AeroElectric-Archive.digest.vol-ka
January 12, 2011 - January 22, 2011
Subject: RCT3 crimper opoeration
Date: Jan 12, 2011
Cheers, I am now 'self-educating' in the realm of teeny-weeny DB9 pins and sockets. I have the subject RCT3 crimper but am flummoxed by its construction. It has a 'tunnel' through which the aspiring pin/socket slides until properly situated to be crimped onto its inserted wire. Then, one squeezes the handles until fully compressed, four shiny probes close in on the target until the clamp is acquired and the crimp is accomplished. A very efficient device. However, the rear of the tunnel has a threaded ferrule into which a spring and an insert fit, and an external cup threads, closing the tunnel off. Thing is, unless I dismount this latter cup and its bits to open up the tunnel , I cannot insert the pin/socket for crimping! What am I missing? Your advice, direction to instructions or otherwise is keenly requested. happy landings, Ferg wiring a cable extension to the magnetic sensor for the Dynon D100 ________________________________________________________________________________
Date: Jan 12, 2011
Subject: Re: RCT3 crimper opoeration
At 09:31 AM 1/12/2011, you wrote: >Cheers, > > I am now 'self-educating' in the realm of teeny-weeny DB9 > pins and sockets. I have the subject RCT3 crimper but am flummoxed > by its construction. > > It has a 'tunnel' through which the aspiring pin/socket > slides until properly situated to be crimped onto its inserted > wire. Then, one squeezes the handles until fully compressed, four > shiny probes close in on the target until the clamp is acquired and > the crimp is accomplished. A very efficient device. > > However, the rear of the tunnel has a threaded ferrule into > which a spring and an insert fit, and an external cup threads, > closing the tunnel off. > > Thing is, unless I dismount this latter cup and its bits to > open up the tunnel , I cannot insert the pin/socket for > crimping! What am I missing? Your advice, direction to > instructions or otherwise is keenly requested. Strip the wire appropriate proper depth of insertion into the pin. Hold stripped end of wire up, drop pin onto wire. Lower crimp tool over the pin until pin is seated in tool and close the handles. Withdraw wire and pin from tool. Some folks like to drop pin into the tool. The wire-grip barrel of the pin should be flush with the face of the tool. Insert exposed strands and crimp. Wire with attached pin can then be withdrawn. It all happens from one side of the tool no matter what brand or style of tool is being used. Bob . . . ________________________________________________________________________________
Date: Jan 12, 2011
Subject: Re: Circuit protection for relay/contactor trigger
circuits.
On Wed, Jan 12, 2011 at 8:18 AM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > nuckolls.bob(at)aeroelectric.com> > > > and in particular paragraph 23.1367 > We use 23.1367 a lot in Flight Test, particularly "(c) Accessible to appropriate flight crewmembers;" and "(d) Labeled as to operation and the circuit controlled" in our Human Factors evaluations. 23.1367(c) is my favorite regulation. It's how us flight testers get to completely redesign the cockpit after someone with far more intelligence than us has put a lot of time into layout. Just kidding. (Lately, most designers have become much more tuned into the human factors aspects of designs. Everyone wins, especially customers.) Sorry for the digression. Fuses and breakers protect wires from hard faults (LOTS OF CURRENT) and > nothing more. > > Now, armed with this simple-idea, run the > traps on what kind of fault would cause the > contactor control wires you've cited to become > exposed to high fault currents? > > Faulting a supply wire > to ground exposes it to the potential fault > current of a battery . . . perhaps 1000 amps > or more. Faulting a ground-to-close control > wire to ground exposes it only to the current > it takes to close the contactor. Hence, no > protection is called for in these lines. > To summarize to verify my own understanding... I'll protect all wires over six inches who supply enough current to make bad things happen. Why, then, does the starter contactor circuit in Z-10/8 show a 7A fuse? I see that it closes two relays... Bob . . . > > -- Andrew Zachar andrew.d.zachar(at)gmail.com ________________________________________________________________________________
Date: Jan 12, 2011
Subject: Open squelch
I have finished assembling my panel and everything is working fine except the squelch on the Icom A210 is open unless set to the highest level **or** I turn OFF my GRT displays. Either one of them ON opens the squelch. The Garmin 430 does not have the same problem and I tested them both with the same antenna/coax connected to one my wings. Both radios receive fine. I have removed all connections to the radio not essential to testing, like the swap & serial lines as well as all connections to the audio panel, then just using the speaker output on the radio. Also fed the radio from a separate 12V source. Nothing I have done has made any difference in the squelch setting. With the GRT's OFF I can set the squelch to level 4~5. With them ON it must be at 10 (highest) and even then it will occasionally open. My wings are stored overhead so the antenna is in fairly close proximity (8') and is horizontally polarized in it's present position. I dont think that should matter but I plan to try a different antenna today. It seems the radio is just overly sensitive, but that is just speculation. Single point ground per Bob's instrument panel ground bus. There are no shielded wires attached to it at this point except the speaker leads. Any thoughts or comments are appreciated. Tim Andres ________________________________________________________________________________
Date: Jan 12, 2011
Hi Ferg This link has been shown before but just in case you missed it http://www.eaavideo.org/video.aspx?v=713328494001 It gives a good breakdown on the Machine pins installation, Hope it helps regards Ivor On 12 January 2011 16:02, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > nuckolls.bob(at)aeroelectric.com> > > > At 09:31 AM 1/12/2011, you wrote: > > Cheers, >> >> I am now 'self-educating' in the realm of teeny-weeny DB9 pins and >> sockets. I have the subject RCT3 crimper but am flummoxed by its >> construction. >> >> It has a 'tunnel' through which the aspiring pin/socket slides >> until properly situated to be crimped onto its inserted wire. Then, one >> squeezes the handles until fully compressed, four shiny probes close in on >> the target until the clamp is acquired and the crimp is accomplished. A very >> efficient device. >> >> However, the rear of the tunnel has a threaded ferrule into which a >> spring and an insert fit, and an external cup threads, closing the tunnel >> off. >> >> Thing is, unless I dismount this latter cup and its bits to open up >> the tunnel , I cannot insert the pin/socket for crimping! What am I >> missing? Your advice, direction to instructions or otherwise is keenly >> requested. >> > > Strip the wire appropriate proper depth of > insertion into the pin. Hold stripped end > of wire up, drop pin onto wire. > > Lower crimp tool over the pin until pin is > seated in tool and close the handles. Withdraw > wire and pin from tool. > > Some folks like to drop pin into the tool. The > wire-grip barrel of the pin should be flush with > the face of the tool. Insert exposed strands and > crimp. Wire with attached pin can then be withdrawn. > > It all happens from one side of the tool no matter > what brand or style of tool is being used. > > > Bob . . . > > ________________________________________________________________________________
Date: Jan 12, 2011
Subject: Re: Request review of Electrical Load Analysis - using
Z13/8 architecture > From: "Howard M. Plevyak Jr." <hplevyak(at)mac.com> > Subject: AeroElectric-List: Request review of Electrical Load > Analysis - GlaStar > using Z13/8 architecture > > I finished an initial version of my electrical load analysis. I'd like > to get some feedback on this from the list. Minor amounts, but you appear to be missing the loads for the voltage regulators, essential bus relay and SD-8 relay. What about an avionics fan ? Jeff Page Dream Aircraft Tundra #10 ________________________________________________________________________________
Date: Jan 12, 2011
Subject: Re: Open squelch
At 12:05 PM 1/12/2011, you wrote: I have finished assembling my panel and everything is working fine except the squelch on the Icom A210 is open unless set to the highest level **or** I turn OFF my GRT displays. Either one of them ON opens the squelch. The Garmin 430 does not have the same problem and I tested them both with the same antenna/coax connected to one my wings. Both radios receive fine. I have removed all connections to the radio not essential to testing, like the swap & serial lines as well as all connections to the audio panel, then just using the speaker output on the radio. Also fed the radio from a separate 12V source. Nothing I have done has made any difference in the squelch setting. With the GRT's OFF I can set the squelch to level 4~5. With them ON it must be at 10 (highest) and even then it will occasionally open. See what effects, if any, are noted when you disconnect the antenna from the Icom. It seems the radio is just overly sensitive, but that is just speculation. You can never have a radio that is "too sensitive". I MIGHT be poorly shielded or the GRT equipment may be overly generous with their radiated emissions. What, if any, are the DO160 test claims for the GRT equipment? Single point ground per Bob's instrument panel ground bus. There are no shielded wires attached to it at this point except the speaker leads. Ground busses have no participation in the kind of symptoms you've described. Bob . . . ________________________________________________________________________________
Date: Jan 12, 2011
On 1/12/2011 7:40 PM, Robert L. Nuckolls, III wrote: > > > See what effects, if any, are noted when > you disconnect the antenna from the Icom. > > > Thanks Bob; When the antenna is disconnected the radio goes silent. I spoke with both Icom and GRT today. At this point I'm going to leave it as is until I still have a problem after the panel is installed in the aircraft. If so GRT indicated they can install some filters on the video display that may help. Tim ________________________________________________________________________________
Z13/8 ar
Date: Jan 13, 2011
Jeff, Thanks I'll add those items. I'm going to go without the cooling fan initially and see how the avionics fare. I might have to add later. For those planning IFR w/ similar equipment....it looks like the LC-60 amp alternator is a must due to the high current consumption of the pitot heat, navigation, strobe, and landing lights. For anyone who has not yet purchased equipment you'll want to buy LED style, and maybe the Gretz Aero pitot heat system to keep the amps down. I'm going to switch to the B&C LC-60 amp alternator and plan for a max continuous electrical load of 80-85% or 48 to 51 amps. Howard -------- Howard Plevyak GlaStar North Bend, Ohio hplevyak(at)mac.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=326839#326839 ________________________________________________________________________________
Date: Jan 13, 2011
- using Z13/8 ar At 06:48 AM 1/13/2011, you wrote: > >Jeff, >Thanks I'll add those items. I'm going to go without the cooling >fan initially and see how the avionics fare. I might have to add later. > >For those planning IFR w/ similar equipment....it looks like the >LC-60 amp alternator is a must due to the high current consumption >of the pitot heat, navigation, strobe, and landing lights. > >For anyone who has not yet purchased equipment you'll want to buy >LED style, and maybe the Gretz Aero pitot heat system to keep the amps down. > >I'm going to switch to the B&C LC-60 amp alternator and plan for a >max continuous electrical load of 80-85% or 48 to 51 amps. Really that high? Do you run all those things all the time for any flight condition? Here's an exemplar load-analysis form I've used for many years. http://www.aeroelectric.com/PPS/Load_Analysis/Blank_Form.pdf It set's up a series of flight conditions that comport with suggestions offered by FAR23.1351(a)(1)(i) that says:i) "For normal, utility, and acrobatic category airplanes, by an electrical load analysis or by electrical measurements that account for the electrical loads applied to the electrical system in probable combinations and for probable durations" The operative words are "combinations" and "duration". Not all things are turned on at any time. The last detail load analysis I did on a small airplane some years ago showed a max CONTINUOUS demand of 27 amps for the worst case flight condition (IFR, pitot heat ON). This left 10A plus for battery maintenance with only a 40A alternator. The rule of thumb for alternator sizing is to reserve 25% of total capacity for battery charging so if you're planning a 60A alternator, you want to establish operating conditions that do not demand more than 45A continuous. Bob . . . >Howard > >-------- >Howard Plevyak >GlaStar >North Bend, Ohio >hplevyak(at)mac.com > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=326839#326839 > > >----- >No virus found in this message. >Checked by AVG - www.avg.com Bob . . . ________________________________________________________________________________
Date: Jan 13, 2011
Thanks Bob; When the antenna is disconnected the radio goes silent. I spoke with both Icom and GRT today. At this point I'm going to leave it as is until I still have a problem after the panel is installed in the aircraft. If so GRT indicated they can install some filters on the video display that may help. Interesting. I didn't mention it in my earlier post . . . but the LCD color display panels have cropped up a number of times before as potentially serious radiation antagonists. Sounds like GRT might not fare well in the DO160 qualifications tests. Bob . . . ________________________________________________________________________________
Z13/8 a
Date: Jan 14, 2011
> "nuckolls.bob(at)aeroelect"]At 06:48 AM 1/13/2011, you wrote: > Really that high? ...... The last detail load analysis I did on a small airplane some years ago showed a max CONTINUOUS demand of 27 amps for the worst case flight condition (IFR, pitot heat ON).... Bob, You have me thinking my scenario estimates are wrong. In my sheet I estimate Pitot heat (8amps), Strobe (7amps), and Navigation / Position lights (8amps) totaling 23amps just for that alone. I've checked with a few other builders that have similar equipment and they all told me they had to upgrade to a 60amp alternator....and that 40amp wouldn't do it. I did talk with Whelen engineering yesterday and I can get my Nav/Position lights down to 1.0 amps by switching to an LED setup. But I'm stuck with high loads for the pitot heat and strobes. I need some help with a paradigm shift on how I'm estimating these loads. I'm looking at your form and for IFR cruise I would still think I'd need to assume Pitot heat, Strobe, and Nav/Position lights as continuous loads if I were flying in the soup on a cold wet day. I'd appreciate a reality check from the list on this assumption. I'll try to rework my numbers using the flight condition approach and see how I fit using the 25% reserve factor. Thx. Howard -------- Howard Plevyak GlaStar North Bend, Ohio hplevyak(at)mac.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=326997#326997 ________________________________________________________________________________
Subject: model airplane servo
Date: Jan 14, 2011
I want to install electric aileron trim. I could buy a Ray Allen servo and control its speed with PWM. I was wondering if there are any other options that might be lighter weight or smaller. Has anyone had experience with linear actuators or model airplane R/C servos? Do the RC model servos hold their position when power is removed? The ideal 12vdc servo would be slow moving and would be operated by a switch without electronic controls. It should also have built-in limit switches and a position feedback pot. Maybe the Ray Allen is the best. Thanks, Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327009#327009 ________________________________________________________________________________
Date: Jan 14, 2011
>Has anyone had experience with linear actuators or model airplane R/C serv os? > Joe Gores Hi Joe=2C A couple of years ago=2C I considered doing the same thing you are referr ing to=2C using an RC model servo for a full sized airplane. I checked them out=2C t here are a LOT of them=2C and they are usually graded by how much "pull or push" they can generate. If my memory is correct=2C I think I can remember something lik e "32 grams" as the biggest version=2C or at least a 'near' biggest version.. I did some m ore looking around=2C but I don't remember if I ever found out what the RC Allen servo' s rating was.=2C ....but after I weighed the option of trying experiment (yet again!!)=2C I decided to go with the RAC servo=2C and frankly=2C I'm glad I did! It was made precisely for my intended use=2C so no experimentation necess ary=2C and they even come with little clevis forks=2C and matching pins=2C and the kind of stuff you'd expect to find on such a devise. I suppose if a guy looked long enough=2C he may be able to find a servo t hat rates higher than 32 gms=2C but even still=2C I'd think he'd still be better off with the RAC servo. That's not to say it can't be done=2C but I think you may be installing som ething that MAY not be up to the task. Mike Welch ________________________________________________________________________________
From: Bob McCallum <robert.mccallum2(at)sympatico.ca>
Date: Jan 14, 2011
Joe; It does have all of those features and that is specifically its purpose, so it would be a logical choice. Any of the other options you mention would likely require adaptation and you would have to do the experimentation and reliability research already done for you by Ray Allen. In my humble opinion I would suggest you've reached the correct conclusion when you said "Maybe the Ray Allen is the best". Bob McC ---Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list- > server(at)matronics.com] On Behalf Of user9253 > Sent: Friday, January 14, 2011 9:57 AM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: model airplane servo > > > I want to install electric aileron trim. I could buy a Ray Allen servo and control its > speed with PWM. I was wondering if there are any other options that might be lighter > weight or smaller. Has anyone had experience with linear actuators or model airplane > R/C servos? Do the RC model servos hold their position when power is removed? The > ideal 12vdc servo would be slow moving and would be operated by a switch without > electronic controls. It should also have built-in limit switches and a position feedback > pot. Maybe the Ray Allen is the best. > Thanks, Joe > > -------- > Joe Gores > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=327009#327009 > > > > > > > > _- > ==================================================== > ====== > _- > ==================================================== > ====== > _- > ==================================================== > ====== > _- > ==================================================== > ====== > > ________________________________________________________________________________
Subject: Re: model airplane servo
Date: Jan 14, 2011
Check out http://www.periheliondesign.com/moreproducts.htm for a controller for Futaba, etc servos. Also has trim wheels, etc. Bill Schertz KIS Cruiser #4045 N343BS -----Original Message----- From: Bob McCallum Sent: Friday, January 14, 2011 10:19 AM Subject: RE: AeroElectric-List: model airplane servo Joe; It does have all of those features and that is specifically its purpose, so it would be a logical choice. Any of the other options you mention would likely require adaptation and you would have to do the experimentation and reliability research already done for you by Ray Allen. In my humble opinion I would suggest you've reached the correct conclusion when you said "Maybe the Ray Allen is the best". Bob McC ---Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list- > server(at)matronics.com] On Behalf Of user9253 > Sent: Friday, January 14, 2011 9:57 AM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: model airplane servo > > > I want to install electric aileron trim. I could buy a Ray Allen servo and control its > speed with PWM. I was wondering if there are any other options that might be lighter > weight or smaller. Has anyone had experience with linear actuators or model airplane > R/C servos? Do the RC model servos hold their position when power is removed? The > ideal 12vdc servo would be slow moving and would be operated by a switch without > electronic controls. It should also have built-in limit switches and a position feedback > pot. Maybe the Ray Allen is the best. > Thanks, Joe > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=327009#327009 > > > _- > ==================================================== > ====== > _- > ==================================================== > ====== > _- > ==================================================== > ====== > _- > ==================================================== > ====== > > ________________________________________________________________________________
Date: Jan 14, 2011
At 09:56 AM 1/14/2011, you wrote: > >I want to install electric aileron trim. I could buy a Ray Allen >servo and control its speed with PWM. I was wondering if there are >any other options that might be lighter weight or smaller. Has >anyone had experience with linear actuators or model airplane R/C >servos? Do the RC model servos hold their position when power is >removed? The ideal 12vdc servo would be slow moving and would be >operated by a switch without electronic controls. It should also >have built-in limit switches and a position feedback pot. Maybe the >Ray Allen is the best. I have a skunk-werks bin with about a dozen RC actuators that were used in various remote control situations over the years. These are short throw (short rotation) devices with output shafts designed to move control surfaces with a bellcrank. I have some about the size of a postage stamp that cost about $10 up to puppies like this: http://www.gpdealera.com/cgi-bin/wgainf100p.pgm?I=FUTM0216 for about $100. They're spur-geared and do not LOCK position when turned off. Linear actuators like the RC Allen will not back-drive when powered down. Further, they're a bit user unfriendly as stock actuators. They run on 4.5 to 7.0 volts. The position command signal is a variable duty cycle pulse. Easy to control out of a microprocessor (or r/c receiver) not to easy from the pilot's seat. I've used these as rudimentary motor-gearbox assemblies. You can remove the stops, pot and electronics. The rudimentary assembly can then drive a lead-screw to provide a LOT of force over long distances. I guess the short answer to your question is no. But they DO offer some interesting opportunities for a variety of remote control tasks if you've got the interest and energy to stroke 'em. Bob . . . ________________________________________________________________________________
Date: Jan 14, 2011
While the RC servos do hold their position with power off, it is not quite locked. You can move them with some force. Whether the ailerons would apply enough force to do so is a question unanswered. I would suggest you stick with the proven solution even though it is somewhat pricey compared to an RC servo. You can change the speed with PWM or if you want a true servo based on the Ray Allen design, see the same page listed below for an add-on.. Dick Tasker Bill Schertz wrote: > > > Check out http://www.periheliondesign.com/moreproducts.htm for a > controller for Futaba, etc servos. Also has trim wheels, etc. > > > Bill Schertz > KIS Cruiser #4045 > N343BS > > -----Original Message----- From: Bob McCallum > Sent: Friday, January 14, 2011 10:19 AM > To: aeroelectric-list(at)matronics.com > Subject: RE: AeroElectric-List: model airplane servo > > > > Joe; > > It does have all of those features and that is specifically its > purpose, so > it would be a logical choice. Any of the other options you mention would > likely require adaptation and you would have to do the experimentation > and > reliability research already done for you by Ray Allen. In my humble > opinion > I would suggest you've reached the correct conclusion when you said > "Maybe > the Ray Allen is the best". > > Bob McC > > > ---Original Message----- >> From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list- >> server(at)matronics.com] On Behalf Of user9253 >> Sent: Friday, January 14, 2011 9:57 AM >> To: aeroelectric-list(at)matronics.com >> Subject: AeroElectric-List: model airplane servo >> > >> >> I want to install electric aileron trim. I could buy a Ray Allen servo > and control its >> speed with PWM. I was wondering if there are any other options that >> might > be lighter >> weight or smaller. Has anyone had experience with linear actuators or > model airplane >> R/C servos? Do the RC model servos hold their position when power is > removed? The >> ideal 12vdc servo would be slow moving and would be operated by a switch > without >> electronic controls. It should also have built-in limit switches and a > position feedback >> pot. Maybe the Ray Allen is the best. >> Thanks, Joe >> >> -------- >> Joe Gores >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=327009#327009 >> >> >> >> >> >> >> >> _- >> ==================================================== >> ====== >> _- >> ==================================================== >> ====== >> _- >> ==================================================== >> ====== >> _- >> ==================================================== >> ====== >> >> > > ________________________________________________________________________________
Z13/8 a
Date: Jan 14, 2011
With glass panels, IFR and HID wig-wag headlamps (I fly with them on all the time to increase visibility and perhaps reduce bird strikes), even with LED position and collision lights, I still add up to 34A continuous in cruise. Jeff Page Dream Aircraft Tundra #10 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327025#327025 Attachments: http://forums.matronics.com//files/load_analysis_onebus_a_591.pdf ________________________________________________________________________________
Date: Jan 14, 2011
I think these servos should be considered: http://store.firgelli.com I haven't used them myself, but they seem appropriate to the application. They are located a few miles from me, so one day I should go visit and give a PIREP. Vern Little -----Original Message----- From: Robert L. Nuckolls, III Sent: Friday, January 14, 2011 7:59 AM Subject: Re: AeroElectric-List: model airplane servo At 09:56 AM 1/14/2011, you wrote: > >I want to install electric aileron trim. I could buy a Ray Allen >servo and control its speed with PWM. I was wondering if there are >any other options that might be lighter weight or smaller. Has >anyone had experience with linear actuators or model airplane R/C >servos? Do the RC model servos hold their position when power is >removed? The ideal 12vdc servo would be slow moving and would be >operated by a switch without electronic controls. It should also >have built-in limit switches and a position feedback pot. Maybe the >Ray Allen is the best. I have a skunk-werks bin with about a dozen RC actuators that were used in various remote control situations over the years. These are short throw (short rotation) devices with output shafts designed to move control surfaces with a bellcrank. I have some about the size of a postage stamp that cost about $10 up to puppies like this: http://www.gpdealera.com/cgi-bin/wgainf100p.pgm?I=FUTM0216 for about $100. They're spur-geared and do not LOCK position when turned off. Linear actuators like the RC Allen will not back-drive when powered down. Further, they're a bit user unfriendly as stock actuators. They run on 4.5 to 7.0 volts. The position command signal is a variable duty cycle pulse. Easy to control out of a microprocessor (or r/c receiver) not to easy from the pilot's seat. I've used these as rudimentary motor-gearbox assemblies. You can remove the stops, pot and electronics. The rudimentary assembly can then drive a lead-screw to provide a LOT of force over long distances. I guess the short answer to your question is no. But they DO offer some interesting opportunities for a variety of remote control tasks if you've got the interest and energy to stroke 'em. Bob . . . Checked by AVG - www.avg.com 19:34:00 ________________________________________________________________________________
Date: Jan 14, 2011
At 01:03 PM 1/14/2011, you wrote: ><sprocket@vx-aviation.com> > >I think these servos should be considered: > >http://store.firgelli.com > >I haven't used them myself, but they seem appropriate to the >application. They are located a few miles from me, so one day I >should go visit and give a PIREP. These look interesting . . . especially since they're offered with built in servo electronics to integrate into a variety of voltages and control protocols (including R/C variable pulse width). They DO report a back-driving force value but it's probably very high compared to working loads. It would be interesting to know what lead-screw configuration they are using. Bob . . . ________________________________________________________________________________
Date: Jan 14, 2011
On 1/14/2011 8:56 AM, user9253 wrote: > --> AeroElectric-List message posted by: "user9253" > > I want to install electric aileron trim. I could buy a Ray Allen servo and control its speed with PWM. I was wondering if there are any other options that might be lighter weight or smaller. Has anyone had experience with linear actuators or model airplane R/C servos? Do the RC model servos hold their position when power is removed? The ideal 12vdc servo would be slow moving and would be operated by a switch without electronic controls. It should also have built-in limit switches and a position feedback pot. Maybe the Ray Allen is the best. > Thanks, Joe > > -------- > Joe Gores Hi Joe, My 1st homebuilt was a (purchased) Thorp T-18 that had a homebuilt autopilot (wing leveler) and aileron trim system using a trim tab on one aileron. It used a standard model a/c servo, just like what you're probably thinking about. The autopilot used an ingenious pneumatic/thermal rate sensor as its heart. A stream of air moving between two thermal sensors made up the rate sensor. The system had roll trim that used a generic potentiometer to drive the servo controller. The autopilot section wasn't functional when I bought the plane (it had been stored for about 5 years before I bought it), but the trim feature worked just fine for the short time I owned the plane. Failure modes were never explored by me, because it just worked. If you're handy with electronics and the application of tools to small projects, I can't see why you can't add a worm drive to the servo if it would make you feel more comfortable. Or, you could just do flutter testing on a trim tab type system with power removed from the servo (which you'll need to do anyway, if you add any kind of trim tab to the aileron). It's not likely that you would have any luck mounting the trim tab on the wing tip itself (it's been tried by others; there just isn't enough aerodynamic authority unless the tab is almost as big as the aileron). BTW, a neighbor has a homebuilt that has the same autopilot design as my Thorp, but with the addition of a homebuilt magnetic heading source that allowed the autopilot to actually follow a magnetic heading. Compared to the 'oldtimers', we young 50-60 year-old 'experimenters' are just delivery guys for Ikea. :-) Charlie ________________________________________________________________________________
Date: Jan 14, 2011
>ust isn't enough aerodynamic authority unless the tab is almost as >big as the aileron). > >BTW, a neighbor has a homebuilt that has the same autopilot design >as my Thorp, but with the addition of a homebuilt magnetic heading >source that allowed the autopilot to actually follow a magnetic heading. > >Compared to the 'oldtimers', we young 50-60 year-old 'experimenters' >are just delivery guys for Ikea. :-) Charlie, The system you've described sounds like a DIY system designed conceived by a NASA engineer named Doug Garner. I think it was written up in several issues of Sport Aviation circa 1980. Doug developed a home brew rate sensor based on a small speaker huffing on a venturi to produce a steady stream of air between two de-bulbed lamps used as hot-wire anemometers. He also crafted a flux gate compass for magnetic heading hold. Very clever stuff. I met him briefly at OSH about 1986 or so. The autopilot brains was an 8-bit micro-controller. Today we have solid state rate sensors, silicon magnetometers and GPS serial data to effect VERY precise course hold. Of course, the R/C servos have become still more robust and many feature all metal gear trains. I think I've got copies of his articles buried somewhere. I ought to scan them and put them up on the website as historical data. Bob . . . ________________________________________________________________________________
Date: Jan 14, 2011
On 1/14/2011 4:59 PM, Robert L. Nuckolls, III wrote: > > > >> ust isn't enough aerodynamic authority unless the tab is almost as >> big as the aileron). >> >> BTW, a neighbor has a homebuilt that has the same autopilot design as >> my Thorp, but with the addition of a homebuilt magnetic heading >> source that allowed the autopilot to actually follow a magnetic heading. >> >> Compared to the 'oldtimers', we young 50-60 year-old 'experimenters' >> are just delivery guys for Ikea. :-) > > Charlie, > > The system you've described sounds like a DIY system designed > conceived by a NASA engineer named Doug Garner. I think it was > written up in several issues of Sport Aviation circa 1980. > Doug developed a home brew rate sensor based on a small speaker > huffing on a venturi to produce a steady stream of air between > two de-bulbed lamps used as hot-wire anemometers. He also crafted > a flux gate compass for magnetic heading hold. Very clever stuff. > I met him briefly at OSH about 1986 or so. The autopilot brains > was an 8-bit micro-controller. > > Today we have solid state rate sensors, silicon magnetometers > and GPS serial data to effect VERY precise course hold. Of > course, the R/C servos have become still more robust and many > feature all metal gear trains. I think I've got copies of > his articles buried somewhere. I ought to scan them and > put them up on the website as historical data. > > > Bob . . . I think you're right about the source; I have read the articles. I have the schematics & wiring diagrams somewhere; if I stumble upon them I'll scan & forward. I even have the 'heart' of the hardware somewhere; I'll try to send some pics of that, too. IIRC, the rate sensor was built into a coffee can. :-) I'm certainly not advocating a return that technology; I was just trying to point out how little real experimenting we really do these days. Charlie ________________________________________________________________________________
Date: Jan 14, 2011
Z13/8 ar Howard, I'm surprised your anticipated load is going to be so high. My IFR RV-8A only uses about 32A with everything on. I use the 60A Plane Power Alt and it is loafing. If you are recommending LEDs to be used for landing lights, I'd suggest builders consider HID instead. I have both on my airplane and, as much as I like them, the LEDs are not yet up to the task of landing light. They are great for radiance, but do not illuminate well. The power and optics are just not quite sufficient. I use the LEDs for taxi and recognition lights. They wig wag much better than HIDs and light up using a square wave which makes them visible and discernable at long distance. The HIDs, although expensive, are excellent for landing illumination. Regards, Stan Sutterfield _www.rv-8a.net_ (http://www.rv-8a.net) Thanks I'll add those items. I'm going to go without the cooling fan initially and see how the avionics fare. I might have to add later. For those planning IFR w/ similar equipment....it looks like the LC-60 amp alternator is a must due to the high current consumption of the pitot heat, navigation, strobe, and landing lights. For anyone who has not yet purchased equipment you'll want to buy LED style, and maybe the Gretz Aero pitot heat system to keep the amps down. I'm going to switch to the B&C LC-60 amp alternator and plan for a max continuous electrical load of 80-85% or 48 to 51 amps. Howard -------- Howard Plevyak GlaStar ________________________________________________________________________________
Date: Jan 14, 2011
Subject: Transponder antenna signal
Bob - or other antenna gurus, I want to streamline my transponder antenna. I have the short (3 inch) stub antenna with the ball on the tip. To streamline it I'm going to make an epoxy resin fiberglass covering that will look like a blade antenna. Please confirm for me that streamlining with a fiberglass covering will not affect signal performance. Thanks, Stan Sutterfield ________________________________________________________________________________
Date: Jan 14, 2011
Stan, Can't answer your question but check out this site for a streamlined antenna. www.deltapopaviation.com From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Speedy11(at)aol.com Sent: Friday, January 14, 2011 8:41 PM Subject: AeroElectric-List: Transponder antenna signal Bob - or other antenna gurus, I want to streamline my transponder antenna. I have the short (3 inch) stub antenna with the ball on the tip. To streamline it I'm going to make an epoxy resin fiberglass covering that will look like a blade antenna. Please confirm for me that streamlining with a fiberglass covering will not affect signal performance. Thanks, Stan Sutterfield ________________________________________________________________________________
Subject: Re: Transponder antenna signal
Date: Jan 15, 2011
Stan, << streamline my transponder antenna... streamlining with a fiberglass covering will not affect signal performance. >> As long as you don't use any paint/ingredients containing metal or carbon there shouldn't be any observable difference. Tom Kuffel ________________________________________________________________________________
Date: Jan 15, 2011
Subject: Squaring shear in KC area
A good friend of mine is trimming down his shop. He's got a really nice squaring shear for sale <http://kansascity.craigslist.org/tls/2158343501.html>http://kansascity.craigslist.org/tls/2158343501.html Obviously, this is not something you ship by UPS. But readers within practical driving distance might be interested. Bob . . . no not archive ________________________________________________________________________________
Date: Jan 15, 2011
Thanks to Bob and others for the replies and suggestions. > It's not likely that you would have any luck mounting the trim > tab on the wing tip itself (it's been tried by others; there just isn't > enough aerodynamic authority unless the tab is almost as big as the > aileron). That is exactly what I had planned to do. Thanks for the warning, Charlie. Sometimes I get obsessed with details and neglect to stand back and look at the feasibility of the whole project. I do not want to add a trim tab to the ailerons because I am afraid of causing flutter. So I had intended to mount a trim tab on the wing tip. Since it has been tried by others without success, I could be wasting my time and money if installing wing tip trim tabs. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327107#327107 ________________________________________________________________________________
Date: Jan 15, 2011
> > It's not likely that you would have any luck mounting the trim > > tab on the wing tip itself (it's been tried by others; there just isn't > > enough aerodynamic authority unless the tab is almost as big as the > > aileron). > >That is exactly what I had planned to do. Thanks for the warning, >Charlie. Sometimes I get obsessed with details and neglect to stand >back and look at the feasibility of the whole project. I do not >want to add a trim tab to the ailerons because I am afraid of >causing flutter. So I had intended to mount a trim tab on the wing >tip. Since it has been tried by others without success, I could be >wasting my time and money if installing wing tip trim tabs. It's an easy experiment to explore. Use some speed tape to stick a fixed sheet metal tab on the trailing edge of the tip. Size it to some value you think might be tolerable from the perspective of appearance and practical implementation. Go fly and see how much trim authority you're having to offset in the stick. Keep in mind that you're wanting to trim out small operational variations in roll trim. This isn't an autopilot design project with a goal of exerting the same authority in roll as the pilot, you're wanting to offset relatively small trim offsets due to loading and fuel distribution. The Zodiac avoids aileron flutter issues by trimming with a separate mini-aileron. Emacs! Other pictures of aileron trim tabs seem to illustrate relatively small mechanisms Emacs! Emacs! Also consider an actuator driven spring cartridge rigged to the aileron controls under the floor boards. This technique has been used by many designers with success. You can develop your own design goals. Bob . . . ________________________________________________________________________________
Date: Jan 15, 2011
I have been successfully using model aircraft servos for several years, first on a Kitfox 2 and more recently on a Model 5. Initially started with rudder only trim, graduating to full three axis trim control using a microcontroller Motorola MC68HC08 to operate the servos. This was expanded several years ago to include GPS route tracking. More recently altitude hold. This autopilot design is still being developed, and refined. For trim only the R/C servo will tracks the potentiometer position, and is constantly powered to maintain its position. Satisfactory R/C servo controllers for trim only can cost less than $20, servos $40. and a power supply for 5-6 volts at 5 amps < $20. I have found these servos to be quite durable with one servo on my Kitfox 2 (Hitec 805BB) lasting over 500 hrs flying, a similar servo on the 5 now has 150 + hours. I could go on forever, but will wait to see if there is further interest. Meanwhile I suspect there will be a few questions. Jim On 2011-01-14, at 7:56 AM, user9253 wrote: > > I want to install electric aileron trim. I could buy a Ray Allen servo and control its speed with PWM. I was wondering if there are any other options that might be lighter weight or smaller. Has anyone had experience with linear actuators or model airplane R/C servos? Do the RC model servos hold their position when power is removed? The ideal 12vdc servo would be slow moving and would be operated by a switch without electronic controls. It should also have built-in limit switches and a position feedback pot. Maybe the Ray Allen is the best. > Thanks, Joe > > -------- > Joe Gores > ________________________________________________________________________________
Subject: RCT3 crimper et al
Date: Jan 15, 2011
Cheers, I wrote this week at an inability to understand how the subject crimper worked, and probably caused some heads to nod, including Bob's, over what must have seemed a simple problem. It was. The way I used the crimper, it was impossible to insert a pin/socket and wire in order to crimp same. Thanks to those who replied, I discovered the fault: Inside a threaded cap at the back, is a formed spring-loaded spindle. One end of it is solid, the other is hollowed out. I found mine reversed, turned it 'round and voila, the pin/socket slides into the hollow just far enough to crimp it solidly to the wire. No wonder I couldn't slide the target into place....... As Major Hoople says, "Egad!". Apologies to all who mused over my stupidity. Best for 2011, Ferg ________________________________________________________________________________
Date: Jan 15, 2011
Subject: Trim device
http://www.sabermfg.com/trim.htm Pretty sure this is the one I purchased without the indicator. Simple stepper motor and a switch and some wire. Small flap that does not over control the aileron at full deflection And http://www.aeroresourcesinc.com/store_/index.php/cPath/77 Paul ________________________________________________________________________________
Subject: Mounting a d-sub connector to a bulkhead as a pass-through
Date: Jan 15, 2011
I will be using a d-sub connector on my removable rear Infinity Stick Grip. One of the connectors will be secured to the covering I will be fabricating to close off the floor opening around the aft stick. My problem is that I am not familiar with a means of securing one connector in this panel and yet still be able to screw in the other half of the connection onto the panel mounted connector. Any suggestions and sources for the means of accomplishing this task? Thanks, Jack -------- Jack Clark RV-8A Fuselage http://www.mykitlog.com/jackclark/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327130#327130 ________________________________________________________________________________
Date: Jan 15, 2011
Jim Corner wrote: > > I have been successfully using model aircraft servos for several years ... [snip] > I could go on forever, but will wait to see if there is further interest. Meanwhile I suspect there will be a few questions. Jim, I'm happy to see someone (else) proving the naysayers wrong. This has been a pet project of mine for almost as long as you and I've taken a similar approach using a different controller (ATmega8). I'm even using a $18 servo to change the position of one of my landing lights for taxi. Question, please: where have you found for a source of bellcrank, clevis, threaded rod and other hardware? I'd like to find some 10-32 but all the model airplane stuff I've found is pretty wimpy (4-40 or 6-32 at best). On my landing light the RC stuff is OK but I'd like an "aviation grade" mechanical coupling for the elevator and aileron trim on my RV. -- Joe Independence, OR http://www.mail2600.com/position http://www.mail2600.com/cgi-bin/webcam.cgi ________________________________________________________________________________
Date: Jan 15, 2011
> It's an easy experiment to explore. Use some speed tape > to stick a fixed sheet metal tab on the trailing edge > of the tip. Size it to some value you think might be > tolerable from the perspective of appearance and practical > implementation. Go fly and see how much trim authority > you're having to offset in the stick. That is a very good idea, Bob. I should have thought of that because I did the same thing on the rudder. The runway is covered with snow, so I will have to wait before experimenting in the air. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327143#327143 ________________________________________________________________________________
Date: Jan 15, 2011
Hi Stan << streamline my transponder antenna... streamlining with a fiberglass > covering will not affect signal performance. >> I am using an AAE transponder antenna in my plastic Europa. AAE says if you are installing it on the side of a plastic aeroplane that you must stand the antenna off with a supplied piece of Balsa. You could contact them and ask why. I thinkI did and it was perhaps electrostatic build up? Ron Parigoris ________________________________________________________________________________
Date: Jan 15, 2011
I like that. You've been watching: http://www.youtube.com/watch?v=ftq8jTQ8ANE (excuse me if I'm being circular here) Bill "need something to do until it warms up" Watson On 1/14/2011 11:41 PM, Speedy11(at)aol.com wrote: > Bob - or other antenna gurus, > I want to streamline my transponder antenna. I have the short (3 > inch) stub antenna with the ball on the tip. To streamline it I'm > going to make an epoxy resin fiberglass covering that will look like a > blade antenna. > Please confirm for me that streamlining with a fiberglass covering > will not affect signal performance. > Thanks, > Stan Sutterfield > ________________________________________________________________________________
Date: Jan 15, 2011
Joe I'm using hardware designed for giant scale RC. The bolts are 8-32 and the push rods are 6 gauge rods. Your speeds are higher than mine, but remember that you require less deflection for the same result. Also we are trimming aerodynamically balanced surfaces and the air load on the trim tabs are a lot less than most expect. I have attached a photo of my flaperon servo installation. It is very effective and can induce a very high roll rate. Jim > > I'm happy to see someone (else) proving the naysayers wrong. This has been a pet project of mine for almost as long as you and I've taken a similar approach using a different controller (ATmega8). I'm even using a $18 servo to change the position of one of my landing lights for taxi. > > Question, please: where have you found for a source of bellcrank, clevis, threaded rod and other hardware? I'd like to find some 10-32 but all the model airplane stuff I've found is pretty wimpy (4-40 or 6-32 at best). On my landing light the RC stuff is OK but I'd like an "aviation grade" mechanical coupling for the elevator and aileron trim on my RV. > > -- > Joe > Independence, OR ________________________________________________________________________________
Date: Jan 15, 2011
I am interested in the possibilities of using an R/C servo for the pitch trim on my TigerCub. Any and ALL details very welcomed! Thanks for any info. Bob Taylor TigerCub N657RT -------------------------------------------------- From: "Jim Corner" <jcorner(at)shaw.ca> Sent: Saturday, January 15, 2011 1:08 PM Subject: Re: AeroElectric-List: model airplane servo > > I have been successfully using model aircraft servos for several years, > first on a Kitfox 2 and more recently on a Model 5. > > Initially started with rudder only trim, graduating to full three axis > trim control using a microcontroller Motorola MC68HC08 to operate the > servos. > > This was expanded several years ago to include GPS route tracking. More > recently altitude hold. This autopilot design is still being developed, > and refined. > > For trim only the R/C servo will tracks the potentiometer position, and > is constantly powered to maintain its position. > > Satisfactory R/C servo controllers for trim only can cost less than $20, > servos $40. and a power supply for 5-6 volts at 5 amps < $20. > > I have found these servos to be quite durable with one servo on my Kitfox > 2 (Hitec 805BB) lasting over 500 hrs flying, a similar servo on the 5 now > has 150 + hours. > > I could go on forever, but will wait to see if there is further interest. > Meanwhile I suspect there will be a few questions. > > Jim > > > On 2011-01-14, at 7:56 AM, user9253 wrote: > >> >> >> I want to install electric aileron trim. I could buy a Ray Allen servo >> and control its speed with PWM. I was wondering if there are any other >> options that might be lighter weight or smaller. Has anyone had >> experience with linear actuators or model airplane R/C servos? Do the RC >> model servos hold their position when power is removed? The ideal 12vdc >> servo would be slow moving and would be operated by a switch without >> electronic controls. It should also have built-in limit switches and a >> position feedback pot. Maybe the Ray Allen is the best. >> Thanks, Joe >> >> -------- >> Joe Gores >> > > > ________________________________________________________________________________
Date: Jan 15, 2011
Look at the model helicopter suppliers too. Like this one: http://www.ronlund.com/mm5/merchant.mvc?Screen=PROD&Store_Code=RHPS&Product_Code=RCHCR&Category_Code <http://www.ronlund.com/mm5/merchant.mvc?Screen=PROD&Store_Code=RHPS&Product_Code=RCHCR&Category_Code=>It's a hollow carbon fiber shaft with titanium threads and an aluminum ferrule. For stiffness, weight, and strength, it might be something to consider. On Sat, Jan 15, 2011 at 8:55 PM, Robert Taylor wrote: > Flydad57(at)neo.rr.com> > > I am interested in the possibilities of using an R/C servo for the pitch > trim on my TigerCub. Any and ALL details very welcomed! > > Thanks for any info. > > Bob Taylor > TigerCub N657RT > > -------------------------------------------------- > From: "Jim Corner" <jcorner(at)shaw.ca> > Sent: Saturday, January 15, 2011 1:08 PM > To: > Subject: Re: AeroElectric-List: model airplane servo > >> >> I have been successfully using model aircraft servos for several years, >> first on a Kitfox 2 and more recently on a Model 5. >> >> Initially started with rudder only trim, graduating to full three axis >> trim control using a microcontroller Motorola MC68HC08 to operate the >> servos. >> >> This was expanded several years ago to include GPS route tracking. More >> recently altitude hold. This autopilot design is still being developed, and >> refined. >> >> For trim only the R/C servo will tracks the potentiometer position, and >> is constantly powered to maintain its position. >> >> Satisfactory R/C servo controllers for trim only can cost less than $20, >> servos $40. and a power supply for 5-6 volts at 5 amps < $20. >> >> I have found these servos to be quite durable with one servo on my Kitfox >> 2 (Hitec 805BB) lasting over 500 hrs flying, a similar servo on the 5 now >> has 150 + hours. >> >> >> I could go on forever, but will wait to see if there is further interest. >> Meanwhile I suspect there will be a few questions. >> >> Jim >> >> >> >> >> >> On 2011-01-14, at 7:56 AM, user9253 wrote: >> >>> fran4sew(at)banyanol.com> >>> >>> I want to install electric aileron trim. I could buy a Ray Allen servo >>> and control its speed with PWM. I was wondering if there are any other >>> options that might be lighter weight or smaller. Has anyone had experience >>> with linear actuators or model airplane R/C servos? Do the RC model servos >>> hold their position when power is removed? The ideal 12vdc servo would be >>> slow moving and would be operated by a switch without electronic controls. >>> It should also have built-in limit switches and a position feedback pot. >>> Maybe the Ray Allen is the best. >>> Thanks, Joe >>> >>> -------- >>> Joe Gores >>> >>> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Jan 15, 2011
I built just such a radome for my XPDR antenna and it worked fine, until a bit of oil collected in it from the belly - that was a different story. I think it attenuated the signal quite a bit, but I later found I was having other issues with my XPDR tray coax fitting that overshadowed any oil contamination problem inside the radome. I must say: while it was a fun exercise in making molds and casting a fiberglass part, it did nothing noticeable for my top speed. Bill B RV-6A On Sat, Jan 15, 2011 at 7:30 PM, Bill Watson wrote: > I like that. > > You've been watching: > http://www.youtube.com/watch?v=ftq8jTQ8ANE > (excuse me if I'm being circular here) > > Bill "need something to do until it warms up" Watson > > > On 1/14/2011 11:41 PM, Speedy11(at)aol.com wrote: > > Bob - or other antenna gurus, > I want to streamline my transponder antenna. I have the short (3 inch) > stub antenna with the ball on the tip. To streamline it I'm going to make > an epoxy resin fiberglass covering that will look like a blade antenna. > Please confirm for me that streamlining with a fiberglass covering will not > affect signal performance. > Thanks, > Stan Sutterfield > > > * > > * > > ________________________________________________________________________________
Date: Jan 15, 2011
Stan, One of my local chapter members found a shark-fin style unit on ebay for less than $20 shipped. He stripped the paint off and found it to be made of what appeared to be mostly solid aluminum, so he repainted it and installed it. You might be able to find something similar, unless you are wanting to enjoy the sport of building up some foam or balsa and coating it with light fiberglass cloth and such. On Sat, Jan 15, 2011 at 10:05 PM, Bill Boyd wrote: > I built just such a radome for my XPDR antenna and it worked fine, until a > bit of oil collected in it from the belly - that was a different story. I > think it attenuated the signal quite a bit, but I later found I was having > other issues with my XPDR tray coax fitting that overshadowed any oil > contamination problem inside the radome. > > I must say: while it was a fun exercise in making molds and casting a > fiberglass part, it did nothing noticeable for my top speed. > > Bill B > RV-6A > > On Sat, Jan 15, 2011 at 7:30 PM, Bill Watson wrote: > >> I like that. >> >> You've been watching: >> http://www.youtube.com/watch?v=ftq8jTQ8ANE >> (excuse me if I'm being circular here) >> >> Bill "need something to do until it warms up" Watson >> >> >> On 1/14/2011 11:41 PM, Speedy11(at)aol.com wrote: >> >> Bob - or other antenna gurus, >> I want to streamline my transponder antenna. I have the short (3 inch) >> stub antenna with the ball on the tip. To streamline it I'm going to make >> an epoxy resin fiberglass covering that will look like a blade antenna. >> Please confirm for me that streamlining with a fiberglass covering will >> not affect signal performance. >> Thanks, >> Stan Sutterfield >> >> >> * >> >> ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> * >> >> > * > > * > > ________________________________________________________________________________
Date: Jan 15, 2011
Good Evening Bill B. I always install the little blade antennas because I have broken so many of the little "wire with a ball" style either when washing the belly or just rolling around under the airplane on a creeper. Happy Skies, Old Bob LL22 Stearman N3977A In a message dated 1/15/2011 9:10:23 P.M. Central Standard Time, sportav8r(at)gmail.com writes: I built just such a radome for my XPDR antenna and it worked fine, until a bit of oil collected in it from the belly - that was a different story. I think it attenuated the signal quite a bit, but I later found I was having other issues with my XPDR tray coax fitting that overshadowed any oil contamination problem inside the radome. I must say: while it was a fun exercise in making molds and casting a fiberglass part, it did nothing noticeable for my top speed. Bill B RV-6A ________________________________________________________________________________
Date: Jan 15, 2011
Subject: Re: Mounting a d-sub connector to a bulkhead as a
pass-through At 01:52 PM 1/15/2011, you wrote: > >I will be using a d-sub connector on my removable rear Infinity >Stick Grip. One of the connectors will be secured to the covering I >will be fabricating to close off the floor opening around the aft >stick. My problem is that I am not familiar with a means of >securing one connector in this panel and yet still be able to screw >in the other half of the connection onto the panel mounted >connector. Any suggestions and sources for the means of >accomplishing this task? Take a look at the back of your computer. The stationary connector is fitted with jackscrew sockets Emacs! while the connector on the pendant cable is fitted with jack screws of some variety. We had some discussion here on the List a few months back about the convenience of 4-40 capscrews with recessed hex sockets. But this catalog page shows several of many alternatives. http://www.keyelco.com/pdfs/M55p74.pdf Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Go ahead, make my day . . . > < show me where I'm wrong. > ================================ ________________________________________________________________________________
Date: Jan 15, 2011
>On Sat, Jan 15, 2011 at 8:55 PM, Robert Taylor ><Flydad57(at)neo.rr.com> wrote: ><Flydad57(at)neo.rr.com> > >I am interested in the possibilities of using an R/C servo for the >pitch trim on my TigerCub. Any and ALL details very welcomed! I know that there are many success stories that cite the use of R/C servos for moving things on airplanes. Just be aware that there ARE failure modes in these little guys that can cause a fast and total "hard over" motion to the mechanical limits of the system. I would not be able to get these products blessed for use on TC aircraft without some very convincing analysis and safeguards against such behaviors. Having your trim system drive to a limit in a few hundred milliseconds can really put some excitement into an otherwise boring day. Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Go ahead, make my day . . . > < show me where I'm wrong. > ================================ ________________________________________________________________________________
Date: Jan 16, 2011
Thanks, Bob. That's some of the input that I am looking for. I would also like to hear about some successful installations and how they are controlled. Bob Taylor TigerCub N657RT From: Robert L. Nuckolls, III Sent: Sunday, January 16, 2011 12:11 AM Subject: Re: AeroElectric-List: model airplane servo On Sat, Jan 15, 2011 at 8:55 PM, Robert Taylor wrote: I am interested in the possibilities of using an R/C servo for the pitch trim on my TigerCub. Any and ALL details very welcomed! I know that there are many success stories that cite the use of R/C servos for moving things on airplanes. Just be aware that there ARE failure modes in these little guys that can cause a fast and total "hard over" motion to the mechanical limits of the system. I would not be able to get these products blessed for use on TC aircraft without some very convincing analysis and safeguards against such behaviors. Having your trim system drive to a limit in a few hundred milliseconds can really put some excitement into an otherwise boring day. Bob . . . //// (o o) ===========o00o=(_)=o00o======== = < Go ahead, make my day . . . > < show me where I'm wrong. > ======= ________________________________________________________________________________
Subject: Re: Mounting a d-sub connector to a bulkhead as a pass-through
Date: Jan 16, 2011
Jack; I saw a system kinda sorta like you describe, What this person did was to cut the stick very close to the bottom of the stick just above the mount removing the stick made it much easier to get in the back seat on a tandem. The stick control cables hung below the stick when the stick had been removed. At this point the pilot simply disconnects the two stick parts. For reconnecting, the pilot would pull the excess cable with the connector on it out of the stick top and bottom parts. The cables were then connected via the method normally used to reconnect circular connectors and set the upper stick part on top of the bottom stick part, which was all held together by a quick connect clip passing between the upper and lower part of the stick, For those of you still following this, the answer to the question you are ready to ask is the pilot welded a short collar on the bottom part of the stick part with a hole through the collar and correspondingly to the bottom end of the upper part of the stick. With the quick disconnect connector and the quick release pin (from Summit Racing), she was able to reconnect the rear stick with ailerons, flaps, radio, trim, and radio freq select. Worked great. The two cable connectors, when connected with their corresponding wires, were all tucked away inside the stick completely out of the way. HTH and is a little more clear than mud. -- Keith ________________________________________________________________________________
From: "David & Elaine Lamphere" <dalamphere(at)comcast.net>
Date: Jan 16, 2011
What about using what I remember as retractable landing gear servos? They were slow and powerful and perhaps could be controlled by a 3-pos toggle switch. Please understand, I got out of RC 14yrs ago, so the current technology may be quite different. I think these servos were not proportional, just on/off, supply power polarity reversing. Just momentarily move the toggle several times until you have the desired trim effect. A caveat: I don't have one, nor any plans to use one so I have no stock in this, just contributing to the discussion. Dave ________________________________________________________________________________
Subject: shielded 5 wire for trim servo
Date: Jan 16, 2011
I'm wiring my elevator trim servo and wondering what to do with the shield on the 5 wire cable that came with my kit. The Ray Allen instructions say n othing about it. Should I ground it at one or both ends=2C or just ignore i t? Thanks. Jesse ________________________________________________________________________________
Date: Jan 16, 2011
I agree with Bob's comments on this. I get around this problem by early testing to make sure that the "hard over failure" is easily controlled by manual override. Since we are controlling a almost balanced airplane it does not take much servo deflection to correct minor trim or to control heading and altitude. With this approach the "failure event" is similar but no more dramatic than hitting that invisible air pocket. Pitch trim for landing for example is a separate system. I have encountered that sustained "hard over" electrical failure of a servo but have found that when the power was switched off the servo will re-center itself reducing the in-flight control loads, something that does not happen with other trim methods. Jim On 2011-01-15, at 10:41 PM, Robert Taylor wrote: > Thanks, Bob. That's some of the input that I am looking for. I would also like to hear about some successful installations and how they are controlled. > > Bob Taylor > TigerCub N657RT > > >> On Sat, Jan 15, 2011 at 8:55 PM, Robert Taylor wrote: >> >> I am interested in the possibilities of using an R/C servo for the pitch trim on my TigerCub. Any and ALL details very welcomed! > > I know that there are many success stories that > cite the use of R/C servos for moving things on > airplanes. Just be aware that there ARE failure > modes in these little guys that can cause a fast > and total "hard over" motion to the mechanical > limits of the system. > > I would not be able to get these products blessed > for use on TC aircraft without some very convincing > analysis and safeguards against such behaviors. > > Having your trim system drive to a limit in > a few hundred milliseconds can really put some > excitement into an otherwise boring day. > > > Bob . . . > //// > (o o) > ===========o00o=(_)=o00o======= == > < Go ahead, make my day . . . > > < show me where I'm wrong. > > ======= > > > > > href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.m atronics.com/Navigator?AeroElectric-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > > > ________________________________________________________________________________
Date: Jan 16, 2011
Great responses from everyone. I appreciate each one. Like Old Bob, I've broken off stub antenna. I'd considered switching to a blade antenna, but didn't want to fit a new antenna. I will reconsider that option, but I'd like to investigate doing my own "antenna fairing." I've been gradually making streamlining changes to my RV-8A and I now claim the status of "world's fastest RV-8A." Maybe a streamlined transponder antenna will help a tiny bit more. My new target is 200 KIAS in level flight at 1000" MSL. I'm already within reach of that goal. Thanks again for your responses. Stan Sutterfield I like that. You've been watching: http://www.youtube.com/watch?v=ftq8jTQ8ANE (excuse me if I'm being circular here) Bill "need something to do until it warms up" Watson On 1/14/2011 11:41 PM, Speedy11(at)aol.com wrote: > Bob - or other antenna gurus, > I want to streamline my transponder antenna. I have the short (3 > inch) stub antenna with the ball on the tip. To streamline it I'm > going to make an epoxy resin fiberglass covering that will look like a > blade antenna. > Please confirm for me that streamlining with a fiberglass covering > will not affect signal performance. > Thanks, > Stan Sutterfield ________________________________________________________________________________
Date: Jan 16, 2011
200 KIAS at 1000 " (inches) - WOW John ----- Original Message ----- From: Speedy11(at)aol.com To: aeroelectric-list(at)matronics.com Sent: Sunday, January 16, 2011 9:57 PM Subject: AeroElectric-List: Re: Transponder antenna signal Great responses from everyone. I appreciate each one. Like Old Bob, I've broken off stub antenna. I'd considered switching to a blade antenna, but didn't want to fit a new antenna. I will reconsider that option, but I'd like to investigate doing my own "antenna fairing." I've been gradually making streamlining changes to my RV-8A and I now claim the status of "world's fastest RV-8A." Maybe a streamlined transponder antenna will help a tiny bit more. My new target is 200 KIAS in level flight at 1000" MSL. I'm already within reach of that goal. Thanks again for your responses. Stan Sutterfield I like that. You've been watching: http://www.youtube.com/watch?v=ftq8jTQ8ANE (excuse me if I'm being circular here) Bill "need something to do until it warms up" Watson On 1/14/2011 11:41 PM, Speedy11(at)aol.com wrote: > Bob - or other antenna gurus, > I want to streamline my transponder antenna. I have the short (3 > inch) stub antenna with the ball on the tip. To streamline it I'm > going to make an epoxy resin fiberglass covering that will look like a > blade antenna. > Please confirm for me that streamlining with a fiberglass covering > will not affect signal performance. > Thanks, > Stan Sutterfield ________________________________________________________________________________
Date: Jan 17, 2011
I figure that a transponder antenna will have about the same effect on an aircraft that flies less then 150kt/hr as a good wax job. As the speed goes up the fairing of everything becomes more noticeable. Pardon me for stating the obvious. As for the look of a faired antenna it is, to me, much nicer to look at. If you consider fairing the antenna yourself then I guess you should also consider the cost of the resins, fillers and paint or finish. Then factor in all the time to cast a reasonable fairing and the extra ounces that it will add to your plane. If your plane is less than 200kt I wouldn't bother... If it's better than 200 kt I'd be on the lookout for a faired antenna.. Put the bug in to all local avionics shops you'll be surprised what you can come up with. Noel From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of JOHN TIPTON Sent: January 16, 2011 7:55 PM Subject: Re: AeroElectric-List: Re: Transponder antenna signal 200 KIAS at 1000 " (inches) - WOW John ----- Original Message ----- From: Speedy11(at)aol.com Sent: Sunday, January 16, 2011 9:57 PM Subject: AeroElectric-List: Re: Transponder antenna signal Great responses from everyone. I appreciate each one. Like Old Bob, I've broken off stub antenna. I'd considered switching to a blade antenna, but didn't want to fit a new antenna. I will reconsider that option, but I'd like to investigate doing my own "antenna fairing." I've been gradually making streamlining changes to my RV-8A and I now claim the status of "world's fastest RV-8A." Maybe a streamlined transponder antenna will help a tiny bit more. My new target is 200 KIAS in level flight at 1000" MSL. I'm already within reach of that goal. Thanks again for your responses. Stan Sutterfield I like that. You've been watching: http://www.youtube.com/watch?v=ftq8jTQ8ANE (excuse me if I'm being circular here) Bill "need something to do until it warms up" Watson On 1/14/2011 11:41 PM, Speedy11(at)aol.com wrote: > Bob - or other antenna gurus, > I want to streamline my transponder antenna. I have the short (3 > inch) stub antenna with the ball on the tip. To streamline it I'm > going to make an epoxy resin fiberglass covering that will look like a > blade antenna. > Please confirm for me that streamlining with a fiberglass covering > will not affect signal performance. > Thanks, > Stan Sutterfield href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matro nics.com/Navigator?AeroElectric-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Jan 17, 2011
Subject: Re: shielded 5 wire for trim servo
At 11:28 AM 1/16/2011, you wrote: >I'm wiring my elevator trim servo and wondering what to do with the >shield on the 5 wire cable that came with my kit. The Ray Allen >instructions say nothing about it. Should I ground it at one or both >ends, or just ignore it? >Thanks. >Jesse Your choice. There is no value for having these wires shielded so what you do with the shield is optional and of no electrical significance. Bob . . . ________________________________________________________________________________
Date: Jan 17, 2011
At 12:48 PM 1/16/2011, you wrote: >I agree with Bob's comments on this. I get around this problem by >early testing to make sure that the "hard over failure" is easily >controlled by manual override. Good for you. Nothing can replace the value of doing failure modes effects analysis and/or demonstrations on a motor driven flight control surface. See: http://www.aeroelectric.com/articles/Trim_System_Failures.pdf Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Go ahead, make my day . . . > < show me where I'm wrong. > ================================= ________________________________________________________________________________
Date: Jan 17, 2011
That is exactly what I was looking for to make the connection. Thank you for your help and to all other responders! -------- Jack Clark RV-8A Fuselage http://www.mykitlog.com/jackclark/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327290#327290 ________________________________________________________________________________
Date: Jan 17, 2011
Stan, Interesting post "world's fastest RV-8A", indeed. How about sharing some of the tricks you used to achieve this goal. You maybe onto something here, starting a new trend in "experimenting". Marty RV-6A N826ME From: Speedy11(at)aol.com Subject: AeroElectric-List: Re: Transponder antenna signal Great responses from everyone. I appreciate each one. Like Old Bob, I've broken off stub antenna. I'd considered switching to a blade antenna, but didn't want to fit a new antenna. I will reconsider that option, but I'd like to investigate doing my own "antenna fairing." I've been gradually making streamlining changes to my RV-8A and I now claim the status of "world's fastest RV-8A." Maybe a streamlined transponder antenna will help a tiny bit more. My new target is 200 KIAS in level flight at 1000" MSL. I'm already within reach of that goal. Thanks again for your responses. Stan Sutterfield ________________________________________________________________________________
Date: Jan 17, 2011
From: Etienne Phillips <etienne.phillips(at)gmail.com>
Hi Bob Thinking aloud here... Wouldn't the noisy current of a brushed DC motor emit a heap of RF over long wire runs (especially if the trim servo is locally grounded)? Would that not be the reason for the shielding on the cable - not to stop the servo from being interfered with, but to reduce the emitted noise? Thanks Etienne On 17 January 2011 16:40, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > nuckolls.bob(at)aeroelectric.com> > > > At 11:28 AM 1/16/2011, you wrote: > >> I'm wiring my elevator trim servo and wondering what to do with the shield >> on the 5 wire cable that came with my kit. The Ray Allen instructions say >> nothing about it. Should I ground it at one or both ends, or just ignore it? >> Thanks. >> Jesse >> > > Your choice. There is no value for having these > wires shielded so what you do with the shield > is optional and of no electrical significance. > > Bob . . . > > ________________________________________________________________________________
Date: Jan 17, 2011
I'd add that, in my application, I have already done the hard over failure analysis. My TigerCub is safely controllable with the trim tab at either limit. Bob Taylor TigerCub N657RT -------------------------------------------------- From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Sent: Monday, January 17, 2011 9:41 AM Subject: Re: AeroElectric-List: model airplane servo > > > At 12:48 PM 1/16/2011, you wrote: >>I agree with Bob's comments on this. I get around this problem by early >>testing to make sure that the "hard over failure" is easily controlled by >>manual override. > > Good for you. > > Nothing can replace the value of doing failure modes > effects analysis and/or demonstrations on a motor driven > flight control surface. See: > > http://www.aeroelectric.com/articles/Trim_System_Failures.pdf > > > Bob . . . > //// > (o o) > ===========o00o=(_)=o00o======== > < Go ahead, make my day . . . > > < show me where I'm wrong. > > ================================ > > > ________________________________________________________________________________
Date: Jan 17, 2011
Thanks Bob=2C In digging around on the Vans forum I saw mention that the Ray Allen trim i ndicator could go bonkers while transmitting on a radio if the wire wasn't shielded. I'm going to attempt to use the trim indicator on my Dynon screen so hopefully it won't be a problem=2C but I soldered a 22 gauge wire onto the shield at the servo end so I can run it into the fuselage just in case. > Date: Mon=2C 17 Jan 2011 08:40:15 -0600 > To: aeroelectric-list(at)matronics.com > From: nuckolls.bob(at)aeroelectric.com > Subject: Re: AeroElectric-List: shielded 5 wire for trim servo > kolls.bob(at)aeroelectric.com> > > At 11:28 AM 1/16/2011=2C you wrote: > >I'm wiring my elevator trim servo and wondering what to do with the > >shield on the 5 wire cable that came with my kit. The Ray Allen > >instructions say nothing about it. Should I ground it at one or both > >ends=2C or just ignore it? > >Thanks. > >Jesse > > Your choice. There is no value for having these > wires shielded so what you do with the shield > is optional and of no electrical significance. > > Bob . . . > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Subject: Re: model airplane servo
Date: Jan 17, 2011
It is amazing how many neat devices the "Nonman-carrying" quadrant of the flight universe comes up with. For those looking for more powerful servos and other neat devices, Google: Robot Zone or Servo City. Here's a great example: "the Magic Box" http://www.circuitcellar.com/psoc2002/winners/297.pdf It's hard not to want one of these. Complete info is back up a level. I sell two distinctly different servo controllers: the EGPNMSC that drives Futaba and other servos, and the TSCMR, that turns the MAC/RAC "sort-of-servo" into a real servo. (Some glitch on my website is being worked on... so you might not be able to see them now). The Ray Allen trim box is really a nice piece of hardware. For those who want to improve it a tiny bit, read the attached. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327300#327300 Attachments: http://forums.matronics.com//files/tscmr_installation_manual_152.pdf http://forums.matronics.com//files/egpnmsc_209.pdf http://forums.matronics.com//files/rac_trim_and_trim_indicator_schematics_756.pdf ________________________________________________________________________________
Date: Jan 17, 2011
At 09:53 AM 1/17/2011, you wrote: >Thanks Bob, >In digging around on the Vans forum I saw mention that the Ray Allen >trim indicator could go bonkers while transmitting on a radio if the >wire wasn't shielded. I'm going to attempt to use the trim indicator >on my Dynon screen so hopefully it won't be a problem, but I >soldered a 22 gauge wire onto the shield at the servo end so I can >run it into the fuselage just in case. If that's the case, then the problem is in the indicator, not the wiring. DO-160 qualification protocols for accessories in TC aircraft do not generally allow a latent design deficiency to be masked by user installed shielding, filters, relocation, etc. If you're wiring the actuator's potentiometer leads to the inputs of some indicator OTHER than a Ray-Allen product, then you've got a whole new ball game. If you DO need the shielding, it should be connected to ground as close as practical to the victim. I.e. the indicator. Take the pigtail to a ground pin in the connector. Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Go ahead, make my day . . . > < show me where I'm wrong. > ================================ ________________________________________________________________________________
Date: Jan 17, 2011
At 09:42 AM 1/17/2011, you wrote: >Hi Bob > >Thinking aloud here... > >Wouldn't the noisy current of a brushed DC motor emit a heap of RF >over long wire runs (especially if the trim servo is locally grounded)? Given that the actuator is a PM motor device with both lead wires floating (to achieve CW/CCW operations) then there's no 'local grounding' opportunities to be considered. So all 5 wires from the actuator should be brought forward with the motor pair splitting out to the trim command controls and 3 position-pot wires going to the selected indicator. Brushed DC motors DO emit noise. But it's a matter of degree combined with the manner in which the noise gets out of the system (radiated, conducted or both). In this case, that tiny little motor (draws about 100 mA as I recall) is a mouse roaring in a cacophony of other noises. Further, the noise will come out conducted on the twisted pair . . . these cannot radiate nor can they become victims of radiation with respect to the motor noise. >Would that not be the reason for the shielding on the cable - not to >stop the servo from being interfered with, but to reduce the emitted noise? The actuator itself contains a motor and a pot. These are not potential victims. The motor does generate a modicum of insignificant noise. The pot generates no noise. If the Ray-Allen indicators have proven susceptible to RF, it will be shown to have root cause in a common mode conduction of RF into the indicator circuitry. This MIGHT be improved upon by shielding, the common wisdom seems to indicate this is the case. But it's like carrying a fire extinguisher to offset the potential effects of known fuel leaks. Better to fix the 'leak' inside the indicator. Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Go ahead, make my day . . . > < show me where I'm wrong. > ================================ ________________________________________________________________________________
Subject: shielding through DB9s
Date: Jan 17, 2011
I am keen to provide a shield through one end of a 4-wire cable to the other (it's grounded only at one end and that will be preserved). The cable must be cut to accommodate feed-through needs, so am using DB9s.* Thing is, if I use metal-sprayed bodies, can I feed the wires through the shield (as for a single wire) and then solder the shield to a wire which is wound 'round one of the assembly bolts (#4x40)? This I hoped would continue the shield through both DB9 bodies (bolt-body-body-bolt) and onto the next section of shielded cable. What say you? Fair winds, Ferg Europa Classic mono 914 *The cable joins the Dynon D-100 EFIS to its attitude sensor eight feet away and might be sensitive to nearby RF ________________________________________________________________________________
From: Bob McCallum <robert.mccallum2(at)sympatico.ca>
Date: Jan 17, 2011
Ferg=3B Simply carry the ground through one of the pins in the DB9. Don't worry abo ut the cover. The unshielded portion within the cover is so tiny as to be i nsignificant. Bob McC From: VE3LVO(at)rac.ca Subject: AeroElectric-List: shielding through DB9s Date: Mon=2C 17 Jan 2011 14:56:36 -0500 I am keen to provide a shield through one end of a 4-wire cable to the othe r (it=92s grounded only at one end and that will be preserved). The cable m ust be cut to accommodate feed-through needs=2C so am using DB9s.* Thing is=2C if I use metal-sprayed bodies=2C can I feed the wires t hrough the shield (as for a single wire) and then solder the shield to a wi re which is wound =91round one of the assembly bolts (#4x40)? This I hoped would continue the shield through both DB9 bodies (bolt-body-body-bolt) and onto the next section of shielded cable. What say you? Fair winds=2C Ferg Europa Classic mono 914 *The cable joins the Dynon D-100 EFIS to its attitude sensor eight feet awa y and might be sensitive to nearby RF ________________________________________________________________________________
Date: Jan 17, 2011
Subject: Re: shielding through DB9s
And use a solder sleeve to attach a pig-tail to the shield, and then the pig tail to the pin. Steinair SS-3, under heatshrink. Peter On 17/01/2011 21:20, Bob McCallum wrote: > Ferg; > > Simply carry the ground through one of the pins in the DB9. Don't > worry about the cover. The unshielded portion within the cover is so > tiny as to be insignificant. > > Bob McC > > ------------------------------------------------------------------------ > From: VE3LVO(at)rac.ca > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: shielding through DB9s > Date: Mon, 17 Jan 2011 14:56:36 -0500 > > I am keen to providea shield through one end of a 4-wire cableto the > other (its grounded only at one end and that will be preserved). The > cable must be cut toaccommodatefeed-through needs, so am using DB9s.* > > Thing is, if I use metal-sprayed bodies, can Ifeed the wires through > the shield (as for a single wire) and then solder the shield to a > wirewhich is woundround one of the assembly bolts (#4x40)? This I > hoped would continue the shield through both DB9 > bodies(bolt-body-body-bolt)and onto the next section of shielded cable. > > What say you? > > Fair winds, > > Ferg > > Europa Classicmono 914 > > *The cable joins the Dynon D-100 EFIS to its attitude > sensor eight feet away and might be sensitive to nearby RF > > * > > -List" target=_blank>http://www.matronics.com/Navigator?AeroElectric-List > ttp://forums.matronics.com > =_blank>http://www.matronics.com/contribution > > * > * > > > * ________________________________________________________________________________
Date: Jan 17, 2011
Subject: Sandia txp/encoder combo any good?
Does anyone have any thoughts on the new Sandia Aerospace transponder with built in encoder? I like the small size and integrated encoder, and the unit is attractively priced (for a new unit). Is there any general problems associated with encoders that make it advisable to keep the encoder separate, so it can be replaced without replacing the transponder? Thanks for your thoughts. Skip Simpson ________________________________________________________________________________
Date: Jan 17, 2011
Subject: Re: Sandia txp/encoder combo any good?
Well, its only mode A/C, and a Trig TT-21 is $1870 from Spruce (less elsewhere?) and provides Mode S. Apart from that looks good from the web page. Will be interesting to see how it performs in the field. http://www.sandia.aero/?q=node/66 Peter On 17/01/2011 21:56, CardinalNSB(at)aol.com wrote: > Does anyone have any thoughts on the new Sandia Aerospace transponder > with built in encoder? > I like the small size and integrated encoder, and the unit is > attractively priced (for a new unit). > Is there any general problems associated with encoders that make it > advisable to keep the encoder separate, so it can be replaced without > replacing the transponder? > Thanks for your thoughts. Skip Simpson > * > > > * ________________________________________________________________________________
Date: Jan 17, 2011
At 03:20 PM 1/17/2011, you wrote: >Ferg; > >Simply carry the ground through one of the pins in the DB9. Don't >worry about the cover. The unshielded portion within the cover is so >tiny as to be insignificant. > Right on. I might add that there's no great transgression for 'exposing' what might seem to be significant lengths of the 'protected' wiring. Shielding breaks electro-static coupling of noise that is potentially significant if the victim wire shares a wire bundle with a anatagnonist wire for considerable distance. In a Beechjet were a pressure transducer wire might be 40' long and share a wire bundle with lots of butt-@#$@ noises, then the shielding has a high probability of standing off a noise problem. In our itty-bitty airplanes, wire runs are so short that the probability of introducing noise issues for lack of shielding is very low. I'll bet that 99.9% of all shielded wires in small aircraft could be replaced with unshielded, twisted pairs with no observable adverse effects. So make your shield transition at the connector look nice even if it exposes what appears to be a lot of wire. See: http://www.aeroelectric.com/articles/pigtail/pigtail.html Solder sleeves are cool . . . and I do use them on occasion but 'shade tree' shield terminations are just as functional. Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Go ahead, make my day . . . > < show me where I'm wrong. > ================================ ________________________________________________________________________________
Date: Jan 17, 2011
Good Afternoon Skip, The only comment I would make has to do with Sandia, the company. Everything I have bought from them has been well built and has worked flawlessly. I think the new product will likely be great. Happy Skies, Old Bob In a message dated 1/17/2011 4:00:50 P.M. Central Standard Time, CardinalNSB(at)aol.com writes: Does anyone have any thoughts on the new Sandia Aerospace transponder with built in encoder? I like the small size and integrated encoder, and the unit is attractively priced (for a new unit). Is there any general problems associated with encoders that make it advisable to keep the encoder separate, so it can be replaced without replacing the transponder? Thanks for your thoughts. Skip Simpson (http://www.matronics.com/Navigator?AeroElectric-List) (http://www.matronics.com/contribution) ________________________________________________________________________________
Subject: re: Shielding through DB9s
Date: Jan 17, 2011
Wow! What swift returns! Many thanks for the suggestions on the above topic. To Bob N: Sorry I missed the discussion on "articles/pigtail" and it of course answered my question superbly. It also saves me a lot of fiddly-fooly wirework. I am appreciative once more for the good offices on Matt Dralle's net and Bob's Connections. Thanks too to Bob Mcc. way down the QEW, 50 cliks from here.....! Cheers Ferg ________________________________________________________________________________
Date: Jan 18, 2011
Subject: Odyssey PC680 Battery load tests
Hi, I used the West Mountain Radio CBA to test some batteries that I had hoped to use in my aircraft. Unfortunately the PC680 batteries have been laying around for about 6 years, and had became quite discharged. I have used the Battery Tender to charge them a few times, and have re-run the load test. The results of two tests (with a recharge in between) are below, along with a test of a Panasonic LC-XD1217P (12v, 17 Ah) of a similar form factor, and with identical treatment. https://docs.google.com/viewer?a=v&pid=explorer&chrome=true&srcid=0B5D8Jl0C8SZbNDQ0N2FiNzItYjA0Yy00MmQ5LTk0NjUtOWVkZTMwNzlmMTU3&hl=en https://docs.google.com/viewer?a=v&pid=explorer&chrome=true&srcid=0B5D8Jl0C8SZbYmUyMzdhN2ItYjBkOS00MWJkLThlNWUtODUzNjRmMWVmOWE1&hl=en My question is do you think that I can get the Odyssey batteries back to a decent state? Below are the test results in text for those that don't want to download the above PDFs with the pretty graphs. Panasonic2: Description: 6 Lead Acid cells, 17.0 Ah @ 7.50A Started At: 16-Jan-11 2:56 PM Discharge Rate: 7.50 A Starting Voltage: 12.91 V Ending Voltage: 10.50 V Total Time (hh:mm:ss): 01:26:37 Tested Capacity: 10.878 Ah Odyssey: Description: 6 Lead Acid cells, 16.0 Ah @ 7.50A Started At: 16-Jan-11 4:34 PM Discharge Rate: 7.50 A Starting Voltage: 12.56 V Ending Voltage: 10.48 V Total Time (hh:mm:ss): 00:39:53 Tested Capacity: 5.006 Ah Odyssey2: Description: 6 Lead Acid cells, 16.0 Ah @ 7.50A Started At: 18-Jan-11 6:14 PM Discharge Rate: 7.50 A Starting Voltage: 12.80 V Ending Voltage: 10.49 V Total Time (hh:mm:ss): 00:39:37 Tested Capacity: 4.973 Ah I really thought that the Odyssey batteries would hold a charge better than a "standard" Panasonic. Also, the fact that the Panasonic is giving me double the capacity is quite surprising. I have not yet tried my desulfator, but that's my next step. I've only tested one of my two Odyssey batteries, going to test the other "soon". Thanks, Mickey -- Mickey Coggins ________________________________________________________________________________
Date: Jan 18, 2011
Subject: Re: Odyssey PC680 Battery load tests
Hello Mickey, I would try the desulfator once as well. I had a lead acid battery from a car where one cell seemed to be shorten. I did it leave on the desulfator combined with a battery tender for 2 years and had to use it for my car as that battery was to much depleted (cabin light on for 4 days with minus temp). That Battery showed full recovery for usage in my car even that it is only 2/3 of the capacity of the original battery. Give it a try, just a few cents of power you spend on it and let it there for at least a month. Werner ________________________________________________________________________________
Date: Jan 18, 2011
I just saw a picture posted re: oil separator that showed a transponder antenna mounted inside the lower cowling. Looked interesting but I'm not sure which group it was. john On 1/16/2011 1:57 PM, Speedy11(at)aol.com wrote: > Great responses from everyone. I appreciate each one. Like Old Bob, > I've broken off stub antenna. I'd considered switching to a blade > antenna, but didn't want to fit a new antenna. I will reconsider that > option, but I'd like to investigate doing my own "antenna fairing." > I've been gradually making streamlining changes to my RV-8A and I now > claim the status of "world's fastest RV-8A." Maybe a streamlined > transponder antenna will help a tiny bit more. My new target is 200 > KIAS in level flight at 1000" MSL. I'm already within reach of that goal. > Thanks again for your responses. > Stan Sutterfield > I like that. > > You've been watching: > http://www.youtube.com/watch?v=ftq8jTQ8ANE > (excuse me if I'm being circular here) > > Bill "need something to do until it warms up" Watson > > On 1/14/2011 11:41 PM, Speedy11(at)aol.com wrote: > > Bob - or other antenna gurus, > > I want to streamline my transponder antenna. I have the short (3 > > inch) stub antenna with the ball on the tip. To streamline it I'm > > going to make an epoxy resin fiberglass covering that will look like a > > blade antenna. > > Please confirm for me that streamlining with a fiberglass covering > > will not affect signal performance. > > Thanks, > > Stan Sutterfield > * > > > * ________________________________________________________________________________
Date: Jan 18, 2011
I used the West Mountain Radio CBA to test some batteries that I had hoped to use in my aircraft. Unfortunately the PC680 batteries have been laying around for about 6 years, and had became quite discharged. What kind of maintenance did you do on the batteries while stored? The Battery Tender and Battery Minders are not intended to be 'chargers' so much as 'maintainers'. When you have 12v batteries on storage, it's a good idea to clip them all together in parallel and have some sort of sophisticated maintainer supporting the lot. I use the Schumacher 1562 or a Battery Tender to support my test batteries. Some are pushing 7 years old with better than 80% of new capacity. I really thought that the Odyssey batteries would hold a charge better than a "standard" Panasonic. Also, the fact that the Panasonic is giving me double the capacity is quite surprising. Were all three stored under the same conditions? I have not yet tried my desulfator, but that's my next step. I've only tested one of my two Odyssey batteries, going to test the other "soon". We'll be interested to hear what you discover. Bob . . . ________________________________________________________________________________
Date: Jan 18, 2011
Subject: Robust transponder antennas
I've been away from the home 'puter for a few days and didn't have access to my big archive of reference documents when the List was discussing transponder antennas. Got home a few hours ago and posted a patent issued in '61 for what is euphemistically called a "scimitar" antenna. http://www.aeroelectric.com/Reference_Docs/Antenna/Scimitar_Patent_3015101.pdf I recalled seeing these all over the empannage belly of the B-52. They looked like tie-down rings except that there was about a half dozen of various sizes. They were associated with the electronic counter-measures system. I was a bomb-nav guy so I didn't get any schooling on them. Years later I was thinking about making a robust transponder antenna using this design philosophy but never got around to it. Others here on the List might be interested in trying it out. Note that where the SWR on the exemplar antenna in the patent goes below 2:1 (4,000 Mhz) the horizontal radiation pattern goes pretty circular. An antenna could be crafted from aluminum or perhaps brass and thick enough to offer the wished-for mechanical robustness. The edges could also be sculptured as necessary for aerodynamically appealing affect. It was interesting to contemplate the development history of this antenna. While based on development work by the Turner guys pre 1958 the patent wasn't issued until 1961. The airplanes I was working on were built in the 1954-58 time frame and already had several sizes installed. Similar antennas on the spacecraft programs were faired with radomes. The antennas on the B-52 were bare and hung right out in the breeze. Anywho, for what it's worth, this might be the basis for a nice DIY antenna project. It would lend itself well to an article featuring fabricate-to-drawings illustrations. Bob . . . ________________________________________________________________________________
Date: Jan 18, 2011
Subject: Buss Bar
I know copper is generally used, but is there any reason NOT to use aluminum to construct a ground buss bar? John Grosse ________________________________________________________________________________
Date: Jan 18, 2011
Subject: Re: Buss Bar
At 09:27 PM 1/18/2011, you wrote: > >I know copper is generally used, but is there any reason NOT to use >aluminum to construct a ground buss bar? How do you plan to attach wires to it? The bus bar designs suggested by AeroElectric Connection and B&C products go to some lengths to reduce threaded fasteners to a minimum. There are none on the panel ground bus . . . and only the fat wires are brought to threaded studs. Bob . . . ________________________________________________________________________________
Date: Jan 18, 2011
Subject: World's Fastest
Marty, I thought that might pique someone's interest. I'm still experimenting so my "tricks" thus far are still unproven. But, like Dave Anders and Bob Axsom, I'm making small gradual changes, some of which have failed, to increase speed and improve efficiency. I am on to something. Before my recent aero changes I could get about 185 KIAS at 1000' MSL. My goal was to reduce drag so as to reach 190 KIAS. Last week I got 193. My new goal is 200. 193 is pretty good for a normally aspirated, stock cowling, 3 blade prop, nose dragger. I have several more ideas for speed improvement and I'll be trying them during the next few months. I have no objection to sharing my ideas so long as guys don't claim them as their own. When I have copied others guy's ideas for building techniques , I gave them credit. My speed improvements can be done by anyone and I have tried them after doing a little bit of aero study and talking to some guys educated in aerodynamics. If guys aren't interested in making their own, I may make them available for sale. We'll see. If anyone would like to see what I'm doing, you can visit my web site at _www.rv-8a.net_ (http://www.rv-8a.net) and look at pages posted since Jan 2010. The primary gain came from my Speedy Cuffs added to the main gear (shown in Jan 2011). The web site will explain and has photos. If you have questions, feel free to write me. Regards, Stan Sutterfield PS - Don't tell the guys in the SARL - I want to beat them this year. : ) Stan, Interesting post "world's fastest RV-8A", indeed. How about sharing some of the tricks you used to achieve this goal. You maybe onto something here, starting a new trend in "experimenting". Marty RV-6A N826ME ________________________________________________________________________________
Subject: Re: Transponder antenna signal
Date: Jan 19, 2011
Hi John (Morgensen) I saw that article, and I checked it out, see below John (RV9a wings - England) ----- Original Message ----- From: Ralph E. Capen Sent: Tuesday, January 18, 2011 12:57 PM Subject: Re: [RV Builders] Andair Air/Oil Separator [2 Attachments] That is a transponder antenna connected to my Monroy ATD200 traffic detector. The antenna connected to the transponder is mounted on the opposite side in a similar fashion. Both work fine. -----Original Message----- From: JOHN TIPTON Sent: Jan 18, 2011 6:18 AM To: recapen(at)earthlink.net Subject: Re: [RV Builders] Andair Air/Oil Separator [2 Attachments] Hi Ralph (off list) As a matter of interest: is that your transponder aerial positioned inside the cowl !!! Best regards John - RV9a (wings) - England ----- Original Message ----- From: Ralph E. Capen To: RV7A(at)yahoogroups.com Sent: Tuesday, January 18, 2011 2:49 AM Subject: Re: [RV Builders] Andair Air/Oil Separator [2 Attachments] [Attachment(s) from Ralph E. Capen included below] Dan, the 125 shot shows detail on the condensate trap. The 399 shot shows both parts mounted on the front lower left corner of the firewall. Only ones that I have of this installation. I can take a couple next time I have the cowl off if it'll help........ Ralph ----- Original Message ----- From: "danbaier" <dbygroups(at)gmail.com> To: Sent: Monday, January 17, 2011 7:52 PM Subject: [RV Builders] Andair Air/Oil Separator > Has anyone installed this? What results? Any pictures of installations? > > Lycs pretty much blow down to about 6qts and then stabilize. I'm hoping > that putting one of these on would help keep 7qts aboard and the extra > quart would help with cooling. My CHTs / EGTs are fine - oil temp is > running about 10-15 higher than I'd really like. > > Thoughts on whether this would work? > > Thanks, > > Dan > > > > ------------------------------------ > > Want more RV news? Sign up for the RV Builder's Hotline. It's free! > http://rvbuildershotline.comYahoo! Groups Links > > > __._,_.___ Attachment(s) from Ralph E. Capen 2 of 2 Photo(s) P5260125.JPGPA230399.JPG Reply to sender | Reply to group | Reply via web post | Start a New Topic Messages in this topic (4) Recent Activity: a.. New Members 1 Visit Your Group Want more RV news? Sign up for the RV Builder's Hotline. It's free! http://rvbuildershotline.com Switch to: Text-Only, Daily Digest =C2- Unsubscribe =C2- Terms of Use. __,_._,___ ________________________________________________________________________________
Date: Jan 19, 2011
Subject: Crimping Big Lugs
I've been crimping a few 4-gauge welding cables with lugs that I also got from the welding supplier. The lugs and cable are both labeled #4, but the lugs are bigger than I would think that they should be. The fit is very loose before crimping, which means that after I crimp them in my whack-a-mole crimper I end up with quite a bit of daylight on either side of the cable strands. While I'm keeping in mind that the term "gas tight" describes the ideal crimp, I'm concerned that these crimps may not be optimal. Has anyone else noticed this problem? Is it a problem, or does it just look odd? These are obviously some pretty important connections that I'd rather not have any trouble out of once they are in service. ________________________________________________________________________________
Date: Jan 19, 2011
Subject: Re: Crimping Big Lugs
When I did mine I couldn't see through them at the end after they were completed. I got my lugs from the same folks that sold me the Whack-A-Mole crimper....B&C if I recall correctly...... -----Original Message----- >From: Jared Yates <email(at)jaredyates.com> >Sent: Jan 19, 2011 8:46 AM >To: aeroelectric-list(at)matronics.com >Subject: AeroElectric-List: Crimping Big Lugs > >I've been crimping a few 4-gauge welding cables with lugs that I also got >from the welding supplier. The lugs and cable are both labeled #4, but the >lugs are bigger than I would think that they should be. The fit is very >loose before crimping, which means that after I crimp them in my >whack-a-mole crimper I end up with quite a bit of daylight on either side of >the cable strands. While I'm keeping in mind that the term "gas tight" >describes the ideal crimp, I'm concerned that these crimps may not be >optimal. Has anyone else noticed this problem? Is it a problem, or does it >just look odd? These are obviously some pretty important connections that >I'd rather not have any trouble out of once they are in service. ________________________________________________________________________________
Date: Jan 19, 2011
A combination of threaded studs for the large wires and riveted fast on connectors for the rest. John Robert L. Nuckolls, III wrote: > > > At 09:27 PM 1/18/2011, you wrote: >> >> >> I know copper is generally used, but is there any reason NOT to use >> aluminum to construct a ground buss bar? > > How do you plan to attach wires to it? > > ________________________________________________________________________________
Date: Jan 19, 2011
The end is closed on these lugs, so I can't see through them, but there is a lot of space in the finished lug. On Jan 19, 2011, at 9:04, "Ralph E. Capen" wrote: > > When I did mine I couldn't see through them at the end after they were completed. > > I got my lugs from the same folks that sold me the Whack-A-Mole crimper....B&C if I recall correctly...... > > > -----Original Message----- >> From: Jared Yates <email(at)jaredyates.com> >> Sent: Jan 19, 2011 8:46 AM >> To: aeroelectric-list(at)matronics.com >> Subject: AeroElectric-List: Crimping Big Lugs >> >> I've been crimping a few 4-gauge welding cables with lugs that I also got >> from the welding supplier. The lugs and cable are both labeled #4, but the >> lugs are bigger than I would think that they should be. The fit is very >> loose before crimping, which means that after I crimp them in my >> whack-a-mole crimper I end up with quite a bit of daylight on either side of >> the cable strands. While I'm keeping in mind that the term "gas tight" >> describes the ideal crimp, I'm concerned that these crimps may not be >> optimal. Has anyone else noticed this problem? Is it a problem, or does it >> just look odd? These are obviously some pretty important connections that >> I'd rather not have any trouble out of once they are in service. > > > > > > > ________________________________________________________________________________
Date: Jan 19, 2011
I would be concerned that I have used the correct size lug for the wire?! -----Original Message----- >From: Jared Yates <email(at)jaredyates.com> >Sent: Jan 19, 2011 9:34 AM >To: "aeroelectric-list(at)matronics.com" >Subject: Re: AeroElectric-List: Crimping Big Lugs > > >The end is closed on these lugs, so I can't see through them, but there is a lot of space in the finished lug. > > >On Jan 19, 2011, at 9:04, "Ralph E. Capen" wrote: > >> >> When I did mine I couldn't see through them at the end after they were completed. >> >> I got my lugs from the same folks that sold me the Whack-A-Mole crimper....B&C if I recall correctly...... >> >> >> -----Original Message----- >>> From: Jared Yates <email(at)jaredyates.com> >>> Sent: Jan 19, 2011 8:46 AM >>> To: aeroelectric-list(at)matronics.com >>> Subject: AeroElectric-List: Crimping Big Lugs >>> >>> I've been crimping a few 4-gauge welding cables with lugs that I also got >>> from the welding supplier. The lugs and cable are both labeled #4, but the >>> lugs are bigger than I would think that they should be. The fit is very >>> loose before crimping, which means that after I crimp them in my >>> whack-a-mole crimper I end up with quite a bit of daylight on either side of >>> the cable strands. While I'm keeping in mind that the term "gas tight" >>> describes the ideal crimp, I'm concerned that these crimps may not be >>> optimal. Has anyone else noticed this problem? Is it a problem, or does it >>> just look odd? These are obviously some pretty important connections that >>> I'd rather not have any trouble out of once they are in service. >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Jan 19, 2011
At 08:46 AM 1/19/2011, you wrote: I've been crimping a few 4-gauge welding cables with lugs that I also got from the welding supplier. The lugs and cable are both labeled #4, but the lugs are bigger than I would think that they should be. The fit is very loose before crimping, which means that after I crimp them in my whack-a-mole crimper I end up with quite a bit of daylight on either side of the cable strands. While I'm keeping in mind that the term "gas tight" describes the ideal crimp, I'm concerned that these crimps may not be optimal. It is a certainty that they are not . . . Has anyone else noticed this problem? Is it a problem, or does it just look odd? These are obviously some pretty important connections that I'd rather not have any trouble out of once they are in service. What you're experiencing first hand is an enduring question as to effectiveness of mating wire size (A) with terminal (B) installed with tool (C) operated by craftsman (D). Companies like AMP, T&B, Daniels, Molex, et. als. have invested $millions$ in designing and fabricating both tools and terminals that minimize risks in the A+B+C+D equation. I produced two articles some years back. Several of which spoke to the idealized end-game for terminal application www.aeroelectric.com/articles/terminal.pdf www.aeroelectric.com/articles/CrimpTools/crimptools.html and another which provided a work-around for making high quality installations of big terminals with virtually zero-risk for loss of electrical integrity with time in service . . . www.aeroelectric.com/articles/big_term.pdf We also discussed a number of articles wherein the authors seemed not to know or care about the simple-ideas that support all the work and receipes for success developed by the companies cited above. http://www.aeroelectric.com/articles/rules/review.html www.aeroelectric.com/articles/Wired_for_Disaster.pdf A couple of years ago, we all read in wonderment about an unplanned arrival with the earth experienced by an RV builder wherein accident investigators noted "wires pulled from their terminals" either as a result of the accident or perhaps they came out before and contributed to the accident. This was an extreme example to be sure. But why treat your terminal applications any differently than you would treat installation of a rivet? The problem is that the quality of an rivet installation is a pretty much a visual inspection thing. What goes on down inside the strands of wire being joined to a terminal is quite another matter. The hedge against building un-inspectable risk into your project is to exploit recipes for success. Any time a particular combination of A+B+C+D come together, they should be evaluated for the suitability of EACH ingredient. It sounds like the terminals (B) you spoke of are not matched to the wire (A) and the suggested tool (C) is perhaps not matched to either. For myself, I don't even own crimping tools that are whacked or jacked together with screws. I have some low cost, tools that are used with attention to detail based on decades of experience. For all the problems you have to wrestle with in fabricating your airplane, terminal application should be the very least of your worries. Clearly a new combination of A+B+C is called for. The good news is that the craftsman (D) has observed, "maybe that doesn't look right". Bob . . . ________________________________________________________________________________
Date: Jan 19, 2011
Subject: Ray Allen position indicator dimmer
I have a couple of ray allen trim servos with the LED position indicators. I'd like to hook the dimmer circuit (white wire) to my panel light switch so when I turn the lights on the indicators dim. This would work fine in a 12 v system. Mine alas is 24. Does anyone know the correct value of a resistor I can put inline to drop the voltage to around 12. I called Ray Allen and they couldn't give me an answer other than the circuit draws "milliamps". I could also use a relay, but would rather go the resistor route. Thanks Dan Ballin Lancair Legacy N386DM ________________________________________________________________________________
Date: Jan 19, 2011
Thanks Bob, I hadn't seen all of those articles yet. The "big terminal" article looks especially helpful. On Wed, Jan 19, 2011 at 8:48 AM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > nuckolls.bob(at)aeroelectric.com> > > > At 08:46 AM 1/19/2011, you wrote: > I've been crimping a few 4-gauge welding cables with lugs that I also got > from the welding supplier. The lugs and cable are both labeled #4, but the > lugs are bigger than I would think that they should be. The fit is very > loose before crimping, which means that after I crimp them in my > whack-a-mole crimper I end up with quite a bit of daylight on either side of > the cable strands. While I'm keeping in mind that the term "gas tight" > describes the ideal crimp, I'm concerned that these crimps may not be > optimal. > > It is a certainty that they are not . . . > > > Has anyone else noticed this problem? Is it a problem, or does it just > look odd? These are obviously some pretty important connections that I'd > rather not have any trouble out of once they are in service. > > What you're experiencing first hand is an enduring > question as to effectiveness of mating wire size (A) > with terminal (B) installed with tool (C) operated > by craftsman (D). > > Companies like AMP, T&B, Daniels, Molex, et. als. > have invested $millions$ in designing and fabricating > both tools and terminals that minimize risks in the > A+B+C+D equation. > > I produced two articles some years back. Several of which > spoke to the idealized end-game for terminal > application > > www.aeroelectric.com/articles/terminal.pdf > > www.aeroelectric.com/articles/CrimpTools/crimptools.html > > and another which provided a work-around for > making high quality installations of big terminals > with virtually zero-risk for loss of electrical > integrity with time in service . . . > > www.aeroelectric.com/articles/big_term.pdf > > We also discussed a number of articles wherein > the authors seemed not to know or care about > the simple-ideas that support all the work > and receipes for success developed by the companies > cited above. > > http://www.aeroelectric.com/articles/rules/review.html > > www.aeroelectric.com/articles/Wired_for_Disaster.pdf > > A couple of years ago, we all read in wonderment > about an unplanned arrival with the earth experienced > by an RV builder wherein accident investigators > noted "wires pulled from their terminals" either > as a result of the accident or perhaps they came > out before and contributed to the accident. This > was an extreme example to be sure. > > But why treat your terminal applications any > differently than you would treat installation > of a rivet? The problem is that the quality > of an rivet installation is a pretty much a > visual inspection thing. What goes on down > inside the strands of wire being joined to > a terminal is quite another matter. > > The hedge against building un-inspectable risk > into your project is to exploit recipes for success. > Any time a particular combination of A+B+C+D > come together, they should be evaluated for > the suitability of EACH ingredient. > > It sounds like the terminals (B) you spoke of are > not matched to the wire (A) and the suggested tool (C) > is perhaps not matched to either. > > For myself, I don't even own crimping tools > that are whacked or jacked together with > screws. I have some low cost, tools that > are used with attention to detail based on > decades of experience. For all the problems > you have to wrestle with in fabricating your > airplane, terminal application should be the > very least of your worries. Clearly a new > combination of A+B+C is called for. > > The good news is that the craftsman (D) has > observed, "maybe that doesn't look right". > > > Bob . . . > > ________________________________________________________________________________
Date: Jan 19, 2011
Sounds to me like your crimp is not right. I would try inserting the wire into the lug and then collapsing the middle of the crimp ring with a cold chisel positioned parallel to the wire in the ring then fold the ring almost in half and give it the what for with your "Wack-a-mole" crimper. If you can see light through the crimp that is a place for corrosion to start leading to inevitable failure. Noel From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Jared Yates Sent: January 19, 2011 10:16 AM Subject: AeroElectric-List: Crimping Big Lugs I've been crimping a few 4-gauge welding cables with lugs that I also got from the welding supplier. The lugs and cable are both labeled #4, but the lugs are bigger than I would think that they should be. The fit is very loose before crimping, which means that after I crimp them in my whack-a-mole crimper I end up with quite a bit of daylight on either side of the cable strands. While I'm keeping in mind that the term "gas tight" describes the ideal crimp, I'm concerned that these crimps may not be optimal. Has anyone else noticed this problem? Is it a problem, or does it just look odd? These are obviously some pretty important connections that I'd rather not have any trouble out of once they are in service. ________________________________________________________________________________
Subject: Buss Bar
Date: Jan 19, 2011
I was also thinking... you may also be able to find a nicopress crimper the right size to close the lugs. Noel -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of John Grosse Sent: January 19, 2011 10:45 AM Subject: Re: AeroElectric-List: Buss Bar A combination of threaded studs for the large wires and riveted fast on connectors for the rest. John Robert L. Nuckolls, III wrote: > > > At 09:27 PM 1/18/2011, you wrote: >> >> >> I know copper is generally used, but is there any reason NOT to use >> aluminum to construct a ground buss bar? > > How do you plan to attach wires to it? > > ________________________________________________________________________________
Date: Jan 19, 2011
Dan=2C I'll take a stab at this=2C but I need the real electronic gurus to verify I was on the right track. Re: the 10 LED bar graphs=2C I have many of them=2C but they are either all red or all yellow. The ones that contain all three colors are just a c ombination of the available LED colors=2C namely red=2C yellow and green. See below f or an 'all one color"=3B http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=330271806124&ssPageNam e=STRK:MEWAX:IT Although this particular bar graph is offered in one color=2C eBay has se veral of the 3-color bar graphs that are exactly what Ray Allen uses. If you scr oll down far enough in this eBay listing=2C you'll see that ALL THREE (green=2C yell ow=2C & red) colors have a MAXIMUM forward voltage of 2.5 volts!! This should be sufficient enough information to use our handy LED formula to calculte the necessary resistor. R= (Vs-Vled)/I Vs=24 volts Vled=2.5 volts I mA Let's solve for R now. 24 volts-2.5 volts= 21.5 volts Therefore=3B 21.5 volts/20mA = R But we need to make sure we convert our mA into Amps first. So 20mA / 10 00 = .02 A Well=2C continue..... 21.5 volts / .02A = 1075 ohms You're going to want at least 1075 ohms to keep from popping LEDs. I fou nd it makes VERY little difference in brightness by making small resistance changes=2C so if it was me=2C I'd be shooting for close to 1200-1500 ohms (probably 1500 ohms). Hope this helps=2C Dan Mike Welch ________________________________________________________________________________
Date: Jan 19, 2011
The end of the lug should be open so you can be sure of proper penetration into the fitting. Noel -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Jared Yates Sent: January 19, 2011 11:04 AM Subject: Re: AeroElectric-List: Crimping Big Lugs The end is closed on these lugs, so I can't see through them, but there is a lot of space in the finished lug. On Jan 19, 2011, at 9:04, "Ralph E. Capen" wrote: > > When I did mine I couldn't see through them at the end after they were completed. > > I got my lugs from the same folks that sold me the Whack-A-Mole crimper....B&C if I recall correctly...... > > > -----Original Message----- >> From: Jared Yates <email(at)jaredyates.com> >> Sent: Jan 19, 2011 8:46 AM >> To: aeroelectric-list(at)matronics.com >> Subject: AeroElectric-List: Crimping Big Lugs >> >> I've been crimping a few 4-gauge welding cables with lugs that I also got >> from the welding supplier. The lugs and cable are both labeled #4, but the >> lugs are bigger than I would think that they should be. The fit is very >> loose before crimping, which means that after I crimp them in my >> whack-a-mole crimper I end up with quite a bit of daylight on either side of >> the cable strands. While I'm keeping in mind that the term "gas tight" >> describes the ideal crimp, I'm concerned that these crimps may not be >> optimal. Has anyone else noticed this problem? Is it a problem, or does it >> just look odd? These are obviously some pretty important connections that >> I'd rather not have any trouble out of once they are in service. > > > > > > > ________________________________________________________________________________
Date: Jan 19, 2011
At 09:15 AM 1/19/2011, you wrote: > >A combination of threaded studs for the large wires and riveted fast >on connectors for the rest. Rivets are designed for use in shear, not in tension. Further, your fast-on lugs are no doubt going to be of a material dissimilar to the bus bar. Suggest you go to a hardware store or hobby shop and get a chunk of sheet brass or better yet copper. Roofing companies often have scraps of copper flashing around from which you can get a suitable piece. Also check around on Ebay. http://tinyurl.com/5sa26kp Here's a nice chunk of .062" sheet that you can shear up for what you need and offer lots of similar chunks to other builders. Use copper pop-rivets to fixture the fast-on lugs and then solder using electronic 63/37 solder. There are ways to do the best we know how to do at minimal time and dollars but bolting up an array of terminals on a piece of aluminum is not the best we know how to do. Bob . . . ________________________________________________________________________________
Date: Jan 19, 2011
These discussions on crimoing big lugs is interesting. My method is to take the parts to the battery store and have them crimp them with their high leverage crimper. They have dies for all sizes and combos of lugs & wires. The same store stocks lugs (open or closed) and the welding cable in several styles. The cost for the crimping was minimal and they always included the heat shrink in black or red. They were glad to help. To find a proper battery store look for the stores that cater to the solar people. Paul ========== ________________________________________________________________________________
Date: Jan 19, 2011
Subject: Re: Ray Allen position indicator dimmer
At 10:18 AM 1/19/2011, you wrote: > >I have a couple of ray allen trim servos with the LED position >indicators. I'd like to hook the dimmer circuit (white wire) to my >panel light switch so when I turn the lights on the indicators dim. >This would work fine in a 12 v system. Mine alas is 24. Does anyone >know the correct value of a resistor I can put inline to drop the >voltage to around 12. I called Ray Allen and they couldn't give me an >answer other than the circuit draws "milliamps". I could also use a >relay, but would rather go the resistor route. Not easy to deduce without more data. I suspect the bar graph array is driven by an LM3914 (or similar) device. www.energies.alba-annuaire.fr/data/lm/LM3914.pdf I presume further that the chip is configured to illuminate only one led at a time as opposed to a variable length bar of multiple leds. The data sheet says that an LM3914 controls LED current INTERNALLY as a function of the current flowing in the reference voltage divider (R1, R2). Adding resistors in series with the leds will wrestle with the brightness control feature built into the chip. So driving your stock indicator directly from the dimming system will similarly wrestle with the chip's built in features. Use an LM7812 or equal to provide 12v power to run the indicator from your 24v system. http://tinyurl.com/2fwxrgm If you want to do real dimming control, you'll need to get inside the indicator and "jeep" the design to add a dimming feature that exploits the chip's built in feature. Bob . . . ________________________________________________________________________________
Date: Jan 19, 2011
Dan=2C everyone else=2C too=2C Regarding those little RYG (red=2C yellow=2C green) 10 LED bargraphs=2C l ike I said=2C I have several! I bought a bunch of them years ago=2C and so far have never really found a good use for any of them. However=2C recently I thought I'd see how they work=2C and if they look good enough (brightness =2C notice-ability=2C clarity=2C etc.) I'd find a good home for several of them . First=2C I thought I'd see how they 'operate'! Can I hook all the anodes in parallel=2C and dispense with a resistor? Do the yellow ones look sharp enough? Can I use a stack of 3-5 high=2C and make them look better? Lots of questions.... First=2C I found out the yellow ones are near useless. At least=2C that' s my opinion. They look more like off-color white=2C somewhat diffused=2C an d not very 'attractive'. IMO! So=2C I thought I'd put one (yellow) on a breadboard=2C hook up ALL 10 an odes to the positive 12V transformer=2C combine all 10 cathodes to the negative=2C and give it a 'go'. Pop!! about 8 of them blew out=2C and a couple of others lo oked dazed and confused!! If I'm not mistaken=2C I may have had a little puff of magi c smoke. In the trash it went!! Okay=2C so far=2C I found out that just because they are all in a tight l ittle rectangular package=2C they're STILL LEDs!!! They will still pop if you don't give each and ever one of them their proper individual resistor. Duh!! But=2C hey=2C I was experimenting !! The next thing I did was look on eBay for someone selling some of these =2C so that i could get a 'data sheet'. That's where I found that link I shared. In a nutshell I found out=3B a) 10 LED bargraphs are still regular LEDs=2C just neatly packed in a line ....and really small b) they burn out---just like the regular kind if you don't allow for prope r resistance c) never buy 20 of them when you don't have a use for one of them d) the yellow ones aren't worth buying....at all!! Mike Welch Learning LEDs 101 ________________________________________________________________________________
Date: Jan 19, 2011
At 11:50 AM 1/19/2011, you wrote: These discussions on crimoing big lugs is interesting. My method is to take the parts to the battery store and have them crimp them with their high leverage crimper. They have dies for all sizes and combos of lugs & wires. The same store stocks lugs (open or closed) and the welding cable in several styles. The cost for the crimping was minimal and they always included the heat shrink in black or red. They were glad to help. To find a proper battery store look for the stores that cater to the solar people. An excellent A + B + C + D = recipe for success! Bob . . . ________________________________________________________________________________
Date: Jan 19, 2011
At 12:12 PM 1/19/2011, you wrote: Dan, everyone else, too, Regarding those little RYG (red, yellow, green) 10 LED bargraphs, like I said, I have several! I bought a bunch of them years ago, and so far have never really found a good use for any of them. However, recently I thought I'd see how they work, and if they look good enough (brightness, notice-ability, clarity, etc.) I'd find a good home for several of them. Excellent experiment. But know that there are leds and then there ARE leds. They come in a constellation of capabilities ranging from the ALARM ON light in your bedside clock (where 6 mCd is enough) up to those used on full color billboards were 15,000 mCd is marginal to the builder's design goals. The market for bar-graph displays is consumer products most of which are used in the living room and have no sun-light viewability issues. Further, the customer seldom has an opinion or desire with respect to color, brightness or other viewability wishes. So be aware that most of what's out there is probably not suited for use on the panel of an airplane. Further, MOST bar graphs of any manufacture will be hard pressed to make it into the cockpit of a TC aircraft. First, I thought I'd see how they 'operate'! Can I hook all the anodes in parallel, and dispense with a resistor? Do the yellow ones look sharp enough? Can I use a stack of 3-5 high, and make them look better? Sure. The LM3914 data sheet I cited earlier says you can stack chips and displays. One of the guys I worked with at Electro-Mech about 30 years ago did a 100 lamp display from a 10x array of chips and displays. 1 percent resolution. Cool! First, I found out the yellow ones are near useless. At least, that's my opinion. They look more like off-color white, somewhat diffused, and not very 'attractive'. IMO! Most "yellow" is not very aircraft oriented except for painting a J-3. What you're really wanting is an amber led. Hard to find in bar graphs assemblies. That's why you mgiht consider building your own. It's just 10 leds in a suitable housing . . . and the LEDs are plentiful, bright and cheap. So, I thought I'd put one (yellow) on a breadboard, hook up ALL 10 anodes to the positive 12V transformer, combine all 10 cathodes to the negative, and give it a 'go'. Pop!! about 8 of them blew out, and a couple of others looked dazed and confused!! If I'm not mistaken, I may have had a little puff of magic smoke. In the trash it went!! Okay, so far, I found out that just because they are all in a tight little rectangular package, they're STILL LEDs!!! They will still pop if you don't give each and ever one of them their proper individual resistor. Duh!! But, hey, I was experimenting!! The next thing I did was look on eBay for someone selling some of these, so that i could get a 'data sheet'. That's where I found that link I shared. Yup! Fortunately it was a low cost experiment . . . LEDs are current driven devices and CANNOT be practically connected to any hard voltage source. EACH led needs to be driven by its own current limited source (unless wired in series). In the case of the LM3914 driver, the current controls are built in. But if you're going to light these fellows up on the bench, pay attention to their requirements. They are generally NOT fragile devices. We had a discussion back in 2004/2005 where I cited an experiment where I'd wired a 30mA rated LED to a wall-wart biased at 5x rated current and plugged it into a little used outlet in my garage. A least a couple years later I terminated the experiment with the LED still illuminating the whole garage at night. In a nutshell I found out; a) 10 LED bargraphs are still regular LEDs, just neatly packed in a line....and really small b) they burn out---just like the regular kind if you don't allow for proper resistance c) never buy 20 of them when you don't have a use for one of them d) the yellow ones aren't worth buying....at all!! Mike Welch Learning LEDs 101 Good for you. Keep us apprised of your discoveries. There are no doubt others who would like to incorporate your own experiences into their bags of tricks. In any case be aware that most led arrays you might put your hands on will want to be up under the glare-shield to be visible while flying in sunlight. Consider also putting them behind a 'smoked' plexiglas . . . while you toss way 1/2 or more of their intensity, the CONTRAST ratio is so much higher that they GAIN sunlight viewability. Bob . . . ________________________________________________________________________________
Date: Jan 19, 2011
> > First, I found out the yellow ones are near useless. At least, that's >my opinion. They look more like off-color white, somewhat diffused, and >not very 'attractive'. IMO! Check out these critters. http://tinyurl.com/4v7clqr Really good intensity numbers for a bar graph assy. Plus DUAL color red/green which means you can light both lamps to get yellow? Bob . . . ________________________________________________________________________________
Date: Jan 19, 2011
Does anyone > know the correct value of a resistor I can put inline to drop the > voltage to around 12. I called Ray Allen and they couldn't give me an > answer other than the circuit draws "milliamps". I could also use a > relay=2C but would rather go the resistor route. > > Thanks > Dan Ballin > Lancair Legacy N386DM Dan=2C In re-reading your question....and my response=2C I think Bob's answer was more what you're looking for. (as usual!!) Since you wouldn't normally need ANY resistor attached to the white wire (for dimming the LEDs)=2C your question is more directed toward dropping 24V to 12V. In that case=2C obviously=2C the LM7812 is the correct way to go. Mike Welch learning from the best=2C all the time. ________________________________________________________________________________
Date: Jan 19, 2011
Hi Bob, All three batteries were just sitting on a shelf - not connected to anything. I didn't do any charging to them during these years, which makes me wonder if perhaps they are now "damaged". The two Odyssey batteries had very low voltages - can't recall exactly, but it was low single digits, and they could not trigger a battery contactor. The Panasonic still had about 12 volts and worked fine. Exact same treatment for all three batteries. You mentioned that the battery tender is not meant as a charger. I also have a "dumb" charger that just dumps in either 2.5 or 5 amps - I forgot to check the voltage it puts out. Do you think that this charger would be better at recovering these batteries than the battery tender? Thanks, Mickey On Tue, Jan 18, 2011 at 23:50, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > nuckolls.bob(at)aeroelectric.com> > > I used the West Mountain Radio CBA to test some batteries that I had hope d > to use in my aircraft. =C3=82 Unfortunately the PC680 batteries have been laying > around for about 6 years, and had became quite discharged. > > What kind of maintenance did you do on the batteries > while stored? The Battery Tender and Battery Minders > are not intended to be 'chargers' so much as 'maintainers'. > When you have 12v batteries on storage, it's a good idea > to clip them all together in parallel and have some > sort of sophisticated maintainer supporting the lot. > I use the Schumacher 1562 or a Battery Tender to > support my test batteries. Some are pushing 7 years > old with better than 80% of new capacity. > > I really thought that the Odyssey batteries would hold a charge better th an > a "standard" Panasonic. =C3=82 Also, the fact that the Panasonic is givin g me > double the capacity is quite surprising. > > Were all three stored under the same conditions? > > =C3=82 I have not yet tried my desulfator, but that's my next step. =C3 =82 I've only > tested one of my two Odyssey batteries, going to test the other "soon". > > We'll be interested to hear what you discover. > > > Bob . . . > > -- Mickey Coggins ________________________________________________________________________________
Date: Jan 19, 2011
before i crimped i put as many 1/2'', 12 or 14 solid copper wire pieces in the lug as i could fit/tap in. then the lug didn't deform so much when crimped and it was TIGHT. bob noffs On Wed, Jan 19, 2011 at 9:37 AM, Noel Loveys wrote: > Sounds to me like your crimp is not right. I would try inserting the > wire into the lug and then collapsing the middle of the crimp ring with a > cold chisel positioned parallel to the wire in the ring then fold the rin g > almost in half and give it the what for with your =93Wack-a-mole=94 crimp er. > > > If you can see light through the crimp that is a place for corrosion to > start leading to inevitable failure. > > > Noel > > > *From:* owner-aeroelectric-list-server(at)matronics.com [mailto: > owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of *Jared Yates > *Sent:* January 19, 2011 10:16 AM > > *To:* aeroelectric-list(at)matronics.com > *Subject:* AeroElectric-List: Crimping Big Lugs > > > I've been crimping a few 4-gauge welding cables with lugs that I also got > from the welding supplier. The lugs and cable are both labeled #4, but t he > lugs are bigger than I would think that they should be. The fit is very > loose before crimping, which means that after I crimp them in my > whack-a-mole crimper I end up with quite a bit of daylight on either side of > the cable strands. While I'm keeping in mind that the term "gas tight" > describes the ideal crimp, I'm concerned that these crimps may not be > optimal. Has anyone else noticed this problem? Is it a problem, or does it > just look odd? These are obviously some pretty important connections tha t > I'd rather not have any trouble out of once they are in service. > > * * > > * * > > ** > > ** > > ** > > ** > > ** > > *http://www.matronics.com/Navigator?AeroElectric-List* > > ** > > ** > > *http://forums.matronics.com* > > ** > > ** > > ** > > ** > > *http://www.matronics.com/contribution* > > ** > > * * > > * > =========== =========== =========== =========== > * > > ________________________________________________________________________________
Date: Jan 19, 2011
At 01:51 PM 1/19/2011, you wrote: >before i crimped i put as many 1/2'', 12 or 14 solid copper wire >pieces in the lug as i could fit/tap in. then the lug didn't deform >so much when crimped and it was TIGHT. But was it GAS TIGHT? Unless you cross-section the joint and get a picture like http://aeroelectric.com/articles/CrimpTools/GL.jpg moisture and oxygen can get in and start working on the joint. It's like copper eating termites. This is particularly important with fat-wires where the corrosion process is aided and abetted by the flow of electrons across the compromised areas of the joint. Just because your finished task is mechanically 'tight' is not 99.9% probability of good outcome. Bob . . . ________________________________________________________________________________
Date: Jan 19, 2011
At 01:40 PM 1/19/2011, you wrote: >Hi Bob, > >All three batteries were just sitting on a shelf - not connected to anything. > I didn't do any charging to them during these >years, which makes me wonder if perhaps they are >now "damaged". The two Odyssey batteries >had very low voltages - can't recall exactly, >but it was low single digits, and they could not >trigger a battery contactor. The Panasonic >still had about 12 volts and worked >fine. Exact same treatment for all three batteries. Interesting. As you've noted, I would have expected Hawker products to be equal to or better than Panasonic. >You mentioned that the battery tender is not meant as a charger. Battery Tenders WILL charge good batteries. With it's limited output (0.8A as I recall) it might take some time. But when the BT is INTENDED to stay hooked up for duration of a storage interval, recharge time is not a significant consideration. When I returned my instrumentation batteries back to the shelf after a job, I just let the battery maintainer top it off . . . never ran one down seriously that I recall but it didn't matter. With weeks to months between tasks, the battery maintainer had all the time in the world. > I also have a "dumb" charger that just dumps > in either 2.5 or 5 amps - I forgot to check the > voltage it puts out. Do you think that this > charger would be better at recovering these batteries than the battery tender? "Recovering" is a term subject to interpretation. In many, many conversations with Skip Koss at Concorde and the gurus at Navy Battery Labs at Crane, IN, I've been made aware of numerous successful recoveries (80% plus of new capacity) for batteries that were accidently (or even deliberately abused). There are numerous qualification specs for aircraft/military batteries that call for total discharge and store at elevated temperature for some period of time. Then conduct some sort of recovery process. Usually starts with connecting a 12v battery to a 20v source until it starts to draw recharge current exceeding 1A or some such. Then charge at 14.6 until current drops below 100 mA. Then discharge and repeat up to two times. If the battery doesn't 'recover' after the third attempt, it's scrap. I don't recall the exact numbers but yes, SOME batteries can be 'recovered' under SOME conditions. YEARS of dead storage . . . it's a long shot. Bob . . . ________________________________________________________________________________
Date: Jan 19, 2011
Subject: Found it . . . how to abuse your battery on purpose
Earlier I wrote: "There are numerous qualification specs for aircraft/military batteries that call for total discharge and store at elevated temperature for some period of time. Then conduct some sort of recovery process." From DO-293 we find this recipe for investigation . . . Emacs! This test is run on a factory-new battery with the total test running 28 days. Bob . . . ________________________________________________________________________________
Subject: Good Quality Wire Terminals?
