AeroElectric-Archive.digest.vol-kq
September 09, 2011 - October 06, 2011
      >> They fail in less than 10 hrs of operation.  Interesting both seem to
      >> fail
      >> nearly at the same time.  The "pulse" mode for traffic recognition is
      >> the
      >> major use.
      >> My ignorant guess is that halogen bulbs do not like to be pulsed or
      >> ramped
      >> up too quickly during pulse mode.  If the rapid power ramp up is the
      >> primary
      >> cause, I am wondering if an appropriate choke (induction) would slow
      >> that
      >> ramping down and return normal life to these devices.
      >> Any insight, suggestions into the failure mode and how to work around
      > it
      >> would be greatly appreciated.  David
Date: Sep 09, 2011
Subject: RF noise from Jeff's LED lights
I am getting a loud hiss on both aircraft radios whenever my LED position lights are turned on. In fact, any FM radio in the vicinity gets the hiss too. I have "Jeff's LED lights for RVs" installed in the wing tips along with Bob Archer antennas. Though it may be worth noting that the SL30 Comm antenna is a standard belly mounted bent whip. I know the RF is coming from the radios because if I turn the volume down on the radios, the noise disappears (in other words, the intercom is not affected). The archives have some discussion of filters, resistors and capacitors but I'm not sure where to start. My first inclination is to disconnect one at a time to see if the noise is coming from both lights. Then I don't know where to start. Please help. Bill "falling in love with his first George" Watson ________________________________________________________________________________
From: Bob McCallum <robert.mccallum2(at)sympatico.ca>
Subject: Halogen bulbs with wig wag circuitry....failure
mode
Date: Sep 09, 2011
David; In automotive use halogen bulb life is adversely affected by low voltage, high resistance connections, poor grounds etc etc. "Dimming" a halogen bulb (at least certain types) is deadly for it. A bulb operated on low voltage will very rapidly darken as the filament material which evaporates is deposited on the quartz envelope and the lamp will rapidly fail as the filament cross section is reduced. I'm told, but don't quite understand why or how, that operating these bulbs at full or even slightly increased voltage somehow keeps the quartz hot enough that the filament material does not "plate out" or coat the inside of the envelope and instead migrates back to the filament keeping the filament intact and extending its life. That apparently is part of the purpose behind the halogen gas filling the envelope. I don't fully understand how this process works but anecdotally have proven it to be correct. I had a van with H4 halogen headlamps which used to "eat" bulbs. Couldn't keep bulbs in it for love nor money until I discovered that the voltage regulator was faulty and was barely keeping a charge in the battery. Upon replacing the regulator, thus getting the voltage back up to spec, the battery was noticeably healthier, starting was much quicker and easier, the lights were significantly brighter and they lasted for several years rather than the couple of months I'd been getting from them before. Your "pulsed" circuit may have the effect of appearing to be a reduced voltage source for the bulbs causing a similar situation to what I experienced first hand in my old van. Or this may be totally out to lunch and Bob's theory of heat cycling may be the answer, but because I've first hand knowledge of reduced voltage killing halogen bulbs I'll put the theory forward for whatever it's worth. Bob McC > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list- > server(at)matronics.com] On Behalf Of David Lloyd > Sent: Friday, September 09, 2011 1:31 PM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Halogen bulbs with wig wag circuitry....failure mode > > > A general question for Bob and the List Members concerning halogen bulbs, > i.e., GE H7604 landing light style. > > I am hoping someone on the List knows a lot about halogen bulb failure > modes. > > I have H7604 lamps in my wing tips that aid landing and traffic recognition. > They are controlled by a solid state switcher that is either OFF-ON-PULSED. > ( I do not know the turn-on ramp characteristics..) > > They fail in less than 10 hrs of operation. Interesting both seem to fail > nearly at the same time. The "pulse" mode for traffic recognition is the > major use. > > My ignorant guess is that halogen bulbs do not like to be pulsed or ramped > up too quickly during pulse mode. If the rapid power ramp up is the primary > cause, I am wondering if an appropriate choke (induction) would slow that > ramping down and return normal life to these devices. > > Any insight, suggestions into the failure mode and how to work around it > would be greatly appreciated. David > > > _- > ==================================================== > ====== > _- > ==================================================== > ====== > _- > ==================================================== > ====== > _- > ==================================================== > ====== > > ________________________________________________________________________________
Subject: Re: Halogen bulbs with wig wag circuitry....failure
mode
Date: Sep 09, 2011
I used inrush current limiters on my halogens (450+ hours so far). Since this also causes the lamps to take more time to reach full brightness, I modified the B&C flasher to slow it down by doubling the capacitance of the electrolytic capacitor inside the can. Double the resistor value would also work. V -----Original Message----- From: David Lloyd Sent: Friday, September 09, 2011 5:47 PM Subject: Re: AeroElectric-List: Halogen bulbs with wig wag circuitry....failure mode Bob, I think that you are totally correct concerning the thermo rapid cycle being the stress failure mode. When viewing the filaments with a mag. lens they look completely normal and intact until you look carefully at one end of the filament. They are broken at the very end. Odd that I have not run into others that are having the same problem as these bulbs are used in a lot of recognition applications. I suspect that if I left them ON continually, they would last a normal life. And, as you outline, in PULSE mode the thermo aspect is too much stress. I wonder now, if there is a heavy duty version of this bulb with bullet proof filament structure. I am installing new bulbs when delivered and will report back when I have a similar failure. Hopefully, I may have learned more. Thanks, David ___________________________________________________________________________ ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Sent: Friday, September 09, 2011 4:15 PM Subject: Re: AeroElectric-List: Halogen bulbs with wig wag circuitry....failure mode > > > I have H7604 lamps in my wing tips that aid landing and traffic > recognition. They are controlled by a solid state switcher that is either > OFF-ON-PULSED. ( I do not know the turn-on ramp characteristics..) > > They fail in less than 10 hrs of operation. Interesting both seem to fail > nearly at the same time. The "pulse" mode for traffic recognition is the > major use. > > My ignorant guess is that halogen bulbs do not like to be pulsed or ramped > up too quickly during pulse mode. If the rapid power ramp up is the > primary cause, I am wondering if an appropriate choke (induction) would > slow that ramping down and return normal life to these devices. > > If I were to do a WAG . . . I'm guessing that you're > getting repetitive stress cracks in the filaments. > These things operate somewhat hotter than their older > cousins . . . most seem to have heavier filaments too. > > There are two things that erode filament integrity . . . > evaporation (total operating hours issue) and stress > cracks (combination of vibration and temperature cycling). > I'm wondering if the halogens are not more highly stressed > during each illumination cycle. Since a wig-wag operates > on the order of 2 flashes per second, 10 hours of flashing > would offer 72,000 or so temperature cycles. Far more cycles > than would be expected in automotive applications. Just > assuming 200 cycles per day in a high-beam lamp for night > highway driving would take 360 straight days of such service > to equal 10 hours of wig-wag. > > Any insight, suggestions into the failure mode and how to work around it > would be greatly appreciated. > > Not sure 'current ramping' would have a very useful effect. > Some of you may recall an experiment we did some years back > to evaluate the usefulness of inrush-limiters in wig-wagged > landing lights. Remember this plot? > > http://www.aeroelectric.com/Pictures/Curves/Wig_Wag_Currents.jpg > > We discovered that the lamp temperature stays pretty warm > during a 250 mS off-cycle such that you don't see the typical > cold-filament inrush each time the lamp is powered up. But > the temperature excursions between no-visible light and full > intensity is still significant. It may well be that the very > thing that makes the halogen a stellar illuminator amongst > incandescent lamps is it's Achilles Heel as well. > > Just a guess . . . but until I hear/get a better idea, I'm > sticking with it. > > Bob . . . > > ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
From: "Paul Zimmer" <stickandrudder1(at)comcast.net>
Subject: Low Cost WigWag Alternatives
Date: Sep 10, 2011
Bob, of the alternatives presented in your article 'Low Cost Wigwag Alternatives', which would be most appropriate for a HID Taxi and Landing Light implementation, given that the HID lights need to be warmed up prior to flashing (assuming a manual warmup perior prior to switching to flashing)? Also being unfamiliar with the B&C WigWag, do both switches need to be in the wigwag position in order for wigwag to work, or is it an either or situation?. I'm referring to the to switch drawing on P.5 of the article. ________________________________________________________________________________
mode
Date: Sep 09, 2011
I bought a 55W HID kit on Ebay for $55 + shipping ($70 total) as other have. Most HID's are 35 watt. I'm expecting these to be about twice as bright as 100watt incandescent, but haven't powered them up yet. I don't consider this to be an expensive upgrade. Bevan -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of David Lloyd Sent: Friday, September 09, 2011 5:51 PM Subject: Re: AeroElectric-List: Halogen bulbs with wig wag circuitry....failure mode --> Bruce, ...also a good suggestion, but, like HID's they are quite expensive when one needs a really bright recognition lamp. I plan to keep watching the LED market and see what comes in cost reduction.... Thanks, David ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ ----- Original Message ----- From: "Bruce" <BGray(at)glasair.org> Sent: Friday, September 09, 2011 3:44 PM Subject: RE: AeroElectric-List: Halogen bulbs with wig wag circuitry....failure mode > > OK, how about LED? > > Bruce > WWW.Glasair.org > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of > David Lloyd > Sent: Friday, September 09, 2011 4:49 PM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Halogen bulbs with wig wag > circuitry....failure mode > > > > Good suggestion...all except for the considerable cost for dual > sets..... > David > > ____________________________________________________ > ----- Original Message ----- > From: "Bruce" <BGray(at)glasair.org> > To: > Sent: Friday, September 09, 2011 11:16 AM > Subject: RE: AeroElectric-List: Halogen bulbs with wig wag > circuitry....failure mode > > >> >> Switch to HID. >> >> Bruce >> WWW.Glasair.org >> >> -----Original Message----- >> From: owner-aeroelectric-list-server(at)matronics.com >> [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of > David >> Lloyd >> Sent: Friday, September 09, 2011 1:31 PM >> To: aeroelectric-list(at)matronics.com >> Subject: AeroElectric-List: Halogen bulbs with wig wag >> circuitry....failure mode >> >> >> >> A general question for Bob and the List Members concerning halogen >> bulbs, i.e., GE H7604 landing light style. >> >> I am hoping someone on the List knows a lot about halogen bulb >> failure modes. >> >> I have H7604 lamps in my wing tips that aid landing and traffic >> recognition. >> They are controlled by a solid state switcher that is either >> OFF-ON-PULSED. >> ( I do not know the turn-on ramp characteristics..) >> >> They fail in less than 10 hrs of operation. Interesting both seem to >> fail nearly at the same time. The "pulse" mode for traffic >> recognition is the major use. >> >> My ignorant guess is that halogen bulbs do not like to be pulsed or >> ramped up too quickly during pulse mode. If the rapid power ramp up >> is the primary cause, I am wondering if an appropriate choke >> (induction) would slow that ramping down and return normal life to >> these devices. >> >> Any insight, suggestions into the failure mode and how to work around > it >> >> would be greatly appreciated. David >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Sep 10, 2011
Subject: Re: AeroLed landing lights not working with wig
wag relay Check out the Show Me units - Their a Wig-Wag flasher unit like used on emergency vehicles like police cars. I have one of these on my plane which drives a pair of driving lights for the purpose of recognition lights and it works good. The unit I have allows you to select flash both, alternate flash, or both lights on. Also check the wattage of your landing lights and what a unit can handle. They can be purchased with wire pig tails or screw terminals, I got the one with screw terminals. Also there is flash rate, I got the slowest I could get which comes out to be a second on, a second off. I think mine cost me around $45 dollars a few years back - I use it for switching recognition (driving) lights on my ultralight. http://shop.store.yahoo.com/bcssales/shomranheadf.html Do a search on Google.com for Able 2 & Show ME wig wag flashers. There is a lot of price variation between places that sell them, I got mine from the manufacturer - they had the best price. The problem you may be experiencing with the LED lights is the low current load if the unit using a thermo-switch much like a turn-signal flash unit. I don't think you would have a problem with the unit above. I now had the units and the driving lights running for over 10 years. My how time flys . . . . jerb At 08:13 AM 9/9/2011, you wrote: > > >At 07:56 AM 9/9/2011, you wrote: >> >> >>I purchased the B&C wig wag relay and wired it according to the >>schematic for an off-on-on switch and B&C diode assembly. The >>wig-wag is in the middle position. I included the >>resistors between the relay and ground shown in the updated >>schematic. The system works fine with incandecent nav lights but >>not with the LED landing lights. Only one LED light turns on in wig >>wag mode and both lights turn on in continuous on mode. The nav >>lights draw about 3.2 amps, the LED lights about 3.7 amp. Anyone >>know what is going on here and how to fix it. Should I just >>purchase an electronic wig wag unit designed for LED's? > > I modified that drawing for B&C based on testing I > did using one of the flashers from their inventory. > The resistors were added to emulate the fixed load > offered by incandescent lamps. You are the second > individual who was unable to duplicate the behavior > I was getting on the bench. I have a pair of Whelen > LED landing lights loaned to me by another reader > and I plotted their current draw vs. voltage curve > which I posted on the List a few days ago. > > I'm somewhat tied up with some family matters and > can't get back to the bench right now to figure out > what's going on . . . but the solution will not > be difficult. Sit tight for the moment . . . watch > this space. > > > Bob . . . ________________________________________________________________________________
mode
Date: Sep 09, 2011
Bevan, I think that I have viewed some of those on eBay. But, I came away with the idea that they were not a complete kit; power supply, harness, bulb/lamp combo, etc. I will take a better review of the offerings. Please let me know if you receive a complete operational system. David =============================================================== ----- Original Message ----- From: "B Tomm" <fvalarm(at)rapidnet.net> Sent: Friday, September 09, 2011 9:20 PM Subject: RE: AeroElectric-List: Halogen bulbs with wig wag circuitry....failure mode > > I bought a 55W HID kit on Ebay for $55 + shipping ($70 total) as other > have. > Most HID's are 35 watt. I'm expecting these to be about twice as bright > as > 100watt incandescent, but haven't powered them up yet. I don't consider > this to be an expensive upgrade. > > Bevan > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of David > Lloyd > Sent: Friday, September 09, 2011 5:51 PM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Halogen bulbs with wig wag > circuitry....failure mode > > --> > > Bruce, > ...also a good suggestion, but, like HID's they are quite expensive when > one > needs a really bright recognition lamp. > I plan to keep watching the LED market and see what comes in cost > reduction.... Thanks, David > > ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ > > ----- Original Message ----- > From: "Bruce" <BGray(at)glasair.org> > To: > Sent: Friday, September 09, 2011 3:44 PM > Subject: RE: AeroElectric-List: Halogen bulbs with wig wag > circuitry....failure mode > > >> >> OK, how about LED? >> >> Bruce >> WWW.Glasair.org >> >> -----Original Message----- >> From: owner-aeroelectric-list-server(at)matronics.com >> [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of >> David Lloyd >> Sent: Friday, September 09, 2011 4:49 PM >> To: aeroelectric-list(at)matronics.com >> Subject: Re: AeroElectric-List: Halogen bulbs with wig wag >> circuitry....failure mode >> >> >> >> Good suggestion...all except for the considerable cost for dual >> sets..... >> David >> >> ____________________________________________________ >> ----- Original Message ----- >> From: "Bruce" <BGray(at)glasair.org> >> To: >> Sent: Friday, September 09, 2011 11:16 AM >> Subject: RE: AeroElectric-List: Halogen bulbs with wig wag >> circuitry....failure mode >> >> >>> >>> Switch to HID. >>> >>> Bruce >>> WWW.Glasair.org >>> >>> -----Original Message----- >>> From: owner-aeroelectric-list-server(at)matronics.com >>> [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of >> David >>> Lloyd >>> Sent: Friday, September 09, 2011 1:31 PM >>> To: aeroelectric-list(at)matronics.com >>> Subject: AeroElectric-List: Halogen bulbs with wig wag >>> circuitry....failure mode >>> >>> >>> >>> A general question for Bob and the List Members concerning halogen >>> bulbs, i.e., GE H7604 landing light style. >>> >>> I am hoping someone on the List knows a lot about halogen bulb >>> failure modes. >>> >>> I have H7604 lamps in my wing tips that aid landing and traffic >>> recognition. >>> They are controlled by a solid state switcher that is either >>> OFF-ON-PULSED. >>> ( I do not know the turn-on ramp characteristics..) >>> >>> They fail in less than 10 hrs of operation. Interesting both seem to >>> fail nearly at the same time. The "pulse" mode for traffic >>> recognition is the major use. >>> >>> My ignorant guess is that halogen bulbs do not like to be pulsed or >>> ramped up too quickly during pulse mode. If the rapid power ramp up >>> is the primary cause, I am wondering if an appropriate choke >>> (induction) would slow that ramping down and return normal life to >>> these devices. >>> >>> Any insight, suggestions into the failure mode and how to work around >> it >>> >>> would be greatly appreciated. David >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
mode
Date: Sep 09, 2011
Vern, I am unfamiliar with the "current limiters" that you mention. Your solution looks great. Please give a bit more detail... I will check for my solid state flasher model and if it can be modified...(not potted, etc.) It was part of the RMD wing tip system. David =========================================================== ----- Original Message ----- From: "Vern Little" <sprocket@vx-aviation.com> Sent: Friday, September 09, 2011 7:57 PM Subject: Re: AeroElectric-List: Halogen bulbs with wig wag circuitry....failure mode > <sprocket@vx-aviation.com> > > I used inrush current limiters on my halogens (450+ hours so far). Since > this also causes the lamps to take more time to reach full brightness, I > modified the B&C flasher to slow it down by doubling the capacitance of > the electrolytic capacitor inside the can. Double the resistor value > would also work. > > V > > > -----Original Message----- > From: David Lloyd > Sent: Friday, September 09, 2011 5:47 PM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Halogen bulbs with wig wag > circuitry....failure mode > > > > Bob, > I think that you are totally correct concerning the thermo rapid cycle > being > the stress failure mode. > > When viewing the filaments with a mag. lens they look completely normal > and > intact until you look carefully at one end of the filament. They are > broken > at the very end. > > Odd that I have not run into others that are having the same problem as > these bulbs are used in a lot of recognition applications. > > I suspect that if I left them ON continually, they would last a normal > life. > And, as you outline, in PULSE mode the thermo aspect is too much stress. > I > wonder now, if there is a heavy duty version of this bulb with bullet > proof > filament structure. > > I am installing new bulbs when delivered and will report back when I have > a > similar failure. Hopefully, I may have learned more. > Thanks, David > > ___________________________________________________________________________ > > ----- Original Message ----- > From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> > To: > Sent: Friday, September 09, 2011 4:15 PM > Subject: Re: AeroElectric-List: Halogen bulbs with wig wag > circuitry....failure mode > > >> >> >> I have H7604 lamps in my wing tips that aid landing and traffic >> recognition. They are controlled by a solid state switcher that is either >> OFF-ON-PULSED. ( I do not know the turn-on ramp characteristics..) >> >> They fail in less than 10 hrs of operation. Interesting both seem to >> fail nearly at the same time. The "pulse" mode for traffic recognition >> is the major use. >> >> My ignorant guess is that halogen bulbs do not like to be pulsed or >> ramped up too quickly during pulse mode. If the rapid power ramp up is >> the primary cause, I am wondering if an appropriate choke (induction) >> would slow that ramping down and return normal life to these devices. >> >> If I were to do a WAG . . . I'm guessing that you're >> getting repetitive stress cracks in the filaments. >> These things operate somewhat hotter than their older >> cousins . . . most seem to have heavier filaments too. >> >> There are two things that erode filament integrity . . . >> evaporation (total operating hours issue) and stress >> cracks (combination of vibration and temperature cycling). >> I'm wondering if the halogens are not more highly stressed >> during each illumination cycle. Since a wig-wag operates >> on the order of 2 flashes per second, 10 hours of flashing >> would offer 72,000 or so temperature cycles. Far more cycles >> than would be expected in automotive applications. Just >> assuming 200 cycles per day in a high-beam lamp for night >> highway driving would take 360 straight days of such service >> to equal 10 hours of wig-wag. >> >> Any insight, suggestions into the failure mode and how to work around it >> would be greatly appreciated. >> >> Not sure 'current ramping' would have a very useful effect. >> Some of you may recall an experiment we did some years back >> to evaluate the usefulness of inrush-limiters in wig-wagged >> landing lights. Remember this plot? >> >> http://www.aeroelectric.com/Pictures/Curves/Wig_Wag_Currents.jpg >> >> We discovered that the lamp temperature stays pretty warm >> during a 250 mS off-cycle such that you don't see the typical >> cold-filament inrush each time the lamp is powered up. But >> the temperature excursions between no-visible light and full >> intensity is still significant. It may well be that the very >> thing that makes the halogen a stellar illuminator amongst >> incandescent lamps is it's Achilles Heel as well. >> >> Just a guess . . . but until I hear/get a better idea, I'm >> sticking with it. >> >> Bob . . . >> >> >> >> >> > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > > ________________________________________________________________________________
mode
Date: Sep 09, 2011
Thanks Bob for giving me other possible answers. When I carefully looked at the halogen bulb inside the lamp, they did not appear to have any darkness that I could see. Appeared crystal clear. I will look again... David =================== ----- Original Message ----- From: Bob McCallum To: aeroelectric-list(at)matronics.com Sent: Friday, September 09, 2011 7:16 PM Subject: RE: AeroElectric-List: Halogen bulbs with wig wag circuitry....failure mode David; In automotive use halogen bulb life is adversely affected by low voltage, high resistance connections, poor grounds etc etc. "Dimming" a halogen bulb (at least certain types) is deadly for it. A bulb operated on low voltage will very rapidly darken as the filament material which evaporates is deposited on the quartz envelope and the lamp will rapidly fail as the filament cross section is reduced. I'm told, but don't quite understand why or how, that operating these bulbs at full or even slightly increased voltage somehow keeps the quartz hot enough that the filament material does not "plate out" or coat the inside of the envelope and instead migrates back to the filament keeping the filament intact and extending its life. That apparently is part of the purpose behind the halogen gas filling the envelope. I don't fully understand how this process works but anecdotally have proven it to be correct. I had a van with H4 halogen headlamps which used to "eat" bulbs. Couldn't keep bulbs in it for love nor money until I discovered that the voltage regulator was faulty and was barely keeping a charge in the battery. Upon replacing the regulator, thus getting the voltage back up to spec, the battery was noticeably healthier, starting was much quicker and easier, the lights were significantly brighter and they lasted for several years rather than the couple of months I'd been getting from them before. Your "pulsed" circuit may have the effect of appearing to be a reduced voltage source for the bulbs causing a similar situation to what I experienced first hand in my old van. Or this may be totally out to lunch and Bob's theory of heat cycling may be the answer, but because I've first hand knowledge of reduced voltage killing halogen bulbs I'll put the theory forward for whatever it's worth. Bob McC > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list- > server(at)matronics.com] On Behalf Of David Lloyd > Sent: Friday, September 09, 2011 1:31 PM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Halogen bulbs with wig wag circuitry....failure mode > > > A general question for Bob and the List Members concerning halogen bulbs, > i.e., GE H7604 landing light style. > > I am hoping someone on the List knows a lot about halogen bulb failure > modes. > > I have H7604 lamps in my wing tips that aid landing and traffic recognition. > They are controlled by a solid state switcher that is either OFF-ON-PULSED. > ( I do not know the turn-on ramp characteristics..) > > They fail in less than 10 hrs of operation. Interesting both seem to fail > nearly at the same time. The "pulse" mode for traffic recognition is the > major use. > > My ignorant guess is that halogen bulbs do not like to be pulsed or ramped > up too quickly during pulse mode. If the rapid power ramp up is the primary > cause, I am wondering if an appropriate choke (induction) would slow that > ramping down and return normal life to these devices. > > Any insight, suggestions into the failure mode and how to work around it > would be greatly appreciated. David > > > _- > == > ====== > style='mso-spacerun:yes'> - The AeroElectric-List Email Forum - > > style='mso-spacerun:yes'> --> http://www.matronics.com/Navigator?AeroElectric-List > > _- > == > ====== > style='mso-spacerun:yes'> - MATRONICS WEB FORUMS - > > style='mso-spacerun:yes'> --> http://forums.matronics.com > > _- > == > ====== > style='mso-spacerun:yes'> - List Contribution Web Site - > style='mso-spacerun:yes'> Thank you for your generous support! > style='mso-spacerun:yes'> -Matt Dralle, List Admin. > style='mso-spacerun:yes'> --> http://www.matronics.com/contribution > _- > == > ====== > > ________________________________________________________________________________
mode
Date: Sep 10, 2011
Awhile back, I did a post about this exact modification. http://n999za.com/2010/11/07/hacking-the-wig-wag-flasher/ Of course, I was only successful because if this list's gracious help and advice. Hoping the pictures assist the discussion... __ Andrew Zachar andrew.d.zachar(at)gmail.com On Sep 9, 2011, at 10:57 PM, "Vern Little" <sprocket@vx-aviation.com> wrote: > > I used inrush current limiters on my halogens (450+ hours so far). Since this also causes the lamps to take more time to reach full brightness, I modified the B&C flasher to slow it down by doubling the capacitance of the electrolytic capacitor inside the can. Double the resistor value would also work. > > V > > > -----Original Message----- From: David Lloyd > Sent: Friday, September 09, 2011 5:47 PM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Halogen bulbs with wig wag circuitry....failure mode > > > Bob, > I think that you are totally correct concerning the thermo rapid cycle being > the stress failure mode. > > When viewing the filaments with a mag. lens they look completely normal and > intact until you look carefully at one end of the filament. They are broken > at the very end. > > Odd that I have not run into others that are having the same problem as > these bulbs are used in a lot of recognition applications. > > I suspect that if I left them ON continually, they would last a normal life. > And, as you outline, in PULSE mode the thermo aspect is too much stress. I > wonder now, if there is a heavy duty version of this bulb with bullet proof > filament structure. > > I am installing new bulbs when delivered and will report back when I have a > similar failure. Hopefully, I may have learned more. > Thanks, David > > ___________________________________________________________________________ > > ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> > To: > Sent: Friday, September 09, 2011 4:15 PM > Subject: Re: AeroElectric-List: Halogen bulbs with wig wag > circuitry....failure mode > > >> >> I have H7604 lamps in my wing tips that aid landing and traffic recognition. They are controlled by a solid state switcher that is either OFF-ON-PULSED. ( I do not know the turn-on ramp characteristics..) >> >> They fail in less than 10 hrs of operation. Interesting both seem to fail nearly at the same time. The "pulse" mode for traffic recognition is the major use. >> >> My ignorant guess is that halogen bulbs do not like to be pulsed or ramped up too quickly during pulse mode. If the rapid power ramp up is the primary cause, I am wondering if an appropriate choke (induction) would slow that ramping down and return normal life to these devices. >> >> If I were to do a WAG . . . I'm guessing that you're >> getting repetitive stress cracks in the filaments. >> These things operate somewhat hotter than their older >> cousins . . . most seem to have heavier filaments too. >> >> There are two things that erode filament integrity . . . >> evaporation (total operating hours issue) and stress >> cracks (combination of vibration and temperature cycling). >> I'm wondering if the halogens are not more highly stressed >> during each illumination cycle. Since a wig-wag operates >> on the order of 2 flashes per second, 10 hours of flashing >> would offer 72,000 or so temperature cycles. Far more cycles >> than would be expected in automotive applications. Just >> assuming 200 cycles per day in a high-beam lamp for night >> highway driving would take 360 straight days of such service >> to equal 10 hours of wig-wag. >> >> Any insight, suggestions into the failure mode and how to work around it would be greatly appreciated. >> >> Not sure 'current ramping' would have a very useful effect. >> Some of you may recall an experiment we did some years back >> to evaluate the usefulness of inrush-limiters in wig-wagged >> landing lights. Remember this plot? >> >> http://www.aeroelectric.com/Pictures/Curves/Wig_Wag_Currents.jpg >> >> We discovered that the lamp temperature stays pretty warm >> during a 250 mS off-cycle such that you don't see the typical >> cold-filament inrush each time the lamp is powered up. But >> the temperature excursions between no-visible light and full >> intensity is still significant. It may well be that the very >> thing that makes the halogen a stellar illuminator amongst >> incandescent lamps is it's Achilles Heel as well. >> >> Just a guess . . . but until I hear/get a better idea, I'm >> sticking with it. >> >> Bob . . . >> >> >> >> >> > > > > > > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > > > > ________________________________________________________________________________
Date: Sep 10, 2011
Subject: Transponder troubles
Had strange occurrence with Salt Lake Approach yesterday. Initially, when they said they couldn't see my transponder, I had a reply light. Then they said they could see a 1200 code from it, not the 0363 assigned that I had dialed in. A bit later they saw the correct code, and it continued to be okay until out of their airspace. Now I departed the Phoenix area the day before, communicating with 2 radar equipped towers that had no complaints on my transponder and were giving me radar traffic callouts, so I know it was working. Not sure how a transponder could possibly put out a 1200 code when set to something else, and then revert to sending the selected code. I could see one or two digits being wrong, but the whole code? I could only think they had a weak signal, but checked after I landed and antenna was clean. I guess I can check the coax connection, and reseat the unit in its tray, but would rather not have to spend for an unnecessary bench check. It is an old model with cavity tube, but has been rock solid since it was aligned 8 yrs ago, passing every biennial check. Any other thoughts? ________________________________________________________________________________
Date: Sep 10, 2011
Subject: Re: Transponder troubles
I had something similar happen to me only a few weeks ago arriving at Lancaster, PA. I was on a discrete code from prior flight following services and the tower said I was squawking 1200. A quick right turn followed by a look down revealed a VERY close VFR aircraft underneath me on my exact original course which was the runway heading for a straight in to the active. Was he blanketing my signal in some manner? unknown. Once I had diverged a bit the tower began seeing my signal and correct discrete code. I wonder how long we had been flying in "un-intentional formation"? On Sat, Sep 10, 2011 at 9:52 AM, Kelly McMullen wrote: > kellym(at)aviating.com> > > Had strange occurrence with Salt Lake Approach yesterday. Initially, > when they said they couldn't see my transponder, I had a reply light. > Then they said they could see a 1200 code from it, not the 0363 > assigned that I had dialed in. A bit later they saw the correct code, > and it continued to be okay until out of their airspace. Now I > departed the Phoenix area the day before, communicating with 2 radar > equipped towers that had no complaints on my transponder and were > giving me radar traffic callouts, so I know it was working. Not sure > how a transponder could possibly put out a 1200 code when set to > something else, and then revert to sending the selected code. I could > see one or two digits being wrong, but the whole code? I could only > think they had a weak signal, but checked after I landed and antenna > was clean. I guess I can check the coax connection, and reseat the > unit in its tray, but would rather not have to spend for an > unnecessary bench check. It is an old model with cavity tube, but has > been rock solid since it was aligned 8 yrs ago, passing every biennial > check. Any other thoughts? > > ________________________________________________________________________________
Date: Sep 10, 2011
