnUTrkuzYXSQo4irBtqpXXeXq+73WqMkp2c7K1PmYo daBYKLxLXX4ENM/gUiuVcu3WtzOf3RgLY6Gz7Tt8Cw9sz3TbF1hxOM02KE4wIYVT78wVtUJm Ua+SGeKJIUTm7WPgoO/+4yq91w1lbmRzdHJlYW0NZW5kb2JqDTI1IDAgb2JqDTw8IA0vVHlw ZSAvUGFnZSANL1BhcmVudCAyMTEgMCBSIA0vUmVzb3VyY2VzIDI2IDAgUiANL0NvbnRlbnRz IDI3IDAgUiANL1RodW1iIDE2NCAwIFIgDS9NZWRpYUJveCBbIDAgMCA2MTIgNzkyIF0gDS9D cm9wQm94IFsgMCAwIDYxMiA3OTIgXSANL1JvdGF0ZSAwIA0+PiANZW5kb2JqDTI2IDAgb2Jq DTw8IA0vUHJvY1NldCBbIC9QREYgL1RleHQgXSANL0ZvbnQgPDwgL0YxNiAxMTcgMCBSIC9U VDExIDIyOCAwIFIgL1RUMTUgMTE4IDAgUiA+PiANL0V4dEdTdGF0ZSA8PCAvR1MyIDIzOSAw IFIgPj4gDS9Db2xvclNwYWNlIDw8IC9DczggMjIyIDAgUiA+PiANPj4gDWVuZG9iag0yNyAw IG9iag08PCAvTGVuZ3RoIDEzMTAgL0ZpbHRlciAvRmxhdGVEZWNvZGUgPj4gDXN0cmVhbQ0K yFY3rBqCrZ89ZDGpWnSvBN9JiryDERyTMBDzF3CzQNWVzj9hdlKy4pRnfNYUXbQ6iMwjLjsG KreMJ90kox0RjIrSXvhIrlI31LO6ZoEzzNXxXv5TXPpJs6VSy+UrNMzm3HNurlHQDoiJP4wV D7kMlL7Vha3PFUFkh4rM5h1wS4yVeiMvYrSi1xv00wVUx5lPowDsZf9OJsgvhejxT5tnM1LW jGL2hpfnkr3SVByCJQHvh20ZchLV7vRayj7J5kjM1muOwFAQw1ZFaDMb/DCpGk42dsi4MVbJ LHFeXefM2ZuZ/PqL9a6mBnuApYHNvP8pRh1k1w6J3JdFODj6oM0p6YS87/RYaI9F1pK3UWHh Oz+MuzRSbDhnnRnCr1Fklrul8CzLRMVx0pApfK6TsL8Yh++Me81n0GD/nX8Wnk4gvJRQDeOa kQsdmdMIrvRG/yvN94R+XroaKj3dteb0DRjOtM0XAiSPxBcRtDZKdBD46b7qqQXb89wSbMhU Z54D3AQhNujDPQKLH0abQDT+AnRYRND9LUe9lFAmqGYV3GXAt6G3s3Z2DFMHxI6uyAuMEkJ+ oMkOznkXgw+7QlyZVyKXVqI6IwHsGPtkL4K9EayWoXEVX+b324OEgGSn+wvg2e6J6e+JZeEm gyf7P8r/n1iXKDb7NJ9Z1f9ZIbwgfXK1sGFT76ftwdokAanC8h2R5GQwunnw6oGMRujBN4++ 6z5etbbGmhYIVyCCBZP/Gq1vx+E/8xKPPPRO5B88nfZIOkHpIvP6V1yAyoCFMNB04ZFrjrT8 90rxjyLHRGIlfE+0/PFaRJksVIqjRFDhjBv3fnaCZ0ZUJUCR3CeafHiRjRnzn9iwR301xJbv EZhMbB/ZVoQbZYRlvOJnxHPCBCJq0LpLMGt1hC0yWlA8hDMseBRY/fodcRsnWxoxJulPpX06 GCL7XaJ14Z6Q21O2cp1/2XH+Bx9FngTdNTqlmSZpHy9jKwC97xl3kE4nO5gSOF5+Ud+6Q78m 7lj1XNxWcOisDV+S0WL1bKRqXOCK95+rOYgIiUy+0YoF4mw8OGO3Vt4skcr7FCipfkzyMavI PZpsqoVAuelHv0L0TyY7E1HPIogelfCNGxvb5ErSECH3B8cD8rcAjx9UPFTLor1eoIa+t7Y4 Vu54/T8D6zuZf69JbsH0N7ZxWZ7NFCsTFYFB8SijS075ku7XVKInrpH8VtmBgifQbPer1kzr skjyMOe6lqTBwlHdpai3yoKQLNmETGNMPNkf4bkPD+dOuzMJzhpj2aGe597hei4AFjZJdwKV ivJsV7nmCkEwnvnaUHwEG4u84LUZdCSHPJZq47TcE6HMsnhDQw48JXZsYGHnqCI7NiU5zAq5 91V1hMiSbFHcle3BLEzLmVo9E1+zBMGpO7zvtTtbJYoUTGmHtxPphuaOdu/U/2UGZyZbZdm2 ZYxIojmLe4qU9QEjcNUHcflONwZM1pGskNFnijoJPw82O+Nwrt8FBhp1gp/O+gmZVgwXPMUa 8uW4r3Y95LdHLugPTSiSPd6aCF/Z3qyVClGA87hDYcJje6XAVRMRsoYv153JhuNgaL4kfLo7 e/4eJz8dPjfOx/27Y9rBlLUgUXJ51t5eiTKun/dkCQ+YltFLdTJr1Dk2voTl/SxhMVeesXE4 mUWruSaXr6YiU9rj5bgUA3zb0YhQUtzmUlWRKA521lGVJaKmXtY5u25PsrW7UdczVt/Xr087 /joIo08dBGNZ3rhnJ2QNZW5kc3RyZWFtDWVuZG9iag0yOCAwIG9iag08PCANL1R5cGUgL1Bh Z2UgDS9QYXJlbnQgMjEzIDAgUiANL1Jlc291cmNlcyAyOSAwIFIgDS9Db250ZW50cyAzMCAw IFIgDS9UaHVtYiAxNjYgMCBSIA0vTWVkaWFCb3ggWyAwIDAgNjEyIDc5MiBdIA0vQ3JvcEJv eCBbIDAgMCA2MTIgNzkyIF0gDS9Sb3RhdGUgMCANPj4gDWVuZG9iag0yOSAwIG9iag08PCAN L1Byb2NTZXQgWyAvUERGIC9UZXh0IF0gDS9Gb250IDw8IC9GMTQgMTE2IDAgUiAvRjE2IDEx NyAwIFIgL1RUMTEgMjI4IDAgUiAvVFQxNCAxMTUgMCBSIC9UVDE1IDExOCAwIFIgPj4gDS9F eHRHU3RhdGUgPDwgL0dTMiAyMzkgMCBSID4+IA0vQ29sb3JTcGFjZSA8PCAvQ3M4IDIyMiAw IFIgPj4gDT4+IA1lbmRvYmoNMzAgMCBvYmoNPDwgL0xlbmd0aCAzMDEyIC9GaWx0ZXIgL0Zs YXRlRGVjb2RlID4+IA1zdHJlYW0NCnfCLOH0gxqQoUEd6XYzFUGtzxlOJimqp5f60pBRJarw v3+gE52kEfabp3LOPqB0Sr8aUM9KVzosFPnG+zLNZEfCEmfwl6v+uZf/cYVYgan7gtPlXPe5 I0JVtzGb9dUeOBEvuKxEqJvlawnz1uTwfJZNzXOXOqnchJG0sdI/40rzMHJJpG7puFZnDi5I sZ+6EJeuS1TQ4zhUtQXZxGe859pzAWXTeYyb06QT/y6qfETKLtnkweZGP5gXnAaLJjkmLjqm O+ZORIekaDRh5jmxmUhRS6rumkzNr+1fObpm+VbLzn3lGbZy+8GvgRO6TzXXv6GygP3h00Pc /01s9GidxPD0zyorjxOuG2Q41dfPsMQuR1hQluHnzcwBm0bF9NaCG7NqtDYXkx8yhZuWvdZM T2JfOWUOnazV1H4Mk6jml0IsBuERAoTH/oK5eIjamDJ634d83KkqaCsy//wJyqiUPMSaPQ9n zw0ydB/g7aSsJUBo3vgIxaytWGGEBZuZrKuI1h7hAtSqfEaLdHN+HftMyXCCh389YH9yd4GK bF/5ryFrMJngvGmqtIu4EdsuVJWeK3H8uyYP4r6EXfJHusTIwSSAAn+Ye5nTUWfQgjOmepjl HNQP0ovRpPNj681mebPsbYBz2Vpa7HrxOVBLpwhqhT4pfHveDq6wKq12RRlW0ej9J07BiZck 7j5Xm8esGlQdHQpZl4RyM7AiUf7yBL69wPfakkLnpP3cl7nm0zNkWE4TQmS70XS2qlmtv3si 2ruuGZbY1ac08XILcIoDow9qvdVsXX+wOglO/aBDEH8UIzy9m5j56qpUkkexBUgHbgdBE8vr 6VO6icTtzBNEFFVhgF3F6YmCjBv8nUu7FwSlELPkPDW8tgnTK3gYYpdpnN+QDP64Oz44n2Sa /Mb7qS1hs6Yu3A8jwdz5HLNG4iUr3ZJSg6YBIchSR7Yuc5SUPi/+mn0A+04SK55Jt4I6Os9+ XuVeisScYhCHua/s3RAZcZGkxXJt2KhH0aNGgMuV9kCr5QEKYC7mUgPo8m0b3JGe6FDCde/E 5XmA//or6k+19a+6yPx9L9y6uhBIqOtx0Xrno9Bnbp44vPQob65NuzPXDeKkqHC760CQ7zpo hm2XGKwSBID0iKvhNPzbvYYNO5JtEZo2zc4U9au6tLxnYhVcMGFr5E9Vcx0TWFI4cNBik+hx Z69lDuko0X9tQGrOyoS7XqRMlkZ7gvFnZ+kofBEwvHDieOExkjr5AMo12U+3FjC8fpVJ9PGW F5p0hwqRBfiMBCLanc2ZUfOBjAbb0fmt95aHGqALhFonE8TFa990ZXfaVUQ8hEe5UABUmCz/ Lt+OSkLNe4EdsNeA8PxGCxIrU0do0/5m41CsxWAq1xVJN+7JwfI40czeWUDq0mAtkPIWhlqU tpHnJkO4Fnb5PyOFUaIQSYE9n6daA8z7xE6NCHB1WgAKQVnGQOoKUyLgaPXvFNmxvV05AInG 0NnJrp2rTlgUZc03k7e0yNpIUv0Nvj6AvuqS2veJGKG6FuCRaFu8f9sfORDnkeXO7kBYyskN NcA3ad3Oag0W/pjutj1zDVMLGQrMGNZgAd4adyjT4xUmK8g8fkuGLGV584MZMo3g3wsztAVU 92sjKIaD7iP5eBA+YKzAhrijXVdzrRpzuXQMeZI4RT8yixCRnWsRGIOS8kpZT5miUT/B92Vw kbfvns/qjsmT9FFBr2oonhxuSVn//Yc4QFxOqR1VcW7CzUvHhbKaOqFklRN00DtTIQVJHAID ZlrCm3yIJwu2HMmT2oF13vl4gYVEjLbuExPQcRLTiH9Py29Sk3v0ZZ2a1VorhwLpdPvG8+2u mhFjrBfoycCvlF4wQVOeE5VJRLUhDfZ37Vapqt1+JraAExcWMNG6Os8mj6BON6kPGn/V3svI 5l4I2oUfDD643xa/NLUtSGlc4J9NAl0ebqS4KZPswLpCxbgLrF/t5o5P46PwMna8Cq+iZLzA GziCI+B5wBhGa9xBiDFjn5RXcd8V9SyAfU5A1tZIv8eWe5snI49/6HWYcHPpKsbu8U67tpS7 1+Sw0RGN6TcyefJMDZgEBjlC6XKmXxskeqqDCkD0L+xSwWXlXQiWHdBguX7k4uNh065i60kk 4ye+pvdm3qCNMIYM/tApEgegPsx5WXvwZNebujDcpB1dyvzaHZvocwXp5xD31JNplRVlkgdd s5zZU4F9d+hcMZTiyIVaOrbEagDFoGw1ag5P8dp04Lfs6dr3FF7AghMLSQknwPH7Y5PxeW6u 05AWuykKClY/pjYbvguwmcwpVHuEMovct/F4QsiN6RgDL6bo1yTuLPJt5OkL2Kk5nOvNgNmy oXLaHuQtkvd1LCSzN/PuRgzKenXAKfnC13I5JH5hr88J4U8vc5SsS7LXmIqFPzPpgtIuHHES 3MnoEVLj8vSRv5ejSsHaKjMYZH66CE0A9KDWz5UNgGTrHutn6syF1BuKUYoHmjlGrTOKKNDb cIK05rkzo25WOUkDPxjOlbOUknonoFuIIgtC7Gdf2Irt2a3vPbX9H92nUc/ouXh/VbTAZkx3 Yw3iK1qPSLOsMAG5e82dvIqYAPtWkLa4/O99pzXvOeuM+J0nvgZOVvNxyEWjlaa3TseVXciz MYvGHNQU84PnwXGkvrqTwadRIG+gX0DQ2yYaHbk89rRjRi843NPgMVUIhtdUF/lVDPfUdOh5 8ZD9KsiktBZO8XLRvOIa+b0jN2CtBc+gglF0FgGv38K7HwtA57oHPKOP3yjrRt9PUXuH1Qb7 1V7JcL0jKIxcV7tJTYLtu9ekrhDSNyrbdsuhYzS7/m/rpMMuhZ3iBnBw8bXl4C8g8dDp87Jb 9RDzmHbydZt06L6+9MgeOzkyfO6R+HIvswqLuyvDAESE0IXWuXxwTHkAqcQ2UA16KmQXz2Gp y+17rQAR7apFOHfuLdQm/YA4ZzezIdydPHwaLFHH16VCnV6Qc3TxFjyFfnHTUNO0HMl3QvjE vWqm1lYCFLKCSJBgHeDbCNO/sc/90/e9H4wNNR2K+3ItGHoQ53FCTzqvrwXgcVqsVAolWUut /CkAmZ2GO1WaDaeRkgpRVBYc25/+LF1+ruRrQOA25K73Q8g58Goj1J7+YsNNV9s9dedzDwbo EHuoM95rJfoSgQ+CFgPhu4fHS0gsLeKMmNouo7i9iqT5jLZhEqBI6DChMeRxj8nEgWwbUuEt H811wqIED8HoROZPGBVeBb8jp2w1KY+sul9Qxmi9p7vp6OFlNow1uFr2l8TGxsKdjNXEjAbA n6al4SpesIRw2OjW/ZNTK/+otsqcBVwwcHdLDGAitzPEmcV6AKQmWzNs2qoHNz4UYtksl2dy kDePYsFGTxd4dduPZtMrzRY25KDz68w6InT7Cxx9qg9qUMpALRRnVcQz0uaXYNNhiVi2wdEI Cs7BhlKmaXY+1ukos/kGOtcC/IxQw6GHOvdg90CfW8otAeGhcK49+HToT8cv4QFP9ksVh+fh 69UDT5dhlPEyo3x7s32cZVFeJVtbYJzFpg1h4BXWGp9wu8zl24jhoVkRTWSm5JdZdJ76Nlr4 TKSNRI3djBqHVQeWYZKbCBz4Vnpn4MMnJDtNscLtqF2BGOFFRahe6T2RqajfUZNWKEcICAzl 7zGWvGizEfoCYpiO82uqhrkilF1c4NFW2C+rMzVdgUvdadt4WvLepfEvGD1816sFY1rvlFey Oe1EtbmyuyJ3ICnN/WxLn+r4wpnJsTJtLamxmeXwoVqy0p+qWqlVezPrkdBn6YSxgcTLPH9/ GMh7rNnztn3vyM6OECNyBJYRRWf+MdR5oxE1noh4kSReZvn0ln1+P9CMuvnArTassmSW6iuC +SnJfFLlPN5XCMxt8VVjHYNW88CPYvrQYsHYGj/xFrRTTWCQM/aAEUIZcEJAijrgiJdZbv8b Vfxb/UPWS77D7hOK8wr+ZICD/lHB7PDEaiLABKGZUtlNvQCr6wh8wo1UlTU/s3NWj+JF4u7B HqnQdcC1sxummw1lbmRzdHJlYW0NZW5kb2JqDTMxIDAgb2JqDTw8IA0vVHlwZSAvUGFnZSAN L1BhcmVudCAyMTMgMCBSIA0vUmVzb3VyY2VzIDMyIDAgUiANL0NvbnRlbnRzIDMzIDAgUiAN L1RodW1iIDE2OCAwIFIgDS9NZWRpYUJveCBbIDAgMCA2MTIgNzkyIF0gDS9Dcm9wQm94IFsg MCAwIDYxMiA3OTIgXSANL1JvdGF0ZSAwIA0+PiANZW5kb2JqDTMyIDAgb2JqDTw8IA0vUHJv Y1NldCBbIC9QREYgL1RleHQgL0ltYWdlQiBdIA0vRm9udCA8PCAvVFQxMSAyMjggMCBSIC9U VDEzIDExNCAwIFIgL1RUMTUgMTE4IDAgUiAvRzEgMTIwIDAgUiA+PiANL1hPYmplY3QgPDwg L0ltMyAzNCAwIFIgPj4gDS9FeHRHU3RhdGUgPDwgL0dTMiAyMzkgMCBSID4+IA0vQ29sb3JT cGFjZSA8PCAvQ3M4IDIyMiAwIFIgPj4gDT4+IA1lbmRvYmoNMzMgMCBvYmoNPDwgL0xlbmd0 aCAxMzkxIC9GaWx0ZXIgL0ZsYXRlRGVjb2RlID4+IA1zdHJlYW0NCuxeqTsQF1fawfa+JxTh KbiIjGlICcC5ZL4OBU7EOwI9FoYhxVwSuzjSm0fcLMYOwNTweVKQuVZtUABssaS/LhvCNHpZ RPgnA2YSRVnHsZnYY2TwYlCg1W3DYkQlmsQrLeSRQfPPtgNS0AkVtbMmUk0SWl8NVC0xag9E PB7en5MzGkbVc/zaC7IepQyxGBsVfoEVOj2B4+rVBoswCO1uZpQRmCnLerPhetw/xo/w4jL6 grwwOzI5CpGAzAVPalmHX6v1BEQQX1VNXeKbZK/sCgHYIPTbg7cV54rVM1JCR0b/TRKJkRTg 7ODBOAoPfYJDO32M9/gFMGApypdFxfxGC+9+XJqEDrsT+hLB/5jkWd/1aG39icZwJRXQNzhx zE+h3Sle3uGT3sQXAnT/J9gLgD/BU3GWWRFrEtNizap0dZxobgTnGMpI7MIDOok3LHFBFw0K LzqbdXbkW+ph/xJMi62G9dRMRQCqbgQ2FXuL7K/tFXnci0e7i+T3d1gimwPb4Rxoh2dpXhDy