Date: Jan 19, 2011
Hey Bob, Back in the "old days" we used to use T&B Stak-on (sp?) wire terminals. I think I read somewhere that you recommend Amp terminals. A couple of questions: 1. Are Stak-ons still available? 2. Are the still considered high-quality? 3. Is Amp now the "top dog" in wire terminals? 4. IIRC, Stak-ons were not cheap, are Amp less expensive? 5. Is Thomas & Betts still around, or have they been bought-out several times over? Thanks ________________________________________________________________________________
Date: Jan 19, 2011
Subject: Re: Good Quality Wire Terminals?
At 06:32 PM 1/19/2011, you wrote: Hey Bob, Back in the "old days" we used to use T&B Stak-on (sp?) wire terminals. I think I read somewhere that you recommend Amp terminals. A couple of questions: 1. Are Stak-ons still available? 2. Are the still considered high-quality? 3. Is Amp now the "top dog" in wire terminals? 4. IIRC, Stak-ons were not cheap, are Amp less expensive? 5. Is Thomas & Betts still around, or have they been bought-out several times over? I don't think any one brand is "golden" . . . for fat wires 8 AWG and larger, plain-vanilla bare-foot terminals are fine . . . and I don't think anyone makes a "bad" one. Emacs! Crimp or solder and use double-wall heat shrink to seal the joint and provide support for the smaller gages. For 22-10AWG wire, the AMP PIDG (pre-insulated diamond grip) style is recommended and made by many folks under Mil-T-7928, class II, type 1 and 2. The thing to look for is the 'extra' copper sleeve over the wire grip barrel and under the insulator. Emacs! In other words, avoid the 2-piece terminals (barefoot + insulation only). There's lots of brands to choose from. Be aware that for small quantities of various sizes of the PIDG, http://Digkey.com is a great source of about every size you'll need and they offer small packages of 10 pieces like: http://tinyurl.com/6bvzcuk Bob . . . ________________________________________________________________________________
Date: Jan 19, 2011
Subject: Re: AeroElectric-List Digest: 8 Msgs - 01/18/11
Bob, That could be a very interesting project. Were I not so ignorant about antenna physics, I might try it myself. Stan Sutterfield In a message dated 1/19/2011 3:02:38 A.M. Eastern Standard Time, aeroelectric-list(at)matronics.com writes: Got home a few hours ago and posted a patent issued in '61 for what is euphemistically called a "scimitar" antenna. http://www.aeroelectric.com/Reference_Docs/Antenna/Scimitar_Patent_3015101.p df I recalled seeing these all over the empannage belly of the B-52. They looked like tie-down rings except that there was about a half dozen of various sizes. They were associated with the electronic counter-measures system. I was a bomb-nav guy so I didn't get any schooling on them. Years later I was thinking about making a robust transponder antenna using this design philosophy but never got around to it. Others here on the List might be interested in trying it out. Note that where the SWR on the exemplar antenna in the patent goes below 2:1 (4,000 Mhz) the horizontal radiation pattern goes pretty circular. An antenna could be crafted from aluminum or perhaps brass and thick enough to offer the wished-for mechanical robustness. The edges could also be sculptured as necessary for aerodynamically appealing affect. It was interesting to contemplate the development history of this antenna. While based on development work by the Turner guys pre 1958 the patent wasn't issued until 1961. The airplanes I was working on were built in the 1954-58 time frame and already had several sizes installed. Similar antennas on the spacecraft programs were faired with radomes. The antennas on the B-52 were bare and hung right out in the breeze. Anywho, for what it's worth, this might be the basis for a nice DIY antenna project. It would lend itself well to an article featuring fabricate-to-drawings illustrations. Bob . . ________________________________________________________________________________
Date: Jan 19, 2011
At 08:51 PM 1/19/2011, you wrote: >Bob, >That could be a very interesting project. Were I not so ignorant >about antenna physics, . . . . . . as were we all once. It's a matter of choices as to which of many opportunities will be explored. Methinks you have a great many opportunities to choose from already! I might be able to sift through the data and fabricate a test-article out of copper clad and sneak it into the test lab. Once the dimensions are known, there's probably a bunch of folks on the list that could carve some aluminum. Bob . . . ________________________________________________________________________________
Date: Jan 19, 2011
Subject: Off topic -- Slowing an electric motor
I built a wind tunnel for my son=92s physics project. Works great! The is sue is that I would like to slow the fan down to generate airspeed below the Reynolds number of a dimpled golf ball. Current airspeed is about 58 mph. I need to slow the fan to generate airspeed below 30 mph. The motor is a permanent split capacitor type: http://www.grainger.com/Grainger/DAYTON-Direct-Drive-Blower-Motor-7E658. A ny thoughts on how to slow it down? I've read that slowing it with a dimmer might damage the motor. Thanks, Dan O=92Brien ________________________________________________________________________________
Date: Jan 19, 2011
Subject: Re: Off topic -- Slowing an electric motor
At 11:35 PM 1/19/2011, you wrote: >I built a wind tunnel for my son's physics project.. Works >great! The issue is that I would like to slow the fan down to >generate airspeed below the Reynolds number of a dimpled golf >ball. Current airspeed is about 58 mph. I need to slow the fan to >generate airspeed below 30 mph. The motor is a permanent split >capacitor type: ><http://www.grainger.com/Grainger/DAYTON-Direct-Drive-Blower-Motor-7E658>http://www.grainger.com/Grainger/DAYTON-Direct-Drive-Blower-Motor-7E658. >Any thoughts on how to slow it down? I've read that slowing it with >a dimmer might damage the motor. It is difficult to slow these critters. May I suggest another motor? Ebay has a bunch of DC motors and controllers intended for treadmill service . . . but easily adaptable to other tasks. These controllers usually have some form of tach feedback for very stable speed control. Alternatively, how about putting a damper across the inlet to throttle air flow? Bob . . . ________________________________________________________________________________
Date: Jan 20, 2011
Dan, A PSC type motor can be safely slowed using a properly rated dimmer. These dimmers are specially designed for this type of motor and are NOT just lamp dimmers. Search for Lutron Fan Speed controls and look for the fully variable type, not the 3 or 4 speed preset type used for paddle fans. -Bob Newman ----- Original Message ----- From: Dan O'Brien To: AeroElectric-List(at)matronics.com Sent: Wednesday, January 19, 2011 11:35 PM Subject: ***SPAM*** AeroElectric-List: Off topic -- Slowing an electric motor I built a wind tunnel for my son=92s physics project. Works great! The issue is that I would like to slow the fan down to generate airspeed below the Reynolds number of a dimpled golf ball. Current airspeed is about 58 mph. I need to slow the fan to generate airspeed below 30 mph. The motor is a permanent split capacitor type: http://www.grainger.com/Grainger/DAYTON-Direct-Drive-Blower-Motor-7E658. Any thoughts on how to slow it down? I've read that slowing it with a dimmer might damage the motor. Thanks, Dan O=92Brien ________________________________________________________________________________
Subject: wiring thre phase power
Date: Jan 20, 2011
I am wiring a three phase vertical mill to a static converter (add a phase) from my 220vac single phase source. The motor is a reversible single speed. Does the order of the phases matter? The instruction with the mill are Chinese version of English (useless) and the instructions from the phase converter don't specify which leg goes where. I know this is slightly off topic, but the mill is going in my hangar to build airplane parts! Chris Hukill ________________________________________________________________________________
Date: Jan 20, 2011
Subject: Re: wiring thre phase power
At 09:28 AM 1/20/2011, you wrote: >I am wiring a three phase vertical mill to a static converter (add a >phase) from my 220vac single phase source. The motor is a reversible >single speed. Does the order of the phases matter? The instruction >with the mill are Chinese version of English (useless) and the >instructions from the phase converter don't specify which leg goes where. > >I know this is slightly off topic, but the mill is going in my >hangar to build airplane parts! Not critical for the initial start-up. But if the motor does not run the right direction when you turn it on, reverse any two leads. Bob . . . ________________________________________________________________________________
Date: Jan 20, 2011
Subject: Re: Transponder Antenna
Should you do that, we will be very interested in the dimensions. Stan In a message dated 1/20/2011 3:06:48 A.M. Eastern Standard Time, aeroelectric-list(at)matronics.com writes: I might be able to sift through the data and fabricate a test-article out of copper clad and sneak it into the test lab. Once the dimensions are known, there's probably a bunch of folks on the list that could carve some aluminum. ________________________________________________________________________________
Subject: DIY transponder antenna
Date: Jan 20, 2011
List members=2C Would someone be kind enough to share a link or reference for a guy to make his own transponder antenna? Preferably=2C a site that lists the necessary materials=2C has some pictures=2C etc. I'm real close to the point where I need to think about installing the antenna for the transponder. Thanks=2C Mike Welch ________________________________________________________________________________
Date: Jan 20, 2011
Mike, On E-Bay you can purchase production built transponder antenna's for anywhere from $15 to $20 in AS page 548, pt.no. 11-17995, 2009 cat. they are $18.95..two ups shipments of pcs parts will be at least $12.00 to $18.00 alone. ????? Take care build where it counts. Jim Wickert Vision #159 "Vision Some Will Have IT Some Will Not". Tel 920-467-0219 Cell 920-912-1014 From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Mike Welch Sent: Thursday, January 20, 2011 8:47 PM Subject: AeroElectric-List: DIY transponder antenna List members, Would someone be kind enough to share a link or reference for a guy to make his own transponder antenna? Preferably, a site that lists the necessary materials, has some pictures, etc. I'm real close to the point where I need to think about installing the antenna for the transponder. Thanks, Mike Welch ________________________________________________________________________________
Subject: Re: DIY transponder antenna
Date: Jan 20, 2011
Not much help, the simplest one I saw was made from an AN bolt of the proper length. I bet someone on the list will remember the source. Tim ----- Original Message ----- From: Mike Welch To: aeroelectric-list(at)matronics.com Sent: Thursday, January 20, 2011 7:47 PM Subject: AeroElectric-List: DIY transponder antenna List members, Would someone be kind enough to share a link or reference for a guy to make his own transponder antenna? Preferably, a site that lists the necessary materials, has some pictures, etc. I'm real close to the point where I need to think about installing the antenna for the transponder. Thanks, Mike Welch ________________________________________________________________________________
Date: Jan 20, 2011
Hi Jim=2C I'm very familiar with the eBay ones=2C I just thought I could build my own for a couple of bucks=2C but since you suggested it=2C I might as well go ahead and get one of those off eBay. (I was seriously considering the eBay one=2C anyway) If no one else bids=2C I can buy it for $9.99. Add the $6 for the shippi ng and it comes in at $16 delivered. I have enough projects=2C I think I'll g o the easy route on this one=2C and buy one ready-made. Thanks for the responses=2C guys. Mike Welch From: jimw_btg(at)earthlink.net Subject: RE: AeroElectric-List: DIY transponder antenna Date: Thu=2C 20 Jan 2011 21:50:56 -0600 Mike=2C On E-Bay you can purchase production built transponder antenna=92s for anyw here from $15 to $20 in AS page 548=2C pt.no. 11-17995=2C 2009 cat. they a re $18.95=85.two ups shipments of pcs parts will be at least $12.00 to $18 .00 alone. ????? Take care build where it counts. Jim Wickert Vision #159 =93Vision Some Will Have IT Some Will Not=94. Tel 920-467-0219 Cell 920-912-1014 From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectr ic-list-server(at)matronics.com] On Behalf Of Mike Welch Sent: Thursday=2C January 20=2C 2011 8:47 PM Subject: AeroElectric-List: DIY transponder antenna List members=2C Would someone be kind enough to share a link or reference for a guy to make his own transponder antenna? Preferably=2C a site that lists the necessary materials=2C has some pictures=2C etc. I'm real close to the point where I need to think about installing the antenna for the transponder. Thanks=2C Mike Welch http://www.matronics.com/Navigator?AeroElectric-Listhttp://foru ms.matronics.comhttp://www.matronics.com/contribution ________________________________________________________________________________
Date: Jan 21, 2011
From: Etienne Phillips <etienne.phillips(at)gmail.com>
Hi Mike I built one out of a simple BNC panel mount connector (can't remember if it was male or female), with a piece of coat-hanger wire soldered into the crimping hole, all covered in red heatshrink with a ball of glue at the end to prevent bleeding. It took less than 10 mins to make and cost about $5. Here's an example BNC: http://za.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=6807361 I have an aluminium skin which acts as a nice ground-plane, and I've had no issues whatsoever with the transponder in 2 years of operation, at an airfield that makes you come back and land if your Mode C isn't working! I also know of one person that just strips the coax and lets the protruding inner core of the correct length dangle in the wind with the shield attached to the skin with a lug and bolt. It also works for him, although it terrifies me :-) Hope that helps! Etienne On 21 January 2011 06:27, Mike Welch wrote: > Hi Jim, > > I'm very familiar with the eBay ones, I just thought I could build my > own for a couple of bucks, but since you suggested it, I might as well > go ahead and get one of those off eBay. (I was seriously considering > the eBay one, anyway) > > If no one else bids, I can buy it for $9.99. Add the $6 for the shipping > > and it comes in at $16 delivered. I have enough projects, I think I'll go > the easy > route on this one, and buy one ready-made. > > Thanks for the responses, guys. > > Mike Welch > ________________________________________________________________________________
Subject: Twisted pairs
Date: Jan 21, 2011
Generaly speaking: when are 'twisted pairs' required, and why ? Best regards - John ________________________________________________________________________________
Date: Jan 21, 2011
Subject: Re: Robust transponder antennas
I believe the antenna design in question is an approach to getting a VERY broad range of frequency coverage (10-1) from a single antenna. Note also that it was designed to operate from 30 to 30,000 MHz and the ATC transponder frequency is a single one at 1090 Mhz. You certainly don't need the broad coverage and are almost certainly better off with a single blade or stub designed for 1090 MHz than this. The antennae on the B-52 needed to cover almost DC to light (400 khz to 30 GHz) and this design was very workable. All true. But keep in mind that the roots of this thread went to robustness. All of the antennas offered commercially for transponder/ DME service ran from cheap (single exposed monopole) to rather expensive (aerodynamically faired blade). All active portions of the antenna are insulated from the airframe. The feature of the scimitar antenna that attracted us was the one-piece, all metal design grounded to the airframe. Such antennas could be crafted from two pieces of metal, a base and a blade. Further, they could be rather thick, say 1/8 to 1/4 inches. Such a construction would be MUCH more robust than any commercial offerings. If such an antenna were attached to good structure in the airplane, it might well double as a tie down ring. As I noted before, the patent given to this design was curious. It was applied for years after some of these antennas were already in production. The patent was assigned to government in the first paragraph. Finally, the patent was long on geometry (you can make one "this" way, or make one "that" way) and long on radiation patterns. But not one word as to the reason why one would make one this way, that way, or dimension it for optimum performance at any frequency. Methinks this patent was issued as an afterthought during the cold war when unwashed citizens began to observe such antennas on military aircraft. The patent was more a deterrent to commercial development than to protect new art. This leaves the modern day DIY developer with the task of re-discovering the simple-ideas behind the design. Not difficult and even fun if you have the test equipment. Bob . . . ________________________________________________________________________________
Date: Jan 21, 2011
Subject: Re: Twisted pairs
At 04:43 AM 1/21/2011, you wrote: >Generaly speaking: when are 'twisted pairs' required, and why ? Pairing two conductors effects very tight coupling of the magnetic fields around current carrying conductors. When one conductor is the return path for current flow in the other conductor, the two resulting fields are equal, opposite and in intimate proximity to each other thus canceling each other out. The conductors can be simply parallel to each other (hard to maintain in a wire bundle) or twisted such that they cannot get separated. The corollary accurately suggests that the same pair of wires are just as vulnerable to externally impressed magnetic fields. Suppose you have an itty-bitty signal you want to carry from one place to another. Suppose further that the wires carrying that signal are to be bundled with lots of other wires carrying who knows what . . . and worse yet, SINGLE wires with @#$@-ugly currents flowing in them. They physics of magnetic coupling for pairing outbound and return paths for currents COMBINED with the physics of electro-static coupling (easily broken by shielding) makes the shielded-twisted pair a very robust guard against signal contamination. But as I mentioned earlier this week, fast rise antagonists are rare in airplanes and electro-static coupling is weak. Hence, shielding is not nearly the guardian of signal purity as is pairing (or twisting) of the two conductors. I suggested that the simple twisting of potentially vulnerable or antagonistic current paths was about 99% of everything a system integrator could ask for in terms of interference control. Bob . . . ________________________________________________________________________________
Date: Jan 21, 2011
At 10:24 AM 1/21/2011, you wrote: >My 1949 A35 Bonanza has twisted pairs to the mag compass light. It >is mounted on the windshield. Came out the factory door June 1948. >Noted when replacing the windshield 47 years ago. BBB Great observation! The compass is tasked with aligning itself to Momma Earth's very weak magnetic field. It doesn't take much interference to generate significant error in the compass reading. This is why each compass installation is individually calibrated (swung). Further, the calibration is accomplished with certain conditions noted and placarded (like radios ON). A single illumination conductor up to the compass has significant potential for adding magnetic interference to the compass reading when illumination is on. Further, the magnitude of that error would run up and down with panel light dimmer settings. I've suggested that the builder could also used a shielded wire where the inner conductor is power up and shield was power down from the light. The vast majority of such installations do use a twisted pair to accomplish the same result. Bob . . . ________________________________________________________________________________
Date: Jan 21, 2011
Subject: D-sub crimper
I have a supply of gold-plated D-sub pins and a ratchet crimper -- both pins and crimper were purchased from B&C. I will be using 20 ga and 22 ga wiring in my aircraft, but note that there is no adjustment on the crimper for different wire gauges. I saw in an EAA informational video the use of a D-sub crimper that had an adjustment to adapt it to different wire gauges. Do I need one of these adjustable crimpers? If I use the one from B&C and give each pin a pull test after crimping, is that good enough? Thanks, Paul Kuntz ________________________________________________________________________________
Date: Jan 21, 2011
Subject: Re: Buss Bar
Bob, I'm not quite sure I understand. Are you saying that aluminum is unsuitable for some reason or just that copper or brass is better? I'm not questioning your opinion. I'm just interested in the "why" one works or doesn't work. John Robert L. Nuckolls, III wrote: > At 09:15 AM 1/19/2011, you wrote: >> >> >> A combination of threaded studs for the large wires and riveted fast >> on connectors for the rest. > > Rivets are designed for use in shear, not in tension. > Further, your fast-on lugs are no doubt going to be > of a material dissimilar to the bus bar. > > Suggest you go to a hardware store or hobby shop > and get a chunk of sheet brass or better yet copper. > Roofing companies often have scraps of copper flashing > around from which you can get a suitable piece. Also > check around on Ebay. > > * http://tinyurl.com/5sa26kp* > > Here's a nice chunk of .062" sheet that you can > shear up for what you need and offer lots of similar > chunks to other builders. > > Use copper pop-rivets to fixture the fast-on > lugs and then solder using electronic 63/37 > solder. > > There are ways to do the best we know how to > do at minimal time and dollars but bolting up > an array of terminals on a piece of aluminum is > not the best we know how to do. > > Bob . . . > > * > > > * ________________________________________________________________________________
From: Bob McCallum <robert.mccallum2(at)sympatico.ca>
Subject: Buss Bar
Date: Jan 21, 2011
Different Bob here, but--- What Bob is saying is that first of all it's very difficult to keep aluminum clean enough for a good "gas tight" connection as it oxidizes almost instantly after it is cleaned and aluminium oxide is an excellent insulator. Secondly the assembly method you are proposing using rivets is unsuitable because a rivet is not designed to provide the tension in a joint which you require to get the necessary "gas tight" joint. Rivets are designed to be loaded in shear. Thirdly the dissimilar metals in your connections will almost certainly result in galvanic corrosion within the joints when you join the copper wires/lugs/bolts to the aluminium bars. Where and when aluminium is used for current carrying purposes great pains are taken to alleviate the above issues through the use of special compounds within the joints, such as Burndy's penetrox. (see http://tinyurl.com/4gnx4q7) The above factors are why the attempt to use aluminium wires for household wiring in the 60's was such a failure and resulted in many homes burning down. The difficulties in getting reliable joints are significant whereas using copper or brass there are no such problems. Bob McC > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list- > server(at)matronics.com] On Behalf Of John Grosse > Sent: Friday, January 21, 2011 7:50 PM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Buss Bar > > > Bob, I'm not quite sure I understand. Are you saying that aluminum is > unsuitable for some reason or just that copper or brass is better? I'm > not questioning your opinion. I'm just interested in the "why" one works > or doesn't work. > John > > Robert L. Nuckolls, III wrote: > > At 09:15 AM 1/19/2011, you wrote: > >> > >> > >> A combination of threaded studs for the large wires and riveted fast > >> on connectors for the rest. > > > > Rivets are designed for use in shear, not in tension. > > Further, your fast-on lugs are no doubt going to be > > of a material dissimilar to the bus bar. > > > > Suggest you go to a hardware store or hobby shop > > and get a chunk of sheet brass or better yet copper. > > Roofing companies often have scraps of copper flashing > > around from which you can get a suitable piece. Also > > check around on Ebay. > > > > * http://tinyurl.com/5sa26kp* > > > > Here's a nice chunk of .062" sheet that you can > > shear up for what you need and offer lots of similar > > chunks to other builders. > > > > Use copper pop-rivets to fixture the fast-on > > lugs and then solder using electronic 63/37 > > solder. > > > > There are ways to do the best we know how to > > do at minimal time and dollars but bolting up > > an array of terminals on a piece of aluminum is > > not the best we know how to do. > > > > Bob . . . > > > > * > > > > > > * > > _- > ==================================================== > ====== > _- > ==================================================== > ====== > _- > ==================================================== > ====== > _- > ==================================================== > ====== > > ________________________________________________________________________________
Date: Jan 21, 2011
Subject: Re: D-sub crimper
At 01:57 PM 1/21/2011, you wrote: >I have a supply of gold-plated D-sub pins and a ratchet crimper -- >both pins and crimper were purchased from B&C. I will be using 20 >ga and 22 ga wiring in my aircraft, but note that there is no >adjustment on the crimper for different wire gauges. I saw in an >EAA informational video the use of a D-sub crimper that had an >adjustment to adapt it to different wire gauges. Do I need one of >these adjustable crimpers? If I use the one from B&C and give each >pin a pull test after crimping, is that good enough? The B&C crimper (mfg by Eclipse) has been on the market now for 10 years that I know of. It has performed well with 20 and 22AWG wire in d-sub pins. Bob . . . ________________________________________________________________________________
Date: Jan 21, 2011
Thanks for your always prompt and useful information, Bob. Paul Kuntz On Fri, Jan 21, 2011 at 7:30 PM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > nuckolls.bob(at)aeroelectric.com> > > > At 01:57 PM 1/21/2011, you wrote: > >> I have a supply of gold-plated D-sub pins and a ratchet crimper -- both >> pins and crimper were purchased from B&C. I will be using 20 ga and 22 ga >> wiring in my aircraft, but note that there is no adjustment on the crimper >> for different wire gauges. I saw in an EAA informational video the use of a >> D-sub crimper that had an adjustment to adapt it to different wire gauges. >> Do I need one of these adjustable crimpers? If I use the one from B&C and >> give each pin a pull test after crimping, is that good enough? >> > > The B&C crimper (mfg by Eclipse) has been > on the market now for 10 years that I know > of. It has performed well with 20 and 22AWG > wire in d-sub pins. > > > Bob . . . > > ________________________________________________________________________________
Subject: Belden 9222 triax cable
Date: Jan 22, 2011
Guys=2C I have quite a bit of 50 ohm triax cable. It has the stranded core and h as double shielding. Is this an okay cable to use for a radio and transponder antenna cable? Also=2C does anyone have a drawing how the BNC connector is attached to the cable? Thnaks=2C Mike Welch ________________________________________________________________________________
Date: Jan 22, 2011
Thanks, Bob. I get it. John Bob McCallum wrote: > --> AeroElectric-List message posted by: Bob McCallum > > Different Bob here, but--- > > What Bob is saying is that first of all it's very difficult to keep aluminum > clean enough for a good "gas tight" connection as it oxidizes almost > instantly after it is cleaned and aluminium oxide is an excellent insulator. > Secondly the assembly method you are proposing using rivets is unsuitable > because a rivet is not designed to provide the tension in a joint which you > require to get the necessary "gas tight" joint. Rivets are designed to be > loaded in shear. Thirdly the dissimilar metals in your connections will > almost certainly result in galvanic corrosion within the joints when you > join the copper wires/lugs/bolts to the aluminium bars. Where and when > aluminium is used for current carrying purposes great pains are taken to > alleviate the above issues through the use of special compounds within the > joints, such as Burndy's penetrox. (see http://tinyurl.com/4gnx4q7) The > above factors are why the attempt to use aluminium wires for household > wiring in the 60's was such a failure and resulted in many homes burning > down. The difficulties in getting reliable joints are significant whereas > using copper or brass there are no such problems. > > Bob McC > > > >> ________________________________________________________________________________
Date: Jan 22, 2011
Subject: tool multitasking
OK, I'm cheap. Is there any chance that the B&C RCT-2 crimper will crimp regular &/or hi-density d-sub pins? If so, I can just buy the RCT-2 instead of both it and the RCT-3. Will the RCT-3 crimp the hi-density d-sub pins, or is one of the +$100 tools needed for those? Thanks, Charlie ________________________________________________________________________________
Date: Jan 22, 2011
Subject: Re: Belden 9222 triax cable
At 09:38 AM 1/22/2011, you wrote: >Guys, > > I have quite a bit of 50 ohm triax cable. It has the stranded core and has >double shielding. Is this an okay cable to use for a radio and transponder >antenna cable? > > Also, does anyone have a drawing how the BNC connector is attached to >the cable? The cable is fine. The problem is to insure compatibility between cable and connector. What's the part number and brand of the cable? Bob . . . ________________________________________________________________________________
Date: Jan 22, 2011
Subject: Re: tool multitasking
At 10:48 AM 1/22/2011, you wrote: >OK, I'm cheap. > >Is there any chance that the B&C RCT-2 crimper will crimp regular >&/or hi-density d-sub pins? If so, I can just buy the RCT-2 instead >of both it and the RCT-3. > >Will the RCT-3 crimp the hi-density d-sub pins, or is one of the >+$100 tools needed for those? The RCT-2 is a hex-die tool for COAX connectors. pins, the RCT-3 is a 'quad anvil' crimp tool for MACHINED pins. They're entirely different breeds of cat. I'd be cautious about mixing-matching pins/wires/tools without some careful study of the end product. The smallest hex on a -2 MIGHT properly close on a d-sub pin but I've not investigated it. I have used the -3 tool on hi-density pins and it seemed to produce a good grip. I thought I had cross sectioned the joint under the microscope . . . but I don't find any notes or photos on the experiment. Therefore, I can't offer advice based on any solid information. RCT-1 (PIDG style terminals) http://www.bandc.biz/pidgstylecrimptool.aspx RCT-2 (Coax Connectors - Hex dies) http://www.bandc.biz/bnccoaxconnectorcrimptool.aspx RCT-3 (Quad-Crimp for machined pins) http://www.bandc.biz/d-submachinedpincrimptool.aspx RCT-4 (Butt-cheeks crimp for open barrel formed sheet metal pins) http://www.bandc.biz/openbarrelcrimptoolratcheting.aspx which is an upgraded version of BCT-1 tool I used to offer for open barrel crimps http://www.aeroelectric.com/articles/matenlok/matenlok.html This doesn't mean there are not other recipes for success using these tools for other-than-offered purposes. Just proceed with caution. Bob . . . ________________________________________________________________________________
Date: Jan 22, 2011
Charlie, the RCT-2 type tool I found appears to be for BNC connectors rather than D sub pins. I have one of the RTC-3 type closed barrel crimper and it works fine for Machined crimp pins/sockets - but, never tried it for the fold type crimp pins - or high density pins. SteinAir has the same tool a bit cheaper - there they state not for use with High Density D sub pins. See link http://www.steinair.com/tools.htm their equivalent tool is the SAT-004 for $31.00. The also have the crimper needed for the High Density pins - $$$$$$$$$$$$ Ed From: Charlie England Sent: Saturday, January 22, 2011 10:48 AM Subject: AeroElectric-List: tool multitasking OK, I'm cheap. Is there any chance that the B&C RCT-2 crimper will crimp regular &/or hi-density d-sub pins? If so, I can just buy the RCT-2 instead of both it and the RCT-3. Will the RCT-3 crimp the hi-density d-sub pins, or is one of the +$100 tools needed for those? Thanks, Charlie ________________________________________________________________________________
Date: Jan 22, 2011
I'm cheap also, but I saved several thousand dollars over having this panel =0Abuilt-for me. One of the-panel builders qouted me $8K to build the panel and =0Awire it with power only. That did not include the avionics int erconnects. So I =0Abought the Daniels crimpers with the proper positioners for about $200, and =0Aspent about 3 weeks doing it myself including havin g the panel CNC cut.=0AI believe to crimp the HD pins you need the Daniels crimper (or equivalent) =0ATim Andres=0A=0A=0A=0A__________________________ ______=0AFrom: Charlie England <ceengland(at)bellsouth.net>=0ATo: aeroelectric list =0ASent: Sat, January 22, 2011 7:48: 59 AM=0ASubject: AeroElectric-List: tool multitasking=0A=0AOK, I'm cheap. =0A=0AIs there any chance that the B&C RCT-2 crimper will crimp regular &/o r =0Ahi-density d-sub pins? If so, I can just buy the RCT-2 instead of both it and =0Athe RCT-3.=0A=0AWill the RCT-3 crimp the hi-density d-sub pins, or is one of the +$100 tools =0Aneeded for those?=0A=0AThanks,=0A=0ACharlie ======================== _ == =0A ________________________________________________________________________________
Date: Jan 22, 2011
> > I have quite a bit of 50 ohm triax cable. It has the stranded core and has > >double shielding. Is this an okay cable to use for a radio and transpond er > >antenna cable? > > > > Also=2C does anyone have a drawing how the BNC connector is attached to > >the cable? > > The cable is fine. The problem is to insure > compatibility between cable and connector. > What's the part number and brand of the cable? > > > Bob . . . Hi Bob=2C I should have included the cable information in the email itself=2C rathe r than just the subject line. The triax is Belden 9222 004 RG 58 A/U type 50 ohm tri axial 3075 cable. Here's my confusion=3B this triax is what Glasair Corp supplied to me as their comm antenna cable. At one end=2C the Glasair folks had already soldered a set of 1/2" wide copper tapes....to be glassed vertically in the vertical s tabilizer. Okay=2C I did that! But=2C after the tail is sandwiched together (and no l onger accessible)=2C I THEN find out it is triax!!! Glasair also supplied the 'run of the mill ' "Amphenol 31-2-RFX" BNC connector. But this is a COAX connector!! Glasair says the antenna installation instructions come with the antenna kit=2C but I sure can't find them in my paperwork anywhere! Does anyone have the Glasair comm radio antenna kit instructions (that th ey can email me)?? My dilemma is I have the parts=2C but no instructions. Additionally=2C the silly TRIAX BNC connector is over $25 each!! I think I'd rather stay with the regular coax types=2C and use their design.....if I had it. Thanks=2C Mike Welch ________________________________________________________________________________
Date: Jan 22, 2011
On 1/22/2011 9:21 AM, Robert L. Nuckolls, III wrote: > At 10:48 AM 1/22/2011, you wrote: >> OK, I'm cheap. >> >> Is there any chance that the B&C RCT-2 crimper will crimp regular >> &/or hi-density d-sub pins? If so, I can just buy the RCT-2 instead >> of both it and the RCT-3. >> >> Will the RCT-3 crimp the hi-density d-sub pins, or is one of the >> +$100 tools needed for those? > > The RCT-2 is a hex-die tool for COAX connectors. > pins, the RCT-3 is a 'quad anvil' crimp tool for > MACHINED pins. They're entirely different breeds > of cat. I'd be cautious about mixing-matching > pins/wires/tools without some careful study > of the end product. The smallest hex on a -2 > MIGHT properly close on a d-sub pin but I've not > investigated it. > > I have used the -3 tool on hi-density pins and > it seemed to produce a good grip. I thought > I had cross sectioned the joint under the > microscope . . . but I don't find any notes or > photos on the experiment. Therefore, I can't > offer advice based on any solid information. > > > RCT-1 (PIDG style terminals) > > http://www.bandc.biz/pidgstylecrimptool.aspx > > RCT-2 (Coax Connectors - Hex dies) > > http://www.bandc.biz/bnccoaxconnectorcrimptool.aspx > > RCT-3 (Quad-Crimp for machined pins) > > http://www.bandc.biz/d-submachinedpincrimptool.aspx > > RCT-4 (Butt-cheeks crimp for open barrel formed sheet metal pins) > > http://www.bandc.biz/openbarrelcrimptoolratcheting.aspx > > which is an upgraded version of BCT-1 tool I used to offer > for open barrel crimps > > http://www.aeroelectric.com/articles/matenlok/matenlok.html > > This doesn't mean there are not other recipes > for success using these tools for other-than-offered > purposes. Just proceed with caution. > > Bob . . . > I was hoping that the die for the coax center pin would do double duty for d-sub pins. Oh, well...if the -3 tool will do both std & hi-density d-subs, that does help somewhat. And there's always solder.... :-) Thanks, Charlie ________________________________________________________________________________
Date: Jan 22, 2011
> > I should have included the cable information in the email itself, > rather than just >the subject line. The triax is Belden 9222 004 RG 58 A/U type 50 >ohm triaxial > 3075 cable. My bad. Missed it completely. > > Here's my confusion; this triax is what Glasair Corp supplied to > me as their >comm antenna cable. I am confused too. First, RG-58 series coaxial cables are a legacy product dating back to WWII or perhaps earlier. It was for a single shield coax with polyethylene inner insulation and PVC outer insulation. Best we knew how to do in 1940 and manufactured by the mile since that time. RG58 as a supported specification (meaning updated periodically and recommended for new design) fell off the wagon many years ago. We learned how to do a lot better since then and the spec was canceled years ago. Since that time, folks who should know better have been offering "RG-58 Type" coax cables. At first, they were clones of the WWII vintage product. But after a time, many of the cables being offered as replacements for RG-58 began to morph. Here's your 9222 data: Emacs! Here's the original RG-58 data Emacs! Hmmm . . . Still has a 20AWG center conductor. The center pin will go on fine. Still has a core on the order of .116" so it will probably go down into the connector. This means that both shields will easily slip over the shield grip barrel. Here's the problem. With an OD of .240 versus .193, the shield grip ferrule will not fit over the outer jacket of the coax. You might try installing a standard RG-58 BNC male. Put a piece of 1/4" heatshrink over the coax. See if you can strip the outer jacket and peel pack outer shield to remove the intra-shield insulation. Then see if you can work the shielding over the connector shield-grip with the ferrule in place. If you can, go ahead and crimp it. Then cover the slightly non-standard crimp with the heatshrink. I'm mystified as to why anyone would supply this sort of coax . . . except that obviously, more shielding has to be better than less shielding. The "RG-58" notation probably misled them into believing that they were form/fit/function interchangeable. Not so for obvious reasons. > Additionally, the silly TRIAX BNC connector is over $25 each!! I > think I'd rather stay >with the regular coax types, and use their design.....if I had it. If it's a TRUE triax connector, it will maintain separation of the two shields through the connector and wouldn't even fit the back of your radio. It also occurs to me that an RG-59 BNC connector will be configured for slightly large diameters and could be the elegant answer . . . but those go on with different dies. I've not installed one of those since my video days! My best recommendation is to 'jeep' the RG-58 connector on by treating the two shields as one shield. Bob . . . ________________________________________________________________________________
Date: Jan 22, 2011
Subject: Here's a chance to own the best . . .
While looking for other things on eBay I ran across this listing http://tinyurl.com/4d8nu7r It's for the Tyco-Amp 59170 t-head, red/blue crimp tool. All of my tools are 59250 but when you check the data sheet . . . http://aeroelectric.com/Mfgr_Data/Tools/Tyco-AMP/59250.pdf it appears that everything the 59250 does, the 59170 does also. In fact, it wasn't clear to me what, if any, differences there were between the two model numbers. These tools now retail new for over $1000. Check out the data sheet for yourself but if you've a hankering to own the best, this is one to consider. Bob . . . ________________________________________________________________________________
Date: Jan 22, 2011
