AeroElectric-Archive.digest.vol-kg
March 06, 2011 - Present
Date: Mar 06, 2011
rparigoris wrote: > Hi Howard > > I too have a LR3c on my Rotax 914 Europa that I chose to use a LED for low voltage warning. > > For starters, follow Bobs advise using this layout to prevent LED from glowing when there is high enough voltage: > http://www.europaowners.org/forums/gallery2.php?g2_itemId=79802 > > Ron Parigoris Ron, Thanks for the information. I took your recommendation and switched to a simple LED in my schematic. I'll be posting my entire electrical system schematic today for forum input and review. Thanks again! Howard -------- Howard Plevyak GlaStar / North Bend, Ohio hplevyak(at)mac.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332896#332896 ________________________________________________________________________________
Subject: Where to hook voltage sense wire
Date: Mar 06, 2011
I have just powered up my panel and I have two EFIS units that talk to each other (Dynon 180 and a 10A), I was putting the 10A on the EMS page and noticed that the voltage reported on it was 13.4 V and the voltage on the D180 (which is the box with the EMS) was showing 12.8 V. I have things powered with a power supply putting out 13.8 volts and the battery is out of the loop. I will have to run down why this is from Dynon but it got me to thinking Since there is a voltage drop when the power flows from the main bus to the E-Bus through the diode, I wonder where the best place for voltage sensing wire should be, since it will activate on a lower voltage from the main bus. Right now I have the Low Voltage light and sense wire on the same breaker on the main bus which gets the highest voltage, the D180 is on the E-bus so its power is going through the E-bus diode. I am not sure if this is why I see the voltage difference between the two displays, I kind of think not because the 10A when on the EMS page should just be repeating what is on the D180 EMS. But all this begs the question is there a "Best" location for a standby alternator regulator to monitor the system voltage? Main bus or E-bus? -------- Mike "Nemo" Elliott RV-8A QB (Fuselage) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332925#332925 ________________________________________________________________________________
Date: Mar 06, 2011
Subject: Re: Where to hook voltage sense wire
At 01:58 PM 3/6/2011, you wrote: > >I have just powered up my panel and I have two EFIS units that talk >to each other (Dynon 180 and a 10A), I was putting the 10A on the >EMS page and noticed that the voltage reported on it was 13.4 V and >the voltage on the D180 (which is the box with the EMS) was showing >12.8 V. I have things powered with a power supply putting out 13.8 >volts and the battery is out of the loop. I will have to run down >why this is from Dynon but it got me to thinking > >Since there is a voltage drop when the power flows from the main bus >to the E-Bus through the diode, I wonder where the best place for >voltage sensing wire should be, since it will activate on a lower >voltage from the main bus. Can you disable/work-around on the low votlage warning for the device powered from the e-bus? Normally, one low voltage warning system suffices. >Right now I have the Low Voltage light and sense wire on the same >breaker on the main bus which gets the highest voltage, the D180 is >on the E-bus so its power is going through the E-bus diode. I am >not sure if this is why I see the voltage difference between the two >displays, I kind of think not because the 10A when on the EMS page >should just be repeating what is on the D180 EMS. > >But all this begs the question is there a "Best" location for a >standby alternator regulator to monitor the system voltage? Main bus or E-bus? Which z-figure are you using? If Z-13/8, the rectifier/regulator gets it's voltage sense info from the system it's powering. That would be true also for any other auxiliary engine driven power source. Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Go ahead, make my day . . . > < show me where I'm wrong. > ================================ ________________________________________________________________________________
Subject: Need help in reviewing Z10/8 arch for dual Lightspeed
ign.
Date: Mar 06, 2011
Folks, I've made up my electrical system plan and sure would appreciate some fresh eyes and input. I'm an electrical sys neophyte....but trying hard to get smarter and not do anything dumb. Ive read the AEC and started with a Z10/8 architecture as my base. Heres my GlaStar mission profile: - Cross country IFR capable airplane that enables me to do over water flying down the Bahama island chain, and reach deep northern Canada backcountry strips and lakes for camping and fishing. I plan on doing some serious cross country flying. Some challenges I'm still scratching my head over include: 1) How best to wire the dual Lightspeed electronic ignitions to ensure they see higher than 8.5V during engine start to minimize chance of starter kickback. I'm using a Skytec 149-12LS starter (PMG) which has the high current draw at start. Should I move both Lightspeed ignitions to a Brownout Battery Bus? 2) My batteries are also located in the tailcone due to W&B needs with about a 12ft run aft of the firewall. I estimated the starter would see about 10.3V after losses. Does this sound right? 3) How best to wire my dual Grand Rapids EFIS/AHRS and the Engine Info System (EIS 4000) to enable them to be ON during engine start. I want the EIS on to monitor engine vitals (oil pressure). For the EFIS/AHRSit can take up to two minutes to align the AHRS, and I'd prefer not to burn gas, make noise, and blow stuff around while I wait for alignment. Id like everything ready, checklist complete up to the point of "ignition", then start up, and taxi away. Im considering moving the 2nd EFIS/AHRS to the Endurance bus as well, or a Brownout Battery Bus. 4) Overall does the wiring schematic make sense? What mistakes did I make? Can it be simplified? I've attached two versions of the architecture. One is printable (4 pages) to read, and the other screen viewable. Ive also attached my electrical bus load analysis. Thanks in advance for any inputs! Howard -------- Howard Plevyak GlaStar / North Bend, Ohio hplevyak(at)mac.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332972#332972 Attachments: http://forums.matronics.com//files/glastar_electrical_load_analysis_6mar2011_108.pdf http://forums.matronics.com//files/printable_glastar_schematic_v0_6mar2011_for_review_689.pdf http://forums.matronics.com//files/glastar_schematic_v0_6mar2011_for_review_172.pdf ________________________________________________________________________________
Subject: Adding a 12 pound cord to a 12V cordless drill.
Date: Mar 06, 2011
http://www.europaowners.org/forums/gallery2.php?g2_itemId=87399 Adding a 12 pound cord to a 12V cordless drill. I have been working on outfitting trailers for a solar charging station trailer project that has the trailers scattered apart by at least a few hundred feet. It is far easier to carry around a 12 pound line cord than it is to try and run a few hundred feet of extension cord or move a ton and a half trailer to were the power is. This model Dewalt cordless drill comes with NiCad batteries that are somewhere around 2000 to 2200 mAs and 12 volts. We purchased a NiMh aftermarket replacement that comes in at 3000 mAs. It's a pain running back and forth to a charger with now only two battery packs. It's true that three packs that are now retired were not new, hard use didn't do them any good. Anyway we grabbed some fairly flexable well insulated round wire and tied the hot, neutral and ground together and used one each to the posative and negative of a ~ 5,000 to 8,000 mA (realistic output under drill load pulled down to 12.1 volts (approx 50%)) lead acid battery, using the carcus of one of the dead packs to get power to the drill. FYI, this Harbor Freight jump start pack has the battery marked at 17aH, but with a 330 mA load, it nets out at only 12,000 mAs (12aH). Bottom line is it works a treat! Thus far a full day of use has not run battery down. To tweak performance just a little, thicker wire could be used. Yellow pack to the left of drill is NiCad pack. Black pack below the NiCad pack is aftermarket NiMh pack. Ron Parigoris Y11-03-06 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332974#332974 ________________________________________________________________________________
Subject: Non-passive failure, Fuse link allegator clip
Date: Mar 06, 2011
Video: http://www.europaowners.org/forums/gallery2.php?g2_itemId=87396 Double click picture to play Working on the Solar powered trailer charging station project, we discovered a situation that needed to be addressed. Each trailer services forty 17aH lead acid batteries. Each battery pack has a low voltage cutoff that cuts power to the load when the battery reaches 12.1 volts. The problem we discovered is since the charger charges through the low voltage cutoff, if the battery were to sit and fall below 12.1 volts you would not be able to charge the battery. We needed a stupid, simple, cheap, water and dirt resistant of bypassing the low voltage cutoff to charge a battery that gets below 12.1 volts. The answer we selected is cheap 12 " long alligator clip from Hosfelt electronics (think 27 gage wire) soldered to a leftover piece of ~ 18 gage wire that already has a ring terminal on it. Resolution is the alligator clip is located in a easy enough to access location where it can be clipped to a PIDG terminal to bypass low voltage. Since it is connected direct to the hot side of the battery its a good idea to give it some protection. Hence fuse link alligator clip. Many hundreds needed on first run. Funny thing, after we tested the Fuse link alligator clip and burned it out, it somehow ended up on the bench. I needed a short alligator clip a few days later and picked it up figuring it was the good half of the one I cut in half for the test. Ha ha ha, strip, strip, strip, no copper to be found anywhere! Ron Parigoris Y11-03-06 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332982#332982 ________________________________________________________________________________
Date: Mar 06, 2011
Subject: Re: Need help in reviewing Z10/8 arch for dual Lightspeed
ign. >Some challenges I'm still scratching my head over include: > >1) How best to wire the dual Lightspeed >electronic ignitions to ensure they see higher >than 8.5V during engine start to minimize chance of starter kickback. Turn the ignition switches on after you hit the starter button. The 'brownout' lasts but 100 milliseconds or so. Is the 8.5v number from Lightspeed? I believe the ignition systems run at well under 8.5 volts. ??? Don't understand Ign #1 sparking cylinders 1&2 and #2 ignition sparking 3&4 ?????? >I'm using a Skytec 149-12LS starter (PMG) which >has the high current draw at start. Should I >move both Lightspeed ignitions to a Brownout Battery Bus? No. I'd put one on a battery bus, the other on the e-bus. If you were sparking all 4 cylinders with EACH ignition system, then alternator-out ops would call for turning one ignition OFF> >2) My batteries are also located in the tailcone >due to W&B needs with about a 12ft run aft of >the firewall. I estimated the starter would see >about 10.3V after losses. Does this sound right? That's fine. >3) How best to wire my dual Grand Rapids >EFIS/AHRS and the Engine Info System (EIS 4000) >to enable them to be ON during engine start. I >want the EIS on to monitor engine vitals (oil >pressure). For the EFIS/AHRSit can take up >to two minutes to align the AHRS, and I'd prefer >not to burn gas, make noise, and blow stuff around while I wait for alignment. At engine idle? Don't you let things warm up a bit before you drive off? I think there are plenty of things on a well crafted check-list to soak up 2 minutes wile the AHRS gets up on its feet. If you're charging off into the deep woods with this airplane, battery maintenance is VERY high on the list. I think I'd rather have a better payload and one battery that's changed out often than two batteries that need extra-ordinary attention. > Id like everything ready, checklist > complete up to the point of "ignition", then > start up, and taxi away. Im considering > moving the 2nd EFIS/AHRS to the Endurance bus > as well, or a Brownout Battery Bus. Simpler is ALWAYS better if you can configure an operating procedure that accommodates the special needs for some accessories. >4) Overall does the wiring schematic make >sense? What mistakes did I make? Can it be simplified? Yes . . . none that I can see beyond questions cited above . . . and yes. >I've attached two versions of the >architecture. One is printable (4 pages) to >read, and the other screen viewable. Ive >also attached my electrical bus load analysis. Nice job Bob . . . ________________________________________________________________________________
Date: Mar 06, 2011
ign.
This is a good time to introduce myself to the list. I'm doing almost this same configuration to an RV-6A -- with batteries up front, of course. It was bought flying a few years ago by my father-in-law so he isn't the builder. He wants to replace the steam gauges and mags and move to an all electric airplane. It will have dual GRT (one HX, one HS) screens, and EIS 4000, and dual LSE Plasma III ignitions. I'm just the electrical designer since it is his plane, though since they now live closer to me, maybe I wil l get to fly it occasionally! Mission: Day/Night VFR, future path to IFR when pilots get rated and plane gets the right GPS. Our plan was to use something like Z13/8 with a small SLA (alarm system type, 4 ~ 5AH) battery as an AUX battery, diode connected to the main battery bus. (Incidentally, I see in Z10, Z30, and Z35 no diode on the AUX battery line -- why is it not needed? On Z10 I see that it powers the whol e E-bus, but not on Z30 & Z35.) This aux battery would only support one LSE ignition ("primary -- #1") and the GRT system during cranking. I hadn't even thought about kickback -- this was originally for brownout on the GRTs. If it is a demonstrable and catastrophic failure mode, why is it still allowed to exist? In my simplified view of things, I think the fix would look like this: if input voltage too low, then no spark trigger allowed. For ignition controls, my FIL wants to use toggle switches with #1 having momentary starter engagement at full up position, rather than a separate starter button. Other questions for the list: Does the inclusion of the limited mission, small aux battery justify its weight? What would be a simpler configuratio n with similar benefits? -Jeff- Albuquerque, NM On Sun, Mar 6, 2011 at 8:35 PM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > nuckolls.bob(at)aeroelectric.com> > > > Some challenges I'm still scratching my head over include: >> >> 1) How best to wire the dual Lightspeed electronic ignitions to ensure >> they see higher than 8.5V during engine start to minimize chance of star ter >> kickback. >> > > Turn the ignition switches on after you hit the > starter button. The 'brownout' lasts but 100 milliseconds > or so. Is the 8.5v number from Lightspeed? I believe the > ignition systems run at well under 8.5 volts. > > ??? Don't understand Ign #1 sparking cylinders 1&2 and #2 > ignition sparking 3&4 ?????? > > > I'm using a Skytec 149-12LS starter (PMG) which has the high current dra w >> at start. Should I move both Lightspeed ignitions to a Brownout Batter y >> Bus? >> > > No. I'd put one on a battery bus, the other on the > e-bus. If you were sparking all 4 cylinders with > EACH ignition system, then alternator-out ops would > call for turning one ignition OFF> > > > 2) My batteries are also located in the tailcone due to W&B needs with >> about a 12ft run aft of the firewall. I estimated the starter would see >> about 10.3V after losses. Does this sound right? >> > > That's fine. > > > 3) How best to wire my dual Grand Rapids EFIS/AHRS and the Engine Info >> System (EIS 4000) to enable them to be ON during engine start. I want the >> EIS on to monitor engine vitals (oil pressure). For the EFIS/AHRS=85it can >> take up to two minutes to align the AHRS, and I'd prefer not to burn gas , >> make noise, and blow stuff around while I wait for alignment. >> > > At engine idle? Don't you let things warm up a bit > before you drive off? I think there are plenty of > things on a well crafted check-list to soak up > 2 minutes wile the AHRS gets up on its feet. > > If you're charging off into the deep woods with this > airplane, battery maintenance is VERY high on the > list. I think I'd rather have a better payload and > one battery that's changed out often than two > batteries that need extra-ordinary attention. > > > I=92d like everything ready, checklist complete up to the point of >> "ignition", then start up, and taxi away. I=92m considering moving the 2nd >> EFIS/AHRS to the Endurance bus as well, or a Brownout Battery Bus. >> > > Simpler is ALWAYS better if you can configure an > operating procedure that accommodates the special > needs for some accessories. > > > 4) Overall does the wiring schematic make sense? What mistakes did I >> make? Can it be simplified? >> > > Yes . . . none that I can see beyond questions cited above . . . and > yes. > > > I've attached two versions of the architecture. One is printable (4 >> pages) to read, and the other screen viewable. I=92ve also attached my >> electrical bus load analysis. >> > > Nice job > > > Bob . . . > > ________________________________________________________________________________
ign.
Date: Mar 06, 2011
It might be worth while to try PMAGS and get the GRTs with internal backup batteries. This eliminates all of your concerns. I run a similar system except I have AFS instead of GRT. From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Jeff B. Sent: Sunday, March 06, 2011 9:25 PM Subject: Re: AeroElectric-List: Need help in reviewing Z10/8 arch for dual Lightspeed ign. This is a good time to introduce myself to the list. I'm doing almost this same configuration to an RV-6A -- with batteries up front, of course. It was bought flying a few years ago by my father-in-law so he isn't the builder. He wants to replace the steam gauges and mags and move to an all electric airplane. It will have dual GRT (one HX, one HS) screens, and EIS 4000, and dual LSE Plasma III ignitions. I'm just the electrical designer since it is his plane, though since they now live closer to me, maybe I will get to fly it occasionally! Mission: Day/Night VFR, future path to IFR when pilots get rated and plane gets the right GPS. Our plan was to use something like Z13/8 with a small SLA (alarm system type, 4 ~ 5AH) battery as an AUX battery, diode connected to the main battery bus. (Incidentally, I see in Z10, Z30, and Z35 no diode on the AUX battery line -- why is it not needed? On Z10 I see that it powers the whole E-bus, but not on Z30 & Z35.) This aux battery would only support one LSE ignition ("primary -- #1") and the GRT system during cranking. I hadn't even thought about kickback -- this was originally for brownout on the GRTs. If it is a demonstrable and catastrophic failure mode, why is it still allowed to exist? In my simplified view of things, I think the fix would look like this: if input voltage too low, then no spark trigger allowed. For ignition controls, my FIL wants to use toggle switches with #1 having momentary starter engagement at full up position, rather than a separate starter button. Other questions for the list: Does the inclusion of the limited mission, small aux battery justify its weight? What would be a simpler configuration with similar benefits? -Jeff- Albuquerque, NM On Sun, Mar 6, 2011 at 8:35 PM, Robert L. Nuckolls, III wrote: Some challenges I'm still scratching my head over include: 1) How best to wire the dual Lightspeed electronic ignitions to ensure they see higher than 8.5V during engine start to minimize chance of starter kickback. Turn the ignition switches on after you hit the starter button. The 'brownout' lasts but 100 milliseconds or so. Is the 8.5v number from Lightspeed? I believe the ignition systems run at well under 8.5 volts. ??? Don't understand Ign #1 sparking cylinders 1&2 and #2 ignition sparking 3&4 ?????? I'm using a Skytec 149-12LS starter (PMG) which has the high current draw at start. Should I move both Lightspeed ignitions to a Brownout Battery Bus? No. I'd put one on a battery bus, the other on the e-bus. If you were sparking all 4 cylinders with EACH ignition system, then alternator-out ops would call for turning one ignition OFF> 2) My batteries are also located in the tailcone due to W&B needs with about a 12ft run aft of the firewall. I estimated the starter would see about 10.3V after losses. Does this sound right? That's fine. 3) How best to wire my dual Grand Rapids EFIS/AHRS and the Engine Info System (EIS 4000) to enable them to be ON during engine start. I want the EIS on to monitor engine vitals (oil pressure). For the EFIS/AHRS.it can take up to two minutes to align the AHRS, and I'd prefer not to burn gas, make noise, and blow stuff around while I wait for alignment. At engine idle? Don't you let things warm up a bit before you drive off? I think there are plenty of things on a well crafted check-list to soak up 2 minutes wile the AHRS gets up on its feet. If you're charging off into the deep woods with this airplane, battery maintenance is VERY high on the list. I think I'd rather have a better payload and one battery that's changed out often than two batteries that need extra-ordinary attention. I'd like everything ready, checklist complete up to the point of "ignition", then start up, and taxi away. I'm considering moving the 2nd EFIS/AHRS to the Endurance bus as well, or a Brownout Battery Bus. Simpler is ALWAYS better if you can configure an operating procedure that accommodates the special needs for some accessories. 4) Overall does the wiring schematic make sense? What mistakes did I make? Can it be simplified? Yes . . . none that I can see beyond questions cited above . . . and yes. I've attached two versions of the architecture. One is printable (4 pages) to read, and the other screen viewable. I've also attached my electrical bus load analysis. Nice job Bob . . . ________________________________________________________________________________
ign.
Date: Mar 07, 2011
Hi Howard I like very much your load analysis, and your electric schematic as well, and I will probably use it in a future project, or in refurbishing my current aircraft, which has an electric dependant engine. Our guru (=98lectric Bob) already answered your questions, and I have not enough knowledge to answer your questions 1 to 3 or comment on his answers. I will just comment on some details of your architecture, and make some questions in order to learn something else. a) In the SD-8 circuit, you have put a =9CLow Volts Aux Alt=9D LED light that seems it will be permanently On, since it is directly connected to the (+) terminal of the Main Battery through the NC terminal of the Aux Alt S704-1 relay. Is that wrong on your schematic, or am I wrong? b) Why did you connect the Fuel Primer pump to your =9Calways hot=9D Main Battery Bus? c) In this =9Calways hot=9D Main Battery Bus, you have a connection (lower left) called =9CEndurance Bus=9D, which is not connected to the Endurance Bus, but rather to the COM terminal of the S704-1 =9CBrownout Battery Relay, which is connected to the (+) terminal of the Aux Battery, except when you push the Start button . Would you please explain this connection and this relay function? Regards Carlos > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list- > server(at)matronics.com] On Behalf Of plevyakh > Sent: segunda-feira, 7 de Mar=C3=A7o de 2011 0:44 > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Need help in reviewing Z10/8 arch for dual Lightspeed > ign. > > > Folks, > I've made up my electrical system plan and sure would appreciate some fresh eyes > and input. > > 4) Overall does the wiring schematic make sense? What mistakes did I make? > Can it be simplified? > > I've attached two versions of the architecture. One is printable (4 pages) to read, > and the other screen viewable. I=C3=A2=82=AC=84=A2ve also attached my electrical bus load > analysis. > > Thanks in advance for any inputs! > Howard > > -------- > Howard Plevyak > GlaStar / North Bend, Ohio > hplevyak(at)mac.com > ________________________________________________________________________________
Date: Mar 07, 2011
My 9.8 volt drill battery lasted only a month or so when new. It would have cost twice the drill price just to get a replacement battery. So, I've been running the 9.8 volt drill from a 12.8 volt PC-680 for a couple of years. Works great. Charlie Brame RV6A N11CB San Antonio ---------------------------------------------------------- > Subject: AeroElectric-List: Adding a 12 pound cord to a 12V cordless > drill. > From: "rparigoris" <rparigor(at)suffolk.lib.ny.us> > > > http://www.europaowners.org/forums/gallery2.php?g2_itemId=87399 > > Adding a 12 pound cord to a 12V cordless drill. > I have been working on outfitting trailers for a solar charging > station trailer > project that has the trailers scattered apart by at least a few > hundred feet. > It is far easier to carry around a 12 pound line cord than it is to > try and run > a few hundred feet of extension cord or move a ton and a half > trailer to were > the power is. > This model Dewalt cordless drill comes with NiCad batteries that are > somewhere > around 2000 to 2200 mAs and 12 volts. > We purchased a NiMh aftermarket replacement that comes in at 3000 > mAs. It's a pain > running back and forth to a charger with now only two battery packs. > It's > true that three packs that are now retired were not new, hard use > didn't do them > any good. > Anyway we grabbed some fairly flexable well insulated round wire and > tied the hot, > neutral and ground together and used one each to the posative and > negative > of a ~ 5,000 to 8,000 mA (realistic output under drill load pulled > down to 12.1 > volts (approx 50%)) lead acid battery, using the carcus of one of > the dead > packs to get power to the drill. FYI, this Harbor Freight jump start > pack has > the battery marked at 17aH, but with a 330 mA load, it nets out at > only 12,000 > mAs (12aH). > Bottom line is it works a treat! Thus far a full day of use has not > run battery > down. > To tweak performance just a little, thicker wire could be used. > Yellow pack to the left of drill is NiCad pack. > Black pack below the NiCad pack is aftermarket NiMh pack. > Ron Parigoris > Y11-03-06 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=332974#332974 > ________________________________________________________________________________
Date: Mar 07, 2011
> the 10A when on the EMS page should just be repeating what is on the D180 EMS True if both are powered from the same bus. But if one EMS gets its power through a diode and the other does not, then they will show different voltages. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=333052#333052 ________________________________________________________________________________
Date: Mar 07, 2011
You are correct, my grounds are good but there is a difference in voltage due to the diode the power goes through to get to the E-Bus. I was surprised to see the difference in that the D10A is and EFIS only unit not and EMS, but through the Dynon DSAB network you can display different items on the D10A screen to include engine instruments. My surprise was I thought showing this data should just be a repeat of the main EMS information. My real question here is given that there is a voltage difference between the main bus and the E-bus by about .6 volts which bus would be the best place to have the standby alternator monitor bus voltage. The standby regulator is set to a lower voltage so if the main alternator is operating fine the standby just stays idle, when the bus it monitors falls below the set point in the standby regulator then it wakes up and starts to provide power. user9253 wrote: > > > the 10A when on the EMS page should just be repeating what is on the D180 EMS > > True if both are powered from the same bus. But if one EMS gets its power through a diode and the other does not, then they will show different voltages. > Joe -------- Mike "Nemo" Elliott RV-8A QB (Fuselage) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=333054#333054 ________________________________________________________________________________
Date: Mar 07, 2011
nuckolls.bob(at)aeroelect wrote: > At 01:58 PM 3/6/2011, you wrote: > > > > > > > I have just powered up my panel and I have two EFIS units that talk > > to each other (Dynon 180 and a 10A), I was putting the 10A on the > > EMS page and noticed that the voltage reported on it was 13.4 V and > > the voltage on the D180 (which is the box with the EMS) was showing > > 12.8 V. I have things powered with a power supply putting out 13.8 > > volts and the battery is out of the loop. I will have to run down > > why this is from Dynon but it got me to thinking > > > > Since there is a voltage drop when the power flows from the main bus > > to the E-Bus through the diode, I wonder where the best place for > > voltage sensing wire should be, since it will activate on a lower > > voltage from the main bus. > > > > > > Can you disable/work-around on the low votlage warning > for the device powered from the e-bus? Normally, one > low voltage warning system suffices. > > Not sure what you meant here but my primary low voltage warning will be the EFIS alarm, since it monitors voltage. > > > > Right now I have the Low Voltage light and sense wire on the same > > breaker on the main bus which gets the highest voltage, the D180 is > > on the E-bus so its power is going through the E-bus diode. I am > > not sure if this is why I see the voltage difference between the two > > displays, I kind of think not because the 10A when on the EMS page > > should just be repeating what is on the D180 EMS. > > > > But all this begs the question is there a "Best" location for a > > standby alternator regulator to monitor the system voltage? Main bus or E-bus? > > > > > > Which z-figure are you using? If Z-13/8, the > rectifier/regulator gets it's voltage sense > info from the system it's powering. That > would be true also for any other auxiliary > engine driven power source. > > > Bob . . . > //// > (o o) > ===========o00o=(_)=o00o======== > > < show me where I'm wrong. > > ================================ My system is Z12 so the standby alternator attaches at the start contactor and then uses the same main bus feed wire. I have the alternate feed switching for the hot battery bus to the E-bus as a way to isolate the E-bus if I get to a battery only situation. Since the standby regulator needs to monitor bus voltage I have it set up to monitor the main bus. As you can see the low voltage alarm off the EFIS will be different from what the standby regulator reads due to the drop in the diode. I think I can work around the issue in that the EFIS #2 attached to the main bus has it's own alarms and I can set that to my specifications. -------- Mike "Nemo" Elliott RV-8A QB (Fuselage) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=333055#333055 ________________________________________________________________________________
ign.
Date: Mar 07, 2011
"Some challenges I'm still scratching my head over include: 1) How best to wire the dual Lightspeed electronic ignitions to ensure they see higher than 8.5V during engine start to minimize chance of starter kickback." > Bob Answer: Turn the ignition switches on after you hit the starter button. The 'brownout' lasts but 100 milliseconds or so. Is the 8.5v number from Lightspeed? I believe the ignition systems run at well under 8.5 volts. > > ??? Don't understand Ign #1 sparking cylinders 1&2 and #2 ignition sparking 3&4 ?????? I'd prefer a more elegant solution to what you suggest Bob. I know that's a simpler one....but with my spouse flying or others down the road....I'm sure that "ops manual bold face procedure" would get missed. The Ign #1 sparking cylinders 1&2 and #2 ignition sparking #3 & 4 cylinders is a type O mistake in my schematic. I have updated it to "LSE CD Ignition Box #1, and LSE CD Ignition Box #2". Per the LSE Install manual: "Dual systems can be connected to each other such that each system knows if the other one is operating. If one of the two systems is turned off or has failed, the remaining system will automatically shift its timing curve to provide optimum engine performance with one system. This eliminates the common power loss when one magneto is turned off. The extremely wide operating voltage range, from 5v-35v allows hand starting long after the electric starter has stopped due to a low battery." You are correct on the Lightspeed operating voltages. Service Bulletin PL-2 dated 6/26/2006 state that the "minimum supply voltage for starting is 6.5 volts, and minimum operating voltage is 5.5 volts" See URL here the Lightspeed Service bulletins: http://www.lightspeedengineering.com/News/ServiceBulletins.htm Service Bulletin PL-1B addresses "Misfire during Start and Kickbacks"... This SB states that "unmodified systems shipped before 12/04 can misfire if the supply voltage drops below 8.5V repeated during cranking. This can only occur if the starter draws excessive current and the battery is not sized for that current requirement. .... Toggle switch operated systems have no tendency to misfire, (the issue was triggered by the rapid "on" / "off" "on" sequence of the key switch motion)." I have U3+ versions of the Plasma Ignition boxes and I'm using TOGGLE switches. So I think my boxes are good to 6.5V min. for starting. I have an email to Klaus Savier at LSE to confirm this. So if my starter sees ~10V, and my LSE Ignition box timing firing is good down to a starting voltage of 6.5V....should I NOT worry about a potential for misfire? I'm thinking of that cold day scenario where it might be tough to get the engine started. What I'm not clear on is what happens if main battery circuit or the brownout battery circuit drops down below the minimum starting voltage? With a good battery maint. program, the probability is very low of an issue, but I'd still like to know how would the dual LSE Ignition systems respond? I'm hoping that with the Dual system interconnect, the box on the circuit with voltage greater than min. starting voltage would still keep the timing in order and no issues with starting. I know this is a question for Klaus at LSE, but wondering if anyone with dual LSE ignitions can shed some light? ==== "I'm using a Skytec 149-12LS starter (PMG) which has the high current draw at start. Should I move both Lightspeed ignitions to a Brownout Battery Bus?" > Bob Answer: No. I'd put one on a battery bus, the other on the e-bus. If you were sparking all 4 cylinders with EACH ignition system, then alternator-out ops would call for turning one ignition OFF> Agreed. Each Ignition box sparkles all 4 cyl. So if main alternator is out, then I think my ops procedure would be: 1) MAIN L-60 ALTERNATOR FIELD CIRCUIT BREAKER - PULL 2) DC POWER MASTER SWITCH - OFF - drops off main battery contactor (1amp) and main bus...saving amps 3) AUX SD-8 ALTERNATOR SWITCH - ON - brings online SD-8 yielding 5.4 to 7.0 amps with 2150 prop RPM 4) EBUS ALTERNATE FEED SWITCH - ON - provides power to endurance bus 5) LIGHTSPEED IGNITION #1 SWITCH - OFF - to save 1.3amps from main battery drain ------------------------------------------------------- LSE has a recommended Dual Power Supply wiring schematic. I've attached below, and link is also here. http://www.lightspeedengineering.com/Manuals/PS_Diagram.htm Should I just simplify my dual batt brownout schematic and just use a single Shottky diode between the two as shown in LSE's schematic? "3) How best to wire my dual Grand Rapids EFIS/AHRS and the Engine Info System (EIS 4000) to enable them to be ON during engine start. I want the EIS on to monitor engine vitals (oil pressure). For the EFIS/AHRSit can take up to two minutes to align the AHRS, and I'd prefer not to burn gas, make noise, and blow stuff around while I wait for alignment." > Bob Answer: At engine idle? Don't you let things warm up a bit before you drive off? I think there are plenty of things on a well crafted check-list to soak up 2 minutes while the AHRS gets up on its feet. > > If you're charging off into the deep woods with this airplane, battery maintenance is VERY high on the list. I think I'd rather have a better payload and one battery that's changed out often than two batteries that need extra-ordinary attention. "Id like everything ready, checklist complete up to the point of "ignition", then start up, and taxi away. Im considering moving the 2nd EFIS/AHRS to the Endurance bus as well, or a Brownout Battery Bus." > Bob Answer: Simpler is ALWAYS better if you can configure an operating procedure that accommodates the special needs for some accessories. I prefer to find out issues with my EFIS/EIS system before engine start. In addition, Grand Rapids Tech. in their installation manual pg. 6-1, recommends in section 6.2 Power Connections: "It is desirable to not have the display units and AHRS connected to the power supply supplying power to the engine starter during the engine start (to maximize current available for the starter, and possibly extend the life of the CCFL backlight in the display unit), this feature allows the fitting of a small (3-5AH) auxiliary battery to one of the power input connections provide power to the EFIS during engine start." I could size the AUX/Brownout battery 17AH (15.3 lbs) down to a 5AH (5.9 lbs), but I do like the idea of two batteries the same size and swapping out one each year for a new one. An Aux. PC680 also gives me approx. 2.6hrs at an endurance bus load of 4.6 amps. "4) Overall does the wiring schematic make sense? What mistakes did I make? Can it be simplified?" > Bob Answer: Yes . . . none that I can see beyond questions cited above . . . and yes. > > Bob . . . Lastly, I wanted to add...You and the AEC forum are just an INCREDIBLE resource! THANK-YOU for writing the AEC book and providing a place for us electrical challenged guys to bang heads and build better airplanes! -------- Howard Plevyak GlaStar / North Bend, Ohio hplevyak(at)mac.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=333058#333058 Attachments: http://forums.matronics.com//files/glastar_schematic_v0c1_7mar2011_for_review_653.gif http://forums.matronics.com//files/dual_power_supply_diagram_358.gif ________________________________________________________________________________
Date: Mar 07, 2011
Subject: For Sale on Barnstormers
I'm finally getting around to putting some unused Long EZ parts up for sale on Barnstormers. This morning I listed an unused Ken Brock carburetor heat valve (I'll be using a ram air box which includes the heat valve) and the entire Brock manual nose gear retractor. Includes new gears, spring strut, strut bracket, crank, bushing and rod. The gear retractor was installed, but has never been flown. I've replaced it with an electric gear retractor, so the entire system is for sale, not including the NG14 spacer rods and the NG4 bracket...both of which are used on my new system. NG14 is just an aluminum rod and NG4 is sheet steel. Both are easily fabricated and included in the included plans. The gears are like new, but will need to be lubed before use. If interested (or just want to look) Just go to the Barnstormer's search box ( www.barnstormers.com/cat.php?mode=search) and type in "Brock". There are currently only four ads there...the above items are the first two (obviously ). They are priced well below their current ACS prices. Harley Dixon ________________________________________________________________________________
Date: Mar 07, 2011
Lightspeed ign. At 11:26 AM 3/7/2011, you wrote: > >"Some challenges I'm still scratching my head over include: > > >I'd prefer a more elegant solution to what you suggest Bob. I know >that's a simpler one....but with my spouse flying or others down the >road....I'm sure that "ops manual bold face procedure" would get missed. >Per the LSE Install manual: "Dual systems can be connected to each >other such that each system knows if the other one is operating. If >one of the two systems is turned off or has failed, the remaining >system will automatically shift its timing curve to provide optimum >engine performance with one system. This eliminates the common >power loss when one magneto is turned off. The extremely wide >operating voltage range, from 5v-35v allows hand starting long after >the electric starter has stopped due to a low battery. >You are correct on the Lightspeed operating voltages. Service >Bulletin PL-2 dated 6/26/2006 state that the "minimum supply voltage >for starting is 6.5 volts, and minimum operating voltage is 5.5 volts" >See URL here the Lightspeed Service bulletins: >http://www.lightspeedengineering.com/News/ServiceBulletins.htm > >Service Bulletin PL-1B addresses "Misfire during Start and >Kickbacks"... This SB states that "unmodified systems shipped before >12/04 can misfire if the supply voltage drops below 8.5V repeated >during cranking. This can only occur if the starter draws excessive >current and the battery is not sized for that current requirement. Which obviously will not be a condition on your airplane . . . > .... Toggle switch operated systems have no tendency to misfire, > (the issue was triggered by the rapid "on" / "off" "on" sequence of > the key switch motion)." > >I have U3+ versions of the Plasma Ignition boxes and I'm using >TOGGLE switches. So I think my boxes are good to 6.5V min. for >starting. I have an email to Klaus Savier at LSE to confirm this. Okay, a solution from Klaus's perspective would be a software fix in his product so that sparking cannot commence until the after two crank triggers are sensed . . . or just a timing sequence that holds the system quiet until a few hundred milliseconds after starter initiation. But yes, I think you're worrying about something that doesn't happen except in the most abusive of battery conditions. The TC aircraft guys do lots of mystifying things with their airplanes. I'm hoping that folks who hang out here on the List will give their battery choices AND maintenance and educated degree of respect. >So if my starter sees ~10V, and my LSE Ignition box timing firing is >good down to a starting voltage of 6.5V....should I NOT worry about >a potential for misfire? How does your ignition system voltage get to be anything less than what the starter sees? The brownout occurs during motor inrush . . . zero-rpm at start=up means the starter draws stall current. Maybe over 1000A with a good battery and stiff wiring. Here's a plot I took off a GMC Safari with a wound field starter and an RG battery http://www.aeroelectric.com/Pictures/Curves/95_GMC_Safari_1.gif Here's one I got off a Saturn with smaller engine, PM starter and wet battery http://www.aeroelectric.com/Pictures/Curves/99_Saturn_SL1.jpg Here's another Saturn shot at higher resolution in time http://www.aeroelectric.com/Pictures/Curves/99_Saturn_SL1_2.gif Note that cranking current goes nowhere but down and after 250 mS the battery V is up over 10V. Airplane engines crank similarly. >I'm thinking of that cold day scenario where it might be tough to >get the engine started. The concern is not for extended cranking but for the initial effects of accelerating a very low resistance PM motor. >What I'm not clear on is what happens if main battery circuit or the >brownout battery circuit drops down below the minimum starting voltage? ?? not sure about the point of the question. The purpose of the brownout protection battery is to insure this doesn't happen. Any time the voltage drops below the manufacturer's specified minimums, operating performance is not guaranteed. This doesn't necessarily mean you should EXPECT any particular symptom . . . unless those symptoms are also called out by the manufacturer. My general sense is that piling two batteries into your airplane will have a negative effect on payloads while adding no measurable or demonstrable benefits. >With a good battery maint. program, the probability is very low of >an issue, but I'd still like to know how would the dual LSE Ignition >systems respond? > >I'm hoping that with the Dual system interconnect, the box on the >circuit with voltage greater than min. starting voltage would still >keep the timing in order and no issues with starting. I know this >is a question for Klaus at LSE, but wondering if anyone with dual >LSE ignitions can shed some light? That 'timing' issue is for RUNNING operations only and is a very small issue at that. ALL starting ops are after top dead center irrespective of how many ignitions are running. And as I mentioned before, alternator out ops should call for shutting one system off . . . even if it did result in a slight reduction of power. Your PLAN-B needs to acknowledge that a significant failure has occurred and subsequent operations are designed for minimizing risk to a happy ending of the flight . . . not keeping all the electro-whizzies running. >Agreed. Each Ignition box sparkles all 4 cyl. So if main >alternator is out, then I think my ops procedure would be: > >1) MAIN L-60 ALTERNATOR FIELD CIRCUIT BREAKER - PULL No necessary. Circuit breakers are for protecting wires, not switching equipment. >2) DC POWER MASTER SWITCH - OFF > - drops off main battery contactor (1amp) and main bus...saving amps And shuts off the main alternator. >3) AUX SD-8 ALTERNATOR SWITCH - ON > - brings online SD-8 yielding 5.4 to 7.0 amps with 2150 prop RPM > >4) EBUS ALTERNATE FEED SWITCH - ON > - provides power to endurance bus DO THIS FIRST >5) LIGHTSPEED IGNITION #1 SWITCH - OFF > - to save 1.3amps from main battery drain Yup. >------------------------------------------------------- > >LSE has a recommended Dual Power Supply wiring schematic. I've >attached below, and link is also here. >http://www.lightspeedengineering.com/Manuals/PS_Diagram.htm > >Should I just simplify my dual batt brownout schematic and just use >a single Shottky diode between the two as shown in LSE's schematic? No. One ignition from the main battery bus, the other from the endurance bus. Each to have it's own breaker and one system to enjoy dual power sources no matter what. You don't need the second battery/diode combo. If you're not putting in Z-13/8, THEN you use the dual batteries/diode configuration. > > Bob Answer: Simpler is ALWAYS better if you can configure an > operating procedure that accommodates the special needs for some accessories. > > >I prefer to find out issues with my EFIS/EIS system before engine >start. In addition, Grand Rapids Tech. in their installation manual >pg. 6-1, recommends in section 6.2 Power Connections: > >"It is desirable to not have the display units and AHRS connected to >the power supply supplying power to the engine starter during the >engine start (to maximize current available for the starter, This is B.S. Minor system loads are never an issue for getting the engine started in an airplane with a well maintained battery . . . i.e. one that's traded out at intervals or when test limits are not met. > and possibly extend the life of the CCFL backlight in the display > unit), this feature allows the fitting of a small (3-5AH) auxiliary > battery to one of the power input connections provide power to the > EFIS during engine start." Hmmm . . . "possibly" . . . suggests these folks may not understand their product. Either they have explored the suitability of their device to join the ranks of other products designed for the aircraft environment . . . or they have not. See: http://www.aeroelectric.com/articles/Philosophy/Whats_all_this_DO160_Stuff_Anyhow.pdf If they have not, it would be better that they at least tell the customer in what ways they chose to reduce development costs. I'm not suggesting that low-cost offerings are necessarily a poor value . . . but they should KNOW exactly what things are at risk and why. Is their installation/operation data published on the 'net anywere? >I could size the AUX/Brownout battery 17AH (15.3 lbs) down to a 5AH >(5.9 lbs), but I do like the idea of two batteries the same size and >swapping out one each year for a new one. An Aux. PC680 also gives >me approx. 2.6hrs at an endurance bus load of 4.6 amps. Does this include support energy from the SD-8? Once you add the SD-8, battery sizing for endurance shouldn't be an issue. >Lastly, I wanted to add...You and the AEC forum are just an >INCREDIBLE resource! THANK-YOU for writing the AEC book and >providing a place for us electrical challenged guys to bang heads >and build better airplanes! Folks on the List are as much a resource for me as I am for them. I could write another book on the number of products that never came into being purely for reasons of regulatory, management or marketing boondoggles. That sort of thing wasn't happening in the heydays of Walter, Duane and Willy. That's how I got to put a speed regulated trim system on the 55 Lears . . . which was so popular that it got retrofitted to the fleet of 30 series airplanes and made my boss a few $millions$. I've chased much slicker products through the rat-maze since but none have been so satisfying . . . so I guess I could say my career 'peaked' when I was 37. Not that it hasn't been educational and fun. YOU folks are my reason for thinking hard these days . . . you're saving me from Alzheimer's. So THANK YOU too! Bob . . . ________________________________________________________________________________
Date: Mar 07, 2011
> >My system is Z12 so the standby alternator attaches at the start >contactor and then uses the same main bus feed wire. I have the >alternate feed switching for the hot battery bus to the E-bus as a >way to isolate the E-bus if I get to a battery only situation. >Since the standby regulator needs to monitor bus voltage I have it >set up to monitor the main bus. Right. > As you can see the low voltage alarm off the EFIS will be > different from what the standby regulator reads due to the drop in > the diode. I think I can work around the issue in that the EFIS #2 > attached to the main bus has it's own alarms and I can set that to > my specifications. If the alarm for the e-bus instruments can be calibrated, then set them for 10.5 volts. That's the voltage your battery is 95% used up. Gizmos with LV warning attached to the main bus get set for 13.5. Bob . . . ________________________________________________________________________________
Date: Mar 08, 2011
Subject: Bistable relay control
I'm thinking of making a monostable relay type control for bistable relays (if and when) in one or more (or none) of the following shapes: - 2 square inches of pcb - mounted in a DSub DE-9 backshell - integrated with a Tyco BDS-A contactor plug Components will be SMD's. Attached two contemplated variations. Any and all comments welcome. Jan de Jong ________________________________________________________________________________
Date: Mar 08, 2011
Subject: Low power and weight exercise
I concocted a design for a very light weight and very low control power Rotax 914 electrical system. It features LiFePO4 batteries, bistable relays with monostable control and solid state load switches. See attached page if you will. Thoughts welcome. Jan de Jong ________________________________________________________________________________
Date: Mar 08, 2011
Jan, I'm assuming that you are referring to the Tyco latching relays that were discussed here a few weeks ago. That looks like a lot of (pretty cool) engineering, but is it really necessary? I'm thinking that a SPDT (on)- off - (on) toggle switch is all that is really req'd to control the Tyco latching relay. Am I missing something? -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Jan de Jong Sent: Tuesday, March 08, 2011 09:25 Subject: AeroElectric-List: Bistable relay control I'm thinking of making a monostable relay type control for bistable relays (if and when) in one or more (or none) of the following shapes: - 2 square inches of pcb - mounted in a DSub DE-9 backshell - integrated with a Tyco BDS-A contactor plug Components will be SMD's. Attached two contemplated variations. Any and all comments welcome. Jan de Jong ________________________________________________________________________________
Date: Mar 08, 2011
Subject: Re: Bistable relay control
Jeff, You are absolutely right. It is only when one wants to do more than switch one latching relay on and off that it is useful for latching relays to behave like monostable relays. Say there are several latching relays in a system: 1. Progressive power down may be needed so that a relay has power for switching off (can also be in a checklist) 2. It may be nice to have a handle position reflect a relay state (can also be provided with an indicator led) 3. The system requires automation - automation has open/close outputs and cannot be expected to provide pulses. Jan de Jong Jeff Luckey wrote: > > Jan, > > I'm assuming that you are referring to the Tyco latching relays that were > discussed here a few weeks ago. > > That looks like a lot of (pretty cool) engineering, but is it really > necessary? I'm thinking that a SPDT (on)- off - (on) toggle switch is all > that is really req'd to control the Tyco latching relay. > > Am I missing something? > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Jan de > Jong > Sent: Tuesday, March 08, 2011 09:25 > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Bistable relay control > > I'm thinking of making a monostable relay type control for bistable > relays (if and when) in one or more (or none) of the following shapes: > - 2 square inches of pcb > - mounted in a DSub DE-9 backshell > - integrated with a Tyco BDS-A contactor plug > Components will be SMD's. > > Attached two contemplated variations. > > Any and all comments welcome. > > Jan de Jong > > > ________________________________________________________________________________
Subject: latching relays
Date: Mar 10, 2011
Hi Bob, I'm following your Figure Z-19 schematic as a guide to the electrics to service an MPEFIed Sube EA81 derivative put out by Ron Carr at RAM Performance...it is powering a Europa XS, well along in its construction. With the FWF complete (well, almost complete), a lot of the wiring done for ancillary systems (fuel pumps, lighting, antennas, etc.) I'm taking a hard look at the power side of things and have just ordered 35 feet of Super-4 fatwire, and am planning on dual Odyssey batteries. And I have a couple of the generic contactors which Acft. Spruce sells as Master Relays (p/n 111-226), purchased w/ the intention of using one at each battery. A pal...a savvy guy for MARINE electrical systems...has suggested that I use "latching relays" which, he sez, will add to flight safety. I've not seen any references to them in your discussion of battery contactors in your book, though you do include some cautionary words about proper installation and potential contactor failure. What do you have to say about "latching relays" functioning as battery contactors? Thanks in advance for any wisdom you can offer...I confess to be one of those airplane builders w/ scant knowledge of the electrical side of things, Fred ________________________________________________________________________________
Date: Mar 10, 2011
Subject: Avionics installation tools and supplies
I hope this is allowed here - My project is over and someone on this list m ay need some of the things I have left over, now-for sale. Check out this -auction on eBay - Avionics installation tools and supplies. Have many ot her aviation related items as well so check my other items on eBay. More th ings will be available soon. - http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=16055680361 0&viewitem=&sspagename=STRK%3AMESELX%3AIT - Thanks, I hope someone will need something for their project. - Jim=0A=0A=0A ________________________________________________________________________________
Subject: Re: latching relays
Date: Mar 11, 2011
Fred, I know you asked Bob for his opinion on self latching relays, but thought I would through my two penneth in. Self latching relays operate in a number of different ways including the use of permanent magnets and cam mechanisms to achieve the latching. I suppose that there are two main perceived advantages of these devices for an aircraft: 1. Once latched they do not require power to hold them open (but with your Sube you have a fairly meaty alternator so that should not be an issue for you, especially if you install an essential bus that does not require a made contactor to provide power to your ignition system). 2. Once latched they are closed unless they are positively unlatched and so any failure in the wiring etc will not cause them to unlatch, but see comment above ref the use of an essential bus. Contactors are very simple devices and have proved extremely reliable in practice. One of the principle benefits of a simple battery contactor is its function as your last port of call isolation device for your main electrical systems. If you have a fault either with a stuck starter on the the ground or perhaps an electrical fault in the air that causes smoke in the cockpit your ultimate get out of jail card is to switch off the battery contactor, and in flight with an electrically dependent engine operate the essential bus depending on your electrical architecture. If the wiring fails to a latching relay at the same time as your fault you cannot release it but if the wiring fails to a battery contactor it will release under its own steam. If I am sailing a boat, the issue is somewhat different. With a major fault and unable to release the latching relay I can normally gain access to the battery and release the positive terminal or if that isn't possible most boats I have sailed have battery isolation switches for all battery banks which would isolate the fault - both scenarios are not possible in an aircraft. So your fault isolation logic would seem to me to need to be different Just food for thought. Mark Read this topic online here: http://forums.matronics.com/viewtopic.php?p=333524#333524 ________________________________________________________________________________
Date: Mar 11, 2011
A designer needs to ask, "if this part fails, how will I deal with it?" If a latching relay fails to open when commanded to, how will the electrical power be shut off? In case of a fire or imminent forced landing, the power needs to be shut off immediately. What is safer, a master contactor that fails open or one that fails closed? The engine will keep running with a failed contactor. And the essential bus will keep powering critical equipment. Your marine friend might not realize that an airplane can keep flying with the master contactor off. Simpler is better. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=333525#333525 ________________________________________________________________________________
Date: Mar 11, 2011
> >What do you have to say about "latching relays" functioning as battery >contactors? A couple of List members have accurately captured the thought processes unique to aircraft systems design. The well considered failure modes effects analysis speaks to Plan-B . . . mitigating the effects of any particular failure. It also seeks to identify whether or not the failure is passive (fail safe) or active (oh @#$@#! how do I turn this thing off!). I've considered the latching contactor often since it was introduced to us on the List a few weeks back. I've not yet discovered the right words and reasoning one might apply to say, a design review at Hawker-Beechcraft suggesting incorporation of the device onto one of their airplanes. Bob . . . ________________________________________________________________________________
Date: Mar 11, 2011
Subject: Re: Avionics installation tools and supplies
At 11:29 PM 3/10/2011, you wrote: >I hope this is allowed here - Absolutely. Thanks for the heads-up. Are you flying now? Bob . . . ________________________________________________________________________________
Date: Mar 11, 2011
At 12:39 PM 3/11/2011, you wrote: > >Mark, Joe, Bob, > >Your wisdom is very much appreciated...thank you...I have much to learn. > >Though I've been active on the matronics Europa-list, I've just joined >here and look forward to a time when I might have some wisdom to share >as well...til then, I fear I'll just be askin questions. Good . . . 'cause for sure, we can't build your airplane for you. Here is where you'll find lots of recipes for success and some help on sorting through the options. What ever you decide to do will perform as advertised. Questions are the place to start . . . Bob . . . ________________________________________________________________________________
Subject: remote battery charging
Date: Mar 12, 2011
All, As background and as previously posted, I'm building a Europa XS powered by an EA81 Sube variant produced by RAM Performance...it's a MPEFIed engine w/ dual intake ports and dyno'ed at 144 hp, is fitted w/ a geared Autoflite PSRU, and a RWS EC3 controller. Listed weight "wet" (?) is 176 pounds, though that would not include exhaust and cooling systems. For the past year, I've been able to design and fab an engine mounting frame, FG cowls, a twin radiator cooling system, a muffled 321 SS exhaust system, and install the various EMS temp. & pressure senders. Hopefully, the engine is hung for good...(finally). Since the Europa-list posters are virtually all using the Rotax engines, I'm hoping this aeroelectric-list will be a receptive place for me to post questions related to electric issues...particularly on the power side of things. I confess to be an absolute neophyte on all things electrical...I'm been using the AeroElectric Connection and an old copy of Tony Bingelis' Firewall Forward as my primary references. A couple of current (no pun intended) questions: Dual batteries will be located in the aft fuselage for W & B issues...I want to be able to recharge the batteries by installing a (more or less) flush, weatherproof receptacle and plug in the side of the FG fuselage, one which would replace the alligator clips on the charger. I believe I erred in buying a "Piper type socket" and "Piper type plug" (Acft. Spruce p/n 11-00500 and p/n 11042) thinking they would serve, but have concluded that their purpose is for "jump starting" rather than battery recharging. (If this is in fact so, they'll be returned.) Soooooo...can anyone suggest a brand/type/ model receptacle - plug combination suitable for battery charging? As for the batteries, originally I was thinking of using (1) Odyssey #680 and (1) #310 as back up; however, I'm persuaded by Bob's book's Fig. Z-19 and rationale for switching out one of two dual batteries of equal size during annual...thus...I'm now looking at using (2) Odyssey #545s (14AH each) for a total weight of 23.4 pounds. I see that B & C lists a slightly more powerful (16AH) battery, a BC116-1 w/ weight of 14.6 pounds (each). I can't seem to find any performance specs such as CCA rating for the B & C batteries...are they available for comparison w/ the Odysseys?...and do these brands utilize the same battery technology? Much obliged for any advice or assistance, Fred ________________________________________________________________________________
Date: Mar 12, 2011
Subject: Re: remote battery charging
Dual batteries will be located in the aft fuselage for W & B issues...I want to be able to recharge the batteries by installing a (more or less) flush, weatherproof receptacle and plug in the side of the FG fuselage, one which would replace the alligator clips on the charger. I believe I erred in buying a "Piper type socket" and "Piper type plug" (Acft. Spruce p/n 11-00500 and p/n 11042) thinking they would serve, but have concluded that their purpose is for "jump starting" rather than battery recharging. (If this is in fact so, they'll be returned.) Soooooo...can anyone suggest a brand/type/model receptacle - plug combination suitable for battery charging? You CAN charge batteries through such connectors . . . as well as crank engines if that need arises. It depends on how you wire the connector to your airplane. If you have dual batteries, then getting the pair of batteries connected together for charging purposes poses a problem for needing to have contactors closed. So if the goal is battery charging/maintenance only, then about anything is fine. Take a look at trailer lighting connectors like . .. Emacs! Walmart automotive has some like this. You need three or more pins. One for ground and one to each battery through an inline fuse (can be a fuse on the battery bus). If you don't need to lock the canopy closed during charging ops, consider mounting the jack inside the airplane so you don't need to poke a hole in the skin. If the socket is inside, remove the spring loaded "lid". It's not needed and only gets in the way. I'm now looking at using (2) Odyssey #545s (14AH each) for a total weight of 23.4 pounds. I see that B & C lists a slightly more powerful (16AH) battery, a BC116-1 w/ weight of 14.6 pounds (each). I can't seem to find any performance specs . . . If you're doing the yearly change-out of the oldest battery, absolute performance is not significant. The two batteries in parallel (on less than two years old, the other less than one year old) are going to crank your engine just fine. Buy the cheapest batteries you can find that have connections which support cranking currents. Bob . . . ________________________________________________________________________________
Date: Mar 13, 2011
May I offer a thought in support of latching relays. How likely is it that the fault that causes smoke in the cockpit coincides with the failure of the relay to open? Wouldn't they be generally independent failures? I do agree that if you have plenty of amps it is hard to find a compelling reason to use them. On the other hand - Tyco must see a market for automotive power saving. For the minimalist system with PM alternator I think the notion of using latching relays can be played with. Jan de Jong ________________________________________________________________________________
Date: Mar 13, 2011
Take a look at www.powerlet.com. They make receptacles for charging motorcycle batteries which could be adapted. Especially if, as Bob suggests, you mount them inside the cockpit. I don't think there are any 3 wire receptacles so you will have to use one for each battery or split the power feed. The nice thing is that you can get a receptacle with the 2 prong SAE connector that will plug into the harness from most battery tender type chargers. John Ciolino RV-8 N894Y From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Saturday, March 12, 2011 10:45 PM Subject: Re: AeroElectric-List: remote battery charging Dual batteries will be located in the aft fuselage for W & B issues...I want to be able to recharge the batteries by installing a (more or less) flush, weatherproof receptacle and plug in the side of the FG fuselage, one which would replace the alligator clips on the charger. I believe I erred in buying a "Piper type socket" and "Piper type plug" (Acft. Spruce p/n 11-00500 and p/n 11042) thinking they would serve, but have concluded that their purpose is for "jump starting" rather than battery recharging. (If this is in fact so, they'll be returned.) Soooooo...can anyone suggest a brand/type/model receptacle - plug combination suitable for battery charging? You CAN charge batteries through such connectors . . . as well as crank engines if that need arises. It depends on how you wire the connector to your airplane. If you have dual batteries, then getting the pair of batteries connected together for charging purposes poses a problem for needing to have contactors closed. So if the goal is battery charging/maintenance only, then about anything is fine. Take a look at trailer lighting connectors like . .. Emacs! Walmart automotive has some like this. You need three or more pins. One for ground and one to each battery through an inline fuse (can be a fuse on the battery bus). If you don't need to lock the canopy closed during charging ops, consider mounting the jack inside the airplane so you don't need to poke a hole in the skin. If the socket is inside, remove the spring loaded "lid". It's not needed and only gets in the way. I'm now looking at using (2) Odyssey #545s (14AH each) for a total weight of 23.4 pounds. I see that B & C lists a slightly more powerful (16AH) battery, a BC116-1 w/ weight of 14.6 pounds (each). I can't seem to find any performance specs . . . If you're doing the yearly change-out of the oldest battery, absolute performance is not significant. The two batteries in parallel (on less than two years old, the other less than one year old) are going to crank your engine just fine. Buy the cheapest batteries you can find that have connections which support cranking currents. Bob . . . ________________________________________________________________________________
From: Richard Reynolds <richardreynolds(at)cox.net>
Date: Mar 13, 2011
Fred, In the aviation electrical section at West Marine, look for: Marinco ConnectPro Trolling Motor Plug and Receptacle, model 1422591, $45. It is small, light and heavy duty. I put mine under the plane. I do not "jump start" the plane from this connection, but sometimes there is a heavy current 10-15 A when recharging a dead battery after the master switch has been left on. I used Bob's Z-31 design to protect the battery from reverse polarity and 24 V. Richard Reynolds Norfolk VA RV-6A - N841RV ________________________________________________________________________________
Date: Mar 13, 2011
Another option for using a conventional master contactor is to energize it at full voltage, then hold it at reduced voltage. I believe that Bob was working on a microprocessor based device that would do that. One could also make their own reduced voltage holding circuit using a resistor or diodes to drop the voltage along with a 3-position master switch: off, low voltage, and normal voltage. Or how about this IC along with a Power MOSFET? http://ww1.microchip.com/downloads/en/DeviceDoc/21448c.pdf I was going to use this IC to control the elevator trim servo. I think it would also work with the master contactor. It applies full voltage for a timed interval, then puts out a PWM voltage, for a price of $1.38. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=333732#333732 ________________________________________________________________________________
Date: Mar 13, 2011
On 3/12/2011 10:45 PM, Robert L. Nuckolls, III wrote: > If you don't need to lock > the canopy closed during charging ops, consider > mounting the jack inside the airplane so you don't > need to poke a hole in the skin. If the socket is > inside, remove the spring loaded "lid". It's not > needed and only gets in the way > > Bob . . . > I took this approach on my not-yet-flying RV10 with dual Odysseys. Used these "XLR" connectors: http://www.radioshack.com/product/index.jsp?productId=2104076# http://www.radioshack.com/product/index.jsp?productId=2103444&CAWELAID=107593419 With dual batteries and scheduled swap outs, I'm thinking charging should never become a regular or normal procedure. Therefore, no holes in the skin. I mounted the XLR connector on the rear baggage bulkhead, inches from the batts, and bypassed the contactors with inline fuses. The baggage door has to be opened to access the jack. My charger came with an inline plug so I can attach the regular alligator clamps or the XLR plug. Thanks Bob and the List for guiding me on this. Bill "all I talk about these days is paint" Watson ________________________________________________________________________________
Date: Mar 13, 2011
If you have a cigarette type power outlet in the cockpit, you can use one of these chargers for sale on eBay: https://lh6.googleusercontent.com/_9Rmupq9lpCs/TXzXScNgc-I/AAAAAAAAAKk/uPU9_yO6qpM/Charger.png WalMart sells a similar charger http://www.walmart.com/ip/Schumacher-SpeedCharge-Battery-Maintainer-and-Charger/13005742 but you will have to buy a separate cigarette lighter plug. Or you can put flush mounted anchor nuts or nutplates on the outside of the fuselage and use the ring terminals that come with the charger along with some screws. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=333736#333736 ________________________________________________________________________________
Date: Mar 13, 2011
At 05:59 AM 3/13/2011, you wrote: May I offer a thought in support of latching relays. How likely is it that the fault that causes smoke in the cockpit coincides with the failure of the relay to open? Wouldn't they be generally independent failures? Very low risk. I do agree that if you have plenty of amps it is hard to find a compelling reason to use them. On the other hand - Tyco must see a market for automotive power saving. I suspect that 'power saving' is way down on the list of design goals. Increased longevity due to low values of internally generated heat might be a big driver. The mechanically latched device is not going to aggravate the effects of a transient event. It wouldn't drop out and re-close during a severe brown-out . . . and the folks who brought these to market may not have considered either . . . For the minimalist system with PM alternator I think the notion of using latching relays can be played with. Absolutely. I should remind readers that my background calls for sifting the sands of risk for the purposes of keeping folks-who-know- more-about-airplanes-than-we-do happy. I'm not implying that regulatory mandates do not mesh well with elegant solutions. But they DO tend to discourage new solutions from emerging and evolving. Let's do our own sand-sifting. Bob . . . ________________________________________________________________________________
Subject: Remote Angle of Attack Indicator
Date: Mar 13, 2011
A few months ago, there was a lot of discussion on providing remote (glareshield) mounted AoA indicators. Vx Aviation had developed such a unit in 2006, but discontinued it after a few years due to lack of demand and high support costs. Things have changed. It looks like the average pilot appreciates AoA a lot more than they did 5 years ago. In addition, the original unit, which was only compatible with Dynon D10A/D100/D120 systems is also now supported by GRT Avionics, and both MGL and Garmin are looking into supporting it as well. Due to the customer demand and the support from the OEM's, I've reconsidered reintroducing the V-Speed ADS Remote AoA indicator. More information is available here: www.vx-aviation.com. If anyone is interested in this product, please contact me to put on the notification list. Alternatively, you can order right off of the website, however, we won't be shipping for a few weeks yet. Thanks, Vern Little Vx Aviation ________________________________________________________________________________
From: "Bill Bradburry" <bbradburry(at)bellsouth.net>
Subject: Radio Reception Problem
Date: Mar 14, 2011
I have a very noisy airplane particularly when in flight. I have the Garmin GNS430W and I am using an old Sigtronics headset. On the ground and taxiing, the radio works fine. When I am in the air, I start getting a lot of noise in the headset and I can hardly understand ATC. I think my sidetone goes away at this time as well. To be honest, it is so bad that I am not sure. Nothing I have tried with squelch has seemed to have any effect. I don't know where to start to try and resolve this issue. Can anyone suggest what I might do? Thanks, Bill B ________________________________________________________________________________
Date: Mar 14, 2011
Circuits like these do have their places but I don't think controlling the coil of a master solenoid is one of them. This sort of smells like a solution looking for a problem. Keep in mind that when you place more components in the critical path, the reliability of the system goes down - no matter how reliable those components are. In the case of master solenoids, (as Bob & others point out) they have proven to be pretty darn reliable. Therefore so I would be reluctant to "over-engineer" a solution to a problem that doesn't exist. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of user9253 Sent: Sunday, March 13, 2011 06:26 Subject: AeroElectric-List: Re: latching relays Another option for using a conventional master contactor is to energize it at full voltage, then hold it at reduced voltage. I believe that Bob was working on a microprocessor based device that would do that. One could also make their own reduced voltage holding circuit using a resistor or diodes to drop the voltage along with a 3-position master switch: off, low voltage, and normal voltage. Or how about this IC along with a Power MOSFET? http://ww1.microchip.com/downloads/en/DeviceDoc/21448c.pdf I was going to use this IC to control the elevator trim servo. I think it would also work with the master contactor. It applies full voltage for a timed interval, then puts out a PWM voltage, for a price of $1.38. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=333732#333732 ________________________________________________________________________________
Subject: Re: Need help in reviewing Z10/8 arch for dual Lightspeed
ign.
Date: Mar 15, 2011
Bob, Carlos and AEC list, I've revised my architecture diagram after absorbing the feedback. I agree I have no need for the brownout battery (Z10/8) architecture. Since the LSE Plasma III's are good for starting voltage down to 6.5V.... I no longer have a worry of starter kickback with my Skytec 149-12LS (PMG) starter. I switched back to a Z13/8 architecture as my base. I did include a very small (3 lb / 2.2Ah) battery to support my EFIS's, AHRS, and Engine Information System (EIS4000) to be ON prior to start. Again, my reasoning for this is that I want to be able to turn on EFIS 1/AHRS 1 and EFIS 2/AHRS 2 to start the AHRS alignment since that can take up to two minutes. I also want the EIS on for oil pressure during start. I'd like your feedback on this small AUX Battery circuit, since I wired the DC Power recharging feed from the Main Battery Bus direct. Is this a safe approach, or should I place a Diode in between Main BATT BUS, and the AUX BATT? If yes, what kind of diode? As a follow up to prior post reply questions: > Bob Knuckoll's question: > "Is their installation/operation data published on the net anywhere?" Here's the link to the GRT EFIS Installation Manual. http://www.grtavionics.com/File/Install%20Manuals/Horizon%20Install%20Rev%20A%20Feb%202009.pdf All of their documents are found here: http://www.grtavionics.com/default.aspx?id=4 Carlos also had a few questions: > "(a) on the LOW VOLT warning light circuit for the SD8 Alternator....is this wrong in your schematic?" I pulled that off the B&C Power Distribution Diagram for the SD8. I've attached it below. It shows the alternator warning light coming off the Normally Closed tab thru the light, and then to ground. Bob, did I wire this correctly for the SD8 Low Volt LED light in my architecture? Carlos asked: > b) Why did you connect the Fuel Primer pump to your "always hot" main battery bus?" I'm using the Van's Aircraft fuel priming system. Link here: http://www.vansaircraft.com/cgi-bin/catalog.cgi?ident=1300231865-498-318&browse=engines&product=eng-prime That circuit would be wired to the Parker Solenoid valve, via a 2-50:OFF-ON-(ON) progressive switch. With first click up PRIMER ON, and second click (Momentary) to give the engine a shot of primer. Should this be moved to a different bus? Wondering why you ask. Carlos asked: > c) In this "always hot" main battery bus, you have a connection (lower left) called Endurance Bus, which is connected to the COM terminal of the S704-1 relay....Would you explain this connection and this relay function?" When you hit the starter button, the S704-1 brownout relay is energized and isolates the BROWNOUT BATT from the MAIN BATT. My intention of using the brownout battery circuit was to isolate the brownout battery from the Main battery during engine start, such that the Endurance Bus received full volts to power my EFIS, EIS, and 2nd Plasma Ignition and NOT suffer a voltage drop due to the high initial current draw from the Skytec 149-12LS starter. But since I confirmed that my Plasma III Ignitions are good down to 6.5V, I took this circuit out. -------- I look forward to your next round of feedback and questions. Sorry for the long post....but this is helping me solidify my architecture big time! Thanks, Howard -------- Howard Plevyak GlaStar / North Bend, Ohio hplevyak(at)mac.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=334011#334011 Attachments: http://forums.matronics.com//files/power_distribution_diagram_for_model_sd8_alternator_146.pdf http://forums.matronics.com//files/printable_glastar_schematic_v0p2_15mar2011_for_review_391.pdf http://forums.matronics.com//files/glastar_schematic_v0p2_15mar2011_for_review_849.pdf http://forums.matronics.com//files/glastar_schematic_v0p2_15mar2011_for_review_148.jpg ________________________________________________________________________________
Date: Mar 16, 2011
Lightspeed ign. At 08:07 PM 3/15/2011, you wrote: I switched back to a Z13/8 architecture as my base. I did include a very small (3 lb / 2.2Ah) battery to support my EFIS's, AHRS, and Engine Information System (EIS4000) to be ON prior to start. Again, my reasoning for this is that I want to be able to turn on EFIS 1/AHRS 1 and EFIS 2/AHRS 2 to start the AHRS alignment since that can take up to two minutes. I also want the EIS on for oil pressure during start. I'd like your feedback on this small AUX Battery circuit, since I wired the DC Power recharging feed from the Main Battery Bus direct. Is this a safe approach, or should I place a Diode in between Main BATT BUS, and the AUX BATT? If yes, what kind of diode? If you're going to have a second battery, and particularly if it is small, you don't want it being 'hit' by starter draws. You might just as well wire it as a brown-out battery a per Z10-8 so that it's automatically unhooked from the main battery during cranking. As a follow up to prior post reply questions: Carlos also had a few questions: > "(a) on the LOW VOLT warning light circuit for the SD8 Alternator....is this wrong in your schematic?" Which drawing? Warning lights shown on any of my drawings become surplus if you've got lv warning built into other systems. I pulled that off the B&C Power Distribution Diagram for the SD8. I've attached it below. It shows the alternator warning light coming off the Normally Closed tab thru the light, and then to ground. Please don't mix/match features of multiple architecture sources. Let's pick one Z-figure and adjust as necessary to meet your needs. I'll suggest Z10-8 Bob, did I wire this correctly for the SD8 Low Volt LED light in my architecture? Do you need any more lights? Carlos asked: > b) Why did you connect the Fuel Primer pump to your "always hot" main battery bus?" I'm using the Van's Aircraft fuel priming system. Link here: http://www.vansaircraft.com/cgi-bin/catalog.cgi?ident=1300231865-498-318&browse=engines&product=eng-prime That circuit would be wired to the Parker Solenoid valve, via a 2-50:OFF-ON-(ON) progressive switch. With first click up PRIMER ON, and second click (Momentary) to give the engine a shot of primer. Should this be moved to a different bus? Wondering why you ask. Many moons ago, a couple of my readers installed 4-port primer systems and add a needle valve to their primer line such that flow to the engine was about the same during priming as it might be for 75% power. The idea was that the primer system could provide a po' boy's fuel injection system to back up the normal fuel delivery pathway to a carburetor. The topic came up again about 2006 when we talked about ways to eliminate fuel selector valves and their attendant risks for fuel leaks in the cockpit. Here, the 4-port primer/injector system and a suits of Facet pumps was proposed to eliminate all breaks in plumbing to install valves, provide for priming, and a second fuel delivery pathway. http://aeroelectric.com/Pictures/Misc/All-Elect-Fuel.jpg If your airplane is low wing and DEPENDS on a pump for engine operation, then it seems a prudent thing to have at least one ignition and required electric fuel delivery to run from a battery bus. This allows the electrical system to be configured for 'max cold' without killing the engine. But since I confirmed that my Plasma III Ignitions are good down to 6.5V, I took this circuit out. But you still have concerns for the avionics . . . so the brown-out battery is the cleanest way/ Bob . . . ________________________________________________________________________________
Date: Mar 16, 2011
> Circuits like these do have their places but I don't think controlling the coil of a master solenoid is one of them. > This sort of smells like a solution looking for a problem. Keep in mind that when you place more components in the critical path, the reliability of the system goes down - no matter how reliable those components are. > In the case of master solenoids, (as Bob & others point out) they have proven to be pretty darn reliable. Therefore so I would be reluctant to "over-engineer" a solution to a problem that doesn't exist. I agree with what you are saying except for the "critical path". There should always be a backup plan like an alternate feed path. A backup plan will turn a critical component into a non-critical one. I am not recommending reduced current to the master contactor for most installations. But it will be of benefit to systems that have limited generating power, or to prolong battery life when the alternator fails. A contactor coil operating at reduced voltage will generate less heat and thus be even more unlikely to fail. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=334067#334067 ________________________________________________________________________________
ign.
