AeroElectric-Archive.digest.vol-kd
February 13, 2011 - February 24, 2011
      http://www.aircraftspruce.com/catalog/elpages/masterrelay.php.
      Mounting will be different.
      If we use the latching capability, does is make circuitry simpler, more
      reliable, better, stronger, faster, (will it help prevent icing? - sorry,
      couldn't resist ;)
      I'm w/ Bob, definitely needs more noodling..
      -Jeff
Subject: Re: Open squelch
Date: Feb 13, 2011
The new firmware was suppose to fix the intercom squelch issues which it may do but in my case it seems they messed something up with the radio squelch.... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330866#330866 ________________________________________________________________________________
Date: Feb 13, 2011
Subject: Re: AOA indicator
At 08:01 PM 2/12/2011, you wrote: > > >That is what the original poster was referring to. Even though the >AOA is working perfectly, it is giving you false information. I think this is the 'nut' of what has yanked some folk's chains. Heated AOA or IAS will indeed continue to MEASURE and display the rudimentary stimulus that the sensor watches. IAS measures the DIFFERENCE of two pressures that is translated into a CALIBRATED IAS reading (complete with sweet-spots . . . or sweet-bands) AOA can be a vane that actually weather- cocks to align with relative wind -or- the system can measure pressure differentials. Both of those phenomenon are calculated upon interpreted, CALIBRATED data are displayed along with sweet-spots intended to be a guide for operation of the airplane. The concept often missed is that these sweet-spots are DERIVED numbers confirmed by repeated flight tests. In no case does either IAS or AOA directly measure the the conditions (shape) that set flying qualities of particular wing under conditions that exist right now. So while the heated instrument is indeed performing as advertised in spite of icing elsewhere on the airplane, prior CALIBRATIONS for the sweet-spot are no longer valid. It's perfectly GOOD information. IAS is correct. AOA is correct. But the rules of application have changed in ways that are difficult to scale without taking off our GA pilot's hat and putting on the engineering test pilot's hat. Here the debate becomes purely personal. Do you understand what's necessary to re- interpret this data before you attempt a landing? If so, it's your choice. But if not so sure, then what behaviors (plan-b) are most likely to produce a happy outcome while ignoring previous calibrations of compromised sweet-spots. Bob . . . ________________________________________________________________________________
Subject: Re: ALTRAK Dimmer Circuit
Date: Feb 13, 2011
Gang, Nothing heard from the list. As an aside, I tried contacting Trutrak, but according to the person I spoke, with the only tech who can answer my question only corresponds via email. His response to my query seemed to indicate he either didn't carefully read it, or he misunderstood it. I requested he call me to clarify, but so far no joy. Any help from the experts here would be greatly appreciated! -------- Mark Sletten Legacy FG N828LM http://www.legacyfgbuilder.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330874#330874 ________________________________________________________________________________
Date: Feb 13, 2011
Subject: Re: Machine Pin sub-D crimpers
At 11:58 PM 2/12/2011, you wrote: > > >Hi Group > >I modified my Steinair D-sub crimper (and Jans the same time) by >making new pins and moving them to the other side of the spring. > >See pics DSCN5312 thru 16: > >http://www.europaowners.org/forums/gallery2.php?g2_itemId=30957 > >I believe the tool with the modified ratchet is probably for High >Density pins, but with the ratchet ground off the last two clicks >works well for D-subs as well. Anyway if you have a tool that is >over-crimping D-sub machined pins, all hope is not lost Hmmm . . . It's not clear to me that the tool "supplied by Steinair" was stock. Over-crimping has never been an issue with any of the Eclipse tools that I'm aware of. Further, positioning of the spring has always been such that it presses the entry end of the positioner to the tools wire entry face. A little lathe (or file and drill motor) sculpting of a stock positioner will correct approximately .040" of mis-positioning. Some more lathe work will fabricate new positioners for HD pins. But in any case, errors of penetration for the punches is a whole new issue. I'd certainly like to put my hands on any tools that appear to be badly fabricated for this feature. Bob . . . >Ron Parigoris > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=330857#330857 > > Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Go ahead, make my day . . . > < show me where I'm wrong. > ================================ ________________________________________________________________________________
Date: Feb 13, 2011
Subject: Re: solid state relays
At 12:45 AM 2/13/2011, you wrote: >Hi Bob >What is your opinion of these relays as replacements for the >mechanical relays we have been using? >Jim Robinson Lamar (and perhaps others) have brought production solid state contactors to the market that are BI-DIRECTIONAL. I.e, the can both load and charge a battery making them suitable for battery contactors as opposed to rudimentary control devices (relays). Emacs! I have no reason to believe they do not perform as advertised. Lamar was going to send me one to play with but I think that offer fell into a crack. In any case, assuming they DO perform as advertised, what are your design goals that might drive a decision to substitute this product into your airplane? Assuming further that your airplane is architectured to offer a plan-b for contactor failure, will this substitution offer a demonstrable reduction in cost of ownership? Bob . . . ________________________________________________________________________________
Date: Feb 13, 2011
kuffel(at)cyberport.net wrote: > It will still tell me accurately if my angle of attack is well above stall with clean wings. While I don't know what my stall margin actually is at the moment I'm certainly better off than with no or incorrect AOA information. That depends on how you interpret and use the data it provides. If you are flying with an iced wing, the only data even the most accurate AOA indication provides is that the wing is not stalling at the current AOA. An AOA indicator is only that; an indicator. It tells you the current angle of attack. Its only value lies in knowing a second crucial piece of data: at what AOA the wing will stall. If your wing is iced you no longer have the second crucial piece of data. Given that you have not stalled, the AOA indicator is not providing data you don't already have, that you have, in fact, not stalled. How does an accurate AOA indication help in this scenario? Mark Sletten Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330881#330881 ________________________________________________________________________________
Subject: A210 issues with Radio (not intercom) squelch always
open
Date: Feb 13, 2011
If you are having problems with the your A210 radio squelch (not intercom) always being open or taking the max setting of 10 to prevent it from opening please contact http://www.icomamerica.com/en/contactusform.aspx?ContactType=TS and let them know so they might start to build a case on this one. It seems that version 1.53 has changed the way the radio squelch works for the worse... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330884#330884 ________________________________________________________________________________
Date: Feb 13, 2011
Tim, Please visit http://www.icomamerica.com/en/contactusform.aspx?ContactType=TS and let them know about this so they might start creating a case on this one. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330883#330883 ________________________________________________________________________________
Date: Feb 13, 2011
Bingo Bob, Thanks for the summary PaulW ======== At 07:04 AM 2/13/2011, you wrote: > > >At 08:01 PM 2/12/2011, you wrote: >> >> >>That is what the original poster was referring to. Even though the >>AOA is working perfectly, it is giving you false information. > > I think this is the 'nut' of what has > yanked some folk's chains. Heated AOA > or IAS will indeed continue to MEASURE and > display the rudimentary stimulus that > the sensor watches. IAS measures > the DIFFERENCE of two pressures that > is translated into a CALIBRATED IAS > reading (complete with sweet-spots > . . . or sweet-bands) > > AOA can be a vane that actually weather- > cocks to align with relative wind -or- > the system can measure pressure differentials. > Both of those phenomenon are calculated upon > interpreted, CALIBRATED data are displayed > along with sweet-spots intended to be > a guide for operation of the airplane. > > The concept often missed is that these > sweet-spots are DERIVED numbers confirmed > by repeated flight tests. In no case does > either IAS or AOA directly measure the > the conditions (shape) that set flying qualities > of particular wing under conditions that > exist right now. > > So while the heated instrument is indeed > performing as advertised in spite of icing > elsewhere on the airplane, prior CALIBRATIONS > for the sweet-spot are no longer valid. It's > perfectly GOOD information. IAS is correct. > AOA is correct. But the rules of application > have changed in ways that are difficult to scale > without taking off our GA pilot's hat and > putting on the engineering test pilot's hat. > > Here the debate becomes purely personal. > Do you understand what's necessary to re- > interpret this data before you attempt a > landing? If so, it's your choice. But if > not so sure, then what behaviors (plan-b) > are most likely to produce a happy outcome > while ignoring previous calibrations of > compromised sweet-spots. > > Bob . . . > > ________________________________________________________________________________
Date: Feb 13, 2011
Jim, I=99ve used them in several application in our projects. They performed well (better than the mechanicals) in high stress applications like running the hydraulic gear pump that is prone to fast on/off re-press cycles. In fact, I liked them so much I replaced my old heavy clunkers with the lighter Crydoms. http://www.berkut13.com/berkut50.htm#SSR Don=99t forget the =9Cfreewheel=9D diodes on motor loads. The schematics are in the data sheet. James Redmon Berkut/Race 13 From: James Robinson Sent: Saturday, February 12, 2011 10:45 PM Subject: AeroElectric-List: solid state relays Hi Bob What is your opinion of these relays as replacements for the mechanical relays we have been using? Jim Robinson www.newark.com/crydom+relay ________________________________________________________________________________
Subject: solid state relays
Date: Feb 13, 2011
The Crydom units seem pretty cool & for certain applications they are ideal but.. (putting on my devil's advocate hat..) There are a couple of things to consider: 1. They seem a little pricey - Digikey lists them for ~$118 each. (the equivalent 'can-type' contactor is ~$30) 2. If you need SPST or DPST contacts you are SOL 3. In many applications, you need to surround them w/ protection diodes and/or MOVs or whatever (more components to mount & connect & possibly fail.) An example: (I'm just making this up;) Let's say you want to run a PM motor forward & backward. You can create an H bridge circuit w/ 2 mechanical SPDT relays pretty easily & for less than $50. To accomplish the same thing w/ the Crydoms you'll need 4 Crydom units. (That's ~$500.) And some clever circuitry to prevent the wrong pairs of relays from energizing at the same time. (so you don't release their [expensive] magic smoke) With the versatility of a properly-chosen good-old mechanical relay, it is often possible to use the same relay in many different circuits aboard you plane. That can mean reduced part# count. That's simpler, easier to keep spares, allows emergency substitution, etc. Don't get me wrong, I'm all over semiconductors when they make circuitry simpler, better, cheaper, etc. But until the price point comes down quite a bit, it's hard to beat good-old mechanical relays. -Jeff _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of berkut13(at)berkut13.com Sent: Sunday, February 13, 2011 09:28 Subject: Re: AeroElectric-List: solid state relays Jim, I've used them in several application in our projects. They performed well (better than the mechanicals) in high stress applications like running the hydraulic gear pump that is prone to fast on/off re-press cycles. In fact, I liked them so much I replaced my old heavy clunkers with the lighter Crydoms. http://www.berkut13.com/berkut50.htm#SSR Don't forget the "freewheel" diodes on motor loads. The schematics are in the data sheet. James Redmon Berkut/Race 13 From: James Robinson <mailto:jbr79r(at)yahoo.com> Sent: Saturday, February 12, 2011 10:45 PM Subject: AeroElectric-List: solid state relays Hi Bob What is your opinion of these relays as replacements for the mechanical relays we have been using? Jim Robinson www.newark.com/crydom+relay ________________________________________________________________________________
Date: Feb 13, 2011
Subject: Re: Shorai LiFePO4
At 11:16 AM 1/31/2011, you wrote: > >Check out "Shorai". >New light weight Japanese LiFePO4 battery with quite enthousiastic >motorcyclist customers. >Works well enough at low temperatures. >Max. charging current 18A (no external shunts). Higher ratings coming. >Has a 5 pin plug that I suspect may give access to the 4 cells. >For our use I might want to monitor max. cell voltage to see <4V or >interrupt charging. Interesting offering. I had some conversation with my battery guru of more than 30 years (Skip Koss) last week. He was telling me of a Lithium product being sold onto come of the smaller bizjets. Amazing power to weight ratios when warm. But won't deliver more than 200A at 0C. Operators take the battery indoors for overnight storage at low temperatures. He also told me that GM was on their third supplier of lithium cells for offerings into the all electric car market. Qualification hoop-jumping levied by automobile manufacturers on purchased goods is about 3x the thickness of an FAA qual package. It does not bode well that a game of musical batteries has not produced a solid winner so late in the commitment to field a product. As the King of Siam might note, "curiouser and curiouser". Watch this space . . . Bob . . . ________________________________________________________________________________
Date: Feb 13, 2011
What you wrote is all true...however.... At work, we were using the Leech Mill-Spec, inert gas filled, high-end relays...they were still failing during circuit break due to arcing. 2 Crydoms were cheaper than 4 of these for an H-bridge. Admittedly, the switch to SSRs was done in the interest of a quick fix to get the vehicles back in air...but it did solve the problem. Putting the mechanicals in the H-bridge config was not a guarantee that the failures would not re-occur and we didn=99t want to pile on arc snubbers. Personally, I had more than reliability reasons for the change =93 mainly weight, environmental concerns, and ease of retrofit. -James From: Jeff Luckey Sent: Sunday, February 13, 2011 11:44 AM Subject: RE: AeroElectric-List: solid state relays The Crydom units seem pretty cool & for certain applications they are ideal but.. (putting on my devil=99s advocate hat..) There are a couple of things to consider: 1.. They seem a little pricey =93 Digikey lists them for ~$118 each. (the equivalent =98can-type=99 contactor is ~$30) 2.. If you need SPST or DPST contacts you are SOL 3.. In many applications, you need to surround them w/ protection diodes and/or MOVs or whatever (more components to mount & connect & possibly fail) An example: (I=99m just making this up;) Let=99s say you want to run a PM motor forward & backward. You can create an H bridge circuit w/ 2 mechanical SPDT relays pretty easily & for less than $50. To accomplish the same thing w/ the Crydoms you=99ll need 4 Crydom units. (That=99s ~$500.) And some clever circuitry to prevent the wrong pairs of relays from energizing at the same time. (so you don=99t release their [expensive] magic smoke) With the versatility of a properly-chosen good-old mechanical relay, it is often possible to use the same relay in many different circuits aboard you plane. That can mean reduced part# count. That=99s simpler, easier to keep spares, allows emergency substitution, etc. Don=99t get me wrong, I=99m all over semiconductors when they make circuitry simpler, better, cheaper, etc. But until the price point comes down quite a bit, it=99s hard to beat good-old mechanical relays. -Jeff ------------------------------------------------------------------------- ------- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of berkut13(at)berkut13.com Sent: Sunday, February 13, 2011 09:28 Subject: Re: AeroElectric-List: solid state relays Jim, I=99ve used them in several application in our projects. They performed well (better than the mechanicals) in high stress applications like running the hydraulic gear pump that is prone to fast on/off re-press cycles. In fact, I liked them so much I replaced my old heavy clunkers with the lighter Crydoms. http://www.berkut13.com/berkut50.htm#SSR Don=99t forget the =9Cfreewheel=9D diodes on motor loads. The schematics are in the data sheet. James Redmon Berkut/Race 13 ________________________________________________________________________________
Date: Feb 13, 2011
What concerns are there from "freewheel" diodes? Thanks, David M. berkut13(at)berkut13.com wrote: > Jim, > Ive used them in several application in our projects. They performed > well (better than the mechanicals) in high stress applications like > running the hydraulic gear pump that is prone to fast on/off re-press > cycles. In fact, I liked them so much I replaced my old heavy > clunkers with the lighter Crydoms. > http://www.berkut13.com/berkut50.htm#SSR > Dont forget the freewheel diodes on motor loads. The schematics > are in the data sheet. > James Redmon > Berkut/Race 13 > *From:* James Robinson > *Sent:* Saturday, February 12, 2011 10:45 PM > *To:* aeroelectric-list(at)matronics.com > > *Subject:* AeroElectric-List: solid state relays > Hi Bob > What is your opinion of these relays as replacements for the > mechanical relays we have been using? > Jim Robinson > > > www.newark.com/ <http://www.newark.com/>*crydom+relay* > > * > > > * -- If you're an American, just say NO to the Obamanation, to socialism, and get rid of Soros. ________________________________________________________________________________
Date: Feb 13, 2011
Hi Bob To clarify things, I was speaking about two separate tools, one from Steinair on the right and one that was lent to me which is on the left. The Steinair tool is on the right and crimps D-sub pins just fine. The problem with the one I received was it had an aluminium spacer on the wrong side of the spring, and even if you put it on the right side of the spring, it would not properly position D-sub machined pins. That said, the tool on the left which was lent to me has a nice machined brass spacer that works perfect on the Steinair tool to position D-sub machined pins, so I made one exactly the same as the tool on the left and installed it on my Steinair tool on the right and now the Steinair tool works perfectly with machined D-sub pins. I made a comment about the tool on the left. It is plenty old if rust and corrosion is any tell. I have no idea where it came from. The dies are different compared to the Steinair tool. If you insert a D-sub machined pin and squeeze the tool all the way it will over crimp. Someone ground off two of the ratchet teeth where instead of having to squeeze 5 notches before the tool releases, it releases after three ratchet notches. If you are careful it works fine on machined D-sub pins if you only click three times. I know the tool is designed for slightly smaller diameter pins and made mention if someone else happens to have one of these and tries to crimp a D-sub machined pin and obviously notices it overcrimps, by grinding off a few notches you can easily get by with this tool, and if you need to crimp smaller diameter pins, just crimp all the way. Sorry for any confusion. Ron Parigoris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330952#330952 ________________________________________________________________________________
Date: Feb 13, 2011
>From diodes? Point them the correct direction. >From the motor...there is a reverse break down current generated when the power to the motor is cut off. That reverse flow of current is not good for the MOSFET inside the SSR. The diodes channel that current back to the robust windings of the motor (freewheeling) instead of making the SSR convert it to heat. Fun stuff, no? -James -----Original Message----- From: David Sent: Sunday, February 13, 2011 12:45 PM Subject: Re: AeroElectric-List: solid state relays What concerns are there from "freewheel" diodes? Thanks, David M. ________________________________________________________________________________
Date: Feb 13, 2011
I currently have one com antenna in the vertical of my Glasair. I only have one comm radio SL30. I have been thinking of adding a second com radio, possibly a Garmin 430. Will I need an audio panel also? Can both radios share the one antenna? Or what would be the best arrangement for the setup? Jim James Robinson Glasair lll N79R Spanish Fork UT U77 ________________________________________________________________________________
Date: Feb 13, 2011
Subject: AOA
My comment on icing and AOA systems ~~If you encounter any type of icing turn the AOA OFF unless you have full de-icing vane & aircraft. We haven't even done R&D on a heated vane because of liability. Even Boeing can't give you hard numbers with icing on wings. Heated vane and icing on wings is NOT a good deal! Elbie Mendenhall, EM Aviation, LLC _www.riteangle.com_ (http://www.riteangle.com) Is it your understanding that Elbie > claims that the "sweet spot" on his or any other > AOA display is golden under all challenges that > a pilot might face for comfortable arrival with > the earth? > ________________________________________________________________________________
Date: Feb 13, 2011
Subject: Re: Battery disconnect switch
Jeff, What I mean by noisy is 86 dB. That is the noise generated by the device as listed on the Tyco web site. 86 dB, while not immediately damaging to hearing, is very loud and can damage hearing if experienced over time. I wasn't referring to "noise" that would interfere with radio transmissions. 1. I don't know if the noise is continuous. Check with Tyco. 2. My experience with contactors normally used in aircraft is that the only significant noise generated is when the contactor is initially excited and the noise is the mechanical movement rather than an electrical noise. Thus, if the Tyco web site information is correct and if the noise is continuous, then my estimate is that the Tyco device is noisier than traditional solenoids. 3. No. Stan Sutterfield In a message dated 2/13/2011 3:01:45 A.M. Eastern Standard Time, aeroelectric-list(at)matronics.com writes: Not sure what you mean by noisy. Can you be more specific? 1. Is the noise continuous? 2. Is this device any noisier than the traditional solenoid? 3. Have you done some kind of testing or do you have you worked w/ this device? ________________________________________________________________________________
Subject: Power for Checking Systems Out on the Ground
Date: Feb 13, 2011
Bob N., et al, I'm getting closer to powering up my new IFR panel. I need a source of power for an extended period of time on the ground without the engine running for checking out the systems, their initial set-up, and for training myself on the real boxes. I have a BatteryMINDer charger/maintainer and a Radio Shack power supply whose output is rated at 13.8 VDC at 15 Amps. Should I just disconnect the main battery and use the power supply in its place? Can I hook the power supply up to the battery + and - terminals and use it as a "battery booster" (or would this toast the battery)? Should I just use the battery and charge it overnight with the BatteryMINDer? Other? I intend to bring up one circuit at a time and I want to measure each circuit's actual power consumption and I'll need to be careful not to overload the power supply. Best regards, Bob Falstad GlaStar N248BF ________________________________________________________________________________
Date: Feb 13, 2011
Stan, I thought you were referring to electrical noise and thus was a little confused. I'm certain that it is not a continuous noise - just a single "thunk" or loud click when switching. The mechanical noise it makes when switching has never been a design criteria for me. (we aren't talking about nuclear submarines here;). Thanks for the clarification. _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Speedy11(at)aol.com Sent: Sunday, February 13, 2011 19:29 Subject: AeroElectric-List: Re: Battery disconnect switch Jeff, What I mean by noisy is 86 dB. That is the noise generated by the device as listed on the Tyco web site. 86 dB, while not immediately damaging to hearing, is very loud and can damage hearing if experienced over time. I wasn't referring to "noise" that would interfere with radio transmissions. 1. I don't know if the noise is continuous. Check with Tyco. 2. My experience with contactors normally used in aircraft is that the only significant noise generated is when the contactor is initially excited and the noise is the mechanical movement rather than an electrical noise. Thus, if the Tyco web site information is correct and if the noise is continuous, then my estimate is that the Tyco device is noisier than traditional solenoids. 3. No. Stan Sutterfield In a message dated 2/13/2011 3:01:45 A.M. Eastern Standard Time, aeroelectric-list(at)matronics.com writes: Not sure what you mean by noisy. Can you be more specific? 1. Is the noise continuous? 2. Is this device any noisier than the traditional solenoid? 3. Have you done some kind of testing or do you have you worked w/ this device? ________________________________________________________________________________
Subject: No click when pushing PTT
Date: Feb 13, 2011
Just trying to start the troubleshooting of a strange issue I have in my plane. When I push PTT button while COM2 is selected, I don't get that click at the beginning of transmission... The radio transmits just fine.. just doesn't give that click. COM1 works fine. Both are using same PTT button and are wired into the PSE 8000 audio panel. (COM1 is Garmin 530W and COM2 is Garmin 430W) Since the radio works fine it's a somewhat lower priority issue, but it does cause a problem when flying at night... I cannot turn on the runway lights with the second radio because the click isn't there... Tried swapping antenna leads but that didn't help... haven't tried anything else yet.. looking for some ideas.. Thanks! -------- RV-7A N777TY Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330985#330985 ________________________________________________________________________________
Subject: Inexpensive HID light data point
Date: Feb 14, 2011
I bought a pair of 35W HID lights from Ebay to replace the bulbs in my 55w Duckworks kit that was a set of fog lights converted to use with their brackets. I got the 6000K H3 bulbs because I wanted white white light. The 55w halogens always looked very warm in color. The HID kit was advertised as a "Digital" ballast kit. After looking at a million sites selling these things it seems that almost all of them are clones of one another and or made by the same shop in China. The kit I bought was ~$37 delivered for the pair. I did open the ballast after I received them and they do appear to be mostly electronic but there was a small transformer in there. The inside was sprayed/potted with a rubber coating so it was hard to tell what was really in there. Anyway....I mounted the ballast to the back of the Duckworks bracket using the mounting bracket that came with the kit. I did modify the bracket somewhat to cut off extra that was not needed. The wiring was simple as pie. After mounting everything and turning them on, I can honestly say that these things are at least three times brighter than the 55w halogens. Here is a comparison, the left side is the HID, the right is the 55w halogen: Here they are straight on with the beam: Same shot with the old 55w: I had to leave the airport before it got dark so I did not get any other pics. One thing...I tried to wig-wag these after they warmed up but that was a no go!!! They will not wig-wag with the NAPA flasher relay!!! Maybe they would with one of the solid state wig-waggers but they won't with the NAPA relay. It just buzzed and sounded like it was going to fry itself so I stopped trying after a second or two. I have always been afraid to try and regain my night currency (never had it in a TW airplane) with those dim 55w halogens. Maybe now I can give it a whirl. Just ordered one of these http://www.soundoffsignal.com/warnamber/flashers/Headlight/ETHFSS-SP.htm . Since it is totally solid state, maybe it will work. It also has a few different flash speeds to pick from. Here is an iPhone Video of my new inexpensive HID's wig-wagging with the new flashed I installed. Works better than great!!! http://www.youtube.com/watch?v=vY7UcK6XD2s To finish the story on my inexpensive HID lights, after flying with them for some time I did notice that they reflected a ton of high frequency noise back onto the power lines. This is clearly evident when listening to the background noise on any non-active com channel with the squelch in test mode or open. This noise also caused my Dynon's DSAB bus to drop out...really bad in Wig-Wag mode... The HIDs initially give a pretty good "bezerp" when they ignite and then they settle into just plain old static. The noise threshold is obvioulsy increased quite a bit. The Wig-Wag mode only exacerbates this issue. If they are warm, the Wig-Wag does not bezerp each time they come on, they ignite instantly with no "bezerp" but the noise floor is still elevated. Those that know a little about radio will understand that just because you can squelch out background noise, it is not desirable to just mask the issue since an increased or high noise threshold can cause your AGC circuit in the radio to automatically reduce the sensitivity of the receiver resulting in poor performance. That being said, Here was the fix: I installed a Ferrite Core as close to the HID ballast as possible. I wrapped the power and ground wires thru the core three times each. Ferrite cores act as a choke to high frequencies basically blocking them at the source before they can do any harm. I also installed a .1uF capacitor across the power and ground wires right behind the ferrite core. This capacitor functions as a decoupling capacitor and will shunt any high frequencies that get past the ferrite core to ground before they can travel back up the power wire. The ferrite core I used is similar to this one: The results are complete elimination of the noise reflected back onto the aircraft's systems. No noticable noise floor increase, no Dynon DSAB dropouts!!! Could not even tell I had switched them on and the Wig-Wag only results in some very slight clicks over the intercom. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331009#331009 ________________________________________________________________________________
Date: Feb 14, 2011
Subject: Re: AOA
At 08:03 PM 2/13/2011, you wrote: >My comment on icing and AOA systems ~~If you encounter any type >of icing turn the AOA OFF unless you have full de-icing vane & >aircraft. We haven't even done R&D on a heated vane because of >liability. Even Boeing can't give you hard numbers with icing on >wings. Heated vane and icing on wings is NOT a good deal! >Elbie Mendenhall, EM Aviation, >LLC <http://www.riteangle.com>www.riteangle.com Exactly. The fleet of bizjets at HBC were all qualified for flight into known ice. Everything was heated or hammered. I'll have to call some of my jet-jockey friends at HBC and inquire as to words in the POH concerning usefulness and cautions about AOA displays on the production fleet. I worked a REALLY strange problem on the Beechjet some years back were pilots experienced loss of IAS on BOTH sides of the airplane. Displays always recovered at lower, warmer altitudes. This often occurred in relatively clear air. There was a LOT of brainstorming by a LOT of grey beards as to the physics behind this rare but disturbing event. My task involved cutting a pitot tube open, peppering it with thermocouples and putting it back together again so that we could study not only temperatures at the surfaces to be de-iced but internally. There was some question of ice crystals bouncing through the labyrinth of pressure channels only to melt and re-freeze inside the pitot tube. During the fire drill for sniffing out root cause, somebody asked the question: "How does the existence of a working AOA display help the pilot who is temporarily deprived of IAS?" Good question. The Beechjet had been fitted with AOA indication since its birth as the Mitusbishi Diamondjet. But nobody had ever researched and written the approve procedure for using AOA as an aid to maneuvering without IAS. That amendment was quickly added to the POH. I'm not sure we ever deduced how pitot pressure was being obstructed. I'll have to ask how that problem resolved too. But it was interesting that a perfectly useful display had existed for so long but was never fully developed as a component of plan-b, plan-c, etc. Shucks, with DUAL air data systems, what are the odds? Bob . . . ________________________________________________________________________________
Subject: HID Light marketing
Date: Feb 14, 2011
There seems to be a lot of marketing ploys etc. for the HID lights. I have a couple of questions to help clearify the hype. Some of the descriptions say HID type lights with halogen bulbs, and some are HID devices with xenon bulbs. 1. Does a true HID light use only a xenon lamp? 2. Is a so called HID type Halogen a real HID light, with the same brightness as a xenon? 3. Does anyone have a temperature/color spectrum chart for HID lights? example: 6000K, 10000k 4. Does anyone have a chart/description for Lamp configurations? Example: H3 Roger ________________________________________________________________________________
Subject: Re: HID Light marketing
Date: Feb 14, 2011
HID Lights use an Arc Tube bulb. No filament like a Halogen HID Type Halogens are not HID I used the 6000K H3 bulbs. 5000K-6000K is about as white as white can get! Here you go: Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331029#331029 ________________________________________________________________________________
Date: Feb 14, 2011
If you have a look at an e-bay listing (example here - e-bay listing # 280629659435) they give a colour chart v Ktemps John ----- Original Message ----- From: "Roger" <mrspudandcompany(at)verizon.net> Sent: Monday, February 14, 2011 3:37 PM Subject: AeroElectric-List: HID Light marketing > > > There seems to be a lot of marketing ploys etc. for the HID lights. I > have a couple of questions to help clearify the hype. Some of the > descriptions say HID type lights with halogen bulbs, and some are HID > devices with xenon bulbs. > > 1. Does a true HID light use only a xenon lamp? > > 2. Is a so called HID type Halogen a real HID light, with the same > brightness as a xenon? > > 3. Does anyone have a temperature/color spectrum chart for HID lights? > example: 6000K, 10000k > > 4. Does anyone have a chart/description for Lamp configurations? > Example: H3 > > Roger > > > ________________________________________________________________________________
Date: Feb 14, 2011
Subject: Re: Power for Checking Systems Out on the Ground
> Can I hook the power supply up to the battery + and - terminals > and use it as a "battery booster" (or would this toast the > battery)? Should I just use the battery and charge it overnight > with the BatteryMINDer? Other? Most power supplies are NOT intended to work in conjunction with a battery. The primary difficulty arises when the battery is connected to a powered down power supply. Output monitoring and ov protection in many supplies do not like to be "back fed" from an external power source. My favorite technique uses a hefty switchmode power supply similar to this: http://tinyurl.com/4aoszlf Combine this supply with a power diode (to prevent back feeding) and a relay to emulate the "field control" input on your ship's alternator. The relay controls 120 vac going into the power supply. You can connect this AC mains powered "alternator" in place of the ship's alternator. With the alternator emulator ON, adjust the power supply for a 14.2 volt bus. The ship's load meter (if installed) can be used to monitor loads on the power supply. This will allow you to run the ship's battery in parallel to let it pick up any transient loads that might exceed the ratings of the power supply. >I intend to bring up one circuit at a time and I want to measure >each circuit's actual power consumption and I'll need to be careful >not to overload the power supply. If it's a switchmode supply, it will have built in overload protection. Further, the supply I linked above has a thermostatically controlled fan built in that turns on when the supply is being taxed to rated output. Bob . . . ________________________________________________________________________________
Date: Feb 14, 2011
>I have a BatteryMINDer charger/maintainer and a Radio Shack power >supply whose output is rated at 13.8 VDC at 15 Amps. > >Should I just disconnect the main battery and use the power supply >in its place? Can I hook the power supply up to the battery + and - >terminals and use it as a "battery booster" (or would this toast the battery)? Forgot to touch on this. Your existing supply output voltage is not high enough to hook directly across a battery and still have the recommended isolation (back feed prevention) diode. So you can use the power supply to emulate a battery. Disconnect the battery and put the power supply in its place. Bob . . . ________________________________________________________________________________
Date: Feb 14, 2011
Subject: Re: No click when pushing PTT
At 10:32 PM 2/13/2011, you wrote: > >Just trying to start the troubleshooting of a strange issue I have >in my plane. When I push PTT button while COM2 is selected, I don't >get that click at the beginning of transmission... The radio >transmits just fine.. just doesn't give that click. COM1 works >fine. Both are using same PTT button and are wired into the PSE >8000 audio panel. (COM1 is Garmin 530W and COM2 is Garmin 430W) > >Since the radio works fine it's a somewhat lower priority issue, but >it does cause a problem when flying at night... I cannot turn on the >runway lights with the second radio because the click isn't there... > >Tried swapping antenna leads but that didn't help... haven't tried >anything else yet.. looking for some ideas.. Thanks! Are you expecting to get an audible click from the radio itself? I think the use of electro-mechanical relays common to transceivers for 50 years have been replaced with all solid state switching. If the radio is working, it's probably performing as advertised. Bob . . . ________________________________________________________________________________
Subject: Re: Speaking of Wig Wags
Date: Feb 14, 2011
Tom, You can Wig-Wag HID's with the right flasher. The Napa relay won't work but this one will: http://www.soundoffsignal.com/warnamber/flashers/Headlight/ETHFSS-SP.htm http://www.youtube.com/watch?v=vY7UcK6XD2s Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331052#331052 ________________________________________________________________________________
Subject: Permanent Magnet Alternators - Over Voltage Protection
Date: Feb 14, 2011
I live in the UK where the Rotax 912 with its 18 amp Permanent Magnet Alternator (PMA) is ubiquitous. Many folks are now fitting very expensive avionics in their Rotax engined aircraft and are keen to guard against over voltage (I know how rare that is with PMA regulators - but it does occasionally happen). The only device that I have come across to meet this need is the excellent B&C 505-1 (I have B&C alternators on my RV - outstanding pieces of kit). I spoke to TJ at B&C who could not have been more helpful but did explain that the 505 had not been tested an any other PMA other than their own alternators and so he could not formally recommend it for the Rotax PMA or any other PMA for that matter - a position which I understand. As I understand it the 505 OV module controls the relay which takes the output from the PMA regulator. If an OV event occurs the OV module releases the main relay contacts and so cuts off the supply voltage to the main bus. If my understanding is not wildly out it would appear that the 505 could be used successfully on almost any PMA (Relay current limitations not withstanding) including the Rotax. I would be grateful for any experiences of members who have used the 505 on PMA's such as the Rotax etc, or any another comments about the 505 generic suitability, and who could confirm whether or not they agree that the 505 seems suitable as a generic PMA OV device. Many thanks Mark Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331083#331083 ________________________________________________________________________________
Date: Feb 14, 2011
Thanks for your article in the previous message. Do you have any more specifics about the bulbs that you are using? On Mon, Feb 14, 2011 at 11:13 AM, Brantel wrote: > > HID Lights use an Arc Tube bulb. No filament like a Halogen > > HID Type Halogens are not HID > > I used the 6000K H3 bulbs. 5000K-6000K is about as white as white can get! > > Here you go: > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=331029#331029 > > ________________________________________________________________________________
Date: Feb 14, 2011
This may be slightly off topic but is there anything wrong with charging my a/c battery (modern automatic charger) without disconnecting from the battery terminals from the a/c? I hook up the charger occasionally in order to maintain the battery if I am not flying regularly. Also,if I am testing electrical components such as radios or lights I have the charger hooked up in order to more accurately simulate actual alternator operation. The a/c engine is a Rotax 912UL. Is there something wrong with this reasoning? Don On Mon, Feb 14, 2011 at 12:10 PM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > nuckolls.bob(at)aeroelectric.com> > > > I have a BatteryMINDer charger/maintainer and a Radio Shack power supply >> whose output is rated at 13.8 VDC at 15 Amps. >> >> Should I just disconnect the main battery and use the power supply in its >> place? Can I hook the power supply up to the battery + and - terminals and >> use it as a "battery booster" (or would this toast the battery)? >> > > Forgot to touch on this. Your existing supply output > voltage is not high enough to hook directly across a > battery and still have the recommended isolation > (back feed prevention) diode. So you can use the > power supply to emulate a battery. Disconnect > the battery and put the power supply in its place. > > > Bob . . . > > ________________________________________________________________________________
Date: Feb 14, 2011
I used the 6000K H3 bulbs Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331090#331090 ________________________________________________________________________________
Date: Feb 14, 2011
Yes, I'm expecting a click.. Considering that the other one which is same technology (ie, not a case of old vs. new) I'd think the expectation is reasonable :) Don't remember last time I ran into this situation in any plane ... so what I'm experiencing on COM2 is not typical.. Looking for ideas what to look at.. -------- RV-7A N777TY Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331092#331092 ________________________________________________________________________________
Date: Feb 14, 2011
At 07:02 PM 2/14/2011, you wrote: > >Yes, I'm expecting a click.. Considering that the other one which >is same technology (ie, not a case of old vs. new) I'd think the >expectation is reasonable :) Don't remember last time I ran into >this situation in any plane ... so what I'm experiencing on COM2 is >not typical.. Looking for ideas what to look at.. Maybe I missed something . . . is the radio misbehaving in any other way that being free of audible noises when you hit the PTT button? Bob . . . ________________________________________________________________________________
Date: Feb 14, 2011
At 05:49 PM 2/14/2011, you wrote: >This may be slightly off topic but is there anything wrong with >charging my a/c battery (modern automatic charger) without >disconnecting from the battery terminals from the a/c? I hook up the >charger occasionally in order to maintain the battery if I am not >flying regularly. Also,if I am testing electrical components such as >radios or lights I have the charger hooked up in order to more >accurately simulate actual alternator operation. The a/c engine is a >Rotax 912UL. Is there something wrong with this reasoning? No, as long as your external power source is INTENDED to be connected across a battery (and will not be damaged if the input power is disconnected while the battery is still attached) then there's no reason not to leave it connected during ground ops. Bob . . . ________________________________________________________________________________
Date: Feb 14, 2011
Subject: Re: Permanent Magnet Alternators - Over Voltage Protection
At 04:49 PM 2/14/2011, you wrote: > >I live in the UK where the Rotax 912 with its 18 amp Permanent >Magnet Alternator (PMA) is ubiquitous. > >Many folks are now fitting very expensive avionics in their Rotax >engined aircraft and are keen to guard against over voltage (I know >how rare that is with PMA regulators - but it does occasionally happen). Recommend you use the parts supplied in the BC505-1 kit and wire per http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z16M.pdf Bob . . . ________________________________________________________________________________
From: Bob McCallum <robert.mccallum2(at)sympatico.ca>
Date: Feb 14, 2011
Bob; I think you might have missed the part where he said that his com 2 radio will not activate pilot controlled lighting whereas his com 1 will. He is associating the "missing click" with the inability to activate the lighting systems. Other than this one item it operates "normally" Bob McC > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list- > server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III > Sent: Monday, February 14, 2011 8:13 PM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Re: No click when pushing PTT > > > > At 07:02 PM 2/14/2011, you wrote: > > > >Yes, I'm expecting a click.. Considering that the other one which > >is same technology (ie, not a case of old vs. new) I'd think the > >expectation is reasonable :) Don't remember last time I ran into > >this situation in any plane ... so what I'm experiencing on COM2 is > >not typical.. Looking for ideas what to look at.. > > Maybe I missed something . . . is the radio > misbehaving in any other way that being > free of audible noises when you hit the > PTT button? > > Bob . . . > > > _- > ==================================================== > ====== > _- > ==================================================== > ====== > _- > ==================================================== > ====== > _- > ==================================================== > ====== > > ________________________________________________________________________________
Date: Feb 14, 2011
Yes, the radio works fine otherwise (as in, it transmits fine). COM1 produces the click (hence I can turn on the runway lights). COM2 doesn't do that. It's not audible, and consequently lights don't come on.. I can hear the click on COM1 (and as a result, lights can be turned on, for example).. -------- RV-7A N777TY Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331101#331101 ________________________________________________________________________________
Date: Feb 14, 2011
On 2/14/2011 8:58 PM, N777TY wrote: > --> AeroElectric-List message posted by: "N777TY" > > Yes, the radio works fine otherwise (as in, it transmits fine). COM1 produces the click (hence I can turn on the runway lights). COM2 doesn't do that. It's not audible, and consequently lights don't come on.. > > I can hear the click on COM1 (and as a result, lights can be turned on, for example).. > > -------- > RV-7A > N777TY I would expect the light control radio to trigger on just the carrier, but for troubleshooting purposes you might try synthesizing a click verbally while holding the xmit button for each trigger, & see if the light control radio would respond to that, assuming that it really needs to see audio on the carrier. I'd also ask the control radio's mfgr about whether it just listens for carrier or not. Charlie ________________________________________________________________________________
Subject: Vx Aviation expands it's EFIS Wiring Hub Product Line
Date: Feb 14, 2011
This is a follow up to a previous announcement made on 'Lectric List. I've been a long time follower and contributer, and I hope this is of interest to many. Thanks, Vern Little Vx Aviation www.vx-aviation.com Summary of Announcement: ======================== Vx Aviation Enhances EFIS Wiring Hub Family VICTORIA, BC---February 15, 2011---Vx Aviation today announced the introduction of three new AXIS wiring hub devices for the interconnect of Electronic Flight Information Systems (EFIS) to other avionics and instrumentation behind the instrument panel in owner-built aircraft. The new AXIS-9A, AXIS-25A and GBX-25A join the previously announced AXIS-15A to provide a complete family of wiring hubs. The AXIS-9A is specific to the Dynon SkyView Network and functions as a multi-port splitter, providing a 9-wire backplane and allowing up to five SkyView Network compatible instruments to be connected together. The AXIS-25A is a general-purpose 25-wire backplane with five connectors that facilitate the wiring of modern avionics panels that have a large number of RS-232, ARINC-429 and similar data interconnects, such as would be found on IFR panels. The GBX-25A is a ground bus wiring block that simplifies the distribution of low-current ground or power by providing 25 bused connections. ======================== ________________________________________________________________________________
Date: Feb 14, 2011
Subject: Re: 2nd radio
I am considering a second radio. I currently have a SL30. I would like to add a second radio, but only have 1 antenna. Can 2 radios share 1 antenna? Are there problems with this approach? Will I have to add a audio panel? Jim James Robinson Glasair lll N79R Spanish Fork UT U77 ________________________________ From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Sent: Mon, February 14, 2011 9:06:47 AM Subject: Re: AeroElectric-List: Power for Checking Systems Out on the Ground Can I hook the power supply up to the battery + and - terminals and use it as a "battery booster" (or would this toast the battery)? Should I just use the battery and charge it overnight with the BatteryMINDer? Other? Most power supplies are NOT intended to work in conjunction with a battery. The primary difficulty arises when the battery is connected to a powered down power supply. Output monitoring and ov protection in many supplies do not like to be "back fed" from an external power source. My favorite technique uses a hefty switchmode power supply similar to this: http://tinyurl.com/4aoszlf Combine this supply with a power diode (to prevent back feeding) and a relay to emulate the "field control" input on your ship's alternator. The relay controls 120 vac going into the power supply. You can connect this AC mains powered "alternator" in place of the ship's alternator. With the alternator emulator ON, adjust the power supply for a 14.2 volt bus. The ship's load meter (if installed) can be used to monitor loads on the power supply. This will allow you to run the ship's battery in parallel to let it pick up any transient loads that might exceed the ratings of the power supply. I intend to bring up one circuit at a time and I want to measure each circuit's actual power consumption and I'll need to be careful not to overload the power supply. If it's a switchmode supply, it will have built in overload protection. Further, the supply I linked above has a thermostatically controlled fan built in that turns on when the supply is being taxed to rated output. Bob . . . ________________________________________________________________________________
Date: Feb 15, 2011
From: Etienne Phillips <etienne.phillips(at)gmail.com>
Hi Jim If it is possible to share an aerial, do you want to? It would be a single point of failure for both radios... Every time I've has an issue with my radio, it's been an antenna problem (about 4 times in 12 years). Having an independent radio is more useful to me as a backup than a convenience, and so would require an independent aerial. But that's me! Thanks Etienne On 15 February 2011 08:05, James Robinson wrote: > I am considering a second radio. I currently have a SL30. I would like to > add a second radio, but only have 1 antenna. Can 2 radios share 1 antenna? > Are there problems with this approach? Will I have to add a audio panel? > Jim > > James Robinson > Glasair lll N79R > Spanish Fork UT U77 > ________________________________________________________________________________
Date: Feb 15, 2011
At 08:58 PM 2/14/2011, you wrote: > >Yes, the radio works fine otherwise (as in, it transmits >fine). COM1 produces the click (hence I can turn on the runway >lights). COM2 doesn't do that. It's not audible, and consequently >lights don't come on.. > >I can hear the click on COM1 (and as a result, lights can be turned >on, for example).. When you say 'transmits fine' do I presume that you can communicate with some distant facility? If on the ground, can you talk to say a distant aircraft and the pilot reports strong signal on either radio? Suggest you get a rough reading on power output. You can do this with the most rudimentary of SWR meters if you don't have access to a real wattmeter. Use the meter to check the #1 system and set the device for a full scale, forward reading on #1 then move it to #2 without changing the calibration. Talking to another airplane in the hangar or to a local hand held might appear to be just fine when in fact, transmitted power output is a tiny fraction of what it should be. Bob . . . ________________________________________________________________________________
Date: Feb 15, 2011
I would expect the first thing to do is to verify your radio is not transmitting... If you have another radio close by you can test the transmitter is operating. An old trick we used to do with taxicabs years ago was to have someone hold a fluorescent tube (tube only completely unplugged) close to the transmitting antenna and key the mic. If the tube lights up the transmitter is active. Of course you can also see if you are putting out any power by inserting an SWR meter in the antenna feed line. In this case where you are only looking for the presence of power the cheapest of SWR meters will suffice. As Bob said, gone are the days when there were mechanical relays happily chattering open and closed with every transmission. Noel -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of N777TY Sent: February 14, 2011 9:33 PM Subject: AeroElectric-List: Re: No click when pushing PTT Yes, I'm expecting a click.. Considering that the other one which is same technology (ie, not a case of old vs. new) I'd think the expectation is reasonable :) Don't remember last time I ran into this situation in any plane ... so what I'm experiencing on COM2 is not typical.. Looking for ideas what to look at.. -------- RV-7A N777TY Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331092#331092 ________________________________________________________________________________
Date: Feb 15, 2011
>I would expect the light control radio to trigger on just the >carrier, but for troubleshooting purposes you might try synthesizing >a click verbally while holding the xmit button for each trigger, & >see if the light control radio would respond to that, assuming that >it really needs to see audio on the carrier. > >I'd also ask the control radio's mfgr about whether it just listens >for carrier or not. If the lighting control system needs audio, it would be a published feature. Some of the early lighting control systems were jury-rigged onto the facility's unicom radio. It was a circuit that needed to see a sweeping frequency tone that pilots were expected to generate by whistling. I haven't seen one of those in service in 30 years. They're all carrier operated now and generally have their own dedicated receiver. I would certainly resolve the power output question first. Bob . . . ________________________________________________________________________________
Date: Feb 15, 2011
At 12:24 AM 2/15/2011, you wrote: >Hi Jim > >If it is possible to share an aerial, do you want to? It would be a >single point of failure for both radios... Every time I've has an >issue with my radio, it's been an antenna problem (about 4 times in >12 years). Having an independent radio is more useful to me as a >backup than a convenience, and so would require an independent >aerial. But that's me! > Excellent point. Antenna duplexers for transceivers are not cheap. Two antennas are certainly the least expensive and most reliable configuration. You don't need an audio panel but probably an audio isolation amplifier as described in the 'Connection's audio chapter. http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z16M.pdf Bob . . . ________________________________________________________________________________
Date: Feb 15, 2011
Subject: Low Ohms Adapters
I was able to finish the batch before I had to leave M.L. on important matters last Saturday. Had a Valentine's day appointment with my grandkids and later my wife! I've been in Lindsborg the last few days and will be back in the shop this afternoon. All low ohms adapters on order will go out first class mail this afternoon. I've not finished the official instruction sheet but there's probably enough info in these photos http://www.aeroelectric.com/Catalog/AEC/9008/ to noodle out how the critter is used. I'll announce publication of the official instruction sheet as soon as it's posted. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Feb 15, 2011
At 08:06 AM 2/15/2011, you wrote: > >I would expect the first thing to do is to verify your radio is not >transmitting... If you have another radio close by you can test the >transmitter is operating. An old trick we used to do with taxicabs years >ago was to have someone hold a fluorescent tube (tube only completely >unplugged) close to the transmitting antenna and key the mic. If the tube >lights up the transmitter is active. Yeah, that was the primary reason for keeping the little NE-2 or NE-51, neon bulbs around. Emacs! They were handy for 'sniffing' strong RF either within a transmitter or out on the antenna. Since then transmitters have morphed to low-voltage, high- current architectures. The lamps won't sniff within the circuitry but will still light up when held in close proximity to the tip of a 1/4-wave antenna. Haven't tried it but I suspect it will still be limited to getting excited at 5 watts or more. One is looking for an RF field on the order of 75 volts or more to capacitively excite these lamps into visible activity. The very first transmitter I built http://tinyurl.com/4hwa2da had an NE-2 permanently attached to the hot side of the tank coil and could be used to tune the transmitter. Can anyone spot a risk-issue in this as-published diagram? Bob . . . ________________________________________________________________________________
Date: Feb 15, 2011
I'll have a stab at it - when the switch is open, the chassis sits at line voltage? On 15 February 2011 16:49, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: Can anyone spot a risk-issue in > this as-published diagram? > > Bob . . . > ________________________________________________________________________________
Date: Feb 15, 2011
#1 The chassis is directly connected to the line. #2 the switch is in what is hopefully the ground side of the line. #3 It's probably old enough that the line plug is not polarized and the cha ssis may be attached to the "hot" side of the line. More than one person has been electrocuted with such a layout. Bob McC Date: Tue=2C 15 Feb 2011 08:49:32 -0600 From: nuckolls.bob(at)aeroelectric.com Subject: RE: AeroElectric-List: Re: No click when pushing PTT At 08:06 AM 2/15/2011=2C you wrote: > I would expect the first thing to do is to verify your radio is not transmitting... If you have another radio close by you can test the transmitter is operating. An old trick we used to do with taxicabs years ago was to have someone hold a fluorescent tube (tube only completely unplugged) close to the transmitting antenna and key the mic. If the tube lights up the transmitter is active. Yeah=2C that was the primary reason for keeping the little NE-2 or NE-51=2C neon bulbs around. They were handy for 'sniffing' strong RF either within a transmitter or out on the antenna. Since then transmitters have morphed to low-voltage=2C high- current architectures. The lamps won't sniff within the circuitry but will still light up when held in close proximity to the tip of a 1/4-wave antenna. Haven't tried it but I suspect it will still be limited to getting excited at 5 watts or more. One is looking for an RF field on the order of 75 volts or more to capacitively excite these lamps into visible activity. The very first transmitter I built http://tinyurl.com/4hwa2da had an NE-2 permanently attached to the hot side of the tank coil and could be used to tune the transmitter. Can anyone spot a risk-issue in this as-published diagram? Bob . . . /9j/4AAQSkZJRgABAQAAAQABAAD/2wBDAAEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEB AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQH/2wBDAQEBAQEBAQEBAQEBAQEBAQEBAQEB AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQH/wAARCABkAFADASIA AhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQA AAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3 ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWm p6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/8QAHwEA AwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSEx BhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElK U1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3 uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD+95Lv zOsgiPQZ57/T/P4U8Sl+jMO+RKBj8gP89qw0jjjm/dyed6D+fB/Mj+WKlSSNP+mXX/Uf1x/n9a+c 9q/P/wACf+QGwJHDcebJ7Dgf0x/npyKNzf8APWT9P8aoi4jk/M+R/n359fw4qWGWONBcSSGKLyP3 3n9s8A+vrnHatfa+cfv/AOCBU1LV4tLjE93OsUIxgY/0m4x6DgDH1HtXBXnxKtvtBtbTRfEN0+OJ gv2MfTB4/IV594h8bx2E8l9eQXc2vajNiHS4ZhnRdI66ezBQBvdssxAALEnAzXkXif40aH4b1XRv D+saHr114j8VT2dv4c0uAf8AISvNRv8A+zdOsP7S1P8A6iunf2ONHP0Ncrq16z/cfjsu/wCHpsr9 w9lbpb1fprvp01PsfR/E9tqD/Z5HubC75/cXw547ZOP16A9K3vtbRv8AvHHpjzh/+r/H86+LrP4u RxzS6frnhK/tdPmn+zz/APE8+13em/8AYR07U9J/4lg6Z0fp9a9i8O/Fjwy7WGkeIruWymlBgsdT uDi0uSB/zED00zVMjABIBzywxyUqtfT7te11b+trdV0y9tR8106Lt5dNPwPajO7vEkby/ve/nZ6D n1P4+wxUyPIJot7yiP8AHGTzzgH8c44qpcW6Rw+ZG5k9O/8AX26fyqhbyXEdzbebwDPZ2/6f179P 0rWlVft+tvJ/pt1+Tuyfn9zurabf8P27FFNQjKeWI/KMP+v65H+eOw9ferSSSXD/ALuTzoufPPPv +f1/lXG21xIIZZJP9TxnBOcg89/6en1res/LCfu8Zm7euSP5fX0/HI3Ooth5iesUPrz6+/1/nXnP jbxB5uq23h+DzYooYP7Qv58/8fPJ/wBA6H6kdv59vDcSb/p08+f246ZHuc//AF68g1iT/ioNek8y OK1gsbz/AFE+Oun/AMvw7dcVznVhVrd7p/Lb/gaHhnxFuZPD/hvXvEkcXlXWm6V9nsZ55zzeajf/ ANm/b/8AyokY/wAa+AfjhrnhW58QfsYz+ItYk8VeGf8AhcXwf06Nn8OGRbfWdO+JGl6kPChjDodT VW1E6u2qh4yx1EkNrn9jDQq+vf2o45I/hFqn+mRRfbNc8NW58/H+k86l/nGO/Xk18bfFnX/DWuXv 7GWlyWdtf6DZ/E3wGPs9xomheH9VufEnh3QvBenCw03xDpukkalpmi6rYHWDgA+IAAuSAuOjC1f6 X33X9dl5hjqftbWt+V7bfgtrW3PdNS8aaP8ADvxdaaXcW/2Dwv4w1z+x7GC+sMf6ZqP/ACDv7R/s z/kGZ0onv6GveNSs7OMXUcnm2sXkfuOn2TP2DTfXrpec/wD66+Gf2qLjS7P4wfC/w3p+qRebqXj+ 8/0eD/kE3Nnp39m6b/xLj+eOv419/pJcW9zdRWn/ABNIobG8z+4/7Bv6f55rCO69V+Z5WJX732Cv y2ve3RaXf9bbnpP7PnjuTUF1jwDqd5LdR6NAb/w7f3H/AEBs/wBnGwGf+gMQBjjqSORX0RBITd24 j6mW0E/1N8R9O2O36V8bfCK30u8+MNheRaXc6Nqh0TxGD9iYraaiDZaYGOo2GogkMFJK4wCwGWX7 w+xIvLj1SOPzPOl+22mZumcg5H4/WuuL/wBoj8n5foVhX+5Xlff0Xp+Z5qmoeZ/y0x5OT/nH/wCv itnTLjzHz/yy/wDrYwP/ANefrXnOm3FwfK/1p6/v/qfr+Hbv9K62G98t/L8zn9c/r/gfYYrjPT9l 5R+7/gHoMPmSeUJP/IGcY4/z9a8g1i3uLi216483ypZ777PP9ePf8/8AOPRrDVPkl8ySL/j3/LP8 /wAvavJdV1y3j03zPLh/fareXE/n/wDPn/8AW/nWOL0w+nn+ZrhL6ev6r/gWPmT9quOf/hXWl6dJ Jaj7Z4jvLjyLj/qHaD+f/MR/IV8g/E7wnH4f+Lv7Cng+zvBqlgfipeXF9PYn+ybS5vNO8B6bqX/I OP8AyExomq6jqOj/AKGvof8Aa38SaXJbeF/D9wIpZv8ATNQ+wzn/AI9jqP8AZub/AI7e3vXxv8YP iZ4L8YftLfs06hZ+OPFsujfCX4jeI/HHjjXNK8K393pWpaP/AMIl/wAS3/iY/wDIX/5Cv9naP0/4 kH9p/wDCRdKWFq9Funbu/T1t8radTqq0vkrdddGr6+XZ+Z6N8e9Ds5P2k/gOlx5UUVn4j/tCCe+4 +03n9vabx3/z61+hw0uT7TqlxH+6lgsbwQTwc/6Z/wAS38Mfl/PP5f638RLf4kftV/BG40fULXVL XR4LzUb79+Ba/bDqGpal+P8AyDtO+vIr9GNH8WXklnr0cln9qsPP/f8AP2Tpz2/7B2T1rr9pra2u 9r6272seBU2xTflZv/DH/g/j5nWfBqKS5+L92Lm3ljktPCmsz2WqQ9CDf6bwRyMEZ45Br6gt5Jf7 asox+9i+22n77/t+6f4V8yfAnxRp9x8WvFtp5kV1dWfggaxxb/ZbS2szqGm/2dYadqH/ADE+/J4A 57YP0Fp88Z1rTHt5YhFPqlp+4HUZv8ZHqR29/wBdNfbf1te35/gb4SnagvLp6a+um/4HjkNxLv8A L8zt6/kf5/z963odQ8vH7z/vx+nr6de1efWFx858y8il49+Oc9P89q6iGS3kxH/re/uP84H5Vze2 fn9yPT9n5/h/wTvE1Ty7OWSS4liPkep6f549fTNfnZ+2N408YeH/AIIf2h4C8WReEvEd54x0a3Gq /Yf7W+zWYsNS/tKw07+09W/5Cn/IO6f4V9zP9njT/llL/wDrP09vQH2xX5L/ALefjCz8L/Cuwvbz zYrWbxx/y42N/d/av9A1L/mHaZpPp0x17V4ue4uvQyvG4jD2TSSTtr9n8Xu7M9TK8Kq1d9V2e3/B tf8A4B+enwq8E/tT/trfEm8+Fuo/tAS3NnYi9ubG+g1YeB9XNnpuP7R/4mWnfD7xuozjAJ0MAkjJ HJryr9q/9hn9oP8AZm1ZWX4gS67Dp9hd3OlA/FTT/EN2LP7Bg/2j/aXwn0QEAjqND0NT/aWVJGCf sD/gkp4i0NvjtBqs+qRWM1/bfEi+869t761s/sVgdupZU6ZH/ZqaIDp5fV9YddDKhgh3la9M/wCC rfxK0S2+JXxD8LNr+iS+JdG8J6Lc3PhS21CxvdetdJ1LT82F9f2DANpqaydOIQkA7cZGen84z4v4 tpVlWoYx3/thLl6cmiat8/nf0PczTBYOjHl05f7HTbtrz8yWmnZN23Wnqfzp/Bn9rD42aH45tY9P s4tUutNvry3Gq6rrmn/r/wASn+R7Gv6ivgn+0hHqPwosLjWLfxHpfxBvPEdnqGq2Phz7BqxubP7B /wAS4f2j/ZP/ACC/+Jd/yB/+wuK/ja8N6hcHxbr3iCO4tfKm+2W995EOLS5/s7/l/wC/1HX/AJhF ft74D8ea54f8PaN/Zeq3+l3U2lfZ5xY332X7T/n/AOsO+f6D4WxeZ4zM19Yf/MoTafRu3Tve99uj PhuIVQwmCwf1fd2T0v2Wuuvz/U/o6/ZM1jxJ4gvPiX408SeEtQ0H/QdH0eeeeDNpqV5xqWo3/P8A xN/+gb+ufb6u0bUPtOuaGIo5edb0gTHz8jm+6kcZx1x6dPSvjP8AY/vNQ/4Zs+HNzqF7LLf+JILz xRfT/wDYRv8AUv7O9M/8Sr+zuvr619N+HLvy/E/hiPzPMlOt6R5/0N/zzn8fx/Cvrrv219N/w5rW +/S21tDHCU74G7ers3e972X+X4Lvp59Z3Fv5P7v/AD7Dn/P1rZTUPL482I9PU8fh9PavL01AxpF+ 7ii8n/H16/l+Vaiap5kOJDF3/Dn/AD+PHNeefR+y/u/j/wAE9GudZjjtjH5vlfuPXnr0z9eP5+g/ Gr/gpHqGuf8ACuvBtv4f0eLWbqbxHrGoT2P/AAkd/wCE/tP9n2H/ABLv+Jj/AGVrn/QS/n2r9VP7 RjNtLJJJL/qMfXrz37djx9a/Ev8A4KA+PbjxBN4O0eTw3r+gaDoureLwdcuPEXhPVf8AhLdH06+1 Hw5qN/pun+GfFmuat4a/sXVPDw/4lHjLQtD1/OQeQRXxPGuP+p5LjLb9ktdXG2nk3+Nu57OTYZVa 99Enol3focT/AMEo/hPqvxM8beI7UaP4l/4Ri8+GnxF0e+n8M6vYWVnp3i7xF4v8NanZX/jI6nqj avqnhsRaboDRroo1wM+lqrNrikuvyz/wWY8caxZftV/HvUNLim0rzfAujeHtD1u4uNAJ1LxH9u1L /hIs6f8A2w2rnTNF0rUfDoP9taJoeTpmcnqf1V/4JEmfwe3iTWtImsNc0vU/CCW1jZeR9k1a1OnM o26jqJxnTG/s7TlGsD+3SScfT8Lf+CtV34p8T/HHxF4z8UeIdL0awu7fxHcT6XY3F+bU3g17rp39 p/8AMMI/4k5zivwfIcfHMM4wOHajdZxeS/4UNl/ZzTd9Hq2vLXoz2MzyvEuMniFeEaceSV07uTk5 KyfNb3Y9k9N7O35EfBz7RGlrH5kMWl6PffZ/sNjP9ktLqz/t7/kH/wDIJ/5Bf9lf2d/Udq/ZvR/G P2fSbC38z/lx+zz+f/on+mD8P0/nX4/fB+wt7zUtL07UNYi+yzarZ6hfXHn/AGS0uv7O/wCJlqN/ /Xj/AKBnavvq58SSQTXUlncC6tZrH7RYz/8APzZ6j/xMtOv/APPOT3r+kOG8VbOc2jdaJJK9u2y/ G2j2voflnFdKt/ZuC0fxJeiTju+yX3fI/sg/Zy1CSz/Z7+C0fmeV5Pwy8H6gbf1/tGw03Uvy/wCJ kfX/AA+gvCuqeZ4q8LySJ/zMej/pf8f1z7V4F8LY/wCz/hR8L7OSTyvsfw58Haf5Hr/xIdN/x79O Owr1DwZef8Vh4Xj/AHvPiPR/X/n/APXGeeOg619JVvV1vb8Oz7fpselQpWw0e9l67W9Ov466o8qe 4MaRRxyYEE/2cz/T2/z/AEq0lzHH/wA8sf8ALAT/APP6P8P5enfGmk81P3cnlf8ATf19c/y/Gonz Gn+c85/L09qo9gv6rrF59m32/wDh+Y+n4V+S/wC17+w/qHxMOs65+z3o/wAOfBGs+Pb7xLrHxbsZ /t+k3fj/AFjUf+Jl/b39o/8AE8/4mn/Ex1H/AKAQx1GK/U+aSO4iJuIzmYcwf5/yPp0xvL/1Ucf+ HH+HH4fhXlZnleBzKiqGP1V0vJq6v6/j3d7nZhcTXweyWu2np+fz266n8uP7NX/BbTS/+Cfes+I/ hh48+A2ieLtT0G/u/CFwdR8ZeOvCXiLRLvTSNNOnajp+q/DvXtI1MaPqunbSRroYA6uVKnXAa/Ob 9r39vzwv+1B4z1Txpo+l6NoOl69fXlvYaVP4j8JaTpOm/wDIS/0D+0caHn+xef8AkNf2Fzwc9a/b j/gpH/wRb8P/ALXHxUi+NHwr8SDwR438bfbR8TbG+1WwtPCdzeadoP8AxLvFunad/wAInrmr/wDC Ua1qv9naP4g9/wDio6/mY+Pf7A/jj9kvxbF4O+OlvdaNqn2E6xpVjBf/APCQ6T4t0f7f/Zun6hp3 iLTNJOkaZpf9q/8AEmz/AMh/9RWOV8A8F0cX9ewOF/25O+t7czUU2vuVu1tDHHZ5nHsnTrLWXKm0 38EbtK17L4pbJXvu9D0b4UeKNH1S2l8N65p8UthqMF5b32qweKtBu7u20fUbD+zft+nf8TfH+fpX 1V/wsDxZ4x1WwuPFnjDxb8QfFF4NH0eDVfFWq/8ACQ+ItSs9OsNN8N+HNB/tE/8AUK07TtHzj+df IP7P3wo+Inxk8eaD4L+F/h+/8W+N/FV99osbHS5/9E+x8f8AEw1HUf8AmGeF9F0r/mMdK/qj+A// AARv+F/w/wBZ8EeNPih8UPFvxB1nQJ9H1jVfB2kwWHh7wRc+JNOzqX2D+0f+Qvqel/2r/wBgL+3s d69n+x8sy7GvEYf/AH6zvrda2vdbb7fefKYqrjs2aoUl/sKcW31+z87/AHL5n6gfsta58XJP2fvh zH8fNPOl/FWz0O8t/EdiLGwtLu2s9Ov9S03w7/aOnaZ/xKP7T/sr+zu/4c19N+EtUkk8VeGPL/6D mjjpj/l/03HU+v6/nXBvqEcj5uIxLj/6x9q2fCt5b2/irw5JJ+9ih1zRz1/6f9Nz26Vl7X/oI6vp /SXW/wDVz16NP2EVh/ze+ltetvyfyt9Ep8DvCct0Yn1HxGUE/AF9p47f9gqp4/gh4T+f/iYeIfmt 8n/S9N79f+YT7UUVzHcZFz8EfCnlg/2h4h+c4P8Apenen/YJpn/CkfCgl2jUPEOMA/8AH3p3fj/o E0UVpU6fP9DoM26+B3hMTZGo+I8/aOv27T+3/cK96z9X/Z7+Huq6ZqEGsQXutWd3P/ZV7p+sxaHq lhfWHB+zXdrfaJPHKnP+yf1yUVzUm/ZrV/Elv05loaVNbX8/0M/4dfscfAPwAdTuvhz4H0H4cz6x chNWk8CeFPAnhhtTX/p8/s3wlD5vTtt/lXbwfA3wnMYxJqXiQ7en+nWHoP8AqFe9FFdy1qq/8i/I 47JbKxMnwM8JF/8AkI+JP+Xw/wDH9p/f/uFVn/8ACnfDUOtaNcx6j4gEv/CQaRJu+16efm+3nt/Z fSiilV/jP+u5nU6fP9D/2Q= ________________________________________________________________________________