At 09:52 AM 9/10/2011, you wrote: Had strange occurrence with Salt Lake Approach yesterday. Initially, when they said they couldn't see my transponder, I had a reply light. Then they said they could see a 1200 code from it, not the 0363 assigned that I had dialed in. A bit later they saw the correct code, and it continued to be okay until out of their airspace. Now I departed the Phoenix area the day before, communicating with 2 radar equipped towers that had no complaints on my transponder and were giving me radar traffic callouts, so I know it was working. Not sure how a transponder could possibly put out a 1200 code when set to something else, and then revert to sending the selected code. I could see one or two digits being wrong, but the whole code? I could only think they had a weak signal, but checked after I landed and antenna was clean. I guess I can check the coax connection, and reseat the unit in its tray, but would rather not have to spend for an unnecessary bench check. It is an old model with cavity tube, but has been rock solid since it was aligned 8 yrs ago, passing every biennial check. Any other thoughts? Don't worry about it . . . yet. Aviation electronics, transponders in particular are prime examples of what CAN happen when one agency with no particular expertise has the power to mandate behaviors to others without regard or responsibility for the unintended consequences. Modern transponders are descendants of the WWII IFF (identification, friend or foe) systems that helped avoid shooting down our own airplanes. The Mode A (identification only) systems of the 1960's were relatively simple pulse generators tide to an almost stable high power oscillator that would, most of the time, let the guy on the ground sort your primary radar return from perhaps hundreds of other returns. Then they added altitude reporting by making this little bitty change to the pattern of pulses . . . that were supposed to let the system on the ground tell the difference between two closely spaced string of pulses . . . first being I.D. the second being altitude. Of course, there were volumes of specifications written to which willing players complied so that they could play in the avionics sand-box. When some transponders failed to deliver a flavor of pulses distasteful to the ground systems, it was discovered that the agency in question 'made a mistake' in writing the specifications. The cost of a work-around nearly sank Terra. This is but one of many examples for how our avionics and the efficiency to which they perform has be regulated into inept antiquity . . . While the rest of the universe is communicating in digital spread spectrum, we still talk on radios that suck for air (VHF AM). This is but a hand-full of examples of system evolution that has been subject to administrative retardation. Yeah, it's getting "better" . . . but only by stacking band-aid on top of band-aid to a system that should have been trashed and replaced decades ago. You've got more capability, flexibility and utility in the computer upon which you're reading these words than the FAA has in their radar systems they depend on to tell other folks what to do . . . ostensibly to keep them from running into each other. It's sorta like sending a one armed man blind in one eye into a sword fight with a atomic powered table knife. If he's VERY talented, he'll be okay most of the time. So when somebody on the ground says there's something wrong with your radios, do your own due diligence but don't be surprised if the difficulty cannot be identified or repeated. His perceptions are altered by systematic retardation and may not always be accurate. Bob . . . Bob . . . ________________________________________________________________________________
mode
Date: Sep 10, 2011
David, The HID kit I bought included two ballasts, H3 bulbs, and harnesses. I have yet to make a way to mount the ballasts but shouldn't be difficult. The ballasts are the newer slim (lighter?) version. The whole assembly is heavier than regular halogens. The solid state flasher I bought has a max rating of 55W per bulb, so this was the original reason to go away from the 100w halogens I was originally planning. The benefit will be more light, less power, and longer lasting I hope. Bevan -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of David Lloyd Sent: Friday, September 09, 2011 10:55 PM Subject: Re: AeroElectric-List: Halogen bulbs with wig wag circuitry....failure mode --> Bevan, I think that I have viewed some of those on eBay. But, I came away with the idea that they were not a complete kit; power supply, harness, bulb/lamp combo, etc. I will take a better review of the offerings. Please let me know if you receive a complete operational system. David =============================================================== ----- Original Message ----- From: "B Tomm" <fvalarm(at)rapidnet.net> Sent: Friday, September 09, 2011 9:20 PM Subject: RE: AeroElectric-List: Halogen bulbs with wig wag circuitry....failure mode > --> > > I bought a 55W HID kit on Ebay for $55 + shipping ($70 total) as other > have. > Most HID's are 35 watt. I'm expecting these to be about twice as > bright as 100watt incandescent, but haven't powered them up yet. I > don't consider this to be an expensive upgrade. > > Bevan > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of > David Lloyd > Sent: Friday, September 09, 2011 5:51 PM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Halogen bulbs with wig wag > circuitry....failure mode > > --> > > Bruce, > ...also a good suggestion, but, like HID's they are quite expensive > when one needs a really bright recognition lamp. > I plan to keep watching the LED market and see what comes in cost > reduction.... Thanks, David > > ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ > > ----- Original Message ----- > From: "Bruce" <BGray(at)glasair.org> > To: > Sent: Friday, September 09, 2011 3:44 PM > Subject: RE: AeroElectric-List: Halogen bulbs with wig wag > circuitry....failure mode > > >> >> OK, how about LED? >> >> Bruce >> WWW.Glasair.org >> >> -----Original Message----- >> From: owner-aeroelectric-list-server(at)matronics.com >> [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of >> David Lloyd >> Sent: Friday, September 09, 2011 4:49 PM >> To: aeroelectric-list(at)matronics.com >> Subject: Re: AeroElectric-List: Halogen bulbs with wig wag >> circuitry....failure mode >> >> >> >> Good suggestion...all except for the considerable cost for dual >> sets..... >> David >> >> ____________________________________________________ >> ----- Original Message ----- >> From: "Bruce" <BGray(at)glasair.org> >> To: >> Sent: Friday, September 09, 2011 11:16 AM >> Subject: RE: AeroElectric-List: Halogen bulbs with wig wag >> circuitry....failure mode >> >> >>> >>> Switch to HID. >>> >>> Bruce >>> WWW.Glasair.org >>> >>> -----Original Message----- >>> From: owner-aeroelectric-list-server(at)matronics.com >>> [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of >> David >>> Lloyd >>> Sent: Friday, September 09, 2011 1:31 PM >>> To: aeroelectric-list(at)matronics.com >>> Subject: AeroElectric-List: Halogen bulbs with wig wag >>> circuitry....failure mode >>> >>> >>> >>> A general question for Bob and the List Members concerning halogen >>> bulbs, i.e., GE H7604 landing light style. >>> >>> I am hoping someone on the List knows a lot about halogen bulb >>> failure modes. >>> >>> I have H7604 lamps in my wing tips that aid landing and traffic >>> recognition. >>> They are controlled by a solid state switcher that is either >>> OFF-ON-PULSED. >>> ( I do not know the turn-on ramp characteristics..) >>> >>> They fail in less than 10 hrs of operation. Interesting both seem >>> to fail nearly at the same time. The "pulse" mode for traffic >>> recognition is the major use. >>> >>> My ignorant guess is that halogen bulbs do not like to be pulsed or >>> ramped up too quickly during pulse mode. If the rapid power ramp up >>> is the primary cause, I am wondering if an appropriate choke >>> (induction) would slow that ramping down and return normal life to >>> these devices. >>> >>> Any insight, suggestions into the failure mode and how to work >>> around >> it >>> >>> would be greatly appreciated. David >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Subject: RE: Avionics-List: Transponder troubles
Date: Sep 10, 2011
It's ATC problem. I have had the same issue with ATC on a number of occasions, if one radar site has a problem and nobody else does I wouldn't be in a hurry to get to the repair shop. George -----Original Message----- From: owner-avionics-list-server(at)matronics.com [mailto:owner-avionics-list-server(at)matronics.com]On Behalf Of Kelly McMullen Sent: Saturday, September 10, 2011 8:52 AM Subject: Avionics-List: Transponder troubles --> Avionics-List message posted by: Kelly McMullen Had strange occurrence with Salt Lake Approach yesterday. Initially, when they said they couldn't see my transponder, I had a reply light. Then they said they could see a 1200 code from it, not the 0363 assigned that I had dialed in. A bit later they saw the correct code, and it continued to be okay until out of their airspace. Now I departed the Phoenix area the day before, communicating with 2 radar equipped towers that had no complaints on my transponder and were giving me radar traffic callouts, so I know it was working. Not sure how a transponder could possibly put out a 1200 code when set to something else, and then revert to sending the selected code. I could see one or two digits being wrong, but the whole code? I could only think they had a weak signal, but checked after I landed and antenna was clean. I guess I can check the coax connection, and reseat the unit in its tray, but would rather not have to spend for an unnecessary bench check. It is an old model with cavity tube, but has been rock solid since it was aligned 8 yrs ago, passing every biennial check. Any other thoughts? ________________________________________________________________________________
mode
Date: Sep 10, 2011
I used the CL-21 from www.ge-mcs.com/download/temperature/920_325a.pdf Available at Digi-Key Thanks, V -----Original Message----- From: David Lloyd Sent: Friday, September 09, 2011 11:00 PM Subject: Re: AeroElectric-List: Halogen bulbs with wig wag circuitry....failure mode Vern, I am unfamiliar with the "current limiters" that you mention. Your solution looks great. Please give a bit more detail... I will check for my solid state flasher model and if it can be modified...(not potted, etc.) It was part of the RMD wing tip system. David =========================================================== ----- Original Message ----- From: "Vern Little" <sprocket@vx-aviation.com> Sent: Friday, September 09, 2011 7:57 PM Subject: Re: AeroElectric-List: Halogen bulbs with wig wag circuitry....failure mode > <sprocket@vx-aviation.com> > > I used inrush current limiters on my halogens (450+ hours so far). Since > this also causes the lamps to take more time to reach full brightness, I > modified the B&C flasher to slow it down by doubling the capacitance of > the electrolytic capacitor inside the can. Double the resistor value > would also work. > > V > > > -----Original Message----- > From: David Lloyd > Sent: Friday, September 09, 2011 5:47 PM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Halogen bulbs with wig wag > circuitry....failure mode > > > > Bob, > I think that you are totally correct concerning the thermo rapid cycle > being > the stress failure mode. > > When viewing the filaments with a mag. lens they look completely normal > and > intact until you look carefully at one end of the filament. They are > broken > at the very end. > > Odd that I have not run into others that are having the same problem as > these bulbs are used in a lot of recognition applications. > > I suspect that if I left them ON continually, they would last a normal > life. > And, as you outline, in PULSE mode the thermo aspect is too much stress. I > wonder now, if there is a heavy duty version of this bulb with bullet > proof > filament structure. > > I am installing new bulbs when delivered and will report back when I have > a > similar failure. Hopefully, I may have learned more. > Thanks, David > > ___________________________________________________________________________ > > ----- Original Message ----- > From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> > To: > Sent: Friday, September 09, 2011 4:15 PM > Subject: Re: AeroElectric-List: Halogen bulbs with wig wag > circuitry....failure mode > > >> >> >> I have H7604 lamps in my wing tips that aid landing and traffic >> recognition. They are controlled by a solid state switcher that is either >> OFF-ON-PULSED. ( I do not know the turn-on ramp characteristics..) >> >> They fail in less than 10 hrs of operation. Interesting both seem to >> fail nearly at the same time. The "pulse" mode for traffic recognition >> is the major use. >> >> My ignorant guess is that halogen bulbs do not like to be pulsed or >> ramped up too quickly during pulse mode. If the rapid power ramp up is >> the primary cause, I am wondering if an appropriate choke (induction) >> would slow that ramping down and return normal life to these devices. >> >> If I were to do a WAG . . . I'm guessing that you're >> getting repetitive stress cracks in the filaments. >> These things operate somewhat hotter than their older >> cousins . . . most seem to have heavier filaments too. >> >> There are two things that erode filament integrity . . . >> evaporation (total operating hours issue) and stress >> cracks (combination of vibration and temperature cycling). >> I'm wondering if the halogens are not more highly stressed >> during each illumination cycle. Since a wig-wag operates >> on the order of 2 flashes per second, 10 hours of flashing >> would offer 72,000 or so temperature cycles. Far more cycles >> than would be expected in automotive applications. Just >> assuming 200 cycles per day in a high-beam lamp for night >> highway driving would take 360 straight days of such service >> to equal 10 hours of wig-wag. >> >> Any insight, suggestions into the failure mode and how to work around it >> would be greatly appreciated. >> >> Not sure 'current ramping' would have a very useful effect. >> Some of you may recall an experiment we did some years back >> to evaluate the usefulness of inrush-limiters in wig-wagged >> landing lights. Remember this plot? >> >> http://www.aeroelectric.com/Pictures/Curves/Wig_Wag_Currents.jpg >> >> We discovered that the lamp temperature stays pretty warm >> during a 250 mS off-cycle such that you don't see the typical >> cold-filament inrush each time the lamp is powered up. But >> the temperature excursions between no-visible light and full >> intensity is still significant. It may well be that the very >> thing that makes the halogen a stellar illuminator amongst >> incandescent lamps is it's Achilles Heel as well. >> >> Just a guess . . . but until I hear/get a better idea, I'm >> sticking with it. >> >> Bob . . . >> >> >> >> >> > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
mode
Date: Sep 10, 2011
... this is a circular reference... your quoting my own posts on your site! Nice to see you documented it properly. Cheers, V -----Original Message----- From: Andrew Zachar Sent: Saturday, September 10, 2011 4:05 AM Subject: Re: AeroElectric-List: Halogen bulbs with wig wag circuitry....failure mode Awhile back, I did a post about this exact modification. http://n999za.com/2010/11/07/hacking-the-wig-wag-flasher/ Of course, I was only successful because if this list's gracious help and advice. Hoping the pictures assist the discussion... __ Andrew Zachar andrew.d.zachar(at)gmail.com On Sep 9, 2011, at 10:57 PM, "Vern Little" <sprocket@vx-aviation.com> wrote: > <sprocket@vx-aviation.com> > > I used inrush current limiters on my halogens (450+ hours so far). Since > this also causes the lamps to take more time to reach full brightness, I > modified the B&C flasher to slow it down by doubling the capacitance of > the electrolytic capacitor inside the can. Double the resistor value > would also work. > > V > > > -----Original Message----- From: David Lloyd > Sent: Friday, September 09, 2011 5:47 PM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Halogen bulbs with wig wag > circuitry....failure mode > > > > Bob, > I think that you are totally correct concerning the thermo rapid cycle > being > the stress failure mode. > > When viewing the filaments with a mag. lens they look completely normal > and > intact until you look carefully at one end of the filament. They are > broken > at the very end. > > Odd that I have not run into others that are having the same problem as > these bulbs are used in a lot of recognition applications. > > I suspect that if I left them ON continually, they would last a normal > life. > And, as you outline, in PULSE mode the thermo aspect is too much stress. > I > wonder now, if there is a heavy duty version of this bulb with bullet > proof > filament structure. > > I am installing new bulbs when delivered and will report back when I have > a > similar failure. Hopefully, I may have learned more. > Thanks, David > > ___________________________________________________________________________ > > ----- Original Message ----- From: "Robert L. Nuckolls, III" > > To: > Sent: Friday, September 09, 2011 4:15 PM > Subject: Re: AeroElectric-List: Halogen bulbs with wig wag > circuitry....failure mode > > >> >> >> I have H7604 lamps in my wing tips that aid landing and traffic >> recognition. They are controlled by a solid state switcher that is either >> OFF-ON-PULSED. ( I do not know the turn-on ramp characteristics..) >> >> They fail in less than 10 hrs of operation. Interesting both seem to >> fail nearly at the same time. The "pulse" mode for traffic recognition >> is the major use. >> >> My ignorant guess is that halogen bulbs do not like to be pulsed or >> ramped up too quickly during pulse mode. If the rapid power ramp up is >> the primary cause, I am wondering if an appropriate choke (induction) >> would slow that ramping down and return normal life to these devices. >> >> If I were to do a WAG . . . I'm guessing that you're >> getting repetitive stress cracks in the filaments. >> These things operate somewhat hotter than their older >> cousins . . . most seem to have heavier filaments too. >> >> There are two things that erode filament integrity . . . >> evaporation (total operating hours issue) and stress >> cracks (combination of vibration and temperature cycling). >> I'm wondering if the halogens are not more highly stressed >> during each illumination cycle. Since a wig-wag operates >> on the order of 2 flashes per second, 10 hours of flashing >> would offer 72,000 or so temperature cycles. Far more cycles >> than would be expected in automotive applications. Just >> assuming 200 cycles per day in a high-beam lamp for night >> highway driving would take 360 straight days of such service >> to equal 10 hours of wig-wag. >> >> Any insight, suggestions into the failure mode and how to work around it >> would be greatly appreciated. >> >> Not sure 'current ramping' would have a very useful effect. >> Some of you may recall an experiment we did some years back >> to evaluate the usefulness of inrush-limiters in wig-wagged >> landing lights. Remember this plot? >> >> http://www.aeroelectric.com/Pictures/Curves/Wig_Wag_Currents.jpg >> >> We discovered that the lamp temperature stays pretty warm >> during a 250 mS off-cycle such that you don't see the typical >> cold-filament inrush each time the lamp is powered up. But >> the temperature excursions between no-visible light and full >> intensity is still significant. It may well be that the very >> thing that makes the halogen a stellar illuminator amongst >> incandescent lamps is it's Achilles Heel as well. >> >> Just a guess . . . but until I hear/get a better idea, I'm >> sticking with it. >> >> Bob . . . >> >> >> >> >> > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Sep 10, 2011
interference from something else? Kelly McMullen wrote: > --> AeroElectric-List message posted by: Kelly McMullen > > Had strange occurrence with Salt Lake Approach yesterday. Initially, > when they said they couldn't see my transponder, I had a reply light. > Then they said they could see a 1200 code from it, not the 0363 > assigned that I had dialed in. A bit later they saw the correct code, > and it continued to be okay until out of their airspace. Now I > departed the Phoenix area the day before, communicating with 2 radar > equipped towers that had no complaints on my transponder and were > giving me radar traffic callouts, so I know it was working. Not sure > how a transponder could possibly put out a 1200 code when set to > something else, and then revert to sending the selected code. I could > see one or two digits being wrong, but the whole code? I could only > think they had a weak signal, but checked after I landed and antenna > was clean. I guess I can check the coax connection, and reseat the > unit in its tray, but would rather not have to spend for an > unnecessary bench check. It is an old model with cavity tube, but has > been rock solid since it was aligned 8 yrs ago, passing every biennial > check. Any other thoughts? > > > -- If you're an American, just say NO to the Obamanation, to socialism, and get rid of Soros. ...democracy and a republic can function only in a firm partnership with morality and religion. -- John Adams. Indeed. Same should be said for ANY type of gubmnt ________________________________________________________________________________
mode
Date: Sep 10, 2011
I've been selling Wig-wags for many years. Our wig-wags do not depend on lamp resistance. They consist of two big mosfets driven by a mosfet driver and some simple internal timer. They cost more than the automotive type, and they are 100% solid state, so in theory that will last forever. Early on, it was discovered that HIDs would destroy them for two reasons: 1) the starting current surge on an HID is very large (okay, short but tall), and the lamp and the + line sees a HV pulse at the same time. The solution to these issues was to supply a surge arrestor and an HV suppressor for those who wanted to wig-wag their HIDs. There are additional issues--these vary by lamp and ballast manufacturer--but people seem to be having few problems. Wig-wagging LEDs is trivial, but some LEDs require a Voltage booster or constant current supply to function well. These employ littel switch-mode power supplies that frequently make noise on the audio or HF transmitter lines. Wig-wagging really big halogen lamps is also easy providing a current surge protector is used. I have demonstrated 2X 250 watt lamps wig-wagging happily with our WW(c) or WW(d). After using these on my white LED tail lights, I finally had to give up and return to a simple, reliable (but not as efficient) LM317 current regulator (which I offer as a free design if you want to roll your own). One final note: BMW is now testing white LASER auto headlamps. No, the lasers won't poke holes in things--lasers are used because they can be made to be several times more efficient (Lumens/Watt) than LEDs. But LEDs are not slacking either...Cree has demonstrated a white LED of 231 Lumens Per Watt. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=351901#351901 ________________________________________________________________________________
Date: Sep 10, 2011
Subject: Re: Avionics-List: Transponder troubles
On 09/10/2011 08:52 AM, Kelly McMullen wrote: > --> Avionics-List message posted by: Kelly McMullen > > Had strange occurrence with Salt Lake Approach yesterday. Initially, > when they said they couldn't see my transponder, I had a reply light. > Then they said they could see a 1200 code from it, not the 0363 > assigned that I had dialed in. A bit later they saw the correct code, > and it continued to be okay until out of their airspace. Now I > departed the Phoenix area the day before, communicating with 2 radar > equipped towers that had no complaints on my transponder and were > giving me radar traffic callouts, so I know it was working. Not sure > how a transponder could possibly put out a 1200 code when set to > something else, and then revert to sending the selected code. I could > see one or two digits being wrong, but the whole code? I could only > think they had a weak signal, but checked after I landed and antenna > was clean. I guess I can check the coax connection, and reseat the > unit in its tray, but would rather not have to spend for an > unnecessary bench check. It is an old model with cavity tube, but has > been rock solid since it was aligned 8 yrs ago, passing every biennial > check. Any other thoughts? Another + for it being an ATC problem. One of my neighbors used to fly all over the central & southeast USA, & whenever he (and others) would fly through Memphis airspace ATC would tell them that their transponder wasn't working properly (no altitude, incorrect altitude, etc etc). The various transponders seemed to work fine around other class B/C airspace, & all had problems whenever they entered Memphis airspace. Charlie ________________________________________________________________________________
mode
Date: Sep 10, 2011
Bevan, Thanks again for details. I note that the HID bulbs are just that... "a bulb" made to twist into a reflector. What did you use as reflector that could mounted in the same hold-down mount that would normally contain the typical halogen lamp assembly like a GE H7604 50W lamp used in landing lights, etc..? david =============================================== ----- Original Message ----- From: "B Tomm" <fvalarm(at)rapidnet.net> Sent: Saturday, September 10, 2011 9:04 AM Subject: RE: AeroElectric-List: Halogen bulbs with wig wag circuitry....failure mode > > David, > > The HID kit I bought included two ballasts, H3 bulbs, and harnesses. I > have > yet to make a way to mount the ballasts but shouldn't be difficult. The > ballasts are the newer slim (lighter?) version. The whole assembly is > heavier than regular halogens. > > The solid state flasher I bought has a max rating of 55W per bulb, so this > was the original reason to go away from the 100w halogens I was originally > planning. The benefit will be more light, less power, and longer lasting > I > hope. > > Bevan > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of David > Lloyd > Sent: Friday, September 09, 2011 10:55 PM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Halogen bulbs with wig wag > circuitry....failure mode > > --> > > Bevan, > I think that I have viewed some of those on eBay. But, I came away with > the > idea that they were not a complete kit; power supply, harness, bulb/lamp > combo, etc. I will take a better review of the offerings. Please let me > know if you receive a complete operational system. > David > > =============================================================== > ----- Original Message ----- > From: "B Tomm" <fvalarm(at)rapidnet.net> > To: > Sent: Friday, September 09, 2011 9:20 PM > Subject: RE: AeroElectric-List: Halogen bulbs with wig wag > circuitry....failure mode > > >> --> >> >> I bought a 55W HID kit on Ebay for $55 + shipping ($70 total) as other >> have. >> Most HID's are 35 watt. I'm expecting these to be about twice as >> bright as 100watt incandescent, but haven't powered them up yet. I >> don't consider this to be an expensive upgrade. >> >> Bevan >> >> -----Original Message----- >> From: owner-aeroelectric-list-server(at)matronics.com >> [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of >> David Lloyd >> Sent: Friday, September 09, 2011 5:51 PM >> To: aeroelectric-list(at)matronics.com >> Subject: Re: AeroElectric-List: Halogen bulbs with wig wag >> circuitry....failure mode >> >> --> >> >> Bruce, >> ...also a good suggestion, but, like HID's they are quite expensive >> when one needs a really bright recognition lamp. >> I plan to keep watching the LED market and see what comes in cost >> reduction.... Thanks, David >> >> ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ >> >> ----- Original Message ----- >> From: "Bruce" <BGray(at)glasair.org> >> To: >> Sent: Friday, September 09, 2011 3:44 PM >> Subject: RE: AeroElectric-List: Halogen bulbs with wig wag >> circuitry....failure mode >> >> >>> >>> OK, how about LED? >>> >>> Bruce >>> WWW.Glasair.org >>> >>> -----Original Message----- >>> From: owner-aeroelectric-list-server(at)matronics.com >>> [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of >>> David Lloyd >>> Sent: Friday, September 09, 2011 4:49 PM >>> To: aeroelectric-list(at)matronics.com >>> Subject: Re: AeroElectric-List: Halogen bulbs with wig wag >>> circuitry....failure mode >>> >>> >>> >>> Good suggestion...all except for the considerable cost for dual >>> sets..... >>> David >>> >>> ____________________________________________________ >>> ----- Original Message ----- >>> From: "Bruce" <BGray(at)glasair.org> >>> To: >>> Sent: Friday, September 09, 2011 11:16 AM >>> Subject: RE: AeroElectric-List: Halogen bulbs with wig wag >>> circuitry....failure mode >>> >>> >>>> >>>> Switch to HID. >>>> >>>> Bruce >>>> WWW.Glasair.org >>>> >>>> -----Original Message----- >>>> From: owner-aeroelectric-list-server(at)matronics.com >>>> [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of >>> David >>>> Lloyd >>>> Sent: Friday, September 09, 2011 1:31 PM >>>> To: aeroelectric-list(at)matronics.com >>>> Subject: AeroElectric-List: Halogen bulbs with wig wag >>>> circuitry....failure mode >>>> >>>> >>>> >>>> A general question for Bob and the List Members concerning halogen >>>> bulbs, i.e., GE H7604 landing light style. >>>> >>>> I am hoping someone on the List knows a lot about halogen bulb >>>> failure modes. >>>> >>>> I have H7604 lamps in my wing tips that aid landing and traffic >>>> recognition. >>>> They are controlled by a solid state switcher that is either >>>> OFF-ON-PULSED. >>>> ( I do not know the turn-on ramp characteristics..) >>>> >>>> They fail in less than 10 hrs of operation. Interesting both seem >>>> to fail nearly at the same time. The "pulse" mode for traffic >>>> recognition is the major use. >>>> >>>> My ignorant guess is that halogen bulbs do not like to be pulsed or >>>> ramped up too quickly during pulse mode. If the rapid power ramp up >>>> is the primary cause, I am wondering if an appropriate choke >>>> (induction) would slow that ramping down and return normal life to >>>> these devices. >>>> >>>> Any insight, suggestions into the failure mode and how to work >>>> around >>> it >>>> >>>> would be greatly appreciated. David >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Subject: Re: Halogen bulbs with wig wag circuitry....failure
mode
Date: Sep 10, 2011
A couple more things: 1) I have a note from GE that says that wig-wagging lamps extends their life. (I have no dog in this fight, that's just what GE says.) 2) I have noticed a degrading of quality in incandescent lamp manufacturing generally. It is typical that a big company will just transfer...for example...their line of filament lamps to Elbonia, or wherever, instead of where they had been making them for 30 years. Welcome to the new world order. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=351918#351918 ________________________________________________________________________________
Subject: Halogen bulbs with wig wag circuitry....failure
mode
Date: Sep 10, 2011
I had originally bought the duckworth kits from vans. You could just buy the lenses from Vans and make your own bracket, and scrounge a reflector from somewhere or buy an auto fog lamp assembly as a source for the reflector. Bevan -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of David Lloyd Sent: Saturday, September 10, 2011 10:47 AM Subject: Re: AeroElectric-List: Halogen bulbs with wig wag circuitry....failure mode --> Bevan, Thanks again for details. I note that the HID bulbs are just that... "a bulb" made to twist into a reflector. What did you use as reflector that could mounted in the same hold-down mount that would normally contain the typical halogen lamp assembly like a GE H7604 50W lamp used in landing lights, etc..? david =============================================== ----- Original Message ----- From: "B Tomm" <fvalarm(at)rapidnet.net> Sent: Saturday, September 10, 2011 9:04 AM Subject: RE: AeroElectric-List: Halogen bulbs with wig wag circuitry....failure mode > --> > > David, > > The HID kit I bought included two ballasts, H3 bulbs, and harnesses. > I have yet to make a way to mount the ballasts but shouldn't be > difficult. The ballasts are the newer slim (lighter?) version. The > whole assembly is heavier than regular halogens. > > The solid state flasher I bought has a max rating of 55W per bulb, so > this was the original reason to go away from the 100w halogens I was > originally planning. The benefit will be more light, less power, and > longer lasting I hope. > > Bevan > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of > David Lloyd > Sent: Friday, September 09, 2011 10:55 PM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Halogen bulbs with wig wag > circuitry....failure mode > > --> > > Bevan, > I think that I have viewed some of those on eBay. But, I came away > with the idea that they were not a complete kit; power supply, > harness, bulb/lamp combo, etc. I will take a better review of the > offerings. Please let me know if you receive a complete operational > system. > David > > =============================================================== > ----- Original Message ----- > From: "B Tomm" <fvalarm(at)rapidnet.net> > To: > Sent: Friday, September 09, 2011 9:20 PM > Subject: RE: AeroElectric-List: Halogen bulbs with wig wag > circuitry....failure mode > > >> --> >> >> I bought a 55W HID kit on Ebay for $55 + shipping ($70 total) as >> other have. >> Most HID's are 35 watt. I'm expecting these to be about twice as >> bright as 100watt incandescent, but haven't powered them up yet. I >> don't consider this to be an expensive upgrade. >> >> Bevan >> >> -----Original Message----- >> From: owner-aeroelectric-list-server(at)matronics.com >> [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of >> David Lloyd >> Sent: Friday, September 09, 2011 5:51 PM >> To: aeroelectric-list(at)matronics.com >> Subject: Re: AeroElectric-List: Halogen bulbs with wig wag >> circuitry....failure mode >> >> --> >> >> Bruce, >> ...also a good suggestion, but, like HID's they are quite expensive >> when one needs a really bright recognition lamp. >> I plan to keep watching the LED market and see what comes in cost >> reduction.... Thanks, David >> >> ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ >> >> ----- Original Message ----- >> From: "Bruce" <BGray(at)glasair.org> >> To: >> Sent: Friday, September 09, 2011 3:44 PM >> Subject: RE: AeroElectric-List: Halogen bulbs with wig wag >> circuitry....failure mode >> >> >>> >>> OK, how about LED? >>> >>> Bruce >>> WWW.Glasair.org >>> >>> -----Original Message----- >>> From: owner-aeroelectric-list-server(at)matronics.com >>> [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of >>> David Lloyd >>> Sent: Friday, September 09, 2011 4:49 PM >>> To: aeroelectric-list(at)matronics.com >>> Subject: Re: AeroElectric-List: Halogen bulbs with wig wag >>> circuitry....failure mode >>> >>> >>> >>> Good suggestion...all except for the considerable cost for dual >>> sets..... >>> David >>> >>> ____________________________________________________ >>> ----- Original Message ----- >>> From: "Bruce" <BGray(at)glasair.org> >>> To: >>> Sent: Friday, September 09, 2011 11:16 AM >>> Subject: RE: AeroElectric-List: Halogen bulbs with wig wag >>> circuitry....failure mode >>> >>> >>>> --> >>>> >>>> Switch to HID. >>>> >>>> Bruce >>>> WWW.Glasair.org >>>> >>>> -----Original Message----- >>>> From: owner-aeroelectric-list-server(at)matronics.com >>>> [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of >>> David >>>> Lloyd >>>> Sent: Friday, September 09, 2011 1:31 PM >>>> To: aeroelectric-list(at)matronics.com >>>> Subject: AeroElectric-List: Halogen bulbs with wig wag >>>> circuitry....failure mode >>>> >>>> >>>> >>>> A general question for Bob and the List Members concerning halogen >>>> bulbs, i.e., GE H7604 landing light style. >>>> >>>> I am hoping someone on the List knows a lot about halogen bulb >>>> failure modes. >>>> >>>> I have H7604 lamps in my wing tips that aid landing and traffic >>>> recognition. >>>> They are controlled by a solid state switcher that is either >>>> OFF-ON-PULSED. >>>> ( I do not know the turn-on ramp characteristics..) >>>> >>>> They fail in less than 10 hrs of operation. Interesting both seem >>>> to fail nearly at the same time. The "pulse" mode for traffic >>>> recognition is the major use. >>>> >>>> My ignorant guess is that halogen bulbs do not like to be pulsed or >>>> ramped up too quickly during pulse mode. If the rapid power ramp >>>> up is the primary cause, I am wondering if an appropriate choke >>>> (induction) would slow that ramping down and return normal life to >>>> these devices. >>>> >>>> Any insight, suggestions into the failure mode and how to work >>>> around >>> it >>>> >>>> would be greatly appreciated. David >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Sep 10, 2011