Date: Mar 16, 2011
Bob, Thanks for the quick reply. I'll make the tweaks. Regarding your question on the SD8 Low Volt Warning light.... > "Which drawing? Warning lights shown on any of my drawings become surplus if you've got lv warning built into other systems. The only other LOW VOLT light I have is on the L-60 circuit. Here's a clearer picture on my question regarding the SD8 Alternator LOW VOLT Warning light wiring. My goal here was that when running just on the SD8, I could use a low voltage warning for the SD-8 to indicate when the battery is actually carrying part of the load. At 2700 Prop RPM (SD8 @ 3500 RPM) I get 8.4 to 10.1 amps with high fuel consumption. Having the Low Volt light allows me to make the tradeoff in flight, depending on the distance to destination. I've sized my endurance bus to 3.7V....but if I wanted to keep some equipment on with the SD8 I'd like to be able to make that tradeoff to help get me down (assuming IFR, in the soup). So directly my question is....by swapping in the LED light on the highlighted circuit is it wired correctly? Since I couldn't find a Z-architecture that had this included, I used the B&C SD8 Power distribution diagram as reference on where to pull the light warning signal. Also can you please explain how the OVM-14 module works in tripping the light to come on....or point me to one of your articles that explains that better. I'm not clear on how this works. Thank-you, Howard -------- Howard Plevyak GlaStar / North Bend, Ohio hplevyak(at)mac.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=334084#334084 Attachments: http://forums.matronics.com//files/bandc_sd8_schematic_144.png http://forums.matronics.com//files/sd8_low_volt_circuit_844.png ________________________________________________________________________________
Date: Mar 16, 2011
WARNING - STANDBY FOR LEVEL 4 NIT-PICKING. IF YOUR'RE NOT REALLY INTO THIS, DO NOT WASTE YOUR TIME I'm gonna provide MY definitions for some of the terms we are throwing around (just 'cause it's a slow morning around here) Let's talk about Critical Path (CP 'cause I'm a lazy typist) and Redundant Circuitry (RC). Critical Path: The chain of components required to make a circuit operate as designed. Example: Circuit breaker -> switch -> contactor coil and the wiring that connects them. All those things are in the CP because if any one fails, the circuit stops working. [Let's add an LED in parallel w/ the coil (to give the operator a visual indication) - I would say that the LED is not in the CP] Every circuit has a CP. (regardless of other circuits that may be added for redundancy) If every circuit has a CP and adding components to the CP reduces reliability, we can still increase reliability by adding a Redundant Circuit. The RC still has its own CP, but the reliability of the SYSTEM goes up. ---------- I agree that reduced coil current may add to coil longevity but these devices have proven to be so reliable that I don't think it's worth the effort. -Jeff -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of user9253 Sent: Wednesday, March 16, 2011 06:08 Subject: AeroElectric-List: Re: latching relays > Circuits like these do have their places but I don't think controlling the coil of a master solenoid is one of them. > This sort of smells like a solution looking for a problem. Keep in mind that when you place more components in the critical path, the reliability of the system goes down - no matter how reliable those components are. > In the case of master solenoids, (as Bob & others point out) they have proven to be pretty darn reliable. Therefore so I would be reluctant to "over-engineer" a solution to a problem that doesn't exist. I agree with what you are saying except for the "critical path". There should always be a backup plan like an alternate feed path. A backup plan will turn a critical component into a non-critical one. I am not recommending reduced current to the master contactor for most installations. But it will be of benefit to systems that have limited generating power, or to prolong battery life when the alternator fails. A contactor coil operating at reduced voltage will generate less heat and thus be even more unlikely to fail. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=334067#334067 ________________________________________________________________________________
Subject: Bob Nuckolls - advice
Date: Mar 16, 2011
Bob, I realise I should test for myself, but thought it might apply to others: I am using a DB25 female and male pair for quick disconnect to accommodate up to #18 wire runs for future circuits in my instrument panel. [The whole panel OR each sub-panel is meant to be dismountable]. Since it will hold up to 12 + and - runs, I measured the male pins at 0.04 inches in diameter from the pack of 100, labelled as `S604P'. These are solid, not stamped pins and sockets. Can I consider these to carry a constant 4 amps if not bundled tightly together? AND could I parallel a set of three to carry a constant 10A in similar circumstances? I would like to know I'm operating in a`conservative' milieu and don't plan to run cfuture equipment at greater than 10A. Cheers, Ferg ________________________________________________________________________________
Subject: Bob nuckolls - advice 2
Date: Mar 16, 2011
Further to my previous: A measured pin diameter is 0.04 inches, radius is 0.02", area is (0.02x0.02)xpi = 0.00125663 sq.in. x 645.16 = 0.8107319 sq.mm. This comes out between AWG20 and AWG18 - call it AWG #19. That would infer that the pin carries about 6-7 amps, having regard for irregular measuring, improper meshing of pin/socket, differing metals, temp, bundling etc. Am I in the ball park? ferg ________________________________________________________________________________
Subject: Transient_voltage_suppression_diode failure
Date: Mar 16, 2011
3/16/2011 Hello Fellow Aeroelectric Listers, You may be interested in the attachment and the below information: http://en.wikipedia.org/wiki/Transient_voltage_suppression_diode 'OC' Baker Says: "The best investment we can make is the time and effort to gather and understand knowledge." ________________________________________________________________________________
Date: Mar 16, 2011
Lightspeed ign. At 11:40 AM 3/16/2011, you wrote: > >Bob, >Thanks for the quick reply. I'll make the tweaks. > >Regarding your question on the SD8 Low Volt Warning light.... > > > "Which drawing? Warning lights shown on any of my drawings become > surplus if you've got lv warning built into other systems. > >The only other LOW VOLT light I have is on the L-60 circuit. > >Here's a clearer picture on my question regarding the SD8 Alternator >LOW VOLT Warning light wiring. My goal here was that when running >just on the SD8, I could use a low voltage warning for the SD-8 to >indicate when the battery is actually carrying part of the load. At >2700 Prop RPM (SD8 @ 3500 RPM) I get 8.4 to 10.1 amps with high >fuel consumption. Having the Low Volt light allows me to make the >tradeoff in flight, depending on the distance to destination. These are NOT the kinds of things you want to be doing in flight. When the big guy wanders off into the weeds, then you should have a Plan-B for the little guy's task. When A fails then B and continue flight to airport of intended destination. You don't need a light to tell you anything that is pre-ordained by planing. >I've sized my endurance bus to 3.7V....but if I wanted to keep some >equipment on with the SD8 I'd like to be able to make that tradeoff >to help get me down (assuming IFR, in the soup). You won't find a pilot's operating handbook anywhere that has the crew flipping switches, taking measurements, and crafting new plans based on real-time judgement calls as an in-flight activity. When the main alternator fails, craft a plan, test the plan, exercise the plan as necessary, fly the airplane . . . >So directly my question is....by swapping in the LED light on the >highlighted circuit is it wired correctly? That's not a "LOW VOLTS" warning light, it's an "ALT OFF" annunciator. >Since I couldn't find a Z-architecture that had this included, I >used the B&C SD8 Power distribution diagram as reference on where to >pull the light warning signal. Ditch that light. I was under the impression that you had some form of Low Volts warning in one or more of your panel mounted accessories. If not, then you need some independent, timely, and insistent notification like our 9005 DIY project or Eric's LV warning light module. >Also can you please explain how the OVM-14 module works in tripping >the light to come on....or point me to one of your articles that >explains that better. I'm not clear on how this works. See: Chapter 6 in the 'Connection. Bob . . . ________________________________________________________________________________
Subject: Re: Power for Checking Systems Out on the Ground
Date: Mar 16, 2011
I tried to order one of these power supplies, but the vendor in the example was not willing to ship to North America. I found what appears to be the same product, from anna758595 for $40 which included shipment by mail. I received the product in three weeks, nicely packaged. It is a little smaller than I imagined from the photos, which is nice. I haven't powered it on yet, but I expect it works as advertised. I ended up buying the 13.5V unit, since it can be adjusted upward to simulate battery charging voltage, or down to 12V if I wish. The adjustment is easily accessed without opening the case, tucked in with the terminal strip. Looks like a pretty decent product at a very attractive price. http://cgi.ebay.ca/13-5V-DC-25-8A-350W-Regulated-Switching-Power-Supply-/150471439243?pt=LH_DefaultDomain_0&hash=item2308cbf38b Jeff Page Dream Aircraft Tundra #10 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=334140#334140 ________________________________________________________________________________
Date: Mar 16, 2011
>If every circuit has a CP and adding components to the CP reduces >reliability, we can still increase reliability by adding a Redundant >Circuit. The RC still has its own CP, but the reliability of the SYSTEM >goes up. Generally speaking, the adjective "critical" is reserved for conditions that have a potential for (1) single points of failure in (2) systems needed for comfortable termination of flight where (3) no effort has been made craft a failure tolerant system. When failure tolerance has been achieved, no single failure is "critical". In little airplanes maintained by the competent observer/owner/operator, probability of two potentially critical failures in any single flight cycle (typically 4 hours max) is vanishingly small. Once a degree of failure tolerance is achieved, the system integrator can begin to massage cost/performance and parts reduction issues. The successful program starts with design goals. Goals that add/upgrade performance features (A-N versus VOR versus TACAN versus GPS). To reduce cost (less expensive parts with perhaps shorter service lives are attractive). No doubt there are other goals. When I was heavily involved in new products design and certification at Electro-Mech, one could look forward to a pretty steady stream of hopeful sales folks with a new electro-whizzy to show off. Some were really amazing advances of the state of the art . . . and would be considered for a new design. But the $time$ required to modify and old design made it unlikely that anything new gets a field retrofit. In 40+ years, I've only worked three programs that produced a fleet wide change-out of hardware and two of those were under safety of flight duress. Even when I could tell the bright-eyed salesman that he had a really nifty product, I had to remind him that we'd beat him up on price, delivery, cert documentation, and maybe . . . just maybe we'd bless him with an order for 1000 parts spread out over 10 years. Of course, that order would get perpetually modified/canceled as our line rates moved up and down with the stock market. Aviation is one of the most demanding customers yet the numbers of airplanes built every year makes them a ho-hum target for the electro- whizzy guys. Now, if you're selling rivets or aluminum . . . Okay, you've got this nifty latching contactor. I think it's fairly obvious how it might be used in our airplanes. The questions to be asked and answered are (1) does this product 'fix' some nuisance of maintenance, costs or sense of less-than-elegant functionality? Since (repeat after me) we DESIGN, CRAFT AND MAINTAIN FAILURE TOLERANT SYSTEMS, reliability and criticality are not part of the considerations. Only cost of ownership and reasonably seamless integration into the-best-we-know-how-to-do-today are the go/no-go drivers. Bob . . . ________________________________________________________________________________
Date: Mar 16, 2011
Subject: Re: Bob Nuckolls - advice
At 04:16 PM 3/16/2011, you wrote: >Bob, > > I realise I should test for myself, but > thought it might apply to others: > > I am using a DB25 female and male pair for > quick disconnect to accommodate up to #18 wire > runs for future circuits in my instrument > panel. [The whole panel OR each sub-panel is meant to be dismountable]. > > Since it will hold up to 12 + and ' runs, I > measured the male pins at 0.04 inches in > diameter from the pack of 100, labelled as > `S604P=92. These are solid, not stamped pins and sockets. > > Can I consider these to carry a constant 4 > amps if not bundled tightly together? AND could > I parallel a set of three to carry a constant 10A in similar circumstances? > > I would like to know I=92m operating in > a`conservative=92 milieu and don=92t plan to run > cfuture equipment at greater than 10A. That works. When I qualified paralleled d-sub pins onto this vehicle http://aeroelectric.com/Pictures/Misc/GQM_1st_Ops_Flight.jpg I had to suffer the indignities of 70C environment at full electrical loads. I de-rated the pins to 3A, paralleled 6 pins and handled three 20A input output pathways on this solid state relay box. http://aeroelectric.com/Pictures/Misc/GQM_Power_Dist.jpg So your suggestion of 3 pins to handle 10A is as conservative that which flies at Mach 3 and 15 feet off the water. Things get really warm on the launch stand . . . and warmer still in flight through dense air. Just keep your airplane below M3 and I think you'll be just fine. I presume you understand the necessity for 'ballasting' resistors in the form of 12" of 22AWG in each pin path? Bob . . . ________________________________________________________________________________
Date: Mar 16, 2011
Subject: Re: Bob nuckolls - advice 2
At 05:33 PM 3/16/2011, you wrote: >Further to my previous: > >A measured pin diameter is 0.04 inches, radius >is 0.02=94, area is (0.02x0.02)xpi = 0.00125663 >sq.in. x 645.16 = 0.8107319 sq.mm. > >This comes out between AWG20 and AWG18 ' call it AWG #19. The pin diameter isn't much of a driver. It's localized heating at the pin-spring interface inside the female pin. 3A de-rating will give you VERY comfortable performance. Bob . . . ________________________________________________________________________________
Date: Mar 16, 2011
Subject: Re: Transient_voltage_suppression_diode failure
At 06:44 PM 3/16/2011, you wrote: >3/16/2011 > >Hello Fellow Aeroelectric Listers, You may be interested in the >attachment and the below information: Interesting. I had a chance to review some power distribution diagrams for Cirrus products several years ago . . . it was about the time they were incorporating the SD-20 alternator into one or more models. Many of their architecture decisions were, shall we say, novel? It would be interesting to see the details of the service bulletin . . . the wording in the notice sounds like they 'sprinkled' transorbs around the system with some notion that it was a good thing to do. Any of you who have been on the List for 13 years or so will remember some discussions about transorbs. Several of our members were proponents of transorb "sprinkling" . . . but without having a terribly good notion of how these critters are rated and how they behave. http://www.aeroelectric.com/articles/spike.pdf There's another transorb issue that popped up a few years ago. It was centered on this critter: http://www.aeroelectric.com/Mfgr_Data/Semiconductors/704-15k36t.pdf Seems that somebody got the cool idea that you could PARALLEL numerous smaller devices and come up with an array good for soaking up lots of energy. This sorta works and a few manufacturers managed to qualify devices to this spec. But process control for having tightly matched devices to parallel was critical. I think Mooney had some of these critters "sprinkled" in their airplanes and suffered some smokey events. I discovered that situation when a hopeful supplier to Hawker-Beech proposed a new starter-generator controller- regulator. The thing had TWO of those monster transorbs paralleled in the box. Seems that lightning issues in composite airplanes drove the DO-160 qualification stresses out to the moon. Some of you may recall that I sketched a circuit for adding a transorb to the main bus of an airplane with the goal of standing off all evils. http://aeroelectric.com/Pictures/Schematics/SpikeTrap.gif The idea was that if something evil came along, the transorb would catch it . . . that's what transorbs do. But if it were so severe as to trigger transorbicide (transorbs do that too), then the fuse would blow and you would get an indicator light. In any case, transorbs are quite helpful for getting a black box to pass DO-160 + lightning tests. But as soon as you see these critters scattered around an airplane's electrical system, well . . . 'nuf said. What was it somebody said about latching contactors . . . "a solution looking for a problem?" Bob . . . Bob . . . ________________________________________________________________________________
Date: Mar 16, 2011
Subject: Z-12 and Plasma II ignition
I am building an RV-9A per Z-12 outline. The plane has one elctronic ignition on the right going to the top cylinders and one Slick magneto on the Left side. The manufacturer of the electronic ignition insists that the rather thin electrical wire (shelded cable) be attached directly to the battery. I am questioning the advisability of this unless a fuse or CB placed at the battery. Uncomfotable with this hot wire entering the fuselage and being seperated from the battery bus. If the fuse is on the engine side I feel less in control to replace the fuse or reset the CB. Could not find any references on the this website. Would appreciate your thoughts on this matter. ________________________________________________________________________________
Date: Mar 17, 2011
>I ended up buying the 13.5V unit, since it can be adjusted upward to >simulate battery charging voltage, or down to 12V if I wish. The >adjustment is easily accessed without opening the case, tucked in >with the terminal strip. Looks like a pretty decent product at a >very attractive price. > >http://cgi.ebay.ca/13-5V-DC-25-8A-350W-Regulated-Switching-Power-Supply-/150471439243?pt=LH_DefaultDomain_0&hash=item2308cbf38b I used about a half dozen of various models in projects over the last two years. Got two of them on the bench right now. Just be careful when hooking these guys across batteries. Some of these products don't like to be reverse powered when their ac input power is removed. I use a fat schottky in series with the output to prevent tug-o-war issues. This means you might want to order the next higher voltage next time . . . but there's one resistor you can change inside that will boost the output if necessary. Bob . . . ________________________________________________________________________________
Date: Mar 17, 2011
Subject: Current draw for lighting Buss
Hi all, I am wiring my panel. It includes a PMA 8000 audio panel, SL30, Garmin 430W and 327 transponder. Each has a pin to control the brightness on a separate lighting buss. I was going to use B&C's dimmer circuit. What I can't seem to find is what the current draw for lighting is likely to be. The specific question is, which B&C dimmer do I need. Anyone know the answer? Regards, Michael Wynn RV 8 Wiring San Ramon, CA ________________________________________________________________________________
Date: Mar 17, 2011
Subject: Re: Current draw for lighting Buss
I'd like to piggy back on this question by asking how people have set these 3 units up for dimming? I have a Perihelion dimmer in place but no plan for applying it to these 3 units. I just couldn't figure out what to do. Bill "praying to the spring gods of warm painting weather" Watson > Hi all, > I am wiring my panel. It includes a PMA 8000 audio panel, SL30, > Garmin 430W and 327 transponder. Each has a pin to control the > brightness on a separate lighting buss. I was going to use B&C's > dimmer circuit. What I can't seem to find is what the current draw > for lighting is likely to be. The specific question is, which B&C > dimmer do I need. > Anyone know the answer? > Regards, > Michael Wynn > RV 8 Wiring > San Ramon, CA > ________________________________________________________________________________
Date: Mar 17, 2011
Aren't all or most of those auto-dimming? I think you should verify that fe ature and only manual dim the ones that can't. Most things can. Tim On Mar 17, 2011, at 6:37 AM, Bill Watson wrote: > I'd like to piggy back on this question by asking how people have set thes e 3 units up for dimming? I have a Perihelion dimmer in place but no plan f or applying it to these 3 units. I just couldn't figure out what to do. > > Bill "praying to the spring gods of warm painting weather" Watson > >> Hi all, >> >> I am wiring my panel. It includes a PMA 8000 audio panel, SL30, Garmin 4 30W and 327 transponder. Each has a pin to control the brightness on a sepa rate lighting buss. I was going to use B&C's dimmer circuit. What I can't s eem to find is what the current draw for lighting is likely to be. The spec ific question is, which B&C dimmer do I need. >> >> Anyone know the answer? >> >> Regards, >> >> Michael Wynn >> RV 8 Wiring >> San Ramon, CA >> > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Mar 17, 2011
That's what I was sort of thinking but didn't finish the investigation. Autodimming is good and I won't mind have an unused dimmer. Right now, I'm just dimming my Honeywell lit rockers and indicators. I assume that for autodimming, no physical installation action is required? Just turn it on (configure it) and it figures out what to do. > Aren't all or most of those auto-dimming? I think you should verify > that feature and only manual dim the ones that can't. > Most things can. > Tim > > > On Mar 17, 2011, at 6:37 AM, Bill Watson > wrote: > >> I'd like to piggy back on this question by asking how people have set >> these 3 units up for dimming? I have a Perihelion dimmer in place >> but no plan for applying it to these 3 units. I just couldn't figure >> out what to do. >> >> Bill "praying to the spring gods of warm painting weather" Watson >> >>> Hi all, >>> I am wiring my panel. It includes a PMA 8000 audio panel, SL30, >>> Garmin 430W and 327 transponder. Each has a pin to control the >>> brightness on a separate lighting buss. I was going to use B&C's >>> dimmer circuit. What I can't seem to find is what the current draw >>> for lighting is likely to be. The specific question is, which B&C >>> dimmer do I need. >>> Anyone know the answer? >>> ________________________________________________________________________________
Date: Mar 17, 2011
At 01:58 AM 3/17/2011, you wrote: >Hi all, > >I am wiring my panel. It includes a PMA 8000 audio panel, SL30, >Garmin 430W and 327 transponder. Each has a pin to control the >brightness on a separate lighting buss. I was going to use B&C's >dimmer circuit. What I can't seem to find is what the current draw >for lighting is likely to be. The specific question is, which B&C >dimmer do I need. > >Anyone know the answer? In days of yore, the dimmer input line to a panel mounted accessory was a direct power supply to incandescent lamps scattered about the panel of the accessory. The dimmer input did indeed have a small but significant POWER requirement. It was this lighting philosophy that gave rise to dimmer products designed to handle power . . . the largest of the B&C dimmers would handle a panel full of post lights and a center stack stuffed with radios. The 1960 Cessna 310 had two (count 'em) TWO fat rheostats on the center console for panel dimming. Under some lighting conditions these were so hot that you could not touch the panel around the knob that controlled the rheostat. Modern lighting technologies are all over the map. Florescent, electro-luminescent, LED, gas discharge, etc . . . To further complicate matters, they do not all share the same dimming curves (apparent brightness versus applied voltage). The transition to mixed technology illumination was well under way by the 80's. I wrote a specification for the Gates-Piaggio 180 for a 3 channel dimmer controlled by one knob but with independently adjustable dimming curves to accommodate a variety of technologies. The installation manual for each of these accessories should call out the current draw for the dimmer controls. It may well be that these control pins do not supply power to the lighting components but only send a signal to the internal power supply that services those components. In this case, the control current may be measured in a handful of milliamps. Further, the dimming characteristics may be tailored to the legacy incandescent curve. Long non-answer. The short answer is you'll have to research the installation data that should be included in documents supplied with the accessories. It's a SURE bet that dimmer inputs of any stripe will not be damaged by a linearly variable dimmer control input. It probably won't be damaged by duty-cycle switched dimmers but the switching frequency of the duty-cycle dimmer might produce strange behaviors of the dimming function. You should check this out with the manufacture's field services folks or some knowledgeable installer. Has anyone on the List resolved these questions? Bob . . . ________________________________________________________________________________
Date: Mar 17, 2011
As for autodimming, yes they all do this. A friend with a 430 tells me that it autodims so dim that he can't see it. He goes through the menu to adjust the brightness manually every time he flies at night. Seemed like during construction was the best time to address the issue. Regards, Michael Wynn RV 8 Wiring San Ramon, CA In a message dated 3/17/2011 7:43:14 A.M. Pacific Daylight Time, Mauledriver(at)nc.rr.com writes: That's what I was sort of thinking but didn't finish the investigation. Autodimming is good and I won't mind have an unused dimmer. Right now, I'm just dimming my Honeywell lit rockers and indicators. I assume that for autodimming, no physical installation action is required? Just turn it on (configure it) and it figures out what to do. Aren't all or most of those auto-dimming? I think you should verify that feature and only manual dim the ones that can't. Most things can. Tim On Mar 17, 2011, at 6:37 AM, Bill Watson <_Mauledriver(at)nc.rr.com_ (mailto:Mauledriver(at)nc.rr.com) > wrote: I'd like to piggy back on this question by asking how people have set these 3 units up for dimming? I have a Perihelion dimmer in place but no plan for applying it to these 3 units. I just couldn't figure out what to do. Bill "praying to the spring gods of warm painting weather" Watson Hi all, I am wiring my panel. It includes a PMA 8000 audio panel, SL30, Garmin 430W and 327 transponder. Each has a pin to control the brightness on a separate lighting buss. I was going to use B&C's dimmer circuit. What I can't seem to find is what the current draw for lighting is likely to be. The specific question is, which B&C dimmer do I need. Anyone know the answer? (http://www.matronics.com/Navigator?AeroElectric-List) (http://www.matronics.com/contribution) ________________________________________________________________________________
Date: Mar 17, 2011
>> http://cgi.ebay.ca/13-5V-DC-25-8A-350W-Regulated-Switching-Power-Supply-/150471439243?pt=LH_DefaultDomain_0&hash=item2308cbf38b > > I used about a half dozen of various models in projects > over the last two years. Got two of them on the bench right > now. Just be careful when hooking these guys across batteries. > Some of these products don't like to be reverse powered when > their ac input power is removed. I use a fat schottky in > series with the output to prevent tug-o-war issues. This > means you might want to order the next higher voltage > next time . . . but there's one resistor you can change > inside that will boost the output if necessary. I don't plan on connecting it in parallel with a battery, but this is an important point. I stuck a label on the power supply to remind me, in case I get different ideas a few years from now. Thanks. Jeff Page Dream Aircraft Tundra #10 ________________________________________________________________________________
From: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net>
Subject: Wiring Lightspeed Plasma II
Date: Mar 17, 2011
Klaus wants the hot wire to go to the battery directly in order to minimize voltage sag at the brain box during starting. I have a Lightspeed Plasma II+ that I originally intended to activate with the aircraft's key switch (along with the single slick magneto that I have on the left side firing the bottom plugs). Note that the Plasma II+ (and III+) have two separate wires that work with the key switch made for airplane magnetos. You can't wire a Plasma II into a standard aircraft (magneto grounding) key switch, it doesn't have these extra wires. After I read about some failures of the standard aircraft key switch I gave it some more thought and decided to eliminate the key switch as a single point failure (why lose both ignition systems with the failure of one switch). I decided to leave the magneto on the key switch and wire the Lightspeed to one of the terminals of the bussman six-fuse-block that serves as my battery bus. The fuse block is behind the instrument panel and its common terminal is connected to the Odyssey battery (on the engine side of the firewall) through a 14 gauge wire and a 20 amp klixon breaker (in a box on the firewall next to the battery to protect the 14 gauge wire). The Lightspeed shielded wire goes from the battery bus fuse block to a "BAT" switch (a toggle switch whose stem has to be pulled out of machined notches in the case in order to turn it on or off) and from the BAT switch to the Lightspeed brain box behind the instrument panel (the brain box ground is connect to a forest of faston tabs on the firewall). So yes, I did wire it to the battery but, the signal path goes from the battery through the CB on the firewall, the 14 GA tefzel wire (unshielded), the fuse block, the BAT switch and finally to the brain box!!! Bottom line....2.5 years of flying bliss, the setup works fine and I've had no problems whatsoever. I start the engine using the key switch (impulse coupled magneto only). Once the engine is running I turn on the Lightspeed. It works great with no kickback and, I can still turn the electronic ignition off during the run-up to see how the magneto and bottom plugs are working. I've also started using the Lightspeed only and had no trouble. Like many of these things that we builders tend to fret over, this is one that you should not worry about, different wiring schemes are not a big deal. Wire it in and get that bird flying. Dean Psiropoulos RV-6A N197DM 2.5 years of flying fun -------------------Original Message------------------- From: fedico94(at)mchsi.com Subject: AeroElectric-List: Z-12 and Plasma II ignition I am building an RV-9A per Z-12 outline. The plane has one elctronic ignition on the right going to the top cylinders and one Slick magneto on the Left side. The manufacturer of the electronic ignition insists that the rather thin electrical wire (shelded cable) be attached directly to the battery. I am questioning the advisability of this unless a fuse or CB placed at the battery. Uncomfotable with this hot wire entering the fuselage and being seperated from the battery bus. If the fuse is on the engine side I feel less in control to replace the fuse or reset the CB. Could not find any references on the this website. Would appreciate your thoughts on this matter. ________________________________________________________________________________
Date: Mar 17, 2011
Subject: Re: Wiring Lightspeed Plasma II
There is one other thing to think about before you go changing the way Klaus has the wiring diagram laid out. As was mentioned in a thread a while back, the Lightspeed box has a built in crowbar to protect itself from an overvoltage event. That's why the wiring diagram shows a pullable breaker as the only circuit protection device. If the internal crowbar decides to unload on the system, the breaker pops and can be reset after the errant alternator is offline. If there is a fuse in the circuit, it will blow before the breaker does and you're SOL in terms of getting the ignition running again until the fuse can be replaced. If this one thin un-fused wire were to short to the airframe before the breaker, it would likely burn right through and become un-shorted. In the meantime, you'd be out one ignition. Best to be very careful in routing and securing this wire and after that - don't worry about it. Inspect it at annual and keep flying. There was a case where some guy put 2 lightspeeds into a lancair and wired them, as I understand it, through fuses which blew and caused a forced landing. Think twice about failure modes before changing manufacturers' wiring diagrams. Once you think it through, then wire it as you see fit, but be sure you know why you made any changes. Pax, Ed Holyoke On 3/17/2011 7:52 PM, DEAN PSIROPOULOS wrote: > --> AeroElectric-List message posted by: "DEAN PSIROPOULOS" > > > Klaus wants the hot wire to go to the battery directly in order to minimize > voltage sag at the brain box during starting. I have a Lightspeed Plasma > II+ that I originally intended to activate with the aircraft's key switch > (along with the single slick magneto that I have on the left side firing the > bottom plugs). Note that the Plasma II+ (and III+) have two separate wires > that work with the key switch made for airplane magnetos. You can't wire a > Plasma II into a standard aircraft (magneto grounding) key switch, it > doesn't have these extra wires. After I read about some failures of the > standard aircraft key switch I gave it some more thought and decided to > eliminate the key switch as a single point failure (why lose both ignition > systems with the failure of one switch). > > I decided to leave the magneto on the key switch and wire the Lightspeed to > one of the terminals of the bussman six-fuse-block that serves as my battery > bus. The fuse block is behind the instrument panel and its common terminal > is connected to the Odyssey battery (on the engine side of the firewall) > through a 14 gauge wire and a 20 amp klixon breaker (in a box on the > firewall next to the battery to protect the 14 gauge wire). The Lightspeed > shielded wire goes from the battery bus fuse block to a "BAT" switch (a > toggle switch whose stem has to be pulled out of machined notches in the > case in order to turn it on or off) and from the BAT switch to the > Lightspeed brain box behind the instrument panel (the brain box ground is > connect to a forest of faston tabs on the firewall). > > So yes, I did wire it to the battery but, the signal path goes from the > battery through the CB on the firewall, the 14 GA tefzel wire (unshielded), > the fuse block, the BAT switch and finally to the brain box!!! > > Bottom line....2.5 years of flying bliss, the setup works fine and I've had > no problems whatsoever. I start the engine using the key switch (impulse > coupled magneto only). Once the engine is running I turn on the Lightspeed. > It works great with no kickback and, I can still turn the electronic > ignition off during the run-up to see how the magneto and bottom plugs are > working. I've also started using the Lightspeed only and had no trouble. > > Like many of these things that we builders tend to fret over, this is one > that you should not worry about, different wiring schemes are not a big > deal. Wire it in and get that bird flying. > > Dean Psiropoulos > RV-6A N197DM > 2.5 years of flying fun > > > -------------------Original Message------------------- > > From: fedico94(at)mchsi.com > Subject: AeroElectric-List: Z-12 and Plasma II ignition > > > I am building an RV-9A per Z-12 outline. The plane has one elctronic > ignition on the right going to the top cylinders and one Slick magneto on > the Left side. > > The manufacturer of the electronic ignition insists that the rather thin > electrical wire (shelded cable) be attached directly to the battery. I am > questioning the advisability of this unless a fuse or CB placed at the > battery. Uncomfotable with this hot wire entering the fuselage and being > seperated from the battery bus. If the fuse is on the engine side I feel > less in control to replace the fuse or reset the CB. Could not find any > references on the this website. Would appreciate your thoughts on this > matter. > > ________________________________________________________________________________
Date: Mar 17, 2011
Thank you for your thoughts. So many details with the instrument panel. ----- Original Message ----- From: DEAN PSIROPOULOS <dean.psiropoulos(at)verizon.net> Subject: AeroElectric-List: Wiring Lightspeed Plasma II Klaus wants the hot wire to go to the battery directly in order to minimize voltage sag at the brain box during starting. I have a Lightspeed Plasma II+ that I originally intended to activate with the aircraft's key switch (along with the single slick magneto that I have on the left side firing the bottom plugs). Note that the Plasma II+ (and III+) have two separate wires that work with the key switch made for airplane magnetos. You can't wire a Plasma II into a standard aircraft (magneto grounding) key switch, it doesn't have these extra wires. After I read about some failures of the standard aircraft key switch I gave it some more thought and decided to eliminate the key switch as a single point failure (why lose both ignition systems with the failure of one switch). I decided to leave the magneto on the key switch and wire the Lightspeed to one of the terminals of the bussman six-fuse-block that serves as my battery bus. The fuse block is behind the instrument panel and its common terminal is connected to the Odyssey battery (on the engine side of the firewall) through a 14 gauge wire and a 20 amp klixon breaker (in a box on the firewall next to the battery to protect the 14 gauge wire). The Lightspeed shielded wire goes from the battery bus fuse block to a "BAT" switch (a toggle switch whose stem has to be pulled out of machined notches in the case in order to turn it on or off) and from the BAT switch to the Lightspeed brain box behind the instrument panel (the brain box ground is connect to a forest of faston tabs on the firewall). So yes, I did wire it to the battery but, the signal path goes from the battery through the CB on the firewall, the 14 GA tefzel wire (unshielded), the fuse block, the BAT switch and finally to the brain box!!! Bottom line....2.5 years of flying bliss, the setup works fine and I've had no problems whatsoever. I start the engine using the key switch (impulse coupled magneto only). Once the engine is running I turn on the Lightspeed. It works great with no kickback and, I can still turn the electronic ignition off during the run-up to see how the magneto and bottom plugs are working. I've also started using the Lightspeed only and had no trouble. Like many of these things that we builders tend to fret over, this is one that you should not worry about, different wiring schemes are not a big deal. Wire it in and get that bird flying. Dean Psiropoulos RV-6A N197DM 2.5 years of flying fun -------------------Original Message------------------- From: fedico94(at)mchsi.com Subject: AeroElectric-List: Z-12 and Plasma II ignition I am building an RV-9A per Z-12 outline. The plane has one elctronic ignition on the right going to the top cylinders and one Slick magneto on the Left side. The manufacturer of the electronic ignition insists that the rather thin electrical wire (shelded cable) be attached directly to the battery. I am questioning the advisability of this unless a fuse or CB placed at the battery. Uncomfotable with this hot wire entering the fuselage and being seperated from the battery bus. If the fuse is on the engine side I feel less in control to replace the fuse or reset the CB. Could not find any references on the this website. Would appreciate your thoughts on this matter. ________________________________________________________________________________
Date: Mar 17, 2011
Thank you for your insight. I enjoyed reading your email and found it to be a big help ----- Original Message ----- From: Ed Holyoke <bicyclop(at)pacbell.net> Subject: Re: AeroElectric-List: Wiring Lightspeed Plasma II There is one other thing to think about before you go changing the way Klaus has the wiring diagram laid out. As was mentioned in a thread a while back, the Lightspeed box has a built in crowbar to protect itself from an overvoltage event. That's why the wiring diagram shows a pullable breaker as the only circuit protection device. If the internal crowbar decides to unload on the system, the breaker pops and can be reset after the errant alternator is offline. If there is a fuse in the circuit, it will blow before the breaker does and you're SOL in terms of getting the ignition running again until the fuse can be replaced. If this one thin un-fused wire were to short to the airframe before the breaker, it would likely burn right through and become un-shorted. In the meantime, you'd be out one ignition. Best to be very careful in routing and securing this wire and after that - don't worry about it. Inspect it at annual and keep flying. There was a case where some guy put 2 lightspeeds into a lancair and wired them, as I understand it, through fuses which blew and caused a forced landing. Think twice about failure modes before changing manufacturers' wiring diagrams. Once you think it through, then wire it as you see fit, but be sure you know why you made any changes. Pax, Ed Holyoke On 3/17/2011 7:52 PM, DEAN PSIROPOULOS wrote: > --> AeroElectric-List message posted by: "DEAN PSIROPOULOS" > > > Klaus wants the hot wire to go to the battery directly in order to minimize > voltage sag at the brain box during starting. I have a Lightspeed Plasma > II+ that I originally intended to activate with the aircraft's key switch > (along with the single slick magneto that I have on the left side firing the > bottom plugs). Note that the Plasma II+ (and III+) have two separate wires > that work with the key switch made for airplane magnetos. You can't wire a > Plasma II into a standard aircraft (magneto grounding) key switch, it > doesn't have these extra wires. After I read about some failures of the > standard aircraft key switch I gave it some more thought and decided to > eliminate the key switch as a single point failure (why lose both ignition > systems with the failure of one switch). > > I decided to leave the magneto on the key switch and wire the Lightspeed to > one of the terminals of the bussman six-fuse-block that serves as my battery > bus. The fuse block is behind the instrument panel and its common terminal > is connected to the Odyssey battery (on the engine side of the firewall) > through a 14 gauge wire and a 20 amp klixon breaker (in a box on the > firewall next to the battery to protect the 14 gauge wire). The Lightspeed > shielded wire goes from the battery bus fuse block to a "BAT" switch (a > toggle switch whose stem has to be pulled out of machined notches in the > case in order to turn it on or off) and from the BAT switch to the > Lightspeed brain box behind the instrument panel (the brain box ground is > connect to a forest of faston tabs on the firewall). > > So yes, I did wire it to the battery but, the signal path goes from the > battery through the CB on the firewall, the 14 GA tefzel wire (unshielded), > the fuse block, the BAT switch and finally to the brain box!!! > > Bottom line....2.5 years of flying bliss, the setup works fine and I've had > no problems whatsoever. I start the engine using the key switch (impulse > coupled magneto only). Once the engine is running I turn on the Lightspeed. > It works great with no kickback and, I can still turn the electronic > ignition off during the run-up to see how the magneto and bottom plugs are > working. I've also started using the Lightspeed only and had no trouble. > > Like many of these things that we builders tend to fret over, this is one > that you should not worry about, different wiring schemes are not a big > deal. Wire it in and get that bird flying. > > Dean Psiropoulos > RV-6A N197DM > 2.5 years of flying fun > > > -------------------Original Message------------------- > > From: fedico94(at)mchsi.com > Subject: AeroElectric-List: Z-12 and Plasma II ignition > > > I am building an RV-9A per Z-12 outline. The plane has one elctronic > ignition on the right going to the top cylinders and one Slick magneto on > the Left side. > > The manufacturer of the electronic ignition insists that the rather thin > electrical wire (shelded cable) be attached directly to the battery. I am > questioning the advisability of this unless a fuse or CB placed at the > battery. Uncomfotable with this hot wire entering the fuselage and being > seperated from the battery bus. If the fuse is on the engine side I feel > less in control to replace the fuse or reset the CB. Could not find any > references on the this website. Would appreciate your thoughts on this > matter. > > ________________________________________________________________________________
Date: Mar 18, 2011
I'm with Klaus and Ed, If Klaus doesnt have enough faith in the system to wire it to the bus, neither do I. Hardwire that sucker. If it smokes and you're still around, send it back to him. His problem. I use the switch style breaker right on the panel so it's an easy hookup. I also use the optional aux 5 amp battery and mounted it under the tunnel in my Legacy. Big ole' red hooded panic switch on the panel to change over to battery power. I chickened out on the dual system and pulled one in favor of one mag. I had a Lancair test pilot in that experienced two total failures on dual EI systems. Too each his own. Dont forget to check the amperage on the auxiliary battery over some interval. Other than that the thing doesn't skip a beat. The box is supposed to put out a signal for an RPM hookup, but even with Klaus's help, I never got it working. Bought the cheapo transducer from Vans and it works fine. Glenn -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of fedico94(at)mchsi.com Sent: Friday, March 18, 2011 12:30 AM Subject: Re: AeroElectric-List: Wiring Lightspeed Plasma II Thank you for your insight. I enjoyed reading your email and found it to be a big help ----- Original Message ----- From: Ed Holyoke <bicyclop(at)pacbell.net> Subject: Re: AeroElectric-List: Wiring Lightspeed Plasma II There is one other thing to think about before you go changing the way Klaus has the wiring diagram laid out. As was mentioned in a thread a while back, the Lightspeed box has a built in crowbar to protect itself from an overvoltage event. That's why the wiring diagram shows a pullable breaker as the only circuit protection device. If the internal crowbar decides to unload on the system, the breaker pops and can be reset after the errant alternator is offline. If there is a fuse in the circuit, it will blow before the breaker does and you're SOL in terms of getting the ignition running again until the fuse can be replaced. If this one thin un-fused wire were to short to the airframe before the breaker, it would likely burn right through and become un-shorted. In the meantime, you'd be out one ignition. Best to be very careful in routing and securing this wire and after that - don't worry about it. Inspect it at annual and keep flying. There was a case where some guy put 2 lightspeeds into a lancair and wired them, as I understand it, through fuses which blew and caused a forced landing. Think twice about failure modes before changing manufacturers' wiring diagrams. Once you think it through, then wire it as you see fit, but be sure you know why you made any changes. Pax, Ed Holyoke On 3/17/2011 7:52 PM, DEAN PSIROPOULOS wrote: > --> AeroElectric-List message posted by: "DEAN PSIROPOULOS" > > > Klaus wants the hot wire to go to the battery directly in order to minimize > voltage sag at the brain box during starting. I have a Lightspeed Plasma > II+ that I originally intended to activate with the aircraft's key switch > (along with the single slick magneto that I have on the left side firing the > bottom plugs). Note that the Plasma II+ (and III+) have two separate wires > that work with the key switch made for airplane magnetos. You can't wire a > Plasma II into a standard aircraft (magneto grounding) key switch, it > doesn't have these extra wires. After I read about some failures of the > standard aircraft key switch I gave it some more thought and decided to > eliminate the key switch as a single point failure (why lose both ignition > systems with the failure of one switch). > > I decided to leave the magneto on the key switch and wire the Lightspeed to > one of the terminals of the bussman six-fuse-block that serves as my battery > bus. The fuse block is behind the instrument panel and its common terminal > is connected to the Odyssey battery (on the engine side of the firewall) > through a 14 gauge wire and a 20 amp klixon breaker (in a box on the > firewall next to the battery to protect the 14 gauge wire). The Lightspeed > shielded wire goes from the battery bus fuse block to a "BAT" switch (a > toggle switch whose stem has to be pulled out of machined notches in the > case in order to turn it on or off) and from the BAT switch to the > Lightspeed brain box behind the instrument panel (the brain box ground is > connect to a forest of faston tabs on the firewall). > > So yes, I did wire it to the battery but, the signal path goes from the > battery through the CB on the firewall, the 14 GA tefzel wire (unshielded), > the fuse block, the BAT switch and finally to the brain box!!! > > Bottom line....2.5 years of flying bliss, the setup works fine and I've had > no problems whatsoever. I start the engine using the key switch (impulse > coupled magneto only). Once the engine is running I turn on the Lightspeed. > It works great with no kickback and, I can still turn the electronic > ignition off during the run-up to see how the magneto and bottom plugs are > working. I've also started using the Lightspeed only and had no trouble. > > Like many of these things that we builders tend to fret over, this is one > that you should not worry about, different wiring schemes are not a big > deal. Wire it in and get that bird flying. > > Dean Psiropoulos > RV-6A N197DM > 2.5 years of flying fun > > > -------------------Original Message------------------- > > From: fedico94(at)mchsi.com > Subject: AeroElectric-List: Z-12 and Plasma II ignition > > > I am building an RV-9A per Z-12 outline. The plane has one elctronic > ignition on the right going to the top cylinders and one Slick magneto on > the Left side. > > The manufacturer of the electronic ignition insists that the rather thin > electrical wire (shelded cable) be attached directly to the battery. I am > questioning the advisability of this unless a fuse or CB placed at the > battery. Uncomfotable with this hot wire entering the fuselage and being > seperated from the battery bus. If the fuse is on the engine side I feel > less in control to replace the fuse or reset the CB. Could not find any > references on the this website. Would appreciate your thoughts on this > matter. > > ________________________________________________________________________________
Date: Mar 18, 2011
> Aren't all or most of those auto-dimming? I think you should verify that fe > ature and only manual dim the ones that can't. > Most things can. > Tim My Garmin 430W is autodimming, but the function is adversely affected in my Cessna 172 by the overhead red light that gently illuminates the entire panel. It took a lot of playing with the (non-intuitive) dimming curve to make it work properly. I was unable to truly simulate in flight at night lighting conditions on the ground, because the exact level of the overhead light was significant. Having my hand in front of the unit to press the buttons affected it too. I have it balanced now, but changing the overhead light level messes it up :-( On my Tundra, I intend to try to make the manual dimming mode work with whatever dimmers I choose, which will give me more direct control. I guess the other option would be to not provide general illumination for the panel, which would require reverse lighting of all the switch labels. Jeff Page Dream Aircraft Tundra #10 ________________________________________________________________________________
Date: Mar 18, 2011
An excerpt from a LSI service bulletin found at: http://www.lightspeedengineering.com/News/ServiceBulletins.htm Electrical System Requirements All Plasma CDI systems can be used with 12 or 24 volt electrical systems. Input voltages above 35 volts or reversed polarity can cause system damage. For this reason it is mandatory that all aircraft using Plasma CD Ignitions are equipped with over-voltage protection in their alternator charging system(s). Over-voltage protection is a requirement for certified aircraft. Power connection must be directly to the battery terminals to avoid voltage spikes and electrical noise. Aluminum should never be used as an electrical conductor for the Plasma CDI. Use only the supplied aircraft quality stranded wire. Minimum supply voltage for starting is 6.5 Volts. Minimum operating voltage is 5.5 Volts. ------------------------ This ignition system has been under development since 1986. I met Klaus at OSH for the first time that year. He was offering an MSD racing spark-generator combined with his own trigger-timing system to make it more aircraft friendly. In terms of engine performance, it was indeed a quantum jump forward. He had the fastest Ez on the planet back then. But the system wasn't ready for prime-time in the OBAM aviation market. It was big, heavy, and produced radio noise like Marconi's spark gap transmitter. The product has come a very long way since then. It has suffered the odd error of design or fabrication over the years, there are a hand full of failure events due to manufacturing error . . . but no more than one would expect to see from any emerging product that was developed on 1% of a NASA budget for the same device. It's a safe assertion that Klaus has carried out his development and marketing programs with due diligence to the customers. He has learned his lessons well over 25 years attendance in the school of realistic free-market enterprise. But Klaus is not a system integrator. As a very small business entrepreneur he has properly focused his attention to performance of the INNER workings of his product. It follows then that there may be errors of perception when it comes to recommendations for the OUTER workings when his product is being contemplated for use on YOUR airplane. Klaus is not unique in this fundamental fact of life in the aviation world. Really BIG names like Garmin, King, Narco, ARC and others have displayed their lack of knowledge of real-world conditions that surround their installed products. Their installation manuals have offered ideas and recommendations based on "worries" that have no foundations in fact for decades. Having worked both sides of the fence as both a supplier and integrator of black boxes, I'm blessed with an appreciation of how badly that 'fence' can block the useful exchange of simple- ideas between the two camps. A major component of my professional activities in general aviation was to function as a liaison between the black-box and airframe guys. I've got some jaw dropping stories to tell about $millions$ blown down the tubes because somebody on one side of the fence or the other wasn't interested in understanding the simple-ideas that tied his product to stuff from the other side of the fence. Suffice it to say that I perceive only two niggling 'problems' with Klaus's perceptions of the world in which his products live and perform quite well. Further, both problems are residents of that wildly misunderstood world of noise, spikes and overvoltage. One is the shielded power wire thing. Shielding does NOTHING for the mitigation of noise in anything except a very narrow range of issues. See: http://www.aeroelectric.com/articles/MagnetoSwitchOptions.pdf Page 12 of http://www.aeroelectric.com/articles/richter/response_2.pdf Shielding of the power wire for an LSI ignition system accomplishes nothing. The excerpt above contains the statement: Power connection must be directly to the battery terminals to avoid voltage spikes and electrical noise. We have discussed the spikes and noise thing at great length here on the List. Some of you will recall lengthy discussions about 10 years ago with a couple of gentlemen who had a great deal of shade-tree folk lore to share but neither of whom spent one hour in a DO-160 test lab or crawling around an airplane chasing root cause of a real noise issue. There are no products with any track-record in aviation that will benefit from "purer power" offered at the terminals of a battery . . . and the LSI system is a member of the community of aviation products with long and successful track records. Suffice it to say that the LSI system is at no risk of improper function or premature failure for getting its power from ANY point in the system as DICTATED by your own design goals and failure modes effects analysis. The folks here on the list fly everything from Kitfoxes to LA-IVP. Any and all might avail themselves of the value offered by the LSI ignition systems. If it were my airplane, my LSI ignition(s) would power from separate 5A fuses/breakers tied to the battery bus. If you've got two engine driven power sources (Z-13), then you might power one of the ignitions through a 5A fuses/breakers on the e-bus. If Z-12, then one from the battery bus and the other from the main bus. Whether you use breakers or fuses matters not. Whether you can REACH the breakers or fuses matters not. Exactly where that power comes from is of very little significance except as it becomes a part of your Plan-B for dealing with an alternator-out situation. The LSI system may have ov protection for levels that exceed it's maximum operation voltage (35 volts) but even if it were a crowbar system that pops breakers/fuses it is of no concern in a 14v system . . . or any system that's properly fitted with ov protection at 16.4/32.8 volts per legacy design goals. I'll be meeting with Klaus on other matters later this year and we'll discuss an AEC review of his published installation recommendations. In the mean time, know that the worries circulating amongst the OBAM aviation community have no foundation in facts known to us at this time. Bob . . . ________________________________________________________________________________
Date: Mar 18, 2011
Thank you this information to increase my understanding and eloquently stated as well. I will stay with the design per Z-12. I have one Slick mag on the left and the LSI Hall effect sensor on the right mag location on the Aerosport IO-320. As you have mentioned on other posts, I will probably use the Slick mag until it fails and then switch to a dual electronic ignition system. The traditional magneto gives me some comfort at this time but I would expect the next 10 years to see considerable progress in this area. I to have a great respect for the product which is why I choose it over competitors and the other alternative of using traditional magnetos, although I have never met Mr. Savier he has a well thought out system that is very good considering the shoe string budget. ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Sent: Friday, March 18, 2011 9:53:48 AM GMT -06:00 US/Canada Central Subject: RE: AeroElectric-List: Wiring Lightspeed Plasma II An excerpt from a LSI service bulletin found at: http://www.lightspeedengineering.com/News/ServiceBulletins.htm Electrical System Requirements All Plasma CDI systems can be used with 12 or 24 volt electrical systems. Input voltages above 35 volts or reversed polarity can cause system damage. For this reason it is mandatory that all aircraft using Plasma CD Ignitions are equipped with over-voltage protection in their alternator charging system(s). Over-voltage protection is a requirement for certified aircraft. Power connection must be directly to the battery terminals to avoid voltage spikes and electrical noise. Aluminum should never be used as an electrical conductor for the Plasma CDI. Use only the supplied aircraft quality stranded wire. Minimum supply voltage for starting is 6.5 Volts. Minimum operating voltage is 5.5 Volts. ------------------------ This ignition system has been under development since 1986. I met Klaus at OSH for the first time that year. He was offering an MSD racing spark-generator combined with his own trigger-timing system to make it more aircraft friendly. In terms of engine performance, it was indeed a quantum jump forward. He had the fastest Ez on the planet back then. But the system wasn't ready for prime-time in the OBAM aviation market. It was big, heavy, and produced radio noise like Marconi's spark gap transmitter. The product has come a very long way since then. It has suffered the odd error of design or fabrication over the years, there are a hand full of failure events due to manufacturing error . . . but no more than one would expect to see from any emerging product that was developed on 1% of a NASA budget for the same device. It's a safe assertion that Klaus has carried out his development and marketing programs with due diligence to the customers. He has learned his lessons well over 25 years attendance in the school of realistic free-market enterprise. But Klaus is not a system integrator. As a very small business entrepreneur he has properly focused his attention to performance of the INNER workings of his product. It follows then that there may be errors of perception when it comes to recommendations for the OUTER workings when his product is being contemplated for use on YOUR airplane. Klaus is not unique in this fundamental fact of life in the aviation world. Really BIG names like Garmin, King, Narco, ARC and others have displayed their lack of knowledge of real-world conditions that surround their installed products. Their installation manuals have offered ideas and recommendations based on "worries" that have no foundations in fact for decades. Having worked both sides of the fence as both a supplier and integrator of black boxes, I'm blessed with an appreciation of how badly that 'fence' can block the useful exchange of simple- ideas between the two camps. A major component of my professional activities in general aviation was to function as a liaison between the black-box and airframe guys. I've got some jaw dropping stories to tell about $millions$ blown down the tubes because somebody on one side of the fence or the other wasn't interested in understanding the simple-ideas that tied his product to stuff from the other side of the fence. Suffice it to say that I perceive only two niggling 'problems' with Klaus's perceptions of the world in which his products live and perform quite well. Further, both problems are residents of that wildly misunderstood world of noise, spikes and overvoltage. One is the shielded power wire thing. Shielding does NOTHING for the mitigation of noise in anything except a very narrow range of issues. See: http://www.aeroelectric.com/articles/MagnetoSwitchOptions.pdf Page 12 of http://www.aeroelectric.com/articles/richter/response_2.pdf Shielding of the power wire for an LSI ignition system accomplishes nothing. The excerpt above contains the statement: Power connection must be directly to the battery terminals to avoid voltage spikes and electrical noise. We have discussed the spikes and noise thing at great length here on the List. Some of you will recall lengthy discussions about 10 years ago with a couple of gentlemen who had a great deal of shade-tree folk lore to share but neither of whom spent one hour in a DO-160 test lab or crawling around an airplane chasing root cause of a real noise issue. There are no products with any track-record in aviation that will benefit from "purer power" offered at the terminals of a battery . . . and the LSI system is a member of the community of aviation products with long and successful track records. Suffice it to say that the LSI system is at no risk of improper function or premature failure for getting its power from ANY point in the system as DICTATED by your own design goals and failure modes effects analysis. The folks here on the list fly everything from Kitfoxes to LA-IVP. Any and all might avail themselves of the value offered by the LSI ignition systems. If it were my airplane, my LSI ignition(s) would power from separate 5A fuses/breakers tied to the battery bus. If you've got two engine driven power sources (Z-13), then you might power one of the ignitions through a 5A fuses/breakers on the e-bus. If Z-12, then one from the battery bus and the other from the main bus. Whether you use breakers or fuses matters not. Whether you can REACH the breakers or fuses matters not. Exactly where that power comes from is of very little significance except as it becomes a part of your Plan-B for dealing with an alternator-out situation. The LSI system may have ov protection for levels that exceed it's maximum operation voltage (35 volts) but even if it were a crowbar system that pops breakers/fuses it is of no concern in a 14v system . . . or any system that's properly fitted with ov protection at 16.4/32.8 volts per legacy design goals. I'll be meeting with Klaus on other matters later this year and we'll discuss an AEC review of his published installation recommendations. In the mean time, know that the worries circulating amongst the OBAM aviation community have no foundation in facts known to us at this time. ________________________________________________________________________________
Date: Mar 18, 2011
Thank you for the practical advice regarding the rpm hook-up. The Garmin G3X sytem I am installing uses a pick-up off the Left Slick mag. I will still use the output section of the LSI control box which I beleive can be used for checking timing. ----- Original Message ----- From: longg(at)pjm.com Sent: Friday, March 18, 2011 8:40:47 AM GMT -06:00 US/Canada Central Subject: RE: AeroElectric-List: Wiring Lightspeed Plasma II I'm with Klaus and Ed, If Klaus doesnt have enough faith in the system to wire it to the bus, neither do I. Hardwire that sucker. If it smokes and you're still around, send it back to him. His problem. I use the switch style breaker right on the panel so it's an easy hookup. I also use the optional aux 5 amp battery and mounted it under the tunnel in my Legacy. Big ole' red hooded panic switch on the panel to change over to battery power. I chickened out on the dual system and pulled one in favor of one mag. I had a Lancair test pilot in that experienced two total failures on dual EI systems. Too each his own. Dont forget to check the amperage on the auxiliary battery over some interval. Other than that the thing doesn't skip a beat. The box is supposed to put out a signal for an RPM hookup, but even with Klaus's help, I never got it working. Bought the cheapo transducer from Vans and it works fine. Glenn -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of fedico94(at)mchsi.com Sent: Friday, March 18, 2011 12:30 AM Subject: Re: AeroElectric-List: Wiring Lightspeed Plasma II Thank you for your insight. I enjoyed reading your email and found it to be a big help ----- Original Message ----- From: Ed Holyoke <bicyclop(at)pacbell.net> Subject: Re: AeroElectric-List: Wiring Lightspeed Plasma II There is one other thing to think about before you go changing the way Klaus has the wiring diagram laid out. As was mentioned in a thread a while back, the Lightspeed box has a built in crowbar to protect itself from an overvoltage event. That's why the wiring diagram shows a pullable breaker as the only circuit protection device. If the internal crowbar decides to unload on the system, the breaker pops and can be reset after the errant alternator is offline. If there is a fuse in the circuit, it will blow before the breaker does and you're SOL in terms of getting the ignition running again until the fuse can be replaced. If this one thin un-fused wire were to short to the airframe before the breaker, it would likely burn right through and become un-shorted. In the meantime, you'd be out one ignition. Best to be very careful in routing and securing this wire and after that - don't worry about it. Inspect it at annual and keep flying. There was a case where some guy put 2 lightspeeds into a lancair and wired them, as I understand it, through fuses which blew and caused a forced landing. Think twice about failure modes before changing manufacturers' wiring diagrams. Once you think it through, then wire it as you see fit, but be sure you know why you made any changes. Pax, Ed Holyoke On 3/17/2011 7:52 PM, DEAN PSIROPOULOS wrote: > --> AeroElectric-List message posted by: "DEAN PSIROPOULOS" > > > Klaus wants the hot wire to go to the battery directly in order to minimize > voltage sag at the brain box during starting. I have a Lightspeed Plasma > II+ that I originally intended to activate with the aircraft's key switch > (along with the single slick magneto that I have on the left side firing the > bottom plugs). Note that the Plasma II+ (and III+) have two separate wires > that work with the key switch made for airplane magnetos. You can't wire a > Plasma II into a standard aircraft (magneto grounding) key switch, it > doesn't have these extra wires. After I read about some failures of the > standard aircraft key switch I gave it some more thought and decided to > eliminate the key switch as a single point failure (why lose both ignition > systems with the failure of one switch). > > I decided to leave the magneto on the key switch and wire the Lightspeed to > one of the terminals of the bussman six-fuse-block that serves as my battery > bus. The fuse block is behind the instrument panel and its common terminal > is connected to the Odyssey battery (on the engine side of the firewall) > through a 14 gauge wire and a 20 amp klixon breaker (in a box on the > firewall next to the battery to protect the 14 gauge wire). The Lightspeed > shielded wire goes from the battery bus fuse block to a "BAT" switch (a > toggle switch whose stem has to be pulled out of machined notches in the > case in order to turn it on or off) and from the BAT switch to the > Lightspeed brain box behind the instrument panel (the brain box ground is > connect to a forest of faston tabs on the firewall). > > So yes, I did wire it to the battery but, the signal path goes from the > battery through the CB on the firewall, the 14 GA tefzel wire (unshielded), > the fuse block, the BAT switch and finally to the brain box!!! > > Bottom line....2.5 years of flying bliss, the setup works fine and I've had > no problems whatsoever. I start the engine using the key switch (impulse > coupled magneto only). Once the engine is running I turn on the Lightspeed. > It works great with no kickback and, I can still turn the electronic > ignition off during the run-up to see how the magneto and bottom plugs are > working. I've also started using the Lightspeed only and had no trouble. > > Like many of these things that we builders tend to fret over, this is one > that you should not worry about, different wiring schemes are not a big > deal. Wire it in and get that bird flying. > > Dean Psiropoulos > RV-6A N197DM > 2.5 years of flying fun > > > -------------------Original Message------------------- > > From: fedico94(at)mchsi.com > Subject: AeroElectric-List: Z-12 and Plasma II ignition > > > I am building an RV-9A per Z-12 outline. The plane has one elctronic > ignition on the right going to the top cylinders and one Slick magneto on > the Left side. > > The manufacturer of the electronic ignition insists that the rather thin > electrical wire (shelded cable) be attached directly to the battery. I am > questioning the advisability of this unless a fuse or CB placed at the > battery. Uncomfotable with this hot wire entering the fuselage and being > seperated from the battery bus. If the fuse is on the engine side I feel > less in control to replace the fuse or reset the CB. Could not find any > references on the this website. Would appreciate your thoughts on this > matter. > > ________________________________________________________________________________
Date: Mar 18, 2011
Two things: 1) It is BUS not BUSS. 2) Because of the low luminous efficiency of incandescent indicator lamps, (maybe a few lumens/watt), the current draw of a panel full of small incandescent lamps is enormous. They are also rarely put in series. So--consider it important to use LEDs in your airplane. And get rid of those push-to-test lamp buttons. Okay that's three or four things. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=334302#334302 ________________________________________________________________________________
Date: Mar 18, 2011
Yes, I bought the Simpson display and wiring harness that Klaus sells on his website. It's very helpful in determining rpm/map/timing for each. One note is that the dual system display only works for both if the powered side (on mine, that's the left IGN) is on. If you go this route and are planning dual EI in the future, get a display for each which makes the wiring easier and isolates the display in case of a failure. The display values seem very accurate. If you are comfortable with wires and solder you can buy the display cheap and wire it yourself. Glenn E. Long -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of fedico94(at)mchsi.com Sent: Friday, March 18, 2011 12:51 PM Subject: Re: AeroElectric-List: Wiring Lightspeed Plasma II Thank you for the practical advice regarding the rpm hook-up. The Garmin G3X sytem I am installing uses a pick-up off the Left Slick mag. I will still use the output section of the LSI control box which I beleive can be used for checking timing. ----- Original Message ----- From: longg(at)pjm.com Sent: Friday, March 18, 2011 8:40:47 AM GMT -06:00 US/Canada Central Subject: RE: AeroElectric-List: Wiring Lightspeed Plasma II I'm with Klaus and Ed, If Klaus doesnt have enough faith in the system to wire it to the bus, neither do I. Hardwire that sucker. If it smokes and you're still around, send it back to him. His problem. I use the switch style breaker right on the panel so it's an easy hookup. I also use the optional aux 5 amp battery and mounted it under the tunnel in my Legacy. Big ole' red hooded panic switch on the panel to change over to battery power. I chickened out on the dual system and pulled one in favor of one mag. I had a Lancair test pilot in that experienced two total failures on dual EI systems. Too each his own. Dont forget to check the amperage on the auxiliary battery over some interval. Other than that the thing doesn't skip a beat. The box is supposed to put out a signal for an RPM hookup, but even with Klaus's help, I never got it working. Bought the cheapo transducer from Vans and it works fine. Glenn -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of fedico94(at)mchsi.com Sent: Friday, March 18, 2011 12:30 AM Subject: Re: AeroElectric-List: Wiring Lightspeed Plasma II Thank you for your insight. I enjoyed reading your email and found it to be a big help ----- Original Message ----- From: Ed Holyoke <bicyclop(at)pacbell.net> Subject: Re: AeroElectric-List: Wiring Lightspeed Plasma II There is one other thing to think about before you go changing the way Klaus has the wiring diagram laid out. As was mentioned in a thread a while back, the Lightspeed box has a built in crowbar to protect itself from an overvoltage event. That's why the wiring diagram shows a pullable breaker as the only circuit protection device. If the internal crowbar decides to unload on the system, the breaker pops and can be reset after the errant alternator is offline. If there is a fuse in the circuit, it will blow before the breaker does and you're SOL in terms of getting the ignition running again until the fuse can be replaced. If this one thin un-fused wire were to short to the airframe before the breaker, it would likely burn right through and become un-shorted. In the meantime, you'd be out one ignition. Best to be very careful in routing and securing this wire and after that - don't worry about it. Inspect it at annual and keep flying. There was a case where some guy put 2 lightspeeds into a lancair and wired them, as I understand it, through fuses which blew and caused a forced landing. Think twice about failure modes before changing manufacturers' wiring diagrams. Once you think it through, then wire it as you see fit, but be sure you know why you made any changes. Pax, Ed Holyoke On 3/17/2011 7:52 PM, DEAN PSIROPOULOS wrote: > --> AeroElectric-List message posted by: "DEAN PSIROPOULOS" > > > Klaus wants the hot wire to go to the battery directly in order to minimize > voltage sag at the brain box during starting. I have a Lightspeed Plasma > II+ that I originally intended to activate with the aircraft's key switch > (along with the single slick magneto that I have on the left side firing the > bottom plugs). Note that the Plasma II+ (and III+) have two separate wires > that work with the key switch made for airplane magnetos. You can't wire a > Plasma II into a standard aircraft (magneto grounding) key switch, it > doesn't have these extra wires. After I read about some failures of the > standard aircraft key switch I gave it some more thought and decided to > eliminate the key switch as a single point failure (why lose both ignition > systems with the failure of one switch). > > I decided to leave the magneto on the key switch and wire the Lightspeed to > one of the terminals of the bussman six-fuse-block that serves as my battery > bus. The fuse block is behind the instrument panel and its common terminal > is connected to the Odyssey battery (on the engine side of the firewall) > through a 14 gauge wire and a 20 amp klixon breaker (in a box on the > firewall next to the battery to protect the 14 gauge wire). The Lightspeed > shielded wire goes from the battery bus fuse block to a "BAT" switch (a > toggle switch whose stem has to be pulled out of machined notches in the > case in order to turn it on or off) and from the BAT switch to the > Lightspeed brain box behind the instrument panel (the brain box ground is > connect to a forest of faston tabs on the firewall). > > So yes, I did wire it to the battery but, the signal path goes from the > battery through the CB on the firewall, the 14 GA tefzel wire (unshielded), > the fuse block, the BAT switch and finally to the brain box!!! > > Bottom line....2.5 years of flying bliss, the setup works fine and I've had > no problems whatsoever. I start the engine using the key switch (impulse > coupled magneto only). Once the engine is running I turn on the Lightspeed. > It works great with no kickback and, I can still turn the electronic > ignition off during the run-up to see how the magneto and bottom plugs are > working. I've also started using the Lightspeed only and had no trouble. > > Like many of these things that we builders tend to fret over, this is one > that you should not worry about, different wiring schemes are not a big > deal. Wire it in and get that bird flying. > > Dean Psiropoulos > RV-6A N197DM > 2.5 years of flying fun > > > -------------------Original Message------------------- > > From: fedico94(at)mchsi.com > Subject: AeroElectric-List: Z-12 and Plasma II ignition > > > I am building an RV-9A per Z-12 outline. The plane has one elctronic > ignition on the right going to the top cylinders and one Slick magneto on > the Left side. > > The manufacturer of the electronic ignition insists that the rather thin > electrical wire (shelded cable) be attached directly to the battery. I am > questioning the advisability of this unless a fuse or CB placed at the > battery. Uncomfotable with this hot wire entering the fuselage and being > seperated from the battery bus. If the fuse is on the engine side I feel > less in control to replace the fuse or reset the CB. Could not find any > references on the this website. Would appreciate your thoughts on this > matter. > > ________________________________________________________________________________
Date: Mar 18, 2011
Subject: Re: Toggle switch keyways redux
>At 10:54 AM 3/1/2011, I wrote: >I would take "keyway conventions" with a grain of salt! > > When we began to study the application of progressive > transfer switches I published drawings with numbered > terminals to assist the neophyte technician in getting > wires on the right terminals the first time. I discovered > that the way Microswitch and Carling built their progressive > switches was not the same. I had to publish this piece to > make folks aware of the differences: > >http://www.aeroelectric.com/articles/Carling_Micro/Carling_Micro.pdf > > . . . right and left hand columns were functionally > swapped between the two brands. In later years, > I think Carling swapped their progressive transfer > switches to conform to what the mil-spec guys > were doing. > Microswitch had numbers molded into their switch > housings as did the other high-end suppliers. So > I adopted THEIR convention for speaking to terminal > numbering versus functionality. -------------------------------- I was wiring up a Microswitch product yesterday and noted (1) terminal numbers were indeed molded into the switch housing and (2) my illustration cited above was technically correct. But I see that while looking into the back of the switch, the numbers are right-side-up for reading when the key-way was down. Years later, I have no recollection of why I chose to reference the illustration key-way up . . . flip of the coin I guess. In any case, a degree of confusion would no doubt have been avoided had I translated more accurately from the data presented in the manufacturer's catalog data. For newer members to the List, I'll mention that the 'Connection website has an archive of manufacturer's data publications at: http://aeroelectric.com/Mfgr_Data.html If anyone discovers data on a useful product that could be added to this archive, please let me know about it. The short lesson here is that it's never a waste of time to look over and understand the published data that supports proposed installation of a device. Bob . . . ________________________________________________________________________________
Subject: Re: Transient_voltage_suppression_diode failure
Date: Mar 18, 2011
Looks just like that Perihelion Design thing they call a SnapJack. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=334316#334316 ________________________________________________________________________________
Date: Mar 18, 2011
Eric, you're on a roll today. Q - the whackjack thing you sell: does that have a mounting hole or does it screw onto a 1/4 bolt or what? I'm pausing about where that thing would install up front. Also, how large a wire do you run from the whackjack to the B Terminal? With the Nuclear Plant problem in Japan (sort of like an alternator that won't turn off), I'm thinking this is a good investment. Glenn E. Long -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Eric M. Jones Sent: Friday, March 18, 2011 3:43 PM Subject: AeroElectric-List: Re: Transient_voltage_suppression_diode failure Looks just like that Perihelion Design thing they call a SnapJack. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=334316#334316 ________________________________________________________________________________
Date: Mar 18, 2011
Subject: Re: Current draw for lighting Buss
Thanks, Eric All this time, I though bus was what you drove and buss was where the power was. I guess the real buss is a kiss and kisses, while powerful, don't actually carry current (although they can be electrifying). I understand the LED advantage and plan to illuminate the panel with an LED strip. I was looking at a lighting bus just for the avionics. It would only carry the current necessary for the four radios. I can't imagine it is more than a amp or two. Do you have any idea? Regards, Michael Wynn RV 8 Wiring San Ramon (land of the functionally illiterate) In a message dated 3/18/2011 10:40:24 A.M. Pacific Daylight Time, emjones(at)charter.net writes: --> AeroElectric-List message posted by: "Eric M. Jones" Two things: 1) It is BUS not BUSS. 2) Because of the low luminous efficiency of incandescent indicator lamps, (maybe a few lumens/watt), the current draw of a panel full of small incandescent lamps is enormous. They are also rarely put in series. So--consider it important to use LEDs in your airplane. And get rid of those push-to-test lamp buttons. Okay that's three or four things. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=334302#334302 ________________________________________________________________________________
Date: Mar 18, 2011
I'm just guessing here but I imagine at least some of these just use the dim mer input as a reference source. You will have to call the various mfg's to k now for sure. Tim Sent from my iPhone On Mar 18, 2011, at 3:23 PM, MLWynn(at)aol.com wrote: > Thanks, Eric > > All this time, I though bus was what you drove and buss was where the powe r was. I guess the real buss is a kiss and kisses, while powerful, don't ac tually carry current (although they can be electrifying). > > I understand the LED advantage and plan to illuminate the panel with an LE D strip. I was looking at a lighting bus just for the avionics. It would o nly carry the current necessary for the four radios. I can't imagine it is m ore than a amp or two. Do you have any idea? > > Regards, > > Michael Wynn > RV 8 Wiring > San Ramon (land of the functionally illiterate) > > In a message dated 3/18/2011 10:40:24 A.M. Pacific Daylight Time, emjones@ charter.net writes: net> > > Two things: > > 1) It is BUS not BUSS. > > 2) Because of the low luminous efficiency of incandescent indicator lamps, (maybe a few lumens/watt), the current draw of a panel full of small incand escent lamps is enormous. They are also rarely put in series. So--consider i t important to use LEDs in your airplane. > > And get rid of those push-to-test lamp buttons. Okay that's three or four t hings. > > -------- > Eric M. Jones > www.PerihelionDesign.com > 113 Brentwood Drive > Southbridge, MA 01550 > (508) 764-2072 > emjones(at)charter.net > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=334302#334302===== ========================== =============== ========================== ======= - MATRONICS WEB FORUMS ====== ========================== ================ - List Contribut ion Web Site sp; ============ ========================== ============ > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Mar 18, 2011
> Years later, I have no recollection of why I chose > to reference the illustration key-way up . . . flip > of the coin I guess. In any case, a degree of confusion > would no doubt have been avoided had I translated more > accurately from the data presented in the manufacturer's > catalog data. Actually, now I do recall. We were just beginning to consider the utility of 2-pole, progressive transfer switches. In particular the 2-10 for OFF, BAT, BAT+ALT function as a DC PWR MASTER and the 2-50 as an OFF, PUMP, PUMP+PRIME functionality for fuel systems. The -50 switch would be oriented such that the PUMP+PRIME position was spring-loaded back to center for PUMP only. The the spring loaded position was on the key-way side, hence . . . key-way up became the "AEC convention" if you will for use of these switches in the Z-figures. Stir the gray matter gently and with patience. Never can tell what useful data might bubble to the surface. . . Bob . . . ________________________________________________________________________________
Subject: Wiring dual lightspeed ign w/ key'd ignition switch
Date: Mar 19, 2011
Folks, If anyone out there has wired their dual plasma III ignition system with a key'd ignition switch....I'd sure appreciate you sharing your wire schematic with me. I have the schematic from LSE, but just am looking to for a double check on my wiring understanding of Klaus's schematic with how it's then wired to the back of the ACS Products A510 keyed switch. I just want a sanity check. Thanks! Howard -------- Howard Plevyak GlaStar / North Bend, Ohio hplevyak(at)mac.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=334415#334415 ________________________________________________________________________________
Subject: Switch Selection
Date: Mar 20, 2011
All, I have a EI that I want to provide power to from two sources (main battery and alt battery). Would using a 1-3 switch be ok for this application? ON-OFF-ON I'm thinking... Terminal 1 - From Batt Bus (Primary) Terminal 2 - EI Lead (grounded separately) Terminal 3 - From alternate Battery. (Emergency) Thanks, Glenn ________________________________________________________________________________
Date: Mar 20, 2011
Subject: Re: Switch Selection
You're putting all your apples in one basket. It the switch fails your two batteries won't do you any good. John Grosse > ------------------------------------------------------------------------ > > longg(at)pjm.com > March 20, 2011 8:27 PM > > > All, > > I have a EI that I want to provide power to from two sources (main > battery and alt battery). > > Would using a 1-3 switch be ok for this application? ON-OFF-ON > > I'm thinking... > > Terminal 1 - From Batt Bus (Primary) > > Terminal 2 - EI Lead (grounded separately) > > Terminal 3 - From alternate Battery. (Emergency) > > Thanks, > > Glenn > > * > > > * ________________________________________________________________________________
Date: Mar 21, 2011
At 09:27 PM 3/20/2011, you wrote: >All, > >I have a EI that I want to provide power to from two sources (main >battery and alt battery). why? >Would using a 1-3 switch be ok for this application? ON-OFF-ON yes >I'm thinking... > >Terminal 1 - From Batt Bus (Primary) > >Terminal 2 - EI Lead (grounded separately) > >Terminal 3 - From alternate Battery. (Emergency) If you've got a well maintained and failure tolerant system, you won't have an electrical 'emergency'. Under what conceivable scenario do you believe you're going to loose the main battery as a source of ignition system power? Bob . . . ________________________________________________________________________________
Date: Mar 21, 2011
Bob, This would happen is if the battery connection became loose, the 5 amp panel breaker switch failed, the switch wire comes loose behind the panel or it blows my inline 20 AMP fuse (near the battery) that I have in front of the 5 amp breaker switch which protects the line from major overload. The alternate battery concept is a suggested design from Lightspeed. There needs to be a way to switch between the two. Naturally if there is any break in electrical power, the EI goes away immediately and you're in instant do-do. If the Lightspeed were really well designed it would sense a loss of power go directly to backup power and alert the driver to the fact. This is not the case. If on take-off my breaker switch decides to give up the ghost, I've just lost 1 EI. Paranoid? Maybe, but it does happen. Yesterday, the switch I used to change between normal battery power and backup battery power died just as I was beginning my run-up. Glad that happened on the ground and not at 50 feet above the ground. If flying at altitude I could have easily switched to backup power and everything would have went along fine (assuming the switch is OK). So bottom line is that any loss of power and you lose a very critical component. I'm not talking here about losing a light or a radio or whatever (they don't make the engine run). Glenn E. Long -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Monday, March 21, 2011 8:46 AM Subject: Re: AeroElectric-List: Switch Selection At 09:27 PM 3/20/2011, you wrote: >All, > >I have a EI that I want to provide power to from two sources (main >battery and alt battery). why? >Would using a 1-3 switch be ok for this application? ON-OFF-ON yes >I'm thinking... > >Terminal 1 - From Batt Bus (Primary) > >Terminal 2 - EI Lead (grounded separately) > >Terminal 3 - From alternate Battery. (Emergency) If you've got a well maintained and failure tolerant system, you won't have an electrical 'emergency'. Under what conceivable scenario do you believe you're going to loose the main battery as a source of ignition system power? Bob . . . ________________________________________________________________________________
Date: Mar 21, 2011
Which is exactly why I said you don't want ONE switch. Give each battery its own switch. John Grosse > ------------------------------------------------------------------------ > > longg(at)pjm.com > March 21, 2011 9:55 AM > > > --> AeroElectric-List message posted by: > > Bob, > > Yesterday, the switch I used to change between normal battery power and > backup battery power died just as I was beginning my run-up. > > Glenn E. Long > ________________________________________________________________________________
Date: Mar 21, 2011
Thanks John, Sorry, I missed your earlier comment somewhere. Yes, that would be a more secure/separable option. I'm open to good ideas and not afraid to change for the better. I'm also a bit tired of paying good money for switches that offer lots of capability but later fail as a result of it. Single pole is simple and usually works - even if it means a few more switches. Glenn E. Long -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of John Grosse Sent: Monday, March 21, 2011 11:18 AM Subject: Re: AeroElectric-List: Switch Selection Which is exactly why I said you don't want ONE switch. Give each battery its own switch. John Grosse > ------------------------------------------------------------------------ > > longg(at)pjm.com > March 21, 2011 9:55 AM > > > --> AeroElectric-List message posted by: > > Bob, > > Yesterday, the switch I used to change between normal battery power and > backup battery power died just as I was beginning my run-up. > > Glenn E. Long > ________________________________________________________________________________
Subject: HD pin crimp adapter
Date: Mar 21, 2011
Bob, I have just received your adapter for the HD pin crimp, and need guidance as to how to use it. I have the pre-calibrated d-sub crimper from you, an Astro, and a Buchanan crimper. I can send a photo of the three if it would help, but would need your email address for that. Yours, Kenneth ________________________________________________________________________________
Date: Mar 21, 2011
Subject: Re: HD pin crimp adapter
At 12:44 PM 3/21/2011, you wrote: > >Bob, I have just received your adapter for the HD pin crimp, and >need guidance as to how to use it. I have the pre-calibrated d-sub >crimper from you, an Astro, and a Buchanan crimper. I can send a >photo of the three if it would help, but would need your email >address for that. You unscrew the silver cap on the back side of the crimper. Under this cap you'll find a spring and a positioner for the 20AWG pins. Remove replace the 20AWG positioner with the 22HD positioner. Put the cap and spring back in place and you're ready to go with the smaller pins. Bob . . . ________________________________________________________________________________
Date: Mar 21, 2011
At 10:55 AM 3/21/2011, you wrote: >If the Lightspeed were really well designed it would sense a loss of >power go directly to backup power and alert the driver to the fact. Refresh my memory. What's your engine/ignition setup for this airplane. Is the LSI system the only ignition system for the engine? Bob . . . ________________________________________________________________________________
Date: Mar 21, 2011
Bob, I had dual LSI but removed one in favor of one MAG. So, one LSI and one mag. Thanks Glenn E. Long -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Monday, March 21, 2011 2:28 PM Subject: RE: AeroElectric-List: Switch Selection At 10:55 AM 3/21/2011, you wrote: >If the Lightspeed were really well designed it would sense a loss of >power go directly to backup power and alert the driver to the fact. Refresh my memory. What's your engine/ignition setup for this airplane. Is the LSI system the only ignition system for the engine? Bob . . . ________________________________________________________________________________
Date: Mar 21, 2011
At 04:02 PM 3/21/2011, you wrote: > >Bob, > >I had dual LSI but removed one in favor of one MAG. So, one LSI and one >mag. > >Thanks Okay, you got two ignition systems. Why the great concerns for keeping the electronic one running? You cited potential for a lot of things to get unhooked or otherwise become unusable. My best advice is keep it as simple as possible and take good care of it. Sometimes the best way to drive a nail is with a hammer. No batteries, no moving parts, works in the worst of weather conditions and it will still be functional after we're all gone. I just cleaned up one of dad's old hammers. Brightened up the head, sanded and oiled the handle and put a piece of heat shrink over it to tie down the splinters . . . good for another 60 years. Bob . . . ________________________________________________________________________________
Subject: Bad Tach Readings - Grand Rapids EIS 4000
Date: Mar 22, 2011
Hi, I have just started flying my GlaStar again after installing a Grand Rapids EIS 4000 and single screen Horizon HX. I've wired my traditional mag P-leads to tach input 1 (left mag) and tach input 2 (right mag). At first, the "left" mag and "both" positions showed normal, reasonable, stable RPM indications. During my runup at 1700 RPM, the "right" mag would fluctuate wildly between 3200 - 3400 RPM. After talking with Greg at GRT, I switched the inputs and the problem jumped over to the left mag. I then switched the inputs back and, again at Greg's suggestion, increased the resistor values on the right mag/input 2 to 47K Ohms and then to 100K Ohms. With the 100K Ohm resistor in place of the original 27K Ohm resistor, the problem abated somewhat. On runup, the right mag would show a believable RPM for a couple of seconds and then would fluctuate between 1200 - 1400 RPM. The pulse per revolution and mag sensitivity settings in the EIS are "1" and "low", respectively, for each mag. More recently, the left mag (and consequently, in the "both" mag position) is exhibiting the same wildly fluctuating behavior - to the point, the tach indications are useless. This occurs even though the engine is running at a constant RPM. An A&P/IA buddy of mine with extensive experience in light GA aircraft thought that maybe there was a bad ground in the P-leads so we put jumper wires from the magneto cases to the ground "forest-of-tabs". (The "hot mag" check was fine even before the jumper wires.) This damped out the RPM swings somewhat but did not eliminate the problem. (I'm using a conventional Start/Mag switch with the four shields (from each P-lead plus the shielded wire to each tach input) crimped on a common ring terminal attached to the ground lug on the switch. GRT's installation instructions say it isn't necessary to carry the shield all the way to the EIS box so I didn't.) Has anyone seen anything similar to this? Any thoughts whether it is in the wiring or in the EIS itself? Any troubleshooting steps that I can take to try to identify the root cause of the problem? Best regards Bob GlaStar N248BF ________________________________________________________________________________
Subject: V-Speed ADS remote AoA indicator is back in production
Date: Mar 22, 2011
Several months ago, there was a discussion about our remote AoA indicator. It had been discontinued because it was costly to support and demand was low. Recent events, including the blossoming popularity of AoA, support of our device by multiple EFIS vendors and some good old arm twisting have resulted in the reintroduction of our device. The V-Speed ADS has more than 5 years flight experience in numerous aircraft, and is supported by both Dynon and GRT Avionics. MGL is also considering support. The V-Speed ADS is a glareshield mounted remote AoA indicator that interprets a serial air data stream to present a progressive bar graph type display in a 'heads-up' type location. It also presents cruise flight information at low AoA's, such as (programmable) Vfe, Va, Vno and Vne. If you don't have an AoA probe, it can be programmed for a slow flight display of Vx, Vref, Vso and Vs1 It has an internal light sensor that automatically dims for night operation. The device comes with a 5' tefzel shielded cable, SPDT switch (for in-cockpit programming access) and a snap bushing for routing the cable. The datasheet can be downloaded from the vx-aviation.com website. Availability: Devices are in stock. Price: See website for ordering $250 including shipping anywhere in the world. Thanks to the many customers who have shown support. Thanks, Vern Little Vx Aviation www.vx-aviation.com http://vx-aviation.com/documents/VSpeed_ADS.pdf ________________________________________________________________________________
Date: Mar 23, 2011
From: Larry & Sandy Sharratt <sandlar1(at)embarqmail.com>
Subject: Re: Bad Tach Readings - Grand Rapids EIS 4000
I've had a somewhat similar experience with my GRT 4000 with a G3i electronic ignition. When I first installed the ignition, I got apparently correct tach readings up to about 2200 or so, then wildly fluctuating above that (the tach pickup came off the ignition module). After moving the tach pickup back to the L mag, the EIS readings returned to what seemed to be correct. (The G3i ignition uses the original - though modified- Slick mags on my O-320). However, now when I switch the electronic module off, the EIS drops off line completely with just a row of black squares across the display. When I turn the module back on, the EIS will come back after switching off and then back on. I know the obvious answer is to just leave the ignition module on but I would still like to know what gremlins are running back and forth inside those wires. Now that spring is returning to the frozen tundra of Minnesota, maybe I'll get a chance to pursue it. I realize the causes of our two issues are probably different, just thought I'd throw it out for discussion. Larry Sharratt Waconia MN From: Bob Falstad <bobair(at)me.com> Subject: AeroElectric-List: Bad Tach Readings - Grand Rapids EIS 4000 Hi, I have just started flying my GlaStar again after installing a Grand Rapids EIS 4000 and single screen Horizon HX. I've wired my traditional mag P-leads to tach input 1 (left mag) and tach input 2 (right mag). At first, the "left" mag and "both" positions showed normal, reasonable, stable RPM indications. During my runup at 1700 RPM, the "right" mag would fluctuate wildly between 3200 - 3400 RPM. After talking with Greg at GRT, I switched the inputs and the problem jumped over to the left mag. I then switched the inputs back and, again at Greg's suggestion, increased the resistor values on the right mag/input 2 to 47K Ohms and then to 100K Ohms. With the 100K Ohm resistor in place of the original 27K Ohm resistor, the problem abated somewhat. On runup, the right mag would show a believable RPM for a couple of seconds and then would fluctuate between 1200 - 1400 RPM. The pulse per revolution and mag sensitivity settings in the EIS are "1" and "low", respectively, for each mag. More recently, the left mag (and consequently, in the "both" mag position) is exhibiting the same wildly fluctuating behavior - to the point, the tach indications are useless. This occurs even though the engine is running at a constant RPM. An A&P/IA buddy of mine with extensive experience in light GA aircraft thought that maybe there was a bad ground in the P-leads so we put jumper wires from the magneto cases to the ground "forest-of-tabs". (The "hot mag" check was fine even before the jumper wires.) This damped out the RPM swings somewhat but did not eliminate the problem. (I'm using a conventional Start/Mag switch with the four shields (from each P-lead plus the shielded wire to each tach input) crimped on a common ring terminal attached to the ground lug on the switch. GRT's installation instructions say it isn't necessary to carry the shield all the way to the EIS box so I didn't.) Has anyone seen anything similar to this? Any thoughts whether it is in the wiring or in the EIS itself? Any troubleshooting steps that I can take to try to identify the root cause of the problem? Best regards Bob GlaStar N248BF ________________________________________________________________________________
Subject: apparent alternator issue
Date: Mar 27, 2011
I have a vp100 and single alternator, single battery, 2 EFIS chelton system similar to Z11 type wiring diagram. I'm having trouble with my alternator charging. Although I have a 50 amp load analysis (if I have everything turned on and max) I have the 60 amp alternator recommended by VAN's, but rarely use more than 30-35 continuous. Even so, I frequently get battery drain warning below 12.5 volts, and I have to conserve. But it is very inconsistent and for some unknown reason it will bounce back up above 13.5 and charge along just fine. I don't think it is the battery, because I'm not finding any problems on the starting side. But the problem does seem to be getting worse. thanks for any suggestions, ajay Read this topic online here: http://forums.matronics.com/viewtopic.php?p=335213#335213 ________________________________________________________________________________
Subject: Re: apparent alternator issue
Date: Mar 28, 2011
A loose / dirty / corroded wire between alternator and regulator can easily fool the regulator into thinking that the battery is fully charged. Dont forget the ground straps and make sure that the alternator is solidly grounded. Easiest first step is to pull and clean all battery connections. When done, a little petrolatum on the heavy terminals will keep things shiny for a long while. Look carefully for a loose or broken connection at the small wire terminals on the alternator. Because of vibration, alternator connections often open up. Wires rarely fail in the middle unless rubbing or another form of abuse takes place. Any wire problem generally appears at the termination. You could check for excess resistance using a digital voltmeter. Intermittent problems can be tough to locate, but wiggle any suspect connection and watch for a change in resistance. It is possible that a diode within the alternator went bad, which would cut the alternator output by one third, but I doubt it because diode failure is rarely intermittent. If your wiring checks do not reveal anything, you might consider removing the alternator and taking it down to the good folks at AutoZone. With their test machine, they can do a quick free diagnosis. They didnt even ask me what car it was from. Good luck. -------- Jerry King Read this topic online here: http://forums.matronics.com/viewtopic.php?p=335246#335246 ________________________________________________________________________________
Date: Mar 28, 2011
A loose / dirty / corroded wire between alternator and regulator can easily fool the regulator into thinking that the battery is fully charged. Dont forget the ground straps and make sure that the alternator is solidly grounded. Easiest first step is to pull and clean all battery connections. When done, a little petrolatum on the heavy terminals will keep things shiny for a long while. Look carefully for a loose or broken connection at the small wire terminals on the alternator. Because of vibration, alternator connections often open up. Wires rarely fail in the middle unless rubbing or another form of abuse takes place. Any wire problem generally appears at the termination. You could check for excess resistance using a digital voltmeter. Intermittent problems can be tough to locate, but wiggle any suspect connection and watch for a change in resistance. It is possible that a diode within the alternator went bad, which would cut the alternator output by one third, but I doubt it because diode failure is rarely intermittent. If your wiring checks do not reveal anything, you might consider removing the alternator and taking it down to the good folks at AutoZone. With their test machine, they can do a quick free diagnosis. They didnt even ask me what car it was from. Good luck. -------- Jerry King Read this topic online here: http://forums.matronics.com/viewtopic.php?p=335247#335247 ________________________________________________________________________________
Date: Mar 28, 2011
At 08:57 PM 3/27/2011, you wrote: > >I have a vp100 and single alternator, single battery, 2 EFIS chelton >system similar to Z11 type wiring diagram I have the 60 amp alternator recommended by VAN's, but rarely use more than 30-35 continuous. Even so, I frequently get battery drain warning below 12.5 volts, and I have to conserve. But it is very inconsistent and for some unknown reason it will bounce back up above 13.5 and charge along just fine. Your normal bus voltage should be on the order of 14.2 to 14.6 volts. I don't think it is the battery, because I'm not finding any problems on the starting side. But the problem does seem to be getting worse. Voltage issues while in flight are never a battery issue. If your alternator has a built in regulator, then it's a very high probability of being bad. The fact that your 'normal' bus voltage is so low suggests that it may have had some kind of problem right out of the box. Bob . . . ________________________________________________________________________________
Date: Mar 28, 2011
At 08:57 PM 3/27/2011, you wrote: > >I have a vp100 and single alternator, single battery, 2 EFIS chelton >system similar to Z11 type wiring diagram. > >I'm having trouble with my alternator charging. Although I have a >50 amp load analysis (if I have everything turned on and max) I have >the 60 amp alternator recommended by VAN's, but rarely use more than >30-35 continuous. When you say "alternator recommended by Van's" is this the 60A PlanePower product? When working with alternators having built-in regulators, there's not much you can do to troubleshoot a voltage variation except to monitor the b-lead terminal with a test voltmeter to see if readings at the b-lead agree with readings on the panel displays. If you have two panel displays and they agree to within .5 volts of the b-lead terminal, then your alternator is probably in need of attention. If the b-lead says where it belongs, 14.2 or a little better, then there's a wiring problem. A wiring problem that drops 2 volts at 30+ amps is going to dissipate some heat. If something 'loose' is your root cause, then it's likely to have a somewhat cooked appearance. Bob . . . ________________________________________________________________________________
Subject: New Avionics Modules from Vx Aviation
Date: Mar 29, 2011
Last week, we discussed the re-introduction of our remote Angle-of-Attack indicator, discussed at length on the list several months ago. Today, we have two new devices that may spark an interest: ================= RS-232C Buffer Board: ================= Vx Aviation today has announced the availability of the TRX-232A RS-232 buffer . Like most Vx Aviation products, this fits in a D-Sub backshell thus making it extremely compact and light. It provides either a one-to-eight fanout buffer or a dual one-to-four buffer. Primarily used for GPS systems that need to drive many other instruments or to convert the low-level outputs of portable GPS devices into compliant RS-232C level signals. Price for the TRX-232A is $100, it's $114 with a mating connector and barrel crimp pins. Full text of the Announcement: http://vx-aviation.com/documents/TRX-232A-110329.pdf ================================================ General Purpose Prototyping Board with PIC Microcontroller: ================================================ The PROTON-225 fits in a D-Sub backshell, a hallmark of most Vx Aviation products and has provisions for a PIC microcontroller for smart applications. It can be used for developing simple things like bias resistor packs for engine monitors all the way up to custom programmable devices like custom annunciator displays. For example, both DB-25 connectors can be used to form an 'inline' processor, or a row of LEDs and a transparent window can be mounted on one end to form a custom display. Price for the board only is $29, it's $39 with the connectors and backshell. Full text of the Announcement: http://vx-aviation.com/documents/PROTON-225A-110329.pdf Thanks, Vern Little Vx Aviation ________________________________________________________________________________
Subject: Adapting Aviation Headset to work with a PC
Date: Mar 29, 2011
Hello Group, I would like the noise attenuation and noise cancelling properties of an aviation headset to use with Skype on my PC. I contacted Quiet Technologies because I like the in-ear style. They referred me to RCM Headsets and the Starkey line: http://www.rcmheadsets.com/products.php?m=1 I've sent an email and am awaiting a response. I am familiar with the "roll your own" headsets threads here and on VAF, but that is generally "going the other way" (PC versions to use in aircraft) I searched and only found this thread (which, again, is the opposite of what I need) http://forums.matronics.com/viewtopic.php?t=54658&highlight=headset+computer I thought I'd throw this thread out there for additional ideas. I'll let you know what I learn from RCM, and, as a next step, I suppose we'll find out how well the Skype "squelch" works when paired with a good mic (I see that as the most likely next hurdle/issue) Thanks. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=335400#335400 ________________________________________________________________________________
Subject: Re: Adapting Aviation Headset to work with a PC
Date: Mar 29, 2011
Go to here: http://www.flightsim.com/main/howto/adapter.htm Here are the recommended modifications: Use a 1K resistor rather than the 470, and eliminate the electrolytic capacitor on the far right (not necessary) Should work fine. Vern Little Vx Aviation -----Original Message----- From: jhausch Sent: Tuesday, March 29, 2011 7:50 AM Subject: AeroElectric-List: Adapting Aviation Headset to work with a PC Hello Group, I would like the noise attenuation and noise cancelling properties of an aviation headset to use with Skype on my PC. I contacted Quiet Technologies because I like the in-ear style. They referred me to RCM Headsets and the Starkey line: http://www.rcmheadsets.com/products.php?m=1 I've sent an email and am awaiting a response. I am familiar with the "roll your own" headsets threads here and on VAF, but that is generally "going the other way" (PC versions to use in aircraft) I searched and only found this thread (which, again, is the opposite of what I need) http://forums.matronics.com/viewtopic.php?t=54658&highlight=headset+computer I thought I'd throw this thread out there for additional ideas. I'll let you know what I learn from RCM, and, as a next step, I suppose we'll find out how well the Skype "squelch" works when paired with a good mic (I see that as the most likely next hurdle/issue) Thanks. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=335400#335400 ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Mar 29, 2011
Very interesting. Thanks! Sorry, just for my own extra-cautious clarification - You mention that I would eliminate the cap. on the far right. So I only need the one cap. (oriented as shown), or do I eliminate both? Also, since I might be using this in a very noisy environment, a PTT might be a great idea. I Googled and found this note about aftermarket PTT buttons on the PS engineering website: How do I modify a portable Push to Talk switch to work in series with my headset? When using a standard portable PTT switch, when installed in series with the headset microphone line, there will be no audio present through the intercom until the PTT is pressed. This is because there are two switches inside the PTT switch, One shorts the TIP and the Sleeve which is what keys the radio. The other switch closes to allow the mic audio from the microphone to the ring of the PTT's mic plug, which will allow the audio to pass to the intercom.. To modify the PTT so that the mic audio is always present, the PTT must be taken apart and the switch that makes and breaks the microphone path will be closed permanently. Due the large variety of PTT, it is not possible for PS Engineering to provide details on how to accomplish this modification. PS Engineering does sell already modified PTT switches, call 865-988-9800 to order. The wording "One shorts the TIP and the Sleeve which is what keys the radio" is a little confusing. Shorts them to each other, Shorts both to V-, what? So a little more searching and I think what is being said is this: The PTT has two switches. The "sleeve" of the jack is at V-, the tip would be wired to mic V-. When the PTT is pressed mic V- is tied to battery V- via the sleeve. Simultaneously mic V+ is tied to the ring. In other words, when the switch is open they are opening V- and V+ to the mic. I guess they use this DPST action to keep all possible current paths open when the mic is not in use, and, perhaps, to guard against issues when plugging/unplugging? Do I have that right? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=335440#335440 ________________________________________________________________________________
Date: Mar 29, 2011
thanks Jerry and Bob, exactly the kind of advice I was hoping for. Also thanks for the autozone tip, very much obliged, Read this topic online here: http://forums.matronics.com/viewtopic.php?p=335471#335471 ________________________________________________________________________________
From: "dougshep(at)netzero.com" <dougshep(at)netzero.com>
Date: Apr 01, 2011
Subject: Coax Cable
I'm installing a Garmin GTX-327 Transponder and will need a coax cable with a 15 foot run to its antenna. According to the GTX-327 install. manual, a double shielded 50 ohm coax cable with less than 1.5db loss at 1090MHz should be used. They suggest either RG304 or RG393 and a vendor: www.ecsdirect.com Wonder if anyone knows of other sources for this cable requirement? ________________________________________________________________________________
Subject: Coax Cable
Date: Apr 01, 2011
Put it RG400 and call it good! That's my 2 cents and what we use extensively (as do most). Cheers, Stein -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of dougshep(at)netzero.com Sent: Friday, April 01, 2011 1:18 PM Subject: AeroElectric-List: Coax Cable I'm installing a Garmin GTX-327 Transponder and will need a coax cable with a 15 foot run to its antenna. According to the GTX-327 install. manual, a double shielded 50 ohm coax cable with less than 1.5db loss at 1090MHz should be used. They suggest either RG304 or RG393 and a vendor: www.ecsdirect.com Wonder if anyone knows of other sources for this cable requirement? ________________________________________________________________________________
Date: Apr 01, 2011
Subject: Coax Cable
At 03:10 PM 4/1/2011, you wrote: > >Put it RG400 and call it good! That's my 2 cents and what we use extensively >(as do most). Agreed. The run-o-the-mill GA pilot would be hard pressed to detect any difference in transponder performance for the increased loss. However, for the purists and the curious, I'll point out this Internet resource: http://www.timesmicrowave.com/cgi-bin/calculate.pl Using this calculator you can wade through all the possibilities. For example, RG-400 at 1090 would have to be limited to 10 feet to meet the 1.5 db target . . . actually a tad less because connectors add a bit more. Taking RG-400 out to 15 ft adds less than 1 db additional loss. A popular low loss cable for microwave is LMR400 which is available by the foot here http://www.tessco.com/products/displayProductInfo.do?sku=59520 The calculator shows phenomenal performance at only 0.6 db loss for the 15 ft run. I used this stuff to get real-time GPS signals down from the roof of our building to the electronics lab . . . about a 50 run with excellent performance. But then you have the problem of mating connectors to this cable. You might find someone on the 'net that can sell you pre-cut cables with connectors already installed. All things considered, the RG400 terminated with tools and connectors readily available to the OBAM aircraft builder is a really good value and unlikely to present any performance issues. Bob . . . ________________________________________________________________________________
Subject: Specific Gravity on Batteries
Date: Apr 01, 2011
Dear E-Wizards, I recently got a small YUASA Battery (15AH or so) and it came with 2 bottles of "GILL" branded electrolyte from a friend, as he was going with a PC-680 in his bird. The Yuasa is a wet cell battery with filler caps, and it has never been filled, although it is about 15 years old. Package was never opened until I got it, same with the electrolyte. Why would I even bother with a battery like that, you may ask? A: Because if is the perfect size to start my back up generator at the hangar. So my question is this: The battery came with papers that specified an automotive electrolyte with a specific gravity of 1.285 (I believe). However, the specific gravity of the Gill electrolyte says it is 1.265, so it is a bit different then the automotive stuff. Can I use the included Gill electrolyte, or am I better off to just go to NAPA and get the automotive electrolyte? What is the main difference in operation between electrolytes with different SG's? Different charging current? Thanks all, Konrad ________________________________________________________________________________
Date: Apr 01, 2011
Subject: Re: Specific Gravity on Batteries
At 09:43 PM 4/1/2011, you wrote: > >Dear E-Wizards, > >I recently got a small YUASA Battery (15AH or so) and it came with 2 >bottles of "GILL" branded electrolyte from a friend, as he was going >with a PC-680 in his bird. > >The Yuasa is a wet cell battery with filler caps, and it has never >been filled, although it is about 15 years old. Package was never >opened until I got it, same with the electrolyte. > >Why would I even bother with a battery like that, you may ask? A: >Because if is the perfect size to start my back up generator at the >hangar. So my question is this: > >The battery came with papers that specified an automotive electrolyte >with a specific gravity of 1.285 (I believe). > >However, the specific gravity of the Gill electrolyte says it is >1.265, so it is a bit different then the automotive stuff. > >Can I use the included Gill electrolyte, or am I better off to just go >to NAPA and get the automotive electrolyte? > >What is the main difference in operation between electrolytes with >different SG's? Different charging current? It's not a critical application so the risks are low. Assuming the battery is not subject to other vagaries of age, then the .020 difference in the electrolyte only accounts for perhaps 25% of capacity. If all you need it for is getting the engine started, then I'd go ahead with the acid you have. If there are no moisture tight seals on the cells, I suspect that there are larger questions than S.G. of the electrolyte after 15 years. I'd put the juice in and stick a battery maintainer on it for a day or so and put it in service. Bob . . . >Thanks all, Konrad > > >----- >No virus found in this message. >Checked by AVG - www.avg.com Bob . . . ________________________________________________________________________________
Subject: Vans Manifold Press. Sensor?
Date: Apr 01, 2011
Hi I'm working on a friends RV6 and we have a problem with a Vans Manifold pressure gauge. When power is applied the needle swings full scale. I'm suspecting the sensor, it has 4 wires coming from it pos,neg, and two to the instrument. If power is applied could anyone tell me what reading I should expect between the two wires to the instrument if I disconnect them? In the olden days I think one could have used an Ohm meter to read the sensor, not quite sure what's in that little black box in these modern times. Thanks Chris ________________________________________________________________________________
Date: Apr 01, 2011
Thank you Bob!!! On Apr 1, 2011, at 9:47 PM, Robert L. Nuckolls, III wrote: > > > > At 09:43 PM 4/1/2011, you wrote: >> > >> >> Dear E-Wizards, >> >> I recently got a small YUASA Battery (15AH or so) and it came with 2 >> bottles of "GILL" branded electrolyte from a friend, as he was going >> with a PC-680 in his bird. >> >> The Yuasa is a wet cell battery with filler caps, and it has never >> been filled, although it is about 15 years old. Package was never >> opened until I got it, same with the electrolyte. >> >> Why would I even bother with a battery like that, you may ask? A: >> Because if is the perfect size to start my back up generator at the >> hangar. So my question is this: >> >> The battery came with papers that specified an automotive electrolyte >> with a specific gravity of 1.285 (I believe). >> >> However, the specific gravity of the Gill electrolyte says it is >> 1.265, so it is a bit different then the automotive stuff. >> >> Can I use the included Gill electrolyte, or am I better off to just >> go >> to NAPA and get the automotive electrolyte? >> >> What is the main difference in operation between electrolytes with >> different SG's? Different charging current? > > It's not a critical application so the > risks are low. Assuming the battery is not subject > to other vagaries of age, then the .020 difference > in the electrolyte only accounts for perhaps > 25% of capacity. If all you need it for is > getting the engine started, then I'd > go ahead with the acid you have. If there > are no moisture tight seals on the cells, > I suspect that there are larger questions > than S.G. of the electrolyte after 15 years. > > I'd put the juice in and stick a battery maintainer > on it for a day or so and put it in service. > > Bob . . . > > >> Thanks all, Konrad >> >> >> >> >> >> >> >> ----- >> No virus found in this message. >> Checked by AVG - www.avg.com > > > Bob . . . > > ________________________________________________________________________________
Subject: BMA Engine Pod
Date: Apr 01, 2011
I=99m looking to purchase a BMA engine pod (sensors optional). If you have one or know someone who does, please get in touch with me off-list. Thanks James Redmon www.berkut13.com ________________________________________________________________________________
Subject: Re: Coax Cable
Date: Apr 02, 2011
Try this-- RG+142 Its main attributes are are that it weighs 1/3 of standard RG142 (incredible) and has markedly better temperature performance, better shielding and lower loss. I sell a lot of it, some to Indy car builders. The main trick is that it uses Copper-Clad Aluminum for it's core, not copper or steel. So it's made for military aircraft and satellite use. Sample on request. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=335838#335838 Attachments: http://forums.matronics.com//files/rg142_172.pdf ________________________________________________________________________________
Date: Apr 02, 2011
Subject: Re: Vans Manifold Press. Sensor?