Date: Feb 15, 2011
At 09:04 AM 2/15/2011, you wrote: >I'll have a stab at it - when the switch is open, the chassis sits >at line voltage? Right on! I'd built a number of transformer-less circuits where injudicious wiring and positioning of switches could put a chassis at above ground potentials. Since all ham gear was expected to be well grounded for reasons of antenna performance, it made sense to use the SAME ground as the power return for the device. Make the line-cord a one-wire lead that was switched. If the gizmo didn't power up, reverse the plug. But in no case was the properly grounded system at risk for presenting a shock hazard. So called AC/DC radios popular at the time were always housed in a wood or plastic case. Quite often, the line-connected 'ground' within the appliance was floating from the chassis. When launching a line-powered, transformer-less DIY project, it was good to understand such things. Good eye! Bob . . . ________________________________________________________________________________
Date: Feb 15, 2011
At 09:16 AM 2/15/2011, you wrote: >#1 The chassis is directly connected to the line. >#2 the switch is in what is hopefully the ground side of the line. >#3 It's probably old enough that the line plug is not polarized and >the chassis may be attached to the "hot" side of the line. > >More than one person has been electrocuted with such a layout. Yup . . . you're tied for first place. Bob . . . ________________________________________________________________________________
Date: Feb 15, 2011
Subject: Shielded wire use with "wiring hubs"
What is the appropriate way to handle the shield part of "shielded" wire when wiring using a commercial "hub" or a diy "hub"? For intercom/aviionics use. Thanks, Skip ________________________________________________________________________________
Date: Feb 15, 2011
I'll take a stab at it. The crystal and the heater for the tube are both powered by 115VAC. Considering the potential instability in both the voltage coming from the wall and possible changes in the frequency of the AC current it may be a bit edgy. Noel Now give us the real reason. Please! Noel From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: February 15, 2011 11:20 AM Subject: RE: AeroElectric-List: Re: No click when pushing PTT At 08:06 AM 2/15/2011, you wrote: I would expect the first thing to do is to verify your radio is not transmitting... If you have another radio close by you can test the transmitter is operating. An old trick we used to do with taxicabs years ago was to have someone hold a fluorescent tube (tube only completely unplugged) close to the transmitting antenna and key the mic. If the tube lights up the transmitter is active. Yeah, that was the primary reason for keeping the little NE-2 or NE-51, neon bulbs around. Emacs! They were handy for 'sniffing' strong RF either within a transmitter or out on the antenna. Since then transmitters have morphed to low-voltage, high- current architectures. The lamps won't sniff within the circuitry but will still light up when held in close proximity to the tip of a 1/4-wave antenna. Haven't tried it but I suspect it will still be limited to getting excited at 5 watts or more. One is looking for an RF field on the order of 75 volts or more to capacitively excite these lamps into visible activity. The very first transmitter I built http://tinyurl.com/4hwa2da had an NE-2 permanently attached to the hot side of the tank coil and could be used to tune the transmitter. Can anyone spot a risk-issue in this as-published diagram? Bob . . . ________________________________________________________________________________
Date: Feb 15, 2011
Certainly a short across the 1 muff cap could cause that. Noel From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Etienne Phillips Sent: February 15, 2011 11:35 AM Subject: Re: AeroElectric-List: Re: No click when pushing PTT I'll have a stab at it - when the switch is open, the chassis sits at line voltage? On 15 February 2011 16:49, Robert L. Nuckolls, III wrote: Can anyone spot a risk-issue in this as-published diagram? Bob . . . ________________________________________________________________________________
Date: Feb 15, 2011
Many years ago I had a radio/Amplifier which the chassis could be hot if it was plugged in that way you would get a terrible AC hum from the speakers... I always put it down to the shielding on the tubes being hot. Yes I did get several good roots from that thing until I realized that turning the plug around removed the AC hum. Noel From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bob McCallum Sent: February 15, 2011 11:46 AM Subject: RE: AeroElectric-List: Re: No click when pushing PTT #1 The chassis is directly connected to the line. #2 the switch is in what is hopefully the ground side of the line. #3 It's probably old enough that the line plug is not polarized and the chassis may be attached to the "hot" side of the line. More than one person has been electrocuted with such a layout. Bob McC _____ Date: Tue, 15 Feb 2011 08:49:32 -0600 From: nuckolls.bob(at)aeroelectric.com Subject: RE: AeroElectric-List: Re: No click when pushing PTT At 08:06 AM 2/15/2011, you wrote: I would expect the first thing to do is to verify your radio is not transmitting... If you have another radio close by you can test the transmitter is operating. An old trick we used to do with taxicabs years ago was to have someone hold a fluorescent tube (tube only completely unplugged) close to the transmitting antenna and key the mic. If the tube lights up the transmitter is active. Yeah, that was the primary reason for keeping the little NE-2 or NE-51, neon bulbs around. Emacs! They were handy for 'sniffing' strong RF either within a transmitter or out on the antenna. Since then transmitters have morphed to low-voltage, high- current architectures. The lamps won't sniff within the circuitry but will still light up when held in close proximity to the tip of a 1/4-wave antenna. Haven't tried it but I suspect it will still be limited to getting excited at 5 watts or more. One is looking for an RF field on the order of 75 volts or more to capacitively excite these lamps into visible activity. The very first transmitter I built http://tinyurl.com/4hwa2da had an NE-2 permanently attached to the hot side of the tank coil and could be used to tune the transmitter. Can anyone spot a risk-issue in this as-published diagram? Bob . . . ________________________________________________________________________________
Date: Feb 15, 2011
Bob, Many thanks for your reply. Your time is always much appreciated. Regards Mark Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331164#331164 ________________________________________________________________________________
Date: Feb 15, 2011
Subject: Re: AeroElectric-List Digest: 24 Msgs - 02/14/11
Bob, Excellent comments on the list I was a designated examiner & PPE for about 7 years on the CE 500/550 series and along with the FAA used the AOA to see if the applicant had used the "bug card" correctly in figuring his approach speeds. If I recall correctly was 1 Kt per mark on the AOA scale. Tell the appplicant it looked as if he was in error on his approach speeds by a couple knots he would look at you like you were crazy, then refigure and guess what, we were exactly correct, told the applicant to use equipment he had in his plane! Navy pilots lived by AOA, they are among my best customers. I had a pitot line freeze on a D-50 T-Bon in the late 60's seems a mechanic had bent it to make it easier to attach an engine mount, however just outside the cowling it had made a low spot. I lost all airspeed at about 11,000 in IMC, declared an emergency and descended into Prescott, AZ finally getting airspeed back in final turn in holding pattern prior to approach at 0200 AM Been there done that. In a message dated 2/15/2011 12:00:48 A.M. Pacific Standard Time, aeroelectric-list(at)matronics.com writes: ________________________________________________________________________________
Date: Feb 15, 2011
Subject: Re: Shielded wire use with "wiring hubs"
At 01:56 PM 2/15/2011, you wrote: >What is the appropriate way to handle the shield part of "shielded" >wire when wiring using a commercial "hub" or a diy "hub"? For >intercom/aviionics use. > >Thanks, Skip Instructions for installation/fabrication should speak to at least one pin in every connector reserved for the purpose of connecting to shield grounds. All shields in a bundle can be daisy-chained such that the shields can be handled on a single wire in one pin of the plug. http://www.aeroelectric.com/articles/pigtail/pigtail.html Bob . . . ________________________________________________________________________________
Date: Feb 15, 2011
Subject: Re: AOA indicator
At 03:39 PM 2/12/2011, you wrote: > > >If you are an EAA member you can see ALL back issues of Sport >Aviation on http://www.oshkosh365.org > >If that doesn't do it for you I do have the 2005 issues but I would >have to see what issue it was in. Do you remember what month? Sorry, no. It was mentioned on another forum. Had an EAA membership for 20+ years but gave it up about 10 years ago. So if anyone could find and capture the article, I'd sure appreciate it. Bob . . . ________________________________________________________________________________
Date: Feb 15, 2011
Y'all lost me there :) Anyways, back to square one. The radio works just fine... it's been installed for a little over 2 years and never had issues communicating with anyone (even distant facilities). I acquired the plane last summer and this click was never there.. so I can only assume it was like this from day one.. but have no way of confirming this. For clarification -- this is a certified plane that's been flying for a long time.. not a homebuilt sitting in my garage.. This radio allows me perfectly normal "5 by 5" communication with anyone on frequency.. there have never been any issues with clarity nor strength of normal voice transmission.. It just doesn't click... that's all. -------- RV-7A N777TY Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331193#331193 ________________________________________________________________________________
Subject: New Stereo Audio Mixer Products
Date: Feb 15, 2011
Discussed several times over the years on Aeroelectric, audio mixers have matured. In addition to mono audio mixer/audio panel devices and stereo headphone adapters available for some time, Vx Aviation has released a pair of stereo audio mixers in our unique form factor-- the D-sub backshell. Although we avoid posting too much commercial material to the list, I hope Bob appreciates what we've done here, because it's relevant to what we have debated over the years. Thanks, Vern Little Summary of Announcement: VICTORIA, BC---February 16, 2011---Vx Aviation today announced the introduction of the first stereo audio mixers designed specifically for experimental aircraft applications. The AMX-4A and AMX-4B dramatically simplify and lower the cost of audio system installation in both existing and new aircraft. Both units are virtually pin-compatible with the industry-leading AMX-2A monophonic 10 channel miniature audio mixer, introduced in 2008. Both the AMX-4A and AMX-4B units provide five independent stereo input channels. Three channels are fixed-level, designed to connect to audio sources that have their own volume controls, such as EFIS systems and XM radios. Two of the channels have screwdriver adjustable audio levels, providing the flexibility required when connecting to fixed level sources. Monophonic sources are supported by connecting together the left and right inputs of any input channel. The AMX-4A low output version works seamlessly with PS Engineering intercoms, providing the critical 2 volt peak-to-peak voltage limiting required that prevents damage to the PS Engineering products. The AMX-4B high output version has no such limiting and provides up to 12 volts peak-to-peak drive capability and a gain of 15 decibels, making it compatible with intercoms that require input amplification or for directly driving headphones. For further inquiries, please contact me. Thank-you. Vern Little Vx Aviation www.vx-aviation.com ________________________________________________________________________________
Subject: Re: AOA
Date: Feb 16, 2011
Bob I just noticed your comments about loss of IAS on both sides of the Beechjet. l attended 2 of your Seminars and I know we talked about both having worked for Cessna. When I left Cessna as a Flight Test Engineer in 1968, I went to work for the Army Aviation Systems Cmd in St Louis as a Dept of Army Civilian Senior Aeronautical Engineer and was there for 28+ years. Most of my time there was spent with the Army's Fixed Wing Electronic Intelligence Gathering Aircraft. In the later years I was the Army Technical Manager for 7 different versions of the RC-12 (Super Kingair 200), the last 4 versions comprised of 36 aircraft with 1200 SHP engines and Gross Weights in the 16,000 to 16,500 lb range. In the early '90s, we took the RC-12N configuration which had the largest antenna array to Duluth, Mn in January for natural icing tests. The Army test crew from EAFB had a specially instrumented U-21 to search for icing conditions and would then call out the RC-12N. I rode with the Army test crew on flights 2 and 3 as a FTE/ Observer. On flight 2, we were in a low stratus layer around 3000 ft MSL, 140 KTS, about 45% cruise power. At 50 minutes we has collected 5 1/2 inches of ice with all of the deice going, at 90% cruise power for the same air speed and had just lost the right pitot airspeed. About 3 minutes later we lost the left pitot airspeed. About 2 minutes later, we climbed out of the low stratus layer so the U-21 could get photos of the ice buildups. Fortunately the U-21 was able to get a picture of the right pitot which showed that ice had grown forward on the unheated pitot mast and then curved downward to block the pitot inlet, at no time actually touching the pitot tube itself. Before the U-21 could move to the left side, the left mast had lost enough ice that the left airspeed had come back and a few minutes later the right airspeed was back. Beech attempted to get some heat in the mast , but abbreviated tests the following winter showed that it was insufficient. Bob, I don't know whether the Beechjet used the same pitot units or a similar design, but that was our findings on the Model 200. Alden Van Winkle Slo Build RV-9A dvanwinkle(at)royell.org ----- Original Message ----- From: Robert L. Nuckolls, III To: aeroelectric-list(at)matronics.com Sent: Monday, February 14, 2011 9:08 AM Subject: Re: AeroElectric-List: AOA At 08:03 PM 2/13/2011, you wrote: My comment on icing and AOA systems ~~If you encounter any type of icing turn the AOA OFF unless you have full de-icing vane & aircraft. We haven't even done R&D on a heated vane because of liability. Even Boeing can't give you hard numbers with icing on wings. Heated vane and icing on wings is NOT a good deal! Elbie Mendenhall, EM Aviation, LLC www.riteangle.com Exactly. The fleet of bizjets at HBC were all qualified for flight into known ice. Everything was heated or hammered. I'll have to call some of my jet-jockey friends at HBC and inquire as to words in the POH concerning usefulness and cautions about AOA displays on the production fleet. I worked a REALLY strange problem on the Beechjet some years back were pilots experienced loss of IAS on BOTH sides of the airplane. Displays always recovered at lower, warmer altitudes. This often occurred in relatively clear air. There was a LOT of brainstorming by a LOT of grey beards as to the physics behind this rare but disturbing event. My task involved cutting a pitot tube open, peppering it with thermocouples and putting it back together again so that we could study not only temperatures at the surfaces to be de-iced but internally. There was some question of ice crystals bouncing through the labyrinth of pressure channels only to melt and re-freeze inside the pitot tube. During the fire drill for sniffing out root cause, somebody asked the question: "How does the existence of a working AOA display help the pilot who is temporarily deprived of IAS?" Good question. The Beechjet had been fitted with AOA indication since its birth as the Mitusbishi Diamondjet. But nobody had ever researched and written the approve procedure for using AOA as an aid to maneuvering without IAS. That amendment was quickly added to the POH. I'm not sure we ever deduced how pitot pressure was being obstructed. I'll have to ask how that problem resolved too. But it was interesting that a perfectly useful display had existed for so long but was never fully developed as a component of plan-b, plan-c, etc. Shucks, with DUAL air data systems, what are the odds? Bob . . . ________________________________________________________________________________
Date: Feb 16, 2011
Subject: cell phone rechargers
bob, i put together a $15 kit to allow the light of a cell phone to turn on a relay which i use to activate a 20 amp connector which someday will preheat my engine. with a $15 kit there are no codes or protection from false starts so to protect from power out and back on which activates the display on the phone i was wondering about using a 6 volt battery instead of the120 volt ac phone charger. the chargers are rated 4.5-9.5 volts. my question is .......do cell phones have internal means to regulate the current flow to charge their battery or will wiring it to a 6 volt battery for charging fry it? it does take 2 calls to activate it so that lessens the possibility. thanks for the time on this ''off topic'' issue bob noffs ________________________________________________________________________________
Date: Feb 16, 2011
Bob Noffs=2C My apologies for stepping into your question to Bob N=2C but I have exper ienced this. I had two different brand cell phones=2C yet they both could accept either one's wall charger plug. However=2C the wall charger's output voltages were NOT the s ame voltage. I can't recall exactly what the voltages were=2C but it was LESS than 1/2 v olt. I figured I'd take a gamble=2C and plug the higher voltage wall charger i nto the lower voltage cell phone. Poof! The phone went dead=2C D-E-D=2C dead. It wasn't just the battery=2C either=2C because I plugged it in the correct charger =2C but that didn't make a difference. You could see some kind of proof that the phone was on=2C like the screen was lit=2C but blank=2C or something like that=2C but no amount of fiddling with it ever s howed it was ever going to work again. Less than 1/2 volt too much fried it!! So=2C in answering your question=2C in my experience=2C no=2C a cell phon e can not take virtually any higher charge than the wall charger rating. Mike Welch Date: Wed=2C 16 Feb 2011 06:26:51 -0600 Subject: AeroElectric-List: cell phone rechargers From: icubob(at)gmail.com bob=2C i put together a $15 kit to allow the light of a cell phone to turn on a relay which i use to activate a 20 amp connector which someday will preheat my engine. with a $15 kit there are no codes or protection from false star ts so to protect from power out and back on which activates the display on the phone i was wondering about using a 6 volt battery instead of the120 vo lt ac phone charger. the chargers are rated 4.5-9.5 volts. my question is . ......do cell phones have internal means to regulate the current flow to ch arge their battery or will wiring it to a 6 volt battery for charging fry i t? it does take 2 calls to activate it so that lessens the possibility. th anks for the time on this ''off topic'' issue bob noffs ________________________________________________________________________________
Date: Feb 16, 2011
Bob, I did a search of past EAA articles and found the following pertaining to AOA: Better Way to Fly - May 1998 Carrier Pilots' Secret - July 1999 Test Pilot: Angle of Attack - April 2001 Test Pilot: Angle of attack and lift/drag - May 2001 Test Pilot: Angle of Attack - November 2003 Shop Talk: Angle of Attack Indicator - December 2008 I could not find anything in 2005 about AOA. The December 2008 article by Dave Barker might be the one that you are looking for. It describes how to build the AOA sensor using a hall effect transducer and LED bar graph display. Here is a link to the December 2008 EAA article: http://www.oshkosh365.org/saarchive/eaa_articles/2008_12_21.pdf Below are links to the author's website. Dave Barker's pdf gives more detailed construction details than the EAA magazine article. http://www.barkeraircraft.com/files/AOA_rDisplay.pdf http://www.barkeraircraft.com/AOA_kit.html Although Dave Barker no longer sells AOA kits, he still has some circuit boards available. There is a link to his email address on his website. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331206#331206 ________________________________________________________________________________
Date: Feb 16, 2011
Subject: HF hyd Crimper on sale
The hydraulic HF crimper 66150 of recent discussion is on sale for $45 thru the 19th with attached coupon, $59 without. http://www.harborfreight.com/hydraulic-wire-crimping-tool-66150.html?___SID=U Ron Q. ________________________________________________________________________________
Date: Feb 16, 2011
Subject: Re: cell phone rechargers
How about a DC powered cell-phone charger? You can find a cheap automotive charger for just about any cell phone on ebay. I've been ordering them from china directly, usually for a few dollars including shipping. You should also be able to find a cheap alligator clip lead with a female SAE 12v jack on one end. Could you clip those alligator leads onto your airplane's battery, which is already connected to a maintaining charger like the Schumaker 1526? Then you are using AC power for the long term, but DC power for the short term. In this case, "short term" would probably still be a really long time. When it's time to fly, just unhook your alligator clips and charger, and leave them at the hangar. If your phone system is located some distance from the airplane, you could use this same strategy with a stand-alone 12v battery and an AC or solar battery tender. This would be a great use for a retired odyssey battery or something like that. If you keep a lawn tractor or any other GSE in the hangar, you could use one of those onboard batteries instead. On Wed, Feb 16, 2011 at 8:50 AM, Mike Welch wrote: > Bob Noffs, > > My apologies for stepping into your question to Bob N, but I have > experienced this. > I had two different brand cell phones, yet they both could accept either > one's wall > charger plug. However, the wall charger's output voltages were NOT the > same voltage. > I can't recall exactly what the voltages were, but it was LESS than 1/2 > volt. > > I figured I'd take a gamble, and plug the higher voltage wall charger > into the > lower voltage cell phone. Poof! The phone went dead, D-E-D, dead. It > wasn't > just the battery, either, because I plugged it in the correct charger, but > that didn't > make a difference. > You could see some kind of proof that the phone was on, like the screen > was lit, but > blank, or something like that, but no amount of fiddling with it ever > showed it was > ever going to work again. Less than 1/2 volt too much fried it!! > > So, in answering your question, in my experience, no, a cell phone can > not take > virtually any higher charge than the wall charger rating. > > Mike Welch > > > ------------------------------ > Date: Wed, 16 Feb 2011 06:26:51 -0600 > Subject: AeroElectric-List: cell phone rechargers > From: icubob(at)gmail.com > To: aeroelectric-list(at)matronics.com > > bob, > i put together a $15 kit to allow the light of a cell phone to turn on a > relay which i use to activate a 20 amp connector which someday will preheat > my engine. with a $15 kit there are no codes or protection from false starts > so to protect from power out and back on which activates the display on the > phone i was wondering about using a 6 volt battery instead of the120 volt > ac phone charger. the chargers are rated 4.5-9.5 volts. my question is > .......do cell phones have internal means to regulate the current flow to > charge their battery or will wiring it to a 6 volt battery for charging fry > it? it does take 2 calls to activate it so that lessens the possibility. > thanks for the time on this ''off topic'' issue > bob noffs > > * > > -List" target=_blank>http://www.matronics.com/Navigator?AeroElectric-List > ttp://forums.matronics.com > =_blank>http://www.matronics.com/contribution > * > > * > > * > > ________________________________________________________________________________
Date: Feb 16, 2011
Jared, Although I failed to suggest that, what you suggested is what I woul do. If a guy got a small 12V battery, and one of those 12V cigarette lighter recepticles, and used the 12V cell phone chargers, he'd be fine. Plus, he could get one of the battery tenders from Harbor Freight that keeps his 12 V battery always topped off. Battery tender, small 12V battery, and the car charger would do it!! Mike Welch Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331211#331211 ________________________________________________________________________________
Date: Feb 16, 2011
Subject: Heated Pitot Tubes - Some first hand history
At 02:09 AM 2/16/2011, you wrote: Bob I just noticed your comments about loss of IAS on both sides of the Beechjet. l attended 2 of your Seminars and I know we talked about both having worked for Cessna. When I left Cessna as a Flight Test Engineer in 1968. I'd forgotten that conversation. Were you working at the Pawnee or Wallace plant? I was a tech writer at Cessna from about 1964 to 1969 . . . just a few months over 5 years. I went to work for the Army Aviation Systems Cmd in St Louis as a Dept of Army Civilian Senior Aeronautical Engineer and was there for 28+ years. Most of my time there was spent with the Army's Fixed Wing Electronic Intelligence Gathering Aircraft. In the later years I was the Army Technical Manager for 7 different versions of the RC-12 (Super Kingair 200), the last 4 versions comprised of 36 aircraft with 1200 SHP engines and Gross Weights in the 16,000 to 16,500 lb range. In the early '90s, we took the RC-12N configuration which had the largest antenna array to Duluth, Mn in January for natural icing tests. The Army test crew from EAFB had a specially instrumented U-21 to search for icing conditions and would then call out the RC-12N. I rode with the Army test crew on flights 2 and 3 as a FTE/ Observer. On flight 2, we were in a low stratus layer around 3000 ft MSL, 140 KTS, about 45% cruise power. At 50 minutes we has collected 5 1/2 inches of ice with all of the deice going, at 90% cruise power for the same air speed and had just lost the right pitot airspeed. About 3 minutes later we lost the left pitot airspeed. About 2 minutes later, we climbed out of the low stratus layer so the U-21 could get photos of the ice buildups. Fortunately the U-21 was able to get a picture of the right pitot which showed that ice had grown forward on the unheated pitot mast and then curved downward to block the pitot inlet, at no time actually touching the pitot tube itself. Before the U-21 could move to the left side, the left mast had lost enough ice that the left airspeed had come back and a few minutes later the right airspeed was back. Wow! That would be some interesting pictures to have in the library. Talk about tweaking the tail of the tiger. I have 2 hours of dual in a King Air. I had the electrical/avionics group at Lear for the GP-180 program and Collins came down in their company demonstrator to show me some new features of their autopilot system. The demonstrator pilot was also an instructor and he invited me to take the left seat. One of the most profound demonstrations of the King Air (after we BACKED out of a parking space) was the autopilot's ability to quickly manage a loss of engine event. Climbing out we were showing something like 2700 fpm and he pulled one throttle to zero thrust. The airplane barely yawed and the only thing that happened was that noise level dropped and rate of climb decreased to 1500 fpm. Now THAT'S what I call single-engine performance. If there was ever an airplane capable of staying in the air under the most adverse of conditions, it would have to be the twin turboprops. I had to run home after that flight to get my log book. Didn't want to miss getting the experience recorded. I also have 2 hours of dual in a Baron and got a chance to play with single-engine performance of that airplane. The differences are profound. Beech attempted to get some heat in the mast , but abbreviated tests the following winter showed that it was insufficient. Bob, I don't know whether the Beechjet used the same pitot units or a similar design, but that was our findings on the Model 200. Back in that era, pitot tubes had a LOT in common including the ways they distributed heat. While working the BE400 pitot heat issues in 2002 I discovered that the heaters are long, tubular devices that snake from each connector pin through various locations and designed to create localized hot-spots. These are not linear, uniform toaster heaters but specifically tailored to distribute heat based on tests in icing tunnels. In this case, a percentage of total heat was dumped into the mast. Further, the inside of a pitot tube can feature a labyrinth of passages, chambers and 'melting pots' tailored to stand off the various effects of icing. See: http://aeroelectric.com/Pictures/Pitot_Tube/ Another interesting feature of pitot tube performance is illustrated by the plotted flight test data (gathered with my po' boy's laptop based instrumentation system). At 40KFt -30C RAT and over 200Kts IAS, temperatures at some locations on the tube were well over 100C. Now would like to believe there's no way that icing could be a factor in the loss of IAS . . . yeah . . . right. After the studies were completed on the 400 I think they re-distributed some heat and moved some drain holes. Unfortunately, they could not increase total heat without impacting the DC load studies for the whole airplane. We had to live within the existing power budget in spite of the fact that for 99.9% of all operations in ice, there was power to burn. Any heated pitot tube installation certified in the last 30+ years is probably blessed with a heated pitot tube that is "similar" but not identical to other installations. Of course, ANY heated pitot tube adapted to a single engine light airplane can be expected to perform pretty much as advertised. I don't think there are 14v airplanes certified for flight in to known ice that would also have finely tuned pitot tube heater systems. Virtually all supper-whizzy heated tubes will be off a pretty heavy duty foul-weather capable airplane and will have a 28v system. Thanks for sharing your experience with us. Bob . . . ________________________________________________________________________________
Date: Feb 16, 2011
At 08:50 AM 2/16/2011, you wrote: >Bob Noffs, > > My apologies for stepping into your question to Bob N, but I have > experienced this. >I had two different brand cell phones, yet they both could accept >either one's wall >charger plug. > > So, in answering your question, in my experience, no, a cell > phone can not take >virtually any higher charge than the wall charger rating. It's unfortunate that there's so little standardization for power supplies . . . especially for cell phones. We've owned a variety of brands and models in the family and cursed the need for separately tailored wall and mobile chargers for each phone. There appears to be a trend toward "USB Port" standardization which would be 5.0 +/- 0.2 volts DC power. If your phone is indeed a USB compatible device, then you'll want to provide a tightly regulated power source. One easy way to get the right power AND the right connector is to acquire an IGo universal adapter. http://tinyurl.com/4un3rdk and combine it with the appropriate custom tip that mates with your phone. The adapter has it's own switchmode power supply that is set to the right output voltage when the right tip is installed. The adapter will need to be powered from 12v or so. A small SLVA battery and BatteryTender would be a good choice. The nice thing about this arrangement is that you can change phones at any time in the future by simply swapping the power adapter tip. I've read some descriptions of similar remote control systems. One of the most interesting used an audio detection system. The phone was set to 'silent' except for a custom ring-tone that activated by your controlling phone number only. Bob . . . ________________________________________________________________________________
Date: Feb 16, 2011
Subject: Re: No click when pushing PTT
On 02/15/2011 11:32 PM, N777TY wrote: > This radio allows me perfectly normal "5 by 5" communication with anyone on frequency.. there have never been any issues with clarity nor strength of normal voice transmission.. It just doesn't click... that's all. I've been trying to figure out what this "click" is that you indicate happens on COM1. I don't remember ever getting a click on the radios I've used. Even new solid state handhelds will trigger the runway lighting, and they (or at least mine) doesn't make any noise at all when pressing the transmit button, and I do not remember an audible click being heard on a receiving radio when transmitting on the handheld. I have no real data to back this statement up, but my gut tells me that the "click" or lack of is simply a red herring and has nothing to do with being able to activate the runway lights. Just a passing thought, have you tried to activate the runway lights with this radio at a different airport? Just wondering if there might be something a bit off with the receiver at your local airport that might be causing the issue. -Dj -- Dj Merrill - N1JOV Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Please use Netiquette Guidelines http://tools.ietf.org/html/rfc1855 Kindly TRIM your email replies and post AFTER the relevant text ________________________________________________________________________________
Date: Feb 16, 2011
Attached is an AOA approach by by Jim Mantyla of Barrie Ont for the AirSoob list. I borrowed the idea for the AOA "pitot tube" with the angled holes. But, instead of an analog pressure gauge calibrated for "Reserve Lift" - I put a pressure sensor next to the probe. I then processed and compared the dynamic pressure component provided by each tube of the probe, I used a microprocessor to do this and provide a display of both the calculated AOA value and a visual (graphical) indication of the angle of attack with alarms that could be set. I tested it on the bench with air flow and by varying the angle of attack between wind flow and probe, it would indeed respond as expected. I had initially intended to offer the unit for sale, but later decided that it would probably not be economically viable as other units were avaliable and the market for AOA was uncertain. I also question how many folks would want to hang another "Pilot probe" under the wing. It was a fun and educational project and I still have it for some future time when things are slower and I find the time to hang it under the wing and see how it works in the real world. Too little time and too many projects {:>) Ed Edward L. Anderson Anderson Electronic Enterprises LLC 305 Reefton Road Weddington, NC 28104 http://www.andersonee.com http://www.eicommander.com -------------------------------------------------- From: "user9253" <fran4sew(at)banyanol.com> Sent: Wednesday, February 16, 2011 9:44 AM Subject: AeroElectric-List: Re: AOA indicator > > > Bob, > I did a search of past EAA articles and found the following pertaining to > AOA: > Better Way to Fly - May 1998 > Carrier Pilots' Secret - July 1999 > Test Pilot: Angle of Attack - April 2001 > Test Pilot: Angle of attack and lift/drag - May 2001 > Test Pilot: Angle of Attack - November 2003 > Shop Talk: Angle of Attack Indicator - December 2008 > I could not find anything in 2005 about AOA. The December 2008 article by > Dave Barker might be the one that you are looking for. It describes how > to build the AOA sensor using a hall effect transducer and LED bar graph > display. > Here is a link to the December 2008 EAA article: > http://www.oshkosh365.org/saarchive/eaa_articles/2008_12_21.pdf > Below are links to the author's website. Dave Barker's pdf gives more > detailed construction details than the EAA magazine article. > http://www.barkeraircraft.com/files/AOA_rDisplay.pdf > http://www.barkeraircraft.com/AOA_kit.html > Although Dave Barker no longer sells AOA kits, he still has some circuit > boards available. There is a link to his email address on his website. > Joe > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=331206#331206 > > > ________________________________________________________________________________
Date: Feb 16, 2011
_____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: quarta-feira, 16 de Fevereiro de 2011 14:38 Subject: RE: AeroElectric-List: cell phone rechargers At 08:50 AM 2/16/2011, you wrote: It's unfortunate that there's so little standardization for power supplies . . . especially for cell phones. Recently I saw in some TV news that the great majority of world cell phone manufacturers (including Motorola, NOKIA, Siemens, Samsung - I can't remember if iPhone and Blackberry were in) had reached an agreement exactly to standardize all cell phone chargers. Let's hope they do it quickly Carlos ________________________________________________________________________________
Date: Feb 16, 2011
At 10:43 AM 2/16/2011, you wrote: >Attached is an AOA approach by by Jim Mantyla of Barrie Ont for the >AirSoob list. > >I borrowed the idea for the AOA "pitot tube" with the angled >holes. But, instead of an analog pressure gauge calibrated for >"Reserve Lift" - I put a pressure sensor next to the probe. Great minds think alike . . . ;-) I fiddled with an identical configuration about ten years ago. Looked at a molded two-port AOA mast with electronics built right into the base of the mast and driving a small analog instrument. Mount mast, hook up 14v, install indicator and calibrate. >Market for AOA was uncertain. I also question how many folks would >want to hang another "Pilot probe" under the wing. > >It was a fun and educational project and I still have it for some >future time when things are slower and I find the time to hang it >under the wing and see how it works in the real world. > >Too little time and too many projects {:>) You got that right. Never got a chance to fly the poc item but I did "fly it" on the roof of my car. But aside from packaging, I had nothing particularly unique from other products on the market . . . and the "lift reserve" approach with mast, two tubes and a Magnehelic gage was pretty simple . . . tough competition. Bob . . . ________________________________________________________________________________
Date: Feb 16, 2011
At 09:44 AM 2/16/2011, you wrote: > >Bob, >I did a search of past EAA articles and found the following pertaining to AOA: thanks to all who responded to my query about S.A. articles. I now have several. It's interesting/useful to see what kinds of things have been published for the OBAM aviation community. I've added all your contributions to my library. Bob . . . ________________________________________________________________________________
Subject: follow up shielded wire/hub question
Date: Feb 16, 2011
My first question needed to be more specific. My audio panel installation manual shows that the shielded wires are "open" (shield not grounded) at the end where the wires connect to the radio, and the shields are all gro unded together at the audio panel. If I use a "hub" system, where all avionics go in and then out of the hub, do I keep each shield on a separate pin going in and out of the hub, or do I ground all the shields together going into the hub and then start a set of new shielded wires comng out of he hub (open coming out of the hub ) and tie all the shields to ground at the audio panel? Thanks for the help, Skip -----Original Message----- From: AeroElectric-List Digest Server <aeroelectric-list(at)matronics.com> Sent: Tue, Feb 15, 2011 11:56 pm Subject: AeroElectric-List Digest: 21 Msgs - 02/15/11 * ======================== ======================== = Online Versions of Today's List Digest Archive ======================== ======================== = Today's complete AeroElectric-List Digest can also be found in either of the wo Web Links listed below. The .html file includes the Digest formatted n HTML for viewing with a web browser and features Hyperlinked Indexes nd Message Navigation. The .txt file includes the plain ASCII version f the AeroElectric-List Digest and can be viewed with a generic text edito r uch as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=ht ml&Chapter 11-02-15&Archive=AeroElectric Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=tx t&Chapter 11-02-15&Archive=AeroElectric ======================== ======================= EMail Version of Today's List Digest Archive ======================== ======================= ---------------------------------------------------------- AeroElectric-List Digest Archive --- Total Messages Posted Tue 02/15/11: 21 ---------------------------------------------------------- oday's Message Index: --------------------- 1. 06:03 AM - Re: Re: No click when pushing PTT (Robert L. Nuckolls, III) 2. 06:08 AM - Re: Re: No click when pushing PTT (Noel Loveys) 3. 06:10 AM - Re: Re: No click when pushing PTT (Robert L. Nuckolls, III) 4. 06:13 AM - Re: Re: 2nd radio (Robert L. Nuckolls, III) 5. 06:35 AM - Low Ohms Adapters (Robert L. Nuckolls, III) 6. 06:52 AM - Re: Re: No click when pushing PTT (Robert L. Nuckolls, III) 7. 07:11 AM - Re: Re: No click when pushing PTT (Etienne Phillips) 8. 07:51 AM - Re: Re: No click when pushing PTT (Bob McCallum) 9. 08:19 AM - Re: Re: No click when pushing PTT (Robert L. Nuckolls, III) 10. 08:19 AM - Re: Re: No click when pushing PTT (Robert L. Nuckolls, III) 11. 12:02 PM - Shielded wire use with "wiring hubs" (CardinalNSB(at)aol.c om) 12. 12:19 PM - Re: Re: No click when pushing PTT (Noel Loveys) 13. 12:40 PM - Re: Re: No click when pushing PTT (Noel Loveys) 14. 01:01 PM - Re: Re: No click when pushing PTT (Noel Loveys) 15. 02:19 PM - Re: Permanent Magnet Alternators - Over Voltage Protecti on markcs) 16. 02:55 PM - Re: AeroElectric-List Digest: 24 Msgs - 02/14/11 EMAproducts(at)aol.com) 17. 04:31 PM - Re: Shielded wire use with "wiring hubs" (Robert L. uckolls, III) 18. 04:33 PM - Re: AOA indicator (Robert L. Nuckolls, III) 19. 08:36 PM - Re: No click when pushing PTT (N777TY) 20. 10:58 PM - New Stereo Audio Mixer Products (Vern Little) 21. 11:14 PM - Re: AOA (Dean Van Winkle) _______________________________ Message 1 ______________________________ _______ rom: "Robert L. Nuckolls, III" ubject: Re: AeroElectric-List: Re: No click when pushing PTT t 08:58 PM 2/14/2011, you wrote: Yes, the radio works fine otherwise (as in, it transmits fine). COM1 produces the click (hence I can turn on the runway lights). COM2 doesn't do that. It's not audible, and consequently lights don't come on.. I can hear the click on COM1 (and as a result, lights can be turned on, for example).. When you say 'transmits fine' do I presume that you can communicate with some distant facility? If on the ground, can you talk to say a distant aircraft and the pilot reports strong signal on either radio? Suggest you get a rough reading on power output. You can do this with the most rudimentary of SWR meters if you don't have access to a real wattmeter. Use the meter to check the #1 system and set the device for a full scale, forward reading on #1 then move it to #2 without changing the calibration. Talking to another airplane in the hangar or to a local hand held might appear to be just fine when in fact, transmitted power output is a tiny fraction of what it should be. Bob . . . _______________________________ Message 2 ______________________________ _______ rom: "Noel Loveys" ubject: RE: AeroElectric-List: Re: No click when pushing PTT would expect the first thing to do is to verify your radio is not ransmitting... If you have another radio close by you can test the ransmitter is operating. An old trick we used to do with taxicabs years go was to have someone hold a fluorescent tube (tube only completely nplugged) close to the transmitting antenna and key the mic. If the tube ights up the transmitter is active. Of course you can also see if you are utting out any power by inserting an SWR meter in the antenna feed line. n this case where you are only looking for the presence of power the heapest of SWR meters will suffice. As Bob said, gone are the days when there were mechanical relays happily hattering open and closed with every transmission. Noel -----Original Message----- rom: owner-aeroelectric-list-server(at)matronics.com mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of N777TY ent: February 14, 2011 9:33 PM ubject: AeroElectric-List: Re: No click when pushing PTT es, I'm expecting a click.. Considering that the other one which is same echnology (ie, not a case of old vs. new) I'd think the expectation is easonable :) Don't remember last time I ran into this situation in any lane ... so what I'm experiencing on COM2 is not typical.. Looking for deas what to look at.. -------- V-7A 777TY ead this topic online here: http://forums.matronics.com/viewtopic.php?p=331092#331092 _______________________________ Message 3 ______________________________ _______ rom: "Robert L. Nuckolls, III" ubject: Re: AeroElectric-List: Re: No click when pushing PTT >I would expect the light control radio to trigger on just the carrier, but for troubleshooting purposes you might try synthesizing a click verbally while holding the xmit button for each trigger, & see if the light control radio would respond to that, assuming that it really needs to see audio on the carrier. I'd also ask the control radio's mfgr about whether it just listens for carrier or not. If the lighting control system needs audio, it would be a published feature. Some of the early lighting control systems were jury-rigged onto the facility's unicom radio. It was a circuit that needed to see a sweeping frequency tone that pilots were expected to generate by whistling. I haven't seen one of those in service in 30 years. They're all carrier operated now and generally have their own dedicated receiver. I would certainly resolve the power output question first. Bob . . . _______________________________ Message 4 ______________________________ _______ rom: "Robert L. Nuckolls, III" ubject: Re: AeroElectric-List: Re: 2nd radio t 12:24 AM 2/15/2011, you wrote: Hi Jim If it is possible to share an aerial, do you want to? It would be a single point of failure for both radios... Every time I've has an issue with my radio, it's been an antenna problem (about 4 times in 12 years). Having an independent radio is more useful to me as a backup than a convenience, and so would require an independent aerial. But that's me! Excellent point. Antenna duplexers for transceivers are not cheap. Two antennas are certainly the least expensive and most reliable configuration. You don't need an audio panel but probably an audio isolation amplifier as described in the 'Connection's audio chapter. http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z16M.pdf Bob . . . _______________________________ Message 5 ______________________________ _______ rom: "Robert L. Nuckolls, III" ubject: AeroElectric-List: Low Ohms Adapters was able to finish the batch before I had o leave M.L. on important matters last Saturday. ad a Valentine's day appointment with my grandkids nd later my wife! I've been in Lindsborg the last few days and ill be back in the shop this afternoon. All ow ohms adapters on order will go out first lass mail this afternoon. I've not finished the official instruction sheet ut there's probably enough info in these photos http://www.aeroelectric.com/Catalog/AEC/9008/ to noodle out how the critter is used. I'll announce ublication of the official instruction sheet s soon as it's posted. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- _______________________________ Message 6 ______________________________ _______ rom: "Robert L. Nuckolls, III" ubject: RE: AeroElectric-List: Re: No click when pushing PTT At 08:06 AM 2/15/2011, you wrote: I would expect the first thing to do is to verify your radio is not transmitting... If you have another radio close by you can test the transmitter is operating. An old trick we used to do with taxicabs years ago was to have someone hold a fluorescent tube (tube only completely unplugged) close to the transmitting antenna and key the mic. If the tube lights up the transmitter is active. Yeah, that was the primary reason for keeping the little NE-2 or NE-51, neon bulbs around. Emacs! They were handy for 'sniffing' strong RF either within a transmitter or out on the antenna. Since then transmitters have morphed to low-voltage, high- current architectures. The lamps won't sniff within the circuitry but will still light up when held in close proximity to the tip of a 1/4-wave antenna. Haven't tried it but I suspect it will still be limited to getting excited at 5 watts or more. One is looking for an RF field on the order of 75 volts or more to capacitively excite these lamps into visible activity. The very first transmitter I built http://tinyurl.com/4hwa2da had an NE-2 permanently attached to the hot side of the tank coil and could be used to tune the transmitter. Can anyone spot a risk-issue in this as-published diagram? Bob . . . ________________________________ Message 7 _____________________________ ________ ubject: Re: AeroElectric-List: Re: No click when pushing PTT rom: Etienne Phillips I'll have a stab at it - when the switch is open, the chassis sits at line oltage? On 15 February 2011 16:49, Robert L. Nuckolls, III < uckolls.bob(at)aeroelectric.com> wrote: an anyone spot a risk-issue in > this as-published diagram? Bob . . . ________________________________ Message 8 _____________________________ ________ rom: Bob McCallum ubject: RE: AeroElectric-List: Re: No click when pushing PTT 1 The chassis is directly connected to the line. 2 the switch is in what is hopefully the ground side of the line. 3 It's probably old enough that the line plug is not polarized and the cha sis may be attached to the "hot" side of the line. More than one person has been electrocuted with such a layout. Bob McC rom: nuckolls.bob(at)aeroelectric.com ubject: RE: AeroElectric-List: Re: No click when pushing PTT At 08:06 AM 2/15/2011=2C you wrote: > I would expect the first thing to do is to verify your radio is not ransmitting... If you have another radio close by you can test the ransmitter is operating. An old trick we used to do with taxicabs years go was to have someone hold a fluorescent tube (tube only completely nplugged) close to the transmitting antenna and key the mic. If the tube ights up the transmitter is active. Yeah=2C that was the primary reason for keeping the little NE-2 or NE-51=2C neon bulbs around. They were handy for 'sniffing' strong RF either within a transmitter or out on the antenna. Since then transmitters have morphed to low-voltage=2C high- current architectures. The lamps won't sniff within the circuitry but will still light up when held in close proximity to the tip of a 1/4-wave antenna. Haven't tried it but I suspect it will still be limited to getting excited at 5 watts or more. One is looking for an RF field on the order of 75 volts or more to capacitively excite these lamps into visible activity. The very first transmitter I built http://tinyurl.com/4hwa2da had an NE-2 permanently attached to the hot side of the tank coil and could be used to tune the transmitter. Can anyone spot a risk-issue in this as-published diagram? Bob . . . /9j/4AAQSkZJRgABAQAAAQABAAD/2wBDAAEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQ EB QEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQH/2wBDAQEBAQEBAQEBAQEBAQEBAQEBAQE B QEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQH/wAARCABkAFADASI A hEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQ A AF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY 3 Dk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKW m 6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/8QAHwE A wEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSE x hJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSEl K 1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba 3 Lm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD+95L v OsgiPQZ57/T/P4U8Sl+jMO+RKBj8gP89qw0jjjm/dyed6D+fB/Mj+WKlSSNP+mXX/Uf1x/n9a+ c q/P/wACf+QGwJHDcebJ7Dgf0x/npyKNzf8APWT9P8aoi4jk/M+R/n359fw4qWGWONBcSSGKLyP 3 n9s8A+vrnHatfa+cfv/AOCBU1LV4tLjE93OsUIxgY/0m4x6DgDH1HtXBXnxKtvtBtbTRfEN0+O J v2MfTB4/IV594h8bx2E8l9eQXc2vajNiHS4ZhnRdI66ezBQBvdssxAALEnAzXkXif40aH4b1XR v +saHr114j8VT2dv4c0uAf8AISvNRv8A+zdOsP7S1P8A6iunf2ONHP0Ncrq16z/cfjsu/wCHpsr 9 9lbpb1fprvp01PsfR/E9tqD/Z5HubC75/cXw547ZOP16A9K3vtbRv8AvHHpjzh/+r/H86+LrP4 u xzS6frnhK/tdPmn+zz/APE8+13em/8AYR07U9J/4lg6Z0fp9a9i8O/Fjwy7WGkeIruWymlBgsd T Di0uSB/zED00zVMjABIBzywxyUqtfT7te11b+trdV0y9tR8106Lt5dNPwPajO7vEkby/ve/nZ6 D 1P4+wxUyPIJot7yiP8AHGTzzgH8c44qpcW6Rw+ZG5k9O/8AX26fyqhbyXEdzbebwDPZ2/6f179 P rWlVft+tvJ/pt1+Tuyfn9zurabf8P27FFNQjKeWI/KMP+v65H+eOw9ferSSSXD/ALuTzoufPPP v f1/lXG21xIIZZJP9TxnBOcg89/6en1res/LCfu8Zm7euSP5fX0/HI3Ooth5iesUPrz6+/1/nXn P bxB5uq23h+DzYooYP7Qv58/8fPJ/wBA6H6kdv59vDcSb/p08+f246ZHuc//AF68g1iT/ioNek8 y K1gsbz/AFE+Oun/AMvw7dcVznVhVrd7p/Lb/gaHhnxFuZPD/hvXvEkcXlXWm6V9nsZ55zzeajf / Nm/b/8AyokY/wAa+AfjhrnhW58QfsYz+ItYk8VeGf8AhcXwf06Nn8OGRbfWdO+JGl6kPChjDod T W1E6u2qh4yx1EkNrn9jDQq+vf2o45I/hFqn+mRRfbNc8NW58/H+k86l/nGO/Xk18bfFnX/DWuX v GWlyWdtf6DZ/E3wGPs9xomheH9VufEnh3QvBenCw03xDpukkalpmi6rYHWDgA+IAAuSAuOjC1f 6 33X9dl5hjqftbWt+V7bfgtrW3PdNS8aaP8ADvxdaaXcW/2Dwv4w1z+x7GC+sMf6ZqP/ACDv7R/ s /kGZ0onv6GveNSs7OMXUcnm2sXkfuOn2TP2DTfXrpec/wD66+Gf2qLjS7P4wfC/w3p+qRebqXj + /0eD/kE3Nnp39m6b/xLj+eOv419/pJcW9zdRWn/ABNIobG8z+4/7Bv6f55rCO69V+Z5WJX732C v 2ve3RaXf9bbnpP7PnjuTUF1jwDqd5LdR6NAb/w7f3H/AEBs/wBnGwGf+gMQBjjqSORX0RBITd2 4 6mW0E/1N8R9O2O36V8bfCK30u8+MNheRaXc6Nqh0TxGD9iYraaiDZaYGOo2GogkMFJK4wCwGWX 7 +xIvLj1SOPzPOl+22mZumcg5H4/WuuL/wBoj8n5foVhX+5Xlff0Xp+Z5qmoeZ/y0x5OT/nH/wC v tnTLjzHz/yy/wDrYwP/ANefrXnOm3FwfK/1p6/v/qfr+Hbv9K62G98t/L8zn9c/r/gfYYrjPT9 l R+7/gHoMPmSeUJP/IGcY4/z9a8g1i3uLi216483ypZ777PP9ePf8/8AOPRrDVPkl8ySL/j3/LP 8 wAvavJdV1y3j03zPLh/fareXE/n/wDPn/8AW/nWOL0w+nn+ZrhL6ev6r/gWPmT9quOf/hXWl6d J aj7Z4jvLjyLj/qHaD+f/MR/IV8g/E7wnH4f+Lv7Cng+zvBqlgfipeXF9PYn+ybS5vNO8B6bqX/ I P8AyExomq6jqOj/AKGvof8Aa38SaXJbeF/D9wIpZv8ATNQ+wzn/AI9jqP8AZub/AI7e3vXxv8Y P Z4L8YftLfs06hZ+OPFsujfCX4jeI/HHjjXNK8K393pWpaP/AMIl/wAS3/iY/wDIX/5Cv9naP0/ 4 H9p/wDCRdKWFq9Funbu/T1t8radTqq0vkrdddGr6+XZ+Z6N8e9Ds5P2k/gOlx5UUVn4j/tCCe+ 4 03n9vabx3/z61+hw0uT7TqlxH+6lgsbwQTwc/6Z/wAS38Mfl/PP5f638RLf4kftV/BG40fULXV L R4LzUb79+Ba/bDqGpal+P8AyDtO+vIr9GNH8WXklnr0cln9qsPP/f8AP2Tpz2/7B2T1rr9pra2 u r6272seBU2xTflZv/DH/g/j5nWfBqKS5+L92Lm3ljktPCmsz2WqQ9CDf6bwRyMEZ45Br6gt5Jf 7 sox+9i+22n77/t+6f4V8yfAnxRp9x8WvFtp5kV1dWfggaxxb/ZbS2szqGm/2dYadqH/ADE+/J4 A 7YP0Fp88Z1rTHt5YhFPqlp+4HUZv8ZHqR29/wBdNfbf1te35/gb4SnagvLp6a+um/4HjkNxLv8 A 8zt6/kf5/z963odQ8vH7z/vx+nr6de1efWFx858y8il49+Oc9P89q6iGS3kxH/re/uP84H5Vze 2 n9yPT9n5/h/wTvE1Ty7OWSS4liPkep6f549fTNfnZ+2N408YeH/AIIf2h4C8WReEvEd54x0a3G q Yf7W+zWYsNS/tKw07+09W/5Cn/IO6f4V9zP9njT/llL/wDrP09vQH2xX5L/ALefjCz8L/Cuwvb z YrWbxx/y42N/d/av9A1L/mHaZpPp0x17V4ue4uvQyvG4jD2TSSTtr9n8Xu7M9TK8Kq1d9V2e3/ B f8A4B+enwq8E/tT/trfEm8+Fuo/tAS3NnYi9ubG+g1YeB9XNnpuP7R/4mWnfD7xuozjAJ0MAkj J Jryr9q/9hn9oP8AZm1ZWX4gS67Dp9hd3OlA/FTT/EN2LP7Bg/2j/aXwn0QEAjqND0NT/aWVJGC f D/gkp4i0NvjtBqs+qRWM1/bfEi+869t761s/sVgdupZU6ZH/ZqaIDp5fV9YddDKhgh3la9M/wC C fxK0S2+JXxD8LNr+iS+JdG8J6Lc3PhS21CxvdetdJ1LT82F9f2DANpqaydOIQkA7cZGen84z4v 4 pVlWoYx3/thLl6cmiat8/nf0PczTBYOjHl05f7HTbtrz8yWmnZN23Wnqfzp/Bn9rD42aH45tY9 P 4tUutNvry3Gq6rrmn/r/wASn+R7Gv6ivgn+0hHqPwosLjWLfxHpfxBvPEdnqGq2Phz7BqxubP7 B wAS4f2j/ZP/ACC/+Jd/yB/+wuK/ja8N6hcHxbr3iCO4tfKm+2W995EOLS5/s7/l/wC/1HX/AJh F t74D8ea54f8PaN/Zeq3+l3U2lfZ5xY332X7T/n/AOsO+f6D4WxeZ4zM19Yf/MoTafRu3Tve99u j huIVQwmCwf1fd2T0v2Wuuvz/U/o6/ZM1jxJ4gvPiX408SeEtQ0H/QdH0eeeeDNpqV5xqWo3/P8 A N/+gb+ufb6u0bUPtOuaGIo5edb0gTHz8jm+6kcZx1x6dPSvjP8AY/vNQ/4Zs+HNzqF7LLf+JIL z RfT/wDYRv8AUv7O9M/8Sr+zuvr619N+HLvy/E/hiPzPMlOt6R5/0N/zzn8fx/Cvrrv219N/w5r W /S21tDHCU74G7ers3e972X+X4Lvp59Z3Fv5P7v/AD7Dn/P1rZTUPL482I9PU8fh9PavL01AxpF + ii8n/H16/l+Vaiap5kOJDF3/Dn/AD+PHNeefR+y/u/j/wAE9GudZjjtjH5vlfuPXnr0z9eP5+g / r/gpHqGuf8ACuvBtv4f0eLWbqbxHrGoT2P/AAkd/wCE/tP9n2H/ABLv+Jj/AGVrn/QS/n2r9VP 7 jNtLJJJL/qMfXrz37djx9a/Ev8A4KA+PbjxBN4O0eTw3r+gaDoureLwdcuPEXhPVf8AhLdH06+ 1 w5qN/pun+GfFmuat4a/sXVPDw/4lHjLQtD1/OQeQRXxPGuP+p5LjLb9ktdXG2nk3+Nu57OTYZV a 9Enol3focT/AMEo/hPqvxM8beI7UaP4l/4Ri8+GnxF0e+n8M6vYWVnp3i7xF4v8NanZX/jI6nq j vqnhsRaboDRroo1wM+lqrNrikuvyz/wWY8caxZftV/HvUNLim0rzfAujeHtD1u4uNAJ1LxH9u1 L hIs6f8A2w2rnTNF0rUfDoP9taJoeTpmcnqf1V/4JEmfwe3iTWtImsNc0vU/CCW1jZeR9k1a1On M 26jqJxnTG/s7TlGsD+3SScfT8Lf+CtV34p8T/HHxF4z8UeIdL0awu7fxHcT6XY3F+bU3g17rp3 9 /8AMMI/4k5zivwfIcfHMM4wOHajdZxeS/4UNl/ZzTd9Hq2vLXoz2MzyvEuMniFeEaceSV07uTk 5 yfNb3Y9k9N7O35EfBz7RGlrH5kMWl6PffZ/sNjP9ktLqz/t7/kH/wDIJ/5Bf9lf2d/Udq/ZvR/ G 2fSbC38z/lx+zz+f/on+mD8P0/nX4/fB+wt7zUtL07UNYi+yzarZ6hfXHn/AGS0uv7O/wCJlqN / Xj/AKBnavvq58SSQTXUlncC6tZrH7RYz/8APzZ6j/xMtOv/APPOT3r+kOG8VbOc2jdaJJK9u2y / 2j2voflnFdKt/ZuC0fxJeiTju+yX3fI/sg/Zy1CSz/Z7+C0fmeV5Pwy8H6gbf1/tGw03Uvy/wC J fX/AA+gvCuqeZ4q8LySJ/zMej/pf8f1z7V4F8LY/wCz/hR8L7OSTyvsfw58Haf5Hr/xIdN/x79 O wr1DwZef8Vh4Xj/AHvPiPR/X/n/APXGeeOg619JVvV1vb8Oz7fpselQpWw0e9l67W9Ov466o8q e MaRRxyYEE/2cz/T2/z/AEq0lzHH/wA8sf8ALAT/APP6P8P5enfGmk81P3cnlf8ATf19c/y/Gon z n+c85/L09qo9gv6rrF59m32/wDh+Y+n4V+S/wC17+w/qHxMOs65+z3o/wAOfBGs+Pb7xLrHxbs Z t+k3fj/AFjUf+Jl/b39o/8AE8/4mn/Ex1H/AKAQx1GK/U+aSO4iJuIzmYcwf5/yPp0xvL/1Ucf + H+HH4fhXlZnleBzKiqGP1V0vJq6v6/j3d7nZhcTXweyWu2np+fz266n8uP7NX/BbTS/+Cfes+I / h48+A2ieLtT0G/u/CFwdR8ZeOvCXiLRLvTSNNOnajp+q/DvXtI1MaPqunbSRroYA6uVKnXAa/O b r39vzwv+1B4z1Txpo+l6NoOl69fXlvYaVP4j8JaTpOm/wDIS/0D+0caHn+xef8AkNf2Fzwc9a/ b /gpH/wRb8P/ALXHxUi+NHwr8SDwR438bfbR8TbG+1WwtPCdzeadoP8AxLvFunad/wAInrmr/wD C a1qv9naP4g9/wDio6/mY+Pf7A/jj9kvxbF4O+OlvdaNqn2E6xpVjBf/APCQ6T4t0f7f/Zun6hp 3 LTNJOkaZpf9q/8AEmz/AMh/9RWOV8A8F0cX9ewOF/25O+t7czUU2vuVu1tDHHZ5nHsnTrLWXKm 0 8EbtK17L4pbJXvu9D0b4UeKNH1S2l8N65p8UthqMF5b32qweKtBu7u20fUbD+zft+nf8TfH+fp X V/wsDxZ4x1WwuPFnjDxb8QfFF4NH0eDVfFWq/8ACQ+ItSs9OsNN8N+HNB/tE/8AUK07TtHzj+d f P7P3wo+Inxk8eaD4L+F/h+/8W+N/FV99osbHS5/9E+x8f8AEw1HUf8AmGeF9F0r/mMdK/qj+A/ / ARv+F/w/wBZ8EeNPih8UPFvxB1nQJ9H1jVfB2kwWHh7wRc+JNOzqX2D+0f+Qvqel/2r/wBgL+3 s 69n+x8sy7GvEYf/AH6zvrda2vdbb7fefKYqrjs2aoUl/sKcW31+z87/AHL5n6gfsta58XJP2fv h H8fNPOl/FWz0O8t/EdiLGwtLu2s9Ov9S03w7/aOnaZ/xKP7T/sr+zu/4c19N+EtUkk8VeGPL/6 D jjpj/l/03HU+v6/nXBvqEcj5uIxLj/6x9q2fCt5b2/irw5JJ+9ih1zRz1/6f9Nz26Vl7X/oI6v p SXW/wDVz16NP2EVh/ze+ltetvyfyt9Ep8DvCct0Yn1HxGUE/AF9p47f9gqp4/gh4T+f/iYeIfm t n/S9N79f+YT7UUVzHcZFz8EfCnlg/2h4h+c4P8Apenen/YJpn/CkfCgl2jUPEOMA/8AH3p3fj/ o 0UVpU6fP9DoM26+B3hMTZGo+I8/aOv27T+3/cK96z9X/Z7+Huq6ZqEGsQXutWd3P/ZV7p+sxaH q hfWHB+zXdrfaJPHKnP+yf1yUVzUm/ZrV/Elv05loaVNbX8/0M/4dfscfAPwAdTuvhz4H0H4cz6 x hNWk8CeFPAnhhtTX/p8/s3wlD5vTtt/lXbwfA3wnMYxJqXiQ7en+nWHoP8AqFe9FFdy1qq/8i/ I 7JbKxMnwM8JF/8AkI+JP+Xw/wDH9p/f/uFVn/8ACnfDUOtaNcx6j4gEv/CQaRJu+16efm+3nt/ Z SiilV/jP+u5nU6fP9D/2Q ________________________________ Message 9 _____________________________ ________ rom: "Robert L. Nuckolls, III" ubject: RE: AeroElectric-List: Re: No click when pushing PTT t 09:16 AM 2/15/2011, you wrote: #1 The chassis is directly connected to the line. #2 the switch is in what is hopefully the ground side of the line. #3 It's probably old enough that the line plug is not polarized and the chassis may be attached to the "hot" side of the line. More than one person has been electrocuted with such a layout. Yup . . . you're tied for first place. Bob . . . _______________________________ Message 10 _____________________________ _______ rom: "Robert L. Nuckolls, III" ubject: Re: AeroElectric-List: Re: No click when pushing PTT t 09:04 AM 2/15/2011, you wrote: I'll have a stab at it - when the switch is open, the chassis sits at line voltage? Right on! I'd built a number of transformer-less circuits where injudicious wiring and positioning of switches could put a chassis at above ground potentials. Since all ham gear was expected to be well grounded for reasons of antenna performance, it made sense to use the SAME ground as the power return for the device. Make the line-cord a one-wire lead that was switched. If the gizmo didn't power up, reverse the plug. But in no case was the properly grounded system at risk for presenting a shock hazard. So called AC/DC radios popular at the time were always housed in a wood or plastic case. Quite often, the line-connected 'ground' within the appliance was floating from the chassis. When launching a line-powered, transformer-less DIY project, it was good to understand such things. Good eye! Bob . . . _______________________________ Message 11 _____________________________ _______ rom: CardinalNSB(at)aol.com ubject: AeroElectric-List: Shielded wire use with "wiring hubs" hat is the appropriate way to handle the shield part of "shielded" wire hen wiring using a commercial "hub" or a diy "hub"? For ntercom/aviionics use. Thanks, Skip _______________________________ Message 12 _____________________________ _______ rom: "Noel Loveys" ubject: RE: AeroElectric-List: Re: No click when pushing PTT I'll take a stab at it. he crystal and the heater for the tube are both powered by 115VAC. onsidering the potential instability in both the voltage coming from the all and possible changes in the frequency of the AC current it may be a bi t dgy. oel ow give us the real reason. Please! oel rom: owner-aeroelectric-list-server(at)matronics.com mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. uckolls, III ent: February 15, 2011 11:20 AM ubject: RE: AeroElectric-List: Re: No click when pushing PTT t 08:06 AM 2/15/2011, you wrote: I would expect the first thing to do is to verify your radio is not ransmitting... If you have another radio close by you can test the ransmitter is operating. An old trick we used to do with taxicabs years go was to have someone hold a fluorescent tube (tube only completely nplugged) close to the transmitting antenna and key the mic. If the tube ights up the transmitter is active. Yeah, that was the primary reason for keeping the little NE-2 or NE-51, neon bulbs around. Emacs! They were handy for 'sniffing' strong RF either within a transmitter or out on the antenna. Since then transmitters have morphed to low-voltage, high- current architectures. The lamps won't sniff within the circuitry but will still light up when held in close proximity to the tip of a 1/4-wave antenna. Haven't tried it but I suspect it will still be limited to getting excited at 5 watts or more. One is looking for an RF field on the order of 75 volts or more to capacitively excite these lamps into visible activity. The very first transmitter I built http://tinyurl.com/4hwa2da had an NE-2 permanently attached to the hot side of the tank coil and could be used to tune the transmitter. Can anyone spot a risk-issue in this as-published diagram? Bob . . . _______________________________ Message 13 _____________________________ _______ rom: "Noel Loveys" ubject: RE: AeroElectric-List: Re: No click when pushing PTT Certainly a short across the 1 muff cap could cause that. oel rom: owner-aeroelectric-list-server(at)matronics.com mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Etienne hillips ent: February 15, 2011 11:35 AM ubject: Re: AeroElectric-List: Re: No click when pushing PTT 'll have a stab at it - when the switch is open, the chassis sits at line oltage? On 15 February 2011 16:49, Robert L. Nuckolls, III nuckolls.bob(at)aeroelectric.com> wrote: an anyone spot a risk-issue in this as-published diagram? Bob . . . _______________________________ Message 14 _____________________________ _______ rom: "Noel Loveys" ubject: RE: AeroElectric-List: Re: No click when pushing PTT Many years ago I had a radio/Amplifier which the chassis could be hot if it as plugged in that way you would get a terrible AC hum from the speakers.. . always put it down to the shielding on the tubes being hot. Yes I did ge t everal good roots from that thing until I realized that turning the plug round removed the AC hum. oel rom: owner-aeroelectric-list-server(at)matronics.com mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bob cCallum ent: February 15, 2011 11:46 AM ubject: RE: AeroElectric-List: Re: No click when pushing PTT 1 The chassis is directly connected to the line. 2 the switch is in what is hopefully the ground side of the line. 3 It's probably old enough that the line plug is not polarized and the hassis may be attached to the "hot" side of the line. More than one person has been electrocuted with such a layout. Bob McC _____ From: nuckolls.bob(at)aeroelectric.com ubject: RE: AeroElectric-List: Re: No click when pushing PTT At 08:06 AM 2/15/2011, you wrote: I would expect the first thing to do is to verify your radio is not ransmitting... If you have another radio close by you can test the ransmitter is operating. An old trick we used to do with taxicabs years go was to have someone hold a fluorescent tube (tube only completely nplugged) close to the transmitting antenna and key the mic. If the tube ights up the transmitter is active. Yeah, that was the primary reason for keeping the little NE-2 or NE-51, neon bulbs around. Emacs! They were handy for 'sniffing' strong RF either within a transmitter or out on the antenna. Since then transmitters have morphed to low-voltage, high- current architectures. The lamps won't sniff within the circuitry but will still light up when held in close proximity to the tip of a 1/4-wave antenna. Haven't tried it but I suspect it will still be limited to getting excited at 5 watts or more. One is looking for an RF field on the order of 75 volts or more to capacitively excite these lamps into visible activity. The very first transmitter I built http://tinyurl.com/4hwa2da had an NE-2 permanently attached to the hot side of the tank coil and could be used to tune the transmitter. Can anyone spot a risk-issue in this as-published diagram? Bob . . . _______________________________ Message 15 _____________________________ _______ ubject: AeroElectric-List: Re: Permanent Magnet Alternators - Over Voltage rotection rom: "markcs" ob, Many thanks for your reply. Your time is always much appreciated. Regards Mark ead this topic online here: http://forums.matronics.com/viewtopic.php?p=331164#331164 _______________________________ Message 16 _____________________________ _______ rom: EMAproducts(at)aol.com ubject: AeroElectric-List: Re: AeroElectric-List Digest: 24 Msgs - 02/14/1 1 Bob, xcellent comments on the list I was a designated examiner & PPE for about 7 years on the CE 500/550 eries and along with the FAA used the AOA to see if the applicant had use d he "bug card" correctly in figuring his approach speeds. If I recall orrectly was 1 Kt per mark on the AOA scale. Tell the appplicant it loo ked s f he was in error on his approach speeds by a couple knots he would look t you like you were crazy, then refigure and guess what, we were exactly orrect, told the applicant to use equipment he had in his plane! Navy ilots lived by AOA, they are among my best customers. I had a pitot line freeze on a D-50 T-Bon in the late 60's seems a echanic had bent it to make it easier to attach an engine mount, however just outside the cowling it had made a low spot. I lost all airspeed at about 1,000 in IMC, declared an emergency and descended into Prescott, AZ finall y etting airspeed back in final turn in holding pattern prior to approach at 200 AM Been there done that. n a message dated 2/15/2011 12:00:48 A.M. Pacific Standard Time, eroelectric-list(at)matronics.com writes: ________________________________ Message 17 ____________________________ ________ rom: "Robert L. Nuckolls, III" ubject: Re: AeroElectric-List: Shielded wire use with "wiring hubs" At 01:56 PM 2/15/2011, you wrote: What is the appropriate way to handle the shield part of "shielded" wire when wiring using a commercial "hub" or a diy "hub"? For intercom/aviionics use. Thanks, Skip Instructions for installation/fabrication should speak to at least one pin in every connector reserved for the purpose of connecting to shield grounds. All shields in a bundle can be daisy-chained such that the shields can be handled on a single wire in one pin of the plug. http://www.aeroelectric.com/articles/pigtail/pigtail.html Bob . . . ________________________________ Message 18 ____________________________ ________ rom: "Robert L. Nuckolls, III" ubject: Re: AeroElectric-List: AOA indicator t 03:39 PM 2/12/2011, you wrote: If you are an EAA member you can see ALL back issues of Sport Aviation on http://www.oshkosh365.org If that doesn't do it for you I do have the 2005 issues but I would have to see what issue it was in. Do you remember what month? Sorry, no. It was mentioned on another forum. Had an EAA membership for 20+ years but gave it up about 10 years ago. So if anyone could find and capture the article, I'd sure appreciate it. Bob . . . _______________________________ Message 19 _____________________________ _______ ubject: AeroElectric-List: Re: No click when pushing PTT rom: "N777TY" 'all lost me there :) Anyways, back to square one. The radio works just fine... it's been insta lled or a little over 2 years and never had issues communicating with anyone (e ven istant facilities). I acquired the plane last summer and this click was never here.. so I can only assume it was like this from day one.. but have no wa y f confirming this. For clarification -- this is a certified plane that's been flying for a lo ng ime.. ot a homebuilt sitting in my garage.. This radio allows me perfectly nor mal 5 by 5" communication with anyone on frequency.. there have never been ny issues with clarity nor strength of normal voice transmission.. It jus t oesn't lick... that's all. -------- V-7A 777TY ead this topic online here: http://forums.matronics.com/viewtopic.php?p=331193#331193 _______________________________ Message 20 _____________________________ _______ rom: "Vern Little" <sprocket@vx-aviation.com> ubject: AeroElectric-List: New Stereo Audio Mixer Products Discussed several times over the years on Aeroelectric, audio mixers ave matured. In addition to mono audio mixer/audio panel devices and tereo headphone adapters available for some time, Vx Aviation has eleased a pair of stereo audio mixers in our unique form factor-- the -sub backshell. Although we avoid posting too much commercial material to the list, I ope Bob appreciates what we've done here, because it's relevant to what e have debated over the years. Thanks, Vern Little Summary of Announcement: ICTORIA, BC---February 16, 2011---Vx Aviation today announced the ntroduction of the first stereo audio mixers designed specifically for xperimental aircraft applications. The AMX-4A and AMX-4B dramatically implify and lower the cost of audio system installation in both xisting nd new aircraft. Both units are virtually pin-compatible with the ndustry-leading AMX-2A monophonic 10 channel miniature audio mixer, ntroduced in 2008. Both the AMX-4A and AMX-4B units provide five independent stereo input hannels. Three channels are fixed-level, designed to connect to audio ources that have their own volume controls, such as EFIS systems and XM radios. Two of the channels have screwdriver adjustable audio levels, roviding the flexibility required when connecting to fixed level ources. onophonic sources are supported by connecting together the left and ight nputs of any input channel. The AMX-4A low output version works seamlessly with PS Engineering ntercoms, providing the critical 2 volt peak-to-peak voltage limiting equired that prevents damage to the PS Engineering products. The AMX-4B high output version has no such limiting and provides up to 12 volts eak-to-peak drive capability and a gain of 15 decibels, making it ompatible with intercoms that require input amplification or for irectly riving headphones. for more information, including photographs and drawings, please see ttached document> For further inquiries, please contact me. Thank-you. Vern Little x Aviation ww.vx-aviation.com _______________________________ Message 21 _____________________________ _______ rom: "Dean Van Winkle" ubject: Re: AeroElectric-List: AOA Bob I just noticed your comments about loss of IAS on both sides of the eechjet. l attended 2 of your Seminars and I know we talked about both aving worked for Cessna. When I left Cessna as a Flight Test Engineer n 1968, I went to work for the Army Aviation Systems Cmd in St Louis as Dept of Army Civilian Senior Aeronautical Engineer and was there for 8+ years. Most of my time there was spent with the Army's Fixed Wing lectronic Intelligence Gathering Aircraft. In the later years I was the rmy Technical Manager for 7 different versions of the RC-12 (Super ingair 200), the last 4 versions comprised of 36 aircraft with 1200 SHP ngines and Gross Weights in the 16,000 to 16,500 lb range. In the early 90s, we took the RC-12N configuration which had the largest antenna rray to Duluth, Mn in January for natural icing tests. The Army test rew from EAFB had a specially instrumented U-21 to search for icing onditions and would then call out the RC-12N. I rode with the Army test rew on flights 2 and 3 as a FTE/ Observer. On flight 2, we were in a ow stratus layer around 3000 ft MSL, 140 KTS, about 45% cruise power. t 50 minutes we has collected 5 1/2 inches of ice with all of the deice oing, at 90% cruise power for the same air speed and had just lost the ight pitot airspeed. About 3 minutes later we lost the left pitot irspeed. About 2 minutes later, we climbed out of the low stratus layer o the U-21 could get photos of the ice buildups. Fortunately the U-21 as able to get a picture of the right pitot which showed that ice had rown forward on the unheated pitot mast and then curved downward to lock the pitot inlet, at no time actually touching the pitot tube tself. Before the U-21 could move to the left side, the left mast had ost enough ice that the left airspeed had come back and a few minutes ater the right airspeed was back. Beech attempted to get some heat in he mast , but abbreviated tests the following winter showed that it was nsufficient. Bob, I don't know whether the Beechjet used the same itot units or a similar design, but that was our findings on the Model 00. Alden Van Winkle lo Build RV-9A vanwinkle(at)royell.org ----- Original Message ----- From: Robert L. Nuckolls, III To: aeroelectric-list(at)matronics.com Sent: Monday, February 14, 2011 9:08 AM Subject: Re: AeroElectric-List: AOA At 08:03 PM 2/13/2011, you wrote: My comment on icing and AOA systems ~~If you encounter any type of cing turn the AOA OFF unless you have full de-icing vane & aircraft. e haven't even done R&D on a heated vane because of liability. Even oeing can't give you hard numbers with icing on wings. Heated vane and cing on wings is NOT a good deal! Elbie Mendenhall, EM Aviation, LLC www.riteangle.com Exactly. The fleet of bizjets at HBC were all qualified for flight into known ice. Everything was heated or hammered. I'll have to call some of my jet-jockey friends at HBC and inquire as to words in the POH concerning usefulness and cautions about AOA displays on the production fleet. I worked a REALLY strange problem on the Beechjet some years back were pilots experienced loss of IAS on BOTH sides of the airplane. Displays always recovered at lower, warmer altitudes. This often occurred in relatively clear air. There was a LOT of brainstorming by a LOT of grey beards as to the physics behind this rare but disturbing event. My task involved cutting a pitot tube open, peppering it with thermocouples and putting it back together again so that we could study not only temperatures at the surfaces to be de-iced but internally. There was some question of ice crystals bouncing through the labyrinth of pressure channels only to melt and re-freeze inside the pitot tube. During the fire drill for sniffing out root cause, somebody asked the question: "How does the existence of a working AOA display help the pilot who is temporarily deprived of IAS?" Good question. The Beechjet had been fitted with AOA indication since its birth as the Mitusbishi Diamondjet. But nobody had ever researched and written the approve procedure for using AOA as an aid to maneuvering without IAS. That amendment was quickly added to the POH. I'm not sure we ever deduced how pitot pressure was being obstructed. I'll have to ask how that problem resolved too. But it was interesting that a perfectly useful display had existed for so long but was never fully developed as a component of plan-b, plan-c, etc. Shucks, with DUAL air data systems, what are the odds? Bob . . . -======================== ======================== =========== -= - The AeroElectric-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?AeroElectric-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Date: Feb 16, 2011