mode >Wig-wagging really big halogen lamps is also easy providing a >current surge protector is used. I have demonstrated 2X 250 watt >lamps wig-wagging happily with our WW(c) or WW(d). Inrush current beyond the initial cold start is not an issue for incandescent lamps. The reason I plotted the this data . . . Emacs! was to show that while the first, cold start inrush was the typical 30+ amps, subsequent start up currents were quite nominal. The lamp being tested had a nominal on current of 4A (55w) but as you can see here, the average start up current in the wig-wag mode was a tad above 5A. This is because the filament doesn't cool off enough between flashes to push the inrush even close to a cold-start value. It isn't inrush killing these lamps by flashing them, it has to be temperature cycling . . . for which there is no mitigating 'fix'. After all, the reason these filaments produce white light is because they've been elevated from below a dull red glow to the white light produced by a metal glowing at 5000 degrees F. THATS a big temperature shift. I need to re-plot that trace above. There was some very strong noise source going on at the time that produced the fuzzy spikes on my data. Bob . . . ________________________________________________________________________________
Date: Sep 11, 2011
Subject: Re: RF noise from Jeff's LED lights
At 08:05 PM 9/9/2011, you wrote: > >I am getting a loud hiss on both aircraft radios whenever my LED >position lights are turned on. In fact, any FM radio in the >vicinity gets the hiss too. > >I have "Jeff's LED lights for RVs" installed in the wing tips along >with Bob Archer antennas. Though it may be worth noting that the >SL30 Comm antenna is a standard belly mounted bent whip. > >I know the RF is coming from the radios because if I turn the volume >down on the radios, the noise disappears (in other words, the >intercom is not affected). > >The archives have some discussion of filters, resistors and >capacitors but I'm not sure where to start. > >My first inclination is to disconnect one at a time to see if the >noise is coming from both lights. Then I don't know where to start. Some years ago, folks were building their own nav lights that utilized a "Buck Puck" constant current driver. They were experiencing similar noise problems. I proposed and fabricated a filtered version of the Buck Puck http://www.aeroelectric.com/Catalog/AEC/9051/ We also offered a filter-board that builders could use to quiet Buck Pucks they already owned. The instructions above describe a line noise filter that proved useful on the Buck Puck. If your fixtures use the same power supply then values for a filter are given in the document. You might be able to use one of our filter boards . . . or substitute a fully assembled power supply. Bob . . . ________________________________________________________________________________
mode
Date: Sep 11, 2011
> Inrush current beyond the initial cold > start is not an issue for incandescent lamps. > The reason I plotted the this data . . . Quite true Bob, however I tried not having a first cycle, but it never seemed to work. You ALWAYS have a first pulse. Also, most timers using a 555 have an initial 1.5X times longer pulse than the second pulse. I no longer use the 555 for this reason. What I do now is have a faster r/c oscillator and a divider to get the correct timing. I'd be glad to share the schematic with interested parties. Nice graph of the pulses. I'd still bet that many halogen lamps have declined in quality. I've seen this first-hand. There are many variables in the making of halogen lamps. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=351971#351971 ________________________________________________________________________________
Subject: Re: ...failure mode
Date: Sep 11, 2011
Bob's scope digital sampling is very slow sampling as usual. The peak inrush current is basically current limited to the power supply and wiring and switcher resistance. He shows one sample at over 30 amps and who knows what the peak current is. HID do have issues with wig wag and below I got info from a pilot who solved it. Your current limiter as you mentioned would limit this way down and produce a great increase in lifetime. However if one uses the H3 bulbs there is one type of HID supply that works well with wig wag while most do not. The H3 is a drop in for most Vans and other wing mountes aircraft. There is also a replacement bulb for the round lights using the same ballast that should work well.. Then you need to use a specific toroid filter on the lines and a no bounce switch contact (solid state). I got the info from a suscessful fligher months ago and the parts are cheep also Like at the time 30 for a system. NOT all hid systems will work wig wag as the supply simply dies soon I can go back and try to find the link if you are interested. I will not post to Bob's list ever!!!! Pardon the smelling but my chkr is off as comp[uter crash and ng backup is back and running but word is the spel checker and its not reinstalled Paul ----- Original Message ----- From: "Eric M. Jones" <emjones(at)charter.net> Sent: Sunday, September 11, 2011 10:27 AM Subject: AeroElectric-List: Re: Halogen bulbs with wig wag circuitry....failure mode > > > >> Inrush current beyond the initial cold >> start is not an issue for incandescent lamps. >> The reason I plotted the this data . . . > > > Quite true Bob, however I tried not having a first cycle, but it never > seemed to work. You ALWAYS have a first pulse. > > Also, most timers using a 555 have an initial 1.5X times longer pulse than > the second pulse. I no longer use the 555 for this reason. What I do now > is have a faster r/c oscillator and a divider to get the correct timing. > I'd be glad to share the schematic with interested parties. > > Nice graph of the pulses. > > I'd still bet that many halogen lamps have declined in quality. I've seen > this first-hand. There are many variables in the making of halogen lamps. > > -------- > Eric M. Jones > www.PerihelionDesign.com > 113 Brentwood Drive > Southbridge, MA 01550 > (508) 764-2072 > emjones(at)charter.net > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=351971#351971 > > > ________________________________________________________________________________
Subject: Re: ...failure mode//sorry posted in error
Date: Sep 11, 2011
----- Original Message ----- From: "Paul" To: <aeroelectric-list(at)matronics.com> Sent: Sunday, September 11, 2011 11:29 AM Subject: AeroElectric-List: Re: ...failure mode ________________________________________________________________________________
Date: Sep 11, 2011
Subject: building a batter capacity tester
I have been following the PC680 thread with great interest. I have a couple for my RV8 that have been sitting around longer than I had meant for them to sit. You know how construction goes. I was going to build the capacity tester from the aeroelectric site: _http://www.aeroelectric.com/articles/battest.pdf_ (http://www.aeroelectric.com/articles/battest.pdf) This looks pretty straightforward and I assume that I can get all the components from my local Radio Shack. The one thing I am foggy on is the 10 V. Zener diode in the schematic. Never having used these, are they sold by voltage or amperage or what. Specifically, how do I make sure I get the correct component? Thanks, Michael Wynn RV 8 Wiring San Ramon, CA In a message dated 9/11/2011 12:09:07 P.M. Pacific Daylight Time, paulm(at)olypen.com writes: --> AeroElectric-List message posted by: "Paul" ----- Original Message ----- From: "Paul" To: <aeroelectric-list(at)matronics.com> Sent: Sunday, September 11, 2011 11:29 AM Subject: AeroElectric-List: Re: ...failure mode ________________________________________________________________________________
Date: Sep 11, 2011
From: "Richard E. Tasker" <retasker(at)optonline.net>
Subject: Re: building a batter capacity tester
Pretty much any 10V zener diode will work there. Zeners are sold by voltage since that is their purpose (to control the voltage across their terminals). The other thing that is important is the wattage rating, although in this case the power dissipated by the zener is so low (50mW) that any 10V zener you can buy will work. Dick Tasker MLWynn(at)aol.com wrote: > I have been following the PC680 thread with great interest. I have a couple for my RV8 that have been sitting around longer than I had meant for them to sit. You know how construction goes. > I was going to build the capacity tester from the aeroelectric site: > http://www.aeroelectric.com/articles/battest.pdf > This looks pretty straightforward and I assume that I can get all the components from my local Radio Shack. The one thing I am foggy on is the 10 V. Zener diode in the schematic. Never having used > these, are they sold by voltage or amperage or what. Specifically, how do I make sure I get the correct component? > Thanks, > Michael Wynn > RV 8 Wiring > San Ramon, CA > In a message dated 9/11/2011 12:09:07 P.M. Pacific Daylight Time, paulm(at)olypen.com writes: > > > ----- Original Message ----- > From: "Paul" To: <aeroelectric-list(at)matronics.com> > Sent: Sunday, September 11, 2011 11:29 AM > Subject: AeroElectric-List: Re: ...failure = Use ilities ay - MATRONICS WEB FORUMS - List Contribution Web Site p; > > > * > > > * -- Please Note: No trees were destroyed in the sending of this message. We do concede, however, that a significant number of electrons may have been temporarily inconvenienced. -- ________________________________________________________________________________
Date: Sep 12, 2011
Bob, I'd like to get a couple of those if they are still available from you. What I have is a couple of "Luxdrive 02008B-700 PowerPucks" producing 700ma. They are round rather than square as the ones in your link but look like the same thing. they have 2 input and output leads. If you have a couple of filter boards that I can wire them to, I'd like to get them. Or perhaps a couple of boards with the pucks installed. How much? How can I get them? Thanks! On 9/11/2011 12:01 PM, Robert L. Nuckolls, III wrote: > > > At 08:05 PM 9/9/2011, you wrote: >> >> >> I am getting a loud hiss on both aircraft radios whenever my LED >> position lights are turned on. In fact, any FM radio in the vicinity >> gets the hiss too. >> >> I have "Jeff's LED lights for RVs" installed in the wing tips along >> with Bob Archer antennas. Though it may be worth noting that the >> SL30 Comm antenna is a standard belly mounted bent whip. >> >> I know the RF is coming from the radios because if I turn the volume >> down on the radios, the noise disappears (in other words, the >> intercom is not affected). >> >> The archives have some discussion of filters, resistors and >> capacitors but I'm not sure where to start. >> >> My first inclination is to disconnect one at a time to see if the >> noise is coming from both lights. Then I don't know where to start. > > Some years ago, folks were building their own > nav lights that utilized a "Buck Puck" constant > current driver. They were experiencing similar > noise problems. I proposed and fabricated a > filtered version of the Buck Puck > > http://www.aeroelectric.com/Catalog/AEC/9051/ > > We also offered a filter-board that builders > could use to quiet Buck Pucks they already owned. > The instructions above describe a line noise filter > that proved useful on the Buck Puck. If your > fixtures use the same power supply then values > for a filter are given in the document. You might > be able to use one of our filter boards . . . or > substitute a fully assembled power supply. > > > Bob . . . > > ________________________________________________________________________________
Date: Sep 12, 2011
To share some experience. I have a Cherokee 6 . On a regular basis on V16 over Deer park, heading tow ards JFK ATC reports my transponder is not working. It comes back shortly. The consensus was there are some angles that are blocked by my fixed gear. -----Original Message----- From: Charlie England <ceengland(at)bellsouth.net> Sent: Sat, Sep 10, 2011 1:50 pm Subject: AeroElectric-List: Re: Avionics-List: Transponder troubles th.net> On 09/10/2011 08:52 AM, Kelly McMullen wrote: > --> Avionics-List message posted by: Kelly McMullen > > Had strange occurrence with Salt Lake Approach yesterday. Initially, Another + for it being an ATC problem. One of my neighbors used to fly all over the central & southeast USA, & whenever he (and others) would fly through Memphis airspace ATC would tell them that their transponder wasn't working properly (no altitude, incorrect altitude, etc etc). The various transponders seemed to work fine around other class B/C airspace, & all had problems whenever they entered Memphis airspace. Charlie ________________________________________________________________________________
Date: Sep 12, 2011
Just a quick update on my PC680 odyssey.... while 1 battery was beyond hope, 2 that I had removed for poor performance recovered enough to pass the minimum test as defined by the manufacturer - >12.65 volts with no load, > 9.6 volts @70F with 120amp load for 15 seconds My oldest battery, a3+ year old Odyssey PC680 that has only been trickled charged, tests at 12.89volts with no load and 10.8 volts at end of load test. A 'new' battery a neighbor gave me, the certified version of the PC680, 13.18 with no load and 10.0 volts at end of test How did they recover? A couple of charges/discharges with a 10amp Schumacher charger (model XC10). The 2 batteries I have installed in my '10 have 'recovered' too. Though I haven't had a chance to test them with the HF tester recently, batt1 has been discharged with extensive panel work and batt2 has given me 10+ starts. They've been charged on a number of 1 & 2 hour flights. They now both perform almost as desired, i.e. batt1 will run my panel for extended periods without losing the 3 GRTs due to low voltage, batt2 gets thru the first compression stroke on the first try... sometimes just barely and it is certainly not 'snappy'. I can run with what I have for now. Cold weather may change things. My sense is that 1 or 2 fresh batteries will give me what I want in the end. A different starter may still be desirable for better starts in cold conditions. PS - the certified version of the 680 labled "PowerSafe - SBS J16 from Enersys" seems to perform differently. Though it is physically identical except for color, it appears to have different characteristics under load. Not necessarily better. Bill "smiling ear to ear with the new OBAM plane" Watson On 9/11/2011 5:50 PM, MLWynn(at)aol.com wrote: > I have been following the PC680 thread with great interest. I have a > couple for my RV8 that have been sitting around longer than I had > meant for them to sit. You know how construction goes. > I was going to build the capacity tester from the aeroelectric site: > http://www.aeroelectric.com/articles/battest.pdf > This looks pretty straightforward and I assume that I can get all the > components from my local Radio Shack. The one thing I am foggy on is > the 10 V. Zener diode in the schematic. Never having used these, are > they sold by voltage or amperage or what. Specifically, how do I make > sure I get the correct component? > Thanks, > Michael Wynn > RV 8 Wiring > San Ramon, CA > In a message dated 9/11/2011 12:09:07 P.M. Pacific Daylight Time, > paulm(at)olypen.com writes: > > > ----- Original Message ----- > From: "Paul" To: <aeroelectric-list(at)matronics.com> > Sent: Sunday, September 11, 2011 11:29 AM > Subject: AeroElectric-List: Re: ...failure = Use ilities ay > - MATRONICS WEB FORUMS - List Contribution Web > Site p; > > > * > > > * ________________________________________________________________________________
Subject: Re: static check
Date: Sep 12, 2011
9/12/2011 Hello Corky, Now you have asked a new question and it has two parts to it. 1) The first part of your question is: "...can i as IA PERFORM STATIC CHECKS......" The answer to that part of the question is YES, and the details of that YES answer are found in my previously posted answer of Sun, Sep 11, 2011 at 9:43 AM. 2) The second part of your question is: ".... can i as IA PERFORM ALTIMETER CERTS." By "ALTIMETER CERTS" I believe that you must be referring to ALL of the tests required by 14 CFR 91.411 (a). ALL of those required tests (with the exception of the static pressure system tests and inspections) must be conducted by the one of the organizations listed in 91.411 (b). See here: "(b) The tests required by paragraph (a) of this section must be conducted by- (1) The manufacturer** of the airplane, or helicopter, on which the tests and inspections are to be performed; (2) A certificated repair station properly equipped to perform those functions and holding- (i) An instrument rating, Class I; (ii) A limited instrument rating appropriate to the make and model of appliance to be tested; (iii) A limited rating appropriate to the test to be performed; (iv) An airframe rating appropriate to the airplane, or helicopter, to be tested;" Since a normal A&P Mechanic, even one possessing IA (Inspection Authority), does not meet any one of the qualifications listed above then he CAN NOT PERFORM all of the 91.411 (a) required tests on either type certificated or experimental amateur built aircraft.## Please let me know if you have any further questions. 'OC' Baker Says: "The best investment we can make is the time and effort to gather and understand knowledge." **PS: Every once in a while the builder of an experimental amateur built aircraft decides that he is the "manufacturer" of that aircraft and therefore under paragraph 91.411 (b) (1) is permitted to perform the tests required by 91.411 (a). That is not correct -- he is not considered the "manufacturer" of his experimental amateur built aircraft by the FAA. ##PS: It is very unfortunate that the tests required every two years by 14 CFR 91.411 and 91.413 are routinely referred to as ".... pitot static system checks ...". That is a very misleading and confusing term for the tests that are required. =============================================================== From: "corky childs" <corkyabc(at)charter.net> Sent: Sunday, September 11, 2011 5:12 PM Subject: Re: static check my question is can i as IA PERFORM STATIC CHECKS AND PERFORM ALTIMETER CERTS ================================================================= ________________________________________________________________________________
Subject: static check
Date: Sep 12, 2011
9/11/2011 Hello Corky, I'd like to respond by cutting and pasting a previous posting of mine. Let's start with a look at 14 CFR 91.411: "91.411 Altimeter system and altitude reporting equipment tests and inspections. (a) No person may operate an airplane, or helicopter, in controlled airspace under IFR unless-** (2) Except for the use of system drain and alternate static pressure valves, following any opening and closing of the static pressure system, that system has been tested and inspected and found to comply with paragraph (a), appendix E, of part 43 of this chapter; and....." "(b) The tests required by paragraph (a) of this section must be conducted by- {several different qualification requirements listed including:} (3) A certificated mechanic with an airframe rating (static pressure system tests and inspections only)."## Being a certificated A&P mechanic I turned to Appendix E, of part 43 which reads in part: "Appendix E to Part 43-Altimeter System Test and Inspection Each person performing the altimeter system tests and inspections required by 91.411 shall comply with the following: (a) Static pressure system: (2) Determine that leakage is within the tolerances established in 23.1325 or 25.1325, whichever is applicable." So I then needed to go on to PART 23--AIRWORTHINESS STANDARDS: NORMAL, UTILITY, ACROBATIC, AND COMMUTER CATEGORY AIRPLANES to find out how to perform the test and what the leakage tolerances were. Here is what 23.1325 says in part: "23.1325 Static pressure system. (b) If a static pressure system is necessary for the functioning of instruments, systems, or devices, it must comply with the provisions of paragraphs (b)(1) through (3) of this section. (2) A proof test must be conducted to demonstrate the integrity of the static pressure system in the following manner: (i) Unpressurized airplanes. Evacuate the static pressure system to a pressure differential of approximately 1 inch of mercury or to a reading on the altimeter, 1,000 feet above the aircraft elevation at the time of the test. Without additional pumping for a period of 1 minute, the loss of indicated altitude must not exceed 100 feet on the altimeter." So how to evacuate the static pressure system? After plugging up the two static ports I opened the system drain connection in my static system and plumbed in this MixMizer syringe: http://www.hopkinsmfg.com/10111.html This device readily evacuated the system and the static system passed the leak test. After closing up the system drain connection and making the required log book entry I was good to go. What did we learn from this exercise? A) For some mandatory regulatory requirements there are some provisions of 14 CFR that do apply to our experimental amateur built aircraft even if at first glance some of them (Part 43 and Part 23 for example) do not appear to apply. B) Even though anyone can work on, repair, modify, inspect, and maintain an amateur built experimental aircraft there are certain items that require action by specially qualified individuals. The annual condition inspection is one item requiring performance by either the holder of the Repairman Certificate for that specific aircraft or the holder of an A&P certificate. Another is the requirement for either the holder of an Airframe certificate or one of the other entities identified in 91.411 (b) in order to conduct a regulatory acceptable static system check. Please let me know if you have any further questions. Thanks, 'OC' Says: "The best investment we can make is the effort to gather and understand knowledge." **PS: Note that while this section pertains to "..operate (ing) ... in controlled airspace under IFR ...." a careful reading of the FAR's (see sections 91.215 and 91.413) will show that a VFR only airplane with an integrated altitude encoder and transponder system (which is just about everyone) will also require a static system check under certain circumstances. ##PS: Note that being the builder and designated repairman for this specific experimental amateur built airplane did not qualify me to perform the static system test and inspection. ==================================================== From: corky childs Sent: Saturday, September 10, 2011 4:09 PM Subject: static check if i had a ap and ia what else would i need to static test experminital anc certified aircraft thanks corky ________________________________________________________________________________
Date: Sep 12, 2011
At 01:29 PM 9/11/2011, you wrote: > >Bob's scope digital sampling is very slow sampling as usual. Really? As usual? Exactly what was the sampling rate for the data depicted? What is your basis for the assertion? Inquiring minds want to know. >The peak inrush current is basically current limited to the power >supply and wiring and switcher resistance. He shows one sample at >over 30 amps and who knows what the peak current is. Is that the point? The purpose for producing that plot was to demonstrate that the incandescent lamp under study (I think it was an automotive halogen) does not cool sufficiently between wig-wag flashes to produce a series of inrush currents even close to what is produced by the first, cold start. >I got the info from a suscessful fligher months ago and the parts >are cheep also Like at the time 30 for a system. NOT all hid systems >will work wig wag as the supply simply dies soon > >I can go back and try to find the link if you are interested. I will >not post to Bob's list ever!!!! . . . yet here you are! Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Go ahead, make my day . . . > < show me where I'm wrong. > ================================ ________________________________________________________________________________
Date: Sep 12, 2011
At 05:08 AM 9/12/2011, you wrote: > >Bob, I'd like to get a couple of those if they are still available from you. > >What I have is a couple of "Luxdrive 02008B-700 PowerPucks" >producing 700ma. They are round rather than square as the ones in >your link but look like the same thing. they have 2 input and output leads. > >If you have a couple of filter boards that I can wire them to, I'd >like to get them. Or perhaps a couple of boards with the pucks installed. >How much? How can I get them? They're in the catalog at: https://matronics.com/aeroelectric/Catalog/AECcatalog.html AEC9051 at the bottom of the page Bob . . . ________________________________________________________________________________
From: "CHARLES T BECKER" <ctbecker(at)atlanticbb.net>
Subject: External Battery Plug
Date: Sep 12, 2011
Can someone point me to the diagram for wiring in an external power plug for connecting a sustainer? I've got an 8A, two rear mounted batteries, subie, all electric. used a switched buss, as opposed to a diode, for managing the two busses. ________________________________________________________________________________
Date: Sep 12, 2011
At 04:50 PM 9/11/2011, you wrote: >I have been following the PC680 thread with great interest. I have >a couple for my RV8 that have been sitting around longer than I had >meant for them to sit. You know how construction goes. > >I was going to build the capacity tester from the aeroelectric site: > ><http://www.aeroelectric.com/articles/battest.pdf>http://www.aeroelectric.com/articles/battest.pdf > >This looks pretty straightforward and I assume that I can get all >the components from my local Radio Shack. The one thing I am foggy >on is the 10 V. Zener diode in the schematic. Never having used >these, are they sold by voltage or amperage or what. Specifically, >how do I make sure I get the correct component? Keep in mind that this is more of a battery bench-marker as opposed to a quantitative tester. A battery's ability to deliver energy depends on size, condition, temperature and load. A battery 'rated' at 20AH will deliver that amount of output when new and generally under a very light load compared to how you intend to used it. Consider the exemplar plot below Emacs! This battery is 'rated' at 17 a.h. But it will deliver that output only when loaded at .85A x 20 hours = 17 a.h. Your airplane's endurance loads are more likely to be on the order of 4A so you can expect about 3 hours of service or 12.75 a.h. of output. Of course, this is an as-new performance value. You'll want to size and maintain your battery to meed design goals when the battery has just degraded to the point of needing replacement. For most folks this is at 75 or 80% of new capacity. So this particular battery could be used in a system where endurance expectations are for 2 hours of service at 4.25A. The battery cap tester depicted in the book is not intended to give you an accurate reading of the battery's capacity. What it will do is let you know when the battery has fallen so far below its as-new condition as to require replacement. If your new battery ran your exemplar load for say 200 minutes, then you would benchmark the replacement at 150 minutes. If you'd like to get real numbers at loads matching your system's requirements, you'll need something like http://www.westmountainradio.com/product_info.php?products_id=cba3&navcode=/cbaLink1 I've got a couple of these critters. They were used to produce the plots like these http://www.aeroelectric.com/Pictures/Curves/HF_aa_vs_Duracell.jpg http://www.aeroelectric.com/Pictures/Curves/El-Cheeso_Battery_Test_3.jpg The device can also be used as a voltage versus time data acquisition system and get you information like this. http://www.aeroelectric.com/Pictures/Curves/schumacher_3.jpg I would not discourage you from building the po' boy's cap-checker. It's a useful tool within its limitations. Radio Shack won't have a 10v zener. You'll have to get it from a supplier with a broader range of product offerings. I'll be back in my shop later today. Let me see if I've got one in drawer I can send you. Bob . . . ________________________________________________________________________________
Date: Sep 12, 2011
mode At 12:27 PM 9/11/2011, you wrote: > > > > Inrush current beyond the initial cold > > start is not an issue for incandescent lamps. > > The reason I plotted the this data . . . > > >Quite true Bob, however I tried not having a first cycle, but it >never seemed to work. You ALWAYS have a first pulse. Sure . . . The purpose of study was to support a discussion about the NTC thermistor style current limiters. These things 'work' when allowed to heat up past the resistance vs. temperature break point where the device's resistance falls to some low, tolerable value of series resistance. I think we were talking about the CL series limiters http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=KC023L-ND http://www.ge-mcs.com/download/temperature/920_325a.pdf These stay in a low resistance state by a sustained current flow and have a 'cool down' requirement of 2 to 20 seconds for them to 'reset' and be capable of limited the next inrush event. The discussion concluded that the thermistor style device would perform as needed for the initial cold- start transient but was too slow to help for closely space repeat transients. The data plot showed that second and subsequent events in an incandescent wig-wag system were insignificant. >Also, most timers using a 555 have an initial 1.5X times longer >pulse than the second pulse. I no longer use the 555 for this >reason. What I do now is have a faster r/c oscillator and a divider >to get the correct timing. I'd be glad to share the schematic with >interested parties. Yeah, my favorite is the CD4060 oscillator/divider. Hope these don't go obsolete soon. I'm putting one into a high school electronics class project. The critters are 40 years old and still great ol' work horses. An alternative (if you can live in a 5v world) is a PIC microcontroller. I keep the 8-pin flash devices around to emulate more complex logic and timing functions. It's a jelly bean part at about 75 cents and capable of dropping into a bunch of applications with the right code. I used one to generate a pair of 17 Khz outputs to drive a push-pull, dc/dc converter design. The single chip replaced 4 parts in the next-best choice and was more stable to boot. > Nice graph of the pulses. That's a plotting feature of even the low cost lines of most 'scopes these days. I can plug a thumbdrive into my TEK TDS220 scope and dump the screen to a .jpg file. I can also get a dump of the numbers for use in other analysis. >I'd still bet that many halogen lamps have declined in quality. I've >seen this first-hand. There are many variables in the making of halogen lamps. You got that right. But I'll bet it's cyclical too. Suppliers are always wrestling for contracts but price cannot be the sole driver. I think the value trends are generally upward. Bob . . . ________________________________________________________________________________
Date: Sep 12, 2011
Thanks, I ordered a couple. FYI, Had a heck of a time finding your catalog page before you sent this link. No matter how hard I hit Google or fooled around with my other AE bookmarks, I just couldn't find it. Bill On 9/12/2011 8:23 AM, Robert L. Nuckolls, III wrote: > > > At 05:08 AM 9/12/2011, you wrote: >> >> >> Bob, I'd like to get a couple of those if they are still available >> from you. >> >> What I have is a couple of "Luxdrive 02008B-700 PowerPucks" producing >> 700ma. They are round rather than square as the ones in your link >> but look like the same thing. they have 2 input and output leads. >> >> If you have a couple of filter boards that I can wire them to, I'd >> like to get them. Or perhaps a couple of boards with the pucks >> installed. >> How much? How can I get them? > > They're in the catalog at: > > https://matronics.com/aeroelectric/Catalog/AECcatalog.html > > AEC9051 at the bottom of the page > > Bob . . . > > ________________________________________________________________________________
Date: Sep 12, 2011
At 09:13 AM 9/12/2011, you wrote: > >Thanks, I ordered a couple. > >FYI, Had a heck of a time finding your catalog page before you sent >this link. No matter how hard I hit Google or fooled around with my >other AE bookmarks, I just couldn't find it. Hmmm . . . one could start at the home page http://aeroelectric.com and select the "Catalog of Products and Services" link. But how you get there is not so important as getting there. I'm pleased that we can help move your project forward. By the way, did you see the link to the installation manual? http://www.aeroelectric.com/Catalog/AEC/9051/9051-700A.pdf Check this over and make sure it looks like a doable and useful experiment . . . Bob . . . ________________________________________________________________________________
Date: Sep 12, 2011
Subject: Rotax 912ULS charging problem
On aero electric web site I found the internal diagram of the charger rectifier associated with Rotax 912 engine, the diagram is located here: http://aeroelectric.com/Mfgr_Data/Regulators/Ducati_Rotax/Ducati_Regulator_Wiring_1.pdf My question is if this diagram is correct (because I can see some ?????? beside some of the components) or is it some kind of "reverse engineering"? The problem I am trying to solve however is intermittent false indication of the charge warning light. The light will come on from time to time or just flicker while the charge is on, I can verify it on the voltmeter installed on the instrument panel. I am trying to locate the source of problem by looking for any loose connection between the trio of R, B and C of the rectifier terminals. The airplane is RANS 6S6 Nati Niv Illinois ________________________________________________________________________________
Date: Sep 12, 2011
----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Sent: Monday, September 12, 2011 5:21 AM Subject: Re: AeroElectric-List: Re: ...failure mode > > > At 01:29 PM 9/11/2011, you wrote: >> My comments were intended to be private and addressed what I understood was the suggested cause of short Halogen auto lights. The data you showed and my personal experience is the initial ON spike does NOT shorten the life and your data shows wig wag surely does NOT have a significant effect based on heating and cooling from wig wag vs no wig wag after the initial ON pulse as there is no significant inrush on later ON pulses. >>Bob's scope digital sampling is very slow sampling as usual. > Really? As usual? Exactly what was the sampling rate > for the data depicted? What is your basis for the assertion? > Inquiring minds want to know. > Well Bob surely you know. You say its a TDS 220 which is advertised as a 2 channel 100 mhz with sampling rates AS FAST AS 1GS/s; But that applies only for a fast sweep speed as the line buffer is limited to 2500 samples per line or one sample every MS (in the above sample) far below what is needed to determine the initial surge current width and peak to get the energy produced into the bulb. Further there is HUGE NOISE on top of the signal from apparently a defective setup. Further it (Sampling) is too slow to characterize the wig wag ON inrush current spikes but it does imply the inrush is small negating wig wag as a factor in bulb life Its generally accepted in the industry one needs a MINIMUM sample rate of 10 times the expected pulse width to characterize a repetitive pulse and higher for a one shot event. In digital sampling scopes the line buffer is critical in determing the true sampling rate NOT the advertised sampling rate for slower sweep rates Thus we can determine the inrush pulse is between 1 and 2 MS with a peak of at least 31+ amps Who knows how much the true peak current might be but that info is not known as the detailed setup is not discussed. Further the next 1 MS sample is at least 15 amps followed by a 10 amp sample. While there is no significant repeating inrush an inrush limiter would stop the initial inrush and extens lamp life a point not noticed in the discussion as I recall. Note sampling rate is not the average value during the sample time its a very short time period every 1 MS as the value must be captured and processed before the next sample period. Basically what you see is a very small sample time period being taken every 1 MS The tek data sheet for the scope suggests the sample period is a very small part of 1 MS in this case thus perhaps 99+% of the time the data value being sampled could be far away from the sample snap shot on average. Sadly sampling scopes are easilly misunderstood when it comes to specifications and what is implied is often far from general truth for other than the specificaed setup conditions After the initial pulse ther is so much "NOISE" on the data its basically impossible to determine if there is any following peaks in the ON current. Not only is there 4-5 amps of noise but there is a lower frequency of noise implied suggestion low frequenct ripple even in the ground along with high frequency noise. This suggests a bad setup coupled with perhaps a switching power supply VS a batttery as the source of power. >>The peak inrush current is basically current limited to the power supply >>and wiring and switcher resistance. He shows one sample at over 30 amps >>and who knows what the peak current is. > > . . . yet here you are! AS you would have known if you read my next message before replying to this one you would have known it was posted in error. Many groups I belong to default to the poster not the group. My mistake I have replied to a question you know the answer to and it would have been helpful to the group (at large) to simply state how the scope shows data and how sampling scopes wotrk and when and where they should be used. In addition how they can decieve. related comment try to trouble shoot your turn signal with a $5 digital meter where it samples one or twice per second. :-) Further I am suprised your posting the subject scope pix with all the noise as its not typical of your generally high quality work Have at it! as I will not post again unless I make another mistake in addressing posts. Nor will I reply to any further comments Paul > > > Bob . . . ________________________________________________________________________________