>My best recommendation is to 'jeep' the RG-58 connector >on by treating the two shields as one shield. >Bob . . . Hi Bob=2C your suggestion is EXACTLY what they had in mind!!!! I failed to mention in my previous reply that the heatshrink was=2C in fa ct=2C also included in the GlaStar antenna kit=2C although exactly how to install the whole arrangement was still a mistery. So=2C I did some experimenting....... Eventually=2C I kind of figured out what the whole picture was=2C so I tr ied the 'jeep' method earlier today. Actually works out quite nicely=2C too. What I did was=3B remove the outer yellow jacket and the outer shielding about 1 1/4". Next=2C I put on the 2 1/2" piece of heatshrink and shrunk i t up nice and tight. (heatshrink was yellow=2C so everything so far looks like it was planned). At this point=2C the 'necked down' part that's about 1 1/4" long=2C is en capsulated in heatshrink is virtually perfect for the 'run of the mill' BNC connector's I .D.. Once I had the outer layers of jacket and shield removed=2C and replaced them with the heatshrink=2C it was just a matter of installing a typical BNC connector. Seems to look really nice=2C and a quick continuity test showed no stray wires wh ere they shouldn't have been!! Thanks for your help=2C Bob!! Mike Welch /9j/4AAQSkZJRgABAQAAAQABAAD/2wBDAAEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEB AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQH/2wBDAQEBAQEBAQEBAQEBAQEBAQEBAQEB AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQH/wAARCADVAx4DASIA AhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQA AAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3 ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWm p6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/8QAHwEA AwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSEx BhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElK U1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3 uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD+2D9t PXtc8K/scftZ+J/DGtat4b8S+G/2Z/jxr3h7xDoOo3mj65oOuaP8LPFWoaTrWi6tp81vf6Xq2l39 vb32najY3EF5ZXkENzbTRTRI6/56v/DeP7cf/R5v7V3/AIkT8Xv/AJsK/wBBT9vH/kxz9s3/ALNR /aJ/9VD4wr/M9r9Z8OsPh62CzGVahRquOKpKLq0oVGl7K9k5RbSvrZddT+PfpL5lmOBzzhmGCx+N wcKmU4uU44XFV8PGcljElKcaVSClJLRNptLTY+rv+G8f24/+jzf2rv8AxIn4vf8AzYUf8N4/tx/9 Hm/tXf8AiRPxe/8Amwr5Ror9F+oYH/oDwn/hPR/+Q8l9x/NH+sGff9DvN/8Aw5Y3/wCXH1d/w3j+ 3H/0eb+1d/4kT8Xv/mwo/wCG8f24/wDo839q7/xIn4vf/NhXyjRR9QwP/QHhP/Cej/8AIeS+4P8A WDPv+h3m/wD4csb/APLj6u/4bx/bj/6PN/au/wDEifi9/wDNhR/w3j+3H/0eb+1d/wCJE/F7/wCb CvlGij6hgf8AoDwn/hPR/wDkPJfcH+sGff8AQ7zf/wAOWN/+XH1d/wAN4/tx/wDR5v7V3/iRPxe/ +bCj/hvH9uP/AKPN/au/8SJ+L3/zYV8o0UfUMD/0B4T/AMJ6P/yHkvuD/WDPv+h3m/8A4csb/wDL j93/APgpX+1r+1X4E/4YC/4Qf9pr9oPwb/wmX/BM79lbx54v/wCEU+M/xH8O/wDCV+OfEX/Cef8A CQeM/En9keJLP+3PFmufY7T+2PEWqfatY1P7LbfbbyfyItv5nf8ADeP7cf8A0eb+1d/4kT8Xv/mw r6u/4Kq/843v+0Uf7H3/AL0Svyjry8lwWDllmFlLCYaUmqt5SoUm3+/qbtwu9l9y7H1fG+eZ1S4o zOnSzjNKdOP1LlhTzDFwhG+XYRu0Y1lFXbbdlq23uz6u/wCG8f24/wDo839q7/xIn4vf/NhR/wAN 4/tx/wDR5v7V3/iRPxe/+bCvlGivU+oYH/oDwn/hPR/+Q8l9x8p/rBn3/Q7zf/w5Y3/5cfu/+1F+ 1r+1X4f/AOCc3/BLTxxoP7TX7QeieNfiF/w27/wn3i/SPjP8R9N8UeOP+ET+Ovh/SPC3/CX+ILLx JDq3iX/hGtJmm0vw/wD21d3v9jadLLZad9mtpHiP5nf8N4/tx/8AR5v7V3/iRPxe/wDmwr6u/a5/ 5Re/8Ehf+7/f/WhfDVfEn7Mv7N/jj9qz4pQfCP4ear4U0bxJP4X8Y+LUvfGd9q+naINN8EeHb/xN qsDXOh6F4ivxe3Fhp80OnxjTWglu2ijubm0hZ7hPHy6hl9HLcdisRh8JChhMXxJisRWqUKTjRwmC zTM61arJ8jap4fDUJTaV+WnTtFaJH2fE+Y8R4viTJssy7Ms3q4vMsg8OMFgsJh8fiozxWY5pwfwx RoUqcVWjF18ZjsTFczadSvWc5yvKUjrf+G8f24/+jzf2rv8AxIn4vf8AzYUf8N4/tx/9Hm/tXf8A iRPxe/8Amwr13Uf+Cavx00z4C3P7RFx4r+Ez+CrX4AeE/wBo6TS4dd8YN4pbwR4x8U3XhHTNKSyf wJHpJ8VQalaST39i2trpEViySW+uXU5a2Xxv9kz9kD4rftneM/G/gH4P3XhSLxN4G+GHiX4q3Vj4 q1DV9OGuaR4ZvdG0+40Pw8+k6Drv2jxNqV3rljDpVpqS6Xpczeb9r1iy2p5nQquQuGY1FHL+TKY4 uWZS9hStg44CWJji3W/d+6sPLBYlVLXt7Cdr2V/Nng/EGnislwU6nEUcVxF9TeSUHmGK58y/tChg 8Tgvqy+s2l9YoZhgqlPmcbxxNO9m2lP/AMN4/tx/9Hm/tXf+JE/F7/5sKP8AhvH9uP8A6PN/au/8 SJ+L3/zYV9Uah/wSQ+M3hnwPe/Ef4i/Hj9l74WeCtO8NfCTxNe69498WfFiytbaP40aJd674Q0iZ dG+DGuTR61HBZTWer27xrZ21/shtL6/iYzr5z8Qf+CaHx0+HX7PV5+0ZqHjP4M654f0zwV8P/iZq /gTw34t8RXvxN0j4afFTX7/w78PvH2oaFfeDNM0SPw/4nu9PluLKOLxLNrUFnIjahpFncx3drbZP GcORqVKbeX89HHUMtq2w0HGnj8RZ0MJKcaTgq84uM1ByuqbjUlam1I7VkXic6Uayp8S8k8uq5vCP 9o1/bSyyhOVKpjY4f637d0FWhKhGSp/vMRGVCmp1k4Hjv/DeP7cf/R5v7V3/AIkT8Xv/AJsK/TH9 qL9rX9qvw/8A8E5v+CWnjjQf2mv2g9E8a/EL/ht3/hPvF+kfGf4j6b4o8cf8In8dfD+keFv+Ev8A EFl4kh1bxL/wjWkzTaX4f/tq7vf7G06WWy077NbSPEfx/wDjn8FfFP7PvxEvfhf421Hw9f8AivSt D8JazrcHhu81C+tdEufF3hbSPFcPh3UZ9R0rSZF8QaJZ6zbWGv29tBc2Fpq0V1bWeo6hDEtzJ+o/ xT+G9x8Yv2Gv+CG/wmtdb03w1c/Evx9+2h4Dt/EGsbjpeizeK/2ovBmhxapfKjxvJbWT3q3EkKSR vMI/KSRGcMFiMLgMTieHpYbDYSpTxOaTjTlTo0eStCWTZu4WlyqM6cpRhOEruErQnFtKMjbJcw4k w+B4/wAJjMyzenjcLwvgl7GtmGK9thsTLjjgulKNnXboV1TrVKFWN4VKanVo1VFupA+B/wDhvH9u P/o839q7/wASJ+L3/wA2FH/DeP7cf/R5v7V3/iRPxe/+bCv0T8T/APBGmC1+JfjD4beBv2p/C/ir WPAvwW+NnxS8U6H4j8DaT8O/iH4d1r4Qa9p2h6f4b8R/DvWvive6noXhf4mLqKa34H+JV7qH9jX/ AIbjGvjTJNKuLa7l+Tm/4JRft+R6p4V0aX4CGDUfGdrrN3okNx8UfgvbxRjw94fs/Fes2mv3c3xF js/CGq2Ph2/tdXk0XxbcaJrD2ju0NjI0E6xZYfNOFsTCM6dXLYQnh/rUJYnDwwalh/rOOwvtYfW6 NDmiq2WYy/LdqlRhiGvq9bD1auuYcKeLOWTVPEYTimvN4yrl7jlmYV86ccbRw+V4mph6n9j4vHKn UjTznLoJVHFTxFeeEg5YrDYqjQ8d/wCG8f24/wDo839q7/xIn4vf/NhR/wAN4/tx/wDR5v7V3/iR Pxe/+bCvrf4A/wDBHX9q/wCKXxa8SfDz4oeHm+CHhnwLdalo/jzx9ean8OfG8Oh+JF+GsvxM8O6H ovh7S/ibpF147fxDo0ukPJfeCtQ1q00Ox1UapqbrFZXNuPFpP+CXn7dKXHwxth8CrlpvjFrEOgfD +E/EH4ULcajrVz4Ju/iNaaVr1ufHnneBdSu/BFjc+ILew8dr4buZrZFt443vZobaTdYzhp1XRjXy aU1hsHjG4ywcqf1fMHifqUvbK9FzxMMHWrUqKqe2eGVLFOmsPiMNVq8Usj8U4YWGMnl/HEaFTE4/ CxTp50q/tcrjgXj5Swn+9Qw+GlmOFozxk6McJLFSrYSnXnisLiqNHzH/AIbx/bj/AOjzf2rv/Eif i9/82FH/AA3j+3H/ANHm/tXf+JE/F7/5sK+ndY/4JNftGfDf9nb9oL4//Hu2g+EEfwa0PwnrPhbw kdQ+H3j67+JY17xvL4J1hGvPBvxLvr7wVZaDdok9tq2p+H9TsvEchntdLYCzublPnPxV+yZqGg/s rfs7/tJaT4sufEuq/tBfEr4g/DbTfhnZ+E3ivNHv/BOoW+m2c9r4hj1+9k8QXPiG4uY44NNj8OaW 9nKyxLdX7MCHSxPD1ecoYf8As/EuGMweXt4XD08TD65j4RqYXDxqUKVSnOc4yipckpKjNOlXdOpG UFOKyjxKwNONXHriPL1LLcyzdUswzHEYDExy7KJU44/FVMJi8XRxVKNF1qbhCpRjVxMJqphYVqfv Gd/w3j+3H/0eb+1d/wCJE/F7/wCbCj/hvH9uP/o839q7/wASJ+L3/wA2Fet3P/BKz9vOz8baP8PL v4FR23irXfCfi7xvp1rP8VPgtHpZ8OeAtR0bSvGdxfeJn+Io8MaTqHhq/wDEGkW+r6Bq2sWXiC0N 2JX0vyYLmSFZP+CVf7edta+Nry/+BcelW/w7m8UxeLP7X+KfwW0i4tIvBGj6Tr/izUdKstT+I1pe eKNG0PSdd0i6vNc8LQazo27ULe1hv5btjAKhiOG5uCjiMiftKdStTft8vUZUKOKWCq11JzUfY0cY lhKta/s6WJXsZyjUXKR/ZPijzOP9mcfc0a8MLKP1LiLmWKqYT6/Twzj7K6xFTAp42FG3tJ4T/aIx dH3zyP8A4bx/bj/6PN/au/8AEifi9/8ANhX0x+xZ+2n+2P4q/bH/AGTPDHif9rP9pjxJ4a8SftMf AfQfEPh7Xvjx8UtY0PXtD1j4p+FdP1bRda0nUPFVxYappOqWFxcWOo6dfW89ne2c81tcwywyujfQ vxf/AOCGPxw8EeE/iFqXww8e2Hxr8beBPGvhXw+vgLSNI8HeFJtb8N638JrX4n654otdb1n4sXMK aj4deW70WHwXb6ff6/4is7SPxJpQNhfW1u3hfwD/AGJf2of2aP2s/wBgbx98bvhXd+CPCfjf9rr9 m/TdA1R/E/gnxA/9q3XxB8C+JrbR9c03wr4l1zVfCesz6Be2+qw6R4rsdF1KS1aR0tS0E6xefPMe GMZhcZHDVsrdWNGNNU506OHrOpi8Iq+FVKnXp0qlT20JJU5U4yTrUq+HT+sYavSpfQUeG/FLI84y Opm+D4qp4WrisJjZ4ilisXmGChg8PmVPDYqWLxWBxGKwuGeHny/WaGKq0q1GjXwtetSjQxmFqVs7 9tP9tP8AbH8K/tj/ALWfhjwx+1n+0x4b8NeG/wBpj48aD4e8PaD8ePilo+h6Doej/FPxVp+k6Lou k6f4qt7DS9J0uwt7ex07TrG3gs7KzghtraGKGJEXiPgd8df+Cn/7SPjj/hXPwX/ae/az8ZeLU0TV /El1ZH9qHx74c0/TPD2gwLcavreteI/FnxG0Lw3oelWEckSzX+savY23nT29skjXFxBFJ49+3j/y fH+2b/2dd+0T/wCre8YV79/wSq8aaP4D/aU1/XdV+LPw5+F0x+DHxI0/SLD4ySaBZfB/4ualfWun Rf8ACm/iZrvia907SfDfhbxpYi8aXXJbyGW01DTNPWEXMkos7nvp4XDUslliKeCwk69DJq2JpKph lOM8RQy+deiqsaNKpiKkJVacFVhQhPEThzRoQlVcIvxqeYZlmPHkcqxmfZzhsuxvFqwGKnh83lha lHBYjOPYV3h62NxEMDQqwoSkqE8VKOFp1FB1mqSkdH8W/EP/AAV/+BOgeL/FPxY+PH7X/g/w/wCB PH2j/DHxPqtz+1P4w1G2sfGviDwxb+M9E0u1/sX4oalJrNpqnhi6t9Xs9e0RNR8OzW8yIuq/aD5N fL3/AA3j+3H/ANHm/tXf+JE/F7/5sK/qh0j9or9mWx1fUfCPgz9uDwD4e8OWX7Yvw58cas/i/wCP vg/4jQ+EvD91+zn9i1jw78MPEfxS1XVLTxJ8PfDfxGj0bQ/DHiq3g1fw18P7+G21G3+y2fhe3ig7 vwv+2J+zZ4e/aG+Kniuy/aS+AnhseNtB/YAsfEGor8fPhd4gj1h9H1v4mad8U9O1Lxpba+un+Mbr w1ol7p9h4212J3MVhNY32oGztLy0J+Rw+f1VTn7fhvCV6rqZPSpeyw0sJBzzGhksakpqVHHwlRo4 vH4urKthq+JVHB0KHMqsK1DGYr9ezTw6waqYSeW+KOa4PDzwmY18XTxWaUs4rU54HE8SyUKVShmG RyhVng8nwFCODxuDwtaWNxVaTqUpQqYHC/y8+GP2hP8Agpn4y+FvxM+NPhv9qb9q7Uvhn8Hbzwfp /wARvEv/AA1H49s/+Edu/Huo3Gk+E4f7Gv8A4jWuv6v/AGtqFrcW/maFpWpxWPl+bqT2cDJI3lP/ AA3j+3H/ANHm/tXf+JE/F7/5sK/qk8Y/tNfs36h8F/BXhTQP2rP2dvDPge01r9huHw7oNl8Q/hLr t54L8T+EP2itb1T4w+JH+Gd3qtxc29tpumf8IzruoatrGiv4eOn2sXiBmm0yxu56h/ag/bR+Bfhf wN8efFnw7/aQ+DGo/EPUf2efgf4OW+0n4yfCP4qeNPFf9m/tAeNrPxTYG40K7u7bxT4gX4e65eav e2Oj6U83h/TNYWbTbextoLS4TWjn7q1lH/VjDxhic8eUYSM4Om6NOGVZNiPreLr/AFCpGVOrjsdi YzdOjTWEo0qdFLGVaVWtUzxfhrTw9Kq4+LWPc8uyDBZvj61OpDExx9fG8QZrl7wuWYZcRYeVKeEy 3DYOrGnXxWJnjqzrYhzy+hWpUKP83Wr/AB//AOCm2g/Bzwj8f9V/al/autfhH478W674G8KeLf8A hqTx5P8A2r4p8NW63Wt6X/YNt8R5vE1j9igZZPtupaNZ6dc522l3O4Kjyb/hvH9uP/o839q7/wAS J+L3/wA2Fftb/wAFuvj18L/i18EPh5pPgf46/CP4ryWH7SnjPXPDOifDr4n+BfHOoeG/hhd/DbQb Pw8L7SPCms6jfeHtPTVI9UtYbbVba1ltrlmtpFSTbEP5pK9zh6vTzjCVsXicnwuAft6UaOGnho+2 pUamX4HFOniXUpQ5sTRrYirh6/JThCnVoyopSlSlUn+XcfUMZwlnVHKMs4wzfOacMCqmIzGOZ1fq +JxUMfj8JOtg4YfFVY08DiKWFo4nBxqV69WdCvCtKparGEP3f/4KV/ta/tV+BP8AhgL/AIQf9pn9 oPwb/wAJl/wTP/ZW8eeL/wDhFPjP8R/D3/CV+OfEX/Cef8JB4z8Sf2R4ks/7d8Wa79jtP7Y8Rap9 q1jU/stt9tvJ/Ii2/D3jX9oL/gqb8NfD3hzxd8Rfjd+3/wCAPCnjGOOXwj4n8a/Er9orwr4e8VRT WiX8MnhzWtd1qw03XI5bGSO9jfTLm6V7SRLlSYWVz7h/wU8e1i1j/gmRLfBTZR/8Etf2MHvAwLKb VLrx+1wGUcsvlB8gckZA5r95fHnwl8e/EH9sKXVvi941+Hvjv9j/AOK3xZl8Q/s6fs8eO9D8I+ON I+K3jzQP2Lje+FfH/hSXVdK1b7f4EsNRs5tGbwomrW/h3U/EqQ3Fzo9zdTxS3XnVcVhMoybLMTLA 4OtGph89xld1KClUnDJ62WzeBwsadKpOtmeZUcwryy2lJKnOpl1WFadHDOvjMF9tQyTOOMOKuJ8L Rz/P8JVwmK4VwGDhg8Y1haFXPsvxkVmuZyxGPwscPkeV4jLcPDN69B1MTShmlCphcPi8V7DA4z+V r/hvH9uP/o839q7/AMSJ+L3/AM2FdZZ/taf8FHtR8Haz8RNP/aY/bbvvh/4d1XT9C8QeOrP4zfHa 68HaFrerKX0rR9Z8TweJH0TTNV1NFL6fp97fQXd4oLW0MgBNf1jeEv2V/wBlwQW2m+If2Vf2ak8Y +NNb8HaF8XtDm+CPw2aTwN4xvf2Ltf8AiD4n8O+FYE0F2+HksHinQdF1xtO8Mz2MVlf3l9ewCO81 Cec63wI+CfwYj+Bn7P3w+f4J/B9vgd45T9knW5orn4c+Drjw/wDFzxZrfwU8eXOv6n41ubrS5bL4 jeIIvFNro/lXniBNT1G01eSCKKUXJhRPPxnFmWYenjvZZHQq1cDi+H8PeMcNUoYmOcYvF0qksLUh TTqqFHLsRLBzUVHFOrhq3LCn7SK9vB+D3FlSeXyxXHWYU6OY5FxVm9OCnmtLFYWpkGX4bEYehjqN avbDuricdhqeOi5c+FVKvQi51pU5L+Pf/hvH9uT/AKPN/au/8SJ+L3/zYV03ir9r3/gor4E1G20j xv8AtQftqeDdWvNL07XLTS/FXxr+Ofh7UbrRdXgF1pOsW1lq/iazuZ9L1S2IuNO1CKJrS9gImtpp YyGr+oDRv2SPgxpU/iXTvCf7I/7K3ir4saN+zR+x5d6/4F+Lvgzwt4Q8N6NpeuW/xji+K3jPXru0 8D+JdQ8G6/JcaPbjXvHth4YufEkmqaPpWnahqNvGiz23ut78F/hL8aPiNpninxt8Bvgf8TbzUPCX 7KuleJr/AMTfDLwN4osvC/7Peq/CD4g6pqfibwxeatpD/wDCPaUnjeC60m38WaO9teWVpo2maVbz W1pptnHG8ZxblWHliXTyXD1KWBxVHC4ipL6pBT+tQbw9ei1F8uFU7e2xVVRpQjQxsaftJ4Sad4Xw c4trKVGtx5mEcXVwuKxWEhSecTpOOX4ivSxdCrKVePtMdOGFqSw2BoSlXl9byqpV9nSzCDp/xyf8 N4/tx/8AR5v7V3/iRPxe/wDmwr9Mf+Clf7Wv7VfgT/hgL/hB/wBpr9oPwb/wmX/BM79lbx54v/4R T4z/ABH8O/8ACV+OfEX/AAnn/CQeM/En9keJLP8AtzxZrn2O0/tjxFqn2rWNT+y23228n8iLb5X/ AMFSdJ+F/wAPvhx+w78P/hT8KfhF4U0jxF+zd4T+KerfEHwp4C0PRPiN451TUrvXfD0M3izxjptt Z33iKxn07TrbU3/tOGW9utWnlv7y7mcQpDyH/BVX/nG9/wBoo/2Pv/eiV7WGqYHM8Vl2Ip5dSw9F YzPsHGFWhRVSo8trTwM6lSmofu28Rh6vLTk5SjFRbacrL4fOcJn/AAjg+M8lxXEuMzHG4TA8F4ye KwuOxzoUnnMaOaQpYatVqqdWH1PGYfnrRjTjUk5R5bRu/lH/AIbx/bj/AOjzf2rv/Eifi9/82FfY fiq1/wCCzfgnwlrnjvxR8bv2t9J8I+HfhL4P+Oera3J+11rlxbQ/C3x7fy6Z4V8T2yWfxdubnUn1 C+he3uNB0yC88S6QTG+taPp0U0LyfkdX9tGn/ts/saat8A/D/wAO/G3xk+DF3f8Aw6+Df7E9veLL 4+8D30XiTwrqniP4b3vxF8CwWcOpvca9r3gG9+H2rX/i3wxC11qug2WvKdTsYIbtAvRn7eW4bB1s BleBryrZlh8JiFPA+2dLD4iliIqtCnRdKTdPFRwrqOU1COH9s9JKElx+G2FhxZmOaYLiHjHPMohh 8sWKwFeGePCU6uLjjMNGpRr1MXHER5JYJ4t0lBQm8UqCcnFyhL+UX/hvH9uP/o839q7/AMSJ+L3/ AM2FejfDP9pn/go78YNX1nQvAH7Xf7Teqan4f8Ka/wCNtVh1T9rLxl4Shh8N+GLZbzWryC98YfEz QbG/u7a3cSQaNp9zda3qGGTTdOu5EdF/qV8Tfte/s82DeIbrWf2qv2eNf+JTaX8SDaeK9G+NPwx1 tG+H+rftfeGvEnwm8Kw69Y689nNqXhv4apcXkPh+J5NV8L6bbXV3Mlqim5fz74pftY/s2+JPFq6v cftJfAzWrmx+H3/BTLwnp+pt8Xvh9fTWui+KNW8Lp8LfDtreL4gkeLT/ABLZWbjwHpcUgg1u3tnO gQ3SRMV+ZlxNKdCLpcJ0oVa2CzyvTqTg61KjWyuONjhlOmsBQnXhiauGw7dNVcNPkq1I06kpU6c6 v6dhPCml/aMKOL8YsTVwlLPcjy2vChXjhK+IweZU6eIxeJo4mpxDjaWFdCgq8aNWWGxtJzeFqVoQ VarSofyy/wDDeP7cf/R5v7V3/iRPxe/+bCvWdO+P/wDwU21b4MeIv2hNP/al/auuPhB4U8baV8Ot f8Xf8NSePIvsHjLW9P8A7U0zR/7Am+I8fie6+1WH7/8AtCy0W50qH/VXF9FN+7r+pPxj+15+zf4p 8TeFZY/2vfgVa3Pgf4na0/g25sPjB8GotWj8OXH7G+gQXHh3wz441/UdT034ZWfiX4hzatoc/wAQ JEjj07XxqOhW19ba5PALb8wv+Cm3xt+APjL4I/tyaT8OPi18HvE+p+N/2uv2efGfh7R/BHxD8F+I 77xTpdj8BfC+neJ/E2jW2hatdXHiGw0/X4rvTtd12yhubeDWIri31C4ivVkjHQ8+dSvQw1LhmhSl WWT1fb1KTrU6dHH59w9gK9OVNYLDr2sMuzbF11OOIaw2IwMnWo1sPHmn5Fbw9+o5Xjs2r+KeNx8c LlmfYingcNjYYOvVxeX8I5zneBj7Z53mUuR5tgcDgquHngqU8bh8TOODxVLFKUaP4of8N4/tx/8A R5v7V3/iRPxe/wDmwr9Mf+Gtf2q/+HOP/Cz/APhpr9oP/hZX/DzH/hA/+Fh/8Ln+I/8AwnP/AAg3 /DLX/CQ/8IZ/wlv/AAkn9v8A/CJ/2/8A8Tz/AIR3+0P7H/tj/iZ/Y/tv7+vwgr9XP+cHH/eVz/30 Ovp8zwWDj/Z/LhMNG+aYOLtQpK8W53i7Q1Tsrp6Ox+WcK55nVT/WT2mcZpPk4UzipDnzDFy5Kkfq 3LOPNWfLON3yyVpK7s0fKP8Aw3j+3H/0eb+1d/4kT8Xv/mwo/wCG8f24/wDo839q7/xIn4vf/NhX 0n+yT/wTm0H9pT9njxd+0H4t/aP8PfBPQ9A+IOt/Day/t/wSdc8JafrWk+Al8b2uq/FP4gT+NfC+ lfCfwrr00tr4X0TX9UsNagvfEd7ZabHCb2+sLS77gf8ABIP4w3th+yf4x8N+Ibrxb8Kv2ivDXwZ1 Txl470LQ/BQvPhB4g+M+sXGj6F4cHhDVvi3per+OLRJoofsniwzeEPD2o3FwLKa50y4jIZ1cVw/h 8ZLAV44KjiYYnLsHKNTB8lJYrNsNXxeW4f6zKgsM6uLo4afs4qs2q0sNhp8uJxeEo1tcLkHibjcp o55g5Z5istxGAx2aUquHzyNWvLLstx+Gy3H42WBhmEsfTw+FxWKpqtUqYWMY4enjMdf6lgMdiMP8 af8ADeP7cf8A0eb+1d/4kT8Xv/mwo/4bx/bj/wCjzf2rv/Eifi9/82Fe/aP/AMEr/wBp++8W+GJt W8I6n4e+CHib466D8G0+MF5P4Eu9V07TfEfxek+D2mePb74TWHxEn8Zx6Nda/BObWUuPDt/cRfZr HxdcWcsGrS+reGf+CPXxg1i4/aZ8Qa14qPh34Q/Am2+NEXgj4lPonhG+vfjPr/wX8aReDtX0bTPh 6/xTsPFfhOzvJxdyzeJryLWvD2l31smkPfXlxdQzVEcdw1OFOcKmWSjUp4mcXGlRbi8HTwNWvQqR VPmo4yNPMMFKGBqqGMqqtFUaFRwqKFf6ueKtqjeF4rgqWJw2GlKpi8ZSi3i45hPD4qnKpiYqtlk4 5Vj283oueVU/q79rjIOpR9p8V/8ADeP7cf8A0eb+1d/4kT8Xv/mwo/4bx/bj/wCjzf2rv/Eifi9/ 82FfSfxk/wCCSf7XHw81X4x6l4H8B3/xG+FHwdvPEcGq/EC91/4R+DtevbTwZ4c0jxH4vvU+GcXx c8V+JXGg2urRGeHQZ/EouIBFPbzNLM9rB86fHT9hb9qb9mvwNpPxI+NXwyt/BvhDWvEWneEbS/Tx /wDDLxNf23ifVfDI8Y2Og614e8IeM9f8SeHdUl8MPFrEln4g0jTJra1uLT7UsMt3axyvDY3hrF08 PVw9bJ5xxVLB1qEX9Vp1Zwx8aU8FehVUK8J4lVaXsadSnGpOU4QUOdqJy5jlHidlU8bHH4PjTDxy 6rmFHGYi2b1cFSllNWdDMprH0ZVMFVoYOrTnGviaOIqYeCXP7Vwak/0p/wCGtf2q/wDhzj/ws/8A 4aa/aD/4WV/w8x/4QP8A4WH/AMLn+I//AAnP/CDf8Mtf8JD/AMIZ/wAJb/wkn9v/APCJ/wBv/wDE 8/4R3+0P7H/tj/iZ/Y/tv7+vzO/4bx/bj/6PN/au/wDEifi9/wDNhX1d/wA4OP8AvK5/76HXe/sn /wDBH3xJ+1R8DPgb8ddJ+M6eGNB+K3xH+IfgPxXpw+Gza/N8ObTwZoHjTUtJ8Sfax490VfE1r4j1 nwpZ+HZrNrfw6dGufENjcLd6t5RtpuSnPJ8swmbY7MaWFoYTD5piYzqywqqKmnGDjFQp0qlR35Wo xhB3laKXNKKfv4rD8a8TZhw3lXDmKzbG5hU4My3HTw9LNpYZzp0VWeJxE6mJxmHpNwjKMqkpVOfk Tm7xhJx+FP8AhvH9uP8A6PN/au/8SJ+L3/zYUf8ADeP7cf8A0eb+1d/4kT8Xv/mwr1XS/wDglv8A tz+ILDwHrHh34HXGraP8ULnS4fAl1/wn/wAKLG81S31/RNa8TeG77WdFvvHsOr+C7PxDoHh/VNS0 i58Z2eg2t99nW0tbie9uLSC41dN/4JZ/tgWWofDu8+Ifw1bwd4B8c+Nfg54WvPF2j+Nvg9471bw/ p3xu8T2fhfwT4jl8E6J8UrfWZbDV7+4uLbTJtVn8P6Nd6pY3ekXuvaVcW15JaejGtw9KqqCq5Mqz xNHB+xlPBQqrGV6kaNDCSpzcZwxNWtKFKFCcY1ZVXGmoc9keBUyjxQpKpOeA44VKlQqYqeIVHPJY WODpKrKpjfrcU8M8DCFGtUljVVeFVKlUq+29nCUl4r/w3j+3H/0eb+1d/wCJE/F7/wCbCj/hvH9u P/o839q7/wASJ+L3/wA2Fe4/Ej/glZ+2N4MsvHXjHw58LNR8Z/Cjwl4w8WeGNN8aQ+JfhXY+IvEF r4U+It18MLjVv+FY6Z8TPEvjGy3+K7dNOurazt9atbKWZJl1S701o9Rl6fw9/wAEn/2jdKvfidZ/ H2xPwQXwP+zn8Zfj74Zu7e48C/Fex8bz/BbUfDuleIvAj3/gP4jXNh4W1SO+8RQ22pXGpXV1qeiz QmOXw3dl3MHN/aPC/wBXeK9vlHso4fE4lx5cP9Y9ngsHPH4uKwnJ9beIw2Do1K9bCqi8VTjTkpUV Jcp1x4a8WJZgssWX8ZLEvGYfA+0nUzKngFXxeLWAwkpZrUqxyuOGxWLcaOGx0sYsFXcoypYicJKT +Z/+G8f24/8Ao839q7/xIn4vf/NhR/w3j+3H/wBHm/tXf+JE/F7/AObCvpD9jj/gnTof7T/wz0H4 keNf2gbf4LQ/EL49wfs2/CbSl+F2p/EWTxf8TJ/B48YLFrd9Z+LvC0XhHQGtpbewj1bydeka8eYS WMKRRG49rtP+CQlhL8LLPW739pT7B8bdU+Dn7QPxg0j4QN8G7mfw5qFl+zn4yu/BvjTQl+KSfElX t767uoLe60ua48BIJY7lo3twLaWYrHZjw3ltSvSxsMNRnhnasll1WqotZXUzqpySo4WpGr9XyqjL HYv2TmsHQ9nLFexdSkp3k/DXidn2HwWKyqtmWKo5hRjXwkpcUYLDTnSqZxh8goOpSxWb0K2HljM5 xNHL8BTxFOlUzCvKSwUMRGnUlDtv+Can7Wv7Vfjv/hv3/hOP2mv2g/GX/CG/8Ezv2qfHnhD/AISv 4z/EfxF/winjnw7/AMIH/wAI/wCM/Df9r+JLz+w/Fmh/bLv+x/EWl/ZdY0z7Vc/YryDz5d35nf8A DeP7cf8A0eb+1d/4kT8Xv/mwr6u/4JVf85If+0Uf7YP/ALzuvMP2Kf8Agn54j/bU+G/7Svjbwn47 Xw7rn7PWi+Cddg8If8Ik2vyeOrTxRP4nfVYbbVV8S6O2iXmh6V4Wvb6zgGla1/blzLFp5fSh/pZd Ohl+HxWeYnEYfCww2EWWSqzlh6bhRhXdHCwlyqDajLEYijGcoxtBSdWo404TnHWeI4qzjJuCMvyn H5tisyx/+s3s6NLMq9OtiXhMQ8TKPPUxFOM508NQqunCU+efKqVJSqThCXkH/DeP7cf/AEeb+1d/ 4kT8Xv8A5sKP+G8f24/+jzf2rv8AxIn4vf8AzYV9KfG//gkx+1N8OPGvxwsPht4XufjB8L/glrmq 6Nf/ABP+2eBPh/eeIk8OeFPDnivxVqGifDjXviFfeLtUtPDVp4ktYtWm8Nx+JbW1MbvNdxSrPbW3 I6z/AMEnf2/fD9j4jv8AVvgPDbReFY/EL61bx/Fr4H3mpo3hXw5aeLtettO0ay+JVzq+uX9h4Zvr XXP7N0Kx1LULrTpDcWVtcrHLsKeY8LVMNRxaxOTU6FfB0swpyxDwuFksFVo0MRTxFSliVSrUKfsM ThqkvbU6bpxrUvaKLlFPjr8P+K2HxmIwEst44rYnC5hicrqrB085zCjLH4TFYjB18Ph8VgXiMLi5 RxOExNGM8JWr0qsqFR0ZzjFs+y/+Can7Wv7Vfjv/AIb9/wCE4/aa/aD8Zf8ACG/8Ezv2qfHnhD/h K/jP8R/EX/CKeOfDv/CB/wDCP+M/Df8Aa/iS8/sPxZof2y7/ALH8RaX9l1jTPtVz9ivIPPl3fmd/ w3j+3H/0eb+1d/4kT8Xv/mwr6u/4JVf85If+0Uf7YP8A7zuvU/8Agir8Ffgl8c/Hn7UnhD46eEPC XiTw1cfs8y6fpus+J9A0TWbrwFrXibxv4a8K2vjTw1faxbyv4b1zRTrH2iHXNLmtNQtYUlEcxVmi fGdPBYOrxFi3gKNeOBwtLFRoU6FHnqLD4CpXdGkpRUIzqunyxu1HnacmlqerhJ59n+E8Ocmo8QY7 A186zDNsBLHV8fjvZUnWzWhRhXxLpVXVnToRld2UpKCaguh+f3/DeP7cf/R5v7V3/iRPxe/+bCj/ AIbx/bj/AOjzf2rv/Eifi9/82Ff0ffHX/gkj+zD8SvjRqMOuQ+JvhPqeua74I+A/gfw38CrH4ceC PAmg+NPDv7Kl78ZvEHjfxnoUngbVv+EiTXdT0l7G8h0G90DULqeSW9udTnluPOh8K+G3/BGz9kHx Fovw3fxN4y/aSk13xb4M/ZL1bW20Lxr8MNO0m1139pCw8WRak+lR6h8HtXvDpPh3VfDQu7Gyu5Wv LjT7j+z7jUXuf+JmnBS4k4bqUZVXgoJxq5VSUIYOjU9pPO6tejlipVLRhJV50IxnKThCjKrS9pJR 5px+hx/hZ4p4LF08P/bdWdOrg8yx0a9TPsXRUKGUYaniswdWl7SpOE6VN4iVKnH2k68cJXdOPN7O FT5n/wCCPP7Wv7VfxN/4KM/s7eB/iT+01+0H8QvBWt/8Lc/trwh44+M/xH8WeF9X/s34FfE7V9O/ tTw/r3iS/wBJv/sGrWFhqll9rtJfsuo2VpeweXc20Mqfmd/w3j+3H/0eb+1d/wCJE/F7/wCbCvuP /gkV4Wg8Df8ABYb4QeCbW7mv7bwf41/aS8LW19cRpFPeweH/AILfGfSYbueKMmOOa4jtFmkjjJRH dlUlQDX43V6WApZdi8xxGIoYbDTw2IyXIsVQvhqcU4YivnM4z5JQThKdNU+ZNKXuxUvhSXx+dZhx DlvCmU4XEZtmcMdhONeOsvxc4ZlipSc8DlvA1N0vbRrXqUqVaVd0tXBOpUlBL2km/wBAvgp+0L/w Uy/aK+Jnhv4PfBz9qb9q/wAY/EbxcdUHh7w4P2ofH+gHUToujah4g1MDVvFHxF0TQ7U22kaVf3Y+ 26nbef5H2e3826lhgk1/iv8AGf8A4Kk/A7Q/APiL4q/tL/tbeENJ+J8PiyfwTLd/tQ+PL+61ZPAv iKTwn4rS50zSPiPqOqaHcaP4hhl02a18QWelXM8iNNZw3FsPPqX/AIJKePfB3wx/b9+Bnjjx74y8 MfD/AMLaHD8Tn1Dxb4y1/R/DHh3SZrz4R+O9P003+t6/c2mk2j3mqXdnY2a3c6rdX1zbWkayzTxx P/TMv7av7Kvjm6+GvjT4e/tAfAb4afEzxV8BYdegu/EHxY+HnhV/h/rXif4/eAPHXxu8C6treq6v Z2vhjXNfgk1q4h0PUxZ6l4m0+wu59PiuLaCSQcmfYp5XmeU4bB5LhMZhMVhvb4+p9UTnQnKhxRUp QhVpxcKUHLJMJOtUnRrPD0ZVnyVZ4rCRp/UcCZDT4r4YznMcy49zfJs4wuZUcFltCecfuKtGeYcJ YariauDr1qOIxMoUc7x8KNKjjMMq+Jhh26tGjhMV7f8Akp/4bx/bj/6PN/au/wDEifi9/wDNhXol 3+07/wAFG7H4XaT8Zrn9rz9pxfh5rnjDUPAem6qn7WPjOfVZfFGl6bHq97Yz+D4PiXL4zsbSLT5Y 5o9bv/D9toVy7i2ttSmuv3Ff0/at+2l+zHo+laynwx/aU+CvhjSk8FftXXuiWWk/FPwJod5beKNS /a58L634WnsbZddg1Cy1DWtBm8ReJvCdvGIZr/w9cXmt6Vbmw8ydMbQ/2sP2ZfDPjD4r6v4f/aQ+ AejTf8NL/tgeM/Dd7p3xb+HNqk0fiP8AZ10W08NeJtKaLX1hurbxF4ujns9H1SAS2+t+IFntLSa6 1DzY68V8SN4eVaPCcKTjluZ5lGFSnzzayrP8JlEsFKCwNP2eIxtCrVxeHmp1FRjThJ0cTBSt9TT8 NIrMIYGfi9icQqmd5TkP1ijXVDD055zkGLzinm0asuIMT9ZwGX1qFLCYqi4YV151XGOLwk1FS/lW /wCG8f24/wDo839q7/xIn4vf/NhXq3xd/aD/AOCmfwI1nw14f+K37U37V3hXV/GHgTwt8TPDtp/w 1H491z+0fBHjS1lvfDOt/aPDfxG1i1tP7StoZZf7NvprXV7Pbs1CwtZGVD/UD4m/ac/ZU1TQ/wBs Z5P2pv2fNcsfiX4T8TWk3hKP4v8AwV0XStZ1y7/ZS+HmnQ6/c27X/wDb3xc1/W/Fen3PhfTo7XUr rTfC+q2Oo2jWY1wlR/NR/wAFRPHngf4gfFf9n3UfAXjPwp430/Rf2MP2cPC2sX/hHxFpHiSz0nxP ofhzUYNb8OandaNeXsFhr2jzukOqaRdPFqGnyukd3bwuwB9DLs2jmGPoYSXDuHwcWsqqV6tSj7aP LmWU51jp0qUnhMNGE8Jicsw9GVWXtI1aWJhzUsPVnGMfmuK+FK3DGQzzal4j5jneIr0cZPB4XD4y WDlRlg814dwsZYmnDNsynXWLwWd16saVOWGeHxGBrJVcVShNnz//AMN4/tx/9Hm/tXf+JE/F7/5s K/TH/gsN+1r+1X8Mv+CjP7RPgf4bftNftB/D3wVon/CpP7F8IeB/jP8AEfwn4X0j+0vgV8MdX1H+ y/D+g+JLDSbD7fq1/f6pe/ZLSL7VqN7d3s/mXNzNK/4QV+rn/Bb7/lKF+07/AN0W/wDWevhNXuVc Fg1nWXwWEwyi8rzeTiqFLlcoYvI1GTXJZuKlJRbV0pSStdnxODzzOnwPxFVecZo6sOK+DKcKjzDF upCnVyjjyVSEZutzRhUlRpSnFNRnKlTck3CNvlH/AIbx/bj/AOjzf2rv/Eifi9/82FH/AA3j+3H/ ANHm/tXf+JE/F7/5sK+UaK9T6hgf+gPCf+E9H/5DyX3Hyn+sGff9DvN//Dljf/lx9YJ+3d+3NI6R p+2Z+1czyOqIv/DRXxdGWchVGT4xAGSQMkgDuQK+u/i0v/BZX4GaJ8RvEfxV+OP7W3hLRPhO/wAP k8eX8/7XOvapHo4+KhuF8By2keh/FzU5/ENvrktpdQG68NRaxbaVc2txa61Lp1xBLEn5O2bKt3as zBVW5gZmYgKqiVSWYnAAABJJOAOTX92vjf8Abo/Ye8YazfQeJfjf8CL2bwR+0d+zboTaifiN4B1T T/Ffg/RLbR/Gvhbxnp72mqNFq2gfDzxv418QWWv6zbSXtj4Uk0C6u9cntfs8rDwOIqn9lwyaWX5R hcZPG5h7HHQ+pRrSo4KOacNYKVWhGk6X7+VPN8SqUKjlCVSnTru1DCYmFX9M8O8vjxZQ4olnnGuc ZNVynKquJypvO5Yeliscsm4ix1KniFinUlPD08TlWDlXVCVOrKhKrhqbWIxWHrUP47/+G8f24/8A o839q7/xIn4vf/NhXongb9p3/go38SNM8fax4Q/a8/acv7D4Y+D7vx54zkv/ANrHxn4dm0/wvY3N tZ3V9p9n4k+JekXviW7juLu3jXRPDFvrOuzCTzIdNkjR3X+pPTP2vv2eNFvdGfxB+1R+z3qfxT+1 fsSWPxO8a2Hxo+GWq2niSDRvj18RrrxMR4pt9fbTtej8K+CNUjfxXf2Msq+HdB1O1TVrm1tZUVPH fEX7VX7Ouuaxqmval+0Z8EdT1q+/ZG+J/gy51a5+LfgK51G71C2/au0vVfCXhSW8bX2nmvYfB0T6 n4e0JpGnTw2j32nWo00NLXhw4g9tKNOnwvRpSq4zM8DTrTh7WEJ4Dh3+3KeLdJYGg6uFxNZwwNK1 ajKc+aSnGaVJ/aYnw6jgJ1XW8WcZjoYbBZNmFWhhqyws61PNeI6WQ1MJDFS4gx0aGNwNOpPH4mLw mIjCFKVJpRbxEf5iv+G8f24/+jzf2rv/ABIn4vf/ADYV6tfftB/8FM9N+DOhftB3v7U37V0Pwg8S +O9T+GeieLv+Go/Hsn23xvo2kprmpaJ/YEPxGk8T232bS3W6/tK70WDSJs+RBfy3AMI/q01v9sL9 mrxD8YvCHi5v2v8A4Drf+FZf2obCzuLL41fBjSr/AFnwvcfFP4RXPhLwivxI1nUdQTwX4d1fRtNv 9UtDp89lqfi3RtI1Cx0K8kX7U9fh7/wU8+K3wT8Xfs6eN/DPwy+Jfws8U30//BSv41+P7DQPAnjT wlr11N4K134d2kVl40s9L8P6ndyyeFtW1R54LXxDDAdJvdQMsMN3Jcb0owXEH16WAguF6WDljMNQ xcp1qXto0KcuI8ryipQnH6lhv3s8FjqmNp1HUiqM8PUUqNajTdWfPxDwBLh3L82zD/iKeNzr6hic ywFDDYTFPBVMRiMLkeeZjRxSqf23mfNhvr2UQwkqEKKnXo43DVIYqhWqKjH8t/8AhvH9uP8A6PN/ au/8SJ+L3/zYUf8ADeP7cf8A0eb+1d/4kT8Xv/mwr5Ror7v6hgf+gPCf+E9H/wCQ8l9x+D/6wZ9/ 0O83/wDDljf/AJcfV3/DeP7cf/R5v7V3/iRPxe/+bCv6Yf8Ag3X+PPxy+Nv/AA2F/wALn+M3xX+L v/CM/wDDPv8Awjf/AAs/4ieL/H3/AAj39tf8Lu/tj+w/+Er1jVv7J/tb+ydK/tP7B9n+3/2Zp/2r zfsdt5f8eFf1cf8ABsR/ze9/3bX/AO9+r5fjLCYWlw3mU6WGw9OcfqfLOFGnCSvj8JF2lGKavHR2 eq02P1bwQzjN8V4ocMUMVmmY4mhU/trno18dia1KfLw9m0489OpVlCXLOMZxvF2lGMlZpM/oK/bx /wCTHP2zf+zUf2if/VQ+MK/zPa/0wv28f+THP2zf+zUf2if/AFUPjCv8z2vI8Nv9xzL/ALC6X/pk +0+lD/yPuFv+xRjP/U1BRX6zf8E7/g/+zn4t+Bn7XPxh+PXwTsPjZcfB7Xf2ZdN8KaLqPjz4leBr eys/ip8RNc8H+LJFuPh14t8LS3d09gLO6sjqv2+G3u9PhEcccNxeLP8Aa/xr/wCCGemvqv7TPj74 cfFeT4eeA/AXiX4p6h8N/Beq+BPEHjLw9ZeDvhxoXhjXtVtfHHxbl8VwT+E7sya7qlj4atr7w94p 1PWtP8O3N7Jd3FwLsQfXY7iDL8uzGrl2NdWg6VCVaWLcIywjcMLw/jJ0Y8k5Yl1YUOJctnJ/VlRS +tS9ryYeUn+Q5P4YcUcQZFg88yOngsz+uYmnh6eVUMROlmlOFWfElKniaqxVDD5cqE6nCua04Rp5 jUxMqn1WmsO54mEV/OFRX78+K/8AgiR4O8GeP7rw74g/bU0rS/BHhz4PeI/jH458e6j8CdSs10Pw 1pHiHwjoWka3oVm3xRk8MeL/AATr8XimXVf+EwsvHdjJo1po17DqegR3TeTFqfBn/glN8BdN8Mf8 J14s/aB8I/HWbxz8Hv2s/Fnw48G6T4B8c2PhW9074BarrHhyD4p6J8SfBvxf0BNQia/tfDl/peia rZyafdL4nmiudM1200WW6uOWtxdkVHBVMesTWrUYYfF4mEaOCxrq1lgoZrOtTpxnQpqNVrJczcVX lRh7PCVMROpDDL2524Pwd49xeZ0MqllmBwdetjMFgp1cXnuSKhhpY+plNKhWq/V8wxFepQcs9yqL lhKGJqTq42jhqNOripKgfz5UV/Td8A/+CI3wa0fxv8MfEfxe+NOqfFvwP4hsTY+Kfh7B8NNU+Hr2 3iDxZ+zzrvxk8LyWHjDQPjFqGqX9loEFkbi7kFjo51DUNNt9OltGsdSuJLbzmX/gj78MPi1pvwS8 QeFvivY/BLwt4m+Av7KNxLqunfDbxh4+1L4gfFv9onV/FukaVqGuaN4k+NcqeFIp30Swm1y78P38 Hh+xa9WPSfCNslvcyS1V4ryaliamG9tXqOjWwGFr1aWFrzp0cXmVbNKGEwrjyKvVr1q2VypU44aj XjXqYzBww8q0ni1hLpeDXHVTK45nLBZfh1Vw2Mx2GwWIzfL6eLxWX4CnlNbFZhSkq8sFTwlChmvt 688VjcPPC0cvx88XTw6WC+u/zr0V+zfxf/4JESfCT9k3xh+0Zd/tCQ6v4w8C+EtP8YeIfhUvwrls dMWxu/ixqXwmuINO+Iq/EK/N5Pb6rpN5qEPmeCrVbm2WOJ/spkE1fjJXo5dm+XZssS8vxKxKwleW GxDVOtTjCtD4oxlVp01Vinde0pOdJyUoqblGSXyHEfCHEXCc8DT4gy55fPMsLDGYOLxWCxLq4edO jWjKX1PE4j2E3SxFCr7Gv7KsqdanN01GcW/1c/4Kq/8AON7/ALRR/sff+9Erp/2Xv+CVmiftI/An 4WfFFv2ir7wV43+M0nxxtfAnw+HwUufFHh83nwQ06+1TVP8AhJ/iLa/ErSj4c0/WLW1hWHUpfBt3 FaXd3HZrHfXDQJc8x/wVV/5xvf8AaKP9j7/3olS+FP2vvi/rv7Bvw2/ZB/Zftf2jLbxp8PNT+NPj 39oaT4YaNfy+G9Z+EHiLU7a8WbUNT8GarqPieDw/owu/I8V32uaJoGhWkWomzn1K9tb54pfFf9oP hrDxyvERweLqVnS+u1I0pUsDQqVMVGrjq6rUMTT+r4N8mJr3w9Ryp0pU1yc7nH9BpQ4Yn4k5vLiz AVM1yyjl9OvSyqhUxlLFZnjqWByuWHy7BywOLwNd4vGx9th8P/tEYQqVFVnTrezVKfkd3/wSw/bz sfEPw88KXPwFnTxB8VLvWdO8E6cvxH+EUr32qaB4Qfx7q2j6xNF4+e28I63a+EI31saJ4wm0HVbi 3VorWznux9nrI/bI/YM+IH7F3hT9n/WviH4i0fUPEHxr8J+Itd1jwpplz4ZvpPh9rnhrWINMv/DU 2s+GvGPiqw8UKsd1bzNr2nrY6WLr7VpcZmvLG7EX7b+Pv+Cr37O3w3179mfTdS+AP7UXws0j4c3n iT4j6f4L8TfB/wAB+C7lfA3xJ/Zr8RfC3QLzwlcXvxMtdS+INhrHjPVbrxYfH/iGPTrjxBpF/f3E VzeXOn2thP8AiP8AtVftL/Df46/Af9i7wB4X0zxxpnjb9nb4XeJ/hz47bxBpugw+F9UfUPEq63pO p+E9V07xHqWrX4lhedNSg1jQtCNnKsSWz6grPMmOHzDiXE4/AQng6WHwEMfQjjqlPD81SrRq4Him NajOTxeIp0FgMdgskpYl4f20pYvFQdPF/U1Vp4is54e8McryTPZYHNsZmWezyh1cno4rMoQp4XF0 sx4IqqpCjSyrBSxVXHZdmXEssKsXOFJYLL60Hgv7RqYXF4T2/wDa5/5Re/8ABIX/ALv9/wDWhfDV ePf8Ezvjr8Mv2eP2s/Cvj74wa5deFvh/eeDfid4J1vxTa6NqviH/AIRtvG/gLXvDunazc6JoVrfa 3qVja6le2ovLfSrO6vhBI8sMEvlFD7D+1z/yi9/4JC/93+/+tC+Gq+rrz9j79jOS3/ZS/Zc/4Uj8 T4vjt8fPhL+x78TF/aR8I+JPE2u6TY6h8avGl1D8TdL+IXh7WfF1r4J8JeHLfwtBJZ+BLvQfB1/q 11rUcMF/MrLLdXfZTqYf+yK+BxVOtWo59nHEXDc4UHFVI0s5xmf0MTXlKdSnyUsPgoYqtUqU3Urx 5Yuhh8RUtTfK8uzPE8Y5fnOVYrLcJjOEOFfC/ivDzzSWJWHrYzKOG+CqmW4SEMNh67qVsVmUsJSj Cu8NhHGU/rOMw1K9Rer6l+1v+w9rnwD8V/smD9qjStN0y2/Yg+EP7P2kfGvUPg78dD4T8ReOPDvx I13xV4i+w+FNO+H2oeN7LT9L0x7AC71nSNOhvrm+EVlJMLad1+Af+CcP7Sfwk/Yg/aC/aV8bX/xS 07WrC1/Z7+J/g74N+MdO8J/EGLSviV49j8VeCta8E2kGj/8ACODxL4bsPE6+HriRpvF+naFaWFvu t9aubKSRY5Pu/wCGn7Df7G3xB8ZfB8/8KRSx8P8AjD/gph+0L+ztqukL8Q/isxvPhB8Nvht4mv8A w14amu38dveW9zHrmiW+t3eu2Fza67c3Uk1nJqZ0kpp6fJv7Tf7NH7Nvwa+Mn/BOXT9I+FsbeC/j P4f8Mar8Z/DsnjD4gz/8Jouo/Fu68KanJHqMvix9W8PXB8PhYLUeGb/RreO5hiuHgkkabzfDynEZ TPG/UcPLO54jjKGIw9aOJhlfJLEZ9lOYcSVMRVdOMVQrww+NxdGMKSng4YipGnLD1qMI14/c5/Q4 zhgcNxTi6HAdPD+GOKyupg6uCq8V8/1PKc0yngjC4KFPEV5LE4CVbA5diq1WtLD5rLDUJ1qeMp16 lTCVP1H+PP8AwUf/AGFPjH4c+Mvh7wX8dfg34Z/4TfTv2fH8NWXx+/Zc+LHxm8BWkfgfSPFEfiXR 7nwZN8J/Edl/bPh6XVLGy0jV2gW2guh9r0a+ureJpK+KvGHxK/4Jn/tEt+zd42+KnxwvD8Q/AHws /ZR+BjeCE8GfEPwx4f8ACVl8IfGeqTfGLxl4h1m88InwnrvhfxX4IHkeCtHsNTGt293fWkOo6VaT vcwWHgXwX/Yk+EOg/t9/tifBf4raBefEj4afsqfDT9ob4paV4Pl8Ra54XHji0+HlpZ3fgnRte8Qe GLyw8Q2VvNY67p11qU+jalYXct1aAed9nea2l+n/AIZfs0/scfF74K/tG/Hj4I/sQ3PiW+8NeNPg ppfgz4S/tH/Hvxh8DLHwvZ+J/BAvviB/YnjC4+Pfhm017w3LqsMmteDb7xT4nv8AxJq9lMbeG1RV S1TgpRyLKMPRzLLsVn9KlXp8McX0cXQnlq+qLMK1fIMohUr4xUalGliaf1lY9VK31WhhI1q9bG4a rUvU9iri+PuJsRi8uzzLPD3EYjD4vjbgivgMdh+KMTUzCrwnKnxTxBXwuAyyWYYXFV8HiqtD+y+X BzxeMxc6OHo5Zi6EGo/hT+0B8Ur743fHD4tfF3UGc3HxF+IPivxakbkk21lrGsXd1ptiuVUiLT9O e0sYU2IEit0RURVCj9TPif4q8FeBv2Gv+CHfjH4keDl+IXw/8NeNf229Z8aeCDcSWreKPDNh+0x4 Sn1rR4riO4tDFcXlgk8dqzXMEX2jyhNIsJkNR/tffBv9jP4HfALwn4G0z9nj4hWvx98Zfsyfs/ft BaH8cPB/ivxh4t8LaZ4h+J+va5c+MfCXxD0nXPG48K+HvBVpotrb6N4I1XRfDWra9qF9FH/aeoPM J9QvPZNb/ZU/4ab/AOCXv/BLz/jJH9lH9nz/AIQn/htj/k574w/8Kn/4S7/hJP2hYv8AkSP+Kd1/ +3/7A/sD/ipf+PT+yv7a0D/X/wBo/ufoaWOwOFjklKhRxGEweRZ5VyinLEKnUjUWXZNm2BUqMsNV ryqUY1qcsPzTVOpKdKc/ZqlKnVn+ey4dz143jydfF5Zm2d8ScJYbiKrTy+eKpxo18y464LzipRxU M4wuAdOt7CvHEum3XpclRUXXniIVqVPsPFP/AAVs/ZT1nxDptofCv7SHinQ4P2a/2ofgTc/E7xp4 c+GcvxfTT/jdrehX/wAP/CUsFn8SJ7XxF4N+F+l6VNo9vruveMpPE96kkd7PY3V9NqFzd+m6r/wW j/Y6i8N+DfDXhP4ZfHnQ9G8MaL8SdPsvD0HgD4VafYaAvjf4Gj4c2+nWuq2fxZk1HxcR4ze/8R6x 4r8RW9pr9/ZatO8tvcXNnb2Un5qf8Oqv+skP/BKP/wATB/8Axd0f8Oqv+skP/BKP/wATB/8Axd15 88o4SqUJYeeIxcoVMPWw07zxTcoYjG4/MKknehy+1eIzTEuNbl9pCNScYSj7fFvEfRUeNvGahiKG IpYDKY1MLi6WNw9qGTpU6tHD5PhqceZY5VJ0VSyPAJUas5wSpqEUqVHCU8N+mmlf8Frv2R28ZeJf EWteBP2jLayh+JOmfEXwhHpfg/4Z311qUr/sm237OmsaT4kiu/i7p8WiR22rLceINNvdLudfa+05 YYrq2065d4o8HQv+Cyn7H3hrRv2W9G0H4Y/HTRdI+CXxJ8PeOde8P6f4E+F8cFtaWX7O/iv4Ua7Z 6N4gX4rR6t481rU/GuvL4kfxH4yg0PUbzSbu6hupIp9MsrO8/On/AIdVf9ZIf+CUf/iYP/4u6P8A h1V/1kh/4JR/+Jg//i7pzynhKoqylXxTVehluGqJSxSTpZXTr0sIkvYWUlHFVHOdnJuVouMXOMpj xp4yxhQh9QyprD4bMcJSk6OUOapZpHCQxXv/AF7m5nDBUIwaaSUW5RnJqS+gfiP/AMFOf2evHP7D Hi39n+Dwr8Z7L4veIvgP8PvgrDLP4d8ESfDiH/hXvxf1jx9a6/N4kT4hnxPnWNF1cwXNkngp/sGq wC3juL20lN/H4j8Mf2v/ANlSz/ZP/Zg+E/xMt/2g7P4qfss/GDx18aPDP/CC+DPhxq/w+8Ya7rHi S08R+HdB13Xtf+JuheI9J0lpNMtLXWr7T/Cl7eWiXFzLY2+oNBEk+z4U/wCCNvjnx3/wkn/CD/t3 f8EzvGX/AAhvhPWPHni//hFP2n9Y8Rf8Ip4G8O/Zv+Eg8Z+JP7I+F95/YfhPQ/tlp/bHiLVPsuj6 Z9qtvtt5B58W7k/+HVX/AFkh/wCCUf8A4mD/APi7rtw9PhrDvFRw2LrU6lfNKGczcPrEqlHHU6sq 9GpTUqEuSHtKkpKnUjOMk2rcqsvKzLM/FfNMThcwzTJ8BieXJ8ZkUFVjl1PDYvLsRQwWDxNOoqWP p+0qRoYDC0va0Z0503Byb9pNyf6K/FL/AILT/syeMfGd9qmheBPjrb+G9R+Cf7U/hB7O48B/Bvw7 JY+Pfj9feCrrSGh0zwz41xqmj2I8N383ivxprPiG68S6xf3MV6vhuee4upE+rZ/+CjP7Jv7QPwO/ aU+Kz+N4Phnd23gL9qLwx4G8E/EXxj8J9D8feJf+Fk/C/wCGuk2FtL8ObX4gar45vdY1HxFoE9p4 ePhDR/E/h240+K6udV1/S9RhfSY/w9/4dVf9ZIf+CUf/AImD/wDi7o/4dVf9ZIf+CUf/AImD/wDi 7ry62R8JywscPh8ViMNOlgcXl+HrqOIqyo0Mdjo42u3GpR5atW7dGnOpzctNr2iqtScvqsv8RvGT DZhSxuNynLMypU8yjmzwk55Zhqc8bTwUsJB+0oY32kKDlKWIq0YOKlVnNU5UYOEaf6a2f/BbH9km z8VXniVPAX7Rj/218RdD8e6pZt4R+Gg+w/2b+yfqn7P1xp1hOvxbH23d4gfTNXhnuI7Hfo8t/K6Q 3tvb6ddeLah+3X+zx+1P8Zv+CXPw8+HHgz4wWvxG+GH7XH7MMWseL/ignhfzYfCeneJfAmgL4NXx F4e8VavqXxKFn4gjnv8AR/Fni/QfD+u2Gj4sDHLJeX7zfGf/AA6q/wCskP8AwSj/APEwf/xd19B/ slf8E1P+EE/ar/Zm8cf8N+/8EzvGX/CG/tB/BjxX/wAIh4D/AGqf+Ei8c+K/+Ed+I/hvV/8AhG/B nh//AIQSz/tzxZrn2P8Asvw7o/2u1/tPWLqzsvtMHn+at18t4Wpwr4mlXxCrwo4SVL3sVyxeV0MV TwUEnRVlCni6lGcm+edGU6M5unWxMa3DheKPFrMa2V5XmGBy15c6iwFblp5SqiwmPxuXVcXLnWMl L2nNgKFSm4xahUhGrCHtqdCdL5g8U6Fonij/AILOeLvDXibRtK8ReHfEH/BS/wAU6Lr2ga7p9pq+ i63o+p/tO6jZalpOr6VqENxY6lpuoWc01pfWF5BNa3dtLLBPFJFIyH9ebb9hD9l346eFPiR4a8Ve A4Ph/pfhv9ur9t+ZvEXwU0D4eeCPH48GfCfwJea/4a+Hen+ItR8EeIre08FWU0RFj4aOnNpVhIIp LCGzZC5+Pv2k/wDgnrrd7+2X8ffjF4Z/4KIf8E2fhn4jvf2mvir8StA0jxd+1b/wjHxH+H+tXXxT 17xPpemeJ9FHgO9/4R7xr4VvZILTW9K+1Xf9k67YXVp9on+z+Y/sviGz/bt8U6zpuv6z/wAFlP8A glFLqOk6b460u0+w/HP4N6Np7Q/EzTk0nxzeX2jaL+zzp+j6rrniDT4xbXHiTVLC88Q2yvLJYana SzzSSaZniHjcvyyOW5jRwuIoZTjcO51ljaapYuvPh/GYDEQVHCV41vY18pqUasZqCp0sXKrTda1T D1HwxgqGS5pxDT4o4WxmbYLGcX4XMvZ4P+wcS8XlNKPEOAzTA1J4zOsBVwrxGHzeliKDpup7WthY 0qv1WXJiaX1v+zd/wTl/ZR+FHxO8UfDbWPBkfxg8IaT+1B8M9L0Fvi14R+EfirxPLovjf9k3VfiM dD8SeJ5PhrDqt/otj4guRdNouiXHh7RLy4s9PvbjS3vreW6uPzp/4JP/AAL+Bn7RvxE/a7+C3iH4 a+CdbbSfiF8F/ih4Au/Gnhnwt4i8UeGvhx8Pfj9AvxE8P2mt3OjQyQ6brvgrUbDRfFdjpcen6Rrd tugvNMezkFqvrNvpf7dNp4gufFVt/wAFlf8AglNBr134w8L+PbnUI/j18IlMvirwb4H/AOFb+HNT a3/4Z9+yCOx8FE6HLpi240nUo2e81SxvdRdrw+HfCH9lr4//AAF+JXjb4vfCP/gq/wD8EovBXxB+ ImkeKdA8X65YftL+Cby31PR/Geq2uteIrCDQdW+C+oeHNHhvNTsrW6tjomkabJpPkRw6O9hbr5Vc OGWOpyzatXzrD18RispwFHAScsy5I5rldHKsRgsRi7YCLdGrmuXxliq0FPEPBXg4VfrFWjT9rHYv JZVOC6WW8CY3C4HJc1q189o1KHDEpYrLcxnn9DNsPgU8/q+0csBm9NYTC4iphsJDEwk06EaVOdT9 Pv2g/wDgmr+yn4/8Q6L8L9O8F+HvAui+Kp/2lP2wbXVfg/pnwo+GnjjXvh14f034YaH4H+G2jfED xX4cuvDfgvwD/bPxCk1G3sdXg/4RPSY9NMqW1g8rahbeCXf/AASo/Zmj+HXi74cXniLxHrnhH4Sf Hf8AaD8Rnxz4RtvhFp/xY8X+CvA37PXhj4geH/Bd18Vl+GWsXjLBq3iCO21FLm21bwvFPZ3l3pfh bTr64jmtvOfFXwI/4KD/AAg+J3g22+IH/BVj/gmx8P8A4o/A34VRfBHQvCvxD+M/gvRNY8NfCzXd I0TUIPCPizwH4u/Z8hg8QWms6ND4d1aK98eaFrWrajappGrLqE2bS6Pc/Bq8/ai8DfE2Dxt8Uf8A gql/wTA+LXhu48V+P/HXiDwpa/tf/DbwTf6z4v8AiF4IHgPVtWHiGf8AZk8Z6eljDotvplvbeEtX 8J694Ht7bTbaGx8M2M8VteWvJSoY/D4T2GD4jpVqMMnxVHDzqfXp1K+Pw2b4WrkOMfNg503V/wBX sDhMLXm6saazGpWbdXDzeLj7NfF8K5hnNCvm/hpjMBWqcSYWWbRaySnSoZLjcrxMeI8uqrDZzHFQ p0OJsxx1WhSw+CeIqZPhsLLlpY+MsDL1XRf+CUv7H0nw/wDiz+zlJZ+OyP8Ahofw5L4H+MU8fwvv fjXowuf2O7b4zN4X1nxu3w3tRefD59Xh1L7V4X0jTNH+13UllcG9huUuL2T8Wf8Agrh8PPhB8M/2 jPh54f8Agz4Cs/h74evP2a/gn4i1LR9OtdCsbO91jXNAuLt9YlttA0bRbZ9Zv7I2R8Q6jNDLNq2s R3WoA28U8drD+s3xi8UftYeNvjB40+I/wp/4Khf8Emvgn4Z8UeK9L8Y6f4Ctv2pfh78QTo+uab8J ofgu2pXPijxV+zyt5qt7feCBeWN3FDp2kaGk1617Y6FZ39vb3ifBvxo/Yp+Lf7Q2s+GPEHxh/wCC pn/BKDxfrfg7wToHw70DUz+1B4W0C7t/CHheOaHQtMvZPDHwg0X+2p7CKeSJdX1sajrdxFsjutRn SKIJ1ZRPHxzDB5jmOapUXSyutiMDOrjKteGMp5Di8szD2qpYaWFrSnXeVuHJiJ0ZrD1sQnCskq/g 8dUchxvD1fh/hbhCrTx1GhWwFHOYYTIsLhMVQp8QYDNcLLDzrZusyw1F0v7Yd6mCpYmMsVSwk6bw 85Sw/rfx1/Zw0X9qD47f8E1vAfi/U9c0X4feG/8AgjV+z/8AFD4jap4ZlsIPEdt4O+HfhX4qeIL6 DQ59T07V9Pt9T1W+g07RrW6vNL1G3tH1H7XJY3Yg+zyeR/s3/wDBGnxT8QfF37NOt/GL4s/DTw18 JP2idOtfEuneHfBXj67uPjdp/hnxJ8P/ABT428IzW9lrnw0fwdq1zJJoVrp+vXHh+88Q2mkyzyRa gumSSxPF9R/tI/Ffwp+xz+1/+wPpXxC8W+HvEnw1uv8Agkh8Jf2c/iJ8RPhpdXfjTwpf+F/FOnfF 7wU3xF8B39hbWt74q8JJrFtpHizSL6z037drnhdPPsNMN9dW1sPnP4Xf8FltE+Dvw/8A2bPhvo37 LGheIE/Zw8QaPqcPiJvixqdvYeJJNJ8FeLfA+sat4I0XVfhtf6l8Lr/x9D4m/t3xMf7W8SWFxewz hdAtJdQuJIvQdTP3gKSyOHtI1sry6FFvkhThWxGY8WU82r+0rzpQhiMPh3w5Wgr1JciSw1CpUljX HwquG8OaecZhPjavHD43CZvnEq9O+Kq1a0sJkPAlXhvBzw+XYfF16mX4vFR4sw9eolQoe0k/reKp 8uW38nh/4I3/ABl1PXPAelaZ+0J+yZaN8VPCb/EHwFpuufEjx7beKL7wXd65aaF4fv7jwzb/AAkm 1+7utdvr+2tbGLQdI1WKSeK/aV7aCxupIaGvf8EZP2p/D3w48ffEO+8Z/AeSX4ej4uTX/gS28X+N JPHGt2PwU8W2/g7xpqPh2CT4cReGLuzGoX2m3Wl/b/FGmXN1YapY/abay1B5dPh9Q8G/8FjNM8F/ FnwH8R9N/ZouksfAP7Llr+zNpFhbfGxbLxfaWVj46i8Y2/i7R/Hi/CSY6LcXVnCvh3WdJh8NXEmp WTzTxa1YmT7MvU+M/wDgt5P4o8M/EDQbP9mhNJufG3h79pbRbbUZvjGdTi0a4/aG8b+FfGkV/LYr 8K9POqR+DZfDK2DWQvNOPiNLw3H2vQTb+RPvTqcaRq4SDw8JYeVPMnialSWXe1pSoY7Fwyum1HEN VKmLwFHB1sTUhzwjPFzh/s9SjK2GKwvgDVWa1KOaYylWWMway2nTpcSKjWw+IyGGJzCq4yyp+xp4 TP6tTAYejJwqOhhvbJV6FWNVejQf8ETPCHgj4YWr/FD4h3viX40adpP7Q+oeNLH4XfEa0sfh3oFz 8KvAmk+MPDWkRT+J/gRf+I5tdiOqwR+LNNdf7P1CGaJdF8QaZt+1S/MHiD/giJ+1T4f1vwPojfEj 9nPVm8ZeINW8N32o6R4x+Isth4Dv9G+E9z8abl/GyXvwnsdTit5PA0CXVv8A8Ixp3ii5e9vLK2e2 iScTr7z41/4Lnab4p/t6Ww/ZQuNGufFGn/Goa7JN8exqsMuvfGbwFoXge+1TT4P+FMae9lp+iLoM GpW+jyz3st75r2b6tbFftbd38P8A/gtj4N8e/GDwRH8RfhDp3wj8BSfEnXPGPi3xXqnxE8T+NLO0 0i//AGWn/Z+OhPYeDfg9ceJrdr68s7TXl8Q6Tomvz6cbw6a3hq9ht5NVbz6b4/prHYmVClKvLJ6N enQqVcJUwkc2owqOvhaFKniXWWGcqs5RcP8AaMRChQpxlKtJUpetWo/R5x0Moy+lmNahGlnGLwtT FUcPnWDxdfKa+Nyilg8Vj8Zissp4N4z6lDHVJyrTp4LCYmdec/Z4dwm/g/4sf8E1dU+DPwR/aH8Q +J/G2j+Jfiz8BLT9nr4mTT/D7V9S1X4X+KPgh+0AuuaVpN3ZReKPAXg7xfZ+MdE13TbG/vZborpU ui6ibVNPF9btdPa/4Kq/843v+0Uf7H3/AL0Svpz9uH9vX9m3xh4K/ar8N/AbxRe+Krn42+DP2Rvg b4fgGheNNOsLDwJ8BtO1jxN4s8VLqfi7w74Wvb2zvde1HS/BujW+p6RpfiC+bT9T1y90PT9Pks2u e+/bE/Yq/wCGj/A3/BPPxx/w1r+xL8Bv7K/4JnfsmeFP+EQ/aS+PP/CrvHOpfYdH8T6v/wAJJpXh /wD4RTXPtnhO8/t3+y7HWPtcf2jWNH12y+zJ/Z/mzdWCzHGrMIYrOViMNReNrRwSxOGnRqKjLI8s 0jRhTuoyq8867SajmEsdT9yMIwj4+d8OZFPJc1yngmeBzLExynKamYyy3MsPi8LUqU+J80cKk8ZV rxi8TGDnShCcoyeVUspquM6tapVqfzk1/TNqv7Onw88d+Hv2Yv2PfCv7Ifga98J/FP8AZ3/Yc8d+ Ov2tfB3h7w9ofxW+DXin4weNtVh8Z+LPEnjF/Cuta343g8fQQS+HNC8OaprmnaLo13EkqwXVnDHZ 2/56/wDDqr/rJD/wSj/8TB//ABd19q6d8PP2zdJ+HHgT4T6b/wAFkv8Agl1ZeB/hrd+BbvwbY2/7 TXgNNY0wfDHXB4k+H+n3fjAfBH/hMtd0LwlrQW90Xw54g1/VdAtdkdsNNNpHHAvq5tj8HjaWXQw+ Kpf7NneXY/EQrLMKNOphMPDEwqpTwtJVp1qU8RRxWHw7nSoYitQhTxNaFJy5vn+CsizTIa2eTzbJ cXUhmOQ4nLsJPBLhnH1YYmpi8FX9jVhm+MlhqGExuHw9fA4vFU6WIxNChiJTw+HqVLOPSeMv+CSn 7Ffhb4W/EX42t4z/AGoV8E6B4TA8NeHx4m+FF/4pj8cWnx58VfAu7m1y/wD+FZaVpOoeFb/VLDQN XtrawttJ1bTLE6x515qs8lnbQ/JH/BUb/gnD8Gv2IvCHw61z4X+OfG+vavq3j/xJ8PfF+j+O/F3w 68TXV3Jo/hvQ9csPF2h6f4E0PRr3wjpl/NeanaTeGvFrX+uWgTT5ZLjyrhJbn6f+JHgn9tD4taD4 x8L+PP8AgsP/AMEo9U8PePvD2heFvFGkad8fvhT4XsbvRfDfiy98daTDYQ+FPgFog0C8j8W6jd63 e6v4eOlaxq91Iqavf31vDBDHnftN/sgftqftE+AfhLrn7TH/AAU+/wCCa/iD4a3t14u1D4ReI9X+ O/h/wL4T8Z6posum+GPHGs6J4i8M/Arwvp3xI1zRLm003QvEut3N94j1bR7wrYaheWtzdyxzfN4O vm1DEYCpi+I8POCzHESxNFyxs1WwDlQrYWhSU8tpOpiaVBY6hVUnCnUpVqeJk5V8LSnS++zvLeE8 flWeYfJvDbMKGMllGCjl+P8AZ5Dh1hMxWEpYPHYvF+x4mxn1fB4nM3hMTh3T9rOjVvhY/ucdXo1P q5v2d/2cbqw8S/A9v2efgXDo3wZ+Bf8AwTw+Kvhrx5bfDTw3F8SvEPiz4m/EXSbL4gN438cm2fV/ GmkeM7FpbDUdD12e90qS3nmhW1dCqJ8j/wDBUr4f/CB/2efjB4o8M/BH4JfCnxL8Gv8Agop4r+AP hDVfhJ8L/B3wxvNb+GcXwosfFEek+JV8JaXpUXiW4sNWufNiv7yKWe3WFArRtJdNcadx4B/bOuvh 14T+FE//AAWM/wCCWD+CPBQ+H0ehWA/aO+HCaubT4Varb638PNM13xdH8C18YeLdG8K6paW11pui eK9e1vSCYY4rmyngHlVy37Q/wK/ah/aq0fSPD3x1/wCCtv8AwSe8X6HoniLUvF9jpOmftD/DfwFp 8nirV7VLHUfEmqWvw6+BnhOLXNcuLNPs39qa2uoXsMEk8cE0S3E4kj2FZ5p9beb0Z4d5pisXZzzK NTkrZvw5j4YtUlgnSji6uAyvH5PWwkaioUsPjVUhi6qqV6C7sXmOCrcK4rJ6PBmOhmNbJqGBp13h uFY0VUhw9xFlSy+eKhnjxX1HA5rmuAz7C472M8RicTgpQq4DDTjSxD/nzr9XP+cHH/eVz/30Oj/h 1V/1kh/4JR/+Jg//AIu6+g/2kv2f/wDhnD/gjjpXgf8A4Xb+z58ef7V/4KY2Piv/AIS/9m34k/8A C0fA2m/bv2Wtd0j/AIRvVfEH9i6H9j8WWf8AYX9qX2j/AGST7Po+saFe/aX/ALQ8qH6vG5ngcVUy 2lQr+0qPNMJJR9nWjdR523edOMdE11v2Px7I+Fs9ynDcUYzMMD9Xw8eFM3pup9awdW06jwyguShi KlTV9VGy6tHmn/BO39vr9mz9kf4Y61pHxB8B/Fy78fXvijxfdeJIfh9Z+Edc8AfHv4c+IPAV14e0 f4X/ABi07xp4v0uDSdL8NeJ7ubxDpeu+H/DWuatbxy3NrFi31DVbPUfrX4a/8Fif2Y/B3w4+DfhD UPh58bob/wCHvhD9i3QNXh0fw34CuNIW6/Zz+Jninxn41i0O4u/iXY3dzp97pWt2ll4QlvrLT59Q vIJo9ZttBgWO5lyv+CZn/BOX9m79r39ifVPFnjHwV9p+ONx+0nbeGdH8Z/8ACY+N9KMfw28L33wj 13xzoaaFp3iWz8KSySeDNY8ZNHqE+iSazE1z51tqEMtnaS23pfxp/wCCMPwI+M/7T3xI8F/s0+PL j4E+D/Cvw5+GXiPQPBlj4H+Ifxm0+7k8X+DvE3il/FXivx74t+I1ovg3QtYn0i00XS4jq/iTU73U Zp207w2lnZXE8nhZ3jeGaGdY3+1VmFPE4WvkeY4yvBSnhcPDh/BUc2yrEunRnUxEsNN5hWpOEcPU nPE4bHt06OGhLEVv0rhLLfFqXAuUz4YqcM4nKczwGb5Tl+Xz9jRzXExz/HVsHmeHlWx9HC4GljKS yulXlUePowqYatgI+0xmMjSw+GoX/wDwWz/Z0vvh/wCEdFX4efGmw8S6R8SPhld63FZeDfhD9g1H 4e/Dv9pRvjAl1L4wufFdx4y1DXLnwskVvYeBAujeF9L8W3WpPH4qls7qfU7jm5v+CwP7LN/8OviT ol74L+P9t4r1vT/2xPDfhGG18J/Dq58PXOiftJfGnTfiv4f1TxHqUvxUtdS0jVdAg0uHSNZ0vTNH 160Ms8lzZapdpEqSa+q/8ESvhb8a9a+HS/BT4neIPhlocX7N/wCzVr/iuRPhd4m+J954p+Jnxgi8 XmTxhqFpcfE+2bwT4XvIPDZ1HxLLb3U+ieEVeGGysLuF7iePxn4P/wDBKj4TeGNN0DU/iv8AFXSf iJ44+IH7M37Q3xW0/wCEF58PPHeiab4Mm+E6anpD+Krf4h+Dvi3oK69caV4nsrC107TdQsYbPUYt TubrUPDt7aacEn4/+MLy6GMtPGwr5bjM7xDwqjiZYqeJWWYh432ClT9nOFfKMqxOJputVhSwmExX t8XLBKpQdD2ZVfHnNa2By6rDIJ4HNaOQ4ZZhOvlNPLacK2KwmUYKeImsSsXCthszznB5XXhh8LUq 4jMcEqGDo42pRruv7v47/wCC0v7LnifS/jVZad4C+PkU/wAR7D9pa20Jr7wv8PIobWX4yfD3wL4T 8LnV3g+Kdy9vHY6l4Yv5tfazj1BrSxmtJdOTVbiSa2g5j/gr7+0V8APi1+yr4OT4bfEzwl4m8dfE z9o3w18X9f8ABWg+Pvhz431HwzY6b+zpoHgG+nuIvAHinxJdaHpS6hp1hY21v43t/DHiqfVf7Wjl 8O2tpZxTSJ8JP+CM3wv8D+MPgr4w+JfxAuvj58Lvix4W+L9ufDWpfD/x18EGh8Q+GvgdrXxH8MeK fD2p2fxAbxT4h8LR6lp80dne6lYeEf7WOnx3LaLf6NqCFvzh/ba/4J8aD+yB8K/gt8SdM/aCsPi5 J8YLXS9QstMsPhtqnhbRJdH1Twnp/iVPEXgrxqvijxTovjfQbK6vH0HUjPH4V1+xvltLifw8lnqE MqFDB8J0swy/B4LFY2jXwVPh/C05To4mpCrGhjsR9TyuSqUo1KWJ9twrDEYurVpKj9WhCdOs5PE/ V+DN888Xq3CefYjP8pyXE5dmEOLsRiFSxmW4fFZdDH4LJMVmmdpUMXUpYvC16XFmHw2X4bD4irio YlYiFbC04LCvFdd/zg4/7yuf++h19W/sCf8ABXf4PfskfA74HfBzxb4K+KfiC18Jy/HqP4nN4e0L wZe2U8Xj/VtL8R/D3U/B76x420m41HVNF1bSRa63FqsXh6GysdTvbnTbrVbiCG3l5X9m39n/AP4a P/4I46r4H/4Xb+z58Bv7K/4KY33iv/hL/wBpL4k/8Ku8Dal9h/Za0LSP+Eb0rxB/YuufbPFl5/bv 9qWOj/ZI/tGj6Prt79pT+z/Km+fP+HVX/WSH/glH/wCJg/8A4u69rELJ8dhs4ynNaklSr5njPaQh Gup2qUPYKUalOnJRkoV5uLTvGfLL7J8dgZca5HjuFOJ+E8NRlXp8IZThoV688BOm0q0qtWnKhisR TbUpUYQk3C0qcpxT1uv0i+Gn/Baz9ljwUvw21y/+Hv7QFx4qTQfgH4Z+KNjZ+G/h1L4f07T/AIG+ APiD4ct77wDezfE611HXbzxBrni2xlmtfEVl4cgsdKiu5EuZ7yGGC78yX/grx+zYPBfgLw4fBHxw +3eFtE/YA03UJf8AhGvAX2Waf9lT4v6x8QPiG9m//Cy/Oki1nRtQhtvBjTwW76jqayw65H4dtVS9 f4q/4dVf9ZIf+CUf/iYP/wCLuj/h1V/1kh/4JR/+Jg//AIu6yWB4VWLqY321f29bNMuzibbxXK8Z ldeniMG1H2NlShONOMqe04JRk73Z6suLfGGWBeXfUMsjhZZVi8ncIwylSeEx3114p831+/tqs8xx dR1Ok6icUlGMV93+Nv8AgsL+yx4q+G/jbwTJ8OPjtfN4p0n46aYbS60fwTpFjdwfFH9puz+Mul2d 1q+m/E251TS4x4Qgn0nV7/T7O5u9N1+VE0yLUbNBqg0vjf8A8Fiv2UPHmha74f8ABXgH44aXp1z+ zP8AtY/BLw9Y3Pw5+FPhTTdF1H46a18P9S8BWi6f4b+KmpWx8O+FrDwre6Z4j10I+u6hMtnq6aRq N3qV/HZfFWkf8EbfHPiDwv4v8caD+3d/wTO1vwV8Pf8AhH/+E+8X6R+0/rGpeF/A/wDwlmoy6R4W /wCEv8QWXwvm0nw1/wAJLq0M2l+H/wC2ruy/tnUYpbLTvtNzG8Q5P/h1V/1kh/4JR/8AiYP/AOLu uRZPwdKnGisRiJRorM6Tip4ptPOKOOhi1NKjpP2Wb4p0W0pUo1ouPuvXsXGnjXQrTxcsuy2NTHSy 3Exqzw+Ux9rHKJ4ejhZUZ/XYylQVXLKca8IzlRq18O3OPtaUXT6v9hb9vD9nX4F/B3wF8OPj14X+ NN/qnwU/avs/2q/hre/CXTvA+p6d4j1q38Cp4TPhDxsfF/inw3daLpi3dtBfjVdEh1m6mgnlh+yW 72ytdfQP/D1b9m2X4W6Zrlx4O+Oi/tE6F8BP2rPhFpGi2+g/D5fg+ur/ALTnxDu/GVzrt54rm8eT eL5rTwtaSW1tBbp4Fja+uDcpJEkYhuB8p/8ADqr/AKyQ/wDBKP8A8TB//F3R/wAOqv8ArJD/AMEo /wDxMH/8XdehmOH4azWriKuLxFdyxMpSnGn9ahCLr5JPh3F8kfYtRWOyiqsJib30hCrQdGspVJfO 5HmXilw9hcDhMtyzLowy+hRw9CdaOUVqso4TP8PxPl0603jV7SpludYaGLwcmre9OjiI4ijywgf8 Eqv+ckP/AGij/bB/953Sf8E2/wDgoH4O/Yb8MfHCHWvDvjDXvFHxH8Yfs8atoCaBpnh++0NvDXw4 8aa7f/EvR/ENzrPiHSrqyn8R+CfEGo6NoR0/TdXinvrmRNRk0y2UXLfbf7Hf7FX/AAzh4G/4KGeO P+Gtf2Jfjz/av/BM79rPwp/wiH7Nvx5/4Wj45037do/hjV/+Ek1Xw/8A8Ipof2PwnZ/2F/Zd9rH2 uT7PrGsaFZfZn/tDzYfz3/4JMeA/A/xH/bAsPDPxD8GeFPHnht/hD8ctTfw/4z8O6R4o0R9S0j4Y eItQ0rUG0nXLO+sGvdMv4Ib3T7s25nsruGK5tpIpo0cdFTF4OvheLsXJPFYHCZfRzXEUoqVOWJhw /ho8QLDr2kY2VatldKlJTjyThOUJ3hKRyYHBcQZLmHhPl2GnSyvPMxznH5Hg8RX9li6OEnxTnFDh 6OLqRw9SpGcaNPNJ1uWE/aRcE4pSSR+p/iz/AILX/sueIJfifr1v8Ovj3B4ikufj7bfCmwk8OfDx ND1HSfjf4K8F6H5/xAu0+Jst94fv/D+s+H9RYWfhu08TW15pb2Un2yG7mnt7WPxF/wAFqP2WtX8Q eO9VtvAPx/S38T+OvjH4nsEn8LfDpZobD4hfs2+Gfg7osN4sfxUlSO8tfE2i3V9qkcMlxDDoUlvd Wlxe6g8mmRb3hH/git+xxrc3hDTNQ8b/ALTH9peK9Q+E2gtdWfjT4W21jpuqfEr4F6t8V5r9bWb4 O3txf6fpeo6HcWEdibuxuJ7K/hha+Wewe+1D42/aN/4Jl/AT4T/sLyftE+EfFnxeuviloXwo/Zv+ Jmv23iPXvBl94A1X/hd3jDxN4O1XStI8P6Z4B0fxFo/9j3Hh06lp9ze+Mdb3Q3QsrmKeSL7XJ8nP CcEOOIy1xzFRhh8BwZVSlVf7rNq+DpUacZu7cpV8uw9Wtibe660nBOMnCl+qVcZ47U8JR4gqT4bl QwU8w8SINRwvNGWEWZ1q1WVKKi5c0a+Nw+HwadrYSmpunenVxHL/APBPRPg+lz+3mPg7c/Eq6tG/ 4Iz/ALTrePW+Jdj4XsLmL4nGHwD/AMJfB4QTwtqOoxXHgOO4+zf8I3day9t4glhM/wDadnC6x7vz O+Bfxq+I/wAKdQ8VeGfBHxCuPhz4d+Neh2nwu+KesWnhzQPEd1J4A1XW9OutT+zRazaPeWVxYS2s Opw3Ph/VfD2svJaLbwa1ZpK7j7n/AOCVX/OSH/tFH+2D/wC87r8owSCCOCDkH0Ir9Cy6FKOa5tGv GWIoSrYOValOV/aUatOc6mHTtpT9nOVGmmny0lGLcmm3/PudYzER4c4LxWEmsBiaUM8VCrguehKj Vo4zD0o14OE+eNabh7arKM481ac5JRUuVf1ZfFL4c/8ABVTwpcfH65+Hn7XV58W/iRffHjQ/g7pO iP8AAb4A+CYviJpGm/s36V4x1X4w2/jTxdfDw98GV8OfDLXZfDWparplzbX2qGKI3ni0311bxp8b +IPF/wDwUk/Z9/Zt+I/xX+IHx9uPhx43/Zs+L/7Of7Pv/CnLj4Q/A/xMV0/wL4OuvF3wh8QQfEXT bLVtJ1C08L6Z4nuDarb6d4ii8WQagl3rniHUjDBFD75Z/wDBb/4IzXf7NC618NPifc2nhr4L+OvB n7SN03hb4fax/wAJD8SPFXwt8BfD+x8WeEPDWs+OJNF8daLat4Qube/0zxtceEhe6JqCwy2kx860 by79rj9tv4NfFLw58S/h18evhL+2F8L/AAV+0J8bvgX8bfCms6p8MPh94W8Xa58CvAXwp03wCfEH hyw1bXfD/heTU9c1TSZJvDsejWmu+D/7LG1/Fk91C0J+Dhhc9wtWng6uT5bVo1a3DqqY5ZZlsK1f EZFn+U5fialGnTo06Hs6uW4fP8/wVKph54rBUMzqYjLK2EhhIUKP71jcw4DzHL8RmuA464mo4/B5 LxXChlM+J+Ja2XYGrxFwxmmYZZSxGJxGKr4uk6ecY/JOG8VWp5jHK8dVyPDZfnOEx2KzHEYjEeVf 8Emvj98V/jl/wU8/Y1g+J/iSy8Qx+BrL9oTT/DJtfCfg3w1NZ2viP4K/GLxHrK3dx4U8P6HPrU15 rN5c3n2rXJNSurbzWtrSaC0CwL86f8Er/AfgLxf8afjR4i8e+BvB/wARo/g/+yd8ePjB4U8J+P8A QbLxX4NvvGvhDRdOj0GbxB4W1RJdL8QWVm2qXNyNN1G3ubVriOG48oT28MsXd/8ABF0aKP8Agq5+ z0PDb6pJ4dGqfHgaBJrkdpDrT6KPgL8XhpT6xFYSz2MWqNY+Q2oR2U01ol2ZltpZIQjn0f4JfsP/ ABX/AGc/Htn8Tfgz/wAFUP8AglX4L8aWWnaro66nH+1fomuWd5o+uWb2OraRrHh/xN8KNa8Oa7pV /bPtuNN1rSdQsnljguBALm2t5YvfxMsHhZ55gcNKGUTzHheFHA+yw06KwuMx74kisRKnhqd6NSnj MZHEVpRSq+1dSpHnq3b/AD7IY5rmGF4Jz3MqFfi2hkXiVnWJzr2+Pw2Mq4/AZdgPDmEMPCrmuJhD GUp4HL5YbCU6lR4f2FKjQm6VBxt9UfD3/gnl8IP233+Kvxc+Jv7P/wAUP2JPFo0DSv8AhHPAfw+1 r4XeGfg5JqNl8EIvHNj4n0LwxqfgC21rXL3x9cW03iS9+HfgvT/D1l4Q8Lx3WqXvieae7hDV/Dn/ AARz/Zi8SfDn4B+J7HxB+03qPiPxvoH7N/iPx9o/h7XvhZqp1aH44fDrxj4n1HTfA1nqXgDw9b+E U0PXPDNu8niLxb4i8SabpPhmbULzUrS7lsPtEtvTov289Lv/ABnqdr/wWZ/4JTSXnj7VRrfiJtR+ O3wd1eBdSHgyL4eef4cs9W/Z6vbPwVGfBMMfhprXwXB4ftG0xTE0BZmdvUfiR4j/AGoda0v9n3w9 8HP+Cnn/AASp+CHhr4BfDr4ZeGLDR7L9rjwF41bxL43+HXhPWfBT+PtU1PW/2c7LUp9P1vQNbu7L /hXuuXHiTwvpiyTSqL66na5Xwa1bNoe0hgM1wuEo1cRw4sJh6NXMatHLqOCo5pVzuM54vBSqTw+M q1MvwmHjSjUc7U6k8Jg6FKpGH6Bh8HwZXhTr5twdmmY43D5ZxRDMMXjcJwzQxee5jmU8lw/DtenT yrPKODw9fLY0cyzDGVK0sM4wnUpU8RmWJrrn8o8Rf8EeP2RvBHiz4u3Pif4g/tM638PfDXhH9nm/ 8E2Xwqi8LfFPxzHr/wAbdO8cS3V3dJ4O+FeqyfE7w3pF54Ws5rGPwV4S8OXV3o95d6jNqCWtsbtf pjxv+wl+yj4r+BHh7wVd/CbWT4u8YT/sI6R/wm3wm+Hnwf8ADXxOtoPH3hW4u9bi8PQweBvD9nYX uvmw1uXxnrXia8uJp3udN1zxPqF5b+HL6K/8D8JeG/8AgofqvxCuZ/Af/BX/AP4Jdah8Qvido/gP 4UWuheD/AIx/Ci5vNct/D02raP8ADrw54N8F6J+zm9jp/iWzn8W6lpHhy98HaLYeK531ODTba9m8 qwghpXfgz/goN8Pdb1Dwvq3/AAV+/wCCYPhTxN4PvvAXhfVtB8QfG74Z6f4i8Max8BLm80rwlpGp 6frP7PSaro+veErj+0NG1+G8it9W1lftmkeNP7Xi861rOsszxEvZ1eIcPP2ea8PY/DwVTHp08Flm Jp1MdQcf7Mc5VcQ4zkq9SdWOJ9usNiYwp4ZTrb4R8K4CNethPDjMaVDF5RxNlOJqywnDlRTxubUM dDLq3tJcUfV1DDUMRgqc8JSo0J4X6lUxeFrTnjqlOlv6f/wRY/ZFg+L/AIm8K6748/aEufBkXw1/ ZX8V+HofDXxC+Eupa3Y+IP2gfit4q+F+r22o+MIfhPe+GfFWh6Jc6Vpep6Zd6HoOjGaH+0E+1aik 9pLDyN7/AMEZP2X7PxH8I/hY3xK/aWk+JHxA8a6dNqHiiw8J6VrPwtg+Hdx8TfiB4XvdJvtX0v4f zaf8PPHA8M+DYG0PWPGfjCfSvEviSe5j0fwvcRJJptmTWH7dE2vXHiUf8FjP+CS9tq9zpHw20B5L D40fBLTbKPRvhD4wvvHnw50600jT/wBnS10iwtfDPirUbzUoEsrC3+3RSrpmqm/0iGCwiiudO/by utH0XQpP+C0v/BL2PT/D3jm3+I2lG0/aS+G9jfxeKbTxVq3jWzkutYsvgTb6vqegWfiXXNVv7Pwb qd9eeDbWK7Om2+gR6VFBZRbQqZ5zYSUuI6CVPMadXExh9eanl8J4eVOlD2uWVFKpB+2lVp1EljKf JhquJp+0eIoZYrD+Hc6WZQw3hhmcZ18DWpYCpW/sFOji6uGw0J1KiocWw9mp1aeJVGvTc/7PlXhi 6OEr+yeCqfl//wAFKP2RPhn+x/8AFf4eeFfhT4m8R674b8d/CrSPHV3pni/xd4F8deJPCevza5r2 iaroF/4o+HGl6P4T1WKJ9IhubWbTrFNqzyRvNcBEmb0X/gt9/wApQv2nf+6Lf+s9fCavc/j9+x78 a/2oPF2m+Ofjl/wVW/4JS+NPEejeHrHwno00P7UPhXwnpej+HdOnu7q00rSvDngn4P8Ahzw3ptul zfXdxIbLSYJbmed5bmSaTDD6S/4Kn/8ABP8A/wCF2/t4/Hb4n/8ADbP/AAT6+EX/AAk3/Csf+Lef HD9pH/hAfih4e/sX4N/Dzw9/xU/hL/hDNW/sn+1v7J/tzRf+Jhcfb/D2p6Tqf7r7Z5Efp5XmCw9f Ko5pmFPFYulgM/jXxFKGKnBrEZrllbB04yqYalVn7PCKFJylTunSfPObanP4rifhqpmOXcYVOFuG 62UZRjOJ+Aq+W5ZiMTldOtThgeGeLcLmVWcaOZ4vD0/a5jWliI044mV44mPs4QjCdOl/M9RX6uf8 Oqv+skP/AASj/wDEwf8A8XdH/Dqr/rJD/wAEo/8AxMH/APF3X039t5Z/0Ff+UcR5f9OvNH5h/qJx X/0Kv/L7Lf8A5sP15/Zl/YK+Dmsf8E2f2W/E3jj4DeEtc8eap8V/gj8avFnj8+DPDTeJ/FHgDxt+ 0LB4ck8B33jPUNC1DUL3w9/wrfUdM1LWfC13LPpM+ny5NqkkwuY+6+M3/BN39jX46yeHPDvhj4ba r8JrTwn4y/bx8aeIZ/hpf/CH4f8AiLxjafCT4maL4TsvBA8X+IPBEPhfw74ZtNa8Rac/gqXxLHca X4L8J2N9o17Pcy3i65YfEXh34eftj+E9V0vWfDv/AAWF/wCCVGl32i/B3wv8AtK8n9of4ZPZWHwn 8F6lDrHhfwzb6XP8B5dLS40fU7eK8t/E/wBjPi15Q/2jXZlllV/YPFfgL/gpZ4E1Pwlq/jj/AIKw f8ExfBt74p0rXviv4NHiv4i/Cjw9Y+MfCfxpjkTWvF2laXrH7M1npfi/4ffESbTJNQjkSz1TwXrO saadcsIpNYsRfRfB42GLq5ricXQzzC0qWJzPPszwtGU8zpToSxtPCYPLMJCEMLKE8NgsFgMHiakY 8qp4mpiaMYVoSeLn/SmT4/h2hw7gcrx/h1m+Mlgsp4XybMsTClwrWp4vD5bgsxlmWLqVnnNGphsZ mOd5tjJQm3KVfC08O5VcPyU8DQ5jS/8AgjJ+yfNafH6yuPij8cdX1bwV8Vvix4F+GWu+HPFXw1m8 N/2T4L/Z78PfG/Q7jxnZt8ObyfXtSS41W80DXJPDut+HrW9+zxSWVtpLiVizxj/wRk/Zj8N+LvBO iaZ4j/aY8SW3iD46J8Nb/T9J8SfChtVfw9/wyfafHaS9XV9X8A6FoHhp7fxZcSWup+Ktaa+0fSPC ELxvoN9q4S/lwrbw7+3Day+Kp0/4LK/8ErZZ/Gvi7xb468Sz3n7Qvwtv5tR8T+OfBMPw58TX6S33 wEuHsLe88FW1v4fs9I01rPRtEtYIZdD0/TbuJLhdq8T9vPULnwjeXn/BZb/glBNdeB9XfXdBnPxv +C6SPq0ngK7+GE954hMf7Oyf8Jk1z4CvJvDd5F4wGuwXlmtrLdRTXljZXNvUauexaf8ArFhpNZJl GEtJ4/l/tfD4bDRzPGv/AITNaeJxFKbg7KVWGInUnSoSj7KXlxw3ADpSpz8M8y53nef4qNSEeHlJ ZNjc0oYjJ8G/+MpVq2Cy/wCs0JxTcaMnSpUq9eH7+n9c+Af+Cb/7IHwWu/DPwttfB3/Cyrm9/bV+ GulaV8QviJo/wg+Iuut4W8Yfs0T+PZvCGo32q/DCXw94o8ErLHqdxFYNoFvYX2sS6P4gjt4ZLFo5 /kA/8Eev2a/EWneELhvHHxmsfHGt337Kfjnx2dN1P4ead4FPgf8Aao+NHiPwDL4c8CaDB8OWv/Dv iDwfpekm4stR1HUda0KW58uNNAjs2FtbWD/w3mdXl10/8Fk/+CTX9pyeKPC/jRZh8aPgiILXxP4N 8Np4P8N6tp1iP2chYaXNp/hhF0V4dNtrW1v7IGPUoLxmZje1T4Pf8FFvDfwv+EM+t/8ABV3/AIJp 6F8LJ/EGm+J/g54o1f4u+ANO0bxdqnwS8atrFlHoHjy+/Z1hn+IujfDTxzf4uvDU+u+IfDnh3VLi HS9Q0q3XybMZYdZpQxVLEVuIcK6lXNcmqVpOpmMp1svweGyulmGGjCplyU6mIp4HET9gnCGI5va1 69Kc604+pjq/BuPyqtgKXhlm8qWDyDF0cMoUuG6VLCZnXzDNalLG1atDiSU6NFyzXC4aGMmq1TB1 HGnh8LVjSw9Kf5n/APBTj9i/4N/sf+Ivg2nwV174mav4d+Jfh/4hXWo2vxR1Xwtretafq/w/+Imr eBp5bLUfCfhXwfYnTtTXT1vIbSfSpbm1bO++mEoig/Lqv3Y+On7JPxz/AGlJPCcvxr/4Ks/8Eo/G kngeDxJbeF2/4ac8H+HP7Lg8XeIbrxX4hTHhP4N6Ct7/AGhr97dX+7URdvaeb9lsWtrJI7ZPA/8A h1V/1kh/4JR/+Jg//i7r6nI8yWEy2lQzfM4Y3HRxGPnPEU6eLnGVCtmGJrYGHNPCUZOVDA1cNQne mkp05JSqRSqS/E+M+FcVmvEWMx3C3DFXKMkrYbKYYfAVsRlFCdHE4fJ8Bhs0qeyo5ri6cYYnNaON xVLlrycqVeEpQpTcqNP8o6/q4/4NiP8Am97/ALtr/wDe/V+Uf/Dqr/rJD/wSj/8AEwf/AMXdf0Ff 8EJv2VP+GZP+Gpv+Mkf2Uf2g/wDhNv8AhSH/ACbD8Yf+Fsf8Ij/wjf8Awt7/AJHf/indA/sD+3/7 f/4pr/j7/tX+xdf/ANR/Z377g4vzTAYnh3MaNGvz1J/VOWPsq0b8uOws5azpxirRTerV9lrofUeD HCfEGWeJXDeOx2X+wwtD+2Pa1frWCqcvtcgzWjD3KOJqVJc1SpCPuwdr3doptfq5+3j/AMmOftm/ 9mo/tE/+qh8YV/me1/phft4/8mOftm/9mo/tE/8AqofGFf5ntcHht/uOZf8AYXS/9Mn0f0of+R9w t/2KMZ/6mo+0P2U/23vHn7Jfh74peEvDXwy+DHxR8M/F69+HOpeKdE+MegeM9esIr74Wa1qfiHwl caZF4R8e+ByjW+s6n9uuo9RbUobiSxsVWKKJLlLn6Ml/4LGftX33hD4neFNb0L4K+I5viX4k+I3i VfFGv+BdX1HX/Ac3xQGnL4m0zwLav4uTwnDpiJpkCaSPFfhjxZqOnJJcKmoyCXC/lHRX3OJyrLsZ iJ4vFYOjXxFSnGlOrUi3JwhDA00lraLdLLcBSnKKUqlLCUKVSUqcFE/Bsu414qyjBUMtyzPMfgsD hqk6tHDYepGFOFSosepSfu800nmmYSpxnKUaVTGV6lJQqTcj9l3/AOC4v7VjeI/DutL8Mv2Z4dH8 P+FPFnhRvAcHgHxzH4K1mHxj4j8K+K9T1XUrIfFH+2bXULfXPCGlXem2Xh3XNC8N2gkvYToEsVwq xeV3n/BWz9pXUtR0jVtR8KfBi7v9H8D/ALSPgGKc+FvF1sLrSP2ovFCeLPH93c29j4+tbVNT0fUI 0tvBr2UFnYabYDytY0/X5/8ASa/LyiuX/VzI+SNP+zMLyRp4uio8rSVLHU8fSxcLqSfLiKWZ46lU 11p4iUFaMaah6L8TOPXLmfFOat/WMFi9a0WvrOXVsDicFW5XDl9ph8RluCrwdv41H2suadWtKp+9 Pxh/4LfeN4PE/wAIE/Zw+HPgyx8D/DXw74NvNXi+LXg3VP8AhJvG/j7TPg1q/wAG/EC+JpPB/wAV 5rG78H2mha1dHwt/ZE3hrXPOitbjVpGSJrGTwfwZ/wAFl/2k/BCeHLOx+GH7Omq6J4R8CfBjwN4Z 8O674S+I95o+jH4Caj4g1P4ceLrNLb4sWV//AMJdptx4iuRdXUt/Lot2lnpv/Eiiktnkm/I6iiPD uTpVebBwqSrV44mrUqSm6s69KvicRhqjnGUXz4Ori68sHNWlhXPmoyhNKRpX8TuOa0oWz/FUaVPC rBUsNRhRjhqWEdDD4eth6dKdOajRxlPC0VjqSfs8ZZrERqQk4n6UePf+Cpv7RXxI+BPir9n/AMUe G/hLceGPGXgbTfAeu+JLfQPGEPjO4sNN+JOp/FMasl8/jybQo9cvfEurXcV7OfDr6e+meXBb6bbX Stev+a9FFduDy7A5f7dYHC0sMsRVlXrKlHljUqzlKUpuN7JuUpO0Ukr2SSsj53OuJM94ilhZ55mm KzOWCoxw+FlipqcqNGFHD4eMItRTaVHC4eneTbcaUbtu7f6uf8FVf+cb3/aKP9j7/wB6JXrP/BC3 xno/w6/aC/aQ8e+IrSPUPDvg39jb4q+JfENhLALlL3QNG8XfDa/1q0MBeNZTc6ZBdQojNsLuu9XX KN5N/wAFVf8AnG9/2ij/AGPv/eiV+UdefgMPHGcPVcFPl5Mfl+aYCbnD2kFHHU8XhZSnT5oe0jFV nKVPnh7RJw54c3Mvrs3zl8O+JdHPo0ZYiWT5pkmZRoQrrDTrPBYXAV1ThiHRxCoSm4WjVdCsqbak 6U7cr/va8Ufs5fs7+M/jK1nL8JPhH8aLbw94a/Ze8B69f+PvBXhXx2/gz9miH4afFWWw8T6FN4lt dQbwfa32rWNss/izRJ7a+kks7VDdKtvAU/iX+NvwS8Z/Ci80LxHq/hi80T4d/FRvE3iX4N61c3mn 3cPi7wHpniO90e01mzFpdz3cEIMMUW3U7awupcrMtuYnVz4bRXDk3DmKyfG4jE/2xWxtPEzi6tHE 0JuXs/ZVOdRqLF8irSxfs8VCt7Bxj7XMoTpVamOpV8F38ceJGWca5ZhcG+EMNk2LwXPOhjcvx9Dk deWK5k61CWTxrVMO8BUq4GeHjjablLDZNWjWp0csqYPHfq5+1z/yi9/4JC/93+/+tC+GqzfCX/BX D9pLwn4E+GPgKz8L/CJP+FcR/AvRZ/iDZeGNdsvin418Cfs8+MT4y+HPgHxV4hfxVd+HZ9B029ea 0lnsPB9jqtzaTSC6v7iWa5kuNL9rn/lF7/wSF/7v9/8AWhfDVflHXoZbhsPisGo4mjTrww3EGaY+ jCrHmhDF4TPsynh6vLtJ05Sl7srwkpOM4yi2jyeIc7zbI89hVyjMMTl9XG8CcC5fiqmFqeznVweI 4E4YdWi5WbjeVOE41IctSnOEZ05wmkz93v2dv22/2j/H3xx+Jfw6/Yj+CXwa+Itjr/xy+If7UHwb 0f8AaMn8LeHfiB8K/GPxItIfCviGTwJrmpfGn4eeDdR1lZPFD6bpeiyy+Kb7UYnOq2+ixINRtrTg Pit+1Z8VPhX49+AHwN/bk/Zw+AN9qH7Po+HiP478DXafEP476T4M8LePk8Wahpmn+KPCf7QmtfCO 18WeIdT0bU9K1+z1bRoJ9Pg1G6kuNGtHNiD8F/sLeIvD/hH9s39lrxT4r13RvDHhnw98efhfrGv+ IvEOp2Wi6Foekaf4u0u5v9U1jV9SnttP0zTrK2jkuLu+vbiC2toEeWaVI1Zh/UR+zt+0J4Qv/gt8 VvHmn6lY6zrfhb/gol44/Zr+GHibSr611TSPEHw5/af/AGq/hZ8RdTu9C1e1lktNS029sLfXLm0n 066ubWWyge6iZ4ZUJ8TMcFQyXEZHLBZdRxEIxweHVWbrLHUMXgKuV8OZBUo4/wBtKEKlbE59g8HW U8LOVTCRxmIrVK8aXsD9C4MzLMONsvz2hmHFWOyfF1MdmGJqUOTLsVw9XyzE0s04xz+GJ4f+p0K8 8PhKeR4zF4eUMz9lhsRLDUMNQw7qOcv5s9H/AG+Pit4V/a2+L/7WWgaF4L1XWvjNc/EnT/GPgHxz pV7r/gbXvAvxJMsGo+Cdes9M1XQNWudOttPTTYUuNN1nSrx59MglafyZLi2m9p1j/grT8Z/F9p8U dE+I3wL/AGXvib4N+KmrfDzU7/wF4y8G/E1vCPhaH4WeGofC3gnR/B9l4e+L/h+/s9I0nT4ftAj1 rUtevZb+WW5e+KsIl/pb8e/tEfs4+EP2sLfR/iH8f/hJp/xo8N/Cb9q3w9b+LJvjL8PvDep+BpNc /aS8Ka94J+Huq/ErxL/a+hfD/wAU2/gK2v7K38M6/a/2np2l2uqaTbadiZY5/wCRT9v7xT4G8b/t o/tJeLfhtd+GdQ8FeIPin4g1LRNR8GX41XwrqQneI6hqehaotlp8WpadqOqi+vYL+2tIrS7E5uLN pbWSGaThyTE5bncsnwc+G1Qwv+r1f6riZ1qlanhsJkHEbwWV4OnVdCjKo5ums2wOKU41qCnWjS5o VJYitvx1l/EnAtDiPMMN4kSzPF1OOZ0MxyujgsNhJ4vH8VcLSzTP8zrYb+0MfGlByl/Y2ZZfKjPD 4hxwtWvONWnDC0PTviN/wUu+OvxK/Z6uv2c9T8H/AAc0Tw9qXg34e/DbWfHXhrwp4isviZrfw1+F Ou6hr/w88A6nrl94z1PRJvD/AIXutRlt7OSLw1BrdzZoi6jrF7cS3lzdenftc/8AKL3/AIJC/wDd /v8A60L4ar8o6/Vz9rn/AJRe/wDBIX/u/wB/9aF8NV9LiMFhcHjcrnhqMaU8ZnuIxWKmnJyr4ieQ 5tCVWpKTlKU5RhG+tm7ytzSk3+cYDPs4zzJ+NHm2Pr476hwPl+CwSquKhhsLT494KcKNKEIwhGMb qKfLzckadO/JSpxj+UdFFf0C/sA/Eo/Cn/gl/wDtDeK1/aF8f/sysv7WPgjT1+JHw48Bn4i+IJDd /D22I8NSeHl8XeCium64YvLu9RGsMbFoIZBZzFt8XfmuOeW5fWxypKvKlXy2hGk5VYqU8xzXA5XB t4fD4vESVKWOVZ0sNhMVia/s/YYbD1a9SnB+Dwjw9DijO6eUVMd/Z1N5dnmY1MX7LDVfZ08kyTMc 6qQtjMfleCp+3hl8qH1jG5jgsHhfa/WcViKWHpVJr+fqiv2f/wCCzvhzVNe/aH8I+MvC/wANdS03 wjoX7Lv7Olx4n8SaHpfia/8AD+nzeKNFv20EeINYu5dSsNKnmI/sLSmu72GfVm00maXUNUF3cSfj BSyvMFmWE+sOl9XnHEYvD1KDqRqzpSwuKrYdc8oxjZ1YU4V4xcU4wqx+JWk44q4ffDOdYjKVinj6 VOjgsRQx31aeFhiqWMwWHxXNTpTqVlajUrTws5Qq1YSq0KnLNrRfq5/wSq/5yQ/9oo/2wf8A3ndf lHX6uf8ABKr/AJyQ/wDaKP8AbB/953X5R1ng/wDkZ5v64D/1GZ15z/ySnBv/AHcX/qypBRXtf7Nf hHw94/8A2ivgL4E8Xaf/AGt4U8afGX4Y+FPE2lfa76w/tLQPEPjXRdJ1iw+3aZc2WpWf2zT7u4t/ tWn3lre2/meba3ME6JKv9J3x6/4J3fsOeHvgn8d9W8I/s/QeGvE/hf4Tft1+MfDHimD4pfGXVdT0 LW/2a/jVpvgfwO1tYa14/v8Aw1fWV7o2ryRa3a61oOqPciysHhnhvBfXt/lnWe4TIo4SWKpYmqsZ HM501hoUZuMcpwccfinU9tXoJf7O3KkoubnKEotRbhzehwb4dZ1xvhM1xuVYvKsNRyjE5ZhcQsxr 4ylOpWzaWJhhI0I4XA4xSXPhakasqkqShzQfvJycf5Rq+rv2Dv8Ak+P9jL/s679nb/1b3g+vlGvq 79g7/k+P9jL/ALOu/Z2/9W94Pr0Md/uWM/7BcR/6ZmfMcP8A/I+yT/sb5b/6m0Q/bx/5Pj/bN/7O u/aJ/wDVveMK+Ua/SP4of8pe/iN/2kf8Y/8ArTWpV+5fwN+G1r4g/bx/4K4+H/if8NdV8TfDn4o3 vhrwvd6Pqo8WeGtN8YeHdf8AjB4b0LWDpXiDQLnRtWdLG31QXb3eg6rDJA8cQkuI45G3eJXzf+y8 LldNYdV5V8hzPMIXr+xvPJ1kNNYZfuql5YpZxKftP+XMcJK9OrGo5Ufvcu4GqcXZvn9enmDwXs+O 8BkE0sDLFxhDPqfFmN/tCpOGJouFPCVOHqeGdHkft5ZhGSrU5UI0sT/IjRX9N/7QX/BOL9mTwx+y J+0b4j+Ef7OXi/Wfi78O/ih8YdB8NeJ5/iH8QT4il8N+HvjvceC/CGteA9BbV9U8CfELwzpOm+T4 H8ReH7rRIPiI2rxyX8N/fXU1lc3v80etaLrPhvVtR0DxFpOp6Druj3k+navoutWF1peraXqFrI0V 1Y6jp19FBeWN5bSq0U9tcwxTwyKySIrAiunJuIMDnir/AFSNem6Hs24YlUadSpCrSp1VUp06derN 04e0jTqSnGHs66nQklVp1Ix8XjXw9z3gSrhaWb1MFiVipYmCrZbLG1sPRrYXEVcPOhWr4nA4Smq1 R0Z1qNOnKo6uF9nio/uK1Kc/1J/4Lff8pQv2nf8Aui3/AKz18Jq/KOv1c/4Lff8AKUL9p3/ui3/r PXwmr66/4IQfCnwR8cNJ/be+FPxHtG1LwV408BfBrTNe0VNWudBbxHbx+P8AU7238LjWrK4tb/Sx 4nvbW20A32n3VvqNuNRMmnzw3ogkXDDY1ZZwjhMxdN1o4HIsvxEqUXJSqRjh8NGSjyU603JRm5Rj TpVJ1JRVOEJSkj1sz4fnxX4wcQcO08VDBVM2434mwsMVUpqrCjP+08yqwlOEq1CPJKVNQlKVaCgp Oo21Fxf89NFf0s/Hf9g39lrwj+wF8TvjFp37Ny+Bvito/wABvh/8VbLxM3xA+Mupz+EfG/jb48eI fCXiHwENP1rx7e+ENSs/Bfh3TrPw7aRanoFzreFk1LWru91S4S7j/mmrrynO8LnMsdHDU69N5fi5 4Os631dxnVg5KUqM8PiMRCpS5oyUanMlNJShzQlGb8XjPgLN+B5ZVHNsTl2Ieb4SONwywE8c5U6U 8Pg8VCOJhjsBgKlKq6OOoN01Ccqc/aU6vJUpyifq5/wVV/5xvf8AaKP9j7/3olfsh+zlrvjC4/Ym /Zu+HupS6pdfAPXv+Can7bfiD4laPc2DXfg4+IvD/jm3/wCEO1bVJ3tZbez1ywN1qY0V1mju3El0 1vHI0O+H8w/24/hn/wALo+NP/BIP4Qf23/wjX/C0/wDgnZ+wP8PP+Ei/s3+2P7C/4TLxJ4y8Pf2v /ZP2/Sv7T/s7+0Ptn9n/ANp6f9s8n7P9ttfM89PXfjr/AME4v2//AIRfDVPgR8O/2n/jV8WPD198 YvGnwX0T4CW/i/W/hz8Jb/4Y+Hvh1B8YZfiNfL4p+MI+G2g+HL6yv5v7W8NatY2+laZrUd0P+Ej1 