Subject: Re: AOA indicator
Are they online somewhere? Or am I looking in the wrong place? Raymond Julian Kettle River, MN On 02/16/2011 10:32 AM, Robert L. Nuckolls, III wrote: > > > At 09:44 AM 2/16/2011, you wrote: >> >> >> Bob, >> I did a search of past EAA articles and found the following pertaining >> to AOA: > > thanks to all who responded to my query about S.A. > articles. I now have several. It's interesting/useful to see > what kinds of things have been published for the OBAM aviation > community. I've added all your contributions to my library. > > > Bob . . . > > ________________________________________________________________________________
Date: Feb 16, 2011
hi all, with my $10 tracfone came a car recharger so i am all set. have a garden tractor battery i bought for a trail cam and never used and at least 1/2 dz . battery tenders around . i put a contacter together today in a metal box with 120 volt plug and receptacle so handling a 15 amp load is no problem. i was still a little worried about something triggering the device [ although not so much now as a power outage wont be a factor] and it would run something for a week or two. this morning it came to me to plug a timer in the power supply cord and interrupt the power to the circuit board every 8 hrs or so. board will shut off if on and will resume operation if it gets the light signals. including the tracfone i have $40 in this and it works like a million bucks! thanks for the input. bob noffs On Wed, Feb 16, 2011 at 10:17 AM, Carlos Trigo wrote : > > > ------------------------------ > > *From:* owner-aeroelectric-list-server(at)matronics.com [mailto: > owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of *Robert L. > Nuckolls, III > *Sent:* quarta-feira, 16 de Fevereiro de 2011 14:38 > > *To:* aeroelectric-list(at)matronics.com > *Subject:* RE: AeroElectric-List: cell phone rechargers > > > At 08:50 AM 2/16/2011, you wrote: > > It's unfortunate that there's so little standardization > for power supplies . . . especially for cell phones. > > > Recently I saw in some TV news that the great majority of world cell phon e > manufacturers (including Motorola, NOKIA, Siemens, Samsung ' I can=92t > remember if iPhone and Blackberry were in) had reached an agreement exact ly > to standardize all cell phone chargers. > > > Let=92s hope they do it quickly > > > Carlos > > * * > > * > =========== =========== =========== =========== > * > > ________________________________________________________________________________
Date: Feb 16, 2011
At 05:23 PM 2/16/2011, you wrote: > >Are they online somewhere? Or am I looking in the wrong place? I've posted them here. http://www.aeroelectric.com/articles/Angle_of_Attack/ Bob . . . ________________________________________________________________________________
Date: Feb 16, 2011
I think the use of electro-mechanical relays common to transceivers for 50 years have been replaced with all solid state switching. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331315#331315 ________________________________________________________________________________
Date: Feb 16, 2011
They display angle of attack on the left side of the screen derived from, I think, AHARS data, not from unheated pin holes in the wing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331314#331314 ________________________________________________________________________________
Subject: Re: Battery disconnect switch
Date: Feb 16, 2011
Remember that contactor service life predictions are based upon switching certain kinds of loads usually in a laboratory environment. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331316#331316 ________________________________________________________________________________
Date: Feb 17, 2011
Subject: Re: cell phone rechargers
Bob Noffs, I would be very interested in duplicating your set-up. You said the LIGHT from the phone activated the contact? John Morgensen On 2/16/2011 5:38 PM, bob noffs wrote: > hi all, > with my $10 tracfone came a car recharger so i am all set. have a > garden tractor battery i bought for a trail cam and never used and at > least 1/2 dz. battery tenders around . i put a contacter together > today in a metal box with 120 volt plug and receptacle so handling a > 15 amp load is no problem. > i was still a little worried about something triggering the device [ > although not so much now as a power outage wont be a factor] and it > would run something for a week or two. this morning it came to me to > plug a timer in the power supply cord and interrupt the power to the > circuit board every 8 hrs or so. board will shut off if on and will > resume operation if it gets the light signals. > including the tracfone i have $40 in this and it works like a > million bucks! > thanks for the input. bob noffs > On Wed, Feb 16, 2011 at 10:17 AM, Carlos Trigo > wrote: ________________________________________________________________________________
Subject: Wiring diagram question for Pitot Heat On indicator
light
Date: Feb 17, 2011
Guys, I'm using Bob's pitot heat.pdf schematic as the base for a "Pitot Heat ON" amber LED light on my annunicator / warning light panel. http://www.aeroelectric.com/PPS/DeIce/Pitot_Heat.pdf In comparing this schematic to his article titled "Failure Detection and Annunciation I notice a few differences in the two schematics. http://www.aeroelectric.com/articles/Failure_Detection_and_Annunciation.pdf Questions: 1. In pitot_heat.pdf the relay is positioned just before the Pitot heater load and after the Reed switch sensor, vs in the second article the relay is positioned BEFORE the Reed switch sensor. Does it matter? 2. The Reed switch current sensor wire layout is different in the two articles. For example, the LED light wire is after the resistor in one, -vs- the LED wire is after the Radio Shack 275-232 reed relay in the second article. Does it matter? 3. Does anyone have a picture to share on how they boxed up and made flight worthy the Reed Switch Current Sensor? Thanks for any help here, Howard -------- Howard Plevyak GlaStar / North Bend, Ohio hplevyak(at)mac.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331328#331328 Attachments: http://forums.matronics.com//files/pitot_heat_202.pdf http://forums.matronics.com//files/failure_detection_and_annunciation_134.pdf ________________________________________________________________________________
Date: Feb 17, 2011
Subject: Re: 9005 LVWABM
At 09:43 AM 2/17/2011, you wrote: > >Hi Bob, >Let me start with the warning that I am dumber than a box of rocks >when it comes to electron herding. >I just received the circuit bd. 9005-301-10. while placing the parts >I find no holes for the IN4742A Optional diode. I assume that this >is needed for the battery management function. That part was deleted as not necessary . . . Bob . . . ________________________________________________________________________________
Date: Feb 17, 2011
Subject: Re: Wiring diagram question for Pitot Heat On indicator
light At 09:07 AM 2/17/2011, you wrote: Guys, I'm using Bob's pitot heat.pdf schematic as the base for a "Pitot Heat ON" amber LED light on my annunicator / warning light panel. http://www.aeroelectric.com/PPS/DeIce/Pitot_Heat.pdf In comparing this schematic to his article titled "Failure Detection and Annunciation I notice a few differences in the two schematics. http://www.aeroelectric.com/articles/Failure_Detection_and_Annunciation.pdf Questions: 1. In pitot_heat.pdf the relay is positioned just before the Pitot heater load and after the Reed switch sensor, vs in the second article the relay is positioned BEFORE the Reed switch sensor. Does it matter? No 2. The Reed switch current sensor wire layout is different in the two articles. For example, the LED light wire is after the resistor in one, -vs- the LED wire is after the Radio Shack 275-232 reed relay in the second article. Does it matter? Depends on what you want to display. Light ON = "Pitot heat powered up and drawing current" (Page 3) Light ON = "Pitot heat powered but NOT drawing current". (Page 4) Bob . . . ________________________________________________________________________________
Date: Feb 17, 2011
Subject: Re: follow up shielded wire/hub question
At 01:50 PM 2/16/2011, you wrote: >My first question needed to be more specific. My audio panel >installation manual shows that the shielded wires are "open" (shield >not grounded) at the end where the wires connect to the radio, and >the shields are all grounded together at the audio panel. > >If I use a "hub" system, where all avionics go in and then out of >the hub, do I keep each shield on a separate pin going in and out of >the hub, or do I ground all the shields together going into the hub >and then start a set of new shielded wires comng out of he hub (open >coming out of the hub) and tie all the shields to ground at the audio panel? Exactly where shields go to ground in small airplanes is pretty much irrelevant. IF the shield is connected at both ends and is obviously a return path for signal or power, then carry it through the hub on it's own pathway. If the shield is not a signal/power pathway, connect to common ground in hub (which still needs to be carried to shield ground at the audio panel) FYI . . . when replying to a message lumped with others in the 'digest' configuration, please trim away all non-relevant text from the message. Bob . . . ________________________________________________________________________________
light
Date: Feb 17, 2011
Thanks Bob...that helps. Can you comment on use of the 18AWG fuselink in the Pitot Heat.pdf schematic in place of a 15amp fuse? Why wouldn't I just use a 15amp fuse at the bus to protect my wire? Thanks, Howard -------- Howard Plevyak GlaStar / North Bend, Ohio hplevyak(at)mac.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331341#331341 ________________________________________________________________________________
light
Date: Feb 17, 2011
Thanks Bob...that helps. Can you comment on use of the 18AWG fuselink in the Pitot Heat.pdf schematic in place of a 15amp fuse? Why wouldn't I just use a 15amp fuse at the bus to protect my wire? Thanks, Howard -------- Howard Plevyak GlaStar / North Bend, Ohio hplevyak(at)mac.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331342#331342 ________________________________________________________________________________
Date: Feb 17, 2011
indicator light At 10:59 AM 2/17/2011, you wrote: > >Thanks Bob...that helps. > >Can you comment on use of the 18AWG fuselink in the Pitot Heat.pdf >schematic in place of a 15amp fuse? > >Why wouldn't I just use a 15amp fuse at the bus to protect my wire? The cold resistance of a heated pitot tube is about 1/2 that of the warmed up condition. Here's some data I gathered on a 28v tube. Cut the resistance values by about 1/2 for a 14v tube. [] Further, from the time power is first applied until the tube reaches operating temperature can be 20-60 seconds depending on environmental conditions. A 100w tube will nominally draw 7A at 14v, a 150w tube will be 11A. Inrush during warm up can by 2x those values. The duration of that inrush is protracted compared to a motor or incandescent lamp. Hence the suggestion for a 'robust' circuit protection. You can put in larger fuses too. Suggest 30A for fuse. A 15A circuit breaker would probably stay in . . . but be prepared to upsize if you get nuisance trips. Bob . . . ________________________________________________________________________________
Subject: "Starter Engaged" Warning Light Circuit Refresher
Date: Feb 17, 2011
Bob N., I'm putting a "starter engaged" warning light in my new IFR panel. I simply hooked the incandescent bulb from my B&C alternator "low voltage" warning light between a fused wire that runs from the hot side of the starter contactor and ground. (I now have the standby B&C alternator and will use its controller's "standby alternator on" light in lieu of the low voltage light on the primary alternator controller.) But then I ran across a handwritten sketch that I believe you drew up for this circuit. It has a 470 Ohm - 1 Watt resistor in the wire between the hot side of the starter contactor and the lamp. It also shows a 1N4001 protection diode in parallel with the lamp and ground. It isn't clear from your sketch (and my electrical symbols knowledge is limited) whether the lamp is incandescent or an LED. If incandescent, is the protection diode required? Recommended? If incandescent, is the resistor required? Recommended? If the lamp is an LED, same questions. I can modify the circuit pretty easily right now but I'm towards the end of running all my wires in the plane and will be finishing all the harnesses soon. Thanks, as always, and Best regards, Bob Falstad GlaStar N248BF ________________________________________________________________________________
Date: Feb 18, 2011
Subject: Re: "Starter Engaged" Warning Light Circuit Refresher
At 10:34 PM 2/17/2011, you wrote: > >Bob N., > >I'm putting a "starter engaged" warning light in my new IFR >panel. I simply hooked the incandescent bulb from my B&C >alternator "low voltage" warning light between a fused wire that >runs from the hot side of the starter contactor and ground. (I now >have the standby B&C alternator and will use its controller's >"standby alternator on" light in lieu of the low voltage light on >the primary alternator controller.) > >But then I ran across a handwritten sketch that I believe you drew >up for this circuit. It has a 470 Ohm - 1 Watt resistor in the wire >between the hot side of the starter contactor and the lamp. It also >shows a 1N4001 protection diode in parallel with the lamp and >ground. It isn't clear from your sketch (and my electrical symbols >knowledge is limited) whether the lamp is incandescent or an LED. This is an incandescent lamp Emacs! This is an Light Emitting Diode Emacs! The resistor used with the LED warning circuit as sketched serves a dual purpose. It protects the wire that runs from starter to lamp by limiting the maximum current that could flow in a faulted wire. At the same time, it SETS the current intended to illuminate the LED. For an incandescent warning light, the resistor is replaced with a fuse and the incandescent lamp is substituted for the LED. No reverse current diode is needed. Bob . . . ________________________________________________________________________________
Date: Feb 18, 2011
Subject: Power for Checking Systems Out on the Ground
At 10:03 AM 2/18/2011, you wrote: >Bob, > >Is there a drawing showing the circuit you describe below? And >values/part no. for the power diode and relay? http://aeroelectric.com/Pictures/Schematics/Line_Powered_Alternator_Emulator.pdf Power supply http://tinyurl.com/4lqfl8p Diode http://tinyurl.com/4cft9g3 http://tinyurl.com/488ztot http://www.bandc.biz/essentialbusdiode-1.aspx Relay http://www.bandc.biz/spdtsealedrelay12v40a.aspx Bob . . . ________________________________________________________________________________
Date: Feb 18, 2011
Bob N., Is the drawing for this circuit in the Aeroelectric archives? I think I'd like to add it to my very bare bones system. Thanks, Rick On Fri, Feb 18, 2011 at 8:54 AM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 10:34 PM 2/17/2011, you wrote: > > > Bob N., > > I'm putting a "starter engaged" warning light in my new IFR panel. I > simply hooked the incandescent bulb from my B&C alternator "low voltage" > warning light between a fused wire that runs from the hot side of the > starter contactor and ground. (I now have the standby B&C alternator and > will use its controller's "standby alternator on" light in lieu of the low > voltage light on the primary alternator controller.) > > But then I ran across a handwritten sketch that I believe you drew up for > this circuit. It has a 470 Ohm - 1 Watt resistor in the wire between the > hot side of the starter contactor and the lamp. It also shows a 1N4001 > protection diode in parallel with the lamp and ground. It isn't clear from > your sketch (and my electrical symbols knowledge is limited) whether the > lamp is incandescent or an LED. > > > This is an incandescent lamp > > [image: Emacs!] > > This is an Light Emitting Diode > > [image: Emacs!] > > The resistor used with the LED warning circuit as > sketched serves a dual purpose. It protects the wire > that runs from starter to lamp by limiting the maximum > current that could flow in a faulted wire. At the same > time, it SETS the current intended to illuminate the > LED. > > For an incandescent warning light, the resistor is > replaced with a fuse and the incandescent lamp is > substituted for the LED. No reverse current diode > is needed. > > > Bob . . . > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Feb 18, 2011
At 05:43 PM 2/18/2011, you wrote: >Bob N., Is the drawing for this circuit in the Aeroelectric >archives? I think I'd like to add it to my very bare bones system. http://aeroelectric.com/Pictures/Schematics/Starter_Engaged_Warning_Lt.pdf >Bob N., > >I'm putting a "starter engaged" warning light in my new IFR >panel. I simply hooked the incandescent bulb from my B&C >alternator "low voltage" warning light between a fused wire that >runs from the hot side of the starter contactor and ground. (I now >have the standby B&C alternator and will use its controller's >"standby alternator on" light in lieu of the low voltage light on >the primary alternator controller.) > >But then I ran across a handwritten sketch that I believe you drew >up for this circuit. It has a 470 Ohm - 1 Watt resistor in the wire >between the hot side of the starter contactor and the lamp. It also >shows a 1N4001 protection diode in parallel with the lamp and >ground. It isn't clear from your sketch (and my electrical symbols >knowledge is limited) whether the lamp is incandescent or an LED. This is an incandescent lamp Emacs! This is an Light Emitting Diode Emacs! The resistor used with the LED warning circuit as sketched serves a dual purpose. It protects the wire that runs from starter to lamp by limiting the maximum current that could flow in a faulted wire. At the same time, it SETS the current intended to illuminate the LED. For an incandescent warning light, the resistor is replaced with a fuse and the incandescent lamp is substituted for the LED. No reverse current diode is needed. Bob . . . ________________________________________________________________________________
Subject: LED question
Date: Feb 18, 2011
Bob: is it OK to wire an LED directly (through a resistor in series) to a 14V system? Or should a voltage reduction circuit/device be used. I always though most LEDs were supposed to work on 5V. And 14V would be too much. Noel From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: February 18, 2011 11:25 AM Subject: Re: AeroElectric-List: "Starter Engaged" Warning Light Circuit Refresher At 10:34 PM 2/17/2011, you wrote: Bob N., I'm putting a "starter engaged" warning light in my new IFR panel. I simply hooked the incandescent bulb from my B&C alternator "low voltage" warning light between a fused wire that runs from the hot side of the starter contactor and ground. (I now have the standby B&C alternator and will use its controller's "standby alternator on" light in lieu of the low voltage light on the primary alternator controller.) But then I ran across a handwritten sketch that I believe you drew up for this circuit. It has a 470 Ohm - 1 Watt resistor in the wire between the hot side of the starter contactor and the lamp. It also shows a 1N4001 protection diode in parallel with the lamp and ground. It isn't clear from your sketch (and my electrical symbols knowledge is limited) whether the lamp is incandescent or an LED. This is an incandescent lamp Emacs! This is an Light Emitting Diode Emacs! The resistor used with the LED warning circuit as sketched serves a dual purpose. It protects the wire that runs from starter to lamp by limiting the maximum current that could flow in a faulted wire. At the same time, it SETS the current intended to illuminate the LED. For an incandescent warning light, the resistor is replaced with a fuse and the incandescent lamp is substituted for the LED. No reverse current diode is needed. Bob . . . ________________________________________________________________________________
Date: Feb 18, 2011
Subject: Re: LED question
At 06:20 PM 2/18/2011, you wrote: >Bob: is it OK to wire an LED directly (through a resistor in series) >to a 14V system? Or should a voltage reduction circuit/device be >used. I always though most LEDs were supposed to work on 5V. And >14V would be too much. LED's are CURRENT driven devices. They do drop 2-3 volts across the device while illuminated (depending on color) but they can be BIASED up to run at ANY voltage greater than 3 volts by selection of the series resistor . . . which is the purpose of the 470 ohm resistor in the sketch. With 9-12v applied to the starter and 2v dropped across the LED leaves 7 to 10 volts drop across the 470 ohm resistor. This translates to an LED operating current on the order of (7/470) 15 to (10/470) 21 milliampers. Bob . . . ________________________________________________________________________________
Subject: Looking for Cool (Digital) Ammeter
Date: Feb 18, 2011
Group, Here's what I want: I want to mimic the good old zero-center ammeter but in a digital format. 1. digital readout of current in the center with bar graphs to the left and right indicating the magnitude of the charge or discharge. 2. could be LED or LCD 3. each segment of the bar graph would represent say, 5 amps 4. Instrument face - no more than 3 in. wide by 1.5 in. tall 5. scale +- 60 amps, external shunt, 12v power 6. self dimming Artwork (the equal sign indicates lit segments): ---------- 0 ---------- ---------- 10 ==----- -----==== -20 ---------- I've googled a bit but haven't seen anything like this. Have you? TIA ________________________________________________________________________________
Date: Feb 18, 2011
Subject: Corvair wiring
Group, I'm new here and seeking some help for my Corvair powered airplane. Attache d is a diagram that began as the Z-9 drawing to which I've made mostly dele tions. The fuel pump circuits have been deleted as I'm using a gravity feed system.- You will also note the elimination of a fuse for the secondary ignition cir cuit. William Wynn recommends that there be no fuses, breakers, ect in the ignition wiring. I do show a 7A in the primary ignition circuit (that may n eed to be increased but I don't have that spec as yet). Could I also get some comments on the battery contactor? I know some say it isn't needed and that a good master switch can handle all of the amps that the system will need. The Dynamo is 20A and the main fuse is 30A. Any suggested changes and the reasons for the changes are appreciated. Plea se be aware that I'm not the sharpest pencil in the box when it comes to el ectrical wiring so your patience and elementary type answers are much appre ciated. -8~) Thanks in advance for all your help. Dale-=0A=0A=0A ________________________________________________________________________________
Date: Feb 19, 2011
Subject: Re: First Start Alternator Woes
At 05:42 AM 2/19/2011, you wrote: >Thanks Bob. > >This morning, I got the ALT to come on line. I connected up two >30Amp blade fuses in parallel on a fully charged battery and voila, >14.5 volts on the BUS. > >Is it possible the drained battery was pulling more AMPs than the >ANL40 and 20AMP fuse could handle? Sure. But I'm mystified as to why the ANL40 got into trouble. Here's the spec sheet on ANL current limiters: http://aeroelectric.com/Mfgr_Data/Fuses_and_Current_Limiters/Bussman/ANL_Specs.pdf Note that these are VERY ROBUST protective devices intended to carry rated currents + overloads for protracted periods of time. I.e. these are not intended to be fast acting fuses. They're intended to clear HARD faults in power distribution systems. My best guess is that your 'ANL40' may have been a poorly crafted clone that behaved more like a fuse than a current limiter. Get a 'real' ANL of any current rating from 40 to 60 an you'll probably fix the problem. If you can't find a qualified ANL, consider an automotive in-line fuse holder for the MAX series of plastic fuses. http://aeroelectric.com/Mfgr_Data/Fuses_and_Current_Limiters/Bussman/MAXI_Specs.pdf http://aeroelectric.com/Pictures/Fuses/Fuse_Holders/MaxiFuse_Holder.jpg Install a MAX70 or MAX80 fuse in the holder. I charged of in the direction of 'failed diodes' assuming that your 'anl' fuses were performing to specs. But your question is right on point. A 60A amp alternator charging a dead battery will go flat-out and quite often will trip a 60A breaker. My assumption was out in the weeds. http://www.aeroelectric.com/articles/anl/anlvsjjs.html http://www.aeroelectric.com/articles/never_again.html The 60A breaker on the B-lead of 60A alternators in tens of thousands of GA aircraft are DESIGNED to nuisance trip under precisely the conditions you hypothesized. Get the right b-lead protection installed and I think you're good to go. By the the way, paralleled fuses is a useful experiment but not a permanent fix. Bob . . . >Subject: Re: Fwd: First Start Alternator Woes > >At 06:34 PM 2/18/2011, you wrote: > >Dear Bob, > > > >I did a first start of my RV7 EI-EEO last weekend and the alternator > >did not come on line. > > > >I have an L-60 and LR3 regulator from B&C. Wiring diagram attached. > > > >On working through B&Cs LR3 troubleshooting all voltages looked > >good, then checked the Field connector. Connectors were pushed back. > >Great we found the problem. No joy. Then went through all the checks > >again. The ANL40 that I have installed was blown. We put a blade > >fuse holder with a 20Amp fuse in its place. Fired her up, switched > >on the Alt field (no electrics on expect for the EFIS) and the 20Amp > >fuse blew almost immediately. > > > >What are the modes that could produce this behaviour? Would a 20AMP > >fuse always blow? I see now that the ANL40 should have been a 60ANL, > >but why would the ANL40, with such low loads. If the battery was > >low, would that be the reason. > > The only thing that will blow an ANL > b-lead fuse is shorted diodes in the > alternator. A normally working alternator > cannot open its own b-lead protection. Bob . . . ________________________________________________________________________________
Date: Feb 19, 2011
_http://www.aircraftextras.com/AG6.htm_ (http://www.aircraftextras.com/AG6.htm) is similar. ________________________________________________________________________________
Date: Feb 19, 2011
Thanks for the link. Not really what I had in mind but I had forgotten about Aircraft Extras. _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of CardinalNSB(at)aol.com Sent: Saturday, February 19, 2011 08:20 Subject: AeroElectric-List: Looking for Cool (Digital) Ammeter http://www.aircraftextras.com/AG6.htm is similar. ________________________________________________________________________________
Subject: Voltage Regulator Problem
Date: Feb 19, 2011
I have a 912ULS with the Ducati regulator wired into the Z16 diagram that I have been flying for three years. Today on run-up I noted low voltage ( -------- Frank Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331577#331577 ________________________________________________________________________________
Date: Feb 20, 2011
Subject: Ramsey UHF Counter for Sale
This one-owner Ramsey CT-90 UHF counter with high accuracy/stability time base option has become surplus to my needs. It has been listed on Ebay at: http://tinyurl.com/6dyy753 This will directly display the transmitter's center frequency for both handhelds and panel mounted radios. It's also a rough field strength test for a transmitted signal. Might be a good tool for an EAA chapter to have for loan to members. Bob . . . ________________________________________________________________________________
Subject: Re: AC ground prong question
Date: Feb 20, 2011
Here is website that gives the voltage and frequency of countries around the world: http://users.telenet.be/worldstandards/electricity.htm Half of Japan has 50hz and half has 60hz. Although Japan's 50hz and 100 volt power is different from the USA, it is similar enough to operate most U.S. appliances. However, there may be some sensitive devices that will not work. The person who suggested that Japan could have two phase power is completely wrong. Two phase power is very rare and would require more than two wires. I would NOT cut off the grounding prong from a cord plug. Doing so could create a shock hazard in certain situations. Some sensitive electronic devices will malfunction without being grounded. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331606#331606 ________________________________________________________________________________
Subject: Re: Voltage Regulator Problem
Date: Feb 20, 2011
Let me try sending again--only part of note came through on first try. I have a 912ULS with the Ducati regulator wired into the Z16 diagram that I have been flying for three years. Today on run-up I noted low voltage (under 11 volts) in the Grand Rapid EIS & the Dynon EFIS displays, regardless of RPM. Normally I get 13.1 volts indicated with load. With Master off & engine not running the yellow dynamo wires feeding the regulator show continuity with no resistance. I am thinking there should be some resistance--am I correct or is the reading OK? At fast idle (2400 RPM) the yellow wires indicate 18 volts AC and correspondingly increases with increasing RPM. The regulator output B+ terminal reads 8.5 volts DC--I believe I should expect 14 v DC. The system voltmeter reads about 11 volts with minimal load. Battery was 12.5 v. I traded out the regulator with one that I was told was good. Very similar results (8.3 volts output). I assume both regulators are faulty??? Any suggestions to further trouble shoot? If I replace the regulator I'm considering the Key West. Question about integrating into the Z16 wiring scheme. I assume the + & - input terminals are connected to the yellow wires from the dynamo. Not sure how to hook-up the + & - output terminals. Can anyone help me with that? Thanks much -------- Frank Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331608#331608 ________________________________________________________________________________
Subject: Re: Permanent Magnet Alternators - Over Voltage Protection
Date: Feb 20, 2011
Bob, I intend to build an over-voltage circuit for my Rotax powered RV-12. I found a couple of designs on your website: http://www.aeroelectric.com/DIY/DIY_Crowbar_OVP_F.pdf and http://www.aeroelectric.com/Catalog/AEC/9003/CbOV-14_Installation_A.pdf I like the latter circuit due to its fewer parts count. Unfortunately, the MBS4991 Silicon Bilateral Switch is no longer available. Question: Can I substitute a zener (8.7 or 9 volt) diode for the MBS4991? I did find a replacement for the MBS4991 at Mouser: the NTE6403 although it is relatively expensive at $8. I am not sure how to connect it because your schematic only shows 2 of the 3 leads connected. Question: Do the Gate and the A1 terminal of the bilateral switch connect to the pot? Thanks for your help. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331611#331611 ________________________________________________________________________________
Date: Feb 20, 2011
> who could confirm whether or not they agree that the 505 seems suitable as a generic PMA OV device Mark, I agree with your thoughts on this. But I have no experience with the B&C 505-1 to back up my opinion. You could build your own over-voltage protection using one of Bob's schematics mentioned in my post above. Bob sells over-voltage protection for $30 on his website: http://www.aeroelectric.com/Catalog/AECcatalog.html If you go to there and scroll down and click on CBOV-14, the link takes you here: http://www.aeroelectric.com/Catalog/AEC/9003/CbOV-14_Installation_A.pdf I believe the aircraft schematic at the bottom of the PDF will work for a permanent magnet alternator. I am sure that someone will correct me if I am wrong. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331613#331613 ________________________________________________________________________________
Date: Feb 20, 2011
Dear Lincoln (and Joe) Joe is right. I actually designed devices to operate worldwide, and I can tell you Brazil is the worst. The voltage has been known to be from 90-250 from any outlet type! Intermittent, too! Grounds? fahgedaboutit...but it is rapidly improving. The world seems to be "harmonizing" on 230V 50 Hz. But to answer some of your puzzle: The neutral conductor in US systems is the white wire (the larger blade). Black is higher voltage, measured against white or ground. The green wire and the U-ground is attached to the white at the main transformer, but the green is also attached to any metal "likely to be energized in a fault condition." So you see, the ground and white wire are both "neutral" in a sense, but the green ground is for safety. If you are plugging in a device that has "no metal likely to become energized in a fault condition", and you stay out of the water, then you are good to go with only two prongs. Since this condition is usually hard to know with 100% certainly, three is always a better choice. But be aware: Worldwide 230 VAC 50 Hz outlets do not have the neutral and ground connected anywhere. For additional credit: Q: Should the "face" on the US plug be installed right-side up or upside-down? A: The socket should be installed so that upon the inadvertent extraction of the plug (getting yanked out), The U-ground connection is the last prong to be disconnected. This usually means that plugs near the floor should have right-side-up faces, plugs way up high should have upside down faces. Cool huh? Also, be aware that everyone makes mistakes. In the Southwest, Mexican construction plumbers work for peanuts. "C" in Mexico is "Caliente" (hot) and an "F" looks like an "H" if you are illiterate. I have seen branded, UL, CSA, ETL approved, where grievous errors were not caught. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331614#331614 Attachments: http://forums.matronics.com//files/dabbling_with_electricity_357.pdf ________________________________________________________________________________
Date: Feb 20, 2011
Protection At 10:54 AM 2/20/2011, you wrote: > > > > who could confirm whether or not they agree that the 505 seems > suitable as a generic PMA OV device correct Bob . . . ________________________________________________________________________________
Date: Feb 20, 2011
Protection At 10:20 AM 2/20/2011, you wrote: > >Bob, >I intend to build an over-voltage circuit for my Rotax powered >RV-12. I found a couple of designs on your website: >http://www.aeroelectric.com/DIY/DIY_Crowbar_OVP_F.pdf >and >http://www.aeroelectric.com/Catalog/AEC/9003/CbOV-14_Installation_A.pdf >I like the latter circuit due to its fewer parts >count. Unfortunately, the MBS4991 Silicon Bilateral Switch is no >longer available. Yes, the two-transistor emulation of the MBS4991 was crafted after the former part went obsolete. >Question: Can I substitute a zener (8.7 or 9 volt) diode for the MBS4991? No. If you study both the specs for the 4991 and noodle out the behavior of the PNP/NPN transistor pair, you'll deduce that the device is both voltage sensing AND avalanche-trigger that dumps the energy stored on the time delay capacitor into the gate of the crowbar SCR. >I did find a replacement for the MBS4991 at Mouser: the NTE6403 >although it is relatively expensive at $8. I am not sure how to >connect it because your schematic only shows 2 of the 3 leads connected. If it's a bilateral device, it doesn't matter which two outside leads are connected where. The center lead (gate) is cut off. There is a new device (at least new to me!) offered by Digikey. See: http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=835-1126-1-ND It's typically an 8v device so you might have to diddle the voltage divider values a tad to get a trip point well inside the pot travel. The temperature drift numbers look good. As you can see, the 2-transistor+zener circuit is a synthesis of 1/2 of the bilateral trigger diode. All the parts are readily available and the circuit as shown has been constructed by many OBAM aircraft builders. Here's a handy test fixture for setting your finished OVM. http://tinyurl.com/4k455p5 The relay+lamp/resistor should draw about 1A when energized. Set the bench supply for 16.3 volts. Adjust the trigger calibration pot on the OV module so that the relay "clicks" about once per second. Bob . . . ________________________________________________________________________________
Date: Feb 20, 2011
At 09:34 AM 2/20/2011, you wrote: > >Let me try sending again--only part of note came through on first try. > > I have a 912ULS with the Ducati regulator wired into the Z16 > diagram that I have been flying for three years. Today on run-up I > noted low voltage (under 11 volts) in the Grand Rapid EIS & the > Dynon EFIS displays, regardless of RPM. Normally I get 13.1 volts > indicated with load. Alternator/regulator is NOT producing power. >With Master off & engine not running the yellow dynamo wires feeding >the regulator show continuity with no resistance. This is a very low resistance . . . less than 1 ohm that you cannot measure without special attention to test equipment - like the low ohms adapter on my website. > I am thinking there should be some resistance--am I correct or is > the reading OK? If your plain vanilla volt-ohmeter shows continuity, the windings are probably fine. Are they discolored, i.e. insulation very dark and/or cracked? >At fast idle (2400 RPM) the yellow wires indicate 18 volts AC and >correspondingly increases with increasing RPM. That's good . . . >The regulator output B+ terminal reads 8.5 volts DC--I believe I >should expect 14 v DC. The system voltmeter reads about 11 volts >with minimal load. Battery was 12.5 v. I traded out the regulator >with one that I was told was good. Very similar results (8.3 volts >output). I assume both regulators are faulty??? Any suggestions to >further trouble shoot? Is your control relay closing? Try bypassing the OV/control system and connect your R/R output wire directly to the system (unplug fat wires from relay and connect them together). Then do your voltage checks. >If I replace the regulator I'm considering the Key West. Question >about integrating into the Z16 wiring scheme. I assume the + & - >input terminals are connected to the yellow wires from the dynamo. >Not sure how to hook-up the + & - output terminals. Can anyone help >me with that? Do you have the Key West installation instructions? If it is this device: Emacs! The terminal markings are pretty definitive. AC input is from your alternator winding, NEG(-) goes to ground, POS(+) would go to the control relay. But check your control relay closure first. It seems unlikely that you would suffer TWO Rectifier/Regulator failures. Bob . . . ________________________________________________________________________________
Subject: Re: Honeywell Rocker lamp wiring
Date: Feb 20, 2011
Bill, Thanks for your thoughts on wiring the AML series switches. After discussions with Perehelion, I've worked out a scheme to run the switch lamps at 12v (using http://www.semicon.panasonic.co.jp/ds4/AN7712SP_BEB_discon.pdf) for dimming, but when the switch is ON, the lamp gets the bus voltage of 13.5v making them brighter than the dimmer circuit. I may have to adjust the max voltage of the dimmer circuit to get the bingo brightness differential. Or this whole idea may end up in the trash and I simplify to just hooking the dimmer directly to the lamps like you have done. John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331625#331625 ________________________________________________________________________________
Date: Feb 20, 2011
Bob Thanks for your input. As you suggested I removed the relay "C" input and jumped it across to the "A" lead. The reading from the regulator B+ lead was initially about 11 volts with the engine running but steadily decreased to yesterday's reading of about 8.4 volts. Reading was not influenced by increase in RPM. I reconnected to the relay "C" terminal and took a reading from the "C" terminal to the starter relay to check the circuit through the relay & across the fuse link and got a reading of 8.3 volts with the master on ALT. Battery still above 12 v. Any other suggestions? -------- Frank Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331639#331639 ________________________________________________________________________________
Date: Feb 20, 2011
I read about the Silicon Bilateral Switch on the internet today. Evidently it is not necessary to connect the gate because the SBS will start conducting when the voltage reaches a certain value without the gate connected. I am still wondering if a zener diode could be used instead of the SBS. If not, it would be interesting to know what the disadvantages of the zener diode are, or if it would even work at all. Thanks for any advice. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331658#331658 ________________________________________________________________________________
Date: Feb 21, 2011
Protection At 07:31 PM 2/20/2011, you wrote: > >I read about the Silicon Bilateral Switch on the internet >today. Evidently it is not necessary to connect the gate because >the SBS will start conducting when the voltage reaches a certain >value without the gate connected. > I am still wondering if a zener diode could be used instead of > the SBS. If not, it would be interesting to know what the > disadvantages of the zener diode are, or if it would even work at all. It MIGHT work sort of if you used a sensitive gate SCR but that offers a potential for other problems like nuisance tripping due to noises on the bus. The non-sensitive crowbar SCR needs a swift kick in the gate to insure a good trigger at all temperatures. The simple zener has a soft conduction 'knee' in it's V/I curve so is a poor voltage reference at the threshold of conduction. Further, the current that can be delivered to the gate of the SCR due to zener conduction is limited by the source impedance of the calibration voltage divider. The diac has a more predictable trigger voltage which produces an avalanche conduction mode that dumps the time delay capacitor into the gate of the SCR. That pulse is hundreds of mA to over 1A. This same characteristic is also desired for the triggering of triacs in dimmers . . . the #1 commercial use for diacs of any voltage. See: http://aeroelectric.com/Pictures/Products/9003_B&C/OVM_14_Prototype.jpg This was the first crowbar OVM we offered many moons ago. This configuration was modified early in the production experience to add the 10 ohm gate to cathode resistor to negate nuisance tripping. The diac in this version visible on the left was a really cool part. An SD10 as I recall with very good tolerances on a 10v trip calibration. This part went obsolete and we went to the MBS4991. That part went obsolete and I synthesized the diac functionality with the pnp/npn pair. At this time, I think B&C has both the diac and transistor versions in production on the fleet of products. They made a life-time buy on the MBX4991. I bought a couple hundred too so that I can support my own production though it's probable market life. It is similar to this configuration http://aeroelectric.com/Pictures/Products/9003_B&C/OVM-14_A.jpg http://aeroelectric.com/Pictures/Products/9003_B&C/OVM-14_B.jpg except that we now offer a 15 turn calibration potentiometer that can be accessed in the field. This is why the DIY project features the transistor pair. But it appears that the new kid on the block from Digikey would allow one to fabricate the diac version. Your choice. Bob . . . ________________________________________________________________________________
Date: Feb 21, 2011
At 04:44 PM 2/20/2011, you wrote: > >Bob >Thanks for your input. >As you suggested I removed the relay "C" input and jumped it across >to the "A" lead. The reading from the regulator B+ lead was >initially about 11 volts with the engine running but steadily >decreased to yesterday's reading of about 8.4 volts. Reading was >not influenced by increase in RPM. > >I reconnected to the relay "C" terminal and took a reading from the >"C" terminal to the starter relay to check the circuit through the >relay & across the fuse link and got a reading of 8.3 volts with the >master on ALT. Battery still above 12 v. It's not clear that you understood my suggestion. I intended that you bypass the control relay entirely. If you're using Z-16 of more than 3 years ago, then the relay is probably in the DC output wire from the rectifier-regulator. The current version uses the control relay to switch AC power out of the alternator. Unplug both the heavy gage wires from the control relay and connect them together thus eliminating the relay as a means by which the alternator can be disconnected from the system. Then see how things perform. The point of this experiment is to eliminate the relay and its control wiring as potential cause for your observed malfunction. While the relay is bypassed and you're making other voltage measurements, see what voltage you read on the relay's skinny wires too with the battery/alternator control switch full up. One should be seeing battery voltage, the other should be zero volts. Bob . . . ________________________________________________________________________________
Date: Feb 21, 2011
Bob Thanks for clarifying. With relay circumvented (fat wires disconnected from relay but joined together), B+ = 11.6v steady; EIS steady 10.8v. No change to either reading with RPM increase. Re the "little wires", neither had voltage with master on ALT. Reconnected relay and retested, B+ = 1.9v at start and slowly increased to 4v after 10 min engine run. Same reading immediately after engine off. EIS showed 10.8v. No change to either reading with RPM increase. Further suggestions/assessment? -------- Frank Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331739#331739 ________________________________________________________________________________
Date: Feb 21, 2011
At 11:51 AM 2/21/2011, you wrote: > >Bob >Thanks for clarifying. > >With relay circumvented (fat wires disconnected from relay but >joined together), B+ = 11.6v steady; EIS steady 10.8v. No change to >either reading with RPM increase. Okay, this says the rectifier/regulator is bad >Re the "little wires", neither had voltage with master on ALT. ????? Double failure ???? If there's no power coming from the alternator switch, then you're certainly not going to get the alternator on line. Trace the power flow from the bus through the ALT switch to the relay. Bob . . . ________________________________________________________________________________
Date: Feb 21, 2011
You're welcome Jon. I'm attaching an Excel file that has both my switch and indicator layout (I don't know if that will post properly on the list so I'm it directly to you too.) My thinking at the time went something like this: The first block of 3 switches handles the 2 busses and the buss crossfeed switch. I assume I will normally fly with first 2 switches on and the xfeed off so I have a backlit indicator that lights when I turn it on. The 2nd block of 4 switches include fuel boost and lights. Again, since the fuel boost is normally off in flight, I added a lit indicator for it. The light switches just need to be set and ignored so no indicators for those other than switch position. The next 2 switches are for AP navigation source switching and flaps. Since there really isn't an off or on, no indicator other than switch position. I color coded the indicators based on the function. Oil Pressure and Door are red no-go items, Master Warn (GRT) and Low voltage are yellow warning items, Buss Xfeed and Fuel boost are green for normal operation indications. I have panel dimmers on my panel on my Maule but the switches are unlit rockers. I end up keeping everything as dim as possible but when I use a switch, I either do it by memory or I have to turn up the dimmer on the post lights so I can see the switch. That was my original reason for going with the backlit Honeywell's. Two thoughts to consider: - for night flight, you may not want a light to go bright and stay that way. The point of dimming them is to improve your night vision so outside of something you want a warning for, you may not want an undimmed bright light that stays lit. - I'm using LEDs in my switches and indicators. Not sure if that's standard but I think there is an incandescent option. I'm thinking the LEDs will last forever. In either case, I'm not sure if the dimmer and voltage implications are different for each type. Sounds like you are enjoying the electrical stuff as much as I did. Have fun. Can't wait to fly mine. Bill "back to masking and painting" Watson On 2/20/2011 1:24 PM, jonlaury wrote: > --> AeroElectric-List message posted by: "jonlaury" > > Bill, > Thanks for your thoughts on wiring the AML series switches. After discussions with Perehelion, I've worked out a scheme to run the switch lamps at 12v (using http://www.semicon.panasonic.co.jp/ds4/AN7712SP_BEB_discon.pdf) for dimming, but when the switch is ON, the lamp gets the bus voltage of 13.5v making them brighter than the dimmer circuit. > I may have to adjust the max voltage of the dimmer circuit to get the bingo brightness differential. Or this whole idea may end up in the trash and I simplify to just hooking the dimmer directly to the lamps like you have done. > > John > ________________________________________________________________________________
Subject: Video Inspection Tool
Date: Feb 21, 2011
Deal Extreme has a video Inspection Tool worth considering. See: http://www.dealextreme.com/p/2-4-lcd-display-inspection-tube-snake-camera-borescope-ntsc-32414 Hey, free shipping. Amazing. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331768#331768 ________________________________________________________________________________
Date: Feb 21, 2011
> There is a new device (at least new to me!) offered > by Digikey. See: http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=835-1126-1-ND > Bob, I checked out that bilateral switch from Digikey. Unfortunately it is not stocked and minimum order is 2500 pieces. I did find some other interesting devices that could be used in an O.V. protection circuit. http://www.fairchildsemi.com/ds/LM/LM431B.pdf used in this circuit: http://en.wikipedia.org/wiki/File:Crowbar_Circuit.jpg And here is a 16.1 volt zener diode that might work in your circuit without voltage dividing resisters: http://www.mouser.com/Search/ProductDetail.aspx?R=NZX16B,133virtualkey66800000virtualkey771-NZX16B,133 It might be fun playing around with some of these components. On the other hand, it is hard to beat the proven circuit that you have provided. Thanks for your advice. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331769#331769 ________________________________________________________________________________
Protection
Date: Feb 21, 2011
I've built my own overvoltage crowbar with the MC3423 which is a dedicated chip for the purpose - very easy to use and cheap enough. See http://tailwindbuild.blogspot.com/2009/11/15th-november-2009-overvoltage-cro wbar.html for details Best regards Peter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of user9253 Sent: 21 February 2011 19:37 Subject: AeroElectric-List: Re: Permanent Magnet Alternators - Over Voltage Protection > There is a new device (at least new to me!) offered > by Digikey. See: http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=835-1126-1- ND > Bob, I checked out that bilateral switch from Digikey. Unfortunately it is not stocked and minimum order is 2500 pieces. I did find some other interesting devices that could be used in an O.V. protection circuit. http://www.fairchildsemi.com/ds/LM/LM431B.pdf used in this circuit: http://en.wikipedia.org/wiki/File:Crowbar_Circuit.jpg And here is a 16.1 volt zener diode that might work in your circuit without voltage dividing resisters: http://www.mouser.com/Search/ProductDetail.aspx?R=NZX16B,133virtualkey668000 00virtualkey771-NZX16B,133 It might be fun playing around with some of these components. On the other hand, it is hard to beat the proven circuit that you have provided. Thanks for your advice. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331769#331769 ________________________________________________________________________________
Date: Feb 21, 2011
Bob It is with a very bright red face I offer an apology for the time you've contributed to my issue. After sending the last note I did as your note suggested--trace the power from the master switch. After taking the panel out and checking for connections & current flow I ended up at the circuit breaker. Guess what? Yes, it had tripped. After resetting the breaker one of the relay "little wires" showed battery current as you indicated and the regulator B+ showed 14v. So sorry for not checking the breaker first! Now I'll have to be on the lookout for whatever caused the breaker to trip the first time. For me it's been very educational and I thank you. -------- Frank Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331772#331772 ________________________________________________________________________________
Date: Feb 21, 2011
Subject: DIY Over Voltage Protection
Bob, I checked out that bilateral switch from Digikey. Unfortunately it is not stocked and minimum order is 2500 pieces. Hmmmm . . . my bad. I jumped on the full range of quanity pricing starting with "1" but missed the fact that there were none in stock. I did find some other interesting devices that could be used in an O.V. protection circuit. http://www.fairchildsemi.com/ds/LM/LM431B.pdf used in this circuit: http://en.wikipedia.org/wiki/File:Crowbar_Circuit.jpg Emacs! This is a very rudimentary crowbar ov protection circuit. It has no provisions for time-delay from onset of ov condition. The LM431 is an integrated circuit voltage regulator that can function as a zener or, as shown above, a comparator. Further, by adding a couple of resistors, you can calibrate its switching point. Out of the box calibration point for the LM431 is 2.5 volts. So if you're wanting a 16.3 trip point, you can put 2.49K, 1% in R2 and 13.7K, 1% in R1. You'd need a capacitor across R2 to establish the cited time delay. The problem to anticipate is setting a value for the resistor from Gate to T1 of the triac. For best noise immunity, it needs to be low, like 10 ohms or so. Since the LM431 can't deliver the high current pulse offered by the legacy avalanche techniques, you may find that optimum resistance for a good trigger performance is too high for noise immunity. When I run out of MBS4991, and assuming I'm still offering crowbar ov modules, I'll look at a variation using the LM431. And here is a 16.1 volt zener diode that might work in your circuit without voltage dividing resisters: http://www.mouser.com/Search/ProductDetail.aspx?R=NZX16B,133virtualkey66800000virtualkey771-NZX16B,133 If you can get it to hold tolerance over temperature range. It's probably a 5% device to start with. If you hung it from gate to ground, you'd have to ADD the trigger voltage to the zener value to deduce the trip point. Both gate and zener voltage wobble with temperature pretty bad. The schematic shown above (as modified) is probably the best experiment to explore. It might be fun playing around with some of these components. Sure . . . On the other hand, it is hard to beat the proven circuit that you have provided. The 'proven' circuits HAVE been field tested over decades of experience and thousands of delivered products. But virtually all received some degree of optimization early in their service histories. The solid state crowbar system proved a practical for replacing electro-mechanical relays. But history has repeatedly demonstrated that every idea is subject to assault from new technologies, processes and design goals. Suggest you brass-board your experiments and give them a try on the bench. You can do some pretty good tests on effects of temperature using your freezer. Bob . . . ________________________________________________________________________________
Date: Feb 21, 2011
Subject: Re: Video Inspection Tool
I got one at Harbor Freight built to specs for about $89. Works great. Also, the monitor is actually removable and has video outputs so you can tie it into a large screen and/or a recording device. If you look in the archives, we had a long thread about it a while back. David M. Eric M. Jones wrote: > --> AeroElectric-List message posted by: "Eric M. Jones" > > Deal Extreme has a video Inspection Tool worth considering. > See: http://www.dealextreme.com/p/2-4-lcd-display-inspection-tube-snake-camera-borescope-ntsc-32414 > > Hey, free shipping. Amazing. > > -------- > Eric M. Jones > www.PerihelionDesign.com > 113 Brentwood Drive > Southbridge, MA 01550 > (508) 764-2072 > emjones(at)charter.net > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=331768#331768 > > > -- If you're an American, just say NO to the Obamanation, to socialism, and get rid of Soros. ________________________________________________________________________________
Date: Feb 21, 2011
At 03:53 PM 2/21/2011, you wrote: Bob It is with a very bright red face I offer an apology for the time you've contributed to my issue. After sending the last note I did as your note suggested--trace the power from the master switch. After taking the panel out and checking for connections & current flow I ended up at the circuit breaker. Guess what? Yes, it had tripped. Hmmm . . . something to add to your future LO VOLTS checklist. Do you have a low volts warning light? Do you have any notion of when the alternator was lost and what was happening at the time? After resetting the breaker one of the relay "little wires" showed battery current as you indicated and the regulator B+ showed 14v. So sorry for not checking the breaker first! Now I'll have to be on the lookout for whatever caused the breaker to trip the first time. The legacy ovm designs are 99.9% resistant to transient events on the system . . . but the reason we recommend a breaker as opposed to a fuse is that you can reset it ONE TIME after an OV trip just to make sure it's a real OV condition and not a nuisance trip. For me it's been very educational and I thank you. Your welcome. Nobody ever promised us that education was 'cheap' . . . I've had some expensive epiphanies over the years. Fortunately none resulted in badly bent airplanes or bodily harm that wouldn't heal. Lessons hard won at the expense of $time$ and frustration are those which are best retained. The biggest upside of this exchange is that your particular set of conditions COULD have been root cause for your own (or somebody else's) "dark-n-stormy-night" story. By discussing it here in embarrassing detail means that interested readers can harvest benefits that few stories in the flying rags can offer. Thank you for sharing . . . Bob . . . ________________________________________________________________________________
Date: Feb 21, 2011
As these things go, I think you'll find this one is a much better unit. Smaller head (10 mm) longer reach (90 cm) higher resolutions. Soon they will be perfect and free. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331778#331778 ________________________________________________________________________________
Date: Feb 22, 2011
Subject: DIY CBOVM: variations on a theme
> I am still wondering if a zener diode could be used instead of > the SBS. If not, it would be interesting to know what the > disadvantages of the zener diode are, or if it would even work at all. >Thanks for any advice. >Joe Joe, Feeling adventuresome? I pondered the idea of exploiting the LM431's precise voltage set point with a design goal of eliminating the potentiometer and the post assembly calibration. Here's what I came up with. Emacs! The parts count is unchanged but it should be calibrated as soon as the last solder joint is cool. Temperature stability should be as good or better than any previous versions. Bob . . . ________________________________________________________________________________
From: " Dr. Andrew Elliott" <a.s.elliott(at)cox.net>
Subject: Trim tab slaving?