Date: Sep 12, 2011
Subject: maybe OT: need help identifying pinouts on dvd drive
I have a car navigation dvd drive system and the internal dvd drive has died. I finally found another system to replace it but would very much like to identify the pinouts on this beast. The ATAPI (IDE) dvd drive connects to the system via a 50 pin flat flex cable. The only tools I have to help with this are 1. multimeter - not helpful because if you put one probe on say, pin 1, of the cable, many of the connectors on the board give solid beep and some give intermittent beeps! (of course, no power is going to the board or drive.) 2. cheapo logic analyzer, usb and pc/laptop based, but it only has 16 pins. very difficult to use. 3. 4 channel analog (non storage) o'scope, 150 mhz. I would like to replace this dvd drive with a solid state drive, like an SDHC card or USB thumb drive but must identify the pinouts first to know how to connect it to the adapters. In the future, I may use this system in my OBAM Mustang II. Thanks! David M. ________________________________________________________________________________
Date: Sep 12, 2011
Subject: Re: Rotax 912ULS charging problem
N992DN a crit : > > On aero electric web site I found the internal diagram of the charger > rectifier associated with Rotax 912 engine, the diagram is located here: > > > > http://aeroelectric.com/Mfgr_Data/Regulators/Ducati_Rotax/Ducati_Regulator_Wiring_1.pdf > > > > My question is if this diagram is correct (because I can see some > ?????? beside some of the components) or is it some kind of "reverse > engineering"? > > > Nati and all, The diagram on the left was provided by a fellow builder. I redrew the diagram after some study of the rectifier regulator : http://contrails.free.fr/elec_ducati_en.php As you say it is indeed a case of reverse engineering. Best regards, -- Gilles http://contrails.free.fr ________________________________________________________________________________
Date: Sep 12, 2011
>My comments were intended to be private and addressed what I >understood was the suggested cause of short Halogen auto lights. The >data you showed and my personal experience is the initial ON spike >does NOT shorten the life and your data shows wig wag surely does >NOT have a significant effect based on heating and cooling from wig >wag vs no wig wag after the initial ON pulse as there is no >significant inrush on later ON pulses. My data shows the cold-start transient is typical of incandescent lamps. The data further shows that the initial current draw on subsequent on-cyles is absent that transient because the filament doesn't have time to cool down between cycles. The data says nothing about heating and cooling cycles. Heating and cooling cycles are directly related to light output which ranges from very dim to full bright which must be a transition of several thousand degrees and is totally unrelated to the presence or lack of an inrush event. >>>Bob's scope digital sampling is very slow sampling as usual. > > Really? As usual? Exactly what was the sampling rate >> for the data depicted? What is your basis for the assertion? >> Inquiring minds want to know. > >Well Bob surely you know. You say its a TDS 220 which is advertised >as a 2 channel 100 mhz with sampling rates AS FAST AS 1GS/s; But >that applies only for a fast sweep speed as the line buffer is >limited to 2500 samples per line or one sample every MS (in the >above sample) far below what is needed to determine the initial >surge current width and peak to get the energy produced into the >bulb. Further there is HUGE NOISE on top of the signal from >apparently a defective setup. Further it (Sampling) is too slow to >characterize the wig wag ON inrush current spikes but it does imply >the inrush is small negating wig wag as a factor in bulb life. But during the discussions which accompanied the plot in question, we weren't really concerned with specifics of the inrush transients which by the way, were measured at other sweep settings but not included as not being germane to the discussion. And yes, I noted the noise present but didn't have time to clean it up as again, the point being made was to show the huge differences in lamp switching transients between cold start and subsequent flashes. >Its generally accepted in the industry one needs a MINIMUM sample >rate of 10 times the expected pulse width to characterize a >repetitive pulse and higher for a one shot event. In digital >sampling scopes the line buffer is critical in determing the true >sampling rate NOT the advertised sampling rate for slower sweep rates No claims are being made to the contrary. I think I've got the fast plots in the archives. If you want to discuss transient specifics, we can do that too. As I recall, the fast plots also carried the signature of flasher relay contact bounce and were not even useful to the discussion du jour. >Thus we can determine the inrush pulse is between 1 and 2 MS with a >peak of at least 31+ amps Who knows how much the true peak current >might be but that info is not known as the detailed setup is not >discussed. Further the next 1 MS sample is at least 15 amps followed >by a 10 amp sample. Yes . . . but no claims were made as to the inrush specifics . . . either when that plot was published nor in the discussions that started this tread. >While there is no significant repeating inrush an inrush limiter >would stop the initial inrush and extens lamp life a point not >noticed in the discussion as I recall. Possibly . . . but I'm unaware of any commercially produced vehicle that includes such inrush limiters on headlights . . . but I don't follow that market closely. I believe I was the first designer in Wichita to include an inrush limiter on an airplane. I put one on the nose gear mounted taxi light of the GP180. It went onto the first three prototypes but was removed when no definitive data could be offered as to return on investment. The only thing we could demonstrate is a reduction in the flashing of other lights when the nose gear light was turned on. Same thing happened with landing lights. The reliability guys didn't want inrush limiters on those either due to lack of data for return on investment and suppression of reliability due to added parts. Later I discovered that keep-warm circuits for tungsten filaments on high vibration mounts had a far greater benefit for bulb life than inrush limiting. Never had an opportunity to explore that in a T/C aircraft as my job moved out of that arena when I went to the Targets Group. >Note sampling rate is not the average value during the sample time >its a very short time period every 1 MS as the value must be >captured and processed before the next sample period. Basically what >you see is a very small sample time period being taken every 1 MS >The tek data sheet for the scope suggests the sample period is a >very small part of 1 MS in this case thus perhaps 99+% of the time >the data value being sampled could be far away from the sample snap >shot on average. > >Sadly sampling scopes are easilly misunderstood when it comes to >specifications and what is implied is often far from general truth >for other than the specificaed setup conditions > >After the initial pulse ther is so much "NOISE" on the data its >basically impossible to determine if there is any following peaks in >the ON current. > >Not only is there 4-5 amps of noise but there is a lower frequency >of noise implied suggestion low frequenct ripple even in the ground >along with high frequency noise. This suggests a bad setup coupled >with perhaps a switching power supply VS a batttery as the source of power. No, it was just an RG battery. There's a 5KW AM broadcast station 1 mile from the Wichita house that is never entirely absent from test data. I've suffered both the effects of 1.3Mhz carrier and demodulated program material. I didn't have time to chase it out that day but my lab in Medicine Lodge is entirely clean of such interference. I'll re-plot and publish both the fast and slow data for the website archive. It is not good that data be mis-interpreted as to significance or the point being made. Bob . . . ________________________________________________________________________________
Date: Sep 12, 2011
At 11:37 AM 9/12/2011, you wrote: >On aero electric web site I found the internal diagram of the >charger rectifier associated with Rotax 912 engine, the diagram is >located here: > > > ><http://aeroelectric.com/Mfgr_Data/Regulators/Ducati_Rotax/Ducati_Regulator_Wiring_1.pdf>http://aeroelectric.com/Mfgr_Data/Regulators/Ducati_Rotax/Ducati_Regulator_Wiring_1.pdf > > >My question is if this diagram is correct (because I can see some >?????? beside some of the components) or is it some kind of "reverse >engineering"? It's a deduced diagram somebody sent us that was based on their dissection of the product by carving out the potting compound. > > >The problem I am trying to solve however is intermittent false >indication of the charge warning light. The light will come on from >time to time or just flicker while the charge is on, I can verify it >on the voltmeter installed on the instrument panel. I am trying to >locate the source of problem by looking for any loose connection >between the trio of R, B and C of the rectifier terminals. I can't vouch for the diagrams accuracy . . . only that it is typical of such single-phase rectifier/regulators on small engines. Recommend you disconnect the light and use an active notification of low voltage that is independent of the charging system. That light is sorta like the alternator warning light on cars. Tells a limited story. Bob . . . ________________________________________________________________________________
Date: Sep 12, 2011
> >The diagram on the left was provided by a fellow builder. I redrew >the diagram after some study of the rectifier regulator : >http://contrails.free.fr/elec_ducati_en.php >As you say it is indeed a case of reverse engineering. > >Best regards, >-- >Gilles Yeah, I'd forgotten who sent me that. How are you my friend. Long time no hear! Bob . . . ________________________________________________________________________________
Date: Sep 12, 2011
> >I will double check the specs against what I think I have in the way >of LEDs in my current "Jeff's LED position lights" installation. I >really like the product... except for the noise. Good to hear. When you get your system up and running to design goals, how about some pictures and a narrative of your experience and findings. We can post it to the articles section of the website . . . Bob . . . ________________________________________________________________________________
Date: Sep 12, 2011
Bob's filters will work just fine with Jeff's lights. They will completely eliminate your noise issues. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=352107#352107 ________________________________________________________________________________
From: "William Slaughter" <william_slaughter(at)att.net>
Date: Sep 12, 2011
Promises, promises. Have at it! as I will not post again unless I make another mistake in addressing posts. Nor will I reply to any further comments Paul > > > Bob . . . ________________________________________________________________________________
Subject: Re: AeroLed landing lights not working with wig wag
relay
Date: Sep 13, 2011
The Aeroled units with wig wag were an additional $100 each. It was a lot cheaper to buy a simple flasher unit. I have a light in each wing tip. The wiring is also easier with the flasher unit behind the panel. The Aeroled units need to be connect by a few wires that would have to run tip to tip. -------- Thanks Read this topic online here: http://forums.matronics.com/viewtopic.php?p=352124#352124 ________________________________________________________________________________
Date: Sep 13, 2011
Another schematic attached - also without correctness guarantee. Jan de Jong ________________________________________________________________________________
Subject: Re: Low Cost WigWag Alternatives
Date: Sep 13, 2011
The cheap NAPA relay will not work to wig-wag HID's even if you do heat them up manually. I use this solid state wig-wagger and it works great with em! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=352162#352162 ________________________________________________________________________________
Date: Sep 13, 2011
The cheap NAPA relay will not work to wig-wag HID's even if you do heat them up manually. I use this solid state wig-wagger and it works great with em! . Read this topic online here: http://forums.matronics.com/viewtopic.php?p=352164#352164 ________________________________________________________________________________
Date: Sep 13, 2011
Jan Thanks so much, I think the diagram you provided is accurate, the replacement part number for the SCR (2N6504) help verifying that these are SCR'S. by looking at your diagram I was able to understand the principal of operation of the charger. The two SCRs are used to connect to ground each one of the G terminals during its negative part of the cycle making it referenced to ground so the other G terminal can charge the battery thru the in line diode. (the G leads coming from the engine are not referenced t o ground otherwise). With regards to my charging problem, the way I read the diagram is the charge light on/off control is related only to the existing of AC energy between the two G terminals, not to anything else, it=92s a bit surprising. My understanding of the charge light logic did not help me at all to Identify the source of the incorrect indication problem I am facing with. Bob, I suggest that you replace the diagram currently published on your web sit e with the one Jan has provided Thanks and regards Nati On Tue, Sep 13, 2011 at 10:07 AM, Jan de Jong wrote : > Another schematic attached - also without correctness guarantee. > > Jan de Jong > ________________________________________________________________________________
Subject: Report on New Power Supply
Date: Sep 13, 2011
A few weeks ago I reported that I had bought this 12 volt power supply: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=250852141183 I wanted it to power my instrument panel while doing navigation data updates, cycling the wing flaps, and other tasks that would otherwise take power from the airplane's battery. I have one that appeared similar to this one that works perfectly. However, the new one seems pretty close to useless for my needs. If I adjust the output voltage higher than about 12.4 volts DC, the power supply goes into overload and makes a quiet snapping sound about once per second and the output amps go to zero (while it's connected to my airplane's battery). The literature claims the output voltage is adjustable from 10.8 to 13.2 volts and that the input voltage is from 100 to 264 VAC. However, the one I received is labeled 176 - 264 volts AC. My guess is that since my input is 120 volts, the power supply cannot achieve the stated performance. I only paid $15 for it, including shipping, so I'm not all that unhappy. I'm sure I'll find a use for it somewhere. I just wanted to pass along that the power supply I received doesn't seem to be suitable for 12 volt airplanes. I could complain to the seller, but when I emailed them to ask how to connect it, since it came without instructions, my emails was never answered and it's now worth my time to fight for $15. I might look at battery maintainers at Wal Mart instead. Since I'm done building, I don't ground test heavy loads (like raising and lowering the landing gear) that often. A battery maintainer is probably all I need anyway. Dennis ________________________________________________________________________________
Date: Sep 13, 2011
>Bob, > >I suggest that you replace the diagram currently published on your >web site with the one Jan has provided > >Thanks and regards > >Nati > Good idea sir. I'll do it right now. Bob . . . ________________________________________________________________________________
Date: Sep 13, 2011
Subject: Re: Report on New Power Supply
Interestingly, if you look closely at the photo on the eBay listing you can see printed on the top of the supply "AC 176-264V". Not that anyone would notice that when bidding... You should at least give feedback to eBay about this. How many others will purchase this supply just like you did and discover the same thing as you did? Dick Tasker Dennis Johnson wrote: > A few weeks ago I reported that I had bought this 12 volt power supply: > http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=250852141183 > I wanted it to power my instrument panel while doing navigation data updates, cycling the wing flaps, and other tasks that would otherwise take power from the airplane's battery. I have one that > appeared similar to this one that works perfectly. > However, the new one seems pretty close to useless for my needs. If I adjust the output voltage higher than about 12.4 volts DC, the power supply goes into overload and makes a quiet snapping sound > about once per second and the output amps go to zero (while it's connected to my airplane's battery). > The literature claims the output voltage is adjustable from 10.8 to 13.2 volts and that the input voltage is from 100 to 264 VAC. However, the one I received is labeled 176 - 264 volts AC. My > guess is that since my input is 120 volts, the power supply cannot achieve the stated performance. > I only paid $15 for it, including shipping, so I'm not all that unhappy. I'm sure I'll find a use for it somewhere. I just wanted to pass along that the power supply I received doesn't seem to be > suitable for 12 volt airplanes. I could complain to the seller, but when I emailed them to ask how to connect it, since it came without instructions, my emails was never answered and it's now worth > my time to fight for $15. > I might look at battery maintainers at Wal Mart instead. Since I'm done building, I don't ground test heavy loads (like raising and lowering the landing gear) that often. A battery maintainer is > probably all I need anyway. > Dennis > * > > > * -- Please Note: No trees were destroyed in the sending of this message. We do concede, however, that a significant number of electrons may have been temporarily inconvenienced. -- ________________________________________________________________________________
From: "ROGER & JEAN CURTIS" <mrspudandcompany(at)verizon.net>
Date: Sep 14, 2011
Interestingly, if you look closely at the photo on the eBay listing you can see printed on the top of the supply "AC 176-264V". Not that anyone would notice that when bidding... Yes, I noticed this when it was posted a couple of weeks ago and I sent a question to the seller. The answer back was 100 - 264V input. If you look at their spec sheet on eBay it does say 100 - 264V even though the pic shows 176 - 264V. If you have 220VAC available in your shop you might try running it at the higher voltage. There is a lot of Chinese "junk" out there. You just have to weigh the risk to the reward. Roger ________________________________________________________________________________
Date: Sep 14, 2011
At 03:24 PM 9/13/2011, you wrote: >A few weeks ago I reported that I had bought this 12 volt power supply: > ><http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=250852141183>http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=250852141183 When shopping for an AC mains power supply to ground run your project, consider the following: Ideally, you're wanting to emulated an alternator, not a battery. A supply rated at 15 volts instead of 12 volts is likely to be adjustable down to the 14.2 to 14.6 volt range typical of most systems. Also, go for the biggest supply you can get within your means. This supply http://tinyurl.com/43yuvhl is a 15v, 350 Watt device with a cooling fan. I've used a number of supplies from this company for other projects and found them to be of good value. Finally, consider adding an output isolation diode to disconnect the supply from the battery when it is not being powered. I believe this was suggested and illustrated in the form of a relay or contactor by another AEC_Lister a some days ago. Either works. Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Go ahead, make my day . . . > < show me where I'm wrong. > ================================ ________________________________________________________________________________
Date: Sep 14, 2011
> Also, go for the biggest supply you can get within > your means. This supply > >http://tinyurl.com/43yuvhl > > is a 15v, 350 Watt device with a cooling fan. I've > used a number of supplies from this company for other > projects and found them to be of good value. An AE-List member reminded me that these are "switchmode" power supplies with a not quite zero risk of interference. These are probably designed and tested to FCC Part 15 performance rules. FCC15 allows the device to be a 'minor' problem but the user is responsible for discontinuing use if it interferes with other, protected services. The OBAM aircraft is not likely to have a problem. The greatest potential victims are ADF and LORAN which are essentially extinct. But be aware that some systems may object to power produced by these devices. The easy test is to momentarily unplug the power supply and run battery only to see if the problem goes away. They're not going to have a conducted emissions problem, only radiated and that's very low risk. Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Go ahead, make my day . . . > < show me where I'm wrong. > ================================ ________________________________________________________________________________
Date: Sep 14, 2011
Hi Bob, Several months ago I too purchased one of these units (or similar) as it seemed like a great method to power up the panel when working on the electrical problems, changes, etc. Rated at 13.5 v., 350W, the first unit I received (they come from China) would not hold voltage when loaded with about 5-6 amps of panel load. It started at about 13.4 v. and dropped to 12.4 when the panel was powered up. I contacted the seller and he said to return it and he would replace it. I did and about 4 wks later he sent me a replacement. It is functioning in a similar fashion. No load about 13.4 and mild load drops to 12.75. Still Ok for panel work, etc., but, I believe the spec indicate that it should be holding a tighter regulation. Any thoughts on what maybe going on...? David PS: ...voltage measurement being done with a cheap digital DVM and I do not know if the switching power supply would cause errors that I have not considered..... ----- Original Message ----- From: Robert L. Nuckolls, III To: aeroelectric-list(at)matronics.com Sent: Wednesday, September 14, 2011 6:24 AM Subject: Re: AeroElectric-List: Report on New Power Supply At 03:24 PM 9/13/2011, you wrote: A few weeks ago I reported that I had bought this 12 volt power supply: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=250852141183 When shopping for an AC mains power supply to ground run your project, consider the following: Ideally, you're wanting to emulated an alternator, not a battery. A supply rated at 15 volts instead of 12 volts is likely to be adjustable down to the 14.2 to 14.6 volt range typical of most systems. Also, go for the biggest supply you can get within your means. This supply http://tinyurl.com/43yuvhl is a 15v, 350 Watt device with a cooling fan. I've used a number of supplies from this company for other projects and found them to be of good value. Finally, consider adding an output isolation diode to disconnect the supply from the battery when it is not being powered. I believe this was suggested and illustrated in the form of a relay or contactor by another AEC_Lister a some days ago. Either works. Bob . . . //// (o o) ===========o00o=(_)=o00o======== = < Go ahead, make my day . . . > < show me where I'm wrong. > ======= ________________________________________________________________________________
From: "Paul Zimmer" <stickandrudder1(at)comcast.net>
Date: Sep 14, 2011
Thanks. I bought one following your recommendation. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Brantel Sent: Tuesday, September 13, 2011 1:33 PM Subject: AeroElectric-List: Re: Low Cost WigWag Alternatives The cheap NAPA relay will not work to wig-wag HID's even if you do heat them up manually. I use this solid state wig-wagger and it works great with em! . Read this topic online here: http://forums.matronics.com/viewtopic.php?p=352164#352164 ________________________________________________________________________________
Date: Sep 15, 2011
Hey Bob, I was looking over the specs on the West Mountain battery analyzer you mentioned: _http://www.westmountainradio.com/product_info.php?products_id=cba3&navcode /cbaLink1_ (http://www.westmountainradio.com/product_info.php?products_id=cba3&navcode=/cbaLink1) This is a very elegant piece of equipment. The information that it provides is certainly several magnitudes of more exact than the poor man's bench tester I was thinking to build. Further, it seems like something that my EAA chapter could put to more regular use than I would on my own. It is more than it would cost me to build the other, but not ridiculously expensive. Thank you for the direction. With this piece of equipment, would there be any reason to also have a carbon pile load tester? Harbor Freight has one on sale for $49.95. It seems to me that I would get much more useful data from the West Mountain unit and could save on that expense. Regards, Michael Wynn RV 8 Wiring San Ramon, CA In a message dated 9/12/2011 6:32:41 A.M. Pacific Daylight Time, nuckolls.bob(at)aeroelectric.com writes: At 04:50 PM 9/11/2011, you wrote: I have been following the PC680 thread with great interest. I have a couple for my RV8 that have been sitting around longer than I had meant for them to sit. You know how construction goes. I was going to build the capacity tester from the aeroelectric site: _http://www.aeroelectric.com/articles/battest.pdf_ (http://www.aeroelectric.com/articles/battest.pdf) This looks pretty straightforward and I assume that I can get all the components from my local Radio Shack. The one thing I am foggy on is the 10 V. Zener diode in the schematic. Never having used these, are they sold by voltage or amperage or what. Specifically, how do I make sure I get the correct component? Keep in mind that this is more of a battery bench-marker as opposed to a quantitative tester. A battery's ability to deliver energy depends on size, condition, temperature and load. A battery 'rated' at 20AH will deliver that amount of output when new and generally under a very light load compared to how you intend to used it. Consider the exemplar plot below This battery is 'rated' at 17 a.h. But it will deliver that output only when loaded at .85A x 20 hours = 17 a.h. Your airplane's endurance loads are more likely to be on the order of 4A so you can expect about 3 hours of service or 12.75 a.h. of output. Of course, this is an as-new performance value. You'll want to size and maintain your battery to meed design goals when the battery has just degraded to the point of needing replacement. For most folks this is at 75 or 80% of new capacity. So this particular battery could be used in a system where endurance expectations are for 2 hours of service at 4.25A. The battery cap tester depicted in the book is not intended to give you an accurate reading of the battery's capacity. What it will do is let you know when the battery has fallen so far below its as-new condition as to require replacement. If your new battery ran your exemplar load for say 200 minutes, then you would benchmark the replacement at 150 minutes. If you'd like to get real numbers at loads matching your system's requirements, you'll need something like _http://www.westmountainradio.com/product_info.php?products_id=cba3&navcode /cbaLink1 _ (http://www.westmountainradio.com/product_info.php?products_id=cba3&navcode=/cbaLink1) I've got a couple of these critters. They were used to produce the plots like these _http://www.aeroelectric.com/Pictures/Curves/HF_aa_vs_Duracell.jpg_ (http://www.aeroelectric.com/Pictures/Curves/HF_aa_vs_Duracell.jpg) _http://www.aeroelectric.com/Pictures/Curves/El-Cheeso_Battery_Test_3.jpg_ (http://www.aeroelectric.com/Pictures/Curves/El-Cheeso_Battery_Test_3.jpg) The device can also be used as a voltage versus time data acquisition system and get you information like this. _http://www.aeroelectric.com/Pictures/Curves/schumacher_3.jpg_ (http://www.aeroelectric.com/Pictures/Curves/schumacher_3.jpg) I would not discourage you from building the po' boy's cap-checker. It's a useful tool within its limitations. Radio Shack won't have a 10v zener. You'll have to get it from a supplier with a broader range of product offerings. I'll be back in my shop later today. Let me see if I've got one in drawer I can send you. Bob . . . ________________________________________________________________________________
Date: Sep 15, 2011
At 06:49 PM 9/14/2011, you wrote: Hi Bob, Several months ago I too purchased one of these units (or similar) as it seemed like a great method to power up the panel when working on the electrical problems, changes, etc. Rated at 13.5 v., 350W, the first unit I received (they come from China) would not hold voltage when loaded with about 5-6 amps of panel load. It started at about 13.4 v. and dropped to 12.4 when the panel was powered up. I contacted the seller and he said to return it and he would replace it. I did and about 4 wks later he sent me a replacement. It is functioning in a similar fashion. No load about 13.4 and mild load drops to 12.75. Still Ok for panel work, etc., but, I believe the spec indicate that it should be holding a tighter regulation. Any thoughts on what maybe going on...? You got me my friend. I've had first-hand contact with four power supplies from the source I linked. Two are already out the door, two more are waiting installation in a project. I just went to the bench and hooked up one out of the box. It was set for 13.5 zero load. Put a 1.0 ohm resistor across it (13.5A) and got maybe 0.05 volts drop. David PS: ...voltage measurement being done with a cheap digital DVM and I do not know if the switching power supply would cause errors that I have not considered..... I wouldn't think so . . . but there IS a reason for what you have observed. The mission is to figure out what it is. Cross checking with another instrument is a good first step. Forgive the potential for insult by asking whether you've accounted for wire drops? The test I just made measured voltage right at the V+ and V- terminals on the supply. The 1 ohm resistor was connected to adjacent V+ and V- terminals. A tech at HBC built what he thought was a handy load tester where his power resistor was in a nice box that plugged onto the front of his multimeter. The test leads plugged into the front of his load box. Of course, the meter was making measurements a the ends of test leads while loaded with significant current. Like the 4-wire low-ohms adapter, an accurate high-loads adapter begs for the same 4-wire measurement where the instrument and load paths are not shared. We modified his box to add separate banana jacks for load and measurement and subsequent measurements were much more meaningful. Bob . . . ________________________________________________________________________________
Date: Sep 15, 2011
Subject: Re: building a batter capacity tester
From: MLWynn(at)aol.com Subject: Re: AeroElectric-List: building a batter capacity tester Hey Bob, I was looking over the specs on the West Mountain battery analyzer you mentioned: http://www.westmountainradio.com/product_info.php?products_id=cba3&navcode=/cbaLink1 This is a very elegant piece of equipment. The information that it provides is certainly several magnitudes of more exact than the poor man's bench tester I was thinking to build. Further, it seems like something that my EAA chapter could put to more regular use than I would on my own. It is more than it would cost me to build the other, but not ridiculously expensive. Thank you for the direction. Yeah, those are a really good value. I have two of them. I wish they were a little more robust . . . say good for 10+ amps while testing a 12v battery but I HAVE used them to gather a lot of good data. It was a couple of years into my ownership that it suddenly occurred to me that they could be used for long term voltage monitoring and plotting. Set it up to 'test' a battery with a 0.01 amp load and a very low 'cutoff voltage' then hook the test leads to the source being monitored. With this piece of equipment, would there be any reason to also have a carbon pile load tester? Harbor Freight has one on sale for $49.95. It seems to me that I would get much more useful data from the West Mountain unit and could save on that expense. BOTH devices are useful for different reasons. But they can be used together too. LOAD testing is measure of a battery's internal impedance . . . I.e. ability to carry a large load. CAP testing is a measure of available energy at the terminals under various loads . . . where we know that useful energy is adversely influenced by internal impedance. There's more than enough ENERGY in a couple of alkaline lantern batteries to start an engine and the West Mountain Radio device would confirm that assertion. Problem is that a string of "F-cells" wont dump that energy at 200+ amps. Your load tester can be used to check your car's alternator too. Hook a voltmeter to the alternator's b-lead terminal while putting a load on the battery equal to the alternator's rated output with the engine rpms above 2000 or so. The drop should be nominal . . . perhaps 0.5 volts max. It might even go UP a bit! The WMR cap tester will characterize your battery's ability to support endurance loads for an interval set my your design goals. The load tester cannot measure or even help predict that. I considered doing a kit product consisting of a USB linked micro-controller and a really FAT mos-fet but with no heat-sink. Modern computers have a really great CPU heatsink and fan assembly that one can acquire from dead computers. A bill of materials for the hardware is about $15.00. The hardware is simple . . . the software for a graphical user interface and data plotting is a significant task that I just don't have time to address. If anyone out there is really whippy in Visual C or some similarly capable language, we might consider a joint venture to offer a kit for a DIY cap meter with some really nice features. Bob . . . ________________________________________________________________________________
Date: Sep 15, 2011
Subject: Taming the wiley coax . . .