I recently went through this and also suspect the sensor. The trouble shooting info with the new unit says that the 2 instrument wires should have about 3 ohms. Mine was open. John Morgensen On 4/1/2011 10:02 PM, Chris Fordham wrote: > */Hi/* > */ I'm working on a friends RV6 and we have a problem with a Vans > Manifold pressure gauge. When power is applied the needle swings full > scale. I'm suspecting the sensor, it has 4 wires coming from it > pos,neg, and two to the instrument. If power is applied could anyone > tell me what reading I should expect between the two wires to the > instrument if I disconnect them? In the olden days I think one could > have used an Ohm meter to read the sensor, not quite sure what's in > that little black box in these modern times./* > *//* > */ Thanks/* > */ Chris/* ________________________________________________________________________________
Subject: GPS antenna reception
Date: Apr 02, 2011
List guys=2C All this discussion on GPS coax got me to thinking. I'm pretty close to mounting the remote antenna for my Garmin GPS296. The intended location for the ant enna is on top of my instrument pod/console=2C with the reception facing upward through Lexan. My question is=3B will Lexan inhibit the GPS's antenna reception? If it does=2C I'll have to find a better location=2C possibly at the top=2C outside of the windshie ld. Thanks for your help=2C Mike Welch ________________________________________________________________________________
Date: Apr 02, 2011
Subject: Re: GPS antenna reception
Hi Mike My two GPS antenna are mounted inside the roof panel on my Europa, so they are looking through 6 plys of Bid and paint i have no problem picking up a signal, Lexan wont be a problem. Ivor On 2 April 2011 19:29, Mike Welch wrote: > List guys, > > All this discussion on GPS coax got me to thinking. I'm pretty close to > mounting > the remote antenna for my Garmin GPS296. The intended location for the > antenna > is on top of my instrument pod/console, with the reception facing upward > through > Lexan. > > My question is; *will Lexan inhibit the GPS's antenna reception?* If > it does, I'll have > to find a better location, possibly at the top, outside of the windshield. > > Thanks for your help, > Mike Welch > > * > > * > > ________________________________________________________________________________
Date: Apr 02, 2011
Mike, I have mine mounted on top of my instrument panel and it works fine. Bob Borger Sent from my iPhone On Apr 2, 2011, at 13:29, Mike Welch wrote: > List guys, > > All this discussion on GPS coax got me to thinking. I'm pretty close to mounting > the remote antenna for my Garmin GPS296. The intended location for the antenna > is on top of my instrument pod/console, with the reception facing upward through > Lexan. > > My question is; will Lexan inhibit the GPS's antenna reception? If it does, I'll have > to find a better location, possibly at the top, outside of the windshield. > > Thanks for your help, > Mike Welch > > > ________________________________________________________________________________
Date: Apr 02, 2011
My experience is NO lexan will not limit it but you may consider mounting it at the top of your winshield to give a better unobstructed view rather than on your instrument panel. Depending on windshield . . . On Sat, Apr 2, 2011 at 1:37 PM, Robert Borger wrote: > Mike, > > I have mine mounted on top of my instrument panel and it works fine. > > Bob Borger > > Sent from my iPhone > > On Apr 2, 2011, at 13:29, Mike Welch wrote: > > List guys, > > All this discussion on GPS coax got me to thinking. I'm pretty close to > mounting > the remote antenna for my Garmin GPS296. The intended location for the > antenna > is on top of my instrument pod/console, with the reception facing upward > through > Lexan. > > My question is; *will Lexan inhibit the GPS's antenna reception?* If > it does, I'll have > to find a better location, possibly at the top, outside of the windshield. > > Thanks for your help, > Mike Welch > > * > > * > > ________________________________________________________________________________
Date: Apr 03, 2011
Mike, If you are talking Europa (and therefore composite) panels you can mount the GPS antenna inside the panel somewhere near the top. Lexan and glass fibre are transparent to RF ( but not carbon fibre) so there is no need to have it on the outside at all. Regards Bill Read this topic online here: http://forums.matronics.com/viewtopic.php?p=335908#335908 ________________________________________________________________________________
Date: Apr 04, 2011
On second thought, *IF* I were to use this battery in an airplane application instead of a generator, then what would you recommend? Would you rather use the recommended automotive electrolyte (@1.285), as a 25% dip in capacity/performance seems pretty steep by using the provided GILL juice (@1.265). I wasn't too clear on that answer. Consider this chart taken from one of many tomes on batteries; ========= Specific Gravity Readings ' =93True=94 State of Charge The specific gravity (SG) of the battery acid or electrolyte is the truest and most absolute measure of a battery=92s state of charge. The SG reading is NOT greatly or adversely affected by the load on the battery. Basically if a battery is 50% charged, it will read a specific gravity of 1.200 (see Table 1), regardless of whether the battery is on charge, being discharge or being stored. This is not the case for voltage readings. Table 1. SG vs. Voltage % Charged Specific Gravity 100% 1.255 ' 1.275 75% 1.215 ' 1.235 50% 1.180 ' 1.200 25% 1.155 - 1.165 0% 1.110 - 1.130 Notice that here is a 'range' of values that can represent state of charge for any particular battery with a delta of 20 points out of 1300. Other books may differ to some degree . . . for example: Specific gravity does, of course, vary with temperature and the quantity of electrolyte in a cell. When the electrolyte is near the low-level mark, the specific gravity is higher than nominal and drops as water is added to the cell to bring the electrolyte to the full level. The volume of electrolyte expands as temperature rises and contracts as temperature drops, therefore affecting the density or specific gravity reading. As the volume of electrolyte expands, the readings are lowered and, conversely, specific gravity increases with colder temperatures. The specific gravity for a given battery is determined by the application it will be used in, taking into account operating temperature and battery life. Typical specific gravities for certain applications are shown in Table 1. Emacs! The sum total of all information about batteries in general will not help us much for your situation. We are not privy to design goals and design characteristics of the battery that was originally paired with the acid you have, nor the acid that was paired with the battery you have. My "25%" observation was based on a particular offering of data from the 'net but it may not be relevant to your particular acid/battery pair. The point I intended to make was this. Given the low proposed, low criticality application for this particular battery . . . combined with now good knowledge of the battery's condition after so long in storage, there was no compelling reason not to use the acid you have with the battery you have. The amount of GILL juice I got with this battery seems to be more then enough to fill many batteries of this size, so instead of opening it, why not simply get a smaller amount of automotive 1.285 instead? It's your experiment. I have no basis to suggest that one will be observably 'better' than the other . . . or that the battery is even capable of delivering minimal performance for the application proposed. Put the juice in, top the critter off, and load/cap check it. If the numbers are disappointing, deep cycle it a couple of times and they MIGHT improve. Besides difference in output, are there any differences in current and/ or voltage at which you would charge batteries with differing SG's? I do own a "BatteryMinder" model 12248, made by VDC Electronics which allows various settings of battery type: Gel, Flooded, AGM (although I do not know which voltages each setting represents), ...as well as either a 2, 4 or 8 ampere charging current. Consider that when you put any battery into service the charging voltage is what the charging voltage is. The charging current may be as much as the rating for the alternator. The idea that one can get 'better service' from any battery by charging/maintaining it with a device having lots of bells-and-whistles is not supported by a review of in-service conditions. Super-whippy battery chargers are much like Windows. There are a few features that everybody uses that cover their needs 95% of the time. All the rest is 'cool' . . . but . . . Battery minders having a bulk-charge, top-off, and terminated by a sustaining mode just above 13 volts is, for all practical purposes, good for 95% of our needs. If you'd like to explore battery design and performance issues in more detail, check out the offerings by "Mr. Battery" hisself . . . Mr. Isidor Buchmann who founded http://www.cadex.com/ Talk about bells and whistles! Cadex products are indeed finely tuned to specific battery technologies used in demanding situation where costs of ownership a fleet of battery users can be significantly influenced by using the right tools and processes for battery maintenance. Isador has shared a great deal about the inner secrets of batteries at: http://batteryuniversity.com/ Having offered all this 'good stuff' on batteries, it's time to "burst the bubble." When a really good battery designer teams with a really good battery manufacturer they'll tell you lots of good things they've learned about how to get the most from their product. Their advice will be based on hours of laboratory experiments. Then the after-market folks will jump in with battery maintenance accessories with lots of bells-and-whistles to compliment those tests. But a big disconnect occurs when we take all this data on deeply cycled batteries tested in laboratory environments and put them on our garden tractors . . . or airplanes. The ideal engine cranking battery is NEVER deep cycled. Once the engine taps 5% of capacity to get going, the engine driven power source picks up the loads and replaces the 5% taxation of capacity. Then we depart from 'ideal' by walking away leaving the master switch on . . . for two weeks. Our charging voltage and recharge current values are NEVER in concert with those laboratory ideas. Then, perhaps we suffer an alternator out-event and for the first time since the battery was installed. The pilot has to consider . . . . Hmmmm . . . wonder what the CAPACITY of that battery is? How does THAT condition stack up with things I'd like to have working for then next few hours? This is why I've suggested for years that all the smart chargers in the world attached to the world's finest battery products IS NOT a replacement for the owner/ operator KNOWING what the battery capacity is . . . when and if that knowledge is important (poking holes in clouds or long trips over unfriendly terrain at night). I certainly do appreciate your ongoing input and expertise about anything electric on the Matronics list!!! My pleasure sir. Bob . . . ________________________________________________________________________________
Date: Apr 04, 2011
Mike, The below works well on my ship. I couldn't find a suitable shelf at Wal-Mart, so I made one. http://1.bp.blogspot.com/_hkAHk0Xu6wo/SHOnYZwaZwI/AAAAAAAAAZQ/RsdsLydOu7 0/s1600-h/IMG_1171.JPG Glenn E. Long -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bill & Sue Sent: Sunday, April 03, 2011 5:27 AM Subject: AeroElectric-List: Re: GPS antenna reception Mike, If you are talking Europa (and therefore composite) panels you can mount the GPS antenna inside the panel somewhere near the top. Lexan and glass fibre are transparent to RF ( but not carbon fibre) so there is no need to have it on the outside at all. Regards Bill Read this topic online here: http://forums.matronics.com/viewtopic.php?p=335908#335908 ________________________________________________________________________________
Date: Apr 04, 2011
> Mike=2C > > The below works well on my ship. I couldn't find a suitable shelf at > Wal-Mart=2C so I made one. > > http://1.bp.blogspot.com/_hkAHk0Xu6wo/SHOnYZwaZwI/AAAAAAAAAZQ/RsdsLydOu7 > 0/s1600-h/IMG_1171.JPG > > Glenn E. Long Hi Glenn=2C Your link for a photo didn't come in. ?? I'm building a Kolb MkIII. It has a VERRRY long windscreen (approx 65"). (see old photo.....the plane is almost fini shed now) The intended location that I had planned for the GPS antenna was on top o f my radio console/instrument pod....at the forward portion=2C mounted on the pod's fi berglass cover. This location would place the antenna at an unobstructed spot=2C forward of my view. Thanks to all the replied to my question!! Best regards=2C Mike Welch /9j/4UexRXhpZgAATU0AKgAAAAgADAEOAAIAAAAIAAAAngEPAAIAAAASAAAApgEQAAIAAAAMAAAA uAESAAMAAAABAAEAAAEaAAUAAAABAAAAxAEbAAUAAAABAAAAzAEoAAMAAAABAAIAAAExAAIAAAAK AAAA1AEyAAIAAAAUAAAA3gITAAMAAAABAAEAAIdpAAQAAAABAAABGsSlAAcAAAAoAAAA8gAAOK5E Q0YgMS4wAE1pbm9sdGEgQ28uLCBMdGQuAERpTUFHRSBTNDE0AAAAAEgAAAABAAAASAAAAAFWZXIu MS4wMHUAMjAwMzowNDoxNiAwMTozOTozNABQcmludElNADAyNTAAAAAEAAEAFgAWAAIBAAAAAQAB AAAAAQEAAAAAACGCmgAFAAAAAQAAAtSCnQAFAAAAAQAAAtyIIgADAAAAAQACAACIJwADAAAAAQBA AACQAAAHAAAABDAyMjCQAwACAAAAFAAAAqyQBAACAAAAFAAAAsCRAQAHAAAABAECAwCSAwAKAAAA AQAAAwSSBAAKAAAAAQAAAuSSBQAFAAAAAQAAAuySBwADAAAAAQAFAACSCAADAAAAAQAAAACSCQAD AAAAAQAYAACSCgAFAAAAAQAAAvSSFAADAAAABAAAAwySfAAHAAA1fAAAAxSgAAAHAAAABDAxMDCg AQADAAAAAQABAACgAgAEAAAAAQAACOCgAwAEAAAAAQAABqigBQAEAAAAAQAAOJCkAQADAAAAAQAB AACkAgADAAAAAQAAAACkAwADAAAAAQAAAACkBAAFAAAAAQAAAvykBQADAAAAAQAjAACkBgADAAAA AQAAAACkBwADAAAAAQAAAACkCAADAAAAAQAAAACkCQADAAAAAQAAAACkCgADAAAAAQAAAACkDAAD AAAAAQACAAAAAAAAMjAwMzowNDoxNiAwMTozOTozNAAyMDAzOjA0OjE2IDAxOjM5OjM0AAAAAAEA AAH0AAAAQwAAAAoAAAAAAAAACgAAACAAAAAKAAAHLQAAAQAAAAAAAAAAAQAAAGQAAAAKBAADAAgA BgAACAAAAAcAAAAETUxUMAADAAcAAADkAAADegAQAAcAADKoAAAEXgAgAAcAAAFiAAA3BgBAAAQA AAABAAv3KACIAAQAAAABAAxBpwCJAAQAAAABAACBNQ4AAAcAAAAoAAA4aAAAAAAAAAAAAAAAAAAA AAYAAAAAAAAAAAAAAAMAAAAAAAAAAAAAACsAAAB4AAAANAAAAAAAAAAAAAAABgAAAAEAAAAAAAAA AAAAAAIAAAdXAAAH0AAAAAAH0wQQAAEnIgAAACIAAAAAAAAAAAAAAAAAAAAAAAACawAAAQAAAAFb AAAAAwAAAAMAAAABAAAAAAAAAAYAAAAEAAAABwAAAAAAAAAAAAAAAAAAAAMAAAAAAAAAAAAAAIAA AARwAAADVAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEAAAABAAAfQAAAAAivr6+vAAQFBwAD 3yEAA+rUAAQdQgAD9r4AA8BHAANnlwADMdMAAw41SALAIEQCIFAkACAKCQBAoSggDECKDSRAQACA VWAAAoAFGACAIoA4ECmAABDsaIYAFBAAwQqkAAZAEAgSWQACAgUQBoJBYERAQgwQxBgAAgpEBQCM mJlAgAAwAAFLpAQAAgAMQGBGAAQBKAAoAgIYCAUIiIYYgEAABIgACcoAQKBUAQiLAARAgFJEABIA ATEAWACCAoZAQAAMYAAAyChAgEogUAhBBBQdAGYEAgTECCAUqQCBQgQIiKAAAgIIABIAQiAkgQOB CCSkgAAQAwAIQAKEAgg4AAiIREAAAqoEQBQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA5RIAAPYbAAD9GwAA72MAAOjyAADxYgAA5+cAANxUAADXmICABqBFIUAigIgAQIAA FEkSgogARBIBJAUABICcMBqCSIiAQIoAggCKIiIIBECA9AgJACAkGgBAAIkCQAQMiEAURYgJCCiA CCAAACCpRACP5IBAhAQIBCDZiIiAEACAAgpAACAggEBIBIQEKIAABRBogAAAAAAgA6UKAAIAokBI qWHAYAJMBIARQgxBgERAogVQgQQgAABBIARgBBLEAIaJoCiCxkQRKBAAAAGgAABIuKDBABCAICDB AgMg0QgBUCkCQIiMSABAgIAkQIICAE5lwAEgLAIhAIZEAAwgTgCAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADAAAABgAAAAcAAAAFAAAABAAAAAQAAAACAAAAAQAAAAIw CKEghAAAwUAAgGCBKhgQAsQgKAAKQBBphAiiDSAAMEgGAAJkmAAAiiRAAKACBALLBDQUUIJAgCQE AhCgEAAELAAAiACCAACCAAYFAgBAAAJmAJAEBAEECABABKUkSFAIgEAQgEkAIEACBAVAAAIkpAAA YhLAGGjQIAQAIUkCLAAAADIghAACgwAAQAAAIADCgCBBAA0IJKCBAYRUgAASGACAJADAAhwBQSAA LJUQAhgFABQEARoEDCgAAgYgQAMgEQAAkJQAQBwgACoKBAgAASoAQIQQwACSAIAAQEliAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0uJwAMxzkADLx+AA0EKwAM5DUADJcw AAxITwALyM4AC6SfqAUEIACEAVKRAASEIIYAABACoAQgAAGKACAIAHgAAEQEFCBACAwEACEAgQgg gCgIAwAItRkKAEC0BAEQABQCAoYlAgKGCgAi0UQEUqAACIAyYSBUKAIAIiAARMAJIQgAAAEBgRBA AWAgAAAApBUARCIgAEFAEAACEAQCAAEAAQkAAEmAkjCBAggqQiQgZAAkAAEATAAJAgCIqCQEADEw EJAImABCAAAA6gAAAIEAAUARCgBAAEAAQEgAAAgoQgDgESgKQOBgAACEA8FCAtEACgQAAArAISBg AEwiQkCCiIMAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAOv//99d7X737//9/3++/+3mFt387fV/9e3/r3f///+/ 3/6/d9z/3m/r/v/+vvv//O//f/vv3/9u3e//y/m//9/9/3+/rvf/39v1987l//39X+V9937vv/1t /37Xn8vt/r/fnn76/t/399///9/9//75/f/f/fz93ff/d53///333//9779ex+/u9/9f/n/td2Tf z/Xt9/2/67v/7b////fv////5X2/6/19/v5/fv/2937//ev/7/87f+/ffv3f/59/387n/v913vf/ /vn1+/vsfPf//67//939/97+///2AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACZe3f3ft2/9//979bn9r9/+tf/ f2V0b/8bePv/t9/v2l7/v/3+///d7q//6/9t/3n//392/25/f393/+zf31/95/97/r95//3df/3v XXm+//+b//s//9/+/N79zk+5/82t6/vv/9X/y/7//39N8+/979V1vv79d9f/7ft3XV1372/v+75/ 5/P/S73W53ef//329vv+9Wv33393//duv99v/3579+7e+/9/e9/f7///b/237+fu3/t1/93+/ef3 63/+//3T3f/v399u///e83/7/T3+f/f/XN9z+n9/bb+//wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAANE8QADJIIAAyAOAANSCgADMEsAAv9MAALMwwACoOIAAoPv7vrvvrvc 3/Xq3//r8///a31///7+///cz+fv/2y////7f+qzfP/P/u7+t/+s/1f/+nrf/et/v/9Y62+/z/fV 92/v2X/v/+62/+//vlX+///xv93t/n73/sfz7/vP/3/H+t///2ff+/+///8/pnf7+1v+//3nbf/6 X33//1/P//z9/m///+3/Xf3t/vfvb/vf3fvfrs+9/v9b//tv5b9/bdL3715i3/e03z9////9f5/u ////u9//z1l/f/+9/t/f2r//vv7+v9913///7ru/73fr6v5sr/3//P///3fHfe8AAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAnoAAPO+AADu9gABBQgAAQ8lAAD+6wAA71EA AN8sAADfAvu3/7dr/f+vzzf/PXlf925d7v/7Wvvz/vZ+//bj/v/du+/3+f3//39///////Pf/z/v 3//+3u/r/9u9/+/////7vt/XX3t/7tbvfe/vv//++en3f2/7//fTbfW///7++979/917v///X//9 9uf+/v//1/3fcPf7//v2/ld/v/70/8bor5fd39t93/dX7vu//0v//9mX+/7bPbvc//17r/1P/f/s /n763sz+/r/f/3/f/X3nvdz9/7787Xf//L7/7v/29/f3/v/rv3Pf3//0/9NX/f/3bH3//+7//9vp u3bzAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAKIZCBEGJAA0BInQgARQAEpoUJhyoDBAiSAACBgCEAAKgMxEAI A4gSgABAoAEAAgghEgNClSsErIEhBAAjCMIEisCgYQFIIAAAJSggAKABAAgBAAQAoAQkAABQAEgE IEhgCEAIyNjASBUmAACiKJFEQgGFABAlkBGEpIAAqCSAQBQqYAAkQgQCEAQH4EQQAAEEgQBAgAAA KgEgAUEIgAEgAkBMJACCgIgA0EQIAIQAAIBSkaAACQGkSBogASpEAIAAmIoAgCigAYAGgggACBGA wQAZEAiYABAAEEkgUABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAVb fwAFHEEABSrEAAWe/AAFrQoABYbdAAURVwAEm3sABFxyAiqASABBgQgAYkRBCggggUgEAAAAAQCA AEjiiEggAkAB6QAgCBhAAAkAIQACKYIAhCEICMQpAARAAQQKBsYEAAAKABACACaAwgBCAgABCQBK DKBEgVAQTCiMgwDETCQApACAIBBAAEUQCgIIgAEQABQUgYBAiAIQGAIDgQhAAIIIQQAAAQEAAACi AAhACAIAgEgACgkMAIBAMEAnAEAAAABBhgAIABAABUlAAAhABAAJQQUCAEASBAAEwcBCmAGIACAg AEQIAgAOBMAACIEBCICIIQQEigACAACACIQEKQQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAABKmwAAQ6kAAEDHQABH5QAASCzAAEIlAAA+S4AANM5AADChxNrAAIwAkwYEoCg AsQBCAiYAoihkKgBAEAlIAJpAQEBgAAgAZjAEACARoCAIQAAEBuIAAQYKiSWiwACAICAAQCIEYwS gQACQgREAAAkCwwICgAAAIEGogGqzAYAAigEICAABAAoBEEAAIQgAAIABADGAAAAAgIEBIQJiAIB BgAgAQACVDCAQEABoAAgjigITAEgqAAiAAAAQkgJAIBQAIAAhAAAQgUBCCaEAABJAgAAwQIAA6gI EAFAAQiAxkBJTcAFSFWOCACASEQAEgLAAAAAIAAAIQIgRhAqAFhKKBkCAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAUAAAAEgAAABAAAAAVAAAAFQAAAA4AAAAOAAAABwAA AAQUAAQJAAMEgkQAACCABAAADEUgoAEpYIJAACCkIQAoASwgAABqgSQEKCQIgECECAIoEAAAAScC IiRBgURAoAAgiEgJQCEgICEIRQAACAgqAIBKBAIAkAIAAAAERAUCAoAjyEDCVAEIAESgBFKAgYAm CAhCAEUAAMaARQAEgKISAEGBBBACggCFhQAhwhBIAUghEAQAQwUAIIUgAAgABAgIWCBkEAQAEACA IAFIaIAAUMIwgIACoIAAAAEBYIkAAMJgJAMEBAEAAIIIJoCEKUAEaAAAAFsAggJAOACMTkAQQgAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAECEAEhAAIDiIEwBQAACAIiIACCk EABQgCIAgEQAAAAAJSCWAGQAgACKBIgQJAhAIEAAAHwEQhFFYAQAIkAAQEAEABBGAAAAAgQAICaB QhSIhAAAB0AEcBBYIAAAJQlJBJAABQgGRCwyKAEEAgASIsIAANQEACIBAACEAGgCVAJEAAAAIIEA CChQACAYAQCgRIAAIIQAiAAFBgAEAAQAAAoEAABkIgAkZEBBSYgIACCAAAQAICwAAhGIAoAAAgEk ICQAYEEhMAsGBAAIoIACABBAAIwWEAAIlxIAAEFRAgRMIIhIABgAAhAkgCYhAgAAkEUCADIAYjok lCAI1DgCBAFiiBAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAECCiIMgIgIA AAFEGIQJhEADAKAE0BVERISISCgACQDEgACBRMBBCgWggqhQQwCBAEKkgQCAREgMIoQCIHCAJgQA CQAQiQAGAKJAgBJkAoABDIAESCQGACIDBAAAUACgEYBCAEBkgQggFAggAAAgEBJBQAAAAQAAAAQg QAAAIEQABARAAmAFgCT+3////f3/3v7dv792///3f/7//////9v///f9/3td/9dX79/2/+3//rf/ 77///fvC+//9+v//+7P9//9r/f/f3n//39W//////X///f9+/+7//f737f//39///9/v//f/e/// p9/+/7/8///+2v/39+/9/37/v//+/f/7AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAABq5v/d733+z+395//99+v9v3//7/u5/+//59/71//9/7/+3v7d7+t/5f//97re7+/N/99/ rff/d//vb//399/33vz1/5vX3f9fv//+/v3/72f2/+/9///v6t////v+///63f//3/379v//7e// /vfun0/3/u+33//+/e/2zf//993n9/0j///XX/3/3/673/+b3f//z/7/d8vv5v/332/vX35/993u 39mfH9/X0//9/bvL//++93vbyzf/L9v2/9/+/9//f///37/97tv37//7fT3f9//fvv/a/9r93r// /97v9//+//+V91f/X6783vf9V/7/V//3tvff/PylXf3fbv7fbwAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA ///+NP///9YAAAFvAAAC9QAABI8AAAYuAAAG4QAAB2oAAAdqAAAAjAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAz///////////////8AAAAr/////wAAATv/////AAABOwAAABgAAAnE AAAAAAAECqwAAAAAAAz3+gAAAAAAA0L+AAESyAAF0uIAASZsAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAABAAAA/wAAAP8AAAD/AAAAAQAAAP8AAAABAAAA/wAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA 5gAAAAAAAAAJAAAAAAAAAAEAAAAAAAAAAQAAAAEAAAaB/////wAAAdAAAAA/AAAAAAAAAAAAAAAQ AAAAGAAAAAwAAAAQAAACnwAAAAAAAAAAj0BBAAAuAggBKgAAiMIEAAAIAAAAjQBAQCIIAAFJAAAA QAwCQAgAQAQAAAIAAQAAQAIBAAEEiAACAFEAAEQAgAJCBAACIQAECUAAAEFSIACCAAoCAFwEAQYQ MQIBBgAAI4kBgBAIQAACwQEAAhYAAIyoCAAAhARCG8gCEOSYQIEICIwCAQhAEEAkABAAAEAASAQA SEAIQAjI2IBIFSYAAKIokQRCAQQAECWAAYSkAACoJIBAFChgAARCBAIQBAVgRBAAAQSBAECAAAAq ASABQQiAACACQEgAAIIAiADQRAgACcAABKMAAIBBAAAARAQECMAAAJAEIAACCgKgAwoAAAAAJQAA AAAAQCGOiAxJACGGyAgBgAxIAAQlAoAAQAQAAAAAAPnZq7///v3fXOv//9+d+////779Xnr/3+79 /74AAAAMB1cj9Ab/Bv/O//9vAAD6eQAABCUENgRCBDoEPfu/f6sEKX/CAJuABgPoCVYA7wfQAfQE KQRoBBgAAAAeBB8ENgQ2AAAADQAAAIAAAAAA5dd+7/3/u//j/v2r9Xdv/3//7Nf7/2/7fX//7d// /f/r//1e//9r+f+//90GiANCA0IEJwAAAAEAAQAAAAAAAQAA7C4AAAAAAAEAAAABAAAAAAAAAPuA Xu8A6wABb6uXAAABAQAAr6+vrwD4+wAAfQF4AQAAAQEBALgAPDQzAQUGBSgB9AAQAAAzMwUPAAO4 XAAAAAAAAABZBQAAAAAAAAAAAAAAAAAAb1AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAIAA AAAAAAAAACgSHu0nphvvKXgAAAAAAAAAAAAAAAAAAAAAsACxALIAswACawEAAVsAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAQAAAAAAAAAAAAEAAAAAAAAAAAABAAH9AWwAAAAAAAAA AAAAAAAAACWmAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAFByaW50SU0AMDEwMAAAAAQAAQAWABYAAgEA AAABAAEAAAABAQAAAAAAAgABAAIAAAAEUjk4AAACAAcAAAAEMDEwMAAAAAAACAEDAAMAAAABAAYA AAESAAMAAAABAAEAAAEaAAUAAAABAAA5FAEbAAUAAAABAAA5HAEoAAMAAAABAAIAAAIBAAQAAAAB AAA5JAICAAQAAAABAAAOQQITAAMAAAABAAEAAAAAAAAAAABIAAAAAQAAAEgAAAAB/9j/2wCEABAK ChAYKDI8DAwOEho6PDYODBAYKDhEOA4QFhwyVlA+//////////////////////////////////// //////8BEBIYLmJiYmISFBpCYmJiYhgaOGJiYmJiLkJiYmJiYmL///////////////////////// ///////////////////EAaIAAAEFAQEBAQEBAAAAAAAAAAABAgMEBQYHCAkKCxAAAgEDAwIEAwUF BAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0 NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKj pKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6AQAD AQEBAQEBAQEBAAAAAAAAAQIDBAUGBwgJCgsRAAIBAgQEAwQHBQQEAAECdwABAgMRBAUhMQYSQVEH YXETIjKBCBRCkaGxwQkjM1LwFWJy0QoWJDThJfEXGBkaJicoKSo1Njc4OTpDREVGR0hJSlNUVVZX WFlaY2RlZmdoaWpzdHV2d3h5eoKDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLD xMXGx8jJytLT1NXW19jZ2uLj5OXm5+jp6vLz9PX29/j5+v/AABEIAHgAoAMBIQACEQEDEQH/2gAM AwEAAhEDEQA/AMiFs8NyO1PdSvUZHaoAltpApyUaQDoucENWvpd0rEllx0WFQPuqO1AMfPqrAjbE FAOX8xgvmAg1natYG5YfPs77Bk/eIoJK0WgR/wASysOVLBc5K1ft/CitzHaySj7ycqMe1CQG1ZeF FQ/PLsHG1F/hYVrrZQr/AAA/wkHviqsA2RIh1UemPTGayb+zs5vv5Qj5dwIyKfyD5mNPo7KxFvKO glJcgBlYnipbNJ7U7jc27fwxKDnLNUvyGvMc/iVs/NMAehcE8dazrjWQzZMxz90Ag880Ngl3GPq8 xOBcOT0T6mpoNPuJj9527SMw6CgZZbw+yZ8+chPvFkHTFQCC0U/vJLgp0yBg7wKQzCF7KP4wP+Ai njUZT1Kn6gUCNS0tbyZQ0UkCjkxgcEbWIqaexvAuZkibGZWLEkgKDQIrwT3knEXr5mFGdzZrYsPD WovzNcrb55cAc0xHQWOjW8IwA0h6lnPUmrvHYfSqAZJMi/fdVHRie1ZVx4jtAcRymRuwX1oAiedn OGkwPvhgDy6npVORB/C29vuyZzy9K4EEkiYyAP7k3tJQpQrlSOuwEdmKmpGZ0v2Zuhj4/i44qp9k h52TDHXaOfmFK4xdM0+YyKRcIRlZDGoOTgiumuopwBthuXwdwAwCwXNMCSaWZ0bYiFsbZYNpJUsO lU7XSZWUl5GgboqbcYC1QHE7vQr7U+JC3R4x7k1IHX+E7SZovuhsMUDDpt4rpE0tSuJzkfdZR3Bp iJ7WyghGLaBI+xIH3sVK8gUZY4HUn0AqhFO41WJf9Wwkbrhf7ueaxtb8SXMYH2ZEUn5V74AoE2cv 4hu7pWXdezsSBOTnG1mAq94aluJG3TXMsu0GSNXY/PKQcCkBY1LUp4yu60mbH+vZgRvHpUlr4gWT H2u3Vcnyrb2dAM1m2Mhh1B84mnlKn5JOTwD3qU27rEdynhx8w/jAXrVFGNcYAOB1+bA9+1Zk9wR/ q3GP4if4nqGhMemqyKMRs0a/e93NdR4bs4bhM3UEhOdqMScOopryBFjVNHtIlJigwThVbJ+Uk1Jp +k2jKpliUkgs2SeqtWiGY1t4EvnPzrHEvUsxzha6ey8F2UY+cGRum5gMKTiiwjVAkj/hV06ZX+BQ KZNqUKfecY5wR6g0xFKXWJT/AKuMA9Nx74NUzK2P3rs2PlwewFBm5dmRzMD0PH3h7Vi+JbSRlVoi GQZjuFH/ACxdzxSEinfMGZSBHIcKoRh95lUcV01iEt4wsKpu/wBZcnaOXNZxZsPa6dv4gB/EgqpP brL/AKwI39wso+WrAg+wRKfmw3fb61oJeNJtDKqqOEQDgDFAGDrVssX+rJwThQf4CAawHgRvbv8A Q0hsveFtNhmmxcqGQAyKCf8AWFSK9BijVRiNFUDhFA4UUAirqtrLKoESZ53Ox6IoFS24RAoT94wB iV+ikmqQG3imvKo6mmIpz6ki9xXNayVc5hLAjlkHRgaTJY+LUF2guTnv9RUEuqj+CMt6UmzFLyK7 XszceW690PoaTS5pI3PnQvJGw8m7Q/xx5qG30TNIoDp6LJ8pVkX5oHH/AC0zV0TD+I49zVRRY4zJ /fX/AApUK/7Z9DzzTGPZQRkYC/8AoVOt4iTwOew9KBmZr8QYAFC3OSBn0rLttMlcf6Patk/MEJ5U IKiV/sgyVPCeoMcm1jhXoZmdcISa620vEjUCSaCVwNjydAMCiKfUSKms3YYDZeI4GXlTJGQBVi31 20KrtLsMDaCPatUvMPkXbnWUH3TWXc6tI33TimIqNKx+8xNNpMBjsV6AHtkjvVhoyOsbDv07VIDI XA+5uU9DjuKj8s5OHkJ7LzjrQFh6p/0yB+o61PBIV+9CuO49RQOwTjd/q02juSeRVd7Anq+O2RRf yCxJFBs/5aMR94ZPerNo4By0wjAG5m/u0DKiW005yqMkfRZpeAatR2scf+otzO//AD1m4VSKlP8A 4ACzwzPzdyu4HSNB90elR+VaL/rlmi/66grTSZQt3o0Egw7TIP4lU48wUW2nRrkMhwDtiX+6m0Ur jsVihPVqUR+5p3IsKEHvTtg9KVx2Guq9wKdx/CPrSAAR3pQRTAN+OhFKHB7j3pgBmT++v50GYdmH vQBA1xuOFBPc4qzbWIJBcq3dVOCAaGBo5z99ix6ZJ7UnmD+7SGQ3kkmxvs2N+D5I9XxWfp9u5i23 iXqZyJHjPKjdQmDQlnDYox/02WMjB3yOwMxWrWtTzKM6a1vNkjIJyBGExVCOXWVh9x3Htmnfa5+8 8g9MGuS5PzF+3S/89pPc5pfts3aZyfTJ6U7+YX8xrXMzdZW/OrWlXixvm4VpR/AGzhHyOaE+4X8z ZuLsv/FHjqNuMEVz9vNN5pDShRna6k9d3St7lGy2n3DD935UYPDM3VQabH4Yt/8AltPM56kDgZpN dx2G3GkwREEQxlD+5l4+4D0NTyacgHyPcQd1GcgEUwsUJxcW5L29wk64xdRL1ZR3q4mq5AL2sig/ MspGQENMCzb30T/6u6jPtnmphK3aMkddx44qSg+1DuGA6lz0qKTUrZRmS6ix1C0AVTq4k/49LCSb tvPAqN7C6k/1jw2y9dsQ5qvUXoYG4dl/E96RifUjuK5jICxPfHuaIQ7HEW6U90QEmn6IDSttEvG6 wrGOoaQ1ftvDaj/j5uGb0Ve1Uo9yku4uqeHo5ExaRIr/AMMrk/KKzbbwlcoQTdwxkcqyA5BrVDt2 NOHRZv8AlvqN3J6YJGRVopb24ztiX1dmOTSuVbuZmo6+jqRDHkH5Wd6otrV5jH2l8dBjqQKfqIg/ tCbOWllJ6Mdx+YVbsNUnXi0iZx/BByckinYRoS6bqkoy2iQc8lmwCazpoNSg+9BcRKPm2jJVKdh3 KNxeTSH99IW7n61DuoEWP7RuOM3MxxyoJqzDr1wuN0jEfxnu4osFxsej3L/cicn16Vbg8LTH/j5n jj7gLzxWCQrGlb+H7JPvRNMf70h61oRIFGIo1QdlUdK0SKSH7DS7fcCmMR2QffYAdSSelULjX7SP pL5h9EFSMzLvxS5/49ohH/tnk4rInunc5ldmPcmmIiL00tTEXNI06a6cLb8fxSOekUY713llBY2K 4t8M3/LWU9ZTVoTKl3rEr/6v5B61QkupF5ed8dWOelDY0jmdRu/NcnH+yD/eAquD7UhGxp8MjLif TVkHVJn+XalTRaNGeYlU90zyKV/MpLyN9Qe/41IAO5pMQm5e1I0mPQdyfSpKM+78RWyfdcyn0T1r IuvEty3+p2RDtjk4ppdwMya6kf8A1srufVj0qIv70yRN1JmmADPYfjShaBFrT72WBswnHGyRf76E 9K201u0I/eTCM9SrdqBoguPENmoO24LHoAoPWsq91szcRqyr6H+KgLleN1P3kcn+HB6V0mmaTPGo IliVj8zxsgOM9qGCRcL3g6xWr+gUkVC87f8ALbTZlPQtGQSRUl+qNIse3FNLDuc0MkgvtQSBcsCf 4Y0H8TVzN9qs83+tkIXtGOgoSBspk00mqEIWpOO9AAD6ce5pwUfX3oEOxUsNtI/+pid/XaOlAy/D 4eu2++ixjoST0FWLjwomw7Xd5Mfu+w31LfYq3cxU8K35625/EitK18HTf8tpokHoOSKq5KRs2Gh2 0PKqXbqHbsavlfapLQ0ikC0hjyv4UzA9qbIRU1SyEy4BAb78Z/2hXJzROhIkUqw4YHtTQMjoPufp TJEwe3FLt9PzpgWINOuJP9XbyN6NjitC38MXB/1rxxjuOpFS2Ukaln4etk/1oMx/2ugrTSNV+4qq OgA7CpKsKRSCgBaKBhSEmmIT6fjSH3oATzD7n+YpCh7Yx60EiAVXvrS1f/j5QE9I8feNIZnN4YVj 8kskS+jYJNOj8KQj79xK3rgCquKxai8O2a/eiZ/djVyKygT/AFUESHpkClcdiXj0ox+FIoUA0poA BRxQIM0H3oAQ/WkOaYAFPbNBwOpoQCBcdKHkVfvtt7D/AGiaCSI+Yx6+Svr3c09IEX/Vjn+Jj1am CHgeppRUlBRigA+uKDQAfjRQMA3pRmgAz703J9aAEyf8KXA/GmIcKY3+RQB//9kAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAA/9sAhAAEAwIEBgsOEQMDBAUHEBEPBAMEBgsQExAEBAYIDhgWEQUGChATHx0WBgoPEhcdIBoO EhYYHSIiHBQaGxwgHB0cAQQFBg0cHBwcBQYHEhwcHBwGBxAcHBwcHA0SHBwcHBwcHBwcHBwcHBwc HBwcHBwcHBwcHBwcHBwcHBwcHBwcHBz/xAGiAAABBQEBAQEBAQAAAAAAAAAAAQIDBAUGBwgJCgsQ AAIBAwMCBAMFBQQEAAABfQECAwAEEQUSITFBBhNRYQcicRQygZGhCCNCscEVUtHwJDNicoIJChYX GBkaJSYnKCkqNDU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6g4SFhoeIiYqS k5SVlpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycrS09TV1tfY2drh4uPk5ebn6Onq8fLz 9PX29/j5+gEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoLEQACAQIEBAMEBwUEBAABAncAAQID EQQFITEGEkFRB2FxEyIygQgUQpGhscEJIzNS8BVictEKFiQ04SXxFxgZGiYnKCkqNTY3ODk6Q0RF RkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqCg4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqy s7S1tre4ubrCw8TFxsfIycrS09TV1tfY2dri4+Tl5ufo6ery8/T19vf4+fr/wAARCAaoCOADASEA AhEBAxEB/9oADAMBAAIRAxEAPwDjbTx1pV0P9F1y0fHLZbv7E1etNcVfuyWksZ/1mSvzL/8AXrnc fIuM13sXZNE069UbNMsm7lSo4wf61h3Hw58OnIuvDNicfI77ejfhSu+jZop+fkYt18BvC0o50RYj /C8XdM9wfSqqfsu+EJhhJ721foWBB8w/iKak+mpafeK8jL1D9ki0hP8AxLPFN9Ev3sFem09Miqc/ 7OGupg6V40OB9wOxGTn0Iq+fuhOEf5WRDwD8SoD/AKHr6yjpkuMAe4I7VaXTvi3ZnL2cV2PvIwwd wA7YAp80exPsu0hZfjh42XA1TwJHIw+86huMeyioIP2lbpGP9p+DLhR1fG75WH1A60cq/mZDhL7B cg/aj0Uj/SdKv7V/vE8nGPTArp9O/aa8IzjGqatc27dY3aMnP+8aXI/s+iM7y+3E0Y/jD4c/5d/E 9myfw8nofUY9K0k8X6bOB9n1eykU/cJYYYH2b1rKUPItVe6fmXkGlzcanpemynorlV+dR6YrIvvh F4ZB/eeF9OkHQMFwVPvihX7tGntP73kYl18AfB0pJj0MxdgI26Z9M1mL+yr4WmGGvL62brFMmPlI /vAjvVKZrzLrGPYq3n7I5t+dG8Y38YPQnPzDHcL6VQb4B+MIxnTfGbSkfMSXI2MfQEU+f+ZIzcI9 UxV8J/FeE/uNTjuu2GZSD/vKQOtWB4r+LGnZN34cS5A+WUBRjJ/ukCq5o9EDofy1PkVn/aU8Sx5/ tDwJIrf8tDGG5P8A3z3NWbb9ra0K/wDE08LXcL9GdT1+gI/wocV0l6GPJP7KNvTf2r/DOcXBvokP Jyp+QfTFdHb/ABr8KyjOneLIOeXifI8sn1U+tTKm/ISm/txfYtQeKtHvQQl9pk+PvBivyjHo1Sx6 D4fmwLzQtIuB0S4ULlgfVgalRfS5rGt3kV7z4E+EXznwnaY/iK+n1HtWDP8AsweCpc+Xpt1FngFW /wBWD/dGO31ou/5mbRqLrymb/wAMd+HnP+i+J9ShPJRCo4/EDtVY/swX1sSNP+IWoRqP9Vwep9fp Ve0fVITjDrEVPgh48t9x0z4gBh2ckfvD77hTYvCvxkh+5qNjcAHdksCWx6cd6r2i6xIdCP2ZNE7+ L/ivBxqvhG3uj/C6Yyyj3H+FQSfG3xfbn/iZfDaYDG47N2cj0+XtVWj/ADPuS6L+zUTGwftSzRgf bfBupRkfLMoB6n0DL6VsRftUeF5R/psWpWbjhw0TH5vqBUuP8jRPLPrAvaf+0h4YncLDqFyCxCQZ ib95IxwO3cmvpHw74M+zKrai/nTEeZHCeluPf8KicO7XmaRlpeUbfZRb1TXwmTJLub1PYVwmu+LT gkOAOjH3PofetYr/ACPPk+78zxrxV4muruTZYQhs/u3kz97J/u+xrt/C37Ot5axLJ/Z2Qx2LKR96 Vj3AHak9zpoQ0/BH0r4R8FWeh25a+KRyEeZfzN/yzUZ4De1eW+Ovi19uYbJjFbDi0jz/AK3Hd/Zu tVJ6a/IwrO706bnntzqsT/6uUY6/X/8AXWTeRq46gjvjsa8/09DZGTDp/wDdT3yf7orf8O+Erq8k C2EbFj88g7Kgz1NdN+4Rjd/me6+G/CVvYLtiTe3/AC2l/wCeh/8ArVvHBPysMch1P8Lf/Woii6j7 eiKqRhT34/XPrUypKRxlf9r+8lP5ECAAfckwehOOq/WlZMg5YEdcf/W96LBfzBUHtjqB6UyR15wF HovqaLCbImtHXJMwwOfLH8J+nvURvblz/qhs/wCWkn9wH1+tHqHo/UljUNnymIB4fHUA0txIqnEc YYY3P/sk+hpDsSpArfe4XsxqMopJLuw7RgdFX/69L5lfImitG4xyOgPr9TU4tYowcRLjsPc+/vTQ My7mZud4Cr2P+19PamkOf9WcDqo9aGSkSi0L/efJ6VWe3yfnTIHUepz3PtQUl3LCRDAMvA6cd6zN Xg8QbS3hGSzacfMtncnC3o9C+OM0hNd35HJyftaXGmN5fxS+HmqaSgOHuoAZIpkPrIq/xfSsvVvg h8OPFheb4ea3FpOonE1le6ZJtZZDk/vrckYyeeg56d6zdvsvyBpr+Kk0V7f4l/F3wS6nxt4fPjDS l+UX9if3gtz3eJFzmIDPIx2zVfxnf/BrxtZz3HhXUItF8RJho4wDHLJdK3Kz2xwG356gfXvW1O3V 2Maunwao+bPFUmv20YTxRbLdw5Gy+XnB9xj0qj4S1TVdMnWTwXDDq8Yyb7Q5+k8G07ldB/sZPHI6 9RWN+68iY+T84vsbU2kaFqz+f8L7q48La0pLX3h+RtqSADJNtcNjqeMY9+K5HWNegvmDzwPousxn Mlxb5AuLuInncOhY/h+FNeXqKT7rXafmTeIvH39sqja/FFFqiAIupRD/AJCCJnHmgDqP88VmR+Gr uU7mkt7aUHEnmsB5gz6e1TOVuhdKP8wXywQNm0m8w9boJ90Sex9xTV1SCYgSxGIdY3B6/ga57t9P MpN9vQv28cyj/RJPMX+Jx1Iz0Iqtcx203Fwzxv0Bxwx/2vrXK32+Y2/LzZXFpeW4+Xy54+4BzgEd xTorK2lz87xP1EJHY+j+30q3LrD5oleXqVbi1MXMMjkdG4/iPrU/9pXLKPIRcj5GX/norZ6/Stlb eXzJ9CtbwLISLqAp3x6YB7e1SWcBhP7iTcn3JFz/AAt6Cqb7Db7lq30RZHYLIqqFafcO7Ip4/wCB GobDTzO6qX2ZIVnP8C+5PtQvQE+79SbX7+NppFtm3RqfIhc/xqn/ANf6UaV4RuLlGeRfLtF+S4uy OPNbOAg7kmna3QIpdf8AEZtnHJvxboXPIx/sAHOfoKqtkOflA/hI/u/Wt4k/0jT06zkuiFDBYwfN uX9Ix7+9XJ/GiGTEaj7IM20drjIWM55+rf8A6qylHuOz+yvNle8SSzYqyExH57WTHWMk9OO1Zl5I R/qyPXPtRT/4cJJ9UUyHfluP6055wgwCPQAdzXWkL/hzX0zSlD7r6P8AcIDcXxP8L4OBx3Y//XrB mmaViZMZJMhA7KT2A9BTg/8AILdvURWwRhqvmWORcSBzzvjBPCNjsh7mtGg+RavtUE0aJHa28QQF TMg+act/z0P+zXpl78Y9JvdIhtI/CBspoG82PWgxxfIS2QUP98nnk/kRjJpfa9TRSf2V6+h55f65 M8JjM/7rcLloezypn+VZcsxY5Cqo+6VHcj0HvVx8zK3b1JFuW6ylm7KPX8qm2SStl0CjrGijoAKU rFxi+iZ0GmeC72fH2Oznk7hUU/MD9BXZad8DdWVx/aNgLeLo8krD7pHdPr6kVxNN/AvU6FD+aS80 dfb+BbVYJkfWESVik+jyxLzEI85BOP4s+vpxWzrGmw6hp9pbyXN3JPblnN6EP+kCVj1BHcH/AOua 6KVFLqvIhyv8MH2+QWXwHmkiK6hcywxnH2eWQAeSv+yuP4j7Vdh+BOiRACfV7y+UfMFRQvzA/wB8 j+lbqk+tu7E6qW0UdQNfNvbeRD5cdoOIYXOcxHPDn3z/AI1jt4u3BUl1R/LBwiIvEWT/AAgjv9a3 SXRI5Xfrf+Y7Gx+Fuj3q7v8AhMHmQAu5YkAYGcbTjqP/AK9ci8uhxPjT7N9XfPlrEmQMnpulx361 EU+stDZyjtSp67s7TT/hp4rmUFmh0S2b5WhtwGYgE/8ALQg98n61pN+zjpq8i+N1KeTJcAncfof8 KznVf2X/AME6YU4rfV9X2JZPgDLIv7nUYYuyxqMfN7cVFbfD7x3p4B0fXXQfdjjbYRtHoCPaphU/ mimXKEX1ZteFfGfjJrqKLXo7eSEkpcOFIKJjnLY78d6ZD4z0zRLu6F7bSLGz/JPGhPk7c/wDPUmt NH8KXmcrg18Dv2Ou0f4maFd/8eOt27H/AJ5uNpJ90YVx3iSP7DqymN41SQLcSIh78g7gPXFHJ5Ex qd0z0mWLyyfJJI6p7596iF1cKh8jyw3Xa2OVPqcVjbujdPzIJtBsrkf8TPSLdyRuLAAEk+hHpXJ3 3wZ8OzYA00Rnk3UgA4Y9MAj0pOP8rfc1jUfWzOeu/wBn+3gOdB1mZJB91FH+rLf7OKhlg8c2KgTu L6IfNHG4wWX3ZRW0an/PzUipSi/hVi1ZfGy3Q41/Rbizb7okGSFA9MD+Ku1sPEOnTqDpl7DcKfmV QeQR6rVuP8jOW7X8ReSZef5VBKjPoO3NB1R+iRjb/E3qB6j3rE19GSW0keegXP3F9KsSK4/iHoB6 fjRYCJGI5ZiR0I9fwprAoCQfdV9c07DI443P32Zc8jHpV2GHI+R8HqVPcfWk/QpL/gjQhH8J9GHr +FSyAfw4z2/+uaAIdhLd/TPqBU0MoXPGSeCfQAmgXoPEmMb1JB4IPp7/AFpJEQDIAXsBRYPUgZf7 u1f4nP8AePt9aRruHPzwM5PylR0x707D/wAJFsBPCbP73HVPpWZrngzTNQUjUbZXb/VxTKOYhjsR 6VDRcZf8E8i8WfAC9swW0t2u4R8zEDlDz1UCvOJtPkU/OhGOCD2Pvmqpy7hVp9YfMqyxHPyZ9Meg +tQSW7L9z5v7zelatf5HIl/mMMQPcHv9T/8AXphJH3VH09/asrf5Ft9hdqnrnPULSPYwS4F7B5yD kxN3J/xoGn2JdY8Mee0Z0G3NuFGBt6ocn+LHYVXuPBt4ATfSuSf9Zg/wfl2FDv0TN3JfaaJ7XxDp mnEeTq6Rdnic53nHbjua0r3x/ZXCfu7iQfxEL3GO/FaLzOeb192Pqc9Hd6Pj/R7Ug9XkkP3zn0I7 mrEeuWxP7qwt8j5SxGeD9RWc2u7NYyfbyZFNqF0chI41X+Abfuk+nFVf7RlUf6YTjsf8iudy7Gko +fmQS3Inx5ZYqOhI69f5VueG9I3Pyg2/ebP8WM9vrWi82R8jtNXvwkTncg4Kf7xcH7tcBMSF/cg7 j8qAfxsx7D3NFQuPp5o92+OwFhZaXaRsQyR/2lfxg9ZEX+P/ALaGvHx4ruCf3iK/YZ9PcgVdV/5k JdvUsR+KIT/rIWA7f5xVyPV7N+jqPVSDx9OK52uzKbfYbJoNpKP3Lqp6t2zn/GsS78Lypny8kcgS p1JHoMdqbbKTXVeRCly6Y86PzR93nqo9h7VqW1wHGY7og8/IR90j6jtW1uxD039SwlxeD7yo47Z7 L9AO9SpdEn97pkrnpGyA8Mf7uB3rNvuaKP8AIzq9C+EXiLURnTdMmij7y3J2hFIPUsO2K6eD4UaH YD/iqvGCFhzLZWibi2ewkx2HtWsIPoRKolurve3Yur4s0W1/5FjwdCccf2jeHkgE8iPH+FYWu/Ff WLvIuvE0yJ1a1tlAA3erKO31rd2Wy8zBpv8AifJGNoPw/OpGQ6fZLPsU3WoTyn/VIAf4m7kA17f8 HPAsAtGbz0iDybZNoGXEa8DPoDVRe+vkaS6aeVj1uPQ4hjCZ7Zq/DpijoBTuZk62fr+XpSi09F/G kAq2YHan/Zx7fShhcUKAeuPQ+lZXiDwRo2rpt8Q6XDdL91JCMNEf+mbj0qWjSnUa+Fnyb8RPgXNp 13IPD8bTwA+ZZxk/NBxnCsP7hOKqad+0X4zsYjEl/PLB/q3juAd6Y7JOVz0qoSt8RrXpKWsF/e9D 2r4Pat4NvQHup7dtVOS1rddYWH/PMN15z3Ne0XErEjcMf1+laSX/AADgjU6SQzcPapBMvcj3rM1u Ne8QdxUP9pg/dB9qLAMkvnPXj6+lVWuznlqpITPLdVt0tNS3FHwWEjHsUf2rv9Usbe+hkju1UxuD HuP/ACzcg4IPsaprTX0K5tfuZ8oW8U2l3UiX5zgnTrkt/FHk4YfWvWfB/wASjZnytRmPkn5Y2Y/6 lye5PappeY8Wtfd/xI9OGtQkfI+R1Rh3Bryb9oHxIFtYIyCfMkN0Qe6QKe3tmm1/mKi/8z5R8QsG Y71yPu49MZ6VJPaxpGgVApPz/Tk9DQl2HL/gn0v8CNYEViVXaU3MWRv42kJzuX3Fcj8a/BenJNG+ jW0VpuGbuNBxNcAnkj3FFSHcWGqPVHlAnkhY/KYn7uO4FerfDD47QaaXXXt5jbAjuk/5ZP8A7Sjs azhLpL5E1YX+D19T3C38W2d0oOmXkdwh5Dp2B9aju9aK/dJ9K1sRGd/yZWh8QlhwT6MPf/69MutV Y9c46/hSZaQ6DVWHT8PpUN1qjlhjj196BJFgXpA5Y+5qnd37A/fOP4R6UkURic4+d/8AdHqPekk1 Dd0b2B9aLiOL+I2jpPDuCZKkeYf9g/4VF8PPE0k0RSVlyhIUf3oz3xVRYqvT7jrLnUVTlnJ9PpTb bWQw+UkjqKS8wuLb6oWzuIA/nU0OsFO4HoPWpZSRQudcYN8wOfvAjuPrVCbxC78Nyv3sHu1UTbsz C1jwpp94OYVjk6mRR98/7QrzvUvB1zak7VLjPyY7DPr7VzyXb1O6nNP4kc/cRIx+eNv94fwn6n0q pLaOPvPuA5WReoA9RWD8n6FtCPdv/wAvILp90Sp1UD/Z9qrsCR8mGHqf6iuinLuc8o/5I3vD/wAR b21Yb8yoPlMbnov+y3sK9h0HxzpV7n+z5FWQ8G2k4KHHIBNW/L0OW1t9itrlutzC6bF3DLxY/gmU Hp9a8I1r4i3lqrf2VNJHcYNhqiJ/y1tz1U/X6fSs3/w512ujnDcGQKWRlJG51P8ACTVYwEnge+fa ob7Al/wTZ1mxB2k5OQAWI9R6+1UreEqp+U46H2PP86hPv6Gkl29Du9I8Tu8YDkZHyD/ax/hWnPqA kXBxk8Hcex9c+ldFzliv+AcfcRbDgjI5Cn1piSgdSfb60XNV/wAEmtdRMTAq7A/dbH90/wCNdVBr aN0f2Yn1NUmYtEcmsFG/dzbyPmA9Meh9qgfxCzZ3kk9S3qPpSb8jT5+QNrZI52+g/H/Cqp1c9mxj 75PelFisNOuN/fPqp9Khl1IMPnyfQntihopEMd9Gw/eYYdAD/Cac0UkYzau0q/eMX90+1ZFJ33Qw 3Rb7uSerhuo/D2qM3B7Z9F9se1a/8OTb/IDOxHQE9Meopwkb1wfT1NJD5fMcFY9APcnuK3NERACc nPRR6gj19qm4kiHUZ2Y9T+PY+1UZN39cjvimUQkk/eB9PwqVVH8B+jehFFhadURlHHQ57Mx7n3+t TquejZ749f8A9VJeQf8ADM5Kf9lzw+SfKu72PsHODtJ9sCqFv+ydkkWfjCaFusBYYBC/32Hr9KXt H28jVqP2kP8A+FA+NbE50jxoVI+4AegPoSDTZPCPxWXPk67Fc95TuX5yPQBe9CkuqE6a+y2Qf238 UbVT5+mrcD+LABIX6Y7VG/xd8bxqGuPBrlf+eyo3zEH+JQO/0oSXR+RLpPpPzL8X7VV0gH9reDLx ezMobp+I7VOP2qNGPXRryL+I5B4HscUuXsyWpdkaA/aT8KScma8hJ+/uQ/Kfy7Vu2Hx+8NkgHxDG 6fdTzBjAb1z6fWh035Eqo/txfkdEniHSnG7R9ftZFPJVXA/8cP8AhVd7u3mJ3zWUh4wflO7Pofas uXyNI1O7fkVn8N6SSTe6Dp1wP9XMGjH8Q78U2f4G+D7pc2/hi1Xurx9Uz6fWqbfdmkanZrzObuf2 Z/CLf8w+4gfoHRu5P90jtWRefsm6KAfsuqXkTdVcAdPaqVR9C3brFCwfslXJAOkeO7lZOu2QEFGH 90j2qGb4QfEK14tvF6TgdFkIG765H9afP/OvIzdOPRMqyWHxYtTl3t7hegB24Ye4ApR8R/iErH7Z 4TWdu4UHp/s4FO66K3cyVF9Khbsv2kdZtSP7f8H3yxDKy+WrY3f7TFeOae/7WGkk/P4c1CPH3xzz 9TinyLowcZ9Ei/H+0z4WkAy97A3SUMh/dke/tXQab+0Z4Yc7T4hGw8iV1Iw3uCO4qPZvy7hKb+1F +Rsv4w0uXB07XLOdTwcsOp7Yb29qZNpthdg+dY6ZMOkgAX5uP4iKjlfRD9p5+bKJ+GnhOUAal4Vs CPu/aEHID+jCsrUf2XfCh5TSpkjPEbRt2+mO1Dk+7Noz7cr6nO3X7J3h9ubTV7+H+7GACVHufaqs X7KN5z/Z/jh4yOIEYEZT8BVqq+qFyx+3Fk7/AAb+JFjldN8YGdewd/un2JB7VGdE+MFuQftcFwBl eCp3L/tDHaq9pHrEhUF9mTQz/hPvilAcXOgpMPvxgJwMe6j1qeH9pXxjFga54Aef1lRWHHsVX+tN cv2nYToNfBO5LJ+1LMmPtXgTUkH8bAtwP9kbavQftZaMx/0vStWtRj5nK5+Yeq4o5V9l+QlGfVI2 Lb9q3whPxeX9zbt1EpQ4b/gOPX3rUj/aD8KHAj8WRkdEDKQQPYkdqUqb8iPaP7UH2NWL4leH5j8m taZLn50VtvzkfWtEweHLzHlx6Q7f8tIyEzn2x/8AXrJxfRM1WI7uQ7Sfhn4bM6MfDtirqweOeNfu lfUD/wCtXq2q+LkTO2UHPO7+8B6U4+b8hYmpotfNHmOueNXDEvcYToiH+/nt9a4HWfFlxcHbbks5 4EQ7D1Yitjiiux6p8HvgA1wwfUkIjH7y5kPcnPCV9KPFawoN6xxQINyg9I1X1NOmu5115WWn+Jnj njn4ly377bYlLYZAX/ns3+0PQ153dxRN/rUV+4BHc1z1p9vQ5qK79feMefQrXvbJ65x3NULnRLYA bIymPuFD3+nua5vmdbfkh+nabJK6rECWJ2RxjuM9vwr3Dw34Hh05RsVlnPN5MPT0z7V0P/gkw7/9 uo6JHVfuHPp7ke9JJNIv+pAHG6X3U1ov+HM2RJ5mTtjY98nsp9/apEdmzvJUfwgetIdiKUlfurtU clh/GTSLek53xg/3SP6ii5LX+YQ3eT8zEdiuOhqVrdX+6On8X9xz7+9Jf8ECKQITh5mOf3jY9VqJ InYHy5cg8D/aB9RQwsTCMxD5Qf8ApoPWr8eklhxtJPLY7AUF27vyLqaLKRjytw6gHuR71LJ4ZY48 xBjpsz0Pv9aixZLd2Ztl3TINn3VB7k/T1rKuLwSZBgkQdQT3+h9q1SMW+z9TBhtniZxcK8q9VZuc 5/2fpV5yVTIaNu8a+imlbuNoZHJIMbUCL1z6ikmUNnY4TswHcH0+tL+kJjkt7iXksm0f6qIdgP7x rF1rXtbszmx8LyajFxuMLgMjZ52wn0HvSv3T7FOP8rM2y/af8MO5j8TSz6S/+qlsdUhYKcnGPMZc cn357Vm6t+y18PtaAk8MyppF22ZINW0eQdASfmgBx19hUOP8oKbWlaOmzMnS4Pjh4WkX+xHtvGum R5ZLSU4la1IPEQxnK4Hr6DtXB/En4i/BvxTFMdc8I6l4M8VgqbV9jL9ou1PP2h8AHPI5UHOD0zWl L+/p0ZnOLSvRd11XY8Q1c+IbGPF3fpqlkSBHcDnAA9ueR25pnhnStK1GdBp3iZvDV1nMN6/CLOBk bpOMbj/9fismv+AZxt203fkT/Er4eeK9PcHxfYW1xnEtlr9kQVuYiTgsyDgkg9cH2rhLqWR8G4ck /dSTucf3j7Clcbh2d+zGi7UgCdA3/PKVeqt7n2psaxyH/SpWGPuuBnj6e1VYI/8ABL6yKpItJUZT /rA4xuP0NMjsEc5eJ4mBzGyd/wAPeuXmNL9/Qv2tkU3eTdEg4liH91u/Huas3l3bEYuAB/CrkdT7 n2Nc03fpbqRfsimtysYPkkMnTI+np702WWOUfIwR+oA/iA9KpR8vUV+3oQSazMFxcqSCcsR0c+uP eqsV+yHMYI/vD2Pp9K6Yw8/IXoWIryOVh5kmwdC4HIz6VLcaLJFzFG0qH/WSAdFGfvcVO2/obRhf 4UOjhmiCtBCWRlIVvXOeCKTTmidz9olaHALbh1DKp6D61cX2fkTODXxLzMzjOJOOcMw75Pr711Uy apqEfk+GraY2CEz3SdA820klzjtj2zVza6jhC+i9X6Fe08Fzx2++2ZWuGyvlZ/494BnJbPov4elZ 2k+CZ7zzGglRYU/107H77nPCA+prP2m9/Q2dNdze0/TbeAL9oVVi639unW6x0yfRfTPNbqeKvB0J f+1fAsc0jYOmMzHFqBn/AFoUcl+PTofUY5pO+zl2JVW38NLuch4h8W3F2R5iQBFHlWkUYHyx/wC0 fU/n+VcxcSA9F2no3vivQpQOdt9X5kH2ooDgAnoCf4c+lQwg9+nXPvXUkFjo9RvIorZUglDyyf6V qrjssedq5HoOf581Q0m8trYO06GSYjytOiI/ibOST/0zH4+lRFAk/sr+6jOUMclEkbsMKep+gq2l jORlYJuewQ5GPUYrX5mvs31XoaFh4c1CXH2bTrmRz8oUI3P44r0jSvhL4wa0kjvPD9tbRSMksGp3 TANYhCf9TGRn950/n2rKS7rzNPZ2+OVhT+zlpcEbHW/Gg3KN0UFtEW81vTcR3+hra0T9n3QJgvla Zqd42MtuYAEkdeB/D9adu9vIakv+XcPJtnTp8AvBdmR/atjGknVrVSWI+uOOB+tPPh/wtAf+JT4P soSORcTfNux/0zx3odPu5ehDrv7FvNk8PjX7Qr/Z7uMRpiO8WFQohL5xkKB1xUVjJHcviwhN0x+Z ImzggerYpc3oujFGHk+7Z3CeBLaF92sztAMeWukw4JLkHlpMfwj/AOtilbXLeyGLOJLMD5IpPvOQ f7z47VuoLr8jCdXpH5+ZkXficSwXDWzs10m1tJaXn7UmDnant09fY15Nf+MPENwT/aOpXWR8m1VA 2L/sKq0nN9V6C9mn/ketv4fhutFtv7NtJGv3IdJhks8aOw+br29RXTL8LdI0oRN4kupJ7krltBhy xuLg/wDPVkHHlZHc5rCCber7tnc5JdNfgghnirRdTaDzNVtIbG0/1VjpEZA3pz/rTj+Lqfy6Vh+F 9I1HUEJ0VI7JU/exBCMnb3Jx/e/ziqnWXRPsiKdL+eX+LzOvtPFvj2zAMzNeQY2LHKvDqP7rqvat ix/aJRONc8PXFqejXUQJCkf7OM804zi99OxEqEl/Clfq0dxofjnSL8f6BqkMjdPKbgg4/ut6VfQt u6GQ9gOw9vrRKLM4T7m7oVoqSAom08szt2wp71xugeH7C889r7ThcyGRlikbpEoJ6H3NSlodKb6F fUv2e7Cfm2UQv1XA+43+9ivFPEV+NM1KJZJZJCW/s/UZc/8AHuobAOD+FVCfST8kVOF/gSvuetp8 XZ7f5dS0maWIfIt7Dk5jXuyYrodO8Z6VfcWFyOeJI5ODnH90+tacvZ+TOK7XxLToayWjRj5JAB1G T2Udz70DUSVHmYBzxj1JrOKfVGzkujQhWMcDH9529/c0s0wP+rwSOeR0b2HtW0aL6RMXVXV+hj3/ AIXsZsnULBbljz5mP9Wx9Mf3a5DUPgXAG3eH7m4tJO20Y59/oa6IYaXTTuQ8THrFs09I0Xxhb4F/ dWd9H9ws4w2zHZlHY11CWd1/zyyP4zg5z7DH9a6pYVdJepzKr/JGRKLGUEFrc+mADwffjvUkv2hv uwNjp0P+FSsJ/fXYp15f8+2RiG4GP3XH90g9fyrI8T+NrPS4jLrjNFEuFJCkksx/hQD1p/VP76J+ sS/59suWOqfao0eAeYjqLi3c94XHGB71orqAA/1JHbI/hPsKmWCfRiWM/mXqH9rhf9Wre5I6Ae9O bUIm6nae2PSsJYWX8prDFR7hHN6OB/ECT1+lPic5+Zge/HYVzSpvrE641F0kiWRj9R0+lVJ5UbGS xHTaB0+v0rKxpccYlz8jA/w59W+ntUTyurEbwx/iwPu0hjpFkxlfmPUL6/WnKcj5cg98dh+PpR/w 4WJDOyjGOPun3z6j3rifE/wd0u/yYIo7WY/M9wB/rWwfvjHQmokuxpTl39GeM698N9Q08/6Xakpy IplHDL9QK5trIdlY91Pt71pCXf0ZNSHYrSW3qwB9R3z6Cmi1Y9cnvn1+tVb/AIJy+g1rbb1XP+0e x9qQxH2PZcen/wBal8/Mv5AJJl/1UrgdSo9aytTlkGfMdmHXHuR/SpcioRXbzOJi+G0l3L++2LGc zXD/AFzweP4q7WDQo4RiPGBwoPcj/Gs3J/qdLaIorJDnzrcKf9XtI++nNSW0bgHyod/OMjtj1NTJ diV8u6HyfaX6ME7uMdD/APWqp/YJkJ+0StKP4Y2x8p+mO9EYf5mbn3NCHT8dV2/3hjofYV1ekwxw jJI3dCT/AAjn+dVJ9gh5mf4gvDc/KsuEHzbh/wA9OfbtSeA/Bd3f6haRBt8bzJ52e1vE2SQcdlFQ pa6+h0W0/E7f9onxT9p1abYC0cIGnWoH8LAHO0Y9RXlJv0bocHoAR0q6pEV2JPtK9yvoAOwpBL6H j19DjtWNhslWWQf6pmB7n1HufarUGt3afdbcfvAHuR+FO/f1CxYW5mnI/wCJSZGPy7o1OVPP90dz V+8+Gl/DEZL+1FvGP9WszAMWY/wxH0NNP+VvzL5f+flvIyrHV5omHmDzI87pVI/1gH+0PWvUdK/a C0+NseH/AArZaU3WK4mO4gMuOGYd/rXVTs/ifn6nJUTX8NvzHat8Tr66/wCQjq010OvlpwoHsigV z0mvvjFpBHB/EzdSxHqSO9Oc+yJpwX6MyZzfvydQlPfYcYH4Y7U37VcqD50COOr/AEHoMVzqXkdK ivs+h9R+A/htc2fh6c20SQXtxG+oln/5Zqw+QP8A7q89+tbHwR8J7dNi/tKZprhWYXEo6O7H+77C u6HUzn+tvwPUhbAdqmRAB2pGVwJHtTPN9KBCPcD1+tN+0L60wIJbkdj+Fc14q+LNjpgxGVnucbkt x/yyPrKfrTSIk/8AI8ibXrjULhTqrFDI4WWQDhY2P/LMewr1rXPhd4YuYvKu9CtnjHMdwBhlkA+9 5g7iqqR/yNqVRrZ+Z4f4w/ZKv7QmTwhd/bQP3qQMcPAuD/q277azPCX7S/ifRTs1q3nvIAfLmtrn h4gP+eUhHOP5VlCVvjOjEUlLWlvu/I9v8LfHvQNXGLO+FtP/ABWM5wVPsa6r7aFH7x8n1HatnHt8 jzYT/nWvUg/thF6D6UQark8AHt9Kk1v5kdxrXPOPTH0qp/a5J+9/uimJnm3xNuJFZHSRh/yzkIHd T2xXUaT4lE0SMsnUBifRse3pWltBT6fceXfF7wxG2yaDv/oWogDpuzgsa5TT1muISYxumj+SVO7Q rn5kPuKwjvqddR3S/wDAWdf4E+K+MR6rMMZ228zH/Vv6Ocd6434x+MGvrrEcimOJfs1uB3Y5z+tb 1V2OKhvZ37o8T1G7GRlepwQexJqTULkKwCg8DCk9fyrBepu35eR7v8FNd22r7UGQ4xn+HcD29q0/ iRG11BlQC6kTBv8AZOc5+lbsxpb6+h5GNN8z/j4CsO2ey1XOgtn/AEeUMT8saN0O7+8cd6xnG50w fc1oLrW9DkBj821l+/GhztkUn3HrXpOhfHm3ucDXR5M33TcIOJCP7wxUUp9J+iJrUusPVnWw6lEc GJ1cH51YdGH1outcDH5vy9hWnqRF9iSLVT/Dx2GPT61FNqIz+v40f8OC8h39o5Ay3uR7VUvr1eCH /wB4eopX7DsMk1UMv3zj+Aev4VAupnHU57D3oCxXv7t5kZZjlWBBXHQ7f6GvMNJ1WbTrjFxI20ny JF9QD3xQhyWmv+I9NuLxmxvKgHgN7UWtyAflYEfdb2PuKXoQTw36Jnaxyep9KpvrK5wZWJ9fQfX2 qUzZsguNTIG4Nx/qz7D6e9ZT+Ioh6/7R96olod/wk8X8IH09TVd9bWRvniQj7uD70vUm/ZmDrGhW b/8AHuiqxHzL/eI9TXIXekzR9I+PU+lc8o9vmdkJfzGa6gn90uxuVII4/wAtUUlsD90mJvQdJSfb 3qPQtr+ZESzFf+PhSD2b+8Pag3cgGbWaRGHzpKvVMeje1bxl5HLJd/kJov7S1/YPt15RdQ5I+0r9 6MH+8AO1ampaLok9u9zZsJXml8qFgODCEJPB9GPqB7VcvJeZlSunZ9dUcrMgHQADoAKry25HT6D3 zXI2dyX+Z0M1qJbdSSW2/JIPQLmsyK2Ug4UHjIA7AetZ/wDDl9NfQks7xkA25X+/9a0m1Lj7wI6n 2rqT/wAjlkvIp3NyH7c9B7Cotp/i4Pr71TfYPReY457g+mantr11HLk+vv8A/qoQmiVL057YpJLr cTjgdQPQUNhb/Mj+0HnaR6j6/Wk+0ccjLfxEd8VKfb1H8/MX7Sx6Yx0x9fWjk/exjr+NO4kvIVSP 89j9ael46Y2OR6MO4o9UVHyJ2MUn+sHlt1Eg7P8ASknVhjzxk9pF6MPce9QmWhnlgfdxjoCO4+tD MAOnuPxq36kkvmjHJ+lbFiwEZ2MAerH1FJkxKUsm49T6r7/WoWKnq2KCl5eo0MewPt9KalyPQHtx 2zVXIfmS71H3iT3WlSUL/dz1/AUmgPOLX9pjXbf/AJCHhJpOwLK3yg/7QHarCftWQEf6X4Ynik+8 PLY4x7kilyL+YXLLovM6HSv2tvDhBGtW17EPuxOEz5bH3A7Grh/aA8JMT9n1pgOqFkYZX/aGKlU3 0sHtH9qLL9t8YvDcw3Ra5BE3Xa+eQPQVsaf8RrHra6xZyoeTlxyv0NQ490V7X+6zZeO1vRmA2cue WX5Tg/l3rIn8MaW/F9oWnyDpt2D5iPU0tehXtF/OZV18GPDEg/e+GbcDqSnHJ9h6VW/4Zv8ABNyB t0ySB/uybW4kb3FVd9WzVS8kYWo/sg6Arf6JqWoW47EAHaP8+1Zkn7J6x5Om+L519GkByrD0IqnU fVCaj9qJVT4D+MoH/wCJb4rGD/y0ZyNjDsVYdquRfDz4t2HNrqELgfMkqOD5n0IHc0cy+0iVSX2X YWfx38UwMX3h6OcD5vMReWKj2FVLf49eLIAf7Q8HtNjo5VuB9celOy6Mn2X8s/Isx/tUTIAbrwde RkcMULYb6MVrftP2t/DE6katbX1o4+SNvLJznP3sehp8n8rM2p9USxftDeFm/wCYvKR91tyEbD7m ti2+L3hxz+78R2pPRCSRk/7xFTKm/IPaf3X5nQW3jqyuhj+1LKT+HYxH/j2fWq1z4Vs+d+k6dKp+ cSAL8yD6VnbsmaRq95eSMe7+GfhycHzPDViV65Ufcz6EVVX4BeB7gYudB8g/dzET8xobfdmqqehj ah+yV4aVv3E99bgcxMuDtH/16zG/ZUSM50vxhdxevGM5/vEVSqPyCUY9YkNv8CvGyAjS/GqFR80M bvjJHpkVOmj/ABg07gSx3SfeKZB3Af3uBT511iR7FfYk10ZXf4g/ES3yb3wmJBna8ir1B9QoPWgf tIavD/yFPAl0hPIaLdwR9VppLrIlUpfYkma1h+1tpKjGtaPqNv8AwlihO36YHarn/DSvhEn/AEfV bwd1DxN82fTAp+z/AJWhe99qJq23x28LNjZ4jgiY8qGBBUj+99a6Kx+LOlXPypr1kzdUO4Ydfqaz lT7rzEq3eL7Gi99G4/1lnOn3lyVO4Cg6Pp9xxe6Fptwp+YK6J8rexFHL2T7lxq/3zLu/gn4Umznw lpwY8ybRja3+yKxbv9nHwmcibwwkZ6K6Mc7R6Clr/MzVVV05THu/2V/C0mPs8V5bgdWQgllP1p9j +w9pd2wGg+IdThfrsIA8vH95qPay8jRKL+KKPov4afs9aP4ZgKteT6hdNze3s38Jx/yzUn+H/wDV XnXivxJLBM6nkjIP+ynP861gv5vVnn4mSb/drTZHmuoeMxcSbLGRZZfvSEf8sB/9evUfhV8DpLxw blCT/rLqY/wJ707f5l0I9Wv+GPq2x0m0tIwtsiQwqNzN/dAHVjXlPjj4mm7JSwcrbj5S4/5eGHt6 Vo3Zfgjlqav8WeYXdvckkpeFR1VCBwv1qlKl4M4eNh1A+nvXnM6kl5mde39wgyIQe20Hqayf7emf i4tvL52xKDkyE+gHuaheZXL2fkez+Dvhk1oBJfQgSkYsg3VIj1JHvXZTTsCN8gB6E+ufeumD7+oV fLpoOSRB/rDkdMDtn2qaK0AB2nPue3/6q0XkZL/gDo5iRgyAt/Gw/wAKbJOoGI1J7lj3PtRYL9iC S5LAbyp7Nj+Ee9NtFhJ+YsO4J7EDt9aVxofLDtB8r5ifuj0P1p0FlgYuX6/6w/3Bnt9KF/wRf8MO t7SME7VWT+FGH90ev1p11bbWGMY6lR6+1IL90Eli7sBcXBMY6Rr/AAnPc+9dEt3p8X+qR5P4dx7n 6ULzHft8x668x/1Fupx9/B6D3J9q5fx58VHsIv8AQnjWZvkiYj7qg9j7/jVxsY1L9/I8ks/iHdfb YTqWozsjHymRzwpb0X2r2Wa55OVYEZBHofaoTNFH+X5lL7RIGy6oY+fNI6uceg9KU7P4YkbPMaHu fc0xoiUKMbg6noU/uv8AWo3gPV2AUcyD+8faj0+QyzHqY4CoF7O/r+FYGu/Eqy0xs6ta32w/Mt5D EzBFGfvBAen+etFybPoZ8X7QXw01JfL1rX9MuweJoL6EjORwD5ijoKwtR/ZY+H1/lvCmoHRJmPm2 +paVP92Rj3gJPU/Ssmv5ZefqNVv+f0HbYj0z4Y/HPQpN3gDxfpviaIcx2GohVZ415G2Q+mD/ABCu b+K37Rz3lrLB8cf2frqwvj8una/H8yRXCngpcovbnjdg/jVwa+2iZ0+uGqeqPmHU7TSowT4b1mVo z8x0+YH5Ae6v7Gsa7FuSP7QsxMv/AC1MfBBPpx2PtWL9fIzv/dt3LNj8Q760BXSdVuWtTnfp0+Cr Kw7xsONw9MVdGv8Ahm9Ui7sZNIuMFv3YLJd3A/uqRx5v5Z9qHH/MSdto+bRyVxYlP9V8y5wCO+T6 e9X7XTWWPdHODLnYlm68PEwPzK5/un/61XJ9zWMSKa1lU/6Xpu09UlXv9QBU1vew5/dySoRwyMOp HqSK5W/5XcTiy/8Abuf3axMvUNnp/uilluI24cKR3Dfw/jXLKPqHyKUumxj/AFYC9uO496q/ZCvS U+y10Ql3RPqQzSSD7+7HTFWbG+gB/wCJhCJIT8spXrGD3C+31rot2foOPp5mwPhzcMAfDzG/jPzw xr1CjsVH90V6N4JsQ8QOraQhK5S6gkBUzhs43Ajsf/rV4uYV9N9T28LStqrW6jpbPS9ki/YY4UyB bnB/0O5yeAf9r9a848UeB7mxbLOkkRJhaVT/AKq4yeHGB94dOKwy6u7/ALxvXYzxVn27GDFYzzMF t0YuTsRh2yf4jX0PdvY6FaxWccFu25RfeMZVbm+vFJKrO3pBxwMe9ezXn2X944IefV2+W5wOranZ DeJZVlDgvJMePLAB+VEA79PSuLn8SxIgW2s0t4xwWU/6xye4rKhB9W+5zzm3t8ylPq5GNsjZ6596 gm1a7uP4Jpj/AKtdqk/MfQAV3RprqOEG/hXma2mfCDxZec6d4euCp5Msnygg+pcd63E/Zm8Qn/kI XWlWf98PKCf+AhQeldPyfqbcsV8c790i7Y/sl3k5xH4mtj3ZkRiAAP7xUdq34v2RtHtwP7X8cR5+ 9PFFHkyqOxAx1+oq+Vv4WuwnUgvsyI4fgh4SiYmaG+vWz+6DMFAT2wPWri+C9BgP+j+H7Re8QYbs L9D/AIUW/mvchVb7OKOu0bwDqM4zpulWkMQwJpWjVREh9yB0HvW41jo9rzdSNqcnQxqNqRcnqxAz j+VaJ/zJevcmpK20m3+RyWu/tL2NodglaLHym0toj8ox3l29xz1rJ0f4rT6tLs8OeH9Qun6PMAcR Ad3cjsKU7fZsTSUn09W+x6MvhGwtOfEEhuJ+v9mLjEUmD/rZAP4R15NU9R8cXDDbbCO2h6LaQgdB /ffHU1Fv5kKcr7PT8zmrTVJZl5hkg6oFbqpBPc+tRw2k0YP2qYSckL7KT049Kbl2+ZUY9zpvAP7P l7aw3h8af6NY3G260picu6ozfdg7ZPTIIPcVs6n8TPD+iRqmmxW2nKcRRheZLxs8GSTGflJqaNPr L1ReJqdKb7RkeV+Kfi1q80ksdrNLp6r8hYHLS8fxMR2q/wCA7TVL62uW+37lt1+2bWIJnGD96Q9k A9P8aVWfZGdKmur82SeC/FBvbe5a/QvNGovbWNB/ro+chx/sj6+ldF8PPCV14nYjTdPkjhHzXl1M Plijwc4dvTFF+/ojWMfPbWTPVn8R6ZpSLF4SLSMmbeXVWX7pbP8AqYm7tn+tYnhTxbY2l9nX2ZYi pIvpATmc5wCB2/PrXQ42VvmzBTu72feK8ih8XPG66xKsWlyCWJV3zuvAg3f7fqF6+lbvwt0GwtoC YZZLlyRHCDx5ojzyxPYH/wCtXlyTvr6nowkrbHqOnzXL/wCsIEf8C+rD/ZxVmfw3YXKn7dp1tIer OVAKn2I9K2UexHN2fqcfffATR5zmxlkt2HEbju3qGA7VBB4V8Z6Sf+JXfG9hHPkyc7lB7uBkZ+ta qb6q5Moxe6s+53vgT4oT6hMyaroMljMqNMjAkiYIvUEgfeJrY+HNtFNbExzRmQuzTxEjIJY9R7it Lfyepk7r+I/JHSzWQH8YB7kf57V84/tAeDtOt5N94CXOLv7Sn8ZLHGcf3awmn0R2YeeunVWPUfBP h8XthCf7KWVWXzIZXH30bpl/b608/s0RTnM8SRH7yFDjYPY+wrvpwS+KXyOKUn2XZHR6f8EkhUD7 fKyj5QHOcqB9OwrXX4ZWw+9csT24rp9qvswOf2a6tky/DmwH31LdzwOTVlPBGmr0tQfr6/hSdd9E NU1/KiZfCenDpYx46gehqRfD9iOllF6g1Dqy/mZSiukUSjSbUfdtIh+FOGn246W0X5dKj2j/AJmO whsYO0EX5UHT4f8AnhH+Apc7/mYxjabAettH9cfzrx39p2Oxi0krPpUcvmN9nidf+WVxtODJ7D8a rnf8zKivJFj9nO7j1TQ7dtXht5biMto08id47ViBuXPUrivSX8E6e3S3Cn1Fbe3l38zD2Uf5UVZP hzZn/VzSL9AO/tVCX4Yf887kMOuCPX8K6YYt/aRzTwseisUZfhzeL92FZD2Ge3txWdNod3H962kU 9toPQ+nFdcasH8VjinhpL+FIkTRr4LwkjDtkd/fiqxtLtOkILdgc/KfriuadCD+Bm8ZzXxq5Ve8u VYbrYA/xsP4D+VM/tyzgz9okYHsME5JPtXPLBP7L8y1jV9teRfj1y0YZjkUL03Nxgn2NRtcqQPLK 46iQc5HsK4JUWviTO6FdPaSJl2NxHISc/MSPvGmSxjJyAw6MfesGu50plW4ggkG25RXiPMqMMg49 Pwrz3xP+z9FNufw60cRHC2Z/5a5/u8dvzrL0NoS6SPIdU8K31s5W8tWQj5X3A/Kfbis3yWH3OnTn 1FbxfY56kLb+qIpQTwV+rDvTygA+YA+h9T9aGv8AIzRXhcg8gD29qytbVcHBP+JGaiSLRgW14ysN pOe49TXTLZXbr/rgn8UG4dcds+9QvJFrzXkMVblR/p1qAvVJkOdy+/FZ02ptZsDYSAox3TZ6fNnr kd6Uo9vmX/iOltdV065GZoVgY/xxY6/7Qqnf2E8BzbBZ4TwJUz1XP8GO4rZ7bHNfv8htnqMbfdWT PU7gRg/UirTa7IRiPI7EkdB7EiuOTOpR7FE5UngAdeP4ifX616/+zTpqzak8twgEdvC91u/6bSAj 07Lmin6+ZpJf5Hk2oeNYtTublzc+bI0ryOc/whj90f7IqB7SJ/8AWKD3APc/Sis3fQEyBtJizmEF T0JT/DFT23hjU5zjT4LiY9AgU8P9cdqiMu/oaKN9/U63T/2fPEiDd4mvrDSoeokmkG7aM9IgO3vi r8Vh4QsmIhXUPEEnSKULtjVsH774rpVN9V5Mx9ov+XWvn0LT/ErUrVNtj/ZmgR/cDwqrMy/7TMDz +HX6V514o0vTL5w0uo3d7KDmadz98+wPb8KJr+X0uTCX812THWGKBcIqDhMjk/7zY/rUQWNv9a6n /ZI6f/rqIv8AzK/4cnt7uSPmF3x0244H4+9aK+KM586329hg9Rjtx3rZu+7M3H+X1ZaGt25+82PQ 46Y/xrU0m0S+ljjt5eZHW3XHUozc/kKlR/yJ5ux91agkKW7xxYCLEbZE/wBiGP8AoBXn/wAEvGNt c28otZhIFk3ZHYOvYe1d0Ov3mMnp8z0xtQHY03+0B60rAH273/Co3vwP4qLAmVJL9e7fjVaXWlX+ LnptHrTSFc4nxn8X/sYK6acz/dlmP/LDPp7iuL8K+C59UcvqU0hgJ3zyN1uW9FatfkQvM6D4pxLC kD2EUUKofIVYx0CHj9K6yx8Vi4jRhJnKhmP+0B6fWpS0LqPb0sydtS9GOe3saw/EfgnRdVQDW9Lh lbpFcrw0XX7rj+7ms2u5pTqNfD8zxPxP+zXqtkS3hy6F/EuXRBw8KnJ+UDqRVbwz+0nr2nfJfvJe QjiW3uBh4QvZZCOdtKErfEjWvST1pfPyPWtF+NujalgWl2IZj96yl4IYf3Sa6O113B5Y+3vXQ12P OUn9teRBcaycncTmqD+IZB93j3/xpI0kYvjG5e7tmVcFh+9jB77Qa5v4f+JZTGySNgqSwHcRkn+o pjktFfozoL63juo3S7f5WBjYehI9/SvIrHU7jTJ2E6EhSbK/j/572RPUA+o5/lXPNHTTWj+86PX/ AAXGhWTSwGtnxKpHVSfX6V5Zr2pRtI5hDKMlVQ/wBff2olL/ACCEeq+Z59fakfMwu4jPAx057mn+ IbqVSDFGxyNpA/hPrWdxyX/APVvhF4yliEiuo5xNz26/yFehzaq1wGUhDkFASevB6itfn5HNBPr6 nm8kZiyJF5Hyge+e9T2WkvIc9P7uOx9qhzOpxPSLUxXUSjUIY58Dypi3Zh6H/aHvXHa78IFGTokz EH5zbOejH+69Zy8i6MuktjH0bxtqulNho8/89rWYcOv+y2PSu40/4mabfDhzaSjhoX6OwP8ABJ9a qMu5lUp2+H5mp/bez78o9QR3zVeXxCoPzPz0Pua1M/Qa/i1UXkfj6VDe+MLbyh5YDP0dfb3qLAmZ v/CYALw2D0x7f/Wqs/jKQ/6pz/eLVXr6it29CmfHNyT807N2Df3TXM+IfMkO+PcxHzSMP4W56n3p t+RcfP0LemePZZI8SSvuHy4z0A9K6Gw1OQj5nb1okzKMf8ie58RLD0bOe3p9fpWMvitjnDnngH0r NGr8/Uil16TBEkzHB+dP7pFZ51wDOJQM8k+uP8K0YrdiJNdx9x+R8xHqv1pg8SkMCJ2HfI7VN/Ly C3+TIT4nYn52/E+tRS66GHzEEfxD2FEl5Cv2IiIJRkHb3x7j2qA28Z++Aw68e/rXPJdkdcZ915EU umnHCLIn3WVuyn0rLm0dhn7K5XP3kHpisk/+CXOHc898SaBOm4vFkcgN6MQe/vXo9vDLa6bYxPbu nyHVpMn/AFjXkhOSPcfWum/+Ri4ar7zA1a8njX/R4t5JCkf3U9qjnuJFGUznoAO3HpWFu5u0dR4W kmmgkVoSetzET24549zXOWcF4sjC6Y7M7Y/oR/SshqOm/W5YLc8nvtHvUiuwPbHcegroi/LyOeRK B69OuR6U8RA/dyfQ1aB+XoCnHU+5H+fSkV1HQH3/APrfShCuOYqPuMSeoA6fiaGQHoTjt/u0vkTf t6igZHyoR/tegFKxU9SCPUe3vTKdv0HI+PT2I7j/AOtTlcfXtn1FCFfuxGQEfe49PemqqngY45x6 U/n5gn3HGX+8wPoB3+tWIL/s7DHofUe9Q12HFkxskxm2bP8AFJH6fSq7qrfd3Keu0+3pRF9/QuSG PcLj5QQRw3vVq31vahAIGeT7j8adjK5A2oED5Cfw7D2qvJqG7vz03elNDuM/tBj0Y46Z9qPtx/hI A/iPuP8AGnYfqSi/IP3+e1H28fxY9SfX8KYf8OdSl7vP+qhfuVwMMPfHpTLfTNPUn7RollIp+aQF ByDXMvQ1VRdJeRHe/CnwpcofJ8M2S/xttHI4rAl+BXhF/wDX6GIx0QIx+Qj0+tPmf8zKT728jOn/ AGZvCzf6qS7h7Fsg4Y+xHaqK/siaRL/qPE1zC54QlBg/72KqNT+6NpfaRBc/so6raHOk+M5FYcIV yMg+w9Kqn4GePYwfsXipZF/jXzOS30I70+f+ZGUqceiYxvD/AMWrdf3d+86jgqGUkY9CRRL4s+Kc YDXeitN2Eqpkke+2qTXReQvY9p+Zej/ad8VW42694Ee5/gLqGBA+oWoW/ahCn974Puo1+84DHgZ/ gyO9OUV1l6GbhP7KT6l5P2oPD5bF1p+oRA8liM7CPRQO9b2nftOeFpOG1SeOL+ESIRgH0+n1rP2b 6BeX2o+Rr/8AC2fDjY+yeILbYeVJPJ/CrkHjjT5/+PbWLOTHEse4fMD7H1FRy+Q41O6Zbt9QhxxB ZTRfxIApBHsBReeB9AvVJGhafJjmaNUHy8d8UKPmzVVP75zdz8FPB8v+s8NW8LdGKZ5x7f8A66yb r9mDwnJjyo7uDqXVDncuewIp3fe5rzrrGPchk/ZC0BwTpXiDUrcjoGA4z/tr6H2rOH7NGpx8af47 uQBwgfd19jV876pEtR+1Eqx/B/x7a5+xeK191Zh+8H4g9asR+HPi0q/6PNb3AHCqxXLD2OB1pua/ lM1QX2ZW7Ez/ABH+J1kNur+EIrkY2p1yFH91lFUT+0Xr0J/4mXgm5RQf3yqG+b/dyv8AWiMV/ML2 T+zO5aj/AGpdPz/pnhvUrbuBySuPVMdjW/pf7V/haXjVXu7cdFnZSSgx3x6UOHZkrm+3E27f45eG T/x7eK4GXogOeUPqD6VqQeP9JmANvrFjL3XcV+X6ZrJ0/IUa3lJFwy6VdjF3p2l3BPAOB849zWTf fCrw23/H54S07/ZZAQVz6EGhp92bKt/eMC8/Z48ITD91o7Rd2khbk5/vAio4/wBk7wXcj5Jr61k+ 6UB4Lf7JoU30Zs5d4xMt/wBkvTYyRD4q1WH/AJ5MewHuKrt+y7fIMWPj64UdUjbcNxPrirdV9UvM hxh9qBJa/s+eO8A2Hj5Sw+aOFn6KvoxFObwN8XIGwnieKU/8smZh8v4Y701UXWBPsY/ZbXY6fwH8 Pfi9qFwE1DWLSK2+/f3zhT9mA9FwPvHivqWy0Sy0tMW/lvJ92e5xzI1Q2n8KHOKS0k3fX0Rhav4t xna4Hf6fSvAPiTqUsxb+zJVNw3ytu/hyew9cV0LzPL/w+iLHwm+AlyzjdD5k78ys349Tjtmvs7QP B9ppkW2EKON93Of42Hr/ALtKK/zZ31XZaf4fkeceP/io02U0x2EI/wBdIvW4YZ6D2/WvMJNcTHzR Sr3xtP8AKsa78zlox7+pVOsW7fxkejEGq8mpR/8APQY757/hXLfz9Ddt9jKvtXjAOxlZeob+8D6V gLdFZEeNCSrKyL9W9KmXkVT/AOCfV73TTYL4HAbI6EEf41UmuVH3QCewHc/WuqH/AACZeQ+2bd98 Ad//ANVXguM45/2T2qkZvzKskoXiNQM8Ow/iPtSyQll+6QRzIfWncDPFwxz5a4H3XJ7t7VasI+D5 nzDpj0BqCkiw7qp4IA6knv8AhVJrvJ4fjqAe4FUyf+HLmm3Q7uAD80WR2Hp9TUklu5f5zhT83mD+ FR7UXK9fURZEbm2kMq5+STGNw9lq0soGdyg93H93PtQIuwzoqfuUA6uD/s4714r8UNbeeSMFRsGV P++uec1dzOf/AAWePeI9Vk8xDE7qR+8gZezKT0r6m8NXqz2sLyS/eQGX2ZSev1rFLsawW9ya3uFn JMAYLk+TIR95R6A1Fdja3+kZIBzCR/y0Jz29qsPX1Cd5VI3K5XqE/un6+9WF02NuJXYZ+cn3HoKQ IYtmgybiMv8Awkn+ID2HpVDxD4603T1VtVgumX7sKRxs3GP4ggPTHpSa/m9ATf2V5nB6l8a/g5qO F8S6XZSP/wAt3uLR1xn/AG9o61h3Xwf+DF8f+KY8Qf2VIx8yO4sZyNhb0jkOOT9KyaX2Z+RXtZf8 vqLZo2vwE8d2BB+F3x7lnZf31vYXwjKuD13Oc9B7dKZ4x8U/tEW9hMvinQfDmvacR5eo3dtIgaGA KTlYBjOAP7rY6jkZranJ21po55wg/wCFUlF9UfIfiTW4Zf8Aj78KPps/3nZQcZ56LjuaxbPS7ST7 2tNCerJKpx+DD0rK3b5jX9/XzH6raZAJmtZiPlSaLHIHrgfzrJLI/BB3e/c/WmkL0v3HQ3ckfEy8 Hnj296vx3Lr1jB7xt7e1TUiESVNYYfecge/eri6lA4/fmM9myBx+PtXHKk/sDUn1G/YLV/8AUwx9 cJt/jPrz61NJZbVO+KUj1Azz+FZyb+2aRV/hRXj0q4kOIlkPoCDzn1yKuN8PdRwTNGqDqFGSSB6j HeplVS3ZqqP83yK//CORMcG5dX6FHU4OPQ4qCXwLc4JtmjOMlk6Ej/Zz6VvSqd/kTKPk+weHfGOt aPJv0snI+9H2dT13cd/pXqmo/HfTtXgXEE1vfKRK8+MFNmeBjrzXn5jhbtOC/wARpTrNKyOM1Px/ cSljIVy3zXYXjzLjn5guPXt0rGn8XyzxMsrOW4klQg8TR57Y7itKGH7LzMLS8y74O1ee1IlbTZbj GTbQFDiSYqcZwOzYNXk8DeL9RYyatYLErkySyzkDAPQBSOi16ns/LyLlB/8ALyXkWZvg1Adn9ueM k3MfJgt7WMsUb/aBArrtP/Zf00KWv7m9kh7zTbVBH+wvua6Iwf2Uhc0V8MH216mkfhj8OrZcDQ7n VXzu3sxC7x6nGeTRdePrHS1/4lOm6bpUP3A6RgthuMeawzWvIujIlWk/hVu1upe0ux1HVl8wXW23 4eS7mYqNjdPkI/i+n6VZkbRLRswMb5+nmy8KpH9xDycmrh5+hhUmlstd5eRS1LxlqE6kRzZQcW0c Y2qufXaO5rz/AFdfFjxSC3S3LEgWUqdYovfcOrH3x9aGxQinvLyOT0r4Y+PtQlEemWmpTzHOZC2F hVByWlIxhR717v4a+Fej+Fxv8W67Jr1+AGuNPY7YtMkweDL3PQn06etF77L/ABHROmorZX+z5Luc b47/AGuprgkaa5u2HyEj5UiOf4QBzXEwftDaof8AkJ6fbyoPmcIccAdgB/WtpJHBGL6vz9T2f4Sf DtvFMElzqemNpejxnyrrVZlB8+Xni1BHPzcHGcd63NR8f6DpwaLwjb2OkwNgyRIfmvXUn/WOfT61 hFdfkvM7qsmkou+usyPQPgZquoH7T4t8VjRdIUFrW22Za/mwQPfhxnA6+w5riG8UQ24c6pE8Khik bKCfMiB4IAH8XHane/5RInZaR3Ws/V9DOi+LejS5+zTSvjjGwjAI75Fe6/s8eF/DOr/abvxaVl0+ 12rbWzg7bu9dCckcE7OwxyevFRNdrdjSjJrWS295HKePPjrf3t8gfT5naUmKKdcBdPQcY2Y6lcel cLrlroD3EkeoXcX2yJ/s8ySg/LKP7shHX9a0lLpD1ZhFW1mvNGVrHwZumy0N653fOpbnfD/skDsK XSG1HTIrhEhlVJU8mTZnkrnggdc9ehrL0RtLb3fmdt+z18PrzUZbkB1gsxGLbW7p8fuo592AsTf8 9Ap7Yr2a916zt4Bb+D4zbaeo8k7et64PUsff35rSlHq15ImtLSye/vTMJbMAfMoHdR6E/wCNNk0u 0O5tSMawAGSd3I/hB4UH1Na1lpp6oVKXc4m21bRL3eYnNrHnyTcuP9Z5hOMZHO8+1d1pVxqWiBf7 R0iSezx5puFOCQQcEcdE/OuFST+L7zot52O78O/G3w1qZA0zVwZeRLbSIVKSD+6WArqdUuoLWFnu peMFlX1bB7D1rWUDnjU/mRzfh7xpqGpp/oNotqmN63bdSQD/AAkf1IrrrG4dkXZNufH76QfxOfT6 0Py9DZJ9fVm7p7uxbyrMGTYYYpAP9Yzg9W9vxrl9I/ZaYkPqGqTWEv3pPsrcsSfXHrW8PIa/6eK/ Q9OtfBVtGAJJZZ8dHk7/AFrz74+fD23ubANb2yIyHZcMP4oXB+9n+6acwpPVWRa/Z48VG80lUllV 5IHbTpCP+eGcrke6mvUdvrQv+CRU3f3i7h7UgoIDPoKCfSgAJpN3tTEGT60UDAmj/IoATHv/APrr yr9onRYZNLZ5IPNKMAIyeNkmc8e9DX+RpTepzP7JFlarptwbaBkf7Q0M4JJAjVFxtU+uT2z617zj 8afz7fkKpuLijHsKRmIR9aHUH7wB+vYUXGBbPf6j3qCWzib/AFkMbfhVKT6MClP4Ysn626g9OO1Z Fz8MbFv9VtU9ASo4/H3rtp4prc5alCL3ic/qPwbMn3Sko67W7Z9sVkyeA721GIbVlAB8or/CT6DH evRhiIv40jzKuDkv4E/MyJ7nUYh+8luPVgV+9j8O4qrJ8SNSiJxoSXQJ3MzMV5Ptjt9K0lgoP4Gu 5yfWqi+NPsWLfx/p+3Otk2WONqgthieAMD+L6Vb0f4kaFc5+x3uDnBZ1I3L+I7V5dXLpfY1PRpZj F/H6MbqeoeE7lmTW5bRj03nrux/CR6V5j4i+A7x7n8PXFvdQDMgQMoKRrk8r7LXnTw01vB+Z6lPG Qekpf4WecXFo8Zw8ag9HHdT7/SqkkTDvj2NS13Rb8mC2YPVgR1JrK12NAD5WcYJAP9T7VlIcWc94 U0g3crGRconOP78mD976V3ErqMjBwOI1H8LH1ppd0NsybjXnj+Upn+EgDsc9Tiq9zpltKMT2/B5b 3U54aueUjdR7epmP4EeM58P3Ajbq9u3RiSenHeqi+LL+2YjV7O4iA+5cxgnao7nA7VpCf8wSpX+D /hzT0Xxgjk7pku0PKOow0eAeq4/hrSF/bSEiCcZ6lWH8ifSolDshQn3X/AB4iPvMQOmQO9ezfDmJ tM0LUJ43KySltMsJB1ZY42HH1JNYx/4KOhLz8j5s0Twq64Mw8rjfIw/5auQfvcdzXb6F4dsp2b+0 dUFqANwLDJdTn/Vj6+9auLf6GU5q+3qW7eeCKT/iX6At4OgmnJAyv+yBz/hW9P8AEzXdu2XWINNi BwILSMA5z0L4z1qKMLfG0+ljSu77Pzsc/Pr1u5O9p7p+Vd5ScbfxFU7rxbdkYgZYh6RgD8jjvWsq v/AM6cO68zEubNZv+P6MueoJ65FL/ZEZ+5le4Hviubm82bW7pB5Fwv3XV/QN6e2BTFvbkHm3AHXc P68dqtPuQo9n5ky67tPJwevT+mO9Wl1iBsZOD/ER3/CrTJa/yLaojA7SMdNw/iH+0Peur+GOq6XZ albSa9L5NujGSefBIRypwXA7A1tB/wAzM5r+VeZ9rWviOxvkL6ZfQ3lu2UaSNuqSA8GvKPhna2ui 3c8FpH5UbFpIUPaTf6+/5+tdsI/5HJ7RW08meutqOPvNjtUR1n0b/wCvQMi/t7PQkUn9tx8+Y5Hf juaGuwJmVP4h3H5ZAo6ZrlPGvxWi00BYHBumGYOM+QnqwxVJEN9jzbw1YyaxORcuzIv768nburZ4 z/tV7LZ6rHHhbVAkY+SJAPuqP8auf/BBGN44ka5t3C8sP3tuD/fH+Irmfh74tmaPbPkFCVyT1RvT PpST/wAypr87HarrbPwCMZ5PpU13ekD7/wBMVnf/ADKRRGosB/rDnrn0rmdc8FaRqSt/aVkDJyYb pOGRvcj0NEvQqnJrb5nl2t/BTVbTnTc30Y/e7lOHtxz91QP4aXwv8c9X05gL5HvIhxLDNw0Sj+4S O9YRnbc3r0k1en6+h6fpfxW0vUSfsM6xydZLRzgo341eGp5+9j6V037HDF/zL1IprpefNYY5VgOw Irg7OZrC4PlMMElJCOyMT2981HMb2/zR2a30R6Tbu+49/wAK4b4jaOjhZbYOuP8AR9SIH+tibPJ+ lZyNaD7+hrfDjxhH5MiasQ3ko+ows54e0iU4Acj+E14NLqDS7jMgUsTOR6MxPaok/wDgDpre/qjn LmEg54PqPerurxsNuVJBG4n3rNPyLt3NrwbqrQTKQxUEGFz2GQfvCvSxqpVuq5+6+f4cV0fM53Hz 8zK1iMSODH82eqjsx9frV62laID9yM/xsfX2FYzZvFf5GzZa4VPC7QeQnofrU95r0gA8sg9iM9vp Ti+5Fu/qZeoNbXAxeQI38O7HKfQ1yN14eeL/AI8troDgI5+6Dn7pxSmv8y4y/m+Q6z8Y3cJxKxkU HmBz/qwPRsVryeLoJz+7bYfvGE9/ofanGXcynG23zIH14ciQN6AdiPr7VQuNfjxwcnqD/dPsK0uJ LsigPEgP3V4/z/OmjXwPuN7E+opPy9BNELauf75PYD0p667JsZQ2QeHU98e/tWif+QW/zKFhHKkg HY/fHtXZS6mEH3gAOAPpWEmWl/mc5qXijd/ERWV/wkj5+WQjvj1NXcT835EMniSZc4fAPD+4+lRt quemf970BpNhFFf+1mP3Rx1J9f8A9dSnUWI+Q47HPYCm2UvMgFy/97P97Pb/APVU0c7nowA6gH0p X7kMfFqrrnb/ALhPoD/jViLUnjPTJ689x7ik/wDgDT/zLttrMUnUIh6Af3j7n3p01pFnqUfqjjuB /wDXrCUe3yOqEu/oZ93ZQOCLiFWONu/sSf8AZPrWLNd6vLKP7RlLwqgtbJe0cCHgLn0Hvx0FKL7+ pbj5+USd0JHzBT7egqvFZqTyCR1X3pehN/I6Xw7KIZU3lVjP+jzt/dWQd/xrU1nwnKkm1YAMndG5 HDKT61m/+Aa033/xHP8AiTw0bKQAhSpAlU+h79PSspZAfT1bFdUH5HPUX+ZKZgOijHU/U0+OZT1x 6gVXp6mf/Dg1wnZhjvx0OfWkNxEOuG/uj+6TQxJ+QhlHdsDsPpTGu1PVj9P9kf4U0DYSXbdnx6qO 496jFw/qPc0rCa7D2lIH6Y/+tQbp8fOp9vp7Uf8ADD+XoILrH3uvQ/QetNEp9Px96ZKXccHPc4/h x6GpDdRqPnVSezejEentQn2Gv+CJDqTR/fY46D2//XWimoxy/eUeqsO34Col5IuL7hLYEjkhh0BH UD3+lcrrVxc254J29VkH933FNMpx7fIt2OpiRflfJ7j6+3tUon9gf7rVVzNr/IUSt/CSO5PtTDPj 7qf7RHr/APrpNdhpdxitI33kIH3R9KtG1bvk9lI7n2obHbv6nNL+z74uhJFj4hgx/CQ/+sHuMUyH 4bfEyPi31BmUfcTzB8y+xIqOZFezXT0J0uPivZZLWEkijht65JA9SKiuPjB43B/07wwxP3mCoeWH ckL/AFqrLoJ0v5Zjbb9ovXIwRf8AhMyfxFgrDGPXj0q1bftTxAH7R4amiI4LRk/Ofow7UnBfzC5Z dEdBp/7V/h+TA1aG8gPQlVJwvqCP7pq0f2hPCpJ+z624/uBoz8w9x7UnB9LdhOb+1Fmha/GHw7Ku Y9et17FGON2f7wNbdp8RrAYNvrFq6H+6w6H1X2qHHv6sXtP7r7Gubq1uRmC6tnHUoWBJx65qncxW 8vF5YWzjohKjr7Nik12XmX7T+8Zl54M0SfH2vw9YOeqkJgn/AHsVF/wpbwTcg+Z4TtUb7sxjyMsf 8aV3/MzRT7WMOf8AZf8ACAJ36dcRdkKNwqfjWTcfspaCDm112/iXoNqjKH2rRTfQptdYrsylbfsp OCfsXjWeHPMe4Hk/7be/0qb/AIUB4+sOdA8Zhj12l/vKPdhRz/zITpx+ymVp9C+LSqd15Fc/xHBB Jx6LjvUbeN/ijbLm60UTKPk3bMkD3wKfMuiMnQ7VBf8AhoXxTBg33gqUKepVX+cfXb3rRt/2sNPI xqnhPU7dum5cn58d1I7VTS6SE6cvs6j7X9p3w47Yukvol5DtsJK/8Bx2rXtv2g/Cp/499ceE9VMq Ebse4FS4PpbuJSf2ovyOj034z+G73Hm+JIE7hx/H9AcVbPi+xPXVrOVewZlP6Gs5Q/u+YQq+T8x0 ul2Mp3NbaXcA8pLhThT2x71A/wAN/Cl2cXHhfThIfv7RjzCPcf4UtelzVVv7xz+o/s5+EMnzNAEI 6Boz1b3+lYN1+yr4ecZtru9t27yJjgZ7rjtT5n0ZpzJ/FFdiGH9kyPg6V45vIXHJVwRge22kk+Bn jeI/6D4+8xR/qsnGCfcjvWiqfzpEOnD7KfcjHgb4sWxP2fWLW5B5Vy6/MoHbK+tR/wBpfFhRmXSI 59vcDl1H93aKTnH+XyJ9j2qFuX46+OYU26t8P/Mxws3zZX64H+NVI/2mtRiOL/wLdIP4yu/IP+wS tUlH+Z9xOnL7LTLEf7WFopP2jwzfwEcqRk7VH9447VuW37XfhOUD+0ItQtnxgMI2OT/tEDsaTj/K yUpreJ7/APCrx3pd1Zebo90ZVdiN7AghY+zIwo8R+MJWB+zygN2Y+3v704R7mVd9/Q4LW/HGwEQs XcjChRzIf9n612fwl/ZeluWFx4wV1jP721tX6upz1+lOReHitW/RHvOi+A9KsHdtMs1iLfeP/PNV Hb61xfjr4nLJmPTJsR/duZx/y1I/un/ZNat/5HNVnd/izzSa4B6jJ7e4qjIxJ/hz0IP9RXnP/gnT /hKFwqHqg9CKw9QNqAfNiRh/dPrj+tL5Bd/oc20u/IUlQOEjX+E/T3pUVlKnbnBD7P74Vqlrt6mk F/mfTuno8iKWcBSAdg/hVh0P4VclijQcR5I4J9a6ILuZzfb5jorKUjOxcdUGe/sKteapU7iU7M/q atEMrJGFH3gwHUjv9PrU24twjhR1Oe5FMb/4cz/s5zw/HRl9TVi3THRueufep+QCXDgH5UB7sP7p HrVPYw6AEdMnsDQwRetwpGML6Z/vfhUk8M0gG5Ao+6VHRgPUn1ppg0XbV1UZmQL/AM8yv/LRcdVH 1ps1pHklh1+97rnv9KF5Db7jb5Ao/wBYxGM4Hdfp7V4z8TNTDughUBeS2P4WGfvH3ptf8AxkeO37 h5Fxk9enZj/9avor4ba3PLYoscSttzAxboQWPX6VBrFaOx2SQxHAeQk+i+3tQ9q7E75fMX/ljGf4 CPU+9ML+RE1tMvW3K/wgg5GPcmrqRDg7m3fwD+7n3piQya2x1GT3PqTULapFb5898DGMYzn8DRbu P/D8jzTxP+1R4FtQRqOk3WrMPkMMNqSFDjvIV7j3ryzUv2k/htK/+mfs+3lwnQzIpG4Z77B3PvWT jD+ZLroNe2+zDQ4vxh4l8BXo3+CvBPjPw5dDBgSIuVkbcclzyfu/hx78Y9n4xtktpRb+NfG2n3TE CXT5I3MV8F/56O34n7p5A9TjNT192at6hUoSteth12OI1LxTeSDbPfSv3LMPvAfUfxVktqVwmd0V vID8m7b9zI7fhVQ8zDl7XRRVoufMjIfoHU9PqKBP6geoatrf8AH/AMAfgN97/gLD+tOhvXiOGZ8f wOP4f/1VNu6D0FmuZx1fev8ACSBwPY4qoZh/FCD3H1pqPZjsyxaTwk/O3lnopweSfYetdro+vT2y EXl9DtOEgikX/WcnocVx4mGmvyN6P/b3ZnU6DNb3RAlWOI52+aD/AMtCeAPrxXp1j8G2dCbZpDkb jPG6/uwR/EG9q+Vxanf93FvoexCpG37xLyZzl34DVCfPMMx+6xnABVwfUehrPtPgrcXefss8NsvR nXOCrZ65H9a9XCYWp9u67I82rUj1vYgm+AOlW+ftXj9EbrLbRRbsjHRmqH/hWvhWNgbi0uL5uomL bQ3/AAFR/WvfVJ/8vGvM5FWX/LqPlqdBY/Daxm+bT/CdlBGM4nlycD3Z6t7tIs/9RaWl9J/y1jjj AUNj/noR+NbUoLpcmpN/Zm79fIzNc+I2pImLWyDR/wANvaRj5cZ+84Gf8/SrXgnRdQ1ZXe/06fSr ZMB72/OBLnsiH+mffFVU/uR8kOEXvOWnXua0/ifRbE48P20N3P8AwarOo4YdTBCR+tczr/ja5k+b UmluTkKQB93d/dQDoo9qfo/VkO7+L/t1di3Y+C9W1Y7PD0Z8774lONsaryTI7cDCium1Pwp4b09Q uq21trd4CHeF/uWtwo43nvz/APXrKGu3qzZuy838Pkji/Gni/wATXC50+CGR+qIeFiB/uIB24rxL XrHXnIOuxXZf7+cHCf7gUdq6Obsc0aV/idyvD4ovraP/AEXUJ4mJ3lyeiL6A+te5fCP4ceMtcBn8 SaqNJ8Pp8t3qM0YLXLjOFtkOCTIRjrx1PvDfktdjohSW89EtX5nofiv4vvAoh8B6YLHTyC+pXCfe vvLOR1GcA+/1rx6T4keFtWBTV794OTFJBOpAMgJzmQep960S/kfr5nPUk95K99WuyKt5+zpYzLnQ r4Kp+6UYMGb3GO9YFt+zh4juriKGxsxdNJIlrmLPyxO4ByAP7uazlLvc7KCT29D6y/aj+LVhoVvB YeD7X7Jb2yLaQW0Yx9omdAAGQf3AMnqSTk815R8L/wBla3kAv/jE7JZf8fGiaRJ97W3GcGZFIIWN gMDHzd+KTvooPzb8iY2vKVWK3tFeZn/Fv9qW7vZQmmCFVT5LG1X7thGPUAcs4/LpXHaT8bC/GvaM j/37mIZPOfvRkdq1nbo/JHFShLdX/mfmdxo3wkttfieTw1Zho1xFfyKu0xu2fvIR/COeB0r37UfC mj+FtAig8Ktcanfuy3GpWkUbf6VI8gLecyA42KcdT9K5U9d9tWevKOnwu79x+RyWt/BnVJrhT4e0 O7kXAvIJGU5huCecPjHB9/rXAaz+wB8R9XuZpLnSrG0SR/PW4lmXPlr32Y71Cl5PsaxoL/l7UivI 9F0b9hTxe0gbW/ibaWxUC3gtol3CKNR6lRnafy7cV6He/sn6PY2M83iTxGbiOFDeXNysYXciA9Af f3rZJv4bGMnTX8NS+Z826V4x0qY7tEku7H+CeFTgXkRPS5Ueh5+vtXqGgXbXIzuR+2ffHp713Rj2 PJk+6V9mdONHJ+8uR1Nch8RvDcklqTbxyMysHaNAf3ikH096U9jSH/AOH8JfCO9vZE+3gIAfMsbI dXZOSWXtxXqXi6+1y6ikbVtTW1t4sLaWESj9+WOMSvjsQD+grw6UtdF5HqVYq29/tPzPKvscTYKQ qp6hxxtJ/uketdFYL4hvFEVkdRuoeVFoykjd7nH9a9Ny7+hyQpX2ifS3gz4Z6w1si6lpC6cwHlXD lgfPHPOB7f5xXeaR8ObO1QCRmmI6OfrWcY/5ms3bqn0N6O2iTiKNVHTAqUKK6LHM33Fz/n0rM8T6 AL60mjZQxZCIF9ZgOP1oHE8j+BPw58T6CbhdS0EraSBZ7V/MHN0jN0Uf7OO3PrXsEbag/wDrY4oV 7qDkkfX3FKD7p9jfExV/dki8oPfntS4//VVHMNKN6jHcU7bSAQL/APrpce9ACEn3piSOc7o9o/hJ /iH0pgSf5NFAhM1xHxks/N0m6AUEgCVfqrU0VA80/ZGuiLa+SQBSJVuUQdo5UPP44r6BA9KlGlVa /iGPf/69AFMyEz6/5FJkf570AIW/wzTSfX6kUxDWf0/Omlx/n0oAjZqjMh7H2xTQyrPZQP8A663i ft8w6Vh3fw/0uX/l2EXYsnce4rpp15L4ZGVSmn8cUzl7n4FWuSba4Rz1xKOhx247Vyus/AbX5B/o E9iq9HCnmRT6cV7NHMF/y8XkePVy2L+CTXWxgL8DJLUZutKWR+hbk8+xI9az28IGDmGzuIG6FkB4 Ptgdq9OFeD3kjyq2EqL4Vcxb3wpuP76NmH8WR/6EMVm3Hg2Fv9WcgfLz2P8A9es6mDg9khQxk18U WZ7+FCP9WCAOMDuK5vX9BlKnyoJCMHccfe69K8DE5dJfCr9T3sLj4v49Cl4I0O6hg+eJVLEmRG6j k43D6VtfY5iGzA5IGUZe+B3PvXk1ov7SZ69Nq/utGOumFVBmgKufnww6Ln+tOcE9AB/CAPSvPfkd b8xrRIv3dw/vk9zSggrgrG4PzGNwD1H8OfWi4r9jAm+H0KtnTz9mc8yR9pAufu8f1rMOlXlu+dWt DLGMmPH8QIOOQO1Wpf8AAHKPZK/XzNSy8Qqy/wCioyEcC3l9cnvj/PavSdQ/aCgOmxWllorQsN8k 0rMf38rk87MfwZPc59quUUZRcuy7nFoi5wx5HU/7Q9qmj1BELb7eNpOqOw+4OeM49a0m9NPVEJO+ vqSTahOw5fA7hcd/pVF8k8uSvWPPY/WuFm9vIQw46MQPvMR60EHPK5HcmpSNX5fMcwBztI/xI96j Vzz82f8AZ9TRYX/DiCUd8A9l9B/9elcHHGAewNV6+g0vIhKD+6D2b3PtVdtJiPITB6kr/eNUn2Hf uIunOhzFcuOygdPyxXXeCdEl1W5SG5uEi35EdyB0kC919/rWkNdvkYy0/Nne3vw48XeGZC+iTXfl glvtFtyrj/prbgdx7U3Rvjndfao5dfjBcNvvpVBG5R1zGB1Irup1ek/QwrYZb0X6n0NYfEKy1BS2 lalBdJnJ2HoW9V9/pTpdaY/dwv8AWt7f5nFCf+TFttVAOZHOOn0OKqS6kGzyT3ApNmqMe68QQxAm ViAMsSO5Hp9TXkGsavPdSFrjJJ+VB6AE44xVoXKen+GdJFlEoCje37+5bH8TZ4/AVsRXkmf3f/Aq hsuxFeEv998DpID3Brz63nGn3LjLBGYqGx/Cc9alMtrT8Tu4NSiUHBG7PX1Wp7jVgw+Vu3X1NTcl MoSa2ijuT1IH8JqJb8kfMQvfJ7ChspIWHUJQMo4x1Vx/EPaub17wzZ6mT9tsow4GyO6QYKDJ6N9f rWUkb05W2POdR+HOq2mTYAXCjlZUOGjx/sgdqvaL8Y7qDC63HJcxj5PPUYaJf93HO2ojLuXUpJ60 0dxY+JNPu+bDUPOHV4zwyEeqGqetaYr4KoQfuye8fufrWjMIPy8mXtMfcACACOCPUD3rQudOWdSr gFSNrqf4uPSpbGjwnx7YalbK62EUisp8tpVz+9gycKTjsfY1jRJLsBnVQxAMg/ut9aycv8jplHqv QzbuzDZ+UeuPcVp6hppeJGbBGPLXHsT/ACqWxxXdFOBWjwUxnon0/wDrV1ltq6sPnJ/2l9PrWql3 MpR/yN3R7yKXPmNwPmQn++B/Wnat4gVfuMPoB93n2pSCD8vIr/8ACQAj5yc9h6H2qG88VnHAYkdA O+KuJl6/MqSeInx8rE9mHpWcfEr5+8Qfetfl5EW7Mp3WrBvv7SeuR6//AFqpDUWGDKdw/wCWbf3R nt9KxfkjS/deRqxa0XH396j5QD1Uc98fw1Qu0frFlh12H+Ec+3ahS7jt2M83bL93I9/XNJ9uZT1x 2I9/rV37g139BPtL+nvg+tSR3ueij2x60r/5E27ehtaXHJI/zoBgZDehAPUe1RalqEuSBMxHQZ7f SoZcfTyMC4lfBywP+FQo4I5Pvx6D2pr18zO3ZEkkqMBkcetNecAcYA+7j1oa8/Iu/ZEAucdMen4f WpPthPUexPv9Kdu/yIuRef8AXPt7VPBcDvx6n29vrTE/T1HPcA9V9s0iXWPuZHYj1pob8kNErd8f T3rTs/EBUYnAce/b6Ul6C/4c1fItpceQSD1lib+HHoagkiKEiFSQeGVux+tc7Xc64z8vIoSWi/8A LNQD02HvVYeYp5GOy+2agrX9Cyt0oBy3+yGHr7fSu8TxkbuBfMOZEGwMe0S//XpE3/yZxeu6ubgf vizODmP/AHPf8K5rzcdwB6f/AFq6IomS/wAiRrh+7EDrx2akjlz0J9MnuR6fWtf+GMr9xR5h6Zz/ AHfU+9NkjkT/AFjA9jj19jST/wAif+HHvC+3JZgp4BPoT2pokY8I/tn1PtR/wwND5QR169sdqEkY /dUns2fWnf8AzLJ4XI/5Z57YPrSF5B9/jsPYe9ShLzXoPNpkHaD60kURH8DMO4I6Y9KXzLcey8yV 9PY9I2x0J/vH3piadIeqOR24pfMHF9iwNGPdSfakGhy5+RTjqox1ai/mVyGjbWM69UB7HNLd6NDP xPEiHopbo30PvWXMacvY5uXwbNZtm3JdP+WkZ/8AZcelWrW1Sb/Vhs9HTHcetXf/ACIcP5TatfCj yEYSXnnZt+6T+Heth/hRIcbopN3VVx1o5n2NEu/qy7H8G7w5zpz4HzMCOw9E9q14PgdfPjbZ/L3d j0J9SKF5jaXkeYWfx78NysQ2piMdAXB4P+yxrUs/ipoMhzD4itkbqEOfmHtxQ4HKqneLOksPH2m3 PA1e1bqiHcOSf7+asy20qf8AHrMkifeYKwxg+p+lR8mPnXV+ZWlRmH3IR26DlfQ1Ui0fT1J87RrK XPDkoPmUfT1o9DSM+0htx8K/CtwOPDViVHAUDuw9vSsGf4D+EGzv8PrE3QvGSNo9qWvWTNObul3M yf8AZn8LMDtiukbpHIjZ2j/aU1Th/ZK0WVfl8R3cMnWMlR+oHrWin2SErfaiitc/soX9uAdL8aTY +6y8jafwqjL+z/4xQf6L4pWX+IAykY+hI70Kf8y8iHCP8rGP4F+KEABtdXM2ONiyDKn3BXv9adM/ xahw0lrLIPVQp3E+pAHWnzx6R8jP2H8s/NDx8d/Htv8ALqvg8yEcebtbke+AaZH+0xrSN/p/g9sc 5XDdPY7e1HKv5g9k+5aT9q20J/0vw5cx9gynlj/u4ra0r9rLQgSNQtryJP4gwzgexUdqfL2fmZrm +2vI1h+0D4NkP+ia8Y88oJEIyP8AaPt9K0Lf4q6BNk2+v257DJ+8PcGplB+Q1V/us3LP4h24Hyal Zyxn7illJAJ7A1eutGs7obo7SxmHRwVU4z68dqzS8i/a/wB4wrj4caBKf9L8L6czdSwX76/T3rLb 4HeECx+0+E7fniRVyNo/2Vp3f8zNo1PR9SG6/ZW8Dzg/YbC5iPUqrfdIHYEVhyfsk+HD/q9V1C2b oigA4I9TTU30HdfahEz7r9lBYudL8YXxYchnHAJ9Men0qaL9njxeh3aJ8QAzjlUY4KfgwPSm5/zJ dyOSPZksuh/GWEbY9Us7tBzGSVy6/wC0CBVCPxL8VrRj9q0CO47hQOo/2do7/Smpr+XyJjh/5ank kMX48+KoRm68BSsRxKyB+vuoXvWkn7VtmQP7Z8LalbMRncqnqPUY/pVcsekiXTn9izHQftS6ISBK l7Ep5wyn5F/EVtW/7RXhcn9zrjo2MKJEI4P95v8A9dT7N9Ldxc7XxwZ0GnfGnw/fcL4itQ+OGJx8 47DPrVkeMrE/e1WyY9NzEfdI/vms3T/ujVbyfcIU0x2yLfTLj1Yhfnz61NJ4K8LXanzdJ06OUYEc RQfvmY927Yo5X5o0dbtI9AvfhfdaBaqVW3t7c4aOKL/ljLJ7D+9Xnur+LgRhlbeciGJeTKw9h61q clR3enzO5+C37Pst/N5/iVWWBOYbZh/rZGzwB7fpX0xJKDwoVF6Ko6Io9qumv8kbV9Ekv8Ujz7xl 8Rsgx6ZKQv3Lq5X+P2Q+1eYanYxS/wCuBP8AEoz/ABGsq0uxhRj1f9Ix5NGVf9XJIo6jnsD2zVK5 spAP3d44PYkdq5v6Zun5GDqmo3EWM3yntJkfeB7CsG91gyngcHjB/g+tTfv6Ciu3zGJCfQZ/iYfx CrcULHGcf7J9CP8AGheZfzPpXw9bl40O8s5AklX0UD+la2Im6BXHcHuRXTH/AIBlNkkcKD7z5P8A Ap/hHtUEuoRKf36sqdHbH3mPoPemiL9h1q4lOYkKqfmRsfw/Q1JJCVzlgR936E1X/DD9fUzJMqem fXH8X4+1WowpHzDHf61I1/wCB3zwoUdmY9cf7NNmUkgBF44L/wB4fSm/P1D/AIcngAPYgdBntV+X UEjBEo3DoF/vZ9B7UvUH5CW86MOIiqjhA/UHHZaS5mL42xbc8bz/ABovp+NUJ+fzI3ttmTuLEjAU 9Aoz/SvAviBrMs1w4mi2EfKkY/h4PTHoOKGZSPNoixkOFDHoAO4Ga+jfhmki2ifZ41GSWZj03E1n Y3pr/I7VInU8DHcn0x6ULCR1kLe+KsRBLesgO4Fu6kfwge3vUqSSEcjHcg+n0oT7it5+RI0wP8Q+ o9aryuuR5xRwP4WHQ0f8MFyG4a5K401dNznKK8Y4J9TiuO8UXvxFt8Mlt4dMIIzcCMESRc8TpjsA e9YuPZI15v5q00YR+O/jeHLadpnhG+Ef72dIyuYIlHXYwB6V5z4w/bs8U3ccsf8Awi3hohgbaf5M NCTwQrY6j6fTnFc/tLfY8r2Oapd/BXn6Hzprer31w2670+1gPXEIwGyfpWXPfb/v+Wp+7hRjP5Vr F9vUFHu2yF4kxzt9296jXTp3P7i3eX/ZUHJUegA7Vqn3L9m+z7m5p/wx8RS4Nj4euXTrmUbcg+7e tbkfwd11z+/0q0jHQxvIOD/tYpT8r9jVQXWS72N21/Zu8QTLmSz0iCLqs00p+7n3Hemx/AK3Vv8A iY6/aAdQlrGzF/beazUH1k/IpSX2Yyfc6nwx+znp9yx/s/QL25VcF7ychF8xgeMEdsHv0+tdJL4Q 8C2hH23TINSkHWzTJCOOm6b6Vp7FP4m/XuROs18KjfdeXqVH8UWanGg+FdOsQfuQqu5guP7xH8P0 rXh8FanOu/xNqjafa4+R2PMqf9MrdcdT0q+VfYjfs+xl515N/wBdDH1X4i+EtI4s4UlkHy/b7znd J/0zgX/9dc/P8Y7K+P8ApGvRPnlIx8oAP91QBXS0/wDM5XO/xRfkiD/hCLvWX2+H9VmDH5h5QBEa c8yHHpW3YfB3RdDJPibVZ9dvsbkskJCWch6CZ168YJ6elY8rfXzkdHMlvHV/D5GN4w+I+vTDFvZS yxjK2wThIYsd0UfxmvMF8eeJA6iC6upJWPk2duqf6yVzwI0x3NaykuxnTo+bPqbTPhBP4TgSX4wC C71GQedpvhiPH7lkJ5uZU7IMHp149a881P43S61PtuJnn2nybe0jHEcjf3Ix149ulTF6Xl6ryRpV WtqWqWnqzsfEHwNtLCyM+t6lHaao4xpOm45lt0bnzD2Cg55/LnNcbpOhXNx5a27RTysVthjH35GA zsHpmo1tqvNehcWr2i/7nzPoP4zTaV4G09LXwaPP1JlF54ruU/1ktvk4LAZx5jbgoHYdzXzZ4Pt7 XxSsqR3cthqaA3VjYP8A8vcODuMbnqYzg+306Uo2X/kzFJ3bb2/hx9DiLnxV4n0lzHdX7Nj5RDMM 7gp9GH9a1LX46q4/4nWhQkdXkiP3cf8ATPHen6mTi18D+R6z8PfgN4F1iD7d4ujhh0tDu8uNcNe3 eSAqRjB5kGOnNS+JPjJLrm37LAthp0eYNE0ZOlmgPVzgZMnX+VEI7uT/ALsTerNuyS/6eT830MTY T2P90gjqP/r14Z4p8C30V3Ktno97MjMZ7MxxsQyv2DBexpc3dm0MPJ/DBm34V/Z+8f3cn/FPeH9c s2PzLdeW6jK+u5R2r7Z+D3wl1/ws8cupOfE900ZUxKvlnSJ2yCBKRzuQ9cf41nKd9vVs6vqvKryk rv3Y+XqXj+zq+s3j3XxD0m3uJy32qz0iQ/KjoML5jL/zyUDuaTxf+yzrHiBydd8cyWini2ggQH7L Ftx+74H3vpx9Kak+n+GPoYtQ0VS7S19Wc/pP/BMv4fwf8hPUtW1JvvSlwo3v7lR3rubL9jn4YwAY 8EWs2BsVpmPKj+8BUODfxvzOn62lpSpQXQ6/SfhX4XslK6TodjZRH/W28I4k/wB9a1beHTYPuRQj sFCjkflWsafmzgnXfVjJ/EFuv3cZ6j2HsKy5/GsQ/i5749a1UEc7myrL4xi42hR3x9fU14/+1p47 1CPQSkEzqk0sdpMFbhoFJOGA/v7a2h5GT13PjTTb/BwuFXuB2Ne4/CDxfIboJduvlMpADdpgD0ND YreXqfQ39mqOnPoR3B/xrJ17S5XikELFTtLKy9QUB+7VrzBPseP+CdT1b7VlNJlfAKQxJuPmjBxv fH8PWvc7z9n7xFqtuqQlIi7C41SeTjaqk8D/AHfT868xRt8C8z1VS61nbodV4a/Yt8O2hzr9xJqb 8ZhIwFIz0K+teraZ4f0+xXboumW1onTbGozgerH0reMP5xVa/SkrL8y4zE/eJPuaP84rY4QAFGff 6UwFyaOT/SkAm0etOAoSAKUCgBMCjNABijA/+vTATGelG31oAQ0hPpQIQVk+LNCkvbOeO3jDyOhj tUP8c3bB+tBUfM8N+B/w68Z+Fp7o654WkltZlQQNE4JW5hY9EA/jVvXtXr0vxRaP/X+HdUQ9QNpO fxAp0/PQ3xNN3/dTgyay+JEEv+u06/g7guh/oK34rpJADGTg/MufT3FVJdmjmSf20PLf59KTP+fe oGN30wv/AI0wGl6jaSgRGZKYZfp7UAQs/wD+qonemBEzf59KjZvagLETOR/EfXFV5oI3/wBbDG/1 AqlLs2MybvwdpUv+u02D0JHYe/1rnb34K6XJ/wAe8jwnqAAME+/Fd1LFyX2rnPUoRfxQXY5u/wDg feD/AI85Y5D1C5Az+lcrf+ANVtyTNZO2OoAzx7DFe/h8fF/xPQ8DEZd/z4kc/d+HFY5ktXhP3iVG OfcY9KqNo86giCUFf4g3Xn8O1bYjCwltb1OWlXnH47mZquhXEmOFO0bQB/F9G9vpWHNpMwPNuwX+ Fq+SxWXSXwq59NhsfF/EysYzzlWI6DIpFj/wHv8Ah7V4rg+qPVjLsL5YPQnPXHt70rAf3VI6hW/i qDV/3X5mdc+GrdwSm6NjnlexPtisy5s72JlZ1Eyg+UzL2jOe2Ku/cH/wC5bXUDMWSeXp5ZhP8J9e naq9tqh3N5gyM5RvVST2FN36mZqw3MUi/K24fd2nsOadPAMDH0b2NYyRSYxBk8sWONpH93HoPekl BPTB/iBHoKk0X/AIfLY4xgf3gP4wfWhV68f/AFqTJY1UyOTznr7U5nHf6fjRfsi2yKQEfeBz97A7 GlTp86YHqfX3psUV/mIO+VGBwMd/pXQeBdQlhu42hcAr+/wO5Gegrej/AMOZ1ep9La/4r17fA3h4 xtA+I9Y3jpbMee3cf57HF8c/DDSr1GeC0jhuAd0k0Y/1ijPVcV1Sh3MaE7W130kjyYeBdcstz6EZ uDuaW3JyvP8AFHjv9K6bQv2hL2HjxJAZl6NPGuGiH+2gHatIVek/RGdeh1pfM9K0jxrZ3i7tLu0m XrIB1Xj+JTVkalgnA/8AritZepzxf+TOS8YaudgVVIB5fH8Q561zOmW+6RcgHB3H6j3pplts9JbV xnqff2//AFU+LWFTqfce49qgPkVda1d3UGKRwfu7FA5Ga4nxTHdygNbHYw+QsO+PX/8AVUXNYru/ I1PDWqzyxk3bkHPlhPRR6/Wt6OU92+o9RTb7Ga/4AgeNjycen1qO+gEiFQ5wRhwO6+9QzZPsON5G qgRjAACn3xUX2mMHhgfp7UguNGoRc4C/X0P1rG1jwxpd6P8ASYFifolzHjIb1PHY0mjSM7bHnOq+ EL2yYmzk88D5hNFwVAJ/hq/pnxcu4xi+xcr9wtjDR59FA7VKfcupFPWJ0lh42gk5tph/tJ3U+/Fb B8TAAFWx7nuPanbsc6ff5mH8Qb9RaRbBHvkdrlmxyYYhj73uSa8wkj/x/wA/WsZ+XzOyL0Kstmey j6Vr6Za+dbsCFDKTMm7+5g9qzkyof3jGFs+07slupFTbmQDaSO5x3Jqosc4+ZsWd68a/KRjufU89 DS3c6uOQGP3sH+H6VuzmTK8dyp+8T659FpJJlH3EJ7KT3HuKr0ZPyK2T6+//AOqqk9ux9++KVwsV Gifso981H5ZU/MQfTH9KS/4Ax0YwSV69QfXH+FXYtVz/AK9d38Kn0Hv9KmSCL7rzJZbKOQfuwD3Z h/CfeqE2lMPuEE9R/wDXpplSX/BI2tMD5sA/dwKiXAPAwe59SPWm2TynVeF3V93zEHaSv1APWsLW bnDHBA/qf/r0BFmM05/iGR6VGZQfuMR2+hqyFcUSDufofWmSTN3X2waX9ILkfmkHgDH3ceoNSyjH Tg9Qo7j/AOtQwS/yJ7K+VW/ew5GMbT2H1ps3lk/IDjoPp7n2plW8xVVz1V2HTgdf/wBVRPIVP7t9 o/iHqPf60ILiykHlcL/XH+FCSA/dYH+Ie+Kd+xD/AOAaC3JP3JSp+8SP61oDxOVOLtBIn/LOdeuP yrO3cd+xoLaQTDNu+4dNveNv9oH2qtcae2PnXcOhI7fhWMkdkP8AgHM6pol+JUNnKfK5M0Z/jX/6 1bGn6m0TYkQ4PysR2x/jUtCa7FLWoyDmNTg85HcmsmNRkZJHfb7/AF96uD7vyFU8jRXTpWHCjPUk diKkh0SU9Ax9vWtLmaX+RYXw9OP9Wpx1A9TSSeEJ36ozDqR/dNLm7FRh6dhR4NnbGUcD+H3+n0qy nge4B5b8PU1PON0/PyRYj8Eu3+sdR6j1PtU8XgVerH3BPY+1JS/yRagiz/whyDo5P8Q/D2FTp4Jz /wAsXY9yAeh9/ajmNFH+6Xofh9cNny9MuD/FF8p+ZB+HanDw3j71qVPSQ4/pRZ9GL7uxs2/wk1GQ AxWClW+eN27rn+Ee5rUT9n3WApL28USgGV8nso7gjvT5e9+4KS7mLcfD66g2/wBqIsEZO3zQQdkZ PUIP/rVPeaT4dtgCNWursYLSKExtkB6ckdql+S8mTft8mecJ8SFeTamlOgz95s/cB9cd671PFegt CF/4RhpZ+VF08hxls4yo/u8elEo9mzJTfkc7cWDoCXgLKOWjUcrj0+lQ6DrcsD7ra2MZHG2ZPvA+ iN/nuK0t3KcX9lep6Z4G0l9UZgurmCQZmKLjMnrgY6Lx2r1/S/hvaxL+8Rpjj5i46N7VduyXczUv U2I9CQdI9gPyYHeMetP/ALH4+dhHH1CqPvAD+L6mgX/Dnwzcfs+eEW5j02eMdNit3/2eO1ZA/Zd8 PM3z6lfrGecAD5GPqfas4z7o0b7pBdfsbWqgmx8VzbesSlehx6gVmx/sz62mPs3jHoNnzM3U+3tV ufcjlj2ZCPgF43tyf7N15GP3mZJD8/50218J/FFTi0vjnrtLghuP4MjvScl1QvZL7LSJoNU+Ktly LKWXH+sJUHI9jT5vjr46H/H74UVz912VG6f7ZC07Ih0X9mfmMtv2l9YiyL7wm7DvtDfKR/eO3+tT wftVRAf6R4cuAw4dkJwT7ZFDiukhcs/s/M3dN/a40Jhi/sLyIHhuM7SPcCrcn7RPhJuYNVuAOoVo zn8fpS5H0sHM/tRLdv8AGjwtKoI16NP7yMCCD7j2rbtPinpYAMOvWpQ8bt+MA+qmo5e68iva94vy Ns6pbzDdZalbnPBAYc/TJqq16vScWrnsx2n/AMeqOXyH7RfzeZTl8OabKQZdEspj1VnQfNk9sAd6 if4Z+EbjP2jwtZJL90lR97HtTSfWT7FqfdmDefs6+D93zaCy+uxiMH1Ue30rKl/Zm8LSfcN7COgC kHH0FHM+5rzf3YmfH+yRpLki28V3MH/PEsnXjo+PWkuP2XPEVng6R46kOeAvzDYfp/8AWq1Uf2rG coQ/lfcpz/Bf4kRf8eviX7RjkFZRlSfTiluI/i1aYM7tc/wrgqcjH8fFXzr+Uj2P8kgj+IvxOtGB uNCeQfe2hDhwPcD+tWJv2mPEY/4//h+uf4iu/IbHUDbS072JdGX2Z3G2f7V1xHkah4RnK9gmcrn+ 8SKtD9rbScA/2Dfwv0lA/o2KHFdGLln0S7m5bftU+Dpl/wBNub63k64aMnA+oq3F+0V4VOAviTaO sL7D8hPqcUOk+lg9o+sH5m3Z/FXRXb/Q/E1lKf41c/eX6NW9Dq+j3/EU2mzP/FG23n6ZFZcnaJca 3mzO1HwLo0h/07w3psh/vBRyD/tD1rDufgn4Rcgv4XgHaREyNwNDv/MzaFVd0yB/2XvAtwP9H0y4 jbqVDfcA/u1jXP7JfhccLd6hbnpxg4x7GmpPoy+ZdYR7FG4/ZJswP+Jd4ru426RhxwF9sDtWloX7 OOr2syPZ+N5bmNSGvbZ+skKn374+n9KHUf2reZKjDrF90faEF34Y1KzEWt6qrxYEb7+GMqdPLB9D XGeEv2WNKjuZJZ5ZZrYtu0wScmSMZ+4a0t3OanNXfu+Z7VHapEgWziSGMcRov8Kj1NcD4v8AHzEG PS5sHpczjuPRDWrdv0OSbu9X5s83ujeE/uo4mXsC2MH6YrPmvL0fes1PYlW6fgRXA33b7nVy9mUL nUnUfvrOQdsAd/bFY1z4hRiQkbqRwSR0J9DQga9PM4zW1mZ/3r/J1RT/AANn+tNSHd3H19QKh+Y0 i3GhHVRj7pb1NTCEHnn0JHpVWJt5+R9EeGb4m3i8lyvyCNnH/LQknqK2gqAfKuMcSN/e/wD1VvD/ AIAqhNGqt/ER/eI/h+n1qq5gQ5mJC5whPOC3tVWIX/BJkinUnfLlSf3KIPurjufepxOR0IweGBpl P5+ZTeFiR+5BHJZ/QD0oNwuThc+/pSsD8vUqTOp/1ed/QE9v/wBVTtLkfLHk9HPrg9z7Ckx/8MSm 5jUAlifUAdT9B7U5GuJsGK6jjA6KRy6+3HpT/wCGJt6jXgfORGsnbae4PtWzLGqAebCf9k9ix9D7 0JDMTUtUQofOAVQGYDOOEB6j2NfNvibWBPITCT/ciYdSATSk/wDI51v7vqczaWz7jnjsWNfSHw/8 V2K2iCa6jXblUjbH7tmY9T7ms4y8jpbstTtf7e0wD9/fw89U9PqBUsV3E4/0aVHB6bewPqa3sYKf +RUltmJO5VyOAPf3+tJHED0OSOHX0/CpsajJIv7v1x71CNPOPmHPZR3+p9qPUfz8iwbq2jBEwG4g 7B/dkx2/GuDvtE1FhjWYtWuLb7sYtJQPM5z+8jPpgdc1EvKN+gJr7XL5XOGtfg58IftK/wBtaV4h hcnZcPIX+VF/vSJnofzNXfiH+zb8GPJLeGdbvNJnGdsu4t9pbacAxyY5Zvp9aI4Zv4n6FVcXbT2V Ps2jwG2+D9uzEDXZr3kiBIYvvp6liO9dJafs/eGbEq/iexiXuIJ2yZxjvGnvx1FTGj/e8n5E+0t9 nziuo7Wb74fRJ/xL/h7anHK3chbt/djFZGmfFUyyBPD8EUcn+qSK2t+VHvKV7fWtnFLrfoYqU38T fdnYz+DYoBnxf4geOQfP/ZsZBYkdd7DgYGO5rEn+NWh25K6NJa2Djhnf53I/3m6ED9auK7rzSM5V OkL9m+5peEoL3W5c2dmNTjGXuZZHwqRhD99jwNgFdjeeJvDmlDH9mWWr3PVYo8hLPb/z0fHO70/O uGrRcmvfaS1kjrdXlVoJJvVeRxOs+PNU1H/j/vtsQyILSIBVVSf7qgUvhP4ceINWkb7HZJFYoN15 qkhwIGOeAGH8OPf3xXXOXZeUUZ0qfd/36jOim8S6Bo5b/hFYI766x5UviGZeFx1+z27D8B6dRXlf iL4w2xlzrdzcSO2SZiCc7RjCr2wPStEv5fmzGpJvp5QXZHPnwn4V1Ilra/UTN833uVJHdWrf8Jfs Yz6kGk1HV1tNIj51TUSo3ZOcLAnGS5446d6iTf2fRG9Fr/l7Hb3meg3OtWunQrB8LNLSwtDk6res 3z6gy5x85HRCT356nmvArjxj4kkkfyLuWDa/kGLA5bd/GSOd/Wrulv6PzMHG7vL/AIZHSyePtWtS Be+XOcZkB4249AvpXv8A+yXZ2Ouai9xeaJGtvZo1zdzuARFeSKdpQ45KYY+2KwduvodmHTTvCWyc rnLePvG1z4q1JppgJwzeRa6Sh/1mnxHCoQOfuAE4wSea7698KeCvDG2ZvBVlb60QTp1jE5YwNjk3 LjI4B649hWlSCb1k9NH6GEJtL3Erv3V6nz38RfibqGpu51Ge4eRj5UkpGDKxOAsS4Hyr0HavUP2X f2frnTtRju/iTDNpmnohutDtLjJGo3JOAXRef3TcgYOfTFKpPpH0+R1YbD21l095ebKfxF+Muv8A iDVJ5fDvgXVdQtnIWwDxSDFnbqFXK7eN4Gfx5rV8N/ArxFfsskPgfUNIu1Pm2k0ikGOQc/LKwH06 fzonUX2Hf7JdHCyteo4rrJHaeNf2J9X8TRq11aW+naiPlvLncMTH1jIH9PpXLaV/wSbvyf8Aid/E aGE4w0cCA8H3K96ycn9lHTTjS/5fOT6Kx6z4X/YN0PTIBDc+KL/UYlY3MLSKBsLADCxj2H19a6y2 /ZU8DQ/6zTjP/EVYjDH3AFNRf2mZvERX8Kmu5vWfwe8GW/8Ax7+GtP8AX5hnn8a6C3TSbX/jy06w i/hyiLxj3xVqn3bMZYqXSTXQmk8bx4wHGP7o7fQYrOk8WQ/whV+nr/8AXrRU10RxyqPq2UZfG0Q6 yqBVc+OYz0kX/EVpYycvMpzfEGJf+Wo9c1Qm+JSdpQPQ/wD16aRLkZM/xWU/8tlB6Z9qy734oHHy Tj2PqPanchy7Gefifj/lrn3B6CqknxJX+Ak9icf56UyeZ/oUJvHTk/K5J7e2K4f4zahd6xpjRwBn eN11KFADlkiznaPpTT7gvJHzjptqx52n3HqP/rV6p4A0ZvNUtJLEOUSRByjMD0+opS/4COuEH0Xm z6W8IeAPEU6j+wZXuIv4Fuhjj2kxXq+k/BRyAdbuUQ/8tLePnPPc1jCTOlwit18jqtI+H2h2BJ0j RbWFz/rZwOXP4+tbBY96tRM6lRv4n5IUZoyf61ZkG0/40bT6/SgBQnqKUIKQC7fWjaKADYKAKAAg 9j/9ejJpgJk9vyoDY6fhQAbv/wBdGfQ0CDP/AOuikMTHrRtpgJikJ9/woAPNb+830pTMe5+maVgu MaUn+v1puPYU7BfuJn/9XrSFqYDC/wD9ems3/wCqgCNpB/ntURf3/GgRG0uPSozJ60IZE0noPpUb SCmBE0nvUZk/+ufWgRCX9v8A69RtKKYETSn+EVEXb0oBEbZ703YO/PpQHyM+88NafP8A8fmn2799 xHY+pFczqPwU0qXm1kaBumABg/U4rtoYqS2bMatKL/iRXY5vUfgxfIP9EWKYdWI7L7KK5W98F3cf F1ZOuOwU8j64719FQxkX8fofP4jANfwWYj6DCc7sr2ZGHQj2IqhJ4Pjb7o9l9h9KWIwEH8Nkc9DH Tj8d+1ilN4PlX/VHIHynj72fU1WbwxeEZWHcOnHYH1HvXy+Iy+S6XPpMNjovd2KslnIOHif8j0Hv VfyiRyQB12+wrx+R9Uz1r9mu5Ru9Jif7ylO2V4z9a59vBuoRNnTp1kHLCNv4lOfUU0+/oXZfqV28 QzQ/8ftnLHzjz1B+U+yAVrWvieJwNk6ydmHdSP7ykVVjF6bl+HUrZgNjkN911Pf6VMwYD5VAPUE9 h7fWsJRNFIiROOVCnoT6/wD6qcSBnaR6n6fWs2v8i/X5CIv+w2OpJ7NTBFkfJgd8fT0oYyOVWH3R u77v7p96ERCDnPrt9SP8KbBAYTj5QPQk1r+EoM3KDcMnKkeuFJGPpirg+wp7PQ9z8BfEaDUPNjhl Jkhb7NNG2egH8JI7V2Us/B3Ef3CD6EV6TfY86KfU5OO/NnKwVjtPDr2ZST/KqWseENKvsma3EMh5 S5i4J6/eHtUyibKdtn5s4S7+Her2DF9FumkIO8yxcMFHqmO1XbH466inGuWe9u04GDtH95MCpUv5 vRFVIJ60/mbF9rkF+AbCdHA5ljU8xsM/eX6e1M06XYw5/D0JHrWl+xyrz9Df/tRf731+tA1f+83t 9BTbLSEfXR3IPqKqXV6jA78kH+vtUstGTZau8THbnb2APf6Vtp4iPbp6/wCyKhvsNL/Ma/iZP+WJ Df7Q7mql14mfn5ycjJA7H2FT8x2KEHiGUjrz39ql/tiXPDf731q7iSEW8l8zAkypG4n+6w9P96rZ unx8zexP/wBas3I0SMqWfnL8fwqPUf8A16w9U0e0kJPlhG6q6d/96s2VBnPXFjPDyhLL/wA9E6qQ e61pWXjKUf6wGRfuknsT6jFOL7ja7Frxx48064uYYrC5DskCs6josrEk/MM/zz64rB1SOWOJjbR7 5ACYI/VgD0FTP/gm1J90U9K+0ywI1+myTG6dPRyT2960/Ct+5mKyQssbA2zuf4gwPTPoazfl8htO 2jKHiew1OzlxbRI0ROJ39B/+qoYsMcDJ7sp/u49faim/L1Kqrz8y6iAngYHRfb/9dWfLB6nnoR7G ug5SLaQeQPTA9Pb61Kyp2IP4dvpS/wCHK/4YiMidh7fXFQykHqo9QPWqJKrLn7x2j+dVpFyeR9Pp TuD/AOAROPTj3H+NQMR/ewRyPfPofakv+CJEsV2ynjAzyp/vCrcWtIT/AKUp/wBlx2GPSocfMuJL LYpKP3YLd4mXuPpWbPp8icheOnHY/wD16aZTXb1RNpXiL7OTuPXj8/8ACs/UtQEpJbaTndj61V/8 jKP/AASmnI9/4V9qI7d2PzMF7g+1DY0hwgYHn5vTPYU548/dXHYn1NSpd0PlIXtm/gz+HanBH/i3 Zz8vsfp71fMDj2JFt5O+PXPtU6WWexHZfb6Uk+wNeRoQLcKMRMAO3HT6Gqk/hqVjkuQere9Z8/Y0 jAY3heU/6uMkfw59atQeEpAOUOfusAOn4+9CmUqff5FhPCsuOYHI6Zx1Wpk8Ly8bICR/Fu7D2FJz L5O1i/b+G5FPyBlbo2P4setakmmTKDkIT/Dj1PrUNjUf8zEj8O6tIxLWaqmf3ZB/1i4/iGO9F14f mX/j5t5Iz2cA4Bx/exVSS6FRh/mZ7WEoBE8Z2dVYf3qzW0nB5UkdV9h9Kgn/AIdF61uxEOqt3Cn+ 7/8AWqeb4laZCM3xSDH3mPrjuKS9TJx7fM09P11Jow9uN0RHnQyD+OPHVT71FpXj+3vEd7SJgikp MrDHKDsD61q49yVLsvIj034rW9yu6PT5FXkOoHVh+Hr9a6my+JPhZR/xMNI1xjgZGFwsvfAHYfhW qiiPf6KPY6zS/iV8JeP7SsNaikPGDET5anuSPT6VqH4h/B3eDHd3zL0aN4WxIR6L9apU30sCqz6w j2L9n8Y/hyrkxmG3GPLiPlcqf9pD6Vd/4Xl4Mc/v9Yttv3ARGB/QUOn6djN1pdn2L/8Awtvwk20v 4mtnIAjjjYcLGvbd7Vx3iDV9Knctpt9aSBiSsMX8Cf8A2X0o5fJdio1f5oyOh8LfEsWiFNSYFOXt LhhnycDofw6VU174o3WofLoV3a26keW000gG9c989unrQ/JEp/zeqK1j8Cm1BQdY+KWm2x4JSJlJ xj/aPb6U6b9iLT7hx9l+MEJU/M6ybOpP8Kg1ny/3TohXh9qnM8k8WeCbTSrqWGLVYL0RMbeS8XH7 wgDqFJ6g+taPhDS9Oklj/tueRLMnF5JGeViY9UP+z+tKTCaX2V/eR9K6b8GPBAw1qk97Ef3luznh s9zjFL4t+EHhbUI8W9jHYzgYhuYRw2O0kfvWjXdeo6WIfRLs0ZXw2+CVtobtJqN5DezMPJs9owIY j3Yeua9HOtw4+cA9sVVv8jGT190iTW4FPCr6kUyTX4O8Skdx6j6UW/yJufmzbftSTRnGoeFZAnRA rN8n13DvV2L9qHSmJ+0aLeQ+uDnH1GO9Z8i7haXZdjRtf2ptHiB/0edxwGgcHBTP98Cty8+N/hTA zqxhc/MsRBOw+jOv+H1pcr/UXM+q8kFr8YtAlOItdts43ckjOB/Dkdq1bbxdpUhzaa5ZyEdGLAEH 6Gk13KVTvFm5ZeJrefiTUYH7eYjDjjvSTvPGSI5g/wDFjIO5fapa8mWpruQsC/8ArIIXPSQFRycd GbFQLY6cObnQrFkPDAxg5HtxSS7epfP2l5MZd/Djwxcr8/huxYHkqV+6awpfgt4QORP4ejTsuz+H 607v+Zgpf5Gbcfs5+FHB8q1uIz0ikU/cz6r71nx/sq+HJVwdVvoZf+eoCkN9eP6U4zfRF37xXkVL 79kVI/8AkHeLbuP+EqyngD0Aqjcfsua2o/0Pxeso6rGxIyP9nPpVKo+qM3CPZ9iOT4MfEKHBsdea UjiICX7gP+zj096sf8IT8XLcgxTJcfxHDKRn/aGKHNdmL2S6St2JX8cfFOLI1HQ1uu4cr9wY/hKi qKfGvxfbk/a/Cm8fxpsYZx6ECq06Ml0X9mZZX9py9U/6b4KlXuFXcCCPbHQfStLT/wBrvTlGNZ0e 8jXocZPllvQ4/pS5V0YuSfYvH9p/w0Sfs9zdqPuhHjPzH3NWrf8AaH8OSLmPVmQ/xqynI/HHep5H 5E876xfc2rP42aG2Nmu28gPKBjyp/wBrGa2ftdtPzZXtrOPvPgr19xWbh2RrGp3uik8cLZ3R2zZ5 K7VO5RTLfQ9MUn7RoGnzIeZkZB8wHpU2fZmkaq/m9CeX4W+DrsZt/C9iMcGMDqPrWPcfATwXIMHw 4kBHDNG2ML7BvWr1/nZan3S7mXe/steEZP8AUxX1qejMpzkj/eqt/wAMb6M+To/i/UYCPmWIAZVg O5H51XtH0S8w0+1FFP8A4Zp11P8Aj1+IlyB0VZc8/hzUL/CH4j26Eab4zSQA5iidwN2D2O3vTjNf bijL2UfsXI1b4zwFT5aXQHMRXackeu0dqkufjP8AEePjVvBaSsPvsEPz/wDfIq1KPRWJlh+1TzKs f7TPiGIn+0PAshHJMYD/ACNjs23tT4v2vJFA8zwlco/UmNjjAPqR3p8sf5n2MZU5/Z1OgtP2ufC1 yMaxp19bSdUmCE7T/tcetevaZ/wUq8PxxRx26wqVHkm7kDfOF7suKqEPP0MqnN1i+7NNv22dLvAV fxjpyIeGSLjCn/aIptp8VNEuf+PHXLOX1O4fMT9azqp9jGD8peZbHiSzfGL+29V+YckegrPvfFtp CCZJG/vEgfwY6jFYOPdHQp9mc1cfE/T3IEbvk/6tiuM1DBJDJk+cD3BI6g+v0rNrv6mkfNehl63a KCCsqyKflCgfdI/+tWfbxk9vYY9P/rUFf8OWlH+xn1+tTLHgHDDPQ49KtIX9M+gfBpiW0gJBPyES exDHt7VukFhnb14QHjcc+ntVx8gnuWFhU8KSg+9O2OwHr71AqozYV18sfefHr/eHuasy/wCHJBfe bzbyfL90Njpj/GntBj7zo3Yuf6U/QH537lCbA6sTjlAO/wCNQtcRAHcxX1OPut/9c0n6h6LyKcbE f60hgPug+/v7VOlzM+BDt29OB94j1NTcpImjYjh2JlOTChHXbTtR8Z6Pp4H9tXcULnLpt5KYHcCr SM5y7eiOV179pXRYox/YVq95J/FOwKhTnsCK8/1b9oPxDcZDXyov/LONRxEB/dNTKoltqRGDfx/I 5i7+IGpv/wAfWoyscbAx9PpjtWDLroXqcnqQe+a5JSOiEUtkUZvFLL/qYlH8QJ6kfj/hVRvE903W Z077U7VMX2ZXL3J4vFt+v+pups9ck9h6mtXTPi/r9s2bS+mJ/uD398VpGo+voEqPZHpXhT9pHxIp AvtCa5iyDdTOAMg+jYH3R713M37R3g1EzfXMttP/ABWcaliXPoVHeuymr+Ryz0+B36ehly/tFRyg f2P4dvZY/vG4nYLhSf4hjtWVL+0ddMSLOyhkc8CKJs7G/wB/A7Vvyrq2Yvm2bX+RJdeJvH9zG2zR 7LTYv+WlxORllHsQPu1w2ofEa8ib/iaeLJ9WONq2FuNqQsM/fmA5yeevtURkvsw8i3BLeTk/wRz8 /wARtXum2WJaIH5Vt4Rljj1kIzyfpV9fhTBaZbx1fLA+d9rpyHc90g6l27bf1NKUv5NOly4xS1kr /wAq7lXUfiNcojL4T0q30+LGQiHLSEdN8xB6de9eaXniLxHGxL6OZ88KSSfNB/2sVEpL7KfmT7Nt 6y129D0fwb8M9SmiE3j6zg0bTz81pI7Ze7UE/wCqtQM/Mw9PftUPiP8AaE0aw/d+HNPi0yDOZ2gG 57jaTjfJjgIPeiC6v0iVWlbSD/6+P9DjrnxX4Y1AET680eefKkVgS2e7H1rrvhx+xBoeqxPd+IdZ e10GI5vLhcN9tkP8MB/2mIHfGaJ36Pf3TbDyWrnT0S52W/HPxSu4oTF8PPDUWmaeo2W+mQHmVA3/ AC2nIyd75J5rhfhh8FPF/iadpNZ1O40PS4vm1vVHGBuYEhbWJsZMhHXkL1NOT0tD0RnThduVd6fG /wDI6/xtfaNrd/aWnw80to/mW1jZCc30av8AM0reiJnvn36Aes/tD/FnR9NMen+EIxZ2cK7NZaEH N7cyAHbJnnEZOT6n6UklfV7LmCc3bWPxP8EeA3U0F6Nul+Io4pR/CMZB9GVvSs/Xvh2byHFwES5X MlvcAcTPg5yB/ePvST7LzZN1+hS+EP7Pdrq08r+PLsabplsBcaqCpLXz4OFtVHUyNjseOele2SeK INftx9ku5ND09AyeHtBVScDJHzPjJMhGcnv045pxe93/AHInTUhokov/AJ+z8+xzekeDb0KFj+1T 4+V38tuXPoAK1bX9mu/vG3Q6NKzZ8wkoRuf34qZvsa0sO+uhuWn7BGr3kwbXhNFaEE3MKbdxz6Kf U/SvVfDX7PniPT9Pls/B17Y+H7aXI1DUlO6W4jbs7bf+efHGDz1qIrXVf4fU3qKNrc3+Nj/hr+wp pnhws513+0b45NjfOuP7OVgc+QnqwPU810Ef7KXhtpWfVp7m+lf57neRhh6AY6IPerjF6367mcq0 L+5Db3Y36GzB+z/8P4cZ8G6ZK33szjOCPQH1rdl0/SEx5sFuQOLeNxnylA/hDegqlS82ZVMW+r9D Ri8VWcY/cTBOwVFA/kKgk8f2w/1oaT+6WPT8Peq9kuyOaVV9WZl78RY/+WYCDoFB6VkS/FBUPyyK OwPpWtl0MubuzPuvigv/AD8L7gms2X4rIOtwB7+tL5E3M6X4wIvWfP49qzrn40xdp89gPQ+9NEOX YyJPjnHnibJ7j2/+tVG4+O6n/VuxHQE55b24qv8AhiObtfsZtx8YJmHCO/ZgB90H2xVX/haFyeE5 P8A9PyHas5Psx8v+RVk8dXp+8+OwPr+lUx4g1N8h7kjnKP8A3lJ+nYUcwmhzyuOWuCW7P/hT45Tj 95vb/aA+8fbFLmKjG+0SzY6cx/1VtKRyWwp4bntjvVyGxkY/6PZXjY4k2xtyfYhe9JvzOmOHl1j5 mtD4J1JhlNCvMfeJKEY+hIo0XwrqWpSbNF0Sa5OCbhjwoUf32YdGob7m6w77x7vyOn0j/gnRYXEm /wAQomnZPmSw27A+a3+0uO9e1eHP2cvBelbf7P8AD0E0i8RXM3UE/wCx71Ci3vc7pV0laklfqztg MfdVVHUKo6fgKAvt9frXQkeY33Yu0etAWmIXaaMUgF2j1pSB6UAG36UpH1oAPpSY/wA+9AABQBQA H/P1ooANvp/+ukx7D/69ABtFIVHamAm30o3fT2oAN1BNADcj/GkZx6UCG5o+v/66YDSf/r+1IX9M 0DIZ5XAPlKC3VFPc+596rWV1cuv+mwCJ+hQHOVB65/2hSH8yZmPqBTGlqiSNpPr6VEZfc0ICJpff /wCvUTS/X6UDIjMPX8KY03+P4UCIXuR2/Ko2kY/TqKBjCvrn3xTScdBQJjCw9aYf/rYpARk+lNZq YyMj159zTCc9h/jSCwzd/wDrpJVRhiWOOQdNrDtVJ9mBi3/w90ef/WWCRnu6Ac59jXN33wRgJzYX 0gOMeUQBnHvXqYfGyXxO5xYjDRfxR+Zzt58KtWhJ/c7l6pj+6PXArFl0W4U4lsWB6kgHoPQ4r6Gl ioPdo+br4Ca/hampb6PAwzcRbVHEruAcZ9ARXO65rGnwAmKG2wPkjVk/1in+9x3olh4dl3ZzxxFT bmmcPfakLg820MQ6KUH3lx3H1qmIxjp7J7/SviMxglL92vM+0wDlb947sWayRxiSNCP4lwOtc1qP wygf5rGTyZM8AjhwM9SBXnJ9j0v8S9TGvNOvrb/j9gYr95ZFBP7v2wK0tF8SlziScuOMBh9zr/Fi qT7Gco/8A6qPQp3J8pEKAeYrg/fB9h61BJYuMhkK9m9iP8KmUf8AMuEvNAoGDgn0wKgEZ7cVkWn2 HiAY+bOepI7UxUA6Aehb+9QU33BkxnJPsPXHtU+m6mbaaN1BBVhNn0UHnH4U4vyIe34HuVqlvbO0 mnRJEX/fO6gDzS/Pz4HYmm2HjW/mD/2mI1cEiHZ/HCO+Peu+L7nI11v5FTUtZEnII3Dv6gUyHxEx A3gHHBx2qrmbX+Q2TxAwHyueeT7/AFPvWFqEVrdf8fMQU9FkUcq3tSZUH2+Zzk/hqeAltPlbPQOp 5P1+lWrPx7cxnF+hlxwZCMFMn0A7VnF/zG0op6xOmt/FlpMD9nmG7qYj1Ue4PpT31CQdc+5/xrS/ +Rh6oqSeIYh1cDsT6Ee9V5fFO5flk3ew9qGV6FC114E/vMk/d4Pf61Zm8RFR39waTLS/zItN8RB1 /dqVzn5fQ5Oc/U1ML2Q9GOOh9vpUsaZWhndCd82QeVUD7p96mW6lJH7x/Tj1pXLt2v3ZfiMi4+dy