Date: Feb 22, 2011
Gang: On my 601XL, the elevator trim tab is not effective enough to trim out all control forces on a full-flap final when the CG is in the front half of the allowed range. Although the remaining elevator forces are light, I would like to be able to trim them away. The trim tab is inset on one side of the elevator, and takes the entire width, minus about 20 mm on each end. Servo is RAC One option would be to add another trim tab to the other side of the elevator. But to do that I would need some way to slave the two sides together. Does anyone have an idea about how to do that electronically without very high cost, or perhaps some way already exists and I haven't found it? (The elevator design doesn't allow for a simple mechanical connection.) Another option, of course, would to be to increase the size of the trim tab, either making it full width (probably not too effective - delta area <10%), or extending it aft 20-25 mm (probably would work, but ugly), or both. I might go that way, but thought I'd ask about the saving first. Thanks, Andy ------------------------ Andy Elliott N601GE/Z601XL/TD/Corvair 298 hrs since 11/08 ________________________________________________________________________________
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Date: Feb 22, 2011
Subject: Re: Trim tab slaving?
My RV has tabs on both elevators, each cable-driven by a single servo. I think it would be needlessly complicated to get two servos married together at all times. If you didn't do that, you'd have to have some scheme to make sure they were at least able to be manually coordinated. I'd recommend extending the existing tab. You might not need as much as you think. We regularly just tape a tab on temporarily until we figure out what size to use. Dave Saylor AirCrafters 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell On Tue, Feb 22, 2011 at 7:09 AM, Dr. Andrew Elliott wrote: > Gang: > > > On my 601XL, the elevator trim tab is not effective enough to trim out all > control forces on a full-flap final when the CG is in the front half of the > allowed range. Although the remaining elevator forces are light, I would > like to be able to trim them away. The trim tab is inset on one side of the > elevator, and takes the entire width, minus about 20 mm on each end. Servo > is RAC > > > One option would be to add another trim tab to the other side of the > elevator. But to do that I would need some way to slave the two sides > together. Does anyone have an idea about how to do that electronically > without very high cost, or perhaps some way already exists and I haven't > found it? (The elevator design doesn't allow for a simple mechanical > connection.) > > > Another option, of course, would to be to increase the size of the trim tab, > either making it full width (probably not too effective - delta area <10%), > or extending it aft 20-25 mm (probably would work, but ugly), or both. I > might go that way, but thought I'd ask about the saving first. > > > Thanks, > > Andy > > > ------------------------ > > Andy Elliott > > N601GE/Z601XL/TD/Corvair > > 298 hrs since 11/08 > > ________________________________________________________________________________
From: "ROGER & JEAN CURTIS" <mrspudandcompany(at)verizon.net>
Date: Feb 22, 2011
On my 601XL, the elevator trim tab is not effective enough to trim out all control forces on a full-flap final when the CG is in the front half of the allowed range. Although the remaining elevator forces are light, I would like to be able to trim them away. Andy, Can your existing trim tab be adjusted to go slitely farther than it now goes. I.e., can the actuator be adjusted to give a little more downward deflection to the tab. Since you are on the edge of being in trim this might be a solution without any further mods. Roger ________________________________________________________________________________
Date: Feb 22, 2011
Would VGs on the trim tab offer any benefit? Still might be ugly but quick to try. Raymond Julian Kettle River, MN On 02/22/2011 09:09 AM, Dr. Andrew Elliott wrote: > Gang: > > On my 601XL, the elevator trim tab is not effective enough to trim out > all control forces on a full-flap final when the CG is in the front half > of the allowed range. Although the remaining elevator forces are light, > I would like to be able to trim them away. The trim tab is inset on one > side of the elevator, and takes the entire width, minus about 20 mm on > each end. Servo is RAC > > One option would be to add another trim tab to the other side of the > elevator. But to do that I would need some way to slave the two sides > together. Does anyone have an idea about how to do that electronically > without very high cost, or perhaps some way already exists and I haven't > found it? (The elevator design doesn't allow for a simple mechanical > connection.) > > Another option, of course, would to be to increase the size of the trim > tab, either making it full width (probably not too effective - delta > area <10%), or extending it aft 20-25 mm (probably would work, but > ugly), or both. I might go that way, but thought I'd ask about the > saving first. > > Thanks, > > Andy > > ------------------------ > > Andy Elliott > > N601GE/Z601XL/TD/Corvair > > 298 hrs since 11/08 > > * > > > * ________________________________________________________________________________
Date: Feb 22, 2011
Dr. Elliott, Is the up and down movement on your trim tab per your owners manual? You should be able to adjust the push rod, however, I'm sure how yours works. Jim On Tue, Feb 22, 2011 at 9:09 AM, Dr. Andrew Elliott wrote: > Gang: > > > On my 601XL, the elevator trim tab is not effective enough to trim out all > control forces on a full-flap final when the CG is in the front half of the > allowed range. Although the remaining elevator forces are light, I would > like to be able to trim them away. The trim tab is inset on one side of the > elevator, and takes the entire width, minus about 20 mm on each end. Servo > is RAC > > > One option would be to add another trim tab to the other side of the > elevator. But to do that I would need some way to slave the two sides > together. Does anyone have an idea about how to do that electronically > without very high cost, or perhaps some way already exists and I haven't > found it? (The elevator design doesn't allow for a simple mechanical > connection.) > > > Another option, of course, would to be to increase the size of the trim > tab, either making it full width (probably not too effective - delta area > <10%), or extending it aft 20-25 mm (probably would work, but ugly), or > both. I might go that way, but thought I'd ask about the saving first. > > > Thanks, > > Andy > > > ------------------------ > > Andy Elliott > > N601GE/Z601XL/TD/Corvair > > 298 hrs since 11/08 > > > * > > * > > ________________________________________________________________________________
Date: Feb 22, 2011
Take a look at the wickerbill, otherwise known in the U.S. as the Gurney flap. Rick Girard On Tue, Feb 22, 2011 at 9:09 AM, Dr. Andrew Elliott wrote: > Gang: > > > On my 601XL, the elevator trim tab is not effective enough to trim out all > control forces on a full-flap final when the CG is in the front half of the > allowed range. Although the remaining elevator forces are light, I would > like to be able to trim them away. The trim tab is inset on one side of the > elevator, and takes the entire width, minus about 20 mm on each end. Servo > is RAC > > > One option would be to add another trim tab to the other side of the > elevator. But to do that I would need some way to slave the two sides > together. Does anyone have an idea about how to do that electronically > without very high cost, or perhaps some way already exists and I haven't > found it? (The elevator design doesn't allow for a simple mechanical > connection.) > > > Another option, of course, would to be to increase the size of the trim > tab, either making it full width (probably not too effective - delta area > <10%), or extending it aft 20-25 mm (probably would work, but ugly), or > both. I might go that way, but thought I'd ask about the saving first. > > > Thanks, > > Andy > > > ------------------------ > > Andy Elliott > > N601GE/Z601XL/TD/Corvair > > 298 hrs since 11/08 > > > * > > * > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Feb 22, 2011
Good Morning Andy, Have you thought about adding a small angle on the top and bottom of your trim tab? Some control surfaces experience seperation at the trailing edges. One trick that has been used was to add a small angle to the trim tab or, occasionally, the whole surface to increase effectiveness. Supposedly, if the air is separating at that point, the angles create very little additional drag and do a good job of increasing affectivity. That was how Morane-Saulnier solved the problem on their Paris Jet 760. Happy Skies, Old Bob In a message dated 2/22/2011 10:15:39 A.M. Central Standard Time, mrspudandcompany(at)verizon.net writes: On my 601XL, the elevator trim tab is not effective enough to trim out all control forces on a full-flap final when the CG is in the front half of the allowed range. Although the remaining elevator forces are light, I would like to be able to trim them away. Andy, Can your existing trim tab be adjusted to go slitely farther than it now goes. I.e., can the actuator be adjusted to give a little more downward deflection to the tab. Since you are on the edge of being in trim this might be a solution without any further mods. Roger (http://www.matronics.com/Navigator?AeroElectric-List) (http://www.matronics.com/contribution) ________________________________________________________________________________
Date: Feb 22, 2011
Andy, there might be another way, on the Glastar a similar issue exists especially for TD's. Two ways did help, first one was having a tape over the hinge line between HS and Elevator, this did increase effectiveness (not sure the 601 is using hinges?) Then another was to add some vortex generator in front of the tab (lower side) increasing effectiveness of the tab as well. Werner On 22.02.2011 16:09, Dr. Andrew Elliott wrote: > Gang: > > On my 601XL, the elevator trim tab is not effective enough to trim out > all control forces on a full-flap final when the CG is in the front half ________________________________________________________________________________
Date: Feb 22, 2011
A T-strip would most effectively increase the hinge moment of the tab, thus increasing it's effectiveness. Be careful though, messing with hinge-moments on a surface so far away from the elevator hinge line can quickly get you into trouble flutter-style if you don't have some flutter analysis to back it up. (Also, a t-strip on the tab would also increase the hinge moments on the elevator resulting in higher longitudinal pitch forces.) I'd stick with increased tab travel or second tab on the other elevator. On Tue, Feb 22, 2011 at 11:23 AM, rayj wrote: > > Would VGs on the trim tab offer any benefit? Still might be ugly but quick > to try. > > Raymond Julian > Kettle River, MN > > On 02/22/2011 09:09 AM, Dr. Andrew Elliott wrote: > >> Gang: >> >> >> On my 601XL, the elevator trim tab is not effective enough to trim out >> all control forces on a full-flap final when the CG is in the front half >> of the allowed range. Although the remaining elevator forces are light, >> I would like to be able to trim them away. The trim tab is inset on one >> >> side of the elevator, and takes the entire width, minus about 20 mm on >> each end. Servo is RAC >> >> One option would be to add another trim tab to the other side of the >> elevator. But to do that I would need some way to slave the two sides >> together. Does anyone have an idea about how to do that electronically >> without very high cost, or perhaps some way already exists and I haven't >> found it? (The elevator design doesn't allow for a simple mechanical >> connection.) >> >> Another option, of course, would to be to increase the size of the trim >> tab, either making it full width (probably not too effective - delta >> area <10%), or extending it aft 20-25 mm (probably would work, but >> ugly), or both. I might go that way, but thought I'd ask about the >> saving first. >> >> Thanks, >> >> Andy >> >> ------------------------ >> >> Andy Elliott >> >> N601GE/Z601XL/TD/Corvair >> >> 298 hrs since 11/08 >> >> * >> >> >> * >> > > -- Andrew Zachar andrew.d.zachar(at)gmail.com ________________________________________________________________________________
Date: Feb 22, 2011
Subject: a couple questions about Z10/8 diagram
Maybe I missed the answer to this question in the text ... I am unfortunately unable to install a backup power source (SD8, SD20) because of how the engine mount on my RV4 comes across the back of the engine hear the vacuum pump pad. That said, I am planning to install a 7AH backup (brownout?) battery on a tray behind my instrument panel. - I am wondering if I would be OK to install a switch in place of the brownout battery relay? My only reason for this is that I have seen relays fail more often than switches in my automation control field. I could be dissuaded. - I ordered the BandC ebus diode on a heat sink based on an older copy of the 'Connection. Now in 12a I see that a Schottky is mentioned. Any reason to abandon the original diode plan? - I plan to use the same PB/Tyco circuit breakers as Composite Designs uses in their power panels. They have a circuit board that the PIDG terminals on the breakers are connected to. My thought is to use a piece of brass and 'forest of terminals' such as the ground plate BandC sells for power distribution to the breakers. The plate would be insulated from the panel and covered to protect inadvertent shorting by 'falling objects'. Does this sound reasonable? Thank you! Phil ________________________________________________________________________________
Date: Feb 22, 2011
Subject: Shop tip
I had a little cut-n-glue job in the woodshop this morning . . . and had to fill a new dispenser bottle with my favorite wood glue. I occurred to me that builders here on the List might be interested in the following: I've found it useful to have lots of small glue bottles around as opposed to one big one. Further, the bottles used by Elmer's have a handy, narrow tip for precision dispensing. The tip is liquid tight when closed. Every fall before school starts, Walmart has a row of bargain bins stocked with pencil paks, tablets, etc. One bin will contain a bucket load of Elmer's School Glue in these 4 oz bottles. I've paid as little as $.25 for a bottle of glue. Emacs! You can rinse these out and refill with more sophisticated products like glues, lubricants, solvents, etc. The labels can be removed to get a 'clean' bottle but it's pretty labor intensive. Most of my 'recycled' bottles still carry the original labels with a new tape- label wrapped around and re-identified with a Sharpie. Unfortunately, the beginning of the next school year is some time off . . . but perhaps this note to the List will surface in the gray-matter the next time you walk past a row of those pre- school bargain bins. Snatch up a half dozen or so . . . Bob . . . ________________________________________________________________________________
Subject: Circuit emulator - Icircuit
Date: Feb 22, 2011
Hi all, I downloaded an app into my IPad called "icircuit", for $9.99 It is a circuit emulator for the IPad. Since I know nothing about electronics, I thought it might be an interesting way to learn! First problem was that I had to learn how to use the program. In going to the main web site, i found a video demonstrating the app; http://icircuitapp.com/ I also found that the program is based on a set of free programs at; www.falstad.com/circuit/ The whole thing is quite an eye opener into electronics, maybe one of the EE types could comment on this whole deal, does it have a practical use to this group? There is apparently a way to add circuits via email to the IPad version, haven't figured that out yet?! Bob Mitchell L-320 Sent from my iPad ________________________________________________________________________________
Date: Feb 22, 2011
Subject: Re: a couple questions about Z10/8 diagram
At 02:49 PM 2/22/2011, you wrote: >Maybe I missed the answer to this question in the text ... > >I am unfortunately unable to install a backup power source (SD8, >SD20) because of how the engine mount on my RV4 comes across the >back of the engine hear the vacuum pump pad. That said, I am >planning to install a 7AH backup (brownout?) battery on a tray >behind my instrument panel. What equipment are you carrying that drives this decision? >- I am wondering if I would be OK to install a switch in place of >the brownout battery relay? My only reason for this is that I have >seen relays fail more often than switches in my automation control >field. I could be dissuaded. Not here to persuade you of anything . . . but your worry-bucket seems to be carrying some issues. It would be helpful to know more about your equipment list and the reasons that drive installation of a second battery. What failure mode do you perceive that loss of the relay would be a pre-cursor to your own dark-n-stormy-night story? Things FAIL all the time in airplanes. The best design goals call for crafting systems that are failure tolerant. >- I ordered the BandC ebus diode on a heat sink based on an older >copy of the 'Connection. Now in 12a I see that a Schottky is >mentioned. Any reason to abandon the original diode plan? No. >- I plan to use the same PB/Tyco circuit breakers as Composite >Designs uses in their power panels. They have a circuit board that >the PIDG terminals on the breakers are connected to. My thought is >to use a piece of brass and 'forest of terminals' such as the ground >plate BandC sells for power distribution to the breakers. The plate >would be insulated from the panel and covered to protect inadvertent >shorting by 'falling objects'. Does this sound reasonable? No. To many parts and joints. Why not use breakers that are bus-bar friendly? Bob . . . ________________________________________________________________________________
Date: Feb 22, 2011
> > >- I ordered the BandC ebus diode on a heat sink . . . What are your e-bus loads? Do you NEED a heat-sinked normal feedpath diode? You're building a metal airplane. I suspect the bare-foot rectifier assembly can be simply bolted to some portion of the airplane. Bob . . . ________________________________________________________________________________
Date: Feb 22, 2011
Crud - I had all my answers typed in and forgot to copy/paste to notepad in case I had been automagically logged out. I hit 'preview' and lost all I typed. Back to the keyboard..... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331868#331868 ________________________________________________________________________________
From: "earl_schroeder(at)juno.com" <earl_schroeder(at)juno.com>
Date: Feb 23, 2011
For those of us that bought the 'original' unit from HF, here is a link to the 10mm lens that is said to work. Now you can get into a spark plug hole..I have not tried it. http://www.circuitspecialists.com/prod.itml/icOid/10211 Earl ---------- Original Message ---------- From: "Eric M. Jones" <emjones(at)charter.net> Subject: AeroElectric-List: Re: Video Inspection Tool Date: Mon, 21 Feb 2011 15:29:10 -0800 As these things go, I think you'll find this one is a much better unit. Smaller head (10 mm) longer reach (90 cm) higher resolutions. Soon they will be perfect and free. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net ________________________________________________________________________________
Date: Feb 22, 2011
Bob - thanks for taking the time to provide feedback! My responses are in-line below. Phil >> (7AH backup) What equipment are you carrying that drives this decision? Primarily my electronic ignition, EIS and EFIS >> your worry-bucket seems to be carrying some issues. It sure is! I only have one teenager and had some excess space in that bucket :-) I've experienced the failed alternator in a production airplane and don't want to be there by my own doing in my homebuilt. The plane I owned was rented with a flight school and I was at the mercy of their maintenance as were those who rented it. It was stranded twice because of a failed alternator that wasn't noticed in a timely fashion. The first sign of a problem was the comm radio no longer transmitted. Short minutes later the nav would quit. Thankfully the problem was never more nerve-wracking than having to abort the flight somewhat short of the intended destination and it never happened while under IFR. My plan is to have a well thought-out and implemented electrical system in my RV that will provide the necessary ability to alert me to an issue then let me continue without any worries for an hour minimum and up to two hours. That gives me lots of options to complete the flight to a ho-hum end; most likely at the intended destination. >> (switch in place of the brownout battery relay) What failure mode do you perceive that loss of the relay would be a pre-cursor to your own dark-n-stormy-night story? In hindsight I probably should have left this out. Comparing my auto industry automation where the relays make and break thousands of times before failure compared to fact that the switch that was used to set the machine in motion is actuated one or more orders of magnitude fewer times isn't 'fair'. I had a relay in my BandC shopping cart when I left work, I will just order it tomorrow :-) >> It would be helpful to know more about your equipment list and the reasons that drive installation of a second battery. The 'Connection basic list (xponder, nav radio, panel flood, turn coordinator) plus my electronic ignition and a rear pax light. The ignition adds 2A to the basic list, though I am debating putting one on the battery bus and the other on the e-bus which would lighten the load by 1A to just under 4A. >> What are your e-bus loads? Do you NEED a heat-sinked normal feedpath diode? You're building a metal airplane. I suspect the bare-foot rectifier assembly can be simply bolted to some portion of the airplane. I already have the diode on a heat sink because I hadn't planned on the shelf behind the panel for a small battery. Now that I am going to have a plate there, the barefoot one would work but I will just stick with the one on a heatsink. I was wondering about the Schottky diode and if there was a benefit to the lower voltage losses when compared to the diode I have already. >> (PB/Tyco circuit breakers connected to forest of tabs bus) Too many parts and joints. Why not use breakers that are bus-bar friendly? Size, weight and cost. I'll admit I like the way they look and that I'm not excited about fuse blocks. >> Maybe I missed the answer to this question in the text ... I started to ask just one question - the one about the relay - and then just kept adding more. I miss a lot in the text that I pick up when I reread sections. I recently updated from v10 to v12a and I have to start from square two. So much to learn.... Frankly the adventure of rewiring my airplane has been made tremendously easier because of your text and website. I've gone from tentatively engaging to full-on fun with it because of them! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331878#331878 ________________________________________________________________________________
Date: Feb 22, 2011
Has anyone tried this smaller head with the HF 66550 unit? Btw, when I search the HF site for that part number, it returns zero hits. . Guess it's been replaced but it looks like the replacement does not have the removable screen. For $70, I'd like to be *sure* it works before I buy one. Done that too many times and wasted dollars. :) Thanks, David earl_schroeder(at)juno.com wrote: > --> AeroElectric-List message posted by: "earl_schroeder(at)juno.com" > > For those of us that bought the 'original' unit from HF, here is a link to the 10mm lens that is said to work. Now you can get into a spark plug hole..I have not tried it. > > http://www.circuitspecialists.com/prod.itml/icOid/10211 > > Earl > ---------- Original Message ---------- > From: "Eric M. Jones"<emjones(at)charter.net> > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Re: Video Inspection Tool > Date: Mon, 21 Feb 2011 15:29:10 -0800 > > --> AeroElectric-List message posted by: "Eric M. Jones" > > As these things go, I think you'll find this one is a much better unit. Smaller head (10 mm) longer reach (90 cm) higher resolutions. Soon they will be perfect and free. > > -------- > Eric M. Jones > www.PerihelionDesign.com > 113 Brentwood Drive > Southbridge, MA 01550 > (508) 764-2072 > emjones(at)charter.net > > > -- If you're an American, just say NO to the Obamanation, to socialism, and get rid of Soros. ________________________________________________________________________________
Date: Feb 22, 2011
From: Dennis Golden <dgolden@golden-consulting.com>
On 02/21/2011 05:29 PM, Eric M. Jones wrote: > > > As these things go, I think you'll find this one is a much better > unit. Smaller head (10 mm) longer reach (90 cm) higher resolutions. > Soon they will be perfect and free. Can this thing really get into a 10mm sparkplug hole? -- Dennis Golden Golden Consulting Services, Inc. ________________________________________________________________________________
Date: Feb 22, 2011
Dennis, I recently purchased the General Instruments CDS300 on sale from Harbor Freight (~$90) and it came with 3 meter cable and 9mm camera head. I haven't tried it yet, but it sure looks like it would peek into a spark plug hole. Bob Borger Europa Kit #A221 N914XL, XS Tri-Gear, Intercooled 914, Airmaster C/S Prop http://www.europaowners.org/forums/gallery2.php?g2_itemId=60232 http://www.biplaneforumgallery.com/index.php?cat=10046 Europa Flying! 3705 Lynchburg Dr. Corinth, TX 76208 Home: 940-497-2123 Cel: 817-992-1117 On Feb 22, 2011, at 19:21, Dennis Golden wrote: > > On 02/21/2011 05:29 PM, Eric M. Jones wrote: >> >> >> As these things go, I think you'll find this one is a much better >> unit. Smaller head (10 mm) longer reach (90 cm) higher resolutions. >> Soon they will be perfect and free. > > Can this thing really get into a 10mm sparkplug hole? > > -- > Dennis Golden > Golden Consulting Services, Inc. ________________________________________________________________________________
Date: Feb 22, 2011
David, The General Instruments GSC300 does not have the removable screen. You have to go to the GSC400 and spend a lot more $$$ for that option. Bob Borger Europa Kit #A221 N914XL, XS Tri-Gear, Intercooled 914, Airmaster C/S Prop http://www.europaowners.org/forums/gallery2.php?g2_itemId=60232 http://www.biplaneforumgallery.com/index.php?cat=10046 Europa Flying! 3705 Lynchburg Dr. Corinth, TX 76208 Home: 940-497-2123 Cel: 817-992-1117 On Feb 22, 2011, at 19:13, David wrote: > > Has anyone tried this smaller head with the HF 66550 unit? Btw, when I search the HF site for that part number, it returns zero hits. . Guess it's been replaced but it looks like the replacement does not have the removable screen. > For $70, I'd like to be *sure* it works before I buy one. Done that too many times and wasted dollars. :) > > Thanks, > David > > > earl_schroeder(at)juno.com wrote: >> --> AeroElectric-List message posted by: "earl_schroeder(at)juno.com" >> >> For those of us that bought the 'original' unit from HF, here is a link to the 10mm lens that is said to work. Now you can get into a spark plug hole..I have not tried it. >> >> http://www.circuitspecialists.com/prod.itml/icOid/10211 >> >> Earl >> ---------- Original Message ---------- >> From: "Eric M. Jones"<emjones(at)charter.net> >> To: aeroelectric-list(at)matronics.com >> Subject: AeroElectric-List: Re: Video Inspection Tool >> Date: Mon, 21 Feb 2011 15:29:10 -0800 >> >> --> AeroElectric-List message posted by: "Eric M. Jones" >> >> As these things go, I think you'll find this one is a much better unit. Smaller head (10 mm) longer reach (90 cm) higher resolutions. Soon they will be perfect and free. >> >> -------- >> Eric M. Jones >> www.PerihelionDesign.com >> 113 Brentwood Drive >> Southbridge, MA 01550 >> (508) 764-2072 >> emjones(at)charter.net ________________________________________________________________________________
Date: Feb 22, 2011
Dr Elliot, Adjust / extend the throw or extend the trim tab chord with a temporary tab, which ever is more convenient, and measure the effect. We used to use simpl e hanging scales like those to weight small fish to measure stick forces at r epeatable flight conditions. Baseline the forces at the desired landing conf iguration, weight, and CG location first. Make the tab mods and analyze the r esults. If there is no noticeable change then there may be some flow separat ion on the underside of the elevator as others have suggested that has contr ibuted to the problem. Elevator seals and/or vortex generators at or forward of the elevator hinge line area might help. I would not entertain the comp lexity of synchronizing trim motors. Too hard. Once you find what works the best, be sure and test the rest of the trim env elope at various speeds and CG/wt conditions to ensure flying qualities over all are still ok. Then construct a permanent change and verify via a retest of the same conditions. Then publish findings to all. Tom Sent from my iPad On Feb 22, 2011, at 9:09 AM, " Dr. Andrew Elliott" wro te: > Gang: > > > > On my 601XL, the elevator trim tab is not effective enough to trim out all control forces on a full-flap final when the CG is in the front half of the allowed range. Although the remaining elevator forces are light, I would l ike to be able to trim them away. The trim tab is inset on one side of the e levator, and takes the entire width, minus about 20 mm on each end. Servo i s RAC > > > > One option would be to add another trim tab to the other side of the eleva tor. But to do that I would need some way to slave the two sides together. Does anyone have an idea about how to do that electronically without very h igh cost, or perhaps some way already exists and I haven't found it? (The e levator design doesn't allow for a simple mechanical connection.) > > > > Another option, of course, would to be to increase the size of the trim ta b, either making it full width (probably not too effective - delta area <10% ), or extending it aft 20-25 mm (probably would work, but ugly), or both. I might go that way, but thought I'd ask about the saving first. > > > > Thanks, > > Andy > > > > ------------------------ > > Andy Elliott > > N601GE/Z601XL/TD/Corvair > > 298 hrs since 11/08 > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Feb 22, 2011
Dr Elliot, Adjust / extend the throw or extend the trim tab chord with a temporary tab, which ever is more convenient, and measure the effect. We used to use simpl e hanging scales like those to weight small fish to measure stick forces at r epeatable flight conditions. Baseline the forces at the desired landing conf iguration, weight, and CG location first. Make the tab mods and analyze the r esults. If there is no noticeable change then there may be some flow separat ion on the underside of the elevator as others have suggested that has contr ibuted to the problem. Elevator seals and/or vortex generators at or forward of the elevator hinge line area might help. I would not entertain the comp lexity of synchronizing trim motors. Too hard. Once you find what works the best, be sure and test the rest of the trim env elope at various speeds and CG/wt conditions to ensure flying qualities over all are still ok. Then construct a permanent change and verify via a retest of the same conditions. Then publish findings to all. Tom On Feb 22, 2011, at 9:09 AM, " Dr. Andrew Elliott" wro te: > Gang: > > > > On my 601XL, the elevator trim tab is not effective enough to trim out all control forces on a full-flap final when the CG is in the front half of the allowed range. Although the remaining elevator forces are light, I would l ike to be able to trim them away. The trim tab is inset on one side of the e levator, and takes the entire width, minus about 20 mm on each end. Servo i s RAC > > > > One option would be to add another trim tab to the other side of the eleva tor. But to do that I would need some way to slave the two sides together. Does anyone have an idea about how to do that electronically without very h igh cost, or perhaps some way already exists and I haven't found it? (The e levator design doesn't allow for a simple mechanical connection.) > > > > Another option, of course, would to be to increase the size of the trim ta b, either making it full width (probably not too effective - delta area <10% ), or extending it aft 20-25 mm (probably would work, but ugly), or both. I might go that way, but thought I'd ask about the saving first. > > > > Thanks, > > Andy > > > > ------------------------ > > Andy Elliott > > N601GE/Z601XL/TD/Corvair > > 298 hrs since 11/08 > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Feb 22, 2011
At 08:13 PM 2/22/2011, you wrote: Bob - thanks for taking the time to provide feedback! My responses are in-line below. Phil >> (7AH backup) What equipment are you carrying that drives this decision? Primarily my electronic ignition, EIS and EFIS How much time to you expect to spend with your head in the clouds? >> your worry-bucket seems to be carrying some issues. It sure is! I only have one teenager and had some excess space in that bucket :-) Understand. I've experienced the failed alternator in a production airplane and don't want to be there by my own doing in my homebuilt. The plane I owned was rented with a flight school and I was at the mercy of their maintenance as were those who rented it. Yup, been there, done that. But keep in mind that the service life of alternators on t/c aircraft is miserable. Plane power, B&C, and many OBAM aircraft builders are adapting modern alternators to aircraft with great results. B&C's return rate is a very small number of the total fleet. I suspect others are seeing similar performance. Keep in mind, that for every dark-n-stormy-night story about some failure, there are thousands of other non- stories that you never hear about. The real risks for tense days in the cockpit due to alternator failure are a tiny fraction of what your grandpa had to endure on his Cherokee that keeps breaking certified brackets. It was stranded twice because of a failed alternator that wasn't noticed in a timely fashion. Typical TC aircraft . . . no timely notification of low voltage. Most dark-n-stormy-night story tellers say the first notion they had for a failed alternator was when the panel started going black/silent. The first sign of a problem was the comm radio no longer transmitted. Short minutes later the nav would quit. Thankfully the problem was never more nerve-wracking than having to abort the flight somewhat short of the intended destination and it never happened while under IFR. My plan is to have a well thought-out and implemented By 'implemented' I hope you mean WELL maintained. Your ship's main battery should not be run until it no longer cranks the engine. It needs to be replaced when its MEASURED capacity no longer supports your design goals for alternator out endurance. . . electrical system in my RV that will provide the necessary ability to alert me to an issue then let me continue without any worries for an hour minimum and up to two hours. That gives me lots of options to complete the flight to a ho-hum end; most likely at the intended destination. Okay, what's your endurance load? >> (switch in place of the brownout battery relay) What failure mode do you perceive that loss of the relay would be a pre-cursor to your own dark-n-stormy-night story? In hindsight I probably should have left this out. Comparing my auto industry automation where the relays make and break thousands of times before failure compared to fact that the switch that was used to set the machine in motion is actuated one or more orders of magnitude fewer times isn't 'fair'. I had a relay in my BandC shopping cart when I left work, I will just order it tomorrow :-) What electronic ignition(s) are planned? >> It would be helpful to know more about your equipment list and the reasons that drive installation of a second battery. The 'Connection basic list (xponder, nav radio, panel flood, turn coordinator) plus my electronic ignition and a rear pax light. The ignition adds 2A to the basic list, though I am debating putting one on the battery bus and the other on the e-bus which would lighten the load by 1A to just under 4A. Okay, it looks like you need 2 hours at a 4A rate. An exemplar 17 a.h. battery discharged at 4.25A is good for 3 hours new http://www.aeroelectric.com/Pictures/Curves/17AH_12V_Capacity_vs_Load.gif and 2+ hours at end of life. >> What are your e-bus loads? Do you NEED a heat-sinked normal feedpath diode? You're building a metal airplane. I suspect the bare-foot rectifier assembly can be simply bolted to some portion of the airplane. I already have the diode on a heat sink because I hadn't planned on the shelf behind the panel for a small battery. Now that I am going to have a plate there, the barefoot one would work but I will just stick with the one on a heatsink. I was wondering about the Schottky diode and if there was a benefit to the lower voltage losses when compared to the diode I have already. No advantage from an energy conservation perspective (the main alternator is up and running when that diode is in service). There's an advantage that less heat sink is needed. The Schottky would most certainly run well "bare-sinked". >> (PB/Tyco circuit breakers connected to forest of tabs bus) Too many parts and joints. Why not use breakers that are bus-bar friendly? Size, weight and cost. I'll admit I like the way they look and that I'm not excited about fuse blocks. But I'm not excited about all the monkey-motion for using these fast-on terminated devices. Please consider the miniature screw-terminal devices. http://aeroelectric.com/Pictures/Breakers/Klixon_1.jpg >> Maybe I missed the answer to this question in the text ... I started to ask just one question - the one about the relay - and then just kept adding more. I miss a lot in the text that I pick up when I reread sections. I recently updated from v10 to v12a and I have to start from square two. So much to learn.... Frankly the adventure of rewiring my airplane has been made tremendously easier because of your text and website. I've gone from tentatively engaging to full-on fun with it because of them! Good. Wiring your airplane ought to be the fun part. A guy who attended my second or third seminar way back when wrote to me a couple weeks after the seminar. He had been sticking electro-whizzies in his LongEz for years. After the seminar, he went home, ripped it all out and wrote to tell me it all went back in a couple weekends but with confidence of understanding. I'm not convinced that you need two batteries yet . . . Reducing battery maintenance to two articles will pay for the better breakers in a few years. Bob . . . ________________________________________________________________________________
Date: Feb 23, 2011
2/23/2011 Hello Andy, Is it possible to reduce the length of the lever arm between the pushrod end and the trim tab surface thereby gaining increased movement of the trim tab arc for each longitudinal movement of the pushrod? 'OC' Baker Says: "The best investment we can make is the time and effort to gather and understand knowledge." ========================================================== From: " Dr. Andrew Elliott" <a.s.elliott(at)cox.net> Subject: AeroElectric-List: Trim tab slaving? Gang: On my 601XL, the elevator trim tab is not effective enough to trim out all control forces on a full-flap final when the CG is in the front half of the allowed range. Although the remaining elevator forces are light, I would like to be able to trim them away. The trim tab is inset on one side of the elevator, and takes the entire width, minus about 20 mm on each end. Servo is RAC One option would be to add another trim tab to the other side of the elevator. But to do that I would need some way to slave the two sides together. Does anyone have an idea about how to do that electronically without very high cost, or perhaps some way already exists and I haven't found it? (The elevator design doesn't allow for a simple mechanical connection.) Another option, of course, would to be to increase the size of the trim tab, either making it full width (probably not too effective - delta area <10%), or extending it aft 20-25 mm (probably would work, but ugly), or both. I might go that way, but thought I'd ask about the saving first. Thanks, Andy ________________________________________________________________________________
Date: Feb 23, 2011
Subject: Great ebay deal on Kroy K4100 shrink wrap label printer
I hope this is allowed on this list - great tool for wiring. Check out this new Kroy shrink wrap-label printer - purchased new for aircraft wiring p roject - never used --7 boxes of shrink wrap and 1 box of wire marker inc luded. - http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=160550371023&ssPageNam e=STRK:MESELX:IT - If this link doesn't work just go to ebay and search Kroy K4100.- Contact me through ebay or gjs55(at)yahoo.com Thanks. - Jim=0A=0A=0A ________________________________________________________________________________
Date: Feb 23, 2011
Hi Andy- For what it's worth, I'd suggest there are a couple questions to answer prior to modifying your plane. You may have already run these issues to ground, and if so please disregard the first portion of this note. The first question is, is this trait common to the design? If it is not a common issue, I would suggest verifying your ASI operation / calibration and CG calculations prior to making any changes. The other observation is to be aware of the effect of increased up trim authority on go around performance. There is the possibility that using increased nose up pitch trim for a low power or power off gliding situation could lead to unexpectedly (startlingly?) high pitch up tendencies when go around power is applied. YMMV- >From: " Dr. Andrew Elliott" <a.s.elliott(at)cox.net> >Subject: AeroElectric-List: Trim tab slaving? > >Gang: > > >On my 601XL, the elevator trim tab is not effective enough to trim out all >control forces on a full-flap final when the CG is in the front half of the >allowed range. Although the remaining elevator forces are light, I would >like to be able to trim them away. The trim tab is inset on one side of the >elevator, and takes the entire width, minus about 20 mm on each end. Servo >is RAC > > >One option would be to add another trim tab to the other side of the >elevator. But to do that I would need some way to slave the two sides >together. Does anyone have an idea about how to do that electronically >without very high cost, or perhaps some way already exists and I haven't >found it? (The elevator design doesn't allow for a simple mechanical >connection.) > > >Another option, of course, would to be to increase the size of the trim tab, >either making it full width (probably not too effective - delta area <10%), >or extending it aft 20-25 mm (probably would work, but ugly), or both. I >might go that way, but thought I'd ask about the saving first. > > >Thanks, > >Andy > > >------------------------ > >Andy Elliott > >N601GE/Z601XL/TD/Corvair > >298 hrs since 11/08 > > Glen Matejcek ________________________________________________________________________________
Subject: Re: Battery box being demanded
Date: Feb 23, 2011
Here is an excerpt from an email I received yesterday... > Hello ray, > > After further review, Transport Canada has no objection that you continue operating aircraft registered C-GJRL in the present configuration. Yay. --ray :D -------- Ray St-Laurent 701/Pegastol wings/Suzuki engine Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331962#331962 ________________________________________________________________________________
Date: Feb 23, 2011
Ray, CONGRATS!! Bob Borger Europa Kit #A221 N914XL, XS Tri-Gear, Intercooled 914, Airmaster C/S Prop http://www.europaowners.org/forums/gallery2.php?g2_itemId=60232 http://www.biplaneforumgallery.com/index.php?cat=10046 Europa Flying! 3705 Lynchburg Dr. Corinth, TX 76208 Home: 940-497-2123 Cel: 817-992-1117 On Feb 23, 2011, at 16:18, RayStL wrote: > > Here is an excerpt from an email I received yesterday... > > >> Hello ray, >> >> After further review, Transport Canada has no objection that you continue operating aircraft registered C-GJRL in the present configuration. > > > Yay. > --ray :D > > -------- > Ray St-Laurent > 701/Pegastol wings/Suzuki engine ________________________________________________________________________________
Date: Feb 23, 2011
Some airplanes also benefit from a little ballast in the baggage compartment. Yours might be a candidate for 25 pounds of kitty litter, which can also come in handy if you really need to pee. On Wed, Feb 23, 2011 at 2:37 PM, Glen Matejcek wrote: > aerobubba(at)earthlink.net> > > Hi Andy- > > For what it's worth, I'd suggest there are a couple questions to answer > prior to modifying your plane. You may have already run these issues to > ground, and if so please disregard the first portion of this note. The > first question is, is this trait common to the design? If it is not a > common issue, I would suggest verifying your ASI operation / calibration and > CG calculations prior to making any changes. > > The other observation is to be aware of the effect of increased up trim > authority on go around performance. There is the possibility that using > increased nose up pitch trim for a low power or power off gliding situation > could lead to unexpectedly (startlingly?) high pitch up tendencies when go > around power is applied. > > YMMV- > > > >From: " Dr. Andrew Elliott" <a.s.elliott(at)cox.net> > >Subject: AeroElectric-List: Trim tab slaving? > > > >Gang: > > > > > >On my 601XL, the elevator trim tab is not effective enough to trim out all > >control forces on a full-flap final when the CG is in the front half of > the > >allowed range. Although the remaining elevator forces are light, I would > >like to be able to trim them away. The trim tab is inset on one side of > the > >elevator, and takes the entire width, minus about 20 mm on each end. > Servo > >is RAC > > > > > >One option would be to add another trim tab to the other side of the > >elevator. But to do that I would need some way to slave the two sides > >together. Does anyone have an idea about how to do that electronically > >without very high cost, or perhaps some way already exists and I haven't > >found it? (The elevator design doesn't allow for a simple mechanical > >connection.) > > > > > >Another option, of course, would to be to increase the size of the trim > tab, > >either making it full width (probably not too effective - delta area > <10%), > >or extending it aft 20-25 mm (probably would work, but ugly), or both. I > >might go that way, but thought I'd ask about the saving first. > > > > > >Thanks, > > > >Andy > > > > > >------------------------ > > > >Andy Elliott > > > >N601GE/Z601XL/TD/Corvair > > > >298 hrs since 11/08 > > > > > > > Glen Matejcek > > ________________________________________________________________________________
Subject: How should I use the AeroElectric Panel Grounding Hub?