eWo6k/m8VONhsr3nviygZ7HO5w13mpMFnnWpSFGTPbfA+R3hnnKJ1s7RtJ8x9d+0GG27Hp4/ vV8pP43776zvZA446Eid6QkJKWBRZj5nnBh+GHX8aV1SwnqeMgew5dx4tI2K4sXauw26gMmz qd41TXNJtcXH4OqUi0WgWmSmmsYaH+bk0t2jNrMpWIeLFzmgdDkpaoB+O+J3U6jne7/29/G3 Pqdpr+0t7pqU66PFHbKXErHOAK4cQCwIhGZQ2FIbeFFWoFyaWPztUKUo8dLHlgnNOxKlIMJM YP4jfn5rAXG0lanlhBHLeEekF17eKsSmE+mE4zs1DcNnDrO/Jl1UAklR8mfYZc91iIpsXRwh SBXzDidgq2dFdPPtZL0o5jxvrtAeodklCTbHhZ73ZeznNqNxAp/84Rs+FcRqIzcBnQiRwf3O uL7egFlnoOwPzLaXhrymJVAiaz9oaJmd+KpxHOMgWyASJUBliqAf6cNvzZm7JdUTBiF3pWMy Vv6tSHVkTVlGiuLXHK4Cb/mdLMS3yuQnT/ldTiPAXGmchn6y07EEOSwQ7fESNbmU933lPhx7 T4wDCJSb2LK/eXf8uxPm4Z/QBp91pNDWeMgDkH26rhvPhLWsdcJwBsPoW5+pRsemMGO8CnyZ 1MsjNQmEqG2hMrEbgji5n1IdW0RtITKuUgV0qGDLPCscMXyp1/OzhxkWQyqFIVXnVdX5j4BS FChtJFmsp2a7L8K51OyeMV16/eMkBNfQThmpiBWP8W9LuQ1qzKnh68D3J0Nm92KzMHefaRh+ WrLq/IaiJh22Asje4/s7NsU84Tf9kVHKBPW/pIWubXUPxdVOx/vt+adQ7lojoXpRGupyBnQL s0neXsCeRhOANDAkRvMZ9m2DDhnzsnBzt/sog7uuQXLqNpQLC3BxwEgvQlh/613Zi8dZh/0S 4oYWYN4nevvYEIBeZT71VzJrNtu+QyKEDbu46pgf486abAZHQjHa6rdMg0tyDjjjZZRLf8Je bttAxJ0ahPVoxByk1PfJw6+XFESR8UHXbeQVfun6o8F2fnUMIw1I/JpACKSdKz4KIRfHCxgH LoK9BLAEydoWjC+FbqCJ2zJ6wKpMoNE499/4wTV/fXcxyOlfVIkxl7gZl7gH8hjoDH+ZuyMJ ovKJAp/YLMD4Sa4UbBIvge4Rvg68AlWxf2FCZHDmZmegJttog7ND/zvP+wpTZSuITnY1b9tZ amCOI9GJ6Bv2OVwHWJUQmNeOjanc8Mer3ypDNv96SRpYZFfSxqclGEV3gGnKBDxIyYD41cgG gWcHIl+ZrFRhkCZpgwNJP8cjW/AY6EfMBhLCDWVuZHN0cmVhbQ1lbmRvYmoNMzQgMCBvYmoN PDwgL1R5cGUgL1hPYmplY3QgL1N1YnR5cGUgL0ltYWdlIC9XaWR0aCA5NDUgL0hlaWdodCA2 MjUgL0JpdHNQZXJDb21wb25lbnQgMSANL0ltYWdlTWFzayB0cnVlIC9MZW5ndGggMjYxNiAv RmlsdGVyIC9DQ0lUVEZheERlY29kZSAvRGVjb2RlUGFybXMgPDwgL0sgLTEgL0NvbHVtbnMg OTQ1ID4+ID4+IA1zdHJlYW0NCv/9191VmbqExvrnQy49MCpQVn7bODE+ZWKOhBMyEgr61Rfl GewSdARggKBs3CFq4dfTM0/PO8NveWzXFu7geRrs+n5f7kRCu98VGWPY0+ilnhPK/1vVIysr 4Wy6qW1pL8aDYQPD59voGkObXhRthYRE1Z3oN34uA229sQE+IrVCrq6IuWSSWP9PzjqYJ8Yf fSvhnj0+iWBdBwJiUB7h/3o725wVurnmusU0Hr5VHDCW6rf4rQgQ1LYBFRZ3a1GMW8iDhtKo SxcZCK2SPI4T25N7+NPSokCQWhWX35ZyKRGLIgCOOTxmrLXbTQAmpzZHHFsnG6WfCJIoSeU1 +C7Zq8y+k6OHc5K4vJnrUjI6o80HxQkb4v6KM+KIHn7swh+x+wOunqGcC03MjOAcM6qwH86D dE/cKY2lncDLRFTFORdkuk+iVmgEHbaTnmqunL0OCi4V7utId4VpsDaUPA47FEmpkcYWuXMD 4m52UbP70XlenV8xMPZi08uUFCzUo43cNHSg24yW+NUKcnCPlTpWrpWCGNYdFrOsdPXT61MC KM6Dvqq0Dni20jzdTbyc7vXygs75X5vCQp6YT6XcVJR08ISdmFyRFQ3qBlxp3peou/qLbMh3 foOc6/gdk6l4uiTu9WNwO3BEIszkkEUdHVXIbuPKWD5Ff+mgz9Ls2oHkj9tfj30AmZv0SKqM 6oULaPC9jhQjXvZe6K/8bzpnNVqPDUcQQb8JDZq5+hKrYTC8z/rwIB9JyNezMxi24MRPUCMy /hNsYPw5nnz/qW9lglCh94KSIPifh7Nz3NxohNGfMGHTKhMNwtSoHqslWI+1Njy3/AVZxHy6 /qI9LuSEsLk0Md6X+4avpEVogwTMCBysVt1BXCCkPEYesCWI+gdP5vNR3FwewcG59GgR+uCk z25tj3Gnq1l98i4w0FYS04OFNG+SElFC+WeG0itglBr60rwwt5YPZ3z4j3iIgOuizejIcxIN zQsnMJvzIRkm8PuUzYKLpBLjhDMLHtqfqwbcpjuVPVyVPAXJWo4Z/TPXdSPqtmPgHm41sm41 ewI/4cYcmjcXUI1SnjcuXIJ9GdPwBAEgv2puE5bXcre8hTWwIHYtU/xds6gFRLtgjbprlMMf dLchO4LdsOWrx+mb/SH4vs+nHJ1qperiij7wTcLR3ov/gadisInK6xaTwK+1qlXEZx20xwoh HmG16/1zCAITJ2XleA+SHKh+3Cb0/0fcg5WFp3w+s7yN80x2eDKNX39pRwOSdxW6uztRkgWS N7zkt4Qun6K7cSOXgey14mWs4Nn0xcPnf+hstIRGxf1CZIoglg/mGxy3MDTPLrdwO9Ebmi4O x1WemFU0C+7hn8zCjnKzEq8QxJQwFNx8Dc4hlPirkCr7PJwi7bZXx1F9n916G/z3URbrvXOh x5Bmfjhgz8kgba1zFZPwqaew7QOAuDSnf2Ivph4jkhtNUo6TPoGuSUsGhxjwc6c0mnVjKY3b MqvsSaTNWfXMhtJWkCvgRZ0RIqFvtd/x704UwSCUuiEWPuUzdQekySmmBl5Jl+C5u8QrJyB1 H2VJlESook8EkHqyw0bZgAeFL3UbylpP/nDjectC3WadiIxNEQLXZkS50pxvfslzRWP+tMnG HJbYnw+lZkUJGsNvvp/5kM3YI2EiJ+v8iap5jGxwOfzKu4mvdjGG8zVMPNsTjK+5Wv17Bpmo LAWDArI4ck8Y2SEOsn4BUdY49ATn+tMAW3lZbGdGKNbJh/TZlpi6yK8MpMyRsc64FzSskXfe LdLKVemwy9en8X9ni0oNi4gYKwHl0UeE+VQ6/3gO12LSLVPALUNOMCPWpkNI9FTwBIDZmoiU QbdJ4XbgBbkZopp6++6n2P7cUaTfiY+oEtuYaP0g8LDNM7GpCb2In0jniLgGV5HZ+G4LJbot RoO+PL5ZvMmvQi9wN+52KxZS0aPrqNSsBT9nlOKvdK5Y2YhHjLK0Yyol1fZKolos9qgEfiFx xAhcpy8UJ8sFbyU5GsPNwfXAx1mHivlwojY3aSeM7m+G9yuklqCESpzlnnLm1yNY/YvRM5pK 2yoXb6HexzGNnAs/p4RPZ3JaLosKUvlMlD1SekHp33xtQ4wd4YSqhwvqS4NAFrZzw8DqTl+a 9zGLi1SP4v2U3Wo/YZYlHGHT+ZRWgKEG9UcD4ZG8rItmmzyoKTEtrEghYYwF0CkaBZmiVwXy r/y7pc5iyehdsvKrooD93XMHJT/0Dcr9T+Pl1/OiH7a2zstlbAPHHf/6YGTRgZ7Mx4Bm1PYC 7+A4GklBZ8m87gWQWLLzoWPD/ijEU4uFbH0ov5TaFnlz9gBCW2Jjj6gLp0O4+A00MrLb5j+4 wHicOl8PH8m47JHbRYmI5C0ZeIsY7SBoEWgo2rdbJPzEdzpF5yR+OW+B+Mm7XpOQeooONcuq xfG9cxcJ6tp9yxuEh78xlJZnoGi57lQYBcEhVQu2qkPQswZSkA63/aROtstYhyulRZ5WzUuC hxR7NyeNW93LwGsvgcYSdQlFln6hcgwBMlve24ixHnUFGz1X2MoJ300K6Xe3xPusrIEivlQC LPSbqs+GsB1kZ6ijHPN+U7u/C9mMPKb4y64KEmNCw3B69JqrJXxR0LF1y4kPjZ78sWoYcyWK Slzrr12Rw3mYdEJe5LKbty5S+0HC90izcBamLX75FXEOqiimNhZclBaM2MX/Myt2/ZLPmedl dPTgMH0Q7q0tBJGbgT7/+01LZ/Ao5xOq0I1mBQYwIsdvGgAxXWiaN6LaumZbuPM3KBfVBKr4 FfPLb7kB0BHxGychPL1g9lSBfSGqHGugBKxoLDmzpSzJNFPiF9ic64rgTCWP+Nma2jVPiLN3 MJROv0g4AK5J4PKM+X0JqvrmFrT0wVTbpsPonbwRP682iSk6nzADPMSGfB5hwj4w4i3SKBUP 3qUjoOduyvyCWeoGj83nzGiiZ9k9ZlnfO8OerEgFpBpeH+UdOBeEfH+P+a4oRc/o7Mhtw71j FUvdc///NU9Ntj+1CRHOpvjYpmd+qCIXpdoRTPJkZs5FpE34ekrsuQsQh6Ua7GhxWUH1BWzH rDdLrCjHbdRVOc3vn1qJSMLp51VTkPC4jRDeJXiLlkSGrvE0dLEi8XB+K7LDJH5K7fbKdutz yP/Qzdhbr7qvHE47LkXQqjb+SfBiJLiStkUCtqCqp9K5Ff5zS4SPjQjXQOZF7pDeaFRW9eT9 wOJP1qNWzYTz4Jaz+AX2JrjK7wE0zd/6dr/yH6D5h2MQMnUJaHoWbaytmufhspkcMkmC+kvd E8y5Ri5HZopSnSj6hR8nMT5vJt5A9tKfTWLy/a1md4TChHe290Gt/N14DLhGvKsHxbDf4NJJ 10F3sd3E6jJLKgK47NUj9BamEsu7DK4JzU3naQmlfRmpjkvZ5Ycor8+u7VW1al9MbRGIrnMY Z1l7XRRDBrH1w78y6Qw3iErIlw03mGju5VGBjMc2CTeF+VXI/yFSwV95zA1lbmRzdHJlYW0N ZW5kb2JqDTM1IDAgb2JqDTw8IA0vVHlwZSAvUGFnZSANL1BhcmVudCAyMTMgMCBSIA0vUmVz b3VyY2VzIDM2IDAgUiANL0NvbnRlbnRzIDM3IDAgUiANL1RodW1iIDE3MCAwIFIgDS9NZWRp YUJveCBbIDAgMCA2MTIgNzkyIF0gDS9Dcm9wQm94IFsgMCAwIDYxMiA3OTIgXSANL1JvdGF0 ZSAwIA0+PiANZW5kb2JqDTM2IDAgb2JqDTw8IA0vUHJvY1NldCBbIC9QREYgL1RleHQgXSAN L0ZvbnQgPDwgL0YxNiAxMTcgMCBSIC9UVDExIDIyOCAwIFIgL1RUMTMgMTE0IDAgUiAvVFQx NyAxMjEgMCBSID4+IA0vRXh0R1N0YXRlIDw8IC9HUzIgMjM5IDAgUiA+PiANL0NvbG9yU3Bh Y2UgPDwgL0NzOCAyMjIgMCBSID4+IA0+PiANZW5kb2JqDTM3IDAgb2JqDTw8IC9MZW5ndGgg MTc4MiAvRmlsdGVyIC9GbGF0ZURlY29kZSA+PiANc3RyZWFtDQr1mzYGZptwTpevGUfK+Zfi Urv6M1V7/DNcac57RF2f18QQkgQyN2qkHTxjwUJpsxdTvolYelxh3JmIuGFb6agsWHSpij9K dxXdBCMECUA/yIlAdnxWjg3oS/hmxbyQBv2JFrzKPg/04uLJyGmrZ8N2QgG0jeH4h07CG39/ pwqQb97wzAC4dOC+SdiCUmziys8uLJl7olB+2MPSapBRvCSn8DiyOr8A+9uYjGacLJsOWqpA fktqpQ8INCPy/2/l8LuOudHrTTs1Pk4hIoi6jbDWwiyJ/jd6mTYdmeecGKKwyGFjaUzSfs4M TVTuaR3Qj4fDBz16rrykolBC/AWvrl99SRFNc7QZf6LDPM4uRxhGtYXOvvpbM2gws74tqr5l PCaWxDr3nQqrvHj2QBOwlt0VmuL7KaCeO+ynSoqI46rWzLX260m1/EcNxx9HwVFjaDtKzPxL 0GlDm8ntK43WYUqqthR+rgIuBlIFfscCddZ0ho0HthyvJMEbnj4oJM5UX5zGeYb2Q8bk/j9l W9jEiMXREVlfwTI4eneNckKhkQzCWzmDEMndEXj93hd2UizART6T6Exdye+sAJtUkbkjp+0M WHeALl4lx3dPcRpbddJjaRCN0aowpENk7QuI8bz+UHCepl/Zf0gdz0YxxqdHGs0J74jrVlqP 8UgE2aG2Ogivii9rtx9W623IsDby1P5xu3O6Ldsx6+MiQwXFLkZjqr8WBdalva+E3EyCLimn nhRvyNmUR0XkqUEiO1Pcgm3kVxXVNqXp2ff4xjDYSlAjnq6zR1y1N6O5NpSQTI4VdI8FeIKx kgJbfv5fL/wSZDLUE+xG37L+PNOhqgVAWKxkKW/KSSyHr1PuU0x5kToqfNMXXgdTf92vFm6D gSzKuzUs65na/qprmspmvduNWpzpQWpOmqtHdNBdjC4Al3PMMz+lvG23xyGeT37xMHZLfaBa qpDF1P2oMdL9HibdYHz4gLHrxASkVvASqTTeXoL9ZYuXBpILQFCnBcv8fuSRqbi93Vakn+B9 oYTOMQmwQ57rhH8eQN9BbRsRRKhrkm9gQNUnzspLJteqdZocF3U7QSvyX3BLYfQaPcYxrCTW rNKjkNFPdW0siCBzZsJKSvIt4rXINHwqfhvlj+HuBuHI1uUDoDXRkqsi+IE2rGP8kOhvaVXu 2rCeLx5qfVKhOKu6oEVsxGJPGVWbQOzvLFwWJx6DYNiNNf7hDDg1i0G8S4zWpUm5tgnkX2pj Tz4MReXIq2qur8UFndaOS5cErZd3dE/eeJ4Z+LLjHvHf+bDGLgSFyWIk88kXWCcssJwgpJEd 3zyqXT4mWmtvQ6pVEESv6GDrBHUQ5w4r0n/nApIoyH5seQyn1Y0FdFIYG9y6YxfN7Dwn4XQw nLK0gR3aSjPy4N66juyWWjCLUan/34w2xk/avjQJRnvXo5c7MeUK8EZmzNuBQmQDl5yRROD6 876ZsimXsLHFC3JQ8ZMlNWT1NBofGiadPkR2GLsS27gPer+v9x6C3aFwonKnShp0zsQ5WKD2 YC79Js5lPJva9ki/kJ+SwG7ipcZW/Pmp7xeYyetFoeSwndc17NYiMB0W6otW0CJWloGEGNDZ KP9cBjXm7QqegHWAXDm8PD8czuCEMu0jE1tN1zgEzFVixjj1svUfKnA17u2p1HoTwHpML7WT guNS85XyfMBGTH8mLAYqw/Lu4hGpR7GgkJ45R17OinRR0LlrjNThdAsIPack9eZM2q+ZDqX6 4edZRxOUIOlF3QXNOkxEJRhj5tt9fQ0iochKJI7F5MmPXqoJm2YgSpiBaMXO80yLjBa5YvAr +psq5dyfuDdtP51tnX4zruQC8DILh6OcdqPgE8RobRYc1ztJXCKbanT2bt3+DWxpPq/r+RyT PEZcC+OqxdinAYp8dvlVKbVNZcqD30QVYi1soWT7byzevZzdd719QT7g54iwQfV5bhu+UV2e xqSHnvugu1IP/4lAYF+iIcM6U1efMMWXM+cFXRC5+MZ7fiZ56V6t42G8ILVm/105dOsPU+Ne LDXdxToNU39xwvWs+CpkwdgDOF/OhsWC1/GDlm5c4tEeEIXRTPzGo1nH/c4+nDwmJB/vMXo8 h6J4/+UTK1zYXBTNBl1OQeobv5nsMfJntMLiLMupEdSZgOtkd5xJOjMqKEGHx3+dtWPqFUpa bfcombrjqruV1V+A+hy8Wl/ii06MT0Bwi7xjE2dyVPnmxpwYURuAmwTasPy9vpuZUoVJv/Hc siAoMCjk2MIG9eD274IluuvyDImUV4iPE33ceon4sH62B25aV1NOxJ7RoobNPiV9speLNvTv WHHhFfl0TsWtGHc0c6pplZxLTw5TnE0FiFeCooJJ8buQm87XVHgNZW5kc3RyZWFtDWVuZG9i ag0zOCAwIG9iag08PCANL1R5cGUgL1BhZ2UgDS9QYXJlbnQgMjEzIDAgUiANL1Jlc291cmNl