O9kjim+ZzOOExXDWWZZicZRwc8TXzLF0p4mlVqUJUoZdm3Dtaq5QhKFOrl+K4ty3MqUqsoKMsK6/ NSpYfEYrC/rHDNTO8n8QuKOKcuyHMs8weDweQ5ViaWVYjC08YsTLM+FeLaGEdCrVWJr4bN8HwZmO TYiOHoVnUWYQwihWxGKw+Dxf6d+Mf2Cv2aPj748+KfiP4z/DG68R30Xw8+HvhXwV8Qta+MHxem8R 22taP+ypp/j6DQfCvh3R9cGlLLo0kFx4l1PXviHfanoMtmLLw1ouhS3EtwU8b+DP/BOL9g7X/Cfw bl8Rfs4Weu6t4r+HP7DGp+ItUu/iv8cbNr/Wf2hdK8ZweO9Whs9F+JOl2llcfatAtNU021t4xpln fM8cViumE6c35U+HP2bP+C01zrfjfQPDfif9o211mDxRpfw28a21v+1ppOkDWdes/hhD4y0LRp7u b4zWdp4t02L4WPBcaHqVhcav4fbRimiaZftOv9mj5O+MniL9vf8AZZ8U+HvAHxS+MXxx8B643gz4 c+KPCNpof7QWqeJdFm8DaKmpH4V6n4X8Q/D/AMfeIPDFxonhxJNVHg0aPq0kPhzzr1NLjsDPKr89 HLK851sLhOK8P/tdfhrE4TDYXMqsZxwmEqZhj8yjQpUMQnGOd4DFU5KeHSjWp4aOKqObhCrHtzbi rLcPTwObZx4QZjQhgsu4lwGZ5jnHC+C9licfj8JlWU5NXxOLx2WclSeR5pl9b2f1qUq1GpiqmBot c1WnU/o/8H/8E8P2OfgGv7MXxM8J/DhNQ+IuhfFr9knXrTxVfeLfjFrWqazf/FL4vap4W1qz8X6a t1F8J9L0jQIZtGvvBv8AZAg1jUdW8MXlp4os5LG4MevO8Zf8E3/2MPiLo/ib4neLvhREvj34hfHb xz4l1nWNN8X/ABw/tRGT9slfh5feFv7F0nVT8P8ARPBus+EWvdOvdUvLqw8WWWsaqLzRZ7aCGCXT /wAzP2af2UPjV+0x+z5+zz4g1b/gox8dfBfiD4s+OfjFf/Aj4N32n/EPxb4M074mfAmHXPGsmtxe LI/jVpdr4O169azv9c07xNYeBpNR03VLm6nhlur5g9z1Wk/snfHPWfDnwV8FeNf+CrPxH8KfF744 X/7Onxku/gF4j8VePcmP4+/EpbTQ/Hfg6+1f42aUPiv8T/BOqafB458SWOl+F9N1PT7u0i1H/hJo JI7TVZeR4TFU8bDD1+J8TLMsNn6jKSp5tOaw2c0sJhcNlmHShKg8N9d4dzHHYuVNzwNOWGjSxzoY evOpH6OnmWX4vLo5hhPCTK4cOZjw9hcVhsM6vBdLDzx2U4jFVa+bYhVK9KuswxGC4iy/K8uw9enS zPF08XXq4KlisRgIUz8uP+Cg3hf4ReAP2u/jV8NPgh8Mk+FPgH4YeMNY+Hlj4eTxj4q8btqV74W1 K80+98Sy6v4xvtS1e3k1pkSX+yfttxa6dHFHFFNO7TTy/R3/AAVV/wCcb3/aKP8AY+/96JWD+3p+ xXH8DPCukfHy0/aW8SftFy/EH44fF/4T+M9b8ffDzV/AnjaX4j/DHVZ7DxbrU15q/wAQ/iNc+M9P v9Wt7+OXxHPqttcS3SxGSO4kuJTb73/BVX/nG9/2ij/Y+/8AeiV7+S4ijXpcNxpY6pmVTDYbE4fF 42ssYqmIxiwGGq167+vRjiOWu6qxFLmXIqNWmqVqSgl+ScVZfjMBU8TJYrJsNw/Sx+OynMMtyjCT yqphsBlVbPcbTwOEpyyWpUy9ywlKj9UrOlLnlXoVZ171pTlL8o6K/ri/Zw/Zs/Z9/aG/ZG/Yib4/ /C+3+KWm+Bf2bPEFz4a0q68YePvB0NhqHjH9qvQvB2p3xuvAHijwvfXbrpmpu0UF9cXVsssSMsKM zPXaaZ/wT8/Ze/Z/+JHwL8R/Cz9mvx7q/ibS/wBqfTNXi+Olj8UdSuNJ+F1hoH7Yi/DrQfCnirwz 4r8e2un69ol74Zhh0PTZfDvg/wASeMRqVsNT1/U4UkkvpuifFuAo5nHKsRQxUK9TPczyOlUp/V50 JSy7O8xyhYipUrV8N7L2tPLp42VJqXIprCUamKxHs1VrCeCfEOY5Lh+IMDmeU1Muq5Bw1ntanWhm azCkuIeHsizv6rTwmDy/HxxH1bEZ5Sy6nXjiIKt7GWPxVLL8L7Z4b+Omv1c/a5/5Re/8Ehf+7/f/ AFoXw1XpH/BaH4KfCP4b/FH4XfEb4ZeDX8F6v8cl+Nvir4kWqeI/EfiCz1rxfoPxm8SaBN4khXxJ qWpyaTdazGjXV/pukPY6DBMyJpmlWMaMJPN/2uf+UXv/AASF/wC7/f8A1oXw1U4PN6eeYfhrMqdG eHVXOMwoVKNSUZuliMDl/EGAxUY1I2VSksThqvsarjTlVo8lSdKjOUqUPPx3C+I4Nxfihw7icXQx 08HwdkeIpYvDRq06eIwmacVeHubYGpKlWjGdGvLBY7D/AFmhepChifa0adfEU4Qr1Pyjor+gf/gl N+xd+yv+0T8D9I8VfHH4Sjx94m1v9rDxJ8Jl1f8A4Tz4jeFmsfB9h+zR4n+JdtZR2PhDxXoemzSx eJ9EhvEvJbT7e3mm3nvJ9PU2En6AeBf+CZf7A3iWX4ba1qP7OkEdv8TLH9lXUp9Bs/ix8b4tK8Oy fF3wB8QtY8X2ujTTfEe51qexl1Hw9p17YrrGrale2dxCEjv/AOz5LjT59c04ry/KMXisHiaGNqVM JVyajVnQp4eVN1M9ipYGMHUxNKb3kqzcIxpuErOScHPbIPBnibiLJsrzvB5jw/Qwub5fnGZ4ali8 TmUMTDC5JLGwxsq8KGU4ilGfNgavsYQrVHU56TfJefs/4+K/Vz/nBx/3lc/99DrI/wCCon7P/wAF vgV4t/Zxu/gp4Di+HGk/Fb9nbw78RPEvhqz8S+MfE+lxeKLvxN4m0u7u9NvPHXiDxRr9tDcWmnWa vaSazPapJFvt4YDJIH1/+cHH/eVz/wB9DqnmVDNsFlmOw8K1OlLPPq/JXjCNRVMDjsXga11TqVYc rrYao6bU3zU3GTUZNxXJHhjMODs+4y4ezOrhK2NwXBmJrVauBqVquFnDMstyrNcP7Odehhqraw2N oxqqdCHLVVSMeaMVOXlf7NP/AAUr/aB/ZS+GmkfC34X6R8NpNC0bx548+IcGo+I9G8U3uu3OsfEH 4by/DPVLK8uNL8Z6Lp8ukabpbwa5otvFpkN5b+JbGzvL2+1DTo5NKl+gvCX/AAW3/ap8I6rPqtv8 PP2etXlbTvh9ZWNtrHhb4ltbaVd/DrwFq3w20vWrM6X8WtLu7nUtV8La1ewa3Fq91qmjve+Vf6Tp OkXMZZv6DfCnw8+GPxQ/YX8CadqV5BpPjKH/AIJm/BP4YeNLqCeOHUH+F/xlh8JPo+qM80KwqNE1 fwL4zW0aSZobZ76eaQgXBQfM/jr/AIJk/sG6LYfEzxXF+zlJokfw+8F/tTWum+EJ/it8a/s3iW++ Dnjj4aaT4P8AiDPd6h49k1pJ7rTdd1W21G0064XwveR6vHLDp0V1bWNzH8/js14fxWc5pl2a5I6u MqTxuCxFWPLW+s0cgxOOwuGlVc5YZRjUws8JUw8aUq0qdXMKtCs4UMFUxk/1HL+BPEvK+H8lx/DH HlKjlVLAYPHYfD4h4jA/Uf8AWTKsNjsbQpUsPRzV1OR4TMKWLddYeGIw2X4ath41cTmMcvo/j34Q /wCC0n7Tng+00mxh+Gn7OeuWek/Dj4WfDdLbxD4N+IF7b3tr8G21w+A/E2owWvxTsYbnxNpyeINR husRx+G9QjMH2rw28kKyHyXTP+Cov7QmmXXge+Xwt8ILq88BfAb4q/s9aZNceGvFUYv/AAh8YNV/ tjxRrWqW9h45srQ+KrW8J/sS40u30vw/ZQnyrnw5fKFK/df/AAVL/YM+BXwo8GeFpv2V/gRreg+N R+0h8T/hTPo/g/Xvir8SNT8U+E/C3w90LxvDeXWjeKfEnjS6S/0QXepSTXmgQaZbpo8Mk2qQ3DwN eJ5T/wAEn/FXxO8DfAb/AIKPeKfg5e+IdN+J+i/Cb4Oz+DrrwvazXniCPV3+JN3bCPTrOGC5luZZ 4Jp7eW3FvKJYJJY3QozCu7BVeHc2y7FZ1hMri51PY4iVPFuNCvVedYFYSOIqTo1cS6dPE5bnlbD1 KqUpqjz4ZwTwtKFL53GUvEvKOMcs4NzbjKvSk6s6VPMMqhUxuDw1Th/Mv7RVGhSxWGyn29fB5zw7 hcZGk5UoLEOnjPaSeMryrcnrf/Bbb9qbXb/wvqt18OP2d4dT8M3/AIl1d7618LfE1JPEGseK/hK/ wY1TU9cgm+Lk9mkw8IfZ5bW20G20PTYNYs7e7+wvbNdWNz8z/tNf8FD/AI0/tVfCL4f/AAW8d+E/ hH4Y8J/D7XrTxTb3Hw78Ka14e1TxD4ktPCkPg4axriah4q1zQrOa40qJ572y8IaH4V0m71S5udRn 0955QV/p/wDjb/wujwV4k+Mc/wCxT4J+HviH4qfEn9uyLwv8YfD3i7Rw3w+8T+HW/Yl0LxDr2hfF a50660O6sfDUerXuqeII4n1zTLaXxbcrIZZ7nULq3u/Kf2ktfbU/2E/i54A/4TqXxBf6H/wTA/ZX 8Xn4E6n4fNv8N/BEDasbXUPip4T8YC5119U8W3C2I0vTNB/srSFso9B067k8QXQv/N07wYZ1lEKF DMafDmDjU5OF6kKccdL21KOKybE8Q0XGnHBvkwOWuU6eCr8sMLiJQqYissvpYGLh9jjOCOL68cwy jFeI+cVcK8NxGq7qZDSp4HFwjnGF4clhXXqZ1TVTMswo5dhpZrg4e1x2DlThgcNHNqmIrVH+IH/O Dj/vK5/76HX5R1+rn/ODj/vK5/76HX2D/wAEf/hX4D+N37Mvx7+E/wAT9B/4SfwB45/ar/ZJ0TxV oH9qazov9qaXJqPiid7X+1fD2o6TrVjulgibztO1KzuBt2rMFZgftIYxZfgM4xzp+1VHPsFh3TUu RyWa57kuSOanyzs8Osz+tKHK/bOh7Dmpe19tT/G62RT4mz3hDI6WIhhKuK4CxOMp4ipTdWEZ5Dwv xHxHCjOEZQkoYyWULBSrRcnhliXilRxLo/Vq388VFf2C6v8A8Ex/2G4NL1Hx14Y/Y+8XfEe4174c fBOXSfg54G+NPj2xv9H1bx34j+MGmeI/FvhrXfHHxS0S3fUbWx8KaLdm38c+LbjwrFBpNytrpTXt 40F385/8FN/gV8INb/YQ+HXxnufA91ZfGL4Q/Aj9h3wXoPjV/E+uyXU3g3xj4c8TQXnhXV/DsGqS eC5k0+aze7i1ay0kavJfTyD+15NNSGzrzIccZbVdP2WFxtv7ZyfJq/tfqtOdKtnTnTwtSFOOJqzr U6deWEjiJ2p0lSxFSdCtXxGFq4R/RY/wJ4myvDZlXx2a5JzYLhvN+JcPHCrNq9HF4TJKdXE4yhLF 1crwtDDYmrhMHmU8HRbq1qlfCU6eJpYTC4yjjj84v2Rv+UXv/BXr/uwL/wBaF8S1+Udfq5+yN/yi 9/4K9f8AdgX/AK0L4lrz3/gmp8EvhD8cPiR8fdP+MvgkePdB+Hv7Jnxp+K+gaM3iPxR4YWHxj4Kj 8PT6HqDah4T1jRr+Vbdbu7iazu5rvTZhcFrqwuGii2e3hasaFTibETUpQwuLni6kY2c5U8Lw5lWI qRgpOMXOUKUlBSlGLm0pSjG8l8piMoxPED8KsiwU6FPGZxkTyzC1MTKcMPDEY7xE4yw1GVedKnWq QpRqVIupKFKpOMU3GEnaL/OWiv7GPFX/AATA/YBh17xfFY/s6xaZY+BfGnxR8MCzsviz8bpP7fsd K/ZP0P42aLdapcap8RtTmt9Q0Xxbq80FhJpRsLO40mC3ttbsdYl86eb4H/4KY/sTfso/Bb9lvXfi P8Gfg7B8OPGXhn4z/BTwkur2Hj34n+Jhq3h/4j/Am0+IutWGp6d468aeKdMQ2uv3+NNutMs9OvIr S2hguLi5DTmXxqXHGVVq+Hw8cNmMZ4mGR1IOVLC8sYcQ14YfL5TccZJpOVSE66ipSpU38MppwX02 M8CuLMFleYZtUzPhuphsuwvEWMqwpYvNXXq0uF8BRzDM40Y1Mmp03P2NaFPDKrUpRq1lJOVOmlUf x3/wSq/5yQ/9oo/2wf8A3ndfAXwM+MXxc+BvxDsPG3wQ1y50D4hXOm614Q027svD2h+Kby7svGem z+HNV0i00XxBo2vWF1c6vYahNp8Bj06S/jlnV9PkhuxFIv37/wAEqv8AnJD/ANoo/wBsH/3ndeI/ 8Exbbwpef8FAP2T4PGgtDojfGDw7JGt80S2z+IIPtE/hGOTzisbNJ4sj0WOKNifNmaONVZnVT7VG NKeNz6nXpOvh6lDD0sTh1CNX6zhquAqU8RhnSmnCssTRlUoOjNOFZVHSmnGbT+Sq/WP7I8Ong8XL AYyOY5nPBY+FWdCpgMZDPMLPCY6niKUoVcPUweIjTxNPEUpwq0J0o1ac4zhGS6rUf+Ckn/BQ34de J/7D134q6z4P8X+A9f8ADwuNB8RfB74V6TrvhrxH8PPCGofDfRLTV9F1n4bxXlpf6D4V1C/0O507 VbTdNLI15qtvcatDFeR+m/GP/gpf+1j4r+CP7MuheD/D2tfCX4UfC7Qfh74Yi8RXnhfwl4w8LfF/ 4vfAjVI/ENl4uXX/ABD8LbK3ZtCvNU0m/vPhX/bPifw1pU0trd6naXJ1FS/2p4o+FH7XHib4L/AH Uf2YdH+JHw98beJP2yv2hP8AhdPibSJtW8IJ8RvHHiT4taxb/DzxjqviWyFrZeN/DvhrRfCninw1 f+HVvdZvfDN9pmord+HIYvEenz6vB+3v4Y8G6T+zD+3nb23gO8+HOg2X7f8A8JfEnwk8Ma1oB8KX 1prfjH4LWV1441LTfC99b2GqeGbTxZpTP4n/AOEfutO02/0+wvNMg1LTLCeB7W2+TjmWU1lgK9TJ 8qeNWa4OvXjh3TVelmmGzfhnIqWJxNKFGE2ovi2eZ5V9aqV6kaeX08TUoYbHU4SwP6ziOHuNcBhe JMNS424slk64dzClSeLjiquDxORQyTjPiuGEwOYV8XVdOjzcGrJc3qYHC5dTqYnOq2AjVxGW4upD NPkn/gmr4o1vxv4o/wCCovjPxNdxX/iPxb/wTA/bX8Sa9fQWGnaVDeazrd94C1LU7qHTNItLDStO invbmaVLHTLGzsLVWEFpawW6RxL+Qdfq5/wSq/5yQ/8AaKP9sH/3ndN/4JYfs6fCv9oPWf2oB8SP hN4b+MmpfDP9n+88d/Dvwl4w+J3ib4SeF5fGcHizQdNtm13xl4c8a+BE0zTZ7S9uba5udY1pdNtU l+0GPz44mH01GpQy+tnlVU408NgMLhKvsqMadONPD4TATn7OlFunShGNOnywi5U6UUknKEE2vzCp l+O4mwHAOXQxCnmOdZhn9FYrGzxFX2mLxmb0uavialKlisVVlOpNzqzhRr16km2oVJys/vb/AII7 /Aj4IfEz9mvxFr3jn4M/Cb4nXDftFeMvDnxo8S+P/A/hXxdrPw4+CFj+zX4j8R+Htb0jWPENjdX/ AICtpviVDaIviHQpbS7uLwfZ3mIgRoPjz/gtt4nuvEH7T/wrtpLbRraz0v8AZW+BUmnjSNF07RlM Ws6Bc6vMkqafbWqyQwzXLQ6dA8Yj06wWDT7RIbWCKFPpn4if8Emf2Y/jJ8Sdb1/9mn9pfQ/AvgHx d+0loH7OPwx8CaP4V1z4yeF5vFtr8M/CPj34jS6N8WpfiKs+oaP4YsrnxzeWQ1eO+GoXXhmLQ4vE slzqsD2VDwt/wQm0PxVcw6hZftd3a+C9f0r4Q3ngXxF/wz3u1TXdQ+LHi7xp4KhsNc8NzfG22/4R m30LV/CUMs9/BrHiBr/T9W8+Kztriwe0ufl55jk9bOsPxHic0xOFjNZK8PlGIy7GTq4bEYjInhKV ONShPEUJ18fSzrB119Upzg5QnQVTEyhUqUP1bE8PccPgWrwFlfB+V4qGDo5hSzDijK+Jslhh8yw2 E4lWZyxdbBYuGAx9GlhK+VYjB1v7TqU6sJ06VSVHByh9Xr/In/BEH/lKF+zF/wB1p/8AWevizX5R 1+wX/BHbwxd+CP8Agrn8D/Bl/PDdX3hHxN+0N4Yvbm3DC3uLvQPgd8Y9KuJ4A/ziGWa0eSIN8wRl 3c5r6O/4JV/sQfsx/tK/szeKPF/xj+ER8beLbn49+N/hvF42j8ZfEzQLnwP4U0v9nTVviLpupWmn eE/F+ieFpLi08Y6ZZqt54n0XVradNTfT7lJ0ks4ovcxecYPLv7b4gn7TEYDCcO5Fj5fVowlWrYer js3hTlQjWnQg5S9vCaVSpS9zm15kov8AP8m4KzjijLuFODcJPB4HOK3G3iHhJPMa1WGEoYjL8i4G qYmnWq4Khjqj5Xh6lOMqNGtGU+Wz5Hzr+e+iv6uv2irjT/iV8WP2EfgHrv7SfxAi8FWfwN/Za+Lv xC/Zjl+Hsb/Cyf4d/CvwBqvxH8ZfES/+JUvjAQxanLoPg2808+H5fBpj81bec6k3mAV9S6R+0nL4 8+LP/BMi68RfHfx1os/x+8IaV46v/wBmm38DXWqfDr4m3XiTxp4i1mDxN4l8fW3jXSH8O6h4EupL fV9J0eXwnrtnq9x4b0ywvH+x3c0cGdbiipSrUaEMu9pUq51j8radbFwcKGGhmbweNSWWzeIWY1cj zmhBYVV8Fgp4GUsdmVCnTx8sB6GD8IcNiaWMr1+KI4WjhMlyTMoTeCyir9YxeZYjJqGY4FW4phDC rJo8ScP1ZrH1MJm2Y/2lTpYHJJ1a+VxzX+U79g7/AJPj/Yy/7Ou/Z2/9W94Po/bx/wCT4/2zf+zr v2if/VveMK+jPht4W8QaT/wVW+BniS88B6z4K8K+LP8Agod4Rl8HPdaTr1r4f1K10j9pvSNP1KDw 1q2trIdat9HvALG9kt76+eyucW11Ik2Er3f4YfBT4Y/tCf8ABa79on4W/GDwgPHfgPWf2i/22NS1 Pwsda8TeHxqd54a1T4teItFQ6p4P1jQfEEAh1jTLKcx2OqW5uPL+zzCWCSSJ98NmdKu/7bnB06NL hHFZziKMJKtUpUsFSqZji8NFxUY1MRThQq0Ixfs1KvFRm6acnHw8Rw3iqeBjwhRqwqYvEeKeG4aw eKxFOrhMPXrY+FLKsDjqsJRqVqGDrzr0cVKSjWnDDTcoRrNRUvxOor+xPx74R+Gf7FH7KXx3t/hB 8WviH+xN4c134l/s2eLZtV+G/hvxL8Y9d8N+JvHvwR0/UNd8EW+l+MfiHpPicaNrGowtLNPrXi3U bzSH8tPs80PlLb+VfCL9lr9nL4u2um/BH45/DhviXffsr237DnwmnM/jTx34TbTfHf7VfjnxF4+/ aCuLqLwN4r0WC81K61PxrY6dM1613dWN14bt4rW9iRZxPz0uLaVepi/Z4Cu6OEzXKcsnea+tTeZw y+hUxEYKnLL3DBZtnGUZdXpxzOdVUsdDMJxpUamCp473MX4L4zB08BRrcQ4COY4/IcwzyEZUOXLI PA4jNakMC6/1p577bF5HkOd5vh60+GaWHqVcvrZbSqVa1DMK2X/yg1+rn/Bb7/lKF+07/wB0W/8A WevhNWj/AMFVf2bfgV8Arz9nPVPgf8Po/hvafEbwf8TJvFGiWninxr4p0661LwL8Uta8Habq0E/j vxF4o1ezvL7SrOBtTgttTi0t7lPNstOsQzo9L/gtz/ylH/aY/wCunwT/APWfPhLXZk+Y4fiDM8mx eFjWo0cRhuI8GliIQVWFTB55lOW1pOFOrUg4uthqk6dql5U3By5JNxj4WfcNY7hDh7i7IcyrYPEY vC8S+G2LnWwFSvUws6WbcI8Z5xhfZzxOHwtbmjhcfRhWU6EOStGpCLnCMak/yfor/R4V/h8fiGPi GyW//Cwovh4/7K8TbUNx9jn+E1r+0fIfMyJFj/s6L/VAMGZVc45Nfmd4i8F+D/EngH4tWOj2N18Y viT4w/4J9f8ABPvwnq/7Puq6Lr3hfwzrmi3njH7J4cg/4Wf4Y8YWXiCV/GOoajqOk6haaPpnh+/8 MwWCalFrl0btEtvCo8dOs6sP7IlGpTll0VF4xtTWaTz6WDmpLBvlpzweUYTFTnJKNJ5jOjUcXgp1 K/3uM+j/ADwry5ri2jUp5lQxWJpTeTqm40sHR4bVdezebyqVa0cdnmMwccNRjUr1YZXDE0adT6/G jhv4uK/Vz/gqr/zje/7RR/sff+9ErzX/AIKg/Dr4GfCD9qnXfhV8APha3ww8JfD/AMOaD4c8QLHr fxF17S/F3j+2juJfGfiPw9e/ErX/ABHrR8P22rzS+GdN+zai9hMPD810heaeaV/v39sX9ir48ftS 6B+xl4x+Gvh+3tfAnwb/AOCNn7M3jbxt498UDWdN8H2//CK6J8R9fm8I6frGn6LrCX3jfVdOTzdJ 0JIkXy3ju9VvNL0+RLw+ws2wmLWS5zeeGwNTD5nilPE+zjJYaNFKFZqlUrR5a8IxqUYRm6s41KcH TjXk6S+Jw3CGc4JcccG4elDOM8o4zhrL1QymGKrRq42WOlKrh6SxOGwlfmws5To4qdShTpUp0K8/ aSw8FXl4x/wSZ/4J6fCv9qnV7P4tfHfxGbr4YaJ8W4fhInwkttH8RCf4k+ItW+Gvinxgi3/jjwx4 38I6z4E07Q49OtNUhvLC31qTV7u1Ol3EdlazSTSfcX7Rn/BM39m+3/ZSt9Y+FHwBtPDXxR17wN+x fJ4B+IWg/FX4k+LvEOufEb46+MX8MeOrXxn8PtX8c+JdG8KeDo4H0ibTPEN34Y0Wxu9S1W7sdDu3 l0yS1Wt+yV+zf/wUb/YctNE+HPw3k/Yl+IVp43+MMGua4vxB1n4yayv7P/xR8P8AwD1fx1c3PjG5 8K2vgGS2Nz8JdWnS7i0SH4l2Ml1LYLYpbTSreTamgftFft5aN+1V8I/2MIvBf7Cs/j/xx8HPhTqH hT4zeHh8brfw548+GHwq8EeLPiX8IdT1Lxhfalr+rQ2WialYal4ihhsvhPpd5e+I4Psjiy0e9a5X 5/N8fmGKzivXyzNKFXBYOpw/meGwVLHvBwq5ZlWFr5pnUK8oyoqUMyeGzCarYmpWo4zLqUpUFVwe D5aX6pwpkfCmT8GYTL+JeDsXhs7zbD5llWNzfH8PUs1rU86zjMauW5VVwFSvDGVKX1HB5hkMadDL 6eErYXNJxjip4fFYxVa38/H7XeifCzwt+0t8ZPCHwU0ddF+GXgrxrqPgnwxbrqms60b1PB4i8N6p rr6jr2o6pqE7+Ita0zUtdKG7+yW41FbawgtbGG3t4/s79rn/AJRe/wDBIX/u/wB/9aF8NV418Z/2 Cvip8Pvgr4l/agtPin8HPjd8KtK+I9h4A8Q+NfhLqvxI1mBPGWvQz39158vjL4Y+CY2ttPu3s7DW dQaYRQazrWladEbm6uZEh97/AGm9B1zxT/wTZ/4I2+GfDOj6p4h8R+IdT/bu0TQdA0OwutV1nW9Z 1T9o/wALWWm6VpOmWMU97qOpaheTw2tlZWkM1zdXMscMEbyOqn38LVhWhw1hqeMlmOIwWYUsDi8R JVPbVcYuF8fWc6sakVU9piaWIo4pXXvQxEJRupI/K8Zl2MwVXxNr4jJ/7Dw+b8NPNcqy6EaEaNHL K3ifwvhaFLDLDVKtH2WFrYTEYDlhUlyVcJVptuUW3zv/AAS8/Yb8BftceOdf8XfFvxi2h/Cz4QeP vgLo/inwfbeHNX1m9+J83xg8fS+EdL8GDWND8Y+D9V8F2Goz2UlpqPizT7jUb7SIr1Lu10+R4Wdf 1f8A2k/+Cbn7Hvgb9lP43+PPCX7PdppGu+EPg58XvGnhr4gaP8W/irr3jaw8c+E/jlqvg3wzph+G uo/EHW9OvPBNt4VtYk8R+KdR8KHTtPjiM1xqo1GSa6t/EP2Iv2VP+Cgf7HXjX4heAdCh/ZD0u58Y eD/2UPir400r9o3VPi5caH4V8XeJPihrtv8AATwr5nwysdK1q3+J9p8QNK1Ky1TTon1rwUkgt7e5 1q78xBX0X4h8Rf8ABS4/BvxT4v8AEPwj/Yd1rW9J0P4uaDrXw58NWnxw1D9pTxp8IdM/aTS0+K/h rwfYDWfEHga88MeKPiF5Wk2sMMsni290K601rCybXHtN/g8SY6vi8xw6wGeww+XUsXOny4XHfVpy X9h06eJhOdD2dTE1sPmlPFZnJSr1MPhcq+q49Ua1D6xh8X+ncB8O5NlXC9ann3AeMxOfYjCSeIxW Y5CswVKp/bmFq4WVJ42GLp4GnWymtSy2EcPg6GKxWZVq+XutRxk8PisJ/Pj+2r8MPAfwS+LHh74P eDdEj0nXfh58I/hVpXxevU1XWtUOvfGjVfCFh4o+IV/jVtQvINOTT9T16Pw5HpujwabpluNDLrYr dTXUsv79/wDBsR/ze9/3bX/736vwK+PPwZ/bH8eeL/i9+0T8Uf2avj34ctfEXizxd488eeJdX+Dv xK0rwp4Xm1LxHqX9qRajrmr+HorLSdN0TU0utD36nexfY5dPexuJFubeVF/fX/g2I/5ve/7tr/8A e/V1cQVZ1OCsZ9Yr0quOdPA18wjRxEcRTo4zFZjhsRiKNKUZz5MNSr1KlLCU01ClhqdOlSSp04pf NeGlCFLxwySWFy/EYDKniM/w+TrEZfUy6piMtwPDWa4PB4qtQqU6d8bicNRo4nMaiXNVx1evWqWn UZ/QV+3j/wAmOftm/wDZqP7RP/qofGFf5ntf6l/xb+G2h/GX4VfE34QeJ7vVrDw18Vvh94z+G3iG +0GeztdcstD8c+HNS8L6td6Lc6hYapYW+rW9hqlxNp099pmo2cN4kMlzYXcKvbyfht/xDcfsOf8A RVf2rv8AwufhD/8AOLr5Xg3iPLMkwuMpY6VaM6+Ip1KfsqLqJxjT5Hdpqzv07H7H43eGXFPHea5H i+H6WCqUcBl+Iw2IeKxkMNJVamJVWKhGUZc0XDdrZ6H8TNFf2zf8Q3H7Dn/RVf2rv/C5+EP/AM4u j/iG4/Yc/wCiq/tXf+Fz8If/AJxdfZ/6/cPf8/MX/wCEsv8A5L+rPyv+If8AEu/iT/0C5R/4daX/ AMrP4maK/tm/4huP2HP+iq/tXf8Ahc/CH/5xdH/ENx+w5/0VX9q7/wALn4Q//OLo/wBfuHv+fmL/ APCWX/yX9Wflc/4l38Sf+gXKP/DrS/8AlZ/EzRX9s3/ENx+w5/0VX9q7/wALn4Q//OLo/wCIbj9h z/oqv7V3/hc/CH/5xdH+v3D3/PzF/wDhLL/5L+rPyuf8S7+JP/QLlH/h1pf/ACs/iZor+2b/AIhu P2HP+iq/tXf+Fz8If/nF0f8AENx+w5/0VX9q7/wufhD/APOLo/1+4e/5+Yv/AMJZf/Jf1Z+Vz/iX fxJ/6Bco/wDDrS/+Vn8+v/BVX/nG9/2ij/Y+/wDeiV+Udf30/tAf8ESv2VP2j/8AhSX/AAnHxA/a D0r/AIUN+z58Nv2bfCH/AAiniv4cWP8AaXgb4Xf21/wj+q+JP7X+FGufbPFl5/bt3/bF9pf9j6Pc eXbfYtC0/ZL53z5/xDcfsOf9FV/au/8AC5+EP/zi64Ms42yLC4GhQq1MSqlNVFJRw0pL3qs5KzUt fdkn96PoOKfAjxAzbPcdmGDw+Vyw+I+q+zdTM6UJ/usHh6M7wcG1apTklrqrPqfxM0V/bN/xDcfs Of8ARVf2rv8AwufhD/8AOLo/4huP2HP+iq/tXf8Ahc/CH/5xdd/+v3D3/PzF/wDhLL/5L+rPyv8A P/8AEu/iT/0C5R/4daX/AMrP59f2uf8AlF7/AMEhf+7/AH/1oXw1X5R1/fT8Rf8AgiV+yp8TfgN+ zj+zxr3xA/aDtPBX7MP/AAt//hAdU0jxX8OLfxRq/wDwurxlY+OPFP8Awl97e/Ci/wBJv/sGrWEN v4f/ALF0Tw/9l05pYtR/tW5ZLtPnz/iG4/Yc/wCiq/tXf+Fz8If/AJxdcGXcbZFhsPUp1amJUpY/ NMQrYaUl7PF5ni8VRbalu6NaDkvsy5o7rX6DiXwI8QM0zHDYnCYfK3SpcP8ACeXTc8zpQl9Zyfhb JspxqUXB3hHGYKvGnPapTUaiSUkj+JmvQ9K+LvxX0Lw7oXhDRPif8Q9H8J+F/F8HxB8M+F9K8a+J NP8ADvh3x7a+V9l8b6FolpqcOm6R4vtvIg8jxLp9tb6zD5MXl3q+Wm3+yP8A4huP2HP+iq/tXf8A hc/CH/5xdH/ENx+w5/0VX9q7/wALn4Q//OLrtfHvDkrKU8S0pQmk8JJ2nTnGpTmrt2lTqRjOElrG cFKLUlFnh0vo++J1GUpUaWWUZShUpSlSzmFOUqdWDp1acnCCbhUpylCpBvlnCTjJOLaP4s/EfiTx F4x17V/FXi7X9a8U+KPEGoXOra94k8R6rfa5r2t6reytPeanq+sanPdahqWoXcztNc3t7cTXM8rN JLI7kk4tf2zf8Q3H7Dn/AEVX9q7/AMLn4Q//ADi6P+Ibj9hz/oqv7V3/AIXPwh/+cXRDjvhunCNO nLEwhCMYQhDCOMIQilGMYxi0oxirJRSSSVkrWFV+j54m16lStWo5XWrVpzq1atXOIVKlWpUk51Kl SpODlOc5NynOTcpSbbbbbP4ma/Vz9rn/AJRe/wDBIX/u/wB/9aF8NV/QV/xDcfsOf9FV/au/8Ln4 Q/8Azi6+g/iL/wAESv2VPib8Bv2cf2eNe+IH7Qdp4K/Zh/4W/wD8IDqmkeK/hxb+KNX/AOF1eMrH xx4p/wCEvvb34UX+k3/2DVrCG38P/wBi6J4f+y6c0sWo/wBq3LJdpxYvjbIq2IyupCpieXCY+piK 18NJNU5ZZmOFTiub3n7bFUk0vs80tlr7uTeBHiBgsu4sw1fD5WquccP4bLsEo5nSlGWJpcU8NZtN VJKH7uH1PK8XJTd06ihTteaa/gWrrLfx946s/Bmo/Di08aeLbX4eaxrdp4m1bwFb+I9Yg8Gap4js Lf7JY+INR8LxXi6He63Z2v8Ao1pqtzYy39vb/uYbhI/lr+zr/iG4/Yc/6Kr+1d/4XPwh/wDnF0f8 Q3H7Dn/RVf2rv/C5+EP/AM4uu2XHnDk1yzliZR5oS5ZYSUlzU6kKtOVm2uanVhCpB7xqQjOLUoxZ 4dP6PnibRk50aWWUpSp1aUpU84hCTpV6c6Nam3GCbp1qNSdKrBvlqU5zpzTjJp/x7+IP2gvj34s8 OXfg/wAU/G74veJfCWoaP4Y8O3/hbxB8SvGes+HL3w/4Jubi88GaFd6JqOtXOmXOj+Ebu7u7rwxp k1q9loFzdXE+lQWks0jN5DX9s3/ENx+w5/0VX9q7/wALn4Q//OLo/wCIbj9hz/oqv7V3/hc/CH/5 xdKHHXDVNzcHiIOpP2lRwwbi6lRqMXObi1zz5Yxi5SvK0Ur2SLr+APilifZ/WVl+I9jTjRo+3zuN X2VGLlKNKn7SMuSnFyk4042inKTSu2fz6/8ABKr/AJyQ/wDaKP8AbB/953X5R1/fT+z/AP8ABEr9 lT9nD/hdv/CD/ED9oPVf+F8/s+fEn9m3xf8A8JX4r+HF9/Zvgb4o/wBi/wDCQar4b/sj4UaH9j8W Wf8AYVp/Y99qn9saPb+Zc/bdC1DfF5Pz5/xDcfsOf9FV/au/8Ln4Q/8Azi648PxtkVPG5hXlUxPs 8S8K6TWGk2/ZUXTnzLm0tJ6d1qj2cx8CPEDE5Fw7l9LD5W8Rln9r/WlLM6SgvrmMhXock+S07wi+ a1uV6M/ir0bWdX8O6vpfiDw/qupaFr2h6jZavomt6NfXWmavo+rabcx3mnappepWUsF5p+o2F3DD dWV7aTQ3NrcxRzwSxyxqw9e1H9pz9pPWLDUtL1f9oT44appmtaf4u0jWNO1H4sePb6w1bSviBqkW t+PNM1Kzudflt7/T/G2tQQav4usrqOW28SapDFf6zFe3caSj+vb/AIhuP2HP+iq/tXf+Fz8If/nF 0f8AENx+w5/0VX9q7/wufhD/APOLrqqcccMVuVVlWqqHOoqpguflVWHs6qjzN29pTbhUt8cLxldW T8nD+AvithIzhhJYLCxqSpzqRw+e+xjUnScnSlNU1FTlTcpOnKSbg5ScWrs/iZr6u/YO/wCT4/2M v+zrv2dv/VveD6/q4/4huP2HP+iq/tXf+Fz8If8A5xdeg/CT/ggD+xx8Gvir8Mvi/wCGPiV+0xf+ JfhT8QfBnxJ8PWOveMvhbdaHe654G8R6b4o0m01q20/4NaXf3Gk3F/pdvDqMFjqenXk1m80dtf2k zJcRziuO8gq4bEUoVMU51KFWnFPDSS5p05Rjd82iu9X5PyvtlP0f/ETB5rlmLrYbKVRwuYYPE1XH NKUpKlQxNOrUcYqneTUIuyW70P5Ff23dU1PQ/wBvb9rzWtF1G/0fWdI/a8+P2qaTq2l3lxp+p6Xq dh8ZvFl1Y6jp1/aSQ3VlfWV1FFc2l3bSxXFtcRRzQyJIisMaT9uT9teW6hvpf2wf2pJL23gntYLy T9oH4svdQW1zNa3Fzbw3DeLTNHBcXFjZTzwo6xyzWdrLIrPbwsn9gfxb/wCCAP7HHxl+KvxN+L/i f4lftMWHiX4rfEHxn8SfENjoPjL4W2uh2WueOfEepeKNWtNFttQ+DWqX9vpNvf6pcQ6dBfanqN5D ZpDHc393Mr3Enn3/ABDcfsOf9FV/au/8Ln4Q/wDzi6xo8acNPC4OliVVqzw9CnTXtMF7RU5ujCnV 5HK9udR5ZONueMUndWR14zwP8U45pm2LyyphcJQx+YYnEr6vnrwsqtOeJrVsO6saXLeUI1G4qV3C UpWs27/yE2f7Tn7SenaJP4Z0/wDaE+OFj4buvE58b3Xh+z+LHj210S58ZnW4vEp8XT6TBr6WE3ic +I4INfOvyW7aqdbhi1U3f26NJx5T4j8SeIvGOvav4q8Xa/rXinxR4g1C51bXvEniPVb7XNe1vVb2 Vp7zU9X1jU57rUNS1C7mdprm9vbia5nlZpJZHckn+0z/AIhuP2HP+iq/tXf+Fz8If/nF0f8AENx+ w5/0VX9q7/wufhD/APOLreHG3C1OXPTjVpzs1zQwKhK0o0oyXNGzs40KMWr2caFJO6pwS4K/gR4s YqkqOJq4TEUVNVFSr5+61JVIuq4zVOpzRU4vEV2pW5k61Vp/vJ838+v/AAW+/wCUoX7Tv/dFv/We vhNX5zeAvi78V/hUdUb4X/E/4h/DdtcfR5NabwF418SeDzrEnh7UU1jQH1Q+HtS046g+h6tHHqmj td+c2maiiXtkYLlVlH9037U//BEr9lT9rv48+O/2h/iT8QP2g9E8a/EL/hGP7a0vwP4r+HGm+F7X /hE/Bvh7wPp39l2WvfCjxLq0PnaT4asLi9+163e+ZqMt3LB9mtpIbSD58/4huP2HP+iq/tXf+Fz8 If8A5xdcuWca5Bhsry/B4ieIdTD4DB4etH6tKcPaUKFKE0m3aUVUg3F215U10PY4n8DvEXMOLeI8 8yunl9KjmPEOc5lgayzaOHxEcPjswxOIoSfLFTpVHRrR54qV4tuLb1P5oPEH/BS/9pLxR+y1rv7J +vXHh/WPCHioQp4r8d63qPxL8RfErxHGnje7+INy1/d+I/iNq/ge2v8AVvEd202v69pHgTTPEfiC KG3/ALZ1i+uY/tLfnxX9s3/ENx+w5/0VX9q7/wALn4Q//OLo/wCIbj9hz/oqv7V3/hc/CH/5xdbY fjHhPCTxNTDQrUJ4yu8TiXTwco+1ryjCDnJKVlaMYpQiowjZuMU5Ny4Mz8E/GDOYYCnmuIwWPhlm EjgcBHE51TqfVsNB3VODdO8pPRTqzc61RQpxqVJRp01H8Xf2xviNonwf/aE/4I2fFjxNa6rfeHfh n/wT/wD+CfPj7XrLQoLS51q70fwj4t8Xa9qVtpFtqF9pljPqU9nYTR2MN5qVhay3LRpPeW0TNMn2 LrH/AAXM/Z98aaLpfhvxl8PfjatnL4j/AGlfD+va3o3hr4etq0Hwk+K2k+L9H+HF3pdlP8RrS0v/ ABt4W0vU/DOi61ouoXdpoqWGm3dxYeJNQlS3t5v1g/aA/wCCJX7Kn7R//Ckv+E4+IH7Qelf8KG/Z 8+G37NvhD/hFPFfw4sf7S8DfC7+2v+Ef1XxJ/a/wo1z7Z4svP7du/wC2L7S/7H0e48u2+xaFp+yX zvnz/iG4/Yc/6Kr+1d/4XPwh/wDnF14lXO+EszyzBYHN1i6qwsMfCMadKpBJY+dJVnz05KTcqVGE FqlFSqOznySj+g0eCfGXhzPc3zDhJ5Jh6GZ4rJ8XKeJxOGq1JVcpwsIUYuFWElGEa7nOUbPncKb5 lHmjL4V0r/gth+zBZ+OLbWp/h78ev7A0P42eG/GWhiHw18PZdYvPA3hv9krV/gLE2q27/FCCytfF l54v1IarJpdneXWj2/htTMuuT6on9mzfll+2b+0t+zH+1Do/g/xHptl8eNE+KHwv/Zv/AGe/gv4G sb7Qvh9a+AtT1vwLceIIvifqPiy7g8X6z4hj0qXTdQ05vAdxo9qt3eXyXq+IdN0yAQM/9G//ABDc fsOf9FV/au/8Ln4Q/wDzi6P+Ibj9hz/oqv7V3/hc/CH/AOcXV4fN+C8NiI4qjUzSGIjPL6ntuSfM 55dQxOFhKX2b4ihjMVTxSUVGrGtU5VTfJbkzjg/x0z7LXlGZ4bhSvl31TE4KOG9rh4Rhh6+JjjKc YyjafNg8TToVcJUlKU4Sw9F1JVWp8/4yfsi/8FG/2YvgL8A/2bvD/jjw18eNW+Mv7MHiH9ozxd4P sfCfh34fSfDXxRrfxp8Oa74Y0i38QeJdZ+IFl4m03T9Is9Y+0372Pgy9mFyCIIr2KILP0Oi/8FJf 2LL2b9m34tfEL4J/F3xF+0d8HfC/7KPw9vdXTTPBU/g3wb4d/Z98eXHiHxb4t+Gd9/wnmlaxqnin 4geH5zpY0HxLoWkaVYy+XD/biQxSXd1+vX/ENx+w5/0VX9q7/wALn4Q//OLo/wCIbj9hz/oqv7V3 /hc/CH/5xdb1OIOD6mOnmDq5nHFTxmAxynTjVp+zq5fVzCrThS5ZKUKNeWaY2OLgpXr06ns3JQhB Lmw3AnjfhcpwmS08LwpPL8Hl2Jy2nRxE8FiOenXWWqniKyrU5wq4rBPKsJPBVXDloTVWTpzdapf+ fv8Abw/4KDeE/wBsn4NeF/CepQfEfV/iZ4M/aQ+Nnjjw54q8caL4USHT/gV48vZrjwP4Ft9a0rxL qWsQ6n4ft4tLttR0NtOuNGiFjC9r4h1D7LADD/wVV/5xvf8AaKP9j7/3olf0Ff8AENx+w5/0VX9q 7/wufhD/APOLr6D/AGgP+CJX7Kn7R/8AwpL/AITj4gftB6V/wob9nz4bfs2+EP8AhFPFfw4sf7S8 DfC7+2v+Ef1XxJ/a/wAKNc+2eLLz+3bv+2L7S/7H0e48u2+xaFp+yXzssHxFwtldXAQy94yGEw8s TOrGdGUmp1MHhsMpxV1d1Xh/a12tZ4idavK86sm4zPwu8VuI8HxFVz+OUV82zOjlFDDVaePpRjOn gszxWOqRqz5Xb2MMU6VDmb5aFOlQjaNKJ/D/AKF+0l+0V4W0fSfDvhj4+fGnw54f0HTF0XQtC0L4 p+OdI0fRdGXW4fEy6TpOmafrtvZadpi+I7a38QLYWcENqNbgh1URC/iS4XTf9qz9qKSzTTpP2kvj 5Jp8fi8fEGOxf4w/ENrOPx6NXPiAeN0tm8RGBfF415m1seJVQayNXY6l9t+2kzV/XV/xDcfsOf8A RVf2rv8AwufhD/8AOLo/4huP2HP+iq/tXf8Ahc/CH/5xdey+NeFZT9o6dR1PaOrzvAJz9rKssTKp zfF7R4j9+535nWXtbudpP5CHgb4u06SoU8TQhQVONFUYcRTjSVGGH+pwpKnFqHs4YT/ZYw5eWOH/ AHCSpe6fxr+Ovit8Ufig2kv8TPiT4++Ij6DHqUWht468Y+IvFraLFrOoy6vq8ektr+o6gdOj1XVp 59U1JLMwrfajNLe3QluZHlP6Pftc/wDKL3/gkL/3f7/60L4ar+gr/iG4/Yc/6Kr+1d/4XPwh/wDn F19B/EX/AIIlfsqfE34Dfs4/s8a98QP2g7TwV+zD/wALf/4QHVNI8V/Di38Uav8A8Lq8ZWPjjxT/ AMJfe3vwov8ASb/7Bq1hDb+H/wCxdE8P/ZdOaWLUf7VuWS7Tkr8ZcPOrlTw3tqdHCZhWxVWEMJ7O MYVsuzKhKUYRaTnPE4yEp2V5OVSo23dv1ct8EPEenguLYZhHAV8XnPD2DyzCVaubxxE518LxNwxm MYVas4ylClTy7KMRCm5Nxj7OjRiknG38NXgf46/G74ZabBo3w2+MfxU+HukW3iCbxZbaV4H+IXi7 wnptv4puNEuPDNx4lgsdB1ewtYvEE/hy8u/D82sxxLqMuiXVxpT3LWE8tu3U2n7V37Umnppkdh+0 p8frKPRY9Ai0aO0+MfxEtk0mLwpa3lj4Wj0xIfEaLYR+GrHUNQs9AS1ES6Na315b6cLaG5mR/wCu n/iG4/Yc/wCiq/tXf+Fz8If/AJxdH/ENx+w5/wBFV/au/wDC5+EP/wA4uuufGvC1WUp1YVKkpOk5 SqYBTlJ0P4Lk5XbdG79k226evJbr5NLwM8XKFOFKhiMPRpUoVKVOlS4hnTp06dZydanCEGowhVc5 upCKUZuUuZPmd/4zfGfxJ+IvxHfRJPiF4+8a+PJPDOjxeHfDcnjPxTrnih/D/h+Cea6g0LRG1y/v m0nR4bm5uLiLTLA29lHPcTSpAsksjN+lH/ODj/vK5/76HX9BX/ENx+w5/wBFV/au/wDC5+EP/wA4 uvoP/hyV+yp/wyp/wyD/AMLA/aD/AOFa/wDDQf8Aw0l/bn/CV/Dj/hOf+E5/4Vx/wrD+yv7T/wCF Uf2B/wAIn/YH+mfYf+EZ/tj+2P8ASP7d+xf8S+uTF8Z8Pzjg4Yd14QoZhQxM4xwjpxUIznUqyUYt JylObk7K8pOUm23d+tk/gh4j0KueV8yjga9fMeHsfltKtUzdYirPEVoYelho1Kk4ymqcKdFU1KTa pwhGCXKkl/Dsv7Qvx9XTZtGX44/GBdIufA+l/DK40pfiX40Gmz/DbRHmk0X4fTWI1r7LL4H0iS4u H0vwm8TaDYPPM1pYRNK5bodZ/az/AGqPEUz3HiD9pj9oHXZ5fDmoeD5J9Z+MvxG1OaTwlq09jdar 4WeS98STu/hzU7rTNNudQ0RmOmXk+n2M1zaySWlu0f8AXL/xDcfsOf8ARVf2rv8AwufhD/8AOLo/ 4huP2HP+iq/tXf8Ahc/CH/5xddb424WclNwqOalUmpvAJyU6ymqslLdSqqrVVSSd5qdRSb53zeSv AzxcUHTWIw6pyhSpyguIZqEqdD2fsION+Vwo+ypeyi1y0/Z0+RLkjb+RSf8Aaq/agutTs9auf2kP j3cazp+razr9hq0/xh+IU2p2Ou+I9GPh3xDrVnfyeImurbVte8Pk6FrOowypeapoxOmX009kfIrl fhn8cPjV8FrvV7/4OfF/4o/Ca+8QQ21tr158M/iB4s8CXet29nJLNZwavceFtW0qbUobWaeeW2iv HmSCSaV4lRpHLf2K/wDENx+w5/0VX9q7/wALn4Q//OLo/wCIbj9hz/oqv7V3/hc/CH/5xdEeNeFY RcIU6kISpwoyjHAKMZUad/Z0pRVk6dPmlyU2nGF5cqV9VLwL8W51YVp18NOtSrVcRTrS4hnKrTr1 lFVq8KjvOFaqoRVWpFqdRRipSfKrfyA6N+0j+0R4dl8cT+H/AI9/GjQpvidcT3fxJm0b4peONMl+ IV3dRTwXNz44kstdgfxZcXEN1dQzza8b+SaK5njkZkmkDZ8/x6+Od1a31jc/Gj4sXFlqngPTvhXq dnP8RfGE1rqPww0dmfSPhxfW8msNDd+A9Ld3bTvB9wknh6xZ2a206IsSf7Dv+Ibj9hz/AKKr+1d/ 4XPwh/8AnF0f8Q3H7Dn/AEVX9q7/AMLn4Q//ADi6X+unClreynZwp02v7Pjb2dGlOhRpv+5SoVat GnH4YUp1KcEoTabfgZ4uStfEYd2nWqq/EM3apia0MTiKiu9J18RTp160171WtThVm5ThGS/n1/5w cf8AeVz/AN9Dr87/AAJ8afjH8LrS6sPhl8WfiZ8OrG+1jSPEN7ZeBPHninwjaXmv+H2mbQdcurbw /qunw3GsaI1xO2kanKj3umtPMbKeEyvu/ud/4clfsqf8Mqf8Mg/8LA/aD/4Vr/w0H/w0l/bn/CV/ Dj/hOf8AhOf+Fcf8Kw/sr+0/+FUf2B/wif8AYH+mfYf+EZ/tj+2P9I/t37F/xL6+fP8AiG4/Yc/6 Kr+1d/4XPwh/+cXXNg+NMgpxxsK8sRKGIzCriYweFc4uHPRqUZSi21zQq0o1YppuE4QmrSjFnq51 4HeIuJqZHWy+GX0quX8PYHLK1WGbRoVIV6dLE0cVCnOMVJ06lHESozkmo1aVSpTknCUk/wCRm1/a y/ansZLmWy/aX/aAs5bzw3B4Ou5bX4y/EW3kuvCNtPqF1beFbl4vEaNP4bt7rVtUuYNDlLaZFPqW oTR2qyXlw0nLeIfjz8cvFvhX/hBfFXxn+LHibwT9i8N6b/wh3iH4i+L9a8K/2d4Njmh8IWH/AAj2 paxc6R9i8Kw3FxF4btfsfkaHHPNHpcdqsrhv7D/+Ibj9hz/oqv7V3/hc/CH/AOcXR/xDcfsOf9FV /au/8Ln4Q/8Azi66FxnwmtqUl79Kppl8V79Gc6tGei+OjUqVKlOW9Oc5zg1KTb8yp4H+L9VNVcXR qKVOrRkqnEdSadKvSp0K9JqTadOtQpUqNWD92pSp06c04Qil/Pr+yN/yi9/4K9f92Bf+tC+Ja/ND wh4/8d/D661e98A+NfFvge88QeH9T8J69d+EPEmseGrrW/C2tLEus+GtXuNFvbKXUvD+rLBAup6N ePNp1+sMQuraURoB/d58Ov8AgiV+yp8MvgN+0d+zxoPxA/aDu/BX7T3/AAqD/hPtU1fxX8OLjxRp H/ClfGV9448Lf8Ihe2XwosNJsPt+rX81v4g/trRPEH2rTlii07+yrlXu3+fP+Ibj9hz/AKKr+1d/ 4XPwh/8AnF1hheNchpV81lVniHTxuNhWpr6tKSlR/svLsHNVI3sr1MPWi4u6lBJu6kkelmngb4iV 8FwfDA08upYvIsir4LEVYZtCjOjjZcV8S5xSlh6sYqT5cLmeEmqsHFxqucF71O5/I1N+1n+1RcSX 0s/7TH7QM8up3d5f6lJN8ZfiNJJqF9qHh2Hwhf3t87+JGa7u77wlbW/he8uZzJNc+HYIdEmd9MiS 2XlvF/x6+OfxB0S58M+PvjR8WPG/hu81HSdYu/D/AIv+IvjDxLol1q+g6QmgaHqlzpOtaxe2E+o6 NoUUei6TfS27XOnaRGmm2csNmiwj+w7/AIhuP2HP+iq/tXf+Fz8If/nF0f8AENx+w5/0VX9q7/wu fhD/APOLrdcZ8JppqlJNKik1l8U0sO1Kgk0rpUJJOkl/DavCzsebLwP8X5QnTli6Mqc414zpy4jq OE44mKhiYzi24yjiIJQrppqrFKNRSSSP59f+CVX/ADkh/wC0Uf7YP/vO6/LTR9Y1Xw9q+l6/oWo3 mka3omo2Wr6Pqun3Elpf6Zqmm3MV5p+oWN1CyTW13Z3cMVxbTxMskM0aSIwZQR/ex+z/AP8ABEr9 lT9nD/hdv/CD/ED9oPVf+F8/s+fEn9m3xf8A8JX4r+HF9/Zvgb4o/wBi/wDCQar4b/sj4UaH9j8W Wf8AYVp/Y99qn9saPb+Zc/bdC1DfF5Pz5/xDcfsOf9FV/au/8Ln4Q/8Azi6ywvHGR0cfjsT7XFRj XlhJUZRw81NOjS5JPSScXGdnFp9Lp7HdmPgRx/ish4dy+nhsreIy3+11ioyzOkoL67jIVqPJJwtO 9OL5rW5Xoz+MTx3448T/ABL8Z+KPiD411JdZ8X+M9c1HxJ4m1ddP0zS/7U1zV7mS81LUH0/RrPT9 Ltpby6lluJksrK2haaR3EYZmJ0r34neO9Q+G+g/CG68QTt8N/DXirW/G+keFYbTTrSyj8W+IrDTd K1bxBez2lnBf6vqU2maRp+nW0+r3d8dNsYWtNMFnBcXMc39lP/ENx+w5/wBFV/au/wDC5+EP/wA4 uj/iG4/Yc/6Kr+1d/wCFz8If/nF10R434XhSpUIRqwoUFSjQoxwKjSoxocvsY0qatCmqPLH2Sgkq fIuS1onlT8BfFapiMVi5zwU8VjniHjcTPPnLEYx4tyli3iqzTqYh4qU5vEOrKftnKTqczk7/AM+v /BKr/nJD/wBoo/2wf/ed18SfBL9pDxx8BvDXx28K+ENK8Kalp/7Qfwm1T4OeM5vEljq95eaZ4Y1e /stRub7wxJpeu6PBZa8k9jCsF1qtvrWnrE0iyaXK5V0/to/Z/wD+CJX7Kn7OH/C7f+EH+IH7Qeq/ 8L5/Z8+JP7Nvi/8A4SvxX8OL7+zfA3xR/sX/AISDVfDf9kfCjQ/sfiyz/sK0/se+1T+2NHt/Muft uhahvi8n58/4huP2HP8Aoqv7V3/hc/CH/wCcXXFHjHh6eIzX6w8RUwuYU6FFweGk1UpfVpUK8JpS TSkpOL11i209j3q3gn4kUcr4Whl0MuoZlkdXNa06sczpRdGricbTxGGnRm6bU2oRbenutWaZ/Lp8 Ef2+fjZ+z/4B+Ffw98Aab4CTTfhD+0PL+0p4b1XV9H1681y/8Z3Pg/8A4Qa+8Pa9Nb+KLHTbvwTq Hh557a706x0vTdcaS6nkh8RQqY0j/Rn4c/8ABcnxl4a+H/xVu9e+EXw1i+Kq2fwP0f8AZ88JeHPB XiGT4D+DtP8Aht4t8Z+Jdd1PxPbat8Yx4+j8RPL4vl1Dw/c6bqmsWc2q2VnHqNvaafbGK5/XL/iG 4/Yc/wCiq/tXf+Fz8If/AJxdH/ENx+w5/wBFV/au/wDC5+EP/wA4upx/EfBWZKo8XRrzqVa2FxEq 6wtSFdVcJPAulONWM1KMlTy/D4fmi1KNBVYU3CVWc5dGSeGvjtw9CFHK8wwNDC08JiMDHByzahUw jw2IpY+DpyoTpOM1Tq5liMXTjK8PraoVakaioU4r8W/+CTvxnu/jD/wU+/Y3m1T4ffDHwlrfh60/ aFTXPFPgPw5qGh+IviTqviH4LfGLX77xN8R7y81zVbfXPESXV3Na2t7p9no1vBp+y1+xvsWQfnj8 Pv21fjx8Kf2bfF37MHw28RyeBfBnjj4j/wDCyPEfirwjq/jLwx8Q9Qnk8KxeEL7wfc65oPivTtKu /AeraXBDLq3h+/8AD929/eRRvNfG3RbYf2a/ssf8ESv2VP2RPjz4E/aH+G3xA/aD1vxr8Pf+En/s XS/HHiv4cal4Xuv+Es8G+IfA+o/2pZaD8KPDWrTeTpPiW/uLL7Jrdl5eoxWks/2m2jmtJ/nz/iG4 /Yc/6Kr+1d/4XPwh/wDnF1jT4m4VWIxtKVKq8txGEyunHDSwspUnWweZ5jmcouk5NRpU8RXw1WnT X7lcvsowVKCgdVfwq8W5ZTldSjisJS4hw+b8VVsZjqWaUaNWWX53w/wrkdPlxFOlG9evhsqx9DEV IpV7ONedV1qzqH8eS/Hj41f2vNr9x8VfH2o67N8O7r4RnWdZ8U6xrmqQfDC80yXRpvANlf6xd311 p/hQaTPPpsGiWMtvY2llPNbWsMMUsitnr8Zfi+uo+ANYX4rfEldW+FFlaab8LdUXxz4oGo/DXTrC drmxsPAF8NUFz4NsrO5d7i0tfDsunQW87NLDGkjFj/Y7/wAQ3H7Dn/RVf2rv/C5+EP8A84uj/iG4 /Yc/6Kr+1d/4XPwh/wDnF163+u/C/OqlqyqRacan1H34tSxEk1P4k1LGYySad1LFYlrWvU5/kP8A iA/iu6Toupg3RbbdL+3n7Jt/U7t07cjb/s7L7trX6jg7/wC60OT+Yj9kb4t/FX4m/tu/sPW3xJ+J vxB+IVvoX7XHwWvtEg8ceM/EfiyHRr7xZ8cvCOt+KbzSote1K/TTrrxLrLNq/iC4tFhm1nU2a/1F 7m6JlPoPxR/aS8efslf8FSf2q/jn8NNP8M6n4x8MftO/tYabplr4utNZvNEEfivxz8RfC1/cSw6B rvhvVBd2ljq9xc6dLb6vbrBfxW800dzCj28v9O/wk/4IA/scfBr4q/DL4v8Ahj4lftMX/iX4U/EH wZ8SfD1jr3jL4W3Wh3uueBvEem+KNJtNattP+DWl39xpNxf6Xbw6jBY6np15NZvNHbX9pMyXEZ8W /wDggD+xx8Zfir8Tfi/4n+JX7TFh4l+K3xB8Z/EnxDY6D4y+FtrodlrnjnxHqXijVrTRbbUPg1ql /b6Tb3+qXEOnQX2p6jeQ2aQx3N/dzK9xJ5/+t/Df1utZVo4HEZVisur0oYR041IY6pUWLpuEHG0a 9GtWjVkrOTnJ35nc+hh4M+J0MlwsVPByz3B8U4PPsLi6ubxrVKLy/B0YYKvGvVjNurhsVQoyowlz KMaUNOVKJ/Fx4r/aF+PXjyHXLXxx8a/iz4ysvE3iDSfFfiPT/FnxF8YeJdP8QeJtBs4tN0LX9csd b1i/tdY1jRdNgg03StS1KK6vdP0+GKytZ47aNYhej/aX/aItvEXi7xbp3xy+LGieI/HvijR/G3jT VvDvj/xP4bufE/i7w7fPqXh3xJrQ0HU9Oivta8O6hI974f1CaNrnQ7ljNpUlo/Nf18f8Q3H7Dn/R Vf2rv/C5+EP/AM4uj/iG4/Yc/wCiq/tXf+Fz8If/AJxddseNOFYKMY06kVDSCjgElHXBv3UttcBg Hp1wOEe+Gocnh1PA3xeqynOricPUlUalOU+IZycmo4+Ccrt3ahmmZwV9o5jjoqyxeIVT+NTxt8Uv ib8S10ZfiN8RvHfj9fDsOoW/h9fG3i/xB4qXQrfV9Ql1bVYNGGu6hfjS4dT1SabUtQishAl7qEst 5crLcSPIf0h/4Lekj/gqF+04QSCD8FiCOCCP2evhNgg9iK/oK/4huP2HP+iq/tXf+Fz8If8A5xdf Qf7U/wDwRK/ZU/a7+PPjv9of4k/ED9oPRPGvxC/4Rj+2tL8D+K/hxpvhe1/4RPwb4e8D6d/Zdlr3 wo8S6tD52k+GrC4vftet3vmajLdywfZraSG0g5Vxnw9TzHBYig61HD4fBZnSlGnhHT5a2MxWWYiM owg0vfeGxE6k1rz+87ynd+rHwQ8R6vDWdZfjI4DEZlmGfcLY+lUrZvGs54TJsq4qwNZVK9SMpJ0v 7Uy+lQptu9JSjDljRsfxIn9qv9qE6gNWP7SPx7OqjUv7ZGpn4w/EP+0Bq48LHwMNVF7/AMJF9pGp f8ISx8H/AG4Sfav+EWJ8P+b/AGSTaVX0v9qD9pfQ9SOs6L+0R8c9I1htD8L+GG1bS/i34+0/Um8N eB7lrzwV4eN9aeIIbo6H4QvHe78L6SZfsHh+5Zp9Jt7SVi5/rz/4huP2HP8Aoqv7V3/hc/CH/wCc XR/xDcfsOf8ARVf2rv8AwufhD/8AOLrqXGnCid1Tmnamr/UI3tSjKNNelONSpGC2hGc1Gyk7+U/A 7xebi3iqDcG3BviKo3BydNycdfdcnSpN2td0qbfwRt/G38SPi58VvjJrVr4k+L3xO+IXxV8RWOnR 6RZa98SPGniTxzrVnpMM9xdRaZa6p4n1LVL6306K5u7q5jsop0tknubiZYhJNIzf0ceOv2jPAXwB 8Rfs3p8UvHWo+FPCnxB/4N8fhV4C8Naall4q1nS9d+JvijTvFdn4UsJdK8N6bq8VpfXkcF9aw6/q 1raabp8JkS91WzimAk+7P+Ibj9hz/oqv7V3/AIXPwh/+cXX0H+0B/wAESv2VP2j/APhSX/CcfED9 oPSv+FDfs+fDb9m3wh/winiv4cWP9peBvhd/bX/CP6r4k/tf4Ua59s8WXn9u3f8AbF9pf9j6PceX bfYtC0/ZL53n4zizhvESoUabxFHCfVc0wtZUcJGEqUcxwsqDq0IOMqftYyqTqxlKnOMaqU5wmrqX 1vC/hV4pcO1Mfm3JleMzyOYcN5jgHjs3qYmjiauSZgsS6OOqwqUcRLDyowhRlCOIpynRvShUp6Nf Cmof8FTv2D7fxrZ6vZ/Gy/1HT/i58Xtc8f8AiqeP4W/FO3Pwc0rUf2NLf4FW9t4tiuvCEc3iW8Hj Oyh8xfh7H4qjWwuHug7RW4kn+ALD9tf9l7Rf+Cov7LPxpt/ih/aXwN+A37Nvhn4Na98Un8B+PotN 1rX/AA38EPHfhN9R0zwZP4Zk8eNpN94j8Q6dpcSXvhiKYMZ7m5hTTIzen9Z/+Ibj9hz/AKKr+1d/ 4XPwh/8AnF0f8Q3H7Dn/AEVX9q7/AMLn4Q//ADi682hmHBmHnWnSxmcr2+V/2RKLpUmo4SGUZpkm FcH9X51WwOX5xjadCblJVKkoVcZDFTpxb93MuG/G/NaOAo4rJuCbZdmlDNsPOni8XGbxNPM8lzfE QqJ5jKnOhj8dkGW1MVDkU4Qp1KeCqYOFaaf4lH9q74E/tH/sZ+NvgL8XPib8Kv2ZPF3iP9r7wd48 jtPht+zv4j0TwQPhZp3gw+H77xf/AMIj8HfCCaBf6/Bqlw1/rFve3Wn+IdYSytnijuZIbVE4f9sn yfD/APwTi/4JJ/8ACMeIZdSt9E1z/goN/wAI94r06HUNEm1CDTf2lPDw0nxBY29z5GqaRLdxw2+o 20Fx5N/YNIkcvl3ETY/e3/iG4/Yc/wCiq/tXf+Fz8If/AJxdfQfxF/4IlfsqfE34Dfs4/s8a98QP 2g7TwV+zD/wt/wD4QHVNI8V/Di38Uav/AMLq8ZWPjjxT/wAJfe3vwov9Jv8A7Bq1hDb+H/7F0Tw/ 9l05pYtR/tW5ZLtOiHEXDWExuFxGCr4+NF5msdi8PLD0/YxdPhtZFTq0rU1X5+XC4ac4utKMquIx dRx5PYQo8GL8N/FDPMrzrD53l3DqzCpwtTyLK8fhcyxMcTUX/EQMFxhUw+JU8VVwcacFWzJU60MJ TqqnhcDQ9pzuvUxH5Y/DX/gor+xreaj4f0zxz8fJ/D4T9nn/AIJuwax4y1b4dfF7xDBJ8R/2WPij r/j34oeCb2LSfBeo+ILrW7y3vraHTvEkdjd+FdRu7iaZfEE3lESemeHv+Cp/7Dd1FafEPU/i7qmh a9D/AMLb8Cn4c3vw0+JN3rw0j4iftfaH8V9N8dPreleF7/wkui6f4F0x9X1HSY9bm8TeY76ba6Rc 6nHHZ3Hv/wDxDcfsOf8ARVf2rv8AwufhD/8AOLo/4huP2HP+iq/tXf8Ahc/CH/5xdY4jMuDcTip4 ueKzeE55hjsycKdGjGlGvmWCnlmMjGLw8mqVXLprBKHM3Sp041qUoYtzxE/VweR+OeDwFHL45PwT Xo0cJluD58RjMbKtVp5RisDj8BUq1KeZU+atRzDAUcbKcVFVqsqtKvGphJRw0PkP42/8FLP2O/Gn wm+N3hjR/jfc6trXi/4N/wDBQ3wl4dsZvAXxbhGo638a/jfoHin4P6d9o1DwRBZ2i+IPCVhPdW9x fT21j4dghGna/caLdtFZte/4NiP+b3v+7a//AHv1fV3/ABDcfsOf9FV/au/8Ln4Q/wDzi6/QX9hL /gm58Df+Ce//AAtP/hTHir4r+Jv+Fu/8IP8A8JJ/ws/XPCGtfYf+EB/4S/8Asf8AsP8A4RTwL4K+ zfaf+E11X+0/t/8AafnfZ9P+y/Y/KuftfnYzH8NYfIswy/KcRmNWvi6ODoRWMpQUeTD5xi81b5qd KklLnzHFRu006dOhBJSjOdX2sm4b8Uc08Q+G+KeMMv4aweCyfEcQ4mq8lxVdyU86yJ5a4qjicXi5 zgquHwjgozi4e0rznKacVD9AJ3MUE0igFo4pHUHJBKIWAOCDjI5wQcdxX8M/gP8A4OIP+Cv8/wCy r8Wf+Cifir4Bf8E6PFn7HfwP/aak/Zw8beBvDFx+0H8O/wBpDWdXl13wpplnf+En8QfEP4g+Arq2 8jxnoxnmMN5qRlXUbpfDcen2Mkx/uYnQywTRqQGkikRScgAuhUE4BOMnnAJx2NfwveE/+DTb4oeF /wBkj4o6vp+vfs66P/wVJi/awsvi/wDs+ftLaJ8aP2j7f4aeC/hHaeJfCGuJ4U8R6Ifh7Fop8VR/ ZPGNzDcR/BbxHKL6/wBJhfxabESJYfBZd7ufQqYzm/sqnhcrdS9px9pV4syHD4/kwzUY4uosirZn KrCWIwrw2EWIzCjUr4nBUMDi/wCjpqhPKK1OKg8fUzKmqSdSWHk8LDh/iWs1LFwVSeDoyzWnk8XV hhsW6mIeGwtSjGhiK2Iofrf+0F/wVf8A27vil+2j8U/2Jf8Aglv+zZ8BviL44/Zh+Cngf44ftJeL f2pfE3j7RdGWbxto2j+J9J+CPw30b4dvY30vxK1bRNd0+20zXdb1Cfw5Drh1K11DT4bbSWuLz9l/ 2M/jh8Tf2i/2bPhh8XPjR8AvG/7MHxZ8TaPOvxC+B3j+C4TXfA3ijS9QutL1K1t7q5tLGTVdA1F7 RdY8Oaq1pbyXmi39k1zBBeLcwR/hB+01/wAEYf23Lr9qH9pT9pD9j/46/syWNh/wUH+CfgD4N/tu /C/9o7RfjSum2l34b8M6V4a1r4j/AAR8dfAfWfAvjuHxA0WkxX2h6Vdap4Fjj1G71O6utaSO5060 0X139g3/AIIh/Ez4GfBT9lDwh+0X+25+0jP8Rf2Q/j78Wvidojfs0fHDxF4U+E37QPhbxX8SNA8W +DtG/aP8J+PfBGra/wCL7a30Xwrp2man4Nt/EP2DQbbWvEug6Z4v8QWtzDrNdmBjQlh1QxLhRnL2 E8bipyliKtDHrN8yo5jTy2MHTWIymnleJyipgVV/eYyjhVUg6GPjnCq+XiZV1KlWop1EoUYYehCK outhp8O4GvCpmTkpxoZlPPsLmtDFqjalgp4unTg8Tl8svqRwvh5/wXd+Mvxk/b08S/si/CL9g3wB 4q+GHhT9q7xd+zLqXx213/goX8Avh748v7L4a+KtL8M/E74m+E/2VfGng/Sviz460fwYuotqEume CrzX7bU2hXSrXxCmqNcW9pt+L/8Ag4D0Xwz8cPGfhiy/Y5+I+ufs5fDb9svTf2EPHXx2j+Lfwy07 4kWnx31XXtL8O2s/hr9le7Y/FDxZ8OlvtSWZ/FlnqVpqFzp4hvdK8NanE17/AGd4l8Y/+CIP7Unx 3+N3hHSPEOrf8E4vhL+zl4K/bX0P9tC2+Mv7OP7NPiD4Sfto+KdW0PV59RHgbxM2hND4BOp64krX Hiv4qr4vvtZ8Qa3JDqUvha0g022sJfEvHf8Awbv/ALV/ib4+fE7WrD42/spP4c+J37bVt+2LB+3N rXgb4kS/8FNfhhpdrrljfW3wD8AeOIGk8MQ+A7PR7KHRtPvf+E50rTLSGKZT4Hntru3ttJzyf2Mv 9WaeZar91DOa1ZuNTF2xHAUcdicXHDKjTwVOGDrcefUcHhYYavHFYCjiZYnNKOJyjLcR05tdf6xy y5KMuWtUyenTbnRwvNT41lgsLh5V1Orjp+1pcFfXMVXlVjKlja1BYTL6tHNMZhPoT/grr/wXd+Lf /BPj9vH9n79m/wCFPwu+G3j34L6V4c+GvxN/bo8deLtF8Xan4g+Enws+Knxl0P4WeHL/AMJav4e8 eeGtD8NaxFHc3d7LJ4s8N+LbW8uta8MLDZ29t9ueX6z/AOCtf/BTX43/ALFPhzxtqH7Nnhb4SeNd Q+GP7G3xT/aw8dXvxP0Txh4i0WytdN+Inwt+Gfwb0e3Twb468DSx23jfWvFnjnUrtpb+ee803wPc R6dNYOJbhvzK/aT/AODe39un9rb4pf8ABUr4v+P/ANtn4WfDG6/bXu9H8L/D34XeFPAGnfFrwr4l +EnwlTTr/wCA/hn4t/ED4k/C/SfHfwe1HS/EXhnwvqfieb4E2+syRXaX2ow6r4haCz06T7Q+Cv8A wSR/aa+K37H37XPwP/4KC/EX4TP8Z/2gf2UvgT+xh4Z+JfwM8R+NPiRpGjfDb9nzwPq6eE/HmrHx /wCBPhTqU/ijXviv4t8TeNvEvhy30mKymto9Psh4guZma5t/P5a9ThapFOcM9wtHNM4dOcoxxGNh xDluYwyzJ6WIi44anX4UzGWUVfZ+2q1cT/tkcTQo0YTqHZehT4go1GqcsqqV8ry2Wk54ag8kzDIf 7WzGpRjWeJnT4gwNTih0aypKjB4fJ50p1ZV6mFw/E+O/+CzP7T/hi9/4N+baw8CfAWZP+Cren+E7 v9oc3nhf4hSP4Mk17Q/g7qd4vwXMPxRtx4dSOf4ha0lsPHC/EVkhtdLWVpnhu5L39YP+CkHjv9v7 4Z/AJ/Hn/BPXw/8Asr+IviP4R1PVPE3xHsv2sj8TT4NT4UeH/CHiTWNak8JxfC3XvDusz+OG1my0 OLTodSv10aTTpNUWfy7g2s0f4mfs1/8ABEj/AIKBX3x7/wCCb+t/tzftE/sn+JP2fP8Agk9p8ulf syeHv2d/BnxQsviZ8TobHQ/Dek+Gr/4y33jpLDw9oGo6TN4P8L3E48JSa1aXttpM1u0K3mqT6nb/ ANOfxc8J6j49+FPxN8C6PPZW2r+NPh94z8J6XcalJPDp1vqPiLw5qWkWU1/Na215cxWUVzeRPdSW 9ndTpAsjQ208gWJvQ4nqUZZTnNfJIOONrZ9xfm+TUacZRq0smqV8LV4VyzEU52UJRWFrwrYJyc6V DFeyq1Y1KjVPjym7zfK6eOVsBRyDh7K81nVcXTq51HF53/b+Y0JQk3O2DxuVRpYxJU518FzUoTp0 uap/Mn/wSu/4LX/tkfHP4VfCP9rz/gpQP2JPgh+xx+0x44uP2eP2etU+A3w8/anvvi5q37UN38Q0 8HeF/Cvj61ute+MXgrwZ4G1+30Txl5HibXdS0bTY9Qg0Q3+vaZFNPbSfsB8QP+Cw3/BN/wCFeveL PDvxD/aZ0jwleeBf2hF/ZW8Xajq/w9+L0XhbQvj3/wAIpe+N5/AN742j+H0ng0Pp/hnTrvUNX8SR a9L4P0WVI9N1bxBZarcW9jL+A/x6/YF1L/gnL/wbE+Of2U/2svid8Nbb4zfCXxTqvxI+EvjX4Sy+ OvGHhq++Pf8Awu64+K3wP8NeE7zWfh/4W8TnxB4p1OK08FvJeeF9Ms4b3Wbm1GoPaSLdS/nb8ff2 evj38MP+CcX/AARM8W+ME0Xwd+2P+2H/AMFmfCv7W3j3UfiF4N1ZtJ0r4y/H3V/E+u+D7rx74HS/ 0LXp9M0fRE8GDX/C0ep6PqKWcF5o9te2E4S4j9KdPCY3M6mDwdvqeE4g4Z4boYjCU1Xq4upxXm/C 9PAxlz1aUK+Z4bC1+OKmKpzqYeNOlS4MTjClWxM8bw/7Rh8JTrVG/reNw/EuYujiZtQw+F4dwPEd SpiVCFJeyy3E1KfBtHCyVWrUr4ifFUvddPDfVf7L/Cf/AAVb/wCCd/jb4AeP/wBqHw7+1Z8N5/gf 8LPF5+H/AMQfF+ojxH4fvvCvjtrtLGy8F6n4K8Q6Fpfj0eKtZupI4vDfh+DwvNqvicyRt4dtNTSR Gb3T9mL9sH9m39snwfrPjj9m34p6T8SdF8M64/hjxdZJpXiXwn4v8E+JUtorw+HfHnw+8daL4Y8f eBtdNpNFdJpHi7w1o2oSW7iZLdo8sP5pPGn/AAbs/tSfHH4V/tKfEX41ftO/B7Qv22/j7+2/8H/2 0yvwQsPjF4F/Zs0nU/gjoPivw34b8CWt/Z+IdL+Mnh865Z+Ndb1Kf4heHbyLxv4V1i30a/06/wBb 1GxfVJ/1f/4JU/8ABOD4jfsXeJv2lfjT8b9Y8C6l8a/2nNW8C3Hi9fAnxj/av+Px/s74f6VqOm6J J40+Mv7WHxD8R+MPiX4lhTVLmzsdftPAXw2/s7QobXRbiy1iK2tJ7Pgw8KE44t4mbozp5dl1ahSp zVVRzCvlnD2JxmHdaVOnHF0KeZYziLLoSo06FXDxyfD4mvCpRxtCVfoxEqkFh/q8fbc+OxlKpKcP ZXwdLNM3w1Cq6aqVJYaq8sw2U5kpTnXpYqWYzwtJUatCv9X+5fFX7cX7Jngj9qLwJ+xZ4r+OvgnQ /wBqT4m+Gbnxf4G+Dd5cagPE2v6Bax6hMbmK4isJNEs7u7t9I1a50rSNS1Wz1jWbXStTutIsL23s LuWHH/bf/a9tf2MPg7p/xJh+DnxU/aA8YeLPH/g74WfDj4QfB3SrS/8AF3jPx144v3sdHtJ9S1W4 svD/AIT8O2ccN1qGv+LvEd9aaNotjbM88jzzW8EzfGH/AAT/AP2PvH37XHw9/bs8XfA/wzrX7Vnw t8L3Hg/wP8Wri98QR6jpGizR6hBD52g22rw+FNW1XTLbV9XtNE17WNCv9b0S11S9t9K1C0jlCr5r /wAFPPht/wAFCPjD+y9rPwy/4JtfFL4M/BL47eMdcsdJ1v4rfGPXPGWgr4P+HUllqLeILj4fXvgz 4c/Ey8t/H2oXi6VpmnajeaJbRaPpd1q+qadqNrrtrpUqediJzhgcLKMa88d9cccZDDeyVKWFlnHJ ho4erXp1nQlLKHS+v4mrh8UsJiHicTh8JjKdKlhqvfh4U54+pGUqMMD9UhKjPFOrzxxccvnPEyrQ oSpurRjjkvqeHo1qFbF0lDD1MRhalX29P85x/wAHEnwk8LeCP2hdM+Mv7K/xv+Fv7WH7Pfx4+Dv7 NOpfskQ+KfhZ4/8AEvjn4xfHy31S7+GHhvwR8U/CPii5+GWoW+oWug67d+INRudWtU8P22lys0N/ NcWlvP8AoF+wR/wUa0j9tHxd+0Z8FPGfwO8e/sv/ALUP7Jnifwn4b+O/wD+IXiPwN43vvDkPj7QX 8SeCfEXh/wAefDjWdc8IeLvD2v6ZDdeXfabdRPbXNs8ckLQTWlzcfhT8NP8AghB+3lrv7KNx8E/j Fq//AATj+C3xV+DP7SvwP/bI/Zq+LP7N1h+058TNY+Jv7RHw81DxVN488SftoeKPjvJY+OviO3jT T9W06Cz1zRtZvNT026l1R0sotNt7HSpP1+/4Juf8E/Pjd+zr8d/20v20v2s/H3wo8YftT/tw+JPh re+NvDvwE0vxdYfBf4aeEfhP4Vbwv4U8K+D9Q8fGPxl4mupop5LjWPEGt6do73T21oINLt8zA+zS pYOM8csRUhJwyyn7KdFzjQljo5dwc6FfAU3OrWX17NK3Gyx+Ex1es8Bg8HlvK8PWlRjmHn13U9jh 5YZVVUljKd6dVUp1Y0auPzp4qhjqsVRoulgsnjkE8JiMDQhKtmtbGYapPGYeFSphvk7/AIL5/wDB Y349/wDBMC1/Z48IfsofCr4bfGX4yfFCH4rfE/x54d+JOh+L/EOleF/2fPgn4Zi1zx74qt7XwV47 8B6lpepI16tza61qN3quk22m6Dr4k0a9uvs3l2P2jP8AgtL4y+CP7TP7Gws9J+D99+xP+2J/wT++ On7VPhHx3qWkeLm+I9j8Svg58JtZ+MreHz4otfHVt4Lk8I33hRfD1vPpP/CGN4hGo3N75fiCJWt4 ouF/bO/4It/tj/tuf8FGfjp+1Lq37YPgL9nf4J6x+yl/wyd8GtE8E/DzQfjx4+1L4c+N9Jv4fjRo nxH8HfGf4e2vgHwPD4v1LX9fit/EXw+8S+IPFh0iSyhi1LQ5ROp+G/jn/wAG7X7ffx0/4JY/sP8A 7GXiD46fs12n7RP7Gfxl+J2l6N8VbLx/8Y7Twpq/7JvxM0zXdO1TwXFq9t8GF8UL4tNle6N4fuPC lz4c/wCETu/DWlHT7nxZPDNLby+ThKdTE5aqVar9Vx2KxznGrWcYvCYPOp8T8Lup+7p1aSo5Bh8R wZxhHCVqkcc8ZhM/vFUJUE/Tq/VaeY0b3qZfQwTo4l4eN6tbF4LC5HxXQqfvZtTljsbhOJODcTVw 1H2SweLyqMZ18XWnCh6r+xv/AMHA37V37Ukv/BKPwRefDT9nnw38Vf2tvjB+1hoH7XunReCPitBp 3wr+F37M8On+KZtR+H+iX3xan1nwn4m1jwHqdtdTaj461DxtpI1LFzBosdrNHYj0X4Q/8Fof+CpH 7Umk6t+2Z+yb/wAE+vhb8Z/+Cc2jftAal8ELHwhovij4hX37cnxC8O6L4gsdJ1v42eDNEsYf+Fa2 vhbSbW4lmu/Cep6XcayupRyWP9sixtLrV09Q/ZR/4IW+OPgJ/wAFgf2jf24fE3jL4aav+yp41+EX iTwf8DPhRoviLxrc+PPBvjT4j+CfhX4L+JWt6x4X1HwVpvgbw9Z61p3hDxTbnUfDnjDW9T1W31DR G1Kzhe3aOy/Pz4g/8G43/BSLTP2afEX7AnwM/a7/AGW7X9kTwP8AE/x98ef2aPHPizTv2ivAf7T/ AIL8c+J5bx7X4beKNU+FPiC0+Gt94B1S0uZdM8SeLtd0L4jahaS6hfa74f8Ah5b3lrotnpnouvh/ aZbilho+0xGXU80q4OTawdDM6vEdChm2V4+MUq0MNhuF8ulXynDUKl6uIzTHSpYmnmUssdLzaVOv Up4qjVqUqPJj6eXuvF1HXnldXK83zDB5jg2+ah9bjnmbZblmZ1WpLD4TJcLehUw39qxh/X78bPih q/ws+AvxU+MnhvwB4k+I2u/D/wCFXjH4jaF8MdGtbmDxZ401Tw14V1DxFp3gvT7MWl3ewa5rt1aQ 6PDbrYXd3DeXIjSyuJ1Fu/5bfs6/8FCvi/448N3fxrk+KX7Hf7aXwBt/hn8QvHfxKl/Yg0TxVY/F P9lXxJ4L8Hx+N9N+G3xE+H918dv2g/iJ8cNW8Qx3UXgqWTwP8Lvhj490DxMmm6lqPwhbR/EbR+HP 0lv/AIZ/FVf2XYfhH4D+Kkfwo+M9j8F9K8DeGfjBpfh3RvH9p4N+IGleEbTR7LxhB4Y8b6ZJpHi3 TLLW7Vb2TS9e023/ALW08yQyrYXUyy2/58y/sT/tCfHX9oH4Y/HD9oH4a/sj/A3xj8GfDXxY8Pf8 Lb/Zo8fePPHXxP8A2i7X4o/DbxT8Obrw/wDE638V/s+/Bb/hXfwxt7/XLL4n3Hw3fxv8d1l8b6R4 fS08UWf/AAjb614i4cfCpRqZ/TwFaNdwwGMp5XWcYJKtRw+bLD4ijCup4bEvE4p5XzUZ1MPi8O6d Cthp4vCSzTCVd8DUhWweSVMdRnQqPEQrZnSjN+1nCrLJ39UrypqNXDuilmKo18NCthpqrjI5jTou nllZan7NP/BZ39kj40/Bz4MeOfiDrHjH4P8AxD+Iv7OXgv8AaW8feAdU+Cv7Rl/4d+DPw68W2vis yeM/HfxRuvgxo/grw98J7PVfAvizTNL+M3i2+8K/D3xTBY6Lrei6s+l+M/B8ms+0L/wVX/YXg0Lx t4g8QfFfxj4At/h5e/Ci18WaR8V/2eP2lfhB4ysrP44+NLT4d/CfxPp/gD4o/CDwh458Q+AvG/jS 9h0HSfiN4c8O6t4BS6W5lvfElpaWV7cW/wALfslf8E4P23v2d/hV8SNH0z4ofAn4Y/GNf+Ccv7LP 7FHwZ+I3gPxB4s+Jtvo/jn9mPW/j/FbfFDXtP8b/AAZ8F2mjab4x8O/EbwbqkOkQaX43k8J+Ij4g 06SPxZY+HdJ1jxV5pq//AASv/bZ+Jfxl8R/Gj4j+J/grpl943/4YVfXvDeq/tRftHftE3ejz/slf tp+H/j74l/sXxd8Qvgd4A0KDS/GHw10+/t9C8NeCPhT8KPDtl49WGDX9O1e71zxL8Ub338Zh8oqc URweDxEKWQYrO/ZPHRdVQwGT4nMsa6FeMMVz1qio5Vh6Sqe2rTxNHE16MsVS99U54x56WX4idVyq Y2hg8D7GnFU6n1rHzweQvMKM5UVGMIUMZj82VPEUqf1avTyyUaco3jOf6uL/AMFI/wBj1vBmp+ND 8RPGUcmkfE6L4MXnw1n+Af7Q1v8AtDP8Vbjw/wD8JfZ+A9P/AGXp/hVH+0hq/iLUfBYbx1pdjpPw rvW1TwGknjjTmufCccmsL87/AAH/AOCsPwW8U/DbxV4/+MPiQ21xqH7S37Ufwu+Dvg/4N/BP4+/E z4m+Mfhb8APH7+GJPGl/8F/h/wCFfid8X4X8M6Tc6RL8WPE9x4O0Lwx4O1XUYIvEFl4RNzDYDmPi T+wZ+0fafteeP/2zvhFqvwR8Q+MdO/aJ8DfF/wCF/wAMPiT4u8deEPDHjPwin7Hy/svfEPwx488c eG/hl481H4YeJor66ufFvgrxN4c8D/Fqzls9Nj0jV9GsT4hu59E+S7f/AIJH/tUWXijTvj5q+r/D Lxf8aZPiJ+2lqfiD4Y/DD9tv9uD9h7wPP4O/an+N/hf4x+HLzSv2if2YPC9r8Vn1TwLJ4a/snxN4 B8T/AAw8SeDPHUt3ZarFq3hrU9A069fwaDUq9OU/3dKrk1RV/a+0lHC5pOhkuLoUqVOFK+JqYrHU 8bl1PExnDDZVhsVXlmMpU8NUxsu7ExpRwkFRSqVv7VwNWHJVgqlXAvCcSU8bTrVJqEMLSwCq5Pia 1KcKs83xVGhHAVcPUqVcFh/0L/at/wCCp37NXwS+Anj74hfDf4m6N8SPHSfsweK/2jPhenhP4e/F j4wfDpfDzeE/Eep/DHxj8YPFPwk8PanoHwn+GfjrxJoMuh6P4l+JvjL4a6X4mu7PV9H0DxANWsbo Wntnxf8A2odb+GH7IPg744w6LourfFL4m6L8EfCnw68LNBqi+GNW+N37QWqeEPBPgDSb+C1vJ9bt /Blv438Z6feeI5be+uNU07wfYatdxXM91aiR/wAv7z/glz+1P8Hvg78e/hJ+zC37K91pv7Wn7Hdr +zx8UIfiZ8Rf2ldP0/4N/EHS7X42SL45+Hmq+M9P/ac+JXxq8M+Kbn416pBreifE74i+DNf0nV9K k8bWfiLV4dabwDpf2P8Atv8Awy8YeEP2JfgbqtpaweINY/Y7+Jv7H/xw8b6fo0eoahDq3gv9nfx3 4H1H4v3OhxR2UWrahJpnw/sPF/iTRLaLTo9R1G40mztRp7T3Js26oU8H9bq06lWawFfiHhPBVK9S tGjUwmR1s7zbC8RYmE4QahPBZRWweKrZjCc8NXlSoYihRoxp1aJyTqYp4bLp4bCUamYU8r4oxawc ZurSx2aRynhqvw7hMRXrU6Hs6WMzenm+Bp4OthqVfBwlinWr4mlVw+Knyf7Vnxg/4KJfCH40/s8f Db4S/GX9jXxdqv7S3xg0zwZ4S+FniD9jH44XHiTwn8NvCvh4eK/jp8UfFnxY0r9v3SdHk0fwJ4b0 3UrrRmh+EVguseKvEfgPwFJGlzq8viGvpbWv25/hD4rCfDf4AeOvBPjT9pbxfr/xo+G/wv8AhT4/ 074u+CoH+KXwMt2/4WFa/FaDR/hd4t8dfCzwJ4UuJ9Im1Px14j8F2/hvVrXxL4LXwzq+qnx94MuN Zs2XwE8SeLP28NL/AGwr3W/BeufCvw/+yHF8HPg5aafqN9e+JrPxT8RfibH4++KPiiSA6B/YkXhz xJ4Z8JfCax0TVdL8UXl/fPp2rw3uj2lnHY3l9+fv/DCv7fHwq/aQ/aG/by+AWqfsc6x+1X+1H4d8 afDnxz4D+Kt/410H4MeAvBHgmztdP/ZQ1rwt8QvAvwNvvit418S+F00p7z46aT4j0rw/Z/EebxdJ YaR4i0TT/hl4GS5xg4xw9GjjKVaEXh+JMVi/ZJRx2GxeHxcsuyTKaVWLlVrU8ww2XUsyjOrTjPB4 jOMV9bx+Ho4fDwlfLB1qlTD1qVRw/wBXsPhKkqk62Ax1DF4RZlmeZ1lFONF5fPM3gcQqPM8X/YMM LhcHOtmU8ZhNn4p/t7/tf/st6j+0X8M/jTpf7Pfxl8ZfCb4L/s//AByi+N/wn+H/AI6+DPwc+FPg 741fGvVfg54uv/jl4D8efHj4sa4dE+Cmi6B4i+NupeItK+LPhVPHfw88OeIrSXS/hw+kS+Iptb4Y /wDBSf4j6h8E/il8bdY179n74+fB39nj9qL4cfCvx1+1B+zro+pWHwT+O3wT8eeHfAqeMPij8FdN Pxv+MUPhS8+APjj4m6fpvxKN18Ufi/ourab8M/HVnpsmh+I9X/s/wRzfhj9iP9tTxl8EPEfw++NP gr9mbw/8WdR+L/wM/af8WfHLQf2q/ij8a9V/aV+NvwP+KvgL4hWfgj4ueFdT/Yb/AGe9N+G/wa1r R/BieDPD1n4LvvG9r8MdBh0a00fwB4ia11C61LE/ab/Z7+M837Ov7Z+lfFOy+Gnhz4+/8FS/iL8G vgP4a+DPwa8deIPiH4B8DTzeEtC+GGueLLH4geNfh38Gtd+IXiTSvhZ4c8Z/F7x9rj/Cnwh9i8J+ BNP8Nw6ZrEPhX+3tY68GoRlTjiXhq+Iq4rB4SEaaapV5VM54b/s+NO/sW8NiKdTiHh+VqOX5tUwu Hef53Vp18zyJYCKtSNT28qNGpQo+yxNWc6qc6mCpUskxNPM8TLknGjGrF0KPEiqTq4rJ8BiMZUyf Kko5Tiq1T9376+ttPsLzU7mRVtLKzuL6eXcoVba2he4lk3MQoURIzbmYLgZJA5r8VPgZ+3p+1x4/ j/ZM+JOt2H7MviH4Z/8ABQzw38WL79l/wBpnhb4q/DTxf8NfFXhz4W+LfjJ8KtA+Mvxebx98a9G8 daR448F+ENTXxh4l8H/BHwC/gbUoQmlaH41+0W0D/r14stvF8emeHND8J+HPCvibTdR1ax8P+Om8 V+MdV8Iy6L4BudNvrbWtf8NQaX4C8cw+L/FNtMunwWHg7VpPBWj6pb3l9c3XjfSXsILPU/x8+B37 A/7YPgK2/ZN+G+t6v+zH4c+HX/BO/wAP/Fy2/Za8e6T4i+KnxI8T/FLxN4k+GHjD4NfCXVfjd8IZ vAnwc0vwDo3gTwJ4y1F/Gmh+B/jh49n8ea4En0nVvA1vHEicVJUHPHurLE+7SVLBukoRTpRweZVM 0k4V17N4pzq5D/ZVRKUpYhY+lh5ylRxsKdOU/qeHvCnHFTqYetVhKTnShVlUjDB06lTDv2/1OOIp YxZvTpNVFgXh6soRVfCzqd18Dv2n/wBsr4w/Gj9pr9k/TfjF+xR4o+KvwU8C/C/xde/tB/Cv4F/F bxp8Efg98RvFXi3xDpXjX9l34sfCqf8Aa20rxR4x+KPhnw74aOv2XinRvjT8MruHTvEelan4x+EP hN4dP0XxPxXwB/bu/bGuPCPxi+JPxN8N/CL9pn4e2H7S198BPgNrP7O3wO+KP7Pd34x8IfB/+20/ ah+PHiez8Y/Hv9rFh4J8E3/hfxv4d+GGj6Z/Z+pfE7xN4L03StMvlk+J/hhtJ910j9nP9rn4g/Gr xL+098WdO/Z6+EXxk8LfspfFf9mr4VaH8Ffit8SfiT4Q8dav8Qtb8LeLtO+JXxY8ReLvgb8JtZ8M WHhrxH4N0+Lwp8O9L8OfE5vBtr4h8YajF488S3eqpZp9X/sZ/ANv2Wv2Tf2c/wBnWe60/UNS+Dfw c8A+Adf1XS5p7nT9b8U6D4dsbXxXr1rd3en6VeXseveJF1XWDfXumWF9etetdXtpBdTSxrvS5Pq0 6k5wp4uOCwVKpQ5I1aNeriM+zepHEUJTjKVJUMiyHKaNegpUsdRwnFnsswxFfiTBYvNZzVnF4n2a pVnh6mJdSnJShCVClhMgyiliaNapS5VKri8/zPGYyjVhCrgatbI8bTwVCjkWKwmBg2XU/wBqP4n/ ALP/AIM8SeCk+Fv7LXx48S6boXiHX/DPxj8CeJf2ofC/ga3vIpLrUvB2p6V4A+Ln7MF/q3ieG2ls 7e51ix8Z2+k6NqkV/ax6d4itkgvpPzg/Y3/bP/ap8f8AwZ/Z6/aK/at/aH/ZB8JeDfj38XvGHwj8 O/DT4a/sVftD6b4n1fxL4N8S/FzRm0HTviXc/tp/FfStEvvEOifCnVfFVtrviH4YLoOhx21zoNz/ AGtf3mmXUv7bOCyMo6spAz0yQRzX4u+CP+Cc3xu8Nfsn/sRfAm+8U/CuXxd+zX+1f46+OvjrUbTW /F0nhzVvCPie4/aVlsNO8J3c3geDU77xHCvxk8MC8tNY0jQdMjaw14Q6vcC1086pw4mrVpSxWIwe Hi51MblUqOHqOpiKVGhXxvsMeqca1SV4YfAqFRRm5Q54e2nCpOpW9rdClGtKFHF15xpU8sziUq1F Qw862Nw2VYvE5bTlKnHnj9bzSFChLklGo6dX2MK1JRpzp/RPhv8A4K0fsBeKvBWr/EfS/jfq9v4D 0r4E+If2mLfxZ4i+CP7QXhDQ/F3wR8HafZ6l428b/DG+8W/CvRIfi2vgSDULCDx74d+Fx8X+LPA+ p3tpo3izQtH1i4isX7jSv+Ckf7F+qaF8SvEUnxim8Oad8KNL8E694rh8ffDT4u/DbWr7w58TdUbQ fhj4o+H3hr4g+AvDPiP4u+Ffib4iRvDPw28UfCfSvGugfEDxOP8AhGvCGo6zrpGnn8z/AIo/8Emf 2iPGv7E/7J/7Nuj+Mfgna+NvgV/wTV/aV/Y48X6nf+IfHEHhPUvih8Zvgz8K/h54b1/w5e2vw4u9 WvPAlnr3gjWLzxBqmp6FpHiG30y60+4sPC+qXk91ZWnrf7af/BLv4k/tS/Ee+8aaT448KeGbDRPg Z+yN4c8G2dr46+LfgDXNQ+KH7MX7R3iT423el6j4y+Ew8K+O/h54P8V6Jqtt4e0X4l/DvxgPiD4K 1+UeJ9O8MXL6DZ2mretjqOBoY5UMNiXWwUs4xeAnjnzzWGyzD4/OuTO5UKFCdfFU6uWYPLJU8vw0 PrNfFYyUqNSTqUsHDaMKby+GJ5m8a8LOv9Q56cHUxEcTwzhaWXrEVOWnh511mOeYx42tehhsPl0I 1aUlRrYit9qp/wAFHv2P38ASfEL/AIWJ4wjii+IsXwhf4az/AAH/AGg7f9o3/hac+hN4st/h2v7K c/wsj/aafxnc+DlbxxbeHU+EjapceBVbxvDbSeFFOsDm/wBkD9tu0/aB/Z9/aA/aK8WPoFn4D+Ef x2/aj8HaRqXhzQvEvh6S4+FfwH8Xa5pelav4g0TxjqE2tWXjKTQNHkk8UWt5B4fEOtR3Ns3h7QXi ksYfhfwH/wAE1f2i/hx4x8H/ALVHgrwz8EtK/aY8C/GeHxxF8LPiR+21+3h+1R4V+IfgE/Bbx38E 7jw145/bH/aa0j4g/EzR/Eun2Xj/AFHxV4L1fwT+y1pOgeGILI+BtW8N+MU1U+NdL+5f2OP2UfiL 8N/2e/j78Kf2mJvhprmuftBfHn9qX4neKbD4Tah4kv8AwdbeEP2iPGWu67H4btr3xV4c8Mau+o6b omuSaXqcz6ULea7je6t5XSby4/MxkKioZs8BJfXI8OYhZfDEzpuhSz2pV4dqYdOUIyp4pNvNuStS qRhhsMq2FxNOpX5a84oTpuGWrF0uWm+JME8bPDTnUxFXJaWE4rpY20alPDvBJVFkMpUqkcTHF4ir hsRhcWqdPEYel598Jvjd/wAFFfiT4H+DP7UFp8NPgNrPwa+M7fDzxGf2TtK8P+IfDX7Snw1+EfxL vtIksvH+s/tG+Nfjnp3we8YeMfBPg7VofG/jj4SWvwM8HxyCDV/CfhD4l+JdZ0vSrnxV7XpH/BR/ 9jHXPGmseBNO+MbvqWlTePrKx8RXXw4+LOm/DDxzrPwq07VtW+Jnhn4Q/GbUvAlp8Ivjb4x8AWGg a9N4x8GfB/xv448V+HW0LW7fVdHtbnSdQhtvnPwJ+z3/AMFH/C/wq+F/7IsfxS+BHhT4O/Clfh34 SX9sLwj4z8e6j+0/4++D/wAN9Q0Fbbwhc/s9+Ivg2fhh4B8f+L/B+kHwV4s+KUH7Qvj/AE9fM1Hx Tonw10691m20nw38keKP+Cev7T3hL9mr4Zfs+eP/ABH8CY/2Yv2Crr4t/GT4X/E/wd4o+JOpfH34 2Wei/Cv4y6H8NvB/xA+HOr+BtA8GfCm70GD4kzv8QfF+i/GH4vJ8TZNBDW3hLwLD4hvLTTTPMXhs Fh84xWXxisuwk8zxeVfXHVWLeU0qNOq6+MqtufLl0YVMRQy7HKOdZxi55hg6WLweX08nqIyrDV8S 8HQzGcf7Uq0MBh8UsvjGeArZnUhjFGhhI6ThHHYqODwc8dSjLB5Xha+Dx2Ow+IxcM3jH9E9A/wCC rn7A3iTwF4s+KNn8dbjTfh54P+Fy/G678X+LPhJ8cPA2ieJfg8t1o9hf/E74Y3fjT4a6APjF4F8P 6l4g0TSvFvib4TDxrpPg7V9UstJ8VXWj6jOlqeusP+CkH7G194I8eeP5fivquh6R8OL7wdp/iLQv GHwk+NXgb4l3s/xJvp9L+Fsvgj4O+M/h1oPxa+J1h8W9TtLvTfg/qnw18E+LNM+LOo2l3Y/Dm78T XVrPFH/Pj8Yf2fv2m/H3/BJX4bfHn4ySfAbwjoP7Pn/BLyw+GnwMsfhjrvjnxlqvxJuvjb4d/Z7Z vHXxa0jxN4F8A6b8ObPw9ongDSdPHww8Ka58UbfUtWvr/XW+ItrBFZaJF99fH/8A4Jm/tOftf+Jt R/aH+Mus/CD4efG7wef2c7X4RfC34H/H79pHwj4D17R/2f8AxN8VvFF5N43/AGl/h74Q+C/x1+HP iD4mz/FvWItJ1T4aeC9TufgsdM0t4bn4uL/aCX/q5pg6WAzKvg4Tk6OGzWrgcXVre0VTCYKhn2Jw c8xdGlhqlTE155RDCYyWTUI/X8LLEzqTdarhq+WQ8fKcwWY5bhcY3GWKxeT08xwuFoRUaeLxtbA4 DEUctji8TWo0cLhp1q2OhDPMVbBTnhI0JUaVOvhcdifv3VP+CnP7F+keGvBfiS6+I3jme5+IHxA8 R/Cfwx8PdJ/Z2/aU1744z/FLwj4cj8YeJPhtq/7POh/CHUfjv4X8e6R4Slj8UXXhDxT8OdG8Qf8A COsNai0+TTc3I+qvHfxt+Dnwrg8EXHxU+Knw9+Fi/ErxLpHgr4fRfE7xhoHw9u/GvjXXo2l0XwV4 YsvGN/ot5rXjLU0ST7H4TsIJ/EE7xTRJpxkikRfyU/Z0/wCCa3xU+HHxx+Bnx88SaX8LvCGteGvj 38WPi18U/D1v+1D+2P8AteeMLrSPEf7Ml18APAcL/tCftb3mr+Mvit4tsJ/s1xf30fgr4BeGfDvg w2HhnTfDfiTUvDx8QeI/0O/ag/Yf/ZV/bPf4RSftO/B7RPiy/wACPiRpvxa+FJ1fV/FOkDwr480n y/smqlfC+vaGuu6fJ5MB1Hwx4kGseFdYNraHVtEvjaWxi5akKNOpgouUpQnWyyWYOM6U54fDTp4P +16WG9m50cTi6M3j3gJuvTw1VrC0qsoxVTFT7KVSrNYtOC5qVDMFhJ8lSnTxOLtinlftVVjGrh8K prB0swmoVqri8RiMNT0pYeXgn/BUX41ftZ/svfssfGP9qX9mvxz+ztpOn/s+/CHx78S/Fnw9+OPw A+JXxYvPiLeeG7KLUtK0vw9408BftQ/AiD4d2xggvrXUJ9S8HfEaW6lurW6tksEsprW/v6H+2NpP 7OHwm+LnjL9vX9pX4K3+p/B3RPhZ8Q/iD4l+E37M3xt+CnhXwH8PfjZc/wDCN/DWG68M+IfjD+1D rHj/AFLWvGekeJNNbxD4K8VfZrYwxabq3hTRZ9On1HUfUv8AgoR+z140/ax/Yg/am/Zp+HWp+F9F 8dfG/wCCvjj4ceE9W8a3uq6d4S0/XPE2kTWFhdeIb7QtF8R6xaaVDNIrXc+m6Dq13HECYbG4bCH5 d/bC/wCCdXiz9qX4sfsx6lL4u8E2fwO0DwjqfgP9rz4c63YX91qHxe8OeE9Kn8T/AAHPhW6ttJdT d/D34yS3Wu3CaxqGjQnw/rWsGydr+Q2dzkpqhhnGnSjWnWxsI13UqXq0sCqeIxuIlQdWFZqrVr0K ODw/s1D2U8TCMpRwUa9GfXNQn9XqSm4SpUcxqVKUIyjHEVKM8lp4LDznTjJUZTw9XNp0qro1o1K9 NPEU5SUKtL6f+Jv7f/7KHwk8Q634N8V/EfW9U8d6DrmleG7n4dfDT4S/Gb40fErUta1XwbpXxDFl 4V+HHwd+Hvjvxx41Oi+BNe0Pxf4wuPB2ga7a+BPDutaRq3jSfQLLUrKaf1iw+Iq/H34HR/EP9lL4 r/DK4fxxoj3nwz+KPiHwdrXxY+HNvdw37Wd1Pr/gTw58RPhB4i1z+z7i01HSNV8OxfEHwVrOlazb z2epXFpeafd6e348fAT/AIJv/tpfs0L+zh+0Rpfjb9nn9oL9sr4deGf2gvh/8cdL8f8Aiv4g/B74 QfFbwx8Z7/4RWHhrxF4d+IfhT4RfFDxV4T8ZfDjwX+z38ItB/wCJj8HvENp4ssLfxBoct9oMQ0jW 7X9O/wBhz9mrWv2U/gDa/DLxV4q0zxj41134lfGn4y+PNZ8P6fe6T4Uj8b/Hj4teMvjB4p0bwbpe pXd7qFl4S8Pav4zudD8P/b5zf3mn6fFqWoRwX17cwpvVw+DeGqKOLnWqqEIVfZwqYWNPEe2qwnQo