Date: Feb 23, 2011
I purchased the Panel Grounding Hub because it sounded like a great device and because it comes from Bob. But since getting the hub, I have read about concerns about grounding avionics through the hub because of current limitations of the individual pins and the potential of exceeding the current capability of the hub and the 4 or 5 20 ga ground wires run to the Forrest of Tabs. Something was also mentioned about all ground wires not being equal such as when a 16 or 18ga wire is split into two 20ga wires for insertion into the hub. I understand that low power grounds such as from LED Panel lights are a good choice for the hub. But I am installing a g430W, a SL-40, a GTX-327, a PS5000EX, Dual GRT HX Displays, the GRT Autopilot when it is released, a AFS Sport AoA, GRT EIS and a TruTrac Turn and Bank indicator. Some of these individually have fairly low current requirements but as a collective, the current is considerable. I need some advise from the experts as to what can be run to ground via the hub and what needs to be run directly to the Forrest of Tabs. I would optimally like to utilize the hub as much as possible merely to control the wire runs. Thanks for your help, -------- Jack Clark RV-8A Fuselage http://www.mykitlog.com/jackclark/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331983#331983 ________________________________________________________________________________
Date: Feb 23, 2011
Subject: Re: How should I use the AeroElectric Panel Grounding
Hub? On 2/23/2011 7:41 PM, jhclarkfl wrote: > -I have read about concerns about grounding avionics through the hub because of current limitations of the individual pins and the potential of exceeding the current capability of the hub and the 4 or 5 20 ga ground wires run to the Forrest of Tabs. Something was also mentioned about all ground wires not being equal such as when a 16 or 18ga wire is split into two 20ga wires for insertion into the hub. > > > -------- > Jack Clark > RV-8A Fuselage > http://www.mykitlog.com/jackclark/ > > > I used Bob's Avionics ground bus and liked it. The only difficulty, and it's no big deal, is the Comm grounds. Both of mine (A210 and 430W) require 18 awg wire. So I just ganged the 18 awg wire into 2 pins with 20 awg wire using solder sleeves. No big deal, easy to do. Nothing else on my panel comes close to the limit for the pins except I do have an electric nose lift (10 amps max) that is not grounded yet. I have been debating putting this on the bus with 3 20awg wires/pins. Bob? HTH, Tim Andres ________________________________________________________________________________
Date: Feb 24, 2011
Hub? At 10:41 PM 2/23/2011, you wrote: I purchased the Panel Grounding Hub because it sounded like a great device and because it comes from Bob. But since getting the hub, I have read about concerns about grounding avionics through the hub because of current limitations of the individual pins and the potential of exceeding the current capability of the hub and the 4 or 5 20 ga ground wires run to the Forrest of Tabs. So how much current do you anticipate your panel grounds will need? Something was also mentioned about all ground wires not being equal such as when a 16 or 18ga wire is split into two 20ga wires for insertion into the hub. Don't split stranding of wires. What items on the panel require 16 or 18 AWG ground wires and how much current is flowing in these wires? I understand that low power grounds such as from LED Panel lights are a good choice for the hub. But I am installing a g430W, a SL-40, a GTX-327, a PS5000EX, Dual GRT HX Displays, the GRT Autopilot when it is released, a AFS Sport AoA, GRT EIS and a TruTrac Turn and Bank indicator. Some of these individually have fairly low current requirements but as a collective, the current is considerable. Define "considerable". The current drains of all these devices is known . . . by somebody. The total current that can be loaded to 5x20AWG bundle to the forest of tabs is 25A . . . do you think you're going to push this? If necessary, you can use more leads to the firewall, or solder 12AWG wires to the bottom of the panel bus . . . but please do these kinds of things because you KNOW it's necessary/useful, not because lots of folks poured their own uncertainties into your worry bucket. Bob . . . ________________________________________________________________________________
Date: Feb 24, 2011
Hub? I used Bob's Avionics ground bus and liked it. The only difficulty, and it's no big deal, is the Comm grounds. Both of mine (A210 and 430W) require 18 awg wire. So I just ganged the 18 awg wire into 2 pins with 20 awg wire using solder sleeves. 22AWG pigtails of 6" are recommended but don't change what you have. There's no way the radios you mentioned are pushing the capabilities of an 18AWG wire. A few years ago I described a technique I used to parallel pins to achieve a high current power path through a d-sub connector: http://www.aeroelectric.com/Pictures/Connectors/D-Subminature/Paralleled_D-Sub_Pins.jpg This was qualified for use on a system subject to, shall we say, 'stressful' environmental conditions? The idea was that short but SIGNIFICANT lengths of 22AWG wire could be used as ballasting resistors to insure a degree of current sharing between paralleled pins. For the purposes of bailing the worry-buckets of some skeptics, I de-rated each pin down to 3A for qualification on this vehicle. http://aeroelectric.com/Pictures/Misc/GQM_1st_Ops_Flight.jpg As a practical matter, 4 to 5 amps per pin stays well inside ratings for the device when installed in benign environment YOU share the same space in the airframe as the radios. The environs enjoyed by the panel ground bus is not especially stressful. No big deal, easy to do. Nothing else on my panel comes close to the limit for the pins except I do have an electric nose lift (10 amps max) that is not grounded yet. How did THAT load become a "panel" equipment load. The intent of the panel ground bus is to provide a localized, clean terminus for potential victims (avionics and instrumentation). This design goal is dishonored if one starts tying gear motors, landing lights, pitot heat, etc. etc. to this bus. I have been debating putting this on the bus with 3 20awg wires/pins. Are you running out of pins in the bus? Recommend you put all 5 wires in as suggested. Never can tell what you might add to the bus in the future . . . long after you've forgotten why it was a good idea to use only 3 wires. Bob . . . ________________________________________________________________________________
Subject: Earth return
Date: Feb 24, 2011
Hi Bob, et al A fellow (RV-9a) builder has raised a querry I thought I knew the answer to: my friend is going to wire (eg: wing tip 'nav' lights) with common (airframe) return, plus wire feed return - I was under the impression that this is not nessecary, and is in fact undesirable As always your advice is welcome Best regards John ________________________________________________________________________________
Subject: I found some magic smoke
Date: Feb 24, 2011
List guys=2C for your amusement=3B I know how to hook up a multimeter=2C but yesterday I was a little too careless to verify the setting before I tried checking the voltage my airplane's new battery. I quickly found out where my multimeter stores it's magic smoke!! It's n ear the bottom=2C where the leads attach!! I comes out in large plumes from the lead holes. Yep=2C my fairly new Etec multimeter was toasted=2C and now it has readings all over the pla ce! The readings just jumps around=2C never settle on any specific number. Rats!! What is especially annoying is we recently found out WalMart evidently do esn't sell this particular model of multimeter anymore=2C and that's too bad=2C because I r eally did like it. The last time I tried fix the previous multimeter I had=2C (someone spill ed coffee in it) which was the exact same model=2C I didn't have much success. I hoped I could tr y to fix this one=2C maybe with better results this time. So=2C I took this apart yesterday=2C and found that some kind of large wi re/fuse thing got fried=2C plus it blew the itty bitty fuse (no biggie on this one). I got out my sol dering iron=2C fashioned a similar piece or wire=2C and removed the old crispy one=2C scraped away t he carbon and gunk=2C and replaced it with the new one=2C and replaced the blown fuse. Whoa!! To my surprise=2C it works good as new...well=2C sort of. It still has that 'magic smoke' smell=2C bu t maybe that will remind me to hook it up properly from now on!!! Mike Welch ________________________________________________________________________________
Date: Feb 24, 2011
From: Marvin Haught <handainc(at)madisoncounty.net>
Subject: Re: I found some magic smoke
Hey! I'll try that on mine that doesn't work! The taking apart and repair, that is! Hope I don't discover the magic smoke container! I suspect mine was a WalMart return that had the same treatment you did to yours - and because I didn't use it for several months, didn't discover it was bad until I went to use it with the thermocouple you sent me. That is probably why mine didn't have the thermocouple with it. If the repair doesn't last, let me know what unit you end up replacing it with. I've been looking for something similar, but haven't found anything yet. M. Haught On 2/24/2011 11:02 AM, Mike Welch wrote: > List guys, for your amusement; > > I know how to hook up a multimeter, but yesterday I was a little too > careless to verify the setting before I tried checking the voltage my > airplane's new battery. > > I quickly found out where my multimeter stores it's magic smoke!! > It's near the bottom, > where the leads attach!! I comes out in large plumes from the lead > holes. Yep, my fairly > new Etec multimeter was toasted, and now it has readings all over the > place! The readings just > jumps around, never settle on any specific number. Rats!! > > What is especially annoying is we recently found out WalMart > evidently doesn't sell this > particular model of multimeter anymore, and that's too bad, because I > really did like it. > > The last time I tried fix the previous multimeter I had, (someone > spilled coffee in it) which > was the exact same model, I didn't have much success. I hoped I could > try to fix this one, > maybe with better results this time. > So, I took this apart yesterday, and found that some kind of large > wire/fuse thing got fried, > plus it blew the itty bitty fuse (no biggie on this one). I got out > my soldering iron, fashioned > a similar piece or wire, and removed the old crispy one, scraped away > the carbon and gunk, and > replaced it with the new one, and replaced the blown fuse. Whoa!! To > my surprise, it works > good as new...well, sort of. It still has that 'magic smoke' smell, > but maybe that will remind > me to hook it up properly from now on!!! > > Mike Welch > > > * > > > * ________________________________________________________________________________
Date: Feb 24, 2011
Subject: Re: Earth return
At 11:40 AM 2/24/2011, you wrote: > > >Hi Bob, et al > >A fellow (RV-9a) builder has raised a querry I thought I knew the >answer to: my friend is going to wire (eg: wing tip 'nav' lights) >with common (airframe) return, plus wire feed return - I was under >the impression that this is not nessecary, and is in fact undesirable An additional wire only adds weight to the airplane . . . and raises eyebrows on competent observers who might notice it in the future. Bob . . . ________________________________________________________________________________
Date: Feb 24, 2011
At 12:02 PM 2/24/2011, you wrote: >List guys, for your amusement; > > I know how to hook up a multimeter, but yesterday I was a little too >careless to verify the setting before I tried checking the voltage my >airplane's new battery. > > I quickly found out where my multimeter stores it's magic > smoke!! It's near the bottom, >where the leads attach!! I comes out in large plumes from the lead >holes. Yep, my fairly >new Etec multimeter was toasted, and now it has readings all over >the place! The readings just >jumps around, never settle on any specific number. This one? Emacs! > > What is especially annoying is we recently found out WalMart > evidently doesn't sell this >particular model of multimeter anymore, and that's too bad, because >I really did like it. Every multi-meter of this genre' has what appears to be a 'fat wire' jumper on the board that looks something like this: Emacs! Further, there will be one or more GMA series fuses in open clips. The 'fat wire' is the high current shunt. It a special alloy with a callibrated resistance. The really GOOD ones use manganin wire which offers very low temperature coefficient of resistance. The fuse will be a very low current device . . . usually 0.5A or less that protects the lower current ranges from overload . . . and may protect the ohmmeter circuitry too. It sounds like your test leads were set up for a high current measurement (that is not protected) which warmed things up rather severely. There's a seller on Ebay offering the model above for $40 shipping paid. Bob . . . ________________________________________________________________________________
Date: Feb 24, 2011
>This one? >Bob Hi Bob=2C Yes=2C that's the one. Yes=2C the large wire you refer to (shunt) is th e one that got toasted. Yes=2C the little fuse was 500mA. Yes=2C I accidently tried to measure the 12V battery's current=2C although I didn't intend to! Although I realize my make-shift wire replacement would never pass for an y real calibrated shunt=2C for what I use the multimeter for=2C it should be fine. I don't generally ever check for current=2C and even in this case it was an acciden t. I have two other multimeters that I could use if I was especially concern ed about an accurate figure. As best as I can tell=2C the resistance function appea rs to be unaffected=2C and that is mainly what I use this multimeter for. So far=2C a random sampling of various resistors still appear to be as expected. Thanks=2C Mike /9j/4AAQSkZJRgABAQAAAQABAAD/2wBDAAEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEB AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQH/2wBDAQEBAQEBAQEBAQEBAQEBAQEBAQEB AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQH/wAARCAHfAcADASIA AhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQA AAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3 ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWm p6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/8QAHwEA AwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSEx BhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElK U1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3 uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD+E+jy f3VvPP8A8vQ+nr/n/Iqx537r/wCtx0/Pp+nvzVeft+H9aAK/7nzf/wBef8/+zVX8j3/X/wCtR+6/ ztqx50Hldf8ADOPy68Y/pxQBX/5a/wCf71V/+Wv+f71WKr0AH7/yv849f5/+O0f9e/8AwH/J/Dr+ Haij/ll/n+7QAf8ALPyP179fXp1/T86WH/Uj6H+VJVegAg7/AI/0qxND5X+f5+/TvVerHM0P1/p/ X/PJ6gFeGb/9X+f1H4ij/lr/AJ/vUUUAQTf6k/QfyqeDv+P9KKPI9/1/+tQAUQd/x/pRDD/x8fyz /wDW/Ln60UAFFFFAFiHyPN/0j17Y6Y/l9f50f8sv8/3ar0eR7/r/APWoAsef7fp/9eiq8Hf8f6VY oAPO/e//AFuev5df19uKKr1YoArwzfvf8k/5/QdKsQzf8sJ/89sgf5/mKr0UAWP3X+dtV/8Alr/n +9Vj/ll/n+7VegAqx5xhiuD5Ftc8df8APr7c+1EHf8f6VWm/1x+o/nQBZz/03/T/AOvQP+WH4/0o qv8A9PH6/p/9br7+9AFijyf+W/4bv0zn/P17UUUAHn+36f8A16PJ/df5x0+uenf9M0f+A9H73/O6 gA/df520f+lX+f8AP/2NFFAFijyrjr9o/wBH/wA98Y6+36UUUAHM0P1/p/X/ADyetf8A9Kv8/wCf /sasfufN/wD15/z/AOzUUAHnH/UfjjnOevTP9M/zpIf9cPqf50v/AC1/z/eo/wBT/nOc/l6e3T8w BJv9cfqP51Zg7/j/AEqvViDv+P8ASgCv/wAtPP8A07dPTr0/X8qsebD6/qf8aKJ+34f1oAP3v+d1 WPO/5YeR+H64xj9dv41X5P8A18Wv59fyB/Wgf8sPx/pQBY/5Zf5/u0Q+fx+H5f8A6/vUVY5hh+n9 f6/54PQAseT+6/zjp9c9O/6ZqxD5EP5fXH5duuc8Vn1oQzT9O3/1/wDH3x69BkAx8w/8+/8AP/Cq /wDrv84xj8/X36/lYqvND5X+f5+/TvQBX8n91/nHT656d/0zR+6/ztqxVegBIf8AXD6n+dLNDB1/ z0/z2+neiq8/b8P60AFFFFABVeb9179P1/L+lWKr/wCum9vz6fyH5jjvQAnnH/n4H5H/AApfJ/df 5x0+uenf9M0TTf8ATD0/r0/nn8KsczQ/X+n9f88nqAV4O/4/0qvViigAmm//AFf5/Qfiar/uv87a sY/6Yfr/APWox/0w/X/61AB/yy/z/do/c+b/APrz/n/2aiHz+Pw/L/8AX96jyPf9f/rUAH/LX9xn p/8Ar/p+NH7r/O2q/ke/6/8A1qsf9O/6fr/9fp7e1ABR/wAsv8/3aKKACiiDv+P9KJ+34f1oAKPI 9/1/+tRVigCv/wAtf8/3qseT5XUdff8Az6fpVf8A5Zf5/u1Y/df520AVh9o8v9/+n0/n9e/4Uv8A rv8AOMY/P19+v5WKr/8ALX/P96gCxB3/AB/pVerHn+36f/XqvQBYo8n/AI9/xz/XP9T9AKD/AK63 /wA9hVfzv3X/ANbjp+fT9PfmgCxP2/D+tH/LX/P96q/+u/zjGPz9ffr+RD/y8fhQBYoo8n/lv+G7 9M5/z9e1FABRR5/t+n/16r0AaFFH7iH0HH1wB/n36e1EucnyP+A56+3X/PT3oAr0VY8/2/T/AOvR QAUf8tPP/Tt09OvT9fyo87yu+M+2f89P0o8791/9bjp+fT9PfmgAqxDD/n/P6nHsBRB3/H+lE3kc /j+f/wCr7tABR/qf85zn8vT26fnXhm/dfh/L+n6npVigCxPMfN/1H/H1/n1/HvyKIc/6jH+e3bt6 Y+vpVeDv+P8ASrEHf8f6UAWKP9T7/av8+3X+vvzX/wCvf/gP+T+HX8O1FAFiDv8Aj/SrH7r/ADto g7/j/SigDPn7fh/WrE3kTfZzBxcf8vvX88f5H8qrmH/lvP7EfrnqPw/KjyPf9f8A61H6bhuH/LX/ AD/eqv5Pm9B09/8APr+taEFlcT/6ge/HX+pHT6V9sfsjfsi658ZvFH9reKtK1HRPA+l/6deatd2Z 03Tb7rj+xDjk4zXKsVg8NJwxklzpfDf3lqrXW/a+l+vmdKw+OsnZ8tlr0t627efzPlfTfhj4jvLD T9V8j7Np+qc2f2zH+n8/57d+9T/8Kl1v/nufzP8AhX7Y/H7R/B2m+MtH8OaFpVtbaP4O8B+F9Fs/ 9Dx/0H9ez2/6Dn6detfP80OleUfIsdN7f8uf+BPpknr/ADqvrS6PTpr0/wDAjmPzP/4VXq3/AD3/ AM/lVeb4Y6r/AM9/Tn7H+R/Dp71+kE0OleXn7Dbckf5//Vz7VX8nSpulj+v6/wD6zjj245PrS7L8 f8gPzXm+H2q+b+49P+fP2/w59f5VX/4V7q3+RX6YTaboU3/Ljbf+ARPpx0/Sl/sfRP8AoE23/gEK PrPkvx/yA/NaH4b6rP8A6/jP9B/9f+uBXcab8K9Dn/5Ct94ttuv/AB6aPo3X/wAKT/PbOK++f7L0 r/oFW36f4VPDo+hmX/jxtvX8B0/Suv6z5/j/APbAfD8Hwf8Ah/5Xn/2r42z/ANi3o3b6+JOc9Tj/ AOvVf/hT/g2b/Ua54t/8JvRv0/4qTn/PpX3BNpGlYHn2Ntn8fw6/5/Ck/szS/wDn3tv1rk+tLsvx /wAgPhCb4P8Ahz/oOeJPf/iT8cdf+Zk7fz5HfKf8Kr8O/wDQW8R/+Cdf/mlr7xm0fQ/+fG27fkOT +R61W/sjSs/8eNt9n+pz+eP6fpR9aXZfj/kdHsH3/r7vNfefCP8AwrLwr/qf7V8WY/7FvRc9P+xk /wAmsa8+G+hwxZsdV1u5xz/pej6N9eP+Kkxn+Wfy/QD+zNDzn7DbfaPXP/1v8jjrViHTdDm/19j3 7H8P1Fdf1nz/AB/+2Oc/MebwHqsPP/HznHf6/wCe3+Cf8IHqvm+f2zjHv/6D7fTj2r9Mf7B0qbpY 23rz/k8n/PNV/wCwdD83/jxtv/rdfpnv65/Oj615/j/9sB+a/wDwgWuev6D/ABpf+Fea37fr/jX6 Xw6Dof8Az42w9vqenr/X09aX+wND/wCfC2/8eo+tef4//bAfmf8A8K81v2/X/GrH/CvNb/6dv1/x r9J5tB0qH/lxtvw/pWfNoOh/8+Nsfb6Hp6/19fWj615/j/8AbAfmPrHhzVdG/wBfBi3/AC/+t16/ p749fox8SPhL5MvnwQf6PdaPpd79f7d0X/PfPFfD/irwrPo9/wCf9nzBd88Zz9Ox+n5Ct3ilHeSS WmrSs+3xfgNJt2SbfZK7+5HD/wCp/wA5zn8vT26fmT9vw/rWgbKfnz4O/Pr+H9fr9c59JSjJc0ZR lG17ppq3e60sDTW6a9Vb8yv537r/AOtx0/Pp+nvzVjz/AG/T/wCvVfyPf9f/AK1Hk/8ALD8Nv65x /n696oQVoTXnnWH9lCC2/wCPz7Z/j/M9+e/HNV4s5Hn/APAsdffp/nr7VX8np5H06fTHf6fzzQBY 8/2/T/69V6IYf8/5/U49gKP+Wv8An+9QBY/1P+c5z+Xp7dPzr0nk3H/PAf5/Clg7/j/SgCxRB3/H +lV5v3ue3T/Pf+tWPI9/1/8ArUAV6sf8s/I/Xv19enX9Pzo8n9352f5dc/yzR5Pky/l6/j+H046c UAFHn+36f/Xo/wCWv+f71Hke/wCv/wBagAqxVeHyPK/zj2/D/PpR5Hv+v/1qANCGHzpfIPOefx9s H/PUVX/1M3t+XX+Y/Ic9qPP9v0/+vR5Hv+v/ANagAhm//V/n9R+Io/103t+fT+Q/Mcd6PJ8n9xn+ nX/DPvzzR5M/m/8AyJn8O/P5c80AHk/uv846fXPTv+masef7fp/9eiGeCH999fUHv9f/ANfpR/17 /wDAf8n8Ov4dqALEMMH+ouJ7n8uf/rf09KIYf+m/r/Tr/LH41X/6d/0/X/6/T29qP3v+d1AFiDv+ P9KsT9vw/rWf53Xz4Pr/ACPH59Pzqx5/t+n/ANegCxB3/H+lEHf8f6Uef7fp/wDXqxQBX/e/53Vs abps95dW8EMH2i4uv9Cs/snb/PHQZPGKx6+4v+CeHhuw8SftwfspaVfWVtqWkap+0f8ABv7XaXZ6 58a+H89OxGc8jr6V4ed51LKcmzbHK16VKrVvfb2NN1b6tL7Nt+tlrv6WW4b63m8cE9pOK07Nx176 J9umt7XP6qf+CMX/AARL0r4VeH9I/as/a08LW2pfEbVdIGtfCH4UeIbL+0T4UIAOheM/HOh5/wCR gB5XwrwfBhwzKDgL8e/Gf4sa78Qfi/8AtEa2b/8A4k9r8a/Hfgzwfaf8wuw8L+BwNCHPbg654oPv 65r+z/xVqU8OjXFxBwR/po78E56D6e/t1r/P4j1i4m1X4oTwTjN18X/id0H/AFGBg/y/Gv4F+jv4 kcR+K3ib4gZ/m+aydOhUjRo0lObpUqcZVf3cItyUU2k073b9pKTlKbkftPHeR4Th/h7KsLhFZyin KWnM3aO70vp+nQ8e+LV5PeeN9Yn8/wD6Bdl/5RdA98ge3UivJ/tnlf8ALDGfx/r7fpW/4qvJ5vFH iDz+n2z/AB4456VxE2pWNl+4nvrb/wADfr/T8DjvX+gWF23v7v67/M/DAmmn6dv/AK/+Pvj06nCe dqn/ADxH/fIqD7ZYmX/kK21rb/8AX5/+v6fX9bH9pQTf8xW2H/b5/Xufw9e+a0APNm9f1H+NWPOv /Kz5Hv17fXP4+me+eKrzXkHm5+3W3r/x+dv/AK+a/QD9hvwf+xp8QrD4wf8ADWHxGufCWoaX/wAK vHwru7PxJ/wjf2//AJK7r3jrRT/wj/8A2BPA/hft/wAIWdfA47AHwf8AbL/zvwzj/Pt/+rtR519D L/qO/uM//rP5V+9EP7Pn/BI28uvDFh4j+NP/AAiWn3Wj+KLLR/EPh342az4l1Pxbpf8AxYP+wvid 440P/hG/+Lf+Iv8AhI/HHxU8Lf8ACrfCeP8Aii9A/wCE5/5lGvl/4M/Cv9h/Xvhz8ab74geONN/4 SDS/jx488F6Pq138bP8AhCdT+GnwH0LRdA/4QXxp4H8D/wDCN+Lv+FweI/FniPXPHPhfr/zAMe9b ewj3j+H+XmvvA/K+aa+/D07e30yR/j2rsPh74P8AGPxO8eeD/hz4NsbnUvFHjzxJpfhjw1pNp/y/ 6prut/2D/wC5z/IFfuBN+y7/AMEqLzWfEFjq3xpHgnUPsXgP+x/D2k/HjRvG3hn/AJDXx8/t3/iu P+Eb/wCasfDnwP8ACvt/xRXjXXwP+Zurh/gD4U/Y60Hx5cfFT4V/He5/Zd8c+A/2Y/AetfDfxDq/ xg0bxtqd/wDtafFfwVr+vf8AMw/Db/kXfhP4c0PXPC/jcf8AQ6ePvDGPav8AYv6uc54P/wAFSv2C b79gP4g/Cfw5pV/qXiTwf8UPhvpetWfiG7/5Bn/C0NCP9g/FfRf/AAo/7D8UdP8AmP8Ahjr3/K/7 ZP5OPwz/APW9Mc/1r+iD9qL42fCv4zf8Iv4H/aN+OHj/AOP3gfwv8Bvjx8aPhxq3/DQnwb03+3vj J4F8F6B/YOtf2J4f/ZvH/Cv/ABF8WDrmu/C//hFfFmf+QB718T/s6/s9/sPfEL4VfCfxH8VPjT4k 8N/EDx58VP8AhUmseCNJ8YeDdN/sLVNC/wCE98ef8Jn/AMVB4b/4p/4d+LPDg+FfwvHinxZ/yJfj Tx9/wnP/ADKH/CFk/wBi/q/6ju+7/r/hl9x+T/8AaWq+b/qO349PTp04z6/lWxDeXwl9Og9f8598 8elfrh8YP2M/2XvB9/8AB/xj4H8cal4l+H918VNU8F/tIeE/+F8fBzUvE3w00vXdF+EWg6Fouh65 4f8Ahv8A8VB4i8KeI/HHjf8A4qr/AIQ//hC/Gn/CA/8AMmn/AIrQdx4b/YD/AGQfHenweI9L/aTt vAMFr+1QPBWr+CPEHxU+GfiTxNp/7MH/AAmuvfCX/hNND1z/AIRrwiW+Iniz4i6FonicAEeC/wDh DPH2T4IOD4zJ6CPxv+2/uun+kfT/AOv69/XtWd9suPQfn/8AXr9oP2hP2Cf2V/hv+zn8ePip4O+K niTW/iB4DvPC974b+Htp8YPg34k/sHS9d0XwD/bv9uf8I/8ADf8A4uAB4j8ca5/yKf8Awh3/ACAO a/FCbM3+vn78fZOn5fh2+tc4E/8AaNx6il/tKfzf9R2/Hpjr6Z4x61n/APTv+n6//X6e3tVnzpyf 3E9tz/8AW/XP9MUATf2jceoqzDqfn+n9f89P/wBXNZ8/b8P61XoW6tv0Og+sPsdjr2g6P9oFt9o/ sfS7L/yinv2/Kvrn/gkL+z34O+JH7d+o2Pj/AMK+E/G3hfQfhZ4nvbPSfFukaN4k/wCJp/bWg/8A E6x4gxz15zxjA68fA3hu8n/sbT8z/wCccdDn1+uBmv1g/wCCIV5PN+3D4wn/ANJ/5JZqeMe2taDn uO+P1r8R+kJnmMyfwk4rxuAk4ZxClUtPVWUoW0fTe19N+mrPtuAsLGfEeVKSTTaumk18Ub9PS+/n 3PrP/grV/wAEZfh/8Vfh9P8AEX9mf4V+FPBXxW8MXf2y80jwRo2j+G9N+JGlD5f7GGhaCB4ZHiIY /wCEn5Ayue3A/ho17QdV8OatqOk6rY3OnaxpV7qlleaVd2mNRstSOckj3wMc8YPfBH+v1i3miPnQ /aR/x+47evr7njp6jqa/zZP+C3nhvQtB/wCChvxmg0SxttNg1PSPhjrV5a2nI/tPXfBXh865rI9P mLZ+vPHT+Y/oN+OnE3Fk818POJZvOquGyBYihiJyk61N+0pxVO7b5lGUozjde5yuz5ZNH6N4vcI5 Vg8JDNsIuVuykopRi9ryt0vr5a9z8fPOnh5n/wA/5/PGTxRNN/8Aq/z+g/E0TTQed9P89uf5mj/X f5xjH5+vv1/L/RlKyStaySt2t0P573K/nfuv/rcdPz6fp781Yhm//V/n9R+IqvP2/D+tH/Tx+v6f /W6+/vTAsf8ALX/P96ibyf8AR/T8P17/AF/HtVfz/b9P/r0k3+uP1H86ALP/ACy/z/do8n99/r/0 /wBrr/nv2xVeiDv+P9KALAAm/fn/AI9+f8/z6cYz70D/AJYfj/Sq/lTen6D/AAo/e/53UAWJ+34f 1qvR/wAtf8/3qKALH7jy/s/bp+mPr7Y9e+aIfI4/D8//ANX3qr/8tf8AP96rEHf8f6UAH7iCLvz9 M/1P/wCvv3sed/07/rVfyf8Ap4/SiH9179f89v6UAWKsedBDnyMjP4f5/lk9qr+d/wCBP09/z6fp 7UUAH+u/zjGPz9ffr+RR/wAtf8/3qP8Alr/n+9QAfvf87qsQd/x/pR+4m/f/AGjr/wDq/wA9PxxV c/663/z2FAFj9x/qP0/Xr/n196P9TL/r/tP0J6D6fh/P1o8n/p4/SjyPf9f/AK1AFiGaDp/n/P4/ Xtgg7/j/AEquP+WH4/0qxDNPDFjnr3/Ljt2/WgAz/wBN/wBP/r1oQzeTED9P/wBXb/69Z0P+uH1P 86sww/5/z+px7AUAH/Xx/wAC/wAj8en496/QH/gmZ/yfr+yBBk/8nH/DDORx/wAjnoB7e+O456V+ f0MM/m/1/Dj347c5r75/4Jiw/wDGe37H/wD2cf8ADD3/AOZz0DHXpzjB/PmviePkv9ReKnp/yTHE Tva9movX5Ht8Na8RZTfuv0P9P7xh/wAi3c/9eQ/mtf5/Ohf8f/xJ/wCyp+O//TvX+gf4wh/4pe4/ 68+O35Dv/wDqx3r/AD79JmzqHxAng/6Kl47x1z/yGR+Rz/PvX+aP0Er/AOsHiFu/3y1+/wDPV/ef vnix/wAibKOnuRX/AKQfJ/xg1KezuvEE8E/2b/icaXZXn2TsBx/k/wCR4/qU1jqUtxP/AGVoltcf bPtv/Eq0f+zdM/p+B/yPUPjl5Hm6x/2Mml/XPOM549OvevJ4bzz4reD/AEYfZfX/ADjnj+p9f9UM J8P/AG6vzP5wM/8As2yz5H2G2z0x9j/X/IrY0HwrPrGqafoelaUNS1DVLzS7LR7S0s/7S1O/1XXd a/sD+xdE/wDKH+GaseTBeRXHkf6Nb/5Hp3x078V+5H/BFX9kX/hZHxQ1D9pPxxpJuvA/wbvP7F8H 2d3Zn+zNe+KH/wCCfhz+w/E/f/itNf8ADHJxXYc5w+m/8EH/ANqjUrW3uP7V+CdtcXVn9t/sn/hJ NZ/0D0OP+Eb4/wAcg8VX1j/ghj+1DoNhqGq6r4j+BWm6fplnqmtaxd3fjDWf9A0v/oNf8i3z+X8+ P24/be/Z1+P37S3ijwfP8I/2r9E+Cfg/wbo+qG88PaTrHjL+09e8Ua7rX/E91nXNc8P+JP8AoXND 0Pn+tfzj/tyaP8cP2afiDb/A/wAR/tb+JPjZcXXg/wDtrxhaeHvGHxL/AOEZ0H+3f+QFouuf8JB4 kH/Muf8AFUEZ4/t/8a5PrN+i/H/ID837zTrGG/uLH/iWXNva3v2L/RLP/iWf8x/v+Y9eeayPJghi uB5Ft/4Bkn/6w/zx0q9Nn/l4+y9f+XX1469sZ/8ArVQoWHvrzb67y8vPyX3AV/JgzjyLb7R/15H/ ABx15+ntxVeb/P8Aof8An6Dn6ntVj/U/uP8AJ/HPv096rz48r9/nOe2emf8AP49OaPqq7r8f8wK/ kwZx5Ft9o/68j/jjrz9PbirH/TeC3tvtH/Xn6D26evt+RNeab/8AV/n9B+Jo8/2/T/69H1Vd1+P+ YB50HlH9x9pt/T7H+fHt/jmjzoDFm4gtufw/x9v6Z5qCb/Un6D+VZ15+/wDs8H+HH/6vfrjGa6vq 66W/D/5ECxN580v7gf6Pj/nz0b/JP6dq2LPwd/aUXn4th/192f8AP/6/v3xVjQdN/tI9P89PX/P4 V6RDDBCfIz0/n7/z/KmBw8PgOx/5b33P/Xn9e/8Aifzqf/hCdKhlPn8/hzxz6/T/AArufNh9f1P+ NVpv9cfqP50AcDqXhux/5YW9t/kdfwOfw9RW/wCD9SnmFxpXkfZja2eln/j8P/IU/tkf8To/oasX nf8A4DWP4J/fazrH/Xn6/n+oA7cd+9AH1jo//IG0/wD68h/M1+s//BD2b7Z+2v8AEHpm1+Ff44/t rw/6/wA+vHbNfkPo/wC5sdP8+f8A5c/f/OePzH41+wH/AAQrh/4zI+KE/b/hW/X/ALjWg5Oe/PP4 ntX83/Sg08GuPnt/xjbs/NuP4vX8T9J8N9eLMrvrq99f5T+xD/ll/n+7X+bv/wAFz5fO/wCChnxX z/0KHww5Hv8ADDw/0/8A1V/pID/lh+P9K/zaP+C4U/nf8FDfi/8A9i58MOOef+LYeH/69v0r+BP2 f3/Jzs2/7Jhf+lZF/m/vP2Hxj/5J1f4n+DjY/Haift+H9aKrz9vw/rX+yZ/KpYo/1P8AnOc/l6e3 T86/+u/zjGPz9ffr+R53nfuOvp/nPGMH69O2KALHk+b0HT3/AM+v60f8sv8AP92iHP8A288+v/6v p269qWb/AFJ+g/lQBW87HPkfZvb/AD0z6fp6WKJ+34f1o/5Zf5/u0AHke/6//WpZv9SfoP5VPN5H lf5x7/h/n1pIfI6zzjH+eMfrz9aAKH/LL/P92j91/nbViq//AC1/z/eoAsf8+/7/ANSf69P5fnRL nJ8j/gOevt1/z096KKACHyPN/wBI9e2OmP5fX+dWKr/8sf8AUe3/ANf8u/p2ooAKIO/4/wBKPJ83 oOnv/n1/WrFABN++lxx6jr+vPb8setH+p/znOfy9Pbp+ZRQAUQd/x/pRR5PTyPp0+mO/0/nmgCxz ND9f6f1/zyep/wAsv+Xj/K5/nR53m9849sf56/rR/pEP2f8A0j39/wDPf0/DqAFFFH/LX/P96gDQ m8jzT9n9e+OmP5fT+dEP7326/p+f9aIO/wCP9KsQw+d58/kf8evv/n168Z7dKAK8MM/m/wCv/P8A T6HH0r9Af+CZn/J+v7H/AP2cf8Lf/Uz0HNfn9NDcQe/68+35V+gH/BM2E/8ADfX7H+On/DSHwv8A /U00DoT1/wAivjvEH/kj+Lb7f6r8Rb7W5F+p7fDP/JRZT6r9D/T/APGH7nwzP/15aZ/MD39MV/n4 6d5EOqfECA/9FT8d5Pv/AGyP89sn6V/oD+MB5+g6hB/059c/56Z/p9P8/HT/APkM/EHPX/hanjr/ ANPC1/mb9BT/AJKLxC8q1vXWTP37xgX/AAj5RbdpPzt7i+7R/ifIvxr/AH11rH788eJNL55//X9f pivF/wDlj/r/AH9/p+Xb074r2D44f8xj/sMaZ/7LXk9n+/8As/t6f59hj+tf6n4T4f8At1fmfzMe kfCXwH4q+KnxB8IfDHwPBbXPijx54k0vRdH+15Omf2p/0Gtc5/5F3p/kV/cx4V+AEHwl/ZV0/wDZ s+APjjRPAGoaD4D/AOEZ8N/ELVrP/hJPsHijXf8AkO+Nf+Kf/wCES/4qLxZ4j1zXPFHqP7fzj/ik q/he8B+G59e8R6fYwarc2v2rj7XaH/iZ2H+Gf89a/RnR/wBl3+0rC3uJ/iN8SLb/AK89Y/znnjgG sMTiX6v8n/X/AA97JB9seI/+CJ/xG0HS7nXIP2ttE1u4+2Y+yWngPWdN1K//AOJ16f8ACyP+RiOO e+a+f4f+CS+heNpfjB4j0P8Aavttb8D/AAl8eap8MdY8b6t8B9Z/4n3jzQude0XQ/wDi9n/FQ/8A CJj+w64eb9kabyvI/wCFm/EjFp/1Mn8x39/0os/2Rf7NtbjStK+JvxR03T7q8+23lpaeJP8AiWeg /wCRfz19jx+VL60v7v4/11X3geT/ALXX/BPGf9kv4aaP8RvFXxp8N+Nv+Eo8S/8ACvtH8PeE/Af/ ABM/+E90LRRr3jrwV441z/hJP+EX8Pf8In4d/sP/AKnTxpxkEeEK/M+c/wBR9rH6dv1/+vX64ax+ xbpWpReRffEDx/c2/wBs1S9+x3esaNqemf2n/wBBr/sY/wD9f15//hgnwd/0NPi78tG/+Zymswwn d/e/L/P8+zA/J+ft+H9arz9vw/rX6sf8ME+Dof8Ama/Fvrz/AGN7enhvP0qh/wAMHeFP+hj8W/8A lE/+Zuj+0MJ3f3v+uv59mB+V3/LL/P8Adqv5U3p+g/wr9SJv2CPCvT/hKvFvX/qC9+f+hbx2/Dt6 1Xm/YP8ADnlf8jV4t7n/AJg3t/1LZ/Pr7jpR/aGE7v73/XX8+zA/LeaH/pv6f16fyx+NENn502P+ Xcdv8P58dO2elfpx/wAMK+HIZT/xPPEn1/4k3vj/AJlv/PU+2xpv7BPhzGP+Ej8Sf+Ubjt/0LfPP 86f9oYTu/vfl/n/VmBX/AGYv2Vvhl8ZvhL8L9Ug8Y+NtN+JHjL9uT4D/ALMfiTGj6NpvgbQfAfxX 8F+Pte/trQx/zMHiL/iR4/5k7wX/ANSP/wAzpX1Bqf7Iv7Ifhu/8ca54qg/aQ0P4b6D8B9U+Ot5q 1348+Df9p+Ev+K18QfCXwL8Mdc0MfBP/AIqDxF8WPjT/AGH/AMIR/wAid/yH/wDqURWfoP7HP9m6 N/ZWk/E34kaJp/8Awkml+NLO0tNY/wCJZ/wnmhf8gLxpzn/iovCf/E8/4QjxT7V0HjD9mnxV48l8 Tz+P/jv8Y/Fv/CZDwvZeMP7W8Sf2l/b2leBda/t7wL/bn/CQf8jB/wAIn4j/AOKoHYUv7RfRsD0j /h29+z1NLbwT+Kvi1jwvo/iiy8SaTaax8NPDep/Frx5oXgv4ReO/7a+FfjjxB4b/AOEY8P8Aw7/4 rjB/4Szwf4xx/YH/ACPBxX4//tFfDeD4M/HP4wfCWx1W51u3+HPxI8UeC7PVrv8A5f8AS9C/DjxE cY/zmv1Qh+EvxbsrrwvfaV+018frbUPAfhv/AIRfwfd/8Jh/yKXhf/oC6GP+hdP9h6J6jp7V8P8A 7RX7NP8AwrfwvqHxH/4THW/EmoXXiT/icXfiH/l/1TXdax/bfPX+YowuZXaWmr29bf5+WwHxPWP4 DhP/AAkfiD9x/wAufv6/17+ntWh/y1/z/erH+HsxvNe8Qf8AXn09T78/416cdXHza/ED6o0eE/Zb fH+P9R36+n0r9eP+CEuf+Gv/AIsT/Z8H/hW/8ta0D/PcevTj8j9Hh/0XT/8AHv8A49cdvzr9gf8A gg7/AMna/Gn/ALEQ/wDp6FfzZ9KH/kzHHn+BL5e5ofpPht/yVuV+r/8AbT+w/wD5Zf5/u1/mo/8A Bbjj/gob8bjB0ttG+F9n3/6Iz4C9f8496/0p5v8AUn6D+Vf5qP8AwWsl87/goj8fSe9j8MB78fBn wGCefU59uK/gv9n4r+JueP8Al4VT++tw9HX5SZ+weMb/AOMdj5zaX4foreh+Rn+p/wA5zn8vT26f mfuJvQ8fTIP+fbr70T48r9/nOe2emf8AP49Oar+T08j6dPpjv9P55r/Y8/lYKP8AXf5xjH5+vv1/ Kv5373E/P8sfrxx/k9LFAFiGH/P+f1OPYCjyf3v+c9frjr3/AExVerHn+36f/XoAn/ceV9ox/pHT 8Ov5VQ/5a/5/vVY/69/+A/5P4dfw7VX/AOWnn/p26enXp+v5UAWKP9d/nGMfn6+/X8q8/b8P60UA WP3EEXfn6Z/qf/19+9eab91+H8/6fqOlFWIYYJv9f/o1t9R1/wAPrnjHrQAeT+68+fP8x/kD+veq 8Hf8f6VYm/cS+R5/2q3/AOfv8DnHH/6+vfg/ceT/ANPGfx9frnP+cUAHn+36f/XooooAP+Wv+f71 EHf8f6UUef7fp/8AXoAsf8sv8/3aPO/deR5H498Z+vXPFFHn+36f/XoAD5EF1+4g+047/wBO3H5f oasTfvjx/o+c9T/PB/Kq8EX/AC3z7D9R1/Xn3xRQAeR7/r/9arEMP/Hvj/nz9fy/+t+tFFAFj/Xf 6jn1/XPpj26e1EHf8f6VX/1P+c5z+Xp7dPzsUAWP3X+dtWIZp4Zf3E+P8jj+fr+JrPqxB3/H+lAF iaYy/wCf1+vT/Gvvr/gmlMT+3t+x/wD9nH/B0+vTxnoPf+p6+lfn75PP/Tx+vX6/5FffP/BMzP8A w3l+yB/2cf8ABz8v+Ez0D+v618Xx5/yQ3FKf/RMcQ/c1+p7fDP8AyUWU+q/Q/wBP/wAYf8i5qH/X j/Sv8/DTvI/tT4gev/C0/Hf5f2yP8n8a/wBA7xh/yLdz/wBeQ/mtf59Np/yFfiB/09fFPx3+ms+/ t/Pnvj/M/wCgn/yVfiFr/wAv4Kz2s1K/9eZ++eLH/Imyj/BH/wBsPkb41/63WT5//Hp4k0uyxj6n /PTH0rx+Dv8Aj/SvUPjX5/8AxMP+nrxJpfHv/j/gOleTwd/x/pX+qOF2fp+p/NB7h8Bv+Sgad/n+ Kv3Y8Hw+dpdvn8evt6V+EHwA/wCSj6b9P8K/d7wf/wAgu3+g/mK87MvtfMDufI9/1/8ArVX8j3/X /wCtWxRXzd33f9f8MvuOcz/scHnZ/HH/ANf1zx/Sq/lQ+n6H/CugrPoA5+az/wA/y5/mfw9qsTWc H4evftj+vb+Wa2KoTf6k/QfyoA56azg/D179sf17fyzWf5UPp+h/wrqJoT5X+en+H6ntWfND/k/5 /I49QRQBz80P+T/n8jj1BFdRoOmedL/h+GP19en4Vj/8tf8AP96u40GH/j4/T9c/15/TpQB0E0ME P2f/APXntj/PPvkcV/Kh9P0P+FWJv3ue3T/Pf+tV66AM+aGDr/np/nt9O9fE/wC3VDAPgFrEH/Uy eA//AE9cZ/znt1r7Yn7fh/Wvif8Abv8A+SDav/2OHgP/ANPRqsLf69FP+ZadPs30Og/E/wA/2/T/ AOvVD4VnztU8Qev+f/1+vt0pJv3Xv0/X8v6UfCQn7frHPH2Qj9OB9K+1jsvRfkB9oabZwf2fp4/6 c+n4c/5z+Ffrz/wQftIIf2rvjBPDP9p+1eBNMN5z/wAeBOtcflgHr39K/IbR5oP7Gtz6+v1z7/4Z FfsB/wAEGZRN+1T8cCc/8iJpn5DWh/Pv3469K/mb6ULa8GvECza91dfOn+v9d/0jw6v/AKx5T6K/ e91v1238j+v6b/j0/P8ApX+aH/wWgi8n/gol8fQZz934Yfp8GvAf+f8A6/Nf6X03/HhP/wBeY/8A Zv8A69f5nP8AwWmPnf8ABQ34++6/DD/1TPgPj9e/Pb3r+Ef2fl/+In8Xf9kvD/1IyC//AAT9a8af +RBDzkmvPSmvnpf8T8nar+T18/6dPrnv9f55qx/yy/z/AHar1/sfHZei/I/lyOy9F+QTQ/5P+fyO PUEUUUUxlf8A5a/5/vVY/wCnj9f0/wDrdff3qvDDB5v0z/n/ADk+ozVigCx5Hv8Ar/8AWqvVift+ H9az5+34f1oAsUf8tf8AP96ibz/K/wA49vbGM0Q/vfbr+n5/1oAKKJvP5/H8v/1/dog7/j/SgAqx 5P7n/X/p/s9f89u2ar+R7/r/APWqxQAfuv8AO2ij/ll/n+7R5PldR19/8+n6UAFFWIO/4/0og7/j /SgCvVj/AFP+c5z+Xp7dPzsVXmhPlf56f4fqe1AFj/U/5znP5ent0/OvRD/y7f8AA6P+nj9f0/8A rdff3oAIZp/J+n+e/H8xVijyfJiuB6j+v6Uf8sv8/wB2gA/13+cYx+fr79fyKseR7/r/APWqxND/ AJP+fyOPUEUAV/8All/n+7Vj/U/5znP5ent0/Mqx5Hv+v/1qAD/XRf8AXr9euf8AH9T6dfvP/gmf 