cyAzOSAwIFIgDS9Db250ZW50cyA0MCAwIFIgDS9UaHVtYiAxNzIgMCBSIA0vTWVkaWFCb3gg WyAwIDAgNjEyIDc5MiBdIA0vQ3JvcEJveCBbIDAgMCA2MTIgNzkyIF0gDS9Sb3RhdGUgMCAN Pj4gDWVuZG9iag0zOSAwIG9iag08PCANL1Byb2NTZXQgWyAvUERGIC9UZXh0IF0gDS9Gb250 IDw8IC9GMiAxMjIgMCBSIC9GMTYgMTE3IDAgUiAvVFQxMSAyMjggMCBSIC9UVDEzIDExNCAw IFIgL1RUMTUgMTE4IDAgUiA+PiANL0V4dEdTdGF0ZSA8PCAvR1MyIDIzOSAwIFIgPj4gDS9D b2xvclNwYWNlIDw8IC9DczggMjIyIDAgUiA+PiANPj4gDWVuZG9iag00MCAwIG9iag08PCAv TGVuZ3RoIDM5ODEgL0ZpbHRlciAvRmxhdGVEZWNvZGUgPj4gDXN0cmVhbQ0KEyH1Rthvc/za zfmAtqW0PUSNQu5n7ly6olOuwTWj/C9h5B4aYIsX0eSJz7Ti62BdDl6nfcfBU+Oqizu7YjLb O3FqOwVigl9OyFbsS4UKGjMaZDe8u2QnhnIsLZj2VnAl097exCCdUKa/XiE/L1GMPyNT9x+O NbP0Rn8qXttXYR43ZyaUJLnA3lugDc/KmsfPyqWDuDoFeuC6bVm0zQz2DeD3MSnwaGJWRaK+ 0UdKAN183Yz3q1Guo3pW+VsoErrnAicZAGjDeRnaF5BQR/2mllgHqfBNZGlcQ2EHO8+bG2pn VrFcrIqvvSJCBqrgp0lwYpGBI53MdndRgHceIs24u5g21Jurb5fqFWe+MWKiM4OtCxMU4ilV VZuM1ckffRiq3Z78gW95ijkLDQQIIgzr2tTbXj2V+AShWKWK6JG8vgpghKl+/+6V86r9khag qQQt3OJIuO+8AQYcvcrH3ZJrkTyAKEA4APXl40HZve4Pux/YAH4crC5jvYvRXn1VoX6PA4AW lnW4eG9aucedjNFkhOclRqsr/joNWfFeJvRTkxVW+b3bcO6YHtpoCLpEA2V/HdVsautOgWUA u38MglBVgDzpsRonbmBqwtqAg5Ebv4rkRSfz6+H23thREI6M1l/FZeQdrbMfdjTH5sWG0KB3 w/a8kr0HrQQnt7p4kNCF1yLhALN0JVfWfob6wcFtf36YjqAk/4O70l1nWiS1WTaf9egSu5K4 lPKZbbK3tU6iBTUppwTcuDFkQdrb4gYTSuWxvN+J65YerSs3v8DXY8bejDWqy0V36hDy/BHg 3oKVy8wFEL8zEi5/T1YM9vgUIKH6GQ6sB8HCjJCxK4w8NOUv7Ugg967mvZJV8H15H3TEn2cS yszCuI6kXS7V2aAFk9pAUglnfuDhowy0BqRPLUje7ipFqwA0KkKdjOM/ouqRyZTCez17Flmp aDbT8HNJmVD2clUdaLO/HdeSE7Y2Mo2VM72cQiQsw0gblRLyzl72kMleD4iIyNI3xeRhHZfx uOIFcFnnEuHOCTQLYYRdpXrBL+UhzUlUkDLVkUpf1XApXMC5i2DWlv3rjkH0F0J2SDk3So1+ zW04dbYYSdoXaVvw6w/gQ6Aek0axazvtxyvTKQtjZY6OCo7d/z/gF9QQlY2MbLEpA9lKQDzf ICp9IJwBelp880U63C3kkUWIzZGb9RKp9xo0sCDGLdK+aSlz1N61NEjRE/ijZejDmC8/93oS 3Lu/BgmGkH0hIdxsJn0LwH771yL/jSG/ont5AXQ5by0Ujvn4Ebz0VsY+EzlddAl3MPdOVpjZ LFWuoaEzNHSxG/SwkTya4uKRHCCK1z3rPJtmGhNRLLt29tyFI1T7eFP9gNXy7yQKhod9mbpy xVZAuyR3z+FDWS8oWYSszjYG7v4V4sqQYUo398/LuDAaLqt77tsZvuTQE7gKKOcYAbR8YBzO jXY/iK0wbQKFrXb9jXKw+NEsgI7ptxiK0YMI6Odo2oPs+xGhcoRt1lqBztgoATU1UGPkh9nR Fz/VxpmMTEDqmJNQn2ic6IespjVIyhmyvHIcsUwOf6Y1L699/cB9eT6Ghn7F9q97Bv4fbDYa UTAnvkvKYVR8gd3dDe9UOYcDDjOTB1lzfbXTxuPDis1dPhqL01wYPSHIHPFj4lMMgoeG14L/ Vh6AQzIaUkWw83QMt/CztrPIqIEQ7Faen1xlgmn+7+zk6qoeUvfTyTdA8KBNfYr0jZcK/FLs tzXxiaMYQfV1x8cWQS6LfmCW3WKJPJ6bNIg8hGr+vEiRvNwe5r0fLlWG0iqo3xaJtsDmuKne 6TyqpTTGKpNekKCICI0dOmbCVm6GclScWq1w1hdEBifIFVLM/WHrXiwuN9caLDMGMxPKvC3w xVoAOWJl2CfIlTG7o8kFONrNixhIZbj+t8FtLvDDHGqLzpNNesiVjuY9VomEn/agNi4ar06C Lqc66eqDk7M3NJhtckYp9yRaZm2w/ybRhDAljpp1MLXOL5MhxfFbVtEiEH+MEEgRus8TEYtc 9rcau3yED8YsVOQWDSGiW6XRVClhUmQopiuoPFvLi9ZCJBRRBkqafCFT+aA/xKmNPD2igTot JuTgNpdQcziPTRB9BFvlwzRX04CKxYTC+ljyyRAXqr4O9yHPI9tiJmLVK3Ghmql6OVBpbaMe wDrfpxkwAFHN+rAJQ83RxxV/lFhm81j2pCS+t6rhDkq5K+kUeD4zxdx3ajPiJo8R3Pi7J30B kpBzgrTdCpeJdLpdL7Xi+EPyjuyJK+XSSIG47YWtqawL/FwSRDoHO0NZtR3Kh62mkvKOHO7G XJLYUiLh8ycD0hdsyY6X/tNSizNxxb7w9zcY6vUvJTq/mW2I9MCuPZ1A33YV0OsH8tTzNUGz nSsUwWH0fiWCTjleArIiwU9FiQ/dgFOCQhtv5pKb8nmjw2XbRXYl6PWfSuz7WlHnHxeNj/NN bynI+EM3Czwr7BzgffvDWzYaLzuq65Y7fpKG2F4v4NkPDhOMZyS19yiM5Dlsq1dRcnealnCE VQ9ZaxHM8xp8Jp8RU5taYY+x69gxxiy2Hx1hS19V2gxJOQV7VBjxx0nctS6s7TYwBxR67Hye kSElEanIsoLSmcCMc8creFUc4HXSKPX/9DmiLM8HxDAEVxCYrRhsMEr23fmXghu8GcSVyACg etUTquSbH4mpYMweRK+qCdnMJ2rC8IaNaggrB6J8PHBoNRPp4XWqGB7NALg6YU+8J7hEL+s1 EPkJLSA+Ffech5T0Vrwg8YUuIPYCM/Ner+tJWASCL00XByeDIzjJVEY+a11xbgKINLiPCcRs 3U90NddSgUpghqb6+LkX5TcNL30HlVlq9od7jQLTnofnhP/Je9HeZvkzvYE2Pq3MZalu6H6G g0Fu2z9AV2cgowP2eGxKGldD5utJsnX3AuajBq3yGM/zCwscGfSzs2ieKOiOcE+9xRIWTDaS 1yRWcPh4YhYrL8u/mXTQtaspw2q/O9SjIixq5+bXmzMzipHuCDbqaww7PV+jUb07gEGogJzW MyYd+YBVl+bxbwLLHEpidfevXcqGHCTS/MwtuGcDoftYvoQrba3w37bW/Yj+3Nl5DojwZF/4 DG3y1PqY0RYWCpRUseNtFbXwsITxr9oNgpwS8EqiVflLtU9kFVBIn+xMjYL7/77K9A2ix8B3 YGgkwACWJDTBKN77IZXDGDC6sHf9c8GVsGExFhXjfAW3l5TRYl0NmDWgt3UUEk1H9uIM2myF /aoJHpJM3cQhPhO+flgwaXcEsYQ4EBeLKazBs4rRbZ1BsdgkgaQ7ic/yGaJ48bEKDUIsT4wG rE1s4UMm9Mra9jmPEMPwPZnFMGl91/Xxy1qvz2WM4zRuxeZJkO9yqVMz2dzTl0UnGArTyld/ V2lhAeqWFiJiqmiQQ/FmdJuDvWO+Mv8b+GpQY7ZZtKwt6/VTCSLb99BaPf5HEbFMP6v1SBD1 S8dDbWbdy0jzFB2jMwRx7XcPsExtQBgBUr7Dl24uNciDpoZuzoHSS4Sc6oiPOnzboax50JZF lKH7UDyHAAotxn0dHFKxYmMczeSreHDMccPHRX77GDpAukcGA4o4Ue7xMgizdmZZ62y2uvkp 4ba7gzpIj+kL44umIihTuCNMuhKnDbrSTJvtBv1usT6zXrkxnntiZFNGM7UjjPRtGpbjYMVJ YEdBAVab2J7wm5JVbvpziG8aa5DRCuKeIbMoGIEGtVkiS1VqoEZ3bMNnrmiPHPrs082GObpC WIQ71cTpNLZNi3yPoWO8NwYwc64WANWi2UfOmdCwmtjqzKlqBoHau1cSNFo+ZNN/+aNll8Em JsRBN4K3vCYMX7HAYX0BlkdTPf2hk5e7h4ZZsYSiWgzjD/hplOAb5qswoKAF35huV+jKDF23 3ywlRDbs3NC+oLWQ0QpptUGntj/IHxmQY1gFxD+akNw8/RquaZoBB5uCdq9mcy+kjKT8tjfp p7tJAOaXYrumFhfhucBO3bGerR3lywDBU72KJoeCENiD+Y3yfjkUHXgPFdZEgfh4H9pKad0C dTV2o2twCPkDCaFUwrjbnVvZ3ik50gY/Y5FBbmnZzK8AipN+iV9dAiPxgl8Essy/Tgkussak 5ONV5Ir+TGUVcWlCKMECY23yBDDtqx+Ocjd6jyinVBZcLsPe3SyA2KNa65ysQuEjKCe0XJ0h P/H0ciEjR4Xoupj0dd3Xx5rjCaHuSw1Dm3X6swcQVYtmUtt+5DnEw0P9EEfT9/S08SCGoqik DX8MaQuw5gQh4Z/boABjwMUCNKrvGIHwAo24hmLhw0gRZe//tZ2lYI37i4Hx8/hxEoKxC4Ir 3HTNTvSBGDSErUfiHYgJ6+k13mOe++Zp4NFqnj1oQP3pA4cClYMJ8/PeUvbEmnZa+V4wqnTC fEr53SlTxoA/uKAM15c9hvKF1LUL/r5wHTv4utF5IIpCoRghrXF+FukwX55TNIig8kgi8yPS CC3XeczfmqGV2zEe5hxaAJY3bBd5GxVJXjl3FaSCjCq+uXyDM3s2ITXkJCJ0QB3ZZHxzYSgz lNQ5WB6XonAPxHm7WUuEuF0ZFqwLqPrYBSJNyWoFACLfhnthwU0K8q9VeZaeV4FEWTLCtWjk jPTZOBYtzXmmxxfYd1yOG0cFydkgEdYNUDG65kaDRpYy1JOoxWXg8uOoWxJGGay1rRpEmP/L v1XdmyzI1AM1Ge0b48ith094bIKCyeaPblWaZlj9DoJmc16qq1CWj6wXX1sUiE/E0Hqfb6uZ cGdyi8kueooGZDPYuHxz3eMOa0UIoVWufOZQcfEfljotOZi0LrWMKiTpo/4ZHYhUp1pdOYQn kPAHWIwSpnw96STjcNVvFcdstN2Mcgp98xXFzgsUbIvWJiCoDjJ5p6nLw6wIuM4s+xLKo5xH 8jF0ZblfjzE84y112/xsKm4vuVUxaDLHl/OacJcgmIWzDlscEu15r/dCn05JY2jIdcYuplQX mrLt9PhuOZCTDolif+jPR1suyTZemlxXanJ6ufaEc9S9Ro5DeTlMB3IT9CuGzuom5F2XoSDR 4sX5mJ+pSiPKUFoabDJp20xeWLZbN70q3B8Of7Q7zGZIaHDeYpUJlgNIJ0gB3AiOOSDdOn8m T+22rCn8puUjRhMYZAvslY41+4Rm0w73u0oa7KlXDnBqa/LFX/2Txmlkw7FEUO3/ThkoWfYF QsStHOvmejUKFVyN9zKW4gPDZPIXdcxa1AHJKg0vTeJF2L+tfQc31kUOzB+UESWy+ufL6BhT KMfkrKjFcNmELlCnv4kC2o94zYhxTcBSkXWrWPNmDWVuZHN0cmVhbQ1lbmRvYmoNNDEgMCBv YmoNPDwgDS9UeXBlIC9QYWdlIA0vUGFyZW50IDIxMyAwIFIgDS9SZXNvdXJjZXMgNDIgMCBS IA0vQ29udGVudHMgNDMgMCBSIA0vVGh1bWIgMTc0IDAgUiANL01lZGlhQm94IFsgMCAwIDYx MiA3OTIgXSANL0Nyb3BCb3ggWyAwIDAgNjEyIDc5MiBdIA0vUm90YXRlIDAgDT4+IA1lbmRv YmoNNDIgMCBvYmoNPDwgDS9Qcm9jU2V0IFsgL1BERiAvVGV4dCAvSW1hZ2VCIF0gDS9Gb250 IDw8IC9GMTYgMTE3IDAgUiAvVFQxMSAyMjggMCBSIC9UVDE0IDExNSAwIFIgL1RUMTUgMTE4 IDAgUiA+PiANL1hPYmplY3QgPDwgL0ltNCA0NCAwIFIgPj4gDS9FeHRHU3RhdGUgPDwgL0dT MiAyMzkgMCBSID4+IA0vQ29sb3JTcGFjZSA8PCAvQ3M4IDIyMiAwIFIgPj4gDT4+IA1lbmRv YmoNNDMgMCBvYmoNPDwgL0xlbmd0aCAxNDc1IC9GaWx0ZXIgL0ZsYXRlRGVjb2RlID4+IA1z dHJlYW0NCqmuRpBRQMfx8YzQoMttdBKoRsx1prBd/HyuAo04o0nu2Uh4/qcAHKDje6tUhJHp 0IJolhx5Jwj+3Fi2KabqA9sC/FjHRWyAxBcmTVmXXX5Buo5i01TTRRAZr/nQGB0h281k4hJx qLf5iHN8HSj5ldLwcSBWyG2WHd9n6QW0VUyjCBKkdoGVmiWnWtYl7KHzw2Ini58+BAZOkQS9 MMwTt18W4/ufbz7coAoA+kyNAN8ocqUTbUoitJK+dYk/xQANQfU5zw/FZK9QkexPQPjkuuJI 1ltz6c88LXiA75PZ3syiOPvj8dGenLxAWQ7dEdpzuHctTsDgx0B0oq6SzzXjrgsoxxm0D5QB RAzxkn7Nls+7MisKt9pRZn55Gk2FSf1SqIccDLA2RQDX9uCUJJV/1+uGSQ5V1/rWU3lZVbIw kgGY4kQce6ZIY7GE1ib3uLX0ExdgZYUx543Bm0gj8dJsf/fdKgRj5qdxTMoGu7w1ZuxXTtjj 5fNtNtw4/Yvs6Sv7MHK+o5bmRXCxNPfVfTjBsbCYcEwGgfqqeQstvwDTGnhc1mYI9VOllLMz fPPvt5FQySxeAfEtIDcUIKe4Thzj/T6QbxV2Rwb7YZo1K+uhREr+adXZkDDLOyEOINk7Ds/k Km8Do52WADuiheV9pyNI+Kza+cSFIz41sdOljRGrK3bcD5jyISavXaEcN7/Aamv8mEs+Lai5 iE8bqTc03040PLJy2sQIatfxBs4qV+ievNkUg5nutrRUhjYiw670AckGkPjyWbN0NEHGM2Nw 7LECQoX0CJEip67faue1iGEGlEDwY/ESe9f6DI/a1b9N3GgKqCFoD/+p05+RD4lUyFxjgwF5 s8CtqqtaL1rlFbqSbR20vBSQPpRhfxt0Ve5i+MECi+r7t4RC+b8PHpWO5XdSObeCBoZmpC3e 1XkixPbk4FOjFW0Rwu+SQnVHmd7rWPHr9S1+HX5Dy6AKTLVRVODMet6T7E8/nWXCd3yC/9rB lhyGneS9w72lQY0sgSZMRP/qEi+rpeM9aHfT6fXiEg+WdzAV1FbPGVl75XXMCXpIBThSShMk FKdYG10wlO46Zi1Xx53FeUdzaQ3izNXgoSZsm2U8gvpAleK0B4pAUjVjSZJ50NzSZQzLA898 ZiiQJoLFNnWl2/3bijhMG/581tcEI66ZvZhI6NfcrE9F1mR5d4mKOnNNXbbTBxXlIgZbG759 39hQTvWn9GmweXVJTjHgqSGuwBuB5LDXBx4uwDm7SGrR/MJ+GQJkk7z2ZOaKni47MxXt28rD FyjHCSrE86Djp1gq8guA+ChixonJDtEmVFP+ypwYhCZHFtEe0064OdCuN3vGq2mylwtiL05T fzaNXvdyYpsK7l+gde9DQOyw+I7VXPvfgekY1kC+C4iIemmzBBABBvfagG+g9Mw2atdzRlhL R8UOkObWlRYMS8tlZNhHfdmdQcCLN5jS9IfAANo54pNSJpnfEbA9IA9rUmzalRXdMnTAdQ3U vN2PQ77H0xBSDKHG6ffx808htoY5Mtqhiq+maR+Y7OzM4h98WN9ec6lPhvyABDVI4hwf1LF+ zLZUZhDOV+Ii+6p62kKJ1C8fehSLRbwgXVbxP8MqCbFO7/vJJnEIIT7Of7BSbUDGhQsywq41 DrtXQwYEqmtFzQ+qEt6vklGWGNXuzkbF0uGEGDuabpZLDRbIKev2bhwHSMDnScNlh6sI9G6T