A few weeks ago we were talking about getting a hand-held transceiver connected to the ship's external antenna. Modern coax like RG141 is pretty stiff . . . RG142 less so but still . . . When you extend the ship's coax directly to the hand-held, the result can look like this . . . http://www.aeroelectric.com/articles/Antennas/HandHeld-Ant1.jpg When the radio mounts a 'rubber duck' antenna, it's very much like a microphone. Sticking that coax directly into the top-mounted BNC connector makes the radio a bit awkward. Consider this approach . . . http://www.aeroelectric.com/articles/Antennas/HandHeld-Ant2.jpg A couple of right angle adapters and a rubber band will route the coax down tight against the back of the radio. Bob . . . ________________________________________________________________________________
Subject: one sensor, two gages?
Date: Sep 15, 2011
I regret my lack of knowledge, but could someone enlighten me, in a very la yman's manner, why you could not hook up a sensor to provide readings to tw o instruments. No, I am not planning to do it as it is my understanding it does not work, but what is the reason it does not work. Is it that too li ttle power is generated to signal two gages, does one interfere with the ot her. It would seem that the same data would be sent, such as if two people are looking at the same color and both seeing it as red and then saying it is red. I have been curious about this for a while and as I wait for my n ew Dynon engine monitor to supplement my rotary RWS engine monitor I though t I would ask. Thanks. Chris Barber Houston EFD - Ellington Airport Velocity N17010 Turbo Rotary 13b Z-14 ________________________________________________________________________________
Date: Sep 15, 2011
Subject: Re: one sensor, two gages?
Chris To start answering your question it would be interesting to know what gauge you are referring to because the answer will differ from one gauge to the other. For some you can actually monitor the same signal with two gauges (some RPM gouges are just good example) What exact type of gauge you are referring to? Nati Champaign, IL On Thu, Sep 15, 2011 at 6:04 PM, Chris Barber wrote: > I regret my lack of knowledge, but could someone enlighten me, in a > very layman's manner, why you could not hook up a sensor to provide > readings to two instruments. No, I am not planning to do it as it is my > understanding it does not work, but what is the reason it does not work. Is > it that too little power is generated to signal two gages, does > one interfere with the other. It would seem that the same data would be > sent, such as if two people are looking at the same color and both seeing it > as red and then saying it is red. I have been curious about this for a > while and as I wait for my new Dynon engine monitor to supplement my > rotary RWS engine monitor I thought I would ask. Thanks. > > > Chris Barber > > Houston > > EFD - Ellington Airport > > Velocity N17010 > > Turbo Rotary 13b > > Z-14 > > * > > * > > ________________________________________________________________________________
Date: Sep 16, 2011
Nati, Not any one particular because I don't know that much about it except I hav e been told that you just can't do it. I guess the ones I was most curious about would be temps, ie oil and in my rotary, coolant and pressure, oil, coolant and fuel. The one I have on there now are VDO that were provided b y the engine monitor from RWS (Tracy Crooks aviation rotary business). I a m not sure what will be provided with the Dynon, which should be in transit as I type. Thanks for the interest. Chris ________________________________ From: owner-aeroelectric-list-server(at)matronics.com [owner-aeroelectric-list -server(at)matronics.com] on behalf of Nati Niv [n992dn(at)gmail.com] Sent: Thursday, September 15, 2011 6:50 PM Subject: Re: AeroElectric-List: one sensor, two gages? Chris To start answering your question it would be interesting to know what gauge you are referring to because the answer will differ from one gauge to the other. For some you can actually monitor the same signal with two gauges (s ome RPM gouges are just good example) What exact type of gauge you are referring to? Nati Champaign, IL On Thu, Sep 15, 2011 at 6:04 PM, Chris Barber > wrote: I regret my lack of knowledge, but could someone enlighten me, in a very la yman's manner, why you could not hook up a sensor to provide readings to tw o instruments. No, I am not planning to do it as it is my understanding it does not work, but what is the reason it does not work. Is it that too li ttle power is generated to signal two gages, does one interfere with the ot her. It would seem that the same data would be sent, such as if two people are looking at the same color and both seeing it as red and then saying it is red. I have been curious about this for a while and as I wait for my n ew Dynon engine monitor to supplement my rotary RWS engine monitor I though t I would ask. Thanks. Chris Barber Houston EFD - Ellington Airport Velocity N17010 Turbo Rotary 13b Z-14 ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List ttp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Sep 15, 2011
From: "Richard E. Tasker" <retasker(at)optonline.net>
Some you can easily, some you cannot (depends on the gauge and the monitors), some you can do with a bit of finagling. Let me know exactly what you will be using for the sensor and the two instruments and I can give you suggestions. I have a number of sensors that I share between my Blue Mountain EFISOne and a Grand Rapids 4000. Most were pretty easy to share. Dick Tasker Chris Barber wrote: > > I regret my lack of knowledge, but could someone enlighten me, in a very layman's manner, why you could not hook up a sensor to provide readings to two instruments. No, I am not planning to do it > as it is my understanding it does not work, but what is the reason it does not work. Is it that too little power is generated to signal two gages, does one interfere with the other. It would seem > that the same data would be sent, such as if two people are looking at the same color and both seeing it as red and then saying it is red. I have been curious about this for a while and as I wait > for my new Dynon engine monitor to supplement my rotary RWS engine monitor I thought I would ask. Thanks. > > Chris Barber > > Houston > > EFD - Ellington Airport > > Velocity N17010 > > Turbo Rotary 13b > > Z-14 > > * > > > * -- Please Note: No trees were destroyed in the sending of this message. We do concede, however, that a significant number of electrons may have been temporarily inconvenienced. -- ________________________________________________________________________________
Date: Sep 16, 2011
Subject: DIY comm antenna . . .
On several occasions I've cited a commonly marketed insulated feed-thru mounting for CB antennas as suitable for doing your own comm antenna. I've seen this part in blister packs in lots of stores for prices ranging from 8 to 12 dollars. Here's an offering I just spotted on Ebay http://tinyurl.com/3bq5uhv Emacs! The price is right. You can put a UHF connector on your feedline and it will connect directly to this mounting. Alternatively, a UHF-M/BNC-F adapter will let you use the more common BNC-CM connector on your coax. The other end of the adapter is 3/8-24 thread hole. Silver solder your stainless antenna whisker into a hole drilled in a stainless 3/8-24 hex bolt. Bugger the threads on the bolt pretty good (poor boy's lock screw). Chisel works good, just leave first three threads untouched so you can get it to start. Coat the threads with grease and screw it into the adapter. The internal tooth lock washer goes inside between the doubler and the connector. The skin+doubler thickness should be .09" or better and braced against stringers and/or bulkheads if possible. Make your antenna 22 inches long (base to tip of whisker). Bob . . . ________________________________________________________________________________
Date: Sep 16, 2011
Subject: DIY comm antenna . . . OOPS
Sent this before I was finished . . . here's the whole message . . . --------------------------------------------------- On several occasions I've cited a commonly marketed insulated feed-thru mounting for CB antennas as suitable for doing your own comm antenna. I've seen this part in blister packs in lots of stores for prices ranging from 8 to 12 dollars. Here's an offering I just spotted on Ebay http://tinyurl.com/3bq5uhv Emacs! The price is right. You can put a UHF connector on your feedline and it will connect directly to this mounting. Alternatively, a UHF-M/BNC-F adapter will let you use the more common BNC-CM connector on your coax. The other end of the adapter is 3/8-24 thread hole. Silver solder your stainless antenna whisker into a hole drilled in a stainless 3/8-24 hex bolt. Bugger the threads on the bolt pretty good (poor boy's lock screw). Chisel works good, just leave first three threads untouched so you can get it to start. Coat the threads with grease and screw it into the adapter. The internal tooth lock washer goes inside between the doubler and the connector. The skin+doubler thickness should be .09" or better and braced against stringers and/or bulkheads if possible. Make your antenna 22 inches long (base to tip of whisker). Before you mount the antenna in the hole, you need to make sure the lockwasher doen't migrate and short the antenna whisker to ground. Emacs! Assemble to this configuration, center the washer up on the hex and then use spot of super-glue to stick the washer to the adapter. Not too much. You don't want it to wick under and run into the theads. After the glue is set, disassemble and install in the hole. Emacs! Bob . . . ________________________________________________________________________________
Date: Sep 16, 2011
Subject: DIY comm antenna . . . Plan-B
A reader asked if there was enough 'meat' in the connector base to cut an indexing relief for the lockwasher . . . as opposed to using glue to fixture the washer. The answer is 'yes'. See Plan-B version below. Thanks Bill! --------------------------------------------------- On several occasions I've cited a commonly marketed insulated feed-thru mounting for CB antennas as suitable for doing your own comm antenna. I've seen this part in blister packs in lots of stores for prices ranging from 8 to 12 dollars. Here's an offering I just spotted on Ebay http://tinyurl.com/3bq5uhv Emacs! The price is right. You can put a UHF connector on your feedline and it will connect directly to this mounting. Alternatively, a UHF-M/BNC-F adapter will let you use the more common BNC-CM connector on your coax. The other end of the adapter is 3/8-24 thread hole. Silver solder your stainless antenna whisker into a hole drilled in a stainless 3/8-24 hex bolt. Bugger the threads on the bolt pretty good (poor boy's lock screw). Chisel works good, just leave first three threads untouched so you can get it to start. Coat the threads with grease and screw it into the adapter. The internal tooth lock washer goes inside between the doubler and the connector. The skin+doubler thickness should be .09" or better and braced against stringers and/or bulkheads if possible. Make your antenna 22 inches long (total length of base+whisker). An improved methodology for keeping the lockwasher centered on the connector is to cut away .015 to .020" of material off the face of the hex down to a diameter of .500" as shown here. You can grip the part in a 3-jaw chuck directly onto the threads. Don't mash 'em and take very light cuts. A couple of .005" passes produced this end result with no damage to threads. Emacs! This modification of the base will keep the lockwasher centered while you bolt everything up. After all is said and done, here's what your ready-to-install antenna looks like. Emacs! Here's the order of installation on your airplane. Emacs! Bob . . . ________________________________________________________________________________
Date: Sep 17, 2011
A reader asked if there was enough 'meat' in the connector base to cut an indexing relief for the lockwasher . . . as opposed to using glue to fixture the washer. The answer is 'yes'. See Plan-B version below. Thanks Bill! --------------------------------------------------- On several occasions I've cited a commonly marketed insulated feed-thru mounting for CB antennas as suitable for doing your own comm antenna. I've seen this part in blister packs in lots of stores for prices ranging from 8 to 12 dollars. Here's an offering I spotted on Ebay http://tinyurl.com/3bq5uhv Emacs! The price is right. You can put a UHF connector on your feed line and it will connect directly to this mounting. Alternatively, a UHF-M/BNC-F adapter will let you use the user friendly BNC-CM connector on your coax. The other end of the adapter is 3/8-24 thread hole. Silver solder your stainless antenna whisker into a hole drilled in a stainless 3/8-24 hex bolt. You can purchase a 3' chunk of 'piano wire' at many hardware stores. 3/16" diameter is a good size. Bugger the bolt threads pretty good (poor boy's lock screw). A chisel works good, just leave first three threads untouched so you can get it to start. Coat the threads with grease and screw it into the adapter. The internal tooth lock washer goes inside between the doubler and the connector. The skin+doubler thickness should be .09" or better and braced against stringers and/or bulkheads if possible. Make your antenna 22 inches long (total length of base+whisker). An improved methodology for keeping the lockwasher centered on the connector is to cut away .015 to .020" of material off the face of the hex down to a diameter of .500" as shown here. You can grip the part in a 3-jaw chuck directly onto the threads. Don't mash 'em and take very light cuts. A couple of .005" passes produced this end result with no damage to threads. Emacs! This modification of the base will keep the lockwasher centered while you bolt everything up. After all is said and done, here's what your ready-to-install antenna looks like. Emacs! Here's the order of installation on your airplane. Emacs! Bob . . . ________________________________________________________________________________
Date: Sep 18, 2011
Subject: Bad day at the airport. . .
A friend of mine has been tracking the Reno accident. There's a picture circulating that shows what appears to be a detached elevator trim tap on the accident aircraft . . . That's never a good thing . . . and can be really bad at 400 kts. Emacs! Bob . . . ________________________________________________________________________________
From: "Stuart Hutchison" <stuart(at)stuarthutchison.com.au>
Date: Sep 18, 2011
Tragic ... my wild guess is flutter ... given only 60% of the left trim tab appears to be separating. Cheers, Stu F1 Rocket VH-FLY <http://www.mykitlog.com/RockFLY> http://www.mykitlog.com/RockFLY www.teamrocketaircraft.com _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Sunday, September 18, 2011 3:33 PM Subject: AeroElectric-List: Bad day at the airport. . . A friend of mine has been tracking the Reno accident. There's a picture circulating that shows what appears to be a detached elevator trim tap on the accident aircraft . . . That's never a good thing . . . and can be really bad at 400 kts. Emacs! Bob . . . ________________________________________________________________________________
Date: Sep 18, 2011
At 05:01 AM 9/18/2011, you wrote: >Tragic ... my wild guess is flutter ... given only 60% of the left >trim tab appears to be separating. Don't know about this airplane but I do know that a Beechjet trimmed for cruise is trimmed at or near full nose down. In fact, some pilots complain that they can't achieve book-values for cruise speeds when their trim actuator hits the full nose down stop before they've achieved the last few knots of speed. This is common when the airplane is loaded heavier by the tail. When Beechjet trim systems fail in cruise, it takes a LOT of nose up force on the stick to handle the airplane at lower speeds and particularly in the approach to landing and flare. Something on the order of 170 pounds. Suppose this airplane trimmed for high speed suddenly lost a substantial portion of it's nose-down trim. It seems likely that the airplane would pitch up with some vigor. After that, it's a mater of pilot awareness and reaction to make the right moves on the stick . . . assuming the forces encountered are even manageable. The structural robustness of this airplane may be the only reason it didn't pull the wings off in pitch-up. The rash of v-tail bonanza accidents some years back demonstrated many incidences where the leading edge of the stabilizer failed downward thus causing the airplane to pitch up followed by failure of one or both spars. No doubt others more informed as to this airplane's handling characteristics will be along to help connect the dots of information as they surface. I understand the NTSB/FAA guys are mumbling something about re-constructing the pieces which are numerous and quite small. I saw video of an airframe deliberately crashed into a reactor containment wall at dive speeds. It looked as if the airframe had been run through a tub grinder and spit out in bite-sized pieces. All that kinetic energy has to go somewhere. If tab failure was the initiating event . . .and given that the airplane hit the ground in essentially one piece . . . it seems that re-assembly, even if possible, would only show that the airplane had no other failures before impact. Bob . . . ________________________________________________________________________________
Subject: Two wires in one d-sub pin
Date: Sep 18, 2011
Is it ok to crimp two wires in one d-sub pin, as long as the two wires fit into the socket ok. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=352572#352572 ________________________________________________________________________________
Date: Sep 18, 2011
Subject: Re: Two wires in one d-sub pin
At 08:35 AM 9/18/2011, you wrote: > >Is it ok to crimp two wires in one d-sub pin, as long as the two >wires fit into the socket ok. Sure . . . but those must be very tiny wires. What's the situation? Bob . . . ________________________________________________________________________________
Date: Sep 18, 2011
I am installing an ADSB box and I need to daisy chain three ground pins with #24 wire. Two #24 wires fit into my pins ok, so instead of splices I wanted to use the pins as the splice. Thanks much Barry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=352575#352575 ________________________________________________________________________________
Subject: Re: Two Radios, One Antenna
Date: Sep 18, 2011
Hi Bob. I like this design. One suggestion that I have is to provide an interlock on the PTT function. For example, tie the common pole of the #2 PTT switch (currently tied to ground) to the top pole of the #1 PTT switch (currently not connected). This makes the #1 PTT the 'master'. This will prevent both transmitters from attempting to transmit simultaneously. Your switch makes it easy to add a portable comm into an existing installation. Vern -----Original Message----- From: Robert L. Nuckolls, III Sent: Friday, September 02, 2011 11:03 AM Subject: AeroElectric-List: Two Radios, One Antenna Here's a refined concept of the device I was talking about yesterday. The bill of materials for this gizmo would be on the order of $50. It would have to sell for $100 to $125 with mating connectors as a kit. Seems like a lot of fuss to avoid putting a second antenna on the airplane. Bob . . . ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Sep 18, 2011
Subject: DIY Comm antenna
The missive I've been massaging for the DIY Comm Antenna has be molded into a "shop notes" publication and published at: http://aeroelectric.com/articles/Antennas/DIY_Comm_Ant/DIY_Comm.html Bob . . . ________________________________________________________________________________
Date: Sep 18, 2011
Another solution would be to use a solder sleeve. They come in a variety of sizes. You can get them from SteinAir, ACS, and a variety of other places. Description: main Image -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Barry Sent: Sunday, September 18, 2011 10:09 AM Subject: AeroElectric-List: Re: Two wires in one d-sub pin --> < blalmarz(at)embarqmail.com> I am installing an ADSB box and I need to daisy chain three ground pins with #24 wire. Two #24 wires fit into my pins ok, so instead of splices I wanted to use the pins as the splice. Thanks much Barry Read this topic online here: <http://forums.matronics.com/viewtopic.php?p=352575#352575> http://forums.matronics.com/viewtopic.php?p=352575#352575 http://www.matronics.com/Navigator?AeroElectric-List http://www.matronics.com/contribution ________________________________________________________________________________
Date: Sep 18, 2011
At 11:02 AM 9/18/2011, you wrote: ><sprocket@vx-aviation.com> > >Hi Bob. > >I like this design. One suggestion that I have is to provide an >interlock on the PTT function. For example, tie the common pole of >the #2 PTT switch (currently tied to ground) to the top pole of the >#1 PTT switch (currently not connected). This makes the #1 PTT the >'master'. This will prevent both transmitters from attempting to >transmit simultaneously. > >Your switch makes it easy to add a portable comm into an existing >installation. Yeah, I'm debating whether or not to productionize this design. It's really a really-quick-n-simple. But I've got a lot of more important projects on the back burners already . . . Not sure about the portable comm . . . you'd need to extend a ptt line to the antenna switch. It's certainly applicable to dual panel-comms but a pain in the you-know-what for a hand-held. I toyed with a solid-state, pin-diode switch that would switch by extended ptt lines . . .or perhaps one channel could do it with a transmit power detector. There's a number of amateur radio boosters for hand-helds that simply hook into the antenna feedline. In the receive mode, the booster offers front end filtering and pre-amp to improve receive functions . . . when you hit the hand-held's ptt, the booster detects the strong RF and switches to a transmitter boost mode. A similar technique could be applied to either a hard-contact relay version or a pin-diode version. I have the equipment to develop and test a solid state version but time to market for that task is much longer. I think I'd stay with relays for the quick-turn project. Bob . . . Bob . . . ________________________________________________________________________________
Date: Sep 18, 2011
Subject: Re: DIY Comm antenna
would be nice if those files could be saved in PDF format Thanks Dick In a message dated 9/18/2011 11:10:16 A.M. Central Daylight Time, nuckolls.bob(at)aeroelectric.com writes: --> AeroElectric-List message posted by: "Robert L. Nuckolls, III" The missive I've been massaging for the DIY Comm Antenna has be molded into a "shop notes" publication and published at: http://aeroelectric.com/articles/Antennas/DIY_Comm_Ant/DIY_Comm.html Bob . . . ________________________________________________________________________________
Date: Sep 18, 2011
At 04:52 PM 9/18/2011, you wrote: >would be nice if those files could be saved in PDF format >Thanks >Dick That's easy . . . http://tinyurl.com/3t3nyq6 Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Go ahead, make my day . . . > < show me where I'm wrong. > ================================ ________________________________________________________________________________
Date: Sep 19, 2011
Thank you Dick In a message dated 9/18/2011 9:50:54 P.M. Central Daylight Time, nuckolls.bob(at)aeroelectric.com writes: At 04:52 PM 9/18/2011, you wrote: would be nice if those files could be saved in PDF format Thanks Dick That's easy . . . _http://tinyurl.com/3t3nyq6_ (http://tinyurl.com/3t3nyq6) Bob . . . //// (o o) ===========o00o=(_)=o00o========= < Go ahead, make my day . . . > < show me where I'm wrong. > ================================ (http://www.matronics.com/Navigator?AeroElectric-List) (http://www.matronics.com/contribution) ________________________________________________________________________________
Date: Sep 18, 2011
At 11:30 AM 9/18/2011, you wrote: >Another solution would be to use a solder sleeve. They come in a >variety of sizes. You can get them from SteinAir, ACS, and a >variety of other places. >Description: main Image Agreed. In fact it's preferable. Here's another approach. Emacs! This technique is pretty much standard practice in the TC aircraft industry. See: http://www.aeroelectric.com/articles/pigtail/pigtail.html Bob . . . ________________________________________________________________________________
Date: Sep 19, 2011
Subject: Using the shield as conductor
My audio panel (PS 8000) does not have a pin for "Mic Key Lo" but my com radio (Garmin 430W) requires one. The Garmin install manual says to use a connection to the audio panel ground lug. "Mic Audio Hi and Mic Audio Lo" are in a 2 conductor shielded cable. The Garmin shows a 3 conductor cable with one wire connected to the ground lug on the audio panel .The shield is grounded at the audio panel. Is there any reason I can't connect a wire to the radio end of the shield and use it for the "Mic Key Lo" input on the 430? It would save me from having to redo the cable and I can't think of any reason it wouldn't work. John Grosse ________________________________________________________________________________
Date: Sep 19, 2011
Subject: Re: Using the shield as conductor
At 09:37 PM 9/19/2011, you wrote: My audio panel (PS 8000) does not have a pin for "Mic Key Lo" but my com radio (Garmin 430W) requires one. The Garmin install manual says to use a connection to the audio panel ground lug. "Mic Audio Hi and Mic Audio Lo" are in a 2 conductor shielded cable. The Garmin shows a 3 conductor cable with one wire connected to the ground lug on the audio panel .The shield is grounded at the audio panel. Is there any reason I can't connect a wire to the radio end of the shield and use it for the "Mic Key Lo" input on the 430? It would save me from having to redo the cable and I can't think of any reason it wouldn't work. Works good . . . lasts a long time . . . Bob . . . ________________________________________________________________________________
Date: Sep 19, 2011
On 9/19/2011 6:37 PM, John Grosse wrote: > > > My audio panel (PS 8000) does not have a pin for "Mic Key Lo" but my > com radio (Garmin 430W) requires one. The Garmin install manual says > to use a connection to the audio panel ground lug. "Mic Audio Hi and > Mic Audio Lo" are in a 2 conductor shielded cable. The Garmin shows a > 3 conductor cable with one wire connected to the ground lug on the > audio panel .The shield is grounded at the audio panel. Is there any > reason I can't connect a wire to the radio end of the shield and use > it for the "Mic Key Lo" input on the 430? It would save me from having > to redo the cable and I can't think of any reason it wouldn't work. > > John Grosse > John, you simply tie (tee) into the Com audio low. Use the same method you use for tying the shields together ala' BK's web site if you like. Worked fine for me with a 430W and a different PSE audio panel. Tim ________________________________________________________________________________
Date: Sep 19, 2011
On 9/19/2011 8:34 PM, Tim Andres wrote: > > > On 9/19/2011 6:37 PM, John Grosse wrote: >> >> >> My audio panel (PS 8000) does not have a pin for "Mic Key Lo" but my >> com radio (Garmin 430W) requires one. The Garmin install manual says >> to use a connection to the audio panel ground lug. "Mic Audio Hi and >> Mic Audio Lo" are in a 2 conductor shielded cable. The Garmin shows a >> 3 conductor cable with one wire connected to the ground lug on the >> audio panel .The shield is grounded at the audio panel. Is there any >> reason I can't connect a wire to the radio end of the shield and use >> it for the "Mic Key Lo" input on the 430? It would save me from >> having to redo the cable and I can't think of any reason it wouldn't >> work. >> >> John Grosse >> > John, you simply tie (tee) into the Com audio low. Use the same method > you use for tying the shields together ala' BK's web site if you like. > Worked fine for me with a 430W and a different PSE audio panel. > Tim Sorry John I didnt read your mssg well. I see now you know what to do, just had a question on how to do it..... Tim ________________________________________________________________________________
Date: Sep 20, 2011
Subject: Comm antenna in search of an airplane
The DIY comm antenna featured in the recently published DIY article is looking for an airplane. First order entered to the website catalog and order form at http://aeroelectric.com gets it. Enter your request in the comments box at the bottom of the form "VHF Comm antenna @ $35.00" After your order is accepted by the website, post a note to the List letting others know that the inventory-of-one is spoken for. Bob . . . ________________________________________________________________________________
Subject: Fashion Handbags in 2011
Date: Sep 20, 2011
Thanks Matt, You are doing a fantastic job with keeping the spam out of the forum. Roger -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Matt Dralle Sent: Tuesday, September 20, 2011 12:07 PM Subject: Re: AeroElectric-List: Fashion Handbags in 2011 I have already removed them and blocked their email address. Matt Dralle Matronics List Administrator At 08:55 AM 9/20/2011 Tuesday, you wrote: >Get off this sight ya D bag > >On Tue, Sep 20, 2011 at 12:15 AM, yaya2323 <sf535jhgggf(at)hotmail.com> wrote: <sf535jhgggf(at)hotmail.com> > >Fashion Handbags in 2011 (snip)... ________________________________________________________________________________
Date: Sep 20, 2011
Yes, I certainly agree. That was so unusual it made me wonder just how it got through. Terry -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of ROGER & JEAN CURTIS Sent: Tuesday, September 20, 2011 9:42 AM Subject: RE: AeroElectric-List: Fashion Handbags in 2011 Thanks Matt, You are doing a fantastic job with keeping the spam out of the forum. Roger -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Matt Dralle Sent: Tuesday, September 20, 2011 12:07 PM Subject: Re: AeroElectric-List: Fashion Handbags in 2011 I have already removed them and blocked their email address. Matt Dralle Matronics List Administrator At 08:55 AM 9/20/2011 Tuesday, you wrote: >Get off this sight ya D bag > >On Tue, Sep 20, 2011 at 12:15 AM, yaya2323 <sf535jhgggf(at)hotmail.com> wrote: <sf535jhgggf(at)hotmail.com> > >Fashion Handbags in 2011 (snip)... ________________________________________________________________________________
Date: Sep 20, 2011
Subject: Re: Fashion Handbags in 2011