Sc1XxVCpho0cfDMqbw0KMq6y2eHniqVatT5oVMRF4eUqdONT2tpQVsRTqUYQrOWNcpRjDD2xNOjQ hlmIpV6uIo4h4t14U6MqNT87fgp+1z+27f6X+0r8Rf2iv2mv2IvAfwq/Zn/a61D9lPWrrwt+wR+0 pfaz4w1CDxH8LfDmgeI7W5sv+CgXjO58MS+Mdb+JVj4at9L/AOEQ8WWfhm8ltvEGra3eaPa6hbJ9 y+Ev+ClP7GHjjx1a/Dvw58WNYuNev/HvxS+FOn6nqXwf+OHh7wDqHxW+C+o+J9O+JHwr0/4q+Ivh vpXwvvvidoJ8G+JtUtvh5aeMJvGPiPwzpUvi7wvouteFprXWJ/l/xB/wT3+M+q/s/wD7bHwqt/E3 wwTxD+0j/wAFAdF/as8DXk2teK10XSvh5pvxW+APjqfRvFdwngqS+sfGb6R8K/ENvFp2kadruhtq N5o0L+Io7a4vrzTszRv+CdPxp034N/BP4eyeJvhX/bfw4/4KS/tJ/tjeILuHWfFn9mX3w1+MXjj9 qbxJ4Y0XS528ER3dz48sdO+N3hG313Tb2ysdAtbrTfEEWn+J9Ugs9Mn1bjdSosoy6q4xnjo5RwzD FYeMFCrPNcbkfC39t4qtJLbBZxjM/r4rCwUKLWDeEwbwVKHO+zC0MPL+2KlavUhNcR8WRwEJT5qb yPBVeKsRw9GlBxbtjKGX8O5dRruftJf2h9axUMRiZ1Jv6i+GH/BUL9hb4vadFrfhH45pYeGbz4N6 t+0Fo3jL4i/Df4u/BzwJ4p+Dfhu0sbzxh478FeO/i94B8DeD/HGl+AItS0+P4kW3hDW9b1T4b3t5 b6d46sPD2oSrbHT0X/gpN+xnrfg/4g+N2+K2s+GdL+GNt4OvvFGjfET4PfHD4W/EC50z4j6q2g/D LWPBfwr+JPw38KfE74maH8UvECP4d+FmufDbwj4s0j4l+IkfQfAt74g1dGsh+cfjn/gkB8Vvip+y L+xX+y94p+I3w58Mt8Bv+Cfvxv8A2TPih4p8N3vjLVIn+IHxJ+G/wa8LeHvE3gSyXQvB+o+I/B1j 4i+G+qXniA6rrHw78Rz6Pd2i6bHFqF5cPpmdp/8AwSm+PerzXfxR1Oy+F/gn46/DPV/gVrvwVuPG X7dn/BRf9u3TPG958EvjH4d+MV5oXjzxn+1brkEPwV+HfxDvfDVro6+Evhr8IPiD4i8AatcL4zHx D8fRWH/CGX/o4mlgKWa1cNDEzlldPMK2GqZlCE69WlltPO8xwqziGDhSpvHxeVUstxCyvCVXmFSe JrYuhGrRh9Up4VPaLAUa1ClCtj6tJzWBq4qOEpPEKnlvJgamMdHELCOvOeazWYVaE8Jho0sPQxKj NKti/wBFv2N/20k/a0+LX7Y3h7Q7NbX4d/AD4hfCjwb4IfW/hx8T/hP8TFHjL4KeEfiH4q0/4qeB fi3Z+HvGPhzxPo/iXXb6xt9H1XwL4J1Cw0iOyi1HSrq5J1G58X8I/tKft6/tCeAvFf7T/wCzN4K/ Z/vfgnoXjD4laF8Mf2cvH3hnxb/wvn9pXw38LfGOv+BbvxTon7QjfGvwT8IfgRefEPWfDeq3/wAN tD8U/CD4p6JNoJ8P6h4u8deGT4iv4/CXsX7GXwG/aJ+Hfxa/bL+Nv7Rtt8FNE1/9qH4j/CrxroHg v4J+M/Gvj/R/Bek+Avgn4P8AhjeaHrXi/wAbfDL4UXviTUTqfhy5u7fXrXwjo8Wq2FxBNNo2iTq2 np4f4d/Zn/b++A/w78e/sr/s0+L/ANnTT/gh4m8TfFLVvhR+0d438ZfEay+PH7NXhz4teLfE/jW6 8K6R8ALH4ReK/hz8ar74a6t4mvrH4beKNW+PfwlsV0caJbeI/BWpv4auX8VcdlCeGUY3rxyfLXGE 6tOrR/tX6tlzzCnXrKMMHOuqjxkIyxXNlnIsa41KmOWVVJ6N88eZSo/V/rijiW6ValiJYBUsYozp UuaWJVF1VhJYj6jKnncq0sJKhSo5e84pU/qO9/4KDfsoaP8AFOH4LeI/iReeH/iDH4m8MfD7xA11 4F+IWpfDDwV8WfGFrp9z4e+Cvjf9obQPCur/ALOvhb40asdV0yDS/hXq/wAV7bxxrEup6SdH0S/i 1jSpb3nPA3/BTn9iP4j61daH4S+MWo3jW7/Eq0tte1P4RfG7wz4F1/X/AIOp4in+KPgjwd8R/FHw 30b4f+OPiX4FsfCXiTV/EXwv8HeJtd+IlhoWj3uvyeGDosYv2+HtR/4JuftSJ4O+J/7JFl49+D3i D9lL4v8A7V+g/tWeJ/j/AOLfFfxBX9q3TJz8W/Bvxw8d/DZfhdpHw+h+HHiLV/EfjvwhND4f+NMP xp8Hf8In4d14WC/BvV7rw/aXupfH/wCzz8A/2jfjf+w94K1Dxr/wpLwx+zl+zj8XP2+f2hvB3iTw p4m8bap8bviJ4kh8Vftd+BdB8CeJvAmoeAdG8E+ANE0O98f6xq2t+NNK+J/j/UfHVpY6dpY8HeC2 lvr6bjx+JWEyjE5h+69vhsur4yvT/fU8PSlTyfL8XiJqNRTqwpZfmMs5wtPC1q31jOqeWU44TE4W GLweOxhhaca2Z0cv5q3s6+MnhcLKcKdTFYiCr4+nl86joOOGVTNqcMonip0FKlw88ynLFU8b9Txt DB/tH8O/+CnP7DXxQ8OeIPGXhr47WmmeDvD3wtuPje3jD4ieAvin8IPCfiX4PWK6cuq/E74ceJfi z4H8E6J8VvA+g3er6RpHiXxJ8Mb7xdpfhnxBqumeHNfudN17ULTTpsa+/wCCqP7D+leFR4q1v4me PvDzv458H/DeHwJ4k/Zr/ag8N/Gu78Z/EXRPE3iH4b6TY/s/658GtP8AjlfxfEnS/B/iR/hvq1l8 PJ9F8f3umNpHg/Uda1e5s7G4/JX4d/8ABOf9o39v39iL9kuz+Onif4MfCTw58N/2AfBvw7+AuofB vxf8V9b8Q+PNa8e6T+zz4603xt8WhH4c+EWq/CbStMtfg54f8P3ngH4Y+N/HerPdaxq/ijSfirpd 1aaVpEHu3w4/4Ja/HIfG/wCDfx+8baF8KvBPir4c/Hr4JeLddtdT/bp/4KC/t3+Mta+GHwr8I/Ha 21GCy+L/AO2DJDBpc154w+LWn6j4Q+FXhz4ReErDwylr4q1rWfjL4uutesdD0j3MdgqWEzjEZdKc oUMNmsMDVrTd61LBx4mrZdUx9SlKlQgqlTJ40cXLL4VamLy6daWKxkZRw9fLqfnZVjFmGQ0s1bi8 VXyXEZlh8PTi44fE455BTx+Cy3D13KrXcZZjKtS/tCrhaOFxkaMMDhnTq4vDY+f2t/wUF/bL8Q/s 4fs//BD4t/D74hfBn4H6Z8Yfjr8GvhxrHxY/bB+Hvjaw+H3wn8C/E201i9v/ABb8Qfh9rnxQ/Zm8 V+G9X0eKxs4LjRPGvjjwLd6HfTz2HiCztr+F7SL59/Z6/wCCrngaLTv2gNc/aE/aP/Za+Ovwc+En j74HfDXwT+1f+xP4R8d698Ovif8AE743WWqzWvwW0/4O+C/ih+1v41T4h+Gb2HwvYR3/AId8f+LN E8Y3vjjRtH0y30vxNYatoNv9lft2fBP41/GTwj8C9Q+AWmfC3X/iB8Ef2nvhN8eovDHxg+IXi34W eDvFOkfD8eIF1LQJPHXgv4T/ABs1rQdSvRrELWNyvw71q1zFItwIQVY/D3ij/gnz+0x8cfj9N+1b 8VtK/Zq+E3xJ1j4t/sI3+s/C/wCF3xE8f/FHwmfhl+x98WfH3xK1XxJq3xa8R/Ab4P6943+KfimP x/Po3hrRrr4UeFfD/h3S/D+k6Vc+Lb5ZX1K187LFGdfFUq79jSxfFeFwntsSpVZ5dw5iYcDUp46k 26NLE/Vpz4maWFhQrUayxGMxka+Bpwwc9sxdSnh516SnXrYLhT65hMNhFGnDNeJcPjuKZ1cvqO1W pg418vjk0nUxssThqtNYbBYH2GZVfrsPsvVf+Cm/7Geg+JNB8K6/8QfiD4f1DWtX8AeGdR1HxB+z d+01ofhH4ceM/ilbaNeeAPh78dfHurfB6z8D/s7/ABN8S2/iPw49n8M/jv4i+HXj6E+ItAjvfDlr LrWmJdcncf8ABSX9nbwV4FutS8WfGux+JHi6/wDGH7RejaDbfCP9mn9oy8k0jTfgb8UvFfw58T3n j3wF4b0/4t+LfCHgb4UeIdFg8BfEr9oXxdqHg/4La94isbjxZpWp+D/D/iLRtGsvkH9tf9g3/goN +1F4o+J3huH4sfC7WvhHd/HT4MfGr4K3PiT9oH44/DK28FaB8LvGHwt8S3PwX8V/s9/CX4NReEPH trdz+E/GesWnxP8AiN8YviRYy654l0ya4+CtvqHh3wv4i8Lp8Kf+Cef7ZH7NviDxf8RfhFqH7M3j zxn8Wn/a6+H/AI88OfErx98UvCnhXwl8Ovjj+138Z/2kvhZ8Q/B+ueH/AIO+Mr/xP408J6Z8WLjR fiJ8JtU8NeENB8WX0Frb6T8Y9HtdDg1LWc68fa5RKpSdSjjcVDM1ToxqU/b0I/2DRxOVUZupRSw2 OnxDKrkuKxDdTA0FBZjGrUymKx9f1IfVoVFr7R0MxyKnKlUUVRr4eeOzChnmMjWjKLngqGV08Nmu Fw144uo6kctq4aebTo0sN7v+y/8A8FafgB8Qfgb+yjrvx58c2HhL42/HH4M/s5+NfiHbeA/hL8bt W+CHw18eftE+G9H1HwN4W8bfFqw8NeOPhl8FJfHusapFY/Dbw78ZfivoviHxMt5pVvpU2sz6hZy3 f2X+0r8dda+E1/8AAbwB4GstG1L4pftFfG3QfhV4Kh8RWOqaj4e0rSNM0PxB8TPip4r1u10a/wBL 1B4PDXwm8CeMrjRY49Qs7e98aXPhTS765gsdQuJk/GTwP/wSq/bG+HHgX9mLwj4E1X9nf4a/E/4V fs/fs2/CTxJ+1v8ABT9ob9qr4OfEnQNQ+D/hbQNA8Yad41+BXh/wXqXwT/bv8F6hJo93F8OLb48T fB6DwVo+rSWMnhm+uIZ7vUP0h/bg0vUvCvxk/wCCf/7RUiJN4J+Cf7Smr+F/ileSJLt8P+FP2h/h J44+CGh+L5fs6P5NnpPxR8UfDyx1e6mC6fpmia3qerahJbWOnT3lt7WZRy+rm9d4PkWHrcW4/DYO lQk6eEr5d/auHp5PhacJxlioUMa6jwNfESlRVWjVdTB1KNOnDHVPHjPE08PWTpc86PDaxlSrVnTj KljVlmLrY2ompOlVrYP2UcXh8DH2tStXprA1lOrWjSl8q6B/wVB+IOh23gT9oL4w6v8AAbwx+zX8 X/2wfi9+x14S+Ddr4b8V6V+0P4D134WeNfi54Dg+IPiX4nap8VtS8IfEC41vVPhMNZ1/4U6L8C/A l54G8N+MoL9viP4pfwu6eKOA8Kf8FSfj54z/AGfPin+074E8dfsJfFLT9L/Z00j44f8ADKvg3VvG LftSfsoDx2PDOp/Dmf8AaL03w/8AFT4hJ8R/DQ8E67f+OfiLLD4J/Zkv/C1roE+keH28ZW91N4k0 z2H4g/8ABNrxF+0L+0PP4s+N/wACf2FPBvg/TPjdcfF3Uf2hvgN4a1vRP2of2hNF0Dwt4x8OfCT4 e/GfQdc+GSpoc3w9k8U6XqmueNk/aE+KNn431PwZp8+jfD34a2GsSaPo3ZfswfsP/G/4XeNP2QtC 8dWHwE8JfCP9gP4V+MPhT8HfEvwc8T+L77x18e9N8W+DNF8BrqHxQ+HWtfCvwZ4b+CtnYabocHij WfDPhj4mfG+Hxd47e01z+2vDUGkrZ6h5WEjTqYLGRxH7rE1FQ/spRnUdOjlc8nrxzP69VqOliKuP jn0KMsNGbwubLD4qLy7EU8DhKqn25hKdPMlLBxp1MvSc8W1f2yzGOe1p4GlhIShUpPArh2phqFap TjXwVWthI4jNcPDMsRj8KUf2QP2+/i7+0vrXwp+HGmD4LeP/ABBJ49+NmsfFD43fDPw/4t0/4LeO P2YPhhqNz4Q8BfGr4N6Ld/ETxtdaLJ8efiFqui6F8O49T+JfxJ8OXekeBfi/4g0jW/FFt4ftY0+s f2+/2m9f/ZE/Zp8SfG3w7oeh6lc6V4t+GfhbUvEPjCHXp/h78LfDnj74g+HPBniX40fE6LwxGddk +G/wi0PW77x94zisLvRjcaLoVzbXPiPwzZzXHiDTPzf/AGt/+CWPxs/aQGu/EXVpf2f/AIlfFX4g /FX4pap408DfFnxF41tfhH4d+Hd58OfEPwk/Zk1fwXrGmfC3xVrN749/ZYsNQPxm8I6TqfgrSrfU vjR41+JF/oHj7wDLfaN4qs/0/wDiJ8Mv2lbD4AfDLwf8Bvjboel/Gj4Yf8Ksk1bxP8TvDUPiDwn8 cdN8EWthYeOfBXxCnlsvEHifwjY/FWygvjceO/B5vPGHg7Wp7HW7SLxDbWuoaDrM88amHwsq0XTn RxGQRx7l7SUceq7ozzmdWGXRw+JwdLB4WlRoZssjpyhUrYrF4zhNVMYqmWYCKKnRxk4pPEYecM6l hbyp03h1hq9T+zKCqYt16OIljq2IrvKa+bezrQwWDwVDieFOlbH4z80vHP8AwUg/aF+DPwJ1X426 t47/AGLf2ofgtH8VP2PdB8Nftjfs1wahb/BfxJ4a+OP7S/hv4OfGjwTcfBrR/wBpT49ePdH8f/DH wXqreKPC/jXTvif4p8HeJtQ1Wzgn8Nxah4f1TwtqX27pn/BQf9nT4gat8LE8DfHDTfBC638cPEHw c8aeBPjP+zx8fPAvxPk8T6H8D/HHxnm8Cap4Y+I1n8IvFX7O2tx+CvDkfxWtPHnxk8Can4O8SfD/ AEe60vQdNmv/ABl4b8S6d8C+PP8AgmD8c/jR498TfHTU/h3+yH+y/wDELxX47/YoufFHws+Anj/x 344+H3xB0D9mT9q/wD8e/E3xK+J/xFvP2dPghfeMviu/gjwnc/D74XaXN8GrSLQbOSbSdc+I15o2 swP4V6r9pD/glh8Vv2hP2j/iT4/u/HPgDQPhb8Tv2govH+qG01nxUvxC0r4e3/8AwTY+Kn7FutDT dPj8IDRW8aW/j3x/Y+I9KsG8TQaTL4RtLrUJ9ftNcjg8P3HW5wjlFSbpUp5msRntbC4f2lCNWKoY ThOnk+HxeKhB4PFYXGxnm9ai6WGwNbD1lif7Q58ZTxcJdWFpYSpiqlOtiZYfB08tvLFRoV5Kving MfPEKhg69SrjKFaGZSpUZJ4vEQrKk5ZRPC4Gvl0sJ7V8cP8Agq18EY/2bfj38Tf2X/GFh4z+Jvwx +Fp+KvgXRPin8J/jX4C8IfEzwWninQ/DL/Ef4bXXjfw98LY/jl8JDd61a28XxL+C/ifxN4GmudQ0 hofFEkWo2Qu5/wBsP/gqF8N/gfeaD8OfhJrNr4y+ND/tOfsr/Afxbb6t8JPjXr/wh0CX40/HD4Y+ B/Hfg26+NfhzRNH+Dem/G7Q/hv421Lxhonw0v/ik/jfTUh0/xHq/gTVvDsVxbXXwFD/wRw/aD1r4 U+LPAOvwfCfTfFXhX9mrXv2fvhH8RfFX7en/AAUm/ajfxLd6/rPw9XUfE9r8OP2gtdvfhV+yX4S1 Tw98PLOTXPhr4B8HftC3dzqc+gaZoHxE8L6J4MX/AISb6N+LX7AP7YWqt4m+C/w0v/2ar79nrxd/ wUC+Dv7d158RPHnjv4n6R8adH/4R39of4bfHD4lfCG2+HWj/AAi8U+DtXJvPCOsT+A/iVL8VdIZ7 GfS/AWr/AA90y383x7Z9OEp5fHO8hpVKvtcslmuBxGY16j9nTq4Sjxdk1GVKfPCM8Lg8TwnPM81x dLFUYYnnw1XLf3GYYjD4WXkwljPZ4yrUpezr/VKtOng1KFWOEqVchzOrKTxFOq6OYYrDZ/TyzLqM 8vqTw1Wljvrqm8JgsViI/fP7UP7QvxI8E/En4Dfs1/ATSfBl18d/2jh8TNV0PxX8S7DW9d+G3wm+ Hnwk0PSNQ8cfE3xh4R8L6/4S8TePFstZ8WeCPC+g+BdH8Y+B5PEeteKIEuvG/hmxs7rUF5PSv2mP it+zfonj7/h4E/w5sNJ0DxB4M0T4S/HP4DeC/F8Oj/tJat45t9Wlh+Hfw8/ZT07x5+0L+0XYfGPw xe6TJp8/gTQr74nJ46sL3S9f8DateXJ8SeF/CfT/ALVH7PnxR8bfEf4BftJ/s96n4Ctvjz+zjN8S NN0nwp8Ur7xFoPw6+Lfw0+LXh/TdM8d/C3xT4z8J6J4t8RfD032ueGPAfjDQ/HumeA/iHJoGs+Dr eGfwRrthqd7Avx98TP2RP2/vjP8AEL4Z/tV+NviF8CNK+Mf7P3xk8K/E/wCBf7H2leO/Hmufst6V pWmfDT4u/Cjx1pviz9oSb4I+G/ixqnxA+JehfGDUdWT4kQfAI6H4AuPCnhLRdN+F3iWOPXtb13zM PyciVSapuWIUMwq1qNSuqNCWYUo4erl9GlKNepyZa26v1dVakMU8xqYzD4mlDJsPU9KsqcoycHUd SnlterhKUJQprEZnTp4ycMNVqtOFNYirHC0qk8dKng44adB4OtQxbx1WH3v8Jf20/wBmf44614c8 NfDX4ljV/E/ijRviHrVn4W1jwd4+8E+KNI/4VLqng7R/iX4e8a+G/HPhXw3rfw78e+B7/wCIHg5f Efw28fWHhr4haba67bajN4YGnRXV1b+V6r/wU9/Ye0ceFprn4z3t3pnirwnonj8+I9D+E/xr8S+E PBHw/wDFGq32i+EvH/xm8Z+HfhzqvhT4CeA/GWoaZqK+C/Gnxu1n4feGfGNrZXOpeGdU1XTYXux8 T+Mf+CZH7Rnj74Z/G3xxF8XfAPwf/bB/aC/aptfj7q2t/DjVvGOs/DP4QeCPF3wa8G/sq/FT4aeD PEmreF9A8RfEHV5f2d9J1/VNE8a+Ifh94LtNd+NMfhHxLeeEfCmm6DYpp3J/tH/8EjvGniT4t/F/ V/gtp3hbxH8J/wBob4XfCf4VeKfCPjP9uT/goH+yz4U+FOk/C34fQ/COBbz4GfsfeKPD/gL9rLwT q/gOG1Nz8OvH/iv4IarFd2uq6InxQOieKpH8P68kL4FNJTqRy2njKLxFO6x1XLoY7NKFPFQpVcJh 8Jg8VjcPkuFzSpVxOGxeKyrN8dKNHBV8tVRKMHKolVboSeYSp4v2LTw1GhmMMNgqtXATqQxeMlic vhXzSeGofV8TGNTB4KnTqYuWKhhv0K17/gpj+xl4c8V/FHwXf/Enxlea58GvEsHgX4gv4c+AH7Rf i/QdN+JF83h1dE+E+i+LvCfwn1rwn41+MXitPFnh658D/B/wRrfiP4m+OrHU4tQ8HeFNcsYrm4hi s/8Agpt+xjqPgQ+PNO+I3jm/C/E3WPgzJ8NLL9nf9pO6/aMg+Knh7R7fxJr/AIFuf2VYPhFJ+0xa +IdE8KXdp4y1ezuPhNEdN8E3Vt40vHh8LTxau/zdZ/sU/te/B74UfHfw7+zb8Rfhf4X8U/EP9tTT /jvpmjr408ZeBrPxr8BLb4b/AA28C33wn1v4tXfwp+Mvi74Q+K9TufBC3z+LdD8DfGC+t9I0+10U 6tcz+IdS1bSPzZm/Zt+JX/BNT41R/tmfG745fsseFvHnjj9pb4y+NPAuj/tGftM/tOwfAbVfDHxw /Zw+AXw/+IfhH4qftn/Ef4LfENvhd8RPC3iz4I2eofCXW/FnhKfw78RtAmuPh14J8JfDuHUNK8Ke CZwzwkoL61WlRayfKa7rTjGg62eY7D8L1qmW0sLOVVRovEZpnmXOq8bUqZfXyeriMZCdCOH/ALSx pKvVTvQ5Kn17NoKjCpGvCOXYDE8QYeliZ4qSwyVWrRwGTZkm8NChXweaRjhpzrxxscr/AGnT/gqb +wxd+CfBvj/Q/jBr/jHQPHt/8T7Tw3Z/D74HftA/EbxjJYfBbxhfeAPix4w1r4c+BPhX4i+IXhT4 afD7xhp8+h+Kfit4r8L6L8NNKuJLGWfxYtpqem3F36BoX7VWm6r+0z8NvhRa6j4U8TfCv9o39ne+ +OP7OHxG8Jm5vrXxTP4B1jQoviXpF/rsWqX+h6tZ3/hX4kfDHxj4CutKtNMe40xfGa3Z1BbG0uE/ n3/ZP/4J3/tEfFr4WeAf2tfDemQal478bax+2n4V1v4eXX7Z37dv/BOjw5qvgL4l/tv/ABu+OXw2 +MXg7x5+ydaap4/8U+FPENh4vGp2Hw1+JvgVLHxV4R1fwv4j07xZ4Tv7AjWP1B+EnwAk8A/tQfsB /s++EbPwrB4b/YD/AGTvib4g+J154OufH0vhnSvFPxts/Dnwv+GXhLw6nxS8efFT4hnTNft/Cvxi 8UQL42+Ivi3xRZ6X4X0VtT128/tSN7jpWHhTrRpVoyhiY4vMqM8FKtT9nGlh8u4qrL6xiJUqTVah SweQZnRlQcKOJxeIlkrlPFPEYOksTKHtsb9VqRrZdRqxhhcwUuWpiaf9p5PQoYuhGnLEUo0a9atj 8qq0MTSlWxOHtm+EWFwtTCY6H7HUUUVwmgUUUUAFFFFABRRRQAUUUUAFFFFABRRRQB8+/ta+OPFH wy/ZV/aZ+JPgfVP7E8a/D39nz4z+OPCGtfYtO1L+yPFHhP4ceJNe8P6p/Z2r2l/pN/8AYNWsLS7+ xapYXunXXleRe2lzbSSwv/Fr8NP+CrX/AAWf+NGqahonwd+JHxI+LGtaTYDVdV0j4afsvfCHx3qm maYbiK0Gpahp/hf4Jard2dgbqeC2F5cxR25uJooRJ5kiKf7Hv28f+THP2zf+zUf2if8A1UPjCv5a P+DcYqv7Qn7SrNfPpar+zpcltTjSSSTTlHjXw6TfJHEySu9oP9IVI3WRmjCoysQR+i8J0sDT4f4i zPFZdgcfUy2hicZSji6OHmn9VwFXEql7XERcaMKkqaUpOUYRu5SaSbP5t8XcRnuK8RPDvhnK+Js+ 4ewvEM6eBxdTJcwx2FaeJzOnh/rDw+ErU1iK1KE3yKUZzaXJG97Hz38Sv+Cq3/BaT4M3thpvxg+I nxL+FGo6rDLc6Xp/xK/Zb+EXgW91K3gZFmuLC18UfBLS57yGFpY1llt45I42kQOwLqDz/gn/AILB /wDBXn4l+JtN8FfDj41+K/iB4y1o3Q0fwl4J/Z1+CPivxNqxsbO41G9Gm6DoXwav9VvzZ6faXV9d C1tJTb2dtcXUuyCGR1/Yy18TfsY/t+3X7If/AAT+8YftQeJv2wfEvgHxD4++Knj/AOM1/wCGfEfw 41vxzbeHtA8U3en/AA7sNW13bq8d9q0Ov6el9/Y2q63ff8Iv4FvWu9ettbktZrfov2Zv2M/2e/hz 8c/2Gv2mfh7+z/4z/Y7+Ieu/HL4+/CrVvgT448b+OfGN34i8O6J8Kvjda6f40tD8RmbxHZzT23hr T9XDWqw6NJYa6BbLf2507Vbv26WYZHRjWp5lwzgqOI5MdVwNWnk9GjhsZhqaxlLLcZ7HMKGEx8KG OxuDrYVxp4evVowpvF140MPVhJfEz4T4+zDF0a/DvitnmOyenLAUs1hV4xzDEZnl+M9nhcVnWXRr 5PjMxyOvi8swGKo4uLqZlhqWInWjgcM8Ti6Uoz/DjWf+C0v/AAVa8Oavqnh/xD+0PqWg6/oeo3uk a3oes/Aj4CaXq+j6tp1xJZ6hpeqabffCGC90/UbC7hltb2yu4Ibm1uIpIJ4o5UZRm/8AD77/AIKh f9HO/wDmFv2ev/nTV+uvwX/YC/ZM/bT8UfE3xz4g+HiQ+NfhB/wUO/aG0X9p7Vh478e6ePHPwiju fiP4u8PrNp1t4xh0/wAOwzalfeFtCbU/CNh4e1aRNF1Kc3jO13NN0XwQ/wCCX/7AHxH+FXwv+J1p 8IpPGnhT9orxR8U9Yi13R/ib+0dc678HPBlpqmu23gXwx8NNA+H3hnx9oni3XtAtrSwtPFD/ABl8 QWEsmo2mt3dpf6okY0SymGc8LQw1OeK4bw/1pYXLa9elh8ry2VL2ma5fTzHAqlVrTpRjTx2H+t1M G8U8PKccDiYVY0qqo063OuB/F/F4uayzxNx88vq4rN4YHEYzi/iinXnhcmzTE5TmFTEUMPh8RJVs uxdPC0MxpYZV1RqZhg6lF1sLOpXo/jnYf8Fr/wDgqhqt/ZaXpf7SF3qWp6ld21hp2nWHwO+AF5f3 99eTJb2llZWlv8I5Li6u7q4kjgtraCOSaeaRIokZ2VT1Pj7/AIK7f8FhfhT4juPB3xR+MHjT4beL rS3tbu68K+Pv2bvgt4O8R21pfRCeyurjQ/EXwY07U4be8gImtZpLVY7iIiSFnQg1+snww8G+DPAn /BMPxp8L/Bvw1m+Kuk/Cb/goNc+CJPEdjqHjuO9nuPDfxX8Nx6f8dNd06wkgk0S68KaPPo0Wr+Hb qzs/BinRjPrOnxyXl67ewft9/s4/shftJfEX/goBqniv4ReIn/aD/Zr/AGf/AId/FeD4rTfEHxTB ourW8ng3xHq2h+ELXwRo2raZosWkpaeC3stcvb61utbvDrd3LpmqaVJZ2UkeVfOuHKOJi/8AVrL/ AOzIVMTKtjPqGC9s8DDKeHMzw+PhhJ0qValTcc+Uq9KrGVRYelTdNSzB4rLcH2YPgjxKxmW1fZeK fEMs/lg8rq4fL58QZ/SwMMxxOe8VZJjcpnmNLEYujiqtKpw1KGFxVB06FTFVqqrqllqwOaZh+B1t /wAFtf8AgqVe3NvZ2f7Ss93eXc8Vta2tt8Ef2fZ7m5uZ5Figt7eCL4SPLNPNK6RxRRq0kkjKiKzM Aew+IP8AwVy/4LE/CXxE/hD4q/Fzxv8ADPxZHZ2uoSeF/iD+zX8GPBniKOwvg7WV8+i+I/gvpupJ Z3ixyG1uWthDcBHMTuFbH6PfGP8AYH/YY+EPwY8X/tmeEPhXGPh18S/hz+yhefss6BL8RvifdDwj 8VfiX4g1CDxVq7TXPjq71LxBNYWN74X1z+yPFVxrWiwSadqNtFZJbtcov1r+0n+xL8D/ANqL9uz9 rj4j/F/QbP4k3/wU/Z8+BLeDPhLqXjH4ieCfD+t6n4otPHEsviDxfrHwi0DxL8T49F03+wobW3Hh LRdTmEtzeSXmn3Sx24TfFZrw1QqUmuG8LChhsTnGEziVfK8vVXCYrLMJlddYOhGlKrGtiVVzTDUs UpONCiq1KarOEcRKjwYDhHxVxVDE0peJmcVMzxVDhnG8PUsLxZxHLCYzLc9xWe0pZljp14UcRQwc qGR4qrlzoUa1fFzoYilGg6jw8K38+v8Aw++/4Khf9HO/+YW/Z6/+dNR/w++/4Khf9HO/+YW/Z6/+ dNX7Cav/AMEvf2A/A2sftZeMdV+FfijxX4X+H/7LPg3476F8Lbnx58ZvBup/DzxNan4lTeJ9F8N+ J/Elh4Y1/wAQeFPFqeEtPttE13xv4X8QXdoINUmjsra4H2SLT8O/8Em/2FfiV8Rfg/8AE7w58PNS 8LeBPHH7F7/tBxfs2XfxU+JOoWOveMbo+F5rCO58cWS+JviufDOlQ+KIrDxKfCVpdapJfyaJd6Rp I8+fQ9QpZ1wdd83D1OEIU5zrVJZRlrjRnHL86zJUJqNSVSdSdHh/M6cKlCFbDOrRpyeIjh61KvKa nAnjbCUKX/ER8TPEVa1CnQw8eM+KVUr0K+Z8OZX9chOeGhQp0KVbirJqtWlXrUcdGjXqwhg54rD1 sNH8aP8Ah99/wVC/6Od/8wt+z1/86avRdZ/4Kv8A/BZvw54D8O/FPxD8TPiLoPwx8X3RsfCfxG1n 9mH4P6X4D8UXqi9LWfh3xfffBODw/rd0o03USbfTdRuZQNPvSU/0Wfy8b/grL+x/8Cf2Z5/2fvFv wW0a7+H03xa8IavdeNfhQ1/8Vtf8N+HNf0AaK0mr+AfFfxl8JeEPHXiLwrqb6xNarca1p8d1HPYR SNaWH2s2qfsV8GPgz8Nv2g/2Av8Agjv8H/i94b/4S74deNPjP40tfEvh3+2Ne0D+0oNN+Hn7SmtW Uf8Aa/hjVNF12z8nU9NsrndYanavJ5PkytJbySxSddatw88kw2dYTh/LnTq8QUMmrUcTluChUpwV TNKeNqQdKNWlUqU5ZZL6s4VpUKqqRcqkU3y+Rl2W+JVTi3POD8y8ReJKeOy3g2vxPg8VgeKM9rYP E1pzyBZfRruvUo4zD0KlPO08WquDp4yhKi+WhOLi6n4k/wDD77/gqF/0c7/5hb9nr/501H/D77/g qF/0c7/5hb9nr/501fp94q/4J5/sF/EH4X+IPEvw/wDgP8UPh3e/Bj/goHp/7MfjOTwf8QvHvxV8 W/EzwJYeN/D2jeJ76y8Oaib2Owu5tE8RyXWmaf4W0KfX7IaOEW98Q3dwyy+5eMv+CTX7HrfGr9ne Xw9+zr4csPgZr/xv134e+MNSsP2hPjlBrniDTpPhz40vtF8OeOvh78QY9G8W+FvFkHi3SdKlW78A +PYw5iNtqGgrY3zC35qeccH1IYeb4fo01ia0aVNVcrymLSq5Zk2bYSpN+2cIxxuFz3ARwlPmeIqY h1sPKjCpTtL1JcEeNSqY2nT8SMZX+o4aWIqzo8W8YTjP2Ga8QZNjqVKLwMakpZdjeGcz+vVZU4YS nh1h8TTxNWjWUo/jX4Z/4LL/APBWfxr4g0fwn4N+PeueLfFXiG/t9K0Dwz4Z+AHwJ17xBrmp3biO 103R9G0r4PXeo6nf3MhCW9nZW09xM5CxxsxxUviz/gsh/wAFbfAXiPVvB/jn46+IfBfi3QLo2Ou+ FvFn7PnwM8O+I9FvRGkps9W0TWPg7Z6np10IpY5Db3lrDKI5EfZtdSf2H/Z6/wCCd3wZ+B+s3fxh vPgR4h8A/EnwN/wVI8OeBvgn4h8Q638TrVo/gTL8SPBmkeHP7H0bX/Ekmh+KNCvbO81q30/xbqel 6xqWogyzJrdxJbxSxPf9gz4RfHn9qz9tf4x/HP4FeHPiT4Zuf2s9J+G2jeJPE3xn+MvhL+zoW8P+ BP7V0/w38OfgV4Uv/EOv65K2tsF1jxV4s0TQIJJLH/R4bSy1O8uMqeb8LV69F0MgwDwjwFbE1nPL 8tjiPrEqfA9bB4ajHndCUnT40o0cVGrWpzp4zCVqFFVbU5VuifBni3QwsqOI8Rc/hnFTOqOBw8I8 S8USy2OXQXiJRxuOxdX2P16n/tPAFerg5UcHWo1Mvx+GxNedByqxw/4qf8Pvv+CoX/Rzv/mFv2ev /nTV33jf/grR/wAFkvhnB4aufiR8VPH3w+tvGmjReIvB1x43/Zm+DfhSDxZ4fnSGSHXfDUuvfBWw j13Rpo7i3eLVNLa6spEnhZJysqFv210j9n74N/szfCH/AILA/s+/B74F6n4/8L+GNK+GviODwKfF nxC1bXvGGkeNfhXHrlp4MSfSNRn8RQWXhDUYte1HTNT0uR9e1G31KW21y81CDTbZl8ruv+Cfn7OX xq+K37G2ifEKH4l+NNC0z/gnnc/Gyb4Wan8bPi34k1H4l+LdNi+H1lbeFvDF94v8Z+ItQ8DeH0Ou z3L+HfhxN4YslmTTI7azisbaWIYrPOF51nJcOYKlgIYXL8fLEVMswNTETwuN4PzviyrB4SgpujXw tPJ6mGThUxVPEznFQ5OapLD71eCPFWhhaVN+JueYnOcTVxmDhhKXE3EWHy/D4vDcf5BwRQn/AGji ZL67hsY89pY2SdDL8Rg4wnGpTrctCOM/GD/h99/wVC/6Od/8wt+z1/8AOmo/4fff8FQv+jnf/MLf s9f/ADpq/ab4Vf8ABK39h34leLP2efGvi/8AZt8ZfBCP4zfs9/GDxV4t/ZV8V/FL4qT+IPA3ifwb rfge20bxdY65qmr6J48iltbXW7yK407xGx0i4GtaM9z4dhuba4jf8qf2+P2aP2VtC/YZ/ZP/AGuP 2d/hNrnwV1P4r+OvGfgLxV4Rv/iR4o+JNtqMPhq58W6bBrdzqviiYtDqst14MlumTRNP0TSzFq8l udMDWcEzehTzHhSpiIYb/V2jCp9fw+WV5PLMnqUsLjMXmGc5bh6dStQr1qdeFXEZHjLVsDLF0Ywl Rc6kZOrCj4GY8N+L+W5RXzqr4k4+rhaeU4nO8PSp8U8Y0sZjctwmAyTMcRWo4XG4HCVMNUpUM/wS lhM0WX4tVIV4uhyqhOv5f/w++/4Khf8ARzv/AJhb9nr/AOdNXpPw3/4Ks/8ABaD4yXuqab8IPiP8 SfirqOh2K6prWn/Df9l34Q+Ob3R9MeUQJqOqWvhj4JapPp9i85EK3d3HDbtKRGJC5C14t+zxp3/B NKf9hz9oO9+P2o+LYP2y7W71sfBm20+Tx2kTRvommDwcNFttEb/hAb6zn8QjVF8XyeNv9Ns9PUPp wg3Wcs/jv/BPD9p3xP8AslftbfCb4qaB9pu9LuNfs/BfjrQYJfLTxJ4F8X3lrpWu6a6l0jlubTzL XXdHEzLDHrukaZNKfKjcH34ZRlWKxOYZfhOHcAsZhqVGOErYnKcLDAY3GYzCOvhaNCvGCdSEKzp4 bHSShLDTm9J2XN8P/rRxdgaXDWZZx4m5+8pzqpWqY+llXF+b4nOMlwGExywmLrZhgp11HD15UlVx eBouVSOLpUmuenLm5ftGP/gqh/wWpl+Hl/8AF2L4gfE+T4UaVfyaVqnxPj/ZY+Ej/DzTdUhvYdMl 02/8ar8ED4bs7+LUbi30+SzuNSjuEvZ4bRoxPKkbc34J/wCCwf8AwV5+JfibTfBXw4+Nfiv4geMt aN0NH8JeCf2dfgj4r8TasbGzuNRvRpug6F8Gr/Vb82en2l1fXQtbSU29nbXF1Lsghkdf3r/a5+HX wn+On7aX7N//AAS8uLRfhv8As7weGvH/AO1X8Q/C3he//wCEdn+KvjDVta8Y6tpng/T7y1kN3bRH Wm8T+K9a+yob2S1uLxtLaxn0yxvLTj/g1+wz+zh8CP2tf2IfjR8JvBDfBbxvqPxT+M/w+8S/DjSP EPx78beAvEOjr8GvjBdaVr/h/wAW/HzwH4M8SN4k0230W1XxJpNrF/ZcMuo3KWC3dvYx6hcfIYHO OH62HjXxnDWX4eWOoZjissp0cuwVa2HwX17BUauPlKFOUFi84yzG4eMcJTxDoYT6viMQ6Uakpx/Y sw4H8RY5liMNk/ihxLjMDkmMy7LuIcTi+J86wuI+vYungMzxlDJ6EatWhVWX5Dm2AxMpY/F4SWLx v1rCYSnVqUYU6n40eK/+CqH/AAWp8CeGbbxr448f/E/wb4NvfEWq+ELPxb4r/ZY+Evh3wzd+LdCv NT07W/C9tr2r/BCz0qfxFo2oaJrNjquiRXb6np15pGp2t3bQz2F2kXmH/D77/gqF/wBHO/8AmFv2 ev8A501fu/8AFv4E+Bv2mPgZ+yD8D/iVrdxoHgjx5/wU8/avstfu7K6jsb+9ttM+I37WGuw+H9Pv ZUkW0v8AxPd6Xb+HbS4VGmhn1RHtla5WFT8zfGX9hL9g3wJ4FPxu8b/soeMf2bfC3wi/ba0T4A69 4P8AHfxZ+Lt7pn7RHwe1HxHo3he++JelXuuazYeI9HiOm63f+N9HuPBOrQ6YYvB2p20mparYXE32 TXLszyDEVKeHxXDeXLE4nM6WAwsMJl2AnFwxGJyXLsPVqyr+xvOpmWdUMO6OHVavTpJ4qpRhhoyr HDn3CPiVg/reKynxN4hlluX5TWzHF1834m4ioVufCYXPs0xtOlHALGUqdLD5TkWIxXt8dUwdGtVf 1ShUq4mUKL/Ln/h99/wVC/6Od/8AMLfs9f8Azpq1dC/4LQ/8FXfFGtaR4a8M/tCar4i8ReINSsdF 0HQNC+A3wF1fWtb1jU7mOy03SdI0rT/hBcX2palqF5NDaWNhZwTXV3cyxwQRSSyKh/csf8ESP2MT qg8CnwoF8cW/x4X4uXkB+IPxCLn9keTx1e6VB4FX/irhZLbyaNaLayeJwh8bpM7TDxGkzKY/50/h PJ8MH/4Km/ChPgr4dj8J/CW0/bV+HOnfDvQYtW1vXEs/CWmfFzQ9O0aQ6t4i1TW9avnv7S1j1GWa /wBUvJfNu3RJFhWOJPUyDFcJcQ4yjhMHkWHhKdN1qkq2U5fCNKmv7Pi1NwdT35YjG4jBQ5VKDxmT 5vSc0sNSniPmOL8o8XeB6NDEZ34hZrUpV8zw+WU4ZdxdxJiKtSrXnmcvaU1WjhqfsqeEwGFzGTnU jUeBz3I60Kc3isTDB/Z3jT/goV/wXr+G+hzeJ/iJJ+0F4C8N28tvBceIfGn7GHgDwtocE93PHbWs M2ra58ArGwilubmaK3t43uFeaeWOKNWkdVObdf8ABSP/AILp2Pj/AEr4T3us/HCz+Keu6TLr+h/D W6/Y/wDhtb+P9Z0KBLySbWtK8GzfAdPEWo6TDHp+oSS6jaabNZxpY3jPMFtpin7c/t9ftjfAP9mr Wf24/CPxU/aZ8QfE3xX8X/g9oPgjwD+x23gTxJdaP8Ndd1H4eXVh/bkHiq5N74ZFj4wbWtO8S6xL FP4djsUt5I0ttc1sQGK98Hvid4O8U/sufCD/AIKx+I9Qsr3xn8E/2FPih8KvEUVyipc6l8StF1vw /psE7MqPJHNqHiLw34lsoEMu9oPGkLRRss7Y+Xp5zhVlcs4r8H5T9QjCP+0U8uhGnVxWLyLOcfgc Hh5VMKo15RzXK8PluIxNGdTDVHmuF9hNSpVJS/TMTwZmrz9cM4Hxo4ynnKisViMDX4krOpgsswfE HD2BzPHY2WHzef1X2mS51jM1wGExEKOKtkuJdalOniKSj+GvhL/gpP8A8Fz/AB9eeKNP8Ca78bfG t/4H1O70TxrY+Ev2Qfhr4jvPCGs6e7RX+keKLbR/gReTeH9TspEeO7sNWS0urZ0ZJokZSB4/qX/B av8A4Kp6LqF9pGsftG32k6rpl1PY6lpmpfAz4A2Goafe2sjQ3NnfWV18I4rm0ureZHint54o5oZF ZJEVlIH7IeHdZ/ay8R/8E0v2CvEH/BOq51e88deIfjRc63+0BqHhbyXlu/G+qa94ivfFt38Vnti+ oN4PuPGM8k3ix7veW8OnRftTGw+yA/hL/wAFOrH4wX/7b3jCw/aHvf2fdP8AjBqFt4HtfiBf/s/t 4p/4VzYX9zpVnb213rH/AAlQbWV8S22itp1x4kG0qEW3IU3JuBX0eXQwGMzypk1Xh/h2FSljcxyt 0oYfDLGzxeWQy/2mLp4ephknl2KqYyUaFSU4ypxVDnlUdZ8n53xVLifIuFMLxJgfELxMxcMVgMjz iniq+PzOOSSwOf8A9ozoYGOYUc2nN5vgKOEpfXKMaMoTqyrxhGmqUeb6C8Hf8FX/APgs38RNC8Xe Kfh/8TPiL468M+ALFdT8eeI/B37MHwf8T6F4J01ra9vF1Dxdq+ifBO+0/wAN2LWmm6jdLd6zcWVu bawvZxIYrWdo/Ov+H33/AAVC/wCjnf8AzC37PX/zpq/Z/wDZy/Yi8ff8E+v2T/8AgqX4X+JniDR/ EXhbxh+ztoGreEfiXo9pe6d4R8TT33gP4s2NzpOkTamRNc32mXuraNaXKgbWm1fT1i3C4QtP4W/4 JB/srt8D/Fnh34mfs/ab4H+K+gfszSfEODxroPx5+OXj3xzD4wh0a7f+3PEUP/CM+EPgBp0dxqVo 8kXhLRl8STkQ3QhNxp0TX0PnY3POEMDXzWpLJctxWV4HC5XWw2IwmW4L6xiamIyvE5hmlP2OKjhV fLJYZ0qsIN1oe0hKpTUW5r6HL+BfGLNMu4cjR474my7P80rZ7DM8Bm/FGewweBhgs5wWV5LKji8t nmUZ/wBsU8X9YpVazhhqipyVCtKS5H+LP/D77/gqF/0c7/5hb9nr/wCdNXe+L/8AgrT/AMFkfh9o /hDxD49+Kvj3wRoHxB0ka94B1zxf+zN8G/DWj+ONDMFlcjWvCGp6z8FbKy8S6SbbUdPuBqOiz3tm YL+yl87y7qBpPvDxf/wTh/Za8CfCb4b+DfDX7Gfx5/aN1Tx1+yjH8atU/bH+GHxVn0nSPDfjK+it 5BbHQPGHijwp8FzoFjBdjXIbC4u7jxNLoC2iDSdWK6rr1l9weOf2U/g5+0D/AME+f2VPG/jH4bQf H/4s/Bn/AIJ/aZr3we+Ak/jvxR4Gh8TX134M+GUureKZpvAmt6F4s1s6DJpul2FrpFpqUGnX8+rn TJ3XUdU0i+07XMM24WwVOtXhw/galDA5pPBY6UsvyyNWVCnheJ+evhMO5qvBrMOG6mH5sxpYGisN OpjJTjhqVStTwybg7xYzFVMPX8R8/o5hishwubZTSpcR8VzwixGIxfCEnhMwxjw/1etKOUcV0cUo 5DVzipLGU4Zek8XVpUKv8+X/AA++/wCCoX/Rzv8A5hb9nr/501H/AA++/wCCoX/Rzv8A5hb9nr/5 01frp+zR/wAEof2NfFn7OP7NHiLx78N77xzrf7Qnw31zxx45+KGgeOP2gk8XfDHWdQ0iLU9G8OfD LwB8PPBXjH4c6zD4Uv7s6DryfFfXdN1SGTTLu9Q+IZxcaXb+VftiaF4U0T/gh/8ABDwz4R+FX/CZ aF8P/jx458F2vjfSNV8dz2Xg2+8IfEr4qeFdR+NGoRidoYl+JN7p95BNoPilF8M6Hf8AxBSw0S1t bnT9Cij1xeY8MYfEVMJS4cwlfEUc7y/JqrlgMrpYe+LzHGZZiK9Ot+8lzYPFYRx9hXpYd4qFSFSh UdL33x4bhbxYeVSzjMPE3OcHhZ8MZhxHhqdDiDirG4uf1TK8HnGFweIoL6uqaxuCxim8VhKmPjg6 lKpQxNGNZezXwB4a/wCCyX/BWvxpqT6N4O+O/iDxZrEenarrEmleGv2ffgXrupR6RoWnXOr63qj2 Ol/B26ul07RtJs7vVNVvmiFtp2nWtze3csNtBLKvtXiP9v7/AIL7eDvDOo+NfF0P7RXhbwbpFh/a ureLfEf7FXgXQ/DOmaXtRv7S1HXtT+AFrpVlYbZEb7Zc3cVvtdD5mGGfjL9lO0i8P/sZ/wDBQ74o aQip4103wx+z/wDCix1KMN9t0rwR8XPibew/EAWssbCW2j1u08KaToN/MAI5tOvrvT5nMN9JFL+h 37UHxt/Z4/Zh/wCCjvxv+Mt94r+OHij4uN8NbTwYnwotfhp4L8PfBy81Lx9+z54Y8G2o8Y/FI/Gn WfFfiLwXYabqsfiLU9Fh+C2n3dzrdnZWsEwi05L+99DH4TAU8wq5dl/DuT18TDCY32NOeW4ec8Vm 2Hy7Jc0wmAh7OnCNDDY+jxDleHlmNaXscBiFiJYmEqcYniZJjuJMRkWXZ1nfiTxpgqONzHLliatP inMKGHy3IcwzLO8pqZpP6xialTH47AYjhnOcRLJsJFYnH4aWEWFqRq+1T+Q9L/4LVf8ABVXXNT07 RdF/aLv9Y1nV7600vSdJ0v4F/ALUNT1TU7+4jtbHTtOsLT4RTXV7fXt1LFbWlpbRS3FzcSxwwxvI 6qZ9f/4LP/8ABV/wrrereGfFH7QWr+G/Eegajd6Rrvh/X/gL8BtH1vRdW0+d7a/0zVtK1H4QW9/p 2o2VzHJb3dleW8NzbTxvFNEkiso+7/A/7G/7OGg/tV/FH4H6F8CNZ8FRfsm+GP2ffjJ4G/apufG/ xJ1DWPif4ofxj8OrmO18Y6Tq+qXXwkm0D4uzeINTsPBFp4J8I+Fb7T7jwtqJttU1vdeJpmB8fP2X v2efiF8Vfjr+1zrfgiGb4b/A/wAb/tr6L+1F4Uk8V+NbWw8ZfGfwl4ydfgWw1G28SWmt+Hj8R5vi d4LF7Y+F9V0fTJH8G67Hp9pa+de7uKeO4Z+sYKNPh7Byw+Ky7MMyVR5bl0aksPRhgpZbVhCUkqKz LEV6mWUsNjfq2PjmeIyyjVwlGji3iI+vh+HPFWvluNrLxIzp5jhuIMryKGHXFPE0cMq9Z5is6p1K tWnCdaeS0cNSzavjMDHFZRUyXDZti8NmGKrYWjhq/wAM/wDD77/gqF/0c7/5hb9nr/501dhq/wDw V8/4LAeH/D9j4s1/4y+MND8K6nrF/wCHtN8S6v8As4/BTTfD+oa/pdpZ3+p6HY6ze/BmDTrvWNOs dR0+9v8ATILmS9s7S+s7i4gjhuoHf7Z1v9kb9iT4OfFnX/Aum+DvCmseIPgfovwA+IvhHxTo1p+3 Z4z8f+Ktfv8AXvCF9qN/8dWs/AWn/syeHfhH8Q11a8sfDfinwN498MW3hm+07TYL3xHrU+oatYaP 9EftbTfBXxv418AfC/4p/s++EfH+ifFf/gq18VfhLOX8b/F7ww/h228Q6R8IvDniLx3pUnhn4g6f cXHjrUX1Gx1COPU573wJaPbXsFr4IgjvLc2Gc8bkNTF5dhsDwtha/wDaEatWlOrluAw6r0YZjw9g KVTCOoo06irvOqt44mrhK2GqYWm61H2OJVSGuGyDxChl2cYzNPFnNqFXLK1DC+ywXE/EmNp0cZVy finM6uHzKVNPEYeph58PUIJ4bC4zD4mjisRKlilVwsaVb8b1/wCC3n/BUNmVV/abLMxCqq/BX9no szE4CqB8JiSSSAABkngV0Xi3/gsd/wAFb/APiLU/CHjr46eI/BXizRZYoNZ8L+Lf2e/gZ4c8RaTN PbQ3kEOp6JrHwds9SsJZrO5t7qKO6tonktp4Z0DRSozexeIP2NP2ZfDvhrxX+0tY+BXuvgv8BvA3 7Q3wl+Ifg7UPGvjGWHxD+1V8NPihB8KvhLJrGsWfiCw8RabN8QNK8c+Cfijf6F4f1DSdEWTw7rll Y2Ftosk1i/3d+1f+y9+yfd/HHXfi18YtA8H+Ptf+Of7VMvwx8RweJr39r2fxD4Z0Hw58NfhvYWPh H4NaB+yl4B8c2N/8YNaXVv8AhLNLg+LcMuk6tbLpuk6RoN9BPqepado8dwxOrl6w/DuGrU8bhsyq 8scqy9VpYjDZnlGAwWFoxbUPa4rD5j/az9vOlB5XispxFGpOpjfYRwjw94qRwWY1sT4mZnh6+DzH BUIVKnF/EccA8unkebZrmGZVa0o+2dHDYvL5ZHTWHo1ZrN8uz3D4mnRpYCGJq/kZ/wAPvv8AgqF/ 0c7/AOYW/Z6/+dNR/wAPvv8AgqF/0c7/AOYW/Z6/+dNX2ta/se/sVWnxB/Zi/Z4tvgfd+Jpvj18K f2rNe1b44+IPF3xw8FfErSb/AOEeu/GWH4fa9p3w61PxJonhvw5rws/AVhaeL/DXjL4fTxGQR2z6 BoWp2uqPqPI/Gr9jX9i34eeBfH/w6tLDSLjxj4T/AGPvCfxx8L/FLwhp37anjr4xa145vvDOk+KZ vFHjTSdH+GGr/snaR8BfE1zqj+GoNd0zxJYSeETHZXWteLX1GbUbDTW8fwr7/Lw3GfJHEVIxhkuA dSpQwmPz/LcVXhQclXisPieG8w56NWlTxc6boSo4erzVVR53kHi3GMZS8UKkI8mFdSdTjjiKnQo1 8flnC+bYHCzxdSnHB1J4vCcXZU6WJw+Ir5dGosTCvjaKhRliPn+y/wCCw/8AwV21PwprnjzTvjd4 o1DwN4Y1HStI8SeM7L9nf4H3fhTw9q2u+f8A2JpmueIoPg3JpGk6jrH2a5/sqyv7y3udQ+zz/ZIp vKk28v8A8Pvv+CoX/Rzv/mFv2ev/AJ01ew/8E6PBPhj4lfsh/Ff4d+NdM/trwd46/by/YI8IeKtH +26hp39q+HfEfjfW9I1nTv7Q0m7sNUsftmnXdxb/AGvTr2zvrfzPNtLmCdElX2jwb+zJ+w54/uPG PjHVP2XPGfh3wh8Fv22vij+z9qnh74Oaz+0B8WdS8YfDvQfhd418QaD4k+I/h6Hxd4l8bSWvhrxR 4bs9V8Xap8KbjwXOvhGS9iFslxaNqc3TjZcPZfjM2w+J4fwE6WXVqEYVMPl2XNulPJuDsfOVZVnR SqTx3F2HwlBU+eLp0pVazpRjKT4sow/iTn+U8NZjlviRntCrnuBxuIqYfMuJ+JKThXwnEPHuXSWG nhY4um8PRyrgetj8RPEVKVT21f2GGp15OEV8bf8AD77/AIKhf9HO/wDmFv2ev/nTV0jf8FjP+CuC eEYfiA/xz8SJ4DuPEM3hGDxs37PXwNXwjN4st9Oi1i48MQ+JD8HBo0niGDSZ4NUm0VL1tSi06aK9 e2W2kSU+2/Gb9ib4Fxfs0/Hj49+BvhN8Pv7O/wCFA/Cfx18EfF/wc+KXx78U+D9Zvx8bD4I+Ifjn Tvh78YrLRviV4B+3aJcWmn6x4G+JGpfFDT/D15HcXGheK3miuJIfrv4o/sb+DtE+A37OnwJ8HfAZ /E2hyftD+GPiV8RPhVrPxb1/4ZWc+tP+wb4P8afErWfFfxD16Lxf4g8LaNp2sRX2ueI9K0C1TUTZ Wl14e8KQ6PeXNlJa81XHcLxw1etHIMFSnhswp4GtTxeW5bh/Z+zxdGlmFWtzS/2eGDoOv7Z4n2P1 TE01Sx8cNGFeVL08Lw94sVMROjW8Q8+rU3kcs3w1XLeJOKsYsRUxEKEcrw1CMaKni5Y3EYvDOl9S hiPruEc6+Vyx3PhlX/L6x/4LXf8ABVDU7j7Lpv7R93qF0ILu6NtY/A34AXdx9msLWa+vrjyYPhHJ J5FlZW1xeXc23y7a1gmuJmSGJ3Xa8W/8Fi/+CuXgDXJ/DHjv44+JfBXiS1t7C7uvD3i39nn4HeG9 ctrTVbG31PS7qfSdZ+Dllfw2+pabd2uoWE0lusd5Y3Nvd27SW80cjfqP8HfgP8Dfgf8AC2++L/hP 4L/BOLxN8Yf2DP22rjxlB8OvHX7S/ij4Pa9ZfDzUPAzaTa+DdS+Jfjqx8ZSad4p0LxCbDxdquja/ qNnenSIb34d+KdNtZL3UNR+fvj/+xX+yj8Abnwbr/hP9lW7+O8XxY/aJ+E/wVuvBafEX43QWHwq0 fW/gv8LfF+oxaBceFPF9nr9x8R/iFrvjTWdV0C88a614p8L6faWUFnY+E7qKK6gSaON4cxGZRwFL hvCe/TowpKWXZUqlfGVeIsXw66KlKrHD0KSxOHo1aVatV5a1KvJSWHqUqcMT143hjxQwHDsM5r+J ucupbH4rFcvE3Frw+DyzBZDl2fKuqVLBV8fjcTOji8Rh8RhqWHoywtehS5HjKVWtUwvwp/w++/4K hf8ARzv/AJhb9nr/AOdNXSeHv+Cxn/BXDxdH4gm8J/HPxJ4nh8JeHr7xd4ql8Pfs9fA3Wo/DPhPT JrW31LxP4gfTfg5cro3h7T572ygvta1I22m2k13ax3FzG9xEr/dniT9hP9iP4c/G39lj9mQfBm2+ JB+Pvjn9r3wb4j+M9/8AFD4q2Pi/QtO+FHjPxno/ga68N6V4c8Y6R4AXxT4a+xabpOtz6r4Q1bQN YTRLlJtBW/vptVX85v8AgmraW1jrv7eVnL4N1L4j2Wn/ALDHxujm8F6fdX1jeeJ7Ow8cfDQzadLd 6Qv9qwWk9vCz6pJoxg1Uaet3/ZdxaXxt7mHWhiuGcbl+ZY7B5BguTBZRmWaUZ4nLMvpUsTHL55rh 5QSi51qaWKyqrGp7enRapVKc4OTc1T8nGZX4o5NxDlWRZx4jZ66mM4jwvDeOWV8UcSYqtl2LxOEy 3MIOfto0KWIVTBZpRqUpYKeLTnTq06ihL2aq2f8Ah99/wVC/6Od/8wt+z1/86arS/wDBbD/gqe9l Lqa/tI3TabBdW9jPqC/A79n82UN7dw3Nxa2ct2PhGYI7q5gsrye3t3kE00NpcyRoyQSsn3LdfsT/ ALGnh79mPwp+154i+Ffw/wDBWt/EPwd8C73U/gN8XPGf7YV38MPhY/jbXPH1pqfiu3n+A+mfEX4/ +R8UNP8ACdgPhmvjXVLjwvpE15czX2qeIJn0vSr71Hxj8KP2UNE+B/w5/ZmtPhmL/wCDfjb/AIKJ +LPhfoOq+PbX9oP4bfEXwL4u+J37Oeh33g7xXq+k+NNc+G3iE6l4I8XeK9A8PJ/wlvgXT/Dvib4d +HdO1ObwjPrurX3ifVFiMVw9TnjsPQ4VhiMXgMY8BWo08py2UXi6OYZPg8ThKdaEp0qmKlHOMP8A U4Kao4itKCdenRbrLowuR+Js6GAxuO8WMVgsHmeUU85wU58XcUfWJYDG5fnGMy7HV8JUpUsTh8FK eT1442TpTxuEpqV8DOpGcKf5f/8AD77/AIKhf9HO/wDmFv2ev/nTUf8AD77/AIKhf9HO/wDmFv2e v/nTV+jVz/wS+/ZN8L6J8O7zxro6WUvw+8L+F/2b/wBpi4j8deJrdLf9sL4uah+z9B4V8R2jy+Lm t0t/B2h/GXxNrZ0jQo7Xwld3PgNE1nS761uLm1ua+g/sAfsI/FP41658Iv7As/AM/wANP2kE8CJ/ wqa3/bj1mbxX4P0rwt4r1O6+Hfx58a/HD4R2/wAMPBnxR8SXXhrTtU0LUPhHr8Ft4lsNb1HSvBnh /UZLLRNa1iXmPCFnOGRYetQjHEVZ4mhlGArUoYbD43B4V4tqm5VpYethczyrOcPOnSm6uT5rgMSo qrWeHhb4V8aKapxxHiHjcJia06NGjgcXxtn9DFVcTVyvF5jLBxU7UYYrD4rLM6yCvRrVqco59kea 4On7Sjh4Yqr+dv8Aw++/4Khf9HO/+YW/Z6/+dNQP+C3v/BUIkAftOEknAA+C37PRJJ6AD/hU3JNf bfgP9lT9hDxl4c8Q/E+8+EXh3WrrwH8M/wBq/V9Z8AfCi7/b18PfBXxDc/CjQtM8Q+D72H4n/tG+ Dfh34ktviZ4QvDd+FPHvg3QvE2v6XcrdW3iOTw5pAkfSdN/MH9sz4ZfCjw14N/Y/+Lfws+H1n8K0 /aB+B1z428YeA9D8R+MfE3hPSfFfh/4g+JvBl5e+F7z4g+IPFvjG007WYNGgv30zWPFGuGxndobe 8aMEt3YB8M43McFlz4cpYepjMVgsJz18pyyMKVTMKGe4vC8zjObmq2E4dzCvGdGNanByw9GtOniJ VaNHxc3w/ijlGUYrOp+JuNx2Fw2FxuMUMv4v4or1q2Gy7MuFMox1SmqlGjRpyw2YcZZPQnQxVbD4 ioliq1GlVw9KnVrfdHij/goL/wAF8PA/he+8b+Nf+GhfB/gvS7NNQ1Pxf4o/Yu8BeH/C+nWEmwx3 19r+rfAG00m0s5BJGUubi7jhfem1zuXPz1/w++/4Khf9HO/+YW/Z6/8AnTV+oni/UfhRrP8AwUS/ ba+HXh7wr8Y/CPxd8afsgeNNB8QfGZviJ4W8V/CDQNGi/Z48Ea5f3+t/CP8A4VV4ZvtC0i80fTYP DMeteI/i14tsrLxNqGn3lppEN9qGmS6F88fEv9lr9n/SfjF8ZvAfw0/Yz+Bq+CPgX8MvgJf638Vv jP8AtLftH+E/CNj47+NugeHtTtG8c6L4c8f6l4p8Yx6vc3uo6d4H8MfDdvAk+nX1lfXfiLW/Ei3u ieHV8vCYrJZSwyxnDmVwWNyTLc8oOjgMthCnhsficbg37SrialOlKksThqOHw9ScsPi8TiMSqLy6 jajUxH0ePyfjupQxFfI/EzimosBxJnfDOOjjuIOKq03i8ooZTiYzoU8twdfEKpKhmNWvjqMaGIwO Bw+GjXp5xjVPEwwXzPH/AMFi/wDgrlL4RuPiBF8cfEsngO01+DwpdeNo/wBnn4HP4RtvFFzYyapb eG7jxIvwcOjQ6/cabFLqMGjyXq6jLYxSXcds1ujSAuf+Cxf/AAVxs/CmmeO7z45eJbXwPrer6j4f 0bxlc/s9fA2Dwpq+vaRBa3WraJpniGX4OLpF/q+l2t9ZXOo6baXkt7ZQXlrNcwxR3ETP+k3iz/gl 5+xwnxF0Dw9B8ONW8P2HiH4/fCqyOnaX47+JySyeGtb/AGSPFfxl1b4VeGn8dXFv4gh03xZ8QPDt ppWn6j4p0FfiXYQ38mmi/wBLvgLG15HwN4U/Zn+If7B3wr134y/st6p8HvAHh/4gftX65pXh3TdH /at+JPwc8C+NdIb4ceGrL4i/F5PB3jXUfj/p3w+srW2vfDviC407x1Z6fF450y4Kpp9ndx6JZy8z 4alDETocOYWo8PVwHtqMsqy2NSlRxdClV5I8tWp9axU5LFUaVHDRc4V6cIV4RwsqOOxW64U8U6OJ wOGzDxMzTCPMcpzXG4LEQ4w4nrYbEV8vrYimqlarLBUaWV4GEfqdSvPHVU50Ks6uFq1sTHE4DBfA Ef8AwWV/4K0TeGrrxpD8etel8HWOtWfhy+8WR/s//Ap/DVn4h1Czu9RsNButdX4PHS7fWr7T7C+v rPS5rpL65s7O7uoYHgt5nTB/4fff8FQv+jnf/MLfs9f/ADpq+j5fgZofw78Zf8FBfgengPwj4J+D /jv9gOz/AGofCHh/wh8TPE3xd8H2GteA9Q8KeIfhp428K+MfHnhPwT46tLHUNR1TxNa6fovjTSE8 S6bp3iObSrzVNailt7y8/BSvdy/C5Dj6taEciyylFYXB4ylGpl+BdaFLETxeCq0MWqcalOnjMPme V5lSq0oTnGnRjh+eXtnWp0/z3iTOPEDh2hgZVeP+K8RVrYnM8BinT4iz6NB4rL3g8VCvgnXr0K9X L8VlebZVWoVq9GjUqVninGmqCoTn+rn/AA++/wCCoX/Rzv8A5hb9nr/501H/AA++/wCCoX/Rzv8A 5hb9nr/501flHRXqf2Fkn/Qmyr/w3YT/AOUnyn/EQOPP+i24u/8AEkzn/wCbT9XP+H33/BUL/o53 /wAwt+z1/wDOmo/4fff8FQv+jnf/ADC37PX/AM6avyjoo/sLJP8AoTZV/wCG7Cf/ACkP+Igcef8A RbcXf+JJnP8A82n6uf8AD77/AIKhf9HO/wDmFv2ev/nTUf8AD77/AIKhf9HO/wDmFv2ev/nTV+Ud FH9hZJ/0Jsq/8N2E/wDlIf8AEQOPP+i24u/8STOf/m0/Vz/h99/wVC/6Od/8wt+z1/8AOmo/4fff 8FQv+jnf/MLfs9f/ADpq/KOij+wsk/6E2Vf+G7Cf/KQ/4iBx5/0W3F3/AIkmc/8Azafq5/w++/4K hf8ARzv/AJhb9nr/AOdNR/w++/4Khf8ARzv/AJhb9nr/AOdNX5R0Uf2Fkn/Qmyr/AMN2E/8AlIf8 RA48/wCi24u/8STOf/m0/Vz/AIfff8FQv+jnf/MLfs9f/Omo/wCH33/BUL/o53/zC37PX/zpq/KO ij+wsk/6E2Vf+G7Cf/KQ/wCIgcef9Ftxd/4kmc//ADafq5/w++/4Khf9HO/+YW/Z6/8AnTUf8Pvv +CoX/Rzv/mFv2ev/AJ01flHRR/YWSf8AQmyr/wAN2E/+Uh/xEDjz/otuLv8AxJM5/wDm0/Vz/h99 /wAFQv8Ao53/AMwt+z1/86aj/h99/wAFQv8Ao53/AMwt+z1/86avyjoo/sLJP+hNlX/huwn/AMpD /iIHHn/RbcXf+JJnP/zafq5/w++/4Khf9HO/+YW/Z6/+dNR/w++/4Khf9HO/+YW/Z6/+dNX5R0Uf 2Fkn/Qmyr/w3YT/5SH/EQOPP+i24u/8AEkzn/wCbT9XP+H33/BUL/o53/wAwt+z1/wDOmo/4fff8 FQv+jnf/ADC37PX/AM6avyjoo/sLJP8AoTZV/wCG7Cf/ACkP+Igcef8ARbcXf+JJnP8A82n6uf8A D77/AIKhf9HO/wDmFv2ev/nTUf8AD77/AIKhf9HO/wDmFv2ev/nTV+UdFH9hZJ/0Jsq/8N2E/wDl If8AEQOPP+i24u/8STOf/m0/Vz/h99/wVC/6Od/8wt+z1/8AOmo/4fff8FQv+jnf/MLfs9f/ADpq /KOij+wsk/6E2Vf+G7Cf/KQ/4iBx5/0W3F3/AIkmc/8Azafq5/w++/4Khf8ARzv/AJhb9nr/AOdN R/w++/4Khf8ARzv/AJhb9nr/AOdNX5R0Uf2Fkn/Qmyr/AMN2E/8AlIf8RA48/wCi24u/8STOf/m0 /Vz/AIfff8FQv+jnf/MLfs9f/Omo/wCH33/BUL/o53/zC37PX/zpq/KOij+wsk/6E2Vf+G7Cf/KQ /wCIgcef9Ftxd/4kmc//ADafq5/w++/4Khf9HO/+YW/Z6/8AnTV/QV/wQm/bf/ah/bK/4am/4aS+ J3/Cx/8AhXH/AApD/hDP+KL+HnhD+xv+Ev8A+Fvf8JF/yIfhPwv/AGj/AGj/AMIvoX/IV+3fZPsP +g/ZvtN59o/iZr+rj/g2I/5ve/7tr/8Ae/V81xflOVYbh3Ma+GyzL8PWh9U5K1DB4alVhzY7DQly 1KdOM480JSjKzV4ycXdNo/UPBjjDi3NfErhvAZnxTxHmOBr/ANse3wWPzvM8ZhK3ssgzWtS9rh8R iqlGp7OtTp1afPB8lSnCpG0oxa/o2/a18D+KPib+yr+0z8NvA+l/2341+IX7Pnxn8D+ENF+26dpv 9r+KPFnw48SaD4f0v+0dXu7DSbD7fq1/aWn23VL+y06183z727traOWZP4sfh1/wSf8A+CzXwgvt V1T4S/DL4ifC7U9d0x9E1vUfh1+098HvBN9rGjSTR3D6Rqt34a+NemXGoaY88UU72F3JNatNFHKY i6Kw/vMmRpYpY0mkt3kjdEuIRE0sDOpVZoluIp4DJESHQTQzRFlAkikTch/HHUPEn7YesT/FLV/g p8b/ANpz42eA/D/7RfgX4C2cHhjwf+wmnxHt7H4dya5f/tHePvCWr+NvhV8JfhgmnJ4olsPg2bTx vNqk2kXvgnxbquhQXWsavpEdt+YZNxRjMlhXwGHw2DxFLGSoTxH1uhWr040K+MweU1KlWNGvBrCU auY4V4yUqU1ToVJ1WpU6dXk/qrjnwsyPjnEYHPM0zLPcvxOSUK9DBPJcbg8FUqVo0cTmsadKpi8v xV8fOjgMXUwkKeIoTqfVpwpxlV5FL+ZTQ/8AgjD/AMFX/DGtad4k8Nfs+6v4e8RaPeRajpOvaH8e /gNpOtaXqED+ZBfadqlh8X7e+sryF/niuraeKeN/mRwea9g1P/gnN/wXd1rxj4c+Ius6d8d9W+IP g+G+t/CPjrU/2xvh1f8AjHwtBqdpLYalB4c8T3Xx5l1vRIdQsJ57K+j0y+tUu7SaW2uFkhkdG/oO 8Waj+0R4t8MaL+2j8H/i34w1b4YeAP2ffFuuXXhz4k+ONW8M+O18b/Cvwr8cdN8eeD/G3wE+E3he H9nT4ieJvFvj2XwdYa74z+36a3w71D4Y3EfwzttZ0vxC9zJ9V/sneC9L8BarBaQftEfEv4ma742+ Anwd+IPiv4c/FL4keLvilquna/qsviaLUfjFoOp+NPEmvXXgzRPiTeG50eXwH4Qt9B+G+m3Xg2O4 8J+HtHLajFP7y4/zavWxNOpg8jlVy+SpJ/V8TW5/rkM4jGphWsY6n1athcmx1OvOUKU23Bwo4jK6 jzJfCU/o68H4WhSlheIOOaWGzCnHFWo5tldGnOeDxGSRnDEqGSKl9aw2IzzLq9BuVSjKPPCOIpZv TjlcvwV/Zz/Zx/4Ksfs3fs5ftI/Czwz+wjqHiD44ftOya1F4+/aP8S/tifB/UtRkstWstTsorhvA V54/vLa68U2I8ReKbw+LR4qtdR1XUdZiutai1AaZaxN8N+Cf+CZH/BcH4a+GdQ8F/Dnwr8YvAHg7 VnuJNV8J+Cf2tfhf4V8M6nJdII7p9Q0HQvjpYaXevcxgR3DXNrK0yAJIWXiv7sqK4o8Z4yNfGYn+ y8mlVzClgqGLdShjasKtDLaH1bA0PY1MwnRp0cLRvClSpU4U1eUnFzlKT9iv4HZHiMJlOBnxXxvD DZHLMp5XHD4/IsJUw1XOMRDFZpXeIwvDtHEYjEY6vTp1MTiMVVrV6nJCLqckIxX8Ing//gl5/wAF tvh74a1rwX4B8F/FnwP4O8SXzan4i8J+D/2r/hV4a8Na/qTpbxPqGtaFovxxstL1W+aO0tI2u761 nnZLW3QyFYYwuze/8E3/APgutqV/411XUtI+OWoan8SdDs/DHxG1G9/bC+G91f8Aj/wzp9rd2Nh4 d8a3k/x4kuPFOhWVjqF/Z2mk67Jf2Fta315bw26RXMyP/dFRXTPj3M6kpTqZbkdSUo8kpVMFXm5Q 5YQ5JOWMfNDkpwhyyvFxhGNrRSXn0/o9cL0YQp0eKePqNOnJTpwpZ3l9ONOSnOopQjDJUoSU6lSa lFJqc5yvzSk3/JP+1V+zH/wVJ+PP7OHwB/ZY+F37AcnwF+FXwHvLPWrG3T9rz4NfEnXtd8Q6bZ3l vpV+Ne1bx54evtJstLuNW1m/sNPZ9Vlspry2htNQt7TTbWCvjQf8E3f+C6o8fyfFcaP8cR8UptJi 0CX4lD9sH4bjx/LoUBDQaLJ4x/4Xx/wkT6TCwDRac2omzjIBSEECv7o6K58PxrjsM67pZblDlicX jMdiKlWlj8RVq4vMFGOMryq4jMKtRyxEIQp1EpKLpQhSUVThGK78x8DMhzWphauM4o40vgcvyzKs HTwmMyDLsPhsvyb2n9l4Wjhcv4cwuGp08DKrVqYdxpKUKtWrW5nVqTnL+B3Wf2Gv+Cweha58Q4fE Gt+MtG8S/EbS7XQ/ivFrP7cfwV07XPHeimxnFlo/xDjvf2hIb/xRpZ0zV7kWun+JBfWn2HU5xDD9 nvZPNz0/Y1/4K3R6l4I1mPxl4iTWPhloreHPhvqqft5/AxdS+H3h57e1tX0HwRfL+0SLrwporWtj ZWzaXoMthYtb2drCYDHbwqntf/BdH4qfHz4W/wDBSC813Q/E/wAdvCPgu2tP2M9P+D134Fh+JTfB bWfHHi34u+F/C3xv0j4xp4UiPw71SW7+G+peHrDRNN+LVxDAGv4f+EHaLxDdySP8Y+FP+FnDQP2s vFWpftyfHS2/Zt+GujeE/DXxV/aR1W88ZXT/ABN+Mvgz4sanr3xp0r9mDwv/AMLGuNV+Eui3ng6W w+BFlc/CvxFbWEPja4afwlpuo61oxeX7jLM7rYzL8JjvqmWUI1IZhGvJ4Xko4CnlOEpRnisTy4uV ajl/s8wWFhOFGtXiszwOHw+GxTzCcIfnmaeDuTYPGYvDPiPjHERpYvAUqCjnNKtVx1bNcww9RUsL bI/ZYjH06tCjiq1H2lOVTFZVj6jlBZUsRLsvH/8AwTx/4KW/FjXm8U/FO3sPiX4na3jtG8R+P/2z P2cfGWvNaQl2htW1fxF8fNS1A28TO7Rwm48tC7lVBY59y8M/8E4/+C4em+Hfh9YeDdM+Men+E/AU p8QfCuy8M/ti/C+18O+DJ9V0/UrZtb+H1vpXx5j03w7LqWleINXgOpeHEs3vNP1vUojNJbaldLN8 eNov7XsWgfsv+H7z9oH9oay/aC+KWtXOq/Af9n2fxj4qOufC/wCElj8d38b618Vf2tPGsPjOaD4q 6f4Y+AV7oHw01bw38S9F8QsfF17bafY6rq3iS+u7q2/0LPg3kfCH4VgnJ/4Vv4HycYyf+EY0vJxz jPpk4rDO+IMwynLsPOGAy+EHmWKwn1PE4KUY0Z4SnCbnyUMwqUFiIyxFSnWjQnWp4aq6uFniHjaO Ow2F3yLwU4ZzTNcZKfEfFsq8sCqjzPBZ3g5VMdh54hUeaNetkMK9fAVp4aKoVKqp/WJYR1qdGWD+ oYvF/wASkn/BMf8A4LgS6TrGgS+FPjDJoXiLxoPiR4g0WT9rX4XPpOu/ERb2z1JfHusaa3xzNnqf jRdR0+w1AeKb2GfXBe2NndC+8+2hkS34s/4Jr/8ABc/x7d+G7/x1oXxs8aX3g3UrXWPCF74s/a++ GniO78K6vYlWstV8N3OsfHe8m0PUrNkQ2t9pb2t1blFMUqFRj+6iivlVx7mcXBxy3I4ulKM6bWDx CdOcKVKjCcGsZ7koUaNGlGUbONKjSppqNOCX1svo9cLyVWMuKOPZRrRlCspZ3lzVWEq1bEShVTyR qpGWIxFevKM7p1q9aq051Jyl/Dte/sBf8F99SbdqM/7ReoMde0nxUWvf21vAt0x8T6C1q+h+I8z/ AB/kP9vaK9jZNpOsf8hDTms7VrO4hNvCUzdP/wCCdP8AwXf0i58W3mk2Hx50y78f6kuteO7rT/2y Ph3ZXPjXWFt4LNdW8Wz23x6il8R6ktpa21qt/rDXt0Le3ggEoiijVf7m6KmPHWYRTUcryGKaaajg a6TT9hdNLGJNP6rhrp6P6tQ/580+W5fR+4bnKM58WeIEpxacZSz3ASlFxWIjFxk8lbTjHF4uKaas sViEtK1Tm/hpg/4J3/8ABea18Q+KfFttbfH638VeOdO0/R/G3iaD9sv4fQ+IfGGk6TbT2elaX4p1 qP49rqXiDTtMtLm5tdPstWubu2sra4ngtoo4pZFbCuv+CZH/AAXAvta8EeJL3wr8YbzxF8M9LXQ/ hvr91+1r8LrjWvh9oqW6WqaR4I1WX46PfeFNLS1jjtl0/QZ7C0W3RIRCI1VR/dnRVR48zKDjKGWZ HGUVGMZRwWIi4xhTq0YRi1jE0oUq9elFLSNOtVgrRqTTmf0e+GKsXGpxTx9Ui5ObjPO8vnFzlWw+ IlJqWStOTr4XC1nJq7rYbD1G+ejTlH+GQ/8ABOn/AILwN41f4ktY/HlviLJoU/heTx8f2yPh2fGr +GbqeG6uvDr+KT8ev7dbQrm5tre4n0hr86fNPBDNJbtJEjLw2t/8Emv+CyviXwV4f+GviP4XfEDX /hz4Tv7vVfCvgDW/2m/g5qvgrw1qmoSXs1/qXh/wrf8Axqn0LRr+9m1LUZbu806wtri5kv715pHa 6nMn96lFEePcyioxjlmRxUHBwUcHiEoOlOrUpuKWMSi6dSvWqQas4TrVZRtKpNtVPo88LVvae14o 49q+2VRVvaZ3l0/aqrCjSqqpzZI+dVaeHw9OopXU4UKMJXjSgo/59f8Aw5B/4Khf9Gxf+Zp/Z6/+ ezU9t/wRK/4KlWVzb3ln+zVPaXlpPFc2t1bfG79n2C5trmCRZYLi3ni+LaSwzwyokkUsbLJHIquj Kygj/QNr4Y/4KQa18YfDP7H3xZ8UfBX4j6b8L/EvhvTtO1fWPEM/hnXNe1258JW+rWKeIdE8Fapo Pj7wHceBvF+r2UptNJ8d3B8V23h3fNc/8Ihq1w0D23TDxHz32lJLDZXFyrUYc6o4xez56sIOs7Y9 S5KKk6s+RSquEJKlCpU5YS8uv9GjgGlQxFWea8XSjRw9etKH1/Jv3ipUp1PZL/jH2uary+zhz2pq Uk6koQ5px/kn8T/8Etv+C2HjfxtpHxL8Z+Bvir4u+I/h+GzttB+IHif9qv4T6/420S306e4utPg0 jxXqvxwu9d02Gxubu7uLOKyv4UtZ7q4mgVJJ5WbotT/4Jz/8F3ta8YeHPiHrOn/HfVvH/g+K+g8I +OdT/bG+HV/4w8LQ6nZy6fqUPhzxNdfHqXWtEi1Cwnnsb6PTL21S7s5pba4EkMjo37xfG34tfFTw j8RPjb8c9E8bfEtfEPws/bF0v9n/AMKfD+Hxx4sX4Wan8Kpv2P8Aw349utLv/hOl63gLVtZn8feL NS8cnx3ceGLrx7Bcabp+jW/imLwpZHRT77+xDqvi/Q/i94j+HOp/ED4lfEDQNe/Y3/ZA/aE1G7+J nj7xZ8RNQtPiv8VNW+OehfEPUtFv/F2q6xN4V0TxVB4D8N6hF4D8MyaN4E8O3djdSeE/DGiw399H LjguOszxdGtVpZdkUI4ChlVVQeCxScXxLkX+sWGhR/2tQhGeSVm8wlzQccbUeBhDFQlUxMfTr/R7 4Vo1KqXFHHtSWIo1cbi5xzrL486yniXCcJVPrHtMkjKviMNn1bCxwjiq1KWBh9ehXpSpww8v5gtd /wCCXv8AwW28UaLpXhvxN4L+LPiLw7oXiy+8eaJoOu/tX/CrV9F0fxzqeo6jrGpeM9K0vUPjjcWO n+LNQ1bV9W1S+8RWkEOsXeo6pqN9cXklze3MsqfEb/gl3/wW1+MNtpNn8W/BXxY+KVnoLFtDtfiN +1d8KfG9tozNGImbSYPE3xx1OLTmaICMmzWEmMBCdvFf3eUVK4+zOLhKOW5JF06jrU2sHiE4VnGM XVg1jLxqOMIRdSNpOMIq9opIn9HjhWpGrGpxPx5OOIpRo14zzrLpRrUYylONKqpZI1UpRnOco05q UVKcpJXk2/4bG/4J6f8ABeptcfxO0X7QLeJJPCh8CSeIW/bO8AHXH8Dm6N6fBr6sfj59vbwob0m7 Ph5rg6R9qJuPsfm/PXieh/8ABF7/AIKu+GNb0nxL4a/Z71Xw94j0DU7HWtC1/Q/jz8BdJ1vRdY0y 5jvdN1bSdVsPi/b32m6np95DDd2N/Zzw3VpcxRzwSxyxq4/t/wD2l/DWpeL/AIYyeH9L8beMfBst z4o8JX93afDjxHH4M+I3xF0rw/rlp4i1X4ReBPGZ+IHwvn8I+JfidYaTP4RtfEdl440G70u21K7n S+tkElzD+Gnwr+Mfxk8XfDPxp471b4q/HSy8Sfst+EPgJf8AgTwzffFPxvHqOneIPFn7av7Qnw+8 efC/4+Wdnr11oHx28deGfA/w18LfAjxvq/j+b4m2X9u+G/EPinwP4gudZ19/Gur64Tj7N1GvXp4L JMNHD4vDYatKGFxUaiw9aM8SsXFU8Yo1KccViKsI4eNR4iNZ4qviKWFp4jAVcz58d9Hfg6p7L65x Dx3iV7P2uHqV81yutSjjJ1KOCp4ZOWSVKtGq8NhKdWpWdFUpYPCUqWDnjcRhMRhMH+M3jv8A4JB/ 8FgPil4lvfGfxN+DfjD4i+MNSjtIdR8WeO/2jvgp4u8S38NhbRWVjFe674g+M2oapdR2VnDDaWkc 91ItvbRRQQhIo1Qbln/wSq/4LSad8OdQ+Dun/Dv4mWHwj1a7a/1T4WWf7UnwjtfhzqV+91bXrXuo eCIPjcnhm8u2vbKzu2ubnTJJjdWltcFzLBE6f1ZftUfFb4xfCr41+F/Fd1c/tDeG/wBlbwl8PNH1 n4jeMPg3oX7LGqeE7HxZq/xNsNGnl+KUnxuTUPis/hfRPC0f2vUrT4G6Jfa7Fo+papqEjJqltoqv +i1Z0vEDNamCozWXZLChKviqMMHPCYmE6Msuxk6EKksP9d5adKtOlDF4GpG6q0J0a8eSV4xuX0du D4Zjin/rHxxLGqhhp1sbDOMrlPEUsxwVOs4fWVkntarhSqvCYuE37lalWoS5oxvL+ET4b/8ABL3/ AILbfBu21Sy+EPgv4s/Cqz1tlfWrT4b/ALV/wq8DW2rusYiV9Ug8MfHHS4tQZYgI1a7SYiMBAQox Xmmqf8EVf+Cqmt6jfaxrX7Od9q+r6ndT32papqnx0+AV/qOo311I01zeX19d/F2W5u7q4ldpZ7i4 lkmmkZnkdmYk/wCgNXC/FC/8V6X8NPiHqfgOxudU8cad4H8WX3g3TbOGyuLvUPFVpoN/P4esrWDU nj0+a4utWjtIIYb+RLOSR1S6ZYGcjLEeI+bYaGJx39mZZWrUsNUnL6vgsTUxlenRpuaoUl9ejOrO SgoUaTmlKfJFNaNaUvo1cHYtYXLJcR8ZRwrxEI0aWIzjKo4HD1a0+R15QlkUqVGK9pJ1asYXUHNu 92n/ABA63/wTB/4LdeJvAen/AAs8SeD/AIueIPhhpMVjDpfw41v9rH4War4D02HTNg02HT/CF/8A HK48PWcWniOMWMdvp0aWmxPIEe0Y622/4J//APBfSy02y0azk/aJtNI03QpfC2naVbftqeBINNsP DM8UEE/hyysYvj+lra6FNBbW0MukQRR6fJFbwRvblIo1X+m74CfGz4lWfwK+O9j8R9S+Pl9+0V8E vhpp3i/xj4b/AGhtF/ZlsPEFhqmtfC678SeH77wwv7KVtcfDq88Ha/ruheIILS31DVNX8U2Op6Vq 1hqKQWSaZ9q579iHVfF+h/F7xH8OdT+IHxK+IGga9+xv+yB+0JqN38TPH3iz4iahafFf4qat8c9C +IepaLf+LtV1ibwroniqDwH4b1CLwH4Zk0bwJ4du7G6k8J+GNFhv76OXqlxpmVWvmmEeB4crrBxw GKxEoYXE1qOKrZtQzaVKpGTxShOSwmTY+OKq1nGqpvC4aNOqq9WWHnDeAPDP1XCZjQ4m8Q6H+zVq cL53ltHEYTB5fmmQ5a8PaOUc8FTzLiTK3Rw1JulGH1zEc1OWHhCv/MVaf8Ex/wDguBYfD6X4S2Ph T4w2fwqnt57Ob4Z2n7Wvwut/h9NaXLO9zay+DIfjmnhyS3uHkd54H00xSs7tIrFiTsaT/wAE6P8A gu/oM/hO60Ow+POjXXgHw1ceC/AtzpP7Y/w706fwX4Ou00yO68J+E5rP49QyeHPDVzHomjJcaFo7 WelzJpGmLJasthaiL+5uvzx/4KGNDZ+CvBeoz/FH4xaDqFzceNfCfw0+CXwD8XeOfAHxS/aD+Ovi /wAJ3On/AAr0LRfF3w68ceC9eg0zwRLD4g8YeItP1ma5+HtrpFrceOPiJc6R4Y8DXl8OSv4hZtBT qLJ8pxVWrUTdGhgq1TFYqtVhUw8adGE8fD6xjMTCvUweGpSnF16mJWGlUp0q1SpHpw30dOFZzo0I 8Wcc4enSpezp1KmeZdTw2EoUZQxSlUmskthcFhquGpYuvVjFwwsMOsUqcpUII/lo0b/gm1/wXS8O eHta8I+HtE+N+g+FPEt3ql/4j8MaN+2B8NtL8Pa/fa5PNc61e61otj8d4NN1W71e5uJ7jVLm+tp5 tQnnmlu3mkkdm522/wCCVn/Baey+HF78HbP4e/E20+EepXJvNR+Flt+1L8JIPhxf3jXsOpG6vfA8 XxuTwzdXJ1G2t9QM8+lySm9ghui/nxJIv9XH7UPhL4qXX7Nfw7j13xj8XvEfxI8AeA77xF47+Gn7 NfxAX4R/FX9oPxvo/wAJtT0O8s/B/ju1+LHwZvNC0jw5431eL4l6jp9l4hlh1qDQLHSZ9H1BJotL vfpn9lzxRqPjf9mn9nvxlrHjKy+ImseKvgn8LfEOr+PtNt7i00/xrquseCNDv9R8V2Vpd2Wm3Vtb a/eTz6pDb3OnafcQpdLHNY2kitbx9b42zJSzZQwXD1VZdjMtw9SrRwmKlSxca6zOWAxFKTxUZOFG eU4qVJ1YRUYToSw06lVYyjg+GHgFwzVp5TUnxB4i0fruCzOrThXzrKlVwEorKnj8HVhHKajpSxUM 0oRqxTiq9TDYqFSDp0qNWt/HV8Bf+CYP/BUv4MaV8aPCWo/sfnxp4A+Ovwr1j4beM/C4/aE/Z78P TJerdWuveBvGemaofiHrkUGteBfGGm6brdpFPpdxFqVh/auitJY/2oNRs/GvFv8AwRz/AOCuHj/x BfeLPHfwM8SeNfFOqC1Gp+JfFv7QvwN8SeINRFjZ2+nWIvtZ1n4x3uo3Ys9PtLWwtRcXMgt7O2t7 WHZBDGi/34V8J/t7Po1j8P8AwRrfif4p/FzwdoOn+Mr+xtPhX8B/EnjrwV8Xf2kPHviPwV4o8P8A w1+E3gvxd8MvGngjxzpl9F4s1C08bXFtpupHRrm18KyXvjWbS/Bela/qlpyVvEPNqFSeOWXZZVxM qVDDctLD42devBVpOnh8NQjjmq2OxFSt7ChThGNbHVlgsHUrKnRwzodkfo58JYnBYbJ58QcY/wBn 4bEYrGUaM8wyGFDD1cRSpLEYivWqZFT5MJRhho1qsq1WVDAU3jcXQpRqYjF/WP5Pbj/gmd/wXHu/ CfhjwHdeGvjNc+BvBN3o1/4M8GXH7XPwxm8J+Eb/AMOzpdeH73wx4dk+OraPoF3oVzHHcaNc6VZ2 k2mTxpNZPBIqsPTtV/4Jz/8ABVO7/Zx8Y/BK0/ZT8d3Pi/4xfFTSPip8ffin4w/a8+AvjB/iTqfh f/hJD4YsLHwtN4x0u40FUufETaz4o1fXvFvjnWvFXiGws9QkvdMs7ez0uz/Yz4LeIP2jtH8TfD7x T8afij8RdW+NHgD9rT9n39knx7oOn+P/ABOPhP4k8M6r+x18NvEXxJa5+GNteQ/DvWNY1D4qeMfE 3xDHxFbwu/jeO50/T9Ms/FNt4Qsxootf8FAv2s5Phf8Atw/sy+GrP47Xfw98O/BpPhj4l+Kfwrsf iEPCcfxk039rj4x2v7OGiHVfDSalZT+OrT4QeHrDx38TzYRwX6eGbmHTPFcsdnPZ6ffRdOJ4yzOv iMJgKWByHGSzTO8FQoVsPRxlPD4jH1csyTi7LMVXxUcbTf1bEYfFZDXq1a16P9oUqdGtGtHBUa0l hfAjhjC0cdiqXEvHnLgeGsVKvSqYvLcTVo5fiMXnnBuKyvD4XF8NSlSxTxKzjK8O8PTpung8xlWp V8NDGYqFP8FNR/4Jif8ABb3WPAWlfCvV/CXxf1T4X6EdOOifDfUf2s/hbfeAtHOjy+fpJ0rwfc/H OXw9p50uYCbTjaadD9ilHmW3lPzVzxP/AME1v+C53jfUPDWr+NNA+Nfi7VfBmv23ivwfqfif9r34 aa/qHhTxRZxafDZ+JPDV7qvx2u7nQtftYdJ0uK21jS5bXUYItN0+OK5RbO3Ef2NeftcftM+G54I9 O+PfxI1OP4cfs3fF3/gmdDZ6p461u/n8Uft/T+IfjFD4N+Knii6u9ZM2pfFWz0r4I+DG0vxHqUkn idIfiLqNzHqRXV5mm/VH4deK7PR/iJ4T8a/ET9on9obwz4zh/bB8R/s2eENMvLb4/wDxK+DHjLwV 4ASH4O6V8LfG+iaBPffBLwl4x+JHiGOP4j2Pxm+I9tY/Ei88U3siWviPVfDVtcaRHUOO8xnjKFGG DyN1sTVnisO1gsU69WvVzzC5NSq04Qxsp1cZi8PjuHM4hCjKria2Ax7oUlXzPA0sBi8MV9H3hLDU MTKXFPHk8NhYVMtxPNm2Fw1Ohh8Bk2JzhYfELGcPYeFHBUsRguJsnXtLYXBZrlGJ+uPB4LEVcbh/ ws8S/wDBN/8A4Kl6n+zXH+z9of7JvjWzv/Ffxen+OHxs8feKv2tv2f8AxhN8TPHUOl3WkaLLp+gL 4t8Pt4X0+xivrzVdVbV9e8ca94i8Rzpqt9r8cFlpunWXF6P/AME7P+C8Xh7UvFmtaBZ/HvQ9Y8ez QXPjnVtH/bJ+Hmmal40uLWwj0q2uPFl/ZfHuC68RTW+mQw6dBLrEt5JDYRR2cbLbosY/uZorkjxx j4/WP+EzJZLFTdSvGeGxdSE26OEw3JyVMdKMKMcPl+BoQoU1GjTpYPDU4U4woU1Htq+AfDlb6k5c UccQeXYanhcHKhmeT4aVGlTr47FJ82HyClKpXliczzLE1cVVdTFV8Rj8ZWrVqlXE1pT/AIN7L/gl V/wWk02/8Japp3w7+Jmn6n4B0nWNA8C6jZftSfCO1v8AwXoXiL+0/wDhINF8JXkHxujuPDmk67/b Wsf2xpujyWdnqf8Aa2p/bYZ/t915uhc/8EwP+C3V58OYfg9eeDvi5d/CS3iggg+Ftz+1j8K5/hzD DbXIvLaGHwRL8cn8MxxW92ouoI00xUiuQJ4wsoDV/WSdY+NVv/wUTuPCupfE3R7v4S6z+x/4s8Sf D74cad4R8QaVF4Y8X6V8VPh3o2reKPHeoSfEfUtJ+JOqXo1NIPD8+meFfh3c+FtCGqaKtzq0ut3e qp+a3xu/al+L/wAKP2A/2jPCnxA/ap8LeGP2lviD8d/23fhv4K+OLXC/CjTvB/h/4a634717UdR+ F+geM/iP4s1Hwvf+FvBOjWHgj4XaLa+N/FGoaf471/whehryI3pjip4j5gsFSxdXLsjUa+BzHM4U qmExDk55VxdieHqkZSWMnCM4ZjVrZhOs2lSjiqlWn7acsTOGeE+jnwrWx1XB0uKeOqbo5tleQ1q0 c5y9JQzfg7D8RKooLJIzqUYZXhaGXPCwUqleWDo0IU3ThhoS/EDwr/wSV/4LI+BdOl0fwR8KvHvg 7SZ/Efh3xhPpfhX9pn4N+HtOm8XeD7lr3wl4plstI+NVnbSeI/C9473fh3W3iOp6Jcu0+mXVrKxc 7Gi/8Et/+C2PhqeS68OeB/iroF1N43l+Jktzov7Vnwo0qeX4kTWt3ZTfECSax+OEEj+N5bK/v7SX xWzHXpLW9u7dr8xXMyP/AG7/AAb1+38V/CL4W+J7TW4fEtt4i+HXgrW4fENvqSaxBrseqeG9NvV1 eLVo5rmPU01HzvtYv0uJ1u/N88SyeZvPoc6yPBMkMqwTNFIsUzRiVYZGQiOVoiyCRY2Icxl0Dgbd y5yO/H8d5zhMRjaVTLsnrVsPWrU6lsLiFOtUw0qVNa1sfBcz+pYWMHVnFQ+r4dSlFUYOHn5d9Hrg 6vg8BXocRccYajVw1OrQhHOMsjHD0sXCtWnCKpZFaMX9fxbqKlG03icS+WTr1Of+Gz/h3Z/wXj/4 Tg/E77J8fP8AhZJ0RvDJ+IX/AA2V8Pf+E4Phx5kuG8PnxZ/wvv8At46I08cc7aUb/wCwGaNJDbl1 VhFdf8E5v+C7t9qej61e6d8d7zWfD2tw+JtA1a6/bG+HVxqeh+JLfQE8KQeINHv5vj091pmtweFo 4/DUOq2UsF/HoCJo6XC6cq2w/pL/AGGrD4gQeKfjRN4V+MfxT+P3w08OfDfwR8P7n4xfFHxd4113 wp8ZP2tfCusfEY/G3x38HPD/AI08WeMrfwJ8N4Lm98K+GNQ0P4d6la/Cey8Q6bfeGPBlnM/gzV7+ 6+BPhj8X/jdJ43+Gn7PHiPxH+2B4cu/i54M/Y9k/acuvivqnx48F+KfDvxu8TfFPx1pnx8svg144 8ZHTNV8JeEPG0WgW/hWO8/Z48RaV8ItK0mG2u/gxe6Nevf374w45zCWKwGDo4Hh11cbiMsy/LpfU sZTpVZ5rWzKrhsRSvX9tHKVTwNTMKuKVBVqVPNMm9pgY4vM5UMP6GK+j9wvhsLnWNqcX8f1cNllO tjcfOlnmAqSrwwtPK6FeEYzyWmp5lQnjKOBnhsROklUyrNaUcTKllsJV/wAwbj/gn/8A8F9bvWdM 8R3cv7RN14h0WTWJdH164/bU8CTazpMviG2trLX5NM1ST4/tfWEmuWdlZ2msPazxNqdtaW0F6Z4o IkShpP8AwTq/4LwaBq/iXxDoVj8etF1/xna6XY+MNc0n9sj4d6dq/iyy0SwGlaNZ+JdSs/j1De67 a6RpYGm6Xb6pPdQ2FgBZ2iRW48uv61P2F/EviTxD8Edd0/xNr3iDxRN8Pf2gP2ofhFoPiHxXrOpe JPE2p+C/hN+0P8Svh/4H/t7xNrVxea34m1XT/Cnh/SNIvvEeuahqWua5cae+p63qeoatdXl3Ltft SeMtf0O4/Zy8B+H9V1jQJPjT+0r4H8A6xr2hXN1Y6jYeG/D3hjxx8ZdesE1CzkiuLG38Waf8KpfB F9PDJHK9h4lureGWCeeOeJVON8whVpUKeVZFOGKngcHB/UK0E8PmGIoKk60Prr5KFN4iGIxFFOp7 PlqOMKlSKUtKn0esihVzCFXivxB+sZPUzuvilDiDAVHDEZBSx39o1MPUeSx9pUUMBiYUK37uVaHI m4Rm0v44tP8A+CVP/BaTSbvwXf6V8O/iXpl98N5Nem+Hd5p/7UnwisrvwFL4pu7m/wDE8vgu4tvj bHN4Wk8R315d3uvPob2Lavd3Vzc6gbiaeV2qeAP+CTP/AAWV+FGu3vij4W/C34gfDXxNqNjLpmoe IvAH7Tfwc8Ha7f6bPe2mpT6fe6v4d+NWnahdWM2o6fYahLaT3EkEl7ZWl08bT20MifvVdeIfiN8P PCX7XnxY+G3x2+OPxd8H/s0fCjVfFvxD+KniHx58Rbj4f/Fn9qn4S/E/VPil4r8EfBzwr4g8ceLd F8M+BvC3hPSdY+DnxW8K/DeC0+GM9x4i07wEv9peLPh74gt/Df25+2j4LtPE/jD9kDV4/Gfxt8JH xn+0Z4Q+HviSx+Gv7Qnx4+Eela54L1D4cfFzxNcaRrGg/C34j+D9EvriXV9M0y5m1e4099bZNPs7 M6kbG2htkuPH+cqhl1X+zsmh/a2Mw+AdN4bEpwhmmYxwVCvUtjX7XD46tiZZlR0X1nK8VQx8ksRi p4SnyVPo5cIwr5jKpxDx2v7KoZhmFDEPNsrcsRVyLJsNmOMhQf8AYt6OKy/CSw+V1eaaqYbM8PVy 92oYVYmX8t2m/wDBOP8A4Lt6P411z4laRpnx10r4jeJ7K203xL4/039sX4c2PjXxDp1kFWzsNc8V Wvx5i13VrK0VEW2tb+/uIIAiiKNAoxz3/DrX/gtf/ZPiPQP+EF+Kn9heMPFdt478W6L/AMNV/Cf+ yfFPjiyu7W/s/GXiPTv+F4fY9b8V2l9ZWV7beItThutXgu7S1uIrxJreJ0/pq/ZkEnifxX4Y+Nni 79oH4l+GfG+v/tY/te/A7TvhV4i+J/xB8S/D34i+CPg/4v8AjT8OPBnw10P4ZeJPGF14L0DxV4a8 I/CDRfivf/EXSvDP/CwNav8AQvFz65rV5YeLtWz8wa58Vfif4T/bE+JXiyO4/aOtvD/h39vo/DC4 8f618bdf1f8AZesfAWtfsUeB9X0L4LS/AkfGW+g0/WfE/wAXtY0G70TxFbfAzRtNsPEmtTXafEex vdSurLU4lx7mGHmlPLskovD5TDMJuOBxF6EKecZDg8Lg6LhjuWpVhjM5y+vCFGeuJw86WXxxuKeA jjNcV9HfhuE8Zhq/FHHc5U8zzTBVYzz7LnRr4jC5fxG8yxEnUyNSdPEUMizTCxr1KVqtDE03j5YP D/2j9S/CnxD/AMEpv+C0Pi6x8TaZ4s+HHxJ8T6b408T2vjbxjp/iH9qL4Q61Y+LPGdlaNYWfi7xN aal8bbm317xPaWLtZWuv6pHdarb2jNbxXaQkod/xZ/wTR/4Lk+PLXwrZeOfDnxo8Z2XgS/s9V8EW niz9rr4ZeIrXwbqmnpHHYal4Vt9Y+Ot5F4ev7GOGGOzvNISzuLZIo0hkRY1A/dbwt/wUA/aiGmfs qzfEbV/2dvEtz+0H8NPgn4v8beEPhD8Gf2g9M1bwGPj34G8eeIdOm1r4m6h8U/EHgT4Y2+g3uhaN a+CrbWr/AMReNvjILfxpc6N4c+Hlj4aGuSeFeBP2x/21/iT8Of2O/iv8NrbwprulQT/EXwV4W+CW m3vxWufHPxd+JfgX/gnn4v8AiDp6fE34ieLfjFqkPxD8M6/8T2v7jTPC/ibTv+ElhvNC8KeJdW+J 2reJbq7vbDqjxnnMKucYZZdkUKvDVZxxkIYeooYbE4KDwtVUqssfToSqYZ08rwVKrhalakvrVOlO th6eX4v6v5lXwJ4Mvl0nxTx5UXEWF58PKWcYB/XMNi608bBV7ZDOUaWIlVzXMK0MYqPvUK1ZQrVs fh/b/lR4l/4Jv/8ABdbxnqTaz4w0j45eK9YfwvrXgd9V8S/thfDfXdSfwX4lEY8R+EGvtU+PF1dN 4X18QxDWtAMp0nVRFGL60nCLjzLWv+COn/BXLxLpvhjRvEXwO8S6/o/gnTJtF8G6TrX7Q3wO1XTf CWjXN/capcaT4Ysb74xz2ug6ZPqd3dajNYaVFaWst/c3F48TXE0kjf2ifsefGrxH8dfhPeeK/Fvi LwZ4i8SaR408Q+FdVfwp8M/in8EdU0afS00+6Tw/8Q/gj8Z73WPiH8JviFpMOoxwa34V1jxF4ltr yxOk+LNH1mTSPEtlZ2W3+1tb6fN8AvG8+u/G3U/2efCOkTeFfEPj74o6Hd6tpeu6d8OvDnjDQdd8 f+GtC1/w9r3hrxN4X1r4g+EdP1jwBpfivwpq0Pizw1e+Joda8LQXuv2WnWc/PPj3NMG6LWByChTX 1TEU6/1XF0aFCjioyrU8bJwxLrU6VKhmGIxNR0qFTEqnXxSo0KtetKlV7af0eOEM0lJVuJePa3tq lfB14181y6vUnOjXoYeth505ZJJ1Je3yvB01Sk+WVTBYNScVh6Uqf8gPij/gn1/wXw8ceF77wR40 P7Q3i/wXqdomn6l4Q8UftpeAvEHhfULCLZ5dlfaBq3x+u9Ku7SPy49ltcWkkKbE2oNq4xtD/AOCb P/BdDwx4r1nx54a0P42+HvHPiLStO0LxB4z0P9r/AOGuk+K9d0TR7a3s9I0fWfEVh8d7fV9U0rS7 OztLXTtPvbye0sba1t4LaGKKCJF/W/4+/tPfEX4Pfs2fBX4Ya18e/EX7PnjHxn8etP8Ajrav8avi tJafHyw/Y5g/a58MWPw1+FniDxH488Vv4+vfGfjvwn4j0TTvF8eu6l4i8TaJ8MtA+IfhnxnqQ12z kun+vf2bvG/j/VPjh8HviDqnj34laxcfH74kf8FAvB/jvwfrvj3xXrnw60/w98DfjJrPhz4RXPhD 4eapqFz4O8AT+EvDfhCx8PtqfgjRPDVx4sHiLUtT8a3HiXW7q1v4nDjjMlTqVnlmSUaNTEY3B1Ob AYhVZV6GHwzq0K8KeNnSc1i5YrKsbT9vUlhsZlmIVSM8O8PWq3V8AOFIzpJ8YcdVq9OrRhhpU89w VSn7ONTE1KGJw1eWRRnHDzwcMNmeX1FSgsRhc3y+pT5HPHfUv5zPEH/BM7/guN4tSwj8VeGvjN4m j0rWdA8R6XH4g/a5+GOsppviHwpayWXhbXbBdS+OtytnrPhqzlltNA1S3Ed9o9rJJb6dPbROyHrL