a4JDk86ju/wTluN+FE+HhfhGMhpmnf0ckoH5K8eJC4JThHNKFEw+Jw6xINoLwhI8JmPMdL6y lhS+xk40TbltlnxaqtgxnXaK2YvfWra/LGa1hQQWBwoDHCOmrgLpC8H9sSavhf0VmG07ZQ5r ga4Fde9l5WwizvlJJfsYuYbf/Z22Y96gp3MmulA1Mx1FP6MNjtw+yKCnY4F85fKPHPfiMuE1 bA7RdZ8qiK2xiAWPtUrPGc7qewv7QE5/DWVuZHN0cmVhbQ1lbmRvYmoNNDQgMCBvYmoNPDwg L1R5cGUgL1hPYmplY3QgL1N1YnR5cGUgL0ltYWdlIC9XaWR0aCA4NDYgL0hlaWdodCAyNjEg L0JpdHNQZXJDb21wb25lbnQgMSANL0ltYWdlTWFzayB0cnVlIC9MZW5ndGggMTEzMiAvRmls dGVyIC9DQ0lUVEZheERlY29kZSAvRGVjb2RlUGFybXMgPDwgL0sgLTEgL0NvbHVtbnMgODQ2 ID4+ID4+IA1zdHJlYW0NCgmOKZm/FTEYxC5S8j5/MvDMnB3YZXRG+HmVHE/TKzOGUFl75+2f 5/e8GhfEHXucaYFqKILSn6dA/76SzHmhmpkEtoB2YEHQcSPviBn1SsDEPgJEhNsH2SOT2wFq mtLKTSaN5TvdvYD8UjRteOlvmJZorUUkrQgbeiVNxugA27lHZanCsokXsehROYZJjW99YoGm pb5W0u6r77ZmxsLrXOrO+sStB0srMG8SrDT30jsYHNKytecnf7OP3aR90Y7KROwMGcXenv3j XLNlDVqiS+rz8eH6zlji7P51/qPnP6/oWN1lk5bGFT8ZsDuVtt/wnwjluEFde2Qm99xSfNgN wGmcSG7n3WXLDvRd1iKO9Fr+Wwh8GGFbxWTcjNJNNdhJ0UOfxnNwiUQRBGEh/G3Rzr2lzijn 5C+siehVT0KMPw693fqqmhwaSxIHFJ2LngzPdn2K7jrTlpGV0jBAU6Nuap3Yb0dkZBsiuitR lY/1KEaN/muSEwbHu/m46Dlm22dmBTlcwxp5HAig6uMEezy7bDiwTNJcn+OY+AQLSKVt+a4i nkODYJ9s5ekdS/ylwL/olF0HWvIW2i4xDcLLZbaaYBS54pnmjgHtgImnA9cyIghpIP72t1vd cFQxVdmu5S+e0hI2RxiJiCtok6J2p+vk/qZ6N+uRtEf8YSalfQk2Ovc5gLPSzk/+TlXnsETI l3Afz61M8r3A+dHx9bD68uo9lrmAnSBRHVZb++WvimPJBc1g81+30FyXKwHYwup1UzP0uVQz 6xArpsHI7eecFX+xA1W2T53Jal5ya7wFADdbV8o7T0344GjeZ23TiKAkSqxb3mCGP9U1xHHO 5mOuLik4ADlh5qMC4yeUjViwDcOIu+UtJeeMZnevqZ50QFc0czxFSq9w4M5zvsK0TodlYf6L eM4DLD92SumGx93XnU7R1U9EBcakhKI1VMoxkT63+g2+w9GWX3sXQUCkqiSmwxOpCeKSxJ17 lTv864kWe2Hrn4KhOWi4w7sgJfjf/JvjRz8vQzSUHU6TtpJjYiSDxV19PgRMYm23KQ51NoIK 8az4quOyRzGf4yvHmk7eV3Fue2hcRHcj6+lD5NtaDOCzxYDxrY4wWS30K+5PxDso+a8CiPXK 61v0oRSKd/2TZdEhuDXs6Ofsr48OMoPwq1BVx8I7CdbA3uFuyLWYCj9XZv9Oy+rKFQH/l9G6 vTehV4bhK7BmSBcKwwwwsr6I/Q2drC69MabVbXe/vab1J2CnrtKhWBBt4AbYcxclDZbXxIyz YR9vY/Zud56dsh1KOOmJPQ3oIIl7eVd9LqUUtjOiAUl4LC8iuDkGHJq+Mi1bmL4avjyGw7i8 cSugq2U9/om4sOre7q7Ox6+6qktRUCLVivcWFKZ5SRZRIR22Ks29WpP3adAVlICC5oZrDDf/ p7bTqE10JnKRk9BgblSTYYrccux5lAlXewpqGVAvwU4DL0TURkptUy8XBMeM+0sV6r3EeZ0G s9BYAzCsJHqv9TRq8O8NZW5kc3RyZWFtDWVuZG9iag00NSAwIG9iag08PCANL1R5cGUgL1Bh Z2UgDS9QYXJlbnQgMjEzIDAgUiANL1Jlc291cmNlcyA0NiAwIFIgDS9Db250ZW50cyA0NyAw IFIgDS9UaHVtYiAxNzYgMCBSIA0vTWVkaWFCb3ggWyAwIDAgNjEyIDc5MiBdIA0vQ3JvcEJv eCBbIDAgMCA2MTIgNzkyIF0gDS9Sb3RhdGUgMCANPj4gDWVuZG9iag00NiAwIG9iag08PCAN L1Byb2NTZXQgWyAvUERGIC9UZXh0IF0gDS9Gb250IDw8IC9GMTQgMTE2IDAgUiAvRjE2IDEx NyAwIFIgL1RUMTEgMjI4IDAgUiAvVFQxMyAxMTQgMCBSIC9UVDE1IDExOCAwIFIgPj4gDS9F eHRHU3RhdGUgPDwgL0dTMiAyMzkgMCBSID4+IA0vQ29sb3JTcGFjZSA8PCAvQ3M4IDIyMiAw IFIgPj4gDT4+IA1lbmRvYmoNNDcgMCBvYmoNPDwgL0xlbmd0aCAyMzIzIC9GaWx0ZXIgL0Zs YXRlRGVjb2RlID4+IA1zdHJlYW0NCiO3b9S8tofpDQjXmFtTcDs6GjMISSa8lsIvNV3sFTrH AsbSaXFb9fBtk6cRd7UUNWzJHoZEX1KHKjFKJTrCkCZcUq0MP9kpmovRkfSR2+hFW8YemEJm 4Hp6FDZ8l8ePdmviwj31N91hZFux2DwWFeRpSmpO4NT9B/zX//roT7DDbVDGta+o6NDlrrER sqIZSqaT6N6YG7wh3EdXCgqzms84YHK+6ySqEJYust+ko2q/fJCZIZ6LdcZm+oWZNpr7TeSe AihYl60eXCTYPD5wFRluMXb+tydu6zlsAJnMbaieiBrgHuvD7J4kAhs7WccA9VnL7qzM46eJ GbkKqLAeckg5mASQ65M9iFFtG2A9WU+fOryr1yTX8DTs2MDh2PeqmnEJ+S8Yh9BNKrCC1t6C M+2LSOnMBjPQo+EBdCpQ7c7YuHMXHxquy+rUSFCHr85PL6jxWwI8c4YVWYsx7Tq6pDO1hNCx ygE3RLN7ZXFsympDU1GzPbeawv4CNie4E7D8Q5fjKUjN5ky74fXbn+3+mfDpCjOVXgAjs08v 17tyX1YAqjf8rUWFYAUIn0WWZ9CVhLw6hu2TRlC3WIPMHC2wYnfNAMfJMCfyB380GJAZXtLI ikqn9KwKhO3U/Irou9UGw/erAvar1k7dbJLmJPdE/h7KAQEto0l4dwu1fQ8KndLBkmufk/Ph Xm4843ywDNddigNRFouK2qNccaPCCIVhLqZfDO/+W1u7GxuAFY9czlqb6h3GYnbRiYd542Va 6VE7cWYM2a7/FwsUcYk9Js+KQpdFAW1GMxj18vp3rHbDPm8blq8ehTNzo7cP97z/5bEbnUW+ WaGLqCfyB0InSsITtbvAiNzzn7YHP8CxL0h4oZvtpGTFqEjVPSJ+yVN1taTTiMACVJHoe2tF OMJ2RlomgSHuHPUWkzsbqqK+EVYl2IoaF8r0Jbweh9CO4LYfLgr2Uke371GaLeyh3UMVZfoK MRhUGKP7hvIc5OVPEE02yHMSDgOFbfCUKPs01/H7N1bEeMweMY+wZbSGoJUBBiGkFR27M8GO 8hKy+oaDRP7mdiM102jdQD/LzpXDzocbt3d8svmJbQuMJ7HrVQrhcde346BReloquyjtBWLz YIYIQuKhH+6QVxYivuYPTiNghL/aJwT7X0ASUB1PpK650xefNphBFV2ly7bD0G6Os8bn7cWG Lm0mUMhxlEPI/gnzDaMCt3kVRD1hujPLSOQ5Ls4N00wi1XFQ7DWuWxJMzKifJZR4mRzlkMFO Yj04CMboVyWaiEXSgwI5XW8CpgLp/H0cduraC4o3/l0/mSkxD95jLwfy1wLIUHgsAdpF177u GwpXsrN7+7wl95IELzst80+ls2rvnQ7QTuhJdYzVOlx2dxnUGQJ3oq9mvCqvYVWPaItwxHz5 81wN/4zQmKEdE1MQfMGqaNrSnmX3usXCbRJhTeW/FqhJZeE9eUWEd5U5WOnpsqsOlsVboZr2 cYRrvjBc08UHRAGP26T+mEKiipo/KxPKza+HmtjN0NKhei3AG51/47lP9JP71QRdrhSBZzx0 Kw3WDxhku+rMqmnN6SQXAMAcVY7TIKxqkm9bupBThZfLXJJ0laKSj1HiTQexDxc8PF+u/lY9 /zdYxNnUVMk0A+x6rV6qE5rNkh9Ni0H2j0YVqaiEc8kHhkIoqy/hz8jVQgBWSOdqZi9PAwZA jWcMVJ/fEiSXtjMJK0PKaigOQndZgLsY2/4RizyRmOWJOA31JtJCC3AksR5vADOWiRo1Tn6z 5X+zAH8rYPCW9POns2oH0B1KQBEU8Dw6DDlHqJw7oOxO75vUSzMZIgZAkj8lLO4mgUY/4AVj IltDEKwkC2jGUGvjUccHkHW6S4UXEauSTmmdgoay277jwGdCJ+4zfFxU/2CACsN2klKUWHwl xbLJfLrsLdqxqY6wdEahD/UzrWIjdxsTu5oH5a361C9UpIJyhinNSZ3Svaia02RGH8R+Pbg+ 99imdtrpMSqKsUVKjQKgtpgrrj82k76sQyrXEtQF55Oje41q2QTibyjFYUAxYRSij6WjpJZ5 DJ7Meeqbi5J3wzi0M0kpiVwDrZtuw0AHM+2KDkn+VfrXMH+U6mHebbqxVSaPr4obr+bZYWOl Qob3cevpXqFmBxP4NGoozWuBFrjsnWdka87KHXYMDVWUy2KlgYLGhkXdFIiSZhPtAlCsuwSP GmCBCCNikNQ3fR1kFKJlPEx8YM72/Ov0nSrPlgeop5zewJ2CXaZQ5PYbalUxTGdbnURHbtNg uxc/mnT20gFUamsxuDGSzbz71mRVQ99Chy3wpFRhPf6f0bzx1KZDYI3Wfk/MVoP5UT3NwzQT F+r472ZNY2+weS9CdK1vr7qCMHcaEj7U9WtsWsYS8Jy1JZDdBJHiBg2RufLbDPKMU0z5WFH3 Uj75FDZBBCbV5ZttAs1V3bWSD8uBYRr5rdYVh6nGiQvqCJo42ZKCs6mutwCZBEBJHPQO/lFB QUHLTn14DqBIzG5yilwGmT2Fp/mxxuIOKlQw8utYlxGps28rehEiUTmfLz0GLLhI54rZG39t yvuIUQUTlq3d0V+a3WbNSTTmJr94nYqzzk7reLcymK9itCHY0ClKkZ4f7vvnIMY6MM5YQBze L6nB6mjnoZx6YZSOuLy8KoN2kmzRVUy4o2zP8o06D487Yo1OX4Kq+f28rcW8khfWQoU+TVbh MnGx5aI8ucNuA+1l0OpegQ6u8298vtW99xhQfNv8J0axEJXLgqMSsBf1D3ikJwpbLF5wBzZS 4ewIbHVonUXR5GtOZAP41z2PS8PMUysFKSQpzXz/bnPJ0c5GbpkBcYT8FD8CPR2DixP/JsV0 hFwbwLRPVr12iI+nioiMESnJ+2hbu3QpSwSCQ83/lMtMvDYEqAtIpLtrKlZA/1DW78aDuiHf vwxd5aRtAq5D9UVPaJ6DPtZURMu1GMvZxWXZ0YCBTnh5UUXaFFm89092AH9avOgtBWJOdHsf pA7MWIr8MNOIhtEUlm8Bqn04LW6kXQuT6r/DP75QHp5ijGHSHMzp/9enDqDAkd4OzVHcWGqJ izw2NMiEW0AxjqPtAuhSkTR3B/QQ63ENZW5kc3RyZWFtDWVuZG9iag00OCAwIG9iag08PCAN L1R5cGUgL1BhZ2UgDS9QYXJlbnQgMjEzIDAgUiANL1Jlc291cmNlcyA0OSAwIFIgDS9Db250 ZW50cyA1MCAwIFIgDS9UaHVtYiAxNzggMCBSIA0vTWVkaWFCb3ggWyAwIDAgNjEyIDc5MiBd IA0vQ3JvcEJveCBbIDAgMCA2MTIgNzkyIF0gDS9Sb3RhdGUgMCANPj4gDWVuZG9iag00OSAw IG9iag08PCANL1Byb2NTZXQgWyAvUERGIC9UZXh0IF0gDS9Gb250IDw8IC9GMTYgMTE3IDAg UiAvVFQxMSAyMjggMCBSIC9UVDEzIDExNCAwIFIgL1RUMTUgMTE4IDAgUiA+PiANL0V4dEdT dGF0ZSA8PCAvR1MyIDIzOSAwIFIgPj4gDS9Db2xvclNwYWNlIDw8IC9DczggMjIyIDAgUiA+ PiANPj4gDWVuZG9iag01MCAwIG9iag08PCAvTGVuZ3RoIDE3MjEgL0ZpbHRlciAvRmxhdGVE ZWNvZGUgPj4gDXN0cmVhbQ0K7y4re//pB9nSIzqYtC4qp4M7Q0ulqO1fzoIvJFYpd7Wljgjh PZXDkUmrrqLOABBTnpWnslvMkN9exG1/3/XI/OumtrN7kWQdmsyxP5cHAxrM2Ag70tcY+3Pd ZBv/NcJ+pyJrL18mVH+dJbPxzx8S3/vx9N2KTvqlsGZCetFam2NTx1Hv9nDWZ2UVkA4agGnf grmFLYDJXWxa57U3ULo8GxyjEHf4Ocg+u4KE80MOqUACaZXYaoJQsDWWj5hU5+sPD+6vKmaE O9+O7v8pMkHmJNBdfwkRUvXy5bkZJQvLh6e8P1VTD2IQM9plwtFOccGKbfhpJ7+32iAi3A5i MfPBOY/Dkaey8G+Hbx78gyBmhy/rjGJTMeekoNue2nQ1kfEYJ0zktjLP1w3zeL9FZwm6D3u3 AH57HPQXnDa+VMLss0oAU7PgTISbofwzqAZOHZQfd6Xx+bwO7iWhUoj4ork1jDXm8BqkYtsC p7E0YwtvgPgSejNehpgZfAKptgyBPNqJrkMRCgcA6Q8lVJh3kdPz80rx6FzNx08/ncxCBdYO 4N74yzxQ3cWJLVScAMLyjZIZE+CBgyF408UzPORbuMD4Cui0LxF6zenyWEXOqxRkD42i9uNX jjPCmWBMfosIgdTPNrmJqcORuslVqhhTseWgIeKSoPXKCGZPwG53NoyClpI55r+OBZbEHahw khPB3W7NMmij66BmVnklfvFuCHSqAmnwyPTAwe/CSs8RXVTqhBYUvT8FcJcCVTu7/UpsEIfR /KGM1VFZF2lec5THNdXSzwD4GA/7w6Iblpy1cOZ7CSFlt1mSvquYwPmwPECzRiPIBM7PSumU 1UXcUiM59gwKrhyAzS1A5VMVwNoaUiVDzHftxSrjBvGKTuFKbYnfj5VLYFs4zttJZnGEb9i9 19y3ImveSvIs08HtFzB/uyJ+WH8EXBAhjtXVLgP+DCgJdFRluV/SmZVnycoBHEF7NRtuVvfM oSZ/ik85o6hNe/9ofB96t22+x0Hqm8HQkS6XhgERBs7C0QrVQL7iwd2vBpibxdKLQpaeXoJG OzTQFn/P4Tx4b7PojNsY80rQjz9YW+zS/+IszK1QVH2k4E9yJ0zHeYr61zoR+LXeGq5BfXY6 MhUPVpNenYgEDasRVs5QwSBbhOx/d/NhHne6T0aE3SFuKeCyB7Ra+RxdoTbwuO59XiN2YEL4 65YNyLTIOYO7rFnEddhJFirt+QHTHz9t4PuuQ1MBNVcQKgVFSfVvXpOjEEYMvKbCo2D76CdJ r8LD9hdHdz2mslAc3+VHUKb1wo80x/6iXF0laeq4/eSyY05xuw+07Px48vSkY+gjyCRAPOH3 pe4tw5+8iykGZ6p4Az05KWbF3A98edMXkyDlKpdU/KUQQryvVuK4l178iOwJIr7dWXkT/Dbb eAXvvbyBwecKkWqhD/07Qs0WMDB0DrswDB5mA7yJBhtE9QB/0h62f0hWnq/hs41LW7Pc0m6d CWSeI8vvnmt5SJ+zBOXDhqBsyw/62gQ1n+CthwpuT5Rs8siN+C0wcHESuJ/DxYHypV1XPQXM aIZ0QFOQzuEXmRe0rgnAEaSvw5xXQftHMaAASM1gZIDhm/0XY6x8LXTwo0A7tufcVdGcEW1V pWDyVREno4XcEg2RwYN7ZiuxR6xTqtv6C0UEuAkxDLhM5wwUskWx46Uvwi9m4VfGB8sDm9+Z fqw5LXtUW8C6Bzy/dQWPWo8P85tOXN/4rze1acTe30JMaPXEkYEvvcyPNIGsrQGgcmfR9AkF R7HolBlgFSRGgHAes6fTapDIUPfy6X24Ufd4EX/AN/fWtOxsUtNC/UG+yt2vZYJtZq17/K/5 549RDDm/iotsW8AZn1iutvbmOWJqZyREYX0St0ABomSBIMSwCmAHVxACgKWnf0JUFST94RLM