5/8Aw3f+yFnH/Jxvwd+uf+E00D179K+DP+Wv+f71fen/AATQ/wCT8v2Qv+zjPg7/AOpnoFfF8dW/ 1J4sX/VK1tPWi/z1Pa4b/wCShyj/ABR/9Kif6fnjD/kXNQ/68f6V/nwWt3/xNfiAOf8AkqfjrJ+u sAn04zjkj0zX+g94x/5FfUf+vT/Gv89q28/+2viB+4zj4peOep6/8TgfXntX+ZP0FP8AkrPEP/sJ hb09++nbv/wT998WP+RNlH+CP/th8i/Gaf8A5CHH/MY0r/PX8cfj7V5PB3/H+leofGX/AFOr/wDY Y0v+teTwzfuvw/l/T9T0r/VbCfD/ANur8z+aD3D4D/8AJRtP/f8A8v5j27Y9+lfu/wCD/wDkF2/0 H8xX4H/A2b/ivNPzP+frz2r96fBP/IKsP8+teLnLd3q99PvWwHqEIn4/f/j+p/Dt7n0oqvB3/H+l Hn+36f8A168U5yx5/t+n/wBeiiiab/8AV/n9B+JrnArz9vw/rVf/AJZf5/u1YrPvMwy5gH+eO2f8 9/SugCvP2/D+tZ9aE/b8P61jz9vw/rXOAkP+uH1P867nR/IhiuPIn+1dv8Px/p+FcfB3/H+ldRo/ +pP+e9dGG6X8r3/7d3A2PP8Ab9P/AK9FFV5+34f1oAz5pv8A9X+f0H4mvhf9vCb/AIsPqH/Y4eA/ b/mND+fAxxn88/b95/qh9D/M18Mft1f8kM1jyOn/AAkfhf6dPzx/XrXVhf8Af4/4ltt9kD8T5pv+ Pj/H8uD+n5etX/hL/wAfWsf9eX9aoXkJ/f8A6f8A1ufp1+tHwrE8N1rHpj6dwa+2h9n5fodB9s6R n7Dp3/Xp29Mj+nWv2H/4IGwj/hqT47zDj/ikNLP/AJeg7fh9K/G/w3emaK2gng/49bPJ/l6/n2zX 7Q/8EDc/8NL/ALQHTP8Awh+lfT/kdG/Gv5k+lM7eDHH3/XuN/S8Pw0f3M/SPDi/+teWX/vW9PdP6 5rzP2Wb0+zc/ka/zO/8Agsrn/h4T8ff9z4X/APqm/AX/ANev9MS8/wCPC8/69NV/k1f5nX/BY2Xz v+Chn7Rv/YW8Bn/zDPgP/wDVnPbNfw5+z0V/ELi59uFr+v8AtHD8fuvf7mu5+s+Nd/8AVXLLfzx2 9In5S1BN/qT9B/Kp6rw/vfbr+n5/1r/YVLRJ9kn9x/Lq2XojZh0fVZtLuNdgsdT/ALHtbz7Feara 2f8AxLLDVOCAfX9Bj0BrOmh/4+P8/Tk/p+frX61f8EmV+F3j74t+MP2SP2gNT07Qfgz+1D4ZXwbr HizWLsqfAnjnRtXD+AvG2hg4zr/hfX3VgejowYZBBPxV+1Z+z54h/Zk/aF+NPwC8STXN1ffCb4k+ KPBja9daTq+k/wDCWaPoGta7oeheMotIk8wroHixV0XxKhIZv+J+BiQuUrgw+JTxbym9m3dLdtNp rXrbql/nbrxGWt4T655622T0eut7O6dteumh8xfuf+3n8f8A9fT/ADmirEucnyP+A56+3X/PT3pv /LL/AOS/8/nXobeRy2toQ1Y8j3/X/wCtVf8A5ff8+lWJ+34f1oArzfvc9un+e/8AWj/U/wCc5z+X p7dPzKPI9/1/+tQBYqv/AK6b2/Pp/IfmOO9WP9T/AJznP5ent0/Ov/y1/wA/3qALEHf8f6UUUUAE M0H/AB8dv89vz/pRD+5x5/8Ay9en/wBf0x/nIoH/ACw/H+lWJ+34f1oAr1Yg7/j/AEozD/z7/wA/ 8KsQ2f8An+fP8j+HtQBXqxDD1M5/z3z/ADIP0JrYhs/J9/y/r/nrVjyPf9f/AK1AGP5MEP8Ar+bj +v8Ah2x1/CrHke/6/wD1q2P+Wv8An+9Vj91/nbXOBjww/wCf8/qcewFEMP8An/P6nHsBWh/17/8A Af8AJ/Dr+HarMP8AqR9D/KgCtDD/AJ/z+px7AUTQ/wCT/n8jj1BFWKP9d/nGMfn6+/X8gCv5Hv8A r/8AWqv5Pnf8sMf56dsY/rj67Hke/wCv/wBaq/k/urjB4/w/z75roA5+Dv8Aj/Svvr/gmvFj9uv9 kqfrn9o34ODr/wBTr4f/AMK+Df8Ar3/4D/k/h1/DtX3n/wAE1/8Ak+v9kj/s434O/wDqa+H6+K4+ /wCST4r/AOyUq/8AptntcN/8lDlH+KP/AKVE/wBQTxf/AMgHUf8AryH9K/z2TN/xOviB6/8AC0/H fr/0Gcn/AA9/pzX+hR4x/wCQNqP0/qa/zx4ofJ1Dxxj/AKKP47P/AJWQM+39ev1/zR+gr/yVniI/ +oiP3PnT/r/I/dfGFtZPlOtlyaW/7h3/AK7fM+RvjN+5i1Dr/wAhjS/8/p9c814/D++itx/j1/P8 RzXuHxh/48Ljzp/s3/FSaWLy7H/Ya7//AK+PWvF8QQy/YYJ/tNva3n/H39i/s03/ANf0/lz3/wBU MLs/T9T+eD2j4DzH/hPNPyP07/5/D2Ffuv4Km/4ldv0/I/5H0/HvX4M/BODyfHmnz/X+ff1/DvnH ev3X8E3nk6Xbdh9j7/1/z1x7Z87OF8Tt31/8AS/X8TnPUIO/4/0qxWPPqUF5L59vB9m/6dLTrn8P 0BA5qv8AbPf/AMdr5uz7f1/TX3nOdR5/t+n/ANeisf8AtP8A2f8AP5UfbPf/AMdoA0Kz5pv/ANX+ f0H4mq/9p/7P+fyrPmvIP8/p37fXnPXtQBoTTf8A6v8AP6D8TWfP2/D+tL9st/Q/n/8AXrOmm/8A 1f5/QfiaLPs/6/4dfeBYhm/e/wCSf8/oOldho84miuIM/wCePf8AAZ6V5v8AbPf/AMdrqNBvP9Ku IPPx/n0689e/Wiz7P+v+HX3gdxRR5/t+n/16PO8n9x09f855zkfTp3xRZ9n/AF/w6+8DPn7fh/Wv hf8Abr/5IZf/APY4eF//AE9CvuC8/ffh+HX16/5696+H/wBuT998EdY/7HDwGMf9xr69v/rZxzXV ly/2rb0/8CX6P8QPxXmi/deR/jxz6e+f/rUfDGbzrrUAYBi1+v8AT/Pua2PJ83oOnv8A59f1rH+F cJhv/EJnx/x54/P6dP8APrz9segfY/huz/dW03OMf1+vX/OK/aH/AIIGw/8AGRv7QH7jj/hD/C/t /wAxvt07f07dfxn0f/kGaf8A9ep/z/Kv2g/4ID/vv2jP2iP+xb8L8dv+Q1n1/X1x9K/l76V9/wDi CfHvb/V2PpfT8T9J8Lv+Sryv0X5n9a97/wAgy/8A+vTU/wCtf5lP/BY7P/Dw39o6c548R+A8f+Gy 8B+ufqev+P8AprXn/HhN/wBeh/8AQRX+ZF/wWAz/AMPCf2j/AE/4SLwt/wCqy8BdP61/FH7OvXj7 izr/AMYrD/1oKX6JfJI/WPGL/kn8r9f0Py9mm/dfh/P+n6jpVeGb/wDV/n9R+Ion7fh/WrEMP73/ ADn/AAz+h61/sA3bVn8rHY+D9Y1zwfrXh/xVYwXIuNL1jTNas7v/AKinbPTjgZ46c4PWv6p/+Cq3 g/Q/+Ch3/BOz9nD/AIKXfDPStNuviR8HNH0v4MftCWek2fA8L4H9hazrfA/5FPxINd8Mc5P/AAhZ 8MjOMAfhRo/gqyvP2R/HPn2Nt/bGl6x4EvbP/Q/+xg46/n047da/Wn/g39/ab8D3fiz4nfsF/Hef 7T8D/wBqLwzqnhm7tLy8x9h/tzRmBOhDAH/CQ7hofibI6nw8e4r5bOIvDYvLc3wb+Bx5t3aLlGOv RJSet0l7z7Wf0eTy+tYX+yW3rdpvZ6XXTVWu/krLZn80t5D+9ufPn5+oPX8un4+9Z9fXH7aX7L3j /wDZA/aa+NH7NnxGt/8AiqPhJ4v1TRby8s7PGma9pWSfA3jTRBjJ8P8Aizw4dD8UckYGv7T1GPke vqIvmSktbpPvv9/U8XE6SceqdrdbK9tN9rB/y1/z/eo/5a/5/vUUTQmXv7/j7+3H1pnN+u3mFH/L X/P96jyPf9f/AK1V5+34f1oAnm/1x+o/nSwd/wAf6VXo/f8Am/5z6fy/8eoAIO/4/wBKsUT9vw/r RDN+68jj9ev9cfj2xQAf8sv8/wB2rFV/I9/1/wDrVoQd/wAf6UAWIYf+Pf8Az9eR+v5+lbHke/6/ /WqvDFBNx09e3H+f064HNaFAC/8APv5H2n7R2x/9b9Mc/hmk8/2/T/69HM0P1/p/X/PJ61/+vf8A 4D/k/h1/DtXOBY5hl/1/r+XUZ/wNE00HT/P+fx+nfNerFABVjyPf9f8A61V6sV0AFaFZ9WK5wLHM 0P1/p/X/ADyep5MHld/8j64/+tx93miGHqZz/nvn+ZB+hNWIv30vkf5+v5/iO2aAOH/5a/5/vV95 f8E1s/8ADc37IfTH/DRvwbz6/wDI6+HsYr4Vh/fS54x0PX/D/wCtj1r7r/4JxY/4br/ZK8jp/wAN G/B3/wBTXw/0/HHv1r5Lj3XhPirVa8KVtXt/CZ7XDf8AyUOUf4o/+lRP9QTxj/yANR+v9SP5V/nl NN/xOvHH/ZRvHR64/wCZyUn/AB/wxX+hr4x/5AGo/X+pH8q/zwZ5j/avi/yf+ij+OjnPb+2Ne759 MdB05r/NL6Cn/JQ+In/YQr/+Tn7p4xX/ALHyjtyaffTufM3xmh86w1DnrrGl+3X8fbP4fn4f/o8M Vv8A6R/pH2L39P8A6/58dOK9v+M3/IG1D/sM6V/OvAIfI+y2/wBecdf/ANnFf6nYT4f+3V+Z/PJ3 Hg/xJ/wiuvW+qzwfaTa/8flp9O30/wAeeev3foP7b/hzTbC3g/4RXxJ9o973RvX6gV+cEMP+f8/q cewFFVicN9btt5vby7baW8/U5z9SIf29vCuR/wAUd4t6j/oDf5/z/F0pP+G9vCv/AEJ/i3/wN0b/ ABr8sM/9N/0/+vViab/9X+f0H4muX+zX/L/X9JfcP6u/P8f/AJE/VD/hvzwdx5/g7xb0x/zBvr/0 MnP4fy6WP+G/PA/lf8ir43zn/nz0bpn/ALGTHXjp174r8p6r+bN6/qP8aw/sbCeX3+n+X5dtT6u/ P8f/AJE/Vj/hvbwd5P8AyKvjb/yjenX/AJGT9f0zxVD/AIb38Ef9Cr41/PRf/mlr8vqr/uv87aSy 3B6e7rp0e4fV35/j/wDIn6kf8N7eDvK/5FXxtn/rz0XPTP8A0Mvrx6++arf8N4+D/wDoVfFv56N/ 801flxN+9z26f57/ANaJoT5X+en+H6ntXR/Zz7f1p/kvuQj9QJv28PB3/QueNvws9G985/4qT8/w rY03/goF4Hs7q3n/AOEV8bfZ+f8Alz0b06/8jJnv6+/Nfk/N5/P4/l/+v7tV4Jf+WGPTH8//AK3P vR/Z3l/Wn/A/DyA/bCH9vzwBNF58/hXxtbdf+XPRs9en/Iy/h6dKv/8ADe3w5hl/f+HPG3/gH4N5 /PxJ7Y7elfkRo83nWtv+/wD8g5/P8PWtjyPf9f8A61H9mvs/6/4ZfcB+rH/Dd/w4/wCgJ42/8A9G /wDmkr5/+P37UXhz4teDf+EO0rQ/Emm291rGl3t5q2rf2N/xL/7C4OB7Y/yevw/Pnzf3+MY7Y64/ z/Tij/lr/n+9TWXNNOz0/wCB/kh/V35/j/8AIljyYIenI/yP/r5/wrH8Enyte8UZ/wCfPS//AK3+ ePwrQ82H1/U/41n+Ff3WqeIP+fi6s9L9/wD9eP6+pxXpJWSXZWEfXWjf8elv+Nfs/wD8EB/+Tiv2 iIB/0Lnhj/09a97jvwOK/FbQf3Nhp88+f+PP8Ov+T9T9a/bH/ggaYJv2h/2iZoIPs32rw34XP561 r/8AUd/ev5f+lfZeB/H/AH5UlttzR072t0Xl0P1Hwu/5KvK/Rfmf1k6x/wAgvUf+vPVP5V/mQf8A BX3M3/BQ39pz1PjnTPr/AMid4FHvzX+m3rP/ACBr7/sD6p/6A1f5jf8AwV2/5SHftOf9jxpn/qHa JX8Z/s5lbxA4wfT/AFTT9P8AaMP+t395+seMX/JP5X6/ofmLN9nz++98+v6/561v6Dps95LbwW+f tF1efTHP/wBf8vTmsGb/AFJ+g/lXf/D2zH2qD/j5x35/+v8ATnPtX+tlf/dI37a9/iP5Ww2tr+X/ ALafph4bs4P+GXvixB59t/aF1rHhf7HaZ9cZ9s56fmK/OH4eeO/Efwr+I2geOPCt/c6b4h8G+JNL 1rR9WtP+XDVBj6d/0B9q+toTfab8L9Y1Uf8Ak3/+vjrj+Z9Pkn4eaJpnin4iafpuuTm1tbu+CXhB /ixnHX0ySePw6V5leWEWDzNu7SWiXVcvvKPS7jp6vvc+lyLLMZm+c5TgcHJQdSUYJ3Su5OKs9tn0 3t+P9TH/AAVZ8A2H/BSr9kL9lH/gor8F9F/tb4v6bpGmfAn43+E9KzqPiTXdL3b/AANrThAS3iHw o6634ZOFJPg3X/DDdq/mo+MH7MPxg+Clno+p/ErwsdGttUJslMl4l9kAE8/2A5VTjJxvbJwBycV+ /wB+zvfaX4d8FaT4e8LQnT9J01i1rpbEnTbLVmOSzMSSSTycnJPOete0ftM/CfSvjr8GNW0z7Pat qC2itZ3TZKnVFORrJGQSpxg8g4OK/Gcm8TsThcx/se0nT9o4ptrn5HNWu9Ve3VK3M2tVov8ASvDf QLyrF8AZnnmJzX/jL/YqdOn9jm5VJW0v5NKWzel9V/IdR53k/v8A/Rv0/wD1Dr7nPXNdh408K3/h XxJq2gX1tPaz6fdtZ3Yuc/6CwYhuCT3x07ds1x9fv9OSnCMlrdJuzTSezWnZ+h/mHmmVYvh3OM2y TG/FkdSUHHVP3Zcr0066NLZrXQP+W3/Tt/8AW/Pp/nFV6sQ+fDnt+uMfT365/wAaKs8tapPuV6sQ wmLv7/j7e3P1qv5P7r/OOn1z07/pmrH+p/znOfy9Pbp+YAUf8sv8/wB2jyPf9f8A61EHf8f6UAWP J86L64/HHX8c59+nFaFnD+6/f9vTv/k/Xn0os4YJpcT/AOjW/wD09nH/AOqtCH9xL+4/49z/AJz/ AJ+vFAFiDv8Aj/SrHk+b0HT3/wA+v61Xom/5d/xoAKKJ+34f1o8j3/X/AOtQBYg7/j/Sj/ll/n+7 RB3/AB/pVjz/AG/T/wCvQBXqxDN5MXkfz/w5/wA555zVfyPf9f8A61Fc4FjyPf8AX/61WP8Alr/n +9RzND9f6f1/zyep/qZvb8uv8x+Q57UAWKsQw/5/z+px7AVXh8/j8Py//X96iHz+Pw/L/wDX96gD l6+6f+Cb3kf8Nzfsgf8AZx/wb/8AU18P4/4D/wDWr4er7g/4Jyf8nv8A7JH/AGch8Gv/AFNfD1fI 8br/AIw/O+l+FK2v/cNntcN/8lDlH+KP/pUT/UI8YTf8SHUP59P1zx6Yx7V/nc3uf7a8ben/AAsj x1/6edf/APrV/oj+MP8AkBXP1H/stf532sfvvEfjjyP+ikeKOv8A2Gvf1/D8M1/mn9BZv/W7xEja 98SnfslzJq3mpN/J/L918YU/7Hyl/wBxWtv9hv8AI+X/AIwf8gHUJ/8AqMaXk/p/9brnqfevB4ce Vb+R7+vTtnPfGfw9q94+M3n/APCO6h0/5DGl9OmP7b56c5x+leDwzGHS/Ph/4+O3+ePXnt/T/U/C 7P0/U/ng/Rj9jn9j7w5+0J8NP2gPHHirXLbTdQ8G6P8A8Ix8H7T/AISTRtN/t/4yf2Lr/jz+xf7C 8Q/8jAP+Ec0P/kVvCf8A0H8dSaz/ANqL9m/wd8JfBuj/APCK+APiQLe1vPg3ZWfx51bxho+pfDP4 s6n8V/hjoGva7/Yeh/8AUp+I/wDil/8Aikv+Ex/4orQP+K9HSu4s/wBifStH/wBBn+Kmt/2ha3n2 28+yaPo39mWGqf8AhSe45/HJo1L9jSxvdL0+xg+LmpW39l97vw3/AGl3/wCgH/wkn/FP47/4UfWl 2X4/5AWPjZ/wSd+PvwT+AVx8d9c8VfDfW9P0HSP7a8eeCPD2saz/AMJN4S0v0Ouc+GPEH9a/Lf8A 1P8AnOc/l6e3T8/1Q1L9lG+1jRjocHxbubm4/wCPL/ibaP4y1LTf/BF/wsj9PX6V+Y+pabfaPr3i jQ764trm48Maxqui3l3aWf8AxLL/APsLWufr3+mPpVgY0MP7r/5Ex0/n+X/61/e/53V9cfA39l3V fjB8Objx/P8AE3/hCbe68Y+KPDFnpNp4b/4ST+0P7C/sA/8AE8/4qTp1+p+leof8ME302f8Ai9Nt /wCEGT+h8Sc//q9KLpbs5z89/wB7/ndVf/p3/T9f/r9Pb2r9GIf2D4P+W/xp/wDATwHo3r7eJP8A PXvXz/8AH74EQfAfXvh/pV94xtvFun+PNH8Ua0NWtNHOm6nYf2FrXrz/ANBzp7delR9ZXZfj/kB8 zkT/AOjwQf5Hr6c55/8A10TfvuM/6Rz09On/ANb9elaGj2cGp39vBcX11bf9uf8A1Bdf+uf89a9Q /wCED8KzS6fB/wAJHqX+l+lno3HPXjxIOMev5jNH1pdl+P8AkdB4vVD9/wD6/n6//W+v+HtXt8Pw 38OTWFxPB4juftH2z7EbT7Ho2B1/6mQfl7V1Gm/BPw5qV/cWP/CVal/pWj6pe2d3aaP/AMf+qaFo v9ve/wCH9BQsRhH119eunk+y77DWHxuj1t+n3L9Dw/QbyCaXyIPf/wDXn19OnHX29Ihhg8r+ff6d ePXHavF7P/W3E/n/AGb7Lo+qXv4/0P09Pav0Ah/YJ+I0Nrp8/wDwunwlptxdWel332QeG9Z/5jui 9P8A9Q7nrR9aXZfj/kcx8v8A2P2/8eqx9j9v/Hq+oIf2J/ibZ/8ANcPBNz1/5lvWe/8AL8PwNWP+ GLfibNdW8H/C4vBP+lY/4+/Des/5+hH/AOo+tLsvx/yOg+R5oZ4Zf9R7c/8A1+Tnv0zn61n+G4fJ 17WP+vPSv8+3T17VsSw6ro3ijxx4H12e11LWPBviTVPDF5d2n/IMv/7C56/lWP4bJh17xB6fY9L/ AF/t/r/kevHawPrDR/8AkF28E/P+h/4Yz1/kc49BX7U/8G/k083x8+P/AP2Lnhjn/uNa96e/161+ K2mw/wCgW/8A1588/wA//rV+2P8Awb9/8l1+P/p/wjnhn/08a9X8u/Swf/Gj+PvOP/t8P+D+J+k+ F/8AyVeV+i+e5/WLrP8AyB7/AP69dVr/ADG/+CuE3nf8FCP2nu2fiMT7/wDIH0IdPT+vHFf6c+sf 8gzUP+vTVP8A0E1/mEf8FXpzN/wUD/amA/6KlqnH00jQvX6etfyL+zyTfGvF9t1won/5Xor79dPM /WPGL/kn8r9f0PzVmz/qMev/ANft39MfT0r2j4e2Zmuv8OfXn19/x7V4vB/x82/4Z/T+tfSHw9h8 6Ifn/X/OeK/1ar64S3qvyP5Ww26v5Xv/ANu7n0R8QrO/0H4Qaf59h/o+qfXU/wAx9R/hmvz4stTn 03VIL2D/AEae2vP9E75weD6HqcE+xPrX6T/HK8+x/C/T9K/5d/sel2XPI9fXH4ccV+Y/nfvf+Pf9 f9qjDYXCywbWt2nG3fmXW++7/D5dcMZjMBjqePwW9OcZrVrWLT00Wl0vL8z96f2V/ibB4k0HSJzf YN1/x+D/AKimM/j/APX49/1f+HusQTRDSr7Jt7rGPr0/X9OO/X+Yv9kbx/PoPiC40Ca4NvbXTm60 rPGG5K474ZRnoOVPtX76fDHxV/aNhp89v0Hvz9f6V/L3GuS/2BxE5x2bbV1rq9E3bv2vvfof9Av0 XfEeHil4S5XiMbJSzmkowmrpyahyppreKaWz6a7an5nf8FOv2cz4d8RW/wATtDtCLXVG+zeIPshw qzADBznjeo2McYyFJGBx+OM0JJwev+fQfU5x6giv7GPjX4P0v4y/CvWNLvYba4NzaCyvCCQRg5BH PGDznr3HrX8pvj74P+LvC/jjXfDNvo+o6hdadeNaOLWyb/TLBWJyMIx2uNrKQWwSwyNuD+teHPFq xeVPB42cU4pfFJRejs9Xbq1ffb1P4F+nD4E43KuLf9eeGconKGe61IUoOSU7XlJxhG3vJPVrdLrJ I8Y/5Zf5/u1X/wBT/nOc/l6e3T89nU9H1XRpjb6rZXOnXHa1u7P+zc/mBk/Uf/Xxv+WX+f7tfq8Z Rkk4tNNJq1npptb1R/npisHj8BL6jj4ShUW8ZRcZR62adnpa+q8mu1jzz5Xkc/Tjr0/LPf8A/VRV erHnfvf/AK3PX8uv6+3FUcgef7fp/wDXpIf9cPqf50vn+36f/Xog7/j/AEoA0Kvw/wCuH1P86ghh 8+U/kD9On/1+PrxmtDyPf9f/AK1AFmH/AFI+h/lSdf8Ap5/T/OPw61PD/rh9T/OlhvPIlx5HXnt3 /p64/KgCt5M/ldv8j64/+tz93irMMPUzn/PfP8yD9CasTTQeb5/kdM/5Ht09MZrPoAsUed+9/wDr c9fy6/r7cVXhm/8A1f5/UfiKKANDzv3v/wBbnr+XX9fbiiq9WKACrFV/+WX+f7tWP+WX+f7tc4Fm H/Uj6H+VWIf9SPof5VWg7/j/AEog7/j/AEoA5+vtr/gnT+5/bh/ZIH/Vx3wcPX08aeH/APPX8e9f Es0MHm/6P9ptug/0vr/P+ueK+2P+Cd//ACe7+yR/2cd8HP8A1Z2gV8xxtrwfnKev/GK1Ir0dNr8m +voz2+GteIso/wAUX+MWf6jHiv8A5AOo/h/7LX+dhqcP/E++IH/ZR/Hf5f2yM8+n6jjua/0T/FUP naNqH+ffH+ef6f51HiWYWfjP4kWM8IttQtfiP47srzn/AKjIz3z6f56f5i/QNf8AxmPiKn1xK366 z6dep++eLGmTZR0tCN//ACTf8T5t+M3/ACLmof8AYZ0v/wBPVfP5m8mw8+4z9ntf1+nt+P519EfG CHzvC+seRB/y+aXe8c/X+ePX+VeIWcPk+2fr6Z4+nb+df6rYXZ+n6n84H9AGdK1OW4vtD1zTdb0+ 6vBe/a9J1jRtSPt/jj8B1rHvIZ4f3/n23/gX+Hbgc+nBx0r5X/YP+D/w58efC/4kX3iOxuRcH4we A/BfjDVrT4kf8Kl/4QL4X674L+Luva78Tv8AkZPCP/CwP+ET8R6HofpWf+1p8HvB3gn4S+H5/A/h y21z4T6VZfBr/hA/jdd/GD+0v+Fl6p468F/29460XQ/hX6+E/Ef/ABS//FJ/8iX/AGB/xXv/ACNw rn+qruvx/wAwPsDTZv7Nv7e+nntra3tf+Py7vLz+zf8AP5eh45r8H/GE0E/xB+JF9BP9pt7rx54o vbO7+2H/AKDWv8/25+vOQK/eD9qL9iHSvBP/AATd+G8+k654JufHHwls9L8T/Ej7H481nUtM17S/ +J//AMSXQ9D/AORY/wCEi/4nmhdP+EOP5V+A83kQy28HfPX/AD9f8B1rpw2Gfz6/l+X4fgH6kfsW +RefAfToBfW1rcaX8VPihY3lpd9/+QBr39tHGf1/6AHNfXHkeT/r7j+n+f19q/Ff4J3ng6z8cf8A Fcar/wAI34f17w3488Mf8JZ9j1nUv7B1TXfBev6FoWta5ofh8/8ACT/8I74T8R6516dPpWxN+zrf Tf8AHj8Rv2b7r/nz/wCMkPgFpv8AaB7/APIwfEjwify/PpXNicO+7T3/AK+7t8r2bD9iJv8AVfv5 +fy9sfif554r88P28Ct5rnwIngnt7lrTw58T7K6+xkf2lYL/AG14D3e+cnWtuOMbge1Z3wT/AOFR /AGXxR/wvj7N4u0/xlZ6V/wh3/ChvjB8GviR/YOqaF/b/wDbv/Ccf8K++JH/ACLv/ID/AA9/CHH6 MeMP2Y/gt4q0rwd8U4PAHiT/AIVva/Df4yeJ9Yu/EPjzwZ/ad/pf9t+Ade8C+NNE8Df8LI/4Sf8A 4R3wn4b/AOE4/wC508ffDHP/AAmWaMNhvm9d+mn5r07aXvYPwf8ADUP/ABUdvAIPtNxdWeqfY/8A TDpv0/z07e1fREOsWP2nT/Pvra2+1f6F/pf+PPf8efrX7caP+w3+z1Dqmn/8I58HfH//ABNP7Lsf +Eh0n4keDf7M17Std1rX9BH/AAg//FyOP+QHrn/I2ZOM4/5G6vy2+OVn+z14wuvGHwW+A8GpWvjA eMPC/wBj1b4seMPhp8JdMsNL8C/8Ld/4Wvov/Cb/ABA+Nf8AwjH/AAkX/CR/8Kr/AOEI/wCRO/4T T/ip/WunE4b/AIH9bbdtLfiHgH9s2PlXHS5+y/8AH539+2MH6VsWfiu3s5b/AM+e5/0rw34o+x/6 H/ZuD/whev6D36DGuaH/APrrlz+yj8TYYv8AkK/AC5+1f9XmfsPfh/zchjj/AD61zHxa8KeHfh74 f+G/hex8R+Edb8f6ZpHim8+JF34I8TaJ428N6Dqut+NFOh+C9E8beHifDWv+IfCfhvRtD/4TZvCv i/xirHcFLFWC86w2E093VW6ddPNdWu267nX/AGj/ALJbbW135/j5dvyPFtNIh/tD7P8A9AfVLL7W P+wKM9R/+v8AWv6ALyzv/Nt7iC+tvs50fSzZ/wDT+P7F/wA/hX88/neTjP8Ax8dPb9f6/hxWx/wl fiOGW3n/ALc1v7PnH/IY1n9e369+aWIy61mtn8tN/wA7fNI5E77H74TQ38P/AC3/AJD8P8+nr0r+ Tqv2q3/f/l/yDD9f6/z9Oo/Yb8E2Pir9ka31zXPB3i3xJca9/wAJ3/bHjf8A4ST+zT4S/wCJ14+0 E/8AIwH00P8A4Sg/8In3OK/DfWNe8RzeCPB/iOf+27bUPFFn9t+1/wDCSaz/AGZf9v8AoZOefx5/ ChYa1tVp6gb/AIkhn/4X78cJ+Lm3/wCFkeKP9LPt/kfrWB4bhg/tnxB7Weln69eP8815/NNrmm6X b+Ix/wAe+qf6bj7Yf9P/AB/D/DsT3HgOb7ZLrGq+R/x9Wel+3+fp7Z+vXt+Rzn2BoMP/ABK9Pnnx n7Hpf+H/AOv6fl+0X/Bv4P8Ai/f7Q0H/AFLnhn8v7Z130yMnPP8A+uvyF0fTZodLt/3H/Lnz/h06 e3196/ZH/ggRZn/he/7RE8EB/wCRc8Mdf+w1rxJweM9BX8ufSvaXgxxb504pevNTv67Nep+oeGGn FeVX0ta/lo9z+rHWP+QXqP8A156p/Kv8vj/gqx/yf9+1Fj/oqOq/+mnRa/1Bda/5A+r/APYH1P8A k1f5iP8AwVq+w/8ADwj9p0QTgf8AFdaXjHP/ADJ2h/1z39ua/kb9nS3/AK78Ydb8Jx+X+0UNX62t fzSP1Lxi/wCSfypdm1+v6n5u6bD51/bwc/X39unr6elfWHw903yP7PH/AC7/AGzH079f84r5X0fz 5tZt+3/6v1wRX2P8MfCulalqmnwT/wDpX3/l6/54r/VnMd/K+n4f8A/mU7H9pC98nRtPseTj8uOP x9+a/OevvD9pazg0G18iC+ubn/Qz9jtLu8/48B2/DJ/LPqa+D66sMtEl2SX/AJKGnXRdfQ6LwprF z4b1iw1W3nPn6bei7xzk9wMd+menBAxjiv32/Z1+JB13TLCayzcHU7P7YbO14IPcHPQjkEcdOxFf hz8IPBcPxC8Z6d4dmuPs1vcYvLo44+XBHbBOME1+7/wm1PwD8J/B0GmaZZW5ubazJY5zqhOckt3O TnOe/NfjnjAsK1HCcrebJbpdLptbbJt/lof6dfs9sFxBg8ZxNmk84jDhHlSUJTXMpaKyjLppayWj XXRH3f4V/wCEj/0ixg/0a31T1/4mWp98dMD/AA+tHiqz+Enw30y4vrix8N/8JB/y93f/ACEtT/z9 c/SvH9B8Sar4k/1Fx9mt7r/n0+mfz/8Are9fQEPgPw54k8JXEE+l21zcXVl/pn/T/j0+n8+tfhsG 4uKu1qk7NrtfY/1UrLBYym5PJ4Z9aEnBVI8yuleKXMrb728ttD+dT9vT4geAvGHi7QYvC0Om3F9p dmBq+raSDiRgegzwdgJJ9CR03Cvzy8n3/wA/9819T/tUfCS/+E3xa8S6BPFcnTpr03Wk3Bz/AKZp blnRhg8hyWB/iDLzwVx8wV/XPCdHC0Mnyt4WTm7Rvre10m1q3be+vfa1z/ne+kbm2e5j4y8WYjP8 ojkWZxqzjGnGHLHki0oWSSi3KKvftaz5bBDN50Wf+Xj14OP8/r7VX/6eP1/T/wCt19/erFEHf8f6 V9KfhXqH+p/f+fbf5/HIx3+uPSrEOf8AUY/z27dvTH19Kr1Yg7/j/SgDoLP08j1PX655/wDre/tV j/Uze35df5j8hz2rPg7/AI/0rQoAJpv/ANX+f0H4mib/AJd/xon7fh/WiHz+Pw/L/wDX96gAiHky +f8A57/59+xBoqxP2/D+tV6ACrE/+q8/BHP5n9B+X/66/ke/6/8A1qsUAWKKrwd/x/pWh/qf9fx6 fpj1z79fegAoqv8A66b2/Pp/IfmOO9WPO8rvjPtn/PT9K5wLFWIO/wCP9Kz/AD/b9P8A69WPP9v0 /wDr0AcvnyZuvHft1/n+nXtX3B/wTv8A+T3f2SP+zjvg5/6s7QK+J/J/5b/hu/TOf8/XtX2h/wAE 7/8Ak939kj/s474Of+rO0CvkeNv+SQznX/mlqv4QbaXrZ6ep7fDT/wCMiyh/3l+Lif6lGsQ+dpdx B2/zyf17e2K/hg/4KE/AHVvgd+2H8T9L8j7N4Y+I2r6p8TPCF3jGf+E5H9u63ovbjwn4h1vWx+Bz zmv7rtY/5Bd/+/8As3PJPbr1/H8D6mvyx/bp/Y08K/tdfD7+w55/7F+IGg3f23wH4rOf+JFqh/5g p/6l3/D1r/D36Nviw/CzxMrVsbK2TcQV3GSu2k/aO0ml9qN3FPdRlJJWbP6p404d/t/hxaawit91 pHR6bP8ANd1p/IdN+z34q8Y+HLi+8OaVbakbWy/0zSftnN/79Of8/SvkfXvhj/Zt19gvoNb024tb wWX9lf8AIN//AFd/y4r9QPAf7SH/AApmXxR8Mvipof2bWPBviTVfBeseIdJ5/wCJpoWtf2Drv/pj I/XnrXwh8ZvHnhzxV421DVNK1a2ube7+v+Pp+Gc1/uBlWafXsFTx+C2nCEl9q6kk1be+jVraH8nY rDfVMZ9SbW9vLTa3r16/geDTfD2xm/141K5/6+/8469eBjvR/wAK9gh/5f8AUvtB6f1z9P58HNbG palbw/Z5/t3+j9Py+uf84H15+fWLEzef5/8APj6f4cflivU+sOybutFfTT/0kPq3m/w/zEm+Htj5 Wf8ASf8Ar7/D/ODz3qCb4e2Pm+f/AGtqXUAf8gb8Rj/P0xViHWLHzf8AX2319Pf8ev8AWsi81iCa K4/f2304/H+v/wCqunDYn71+dv8Ahvk1rq0z6q+7/D/Mvw/Dexz5/wDaut/+Ub/HHr34/GrP/CCW P/QyazXDQmfUpfIhtxc9/wBPxPp+FVobyf8A0iCD8s/Tvn/9fJOOK9M8w9B/4V7Y+V+41y6/zn/J H4Y5xXcabr/j/QbD+ydD+MXj/TdHI/5BOk+JNZ03TP8AkC/2D3/6lzP414PPe/uvPgn/ANH65/X+ X057UQ+fDnt+uMfT365/xoOg+iIfiF8W9Hi8ix+OHxatvtX/AB5/ZPF+s+359e3SvN/+EJ/tL7Rf X/irUrm4urz7befa+l/+g9PXH0rhvOP/AD8D8j/hUE15ceV/079cc/Qfqf8A6woOc7D/AIV7B5X/ ACMdznP/AFBvXH0x2x1x3xVeb4Y2P/Qyal35+n+P154rz+a8vof+X823/wCvg9f89elZ/wDaU3/P 7/46KVl2X9f8MvuA9H/4VXp//QxXP5H/ABo/4VZYf9By5/8AAJa85+3XH/P7c/8AgZU9ne957655 /wCnzHT/ABx0PT8aZ1YbDPzd/Xr8/T9OifvGj/8ACxvCmg/8Ir4c+Lfj/wAN+H7r+1PtnhPSfEms 6b4Zv/7dwNd/4kf/AAkf/wCv2rl5vBN9Npej6V/wkf8AxL9BvPtujWf2MD/P+Nefm9gh6X1z0/5/ Pw4z1680TalP5RgM+Mf8vf2zHr+Fc913/r+mvvOn6t/eeu2sdfxOxm8Ez/2Zb6V/wkf2nTx1tPsY 69unOa9v+DPg/wAOTa9o+h3199m0e1vPtusXf2s/2lff/Wzn8PoK+T7y9n8r/j+uT0PF5+P6Y/Xt XoHgPU9Vhv7e+sZ7kY9Pfj/64/piuTEpvpfTp2uv1IW+nS3y2t+h+y/xO8E/CvR/h9qHjfQ9cubb 7LZ/bf7J+2deR/YOi+3H9K/XL/ggp8LNV0jwP8T/AI0arY3Nt/wsbxJpei6Pd3gH+n6Xoef7d9cj /hIsYz/0AMfX8T/2Sv2afin+3J8QYPB1jfXWifDfwdd6Xe+O/EPOLA8deR/wkHiL0x3xkYzn+0/4 G/Dfwr8H/Cfg/wCHPg+xttN8MeF9H0vRdHtM9+PT/Pr2r/OH6bnjJlGD4cl4cYKaeczVpxUvs8yl 7yukm3FWTu9LtK8b/u/hfw1i/rX9sYpWW8VtuktHa33fmj6A1j/kD6z6/wBj6n/6Zlr/ADAv+Cr0 U0P7fH7Sv+mfaftXxF+2A85zrvg/Qj/Y3B54yvccZxnmv9PXxJ+40bWJ/wDqD6p/6Zf6cen61/l1 f8FO9Yn1f9u/9qSa4mwbX4u+KNFz1/5AbPoQ6+2iD8ufWvhf2c8ZvjbjKTvb/VWlGUmtFKVeg1Fu 2jbi3a6bs1s2n7XjX/yIcq786tb5p/he/wAz4s8H2c82tY/+tj2/z/hX3z8B9NM2vW9xBB9p+y2f +f8AP4jvXxN8PYf9Kub/APx69PxH+ea++Pgbo/k3WoT+eLb7LZ/bf+Pzp9PT16cDFf6sYh/7WsJd dGnuuj6af5rtofzd/wAwfn+l1/wPwPn/APaum/4mlv0/X/P+PSvi+vrD9qibztet4Ov+fbof8+lf J9e3hdFHytq/+3TzzZ0HXtV0C/ttV0q4uLfULX/l7GeMc8549xgnp9K9t8N/HPxV/wAJHpN7rupP qK2t8tpcW5bK7QSGUqFGfUNk8jGRjB+eYQfNB7ZPf3A+vtVjpFkdf/sa8zMsswebKX1yEHKUXG8o rmTasrN3ta9011t5n2XB3iDxHwjjYf2Rm1SFKNSE5whOUIyUZRbUkrJxaTTunp0P6UPgP42sdTsN P8if7Tb3dl/od33xj8vQ/wAvSvvDwTNrnP8AYehnUvtX/P3ef2bpZ6fT/wCv9a/AH9jb4tz3FlD4 evZj9v0Mk2eecaYeWAOeRkn0IGCeTX7ffDHxhcfZbf7B/wAvVn69/p/nI71/IvEuWf2BnMsLiU3H mbUraWT912T7NPsf9DfgPx/hfEnw5yniHByTqQhCNRKSupKMU7221XldrbQ+Ov8Agpf+ztPr/gW3 8e2Vnb3GreGbPF79kOB/ZoB/tpmGQCFY7j7ZxzX85s8BhmucgggnIIORjsc989uMYP4f2n+Kov8A hPNB1Dwtrnhy5Nvqllqll9r6e/P9OP8AGv5Pf2nfhHe/Bz4r+JPC13BcCEXpudKurvOTppLMj5Jx hl+THYoTjmv2rww4kWJi8olKzSja+t9k0tNNHf5dev8Ant9P/wAI3hZ5V4o4CDlzyUOJ+SN7N/C3 yrS7037aHzjP2/D+tEM3/wCr/P6j8RVerEHf8f6V+xn+Xaadmtnqra6Pa3fdB/08fr+n/wBbr7+9 aFnD/wAe83n/AEx/T9e341nw5/1GP89u3b0x9fStCDv+P9KANiGE+V/np/h+o71Y/f8Alf5x6/z/ APHaz6sef7fp/wDXoAKsTQ/5P+fyOPUEVXg7/j/SrHnfvf8A63PX8uv6+3FABB3/AB/pRRDN/wDq /wA/qPxFFABNMfK/cT56+v8A9bnIH/6zVjz/AG/T/wCvVfr/ANvP+fwz/n3PJg837P7evHp69O30 9qALMP8AqR9D/KiH/Uj6H+VJR/yy/wA/3a5wLFWKz/I9/wBf/rVoed5XfGfbP+en6UAH7j/lt0/p 3/r1/wAasTGCH/65z6+v9Kr+f7fp/wDXqxQBz9fbP/BO7/k9z9kn/s4/4N/+rN0GviaDv+P9K+4v +Cd5mm/bb/ZJnP8A0cf8GiB/3U/QMg/QkZ9c/WvkuNWlwdnTdtMNilr2+r1El10v0Pb4Z/5KPJ/8 cP8A0qJ/qTakTNa3A/z39vp29uteP3ln+9t/X+v+H68Z75r2DU/+Pa4/D+Rry+b/AJd/xr/m3l/y UrV7P63bTpetHbt1/E/t5a4FJ7OG3rCx/n0/teefN8ef2gIOn/GQXxi6ccn4ma9269+3/wCv5mm8 iW10+eD/AI+bX/Qrzj6Dt/n9DX0x+13/AMlv+PHkf8fH/DQnxP8A/U0178PX3r1//gmn8JfAHxm/ ag8P+Hfibodt4k8L6X4P8eeJv7J1Y/8AEsv9T0PRT/YX9uHvx/h3r/f3LOLsHwZ4SQ4nxibjk3DK qci3kuVSsl1fLdLbXsfyO+G/9YeL/wCx8K2m5q3e7e7v5v8AA/OfyfOuv9I+08ntnr/L3/p61/sf ky+R9SP/AK//AOvNf2c6Z+xH+yz4q1gQQfs9/B22+1f2pefa7Pwfo3A0LRf7e6Dp79hjqK4eb9jX 9lmH/X/s+fC+2uPsQvP+RcPGlj/mM9T0/me9fzs/p0cOrKv7XfAfFP8AZS0cnRSi2uVN8zqaxvqn bZbLVL9nj9HXF/W1g/7WXNZOzkrptLeO+3W60Xpf+P6H99FbwfZ//JPr+P8AM9+Pxz5oYIZf38Fz n/P8v847f2Bf8MU/spXso8/4BfDgnOBnSD39Of8APtX5bf8ABWL9nz4PfBXwb8ENc+Fnw68OeAdQ 8UeL/FGi6wdJszp32/S/7GA5z2wT+nc19J4cfS/4R8SeLcr4QybLKizbObv36fLGKirtNqckpJK1 mt79DxeLvAXNuHcoecPNVbVWv2t+H9Prf8Rqg/cf6+f7N/nr+I/PpV/yT5v+o+1fX/P+ffiv1Yh/ 4I5/tbf29450Pz/hvbf8IbZ/AbWrzVrvxJrP9ma9/wANI61/YOg6L4H/AOKb/wCKg/4RM6GP+E3/ AOhL54r+3MPflV9HbX1tG5/OTTi2nunY8v8A2e/2FfDnx4+Ffwu8VT/Gn/hCfiR8bvip8ZPhJ8H/ AAnq3g/WfEmmX/ij4F+C/APjz/iuNc/4ST/iQf8ACV/8JxofhfwQPXrX0Bef8El9V8K6z4f8HeMf i3qX/CQfEbxJqnhj4P8Ah7wR8E/GXxI1TXtU8C/DHwD8WvHWteOND8P/APFT+H/h34U/4TjQ/C// AAlPhM+Mf51n/CvQP25/g/8Asq+INV+HPir4b6J8H/Af/DWnjQ3Z0fRtS+JnhLVPhRrXwi+Evx01 rwPrniDw3/wk/h/xH4s/4TjwP/yKeR/whegV9AfAfxV+358Qvh94H+LfhX47/sheJLfx58bPC/gv 4b6T8Tv7G1Lxz8NP2jB4L0DQTovgfQ/EHw3/AOKf+Ig+HOh6H/wm+P8AseetMR8nz/8ABOTwd4b0 X4oT+P8A9oz/AIQnxR8L/wBnvwH+0d488Pf8Kf8AGWpfYPAfjrWvAOg6F/zMnhH/AIqL/hY3jjQ/ C+P6GuPh/wCCY/xUvNB/Y38Rz+I/Ddtb/taeMD4LNp/Y+s/8WV1T/hC/+E88C/8ACc9x/wALY+HP /FUeCP8AsAfU19ceNv2Xf+CmnirVPiBP4j/4VtqX/C2v2G9UvfGHiEax/wAUzf8A7OngX4n+Af8A iizrn/CN/wDJRB4j8D6H4o/LivYIdS/4KaeG/ir4G+C2q/tC/sc6l8QNU8YfC/WvAfwc8b/EjwaN M8JeKPhRoo0HwLovgbwP/wAI3/xT/iLxZ4c8ca54X/4Rb/mdD60XXcD+beaHyf8AX/6Ncf8AT3n/ AD7Y/Pmq/wDoMMp8+37+v+fXHPtntX6cfHL9kX4t69o2ofHDxH4j/Ye8E+H7q88UeGNH0n4ZfGz4 aeG/DPxM1X4Uf8j0PA+h/wDCSf8ACMeIPEX/AAkfb/mdOehIr5/+P37Fvxw/Zp0bT/FXxGsfBNz4 fuvGH/CsbzVvBHxI8G/Ej/hEvij/AGL/AMJ5/wAIX44/4R/xJ/wk/h/xF/wjn/FUdfWgFrbz69D5 Pms4PN/5dun6/T+n6HsQ+RZ2tx/oNt/19jj8f88fpVjyJ5pbex88Wtxql5pdl/4PR1/yf1r9MLz9 jn4SabfjFj4kufsn/L3d+JNZ9uOOmenH/wCr4jiPjXCZB/va8v8AgfdZP1R/R/gr9GnjbxrweaYv hzNbf2L0ey2u/JWTeu3RH5fzfvh+/gtvw69ffr9R+vWl+x2//PE/+Adfph/wyB8JLuXz/I8R/wDb prGsZ/Ufp+HqD22pf8E8vCmkaNp+t6p4d+I2nafdXfiezxdXusnU7AeBv7B/tw65of8AzL48Kf23 omGzg474r5vD+KGU4mLkssk0kndLRWs/i1utb301R+uZn9BrxEymWVRxvFPDUZTkopSlaUm7K2q1 fTst+5+R/wBjg8rPkf8Aknzj1+nf611OmwwQy2/kfZvtH2zraevTg+nr/wDXr7Y+M37KPw68B/CX xf4/8N32uW+oeF7PS9Zsvtesf2lpmoZ1r+wccd+w+mB7fD9mfJv7f/n3+2Z/A/n+Wea+t4d4rwfE GEli8GrWvfy0t00TW9t7a7o/CfGjwP4r8DM2ynKuIrSWd2kmrO8W0+ZX+y+/TXfc/qo/4IJ2Zn0b 9pCfyP8AmZPAf+l5/wCw/wDqPb6/X+kDR7Pyrq34P0/x/wA9/Uiv55/+CCemzw+Ev2gJ/IH2e68S eF8df/rD/PWv6KNNh/0rn8O3PX+frwPev8LPpXv6544cU8zb5XdK90tttd+ulj9s4CSXDmVaK9lr 8kb/AIgJ/sbWOf8AmDap/wCmWv8AK6/4KE6udX/bR/agvev2n47/ABPx9D4z1/Q++eRnsfbjpX+q L4j/AOQFrA/6g2p5/wDBPx/X8q/y4f2pNY0SL9pf9oC+ng+03N18dvjFei7vM8j/AITLXvy4x6mv 6k/Z52jnviBjOVt8vDlNW2SmpNp2vo3BPfXXu7fAeNl3lWVLzlp5qUVp+h8zfDeGD7L+/wC957+/ T3/LFfoB8Jf3Ol6xfQf6Tmz/ANM/z7ZH598GvkfR/Hmh+b5E+h/2l/255/8A19v6mvQNB+J3hzQb /wA++8K/aYPfnt6+H/8APtX+oTbeKb6t3/HufzKeL/tLTQy+LbiD/n1/zz6f4ds183/9O/6fr/8A X6e3tX6AeL/Afwy+Klhcar4O8RaJbaxakf6J/bH/ABMiPr4gxgewI9K+H/EnhrVfDeqf2VqtuftH Wz/6f+nX8emPoDXtYfb5fpE5zl/J/e/5z1+uOvf9MVoQd/x/pVf/AK9/+A/5P4dfw7Uf+kv+f8// AGVdPqFl2/r+kj1L4YeNZ/Avi3SNbBufI+2f6UP72mEgbfr1OT1xjnPH9B3wO8bQaxYafPBP/o91 /ptmfb/6/wD+vFfzUQHzBjpnv6bfzxX6gfsW/Fk+UPC19P8Av9Mze2WD6dfQ9+c+tfk3ihw2sXg4 47Bx96O7tulypa9Lar0sj/Q76BHjZLhXizMuA85nbJ88t7NSbspaWUb2XS6t+Fz+ifQdSv8AUrXT 5/t1t9otf+XS76fU9q/MH/gpt8AofEnhKD4l6HZYv/DWBfD/AKhecgkezdMc8kDrz9neA9YsdYtb eC+/0nT9UP8AhnP5f5Fe0ax4b8N+L/AeseFT9p1LT7qz1Sy+yXfP0/p9evSvxLIs5xWU5vHFPRKS Vlpazj28101uf6w+IvAOC8QuAc44SxcYz/tunKdNNKSVo3hvfqk9NV3P4ryCJTbnjHB9iOPr0/X8 6rzf8u/419C/tJ/Cu8+EPxN8SeEJre58m0uzeaYTzu00szI+c8ZU7eOfkzjmvnub/U/gP5V/XmWY r+1cFDGYVq7jGT89E7993r5p/P8A5ueMeGcZwTxRnHDGNjKLyOrUjFSVm0p2TV1dpqzS3tbZk9WP 9TN7fl1/mPyHPas+rEM373/JP+f0HSur1Pllqk+5r85tvPxjj69sZ/z/AEqz53739x/5NnGe/f8A +sKz4Zv3X4fy/p+p6VYhm/8A1f5/UfiKANiGH/P+f1OPYCq9EE08MX7jP+lf/qx0Ionl/wCWGPXP 8/8A63HtQBXn7fh/WrEHf8f6Uf8ALL/P92iHyB/r4Dc/n/gPb2+tABVip5p4JovI/wBJP2U/hx2/ z78+sFABBnyv3+cZ7465/wA/jnHFFHnfuv8A63HT8+n6e/NEHf8AH+lAFj/ll/n+7R/rv84xj8/X 36/kUVzgH7r/ADtrQg7/AI/0rPqxB3/H+lAGPB3/AB/pX23/AME7zj9tv9kmDHX9o/4N/wDqztAH uc8//r7/ABJXtfwKPjf/AIW58Np/hb9pPxGPj3wv/wAK5/sjjVP+E7OtaB/wg2M8bv8AhIv7DC5z gkGvB4vw/wBZ4ZznBqUYqVKrHmk2lH2lKVPmbvoot3b7Lse3w1/yUOU77p+ejTP9Z3Uv+PDzyf8A lz7f15+ucfn2rzeaHzvs/wDj/n1/XvXcw/25/Zdudcg+0ah9j/03/sKf8x36/h3z688tD580Xn31 j9muPtn2Lr36/wCevtX/ADc4zLfqvEsle1sW9e375dV5eXTdH9rYfEv6g99Ifkumtt7b3d7bn+ej +1r/AMl5+PH/AGcF8Tf18Y68a+rv+CQuYf2vbDnj/hVfxPHTg/8AElOPoME/r+Hyx+15n/hd/wAe c/8ARwfxP/L/AITPXsfpiun/AGFf2ivC37Mfx80f4meMdL1LUvC9r4c8UeGb208Pf8hP/ie6Icfp 69P5/wC4+dZNmnEHgC8pyXKv7YzefCrcIrV2cLxjbS6+y/JvfRH818NZng8F4jLGY2XKo1FdvRJJ xTb8/W99j+334BeKvhdpniJj4p8Lahrmg3TDRl8Patd6P4zF/wCORo2f7Y0XwQS/P/COaGcsBjnh Qea8J+KeseFvEmsX994d0u5uoNTvPtvhC8/4TD+0f7C8LjWR/Yfgz+wv+Zf/AOEUzkeFcnGcZyK/ KeH/AIK9fsoaPqlhrdlb/Fm31C2GLO6tPB+jf2nYeo/5GTvnp6fWvgL9qf8A4Kuap47tLjwR+zbp XiTwD4fuh9h8R/EHxBZ6Lpnji/0vr/Y2iZB/sAc/8jOMEnOcYwf4lyTgTxr424Myvw2x/AMOH4Kf 7zilwtyQva7Si5NKPRJt+erP6bzjibgjKs0zPi5ZxKTVOKjTVRySa1do83drurKy63/Sj9pb9vT4 I/sxyah4euL0/Ef4r2p/0v4Z+FLs/wBp6Hjt421zH/EgwRg+Fx/xWYI5IJGf55v2qf2wPi1+1RrO j33xMn0XRfDHhg6pfeD/AAT4UtMaZoWp67n+3NZ1vWx/xU+v+IueQSeQDkd/laeY/wCkf8vOf+Pz 7Zn/AE/kev549Rn0rf8ABHgPxX8QvFGn+G/A/hzW/FviHVObPSfD1n/aWp5/TH9K/svwd+jZ4d+D uEhm7prOM+UI8/EtTllPn91z5Fyx5E5X5Uk5xScfaSWr/nPj7xg4j40/2LBO2TX0avs2rd76b9N9 FexyEHn/AOv/AAz/AFH5/wD1uTX64an/AMFjP2odS8OW/hX+w/hvptva/wDHnd2mj6z/AGnYf8XO 8A+PNC+v/CJ/8IP/AMIv4I46a/4o69/j+b4S/CT4b/aP+F0/Ea28SeILX/j8+GXwnvNH8Sf2DqnG NF8b/FT/AJFj/wAJP/hMaz/+GhNK8K/Z4Pgt8JPhJ8N/9MBsvEOraPo3xI8c8nj/AInnxA58P+Iu T/yKfg/6V+7YnirG4nFKOUZU7aJSkrJ/Da+ney7Wb6I/Jf7Owmjxmaf3mvudnb0a+e17JfoB4P8A 2zPjv8WrXUPDngD9ifTfG3wX1/4b/Hj4fax8MvBGj/GTUvDGvap+0j8TvAPjzx140/4Tjw//AMzF /wAJH8K9C49f+EnrY+FXwx/bu8H2Hw/0rwP+yTbeG/C/w5/bM/4bD8N+HtW8R6Npv2DxQPBegeA9 C+GP/FQeJP8AhJ/+EdH9h/8AY6e/Oa/L/WP2hfjV4x17T77xv8U/iR4t/sK80u8+yeIfF+salpmn 9emiY/4RgH6H8a/rq+KnxB+Jdnp3gC/8A2WuXNlr3w48TeJ1utJ8Haz421LUPHZHgM+B/BZP/Mv+ HfFZ1vxsP+Ep7jQie1fhfjD4s+Ifh/i8rwmDy3hmLzmMpN1JqmlyRc2lKbS5pRVorRym1CKcmr/f 8J8N8P5+no3bffTVWvppre/Sy1sj49vPjx/wVCh8B3HgCf8AZD8E3NvdWeqWX2u08eeDf7T/ALL/ AOFL6/8ACX+xf+RjI/4R3/hI9cHxQ/7HTQOuBXyP+0t8d/22fEnxa+A/x38Y/shfGzTtQ+A3xI0v 4naPpN34k+JfxI+Gf/MA/wCJLoeh/wDCNeLvDHw/Hiz+wsf8Un+QFfqlLr37T82g+OL6Kxt7bxBd fEbwz4Y8B+HhaZ+weGf+FmaFoOt+NNcHPB8Pf20D4oPbPIJwPi//AILC/Ejxj4D+CvwI0TSvEWpa J4w8UfEfVNavNW8P6x/Z2pA6F4NH9u/8Tzw/j/mYvHGifr35H5hwd9IzxMzni3KeGs0y7haX9tOa ahLmnFUYRm24ptxTTtFtJNxlZ2i2vbzTgLKMFlDxutl1eibbSWttbWXV/PQ/L3wf/wAFAvEfg/8A Z31D9mXXPDni220/+2PjJrX/ABT3xU8ZfDf7fqnxX1r+3te0Xxv4H/4Rs/8ACQeHcY6d/rXD/tdf 8FCPib+2B4MuPCvj/Q7a20+1/aF1T40eDru0vP8AkUtL134YnwH/AMKx/wCKf8N/8VBx/wAVR/wl Piz19sV4/Z/tafGrU7X7D4/1XRPjZ4fPJ0n43eG9G+JHOf8AoOeIP+Kn+v8AxWHGMelWPtn7NnxI l/4nnhzxJ8AfFF1/oVnq3hO8/wCFkeBvX/kB+IP+Kn8P46/8Un4w8Yj9Qf7KWd5thbPOcqtHe/Dq 0tprLTRaq/zPy/8As7CYlpYR25WlvbVPtfb+ux8r+d5Uv27/AJeLW8+2/wCfT+n8/wBKPhv+1p4V 8VS29j4/g/4RLWLrH2PVv+ZZ1Djpmvj/AOIf7Pfj/wABaD/wn9j/AGb4/wDhf9s+x2fxN+Ht5/wk ngb1/wCJ5/wj5/4t/wCIv+pW8Wf8Icf5jw+Ga4h/f/6N9n7f9P4rzs7yTh7jXC2wjaqJbS0kn5rf dtvt20SP2zwT8c+N/AvN8zWU3eS5005JNapWUkul7L1e3Q/eizs4LyW3gE/+j3X9l/6Xaf8AQL98 9uf6V/QH+2N+x1e/B79m/wCLXxT/AOGgvEfiWdvDhsdXtNW8N+DNM03xQfHPjDwGf7F0LWtAwfD3 /CWeIdD8EIduCu4DG0sR/FJ8Gfj94j+GMv8AZV9PdeJPB4/0288PXnP2D/sBjn+lfr78Qf8AgqNJ 8Zfhb4J+EHjf4w2//CI+GP7Lvf7KvPDut6fqd7/YeDof/Ca62SV10eFSoZ9qqHYBnDNX5f8A2Hi+ DcHm2CxWVPO3JPkaTfK5KytZ9Lp3V9rNNH97YjxUyn6Qeb+Hud8OcXU8gWRTpy4r4c4knGN1CVOU nTbTUr8llqn7ykpKUUfOf7TZM37OfxYgEHNzZ6VZg3fUY8aaAePfPfr6ZxX5Hab5E1/b/v8AH+me /wBfy6+/41+kHx++OXwr134LeMPCvhzxVbeJNY14aXZWdpaWes/8wLWtA/5jh/T6V+c+mzD+2dP/ ANH/ANH+2aX+X+e46fQV7nhTluMwuUZqsZFxvzNRaa5ea11r2tbS2q0vY/Fvp5cTcOcQcW8KRyfN 457ycNQTcJxklJOK3Tdra267XP7EP+CJVnBaeEvjRBBj7Of+FXXv/g9+GOga9rvHb8e4r96dO/4+ hn1/rX883/BBO9vtY8EfHiC+n+0/ZdY8B2X/AJRdfx6df1/M1/QhZ3nk6z9hgg+0/ZfX/D/HPB96 /wAafpQYf6r4y8VX6u1uusl+m/fc+J4Hf/GOZStvdjdafyxt/S8+lzQ8V/vvDniA/wDUH1Tv/wBQ XA9Pf0zjriv8on9qSYXn7SPxw/597r41fE0g/wDc5a929857Y4PrX+qL8WtS8U6b8NfHF74Vgtrj xB/wjeqWeji74/4mmu6N/YWhccc7iMkdc+9f5RnxS0jxFpHxb8c6V4omNxr+l+O/E9l4juiTm/8A Ey6zro1vWemTjHOevXjqf7A/Z2YeCqeIUnON+fhtKDvzNOnW5pLdWptRUru6542T95x/OPGvEv6p lS6Xd+qveDs300enl1R6J8N9HsP+eP69vXp68fp1r6Is/BOhjQLb9xn7V/y9/h359D714f4b/tbR 4idKg025+1f8/d5+vPrz6ZGfx+h9HvJ/+Ec8i+gtra4tbPpaXh//AFfp+hr/AEvobv1f/tx/N58E fEmGDR/FFxBB/wAut5n3Oc+/6dun1831jWNW1iXz76f7T9lzZWf/AE4Z6/qfTJroPiRei88R6h2/ 0z/H8/8APfrw/nedL+XHP4/hj046c17WH2+X6ROcKKKP+Wv+f71dIbljz/b9P/r16J8NPF83gXxb pHiC3uCWtrtRcKM82BZR09wWA6c7RnHXzOHyOPw/P/8AV96rEOcjz/bOOuePT/PX2rmxWF+uYR4N 6pqSfXRpL77JWunrrqerkWe4zhzO8pzrAtp5HOMnJXu2pRl01adlfo07dT+mD4D+PINe0bR76xvj 9nurP7ZZj39/6/X8a++NB1jQ4tPt76ckXFqOCLzm/wDcZzz+Yz+VfztfsUfF5rOSfwVf3jefbXxu 9IZs4/s4AFhnPXGCc4IJzzjJ/bXwfr3nWun+RPn09/zyP5/1H8i8XZK8gzh4Va3fNre3lv8A1psf 9GH0dvFDB+KvhzlPEGFaecwjGM1fZxjFNST2enW22zbPjT/gpn8DR4y8H6d8V9E0y4XV9FO3WC1q VvxppBCO5A4VGOScHAzwa/nrngIJDDBBxz6j/PBH0Nf2j+KtHsfiF4I1DQ76D/R7qz+xXnPt9f8A OMV/J3+0Z8KL74TfEfxN4anhNvbW1+bq1yeRp2NwOckkFeM9ip7EE/rPhPxMsUv7Hxk3Fqyjro7W ukr7t6rpa+2l/wCBP2hHg3isFm2V+KeS5VFRqWXE6SsnLRXbWm2jemqjbbX57/1P+c5z+Xp7dPzI f+Xb/gdV6K/aj/LXfpa+qXrsjQ8/2/T/AOvWhDN/+r/P6j8RWPnyZRB1/wAnP+ePfnitCH977df0 /P8ArQBsQzGb9xz29vU/T0/pRWfB3/H+laFAB/y1/wA/3qsUTTef+44P6en4+38/SigAo/5a/wCf 71FHke/6/wD1qACrFV/I9/1/+tViGH/P+f1OPYCgAqxR5Hv+v/1qK5wCrEHf8f6VXg7/AI/0qxmb /n3/AJf4UAY/kweb/r+P88ev/wBfvnmvtn/gnt+5/bW/ZRnz/wA3H/Bvj3/4Wf4f/wDr/l2OK+Lo Yf3v+c/4Z/Q9a+0v2AbPyf2yf2WZ/tGP+MjvgQPr/wAXO0A/TPH8uK+X4x/5I7O1e16NaPfenJHt 8M/8lFlH+KN/S8b7+R/qXXk000Vx+/6d/wDP06fl0rz+eafzbf8Af8/5x+v6e9dxef8AHtc/57Vx /wDy1t/+vo/1r/m6m286lzNv/a5Xvv8Axdd+p/byv9RVt/Z6evIf57/7YZ/4vx8f8f8ARwXxiHH/ AGUzXv8AJr5X03TZ9S1TT9Ksf+P/AFS8+xWf/IG9jx0/I9fx5+uv2z4YIf2iP2j4JvtP2e1/aO+M Jszz/wBFM178OvTr718e2l5/ZuqW85gttSuLW8+2/wBk3f8AxMtMv/7C5/sXXe3iHw6B6Y7Yr/oc 4Ccv9R+F/qd+d8Ma73bur38r7X8/I/izOmo5vmrxWjT13Ttdbdb2tb8dT3Cb9m74m6PLp83iOx8N +G9H1TxJpfhe88Q3fxI+GniTTNB/t3Wv7C/trXP+Ef8AEn/CTnv+Wetcf47+DPirwHoNxrnir7Np txa/FXx58JLPSLvnU7/U/hRouga9461rgceHfCZ13Q+3X1NWPFXxhuPF+jXGlXvw5+Dmm6wcWX/C beE/hvo3gnxLY6Wv/MF0P/hHz/wjHh/rxnwf/wAJr9M19YeKvHs/xs0bwf8AH39ovSrbTfht4E0j /hX3gPwRpX9seG9T+PPjz+2jrvjrWvw8Rn/hKPjd4pGCP+KY8Ddsjmr5vxVleMhiMSrc3upJK/S3 Kk3fp/Lro00rvow9HK8XgmsK5WstXJ2dku73T/4Y+aPhv8EoNY8Lz/FP4na2fh/8F7XWBo1n4hNl /aOp+PPFGh4OueCvhXoX/MweIiP+R3/5kvwWDnpU/jD4830/hzUPhx8HfDlt8Jfhddf8hiz0n/iZ eOviX/1Gvir44H/FT+IB/wBSt/yJfgv8a/TD9nv9nbQ/23vAdx8cPjvfeNfDf/F1NL+C/wAN7Twn rHg3TfA1h4X0Lj/hS/gfQ/EH/JP/AA74T/5FYeKeR/wmmv8AhnwNnxlWx8Zv+CTvhXUtG8D6V+y9 8Rv+Fo/Enx58YPFPw+0e78Q+JPBum+Gb/S9B1r9pv/hOtF/tzw//AMzF8J/DnwP8D/8ACb5x/wAj 8O1fSYTh7F5oljM/doyakoqyWri0mlZPp0Te9kro8z+0VhP9jwauktW9ne3rqtvLbqfB/wCwH+1F 4O/ZR+KHxA8Y+MfB2peLdH8ZfBPxP8MbP/hHv+Jbqeg/27rXgHXv7a/tzH/Uj654Xx/1Hycc1+vH g/8A4KBfDn9qjxJcfs5/Cv4Eal/wsj43fB/S/gV4Pu9WvPBv9mX5/wCLu/8AFl9c1z/ojPhP/hON D8Udf+ZB/wCRI9P53/ip8K/HHwZ+Jfjj4V/EbSv7N8YfDnxJqnhjxJafbBqRsNU0Lp09+lY3hXX/ ABH4P1nR/GPhzxJrfgnWPC97/bWj+LNJ1jWfDep6DqnbWtD1zw//AMi/4j7+n6ivqkuRLCRVmlo0 knpbqvK2v4dDzd36v8bnoPxy+Bvjj9m/4q+MPgf8TbG2034gfDm80rRdYtLS8OpaZ/0HtCGh65xn w7/xPB4oOeO1f2cfsr+K7HxV+zd8D9cnn+0nVPhX4Xvu/bRfTPr9Aa/h/wDEvjzXPiF4o8QeMdc1 zxt8UfFGvax/bXiTxZd3ms+JNT17VP8AoNa7448Q+2cD0P1r6x8Kft4fto+A/Anh/wCHPgHxFbeE /B/g3R/7F0f7Xo/g4iw0v/sODw74tPryDnoR6V/MX0kvB7NvFzLMnwmUTjTzanNNyk3GMV7vM5NJ tKyv5W0vc++4B4rwXC+KzP64k1JdFe+iu+3579NT+3fxtN4B02w8Mf8ACK+I7nUrjVNH+2+I/teT 