n9gz/g4BvNY0zxFd3/7SV14g0U6gdG125/bc8Ez6xpJ1a1tbHVTpmpy/tAte2B1OysbGz1A2s8X2 21s7W3ufMit4UT+4Kvy8/wCCgfxH8TWnxE+AnwS0vRv2jda8O/EPwF+0r8RvE1t+y7490z4YfE0y /CHw14Fs9AlHjbUPi98EZbTRtIvfiPP4nl0Ow8dW83ibWPD+iaTeaZq+ky6hp8/JX8QcfRgpSyvI nFOvVaeEnTSjDDSrYyrz1sfToU5LBYScpzr1aFGUaFOGIxFGjF1afXhvo78PYivyUuK/EH21SEYc yzzAuUlRlVq0YPkyV1ZwhWq1Jwp0oVaqnVqPDUK1eoqVX+d3Sv8Agnt/wV/tfhr+0L4c179m/wAV eNvin+0j/wAIToPjn41+NP2ovgZ4l8Uf8K38KX8+t6n4JVdZ+JV/rN7L4u1y38OTazrd54rdBpHh y10aLRmW5lvE+UP+HIP/AAVC/wCjYv8AzNP7PX/z2a/rl/ai+IHxP1P9iL4OfFT4C/HCDTbHWtc/ ZI1/xD8QtT8D6w/jH4nfDTxr8TPhTZ6snh+40Px14Kh+GfiHx3pOutJq+p3uk+M7Ky0vUtW0OLww s11DqNh5rqnjX4gy/tNeI/iIPHfxMtrjwt/wUF+HX7LeleBbfx34sg+F178F/EX7MXgnxVrNhe/C tNQXwDqWtP408a6v48Hj+48OT+PbW50vT9It/FkHhSxOjV20uNs2w2Z4zA08Dk+HxEMbQwFeLwmY Ubeyx3DHDOClToTxcY4fDvH8RZbRlh+XD1KKpZtj6+G9u+bH+difALg7NMowOPx3EfGWJwuHy7HY zB82Y5JiJScsFnHFOPhUr0OH5vFYytgsuxtWGPrzrwrpZXlyx0cNSw9PB/yyf8OQf+CoX/RsX/ma f2ev/ns0f8OQf+CoX/RsX/maf2ev/ns1/oKUU/8AiI2d/wDQLlX/AIIxf/zcc/8AxLLwH/0NuLv/ AAvyb/5wH+fX/wAOQf8AgqF/0bF/5mn9nr/57NH/AA5B/wCCoX/RsX/maf2ev/ns1/Sr8R/2if2k vAWh/tHaB8Vta/aW+HvxA8bXP7Q0P7Pker6J+yza/CBfhb4d+Pfh7wB4d8X/AAu1n4X2utfHXTvG 3hr4V+NfCHiu0l+Nd5pcOpS6nq2pWen6jLpMc2nfcP7IF1rGieN/2wvg9L4m8ceKvB3wU/aB8OeG fh1ffEXxz4v+JnivTPDvi/8AZ0+B3xR1XQL7x74/1nxH408R29h4x8b+JbzTpPEfiHV7zTLDU7fR bWe30jTtMsra8P4iZ3iISmsNlEf+EtZooexxkpxhHMMHl2IwtdRxzjSxVGvjqN4xlVpv2eKjOpTn ToxxGlX6MHA1Oti6Ec14tq/UcXWw1atDMck+rVaUJzpUsbgqv9g/7XhcRVg405xjBuEoVFFpVY0v 4yf+HIP/AAVC/wCjYv8AzNP7PX/z2aP+HIP/AAVC/wCjYv8AzNP7PX/z2a/0FK+C/wBvr4k+JfBX hb4AeDfDmkfFTXE+OX7Sngz4T+ItL+Cfiax8EfE7UfDJ8F/ET4ianpPhbxxf+O/hlH4Nl12T4fWu h6n4kt/HvhXUdO0TUtSbS9Ys9Re2kGM/EnPYujCODyqU8Ri8Fg6a9hjeVVcdi6GDpSnyYupU9nCp XjOp7KlWrezjL2NGtV5KUyH0YeBJxxM1m3F/LhcDmGY1rZhkal9WyzA4jMcVye0yOlTdT6vhavs1 Uq0qcqnKp1acG5x/jf8A+HIP/BUL/o2L/wAzT+z1/wDPZo/4cg/8FQv+jYv/ADNP7PX/AM9mv3q8 OftKXHibx1onhyXxx+2xL8Of2dfhn+zNrI+JNh4u0XT9U+G3i7xf+1b8bvhd47079rLRj8frM/H2 PTx8HdO+CviKW30/9oGGGw0rxt8SLe5v9V12y8TXf0P4O/aV+Nfwr+JUek/tx+OvFPgLw54A8S6l 8Qb2+t9P8Oaw+vt4g8Aa/pvhvwxaaX+zbpmtyXPwCsj4Z+O/xU0+9+KdlB458J+FfhRo/if4zT2F pHb6jXV/r/nrrKh9VyuNWVfGU6cZ0MTF1KeGqUo03GUcxnB4jF05zq4WhGcqeI9mqOGxNfEVI0lk vozcBuNSUc24uq+xw2ArVVRx2Uz5KmPwUcZG6lw7CSw2HlVw+HxOIlGNWjUqSrSwv1T2GIxP8x3/ AA5B/wCCoX/RsX/maf2ev/ns0f8ADkH/AIKhf9Gxf+Zp/Z6/+ezX+gkjpIiSRsrxyKro6kMrowDK ysMhlZSCCDgggivLfjhoup+JfhF8Q/Dei/Emb4Pat4j8L6loGnfE608gX/gu71qL+zYdb0p7nWfD 0UOswPdBNGuf7a02S11SS0uILlJooweafiPnsYyaweUuSTtGVDHJOS2T5MXUmk3o+SnUn/LCcrRb j9GbgGXK/wC2OL3CVneGPyOTcXZ3hzZHThJtax5qkIN2vOKvJfwf/wDDkH/gqF/0bF/5mn9nr/57 NH/DkH/gqF/0bF/5mn9nr/57Nf0HfDrxT8QviF478Q/s56/42/ac+G3gzw14z/bg8UQeFfEXx9+I X/C/PhdP8JfAP7MM/wALvCPxC+NvhT4l+LNd8Z6Pqkvxv8UfG/wro7fF7xz4ZuPCfiPwJ4f1yS9t /DV34W0Ptf2mvjZ8XvGv7KX7EviTTrz41ax8Qfih+zR41+NfjfwL+zz4/wBR+E/xL1LV9I/Zjs9d i+JV1rek+L/hzJP8P/hv8TfF/he48UeEY9fnk13VfE/hW0svBHjaS2Xw/LVbxHzujgamY/VMrnh4 YLI8zSVKrGpPA57hc3xdGSc80jQhXwsMhzVYr2tengIwp4bFQzGeBr1cVhqp/Rh4JnjsHl8sy4vp 4jG1uIcNS/4UMmqQVbh3M8LlmIqP2fD86ssLiamOwtfC1KVKpi6lF11HAutHDUsX/N5/w5B/4Khf 9Gxf+Zp/Z6/+ezR/w5B/4Khf9Gxf+Zp/Z6/+ezX96vwo1qTxJ8Lfht4im8RWPi+XX/APg7WpfFml xNBpvieTVPDunX0niHT4Hht3hsdaac6laRPbwNHBcxo0MRBRflf/AIKQa18YfDP7H3xZ8UfBX4j6 b8L/ABL4b07TtX1jxDP4Z1zXtdufCVvq1iniHRPBWqaD4+8B3Hgbxfq9lKbTSfHdwfFdt4d3zXP/ AAiGrXDQPbb1+P8APsPi6mEnhcqc6WL+qVJrD46MYNYhUJ1ZRqYyFVU6WtWcXT9vyRlGNGVa1J8N L6OXh/Wy6OZRzXi/2U8B9fhD+0cklKUHhniYUlKnkU6bqVFanCSm6PPJSdVUr1F/Gl/w5B/4Khf9 Gxf+Zp/Z6/8Ans0f8OQf+CoX/RsX/maf2ev/AJ7Nf1I/FT4gfEWP9oD4oeP7Dxl8RtKvfg/+2x+x f+zh4M8JWHjrxlZfDHWfhn8aPDHwXuPiLL4h+F1jqtn4G8X6rqF18b/E12vibXdD1XxFos3hHw// AGHrmjxaVNFX0J+x/wCKvjMvhj9sd/jF8QdP+KnjjwD+1H8WdJ0nVdD8N674N8KWXh3S/hz8Ntd8 L+FfCngrXfHXxLv/AAzo2kWupJaz2SeL9Vi1PW5NY8RiOyn1yawt+VeJWdLBY3HVMHlkKOBy3H5n VtQxM5VKOBp8HYlxoxjmF3KpgeNsqrWrKjKnXo4zDOMlShWqdVf6M3AlDHZfl/8AavFs6+ZV8ooU LZjkqUP7XwnFGIozqt5ByxUKnCmOpSUZSvDEYSq3GbxFCh/HV/w5B/4Khf8ARsX/AJmn9nr/AOez R/w5B/4Khf8ARsX/AJmn9nr/AOezX9Wn7A3iXx1J4p+GI8Q/ED4meN0+On7CXwR/aU8eW/xC8eeK vHFnpPxh8V65ff8ACT6p4Qs/FGo6nB8PdG8SQ6/9lHgHwYnh3wDpNt4W05fDnhTS5E1GS5/WCuvE cfZ/hpyp1MNk7nTxGY4SpyUcY4rEZTmuPyXHRi3jYuVKOPy3FLD1HGDrYf2NeVOlKo6UM6X0bPD6 vKfsc54vnTVPL68KjxmU0/aUMzynL86wknCpw9CpCp9SzPDKvTlH91iFWpKVSMI1Z/59f/DkH/gq F/0bF/5mn9nr/wCezR/w5B/4Khf9Gxf+Zp/Z6/8Ans1/oKUVz/8AERs7/wCgXKv/AARi/wD5uNv+ JZeA/wDobcXf+F+Tf/OA/wA+v/hyD/wVC/6Ni/8AM0/s9f8Az2aP+HIP/BUL/o2L/wAzT+z1/wDP Zr+y/wDZa1n4xXXx9/bq8PfFr4kab4/tvC/xk+G8Pw6sdA8Ma14N8O+BvAuufA7wHr9j4VsdB1nx 58QGm1WO+v77UfE3iS01LSbXxPrd7danB4a0C3MGm2/3LSj4kZ3KnRqLC5Tath8NiOX2GMvT+sUK dd0Z3xqTq0HU9jVdNzpOrCbo1a1Lkqzcvox8CRlKLzfi58spJSWPya04ptRqRvkCkoVI2qQU1Goo ySqQpzUoR/z6/wDhyD/wVC/6Ni/8zT+z1/8APZo/4cg/8FQv+jYv/M0/s9f/AD2a/wBBSin/AMRG zv8A6Bcq/wDBGL/+bhf8Sy8B/wDQ24u/8L8m/wDnAf59f/DkH/gqF/0bF/5mn9nr/wCezR/w5B/4 Khf9Gxf+Zp/Z6/8Ans1/Xt+zp8WfjSv7QvjD4fftFyftC+G9Z8ceKP2k9U+CHhvxfoP7LcPwI174 VfDT4t22keFdQ8Cap8K49S+PFt4itfhxrngfV5Y/jRqWjprcOva5dWNhqU+mxSaf+j1NeI2eSo4a ssLlNsTQjXUPY4p1KLc5050K6jj3GFejUpzp1YRlOMZxaU5FVfoxcCUsRi8O834tk8Liq+F9tTzD JpYfE+wm4fWcJVWQWr4StbmoVklzx3jGScV/n1/8OQf+CoX/AEbF/wCZp/Z6/wDns0f8OQf+CoX/ AEbF/wCZp/Z6/wDns1/oKV8L2+tfGK1/4KN/8Ixr3xH07Uvgzq/7I3ifxN4J+GOi+Gdd8PyeHvE2 k/Fj4c6PrviPxnrV14+1/RPH+t6jFqYtfDV/YeCfA0vhDRTqWkn+3pNZvNQopeI2eVcZhMGsLlUZ YuOZyjUdDFuEXluS5nnU4ySx/M3Wo5ZVpQaXKpzi5NJWlhifo1cA4bB18ZLNuLpRoVsroumsfk3N N5rneWZJTlFvIOVKjWzOnXqXabp05xhebSP40/8AhyD/AMFQv+jYv/M0/s9f/PZr+gr/AIITfsQf tQ/sa/8ADU3/AA0l8Mf+Fcf8LH/4Uh/whn/FafDzxf8A2z/wiH/C3v8AhIv+RD8WeKP7O/s7/hKN C/5Cv2H7X9u/0H7T9mvPs/vWk/G7WfFH7dvxDTxXqf7SnhjQvhd+1z4R/Zw8FeIfDPifTI/2adQs td/ZQ8I/ERfhd8RPhg/xdtL/AFvxP4y8X/EHUvElj8VR8E9cn0DULDwN4ZtfGuj2UepWrfshXBmX GebZxlEcPicPl9PDZjRwOIvQpYhVoU8Rhcsz3BXlPF1Y0qtXA4/L69WjWpRrQhXU4wnha2DxmJ+o 4X8C+EeCeKcHneWZlxFicxymGKlSpY/FZdLCyliqea5Fi41aVLJsJWqxo16OPp0q+GxEsNUqUY2r SrUsXhKBXzZffsi/AG9+HGmfClPB+s6P4R0T4k+J/jBoMvhb4j/E/wAH+M/D/wATfGnirxX408V+ M/D/AMTfCnjPRviVoWta/r3jrxi2pzaT4ts47nR/EuseGWi/4Rm9l0hvc/Fnizwr4C8K+JvHXjrx N4f8F+CfBfh/WfFnjHxj4s1nTvDnhXwn4V8Oadc6x4h8TeJvEOsXNnpGg+H9C0izvNU1nWdUvLXT tL061ub6+uYLaCWVfiD/AIexf8Esv+kln7AH/iZH7Ov/AM8avjWlKPLJKUeanPlavHnpTVSlOz05 qdSMalOVrwnFSi1JJn7QpSi7xk4u01dNp2qUqlCorrpUo1atGa2nSq1KcrwnJP7G8GfDTwL8Pvh/ o3ws8JeHLLTPAGgaF/wjen+HJpLvVrdtIeKWK6g1K61m41DUdcuNSM9zPrOpa3eahqet3l3eX+r3 l7e3dzcS+cfBT9l74J/s9X3iPU/hX4Y1rSdS8UaX4Z8PalqPiX4h/En4kX9n4T8FjVv+EN8C+Grz 4l+LvF9x4M+HnhE69rj+F/h54Pk0LwT4fl1fUpdJ0Gzlvbh5PBIv+Crf/BLu5mhtrL/go/8AsH6l e3U0VtZ6dpX7XPwC1bU7+7uJFhtrPTtM03x/dahqF7dTOkFrZWVtPdXMzpDBDJI6qfuLw54j8PeM NA0bxX4S17RfFPhfxHplnrXh7xJ4c1Sx1vQNd0fUYEutP1bRtY0ye607VNMv7WWO5s7+xuZ7W6gk SaCV43VjfPPnrVOeXtMQlHET5nz14xnOpGNaV+aqozqVJpTckpznJaybcKMVCFJRiqdNJU6aSUIJ OlJKEEuWKToUWlFJXo0nvThbZoooqSgooooAKKKKAPxn/a//AOCS3gH9rD9puL9pPxV4Y8Eav4o0 SHwbbeGb7VvHXxS8Ps1v4Lj0rUtCt/FnhTwp5Xg3xlB4d8XWVx4k8KxeLrDxJHoGqSJq2krp2ou7 J8f6d/wbvfBLSvh5rfwmstDhX4ba9c6HfXXg24/ao/bAvtE06/8ADniqHxvo9/4Xtr7xlcnwZf2v iuCLWpL7wg+h3d5dKVvprmB3hb+liivfw/EeNwuHoYalhssVLDxapqWX0JS5p+z9rUlLlvKrXlSh OvUfv1pxU5tySa+cxPDGBxdevXrYvN+fEVoVqkY5niY01OlKrLDqFNS5Yww3t6scLFaYeNScaXKp Sv8Azhp/wQE+G6eKvC3jlZdX/wCE08HaDH4W0TxW37X37aD+In8NReKb7xmnh/XdYfx01/4s0b/h I9Rur5tN8Vz61ZyRG302SFtKs7Oyt/6EPAOg3nhbwL4L8MahJbTX/hzwl4c0G+ms3lktJbzR9Hs9 PuZLWSeG3nktnmt3aB5reCVoirSQxOSi9ZRXPmGd4zMqFLD144anRpV62JjDDYeGHi6+IblWqyjT tGU6sm51Jtc05tyk22dOXZFg8sxFXFUKmMrV61Clh51MZiqmKl7Gjb2VOMqrcoxppKMIp8sYpRSS SCiiivIPaCiiigAooooAKKKKAPFPF37RPwc8Cf8AC2f+Er8Yf2V/wo3w74T8V/FL/in/ABTff8Iv oHjj+1v+EXv/APiW6Jef23/an9h6p/ovh3+172y+y/8AExtrTz7bzqH7R2t/s6Wvwz1Hwp+0/wCO fh14J+GPxJl/4Qu5HxI+I2nfDHS/E97Na3Wtjw7pniC98QeGbuTVpLDRb/VFstH1SPUzYaZf3Sr9 ltbp0/N79rzw/wCNz45/be8A6b8MPi34l1b9qP4N/sz+Evg3q/g34U/EHxp4H1XX/Deu/ELQvFNj 4s+IPhXw7q/gn4Yr4abXtI1XVLv4ma94Rsn0O8Op6bcahFaXy2vpX7UXhH44abfeBvHPxX+M3xTk /wCEH+LfxG8XfA7xD+wl+xZceKvFnw8sNX+EfxB8H6H4W+Nvh3x9rf7auoePbm+03xNdafB8R/AP wg+HOiy+I47a31fSvB+l6um6alSNOh9Yj7SUE2oypU3WdWvSnhYTwmHhTalUxjqV5xhTjeSlT9ml PEyoYfEc2G9viK9fC4ihTS5WlTq89FewrPMXTxWIlOFaH1P6vhsPOpLktNV3O8MMq9fCejaje/sE 6r+1JYavfX76n8atbmsr+DUIL7403/wI1TxjqfwcvpNKv9TuLKab9lO6+Od/+z8tzJpF5q7P8aLn 4OPayafK/gqawZ+o/YwP7Hgg8dR/sqyeJnkFj4Ck8Qf8JvL8eptaPgNtL1aP4Rv4Ff8AaCZ9aPwF bTI/Ef8AwqQ/DNj8E2UeJm8BZlbW2b8z7X4d/tP/ABH8Mat8JfiZ8MviDoP7RXxj+PHw4/aT8VeJ NK8A+K4/g74a00fsLeA/BXjZl+LtpbXHw30rU7D4t+G9e+HNv8P28YReOTdXdnqdn4auPBco8RN9 rfsQaR4o1v4teI/iNd+AviV4A8N+H/2Of2Qf2d72y+Jvw68Y/DPU7v4pfCnU/jfr/j/T9F0rxno+ iTeJdB8LWvj/AMNabD468MprXgXX768vrfwr4m1mLTL+SLvo0PZ/2pQqVY03hMPk1KmsNiYVcPiq eJy2WY472coxg8Rgsmzly4emoU1GOZWxVX6rKtHBK69R1fqdVxlJywNTEQddRrVFWpZ/hcpw2Fi6 VSpDBVcdkVetxRhqNWpOrSy7DTwyjiIt4yH6B/EP4l+CfhToWn+JfH2tf2Douq+MfAXgCwvf7N1b VPP8XfE7xpoXw88D6T9m0Ww1G7i/tzxh4l0TR/t80Eemab9t/tDV73T9Ltru9tzwj8S/BPjvXfiR 4a8K61/autfCPxja+APiFZf2bq1j/wAI/wCLr3wX4S+IdtpP2nUrCztNW83wf468K6x9v0SfUtMT +1P7PkvU1Sx1Gys/mf8Ab58O+Jdf+AGnXXhfwz4j8X3Pgf8AaA/ZS+KutaD4P0PUvFHimfwX8Jv2 mvhP8RvHd54f8LaJbXuveKNU0nwd4Z1vVrXw54e0/UvEOuPZf2boWmalq1zaWNx4z+z/AOHP2hvF HjT9pn4p/CbVtC+DXgr4r/tmaR47Nv8AtHfsy/Fq/wDF3xG+D3hj9nT9n34WeIIvCXg3Vvi1+zn4 y+EWuan4w+Hviyx8O+MvH/hbxpp89hZW2u23w91rRdQ068vc8HSo16ONlWqKnWoSxypx54xioU8R wRRwNatFxnVlSrRzriapJUYyq4iGSy+qUpzwGNp1+2pClTw9Krzv2lR8kIXi3UqQhjatSlCNlafs 6GGtKco0oSxEPa1IRq02vob4w+Nf2TPih4K+KWgfGL4j+GdD8G/A34peCfDHxG8U6r8SPEPwRT4Y /FxbHwH498Cwaf8AFvTdf8Bal4c8Utb+PvA0ul6n4R8YW80t74ij8LtevqU2p6MvytqNh/wS/wDC ni/4HaJbakdVv7fT/h9q3grWfAPin9ob4ifDfXdP1v40a1cfCnxN+0L4++H+reJvhV41XXP2g77x Vq3w88WftTeIdbl1f4uXXi/XfDWqXPi6XxDfHyeX9nbQPh9ov7bei6V8OvjV8Dfhxe/8FIPgb8b/ AAhf/sq/s/eF/EOvyLoXwj/ZR8Taj8S/CPwz1D4b+NdI8ceFbn4s+G9dX4ia94O+GnxC11tatfFl 7HpV1rum6xe6dzuga/8AFL40eJfhB8Nv2g/hp8X/AAtpmpS+D/H3xV+Ow/ZE+Kr/ABO/aO8G/Dn9 pT4lav8AsifCbx34h+GHwWtvB3wgl03QvD/h74wftB6L4wj8Dv4Km+IMvhPRvA/ga38Z+Mrnw7WD pw5ctqQqSpVa+L4ZxeMpUpxpTjWzDhHKc1xeMo1VzOnjMJiMTmmCwftKVTGewyyngcPDHYvEVI4S Mby0Pr6anVo08BWhRqxlGpKpH+3atGlha2HkqSnQ9jSoYivGnXeGoY/MsPXxtfAYLDPGYv7Y+Onw R/Yi+Gs/gDx78dZPEOjSeJPin4M+Fnhe51n4v/H/AFKD4jePviz8a5vF3w8+GvjHw5pPji/tvir4 ai+Lfim+1Lwb4L+Iuk+J/h78MNJvdWt9E0zwh4Bs9St7b79r8W/29/A3x/8A2g9c+BnxJ+G/wd03 xz8MPhL+0N+zk3hzQPGVz8XPh/8AFnw58SfDH7a/gHS/ij8Un+F11+z94mF94C0b4d+CmXwx8UIv FukadB8LvF3xI8eWtprnhPUNEvdR/aSs6UL5VGvNyp1Xnuc4WOEvyKlhqGCyKvTxFSi02sRjsVjM dXliIS9nXwqwcHCGJoYpzWIjbFOTl7WpLB4V16z/AHkp11PE3prEJ+9Tw1J0cLLD1Eq2GxlHG3cq FWhYrxr4k+N/gtc6ld/Af4oatoFxdfEb4S/E/wAXap4J1+2uptN1z4Q+D28MeGPifqetXP2ZtItN CsP+FieHdNv4dTvrS4v4dYmbT4LuHT9VksfZa/LD9p74KajH+13/AMLp+F/7PmieNPHPiD/gnf8A tp/D/wAReJoPCSaRB8R/FY8S/s23Xwf+EnxG+J+l2NpeFNbFn4wtvCOkaxr6XVrpo8W3vh2KCO11 WeLirKU1UpKnTqRll3ENbkq29nOvl/DOdZpgaFTmXI6WKzHA4TCV1JpzoV6lOlatOnKPZltJVcXR XtpYeaxGBVOrGrChKm6mY4OhVqqvNqNKdDD1a2IpTbUVVpU/aSp0+epD0v8AZe8JfsVeP/C2ran8 Brn4k6xpvhfxl4Z8VeKL34leM/2p7LxrqV+/wrTTPBD+NJv2gtds/iB48+Ft18LfFMdz4K0LxQfE PwgvbO6j17w5ps2q6cmo2fov7JPhz9jnSdK8V6l+yL448DfELSr9PC2m+Itb8H/HbVfj6mj6Poen XkPgPwbY67rPj74gTeDfA3h7TLrU28D/AA90G90XwXoEF/q1x4b0CyOo6hJP8W/sUad4k+G3g74x 6Zr+l/tQ/EDSPiRbfB34deBPiJ8Qf2ePFXw8+L19rHhj9m6TRtZ8Lat4I1T4e/DfSvCvw9+Hz+EY 9M8IfE7xxofh/wAL654y8XzeG9e8d+JdZe31zVvZP+Cd7/ErRNN8R/DObVP2hvE37Pvww+Ff7Pvh X4Sa/wDtR/BDRfgN8V9N8Y6Z4b8S6R8SfAEPhrQ/hH8GLLxF4Q8JaFpHwwurTxdbeG/Eem3firX/ ABfpWj/ELxTY6SkOj+pOEVic5hSr1HCjhconCpKfvY6FWM1WVeUVyyWDp08s9jSj7XDKOLpKljqs aWEeO8KlOpPB5VVr4eEak3jeenyVIrCKni1ThDC0q9OnV5cTjK+ZVJzkqGIj9SxlargFKeNeA/S2 viP9sVv2UvDtx8MfiL+0lrnxQ8Pa14YPj/Tfhxqvwh8V/tP6J4vtLLUvDlv4j+JN3JpX7Luq2nim 98Oad4X8Fw6r4l8QeIdPuvD3hbTLCSa61HSY9Sm+2/blflJ/wU38IeOfFv8AwqWHw1D8Z/D+jweD f2lLC6+JPwD+FOt/Gnx5p/i/xZ8LI/B3g/4Yat4L0fwP8Q0034ffFC213xLP4l8cXuhaUPDuq+C/ DFhY+OPBOoa9bayvj4yc6dFzpUo1q0OadGnKE581SFOclGPs4VKqqVUpUaSoUq+Jq1akKGFw2LxN Wjha3sYKmquIhTlV9hTkpqtV9pGl7OgqcnWk51HClZUlJuNapRoSSca+Iw1F1K9P3f49/CX9j/Tf hF4u+O3xu8S+MtE+F/gjQJvjBr/xZtv2hP2htD1Dwx4Y0L4Vx+DNT1zw/wCMfA/xJsvGWmaJrnw5 tVh8R6B4Qv4rL4iancS6/r2j+JPGOqzapd/W/gDTfB+j+BfBek/D3TrDSPAWm+FPD1j4J0rSrJ9O 0zTvCVrpNpD4dsdP0+WKCWxsrXSEs4ba0lhilt4USKSNHRlH5R/tk+Afjn8eP2NLn4M+BPgn4fu/ +FbfCkn41/CHxbd/E/wdpviLxTpX7PsPiP4d+CfghrFl8Gvidp/xs0zwf8SNU0K+lh0K9tbW98X+ A9M8F3niJdQbxDYW36g/Bu3160+EXwttfFOlQ6F4ltvh14Kt/EGiW91eX0GkazB4b02LU9MivNR0 nQb+6SxvEmthPe6JpF3J5W6402ylL28fpzUY189owqSdLDY/LI0JKpCUcfh6tDNIUcXOUG4YmVGn hIUqFWh7XD0sPVi6eIqRxUaVDzKU51MJw5iKlLlr43LcxqV4Sp1IPAOj/YU6WDpU6sI1cLCo8ZWq 1KVblnV9lQSo0nhqkq3pFeL/ABc/Z/8Ahl8b7zwNqfj+18ZjVvhrq+r674I1nwN8V/iv8Jdb0HVd d0K88M6tcw618J/G3gnVLtb3QdQvtMkttRu7y1W3u7jyoI3ldz7RTJQ7RyLGcOUcIT0DlSFJ+hwa 4qr5ac5+zdV04upGnFJylOmueKhfTncklB3VpWd1udSV3Zuyejb2s9Hfys9V1R+dF/ff8E4Phn49 0r45eNPjH8O/APi3w3qWv2Njr3xk/aU8W+GNC1bxX8K9Kv8A4H+JPiHeeFfiv8SbLwb8QPiJ4X0T TNS+GeqfHjU9B8R+OG0uxuvD83j24tLd4E9Z/aA+HP7Jnh/4Z/tDePvjlo27wF8fdD8FeFfjVqlp qHxK17WPHOnLHaeAPhx4X8Iab4EvtR8Zwazd6h4gtNJ8D6B8ILGx8Rap4x8QDUPD9ndeL9Ze9uvj 34SaH458afs4/sB/s7y6Bres6De+Ntf079rnX7TRtSn0Oyuf2cf+Ev1Hx14V8V6pao+mac/xK/aM 8P8Ah7RdS0vWLnyvGPhmXxhpa2d7Z3d75XzF450Xx78Kf2nP2lfjm37I/wAT/i98Mte1uWw/Y68E 638IfiJ8SvBXww/aAs/it8JrL45/HXXvhr4P+F3ibxr4D8H/ABA+Itl4R+Nng/xfpGk65qWraV8E PiX8Rvh7c2Wp/EnTTrHUrvEU8NVrOc41MfGGIpyTpVqOG/s+pSWG+tTwtCjPM8TWr0MLHGY7DTeI w1KpKhKlP2sNJxiqntI81aNCvgcNLlVTmpU6uJxuHjQp1/YyqurleGwzxuI9ngpYaGArVqsatDEY WtgZ/Tutwf8ABJnTdA0bxTrvh1YdO+KX7Vd9+2NcreeDf2kpde0n9pn4G+IfCPw38R/Gb4qeGzo8 nif4NWXwy8T23hLw346m+K+leBvhj4f1a6hPjCygn1e8mvPrix/Zx/ZR+MvxBv8A4y2Gh+Ita8U+ D/jKviDU7CL4i/G3wv4N0j46fCu9tNIj8Z3/AMFj4u0P4bt47s4tK0+KLxzc+ApdQ8Y+Ep9Ouk1r X/COuWk+ofkT8ffgZ4xfwJ4Rtfh9Y/tI+Ote8WfBX9pddX8WWv7MHxW0WX9pL4+fHD44fD3x/wDE D4IfG7wb4q+Gdxq37OXwC8f6voEY0zxhqNr8O5/D3gyNY9B+Num2fh3VW8Wfrr+zFDe3Hxj/AG3v EEEEtv4W1j9oDwfY6SwYvp1/4j8K/s6fBbwx48vtIfzHWW1s/EGmnwrfSRpAn9v+F9ZheI3EM80u tCMY0MJOlOpCthKOYYmFOlLkWCxOR5pw5kGBq4WM40MRTwtPLcvySOFxUqOFxboYLh1UsDhsuw2X V6nDUUKtXGwnSpfVa844aEsTGlKpjsJmFDNczr4LE04zqUJYqvPOcxrYmhSr43CvE/61UnUxOKlm n1H7MrB8U+G9L8ZeGfEPhHXP7TGi+KNE1Xw9q50XXdd8LawNN1mxn06+/srxN4X1LR/Evh7Ufs1x L9i1vw/q2l61pVz5d9peoWd7BBcR71FcbSknGSUoyTUotJppqzTT0aa0aejR1wnOnONSnKUJwlGc Jwk4zhOLUoyjKLTjKLScZJpppNO6PP7b4XeBrTxxovxJi0eZvG/h/wAAXnwv0rX7nWtevLiHwPqG r6Lr17o89veapPY6hNc6v4e0i9l1rUbW615ntWT+1PJuryO4x4fgd8LoPA3xJ+G0XhfZ4K+Luo/E bVfiHov9t+Im/wCEhv8A4tTajcfEGf8AtFtWbVtJ/wCEgl1bUH8rQ7/TIdK+0bdEj01YoFj9YopT jGpB06kY1KcqOKw8oTSnCWHx2LePxtBxleLo4zHSljcVSa5MRi5PE1YzrNzJpfuJqpQ/c1I4jC4u M6X7uccVgsIsvwWJUoWksRhMAlgsLWT9ph8IlhqUoUUoGfpGlWGhaTpmh6VB9l0vRtOstK02182a f7NYadbRWdnB59zJNcTeTbwxx+bPNLNJt3yyO5ZjZuraG9tbmzuA7W93bzW06xyywSNDPG0UoSe3 eKeFyjsFlhkjljbDxujhWE9FVW/2j2vt/wB/7fn9t7b957b2l/ae15+b2ntOZ8/Pfnu+a92KklQV ONFKjGioKlGklTVJU0lTVNQsoKCSUFGyikuW1kfMHw1/Y8+B3wj8M+GfBngSD4taf4R8GS+DW8Ke GNY/aR/aQ8Y6DoFv4BV4/DGlaZpPjP4seILG28P20D/ZNS8NpD/YHiOyjt7HxJpurWdtbwRYuhfs K/sv+GvCXiPwTo3gHXrbQ/Er+Dd8svxY+MV/4j8L2nw31q68RfDfRvhl401Dx/deMvhD4b+G+uX1 9qnw88L/AAq17wb4d8C3d7dy+FNL0g3Mwf65oq5VJydRynOTrVY16rlJt1a0XTlGtUbbc6sZUaMo 1JXmnSptNOnGz/m/vwjTn/ehB1ZQhL+aEJVq0oxd1F1arSTqSvw/w3+G/gz4R+CtE+HvgDSZNF8K +H0vBYWlzq2teINRnudT1C71jWNW1vxH4k1HV/EniXxDrus6hqGteIfEniPV9V1/xBrWoX+r61qV 9qV5c3UuL8WvhbpvxW0Tw9p13qV1oWqeEPHvgn4j+F9fsYYJ7vSvEHgnXrXVol8qcqsun67piap4 V16GOW2uLnw7r+rW1td2lxNHcxepUyRBIjo2SroyMAcEhgQcHscHg9jWVeU53rNKvXhVhi6brNyc sXh6scTh6spSU25xxNOnVU2pNTipWbQoQhGDpKMY0alKph6lNRjySw9enKjXoyhpCVKrRqTpVKbX JOnOUJJxk0fkVpFl/wAE/wC1+EfxF+Gnw9+J/wAYfD/wz8PL4M03xh4V8T+JP2u/iRovjH4f/wDC 27TSj4Z+Cvgr4zah4r0v4keHfin400m6+FaeJvgBoHjF/Es2v3Phfw7qV1qut6bHJ9dS/HL9jv43 aZ4F8Wah8S/BmpXPw7j1z9ofwt4e13Xda8CfEXwhD8N4/GXgPxT4z8QfCfWZfDHxH0qHwTcSeNPC ninRfGfg+KPQvEFpqOk63o9tr+lpDa/hdrX7OP7Rd74y+Ceu+CdX+Pul/Bz9jnSPh58LpAf2O/GP gz40eE/BWlftR+CvEB/sPR/Glz8bvCv7V3jb4eeDfh7H4hl+IXwi8A+IPA2swW2i674a8P69qut3 Gmx/UZ/Zt+KXjrwd4F+L+teHvi/4r+KGueMPjXrF34M17wJ4U+Fvh74hfDD4X638aL/4WeMvjR4M 0r4UeENW8E/GL9of4eax4X+GfjPwZFceAtF1JPit4v8AEt78KdL8V6FeR6LpTdOWT0sdKq6dWjmu MSp1qcYzwdHCTpyyvN40Pa1K8cPifZYbNcNRw1aVODw+LnlVfH1KuJzDDOqqjzrM8FSoRrUObBYZ YqpiFh55rRzLB15Ztgak5YedJ4jCRp4jLcdUxUnCEsdgsNmlHBt4fCY79L734Nfsr/DHXNY/bH1j TNR8KyaDpXiv4pX2v6/4y+LEXgXwjL4r8Owp428faV8EdY8QyfD/AMHfEDxHoEc1n4k8R6H8ONJ+ IerHUtc07Ubue+8Q65b6j4H4Ssf+Cf3xN+L58WWA+KcPxS+Kvxtnmu/h58RLn9sX4cWN98b9L+BB 1i28Q65+zh8UJvCvg3wjrifBHwOmr+GPGOs/DTQdPu/7Et9S8MaxP4uNvPL1c/iT4lfHj9gv4t3f xr+BmtfEHxLr/hX4oaDc/Crwz4a+In7Ofib4n+GrC91Gw0m58MeEvH9/4g+Jvws8S6zpUK3Xh621 XUL3X11i1stW0eWFNR0xYfzz1L4K+Ofj74r+Fngv4neC/jJ+1T+zl4S+O/jXV/CPjn9qz9mS+8Ff E7UdKv8A9i39oTTZNF+LnhLXfhB8LZPEvhjwF461jwh4U+G3xH8cfDXSNU8Ra7rdto8+seLPEmm2 3iHU4xChhqeYXoupQyzJufDYWnJc9PAuvSxbwLXsnOlCcqOHnTwVTB4OjLHYdqrOli8PHDLCnUdZ YRyny1sfmNWnisRLDVXCrjY4evhvrSU6sITTTxVOrX+u4musHiKfs6dfD4ipXX6Xaf8AsV/sdeJ/ E+nW+m/DzxvY6r8ALH4P/DbT7W28e/tG+CfDFva/CPwxBrHwl22q+MNB8GfFm58I+F/GlxoqeO5I /G999k1fxJ4B8ReI55YvEfh6Dw1v2YP+CYK/DbR/ixJ4RvpPhPo3iK7/AGetJhn8a/tJ3Hgm28X6 28P7A2o6YPhfL4nk0mXxRq/l2vwi1T4mXPhCXWNQt7az8Y33jGa2s7bxbD+Nunfs9ftW6pNpkni3 4c/FrSNP1L4a/Cv/AIRnVtf/AGVfi18cfG+k/tPWH7Hv/BO3QPCHjjwzBbeNfhlZfCv4i+FdZ8Ff Frw3ZfH/AOI2uQ+Cfhz4h0Xx/wCE/F2taFfapqFreema1+z541bUZG+J/wCzL8afGfjO6/aP+Amu /s3eILH4FfETxgnwztvD/wDwV7+NvxM+OfiH/hI9J8OX+nfBnTdY+Fet+APHnibXfEN/4Y0/4l/D UaLd6de+LdG8Oy22k/QTy+MMbhaE8yVX+2s7w2EzWdOoniK/1vEUsJmeLrwdR062LxFKpicXGli6 8p08qqUMfiqtalWVOeFB4erPKv8AYlTp0slyTGUZShRjSy9Y2jg8VHA0a8lGeGw+WSrQpSr0MJUU cdha2GhhKbw9SvD+lL4S/Bn4e/A/w9qPhn4daZrNnZa1r994q1/UvE/jTxt8RvFviTxJqNtY2Nzr fijx38R/EXizxv4m1IabpelaRa3WveINRlsNF0nStFsWttK0yxs7fm/jF+zZ8JPj1H5PxO0zxhqs Ai8LJFB4f+LHxa+H8FtceCfHug/E7wpq1nB8PPHHhWKy8Q6J438MaHrFn4mtEg8QiKyOjyanJod1 eabce7UV4UpSnUo1pylKth3Slh6sm5VKEqFL2NGVGbblSdGj+6pODi6dL93C0NDshGNOE6dOMadO pKUqkIJQhOU66xMpTjFKMpSxKWIk5Jt10qrbqLmPHbn4DfDbUfhqPhJrtp4u8W+CP7Z0XX3tvHHx Q+KHjrxFPqvh3xXpnjbRJ7rx34w8Za547u4dM8S6Npl9a2Nz4llsEgtE0s2x0h5bCTH8F/syfBT4 e/E3xB8X/CXhO/07xz4j/wCEpa4uLnxp481nw1osvjzW7HxN4+ufBHgDXPE+pfD/AOHV74/8SaZY eIfHt94A8MeGrzxtrtrFq/imfVtRBuT71RSUpRqOrGTjVcakHVTaqOFalGjVg5r3nGrRhClUje06 UI05Jwikru/Zujd+xdSNZ0v+XbrQc3Cq6fwupB1JuM2uaLnNppydyvGvjF8APhb8ebLRrL4k6Rr9 23h59YOjar4R+IHxD+GHiWxt/EWly6L4h0uPxZ8L/FXg7xO+g+IdLlFpr3h2bV5NC1pILJ9T066l sLGS39loqJQhNcs4xmrp2lFSV4u6dmmrp6p7p6ocZzg+aEpQlZrmjJxdpJxkrpp2lFtNbNNp6M8O k/Zw+Dk3g7xF8PpvC9/N4I8T+JPBXiq+8LS+MvHMui6dqnw6i8EReC7bwlYv4laHwJ4c0I/Drwlc QeD/AASvh/wjcX1jf6jfaJdX/iHxHc6tWn/Zk+Clx8ZIfj3L4Tvz8SodQi1sXa+NPHkXhGXxTB4T l8BW/jq6+F8XidPhde/Ea28Cyv4LtfiPeeDZ/Hdt4TEfhyDxDHo8MNmnvVFaupUdT2rnN1VFRVVy k6nKqVOio89+blVGjRpJXsqVKnTS5KcUoglTpSoU0qdGcZQlRglGlKE3zThKnG0HGcvelFpqT1ab CiiioGfKVt+xF+zFbax4+1p/hvcajL8SdF+IXh7xFpOvePPiT4j8Jafo/wAWdbh8TfFCz8B+B9f8 Yal4M+FY+IPiS2tfEPjGf4YaD4PufEWu2trq+qTXWoW0FxH678Jvg38P/gl4f1Hw38PdO1u1s9a1 +/8AFOv6p4q8a+N/iR4w8S+I9Rgs7O51rxR49+JPiPxb448T6gmm6bpej2Vzr/iHUX03QtJ0jQtO Nro+lafY23qFFVGUoRUISlCCoRwqhFuMVho1niY4dRTSVCOIk68aVvZqs3VUVNuQppVJc80pz9tL Ec01zS+sTpulOvzO79tOk3SlVvzyptwcnF2CvOfih8J/A3xj8OW/hbx9pup3unWOt6V4l0m90DxV 4s8C+J9A8Q6JO0+l674Z8a+BNc8NeMvDGr2u+e3/ALR8P69pt3NYXd9plxLLp1/e2s/o1FZyjGaS nGMlGdOpFSSklUpTjVpTSadp06kIVKcl70JxjOLUopqk2r2bXNGcJWbV4VIShUg7bxnCUoTi9JQl KMk02j5R/wCGIv2ZRP4Fni+Huo2v/CvdN8N6RpNtY/Ef4p6fp/iKw8H+L7n4g+F4vinpdl42t9N+ NkmhePL/AFXxrp118Y7Xx3dW/ivW/EHiFZ/7W8Qa1d3/AFHxK/ZU+A3xft/EVt8Q/BE+vx+K/FNn 4x8QSJ4w8daNd6hrFn4Em+GP2Y32geJtLvbbw1qHgC71PwnrvgqzuLfwb4j0fXPEVt4g0HU/+Ek1 5tR+hqK0553T55XVWeIT5ndV6lWliKlZO9/a1K9CjWnU+OVWjSqSk504SRFuLvFuL9jDDXi7P6vS ovD06F1Z+xp4duhCl8EKLdKMVB8o1ESNEjjVUjjVURFAVURQFVVUYCqqgAADAAAFch8QfAHhH4p+ CvE3w78e6Omv+D/GGkXWh+INJa81DTnu9PvE2yC31PSLuw1fSr2FwlxYarpN/Y6rpl7Db3+m3tpe 28FxH2NFRKMZqUZpTjJNSjJKSkno1JO6aa0ad0+oofu+Xk9zk5eTk93k5bcvLa3Ly2XLa1rKx8jX v7DH7NOoeEU8G3nhPxtNZnxP4k8YX3iX/heXx4j+J+va54w0S28MeKn8WfGOL4mJ8WvGOmeIPC9h pXhfV/D3irxrrHh6+8M6H4f8PT6W+j+HtFsrDT8ZfsX/ALO/jyIw+IfC3i9FXUtTv7NvDnxl+Nfg qbR7LW/BPhr4ea74Q8PXPgv4h6BceG/hnr3hTwh4cs9e+E+gS6b8Mtb1HTI/Eeq+ErvxLPd6vP8A U1FN6+0vr7WFKnVvr7SnQVKNGnUv8cKMaFCNKErxpqjSUElThYj7jg4e66TrOm4+66bxLqSxDg1Z weIlWqus429q6tR1OZzlehpOlaboWl6boejWFppej6Np9npWk6ZYQR21jp2m6dbx2ljYWdtEqxW9 pZ2sMVvbwRqscUMaRooVQBzPxG+Hfg74teB/Enw4+IOj/wDCQeDPF2nNpPiHRv7Q1TSv7Q095Ypm t/7R0S+03VbTMsMbebY31tMNu0SBSwPa0VUpSlJzlKUpyk5ynJtylNvmcnJttyctXJu7et7kKlTV NUVTgqKh7JUlCKpqmo8qpqFuVQUfd5LcvLpa2h4VrX7NXwZ8QfFrS/jdqvhfU5/iFpNzo+oQ3EHj fx9YeEr/AFnw7p2p6R4c8S+Ifhnp/ii1+Gfinxd4c0zV76x8O+L/ABN4Q1bxPoNs1tFpOrWa6fp4 tdi3+BXwxspNbm0/RdW0uTxL8Wbf43+IW0nxp440r+2viTbafo+lDVtTGneJLVb3RrnTtA0m01Hw TOH8DarDaY1Pw3dme5M3rtFRGMYaQioL3tIpR+PE4PGz2t8eMy/AYuX82JwODru9XDUZwdSEK38W EaukV+8ip6Rw2LwUV7yekcHj8dhIrZYbG4ugrUsRWhPwf4Nfsz/Bb4AXfiC++FXhTUNAufEdjouj XTap418e+NI9I8MeGp9XufDXgfwZb+OfE/iS3+H3w78M3Gva1N4b+HPgSLw54F0CTVL1tI8PWRuJ M+8UUVcpSlbmlKVkormbdoraKu3ZLolouhcm5TnOTcp1Jc1Scnec5WUeacnrKXLGMbybdkleyQV8 y/EP9prQ/AP7RvwF/Zvfwf401TX/AI32vxB1X/hMB4V8Z2Pw88K6P4B8G6z4olSX4gSeE7j4fa14 v1a60uOxtvh9B4wsfF1vo8l94sl05tI05RefTVfO3xW+EXiLx38Z/wBmX4h6Xe6Lb6F8GfFHxP1n xXa6hc38OrX9n42+EvijwFpkfh+C2027s7q5t9X1u1ub9NRvtKii02O4mt5rq6SOzlyn7RRk6ajK Sp13GEnZTqfV6yoLnv7iWJdGc3aXPTjOkuRzVWnhXdRU/wB0pe0dbCK6UXy0njMOsS3GS95fVPbp WlFwm41byUHTn87/ALKfx+8OfEr4s69q9t8IdL+Hr/tR/DmH9pD4feNtM+KOsePL34r/AA88A3vh j4S2WueMPC2oeFvD2kfC/wASWvhnVPhrqFr4c8I6n4x0a90vxAJr/wAQf29Yaitx+iNfnV+yh+yh 8Tfg34v+G9x8QJPh3F4U/Zz/AGedY/Zl+DFx4I8VeKfEWueNvB2t+M/CWv3PjL4haV4h8D+FbLwR r0WjfDTwLp0XhnQtf+Idm+oXHiS+bxQkDWFof0VrolHDxw+DVB1HLkxsantYwhU9jDOMzp5TKpTp /uqVWrkMMprYijTUVRxNStSlSw9SE8PS0qOTx+aKN3g4YrDxy9uzbof2VlzxUea7lONLNXmNGnUb kp0qcJUqlag6VaoV8daT8cPBX7Q/x0/aU/ZCvPBnxL0jT/gv4D+DHiPxR4yvF+Kvwhk8VX3xR8Rf FGGPTvh9rKaT4F1vWPD3h4fCq0mb4k/DzxfrPhfxFe61qfhi2vkn8N61FdfYtfI9x8JPix4b/aO+ P3x+8FR/DzXG+IfwG/Z2+GXgjw54p8S+JPDw/wCEl+FHj34/eIfFVz4qv9J8F+JTpOh3Wi/FrRR4 fvNIt/EF/eapp+qWuo6XpNpHaX14UVTcqntbcqoVPZrVP6xz0nSlzJ2cYxVVODirzlTn7SKpyhV1 koPCY1u3t4wwboJpyclLNMBTxcIU1pKbwE8VJuSmo0oVeWm6zpVaPmH7MPhX4Eav8Zvif8SPhX+z v8ZfCT6L4y+PHgGP4teN/iDYa58JZvFNl8XJ9N+Nen/Bj4Y3nx88bX/wxh8dfE3wzf674mv/AA38 GPhrp3jXUPD0mq+ILm5vf7NS7/Qevze+Cn7Ini/wB+1Xqfxsl+GX7Lnwj8PwWvx/h1bxJ+z9B4k0 rx9+0ZefGX4j+G/Guga38cfDmqeCtHs9L1zwLbaLqM17qEvxJ+LUniXxh4i1fXdA/wCFd6NeXPhi f9IaiLX1PLY3acMDGEqTd/YyWIxF4qNqcaaq3+tKlHDYP2X1jknho1Y1KlRVuR43MZU+Z0qmPxNS i5+9U9hOSdBVaqTjXqwo8kKteNWvGrOMpKpC7w9Er4F8efFf4VXf7fnw+/Z5k+GviHXfiV43/ZZ+ L8nij4vaZ4t8R+HdK+H3w/8A+Eo8DXFl8OkttKnt4LzxZ8QL9L7xHaavpV5pXifwZpvhC3vU1GKH xLpqS/fVfnbffsYePPDn7W2g/tO+A/jJ4o8Q2Sx/tAeI/FPw2+Idz8ObHQbvxn8SfBvwz8JeB9F0 XWfC/wACH8eQ+BtIsvh3pdjqEms+ONW1zQrHRdCOjprMdzr1hqGDcViKU61Pmw9PC5q6j9nKq5yr 5XisvWG5aSeIisRQxuI5nRUo4hU3l2Jp1MJmFeI1FTpSgnF1J18E4RlJQUJYbGUcfSxKc3Gi54fF YLDOk6s4PD1p08fRkq2Dps8Wt9Z+B/hj9sLRntvgPqX/AAjnhT4+eCP2Z4vi5fftGfFTUrmf9pSD 9mS28SeFPFniD9njVnu/h340uLP4Sano/wALv+GhvFPijWvjZNrstrpFxodx4Z0q28Vxfr3X5a6x +xV8QfH/AO1d4B+OHjXwp8IfCeheHPiX4C+PXiDWfh38av2hZdV1/wCI3hT4Jz/DV/D2tfAvU7DS /gX4m1qx164iOnftKTR6B4/1T4W6J4f+G1/8NLCSyfxJL+pVdknP6tRjXqKeLjNKtKFR1adRrLsr jisQ3zOKnVzmOcKnGEYRWAp4BRli42x+Lyn7N4inLDRisJ/ZmDjTTpVKNSjUjjM09lg3Tq3nGGFy qWUqSjL2P1upjHTpYNueX4PwD9rHwV4c+JX7LH7S3w68YWX9o+EvH37P/wAZPBXinT/+EA+KfxX+ 3+HPFXw68R6Frdl/wq34F+I/B3xt+JX2rTL+6g/4QD4O+LvCvxT8Y7/+Ed+H3iPQ/Fuo6Rqdr/EF /wAOV/8AgnX/ANEb/wDOBf8AwdNf/TG6/u8+LPjX/hWvws+JfxF+2/D/AE7/AIQH4f8AjLxr/aHx Z8f/APCqPhZYf8Ir4c1LXftvxL+KX/COeMf+Fa/D+1+wef4y8f8A/CI+Kv8AhDvDial4i/4RzXP7 O/sy6/EH/h9R/wBVk/4IA/8Ai/T/APNyVgUfz9/DP9jX4dfsdeN/i/4+/YR+EfhTw5+03qugeCP2 eP2cviHpH7Hv7en7MXxT8J+O/iB4R+MXxr/aM1Twv8Av+Cn/AO0n8bfFT/EjQf2ffg94U8FfBH4h +C/Evge18YeK/wBoi/8ABNjpt/qljazar6j4BsvjZoOlW3h74RWX7fVxpGvP4R8UfD3w9oH/AAUQ +N/hTRPiBqnxq8I+LviD8EdS1yT4f/tR+FvDuma9+11Z/wDC2viX8fPHPgi10H4e3P7QvhfRf2T/ ANnnWLP9oK68Z/tIar9D/Hv9pbUf2gPG178bINP+Afxn+HsH7QPxGT4xxfsPftHaP+154V8KweC/ 2TP2ZfFfw88f/Ab4sXnwv+FV34n/AGmPhf448C+G/iT8H/DOmfCxNfuPi94Ws/hzpCaq2sf2tNzV 58TPjnpslxafFj9l7xlp0FvqPxfj+N0fwy+Jfw30rw14J0b4XDwrrH/BQe6+Cc2m3Oi+I7vwl8Pv 2otX+Dv7SH7Cmu6HD4n+Jfhv9uDxt8Vv2dri9+Fvhq+vl00A870bXf2jLu8sH8I6/wD8FLfF8V9f fs+N4DGtf8FJ/wBobTU+IWlfEXRvE837Ot14hvX/AGt5NJ8Fx/tFa5pHjnwt+0H4j1CzsPD3gHxR 4E8M/sj/AAz0XxV+1Xrd3+0xFJ+yH8Tf2oPCPwVvP26b/wDbo/bwPgP4rfHq9+DX7I/wy8ZL+2X+ 0k/i+wsfDMmjSan4x8M6b8Kf+Ch9loeueONai8N+GPh94G8Y+C5tSs/Gel/ErXrf4qeL9Y1HSLS3 9X8SfFP4r6Hea9a/Fv8AZz1hLWy0r4x6l8eIvBXjXwd4Q0TTp/h7pOj+Pv8AgpfF4W1H+0Gu9F8C 3NzrHwF/ad/Zw8ReDLm41T4e/wDBSe58bfCPW/Fvg+21nU9Rm7D/AIJsfAmPxv8A8EQ/+CW17png 74keMfHvgX4i/HXwpH+zdrM+qwWPjf4m+Pv2gvjRp3jj4lav4j0+yuY/hJ8SPhNZ2/ir4zfAz46e Lje6R8M7JVa30m98S+I/DGqaaAfOGif8Fnf+Clniafwxa+G7j4q+ILnxv4s8b+AvBlvonwo/aJ1W fxd46+GU+qWvxI8F+GIbD/g3uuJNf8WfD650TWrfxv4c0pbvWPCc+kapDr1nYSafdrD9Uap/wUx/ a8g/Yo+Nv7Ta/tH/AB903xf4D8O6f4c8LeHP+GU9V0/wh/wu/WviTa/Ce88N3vi79pD/AIJkfsge DviFpfwo15vEHiH4oeGPh54+HxCh0bwR4l0hdJ0LVlFxafcDfBLWfgtrN14m0X9nGXx9H8G9O1H9 l7RNQ+G3ww1Twd4o8c+NPF8l1bfD34k/sj6ZrWkappHwU+K+iXmnfDeL9pT9pLxXJp3wu8YXxudd HxUudN+BPhfSLT5r/wCCzPwG+Pnwg/YT/Zq+G/wc8Cfs8TaFon/BU79nHXl8C30c/h7wP8Rfgn4m 0Xx3FqXgj9pXVdY0nWf7SuJPGms6V4T+LvxRGtajrHxP+Huj3fjPX5o/E/iLWfCl2AeHfBv/AILE f8FENC8Haf4d+OGteGbz4j6Vp/8AaPjXW7/9jz4xnTPD97q/xgb4VT+EZtW8IW3hfSfGOvfBTxWB 8JfjhL4P8GadqFh8e9d+Fnwy8G+FPFcXxG1fxZ8Pe+0v/gtL+2hqttZIdP8ADOk6vqlw4i03Uf2Q /j250WC6+Luq/Cax07xFJaa9IkXjLR/E+l2Xwl8X+FdIbVhbfta+MPCv7O3hHV/GPhW38Z/H3wl8 vw+Mvit4zstC06z/AGdLrWtK+KsOieHPBXhP42fFPwNqOn/EHTvi58NPESfCqx+OepG+1W38SWnx V/Y1+G3xg8O/t1WVrfePtZuv2Wvh1+yn+25BYQfGC0vNLGfN8R/jl4vsjqulfs/a14hbxlpraToe nfFf4pfDbQ5pNO+Kvw11D4heE7z4/XvnfatFm+Mn7C/hCHU/+CgunPrfiaX4d6/8Kf2Ov2vvDXge D4p+MdYt7cA/Wr/gml+25/wVR/bq03xH8dLT4f8A7Mukfs7Wmvap4U0Dw38XdA+KfwZ+LGuSpBFr fhvxHZ3fhm6+Luj6c154T1vwxrvinQ7zStXstHudZtvCNn4ifxXonjW28P8A62f25+3N/wBEw/ZP /wDD7fF//wCh0r+TT/gjt8JviND+yH8BLqw/4J1ftr/Hr4P+J/AXxy+H3xKu/Dnx1/ZL8AvY2rfG H4ieI/2efHXwfj8eft8fB/4l+FPF+j/BfxX4a+F3xT8N+L/BXgKaSbQ/CXi7wzqn9p+Drub4i/e+ i/Bz9qfw94X/AGf7+4/4JX/tw+P/AIqfBnxleeB/HmpeJ/2m/wBgrw54S/aM/Z317X7DQtW8Y/EX RPC//BRg6D4c/aQ0vwVpXhz4m6XP4U8GjwpL8VfD/iP4faPrngn4X/FbX7/w4AfqX+zn+3F8XviF 8U7Dwl8bPg98Mvh/8OfiR8avjz+zv8Avid8P/i54h8b/APCyvi1+zbp/iG/+IekXXhfxN8L/AAFc 6TpGsJ8NPj6fBeq2mparNqNn8BfFWsXenW+jeJfC9/P+nNfxpfBf4bfEvwP4W/ZD+IPiP9iP9or4 +3/in9pD4ieBvhx8O9J+Nv7MNj4R0jw/qGsfGyf41/CW/wBC8aftffDmz8BftE/D/VPAXxe+NnhX xV4K0/x54evray8S/CnxX8aIbXx54p8Q6b9Wa38CP2jR4K+K/hPwv/wTG/b+s9V0P4p6V8W/2XPH OpftGfsA3Gv21lHfxeKda+APx9tLr/gpjqtj4o+E9/qp8Q/DlfE+nnWfGifCHxjZvYW2jfFT4a+H viDroB/UDRX5hf8ABHT4JftL/s8/8E+PgR8KP2t4fE1j8cfDWm6nH4r0jxl8StN+LnijS5ptQleb +2fH2ja74p0jVrnXdSGo+LY7DS/FHiOw8NWviK38L2utX8WjLMf09oAKKKKACiiigAooooAK+KP2 y/j58R/ganwTi+H8a2Vn49+IPiXR/H/i6T9mn4+ftTp4M8F+HPhV488aHVF+HP7PWsaD4ttptQ8T aD4b0Jdf1bU49AsYNTuYJYbjUrvTlH2vXivxp+DuofF7TdFtNI+M/wAZPgnqWiXOrSLr/wAHtY8G 213q1hrei3mh6jo/iHQPiP4G+JHgXXrAw3a3+nT6n4RuNY0HV7O01Lw/qul3AuWucq3tfZv2MYSq 3jyKrKcKXNzKzqypv2ipRdpVXCNWXs1LloYh2oVNKXJz/vJShBxmpyhGnKpyuEk1TVWnVp+1kvdp OUYJVHF+2w9vb0/y98Qfto/FW3vfFX7Qnhj4vWXjP4O+Cvjx4P8AgZYfDjw34O8F2/w0+JXhHxL+ yV4Y+NafFfTNcvbDV/inpXiXVfHXjawu9Ehi+KNx4Rs/AOmwaDeeFtT8QXNz4rk+lv2Ofir8Y9X+ JniD4ZfFn4mah8WG1X9lv9mH9pnTtc1bwv4E8L3HhfXvjZqPxd0Pxn4F0K38BeGPCtrP4C0m8+HO l3/g1fE0PiTxtYxalqlr4h8beJMWUtt0vhb/AIJ3fA3wZqvhmDw9rfxIsvhZ4WTw1e2fwCfWvDN3 8J73xd4Q+DFn+z/4f8eapJdeD5vibc+ILH4WabpmiHSoviTb+BLnVNOs/F134On8YRnXX9Y/Z/8A 2XfC/wCz9e+INXsPHfxK+Jev634V8AfDuz8Q/FC+8HX2r+Gvhf8ACuHX4/h58N9Fm8F+CfA9vdaB 4Ym8V+J79NZ8T23iLx3rmoa7e3finxhrrxWP2P0acsLTlmcb1K9KrTymOXzr0aUa0I4TKnhM29r7 J8lLEZjnls8ozpQlTjgJSy/2mDjTp4CXLUVWccM/dU44GtSqqnzUYU8ZU4gwuPwlVR9pVeKpYThq GL4fxE8RVVXEY+tDHypYmUVj6f0zR9P8/wA6KK43s9beatdeeqa+9NeRsfkDJ+1t+1l4f8L/ALY2 oeI9B8Fx+Ofhr+3p8HfgF8PtA8C/Dz4uftS+HfAnwZ8e+A/2Y9b1bxBN4T+FPg34R/F/4j61Z6F8 RvGXj7WLWPT7aPwx4g1GbRf+Eh1fwV4btb+5Z8Qvj/8AHzVZvgT8Svhv+0x4W17RfiP4g+D/AMO/ hd8IPh18Ho/B2sfHb4kw/HLXNH/aqX4p/DD4zeGPHXxf+E/hL4OfB/Skee30H4qeFPE/w98U6D8Q bv4mx+ZZ+HfDlx9xX/7LWhh/jRf+EPir8Zfhn4n+Nvxl8K/HHW/F/gLxD4Wsta8OeLvCfw/+G/w0 tdK8P2WueCtf8Lar4M1Xwz8MdGTX/CnxD8OeO9M1a81PW55kWJ9Ht9H8k+HP/BP7wj8JviFofxM8 A/Hb48aN4j03wrL4W1r7Xbfs++Irfxf/AG78VPGvxo+JOvapceJ/gFrWseGdb+MXxC8eatrPxNHw x1bwBomrLpvha00bRdAt/CmgJYdWHnRjDLo1Yr2uFnw5OvVcFONb6nwtlODzSlWptzhXp4nPMFmN TEVqlKUpTzWpmLw2Y1KVCjhLxkrvGzwvK41sLWp0MPOmoxp1qmcVcU6lKrD2VejKlg5YOjRh7aUq +FweIwX1vLKmLr47Fcx+31+0l8V/hHqX7Pngf4GX+mad4h8UftEfs0/8Lm1u/wBOsdX/AOEd+AXj f9oz4afCLXtJs7XUtO1Kwt/EvxO1Txr/AMI1oFzcR2t5b+H9J+IGu6BeW2t+GrS5g/SGviv4qfsD fs9fHOz0W5+M3hux+J/j/wAP/EXwT490r4zeL/BHwfv/AIv22l/Dn43/APC8/BXwsTxjF8M7Zl+F eg6q03giDw9HYpql14CvNTtdQ1+78V6xq3i6++1KzpunDLVQnaeNedZri6lZJuLwFfA5Hh8vo05z SqQpUZYLGOWGbdOGLq4vGU4w+vziFZwlWjKkmqUMLQoK94ylUp1MRUrVJwi3TlKpWrzdLEe7Wlgl g8NXgpYRNlfnj8Zfjr+0J4J/bD034b6bB8NNG+Ctx+xR+0/8YfDl5f8AilrjW/FHxZ+GHin4Bafp d18QLPWfA+g6d8PPCHhGz8c6pb2V5ovxO1+28T2/iHV9Q8U6d4ebw5ojy/odXzv8Wv2Yfhn8bPFy eLfH/wDb+oB/gP8AG/8AZ01Hw3a6haWfh3Wfh58f7v4eXXjv+0UTTX1pdbRPhrotnol/p+t2FtZW uoa19qsNQuZ7C403kqQlNySqTpxll/EFBOFm44nGcNZzgcrrJO16mFzfE5fiqM+aKoVqFPE3vRVu rA1MNTxEHi43o+2wUptU1VkqdLMMHXxCVOUoRn7XCUsRQnCUo89OrOEZ05yjVh8hf8E/v2jPiX8V vhr8avEPjjx543+Kf/CCab8M9Z0m++Jfwt0v4T/Ee013xP8AAbwj8QvGnhqX4f8Ah/4ffDO5uPBF r4m1Wf8A4V34jk8J3M/iXT7u/g03xZ4ystMtNZm9b/YT/aP8Y/tCfD0X/wAUvEugN8WLTwd8L/Ff jT4Z2X7M3x7/AGYNe+GsnxC8My6vHZ6h4Z/aF8Va/wCKvGmhXeq2WuaRoHjvRNP0fw5qF34Y1/To vtWp6bqNvp3XeAP2Q7DwCuq3kfx4+PviTxR4m1Hwr/wmvjnWtV+FukeLfGfg/wAD+BfEHgXwj8N9 Uu/AXwn8F6bo/hPQY/Ed94os9T8F6V4V+IT+MI7fVbvxzc2zXen3fV/Az9mvSfgpr/jLxne/E/4r /Gfx/wCN/D/gLwZqvj/4xaj4I1DxRD4G+GMfiI+CfCEEvgHwH8PNKu7HSdQ8Y+L9budc1zStY8Z6 7rPibU7zxF4o1ZU0+Kx9GdTDzxGaTUIwpV8PliwEYxSVCph1WeNhGNmoLEfWaEZ87qVk8vk3mFbm nLM/Ho0sRTwmX06lV1K9F4t4uTn7R13Ur0aeHlVrOlQlJ0cPQxddOjClh51Mfh4SwFNwtlP0jX5m f8FKPj/8RfgT4W+HU/gT4jeMvhnba5a/GrVdY134afDTQvi748uNR+H/AMHPFHjDwbp0ng3W/AXx MSy+HF14osbFfiN41TwraWvhqzGkW2peM/BdprbawP0zr5q+Pv7Mfh7496l4T8QTfEH4lfCzxb4Q 8P8AxC8GWfi74X3HgRNav/AfxVsNEsviB4J1KH4i+AviLoY0fxC/hjwxqDajpmj6Z4q0vUfD+nXG h+I9MVr6K88vFU61WjOnQm6VSSkoVFPkdOfJL2Uub2dVRgq3s/azdHEqnR9pV+pY9wWBxPqYSVCG IpzxMZSoQcpzpxgqjqqMXJUuSU6fMqrSptKth5PmtHFYSTWKo+Cfto/tFfF34UfsRat40+FNz4Uh /aa8cfCTUbj4cXSR2/iLwdoPjCx+Gep+PvGPj5YDHqmna54W+HnhrQ/Eni6xgvTPpHiW507QvDkt 0z+I7Uy/b/w61W/134feBdc1Wf7Vqms+DfDGq6ldeVDB9pv9R0SxvLyfyLaOG3h864mkk8qCGKGP dsijRAqj5s8efsL/ALP3xT+G+v8Awl+J3hix+IvgKXwefAnw00bx14T+GfiyX9n7w3J8NdJ+GNxb fBDVdd8BX2r+HL270/R4PENzq3iK+8W6rJ4mmkmF4uhwadoVj9O+CfB+g/D3wb4T8B+FrKHTfDXg rw3onhTw/YW9tZ2cFno3h7TbbSdMtorXTrWysLdIbO0hjENlZ2lpHt229tBEEjXvnOnLEZzOMbUc TjMDXy2Lpxi8PhowzNYrDuMZyjh+WVXBOVOMsQqlTnX1utSoYeNPzqUK0MHkFKpNSxGFwOYU82mp yn7fGVlkn1ao6sqdKeJUFhsfGM5wpqlKVWcKNN4urKp09FFFYHQfIX7UPi7xJ4Lb4D/Dv4b+Ibv4 Ya1+0b+0Vp3w11X4geE9A8Gal4i8OWafDb4l/FfxFrek2HjXw74o8IXPiHW7D4WN4aXUvEnhXxLB aprL3radNc2ttLB+fOgftL/tTtcfs1+M/EXxlvF0rxr+0RpH7Mem+EdO+FehP4D+J918O/j/APFv 4R/HX4gfHb4hH4UNpHwm8UeIvB/hrw3r3wV8O+Efix8PbLxZ8R7SXwno/hHxHJrMHhiv06+LX7PU HxZ1I6zffFz4r+D7/R9T8D+Jvh5P4Ql+GYj+EvjTwUvjKzu/G3gmDxb8NPFlteaz448O+NtS8J+N 7D4gReOPCl54ds9Pi0Pw54f1FtU1LU/gjwX8N/8Agn1fa5ZaL4N/bv8AD/iXQPhVc+B/il8VvhDp 37RH7OviTw14p8XfA7xPqHxb074y/F+CDw5eeOvCmsWHjbULf4j+NbzwT4q+GfgzVtQ0vSrjxFoE uhx3On3mmEnQpVsMq9vZ0c7y7MMW5TdVPI8HSwbxlKNKStTw8aGGxuHrYVKnQqVMTQqqtSlKeOyy MwpTxMXHCe1pRnw/jstlOi+WrUz/AB+IzN4PGU3yfx4SxuVOhP2tOrOWVY2krQr06eP9QT4wfty6 h8Q/jN4S+Gz/ALO/xu0z4T6z8PvBeqXmlfC3xd8KZNI8d61HZ/EXx3otzfeJv2nPGFj4kk8N/B26 8P6XpltYQ6CLr4n/ABQ8IPq+o6T4U8K+NXi+6PhDY+O9P+G3hKP4o6f4B0r4lXWmf2r490/4X2Go 6f4DtPF2tXE+r6/B4dTV7u91W9to9SvbhLjWtRmjvPEF6LrXZ7PTn1E6fa+b/su6H8F9O8BeKPEP wK+KmnfGnwh8S/i58V/inqfxE0rxr4Q+IGnap4v8c+NNT1bxHo+n+JfA9vb6DNpPgy5aPwVoWnKL nUtF0Hw9pmkaxqGpanZXV/cfSFJJ0qFKhUjev7DBSrzmpKdLFfVYyx1ChLlpOpg3jalZ4eeKp1MV 9Xp4aLqxUZQdTcamIxFSlUi6H1rGwo+yf7rEUIYiVHB4uVOXN9Wr1MJRpzq4bDypYejXr4mPspzb qBRRRUDCiiigAooooAKKKKACiiigD47/AGjfEvxH1b4r/s//AAD+HPxP8RfBiT4qW/xb8X+J/iN4 N0D4eeI/GFpoHwr8P6B9n8O+H7X4p+DfiF4Jspdc8SeN9Au9U1LU/ButTjQtF1PTdNOl6hqdvq9j 4hpv7ZnxS8E6x4Z+G/i7wT4F+LF54U1D4L/Br4sfGfwj8QLnwxpmtftAfF/wdea14QTwZ8PB4A1u C58C67qB8IQeIvEEnjHTLrwtd+Oo49H8K+JbHw/qMq/XXxv+Alh8aD4N1Wz+InxG+EHjz4e6hrd7 4N+Jnwql8C/8JbokHifQ7nw74n0g6f8AE3wJ8S/AeraRr2lXCJeWmveC9Ve1vrHS9X0mbTdX02yv ofDfBH/BPn4OfDrX/hnf+D/FnxW0rwj8NLL4UGL4WP4h8Naj4F8Z+KPgn4Y1Xwn8OfH/AI4utT8H Xnj/AFHxfo2nanBc3kmj+OtB8P69q2h+HtU17w/qV1pULtlCFaScHX9hCeY4F15+zp1assFGpVeO qYaU4VVh5UsBN4fCUFani82+r4jHU4YPD1Ktd1ZWoVnThCpiY5fjVg03ONGOOcX9SWKUZUXUg8W6 U8Q05yhl0cTGhXjipUMPL5Q8af8ABX3QfC/hHw34sj+FvgvSbbxJ8LPht4+tm+Knx/0n4TaXD4q8 QfCXxx8Z/iZ8Jm1nWPh7qsJ8c/D7wtoHgzSPD1jJbQSePPGPxF0zSdQtvAWk6NqfiE+i67/wUX8d w+Hvjh8QvD3wQ+E8Hwm+FHxN8E/DTRfiH8Vf2qLH4T2fiK48XfBnwB8ZBr/iLTLn4OeJrjw7ZSp8 Q9C+HvhTw94Nn+Knjzxj8QL/AEuytfCWn+HrvUPEej+pWn/BOT4R6BouuWHgL4j/ABs+G3iHXPjT 8W/jW3xB8IeIPAr+N9KvvjToD+EvGXgTRL3xT8OfE2jab8PoPCSaZ4d8MWcehN4p8LWXh/w/d6L4 stdZ0uDVK3fE/wCwL8MNftr7+y/iF8Y/But3Hx1T9oLTvFfh/XvBmqeINB8Yv8ALT9mjUtMsG8ee AfGmk6l4f1j4WQ3tnfv4p0nxD4oh13WNQ8R6V4n03VItKm0zWc5VHmlWNKlh3Xy7DVMpwsPaTpYH NauLyeri8NialStUq4nL8LhZ5nhKGL9qsRVdGvXnhJ1J5emRUadbAwcp1qFHEY+GYVJcjq4vB0cu x1LLqtFwjhYYfF4zMqOExGJXsHQo0sZTlGnCNHE4GHzh4a/4KnXfi3U/hP4p0j4BwQfs+/ELxf4Z +H3iP4max8W47Lx54J8V67+xjqP7ad9InwqtPhzqWk+IvC2i+D49I8EyayPijour3ni281SdPDEG g6VZ6nrf0z+xP+2hoP7ZHhzx1q+l6Z4G0q+8Eal4OFxF8Ovi3o/xo8OzaH8QfAuiePfDDXvirR/D /hmHSvGVhZatc6F448GSabdL4Z8SaRe21h4g8SaTPp+tXfxr4b/4Jb+J/Cvxv+EWm6X4/vrj9kn4 UazonjG68Ja98QdO1XxH8SPEuhfsgax+yDbt4t8A6d+z/wCHYdO1q78F6hpsmq+LNA+Olt4LvrTw /bGH4GWHjHVNV8czfpX8AfgHZfAHw9qHh+1+JnxW+KAu18PWNlqfxU1rw1qN3oHhzwj4d0/wt4X8 K6Bp/gzwj4H8NafpGkaVp6eZenQJvE2v6hcXWq+K/EGvajIlzH6GJeXyq4qeEjKOGq4bB/UYVfaK tSrwq1IZpLEJVJ2lOrGH9l05LkeWurUxcljPq7rc7jiI08lhKdOdell8o57UpRapVswliMVPCSwq qa8iwDwyzOpB06f9oKnDBYWnRljIYb3uiiivPNwooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAooooAKKKKACiiigAr8pPjl4t8cfDj9sO5+KWtzv43+Ddtqn7IfwX07wp4O/bJ+L3g 7xV8NPiD8VfiH448LReJ9d/ZN8F6Gvwy8f6Z4m1nx34Am1bUPiR4v06+1HwV4X1fUdO0jU7bwrBY ap9qftZfGLxj+z/+zh8ZvjN4A+GOtfF/xd8OPh54r8W6L4F0TUfB+lSajeaFod9qUd3qt7438aeA tIj8O6W1qNQ8QpaeIB4gl0eC7j8OaZq+stZ6dcfnv8U/jLA3xn8M/Hu6+Cv7M2tzfA6f9i7wd4z8 beKvhA/iD4+HUf2vPFtt4Kkf4Q/Fp/EFrcfDDQfhpa/ETTdcGl3WhePJfGtvrPifw+t54RkZtWvp pONXFYeHOqdOlmOVUMVPnjSqRhmVTEQoxo1LqvQlipYapgo5hS5IYGpX+szqVKWFxdFOtTn9XdNK c6uY4TM4YGlTUpuvXwH9n+1hKC5qU3RlmGFxEcNiKdaGK9n7L2SlUo1Vg/8ABPfTF0n4jfsz+I9M 0XS9J8V/G/8AYO8X/FH9qLUdHtreG/8AGXxti+L3wwOl+JviFc20jzat4vh1bxT8Y9HstS1qa81S K1ttW0OK6Wz0ZbW3/a2vyn/Yh+KVlr3xO0jW7f4T/s8+BbD9s34G65+1l4X1j4NfCWT4c+OptG8P +P8Aw/o/9kfHHxQ+v6wPi14uutI+LfhbXY/GC6T4L+y6zc+L7I+Hp47iG/b9WK66vP8AVMuU8NHD csc4Spwg6SpzfFGfyxGCVKbc4QybFyxGQ0XJ8lWhlVKvQUMNVoQjlV1zfP5O8aksxwbqULSSotcP 5JGlJc3XHYeNHNJw+OhUx88NXcsTRrzkV+Nnwg8K/DjwB/wUJ8OeNPAlzoU3hD4r/DX9tXUNa+MV p4ostX8d/GT4maX+0H8LG8b+EPjhbL4O8DHRPD/7NOqrqPwz+BTXF98R/sfhy+1HwzNrPg+awht/ G37J1+V/g/V/g945/wCChPx7+A2mfsqfs+r4C1n4FzeJfin8Y5/hd4Rl8a/Gz4ueH/H/AIIHibwj 4l1FdPWLxd4R8Dad4u8JT3t54jttauLn4gSajYQXen3Xg2+hu8cHOSzbBQpa16mC4i5VFKTlh4cP ZlPGe191ShhoUFKt7T2sYPH0svoyp1ZV4cmmJr/V8rxlSpb2CxuSRlGbSg8Ris2w2W4N0+ZTUsSq +PjGMfZVXHBSx9eHsKlGGKw/B/BfwX4C8Hf8FEPDPir4b/2TqPhj4ufDX9ta/wBV+LWleI7bXviD 8aPibpP7QPwtl8c+D/jZYweDPBEuj6B+zPqcepfDX4FtNefEg2Xhq81Lw3NrPg+XT4rfxt+xlfkN +zR8YNBuf2r11yL4P/szeEG/ao8S/theFtK8RfDT4WQ+Efj/AAah+x78WrX4d6q/xs+JMet6h/wt lPHv2fU/FJjHhvwNJ8O7+LSfDk58by3j+ILf9eaaclgMpoysvq+DxFNQXL+59pm2ZYqWF9xRhy4S piJ4Wk4U6cHQo0nCHK1KWmJlKeOzCc7SnLG1YzqJxbrVaUYUK1adk5+1qVqVR1XUnUUqvPOg6eEl h6FH4A/4KUeG9b139m61vdI+InjbwJD4c+Nv7N2s6xpvhBfBotPH2lr+0H8MbSfwb4vuPE3g/wAT avB4WvjcrcX6+C9T8H+ILtreOzl8QHSZ9Q069+R7PT9Ptv2s/AnxYSw0uH4y6r/wUs+Mfwd8YeMF W3/4S5/2fdD/AGNPiJ4h0r4e6xqpkbUrf4baemgeAPH1t4VubiPw5beJpNO8YRabHrGqfbLj7t/b o+LOtfCD4LabrulfA62+ONtrXxa+CPhHWdP1yHwLfeCfA+m+Kfi/4H0JviH4y0nxh4y8K6nqtp4T uNQh1bQLbwPYeK/FEPi210G9i0NLK2u9SsvmLwn8TPh78Vv29fiDo2jeGf2GtR1jSfEHjj9nf4ka BrWieCm/bU8QeANB+FWheJ9c8et4in8ZNruv/CR/Gd/p3wv1T4SXfwyvYZ9LiTxzceOYrGzHhh8s uc4ZhiZ0XCrNYDPG8PUqRpODg+C69XES5ozr1MK3h8DlNVUIOnGjnuYV6bawebU5GJlBYKCrxUac 8R7FVeT2im8Xk/E+ApUYRjKFOOOwjxmIz7Ce1ftZ4vI8tpKKnVy6pT8F1aFdV/4Kc6Z8UbLSdIu/ D1h+2L4U+ER+MCavbn4rWGqt/wAE+vEevSfs8aN4aTTDPefs16xN4g0j4u3/AIjXxnlvifc6jJ/w qu40yxg+Jdt+8NfnPHP4F8Jf8FGPhd8J9A/ZD+GXg9Lj9kz4neK9H/aY/wCEE+Etp4r1C0+Fvir4 HeA/Dvwo+GmueGPENx8RfD3g/wAH+HfiVqtr4l0bxd4P8OaFKtz4XsvAd7e6fYeIY6/Riul2/s/K 5QUnRnh66w9SajTnUjgMXXyTFVJ0VeVGVbM8pzDExpybcaVelGVTG1Y1M1zFYiVWpiVOtGEKlLA4 HDyhTXNBJqvmFDlrKnTjiPZ4XMcPhp1WqlSVbDVXN4ROGUZX8gf8FCZ/Hdt+wL+3Dc/C3xd/wr/4 m2/7IH7S0/w68e/8LF0f4P8A/CE+O4vgv41k8I+Lv+Ft+IvEXhDw/wDC7/hG/EC6frP/AAsXXfFn hfR/BP2L/hJtT8RaJZaZPqVt/lif8Jt/wXX/AOkuX/nxV+x5/wDTD6/1+qK5yD/MT/YF8a/tWatb fEj4X/tjft8fAbxB+0TrXxa/Z/8A2mv2HvjP8Vf+Cn37KX7Xmm2f7Rv7MaeOYP8AhVfxAfwD+0p8 W/EOkeGviJ8OfHes33g5vibqejfCxvix8OfhrYefba9eWUWo/rX8F/gX+3z8afBvw2+J3w+/Zt/4 KKa58Nr6/wDh1daLqt38Yv8Agmpr+m6roXwi1fxZ8bvA99aS+NP2rfBOofGHRvhv+31Ne/GHQviV 5Pg/SP23vgT4g0OL4mX5tfCvhHxJ4w/t6ubW2vYJbW8t4Lu1nQxz21zDHPBMhwSksMqvHIhIBKup BwOKmVVVQqgKqgKqqAFVQMAADgADgAcAcCgD+MLwn+yF/wAFQ4dI8L6f4m/ZG/b105f+Ee8D6f4q ttI+Nn/BLHxW9pqur+Jdc/aN+KmqW+qa5+1xoKeOdX8O/txzaX8bNN1jV9D8IaR+0j8Lbp/gb8av BPhPT/CPhzxRd4P7JP7Av/BVTRvhff8A7Knxs/4Jl/s7fG74TzfGvxB8cvh18Qv+CjHxO/Y68dW/ wY13xv4NF38VvDmnaX8PfCf7ccsvh3xV45NvYeAx4Q+Ffh3VNEstJmufEOpQ6V4nbSvC39rlFAH8 WH/DgX9vX/olv/BK7/w3n/BN7/6mdr3HU/8AgjP+27qP7Hv7QP7Jqfstf8ErdEufjt4JsNDv/jN8 N/jLa/s4+PW8XeE/G6eP/hv4m8cxfsif8Ec/2dNP8deH/B2rRR6HceCNOPgiLxD4On1bSbrXrTV9 c1XxFc/1vUUAfyf+Af8Agg5+15cfDzTdP+MPx4+D2s+OdT8OeKbD4jwQ/EX9qHxx4T+IGreLY/BH hvxAfH1zqGsfD+X4kaR4y+CHhGD9lf4mwa54X0ifxf8As8aL8P8ARfDx+H/jrwdL461z0iT/AIIX /tCStMl9+0P4V8TWkupeNdUu7Xxr8QP2nPEZ8US+OfH+la54r0/x9eP8QbS+8XaD8SPhTpWj/s9/ FzQZ7iz0vxH8MvAXwnPge2+GniDwXqeqeK/6eKKAPwc/4J+/8E3P2+v2Hn+KXgzRP2x/g5f/AAe8 ffEHX/iPYaN4k+EPjn4q+KdO1fWJJYA02par8SPh8I9fu9Mj0Sy8S+IrO9Xwzq9n4Z0WDSPhl4Z1 iTxB4o8Qfpn/AMK7/bJ/6Oh+Df8A4ilrP/0SdfWFFAH5v/s8fsE+JvhF8Vl+InxA+P8AJ8TfDPh3 4m/HX41/C/4PaB8KPD/w3+Hfw4+L37SMjXHxY8e6cZvEXjvxbealf3uvfFjUdBsofE2laVpt/wDH 34y3OrWfiF9b8Ljwf+kFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFABRRRQAUUV8SftY/Hz4o/DHxP8PvAHwkm+G+i+I/E/w8+PHxc1PxL8V/DXiXxR4Vbw 38BtC8KahqHguxs/DPjj4f3WneJ/F17420yWz8R3OsaraeHdA0HxJqj+EfEjQLBb418RSw1KdavL kpU6datVnyymqdDDUKuKxVaUYKU5Qw+FoV8RUjTjOrKFKUaNOrVcKc9sPh6uKrQw9CPPWqvlpU+a MXUqPSnSUpuMIyqzcacZVJQpRlJSq1KdNTqR+26/FL9oaG8N3+3/AKgiyHw74c/a3/4J3eL/AIkF VZ7WD4ReDp/2YPE/xavtYVVZW8N6Z8PNJ8R6n4pE+20/4Ruz1U3pNmJ0b6Q+In/BQjw/4Q+G37IH xBsrf4I+GrX9rbwSnj7Sb39oz9oiz/Z48G+FNF/4Vro3xCezPiy4+HPxCl8ReIn/ALf03SrXQ7XQ rBpYhfatLeQwWMkD95D+134j8YeNP2k/Bvwc+F3h34gTfspW3hjSvijqGsfFK58H22p/EbxJ8OtF +LJ8B+ABbfDjxWuvDTvAfiPw/fT+JPEE/hDTZ9X17TNJhhMKaxqWj74iFXLsbXrVlCnX4fxNSrja dem62HoVMlzLLMZifrsac4qeBp4ihhsHjLVIUqrxtPDRrxrV6MZ5ZXi6WMp4LE4SLxVDM6GGq4Rx 5qbxFHHcv1d0nODcKtWE3OlzR56ahUrOHJQquHbfstfEn4K/Fs/Hjx58CNLsZ/CGqfHHUbTU/ib4 e1uz8Q+B/jZ4t0b4d/DnSde+IXgXWNL1PU9F1HQ7BrO2+HGoXujvDZ3HirwD4h8yOW+S7up/quvw t/ah/wCCr/j7Rvgl8K/2iP2P/CPgbx58NvEfgL9nH4weNIfid4e8W3Gv/wDCvvjp4g1TxDd6L4dj 8KeLtEg074geHvg18Nfivqb6Zex+IYE8XXngNpoJtHkurfV/Z7X9vv44eIP2wv2ovgr8Nfg34X+L Hw0+Evw6+DEHwii0O58R6D408d/Gbxvq/hhviBL4y8cP/wAJL4W8LfBzwX4b+I/gq+vfEVr4FvNU 0aXRPG80765cJo+hy9CoVKlelgI0p0sXhK2KyCtg60n9Yw+L4ZyrL3i3Wp8sY4XDVqdbDvL4xUcK o16OGwtqEKbOaVaNClUxNecVRr0sLmtKuqU6NGvh89zR0MLClUqyaxGLw8sRCWZpTdeioV8Vi6dC aq0qf610Ui7iqlwFYgbgrFlDY5CsVQsAcgMUUkclVzgLXMbp3Seuqvqmnr3Ts0/JpNdQooooGFFF FABRRRQAUUUUAFfNX7VZI+Hfg8jgj9oP9mIj6j9oP4bkV7X468aeH/hz4L8V+P8AxXejTvDPgzw9 q/ifXb0qXNvpeiWM+oXjxxj5ppzDA6W8CZkuJ2jhiVpJFU/H/wCyD+0V8ef2i/2Tx8ZfEPws8AeG vjVL8Sfjt4Ob4Vat4w13wb4U0OH4XfH7x/8ADHTtH8SeNNP8P/FjUbbX9P8AC3hS2l8SappPhrV9 L1XxbDff2Xp2i6Ne266bdJunOGMV+XKsblOOq25k37LHLE0YRaTf714GrCdSCn9XXLUqxtKnGpni 8NLEYKtQb9nHM4YvKKVVpOMa+Ly/FXlK8oR5aVJSqNTqU1N8sFJJylD5A0b44/tKar/wgXh6b9oX xlBP468H+BfiPeeIrbwN8DBrWjvr/wAJf2tvGOoeE9Fhn+E1xoA8MvrPwc8FOkur6Hq/iiOCHVIE 8SqmokQZOg/ta/tE/ETxnD4QtPiNrXgmbXtf+Ceh63NpWgfA3UZfBFn4t8f/ALPuhRal4R0rUNM8 W+J7Gf4heGPHfjvUbi7+Lvhh9JadtIufhtb3mn6FrE8v0x8Ov29PF/jrX/gj8Opfg14KtPip+0Hq Hxy8S/DbTNF+Net658O9R+AfwF1HwzofiL433XjzUPgj4Z8QR2XivXfFugWngDwxZfDjUJPEOm63 o3iCbXdN0i6vLjTef8a/8FBtcfwl8WvDXgXwb4c0X9oz4M/HPxB8FvHXgvxFd6t458EaXJ4N+CX/ AA0zrXizTtZ0f/hANY1zwxrvwVNhJoOp3dl4ZuNN8Z6/p+jaxpcj2httR9D+1cLgq9TNa+VUq+Bw 2Dw2Z1cIqdN04YDL80wmCzDFVGsO06EMRjMHleZc9NrAYuli6eMh9apZhRp/P4rhrMsxpfUcJn2Z YCvWr5jgo4iLxrk6+JwWKqYWnTf1yEm6UsBj8wy+pQmvr9GrhKeBqSw1XL3X/R7whqLanpNxK/ir w94xe017xNpL6v4bt4rW0hbRvEGpaU2h6jFBrWuQHxN4bNodA8WTQ3GnxT+JNO1SaPw94ZRxoGnd TX4M/Dj/AIKkftCeMvCn/BMW31H4efCq2+Jf7R/jPx5oP7ZulaZonj+60r4d6b8L9TuPht4k/wCF LaYvii51mLVPEvxZ1PwxceCl8WXXjBbzwKmtMlnqWpvZXkf7N/B/xf408ffDjwx4z8f/AA6uPhN4 m8R211qk/wAPb/XV8Q6x4c0u41G8Phy38RXiaRokVn4nu/Do0vUfE3h+G1uYPC2vXeoeG4tY15NK XWr/AJsRhqlOWLb9nKGEzLFZXVqUnF0p4rBqCrSoSUYRq0JSlKNOrTi4SlSqreF37VHEUpewppzj Ur4KjmEaNVTjiKNDE4jGUYUsVTqSlWoYmlLCTVejVUJU41MPJxhHEUonpdFFFcp1BRRRQAUUUUAF FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAHg37UEnw+l/Z8+L+g/FD4o+D vgx4M8ceAPFHw51L4l+PdY0TRPDHhWf4h6Rd+DdN1C+u/EOt+HNKnlGoa1bJZaZPremPq160GnQX cM9zG4+GfE/wb+DPi34i/CbQ7D9sH4IQeD/jrYfsw+OJ/hTInhLVfHn7Q8v7K2q23jj4beLfgf4p tfixpr2/hfxBd6B4bm8bJaeBPixa6t4Y8OC18O6x4Xmvb/WX+gP29Piv8M/gt8LfAnjzx3onhPxF 4u0/4x+D7X4Dab4++I1r8KvAcXxxv9M8SWvhfXfHHjfU9T0/RdG8H+E9Ck8U+KvElxqlt4gli0jR rqbw34W8ReM4fDWl3H5IWHh/wn8O9I1H4J6F8W/h/wDFH4sfE/4nf8E1fF/wQ8Q+EdS0lovi9YeE v2m/+FkfGjxJ8F7O21LWX1P4ffDrX2+Mevatp2gat4ki+G/g+R18S30FtdRXF5GDSeI9sqftJy4h yLL/ANyo1pSeHpyxGHbpVOaMsZgJ5viMw+rzpRwtTDLDt1q9WpUq5JWI5+bL6MqkMPD+zM2xdHF1 6ssM8DLF4rDYXF4z2tKMalHL5xyjCUf7QWJp14YuliqWHhh44aq8y/TD9kH4M/DvwX8SL6y8OftJ /CX43S/s0/DW+/Zu8A+APhzpuh6b4q+B3w+1fxla69eeGvjFLpXxO8dy6545nl8BeE/DsWqN4Z+F 9stt4IvP+KTk1G91GeD9Hq/E/wD4J56nb658RP2adG0fXdF1vxX8Ev2D/F/wy/alstFvLO51PwX8 ctU+LvwxvLDwr8RbW2VLrR/Gc+teF/jLrMek61BZamY59W1gWv2XWI7m4/bCuupGUcJl7eJjiIuG aqLhUlWp/ueI87w9TE06s/3lSnm9ajVz6FSrzVJwzWMpVsTf61XyqaZtnsJRTqU8wwsa2IV/9pnP IsnrRbVoxTwVKrTyp+zjCEv7P5vY4eUpYekV8B6R+wboHw0+N2p/Hb4C/EHxN8P/ABLf/Df4m+D4 dA8d+JvjT8bPBNr4p+LPxf0D4u+L/GqeFPGPxytdHtIL/VNO1yI+FNCtdC06HUvEC61Z3toNLi0y 6+/K/LH4X6B+zTpP7W/7Wf7TFx4D+Dnwj0X9mi60z9n+T4j2ng3wl4HuL/x78RfD/gb4w/G/xt4o 8W2Gn6fPrlxrT+OPhR4Mtr3V7m5udP1TQfF6R3HmeJtSWXHD8yx1KpTco1MLgs0xEq1NOc6GGxGD lktZzo6QqYfFVM4w+WVZ1JNYermGHxEKc61Kk4LFQpVcDWpV2pUamKyxxozm6Ua2IwuOo5lQdOsp RcMRhPqNTMYwi4yr4bBYujKTpTq0qul8F/gX8Dh+3J8SfidF8cv2XviP8b/A0fxMNx4F+F/wx+Ef gf8AaK8J2XxT1Twtc3LftH+KPBXjDU/EvxDm8F6Jp+leCfh5qmq+APh1dWnhfVt/jObx34pvYvE8 n6eV+Qn7LGvfAj4q/teeKdR+EPir4W+EvCP7PWu/tZeC/C/wxsviZpXin42fE/4t/Ff4y6T4g/af +LvirwteeI9X8XeDfhzo/wASvCl9oPgzRtQiT+27zUNR8Qw6f4e8GWPw8tL/APXunFWwOVJLlj/Z 0OSHs1T5KTxOJdF2SlK1ai6eIUK1bEYmhGssNip0sTQq4XD7V+X6/mvK5NrM8VGo501Rqe0g4wmq tNP2dOrFx5KtOjCGGpVIypYWWJw0KWNxPyf+2bL8Ibz4MN4W+Mfx2+G/7Pmg+JfHPw3udL8afEzx F4Y8P6Reax4B8e+Hfigvh2wPinxP4Ts9Q1LWLHwTe2qw2+qm6sbR7rWBZ3sOnS2svy/a/AX4cT/t X6ppPgz9q34LQeKNL+LvjL9svR/2fIdG0PWvjdoPxd8bfASf4IS+MvEV5ZfGGx1jV/gzBoHjBfFX /CKj4Y6FqV/quq6TDL8TU0CS102ba/4KL/Ej4aeCW+EnhrUNR+FPhj45fFfTfi/8NPhP8R/jd8QN P8D/AAv+EXgvxR4Z0bTPjX8TfE1nrXiXQdM8azaH4fufD+m+HfBNjBeeJfFHiXWtJ0Cz1Lwj4X1T xl4t0f5b8M6x+z/4C/ay/Ze8D/CXx74L1bwj8IPE3xS1f4reE5ry9k+M+keJNF/Y+HhnTP2s/Gvi rUPH3iGz1H9mrXPhFpfhTwTp8eleB/Cnh7UfGvi3wN4j03xlqAtZvDdznl6pyr5hVlVWGUcDmNH6 xQrfvKlFUsJisxhXbnTlgcLhKmW5LiXmUHUvmHsMPh6eEll2YZthZxksRSpZfCjShXVapXrzo15c qhKdLFZZTnh0qNWOMr5jgMZneXzy5unNYSOKdWeI/tPAZZjv0QvtG8CJ+1x8ANd8a/tCfDFvjx4P /Zx+Lnw8Hwcik0Dw54x+JcfxK8Q/BrxTr3xM8MeDb3x3qXirR/Dmi3XwP1RU0a30zxZbrba3P9o8 VxHw3O+q/ZVfg94H+KmpXv7dnj2xvNV+Bvj/AEj4kftpfC3xv8I/AF5pXiG/+OWofCPU/wBhzwTb +H/2nvhh4vtfijBo0Pwg8M3CeOfDtwP+FT6t4Z1G7ufHdkvjKz8T6tHp4/eGuqbrSweAdVKHLScl h1SjR+pzzONPiXE4OVNQhy1sNjM/xFDEwh7WjQxVOvhIzw1bDYjKstmcoRrqhTnKrThg8LOlWnP2 3tqMKmKy+lWp4hVKv1jD4iGXLE4bEVpU8TXw9elXqUp0amHx+OKKKK5igooooAKKKKACiiigAooo oAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiig AooooAK+Q/2vv2X739qPwt4Z8Kx618IbLTdIv/EE2qaZ8aP2dfCn7RGgTx6/4bv/AA9Fr/hPTdf8 SeENQ8DfEjwuL6a58KeMdP1y/wBJghvdX07xJ4N8UWl7ajTfrpyArFiVAViWHUAAkkcHkDkcH6Gv xG+Afww8NaX8bfjd4W+Cvi29+GPhH4x/scaL49+HX7QXwe1fwX4q+JfxmuLn4m+MtS8W/Hj4st40 +Ddv4I0n4zWWs+MLTQPDaeIvAHxBh1nw5f63eDXxPo48P+HuHGzh7OrTqYf6zCODzHFypc6SqSy7 LMfmyozjKylGvTy2vFr95OMY1MQ8PVwuGxlXD9NCU6K+swrKhKOKy3BqcotqKzfM8Hk7qc6jPklS eYRqK8Y+0cfY0qscVVw1Or9meI/2VvjPB8OdG+E/wp+Pnw88BeAPCng/VPhB4S8O+I/2cLf4gQ6d 8E9Q+F3gzwFZ6DqOpD4teE9fvfiJ4e1nw1rHiDR/G2laz4f8FX2keJf+EY8X/CLxXc6BpHiaPwCH /gnl+0N4O1H9ou2+C/7Wfwz+Gfg741fB34f/AAr0PTZv2YfGviTxhp2o/DrRPBfgbRfH3xT8aW37 WXhmy+InilfhVoPiX4anV/hx4R+AXiafR9c8K6pq/ijWNd+G3h6/m888LzRXf/BI/wD4J+eD9TvL fVNH8aeFv+CaXg34j6drF3bMviX4aeMviH8CfC3jnTPEsEklvFqHh7xdpmpXPhvxPZ3UL6Xrmnaz f6JfWtxaajNaycJ8Dta8T6L+1T4J+Aa63q3w9/Yn0bx5+3Tpvgqy+Hni/XfAOgD4taB8XvAenfC3 4W6hr3gvVNFv/DXgvSdJuP2gYPhx4Bg1bSfCGq6z4T1fQLPSLqfwHo2nWnvY/BOWc57l9evTxE6u J4kyfG4zGJU8LmtLhrB4CvinmDqupGVfHQ4ldPJ4V/rFfFZ1UxkFWoYyccTW4ocmAweVVqNCph1l dTLPqNLD0I/8J/8AaVXH4jDwpVKLcZQoVuF6U81oJuhhsppYCtUVfAUlQpfXvgH/AIJz6T4Y+Cng X4S+IfHXhfUpvD/xQ+Gfj3xLL4N+Ft34J8AX/hj4XfDHTfhH4d+FHgPwBqfxJ8car4E8D6f4N0ix stJXWfH/AMQdXtbh9T1HV9Q8Qapq17fvs/sT/sC3P7IP/CLXmqfGrU/jF4g0f4WeJfh54j8S614O Tw5qvi/Utf8AivqXxEtvFN7KnizxD9lOj6JPpHge10ljfNJYaFa6i2rRmT+zofys+Lfjv4kfHL9m P9sL4X+Jdb1/xp8Jvg9o/wDwUH+Nfwk8XeJNVvdc8ReNPgB4H+DN/wCBfgDH4p1fXFGueIdL1P4p /EP4h678J/HOt3Gq3njvwd8EPDnjMeIfEMN/b6/qW9qf7Yf7Wur/AAW0zxrpHxt8W/Bbxn4f/Z4/ 4KN/GLxj8G7b4f8AwH1lvhj42/ZGX4G6b8Kvgh4lv/Evw/8AHN7rfh630bXLvxL4s8S6T4gttY8f p8QLnXPCnibQfC83ge08PYUI1KtWrmFOUljMwwlLiCpUnFfWKuHr8M4rK8SsfzPnpZjgsFg8yyjN cBy18Pg8ywsamJxUc3xeDlW7oZM8ZPKcppxjUdXNs14Zw9Gu6lOlhcdwxmdLO8HDC1pcyWCzCWPo ZlldScsJicVl1agvqc8lw1Wpg/6S6K+Ff2LvH/xT8S+IP2oPAvxQ+JGrfFRvhN8Wvh/ofhTxT4h8 O+BPDuvpoXjn9mv4IfFvUNGvoPh14V8F+Hbuz0rxV498Qw6HcvoQ1iPRWsbLWNV1q7tG1Gf7qqK9 CeHlThNxbqYbCYlcrbUYYzC0cXThK8Y/vIQrxhVUeaCqRmoTqQ5Zy44S54U6iTUatOnWpt2vKlWh GpRqWTdlUpShUUZWnFSUakITUoRKKKKxKCiiigAooooAKKKKAPOPix8J/BHxt8D6j8OfiJZ65feF NV1Dw7ql5b+HPGnjX4fax9v8KeItK8V6FcWniv4e+IfC3izTjZ69oum3kken63aw38Vu9hqMd3p1 zdWk/wAgfDn9izx/8HfgP8SvgD8Mv2hLnStA+INv+13qtt4p8WeE/G/xF8ceGPiF+0f8S/EHjrwL 4tsfE3jD426hqV7p/wAItM8Uaxo+teH7ucXfxU8QNbeOZ/EngnU5NZsdaZ8YNC1rT/8AgoP+yv4z k+JHjCTw9cfAf9qzTYfhlfyeC7L4baLqemL8Gr2TxtDc23g+18bv4ju7ec6beXGv+N9Y8O6dpcch 0fw/pVzdald3vlX/AAT88beLfCWnXPwo+M2rWfiD4qf8M9fBH4zaj8XtN/bQ+Kn7VXw1+J1j8QJv Hui2niHQ774o6T4c0P4YXOsa74S1rV7XRfhzpepeDdb8OXmlz6T4l1qDQfJscVOE8FmClCMqVTC4 pYvBuKm8Wp/2thZUZwnFYeu54DKa2M/iTrUU8HUpU3XwlSrgu2E8RRp0K1OpFrBZlluPw7nCE40c TGpSwtLFwU41JRhSxWaUsvr05044bEzxKpYhVMPKjKp6t4//AGL/AB5c/ED9i3xP8E/i18NPhN4d /ZG0a28HNYa38CPEHjzxv4n+Hc9h4Y8PeLPAfg/xlovx4+GvhzwLoPjrwl4btdI8QWnjD4b/ABis rXV9O8J+L/DdjoXiPwnaXl55v8Ef+Cdvj/wZcfHHxF8Z/j74G+KXj74xaP8AG2x/4SzwJ8BNd+E0 aeIPjlo3gzw54h+IPjvSvEXx9+MkvjXxtpfhn4eeDfBuhHw9q3w48G6F4H0ODw14a8G6BFc393d/ Ckfxc/aM+Ff7POl/C+bXNY1L4t6tp37CPxG+M/x5+G37ZXxi/azsPFP7NPxY+MOpeHfjv8Sfhjce PND0JPhX4gt/AfhL4ieKinwe0i/0ex+Hkk/jPwp4uvZ/AkFxpH0B8bfiR480j9oz4h/AL4GePvF/ iv4P/Gn9nHwB8Nr7U9W+IXij4jx/D/8AaH+MPxM0Twf4X1b4ceLfGWq+Ir6bVrP9nbX/ABp8YviF 4T0fxLcWWi+HPBngXxtdaHptz45j1bxN218PWxtTEYWpOlia+bYriXIakq1acPrFbMcFRzLNaWJx EoPFYPKM5zJQyrK68qcefiejPCYfBYHHUZyjyxVPK3D2c50sPkseHMyhPDQc1hsHhMVSy7K8bh4y lDD1K2By7Np5rmtOdeFOXD9eGLzHE4qjiKcD1v4af8EvLf4dfF2/+KK/HLUNatD44/Zp8ZeHPB9z 4CS20zwiPgb4OvdE8d6bo12PGly8bfGvxXcweN9ZvTaovh28soLD7F4ibOpD9YK/mC+D3x8+Nvw6 0T9q/wCDnw48Y61+zxoXwt/a8l8IfBmy0rwl8LPEg+I3g/44/wDBVLU/hL8TfipoV5408OeNYIl+ GeiXM3wj0vwhcaTYR6DqOu3fjDxFp2tx+IfhxeaJ95fslfG79ovVP2jfBXgf4j/HbxL8VfCHiu9/ 4KLeDbnRfE/gj4O6B9jf9kH9pb4bfCX4beK7XUfhv8N/A2qHxRr/AIX8R6zJ48S4vJfCWp6nNbXP hzwn4VjtRBLvTpVMXSoOhO+Exn1/MKDq040EqmDyPLa2JTo0nVjRm8BhMvw/1enJxpYyNSni4YbH xzNU7qZPPA1MxkqVP2mV5tLhKvKE6ntak8sjmeYYepNYiNKpOE8NHMcWsVWTr4iEVKFXF4arllfF fsXRRRXCYhRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAHgP 7TXxR8QfCf4QeI9Z8C2en6t8U/EHk+CfhBoWptL/AGfrHxO8UCWw8LjVFt4p7n/hHtDl8/xX4wnt 4JpNO8G+H/EGqMnlWMjD8ivhT+2N+054n+CXwZ+OfiH4vXlxceBPAf8AwS/svid4MsvAvwxtfDnx s8Ufthav4F0T4xeLPFNx/wAIe/iPw7c2Fj8QbDVPh/pfwz174e6LomvaPdf27pvibRb+PSbT9bf2 lNG/ZY1fwNp3/DW9p8BZvh/Z+IY5dAvf2hIPh1J4W0nxnd6NrWmWd9oFz8TIpdEsPFraFe+ILSxu bLZqp0y51eCItZzXsb/mv8Pvhd/wTq8C3P7Nfws+F37Rvi/WfhzpHh39mjw5pPhj4aJ4Z8ffs/fF rU/gv4y13TP2cPEfxq+K3w/+DmueCPBPjXUvit4b1RNCXRfid8GrX4ufEDwzH4cvdD8Xvpq6ANcD 8WIg/wB5iK+fcLLCtUliYU8Hg6ec1cywf1eXM5YnHRxVNPDRi45lbLlVhSjl31yjdedCFKhOpG9G jgsxr4ynKpLCVa8J1aFOTpYqDXs8PTVDDKGMlOhVy2q8w9lVmsb7Cfsf7Gf7Q3xe+I3jf4I3vj74 gap408O/tWfsn+Jv2otH8Lan4a8BaHZfB2/0P4gfDvTrXwV4PvvCHhnQtc1bw3P4Y+LukWF1J491 jxv4gbVPCR1KHxDDDq1zYj9S6/OX9kHw/wDsx6d8UPFVt8Ifi58UviPrngXwPfeCPAXhr4jeF5vD /hP4bfBxviFqjapoXwD16X4R/DlPif8ADceNtCs9DvvHEXi34wvb/wDCKeFdEk8aQ28NlBe/o1Tl OjPC4F0aTpp08fU5nUdb2lGvnea4jLovENL6zUweU1svy3EV1zKpicFXtVxCSxNbGpf+0s4lF8tC