M2rd+AJIc2jGeaZKc3FViVWtHDbNd+lqGxJawYzl2SkUIB0ndA0K2iX4apgq3sy5C/R2ge/2 4K9CbxkHTlD64YqYcvEfNCuOt7n4gjqDRR0kcpLN0O0n/3ZkOYMV5GjOj4YqDyK576e22QmX HamOp9czvPCKFFDcPC+FmVLR3s40t/8ihU0T9VonpwL7Fgp1+D643k4M6LXYT/zk/wpxfmXn 1/R1GZcTPqZ2EqG9IsRL5A1wYokQaj1Aal2/ir4HTwCr7JxWEBc7qGa8MIMIWehV6It22m0f DZ/BKFCHtGVbewjnNhw2jvVQN+9rIrRi3qExAez7zynhhHtjZqWOURtcYWb89xGudlMKv1Vs p8YLkQIVgASpcr4NZW5kc3RyZWFtDWVuZG9iag01MSAwIG9iag08PCANL1R5cGUgL1BhZ2Ug DS9QYXJlbnQgMjEzIDAgUiANL1Jlc291cmNlcyA1MiAwIFIgDS9Db250ZW50cyA1MyAwIFIg DS9UaHVtYiAxODAgMCBSIA0vTWVkaWFCb3ggWyAwIDAgNjEyIDc5MiBdIA0vQ3JvcEJveCBb IDAgMCA2MTIgNzkyIF0gDS9Sb3RhdGUgMCANPj4gDWVuZG9iag01MiAwIG9iag08PCANL1By b2NTZXQgWyAvUERGIC9UZXh0IC9JbWFnZUIgXSANL0ZvbnQgPDwgL0YxNiAxMTcgMCBSIC9U VDExIDIyOCAwIFIgL1RUMTMgMTE0IDAgUiA+PiANL1hPYmplY3QgPDwgL0ltNSA1NCAwIFIg Pj4gDS9FeHRHU3RhdGUgPDwgL0dTMiAyMzkgMCBSID4+IA0vQ29sb3JTcGFjZSA8PCAvQ3M4 IDIyMiAwIFIgPj4gDT4+IA1lbmRvYmoNNTMgMCBvYmoNPDwgL0xlbmd0aCAxODcwIC9GaWx0 ZXIgL0ZsYXRlRGVjb2RlID4+IA1zdHJlYW0NChRTdvu864JA32Uuffa4JusnIzHUTsuDYDHZ je7wAvZIAZFjI5Y51790V+h5Nrb91rlqsF7dNsEkQUWJ29XJx8Ds9PIC/kAThyGgmYRIfW+s G0OlMriqxG0t9DWELdX/dOzCaHcksneqcrGuhH9M52Dj6tb9oFpQHs590QXrB8AAyu6KyIhi 5p55vJ1blMd+bdn7yvOdIRbae0FOaRryVTkj3Y36k0ZZZZEIt4Qv3A/KK4s9c5syJzT8C916 4njh8qO+kFDqoPBqPblF52l/Y1les8HnvxBT420+BvVOugGfY+RB0OnT5X18uTVbjNxwqaFz 57hD9QiVeqs7mm+OzKkdMFV+fdg8y3ge6d5D909hVrIcPTLJ8VahCXd/i7jMu/YPOeHMpJjX co5HRfQlnQiGkhlmiQ2SqSdlyig1NxBP8MvhKutBMu/VE4BQKS+EWNKk0WTb5YvjhDgz0Di9 QxuSk2/xagJt13XJrxV6FupnCaQKItxXFHIeaODzZQF7r5q0yYF7g+aYDgW0HyhdySF0rgEJ zg9bmc9N0pcFl8KEDUpUqk+EzxsuuQLmm+mWxZKTxOCsatuEOMNlyRkLYfqACXh3J4pnM6e6 ZtGGmcjYSy5pc+waHSpSY8qKMGt+5VqM6ncdoU+MnDxMLDL/oiUFuBDNN0MGfe+rerrkzrmd Xt58W9f0nFqrSNsImsCMS+7mC22IfTJFSl+zQGcD7TSUYlTIZAuLTT0OuClLe955Cf5AimNe m9Jw/6CtnqwyieP0C8Y7bFmZ5mtaIYjcxgrkXeUfnpFRcDfu3CZMHHhqiHlGZkUw9oInpK9B kgn5lQhSsVPv30/PvRHoJNMcl+w20nN3CmnqhXL4/u10s2MSAl+zh+4bn7lN7v08VoVjCyoR vf2Pw1G5cJZ+huKK5bIxv/FFTEMnB/SZSlxhtMTzGasfr7I24S8jKYiGD12DyzMayERLWafx y13ReYOEOZJZmQp/uTyrMlyrRXXm0Vt7NY7OHigFUkXrtPm5Hn0jwLHPAxGcj0TA2Gqtgc1W yrFoRtHMFJ3H+5Ex35w39ybZGiAbePmNuLKZRKdmSuUcFJydw91WLxGGs8SsmWYD02l0WVm5 /FZ9azViV9abdmhEDZku7Ux2dRkeNdIGTAw7YPKPgyvaRH+4SJRsNY30xoLX/hG9WDkcFGn0 rAz2jzYkjxhOHoU+Mt4+0BlaGtW3eS0GiZJMw6XjY+7OkfztXMKKssFuIpcCqlDTLDVK650A V+7UUlWHRmYTnvfeR7Ia7ot4tY4eGVJJJfPPUTGKgaw/6hpkCyn4YeA8vXxytXaUVNddUsM6 FKn+VePTjIcbTOAMGZ/OULOQPqjKERLsH/LIW4b+pdI+HKHhsBC7z2KOMHoD6JFjwuS8pe2L F5UP3qgtaIR9JCrvF2LTYi/bqSipKPL937aYlTJepYd3vrOjqtMv2+yQWOZfYp8EkrzZerd1 bcROA+5JT9Ckbbe7S8l23fI8kQUUJhE07z8BxiqRG0Db/jcELQkzChfbL17z6rsG3ZQQD/i6 csgg6xLH/by43jF6aTf9CWQMdkoFpdqD3ic8OBAYE+Bp4qkjJiI8LxFrVpSZsW4O4qjivOTm 8q3eI0gRHAAfTF6l7WXGCpOtkSzwRUXVV20JXjLFrgxWEO4j1KjJpsrfDfEIiNwaz09tXsib xGUuitGUTctD1yQx8fGi82zDN6ibNv51z/SJ/tTdXp4fG7lRq2i5pM3c+c65oXrvQeNSIr6e tqxa/XaDp+soalj2tUDlkTTcqgbTPp2pJuWkr+BMK8cZVD2srmjDlQaJRvgl2Z9v7vVsMp4V fw/7SqmHe+pzR5zSmDP9QPA9T2THNSGO7NCKYVnbU6WxPcPeDKJqG7mgNaKDoR5sKjxUjTSb 5SuJ93Qb+cU+ms9d+KqIRh0Q17Ys5EqMkRc2/JrxQCbWv9HV87lA88p+w+vvUmBINKIdpM5h 1VbH9VyU1R8qS0bA7TCf6V16brf1qh9idimJvYJC6s1QP4ZPW/9sAD5UESPWeG1g8KR0094I zBjduLnWImFyUko4HwCUSdNreYc70/TPxPR1U433nhtejy6pU7VAorZvS8acMIieZ+SYTgwz thRdTIzWJxqbMNViorw6vc4uoGJVrPzIVraPuKDhJ4Ch/nzITYScq99C3o8Bj+y9xl1gr4hl HyTiljqrqpkuNZlGweqcqs66KAvggZDVt4L8yejbwjWgVMSu/oJOs529wlJ89jqIP1knJuPR n8plneCwuhngBXkqo0TBdHnH5szjcoUAC7DCozk7psaBpS3bMw1QMJnZ6PE9o7CPDAenLvNA nWiQQRaP6qm10q49NOyZhylPgmMxg2xqlUvhHGY4NHOC7CowQ9BeyYDpZFlB07eZWMhfrgQL ox9J9HPmpV8csS1/Lzo7eXBJIl2tqVp6sfcv6oco2cW+/bCjXHHCBf1WoD21GcpweCed87Rs cvDu60wCbgINZW5kc3RyZWFtDWVuZG9iag01NCAwIG9iag08PCAvVHlwZSAvWE9iamVjdCAv U3VidHlwZSAvSW1hZ2UgL1dpZHRoIDEzMzkgL0hlaWdodCA1MTEgL0JpdHNQZXJDb21wb25l bnQgMSANL0ltYWdlTWFzayB0cnVlIC9MZW5ndGggMTYzOTQgL0ZpbHRlciAvQ0NJVFRGYXhE ZWNvZGUgL0RlY29kZVBhcm1zIDw8IC9LIC0xIC9Db2x1bW5zIDEzMzkgPj4gPj4gDXN0cmVh bQ0K8pu69v5d1WhA7rtt+Qm24fK040len9PMXZrRj+5j0k62xOw1/P3lhoSpdVQrjRL0CDeg dMUSzP8my26T9OJSFfPRtSws0L5v5jg/C/XMcVPJPCtDb6cLvR12jLrv43h3oNo9f55pRAZ2 lzlTcRPh0rhJsUqY5/y5IHja5VGGDUdttE30vkEJBPWL7Hqoi80t3CZZZaOQmOFi5BssIe9W au7XcnalLj92XvC/0U2aQKFKnCcb3juVIQD9BFeNfx7kvoJiZr3CE5VtysfeBPNdGCAupRn6 dfJm78hgruVQybYeyeM/x5wnWxs11eZd0MfwJF3VzM68XTkVQBs6rWxnirU81zjkvBFOe1Gs /3t/K66H3aBcF02zz3PFpLQkgPdCjxk4WHgbfrznLsPsHGbVe5dgWyxnS/qxgFTmoYmr9YHU QdL6Xl2q4XnuTSPzKr4ybzyxHeAywmj/e6eLpaiDpk9XTz8SKUFpv9KM1nI3wD8JHMY3wxzf 7iVzlh438Fhgf/Rmj1JwAxQSNjiJp+TzY5ZXSxjalXzc/oDRf2PhKc3fubdxCRs79haWjxWI EKPr/MAI9zuq+rojWBxuNA5Ap44Sjrd5R1JX1ZBVy0wdkC2IHpOJmeAuSTLd0rBwROVut5+S k3adoVjtZHKcaM/MYU1AhCdlxJ9w6NlJOL+KILdo9j/SS5sv5cSalzf4LpkBJddX28+ZTQLq A/qwQM8i4h2Qn/IRhiuqAWQzW3RTJ60ObRAxyMTlvQUos7P8kVdwLhOZh3nksmud3DNQXq/p psl+GGnM9HtQ/3SJrvyygK4mZJqly2ifQ2cmjma54xteHoVx6DwN27ut+hjp7LuA8tMNOYo3 PTvWSyKZ5PZDMblvfC/nxM2CFcbE8d57uJjK2b6eFClZKS4qmatSIT4ikiXmruFaFCHx8wdX 0usSX5bXTLC+LqIjGn1XVlB88AhkiIi4Cpl1G46DvZbNS6IAaHr2/WwS/9/GXyoCsSC9jw90 cvm/1PcV+ZISQShklOXtTCjB0ElPjnx0D1PLPIvmBkhc/2eJ4uJDgiRagy5Me87592J5EKGy jQAdk0ldyaCIzdc2+jqqRXENftQrryQcx+trOY8DJr8Ey1Ct+CgaLd8zBC3T4zAagqa9Y+Jj pHykmqQ1ICbrWLrulqiJISVA0OVpvyaKHNa7W2xyK8t2TJSHz7XlU3z0zNMdpit238mS2Ldv 3zuzDYf0i3czKAUACdSLQqn9YezzKaSpF0YjcU25WdbwPSQ+wp1EfMDzJ3QrBT9oCKwnU+8J 44i+uX9djggnueTfqhrUPtC6UTHzZSf/FtiWdn1pHTku+HLZK+OMW7ak755UtszTM3CI2ZeX MgJDKUG/dlQGFbwYtPTM0NOivJKyDqbyXrLNJycHeD4HbEbWLKvykB4DeWtMClQtwRmYomwC lrRhe+eVPb7fw684wEIJTGGWQMAJDxenoa26EqXzmrUnCguxrBzF58z5drWkvhQbWItIAAni 7QLz+mT7S7tr3bXNCyKEwm195C4HKADrolBkFvd7g9FPZcIxxhUVthxnBLVd8LFpN31qcz5h kRPaSkSIbLwi61UQZHvS0CAZgXAKnRexmgLSUCa+e2oA0CXT/aMLg1kID37JQu0KEgaZKamO eo+FJDLQI1KuSL8F2MJEkJs544KPl0f0fsv2VW4vMpRLL4BBRg4dTO+03YQt+aMfGtlzOmHl 3xwGocrI4EhiLnZ/98tj3jeiuhww6jc/qTS2Rhtj++xQ2J9es2ClTgQqFeJrfDHOmESfFoTs JY/EWAQqXjjuMM8PsHUaDYK+hOgK92xvdyAdAdqGX5WUDI5dFbSWR8FLRFq/gtL91NO6eYle aeYBfU/bj9nZJeurunL9qlMLgCudOCf0QqMVAELaMZ4+KrZAh9WCp+welrJDo/tMnWhYKg+G T48qfqN4TWjwUTAiWkIgovfsogH++W9FIY560tybVOn+04BS1DZw90emdx6+YJguzM65vwVK 8vQVa6uImZ/6J7ELHP8zE1OFhKzTtZdSqpqSgR/sXajvmaqmXCND8/zI0Yj2/FFb+fenSWZE JoR2DXVY/7E4LHRvclNDIOtUYKek2PDXnWWZhyz4M4p1ieLP8RqnwDdPmhLjGHFWBJD+iREy tewUihWW5x6IHAf4JzkOxcJebBDOmLLa4Js8AY34fPy8fsL3BvHMW1FpTz+SIptBe3l2F+/u LuQrsolD2Jp8UVKihNf1NeJ8R9MJ0dujnbIL+lVONd5btkcMc21hiA5ix0xC6LRQEE9dbfl+ 7spHQLTVPYwVTEGOB8zxykkLkUaex/VxcZ+9WMKF4LXjtTXSSdUpg6tQMLCdmErW+Hti48TN 4nYek7JF78TNbqO4HCxaBgyU3c+ALS6xAomHOVzLjWButRrF0KiBqHH030fzHzSBXS5LpW5s PR8Y5tUHgxvSd/SaNxIGlfbU2YKVGbryWF/Tu8JzjjqbUeeHEhE9KC/2vatDpDoqIiLFCmtj 9PdQwQr8qzINz8RsEQ8il173vAeRkSgxj8n/0HY8FucMOj0N1fsDzQn7zdGh6qnT6cco3xvy Ykf9Oast6dIUjxepeeK5/XJaJviibMBBQlpmPdjC7p2K4+SAvbRf6ixU8b0sCMUimDedBmH9 znUHCkijNj69ovIkADd+ai9/xnkUyHmxsUNuA6Uaig5z87RigjRKEuqRYA8WjvM2TL1g4/2B nnQ9wfzs3hdpY5HYB3voYmVsCM7a1zjlDSfYMrVuhxVJ0YvzkgJGP+X15NL3Z31iUsO5UvmR sDqdsZWcJeh+4nr9Xw3d+us9BSxzfqpVX2QHqTEK0egA52uCs7k1Cu9jZmlOwMLe1MZCDGBE dlT7s1NlHk9UxQXqq8DxgOsczr4tZh4Vfb++9XejQbu/s1c7GCAysK1jpJGXHd8iwGOPrbcL 8XGivnH9uRsRbDHQwuvD9a0peNuxfyfecZXcFCaoGQuRT6+ft7dK5NfDOojqDuTx3SlFmDgf T2A+E/vDkxAaI26reVALZLFCoHemakaPSJnAYYJfiEERCHm90AqOg69B9dAOYHlqVBCeTJuB ock4CLQRj2hEpmPi5bbCT6IsCurT36x/safue/YipETQo9/Mv/JgrH2MNNzP/1sa1h7aG/+b bjw/sVX+EBVSGJjJIfbJT8YjHTT8klivTWDMZUAsKA9hPrbaVEmBG+XczQtMThW2nhOQwCy0 aiAFZ1Q1jLcaw6mCsibJdusUia54CN2egj90xZBNqGr4+dRyRyLUHS4X5zEo8IzYt5LR21B3 bBlO+ykt6rN1heH1D4g06mn9N9dXowW8lqcotRFv/qR4ms/y/cSY4JVlMFcsxlY66yvfLJMX FFBrI++uRvrJ9/+cRsaChleZn85hurriBzkkqKZkZTr7Z8r9FqKdAs0BKjnhrIq08j1wXP4b JuQ9K79uvtrw17+lltXxulu7n8sasb28S4ylDBhLhx8aoYIQFrAhDyPI0BI7hKiw4+06DLfk SIg6Rc4D85CKckixfhGNwBOoEhKywkMEAGzGLQStt7oAAm/0cvPkJZ5AUuiT8iKcXFfUxK2d sqmrBa9/VPI/tcrZoPuUw9PBf4T/5zZimpAhlH1mGupreM0oA0ha1+XqyAC+q9rpYW+NfwN6 nK5I8ZW71RagN3geNzRtVzX5ut8pPbCvnvlnhgLolRH6lLoyN7Du7/Rx1GsQInrRb4icoFt7 z4nr870QaJV8MoBGBadzB6LNsERvs4GDtsPRSTkn0hzQGw8zIo1e2ZUAqsEHx6Kg5tJcvWVa d5Ol7ox13URG/1EajE8TgoO3dfpCqSoPwrZKirdkcKK4byhTEpgVv2W1Fv0SxHPeXqfWmxXV au+cXe+GbS2zYXzD7TtN7cd7Wxafv9f4yDhYxNmpgLgnqhrcTfcs89/p9IB/WKbf60wURFEw IVGsi78dqfMvtlA2DruhaE/M5SzejXnYJeeWMQCwegMpW7J/8Ywy4ybOVI5hTYMRQBs21hjO snENDwgPxsFMnIxhj5ixlA5l7BCBVyCBKdh5jgw/a7YMY62aP0TpLTpHEZ24mvzO2kFL0nW3 u9geTQMTFbGUKfMV2DpAY8ZQHT2fja1o02e4eS5hXjLscmxxMMbWF+2+elHnsBhXnOUm/UeA 2tBMKxYAaKXJaypcjyA6aV2PHVBjdycFT3LL8mD8orHRb2nvcwhZwuWmIBlowVRT8mhZK8vJ odwFOyq5PvWx8oa0T4Qi+K6VlwpM/Q76LnsvyPXcajFkAByHuqaclKx6q7QeBTijUrQAQ5w3 gimmJNMXJ5cadKOASc8XYElskKcKfFW+ldWVa4TTbLtsI+kTgWM2jnsS48QrGGLfkoV2BSTH