eu70/wD1VdDEjLM+OgB7VFx2KMxxng47Z75/wrLuIyfY9TnsAKVxyRUS6I6/n/8AWqC40yJ+QNp6 hl7E+gpvyEv+AY0ehpA5dbfe+PL80DkRkmtWHUEcckY6FT3P09qzmu5uvJeRIxRug46A+n0pYpVj xsAB6g+p+tZFnRalHBeQBgw8xf3VynqBnmuCcRo4I4/hP+6TVwQm9NfQ0441IOwk9947/QVOtvj7 y/5Nbf8ADHOmu3kNkKDoAT1P1qs9wp+6x9+OuaE+/oIhe7/uqfU/X2qubqQdI89ufSm2Cj/mQmWU /dj567fUD3qs8EzdVwOoPqPak3/mVbuQkP8Ax/iv0psgJ+8f90j0ouCXf0Q3eo/iJP8A6D9KVufu hs+vqKlgl2+Q+OVkIKswPUgehrRTWw4Imh/2RIvb/eXHagLFS/0ZZBmBVY9Ay+g/2a4y6uLm0bFz G+w87yOnX2og+/oVKP8AL8jUtb9X7Aeg9QfWtWLTgfuk+mPT6UPyFEsposjfcjb1PHQVZXwvOekT H2x2/wDrVLZsoksXhCY/djYHrnHQ1ZT4f3HeJm7scf0FS2axgWoPhzKfvofQD1NacPwynY/u7Rnb qwUH5QPUY7Ur9iHbqaEHwpvT9y1OM7cjs1aJ+Etwg/f+WnqzOvBPrzT5X2YnUj3Rn32gadZRGS+1 G1WMHy5drAkM3og9aq6BrGhXxOzUlgQcebIp+YnP3RjtTjAylV/lT7M6d9K8JwAbfF5uX/jjELfu 19mqq+teHV3eTLdzY/1RWPHmH8a0jSfVIUqv8kbEX/CYaShUx6TLKv8Ay3Dtjf8AQr/n3qb/AIT+ xIPkeFbbOfMid5GJiiHY4HpVezXd9yfaPy7CT/GC5MeLPw9pNuehZVJJGe596t22veJdUhMNtY2Z jz5txL5eCGYH7snoM+h7egq+XzIin/PILz9mu+EQNjffaLjG+bT2X+ED/lnIP7v0Nea33hSeBiLq OWCXlJomH3GHoSKwkvLyPQhqvd+Zm3/h5EQmS6KgDLvjp9K5m6+FVnMQ15avdwnEsgH8aj0x/jUJ +Rlzf5L1PbtHutBvIlTSreOBFH2f7GRg24UdAD1z+NZF98P44FIs7YBDl2RB98nPUAd66P8Ahznh Lo0er+D/ANmPwi1lE12ri4YedIqNxHK3qvsa6Wz/AGWfCOwm9e6J6oUA449P/r02vLyNIYnvFdjC 1D9lvwyikxXF4G5eJWAO5sdCuO9Y8v7MWg+WCLmUS9ZoSoA/76H92oa8kbOt3iiBf2avD21f9PnB P+tKp91vYVPF+yRorD/kJTFeiZX7v4H1pq/l5EKa6wHX37HOgoo8vWZsnBwoGPm/2qrW37KkNuT9 i1lYdv3XYZ8xyO4x2p3Y3OPWAms+BLq2X984lT7nnj+JwP7vvXG6T8CV1KVhb6sllwZyr9JT7NWk X2MJW63sSn9km5LAWeqpOersOkX++SO340ms/sq6pp6GS312FmUeeCjEnYg7f7tHtH0l5o3ioP7L 7I87XwjIySfa7x5ZJSZ7qb0yP4COwHtipNL1KSOURhGMITEkx7uuPX296wfmZSXkep/C/wCO88Vy trczfaInBn0+5HP2YIOQSP7w6frXukt2U6vJu6H/AGTWiORLW3/b6EW8c48xgD2JPLN9KuCSY584 rjqqj29TVfM0sVk1FB1kGegUduP6VIo/2uT8wJ/oKXzKPlKTT7R/9bp9s56KSg5P0xVT/hDNB35u fDlg57jbjkjvisL9mbxfmLL8GvCMoJ/4Ru2BPVh/C3sKzJ/gj4RZcTaB5Z6LIjc5NW2/5mJS/uoy bj9mnws2PK+1of8AloB2J9/aqH/DKGisx8vXb6JekZ2j92fTIHrQ5PsvIaS+1FdiOf8AZEmhP+ge LZQPvh8H73+8MdapR/s4eJF/49fGGT6GQ8H3B9aHU/mRHs49mNT4N/EG2J+xa7IB0LeZ9/H+yR2p IvDHxWjOI5HmH3gxcEcf3FA/pTU1/KS6S6SRNBr3xUtP+PnSZZQPu+YvUD0Iol+O3jVDm88J7j90 gKfmHuQvanZdGS6T6TIrf9pnVUz9v8IO/cMNwx9fl7VZg/altx/x9+FrlD1aRGOFIHuO9LlXSTJ5 Z/Z9DY079rbQCMalb30WePmXOwf7JAq6v7R/hJ+Y724HfYUPIH19KfI+luwuZ9Y+pbtvjp4VlGf7 eETdFDqeAf73/wCqtWy+KeiD/VeIbVgflbB7H1FRyPrYaqd4s6AajZuubPVbduMMAw4Pvz3poviA P30LnrEwYdPqKhx/uvuXzr+YiUuG3fZYXPLFioPBz0GKnfS9Eu1xeaDppc8SKUGCMdgB3pxX+Roq naXkc7c/BvweCRc+FLYdlZcj5vcCsy4/Z68HPnytHeLPV0Y/If8AZzSu+smaRn/dj2KcX7JfheZQ F1S/ik6eYQpB/DFZ17+x7ZQnGn+MNQj78KO3sKr2j6RQny/aj5FSf9l3VU/48PGpc/eBfOU+n0FV 2+BXj2Fsab4qhmB+9KZBwR/eDDtTVT+dClTh9lPsWIvh98X7PJtdSjY/89N6nfj/AID60rXPxkYZ NvDIfus4UcD/AHCO9NVF/IZuiulTyGJ40+KUC/6RoAkA+bzCvf8A3QO9D/GPx3FhrnwMwB58yMNi Q574U1V0T7B9KhZn/auvcf8AEy8A3sUo4ZxuwygfwjbSW/7XOnE/6X4cu4Vx0ByUOP4hinyrpL0I cJ9EjTs/2r/Dp++19bHqq4J3KPQiuhsf2j/Cd5gR+IEgmPyqsykbufXH9aXsu9u5DqP7aN4eKLVi M6hYSZ/1c25flJ9SfWnfYrRc+bp2ly54kJVP3gPrWXL2izoVXvLyIbv4feHrsceHtNLDogUdCPUV z178E/Bz8S+F7eJvu74z/ED9Kl3/AJmaqfmu5k6j+zD4Sm+5ZXFp/A7RHPHrtPpWPdfscacwzo/i q5UDiJGUDr6kVcakugpWfxxRkH9ljWxkReLcf881djyR6n2NesaR8O9RsNKT+0737TOC0N3OpztC jjk+i47fnSlNsiUI2fKn2PM11ECQ4kPUqx9GB7j2rsP+EqlABS9jjTgHbg/n9aleaIS/zLUXiWW6 GGuVcDn5ccEjuB61PEuOmT3JpS8reZL/AOHJ1IPUBe3H+e9W1jyOD+A71VjPm7eh774OaI2MGGYk ggJ/dUufvH/ZrWYspxhz3Mnt7Cqii57l6GfaOIRjoS38X41lzptJAtdgJy4B+8D7VRl/wxPCqY/d RPEP4Q3qKTy+P31wzc42Y7fWhDfn6CTnb9+TK9VUDp+HvVN1yOCPXHqP/rUBcgUSOQIkHoQfU+9W l1G3s8/bmVFGWEmPakl2FKXmeVeIf2gbw5GjvsBJTzGAygGfusR2rzq71ieY5up3kbn529fyrOpP +X0M6cP5ijLdbR8gBPXgfeA9SKqm6uW/1NvMT0+6eSfwrlUWdvzGv4a1l/8AWadLEMbo3k43fn6V XutCjg2/a9Ri3MdscKZY7vfaO1bKm+pDkumvQ2Ifh2ijOoXMsUeMCVwBzz90H1qJdF8N526X/aep z/dbyhgOfrjpmt40f57GftXtTin59jbXwxp9iM6xBb2jjhLLO93/AAXpgfTk1WufipIgI8P6JaWx /iuHUM3I/gGOOK0UEv0RlKcn8D8mxll4Z1vU1L6rczQQDAnvpOBz2jQgdQPSllvNDsMjR7Rb+XP/ ACFJxhUI7xQEfxH/ABql56IJXWlNK+8n2LXh27i1O5VNde6uYz/rhbjHklvSMcYH/wBau68TeAvB ukTqmhahd6lfYLxaTnAguFAPzygdFHJ78Ut+ituy+eySUFd6Jmjefs9+MtWAGv62lmP+XawByIY/ 9uRepauYv/2UPFIu4be0jtLouGla7iIAtLaDkm4Yjjrxnr0HPFRzvovRHTGnDaMvOT79yhr+uaR4 fkMfgCzlu7wD7NqXidkYtPI+f9VGw42AkD8+9ed3kV5IT9tiufNbgTyg55/vbhVcy2v5yOX2cnrK Om0PJGPfeE9d3otqbkTn5YEiU/vmJ7DFe2ad4Ss/BsanxzLb6zrrL59rpBAxo4GcebIuQdykEnHs PWuVXb8viZq0krrd/u6f+Z554o1u/wBYn87X9Sllkxt8rgKikfwRAfwjHauOf4c6FeZOl6lAZc75 oScEH2VvSump/wABHNFJbrzb8zE1b4FakNv9nWzXTMRDGqD/AFbu2OWx6+9fRf7R1zeeFtF03Toi 0ciI0+pxRc77osSDLszwjsx6kE1NN6+92bZ01Kenu31a5V3PNvgj8PPE2oAz+LNVnttAj/4+ppY9 zXkwOAtumMkluPbqfSu78Z/E7W9aljh0XwVrFto8eYraztoWKxIx5NxLtGQTz3/xITW7t/LE1nhp aKH+Op/kd/4C+CCeEbtrnwp4Ym17UpE/0OeT5Rpk0qkFTnpuHXrx6E15zqv7CfxF1e7ebXta0yBp Ga6laR+YpJWJ4jA7E/gOKnW2t9dTX2cbr2kkklyRXct2/wDwSyidt3iDx/DuPEkcMX3T7OcV6V4a /wCCffh2yAF14y1q8UYKwNtA2j/ax3pRjLy7FurSX8Om36ncwfAXwjZ7hZaWsgbCXnmHPmhem4e2 TWhafDnwvaLiz0KyjUchVHCyE+nvW6h6nLPFPpZdDQXVdIg/497W0jH8WxRyPrjvUg8e2IHyFB6A d/xrVU/I5ZVn3ZnzfEiI8jH1NZ0vxVx96dR3+hrSy/yMebuyhP8AFxf+fse4zVSX4wQAfNeLnv8A 59qEZ8xiXnxqjz+7u19j6j2FZlx8bbc/627BP8WOx+lIly/zMuT4/QJnZOcdFP8AeFZF1+0OnaQt 2yD0Pv8ASobG32MW5/aClOfKV2PY9ivsfasuf40XchOwkegz93Pvis2ykn1RnzfE3UJOkh9Merfl VY+Kr9/v3Ljvkf4kUuYrl/yBdQun+9PKT2Y9jjtSiBnH7w7+w9x703ITh5ehajsZCcpaTv8Awq6q TkA9mA7VbGkzL961mX+6Cpy2f7oxScjoVCXb0L0VhLDxLPJb5GQHXBKk+hHrWbqeishzY3ZkP3ml 9QexSo+7zFyd79mEEknS+uVVeg49e4rsNHXRgv8AxM9Plusf6ua3cDbz3HuK1iu6M9PsJdi/Z6f4 Tc/u/C2oytncN8vVj3K13enTGEAWPwrdwOI3kOS31yK0cF15jqi5dHTRrweMfEi/8e3w0WM/dXb3 X3G2ut0G38Z3vN34bg0yLjDyOOQc/wAAGcg4obj2fYt0Zf8ALysvM7aDwPEVxqUxuP8Anoq8Bjmt i3sYIVxZW0UK/wB1B1+ppW8iHP8Alfl6koX/AOtRt96oyF2+/tQV9KAF2j/Pel4oAMe1KRQAbf8A 69AH/wBagAxRk0AAFGD2oAM4pMUALt96T/8AVQAYppJ/pQAbvrRkUxCH3/Cgn1oGJj1//VTCT6/Q e9AhC/tSDFMEIXpu/wD+tSGIX/z60zzPc+tMBhkz1/A0wsaAI2kFRtN7/Q0xELTH1/CoWmHrQBE1 x/n2qrdarDEpM8iooBZmPsPWn/wwv+HMnw741tdViEmmtJ5ZJhIcYIkjPPBrULD1H/1qckKL7+ow uP8ACmmT3pFCeYaYW/8Ar0gGFyaYze9A0hCc+v8A9eoyfYUgG49z649DUZB7UBcjLH+lNLY6fj9a Begm8+tVbi+iiVmuHKooM1ww7Ig7AUxf0j5s8Yf8FJY7Ysvgfwe92R+7j1C6cqGPr5OD39cV6P8A B39pfSvEGmeb4x+zf2mkjWOo6XEh+aNehBA6Mp9ea6dP+Xbd92zj95P33/dSIvEviu0uif7O00W0 fURqT85H96uEvfBt/fH/AENY3x9y0U4xGvsR179ap4qVvdk+xusPHepFd2zndU0O7gOLuwkjI42l T0HqcVU8o9/97A7CvGqzb+N+p6cYJW5bdkSKmf8AZ9D6ikaAnq2OwI65z6Vj/wAMMasJ53KH7BWH Un1z61kX/guwmztgaBz8r+SOGzn7wxRF9ht90Q6f4Z1nT23aJdrMmNs8EhOHVB/E2D1Fa1j8RLGf K69amwk+8jHpJ9HA7muiMr7+qMJU3vB/4kXk0ixl/wCQffLtPKN2Jx/eA71FeeGLuAZaBmQ/cmXk Hd7gVzyX/BNYTXb0KjRkcFT7Adz/APWpDbNn7nHrg8gDtx2pG6g+kfUBaykjCMf7rY++R7iqt1DI oPmQOCMlECnkAHsB2FBUaMv5H2PYPGOna1odlAb63e5LxLeWKJ1MTjo+B1X8TWHY+It6KX3ISA7o f4WP+FdMH3OKrC1rDP7fQnge/Pp71HJriqcoo9Mex9K1XmZei8yGbX8/6uMeuTVOXXJh/q1BHT6f pTJjH/ImtdQmf765/vAfwj/69XLqyhlXEkCZ6iTHII96m3c1S7ehkXPhSdDm0k8wdVU9R/unHaoE 8RXsPF0GcdfLfjy+OzY7Vkn/AJGkknt6lqOe2uPuSBT3U9Tj/A1Mvh+ZOCu71J/hH4VbXZma/vDI vDswblm/vID/AENJqmlXCIS8bbezY747VFzWMe4/Q9IeZMrux91gR0yT1+tdND4UcDIB+vp9abYR Xp2HyeBT1U89GOOn41cg8Lrj51A7kDuai5ehfg0eIff256YHekexi6E/7wHbHt7UmwT/AOAULy1g OfmGeqn1A/xrnruKNfvKM9Bjuff60o+foDZlPHk8DaOx9vepRGoHJLejehrS3+ZH9IfG6KOxP9R7 1lX1kjnhApPJde2D/SpsNPv6jHgmiB3jevQEetZOr6rNCm61iaU5C+X65PYfT2rOxqv7pqabq7oP 3wdQw2SIe4I7is3WE2NhhuU5CE9196QRv+pPpepRrxcbh3Ujv1710H2mBhwoJ9T2/wD1VoZX/wAk UbidVPC8dQfX6VXN0jdgT1J/u02ik/Ias3qqnsppjyZ+7GR+HX6Gkyr/AOSHJajH7xWPoMdB9BTv 7LbsjEdV4Pyn3qLjivIjfwxK3SNh/dz6e1CeBJG+8QvcAnqTRcp/8BjofhtMfuTHHcEdR+ArVh+G hP3LgE9WU/w4obG7dUTx/C5s/PDN6jC/fH1IrRf4RqhCybUkI83yWIGFz/Fn0NKz6Ih1I9ZIr/8A CrYiT5Gp2Vqy5EjvKo2t7g1y+vWemwtsvruxuwRkzwMGUOfXFCT6p+QvaroYDeCbVGBtb19p64H3 R/0zU+1dtp2heGVXDa7fyyY3OixY2sP7pars+iQuZdEdHp15oFuP3llf3A6kZA3KPQ+9Z918SdOR z9m8JShOiJJKeBn+JgKcUvtKwOUunKOX4uqFIg8J6cD9xLpnbKAegpW+MerKCLS002AEeXJIE52j 0HvW/IvsyfdmHtH1kzPT4q67GP3WppH/ALUaLz+OO9Rf8JprLMWn1y7Lnh5FOMLjphR2p2X8iJ+b KUmpXj9dSuiOpG7ufXHrVQqCf3js7fdBY/wn61S/4ANeSI5tLhlUiWIMD95T3HufepdN8P2tsuLS PYPvNk9G/GiwN+RcCqeij1Oe+fWrG5z0Tihf8AlsURk9T9B6E+prb8PeA9U1Bsadat5Y+/M4IBY+ jY71Tf8AkXY9J0P9ndUZTqM4c486ZcfKpHYj1rtbXSLe24tbSOXtITxgj0I9axuaS8mW7dJAT5cb DvPg9x7/AOzVLW/h/p2pAjVbKKRsfuLkfehPqn+7UtFQlbZnifjb9m/U4I2NuGvLXG2R0xuhU5+9 HiuT0+KOJAojbCjygHHQfQ1i/M6pxvrT/wAT8hlx4bB+azlMcg5RlOCH/Cr+l/Ea6DpHrFu8rMRD azp1klJ6OMd6cX5eRz1I9Y/M9Et5NR058wCTIO57GboxHYjjqK9O8N/FbTr1dsjC2uPuyW0p+8P+ mLnriuiPn8jmqRtql6l+Z5Sf36gLnEYHpjv9apyTWwIDyGZ/vbccRr9R6Ul5lJ9mOa1iLZVE3Y2q MfcA9PrT5NSSD/j6mDD+CPsFHt70/wDhyv8AhkUjqG9T5LKTneP/AK31pIbd8/O4I+8qnsT7Ug9R L7SYp1xcElMce0jDsK8y1rw1PaONsjx/8tIHXuvuaqL/AMjXp+J3/hbxbb3EeEO2Yfu5wO+fUe5r Sm0qGYFbljsYGK6jUfeR+u7P96hnPTffoeG+OfhRNpTk2KPJYnm2m/54A9pT7etcDJbwTLJ5Myrw YXYdUZl7D2rJ/wDAZ3zfXv8Amc/4buGts/2eZkniIj/tFQfkkPI+f3+tfUvw4+KEGrxgTTql2n7u 4ibrdqv8SH+dV6ep59WPXz5WdvPGOfJtl3fdD+p9z7U6GNwD5jj/AAPt9as0I/IQkDBz1f2P1+lK LKMfddl7Bl7f7ufSgq5+e9vqnxMtzzb3DfxBWUHGPQAd6SP4w+OI2xdaC0pPzqpiI2uP9pR3pWXS xn7J9J+RYtP2j/EluT9s8MSN/FIm1hlfcbf4a0D+1fDN/r/ClzCesuCeWA/hyO9S4ro/MpRl0+Qk P7UGllv3uh3sa/3g2cg+q47VoxftMaAxO+O6iHRZNpOSP9nHf60chLlLqkadh+0n4ZLYl1CWNTwC 6HBHuf8A69asvxi8In7niGHceVGO49fpScPQlVO8X2JLX4peHJTg6/bE9EweBn1zWhD4lsM/6NrV occhlbrj6+tZyT6Iv2i/lZq2viWC5GDeK/OCysOCPUe9OeO4jJAkDeq5HK/7I9qVvIv2i6teRDLc eaT58ccjf6sl1BLBffHQCq0Wj2CZ87SLORScSq6D5iffHehLsUp9pCXHw38N3I+Xwzp2BkFCvQD1 +lZB+DHhQjFx4YtVPQSIT8h/2c+tO7/mZSkZdx+zj4RfOzTZ0/uPGwyGPqMVS/4ZN8LyLiHUL6F/ veYQDk/T2pqbHzd4xMe+/ZGtoz/onie9Q98jp9FA/rVVv2V9SGPsXjBm43YYnj/e+lNVH1IUI9Ys jk+AnjaFh9j8TRy9w3mY8se4Iq8PhJ8VYDmx1eCZesbiReV+hXtVKouqYnRX2XYDqHxei4ksrS4/ hOADuA9cDvUUfxH+JNuT/aPhgy9zHsOBx2wO9Da7CVB9KgkP7R/iCMH7b4HlcjgyKrjYB/eAXtWl ZftfWeMax4WvkP8Az0QHgfXA/lQ4rpIiUJ9EWV/al8LtnKajGeixtGep/vN7fStCH9o7wfIPn1G5 jf7pTyz+f4UlTfkLml9pGpZ/HzwznH/CRJt/2gRgn3rRm+I2gjBsfEloQedpbqw9vaiUX2F7T+6x 8PxAsJyf+J1aFuhBfsfUn1rRsvFiJzBf20ig5ZQ4wSfxqVHyLVVdTRk1CKcEqtrIc4HCng1lXeja VKf9N0LT3bortGOG+gHepUS/bf3jAvPgz4QnbN/4Wtl/56SRZBOR2rNuP2T/AAZMp+yJeQns4IOC R2Uind9/M1Uu8Y9jHb9jnQyD5PibUYG+8gKDke+PWqlx+yTfoM6V42n3DCqkmRlP9lh/dq1Vl1S7 EuMftRGD9nf4hWZzpXjBG/jjlWTuO2Cpok8O/GBBxfW9x26rkn2GKftV1iTKivsSaKLaz8Vrdf8A SNJllx8xkYDIwf4RjvVEftEeLbc5vfDbKBwyMjAOD6sF9atNehm6L+xO/U1LT9r2CTH9reGHib7r NEx+dvcEf0r0v4V/HhddW5gudLkt4PludCuJOks2DlS57456n3ApSiuj8yUpfa/xFG++DNn5jFSV B5kH91/bisa4+E7xnMQ8xD8xA9vauWz6G3Ouw7QtHht3by7do2PEuf4sZ6fjXRxwNz19x6H2px8z KoPSED7zH1+v/wCqrKMD9/cPYdvpWlzGK/zPe/h2AbOLaowNyMPQ5PT6V0c8zDmBd/Yr/ez7+1OK NJkU0YY/6TyeyjoGPoBUTrGf7xPRUPr7fSmT6LyJIIG2ne7buqEdh/8AWpghx3bPVie59qETcq3j PKceTtPOAOgA9/esv7bbQjE92g/gIYj1/u+1Vy9kZ867kN94r0m2Qs+qQhh84UnofavIdc8fT6rI RbX8zRfe+zxKcA+pcjuOetVyefkjJyv0ehgXTaNb/wDIVuzkcvEpyW+iqO1VLfXo71gvhrwvNcP1 SWV8bEHduPT3rN0o/bbN+eT+FJLqyxc2rWh/4m+oW8cn3f7Lt1DHnP8ArZenA9+tQSeNr/OPD2nS RN0TaNzZP+2V7/StLq2sV5EtX+Fv1NGPwhBEC/xG1qeFjzDpkZ3NMo9l6beB061l3vxF8oY8I+HU sU+59okG6SQsf4HI44P50f4/VIpLpQ/7efdmjb/Bm7Maz+PdXOn2p/e2wc5e7QE/6q3HPz4wOB6j NVtR+J0MeV8FaTHpcHO6ReXmX3lYfw/nnmlHvL0ihS7U1/18f6HMaPFPqEhGlRvczZ8mZACTvPvj tXoV14e0rwym7xbE+p6hwYtAg6W0jHjzpk7KuCfyqH5v/EzW1lotXpTRzmufEHUtRcHVSSn/AC72 ycLCW9EA9KzTdwNjfhT91Mj+M+v405rt8kZU01v8z23WrLSfCmm26aJHGNfuFNxrV4etjbnJ3KGH XDBRzjrxmvIdJ0aGSZBe39zbszBWvY+WWQn7w9x9az2Wj/vyNpat6bfuoryPeo7vUvC7bW8ZXHiG 4kG3w7ozL9xkB/1s/YIMHn0wKr22teN9IsbufVZLmG/uSttDexYJitFJB8iEA42pnHHHbNa823Ml rq/QXs93Tdv+XcF3fUyfCHxEVkEeleJtPtWHzGK5tzuaTPO52xn5vfuKs+IbDTtZR/7V+JMLzoCY oILLBadFOAv+8SP07CuOcZdZU+7Zsl5VeyRU+HbeI9PtpTpPhaS81YfutF1iVSv2GF1IPlRuMHzA T24HrXLaX+yZ8Q5udaiSaZiZJ724cAzFj3AGOPatKc/7vqbPDr/l9OOnuwR2GmfsNazJ/wAhLW7O 37bU5KH/AHiKsRf8EwtAeQvqfjDUck7njhRBgn0YjvzTlF/Z9Sk6a2TZ6doX7NOg6XCI7PUruSME TpPcFdwkQcYkA4z7Yz3q43wf8GFy2o6NZ3s3CyT3I3FlQYGd390VrGHf5mM8TreMUv5fI1/tOjQo qwWVsiLxawhRtiz/AHE96iXx0ig+XIqD+FV4x+A9K0VNdUcsq7f2n3Zk3PxEiX7uB/eI/ixWZP8A EaL/AJaN7gj/ABrTlXQwcmZt78UEH3JSx7luwHp9KypfjBIOl1z/AAqe1WYuXcw5fjWxzuv0DDhg Ox9vpWbcfGi2X7+oMR0LerfQetU5dl5mfOu3kY118dLJBzMx/hU+pPtWRN+0FEM+TvY9gc8kf3gB UX8xtvpEybr48XTD5FPrt9D7Gsm4+MOon+EehOe/uMdqhz8/QvlIrzxbqDxhzdQlT8pizyQPUelZ LeKdQfpcEDuB2H1rNz9exbiulxok1Jz8rynswz3/ANoU5bC9IyQynoxPf8anmY1D07iNpjr99gv8 X1xVrRfDk9++3Sba5u3Py7IlPynH8TYos+pdOGvur18j07Tv2P8AW5gPtbw2x6+UWB2g+pA/rXT2 X7Daf8v/AIlC9ikaf+hAjtSs+h6K5F8V30NG6/YosYonOn65LNMB5kcMigCUKP4W+leIweC9VcOl rp7vdDd9mhGf3kaZ5xjsPbinyv7RjKz+FW6FuDR7gIBf2rwTY/0tGUjY464BH9ag0vQlt1IDySkn zRI38KnPGf8APvV+gpw7+iPqD4M6ha3mnfvbS18yFmtLjcoJEfJBLEdwa6bTtLhuyJLq1gaPppkR QYCA9cY7mt1Hy8jL2j/mfc8r+PDB7mBNsSlI2lcKPuq7e1eSajqENunz7c/wg/xZz0+tZyj2Rnd9 W+5wt/dzzZ80gbvlQf3Y/b616J8C/hMdSu/9LuJhZRg3Ooqp/wBYSOAhH941Un2Kw9P+Zf3j6F1L 9mayucHw/PcWjZ3YYAjA/wBvHeux8JfBvUNPA/tHxTPcjobXb936Se4x+VQm+qR1T5ftR12R3FvY xx/6pcHu1Tkk/eJNWkczfmLijP1piDFBzTELt9KXB/z3pDFA/wDrUYoAUn/PrSbvagAz/wDWPtRu oAM+nFBNACE0vP8A9egAxQAO/wCNACf5+lJuFACE/wD1hTSTTEGKMigA3f8A1qQsaBjSfamlqAGs 3rTC3p+XrQIaZMdce1IZfQ0wGmX1qMyf44oGMMlMaXHemBE84/xqq9xQIga8/wD1elQNdGgXqQXG oRxqzTuqgAvuPQMF/wAa+UPiB+0D4i1ELBperIXMot2gRBia4JIHLD39azqT7I6aNO+9+x9PeH/D R0y2iid0Z0QR3ci/8tbo9Sf95qvGf6Vpf/Mwfl6Ced7/AI0nnY9KBCbj2NNLnv8A5FACb/X8DSZ9 vakA0g9s/hTCDQMYXPpn39KQt/jmmL0IXYHp+B9DUbf/AF/pSArvfQICbmdY16u7dgB2FcXrPxj0 i0BM0bXSDh4iDtmRgeGbH8Qp8vcnm/lPhXxnqltc3c7afBHDCXZoIV6ICx6V03wT8TG3vTHLKI4Z l2sT0FzErHp/tCqQqrvuv7zPpiOCzxiG4VnHysPU+30pz6E4Py5VuqEdjXFzM7ItdUOe/vsYvY4b lM5McwB4x2bHpWbc+FPDtxn/AEabT3+6kicqSPqO9U7Pb5Chddn5GPc/Ca9VSdOmivUHJeI8ge6Y 9PauZurCaIkTQTIw4JZT1H4VzOLW5urP+G/VG94V+EXiPWD/AMSHR7mZejyyKVUE5/5aEdsV6raf sNTxjPiDxRBaMcDyYV3YY+rYHTj61i3/ACnVGKX8W76pEx/YrsVX/RvGsx58tgYh1Prx2+tMuf8A gn9oV7j+0/Ec0xHIPkjk0JS7rubKtD/n1LscV4g/YQ8T6UzN4GBvrXOZY2OMQ85MceOpH/1q5iHw pd6YH3PdupJllgdT+7Zs5AQj1rVN/aXkzOpST1pW727M1vA/jjwFa3W3x34YW9Zhut1Ab/R8E5IU YHI9/wAORX1B4a8BfCXVV/4p7QdDuGxmS3wd0QPqjGuinRTWkn5nmvFTi7W07nS2HwP8G2eTa+Dt MjP3pJHQHaoH+1npUWhfD3wvl59O8M6ZADuEcrRj95EvU4PQHmn7PzZt9bl/Oc18bvC9veacJEij R4yssDL/AB20nGFP5V8p32gOyn7O6CTBNuW/iYDjJ+tKS7E810nJ/wB1mVoehahIp/tOERSjgLnq PqB3rXHhVjxICD0z7UmyeUevhAfxf7oH94GkPhXafkUegB9KL/5EovxaKqj5lGen1P1qtJbYPzL7 Y9RVRCX/AASWGDIwR7/gKS60G3lH7+3Vu2e/Pv7UpBB+Rzd74FcD/Rn3jqkbf0IHaq1nr19ZHFxB LtHyiGQHkL/t47VHN/wDVxuddY+KNLvANyi3mHzbG7k56Nj+tXdfti1sxtVV2HzBfop/nSl5EQf8 /ocv4F8QRuNjuO7/AFPPQexr0aCMZxs9mJ7GmxLs/U1YrRCCHA9V+g9azbkRRf8ALVQOp56/TFQa X7mRPrkSn923uwH8QqhN4iRuVYg/dI9TTSF6ehm3Wphh192PofrWdJqQYdPxPfFN+Qv+GIDep7nt j1x7VH9r3fc2+jH1x6ij0YJdyNbyTPCD+6SB1Ge5qc2ckgyq49h6Um/+CVyj4YJmH7yMY9/896jn 8KrKeiq3XjsM96lv/ItepSuNLmi/4+Arr/z1/usPb6USW8FwmGYE/wALd1HPQ1L8vUan2fkZMmmt D/x8RmRfuo+DwTntirMCyRj5maRP4VHUA+v+7TUh8nZeZaTXLNj++t5wOhwD0PpgVeh063cZt7Rs Hox/i+nFX8yHfsiDUdTs9PUG6s1Yswt4AP4pHPfHpRrevw6eENzZK28iKJR/C5J9qF6vsN36LzRC fHsacppsjHGAF/i/3jjuafbfFLy1PneHp5nI/wBHCNgI3+22P6VsoL7TRzXn9mwkHxKncY/4Ry3g fO/zJpCfkx0KKB1NSXXxS1JlC2ljokB/56ujEt+J9DR7NfZm+4tft3+RmzfEHxYcC18Q6fbAfKWi hHyjPuDWVNqXiznd465PzSMqj5h6DC1Vl2j3KaXVTZUuYPE84/f+PLw/w43EYX2AHasub4fX8nNx 4kmlfp5rM2So/wBv2qLfytdyrR6wZTm+F8pID6gkgPO7J4J/vZqdPhdMgxFfWu3O5kycBvy71bv1 kPT+VnTeGPCbqzHUNVtgelqRn5uvU4HStjUVhgkVJbuKSYr9oVoecqfp/kd6mS8yF5J9zQbWYLRE GqXAVnPlWef4iT6j3qe6tIyjFicgF2PsoPBHvWD8l5nRH/hjndK1dbpA0CMFOQqsOpBP8q0Rbg/e wB/Jveuo5Wu68mV3YdAoPZvrU6KT0x7e4popP/IYYiPu8E8N7A/4UqWrt3A7H3I9KBNDghAOTz1A HYe1WY0I/wBZ1+8cdx7ih+pmy2ttn7qHPUHt+NdJ4f8AhvqV8R5Nq0cf3GuH4C4PoRQ/M1Uf8z0n S/gHpVuM6lcLcSf88QPlLn29672LTY4I1W3gijUY2RR9FGO+Kz9S2/IkIkHSFiOp9wP8aoXV9FuA SzKH7zuOmT/tepo9BJdmieLy0Pyyk55CD+E+5+lT2ykk70JPRV9EHqfagRNcXITo46ZZMfeH+7Xn niX4J6dqRJsg1tcHMhuEAALn++o9amSOijUtv6M8c1z4ba3pLn+142MZOYruPlXj7HK1kaD4kSPV bX+1Y0isgwuby8xxFIucZPs3+RWa8yq0P+ffqj6yv/D+nalgzeTcow/0S6jP+rj/ANnH92vP/Evw muLbLQkXMI+ZbhesRBP8I9q1t2MaMk9/RGZpnjrUbTi9mluYPuqSfmiH1/2a7fRdVsLlc6dPGzH5 GTuCP72aow5bbrQ0nuLi2GXtg69N/p/+oVQh1L7XkzxxLydi/wB2Nf7wP+GKTLt5jpzCcC2kijJ+ VpV7Rr6D3pyibosi9coG6mNf8aVyXLu/UlRbhm/eRJGnVCxyWP8Au+1U9V8LzXw/0mS3yOI2JA2A f40X7FxkurPN0uLnTps27BnU7Zox0lQeor0zTfFkF2m6GRUJ4mT/AJ5Z/vZrRoiW+j8iPxXdQJpt wZo1lBHkQ5/56H+79a+ZY/h/JpqL9sCZkH2/epHPmZ6gepH+PNTNdjrpy01tvzI6f4fXenQyvFr9 rCtnMPKa4b/ljdHowf8AyD3rA1ywufD15/xIb5JghJs7kdLm2B43Lz1/SpiYvW6l/jie/eGPjRp+ qwhmuYLWX/U31s7cpKO6j0atSbxpoUf/AB861A56iLPC/U+9NvzOem31T7MrH4qaC3+s1WFOyIO5 Hrimj4saCmTLqMK9iTnPHotK/mjTX+VngsV/K3AvEY+mR8re1Oe+nU/M7E9mBzz749KxUfLyNIyX SS7lqHURLxMkTH7uCo+Zj/fOKybvw/YgkyaVZv8A7JQcZ9ABQ12K5vP0KEngjQHP7zw7YbujAL1r Ok+EfhR2zdeHYsfeKpxuP09qq7/mZSfku5Y/4Zt8FzgmPS5R22I3Tj3HasGX9mHwmD9+/hH3dg7E n1pqQ2+6RBdfsr6B1g1e/wAdGBVfl/3SBWef2UtP3f6L4iulTvuUZX6YFHtH0SEkvtIef2RrqPnS /GZUdVfBzvHrj0qn/wAM6+MFOIfGDsRnBMn3T759arn/AJiZQj0TIh8G/iRbEG01oD+F3Eo+f8cU g0X4s27YSa5ducuSpBH+zxT5l/KS6P8ALJCW/ij4qWhJbTJ5SOZGdM7j7Y/wqZv2g/HI4vPCit/F vWNsg+4C96rTrZEOi+khlt+0v4ihB+1+FVkz94lHHy/QL2qWL9rSXbiXwr+8H35UZsKPcEUlGPWT 7icJdEzesP2udCZcaxpN5E+OJACRkemBUn/DS3hVhkTXiH02Hk/X3qXT7A3L7S8y5D+0H4RccavJ G3RojGeGz3NbFp8cPDikeXr8DIex46+ufSpdNj9r3i+xuzeKdJkGbLXLEA8g7x8w9/oaj/4SOI4D 6haseREyyL8wPpzUOPkwjUXX1NCC5nUjaYm/vE4+df8AbzUr6dY3WFn0ewZvvBSg5Yf3WA7/AFo5 ey8zX2vaRz958NdBbi/8L2DH++FwQfwrEuvgN4PmB3aCIT3khYgr9R70Nv8AmfY0U+1hkX7L/gyY AGC7jI+82772PX6/WqVx+yR4VU8TXqL0VUwQD9SO9UpvoNzX8kSs/wCyR4cJH2XU70cZkXA4A/wq j/wyJYkn7N4tvYh1XK/+hY96PaPpYVo/aiRzfso+ILXnS/GxJ7xrnnH09Khb4IfEFV/0fxXE/wDE sZcZA9nxVe0/mRn7KPRMdP4c+LVsAYdU+1EceWrKT9G47VT/AOFi/FO2b/S9HlkOPlCxdVHoVHeq jNdEiHQ/lmXLf9pfxMoA1LwNPKw+VpAr/MB/eG2p7T9q2dQRqPgu/XHIKbvkGP4iy0JR/m8wlTn9 kvWH7YOgj/j5s7+LtJEVztA9CBXQWn7RPgq6/wCPTxCbeTq0c6MMf7rY70On2aM+eX/LyJetPizo ErY/4SG2c9EB/iz7n0rWg8V6Y2fK1XTLhBxJG5XofVTWUod0aKsuzRx3inxF4Pkyk9rpjy95UjB8 tfYoOpFYlt470S0VRp5aKMAuhReUPsuO9aOL6vzJjUb+FM1YP2h3Uqv9i3WoKR/rkXHlj3bFdrpH iy3u1/eQPat0Ec2OAfVh71Pz8ieSXW3YhvdEiVsxgYPXb0Zj3GPWo0THb/e9zSS7epEhYkTP7xeO 3s3tVmKMZ+bcw78dKLEpnuvwyhJs02IpwWVySPkJbv8AWtPXPGmj2X/H/rlnC3Qx5yS3sorWEey8 ya1VdHfyMGb46eHYxlp5No5MxGA/uNwrmW/al0aWXGjadd6m+DiCFTyR/t49K29n/M0YKpJ/Cv8A gFS8/aU1XPOhW2m9RBHI+52ZfWIDseKq3nxU+Iky50/w63l9TeSKAqoOpZcdB9ab5ezFGk3vVS6N nNah421gnPiDxLdXco5Oj2Cj5V29HdB/COevtWDY3+vaq5Xwl4eOmqOZpbhjlFC9ZppRxxzU8/b0 SNY0fkvicu5VurLQLF/+JzcSeILsZM0IJEcMg7Ow6/pWbe+N9SuyBlYYzlINMt1ABUnvtHU1Epfz f8MOKv8ACtPsrudJF8MtLsog/jFzZk/8elhjL3ajrgdtuR1HJrN1H4gzyqU0GCLSLM8fZYB80ig/ 8tZyM8n3/Ss4rq/WKLnK+kdl8fmaPgT4Kajrzt9hQR26fvtX1BulvGwPLZ+nXOB3q5qnjqwssxfD eHCj91e+IpeTeyettGw4C8gc+9RBfz9NPVmtVaJQ6+9LyRzuleC9QvJgtmjXNw3Jkkz91RyWc+1e /eDvB/gjRLW4l8X2EGrXUG1hEM/NfP0SBhxmQ+vSm9evqOEuVe6vKCPC9a8U3urytJ4rvZWlJ3xx Y+WCMDACKB/CMDpUmjfD6LUJFTSjEZWyEJYAfKCSST/dUZpVm/s/Iigv5l5yZ1Oq+LtA8HFrbwc5 u9WbH/CR66F/48I35/dA8bipxx078muV1hLFpduijUJzjfdTXAyZ5D3QgdAf8auO3vL+9IclJu8Y O3wQ8ki3pfgPU5h+40i7l7r8h5/Su60H9nKZ3hfVdFmmjDeZf6fgg7Af72O34Vi329DuhSa+NryO l8Xfs6+JdfvHmksIdKiYLb2Vo8wJt7eNcfO23q557egrX8K/sl3WmPvudZtZpBlLVyAfIZ/TA64z WrfZPsjOKgt5a7v1Om0T4J2WnySPNrTz3Un/AB83jKMoMY/c+mxeBW3H4e035ft13Ncbci3EnQbv 9gDuKai/tWMHUX2VtoirdaB4Zzn+xLB36GRkGSPY0R69pVt/x72dop/gIUcAe+O1Wqf83qRLEP8A mfkJJ8U4gfvRj0AqrN8W1P37kegq1FdEjllN9WyqPi1Cf+XrPfis29+NMQPFwffJ7VRDl5mLd/G+ 3A/4/VHcZP8ASsG7/aDtVB3XgPYAfxfQe1N/8Ezcuxz1x+0ladpz/dI54PvWRc/tKxg/u1lYdQ3Y j8BU37sNexg3v7Q94/8AqY1+hzgKffFY03x11JjwAO4YHoB+FTzL/IpQfcyp/i1qj52XLgnnco7f lVY+INWlPElwx64HbH0Hep5+3oV7Pv6FVzeSczGUHrvPbH1FLaafLODskRwOC/8AdP4DsKzcn+hp yLt5mna+EJ5RlZ1I9R6gdz7U2w8MJM7r50gZceYCOG3D+FiOw96h3KsvPueneC/2TLjWYTJba3bQ RBvIk39Q4H/PMDuPeu9sf2INMRQNQ8QTSN0crGOfxNNQffzOxTh2bfU1P+GK/CMaMb3VNRHG2KYb fkfHZMdz61ht+xPoENvLLc65eq6g3NtGoAACKeuMf6w1tyPshSqx600eNR+F9vNs7r6kdifr608P KMiR0cd/VWz6UW8vI4ZMpP4XNw6iS7WJGIWWU/wRk+/p9RX134K+H/h7TIAvhKaC4T71xeKRuuWP dh7+natHHt6suNRJeulzqobLb95D6ZPerqwKO1WkO5k67cyHZHA+15Dgtj7sCdenqK434ifCm7td t34DxbXUJFxd2qDIuI4jnLqR/F3omu/qEPXyOk0LUvC/i22EmpaDaSzD9xq9k4+axuMc/MAOHPIr mdZ/ZR0SQE6Jqc1i38MDAFef9rGePxqHH+X5G9Or0qK/T0OAg+HXjnwgZzp2pR3FlOQssRAYGSPO NiY4JHp1r0DRf2o7BNqeJfD17p5UeU0yAsMgdSmAefpVwl/P8jKrT60H6o80+JvjOHU7uSXSXeWA gQWbgHO1FPOzHf6VxOh/BrxTr0mNI0a4kX+KaUEKg56M4HUe9E5rp6I0w9Bv4tOsvI9m8N/8E8lc q3jPWvJI5ewt8HcvPDS4Hb0r3Twx8HvDOjKR4d0WKHOBNKesoXPXPpXOk/tfI66lWKVqC8pPudIs Sj7oAHYU7jtW554m32FKM9qBBg+1Lgf0/GmMXYf/AK1G2kAY/wA+1Lj/AOtQAuKM/wCGaAEx70mK BC4NJj6UAGTRn3/CgYE0bqAEz6f5FJvoAN3qfam/5+tMAzRQIN1NOKBjd1Jv9PpQA0vTS3vTEMMn +H4U1nHr9RQMYz5/z1qIyEf57UITG+cPWmGWmBGZfr/hULTe/wBDQIheb3qrLN/n2oGVHusd/wAf aq733oPp9KYjw/4v/HN1zDocrSN0l8v+K4JIwCK2fhp+zvp1jEs3i/S4bnVGIvYBJ/zDAc4AA74r j3Z6Cdlo/Q9Ve4Zj8zEnqT6mk871IrrPPFE3p+NHm+w+tP1GL5npS7/ekIN3v/8AW+lGR7n/ABoG 2NLHtn0pGP8Aex7+1JjI2+nt9aieQKPnZVHUk9h/9aiwNmHqHjvTYR8k5nboEjHU/wC9iuavPiJf ScWcItx93d3Cn6ihvv8AIlRfQyBomo3rfLa3dwexCk7T/tYHevIfiZ4yt7GZbbU4Z4Llz80UqkBI +R8zkfx/UVkpX3+R0yotK8V5s+e9S02SKWVZUIZWZQD2wx6iqcN69uyvG5RlIlVx/Dj1b6Gtl5/M 5n5I+/8Aw9+xDrN1DFJL4itLcui3cRQn5I5VyNwK9lIrudK/ZCv4MfavG6Sr3XywcY9Dx1rkcX38 j0YSp2V1K9tS/qX7M0wH/Eu1BLo/xRsAOfYV59rfwkvrXIu9MlTseMgj2IFZtM0Vn8P3HLSeFpov +PfzIj2K8Yx7Y7Uf21ewkfbIY7sLh1WVRyF9TjvWkZ/zr0OeVP8Aldj2fw3+1xp+1U1fQ5LHjaZY PugDvgD+I16RpHirRNSGdJv7S5/i2HGVz6Ka6FTX/Ls4HOS/iN+psfY9v/LJF9wB/On+Wfb2x2NR byNubzHKGX7rkf4/SsbX/h5ompKf7a0q3lbBWO4xyrH39jScTWnUa+FniHjz9huG6UtoMkVww+aK FgFaIY/5ZP8A/qryGbwdqmkNtlt9RspU/drIoZSVH92Qen1rmV18PqelJRkvdS80dxpP7VnimJDF qoS6gK+Ut6eHiU5zggdcVf1b4yapPZvH4Yu5ZCVKPbKcMu4HOzvx1459K6va36ep47oW66b+hD4N 8eeJ7u3trXxfJ5heZNPEDrytoCcq5UD/AFcYJyTj68VR+Nn7Osem3cc+mz3EVp/yxiXpC3OVbHZf zrOpPql5P8Drw8LXTd+sTjLzxHbRAtMqoByzAdBVYeJ0nANs4K9Vde6n8KSX+RnNv9DWspg3UH3b 0X6ewqO6voVP949mP+HvSC/+ZAmphvvLtHVSe/8A+uiW0JPzSL7D1HsaP+GBS/m9Rq3UMZ/eso7D FaM2p2bAZKn+IH0/GhoSkVn1TTwPmH/Aj/CfaoZ9c01xi6tY5l/1ZcjuQe+O1Q4lKp/wDhtT0qy3 FdKuVUn5hA38WP7p9qisvEuo2gISZ1UjZJBIOHQ+jH1+tT6mjafTyOMvb7ULOfzLGFghJlkC/wAK k+gFdrY/Hq6cgNEjfwyOCAVx6jH9auLXX0M60HumdKfiUX/1dwvqc+tVLnxKzZ8yRSOi89yKViUj MbU2HKMQPuuf9r3NUzrajrMo989R7/Wn6FX7kUnieEf6y5jHY/Q+mKrt4v01T+8vYyvXv+nFD815 EKf8q8ivL8RtDQ/PesT1TYpO0D1IqM/GHQx/q3uWHRgEPDe5xSUX0a7FOo/5SNPjhp5z5enTsO8p 459kx6028+NjxBfs+mqSeQN33Uz/ABHH9KORdWTzPy7ma3x11I/chiQHke5A9xVW4+MWsOMCdEHT IA5+pxU2/wCANLu2ZMvxD1og7dTkJ/iXjn6HFRWHxC1G3YfvfNzyxP8ACPwFWn5IXL2fmegaV8Q4 Jf8AXHaTyW9/cV0dtNbSDl1I7Ed/wqJR7I2hPuxLbV7F5GS2wZB80ykfcB98VtQrjsD2C+1Fv8yu bv6ENxo8MxH2q2RwD5qbv4XX0PtWF8SddFlbB47Nbhw4WM4/492YHof9oUzS3ZnlK/HDWB0tYsHh xjt9NtOHxz1o/dsosfeAA+9j1OO1XZdWcnK/5n2CX44asT8+nwnuDg/KfY4qJ/jNqzHnTLcj0weB +VOy7kuL/mYD4wauT82mW+O7HuB6jb2px+Luqn7ujWhHXPt78UadGylF9ZPyA/FnV/8AoEWo9SM9 vqO9Kfixq7DnSLUeoB6D6470rrux8j/mJk+Lupj72gWjdtxJyB7nFKfi5qhP7zw5ZMOoG8jJ9sDv T0/mfcTi+kjtfBGrxakrnUNGigwdiojZ5weuR3roLy00+1cSSW0a/wDLsHbnAf0+ta+z/vPyFGb2 foXNR8MWN6EN1EJNh8+xb0b1H0rNufEGy4ERtWbKNMz44GB0dv8AP4VznQpdkZYnML4RSidfLX+E Z7fWtJJo5Bw7Y7jHQj/Gt4mVTf8AMj8nHqw6fWpvLx0BB7//AF6pEPyBY2Od4B7/AOTUyIexPsPX /wDVQvIokjgDfez6fQ1p6L4Vur1wumwO7/8ALRtv3F92PpSZMV5nrPh34JWsDA6mWnYHc0fYuPXH 92vSQ0jKBZxpGg4LKMbFH91Pes2zT0GrtzyQR0DY7mrCxA/dc4/hz6f/AF6aF6sGFxj9yFbPy4J6 j/61VRASOQN3Rz/hTCxELBl/1ZXd1YnsvtVyKHGcvjsrf3qQP/gEbRPnmU56EH+FR/jTnhVemAP4 sfxH6e9H/DDI5beCRSLu3jmjPyNE/Qo3t715h4t/Zthny3hiNM8tJp8p6Y/55OfSpkjejU6T2/I8 +0Hxnr/hyUi2EiDOLrTLjO1lU/8ALMnpn1Fe7eG/j1ousoFh22V0flm0+cj942P+WTdD+dEJd/kc 9em07x23ZR1vwJBN/wAekfky/fdVHEre4HqK4W90O/sXBRpIH6q4H+sUeg+tNeZtvu/+CHiD4pay 8SqDtC4dgv8Ay1CDuB61xn/C5tTj3AO0ZP3j6gdiMUqkuyM40zLf4vamp+TUXQ9x6H8u1Vk+LmpK 2YtWuA33twP3vwrDm8i3FdV5Es/xy1eQ5n1q6JHGV7j34rOf4o3chy+q3THqOTyB/sinzPohWXY0 dJ+J6lwL+4kcHCSO38P411eoWkzKTYTuAfniweH/AA9/pXRCXchruvNHa+P9RkttBhE7ZkcLJcgn qSec18/nxWmACjnHClv4fpTq+RdPb7zXgmS+hIhXEyfOCOvk4/8AZDWFPqxI2zoxx8hk9196zk/8 wpv07EFvdNCwNvtJ+7/vJWh/wl0h6xKfVh3pP18w9EM/4SmQZK26Z6E+o/Knf8JZcdokHqB6D0zW NvPyL+ZwMn7NniaL/j18RRt6SByNwH+1TE+EvxCjP+i6upB+XzVlHJ9wRXTzrrcl0o/ZHr4C+Klu 37qWRz137gQ3HYkf1p83jn4pW/FxppfHDEpnn6Cquuxk6PafmVW+LnjmI5uNDdm/5bIYz84P4VO3 7R+uxN/xMfCSn+Bl2uMfTinyrv5Aqb6N9yS3/ainhfL+GpYh9/y1JBz7qw7Vt/8ADW2iy83Gi3cR +7KR/C35Vny9mJxl/KhIv2mdAz8tveFepyPufpV7/hpLwpIf+Pi5TuWCHgflScH0Byf2kWbP9obw tux/a7KnTc6EcN9a13+J/huT7niK0HdSD0J9SR2ocWEaneLLC/EDRiQBr1izHlRuHT2arqeJLIn/ AEfWLUt94AOOo9D7UreRTqrqn5Glb+JUk4kvImPTAYcH3IqzMswz5cgYEco2Oceq+1Q13RXOukih 9qDceTGT0KlRyffjtVeKwsEz52j2LA8TK8Ywcfh3pvyGqnmNuvh54auQc+F9Ob+Hbt5jJHbFYr/B vwkeJ/DVuv8ACWj/AMD60XfSTLjLuUbn9njwi4ONKlhz92WNu3uKqt+yv4QkUCKS+iboz5B3E+xH b601LsXzd4xKF/8AscaGh/0bW72LsflHNUZv2QYQAbHxW+epDryAPQgdqftJdkLlj9qJXb9mPXYu dK8Ykk8O7sRsU+x9KmT4D/Em2OdK8VQOMb0lMg5x/eUjtVKp/OiHTh0uOGl/GRfv30Fye+Sp3jHc 7ajj1v4rW2ftOkGcdJAVHX/YIFLnj0iQqC6VPNkUXxz8bRgi68GmQjAlkCsNhH+zjvWnB+1pdxJj VfA1ww6iUBhg5/hOOh/GqSj1kR7KX2Xcpv8AtX2/bwxfRnr8x4C/Uira/ta6Pn59EusdHbPRv9kY pOK+yxNT6xXYvWf7W/h/di7tbxIuo46D6AVuQfHfwZdc2XiFYP8ApjOpBH4Gh033RPO18US1b/Fb w3PnyvEVsCOJCeOR/j9K2LD4j2IAMet2csZ+7hxwv+771HJ5eRoqy+1Fm+l/BKM2N3bsTzG4xxx3 PvVaSWMn97BaE/xHap3D2H1qeTvEv2y/n8mZ1z4C8L3H/IS8KWDZ/wBdIF5Le2K5zVv2YfB0nMGh tCp+cGE/dX2qte7KVVeT7HO3X7IfhuT/AI8tTu7XtswDn6giuM8U/sp3NiVOla7b3Cn5IY5OCOe9 OFR9Qmo/aj5G74Y+D9tYqf7QMdxMcGbPIXH93Hp9a6RPC2lR8xaRAGHO4rn5vYY70nfq2Vf+ReRo 29ldSHFpYqncbQACfyqxd+F7qBc6i8EKHlvMYcj/AGVHvVqHZGE6i6yv1JdP8S2RXZbTy3Ug5Uxo cBR6yEenvST+I7SH/j8Zt33vITlgMf3B/drZRXVnHOb6R9EWrN7yZd509bSz6/brpsYGf4YuvzGq jfEyBWK6DZtq0mRHDKAVQEdwCMncfpUXRPK9ov8AxPoiS+1LVI1/4q/xa2npn5dFsx80mexZB2+t c9B4nJcDw3oxtwTt85yXkm+uR1Aq3Pu7dkOFPX92vKT7s9Rj8MeAIYGfx5oeqS3JG6wtpGbczgHO 2Jf7p47VleCNY0O4d0tL4eGLYkKtoqZe9AzgNMw6xtj6k8dKy/xP/Cjou3tTVlo2up0ni34F+F9G EcsfinUklb95Y2TYLXYB6gkevT1P41J4g8K+P9Stl3X0OlWv3IdNLZYqDwJJAP4cUX/mivIl8r+L RLRruzV+HfgvV9Et5pvF1rpllp0IDz3iHLX0j54RcZyWPp356V4/40+LN9qhItIl0yxY5js4RzMC 3/LZwP8AloeT70Qa3l/hiTXjraMnZLmn/kc/p3hWW4YJpytI5+4iDO1R3b6V28V3pHh3P2CKO+1k AxPfuTt0ZWHIRQMFpASPUVnd31/xM1k7L3N37sfI4S7uJZ5Gkv7h55W/1kjnoo7Rr2Aq5a6Y8uRb 285YcEIpOCfoKuTIpwf2F5Hq19Bf6LpCwafcyCa9YzeIIohkx2cHQMyg9sdCBzg5rktC+Eut3JVN NtZI8/KGlUhY0HdnI7Cpc+/+I6VQbbv/AIE/JHskHwo1e0haHwrFPDMQBd+IAv8Ax8zK3RFYHGVJ A4OOpqS6/Z61K4soLfRtIg01YyZtVv5ZCTqMjEnLRnOPLJ9eeppX8vP5lOC+3JdF6JDbD9jN1A/t fxUrDqIolHQ+uR/Wuh079knwnAwaSa4aQHzAy4UNIp/i2j1qYRfVmjrQXwQNZPgR4BiJM/hy0mY/ vJ5JefMYn+P6mtiysPCloc2mh6ZER8quqDJTHqfUVrGn5s5Xin9lpdEWR8SLGP8A1AgUdtoHT6AV Wb4n2pB33iL3A9a1VPsjldZ9WzEuvi5YrndcD0wf4jWPcfGm26RTjPU59q0sZc5i3Pxxgx/r0z1I z1Fc9qH7QcIzi5Udjg9velchs528/aNiXrdMw/hI75rn7r9omE9JJX7kYPJPvipbGk+xz97+0FNn 91HJj07g/THasa6+Ououfkyo6Ak9vpio5vMnkfV+Rnt8WdVfOLhvQhex9+O9QyeMdUm+7POOzEfT txU8/f0OhUvIYsWrTY8iyvZx1QLGcH8dvrXQ6Z8G/Fd7GzWnhi6Ljn5uMjHZCPpWMqvZvsdkML3a RlH4V+K8n7R4V1LaOHcRt8qj229qSy8KZcC4lktgflZpVIEZPruHc1Xp6DlRtvbuzudV+BWmWcKv beJrPUmOEKQHITIP3z9Pb+uOd/4RaCDB+z2znnhhwQap0+78zmc1/wAu0+yMy/1pYFxDHbKOm4KM sR6nFanwy+EHiXxRc4sbpra1X59SuiBiKI56Lgfex/hVS06eSHQppv3pOy95n0zP+yRoboFhvZwR 8rSSKCJWPfbj+KuJ1b9i/WbUMfDNvbTQ8meNGxvLZ6RkUkmbSs/Lojz2T4eavpGVuNBniXlt4yeW JzgEd6gguo8/KGVvuyBxjj3yKX9MwqQf6F7w98TryznddNu7m0K/O0y/dmYjtkGvVNG/al1SMj+1 rS2v07Mp2sU/AV1033OGUez8zs4PjloOpSoL9pNOtwC9yknIlnxx5jjsv/660/iR4ls002ZtPvYb jcBaWxjPXzD2A9vatbdinPpM+ZpAqjC8H19z6n2qhp3ge91a4SHS5CsjndNcf88YEHJJ9hXNF/5m 8Vd2/wC3We+aX8C/ClxcSRT6fI0EKLB5gPMt3KOS2R398mmXH7IUSkt4T8UXlg+fMijbgBj7j0NJ JrZ+p1c0X8cF3Ejk+Lmjn96lvrVuMuxbBLRr6OoHUe1aGm/tbaaTt8WeHdQ0p+kk4VmUN7DGcH6V upr7St2OadFrWi79bHWaR400fVbtToWqQXUaxnyivGZXP8Ib2rsJJWX7y+zqf419/qKqSMoTX6nj njDw3deGbr7V4Xhd7JjjW9OX+FHPOM9u46Y9a9PsPFdlqEaSaVMskLjehH8DejZ7qayibS/4DMnx HDNKYfIjkfEgeQKD8q/7WPSujvPh1a6gP+Jrplsw6B2UZQH+6R6Upm0E+5BoP7OvhexOW05byTO5 JZv4Oeyj0ru0+UYhjSJOixoAMD8KzjDua1Kze2gBD/jShfQVqcwuz3pdvsaYBijFIBdtAH+FAAM0 u6gAxSE0AKfakx60AGM/yoHvQAEjt+NJkUAFGfSgBNwpC/8A+qmK4hA/woGe1AwP/wBf603d7UAG 7/63tTd3/wBegBN1IX9/xoEML/59aRnoGRtKf8+tNMn0/wAaYv8AhyMufX6+9NMvv+FADPM/+t9a jaf0+lMCAy/59qaZv/1+tDGxjTH1qBpv8+9BJXeX0+pqtJKfb29qQFSWUDoT6D61zHi6a/NvL/Y7 MLjafsoH8bbTwD/tUSfZFw82eKfB/wACItwZvGJH2pSV0/T5f4pwD8xBHbPH6V76upbz8zZPUn3r OlH/ADNMRLWy6aE63Oev/wCunif/APX71sc9xyXAJOCCR99f7vHepBJnv9aLf5hGXb0HrJ9PSnbh /jSKDdjpx7e9Luz0P/1qAGlyOpAHVie2PX6Vjaj470u3/wBZciRuhji5JP4UWE32RzV58V7t/wDk H2iRL2d+SPwxWN5epXp/eSXNy3XYM4APsorOU+xpTp9zstC/Zy1u45u4EtI+qyORnBz/AAY9favQ tH/Z20O351Hdfv6MMBfpWCT6nY5JfCdvZ2ENsuNPt4oE6BIwO3qfavKPj/8Aso6f4ztcxKlvq0QM uhX4/wCWpUE7JT6St+VU4/y+qIpVNff/AMMvQ/NHxFo1/YXEkevW80N0hNtfQS9Q8ZI4PsBWFNal wwbuCij6g966KbOevTs2vu9D9Q/2VfiWdc8P2jXEvmTwA+HNSbPIl08gDdn1i2f54r2TYvpTqLXV /wB4xpPy8hdo9KczBhiRVdehRxwR75rJo2T7M4Lxj8G4NQaP+ynh087t2pSBc+dCf7q+tczrn7Ml 0ATpF1Hcj7zRNgEYz90n1rCUOx2QqL7d+zZ5vrnwwv7Q4vrB09QRwfxxWAunTwNm0klhfqjIcfyq Yt9GTUiutn2Ov0H9oLxRYYElyt1EPvxzckpjs2PWvT9C/ae0e4wNWs57J+jSdVLe2B2rvjJPc86d Nr+H9x3tp4o0udd1pqttInXIPT6ioLnxLp7gCLUYGOQH5+5g9ycVPKCqeT8y+dUsl+9qdoP7p3jt +NZ+q3/hy6Urrc+n3Sd0fnafZh6VLp90XCvb4WzwT4kfBbwkEZvCniE2svLCwKkhuv3HbHfA7+9f Pov7+CUfPIm3Ikcf8tFGehA7GuSUbHoupfaNntLzPTfCvxmlt5I3uIYrl4z5tkZh/qpCpGVb12kj 6V0viv8AasvtRjaGTRrcKwzJM56MD/Bgdqaa6nKou+knoeZHT1uFIwj5G2aIjqv4+1Zj6cLcYt4F RR/Avbn+ED1NJeRpJ+fmRT+I76BT9iAL9Ap7/iKpS6nfSL87pDJ/CT/C3P8AKtb/APAMrd2Pg1i5 ZMXk6tJggyqBwfVRj+lZb6nIVZbjVC3aF16xj8v4f/11Hy8wb7fIp/2vbSLsn1ByR8zTHgrtz0IH b/8AXSRfEC2jUhb0EDhCerKPU04/8Fk3/u+ZVk+JOmSKRd3owQVKc8g+vHeq9p8QtJ4j0y9weEXK nG72cjvRyvoxXf8AI+50elW/h2P5/G/iBtOVfkS5jhZzkk9FQen+Fac3jn4OFs3vxN1eWHrJHHYS cr/skr3p+yb+GUTdVLbU2+zMLxPd6LMok8BLeXOnHEUVxdLhmdg2S8ZHA4OM9etc1BY2b8xhRJ0c 46Zz3Arma7ehtKouqXaS7Mf9jnjOViSRs4Qj+4fU+1XJPC9zI3OvtAT++tlTB8sAdCMdj/8AXpcz Cy6Iy47nU7dgt/f+cjE25mIHyOQcdP7wzS3HgKzIIuGkLZz53pz/AHT6VSn2M7eV+qM+7+HckYH2 GdLnuQP4c568f41g3elSxH97CwPQFh2HvjtXRMhR/lKTuewHoR/9eo8k/cHPr6YrG3+RbFz6Fs9d 3+P0p29z/GeOAfb60epL8mKWBHzH6e/40mW789h7fSheYNeYPx94jHXj1/8Ar1Xxlhx9QOy0XJsa GQOnH09RWvpvi+7gIzJvTqVPp+FO45L/AIB1eg+J7MOzLhJW/wBa2OoAP8X0NdmutwuP3TAe49va k15j5u5rW+pRsvUHt0rjvihqhFuiAKCz+fLxyEQH1pNf5m0JI8m8hfQZ6jjtTjD64PYZ9/T6U0zK 40IufmOf4QPQ054F/vfQf4UJeRKGiMjpj2PtSrH6D3J9vamXbz9B4X+4PqKaFUH5gPQCiwg2n+Hp 15p24nrz2z7e30oTJuenfDi1xAxAXlsn34PT6Vo+K2YogJHLKh913eld0PM5ovc6rwT4OvtSlMdg Y/lQ3sobPCRnscf571zk2vpJPKgtQDH+4lmx1ds8Z/8Ar1zSR10/LyTKk9oH+8CO6n1PvWcYZE65 /wBpf7y07E37s041RuYgF7FB6gdxUiRk9z7k96v/AIcksQw8fNGo7gk9B/8AXrU07Qp7ggafaSzs eoQHgn1I/wAaTfctLt6HpXhv9m6YgNr17DbD7yWiMCWOf4iPevT9F8DafZD/AEK3UE/euMc9O1QF 10LRkjhHysSOryP6+31pivu587f3RcdR9fakhsVRj70SQj72T/y0b/61Eaq3Knd2yR1+lP0JHyWD EfKzR54yp5I+lTpZBeBn0/8A10IYLEc8pjsD6gVFPaj8RygHcj296Ldg9RLdG6yDnqR6CkmcsfuE d/wHrTuL5jtij7ykjqadEpP3QB3zSAh1fwPpmppt1mySQdILgD5oWx/C3+zXhXjn9nO/0359OlF5 bj51njGHtxz/AAD0rNr/AIJ2UpX0n/26VPCfx81LTiF1lZb+0H3JgPmhT245wfeva9N1bRNYi3WN 3BeKeJI3625K9wfStL+XqcUk09U+68jzPxbolrZMNkm5G4RW7Nn19q4zVfCFvcDMbAHpuUdHx3FS vM6XLt6o4DVPBF3bEmRRInTevc/7a+9YxI/iBz2Hv9azlH/gA2OS3J/h+p9z6/Wnm0YdQB6AentU CaXQX7J/tc9MHv8A/qr0DwT4vUYjvn6/LZyHu2Oh+lXB/wCRnVX+ZseM7e/ubfYLmQxA+bFH/cx7 e9eXNp7L98KCPlbH96tarZtTX8vqaGi6ibVwQ2R/q5V/vxn1FQ6jbxliYAQuSy57Ams4ruZvy+ZB HEB1AJ7H0pz2q4ygOejr6fSkikILUd298e1CrF2lXHRgD/F71LHE1oviRoe7EWu2pzyHz/rCPTNa A8Q6ax/cavaFuoAYcnPXPsKqS/zMOfyfYv22vIpw13E4PACuOfxzVu6Vhzbz7x1Dqc4J9TTXmn3G 5Lo0Vf7TkHEr7j3JHUCmNGrDL26ODwpYZyAfQ+lZ27o1Ul0l5EyR6dIMXOkWTt03sgyR/tcdqz7/ AOH+gvkv4a05z0B29vfFWn2bByf83kUG+FXhV/8AW+F7MDsBng+5qhdfAfwo5ydEWL0ETY3fU4o5 n1kw5vJDh+zh4KmH/Hnco33WXd1+nFY15+yh4ZyfLvb6EdI1AB3H/aJpqT6Ipy7xXYoS/soaI2PJ 1m6QfdaMqDn8SKr3H7JtqjD7J4qlC/dkynKDH8JFU6r6JdyeWP2kyQfsj6mjZ0zxgGHRHOcpx0YD 0qqPgp4/gP7nxXkDiE+Z94fQjtS5/wCf0E6cezGH4bfFSI5h1R2/hLLIMYP+xt71Hbw/FeJ/lS4u TglFIBBx6AL3qnKP8pLo/wAs15EkPjL4p2py2iTyEcujx8L9CBUkn7Q3i7ObrwOrN0cqr8keoxTS XexPsX0mJbftOasgP27wfLIevyhhsH4rViD9rWID/SvCsob1jY4X9KFFdJMJQn0RtWP7Xfh5gBqW n6hC3Teq5+U+v0p6/tOeEy37ua+PYfuzjaaXs30sReXVeZdi/aK8HsPm1OdD9wKyH5T/ALX0rRg+ OfhdSNviG3cnjYQfu+5x6Ucj8he17xfY2T440AgG18Q2WDw5Ddye4qWPxjYlgo1qyOf9WN45/Gsn DyZoqi/lNCHWSpxDqEEjdWjDD7vvn0q4LiC5yGMBfshCkN/u0uXvE0VVdJGXd6PZ5xe6RYsB8uGj XqffFZ118OfD03Nz4WsXHYhO31FJ36MpT/vET/BrwVcH994NsI2HCsgPLD1A9ayLv9mzwgxPmaE0 feMxNjaD6jFNN/zMvn7xj2M+4/Zd8It/qVuQe65+79GrOh/ZD8OPn/ic3sLdYnKg7G/+vWiqPoK6 +1FEdx+xxJBg6Z41vlU/eXoCD7L/AIVEP2T9aUA6f49l4+6CT8pb2pqo+qIcYdYvuLdfs/8AxRt8 tonipbtQMyySShSUUdww6KKp6RpHxHgbbc+LoIjnfJEMNwp6KFXvW6a6x8jllGP2ZPseiw6zc2wH 9u6nBvHDMi8yPx91Rnq1Nks47kmQ2M/lD7t1ckKIiSeY4zz83I+lQof5GTqP7O3TzIrLVIZ3YeG9 NfVD0Zx8qQ7R1edx07/Sk1Lx4bfIutRid/vNptig/dkDjzJ8fw9f0ppdkROT6t90v8zH0bU9f1Jg ulQSW6nJkRBysaA8ySkcYqxfaJ4X01s61ey6vffebT9+VtZPSeYeg54+lNS7feNxtuk29Y+Rs+GN DvvEQZbG5jsYF6xwABYoByTLMR/D3P0FWrLWNC0kungmKDW7r7v9t3AwtmQD/q4znJf9OvWo9Hps /M0lpte71b7IsaR8I/EOrtJceKdRjks48SanfuQFtSyHAggGP9ZjHsOtc/rXj0KdngvSDaxElLjU VHMu3ugI4Hp+fpSv3XkkE49KT/v1Cj4T+F2oavPstQPNOZJLm6OAdgJJ8xh/CBXc3Y0vw4pHh+E3 +of6ptfxhdMZgeI4znJlGfoKIq719WOpJJWju9vJEXw8sfEMrST2l9o2o3Ix9sg1NwPtDEceQp6B Afw6joa9K8FePdL1C4Y+MfhrYR+QrX17coQVKoh6FR6/UdjUyf8ANfsiotr+DN6K7OXNx4Y8Us9z 4n8RSQaiTusbZcD7BHGeABjHCge361vaD8PtdkfOmfEdruyXD6hHLGrNEgHSIAdWHHXjOaqTfVL+ VFQivtQl/M33Y34vS3esrbw+D7C7u4EzcajsVtrTN0BkIx056muKs/2YPGtx08Pog6hpXxtz6gis 63kzWhR6zkld3O98I/sl+JbOOUTXlhZXDgRx3sZDG2Q9dvHWpdN/4J46dbjF94wnYcuURAf3pP8A fb1OaiCdvxZu3TW939lHRad+xj4Jhx/aEl7dkc7XYAMffFdPbfC/wdYBl07SoIkb93dKxJ89F/56 euKv2d9zOeLX2IRRZE/hy05jtLXd9xZCoJVAegY+lK3xM0tOhhGOBx1+hArVU+7OKWIfRspf8L0s 0zmRMfwgfwj2rMuv2grQDi4+n1rVRXQ55VH3MOb9o2xH3pCe557/AFrF1H9piFR8kke7qjbu3vSM 3J9DjtU/aabvdgdxjtn1Ncvd/tOdQLl37EKO/wBQKOcEuy9DMuP2jZW5hWTPVQT1HvgVlXPx/um/ 1Suf74Oev5VHtfMpQfReRQv/AIt6iygi6Vc8uP7oHvWKfHOpSnInkYdh6H/Z4qHP/I0dJ9U+xe0r w14l1Rj/AGJpl7eY4cxZIjHucV00P7MXxHn/ANV4ZlUdSzMBgfUised9E+zO+lhl9qcEN8T/ALNO vaMkbeILiCBpMolspBMcieuPb/63esCPwJGP+Pi9Y9zx0P5d6fK/tGMuX7Dv9kL3wvYxDLs7/wB3 I6D6itbwz8ENe1ONpNK8NS3MA+S0uM/65lzwvHY1Shprfsggr9l1bJD4RuLRQNb0Oa0l5SbcjffH qxHYU200hIgfKZTn51JH3D7cdjSsOUX39GfWfwk8WLqenwrpVrAs0Y+x61Oqj92VJwQcf8tV59q9 Dh0kr93AP94AZz7muuMV/KjNy7yfdFyHTbs8gt/tk+nvmud8V/CvQdUKR6lotjM5/fXdyFAaCFD/ AAkf3z+FNRXReY1J9/U+e/jd8EtC0GeIeGFljDqZ7qCQ/wCpYHjYf9r6V5JNf5OLhyf4QfTAqWv8 zGUr9PIypvCcEx+Sc4HIj67ia+zfgnqvhOz0+OLQdWsGuzl9dRuHNxnjcD6r0x296lq/5lwqWT0e uj9D0X7OecqAB94//Xpv2vb9w/T3ra3czUuxh+ILqO5lgjvbdJkO6eZGH30iH8R/GvNvi78E4TGZ /DOjwlUBfWtPQfejA+9EP9iplH/M0i/PyOQ0L9nm31y1EvhjVIGk/wBXqFm2Abe4x0kBHYe/Nczq f7OviixPzacG/i3Iev0wMfrWOq2L5E+vkzEhtNZjba9uxb7skcg7D+6wFdTYeG9gP2uaQ/3bcAYX PocV0wZ42Jlb4X6lefwzbuxLFgp4MY7H2rpPhothoc0sl/HJOzgRWs6jm1jwc/KP71Nx/wAgpYlr c9I8HeIdNknujHdKu9kktRLx5iImPlDe/tXefawBxnHt3/GiUTtp1V3Fj1Mr/q2I9foKo6ppWmX4 I1nS7W5XoxYcgH+649Khx7o6Iyf2X5Hkmrfs76TJdFfD+p3Ol/Kbm1ZT9wg9FcdgfrTR/wALQ0U/ 6LcxavbD5I1f5iVHTcQM8/jTUrbjdNPbRno/hefxBrURHiDwe1nEwMUzO2RIuOpRgDyc1veDfgBZ 6Rv8vU55kY+d9lPSF8fwED+Ie1Zt/wAnobqNtKjTO4t9Mhi/1MSr3J9/rVgJ7f8A16pIxbFCUu2m IULSgUAAAoI9aAACloAMf/roxQIM0ZoGHPtTcmgQuf8A69GfT86Bh/kCjP8A9agBP8/SgEUANLe9 GfegBMmjPrj60xCbvrQfr/8ArpDEJ96Zu9KYCb/WkL//AF/rQIYX/wDrU0v/APXoAbv9qaZP8aYy Npf8+lRmSgRG0vv/APrpjSk0wGmX1P4+9Rsw9f8A65pDImk9ahaY/wD1/emJkRuPb/69MeXPQimI rvJ6nPpVZ5T/AE/OkMqSye/0HvVC4bPf8+x9qBHC+L/CTz4ezG2Vf4lHJTnofY1F4b+ILNhNWIWX 7qTf3iD/ABZ9a0gv+AFRdfkzuY7g+hJ6Aep9q4/xf8ftF0hXEl0GuVPkmEg4DkdjUrzZL/urzOf+ CMGoaj597qWoSskrG106zbpGEJyQffj29O9ewiT86V+/oUo+XmyTzfb8akVieg/H0P8A9ekMgu9Z tYBm9uo4x19yPZR61y9z8W4xn+zrB3P3Ull6ZPcLR6k3/lObvNb1K7P+k3ErDoIY+mT7Ad6zpoVh OJV2n+53H1rFyN+S35epq6N4aub+RU0wKXYhSW/5Zx9yR/sj3FfS/h3wJZaVGE06BS/3rm7I5nlx 1JqEhyn5muY5D94E9uaQqR94qOxyR1rZLyMOddyF723X/W3dunrlhVWXxfpMX+u1qzT1+bv+FVyP sT7RdEz5f/az+DHhLxBbNc+G9StBrEQzIkK5OqWq54ZfVM++Rx6Y+D4I3zi4iKyA7GQg/K/txURV t35nXOV0tHp+7l6H2F+xr44fw9b3n9vpcixmdb7SYwPu3ightsf/AE0ULz3r6Qk/as0Af6vS75z1 A9R9cVrp1fkckoyv7qXcqv8AtY2H/Lv4Zu275Z8fzFVJf2r5f+Xfw1EPQu57+2O1Hu9WxcsvtNFS T9qbVj/q9Js07Dnp+lVJP2l/ETf6s2cf0XoPyqXJdEP2f99mXqfxz8RXalb28gMZ+Vo0QDOR/ex6 VyRvnP3m3d//ANVYyfkjSPlJjt8LfejAPTjufenjSlcfIQR2z3H/ANes7djojP8AmFikvLc5tLh4 8cBV6Mf9ritRfGdtMCviLS1uEI8syRkggnucDtWyqd2/UzlT/kKx+Gfhu5H/ABJdeureThYbW5Y/ KAO0vsa1PA/wm1Q3ipcX7LbkNLcMxyGCA/6se+K25n1l6Ey5ftRS6m/8UPhFqVvCz6LcR3CKPtEw OAUhUHoPcV843moQg5vZfKyMiQ93IPI47GuSb/mR0paXpvysZi67p0Sf6RPIWHyxXCj/AFrc9R71 a0vXoJ+Wu42I/wCWRPIPt+Fcyf8Akgb8i9JiUH7NOQcEoR2b2+hrGJ1q2GGlM6ZyolHKj2fHatFL yG0n+hl3fifUQf3sSp3BA6j/AHsVi3Gp3DnMjfQZ6g05PsS4d/QrvJKek0qd9oPSqUmkwMcmMbv4 m7nn+Ks+Z9ykvJED6JBniDJ6Z9AfeoW0K1B4t4h36feb3PvQn5sVhjaZbD/lgn5dadHp8SkeXDGp +8CBjJ9iKd33CPqdbBfwXKYuFXp5coP8QOe1crfaSsLYEQA/gOOi5NU0TBefmhF1a6RSsN1KsZ+/ GDw31Wq6TyRtujcqfuEf3gfUVNv+CEV3RfsfFsyD/SG3fTsD7Vs6f4ltJCTLGqt92Jm6nI9fapkh xf8AmU9b09pFPkbj/wAt43H/ACznTPQ1tWl/FcQh1ZfM4Up/tYPU/Wk9tDR+XoU01JEyV2q/RvcY NVpdajuSFvbRJk6KwHIH5dq6IPuYSfb0ILj4RC7Yf8I9qMAJ/dyQTnb5P/A8fw11emfs1+HNOVn+ I/j+3iUJ5un2VmNxeYj/AJaYH8PHb8qUYjdVfyu/ReZ5jfaPZEM2k3oljzuEbdVDenFZAX6+4olH v6EqV9l6i7fUcehpVxjkAegHapZYjn0qCIZbpz3Hr/8AqpWBovCIDrz3Pt9KcFz1/M9v/wBVHp6A l3Hh2/gkYHqGHY+1a1n4puI+rs6/cZD6Gmn3QNHYaX49RlwH2nBVD/dkwcckdjWJceFtYukzqV6s 75LRkd489OPQUX7lU0ur8zn7rTJojiaJ1HdsdMe9VmyPTHQj3NHyE/8AgoaU9OP6n/61DJ6j60vQ XoKUI7j60bR2yfY+tA7ClSfuAAdceopREv8AEAO5x2P/ANenfsJvyEUE9M465p/l/QdyfSnYSPWf AVqVtgTjJZsH2z/Wm+J9paIcfeDc/wAQGeldsfL0OT1Xc9l+DMCwRXs04KhIzZwk/wALshP68V49 Yq0oLO21nJuJcdySeh9hWUjopvR27pfgTizOec+n1/CmNZRMDuDE9Ex/C/vRr1GvP1M6S3kiPfP9 3/noPb6V0OgaDPfnFhA8r9TGB/q8f3qiL/4A5L/Jnp2h/s9y5B15IiP4LNerN7n0r0a005LQeXo2 lrbE/wDHxIi8wRdyzHuopPzNLfyv1Lotwm0afp6uejzzNyVHoferi3d1/wAtIwq9AQepPoaX39iL eghKscyRF1Hyn/YY+g9alnhjXH2Tbuxgbv4AfSn6lEMcO778u7+EN/dHtUmxF4Esg/ic46D60l5C C2gRm3LOzj7keenPfFWyCueM9j7VTERhWOP321e49TjuadJCHPyKCo+XfnqT7H1psBI7Nj/Ev1Jq ExP25PapGiJ794ziZAzdF29m98U37Xdrn99CmeGx2B9/ej/hga9e5o6a+Ry+7sW9TUOsvnjII6Mp 7j3HvTCLOE8S/BHSdSGbJFsbg/8ALRB8svH/AC1T/arxXV/Bmv6FKSolt2+7HcxZKzxA/wAW3+tZ SO1NNe9v+ZDrfxGuNSRF1O3RZE4Mi9JTnsPesq18X3lo39+Po6N2/wB36US8jncOkvkdLYeJ9Ovx hJlD42vGepYDuDWNrfw2hcZs12N1dT0Z/b61ov8AhhRf8y8mcfNpM8Bxc2sinomBnJHpj0pItKvp Mi20++duikRtjP8AvY71lKPdmqg/slyLwH4hm/1Ph7UXPUgI3T6kV2vgT4FeIWvrY634eu4LTeJL mafgeSB3H+1WkYa9CZxX2px8j0bx+mlQXjx2LKoHPkgfcU//AF/pXnEvwWu9RmI0i5sYDgySzXL7 VYDH3Tg8n6Vs1/mxcy69k2aH/DKl0v8Ax9eN/DsQx5jHzQcKPoO3/wCuvNbxjGWVGMigmJZR/Gqn v9axS8xtr7CZSEEhI24X1Y9hXodjYfDmJB/aeo67NcEfvVjUbUcjoM+p/wA+k27JMy5n9lLuinJr /wAPIf8AU+FtVmbOJJpWwOfRVPcVoR/ELwMrDyfhfC0eP3gkkOZn9Wx6Vdl1bQ5Tl3h5HkUn7KGk /wDLv4hugOhVkHygf3Tis2f9lFAy/YvELhTwzyL90+5HrU8/ki1BfauXH/Y/1Qc6Z4riK9nyQVYV Wl+BHjeA4svFIcdQpkxk+xPp9afOvtE8keiZWf4S/ElR+71JpR1I80fKfy70yfRPilbAGSW6dRzG 0bA4PuMd/pTbX8oKl2ku4kniD4nxhTPa3TL1UhBh/qQKsJ8cvHltxfeG3nXoqsjcc9sCiy8kZui+ khZv2lNeA/0nwgU/2sPxj3209P2rLlVHn+FDn/loxYgY/Ef1pOmv5hOMuiLR/atsjjZoNzGer7T1 PsSK3IP2tPDUoxe2l9BJjCMVJ3D3IFTyfyi977SIR+0b4cP+rmugeoXb1H+9VhP2gfCpT/kJThs4 dTGc8n0o9m/LzB1H1XmjRt/jn4dXBt9fTnhlIPcfx59q3YPiFoN2P3Gs2av94K7Abv8AcNKz8glU /usePEdkv3dUtG7cSDk/nV2C5UgfZb6AZ+dSHHBHoc0SXk+5Sku/kjSttdmTi5lJ7xkkcZ/un606 c3HWBgw5fgD5T/8AXrP5FKf8sl2KX21GOZLaIt0YlRyPfjtUH9l2Cn97pFkwPzMDGPnT/aGO9Fux rGX95kkvw+8L3SceGtL3fecBcZ/Ee1YMvwh8IjIm8JWg7blyMYp3f8zBSfkUp/2fPBb58rRSnfer djVaP9mPwWww9teI3UOGGGGe/HehSffyLUv7sSjf/sjeE8n7Pc38I7DghX9s461Ub9kDQ35tvEt+ vdkKDg+3Har9rLsidP5V5laT9kmMMDY+LriI9A7KeAPVhTk/ZY8Sw86T48C91IJGH9wR1NL2r+0h ckP5WRj4XfFAYFv4pEwGVZWcAsfrt7VEng74uwA+RqJbuyB1O8D+7kf0q1UXWBHsV0kIt/8AF4r/ AMeTuBzuIXLAeoA/wrVt/iF8Vkwt14WtSvRp5iAFA9WI7D61Saf2SXS71Ub2m654gkYfbnsS/WW2 t1J2r/tSkD+GtjUfHlnbAC+i8uUkKtpDl2Le20deneiy7mEpP7F+xYk8X6zGga8s7TRrY/OlzdsG e4Qf88rcD+Inj/61c0Pizd3D7PD1jPeXHVrqYYUKT1jhA9eKcWupnq9FL/G+xc8RW1hbRhviD4su zc8mTQoSBk56OF6bB/hUXhO6XWlY+HN2k2S/JcTlOIVOf9ZcOOSSCTz+lKUn1t2SBJa2Wi1k+5U1 Dx14d04MnhxIdWmJ2/25KMKsmf8Almjep454710kXw4NvBHc/Eu8kuZJst4U0BB818gOM+UvRU4x kDPaht9X5t9i6fdx/uUl5mf8SJfEVq0cN0YLG32+Y2iWRB/s+M8gXMqDky5BPOO3aszwl8K7WTL6 rfDTbNf3uoXZGWkJ6CKM95D/AI0N/wAvqKCWrk7933LviP4k3EgaLwjarpWnn/XPGcvfEHgSysOA v5/hXmF3pdnLKI9SsLhZWZYIducyqzdV4oX/AAQpwbd57nv/AMQfE2m2SRad4W057ewt1z4ov4+X 1m7nAYLORkhYzzjcc965bSvCem3hVdBMlu7Hyxg42Me5ZhRpbR/3n5miTbvy7v7lsjt/iDpGt2EE Fhpty9xtzeeJpIOftTtgqs8ig5AGDjPpurD0X4d+JlIA8K3UwPDSoD8x9gR2qE11XmzaNFvVWV9F 6LQ9M1b4U+N7qwWDwxocGlu/z6xqjMN8qK/G0MDgxDj0PWsDTP2F/EjoF1fX7WGPrMhcneD9O5ov 2T7spU4XbrTv9leh0emf8E+9Dtzu1PxJLcAkMLVV4VR/tj1r0CD4HeGIVlSW4nEEuDqdsmALlVPR 8difoKUYvqxTrx/5dw8mLbfB34a2f/Hr4P0tv4mkcZ3sR3J9a04dZ0K1BGm6bZW69HWNQNwH97Hp Wqh3kznniW9rFeX4o28f+qaNR3C44Ptiq4+L9sBzOvp16mq5Uc3tH1Zj3Hx2tl+7cqD25/pWLqP7 RFog5u1z9aZk5f5HMXv7VFog+a6X0A/vfSuK1f8AafRzmG5kX0HPIP8AeGO1O/mRr59zC1H9oG6w DI5dCN0LD+LBPb6iueuvjxen/VRHHR9x7ey4/rWbqf5o1UX0Me5+MuqMfklfb1IVSckemBVKbx9q 85xF9t3dSiRnnPoAO9Yur2OmOFk9oyLNn4L8ZXpxYaFq8xOQoZGALH+8StJ4l+E3jDSxGfEmgzwK 4/0d5ONzr1CnH8NSpvovM6J4a3xSj2sc8bC5Dqroyq3O/tGf9o/7VaFj4PilZhJc8jlnA7D+7U2f fzRzrz9DSh8Fosi7dzw4JuJOhDAfwj3ruPBOgeGI7lB4n0Zbm0bMd0T/AMsGK8Egf3TVKHe/maKd tku59MD9nb4XzRExeF9IuIeNssbcgnpjB7//AKxVIfsUeApFJ/sCWwY/6hoGyYh7gjtXQ6Pe/kaQ xb6qJh2/7K/jLRCW+FvjtUGdzWF0igSrnOCxU8nC/lS3Xx9+I2jgJ48+Hr3WctFqGnsTmNepKoD0 HNXC324ru2c9SF/4UrPscB8TPi1omuND/ZH2mHywRfx3CkE3TMeBntHXDTwqq52gjoo9T9Paiq/5 WuxhC/2l5s2PDXwL1DVNsl/5sFkxEenhRzffNzz6L+dfW1ho1vaIkemxeTEgENtGv8IA7D/aNNL/ ACOiWi09WX5bOGZdt7a29xGf9bHMoOcfWuU1r9mnwLehjJog09iCxntDjB2nrGeOabgEKjXmfPza H438DsreEdXlisZ2JglcApdSqekwYYBA64xn8K9dX9o/x5pKqfH3w2a9gOHXVNNbO+IHqVQEZH1B ojPpOPncydG/wSt1S7nWaR+2J4I1I4/tefTZOht71Cv7zPTzMY4+tdb4Ku4L2e4e3uorhcrDEUIO E2+g/ve9bNfytGCk0/3sWj5n/aL8Sx3GpTCB9wQLZKOyOF52/jXh8lsxB2khyREi+juf8TSn/kFP yOp0n4efZb5Ib5Mnckd2M/8ALNyD/wCPg19Ia5+zB4MuSfsVrcabKPlS5tz91x6j61zyj2b7o7oT S6J68rMRfhJ4/wBHBPgzxu+oRj5vsN1j51XsA2eo9xTov2mPEWnNjx14CuZFHyyXtoDyq99oGOR7 1op/z/eZOit6Dt1sbWn/ALQPhPUb2E2epSRKEeGVLlCvl3EhGAWbHTHYEfSvSI9fg5NuY51+6Spy GVvUD1qnHszBVLfGrHjXifRrrwpdC68JwSTabK23xDoyf8u00jHJj9m7enSu5v8A41WTpnQY2lZh jewIEIcevfApRXf5EYitbb0PPpNKkmctJGWkJLyMB/ET2HtVa48OXEf34JMdQcHge3FWzxdzHNmS eEJ7gkdhU/l4/gOO2OwobBrumVJtoPzRBvf+79K0LXxbqlqP+Jbqs6L18l+Qceu4VpFjUzqdO+NN +FB1HTEnx8shgzkc9dn0rtvD+szakM2NncAdcSKR69yOxFZTt0Z7OGu+j8zobb4PvJMsl7ftEVBi Nuoz5iP/AHj7GuvtPD9rD/qYBnu7d/wrL19Duuvsr1L5YnqSfQUBfpVW7GbFA9qMUALj1pdooATb 6mlA96ACgj0//XQAYooAAaaT60AKMUfQ0CEwf6ijB70DFNHTpQAm49zQT/8AXoAaXz/hQR7/AP16 Yhv4fjRigYm6gmgBC30pPMoENLn/AAppkoAb5h/+vTS9ADC/vTd9MBhkx0P/AOuozKf6/SgP+GIz L/8AWphc+1MVhpk9KjaT29/rQMjMn+IqNnJoGRvN61E0lIRA71CZsdfwpksiab3+oqvI+emaBlWQ +v1qpMD3+g96AM+4U9h9fpXF+I/BQl+ax2xyA+Yyj+Mj0ppjXn6Mg0r4tGxib+20clAWgI7yrnAY 47mvnmXTNY8b3ki6NHukyZ7iZ+Fgj55Z8HrUVn29S8PH+b+kfX3hLw0umWkEKOrmNBBNKowJp+5A /wBo10trprv1KKPvFm7AUXFJ+foYWp/ELSrY4iuluscOkfcj0xXOX3xRv5wwsoRYoeQytk7fqRQ/ N+hCOelkDEm5laQ9WZ+eaSO8hP3nx3B9R7Vmv73yLbS2XobGnfFn+zD/AMSzSoJJCChupefJDD+A AdxXMvNd3spe5kZ3bmRiPuH/AGQB0Aq3bp8yYp/ab8jf0fxrfaM5Np5sLFdqz7eqjPALDtV2x/aI 1i/ybfXLth/E+ABkf3cjvThLyQqlJ9U/IfN491ST7+t3bHuc/wAsCqU2tXTff1K7J6E7zz+FNzfQ Sgv5UVJULffkkJ6klj196h+xxH7wHpz2FQ6j/mZaj2SGGKNfuKB/eA/iA9awR8N/DSytKvh6xNw2 XllZQcuT1wRWMl5s1hO2xrGdVwIkjjXoiIMBR/uigXPoAff0NNrsyb92NOo+p+hpG1ZOzH1x6fjT Ib7+g3+0x649fr/9el/tYDqf900kNSGPqg/vD1z6/hR/aw/vH61Lf+Q0INZP94D096F10jo59SPe qTJ9S0ni9h/rSHHbParMWv2Mp+dxG3bPT86Guw1P/gk8mlo3MSow/hcdvpTYNX1OzOdMv5YT0BB6 j6Ed6FJ9zXR9DpLv456lPZvHeuslwc24mjH3oSO4A7D3+leE+ONEmMCmxhJkX7yr/EBn+VFV9vUd GPd+SPJ7/U7gJ+9SZefniIPDn1GO9U7K4fdm3Ein7xdR0Y+vHevOidvJ2R694S+H93fBXtUfzfuX MgP/ACwGf4faus8U29tpqA3cp25Ebq/UMxI6e1OVTbTyPUw+Bbi2rdbGQ+k2s6grGrIeUPqDnq1Z U/w8tGzy0J/5ZsBwrejDFdTXf0PEjU7WOavvA+oxE4hEsY/5eI84Y/TH8QrIaFh98MD2B7fUGpa7 +g7dvRldy3ZCT1LD+ID/AAqIr/dH4+hqbE27kTRn+HqOT9R6Gh3B6A56j/ZFVb/MVuwtpdujchSv 3Xz3X6Vr3Vh9oQmEfMo3Bf76DP8AKqsSvM5pkb06cYPfBqJyT98ZH930NL1G/wDgjShPUDPUD3/+ vTNpPTAPRge//wCqkDXkPOqXKDED8/cjX+8W7Y969R8b+AYdDtbd8uu8BdSz/wAsbqQZO1QO5z61 dOJF/wBTzG5vlbJtpjIn3xIP4l//AFVN4f8AihYWBc31gt4SDDAGz+4kbPIAHatrdzFv+UoTfEF2 JKFYmPzoFPT6HFSW/wAVNRXi6itrpT+7eGYfwH0bHpWiJt/mSPBoN3Idtu+mOeXEXIJOf4cd6dd+ AbqMbraQXMXQSLj73+77isqhvTf83yMd7Vl+8rD2btTdme3sffFYNmjj3I3HuD2ApltHljwM+vpR bzJfmX1GfT/aPvUjAL2HoR6fhRYa8hFOPTPRc9zTzGew/wD1VP8Aw5VuyJViH8AYemB39uK1rDxN cwn5VbH8Qwe3qKL9waOgTWbK7H+m2yZPBJHc57Y71Q1L4esctZNGy/3R/Gfb6VS9Sk/5kc7JpUqn 54XHbBHf2qNbKQ/8sj/s8f0oaEoj/wCzpx1iOP4h7j2po06Uni3f1BxQNrzHrpU/aBz3xjpTjpFx 3t2HcZ70egW7tEn9lz9oPdl9KWPRpj963X1A9SPWhMGvM9Z8MW/l2yBhtbBdwOxJ/rWfrp3zRhFU gfO/scGu+5xo9htZf7P8PTMqhJJnKxnPWMnHP1FeU2kQVQGOMAJj6VDNYrTTuyVlb+DdjuPX6Vua H8OdX1D/AJBVl5g6vOTwvH8RPpUthbz9T0fS/wBmy0Kn+3bkyS/dgERGIXI9fauFvvD2teE7kPYy Bk/5Zznpd2u7o4x/+o1jzeXqdkYppq3nE9q8L+M7TWk8y0d1dflurY9YnGM/L7fT6Vs5uCOMoDy4 Y8iL3x3NU15eaOKD/m6e6xP7MVjm3lmUf8tAR/rGX3Pb+dXJ723iH+myLEoHmSOf4UA6kUvX5Gvp 6FXTr+zuEDafIJIj+9ScH/WL7fUVdZA33enTHpQgv/kRMWTGUC9yMdRSzPGc/KxP3nUenvTJJonh QZlZIR95ix6Z9qZb3sEo/wBFk3L93f64+vrTEL9hT+EY/qfrTZbWIKAyO56BV7A/3vpTK9BphiiX 9yrj+L5j/L6moI4pTy7MO689Ix6LRYV/QkZZGGVi2dg394D1qH7FAP8AXbCSd5Of4voPSp/4Yr/h jXgu7ZMZcHPBAHQj/wCtVDV9SsgR5spGTmNQDkgHv9KpLzQl6FT+0bd+IFnOOGyOmfTNRXhjlXZP YmSE8zq4+/Fjtn0Galruiot9GeD/ABR8K6BZSovh+2uYNwMt1bychG3f8sjXCWrRq4N5bLcxD/XW zHHmoO24f3qw9WdVS73tf4jsI/in4Ot8fYPhDZ/3pJGnbLNjuPeqFx8YkuJCZtEgsYT8kdvExIiG O7EdzW1l0lI5Xzfaa7G/p2rrGyyaW0LEfcBAOAR3BHpVjUPjX49iz/ZWrwonWJViTMOB2OPX2qk+ 8UyVr9qXn5HIXXx58byH/TPFd4Dj94FVR8x9gK7f4I+JNf1W/P8AbGv397FGhuWhlbIR1PGB7Ypq 3SC7kVY6fkcT8QPE8kmoTPFMxO7bszw2Petiw1CK+jIO1j/y0wfu8fxCrv2NK3n/AIDhta8KJbOc jMZ4jyT1PtWcwTHyuAPugelTLzZV+y8yCGfP3if7pz3HsKsCSMdSg7L71kgb7EciKe2e5HqKIsj7 xAB+ZWP8P4Ueo7eXmUE/aB8PZwbm8UenlnqfUVof8Lp8Msf+Qo4HYlT8h/2+O1JQfZGfM+q8jQtP i9oaEeRrsLofvA5+bn0rbl8YaNMMw6rZ5PzJHnkj8am3dFKfdPzK8XiK0Byt/bFTycuOGPbH+zVt L9CP3F3bEfeZgw5P/wBelbyfYObuW7bXZoz/AMfAKnjGR8v4VflSSU5gkyeuV9B6nHYUfIbl/Kyi 9244lhif0LKOM/3cjvVSfSbeUYn0u0deg+QcA+vHekVzf3n5jIPC2hFdt74c0+ResZKDI/EelUtR +E3hh/8AmVbH1BUY3EU+Z/zPyL52ZDfBfwi4/eeGoIz/AALGcYB96qv+z/4ScYGlyxHoJVboR/s+ /wBaV/7z7lc3aMRifst+EZlG281C3l6MwwQ6+4P+NUb39kDQs/uNZvQOplKjnHtVKb7Ih26xRmP+ x9br/wAenipz6+YnQEfwgCoZv2TrxB/oPitXfgqjAjYP9lh6fWtPaPqJwj2ZNN+y34wABsPFscp/ 55+YQYm980N8MfirbnFv4hik7Mnmjg+2VqedfaTJdKP2Ctc+GPi7CfnkuXPVfKKkEH1UCm3Xij4q WxAu7K5kb7qIEBDj3wO9XzLpBE+w7TXkMf4o/Ee0f/S9AkY9VjEX3cerAVcl/aX8Tf8AMR8Ekt0Z gGGF98LSdurRPsZdJXI4f2o9RjJ87wkzJ22lsgD22jpVyH9ru0z/AKX4VulPQCMnqPYjt9KXKukh ck+i9DQs/wBr7QGH+maVeqfu7CD8uPcCrbftOeF8fuTep/GxKE8gdCuO9Jw7NDXN1iW7b9p7wm6/ vJr2Nx8pj8s/qfcVaf8AaM8IjHl6xIc8yIEPy8+uKr2T7oh1H/Kaf/C4/B8q/wCj+JIA33trgjB+ hFbWmXEVyheK/iW3ADfa24BDj+EHrms3Bmqn/MmV4fGNxK5TwhC9xJ/qzfuCAfeCMjnP/wBepdZ0 rT7D/keNTkvtR+9FpIYcsf8Anrt4AVf8K1a6R+bMHLrNK+1Ndh2j+EPEGvyCO3MVtDguNMtCP3UC DJNzceoHJ568UuuWw0a1L+DdFtXA/d22uXA/5as3/Luj9TI349zUJd0/8y6kkl7r1esmcTpPw21X V/33iTUl8sfNqd/IR+6LDgQRD24wKvan8SLK2HlfD23NrjCazq8g+bUZiODGhHATOB0Pc07eXoZT stIX11m/ITRPhZ4c1jYuuWInuc+ZdSOT88YPJH0Ge9UPjl8UDqzLafD21i0HSrcfYdL0qAcNIx+c vcEAne4J5ye5ojvq/Quqr2UFZP35fIo/C79lGK/nhXU9Ruphn7VOCQFPk89WwOSPX616rq/xZSWZ 5PD2jX15qZJtbHVmjYrpFjGCubRGU5aVcjpgDoaiL/nt2Z1Vqeyow/vN9uhzmhfDXxbdzAxeD9Q8 k/Pc6hOCC0g/uq47/X3rdf8AZb+IF+f+JnaWkcAJOnws4HlRHu4A6t/9aq5uyZX1df8ALycV1sb9 l+wxqzj/AE/xLaW69XCDJ3fXHau20f8AZS0W1eJ59RE91HlbW/KDJUj1Pp+H1qLPuHPBfBfudHY/ s8+EoXle6SW7mlP2jU5pTwxQceXGOAFHHT61dh+HfgmDmDw/ZKR9yUDkZ9D71agYvEfyJdi7H4h0 O1/487W0iz8zvtHzMfVj60yX40WUZ/dzoB2wenH9a2Ue5wyrPuZF58eLb/noqjqf9o1gXn7Q8Kj/ AI/EHcrkcfhWljBz8zntQ/aes1+9qEfrknqBXI6j+1hbA/JOzHqCOdv4Clci77HN3/7Vqv8A6t5D 6AZ5P1x3rn739qG5cfuIpD/eJ7fQVEpo0jB9DBm/aC1WX7iSDH3QMnBP0FQH4heKbj/jzttQlP3W VImwG+gXvWEqp2Qwkv5WaFv8NPiPqGDZeHdRkJ6eYpGQfQkVia14K8TWErR+JdPltblRvkjlPIiY cFWx0Yf/AF6z530RvPDJfFKPaxnL4euXXckocY3xhedyj+7gVZtPBwkUNLctk8mH+6c/xE+v1qnc wSXReh29z+yZ4ijsftF5aTfZOJplQhmhs8n5hCB0A9/zr0PSP2A9K1S2SXwj8RWugRujjmjXasoz kMV6FTUpPsjsXKvjV+5c0T4XeL/DDFT8MdF8QRAbjOhDFVz2XGe3p3rsvD37TPg+DA8ReD7jw7cc I7y2pwZP9lgvY10QgvtNmM5T/wCXM212PTtP+KGh3Ue/R/EdhcjgIkZAILf7Brx34/XU7yQJd3Id grXU6Eg+XvbGOPXFdCguyPPlUu1zN9j5/wBVt7YfdiUHltw7Z9B7VS8E+EL/AFi6WHSkEbuSIpie EjAPL1y8n+aOqmrv8z1XVf2QfiBZk/2Wthq0Q+f92+CQB/ChHevONTsdfsJs6vomo2qY2PC0TYEm Tz52O496lS7m0qKf8OXoi7pnjtEbNpPJE+fn2Ej5l/wr1Pw5+2F4rs8CS9tr+MfKsd0oyoz/AAyA D+tdkanf0PMnB+aPRNN/bWsLk41zw3LadjNbNuAPrsx3rsfDPx08OXlwxt9ciQKvl2Ed0MeZv67Q 3dfc/lWsor7PoKM2t/VHz38W49P1HUZ2t7aEKCIopIgAJHReSQPU1x+j/DDULy4ji0m6iWaTP2cT MAEVQeWY/wBwCuSp/c+Z1Udbcx6sfD3xO0CWCN7K01+KINc6TZQMOIjnOCozxz/D078V0Gn/ALYm khiPGPhrV9Elzl2ZCy/hgDofatYS/mVuwTpP/l1K/Wx6doPj/wAP6moPh/xFY3IPzBNwBUEfxI2K t6wWET4boCVx/E209D71bT7GCmuqa7mRNoen6lYLDrEKzQugDZA/cy/3oye6muH8H/EjVfDMosvG d2ZbAkp4O1V+RFAx4S4Y9s8e3Soa7o3b7eqOw8Q/DfwvqZ/4n3huylY/K08fDYOejL615lYfs1GC W4Pgzx1faI0eZLOLtIpQnEmD2P8A+qi38g+df8vlfqeGX2r3Nw7HVJ3uZSS0079ZpATycCo7FoRL GbjPlq6z3CD+KJW54+n0pOX83oZU/JeZ23iDxJaS6m02kyK8BkR4Jh0EC45wew/D6CvpmfVY8/I4 OcSBh3DDsapvt2t+QlL/ADQ0axj+MUo17IIfa6nhkYAgg+oPrUvzRaZ518QPAPh24aIzaXBAhYW1 +8YAB809WX2P0rmNZ+ENzo5LeFfGd3AAf3Nsx7eyHPX6CiKf2X6iqTVv3qNu08QeILqEJ4i1FblT xMmwDzdp/wCWgA7GtnRvCE0pxbwYXqT2Ue59q6PkfPVJXfuNnb22h2NmuZ2VmHJduiqPasnVvFM9 3hdPkjij6rcEffYf3FI7Un5/I7aNP7upn3Gkpj/SYYZm+7I4GCzfh61nS+HLYj5Y3jPqP8KxbOyd BfYZSb4XTztjT38xumwd/rxXUaN+y9qEw/4nFxHar1IHOcHstS5fyip4X/n79x6ToXwR8PWHMdgt xJ/HO4+8R/sCutVABhERV7KoHH5Ukv5j0HL+RWF20u3/ABqyBce1GD2oAXjtS7qAAH/Ckz6f5FAC 5/8Ar0f5FAATR/nNACZ9aQZFAgJHp/8AXowO1MYYo4pAB+tGfegBd3tTc+lACb6bupiDH+FGaAEz /n1NGf8AA0DGk0hY/wD16AEJ9/rTCwoENMhppf6mgBGb60xn96YEZlphlpgRl/8A69N8ygQwyGo2 c0DGF/w9KjZ/zoAieT/9VRPN6UgI2l/z6mo2l9qAZG7j19/xrK1vxFaWEEkuqz+Vbxgz3cp/hRR2 UVSJfmVPD3jTTdWgSbQLxLm2fmCdehZeo/4Cavs3v/8AXokgT7orSY/+tVaRj35pWGynMc/yArOu IyOnX09KBnzN8ZPGt1JctFY25jORCIgP9YzE8sfevTfg3pUOgRmO+SON5CJdTu+8fsx/2Qazi77m 9SLS/L0PUdb+JulQsV8PCS6kHEcpU7UBHZyP8K5m58Q6pOD9ou2jHVgvp7EjtQ5GMV/OjGfTSv8A qtv+1j++fUe9VpDOnDZP9efWoi+5pJfy+opvIT/rAyn+Jh3/AP1VPDYCX/VSD8Ow/wD1U0uxN/5k dR4N+D82ru4tbmNVQb72dv4M5wB9azdfsG0e4AtZI5ljIlnXH+u2nJBX/aqYvujSUlbQ+jodF8O+ JbNDNYW8sTLtR04NtIQchWGPuMTXzx43+Gi6DIVCYhOXs5AOGQk9cd6JR7Dp1G1r6o5Qa6mOMD39 hTjrkZ+63PpVf0zmv/kNOvH+Fh7j0obU3PYejg9gPUVm2UvIY2oMekuB6+g/+vUbXhP8eR6jsfr7 0N/5lWHC/Ufw5PQH0/GnC5H8I9/xpNjS/wAyPJP8Ge4Hr9aT7PkcBl/u8dG+tK5aiV5LWcfwsw6Y x0IqD9/nlSPUDv8A/qpc3+RLh/wRqxTfwjHqPXNIUuO2fQZ7NRfyCK7/ACGm3nPRsnoc/wCNNNvc f3sDp9aV/wDgCce3qIdPn7MMfePt9Ka1hMekhH8IYf0o5h8o+3fUYebW7mTH3sdz9DW9Y69eSgi/ CMw5WRRjcPcAVon5EW7fM6L4fTIb2P7UispzCqOBgyMDyQfSuU8aRQ2k8sczBcO3kj/YLH+Zq3Hy NU97eTRyUsdow/e20Mo+6wZR1Prkdq734ZN8PGVovG3guykLHfZ6mQRtyOjFcfdPOefftRyLqZ+1 ktYN9z1K0+B/g8rjwp4hudNH3o4sBgCfQt71xHxR/Yh8V6zblfD/AIl027ckMoc7C8aHo27Pb/Pr x1MO73XqfTYLOI2tWgldON/U+dPEH7Lvx18PoRLot7c2ozOUtXEm1I89NinhQPYetYvhP9pqdG2e JrSVcfuRuGCjYP3yV7V1prqrdTw6+Gtrh6kX19D1nTPGmlXnOk38bnqoU9B+QpuoeFrSfP2q256e bHgEZ9sdqwa/mRnSqdvVo5a/+F90n/IPn+1L98r0ZD/tJj+VczPp0sZ/fwyqRwUYHg+4IqX/AMA2 av8AD80VzGR6/X0FQ5BPAI7Ae31p27+hNv8AIi2+uPXd6Vq6VrHln5vmXoVP8Sn/ABq0RL/glPVL ZNxNup2E7kH9zOep9qzXQj736etR8hr/AII0qe2P/r1A6kdSQe3tS9Rp/wCRd0VR58JLJxIkkgfp tVv4ifWvTv2j/H2larGkWg6sJ5UbdeIFIBjKn+8Oxx2zXZSWhzTlrt5M8RtdNeNcLIWJG1wewOeg qhJ4VZuk5HfZ/kUmgi0IPDajrctnsfT6cUsmikD91PuP90/T6U2+44f8OW9NtpXY+bEwxwMj+Lnp 9RXYabqckZxuOD1z3rO5TR0R8JWl4p89AH6pMo6ADuPeuP1XwNeW5+RfMX+Ar3GewxXKn3OuKujA lgdfvBlP90jpmm2cZBO5j7n86swaLq57fjUoiX+I59xTE/IW1i3P8y5Hb2PvW3HETwyL6qQPvCka XZISw/hI7gDt9BSrM3pz6nv9aehD82O889se3vVi01yaM/K2ByGU9wf8aVhN+ZrR6nbz/wDH0oU/ dz9PU1WudCcc2+WHVB7e9XHz+RSfmUJkkT7yEDqxPb8Ki870IJ6Af/XosS/MkM8h6tgfcyfU+9Ac gcke2f4qleYX8/IGuAPvEZ6n2Boa6G07ZFB6AHuT71a9CFLzPqrwr+zvpcFtGfEGpFpWRZjbp/yx Mi9yfUGvMPE/w4mS7YaPaTzxbSsLBSdxJPBAHb6VXN39DppJW29Gd/8AETw7cCy0+0soyZZCszwD +9nPzY9D+FUYf2a9YBIla1UDhmLdW/KrlL/Mmml9p/3vxNbS/wBnRww+3TJKv/LQKeEI9R7V6Npn hTTrNMWUYQD5Tk9fr+NZL5jm10Q1LqzwTJfW+c7NxI5Y/wB0e1Jqvhe11KIpfvvg/hlA5WU55X6V Uk+qIpz7ep5FJ8GvFekzlvCcyMo+USmQATxHtJn+9+Yr2TT9RjlRWvBBbz4Ant94YrJjnaf9k+1C fdPsVXSveDWvxI0ZL+AY/wBJX3JHT6D2rL12fTRDN9quFXKNFNMVPEe098dqmXqiYPsmWfB3hqFr SAaRd200AjVbJ9wBkjA6tuPc/jV3V7cWG37dLDlz5NpEjgl5D/sg9qhz8n2Hp09TOn1O5Jx/Z+wf dVmb09RinSatIBiO1z2lmPc5rfQj1a7gtm8g+Z4ZCPnAH8P1+lXI1nT/AFs8Q9IVX7o9/pUhb1AJ I/KXkmOq4A4/3eKRdPIOWuJT6gn+gqr90NeSI3t0kPzbgOjgn7wHrTHtI/4gxx/q/YCp9PUPkuxU K9cQt6HPr7/WrNtZKp+ZAD97Ppn3p+oM01hDY35Uddw9Qf8AGs7VpOm0EH7u73NKw0yK3iKjBx9P c+tR6gzEdXU9FH+yKAR4D8UdQZ7gbxwFEaY9AByT/tV59dXBQcnA649fwrGaOqX6FZblH9u4NTNb oT8wUn+9/eJ9qd+5gWrW9ntubeXjqwH/AC0z7Cup0vxpDPxdxCNuhIPU1ov+AYvy+Y/UPCtrcD5i N3RZUxnaPX2ru/gdoSad9rd5oEbYURmIG+NUJ4BrSIqr0+f6nglvqL6lLMTbuuHYu395CeOa6HRL 5LN8vE3ln93dBeoT2H+yaTfY3rLfT0O61rwpHcIMbZkI3wyeoI7H2rgbvwXNECZLB/L6LIFODj3A ra3+REHfb0MK+08KQUUIPuSj398+lWrCAyfdgJ7BgPvfj71ioPsXJeXqdlN8ENfhVTd6NJGWAkhg 43NG3QlB60kX7M/ie4OV05YFP3lmP3D6rx6Vo4jhb+ZdzE/4VfoX/LfQbRj3Iz8x/wBoe9V5Pgl4 Ybp4djHeTB6Ofw71jfzZlzvyKT/s7+Fj00uZB2CN/EffFUZf2ZvDX/LJb1OxYEcE/wB0e1F+y8gU 32iVZf2X9FPEepX2OoLKOT+FV3/ZjgUfuPElwmOCADy34Ci7E2usRj/s6Xw/1Pi+fH8IOflJ9FxU kXwf8Z2+P7P8cKw6IhOPl9yR2oVuoc0ekWLc/D/4inP/ABU8c3987lH9O1RQ+HfidECIr+CQdA2V zt/Kk7dEJRXSTEmvvicgw9hHLj70pAz+IFPt/iF8QrdQLnwlFcJ/G44yfYY9aTj5FqK6VPIY/wAW fE6/8fPgWY8YDHd8j/Tb2qOL46ajGv8Ap3ge6Z/4WXdwPc7afIu4tfsyQ9v2g0AzN4Uv4m/iZc8D 2BHetSy/af0UEDVtP1BP4XcITs4/iwO1Q49mUlLrbyLD/tA+FlBIvrvOfkAiblT74q0nxx8JuOdX lU/3GQg5P+zQ6b7ryByfWLJ0+LWgR8xa7bMv91jjB9+O1bUXi7SLoZg1iyz12hhyR6E0nHuSp/3X 3HxazEv3dTtcfd3GQcj657VYj1AnmG9hI+5vDjkn+7zUtP8AlZoprqy5Br9wOJrnj7gZSD+dLPHJ jdHh16gkA8n1GPSo5f7o1UXSRVNyrHLQQ5/gYoOF9hiqy6fYBsvo1ix+6+6Mcg+ox3p+iLUv7zHv 4O8PzqdvhrSy3WRig+Zj6GsaX4XeFB/x9+FbD0yoPJPqfehN/wAzBTfch/4Z/wDCM+fs/hhAOokV j8igdST7Vk3nwS+HNqu2+FxJP94QW2WbA9do7VrFPrImdbooRfbyGr8P/hxpQMl74Quby5+7a6ZL IeJiOtwUHATv+Qqa0+16pg6pq626pxaWECgLAGzyigd8d/pWkl1XyOWM2379rLt1Z33h3U4/DsEk tq/2u+mIs/D93Nj/AIliFTuaCPp8w7kHpwK86n/Z0W+kLR/EG8mnb52ATJ3Dn7xz938Kyc30S7s3 VNN6p6fu4+R2fhXwJq3ha1f7FJeaxcXLrD5e0jy7WEnO9V7HI64HTrUPjD4AfEzxRIrecLa3Xmx0 0DCwoQP4tvV8dcew4qoy7vXYcqCb99tJWSXc29U/Zb8d3gijSay0+0iGy3tg/wDrHJ5MnGT5jcnJ PtxWtp/7DVxKS2ueMILdjy32dRyB9R27UX/lv2KtDeTb15jv/CX7PuhaM4ez1mV7gBoGunUfdlBH yr7j2p1t8Bfh1Bk3eii7c/Ozyt/y0J9Knk/m9RfWF9iC/lRuDTPCtigW202yijHEES/wh/T/AHvr V6HxzpkHFnbW0Q6jYoGD78d6pQ7vzOeWIffyKmofGFV4M4x1Az0FYOo/H+OMf8fceOoXj+RrRJdE ccqndnM6r+0tEVOy9QHsoP3c1zDftaRIMfasnocd8+mKZDk+hj3/AO2HGMhJpM91ORg/Qiufn/a2 lOdquw/h56N78f1p8w+V9PQ5O8/aT1SVv9G830YJk8Eew7VmP8TfFMwJtbDUWj+8zrG/yqPU7fT3 rJ1Ubwwkt7PzIbXxP4luQxgMzoP3kkjcbEA/jUisr7TqcwBmvWIblH3dRn+H61Lm+z7DdJfaQ658 M3oIF5Kwz8nAyVYf3jitK38BIozJfyFgCw2DJDD0FS79GWkuxB4f+EviHVWl/wCEe0e8uY4vmvWU cqpzyEx0H0rv/BPwD1x0E9l4NtfENsG2XdkJMHenOCgHcf5zUzXr2OinFaXktuZHrmhfHbwBY/Jr 3wnk8P3I4jWS3LCTPcvt/hNeyeGfFnhu9UHw9rekTt1CR7VKEj/nmQOldSpLo7mE60/+XjfZHQXd 1cRKWmdgBwrDuT/dx6183fHXSIru8H9pwK0wQLcHukbE4DY9q05FbY5+e7VmeOXPhkWgxp0+xAdk MGM7i/ZSB3Ndpb/s4+MbiMnTtKtpZQvnGASAFS4OOo/lnFcr8zrhG+7t0R6p4a/aevtHgih+KngP VrN41+xXWowRl454F6eagXuvoSK52D4v+FvDl553w31g3ekT/vPEPhtlINhcPu+a0DcjBIP3QMcZ PbeKXRowrKXVX7M+hPCurfaYFmsZC6S5mDqclVViMED+79K0byGzuxt1jTrO8jPDRXCA5H1Iq2hR n/LLyPOdd/ZR8A3lxGLHTbnSJCHkubiwbG0R9NqNnox7Yr508e6Ff6bczJaa1PqkCHyre4ufvGPH Rjz9zp1pNPr6kzmnbmiurTOGutTtpR/pMUkbH92XH0PQYr0z4G694c0u7Z9Y1mO3+Q29lO4/jk9S PUe1TfsXTdtk+yPqSx1u0nUHStUtrlT/ABROPun1HvVy51IyDbeQRTp0aKVQQwx3zVuHdGUanZnm 2pfAPwNqlzN/anhxIgVUq9sdvkSOCMoq9814B4h+AGo6XerC+sxpbuSmi6jPws6E8CVz0KnAPIFY Sh2fmdCle3tF6k+u/s6/EHS8l9Djv4vvrcWbg7vrHjvXIN4lmhONRs5reX7vlzIQUk9mIqoVO/yC dJf8u3c1YPFkbD539j7cdz9K29K8YRW80cqKJXjO+BGP3lIxjcPUVpp09Tmi/wDNHqFj+1Tp0l3G 2o2t5YqFaC5dMsCWHqvuP7tegr458N6snzXGnajGR/qplGQD9R2rRrt6GUZtHFar+zd4OuWzptrN pcx+eO4tW4Qk9QprGn8C+P8ASwR4Y8bHUbbG17O5x93B43OD1HvSu1tr3Opyi/jS7XKml/tN69Zx hfEfhKaRE/cPcwZzHtJ++pHf6n2rU1r4w+DvEcHl3t49tMPnshMp3QTgceW5x1P0FO6fXzMZQktt UWPAvxakGbfX7yNp0/5Bl2Txe2w7F/VRVnxL4veyMzRBgrxmIN/00AIGR+NKLJl/dPn+JPm/eYHU sf8AaP8AjVS5kEboXDFAwMw/vxFuayb8jZeTO38feF7CzdG0RCtvIokbJ+5N7f7wrT8N6n4qihD6 X4mhaIZha0uGHyuDwCSO/wBaUXbbXoyHZ/F8jpR8aNWs1B8U+H1jj4Y3kL5Drkj7oHcg962rL4z6 Rc/8ed6oJ+aJJMglT6ZFapp7BOLW+vW5W1nxK18pjs4jIfvPPniF16EHHY1c0/QJpCDcs9xL91pC Ov0Fbpf5nj4mrf4TudJ+H2ADeKo7qp7/AIe9a9xr0FqMW4XgfIi9uP4jR6hSp/y+jOF1jxXJI2Z5 dx/5ZxjooPr9a5yfVb6X/j3E3oqRjrz7D1qG/wCb5HU10pJ+Z2Xhv4Y+L7rBK+TCf9Y82BlPYYr0 /Svg9bRj/iZ3BuT1ZAMAMKwbvsj1aULfG7v8jq7TSLaEYtLaOMdOB1/E1ZCVSXYcpdxdtLj2pkhj FGPSgQuBR9P/ANdABj/9VLz6/wD16ADNIRQMXNN3H1+lAhN2etLuoACR/jRgUALj1pMUAGP/AK9B NAxM0m70oEJuPejPvTANtJigBMj+goLf4GkMbn60n60xCF/X8Pam7h/nvQMaWphcds+tMQwv/n2p vmf59KAGmWoi/uPpTEMLjvSF8UgIi4ppc+3tQMaX9aj8z0oAYz+uKjLUAQyPn/PWoXb1oGRtN/8A WPvUJnPr9adgKepa1Haxs9yTsUb5QP4l9vrXyh8Zfj3e+IriO08ORyRW7MltcxryZrhn53fQdqTf +Qox7n1Lo3g6x0mCODSIFigjUQog/ilPUk/7TZqzJgdBSiVIrOR369R/+qoHQ9s59Kr1JsMOkTP9 xAO4JOOPqaxNU8QaTZ/8ft55sn8NtAMkf7xFSHojgvFUVhrTIbDwbDbSp8h1ac/M0fP3Rj1NWbfw gD/yFLrzmA8tV9AP7x9vrWD/AOnd/M6XL/n7bsiaYxxf8eqqD2I9P/r1WaZm+/IWPfNdEIdzCbGA kH5G9/wFXLfTpZf9VHvI/eOPRFHb6ClOn29Sac+/oivNpqj/AJYMB1z/AI1UbSo+sR2nqSO31rnj J/5nQ15eY+1+O2oeEwTaXC+TKRDcq0ZbfMM427RxkZ7friquq69eXx3zIAzfvmkH8Yb04710Nqxz +zd9LnonwH+Kz6fM0GuXZW2f99p0jcC2uu4dvRx7fWvZ/iR8MI9atWEWDKB9o0+ZccyKDxn/AGqJ x0JpTs/e9UfGM+h36My3CiORSYpl/wBpD3471I/hu5x8rEdyO/4D2rkcvI6nFfqRrZTD77HHX6fh U8WnOP48jovuKyb/AMjTlX6E4sWPUH1wO2PepFsB2z6H3pJ/5FfJE0emKOinPUkelWFt8dMnso9B 9ad+5DsPUuvZR7f41Ml238Ua/T/EU7+RKXmK10v8SD6+n4e9DxQP9xlz/EMdPp9aa8hMqMgXoP8A 9dRvGv8AEjHvn3q1FktimJcfMpPuPWkFoP7rH047+9HK+iFcBaMeiN9Mf1pRpzjpCSOw9T/+unyP r6iUuwv9nTZ5jB/vZ7Z9K2/DnhqeUSnAIRfMYeinPf8ACrVPz9Qb/wAiKyl8iRGj+8rCcZ7YP9RW d8RfD0F3dO9wCuAbyDaePmBPJx/hW8mEHv8AcczZ+HWYFm2OW+eP2T2GO9X10+ROiD/AUkv8iW/P 1LUd7fx/8e93LEPVexz6H1rQ0/4ia9A26LWrpucpC2MFR68d6uVTsvIlU11R6FZ/tFeIRGwAyWBj SQN9wt3HHavLPEnwp8MauWbxV4ZilnbLSX9v8rl37sQMHB9vxrlm10Omg2vhl/wTxvVf2NNTtWD/ AA/8UCRvv/Y58I0J5+6cEHH1ra8O6tq2lSiPx9qoy3G11x9nIB6PgDlsVSf8/wB5c4R3pxd+qPQ5 9OVsGCWKSMjzbeZCDhB6fSq1ynmDF3FFcrjam8DKKP7rY7Vlt8SJU0/hZyGr+CYzzptsZf4mg6FT /snFcFrer2tq4W4t7uBz8ssMiH5Dn+/jv/nrV2XcNei9RsiAg7WI7LgdDTAGUcfMe2e9Y+pS9PMv PcBl/X8BWW5B9PTFVLyITISue/P8I9qQqxPy49Cv1qfUP+HBYXUZQsO4f/dz39qzmaSQ8bWz82f7 2a6lt+JlOL7eSJ4gR/rAD2/3fpUjGNh82PTFSn3YcvkQ2VlZq2Zd7D7zoO2fSpnitpVJt32AHdsx 95eepI/wocu5Xy9TT0NrTOdy7uU2v3yPT2rU1fR0Xm2dW/vbe7c98VmmCff5mr4c8ShhtmyD1Yeq j/AV0slhDLjOCB0HoPc1z1Y9vU6qEjm9d+Hdvcc22VbqvsSD3xXnUmkTW7kXMbAdFOD8wz24p05d zarDsvIs/wBnzj/lxvfQYifr7/LVyHwxqb/8e+jalKevywv90e+3tVNruhrCz/kZe0HwlqMu/wAj T7khT9nmZ1x5cxHRiw6j861T4T1KFws2nXJcjMUSqSXI/uqoq4I5pR6OS7WINV+FnxJVGbTvAuuM B/Ebd/kVj3BT/wCvUL/C/wAfxJnUvB2swuB/pm6FgIiB/wAtCV4q+T07nZLCPrUh6HJvNrjEi3tb 0kcMUiY7MejBf4qdB4a8dXH/ACC9M1WUDuLdjyf7zbKSkuvKcjw7+0/I04vgN8YpebXwtqpHZ/LP 7zPqStdj4W+B/wAbAwGoeBTcKfl3yyIm1Md9x7fSr/7cFKhHpiIdzq/Efw11PS1UeMdLgsZHG6GI SK25ST1Kk9/wrzDWvgzq9xIB4c1+KEsQvlT42x7z183B4Woi/wCZPsHu9ZJ9TYuv2SbyzZB4i+O/ hSz3DzZSpz5A/wBpSB0/CmJ8Dfh9H/yF/wBqbT0OcMLe3LYj/wBkg9/wrRL+Sxm50/8An3W7i3Hg D4HQN++/aR8RXg6MbayYZ47EqarwWvwMaaNNM8a+N9WkZ0t7cSwhRNNJIANxYDito0pfaUO39akO sv8Al3SXz/pH6E3OkyuEE+lWigKqRRv1SNV43D2Fc1Z28QeXydPgjIbyHcfxD2H+1WckFJ6aM5TV pJ7zWYxGqbbeAzsD/BM7Y4HqBntxXdxSucl7vGfmwB1f/wDXUtlSX5JE0EDMOJSR/ER/Ws3WPCOn 3QxeBpMc4DHjP+7UsqL8vUyU+Gfh7HzaJbt2y/OSfr61swaaigBSwX7qg0tesmDfdImuNIsHjMc1 qWjIJuGHVnYHo3v/APrrwfxB8N9X0KYTaGGQdYVPIngB+7JRzPv6m0Ippp27xPVPB/xS07VYS7tF DIgxqNo5AImUfw5/v+1XfFccpsGkvZ9MW2m/ci2LDdLCwPBH8wDx3rOt5eqMcO9bTb0dj54utW3I V0W6lh2/KqbjhYUH8Jz6cVmvqEaMjw6pPJOuHBbrEy+hPpXm+0fR+p2tL7UfI+nPCvjOHVbZHik3 P/qbwf3LhRzke9aiQ8febHTB9RXr/wDDnm03/wDIkyR4/wBXhOxI/i+tI9sr/wCuY+4Hce4oNCVZ G7cD7qD2pjJICd0meyJ/dH1piQMUPEUgJ6yEevuajZ3xxn0B9aBjFt5D1f8A/VUjXAQ/PuH8Ab0Y +n0pAaFnChH+tZm6sG/hrMuJlkfESyYHLFv4m9j7UWBegLCy8u+49SfYeg9qq3M5ILRLv6iUt/yz AHYe9KxX/DHzb4s1ZppmL88lFB/h2muMvcf3iexx6+9Zv/gs6JPt6FSGMf1C+h96uKp9QP61o1/w DlT8iZDIByOOhHqP/r0saI33TtPRV+tTFmjj2NSz8U3MB+fcw6OCPug+ldtDp148HmRwyrbt+584 5Adznhj74ra3b0Mor/gGNDpMMefs0MSZPmS7R99j3JHrWfq5iPy20DvKfuBR2/8ArGmo9n5lKb6o 9psvg14jh0pHghF0206hPAeDAuOgLeg9Kyvh58YxawSQ6j4dGozyNt0myYZEdzMuMTH/AOvXVBf5 HNJO14Prdl74lfBvSNMFsn2SH7XJ+91a4A4EkjgYjT/Y5+vU0740fD7TNChhfQ7VIkEflzMOsl3u 6knuc/8A1q1X+Ztdtq/VOR1PgLxtplxZRPNcK9xtEV9IeolUdB7AV0H/AAnmnqDtUOc53N/dHoK5 Wv8AgHNTem3kfJ8epORwhz/CaeNWk/vOO5PqPY15/P5M7HH/ACHf2yx/jP8AscdB7mn/ANssfvFc 9T9BT5+6JcBBr6jG5lB+8OOgz60v9uIejJ67vU/SqU+7Bx8h41yNuoUHpx3pw1BP+ean09qSmiOV j/t0f8UfJ5x6UguYB0Q/7QH9K0v2E/P1Dz4exYDv74qQXkWP3c7gdD1/Sk/ULeSH/bVHSd+eGGfv D6Uouz3nB/hGR2PsRQreRN328xj28Z+/5DdsFB+vHeoTpNm3WwsG/iOY15H4Cnb0LTfVshPg7SW/ 1mjaY5PUMo4/EVSk+Fvh5vveGNNz/fAPK/nRr/Mx+0f8z7FaX4H+F3+94XtVPTKkj9D6VRb9njwk fvaJMp6Ao/XPuR3oXqzT2nlEpy/s1eGTjZbajEBwVV+5HcEdqhb9mXRhgJqeqxL95QvO1vYH1qlJ i5+8YjW/Z3j/AOXfxprKY4XeOg/2cU4/B/W4gfsPxCvR2WJk6DHY4PSpt5RFeP8AKxP+FV+MCAV+ I/zD5kDL3HqQtB8F/EGPlPGlrN28lgMPn+8MU7Lsh+705hE0X4mRtkXekTdljZgAPooFehfDPw9r l3JI/wAUHs9PsYlLy3FqC7XVww+VY4k5Jlbjjn+syS+yn2LhFdZPT3kZmq+BPi7rEn/Eq8BCz0w/ LZ6cZAplhXobifH8fBP5V2Phb9l3xlBG41DTtI0eQjZZzJIHaItnJZsdf60p/P8AzKp0kl+9qRu/ iGaX+wqyMTqnjuTceLgxKCSfZmHauu0X9kvwXpxD3F7eX0o/d+XMRtYH1Uf41E7vsWqkF/Dh5I6e 5+GXgtgg1TSlvEjy9lBJwsDSddqAD72Kt28vhKywdI8OaZasOBIijOD/ALXuKqMPN9jnliH9m3n5 kD/Fewjz9mjt0PRgoHI+lVrv45QoMrfxqPumMfwt+I71tZHDOq/tM5DUP2hbVc+dqCKfvYB659MV y+o/tXabH/qLxmPXYOcY9eKbf+RKl2MBP2qbZ2/eyykn5lhX1HqcVg6l+1OXYfZ43IHABP8AF75q JS7vyHr0Oauf2idRZsxQO2OxP8R9OKqz/G7xBcY+ziRW/gKdx/tNis3NdGVGm+r8ypJrHjK7/wBS bn0I7H65FUL7QvEMY/4mc8iZ+cbm6ge/sKSk+i8zT2a+013IIfB9xMu77crL97GT2HrVjTvAqsAz 3Uinp07j0OKht9PQ0jFdF5kGt+CY4ju/tEgdHVxyQPQj/CtfRPgZ4hu7N7mz8Oyz2aZ8yQdXhB5P l+i/nVNd/QcI3vy9NWexfDD41eCtPhX+0PhdLbAYS71lIy4MhzzKmDjcPoOPevddG+PPhHUMJ4Y1 nTcMCs6OoUomOjRuB1reFNdCq1af2m7dLdiXUvgD4Kv1IvPCdk27Kyz2x2l93rs9c/414z8Qf2Hf D1vG7+GNYv7Qxg3c9vLgqjjpsPqx9jVOn/mYOvpql3PCrmLV7fm48mcf8syP4h75qF/Gk0ZUx2ki jpcFlPyjB+6cVgtN0HK+j8zqdA+NVzZsTpOqTWTkeVMFODJET0k49a6LwX8WrvR5zJpFySGPmanY k/JdEnuo6c+ldCa6JGc0+t+x7DaftX6FfyA+LNABjA8qKJxvCbuvyEd6fc/DH4P60QdNitNOuD88 c9mxRkJP9w8cE+lacv8AK/II1n9pXK938FfGumvEngD4oSXaNumt9O1HbiMwjPzy4PBAx2rx/wAV +PfEDXMh8Y6dG9zn7Pe3NsfldoRj90qjtj2qJS/mQmo/8uvWwvgnXPD9xew/8JBfJb2it5l80oOF cDjzcDpux6+/FfT3hfX9Nu2mfT9WgnDMqxMhH7yFF4wB2/AVEV2NnUsldPqzqJNQU5WfbInRoZAC GGPQ+tcZ4o+D3gq/jf7f4Rs0mILLd2/ysr4PPy/4U3AFUf2WeK+KfhR4q8KRxzfD7xfqJsm4vLbA P2Ny38ScjBH1rs7H4sfFe2jV7vw5pviSzI82K7tWwxiI6sFH9Krn6OPoTKkn8MrD7L9sbSEmH/CQ 6LqukyhSogmQ/vHP91sevHT8RXiPibX1u2Zo5y+9jMSP7rHuPpWsn/K/I5nBp/vPQi8GWUMmpQJL GVGHdt3eRUOOnvXX/C/w9oU97PF4l0S2ufvC2Vx9142PTHqK51H/ADOyL2t5/od9e/s0eGA2fDep anor8shgbILn1U+hqsmi/E7S/wDkEeI7TXIQP9Vc4DBVPYEenuavnfa4pKL+JWeyZSh/aY1CwnJ8 Z+ELq3Zl8t/JJIwvcHHb/OK3b/4m+BvEcLRahqRizzZtMuGtLnsYmf0/Krsuj8zFxa81tci8C/Fa +0+Q2niDVEuCvOg6qG4ubfsC/wDnHSn/ABDv7ElzqWm2t15iFPMdBmO4U8EOe/51lZdSnL+Rs8En 8HWcmfK3QnoGXsc98+lY1xp1xBIqpN5pb5IQ/H7wHu3uay9GW35eRoahoOr2Zxqmkzxd/MUZDEe4 FR2Xi6UMcDphkkP8WfQ47VpTqd/kTOn2sdbpfxSvIseVfSqeoGcgfnXV23xmuiALjypf4iw4yfw9 a6W+xz2LWlfEeNWkEyCKJz54jbndIRzkYPX9ai1jS/DN59+2hz0M8Iwc47jH9K55xNo1GcvL8NEX nQNWZXHzRib+Aj+61ZmqfEzVGHk65cq56QhgMsYz/eFTCfcdSK+yvUykUE9WB6H2zVS8s2KN5m5i Pmj2/wASHPQD0p+noK3f1Ol07Wk1K1CzyMZEGyNmHJZM4yD7VU0K5tF3Jqtr50bfeRv+WUwB6Efl Qn2ZMvQfregay67NFvJLq2JVhYTn/Vqh7yY5wP8A9Vdda+B4nIN5ZKrY/eIo4Jx/WnThr+JGKxKt ZdT1Lw14HlmA8uLy1/5aNj1967+00WzshncoP/PU9/oK6/Q8iEOr9UY2q+OC2fsrFF6NL3cf7I96 wLXw9q9+2NIsZm7GZsjI9iwrOc/67nq0qL6fN9kdnpH7M5bnxDfKv962QA5Hu/vXoOj/AA80awH/ ABLdKhQ9PNbkn86w1+0dsYpfw/mzaIJ60uz61oSKB7UmPrQIXB7f5FLtPrQMXFJj8KADA7UuP/rU CDH/ANakLAUDDcO1BOe1ADSRRuFAWFwPakoAXHtRgdvpQAY/woJ/z6UANz/n0oL+3tQA0n0NH+fr TEGR3/OjmkAZ96TcO1AxC3+FJu9RTAaW9KTPrQA04prMaBDC3pmo2kpiYzf+H9aazD+lMY0v6n6V GWFICPeP8KY0nuP/AK9IY0sDTSf/ANVADSw+naoy2O/4+lMCNmHf6Uwt68UCIHk/+tULy+oH19qA Kzy//WqFnP8AgKYjx/4+/GiPSrYw2jo1xJzdjvDD2xXAfAv9nS6vXiv9ZvGtI1f7TpdljJ1Apu+Y seg3dKzqdLGtLrdeR9Pyzs5JPf5j+NRuT3GPUnsD6mr9DIwNW13QYJFbUtTPmpkQ20OT5gfH3lX0 rE1P4v38mRoWjx265ys0vJK+y4qZP+Z+g0m9tPMxLy81C5A/tjVpmH/PFcDYAf7q+v1qklxp8P8A x52alv75/jA/vNisHJ9TSLX2F5XJ49WllHzER9yi+gz3x3qpMT3I/wA/4110kuiOeT7siJwPvn0C /wD16ElY+nuP/r1qkTNvoShV7L75966bwjEWlI7FHXHqdh6fSlKRpFA0e08hSOhyOuPaq+oyW2CR EgPU7R0x7VyyiWpvob138LtHfTY51vvMkYbrm0kAILsTxg+mPQ1wb+UOBj0K46fSs3B+XY29p5eR FLpUL/eiX1U+31rQ0zxBr2nn/iT+Ib2Benk7sgD2VgauNXuvUiUE/i9TJv8A7XO7Ndy+bI3zSSMA N7fQCs7zbmM/6sY65z/IYpNILPoxJdQZ/wDl0Geplz3/AN2lhsrg9I1A6Z/yKl0hKf8AN8i0umTD uPYipF0ab+KcKP7uO/tQoFOXYeulyY5mJ9PY1IumMespx1I9TV8iI5uw9dJA6u+erfQev0pDpcf8 Zb/ZI/qafKhXfQcNOgI4G8/3vQUptYF6x4HTAHX61pyom/ckWyjHRR65x60426DrEMdMHt9frUtr oUk+gog/uRr6AemaXyiOsaD3/wAaOZBy+YpIHUoPQCgMoHMifQdxU84OIwtGekoB7j2+teifC7Sk ljvRG4J8rgD0Ct1PvT5v8xqP+Z5xewEjoD/Dg9xz/Ki+f7UEDAElPs0uP7yk/wBKcl5+ZRlaVps1 vFtvrVgUJiSUHPnRgnB/Ae9Nm1eEfdgbPUmubm7pms49rdxv9pxOPkjAPc+oHrVUr6A/T3ok/wDM UTThuWUDaxPbJ9BVxNXB++o9DkdPwrNv/MPQVreCToV/vBv7pFU7zTFnQrewRXcJyrW86hhsI7ZH cVd+7NIvt6nnup/ALQ2bdoF/qHh65GZI5YMskkp7PE3qfc1kz3PjvSRnXNJi160Hy/2raHDJF6tA B6c4x6itb/z+iJlFPayf2X0ZsaL8RNF1EEWF6fMHyTWcqkMrAf7QH3c1oXdhbXKlbyGCcddsozsZ P7rEd6ya/wCASpP7SaezLUuj+GrhVXUtHhgIHlpLH3IHdgP4qy734A2UuTpGpbR9+ON8YHB/iA70 OH8rK9r/AM/F6M5i4+DWuwElbdbiPBLMh6Lj+7iuJntTGxDBgeQQexyf5U0hzS3gxjqQOSQOgHtT WtZSMW2C7fuoVHVpXPG0e5qfl5A0fVfiz4feHNB0Fv7Q0K0edYRbNcEfPNqc4P8AH67v0r5EtIXA zKAG+7t9D/8AWrpmvP0IjJtLmfmPlU9uvpUahscjn0Pp/wDXrlKQiOEOTGGxwQe4I702Zjnhdqn7 oHrTiiZeQuWU8ZB6/Q47VsW2sqwxPJtP3Uk7f8CGO9Uv+AK3+RN5UsByoIP3o2H8XPaui0fxw4QG Vmz3BGcDJ747iqcbr8AT7HQwaysy5guImP3tq9mH+NVpPiePDzpPHpkM1wDi3jmXILsDncMen4g8 jnFc8V/kdLlde7J9jbi/b++I9027w3c+H1P3jaNaKGRcfwyFeduK1bL/AIKIfFdgRd3elQyD5WRr dfmb6ADv712+0X/PuJxckvtVZ9meX3PirxRqEkknijX0aJ5GvrgxYBlupTksYExjcTxjjsOBXe/C /wCPFl4eu/Nksp9VVVaKFpyR5LN3iTHUADtURf8AMvUVRfyb9z0jxJ/wVohgU/ZPDIGSI+d2Y1z2 K461han/AMFHfEdwj+VZW8cbKybAf9XHKp+6cdhW8lH9DO0us33PKof2x/HdmmzQdQsbOLqcQqSW P+24P86xrz9sH4oSAg+PbmNT94QxoMD2O2s+ddace5u1/NKXcwrz9or4hzf8fHxJ8QsOiqJMYAHs P4RXP3vxG8UXH/H/AOMdbuD1BeU9B7j1qeb+WPmRKC6xT6mTJqt45BudRvJmHMbSuTsP+yTXR6N8 Wry34vB5sfRz3C/TFN/3mTb+VWO5gv8Aw/qqD7RBbzZ+RkkHJyD/ABEdwa5TxB+zpaLzoEUR7/ZZ P4f9xsVF+9zppyv8RwN94Qa2bF7pxhb+LK9Mf7WK3Pht4cin1XT1SMHN3ACo7xrMCcj8K3pPVW9D KqrdPM/WfVX3SNkgclQfTBriNIYnzTgZMm1fw9KhodPY8/h1/TrHWbuO/wBRWO6ZU8kOD+5iGMjd 0BYt3P4V6RFbqceU6MuOWHO9vr7CoNqm+vZNfcSlVA/c4Xvt9c1AkZP+sVdx6Y7KP8aliJGhijGZ efQ/7R9B70yOUPIFhikbjzXlPRTnpn2oFcsPdoWOVIA4DL/Ew9BUc8a3KFbmzadCMbD/AAe4b2pD T7M+f/ib8C57El7KMLC2TM0ZPA9CR6V5Zfy2sVvttPCkt7dg73vjIx+zqfVPVhj8j6iuOum17spI 9JW0aUfMp2XiXVLaLokBb90y4yQDn7hx2zWPoeoyMzLMzFgdkgb+IE1yU4+ZNTy9T6Q/ZuikaC6I 3bfOMcC+jKnb6fSvZEU9I8N2c/3TXrRe3oealvbuThhnABPdh/8AXoYbeAnX5mPpVor1fmSbfb8f SolAPUn6ntTEIyBB+6UZ/gY+p9qSJJT/AK2YN3PHTjtSD1GSBX4jilznBk7AUgwoxCpc/dwf6k+l DRX3GtbuEHzAZxgD1HvWfHCpYmZ9o+7GPr60hIbgE8Yx0z6//rrK163WOMthsDjy/ViO5pMuP/AP mnWmBkJwM5JY9iT6n6VzN+ij+JQe4FZWOiS7Idp+i3cxAs9Pu5vdY2wP+BAd66vTPgV4quv+PbQZ I+4aY4APvkf0rpUO5jyfzO3Q7HTf2SvEU3/H5d2dsO+Mn9Kd4l/ZH1C1Uf2VfR3kmDcXUUmF8uJQ eVc/Q0Th/KyoTj9v0PLxJLatt1KxkcDidX4JVf7p7j6HmvQviH8W9Fl0WCDwjqTW9w0oL2Z+/Y+U pPz+zn25qU+6JlBpq603/A8x8O/Ei6tBt8RJ5mPka6A5bA7qK9K8O+ILYEPp7wygjMbDnaGHeiL/ AMjnmv8ANM+j/h58WoNSxHcSJbRLGLVoJCP38hGCVBHYe5rxi/u9P0fUi1hLHPCkvmFo+RJGp7EE 9B7/AK12xf8AmZQejUvVHWfG3WEvVt5rSZcDnzB/CpOeo9Kx/iR46s9Z0fIuY2wEcMCOXjPPT15o TNKcvhb/AMDPD/CfxFOngqZD5Z+YqedjAfw5rXm+OaKciZvXCjv9a5eb/IHHfl9TyL/heV+v3Ibf HUHPVvfjtRJ+0LeDHn6TbP2O0nv9P8K415su3Z+Y6D9oBiPn0JAOpbdyT7Cr1v8AHa1f/WaOwPqD 1AqnbzJ5X3RLL8cNIXHn6fcqPufLzkn8Ksr8VNHb/ljcqPvcqcgewHpScexSb8uxMnxE0E/8vE6+ qsvRsdzU0Pjvw+zYTVAhxuUEdSKlL0GpP+Utx+JtGP3dWRT3BB5apf7V03P7rWY/7rH+6TSt3kPm 7xfYnjntjwus2x7Btw+Ye2fWpc5P7u+hz14I6/8A16duwuZdvIX7Nddp8HqGXHJp5gvRw+3+9jjk D1+lGvT1FzLuhpe7HVeOhGPv/T6U0XdwOsR9VAH9KLvq/M007jvt038ds3qje30p41Nx/wAs2A/i FVz+TJ5O1hP7flH/AD1x0x7e49qkXXH/AImfH3gT60/adl5Eun2t3JB4hk/ikcnoCe2P8KeviVv+ epPYgjrT5xOn2EHiZO8y+2B2FPPiWMfekT1AI6k/h3qlLzRCg+qfc2dAsLjUpNumwwO+C2Cwwqgf xE+gruE+BU8WP7Zv7K27Mmc4HuaqPkaSsre0+SItQ8FeELcf6Z4jWX+8y4+UnsppdP8AHvgqzwul 3Icj55PNP+scf3h7Cr5f5vkYuv8AyR9TTvf2mNOUjzdUwOjhf4QB/n0rmdZ/az06MHy9QEo/gz2P sB6UrenY53I4u8/bEix/o9xs/vbe/wCGO9crdftdzMwMFzI46TKB94H1bHapbEk+zM/Wv2rb0keW jhT8yAn/ABFYVx+0Hr04/wBHBCnkEHkE/hUORSpvq/MzR408UTf6tmjPUscfN+lSJ4X8UXOPtOtw wA/eJkHBOOoFK/r2NVSj9pt9SrrfwwurdN83ii0uWyFljgbLbfVsDoOPesjSfDFu5JMsqgfKZGB/ eE/3cj1qX6+ZpFL7EH2NfT/CkAybhSrZHlsD95eev4V1cPwN8N3B3Qa9cW+752gbaTFKfc+pojEb kuqXYhuPgbexAnSb+1u0+7iRgpI/3T/jVHRdT+xZS402SKQEpdFRkqV9f92tuTuiOb+VnU2msabc DEfiKOJhgeTMpGHP196j1j4cavqI26VrNiV/hLE5Yn/nmAOwroSXSxkkvtcxg3XwV8QaKUGq6xbB Hy0dqn3jsPJZSP4Sfx/Ok1K2vIkJsrlAw+4T/eJ9Md65bf5ms2v+Xbf8plOiXbIL22nkYHCxxgnz wOuVHoK+p/DX7T3gyBUilFzo20C2a0uYWCkH+8zDHJ9TzWltd12RWttI/wB5mbqF5b+HZvtPgO70 /UdElJfxR4eDA/ZpHHL2Y54PXHt09Oj034T+A/EEPnXPhqyfzCWS4t+GiCk9WXH3foKrl7X7mVOp /lYgT9m26sjnwD8SdW0vvFaXGHQKB05HQjFcb4y8Z/EXTreUeKbbTdStpWFrNqVqcNIIyesPbp7V qpd0Z1IxeyseNTa3a3LfPOYe3luOjemfc13Ph/TNL8zT0jNvcHc0mul+jTNJwCp/2PT8TWNl1N6c rb91c+gfEHwa8E6mD/bPgnTAfupcQKFZVHoU9Pyry3Wf2K/DrEnwt4k1DTT1it5AGVZD6n3qVB9P Qftl9tJ+Z5vrPwM8Z6cJGthbalbx/LcyQt8yj18kj09/wrmbXxfc7d09hdBOsrBD+6J9cCqVTv6E ezv/AA352Og0X4wXEZBstXnjYZCNk/KD7Grv9vxXGfOmMhPz+YD95m74x61pLU57WesbG54JtfDc MzHxRp0N9A48tsrnynAPb35rd074SeDrqaU6Brt/oWT5mlGI4CBvZ/f6fSoUX0fkkdPtVpeN1+pu yaV8TtHI/sbxbYeIIc7Y4LoKDsx0349Pekuf2m9YtNy+NfAN7ZtgxyXMGWVMjvgf1quf+dGTp/8A PmXyNjw38ePDF9CqXGqQgkGC8srkEbxk/eLeo9/xrBsfEV14YlBsr8z6HMxfarZOk3JJxsX0b9fr Q12JUv8An4munzN/4m6ha3lqHeKC7Uf6qVlGJI5c9G9q+bLvSVV/9FlaLvgdiT6H1rNrsO/cgj8T 6hYSxvbvHJICBb3B6xyE47+oNdNB46u9MvFl1e0kimOZZyBxOsoPQr/eP5Uc/f5lJdU/JI9R0n4/ 6RdEbr1oj1KyLjAP91sCttviBG3+omRlPEbA/eX/AOvWj8vUxu/tIzta1dplDFUkZCJArjO6I9fl 9xVDVvCfhi/G59KgTPziaHgqDnkECueXlfzOqMu78zmL34QwJzoWuMjj54kmA4P+w4FYGs/FfVF/ c+ISZcHZDMBnfs/2wO/+e1OMv5vUia/kXmVItWgf7ki564Pf6kiqGsabMw3IoJU+ZCyH7xPTH0qv QS8zs7H4hm6gH2pSH/1d6rfxuM9Vx6VhLPp8m5dQsoJAM+RKRyyH1NC8kRd3M260azUk2UsseeWB 5Bb2FVVgmj5WSNh1LA8ke49qhSfRjuuqLMHiCZT85b2Vh29q1rXxQrf6xWUdNp9/UitufuPl7epa m8RlBm2JPcJ6n6+9Zd5qSXgR7m0iWbkq46kEn7px6UuVdwSfT0KjOV5zt7YpVumB/eRE54bHv7e1 Sw/4dlqHxFbwN8rJn7iRsMeZn3xXQ2Pg+O9OUhmiU8SH/nr7oxHcVUIMxq1bLVeh6Xong7OBbwHP 3S3qPrXpGj/DKCMZ1IBu/lH0Hr9K6rdvQ8iKb1n8jZufEcUY2adAJX+7FCg4X/eIHam2/wAMNYv2 DakVgTpGW/hHsnvUTl/L8z2cPR61fkdRpnwX0WAg3kBvJByjvwAfdRXWxwogxBGka9AiDoKyUe52 yn/Kh2BRgetWZBtNKR/hQAo96Oe9ABmigAoJ/wA+9ABSbh70AGT65o470AJgUYoAQr7UbaAFCj+l FACE+woyBQITIpPMpjE3e34UpNAhKN3+NIYhHvSZpiEpC3pQMN1BP0/woAjLmkLUCGFqTdTAaze/ 1qM49KAGFfpTCfWmAxm//XUZJ70hEZP+FMx/9epLEz6U0k9gc9B707EnkfxO+N19aXdrb+DJI57u Rwt4owcx7uVcEenuK9YmUqfmIz0cj+9Vt+XmyYr/ACRA0g7/AE/GonakUQOfeoXY/wBKQMhc+h+t Uby9eNWMaF2AMqRj+Mop7UBbsfFaadd+LdYEetXUkMTSZvXYf8sEzwCfXpX2c8umWCKgeKztkHkW cQ/ghj/uoPWs0/8AJGk1bR/4mYWofF2FDjQrB5+7TyZGD/sqRXNahruqXWf7S1B1T/ngvAwP8PrV yl2+ZCj/AM/PkjMN3Y2/+ot2lbkMVXqfqR3qCTXLxv8AUxGLtgfw/Q47Vko9wlLs/IqNDdv94Fu5 B71LFYzkcqqjoB6n2FPk8yEall4fuWDHyzsXHnEfwE5+99arzqR0A+tdUP8AgESj/kQGM98Y+8R6 H3+tEY9Tz1NaSfYcY9xxbH3SD2we1dB4U1SO2lDTHamCk2B2dT/LNQ46fgNy7Iv30YOTbHevVD7f T6Vyk9xKGxLuAP3eOME+tYMo1rm6dF2o77P4oj2b6fWsaVVP31+p9DU1WXTXkQG0mJ/cSlf4kUdD j1yK1dHuIS6DWJRHGTsupgP9UhPU/wC7WKLa/lPXNQ/ZdjkTdoerrMCPMhjdQNwYfwN715Zq/hCa 0cpe25Rx8rA9/cN71Nn1N+ZNXivUxJtDU/dAH+fWq7adPH/qZT9B3B/Cto1O5jKI8anKn+tt1YdC c9vpip/7dt26Rjd/CrA8D6n1q3/dMfl6ETa0F6w8e3aga6Dj5dvoPT8feueUvU0gvP0JG1Unow9w O59zQbtzjOD2I9KyczWMf8y1CipyTt7E+9Ma5VgcD/aBPc1rGXchrsir9sc9X46AehpGcn+PnsR3 /OsGzW3kSCVG/wBacHsfU/8A16jezI6f72R3p38xrzXoQGDPTkdh/dPt9ad5JHTHrn/PrSv5iaEC nuB7n0r2f9nyyRzdBuQQsLn1Vga1iQ0ee67pogldfL+6zJj0AJ71yz3DI4weM5C+nB610yJmtfxN +6AccDGRuH+9zXM3FkM8gD19jXJI1jsaVr8PLw2jXBjjFqH/ALOUkjdJOB2T0FZD/j9faqXmK3Z+ THZI6Ofp70ouGHX86yIY9bkj7h+vuat294/fB9vVfYVVykuxJIY2HzgD/PrVWTSmXBt5HQ9Qyfxf X8aa8ik+/oYmqeDdPuudY0e3lbot1GNroT6Oo7VQ0rwjDZZMmoXF1FnItnGGt4+fuOBzt/l71Y5P vr0Rn6v4jtoHx5D+WeY5T2kJPUAdhWDeeKNQjJ/sbU/s7A73QjIdQOjLj+L8KmL/AOCE43+JGpoP 7QUgGPEVmqEHb9ri6Ome0YH8X14rG8faNZTr9o8P3UcsBOy9xx5dyQxxsPOSOa6mv5fRnFBtaS9I s1PBmheG9dhPnac8FwmILmaEkeYSDzsPr+X4V0Phb9ne1jvoXbUGnt42+2yWzL94xZxzjsay5ddH /eOiFR2/eR/upmp+1P8AEVWS3t7YuxfOqahGB9xVztDKPXrXzo9u6YBicdiGB5P5VdX/AIIRi9El 05iNpGA+Yc9foPrSshPUD1yO4rlsaW7lXaxP3vYL9KmQAjkD1B/wqovsZteYhHHIHoQe4o2L/CAB 1wfSqkv8xmtp2vKpAv4zJH91pB1jX2GO31rRu5o7Y/6M8csbfPbuv8Sknrx6UX7L1D19YmM0Dvk2 UvlvyQo75Pbj1qC41jU5023chlCnMaScEMM9TilLz9SkjT0vULeBT5livnkYjI42AZ71Wmv5ZSTI xPqvox96zS/4BXN39C/pQATlB6jPY5NSyuFV8AdNrP8A3QwPQVo/UiKPOPFrEqoHBLAIfVcnrXYC MKgAx0wT64H9av1I6/gZEzZ6Djpz3P096pzDHOPwHY0DKrr7n1IHaoHjPYk/X0ov5EkTIecDjtnt +NRs2O3sfY/Sr9PUXr6ixXLR8wyMh7Edq7DRPjRfQYF+TMn3WkHXHumKfqS/7rO8ttY0PVkxMsMm flSNx0b/AHsetaHw3+CVtZazYypfrFaxzreXySf8s0XP3WHZTU0nZq/qaOd079rI+/764RyzROro d00cinhlOeQa5bw3GvGWGDJ5jv6Lu7Z9K0l5mdOWnunz/wCLL6x1DULp7PbI3mtCJ8D544umGHYD 3qxonxG1rSz/AKNcGSHO77NJ0C/7P1Fc3N39DuqK+/oj0nw58WtI1EhNssF0fmWB88hT/C9desGM 9WPTcfT2rVr/ADOZN/aRFOqdZXkAH3VUZ6eiikkunGFtbFiWGZZicYQev1qLlltRFCPnUbiMqvcr 7CuX8S+N7mxUkW8gGPMk2H/VxH09zSZUUZVz4ue+hUX8RMZG6SFh97cP4gP8a+avFCb5nXRL6aEB jFKUHVQ3Qgj2qfuNYPSzXmNOt+Wo/tWI3CgCNCR9wD0I9KzLQ6QspeKWYKRvMYH3ZAeMk+g9KwnT /kQKfSXoj6V+BGkrBYMVA2tK87SjrI5I6j2r1BZCp/hA6tn+/XSjn727uwokD/6y5O3rkD73Pt61 LHKjfcyccH61YP0F8s/3h/hToZIVOMFm6nPTFAPyKd9NE59W6Ko6Kfw9KfHaMFwjsp6CQfwk/X0p D9RjXESdZH2D92zNx5j/AOyvuamS+3Y8hW9WLDsD2pifkaSlsfKR6FvSsq5CE/Pk4+9ju3vRbshp kcSqR8scjHtweQPU0zVvDN5fR7Ii0Ckh3lXqAhq+Xv6gn/mc3b/sp6RnN9LdTnqylsAA+uK6Wx/Z +8L22NuhWII5DMMn8zVpdkXKs+ljo4tC0u24higUeiADA9gKrap400GwXdql3HEp4hjJ5mc9o4x1 JpnO5f8AAOYb4rXF7n+yLdNNt/urezf6yWMdSkJ6e1cja67btNI2o6veXw3eUkMh4VE/+KP0pv8A 4IvX0IvGWu6JqkYTULK3UAbbedBhoVxxsYeh/CvCdV+DU4YyW6faY1O77Qp5Td/eQVz1F2Z10qnS b9Dn7uFT9+NWHTPv7Gm+G/NiuYhBfyQoziO4A6LGx5wpqIf8BiqL+ZeZ7Nr0cVs22CdpE/5YzdC3 1/GuXudQg/5ZlVx1Gf4//rVopP8AUhWFvfiFJJCY5LkPH94pnOzjtXFxwNDEY9LS6dHO+RWzhQ3u fU03Ls/UIw7/AOJGVL4ZnU/v5kVugTPKge3tV208AF1Be/Dg/wAQ7fUVKRc2eNzWUYHyYHdh6MKl gtYnHylgOhB7isP6RCfoI+nKP9XK2OvHb8KX7E648u5f1YcfL+JHept39WDfYnl0uYjIuQR/EuP5 mphbXp/1bRnuQT6UrFepD5l3kgKhPUkn+VQ+TcBgWijYj0Pcim12Gi8NVugObIKehwe3196Qa25H /Hrx/d9D/wDWoS7MJJ9Ld2UhKNxJhOD90Y+7t9PrTnuZCf3c86r/ABoM/wCeKfM+jEo915slGtXA B8u9ugeiNk8AelSWfivUIhxql2T/ABbj1GfX2p+pHKusS83xH1bA8jWblSOMn+97A1LD8XPEKlc6 7Nj7sgIHOaVvJC5fXsjZX4v6qp51ZW/hCso6/X3qaP4zav8AxXNqe2Co5B9c1HN5ITh5vsQr8etT DES2NhIB9x8Yzz2wO9XR8dbgAb9Gs3/2Ax+Un3Na3QlF9JPsSP8AtAon+t8OK3QsVf09OO9alv8A F60kXcdFO04bYG5APqfapsurYJS/mRL/AMLS0w/f0qRT94uO4HsKbJ8WfDxIE63SMfuIU7D/AGsf 4Ukl09Rpy8uxt6X8c7fTwx8PIWmIxulGNu3pj61w2vfHzxbqDMb/AFoIfuosQ+7EPTI7VqpdrHNW i2/3l+yMN7q7mwdXv76dPSNu3+1j1rdsoPDikGz0G6abHlrcTS42O3cqf7n61N/579maRT+xGBWT 4W39wctq8MaE/IGkHyqTxitFP2eC+N+uWznrgMOB+XasW39m5olH7V/Mpar8D7u1ybG3t7scHcHG SPcewqhP4YhiIBgMB+9LuH+sXPb6mrjHvcJNfZa7Gpa6Do1zJtvbC0cn5rRemcCtqf4L2wGbSOSF ujIhzs+i47VDT6X7m0JrqkZ8fgDVrNs2kcN6PvGKXOH9mAHer58QNDxqngSOHPDPEC24D1A9a2jL u2ZSh/z7ZdtPHGjMf3en24boI2XGR/tBh2q9JqunzAiXSIGH3lxj5Ux0JA7U5Ptdgpd3boZ0/hnR 5ATFaXMGeCqN1B9FI7GsWHwjPaD/AIlsyXKDlYp/7vPVh6VKn/L8ynT72JY/EUKkDU/C4B6ieFjy B61PcXnhydS2lXk1pcjgRuDibHYs3qavmv8AaZhKDW8bi2PhPRL1P+JmjRy/xsD95h/cbHaug0L4 MwRkyad4nvNLjjxLLqQx+4bHG0HGT+NV6fI0Ul9qK7s4uW/v7m5ke1uX1NVJjh1OUkG4Qj+FGH5f yqG81wHAvrZ4SOZOOC2e5FJS/wAjmUPL+9Y7jwD4k0mC9tWS5WOONWW8eTjNzKD1z6cDPP4V9HPY 6XqaYvrHTtQQ/MdwU5X0DCrUP8zWdXu2jldU/Ze8GS7jZ2F5pLkZke0bhyOf9U3vXn9x4Y8Z+FIf N8F66moWpLf2ppsq5NqiZ+Z1xjBHpV/MznJPp80dTon7SXifyFk1b4fNdWxG5r6wcsVPPLRAHuPW uM8b/HC21ONUsmuIMMbqe3lBHzEYx83p9BWkZrzMalOXSSa6nmWoqvkPugWQ5D7cclMnofpXY+Lv BuhxR2UmlJJaRyKE1GaA/wDLbP3iD6HJ/wA4rnt5nSmuq6qJ6Jb/AA28VWQ3eEPiM0i482CxvBkE Y6ebg9R7Co2+LvjPT1P/AAkvg2O7jzvkvbFicr/sxAd6qNT+deZEqa/5du3Vkmi/tG6I0rm8nltB JhmgnUjYyjBzkd/rVK+1SDSZWn8FyWV/Yv8ANrulZBCq+cmBD6cHH4jpSkvTuJNr4k+1xfE/hTwX qdq0ttpNokmBJHcwDBWQ/wB7HrXjL+DGj/48tSlUDlEbnKj3x2qPRlOX8xXXWdRgYAYkzxGc/eGf cVrN4svICRqdjPEB8pDqRlifp2qo1P5l5i9n/K/Q6DSviq648m+kjPVOfu4/u5rs7T4z37KfNvBO P4kfB3DHc47itfkYowb258MXcjf2to0QLYL+SMGN1/ugev5VTu/h9pxUjQfEVzEp+9Z3HIAPZT9f as5Ra+F+Rvzr/l5EybvWfEGnReVc3RuLMndCEbOwg9h15rnxrMcp5Yg+jAjv2zQn3Ikv5Rl/os06 NiJXA/eKFPKsB2HvWqPFbX1sovFkFxGPJbK/6xFz0JrNr/gF/wDDkdnq+nTptv7CESDhZ1HLq395 vamfZhFj+zNSlt8cIo5wfce9S3/KyX5r1L8XxK1iDi4WO4UZjds9VP8A9b3qSy+I0P3S7x5+aNG/ hGfX2p8xKXZ+Rr22vySf6mXcMHcoP3gPasbUrx2x5seHOXKsOVUGlFd15lN9peRg3GoQltrQ5/jD 44A+vvT4r6aMjyLh0HdfX8farC3deRPF42mhYjULKJ1zjeDjzQe+AO9aaX3h26+/cXFhL0DqMjJP 8WaV/wCUXrqR3Pgy55Ol6hb3y9VOcFV91NYdzFewki7t5U92B6j3x2rO/f5lKK6P5EI1Zh/rGJ9D 6D6Vr2V6G6AntJ9f/wBVD9BrzNQ3lsrfvYpFHK7h/Dn1GO1Uru6njP7i1N3GcFJkHNrGOoMeOcmt eYq3p5FbUNR0m5AEMztKGBSCTKlJV67if7p/P0rVTTpZDtt/nfoSo/8AZsVaiROVr83odzofwnQk G/jWV+qxkAhG/LtXrfh/4ZSy4wmyPoWP8I9hXZHToeBKTb0bPTtG8DLAMWduB2eQjqfY1tr4E8z/ AI+rg7erxr/EB/tVm5dj16NH+deiNmw8O2dsMWVpGncv3Y+7GroT6VFjrbF2D/Pel2/WmIAvrRso ANv/ANajaKAF/wA5oxQAUUABPvRmgAIox/8AroATaKTNACc0v40AGaTcaAEz6/8A66Cx7f5FACbh /n1pCaYhP/1H60baAAf/AKqM/wCfekADP+NIWpgG6k3e1AxCf8KaTQJiE+3uKaWoGNLUm70/GmhD cn/63rTfzpDQ1iPT8aaXoEMOO+fWmEimBGW96idj2NAEZ/8Arim59cUWC5G0wHU/QVynxC8ZXmm2 cklgyow/dtI2PlRlP3c+tDfZDS7vyPlL4Eavc6l4giOtXsrMvmXQGM75xG2A5x/noK+0ZZck5Pv9 cmlzehrUjtb1ImI/z6VGzgd/xpmBE3t9c1GUY9OfSgoivHhhUG4uYEz8zbmHyD3FclffFHSoTi08 29kHAEYOB9Xo9fUlP+RHm2q6BHd3DSx6XaacT/rDFjMjDuz4H3utWnaBf9c7TH7u5jnGPQmudP8A l9Tok/5t9iKTWnz+5wn90j+H/wDVTftAz+9k3nq4Pqa1Vjmd/tC/2hbjr17D0PvUo1aEdCvvT5ux Fn2Gf2xGOg3f0xUX/CSRDojZ7HHQilzDcWeu/CLR01KyvMoQW/0SBj3kSMnj6NXmdzYyR5EyEMpM Uinsy+9aQf8AmataFRm46DPf61CCfTjrxW9u5zyfZkuwEcDJ/wA9TWzpVhnbvKgEiHd6Fz3z6fWl N/5GkF39S7qwisJzHqOYpgcQr3ZffHpTbe5gncBLCS9YcrEinIVe/wAv92uSL7/M19PRM1NS+Hmr zZax0WeOH7qh+qt6cjsPb8K424tihIlX5ujoexHrWc2dDj5rzIxGOMHp8qj6+1OCg53qMdD759qi 5h6+h7l8HPiGZk8jUJCXUZ05z/y1g9B/uf8A6qt/Ff4decnmWikyL/r1H8cWPX2raYUez9Dwhg49 MdQPx7ihpAfvKPTj+v1rBf8AANBrW0TjgD0Gew+tVp9HU9UPPf1FVFjv/kVH0Zl/1TH6elV5LGXu oPYEev0rXmX2kTKPYjyVzlSOxx/hV6xO88A/3yB22isXS7Cc+6Eub/PVi3YD057Vof2NNACb2N42 I/dow/hyfWo6/iWloUNo7kD0+v8A9egAf3sd6wbN4x7jWUnr9Vq1bPKR/qyw9T/D+FVDy9BTRMYE bopU9/fP+FVpLfHTnvkd6qwrkW3+8CB6egr2/wDZ7hA+0EdMrFn6D/69aUzKRgfEzRPKu5SqDDHz wfZhXlF7CA3bPb2Brplt+Ap7m5YS7053cfpj2rI1NACSq8/fCjufeuaSHDz9DtfE2t2kem2VvYuC 2DqmtYPS8cnG7HuT6+lefuUB+c/T2qp/8AUf+CM3R4+U57A+1O+Q9Bk9/wD9dYWL0/Qb5OPu89iP Q1Zijbtgf0NNCQTgY5IOePzqr5ki/wCrcgDqo9KbH6+pKupqB+9Qt2GOw+lIYYH/AIh6bT2pXfYE zOvfCMEv3oUYdPm5zn/Gs+f4caLIPlsmspMbJJ4uRIQf+WiN6j3rb5mik+lvM5XVfgLqHJ0Vo71P vER9RnP3lI71wt74durYsLm0lhf7kysDyfbiri39oHFP4PmjtPhH8dbfww0q6n4Xi1i1n2m8Rjh7 Ros8wtg9QTxx/KvSrn9qPwlDNu8N2d1ArKdvmKcWxJ6ZIPQHHTHriuiMerfk0edKUtVZd15Hlfi3 x5B4m1aFo1lSDC2bNLwWMWc4X/ar1LUtI06fIu9LtHH+rVSo+6voQO1TVRvTm+r6WOT1D4MaDcA+ Sk1o3QOmCB7bSK5W/wDgHfJ/yDdQS57qpwCPqCK5pR7HWqif8ReVzk9Q8AarbH/S9MmQc4kwfm/I dqySrL1QjHGCO/0PrUJ+XoJw7O/YdKnoMg849KZt9iD/ADFayOX1XoOC+q8dwfWujXwZcNpr3ESH asv9nKuO7Kec+5/yaIL/ADNP+GRRttGl2qyTRuOjQL1Rx/eHuK2v7Lsr5cweRb3A+QrjG5x68d6z t2L5vL+6znrmwmiJE6gOPkb2I96jVT6D0PuaT/4YXp6I2rBMLwF9Px+tR3YAR95A52qv95Of5VX/ AAwI8/1qxlmZPJTcAd8jH+AA9q6qWbcvysD3x6CquRYzJEPp9fxqtLtHc4+9z3/Gn/wwFR1H972x 6mq0qFfvD2PsaP8AhiX5fMqmbP8AqkY92OP60wsc/MhHY1SJsNI98jpijJHT6fUVXoIkt7yaI5tp GRvVa9k+Ct/r3iK9S0g8ppGVrpbmQ8RxwKfvjH8WPp607f5kenzPoea68ceFmKXAkFvzGQ53JJD/ ANMpADjI9xXVeGvj7onkSfbpls5FjknzIeJHKH/V++az5v5jqq0ba0tnqeI+GNMt7dSbO6aZXY3h lb+NpT2NO1XXtQFxGttbBoCCb64/uuOgH1/z75S8zaTve2n2kX/DnxLttNvh9ssJpkCFknUcNK/Y cdvr+VerW37UXh+Xi5NxbnoTsJCr7nFbxXZ+RzzjL7KOhtPjH4UmA8rxJag/3ZMgn862ItZ0+4bc uuwMoG2C2VhgRj6dSfrQ4MhVP54vsXbSyec72G49Io8jKRD/AGR/drz34q6gyRSBuH+SDjsGYcfj WU15G9Gavo0aNpGiRrutQflGc9SoHU/7orwXV9IgUb2UCSRnmCHqIFc4/P8AKpt29DSk9P68zEuL ZJAen90A+9c5qGkiIH5AM/Kj+haqCf8AwT6K8DfGPQ4dN8vSpBb3scbA2zj/AI+boA/MjHruP+OK 7fwZr013bRve5kkYD7Q56STEfwj0Faf0jjg/LrY6uGPHLgHvj0A9KUo7cxuVHUIP4h71Jvf/ACDy lI/0kkd2A/iI9qJL9lGIbcsf7393PqfaqsIcuxfuwkt3wOpPvT1tZ2xtt3z/AHT/ABU0gv3LA8NX knNxCm7OYCf+WSkdl9hVqDwTIP8AW3OD1yPX/ZFVYV/Msjw7aoP390fUrn72aSSLSY+si56gD19z 71SM3LsipJ4o02L7gU+5/wAKz7n4oW6/cdFHXA707EtmNd/GGMdJV9cjvisK6+NA/wCehPoaBWOO 8Q/tAXMKn7GFaU/LECeh9x7V5wPFd3K5l1u/E03SFXPFuG/55p9Paoc+xfL5+RYuvjO6D/SNRBHq o6N/sgVy938VZomJhklaNvnDY+7I3+z71LkVGHe/crS+PNVmx5SDHUHPXH4VJpvjDxDA+YZJdp+S aM9GQ+v0rPmL9n3aLcyyXBzJpwhB5kBP3yfVfesV/DM0c6yWuQyfPDGehb61LXZM3vfSb8jUm1a8 u3P9qaxcx9liA4H+7irdv4cs17tN33uerfT2rWKOeTtsvJFtbCBP9VCoPRvY5/rU6k/TuQP6Vvy+ RDk+rMXXdN3ANEDuH+tUD7yH1+lR6VejoWIB+Zcdz9Kxb1NZLT8Dxr+yov4QD6ew+vtTDYouf3jA dgex9q50OREmneYMh2A7nP8AdP8AWp5NNTHEzHsDSsURsGUf6xiP8PanJJN/DOMfxA+pp2M2TJpz yH5JlH94/wB4+31qvKkkfZW9vf3NItpdPUl+3TsOUXH8JHfH+FQiR0/hB9fbPtTS8gT7vyCG/kJI EDfQ9/8A9VOupp5OI4mX/Z/u49aXKLXuJ55QfNEpPQsR1x7063uov44xnvx90/WiwNkc4iz8gP8A tEjp9BTRJbdHVXA4JI+99KB3GSxQZ+QL7jHQmiCG3YkSkeoHqRSSH8ixLa2wx5RI/vA9jnsahls0 x98+oH+NJIPkab+HYuNk7H1/2SfT6VKunSIMLcsOysfSl/w4m1+hDILlDgXBb/bGPmH5VJN4flfG 65U4+dM9z+HpQ/QaXdsd9g1CP7s8bJzhT6/WsoO7g4wp7MP4hnuKPQia7Fy21m5h4kjOOocdDjuK 24NQt5vuBSx/1oHcn0+tXGXcxX/DGfrOkzSY+yRHg5YqeQD6fjWOTPEf3iXPpnnj8q0s+j8y4tfa S7FpdauAOLi6TuCCfmHtVq28Qbx/pV7cOf7rg8Y9TjvWTv1sVy+S7DmuLInIuH3D7rHPyn2FXf8A hPtSsyDpOrSuCcYboFx3yO9JS7+gpR/u+SNOP48aqf8Aj5nIPTegHP4Y7Vah+Nmpn/UanEw+6UlX 7wH+0B2NaadkYcr7sW48V3lwv+laVpt2DxIMDI+mPasW4vJU/wCPa3a3YcFVPBHvmk/Js0SXWRJp /wASNTjfaI0nX1c+3bjsK6aD4r25H+maOqH7rOvRz7AUrLqhtNfCyY/EPT2/1elCUdQqnpj0zVS4 +IGgtkXvh989SWX7w9iB2p+z/lbEqj8vMsaR4a07VY5X0CabTo4/31xeSH5d+DhVVupcj/HisGXx pq80Pl314bu0B8xYTxvZT/EQM/Nj1q1527Iiquj/AMTNK38bxFAE0p4Ix/GgznHqMd6qSXcUisYr tN5/1ake/elBLv5ine/vHU6hoejSfY3a0hkQj7PrUC9Q+48uR/eHv9DXdn4K6RGd3hfxJq+kydY1 jbIBHqDWl+3zKlJdYrexaj1T4j2P+r1yw1uEAnEuAxAHqB3NZunftC6jZEr4m8KXUIOWkCjIZG67 lx39qpzXUydL/n0/KxkWPxdstKmLeF9QmaxkO7UtMZcfYpm7xKw9/wAayPiVr1lqEwa1iib5QjSg DLM2epXuM1Nv+AJ3009UcV9lCr+4uJB2KvzmtTT9V1W7iKSTxzRx/vYrQ4BU4P3D/n9KzTNOXv6n WaF+0FNCoXUNMkGB5TyLk9P72B2rorT4z2M4xFeFM8srf3vTmn6GMr9fUTVtT0y8j/0+wtZ2B81Z XXllAPAYDuPeuVl8LaA2TprTWLHlkj5AJ7FT/jWWvS5vz91cxt2o2iMLK5E0JP76POPMbP8Adx/W qi+I4Mf6WksLdJMjO38vStIy7ohR7FW70t5hnTriKR1/e24VsbsegPvXQxeMb2eHGr2shONssbDO Hx/Spt/kVbtI5yZ9L6XFnGnqycfN6ke5qq8oi5s7xvXyyPu/RqFLs/UT/vR8x0HiyZWzncem71/D FXm8ZCVh5zsgHO3HG4++K1U/MylH/MJdXjTj7UGLZlRPUew9qoXJct8yoydGJ7k0n5lx/wCCRssy f8e80kZ6gg9BU7+ONQt/9dDBcocABx1T3IHaoXn6FNefkaMHifwxOMarplzZt1N3bnIDf7jD+tMn 8P2rH/iS6/Fc/wASCUbT06HPpWTj2fmym/515GRc2l9F/wAfEL/7y88n0I9Kq/2oRxMuOdvTr+OO 9Izt/L8y3CCBm1naI/fGzuB/eqrN4iuZH3XM8k5x5abj/CP8/wCFaKXf0E1/wCddeQ/fUL6A/wCN SfbwTxj3P4VafmV6+ojTxzjE0mDyI29fY/jWZMxjPz7uOAx7fjUsa8i3Z6jOp/0ed0H8P4Vur45v I/8Aj5tZriL7rOFJx9QAaSf83qTbt6ktpqPhu9JH2mC3l6GN+N0hHf6/StGTwdcQrm2lSTumDkMP YrVSj2HGf8yMmTxEY3xewSIfugEHqPfFbdj4oijYGORQfvJj+97AU2v8h/8ADnRXnw0ttaZHudIS Aj55Zoxj7QQe4Feg+G/g9d5xpWmu3csyng/7xHeuyCtv6nmVJSlpD0bPc/C/wGMAB1YqrfeMQ52n 6139p4Ztoh8kQ9j6fhUuXc7aVFLb5mgsIHQAew7U8L6UG4vNG31oANp9qXFAgxRmgYu0UmPWgABo oAP84ozQIQH2pN3qfpQMXdSZ/wABQIP84ooATdS8CgYmfX6Um760CE3elIW//VTATHsPWgigAx6U Z9qADB/wHpTc/wD66Qxc+lJn/A0wEzSbjQA0k+n/ANakz7UCELDsaaZPb2pgGPam4/x/GkAhGP8A CmE0wGk01j6UAyMtTSR/ntQBGwP+e9RNz/X6UCI3YCoHf8u1MCIqPSvnL9rH4ofZo4re1lYMcz3o T0cHgge1DY0dn+zn8LYdK0uOW7sYhf3Gb6S5YfNDZHIUKx/vLzXq+P8A9VZwX+ZtWf8AkhojY/cB PtWbq9xZIhGo38cCkfM6nlP90f7NXbsc7kczL8YtLgUDT7ee+cDAcggE+7Y71zGo/ELXrr712LWP +5BjIU/7RHapch8re+hX034fyXfOwzdpZXP3s+gNdNaeALSIkShXPqv8LD1rllJvdnUrLZIs6t8O tLvY9t4skIA/c3EJx5cgHB4968k1jwfq+jkvd2/9p2BOwXCZzEDnkqBUJ23emxpZP13izd0zwzpm rj/ilb9JW4NxaTEK0L46HPXBrO1HwnqNm2Lu2dMcZUZBwf7wHb61b8/UzST6WfVFVrFiOcg9QfQV XMLJ1BZf731q/Qya7jFuAT0A9vQ0/A/u+xI7Gs16k+p7v8C77y7WYKxz5u5wf4QyD+lY/wAQvCs8 t3IdL02Vo9v2u6kQHAk5zzj0/wATXUmVBeZ53tB6fQ57Ypkcajrn0x612N/5nOl5eQ9UJ6E+m3/6 1bzo0cPy5U8MrejZPf2NYTfc1S7Frw/4snt5xLPbQ3zgGGY3Iz8rrjqfbj6U7w38UH0K4kktdPS5 jcFZYQceUC2cIR6fSoVuvoyGuz84mvqP7TWoXYzNp6Qqv760h3H539JQP7tcFqHiCW5kZ7lRubMk uO7sT0+lZ1LfZHCL+0yoJh/ED+HanibPv6e1YM0saGk69NaSK9pIwdCHUD/lovow9xX1Lo3iO01W 3V4GWSNhsnA7PjkH6Gtof8EhvX8DwLx/4Ck0+c+XH+4b95aOP4RzwPpXGup/z6VidU1/mIGI6Af/ AFqeJSPuk+o9qbZiKZc/eA/D/PehVhP3wV9OOhPtSZdyN9JRv9Xtb1PtVVtHK58slT03rVRkOxNp N/PYyq8VvDcMvzJFMOC2O+PSruv+OrrVJC+vRhnPOU6KFHGAB2FaaMycX9l+RmfaLRvu7fX6U8TQ AfcX0/CsJQL9p/kx/wBvjXpGQeucdB/9ahdQHYEdsAdRUf8ADFX/AMxXus/eTPb/ACKaX/uoaB/8 OM2E9VyP4vxr3P4CRKsFxhefMGW9QV/pWtPzFN/5kXxg0wiVGQdV+b/aYeteF6zAqNwoHOR7VuEn /kX9MmweTwegpNQtSfbHUgdVrnt/kNf8Ez+v/oIJ/uj3rNuYCT19vqtKowfl6Fcxnt16Bh2Ap4kY dCPc+hFY3IZagcnqAfWru1cfMB6n6iqS7FLzXmVJiv8ACDj0/u1WZPXA7H3x61LY/kMYH8aYV9R7 8+lNMPkTwXUi9+PT1qwHRh+8Xno4q7jX/DjDZH/ljLIvfKn7pHpUl1Osy7dasIL2HoFcfMqj0kA7 VqpfzIUV/I/M4bWvgfpU+W0C9Nox+VLKftuz92bHY+uK8z1v4fajZnF9p7r/AHZAMgkHswHarXr6 Fys+ln+Zn6bM9tIjxj5lImU/3gueD9a+ivDnxM8A6qALrXrjRbsnm2uUJXnslwOOT7//AFtnr8Nu 5xSdnrG62kdPe/Ce+AZ9Ilt7+2BKG6hYcsBnhf8Ad/GuUmjeM4dSp+6wPr9K54vv6nVpvTkRmU+g I/ut0P4Vj6h4T0q5H+m6RbOe8gABz9R6VfL/AMEmM30Zyes/B+wCO2lzyw7QZTE2MEKOzYrzmSJx 97cSPlBPYe1Q4/5ocn/kNdsZ3Zz1J9Me9exKot/DsYdSfOmN0it/HHvbt7AU6JL6W73f4njhv3gY mDA/vL/ewT1rp7O3ttSw1lbC3uNuJYE/5aFc8p9Kyb/4Bblrt5Mjg8PAbhfSTNIeUkftj0HtWdea ZJF99A3dT/eH5d6hs1lHsvNGtZxEINowOv1FU79z5R55zhR9M960sQn/AJnOQqpzyc9CcVIi4Bxj 0PuBVIyIZRn7pP8AgKqyp64bsp/uikkOxVmYr/CMdAPc1mXdwE5uMj0T1/CrS7EX7+pmP4gc/wCq jGOvXqfyqSDXFP8ArAR2rTl7Gdy6YQeVPuMelRkjuOaRYA46/nX0f+xBphk12VkBxHZyOzf3XklU cH3Fa0127N/gZVJf8A+4NdkBhkFxGsilSjI4zww9DXjfiH9lHRNRtgbOd7aVh5xgblXb/Z/ya5qs ex6VCpb4ldbHm+p+B9U0hQmpadLCgGy3nj5DICeQwqnbxk9Gz/EW9R/9asb9vma1Idn5o9I+GHgj RL9JH1WwhucN9njZv4Tj+E+9dhP8EPCjnCWLRf7MZHH5jtWkoefmYwrvok+hzerfsxaGf9RdTIDz uZAcc9jXP3P7K2D/AMS/Vyq4yNwxnnso9aE33NnOL+OBUHwK8Z25zY63dbTzFsmySvuh9Kxtb0Tx bEdurau0pyAUmx/rx0GVpup3RnKlH7GnUmvvin42tVK3GlNOpHkyPGh3KuPQA4wK4zXfHNteyxrY 2M9vHHEtvdeYD819uOcZ/wAfyq7roZxpNfA7ox28QBJxGtrISVMonA4wp7mrmpaN9qUqiysfu5jU 9f8AZGKhrt6msF/d8y9pHwv8Qy/LY6BfzL93zipGDjuSPWvpb4e6Nq9vaRx61pLwSJmOM5+8mepA 7tWiXkc9Sl2ku9jr10S5bG1WA6kf3vqauQ+Grg9bjHfBx+n0qlEhvzHjQIf+W87H1B/iPuamSHT0 /wBYoz6+pFV8iXIa3iTTo+iRn0PpVOf4lWqf6vYD0z6fQU7Ecxn3HxZRR/rwfbPT6CsC9+MgHR8f X+tJgc3e/GRz/wAt/bGetc/e/GQj/WXQ/wB3PX60c3YSX+Zz158akP8Ay8s3YAevsa5+5+MTnOGy e2D/AF96jmNeXyMab4s3pH7iJh/C2ewP+H1qnL4w1KUfLK4PQ4HJP1NZORpGHf0KjreyD53f3z3U e9RHw9LL9+RfUgnqP9n6VN+yNUl5D38JoRiSfdx8wx0PvU0HhO3Rf30jSdivoPr7Vaj3E5fyrzLl l4ftk/1Qf1HPQn0rWxn7wB/2vb6CtYxXbzMJy8iQRDuSR1BHekaBW+8MjoR7e1aNeXkTzdihcaCc ZVAw/gY9Vz/hVOK8mt/vYkXuT2Ge4HpXPa3U6LJ/mbNrqEUo4Iz1cepq1sI6KB610X7HP6kckII5 XcOjA+n09q464sTAxDS4GfNgc9hnsayqI0g+/qjze9021jjzZHaw7A/w+9ZsVlv6sf7xPsKwsPm/ yGyukf3GfHZfSq8c7H/lqV9B7n0p2D0Lh05j92Zj36dB/wDWoi0kjOJiO+fT/wDXU/8ADjt3+Qwy TI2IpWz2YjgjPc0tzFcn7yj3H978aF5hYXzJP+eOzuNvp/8AWpiSHnEZJ/z/ADoFb/Id575y8beg A9aWLVVBO9H9jjpQl39Bpf5k01zvA8mFj2PHX8cVHChUndAwPJIx/L60ri5fMkF1GB86Y9iKguGh I/djLHgDHai3cL/8E2Fh0zGWVM9AD2J9D705rTSH+8sSt3C+vv8AWpaNOb+6ZV7YWit+4xs9P9r6 +1RLYxH759gfUfWqMk+6LrWq4/c3BHdk9varNjaGQASXL7iC2RjgD6+lJLyKbJP7EII2XknHBOB2 /wAKr3Cyx42XLEE7S3oMUW7oTfmEiXLD/Wk/3if4hWetrKn8QBzkZHbPY07f5ladfQesk5zs8tx3 VvTFNOnzD/Uy+W3QgdsfWo5e/qTbv6EsOr38X+vRHXv7/Qe9bVp4ktJhidmhPTZIOufTNWpd2YWH nSrRuki+u5T1H+770j6Ci/6qRM90I6fjW7in8IRqW3RUOltExM9izJ/E6jo3sBTS1if+WLL2GVPy jHc/WsJQfbzOiM+z8zPvxAcC2hBHWTj73P8ASnLZWxH+pQH0/uj/AOvS+fmxL/hxRapHzbsVPQ4P 