Obviously, someone has broken into the server. david yaya2323 wrote: > --> AeroElectric-List message posted by: "yaya2323" > > Fashion Handbags in 2011 > > Emma Watson has stepped into the adult glamour Coach Handbags (http://www.shoptshirtfashion.com/catalogues/bags+handbags+187/all.html) world by bagging her first American Vogue cover. Gucci Handbags (http://www.shoptshirtfashion.com/catalogues/bags+handbags+194/all.html) > The 21-year-old 'Harry Potter' actress, who is constantly on theetch her name as a style icon, graced the July publication of the American style bible, headed by editor-in-chief Anna Wintour. discount Handbags online (http://www.shoptshirtfashion.com) and discount Louis Vuitton Purse (http://www.shoptshirtfashion.com/catalogues/bags+purse+196/all.html) > Her flawless skin was accentuated by a slick hairstyle, which was scarped back, as Mario Testino photographed her in sophisticated creations by designers Tom Ford, Alexander McQueen, Prada, Calvin Klein and Dolce and Gabbana.Monogram Canvas > In the interview, she talked about her deliberate championing of emerging designers such as Juicy Purse (http://www.shoptshirtfashion.com/catalogues/bags+purse+195/all.html) and Coach Purse (http://www.shoptshirtfashion.com/catalogues/bags+purse+187/all.html). > "I thought if people are going to write about what I'm wearing, then I would wear young British designers who need the publicity," the Telegraph quoted her as saying. cheapest Handbags (http://www.shoptshirtfashion.com). > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=352746#352746 > > > -- If you're an American, just say NO to the Obamanation, to socialism, and get rid of Soros. ...democracy and a republic can function only in a firm partnership with morality and religion. -- John Adams. Indeed. Same should be said for ANY type of gubmnt ________________________________________________________________________________
Date: Sep 20, 2011
Well, no. They didn't break in. What they did was sign up for a Matronics Forums account. This requires my approval, but if the username and email don't look too nefarious and they don't put any obvious advertisement links in the signature, I really don't know if they're a spammer or not. They even have to answer some aviation related questions correctly to even request an account. The perhaps more pathetic take away from this whole thing, however, is that some REAL PERSON took the time to sign up for an account, waited for the approval, then spent more time to manually post the links for their sponsor's useless handbags. This wasn't an automated spambot. It was a real, misguided person that spent real time to post to a list of predominately Type-A males trying to sell accessories for predominately not Type-A females. In more irony, someone was actually PAYING this person to totally miss the target market. It would be nice to be able to enlighten them on the misappropriation of their advertising budget. Maybe we should all email the company and let them know... Or not. Build your airplane, instead. Matt Dralle Matronics Email List Admin At 03:09 PM 9/20/2011 Tuesday, you wrote: > > > >Obviously, someone has broken into the server. > >david > > >yaya2323 wrote: >>--> AeroElectric-List message posted by: "yaya2323" >> >>Fashion Handbags in 2011 >> >> >> >>http://forums.matronics.com/viewtopic.php?p=352746#352746 >> >> Matt G Dralle | Matronics | 581 Jeannie Way | Livermore | CA | 94550 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Subject: egt splicing--chromel and alumel pins
Date: Sep 21, 2011
Long story short---I have an Aerosance FADEC system in my RV6, I need to replace an egt probe which right now is intermittent. Aerosance has sold out or dissolved to Teledyne Continental Motors. In the past have gotten probes and splice kit from Aerosance, now TCM wants $450 for one egt probe and a splicing kit. I think I can do better looking for a type K probe but presently don't know of a source for alumel and chromel pins/sockets to create a splice in the harness. Also there is a 4 inch piece of braided crimp/heat shrink that goes over the splicing point. I've not found anything yet--anyone got any ideas? Dave Ford ________________________________________________________________________________
Date: Sep 22, 2011
Subject: Re: egt splicing--chromel and alumel pins
Unless you have a very high temperature difference across the connector/splice (unlikely), regular pins and sockets will work just fine. Any error caused by the different materials is non-existent unless the two ends of the pin/socket connection are at significantly different temperatures. Dick Tasker davidbf(at)centurytel.net wrote: > --> AeroElectric-List message posted by: davidbf(at)centurytel.net > > Long story short---I have an Aerosance FADEC system in my RV6, I need to replace an egt probe which right now is intermittent. Aerosance has sold out or dissolved to Teledyne Continental Motors. In the past have gotten probes and splice kit from Aerosance, now TCM wants $450 for one egt probe and a splicing kit. I think I can do better looking for a type K probe but presently don't know of a source for alumel and chromel pins/sockets to create a splice in the harness. Also there is a 4 inch piece of braided crimp/heat shrink that goes over the splicing point. I've not found anything yet--anyone got any ideas? > > Dave Ford > > -- Please Note: No trees were destroyed in the sending of this message. We do concede, however, that a significant number of electrons may have been temporarily inconvenienced. -- ________________________________________________________________________________
Date: Sep 22, 2011
Dave, I have some chromel and alumel pins and sockets for standard serial port type connectors (DB25 etc.) which I would be happy to send you. You can also buy other connector types, probes etc. from Omega. If, however, you are just doing a splice and don't need the connector (and want to do better than std. connector pins) you can silver solder the wires. Steve Stearns Boulder/Longmont, Colorado CSA,EAA,IAC,AOPA,PE,ARRL,BARC (but ignorant none-the-less) Restoring (since 1/07): N45FC O235 Longeze Cothern/Friling CF1 (~1000 Hrs) Flying (since 9/86): N43732 A65 Taylorcraft BC12D ________________________________________________________________________________
Date: Sep 23, 2011
The whole Internet is going to hell in a handbag. *ducks* ________________________________________________________________________________
Date: Sep 23, 2011
Subject: TKM/Michel Radios
I was talking with an acquaintance about radios - his ARC com/nav in his C150 is dying (fades away when it gets warm). TKM makes a slide-in replacement for it. My experience is limited to Collins/King/Garmin. Anybody have any experience with a TKM? Are they decent radios for the money? Any problems with putting them in aging airplanes? Chuck ________________________________________________________________________________
Date: Sep 24, 2011
Subject: Re: TKM/Michel Radios
I recently put two of these in place of a pair of original King KX-170C's in a Cessna 172N. I had two different problems with three different Michel radios over the last few months since install. Never any problem with getting them replaced under warranty BUT they are the slowest company I have ever dealt with. There is always a minimum one month wait (remember this is on 3 radio replacements, not insignificant experience) to get the warranty replacement. Even the company warns you about how slow they are. I am not sure what the issue is with the factory but they are very friendly, acknowledge problems quickly, but take forever to replace them. I was warned by our avionics shop about this issue with them but they felt they were fine radios, I would have to agree. I would not do it again. I ordered the radios through Aircraft Spruce, who were always very helpful and fast. Ed On Fri, Sep 23, 2011 at 9:57 PM, Chuck Birdsall wrote: > cbirdsall(at)member.afa.org> > > I was talking with an acquaintance about radios - his ARC com/nav in his > C150 is dying (fades away when it gets warm). TKM makes a slide-in > replacement for it. > > My experience is limited to Collins/King/Garmin. Anybody have any > experience with a TKM? Are they decent radios for the money? Any problems > with putting them in aging airplanes? > > > Chuck > > ________________________________________________________________________________
Date: Sep 24, 2011
I used Michel radios in a 182 I had. I felt they had good audio quality. They were reliable. I was told one possible problem guys could have was with worn out racks the new radios were put into. If the radio rack contacts are still in good shape these radios should be ok. Sent from my iPhone On Sep 23, 2011, at 20:57, Chuck Birdsall wrote: > > I was talking with an acquaintance about radios - his ARC com/nav in his C150 is dying (fades away when it gets warm). TKM makes a slide-in replacement for it. > > My experience is limited to Collins/King/Garmin. Anybody have any experience with a TKM? Are they decent radios for the money? Any problems with putting them in aging airplanes? > > > Chuck > > > > > ________________________________________________________________________________
Date: Sep 24, 2011
Chuck, Years ago, ( around 14) I changed out my old King KX170B for the Michel MX170. It was a GREAT radio, and personally, I'd highly recommend the Michel brand products. As a side note, I had some kind of problem with the radio several months after I got. IIRC, I bought it used on eBay, and it didn't come with a warranty. At any rate, I had to send it back to the factory. They fixed it, free of charge, and even shipped it back to me at no charge. The repair guy told me it was a common shortcoming of the radio, and the factory felt obligated to correct the problem at no charge to the consumer.......whether it was under warranty or not. Good radio, good people!! BTW, when installing the newer radio, my avionics guy had to remove the old power supply that the KX170B used, plus the related wiring harness. Not an easy job, either! The removal of the old radio and related parts, plus the appropriate FAA Paperwork cost a total of 8 hours shop time. (read that to mean 'expensive', just like any other brand of newer radio replacement). AFTER the initial installation, yes, the MX170 was a direct slide-in replacement, but you have to remove the old stuff first. Hope this helps, Mike Welch On Sep 23, 2011, at 6:57 PM, Chuck Birdsall wrote: > > I was talking with an acquaintance about radios - his ARC com/nav in his C150 is dying (fades away when it gets warm). TKM makes a slide-in replacement for it. > > My experience is limited to Collins/King/Garmin. Anybody have any experience with a TKM? Are they decent radios for the money? Any problems with putting them in aging airplanes? > > > Chuck > > > > > > ________________________________________________________________________________
Date: Sep 24, 2011
From: "DeWitt (Dee) Whittington" <dee.whittington(at)gmail.com>
Chuck, I was a member of a flying club in Richmond, Virginia. We bought a replacement Michel radio for our Cessna 150L. It was excellent. We also own a Cessna 172 that had a replacement Michel radio. Works find. Dee On Sat, Sep 24, 2011 at 9:32 AM, Mike Welch wrote: > mdnanwelch7(at)hotmail.com> > > Chuck, > > Years ago, ( around 14) I changed out my old King KX170B for the Michel > MX170. It was a GREAT radio, and personally, I'd highly recommend the > Michel brand products. > > As a side note, I had some kind of problem with the radio several months > after I got. IIRC, I bought it used on eBay, and it didn't come with a > warranty. At any rate, I had to send it back to the factory. They fixed > it, free of charge, and even shipped it back to me at no charge. > The repair guy told me it was a common shortcoming of the radio, and the > factory felt obligated to correct the problem at no charge to the > consumer.......whether it was under warranty or not. > > Good radio, good people!! > > BTW, when installing the newer radio, my avionics guy had to remove the > old power supply that the KX170B used, plus the related wiring harness. Not > an easy job, either! > The removal of the old radio and related parts, plus the appropriate FAA > Paperwork cost a total of 8 hours shop time. (read that to mean > 'expensive', just like any other brand of newer radio replacement). AFTER > the initial installation, yes, the MX170 was a direct slide-in replacement, > but you have to remove the old stuff first. > > Hope this helps, > Mike Welch > > > On Sep 23, 2011, at 6:57 PM, Chuck Birdsall > wrote: > > cbirdsall(at)member.afa.org> > > > > I was talking with an acquaintance about radios - his ARC com/nav in his > C150 is dying (fades away when it gets warm). TKM makes a slide-in > replacement for it. > > > > My experience is limited to Collins/King/Garmin. Anybody have any > experience with a TKM? Are they decent radios for the money? Any problems > with putting them in aging airplanes? > > > > > > Chuck > > > > > > > > > > > > > > -- DeWitt Whittington www.VirginiaFlyIn.org Building Glasair Sportsman with 3 partners ________________________________________________________________________________
Date: Sep 24, 2011
Subject: Re: Report on New Power Supply
At 06:49 PM 9/14/2011, you wrote: >Hi Bob, > >Several months ago I too purchased one of these units (or similar) >as it seemed like a great method to power up the panel when working >on the electrical problems, changes, etc. Rated at 13.5 v., >350W, the first unit I received (they come from China) would not >hold voltage when loaded with about 5-6 amps of panel load. It >started at about 13.4 v. and dropped to 12.4 when the panel was >powered up. Dave, did you run the reasons for your observations to ground? Bob . . . ________________________________________________________________________________
Date: Sep 25, 2011
Thanks guys, 'preciate the responses. Chuck On 9/24/2011 2:09 PM, DeWitt (Dee) Whittington wrote: > Chuck, > > I was a member of a flying club in Richmond, Virginia. We bought a > replacement Michel radio for our Cessna 150L. It was excellent. We > also own a Cessna 172 that had a replacement Michel radio. Works find. > > Dee > > On Sat, Sep 24, 2011 at 9:32 AM, Mike Welch > wrote: > > > > > Chuck, > > Years ago, ( around 14) I changed out my old King KX170B for the > Michel MX170. It was a GREAT radio, and personally, I'd highly > recommend the Michel brand products. > > As a side note, I had some kind of problem with the radio several > months after I got. IIRC, I bought it used on eBay, and it didn't > come with a warranty. At any rate, I had to send it back to the > factory. They fixed it, free of charge, and even shipped it > back to me at no charge. > The repair guy told me it was a common shortcoming of the radio, > and the factory felt obligated to correct the problem at no charge > to the consumer.......whether it was under warranty or not. > > Good radio, good people!! > > BTW, when installing the newer radio, my avionics guy had to > remove the old power supply that the KX170B used, plus the related > wiring harness. Not an easy job, either! > The removal of the old radio and related parts, plus the > appropriate FAA Paperwork cost a total of 8 hours shop time. > (read that to mean 'expensive', just like any other brand of > newer radio replacement). AFTER the initial installation, yes, > the MX170 was a direct slide-in replacement, but you have to > remove the old stuff first. > > Hope this helps, > Mike Welch > > > On Sep 23, 2011, at 6:57 PM, Chuck Birdsall > > wrote: > > > > > > > I was talking with an acquaintance about radios - his ARC > com/nav in his C150 is dying (fades away when it gets warm). TKM > makes a slide-in replacement for it. > > > > My experience is limited to Collins/King/Garmin. Anybody have > any experience with a TKM? Are they decent radios for the money? > Any problems with putting them in aging airplanes? > > > > > > Chuck > > > > > > > > > > > > > > > ========== > -List" > target="_blank">http://www.matronics.com/Navigator?AeroElectric-List > ========== > http://forums.matronics.com > ========== > le, List Admin. > ="_blank">http://www.matronics.com/contribution > ========== > > > -- > DeWitt Whittington > www.VirginiaFlyIn.org <http://www.VirginiaFlyIn.org> > Building Glasair Sportsman with 3 partners > > > * > > > * ________________________________________________________________________________
Date: Sep 25, 2011
Bob, ...I am on an extended trip with limited email, etc. No, I have not run further tests nor tried anything to find the reason for poor regulation on the power supply. ....more later, David ______________________________________________________ On Sat, Sep 24, 2011 at 6:51 PM, Robert L. Nuckolls, III wrote: At 06:49 PM 9/14/2011, you wrote: Hi Bob, Several months ago I too purchased one of these units (or similar) as it seemed like a great method to power up the panel when working on the electrical problems, changes, etc. Rated at 13.5 v., 350W, the first unit I received (they come from China) would not hold voltage when loaded with about 5-6 amps of panel load. It started at about 13.4 v. and dropped to 12.4 when the panel was powered up. Dave, did you run the reasons for your observations to ground? Bob . . . <http://www.matronics.com/contribution> ________________________________________________________________________________
Date: Sep 27, 2011
Subject: A refresher question about switching for the battery
and "alternator."
Good afternoon, everyone. I need a little refresher on the latest guidance on DC Power Master switches. (Quoting from http://www.aeroelectric.com/articles/Alternators/Know_Your_Charging_System.pdf, which quotes another article...) "The alternator switch turns the voltage regulator on and off, not the alternator output. The voltage to the alternator switch comes from the alternator field circuit breaker, which is tied directly to the aircraft battery through the master switch." (I think I'm correct in pointing out that the field circuit is from the bus, and whether the bus is getting it's electrons from the battery or alternator is another matter...) One of the larger discussions is with reference to the split rocker: "1) Leave the alternator switch OFF BEFORE starting the engine," and "2) Turn the alternator switch ON AFTER the engine is running." Mr. Nuckolls responds to this by pointing out there is "there is no demonstration in the physics of how alternators work that will support this notion...[that starting the engine with both sides powered somehow overloads the alternator, causing failure.]" Okay. I understand. Mr. Nuckolls also points out that even if you WANTED to sit on the ground without the engine running listening to the radio, why would one turn on both sides of the DC power master switch?) Also, "Yes, any truly qualified mechanic will conduct ground tests of electrical system components with only the battery side of the switch closed.") Okay, so while I won't hurt the alternator by cranking with both sides powered, you shouldn't sit around (with the engine not running) with them both on for fun... Here's the actual question. I see in Figure 11-20 of AEC (page 8-98), the example DC Power master is a DPST switch (same with Z-10/8 and Z-13/8), but some of the other diagrams show a DPDT with OFF-BATT-BATT/ALT. Why the difference? I'd rather use a DPST, but is there a good reason to use the DPDT? If I have a DPST, will pulling the ALT FLD breaker be the same as leaving the ALT side of the split rocker OFF in the few cases I'll be "sitting around listening to the radio?" I think the answer is no (removing field circuit power instead of voltage regulator power), but then how do I mitigate against the scenarios above? As always, thanks in advance. -- Andrew Zachar andrew.d.zachar(at)gmail.com ________________________________________________________________________________
Date: Sep 27, 2011
Subject: Position Lights/Strobes
Hi all - I'm researching lighting options for my RV10 project.- I've looked at Ave o Leds, Aero Leds, Whelen, and Kuntzleman.- The Aveo & Aero leds look lik e great products but pricey. The Whelen products also look-nice but again pricey. - I'm leaning towards the Kuntzlemean package that has the 3 position lights (led), with integrated Xe flash tubes, or a home made system which,-when you add all the componets up,-starts to approach the Kuntzleman price of $620.- The homemade system also carries a posible issue with the LED posi tion lights not having the proper 110/140 degree beams. - My goal is to have red, green and white led position lights, and 3 strobes with at least the wing tips strobes synchronized. - Anyone have an opinion on Kuntzlemman products?- Sounds like they've been arounf for about 20 years, but I know nothing about them.- - All opinions welcomed. - Rick #40956 Southampton, Ont ________________________________________________________________________________
Date: Sep 27, 2011
Subject: Re: A refresher question about switching for the
battery and "alternator." At 01:50 PM 9/27/2011, you wrote: Good afternoon, everyone. Okay, so while I won't hurt the alternator by cranking with both sides powered, you shouldn't sit around (with the engine not running) with them both on for fun... Correct. When the alternator field is ON but the shaft not turning, the field draws full-up excitation current that only serves to waste battery energy. Here's the actual question. I see in Figure 11-20 of AEC (page 8-98), the example DC Power master is a DPST switch (same with Z-10/8 and Z-13/8), but some of the other diagrams show a DPDT with OFF-BATT-BATT/ALT. Why the difference? I'd rather use a DPST, but is there a good reason to use the DPDT? If I have a DPST, will pulling the ALT FLD breaker be the same as leaving the ALT side of the split rocker OFF in the few cases I'll be "sitting around listening to the radio?" I think the answer is no (removing field circuit power instead of voltage regulator power), but then how do I mitigate against the scenarios above? What ever means you choose to used for removing field excitation during battery-only ops is up to you. If you opt for crowbar ov protection, then the CB offers a convenient means for accomplishing the task with a simpler switch. You choose. Bob . . . ________________________________________________________________________________
Subject: Re: Position Lights/Strobes
Date: Sep 27, 2011
I got the Aveoflash Powerburst and am very happy with them. They are only $4 00 for the pair at Wicks. http://www.wicksaircraft.com/catalog/product_cat.php/subid=12541/index.htm l Bob Meyers Flying my Sonex N982SX - Building log at http://n982sx.com Sent from my iPad On Sep 27, 2011, at 3:27 PM, Rick Lark wrote: > > Hi all > > I'm researching lighting options for my RV10 project. I've looked at Aveo Leds, Aero Leds, Whelen, and Kuntzleman. The Aveo & Aero leds look like gr eat products but pricey. The Whelen products also look nice but again pricey . > > I'm leaning towards the Kuntzlemean package that has the 3 position lights (led), with integrated Xe flash tubes, or a home made system which, when yo u add all the componets up, starts to approach the Kuntzleman price of $620. The homemade system also carries a posible issue with the LED position lig hts not having the proper 110/140 degree beams. > > My goal is to have red, green and white led position lights, and 3 strobes with at least the wing tips strobes synchronized. > > Anyone have an opinion on Kuntzlemman products? Sounds like they've been a rounf for about 20 years, but I know nothing about them. > > All opinions welcomed. > > Rick > #40956 > Southampton, Ont > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Sep 27, 2011
Hi Rick PITA Noise! I ended up having to put two strobe power supplies in the wingtips instead of one in the fuse. Follow links how I wired to keep noise down. : http://www.europaowners.org/forums/gallery2.php?g2_itemId=31409 Kunzleman not too much a help, just kept reminding me how inexpensive their unit was and insinuating that not all have noise issues. Do a search and you can find others with the exact same noise issues as I had. After talking to Bob, he kept reminding me that strobes should have been designed to not make noise in the first place. Bob offered to help Kunzleman make them less noisy but they were not interested. Twisted power leads to strobe are much better than shielded power leads to strobe. As a matter of fact straight run power leads are better than shielded! Ron Parigoris > > > > > > Hi all > > I'm researching lighting options for my RV10 project. I've looked at Aveo > Leds, Aero Leds, Whelen, and Kuntzleman. The Aveo & Aero leds look like > great products but pricey. The Whelen products also looknice but again > pricey. > > I'm leaning towards the Kuntzlemean package that has the 3 position lights > (led), with integrated Xe flash tubes, or a home made system which,when > you add all the componets up,starts to approach the Kuntzleman price of > $620. The homemade system also carries a posable issue with the LED > position lights not having the proper 110/140 degree beams. > > My goal is to have red, green and white led position lights, and 3 strobes > with at least the wing tips strobes synchronized. > > Anyone have an opinion on Kuntzlemman products? Sounds like they've been > arounf for about 20 years, but I know nothing about them. > > All opinions welcomed. > > Rick > #40956 > Southampton, Ont ________________________________________________________________________________
Date: Sep 27, 2011
The same product is $396 from Spruce. Just depends on where you are for shipping and which vendor you prefer. However, they are not a good choice for the RV-10 which has enclosed wingtips. Aveo does offer an embedded and more powerful version for about double the money. On 9/27/2011 2:22 PM, Bob Meyers wrote: > I got the Aveoflash Powerburst and am very happy with them. They are > only $400 for the pair at Wicks. > > http://www.wicksaircraft.com/catalog/product_cat.php/subid=12541/index.html > > Bob Meyers > > Flying my Sonex N982SX - Building log at http://n982sx.com > > Sent from my iPad > > On Sep 27, 2011, at 3:27 PM, Rick Lark > wrote: > >> Hi all >> I'm researching lighting options for my RV10 project. I've looked at >> Aveo Leds, Aero Leds, Whelen, and Kuntzleman. The Aveo & Aero leds >> look like great products but pricey. The Whelen products also >> look nice but again pricey. >> I'm leaning towards the Kuntzlemean package that has the 3 position >> lights (led), with integrated Xe flash tubes, or a home made system >> which, when you add all the componets up, starts to approach the >> Kuntzleman price of $620. The homemade system also carries a posible >> issue with the LED position lights not having the proper 110/140 >> degree beams. >> My goal is to have red, green and white led position lights, and 3 >> strobes with at least the wing tips strobes synchronized. >> Anyone have an opinion on Kuntzlemman products? Sounds like they've >> been arounf for about 20 years, but I know nothing about them. >> All opinions welcomed. >> Rick >> #40956 >> Southampton, Ont >> >> * >> >> >> * > * > > > * ________________________________________________________________________________
Date: Sep 27, 2011
Kelly, Yes, I got my lists mixed up. I thought I was responding to a fellow Sonex builder on a Sonex list. The lights I highlighted are not for an RV 10. I am very happy with Aveo as a user of one of their products for what that is worth. I promise to pay closer attention next time. Bob Meyers Flying my Sonex N982SX - Building log at http://n982sx.com Sent from my iPad On Sep 27, 2011, at 10:43 PM, Kelly McMullen wrote: > > The same product is $396 from Spruce. Just depends on where you are for shipping and which vendor you prefer. > However, they are not a good choice for the RV-10 which has enclosed wingtips. Aveo does offer an embedded and more powerful version for about double the money. > > On 9/27/2011 2:22 PM, Bob Meyers wrote: >> I got the Aveoflash Powerburst and am very happy with them. They are only $400 for the pair at Wicks. >> >> http://www.wicksaircraft.com/catalog/product_cat.php/subid=12541/index.html >> >> Bob Meyers >> >> Flying my Sonex N982SX - Building log at http://n982sx.com >> >> Sent from my iPad >> >> On Sep 27, 2011, at 3:27 PM, Rick Lark > wrote: >> >>> Hi all >>> I'm researching lighting options for my RV10 project. I've looked at Aveo Leds, Aero Leds, Whelen, and Kuntzleman. The Aveo & Aero leds look like great products but pricey. The Whelen products also look nice but again pricey. >>> I'm leaning towards the Kuntzlemean package that has the 3 position lights (led), with integrated Xe flash tubes, or a home made system which, when you add all the componets up, starts to approach the Kuntzleman price of $620. The homemade system also carries a posible issue with the LED position lights not having the proper 110/140 degree beams. >>> My goal is to have red, green and white led position lights, and 3 strobes with at least the wing tips strobes synchronized. >>> Anyone have an opinion on Kuntzlemman products? Sounds like they've been arounf for about 20 years, but I know nothing about them. >>> All opinions welcomed. >>> Rick >>> #40956 >>> Southampton, Ont >>> >>> * >>> >>> >>> * >> * >> >> >> * > > > > > ________________________________________________________________________________
Date: Sep 28, 2011
G'day Rick, I liked the Aveo range and I already have several of their products, but I wouldn't recommend them to anyone. If first sought sponsorship and the answer was no, but I nevertheless went ahead and bought Aveo products because I liked the gear. I then discovered a broken return wire in my new AveoMaxx landing light module earlier this year. There was no strain relief for the wires, no chafe protection where they passed through the anodised metal body and no beam angle adjustment. There were also a raft of errors and omissions in the advertising for the product itself and they refused to honour the warranty when I said that I removed three ordinary screws holding the lens in place (to see what was wrong). I expected a replacement light because I had already cut my wingtips to suit the larger lights, but they insisted a refund was the only option. I experienced one helpful, constructive person at Aveo USA, but customer service at the decision-level was abysmal and insulting. Cheers, Stu _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Rick Lark Sent: Wednesday, September 28, 2011 6:28 AM Subject: AeroElectric-List: Position Lights/Strobes Hi all I'm researching lighting options for my RV10 project. I've looked at Aveo Leds, Aero Leds, Whelen, and Kuntzleman. The Aveo & Aero leds look like great products but pricey. The Whelen products also look nice but again pricey. I'm leaning towards the Kuntzlemean package that has the 3 position lights (led), with integrated Xe flash tubes, or a home made system which, when you add all the componets up, starts to approach the Kuntzleman price of $620. The homemade system also carries a posible issue with the LED position lights not having the proper 110/140 degree beams. My goal is to have red, green and white led position lights, and 3 strobes with at least the wing tips strobes synchronized. Anyone have an opinion on Kuntzlemman products? Sounds like they've been arounf for about 20 years, but I know nothing about them. All opinions welcomed. Rick #40956 Southampton, Ont ________________________________________________________________________________
Subject: Re: A refresher question about switching for the battery
and "al
From: "tomcostanza" <Tom(at)CostanzaAndAssociates.com>
Date: Sep 28, 2011
I would have thought that starting the engine on with the alternator field powered would load the engine, not the alternator. And with a marginal battery, in cold weather, it might make a difference as to whether the engine started or not. > One of the larger discussions is with reference to the split rocker: "1) Leave the alternator switch OFF BEFORE starting the engine," and "2) Turn the alternator switch ON AFTER the engine is running." Mr. Nuckolls responds to this by pointing out there is "there is no demonstration in the physics of how alternators workthat will support this notion...[that starting the engine with both sides powered somehow overloads the alternator, causing failure.]" Okay. I understand. -------- Clear Skies, Tom Costanza Read this topic online here: http://forums.matronics.com/viewtopic.php?p=353396#353396 ________________________________________________________________________________
Date: Sep 28, 2011
and "alternator."