RoL+dWfzN8kFyGjAI2l8vLeAdTxQTtIgGO4ZeyDAvTDfKJ+8M1nW6dO76ptqYFHhBgFc/psQ HYlvMdCnCO/XodIduAmjyemx7GkvC+QnjG4cNsH8LTx2P/kmUgPrYv/CyNxNuPJcTFdRGhli ie+TQrhdysHRhEJFgFIW8/9yGdyyezjwDz4995eBjA/UPEwxHKPy0HY24pKfUvlAehez+qLX tlcBIxJSrUpd1fYyAxoQGi5sOwCM2FTC6S+KRMwLRTl6Zz+SEj+kNhVBdhVHhx+z3shjKmLc S8Hs1rjqGC0jbILYuQXA1Le8iCl99Vzvy1vBeTU1aPphR4uwEwNR+FGJDbr4vmeLDEx6XdOP 7gToSsc6yHaWL2mGTnT5+QaeyXMrocOS6AJbu6HAvE3zdNUL504OCyvf1cPnIDPlVFp2DntM vdrhSkpPmxdTjShO1UNYfvACqUomu9BrBFz7IY3xB0YFNQ3DeRrNrJN8xGez3u6L7uN+tiIH yHgbc7qFW2c4tdtWMio6d9382IEKSAv/lU57ZRJyxtQWQJn3Qc4i3EPPLXG+vMJVFlnPLsnM W9FtZE41mFWSBtPnglJOrZkvduGsKCoR3E0bScp0Ntq6OwvamO/oIPKu4rz6Wm91aiSJFm7o pfsaMW92DJkSaq5LQKI76NOhdyxHeuCVlXhDBQ9r1Dnq3WC6s+36Jg64ngqzb9jntRuAOzRZ nESWK5RnTUzJBYlTHANVpo0Hax+9Z563JmZxWlkfBERkFeyMtO/JzOahS//Z7XBejLJOfTL5 dBRyfHkAhwlHiXqTeUCD7dmGLvPpvbsYHo/7iAFdICFkfRMq3Cj9ZUzITWf78y1pTmk5lckx aKI7y8Skr2KFc4vfzSwR0ZPsC7oLLLUe+5J0cq8/SIrKCPaYuOeFpp4l5igoTYZoTSM4wmtq N3KoQAQeDMI/JBig7X8fs6/AIv3x/sQJ0YjDG6fucaErdlGH+3HJxdi158lNj0YtjW7zJOAJ ilt6BrvuM4XWtrFenCGspvCJnHUFj+suRv7dln+1f3sHxGuZGQdUUJk75F0S4yllqUCTe2jt 382Srgnw6kDwywiz8YVHJp1P02KuTe2r8kno7C6W0A1A1Kv2FfSQqfDYQi3inbHvqkSsdsGw nSmApOgV5fi+hLnmaS6oY9ZvpBAV2hX7ADbg0e7CkpzuYGhW9SGieKczMZ7CuPKmL5zq4JyC bKfcxswTXSuPYLx8sbBQQaEJY4vRqMH5nEtUNMi5fudF3PhDDIYeYnFrXKEXT1/Jt+8tEcf6 XIDSYKn/zYiQD5lCQupoCqsbc2Lo9q/ktAZJo/ufOvdS5Ejmj4u6Eg54X8N4R3hoJJtBIZj4 mr8aPK0nqZzlAFrx1sUmuWgLAS/oz6tnl5J5c82wJMd9FZL+vNkHy4KsTeJNA3ZEXPzhahMn VVhGkTvYx2oDeKtaFh5ssmyBPOen9rSP99Euc1zcMJM71GyUMq9dW59Nx9SB/n7UjhC01FfQ idh+PL95s9NT6K+mtwM3VgikUezXiC5KDlIuFsdetbT9gXE5PmyTrKC3/JD4+X85o4DsseVg r3nkjiJJsMiZeyahIgLkXGDP9CIPbMv0F2wnADVsaty+raBdi6xwb/j1CpbYSu+7OS+WcGji az5nb5FB9iskz6MaM4j3INxcRcR1jMPM83XvbV9+fi59SlS1u2lV4X+pwzQQkX/16wWBw6Mh eCIvHCx2my26uxe0Tfi/dioBbXaDxBI0CkFVTavx9o7ZBQzRYuarvFurnGEnvUDGY39VW4vY XWojc6fIoOaigaDB26LCLUwNUAk46Hu5BJ+LxKzFMOIH1SkjdVgRGQz8sZnoz7V5sQYxla9D phPlZFmwmnTRn0RDGaIDxuPj4kcfczE+rP1lxMWUoA4RR365dArScOe7iwn4tHkaHWFfqyJC CeZF2PZj7AGFIkf9m4SRKO50WwCARqs4iBOjzFjcAf7vEVsJESCAXndLyCUEHQTBbVwF0m5w U27oKUNMyF3yzzzklhTCHe5JCottHOo17EGOcdlpyugXcx34/kKCoqH0BE4Sn3QH8CQ0DuEj bdFsw+OtXiHE9RbrQvzg0I80kJoQ89diB/f1BCkJwoSRMRJTyqZgJXqUS0hMsKXwC0tlRrAZ zymG3opW1IlDymeggiW9mE4hxRtl+CAU7TnNnMAU2FAR+mGqPmpRkY6snHJ5SnUxzLIF69zf w9dVSVfSPOzoJt3U4XRzCbR1JucfxIC8857mGpjw3m8xU/NSpfWc9RT0A70fYRi5JWHHFG4O JC7ENhn7wEpgKxQb+vdu2JtyNv7AF4C35MgKbrBxDOen/92cll1xXkQmNlFH0weLJEv4FYKC FDxwanV9t7XoSN/2+wPKyMXY/aoY90TS8O8Cx7dcNc40k4lzQIElZkQ+OmWfd6Kb/lYGmBMX OnYqsTaW4qfplVdgNqcm6ZfYJC9VGXMrryY+J4e4segTXybxTmGUDI9JSdIS+MD6Mh0e0bgM Yj9XsUS6DuICo8hsYxIGNASh0/KkvowDWjeiyCV3/Zyjc/Oon8Wes7nA5/xoj82mcOUZRL05 HypMnwx75GFpEP38SwHjdnNhTrHFgmjaGG9QSOB61+IZZ+V+Syx17hPtJYX/tmq9qI8a1CJ+ hGi29vZUEeufdm8Y/xEfGHh2UhTWSI8Phm+RJ4v1ERIElsqJj/ZSjk1DgMh2KkczpP/cAqwn atb+CDVsxriN5+rtwmeWaGsL4qLdGBVAy8ZPi3/Ys/ChUq3GaS9w41Hku4io8kBrrdmtsbkD iOcMFOOw2RlsR0FA5DGkyMN0aNuCvJ5K3UHC7rIjutAJHQ0Epe43wO/halE9riVOwYHa9SHT c5aOjWWvG7WxdEWkb8V+c0+wJZoSQYrETNDWfpBXlg9p8kWA3QoUKeuL72hm5Kfc0832Mg/m SHTOfUsBkaoretSFK/6CFEthlk/OAC3AqtpGkglAnascnHZr9w4arCS1+pDPBR839dQRsB7q a5FMMhHvE1oZqyp6rE02NTI/kaTbNNHLzV+yNwlq/QrFcCv0YhRUyDL492HLagjjopMlVkJQ R5YcUlYabbI3PX1hsbDFJDCk6JT8zKr9bPxA4K8i1RsOJag8UYfGKyedF9O0MfPM1z2g0m7O WiZh7e9nCvJW+mF34NDziUzXqRzrR+YjjiWdv568fhbMkittB1R85I4Hg3/PzkDuS9fg1Jjq ++senxJwHPB3x3/wgzQ8EwkGGedFo44Y5262CzfmWs+4gdhADSL4KbGnCFJMOEU0zwPXUdJq M6M2Y9fBEG95PjYR02Ukvgap/eAepqoBnDKghii29rvdrsz7UU+P03YzSGvtKVTeBYDI+lIN DvSiHZ81ic8VBwwMNHVhS4RoLm7ifjvRpvureVWAXv1FPDzE2mZkmJzHHxg8As9J8/MiusqY G31NA4kDX0sbuUha9ZES2eYu5U3K3fmy8UB+FwhNiorE8HxjY2xX7c6qkTlEkanTiwJkEkbq mEg8YUZSlJKpvR8YAHe1pd6Hhdu81gXMcE6B5hxW7VqpjCzXC0IMs4qDOjLN8jtv4m2+bH+i HcQyYezoJk9Qn4mWBQa/U49f5wmNPFxY/fpUagSUITZKO1sCFvWepztMoIU8GLLzjmXjOEwZ EKgwMllf97VNWaa3w7tbqwN9nJT/iebVGaGRHEPtHa/IhgEyzlq8Lt/qHGC00sOtsQ8jXaG2 YCpDhLBe3+HXfpMfRoCZ1HGwlHlS027bFnCSrV9JYP6oOg7Mng1c7LjxpCTw/qwynZBJaGR2 IT/v5gSgXfHr1Ay/TtkggdFDsJizBJ4WuQsKvHppqPCnuxCVemMRpkHs68jTncD++fn/by0b tPTIk6JJCUT6PjgRNS8frvaWo2aXFBWXxMea9X/IDgPsEVdjR7rXt3RyjK8pHj7iQyJLpGvS lc4b1awYD1a/CKJDrZBbMqYoS7Z7RrUdIn9zsU5KVGATPEoQl7FMaVpv/W+ocfTD0Ac6K+Dk pkxgM5A5RgUrhr73KFEhL4wpUMDPhJ4FQ2kRJpMoswcPpNyiTtQNyD7T/98RqXft5rMvO+ol kMrInJuRBixwyFMO+UjAFwRD3nnGSauDvzxCVHxepqvKVKLza193Jzl0WkpWCt9EjtRPpvx0 YT2PC4urPEFWwZCVP2GiuGQLmIAt9ozwptQsn8FI118Xtz5zhbiP6p6Z8ZLY30djdLvKBykT p9t8P2AYXkeo5hRTHCTIEGNHAndpGsDdyljjRrxRhdSDO8VMuj8+W2WW+rmhs83cvT2kKdxe lmJt7AOTADKL2PQ2+XYMGcjLL+p63YdHP4k/o7kDHHr0CbIk+Cf4EY53Jd9GDE0RrXKKDzYi NjeGztAThZzeBPH63CYrjqXndxB9cK2Kua3hVf3TFaKyzOvYPM69E36lGI6UiZYw7z3VqY+O PdsDLRpVGiKmw1TlCcNXlW00u7IKcp9ji+t6mkn05hv3Kra1nHUYhbQ3Ty4P6HGnDsJx5iY7 ASPwQewH+uaCuRAMPvuKFJxHAzE7U4qucvk3gyTPVOP6+YKLlgdntRNk+8gMXBf1iZxs7uYn n+8IliSUR6afS7OxuHtoe0JxniN5C/SZz0bkOyglx3IRLOQX0IlXyKcxIq/dGPKwnYcIpcL0 Rplw5YiZBKLwaE7II31SljBmT1y7QROhQo04oz66CVBPhtoZwFOZ/dxhFzGai0xk9Z9WYGVB hC7Gtpew7DBFMrYEqQ0Vna68yEYLM3KvwEqZKSy/ZoBI3Idmde2u8zrdIz0kfIXeTq/fPmC7 q8lVx4IGBXz3u7NxfC/9NzAMbIzWnog2+TmwTo8LB+ACk/Rx4xRGVw1Ey0mTUVQmVcX/5NR6 AxItrM5cUtSFzFBrsIhAhxQ05sXEceqaxccVEgJovT6V1J9xmZplMt21VQW+qcr2FNCyZj2M YbCjWABm9/kwSCfnted8j2RBh8UJMmKxALWG8DFwQUbFdq+txhZKElBsXKRPTA+98Xbxw1JO bgmXTLNbb9dw4nTWYWE6rxAIwjoivwNzLPN1YVzM/ptAq5YkFHvtCeGPxyByHt4UumurkdMr hTzziCh5RDsNDzqvSHeiIgNpkhD1DZk1swbueSiHQpBTVszdN6d37d3ZC2+E2ig+/wh7KWSK 1eBh/CQ3JvHgwPljLa3wCqw8gKe3qp1fQhWDuYMotnpFpaSP6FU7mbb096L9m5nVEexKyceR XPNmjSKo2GsnWbLilRxJIs6LtbKITVX31cw/Uls91uFHI8ytVSDxUOE6h2e83WsDxJcEmX66 JaVT5xW06yBwMzgr/1uh/rmZnPRNnifev+gecU1zvYgTbiSvmPBqcDc4T3JVM5ydPRkIc0As dEoB1aO7G3xY5tR9kBPVvhzkv5df1Ai4+i5FUpr0pfUwqXV4HZ9Fytbd7Y6iUGBLtRkMovho O0JR/w+H++9NVmM8cq0f0CpM5wLjho0uM+2fAnUHKuyi1g7wGRTuyMNVDrIcas29DQVaYVpv 6sPdshyLoIfjlKixxG3eLjAqn6uJRrVHU/fGt4BqzG9ljzcUrWBSPGsKWmkYsxP8Vj17We+X Y84RmdyZSwyOKMbiyKoY/TOMvRqC4qayO2zGzqGaMdD0wRUWwGsioWXbX3A3lGJFvsbajElv 4p5yT0moJlDjNzYYp0FNK3+hb+jWQvgtdANN70VFLzXJcPYwEvGlQ/kmDbw6RubSnJ2HeDQ6 ysfFUpAE/BCCNgzwkkLRo/xlQXAVKUv4/EPcYX9DzX/UUm6bUFDS/6QiTUgEQ19iuYTl0Xi9 MIPxee3N82RbeJXIXfYnLtWLDr0gHkMQ62fD0LvqQpJNtXaunEs6mW56GudJdENUMU4Gk3BP V6xNgTjrfJtoRahMqNZWIJcKVHQCyOWW2ke8EFT1ysGV7LHDYx4FhIjAzc7hOt8fIrLZ4a3L 7tY9N/sYwmUOOsYh3Sc2Q9OlpoYxuiYIbD+GtPq7kIVqFf5v9VbxWaKru50abTYq2nyeWUB4 suUak8i50pteD9dMABLwSWMdqYN2tI1OFPnY+PlYFphnVPpKalS2Z0s7TeYK4YfJTB+I75Zi Z5WwhN3Sok6WdM8p8etBaBnL451XR0So8PNZGbJZPNfxK2iETnuvdTw44pxp2Hi9TtSUDuXD rk7P+cPdb68P87tMCEojb8cBai2gxS6m9/cIrLaH55s/nPqblnF+WrAMpKh/XuHnkhJMg4De X8IoJnkpQoWOrqy5UoXCk0wT2Rjx/lvO6+is68A4z5q2uwoNZvXg+kBi/fyMYu+hBj1e9ILO 5IR/UOR3kXv57FUAdRHuMcIi3+D8j9PPkCnuZIYvcKLCz8TbfYPVWTVlga7MMTz1zePc7254 eUsIOZEeoEVFciXQSY/xs3wfJinQ1CwzHgEu1qu1u5J/C7TREUqQXeDgkU8989Sdfbo+wN/U lcgg7Ca3hU4l11/bzA9y3UN9p7v4osc6f3UWTkjgeXRfRSsxMEXNPMm4Jy5l/gwXYUrG1Jty IbdSjtOiRG1zzK5N0puZ+0o8q11WMrBbOxJr1GdlGB6ZQCMg5eBBtEdjCtaxR+hZ/XhqNhSo NpuLItShRDkMTrpax/EoTfT3j5lHRubT8tcdoi0ze6byO3/WNK4zAKIwbGwV9qfSvJAhDaKf vlGew/uxL0xa57KrnGPn08tcmtgJXtf08tlTDVc3wF+AUnZUttUgVDj4VbcqOQcYVzurIWLD uQ/jiOJjXfy4kNHktdGqQlkd1i/t8v2eO4I27hMdK95uSTob287f81mzu/+c714AKvaXPWJO Lo+/HVuIR/JAa9h0XhKEBDTgxmaepsd8J5kc5s8pQnFIF/q59JK0ICQhaj8GB4+gmvM+t6aJ s+fXEMPaMRRTIMEHT7NvSRNIBgdZ4Y9RfLzl9bWeiA4lL/Azq0BjMsahpMozxOFnp5f+vz2B JpvaoM/pga2CVT7bAvnsfmP9W0r8/INBh+PkzVsW5Oh7xegz788jkwWIsHuG/hLhvpkYQc5S aA4saFyGY2XTIj5XJl4CnZZgPDsChDj41Ig+0fku+6vfUzVuc/4C1SWTRYVmkwb2UIDrW+5c 1ADdSKY7ZwoVAcmGL3vOWo8F0RAJIX9xFpvTx7PxT9YHru9lnMnyc87V/X5uj9EiagQ50oAj G9pxWweL0L2ePcMvfnK8qtM4wlLnTJyBN7AL4xnqDjnrdEiJdlYBB+a4D1P3jkUpMbtkcGgY /x1GX01zLAzvtGkVTGx2WgvkxoWGmEK9GvhW5CS2gZlj4sQn+y3mPN3utlZF0Y9LWa4Hr4YF JuLxyvhX21IdSrx7jO1awNIk4HO/Pmb82ZpId5s+4QavlqcRUdtkdkEPc2Vh75f0LB7LPkvx d8JmzwAOpMAA7yL5SNWFFPweOyoAgdwXH6nk4ylBXt/AplwakqdG3ekEWhTA6usyq5rM0lkO WbKBXjvlMdW9iS2Bweza9+IfS7rhQZeEWQ/v9qZwgHKFTNHfK1WvU+2hKeGRTxthFznG8JJv IW9K6E8YiLXrohbu3NVxOa9c+1pqssMijvBEIhxhzJDUJxa31rRWXQAAgNyFwuAUHFJAFfTS fzMu2ZtFCUpUPrzyTM9yR5L6xc/RTVyQYdHF70epm1JijhFMH5F7FJiYvG+hgC5x0KA3pOXt rv38fkwfuwgwQMbA5Y0RDAaIZ8Q+NRjiRqHjAc9T/+foFbnlE8jecCKTEpbrToOJEKdhOS4z lR5Ku3fGRxPxGZ7czxKRhGgIDTynQ75GdXInkzZA3wRYO15giSrk1Ctkchc7iJFcRKSmOzTb gahgvzsgJ8z29/IQc8sF1tXh0B1lVSHiJVsqumjcKes1BIDaP7M91jAZ+hNIjHKNcPsMQcbI 0P6AnMqKzoC4X5xY8kpsYI5Elgj58KGilX+on192kFrWrb4d4kvySfJMeEcevoP1HaDMQ6+J PhxnBreeMg0itMlIjvelEyW8Y8gSHA5zExgrk+Co937cQ3FGkJvQ5GWwqhcrb1KYOVPsBJ8/ 0c+5IYyfq56NvcQBE2y99B9Lx/ZEzUChllZFS0egPdFf0OBzvUNnOvfZ9g670Il1ZS7l2dUh