WNw6w+Hb97Cxp5TllLE05U7J0Y1sfTxmNo05RhP6vi6VSdKhKo6FL41/ad+KPxv+HvxS/Y80P4eW XgmD4ZfFH9oa08A/GLxDq3iC8HjaPRrn4b/EfxDpHh3wl4Nk8AazomoWms614csJ9c8T3Hj7wpq2 g2lgLXStL1o6rcS2Hk3wp8dftEWn7aGp/Czxp8ZrH4o6Zc+Gvjh48+JXw08KeHPBrfDz9nXwdP8A EXw1Yfskada+MLD4e+FPiHD8R/iH8OT4k1Hxr4b8f+LPG8WrazpXinW/CCaP4T0fRZ9U+n/jtpvw o1LXf2eG+JvivUfDOq6Z8ftB1X4S2WnOoPi74pQeBPiHbad4Xv4jousSTaZL4WvPFur3Qik0YxNo 8NxJrVtBFLbXnx98DPD3wSsPiz8d/gn8Iv2xf2if+E88Z+N/jL8SvFui3HgH4UaZYP4zPxB0KT4k 6l4A+L2s/sq6ZB8U774Ralr/AIa+FWoabH8Sfie/w08OTeH/AAL4ntbS70nR/wCz8svbdWrTklWq RxGfVIJJ4iU8OskyNKjOnecaKy+dbEZg6kMPKeDhHDVJfV3m1fMDfHOSpUp0oKMHhMijUUqfskq3 9rcWKriIVeanKp9cpRwuEjCVaEMZXw1S869PIo5ZWj+AXx++Mvi341fDbXfE/wARb/Xfh98fPH37 bHgKx+FNz4V8C6foPwzT9mf4p6p4O8A6t4R8Q6L4d07x5e3mveG/CGsz+PY/HHizxrZ6n4g123u/ C9r4P0zTRpU36k1+bvwK0D9l2x/al8Tad4E+MfxV8WeNPCt58fdR8F/CvxXoN3Y/BrwLrnjX4haH rX7S118FvHEnwn8MW/xM1qz+IuoWNh4+0/8A4W58WH+EWpa1qPg7TtP8BWl9e6HX6RU96GDnFWpV cP7SgnG79i69ZQ5sT7zx0lytSxTqVrtexVWaoq2c4zjicbCrLmqQxldTtSWHjFuSlGEcKn/snJBx jLDOFP2VRTjFVIcter8Hf8FAPGXxh+Gnwc1b4ofDr4o+KfhX4W+HPhL4ieLPGGp/Dj4Y2fxc+I2v +I7Hww8fwx8NWvhLV/hP8VtFt/h7deJp59Q+JviS5tvCdzoOkabYTjxl4d0eXXNWsvjPwF+3R8R2 /at+Cnw+8b/GXw7deKPi9+0LrPwJ1z9lnSrb4byad4R+HFj+yVrHxy8P/tAeGNSs9E/4WxrNp4p8 beF1tLHxfeeNtZ+FereGvF6eH9I8Pw+JdGOrj7r/AGwvDnwS1C18D6z8Xv2rNQ/ZOneDx14C0XxN ZfEr4PeAE8d6H480O1/4TTwDNb/G3wt4y8L6w11p/h+w1qC90DR7Lx14dOjyXugeItIs7jWY77x7 QfA37H9l8bfBPgXQ/wBtRbrxf4TN7pnwH/Zjl+PHwU8QN8KfG8XwPu/h0fEnwl8HaroOp/Fs+JdG +EEPiW/sPCms+JPFPgDSLbV/Fni638BQzXl3qEay1qli8dVrwnjITwk6WHwUHCpbEUm8TWqRc7fV 6lTCrD4alUtVgp4mblh8v+rRzjHGMSqU8DCHLSVOjmssTiHOrRaqYjCyw2WTn7Nv6zRy7Gv+1K8G qL9lhlQdXMKWIq5ZS3PiJ+0b8VX/AG/v2dvgd4Bv9Jtfgah+Jnhv453T6fYX+q+JfinP8HNY+J3g bwTpeoXFrcXGhw+A/DekWHi/xabCayvNSfx/4HtBcvY2+tWU/wCi9fBeofs0/seWH7UvwA1/VdD8 Jj9rbwzoPxF+L+h+MYvh94AsfiV8YbTw34N8KfBDx38Q/iv4w0D4dWB1fVNMg+I3hAW8kGqeFJpN avLNtC0+fQ9EvtL0/wC9KtwUMPhbPnvCu3iIxm6WJnHGYmnXqUKtRQnVo0sXDE4OkpUqc6FPCxw1 ZPEUaxz0vbutiqlaEqUKs8PPD0JOPNQpLBYWnySjB1IqdWUJYqq41qsJ4jEVpUZLD+xQUUUVmdAU UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFeYeB/gl8GPhjf8Ai/Vfhr8Ivhh8PdU+IN/Jqnj3UvA/gHwp4Tv/ ABvqc1zqF7LqPi+80DSdPuPEt/Learql3JeazJe3D3OpahO0hlvLh5PT6KTSfMmk1KEqcrpPmpzc XOnLvCThByg7xk4xbTcVYu7JX0U41EuiqQUlCaXScFOajJe9FSkk1zO/k8/wF+BlzokPhq5+DHwn uPDlv8O0+ENvoE/w68Hy6JB8J43tZU+F8OlSaO1jF8O0ksbKRPBSQL4aV7O1caYGt4SnEXH7HP7I l3rfwy8TXf7K/wCzhdeJPgpp0mj/AAa8QXHwP+GU2t/CTSJZ7i6l0v4ZarJ4Ya/8BadJdXl3cyWP hW40q2ee6uJmiMk8rN9H0U5e/JSl70lUlWUpayVWU8RUlVTd2qkqmMxc5TT5nPFYiTblXquQ9VUT 1VWPLVT2qR5KFPlqfzx9nhcNC0rrkw1CNuWjTUfnv4afskfspfBjwZ4y+HHwe/Zk/Z7+E/w9+I0V /B8QvAfw0+C/w48CeDPHcGq6c2j6nD4y8L+F/DelaH4oi1HSHfSr+PW7G+S805msbhZLZjEeru/g H8Cr++8R6nffBb4S3upeMdK8Q6F4u1C7+HPg+5vvFOieLfD3hbwj4r0bxHdzaM8+uaV4m8KeBvBX hjxDp2pyXVprXh7wf4W0XUobnTfD+k21p6zRVupUbcnUm5OksO5Ocm3QjCNONFu9/ZRhGMFT+BQj GKjZJK4VKlNxlCc4ShUnVhKEpRcatTk9pVi0041J+zp881aUuSHM3yxtzuieEPCfhm817UPDfhfw 74fv/FN9Yan4nvtE0XTdKvPEepaXoel+GNM1DXrmwtrebV77TvDWh6J4esLvUHuJ7PQ9H0vSbeSO w0+0t4eiooqW3JpybbSjFNttqMYqMYq/SMUoxWyiklZJEbJJaJJRS6KMUoxil0UUkklokklogooo pAFFFFABRRRQAUUUUAYl54a8Oajrej+JdQ8P6JfeI/D1rq9joHiC80qwutb0Ox8QLYrr1no+qzwP f6Za62umaaur29lPBDqS6fYi9SYWlv5fzB4q+Hv7MX7PenaJF4T/AGX/AIdza38Rvi3our+HPA/w o+FHwl0LXvGXxg0nTtd8UWPjXzNXfwT4Wi8V+FtC0bxJ4jHjbxF4i0zUNMtrG8Gn6o+qXdpZXn11 Xhvxq8C+NPE9x8LfFvw8TwxfeLfhT8Q38aWOgeMtZ1Xw14e8SWOqeB/Gfw/1jSrvxJovhvxjqOhX EOmeNLjWNOvYfC2tpNfaVBptxawQX8moWVU1TVWm5NwXtKT5opXThiKeIp3kk3CCxFOnVlUWtGUV iIuNSnGSxxTqPC4mNNKcnh8Qo05LnUnLD1abSpu8aspU6lSmqMrQrKboTlGnVmz5RvPA/wDwTD8W fATxXd+NPgB+yJbfCXxLeL8T/iX8K/iF8HvgYlvdeOPD0fjNhqPj74falpN3ourfEXRrrwf8QLGx 1O8i1S+muvDnihtD1a8tLK9uq7jwJ4P/AOCbnhbxpc/tG+AvA37FvgX4pj4YeF9c1n4xaF4U+Bvh L4oaX8JLvQ9A0TwpP4i8d6dY2PirTPA0egWPhnQNI/tLV4vD8Onafo2j2RFtZ2NvH4TP+xR8c4L+ xt7HVfhReaV4isf7e8eateeJvF9hqek+N7nS/wBqK41LSvCmhQfD7ULTXfDM/ib9oazFrruq+IPD mpWujeHbt38N3F5eQQQx2X7Efx1v/EnivV/E3iXwAdL17QNFFjoUHiu91rS9M1qfR/2btG8VaQqy fBXw54hutHeL4GXE9tq+reLNYtdUSbw7a2/gPwhJbapf3Xq0cPglisw5MVHB01BSwtanUT9qo4ar g6mFkov2k17OEaFOpOcYPBYWNFc8Mbhpr5l5nnyw+TuplcsViKtDEUs0hKjNfV6lTFRr0qyqylCl 7KvBUq2IoUoVJwxmOnUnFSyzF0D75tfgx+zt4tttC8U2Xwo+C3iaznuNS8YeGfEVr4F8Da1bTXXj Xxp4f+LWseKdC1eLSrmKS48W/EPw54W+Jmpa3p9wZNe8aaD4f8Z3V1d65penalB2Gk/DD4aaBq9n 4g0L4eeBtF17Trjxxd6frek+EtA07V7G7+J2u2Xij4k3NnqVnp8N5bXHxC8Tadp/iLxxNBMknizX bCy1fXm1DULWC4j1vDmmf2WmtL/wjvhzw59u8Ravqezw5P56az9tmWT/AISLWj/YWheV4i1fHnav Bs1XyplUf27qf+tXo68xzaUFTlONNQcqcHO/so4iCdWmnFRV5KThVfJSlUs/a0qcuanH6yNWvKMl WqOc3WqzqyXtIwq14yrUpYnknKbU6sZ1Hzc9b3a04wxFenP2tQooorMAooooAKKKKACiiigAoooo AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigD5s/a88TfE3wv+zz8QpvgzpHiPV/in4ji 8PfD7wNJ4W8Paj4o1Pw1r3xM8VaH8Prfx9PpWmW9zN/Ynw4j8Sy+PfEWoXKR6XpOg+HNR1PVrm10 20uriP8AN/4ufAvXvBfjDxf+z18Ovh18SZtM+I/j7/gnDqnwk8TaJ4B8aa/8PdD8Gfs1/Ffwt4h+ J8vjP4o6Vpd/4R8C6v4Y8PeA9U8SSQePdf8ADep+MtT8S6dB4UHiTX9VvYI/uX9tqbxjH4L+FUek Q/GCT4cXXxw8JW3x+l+AY+Kx+Llr8JG0Dxc6TeFP+FFq3xiW3f4lx/Dm28WS/DwprkHgu48RT3Ei aJHqzV+OnwQ/aK+OXxH+Fmp/HbxB4/8Ajjp3in4BfHn9kz4L/Dvw7rXjD4g+FrHxT4C8bftk6x8G fF9/8XPhrLc6TpHxC8bePPhhqVjout6n8TPDfiPXvDmuaFb634ck8P8Aicane3E4dQlUpTqXjTjx Fk9Cu4tt1I0vqdbLnUjTSnGjSzDGT55xlOvWwtXNI4WNLE4bDutVScqWLyuhQvLMMRgcdjMsmuR0 IYqpiZYWeHrOSUPbRpZesRUp1n7PDqtldSTlRx9eEftz9hPwH4+0zxz+znpHiDwf8SvDk37LP7FP ij9nX4qax47+H3jbwVo3iL4qa38RvhXPanwN4g8VaTp2jfFDSBYfCbxHr8vi7wPqXijw5HZeJNCL 60t9q0tsv6+1+Qf7C/j74g6v49/Zz1vxF4y+JHiGT9qf9inxZ+0Z8UND8b+PPGPi/QvDnxO0v4lf Coaavgfw94m1O/0j4Z6RFpXxa8QeGz4W8E6f4Y8PXGneHNDafRpdR0yS7P6+V3Yj6z9WwH1nk575 7zKPs7rFf638R/2uv3P7r2H9uf2p9Q5Nf7M+pe2/2j2xjVt/bHEHNf2/9oYD6xbl5P8Akm8h+p8n L9v+zPqP1u37v6/9b+r/AOy+wPhv9rX4O6P42+K/7EXxKtPhZpni7xx8LP2oNMu7fx/b+B7XX/Ff w58D618K/itpvii5h8VR6Xd6v4Q8Katfz6FYa/Ml/p+kX93NpNrqLSzSWcZ+E/2fNF8e/Df9rTxZ 8T/F/wAO/j3LonhXUP267rxR4Gi+AXjy68A/CVfi9+0X8NNf8Eav+z34v0bwRHf/AB01P9oPRfD0 PxK+Itro3ib4uDwpqba0NPg+D+m2N94L1D6O/bqtPFU3xK+GWmfDz4x/Fi3+NvjfTNH8Ofs+fA74 X+K/G/hLSNN8Q6L8RvD/AIg+KH7RHxlg8KeNdE8NeM/hD4H8F/2RoviXSPit4e1bwlAlz/wifh+P WPG3xO0bw/eQ/AnTPGqftseNbTwv8aviv8Z/D/hKD48S/tLeJNc8U+ND8EvDvjPx9478HeI/2dfg L8Ofh3rPi/xL8P8Aw947+C3wvTVNL8a6n8MdN8P3E+nS6frXxLiPijx/Zadp3NlfNSnTqxbputU4 uqxg7t0aU8sy/LK9m28KsLi/qaqyrpXp5lj8LgIYj+1auKy+PRjqspQlD2ih7GlwzQpuTlCGLlGt xNi414qHLiXPCQzjF5a6XPSnXVKVX6vXyOniMccZ+zX4L8eWfxw+EfgTVPAnxO0a9+AfxJ/4KB+N viF4v8S/D7xf4f8Ah/qejfHf41674g+E8Hg/4jatptv4M+I9z4w8PeLLTxO9l4H1/wATXPhaLQL6 x8c2/hfX4rPTJf17r8hv2cPGvxB1D45/CDx7q/jv4mard/Hv4lf8FA/Bnj7wZr/jvxZrXw903QPg X8ZdZ8N/CSfwl8OtV1C58H/D658I+HPB9l4efUfBOh+GrnxX/wAJFqWpeNrjxJrl1a38X680n8FL nt9Z5JfXOW/J9a9rV9ooX05FH2ajy6WXvXnzt4R9l7XFfV3fD/W8R7Fv23M4c75nL2/7yzq+0dFz SqvD+x+sJYn2yPzn/b0tdb0/VPhJ4+8La7+1X4U8Z+CdB+Nv/CB+Iv2aPgR4V+Plm/jXX/B+lWeh +GfiRoOs/Cv4z614d0zxI1tcRaL4ksPB2ieH45rPUtN8UfEnweNQ0mz8Ra3w3m+LXjL4+an8Svjp 4C1/RbH9nn9mn4Z2mgWGleG9f1HRtb+OfxV0LVfFP7Q2q/D6GCC6Txtd+E9H0DwV8PPDVz4bj1TU bGTXfHHhy2upLjX7+ybtv23df8d+Ffhbpup/DL4wfEP4X/EbxD4r8O/C34aab4F0b4Qa1a+MPiV8 U9d0rwn4OHiuD4q/Cb4oyJ4b8I3dzc+LPED+Gl0O7i8K6Z4kubua8NtZi1+aPCHhv4kaX+274R8M eHv2jPjH8dfFvhHWb7xT+1Bf6prevaH8GPh78GtR+AMXhD4dfCfVfhhoXiGL4HWnxt8d/F6z0X45 Wmq+D/h/4e8b23hufxTPqa+HvBGreGtP8STgoubxipzp0pOWKhh8TiISrxhjMNl2IlicLhqVFzvW ll+e0sVmEcZUw2Gjg6eWVsJ7PMoRWPMW4xeEbVSUIYadTGUcO4UpzoVcxwlTB18ZVrKM4Rr4zJ3l OVVMBCvOricTmGCzCosvr1/qnq03wz0XVP8Agoh8Af2kfCvwguNFfxn+xb+0F4e+IHxTm+F914X8 TXEl58Rf2Udb+GPgX4o+IrvQrDXLHXrHS7fxrP4Z8EeM7uHVtJFh4wj0/S7d7HXFi/Q2vy48Uab4 0f8Ab78Mad4E+NXxX8eeLG8e6X8Q/il4G0vxT410f4Gfs+/sqxfA7WvB2mfD3xr4Ei8X3/ws8S/E X4rfG6A+P/BniG58I6d8WLq1udSkhurfwJ8PTPqv6j1u5xlgMsp04qnQw1PMKdCHM5yUMZnOY51W i6ihCFR4TGZtisrrVKUI0p43LsZ7F1qCpYrE61W1iHCdSlXrfU8vlXrUYyhH2scLDCRpVadS9SlW +r4TD4qnSlKoll2Ly+pGp+8lRolFFFYEhRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRRQAUUUUAFFFFAHh37SXxx8M/s4/BPx58YfFWoaJp1l4X060t9KPiLWtP8O6NqXi/x Jqlj4X8DaDf67q1zZ6ZpEHiHxjrOh6K+pahd21lYLfG7u54beGWRfzv/AGIPEXjX45/8E5vENh4i /a0ufGnj68+On7THw81/9orwt4wttQ1TVRp37W3xC0Wz0bwF4ht/HOjDwhJ4l8FnSvB/wk/svxnp j+B9H13wbc+GLjyNN0iOX9BdZ/aY+Dui/tFeB/2VJfFmm33xx8d+AvGfxOs/BGmalot5rGg+BfBF z4esb7xJ4q0kaqmuaLpWr6j4lsdO8N3r6TNa6zeW2qRQzINOuWX5a+HfhT9iv46+PP2l/wBmnwd4 W8cXbfs+a/q+kfFi2t/iD8UtD8EP45/ab8bf8NKeK9S8J3mlfEaCW68faF8SNGh8S2njywsNM8Rf B7xM934a+F3iXw5HH4i0i1dNwnh8XTknUjjKLrU6kUmqeGy3E1MHWqU1UVSnOl/add5fjqsUqMas qFOvTr1MEsLitqlSnTpYKL9pQxFHOcLVlO0rVqdbLcdNULxnSnDERoShj8HTbft6VOvONXDx5ay+ Uf2ff2h/jdd/FX4C/syNr/xV+F3hXx38Yf25f7f1r4pa5onxT+OPgBPgbrPg7WPhd+zHr3j74gX/ AMXdD17xb4n8HeOtS+KB17+3viRqM/wu8NxaZ4Z8X3Isr7XtPreJ/wBpr47fEay/aY/Z6Txp4mTU Pgj+0B8bbHQ/jr4XvofAnivxt8FPgJ+zr4L+Mus3r3/gCDw5pf8AbvhT48/EfwJ8CPHE/hfT9D0f VrKHVtPvtPg1JdesW9K8N6H/AMEwfiTp3i/4paT4t8dXXg79hv8AaVTwvq3xD0f9q39o3UfB/jP9 oaZ/hl8SUufEY8C/HTWF/al8X2XjXxz4Y8DaXpvxh0j4heKI/Hlrq/w38N6HLaSR2Oq+kfCr4bf8 E9/2fvDX7Qul+C7T4lae/hb4MeI/Efxb8LfGf4iftV+KviFonwN8U2mr6rq8PgXT/wBp7xjqfi/w t8NdfvtC1mGC0+GM2h+DY/GWm6jZqbPxNY3qQc+LoyrZTKlJSeKrcJVYUsRzYmq55lXw2S53kHEc KvtKuIdOWEw0qVWhOGJqVspxv1/E1s0zDFY2titMJF0cwi3h701xIm6NNqm44KvjM4y/M8oUEo0K WMwtXNMvp4eMfZ04Zlh44WlRyeFDL4Yb8rPgl8c/2mPEa/8ABLz4J3Px7+KGt+L/ANm34n3ml/tO a3qHxP8AEba/8df+EmvrvwR+zjpnx81ZJrrVvGOl/EL4Y6xq3xR12LXoNWhvPFegaTrT299c6fEH /pO+D+g/Ejw18OPDGk/F/wAdW/xH+JcdtdXnjHxXYaJpXh3R7jWNV1G81SXSfDuk6RpulRW/hjwz HeReGvDM2oW0viG+0HSNPv8AxPqGqeIrnU9Suvzn+D6/8E1Eh8TftAXGieFf2efFF38QtEj8Vt8c fixaeBPFP/CQ/sS+K7r9lzwX4hv7G9+LOs6APDvg7XtTs/BlheW962l+I9U8U+Hh4wtr7xXrVlE3 398Pf2jf2evi5rLeHPhR8d/gz8TvEKaCnil9B+HvxQ8EeNNZTwxJcQWcfiNtL8N65qV8ugyXd1bW qauYBp7XFxBAtwZZo1b18TVlUeMjOHPicZnGOzSdVQhaVPE4LB1KkaMKc6kKFOjicNmUVQoyqUae BwuFqOoq/wBcjHxqGGr0KlJ1ZqGHwWW4TJ1QvU/2fGYHH5h9aoVK1ZOtivZTzLCUaeJxM1iq060Y YinyxwJ7LRRRXnneFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU 13EaO7BiqKzkIjyOQoJISONWkkYgfKiKzscKqliAXUUnezs0nZ2bV0n0bSabSe6TV9rrcFa+u3Wz s7etnb1s/Q/KPx1+018PP2qvhjqGi23wW8cX2ux/tp/8M4fBrw9428efG79kLxpqHxK8BeER8Qrr 4jXXi7SfBvhr47fBOwsvCln47vbddH8MatrHinwlp8aRwaj4c8dS20Xzj4T+Kv7Oes6/8K/iDof7 KsWkeEfgT4k/Zz+DXxd1CD9o74i6fZ/Dv4oaz8c/F/wX+GejS/CXS9MPgD9p8/B34uPd+JX+Inxm ufDniTwvbeKbT4geDLTU/F32/T7H7M1z9k/4sWOoeI/HvhWT4a+IPHeh/t06l+1t8M/DfiXxZ4r8 LeFta0LWvgjF8ENR8MeMvFWkeAvFeqeFdc/sXW/F2qWl1pHg3xzpsV7b6FHKsyXl4+m+CeEP+CeP xq8LWV14HbVfhLeeBvjR8V/gj8e/j/4gj8WeNrbxV4O+Ifwu/aD1r9ozxL4b+Fnhx/h9c6T4/wDC Xi/XbjRPBmla14l8T/C3VfC+kWup+JJ9D8Q3t5baBaaYPlp0spqQTji51+EcXmSrP2MYYyXDmSLO q7qYdUmpUsW87VbEUnHE4XE4algcEqVCpgsHisK/NVxMqdVVZ5c4cT4WtJQpVa9PA/628QLLqOCp 1VONVSyOHDlTD0cRRqYbG/W8XisVGvXo4mthvSP2IfFvwnvPinJfeD/gkPhpa/Hz4O6x8Z/gh4mH x5+IXxfi8QfBHR/iWltqGm2fgTxrY2vhr9na1m1j4heFPGsXwz+El3rHga6g8WW7XF/FqXh6O0i/ VGvzq/ZQ/ZQ+Jvwb8X/De4+IEnw7i8Kfs5/s86x+zL8GLjwR4q8U+Itc8beDtb8Z+EtfufGXxC0r xD4H8K2XgjXotG+GngXTovDOha/8Q7N9QuPEl83ihIGsLQ/orVyWHjhcDCg6r5KePhKNVRhKNCOd 5r/ZblSp/uaFWvkv9mYrE0KShGli6+IhOlQrKrQpa1LvMs4lFXw08bQlhKjSdSrD+ycsWKlUqXc6 zp5msdh6dapKftKFGk6VWth1RrVPyz/bPvNI8AfGS3+NLfAf4m+J7bwN8J/CEvxQ+MXhv9qb9or9 nrTLLwHJ8XG03Qvh94K8JfCyKbwH8a/iHbanrviXxbf+CfFWpeDZrjTR4f0u81+8h1/SLewo/D/S P2b4/wBsn4y/sa+AvBXxzsLVfhf4o+O/xK8YWv7U37Sdv8Ol+InxN+K+keMPGXgnwr4IPxNk0TQv GL3fjjR/iP4j1vwofDp8PWHjbR9C0u1Nlrup21l7b+0P8FPjj8VPj78IvEkHhv4W/EX9n74XWmm+ L7T4aeNfjL4z+Gi33xzs/Esl1pXxC8V+GvD/AMBfijpvxFsvhpollpmq/C/QdX8V6Bo2nePr2/8A FWqaNca94c8C+IfD/AeFf2Mvi38F/wBpDXvj38MPi7qvxSsNU+GPxi0qPwJ8cdc8DaBbP8Qvi78b fCPxNvPM8TfDL9nWDxUPBuiaRpWqaZol1q+r+J/EGnRab4U8NCG60K3lurPLLkoTyuFabp4V1OMn iEl7KUZVMBmtbKqdeNNwjQp4rOI4bEReGpJY1LAVcfjsRVxmYYHDZZtKs6WYuhevXqS4K9nBx9tB U6GPyvD5nXpVJOr9bq4XI54vBqliIxnl8K2YUcFSw8MBgsVjOT/Z18TfCab9qu88VeHPgL/wh+nf F7Xv2qvC3wq+J4+O3jzxrBqHib4SfFLT9I+P4tvgBr1nD8NfgMfiv440HUvGv9tfCjU9Y1D4np4V k8R/E2LQ/EV3a2Mv6sV+dXwR/ZV+K/gH4w+ErzxTcfDUfCH4NeLP2q/G3wx1Xw54k8Waj8Q/GWr/ ALUXxKvfHb2fjXwnqvg3SfDvgmz+HWm6/wCJPDq3GjeO/H7+OrqbS9eNn4HS0m0Sf9Fad/3GEhF3 pUsP7Oim5KoqSr15R9tR92lhqsnOU3QoUqFKMZRm6Mas6rlvOVSeJxtSryOpUxlepJ05VKlOSlJO EoV6ydXERnT5Je2rTq1m24VpRqwnSpfI37XPiLwT4C8PeCvi94++BfxN+Mmk/AXxDrXxn0rUfh34 n+HWhL8PPEPh/wAGeIvC0fiDV9J+IXxq+ENn4vuL3w5408TaZ4f0CK28awtq80d6ukWWv2vhu+Hx N8MPHPw31z9rjxNoFh8BvjJ8OLD4yfFPxZ4G8b6tqH7Xfxxs9dX47an+yZ4M+NfikeMf2ZfDHizU /gz4d0Kz+F2r2Xgy3+IHhjx1qV9o/wARPD+lnw74dtrd9E8Zp+gH7SHwk8Y/GaL4KeGdEvvD1r4G 0D4+fD74kfGOy1q/1a0vtf8AA3w0XV/GugaD4dt9N0q/ttU1G7+LOjfDW61PTtavdF0mbwvZa+0t 9dXKW2kal8kW37Gvxg0v9sXVP2kdOsfgvLe2nj74j+O9O+LM/ivxZbfGTx94K8U/BWH4d+E/2W/H Ohx/DG70jw78GvCfjO20Tx5Fr+i/ELxKwv8Awfo1/a/DOHxFq2uaxIsJ7GM8d9cp3o1MBnVGmrOT kvZcP1eVrDpzr0s0isVQlgK8aXtanD+Gqzq4mf1DLsaY1YipHL1h6sXVpfUpxlKcZxow+s5+6dNe 2kvqtfB1uflqUn7KnT4olWdOhTqZlmWD6Cx8L/CH4FftT+EvD3h34BftdWXin4z+MLaOD4jaZ+0p qviD4O+KbzwB8GtF8PXfj7x38MNW/a9u9b1LRPDPgbwZ4X8G634m8VfA69ur3xYPDclzHqmv+INN 1nUv0pr5W8FfCf4oXP7TGu/Hv4n3HghNNj/Z3+G3wr8AeFvC2r65rs3hDxfe+JvFPi/9oG+S+1nw x4cSXQvFeo23wl0vw/qEcSanq2neAVu9Z0jQJjDZSfVNazdRUqNKtV9tXpe2hUkqvtoRjSrTw+Gh TqRapTjLBUMNXbpUqcKdStUw0HVo4elVnnH2cqk50YclB0cHGlelOi5c2Fp4iqnSrU4V6Lw1fEVc A6VRzi3g3iKTUcRYKKKKxNAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAo oooAKKKKACiiigD4j+NMd5N+2h+yLDp11DY6hL8J/wBryOwvbi0a/t7O8ew+CK2t1PYrc2TXkNvO UmltFvLRrhEaEXMBcSp8t/sR/Dz4i/s7ftKftP8AgDx5458C/FG7HhL9kfT9S8UeEvhjrvwsv/EX inxdP8ddc8UeO/ENpq/xW+K8d7rviTxDqGteINejtbiwt7vVtVlktP7PtYktGKKWEfIlbVYivCjV Ukpp01nVWDUFPmVJyjiaqqTpKE6jVGVSUpYbDulzY/3vqCf/AC6qYqtC2jVSOWY+cZNqzlyulFRU nKMYyrQSUK9eNTxX43eCLfxvY/8ABQGRr+fTdU+Gf/BSj4DftB+G7lVe5sJ/Ef7NX7JP7J3x90zR Nd0tJ7M6ponipvhzJ4Tv41vbWXSxrkfiG2a5u9GgsbvP+I2op+0f+2R4S8fatDN4a07W7P4E/sjv 4WsL2W+t7rwV40m+HH7aXxPvPEl3IlpaeIofGNp4f8M/Bux0dtG04+HNBPjPxENV1ebxfFoXh8or rwdScMTk8YytHAZP4W5nhY2TjTxvEWUcLcI53WlFpxrRzLhunDKMRQrqph3hk3ClGrKVR+hnlOEq OM5oqTxOT8XxrSavKS4aT4myNRl8VL+z88bzCk6Tg6lSU6dd1aE5Un8WaJYT+D/Hv7W+k3mpXPiy 0+OP7Y3g3x/Z/wBvW+nPc/Da3+E3/BbmDwDc+BvCl5b2Ud1N4H8WTeND40udH1GaWTTPGQ8RalHd X1t4jgs9C+/P2SrW2g/a4+EbwW8ELy/EL/guC8rxRRxtK5/bk+DCF5GRQXYpFEpZiSVjRScIoBRX ZknvZRkVV61JYfj2hKf2pUsDl0cswsZPq4YLAYSlObvOtKl7evKpiKlWrP6DM2/rnHFL/l3R8Uqy pxsrR9vwNnuNq67vmxOKr1Vdvl9pyQ5acYQj+6NFFFeSfMBRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAH/2Q= /9j/4AAQSkZJRgABAQAAAQABAAD/2wBDAAEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEB AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQH/2wBDAQEBAQEBAQEBAQEBAQEBAQEBAQEB AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQH/wAARCAChAyADASIA AhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQA AAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3 ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWm p6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/8QAHwEA AwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSEx BhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElK U1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3 uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD+0r9p 79lT/hpv/hCP+Mkf2rv2fP8AhCf+El/5Nh+MP/Cp/wDhLv8AhJP7A/5Hf/indf8A7f8A7A/sD/im v+PT+yv7a1//AF/9o/uflH/h1V/1kh/4Kuf+Jg//AIu6/VyivQoZpj8NSjRo1+SnDm5Y+yoytzSc 5azpyk7yberdtlpofOY/hPh/M8XVx2Oy/wBviq/J7Wr9axtPm9nThRh7lHE06ceWnThH3YK9ru8m 2/yj/wCHVX/WSH/gq5/4mD/+Luj/AIdVf9ZIf+Crn/iYP/4u6/Vyitf7bzP/AKCv/KOH8v8Ap15I 5P8AUThT/oVf+X2Zf/Nh+Uf/AA6q/wCskP8AwVc/8TB//F3R/wAOqv8ArJD/AMFXP/Ewf/xd1+rl FH9t5n/0Ff8AlHD+X/TryQf6icKf9Cr/AMvsy/8Amw/KP/h1V/1kh/4Kuf8AiYP/AOLuj/h1V/1k h/4Kuf8AiYP/AOLuv1coo/tvM/8AoK/8o4fy/wCnXkg/1E4U/wChV/5fZl/82H5R/wDDqr/rJD/w Vc/8TB//ABd0f8Oqv+skP/BVz/xMH/8AF3X6uUUf23mf/QV/5Rw/l/068kH+onCn/Qq/8vsy/wDm w/KP/h1V/wBZIf8Agq5/4mD/APi7o/4dVf8AWSH/AIKuf+Jg/wD4u6/Vyij+28z/AOgr/wAo4fy/ 6deSD/UThT/oVf8Al9mX/wA2H5R/8Oqv+skP/BVz/wATB/8Axd0f8Oqv+skP/BVz/wATB/8Axd1+ rlFH9t5n/wBBX/lHD+X/AE68kH+onCn/AEKv/L7Mv/mw/KP/AIdVf9ZIf+Crn/iYP/4u6P8Ah1V/ 1kh/4Kuf+Jg//i7r9XKKP7bzP/oK/wDKOH8v+nXkg/1E4U/6FX/l9mX/AM2H5R/8Oqv+skP/AAVc /wDEwf8A8XdH/Dqr/rJD/wAFXP8AxMH/APF3X6uUUf23mf8A0Ff+UcP5f9OvJB/qJwp/0Kv/AC+z L/5sPyj/AOHVX/WSH/gq5/4mD/8Ai7o/4dVf9ZIf+Crn/iYP/wCLuv1coo/tvM/+gr/yjh/L/p15 IP8AUThT/oVf+X2Zf/Nh+Uf/AA6q/wCskP8AwVc/8TB//F3R/wAOqv8ArJD/AMFXP/Ewf/xd1+rl FH9t5n/0Ff8AlHD+X/TryQf6icKf9Cr/AMvsy/8Amw/KP/h1V/1kh/4Kuf8AiYP/AOLuj/h1V/1k h/4Kuf8AiYP/AOLuv1coo/tvM/8AoK/8o4fy/wCnXkg/1E4U/wChV/5fZl/82H5R/wDDqr/rJD/w Vc/8TB//ABd0f8Oqv+skP/BVz/xMH/8AF3X6uUUf23mf/QV/5Rw/l/068kH+onCn/Qq/8vsy/wDm w/KP/h1V/wBZIf8Agq5/4mD/APi7o/4dVf8AWSH/AIKuf+Jg/wD4u6/Vyij+28z/AOgr/wAo4fy/ 6deSD/UThT/oVf8Al9mX/wA2H5R/8Oqv+skP/BVz/wATB/8Axd0f8Oqv+skP/BVz/wATB/8Axd1+ rlFH9t5n/wBBX/lHD+X/AE68kH+onCn/AEKv/L7Mv/mw/KP/AIdVf9ZIf+Crn/iYP/4u6P8Ah1V/ 1kh/4Kuf+Jg//i7r9XKKP7bzP/oK/wDKOH8v+nXkg/1E4U/6FX/l9mX/AM2H5R/8Oqv+skP/AAVc /wDEwf8A8XdH/Dqr/rJD/wAFXP8AxMH/APF3X6uUUf23mf8A0Ff+UcP5f9OvJB/qJwp/0Kv/AC+z L/5sPyj/AOHVX/WSH/gq5/4mD/8Ai7o/4dVf9ZIf+Crn/iYP/wCLuv1coo/tvM/+gr/yjh/L/p15 IP8AUThT/oVf+X2Zf/Nh+Uf/AA6q/wCskP8AwVc/8TB//F3R/wAOqv8ArJD/AMFXP/Ewf/xd1+rl FH9t5n/0Ff8AlHD+X/TryQf6icKf9Cr/AMvsy/8Amw/KP/h1V/1kh/4Kuf8AiYP/AOLuj/h1V/1k h/4Kuf8AiYP/AOLuv1coo/tvM/8AoK/8o4fy/wCnXkg/1E4U/wChV/5fZl/82H5R/wDDqr/rJD/w Vc/8TB//ABd0f8Oqv+skP/BVz/xMH/8AF3X6uUUf23mf/QV/5Rw/l/068kH+onCn/Qq/8vsy/wDm w/KP/h1V/wBZIf8Agq5/4mD/APi7o/4dVf8AWSH/AIKuf+Jg/wD4u6/Vyij+28z/AOgr/wAo4fy/ 6deSD/UThT/oVf8Al9mX/wA2H5R/8Oqv+skP/BVz/wATB/8Axd0f8Oqv+skP/BVz/wATB/8Axd1+ rlFH9t5n/wBBX/lHD+X/AE68kH+onCn/AEKv/L7Mv/mw/KP/AIdVf9ZIf+Crn/iYP/4u6P8Ah1V/ 1kh/4Kuf+Jg//i7r9XKKP7bzP/oK/wDKOH8v+nXkg/1E4U/6FX/l9mX/AM2H5R/8Oqv+skP/AAVc /wDEwf8A8XdH/Dqr/rJD/wAFXP8AxMH/APF3X6uUUf23mf8A0Ff+UcP5f9OvJB/qJwp/0Kv/AC+z L/5sPyj/AOHVX/WSH/gq5/4mD/8Ai7o/4dVf9ZIf+Crn/iYP/wCLuv1coo/tvM/+gr/yjh/L/p15 IP8AUThT/oVf+X2Zf/Nh+Uf/AA6q/wCskP8AwVc/8TB//F3R/wAOqv8ArJD/AMFXP/Ewf/xd1+rl FH9t5n/0Ff8AlHD+X/TryQf6icKf9Cr/AMvsy/8Amw/KP/h1V/1kh/4Kuf8AiYP/AOLuj/h1V/1k h/4Kuf8AiYP/AOLuv1coo/tvM/8AoK/8o4fy/wCnXkg/1E4U/wChV/5fZl/82H5R/wDDqr/rJD/w Vc/8TB//ABd0f8Oqv+skP/BVz/xMH/8AF3X6uUUf23mf/QV/5Rw/l/068kH+onCn/Qq/8vsy/wDm w/KP/h1V/wBZIf8Agq5/4mD/APi7o/4dVf8AWSH/AIKuf+Jg/wD4u6/Vyij+28z/AOgr/wAo4fy/ 6deSD/UThT/oVf8Al9mX/wA2H5R/8Oqv+skP/BVz/wATB/8Axd0f8Oqv+skP/BVz/wATB/8Axd1+ rlFH9t5n/wBBX/lHD+X/AE68kH+onCn/AEKv/L7Mv/mw/KP/AIdVf9ZIf+Crn/iYP/4u6P8Ah1V/ 1kh/4Kuf+Jg//i7r9XKKP7bzP/oK/wDKOH8v+nXkg/1E4U/6FX/l9mX/AM2H5R/8Oqv+skP/AAVc /wDEwf8A8XdH/Dqr/rJD/wAFXP8AxMH/APF3X6uUUf23mf8A0Ff+UcP5f9OvJB/qJwp/0Kv/AC+z L/5sPyj/AOHVX/WSH/gq5/4mD/8Ai7o/4dVf9ZIf+Crn/iYP/wCLuv1coo/tvM/+gr/yjh/L/p15 IP8AUThT/oVf+X2Zf/Nh+Uf/AA6q/wCskP8AwVc/8TB//F3R/wAOqv8ArJD/AMFXP/Ewf/xd1+rl FH9t5n/0Ff8AlHD+X/TryQf6icKf9Cr/AMvsy/8Amw/KP/h1V/1kh/4Kuf8AiYP/AOLuj/h1V/1k h/4Kuf8AiYP/AOLuv1coo/tvM/8AoK/8o4fy/wCnXkg/1E4U/wChV/5fZl/82H5R/wDDqr/rJD/w Vc/8TB//ABd0f8Oqv+skP/BVz/xMH/8AF3X6uUUf23mf/QV/5Rw/l/068kH+onCn/Qq/8vsy/wDm w/KP/h1V/wBZIf8Agq5/4mD/APi7o/4dVf8AWSH/AIKuf+Jg/wD4u6/Vyij+28z/AOgr/wAo4fy/ 6deSD/UThT/oVf8Al9mX/wA2H5R/8Oqv+skP/BVz/wATB/8Axd0f8Oqv+skP/BVz/wATB/8Axd1+ rlFH9t5n/wBBX/lHD+X/AE68kH+onCn/AEKv/L7Mv/mw/KP/AIdVf9ZIf+Crn/iYP/4u6P8Ah1V/ 1kh/4Kuf+Jg//i7r9XKKP7bzP/oK/wDKOH8v+nXkg/1E4U/6FX/l9mX/AM2H5R/8Oqv+skP/AAVc /wDEwf8A8XdH/Dqr/rJD/wAFXP8AxMH/APF3X6uUUf23mf8A0Ff+UcP5f9OvJB/qJwp/0Kv/AC+z L/5sPyj/AOHVX/WSH/gq5/4mD/8Ai7o/4dVf9ZIf+Crn/iYP/wCLuv1coo/tvM/+gr/yjh/L/p15 IP8AUThT/oVf+X2Zf/Nh+Uf/AA6q/wCskP8AwVc/8TB//F3R/wAOqv8ArJD/AMFXP/Ewf/xd1+rl FH9t5n/0Ff8AlHD+X/TryQf6icKf9Cr/AMvsy/8Amw/KP/h1V/1kh/4Kuf8AiYP/AOLuj/h1V/1k h/4Kuf8AiYP/AOLuv1coo/tvM/8AoK/8o4fy/wCnXkg/1E4U/wChV/5fZl/82H5R/wDDqr/rJD/w Vc/8TB//ABd0f8Oqv+skP/BVz/xMH/8AF3X6uUUf23mf/QV/5Rw/l/068kH+onCn/Qq/8vsy/wDm w/KP/h1V/wBZIf8Agq5/4mD/APi7o/4dVf8AWSH/AIKuf+Jg/wD4u6/Vyij+28z/AOgr/wAo4fy/ 6deSD/UThT/oVf8Al9mX/wA2H5R/8Oqv+skP/BVz/wATB/8Axd0f8Oqv+skP/BVz/wATB/8Axd1+ rlFH9t5n/wBBX/lHD+X/AE68kH+onCn/AEKv/L7Mv/mw/KP/AIdVf9ZIf+Crn/iYP/4u6P8Ah1V/ 1kh/4Kuf+Jg//i7r9XKKP7bzP/oK/wDKOH8v+nXkg/1E4U/6FX/l9mX/AM2H5R/8Oqv+skP/AAVc /wDEwf8A8XdH/Dqr/rJD/wAFXP8AxMH/APF3X6uUUf23mf8A0Ff+UcP5f9OvJB/qJwp/0Kv/AC+z L/5sPyj/AOHVX/WSH/gq5/4mD/8Ai7r9MfAfhT/hBPA3gzwP/wAJJ4s8Zf8ACG+E/DvhT/hL/Hms f8JF458V/wDCO6PZ6R/wknjPxB9ms/7c8Wa59j/tTxFrH2S1/tPWLq8vfs0Hn+UvV0VzYnH4vGRj HEVfaRg3KK9nShZtKLd6cIt6JLVtHqZXw9k+S1KtXLMH9WqVoKnVl9YxVbmhGXMlbEV6sY2lreKT 6N2PyB/4Lk/t/wDxm/4Jn/sAeMf2qfgL4a+GPiz4i6B8RPhh4QsNG+LujeKte8FS6f428TQ6Lqc9 3p/gzxn4C117y3tpDJYSw+IoYIpwHuLa7j/dH4T/AGcf+Cuv7evws/bCl/ZP/wCConwm/ZB0+z1T 9irx3+3Hpfxe/Yu134rT6D4R+GngTT7rVb3SfH3hT4t6prWtx6tPZ6PrEf2m3vNLtFvbjQoLBdVg vLm6tvuz/guT/wAE/vjF/wAFM/2APGP7KfwK8SfDPwp8QPEXxE+GHiy11j4t6z4q0HwZHpfgvxND rOrW9zqPg3wb481yO+ubSNo9Pjh8PTQS3BC3F1aR5lH53fBn/g3X8O/syfti65rf7NafD/4T/sDf H/8AYN8bfswftc/By3+Knxn8Y/Enxp8U/Gml+JNMvPHfg+L4kaJ4301dDgTUNGnsmuPiH4ck06eD UjZeF0guZbe88nCvFQw+fSahLE1MTntLKI1+WpFqPh9Ur5P7k3Qp4PDf63U6Nsb7evKri08vrYSG ExVbF0fpK6wkp5PzOpGhCllVTNHhW411F8dZXQzJ01y1FicSuFq+PlHByhSg8LGpjYYmOKwNDC4u z+yl/wAFdf8AgrD+0lZfAP8Aa/0r/gnh8MfFf/BOf9pH4u3fw58NaN8JfEnxG8W/tlfC3wNZ+KPE Hhm4+PPxJ0xrb/hXWq+A4JtDnnuNH8PaTZ6qjW7xR6hNFqGk3V1+437ff7W+k/sI/scftAftcaz4 UTx3bfA/wHdeLLXwO/iRPBw8Y6zJfWOj+H/C48UPoniVdBfXtc1TT9MTU/8AhH9Za1a5Ei6bdsoh b+WHxX/wbwf8FTNR+CHwJ/ZS0z9r39ke5+CP7Fvi+9139l7x/Z2n7TPwz+Ovirwr4x+JNp4r8efD j4x2/g3XdQ+EljoP9lxLdaLq48FfFHxBLqmnWuhw3vhvS9T1jV5v3R+Kn/BKO61Dwp+25e+AP2hP HPxf8bftgajoXiOD4Uft/Q6F+1l+xn8LNX8PeMbrxpaaD8PvgDfeHfC48M+FJ9Qu0ggR9e1+90eT R/DOpW6Xs2iG2vvQzH6vLBVI5dKrQprFZrHBYicFiM3jl0KeSLLJYynUjGhUxldV83rzc8M3hsZh a+GlHG4GeWwXJl6mswoSzNU6iccseY0MNN0cslXlmGaLMaeX13z16dChl8MrjTqz5ViIV6c3Ghj6 OZSfzj8Cf+C5nxI8Sfsv/tj/ALWf7Tv7DWkfA/4Z/sl+CdA8TCz+Bn7bv7P/AO2v4q8eeINXv7nT 7/wPqmi/CKw0RvhJrXh+WXQrjVpPiHNYJZ2Oq3t7fwWEGgakw9A+AP8AwWyi+IOp/tL+D/2gf2X9 Z/Zo8cfs9/siS/ttrJp/xn+Hv7Rfw78Q/A67stRu9Cm1Tx/8LIbbT/CPj+7Fmgu/h/qdvJeNs1Cb QtX13TrSHU7z4Vf/AIIE/tW/GLTf29fHvxZ+PX7NX7Knxi/a+/Zt+HX7NXh7wJ+wN4D8e+FPgD4c 8P8Aw58V+HfEM3iDx1beIpvCXiDxZe/ELTPDEXg3xJp1jo2ljR/B/iPxBoFrqet2RVbvn/hL/wAE E/2vPD/izx74q17xF+w58AfCXxZ+HH7PP7NPxT/Zv/Yn8L/En4ffAj4k/B34ffGzwb41+LXxl8f6 d4g0DTf7b+PPjr4aaB4l8F6dZf8ACPywQS+MrqDUviBd21ve3+rawoYfGYh4WrWjl0Mbl9PBRrwl UqQyzGYjC53hqOayr3mqs1mDyDGYuEVVo4PC1cRhZ5bCGHxebU4jVlQoUsROlPFzw+axr4ijpRli svw8uFMRiMDQgoYiVOE8NLi7BwqyhVq4nFYfDYvDYpRrYHK8T9L/ALDn/BWv9tL42/tz/tXfsg/t C/Dv9nfwy37OX7B3wg/aUM3w78JfEvSNeX4ueO/hV8JvHPijwrrd14n+LHiqxuvB+ia5491nSbGy s9I0rXRa6fZfatdmnW4luPtP/ghz+398Y/8Agpj/AME+/A37V3x28NfDPwn8RPE/jz4l+F7/AEb4 SaN4p0HwXDYeDfEs2jaXNaad4x8Z+PdcjvJ7WNZL+SbxHcQyzktb29rHiIfGn7XH/BJ/9vPSP+Cg Hxz/AG9f+Ca/xx/ZY8G+IP2s/gDof7PPx88AftU+E/iRf6VoWj6XpuieH28f/DLWPhtBqs9z4ntt D8L+HRpWgeILCx0FNQtdQbU7nUbS/t4NN/Sf/gk5/wAE/rL/AIJj/sNfCX9kWLxyPiVrPgubxV4h 8X+OItKbQ7DXvF3jbxHqHiTWZNI0iS5vJ7HRtPa9h0jS0urqa8ns9Piu7sx3FxJDHWFrYfEYLF4n EUIYTESyvC4Ong05SnTzdcVcSYzF4nDy95SwseHqmSYWniZyTqxdGgqftqGJ9njjaWJp4vCQo4hY ilLG4bF161OMadN4CHA/D2X4ijVgowjSr1eLqOc476rTi4pVJ4iMlRqUov8ACL4//wDBTv8A4OCf hV/wUo+G3/BObw78Kv8Agk5deOv2h9A+IvxP+A2r65pf7VNzo8fwo8J3fj+70pfiX4g074vWD6d4 3m8PeBL06jaeH/Ct/o8urSRLa3Fvaz/6P+4Hw+/4KzfsY6j8KfAfi3x38ddBh8War+0hoX7C3i7T vC3ws+PCQR/tvfYLWLxT8HfD3hPV/h7J49h0221z7b/ZfivV9MPhFNHW2u73xc6F7lvCv2gP+Cbv xx+Kv/BbX9if/gpJ4e8VfCiz+Bv7N3wA+IXwq8c+FNa1zxfb/FfVfEPi3TPi7ZadeeFNDsfAuo+E L7RoJfH2jte3Gr+OtCvo47bUzBp1y0Nql5+JPwC+Acfxz/4OWvj3oHwd1l/GP7GH7OHxm8T/ALbv xRh07wZrFj4T8Ffty3HwmsfgZrngW+8Q6lpljp8/jG18V3l749W3057hLqOO81CC4uxbvcR8eVyh 7DJsuxN6mIr4DiPMcxrSd8bQo8McV13FzkoyjSp5jwBTxValWlSdKrxLX4e9tOFPFTwdfszqMaVf NcywTl9VwmHyGhg6KfJgK+Z8Q8PVFPD8zXNKvhONnlmHVFTUqPD8eIJU+aph4Yqh/Q/4D/4LV/8A BLn4lePfBHww8Jftf+BLjx38RfiDr3wp8JeH9a8OfEfwjNffEfw74guPC174Mv7zxf4L0LTfD2vX +vWs9h4XsfEd7pL+NNq3Xg/+3bKWK4f0zVP+CpX/AAT/ANG/aHH7K2qftO+A7P42/wDCX2vw5m8P yWnik+F7P4mXwDWPwt1H4qR+Hn+E2mfFO+BzZ/DPUfHFr46u9r/Z/D8nlvt/jy/4Ja/8E5v2rv8A goX8DX8IJ8Xv2ffA37D/AMJ/+CxXxi/aM8e6bN4G8dSftS3XxE+E3iPRxbeHvB3i6w1v/hBJvBfi 3S9Tlguru+stA8TeF9QgS6gvfEthImk2n6MS/wDBuX8dYPjR8V/DUvxs+H3jv9kj4vftlat+2FqT eN/jf+3B4f8AGvhfVta8U2fiifw5a/s1/CT4sfD79nTxj480e5twPC/x78R+IrbxPpk1tZPqnhHX 7OC10+x3y+nCquHZ4+Tw9HM8Fl+Y41w0nDCZjlvBeY06lKMo1IYRxp5zxVUw8cTUrvH0eH8Fb6pi M2w1GeONmoSz+GBca88txuaZfg+ZtxeLyzOeMsqnSrNRpTxTTybhpYl4enh3h6+d4xQjiMNltTEn 9Uvxk+Mnwv8A2e/hf42+NPxp8a6L8OvhZ8OdDufEnjbxr4hmlh0jQNGtWRJLu5+zw3F1M7zSw21r aWdtc3t7dzwWdnbT3U8UL5nwF+Pvwd/ag+Engv47/AHx/ofxP+EnxD06XVfB/jbw611/ZusWlveX Om3a/Z9QtrLUrC9sNRsrzTtS0zVLGy1PTdQtbmyv7S3uoJYlf8cPgR8Jv2k/g945+Afxy8F6b8Rv hL8SfD0vhfxr4P1uW9S11vSJWhlCPe6ddWWqWN9bXVtbX9hqum31nqmnajbW2oWF3bXlvDMmb+zl +zj8FP2Sfgv4F/Z6/Z38A6X8M/hB8N9Nm0vwh4O0m41K+g0+C7vrrVNQubrVNavdT1vWNU1XVb69 1TVtY1nUtQ1XU9Ru7m8vrueeV3OFO1sd7Zu6lgP7O9ktHC2P/tN41Sd1JS/sz6gqF008d9Yd/YFz bccG6atNyxn1+NTWMYcmD+oLCSjZyn7R49Yv2sVFwWEdFqXtU/xu+Mv/AAXo0T4I/EfV7jxb+w9+ 0vbfskeH/wBqXTP2PdT/AGvtR1L4ceHNEvvjBqN9a6cbnwf8F/EPiLTvi541+HkM81xPF490PRZd J1KxsZ59KS9meC1ko+J/+Dgz4S+HviZ47urf9l/43a3+xj8K/wBq3T/2KviX+3JZeIfhnbfD/wAL fH+9vtP0i405PhffeJbf4p6v4E0nV9St7HVfH9jox0yAlXt7W6e5sIbz5G+L3/BNn/gup8Xv2/p/ 2t/iD4r/AOCUPxx+HfgP4kyan+zF8Jfj94o/a98T+F/2cPA9nr+dJ8SeA/hp4S+GnhH4dXHx1uPD kNrdap8RfGcXjfWLPxOrDw3ruj6Nb2Nvb3/GH/BAL9pTXG+Mf7KGk/tB/Aq2/wCCb3x+/b0tv29f H1lqPgzxzN+1No+uS6xoviDXvgl4auLa6j+Gd14K1bVNHtRZ+NdTuofEOkW1pFGdC1Fbu4jj1yeN KpHIJZlLlVapSlj/AGjcJqk814HpYyGaRpKDoVqeRVuOc1wiy+NGlTx9PLcndfOKuEVbOIzSUoVM 8hgE3Gjh5LAypxdSLr/UuLalCpl0qumIpvNKfB+W1449qpVw08yzX2OV0MTyZX/UL8QfHnhz4Z/D /wAa/EzxZqEGneE/APhDxD438RanPLHFb2egeGdHu9c1S8kmkZY0jhsLKeUu7qgC5LAc1/K5/wAE 3P8AgvL+2n+3N8Ef+CiNx4n+A/wQ+G37SfwN/Z0m/as/Y28F/wDCL/EVPC/xW+EOr6P4yu/Cc/jj R7v4r3viHxTN/augaFpeo634M13wVY38niKJbbTtLmgKN+23/BV/9mb9o39rz/gn/wDHn9lj9lDx V8MvAvxO+NPh3Sfh4/ib4s654s0Dwlpnw+1LWdOT4hWx1DwZ4N8ea4dT1jwdBqmgafCmgSW7vqbv c3dqiCQ/kL+yv/wQp/bB/ZA/bx/ZE/aP0P8AbD+HX7Qvwa+Gn7Lmr/sdfHDwh8RPhzonwU8X2fwD 0/w9La/D3wT8NNO+D/w91Dw/8TBoXiS4j1e98RfFbXfD3i2eLSrRLzXtbe72adxU6VbEzzyl7b6r HFZbiMqyetXilHDZi8mzvMoZpGVKpKdOX9sUeFsspVsRRlg1ha+fwlOnXjQ9r1SqU8PhcqryowxV fD46lmeZYSi5yniMJhczyKhVy1SqSoUpUcXlNfiirKjCf12eMoZJWpKnShX5vJPhD/wck/ETxv8A G7/gnJ4I8SeBfgvbfDf9pj9hrxb+0B+0l4u0bQfHlvL4A+N+j+GPjxqOi+DPBOqXvxD1DSPDvhjU dZ+AviKAaF4utPFfia+sbh/sXiCOTT7i5fX+Hf8AwXh/bs+Jf7Mn/BNjwz4K/Z5/Zy8T/wDBRT/g p5rPxn1n4UeGNUb4l/D39mz4V/B34aa/rum6Z8Q/iFay+MfHPxF15tQ0nR21+XT9B8Uad/aOlW2r 3Wnta3Ftp+nap8VW3/Bqn+1hoP7Hf7YHwU8NfHL4CwfGPx9+0z8MPG37KXi65+JXxng8P/Dv9n34 eXHxj02bwR4t1y3+EM3iHwtruu+Gfjb4xOo+G/BmgeJfC93q13dJc668Go3d2361/H//AIIo/HHS NF/4Jd/GX9hj4w/B74c/tef8ExPgna/BnwnafHHw94r8S/AT4t6FfeAIfCniax8WXnhKCDx3oiXW pXHiO7ttZ0vSbm+ms/Et9J9g07U4LO5g9WVXAV54nEVKFehg62d5ZJYek+XGU8mzXCcR8U16VNU5 T9j/AGPm2Z8NcF5lVoRniY5Vk2Nq4Be2m2+WcK9KdPD4arTr16WSZpGGKrUuXCYrP8n+o8OYLE1V Ury9lh87w1DM+LMNhat8NPMMVg1jFCjSqUan6U/8E6f2j/20fjh4b+Lvg/8Abv8A2Vbf9m/44fBX 4gP4Mk8R+BZPE2pfAL47+H3inFn8SvglrniyEa3J4fuLyxvop9H1W91HUtPs5tFvbu6WTVTZ2fkv 7UX7dHxJ8B/thp+yf4U+NX7H/wCyjdj4UeBPiN8PfFX7Znhnxd4ht/2rfFXjDxL410DVvhF8Czpf x1/Z40bR9b8A/wDCM+HW8Xa3b658XPElrN8QtBaP4UmxtVvNW8A/4I5f8Et/2qv+Cfvxq/bH+J/7 Q/xk+E3xI0X9p20+E3iHwz4Q+E2tfHC68OfC3xlol98RtT+I/hvw9o/xt1nxprlr4Ka98V6O3hfW H8e6nqusxw3kWpeHfC1rpul2c33P+0d8Jv2u/FfjT4gaf4c8G/sjftdfs1/FHwx4e0Vv2ev2tdX1 D4Wad8ItastN1zRPGOtaH4j8Gfs2ftDr8aPDPxA0zU7STUvAfxB0Lwxf6LfW2qQ6R8QRoOuDRNL5 scmvqEqfsamJnluCni6eFm6NGObf2bGniKMa8oYjCU6qzJSrSr1sJXyKdRTTw1PLqlFQugqcXm1K 9aWGjiZ/2fia8XUr/wBn1cXhMXGSw/tKNer7PA1cRgHh3i6WawpQlOGLnm1KEqli7/4KLfBv4SeD /hxb/tbyXPwJ+OGs/C/w58Svi/8ACjwno3jX9ojS/gFo2ryXGnXfjD4sfEr4E+EPHfgn4a/Bsa1p 2rwaR8Z/ijqngX4f39lp17cT61Zzabq1vYeb/Cr9v5PGP7Snxq+Fvjb4kfBvwV4I8B/tMa/8Kfhc LbwH461/Uvi58PNE/Yl+En7UWqa1J8UbH4gN4A8C6j4auPHfiPxLfeLdd0Cfwv4j8A6PYeGdH0iy 8Szt4ouflD4Y/wDBMb9rb9k/wj48+H37N/jP9nj4l6F+0P8Asw/D39nr4qaz8ctf+Kvg6T4G6v4C h+JWj6d4t+DPhPw54Q+KS/FL4baT4V+KV9oXhf4E+KfGfwcfR7bwboCN8W7hdb1RrDmPA3/BFj4i eE9buvBk/wAT/CNx8GZPFvxB02DX49a8VzfFU/DHxV/wS7+GP7B2mapPp9x4WTRv+E/i8a+C9U8W X2nDxZLpMPhi40+8t/Ed1rMlxoVrvKVFQ4qxFOFKpVpZJjnw9QtKjQxebPiDL5xw0KFerVrYaWDy vDqGGxdfGVqGZ4XNca6U6FfLsRGEK/LlFGonThXxuE/tSvCc8TWwmCWCw0Z4iEoU8LKt9ZxWJzJ1 cIqMMRg6mU4ZVlUo47C18V9t/DT/AIKV+CPj5+298G/2dvgVdP4j+Ffjn9m39oD40eI/FXjD4OfH D4Z+IdUvvhx47+Anhr4deI/hPrfxO0HwJ4e+Inwc8ZaZ8SvGVzbfEPwToXjnwd4uutF06Xwn45jt 9O1S3v8A6C/ba+P/AI6+BHw/+Gtj8J/+EFj+L/x5+PPwu/Z4+F2ofEzS9Y8QeA9A8T/EfUbx7vxT 4n8L+HPFPgjxF4s03wt4W0TxFr58L6H4v8M3+u3GnwacPEGiW88+qWnyb+zx+yl+2hpX7Vv7Nvxl /aBi/Ze0jwF+zJ+yF8X/ANlbRl+DXjv4n+J/F/xFvfGHin9n7U/DvxM1LQfGHwf8C6L4BstU0b4Q X66x8N7PxZ46HgrU5rVdM8feO7XWbiTw79B/tm/Av47/AB90rw2fhxoPwWsvE/7Pfxr+BP7Rv7Pu reP/AIheModO8e+OfAGqa6vjzwP8TdO0P4Qaxd/Cbw/qXhLVbzw54b8feD9U+LerS3fiG61fU/At jbeHl0TxTWNp4KEeGoUKjrYeOZ0nnle9VV6+Sf8AERMzeJr1adGMMXQrVuCXhatLCUYRzTC0J0cO oLMaMkpjPFTw+aTdGGGx7yKv/Z1BSoVaNDiGXCVFYOi6tSVTCYmjQ4ql7KviZuWX1o061eTlgG6k vm/Tv2r/ANsK/wDB37SvhbxH8Uf2Evg741/Y0+OV14G/aI/ai+K/gr4s6T8BdP8AhRdfBP4f/G7w l8RfD/wJn+OWj3+n6jrVn8Q7Hwp4o0vxd+2BpOleBm0jUPFdvrXjMXNl4SfhfEX7f37U17+wj8M/ 24m8QfsW/sweAG+HXi/xj451X9oa1+KPjCH4seKtM8Vap4d+FXgf4K+HNF8e/COTwhon7Q2l6bY+ J/h/4z8Q+Lvib4806TxX4a8KQfATxjqk1xfr7T8K/gd+3x8GLn45/HPw5oP7IXiv42/tO/tAn4sf Fn4F+IPiv8ZdC+GXh7whofwc+HHwX+H/AIT+Hf7Tel/AvVfEzaz4dsPhxB4v8Ua54l/ZHvLfxpea 9eeF9P0/wRBp9r4mnrfC39nD9tT9mn4Uy/Dz4T+HP2P/AItaJ8VfG3x9+I3xd+HnxH8dfFz4TeHP ht4t+P3xQ8S/EO+s/hT4q8O/CL4yWXxB+Gng/TfEs/hcfDnxF8JvhTf+M9SjvPGU3j7wlHq8/hC2 4MUqzwso0JQWO/snIpucFQ5Y8SwyClHNKEudTwbo4rMqtSpTxGEp1OGsFmeCgsdh8ZleMqQp9Efq sa1GpF4ieFjjsXGVCtGo51MnqY6tOVeM4yhiEsMqVOhSwuLceI8ZlGNhVwOKweZYGrLE+heBv22f jf498XfBjwhpP7G3jW0b4g+Ffgfq3xC8ReI/G9v4e0X4UeIvH/gqT4j/ABc8PX4h8Ja7/bkXwR8I XHhe1utWtby1svGfxF8e+E/h5pj6dcR+Kdc8NeM/t7/t3+M/2cv2qvgR8Bbb9q39hT9jL4f/ABM+ Avxj+K+r/GD9tvwZqvizRtX8W/Dvx58JvCmhfD3wcY/2vP2S9Fs9Q1bSfH2va/di51zxPqcsHhxj Z6XFbJeXEX35+yN8BB+y3+zF8Cf2dR4mn8Yn4N/DLwr4Bl8TT2z2S6xPoOmw2txdWWnSXN6+l6SJ 1ki0XSDeXX9k6RHY6aLiYWokb5l/aN+DH7WcP7Z/wY/au/Zr8C/s7fFDT/BP7Nvxp+AvizwV8cf2 gPiV8ALyO8+JnxI+DXjzSvEnh7W/AX7L37TEGs21hB8ML7TdR0zUtM8Oy+bqtrcW15OkE0TduK+p f2zTp0+RZYsdxPU9vCGNlCVKfDuef2Fh/ZQrKtDC0s6hlSwTryq1KdStTebV8dh6dRHHRjio5bOT nKpjlgeH6Cg/q9NyrUc3yqOcY29WFRLE4rLpZhVxdKnKNJQpyp5bRwlWUZS8/wDgB/wVF+HWofs0 fC/4sftH6zpNx42+I+rfGe38G2v7KHwy+Nn7R9r8Zfhx8GvH+qeDpv2i/h18Kvgj4Z+N/wAV/Dfw f8UaNF4b8YXd34jXW9L+H0XjHQtA8ReN9Qur3TNR1X2Zf+Co37Ck2raFpNh8cv7aTXvg14d/aIHi Tw78MvjF4l8AeGvgV4pi8XSaR8W/iL8S9A+H2pfD34WeAfM8CeKLLVfE3xK8T+E9M8Parp8Gj+IL jS9V1XR7O/8AhvSf2BP28/AeiRaZ4C+Ivwb03wp8aPiB+0f8T/2i/gf8OvjT8X/2ZvBfgbx3+0H4 20DXrPxB8Kfi98MPgp4j+MvxEsfhv4Y07WtBk0CC7/Zj1D4g+KfEut/ESDxj8NtXuNI0/wAO+WfA v/gjJ8a9F/Zq+PX7PHxk+Jvwtsf+Fv8A/BOL4F/sV2HjH4c6r8RPE1xpXjb4R/EH9pnxPd+MdQs/ Eej+CtduPCeqaf8AFrwJObeDxkPFF7fWXizTLjULH7JpPiXV5tCth8Tiqzo4bExpYWawcJRny4pY PNXmWCk8PTdCt7DHUcqeHzHLk8vzDDYurPCYTCVpVMvynuisP7WtTjOpGlDF4iNCry1XRxGBq8RZ Xh8Di6EcRKeOw1OOQ4vMa9TLs0nVzXC18vgsVjMbH/asd+zvwC/a/wDgB+01qHijRfhH4r8R3fiP wdYaHrWveE/H3wr+LfwW8Zx+F/FJvh4U8daX4N+NXgb4feKfEPw58WPpepx+E/iR4e0jVfAnieXT NRh0LxFqEthdpD84X/x7/av+P/xt/aK+GX7JF98APhp4R/ZS8X+Fvht438fftAfDb4j/ABel+LPx Z1n4e+Hvijrvw/8ABWgfD34w/BKL4deHvC3hbxx4EtdR+KOr638SryTxHq+s6ZB8KZLXQI9R1jjv 2GP2JfiP8EPjD4u+NPxe8L+GNC8USfC+w+D3hi8tv27v+CgX7d3inVfD6+I7fxPreqT+Kv2yvEuk eH/hX4d1XUtO0y4s/hd4L+G3iTUtLvoJ726+Mut2lw2kDrtS+BH7W3wC+Of7Q3xM/ZH0v9nX4keC f2qvFHhj4j+OPAnx8+JfxQ+D978KfjBongLw98Mdb+IfhHXfAPwj+Otp8SvD3i7wn4L8Dzal8MdQ 0T4T3Fpr/h7UdQg+JksfiZ4NGyqRwyknfFXnlOKlho0ZUZ8meLNcJHLZVKlSMKLwWIyOGOxcqWPp UqeEzPE4LA5rB0MNjKk+ejOtKGJVSlQhy4rBRbnKrKTy55fTqZp7NUtVjKGazeEhLCzrqvllDFYn LqssdXwPL0V9/wAFE/hF8H/C/gXTv2v4tQ+AHx1vfh/pnjv4w/CXw1onjP8AaE034EaLc6lf6Fce PPip8RfgT4T8eeD/AIX/AATvtX0fVZvD3xg+L1/8OvCNzpNrcPrV3oeraXr+k6Tt3X/BS/8AYotf itrPwZb4yXV14x8M+MPB3gPxfqWmfC34yax8MfA/in4jeHvCvij4b6f4++N2k/D29+C3gO3+JOk+ NvDKfDnV/GHj/RNF8e6zqLeGvCOoaz4jsNS0mz+I4f2Ef2/PhnqHxr1TwX8ZvgL+0d4v/bG/Z/8A BXwh/aK+J/7Qdz45+GWpfDPxx4VT4k6Z/wALE+EngD4c+AviFpHxK+H1t4c+KV/pHh/4GeJvF3wi vrBfCGiTan8adYvfEOu39v8AF/7N37GXx/8AEFx/wUY/YK+Gep/CF/2ZbP8AaN/Zh+D/AMTvjR4+ 8W+PIfj7oOg/CL9ir9i2LWZvAvw60nwLrXhLxxrnj/w74e06w0jxD4k+L3gIfDDXZr3xG2h/EqI2 +iR9WEo0cXic1VaVKEcHgpZlRWEdSlh68YcRZdleYU+bFxqV8FgsrweZ4LEYfHV44mWcyxlOjhKF LFYTE4OSr+1pYahUo05zUpTo1JVpxq1KbeWUsRgKk40KdN1q2PxlPNKVXB0oqtl8MucsRKdDF4TG 1v2z+GP/AAUm/Yt+MHi6DwZ4E+Mc93f3uo+PtC0vxB4i+GXxe8B/DfXvFHwrl15fiV4J8N/Fzx74 B8M/CvxL8QPAlt4X8Rav4r+H+geMtS8a6H4c0bUPE+oaDB4dt31QYWnf8FSv2FdQ8H/EH4gP8a73 RPBfw18AXXxa1vxJ4v8AhH8cPA+l+IvhHZarY6HdfF34UXHjL4baF/wvL4TRapqml2p+J3wWXx/4 Fb+09OmTX2t7+0lm/IX9lD9jL4+/tsfsf/Cb4T/EnVPhB8Pv2XvA3x5/be8d+HPH3gLxN421X9oD xdq/i/x3+1j8H9K8L6x4E1DwJoPgnwFYeFZvihrfiDVPGelfFTx1qPjyLTdM0oeE/A7TX2oS9An/ AARt/aA174TeLvh74itfhLYeJ/DH7NGv/s9/Cb4heLf28v8AgpL+1L/wk9z4i1f4ex6n4kg+Gv7Q mu33wo/ZN8Iat4d+Hto2vfDPwF4N/aFurrUrjQdM0H4ieGNE8GL/AMJNy4anGpUq08RNUIxw0JUK 1m5V6ksLmjqYiph5KH1SOHzGlleEnltTEVMXXw+IqY/C16uGlUngYqVm6FCth4uvzTrPFxWkMM6W PoU6GDw9W/tcwlj8slXxdPNKeEoYPAYiH1PMMPSxEY0q/wC+Hhf9or4Q+J/g1c/tBXHiTUvh58H7 DTNa13VvGXx18FeO/wBnSHQPDvh+a5i1PxN4k0f49+Gfhv4i8NeFlitJdRsfE2vaRp2g6vobW3iD SdRvtDvLPUJ9288S3vxT+EreLP2c/ib8Lrm68a+FodZ+FPxXvNGl+Nnwlu49UgjudF8UNo3gX4kf DmT4g+Frq3dbiGLw38T/AAyupQSRy2niCGPDPS+NvwJ+FP7SHwa8dfAH44+DrDx/8Jfid4XufB/j zwde3mrabaa5oV4kYntV1PQb/Sdc0ueOSKK4sdT0bUtN1XTbuC3vdPvbS7ghmR3wX+CHwy/Zu+Df gb4D/Afwfpvw/wDhf8LfCtt4R+Hfg+zu9VvrDQdH0+OQWNrJqWs3mr67qMjTyPc6hqmrX+p6vqN1 Nc31/d3l7PNNJjXdPkzB+zruEVh3gadGrzVqtPkxzx8a1SKw7p1lKOXLAuh8ftMY60qLp0Pa70pV GsFK0I1JPEyxaqpclJ3wLy+FKMlUjVXvZjHHutyRj7LBujTqRr140PxnX9vD9vD4eaH+3R8QPHOt /sp/Gf4Nfsp+M/hh8D9L+LHgX9nf4pfs96FZ/FLXvE/g22+P/wATfGUHjb9sr46WusfAf9kzwZ4y t9e+Ilzpms+ENR8T67oPjfw/D4k8G2ngy+12+868X/8ABXL45aL8HNS8Q+HPiJ+xf4q8NaV+1Jf/ AAHsf+CiOn+FvFeofsMeN9Bsf2bbz46W2r+H/BOgftM63qGn67rXxLjsv2UtPUftS+ItGf4r3cN/ YT6zr0r/AAptfr7wt/wTz+J+k/8ABO74Vfs16l4r8AP8fPBfxn8E/tReOtTtb/X5/hN8UvjXoP7T EP7UPjHw94i1hvCen+KH8CfEHxb9t0K916bwTdaxpFndWmsN4Y1mXS10i991+BXwQ/aU8CSfthfH XxNp3wR8NftD/tL3fhvxD4a+Efg74ieOfGXwK8EeJfhx8KrH4c+D7rXvivq3wg+HvjLxZf8Ai670 ux1Tx14otfgh4fu7DQ7XQvDGn6HrreGY9b1naf7vC5hBuNfFYXCU8NSnQhTjOvi8IuGsRHMsFKrO OErU8xxn+tlHCYGt7VYOh7GPEFbNMBPI6FHaKp/WKcI06ahisZjfZzrVqzpYejXjmGDw1PEqE5Tp ywmFhk2OxeJbWDxOKqYpZTQwGJ+tVVL+xr+1l8Tf2sdTn166+HGnfDXwD4R+DfwcHxJ0jWbbXZvG uj/tTfEfwdovxK8e/CSyv7ufSrGDRvgh4Q8QeF9G8XNd+HbnVtR8ceLZdEe68PX3gTxBpWpfPP7e /wC3f4z/AGcv2qvgR8Bbb9q39hT9jL4f/Ez4C/GP4r6v8YP22/Bmq+LNG1fxb8O/Hnwm8KaF8PfB xj/a8/ZL0Wz1DVtJ8fa9r92LnXPE+pyweHGNnpcVsl5cRfPo/wCCP3xQ8NftJ/s/fE7wl42+GfiD SvAMvwE8W+Kvjh401PxNZ/tD+APiL4A+LfxI+L/7Td38IND0nwRqPhzUtK/bw1T4jXfh343yyfET 4XQ6N4e0yysbnw78SNLttI0XRfuT9o34MftZw/tn/Bj9q79mvwL+zt8UNP8ABP7Nvxp+AvizwV8c f2gPiV8ALyO8+JnxI+DXjzSvEnh7W/AX7L37TEGs21hB8ML7TdR0zUtM8Oy+bqtrcW15OkE0TdeI WBqY7A1oyo4fCPG8VUcRhKEcdiKEVS4czivlOLp1m6ONlgMZxPicNhcrpY5KrgqWBwv1/wCu5X7L E4zzKSxVKhjsPH22KqwwPDNXD46t9Xw9WtUqZnlVHNaLw0/bYeji8PkuHr4nMvq1SdPEYnGYxYN4 fFp06Pn/AMAP+Covw61D9mj4X/Fj9o/WdJuPG3xH1b4z2/g21/ZQ+GXxs/aPtfjL8OPg14/1TwdN +0X8OvhV8EfDPxv+K/hv4P8AijRovDfjC7u/Ea63pfw+i8Y6FoHiLxvqF1e6ZqOq+66T/wAFMv2J fEPifwr4S8M/Ga58VX/i/wCEXhn4+2OreEvhd8Y/FXgjQ/gl4uTxc2ifFb4gfEfw98PdS+Hvwt8B GTwL4os9W8TfEvxP4S0rw5qenRaT4judK1PVNItL/wCDNJ/YE/bz8B6JFpngL4i/BvTfCnxo+IH7 R/xP/aL+B/w6+NPxf/Zm8F+BvHf7QfjbQNes/EHwp+L3ww+CniP4y/ESx+G/hjTta0GTQILv9mPU PiD4p8S638RIPGPw21e40jT/AA7xv7Mf/BHv4xeCvgD8ePgH8cfiN8NYbD40f8E0fhP+wi3i74W6 v448R6vpPiPwN4l/aqn1vxv9m8aeG/Dd7Nol5oXxu8F39jDceIr3Wr3WtO8S6ZqUsMFppviDWuef 73CYzFyVGhjYYehUpYCE6cr42OCzZ4/ASnRjHC1fZZhQyhYfM8BJZbjsLjKtTDYbB1ZVcBlPq0YY SeJnRlWqUMP9eq06eKdOvUozy6txJlWGwmOoUq0p5hRp0uH8XmWKqZXmVSpm2Hr5dCGJxuNTWLx3 64/AL9s79nT9prWNa8PfCDxnr+p69omi2Pio6L40+Fnxb+EOq+IPA+q3T2Wj/EjwFYfGDwL4Euvi V8K9bu43ttC+Kfw9i8T/AA81uYCPSvE14zKD893/AMe/2r/j/wDG39or4ZfskX3wA+GnhH9lLxf4 W+G3jfx9+0B8NviP8Xpfiz8WdZ+Hvh74o678P/BWgfD34w/BKL4deHvC3hbxx4EtdR+KOr638Sry TxHq+s6ZB8KZLXQI9R1jyb9hn9gb4l/Az43Wnxi+L/hzwlY6v4F+DGs/BHwT4gh/bv8A+Ch37a/i vxFpfiHxD4O1jXddsLD9rfxfpXw6/Z88Ma2vgPQLnUPhT4O8E/FPVF1SHTTafGmDSdBl03xD6tqX wI/a2+AXxz/aG+Jn7I+l/s6/EjwT+1V4o8MfEfxx4E+PnxL+KHwfvfhT8YNE8BeHvhjrfxD8I674 B+Efx1tPiV4e8XeE/BfgebUvhjqGifCe4tNf8PajqEHxMlj8TPBoxXhg4SXJVxVTnyvHvD+xVJcm dxzuhDKZVHWUKf1Kvw9TxWLnDMKVGnh81xOEwuZ0YYahikcWGqV50a3tqVKnNYjBRqKoqiawLwEJ 5pGi6NScp4qlmkvq1OphpT9rltLF1ctnVxs8BXqdFff8FE/hF8H/AAv4F079r+LUPgB8db34f6Z4 7+MPwl8NaJ4z/aE034EaLc6lf6FcePPip8RfgT4T8eeD/hf8E77V9H1Wbw98YPi9f/Drwjc6Ta3D 61d6Hq2l6/pOk7dz/wAFLv2KLX4rax8GT8ZLq68ZeGfGHg7wF4u1LTPhb8ZNY+GPgfxT8RvD3hXx R8N9P8ffG7Svh9e/BbwHb/EnSvG3hlPhzq/jDx/omi+PdZ1FvDXhHUNZ8R2GpaTZ/EcP7CP7fnwz 1D416p4L+M3wF/aO8X/tjfs/+CvhD+0V8T/2g7nxz8MtS+GfjjwqnxJ0z/hYnwk8AfDnwF8QtI+J Xw+tvDnxSv8ASPD/AMDPE3i74RX1gvhDRJtT+NOsXviHXb+3+Mf2bP2Mvj/4guv+Ci/7BXwz1P4Q v+zJZ/tHfswfB/4nfGjx94t8eQ/H3QdA+EX7Ff7FsWtTeBfhzpPgXWvCPjjXPiB4d8PadYaR4h8S /F7wEPhhrs174jbQ/iVEYNEj6cDQoY3F5nCvKnThhcH/AGhSWEdSlh60I8R5blWYU1LGRqV8Dg8r weaYLEYfHV4Yl5zPGU6OEoUsVhMVg5lf2tHC0KtGnOScp0akq041qlNvLKWIwFScaFOk61bH4ynm lKrg6UY1svhlzliJToYvCY2t+2fw/wD+CkX7GfxQ+JL/AAp8GfFrUr7xQnjvx/8ACoapqnwn+M/h b4bTfFf4Xar4g0jx18J7X4y+K/h5onwfvPipocnhXX9UHw2tfHU3jfVPC2nt4z0bQtQ8I3Fprc+H p/8AwVH/AGFtR0T4heJ4vjZdWvhX4b/DDxj8a9S8Wax8KPjXoHhLxn8Ifh6sbeOfiX8EPFOufDnT tA/aN8EeE/tFmmveJP2f9R+Jml6bLqOlQ3Nykuraal1+Sv7IP7L37Qn7WvwV1b4U+JZvg34L/ZN8 Jf8ABS79uj4wv8QfD/i7xzfftG6/rPg79r39oez0r4eR/D6b4f6b4B8L6d/wmd3/AG/qXxST4teJ dR1XwpC3geP4X6TdXUnjGLNtv+CJnx4l/Z48T/AC/l+GE+peAf2PvjF+zf8AAz4t+M/27v8AgpF8 cbPxP4q+Ifwkn+EOk+LI/wBmz4reIr/4B/sf+G/7Dlk/4Snwz8PNG/aTiWyuIdH8CDwZZ6NYmfCj h4NVIYqp9Xq/V6M8NG13iPbZRLEVMZWjLlp4GODzh08BPKquJq43HYaSx2X4ithpyrUeypCEM1eD tfCUs3q5fjMVKtyPBxw/EmMyyrS5VQqSxU5ZPRo5l9foU3g8LiJVMJi6dOrGVKn+x3xu/bO0zTv2 B/2kf2yPgBZ6lrB+FXwM+MfxM+H4+Mfwk+L/AMM9G8S6z8OvBWseJNFv7rwj8Q9E+FXjjxB8PNcu bG0uNP8AE/h6Sx0PxfoE/wDaXhHxVc2Vxb6mPgP9nj/gqpc6v8UNA0nxz+2j/wAE7P2vvhU/7OXx X/aD+Nfib9i3wz4h8LeLv2VdA+Enh/w/4i1C++Ifhqz/AGs/2wrj4gab4h/tq70Oy0jRLbwR42sd R0O6vbPw54msH1H+wf02/at+A3i344/sP/H/APZp8G3/AIZ0zxx8U/2afiH8GvDWpeIrvU7DwhY+ JvFfw51Pwhpd5rN9pWjaxq9p4ft9RvIZb250/wAP6lqENgsklvpV1OqWr/m38cv2GP20f2xfCvgf Rfjb4J/ZG+Bep/Aj4BftE+APhZq/ws+PvxX+POs/ELx18b/2afGf7PFpYeOPEHi39kj9n64+GHws 0tPFg8YeIdO8O6Z8UdY8Ra1pfh2SKDTR4b2a5z12qE85ng17eVHA1fqFKuuaNerDLOIVSnGc/Z0J c+ZrJ6k8Ph4UsfOn7OlTxUKcp1Vpg40cVgeF4Y6ccJWxGa4x53Uw/wC7q4bCVMTwe8LSnzKtUgo4 eXENKniZe0wlGaxFfF4arBUqC+vbv/grD+w9Z+ErLxwfHPxhvPDd/oV54ziuNH/ZA/bG13UYPhpZ pHJ/wujUfD+i/AO/8Q6R8AdQWRv7C/aA1XS7P4LeI3t76PQPHepSaffrbb9x/wAFCf2a/DN98Q9V 8QfHvw9438PWvi34TeF/h74O+EfwO+NXjn4lahqnxU+D+lfFzwx4c8LaX4Ah+JviD9pXW/GHgu7u PibpVx8Efh3bQ+FPApntfEmn3dx4e1nxA3yt+0x+xh+3d8S/C2k/Br4dfFT4eL8BtY/ZA8N/AXWf CrfHP4z/ALP9z8Nfivo+ha5o+v8AxM0+f4J/CrUPHXx38M+L7W68L6UvgvUfi9+z7D4Z07wpcuJ/ Edt4v13Rh4b8F/8Agl/+158Cta+GXxs8P65+zf4r+NHwX1n9nLV/Dnw61rx78TdD+F3j2z8C/sD6 F+xz8W9B1r4k2vwa1zxR8Pbxtct9Q8ZfDjxfp/wr+Ib3ekWFtpfiHwro0/iK+/sHolTwyrZtas44 fC4jD0MuruMqs8bRqZtj8NiZywsIKpB0sHgsFiYV6fND2WZRrRc408RhJebh54prAe1o0p1MTk+L xeLoxqrDRwuZLBZDiMDgli60atNupicfnOErwq06LjXyhwlWoYbEUcdV/TL9hL9rHUf2u/hT8Wvi pLbaFNo/hP8AaX/aK+E3ghvDOheJfDs+r+BvhN8QNT8LeFbvXdF8YX1xrdl40vdOskXxNa3dtoIg 1sXFufDuhPFJYQ/EH7Jf/BQ79oj9prxD4P8AFHhXxf8AsafEWx1fxpB4Z+Of7Dng2S/8B/tp/sVa Lfza1Yy+IvjH4n8fftC31n4+1vwPf6Bc/wDCa/D+1/Zu+EWqalZzapN4D1nxPL4YWHxN9o/sL/s6 /Gr4C/Bn4xeGPjJ4h+Hlp8TPiz+0f+0n8cV1T4Nz6vrfhjwta/G3x9q/jDw/a6c3jzwpoc17rHhm 31KGG9XUtAuNLvb+0MzLc2ty9uvyb4i/Yn/a7+PPiL9nTSf2ndG/ZF1jW/2bPih8MvifZft6/DzX /E+lftW/Ey6+GOp6Xf3elW/wVtf2efCXgr4GJ8YdPtbrwn8Vx4V/aL8feE7rwpea1pGkeA4bHX7O z8Kcii4ywcIu0llPDVHEOpONX2VeeDwseIsVKoorC42WGlGvLMMMlgM0xcp03wrjKGOeJdPqxU4S pZ97KN+fOOKKuV1KUJ0ZLCU8Zmz4foUKFSUq2GhiqdTAPL61WWNweDeHgs/wWMwcvZVr37Lv/BXL 4QfHD9lvw/4z+InxH0D4SfHvUvgD8UvizrGoal+zz+0U/wAC4Lv4UaXrWp/EG8+G+p6pbaVofx8j +Fdjp8Wr/EX4ZfCD42eIviBp1va6hpd7d+Hr9vPsvrL/AIeI/sl6L4t8KfDTxF8ZY7/xjq4+Guj6 14n0D4TfGEfCXw14w+KujaJqvw88N/EX4n2vhXxJ8LfgV4s+JcHiHQrzwD8N/jB8TdA8ba1F4i8P 2GmWus3mqafJffn14q/4Ja/HzWv2Nf2P/wBnew8W/Bu38Z/s/wDwM/a3+GfjPUpte8aReFtU8RfH 39nH4q/CLwnfeGbyH4ey6re6VY+KfHWl6j4nudV0TRb610WHUrvTbDWdRjt9MvPNpP8Agjf8U7Hx l460WSTwf8RvhX8dvGvwo+IPxM1DxD+3R/wUU+D2geA9Q8H/AA3+Evgfxl4bX9j39n3xh4G+BP7T Vtq158Lv7U8J+L/HPjn4K6xpUOqaRp3ivR/GmneD7Cw1HqoKjUzPFUsQ1TwSWClTrUW4fW6ss3zG liMPhVVVangIU8ndLGqtiqyo+1w6oVquJr43LsNh1j58tD2mEpqpVWJzrlpSkoxoYWng8jqYCtVl CmquMdfHSx+GjQpU51VTarYanQhhMxqY/wCv/hX/AMFT/h/H8HNb8UftAarY6H8U5vjT+2h4H8I+ CvhH8Ivjb8T5Ivhx+zR+0X8Svg1ovxK8e6B8ONH+KWu+BPA1npfhXw2fiV8XPGt34Q+FmleItUuG m1nwta3llplr9kfsK/HXxX+09+xj+yz+0X46sPDmleM/jj8Bfhd8U/FOm+D7TUrHwrY69438IaV4 g1O18O2Ws6vr+rWujQXd9LHp0Gpa3q17FarGlzqF3KGmf8x/hR/wTx/bF/Zq1/xd8Qvg/qH7M/jz xj8V2/a6+Hvjnw58S/H3xT8K+F/CXw4+OH7XXxm/aR+FXxD8I65oHwf8aah4n8a+E9L+LE+i/EX4 Tar4c8JaF4sv4La30n4yaRa6HBqes/pv+wp8DPF37MX7GH7LH7Ovj/UfDeseOPgh8BPhb8LfFuq+ DrrU73wpqPiHwT4Q0rw/q174cu9Z0nQdWudFuL2xml06bUtF0q9ktWia5sLWUtCm9P6rLL80qzUI 4yWKyGGFp81vZU6NXjOlmEaFN3lNV8HDhfH4zEKcqEq2NpYSnyYjBY2lTvHOMcxxFPDJPBRzLPZY eqrS9tgqjyargXo06VHD4ipnGX4OlVpxxFTD4FY2cVQxeFnV+raKKK88zCiiigAooooAKKKKACii igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKK APxM/wCCxX/BSP45f8E9/wDhnX/hTHhX4UeJv+Fu/wDC3f8AhJP+Fn6H4v1r7D/wgP8AwrH+x/7D /wCEU8deCvs32n/hNdV/tP7f/afnfZ9P+y/Y/Kuftf4mf8RI/wC3H/0Sr9lH/wAIb4vf/P0r6u/4 Od/+bIf+7lP/AHgNfV//AATw8UfEHwf/AMEnv2Ntd8CfGX4KfBKztPjN4hf4keI/jrq2maP4W1z4 VxfGH4oXHjbwjot1qtjdW7eLtX0+FZtFiF5oTlbG7kbXdPhjlZ/1LLsFk2E4OyzOcXlWExuIxGa4 fK5yxFWeHgnjsbmVOGJr14067jRwsMJD2kYUJzdJylBOUFCp/K3EOZ8bZ34wcW8J5Txnm3D2W5Vk Uc7oUsDhKGPbWDyHJMVXweGwtXFZfB1sZWxlWdOdXGU6arSUZuMJupT/ACi/4iR/24/+iVfso/8A hDfF7/5+lH/ESP8Atx/9Eq/ZR/8ACG+L3/z9K+kP2iP2P/8Agnz+0L45/aN/bl1Tx18Sp/gHe/Hj 4b/Ajwvo37Jdn4EZtc+JWt6b4J0fxd49luvE+javo114dvfFPimMsujWVtLq8thqWt6beau+u6bB L7PN+x/4A/Yx/Yh/4KP/ALPXjDxn4h8U/B61+NfwE1jU/E+lvpWm+Orf4a+LdR+D91qyyFtM1bR7 Txbo+mPqUcFw+iXVhdy29nqJ0dbe8FgmkMTwrLBYWpLhyNLMcU8rpRwFeNWlTji8fX4dVbBrGSp2 dbCYLiTL8wcZUIOtQmoSVGo6saPm0sp8X6ud4rBR8S6lbJMOsxrxzzB1sHi6ssvw1PiSGBzGrlcM RGVPD4/MeF8zypunja/1bF0K0ovE0YU6lb4I/wCIkf8Abj/6JV+yj/4Q3xe/+fpR/wARI/7cf/RK v2Uf/CG+L3/z9K9L+Mn/AARK+C/w2i8bwWnxK+KVvdePv2j/AIEfAn9k/U9c1rwXPpOtWHxR0bwd q3ifxX4+htvBGmTeKYvD0eq+LW0+Dwpd+DxcP4bSyk86e4Mxt/G3/gkD+yt8FNL1vxjpHxF+K11d fAn4n/De1+IfhTx78Q/2b9Ym+NPga/1rw/B4xuvhj4e8IS3/AIj8B6pYR6jdi20H4saFPe36WjQD S7u2u0vl7sNPgPEywkY5fTgsXisNg4ueFrJ0q1ejklacasOfmUsIs/y6GLgrzpTeKdpUsHjKtHw8 XhPpB4OnjZ1OI8RL6jga2YzUM2wU1UwlOpnsMPWpVIUZU/Z4+PDmaVsFUnKEKtOGGhN08RjsHQr+ U/8AESP+3H/0Sr9lH/whvi9/8/Sj/iJH/bj/AOiVfso/+EN8Xv8A5+lfsr4J+GH7O/ws/wCCpv7Q Pgj4S/D+1+ENqP2ANWvfH+meC/DPgzw58PIrXU/F3gwaZq/g7wh4R0PQng1lbGPVZPE8mp3F42r3 kemfY5LRI51b8v8Aw9/wSN/YW8b+Kv2QdS8HfGL9o6T4Vfth/D34nSeAp/Ed78O9F8Z2fxM8F6HY eKdD+3iD4d6hpUPhrV9Gs/FdveaCbV9Vh1G00r7J4pnjuJIn87C47hGtTp163DjoYetlyx1KcKdT E1HUVfiinLCzpUlanOrR4Wr1sDN1G8bKu6MadN4epOftZhlHjLh6lXC5d4kf2jjcNnOMyvFUKmKw +XU4UMNh+DascwoVcVeeIo063GOHoZnBYenHLPq0JzrV3jaFOPlX/ESP+3H/ANEq/ZR/8Ib4vf8A z9KP+Ikf9uP/AKJV+yj/AOEN8Xv/AJ+lfoP/AME8v2Lfh3+xb+0B4H8PLrXjy/8Aj/8AE/8A4J/f Fj4i/GjQ/EGo+H5PC3hJLvx58L7Lw9pfhvR7Dw1puuadO88WtQagda17W/Mk0svALdZNo+OPgZ/w Rd+BHjP4F/AXxj8XPi18R/D3xA/aP8A6v8Q9I8W6B4z+Avh34UfC20udIg13wnp3irwd8QNVsfip 8Q59SttQsbbUJ/h15sGm6jJLb6sdGsVh1SfrnW4KhUxMv7JoTwVChQlRxdOE5PF4meY8VYCtQw9F tN06a4TxtejiJVEsZ7SFGjT9rPDxxXM8r8dvq2Wwhxhj3nOKr4+OYZVOvh4wyfDYbAcHY7C1cVjo e1hVxGKXGeApVsLRoNYBUp1q2InRWJlg/P8A/iJH/bj/AOiVfso/+EN8Xv8A5+lH/ESP+3H/ANEq /ZR/8Ib4vf8Az9K9d+Hf/BHT9jj+y/2QdC+LPxS/aLHxK/adu/in4KU/DXU/hZf+Abbx18NrTX9U u9atNU1fwfLqWn+C5dP8M3kVnaRxeLNS1m81PT5V1bR7K2uJp3fDH/gh18DrPwhZ6t8cviz8TLm/ 8afGv4rfDHwtrfgDxf8AAjwB4Y8CeG/h54t8V+D9P8ZeO7D4uahHr3jefVb3wwt7f+G/hobjXdMh 1KO3FhOlpPfm6lbgOn7W+X0moVKlGnL6tVUMTWpYueDlToVJzjBy56bqXqypQVF805RkqkIcdLL/ AKQlZYZw4jxL9vQo4mrCOa4OpUwVCvgaePp1MXSo0alRJ06ipfuI4huunGKcHCpLyD/iJH/bj/6J V+yj/wCEN8Xv/n6Uf8RI/wC3H/0Sr9lH/wAIb4vf/P0r8/fg38JJfgP/AMFP/gx8HZfEWleLh8O/ 2xPhT4at/FOhywzaV4isbL4oeHf7O1mza3uLuGNNRsHtrp7ZLq4+yTSyWrTSPCzn96f29v2Jv2aP jb8b/wDgoD+1D+0J4t+N+gWP7PE37P8ABLp3wfl8C3Fxq/hrUvhj4Nn1S1TSPGOhyrPr1090bPTL 9vEul6bphlW9vNO1RLdrO52xlHhLCxyXELJ8PWwGc4TEYynioRqxnTowr5Dh8I1hpR9rV+tVM9oO UW6VSjGlL93VnU5I82QV/GLPqPFVCnxvmOFzzhbNqWT18przwro18TGnnFXMObM4VPY0PqUMmxPI 40cTSxU5RUa1KFqkvhj/AIiR/wBuP/olX7KP/hDfF7/5+lH/ABEj/tx/9Eq/ZR/8Ib4vf/P0r2e4 /wCCKX7K+j/tOfED4X6p8bvineeDrX4EeAfi38JPA7+KPhb4L+Kvj3V/F+seLtI1Dw2fHPivwuPA DPo7+FrSZI4vDFlPcjxJaieWyttJur278W+K/wDwSR+EXw4+C/7dfxHu5P2l/DXiL9nKHwFqvwp8 NfEOX4W6fPqujeLLKya+m8YL4N03xlo/i6zttQGrW+m+IPBPi3QLG5S0aO6sLa7tLyAYxrcCScI/ 2bCMp06dRRlhasXzVMxo5X7FXnadWniq0VWVJ1KdKMZupUjK0JdMsB9ION/+MmrySxFWhzQzXCTh y0sqqZysRKUKMlToVsFT5sP7Z061aU4clFw56kHf8RI/7cf/AESr9lH/AMIb4vf/AD9KP+Ikf9uP /olX7KP/AIQ3xe/+fpX6M6F+xR8Nv2KvgT/wUz+GHwj1j4h+JdO8c/sJfDXx7ft49v8AQNZ1xPEe vWP7RelT6dpn/CM+FfCkC2AXS7UWtnNYXd99okmD3soeOOP5K1P/AIIofs/W3wD+K/iy61n9prwF 8WPhX8C3+LU1n8RvFn7Oos/EF3p2hatrWpWj/CTwLJ4v8f8Ag7RLr+yGtNNvfFfiy1u0nuzFJBdT 6dcwy4VMXwPRr432+V0KWCwkMFKnjJQqc1eVWjXqY5fVk+aEMveHlzShUrVMRSkqtOjH3oHoyyXx 5qUsrp4Li/HYzNcdRxNfFZesRhqVLBR9pglllOOOlzU69XM6eNhKPtaWDo4arCdCpWm7TPG/+Ikf 9uP/AKJV+yj/AOEN8Xv/AJ+lH/ESP+3H/wBEq/ZR/wDCG+L3/wA/Sv0K8U/Ab9nLR/2xP+CTmifs 8aL4w/Zr8b/Ef4LeKfE0fxE+FHh34F6Hrd54QX4Ha9ftqPjGHUfhT4g0LxT8V9RuXsrPWPE2saBq mlTaXqPiA2enWOqXGn6lZ/Gtn/wTK/Zt8R3Oo/Gb9qP4r/tHeIdZ/aT/AG8vif8As5fDJvhFa/DF b+w8QP8AFTxx4RtfGfxen1Lwg2lMdW1rwzqmq61D4P0Tw9b2Ntc2p0vRTFM0FjtFcK+1owqZBTpR ryx1CjGUZzxNfG4XiWvw1RwuHo01OlP6zicNUlz1cTRnSqQq0ZUZ04fWZ8WIpeMMKVaWD8QcTjam GWXYjFVlWwuGy3CZfjuEcHxbUxWIxlepHFRnh8LjaNNUaeXVadenOliIYmNSr9Vj5/8A8RI/7cf/ AESr9lH/AMIb4vf/AD9KP+Ikf9uP/olX7KP/AIQ3xe/+fpXr1z/wRn/ZI+E3hePVPjz8Wf2hdU1E /th6d+zNbXHwmf4axWOsWXjm80uz+H2pS6f4n8N303hq+sl8Q6ZeeNb86v4mji/s/UtP0jw29xc2 81t+Mv7dH7MHh79kn9r74lfs7aV4t1DWvCPhHWvDa6X4q1y1hfWIvD/ifQdF8Qwy61b6XbW1vd6h pFtq7292+m2ltFqDWhuLa0tTcC1h68qo8FZzi8Lg8Bl1Gc8bQdfDValCrRoVIxwuTY2UXVqyioVI YXPsrrzjUUeWGIfM04TS8LibH+OfCOWYnNM64nxlKhgsVTwmLo4fMcJi8Vh51sbnmXUqk6FClNyo 1Mdw7muGhUpSqKdTDrkUo1ISf6ef8RI/7cf/AESr9lH/AMIb4vf/AD9KP+Ikf9uP/olX7KP/AIQ3 xe/+fpXxN/wUc/Za/ZE/Zm1D4MW/7Kn7SiftBQ+OPB17rfjdP+Ej8HeKm8O3cLaZ/ZOoRX/grT9P stHs/EaXeoPa+GdZW617TF01nury4jnRh+9n/BL74iX3wt/4JE+HvF9j8YbX4GNa/tFanZXXjy7+ FmufGOKPTtS8d6FZ6hoK+CfD2nanqc0viO0ll0iLWY7dIPD73I1e6uILe1kkE18JwxHKoZphchp1 o1Myw+V06OJo4rB1HXr5vDJ3KVN0a+JcIYiTnGnRwtfEYiCUMPQq16kKUunJs08U8dxZi+Fcz8Q8 ZgK2C4fxfENfF5diMrzmg8PhsmhncaEK317L8vhUq4apGnOtisxwuEwtS9TFV6WFjLER/Oz/AIiR /wBuP/olX7KP/hDfF7/5+lH/ABEj/tx/9Eq/ZR/8Ib4vf/P0r9g/2i/CtxoGuf8ABaC+j8FaD4S0 rxX+xV8Itc0S78PmD/itIG8IfH3T7zxXrFtb2lobTXbjVLO80e6t5YpZ3ttHsbl7m4a531+cHg// AIIk/AnxL8Ete1LXNY/aY+HHxn0X9n2X4twt8QPE/wCz1ZaFqmu22ky3VxBH8F/DM3iz4saP4QTU I0tV1TxP4h0O9Hmi1mjh1BBbyeNRzDg9YbEYvMMhw+CoYfBZZi24TliqkpY3A4vHYqiqahRlzZfT wVRVI64mo3yywtGsp0V9dmeQeNVPMcLlmQcfZlneIxGJzSi3Xo0sqpU4YPHYDA4Gqqk6uMjNZpLH 0p0pXhhqcUpxxVehOFd+N/8AESP+3H/0Sr9lH/whvi9/8/Sj/iJH/bj/AOiVfso/+EN8Xv8A5+lU vHv/AATB/ZD+D3grwF8P/iV8Sv2q9S/ae+In7N4+Pul618KPhhbfE/4HaZLdTw2dr4c1Hw34M8I+ IPiS9la6jdQ2t74n/ta10M2iJqU93plxqWmaNP8ApR8fv2Kfhr+0b/wTq/ZA+N/xWu/itq3h/wDZ l/YQ0nxFp3w3+CV14Z034geMtc1XwN8Nr1J31Pxb4c8V6dZeGtGsfD10+sLbaDd6m0V2b21bfpg0 3Vu/H1ODMDSliHk9OphKGZSy/F4r2NaFGEYUOIeavhZNSWMtmPD1bLZUoulyTrxxVWpDDKMq3j5R g/G/NHicNLjbEYbNFkmGzjA5ZHG4HEYirKviOGJPC5lyThLKnDJ+J8PnEa0qeKVeGHqYOhTnifa+ w/OT/iJH/bj/AOiVfso/+EN8Xv8A5+lH/ESP+3H/ANEq/ZR/8Ib4vf8Az9K8M/4IQNA3/BSv4aNa xzQ2reEPi61tDcTpczxQHwLrRhjnuY7e0juJo49qyzx2tskrhpFt4VYRr+2X7cX7W3h34H/CDVdf +O3xt/Z0+M/7Tfw4/bJ0fx5+zh4d+Duq6PqPjzwH8LfDfxG0e5bwp42OnadYalomrQ+B7Hxp4U8b XF5p9rp942qJoUmo67qEZuZOjNsHkOW5vk2Uw4cwuJnm1DAV+d1p0p0Fjc+/sScY0oUsRGt9Uinm FepOvh6McLSxLlVh7KMq3FwjmnH/ABNwlxDxXivFPNcooZDmOb5e4SwNHFYav/ZXDeF4hhWqYupj MDWofX3iVluEw9LAYzEzxk8Mo0puvKnR/MD/AIiR/wBuP/olX7KP/hDfF7/5+lH/ABEj/tx/9Eq/ ZR/8Ib4vf/P0r9bf2xtP8Mfsk/CX/gor+3L4Q1K0W9/bK+H3wR8IfCy+sXgWX7d4o8Hy+HNS1Wwk V2dpLuHWX8WSMgUyjRRMo/dmYcB8Q/iT8Zv2N9I/4JzfAH9hn9nbwv8AGj4P/GP4Sza1488IRaDo lha/HHWLrw1ouo3cniD4jazYXmleG729t9SvvF13rGrNJHN9pW2uxLpVstkPHw+JyLFRjGlwphY4 iWKwWWOGIxdShh6OcyyTG55m+X4nEywrdGOVUMLRoQxMqD+vV8T7tGhCjUk/qcdlviDllSq8Z4u5 zLC0cBis6lLL8khmOYVshr8TYDhrhvM8HllDMlWxbzytisTi6+Hp1EssoYJxjXzCVZOn+aP/ABEj /tx/9Eq/ZR/8Ib4vf/P0o/4iR/24/wDolX7KP/hDfF7/AOfpX5e/Fn4M+NfiX+2/4u+CHhb4Q6F8 DviB49+MknhTSPgqfHGga94d+H3ifxNqEPleD4/Gukx2/h+XTbDUL029u1nDHb6dC0elrF5toUP7 w+AP2avib8If+COX7W/7NPxJ0S9034ij9rvwp4Hk03w/bjxDcapqPiLxN+zzaWK+EY/N06DxTPeN eLFpcVpdQw6jeo1ol1EQ8kft18HwxRy3L8asmwE8TmUcnnhsCsVSm6tPM81yTK61SjisPPE4fE08 DPO8NVnVwzrUa96UYVY08RCsviMkzjxXznP87yhcbcQUMBkVbiDC4vOZZbXp04YvJcrzvNMNhcTg MdTy/G5fXzOlkWLjDD4+OHxWE5K3t8O62Gq4c+YP+Ikf9uP/AKJV+yj/AOEN8Xv/AJ+lH/ESP+3H /wBEq/ZR/wDCG+L3/wA/SvY/ir/wRG+Bdj8Cfiv4p+Hvif49eBfi78M28CRxaF8avHn7PPiHTNVf xbf6XZtL4j8JfCBNa1j4dW8y3tw+mr4h8ZXF40UAumtLmBLgRfOn7WP/AATp/Y3/AGeNP+MPwz8L fEL9rbXf2lfgJ4L8BeMvEOtXnwqt/FfwB8VS+KNJfXpLWC/8BeEbvV/hrYGys7xI9Y8f+J49LtLn EUd7rMNhq9zYxg/9RMZiqGFp5fGVStiaNFKlg62IqKhU+pOeNjTpVJOeHoxx2HlUV1XvKUPZc0Ki