3hVu11m42/vZgR2BAp3E4+QvnWzEma0RW6GSM/eHuMUz7FC3Fvqci/xeVIOn0OKfr8yHJ9Rsnhu6 IG2Xf3Ro++PYeldH4Q+Gmp6k7faL9YLSP59VvZAP9FRgcbUOMlsfh1NDv9leg1b7T82F7rd2YzDa XRlsAxMAHHmgk8kgdGx/nFZkTKMDLxj7rEjoBRfv6MzjHr3943be5DLtjkjI6gn+I/j/AHqrvp0f PnQHPTIHf6+1Fv5fUiUu5Hoen2x8xbi6nhn/ANbpsqngoP7w/wA+9b2leKNbh/1GqJKw+UQygfMv +yR6U1IJLuvQ3oPjbdRf8hTTWXt50Jz+aY7VoN8XILnabe5QsP4H6k+4I7ik7EXf+Rmave6fc83O kW4c8tIo/iP+76Vx2pQeS5+wzHZ0CMOw9aa9Rxl/N6lCLXlI+e1DD+8vHIPYU62u4Ek3Wt+0BPE0 Tjof96j/AIY0Xmaa6dfSEtYiGZerqpHzH2Ws6dnywvtNMbfdcEEbWH4dqyl/wBRXmuxHDrdxFj7N eSIPurEe+PXNaMfjSXA862jl/iZkOCfwpc/8wkTXvja2IRYIJkBy87yHoSex/wDrVRlZXIIfHZkP 8QNW32CL7+qIDax7vkQA9yvH5fjSN4i1WyObW7zH1CMPX8KLmlu5cHxRs7gY1zwrp9wfu/aIvlYE 92AHaqhbRZjiyvbi19I3Xgf8C/8ArUrefmTzPr6EEvh+brazW8o+9lW54/2TUYEoP+mwOvctjjH1 96yYvQqXs0O4GA7WHKsP4T7D3p8euSj7+JPf1/HH9KrmEv8AgFtNaiYfMpB6g+3v9acl1FNuBUlR 9yQ/xAj+GqU13Hfy8zOvdHmhJwGdPVR0B9aprMv8GR6n1x6/Sob7BJdjQttbvY/9VM+Om0/3qst4 p3f8f1mJO+VXv65UUlPuJJ9F5jbgxyD/AEHfGero3fOejEVjSw3cZ+aJiP749fwrRMpx/wCCMF2x /gb+7uI/iPtV23066f7gA+p6/hUhyPr6FtNIvAfmRD/z0yeh9uK0HtGK4uIY27Fu4/GtE+/qCXYr Dw1OOY4rnYeAWRsE5/v4/rWpa3l5DjynZccxg9Ax9eO1JNd/I3lS7p9za8O/BrQfFxdJdXg0rWwD LpkZUBNXdB0Enqx7YJHpjpxOqeDvE+gSmPUZbyylU7WbPAYf3DjnPtWsZ/zNeRCgmtF6+Z1mjaZ4 i1IqscbagD0Oz1/vMi/WvoHwB+xZfkh760VM/N854jJ9FYDpVRa7ehlKk+7S6nvmifs+6PagfbD9 rYcqCMBT+FdxbWEMIxZ28cS9Nq9x7mtf8QJJaU16vuTbR3NGPT8aoBc0YpiFxShqQxAD/WlzQAY9 T9KUCgBMUYoAXNJigAx/+qjB7UAIfb8aTHpQAFaQigQZ9DRu9aAEzR9KBhSFqAExRtpiDFGf/wBd AxMUY9/egBCc/wCFJn/61AAD60mB2zQAm7FIW9PyoAaSf8ajLntTEGD3oyP8+tADd3ufT8KCaAGF 6TIoGMZ/b8ajeT0pCGZP+fSmlv8APtQBG0n/AOv0qFwf60xkTZ9ajKep/wDrCgQ0E56fQep/+vXw z8SFv9W1wJ4gSa0RphbzmRThLNJOzHsy8dR9amT7vyNqUO3T3j7cu9V0q3ACahawwKohtADwsEa8 bVHqK5nUvjHpMWf7Ljkv36KRkKD/AL5FWl3+ZhzN/CvM4rVfiPrt4f3lytrF0EEPZf8AafFZFt4f WaVFk3TTODJbJJyXjTqQD2SsJ1P5fmaRh3N7xB4ag0+LLXQNwTsitwOqAckMf7v0rip9TbBM0pRB l5iB0Qeg9qiMe/qOb/lPTtBu8WkbaDGLosPPhRvlEpkPUsfQe1XrOPUSSNQ0yKHPzhkfPzejcVm3 3T7F28zTERIxtO3qV/vEev0oa3Cp+/hDfwiI9HQ/3wR3pPzQ0+3yOLvPgxogYyWFg8FyP3lssDYD TA5Gc/7XvVCb44+Syxa94WurcfckvGOQzZ/iGO3TvVQa2nfyLqNv4FHTfzN+fwrpV2pOmW6OSN1p LF0lBB6k+hriF8D6yA327TBEoO1FVgSQM9h6ik3bowjr1RhXWlsp+4QfQ/wn3HtUKF8/c57D1NNo yt/kew/BC8IjnUqw+ZZMnuWB7113jP4nS6XEUtLYu8oMZl/ux4wcn2Ga3i+5nKL6ep5frngae0jV 2miljcea3l/8sWf+/gdxXN9PugkngL6/SumD/wAmRLy9TWstGbgyjb32+p9/pV/VplSImQgDgED1 5rCcuxaX+Zz0etREfKxU9MY6j61Tu79F/wBc5z1AHf6ChNdGTb/gFc3ecbYnb8DyKnSO4bG2P6H2 +lZNdzSwruVOG69GHvSeYfr7elZf8OD8yQS+oGPQ9xXpvwj+JBspvKvJT9nkP7onpDcn/wCKrSm+ /oZzXb1PXfHXgWPUoGCj94AZLZvcA/8AoVfMt5aPESJFwykpID6qaU0dUXoVGI7D3PvQZCemB3zU f8MZsXfjv9fr9Kdu74BP8Ip3/wAhWE3k+3b6fh7U/wC0svTnsaEMUSA/eX2z60w26N1O09s9x9aL 9ir/AOZXbQ8/dH0I7gVXOlzD7rOPTitFLuibITz51++gYdCfT8Klj1NAf4lPbjt/vUSivs+oreZY WVG6MD/tD1pwUdj7cVjy/wDBNIscoz39ue9e6fAqMfZpjk8ybMeyr/WtIEzNL4n2AeJSVzg+UT6b q+c/EkYydwz/AHfat0xS8xLeQDHI9eKvanKQmVxzwQex9vwrmRXp6GTtAH3cjqw/2jVd7cnqSfU+ gqZvuP1K0luR0zj1FRHP93/dHr/+qspIb/4YsWyMOjH0P41aklwOn4n1rWJK9Sq8inoT747Ggwk+ mf6Cs2xpkZtyP89BUbJn1z1A+lT/AMMNIfEoPbj+L61MxUD5fz9v/r1aYFMzEH5W/wD1CrMOolvv 4PoMUeor+RNLpkb/AHMewNULjS5FB4WRTwUcZ3A+2O1aKXc1S/zRwniD4XQSHNlCYG+86j+LHpx0 NcRqfgm5i/19oWT7273H0FaKQpQ7+pa8PfE7xDpJ/wCJHq00Y+99nJ+V1X1yDXfWX7QdrqX/ACMd oLS6+59qXlZwPUAcZP8A9auh2f6Hn2a+Ff4kb8V0jrmF1deqsp6j/wCtQW9Rj6/0pNd0aKS6GF4t uNlrLsZhkeUBj7+4HvXkzQM65THHySj6g8qPesZM2sUbhNqnk8g9OzYPb3r2X4hQyWunafFtBIi+ 2SKO6uD1HsaqHX+u4rbWPFb2PrkD2Aq7ZzTRYNrK8bj5kdezD0+lc6ZtKHdeR6JpuuafrACanssr 4D/iX3y4Czuv94Y4J/L8Kq6r4buIWZNWtNjDlZCPvj/ZP+yaz0T19EXS2s91qvNFCawKL+6IZR8r EdvwrD1MERjkZJy2Oxwe1bNmbRiwx8EtxzgD25/nTnUY6cdDiny9jKXkVZFGflzjp9agkU/w4x/S m33D/hjNvbtYxl146Kn94j0rk7m5eU5fBPUKP4c+laQREiIxN2GP8PpSeW3c/l3rUzNXS9SA4lOR 0Un+FqvTwEH5RkdC3qaljX/BQwIB1Oexx2r6s/YQ04G/1B2U4S2S1z/tTTHr9QK0p+XZ/kZ1v8vz R9deInIhbB64THruquHEaKCwXACDPc//AFzWEjsRTntxOpF5aRzxngrL3bHYGuD8QfAWxlP/ABIZ ms5iCzW2MqTj17c1g12OmnU/n1XU830vTfFHhP5EebyCxup4m5WaRzySwHBr0zQfjjp16QtwRZyZ 23EknQHH8LY7mrhL+b5GNei1rTd09Wd29qiDd9sjlHCQnPDO390e9Nmt5Ryzxn+5H6t7mqaIjJdG ONwOPOYF/vSBfUeledeKvBGq6jNA1rZuUSf7fes3G2Ff7o9/5VPKax835I63WNS/sqCSW9tD5aqQ FHV3I4C57k1z2g/A2PXYEk8QWa2ayj7RBAoG6OBzwZSB1br3xWih2XkRCTVrvyOS8N/BHTk1gw6n zbJuWCF+twV6b2x6H/8AVXv1p4G8P2f/AB66fZRfwjao4ArTl7erHVqa6PomW5NZsYxwyAdAP8BW bP48s0+4UHYD0AoSOdy7mdP8VoUHyuv1HrWDefGZf4WGOmc/0p28yH6GBdfGFj0lA9cmsS6+MgH3 7wL3wPSpchpHOXvxuhB/4+9x6Ko7/X6Vg3XxvUH7sjk8bvap5ilHsjKuvi5fuf3cW0dY2LdR78Vn v421WXork9XIBO0VDkdEKb7EKadrlwf9Giv5c/OPLQ9PbjvW3Z/ATxlcnjRruNekck3AJPru9Kzv 2OlUf5mkaVv+yprx/wCP57KI5wzlwfLb/aAFQeIvgpY6awWTVRcy8PeBBxDIR0z64qfQen2dephH SYYshUD/AO3/AHQKy57pg3yHC/cAx1/yacV/kZTf+Y6Odv48geg6H61ZhPrn1OK6IrsYS8x6nJ4w T159KsLH2z9fb6Vov+CZ3/4JYhQDoo+nv71digZ/uq7eiqOv4Cj1E12LKaXITgQS7u6hT0HrxUg0 qUH/AI9nDdApB6+wxTv2NvZPsSSaVOmN9pcKOhOw8fXjvVeTwhJN/q7S4zj74U8/Tik13XmVyPoj Ku/AGp243LZ3Kf3pQpxj/bB9aitPEDLxqEQQ/wAEnqv096yjK3xfIqpS6w+ZtRWhcZiDMD9wqM7h 9R6VR1PwNc3+1bS1kaXO9FAPzR99xPb8a1l6GVNdvmfOgjjPXkdeO/4VZt7KHHLMB/snvXHcafdL uV5NPUsRuJHXHt9aRNFVukzDuOnFV6eoF1tHuE5TUGU9V/2l9jiqKT3GSDKR/D9cUv8Ahg+8mEU7 EfvVX+6xHYep96mke8Iy4Q/7Q/i+g9xU28yvS5UEl0SPLVefve49h7VIksyE/uh6MD61VibeYyXU JB963A7MQeopvmyHrbn1wPaiwtejRpxeJPLUA2zkjhcDrk96sQeLYs/vLY7upGOhHt71LG79ytq+ rW8/KQlR94rjpVVLiD+FMfwtx0OPWi3n5CQJfQj7zjPQcdcelVWuEYklDt9CPT2p/wBIbTHLdRvn ap29Bkf56Uo8sfTtR6+oy3bW9qx+dQD1Y56kVqtoln/yzZsdQAfut7mlbsxN+SM6aylVsRXbc5Iy fugen0qKOylI/eTtnonsT6U2xJf5kj2suOJf9pvcCq6Ru4H71x2I9MU35eg7E62kq/dkX1yB3pst xOp4RSTzk98f40rCflcd5crcsoOORjuT60lxC7DNxCn1B6DFJf8AAG1/wSqAq/6lnj7KV7H2FW4t Wv0HzkSDp83f6jHej0MZQ/yLcXjBh/roGQ/xFOePZaup4ot5fvCGTuwkX7w+vvWsan8xk4v7PoSI +mSf8uzRjoNp4X8D60tz4SgkA+wXkT9/LcEZGfX2rTlX2WUqj+16Fy58MpHky2OV7FRng+mKy5bC xH3U2t1VAMY/GsXDvc2U/wCUyxFGCdzc5wM9gasfYoz94geo/u/jQy1/eR0HhL4b3OoynbcyW9kg MmqX5HFuADgDPdsfh3qbWdagjd18PX1yLQ4heKQ/8fQXqW4HBP59aSX+SMaqWyX/AE8n+hkPeoB/ pAK996H7oPsaliton66pIgPQOv3h/vY7GiS7JdxJv7RNOLR+Iip2/u2df43HrmorZ7qIYF22e49R 7L7UvT1E/Qm/tPHzTWiSMOjKOdo9xU0Gu6POP3s95ZN0d8ZAYH+KpYCS2Oc/ZNXguV7EnB2n0U1n T2cq/wCth46ow7/QisXci/YmstZvUz9nu5Yz3X+8v0PpVN9UuFJF3N5pzuLgdcn0/wBmtIz8vIPl 6AupR9hg9Meuae00BB80rtPysfQ/T3qro0RUmhmtyfJLoPvCRP4gDU0fjbU8fNcNMvQq4zhMds1m 33JcexKNft3z9s08HuXQ4xn+6oFKFtDzaXjqf+ecg5AI9fapuunzFfuUdTvXOBgsBwpUdQTVKHUn A/dysD057D6U2KKL8Gr3I6bT3x6/QirsWqsSftahozyYT0BweR9aFL+75mi8/Qqy6DGxzpsyj+Ix N/Dn0NVW06Uf6xXHZiB/LFTK/YduzJ4NHlziENk/d49Pwrbg0jVACGmVk/jjJH3T7VN31RUYLq/I q3HguZj8kTZPO5P4B7gis+58N3VuuZSdgPlvI44Eje+O9aPz9BuC7+aFt4GYgfu3Y/KqqfvFj2B9 TXTa/wDCjxBpRT/hIfDd9ZBwWsJJUIFwq/8APMsB0HtUxh2v3BQ01a7LzMX7VcRZDrMg+88bDO4D 1HtWefEGnSn/AEzTdp6BxkYPupFbuPmZxv2ubNkdLfpLLkfMsf8Ae49cVftWgcfurdQOhLD7xH19 ajkLUvIe1lGf9ZEp/ix6Ee1auieEo7+Xb5RVcGSV0H3QB2GP6Vbj/KTf/M7Ox+Cujj/j6S6fphlx lR9AO1dTrP7J3h2SON9G1+5tLlhu+x3owk7A9Y5wP7/Hf1puDXY0jW01ivM8f1zwu9k7LfIsUgPk SMpBxIp/gce9Vry13D54AycIhXrGTn72fSrXmZqXY9h8M/GrxPBY7P8AhD9P1q2QeX5qDLRRc8XK AE4I/wAO1cp4j+MfhS/RV1TwZ/Zlxz511Ep5VQeFTA6n1qoxj0umL3ukr9LFj4Nfs52+p3cM15p9 1c2qszJAAQbeU52uzcf6k84719M3n7JVlqqhPGsqXkaHdpt3IP3jW2eBI/8As1x8rb0b7HqySSXM l/M15no3hf4U+G9FQL4Z0G2tR/FKBy5/2ifaugJJ+9z/AEr0IRPNqVG9/kKBigCrMRc0ooAQijB7 Z9qBjsUAUABo/wAmgAooAM/59KPy/wDrUAJnHX60ZoAN35UmaADNGfegA/KgmgQ04/xpCppjE3et LuFArhk/57Un4fhSATNL+NAwx/n2pCx9KYhMn1ozQMMfSkINAhuR2pN+OtAxC9NLen/6qAG5Pf8A ClBHamIafemk0AMY5/l+NAPr+dIBpI/rSE+v1H1pgRkf/XqF3x0NADC2f5mmlh/n1pIYwt60wk/X 0+lMQfZXPRcDqSe341j6h4t0m1z9v1eCNhz5S8kgewqkiJS7ehyWpfHizTP9i6e92/RJJcgDH4d6 868Watquuyq+sw2saqNlska8xqCf4yPc/wCRWU2u5rST6uxteHPhPf6gcWFos2P3kjseEUf3mNem aP8As0xYJ1XUVjbBIijAIjbB6t/s1zczfc7IuP6o8Yu9PuZLgxpI3D+QE/uqG5yfYVW034pRxa6k MOkzyIgbRdPniyd9w/UsMex9foK3suvocri/s+pqfEC/eS7cS42xn7NCufukDn8zXC67dMqYSTGe vsP/AK9K5Fv8j27wBGFs4AduAnmAH+Fee/4Vs20glGcdeVJ/ug1k/wBTUtRqvJZmwOBj+Ij/AOvS BVbHUfxD/aH0pf8ADD9BHCgZCE8cAj7oHtVTUvD9jex41SzikT7g3AZXr904oce5UZeZ5lf+CtX0 EtJ4Qne8tOZNRsCPuAei+hHpWz4J/aJ0nVSReL/Z8+cQxyDiRgOdjkev09aqHn8jOsraw/7eR0mt fDW3vvntwsMuPN80YxORn731+tcl4d+Dmq6lOI4YjAB895eY4igB65x3+tS/P0RrFp9fNns9pqmg 2Ti08PKjOoN3qFwuP3syf89GHfn6VyPxgsp5LeM2al5N3kYUZJV/QfWuhxt18zCErv8ABE+n6I8d lDHr8QSYqVkhYjdhCeWH4iuFm8LvaSMJ1BGc28n9+I04sEh8lyiKS5GBzj1A/wAKzdcv0ktz8o+8 N3uuDWckFzkN/T3OwfnXa+IfhTe6ZIjajeJLBJGJoIlA+SQ55B/2h6n6Ac1nC/ReRaS6/I599ct0 P7m3Ddjn0/KoD4mm/wCWSqnuB0+nFK4MqtdM3Vznu3vT1uWHT6Gs7+QiVbgfxAen+frU0V2RjY5V h80Tg/dkHoRTTCx9PfDD4kpq9uBc4Fwn7i8j/v474HZ/rXB/GH4eGFvOsovkPy3IH8L+4rpn5eoY d9H6HkUjDvz2yOxNR+YCOSfU49K50P8A4YVZs9M/40qznuq+3uaPX1GvIUPnoSD0H+fal80+gPoT 3NAkh/nDsfcZpvmA/eGf4Tmi4xfOYfdZgegx/D9KlW/fuQ3Y57/SmmA5Z4G/1kQU9M/59aT+zIW+ 7Inpt9DVJ9h37iP4aYfcyO+R3/8A11GbGaPopPbBpqX8yGo9hFugP9ajL2Bx3HqK94+CGpWYtpFa +gEpkMwhYgFosDGFPrWkI/y+iMqj7o63xzppa2bcBwRJk9xjtXy74mbk4AYdx6GtIx7jUl0ZStjl R8vuG9/eprm4LABiT3/Ouew1/wAMQqhzzkf/AF6c8QHb2JqJor19CGS2BHb0x7e1V3tx/iaz9BpE sagDk496guJV9T/sg+tX6D9UU/tH91jnuPp6U5br3IPXNYk3JftZ7AH1NNa4Q9Pp+NUVfsvMkgZT 1Ge5HoKfMVH3Sv0P9KX/AAwR8zPZs/4+hq3ZgHsPQmhDS/yLMsqjlRn+FR6VSbVHHTBHfPb6Vcn3 9Cr9hgu43+/Hj/a9R7CobjQkccKrA9j3Qe3tSTBPv6HM6p8LLOf/AFUPkv8Awuv8P6dxXGav8KtR t+YoWnj/ALw7D3wK2jIqUe/oY9nql/ZH/RJXh674yOGU/wCyR3retPixepxKFP8ADhujj/exXWp3 /Q4alNrZEXiLx7dXcOxbDykJDzToSd6KDwq471R8KeBda1BgND8O6neKxFqzwRMRvbIG5wuOvvXL N9zpoxv18zu/h9+zzBqGqiz8d39xozEMYwijdPdJ0TbIBjePYn27j15vhN4Z1TXTb+LJHm063ga0 s0U4867STA349Vz689quL/FFVHZ9NP3kfNM9T/4ZS+D8SkJ8P7Bz91mkZsqCP4cn+Gvlz47/AAR0 LRJkbwj8to4PmWY5+xzBjwHPUEdK4Lf3md8a7ek4x7ryZ5FFGD9yJyeuVU5B9uO1eheE/G328eRr 9vNMoz9g1HHzWYUdJmx0Hv8AStJW6+pw+zktUn/mYeqXjWMrAQ+ZFk4mwcTjJ9u496xtUVZ0zaIM D5pF7jrWtPzZVb08zhLK/kku9jTFYxkyxj+Jse/vXUXiBPuDA67fY1s/+Cc/Lrt5szHJHc+gHrmo 9uemB7n0AqBrzOQ16/8AMbEf3F+RT/e5Pas4W4A6Y9/U1tHzMZsUn2H19qQ4PYepH+FV6EevqNUE dDz1H/666SN1kQHHOMPjs4zRIP8AhiIReuPp619j/sHaXtj1ORwOTFYqfQKCcEfiKqmTUX6fmfS3 iVh5WG+XLKpPtupm3PoB0X3/ABrGR1oqz3OMiIFz0AHr9falhmZB8kWG+8WHUn61HKU2QtZSXAxc 2nmx9Hidf9YCO9cjr37MUV5k6JFFZn7xgbpI4p8nc2p1P5tupwd5YeLfDDg31q8kYOYFY5Xbn+Ej pgV6T4O+Mvh3UgF1G+Njc9fJn4EjZ/5Zv7VcZfzfI58RTtrS1XU9B+y6dH/FG/8Atrzn8faom8U2 kX3dnsParsYqXY4L4seLYrmwdYAPvB5AP4lXPT6VF4b+NkRtIv3wUqiwMufulF/+tVJ/5jm9vVpn mfj7x4Vu0n0+chxggrn5pEP9RXSN8dxKoImUZG5lz900r/5Cmtn5crMq8+NUY+9dKe4APb2rmrz4 0An92zt3J9D71m5Gij5eZh3HxdunzsXHZPc47isqTx1qTHnj/aH8Ix9Kzuawp+RCH1eYfuUupW/h VVP7zP0Hc1p6T8EfF90AbjRLxc/NGjgj5T/tH0qOY6o0f57LqdXZfsh6+xH2ySytV+9l2ztH0A7/ AIV09r+x5ZjH9oeJQSebiOBB8g9Nx9fwpWfcTcVsmzpbH9l3wdbkfaoLm7/uLIev0Arr7L4WeGLc f6F4YsUPVmYZyfqaaRLrP7KSN97tI8C0gigA53RqBzjsayL24upOZLlowDuRs/xH296uyMb/AMzf YzZQ564b0/2ifWvMfiFsU4cBmyXlkx0J+n900maQPMLuct2GOm32HrXOuDu5P1H93NZxXYUvQsRL 7ezA9vx96vQ5/hx+PYe1dKOdoeq47D2NTRwHvn1JHrithW/zL0KnHTHb8PpXtXwm8KW6QeZNDFLI xKRMwH7tFPakZS/4B6EtnDnItoc9SQByKDp9uTlrSDPZto/n7VBupPuxzWkTD57eFh2BUcGnR20a /wCrijUegHemK77scQp/1kcbj7rKwHIP94V5x4y/Zv0vUgW0hUs5/vtEPu3DEdDnpuNJo2o1LfF6 M8htx4k8LTDdab1H3raXo6Z52nH8Q/xr2bwt8btA1KKVra0gsryOKS9ngYAFPKjJzHJ/sHmpT/zJ r07O8G7PRnwU9nbqOR/uYPf6VBDaxd3ZOvK9+e4rFEp97Ej2SjpIfcep+tR/ZTj5ZWHZh6Z9KUUD ZqReH2kAxqBX2Pr/ALRpF8HOBkXpJ7kDofpipb7ItehBe6XPDj/SFPcsP4t3rVeaO9A+YoR94Adj 70JCuvPyKyLKMbCMdST6mrELXLthIkZuhU9GGO9VbzEl/mSvpF22MQKP4sE9CPShrW6X/l1I759h /jRfuHL2aIU1Nm+/Ax9F9PpURuyDloiO3TofrR6hbsPGo25GJVbPc46Y/wAadPcqcCOJh6sB1o9F 5g0+nqRRyRKP3kRP4dDVmHUbf+KNQOhyO49R70rFIZPPB/yxC9fmYdvr9RUWI+yKecjPQ/h71S8y G/UlY2zDiEZ7k9wPWrelwWjcS4A7gnrj0qfmUn3Rp/2PYk/6xsdN27JH4VWutIiTpOwGcHpz+FFv LyBSXVLsTN4dQ9LjGeoyPlFRXHg5I1/0e9f/AGRgc896S8vQHJDtG8LNMT51+6/wk4Hy/QY71sz/ AAvjkwYdaZT90Hb39+DUuT7ItNfauIPhbcrxFq8B7r7k/Wm/8Kuv2Bxf2zfwntk/j6Vnz+XmPlj3 fmQt8KNS/wCelq/bhhx+frUjfDrVh0ggPoN45Hsar2ndMbiuj8ikfhrrBbItogP4wD1+vFTT+AdR kx5mkrt7lf7wPoBSc/J9ilT7SXcrXHw71If8ethcx47L3BHp7Uq+H9fj+7aSSKOASDxkduKan2Zz uj5ryJYdS1eE/NpNwvYumeB74HarI8XwsSLy2Rv4ZElTv9SP611Qrd7djmnRfQkNvpU3SzWM9Xkj P3hjup9ansfAVhcyIJdWEMOc3JYfdT3P0960nFfYYqU/+fiL/iz4mw3bG18F2gttKj+WVwDu1GZT zy3O3dnr16ntXF38ZH3oZ1f+FSjc4P07Vg15+RrRg3qovXX0RM1mDgfZblz1AVG4P0xTotC1CTIT R9TcDjIibBX64pRXeXmdjoS6wNfTfhnrFwoNrpGqnPXbE3P5itf/AIUf4u/5dfDerzHoC0ZGB9dt JrtYn2XeUUbOjfsx/EG8JFv4TaHAMgubpgi4QEnLOO4rC8Rfs9eK7Ebr7w1d268+ZKq5SQg9UkUd z+FS4vsZyiutSLOJmUx8X9oynsMd/Y4qa3idv+PSaRP4hz6exrkk30ZhyvovI0Usr2QHcI3/AIS5 GOf/AK9Zl54cuxnygMjjJ7mtIvyFyeZWtdP1RjiLS5pscMIgSefVQK3tP8HXkyO02j3lvGuDcTyo VClgehYVD/uvyOiNJ2u9ty9J8J/EqWyTxxQSWEmf7Nlcj/SFViO3uD25rHvdClX/AFtm8Y+7vi5w D6rWtv7rIa7Nf3hINEjB5uCy9Qce3oPWrVtHYtuCgu44kDAjapHY+9QqfZiuuiGNoEBP7osg6MvY Z9KbJ4ODkYaJ+6g9h9fetWKP/BYsHhvyD/pFuyc5BHdR6iugNto1x9+2UH7pI4IYen0relH+Yzm+ yIT4CtDxHMzAfMd56H2IqNvC13AP9FzMeoA6qPp7VrKmuooy7FKebUdh+8pPCSBeUwf4hj+lbFg8 8oG2IMRwwXqcf7P0rBw7L0KT/wCCWTcqvEomjPRlKnnHsR2p9lqdldxlJ54pIifNWFv42UdQTUKH cqT8vMo3fwnspWD6TdyWMg/eQBOiyDupH9088V6fqfx58T6taJB8Q9K07UjHhdN1yAlWXYMZkgUY yQBnGM9+1bRXf0Ik7/C/7xyWo/D66cIbCWG4B3SXVv8AxW8UffA/uj9Kwdd8G2EysBaB1yCuBzhR zyP8+1Fg5uz8ynpfwevr5gvhRBdzHJjtc4KyKM8Z9qlht2024EPxIsrjQ+dhvHQ/um9eByGPfmot 5DT6u3Zo9W8Qfsi6xb2a3Wga/YarYkCSUxsPljY8FCBznPQE47157pc/iLS3Z7W0uBH/AKu4XYcB c9GJH8RFNO24Oz+F+b8j0zwx+0l4MbC+KdK1WxkPMksOWUnPYY+le/6B8R/AuqxJHpuuabexY8n7 HcjBMZHRlkx0HvXQop/CzFza+KHoz5j+JPhK1g1KePQ0WSIN5lpblsqjBeQrDPauH07zrx2ils7u OTOzCIxwwB6EDvXNWdt7/wAzN8NTbXuxZ7b8L/2TfiNu3G4OjWxAaO6ZhukUHjdBjsR3FfQdh+y3 4REgk8Q6Ra6reffuLp1wJpD/AHox/XNKCv0sd75Y/wAN3fXyPQ7e0ghULY2sNtGOEhiUAAfhUm32 /wDr11Rj2RwTm38bfmOIFGD2qjMXFG33oAUAUmM0DF20fnQAUZoAM+hpMD/GgAyewoz/APqoANw/ +vQTQIKTigYY/wDrUYoANwooAT6fnSZx/noaYgJpP8/WkMTPrmkJ+lMQm/8A/XQG/wADQCHc0mT6 /wD6qAE3f/WoxQAgJ70bvagA3H2pNx/pQA0/596QigBMf59qTI/z3oGIT60zd6UxCZ9TTSfr/wDX pAIT6Uhb1/L0pgRl6b5p/wDr0ARs2ehphT1pDQ0IT90flUF9dRWyg3s8cS/dYsen4e1CXZEuXdnH av8AGnw/buPs9/NdNjY9vGpwxz3b3rm9R/aHvXJ/sfTUth0V5DnJ/KqVvtMjV+XQ5q78Wa9fnF7q lzJngQR9G/ADtWrZ/BvVJjmLSZmP/PVwen4iuWpW7eh6NCgutuxan+EmtwY26BcyL3Keuewrn/Fv gPxI6kab4b1O0AG4yAZ3YHcgdvp+lYqXdehu6D+zOFt2e2fB3whcaZpsf9oXMkt1L/pd8X6xAnhc n+6K6HxV4kGn2zvuAbGIye5+vvXTHzXqcFRfy/4Twr4Wmzku5pdfmXIR7y2kc/x/T/ZWuW+E0Mti l5qGsQIsu9rPwRGeft0k5bc4Y9NvTp64olb9B3Zz9zeMNzXLksSZpHPeRiTz9TXEXOrtcSbTclWb Lwp6oD647VLf+ZCX+R9E+FfEujJbQrNq9srKnlXcT8FXUnr/AL1dHDrGnSrm21O02/dDBxwPYUcr 6epPP3i+xLb3YcH7PJHIvRSGHzk+gqypGRiIFsYXB6gj29KTi+zBVF3RXvRMmDcFRnhVX+D649aE tFY/P5hxjKjop98etT6F8y6NEOqXaxRyky+WFRmlYeu0/ePsa+VI4A/Plr3KezEn+Ypx/wCAWn5+ p7N8HtT8V6lMIYA91ZKAL27kH/INhAOMOevIxXq/j34rQaUn2fwkA1wRsu7peqnH971rWPn8/Uxn G2kXucn4I8G6xbXSNNavIXVlup/RmH8fFepeIvE+jaIgbVljurr/AJcLbGdk5Bwfypp3/Uco2+F+ h4Nqfji6jnWW7mMhLCO6JPCW8h7D0QV1XityY0a2R5Odh29437qParfl6Ew/r1OZvIGdPkDLjlxj qo9RWHq0gEXfOcY9EwaXRlyX+RjachZxheOp+ig102reLL65Rft900qoPJtVbpHGB24rCKF1/I5I 3GT+n4UBwfu5x6elc9zV+Q4H+79CPSjc3b6H2NFhjgQOgx7j1p/mfiehPuP8KUSbdvQ6nwJ8QptJ uUdHAiJ8jU4/78LHqB6qa+qNS0y11SAjCyRuu6Fv95fX2rri9PwM1o/xPlPxP4Tn06ZkmQgAnymP 8cZrDeUDoPYfSuf/AIY6Zx/zQwz4/kc+tOWb+8D7+1O/cgVZx2yPX6e1OW59T7UNCT8hfMyeOR0p ROKF/wAELdx3nH1pfOB+9x9KSHbzAy/7XuPfFIZFX7oGe59/enfsFv8AIsw6zcR/6uYgdNv978Kv J4qU/wDH3ao3bK8foB/Sqv8A5C+ZKstjMOGCn+44/rTH8E7/AJraGUY6TRZ4z6MtUm1sy1ro0Sjx H4hhjKR69fGE8SRSc7iP9phXK34n/wCW8zs3cn/CtlU8kZukuiJ7MYXk+2B3qYqSeh9APpWRROkP y5Cn/ACoJAPY+n1rKRbGA/3+fp61Gy5/hHuPY0vQPX1GMpPt/U1TmhYnsexB7VLF/TKjQsOnPr+N RvEvb6qP8KzQNdxMjv8AgDSiX2+n0ouBatWx14+ncfWnXbEdMjtn0x7H1q0gRQWUH7o98VpWqgD5 uD0GP89qcUCI7y4Cjhs9yR71nsx9j/nvUSfkNrsMwx649Oe4p6TSL9xz/u/T3qAfkizHqbn7yK3Y H2+vtUi3cb/eUHsQ3qP8K0T/AMwuZ2reBtNvB/pVlHnkeaowQx9SBXDat8FrpM/YXEw6LEOqr+Xa tE/5Te/8xx82j3ducTwyxfwn5ThuvXI7V9EfCf8A4KCXeh26Qa74Xgnt0HlWN5aNhkyT/royD3/w 6V1xkn8Rw16Ul/Dfn6mV8dPHFj4iC3ng+YwXcYVbmUcPC6E4ZFPdOO3vXP8AgPx3dXLNNqd5JJcY W0eVBjJjJ5K+5/8ArVjytJ39UEpJ2dtbeyl+h61rXxskfaLRgWwPMunPJf8A2EHp9a5O+uY79s6/ BDdxgjzLeQcFAT90D+99RXnVJd7nXSX/AADeuPHehQhR4a+HPh6yjHyeYVBMox1MhGePrVJpdMki Mem+GtOs7t3N1qOoR8GUAHgccYHbp3NS6vZvsjo16zfmcHr2lQzDY+zYDlmA+8xz3rybV9Au7KQt YyvJF93B/iU57AVph5fzE1krb+h2/wAJdG8ANctL490Ke5nK+XZQ5KoJznJm2kdTjuQPTmug+Jfg PwxdLu8G6QNPdQXkt4iSLhMn/VhvY12VF2bOejWe00v5WeISxMDykgPXlT0Hviqt1OI42bYCcFIy ezsDVLyFOm18SfkcGqFjljnuT7mgpn3HYetdJyP09RfLJ9aCgH32x3/yKPQSQjMpP7tXkPQLGpP6 AV3Pg34aeJb9WXTPCOsTdGj/AHLgMcH7rlaZ0KhJ/Z+Z6Jov7CPxOviPK8LxWinnfeSBdvPVUx2r 6x/Z2/Z+1nwba3Eeuta3NzNKL92gORDGkeMBiPXmhF1qS6TT6nqOoeHJ7oATfuwCJRg/xL6/SpBo YX/W3WPUe3/1qGjHm8xFstOi+8wJ6kjuT6mkOv6ZH0RM0WJcuxWm+JFpH9xlHqR3rHufjBGv3ZiP p/jR6k3Oe1T4ywyKVuUiljPEkT8hhjuPcV5B4j0nSXObBkjPXyWxhWH9w/pWM129Top1P5vmVNK+ KOsWHFreGaL7hhkP3I/9h62P+FzSSjgyI3Von7Y9G9qUZ/zEypfyFO98etLG32kEj7u49iR3HvXA W/jGdsi3cogPyoO4Hv70r9i1HuvQJ7q8n+/ISPvJn+FfYUn9kykHfMoHQYP8xWMpPon3NOVB/ZkQ /wBbMSMcnHU/T3qxBplieQjE9GY+g/2fejXv5lya6Ic9tCo/0WwjP/PQnsDXo/wm8YeFy3l+ItEt RdcvY3EgyLoDsievf/61aKPm/IwnN2vH5+h77HNbwgeTpVpCfvJhR+6X2x3qwtxO/wDr5mbPOD2H sKdg5+8vNETxnuv/ANaoTOityqonfaOXcnvVh6CJdRs3yq+eoBHRRV0OOPzAHcipEx90xXsAe/8A sn/61Yr2rSZ3TMR1QH+97Ci3kX6lafK/60ED7qKvcn1ryf4gSAy43rtAPmD0Pv8AWpfma00ebXqL j5cDvj2Fc2GBY9SCe3YiiBMv+AXo1b+LPpj/AB+lW0ZVByo9M+ufauhLsYNj4ST79yf/AK30qwh9 8diKsz9C3G6jqTjr9QPSvo74a+FtQjso/tNm0OczRxv18tumV9xVvzI/4c6/+w7jvGPfnr9KU6JO P4B6kZrI3t5i/wBiT/3B6jmlGiXH9we+T0pXFbzEOh3B6Iv59/rSHQp/7o/OncdvMqan4EjvUK6p aQzxnjDEZX/db2rxXxt+yDqcaSP4VvZApBiuYYyNxtG6qVzyPzrOXkdlGa2qP08j5CTw5p8gGLj5 vvMM9GHr9agOh2+fmlbH+z2//VWETmcvJFG7stjYimcjqw9CKaunk9Z2PbPp9KP6ZCfdC/Zpk/1N 9ID1IP8AUmrmmxalJny9VYEc8gfoKH6Fosz6Ldyf6y/BbrkjuPw71Un0+8QYe4hPYkdyPamFl0uM j0e+lX9z5bemfb1xU9vompIciKDPQhm/lxQ33uCS/QfcapfxD99apnpkHqPY+9V2169P/LKPHck9 PxxTsZ/8MVmluF6RHPVSO4Pr9KQanPx51uzH7qDH3hn6dqVvL1Kt2fkNlnB6REN3OOn0qwdajUYk ifPRWI6j2+lMcn/wSUa1bEDKuT96QhT+hFVzd2xbOGI/ibHf3HvRYS9H3JXvrM/dwMfKykdSR3qu 09nj90uD/EcfxfSkGvYkjlgAG7ax7+x96eYrdsDy0z97dnoabXn6DT8hTb2ueHDH70g9fxpghTtI 2P4Vz/D/APWofmyfkSm1H/LOc47JnoRWjp+hNKgIvn7mT/ZKk9jUS/4JWnVLuRarps1oha21CRzk Bo+Op9cVip411DPyXUg78HofriqjHujKb7fI1V8U6yoyt3K3dg3qPwpG+JWqD78pP8LA45P0IqnB diL+ZLD8V78fekUnouQO3vU6/Fa7HMiI2OAAOo9wB2pOI16s+svhn+yTY6zYW9zqPiq4iaZTM1nE nEAViMBs9x70Xn7P+n2bOlnqdzjOFkbGQfYf7VZxh3t3O2rUSdox8mzI/wCFGHJ2eJ7kAc7fLGCG +g7Uj/Am6/5Y+K9npmOj2fkjBTXXmI/+FG6oM+T4otwTyxKH5iKr3X7PF1cD/TNR0ycfdKyp94e5 x3pqmXzr++c/d/sbNLn7JdWNsfvMYWP3h6AjtWZL+xr4rT/kH+KdOI6hGbkAejYq+X+8zN8vVMZ4 d+Cfibw3ctLqvge08RRY/wBGSCTIR8870x3+h798V09/+26LUgXfwWsbUj5FNzEflwPdKItfacuw TUtPYSEg/bmv2OdN8E+Gbc9UwOQR6/LUy/tueMZARBHpNpkFSFQHqPUDtW8XE4pc/wBurMrL+1n8 SY0A03UNLdRkoFQcFjnp/jTz8fPjbMm6Mtg/MgjiByuT6DsaLf3I9hwpX3rNHRfDHWviPr16sPjf xDqlnZsryTMsIGZUTIAbA7+9ekXfwrnXKXPjLXLqMZhRJdv3Ae5x2xWMn/cj3Oz2MVbZ/abMS2/Z g8GvIr6rpc1y4BVnkb19AoFZms/sheE5snSbq50+T0wpBB/Dt9a5eTsjf2v92Pmed6h+x14otlJ0 zVbPVVXLSgfKxT/cx2HvXAan4H1u251HRLyEdnCkgY9WUU7+Rm6a/wCXb+R6/wDsx69Yp9q+0XNs kxKwxpcADcqA52B/TI7V6D8a/BWua5p7J4VitJLgsDgMo32y9cMPerhHy80KpPZOVtuY47x14Wl0 /QrKK8i8qWJRbXkB7XbEk8j+6a8OZCeoOP419x61XRXMZPV8r6mTdaHt5tCIz99k7Ox9eKZbXFq5 xqlmIWP+rlHQgehHqaI/8MK3n6m7L4Mt/KL294xOQgiPQg57/wD16w4tG1NSWt9jxj5fLB5V/X8q VvLyE7foSW/jKNuJ4Rx8rEdmU+uKsyXenTdQB3QnsfYCt0iW+4i6Sif8e966jrsyDj8CKnjub+P7 jiX3HH/fIP8AjVcz6kuPYeuvj/l7tGXu+RkhvcAUMthM2UkWCT7gkj4K/Qe1W32J16s2X1S7K4aW Ode7SAHap9G/H1ql/wAK5sbjBkv1tX5aREX7rE+uO9Q15Iafr6GjF8GtQXH9neIopT0QP/EWPr/9 aur8T/s1/EPQ4BLqGnWmoWpw7yWsgLQBh/FEB/LNZc38yZvCMbbtdEcNZeP9nFxDc2zf6uUsD8rH s5wOtWoZrGQfu3G7/lmR6fX3rW3Z+ZzyX8yLFpp15ZyLL4a1OS0uh+8t5lIwSw7/AFrrPEPhY+NN PkTXNcMmuphtES4wFuDnkmUDuvGAMjA4PZp94IbS7+Rt+Hf+Cf8Ar1pYRrYfFO+trwgXVxpoH7mO 5BJ2gqfpn3HStK1fULBDB8YtSuLBX/cDUYUDRXksZIG5lGBn09uamN/tQXkXU5NfYvyfmZ/if4Oa taIJPDsOh63Ykb7W4jQFnX1aIZ6j0PFcFYfAbxTr0gGjeHmRgfmcJsCBs/xsB0PvWV2ur7I3o0r/ AG3bd+R9A+BP2DksXSTxH4lmMwGZ7CIAjec8ebj+EV7ppngvRbI50nQ7GCT/AJaXCoMucdzirUW/ 4h0TqpaYe66N9zUZ2b75yaAK3t2OH1DA9KXHpTELj1/OjYKQABS4FAxCD60Z9RQIUGjFAwpCKBCH H9KM0DDPpRigAx9KMigAz6Gk5H9aAAmj6YoATNGKACkOO9ACZpC3p9PxpiE3H/Gjb7mgBDjtS49P 1oAN/wDhigtmmAYozSGIW96Rj9fTFAhu70Htmgt6flTACR2+hFIW/wD10gG5PY5pu7P+FMAI/wA+ lNxQA0kf1FNzQBGZKaXNADGI9fwqC4vfLx+7kIJ27lH3T/tGkFhL/UrK0GdUv4LcdRuPJB9h6iuM 1X9oLRocjSrae+b7gYggA/UjtVpfzMz5v5F5HDar8dteuMiCWKzToFi5P/fZFclcS3M5zdXM87fe ZpWJ5J7D2pSn/KVCn/N8xqaeB/AB3yB/WrkFpEBmSQBejjvgei1y+hu/+Cdl4Z+K3hnSXDfZElmH Ec8mRsLf3fqD6V6VY/tWaJL/AKyB17lg3f2yP61caS6sznUl1Xoa9r+0T4dkPz3Dx+pI6H6e9bNn 8StKu0c6dJJcKgLXGBgH5c4yf7wpzguyCE30fmZvhqV5YkyxPGRn0JPevL/jd4x3MsVs42/euBnt n+7/ALRqvQbfc7G2+A3gW8tUF5Z25YoDcXYkw/msvJYn+6c/w8V4v4/1awV0t/DE6tptsDa6ds6N cn72X77XyPrWKhbqb1MRfTkjpqn5HmHiy5uYQqiGWNWxI05U4dMngNjua7j4AfA3w74mkuG1u4WR rcrZmxjI3JJdKxDTd8EKQOMHnrjiJa/CzSnprNeaPcJf2JPBrfdtZh/Fkt/F9Kx7n9hDw8T/AKNN cR/7hHP1yO1JKXRs6vrMH9iJmzfsJxL/AMeev6hH3TDfzA/wqqf2LNai5sPGWoR56qT/ADoUpdWK 1N/FTiQ/8Mt+OoeLTx5ceqB1Hyn3471Rk+A/xRiH+j+KFkGd/kkDDN9dtX7V9YozdCl0bRyWvWfx N3va4tLy4cGOWOHGUTH8bAcce3HeoPD37Lfi67mSO7sTZqeby+c5FtEo5O3A/CpdTtDzIhh0r+/p 0PY/EPjDTPDduLTwDHumxt1G9UZJkPUyMO7fkO1cd4T+FniLWpgbeZ7SJGEupaxMv3nXtDG3X+Qr Z6aL/EcsY31l6L0PV/E/xWstJXy9AAnuPuTXHo4HVx/s15NqZuLr59cu3ctxGo7lj/Cn41pb/gmf K3rZ/wB0r+L/AIfywRjeFkjOFPPKKfX64rT0DV3ntipOZIyJAD/HGp7H6VKl39Qn5HTyaIl2MiBY yeQ46EY9P9qud1L4X/aBh2WIdRI3Qn3471z3fQ6otfaONufCDWLHe6N/yziZT978BWNrmoJDH+/Z gM4Jx2APXFaLYxa192/kY8d6jjMcisOpx71N5uPQDoB6GuZgn3XkL5rdiR6g/wAX/wCqnrOf4jz0 2+1Tf/Jltf5jvMHOcjt9DSGQD6dyKf8AwwP1JVKkcjPqK9/+BnxTaQfZ9SlJdR5lhIT/AK2LPQf7 gropP/Iwqrr8zc+MPw1F5F5llH++T5yB/wAtYf8A61fNUjlScL67j6HPeomjqb00/wALIPPB/wDr 9z9KUzqegPsKz/4cgBNjoc9gT3xS+eT159fwo5v8hMf9oJ7/AO6T3oEpPoD6+9O//BEKZAOpOeuf SpPP9APcUXGwW4B6E+59KVZAe/uPpTt5eZTfcVpj2PuT/hT1kU/xH/aNC9CRyuP4iD2/Cvo34KwI dOHnxRyfO4beM5BPqfYVpDzHJ9n6CePvhtYywu2l6fHHMv76TH8cY9vevnLVJgvE0ZD9Gx2qoo1l LTX0GWWDjG0d8fietL/akW/bG434MjIP7o9PpTsYs3I41K/L6YYeuaxpwVPyjHt7Vi0WnpoReaT0 xQX9OT39hSsK/dDfMz746/Soii+4759frQC8yBlQ9cHtkf41GYU54B7c9qzkMrzRgdT9foai8tR0 PH8gfWkkNv8AzLNq5HAHHRfwp91NjqB64PvVMSKlvEp69PatDdt+6Qe31z6U0BRnnB7j0/3fpUe9 B7j1PYVF/wDIq/YeVi/hf2P+yaPLj7OPQH+8KAuBtwDw3uPpQqKP4h/jmpX/AAEH/DkkUzLwM+p/ CrkE6N1yp9R/DWlxxY6bTrK5GNUtYrhcbc4Hyg+hxXGa9+z/AGknPh68EZ6/Z2/iPucU79jaL/nO GuPDWs6dlbqxlZDk7wDwvsMfw1c0PX0hBFi21ut3G64/eHPTI9DW6nff5nNVp2+FX6nTW7zS4w2H 6sn09BW9DrMccTrNZiSU8RTFseQR6p715leNt0zooO/YgfVbcquDKZOkgI4wD/CRWvc6SyuFtLy3 uWK+aZozwrY7E+g/+vXJfz9Dofmjn9ShkCkjaRyoYn0B5/CvMdS8URwOv7sSRhvJmJ5BZs9/eu+g jCq/P0NGa4spci3RUODMsWOowenFGifF1i4RoHhlU8MwOHVfRvp711LzOW3+Z6unxM0rVz5eseG9 BVT895etHjyol/2wB1P0Arxj4r/DdIo0bwTA97ayuTpMEAJa4iDkZjTuCeh71C33fZnTBvao33iy loX7CXxbvAPs/wAPJ7UH5g984TaD6owzXe6P/wAEr/iBN/yGtb0LTB3COXKj6Bf613t97iVGK+Or F9dD0HR/+CS2kLj/AISLx/qNwepito1AH1dh3r0jR/8AgnZ8J7Ej7V4dl1Jh/HeSZ3Nj+NRjrS9U vJle2iv4UF8z0LRfhB4E0sf8SbwboNrj7jLEpIx/tHNdLJ4rsoh8jog6bVGPzAqrd2cc6z6szrj4 j2a/xA9vp9ayrn4uxL9x1FVYwcu5h3nxkA/5bD6A1z198bIx/wAvYHbPvSuI5y8+OEXe5f1J9fpX O3nx7jGcOzN1Ue3vScikjBuPjfNJ/qsg9Bnsfc4rLuPiXqEvCuQei49vXjvWbfn5m8Kb7eRU+2a3 c8RwXbE/NnaeMe+K0Lb4TeKrkAjTLll+4Sejk+xFY83Y6Y0P5nY6/Tv2W/ErbftElnDn51SRhkJ7 rXTj9lCcoTLrtu8nSKAjgtjvIPWs2n0uaxcet2eZeM/h54ntUERs2SHf5l3dYyTCARhGxWHPBaoq rZ6akLKNs0ozmd/V804vuyqlP+X1IlBJ5c+mwfxf/qp3lkHlR689vr9a1+Ry27fMWRwehPr/ALuK sWrADkA55Vz2HtQkTItoVb7gA7bfX612P/CjZb2zWfw+reev7yWId3jB5iYd0+hq5eXqRTl/PbX3 WdT8MfjoJWFv4sYxXI/dWN42f3wXH3ya9n2lfvZz0X3oMuWzs/WPoMLE9Sx9D/8AWqLDg42qf+ej f3R7/Wkza5IrnPTB/hqa1yW5+uf8KBXJL2VR1I9cetZM0kY++uCedvqKBlCeNzypAPXb6qK8g8cu WlboPT/ab3qJG0F29Dz++AIPzEdyT2A/xrnoR/dU+p9h7U6aFP1L8UY/h+gPqKkEP1/wroj/AMFn K0WI4D3OO2B/hVpYP73T+EiqE/8Agm94asomuIRKhZd6iVP7wJ9a+pv7TlHAwAPkRR/Co9B7U5Gf UBqsv94/Wl/tKX+9UXNLC/2pJ60DU5T3pjsL/aEvr/8AWoGoSf3j7GgBBfyD+I+1H9oSj7rn8O34 0Aflf9niA/csy+p96WGEkczOv8Iwex9q5UjS/l5k7aKo4lupCPulh6//AF6a+kOpO24bjjB7f/rq Qb7ehXa1kPWZz2ye2KtQ21yp/c3G3PI9iKaQ0/8AMka+1RPvXYI+4x4z+J9qdPb35zunQ9o/eqfk Jx82Jb3moxD91sI6tGf6HFSDxXfAjzLaL656n/aGO9Ql/kHp6MjvNSupx89qoHTKnoFNU3SZj9wq Oy//AF6tvsJLuyxHfv8AwQM2PlYjtUbam4P71Gx91R7e2aleYNdmMmvC5yI3Vejf/XqRtVDDBjP+ y2O31qvkFvMLPXI4h+8gf0DAHkEVcOr2bfdj2npt2/eJ9TUtFXfT0IZrqxYDZhj1bj0PYUpmsP4Q uDyB7n1oaBN9n3Hs9k334YyDyCex/wBke1QWotN5DDcP+Wee4+vtQvUpvsjVW00vGZAgfoVP+e9Q 6jb6aEJtQiyfdjA9faj5mcpeXkJpmh2MifPxJ95iGx8w9qsx+HoR/qrl1HVgp7n1ot/kXNrsjN1b Sgivi7dwMeWh5yG9x6VgJhTyM/3q0j5HMzSi8RwrxIzA9R/9Y1FcXUTnKAY6sBVf8OJf8Aj8hD90 D6+tDWzYO0EemOxqSkj9G/2atV8/w/Z/Nyoe3b/gMh/nUniiArcP3B+dT6Zop7G2MXvaev4HNTXg iYec5wx2xcdG9z71o+QB3BPTPqKLnPHzHfY27Y9j7UrWbDrg98ipuXbzD7MfT24pPsjd147AelO4 rDlt5B/qyR3AB6UlzapMMXlpBOvRllUHJ+hFDa6lLyZx+rfs7+Cr0k3PhiG3Y8NLakrlvoK4nVf2 M7bk+HfFl5bH/lnDcruABHdgKza7M0Uv50cjf/sz+O7TJtrey1FRyGt35f8A4CR1IrG/4TPxjpBH nRa9pzDgfIxVdvq+O9axqfzGUqF/ga8kdp4R/bR1+xkVrv7FqQXiWCf5CxI7MB/Q16bYfts6Lc5/ tHSLuyY/PM0fzhgf7pA7VquV/DoczjJbnZaT8YvCd/8A8gzxBas/XyZflIP/AAPHWugFukozHJG6 9SyEHDH6etYygy41e6FjilUH+DjKn+8v1rJkuMoVKqyfxqR94Z7g1lbujpUuzKF18KvB+o4/tbwn ZPjhbmMFWY8/xLiuXvvga9q+fBXi/WNKA4tLVzvVB/wOhX6MpyT+NLvc434oDx7HbJ/wkN7p2p24 YBLmAAN5n/TRAB1rxxfEC/8ALxG8R6bSOh+uKttHMo6/u2/MeJVkH7p0b+8M+ntU1vYxSjF1Ajg8 OpHUe2fWhLuF/wDJj5PD2oW6E2N1JJAMebbN/wAs8/3T+FO0XWrSVXBPlydPKk4wQDnmpSCT8jnL GABm3gE5YBSOnJrLuLPDHZkdww7GtkiL/wCZvaN4UnmglkN+yeXt2gj7zyHox/8ArVLp51hji3tD cAfOSOwA9h2pNPr6ItLz6czJJNYZW/4mFpMg6s204JPoQKbLDp83ZN3QY7/U+1Wl5ia7lqLRpl5t b2QDoqcHgegI7VaWa/j+6sU4/iwcZx7Gk0Tbs/JGhbeJ1jIFyLq3b1UHj6OB2NfSdp8Rp9T06NJ/ EUNxOwykRIBjtYB1lH05/wD1UN9hvb3rnk3xD1rw62nKtnrukXN88huNSBxuhhiBAEc3cSZHA/Gu PXwt4MuYojb+KLe0uQu3VgzAbptx+4p4wR7/AI9q0kl/mZRq73hLol6FrU/CPh63I/4Rv4oWd0Me Y8Uoxhh2Rhn735eprlv+E5gDEXBSTHEdyueCe6MB3qVJdWuxXMn/AA4SXc7Xwz8Rte4XRdZ1eQni OOME7vxIPSvevDPwh8UarGF8a6ar2p+SUzty6H1jPpgdqmU+x2Qw3Wokuq8z0fwt+z54f0nI01Lh kz5iWzH5Uc9cL/tV3UMQjGIESNOoRBjH5etCj3HOp/KrdGOCD0p2PXPp9K0OcXH0+tGP8M0Ahdp9 qMUDDntQSaBBnH+elAHrQAuaNwoATHv9KM/4YoGGfb8aM+uaAEx/hSH/AOsRQAEf/Wo3UAG72oJ+ vvQIN31o3fWgAJ9KTNAxCfSkoAC3/wBam7z/APXpiDJP9aMCgAwf89xQP8+9ACYPpQD649aBh+X+ FIR6UxBuFBYf/XpANd1H3iB7n1+tOx/iPcGnYVwI9abSGNLD/Gm8n/PagAx/+uk3Dt9KYAW/+vUZ egBhbPtTSff2pANCk/dU5/rUF5qNnb86lfwWw+8d552+yimkKUjjdU+PelRAjSbOa+bokh+Vcj3N cHrXxw8R3PC36WUf/PG3AyRnu5HaqbSISb3OUnvJJTmVnmb+KSQ5Jz9fSoSuR87hB1OOwrnlJmyR g6r8T9EsTi4nZ3/uohOW/wBpgOwpp+LXh57ZmbUjHcni1tApJjB7uMdhzTjD+aSMpzf2YPsSaZ8W dI2qLzXLeRyMyBlI8sj1IH8Rq5D8TvDMzkQ6vGjfdBZSBIPZiO9Vy/3kQpvrCRsrp1rKOFguF7t6 r/8AXqK58A6DOoE1rc2cna5tm+62epiP+IqGvXujoU+yXoYF/wDBPWyR/wAIz4yiuB0EE/ybMn+9 jt9a+pvDXgy20XSQkNyk0xTztRul/wCW1zIMnP8AudKmz+16s05o/YTvszT8N3qQ2SuzdF3hvU47 mvln4h/EVkeWWQF8HZGR/EQTwAPetfX0MWuxLo3ibxBNZpNqu+3hlz/Y0bHmWBCQSFx0yOM/hWPq OsR2sZadsIODgdCT2x61HN/kilC2yG/8NWJPEseoWSXNuMLFBIv3VUdyB2HvXLXOq+GHk8zQJL7R rnqZ7ZmHmE+rD1qbf8+3bqiU5L4lddUdVof7W/jvTsLF4vk1GIcM12isSoPTcwzyPeu80r/goFqj nGo2qr/eeNQdw+m2t4zX/LyKIdP/AJ9NryOztf2zVlGY5EP98FRkfVcVrwftdQH/AFiQ+mT3P4VT S6JE69TZtP2pdNf/AFkcY+hrWi/aH0hv4G98N0H0xU8i7jjN/ocX8K/FguNX1Epo7kSmO5t75R/q oYE24kc/89gAe3TpWt8TfjmlqDFoDRm4I8u7uR/yxX03VnCKN6kn39CL4S/DfSxAZ9bgW6uWPmi6 m5EUCjjy6r+N/jZI2YfC0Sgf6uWROAOein1ogusgnLovmdB4S+C+iQxq2tTR3t0wEty0jDEbMOiJ /s/qa6T/AIVV4dP3NOt+PmUjHysPT6Vnyvrc2Vf+VLsZniH4FWF8hEd7NA3WNuo3f7S//XrxHVfC d1oF3sv8mJwY4plxieF8849j9KEn1XkE3FrTR7+p0vgvxHb3Mpgu5fIuB8mml+l4q9kPquK9GPwu uiCHaN+2Se3tTkv8yKUl9p+aPEfiJpa2Nx5axRqVUNIV7hsnJPvmuo8NfBaC/tFbVdIjmD5kgY/w pzgjFE46atmkHr7pyWvfsVXOCfDN1IkueIJOAoPo5H8Jrh9Z+CnjfSv+QpoBmiHBuIDnGc9QB2rk afU7fZxezSZz39rAH/SopoD90rIpGD9SO9WFmUjKMG9SOy+31o9DjnBr40/IGlx91iexI7U8SDue emfUD/CmZIkW4x1OD/D7j3rR0rX7izkWSxlZJVIkjI/jx2Ye/wD+qmpdga7n2H4V8XWms2yvbMHD DZdKcfu5R1DAehr52+Kvw1fTZybaE+S+ZIyB9xiTnn2NdFZdvUrDvS3yPOmjXuMf40wMPT6GuZj9 RufUfX2NG446kf3T649aL9hMBKR1x67vTHpTsnuc9x+NDD+kL5xPcfX1FOMgHTI7DPcfWj/hwfmK J/Ugeg9fqaTcfU/4iqQMf9oPcD/HFPjmP978+5HpTT7isSxzD/4o+v4V9OfBhVGmR7ARlnY57HdW sCZHV3kIeOTIJ+Vhj/gP9K+UPE9iBI2RgdMevXtWqLexhWs+zGRx057CoW0IrOZHuFK7fs8Ea98s T8xrJsS/4Y6LSb4OCGI3f3fRaratARyMj+Fvc57VEio/8EzRIP4WA9PYe9J9ox0x6H3qRkRu+uPy 9SKja+A7k/0apYJlSTUCOgB9vQ//AF6rf2i/b6n2qRPyImvHPR8+/pTRcuPr6etSHr6FyzuCTx17 +30p17MAecEd2/wrQaFskXvn8e4+vtU09xgnPTr9AaaGv+CZUl0CeFx6fSo/MHYAHoc+tY/MTfb1 D7T/APr9CaBeN7e5NAiQXan73/AD/n0pGvvx7BvSmVFgt7jqWJ6H6e5p/wDaB7Gi/mHoSpq5H3T7 8egq4ddK9RkdVHoKLgpFvz0nAE2xvRHGR+BNYGq/DW1kyViEZPJI7Z6cj0q2uxtCp39Dk7vwzq9q xNswu16xoOCoH91sVZtfHFqp26jG8cmdoglGMj2k+taXT+JeRnUpvek/M03ePrBux1VB2A9PpTBI W+5GT/FIB3A9vavNrUrbeqN6dW+6RieK9OurkBdP3qeWLnOAee4Hc4rz69+HVxFt8/UT/wA954ey MD2OOxrShU7LzZVSnff0NfSdNv8AU51j0a2Sc4MERyBlwCfmcj+H3r079nz4AaTq+pPH49kW5hRH kayiOBcSxnGDIMHuf8816NCF9/NnHWklt0tY+vv+FOfDi1jaGy8HaXCHVoR8uWKuMZDtn7ufWvk3 w38Htbt/ESRXjSPaW7nVYtSUYX7LbkFRGR3JxxnNXy2tc39rdPm/xRPrLUPidE5/fXDMOijPRc+n tWNcfFmBP9Uw44/zmtkux5xhXvxrA6TIOxxWBc/HVF63Y/2SOwo9ARgXnx+hHW59j9Kwbz4/IfuS uw9geaLgl5GDefHG5kP7hXPoDnqPU471kS/FDU5D8qz+jBQeW/AVnzG0aT638iI3niCf/V2t0SeQ mD84z2IFaFl8JvFF4cR2M4/vZU/J9QR/Ss+Y6Vh/5jp7H9lDW5f+QhdwQfwqhYZwR/dIrXi/ZGUb ft2qZY8bVAyIV7k4rNvsa+7/AJHWQfsreE4AN7zXHeQv/wAtD74/vV1GnfCrw3bqPL8OWobqXcZJ A/wp8vmQ6r+wl3Na1023iObaG3gP3Y0jUYVD6nHU1NI7L1dweqKO5PtVWMXJ9Wzz34nftL6B4X8t dUiuLy+kICWEHW3tiQN07HpuJwO/tXoNvfrIiNEu1WC3AX0Dj1rW3n5GTbvr25h12UmQrcW8csZ4 kRx0AHY/SvFPit8PND0y2883jW6bvs0vmD7pIP3GH90+xrBx/lO6jPo/Q8TdnugjeH7uK4iOHnkH UJ6Ba0Pn/ix/tD1p37mK7xYTMqAk4xgs31A7fWvNdb+Ol+Ts0rSkgOfKWdjkyk+i49a3oruzKre2 /kz0fwnDerEv9qO0rn5nkPrz29q+ivg/rL/ZXjhcx7XLKw7I69q0k99jmXT7yj8Sv2f7e9Uy6CWW 8H7+4QcecR3THf8ADmqXw1+P0m4W/i92jkH7jTLuT+Lb2mYjv61zw8/kd1eN0nHdaS9D185XBWQP nmJ1PQe2PSoYZSP9ZlmPzBfp/eNP1MIy7FtXHc89MVYtEOf5H0oKfoR3EQYnkH1OPuqPf3rNN8jn MUWF+6hP8RHp9aPUfp6EE963RIIwerSZ+6B6D3rxHxfJvlO4Y7fX8aiTN6fmcLqbYUhhxjaAfSsa 3jAx8wx0P+fein/wDKp5lxYgOjKOwI74qdGUdHGeufT8a6EzGT8yzGy/3l9c1ZjMZ+9IM9Rj09/r Wi9CG11fkdb4EsRJdxcoAG3ncehUf0FfQrXMQPEqH3BHXPrQ/QzT1FFwn99B9SKX7Un/AD0QfiOa j5M1uKLhe7p6dacLqPs6eh5HWn8guH2uP++n5jil+1L/AH0+uRQF/wDIBcp/z0j9MZHJo+0J/wA9 E+mRRbyYXPy2FrFzgAY7+pp9vZBvvM3tj/GuX5+Zqn5DJ4gp4kf0ZfRhT2tH73MnqSD1AptCT8kS Jppb7kxz1B9PpTVhlJw07L2UjvikUn2EuLN1H/H057EnsR6U9Lyc4/fDnnLfw0yfmxDeXQ+48ZP3 Q57g/wCNMVJupZQ3T659aLeZSS8x7Xd1GMSQR4+9vB5AHtikW5mb7kKMOvJ6L7Uibf8AAHQx3BJ2 Qqx6qgPb3qG68w43wFD93b6N9aExyXp3JHM6r+9t2K9BnsPb6UR6ojcCL2/ChvsireaHf2ooGPs7 nsSB0PuKi+2RqfmibHXkd/8A61FvIhLzJY9Ztx/yzH+1x3/KpTq1s68rg/w/LjmhIbv0uS2Gp2PS 6VM/wbgev1q6NT0Y/fjhYdT8v3WpfMd30TKeqvpgKm1xjpKAOnB7Cq7m0P3Ap9fcf7VO5GvVeZYS 3syOYlB6qw9fpVix0uwkH77AbO3r0UHvUfN9y790LqGgWigmCTB7EHqK5+fTlXBJBHp6HPcVrDzZ jN9h4W2/5bWqN257N7D2pk0Cf8sgB7VRndjVtj/f+gqeN3HDgn/2alYpPt8z72/ZEv1k0Qqh4jma KMf3UcZ+b6V1njKNhOcKOgLH8+lFM6Mbvp2X5HGa0jbR09PwJ/pVi1umZRk5PRz61RzWLyzH+8fY UplPqfp7VFgZIsx9T7ik80/4GnYY5bhv73/6qDOe3H+FDQJiic46UNKe/wD+upsN+Q6O4ZemPY+n 4U+W9ZhidI5V7pIoIz9DSce41J9GZkPwY8GapMo17wdpkwJ/esibSTj+8uK5Xxd+w14WaRz4W1PV NJbrBAuGVT/wL0qOTs35G7qfzpebOB1P9ijxvFzo+oaVqq/ew7bWI9lx6e9cxJ4c+IHh8/6Rouv2 K/8APa2y6sfZlB6VcKr/AFZE6CfwSXoa+l/tgeJ4cC71GO8A+UxXUeG3D+8cDoK7K1/bD0sqp1fT RbPnbIkZJ3Z7gAf4VreL20OSUJLv6HoHh340eFdQGNM1tWlH3rZwQdzD09q6RLhHB3Zz0X2BqHAa qd/Q4X4uOFssruLbgSMdDnsK+e5YUP8ACvoeP51EkXHyM660a0PPk7W+8rJxgn1Ap1nYXK829+wx 92NgOc+hA7UkypJdfU1Gv9XjjPm2sUkZ/wBa6HnAPZTWX51hMD9rhlR+kcxU5jYf7eP61p/w5Fu3 qZUXmox/dq6cgSr3X/dx3FV7m0kLZwwHUMB6nt9Ka/4JHoa1vcXcURS3cbHIlvlI/wBYI84/75// AF1o6Tr00HH2p4E+7KyAHKmm35eY+X/JnXadpYv0Pla88yDCTxMoyhI75HpTH+B+kyctdyof42QD gn1Wj0SCEkt0V5fgdOmf7G17a39yYDDKP9oetZGpeHdesRm/s45UHEs0TA4PPVB61on/ADInmXR+ hXtvF0L43ggdVB7Y9eO9dNL4t0gWzjVbCG6JUxWKjgwyHPJdf7pP9KH/AHfQLPqvM80msJLpkN4I 9ijyLWEKOEyf9Y3c5J5PPboK2ILK3H+u0WCYf30XJJ90AqHL+ZvsjRQf2Wdz4N+Beqa23/En8Hyh ejTyptABzyzMO1e5+Ev+CeejQMH8U6iZT95tLRVKjPq5HasJa/B956NOKWtdXe6R7roHw90HShjw 54fsrIdC6Ly2PVjWyVLffJPvXRGBzVajfxP0Dyx2pdtWYBs9DTgDQINvqKWgAwKM0DCj/wDXQAYp M+v5UALuFJkGgBM/SjPt70AFHPagBP8AIoyaAEJo+tABR+NMBN309qM0ALSZpAIWHam7/wDPvTsA E5ox/hQIP8/hSE0AGaXIpDEHtn0NJ/8AqpgG7FGc9j60CEI/+vSbsUwPMfjv4oubKxU6ddeVKXAj PH3VPOQfau68LySPZ25ml8xmiWWWT+/Iw9qpv/MlL/I1M+tISP8APpUFCcf400j3oQxhP/6qaZD3 +lCAQn1zSBCemfYetMRS1C6eAgzSwRx9bh5GA2Af3R9a5nVPjdo1uSLRZb1hwDGMAn/eI7U7dyHL +U4TU/jjrkufs93FZIeFSIAlVP8Atkdq5C81WWY5uXkuX6GWU5yPpUyn2HGH/BKru5/1khUeg7AV l3/i3TrYf6TdKSOGjXk/gozWF2aX/wAzzzXf2kXV2XRtMWLHyNczNyzf7MeKwV+KOqynN1qrNngx YGP+AjFapLp8zjnf7V/Ivx+N415khhc9AXGc7vVSO9aUHj3SUQrP4ctHduUu1HNuf+ma/wCf5UW7 tmqk+78jovD2t+CrdCbyxF1djiG2kT5VDf7ePX3/APrZ7x2N5Lm4hs7VDzwAAsWO31ocez9BScvt J/5nY6hrvhOGEReGrpWvD/qb+In5ZBnqDxwx78evWue0z4iaxb7hrN1DeKCUExXDRoo/iIHapfm/ Njp67xa/lO60WK81O0efQrSV4EPlyg/3z/dbHY16r8Ob6eXTJBe589dwmVjyiMCRg+wpqX+Ru4bX Knib4lR2+lxpay/vCPIwO2D1zXg8UdndXMMerFBal1OpbjwYATkM56bh70S/4cmmzvfiDqllqEjj StXttNtLdVttAsFTIvkx0gbH8R49envWHoHiHwrBJ5XjzStyviWxubhW2xtyMFR2k9ccVg+zflE6 It7wi7/FLzO8f4G+A5FZv+ESsJIzkW00J6IQfuFe5r5613wHpELP9mheIAlLcZP+qyfX1rJU/wC8 y3Xb3SPZbL9lHwcbeIyyailw6iZpFI4dhztyP61FL+xNoLj9z4o1KF/vK2xTjjucd6iUX9mxvCsv t049jMn/AGMmhx9k8dO+fl2PGOD/ALRX0qlq37NHiKAf6BeW2qr3j+6WA9FI9KuMpfaG1B/zLscD qXhfUbNsahb6hp8g5Q7SVJHo2O9dX8N/hz4t1+cJpd6BbjB1LUm6QQnuVIH3h0Hemqvb0RlKh/N/ iue/+LfiPp+gQi28HESzkeVqN8erPjq7jvn8q5HwN8ENT1iZm8RRTWunr+81W6k4bU5eflgHYKep 7dBXU12+ZyQ11b9PQ6j4h/GKJV8nw15VtaoPInmj4EUSjpGB3FfOF78fWic/2NA2wHaly3/LZgeu Md6qUkt/VmSi30Ltp+1HqKj53bPUjPUD0rVtv2r7wffkZR/EcnjPoMd/rR7Xz9CfYvojUh/a2mH3 rtl+ueD+XenX/wAb49bKCa43SKC0LHqYx6Z9KrnJ5X1XmNnuFfGZDHJw1vKvWORehjb/AGTXdaD+ 0j4lsht1C8/tCIcQyyAb06/efHIHHvUJ90U49n6HJ654juNRmeS+l3yOcsT/AAoBgBf90V65oH7R dnbxJGpg+RRbnrztHp7CtLd/VBJ9n6nQW/7QdjJ1WFvXmtW3+M1g/WNMdCoPr6ihwRKqvpIydc0T wRrAI1zw/auxyPOUYZWbuGXHI68g14l4o/Y0bLP4D8SDuY9PnwAOv8Rz/OuSpS/k+Z6VLEp6Yj0T 7Hmt14Q8T6YxXxNoxQj5Wki5EijujAdKjivVf7uVP3XDDpXPb1CcP5HoSiQnrg+gqZJs+vsaZmz1 T4LfFRtOuPLvHAtpflQk8QXPP/ode+ePfAkOrWzKVG7G+1k/uSY9vWupar/yVmNJ2f8A5Mj5F1HS 5bd2W5Uq6kxyL7g1nFsfTqK5LnXNf8AY0394f/ZfWk3nvgf0+lIhsQlcdffNOVl759h6/SqIt3Yp I7D6n0+tLvB6dOi59Kf/AAw36Dd6jr+Psfel37f4y3pjv/8Aqpf8MA4OT1Ix7dzUjyg4yPdT6fSm /Idv8xytnq4H/wCqvqn4RRBdMixjktIPcFj/ADramyJI6uX7jc9VZfzU18teMIxvPX0z61vH/gFH GrIB1OO2T6imvdjuw+vp9K5ZeQRXb0L2k6gI37HPyE+uR/Stq+hLKcoCRyCR90/T2pWHB9/Q5WSd V6gccge9UNV8T2VnGXv5hHGPvEAkng/dUetVEbX+SOZm+NekEJ9lkaaVvniiwRhCe5I7Vft/Fxl/ 5c5COxU9CPbFRUXciFyRNWQ53CRT6EdCffHalW/tz0uYy393POT7Vjfsi2u/qOUp64HUAdzUZulH X6fhSZL8/kWrO4BPB6dfp9add3O44GfRfp71rb/gjjfsaELCMcYJ6HPr9KguZgQeuOhP+zWrQ1Ly Mp5UA4b/AHW9vemSSqeDj0Nctu6BL/IQygfxZ7KMdR70GQdxz0OPX2p37hbt6MUPnqox/I//AF6l DxcdT6+x+lJlAJo/Q46c02Rl7Z9PrSfqIjwP4Sf/AK31pSrjoT9PQUXHb/IvWl64Pzgf7JB9fX6V LNqVxH/qsH0BPU/WtL9wUf8AgE8OtQSD/SIMt/e/xqvqPgawu1H2iCJz95Rj7v4Yo9DWE/5mc3N4 HvLAlrK7Jj6eU5GFdj03Ed/xqo+twowOqR3Fo/SO6iziRSf4jj1rWL/nRnO3/Lu3exuNd6lJH/xT 99aS/wB7fjLJ9celeaa7Y6tcXW3U1aOEDY3y8TyNnJXjoD71l7BL4UVTlfr6o1dNsTYD/QpWhYfN G8ZwUPswrb+HPxGk0i8jktHk4by77H/LW2kJzuz6V20H/kzhrx319D6T1T4/6cOUu4wSN8QyOh9/ b6V57rP7QtsCTDKu8jy2YDlkWtZ/8MKm32fY4u/+Pczf6pJD2JJPT2GKxbn4tanIP3JYDPAJ/wAK zczRQ/mKv9va1N953Tud2OB/skiq93J5f/IQ1KKMHgMzcuT/ALNYSqdmaqK/Uqyano8KFrjV5Cij dKY0Jyp9KqaN8UvD12xGk2t3KMblkmG0En0+tO/95dmK/wDJHyMvXPjXdWm8Wnh63jxlhJITnCj+ HjvX3T8Kvh3ox0uyl1PQLWS9mhTU9SkccCWcZwqf7NawirXTfZinJp7s2bixtUu1+yWNtAApdljU dcdgPSrUt2+f3TL/ALZHepaNHJ9WyvnB+SM56FvekDsvMts7Of3an+6v+19KBfcPa2CEfOF/hRf9 o+1NmgfgB1PeZ29PpQg+QoAH+pRSvZv75PoKFI/jXJ7Z9B70gsfOX7Q3h62u9W0yFreL7RKVuL6Q dVs45c/Mf93NfR72u3hY1RAPKtox2jT1+tadPvCo9V6Ec7gIxm+RFBnuT/ciQck/QV8bfFX41Xfi +WVbMNHoNoC1pbjOdRvgp+edh1HoKIR7jXl/hQv7Nmi2cu43lkZ0Ys8VvnAB9iPQ17h4u/ZytAgf QpAhIE88DfwyOekPrt/OliI9icLPVqS9TxLX/CGrQSKJreRIvu3gcYJ+ma5H/hV08l6GEES2i/Pb ov8Ay0fP8Y96Kc+/oa16fZ+aPUo7VkG1eF7Y7n2NeqfBt5BJMFZtu0SMP7rZ7n3rR+Rxy209T1cr juf7wHoa8p+MfwZs7u3kns5Vs5kHm3oXjzx6qR3zWDXb5HoYd6+9191nlXwf+OFxov7vWpJLu1cg C5cktag+n0HvX1Da3ayIGsbmKaNh5tvKveJvX6VrL/gM8+9m180WUlI++oPYMex9hVy1kGDnn+6R 2NZ/M3KEsr4PksW/uk/xE1XWOVQMD6n0Y0y0uxWlQc+YnOCS/pgV4d4mJeVs4xnKr7Y/pUSNY/8A AOJ12AlcSDIPB/2vxrIi8PWvG6L/AHAOwP8AjSprzIn5+paTw9b/APPBfcnvVgeHLc/ej/2QM9j6 iuherMWu6Xcsf8I3aN/rIN3YDPb3+tTR+FrQ9LZQe2CeMVa9WSl5I6r4feDrM3SeZbE9XY5PYenv XvS+G7HvYRn0HPem7/zPuZrfZDh4asB0sYvx9aX/AIRyxP3rOI1N33ZomNHhyy/59YyOm00p8OWH /PjD6kY64p3fVsd/Ijk0GxH3LRB6gVCnhyyH/Lonrn296WvdgS/8I7YcZso/r6imnw9YdrNPand/ zMXyR+ah0+LHDj0x7Go44EOQpKDopB7j/GuX1NL9l5E66YP4pgf9rPQn1qWewQY2TZ9G9KGF12Ko t5DjE74+8MdwKkh0+SQ4Wd17hh3P40WFEfcWcg+/cswHSNv4T/n3pi2jn/loR3pshenmLFZyyE7X X1fPf8KR7eZfvyD29xR6stj5HnI+YqR6D/GiG1uSuYhFt6A5/n/+ulcLEkV5cr/yxjb+Ec9c+49a ieeZyN0aDHzFc+3rSHoNl1luRIq49j0NMg+TpAG74+tP0Bf8EVLyTJxFx1C/T1PtUdzOW6Ruvqp7 07EMcFRetsR/Fn39x71YiuET78TnPPC9QKTL+fmSpexHn7Ox78L2+opY7iEEl4mC9WAXoT68Uf8A DE2fQU39uw+WJhz8hI7D6ioJZYG6IuehXH3gPUe1CKfnc0kuNOIHmIg/vAj7zCpXm0j/AJZxxMTy ox/D+FL5kv0M14oBuNttBxuiU/xn2qg187D9/GFOcjHcj/GtUZtdxHnx0GexP901XllPv6H2FU0Z XHRs+eOvvVuJ5OxJ9D60vX1KXqfan7E+oB7C9XLHbKkiof4d8f8AU16v43gxIpBOSMn6A1NPqb4r dei/I42/tVkQjn6+hHpWXaXYjO0yMT15H3h/9amjC5trz1PHrUuB2x9femNig/X0pSuPX1H0oD0B TxyPejHt/wDWpXAXJA6H8O3/AOqhsn/PegV+wqsR1A9KViT2P19aYl5Gp4fJEyfN3x+f+FdFqcDt I2OvQH0qDWwCHbxuOem4dj7VJbX0xGDMzKflZW9vr6VFu6HfszA1v4YeGNRB/t7wtpl23J+0Og3D js4rx3Wv2O/BlwCdKOpae3JieJgw3H0RxWbj29DVT/mSZxV3+wz4lgw3hrxDaXEn30VzsYIp7kD/ ABrOvR8ZdFH7/wDtwRrx5kAEikewVT2p0523VyalGL+BlCT9qPxM4C69Ja3Q+8ba8hKlicj94AB7 9qlT4x6bKMan8O9Lm43NJbTEbvopH9a6oyT+NtdrHnuDXV+Y9fEngu4/4+NA1ixY8hY2VgB9T6Gr VtpPhRenim7g/uLNCeM+rqO9CpfyJGntf54r5Gp/wi1hOpGneJdNnP3oVdtuR9G9aZafCHWgj5sr ORSAUaN1O5Pw9aiUeyb7jUl5rsef3Pw21W3kb7VpN7GpJKsFbAP1A9aoST31q2FEpHR0lQ9PqRTZ pGP8rv3IG1KV3Jv4EUDi0aPpGgH8QPdq0I2Rx+66feGOw9zUhbuvM6zwlpdhPFmLWTExJBjUgFiO 5z611Efg4f8AQRuHB6tu6H61pFeRhOa6xXcePAlt/wAtb68YdwzdCP8AZGKengm0wRLdXDA8MpbI OPY+tW0+3kQprpGJj6v8IoEBbSGQkEebZyniQg9iPWvYtP8AA3w08RaXts/CZstTQfZrtdjK63aE ZYN0YSZ9/oOlc8o92ddObs+VX7+hyeg/sFeIb1/9KvYbCy6xzvyzAA9Yzjv9K928Hfsf+CtHAJsW 1S4HzG7uOAXz2jFSot7nfzxS9xJvq+x6ip2jEKJGnRY0GAF+gpBGBXSl2RwSk/tMdtpQf/1UyAwa XHrQMNp70uPQUAH40flQAUf5FABij/OKAAj0pN3rQAE+n5UhoAPpRj6/4UAJikzQAZP/ANb2oz9K ACkLUxBn0z7GgLSATHrRQMTzKTd9aYgxSD/PuaADP1o/zigYv6U0igQEf/qozQMM+lAH0oATd7fj 70uaAELHvTf85oEfM/7UGrTSNEnmyW0Jys2MfM3POD+PtXqXwF1rTptIt00q5klEOdMmZwRjYTjY T1G3HQn3rFT1O6VNKO3mz0Y/X2prPWxxDN1NZzQIZzSiMkZ4A6s56KB6k0A33OW1z4u6PZAbJRey dGt4f4AP7zVxOs/tBajMCNMghsE/im6syD0+pq/UxbfT0OCv9clun3XlzPcv08yToPotV5JpG+8+ wdT7/wD66xlN9TojEqXGpW0OftMyjsM+vsBWBffEiNf+PGJnPZ24wv0x3qIr+Ybf8p5r/wALN1i9 1Bo5dRIt1B8q2UABmA6sQPWtjVtPh8tmWICUfLFcDqI+f61pJ9jnX/BOLmv7CdiL+3WKQHaLkf8A LQf7QA9ami0ZU+5tdeqOv933qY+Zc35l1IoR/CnqT3/P2rrPCOlW0rA3ljbzRr87K54cnP3s+mKt r/I5ufz8yTxTeaZcuRFY2sIHyqIAANo9cetY8GhK3/Hvern+GN8cE/7WO1HK+hrGr/MdfbfDXxNY ost34csruEBnUxuuYwAckgc/u+c/0rntFWW+wrWxSaQ/Zxak5LSuSMfiawm39qLOuMV9iafR+R9u +H/hfa6HpS2trEoYIWv2Bz5l2+STuPo3/wBauK+G1zHuuY5nKkxtPtPaRQen0q4L/MKsv8jxjWdY kIId8KCSif3ef8Kj+Hnh2yvrz/icWkVzCEaR4ZDgSSnp+VOf/AM4rz80e46d8MPDbI5j0GzDLhol Bztcn696reIvC+n6qu3X7COdQPKtQetuMH/VsO4rnnDu35HRCqzzC6+Hvizw4rt4S1Q3unHLXWjy EboFwenHp6YrzDUfEa3anzIwkpYMUB+5z3OB0qoy/mXl6hOC3h1+Jdj6gsLkMsYYMGRFhlH92Tb6 1orq3BHPH7tWx9/6fjRcz9Atwx4ji95XPY+1StahDkuOf9WM9AvvQx+vyLVv4eudQbZPZW08fSRJ ACAmOrEjsKwfGPxN0bw9EbbwBawRynJ1GeIfdlcc8gdR/wDqqqcFu15jnOW0W9TmvBnwC1XUnSTW Lz7Pag/adVnP35x12oD03H6/nXXfEb4xRqPI8OSmKNR5Ms0f8Eajoreoq4PqyKkekf8At4+bvEnj aKdxHaXCqDl5get2ozn8AayVsI+jwRt2IIHOf8Kzn6mlP0fcbD4YtJXRfsaMzMIEAXoHb0A9K+g5 fgJ4KjAF14Ws3PCySLnO4D+prnlT7SZv7S3wsrP+zd4ClB/4pvaT0dXOQPbNVF/Zg8L2z79BhvYp VBWKLORKxB65HahQf2Wy3X7wh2PPPF2gTzwkW8kkU6N50Lp1V4yegHt9a2/DcUFzbbhrEdzcINup WjrhomA5wD1wf89a6l5Ndzg5e6f8oQpuzhTnB2/7OQf5VxFj8GPFV25/sy6tJWyXVXcKXBOeAR2H vTrS7XKgl9sl1L4S/ELTVZ72xdoh8xkikBwoB7Y6CsnQPGXim8k8vRIL27nwZfIjGSqJ13ADoKin Wf8AKx1MPH7Ml2RvX3xN8W6awGtWF5asfnSOVG+ZPVcr2xUlt+01qaYzI/oykHk+xIrojWXX5mFT CvozXX9qq8kBF4kMq9JEk7Aj1x3FYl/4+0S6OYtOFu/R3Qn5jjqEqZpdBQ5l1foZy6vbE4E+P7p9 qto8o/1WJV+8CO35jvXJNdzqT8vIZB4vsy+z7RJBOPnRWBB+U9Y3wPun0NfYnwh+KKatbbbiZDcx /wCj3iDrtA4OP9sVtRX+ZhVX+Rwvxu+FRQ+dp8Iwfl1AL/dweWrwqVMdDz2HtXPUX+Z3yei+4hYk /wB32HofpUO8nuD3HsBWZk0M2g/6vJHUn3PrSM7c4OMcMo9KpPuJrs/IYbvH8R9B7/8A6qab4n0z 0qb/AOYmv+CDX7dsemR7fWni6lH8RPoPUU7/AOYorzInvm/v/T6U03spPyyZHbPb6UnJl/8ADCtc zAH94rYBK5PVsH2r7P8AhbaBNLtcEn92JGPqWzXTSIqI32YHIJHQjHsVr5k8bLiRsD1P6ntXQhI8 3u5VXqc+n1qubpezA9ifWuOZovQkS5VDkEcc5Hb6V3FveJKgKgcjdkd8+gql5ibOR1q3aJzkYH30 B7rn+lcR4n8JyXiHynde4K9y3+yfT6VHN5Gtu/qQ+HPhZpFpGDfK89yR88pAypBPQkVvQXQhGIY1 A+7jA6Z7nFS3/MZN9vkPOpMc7oFJPyNkdV9mx2rlf+FY2AmLoZg2fOaLPDs3XI9/wqU+3zKv/kdC 6gevoB6CoGY/wj3qRFqxmOfmOT0x6fUVMZWZ+BgfxsB057fStookvi4PYHHr6/jQJQf4Ceox6HH9 K0bGl3Me5iYE7VOB98+je9VRcxA/NNGO7AnpXO0E2v1LKRg/6l1IPEf+2PY0CJh94Nn+IHsfapt3 QlJdH6irG3dWP8QpCuOvPfjsfek/+AaXXcVCDjAznlR7f/XqQIW6e/4Eeoo9RJryLVvabvu7T7+1 aX9m2wA34Xvvz1UegqlH/gj510sZV1DEjYtZt38UZ/vD/wCvUsglfjCnsvufb6U0huS6GNqr3Vuj tChkZQZRADzIyDoOO/0p/hzxbFqEWbW4kSUcXUPeCT0P0q4R7epDf58jMzxf8OrrU0VTrt5CoO6W EHiU/wC0CKqabpFzYoEnkS6QcJHJ/Eg9cjtWd31XmdFl0Ww2XTbGPLafPJpzcy7eoLZ+nc1o2vix JQBqkcEoxuhvIzncmOwA7iupS/m+RhJfyrzfmZOv2G4f8S+Zdp++PVTnpx2rH0jT5Y8+aV9z6k+1 Wn2Jt5ebNx7dFP7+WRj0KY6Ae1VvLth/yzHJ+RT/ABPXNUq935GiXa3cqQNJdqw021S3mU7Ikm/5 eFHdG96yNQutct3i3zpDg7Lyw2j51558wj+A+9Tz9vUqUez8maF8888p8tRcwqVMhXO2UDkhsdiO vSnHQrK8kdtShUcGWwtTjCu3dAf7ufT6V485PpJ90Ql/kyre6dC0TR+cIt37pXH/ACzX1Un0FO0X w/Z6aU+yW/2hUHnl7gf8fT99yDsT6VcKr69dS/L7jN8U2t7rMpxHDBn91HtGB8xPtwAPyr7QvP2k LfQlsraPRnuY0t4bS6us4/eBQP3Sf7YwRzmvUoYhJe8+qb/E5q0G3o9k2vwOqg1+W4udwtgibcAZ yVJ9q13gA6MSfvY9BXY32HHzIjc7R+6Zwem3B/8AQqUTZ6hx/CzN3b2FBViTyF3ZkVF/hhc9XOOw 9qjKMBn5HY/LkH/Vr/8AXpfMCQQOOZWB/uD+6BT4o2yPu+uD3Pv9aAt2PlDxv4kln8XQm8n8xEZb GAHpGpQcRj0ya+rijZOAW54J7iumotFYmp8WvZNHj37SvxPfSdMMVhcFLq5P2OQqeYbDvkj+/wAC vlq1+IsWnaTLbWFiHupWUXV+3HlWaHOM99x+n49rox0/IqpF6cq/vs6z9neDWlu0NucWO1lYf352 7rX2HqZiEi+SQxVQGI5O8en0rOs+3octGLu9+5xHx3iSPT2uJZIonjAgs7U/8vUkjfw+7Njsa8H+ GMOq+I4Xe1tFUxnyZiDjzWIz8gPpWMY6fij0JPRa/wByXob268tHI1S2ZQPl2nqGHt7V658KNYtJ TKYpFLnHkw9CUH/xJqovyMK8LdND0wTAdVyejL6NXFfGXVkt9Ml3qS7lLSHb2LN3H0osaUXqrPzP k02jf3Tg9iOg9h7V3vww+P8AdaJKE11JbnTmwjAH5rZ2PVBjt+tOHn6HNWj2/wASPqC28Q2lxgxy oqfet1b+MY7ZrWtryIDk59MdxSt/kXB+TKsg3fcRh2VcHp/9eo5luOAkMhH3i208Af40+U1t5EV0 JipMsEnQoq7Txn2x2ryy++Eev3blrXTCEPMJb+Ie4xUSgaw8yhe/ss+Lpx+502JOctvY8qB24p0P 7IPis4/0a2HtuPT3OO1XGK6yLcV1ZpQ/sc+KX72qjuQTyPc4q3F+xr4hP3rqDHYEdR7nFapLuQ4x 7+ReX9jLXO99GPfH+elWIv2NdXH+s1FSOgAXqaat3FaPdm14f/Zd1OwlV/tPm4BTysdd3v713K/D 7VP+fdB6DP8AXFJ+ZlNLo/Icvw51U/8ALGIeuW6mpP8AhWWqHr5A/HvU3XUXKv5hR8LtS7ywD0x2 p/8Awqu/P3rqEevuaLrzCy7kZ+EF6et/Hn1x1B9qkT4O3PfUlH0HSnzLsGnmPHwbk/i1dvYADr+V A+Cmfv6vL+AHH4Yp8y7CuuzPyttfD1oyDcDk9CD2BqQ+F7MH5EcN3O7rz6VyMrn7JEF54dt16b+o VsnufanjwpGety4P8QPb6fSk/IFLvYkj8GKB8l9KR0GAOB9feqN7oXkEFLyQk8c/wkelL5Ck1+pX ezc/eunb1B7U6KykYZjvSP8AYx1+p96q3cSIYYrtWPlzY7sD2/H2omhnZhumUf3D6n3phb/gD2in H8SY6MMdRTf7QmQYCqB94+4z61LF8gR5jzGqsP5D3qNi7nhVB6Z9/p7UylEY+gTL6Y+9IR6mnrcy kcQD0BHfmmv+ANrt6BDJIrfPbO56Mg9ff/dpJ7xwwMsLhemMdG+vtT/4Yzt5odFqAP8ACSOgq0+t cAGDAHy5/v8A1qfkU0+hb07xDHEuHtWbnIwOnPb61fHi2H+G1f2Xb/QDtSt5DV+hVvtXSQDZbOD1 wF6Z+gqj9ojH3o3/ANrKnk//AFqoVn1fmOjurYjhST1wB90j/GprC9sVz9ojJP8Ayz3L047Uku40 3/kaEk2mOv7tYw38DKO4HqfWuZupVLcAegq4ephN915CugHcZ/pUMhUfeHvkd6tkIYkh7Aj19qtW 5kH8Q9F/+vQCPrz9iPUB/wATBC2SfLuMe6If5V7146gP7sn3U/Tmpp9dDpxK+H0X6nFumRx+XpWH e2zrzErEjkj1HsKDlt3Ne1fIGRk9x6VaIHYfUUFMEXPXJ9RTsg9sdh702IFX1/ClJ9/ypIYsZ/vY I9fWlI9KGAq49P8A9dLn/wCsfWiw7F7RHPmpx35rrdSm2u3DMeox2x6UmX6fIrwx7cmVizHk/wCz j29qjh80k7mHsB2FRfyHYllbg/LjsT61hTW56JGI1Hdf4z70hD0UnOzcew9vpVyO/lQYikYHp16D 2pW7oZ5r8bNBsLm0/wCJhpNlJJkPHMUG5Vzzlx7V8wXnw/tsf6NNLCeh2Hsfb2pNdjLm3vqUJfC+ oxZ+y36TjoscnHA/2sd6gTUtTj/1+nsoHAaPJyPpinCo+pDgvsvzLkPjiIgC6jRv4TFKvQfTFaen a3ZKTsjkVj0eJyCuPTFdUZ/3mjNx7+hpWfjvxBC//Et8Y3yJ1jhlIYKP+Bg/drQuPjP4nLf6eum6 mvRzcQrzj/aUCq5e0V6k+kmu5PZ/EbT7jjVPhho8rN+7SWKRlCsw6sn+z16j2rmpvAWuW0jGwhia 1PBsywygPpj0+lZcvZyZspP7cl2On0Twp4JkTPiTUrnRps7VUqcFveRR6+uK6S1+D9ncj/ilviFb SD+GKSQcj2Bx1p2fR+iHKa6w9WVL34Q+KLbJltxep628vJAHdB61teE/hDqGqttttB1mFhxLJNuA U47Mw7Chz73NKdD/AJ9uNup7F4b/AGItPjIbXtWuz/E1mjcM3u49K9h0vwTpNkFGmaVBEVHlJNjL Mg/vueuKhR/m+R0SmlpSSX8z7mtgnrk/4Uu0VsctxcjuKXA9qADHpQB/n2oAXFBFACg//Xo/GgAw KMCgQYFIQB/QUDF3Z/z2oz6UAIT60mKBBj60ZNAwz/n3pM+v40AJ+VFMQgJ9PxowKAEP/wBajH+F ABmjcB3+vvQAhf8A+tSYJ9aAF2jv/wDrowO/5UAJRj60AIT9aC1AxN3tn0o/z+FAASfT6UY/z70A IQKbkf0/GgQ4f596bnHU/h7UDF+tNIx/OgD5O/ai1JmvUQRrIu3LI3QyEV9HeANIhs9OtEt4UiAi WSZFH3pnGSW+pNYW1O+XwrXrY3jIewFIT6mtzzxViZvuKSeg+tc74q8YWGnAG816CBwcmzA3G5U9 lx6U0uxLkuvocXqv7TRAxpGixxnqlxM2f/HMVwGs/FvVr/i+1CR1+6YI+FBI7geoq7roZpP7RiqZ T1xH2wP6n3qC91jT7Rd2qajBAo5cuf5KKxbfQ1bS+JnA65+1PoVscaRbzai3RmUEKD/vEVzl5+0X NeD/AEMfZmyAYSOqZ7yNT5O5ipt9PJGuNWilAK3KyHqcEHHNOlm2clQTzwf4mAPQVl6+h0KXZnmf gqbzL5mUybmDuzt3XJ/nXpmrMRbvjI5AK/UnoPatDFnlV7Zo8jZG7kswz0P0rY02WRBiCTI6FT/E DSSJk+69SxPbwdWtpd38RQHqT6D1re0rQdNCt9rkuyetuitwGx/EaaXmVOP92L7EA8M2OThDjquT zg+prsfCfwVt79svItvEOZpg2DjPocdSKqSf2WzKMl9q3c9Jk+GfhCFQIL3UruTrtWQ4bA7gfSup +Cf7Peni8M8+jNDFD++tDIf9beODjcAefK688ZrCcX9p+R1Uaq+xCC6nv11cF2+Y57Eexr548V3V zpd1J9mkKOCYwOzRyD09/wD9VbRHNHk2tagBneckktj1XJ/lXWfBvwDoGvLI2osX2kQ28atgsgBz lTz1rF36PzKUkt15HuPh74Y6Vo8cv9jWksO7aszMxOQufu5quYZH+5jA+Yg/xH6+1S/MtSvtYrXo xGfMVQSCFX0JU8g+1fMnijwxBvJidFl3bVcerk/ePtUehVzotM+MXinw7MsPiaK31GyA8wzK2Xih ZeNjqOdgx/I17H4e+IGi6qm7RL1ZedssDcNA5/vRmtN9l6mElbrpuvI6OJGA+UFf4DntVm18MyXr gWikn/lq56Qr71KRqip4v8ffZiLP4fI098/7m/u1/wCWKd/n5+6Ks2nwu0DSkX7XZw317/rL7UJe rzHn5R/smtnHp/28zNS6r0j6GP4n+MNtGhjtyYXIKDZ/CxHU49axdA8HW8Sk6hbxzlxveOQcfP8A 3vwpVV2YU5dX8jJ1f9nzw1eNvt7EWVwMpazxchUPXCt/e+tcVqnwR1eEj+zGTUF+8CvBX6piuPlf Q9BTT+NeVzlLTVZ9OvYhq+mXUKL/AKTPOVP7mSM9hjqK+hNP8caFqIH2PWYZXJGU6EsfY+preGvw +py1k18UdO5uJB5XDoM9AfT6U37YVxvjU46sO5PtS+8lPszhfEFibG5SR4kKMRNcRdgxY5DY9qPE Gh6XarLLaaSIp5yDKqdIE564/vj8PTFaW2+4d/8ANnBX/i+x01AdVLorEW8JUZ5OfuqB/CPpVyz1 OGfDaPe5P34pU6qR7H0rRrsYN9/kdBqXxXvJLZku7bM2DCtyP41I6lfpXG/sy3cker3HzHd5LJu/ 55sX7H6VMUr/ACLtp+KPTvjpdu7wCXD/ACsfm7DPb614hqsKhOYY/VflHAAPfFRKK7Gyfmc+NPhP /LsjfXsx9Kc+ixYwsS/7Z9RXM/JvszX1A6Mq/djI/usPT61IDLFzHI49B6Uer8mTJdkjRF+jkG9t opyPmiZhynB+63uK634a/FeDR71XieaFW/dalFg4mtR3B6fIaqk9d/UzqJ2/I+07mzstUg+cJNDI vBH8SSLXxN8QfhzLo1xIku8rn7RaMf8AltbsT29vrRio+b7G2Flda/4kcBfXzyfcLxj+4vdfcn1q ukhXkyMP4Qg7g+9ecn2Z0NeRd+0z8fM23qB70JFNIflmZR95iew/2R701Ls/IlR7otXVgsrAi4MQ 67PdfT/fqEa3pvmbHvZUbqsZU5YL6MB612RRzTXa/mOW/LEi2LPzhEYdUHoadLrwC/KhR+hRuxIq 2uyJiuxXHiHggw5bGQfRsetNXXCPvLn+h/LvS5e5WvX5itrj7W2xAcE7s9gp7Yr7r+F10X0mzJBG Yl49wK6aaXTy/UymbW7J/wDHT7ZFfNvjyIrK/Pcg+3J/lWqK/wCHPGPFclwpH2ScoOSTjocnoDXO 6bqErSBL3UpnkOZQAvBCejAd/rXM1rsu45fM6lraVf8AaHQk9cn29q6vwpcyBWWebfg7os/wq3YY 9KP+GIkcl8ctN1BbVZtEu3SSM+Tdxr/FbNntjs3tXmFn408apCGC2VyCuUhI+baw7kCs4yX2l5nV OndLV/yszr749eIbNlXUdHszkb8buqt6ECib9o++b/U6HagdJGLnJx6cVuox8zidN/zPuDftMaou fsumWyH7zPJzlgOwx/hV3w38YtbvtxuY7dADkui9ZDn27UpRXQSj3k+xuP4y1I/emjUfwsqjkj14 pg8V338U6nswwOSPasX6eR0qHm+xseHNSvJy3mMAo+ZWIH7xj9BWxpuvee7qsPzLhZSO7N7VcTNr s/U10Mv/AC1hYenuM+tK6MfuxlfVvQ+59qb8kEfNniXi/wAfuZHS0kkljyfMlDfxrnhSP7v4Zrhr d52PyzzbidsK5PylvQ+1JPsbSXdLsd3b2l1YErfvJEwXfbZJ+bceuD7/AFqSPxPeqRjU7kDozDHC k9hj+GuVT7kcvku4xvF+uPuFjq85wdqnaOF+uPSo21zUxET9vkd8+U7kj5HIPYegrCcuy82UoI52 PxbqMEgNxf3Fyg4kAU43N6BR6/jXVQ+M7sCQpboV2G4mErf8exXvF74+v0rOa13fZowivLzM8/EJ 5duy5lt12jaoBPnuT6kd6SLxNcqx/wBPuBniOIk4Pr9MCnr1ZXqjp/DMVzfzKIrlniX95csp+6ew Ndt4mvpLZAsEwSVz5EMo/wCWCHPIU+n5VrSdk+d9dBw9PI4eK4msn22d28+7Jvr5v+WuT2UgdR7C m6bMtnIzx3HlHHmSIoH+kMxPU+351z0sQ/tfM3nFdDuYvHWlMmbm8MJxvlDj7p/3/esq41jSpmBW 9DAriGPH3gffFdiqLo0Zxl3T7FDVdW01YyBJ5mSEEfqD/jSyT6bDj7LYmJ1Xy51bgKx6dfeuetiP 5H6mqfdeZSTU42DNNAyhf3s0i9kAPQD0qS1uopObcq4/1mwdgPUV00at/i+ZjJro/ImmsVuM+Tdy 2zngkf3vbI7VvWWgaOmnBNUjlfVBN9qttRwf3mnGNuMjgBST2De5p1qX8hpCXl5P0OC15WS4RbOb zCCIreReN7MTyWOP1xxUtzqk0mY9Yiia4DYs7voCo7O/1/Kuag/5vVDiu1/LzR0vgXwTfxSOltEj TSKyraKwIndwehP4E+la95+zr43bHl+G58nEcrqf9UB2Vj7++KxrU3e8YvsjWlTTv76X2i/H+xz8 QJkVLfwgrSFvNurqVwNsHPALAfy/pXTf8MQfEUZY6PpaNt+zQJJMPkXH8Rx1B9uO1JUJdYs1VGK+ OrHyIB+xL45RFElnp7tkTXUqy/fkU9OFPB//AF16tN8FNc1K7SXxNpFtFHEEttLto+QEgYnMi+rZ 9ce1d1Kh/NffmMqkV9mS2aO80/wbexSOyWj4bhTjoCew9qvnwvqBP/HlKT0DDsor0rHNyeZIPCGr N1sWUdFYdSKVPBOr/wANop7Rg9gP7xxRYdv7yJH+H+quBvtMHpvHbP8AdGKP+FV6ngeVGid+T1NV yr9R6dWieP4X6tn96Ym/hRSeFzUo+Fupn+OJD90EH7oPpRZC07nn19+wDot1d/ab7Ubr7buF4jKR hZY8diPb1r0v/hVl5/z9RjtuHrVuXl5IqpJPdf3X5nP+Jv2TdF1vb/wlcKXpXm3J/gOe/wBKy3/Y D+H8gAutBgcdQB2+mKmL7G0cR2SN3Q/2S/DGmADQLSO0UcKqDsff3raT4IWQJP22XJ/1jY64HYU7 9zCVVfykWp/s7aBfqF1+H7fEPnS3nAI3Ad09hT9M/Zy8K2QI0bSILJT88kduoAdh6gelCfYTqrsT XnwB8M3IxqOmJP2V2xlD/stjtXm3ir9h6zOX8Eavc2NwPnhgfGHwDwsvGPm9QRUPyRvSxC2rRTW3 ocD4Y+Mtxotz5HxS0q4aIN9mOrL/AMu7Y+9Mo6jA7ZNa37Q/irwe1rbroGt2NxI7+fHFbSBi8Cjr MgPGDkcjr261pzf5Mxpx5Ze9qvig/kfN+o6hbop3n5v4QR1H/wBeuT1XSdSWJZpUVYGbdYBWGZhE 3Py/7OP6etKPn8jL5n6N+ANM8MXllbS+dYXpMSN5xIxHME5Hl/8ATJsjkZGMV2Ij0ZOgsV9AMcfl VSXZ+hzUauis/Ieb3Sl/js/9kADk/QUyTxDpCn95PbA/dIK9Meox2pWfc15/NmZrPxE0G3Ci6Mco Y4KqPuJ6tmn2fxN0WX/j2Y8fdIUcIo7Y/uiizBzfclk+KWhIMzapGi9Czds+p9qY/wAW/DyrufWo BF937Rn5c/71Ll72FzPz7Ihk+NPhlV3Sa5biI/LHck/K7H+63vUcfxw8NO+yLVkeXb9pWJepgz1+ hNHL6Cu+xYf4q6UOkrn096jPxe0ofxn6570+UV30sM/4XHpX94/nUb/GnSV6k/XNPl8wuRH446V/ CD9SaY/xz0v+ED6Zo5fMLlSf9oLTk6InpgnvVc/tG2P8MMR/Gly+ZRFJ+0hbD7tvD6Ak9/pmqrft KQ9MRqexoSCwh/aUj/6ZZ9fb2pn/AA0in/PSMf0p2Efl+lvbqD5bbT1bB6t7H3pFWHd87v04wTwf euW3mdDfdIteTGR/rZMdU+b+L3z6VFIGHW6kPoM9KdhN9ku5S/ta5QHyrub0AB6nHtTvMnkx9oml bPt05ppeXkCXdEjWrAfu5iT1J9SP/rUtrE4GftJUd0x97/8AVSaEn39CRNMkb/V3fX7wI7D0qO6s 5YwC0xbui/3eaaG/mK0M56SKTjgevHeqTwyE4Zhnv7GpFb/MtJaSxjCkEHnPpilkhmXGViH/ADzZ f4m/2mpr/glf8MOaa56OiemQegNRQiXsq+nPt6fWlbsQ/Uc5nVuI88dj1x60ty8zrzbgZ+4M9M0N jt6D10i6Uc2ee6n+8fr7U6TSLtulm4HQse30oTLce7RHA7pkSQEn+FvQVYi1ORTkw+yj0+gFN+aJ 9H6Gm/iqAAeZA4HRmx/F9KivNahkJ2wMvdAB1z7ihegnfuRW+sW0ePNiIPVeO49auDxDZN9yBSR8 smV/iPsBRYSv+hUWe0V/3kOeDuIH3WI9awrpQW44qomc1tcuXNsduSo9CPRvpWa5J6qPXPoa1RDX +YLL/cGfXNWIVYfebHfHvQC/4Y+oP2KtTK6jcoQoDQmQY/jKEdvavp7x/NHHEjS52g7WIHTdx0Hu aiPkdWJ2jbtb8WcK91GMBnwTzEPUD0+lVZYx3z6E+g9qRysgsZpFYiTJGcxk/wB3/wCtWspI6fUi gF/wRyD/AOuPWl5/pn0FMAAP19v8+lPye4FKwCInqR9P/r04D/PvTY7AP/rE0u30z6ZpDLmkyYkX r14xXZ6srCQ7FHqze1JlFVFBHzY+voaLeMc4HuT/AJ9agojmJwcH6CskiQ/ebA6Z9T9aTJJYnA42 59T6ke9VprgKSQcMPl56HPv70DZxvxXsg9k7MMtlUgI/gXdzx7186z5zxn1A9DSkYFSePHTBP+e9 OsnPYL9fQf8A16Iov0XmadxolpMp+02EEh6MWA+asS3+Gumzkkb4XAIEieo9qpx7ME+68zBl0W8h kK2t0JMcDfjnjufahdXvoDi7tge7Oh6/UVopP9TJpdi9D4thb74OevzDoAe30rd0/XbB8efZl+0j I+Mj3X3+taxn/N6hbsjq9NtfDd6dkenXLuf9VCwJyQD/ABAdRg16Dpv7BlxfENEx0uHqfOweDn7q YB/UVnP+6/NHbSh/z+Vl18z3Dwb+yt4X0XBi+13kw48+RyAx/wCuQNekJkDCYVegVewpRh/O7hUq f8+4pIUIO9PC1qcwA0YFAC4ox/8AWoGKBQBQAc9/zpcigBD7CjB/z6UAAx2pTQAA0Y9f/wBYoATF GDQAlGKAENGDQAn+fpQTQAbaTI9aYCfSigQmaN4/wosA3BpcUAGaXce1ACbvWl3egoATj/CjHv8A jQAn+QaQ5oGJk96A3+fSgQu71zR+FA7iYHcmjHpQAmB7UmPU0AIXApu/NAHx3+0LqBk1TGAf+WK5 7AEfdFfXFhYmKKJcHiNI8e4Qdq5ovV/I76i91EtxPHACb24igTq0kh7D29q4jXP2h9AtONPD6lJ0 /dnARgP4mI9frXbGPc8qU/5EeZ69+0D4gvciKdbOI/KkNv12H1lrjiLiU5k3M3eViSWJ9SfWolPs VCn3BoIh/r3UkfMSf4T7/WsvU/GtrbKTBGZmzwi+v+97Vh8zZ/3fQ47VtY+JGpKT4Q8PTC2/1cl3 bLubexPG4Dt9K4a8/Zv+Id0c6j4V125k+9Izo/zfRStHtf5Tpp4FvVziJH+yt49b/U+A9W9hsYcD /gNH/DKvxDPTwHq//fDcZ9flp8/ex0/2e/8An5TJbb9lr4kxf8g/wbq0RHGVVs/kV/pW5B8D/i0N v2vwTqFyFOV3AjII9QtLn/4BLy99KsDodI+APjQOXl+G1/aycl32H5kb6D+L86m8QeEtagjZNU8P 6nascN5jRNgKp/vgfxCp5v5mRUwT+zKLPMYfhlrF3MV0+0eViSY0yBuAHYMB90V3Fv8AsiePRjzv CmoBeoOfv5/vYHehPy8zCGG/nnFdkyS++Dus6Lj/AISTT7q1Z/mtVlz+8Rf7ufTFUptNZv8AV5Pc AensKafkKcLaadiDwp8MNY1e4MWk28s1xhriONW6WkQ5LE+nA9c13MX7K/jFODYakvYgMfmP+0AK fM+l+4qeGT6x7WOo0X9kHxOhBl1LUrM9xGTkZ/2iO1fU3hLwcui2cUIvJrqUAHUL2Y5a6nx1lYY5 x7UrvqVOkl8NuxpW8RY9M9yPWvA/jPcRz3oGmpvkYC38tf4p89hWhiSt+x/YShf7XvdUaTG6VVQD bMRzsyM8fWqrfsW6WGH9mX+r2ZHKXMY5VyewA7mubXpbujtT6OEfMki+EvxT0jd/wjWsHWLdsLNa 3a9UXP3SR2HvUMnxY1iwYDx74F1TTkGVa7gVmUsO/C/xfU1pzfz/ACZm8N1w8l3cTodK8d6JrS7f DupJNJhk8mQbSJCvdXx0zXn99+yF43kHGmWvLedPmT7wLeuO9E4/5mdKz/iO3kcH45tpDeSpd2aw umLKSHOdrovPze5rj7rTr21O/R72SylXmG5TqjL03H/61TzdvUmfZryPo34B+LfE3iSFv7SgjmER FlPqy4AupmUkkxf7K46V2nj/AOLaaaBa+CENzqMh8iaaMc+Yey+6j8BWya3a8zJxeyLngv4fW/h6 Ite3CT6lJ8+rXhH3Dk/LH/u55PeuK8bfFkREiJtz/dQj+9749K0pL+b1ZFaX8q/uo88063ur+YeV C88zNtRF5Mjt2Uf7X6V9GxfDfU8AXFircYk59B6isqpvSh3a7D5fhlqB/wBXbKx/gVj9wkduKgj+ Fepqci3Xd3YHv7D2rO3+RvZfzIS4+EmoTgDUrKC6TOZklwflPYAjt+FcTqv7E8NwxawjXT2zvt/J P+pIPb/9dZ8n8rZtCa+3JNbWKUXwD+J2lg/2JqNlqcXU287AHA/usw7jjqazrj4u3mmOV+IHha90 1h8gnRWZWYHqrKvRh36VrzfzelzOeHW+Fku7ib2q2VlqNtu0jUrW7Vl+0W/lMCYmUdJF7VJ4q8S2 Y0e3Qyq127CW4iXkxrFuyXP0xWqj3OJS7J/ynz18QLNp/LWORVCgyunqzE+vqK4Wy1e8sriP+z7t gzMtk9v2dpmxl/pU37ehpby8z6r1v4Aa9ZR7pYFuowN1xNEc7cjunp/k1x/gy4sNFvPP+ykKymzv 9g5MTnqQB/Cazi+/ozScdPcfl8z1zxN8FrjxKIpNO1KNIQpFvIhB37z6H+7XOXX7EeoTKB/bUS/3 nI6n2GKuovMujKH22+zKi/sGXqj5deQ+o2j5gPwpR+wlenrr8WPTYOuPpXOoPudXPT6Jin9hnUO/ iCP1LlRyPcYpr/sMXXOPESn03oPlz6DHal7N9wU4dmIv7C9yPveJFz6hBx+lL/wxDcY48Qp3UnYP ukduO49qrk8/Ji56faR638N/Cmo6JCsWqaj9siHy2c+P9VETwp6/6se9Vvi98GoNaiXynSGcHal0 R92NvWtqivv6HLSaT93bc8F1r9jnxLbZKwJdx4xuhIOWGeSmM815lf8Age4tmxdQTKRw6Mp+XHuR Xlez7r0PRlZ/wnfyNvw54X8O3su3WfFw0YdIVmjyGP8A10bHQ/h07Zr1zT/2KmJ36P4ktNRgPAkK jDf7hHt9a7o0O1jz411tWUvU4H4s/s4ahoCedJqMC2+djISMIwBOBnB5H4V5TZTW16oe0lSQ/dbj oPVG96zjHv8AI1rW0cH5MXayddykfMT/AHcVbvbQSqGhK4/5aL/ef2+tVbuc8v8AgGPlgeeeygds 0uw/XuR9PUUNlf8ADjppQFOQehKgdzt7mvv34axbdJs+g/coePdK6KWz+X6mczWDc9fxr548fw/v 36Hkgexyf51tEaPD/F0TAj5mHUDHcmuYt7swsCSTj5mGOq4PpXLNlnb210kqgoBjofY+5rV0y5aJ xxwfkz7+/wBKPmZPzOh1fR4rqGRJow4dTFz2OD0H1rwu504wMVK42/uCPQrWMl5+R0xemnqcz4l8 JLfp+7wkq58pj/y0HoRXnc+hX0JxJYyg9CMH7vsQK0hLuxtXLdv4WvZ+EtnQ92cEbVHuRXdaBpEd tEBFnP3rkn+KTJ6fhVNkNd2aRX/Z47//AF6hZgudo993oKyYjv8Aw1piQW4Z03FsyMD6nNM8JxhX lIUbi2ZH9Rg/yzV3MXsdVtz0we/PrXAfErx3ewxGLQY0Nw3F7ODzbx88Ljuaq/ccEeK/8I7dgDNv JuPc9z/tNWnp/hWVfmydw+bb/wA88envXPUl2Zs15l3V765mAN1cmRwPLDN1EYz0+lWpltI4k8i6 kllOTNHt4iA6Yk7l/p/9bz4vt6Mx7cq8mSLpp2F0u3TJ8p7VeryYPPlgZxj/AOtVHUNOvpI2Ftac qDdmZeqoo/j/AN3/APXVq36I6Lf5MwPDOpuVb7Q+GB82FmH3owD936mnXevPOHNxjzM4hVejQkH+ ED1xW7hrp8jnj/e+Za8NeH7ufDRGMsMlreT+DPdAR1/Cr2peGrhpUE6AAlYJo0/hldurfQe9YSnr /wCSlW7+h7b4a8M2mmRMcIo5mvJl/iRB2B9a88HieXU5WkUSIc+RpwPTyEJwdxHANGKlZfiy0vLy ZNZ+H724aYvOkUUSNe3Dj+KRTjCk/wB4+n/165Z3uiRthcZBlAI6xLnqfbmuSL8l3NJevky/Hrdv JHtmQMeFYHoQD2//AFmren3VuzHzFAAUpbN/dcg9RWc0+jFfuvIrvqARdskcDniSCbHJ25xiSqvi jxAZoh9thDMcHzj1Mo6bFFKlDVXfmV6IyoJr3aVv7q4iQAywLyRlRxgY6vx61o+G723to5HN+ftD gJaK4+6i5/h/2K7ZL/n36GHJ5eZu+F/G0l6xRoI5mRWnubkcbFjHcY7102geN4rnIngCMD5e1+61 3U5/z+qFfz62Nq88G6XckFbURyf8s5AARn1VvcZrmNZ+GdzDBKbeUzvnzNNjUdZHz9446KM/4GlU p31idMJdzP8AgJq8s2sWp8T3E1rBG4i1NjwWUg8FsdM//WxX6Sai+nuR5MjLGMOFX+Mfj6ivQcNE cPNZtFh/F1qv3AfQc9AKE8cacP8AWQF/cnpWkYibY8/E3TE+7bqPy/nTT8X9NX7yj3wafL5hzPqx rfGjSx2Ptz1pn/C7tM7qfzp8vmTzvuRv8dtMHRc/j/8AWqFvj5pw/wCWY9M7u9HJ5i5iE/tCaeP+ WS/nUB/aLss/LHGPx6Yp2XcTf+Qx/wBo20A+WOL3OaqyftM2o6eT+Hf/APXRZdwIG/adh/h8n1qu /wC1AnaSL36UXQfMYf2okHWaL2wB+tV2/aox/wAt4vToKLrsO3mQS/tUMfuXUfuQBxUDftUOvW9X PYcUXXYlIgb9qSTHOoAHsM9Krn9qSb+LUMnqMHofwp3XYdiA/tOuc7tTZT069KryftPEddUb0BDV Kl5BbyOd8QfFbQNWXbr6QynpDcd4zj+H/dNeE+KPAmlxS79EvxIoB2Kf4S3t/n+dYy/u+jOynV6V F6M43VdVZM+aSxHp3PsBVFdUby18wO6E7o42P3C3+zUp9yHHuj0v4f8Ax2udIjZLWVmjP72CFycR uR/CR6/Q16BdftMStH/o1+8cvUHGdpx2BrZyZjGC/VkCftK3LxAS6jLHc43CZf4XHcCq+nftIzIu NR1GW6l5Zpm/iJ9SPT86Tfb5BFd0cvL8YZ3Zi99JICd8SuT8nHbPr+AqldfGy5dSgu3g/iVkP3SD 2A9alX7m0o9o+Ztf8L03QhJ2kkGBHIe7nHc+9LH8YrZIvLW3byD8vlZ6fVj607936kRXb/EQT/Fm B4xG9s3kdEjz2H95vepo/j20WPJhwQBGHHXy19W/+vSXqVNefmSn9oi8I+XeB0xnqPwqB/j9edt/ sT3z7VtzEKHf5EP/AAvm/PQtnqMnqP8APtUT/HDUW+8cH+H5uoHpxUN9x8vZ+pH/AMLq1AD72PfP f6VDJ8ZdTPSRQfvHOe/o3/1qd/JlKPciHxg1FuDMD2JHc1CfirqHOZyv8IPrSKUQb4p6l/z8P6Z9 Kil+JOonpckeoP8AGf8AZNNE6f5ER+IWpZ4u5Sf7uOh+uKd/wnWp85nf2X0NNX7DseMRWkDD96in 6fxN/wDWqePTLdvvMV9P9r/9dc6X/AG5eQlzbWwHyFs9cA9h7VCLZD/ExH8J9D7ihrsNS7pEkelx H7rkfxHHdvcUSWpX7kzEd8fwn2ot5A5diX+zzjmVvTjuTUD6cy/dmcev1pL08xO3USH7QGxHdEj0 9R+NSz205HzTtJ6qfT/61Uif+GGrbzdpgD79qLfT3JJ80Z7E98Gpt2ZWhNcRXXG+dTgfKAP51XaS cD5ip9sevvVa9CZW7skWxuMfKyk9QD3HtUYjul/5Zrnoc9v0pfMdv5Rn2icnlMHqM+gHpT47u4fp EOPmGD3PvTbHFGo3iG9HL28S8ZjAPQ/Q+tSR+ILjGWtlYH5iSfu49QKn7yX5PyMyW+nJJWEHPPXo PYY7U1L90IxEc+me/ufancETPdNIP9WfUD/a+tKl869YCT0JPvT+RTXmMFy3XyGI6BcdD7ir1hqq RFjLZnB6HHI+gx2pP0Kj6ouzeI7QqQkL5xgAj731yO1c40O4917gnt+NVFeXmc8y1doGUbWOOpP+ 17GsqRCcbEPu1aRfcxGrCR94c9vap44+m/P09c+3tQWvM9+/Y/1HytdRckB4pYiv95ljz/Kvs7xt GDDyNwBBPHU59Pepg9Tor7L7vxPHdX8WiCRA9uGydqyf88j9PfNXZLiYf8sGJHI9/pRY5Vf9EUZp 5cgpEynqfYCtSHVNwHyE/wCNVYGPTUT3Rvy/rUn9pqeit6cj+tFvMd/IQaindH9Twe3pUn9qp2Vs dOnUUWFfyBdTj/2vUcdPxpw1JO2fUfSkkVr2FF/Ee59Mehp39oJ/EfbHrRYV/It6depvXDAcgY9O a9A1YHecH/dPqKlmplLOQcKh9HPpx/WrGwqOp9v8+1Zjt/kQMpPUAfSs9hg8En+6PTPtQAoIHfHc mq8dhG5yST3Bb19hSGjlfila5sXCg4yNzDsAf4RXzjMmeR+APvSl/wAAwT1f3lOReu7H4dsf41HZ Rc87vQgd+KIvyKbN+KMle5+voPT6VFp8R3HGF4IIPYD/ABq5Ev0Oa1C1IuG+o247jFVr6NQ37wj0 5/u/StWTFdl5I6/wf8Etc1lgNG8PXE6cBpZFIAX2dh3HvX0Fo3/BO3w+5VvEbtBj55rO2P8ArXx/ G9Yv+6elCFtaqT6pHtvhr4V+G9GXHhrw/a2o6tMRlmPvI2a6HBP3iT7+tbQic9Wq38XyQBR/ntTt vp+VWYi4FGD6UAG0+lLt96AFAxRmgAz/APXNIW9KAAD/AOvQf/10AGT2pOf60AHPtS5oAM+lBOP8 aADd7fSjd60AJn60GgBCT3NJQITFGfx/xpjDn1pCRQAfQ/8A1qQt/n1oEJtNG2mAooI9vwpDEx/+ uigQm40mf8+tAICTRk0ALn3+lITQAfT8R70m31oAAB/SgYoGNJx1/A+tBagBpmH+FM8wn+VABtPp +PtUqRRxjN9MkMY5eRzjAH1o9BN92fIHx+sNOu7tW8P60k5DZnuEU/uXJ6I3+yR16V25/aq8SPGq pLaFwBDJeBMFyo67Md/wrOEbP3mjapUula/mcjf+J9TvSTqd7LOTzhjxg+iVU+yoD+9KD2HYH0Jq pTZjFJb/ADLVpDHn/WRRDvK5HB/H1qonj99HmL6x4Oi1yyGUKRXG0uWHWMgdVHP5iskv5ri9ovsy XkecL8S2vmdrq0eyLMXg08tn7PCWOBvwPuj2HtWTqvieEggSjuDjsuPT2o9Av5+TPpn9nP8AaH0m y0hEnSMSRSNBeOW++JWJBZfdff6V6uP2q9CPR4z9G6fWtlSX6kTrvo/Ic37Umij+OL67qeP2pNB7 yx56bQe//wBaq9iiPrD/AJmRn9qvQQeXT/aOen6UwftXaF3eMDsc9T9aPYryD27/AJn3E/4av0Qn 93sbufm7j0qKT9q7QmBE8ULA5VkY8MpH8QI7in7JCVd9JM848V3Hwv1clnsI9Luj8yalZnBSXnnY vHGfT61zdh8WPHeiEDwr48svENmOY9P1JFBRE7JOMHgAfxdPcVnyW6XRrKvf+Jv9mRw3xP8A2ltV 8TTQrrXhqHS1hVxujkLCe6mIBwSBgDbjv7npXGz+IIoUJcD1jb3wen1qJyX2U+yNIP8AmkdP8EPj JpGkarE6QvmSB7DUZZ2AU3bOCDG5xgcAck+vHb6cg/bM00uyzxWyspMTBW6sPRvatIRXX0MalR+n Q7bwl8XF1kObG3AhXCSzj+KRh0XPtWjNOWPb6Uml0Not/a9SPUdSjtIXeZgoAO3/AGjivmzQ/iLB BqIn1h02qWkWNv7xBA5PoaEv8hSkerf8Ng6YfuLBt7HPamH9sPTP+mI7Dn0rXkRy+1fdjT+2Lpw/ 54ewz3ob9sHSzxLFbuD8siE8Mp/vD3FJxiNVX0bPM/GF38NNWO+PT4dKuvvjULRiD54J52Lx1PpW JYfHrx7o2F0LxvZazZrxbQXyKWSEdvNPzfKMfxdKy26XXY3lVv8AxFrsmeTXPjbUbueaTX3Q3Ekj XE2P7zsew9D27dBXR+CPAWp+J7uOHS7Ay24Kz+IbhshLfTlJz5sg/wCepGMA5Pbvjnb/AMkdNJd3 5tn0J4t8eaJ4Tg+yfDPT4xcuS1x5XX7RL13MM89vboKveAfhvBokfna26y6q4LXErdbWOQnhG+nW trdPmyObdv8AwxOZ8f8AxkWBW8psvyAP7x9vrXgs/iSe6k3XDtu6KP7q10tHKj1D4b/FLRtHJknn ie4x5cAP/LLdnJ/4EK9G/wCGzrYH/j6h9SCB19qiKXUmdR/Zv2HN+2hagfNNBjrnHYfhVf8A4bUt X6XkAXqCO4+uKuy7E878yKb9ty3BGLqADqOnIH4VP/w2pbAf8fdue/OO/wCFJqI7vzGp+2tB3nh+ pA5/Gqeq/tfafdALeRWFzbk7b6KXHKkH7o9wcdqmSXQqM30bOF8O6/4OTUkPh2Yacsh+yXESBiCs zdlOemf/ANVavjXQobe7dbFnKZ3ozDGVYnnafUis7f3vJHVGTf2fU8O8W+Kg1xIU+6p+zwMO6x+h 9zXN3fxUzYvHFolm0rSjU4NY6SWwQfdicDpkZ6/geKlNdQcX9k+r/D/7cCz2sLXtzaq5QQajFxlr hBg5Uf3/AGri9b+JGh3TlrG4iQt80sB/vHPKk1pJL7JzQm+t+zNXwt8StZ0g7vD+oAwN889i/KOR 3RexPtXcH9sJlAN8jW5+6VI+6x/2setOMl9pehco9ab82hp/bMtB1voz/Dgf4ikf9sq0H+rvoyep Udh9cVpZeRhzPsxf+GyLQ9LtM9Tnv+napE/a4tG63iY7e5/KlZeQczHJ+1faN/y9qh9D3A9BjtSN +1Za/wDP2nvn+nFKyK5mS/8ADUFo4wLpGHU47Ee1et+FPFllrFqr2cyTIcxOR/DIvr/umk49ioT1 19DlvE3j+70YgXLsIj8ltKe59K5DUvil4b1QEa/Z2c/ozdVbnkEf3SfWs3FPc6ZSa+B+Z51q/wCz 74av5d3h7xSIcjZ/ZE2Coz/cl68niuJitPFPhqf/AIp/V7vSesixxuGS5XJ5e3ORyR3Fc/vLZG3N CS95a7s5z4weJfG3i2FY/EfiDfArCaMW6BfMdf8AnrGgx79P0rP0nw9DZRKlvCV2gJg92Gc7z7mk p3fw26ovlVtG2Nu5sn5x7fUVPps2chjnvH+Gev0oZDfb5Gdc2+1uFA7gj1qDBx8ox9f6Go9fQtCz v8rbumCrY9Sp7/Wv0G8BxFdMtP8ArjGfxaIV001pp5fqYz6FtuvX8K8H+I0QE74HOSM/7PNaIZ4V 4wYYGAFPTd/e5P8ASuPfrzjPdvWuWZcUaGj661scXH3Ceg/hbnvXTarrLWyBobaa5JIijEXYOepz 2UULz9DOSdzt9NvTIg+mCR2IrzHx9o4hnJQMFcfaM46yknPSoqLsbUWcoYz/AHh9PT60xwP4zyOM eh/+tUNF3IJAADhRzxj8Kp2saheAcd/bnv8AWrREiz8oHU+qin2li8zquM5Oxh/sH1+gpLzEz0fU nW2hIU7gPmBPYKDwKxfAwmYyHbHsJ35Hdmz29quPmRbQ6LWNVEEbGE/vAC8We21T1/GvHppnckzP uc/PI/8AeY+/tUyfkXBabEJmfBG/j09/pSzQSEJ/ZcMpbDLfgniU7j/q1A9Pr657Vz1lpoO3+Ytz 4WeVh9mjeRiMrbgdXPbaPQ1Y1C8gtECTWNs0qMGeMnHkqW5DAdyffIrzYvzCXkyxrktjb7H8K2Zn kXEmpzyHHmXPPEKDsPz7ms6/1zU5A5kESJINl4YhxtkJyGCjGCe2APampdn5Md/NeZjeLbHekR06 2ii2qIXlUcvCGPU9yK586JCVJGoyCf8A1lvaqnC26jq0h7sfauqhU/4JCj/N8zd8L+LTbp8liplH 75bxz/rTg8FPcd67vwt4eXUp1kmUmBcT7f710SeGH+z9ah0/e09SGn19Dc8c/EK3jmW2tJwWwbnU QMfKo6L07irvgn4X2FxaTy6jcsM+YdJs4sAIkCkkzZ7Zz2/+ty41a6p7cxvTkk1zW7HmWr6hrSBh YSGKJwEnOf8Aj4hB6EYPGRQdTjUp5MZm+XYQ/GXIPDEdgf8AIrOEdN33HOOunqVLpRASIo49oGJe PvStno2PSo9BurQSqNcneK2Y+XdSoOSOfuj/AGzxW8I33+RFV9vU2/GOpadJeIvh6ymgslXCpj/W yYP+sb3P0P8AKqL6HK8hHlCRowZyr9ImIJ+UjvGv1I71M/7vqOE+/ZFt3cKHuJEd2+VUcD5o1zyB /n2qrb2mg3TqNYtFXLbpltxgNF6M/q3XjFaRv0Y+bz9TS8WaNpOhTeXodlLDKy+dcRM2dtu38M0q jHH0yK5m48Z2rRD7NBJDPuJkjI4VvZ8U2m9m9/wM6sr/AAxX8zOrt/is9ns8maHVFMa3GotyBp05 zlQQOSBg9TjPPOQOh8MfEltS3eXGUGN0aD/a6AvjtXpRfd+SIhLsmZd7pMkMr/ZRJFMw3q4HCyA9 +O30r2fwx+01q1pbRprQNxKiiH7Rg5dV/vD6V0Up90b1qD3SLsn7Wf8A07c9+Dx9Mis26/asuc/J Hx1I9vxFdTZwuDMu8/ajuCDkKB/CCe59TismX9pO9YfuyD6gHv8AWp5kOUe5XP7QmpMPl2j8eo/L tUL/ABy1g9CvrnPUflUuQcnmRSfGvVj96cAfdxno30x/WktPib4ju8jTkMxUGe4Zc4it4xkl/ZQP w70c3ZF8i7+RTb4taqoJNyx7qR3wO1ZVv8atSkYhrx17H/eH4VPN5FuC6eheX4oXw66i/PJA75/w pv8Awsa/bOL5lXrkY5HvxRzdvQlxXfzKL/FK8H/L85PQFfT3qNviXeDrcTKe7Hvj3xTuCS7DP+Fj XLD5r6YHopH/AOrtQ3jyY4/02f1znr9aLPshJojfxjcDpLMez+/1PtUT+Npunny4/hGeoP8AhQr9 g07oWPxbIv8Ay2mYfdIz1z/hTH8TzY+V5B6En+H2obfU1v2t3Kz+JZR96Rznk5qNvFJUHCPjqc9/ zqEn3IfkihF4ylkJEExB6hR2UepNWxr8v/LSQn0HvVNeYf8ADFeTU5H++ykdcGoJJ5ioCMu0fMqf 7R9PrSS7stS8vIRZZV/jH+6PatPT7oOcTyon8QZuzD0+tUl2Yrm3/Y6Af8fUBHUkHr9aY+nx4Gbq M9j/AJ966PZf3jn9r/dLS6HakfPexfX3PrVeTwrZfx6oufukD+EH0NX7Jdyvav8AlJo9HsIx/wAh BQBwhbufb61TkNqv+ruh6lh/EfanyIhTf8pZglsCebz3ZR3X3+lTMmmYytxntt+vvik4IOd9vJEi z6SP9ZcEDorH+L6fWpnvNFPSRyegX0Psfaq5EClLqiu9/pY+8hz0Zznp9KQalpXGQ57q5H3W9hQk h3fQsPqekD7kB9Y8+vuKhm1TTOhtd39/3PsPaldA7jYdbsB0sh6rx/CBUz+IrI9LBmH3gmOo9uKf Ou3kNp9Gxv8AwkVnxjSm9Sv99fw9aWLxVBj5dJC91UjoR6Z9frRzofK+rCbxVnGzScY4bA+8fpio 28VyHppoz/EhH3fp9KfOhKD6yPKVW36FR65HY0C1t2Ybnx/eNcCXm+50X7r1NJdAsSTtkHowJ6/T 604aRa4xHK69856n6mpaC/exSXRY2YgPuA+cc9RV1fDdswGyaQHqQD91x7e9AOXkhZtA8sfNcv6l SejVlLE7E5nc/wAIJPQe30q+VE8y7eZKNLXg/aGVvu59qbPpkyH5bpmH3ckdTWbXl5j06/IuR+GZ Sfm1AjPQYGFAqwPCMo+5fMf4unVfbFF+yLdiu2jXIcK92BkblJHUD1HtT5PC0p+9fjHRUA/iP+FN NkK3VPsMfSLxRn7Sj9gMdT9arLLdnO6VQ3TB9f8A61DHp59xs0UvWR1J6YPdab9pkjA2qp9/b3+l JDdujZK4uXz8iFepYVXW4lHTYfYn/CqJt5kgaVzxGq+vPUUSW0gOVQeqkntQ/mCQ9mkj+/GQPvKM 9RUxkmbH7kDucH+VJvsFu7FX7Qh+aAeo5/mKDPPI37u2fPXavYe/0pIduzRJDbXanMlizKMkg9sj +lc5e667ZBtynZge2PpWkWZVF5l7R5lKkMGPcf7PB/masW6oG+fGPftVWM2119C8YbYn7yH3H+e9 OS1t25YD/ZA/vU7C9T1f9nV0tddtCT1325P97zE/pX3R4ut8wvjsdw9yCaiK1Oqs/dXq1+R4J4o0 yZnjMERzuDHPZR6kV1yqzY3cn+L6+1Jv/IxivzuVLi1z/CR64rKsNYWN2S7O3+OF8dV9qaJa/wAj XXU0xwjFf7230q5EQRmMAg/Mp9QfSj1ZdvIf5Q/uj/Cjy89AB2zjvRf/ACJ+8DEP7g/LrR5K/wBw emPSkmNifZ0P8A/xFL9nj7ouPftVfMLf5FiztUDL8i9QQfRs9q7/AFhhu4GOOR+FSUZinrkYHY04 Tgnrn0NQA0O2cFQR2PqfpVKaA7u3oR7UB6j3UNnZgemO/wCFRyliuBwf6f8A6qA/pHHfE6EmwkyC cYIx/AM/4V85TIc8r75oku5jHdlSSD+7j1OPX/69RWUJB+XOPT0Pt9aI+XzK5f8AI6C3hJHygZ9D 70/TtPeWQCCGUvyiooPzNjsMd6UioRb+BHZeHf2K/F+qzF7hI9NtThvtU5GcYP3ISM8n6V7x4X/Y z8FaeQ2paeus3A+eO4uBgI4/uoKrc7YtR2s318j1eGGOMBbSCKCMcRwxgAKPwpwX2rdLscUpN/Ex wX2H0pdo70yBOP8A69OzQMPrSj2oAN3/ANeigAxSZFAAaTcaAF3/AP66SgAzRmgAyKKADj1o3UAJ uo3CgQb/APCjOf8APegBDRimAmcd/rRkf0NACFv8MUnP/wBegAxSUAG49qKADcB/U0bgf5UDE3/5 9qM+lIAKj/CkxQIMUYpgGRRigYUf5zSAQ4phcUwGs9NwTQIebVgMybVXqXc8AD3Ncxq/xg8N2Oft OqpM44WCHkkj3qoxIlPscBrn7VF43HhzTo7cdTNLyW/3RivNtd8c6zqLZ1XU7iYHkx5wEP8AsoPS nKSXwkKD+18jFGhI330HqR7D29qq3ninSrIH7ROg/hCJyWI9h61zXNXJI818R/tRPExXQtIIb7ou Zz90eyAGvOtV+NeuXDH7dqkx/uRxYAC5/ugf1NU1/L8zms38T9EZh8fXh5+2Tg/3wf5//qpT8QdQ GP8AiYXP+zg/dxS17j5PJeQ2TxbcP/rZnY/3j6AevtT7bxKwbLkMR8uW/iX/AOvWai/0KXoNTWnQ lrZnhJO7CEjJJ74qdfG96et9PnrkHpj3x3q7PoxtLsiT/hN77vf3Ppjd2pknjW9P/L/cAjgEE9/W nr38xNLql5Glplxqcy5kuJXT7sbvIBhQe2SO9W2iuhj/AIm7Y6CNpB8p/wDrUrvqmU0vIS4h1Q/8 e2qh267Vfqg9cVX+xeIypYSlUUhWLt0Zz2BH9aj2nr2KjTj9lELHWwCWvoywIj2B+o9VJHbipYLf WJF3NqOxgREINxztPUgEdvw9qFPtcpxj/mTatdXtkhN3qjyLu8iEqCRKrKeVJHQgd8H2qbT9Cvp4 8tcSKD/q4sffiOeQ3+zRyvovMSS6X7GnceAppgoaSPK/dkHUj6Y7Vp6D8E9QunVbTXPLLERQqB95 3P8ACMf0ocZdJeZScftJ9j9DPA/w4h8OWMNvbyebIo36ndd7q7bqWNbMUeT6+tXHz9TWXl6I85+N XjEwRCKBwGbmUf7FfMur/A/X9dZTpV7HBEPvhv8Aloze/sKc329SYJfb+ZZtf2BvEsv+s8T2tuOo PfH1xT3/AOCfuu78J4utnJ+ZiewHrkVy80u7OvlpdVI1rP8A4J13/lu2p+PBEwIW2REzgf7TVHN+ wIEC/wDFxbhpDyV8rhTUNz6NGtqX8kihrH7CZtwPs/jqaYsC77o8bCq/1/D615ZP8MrmJlUa4z8+ SpA7E9ef8acXP7TRhUUPsRZ7jpn/AATvW7ZBH8Qrhiw3XCiMfu1A/hz7e9eo674r0TwXaLZ/D9TJ c4xqN8eXlnYctcOB1Y/gOgrWlF/8vLdyKs42tRT10kec+DviP4b0KZpfFvnXV8fmtwqk+QSDkkju SfQ10niX9oLTbyJn069DofmB7g46bTXfCn1fqefOo9rabI8D1zxDJetuunYr0jT+7n1HvXeeEv2a LrVLcyaprkmlK3y6eNmWljGeWHbJrCvJ/YfodVCK+2n/AHhZv2F9PI/0Px7d7us5eIdf/r/Wpo/2 C9OCqZvHN7uOS48ofKAfeuD3+6O9On/z7ZJP+wjpagGPxzqHPRBEvAPoD6Vatv8Agn9ovPnePtQI HQCJeCfTij3/AOaIc1P/AJ9Mpp+wdo5ZvN8b6gFH+rcRL1Htjv8AjSwfsL6Uc+X441Bu6mSNeD+V L3+riNSh/wA+2Sv+w3oIJ8jxxfkAhHZol6kfwgetJN+wxo4A8nxpekdCWiHLH2x/Wn7/APNHyDnh 1pM6v4V/sd2NjqME82vT3TxMbpbMqAsbBDjd7g812PxXuXv7xYrVUDYKGT+6p9T/ALNdFO9vft5H POS/5dxt0Z5MP2HrEMTceOboIcy3bpGD+/Y9ArZ6n6+9RXP7FGnEkW/i25xnGTCOV9RiuZqXeJ1K cP5Gcl45/ZItdGjV7LxG11k+W0bRgGMkHv71D8G/2VbTxUty1/4lksEhcaeojjDG4kdM85/u/StY qX8y8jCbh0j5s6rWfg5c+E5xHaeJ31O1KiUJKgBjbJ+6R/d/CpporW6U7whB/dujd93qDWqv9uxh O1/3adtzzbxD8EtpJ0+5eND87QD1z9O1c9/wr+TPzXhDdGOPT8O1YuT7+Zryx7eTG/8ACDOv/L2T 3DD+E+3HehfBkwA230qj7y+59sjvRzPuQ4R7Ey+D5h/y/Nn/AJaKe5/KgeDrn+LUmPsf4T6ZxQpP qP2a6XJk8K3A6XpB+6/uD6cdq92/Zq+Kl1o1w0Gr3xksZSFtGY/8ed+QeoPaQDH16+tb0pvq/Iwq 019lf3j6o8dfDu11q1kiulBJU/ZJR/yymI4II96+AvEHw51TTZmS7u3VlJi2A/3Sf50pt9H5HXTS a16aoowTX8LZa7YkHejj+BiP4SBVy58RXUhzIxdxzHuPR8euO9KU+7Zzqmvs+hEmszjqxz/Ep7n2 PuKV9dkb/VxIG6BCe3+9iso+fqaejK7OzH58bukg9Men0FLHIFPy4HoPWmNehdv7UNyg/wBoMB94 f/rrJ2k/ez6D8fSmxpd2E0Ue1uCowT9MA1+g3gsMunWoOP8AUxfn5Q/nW9NaP5fqZTLBAzz+NeH/ ABMjInfP4j8a1QXPBvGaKQNuODls+mD/ACriXkBPOc/d/wCA1y1NzRbDCnHzEH0B710/h3xBI3yX IBx81s3qmOhPtUoma8zudEvcEqcL3A/vHPb6VU8f6MZrfdHHl0PmNjqYmz1H+yaJlUdzyTcO+71w ex96ictzuHPTHpUJ/wCRUl29CJ5NoOMZwcA/Sqdo67BtUjqCD257n3piXp5k5Yg88jtXTeB9L3yl 5BuVRtQH/nswPb2FOKJb/wAjQ8Z6kFQBcBm6IP8Ankuev1NL4Ik8uFjGoPJXP+0c9aaFN6DNZldo pC7MflIKjufb6152y+qgew7Gs0bvyZFIP7/1GPanQXZQ5BIP3gfT6USiZS9BNKm1Ml3sdUW0kQgJ OzYO5jx5GR1X8x1rF1vQU++l5PcuxEt5M6kCKdSeFceuK82MfLyYKK6p+Rj6JrF08rKrjLMZId7Y AUDoM/T2ragF7N5wucLGCAsadJlGec+1VVik9F0uZRX+bH6WRGf9OnHl/cQMM7cnj86t+LNBt7WT doGpwXihQ9+QBiCds/KW9QMf5yKxpRd79NmUn3T11Rn6PqVreSj+0I4g7DYlpCOPNwegx3/LsK9x t4rTRLXLoqkfIqH/AJbXL5wOfU16bjb9CYPvfzPCdb0+Ka4Z2gmF0z7p52P3EJ7f7q+tdbJrGv2w dbIXE9iQZZPKzthIHVsD+MDuK81u9rr1Kau9Wu6MCHxLqV26CFkg3EWkUC4IW3JPMjMO559q318N CKdkeQLOGwz4H7tY88Ifrn096ym7fZ9WF+7Mq48J6jM0pV4flDXtzG7gbY0P8IbHIPYZ9egNcpPr MFz5a3MAiZT5Kxp/G7N1kb2Jrpw+uy80FR+f91nbXWj2lgiltSAkLCGKzx82xQeS49Dj0/wl1hrV YCZpMPuUTp3ZmJ++ff61wSb05e5vSt+jM/WvFmmTSuNZikh/dbLKSHkR3KLwNoHfj/61ckFuIoQ3 2h0QuAmMDcwB5VDzzXqU4afgZz9PJeh16a1pckZ+2XQml2eVErg5Ezf3SP7o47n2qC88FS3Eca2M 8RPHnysAAoyeS359TXKtN+/MyKUl1v2MZWNoZEmeOaHc1pIVwTJNzyhx059Oa+7/ANmX9jnRrKwj n8baWt5cyjzdOsrgHFnYMTgvFnkyjnnoMd+np0lf/wBKZLdn7r80e1Wf7O3gKFyy+ErCSRjuBnG7 yix6RqxPC/pXy58c9e8Pi5kj8NeHLWzSMmK4u4v+XmRRzhR2Ug/17V2qmurfc7VXk76o+fL3W0DY Em08tjPRB3x7U7WvFmjCSM6JaNfRBQ175jEfaJs8+WB2x+P06VU2vs/M443v7y9DAuvHcEkciHQ0 i+Yzaa2CTEBngvjt+FZK6Nq/2bzipjhLGGFm4LkA/dQjufb6VkrLdvsb8je/y+4pRa9dkfIZB2PH f3rUsZdQc4QyMeqqozke/HatWzn5fLzLn2S/BIlSRT98HnG0+jEVf0251FVcWN1dwbgbe7aPI82I 9Q3sT+FJMbXcwG8OayCPsUdy0eSyuc/MwPbI7+1Ubk6pbOSyyhyS20qeHP0FL1NeXsy7Z/2rIMyi 4yflEaj7hPrxV6HwzqcnEv2kD7xmH8Iz/Ecdq007Ix5fMrposiXGyyZ3OMsx4AP+0frVrUNKvonC yls43BweAD6H2qY+aNXHoh7eA9VcZaR1Xqqhh+859KlHwz1PIEjFDjfHE5GWb/a47VXN5Mz5V3GX XgK+VsR3JkbHMQ7Mf9rHao7b4cam5zFC87A4kjU8Rk/3jjsKpS8hezOig8A3iqPKt0bHMuD/AKsY p8fgq8lP7kx+V/y1lz/q2A/hFQ369wUf8h0nw7uDzHcQbeXJbvgfwmmD4f3eC07W6wgbic5Lt7DH pS9X6Fq3W/Y5nT9Ct5rh/wDShaoBy+M5Zjxx71JqOlmJ/kuS6diB9/3AoTCpu7XN7TfAM1xC7xuS qjcxQf6tT6j3rmHmmThYy56tKf4h/srTfmEF29GQSPek5itFUdAGz1+uKvafpFxcY86GRezEDg/U +9SpeZUqff0N6LwGT96Rx2YH+Ij3q8Ph6oxvlkz1DN/Q+1Xz+fkSkuqRaTwFbEfOzkdCc9h7VKfA Vif+WRz99znqw9KHJ9w07IifwNaH7qj2JP8AIe9QL4Mt1Pz4x6e59KSk+rE/RF2Hwna98L/Cc9/q alHhe14wij+At2XP+NNPuT/w46fwtZZxCqN23HuP/wBdQroNqD85AP3T7Z9qOYbfYtwaHZDsn93P 19j61PJpNkn3I0B6HGOP/wBVTft6DizMuBEh/wCPZCOnH8WfUe1OW7gJ+WFB65HetAfkaS2sPGTE D1K+hqRhb/7Hp06Vn6h941RAB8z+ynH8PuPamN9nP354/p/hVeiHEQ3MA+7Jz1x7YqHzbXu4H1Hf 2pLyB+Z5NaCwZz5yAj+A9iMevvV19N0wj/UQnvu/uiov2YX7oadG0socRxhupKn7xIrCSxiUYDHg /Kc9OfWhebfcTfZE0dnGPuvz1Jz0A9KWe2Cr+7mdT14PTNL5+Y5enkPitdwG69lPdsnoarG1QE7W PtjvR/w4rLol2EZAuNsh9GP92r39loQMXLt2O4/dLVQ7+S7DRDKBj7a4A+4p/pxTrC2lJO7UpExx x/ET7e1R8gujSk8OuSDLfPu6lhjkn2x3om06dR8moN64IHyn6YoTfZEtr9TOaW4I/wCPp278Dvjv VdbGb/ntjux9D7Gqt3KSQ2S3kGMzBs84P8J+tO/s+VsnzRj+H2+lJ+Qo+gq3N2RhXUL0cAdR9aiT T3J42+m72FCBpEotpowTkY7n0WmJdu3oRTQ9CwqzvwAh7kn0HpUi3Fwv/LJD2ye+KEv8xW/zIRc3 THiOPPUDPX8cdqsWmoXSN8sak9H+lS0C/wCCaH/CX3yjE+noM8qc9fwHqK5K40eR3JPGTuK/3c1a 8jKa7vyRd0zTZIs+YRjplT2GakkhBBzz2z6Zq4mcvMsR2ULRYRfm65/2Rnp9abp9pGxw+7oSgz0I FMpenmdV8I/Ev2PWbPzJJCPNCnPTDNjk/Sv0u8VW/wAkuMH+JR7ZqFv+J01F7q9WvyPKZIIz95Q3 dT/d+lHmke/ak0YX/wAyFpTnkfQn/Pas2/09Sys0YZhxn29qEgNiK6DDhRj+7j+lTJLjoBjt9amw 2w80H+Ee3v8A/qpwlHoPp701EV/MBIpz8vsKDKO60coCq47qM96XcvoPSlYL/wCZLahdwyB1Bz9D /Wu21qXBB2gnHHvn0ppDuZklw3ZQPX/9VOjlA+9+JqfkUKs4P3AT/dz2H1qjLC3fO7+L2FF/IQBW U/M3HXHrmo/OI+8Oeg+lHqP/AIY5v4jRPJZSAE44dh/eUZ6/U186XEI/jznoo9Af8KJmKW+pUa2I 6AgfdI9D71r+FfhprepNjRtJubg5xkDAx7ueP1qOZHRSpN7fM988L/sWTHDeKtTW39bO3wSy/wC1 J717H4c+Ffh/SR/xI9EgibvcPyzk9yTWkY/zfI2lNLSj82dCQx+8SfX/APVQFroOJsdsFLtHpQIA B3ooGAX/AOvS7TQAYozQAoUUm72NAATSZ9aADNH/AOugAoxQIQtjtR9f/wBVABuFBIpgG72pKADF Jj/61AAD60baQBmjcP6fhTAQkn+tH5/WgAxSAHvQMTNH+c+1AATSbh6n2oBCYPpRtPrQIPyoyew/ H2oGGfU/hSZ9qBBk0ZFABj/69ISKBieZ/wDW+lJ5lAhpYetVrnVIIhm5njjHXLHqB6U0hSkcpqvx z0K2U7mlmbBCpH3cDt9a89X9pnVlXFjbQRDnyWkOSUJ/iBFaJL7TMW3/AJHKa38S9bvsm91e4cHn ylwAvtgCsAxkn5hjtjH8X196xnPsbRp9/mQXus6faDOo3qQjoA3V/oorjNS+O1qnGlWTTN/z2fIA H0xWVv5gqT/59/NnFax8RdZus+dqEkSHhIYuAAfU1mWoKp8zZPO4+v4+9Jy7GfKcZrLkynIPptH8 Oa566c7jz7Z962t5gvMarHv9KUqfXNKxVyRFbHWnmF/4Xx3oJv3QEN3cn1o+cD73H86r0AArd3Ps KeN4/iGOjGlYT9A8sn09B9PagIcffB7H8aq7/QWnY7X4aRn7Q3mbWAQuVYfebBxj/dNekeJCotjm NPvLnA5HPaspLuPm7Hlt0JvMPlOgGSOnYGr9m96PuPHn0x296mISt1uWdR0q/uomWSRGB/eqMf8A LRQareD9avnTZHMgZcoNw5WMk/56Vbf+RcUrat92dVCNW/57xHtnHX/9dfRH7MXwxvb26e412OF7 SAbLBcf63UHBx/36H4dKJS/yClBd3/MfUFxcFyST71JC6xgtIQFA3sT6AdzS/wCGNT5i8ZanqGuX rLo1uLh+QkDHA2R9eeeoxViHQ/ibGB9k8JaREBgBhLy5H95QO5qJS11TJVO+80upqWuvfFmP/j58 KaRKOm0y9P8AgQFaMXiP4k7/AJfCWkFyMNGZT8mP9rFPnX8shKh/0+Ox8P6nr7wv/wAJXpVtbOWy ogbICAd2I7/hVY4PJUAfdQf7NQ3/ACpm8V3dzG8RzN5bbpjEoDYcDJOEPQV822mitfTxADrIvnue kNtv5JY+g9xQl29BNHvvj34jyaNciPwlcpcHYITMOwcdhzyo/wDrV5XrWrw6cha/nM+ovlzu/wCW AOeX9z+larovnI5vNf4YnlF/qkk5yzHeeHz/ABfjUtpbbRgKFzw4Hb6j3rqk+xEI+R6r8MPhE144 l1a2zaqdtvA/H2q4A4LeyV7yfMbA+UKBkAdAB/dUegrzpP8AyO7l/wA2VjLnjy1CdwO7H1PtUg3c bDnHAzzx+PqKAsNguo2bAds9IIf7oB7mrr3RT/URK56sp7Z9D7VX/Dh8inNeuud3BP8ACO6t6062 miG7agBHLZ/iOKgERLBuXJixzuIPYj1+tSyEysAJeBzI/ZiPan/SGdf4HaIeY0ZJCjyix7yEZ4/C vMrWSS8vppN7AL+4jb2Pp9Oa0W34Eo6g3EaE7VJH8PH3ifb2qm0shPygIM4b1Zj6g+lR6jPPfjRI PITeD127R3bB/lTP2UEX7JfFIxg3Ay3qwhFXTX9fMVRC/GWb/TRkA/Jj/d6fzryzUL54cGFyD94L /ewO9OTFbujX0vxjBd8XSqj+n98Y/hPtUWqeD0fmIbT1yP4/r9axkuxUH3RyU1pIh/eK3+0D6Unl k45JHYVnf/gmz8xCFXsTUxHqo9GYd8etD8l5i9fUR5EwNwJ/u+xpkbspysjRn7yOhwY2HQo47qap eQm+68z7d+CXxhXXLNRdzKbyP/RdRTu6pwGK/wDTTH09K439oT4NrMn2jTbcM4/d36KOqnPJA9K6 Ky7eqIwb6P8AwHyvLEM8H/ZI9T/9aoHGDwAR90L7/X2rl9S5ehEy/wBw474NMSMD1LHkj0HsKLgv +CLu9APVj704g+gb+I+wH+FMaNDTrzepEvJ6KP8AYPqKz7uAox7DquPWqZC8/VFe4kcKTt3e/rk1 +iWgRhbK3A/55Rgf9+hW0OvyX5imv+AMZ/QV4x8VV2znPBPOfXjvWqBHgfjG3ynI75DehAPT61wj J7H6+prlmaLy9AIA9PUZ7n2NafhpP3wxjOCH9lweh9jUIUzu4pdjjaxUdCB3U10IRZlZZPukG3bP dXB6j2q36GcDw/ULF4ZGWRdpUmIg91U+vuKpuwPb/ex3xWC8vkdM/J+hFJtOeAf6VXtmyPUdSPTr 0ql5kNdh/l46AAdVB7V6X4X0n7LAuQS5/fO3qTnr9KqJDfc4rxVq3nykKANn7gfXJz+ZrpPBUI8g 5Bxktkd+T2+tOIVP+AO1yJRBJt3KcYGO+T3rzMr/AH8Hu31FQvM0ZFIo9/8AZb0FRNGD94f7vvTv 3J9C+t9bCB1m0pb2Q5mgAHKMoP3QAegrmLWTVtRKxofsUJIF1CRhUQHruYdce+BXI0ur/vIzmn1e 2o/xMPCtpKqaFbM0UbbbvW5M5v5lbnyI+OG6Dgd60dc8Xw6u+3wxpqw2+0RW1ui4MjKD/rDjnJzz ROHdmcpdl5MivtOvNJONct7c5X5rZiCUkAPcdMVnWliogPm2jeWx+1MinGYuTycdB3rOn8+1glfa 67o7r4PeBLOVjcHS5IQP3OnRyd9ucsp9j/8AWre8f+NNKaGRTegzq260iZf9ZOoPMR/2OnrXVVvb dF033XkzxYavPNktOxkwWuEbsEHY47CqyeLdUOU0uae3i4/tJYskXKKc/Px3NRGC6rzMmvLyZ0+m 6E5gY2ch+2EhbWNjjyUP8QY+nHWp4bRrNwuozhpwP9IAPVyO5HpXlSlvp5I3iv8Agmxa/DXTdRVj Hr3/ABND+606xfoY2P8Ay0fsEOPXH545a++El7Yy41WRI5UIjnMZBDygnnOOx962hVttHyRWj3Wq /EyPE/iSaW5/0cmRY/ljYdC+T1YVoazcRNb7p5Jo5GYMiOvDRc8qf94elaxgrLbuRH/gE3hDSkvF eTUYSY0Ux2URH33VSdx45x/+qoNcvLEhVj/eyEb2L4xA7Z+79eO9SpPmtHpoVF9zNbw/fwKXtIGd QfKkKDO2T2ABrp9AW8kbF5LMgYAMuOYGPXap9Kqs1Yz5ezPb/gF+zv4V1a98zxxd21tBbuJ4bKVg DrF4vI8zJHyxnGccnp0ya+j/AIgftUG0laPwu9s4QGJZONsZXsir/c/+sK9LDKyuxXu7LpoZmift U2OyM6zf75z894QDguD/AA/h/wDrrwfxtqdtdXMrWgEkTs0ySH+657j2rql5GlJvW6OHuPClszZe GNmx5RLD70Z7Gqg0SzgbMFhArY8okD7seexrK3mU5PovIdGtgJAZI1jQDypYMZE7nua57xh4jMka J5KiDzBHDEOhBPce9JruXSbvv6DrzSYGUi2VQucxvjovtxWtoM1vbL/pBIzxIV6qPb61aXcxd+nq as19psq7cyJ/ekA5yP8AaNS/2zYhVGzpyhX+JR/e4oVuwrPsTz+KbZiDhzj5FQDA2/So016xDlnt Vcn5FLDOB7cd6Hb/ACHyvoVzr1mnFrbouTvdgOmfwpsOtiNGWFPlb529yfU0f8MVyPqvM5XRPINx L9utQ4A8tS2eCSeo9q39VtopMGMKBj5R7D1PvUXNHF3dl5ILe+iBG6Pdj5gCD2HY+4rUfxJbMwZ4 AHxhHYHmL0B9q05vMz9k+i8ieLxmkXMNnGzEbVk29Uz2PtVOPxZJGcpHtGcvGB95mHf61Sn/AJFq k+zHx+N41B8qydW+86gHLN6jPrT4vH4K4Gm7F6lFHVm6nA/vd6lS7saoy6LzI38WADBtJNv8CgH9 4vuMetIdSnuVZLKxuC33mwp4Cjuf9kUOXYPYy6rzOL0aC5hml82yTd/qpFIztIJ7DuKt3ukXgIZI GXHzFip4A98dqSl/kW6T15V5Mt23iC/tgws5ZPKf5bmNf+Whx3GPWibQZ5DkafcFurgI3IH4Upvu Z0ab+z8/Uu/Y78j/AJBD5xsQBD8yfTHYe1TRadqyj9xpl0vt5ZwSPQ471PMjp9hLrfsOi0bXuT/Z 94SfmKFG+Qj2xTl0zXmHGm3xx1Vo25HscVfMulifq76+pG2n61/y0trmHuwZcYPtkf0pxtNW/wCe T+iyeh9yfSp5kRKlbdjPsOpt1H5f3qi/snVf+eBPbGf5jHanzf8AAM+Tu0SpoGqn/lmW75B6D3+l IfC2rH7qSMfvZ9R7DFVfyZKiurXYVvC2r9oyOysT0H4U9PB2rcZjcnqwHc+xNUl5DcV3R0mnfs8+ NrtQ1joczRn5kk3ACQ/7H41dT9lf4hEc+Hl9fmkAwfc1OvZm0YR6zicn4u+GXiTRpkXXIXtXx9oM WQcxZ7MPWuo0f9nHxZfwefp+nhrTaboTswG+NBycH+7Q35MmUEnrJa6IzvC3wq1nW5DH4eSOeQAz 3OWwI4l75Pqa7Ifsa+Os8xaeB6GUcgetNf3r9yrL7cvJlg/sZeNG+9Npi/3gZAcD8B2qQfsT+Kz9 +90vPqXHA+mKtLzYe7/MI37GviTzNkmpacGI84sG4CfX6/WrI/Yd1zHz+ILEY469R9aSXmwbh15j 5g+z6S3VYs5+Qeg/Gs/UbexGPIWFufmI7AelZr1OWTLC6bpw++kHux7/AJVKLDS16CLHUc9D7YpX 82Pn7RMu4srQMNm3aeQQeoPvVwaLpePvg84bn72PXNVbz8gUu6Em0axX7rH8G7H0FZctuqsQjjH8 Iz1H/wBakl3Jb8hws4f45TnsPWpZtPhUcSuT1Qdif/rUxN+XkR20UbAb9wPU5Pf2q0mlwN99mXPD sO+Kkrm8l2IpkdQAl3IP4Qc9vxpxspCPnvXYdCrf1pv0JjbqvIDa3CjMFzgDnnv9PpVa3mnk4afJ 6fjVJFN/5lx9Mk6vIQf6+9V5nmHSY+mR2+lSxJontjKq/LKD6jHY0wRTDOJuvJGO3tR8h2BnuOjT ZHT8KI9MbHyzKO4X+6R6/Wgb8/UBBcpz5yHttHb/APXUu26I/wBZHt67fT6VV/8AInTpcFt5ezr6 kelSQm5JxFsJ759B70vmJLtcsS6TqD8MULDkIeyis2Z2jYh4xkcNjoD9TTg/8yZr/MpXGst2Cj1x 2zWe+sSD/lofcetP/hzNLv6G9oF4JOON3v8AQ9PrUkoaJuVAwdrZ7D6VSY5C6BqAj1GB0yVWWPOO waYdPwr9X9bVXD4OQV3qfUFah7nQ/h+bZ5GVPf6E+4pjAe/0ptGBE6c88dzimvEGH6D2pAQ2LMpI Y/7ufT6Vfx/+v3qguGBT9x7D8ff60kD8kA4PP4ilK56H/wCtTQXECYPBwf5/Wncn+pqRDojgjA5y Mfn/AIV3WtBm27VB4BJ/u8dqbLsZuwk9CPr3FROpz6f3vp7Vn8hkomCjoCOhJ75qCZgv/LPJ7H0z QgXp5Fff0yOev/6qkMY45/2jj+tCEY3jO0lktZBDAzEj5FH8RHYAeprzHwx+zJ4n1XBSyFpB1a5n 4wM9kIok+y9DWlT353Zbs9o8LfseeGLHB1rfq8o5USDCr16qOv45r1S00+CBQthaw20Y+7FEAAB+ FVCn/MaVa3SnovzJQvrTttbnGKDRigQfh7Uu2gBRijFAwxSEGgBaTbQAZPrSZ9f/ANVABj0ozn3p gJkf40ZpAJn/AAozQApPrSEmgQZ9KMf/AF6YBj/61GBQAZPejmkMCabu9M0xASf8+tJg96AF/wA/ Wg/5+lIABpM+lAxMGmtKB1PHVj6KPX6UyWVbDXbK6BOm30FwoOyXyznYxH8VWgP8M+lP1BPyDcfX /wDVRn0zSGB/+vRn3xSATNGT/T6UxiF8d/wppkz0/wD10CE3mkz/APW+tAeo8W7HsAB99j0X6muX 1r4r6NZZDXazP0McfZh6tTiiJS7HmuuftHXsmRpqqoPC8fdB/wBrFcHqXjC/n/4+76V+wCk4FU5f ykxj/MZRLHkjB7kdx9TTJZLeJS19PGi9i/v7fSueUjbTqctqnxv0SAkWYlu36bUBAGP9vFcVq/xo 1y5/49fLso+6R4J5PdiPSi3cybb/AEOZeSRzm5kaVupkc5NKASeBnvj2Hr9KhyKt2Irljj5cH6/1 qxaqfL+Xp0P1+lD/AOCS2cPrUpMxw/HVc98ev4Vz90TuOTz39zW5KEU+pPtTs+pPt9aXoUv+ATrG cct+NP8AKfs5/wAakf8AwwzY3976e4pfLc989wParuJCEN6//WNOEMn9/I6H2oAXbJ/e+n0p3lvj qD2+tNsmy6ncfC5JBcP5m1vkKhB/CCD1r0TxO5W39PmVeO+c9fpUsP8Ahzy65kk3/ulUDoxPrWhZ y3QPCKT0I9B9MUkQ0u/ma8M9+BzEgHoM/MT2PHes3T9MltbhnWH5n+RYx0Q8/wAzVMqPr5M7GwXW JnVbSwjlkYiKGHP+skboOg6n3r9BfBvgSPQrKKFFQShRNqsq/wDLa8frk+xqZv8AzZtSW+v91Gqq D/PrXN/EvxcunWh2th2+RFHce1NFSZ8qW3xN1fS5jJoGnpPI2Y5WdsbVJ7cd63Yv2rfGi/6zwzbS dmBk5wP+A9qqLX20zlqU30kXoP2rPFvG7wZbEdc+b1z6jb3q3aftSeJN/wC88BhnIwyrKf3ePUha bcP7wKnLpNHqng3x5earZu+qaM1g4fykt92fMTZnk4HQ04REjJbGOSv96uaX907YL+YydbjjMRNw NgIIiTP3iQev0rxp5ILMFdNgBcnDyemc9DjtVRXV+hE5dPvLkhTQIxLeyiS+YE2Nq/PlR4PMg9h/ 9avGtW8R3F25a6mMzkmQk/xFiegHqK1orq+uxhUf8r20K8VuT94Y7jH8P0r0j4bfCVtUcPfRyrZK Qt3N/wA/D8/KlKq+3ozaku/qfR4tYEVRZW0UKL8sUKdl9zQQ3b5eenrXNY3uVw458wdPlVR3Hufr ToZ1xl49uRlF9vrQwGQ25yu1cEguw9B71PESv3ie4Y+oFMV+7I5GjDfKCG6o2M5H1NRosr/6qMqu dm1e756k+9SNHFSfG8Pfm0s9Inlulb7PPcMflWELkspH90ev+Fd0IRHnGSM7VPqOetCkunzIjfy/ unWwzrY6e7SgIz7p39hjv9K858CWzeUzTKpLsZ2J/urnr9a2KR0O1GOeFXGeP4mqO3cDOQHbOUz/ AAisx3/yPNvjJK2yMOmM7ppGz1bB7e1Wf2WFU6fdkJ1u2yR3CxL0PtVUutv61FU8yh8X3zfNzn5Q i57cd/yryrWCeN31z64omikjFjJGcEAjlMdj7V02kePdoC35JT7qP6f73HasYvz8hy/4KNy+0G3u RmDDdw47kenFchfaFNCf3iDb03j+97j6e9KcfLyZUZeXkZ8cY/vk98HtUiRYHXPcMPSi4P8A4ccW Ue3cU0Nu6gH6d/rSS7Dfkdx8L/iVPoF4kkZJt2Ittaj9bZyeQf8AZNfccsNrfw4JWSGReCP4o5B2 rri9PwORaPT1R8UfE/4VT6Pcurwr5RJmspSPvxMT/IV5xJDtP8Q7/Qex9q47Ho1V2/xETSf7Ge5/ 2vwpuCeoAHQ//qp27mXyA5PQgHsPemMpH3gM9Rj1PvQCXcfDMUYcj0IHcH/Cr9/aMQDk+v8AvL9a qP8AwTLr+BlzxFlO1z/eBHoD/hX6K6WAtpAF/wCeUYH0EQrem/LsyZ9PmViRnrjvXinxN1FZpTsP Q+WCOxUf1rVIa/4B4f4pjUxnzDjngepzXAHIPzf7oX1H/wBauSoaRGGT2z7+n0NbXhcBpvkPGCGJ /hOD396n0QpeaOunPPbPT8R71o+HtaE6ffBKkwSc9GU9wfUYq35E2/yOM+IuixpMrx5CuMH3nXPU +4rjCo7D2A9B9KwsdMkRFAfv5x7evuarRKSOBjsPYD0+tWn3My9p2jvcuijDDOZFHaMeteoX14tv GSuFVQWDepA/xqr6fgTbU8gmuWfl8biTI5/vMSen1r0jwjEBbj5COpwO4JNEUTUZX8VuUt32Ieqq uOxOa813En7qjsWPpUWNV6CTbIxk4k74XsMelQTOxAOR6JH/AHkGf5GsHL/gCbX6D9He9aQDTy6z 8mBl4MZAPO7/AGRXN+Ir7VYJMPIwVd0cYA+8CSNytjofWoh/fXqZNPv/AMEg8BeGNL1G4Ua5NLtT N29qBxcqn94+/fmtOOJhNLLpOpx2cSbhBboNuZt54iGOikcY/Dirq3Ji19u/Y5zUIbqcrLq/mOGx NCZDnzI9x+8f9rpXVaLp51ubbaR+TEfnlQfwwjqMY/iqGtPdX90zkv8AM9l8Ra7ZaDaAW0bBQPsG lwpjLFgRkD/ZrwjWLlJMbRIW6qZOqEk/fJ96uq9jZp22XmcpcQSbsws5z8jEDpyfatzTfEK2sbIE hJbE0k4BzbNHn5SMf8tB+Hr7btLZ+hk12+R0Gm+OrAQyAW3m3b4WK7bj7JEo7D/a+nH8oNQ8e2V5 Kp1BIlkUCCN7dMAxqDksvcuT6j06V57o/wAvqKM3+hlaFrOprcu2nJ54G420bA5aM552gelWdQ1G 6RXa+kmOT5eOwuGB7+2KcorT7i7dn5kGksotCs0cYyxvN5X5tgB4Ln+8c/XvTLzxxqOoLH9stkuI Y8Q6bCR8qQsf+WnHc/kOOgFaNb3a0+EST6N9jovFPjFra1RLVEhZji4kAwQmTkIB61wjXNjt/eif zs5CFePL+vqDRhYbvuxvz+Z1vhLxN4gRHh8L2KKj5nvrgclIUXnAIOMgew7mtXwml1HMTq4cckwO 3V3x2X/Z4rWpST/Vk200f96x39o1rBlryURR533Eh/hY5+5+NI/iGZ2x4eZJbbkySzAgkEcbCR3+ laVJbKO2zNory8wudXVQEtLKK9vHISGEuAqyZ/5aTHjGPyqKw8cxqsv9t6P9nMR+zzMHzvnA6Aex H1rGdddebsim+zXmcqf2gY5CwXwlK4HyK6ufmb/awP6mmD4qidSYfDyhhwqNIR/31x61u5r+Zmd3 5djOm+Jzj/U6DaM/3ShkP3m9BjtVFtceXat3BEvz/aJoP+eUyA/ePt+FNtfZb/mNYv8AyNNPiBHh 2l0KMRL8sBLH/SvcDH8Rqhb/ABlgIO/w1B5hOYIw5wB/tmlGV9pPsYuT6ryNfSfiHbyk/a9ItbYY 8weWSTJIPb61Z8OePLa6mA1XR/LhBMZePqDj/lpn3rOcu0n3Rom7bPueiaBo2gTNv1h1S0DG0lVR 8xdl4K59Tx057V6dP8HvBflSjStPmubgQnUdPftKyr/dA6Z4659qzpz095m0K1n8K7Fbwn8JvD2q Kht/Dc3l7FOpTzc7dRx82046A9OTWv4y+BPhuxsJpNNs547iNfNtpUP+qm9dg9PrXQl5vsdFKo7p TS/kZ5/+zR8HtM1aC4uPFOmy3RMv2TTjJkBoETnaO+GNe4r8A/B/OzwvbL2U5Pyn8a1cPN9zH2rT fLbeyJf+FIeC4xlfCdmW6AnOWI7ge1Ft8F/CKf63wvbOTyue2fpScPN9ivbvyLkfwZ8Ij/W+GbP0 IHcfSpR8I/CC/d8H6eSfvMwNUof3mR7eXccvwo8KjPl+FdNX+8wX/WGnp8MPDC5EXhLTAT80jhfu r7+9Pl/vMPbS/mFT4deGWxs8M6eAOSxXl8ehPauV+K3gGwOnTtoWi2VrKg85GhGCFXOTuFKS82aU qjuuZ/3WcF+y78KbSKxlm8SaVaXM00hfTJJjuaKyhXHLe757/Wvb18I6IwIl0DTnQ/LJlByp/umr a/yOeM3d2b3sj50+I/wcuPDdys+gwJcWm77VaQOMrFk8q/8Aujv1Fe0eEviLoWqQq+k6LZ78Y1GE IM29yeoY4HU0RXcrEN3Tg3rpLyZ1Om6DaK25tNgVjwUZR8i+4rVv54RgfZ7de3CD5R7YFLl8ifaP +ZmW14YwfsyRqSdxIA+79Md6ks5plxjy3Y/61QBg/j7Ucq7IXM/5meLfEK/MkxwxwMoM9mUn7pHt xXnF6Bg7M4wcf/XqGuyR0y82c9bu395vce/1HpWhGh7/AJ+5963SOOZaihx93J7Z9BUyv7nHQAdw fWto/wDBMUWFUcbcjvkfwn/69XkiYjgHd90N/tH1PtTRPofTugwvDBEoZgAi5Gf4iPStDex6u1KS HT/4J4J+0zpW5rZ3b+A2wPqyt/SvSfhK4k0iII/ymN4CPbB6/Wpt/X3nTX+z/Xc8n+ANsbfUZguE BidBGv8AEiSDv9a+jBk9yat/197Jr/E/vDZ9Pc0bR2pEGWihp2yeiiIH3Pv7VoYosJn5WwpbjPmY I7Z7/Wpwtke6Dtj+5XOzRJ9UJ5NufutGe6t6Gq1vZQseXU9cE91Pv70hXLbafbd9h749BVS4sLb/ AJZY9Qc9KF/w42+y8iO3hjP+vYsOgB/h+n1qwtjb9mIH8Az0H1pgvQfLZRAjYR6Mc/eB9fpWofD9 hIRuYkY+Uhuv1NL7wT7pEw8K2hHyNg/dCg9v9oVmy6Jab9qzPt6g+rimvMfOvLzNI+D7XAyxB++p z39qrzeG4cEidl9RnqR7e9K3YUpdkjLis1I+aV898e1SJpCk/K7f3Wb0HtS+fkEWuwyWydDhLwle j57YqwdEJHEzeuPVR70xW8vQYunTf8s52B6ADsB/hV2z0eWUHfeE46ZHb2p27hdfqPPhiTPN7nqP pkdxiopdDnTGLslehyPX0+lFn1HddCzP4UlH/MRDDptA6Y/DtTT4bkQZjvfM7IpH9aS9PUm68+xV tLO6lJ8qbbjgtj7oNXU8PXinP20IfcfeB9KGXC3W/kS3N5ewAH7Wj9hgc8j6VyOp6nMznzG5zlj6 k0zKVvs3MuWRyeuPemsf9r2yKaJLVjqMkZzH1GM/T610GtapHKFa2dAx4uEHdh7H1rWJnIo6dMyf OJV3B45FUn+5KOlfrbbXguIImUffiSX/AL6irK2v4HZ9n5pfgzy6RcE7lHUgj8ajZc9seuO9NnKh jjPXj/H600Z9OfUelA7lO6UxkFckdJB6itGNwRxg5+YEe9NiQoYZ5zTgPqe/0oQ/UXbzwfxp3XqB 9fekA0deo+tOJ9fwNJCSFTGeeemfwP8ASu9vWyFyR0H4ACmX/wAMZzEN90HHdh3FQ/ZXfqQvfB9P /r1DD1EfOeuQOB9aZOQx4z7Ed/8A9dSUKmms5+SFmbuAOv4+1btp4Dmc/vx5Y6HPcewqkird/kdF aeFLSPkwLI395vb0FapBPXGOwHYe1bKJlKQbaXH+fWqIDJpRQAoY0u6gYgalB/z6UCDH5elAP+fS gYEUuRQAUhoATHpRigApM+1ACcUY9aBBRTGFFAhMj0oxQAuaP8igYhbHak3ZoEBFGP8A69ABxQaB iY/xpcUgEx7+9Jn3oAM1n6/qkdrbTvLcCHbGzRyn+GUqcYB9TVRRE2fOn7Gfio3CaimpX4mvfNW/ AbAM1ttILBRj7pAHSvprbRLd69dDR+nSwFf/AK9BHv8ASpJG/lSEjvTGDPTdx7fnQA2nJA5+4pPY UCKGq+KdIsRnWNVgg7hCeWPsB615V43/AGo7ARlfDen3MzAhhd8jOD/CuP8AGtFH+Z+Zg53+BeTO Q1n4za9eLi71WRU48yOIAbwPVh/jXLMzt0Xnsx6/mazlM0hAjNuBy8qj+J93HT1JrmtZ+LmgWPEt 0bmTkrbQ5OSPVhWGo5zS+E4TVPj/AKpPxpVrHZJ0WVuW2k9gRXJXur3VySb+6nmJ5G89fwq219kh L+b1CFMkCJSD0A+tWJrKWM4uYnRu4I7/AI1k/XzNlF9vUhWM5+4B6H1HvSsD/DnPUD2/+tQL/hyC 8DDGQpPVf/rmrduuY+OOxNOxn6nD60B5zYC46Z9MZ/nXP3ZO48gdgB6VsJLsMQt6ingP/eFAyVC3 8R9x7fSnb3/vY7D6Uv8AhgYoRz/Fjv8AX8ak+xyDOWIPUe61f/Di9fQjAYfxn0PvTlEg6SY9vX60 kCFRZD0bH9akCydmB7gGqaDT/I7j4Wq3nvvYE7SUHvg9RXovihALf5s/eUYH8R57Vm35eSBr/gnk 7xz7jkp1JAPYVp2kd3/CyZ/hPqPrVIzaRtoL8jgxnncc9qtwLeZyYYCf4M9yfw7VaIsv5mfQv7MP wvu767efWYIjZ24/0X/pvqMgOMD/AKZDnpivqq4uC5yT7n2rG/8AkdyWit/iY+2gyfm6dTXzr8c/ HbzzbLd12r+6jQd2YHv7/Snf/IUv+CeZaNr92pw/w7lu9vyySpJ/rGP99SOM10t1rcsiED4S6rC2 MLMrZ8s89gOcGhtdeYyjGX2ZUzL0z4hS2X/IX+HuozJ1Dc5QfQDtXTW/xh8OK2X8CayMjdG0aE7c f3ttZ6d/IpQqdOQ9U8F+IrO9s3bS9PubJPMKPBOpB3hOpB/z3pl3qEMSM1zKFXoij+NjSa7G6v8A bXmzzvxr8QbeRFXTlPmdZmz0GPevKLvUrh2/0KRkx+9ubkfwsvZTj+Krl2+bMU+/oc14m8U6jfSM 2pXTSP8AcL4H3VGPugdvpWGlqR2X3Yd8+tdN+3yM1Ht6jNU1oW8bEHeBkRRn+JvbFfV3hH4h6HHa WiTyW1hK0YCWhOS056k4H8Z59OcVxzkv1NNVun5eZ26W7nJjUEdQT3H1ppaIj5p1B74/hPtUm1yp JGrn/R3UDp5h/iP0pJbgMcfdA+R2H94en1qf+HGhnkhtwDvHkbVkXqpx2P8As1XWMRAH7XIY0Gzz JON2e7E+tDfaxXqiCx8SWd0xXSNSilZRm6eMg+UT3K/SsDS/iPHfXFzZXMElteJG9xFdRk4uYHTh 4iR759u9P0fmvUxUuqXr6HF/A3RWhe5k8Yzwx36P/YcUty3Iht1PO5v7xIA7eldp4m+M9tBLFDpj w3txLLHYQSRciASNzuC+q++P5VjBLdp6vUTl0j/hR6b8Yb8WlokcDgEgQ5Hc/wD1+awtPjgtYIwE ZiQEI9T3rqf/AATVE0d8pb9xbAKBjL/3fqam86NzmLaAOI2/vn1AqR/0zyv43zx/ug5OdrHI/vE9 /pWv+y1GRpU3CgG6kZR3K7R1rSmt/T9SKj2MT4syg30nXgBdvtivL9YkzjJHoq/3RzUTNEYki8/I QfWhD6keuPXNcyf+Zo12Rqad4qubb/VqXX7zxn0PoK7KG7s74Hayq3VkPd//AK1bKXcwk+3zOc1L wi0RJhjY9yoHRQD0+lYucD5gc+noT61mzo9PmJhj98j2x2FMhL56L6FvYUIhepbST+8T/iPrX1L+ zh8YjdRm21OU+dH+80t3PM1pnouf+eP8ulb0TnrLt6ncfGD4TxaxasYYgbqMGa0YdXUDpn3r4r1L SGQkPGwYEqwP8DAnt7VjUO+L01/wma4253ZHfp1x6VGIgfu4z0we/wBan/hjO/YjeIZ+YDPQ+496 axJ6gf7QHbPp9KEiSFlHbIHf6mt6wlM0ZBxuHDe6c9PpVoh+hkSxOG+XpkLID6buo+lforCgEEWP 7iAfTYO1bQRMun3mRqN+IY2ZuwIH+8RXgniSUy53kAk+YT6mtUDfY8v8WQgxNnA5HPcYz0rzpx9f p/jXNVWunqaw21I2688egFbfhVcSHGMY5x2bnqKyj6hM6x5Ofuhh0I9QfWsLwjqhimdZAMNm4jA/ vqT/ADFaMh7fidN4p0lbu2bbhmT/AEuNT/Eqg52j2FeRsW7YHpj0NZm3RW9CJmIHI+oqGGMEdOvI +lKxN+/qdf4F03LM7KcD9zED/E2D0qx421FggRerHzpV9IVB4/E1b8xR8jg3TPTA/hC+oP8AhXqH hyJkt05zkd/4cE04+ZMvP0MzxtcYt/lXkuPlHQbQep9685GfY98e1Ztd2alS7u7uJSdOwJeisR93 I/rWfo+s3FmyHU4UlZvkKuMgq2enH4ex9656lr6/4Uc1RdmXtU13yHMumbLb/lgtonOd/cEj/Pao 4L8XLSHW45bpiPKWUtykm04/CMY4x04rNQ6N/Maj5+ZQtltoGH2DzUuhlGUDgRYP8WO36VRuPAer apcRxeHoQ5OZlZyAINoJZpGPovelTlr7/wAip26+jLniDS7CG3OzV3nhUixjnOAbicZyI48fdQ8A 969X+EPgh7O1D6ggSZ8yI7DmKxGe+P4RW9JfzL+8KS/l9DkPEfxI0y8viviyK+h0+P5dLlthlpmH G4xnsDn37Vy3jaDTwceGb9rqM4dZ2GDEeeHGO30qZx2fyZbqdHFW6Mx7jxp5SIj2kQRQTIQOZJ2H V2/2f89qxG1NQxK4cHmUH+GtoROS76vzQ6MTz5Gm2s8ncqik4B9cCorac2xIubSVXycl8gxvnupH ar07q+5dnujTtPGVxDNu028e3JHlXTKB88be2KTXdYmnYKNQa4jXM8W3ohI6quOpHtn1qFDvFE37 +hpaP4ujDD7ZG1woBFxCq/8ALIA85H90c04alJDCXtZY4oWYw2MBx88bk/w/1x9KxnS8hqXd+aCP SdVm8t7mKKYIfMjjmPyhM9HA9f8AJrem8IX+sPvFvFH6JCuFGCehxWsVZaL08zaEPM3dJ+E2qWu5 01o2zEbJ7eAj54vTdjufwrd0jSJp/wDXkyMvDO3/ACzUDpn6VUH/ADLyRpKl/K/Ur6/PpUHPiW6x Ev7y2tME+ac/3B3NcPc+O73Wpivh+3+w2o/dgk/MF9WGO/4U6jVrv1JlPsvJGa2trZ8eez7GZcg8 tNk9CBWFJ4lvpOEuX2k/aXUHrMx/u/5965qMFvNf3kYPyXodP4b8TPGzLHbRmLHmzSP/ABTHOAOO /wDnFZX/AAmJiLHysvuJGegGT2ApKGu/myovcqfbzuDuibgwmJ/2gf4fwr0LT9a03TphLfaBDdRY 3TW02cSpKP4mHc//AKsGuxQXfyDnfT1OP1LW5dVnc2lkLW0yZLC2j+7box/iJHVhWXqejJbFQtwJ HxvlI/hBP8VYwdtIrzZrJ33Xmeg/DH4gaTou6a80az1WcA2cGlXQysYfPzx8HlT7Zx055F6HXvOi k863WGAN9vMKD/ltg8ZA/i/XvXNil/myaUn+pRsNZvb5saeyWy9YEJHDH+8zf3a6zwn8Z/FGjTH7 DqkV0202N3DPjEyA9EfBxjHHpWMWl8tSprv6I9WH7SOpC2H9mXUelMPl+yooIuSx5LMR1Y/Q56Vo p8aNRk0+4WWFLktGUF8TgxzSDnEffJ981usRrZR80aUYPRuWt7s3/wBn/VrpdJiRdNniIaS5lkcH 97I7nnB9Px9elelR63Cx2yrIr/fLEfeX/Z/GvTv5eQmnd+rZcMW45YjPQIewFKiHu2OwxVEomVQD 8ygnsT3p3mOOoX02+30oECwPjk5PXd6Aegprludi4H3eP4s+9MaFWBhzIOMYUj+v1rnfiRZXUmmX C6VEZbl1MFrAnUs3qB/n0pWNaT1V+9zM+Engu50vS7aPVrVobkJuv4m6xzOec/U12qoo6j/9VNmC Xfvcr6rolnfxNFepvRgVdmH+ocjrGfUV83W0ep+CNQ/fCWWwc4vgn/LSz3fej909KE+/odFrppf4 4ep9OaZcQXKpJZzLNA4E9rMD99G/wp9+pJ+QAdgp/wAaGjmpy/4JQFq5P+rjHZ3z/OnG2AyElHH3 5T/CPYUPyNf+HPB/GFwrzN5AJGTsP94A9RXC6nMQpIJ7gkehHasjd/8AAMSz2gc5PqPariAHqfov oa3ivI5Wi+C2Oceh/wD1VLGvsfUk+tamVv8AMmAwRkfX3FbFjAZHUfMCWVFA7Zbt9KuKIb7n0/DD tCg9gEx/uipKgcDyf9oTRDNZwtEpYpJsYDtHIPX2FbnwJfdpsYYg4eSAAdxz39s0jprvSPry/meZ /CR/L1iQKSoImjX2CuOv1NfRQP8AgPeq/wCH/EMR8T+8Np7fl60Bc9vzpGBl2IDPIVOfm8sH/dUV
March 06, 2011 - Present
AeroElectric-Archive.digest.vol-kg