Ybmz0YPLZarf9cqCrYDAsm/peEtnUROrVGfuO4yxzv4+wogx4aO1IDnRQjsXwhnICib3lm88 CeUM+5j/ChGGW67rpdXKP+8eRgkDinGcbq/nr3MekHXLXEtcmWo+ziNX274LQ7oJTnKOnhqn LpAtA4qoOSqmvVSqg93tQswlgoh0dckByD3QGGcEj4vpeFhltFl162Jft/Qm5f0zD6UoNHif TgMFaaF0eetdQGK1c9CPf7fqRgR6v1jbCx9/6n8l2b7+SJUeNe135SNwWhdo9V2enoUV5u6x MVGGzzZfUZCtnDF5pkfxVn2XIfYXsbO3srUMmvsohmAeqw/DUgLlKJQRXVoFY9ByGTwsovUs MkwmmSZahiH5MXpmHheYRQSvdFs2CVlPDZZ5Eovy21HM3IsAenLLOQGLcJBmtXGRAxFjgDSx xKEBClOnZsD68F4oKl+VAMeTDdNXAbleA6WNOz7LFS88y38x+yNnRahhoxg3r0MwNbBVLAa9 J0zuiSCMAEELae0jsVYkG0KTV41JB5sxKsQE68MvWCaoZzJLCXi8cbDl079X6QvzaO+L00jO +tD/SzGkeep1B2CdM2pZXdIp97yrn1UQUhbrCshA0IwgoAGjhuuv5bXY3AlixClMFa+CmyEs pErlGMiC4Hr/ADy5ZOVF2rM0x8kxKUK4uJux6LDmcjc2TR7+Yvd/tIZ3/t801quz3cJqVxMd u04Z+D5xVkLRJ6K9+bTEHcBEzRPVRyOmtEYjh4gD/Bwv6oWwUMvnhG7hapM9iC4jI5tvzOJ9 YhCYGh9Z7qVrrXSSxLfasL4yh6m/OIaj9RBhCAa+QTiHpJVaWla4mSy8zi4GoHbpvuqTy/FH ByjdLJJ70nN+4zHDteX8fPW3mPq6TcC+/LJjGIlRchK/HV73e6e4yRgwPM08X9bqU7x7gXyi kK2VXxT069NPeYeFKH5pAbbhtjHXwt6ySNuvBc8cms7TsRsGwhT53Uz0ujWo2G3WW8LBTa2w 2tq/VyTBgmDDAh6QgGMseB3ypAZSu+MGIra9o9Pu70roVtlmzZRACeqfPOaBT+AcuS5YsY3Q 7smYmFEX9t1D9lBDh0X1hpBybcE4jwfVNy4/qsaMJJNQ2OumyUKreqgljcLLGmU4ImNISSi0 T+H/bSgiblsJn8bnpA4DlS3nyoXI606clQgS6Yh8/vv496nRITViBcVvlUDiI2q29pSw6RZK EOq5uISYfxNSdg/2yqBeukWzUpR0IR/GXrNAMPMv1+jZKVZmQgX2OHonGuiyb4cMEqvONxmN oZRCsYv0ZOqhgqJvWXknLDVcfHoekulT6gw2Kza64MQ+c0BwvoHMwaKtf04jcCEdc5IVl5lB qCgzNzc8AY2RfzPsT9xjocXrUrs4vHbmcOyz0lBGKnhQg/Vu6O1gmrMwPqRQsc2RAP+kUIEQ dmHJk1oH3PoBPzhUn+m6/4HLsiAp4TwtFHRI03TeEPrCwi9Qh9B65/lq2izgxH2zFrYGlx2/ RPLl0v1Kgetawdltca5OlNWXmKFdpQkbeQrb9cwnSNn6ed9F3k5ALM8v37Ek8pR2IwXxwMso JgjTmSAf1iZ0Ln+qWLu6mevUzUWfIb9LOIPlaP7p2h1qYLloTWcY0+S8jbAZNJY05RAMzytc 24BLufqdt+YX4Tqw8Ua0JUvDaV3p6frozCWkIKpjSo+waGhcOZGEfb5XkEVaZWTOQB8HE3bO 3ij8GX5ar9QWm++z0KLVHJdl6GSPD0t78AOiqMdsVS/HJbAmMWtpURmTryVa/Hui7KhR5f5Q CVtv17QD4huJ3De11G+lRmfDHJuRQliUOInvww31+Z9q3qXrTARIUAeZDicPaNrzl0uvlKIe 6O463DGl2pq9OnD+xxAGhzF134TSoZsHqSJkKa1Kf1we3DqLiIDax4duPFd88wx9jBlZgp99 PobBK6mnml1tIRQ86hjileiT51Y9OB+29+jWG/MEukvHiEB+8zT9GeNYYzeF+LhvjXlwNMLz wreiHYzw32JaR7ZnwqNtxYu5dDp00OQr8v07KTQnQopX3gogk2CLkub0loW014TW5kbmG+lY QpwLO91j/GYIYFyN9Chlbn0o2uMw1WP9usZBthCT0A/3ajzew0I+rlQqNqOxAjvGSA8uHGmX LWYfl8dnIPmcKbmDUaPHReZQHFgKKyrYeLPyTNQpc55Jk++BCyp8gO9bDKIawXt5zebOmY2P f4y1YFJOcSVYqWydN3R3JF7PHwxvnL8Iwqjq8TJknvSVCa2YcFZiHzzeJr/nCFa1wMU8uQmk L/rE6LpwZfHUtTAz652jkB8wrg+OEZMKZ/rnW/sWcYcaVmS6Ye/BfvrecS7fujeCt6kvMNrT HQMGVli2dYgrqKHXYkak45K/mVVy+eUrollhorAmFxW5kK4TByLss/SYGLDFLVK6wAb7EA+F uCi8LYCPOsS48u6uhu1UQJR7m4sQTWHjDJBVsDd6jLXXxVeRVmd43qIobdQXpEERx2nLpMEi eysR98sK46C/aJXgmQekKlhPA1SEvshvqBXi5TJ9OWg8y9wpWx42sOd6XwA5TDJ4uudn4rDT fg4jQx7v1BMvGnhSEE6JKZC52mA9BsGG9Uc5yaCIfiWvBRh07XXYHt0Wow/+/UFbbso9kKmB uMm6izFgpIrdvzRUNacvP2x4bsKNQylx3tR5+feEI2p57/fEqNK7fHoL+iI6Xfjs5F3cyiFf mWYK56pqpMd3yxSk0gF/QNdsKd35ynxTFq99lHAfn17opsGvHXP0QY5dQTr23Gkj7ri7cCej /tbCwiY7IV2PwBnIQR3Y0/r+wjp3kSxcBPxgWytlfew/ajk/lr4nw/zXrwoT2OdFSyI3GN3O gpk1eKJjE5JTzWa9ypWUCjOVWAtZxatyjHOviIUjDzV7UM6+ZfqwbocZKhVPMtRIMZqH7J7a n1H8gPaKYy64ipmuu3zpqC2eWvFupb3Ly3mPjANjFBmsGfv50opa8FHCpMmAEb2Y0jOkOQDG 4Q8OaJfEYstocXK7tGjRmbExjc8j1L7u4EN5oSNpna9koytP+UskYoegHmrQvhSXIyCLTDcH kYhhnU9LNdJRacXVRsCLi+kxNG3g89X+0rmvMokqFKczvMn18JWlpxAPg2WvNLsGOCcjFlT4 /olaPB/x3JQjrMep4JqoGgJ0YbiXeh7BLDSynNAsDjZBg+HeKT4q3s5kRL30e4NXmcwr7Qn+ FdLMK5Ob6/HV8C6zafUxUUS8JxWXHruCEt9/xSHk16Zhh/ZkBct5paHRnJ6AsWrCMv73YpKl c+vczn/XeJ0UtjgfI2EBLwHvw+9jEYKAmzziu41lcVJjHd7C/Kd+maC7IbJCJomJr6rwS0jp IxdqU5nk6hcNubEHo+wXDbsC8NxPIdL1Sp3J1TxUGx9PuHVQhvW89vqH8HDrdbQaZl1odUka ZJ5VpN++rA3LKzKZfdveqMyBN3VLtI+UHFtFqK56EewbqaSDVP7X2wyY9QKDTP+ClaNN3cn0 zF7OsQNfZ9B+WALBJIGmqdfgHemNntvg93ntL+2PHb4jsSDxMWuqm2IfXqnGCY1tUA33VBmI QV04mQeCGIXuORbzTEnPRKKh0YxZ/aSY6+pkW5ao26nDX7BOOJPNQ/gSNA28c7lmI822YCwU qcBV9MKmXzx9yOPWIreB0Hy9YD/N6RbmQHIGu7q029MJ2bvCr59/GwFSbQnMv1LU4DGwXyFi 0Le6uSobiFYYAgRI4Acg73Pud568ZYdDBPY+BMBZC2WPv0FAbvxEVTCSoNJIYVyDZacpVoVi 8QytwBfw/8c6z9+JknQ46XNfIrxddxnnCeoABs+2QOmLaPdCiyPBvn73rKJhXkLqCk2kco4j IFk4t8ogLAq1tlltG3GgwAgxG3zd/hDyEp5u8ahiHAOS7mQNEdF7dvPAYKq7Q3zF0BSAmd39 A9Dfsdu6DNCc0rMX4fV+Qgo5hd35gYv0fM7OB3tjFAWdlchmzJV5X818WYTH8oxaxDI69mbJ jk1CDtgI4RjFtuR29jdOaeWDKR2WCH/Sk5xrOCLfXiChdFO5/Ei/aJu5SNp6vsI4xrBTuJNV MTlDGPG5+oeyeHtsXL1e7+tSw+T9ApXcryYQjhvoiTiZNnGdYzLnjOrstNzN0did1U0Rh8kl KWaPbiIAerUbC5Au/R95eurWUwp4RqvxQZDeXpTcE49M8Hpk9MmHoPS+539zJNrbjCMtGL1s EPWZN0Rqza8omr5h3qf9YpY45/G3BiirBNAKvPJHAq8hLtfkA/2qj6/LX8dKRhvYDpu076bJ LLVOU5TEHfJKUno79FKfB63Pbk/fNAlcvirzThtI7YiMn/qjEEe9uvuABteArKQmlkCamYFZ 6eEebuTw5VO/MKYTGbBFgM4hh7oqyu6a+aG/LKbdnkmrNfhR67ZyZqvLUvs1DmLT7JWhdaei IXAb09o2e2fu021pvYXcf51aF7nzPJX1Va2PZh1ubOMyIjg9kjr5m24knopjKxFDgj9iY9ri PeWEvlg5LJ7M13AYH4xKk6E5txTSKcWli1y+I+95UwLVCLq+uHNYeLjO/IFJwSk4Lh+7K5bl qcPsIpUV34bAofUm6J2Dc0JOmrr8Lhg6PZRO6Jy+C7e6/uI4boCpCc0W+wxkYfY02nytcgR5 hHDyOWc9IIH6kE5nw2Ds0aq40flFc+1Ut9DQO92cAdR057TxwZyxy1lSeGemCkgxAyZkbbgo Qm7Eg8YzK4uXzWcn64K8WPc2UjmWRn0EIMBMY72zcvo0bm6KOq/zo17pfkWPzug3+/AGnpPq HKqHmdpgPdzMKtW+nAa+KL6U6IGu1HBXYIEK3TCqNp7jjsu4as7IYfUN7S/SRNJC4bndGDo3 zEBo0xGLWyJ9bkeWmQ/GLPGxzUAv36NXeLQCHCHAMYgek0SZF1jwtr5MdmyzsVuG5Dxm8DfS yCV6TuV0/jcIc3HROnSEaLiuWY/E9ZX3PjHjtMQBK0G+rK6zAIQKPMYuGVQ0Tx4dBfCq6xmN u/lWn2ZVkbiuyuZlyg4O+dkPMDa7BHvxFwfVaNAafDaKcYxvvZgphgqv0rQ1UGW7bRUrsamM OC0vczjq1ZMOb5zWMvlhwaL5sxwsNuZjx6Qn7yQSC3XqD3FrceinB0BorwltKSgoAGfG4+DK mRbFEOvEZO9grOoe06tOCkSIbvMjVyOSrBobwJxt5LWdlJIkZxGaa3gFF4ThrqP9qZ1l8O6M tLhI92pkGgkbhV9/QQX2RV46npNB6ZHuggS5k2rUSw72RNKATrSzBONh8+8/JHx1xA+AMYTm rlk4+GIUtfyuKxqERi4pcwIf1zQg2HF5bs+grGmLGzto/vmbwHK9b75EWADtx6IOiLkfn14D 5wf1yM/0ZEaqa7e/AiX8KIgXdpbVSSd3OOuiO25M4cq5nuUClFWpIclFk7R1sBTAdrjqkyst p+jD7hu8bDEG17+CadmbqE0Gsr1YyUdU37/337tN+WY56JZoVMJXslFWET/LChoQFLgnGvX7 Lao2DuK2aQ9hea39mTijoc0JifRgSWNOUqrwU4uGbLc30e/1GVcCnC26pCir8cUELCGs2yfh YV7vIKK/HVsrXGBy3xJl++CWrOM9/M1VZ67k3qwd2VDa9UVNt/phkRGUoShYP7zMaFUxL+on syIGqXCGLEaChAV5iCVaqhF1CRTMU2ESK0LwsbxGaEO088gpVXYv+DPvpG4RyEbdppaGwbLs WaOJ6md97+8cxO4jPMoW0iwIOjQtsJgfcADnIRQ9VC9ykD1avXuK6IYiZYVQxAajW/78nl2f EwNkc2+RMEwnIehENb0nRqhmsbSQHWaS2VkOfQJ5jF1vee0O5x93EWcVasd+HweUXAEXtJHI udfzmvZdqauatjuH6iDzr2csvPlo8y3yRo/hiZOe7E+TinwgV9JuVla9DWECx+RSpaOl5D+T CUzRUxdk7pGMqUhiQRwEVtHZn1yUXm2s4h6NaNjAxgKyPBiQlUR3johVUpB7UanQzRd1yAHX 8ACZzMeJrHkOAMzTUdWkwFwZHWgVbpBmfgDyDAVc64rW3ziykyU8veFf3GzIJNAGOWn4SNY/ jfUDiFri1SwRzT15J0OKXJT48A6+I4ISxEpJLNqcmaKFDbuOJXd4m2KQtEcPaTpF7d7JC+hq /afvN7I9fa+hdmjfzvtG8SqHZ2Es0twSU2O7qUGKtCXkF7w3eMWQ40NoL8cIEKIz8XVeRa4x I7wMP0k4M9PxxY1ZhS64lU3jdyhyZ9m0KxHAWn6RxqTt3Vt/iEQfF9ShcjqaVHHuGex+X1HV J9l2jfiHsGihoMTBV7+tHWy93/4pNpYvyPGCIYE9vkhsIVwSRpsC7A58/Z8YMJpxQwyr5AJe oi6HPfomhuJ6I71KhnczmKSbrmU0c1berrOlOhFLvv+FqZPXHawjtlHKxOx0A5XXSpsob8vS DrnTrPs94gep9A86DHBirU2HUrodq2sLLaTL9cjqIVkw5SAx8BdrzC3U6QUOJ3jBzdJmkRm1 F2naQZBgvMbLv1CEvlfQ5bZAr1ezxGRxkrPQ11ZhKmwzeGO7lkV+OY6z2xI+H5TCqbymwM8I fofU57Cek6byQBTbMhypwhk49AhegmLu30C4JEGrBWzrGQcf0oHplKT5b5klNETNK2oftRIt wuAJcqIL1vq3sdADIkO4LK5M0tvRkXljT6vmXIRyqh40izTqcF3b0QnSJ58DZIQuybC13I5K MBAllbRP3EQ0GNGuwd36omktmqsdCOJj6AeLdun3KFXzHhsVRTwY1Qq33abrJrhCBFi87d+C p/7wkqjI/1TF22ZZlMafBCOHnJBwWVZxD2/8FpjXnCiA95NXBmy2vV6YbIs90L5FZ97Ftr/I V9Fy2N5WALzyiDxEDLQRP53vqOJHUHnlqSXE5KWLqPLRjX7uMuUwjomSFSQJzYyXJnDTx1N/ Bx8xsz8iP4JSjjShg8llkNe3rvkWQIFN+VOEGGrUeIN4TSNW+9WC3FDj48vgGVaUSuCyCBig 0YvfckTLwTRnAlCbsWcV0XvWZsMoBpmV1L6vXZ7UggsHPmieWc0tmHAXwMtSmJmSv7q8dIq+ sfJBeAjWdcEQH6+APh7FUTa8o8Qo/xPHWvZtArQv/tk0pFrWwTIB4sqGmIJ1sx0A51FTtX4a ulX18XnkGrWVyvebLaCUil0Z2zbur2fJvL+F6MwUmJKJCqSWdcD4SU96oQJj1dDMQqPGc2py Sw1v7Aw3maxnUrLvd9YHnxGkVFkpKQ3pKZsysPqKyfV7yY3Mpz2Mq7dF4BryDaTmqapfhMgG PvY8EBcKEBPsXjA2716o0jYqBCudhmumpahy0Ib8BNIhiAXWFt09LWlLHuz9V+SZKAdrzw24 ffBdrmzE69YygLHdo9XquP+TBFbZ0rlMxeKJaVgxRqNgqJYLlCxXMTVF7li9jp4t3y2ACweo mxKwPjQ8Fn+xn7K1W+yS9EhcZTmUjAVRRL5b/CCmOMDSksDETYuMwMPUSIp5AsouX5r7XtJc 6X3OOWP1mKfdhzvTXvy2sF+7lpZi5NOegN0dzoG9r3PMKZtabEY9Q98FDpnvX+DGEYAwdgTL MoEZ4SgnAkcBpgF3URLxHIKypElnwIn+e4nBAvt3CWoiJjuE+t7Olqb8XSlMlABywM3jjyv+ p7GBzGn1GP3DAxRpfLlZj8cCwHTsV0pCSXX1ymZc5aGNvbrNdHVXaN0u+hdwUOipx/GHiOeB d0UHJJutuFzEIPwGgFp9mqGN58LO5ynNwa0/EswdCsWSzUXiv+PR/IGhK/1jTA7nSZ1JPvfH G/vT5eOwYKCq0HXHiV+jfdPwqJ1+kOJypmSn5hCIN9gOq113jaf5nCyv6gctqJsmom+v50VJ PVyg0O3kAFK+tHR+CNi/YQN7f81+kDzalVxxTkWxYu6BfjuvvLbPXMgHQSwLbvlScQ7JaObS vMt/vpaCYl0fa+wSHOJpFLakvfI/FJ1GgcplCutUrlYkpVyO+q8T31XUkEqoyB/3lYuIPqbN alzNWXK1t6GBjrL/7WDnbg/Z8e9z6vp6/EWf9e5r7DYehBr+n+R1swksT0IvgcOfaX8kj8N5 +qUaHgxMXQAMDdCZ9cZ/MktSn7nwtXOBSi+2SJgvSwagVwzaR7IpoFXm+XiVZ5qzc+0G/ZiV