j34zD+P+AoVcVi+J6uHw9HCSxM62IzjA4al7ZVMXShgHLEUqTWMq1MFXjSUksPK0X9YSqQcuo/4i R/24/wDolX7KP/hDfF7/AOfpR/xEj/tx/wDRKv2Uf/CG+L3/AM/Sv0Y/4LS/sU/C/wAT+CfHX7bP xCn+LXirW/BHwp+Fvw18C+BPhRqXhXRdN0O9m1nxIZ/G/wAVNR8R+FfFl9J4RjvvEunRG38PW2m3 cQsZIptQCaub7QfkrxZ/wQz+B/hT4e3XhfU/jP460f492nwOh+KMfjfXfHPwD074Hat4xZJHf4b2 Hw6uNWt/jtALhoZY7PxtcQSeFZIFa5F5JqMZ0BvOw2O4JngKmOxuUUMEqOMxGCrRUauIhGrhqDxt ZwqJUp1VRy54bFV1GjfnxVLCYb61iZckvWzDJvHijnKyrKuMMdmkauXYTM8LiKlfDYGdXC43EU8B hnVov6zSw0sRmf1rCUFPFS5aWDq43GvBYWUJvxz/AIiR/wBuP/olX7KP/hDfF7/5+lH/ABEj/tx/ 9Eq/ZR/8Ib4vf/P0rI/4KyfC39lX4f8A7Jf/AATs8QfB34UXXgLxj8RPg9p3iC28Qabonw40Wfxb 4XHg7wPc6lffGXUPCvhXSNT8a/Ex73U9HubLxDFexaarXPiySeyll1K1kh/AyvostybhzMqeKqQy OlQWFzPM8skq0dZ1MsxtbA1akOWo1ySqUJJp6wnGdN8yjzz/ADvirjbxO4VzHDZdX48xuNqYnJsl zhVMLUSjSp51luGzOjQqRqUIyVWnRxMG2rxnTlTqrlc3Th/QV/xEj/tx/wDRKv2Uf/CG+L3/AM/S j/iJH/bj/wCiVfso/wDhDfF7/wCfpX8+tFej/qrw9/0KcJ/4DL/5Py/Puz5r/iLfiT/0WGb/APgy l/8AKj+gr/iJH/bj/wCiVfso/wDhDfF7/wCfpR/xEj/tx/8ARKv2Uf8Awhvi9/8AP0r+fWij/VXh 7/oU4T/wGX/yfl+fdh/xFvxJ/wCiwzf/AMGUv/lR/QV/xEj/ALcf/RKv2Uf/AAhvi9/8/Sj/AIiR /wBuP/olX7KP/hDfF7/5+lfz60Uf6q8Pf9CnCf8AgMv/AJPy/Puw/wCIt+JP/RYZv/4Mpf8Ayo/o K/4iR/24/wDolX7KP/hDfF7/AOfpR/xEj/tx/wDRKv2Uf/CG+L3/AM/Sv59aKP8AVXh7/oU4T/wG X/yfl+fdh/xFvxJ/6LDN/wDwZS/+VH9BX/ESP+3H/wBEq/ZR/wDCG+L3/wA/Sj/iJH/bj/6JV+yj /wCEN8Xv/n6V/PrRR/qrw9/0KcJ/4DL/AOT8vz7sP+It+JP/AEWGb/8Agyl/8qP6Cv8AiJH/AG4/ +iVfso/+EN8Xv/n6Uf8AESP+3H/0Sr9lH/whvi9/8/Sv59aKP9VeHv8AoU4T/wABl/8AJ+X592H/ ABFvxJ/6LDN//BlL/wCVH9BX/ESP+3H/ANEq/ZR/8Ib4vf8Az9KP+Ikf9uP/AKJV+yj/AOEN8Xv/ AJ+lfz60Uf6q8Pf9CnCf+Ay/+T8vz7sP+It+JP8A0WGb/wDgyl/8qP6Cv+Ikf9uP/olX7KP/AIQ3 xe/+fpR/xEj/ALcf/RKv2Uf/AAhvi9/8/Sv59aKP9VeHv+hThP8AwGX/AMn5fn3Yf8Rb8Sf+iwzf /wAGUv8A5Uf0Ff8AESP+3H/0Sr9lH/whvi9/8/Sj/iJH/bj/AOiVfso/+EN8Xv8A5+lfz60Uf6q8 Pf8AQpwn/gMv/k/L8+7D/iLfiT/0WGb/APgyl/8AKj+gr/iJH/bj/wCiVfso/wDhDfF7/wCfpR/x Ej/tx/8ARKv2Uf8Awhvi9/8AP0r+fWij/VXh7/oU4T/wGX/yfl+fdh/xFvxJ/wCiwzf/AMGUv/lR /QV/xEj/ALcf/RKv2Uf/AAhvi9/8/Sj/AIiR/wBuP/olX7KP/hDfF7/5+lfz60Uf6q8Pf9CnCf8A gMv/AJPy/Puw/wCIt+JP/RYZv/4Mpf8Ayo/oK/4iR/24/wDolX7KP/hDfF7/AOfpR/xEj/tx/wDR Kv2Uf/CG+L3/AM/Sv59aKP8AVXh7/oU4T/wGX/yfl+fdh/xFvxJ/6LDN/wDwZS/+VH9BX/ESP+3H /wBEq/ZR/wDCG+L3/wA/Sj/iJH/bj/6JV+yj/wCEN8Xv/n6V/PrRR/qrw9/0KcJ/4DL/AOT8vz7s P+It+JP/AEWGb/8Agyl/8qP6Cv8AiJH/AG4/+iVfso/+EN8Xv/n6Uf8AESP+3H/0Sr9lH/whvi9/ 8/Sv59aKP9VeHv8AoU4T/wABl/8AJ+X592H/ABFvxJ/6LDN//BlL/wCVH9BX/ESP+3H/ANEq/ZR/ 8Ib4vf8Az9KP+Ikf9uP/AKJV+yj/AOEN8Xv/AJ+lfz60Uf6q8Pf9CnCf+Ay/+T8vz7sP+It+JP8A 0WGb/wDgyl/8qP6Cv+Ikf9uP/olX7KP/AIQ3xe/+fpR/xEj/ALcf/RKv2Uf/AAhvi9/8/Sv59aKP 9VeHv+hThP8AwGX/AMn5fn3Yf8Rb8Sf+iwzf/wAGUv8A5Uf0Ff8AESP+3H/0Sr9lH/whvi9/8/Sj /iJH/bj/AOiVfso/+EN8Xv8A5+lfz60Uf6q8Pf8AQpwn/gMv/k/L8+7D/iLfiT/0WGb/APgyl/8A Kj+gr/iJH/bj/wCiVfso/wDhDfF7/wCfpR/xEj/tx/8ARKv2Uf8Awhvi9/8AP0r+fWij/VXh7/oU 4T/wGX/yfl+fdh/xFvxJ/wCiwzf/AMGUv/lR/QV/xEj/ALcf/RKv2Uf/AAhvi9/8/Sj/AIiR/wBu P/olX7KP/hDfF7/5+lfz60Uf6q8Pf9CnCf8AgMv/AJPy/Puw/wCIt+JP/RYZv/4Mpf8Ayo/oK/4i R/24/wDolX7KP/hDfF7/AOfpR/xEj/tx/wDRKv2Uf/CG+L3/AM/Sv59aKP8AVXh7/oU4T/wGX/yf l+fdh/xFvxJ/6LDN/wDwZS/+VH9BX/ESP+3H/wBEq/ZR/wDCG+L3/wA/Sj/iJH/bj/6JV+yj/wCE N8Xv/n6V/PrRR/qrw9/0KcJ/4DL/AOT8vz7sP+It+JP/AEWGb/8Agyl/8qP6Cv8AiJH/AG4/+iVf so/+EN8Xv/n6Uf8AESP+3H/0Sr9lH/whvi9/8/Sv59aKP9VeHv8AoU4T/wABl/8AJ+X592H/ABFv xJ/6LDN//BlL/wCVH9BX/ESP+3H/ANEq/ZR/8Ib4vf8Az9KP+Ikf9uP/AKJV+yj/AOEN8Xv/AJ+l fz60Uf6q8Pf9CnCf+Ay/+T8vz7sP+It+JP8A0WGb/wDgyl/8qP6Cv+Ikf9uP/olX7KP/AIQ3xe/+ fpR/xEj/ALcf/RKv2Uf/AAhvi9/8/Sv59aKP9VeHv+hThP8AwGX/AMn5fn3Yf8Rb8Sf+iwzf/wAG Uv8A5Uf0Ff8AESP+3H/0Sr9lH/whvi9/8/Sj/iJH/bj/AOiVfso/+EN8Xv8A5+lfz60Uf6q8Pf8A Qpwn/gMv/k/L8+7D/iLfiT/0WGb/APgyl/8AKj+gr/iJH/bj/wCiVfso/wDhDfF7/wCfpR/xEj/t x/8ARKv2Uf8Awhvi9/8AP0r+fWij/VXh7/oU4T/wGX/yfl+fdh/xFvxJ/wCiwzf/AMGUv/lR/QV/ xEj/ALcf/RKv2Uf/AAhvi9/8/Sj/AIiR/wBuP/olX7KP/hDfF7/5+lfz60Uf6q8Pf9CnCf8AgMv/ AJPy/Puw/wCIt+JP/RYZv/4Mpf8Ayo/oK/4iR/24/wDolX7KP/hDfF7/AOfpR/xEj/tx/wDRKv2U f/CG+L3/AM/Sv59aKP8AVXh7/oU4T/wGX/yfl+fdh/xFvxJ/6LDN/wDwZS/+VH9BX/ESP+3H/wBE q/ZR/wDCG+L3/wA/Sj/iJH/bj/6JV+yj/wCEN8Xv/n6V/PrRR/qrw9/0KcJ/4DL/AOT8vz7sP+It +JP/AEWGb/8Agyl/8qP6Cv8AiJH/AG4/+iVfso/+EN8Xv/n6V/Xz+zR8Sdc+Mv7OP7P/AMX/ABPa aTYeJfit8EvhT8SfENjoMF5a6HZa5458CaD4o1a00W21C/1S/t9Jt7/VLiHToL7U9RvIbNIY7m/u 5le4k/y/K/0wv2Dv+THP2Mv+zUf2dv8A1UPg+vguPMoyzLcJgJ4DB0cLOriKsKkqSac4xpJpO7ei evqf0H9H3jPinijOeIaHEGd43NaOFyzC1sPTxU4SjSqzxThKcFGEfelD3Xe+h+Jn/BxR8Bvjl8bf +GPf+FMfBn4r/F3/AIRn/hoL/hJP+FYfDvxf4+/4R7+2v+FI/wBj/wBuf8Ipo+rf2T/a39k6r/Zn 2/7P9v8A7M1D7L5v2O58v8J9a+H3/BWLxF+zt4V/ZP1j9nD9q68+AHgnxFN4r8MeAf8Ahk3xVb/2 Zr9xf69qc1//AMJTa/CyDxre777xPrk/2XUPEd3ZL9u8pbZYbazjt/7yP2jPGniH4a/CHxl8SdD8 e+BfhvZ/D3RtV8aeK/EvxB+HPiH4o6NF4S8PaTf6jq9raeGPDPxP+E2pvrNwYbf+zrhfEtyjSI9i uj3lxfQTWvwh4C/az/aU0n4x/D74Y/tIax8M/hiuqeAvgDea9f6T+yJ+0xqHgvxP8WPjZ4h+JkD/ AAw0v49QfFbW/gt8JdZ0Wy0b4eeELHT/ABtrnjDUtd8ea9MLCKSPxL4U0KvHyni+thMtw2TvKsJj qeBx2EnQhieapUq43EV8bisDiMLh1Go62KoV416ND6vCeMo1ZU5QpxjWhUn9xxd4MYXPuJc44rjx XnmS18+yythsdSyyMKVF5dg8vyzKcxwGJxHPS5sHisN9XrYyniprAVKVSUK9S8VTf8p/7N1r/wAF kf2RrHxDpP7PXwT/AGxfh/o3iq7t9R13Q2/Za8X+LtBu9TtYkgg1aLQvHPwu8TaTYauIIoIH1bTr O01GaG1tIprqSOztVi1b3/h8R4r8N/Fv4e+Pfgx+2j4g+H/7RHi3RfFHx1s7n9lXxLquv+L7rSZN DiguLHXtW+Fsms6C+naf4e0q20jSvD+r6FodtHp9rZizjsjNE/8ATb4W8X/t+L4m+FHwX+NHj/xb 8J9Y+OHxd1HTX+I1jov7M2veMtE0z4f/AAZ+IPxD+I+nfBiz0Pwr47+H9v8ACPxD4w0LwVpXwx1H 43+DPEHxstfBs3jqPxvb2XiK48L6xpn6gfBqLx3bfDPwnZfEzxh4d+IHjrTrO60rxF438LQW1ppH iq60rUr3TodcaysbLTtO0/V9Qs7W2uPEem6VYWekad4ifVbHSbaHTbe1jXuq8bxqV5YvE8P5JicR KGDjKpWgsRVxFGKwuMp051HTnJ08HiMLhoToVpwlSxeFoyo05LDwrR8XD+BEsJQWU5f4l8aYbBYG tjlDDYHE1MNgsDiZvFYStPD0Y16VGNTH4TGYivTxGFpzhXwOPqRrVIzr1qB/JF/wUS+IP7XX7R3g f9lb4Sfs4/sZ/wDBRrwx4N/ZlsNIv7Pxz8VfgB450n4n+I/HHhnR9I8P+FfFM7+AtJ1bTLTVtCsN Mub5NZs7+znn1bWLqe307TltojL8l/GHxr/wXB+PXgj/AIVz8U/hf+2b4g8HyXuk6jfaXp/7KniT wjPrd9oMttcaPc+JdY8GfCbw9rfiiXT7mzs7q3PiLUtTC3dpbXRBuIIpE/vforiwvGEMLCEVkmBx E4ZhiM1jXxc5YjERzHE4iGJqYynVnBulXVWlR9lOkoOlDD4aFPljQp29fNfBnF5ricRiJcf8RYCG KyrBZJXweU06eXYGrlOAwk8Fh8BWw2HrxhiMMqNXEe0p4l1lVnisVKd/b1E/4T9S+N3/AAXi1fxZ b+OdT+F/7WF54stvh1r/AMKI9am/Ymtjct4B8UX+janruh3CL8Clt7uS/vvD+k3B1i7hm163e2db TU4Eu7xbjb/Zjuv+Cg/hz4k/snWf7Tv7OH/BQHWv2ff2Q9em8V/C7wn8Hf2SprTxlo2rWkPnWGkN qmreAfC914g8Oa5cxRaX4qj8ReKLvUG0C5v49KuILySOQf3K0VtDjWlSjy0eHMno8rUqcqVGEJUa 0Z46tSxFG1K0K+HxGaZliqFSzdLE47F1knPE4h1eReB2LeJp4qv4k8Y4ycZp1YYzE1MTSxdFrKqd fB4uFTFN18HjMPkeT4TGYeUuTEYTLMBh5+5gsKqP8S37R3xm/wCCqXjb9tL4oftWfs7/ALKP7Ynw iXxd4Dtvg94dstc/ZX8TeLNWtPhTarplxPo+pWPiT4b+K9Asb/Wtc05/EF5LpKyXOn3N3JZWerzQ edLc+H/DHx7/AMFyPg58NbD4RfDn4aftoeH/AAFo9rqFjoOmSfsq+Jdc1Xw1ZaoZTeWfhXxb4h+E 2reMPC1qxmk8i38Pa9pkNmGxZpbhVA/vZpkjMkcjKu9lRmVf7zKpIX8SAPxrkpcXYTB5dDBPh3LK +Ew2Do4eUcRCWLqVqGEeJrU41nUpzniJRq4zHV4qSk/b43FVIpTxFVz7Mb4N5lj83xWc/wDESuLc FjsXjcZjW8tqRy2jh6+YLB08V9Uo4TEUqeFhWo5fl1CoqSi6lHL8FCrKawtFw/gV0jxD/wAFq9DT 4FJp3wY/a2U/s1XfiC/+C813+x/qmp3fhG98VaXf6N4gu7q91P4O3l34uuNT07U76GabxtP4jkSS 4a7haK8WO4TrPBPxa/4LtfDuDxZbeEfhx+2Np1t408Y+JPH+s213+yHqWuW1r4v8X3t3qXiTWvC0 GvfBrU4fA02q6jf31/Nb+CU8PWUd5eXVzb20M1xK7/R3wI/4Koftu/HPxF8b/B037d3wc+FyaD8I Lz9o79o/xJ468JfBi11r/gnh4P8Ahr+2R8QPhP8AF/4TeBNJ0L4P+K4de+J0vwR0nwnqfgjw7+0z oPjrUL3xTqFpq91q40jXtNsZYviL/wAFQP8Agp34R+GXwi8U+IPivqPw48RfDn9jvwj+1t4j0PXv gp8I9P1/9pPw18QP+CgOi/s7/DeD44+HNc8A3N38K7nxR+z3qekeNde0T4Nn4YappHjvxBOY307T rGLw9b9+H4vp5gsA3w5kn/CzjsRgYe3pRnzNrPMwxuKxDp0ayngp4rhbOWq9N1/7UxeX1MRlsMwp UpYmPn1vBPHZZPHwh4o8dxlkM8tozWFx9aHs6+IWRZXluHwieMpONalQ4uyfCTi1RWU4fNaWGzGW AWIhSqfl1pf7NH/BSrR/itpvxwtf2Xv2v7j4r6T45sviXaeNdY/Z0+KniDVH8c6frcXiO18RahHr 3gfUrHV7sa1DHfzxataXtnduDHd208DvE30z458V/wDBbD4k6P8AGnQPGvwW/au1rSf2h18Np8Yb T/hjO507/hL18I6Zp+jeHh5+k/BawufD/wDZ+m6VYW2fC82iG78jzr43M8s0sn9O37En7Tf7W3xb /b3/AOCivwR/aR0j4feCfB/wF0D9lq/+C3w6+HPiKLx3p2k+Hvihp/xf1S+8W694+v8A4efD7xPq nizxtY6B4dutb8N3lpe+HfBz6bb6V4cuLt21bW9a/W6tK3G8pUcB7bIcpq0vqWFxGDpzjzrC4fFQ weMp0YQlTaw84SwuDlVoQS9liMJQUl7TCw5OXB+An1OtmLwHiLxhhKmIxSq5hWwtZ4Z5hiK2FlV+ tVqlLEQli5VMPmVeKxFbmdWGJxHJKdKvKVT+Ej/hc3/Bd4+LL3xrJ8Mf2tptc1LwXoHw+1SO5/Yv Fz4e1Twl4WvtV1Hw9puqeDbj4Hy+D9Sn0m81zVpbTWL7Qp9bVb+eBtRaArEtHQPiv/wXd8M+OfH3 xI0jwH+2xH4v+J2laLonjPUL39ljxLrFlqGmeHI7+LQbbTvD+sfCW/8ADvho6SmqakLCfwxpOjXN u19dPHMHmkZv7xaK5Xxnh3zX4ZyR+0pzpTvQh79KrUVWrTl+696nUqr2k4O8ZVEpyTkrnof8QSzJ eyt4qceL2NWnXo/8KOI/dV6VH6vSrUv9r/d1aWH/AHFOpC04Uf3UZKHun8Hfij4q/wDBdLxpD8QI fE3ws/a51P8A4Wl8O9G+FPjyc/saz2l9r3gTw/J4nl0jSDqNj8FLW/027tJvGXiSY+INIudP8SXE 2pebdavPJZ2DWu3rXx3/AOC9PiPQ/EXhzXPht+1rqmk+LvBN58O/FEN3+xTBJceIfCV9Yzabc6fr Gpf8KLGpaheNY3FzbRa7c3kniC2S6uzbapC11cNJ/dTRUz4wwlSLhU4XyKpCSalGeGpyjJSjKEk4 yotNShOcGmmnGcou6bT0h4L5vTq+3p+LHiBCvaC9tDNMVGralKEqa9pHGqdqcqVOUNfclTg42cI2 /gx0/wCJH/BcjTLb4IWlr8Jf2tWj/ZxVk+DUt7+xpPqV54PRvBepfDwo+oal8FLu/wDEqf8ACHav qGjKvi6515VWaO9UDUrW0vIGfC74j/8ABcz4L/8ACdJ8Nvhl+2R4ft/iP4z8Q/EPxXYzfsla1r+m T+NPFd5LqHiLxBouleJfg/rGm+EbzVb2aS5uV8IWuhW/mlWjgj2R7f70aK1qcbU6sqsqvDmT1JV1 UjXlUpRnKtGtXhiq0arlTbqKriYRxFRTclOvGFaV6kVI5qXgXjKH1b2PidxvR+p+y+qeyxtWn9V9 jhpYKj9W5MUvYeywc5YSl7Ll9nhpSoQtSk4P+AJ73/gtDP4R0/wNe/Bn9sHVPDmmfGe0/aEtYda/ ZQ8S63qjfGGx1xfElr4zvfEmrfCe98SanNFrKrdnRtS1e78OyKq2kukPZKLceJfG/wDZ/wD+Cmv7 R3xL8QfGD4z/ALLX7V3jL4i+KV01de8Rf8MuePPD324aRpdno2nD+yPCnw40PQrX7PpthaW2bPTL czeV50/m3Ekkr/6NVZus3E1ppGq3Vu/lz22m31xBJtV9k0NrLJG+11ZG2uqttdWU4wykEis5+IFP LqVXG0+HsrpPCUMRW58PTjTrRgsNhaVeNKSjC0quGy3A4eS54qdLBYOlN+zw1FQzr/R9nm0Vgcd4 jcXY2hiamHpzoY6u8Th5yp4rGYnDurSrV6kJKhi8zzDE024SdOvj8bWglVxVeVT/ADT/APhg79uP /ozL9q7/AMR2+L3/AMx9feH7P/xC/wCC4P7Lfw6tvhP8Cfg9+1d4F8AWeq6prdtoH/DFzeJ/L1TW pUm1K6/tXxj8EvEOtP8AaZY0byZNSa3h27beKJSQf6T/AIO/tt69omg/sB/ED9pL45+B/Anwy+J/ /BOHxn+0F8fvHfxIuvhv8NvBM/xL0/Vf2PNL0Xxnr3izUbLw7ovgu3F58W/F9hDpWl6j4f8AC93d +Jre3k0qeez0NbGL4l/8FG9b8I6/+0l4n07xf4DPwf8Ah14I8QeJv2fJ0/Z5+OHiDw7+0mumfska f+0bY6p4F/a/sfGth+zXqKale3OuR6T4Y0TTtc1vWvDvg3WDYzma4TVLP18141xtJYjB4vJctzCF JZpLEYeM54im5ZNneYZJODpYiEFOricwyutPL6fK6lShKniakaEKOMeGnJ/oyU8DmGHq5JxxxHlm YVo0qWHxeBdLLq8oYxYRVKcMVRq0ZxpwjjKDxn7xUqcHeo2pU+f+Z7WPFH/BbXxBP8brrXvhL+2N rVx+0X4R0vwH8X5dV/ZO8Q6g3iXwdotpr9lpXh7TvtfwklHgvTrG38Ua/wCRF4FHhphNqdxdF2uh FNH6Ivx+/wCC940s6PJ8O/2uruyk8FyfD27bUf2LY9Tv9T8JS2/2VtN1rV9Q+Blzq2uTrA0qw6vr F7fa1btdXssGoxy3148/79WXxk/abn/aP0H9iqf9pbxt/avinwN4G+Nc3x5h+HXwFT4haNo+vfCv 4pX+q/D3Q9Gk+FcvwvXRf+Fh+AdK1ay1HXPhxr3ieHwlqOseHZfEc+qtp3iSw/SL9kX4sa98d/2W v2evjN4qgsrbxR8T/g58PfG3iSHTYGttNXxB4g8MadqGsnT7Z5Z3trF9SmuZLO3eaV4Ldo4mkdkL Hz63FFCVPG0K3DOQVKeCeX4OvRnh4zhKGKwuPo4enCEsO6cqNClg8dgZwlZU43p0ozw1WNSeuA8H cyrKGZYHxU8QYOdSrOeLhmNehWpYitVo41e0l9ehXdXGuNHMY1KaqRlKnCeIqUsXCNNfxZaP8Qv+ C53h/wCDcXwB0f4efts2Xwtt/DMngy00dP2XvFcmu2XhSS2Nl/wj1h4+m+FUvxBsNKissWNrZ2fi mCKzsUis7VYbaKKJLvhP4n/8FzfAw+G6eFvhR+1tpUHwl+GVz8HPAdmP2NJrzT9L+G93H4cim8Na jp2ofBS7sfFCbPCWgCHVPFdvret2zWLvbalC99qLXf8AZT+2l8RPGPwl/ZY+NnxH+H2sf8I/4z8I +DZ9W8Paz/Z+l6r/AGfqCX9jCtx/Z2t2OpaVd4imkXyr6xuYTu3GMsFI8qvf2ufAnwo/aX+PXg79 ob49fCz4TfDfTLP9mTw78IYPir4x+Hvw10/UviJ8UtM+LF5qvhjw5rviW50G98V+KPFI8JWE+neG jqer34j0q4bRNPgja+82XxnTrTrTnw5k1SpjK967lRjOpjMTXp1cDepek5YivXpZti8IudzqVaeO xWH96OJqwq4LwWxOHqYXCQ8TuO6ccFhadPCKnjakKGAwVCazKFOiljIrC4XC1sgwuNcKcYUqFbAY HEpKWFp1KP8AFL8GfhB/wVK/Z7+Lkfx0+Dn7L/7Ungj4oQnxD9n8QWX7JPinULO1TxVb3VprkNp4 W1v4W6n4QtLa6try4ggtbbQYrbTYnVNMisxDCI/MfGf7Hv8AwUF+IPi/xT488X/sh/tXav4r8aeI dZ8V+JtV/wCGa/ihYf2lr/iDUbjVdXv/ALDpngay02z+1393cXH2XT7O1srfzPKtbaGFEjX+zf4j /tWftVfD/wAY/tu2tx4Y8GSj4VeJf2NNC+Bfh3wZ4U+J/wC0abXwR8c/iHqHg/xj8S/GPgb4d+Bv hv8AFTxB4pttIfUfE2rfDTwhqfiXTdDsfCenJovjLUGv9bkbm/j7+0J8fL74I+EfjL8If2nfC8Fy ml/EPwH4N8G+Bvgbc/D3xr+0J+2Jb/ECx8PfDn4E698E/wBoLw18WviL4E8H6VB4f8aaD8WdK03x b4P+J2iyx6l4wn1zwj4Z0G9utM6cPx/XrYjB1IZPlsKrWHynD4mUpRnhqOJoUsxpYKTjGWJw1CdX E4WlTwns4+2zPF0cJQo1cXGvClxS+jhga2X16U+NeJKuAq5vjcZXwk1hpYavm2HksBi81nTnX+q1 a/1ajUnVzScnJZXg6+JrV4YOg5r+Wr4oaB/wV/8AjP8ABb4c/s8fEv4C/td+J/g78J10VPAXg6T9 lPxZpa6MvhzRJ/Duhrca7onws03xNrw0zRbmextR4i1nVtiP5pzcIkq+o/CL4mf8F1PgT8NbX4Qf C34fftr+HPh7p1rNY6Rod1+yz4m8Tz6DYzbybHw7r3i34Ta74j8O2UJkc2dpoer6fb2DNuso7cgE f1a/8FBf2i/i58HPBvwx8O/Ay90fSviZ4p+Jnwk1TxzrGpada63beD/gZD8Y/hr4R+Jl9b2OoWN/ ps+teLbjxpo/w38Mi9SKa2fxPqvinTTJN4RuBH+jNc8uOY4nDYqNXIMorYfFZliZYmjUgqlLG4yj Tw/t8wqRdOdHEylUrVcG8TOU6/1nCYujUUVSjKp6FDwFrYbFYTH4fxI40w2Ow+V4fA4XF0sRUoYz BZYnKeHymFaOIhXwuHpQjTxEMBCUaFOlXw9WMF7RW/zY0/ZC/wCCiUfjFPiEn7LP7ZieO4/Ea+MI /GK/Av41r4mTxUmpDWE8RrrY8KjUF1tNVA1JdTFwLtb0C5EomG+vsf4t/EL/AILnfHPSPB+hfE74 d/tsa7pfgPxNoPjPwxb6d+y74r8IyWnirwvdRX3h3Xr+78GfCnw/ea9qWi38MV/p1x4guNUa2v40 vY8XSiWv7zrlrlLa4azignvFgla1gubiS0tprlY2MEVxdRW17LbQSShEluI7O7khjZpEtp2URP8A jxL8b/2u/E37LfxJ+Kfjv4jf8KW1b4R/tEftV6T8V7v9nDwNN+0V400j4ffDPVfH3hn4WeCPhJom tfs2+I5PHqQ+IIvBNz448UeJPg/oOrnw7p/iG8F3o8bNqFrFfxFsoutkWX1Fk2Feb4a8XUlhI4bG ZdhFUy+Di6kcVTq4jCzgsJD2kY0acU1XeDpYhYP6OaoRrwwPiBxVh1xHj6eS4+lhp+y/tWtjcHmu MjTzSNGqo4nD1qeFxlKbxjnGVTEtyi6Lxlah/Ol4++MH/Bdf4n+EfHvgXxx8K/2sda8K/E/RrfQf HWlp+xVHpP8Ab9haxiGF5b7RPgbp2pWOqLEsUTa7pl5Za5LHbWaS6i62VoIcT4i/EH/guZ8WfhVN 8FPiD8Ov21vEXw4vNPsNK1TSJP2W/FOn6rrum6a0TWtj4k8YaT8KLDxp4mtS0MZuodf8Q6kmoYYX 4uRJIG/q+8TfGD4yeMPhd+wF4bsviDD8M/iD+1dc+G7f4j/Er4V2Xw+8YPoLad+zR49+NviU/DV/ G+h/EX4d3Nrr3ijwdYaNaavqXhzxdp//AAil/qUmkeXqM+l65Y/Rn7I/xK8UfF79nD4T/EDxvc2l 94x1nw7LaeKtSsLCPSrLV/EPhzVtS8MavrVrpcMs0OmQa1f6NPqsenwyvDZLeC2iIjiUDevxTTwG JxOFnw3kFOtgMfGMFSpQcatfBTnThjcLOnRcVHC1qLp0qtR0cRGThOhTdO9ROj4O4vMqGHxMfFXj 6ssyypVKka2PxDqwwOOV5YDGKeLaar02qlbDQlXoOEkqsud8h/GdrPxe/wCC6niG98fXuu/Cf9q3 WP8AhaHgHSvhh490/Uf2JoLzQvEfgjRF8QppukXPhuf4GP4ftpoI/FWvQvrNhplprt1BfCC71OeK 0sUtsqf4j/8ABdG5+FB+Cc/w9/bYk+HzeFP+EGe2P7LnikeKpPCH2b7GfD0nxIX4UD4kSaW1p/or 20ni1le2JgctESp/vSr8/Ph1+1H418QftbfE34MeOte0LwR4T0r4la14A+EHhbVv2Yf2gtB1L4p2 /h74O+B/iDq2p+H/ANqLxD4os/gF4o1u11XVvG1wfBXhHwxqOuv4Y8HaqVP2nQfEWo2PPT4vw+Jq 1cIuF8jnKWDqY+tCWGpuNShl1WlQTcfYydapRnmr9lBRnKlSr4qu/Z4eGKqx6ZeCmY4eFPELxU49 hyVXg6U4ZhiVKEsfD21eCnHFqNClXp5ZGpiJVJ06VaWEw1JupiPqlGf8cHxF8Of8Feviz8Dvh/8A s3/ET9n/APa08T/Bn4WvpD+A/CV3+yb4ntrjw+NA0y80bR4o/FWn/Cmz8ZX9tp+lX1xYwWmq+Ib6 2Fv5CNC32S0MHy//AMMHftx/9GZftXf+I7fF7/5j6/s38W/tleNvCH7cFn8MdY+M9hpcmp/tZ+Bf 2dtB/ZVv9H+H1vceIvgr4y/ZytfiJH+0VplxPoEXxfvL5Pixdaj4bHi6x8YT/CSPS/Dl94El8IDx 1Hd64n7F12YfxBrwoPG4bJ8upwx9dYnESpOpTqVcbisvyzM5zxTjCKq4yWBzLL54iblVqU6s3hMR OGLwuIoUfIzH6N+AxeJw+GzLjfiPHVsDlmHo4NYynDEfVcrpY3M8DhsJhfrU3KjgqWLwGYLC0aKj hZ0nHF4T2mFxVGvW/wAz3/hg79uP/ozL9q7/AMR2+L3/AMx9H/DB37cf/RmX7V3/AIjt8Xv/AJj6 /wBMKvx0/bG/aJ/aS/Zo+KPi7xrpnxZ0zxdp1jo/xO+JPhf9lzw34b8Hatomlfsx/CT9l/xP4r8V /GH4ua9eeAtO+JvhfxhP+0Zp1j4V0G7034ot8PNW0PVPCPhmz8PXXibUfEd5pLfiXjlLlWV4aUnT qThGNapeo6XI5U4JtXmqbqV5t2p0cLQxOLxFSjhcLXrQzwv0VMlxlT2VHirM1Uk4RpwqYbBQdWrU nGnSo05SfK61erOFDD05SjLEYmrRwtH2mJr0aVT+Mj/hg79uP/ozL9q7/wAR2+L3/wAx9H/DB37c f/RmX7V3/iO3xe/+Y+v72/2V/HXxTHxR+MPwV+KHxN1n4wXHgz4afs7fFrSPG3iTw34B8MazB/wu jTfiLYa/4U+xfDjwp4L0CbQtG134YXeqeHZrrRZ9ft7DxC2m6xr2uyWMF5X5seFv2/v2jG8ffFHx P4m8chfhHP8AtMfAfx58LdOHhLwLBbxfsgeNv2oPiP8AsR+M/D39qw+HDq2pafaeJ/CPgz4/Xni+ +1CXxTp1v8Q7TSIPEUPheKDRk6KniJj6OMp4Krl+AhUq1MNSjOeKnCl7bEYzB4aVNuTU39VoYjF5 ni6kacqFHLMozTE+1lKhh6WK86h9Gfh7E5fVzHD8TZ3Vp0lzfV6eAwcsZUU6FephfY4aMnOo8diY 4LLMJGPvTzPOMpwtWNL6zOdH+Uv/AIYO/bj/AOjMv2rv/Edvi9/8x9H/AAwd+3H/ANGZftXf+I7f F7/5j6/pb+F3/BSz9rfW/hrqWo674v029+Ifg62/a/8A2hdRtb7wB4Zs9D1T4G618Ofgx49/Y68F eJbbT9D06+03T/DUH7Xfwoh1jVtGudL8YeKZ/hTrttq+u6k17rz3f7R/s0+J9e/4T340/DHWv2rv AX7UP/Cv18CSylNd+ErfHT4beJdVj8UaV4x8LfFfwZ8GfBHgLwr4Y8Nzat4Yiu/h1cahoi+Kry6H jjRtdnuV8N2FzNc+Ps1pwozq5Th6SxGX0cxoqpPEwqTpVKkKVWk6Th7SlXwdaUsPjI1o06dDEwqY b2kq8HTelT6MfD9OtXoPifOZTw2NrYOty4LB8sYxqVIYXG80pRTwWaRp+3yuor1cZhKlHGRoxwtW FV/wA/8ADB37cf8A0Zl+1d/4jt8Xv/mPo/4YO/bj/wCjMv2rv/Edvi9/8x9f6YVUtTk1KLTtQl0e 0sb/AFeOyupNLsdT1CfSdOvNRSCRrK11DVbXTNaudNsri5EUV1f2+j6tPZwPJcQ6bfSRray8svEv GxjKTyzDNRTk1GpiJyaSu+WEIylJ6O0YpybaSTej1j9F3IZSUVxTm15NJc2EwMY3bsrylJRiu8pN RS1bS1P80r/hg79uP/ozL9q7/wAR2+L3/wAx9H/DB37cf/RmX7V3/iO3xe/+Y+v7Kbn9qf8AbPT/ AIJsfE34+RWXwl/4aC8J/Gr9pHwn4uuT4uvE8IfDfwX8Of2qPiX8Mw/w4uT8EJk+K+seB/Bvh7S9 E8I2vjrwT8OI/HUtnHrvjLWdDv5r2C59C0n9qjxL4x/be8ZfDaD42a74F8PfC39oTQvgIPhNe/Bf WNU+FHxNs9T/AGatD+MGpS6l8dR8I7yy8K/G6fxJ41tZvBvg9PjXoOnX3hDwW8dz4J1rU/FFrdp0 f8RCzJ4mWEWWYKVWmpyqcuIqNRp06uV4eVaKXv16X1nOMBh4zw0K3NUrTcU6eGxNSlFX6MPD9Gpj 6dTinN4vLniI1ZSwWDjGpUw1fNKE6VNzcXCrJZPjq8aeKWHlHD04VKqpurCL/iU/4YO/bj/6My/a u/8AEdvi9/8AMfR/wwd+3H/0Zl+1d/4jt8Xv/mPr/TCr5v8A2p9Q8ZaN8Lxr/hv41aD+zv4W8NeI dN8TfGP4xauPCh1PwZ8HfD9tqOr+MLnwiPH/AIL8f+Al8S6hJaaXpKT+MPDV3pVnot9rV7bPHrdv pIfkq+J2MpRU5ZZhXH2lKE5KvOMacKlWFOdepKcoRhRoRnKtXm23CjCcoxnKKhLWn9FvI6snCHFG cOfJVlCCwOFlOrOnTnUjQpQhzSqV68oqjQpxV6ladOF1zXX+eb/wwd+3H/0Zl+1d/wCI7fF7/wCY +j/hg79uP/ozL9q7/wAR2+L3/wAx9f2z+Iv2hPjNoX7Hf7KHjb4nfErVvgdefFr4l+FPCfxf/aF1 /wANfDzwj4h+Gvww1mz8fax4N+Inizw/8SfBd98Mfh94t+JQ0D4aeEvEVn4o+H8eheE/FPxMu9Ot fDei3ttp1vp3jf7OP/BRr4lfE+/+EA8V+MPC/hr4Xap4e8M6bqfxi1P9lv45fELw18XfGl9+0/8A G/8AZ6tYLb4zfDXxR4Y+BHwKu/GOn/C3wbrWlt43t7/T28R/FDTI9L0mXTFs9Jl6o+IWZSr1sOsr wqnQzVZRO9aspfW3hVi0vY2+sxcoONOGHqUIY6pVklSwk4RnUWEvox8Pxo0K74pzflxGUxzmnFYT ASl9UlmcMpUZNTdP20cTP2lSKnKFHCL61WqQoShOf8fn/DB37cf/AEZl+1d/4jt8Xv8A5j6P+GDv 24/+jMv2rv8AxHb4vf8AzH1/phUVl/xEnHf9CzCf+Dq3+Xr/AEtdP+JX8h/6KnN//CPBf5n+Z7/w wd+3H/0Zl+1d/wCI7fF7/wCY+j/hg79uP/ozL9q7/wAR2+L3/wAx9f2N/tyftUfF34P/ALRfxF0D wr8Z/ip4E0H4f/s9/s1fErwf4O8K/BXwz45+EviDxn49+P8A8XfBXjCT9oD4nah8C/iDffCj4c6j 4Z8J+HNP1XxRqXxQ+EeleHdItdc8Radr9reWOo30H0l+zz4z+Pfxg8YRfG6T43W1n8Mr39oz9p34 M6j+z7r2hfD218NW/gj4MeNfiV8KPCuufDzxHpfgW3+KOp/FG98U/C+18ZeIIvEnxF1XwdJ4V8R+ L7Ox8OWlxoug3VvpR8Q8xrUYYhZXhIYecsbD20q1V041cFWpUPYylT9petialR+xpw5pUowc8d9U jOi614v6LWSYOrXo1OJ84nKgslcnTweBSn/bmTVs9wyp+1lSlP6vgMPU+tS5VBV0qGHliZyR/Cl/ wwd+3H/0Zl+1d/4jt8Xv/mPo/wCGDv24/wDozL9q7/xHb4vf/MfX9i3jP9q34u+Hf22PHvgcfGb4 p2nh3w7+2X+z/wDBPw98LLj4LeGf+Gdp/hp8SP2cfhn408WQ+Lfj5/woue+8P/EW48V+KNf1TwJo uoftA6Lreu+K5/CHg/T/AAtq+n69p+kah1enf8FQPHFh8NP2Vfix8SPgD8LfAnhj9qW/+GX/AAjm jx/tWWOufEFdH+LfxF+G/wAO/DA8HeArn4L+H9b8feJtEk+IK+LfH9gi+GvBfhLwnY2Lr8RdW8S6 0vhrTzDeImZYuGElQyrCyeNxmAwFCMqtaCli8zwGDzDA0XWklhubEUsZGjBqvKKxdDE4WUo1qEou 8R9FfJsPWq0Z8TZxL2OAwGYznTweCmvq+Yzx9Ogo001XlOEstxLrpUeWnD2VXnlSrU5y/i+/4YO/ bj/6My/au/8AEdvi9/8AMfR/wwd+3H/0Zl+1d/4jt8Xv/mPr+uvxR/wUN+Pmq+DbrQvhR4UN1qPg j9oz4O+Gvi78V/GHjfwYniDw54F+Kv8AwUp8a/sy6R4b8FeA9N+CMHhbxxDd+Avhn4o07W7vVbvw Jr3gzw1rXh290vxH8R/H9rqniAfuvVPxCzKOHWJllmDjB43FYBRdeqqvtcHh8Bias3Sa540Z08wo qhUmoqs41J01KkoVKmK+i/w/KEZx4rzWSk7e5hMHOKfJCfK6kW6Tmo1I+0pRqSq0JXp4inRqrkP8 z3/hg79uP/ozL9q7/wAR2+L3/wAx9H/DB37cf/RmX7V3/iO3xe/+Y+v9MKvjX9p34o/G/wCHvxS/ Y80P4eWXgmD4ZfFH9oa08A/GLxDq3iC8HjaPRrn4b/EfxDpHh3wl4Nk8AazomoWms614csJ9c8T3 Hj7wpq2g2lgLXStL1o6rcS2GC8Ssa6uFo/2bhObF4zB4Gm3WqqEauNxNLC0pVJuyhTVSqnJ6zlpT owq15U6VRv6LuQqji63+tOb8mDwGPzCqlg8G5yo5fg62NrRpxTvKrKlQnGmnywUmpVZ0qMalWH8A /wDwwd+3H/0Zl+1d/wCI7fF7/wCY+j/hg79uP/ozL9q7/wAR2+L3/wAx9f1y6H+17+0B48+OWo/B LwX+0VoEHxd+KOsftk+GdX+DeseFvAE+qfsl6X+z/wDFzRNA+G3jTQdD0L4e618RbzWvHfwV/tjx ppFh8YrX4meH/id4t1fwxrfguz0LwCl5pVx+iP7C3xV8V/F74OeIvEHirxh4j8ejQ/jR8Y/Avhnx Z478G6b8OPibq/hDwZ441PQ9Al+J3w80vwj8PovBfjSGC2kt7nR7n4f+B9Rn0iHRtav/AAxplzqz o7p+JONqqPLluE1wCzHWrX5fY/XaeBcFVjGVGpUdWrGdOVKpUoYiiq08NXrvC4qNFV/ov5Bh5OMu Ks3bWaVcpaWCwkKkcTRw2JxUpToVvZYinS9nhasZe0pQq0qkqEa9Kl9ZoOp/AT/wwd+3H/0Zl+1d /wCI7fF7/wCY+j/hg79uP/ozL9q7/wAR2+L3/wAx9f6YVfnXqf7RPxX1v/gor8N/gn4Sv9JtP2dt K+F3xq0z4hMdMtbrWPGXx48PWvwk8U2OnWGq3Vi1zpmh/DPwZ4xsf7RbRr9Ydd8ReO7nStSAuPBc sFKPiVjZVqdD+zcIpVKeJquTq13GnTw2HnWlUqcqlKMKlSNLB058rh9cxmEpVJQjVdSL/wCJXch5 Jz/1pze0XTil9TwfNOdSaioQV7SnGHtMRON01h6Feqrqk0fwo/8ADB37cf8A0Zl+1d/4jt8Xv/mP o/4YO/bj/wCjMv2rv/Edvi9/8x9f1l/tJf8ABSDx7+zp8ZPiBNefFbTta1zSvil+0P8ADu2/ZG1D Svh7ay+Hvhh8Kf2MfHv7RfgX45QNBoen/GC+l8Y+Mvh/aabceI9Q8a3vwyvtC8ZS+GdK8O2PinRG 1WP9EP2VvHXxT/4Wj8YPgr8UPibrPxgufBvw0/Z2+LWkeNvEfhvwD4Y1qA/GjTviLYa/4UFl8OPC ngzQJtC0fXfhhd6p4dlutFn1+3sPELabrGva7JYwXla0fEPMq2Eo46OVYVYbEYDAZhSnKtWXNDMI OrSw7iuZxxVKilVxMGlToc6oSqvFQq0ITivov5Hg54aFfibOY/W8TmeGw8o4TATjP+ycZ/Z+LrNx qNwoPG/uMPKajUxCccTSpywdWlian8En/DB37cf/AEZl+1d/4jt8Xv8A5j6P+GDv24/+jMv2rv8A xHb4vf8AzH1/phV8Bal+09430z9sTWvgvr2u6D4F+GdnqPw68K+Dv7f/AGZP2gtZT4m+M/GXgvWf FN3o1h+1Jp/iXS/2ffBWpC5g07S9G8L6voWu+JL29t7rTlt59Q13QYaxXiXjfaUqX9m4XnrT5IKN SvOUpOyUY04RlVqSnJxhCnShUqSnOKjB6sJfRgyCFOrVfFObqFGnOrNvCYGMYwguacp1JSjTpQjF OUqladOlGMW5TWl/4Ov+GDv24/8AozL9q7/xHb4vf/MfR/wwd+3H/wBGZftXf+I7fF7/AOY+v78f 2Pfiv8bPiRpn7S03x5s/B2l+K/hv+038Q/h9ovhv4fa5eeL/AAv4c8EaD4P+H2s+GdK07xXf/D/4 a694ou57bXZtY1e/1nwfZ38Ot6tqGj2c19o+m6VcScl+wh+0/wCNv2i/Cb3fxW1zQ9K+J0ngT4ee PtZ+Dq/sy/Hz9nHxR8N9O8dRa40C3s3x48Vaxc/FfQ5NQ0i/0Cx8deB9F0bwvJq3hzW0Sa7a5gt7 HSn4j4+pTo1I5Zg3GtlOTZwkq9SUo4bPMvpZlgqcowcm6scNOf1iVP2mFo1KUoPEyVTDyxCj9GHI ZQxlRcT5xyYLNswyas3g8Ck8VluZ4rKq9SDc7OhPFYSXsZScatSFWh+5jUnKnD+Dv/hg79uP/ozL 9q7/AMR2+L3/AMx9H/DB37cf/RmX7V3/AIjt8Xv/AJj6/wBMKvyn+Mf7U/iSx/bIv/hRY/HPW/hB 4f8AhXrP7Lenz+G2+Cmr+M/hd8T7/wCOfivxFaeJPD3xe+LUPwn8WWXwtvdb0C20Hwv8CTa/E/4T vqfxUvPs+uTeMtPvLbw4IXiXjPa4elLL8HB4ivToRk6tdqLqSUVNwhGdapGLavDD0q9azvGlNRlZ y+i/kEadap/rRnD9lSnVUI4HCOVT2a5nTjL+FTk43aqYmpQw6tyzrRlKEZfxK/8ADB37cf8A0Zl+ 1d/4jt8Xv/mPo/4YO/bj/wCjMv2rv/Edvi9/8x9f1xfCz9ur46ePvh3ffGH4Z/EnxH8TPEHxH8Ce GPiLY/A/xh+yT8VNWtPhN4Z1n4tTaDN4s+CWh+APhx8KfiB+0n4G8NeENT0zwx8Q5PD3xM+J+paT 42Gg+KI9X8OeGtVfRNS/Qv8AZN/aPl+N769P418WeDvDvjzXbTT9d8O/s+w+IPDMnjrwV4P8M2On eDvGPijUNDjaPxjfaLrXxftPGtlpXiW+jn8P3fh2y8KPpT29xe3rXulLxFzGrTnUWVYaDp8ynTq1 a1Oo505TjUhQ5lyYz2apV51J4KeJowhQxDlUTw1dQnEfRiyDDYmWErcT50qsakqUnHAYSdOE408P UUa8oN/VKkvrNKMaOLWHruU6V6Sji8FLE/wJf8MHftx/9GZftXf+I7fF7/5j6P8Ahg79uP8A6My/ au/8R2+L3/zH1/phV+eP/BQXxr8cvht4KtfH3wz+N8Hwf8PaB4M+IcOl6F4c8NeDfGXxU+N37SOs jwxpv7N3wb8N+F/Hvw78daVrPhDxbq8ni+38Y6f4Wu/CnxEur7/hFRoHiPSNFi8TalZ5f8RLxqlT j/ZmGvUn7ONqleTc3GTp04wipVKlWvOKw+GoUoVK+IxVahhqFOpWqwhLoo/RZyGtPk/1tzGiuWUp VcRh8DRo04xTlKdWtJ8lGlCKc6taq4UaNOM61epTownUj/CX/wAMHftx/wDRmX7V3/iO3xe/+Y+j /hg79uP/AKMy/au/8R2+L3/zH1/aF4A/ad+POrft8QfB/wAT+Pb6DRZPiL4i8Dat8JofA3hxfhDY +B9D/ZQ8BfFR/EHhv4yx+DDrGtfH6z+M2t6jpWr/AArf4s3upWXwsmvPE1z8JrHSdNtvHEvvvw6/ aj8a+IP2tvib8GPHWvaF4I8J6V8Sta8AfCDwtq37MP7QWg6l8U7fw98HfA/xB1bU/D/7UXiHxRZ/ ALxRrdrqureNrg+CvCPhjUddfwx4O1UqftOg+ItRseiPiFmE54eEMvwFSWJymWdU/Z4mrUj9ThPC U5JTpqUKleMsbQVSjQlVdD9+67pLB4z2HFH6NHDsqdSo+Js8hGli6WBkqmXYanL6xVpVq3LJSt7K EKeGxDlVrulTnKlGFGVWeIwkcR/CB/wwd+3H/wBGZftXf+I7fF7/AOY+j/hg79uP/ozL9q7/AMR2 +L3/AMx9f6YVfDP7cXxf1v4U6Z8CbJPjGf2cfAXxH+Mk3g34o/tBfZPh5Ivwz8OWnws+JPjLQF/t b4t+GvGPwx8NP438feFvCXgRNa8Z+GtTs5h4gfQNF+xeLNd8PajZ80/EzGwjzSyzCW5oR/j1FrOc YK3M48zvLSEeapUdoUoVKsoU59cPouZFPntxTnH7ujXrytgMPUfJh6FSvU92lGpP4KcvecVTh8da dOlGdSH8Ef8Awwd+3H/0Zl+1d/4jt8Xv/mPo/wCGDv24/wDozL9q7/xHb4vf/MfX9gHwW/az/aQ+ IUv7CXxZ8R/Fd4fD/wC0/rvgfwjp3w18N/C+wh+EHijw9pPw98fXPxa8d+O/iTrPw0mvvh78S9e8 Z6Laah8Jfh/o3xvij1zS7HTdJtPBmv3V34jm036/8c/tR+NfCX7Yy/BnXNe0L4efB6PR/gXaaTr/ AIi/Zh/aC8aWfj/4h/FjxD8SNJu/Bdv+0l4d8UaB8A/hdqRPh7wRo3hrSvGVhrOsah4l8VWtgLa7 utd8O6bcbw8RMwnUVKGW4RylmVfKor2mJjOeJoLDNulSlTjXrRqPFUqdOFGlUxCr+1w1ShTxGGxF KnhU+jHw9TU3LirNmqeWYbNXKGEwM4LDYmpiacVOrGTpUZ0/qlapVniJ0cPGh7KvGvOliKE6n8IH /DB37cf/AEZl+1d/4jt8Xv8A5j6P+GDv24/+jMv2rv8AxHb4vf8AzH1/phUVn/xEnHf9CzCf+Dq3 +Xr/AEtdP+JX8h/6KnN//CPBf5n+Z7/wwd+3H/0Zl+1d/wCI7fF7/wCY+j/hg79uP/ozL9q7/wAR 2+L3/wAx9f6YVeN/tDeJfif4N+B/xT8V/BnQ/BfiL4neHfBHiHWfCGlfELxXq/grwfNqmnabcXST 614i0LwN8SNUtYLKKKS9itrfwfqg1O4t4dNmk06C7k1K05sZ4p4rBYTE4yrleHlSwtCriKkadSo5 yhRg6klBScIczUXZznCEbpznCClJb4b6K+SYvE4fC0+Ks0jUxFalQhKphMHGCnVnGEXNrmainJN2 jKVtot2T/wA6H/hg79uP/ozL9q7/AMR2+L3/AMx9H/DB37cf/RmX7V3/AIjt8Xv/AJj6/wBFn9m3 xd4g8f8A7O3wE8d+Lb8ar4q8a/Bf4XeLfE2qC1srAal4g8R+B9D1jWb8WOm29np1mLzUby5uBa2F pa2Vv5nk2tvDAiRr7TXpY3j/ADLAYzF4Gtl2BlVweJr4SrKnXrunKph6sqM5U3KEJODlCTg5QjJx abindHm4D6NfDmY4HBZhQ4nzuNDH4TDYyjGrgsDGrGliqMK9ONSMak4xqKE0pqM5xUrpSkrN/wCZ 7/wwd+3H/wBGZftXf+I7fF7/AOY+j/hg79uP/ozL9q7/AMR2+L3/AMx9f6YVeW/Gqy+Jeo/C7xfY fCDxFp3hD4g3lhb22ieK9R05tYHhq3l1CzTXdd0zRv8AhG/F8Gs+JNK8PHVr7wppF/4Y1zStU8TQ aTYatp8+mXF2tcc/EzG04Sm8swrUU5NKvUjot/em4wit25TlGEVrKSimzth9FzIZzhBcU5unOUYp vBYRpOTSTahzSe+0Yyk9lFuyP84//hg79uP/AKMy/au/8R2+L3/zH0f8MHftx/8ARmX7V3/iO3xe /wDmPr+/b9hb4q+K/i98HPEXiDxV4w8R+PRofxo+MfgXwz4s8d+DdN+HHxN1fwh4M8canoegS/E7 4eaX4R+H0XgvxpDBbSW9zo9z8P8AwPqM+kQ6NrV/4Y0y51Z0f7MrR+JGOUaUv7Nwtq2Hw2JinUxE JKnisPSxNONSnUjGpSqxp1Yxq0qkYzpVFKnNKUGjKP0Ycgm6yXFGb3o4nF4SbWEwEoupg8VWwlWV OcJzhUpSqUZyo1YScKtJwqRdpI/zPf8Ahg79uP8A6My/au/8R2+L3/zH0f8ADB37cf8A0Zl+1d/4 jt8Xv/mPr/S11OTUotO1CXR7Sxv9XjsrqTS7HU9Qn0nTrzUUgkaytdQ1W10zWrnTbK4uRFFdX9vo +rT2cDyXEOm30ka2svxz+wp8V/jR8Yv2dL7xt8bIvCT/ABbtfjX+1R4L1TSPCurS3fgrSV+Gf7SP xY+Hvhbwrovic+CPCGp61oPh/QPC+jaBbeL9U8B6T4h160sRr+taGNYvLu3YXiPj3Tr1f7MwvLh4 05VF7TEOUlVc1FUoqLdWS9nPnjT5pQvTU0nVpKps/ot5GqVOt/rTm3LUxlLAx/2TBJqtVw2LxUZT bkoU6fs8HVXNUlFym17OM4wrzo/wIf8ADB37cf8A0Zl+1d/4jt8Xv/mPr/Qq/Ys0HXPCv7HH7Jnh jxPoureG/Evhv9mf4D6D4h8Pa9p15o+uaDrmj/Czwrp+raLrWk6hDb3+l6tpd/b3FjqOnX1vBeWV 5BNbXMMU0TovJ/sTfE/4zfFf4a/EXWvj1b+ENP8AiD4d/aM/aB+H8mi+AtYufEnhLw94d8C/EvW/ DvhTQ9H8T6h4J+HWreJ49P0CysY7rX9Z8G6HqepXzXU09oieVX2JXzuf8U4jiHC5eq2FoYeDoYXM aTo1XVbp5hgqGJpQlJOVNyjSrRU3SnUp86l7OpUhyzl+h+HXhLl3hvmeeV8Fm+OzKrXqYrJsRDF4 ejQhCplOZYjDVatLktUcKlbDzdNVYU5+ycXOnTqc1OPkfxw+DXhz4+fDy7+GXi7VvEmkeHNR8SeA vEWqP4Wu9MstQ1SHwF478OePYfDd9Nquka1bP4b8T3XhqDw/4ttI7OK+v/DGo6tY6fqOk3txBqVr 538TP2WtE+K/xG0Txr4o+K3xmPhHSvE/wy8bX3wMtvEHhO5+DviDxl8H/EB8W/D/AMSXen634I1j x14du9I8VW2heItQ0/4fePvBmg+J9U8L6DL4q0jW4o9Rh1L6gor5eDdOdGpD3amHxcMdRmkuani6 aoqlXjLfnoSw9Crh7trD4ilDE0VTxEVVP1yT5qc6TtyVKU6M7JKTpVNKkOdJTiqkXKnNxknKlOpR k3SqThLw/wCNvwL0r41W3ge5/wCE28d/DDxr8MvFsnjX4e/En4bS+D/+Et8Ka3eeG9f8GayLaw+I fg74heA9Z07XvCPijxB4f1TTPFPgvX7IQaiupafFYa/puj6vp/R/Bv4UeGfgb8MfB3wp8Hz6xeaB 4N0s2FvqfiG8h1HxDrd5c3dzqes+IPEF9bWmn2t3rviHWr7UNb1i4s9P0+zl1K/uWs7CytjFaxem 0UJuKnFbVJwnK/vNShGUIqDld042k3KFNxhOVpzjKaUlMkpShNr3qdOVKLWj9nOaqOMrW57TvKDn zOnzVFTcVUqKRRRRSGFFFFABQRkEevHBIP5jkfUc0UUNJppq6ejT2a7MD8Tfih/wQv8AgD8X7j4l 6r45/ah/bf13xR8Q/EHgPUdP8Za98UfhR4z8TfDvwp8OvjHq/wAevDvwr8K3nj/4GeLbTxL8Nh8T tUtdZvNK+Mdj8U9bl07w54X8MQeIbbwzotvpB9D+MX/BHj4M/tB6h8Ndd+Nn7RH7VvxE8UeDfBGn /C/4ieKdT8R/A7RtV/aP+F2ifGbTPjx4b+HvxvtvCXwC8PaEvh/w34+0XS5dKuvg/o3wj8RvpNp/ Z2p69qIub2a5/W+inh28LHCwoP2ccDi3j8HFe8sNjJ4WeDr4mjzc3JVxuGq1aeYyX/Iy9rVnj/rN SpOUliEsVLEzr/vJY2nClipO6eIp0a1DEYaNVxtzLBV8LhauAvrl88JhHgnQ+q0PZ/N3w9/Zd+H/ AMNf2j/2hf2n9B1fxhc+Pf2lPDnwY8MeOdG1XUNFn8HaRp/wM0nxVo/hGXwlp9n4fsdasLvULXxd qT+IpNY8Qa9DdzwWLabb6RHFcRXP0jRRQ5NqEW21TpwpQT+zTpxUYQXlGKSQWSlKSSTnyczStf2V GnQp7ae5Ro06at9mCCiiikMKKKKACiiigAqKeCK5gmtp0EkFxFJBNGcgPFKhjkQkEHDIxU4IODwQ aloqZwhUhKnUjGcJxlCcJJSjOEk4yjKLupRkm000002noNNxalFtSTTTTaaad001qmnqmtUz42+A n7FPgX4AeJfBviLSfiP8W/Htv8LPhRqnwN+C/hr4h6h8PrjQfg98KNZ1vwxrOoeD/Ccvgv4c+CfE WvwzJ4F8BaONc+J3iD4geKI9H8GaPEmuLe3fiC/1ryb4vfDH9k/4hfHLxB4Z+Mn7XF/rt5atrnjz U/2PvFXxv+FreGfDmqX/AME9b8Eat4ysvBl1oq/HDw/pkfwo1XxD4hHha18dW3wutbu/1T4jReC0 12abXj+kVfhd+1L8PvjjrHxI/at+GX7PN7+1G/iX9qCfx/pfxI8HeL/gl4RtP2Y28Hal+xDL8OPD /wARvh7+0Pp3w7j1G11608d+Ffh34dsfCuq/He18Ut4pk8UR3Pwih8LTweMqWJq1a/PCtVc3DL8w lSnXVXEKdatjaWLnGslP21RVMfi6+d4uuo18Q8Rhq2PnKjVVTMsL6GXQhWxbnWxksGq1ak62JjLl lTg6fsK7h70IxTy+FbBUcNCdGGJdallsFNYtYavsW1j+xz/wibfEm0/az/a+f4r2Xizw34e0T4tQ /B29n/aei0WP4L+JYPDXgrw18Fv+GRJH8XfC2b4Sal4y8Z2fiw/AHxRBeRnXviM3j2bVNEbXdL/W j4IaL8NfDnwZ+E+gfBq4sbz4SaN8OPBemfDG80y+bVNPvPAVn4d06DwneWepuzvqMF3oaWNxHfyO 0l4JPtEjF5GJ/Gyxl8Vw/ta+Gv20JPhF+0dH8E/DPw38B/BTVfDw/Zy+NrfEmPxnonwe+MD6h4ht vgxH4Kb4m6t4XtdZ8b6F8PF8aaF4L1bw/LrN1cywaw/hayv9bt/1D/Yl+Hniz4S/sffsxfDLx3ZP pnjTwL8Cvhj4Y8U6XJLHPJpOvaT4R0q11PSZJopJYZJNKu45dPd4ZZIGa2JhYxbDXo1Eks3SrTqK GLyRRqupCSxylgs1/eVJ2csRKhCnSxlKcKko0qedutWVStmDxmM+ey9uphcLOph4YCpFYuMcCqM6 ek6tGdadONqUcPHCVbZbVo1aMpyq4VU8PLD0MI8HS9a+L/ws8K/G/wCF/jv4R+NhqX/CKfELw1qf hjW5NGvm0zWLW01KAxC+0jUVjm+xapp83lXun3LwXEUV5bwvNb3EQeF+H+Cv7P8AY/B7WPiB4u1D 4lfEn4w/EH4my+FU8W/EH4pH4eQa/d6V4I0m50jwpoFppfwr+Hvwv8E6dpOjx6hrF7H9j8JRalea jrepXWpaje77WO19/orhi+Vza/5eQjCSfvJRjNTThGV1Tm5JKVSmo1JwSpzlKmlE7ZU4TdOUoRcq U3OE1FKd5QlTtKcUpTgoyly05uVOEpSnCMZycn8HfEnQ/wBnlPGf7U2v6h+0x4u+BPjdNB/Zq1H4 wePNH8e+Gvh3afB228Lav4rvvg9qNt4m8ZeF7nwKY/GN5caxYeKfCnjqXxx4Y8UaXJZaF4i8KrpG vpY618leIfDn7GPwe1f4I/FTTf22/jQmup4f+P8A4p0P4q/Dbw38Jv2hdN8TWvxE+KPh7Wf2gPjl 491zQP2Xfi/4C+FmlReMb/QfC3in4jaTb/CP4Z+D9ClXwkz6PpFrNa29v4tfs5+G9B+IX7d+oaP8 Mfi38MPBPxF8XfsEfFnVPGn7LHwN8K+IfHHiv4gfD/4oax4w8YfETSvC2peCPEmi/FrxBoV3oPha 7+KTWfg74leOrjwvCsFv4V8Tas2j6LecB4x8Q/FP4v8AgnwD8Ivjh4A+NjeGvi5F8ffDfxO/aW1D 9jj4oa78c/E/7Ilh8XE03wL8GtU8OfBz4G/Z/hH49/aD8KrpGqeNU8UeGPh2vhrwdot9rlv8O9K8 e6rpY8J6YKzxeCbnKFR4xU6kYSUZRhVyOn9cdGrOUqc413VnRqUKtCNTH4DJ6zw2DzTMKFDBYOUo vLazdvZ/2jW5qPspTvGjmeIeDxcqHPzfWFGOJUKsavsMDjs2w1HEYvAYHM62Lq/YH7Xf7Pf7F9/8 Mj4m/bPv/D/ii21T4rfD7Q/Cvxh+JPgP4YeJfiToGo+O/jx4a1b4Y/BbwNrmm/Cq8v4fBN9451HR fA+naKmj6jqVx4Y1G+m8SeILq8fU/FKfowqqiqiKqIihURQFVVUYVVUABVUAAAAAAYAxX43f8FDP Anx0/aD8N+Cdf+Efwf0rx78PPgz8SPChsPBfj6f4s/Db4iJ8YvDP7QXgHw23xI8N+Bj8AfG0ni3w J4a+H2neMV8PeNrXXNK0a48M+MvEHjrTV1zTNJ0W8n/ZFSxVS4VXKguqsXVWx8wVyqFlByAxRCw5 KqTgZ0bfVLxTpxeOxXsqOlK1CNDBQpVqlDV+3xc41sV9ahKVPFYWthJytilinLWfN7X95yyrqCWI lFupGOKb5sRSpVOVKNHDqVHCqhJQnRrYevRjShRpUknV+YPizwx+yZp/gnUfENn+2j4g/Z2tLb9q D9odG+Kh+Inwd8ESSfGHx3d+MIPjF8I7D/heHw61z4eeJrDS7iLXpNNsP+EW1zxDpD+FDqmleJ5J dJ1K+k/Te5tra9trizvLeC7s7uCW2urW5ijntrm2njaKe3uIJVeKaCaJ3jlikVo5I2ZHVlYg/hbb /A+y+C3ww0K28N+F/wBpv9nDR/hV+21+2p43+E0H7If7LfhT4hQ+H7TxlbfFnRfCc9z8J7v4K/Fy bT/h34v0jxfqk3hjxJ4L+FV1o91rF3p39oeJtC0nVDdX3LUdL22JVelKdNZPiJKNOj7eeKvnOQU6 mXypOcVWhilODWDjCtUxs6ShySp0qmFxvRaf1bDOm05yzvDQcak/Z08P/wAIPE1SGYKcaNadKeFl TcHimqdPC0sRUfPTq1qWLwf2P8Qfgh+zj8NvhH8JLm+/ar1z9nf4ZfDIfC3Tf2a/Hv8Awsj4HaF4 f+GM3hz4W+J/hvpVv8O9f+KvgXxN4T8XyfEr4aeIdetdfsfiDB8RbfVYVj1/wnaaBqGm2+owfYPw R8I/D/wH8Ifht4Q+FWqQ678OdB8G6FZ+DfEEOuW/idfEeg/YIZrLxG/iW1eW28Q3HiFJTrN1rlvI 8GrXN9LfxEpcLX53/FvX/G3j34Q/spat8b7T9rb4VfG74P6z8LfiX8UfFH7Lf7OUHxfTwt8V/GX7 OfxN8Pa3bWeh6/8ACf41WHjPwdY6z4o13w5rk3wx+H/xH1DwR4q1DwmniF/DGjTz+JbD70/Zr1f4 ra/+z/8ABzW/jlp0mk/F/Vfh14Vv/iLp1xp9npF5beKrnSbaXVF1HR9Okl0/R9VeZjLqukWEjWWl 6k91YWmLe3jA9jEqp7fO/a4hYmtSziFOtXVZYmGJnKjiJKtTxSU/rDlONarOf+x3hiKFf6rW+te3 XDTlB0MolSclCplHO6dROnUo1FjcRfDKDqz56NCnKlUjJTxSoV8TiaHtaNrYn22vzb8VeEP2aPGP 7SMWh6l+3nrn/C5IfFHxBv8A4T/s+n45fAPVtf8AhF8YfFXwh1/wVrvjD4UeCvEfgzXPiqPF/hj4 c3/jfWtC8C+KtX8Z/DXw1HrPiXX1+Gws4YDp/wCklfEN9deJL/8Aas+LfxO8b+DPHUnwr/Zd+B+h W3wsXS/BHivxBc+NPH3xEt/Evin4x+IPAGhaTp17e/EHxHofgvw18PvAXhyDwfp2ra5BqHiPxz4U sPNvfEN7prcFNxhiI1JydOn9Vx9OtUjNwlClPDSqJc13eNTEUcPRSVKc6dapRxUJ0Pq0qselc7g4 0oOrXdXDfV6Hsvbe2rVK0cK4+ycJQnGNHFVqmIhVqU6dfAwxeDarzxUMPV4fUrf4AyftfeFvDni3 9o348eKfHWheLNC1rw78GPElpe6r8ANH+ONr8GNTsNNuofH9t8JI9I8O/FbU/hK2q+Oo/gVD8aNK 0C4+3XHxb034Nw65qg8U3X6LV+PTeFvHN9+0frfgmH4f/Fhbnxp+338Nv2sNK8aXfwz8b2nw50/4 J6D+yz4B8Naleat8TJ9JXwRo3iSPxf4R1P4eyfDTU/EFl8SBqN9b33/CGv4Ulk1sfsLWy55YPDzq +5WksNKdFcqjGdfJMkxuISjFJxeX4/GY3hupGblKFTh+dJKhTp08HhsZyvilCClOjDAUo0a860a8 nTpZrneFoQjNSl7OlicFhsJn1GhK1SEM9VWr7WrWnia5Xwj4+/Zl+GPgjxF+0p8fPiB8a/iraeAf jRoof46eAtQ0n4Qaz4M1bwTpPw4t/hva+B9N1G1+COo/HaHwzDp632raJ4O8MfEp7uTxz4n8Q3uh WzXvim90+8+7q+NP27rW8l+Bejaoiu+g+Ev2gv2V/HPjsKyJHD8PPBP7SPwu8T+NtSvWkmt0GlaF oGl3niDWS8uz+yNKvt0VwubeXKFOFXEYahNxjTx2JwmVYipUtKhSweZ4/B4fFV8RCTVOeGw0eXF1 +e1qWHn78E5M2hUlSU6kJVIyoRni4KhKNPETrYOlUxFGnhqsp01TxNSpBU8PJ1aUFiJ0pTnBRU49 t8Hv2a9I+EumePHT4nfFX4heL/iNo/h7w/qvxN+IU/gH/hO9P8M+D/D914f8D+HtJHg74d+CPC9v ZeD4NS1fUtMl1PwnqOsXuua1q2p+JtR1y6u32/nH8WP+CcP/AATp8MeHfC/7NMrfET4W+JPE/wCy L44/Z8u7/wCCng+P/hZ3xO+F/izxz8AvAV/8VPiJ4k8HfB3xPFr/AMUPBPxRf4YeJtJ+IGs29qvh bVfEPivxprWly+C7fxRdaN4J44+Dfjmz+LX7a1t8PfgT8T/Elh4+0v4qeIPH/j3VfgT8R/APxWvd Em+O/wAJPEHi34SWvxN0fxHqPwt/bT8BfGD4WQ+Lx+zxB4ZsJfil8B/BXh67+FOrLp114wuPDVnx Hiv4E/Ey/wDGPh7Uvhl8CfivovwWb4lapqfwi8JRfBfxz4Mi+H/w2b/got/wTv8AGP8AZUngO/8A Dem6r8OtKu08CfF/4p6R4X1zRfDt3p3gCx1jxH/Yum+H9Ku3s+nLIRzHM8mpYpyo0c9yurXzLES5 Jypwp4DOMtjl8sTK8ZVsTDH4yPtcRTgs5wkM7ko1KUcHmFfOtzZWlTwjTjheKMuy3CwpckKEaeIz bLalTOXgadWpShSwdOhCeGpKU3lFXEZVUhKOGxNSjP8AQvxj+zD+wp8Hvi38UpfHviLxnpmv/tE/ sieAPgPr/gyb+3Ljwfo3wM+D/iPw98Jo/GWgXnhLwYH8E+IZtX+LHwz0bxv4t1TxRHBa6V4Z8H+I 4bHQNB8EeINag+tfgn+y5p/wc+JfxH+MGqfGL4yfGj4jfFHwR8MPh74k8R/Fi5+GEfk+GfhHqPxC 1PwjbaPo3wq+F3wt8PadcfafiZ4kbV7oaTLLqh+wzTkXcVzcXf4Yt8K4vCMvx/1nWP2ffif4a+Jd z+wV/wAFBPAHx8+JWq/B3xx4X0r4vfGz4l/tB+DpfhPpWlfFjVtE0rw38W/E/jW2mmufh3feHPEm tvD4dutJ0axutLTSH0bR/wClHwla6rY+FfDNlr0/2nXLPw/o1rrNzkN9o1W3022h1GfcOG828SaT I4O7I4qqdarVy3B4ydap9Yx2HxtTE03KMsO1W4n4mpr6nC7knUhgKOZYvFyjTljXnNHE00qOI9nH ljGFKvisFCjThh6OJw+EhCMOSvSo5Zw3wTXw0carRlFqtifqGHw6vSw74ddCU6+JwlWpHoK5nVvD 17qfiHwprsHi3xNo1p4al1mS+8MaS2gDw94yXVtMfT7eHxWupaBqOttFoU7DV9G/4RzWvDso1NEO qS6pp+/T36aiuQ6mr9909G1s01qmna61WzV0002j5Yf9kT4bP+z78Sf2bTrfjgeBvij4s+L3jHxB qo1LQf8AhLLPU/jT8V/E/wAYfFMGj3x8NHR7ewsPE3ivUbHQIr3QtQuLXQobK11G61XUI59TuaNx +xz8PZ/jZd/GaPxZ8QrO31X4maD8bdf+E9rc+Ch8MPEXxo8M/Dq1+FWhfE7VfP8AA0/xI/t3T/Be l6BZR6Np/wARrDwPJqPhzRten8Jy65Fd6hefWtFX7SftVWUmqseW009fcrYbEU79H7LFYLB4uldP 2WLweExdPlxGGoVabn78sZOd5Sx/t1jG274hYmWJniVU7xxH1zFwrx0VWjisRQqKVGtUpyK+f/2i v2etE/aQ8LeEvCuv+NvG3gi18HfEfwp8ULG68F2fw31VtT1/wS97eeGrPxDofxW+HnxN8H61o2l6 9Pp/iuztbvwybqz8UeHPDms2V9a3GlqJPoCis2k5U5aqVGvh8TSlGUoyp18LXp4nD1YSi1KM6Nel Tqwkmmpwi+hSk4qolZqrRr4epGUYyjOjiaNTD16coyTTjUo1alOWl7SdmnZr5o1/9nzxf4h0lrKX 9q79pfStYii8DPpfivQLv4G6Nq2k6v4N1TxPe6hri6LZ/AxPAmuy/EDTfEsfhzxz4f8AGHg7xJ4I n0vw14Y1Hwz4V8L+K7C68S3/AJnP+wd4Cew8CeGLb4ufHyx+GnhJfAlz4k+EkXi/wpe/D/4ra/8A D34iXnxZ0rxd47ttZ8B6p4j0jxRrnxEvp/EvjvUfhP4k+GUfxCkSz0rxpa63oOn2GlW33HRVxnKM /aR5Yy+s08Z7sIqH1ijBQp1PZqKprkShJQ5fZ+0pUavJ7SjSnCHFO1780aDw0anNL2saPNTmoqsn 7VSjOkpwqKftITnWnCcZYiu6hXG+O/iN8Pfhb4fl8WfE7x34N+HPhWG6trKbxL478T6J4Q8PxXt6 5js7SXWfEF9p+nR3V3ICltbtciWdwViR2BFdlXgX7U3jD4k+A/2ePi74n+DnhnVfF/xZtPBmp2Xw 00HR9E1HxFd3HjrXBHoXha8n0fS4Z7260nR9a1Kz1nXXREhtNEsNQvLue2tLee4ixqyqRpylSip1 Ek4U20vaSurUlKUoRhKp8Eak5KFOUlOacYtPWlGEqkI1JqlCUlGVWSm40lLT2s40qdWrKFO/POFK nOpOMXGnFzaPz5+Md/8AsMftJfGe8+w/tjeNb5P2kPhN4D/Zz8d+HvgGPAnxI+A/xB8A2vxJ+Mum +HPBXj/4w2XwR+KejfC7W/H/AIx1f4s/DG1EXxl+GXiPxPqWmXvhjwiYvGOlRzr7R8OvhD+yy/xm +H3xL+Hf7QGvfEHQm+MHxs8V/Cn4PeDvE3w88c/BPwh8ePFvhTxLJ8afF9jqvgfwJe+O9N19dJ1/ x3Lq2nePfixeeBtA8QfEPUrWw8P6f4i17wraQ/FnxI/Zv8WeCP2lPhx4G8E+EPi7qHhzQb/9g7RL HRdM+GviTxL8IPj14Z+FXxL8e+K/ib8U/jv8cYvCmsab8PfiN8ItQ8YeJvif4espPiB8ONV8f+M7 fS/+Ejsviuniqx0bR921+E3xZ/Yu8ea54i/Z08A/Eb4q6Xb+MvC/wb8OT/FH4beJPiBq9xo1j8H/ AIf2+qw+F/8AhUml/Dqy8I+CvFOlfDb4F/BHSPjb4x0vWPC/gvUfhRr/AIo+Il54wuNeudSm9LC+ yalyYitGEcdneBwM1aftsPKtk1ONSrSqONVUK2PzD2dNQWJpxxFKVTD08HmuCr5a+TGYmtXdaeIj UdH+z8ixqw9aEqmIhi4YLHYKtQlTpyVOnWwmTYHDU/bwgnXwEJ4edTGZdiHi8L9FftDfCj9nH4X/ ABX1nx78WvjT+0SLD43fFbwV+0VrP7PfgD4bwfFrwz4j8Wfsx+Ffhhp2j+ObjQvhT+zr49+P2heC PAlx8P8A4X+IfEmqnx/pHgyPxf8A2Fpus3os/FEXhnVvOtO/Zb/Y+8f/AA20OP4b/tDfHy48Efse /Cv4F+AvFcvw20/w34tvPGXhT4RwfDv9rz4I3uqW1z8BfF2reOtZt7XUPBvjyyj+BFppsPjYa4PC Ot6R4gube38OaZ65+3poV1L42+Dni7SLL9pf4f8Ainw74K+Mtr4S/aU/Zf8AAesfGvxL4J16/n+G 2qQfBj4gfArSvhD8ZbHxx8M/jVB4fn1LVtY8U+G7DQfD2q/DTStNtfEnhzxP4o8P6rB+PPx7/Zm+ PvjfwB8aPi34g/ZW1zT/ANpnxx4lttG8SXnwy+E2v3uoR+Gdc/4In694N8XeBfBWraJpmqajefCh f2gZLfwFDo+l6rqXhm6+I1povhqSW/8AFFpp8IzyxTlSqSVX2Dy2phcbg5KrGLpY+niKvD2Br06c uerXqYbKZRw9VVJYLE4LBPCV6UMTltbKauI+lwOF/tLGUcHWxs6FDF5VPEYpyq0480cmxWExmHpw kpQ+rSSVepgnClXdbM6UZ1a+Gq4erCf6pfE79hL9mT4d+HtO8f8AiL44ftA/DLwTrfxe+Cut+MrL Qbnwlc6f8UfGl1+2nefHz4G+HPHGnT/BjxN4r03StN+Pnxhu/CsJ8IS+B7qXwT4gXS/iNrWoW+hw eINJ/TEfELwgfiGfhSNX/wCK+XwYPiCdB+wapx4QbWz4cGr/ANqfYv7F51kGz+wf2j/afH2g2X2X 9/X81Ot/AD9o/UPil4t1vUfAfjy88Y/8Lm8Jv41Twn+yv8StFg8UfDq2/b6/Y88afAnUfG/7Qur+ NZfDXxnb4X/BDwjrl14a0P4efDbUYvgt4ctfinp/jzXfCD2so8T/AGL/AME2fhRceBvjxb6pqPwL +IXw7+I9t+x/ofhL9pn4keI/g342+H3h34oftI2vxr8S6n421m38e+IvDWh6H8X9f1a6m1LxK3jz w9f+IbTX/DOr+H7m11y8sbeC1024RlUo5VTnXfssZjM/xWIoOXtKmGcOG6+NoTVZrlqKWMyrA4TF 4uTVGFLE5ZleFwtOvOVeh4tWmqWT4vGqpTlisLjstwMKUJSVKtGtm2TZbWxEKLSqRUsDicXi8JFT lKvhKOHzGdSVCnVoT/cSvCNW+Aml+Jbf4Zp4w8ffEPxdqHwp+NGp/Gzw1rWs3Pg6DU7jV7tfHlpp XhLVxofgzR9OufBXhXQ/H134c0C3tdPsfEraToPh6TXfFGt6vFrGq617vRXF1pysualWw+IpyaTc K+Fr08Th6kW1dSpV6VOpG2jlCPMmlYhtuFWn9itRxGHqx2VShisNWwmIpStq6dbD4itSnHZqd/ij CUfiPxV+w34Y8beIPFXiPxP8df2jtYvb5/E9z8MlvvGvg66/4Z91Lxf458LfEfWNR+EuoXPw8m1y +KeLfBfhybRdI+MOrfFnw34a8N2Enw98O6Jpfw5vr/wlde9fBT4MaN8EvDuv6PYeJvFnjnW/GPjT X/iH448d+On8MHxZ4y8Y+IhZwXus6vB4K8L+CvB9kYNL0vR9EsLDw34T0HS7TStIsYlsmuBcXVx7 FRTg3Tjyw91fV3hbpLmeHlWo4mrTlP45KviMPhq+JlKTliq2FwtXESq1MNQlTVX984uq3U5cVPGx Um3GOLnRq4d14x+GNRUK+IpQcUvZwxWKVNR+tYj2hXx/4t/Ya/Z61/4uWHx+8M+DND+E3xu03QPi 7pVt8Vvhb4G+Feh+OZNe+Mmj6Vouu/ELU9d1j4feIbnXPH2hQ6Utx4Z1jXf7SsY7jUNWi8QaT4h0 /UJrGvsCio5VzKavGooVaSqRbhUjTrw9nWhGcWpxjUjZTSaTtFvWMWrjOULWs4qcKnJOMalOU6fN ySnSqKVOfKpSVpxkuWc4tOMpJ/Hvib9jHwV4+8ZXniP4n/Ez4y/FHwtNb+JpNM+EnjnxF4T1H4ce GfEXjT4V3nwZ8WeLfDRsPBGmePtM1HW/AOs+KdNPh7/hO5vh7pF94y8U614d8FaNq2prd2/f/Ar9 njR/gdJ4s1P/AIWB8Rvit4u8ZQ+E9M1nx38Up/BE/ig+GPAWkTaN4J8I24+H3gb4e+H10Pw3Bfax d2ss2g3Gvahqmvazqmu63q17e+dH9B0VopySaTsnQpYdqyt7GhUqVcPC1rL6u6tSnh5Jc9DDzlha MoYZukYuEJKkpLm9hUq1aLk3KVKeIjGOIcJNuUViZQhWxMU+XE4mMcVXVTExVVFfMPi79l3R/HHx b0j4m+Iviz8aL/w5o3jLwf8AEe3+Bl14i8K6h8Gx8QvAWlS6Z4W8WWdnqvgnUPiJ4efTpRp+vS+F vCfxG8P+AdR8V6RaeKNT8JXmuXuu3ur/AE9RUx92pSqx0qUKtOtRmt6dajUhXoVY9FUoYilSxFCd uahiaNHEUnCvRpVIVJKdKvQkualiaFXDYim/hq4etFwr0J96Vem5Ua0PhrUJ1KNRSpVKkJeB6H+z /o/haTx1N4V8efEbw3L8Sfjg3xz8XyaVqPhdZdS1S50Lw34d1TwRFPd+Ebuew8CaxpvhbTlvY7GS 38ZQTvdT6X4y052g+z4PwQ/Zi0n4L+KPEPje++LHxm+NPjHW/B3hL4cWXij41eIPCfiDXPDnw68D 6h4h1Xw74Q07UPCngnwVPraxan4o1fUNX8Y+PG8Y/ErxTeS28/irxtrT2VoYfpqinTbpQpwptxjS oYbC0lv7PD4PAUsrwlGm3dwhh8vorCUlFrkoVcVCNljcZ7eeSP77SyxFatiK8U2oVq+IzGpm9erU gnyznVzOp9eqOSfPiaOEqSu8Fg/YFfJHxJ/Y3+HXxO+KcnxO1bxV8QdHt9b1P4O618RPhzoF14Lj 8AfFfV/gB4tn8c/CDUPG41nwPrXji1l8G+J5YL9YvAvjfwXaeIYdP0/TPFtvr+lWwsm+t6KUfdqU qq0nRqwrU30jVpyU6c3F+7J06kY1afOpKFanTrRSq0qc429U13TXMtJxvo3TqK06U2rx56coT5JS hzcs5J/Hnwm/Yt8B/BzU7zUvDHj/AOKN4unfDfxL8IvhTp+r3Pw8Fl8Bvh14r8RR+KdW8NfCx9D+ HOiahPCdX0/w1Jb3/wATL/4j6vBbeD/DdkNQa1t9Qi1HS+HP7HHwt+FfxR0b4oeEdV8aWzeH/A2n +CdH8EXN/wCHpvBdnLYeEfBvgFvF+U8MQ+MbjxTfeC/APhfQL1LvxhceFWisJdTtvC9tr19e6tP9 Y0U4twjCMW+WFP2UYt80eT2mOrvmjK6nOeJzLH4upUmpVKmNxVXGzlLFNVkSXNOrUf8AEr1HVrTj 7sqk3DBUlzONm4wo5dgsPTh8FLDYeGGpxjh3KnIr5j+NH7Mln8Y/iZ8KPizF8Xfip8MvFnwb0rx3 pvhD/hBLD4Ma3o63PxCTw7baz4iudJ+MPwf+K1ta+K7LSvD8mgaL4j0AaJqmn+H/ABJ4u0czz2Xi G9iP05RSXuzp1E2p0pSlCSbVnOlUoz0TtJSpVakHGScWpPS6TTTaU46WnHkkmk7xupW1TtdxV7Wb V09G0/iS8/Ya8H3HxA1P4hWnxg+N2kXMvifxz8SvC3h3Tbz4U/8ACO/Dv43fEP4Yah8JfEfxx8Gm /wDhLfeIf+E6fwtrOvTWOh+KfEPij4U2Wt69qmqR/DcvJbxW3Y2f7KWkf8Lh8L/F3xN8Yvjh8QI/ AviXWfHXgT4a+OfEPgvV/h74L+IPiHwBc/DPWPGfh+S18Aad8QoLq48J6v4rtbTwrdfEC8+HGiXX jPxHe6B4K0qeTSm0r6qoqqc5UvY+zk4LD4SOAoRXw0sHCHs6eGpx+GNGjTjShQgly0IYfCQpKEcH hVRmSU1JSSlz1a9ao38dSripTnialSfxzliKlbE1K7nJ+2qY3MalTmnmOOliCvJvjB8LdQ+KuhaN pmjfFv4s/BbWdA8Q2/iLTfGPwg1jwtY64zppmqaPd6PrWj+PfB/xA8AeK/DupadrF4lxo3i7wXrt rZ6lHpfiTRRpXinQdC1zTfWaKzlGMlaSurxbT2lyyUlGS2nCTVp05JwqQcoVIyhKUXcZSg24uzcJ weid41ISpzWqfxQlKN91e6admfCmgfsAfDHwrq3g0+HfiR8adM8A+Cr/AOHHiSw+D7+IPBer+ANQ +IPwo8LReFPBPxK1O/1/4f6t8Sx4rsILHRNcv7LSviHpXgvXfFWhWHiPXPCWoalda3Lq3U67+x7Y eL9b+H+oeOfj/wDtEeOdA8F3Xwd17W/h/wCJvEPw2ufBHxL8efA3U4fEXgb4jeL7Cy+Flhq3h7xO 3i+w0Txl4l0/4Qa38LvBPifxD4e0iXWfCFzp0d5p159hUVtCrOnONSEuWcMdSzKEkknDMKEYxoYy LtpXoxpYaNKorOnHA5aoWWWZf9WznCNRylNOU54NZfKpJt1Hgk5S+r+0b9oqblVxEpJSTlLF46Um 5Y7GOuUUUVmUHTrXwZqP7bn7O/xZ+G/7QKfD/UfEPxc0fwJ8ZLf9kHUo/hFeeBdfvfHvxf8AHHhf wNK3hT4Za9e+LbbwZPdaRL8TbLw/rur+M9b8L6L4W8ReH/Fa+IprTSNBm1K4+86/K3xN+z78abDx T+0b8RdM+HV94nm/4eD/AAQ/aa+HvhLSPFHgSw1z4m/DrwR+zz+z98M/FQ8P3XiDxNpXh7Rdfg1T w546g0fSPH2t+C49T1Dw5ALnUdM0bWNP1qaFQoYupWwmNjzYCvhMLSxFrRkoYvinhfLMwlCUo1I1 J0eHMxz/ABkKHsqkr4T61KFWjhK1Ke8ZzoYfE4rDSiswwlPEYrAwqN8tbFYbLcyxOCw/LGdKUXXz WhltGVb2qjCjOtStCpXpYnDfZH7JviPwN4g/Z6+GNp8Orbxhp/hnwDocnwdXRfiGmiJ4+8Oa18FL +8+E3ibwz42bwxc3vhe48U+HvEXg7U9I1u+8L3194Y1G/tJtQ8O315ot1Y3Mv0VXyr+xx8N/GPw0 +DupW/j7RJvC3iz4gfGX9oH41an4QutQ0XVtQ8Gw/Gz42eO/ihpHhLV9T8NalrXhy+17w7ofinTd L8QT+Htb1vQTrltqC6NrWraYtrqFz9VV246rOvi8RXqTVStXqSr15KaqxeJrfvcSo1VKSqxjXlUj GqpSVSKU1KSld8dHD4bCQeDwN/qGDq18HlspU5UZVMswteph8trTozjCdGdbA08PVnRlCEqUpunK nBxcI8b8QviH4F+E3gnxP8Sfib4v8N+AfAPgzSLrXfFXjHxfrWneHfDfh/SLNN9xf6trWrXNpp1h bJlUEt1cxI0rxxKTJIin5O8R638Kv2p/2aPBn7Sl/wDHH4mfA74D+PPgR4f+K9lqMniD4aeAbHwh pmv3PgH4weB/i34p1jxH4f8AFtjo/jP4bf8ACOWYs7e98Ual8L7nTtc8T6X448LeNrC5sHsPtHWb ea70jVbW3TzJ7nTb63gj3Km+aa1ljjTc7Ki7nZV3OyqM5ZgATXyT+xp4Y+Jvwe/Zt/ZG+A/jv4Za 1peteCv2V/APh/4heJIfEXgPUfD3gn4g+A/CfgTwzc/D6/TTfFd3rOtavrE91rt7peu+E9L1/wAF x2nhPVRqXiWxudQ8OQa1yqMpYXN6kJQjjcP/AGY8p57qLlXwHFM8yqOLqU/bzw7wWVOhKnUo1cNi q+HjQn9exeAlHsThCOHq3ulXqfWoJxdSUIVstlhfZXjP2a9pLEqu50cRCrTs5xp4fDYuOIufsOSf C7xD+zz4X+L3wl8XeOPiJ4Z/aGu7347TfEn4kr4Ni8a/EG/8dR2gt/FGtWvw80Tw34FsEuNB0vQ9 P0ex8K6BpGlW2g6dpaC0+1/appvryvmX9jP4e+MPhR+y38Efhz4/0j+wPGfhDwPY6P4i0b+0NL1T +ztRhuLp5Lf+0dFvdR0q72rIh86xvrmA7sLKSCB9NVrWcHUcaMXChSjDD4Wm3TaoYTDU44fCYePs qdGkqeHw1OlQpRo0aNGFOnGFKlSpxjCPLCmqakrqUp1a1etUXNetiMRWnXxOIm5TqTlUxOIqVa9W dSpUqVKtSc6lSc5Sk+G+J3xF8L/CH4cePfit42up7Lwd8NvB3iTx14pu7W2kvbq38P8AhTR7zXNW ltbOL97d3S2NlObe1jxJcTbIUO5xXxL+yn4g+Glh4I+IN3omofH34Jaf+z38Zfj144+OHww+Mkvw fk1CLXvjul3+07qp8Y6l8Oz4+8O6j4M0TSfjJZ+LPh/J4D8fWup6XZi00XxzfavrOl63p7/bvxJv vHemfD7xrqXwv0PRvE/xG0/wxrd74H8N+ItSk0fQ/EHim10+efRNF1TVoyG0uz1S/SCym1AsqWaz /aJGWONyPy58F/AD42at8Gf22/hVD8Ivil8MNK/bM1L4yHwlffFf4q/Dn4i/ET4SX/iz9m7w34Ek 8RfFPxronxZ+Jeu+I9I1/wCIGk3Ol/DnTPD/AI1+KGr+B/CNroWlXZ8IeFLDSfDnhvlqVqtPDZy6 cZTqUskq4nBRs5KWZ0sbhI4aiqK9nPFKthqmNlUo06sqkZYeg1CkpupL0cPTwleeVYbF1qmHw1bP MO8ZWhO6hh1RlQ+tShGnVnReCp4rEpSqRjSxUcXUtWgsFUw2N+q/2MvF/gnXtH+Klh4Q8B/G34fy an8SdX+M9/p3xusfBFtqWt2v7QU1z8SdL8T+EJvAGv8AiPSo/Buote6hZ6ZoHiK8sPiJ4Zk02fTf G+h6fffZpr37Rr8//wBhn4cfGnwB/wALDX4g6J8ZPBHgO68P/B7SfBvgH46fGi3+OnjG08c+GvCu pWHxZ8ZaJ4pt/ix8ZYtB8AeLrqbwnZ+HPBsXirS4LDUPDHiDXIvBnhn/AISFlv8A9AK7sXSoUKsc PhZqeFw2HwmFw0lNVP8AZ8NhKNCgnNKClKNKnCMmqVBcya+q4X/dqXjYKtiMTRlicZSdLF4qvisX i4uHs08Xi8TVxOKlGDnVajLEVakouVWq2nf21dNV6n83n/Bwb8Lv+C2XxK/4ZH/4c7an8RdO/sX/ AIX3/wANFf8ACAfGD4LfCjzv7R/4Uv8A8Kj/ALW/4W/428Hf295f2D4nfYP+Ee/tH+y997/a32P+ 0dM+1fzef8Mu/wDB7J/0M37RX/iX/wCxb/8APsr9if8Ag61/4KK/GL9gT/hgz/hU+if2x/wtj/hq P+3/APjIf9uz4CfZv+EE/wCGdf7K/wCTKf2uf2V/+Er87/hMtS/5KX/wnf8AYXlf8Ub/AMIx/bHi v/hIf5Av+Iir9sP/AKEn/wA6H/8ABdf/AOm5VzHWfrp/wy7/AMHsn/QzftFf+Jf/ALFv/wA+yj/h l3/g9k/6Gb9or/xL/wDYt/8An2V+Rf8AxEVfth/9CT/50P8A+C6//wBNyo/4iKv2w/8AoSf/ADof /wAF1/8A6blQB+o/jT4Qf8Hj3wv0nT/FHxW+Lnx0+Hfgq78ZfDzwNc+Ltb/a2/ZEvtP0/Xvil4/8 M/DDwTZtYaB8XNX1zUbvXvG/i/w74f0zTtI0u/1LUNT1Szs7O0muJ40P65/A/wDbc/4KO/Cn4pW3 ww/Z3+F3x5/ao8aW3wCg+P3w+8QftWftPX/ibSf+CkXwTeDULHXPjh8JfBc9tq2nfs/Xlrrb+GPE fw88BfD7TNDsYfBOvaT4f+Kep6j8RfFfg7RPE38z3wP/AOC1P7UH7S3xGT4d+J/B0otNE+G/x/8A jFotjF+2J/wVo+Lv9seO/gH+zv8AFj41fDPSv+EA/aH/AOCgf7RHwt1u4uPiN4D8Ky6adZ+FmtXl jq8Gn3+lXui3tvFqlr/Wp4Y0z/gn83wk+H/wovvjb8DNC0zx18UtD8eftMftWeC/jVDp/wAP/wBl NPA/inx1o/gj9h79lv4uXOvaX4i8Ea94iXTPjd8OtB0vwGfDelaJ8JP+Gmvi9rFn4I1D4reAtD8X AHR+Ef8AguV+3/41tv2YPGOkfsHfC+D4N/thXVz8PPg38U774q6o9jpf7RFpNrOkzfBf4o6TpEer P4bnOv8Ah3Vo7XXfB2ofEPUdQ0RfteneE7zxJ4d+Ivg/wJzF5/wXf/4KWeHfhP8AFD4qeOP+CYWg eGW/Zh+MNj8Jv2xvAY+K1te+MvgZDrd3F/wj/j3SpJ9V03wp448G6jpd1Y6nPq2oeJvA9jZaff2H ip72X4ZaronxC1XpfEnxJ/Ye1eX9pf4raPcfs9+Dvib8SPhNZ/Dv4dfszfE2yg0/4c/sd/s3eHPh n4d1vXP24f2tPgGL3w7qPhPx3rXwi8T/AAq1nxFbatB4R+IUXgmw/Zi/ZR03VvAfxN8SeLrq65T4 665+wH4Z8I6/Z6D4++H+v+Gf2Zv2bPincfs661q/j+z8cfH3/gov+1DpHiorf/FbxKZppI/jR8Nv gl+1De+GPEmgeMPEVx4h0nU/2sR478d2Fp4F8Pfs6x674qANbwH/AMHO/wAKvh/r3gyD9tK6/Z0+ H9h8QZ5dZ0zwp8E/HXxL8efEfwf8INah1K8+E3xy8YQ+IPh7ovgqXw/8aNFt9C8d+Evh3a+KrD4o aT8KfG3g74ha34fWLW7HQrn6z/4ihf8AgjX/ANHJ6h/4QniH/wCNV/ND+zzazW3w28ybUf8Agzqv /tvjv4rXtrb/APBSfW9Q1v8AbR8N6RJ8T/F8Xh/wN8ZjfrENFn+H/h6HSvBHgzwzYWljp3h34faB 4V0m3tFNtJLL7h/4wB0Af0N+Af8Ag5F/4JXfFjxx4T+GXwm+J/xR+K/xH8c6zFoPhHwD8L/gX8S/ iJ4z8QanJBcXbxad4Z8HaJrWszwWdjaXeoajfCyFlpun2txe39xb20LyD9pvhp8TfAvxh8FaN8RP hv4ht/E/hHXjqMVjqUNtf6fcQX+i6pe6Dr+h6zo2r2mn654d8TeGvEGmap4d8U+FvEOm6X4j8L+I 9L1Tw/4g0vTdZ029soP5J/2dtZ/Zv+AX7W37Wv7TX7Mb/wDBJ39pfWv2R/8Agl/4j+Ivgq+/4Jk/ sxeEvgJ8NYPGvxF+K2vx+JtP+KMfwZ+NH7YfjLW/FegeGvg9oMk+qeH7ubxbpXw18beJNH8K+A7i 48TX3/CU3vhr/wAHC3/BPD4Xa78Xta8Pf8FQv2ZDb/GP4lN8V9X8PXf/AAT4/wCCjc2h+GvFN94J 8GeDvEMfhKCJbaTTtL8S3XgyPxprdpK05vPHHiPxb4hLpPrtxEgB/YLRX8qP/ETl+wd/0k0/ZP8A /FeH/BSP/wCSa4L4nf8AB0P+yxo3gnVr34Pft6/sd/FD4lNPoun+E/BGu/sVf8FBfhnoWq32sa9p ekT3eu+PPEs76L4a0TQNPvrzxFrF/dxzSHTdJubeyguL+e2hkAP666K+fv2T/jB4i/aC/Zj+AHxz 8XeEP+EB8UfF34QfD74i6/4NVdbWDw/qvi7wxput3lhYr4n0fw94mXS1mvGk0pfEvh/QfEQ02S0G u6JpOqi70+3+gaACiiigAooooAK/Pr4n/tX/ABE8Ff8ADWH9laN4LuP+FE/GD9mH4feEf7Q07XJf 7R0b41f8Kc/4Sm58R/ZvEdp9s1Ow/wCFh61/wj82mf2Pa2v2XS/7RstV8i7+2/oLXwN8V/2M/F/x C+InxF1bRfjNofhb4VfGnxx8CPiB8W/A198KbrxL45v9b+BN/wCFrnTLfwB8S4/ib4f0XwZpXimz 8C+EtN1+3174X+P7uCK21i50a/0661a3k0rNqbr4dJqNKU6cKs5P3KUfrWFqTq1FFSqOmsPTxFNq jTq1W6qUack3KOkHBKpKa5nGHNGC+Ko1KN6cG2oKco3s6k6cNHeabV/Sf2x/j748/Zz+FWkeOfAH wt1L4l6lqnxQ+EfgTU7iO/8ACdn4d8BaB8Qfid4S8E6z438XQ69458Ga9qWlaRp+v3BstP8AAtt4 q8R3GtvpiyaC2kf2je2vyX8f/wBvr4jfA7XPjb8S7jR/h5qP7PPwF+LV38DPFXheTQ/Fa/FjWfE1 t+zVa/HtvHeleOIPFL+F7LQ49a1zQPAZ8CzfDPUL6azTVPF6+PYX+zeGB9J/Ez9kz9nbw98FviF4 G+HPhn4LfsreH/iJ8V/h78VviB4n8E/DnwN4F0bxP4/0f4p+B/F02v8AjG30JvBVl4h8YeOb/wAO 6f4Yl8S61qU+tXF5qdnI76rNDBp1z84/Gf8AZa+D/wAWPjj8Rvgl4x/ad+F1h4X+Neu6l+0B4x/Z ZbT/AAvH8d9W8U3HwHf4BP4s0nxBc/EZL+P4U22gaLZ+LpdKm+Depam3jXQ5rk/EaHwybnwwkJyT qxm5NOn7SDhKEa0Jqtw1Vx2Ho80vYzhDJ8NxbSy+viKUZLMMZhMbi/q1ClQnl/Rh/q3NGVdRdKM6 0K8ZKteeHeHzGngq1OVJp0cZLNa+SzqxlU+q/U8PicKo16lZrGZ1p+1v+1Zc/F7Sv2UHv/2eIfj1 4l8PeEPilpvxGHwv+Jc3ww0X4beJfhn8QfFVzol78OP+F1w+JNe8W6f42+H03hOLXoPip4d0260H XIPFh8LQXWlS+GtR/QL9mr4vn9oH9nv4J/HBtITQJfiz8LvBHxAudCiuHvIdGvPFPh6w1e90qC7l igku4NPu7qe0gunhie4iiSZo0LlR+X8Pw8+H9tZS/tgL/wAFGf2Rj8T/AAjq/h/4TQ/tEy+FfCR/ Z+0fwvoPw58TeCtP+Ffibwwv7TqBvHc8/jzV/Hc+pWvxo8OzTeI59JSLwdF4Zgk0K/8A1X+BPwy8 L/Bf4K/Cb4R+CdQl1fwj8Nfh14O8E+G9YuJre5uNY0fw3oNjpVjrFxcWYFpPPqsFsmoTTWoFtLLc O8AETIK9OfsGsydOKVN4nKfqHu1G4UXgsbVxS55XaU8PWyXmVacp16tOpjKPPHE18XjPHwf1mFCh DHylPHf7VzTpujGly060KVdVqcVS5qrxscQ8N9Xo+ywuH5sJXdCpTo4anyP7V/xZ8R/Ar9nT4tfF 3wjZaJqPiTwF4Vm1zR7HxHbX13odzdx3lnbiPUrbTNS0i/mtylw5KWup2cu8KRMACrJ4C+LXiPxT +0X+0H8ItQstEh8N/Cfwp8DNd8O31nbX8euXt38TbP4h3GvR61cz6lcWFzbWj+EtOGkJY6Zp0tuk 96L2a/MkDW3SftBfCCy+P3wT+JvwZv8AXLzwxb/EXwlqnhtfEen2lvqF3oN3dxh9P1eLT7to7bUP 7Ov4ra7k0+eWCO+iie1a4txN50fzp4f/AGG/BnjXxJ438e/tjaN8BP2rfG3izxJ8LfEmjxaz+zno ulfDv4fal8HdD17SfA+v+CPBHxL8afHTUtG8dWVx4u8WX8/jaHxiNRRNXisNKt9Kt7SQ3nLDlfNG V4pckud6uUZ1qMKkaMU3zVqNFVqyhW9hRqe7T+sRlJuBVp4n6xTqU53otNOkpNWnTw+NlF1bpJUa +IqYOk50vb1aahOq6ElTjGr8veKP27f2i/BfxY8Z/CDW7T9nu78b6rd+DNH8N+FNBtdY17Wf2bNU +Ln7UvhT4EfBI/tHT+HPi/4gtfHEnxN+HPjB/jToWh6DF8FdSuIPA3ijwok4S8j8S6Lu/E/9vz4v fDH4M6QI/CHw88c/tCW/7W0X7O3imHSLLxBoHw7j8A+GvjP4O8H/ABD+NkXhu/8AFeq+KND0238B +NPDMemeHn8X+J10v4o+M/C3h2717W9Jee9n5LxT8CvAfxJ8bfELxd42/wCCgvwJ8UeN/wBlTSZH 0HVl0fwkviD4CW+lftEeCv2gNEvv2u2k+O1+vjew8L698GfD3gqy82y+AAsvDFv4/Frd2PiLXf7a 0DZ8TfsQ/s3fFb4Cw/Enxh+0zpmo+JfiB490vxjqX7UPw2+LXj74ZfB3xXf+M/2ivCnxFbw14Z8F +Bf2gLTwFc6N4h8S6P4d+HHgf+2/GPjfxVZ31r4WlHiXxL4l0qxWesG4rDZPKvGM5qrWqY+3POpU w1XNssr8OQjytUcRCpgMPneCzJ08TQrYrC47Cyo47M8xwP1lddeM1iMYqMouMsbg6dGFWHLVpcmS 4rDcQSi4RjShShmVfKczy2jUwdSrQxeHxOGr4TDZXi1Gt6t+3r+2T8R/2XvE/wAN9E8En4T6fF4o 8D/EHxlZxfFOw1u+vvjH408GeMPhN4c8N/s2fCSXSvHHgiDSvi38T7P4g6zeeGNUu4vHs9vJ4ezb fDnxDaLqk+n/AKWqSyqxUqSoJUkEqSMlSRwSDwSOOK/Kf9r74AaX4x1mwX40fth/Az4TzfGjwz8S f2Z7Ww8f+BNM0jVfE/ww+JPxA8P+I9D8IfBG68SfHjQbrRvj/odjY6LoEnxFtIPG9l4o1xNC8SP8 J9PutM0XS7f9VoYlghihVnZYY0iVpGLyMsahAzueXcgAsx5Zsk8mik4PLMI5RSxX1rNFinaUpa42 dTB06lVOdF1KWXVMFGVLDyhTpXtOjKu62YZlFRTjjq6Um8OqOHjRtyqlNQoUY1cRRjKFPE8lfGrH KLxMfaONKNTnhCrTy7LOe8Z6j4j0jwf4r1bwf4eHi7xbpnhvXNQ8L+FG1Gy0dfE3iKy0y6udF8Pt q2pT22naWusalHbacdQv7m3s7IXBubmeKGN3X8ePEH/BQL42fDzXNW+C/wAVvil+xv4A+Jtv448O eFL/AOPfivRNb8J/s9/DnVZfgHqXxi8c/D7xZ4V179pCK/8AEvj3whq1v4T8NmTTvjX4Vt7vSPih 4b8TS6Lato11o+t/r38RNL17W/AHjjRvCvi+H4feJtW8IeJNN8O+PbjSo9dt/BOuX2j3lrpXi2fR ZtT0WLV4vDt9LBq8mmS6xpUd8tmbZ9RsllNzH+WHwL/Zp0Lxt8MfhBf/ALOP7Vf7Jfj3Wv2aPGvj KbwR8SfhT8J9X+Jfge6174mfD7WvD3xbb4z2UH7XnjLxD4/+J/jiPxlB491DxjcfFXw14hk8QXKa x4js/E9prdzFccqVV/2n7PmlUjgsvlQg3CSUvr1b2tWk05LCpWoU8XVxVGpCvGphaeFc40swy/Mt 6nuxy6cZRT+u42NaNlGMqbwdL2axEqlKp7aSftp4DD4Vq04YyrmKUVl9eh9TfEL46fGS08E/smaB 4Th+FPhb42ftO63pfh671nWrbWfi58KPAt5pvwT8a/Gbxpf6TZeEPGXw+vviJpUyeBrnw14UurPx
January 12, 2011 - January 22, 2011
AeroElectric-Archive.digest.vol-ka