Thanks for your quick response, Mr. Nuckolls. So I'll need a way to remove excitation current for battery only ops (either crowbar cb or 3-position switch). Makes sense. With one more question, I think I'll have my path. (Whoops! It turned into two!) Knowing that I won't damage anything while cranking with the excitation current there, does a 3-position switch (so I can crank without excitation current) help with cranking ability? (I guess the same question goes for various other electrical equipment/avionics; I know cranking with avionics ON won't hurt the avionics, but will turning electrical equipment off during cranking provide better cranking performance? I think we're talking 200 to 300 amps versus just a couple amps...maybe I have more issues if those few extra amps are making a big difference.) Thanks again. On Tue, Sep 27, 2011 at 4:59 PM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 01:50 PM 9/27/2011, you wrote: > Good afternoon, everyone. > > > > > Okay, so while I won't hurt the alternator by cranking with both sides > powered, you shouldn't sit around (with the engine not running) with them > both on for fun... > > * Correct. When the alternator field is ON but the shaft not > turning, the field draws full-up excitation current that > only serves to waste battery energy. > > * > Here's the actual question. I see in Figure 11-20 of AEC (page 8-98), the > example DC Power master is a DPST switch (same with Z-10/8 and Z-13/8), but > some of the other diagrams show a DPDT with OFF-BATT-BATT/ALT. Why the > difference? > > I'd rather use a DPST, but is there a good reason to use the DPDT? If I > have a DPST, will pulling the ALT FLD breaker be the same as leaving the ALT > side of the split rocker OFF in the few cases I'll be "sitting around > listening to the radio?" I think the answer is no (removing field circuit > power instead of voltage regulator power), but then how do I mitigate > against the scenarios above? > > * What ever means you choose to used for removing > field excitation during battery-only ops is up > to you. If you opt for crowbar ov protection, > then the CB offers a convenient means for accomplishing > the task with a simpler switch. You choose. > > *** > > ** Bob . . . > > * > > * > > -- Andrew Zachar andrew.d.zachar(at)gmail.com ________________________________________________________________________________
Subject:
Date: Sep 28, 2011
From: "Phil Hildebrand" <Philh(at)thepritchardgroup.com>
I have a Lancair ES and am having Transponder issues. Should the ground plane be grounded or does it matter. Philip Hildebrand ________________________________________________________________________________
Date: Sep 28, 2011
Subject: Re: ectric-List:
IIRC the Lancair is not metal-skinned.... The ground-plane should be electrically connected to the shield of the coax - which should also be electrically connected to the ground-side of the electrical system via the radio. -----Original Message----- >From: Phil Hildebrand <Philh(at)thepritchardgroup.com> >Sent: Sep 28, 2011 9:49 AM >To: aeroelectric-list(at)matronics.com >Subject: AeroElectric-List: > > I have a Lancair ES and am having Transponder issues. >Should the ground plane be grounded or does it matter. > > > > > >Philip Hildebrand > ________________________________________________________________________________
Subject: ectric-List:
Date: Sep 28, 2011
Then why do some radio manufacturers require a ground plane of a minimum diameter? If the ground plane was connected to the aircraft ground, size would not matter. (no puns please) Bruce WWW.Glasair.org -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ralph E. Capen Sent: Wednesday, September 28, 2011 10:13 AM Subject: Re: AeroElectric-List: IIRC the Lancair is not metal-skinned.... The ground-plane should be electrically connected to the shield of the coax - which should also be electrically connected to the ground-side of the electrical system via the radio. -----Original Message----- >From: Phil Hildebrand <Philh(at)thepritchardgroup.com> >Sent: Sep 28, 2011 9:49 AM >To: aeroelectric-list(at)matronics.com >Subject: AeroElectric-List: > > I have a Lancair ES and am having Transponder issues. >Should the ground plane be grounded or does it matter. > > > > > >Philip Hildebrand > ________________________________________________________________________________
Subject: Transponder Ground Plane
Date: Sep 28, 2011
The Lancair belly is E glass. What is the proper method of attaching the coax shield to the ground plane. At the present time my BNC connector to the antenna is isolated from the ground plane. Philip Hildebrand, CET TPG The Pritchard Group -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ralph E. Capen Sent: Wednesday, September 28, 2011 9:13 AM Subject: Re: AeroElectric-List: IIRC the Lancair is not metal-skinned.... The ground-plane should be electrically connected to the shield of the coax - which should also be electrically connected to the ground-side of the electrical system via the radio. -----Original Message----- >From: Phil Hildebrand <Philh(at)thepritchardgroup.com> >Sent: Sep 28, 2011 9:49 AM >To: aeroelectric-list(at)matronics.com >Subject: AeroElectric-List: > > I have a Lancair ES and am having Transponder issues. >Should the ground plane be grounded or does it matter. > > > > > >Philip Hildebrand > ________________________________________________________________________________
Date: Sep 28, 2011
The ground plane of minimum diameter provides for the reflection of the RF energy at the antenna - specifically for non metallic airframes. I think there is at least one Berkut out there that is set up this way. In my case, I have my transponder antenna mounted inside my engine cowl pointing downward with an aluminum circle providing the ground plane. It is isolated from physical grounding by the mount and is electrically 'bonded' to the ground system. Bob could probably explain the theory better - I took it in to practice and it works well for me. -----Original Message----- >From: Bruce <BGray(at)glasair.org> >Sent: Sep 28, 2011 10:43 AM >To: aeroelectric-list(at)matronics.com >Subject: RE: AeroElectric-List: > > >Then why do some radio manufacturers require a ground plane of a minimum >diameter? If the ground plane was connected to the aircraft ground, size >would not matter. (no puns please) > >Bruce >WWW.Glasair.org > >-----Original Message----- >From: owner-aeroelectric-list-server(at)matronics.com >[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ralph >E. Capen >Sent: Wednesday, September 28, 2011 10:13 AM >To: aeroelectric-list(at)matronics.com >Subject: Re: AeroElectric-List: > > > >IIRC the Lancair is not metal-skinned.... > >The ground-plane should be electrically connected to the shield of the >coax - which should also be electrically connected to the ground-side of >the electrical system via the radio. > > >-----Original Message----- >>From: Phil Hildebrand <Philh(at)thepritchardgroup.com> >>Sent: Sep 28, 2011 9:49 AM >>To: aeroelectric-list(at)matronics.com >>Subject: AeroElectric-List: >> >> I have a Lancair ES and am having Transponder issues. >>Should the ground plane be grounded or does it matter. >> >> >> >> >> >>Philip Hildebrand >> > > ________________________________________________________________________________
Date: Sep 28, 2011
Subject: Re: Transponder Ground Plane
The coax shield should be attached to the connector thereby physically connecting it to the ground plane - that's how mine is.... -----Original Message----- >From: Phil Hildebrand <Philh(at)thepritchardgroup.com> >Sent: Sep 28, 2011 11:14 AM >To: aeroelectric-list(at)matronics.com >Subject: AeroElectric-List: Transponder Ground Plane > > > The Lancair belly is E glass. What is the proper method of attaching the coax shield to the ground plane. At the present time my BNC connector to the antenna is isolated from the ground plane. > >Philip Hildebrand, CET >TPG The Pritchard Group > > >-----Original Message----- >From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ralph E. Capen >Sent: Wednesday, September 28, 2011 9:13 AM >To: aeroelectric-list(at)matronics.com >Subject: Re: AeroElectric-List: > > >IIRC the Lancair is not metal-skinned.... > >The ground-plane should be electrically connected to the shield of the coax - which should also be electrically connected to the ground-side of the electrical system via the radio. > > >-----Original Message----- >>From: Phil Hildebrand <Philh(at)thepritchardgroup.com> >>Sent: Sep 28, 2011 9:49 AM >>To: aeroelectric-list(at)matronics.com >>Subject: AeroElectric-List: >> >> I have a Lancair ES and am having Transponder issues. >>Should the ground plane be grounded or does it matter. >> >> >> >> >> >>Philip Hildebrand >> > > ________________________________________________________________________________
Date: Sep 28, 2011
I believe that the minimum size of the ground plane is related to the wave length of the radio. John Grosse Bruce wrote: > --> AeroElectric-List message posted by: "Bruce" > > Then why do some radio manufacturers require a ground plane of a minimum > diameter? If the ground plane was connected to the aircraft ground, size > would not matter. (no puns please) > > Bruce > WWW.Glasair.org ________________________________________________________________________________
Date: Sep 28, 2011
I would attach a jumper wire to the to the shield (preferably under the crimp) and then attach that to the ground plane with a screw or bolt. John Grosse Phil Hildebrand wrote: > --> AeroElectric-List message posted by: "Phil Hildebrand" > > The Lancair belly is E glass. What is the proper method of attaching the coax shield to the ground plane. At the present time my BNC connector to the antenna is isolated from the ground plane. > > Philip Hildebrand, CET > TPG The Pritchard Group > ________________________________________________________________________________
Date: Sep 28, 2011
Then why does my WX-500 require a 12 inch ground plane? It only receives RF. Bruce WWW.Glasair.org -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ralph E. Capen Sent: Wednesday, September 28, 2011 11:31 AM Subject: RE: AeroElectric-List: The ground plane of minimum diameter provides for the reflection of the RF energy at the antenna - specifically for non metallic airframes. I think there is at least one Berkut out there that is set up this way. In my case, I have my transponder antenna mounted inside my engine cowl pointing downward with an aluminum circle providing the ground plane. It is isolated from physical grounding by the mount and is electrically 'bonded' to the ground system. Bob could probably explain the theory better - I took it in to practice and it works well for me. -----Original Message----- >From: Bruce <BGray(at)glasair.org> >Sent: Sep 28, 2011 10:43 AM >To: aeroelectric-list(at)matronics.com >Subject: RE: AeroElectric-List: > > >Then why do some radio manufacturers require a ground plane of a minimum >diameter? If the ground plane was connected to the aircraft ground, size >would not matter. (no puns please) > >Bruce >WWW.Glasair.org > >-----Original Message----- >From: owner-aeroelectric-list-server(at)matronics.com >[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ralph >E. Capen >Sent: Wednesday, September 28, 2011 10:13 AM >To: aeroelectric-list(at)matronics.com >Subject: Re: AeroElectric-List: > > > >IIRC the Lancair is not metal-skinned.... > >The ground-plane should be electrically connected to the shield of the >coax - which should also be electrically connected to the ground-side of >the electrical system via the radio. > > >-----Original Message----- >>From: Phil Hildebrand <Philh(at)thepritchardgroup.com> >>Sent: Sep 28, 2011 9:49 AM >>To: aeroelectric-list(at)matronics.com >>Subject: AeroElectric-List: >> >> I have a Lancair ES and am having Transponder issues. >>Should the ground plane be grounded or does it matter. >> >> >> >> >> >>Philip Hildebrand >> > > ________________________________________________________________________________
Date: Sep 28, 2011
Try it without the groundplane and you will find out why you need the thing... Met vriendelijke groet en verzonden vanaf de bijna illegale Samsung Galaxy S2, Eric Tiethoff. Op 28 sep. 2011 18:36 schreef "Bruce" het volgende: > > Then why does my WX-500 require a 12 inch ground plane? It only receives > RF. > > Bruce > WWW.Glasair.org > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ralph > E. Capen > Sent: Wednesday, September 28, 2011 11:31 AM > To: aeroelectric-list(at)matronics.com > Subject: RE: AeroElectric-List: > > > > The ground plane of minimum diameter provides for the reflection of the > RF energy at the antenna - specifically for non metallic airframes. I > think there is at least one Berkut out there that is set up this way. > > In my case, I have my transponder antenna mounted inside my engine cowl > pointing downward with an aluminum circle providing the ground plane. > It is isolated from physical grounding by the mount and is electrically > 'bonded' to the ground system. > > Bob could probably explain the theory better - I took it in to practice > and it works well for me. > > > -----Original Message----- >>From: Bruce <BGray(at)glasair.org> >>Sent: Sep 28, 2011 10:43 AM >>To: aeroelectric-list(at)matronics.com >>Subject: RE: AeroElectric-List: >> >> >>Then why do some radio manufacturers require a ground plane of a > minimum >>diameter? If the ground plane was connected to the aircraft ground, > size >>would not matter. (no puns please) >> >>Bruce >>WWW.Glasair.org >> >>-----Original Message----- >>From: owner-aeroelectric-list-server(at)matronics.com >>[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of > Ralph >>E. Capen >>Sent: Wednesday, September 28, 2011 10:13 AM >>To: aeroelectric-list(at)matronics.com >>Subject: Re: AeroElectric-List: >> >> >> >>IIRC the Lancair is not metal-skinned.... >> >>The ground-plane should be electrically connected to the shield of the >>coax - which should also be electrically connected to the ground-side > of >>the electrical system via the radio. >> >> >>-----Original Message----- >>>From: Phil Hildebrand <Philh(at)thepritchardgroup.com> >>>Sent: Sep 28, 2011 9:49 AM >>>To: aeroelectric-list(at)matronics.com >>>Subject: AeroElectric-List: >>> >>> I have a Lancair ES and am having Transponder issues. >>>Should the ground plane be grounded or does it matter. >>> >>> >>> >>> >>> >>>Philip Hildebrand >>> >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Sep 28, 2011
Not the expert on the theory - but I think RF exhibits the same behaviour relative to the antenna regardless of being transmitted or received. -----Original Message----- >From: Bruce <BGray(at)glasair.org> >Sent: Sep 28, 2011 12:24 PM >To: aeroelectric-list(at)matronics.com >Subject: RE: AeroElectric-List: > > >Then why does my WX-500 require a 12 inch ground plane? It only receives >RF. > >Bruce >WWW.Glasair.org > >-----Original Message----- >From: owner-aeroelectric-list-server(at)matronics.com >[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ralph >E. Capen >Sent: Wednesday, September 28, 2011 11:31 AM >To: aeroelectric-list(at)matronics.com >Subject: RE: AeroElectric-List: > > > >The ground plane of minimum diameter provides for the reflection of the >RF energy at the antenna - specifically for non metallic airframes. I >think there is at least one Berkut out there that is set up this way. > >In my case, I have my transponder antenna mounted inside my engine cowl >pointing downward with an aluminum circle providing the ground plane. >It is isolated from physical grounding by the mount and is electrically >'bonded' to the ground system. > >Bob could probably explain the theory better - I took it in to practice >and it works well for me. > > >-----Original Message----- >>From: Bruce <BGray(at)glasair.org> >>Sent: Sep 28, 2011 10:43 AM >>To: aeroelectric-list(at)matronics.com >>Subject: RE: AeroElectric-List: >> >> >>Then why do some radio manufacturers require a ground plane of a >minimum >>diameter? If the ground plane was connected to the aircraft ground, >size >>would not matter. (no puns please) >> >>Bruce >>WWW.Glasair.org >> >>-----Original Message----- >>From: owner-aeroelectric-list-server(at)matronics.com >>[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of >Ralph >>E. Capen >>Sent: Wednesday, September 28, 2011 10:13 AM >>To: aeroelectric-list(at)matronics.com >>Subject: Re: AeroElectric-List: >> >> >> >>IIRC the Lancair is not metal-skinned.... >> >>The ground-plane should be electrically connected to the shield of the >>coax - which should also be electrically connected to the ground-side >of >>the electrical system via the radio. >> >> >>-----Original Message----- >>>From: Phil Hildebrand <Philh(at)thepritchardgroup.com> >>>Sent: Sep 28, 2011 9:49 AM >>>To: aeroelectric-list(at)matronics.com >>>Subject: AeroElectric-List: >>> >>> I have a Lancair ES and am having Transponder issues. >>>Should the ground plane be grounded or does it matter. >>> >>> >>> >>> >>> >>>Philip Hildebrand >>> >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Subject: 300mA AA NiMh charger design needed
Date: Sep 28, 2011
Hi Group I need a design for an easy to build, low parts count and inexpensive constant current circuit to charge 3,000mA AA NiMh batteries (~300mA rate C/10 for 14 to 16 hours) from a 12 volt lead acid battery that could have the input voltage ranging anywhere from ~ 12.2 to 14.5volts. I would prefer to have as many cells in series as possible when charging. I have the charge stick figured out to hold cells in series by using 1/2" PVC water pipe that's a pretty good fit for AA cells. Thanking you in advance. Ron Parigoris BTW I just ordered 50 AA NiMh supposedly 3,000mA batteries from E-bay including shipping for $25.85 (~$.52 each) Buy it now. I will report on self discharge rate, ability to dump amps and capacity once I get them. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=353455#353455 ________________________________________________________________________________
Date: Sep 28, 2011
the battery and "al At 05:49 AM 9/28/2011, you wrote: > > >I would have thought that starting the engine on with the alternator >field powered would load the engine, not the alternator. Don't think anyone said it loaded the alternator. It's the battery that has to supply 3 or so amps alternator field excitation when the alternator is not spinning. Hence it is the battery that is 'loaded'. > And with a marginal battery, in cold weather, it might make a > difference as to whether the engine started or not. The mechanical 'load' is not zero but it's so tiny a percentage of what's necessary to crank the engine that adding it to the mix is insignificant. Bob . . . ________________________________________________________________________________
Date: Sep 28, 2011
battery and "alternator." >Knowing that I won't damage anything while cranking with the >excitation current there, does a 3-position switch (so I can crank >without excitation current) help with cranking ability? Yes . . . but by so small a value as to make it unobservable without precision measurements. > (I guess the same question goes for various other electrical > equipment/avionics; I know cranking with avionics ON won't hurt the > avionics, but will turning electrical equipment off during cranking > provide better cranking performance? I think we're talking 200 to > 300 amps versus just a couple amps...maybe I have more issues if > those few extra amps are making a big difference.) A few percent reduction in battery load for cranking will have no significant impact on how well the engine starts. Bob . . . ________________________________________________________________________________
Date: Sep 28, 2011
Subject: Re:
At 08:49 AM 9/28/2011, you wrote: > I have a Lancair ES and am having Transponder > issues. Should the ground plane be grounded or does it matter. > The ground plane is a ground for the antenna. No other grounds are needed. Bob . . . ________________________________________________________________________________
Date: Sep 28, 2011
At 09:13 AM 9/28/2011, you wrote: > > >IIRC the Lancair is not metal-skinned.... > >The ground-plane should be electrically connected to the shield of >the coax - which should also be electrically connected to the >ground-side of the electrical system via the radio. I think he was asking if the ground plane needed some extra conductor from the metal over to the electrical system ground. There is no value in adding such wires from an RF perspective. I've seen such bonding conductors added for lightning strike issues on composite aircraft. Bob . . . ________________________________________________________________________________
Date: Sep 28, 2011
At 09:43 AM 9/28/2011, you wrote: > >Then why do some radio manufacturers require a ground plane of a minimum >diameter? If the ground plane was connected to the aircraft ground, size >would not matter. (no puns please) The ideal ground plane is an infinite number of radial conductors having the same length as the antenna itself. In other words, a 22" comm antenna would ideally sit on a 44" diameter disk. The 2.6" transponder antenna sits on a 5.2" disk. Since the ideal, 'tuned' disk is impractical for most aircraft installations, the next best thing is to have 4-8, 22" radials fan out from the base of the comm antenna and conform to the inside surface of the aircraft. Aircraft power ground and antenna RF ground are completely separate, unrelated systems. See chapter on antennas and feedlines in the 'Connection. Bob . . . ________________________________________________________________________________
Date: Sep 28, 2011
At 10:14 AM 9/28/2011, you wrote: > > > The Lancair belly is E glass. What is the proper method of > attaching the coax shield to the ground plane. At the present time > my BNC connector to the antenna is isolated from the ground plane. What kind of antenna? If it's like this http://aeroelectric.com/Pictures/Antenna/Transponder_1.jpg or a shark fin style antenna, then the act of mounting the antenna to the ground plane takes care of the connection between BNC connector shell and the ground plane. Bob . . . ________________________________________________________________________________
Date: Sep 28, 2011
Subject: Re: 300mA AA NiMh charger design needed
At 03:10 PM 9/28/2011, you wrote: > > >Hi Group > >I need a design for an easy to build, low parts count and >inexpensive constant current circuit to charge 3,000mA AA NiMh >batteries (~300mA rate C/10 for 14 to 16 hours) from a 12 volt lead >acid battery that could have the input voltage ranging anywhere from >~ 12.2 to 14.5volts. > >I would prefer to have as many cells in series as possible when charging. The simplest is an LM317 wired as shown here http://diyparadise.com/yhlmccs.html The resistor would be 1.25/.3 or 39 ohms. The CC Gen will need at least 3 volts of 'headroom' so 12.5 - 3.0 leaves 9.5 volts worth of cells. This means you can charge 6 cells in series. This charge rate will heat the cells. Plastic pipe may not be the best holder for allowing the string of cells to reject heat. If you like, I could take a few of those cells and discharge them on the system I used to produce this article: http://aeroelectric.com/articles/AA_Bat_Test.pdf Bob . . . ________________________________________________________________________________
Date: Sep 29, 2011
Hi Bob Thx. for the reply. ** First off if you don't mind I can send you some AA NiMh cells to test once they arrive. How many would you like for testing? ** I like the simplicity of the circuit you pointed me to. The first question is would Allied part number 248-0718 LM317P be OK to use? This is not a National Semiconductor part, I like the TO220 style and didn't see one offered by National. ** Instead of a LM317, would Allied 288-0963 LM1117T-ADJ Low dropout be an OK choice with only a 1.2 volt drop out? This should allow a cell count increase? ** You mention that putting cells in a PVC plastic pipe may not be a good idea because it can aid in heat build up. You mention that this charger will heat the cells. I am questioning this because in my past experience charging NiMh cells at a one tenth capacity rate for 14 to 16 hours doesn't seem to develop too much heat. Has your experience proved in the past that a 1/10C charge rate for 14 to 16 hours warms up the cells? The cells are AA with a 3,000mA capacity, so 300mAs is 1/10 capacity. ** I would love for this simple circuit to accomplish the task of providing a constant 300mA charge rate. I don't have too much experience working with LM317s. I can kind of see where if you have a constant supply voltage and a constant load how the circuit should be OK. In my application where the supply voltage may be as low as 12.2 volts, or if the motor is running then up to 14.5 volts do you think it will still maintain a constant 300mAs? Also we know that when NiMh cells when discharged have a lower resistance. As the cells begin to charge, the resistance begins to go up thus you need to begin increasing the voltage in order to maintain a constant 300ma charge rate. Then when the cells become fully charged the resistance begins to go down again, thus you need to begin lowering the voltage to maintain a constant current. If you put too much current into a fully charged cell this is where you can get them warm or downright hot (IE 1C or more). Anyway do you think this circuit could do an OK job of maintaining 300mA charge rate with input voltage fluctuating between 12.2 and 14.5 volts, and the NiMh cells changing their internal resistance? ** I kinda had an eyeball on this circuit #2: http://talkingelectronics.com/projects/ChargingNiMH/ChargingNiMH.html But they are using a constant current 500mA charger that is kinda regulated (because of transformer coupling?) and wasn't sure how it would work with a source that could provide a gazillion mAs of current. I was thinking of trying both the regulators I mentioned above and since Allied doesn't sell BC338 NPN transistors (Digikey BC338ND), I was thinking of giving a Allied TIP122G 568-0402 a try. I would rather keep it simple, but if just the regulator and resistor proves unacceptable results, do you think this would work OK? Thx. Ron Parigoris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=353497#353497 ________________________________________________________________________________
Date: Sep 29, 2011
At 04:13 AM 9/29/2011, you wrote: Hi Bob Thx. for the reply. ** First off if you don't mind I can send you some AA NiMh cells to test once they arrive. How many would you like for testing? Four. No hurry, that fixture is packed away somewhere from the move. I'll have to dig it out and dust it off. I've been thinking about repeating some of the tests done earlier and adding a few more 'house brands' of AA-alkalines to the study. But I'm up to my eyeballs in a project for Hawker-Beech and it will be a couple months before I can 'play'. ** I like the simplicity of the circuit you pointed me to. The first question is would Allied part number 248-0718 LM317P be OK to use? This is not a National Semiconductor part, I like the TO220 style and didn't see one offered by National. ** Instead of a LM317, would Allied 288-0963 LM1117T-ADJ Low dropout be an OK choice with only a 1.2 volt drop out? This should allow a cell count increase? ANY of the 117/217/317 series parts will do. You just need to make sure it's heat-sinked well enough to dissipate the power. The low dropout part is only a portion of the voltage drop . . . the 39 ohm resistor has 1.25 volts across it too which boosts your head-room requirements. ** You mention that putting cells in a PVC plastic pipe may not be a good idea because it can aid in heat build up. You mention that this charger will heat the cells. I am questioning this because in my past experience charging NiMh cells at a one tenth capacity rate for 14 to 16 hours doesn't seem to develop too much heat. Has your experience proved in the past that a 1/10C charge rate for 14 to 16 hours warms up the cells? The cells are AA with a 3,000mA capacity, so 300mAs is 1/10 capacity. 'Too much heat' is non-quantified. Further, small surface area parts wrapped in an low heat transfer media will experience a greater temperature rise than when operated in still air. Just a point to ponder and explore. ** I would love for this simple circuit to accomplish the task of providing a constant 300mA charge rate. I don't have too much experience working with LM317s. I can kind of see where if you have a constant supply voltage and a constant load how the circuit should be OK. In my application where the supply voltage may be as low as 12.2 volts, or if the motor is running then up to 14.5 volts do you think it will still maintain a constant 300mAs? The LMx17 series devices are a fixed calibration voltage regulator with a factory adjustment of 1.25 volts. Higher voltages can be achieved by addition of the voltage divider shown in the data sheets. But when wired with the single resistor as suggested, the device works to maintain a constant voltage of 1.25 volts across the series resistor. 1.25 ohms yields 1 amp, 125 ohms yields 10 milliamps, etc. So yes, this is a true constant current generator with an upper limit equal to the design point. It will fall off only if the device looses operating head-room discussed above. Also we know that when NiMh cells when discharged have a lower resistance. As the cells begin to charge, the resistance begins to go up thus you need to begin increasing the voltage in order to maintain a constant 300ma charge rate. Then when the cells become fully charged the resistance begins to go down again, thus you need to begin lowering the voltage to maintain a constant current. If you put too much current into a fully charged cell this is where you can get them warm or downright hot (IE 1C or more). Anyway do you think this circuit could do an OK job of maintaining 300mA charge rate with input voltage fluctuating between 12.2 and 14.5 volts, and the NiMh cells changing their internal resistance? Absolutely. ** I kinda had an eyeball on this circuit #2: http://talkingelectronics.com/projects/ChargingNiMH/ChargingNiMH.html But they are using a constant current 500mA charger that is kinda regulated (because of transformer coupling?) and wasn't sure how it would work with a source that could provide a gazillion mAs of current. The circuit depicted are variations on a theme and all will probably function as advertised. I was thinking of trying both the regulators I mentioned above and since Allied doesn't sell BC338 NPN transistors (Digikey BC338ND), I was thinking of giving a Allied TIP122G 568-0402 a try. I would rather keep it simple, but if just the regulator and resistor proves unacceptable results, do you think this would work OK? Yes. The transistor style is not critical. Go get an LM317 and TIP31 at Radio Shack and do the experiments. LM317 http://www.radioshack.com/product/index.jsp?productId 62601&numProdsPerPage=60 TIP31 http://www.radioshack.com/product/index.jsp?productId 62610&numProdsPerPage=60 This is the simplest approach. If you want something 'fancier' with lower heat dissipation, some sort of active constant current generator like the LED drivers we offer https://matronics.com/aeroelectric/Catalog/AEC/9051/9051-700A.pdf can be used. With a single resistor to adjust output current, you can set your charging level at any value up to 1000 mA. Further, this particular device has a boost output capability. I think it would charge a longer string of cells. Bob . . . ________________________________________________________________________________
Subject: Re: Tachometer Generator Wiring
Date: Sep 29, 2011
To Bob and All, At my age, I know it is only a matter of time before I forget to latch the canopy before takeoff on a hot sunny day. I have learned from the mistakes of others and will fly the plane and latch the canopy after landing. But I would rather not forget to latch the canopy. I want to install an audio and visual alarm that will only go off when the canopy is unlatched AND the engine is at takeoff RPM. The easy part of the project will be installing a limit switch on the canopy latch. My plan is to use a PIC12F509 microprocessor that will monitor the limit switch and also count the engine RPM. There is a tachometer coil on the engine that sends an AC signal to the Dynon D-180 through a 30K resistor. I want to tap into that signal for my project but am worried about loading down the circuit and affecting the Dynon tach readout. My first question is, can the tach signal be fed directly into a microprocessor input or should I use some type of buffer? If a buffer circuit is needed, can I use Bob's transistor squaring circuit above or will it load down the circuit to the Dynon? I found this circuit on the internet: http://www.redcircuits.com//Page17.htm If I used that circuit, I would eliminate the voltage doubler components (C1, C2, D1, D2) and power the Hex Inverter from a separate supply. Using an op-amp or FET are possibilities if I could find a schematic. I am open to any comments or suggestions. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=353522#353522 ________________________________________________________________________________
Date: Sep 29, 2011
What about using a second limit switch hooked up to your throttle lever/knob? That might be simpler... On Thu, Sep 29, 2011 at 12:01 PM, user9253 wrote: > > > > To Bob and All, > At my age, I know it is only a matter of time before I forget to latch the > canopy before takeoff on a hot sunny day. I have learned from the mistakes > of others and will fly the plane and latch the canopy after landing. But I > would rather not forget to latch the canopy. I want to install an audio and > visual alarm that will only go off when the canopy is unlatched AND the > engine is at takeoff RPM. The easy part of the project will be installing a > limit switch on the canopy latch. My plan is to use a PIC12F509 > microprocessor that will monitor the limit switch and also count the engine > RPM. There is a tachometer coil on the engine that sends an AC signal to > the Dynon D-180 through a 30K resistor. I want to tap into that signal for > my project but am worried about loading down the circuit and affecting the > Dynon tach readout. My first question is, can the tach signal be fed > directly into a microprocessor input or should I use some type of buffer? > If a buffer circuit is ne! > eded, can I use Bob's transistor squaring circuit above or will it load > down the circuit to the Dynon? > I found this circuit on the internet: > http://www.redcircuits.com//Page17.htm > If I used that circuit, I would eliminate the voltage doubler components > (C1, C2, D1, D2) and power the Hex Inverter from a separate supply. Using > an op-amp or FET are possibilities if I could find a schematic. I am open > to any comments or suggestions. > Joe > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=353522#353522 > > -- Andrew Zachar andrew.d.zachar(at)gmail.com ________________________________________________________________________________
From: Bob McCallum <robert.mccallum2(at)sympatico.ca>
Date: Sep 29, 2011
Joe=3B Another simple solution would be a second limit switch in series with the o ne on the latch attached to the throttle in such a way that at takeoff powe r setting it closes and if the one on the latch is also closed (latch open) then the alarms sound. Bob McC > Subject: AeroElectric-List: Re: Tachometer Generator Wiring > From: fran4sew(at)banyanol.com > Date: Thu=2C 29 Sep 2011 09:01:29 -0700 > To: aeroelectric-list(at)matronics.com > m> > > To Bob and All=2C > At my age=2C I know it is only a matter of time before I forget to latch the canopy before takeoff on a hot sunny day. I have learned from the mist akes of others and will fly the plane and latch the canopy after landing. But I would rather not forget to latch the canopy. I want to install an au dio and visual alarm that will only go off when the canopy is unlatched AND the engine is at takeoff RPM. The easy part of the project will be instal ling a limit switch on the canopy latch. My plan is to use a PIC12F509 mic roprocessor that will monitor the limit switch and also count the engine RP M. There is a tachometer coil on the engine that sends an AC signal to the Dynon D-180 through a 30K resistor. I want to tap into that signal for my project but am worried about loading down the circuit and affecting the Dy non tach readout. My first question is=2C can the tach signal be fed direc tly into a microprocessor input or should I use some type of buffer? If a buffer circuit is ne! > eded=2C can I use Bob's transistor squaring circuit above or will it loa d down the circuit to the Dynon? > I found this circuit on the internet: http://www.redcircuits.com//Page 17.htm > If I used that circuit=2C I would eliminate the voltage doubler component s (C1=2C C2=2C D1=2C D2) and power the Hex Inverter from a separate supply . Using an op-amp or FET are possibilities if I could find a schematic. I am open to any comments or suggestions. > Joe > > -------- > Joe Gores > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=353522#353522 > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Sep 29, 2011
Thanks Bob McC & Andrew for the throttle switch ideas. Trouble is, I can not think of any way to install a switch on the throttle knob. There is a knurled locking disk in the way. I could install a limit switch on the other end of the throttle linkage at the carburetor. But that will require fabricating some type of bracket to hold the switch and figuring out how to mount it to the engine without interfering with the throttle operation. And the wiring and switch will be subject to heat and vibration. I would rather monitor the RPM electronically because making electronic circuits is fun for me. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=353531#353531 ________________________________________________________________________________
Subject: Short in E-Bus Feed Circuit?