9g1TA6+hP/E89fXr0/mB/wCC23is6j8SPgR4Ut5+NC8C+Otbz9sPB8ceM9DA+vHgrof0yM/CsP8A wUV/4KFaPHcT/wDCY/2lp/8A2Lfw06fj4b7dO/evmf42ftF/Eb9orxbp/jj4tw3Vz4gtdH0vRvtf h7Rz/Zf9mHpx4f8A/rfhyK/L/Bz6NfE3BHiblXF2Olw88qhSlTfvNyvKHJJO9/ivJSVk3d30uj6X i3jbKs24fWU4N2bafe2z6fcj9GP+CdfwlvvB/hz40fts/E3wPba1+zP8JfAfifwxrGrat8N/Bvxa 0zXvFH9teAP+JL/YfxA/4qfw/wCHf+J5/wAVv4q8J58aZ/4ob3r7Y0H9ur/glfZ2FvY+Mf2bNE1I f8If8G/+PT9nvwbpv2DVfhRrXj7x5/Yue/8AwlniPQ/hX4X8b+Kf+Z08F6/4nr8L/Df7SHxp0H4N +OPgD4A+MXja2+B/jzWP7a8efDLSdYxpmvap/wASA/8AE80M/wDYD0PB/wCoB05rwe8h/e/v7fGO f+PP/P8APp7Hj++Wlr7qfklo/L0dkvuPxtabadD6Q8VfHi/8H/tA/GD4m/AHVbnwT4P8ZePPHl7o +k2mj6NpumX/AID13Wtf17QvBeueBv8AkV/EHh3/AIRzH/FLeLOa6j+wfhV+0h/yI8Hhv4J/HC64 Pgi7vP7N+GnxL1TP/IF8D63wPh/4i/6lXxZ/xRX/AEIXrXl/g/8AZ7+NPxC+HPxI+MXgf4V+LfEn wv8AhKP+LqeN/D9n/wASzwkfTXP/AK5zj9P0g+Bn/BJHXPjx4D0fXPhz8YtE/wCEw174VeF/idZ/ DLxD4b1nw34m/svXfGn9g/2KT/0Lv/COaH448U/8JT/zOn9gd+BXzWJ4e+tYh43KL5Nmy1t0lbpo 9eZWWl9G/JrroZjqsFPWL0d77O2t/T8D8h9e0HXPB+s6x4V8R6VqXhvxBoF4bLWPD2rWf9m6nYap 2/tzr1xj/wCtgV0/gPwT4q+JGqahofhWC2uf7L0fVPE+satq2sf2bpmg+F9C/wCQ7rWua5/4IuAP b3r7p+MHg/w5rHxa8cfsr/FvxxoepfFD4S+Jf+FffB/9o/P9m6Z470vQuNC8F/FT/qXfFp1z/iiP FP8AzJfOSK8P+D9npXgO/wD2iPgf8cNWufhL/wAJl4D/AOFfaxd6to+s6lqeg+PNC8aaB490L/iR +H+D4d/4SPwP6Y/4n/5+LPOcUsK8FPK75vdqUns7Wu7Pe+997a2uz1MHgqOElzYGc1lct3CTUuZ2 7PmfpsvQ8X8bfDfxj4D0vR9cnvtE1vw/4o/tTRdH8QeE9Y/tLwzf6poX/Id0T/sY/wDief8AM2Gu H0HyJtU0fyM22bz/AJewOf8APp+nr7z4x17wdpv7Ofw/8EeHPGOneJNZ17x3qnxO8YaTa2es6b/w iWqf2L/wgeh6N/yLf/CMZPhzn/hKcdyOa8G0eaD+1PP63H2z/j7+vTOPTpjuOOmK9LJa2LxGUvFY pKKbado8t7NJtqy2f+Z5uY0p0MbGUpynZJJyk5WWlkrttK3TbW2isf1j/wDBAf8Ac+Ev2kJ4Dj/i sPAfHpjRdf8Axx3Ff0Y2d551/wCfPB/pH1/P355z9Ofb+db/AIID/wDIh/tI/wDY++Av/TL4gr+i rTv+PoZ9f61/hX9LH/k+HFP+OP6H9h8A3/1cyr0V/Xlh/wAEn8VfvtB8Q+f/ANAfVOv+eM/5xX+V V+0RD537TfxdmB+zfavij46vcdcn+2s5P5/1r/VV8VfuPDniDnH/ABJ9U/8ATLn1P5++DxX+VV8S 5p9Y+PvxHvv+PkXXi3xNe8HI/wCQzn/Oee1f1P8As8m1V8QdbJukuuul4r0um16ab6fA+NS/4S8p 0116a6OG/pr8j0XR9NsZrXT/APTra2+0/wDP369PXORXrGvf8S3S9Q8/j7LZ9Ofz7HH/ANauP02z n/4Sjw/Yzw5tx/Zf2y0HP+frW/8AE68gh8L6xP8A8/Vn0/H2/Hr+tf6j4W/Tt+r/AFsfzbX6fL9T 8yPEk3nazqH/AF+Z79vX3x/+usf/AFP+c5z+Xp7dPzsXk3nXVxPB+gH+e3FV/wDlr/n+9XtnOFFH k/vf856/XHXv+mKIfP4/D8v/ANf3qACib/t27fX/APX/AEo8j3/X/wCtRB3/AB/pTW69Q7+e/n6n d+APFV74Q8T6R4hsif8AiWXox169Bng44zz17Hqcf0S/Aj4hWPiPw5p99BP9pt7qz+22efyPHt9M g+vf+afzjDxB/wDr/XHT+WK/SL9ij4vT6bezeCdUnJFtm80jPZ1xkcgjkENye5H8NflHihw59dwU c3wkbypL3mk23DmTelt4uTd+qlqtEf379BnxjlwTxfHg7N5NZPn0lGCcrJSfLa2y9UvM/oG8N+JL iz/15xbn/j8z1/8ArelfnF/wUn+Aw8WeFLb4peHbEC/8NELrBteg01uFY+ysQScZC7h3r7V8N6lB qVrb30E/+j3P/L3nHb/D0x046V6BqWj2PjbwlqHhzVYPtNvdWeqWV4f+f/S/X8f581+EZDmUspzm OLwulnHm3tvFNNP+td9T/YTxM4DynxX4AznhPM/idKUqb3abhem+91K2l9H13R/HORiYg9Rwf++6 r19D/tD/AAku/hB8S/EfhG8gbyrW8a700seDpxdmRgckjcjbT3yjZ4Iz4BX9h5biVmuCjjE01yxa ae90rp2srp6O2l0+h/zTcY8NZpwVxPnXDObxcc1yOrUirxt7sZ8sbp30cbW3umumiP8Alt/r/f2+ n59vXvmrEM3/AOr/AD+o/EVn+f7fp/8AXo84/wCo/HHOc9emf6Z/nXUfLq7Sb3e/qaHn+36f/XrY hmM8RH4gfjx/nPfJ5rn/APVf8sM9uvXPf9PX8ug2IO/4/wBKALH+um9vz6fyH5jjvWhWfDN/+r/P 6j8RWhDNBN0OP0/z/OgArQ8j3/X/AOtVeift+H9a5wDzv+W849f6Y4/x+lH+u/zjGPz9ffr+R+9/ zupIf9cPqf50AWfOg8rr/hnH5deMf04qv5/t+n/16KP+Wv8An+9XQAebN6/qP8aseR7/AK//AFqK X7Zb+h/P/wCvQBP5PkfZ/PnH+f5g4+vsa+wf2GvIh/bD/Zg/5+P+Gj/gQOO+PidoHv05H/1q+Lpv 9bxP/n+mfxzX1z+w1z+1p+zBOTj/AIyD+DeBx1/4Wf4fI/H6V8XxT/yTGcb/AMGpfu/3X+Z7fDX/ ACUWUvzX6H+p/qf/AB7XH4fyNcPN/wAu/wCNdxqf777R75689Py6e3pxXHzfvcz9/tnfv3+v+fWv +b7Gu3ElToli5Nbafvo/12P7ewv+4P0/Q/z8f21IoIv2kv2kIOn/ABkd8YvT/opnj3+XX1r41mh8 mIf8+/Ge/wDj68V9lftw+R/w05+0x/z7/wDDTXxi9P8Aopnj39fT26cV8azQjHb7N/n9f59vb/ok 8ObQ4H4WxbekeGrO+l2mr9d9Nba36H8WcRLm4hzXTRytbteSuu1rfqewfA34Y6V8QvEeoar4jvrn RPhv4D0f/hJ/iR4htDn7B4X0L/mC6H/1MXizxGP+EX/7j/5/THjb9nz9rb9pCXw/8RvCvwP1rUfh ePAX/FrPCfh7WPB2peGfAfwv8CnQNf0HRf8AkZP+Ke/5Dmh/FD/irP8AitPGn9v/APCdf8Vl/wAJ dXl/xg/4sz8OfD/7PVj/AKN4wur3S/id8eLv/nw8e67ov/FC/DED/qk/hzP/AAm/P/I6a/4nxXtH wr/4KS/E34JfD74b+APhz8MfhLomkfDn4b+KPBdn9ktPGX/FW6prus6Br3/CzvG+hnxJ/wAIxr/x m/4SPQ9D8Uf8JSMZ8Gf8Ix4H/wCRE8JHwXXp5Lhv7UzWebY7WNrcOJr3bLlvzXv2a7vXVq9+XEP6 phFhMI7N2bfXptbrt933/m/Pptj5txPPpVtc3F1/y93dn/xM+vf6f/q5rqPAfirxj8N/Fuj+P/hl rmt+APiBoN59t8N+N/BGsf8ACN+J9B1T/qB654f58P8APcGvsj9pzTf2H/8AhQX7L99+zlqvxR1L 9oC68Nj/AIactPFl5rP9mWGqf2LoH/ID9/8AhI/7c/5FL/mS/wDqfK+F4Yf7eluLHSYPs2kWuLLW Lu0vP+P/AP7Aefz9ua+u1679fXqeWunddSxrPiTxH428R+IPEd9q2peLfEGqaxql54l8b+IbzWdS +36prv8AyHda1zXPEH/IweIvrViHw3YzTW8+q/adb1C04s7vVv8AkGWA5/5Aeh/57EVsQwwWcVvB BD/o9rZGys7TtYfkP8+/c87yu+M+2f8APT9KAND9/N/r/wDSbf8Alz9D0+v+Fb8xg/sa48+4P2g2 f+h4+nX365/XisCK8ghx5H6+35HPf+VdReWfnWFvB/x7farP/Oe36+1AGf58EOgnz/8Al1sz/h/k /pXg/hu81WGW4gt582/2z8+nNe4al/oeg3EH/Hz9ls9U/P8A/WP6d6+d9Bm8i6uP8+3+c8f1Vl2Q bn0R/wAK3sfG1rb33kf8TDS7P7adWtD/AGbqdh/3HPrz15xzXD6z4b1zw3Kf7WguNb0/n7Hq1p/y FLDj6/8AFQD8K9g8BnzrW36cc/p+Ofb2969oms4NYi+w33+k2/8Az6d+focDv61y/Wb9F+P+R1/V r9X+H+Z4/wCA/wBrr9oX4V/AL4wfs5/Dj4jf2b8D/jzZ6pZfEjSbTR9F1L7f/bujf2Drv9h674gP /CT+H/8AhLPDh/4RfxvwR/whdc/N+1p+1D9l0exg/aM+P1tp/hfR9L8MeG9J/wCFwfEv+zNB8L/8 gH+xdDP/AAkmfD/h3P8AxS/5Ad6z/iF4Ev8Aw3LcarpcH2nR7r/kMaSePt/17DxFXi/kwQ/Z57G4 Nzb3Q+22fp/9f6envXYm201q7pr9DkPriH9jn9sv4v2H/CzoPhn42+I8HjzwfqnxB/4Sz/hJPBvi PVNe8LjReutj/hJP+En8QeI/+Ec/5lb/AJHT/qR/X2j4nfBP4xeNvCWj+Dvi58P9b8JftP8Ag34V /wDCwfAf9rf2P/afx4/Zz0HRc8nw/wD8jB4i+E/hz/udP+EL/wCp88InH7seFdBn+GPwM0fSv2O/ i3+zN8W9Y+Df7Gfhf4nXnh7w7eeMtS0uw8UaFrWv69r3jTXNE8P/ABI/5KJ/yHP+KW/4Q/8A4TPx p40/4oceBwK/nH+P37cnxb/aE+KHwn+Ld9/Yngjxh8JdH0v/AIQ/V/CZ1n/kaP7a/t7XfGhPiDxJ /wAjF4s8Sds/rmvK4iy5YiKxuE/5G0Vey8ktvPut3pqmenk2ZPCp4J9rbu1mvPt3vo3Y+J5pjNif tdf6bj9Mfr+XetDQAYL+3gz/AD6fjx2Pf6V9EftFeG/Dt5f+F/jT4H0o6b8P/jcNT1v/AIR60/5B nhLx5/zPXgv2/wCKj/4qjwQen/E/A7V876F5H9qWHn/8fHb8+345/T3oy3MFmeUuOnNTVmlayd1d taW13v8A8A58Rh7yTfdavXd93r+v6f10f8EB/s//AArn9pDOP+R88B9PX+xT+mK/oe0b/j7t/wAa /nx/4IDw/wDFtP2iPX/hZHhf6/8AIl/56da/oY0z/j5tvx/mK/wa+lj/AMnv4p/xx/Q/sTgH/knM qXl+KjD/AIJn+N5jD4S8YT/8+vg/xQfb/kC/px0z+A6V/lcXEP8Aa/xf8Xz5J+1eMNT5J7HWc8f0 H1HPNf6l3xbvPsfw0+JE/a0+G/jzqeh/4QvX/c4/pX+Xz4Ks/wC0fjfqIz/x9eMMfkfT68/px0r+ rf2fy9zj9205+HbS6ap3W2t1q3fp1vp8T4164TKtrWfnfVf18/I9Xhm/4re4ng/5hf8AoXXjP+f8 81j/ABs1LyfCVxP/ANOf9BnPI6eg/wAa7CG8+2a9rH+g29tcf2xqn+idP+Y1z6dzXj/7RV55Phy3 g+v59uev+R+H+pWXb/n/AOBI/mY+B6Kr+T+9uMHn/H8v6Y61Zh/1I+h/lXpHOJR5M3/Pf9R/8VRR QAUUf9PH6/p/9br7+9Hk/wDLf8N36Zz/AJ+vahatLuBY87yZPz9fwz+mM8da6zwZ4kvPCHiTSPEF ids+nXa3ef4QwKnLdOOvPv0Ari6sD/lh+P8ASlisN9cj9StdOLXRK0lb71deX6+rlWa43JsflOdY FuM8inGSaet4yi1pZc1rJvvfa239LH7PfxIsfF/hzR9Ugvv+QpZ9Mf0Pf+Xp6fX+g6l5P2eDz7n7 P9s/0z7J/wAv/r9MjvX8+f7EfxfbQtXn8F316TbEm70g9t4Gccc/d2sPfPGMV+6vhvUoNStdPvv8 +nqP8/p/HvF2SYvh7OM0wqVoyblBtWbTkuV32vbTR2TVntY/6KPo2+LWD8U/C/Kc2jKLzmEYx4l1 TfupJdb9NetvU+Gv+ClPwGt/FfhO3+Kfh6y26t4YGm2WsG05F/poVimsnHQF9oPHygk9Mg/gbODb /aPPH2nnGBwQeMgg/wD1/fGBX9l+seFdK8beCNY8N30H2nT9e0fU7L+X/wBf255r+UL9ob4WX3wg +JXifwhfQNbNa6wfsxPIOmlmI5yckqADnByD1AyP1jwn4keLwn9j4yWsUrXer1V+u6vftZSP4F/a H+DaynN8r8Uski3HO1y8TqKVoPTllotLppO/VLzPBKPJ8rqOvv8A59P0qxDD/n/P6nHsBVeft+H9 a/a9j/Lz83suv3fMPP8Ab9P/AK9WM/8AHt5B9P6df6f/AK6r0QzGL/P6/Xr/AI0AaEMxh/f+v/1v 5fjx1zzWhDN/+r/P6j8RWPViGbyYgfp/+rt/9egDqPO/df8A1uOn59P09+aXzh/07fka577Z5PPX 9Px/T09x0o87zpfy45/H8MenHTmgDoPP9v0/+vVfz/b9P/r1j+d+6/8ArcdPz6fp780ed/07/rQB sG88n7R/9b/9eOv4VYhmx/rz9p/Dp0/yOuK5/wA/2/T/AOvR5/t+n/16AOg+2fuunH6/X8u36YrP 86eb/lhz09Ovf/PPPvVeGb/9X+f1H4ij/lt/qPb/AOv+ff17UAdBP2/D+tetfBbxfqvw5+JHgX4i eHYbefxB4E8Y+FvGXhy0u+ft2p+B9bGu6GSOMj/hItEPHfpXlvk+dL+fr+H4fXjrxX0h+x9aQTft N/s7wX0H2iw/4Xv8HPttp1+36X/ws3QeOv8AjjrXzWfuMcjziUoqUY0pylFtxulGDa5ouMo3V1zK UWr3TT1PbyK/9sw9VbvfT5b/AI3P9T/QPEn/AAkvg3w/rt7pdz4cuNd8N6Z4mvNJuyP7SsDrmjf2 6dF+o/tsj2IOfSqHnQTRefYz3PGOmf8AP6/h6dxqUx8q4P8Ao32j37fz/p79a4eaf91/y7e/0H+f YjvX/N1mmJwi4kza1k1jHZb/APL/AGTslrdpW/4f+1MLf2T12p69vg7a2Vz+AD9uaz8n9pz9pf8A f21z9q/aa+O44vO//CzNeGTx37f1ryb9nXQdK1L4l6f4q8RwWtz4P+E3hvVPi34ktLv/AJf9L8C6 L/b2haL/ANzZ4j/sPwv+OQe9e0/tswwD9qb9qDv/AMZN/GLH/hzNe/Hpz0xivNfDfkeFf2ZPixrn H9ofEbx74D+Elnd/9QvQtF/4W346x/5Y/B9a/wB9ODsTfw54SWvvQhHTs4x0te9tdv00P5IzLXN8 2dl8fXXRtdfzPnjxV4k13xV4o8QeKtcvv7S8QeKNY1TWtYu7v/oKa7rXH/6/QVz8sPkH9/8Aaf8A PTGfr69K+2Pgl8ePDnw3/Zu/ao+GWq6r4tPjD4yeG/C+i+G9JtNH0bUvhn/xIv7fOva144/4qTwj 4n/4SLGuf8UOf+ZL/L/hDeo/au8N/sMab8Pv2Z9V/ZQ8ceP/ABL8SNU8Bap/w0haeN/+XDxR/Yug f2D/AGIf+Eb8If8ACP8AiL/hIz44/wCRTx/xRZH1r9bwuH+q4OOF0vZNd1dJ+m3oux8hXv8AW1be 7/Lr87H57zTTzf8AEqsf+PnVLz7FZ8jNhpf/AEGvqR0I9ea7izs4NNsPsMEH+j2uPseP89f6+1c/ 4bhnvLrWNc8j9x9s/sXR/wDsF6F/n8P7A+tdRPmb7PB/T/6/t9K6ww+/z/WJnzTHzbjr/L/H/PPY VnzXk/m/n07E+n+T+Ga0JofK/wA/z9+neseaI+b5HqOOnp+WBQIsQzeRKfzA+vT/AOvz9eM16RNN PNo1v+/H/HngjPXPevN/sfky+R9SP/r/AP6816RZ+R/Y1v0/48+cfU9Pfp75x2oA4+8mzo2of8fP /IH1Q+n6/wCP5enzfZzfvbjP+jfT+n+fx5r6YvIf+JXqH/Xnqnp1/l6fTINeDww+dL+/PUe/+P8A T0oA+kPhtN9stbeDz+g6+v5+n+TwK+mNNh/deRBj/P8APn14/nXyf4DvP3vkW8//AB6+/b/Pv9a+ mNHu4PsvX/SO/Pfnp+f865zoOwms4NR+0QX0Gf8AQ/p6YHp2x3/w+F/iFoP/AAhOvf6g/wDCP6pe c3f/AD4aoP8APp+gr7Qm1jzv9f8AT7X7cflkdscdfr5f8TtHsfFWg6hBNB/y5/zP+f0roOc+T5tY 1XR7q4+w32pab/16f8S3jr7/AOcd+uPD58I/cQf9ONnafl/k96IZri7sPP1Wf7TqGl3mqWWsXfX/ AImnXj/9fvgmv3Z0H/gkL4Hs/hzp/j/xH8ftN8baRr37K+qfHX7X8EbPRdSPwl8Uf2L/AG9oWi+O NDx/wk/iDw7/AMJH/Yfhb/ik89PFHjn/AIo3/hEaDBOzT7NP7j8z/gZ5/wATvhp8WPgRPm51i70f VfjR8K7QZ/5Hz4UaL/bvjvwXofU/8VZ8OND1zpjPjTQPDFfM3hvyP7Utp4J/+XzS/r/Ie35djX7s ftIfsB+Dv2D9L/4a3+Dvxp/4S7UP2c/ip4D1q8+HniH+xv8AhJtd8LjxpoGg/wDMv4P/AAjviz+3 ff8A4ovx94Y5PFfkP8Z/h7pXwr/aH+IHgHQ/9J8L+FvHmqHwdd5/4/8AwHrp/t7wLrWP+xc1zQ/8 8V8hhqH1LNc0wibX9tJuKvts9Nbb9vNeZ7ddfW8JHFrukltrdLy120/yZ/Ux/wAEDPIm+FX7QHkf 8fH/AAnngP3/AOZL6fhzzx1r+gizvLGG/uIJzc/aLX8cfUH8BX8+/wDwQH/c/CX9oDk/8lU8L2Xc /wDMFH+T+Jr+gjTYrH7VcT4uf9K4/XH4f/q9q/ws+lR/yebjpXv8C3vd3in6vTU/rvgf/knMp9F/ 6TE+X/2xfjLonwy/Z0+NHinVYNSNhbeBPFGifa/+opruijQdC69M/wBuc5x061/m8+EdN8Rab8SP EOh619ptfE9r4k1TRdXBJz/ag1r/AInoPJGccfmOtf6N/wC3dD4dvf2Yfj/Y63Y22pQf8Kf8d3v+ meuheC9f14cjOOf/AK1fwH6zoPk/tJfGC38g/wDEr+L/AI7sf/Lz17/659PfkV/af0BcSsJwxxQl H3qlamnJxV37Om1GMZfFf35Oad0/3b3Tv8F4x3+rZVbp09XHV/d+Yn9g2+j6zqEEE9zm17XfW/8A 8/T+ufl/9pbUv3VvB17/AF9Pr29uPz+qLy8/4mniD/n3urzn+vv/AJ65r4v/AGir3ztet7H/AJ9O nH+fX/OK/wBK8I7x/wC3b/ez+bsRv8/8z5foopIf9cPqf516hzEFWJv3MueMdB1/w/8ArYz0og7/ AI/0om6efj/SPw6f4/zx2oAPI9/1/wDrUUUUALD/AKkfQ/yqeDv+P9Kr/wCp/wA5zn8vT26fnPD/ AK4fU/zprRr1QeXfp3+XU6Twlr8/hrWdI1uyn+zT6befbLQ+nzA5x0OCBkd+xHBH9Ev7N/xOsvG3 hfT73nOqWf0/4mmMY/Mfh/L+a/2/5ecjP+fx/wArX6BfsXfF+48I+Jj4QvZz/Z+ukC1GDgangBST 6cFfQYHqK/N/FDhtZrgvruEu5RV9FvFW33t7zv53d7H9x/Qi8ZH4f8dLg/N52yfPZRjrKyU3KKTd 3bV2ivPRLU/o28H6kfN8meft7n6/5/Mmvzc/4KZfs9/8JB4atvitolmF1bRrVF1k23S800nCP/wA scnH3CwA5zX234U143ltp+qwd+cfy6//AKv0x7BrGm2PjzwjrGh6tBbXNvqlnqlleWft/nNfzjwz mUsnzlYrVNSs9XrrZ6Lp37pvpc/2V8VOCcp8TfD/ADbh3M0nLO6MnQdlLllyJwlFu60dmrK2nbR/ xj/9O/6fr/8AX6e3tVevoX9pb4OXvwb+KOv+GJYGtrazvdTu9LJHF7prFymCDyGRW4OCGVu1fPU/ b8P61/ZeWYpZrgoYzCNaxTfov+D8r/M/5r+OeEc04J4nzjhrNlJZpklWcY3jvHmXLZd+Vpre97or 1Y/5Zf5/u1X8n/lv+G79M5/z9e1HlTen6D/Cupfj1t3Plk9FfRvp5hVj/ll/n+7VerGf+m/6f/Xo GH73/O6rEOfN/wBf9m/z2zjtnn/Jr+f7fp/9erHk+b0HT3/z6/rQAT9vw/rR/wAtf8/3qr+R7/r/ APWqxQBY82H1/U/40TT/APPH88/yP6ZH1qv+583/APXn/P8A7NWhQAQ/8u/nf8vXp+HX16dvw74s f8tSPPNz6fp6f09eaz/OP+v/ABzzjPTrn+uf5UQzf/q/z+o/EUAdRN/y8/8AAK+kf2SZc/tJfs/z +Rj/AIvX8Hf0+Jmg/pxjp1PfpXz9NB+67f6L6/8A1vy4xXuP7MMxsvj78EJu9r8X/hhee3/I56B/ k/rmvl+Jv+Sbzjt7Ob8n7itt32v0ue7w5f8AtfKX1bjf58qf4fef6u95D+6uMY/D/PH8gfrXDzfu vfp+v5f0r0G9/wBTcf8AX3/Q159ed/8AgNf81mZr/hazZ2/5iXr/ANx1+lz+2sL/AMi5/wCD/wBt P4EP26xB/wANV/tTwf8AVzfxj9/+am69/n/AdMbXvh7448Sfs+/s/wCh+B/B3i3xb9l0f48fHXxh /wAI94b1nxJ9g0vXficPhLoWta5/wj+OP+Ec+B+f54rqP28ITD+19+1BP5H/ADc58UB/5k7X8dfb 6n3FfTHwH+LWqfCvVP2V9D8K+AP+E2+JHxa/Y/8A+FY/De8u/Hn/AAhOmeE/FHjr9pz9pv8At7Wv 7D/4Rvxd4Y8QcnXPC/8AxVn51/v14ey+t8HeH2F0SlGDV9N1F/Nr8/I/j/M1bNs3X962vXVbfd+Z +Z+vfBn4ueFYvEE/iP4V/EnRLfQbPS9b8SXereA/GWm/2Dpeu/8AIC1nXB/wjf8AxT/h3xZxz29c 4ry+8mns4bi//wCfWz1S9/H1/r0/PGK/q4+IXjD47/HjXrf9kPx/4A+F3wct/wBrTR/FHgvwH8Tb v48f8Jtpmg+KP7F8QfHjx1/wnH/FN/8AFQf8JZ4c/ao0P/hSPhb/AIo0/wDIsDHjIZr+Y/8AaE+G N98GfiV8YfhJfa5oniS4+HPjDxR4LvPEPhO8/tLwzr39ha0NB/trQzX7jayXbZN9eh8gc/oMP2PR tPse1rZ6XZdv8/p6+oqx5Pnf8sMf56dsY/rj66EMJ8r/AD0/w/Ud6KAMfyYPKPn/APHxx39v89fw zWfDD1M5/wA98/zIP0JrYvIT/r/T/JP55/p2qvQBnzTw9f8Al4xz64H9f5YPTNdxD/yANO/68z/W uH/e/wCd1dxZw/8AEh0/H/PmfX8ev+RxQBzN5/yC9X/689U/ka8G07/j6GfX+te73kM/2DWP+vPV Of0/zn/69eD6P/x9W8HX/Ptnofwx2oA9A0ab+zbq3ngx9oteP8f8/XrXvGm+JPtkVvj/AJesZOOe PwP/ANavn+z/AH3Tt/X0657/ANM8V08OpGzl8jP1/A8df89iKAPcf7YP+ozzj19uufT+n51Y+2ed +4/5d/b/AOv149sfpXm8Opfuvr+n5+vTsK2Ibz+vb8+PywPx96APn/WIYNN8W+J7HyPstvdWel61 1P8A2Af6YxWfFNceV5H/AOv1/Xn3Ndh42h/4rzR5v+frw34osv8A0wDv+PTNekeA/wBl347/ABV+ EHxY+O/gD4c+JPEnwn+CNn9t+JHizSbP/kA6X/Yv9vcf9y50P0o2A8HmvJ5pf3+P9K/4/P8Ap/8A 8/nX1B8cv+J9rX7P/jgwE/8ACZfs9/DD7Z63+qeBf7f8B+v/AFI2h/r9K9A8Yf8ABPf47+Ffgt/w v6xg8JeLfh/pfg/S/iDrGreE/En9pDQfAeu/2/8A8TrXev8A0A/+EX/7HQc9Mjh/iFDcTfCr9k+4 /wCXi18N/FDRef8Asp2vn/3Oe309fmM7Vs1yzFpW0/RenTfzWt2ephX/ALKsJ576tLW/X7/O9vM/ pg/4IEQj/hSvx/8A+yp+F/8A1DD/AJ6/0x+/FmfJlx/IDGPz/GvwQ/4IH/8AJEPjt/2V/wAL/wDq GV+8/n+TFcH/AKc//r/59f5/4LfSgbfjlxV6w/BR/wCD95/YnA6f+rmVadFfTyj+v6+Z+eH/AAUN 8VfY/wBmr47wY/4+vhZ47su2f+QLr/T/ADx14r+LfU/Ivfjx8eNcg/48Lr4v/GO8s/fS/wDhM9f5 /wAe+epHNf1Uf8FN/Gx079nn4vzef/x9+D9UH58D8fcnFfyW6DN5Mesarqv+kz3X9qXtl0/5CnTP v/n0r+5/oI4aS4YzPFuNoy4nupPZqMIXS0Staae9vLXT838YsRrli8lpppt5/wCW27MA/wDLxn/l 6vPz/Pr+PvXwh8c7yCbxR/16+vTr+vavv+8+3jP26C2024tbP/j0tOen+fr1xX5v/Fqe3vPFuoD2 Pr/n/PtX+k2F2fp+p/NDd233dzy+abz5R+ZH06//AFufpxiq9WP+Wv8An+9VevTEFWKPJh/57/qf /iqKACiiigAooooBbq2/QswRYPHv/n/E/QAVsaLrN9oOq2+qWVwRf296L21x6ZGe4BJwcep61jZ/ 6b/p/wDXqAZ87ifkgnA5+o6evbH41MksZF4NpbNa7NO3nvdbej0OzBYzF4DHU8wwTcc3pyjONm00 ouMla1rNWX3I/o3/AGV/jBB478JaPN5//H1/oV562GqHngehHI4r9CPB+peT+4n6/j2HHpjtz/8A rr+Zv9j/AOLFx4F8ZweH729/4k/iTaLclv8Ajw1JjhGA6jB+VsHj5DjJY1/Q54I16DUrXT76D/j4 tf8Aj8/z1/H61/J/HGRvh/OL4ONlN80XbSSbaer6Jpq/dWfS3/QZ9FTxij4qeHWVV8a086yCMadS La5vdUVZrfVa69H06fJP/BSv9n0+O/BEHxM0Ox/4m/hkFb0WvI/srrn14IByMkEY5GRX88V3Z3kF wUktWRgSDkYBI9Dxx39SOCPT+0uazsfEnhy40q/+zXNvqll9ivLS7I/lx74618UeKP2a/wBnW/0y 40XWvAXh201oH7GGW1OmaoD6gjByexz0r6Tgvj55XhPqWMbtot3ps2vT0v5dT8l+kh9DT/iL3ED4 x4bzOGSZvJPni1b2kmlZOV9Oz5ottWtotf5bv9d/nGMfn6+/X8lLGIAccdDjk59+Dxj26d6+6v2u /wBlmf4E6nb674d+0aj4J13Asru6H/Ez0T5mJ0dzu+9ghRhcMowcHlvhz/ph/wCO/r/9fp7e1fvu TZjg81wixmEs3a/32TTS2evVfKzTf+PXiP4ccR+GnFeacIcSZbJZrk7Xv6qM1dWkpWtNNarR+id0 FV/O/wCnf9aP9TN7fl1/mPyHParFeifDB/rv84xj8/X36/ked+9/+tz1/Lr+vtxR/qf85zn8vT26 fmUAWYf9SPof5Un/ACz8j9e/X16df0/Oj/ll/n+7VeDv+P8ASgCxR5Hv+v8A9airFAB53/LCCC26 /X/PB/n1qxD+99uv6fn/AFqvDN/+r/P6j8RViGb/APV/n9R+IoA7Gb/Wz/X+lewfAD/Q/jV8KJ+w +KXgX0I/5HLQfw9O/B55NeP3f+tuPqP5V3Hw816fw54z8L+IreD7Rc+F/Eml+JrO0P8Ay/jQ9a/t 05//AFHHHFfL5/hX/YmcYRK7cKiXS94WST0S3td6XZ7eRX/tjKfVb7bRt+v4n+t9d/6q5+g/mK4G b/Un6D+VT/Djx3pXxf8AhX4A+Kfh37TbaR8WPhx4F+Jmj2mrEHU9P03xx4M0Hx3og4yMqdbIIHQj HrReWfnWvnwT/afU/p/n/Jr/AJvM/wAtxmUcTZxgsauWaxsotSTUotV7NSTs011WjTSVj+1ctxKe A0d701r3TgtvK3r383/BP/wUIhn/AOGw/wBqiDv/AMNIfFD2/wCZ11/HbPp3/DNcP8SNY13Tfhf+ xf8AEDw5qupaJ4g0vwJ8ZPDGkeIdJvP7N1Ow1TwL+058Xde9/wDmXPipoZ9TXqP/AAUPh8n9s39q /BP2j/hoPx5e/wDlbP047d+OfWv04/4I/wAPg3x58IPH/hXxT4c8N634g+HPxH1TxP4bu9W0fRdS 1Ow8MeOtG0HH9hYz08ReB9b46/8AE/zxX+0c+Nf9QfBbhLi6OVvOlklClJRV9eanTtbfZyu3onFP VOyP5po5Ms/4uzXKG1q3ZrTqvNL8dLH4jw2f7Rnxmi0fSoP+Fx/FG30r/TdH+13njLxtpmgn/hC/ APgPgeIOf+Sc+B/BHhbgH/ii/AHhj/oUazvi1+yv8fvhj8NNQ+I3xG+HPiXwl4O/48rO81az/s3/ AImn+en/ANbNf3D2ej6VZ/6ixtra35+x2lpZ/wCfr6Z9eK+Uf+Cj/wACNV+IP7HvxI0rVdDubb/i nP8AhNPDf2uz/wCP8aFjXiMYx0OfpX5FkX0x+IuIeL8oyeXCzp5JOcIym46QU5Ri5N+7flvfVp3T Wl7L2sX4UYTB4OTWae8k3y3V3ZJtK7ur99fRa2/jmg/1XEH+j+36dB+H649c+ab97/kH/P6HpWfo 8082jaf584ubi1tP7FvBk/8AIU0Lj24zg/z9asT9vw/rX+g+En7TAxmt5xhJJPbminZejf3n4pKP K2tdG1r5Fe8m/wCeB+v/AOv8+fpjtVeGbzov3/TP+foOT/Ss+8m838P8R1+vX+lZ9neeTL+/H+j/ AOevUdh7flXcI0PO/e4g4/lj9OOf8nr6BB/yALf/AK8x/SvP5c+b+4/498/56+9egQf8gC3/AOvM f0oOc5a8J+w6vz/zBtV/r/TpXhGm5+1n/rx/wx+le3zY/svWJ8f8ueqf578fkePy8Is/9b5+cf5P r6/gaDoPQLPt/wACrQ86Ca68j/l4tef8+vp78+hrGhm8mL98f8/T3/z2ohhnm/f/AKdfr3/z+QIB 2Nlef8sPyJ/Tv+IBroLObyYun9MfrXLWf+qP0H8xXQ2cx/1H/HzjP+T+Pp/LqAcf4w8+bxlo8EGf tFr4b8UXv/pg/Ie+fWu58HftL/Hf4X/DD4ofAn4f/FvxZ4S+EHxjtBZ/FT4e6Vd6K2l+LSCNBAKs D4m0H/inAPC+PCg8Hg+Cs5ByRXk2vTfbfEesTjI+yWeleGPtfbH/ACH9d/8A1f4VYs/DfiPV7XUL 7StD1vUtP0yz/trWLvSdH1nUtMsNL9Nc/wChf/H1xRsc59Ua9/wUC/a28YeF/FPgfVfipbHwv4y8 B6X8MfGPh7SfhV8G/DemeLfAehaLr/gPQtF1z/hH/huP+EgHhPw5rmuf8IQP+ZL/AOKY8c/8j54R 8GVj+Nv3Pwq/ZfsfI/0i68H+PPE/2Tn/AJjvxO1/9f8AiRn/ADivnfUvBPirQf7Rn1zw54k0QaD/ AGX/AGx/a/hvWdN+w/27n+wv7c7+H/8AhLOpH6V9EfGyH+xvGXwn8Dz5trjwH+z38L9E1i05xp/i nXdF/wCFta7+vjj2r5rO9c0yvror/ctz3MJ/ui/xI/pw/wCCD83nfAL44ZP+j/8AC4NLs7P7J3/4 ov8Apnj8OlfuBrE0EOl6h3/0P16df6f/AFu1fiB/wQlvJ5v2ePjRPOP+awaXZf6JZ/2b/wAyXoB/ D8ff2z+v/jbXrGz8OaxPPfW3/Hmf+Ps/T3/ycmv8G/pLJvxx48VvtJejdu+zd3+PQ/s7gpr/AFay lu3weV3pC/36/jfqfgR/wVP8V+b8IvF+iefn7VaCy784xxwev06DPPNfznaafK8Jah3759P8f88d q/ZD/gpB42g1jQdQsPt1tc/av54+nb+hr8b5pvJ8G9eLr/PI+nFf6PfQqyZ4TgSCeivKe28pRgm9 evuL5p3PxLxjxD+uZYk/X/yXVq689V+DOemm/wBAuP8Arz/T2B/Hr/UV+Z/jb994o1jHT7Z/nHXj j+nI5r9KdSm+x6NqH/Xl/n+vX261+Y+vTedqmoT/APT4fXHrj8vTqP0/vLD6RXp+kT8KOfm/de/T 9fy/pR5Hv+v/ANaj/lr/AJ/vUV0nOFWKPI9/1/8ArUUAFHn+36f/AF6KKACj/lr/AJ/vUUUAFLDL +8DeT3wR09v06e9Twwz3gt4IIfrz1/P6c+v0zj6A+HvwH1zxVLp/24/ZrjVbwWVnadv6d/8AOM45 cVisJgo/XcW2la+jfRdf0evRs9bKsqxmc47KsvyeMpZxUahZJt6uKbsrvrtru9mUfgl8MfFXxM8W 2GlaHBc21vbXf2y8uucWOcgnntxx9eelfvt8H9Yn0f7P4cvr77TPbf6F9r/5/wAdf8Pr0pfgn+zr pfwg8CafpdjBbf8ACQXVl9t1jVrvPHsO3HGOtfHPir9snwRoPxJg8FeFtKtdR8P6V4i+yXfis3pJ 1HU94Q60owQcEk8kcKcZ6V+CcS4jG8a4mTwMW6dJNtqOnKmruUlr2320W9z/AGQ8EuF+E/os8KZN iuMM35c646cGoOVmnPlslFvSzerS9X1P2N8N6z9juoOn2f8AD/8AX0+vpXhP7YXgLU9T8H2vxF8I G5XXvBxF3fW9pk/234XJHz4UEsF6sMEkZC8kEdd4J16DWNG0++gn+09efXofqf09ea940c2OsaNc aVfwC5trqy+xfZPqfftx+fvX5Jh6/wBUnytXlzcqvdPSSXqtWuvXvZn+gVek+KsjjRy6VnKCnTnG S1fLGUHF3a3s+tn6n5YS6nY/H39nnxx4V1X/AEnWbPw5/bej5/5cP7BOcEen+e1fgNew+Vd3EGB9 otr3/HH9Py4r+giHw3B8DfjxqHg7VT9m8L+MrPVP7Hu/fP5fX8egr8FPHNrFY+Ktcjh6Pq+qYwRn hmXGB6bemBn61/QvhvLFNZjhE7KVrLVrVLZaWsk27LVvY/x1+nhhaeZVeGMXiHFZ3k7cOJmmlOVt Ip21lZJ3vf8AU5KiH9179f8APb+lE37mLHOev+en+OeeKWH/AFI+h/lX62r2V/v8+p/nDdPZ+a72 6XE/5a/5/vUTfvc9un+e/wDWjyPf9f8A61Hk+V1HX3/z6fpSbS3aXq0hqMm0lFt9km2/Ky1D97/n dR/y1/z/AHq0IbOe8/1EBH4Y7duf8++RWzZeCPFN7/qdE1q4/wCvXR2/XGen4dcj0rn+t4JbyV1u m3v5rm/Q9fDcPZ7mn+55LWdlp+7qXdrdo36aWXz7c9R/y1/z/ersJvAfjGKLM/hzW/8AwT6yPX1/ z/XHvNNvrP8A19hc23B46+/+f8mp/tPB7c0b/Ly/zQYnhzinBpfXckrK1l/DmnpbryrfZJ997Mz/ APlr/n+9R+//AOWPX+v+cdPx7Ufvf87qsQ/9N7j8c/qTj8Oa6lJS+Fp37O55DjKL5ZRlGXWMk1Jf JpP8Dubz/Wj6n+RruPhtaWWo+OPC9lqn+kWGqeJPC9leev8AZf8AbXXnrx+tcdqUMH2q4/H+fvj+ g/Guw+G/kReMvC//AGMfhc/lrRJ7/wBTnHtXg8QtrIc6lFtTVGo00/eUlCNmnumns7rU9vIf9+yi /wDNHfveF/1P9Z+y0HQvDel6foWlaVbado+haPpmi6PpVr/xLdMsNL0LRjoOhdc8Dw70GcjAHpXM TeRZxXHkQfX1Pf8An/8AqPSvQLw+dFcdv/1/57f/AFuHn7fh/Wv+bLiBvF8XZw8Y7/7TKzd3/wAv dF06eXe2p/amFw1svVtuRW6fZVtk1pZfht1/hY/4KTw+T+2l+1tAe37Qfij6/ebBP5/y/H1//gkj 8WoPAf7Tf/CD6rP9m0f4oaPqnhj6+KNC/wCJ9oXXqedcI/LIrzH/AIKcw/Yv21v2rv8AstRyTz/z CNCx6/Tr+Wc18O+D/FWueCfFvh/xj4cn+zeIPC+saXrWj3d3nnVNC1r+3un+eua/3J4d4ewvFPgF lGU2UuXhOjLldnzNUYOOnVu1k/1P5j/tF5Vxe8Vdr33d63V5WXRKy3s9vz/0QPO+Ek32ixnn0wn7 H4Xsv7W0n/oKZ1/jQ/8AoXuv+HeuG+Kmo6F4p8O6BpY1TUfEmkaZZfYT4f8AEA0XUidK1zRtCOuA ng8Fj4Yx0B0E9zz80/s4fE7Q/wBoP4a/Dfx/4cvrW30/xlo+l3n2S6x/xIdUH/Id0Ue3/CR/234X yfbpX1N/wqXxVN9n/wCQJ/pV59iz/bH/AB4ca/j686Frn4jtX+deZ5hxbi6ua8OZNwt7OpRnpPlU ZJ05KzTsnuk9G/LQ/aLZROKxmNzO8WtlrZtK662dm1olftax/Cz+1p8AL39m/wDaP+J/w6ng/wCK f1W90zxN4QvOov8ASx/b39hDPr/wjvJHT/hM/AXiX3r5WvIT5vGf5/59+w+hFf1wf8FPv2Idc+PH wb0/xxpWhalpvxI8BnVLzwfd/Y/+Q9peRr2u6Ln1/wCZo9P+Rn4/4q6v5PtShnml1Dz7H7NqFref YtYtM/8AHhqn+QPy61/o79HzxHxHGXCWUZfjEocX5HCNPiWEn/JCEb2drt2vZLrbWzZ/PXFuWvC5 vz4NXydtyvbe7vu+nl9xxE0P+T/n8jj1BFY8/b8P611E0P8Ak/5/I49QRXPzQ/vf85/wz+g61/RS 1V1qu62+8+QM/wDtI2cX78/abf8A+t0/n/T29g02YzeHNPuIPfp6fgf857cV4veQ/wCf5c/yH596 9o0GH/iktP8AX7Hzxg+3f1x/nNAHHzQn7LqHp9j1T/PX/wCua+f9NvIIP+nm4P6Z/wA59/Wvpib/ AJiP/XmP6V8v2kME0tuD+ZPb/Pfv16c0Wfb+v6aA6iKGeWXzp/8ASfp/+v8AWvSPO/tm/wBQvvs+ m6abr/l00mz/ALN0yw/Mfn7dfSuX02z877P1/TJ9Pr/kiu4hh/z/AJ/U49gKPPp3/r1Qb7B5Pk/u M/06/wCGffnmjU9Sg0fS9Q1W+/497Wz+2/Tp/wDqFaHke/6//Wrz/UryDWNUM/8Ax86BpZ/8D9U9 e/1o13W/TzfT9A0vr/wbdTOm0fVdN0XT77VrHUrb+3hql79qu/8AkGX/AD/zA/8AoYP+ET/l9a/d HUv+CzGleKvBH2HXP2c7bwT4w8LfAfS/gt4Pu/hP4k/4oa/0sD+wdd1rxx4H8QeGv+EY8Qf8JZ4c H/CLn/oS/Bev+J/+EC/4rzxdX5MeAvjl448B6f8A8IprkGh+P/hvqn+m6x8KPiFo/wDaXge/6j+2 tDGT4m+H/iI/9DV4T8X+Dj68cV183wy+DvxnlM/wW8RnwB4wugf+LI/FjWOP+5G+KnTX8f8AU2f8 Id40/wCp48ZV83ieIsVlOKf9r5W+XdtJuKS3v5pWaS6Pe9z0/wCzvrWFSwtk9L3dn0Wi3d+m33an 6w+Nv+Cifgf9t618Y/sv2Xwd8W+EdP8Ajv4j8L2V54s8Q+MdG1L+wvAehfE/w/8AHj4reNPip/xT f/FQf8Kn8OfCvXP+EI/4RPHfvgH8RviR8SP+FqfG7xx8Rvs/2a28ZeO/FHifR7Q/8uHhfGNC0Xr/ ANC5/Yfhf/69e4WfgjxV+zp8Kvih4q8Y6HrfhP4gfFHHwK8H6Tqtn/Zup2HhfXf+J98V9Z0Pj/mb PDn/ABa88/8AM/eJ+etfI2g/8hW3+o/ma5cvxLzbGf2vhUv7IW19bP5tq99NLWS69HXw7wmFjg9b 3Xe99Hbye3fZH9gP/BCuL/jG74sf9lg/5dP+xM5+nb/9dfqR8TvB9jD8PvFHn6rbf8eeq/6WP84P t6c+lflx/wAEMYZ4f2X/AIsT+nxs1Ufn4L0E/XuP6kV+l/xz1L7F8OfGE/8A1B9U/wDr+vPTpjIr /DX6QaX/ABHHj5aNPieCWm6fJ7q7paq22h/YnA9/9XMp3tyr7rR/X9fM/lH/AG8LOxs4tQ+xXxuf 9M+xc2ZP+evfPXpX576l+58OeH4Of9L/AOPz37V9/wD7bEPk+ErefyP+Qp4w+w+4zovH4c8fj71+ f/iSH/RPD8H5j3/p78Y49K/1T+ivl3/GvMrd7aK72votN++/mfgXizif+Mi+qX09dFflen3vtt62 8/8AG032PwnrE/f7Ef8APX6ivy/vP9b/ANvY/kK/Sn4qTfY/BGsdOv4fy/X1r815+34f1r+rMPt8 v0ifkuI3+f8AmV6KsVBD/qR9D/Kuk5ieijz/AG/T/wCvVf8A5a/5/vUBu7LV9uv3biQ/64fU/wA6 s/8ALX/P96ijyPf9f/rUDaa3TXroFWLOGeaXyIMfaLoj3/zxnr+dV6+uPgD8JftkR8Y63Y/abj/j y8N2n/P/AKpj9ev+c1z4nE/VLN6p/wBemi+4IJylFRXM21ZLVvXoluaHw3+GNj4WsP8AhI/EkH+k /wDPp0+wdPfvnrz+dfrR+x/8Db7zv+FqeMLH/icap/yJ/h67P/IB6c8jPf6+voPB/g98JZ/iF43t 4J4PtPhbwbefbdY4P/E+8Uf9AXrz/wDrHtX33+0B8dPDn7MPwsuNZBtZ/HGvWLWngTw+3oqlv7YH r4f8LEeXGpI3yFFyN2a/E+NM8xecYz/V3KW3dpSabb1avd7X+7bV9X/qN9EvwVyXgXhnNvHfxNUY wjTc+GIVIpe6kn8Mt3a/TpufL/8AwUL/AGqLb4b6DcfBDwHfQXXjbXbM3vjzxBZcHQtMx8uh5wQM 5BYkHABAGSK/AWa7PmFsfZ8Hk9+3Pr3H6ehrc8YeLtZ8Y+JNY8RateHUb7Xrk3d1d3TEm+JOS3oS STngDsOBiuT58wnIwTgjvw2R+H86/T+FMjwmRZQsI43lKCTk9W5OzenSzbS11tdvWx/GPj34x8Re LPHeZ5uqjWU5FUa4Xpqb93IKcny+7tzPRvlu2tL6afu1+wZ8cB4p8ML4W1O+Y6roarZ3RYYzpm0D RcYAHyuGXrkAA45r9VdN16x0e/0+Ce+tra41T/jztPtf/H/jvn8+3HbtX8nXwR+I/i74ceN7DXPC JK6gT9jFsF3Z56Fcjr14xjHQ54/oc+Cej6FZ+HLfx/441U634w+x/bbzVtW/5Blh2/sXQ+nr3x+P WvwPxI4djkWbvGwsud35U0+WUrXSitbJvS61VtXqz/WT6FfjfjvEXgXK+HMdGos3yKKjzzjJKpGK Vvedoz0S1T3bdkmk+i/bY+Hvir4heHNHg8K+B/7buNL/AOJ1eeLTef8AIB/z37nvX80/jbwrqGn+ J7/SoLFjPcXf2wdSFBJOO+ASScdMknHWv6t/DfxC8VePf+JJ4A8Kj+x/+XzxZ4s/4lumdf8AoBn+ n4V8/wCvfA3wP4J8UXF7/wAIromm3F1efbftd3Z/X/PP5dh0cFca/wBgYS+K3fXr00vv23v+JX0h fokYXxz4iyriLKc3/sNc1uJ05OztbVK9m+l/w3PwB8HfsyfGHx2bY6J4O1M211ybu6tCum/gSCR7 HHvivr/wf/wTN8falHBceKfEWiaKDx/op/tM8kckgDnsRjH6Y/Vez1iCGLyNKOD/ANOg/wAO3pj1 +lch4v8Aib4d8F2wvfFHinTtFgJ6XV5nUz9MZOeOMc16mI8RuIs1f1TJk973s31Vnr0t93qz5bIP oPeAPAmD/tbjbOY5u0lJKpUVNNKzb1asnbWS2Vux8r6F/wAEzvhjaH/iovH2tagP7tkdH00cdMFi x7d2OPpxXrGjfsFfsz6NKJ57LU9bHf8AtbWT9Ovh/H+RXz145/b48C6RLcQ+ELXWPFV+Tj7Xe3ja fpx7nCoCeO24ID2bqB8g+Lv24Pi5rkx/svUodA04/dtNLtRfAcdSuul2PrgSAGurB5f4i5rpipum nZN8ziradI6vS10k1f00+bzvj76D/hS7YPhPhzPs4h0UVxC/daWkpWipestHoz9w9B+BvwW8N5g0 PQ9Etvb+xtG+v/1ux9cV6BD4J0OHP2G/03Tf+5a0X/P+fy/nHg/bB/aEz+48f3WOOP7I0XJH1wev 0H06GvR9H/b2+O+jyf6dfaLrdv8A9Ray+v4n9enbilifDri7f+1m9m7N3Wzs7/8ABtZdj0Mi+m79 Gf4f9Uc/yNaJOPDOQKKWivHRySS+dktXZH70TeA/GM0Vx/Yc/gnW8Xn/AB6Xdn/xM+v9emO/foK4 fxh4V0Oz+0QfE34O6Z/Z/wD096N/aWl/+DzP9f8A635w+BP+CmUwxB4w8ICAHn7XpN2QRkdx09eh PTrk8/oN8J/26PAXjDyNP0zxVBMbo5/snVwARzk8FSMHvkdM45NfOZhknEuV64vnklb3lzO9rb2v byvrbzP6C4T8W/o9eKUbZPxFwnCc1ZU+JqVKE76aKLSSey2Su1eyPKPFX7C/7OvxatDe+FYLnwVq 5sxem78P3YOmjHOF0QglevO0rnoeMCvzw+Nn/BPf40fCy2uNd0qwtvHvhe2P+l6r4ez/AGlp/J41 zROWAXjGck8kmv3lu/DXw68a41zwRqFt8OPGHT7ZpQA8NX/r/buhrgdTxhRyOh61z9n8SNc8N3// AAjniqxttN1j/n7+2f8AEs1/S/8AqB8jqc9f50ZfxvxHlUkqF52suWpzbXWiu00tW9O60dzwfEP6 J3gv4hYLmr5VDJM2lquJ+FlFxlqrO0Lxd9LavTqmj+YDUs+Z+46fj/Xn19v0rY8Bwz/8JTo8/wDy 7/2xpeenX/Izj65rP16G3h1S4n8//R/x/D6/kDWj4Zl8rW9Nz3vgfoCR098f/rr9+zhc2RZxH+ah Nd96aX53v53P8FcibWc5Q+zja+1/ct+N/wAT/XGm/wBVP9P6muJm/wBSfoP5V3GT9l8/Jx9j6/j/ AJ79K4e8/wBVceR15+nTjPbOP84r/mw4g/5KHOb7vEVPV2qRv92tz+3MJ/yL/wDt1f8ApJ/D9/wV FMFn+2v+1Rnt8R9LvB/4RmgHnP1x/j1r85/O/e//AFuev5df19uK/Sn/AIKuWfk/tw/tPf8AY9+G PoP+LZeAj/nvjtX5jTTTiW4xz69f6Z9vX6V/v34GRv4XeH6ldqXC3DqlpunCPMn6LTX1P4/4ufLx FmjWnLJbdLT/AFWvzP2g/wCCSP7YF98GfiNcfB3XNdOm+H/Hmsf214Ou7v8A5BugePBx6/8AM15/ L2xX9X95r1/puj297pXxF1K51DSgMaV/Y+jYJ106DrpBGOMDxvrfOeugkAcc/wCdhpmpT2ctvPBP c21za3n22zHB9B/nmv6iP+Ccv7dVj8ePC+n/AAr8fz21t8YPBtl9is7u7/5nzSu2tdP+Ri/4Rwfl X84fSV4Kzfhb+1uMOD8qk203JxV3bRyenX713ufecA51g80tgcc0rdG1rto79et1a+nRH7Ea94v8 R+JNL0jQ9V1W5udH0Lm0tR+nYZ4/X6V+AH/BQ7/gnvPrF9qH7QvwB0LGsXVn9t+I/wAPrOz/AOJZ r3/Ua0Tuf+p28LH/ALHk8Yx+7H7ibHkXH1/l39/84rW8LeG7HxHrthpeqXp0XT7nP2vVRZgfYSOg yTjn34GeTjmv4S8NfEfjzKOLst4hynMpuLly16a5kpK8eaM1t00b0TV1rY/Wc8yPJ80yf6pZLTSy 11s+i12vpf57n8AE1nB9quObn7Ra/wDH5aXf/ITsP6eIM9vFPpXL3kP+f5c/yH596/rJ/bp/4Jef Cr416z4g8R/DPWtN8AfEjS9X1W9HiHSbQ6Z4a8dcZH9udV0DxFk4PinwoCD28EeMTzX8w3xs+GPx F/Z78cav8Ofirof/ABUGmYvftfh68/4mf9l/9gPOP/CTz/j/AK5+FnjVw94hwzDKlVjlWd5MlzcN xvKTlaN5OVrPmd5K0mmnq07xP5o4k4TzXIHdfw+a6fS2junftvbre2x4fND/AJP+fyOPUEV7RoGf +EX03H/PmfpnAxXk/wBs0q8B8i+tvtGf+Xv/AIlup5/x+nUZ+te0aDZz/wDCOWHkW/2m4Fnx9k/z 9B+XtX7HiMT9Vtf3VpfyT16+b6r5dD5FYdtdfO3/AAxx4z/xMv8Arz1Xr6cf06V836bD50v+o7ev /wBfv9a+p/7M1aaW5gn0rUrb7UeSbP8Az/k14Bo+jmGXz5z9mt7X/l7u/wDH1/XOKf1/DNXwmZPR K65W10vd2ta1/nquyaw+N03tp93/AICdRo9n+69B35z/AJx79fSuoh/de/X/AD2/pXPw69pUP7jQ 4NS1u4x/y5/8gz/weccflzX3B+z3/wAE8f2jP2ornT77VNK/4QD4b/8AL5qviGy/s7TL/S/rj/hJ /iB4i546+C+2Mc18xxHxxw3wZlf9q8Q5vDJ8stJqCnHnm12Tak230W99Ez08uyPG4yywald2Vkm+ 1tbPT9badD5H8E+A/H/xy8XWHgD4SaVqWt3Ovf6Fef2TZ/8AEz7f8gPp/wCFT9K3/jn8APiN+zf4 8/4Qfx/4cttDuLT/AI8/+Yl4Z17Sun/Ej1z9f0r+zL9lL9gr4Zfs0/CDWNd+HNvptzcaZ/oXjDxZ q15/xXHizHA4z/xT/h3/AKlbkn6kmuX/AGm/2Xvhz+0r4EuPCvj/AEr7NqH/AB++D/FdrZ/8VL4S 1TOf7a0TkZHf+vp/F2c/TGeV8d5UsTlk1wXKXLGtyt3TklGejs+jerVu9rH6fQ8Mlisnvos4Suld JvRP/J+V13svyW8E69+zn/wWA+I3xI8R/tJ33gj9jnUPg1+zf4X8MfDfSfhPef8AH/qn/Caf8jpr uh+IPDf/ABcDw7jXP+EX/wCFXc+NP+EL/wChyNfkv48/Zp8HXnxu8H/Cv9nP40+G/j94X17w1pfi e8+IX9j6z4b8M6Dpf/FQf27rWuf8JB/yAPDvhMf8VR/P2+6fAXirxV/wT++N3hf4ZfFT9nPw34tH /CSfC+90f4hfDLw3/ZvxM8eaVoX7QfwD+LX/ABI/7f8AEh8MfEDxD4s8N/A//hF/BH/InH/iv/FH evg/4naxY/AfwFrHwW0O+03/AIWx4ys9Ksvjv4h8Pf8AIM8JaXoR/wCJF8GND1zGPEH/AENHjfof Gn9g/wDCDV/ZEOLcBxLk2VY3Jczjnkc8im7WlyRklZO10mlffquh+cyyzG4DGfWsbeLTsle21lt9 +tna68zz79ov4q2PxC8ZaPpXhW+1LUvhv8L9H0v4ffDe61e7/wCJnf8AhbQv+Z01zt/wkXizxHjx QK8f0Gz8nVNPg/4+bi7s89en+f1/GuXmmg6f5/z+P0752NBvPN1TT4P+Xj9Onpg9vTp7V9Nl2X/2 VlDwjVr3bS6c1r/Nef3bnLiMT9bxaxWlr62+S6dtE9NOq1P6+P8AghvN/wAYq/EAf8/Xxs1Q5/7k vQM5P+e3Ffoh+0VqRs/hf4o7kWf4/wAvzz9c1+b/APwRJ1Lyf2RvGA/6rZ4oGf8AuC6B2/8A1d89 8fXH7Y3jCDTfg544nnntra3/ALH1T88/Uf574r/C7xvyuWO8fuJ8DGLcnxPFWSvJ/DbRavV2X5pn 9h8FO3COVu6tyt3dracltf8AI/nH/bw1+wvNB+G2h2M9tc3H/CSape3menX2/wD1n8a+B/En/IU0 +D/pz/yfpx+nft0Hj34hf8LC8b6f5H+k2Gg3mqWQ75yPr/8AWrj9em87Xri44xx6Yz6fn61/r/4F cNy4f4GynB4xOL5YtxaalqotXWjW3X7+38w8f5j9b4jbWq2utbWaW/W99+lra6X8X+NnnzeCPIg/ 5esjrzz0/Q/j0+n5/wB5pt9Zy/v7e5/yQOe3YV+gHxs16DQtG0aeeD7T7/59uOnNfN8OseHNeiuI Jxc232r8vQf/AFvXiv23D7fL9Inw54PB3/H+lV67DxV4bn0eXz4P+Pcdf1PU+4/yOvL+f7fp/wDX rpWvp3307mC126bta26308tRQcHrj3/z1p6Q+c+S4XH8WOvbgfQ9OOvftv8Ah7QdX13VINL0qxuN Sv7ohbS1thkDOe3J557deDg8H9V/2dv+CaniLxhHba78TJv7E0+5/wCYTbAHUye3ynK4wOhBH07e HnfEeUZCpPFuHMlZR5k5vbRRs9Nd2tb6Xeh+u+GHgp4h+LuaRwPCeUNU07z4knFxpK1vk3be2qWz 2v8Ak5ZaBqerziDSbO71S4P/AC62tj9vAHHO0DnnPbPpmvc/C37Lnxv8VS/6D4I1ryLv/l6urM6a MepJxz6cN3ORkV/Sf4Q/Zr+AX7PHh03OoWXhzTmtiSdX8XWhJPuSSc/j39q+X/jZ+3f8GPB0M+ie B9bOt3xtCA2k2R03SrEjGQD0JHfHOcccgV+d/wCvmbZm7ZPlMuW+jnfm5dPe0UUnZPTVLz3f9n4b 6FXAPBOVLN/F/wAVKFKWjdClKCUbJNwSlJzaWqTd5adHovxv1n9l7xx4K1nw/B45FtbQXV7/AMeg vANSI5H3Qv05yMehzmv0X8B+Fb7RvBv9qwQf8TDVbz/hC/AmkWn1H9u617/z/r4v4V1LxH8ePHmn 30/2r/iaf6FZfa/89O/8uuK/Sj4b+FLHUvFFx4jvp7a28DeArP8AsXw39s/6Behf8h3Wv+5sx3/X g1351nONw2UfWsWvfaSUevM7Jq2mvSx+V+GPhBwlx544PLOCff8ADXIH7WrxRJ3i1FxcnKTfVJ6t 2387+gfD3w3ofwT+Gg1W+gubn+y7MXpNp/yE9e1Tj+fT+ea/n/8A2qfiP8TPi98RdX8T+LNO1qxg e5+xaBaXCyLpuhaYWP7obkUsoADEhdrEnJbCiv2VP7bvwN13xJfeG7ize5stNvDZ6LIVbY2G2n5s Y+9wMkHPbFetzw/Bb4hWp8+xtrm3uuP+JtZ/2lpnP8vyxzj3r84yXNMTwvjHjsblSn7RKzk7yV2m mnqulk33sf6N+Kvhrw94+8H5XwX4f8frJcn4fXs5xp2dOdSCUWqih2krvVejsj+XnRtA1bXboWOl WNzqFznraWZ4x34yf0x/X7K+Fv7FfizxPNa3/iyf+zrC5xi0tgp1LA4xt24Oepzn1Hof2Ms/2Y/h zZ/aLjwdBpuiXH/P5pVn/aXrj1/z2rifHPgj46eCdDv5/AeieHfGk3OWRRYarp/B6KXjB5wOXXGc jJ4P0eZeI2aZtL6ngUskulFSnyyfvcqunZWu9Xa2nXdP+f8AgP6C3C3BEKvEXiLKfHNPJE5Sp8NK UudR95KdOLfPpduLT10S6Phfh7+zH8MvhxYefPZabbm1/wCPzVtXyfwHt16Yr1rwt8SvhrqHiWbw x4e1nR9QtIN17qtsykaVZ7Dh9hIw21sK2DweDg4FfkB4x1H9pj4m+MD4d8bz+I9N/wBNIvNK+y/2 bp1hyP4OMDHfBGc4JAr9L/2ff2ePD/gvSxcXUT3mo3ChbrezMb5RnAXJOFGSQBxySBya+TzzLfq2 DWMzjNlnmbyV0oy51Hm0S0bSa7a9Nro/evCDj951nT4a4D8KHwNwjknMp8TcSw/1fqVIpfZ0Tm7p attOz0u9PubwH8VLHxJ4o/srwrpV1qfh/S7MfbfEPP8AZh+vX/6/PSu4+J3gmx161/4Sr7dqVz9l P+h+Hry8P9mf2p/L/PvmvD/BPir/AIpfUIPA9jpupaha3mqWVnaWn/Et0z3/ALcx+H16e1ekeCfh vPqWqW+ufE3xHqXiTxB/y56TaXn9meGdB+mhkn0Iz/8AXz8Av9lkuZWbabTXdq+j0T/rZaf1nRbx mAy9xqR95TXtIy91t2SlzLRpPVO+qT76fhV8cf20fiINT1jwh4Q0k+ArfS7sWd2FOPEo+bGHJGfq qjJyMMCa/P8A17xN4j8SXf2/xBqd1rFxc8Zur055z/ESMe2Me+e36pf8FOvgPo/hDx23j7w8VH/C TAWviK0azP8Aoeqg4OrcdC4yQSeNuOC1fkVNDiU/hxn8vbP6A1/VHBGHybE5TDGYLLI8/LC9rKSd oqT8rvVWtp2aaP8ABf6WGe+LmB8Rc34e424prZrSdWX+q/LKdOk+HXqorltFtRstdea7u9Eq9H/L L/P92ijzvJi/cfl/n/OOa+4Wm2n9eR/I2r1xmrVuVvXa271f3+V+hY8/2/T/AOvVeDv+P9KKKAWJ V1d6aden/gRY8/2/T/69aEF5PDLbzwT3P2jPP2S859+v+ep5rHqxDN/+r/P6j8RUuMZbxi/VJ/md eFxlTA4tYzAzlBpacsmuV230a2t1/wCG+zPgr+138SvhlLDDe6pc+ItB3D7XpGqXpOoBe/LuXBHr uYMOMDAr9dPh78ePAHx+8L28EF9/xMLUH/RLv/kJ6CeOfxz7D+dfzj13Hgjxv4j8B67Ya34c1S40 3ULUjHYg5x/I9/Yj3+B4i4CwmaWxmCtHNnr2jrbfXXpb8z+zfAT6ZfHPhrjMryjibNZZ7wfonzNy krWVnzauy6u931Oo8Vj/AE+4/cenf6+3+FQaNCBqFsYP9fuHr7Z9z+hq/wCMLP7HrVzYz/8AHxa3 n2IfZM9cZ+vXn/E1k6XMfPXPdgMceo/z/wDqFfQYzXJZpPenNd1/Djuutux/HeVf79lPdSXqtV9x /rLfA/4j+HfjV8E/hh8YPBN9/aPhH4ieBPDHjPw4Lz/iW6mNM1zRcY5yOD1/E+lbE0J8q4n6evPr 3/z0/nzHwP8Ahz4W+FnwS+EHw78IQnTvDHgT4WeA/DPhy1JOTpmh6NyT3POTn15rpxD5P9oT+fc3 P2r/AJdOh6fz/wADX/ONx48nXHecfUOf2axXEnIp25rKs3TUmtOdK3NZKPNeySev9t5X9b/s9Xav yK9trcse/rp11P4p/wDgrpD9j/bm/aPH/P1rHwvvffj4ZeAcDPvj8gOc1+V/2Oe8uvsNjBc3NxdX mPslpZ/2l9v59v8AP8h+sH/BYw5/bh+O+P8Any+Dd5+J+DHgL3Pf9Oxr8x9B1KDQfFGj65PY3Nzb 6DrH228tLTWNZ8N6nf8A/cc/5l/+X4V/uz4FYjFPwj4SxUbStwtTSWn2YRsl6aLy/L+SOLcPbiPN