YPw2vkI796a8m3wZwDmVlAICevAta5yj61cPmBks4/0amrhqZCMAIXS+UdPtJrVOhbEO32F+ itxu2hq+bIrvfIovlUYTYyXLjFnXQQ/zKW47bEFNLGxEZuftzJXKf4PZQf8hfuqEXfjrGyU+ NhQ5S4w1I82ZT3NGNsCoGhfRWRO+OeteCjZ0/fTJCgx4x01yr0T7mbxRCsTnHjfBbAe30U0N n5fPlAsHaJTeI4galRawdEwLoVRsfnDLeqEsQGIZhAqlfK+1vDioCPt3UMaNryMlxVQ7d0qP HR90V5K3O15gzQRz+AiTG/7nJmQAwfC6fkL/mBO8hz8b4UbIerT23Tsms0QRNAWXVOA+VfoJ o1LQV9SAtDtu6HE4TNkbl9F8/ljplIMh5qaxII6G2sr4la5yxm1Nqc6PeHbQoub8vqmGMh+c i3WhP1O0vfJ6T0rNcnAFccVh28fHYMKr/Xtj/NKSuhrYR/JvASAM9JP17GrmFQa46+HynQTL pz5jun1ooO4AGgtqo5H7DwMGyDxjsBj9LdEP2D195Q1naJXHOMGiGhuNfT6XbT7XMpvwAc3A 8gxvLCQpnzPGmixq6zTy/3HyeVeVpz+VY35riRAbjisSMGB3vFcfZxsTBsTjrFFDYCkVcz6R WKeN3RPurohT4M+V8SStApGI+cMhRx1hHOjkW0AcfsZi2cN5fRsNDtI2x5JauuJDDOuGz+Q7 9MfRXv1bJgOiKP2BkSLCA1nShaLE+3EF2PprWQEO8F8ZrqV3ECtcJkJS0bo8VkFBUNX5VW6o fN5pUxjW3scPjxotn0/wr3oLaDWYe7DzkE5PUFBNklOwcvgVJt+QnucBLg9ZgXJRaLrRJYyg GuQL9irO4r5PcYS2LCuQgKp3YAGSLvk8uEUvY6EsPGI9FPZwy7gfzl0pSckkPhWIoRgDse3b TkwkFGDraSkx/u2HYHXd8oQVdf/kuaFk5B4KQvXNfe+Tx/L6KWRRuqkgaAAeFTdg4+PaPawY WkOKXQVFXMTm+NOFiKC1FSEcfzBoHvbKgiaBS8ZXzviZYMO9oMHo2PDtE9T+Xs2ROFvxak2+ thM74oe2SG6NcCqMGZ+VErRU5OT7UYJhZIVhV2Em9vRvicINZW5kc3RyZWFtDWVuZG9iag01 NSAwIG9iag08PCANL1R5cGUgL1BhZ2UgDS9QYXJlbnQgMjEzIDAgUiANL1Jlc291cmNlcyA1 NiAwIFIgDS9Db250ZW50cyA1NyAwIFIgDS9UaHVtYiAxODIgMCBSIA0vTWVkaWFCb3ggWyAw IDAgNjEyIDc5MiBdIA0vQ3JvcEJveCBbIDAgMCA2MTIgNzkyIF0gDS9Sb3RhdGUgMCANPj4g DWVuZG9iag01NiAwIG9iag08PCANL1Byb2NTZXQgWyAvUERGIC9UZXh0IF0gDS9Gb250IDw8 IC9GMTQgMTE2IDAgUiAvRjE2IDExNyAwIFIgL1RUMTEgMjI4IDAgUiAvVFQxMyAxMTQgMCBS IC9UVDE1IDExOCAwIFIgPj4gDS9FeHRHU3RhdGUgPDwgL0dTMiAyMzkgMCBSID4+IA0vQ29s b3JTcGFjZSA8PCAvQ3M4IDIyMiAwIFIgPj4gDT4+IA1lbmRvYmoNNTcgMCBvYmoNPDwgL0xl bmd0aCAyNTQxIC9GaWx0ZXIgL0ZsYXRlRGVjb2RlID4+IA1zdHJlYW0NCqvBi8O0fEKZrfel 89hqpY20+EQZqbxATIWujTEp41dah3fGbfzTxCc9O7FjFr/89O/utWOBcfvsJesfVFLDfhnn jDnatcnkUaSGSjV7y18Bw5//g7IrmDS6UBIQjSP7rNNfQBC2x/BnP9Bswl/pEpaim9Ywnrjp mzi4lcCdZMv+rmPDnwr/Hjx12wISCLzdzcvK9xI8EBe/RmWnILJHNgizDSMIrI8aRycWDMxd nBYOJq0G8hQFPm7a+Y3iI2mCBX86hRfGNiaGFx6mFl4KwIcwf9Llcn3QIN95ne7UXH9dnX52 4sWkQ0+N+qMHxFUcslQhnvL5kEP2nsSFKWfr9jkwbeXNJFo7kGnaB7yLTJnWo68E+/46xzEF PeCTiV930Y02snwULG6rQ9ksAKckaadUExZfHYQ33cncVE7F5rTlTEcrlz1yr2uiYPb06Kv+ 4xiPUwK4vL0+WetMSaOAGGwEL5qF3GKNutfHE82Sf78byvz1w81AGqnQ5PxQ2td+3BgMEDDK wktTzYh9KA6E8br3Q6t6LeXQDJIFtPVWwxxEuWkfSWtkPY2jL7j/8Yl3NKEUBWBNz6uLA4hJ D08MWF1h0i4zGHca1affy2sWFT1p9/P0jqMiIbaEFPO/Be0bpHnb5qEA2lP1wIqnxwywISEB argJXUXhwKNvfrz8nQalnOC2PZHKVMiWhlPbDZUsPm7KSIO0oZN7I3B3jnqqXWIB+XswQWB6 d1cnk6lgAsPY68tE1vfqbOYLjWGyd+vfgGt/rc07sqq5vSqXPyDsyYTSJq9rshAnypPDcnFI 2l36AJup0Bc2+QdFcBPSnDKrepT0+mZa0pxx69RL9PC7K++VgUhFCRq23WN16LxXkVokuDdr vj6vRg6pjzwrHwkpjIaJlGtQbUUjaQYlU15aetcBTTgLrVvxk4rd8ogGSeg2nWvPB/KYR8En fqo0+iV3GCHzhgs19v+M9EbJzwEfa4tT4t7w3mRAHF1KRYS5E1/WBoqyw893jOpsmHdvl0OX UxceSns/QJ7b6I5vzIyBt6vHjzfylB7YoduBFT8qniJMxfkFcdMw6ckUF0rbPakNMG/VOokd Z8cbxj0eIbYUwdZMJA8JPwqX5bJst4jqHe5lAdZBwmmylYPqk1z0h8dU910nNORZo5IO1gZE kQr1Nh1oKZkNsuhHMGhZH9KpLdSJgt4tvMeUxJVE5Wb6O7Kd93aer4uehjkTaZU1C67lEXEO 7o+pvCxuXm3BOA3wKdH18z0semzLDnytWlFNOi2KpVYAP65l5aFoztvcwsgZ3Q3cH4b7Uk/T JmKd/rxM8jkECirFp9MAnKwDt0FrLR2f4HVRs/ktxH1KW106/2k/Y9Sa3ADy+yiyitgOmjba HfyGosqk1h1aJt1tRbBAACNM6KjyHfIe4yv4AQ/wD5baq/+/09gWc1qK4biXmZL6Odyxt3nZ uqhRjll8GkaJRtt82Ku0pvwpncG1bRA0YTzWHGnMojQyfnDTrhXLbn5BmqMEF/Qk/6b4rpSW PanxSXzNY+XHYfLSCeHGVsIwJBzOpyFkWpr9xYpSMo/Grs6UKu0m0PKu5LDt5p+4KvIx2NVZ c71dfdzkmtnD9hYY/gxeco7tEviT/P7oq5QNI0AtxS9Y0UkN4MemIfw0Jkhs1vJlgsu9Sevr phHl+U9LRruEUowDTaCzD5EEVX8UxO5TtQ2Jrn5hX0PP3GFsVcGICmu/dbvmHQdm/3C60Q9c sW+D7sATXdejOyzIJEPpd1NoHIYFO9hUywVD2aoSOi4aKPVN4l8MBb037MG/7Vr+HiOLUGaW jKTdB1/5DQjzsuZHybj3hc3vJ5jQO3aVJwvIC73QRxE6fW5ZQ8SIAa/Do2VBOoxvo14Y51gA iNxw29FSLDVwuzh59L+qqsEXxxyZShjC0Jqdnaf4t9v6k8Z/cF8Ge1ahQc8FAH6BctJfyzGv Jjq8UffMJAAnTO9Fz68R9tIWmQW9FyPfmdKk2/25gTimN9RS4UnMoSo2rsjAFaExQVdZ5VYs Ike76s8SB4LclXjuc4ExlLlXQn68UQbGfNAGumD9OJZqC8wXFSkiqami4NqK2TvOIGtdvYj4 xQk6+0TqstoF2YAlW4gIG7QT7wkcDvsxlkDNZS+d/xwkRE2DfSAJHdhA8Mq19absyF87LmWV w8LzBStZeEyelZzBBqNrCXtD+8x3QemBfJWWSBYrXy07qdLORLWkZHHjAQEKAfaurqTM1EhM k/pdv42Hc3MpWtBO7ro+7v9zURrb6gRpGEqc/gNGVNupZq2qDTlTmHf7c/UM3py5TlUBfdFs pvdvM9EFiApzFsQ96ipUHF4eHN2LmT7UPIkRArRpzwaNsgcLr3+hcndq7WgxmOVbXPTLK1N4 cQM9dACV5lz2velRIeDg+nbKA2bgvaYiw38pGW/pWBrJRrk6nK52ozNWOvuPJlUohnGOeujK XcxHUzUQIMquntOpvuHTeUE+zykyEhszcHWDYokyDkMa2LfBx8LYxYd2KlR8uhQDMNphA55W xk2dbcjvrePhjw5ZyViy3CPsE3wfTA8MEOExDeWEm3DzxJJztcjaOrM46ZWnpJ8a7T7+UC9C +eeid/c3y1SWZe1MOa2zTJ7YbkUg943UfrpEAUELaL7LGk63N3V61q44BTdCVB7Q/5PEbvmB 8X4hV6a2T0EJyi1Fz1RLEOeICnoZ2HNZaOI6mYbildhXfT1hgSHGXwAAWfuQQuCzF6N3Sr28 PaIEB9sXw2+r0qyXIpBHj5MCaI/jxUS8D+4+SeQjk2vPa7YUqeZFQrruDYVvli0oivNnePV4 r/jDUAxEmXq8mtdfFwrREF5r1PEzQv+zTkd5kC7m6E3Y3ivY9QiJtYEw15HSoIU3wkX3ysi7 Z89fXwG9inFCSdewbWyj7ZABrIIZsxulEw8o/YA0AmzoXrKQajAD4AOmG2vI7ikUADyhX2gS W4oEQ0tRUae0PPO/wXGS2Jebch2BiKSUIbn3D2Lm8vcO2JBGQXWLp5oEz+8ktsDnAEB+cy+r JcHsqR4+qGK2VOfM4S07W5xgpojkeQ3mem07Klvw3/e0T59XP5fsQCcG2GnpvYARUhWujh5n BeyYCpP/h0Zf+RnUEjXicclqRsAg/y3s1BRo+yziqvXNqvI91lT6EX5vXHXnoRJvM3EE/gTZ r4OEkjc4FNFVqmWRF1qpsuB9dEjeeM9SBuDHxAkR1Fby8Aq3mpNirWvGKpeldFCA4ywRgvOr Q17yVOiwZjMM+AeJYl2eKz952kf3+ghG04CtLB4DTF4EqRDRe0qTMuzqWb8lobiGuM1x2oZc UbJzA6wS1LdeWqdZOSeRXWEYw17W5kIdX7vxhG3ejHa4PELBvNDLZWSk82fT7Q1lbmRzdHJl YW0NZW5kb2JqDTU4IDAgb2JqDTw8IA0vVHlwZSAvUGFnZSANL1BhcmVudCAyMTMgMCBSIA0v UmVzb3VyY2VzIDU5IDAgUiANL0NvbnRlbnRzIDYwIDAgUiANL1RodW1iIDE4NCAwIFIgDS9N ZWRpYUJveCBbIDAgMCA2MTIgNzkyIF0gDS9Dcm9wQm94IFsgMCAwIDYxMiA3OTIgXSANL1Jv dGF0ZSAwIA0+PiANZW5kb2JqDTU5IDAgb2JqDTw8IA0vUHJvY1NldCBbIC9QREYgL1RleHQg XSANL0ZvbnQgPDwgL0YxNCAxMTYgMCBSIC9GMTYgMTE3IDAgUiAvVFQxMSAyMjggMCBSID4+ IA0vRXh0R1N0YXRlIDw8IC9HUzIgMjM5IDAgUiA+PiANL0NvbG9yU3BhY2UgPDwgL0NzOCAy MjIgMCBSID4+IA0+PiANZW5kb2JqDTYwIDAgb2JqDTw8IC9MZW5ndGggMTM0NiAvRmlsdGVy IC9GbGF0ZURlY29kZSA+PiANc3RyZWFtDQpw039uf3fbpOWfv8n3V6k/etcsK7xrfuOQrLOx NwgtSdAtAFrs3HQgdPWQBaBi7P515qTy4y2xWkbXQe5y8kvaKUigvD5AY5d98pUPljgoWasn opPjVjpDp+nEQSYwjHmqE7iyD2eIblWwCCQGwJEalx/bLKgKWa0uKE9pAIYjnYL9vGzzwZIM WtPwy5QERLj7+/v7yT1YuZYLtJGTuEVXW6Lx5hlQx1y2kIxjtaTxxT9SlJ67Op2p7SdrBTw4 UbLf4HvBjzZ4ON+6zCLSnkUvGNmsA1iCO4PXJkW0xJ9DQFbsOnzpvipZLCMSqVri7mxd/6M5 Ufhe0DbnUX6Ra7vZTiUTSnmpnBTYm7LtlJmOTFlc30ukFmRgDd2xywlngx9xQlW1oWM7H3LQ gPPSAQV9QNg107Yu9t4C1fs6y4PK6XmNiYQu6LEuOjYgcRgmuBY0sue9NV+XzicWj4+UleZO 5HJOQR8KeZYsp9A1xgSIqUik++UnK/qO5YCfnYMSZe64/XbfQmrROjxtBwV1JcNvGazCsvvT VeG0oxRcMSniKaWBq07XCQvImMu7re+7vscxZoSDGBqVWKqGgbyYgy4862FwiV8uyIjUR55F NkfYiEAaW+Eu2mTtafhqzbRNn2q73J314K+PsmD0wCJOT2AZEjBQWG3/SXzkhvMVop2VZnWp sveotgpmeFQ9VctQcy8cgHcoYgCAJAjmz6oo4+mp0V2HemFO91RaLaFicHTv/Awxw+oT7/Mk I2Z+YubZrtB6Xy+reej0zMLg/Q6AxJEC+NiHU3EIPa+ZGsEMd8LKqYxzD8QaPVZEwiF4yhW6 loxNACf+li0ovxdn/Zq0cs53KOtZtZR5EI3PVP8J9nrV4fx1LEghyaFKR7ZmHNBEI7s8Q/qt rX1quYzm0IZG2Isq1e4k3L8beh59nwRtUiO9wscQmwpqQMuuxvdbChTJGtMxvqlFEWUM6Zx/ E+SsJLdTzmcEECLpIh8aaoaPhLUcvnTKLMDDy9BOzlw74FDMkX0jREftc2tqKJnsnQfRqKZy bgEBv2C6fb5HF/DD/vV1ZM5V/8ha596D7+h5Z4Q8uLpQOu9cSojgaJlRgdaFEHukzNWHLx3l H3lyv5/+wrdbM2I+M3+jCglGFFTHiIimcrwQHOUf3JEr3kOK6ypIlW/djsGbkk455awibkUG O7TZ9ChR7KKvKiD97pmEgXJQVVyki+OkFVx0g3kIL2U531YXGDAJzQkNFWPfXbuMJZ9BCsgR a1Be4++XyNvpCeD7w+qZvEJgobSH3k3F3ePcxAMHnsJXMzfsdylT9S4nSwKe9cLLixDuI2kI /eJdcbcqX/r4CtnVusVIC3FQQtLdHpyN/FSxUADQkR/RANlLTx0BPaWVg3bvruHh2KwRLtL7 kv1KrYz4wPf8an0EXK5TcJSIzV/Cw/OhiPRiKBp7I+hZtHDR9agfwWw4/jM2NrsJe2WjiIEb dSv+CeN5iC9HXEhyadoiSnSNdwIqxgtyskHrdvzJTGwWXNwPzCIX9WdIHvAotLOOx2DDe5oG GlPQ2cPFM0rsTIurMOFhgdebbKQCEHtodol8Sxo9HnwCqWh1Wx5lbYpUuus9u+tyB245Sj17 cuE3HWGTDpwphBzML40NuYuDxZ9FW5pxpHiMoT4SJvM0AAq17phVYULR90g+Rk9CtXVl+CiE F6yt9AE89cIwknXCmVQJf0eSf4u09G7OgdHc3s/k5Uo+fMDGtWeQYWEaWWb/o6oXlpZvzF1C h8CxVyFMi+JUQy9p1hyURHBjCbdfaA1lbmRzdHJlYW0NZW5kb2JqDTYxIDAgb2JqDTw8IA0v VHlwZSAvUGFnZSANL1BhcmVudCAyMTQgMCBSIA0vUmVzb3VyY2VzIDYyIDAgUiANL0NvbnRl bnRzIDYzIDAgUiANL1RodW1iIDE4NiAwIFIgDS9NZWRpYUJveCBbIDAgMCA2MTIgNzkyIF0g DS9Dcm9wQm94IFsgMCAwIDYxMiA3OTIgXSANL1JvdGF0ZSAwIA0+PiANZW5kb2JqDTYyIDAg b2JqDTw8IA0vUHJvY1NldCBbIC9QREYgL1RleHQgXSANL0ZvbnQgPDwgL0YxNiAxMTcgMCBS IC9UVDExIDIyOCAwIFIgL1RUMTMgMTE0IDAgUiAvVFQxNCAxMTUgMCBSID4+IA0vRXh0R1N0 YXRlIDw8IC9HUzIgMjM5IDAgUiA+PiANL0NvbG9yU3BhY2UgPDwgL0NzOCAyMjIgMCBSID4+ IA0+PiANZW5kb2JqDTYzIDAgb2JqDTw8IC9MZW5ndGggMjUxNCAvRmlsdGVyIC9GbGF0ZURl Y29kZSA+PiANc3RyZWFtDQrV7MZ+l6N66LYATfMW68nHwNXSeyj1s/0dMRwiF8zi06kNKepT
December 09, 2010 - Present
AeroElectric-Archive.digest.vol-jx