fs6v8ZLp+l1023fP3vhXxVpsXn6roet6bb97vVtH1nTenP5k5r0D7H8VPgn4k8H65NB4k8AeILrR 9L+IPgO8/wCQbqd/pWu/8gLWtD59fXmvWPEnxs8D+NovD+leKfB3j7RNP/4TDwve+MLTSfjBrPjb wz/wi+ha0P7d/sPwP8QP+Kn8P+Ih/wBTX8YOODxXQftIftLeHP2hPC+jQT+AP+EJ8YeDfHnii98N 3dprGseJNMv/AAH46/5Dui64PEHiQ/8ACPnwn4j0PQz/AMIt4T/4osf8VPXtzx+f4/FPAY/KVPJp +7JSSknFpJ663b6q2i666cuFoZVg8KsZg80azhNXSb1tZ2+5W320R+6H7Df/AAUa8K/HjT9P8AfF SfTfCXxgtbP7F/1LPjw/9BrQ8Z/4R/xF2/4Rbqa/aCz+IUE2jaxYz2Nzc6hqnhvS9F+1/bMgjQv7 f6fT+3PoP7A71/nn2epX1n9nggm+zT6Xefbftdpzqeef18J/5zjNfsR+yj/wVW8Y/Df+x/A/x3g1 Lx/4Htf9Cs/ENoB/wnPhLS+ONb/6GDw97/rX8heLf0cOIOGMTm3E3hJGL/txSb4Z5bpN6zkt7X19 Pz/V+EuPsJmdsFm+jTSUtr8tl5aXtfo+t9j+ij4heMND+HvhLxR4x8VT/ZtG8L6PqmtawB1/4kXr /PvX8dGjm+/bY/bD0+x8Y+OPDfgC4+N3xI+xXnjfxD/yDPCWl66P+JENc+nh3v6devP6/wD/AAUZ /aWt/jN+zJo8H7Pd9c+P/D/jLxGf+Fkat4TtP7S/sHwxoX9g40bXdDH/ABVHh/8A4SvxHrgOP4v7 Ar4P/ZL/AGqPg7pvg3/hUf7Rnwr+DmpfDf4S/Cv4x+NfB/iH/hW+j+JPi/48+KH9tf8AEi0X/i4H iT/hWPiDxH/xXGuf8yf/AMVp/YHhn/oUK+o+h14Xy4Wwmb8ScU2yXPJttqpfnv58yV7uTt8Wz5t1 fxfE7O1jLZTgnzJJNNaq1o7PXX57vzPg/wDai+CmlfAf45/Ej4O2Pjjw38WtP8B+JP7Fs/G/h7+x v+EZ17S/7F51rt/wj+P7c48Lf8Jh9K/SH9nT/glt4h+JHwH+H/xN0T40W/gG48eaR/bX/CJD4caz qOmWH/cd/wCFjN64/wAeBX5PeKdSsde8W+KNb0OxttNsNV1jVb3R9JtNH0bw3/Z+l67rX9vf8gPw /wD8Ux4f/wC5T7/Sv7eP2XfhvPo/wH+G/hyD7Na2/g34P+F728/0z/oBaLoHsO59cV9v9J3xIzbg fK+FsLw5mb/tfO53b5U7pWumpRcW2nommlpts/F4C4bwma/770Sdm+1rrTbRaaH4czf8Ef8A4zeb bQap+0Jo1tb9f+RG1jHfk/8AFQ9h/n16/wAIf8EQ/hHZ3327x/8AFTxJ4tF0ftv2Xw/4Q0bw4Tx/ 0HPEA8XD/PfrX9I/iTTPG/jzRvC+rar/AGbc2+maPqn9j2ekf8hP+zOBye+AMZ9q8f1LTf7Nv7ix n/4+ba8+xf6J/wDXHFfxJxp4/eN2WqMcLmef5NlDSTlGFKLd0rvmhFNRb632avofrWW8IcPYlNW1 XR37pa36vu/LpofL/wAGf+Caf7PXwf8ABJ+I3g74c+G9S/sG8+xfa/G94fG3jjnWv7B69PD/ANPX r7/SEMPkxDyM/Z/+fT2P5nHbHP6V6x4PvPA9n4X1j/hI4La51D/hJNLNnaXd5rB+36Z/bWge/wD0 Ln9uDp/jXH+MJtDh1m4g8OT/AGnR9LsvsVndn/l//wCo0D+H069jX5j4jVcfxLlHC+f4zi2pPN5W cof6xSkm5NX5oa667NPXp1X0eS4TCZTinhMJlMWldczWm611Wi3e92zsPB/iTw5ZxeH7fXP7Ntrf S7zxR9s/4pv+0v7ex/YH9hf+mPr/APXxy/jbxJ4OvNG0/wCw2Ntpusf8fviS7+x/2bpg/sLRf+JF /YfPf/63rXyf8c/2qPgt+z3o1xqvxN8cabon/Pn4etM6l4mv/rofv/k9a/mw/bG/4Kc/E34+xaz4 O+HIuPhx8L+n2T7Z/wAVL4t0vsdc1vw/jHh3/qVvCfHfGa/R/DDw88VvFPK1w7Wyfk4PyXV8UTja Tjo3ZtXk2m0tde63PNzvPMpyDFvF4lpS6RTW+lr69/PRdLn1h/wUg/4KA+FJr8/Cz4H/ANia34w0 G8+w6v8AFi0tP7S1PwGf+QDrmjfCvXP+Ze8Qjv4p+nqTX8+2pefPL588/wBp+1f8fn6/gPyz+lfp TrH7HPhXWLX4HweDtV8W/wBseO/Efwus/Hl3d+JNG1LTdC0rx18Mtf8AHfjvxoP+Lb+ET8P/APhE /Dmh65/zOHjHp+FeTfEL4G/DH4bWHx4Oq2PxIudQ8B6x4C/4Vtd2niTwbpumX/hf4rf2/wD2FrWu aH/wrfxcf+Ei8Kf2H/0OA9s85/0a8Kcj4Y8N+HafDuWRk2lfmmnKV01FybtzJOS0Tsktt23+E8R4 nM8/xbxmJsovazSVna2mi23tdXt2Ph8f8sPx/pWh4bz/AGpb/wDLt+f+f5H616x8bPCvgfw3f+F4 PAEHjYaPqngPwv4nvP8AhLNZ0bxJ9g1Tx1ov9vaFouh654f8N+Efy447d68X0cma/tz5H/Hr7+mi 9/8AJr9vy+TzTBu90+Vtbra217ddtN+p8GsP9VkrtP3v669fv2sf1of8EW9S8n9kHxRP0/4vB4o6 9v8AiS6B7fgP0xXw/wD8FRP23v8AhMD4p+GXgC+/4t/4X/0LxJ4stLz/AIlmveKNC/5gvr/wjpB4 x+nfyj9m79p3/hUn/BPzWPhZ4P1v+zviR8RfjB48srzVbX/kJ+EvAY0XQP7c1rROP+Ri8Wf8iv4J HBIzzk5r5P8Agx8AtU/bF+NOj/DOH7Tpvww8LjS9a+KfiHw9Zf8AEy/szoNF0TP/ADMXiwc4wQSP +E5PBNfxFl3g5k+D8UePPGnjuUI5Pk1Rumpqybi04ySdlJt2SSvJtNWu43/dK/EuLxfDeV8JcO3e bWjzNX205m2u1+uj9D4u+Bs2raxdahfX0H2b/TNUvbMdPb/P8scH2CfjWbjyIOvf0/z+HNfVP7VO meHNG/au+O2ieDvDem+EfC3gS78B+DPDfh3SbP8A4llhpehfDLQfD/8AYv6dumfWvlbTYfO1T0+1 Xn+fbkf56V/amSY/B5lk+U5tglaOdQjKEbbQcYyi7dLxae21j8czPDyw2MeDm25L429WnpdO/mnu 7/I+Z/2qLzybXw/Y9z/LHt/nHavi+GYw/v8A1/8Arfy/HjrnmvrD9q68P/CW6fYn/l1s/tvI/wD1 9c49eufb5Pr3MOtLPTSz8vhPEs72SvJ7Lq30X4r7z2/QZoPEml3Gkz/8fH2PNn3/ADwT/j6dhXFe FPh9rnjXxRbeFtDt57m4uCAARxYnOSCfTsec8/iLXw8N/N4h0+ws1nnubi7UWgXBGQOuQSPQHHQ8 V/Qp+x/+zJpXhX7Rrl/pX2rX9d/0285PHOfw79OM/ia+a4s4swnDGCsrucldWaerS81ptt5eR/TX 0cvATNPGjiGNFy/sbIcjalxNWa92VNcr5ot6e8r7X3bTIv2Q/wBh/wAPeB7Aarr2l22t6vcf2XeL ql1gIisS21R0AycnrnuSTWv+1R/wUT8A/AeKfwR8HYNN8bfEC2szY3fiHP8AxTPhIjGRoWM/2/wQ cnAxkAkivCf2/P25/wCwLfUPgL8EdWH2e2IsvHPjTSbpidT1MEhtH0MgqFjUgruByz5RQdrlPwfv rq4u2m+03P2q4YA5yT1+p5x6/j06fB8OcKYziFriLiLZvmjB3Ss7OPu3Vr6b69dVdr+rvGb6RHDX gpl8vCHwThFZtTjyVOKoKKimrKfvK19b8zu9brSV7ey/FT9oX4r/ABn1a61jxr4s1nUrm6ILRyXr fYQMjCqqybABzn5CT/eArx7ToW1LWbDSjOT9qvcEk9/fk9e3PUe1YGSJepHfr6t/hXr/AMGdCOs+ LtOn+zn7P9sxnn6fp+B/p+sRwuDwWFTioxSskkrW7Nt69d7vZW30/wA2M84o4m4rzV5rxLnNfPG5 OVRSqzmne12ovRLskuVfdb9gP2afh7PoOjahqv8AzEPsel6No5/6imu4+n549DXaftG+L/EA8OWH 7Pnwu+ae4s/+Kv12zz/oemHpopI+6q4+bncchVHzF073wHMfB/w50f7DB9p8QXVn/bVn9r5/4meu /wDIC/8ALc6njpXI65qHgr4L6HfeL/HmpltSurw3oVbsnVNe1MfMeB0AALEnAAyScc1+K8U5ljMV xEsJgoqSVmotXheys3HVSSum0007WaeqP9VfoycCYDhvwOzXPMyzaOQx40fNKUpRg1w4leaUnZxb SabVpJO91ZNeXfCH9mbw94Asjq2rfZRcG0LXmqarkKu47iFGeAOwrl/jL+2J4B+G9rNofw6sLfxH r7A2a3hB/syyHQ7f72Mds4IOTxXxD8fv2ufG3xTvZ9Ksbn+xfDRYgWdmP7OF6oI5Y5wSScADjAyT yAPkY3LTsWuGY3Jzgnk89ucngE9/fgkZ+kyXgPF5o4Y7iSSqNu/I29VpZSas031UdVHVNPb8f4/+ lflPAODzXg3wByx5O9YT4qbvKTVoz5OZNN813GWzfrc+x9C/bk+Nug6vPqg1qDUYrpju0u8tQykZ 42qEXGMjkuQeuAK/TD4Bf8FAf+FjXVvoeueFtRt7/wD5fDn+0tM6Z6HB9+Rj0PSvwe8NeHL3xVrV vpOmQG5mujnAPXGM8/8A6+xya/af4HfD3wd8E/Bv9ueI/stt9ltDe3l3d9L716/5PHWufjvJeHsL hFg8Hla/tiVoxcXZrZXkld2tfR2bvduyd/Z+iT4pePPEHFUsfj+PW+C7SnxQ+JdYyvZtU29NLe7Z tL3VbY/SCaH4ZfEOK3/tWC203ULr/n7zpvv/AMhz3/znrXnHiTwH4x8H2GoX3hye41u3ttH1T/hG 9J5/5ChPPXr+lfBXh74r+MPjr8S01Xw611ovhLwxdmz8PJaKR9qOSACSeWYAOcDCggZLZC/U0v7U 0XwU8Q6D4K8f3v2ldctFvGP2QaiNP0xtxUYyCc7T0BHHPrX5bHLcdhsasG05tJTcUnJpRXO72vtF O/8AKk72aaX+j9LxL4O4o4clmeNzOnw/k1Ry4YXE9lThNt8ilH4eZOT92aT5k043TR8g/sn+MviV 8PviDrvg7xdpGtrca7caleWuk/ZCS+r8kvyTjOcYHAxkV+rnwlvfHGvX9x448VX1zpv2rjw34TtP +YePT8v8cVn3mg/DP4zaX/auh6rbaJ4gurP/AEPVrS8/s3U+n/MD1z/636Vn/Df7d4Djt/CviPXN NuRoNn/yMP2z/j/0v349+nXPYUs7rPMv9qwuVcrT5XK3LtZX2Xm/J3PH8MMizPg7D5vleL4uXG/C Em3wzN1FKS5nzXk7t3V3u7dFZaH0v8QvBXhX41/D/VtC8VWVtqVzqtm1nq939jA1PjHTkHIznjp1 FfyR/tA/BTXPgf8AEvxB4J1uxwba9J0q72hVvtNLNjWUAOMbQD/DzuABAyf6jdB+LVhqeqCDQ9V0 S20e5Js/7Wu9Y7/4/wBPxr8Gv+CkPiPxp4k+N99F4wj0/wCx6FatY+Hri0ucJe6QAMEPuO4sSRt2 LjB5Oa+t8L8XjcJmjwT5lGVuZSeias1ZXXRvvo36r+Y/p68J8IZx4fZXnmBSlnWSu3PCKk0nG7jO au+VNPeyuo+p+bk0Jniz+BP48/5x3wOaKJu8H+jcevP+eR+GO3Y/13EE9t9c/wCe/p7DvX9DH+Mu 2r27hN++/wBR3/zx0xj3/wAKK0Z7OeHn37Y9cfX3qv8AY54f+WFzz/nrzj8j+GaAE/cTeh4+mQf8 +3X3omm//V/n9B+Jqv8A6n/Oc5/L09un52P9d/nGMfn6+/X8gAg7/j/StCq9WKAt0S07f8D1sfXH 7UXg/VfAnx4+NPgfVYPs2oeDPjB8UPDF5/oef+JpoXjTX9B13oP+oH9OPavCLHrcfUfzWv0H/wCC qHhufwr/AMFCv22NKvoP+PX9qj48f+rO1/sT/wBRz6ivz4sYsXc8I+0/ZxaDv6MOuOx44/8A118x S/5E0v8AA7v5I9LK7/2vTt/NG3rdH+t98N5vtnwv+G85/wCXr4b+A70f+CXQO/U9/wBKgn7fh/Ws f4JXn2z4GfBe+/5+vgp8L77t3+GWgcf56/jWhd5/ff8AAvy//V0r/m+4ySXG2c+XFnEavtoqi+5e R/b2Vf8AIvj35Y6f9uxP41/+CyUX/GcPxh5/4+vB/wAB73/zGPgH/J+uK+d/2G/2P779sD4s6x4V 1XxVbeAPhf4D8N6p8QfjB8Qrs/2kfCXgPQv+Q7/Yf/UxHp7Gvpj/AILPefD+2x8UJ+f+RD+Dfrnj wXoH0+g9+fXJ/wAEqfHngDUte/ag/Ze8f+KtM8AW/wC198E9U+GPg/4hatn+zdB8eaFrX9vaFouu f9S74s/tzr3r/eH6N/8AtfhLwonsuGVa7fZX+/0P5G41v/rJmm9+ZX7/ABK//BPm79szUv8Agn79 g8H+Ff2JvCvxjttY8L6xqn/CYfE34sax/aWmePPC/wDYv/Ei/sPQ/bxGOn/CH+Dq+oPhL+w3+yv8 E/2c/h/+1D/wUR8f/EfRNP8AjcPtnwT+A3wcs9G/4Wb4t8L40D/itNc1zxB/yL4/4RvXND8Uf8It /wAUd/xRev8Ahj/iuP8AhPP+KLr4Y/aW/Yz/AGjP2UdUGlfHf4Za34S0/VLzVPDGj+LOdS8M+LtV /wCpH1zw/wD8Ux4g/wCY5/zOB9sV/Rh4q+NnxU/aK/YA/Z38cfsk/Aj4J/tIahoPwg/4UV8ePh74 s8H/APCbfF/4LeKNC8F6BoJ/4QfQ9A8SeET/AMI7/wAhzxR7/wBv+GPHNfuawqstVsu/+Z8gfyf/ ABOm8Dnx544n+GUHiS2+G914w8Uf8IHaeLB/xU1h4D/tr/iRaLrnH/Ix/wDCOf2H0715/NNP07f/ AF/8ffHp1OOo8SaDqvhvXtY8Oa5pWpaJ4g8Laxqmi6xpOrWZ03U7DVNC1r/kC656eIvpxz7GuX/e /wCd1ZaPtdfh/Wg02ndOzNjw3428VeD9U/tzwrrmt+G9Ytf+YtpF5/Zup8fz/r+te8Xnxysdeure x+OHwW8E+P7i6s/tv/CWeHh/wqX4mHj/AKDnh/8A4pjxB/3Nng/0zXg/huz+2S3N9fQD+z9L/wBN vPUdOuP6Vsax5/iS1+w/Ybn+0NLs9LvbP/qIZz7ew/x5r5DMMswmJxf+0vkv/Kra6aq1lfZrz7n3 2T5di8XhPrkt1H7T7JOzvd69O/me4eGvDf7JPiTXtPvoPip8Ufhd9l1jTL288PfEL4caN420z+zP +gN/wnHw/wDEgP0/4s+PfgYr+oDwH+35+yFPYW/9ifH7wTptuNH/ALF+yatef8I3/wASv/uYPb05 5+lfxj/6n9xP/U9+hHqO1E008P7if+f/AOvjqP8A9dfknif4B5R4lvKnieJ+JU8j+G1la9rKOl2l unrsvRvJeNcTw+2v7MTvK3m9V5aX6r5t7n9zEP8AwUB+AOnRaf8AYf2jPhdbf2XefbbMWni/Rv8A kKYOg9D7fy9q8Q8U/wDBQ79jvQori+vvjv4Suf8Ap00k6z4k/Xw/4b5Pb/8AVmv4zpryf27cfqO/ Q/pj8Kzv7RuPUV+T4j6FvDubSWEznj3ieUNG4XesdFyq6drpWuk1fe+h9IvFjFYRq2VLW17JNu7i 9Wum9+nTY/qJ+JH/AAWS/Zy0GK4g8AeHfH3xI1C0/wCPL/iT6P4J0w+o/tzxAD4n/wDLPA9+lfmP 8bP+CtH7TXxItrmx8GnRPhL4e/6lTOo+J/Y/8Jx4gJ5/7FP/AIQ7096/LaH7deS28EH+k3F1n/PX Geenr9QK9Am/sqHw4NKgntvI+2fYrz/sKDH+f69K/SOE/oxeE3BeKgsLwz/bvI0+fiRuTurapSfK ultEtFdau/RheJOIuKXmko5p/YmVJXUXo20louurWpxHirxh4j8Vapca74k1zUtc1i6H/H3q15/a Wp9P5ceh5rl/OM3E/wD+r9cdP54ovLOeyuriCf8A5db3p/8AX/n9arz9vw/rX9HZXgsFgMJ9RwFO FLJ9uSEVFLbS0UnZPvuvx/KMyxWMeMaxk3JXtzXbv2e+rbd19+51E3xH8fzWGn6VP4x8SXOnaXZn RbO0vNY1n/QdL/sX+wP7F4/6lz/il/5dqx7zxJrk1h9h/tXUv7P+yaXZfZPtnX+wv+QEPw/tzXM+ 30rPg8jyv3//AG546/4//W61nzTf/q/z+g/E10rLcEtVBLzUfTy8l/TZy/WcZb4nZbXl6d16fgF7 rGq3kXkT31zc2/8AxK/9EvM4/wCJFj+wvTHTNVtGmP2/yP8ASftP2PVBz/0FP7FHXp+nvVCft+H9 a6D4Y+Gz4q8eaNoYz9n+2f6Z/pn/ADCyf06fh+HPYk1grRVnsraa3sjl1bXe6+/pufRFl5Hw++HX 2fyCNY1QjxNeZ/5CfOBoWi/n+Wcg1/Tz+wJ+y8P2fPhD4P8AB2q2P/Fx/GN5/wAJp8R7vp/xU+uY H/CGEc8+FMf8IwcZ5zjjivxX/Ym+GUPx4/a+8If25ZG58D/Dm81T4taxaXZxpl+PA3/IjaL05H/C xf7EU9M5HY4P9S/gP9x4y0e+8i6ufst59txz/p/6/r069a/zu+mH4lcuc8I+FmXOzq1qcuKeXS/L JKMW09XdttWf2HfTT+jfCDhv/Ys1znGavksm7X2TuuuyStrbXc/kB+Omu/8ACX/tN/tYeKref7Tb 6p+0H8Y/sfp/ZbeM9e0LQuv/AGBMY/HHOa8F8Kw+drP/AC85+2Zz2BGfb/63NdjHpHirwreeKLH4 gaXqXhzxeNY8UXniPw/4h0f+zdTsNT1zWgNc/D/hIgMcccVz3hW80qbVLiH7dpv2gcf8fnH5f4f/ AK/7o4Qw0cJw3lEYWUIQgoJSTSilGMdY3TSilaSbT3Td7n4Znl/7Zza387tv/NC2/n5H5/8A7S15 53xL1D/p1szZd+3P4j64/pXzvXqPxruzqXxR8YTzdf7X+xenCg579sZ98etO+D3gK8+I/jXSfC1n u8m6vMXV1jIsdMB+YsccYHTGTnAPGTX1GJxKweEljJPlUYuUm3y+7HtfS7Wi6N6b2vllGU4vOs5y fJcHFyzapUhB8qbvzyjF2sui1fbW9lqfdH7DHwMn1bVbfxtfWRubkXgHh6zu+B/Zwz/bus8/3Qdp z/Fuwcc1+n/7a3x3m/Zj+Cdt4c8On7N8RvifZ/Y7W7syAdD8LZGdZXORu8W5OM9MHPAxXXfA3w34 O+FfgPxB8RvGNjbab4H+F+j/AG3/AK/zoX/IC0Uj/qbPEfHHHc9K/FH9qz4q+IvjVb3/AMR/EdwH v9c8TapfWlmLwhdE0kH/AIkeic4OPCo+hCnnBr8ey3DS4z4jWMxibyiEvdTWikmkr301aeut7+t/ 9TuO87yj6LngFHhHh6SjxpxFSi6s0vftUjHmlJr3rLm11fWz2Pg7UtZvryae9muDcT3ROc8n1PA7 gAdMAke9Vpj5vWcjnp26/wA+1V5v3ue3T/Pf+tWK/co4dQikrqEUtNlZW6Wttb8PI/yexmMxmPm6 2OblObcnJtyknLV67vVvrukjS07TJ9YvraysTcG4u7w2dmMDIwSORj8QMHg/iPv74b+A4PDfiO40 OCD/AEjS9H0uyvO3/E013n39SP8A61cZ+yR8MH1bXV8b61ZM2laXuNvkYXOTt2c5xjJJPc8Y6V9F +A7zzdU1DxVP/wAvXiTxR4n/AO4XoQ/znkDjHrXxWZZv/aebyy/CfZvGXL8KkrJptbpbaO107aO5 +2rgJcJeGuVcSZ3BrN+M6ilw5GS97/V6LSk5JpNOTTav0krdD6L+Ivxk8H/B3Q5/EGpzi61prM6L 4O0gnAGlaCP7CJJPQKBuPTjJr8Y/iv8AFrxd8UPElzrOv6hcsQWFrBkqLRSRhVQ4IXGCckkn0GKw /iD4213xvr1/qetapd3Ja722a3RJNnphJIAX8QABk5GQcnjjdN06+1KXyYBccdiBjpxwOvbr/Our JuHcHluJeMlFSnJq7kruK912jfS91u+2lk7mniJ4453xPw7lHBuTzlkfCORQjDli3Fzkko3k01o+ kdE93q1y1v3Pm/8A68/5/wDZqsQQ+d/y7kfn7n2HtgYr3DQfhLBDF9u8R332a3/6fO39fw9++K9g 0fTfh/Zxf6DpVzrf2X/n0s+nbn0PtzX0eJxWFWl3G+3S2qX+X9PT8ZweWY7He/CDqxWrspNSV7pS avpJ73t3Xc6L4FaF4M8B6QfFWs6rp9xrtyfltHvfmsQMDLckZPoOnT3rkfix8TvFPxM8Raf4R0u4 uf7Kub0Waj1Ibvx04z/Xmrk3jvwPpt9/ZV9of2a4H/Tn/k446+nB5IruLPTbHUovPsfDupW/pd2e j/T/AD396+IxOXYPC415ri8yjKc4uMIzb0lKKimknrZ2stUrK6aP6IyjxM4lzPhaHA/DnClXJ8ny KUHxXPhyMnOpCPK5c8rXfNZ82vXTc/Tj9mP4TaJ8OPh//a2rE28GmWf269z1OeTznPJySSeT618Y a7Fpfj3xv44/aL+Lc50T4b6XeZ0ezGf+J9pag/2F4M0QD/oaxn6DPasbTviF4j/sHV/B3/CVa5/Y 9zmyvLS0vP7S/wDKH+vf8a8Z/aItPip8Rk0a/wBLm0PXPA3ha0Flo/hzwTZ63pulaGM86w2h686s PEDKTu2kNjoRnNcvDvDmKy7Nnjc3ampNtN63Uv8AgPvd3PuPHf6RuWcc8DcK8A8IZY8hyrIor2jV 4ylUioxcpJauXMt3rt2PMbr9pXx5P8TtX8RWk7Wen3d8os/Cwuy2l2Glbv8AiS6LtJAO1SpCg5Jx lhkAfp98Cvi74X+N9tBoOoa54Zt9YW1INrqb6tY6gSOTh4/DjIwAPVWIPrzz+HsMPk6rp/Jtvtdn 9i//AF47Af56CrWl6xfaDHPqml3rW99pjD7LdDqcccZ7kE4JHU46GvczvhPB5phH9StF6WSXLrdW dtNW7X0u9etz888JfpIcS+H+OWCx9SpnuSXXNGU5StG8U1Ft6XV9NbK1rat/0zaP+z3feFZbjVbH XNNudH1S8+23pxrQ+wc+n+T+FV/jX+xdY/H7wQNEuPEWmW/jDSrP7b4P1U2hxqH/AFBeCD+II/Li vzI+AX7dXxZsorXSvGGranqegY+xWuqm6AAPf+2iGbcB6kLz24r9N/B/xO8ca9a299pXir7Tp91/ x53f9saPmwH1+v5+3Nfl2I4a4r4fxccYk0m1Z7aLlt09D/TThXxK8DvGXhrNMnoYBc84csuHJyvJ OUUpSV3fSTcr/ofzofEr4S6r8MfE+r+FvGP9t6Zq+mXpF59r0gbhjHXHiIdc/e7kEcYxXm3lWIlz PffZuP8AnzHfA7Zx19jX9IHx++Bs/wAeLC3sfG8/2bxx9j/4pvxDaf8AEx1O/H/Uc/8Aretfiz8V f2e/jP8ACvWJ9K8ReHbq2gIP2XVbwAC+0zdgYbJ3ZHXKjk45GDX6hw5xNDGf8JGMlCOc2XutpN3s rpK6+Wy1srH+anjn9HvHcBZzLH8NQnnXCU3KSUYyfJd81nZN2gvd6bdW0fK32OCUzk31tb46gWms cj06Njg5OQRU8Wmz+bceRPbXPT/l86fl29PQ16BNoPj+aLmDj/uDfl0+v4fpy/nTzXWoWN9jFr/x +cnPoOP88c/X6/6titPrSaWj31ei6q29t7X/AF/lx15KTwbi009e6StZN2TWtlfq/Oxj/bJ4Ps8F 9/pNvn6f59x/+utDyfJ/cdh/pvrjHb3zkenr71XvIT/xJ88/av7L465578f5H150Lz/j7/1/2n7L /oX/AIIvyP09KRv38t/L1K9WYf8AUj6H+VVq6DTdNn1K6t4IIbm4uLodj/TP60sU0r6pb21S/mtb 8PwOrCYPHY92wEZTe/LGLm91ba7trb1fmftx/wAF6/Df/CNf8FU/20LcW9za/wBvfFT/AISYY4AH jrwXoGu/20B9Nc4/+sK/Hiz8kyjH2rPH4f5/P0r+g/8A4OavCs+j/wDBUD4kar/y7+KPhv8ABvxP 6f8AMl/2D9T/AMiN05/nX8+Gnf8AH0M+v9a+ZwF3kdS27hO1+7idGV3WcU9NeaO+nY/1f/2Y5ftn 7Mf7OE3e6/Zv+A97ge/wx0D1/l2+ldRN/wAvP/AK8O/YK8a6H8Uv2Gf2SPGHg/VbXWtIuf2e/hf4 aN3Z8BfE/gbwXoPgXxzo/IU/8JD4V8R6HrnhjPOToJyTjNfQN5Z3H+kfuOnT8v0+hzxxX/Oj4l5Z jMHx9xYsZFxceK+I018Li3Pa261Xld6Lax/buRYlPL4JNawilrt7qtbruu/To7W/jn/4LYQmH9sj xxP/AM/Xwr+Dn5/2Lz29v/1ZxX4/3mbOW4/5dvbtj/8AV2/HFfsh/wAFt4f+Mw/GH/Pv/wAKT+De ceo7f459j3r8brybzpcdv8n+Y7ds9+a/29+jPf8A4hLwlrd/6sw/9JirfLY/kXjTXi/NfR/kjsfE nxg+Jvjbw34f8KeOPH/i3xb4X8G3n23w3pPiHxJrOpaZoOqH/oB+vPP6jtVj4Y/Gb4qfB/Xv+Eq+ Ffj/AMWeANY+x/Yv7W8J6xrPhv8AHj1x7V5dN5/m/uOufbp/PH04qCaaeGL/AJ9ja9umP8989fwr +h47L0X5HyR9MfCX4b+I/wBq74v+ILHxV4+udE8U69Z+PPiDrHizxDZf2l9v1T/kPa7/AG5jxJ4R /wCRs/4nnij64xX2R4w/4Jg+FfDl/wCH/Dmh/tYeCfFvijxReePL3R7Tw94D/tLTNQ8L+BfBegeP Ne1r/ktnH/I8aFXi/wC0V8ZvFXwx8Z3Hwd8DQeEtE8D6D8K/gPotlaWngPwbx/wnX7Mfwi8ea7rf /It/8JP/AMJF4s8R+OPHH/FU/wDYsd6+gP2Rfjx8K/FUtv8ADkfsoaL8SNQ8B/B/4X/Y/sl58NPD f/CWf8Ko8F6//wALX8aeONc+MHiTwj/YH/Fx9c0PxR/xSZ/4rT+wPDHgb/oc6MNh8Lffqvla333t v/SPTR9H2Og/4dRz6baXE+h/tQW11b3V54osrO7tPg+P+YF8F/APxa/trXf+MkP+Kf8A+R4/4RfP /UA8T+Of+pLr5Hs/2P8Ax/eeI/A/hy4+OHw3trjx5o/jy9s7s2fxk/0D/hBfBf8Ab39i65/wkPwT 8I+GP+KsGh654X/4pPxh4x/5AFfeGm/B/wAYzaN+0xY337FviT7R8ZPEnx48T/BP/io/gDpupeA9 L13wXoH9haLrmh/8LsH/ABTvhPw4P+Rp8J/8Jj/yP3P/AEJdeL+MPgz+zZqXhz4geAPhl+yt+1Fo n7RPhfw3pdld3d3eaNqXhrQfFHjr4Y+Ade8C/wBuf8XtP/QD+Knijr01/wD5nL/kS65fquFxWLvr ZbvVfO77/r8jrw2Y5thU4rM3yvor2t7un3P1XToef6l/wSX+NOmfGT4T/CSf4jfC7+0PjJefHiz8 N+LPtms/8IzoOqfAvRf7exrn/Mzf8VZx4o8D9ONfryf45f8ABOX4xfAf4c/ED4m+MfEfgC50fwH4 O+F3jS7s9J/4TLUtT17S/iv8Ttf+Ep0XQ8eGz/xUXhPxHoX/AAlHjf8A4rDwd/xRev8AhnFfoB4k +LX7Dxi0fxjffsoftM+Ev7B0f4N3viTVf+ED0b/QNU8C+NPH/jzx1rX/ACWz/ioPDvxZ8Oa5/wAK v/4Sn/ijhnw/7V+M9n8eL/wr498ca5pWlaJ428H69ear/Y/hL4sWf/CSeGbDS/7a0DXtC/4kf/CS A/8ACRY/EV6Sw+CS3/PX8DzsRJt3bbd73v5t6fPU+f5v+m/45/XGPr/L2qv50EP/AD7dAPr+o/Ht +OK++Pip8a/hXoPw0/Z38Y6V+zL+zx/wkHxQ8B+PPE/jy7/4RvxlqWmf2p4E+NHj74SaF/Yeh/8A CSHwx4f/AOKc0P64718z6P8AH6xh+KHgDxxofwd+DmiXHhe81Sys/D2k6P4y/wCEG8W6prui/wBg /wDFcf8AFSf5xjmuX6qu6/H/ADNottR1d7L77I6D9m/wr8OfEnjfWJ/ip4q1vwT4P0H4b+PPFFnq 2k/8S3U7/wAUaF/YA0LRf+Kg8N+Lj/yMeu/09K/SeH9i39mX7BqA/wCGqLbUtY0v/hKP+JTaeMPg 3pn2/wD4ov8At7Qjof8Awj3hvxd/3O/b+de0/A3WPjv4V8UeMPhXofwW/Zv8W+IP7H1T4g6z9r8Y fEvTfDNhpfxX+J3wi8B6Fouh6H8QPgn/AMJOf+RH/wCEoz/yJf8AwhZ8T+OSP+E8/wCEM8F+MrHx nh8Y+D/DniHVfGP7Hf7Kmmah8WtH8UfAq88Q+HviprP/AAk3/GSPjTQNB/sT/kifhH/i4n/M0eCP FOP+KL8F+Avid46xx/whYw9hhLrq+ml/1OpZnjMIlZu2l9dNPuV+v9Wf47/tafDHwd8Mfi/ceFfA /ji58f8Ah/8A4RvwvrX/AAkN3/Y2pf8AE013RP7d/sX+2/D3/FMfTv8AhXytN/rj9R/Ov6Uf+L/f CXwl/wAK41z9kn4S6lrFr4E8eeDNH8b+N/ip4N1LTLDVPhR+zH/b2u+NP+SJ/wDFQf8AFOaHrnij nxh/zIPifwN4C/4rz/itPGX4v+PP2lvg78QvF3jnxl4j/ZJ8AXVx4o1jVNa0a0tPiR8S/Df9g6X/ AGJ/xItF/wCLf+JPCPhjp/1J+en1rpSSVkrI52niv9rle72T0u3bb7r29D43mm/e/wCQf8/oelHm w+v6n/Gvp/xtpvwd8YfAe4+Lfgf4cXPwu8UeF/jZ4X+H2s6TZ+MPGXjbwz4t8L678MfH3jz+2v8A ioPEefD/AIi8J/8ACD//AF6+QJvP/D0+2df8+vfHFOz7P+v+HX3gsPN7cz9L+X930/Avzf64/Ufz r2n4GmfTYvGHiP7PbH+y9H+xf6X/AJ5H15HNfP8A5/t+n/16+iPhvZ+b4NuD5/8AyFPEml2X2Q2Z /n3H/Ej9T9PWMS+VJ9le3oxLdeq/M/fD/gj/AOCYLPwb8YPiNOcX+veJNL8F2f8A2C9D0X+3tdPt /wAVFrgGMn8zgfpj+0p42m+G/wCzX+0N4/sr6507V9B+Cnjv+yLqz4+weJ9d0X+wdD56/wDIx65o mPT3xXwd/wAEkpftn7N3iDE4/wCS2eJ/TPP/AAj+f59TX0T+338Pfi38Tv2X/GPgD4O+FfEnjbxR 4o8R+BP7Y0nwRZ/2l4mHhfQtZOva505/5GTQ9C5+hPGa/wAcfEHm4p+lfRjnH/IpjxTSVpptWhOC Smn9jTVWtbTyP7D4d/4SvDl4vS7g720eqXbfR6devr/Lfr/xat9esLe48R+OLjW/EFrZ/Yry78Q3 ms6lqf68/r7ZrjtS+EvhTx54S1DXINcuNEuNLs/tv2vSbvn/AD7np+NV/Engnw5Nf3E/kXNt9q/4 /Psl31/z6Y+ua6DxJ4Esfhv8JfGHjjSr65+0ap4b1Sy+yfX0/L+n0/18wWGwmEp0sJg7tKMPRLli rbdfRee1z+R8XivreOlpbmk/vv118lv5bH5X6nN52oX8/wBouLn/AEz/AI+7v/l+5/nxx16j1r9P P2E/hjPLouveNp4CLnXboeGdJHb+zWJbXSPohRfqpPc1+Xtsu97VPJxuIGfTJ2nv6n+R9q/pY/Yv +E8KeHvhBorE25trTS728tWJJ/tPXMa6Ack9BrYAx0AA6V8x4mZlPCZMsEtHVkoOz3inBy03S5nH 8+p/YH0JuAlxV4myzrGpSjkEHUd7vVJNPZqzSlvtp1PKv+CnXxGg+GPwn+Gf7PGiTm21fxLZp4y8 dfY2AP2By2haBoxH90JHI3GPmVASQ3P45eNdYnm8B29jP9m/4/D7f5/z7Eey/t2fFT/hcv7WPxQ8 UQTtc6M3i/UtI8OhiMHw1oW7QdAK8ZI8rR1PPIJPBGMfLXjC8/dQWPn/AOj2vPf9fTt6D+VfQcE5 LHLMmg1q5R5novtJWt5ctndd+h+d/Sg8Rcbx54t5xiXP/hEyOb4ZhZt8qg1C6V7XTUmpJbNb7Lzm eFcnk4wNueucfj0OefqK93+DPwlvfHms2881vcHQNMvM3t5g4veeg5wc4xznHTnrXE/D7wTqvjzx HY6JpkJzdEfbLrOfsWnAgMcjpgHJ5zk4GBzX67eEPh9ZeEfDthouiwm3gtjpbXt4Tklicn688/8A 1q8zjTiX+yMF9TwjTzacWt78sWlFt2vaTXMve1+0l8LPe+jT4Fz8SM7jnWdRdPhHIpxklKLiuIZR cXaDas1FrW2t9O5naxZwfDf4S6xPY/6N9ps/sVnaHP8AL+XrXg+vax/whPwq8QT+f9muLXwdpei2 f/YU105z685r2j9pbWIIbXwP4OseftWsC9vP8/4Hn8q+V/i1qf8Awktrb+FdD/4mVxdax9tvbS0/ DQfoR0FedwHhpSwrxsruTd5N631T1eurfS/zPp/pj5zgocU5NwxkqUYZBCMIRjZKMUlokrJLS1lZ fcfH+j6DPqctvP5H+j+v+ec8du/HfFekDWNK8H2v+gQf6T/09/5z7Yqxrv2Dwfa/2VB/xMvEHe0t Mf2bYcddc5HT6jnmuX0f4e+MvGF1b3A0PU7np9rPPoOn+R+VfpF7dbPo+3nr8j+NUni2lZtOS0tu 9LXVm3933t6918PvCvir4pa8Dem5/skdOeAccDB7/pzX3B4j0DQ/hb4J/tWeC2uL+6/0Lw54VwTq euamSq7mx08OZP1JwOScHz3wHoXiqztbfwrpU9tolxdf8wnwnZ/2l4l68f25rnH/AAj/AL1+jHwH /Y5+2X9vrnivSvtOsXR/5e7z+0tTP+f0/SvybivPFhcb9bzLMopK1qcW2m001FtO+v2nprso9P8A Qr6P3hVic+4ehlfC2TcSr+3LPiXiqrBLh3htaP3XNXdulnZX23PkP9mf9jzW/HuqL4++IlsFnuLk Xdpa3IILnO4s2eSTn1wBwPWvr/49/EX4WfsnaFbi8sbXW/HN1Z58N+FLU4/4lfbWdbHXQSeyqGds HAOK9n/ag/aU+Gf7IPhK40PS/wCzvEfxeubQf2T4Vs+dM0DOT/bWuDI5O07VyM4PQAkfzO/EL4ke Kvif4n1jxV4x1W41LWNUvPt159rvOvHXOT/9bHqTXn8OZNm/FOMjm+b3VJP3IXklGPMmoxTbaSvf Xfq7u7/SvGHxJ8NPo4cHy4B4DjRz7xHz2LjxTxQowmveVpa2abs+91dN6M6Hxt8ZvGPjbxlqHji+ vre21C7vM/8AEpzpumWOf6Y79O9en/Df45edLbwa7P8A2ZqA/wBBs9WtOv8Anv696+T/AN//AMtu v9f856/h3qxNN/x7/wA8f/X/AD4+lfuSwuFUUm9Ukrt9lb+tT/KrF4t43GyxrV3KUpSS2vKV9tlr rr6bH2x8WvAeleKv7P13SoLbRPEA/tT/AI9P+QZr38v5f/W+R9S02+0fVNY0q+g+y3H/AD53effX vx/l+Ga9K8CePJrTTxoetzG5sBq5/sm7JBFg2u6OQCAOi7dDUc5O7POMY+hviF4DHjbRtP1yxt/+ KgtbPSr2z+yc/wBvaX0/Hjv3rmoaLfpvt/L6bP7mvI5flfy7nyj4J1c6f4Z16YfZvtOmkAHBycnA 6ds8d8/Wv0e+DXgmDwr4c0/VYNV1LUtX17R/tn9rfa9Y/syw5z/xJND/AKn0r88/h34b8Yalpmr/ ANj+Ddb8RaddXS2d59jt/sOm8jPLAAbs9RgFeBgY493+G/xG8Y/Cd7Hw74+8L+LLbwTcAG0udW0c /wBqaGMgfLuxnw/k5KjkgFhjGK8Xjmtis2yzLMHgs1hGcEm4OUY1GoyTlFJu8pWTbjq30Tdkerwn muc8KcRLOMvqTyZ30nGU0p6Kz2Vru+6vbtuftP8A8E/v2p9D13VPG1j8QDanxhod3pfhkf2q2cf2 ESBrOiY5B4PB5xg4wefrb48eNvA/xI8Zafof/Et8SaP4X0f/AInH9q/9BPXTxovbt9frxk/zpaR4 +1DwLc/FXxtonhfXNT8PeJLo6x4Y1UnR9O0tFOkPof8AbOtaF/wkfALuz4HG52PWvpD9n6Lxd4Em Gt/FHUz41muLw6zeeH7y8P8AZ1ngnDNre5l14kEDapwuOrHLV+L5jwo8q4gfGNOprCNK1O8pSnLk i58vKmlySTbcnHRpRfNof3t4cfSthPKY8MeJOUQlBtr/AFmlFSjy3VuZPWzVtt9Wz6l8efsW/Bb4 hS3F94H1z/hCdY72lp/xMtM/+v0wf8RX506l/wAE7Pj5ey+JpvBFhovjW3F2dx0nWBp2pn5iRhfE Gw9ODlmJPRgMAfqP48/ab+BN5oukQ+G77TfCXxPtb37D/wAI/aDRsf2Zg/26NcOMZ4PHXAzg9a7f 4G+MP+JNqF/Y332k3V59t+2Wn+fw49+cc19FiPEPiSvlcMW6clFONlKEleN1Z6paNLdPz7n7jw94 AfR18Xs0eNwecU41M5jKVuG5RTjLl5tVfe+rVt9lsfgjqX7Ivx90LxRpPh2/+GfiP7f9s0yyu7T7 F/aO7JwAAuVB5z2A7ciug0n9iD9pjV5f9H+EviyA/wDTzZtpvv3Cnj6Y7+lfu9o/ja+vPi/cTzz3 P+i3n/pi0X9O46/jivpD/hbVjZjyL7VbnntaWf8A+r+prycR4o5sklyq6S2unfR9ba6WVuiW739H hv8AZ/eGGazzTF4nNeJZQjK0VpytRla219bW+e1j8O/hx/wSk+NniO7trjxre6P4MsOpMl2NQ1I9 cr5aMxGPXfz02jgV+rv7Pn7Bfwl+E8tvPpeh3Pj/AMX2vP2q7GFBOOQFwBnrwOnJrsNc/aU0LQo7 gaJ8LfGvjzV+P9FvbzR/DeljHrrmvKx/LwceuD7fNfxA+M/7ZnxYs/7D8Or4e+B3hK722X2PwoRf eIr0g8q2trueUOOCVaApjgtkY+czHiTN8/SWKzf+xFpZpq70Sva9tvK3Zd/3Dh7wR8JvBiKXCfh/ LiLObRu5w5027Ju87QXd2a7JXaR7n/wdTaDfWf7eHw/1zyLn7Pr37N3gP/yheNPH34frX8v+mw/6 fb5/Dj/6/uP/ANYr+wD/AIOyvDcEPxu/ZX8VQfZv+Jp8H/Hnhj/wReNNB17+euf/AKjX8g2mZ+3w Z/4+Mc/X/P8AnNfuOAf/AAhztuov5aI/wdj/AMjenfa8U+n2o7/K/wCJ/p8/8E0Phxofws/YC/Y/ 8OeD822n3fwI8B+Nbv7Wf7RF/wCKPito3/Ce+OR2xjxHrmtgDoBgYAr64m8+G/uJ/P8AtNvdf8ug 5J/l/wDWr54/4J6zfbP2B/2MZx2/ZZ+BH6fDPw//AE7+pxzX0Ref60fU/wAjX/Pd4w5ji4+IPiHH G624uqpvq37R3e+8uut/N2P7LyPD4V4HK9dXCL89Yx0bvqvu/wA/49v+C3kWf2vfEA/5+fgR8MPw J/t/qPbA/GvxwvP9aPqf5Gv3f/4LbfD3W/8AhpHT/Ef9lXNzp/ij4DeBLLw3d5/4ll/qmha1r/8A bui9e/Oe/fg1+H+pf8957HXLb/p0/sfOp/j0wOfbpX+zv0X8bgsX4T8KLC1IOUeGIRa51dWjFJNX bTVl5rbVo/lrxAwssLxFmjSdnK6aT7q9un+Xexx8MP73/l2z6+/+fQ896838U/E7wd4buv7Jvr65 1LWP+gV4esz1/Wu48eaxfeGvBHijxHbwXNsbWzH2M3Z/5inf8P61+b/hTzxr1xP55+0XX/L3dg/z Ga/pODTirO+i217dj4fD/F8//kT9KPFXxmvvi14oGueI57nTfFF14a8CeGANWs9G037fpngX4Y6B 4D0LP/CP+vhzwPof/gg5H/FXVs+CfHnjj4b6zqGq+FdWudE1C68N6p4Y1i6tM/6f4Y13nXdF/wCx dFfkvNFqv9qeR5Fzc3Hpn/Pr3/lX3x8Pddv9d0q/0Qj7TrHg46ZeXd59r4v9M1zGdEHrgaJrRI9x nqKffy38vXselbCX2V/lc+55v22P2moNGuLH/hcXiS5+1axql7eWl2f+Jn/xPfBegaDruf8AsbfD n9h/8Ut0/wCJB2rzfwr+0V8YvB/jfWPiN4b8VXNt4w17+y73WPEP2M/6f/YWP7C/tzp/n68eP/67 7R+4ubb1tBZjGfr07/rR537vyPI/hz/x5n+XXH+fauP61G/2b37tO/8ASRyW8v60/wCB+B9UeMP2 6v2qPFWg+IND1z4qalrmn+KPB3/CF6xaXlno3+n+F++i8/8A1uD9K/P/AFKX919n/wBJ+0f8udpa WY6c9s/56+1dvrHn/wCogg+05vPsWM+vTtVCbQYNNtTP5/8AxMP+fv7H/nP5/rXZuc+2j37HH+PP G2ua94S+F/gfXLE6Jb/C/wAN+KLLR7u0/wCJlqd+fHXxO1/x5ro1w+/9ufnXl/nXGm3X7/7Nc291 /wAed2P+X/2/Lnvz24r1jUtB1XUrW4uPt1tc/wDTp/nn15z19K8vvLz/AJcfsP2bH/H53+3+3/1v /wBdAHrHgnx74x8Kn7d4c1zW/DeoXVnpdlef8I9rOs6b/wASv+2v7e0L/wAuPQ/85ruNS+JHxG17 7PNrnjjxJqX2W80u+s/7W8SazqX/ABNNC/t7+wtaGP8AmY/CZ1zXPx1/xOOa8X0GzuIIv3//AB8f 54/+v9cDNdhDn/UY/wA9u3b0x9fSldd194LX9etj2Gb9or47/wDRW/iR9ou/+Pz/AIrHWf8AqP8A f6656fX28Oh0HVdSl8jSoPtP/Pl/oX4Y98e/681saPo99r2vad4c0qD7TqF3efYvp9T+f4Zr9ePh V+z3Y+FdBtz9htvtN0P9Mu7v/l//AFx+Z9/p8RxZxb/q/az1lsn0vt/Vml+f9S/Rw+jhm3jpmyxb zJxyXJmlKysmtE10TfZ62vsfl/8A2P8AFSz+Evij4Y/8IPrf9j698SPC/wATf+Eh+xnFh/wg3gvx 9oP9if8Al8df0xXyvqUOq6bL5F9Bc23p19f15Pr6V/RRqXwy/wBE8iC+0256c/8AIN64/wA+3QV8 D/tCfB+w1KwuIP7KNtrGl/6b9rz/AMf/AKdz1GfpXyWSeJ+KxWLWExlrXVnptprfpdPvr6H9PeLP 0CsJwtw3mudcJZpxJJ5JHmkr35na7WmrW99HpbQ/OfTpfOi/Hqfc45/z/wDW+qPhjps/9l+B77v/ AGxqmP8AP+c/UV8r6bD9kiBnntv9F9Pr/nv9eK++PhjZmb4S+B/Eeba2t9L8eapot51/6AvpnPce v8q/WPrN4rF94tLS+6X/AAOh/mliMJKNT6k73hO0rpXupJe92bt1/Q/cD/gjPDY6l+z7rE+q/wDI PHxg8UY+yf8AYF0D6n/OBzXD/wDBWj4teOPB/wDwpDwd4c8R634JOqax4o8T6xd6TrH/AAjeNM0L +wNB0L/ieeH+3544r1D/AII26P8AY/2S7i+H/L38VfFPbgf8SXQNB/z2PrivjD/gsD4J8Y+Kf2gv D0/iPStb03wBpfwr0zRPDniHppd/qn/E/wBe1z8evpgD8v8AMjhLLcJxB9L7ip4xRl/Yj5knZq7a StG26bTVtVa/S5/Rec4nF4Tw5gle0opLfay2a/FK6t6n5PTTQaxqn2Cxvra2t7k/6Hd2n/UC9P8A A/hXkH7U3ww8VfD3QtO1y/8AiPcalbeKL4Z8KGyOmjGec6GP+KZwM87cnrjnFdP4V+D8+seI7ex0 rxHc232X/jz+12fHrj/in+nr9PTtx/7b0+q6DL8N/hzquq3Ot6h4X8N/6Zd/9RT9P19enav9QMJZ LS2iVvv0/Cx/L+t/Nu/39v0PiPQ4/tWo6dH/AM/F5nGeuOB+uDz096/rk+DPkaDFcX0H/ML8H+KL 2yzz/wAgLRf09/51/IXpJnt7y0ue1q659wcHnn2z9Tmv6rf2ZPGul+NLvwwLi9uhYeMfAhsGBs/+ JaDruikEHjIIPHUd6/LPFZyeJybFf8u4z1vtd+z5uZ6fEktPI/0i/Z+5hg/Z+IWC0WdSoSUW7J2c XZLzjd7Pquh/MxfNPe+N9Wvp+NurapdnnvksSPYk4/8Ar9M/W7ObWLy3trOI3E13eYtcc8ZHTOOR jj1Neo/FH4fa34E+JXjzwreWFx/aOl+IdUsXtAMfMHcDnuSu056c+oOLvhDwtrtlr1vrkEFv9otb PNn9r/5cDjj8Rzz15P1r9JwmK/4R4PCON+SC9HyRSTW/q1206H8R8UZJLCcfZ1huJYzSlxXUk7pp yj7RuTu1qnG9nqra2Z9c/BT4caV8LPDFvfXxt7fX9Tz9r+2cGwGcjOM4Pfrz69KsQ/Hjw5N4tv7G CfUv+EX0H/jz+yWf9pDXdUzjXdaPTnv34I79PFtS/wCJxc+f4q8R6lrdxx/on2zpz1/yOnevQPCv g/xVrEvkeDvA+pXJ/wCfv7H/AGac/wCe55/Cvg8VlGUOUsZxHmsW2720une+mvay7Wb66n9XZT4s 8eYrBZTw14P8IyWUZKlGU402uaTSTu1HVXbfnpu9+X+IUPiv4t+I7bXLGC503T7Uiys/7W6/TOcf Xjt+ex4J+Cf9jfab6+8R6ni6/wCP27tP+Jb/AOV3/PuK+qPCv7K/xb17E+uarpvhK34/0S0s/wC0 tT+p+vtX0h4V/Y58AQy28/iO+1vxbcD/AI/P7WvP+JZ2x/n8cccH+u3DuQYP6pglfT3dN9tu/wAn r16no5f9D7xv8YOIlxLxl/whKTTu072bT+F2crXWnXr1Pzv03wR4As7ryPCvhw+LfEH/AD6aV/xU noP+J7rn/IsY9cdBX0x4D/ZQ+KnxClt5/GN9beCfD4/5l7Sf+QmePyPt2/Gv0P0zQfhX8MNAuNWn /sTRNH0v/j8u7Sy4sO/p+P8ALNfDnxg/4KpeAvByXGj/AAX8KzeI9WtWC2niHVreP7AMEc+Tv83A 9dmM456V85/rXxZxS0spytxi3yqT0XLom7uytbz0ve5+5Yf6N30d/o+4RZz4p8UwzvO42apymruS s+X+wHZ36J2s733aR92eA/gD8MvgnoP/AAkeuf2b4R0e1s/tt54h8Q3n+e/b+lfBf7UP/BUfQvDV nqHw8/ZuiHnfZPsOsfEu6tU8xsdRoY5KDtvdcZI2B8ED8jvjX+1T8Yfjvqdxe+PvGGo3Vi15/wAg u2vCNN045ONmib8cYHLDIOcHtXzbNOQTzknueevX8+f1Oa+tyXw6wsmsbnT5paNpu9n7t9PXZLR7 an4l4wfTgxFbAvgzwdypZBkbThKcIqLnBJRbtG1uZWvdtxvZJaNdV4t8Y634w1m/1TxFq2o6nq+p XYvLu81S7OoFjkks2TnOT9MAcdc8p5Hv+v8A9aq8/b8P61Yr9PjhcHGKjgtEkrLRbJb7W2Wtuh/n vmmaY/OcdLH5hOU5Sk5SlKTbcpO8nq3e8m9vPbUKP3Pm/wD68/5/9mqv/wAtf8/3qPI9/wBf/rUz kNAfvrW4ggg4+2fbby75/wBA/A/Xr0/Hr9wfAfxsfEnhzT/Dk8/2bxR4XtPtujdf7Tv9L/PH5dj2 zXxPpsPnWviD9/xa6Ppf/p60DH+e2ehrqPAfiq+8H694X8RwT/Zha3n56Wf+Q7z+X5VzV1dW2urX 7Xur/ID9Ef8AhZvgjwJ4c0exn0rxILi1Jsry08P6R/aIGqDnknA+g7kAda4CH4y+PfipJqHg/wAA eCLbTdHz/wATjxB4r/4mRsB1ySRgc+mT6gCum8K/DGf4wap4g8HaVff2bp+qaP8A8JoNW/5if9l6 FnOi6Hz/AJ7muw8R6l4c+DXw61C+0OxttNt9LsxZaPpQ/wCX/VNd746/Xg8D2r8zzehkOV41YPB3 zzOZySSk5JRcnGztdK0b3968eslbQ9LDPFvCrmevN1te3X9PPseEQw+N7zwd438LaFY6J4k0fwF/ anhnWPENpd6zp2p67pY/5Dn9h6Hn8+PwPNbOj/B+x+IPh3T9c8O/GHx9c6PdWeLOzvLw/wBpWB5/ 4kvBA9TgHH4YA6f9mS0nPw61C+nAubi68San9s/6f/X655+vU9RXi8+v+JPgb8VfF9j4ct/7b8P3 P/E5u/D/AE/tDS9d/wCY1ohA569c+3cV3UJ4nF4nNMoyhxWbwSnFNOUJNKPM1GSaTlZO1lGy5bKy S6MRiHaP1y7i7LfRWWl+nX/h7lfxv8B9c+H3hjWfEmk+ItM8R6fa2h/teyu9HOm6kulknGsgsxOB 2yW9yTk1xHw7+P3xL+Hllp8HhjxDqkAH/LncsL/Tr8+5ZH6emM59Oc/VPiT43/DXxH8NvF80HiGC 21G68H6ro48P6pZf2fqbanrmjlTpCFSQ6hlYblJUlSBzX566d10CDyPtP+mnFp75NepktLFZlgvq nEdNKanazhFJpJNppa6NNtJWSa2djtyPijOeFs0WbcM5zPI80tZck5NLXlurNLTTbXW17H314A/b t8SeH/EWr6t4k8ODW7drrVD9rtLzkf27rCt2z1JwM46dOtfV2gf8FH/hzNF/xNdE8R6bce9qNR9e OcDt/kivxI09g1jcYAUZ00G1wcnJyM/oBxnGeO1Tef7fp/8AXrlzHgHhzF2bg4vS6g5W0tZpSc9Z b7+mmh/RnBn0zfG7gpfVcJxR/bae8amRKXa6crQunrrZdD94/wDh4X8FxDmE6zc3H/PoPD0Z65HI 3fr+lcB4h/4KX+FIk2+F/DPiC9Ayd19/ZOnrxjvDHKT+APsa/GSznghuf3/2j/jzIH2QYOcdyAP8 k1XglaM8f5/+v1rlw3hjw7o3r5Sk9vw0Xr0Xd3+tzL6fvjhjcJp/q1k0v5o01zt3V3Z86T7pq+uy sf3j/wDB2h4b87wZ+yP4xggx9lvPihot5d/+CDXufT6+1fxH6bDP9qtv/rf04/zzzjH9/H/B1B4P n1j9kb9n/wAVQY+z+F/jZqlleY/6jvgv9K/z/wCHz4br8Ppn9f8APSu7J+Z5Pm0bvVO3raNvTc/j 2t/v8f8AFH842P8AUT/4Jo3f2v8A4J4/sRTen7LXweHX/qTNB/LJ4/TGa+pZoT5tx+nf8unb/PIr 8/v+CMvjyx+JH/BM/wDZRv7Ke2uLnwd4Q8TfDPV7QHmx1TwN4017QgG/3vDn9h+JsZP/ACMGM88f oTeZhuriAfT68f564P6iv8AfHPL/AKt4m+IcsVFxVXi2rOEHe6i5txTva6Vknp07bf2PwxJPKMrT fNywhrv5bfL0dzwb41fs+/Cv9oXwv/wh3xT8K2/iPR/tZvrPtqWn6p31nRDzg4PzD8fp+eOsf8EZ /wBknUpbjM/xItscnHjD9f8AkW/89/f9f5+34f1qvXz+ReJfHnCihguGuK6mS047U+aXK07XildJ X0Vv+GOzMci4ezbF/wC2ZYm7fFy97a39dbN+Z/EP/wAFPv2FZ/2dfEdx4A8K/adS8H+KPDf/AAk/ gPxDq9n/AMf/AF/t3Rdc6DP1/TOK/mn1jQb7R7+4gnguba4tf+PwduO3Q/qa/wBUD9pb9mn4c/tO fD648EeOIMf6Z9t8NeIuf7T0HVP+oH/L37iv5P8A9q7/AII2fHfw3r2oTwfDn/hbXh+1H+ieLPBA /wCJn1/5jeh9/wAvxzxX+oH0aPpYcPZrlEeHePs3WTZyrJ1Juyk9LyvJrWV07Xvr1SZ/PfHvhvi8 JjFi8mTte9vu87JJLXztofy7/wBsapDJmCC2+0f8/eP6k8g+g59T2r7p/ZX+FfjLXrm30rSoLm58 YfFrxJ4X0XR7TP8AxM+daH1wT/bn+FfdHw1/4JUfH7X9dt7Hw7+zp4/udQ5/0rxDZnTtNsen/QwD GcZ7j0xX9KH/AAT9/wCCXmlfsyapbfFv4tX2m+LPi/aEf8I3pOk/8TPw14DPqfTxEe3+Oa/YfFr6 THh5wbkWaPI84hnWcyg1TcJxk72sm1GTcWpO7va6V0n0+b4b4IzfM83X12LSTindWTXu3WyTXR9t Neh87aP/AMEJfAH9jaf/AMJH8cPG3/CQfY9L/tgaTo+jDTP7U/5jv9h/Tr9Kx9S/4Ib/AAxhiuPI +O/j/wCn/CN6N/j0Pv1r+gi87/8AAa8/1ib0/wA/TP4DH4etf5Xy+lD4xvMG1xS1CU3JK7douSaX 3dE+5/Ry8OOE3g7f2Xedkr6WvZWbb81fz89j+JD9sz9lf/hmP43f8K5sfFV14tt/+EP0vWbLVruz /s0/2XrvX9Mf0r421iznhlP7/wB/sn4k5P8A+uv6If8Agrd8H77/AITz4ffHeCx+0+H9T8N6r8JP El3aD/kA6qf7e17wNrWt4/6Gz/ieeF+ePf1/AfXtNnhuv3/+jXH/AE9k/hnPv/niv9fvAPjbFcae HmU5vjM1/tvOXGPOm43UrJSTS2akpcqerVm9z+XuNck/sniH6olaN3ayaVtHZbp2T6eep49509nL cWPS3us/jkf55+vU1z+peCbie6n1vzh9gtbMXt50z6D15/D8q7CaH/SvP/0X7P8AXjrz/n9a+0P2 XfgpD8Zr/UDrk/8AxR+g6xpd7rFnaY/04/8AQF65HPfr0wQea/SeNOLcJwpwnmmcYy8XBq+qXJay e7drPve77625+G8l/t/GLCYRNpNN3u7rS9118/meo/s3/wDBMG++L/w18MeONc+Ldr4J1DXbQ3tn 4e/4Rs6lqVjjP0wMc/zJ619P/wDDmGcRef8A8NGW3/T5/wAUf3/Qcf57V9Q2fjzxj4P17UNK0Pw5 c3Ph/wAL+G/tvhrSdJ8N/wBo/b/7D0Xp/bn/ADL/AOHH0yK6CL9or4jWmjXGq+ONKtdE/wCKP0s2 fh/7HjU7/wAef2zr+g67ouh654f4Hh3/AIkZ8UdT/wAUZr/Ge/8AnLnXit45ZznOZ5rkfE/DqyVy Xs4JXkozaUUtLystO3MtbN6/1Xwx4ScO5xi8pyTCZW5ZvnXLGbtzW+FSbtfl0u9dlp5n5waR+wfL 8B/jR4fm1X4i6L4+sLXw3qfia8tLTSNZ07UrAY9gMc578elfY00P2Ob7P9On496z9B+3alqusa5r l9c3Wsa9Zaoby7vD/wDr49M12GsWVv5txPB0uuufw59PY/5Nfs2W5pxFjcoyqXF+aLOs3aXwpQS2 6RSVuztfp3P9d/Arwlynwg4T/sjBpRlNJydlzcztdd9Lvrp5dfN7yafzvs/UDp9rx36/4fz4rxf4 neD/AO3tK+0QZ/tC1/48/wDPOK9o1L/W+f1/p9eenvz/ACz0Hg/wTrnxD8R2/hXQ4Bc3F1Z/8ffP 9l2H/wBbHfrnJ+izPNsHkmEePxj5XFOWrSty676a6eX3n6fxjisHhuGM4jjnaM6clq1ZpwS13Xfv bztp+U/7Ov8AwTx+Jv7RV34o1zQ9c8N+EvC+l+JNUsrPVvENnrOo/wBod8/4Ht6cCvaPj9+yv44/ Y5+F9x4O8ReI9E8SW+veJdL8aaPq3h6zHp/YOu6L/wAVAOM/8SP8fzr+jD4S/CXQ/hN4J8P+D/Dk H2bT9Ms//A/VCfy7YP8AkV8sf8FIPhJffFv9mrxhPY2P2nxB4Es9U1rt/ad94X/5jp789fFHf+tf lPBX0ruIM28Ucqy3GNLg3nVO0uVdYwTbd7Nt9W1rof4U8d+GOUqjxXnOU6PnnJJ73vzPl6rbS23n seX/APBGLx5Y+Kv2bvG/wzItv+Eg+HXxf8UY0j/oIaV45/4nuhY79v8AI5r8cP2tviRP8Qf2oPj9 43n1S51LT7T4jeJ/Bfhwi9/4lh0vwP8A8ULoWeRjA0QeJvf+3hXT/wDBM79qjS/2af2grjU/El99 m8D67aaXo3jvVfsZ48MHWsaH40A9fCniMAHjP/CFjxN2GKz/ANsf9l6f9l7xTpHh2fxvofj+38U6 PqnjTR9V0e8I1MaX/bP/ADHASfTj0OfpX79wVwbk/C/j/wAWZ/jIuS46jCXDUpQ5rLlVSr73K4xt NRs7xlyNJ6Smj8qzrMsXmXh/leCwrtKD95Xs1ZpLm1vst3pr3sz5e8H+FvH/AIw1W3vvhz4j0Tw3 caX/AGX/AMhbRv7SP/Ei/oelfm/8bJtc/wCFg6xpXiPxVc+LNY0K8/sa81e7/r9O/T8a/aD4V6D4 j8B/C/xh8TtV8K+LdN8H6XZ/Yrzxvd+G9Z/4Rmw1TXcf2F/xPP8AhG/+EX/p/T8J/FWpT+JPFviD Vf8Aj5uNU1jVL3nnr0+ueSMdetf1ll2JwmKbWEabjo2n19ej36/ifj2KTjZO6a026qK79jn/APlr j1x/6FX7NfsGfFW9tNI0fRdUvmtbjwxq4vtIzz/xLio34xxgsWK/7OM1+bvgP4ZQfYP+Eq8VT/2b 4eHP2vj/AE/uP7EI69TyemfQ4r6A8KzaraXWn+KrEDwl4XtebP7Xxqeod89/xrw+NMLhc1yn6ra8 lqtHo1a9uvZW7W8z9++jBxrn/h/4h5VxFlWW/wBr5HL3eKJSlaEYScVd3VtEnfqvI/Vj9uT9mm++ MFhp/wC0L8HoLbU9Y16zP/CYaTaf8v8A0GfQn+fQYr4G+G/ww1WG/t/+EjvrbTfsv+g3lp9j78fl 0/yK+3/2bf28fA9ulx4O8STwCfP2MaZcErpuuNyAQwzgnB4PUdsV9U+MfBX7L3xZi+3C903w5qN1 n7YNWsx/Zh9R/bnh/A55GCep49/x/wDtDiLKcJHBWmo81tU/hfLbW9mmtrWs+p/qJX8JPAvxV4j/ ANfcqzWhm+dPlk+GJTp/6vOo7OSklZpxbs/ivpbVO3xF4f0X9m74aRiXWdT0Z9TPAXU7sszE9MBQ SeOyjt+X1N4J8V+HNeit5/CsFt/Z/wBj/wCPu0s/7N0znsefr/nmvhz42fs7fB3w3fz/APCKXtjq dwLvC/Zb9zhc8AAk4HoAMdMDNfcfg/R7Hwf8IPFF/wBP7L8H+KL3/wAoo/P3rxs6eFxns05T5nbm Uk0r+7bld5X1vdtK2lkz9f4Ey7MOFqXFs48LcJZJlGRU5OEuG1Ceqi9ZytsrJvdWueH+A/2lr74k azrFlpXhb+zdP0uy1T/ibXd5/wAf+T6E9P8APUV6xqPiqD4WeHLjx/8AtCeOLbRNPwb2z8J2f/Et
February 13, 2011 - February 24, 2011
AeroElectric-Archive.digest.vol-kd