Date: Sep 29, 2011
Situation - I am using Z-12. I have a diode, which tests ok, between the main buss and the e-buss. I have the e-bus wired to a switch and then to the battery bus per the diagram. For the wire from the e-bus to the switch, with the switch in the off position, I detect no short to ground. Same for the wire from the switch to the e-bus. With the switch on I blow the fuse (10amps fuse with no load on the e-bus). If I detach the wire from the e-bus to the diode between the e-buss and the main bus, the fuse remains intact. It appears that the problem is with this circuit, yet the diode tests ok. What am I missing? (All wiring has been triple checked to conforms with z-12. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=353533#353533 ________________________________________________________________________________
Date: Sep 29, 2011
Joe, just a thought... How about having the canopy warning come on at run-up RPM rather than take-off RPM. I'd think it'd be best to pick this up before taking the runway. Gerry -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of user9253 Sent: September 29, 2011 10:01 AM Subject: AeroElectric-List: Re: Tachometer Generator Wiring To Bob and All, At my age, I know it is only a matter of time before I forget to latch the canopy before takeoff on a hot sunny day. I have learned from the mistakes of others and will fly the plane and latch the canopy after landing. But I would rather not forget to latch the canopy. I want to install an audio and visual alarm that will only go off when the canopy is unlatched AND the engine is at takeoff RPM. The easy part of the project will be installing a limit switch on the canopy latch. My plan is to use a PIC12F509 microprocessor that will monitor the limit switch and also count the engine RPM. There is a tachometer coil on the engine that sends an AC signal to the Dynon D-180 through a 30K resistor. I want to tap into that signal for my project but am worried about loading down the circuit and affecting the Dynon tach readout. My first question is, can the tach signal be fed directly into a microprocessor input or should I use some type of buffer? If a buffer circuit is ne! eded, can I use Bob's transistor squaring circuit above or will it load down the circuit to the Dynon? I found this circuit on the internet: http://www.redcircuits.com//Page17.htm If I used that circuit, I would eliminate the voltage doubler components (C1, C2, D1, D2) and power the Hex Inverter from a separate supply. Using an op-amp or FET are possibilities if I could find a schematic. I am open to any comments or suggestions. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=353522#353522 ________________________________________________________________________________
Date: Sep 29, 2011
> How about having the canopy warning come on at run-up RPM rather than > take-off RPM. Gerry, That is a good idea. I could get into the habit of latching the canopy before run-up. In the event that the takeoff is delayed and I unlatch the canopy, the alarm will still go off on the takeoff roll, but at a lower RPM. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=353560#353560 ________________________________________________________________________________
Date: Sep 29, 2011
At 11:01 AM 9/29/2011, you wrote: > >To Bob and All, >At my age, I know it is only a matter of time before I forget to >latch the canopy before takeoff on a hot sunny day.My plan is to use >a PIC12F509 microprocessor that will monitor the limit switch and >also count the engine RPM. Is this a Dynon sensor? Call the factory and see what the characteristics of this signal are. It may already be a 5 or 12v square wave. If so, you can tie it to a PIC input through a suitable series resistor, a capacitor and perhaps a clamp diode. Use one of edge sensitive inputs. But the first question to answer is what does the signal look like? If you can run the engine now, the a 'scope would get you this information too. I have a little "do everything" board and enclosure that might be suited to your task. See: http://aeroelectric.com/Pictures/Schematics/Do-Much_Board.pdf http://www.aeroelectric.com/Catalog/AEC/9011/A15_Package.jpg Depending on what parts are installed on the board, what parts are left off, and what code goes into the 8-pin PIC, you can do a whole lot of neat things. Bob . . . ________________________________________________________________________________
Date: Sep 29, 2011
From: "Richard E. Tasker" <retasker(at)optonline.net>
Bob, your calculations are off by a factor of ten relative to the resistor needed to get 300 mA. The 317 series has a reference voltage of 1.25V as you noted. But to get 300 mA you would need 1.25V/0.3A = 4.17ohms. A value of 3.9 ohms is the closest 5% resistor value and it would give you 320 mA - likely close enough. You would need at least a 1/2 W resistor for this application and a 1W would keep the temperature rise in the resistor more reasonable. Other than that everything else you say is fine. It should be noted that using a charger like this is fine as long as one removes it shortly after the batteries are fully charged. Otherwise, the overcharging will shorten their useful lives. Dick Tasker Robert L. Nuckolls, III wrote: > > At 03:10 PM 9/28/2011, you wrote: >> >> Hi Group >> >> I need a design for an easy to build, low parts count and inexpensive constant current circuit to charge 3,000mA AA NiMh batteries (~300mA rate C/10 for 14 to 16 hours) from a 12 volt lead acid >> battery that could have the input voltage ranging anywhere from ~ 12.2 to 14.5volts. >> >> I would prefer to have as many cells in series as possible when charging. > > The simplest is an LM317 wired as shown here > > http://diyparadise.com/yhlmccs.html > > The resistor would be 1.25/.3 or 39 ohms. > The CC Gen will need at least 3 volts > of 'headroom' so 12.5 - 3.0 leaves > 9.5 volts worth of cells. This means > you can charge 6 cells in series. > > This charge rate will heat the cells. > Plastic pipe may not be the best holder > for allowing the string of cells to > reject heat. > > If you like, I could take a few of those > cells and discharge them on the system I > used to produce this article: > > http://aeroelectric.com/articles/AA_Bat_Test.pdf > > > Bob . . . > > -- Please Note: No trees were destroyed in the sending of this message. We do concede, however, that a significant number of electrons may have been temporarily inconvenienced. -- ________________________________________________________________________________
From: "ROGER & JEAN CURTIS" <mrspudandcompany(at)verizon.net>
Date: Sep 30, 2011
I have a little "do everything" board and enclosure that might be suited to your task. See: http://aeroelectric.com/Pictures/Schematics/Do-Much_Board.pdf http://www.aeroelectric.com/Catalog/AEC/9011/A15_Package.jpg Depending on what parts are installed on the board, what parts are left off, and what code goes into the 8-pin PIC, you can do a whole lot of neat things. Bob . . . I noticed that this was just posted yesterday on your website. Is there any documentation available? What things do you anticipate it to be used for? Roger ________________________________________________________________________________
Date: Sep 30, 2011
At 10:38 PM 9/29/2011, you wrote: > > >Bob, your calculations are off by a factor of ten relative to the >resistor needed to get 300 mA. > >The 317 series has a reference voltage of 1.25V as you noted. But >to get 300 mA you would need 1.25V/0.3A = 4.17ohms. A value of 3.9 >ohms is the closest 5% resistor value and it would give you 320 mA - >likely close enough. You would need at least a 1/2 W resistor for >this application and a 1W would keep the temperature rise in the >resistor more reasonable. > >Other than that everything else you say is fine. > >It should be noted that using a charger like this is fine as long as >one removes it shortly after the batteries are fully >charged. Otherwise, the overcharging will shorten their useful lives. Yes! Thank you my friend! Bob . . . ________________________________________________________________________________
Date: Sep 30, 2011
> > I noticed that this was just posted yesterday on your >website. Is there any documentation available? What things do you >anticipate it to be used for? It's the core board for about a dozen different products with the notion of having 90% common bill of materials and differing only by what software is installed. AEC9011 is but one example. > Roger > > Bob . . . ________________________________________________________________________________
Date: Sep 30, 2011
Thanks for the response Bob N. This is an RV-12. The RPM sensor is part of the Rotax 912 engine. The tach trigger coil sends a small AC voltage signal to the tach once every revolution of the crankshaft, according to page 8 of this document: http://flymall.org/aircraft/docs/FAQs-on-Rotax.pdf I do not have a portable scope. But my Fluke meter shows an AC voltage. Does your "do everything" board come with ASM code for the various functions or do we have to write our own? Thanks, Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=353638#353638 ________________________________________________________________________________
Subject: Re: Short in E-Bus Feed Circuit?
Date: Sep 30, 2011
It sounds to me that the polarity of the diode is reversed. Have you double checked that? Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=353644#353644 ________________________________________________________________________________
Date: Sep 30, 2011
It turns out that the rectifier diode was defective. I probable shorted it out or something as I was installing and testing wiring over the past several months. At one point it worked and I thought that I checked it yesterday. I ran down to my local electronics parts store and pick up a replacement and everything checks out now. John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=353653#353653 ________________________________________________________________________________
Subject: Re: AeroLed landing lights not working with wig wag
relay
Date: Oct 01, 2011
Hi Bob, I received the updated wiring diagram from B&C that has the 2W 75 ohm resister across the light terminals. I gave it a try and had the same result. Any idea what is going on? Are the Aeroled lights different than the Whelens I saw in the picture? -------- Thanks Read this topic online here: http://forums.matronics.com/viewtopic.php?p=353692#353692 ________________________________________________________________________________
Date: Oct 01, 2011
Subject: Aero LED'S
I have 2 friends that have installed the new Aero Led Nav and strobes, and both have noise in the headset at all times, even with the strobes turned off. Has anyone else experienced this? I'm trying to trouble shoot this, and don't have a clue. ________________________________________________________________________________
Date: Oct 01, 2011
wag relay At 08:34 AM 10/1/2011, you wrote: > >Hi Bob, > >I received the updated wiring diagram from B&C that has the 2W 75 >ohm resister across the light terminals. I gave it a try and had the >same result. Any idea what is going on? Are the Aeroled lights >different than the Whelens I saw in the picture? I can't imagine how they would be different in any significant way. You can ship your lights to me and I can see. Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Go ahead, make my day . . . > < show me where I'm wrong. > ================================ ________________________________________________________________________________
Date: Oct 01, 2011
Subject: Re: Aero LED'S
At 09:17 AM 10/1/2011, you wrote: > > >I have 2 friends that have installed the new Aero Led Nav and >strobes, and both have noise in the headset at all times, even with >the strobes turned off. Has anyone else experienced this? I'm trying >to trouble shoot this, and don't have a clue. Are these products qualified for type certificated aircraft . . . i.e. are there STC's for installation on factory machines? Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Go ahead, make my day . . . > < show me where I'm wrong. > ================================ ________________________________________________________________________________
Date: Oct 01, 2011
At 09:17 AM 10/1/2011, you wrote: > > >I have 2 friends that have installed the new Aero Led Nav and >strobes, and both have noise in the headset at all times, even with >the strobes turned off. Has anyone else experienced this? I'm trying >to trouble shoot this, and don't have a clue. Do I presume correctly that the noise happens with the position lights on, strobes off but the noise disappears with the position lights off? Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Go ahead, make my day . . . > < show me where I'm wrong. > ================================ ________________________________________________________________________________
Date: Oct 02, 2011
At 11:35 AM 9/30/2011, you wrote: > >Thanks for the response Bob N. >This is an RV-12. The RPM sensor is part of the Rotax 912 >engine. The tach trigger coil sends a small AC voltage signal to >the tach once every revolution of the crankshaft, according to page >8 of this document: http://flymall.org/aircraft/docs/FAQs-on-Rotax.pdf >I do not have a portable scope. But my Fluke meter shows an AC voltage. Hmmmm . . . once per revolution makes for a challenging tachometer design. We still need to know if the transducer is a hall effect device or a inductive pickup. In any case, the output is a very low duty cycle pulse. At 5500 cruise you'll have 91 Hz tach signals the drop to about 1/5th that for idle or 18 Hz. It would be very helpful to know the style of transducer along with the amplitude and duration of output pulse. >Does your "do everything" board come with ASM code for the various >functions or do we have to write our own? You gotta do your own code and your own components selection tailored to the task. Not all components shown in the schematic are installed together for a single project. But with the layout shown, values of parts put in and parts left off offer a huge combination of options for inputs, outputs and tasks. Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Go ahead, make my day . . . > < show me where I'm wrong. > ================================ ________________________________________________________________________________
Date: Oct 01, 2011
Hi Bob, Snip " The resistor would be 1.25/.3 or 39 ohms..." I'm no electron herder but...isn't 1.25/.3 about 4 ohms? Still learning about all this stuff... Tony Babb. ________________________________________________________________________________
Date: Oct 02, 2011
Robert L. Nuckolls, III wrote: > > > At 09:17 AM 10/1/2011, you wrote: >> >> >> I have 2 friends that have installed the new Aero Led Nav and >> strobes, and both have noise in the headset at all times, even with >> the strobes turned off. Has anyone else experienced this? I'm trying >> to trouble shoot this, and don't have a clue. > > Do I presume correctly that the noise happens with the > position lights on, strobes off but the noise disappears > with the position lights off? > > > Bob . . . > //// > (o o) > ===========o00o=(_)=o00o======== > < Go ahead, make my day . . . > > < show me where I'm wrong. > > ================================ > > No, it's all the time, but worse with the strobes on. And no this is not an STC'ed or TSO'ed product. ________________________________________________________________________________
Subject: Noisey Power Supplies.
Date: Oct 02, 2011
I sell some LED tail lights and used to supply them with commercial constant current supplies--Power Pucks from Luxdrive. But making them quiet was another matter. I know Bob N. put together a fix for these. It would be interesting to see how they worked in the field...I frankly never had any luck, but I did autopsy a unit to see why it was so noiseyand found it was simply a matter of poor design. For a while I considered re-engineering them and selling the identical product, but there was no profit in it. So I changed them all to tomb-silent LM317-based constant current supplies and never heard another peep. I will send you the documentation for a Roll Your Own version (attached), and am considering making a slicker version later (also attached). For the beginner who might wonder why one doesn't use a simple resistor, here's why: The tiny LEDs used as indicators use 20 milliamps. So running them on 14.5V requires a R=(14.5V-2Vf)/0.020=~625 ohm resistor. The resistor power is .020 x 0.020 x 625=W=0.25 or a 1/4W resistor (minimum). But the numbers start getting difficult with a 1 Amp LED: R=(14.5-3.2Vf)/1 11.3 ohm resistor. So far so good. The resistor power is 1 x 1 x 11.3=11.3 Watts (minimum). (you can use 10 or 12 and recalculate. You should use a higher wattage resistor, too). The resistor is the size of your finger, not cheap, requires mechanical mounting and gets hot. You could still do it, but this is the limit of the olde-current limiting resistor technique. The LM317 current-controller technique is in fact more expensive and larger and heavier than using a switching power supply, but not much, and it has the great advantage of being as quiet as a resistor...and you can build it yourself easily. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=353791#353791 Attachments: http://forums.matronics.com//files/current_regulator_194.pdf http://forums.matronics.com//files/canopy_latches_for_bipolar_leds_876.pdf ________________________________________________________________________________
Date: Oct 02, 2011
wag relay At 08:34 AM 10/1/2011, you wrote: > >Hi Bob, > >I received the updated wiring diagram from B&C that has the 2W 75 >ohm resister across the light terminals. I gave it a try and had the >same result. Any idea what is going on? Are the Aeroled lights >different than the Whelens I saw in the picture? I checked out the AeroLed website . . . seems that at least some models of landing light have wig-wag features built in. Are you sure you need the B&C flasher to implement your installation?
                         (o o)
Date: Oct 02, 2011
*The green and the red led's are driven by a switched power supply. This gives a hum in the system. The only solution is to build a filter (choke and condensator) at the 12v input of the led's. * 2011/10/2 Sam Marlow > sam.marlow(at)roadrunner.com> > > Robert L. Nuckolls, III wrote: > >> nuckolls.bob(at)aeroelectric.com**> >> >> At 09:17 AM 10/1/2011, you wrote: >> >>> sam.marlow(at)roadrunner.com> >>> >>> I have 2 friends that have installed the new Aero Led Nav and strobes, >>> and both have noise in the headset at all times, even with the strobes >>> turned off. Has anyone else experienced this? I'm trying to trouble shoot >>> this, and don't have a clue. >>> >> >> Do I presume correctly that the noise happens with the >> position lights on, strobes off but the noise disappears >> with the position lights off? >> >> >> Bob . . . >> //// >> (o o) >> ===========o00o=(_)=o00o======**== >> < Go ahead, make my day . . . > >> < show me where I'm wrong. > >> ==============================**== >> >> >> >> >> >> >> >> No, it's all the time, but worse with the strobes on. And no this is not > an STC'ed or TSO'ed product. > > -- Met vriendelijke groet, Eric Tiethoff mail: eric(at)tiethoff.nl web: http://tiethoff.nl ________________________________________________________________________________
Date: Oct 02, 2011
Subject: Re: AeroLed noises
At 11:13 AM 10/2/2011, you wrote: > >I sell some LED tail lights and used to supply them with commercial >constant current supplies--Power Pucks from Luxdrive. But making >them quiet was another matter. I know Bob N. put together a fix for >these. It would be interesting to see how they worked in the field... We've just about used up the initial stocking order of filter boards for the AEC9051 filtered driver boards. Individuals who ordered boards to add to their existing BukPucks never got back to me . . . further, I've not had any complaints/returns from customers who ordered the fully assembled devices. It's a fair assumption that the product is producing the expected result in the field. I did get into the RFI lab to take a peek at DO160 conducted emissions for the AEC9051 and found it to be well within limits. The reason I asked about TSO/STC on the AeroLED products is because a holy-watered product would have been tested to DO-160 requirements. Sam Marlow wrote: No, it's all the time, but worse with the strobes on. And no this is not an STC'ed or TSO'ed product. I'm mystified as to why anyone might offer a non-qualified device that is any less capable than their qualified device. The delta-dollars to manufacture two different products is pretty small . . . further, the risks of having an unhappy customer due to "cutting of corners" can be hard on business. Nothing travels faster than "bad news" about a product or the services of the company that made it. Having offered that, the question to be asked and answered by AeroLed is, "Is there a difference in electromagnetic compatibility between your certificated and non-certificated products?" If the answer is yes, the next question is, "How was it determined that the owner of an OBAM aircraft would be any more tolerant of noise in the radios than the owner of a TC aircraft?" Sam, I'm not sure I asked my question of you clearly. You spoke of landing lights and strobes. I understand that the noise increased with strobes on versus off. But if there is some form of noise with the strobes off . . . does this noise go away when the landing lights are off? We need to be REALLY sure that the offending noises are coming from both products. In the unfathomable wisdom of HBC management, they sold all their investigative and qualification test facilities to Wichita State University. I used to be able to sneak in and get a quick look-see on the EMC performance of various devices. Now, even though the cost of doing a 5 minute test is quite reasonable, the cost and time delays for doing a purchase order, awaiting a quote, exercising a contract and getting on a schedule has built a very effective barrier between WSU as a supplier and myself as a potential customer. I've got a broad-band receiver and conductive emissions pickup transformers to do the work on my bench . . . but no time in the foreseeable future to get the setup calibrated. So tackling the problem before us is reduced to cut-n-try processes on the airplane. Fortunately, after 45 years of shepherding various products through the labs . . . we're not operating completely in the dark. Let's work to identify the players first, then the propagation paths, and finally some first-pass experiments to identify a solution. Bob . . . ________________________________________________________________________________
Date: Oct 02, 2011
At 12:56 PM 10/2/2011, you wrote: >The green and the red led's are driven by a switched power supply. >This gives a hum in the system. The only solution is to build a >filter (choke and condensator) at the 12v input of the led's. Do you have access to a proven 'recipe for success' as to the size and placement of the components? Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Go ahead, make my day . . . > < show me where I'm wrong. > ================================ ________________________________________________________________________________
Date: Oct 02, 2011
*The problem is that you have to use long powerlines from the main switch to the wingtips. So in the wingtips are the "transmitters" (the switched power supply's to make the led's working). These long powerlines act as an antenna and dirty-up your system. In order to surpress this transmission you have to block it with a choke (i guess 20-30 turns of 22awg wire and a condensator of 10 micro farad). See drawing...good luck. * 2011/10/2 Robert L. Nuckolls, III > At 12:56 PM 10/2/2011, you wrote: > > *The green and the red led's are driven by a switched power supply. This > gives a hum in the system. The only solution is to build a filter (choke and > condensator) at the 12v input of the led's.* > > > Do you have access to a proven 'recipe for success' > as to the size and placement of the components? > > ** > > ** Bob . . . > //// > (o o) > ===========o00o=(_)=o00o======== > < Go ahead, make my day . . . > > < show me where I'm wrong. > > ================================ > > * > > > * > > -- Met vriendelijke groet, Eric Tiethoff mail: eric(at)tiethoff.nl web: http://tiethoff.nl ________________________________________________________________________________
Date: Oct 02, 2011
Sam, We also need to know what the conditions are for hearing the noise in the headsets. Does the noise level go up and down as the VOLUME on a radio is adjusted? . . . when the intercom volume is adjusted? . . . when the radios are all OFF? This will give us clues as to whether the noise problem is RADIATED or CONDUCTED noise. Filters for these two conditions are different. Bob . . . ________________________________________________________________________________
Date: Oct 02, 2011
Subject: AeroLED lights - and an alternative
I have followed the thread on these lights for a while, and thought I would toss my .02 in - take a look at Ztron Labs (www.ztronlabs.com). They have a suite of excellent LED lights that will be a world beater, in my opinion. The tail light is $89.00 and the pair of wingtip lights is $249.00 (all LED and sun-bright). The real killer as far as I am concerned is this - the wig-wag is built in and programmable with a button push. Each light has 3 wires - pwr, grd, and sync. Taking the sync wire to grd disables the strobes, leaving the position lights on. Very reponsive company. Definitely worth a look IMHO. Sam Staton Jacksonville, FL ________________________________________________________________________________
Date: Oct 02, 2011
I am also interested in any thoughts, they claim to meet brightness requirements for night flight, and their pricing is very attractive. Bill Greenley RV-10 wing stage -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Sam Staton Sent: Sunday, October 02, 2011 5:11 PM Subject: AeroElectric-List: AeroLED lights - and an alternative I have followed the thread on these lights for a while, and thought I would toss my .02 in - take a look at Ztron Labs (www.ztronlabs.com). They have a suite of excellent LED lights that will be a world beater, in my opinion. The tail light is $89.00 and the pair of wingtip lights is $249.00 (all LED and sun-bright). The real killer as far as I am concerned is this - the wig-wag is built in and programmable with a button push. Each light has 3 wires - pwr, grd, and sync. Taking the sync wire to grd disables the strobes, leaving the position lights on. Very reponsive company. Definitely worth a look IMHO. Sam Staton Jacksonville, FL ________________________________________________________________________________
Date: Oct 02, 2011
At 01:37 PM 10/2/2011, you wrote: >The problem is that you have to use long powerlines from the main >switch to the wingtips. So in the wingtips are the "transmitters" >(the switched power supply's to make the led's working). These long >powerlines act as an antenna and dirty-up your system. In order to >surpress this transmission you have to block it with a choke (i >guess 20-30 turns of 22awg wire and a condensator of 10 micro >farad). See drawing...good luck. Electrolytic capacitors are almost never a part of a solution for reducing attenuation at radio frequencies. The value of inductance for what I presume is an air-wound, helix of wire is only useful as an attenuator at radio frequencies. I'm not suggesting that this approach did not work for somebody . . . they were on the right track for a practical filter. But without knowing the spectrum of energy for the offending noise, this filter was far from optimal to the task. In the instance where a filter was added to the Buck Pucks . . . see http://www.aeroelectric.com/Catalog/AEC/9051/9051-700A.pdf the components were selected to attenuate radio frequency noise reported by disappointed users of the Buck Pucks. A hand-held transceiver held close to an operating LED driven by a Buck Puck was bombarded by a substantial noise sorce. The capacitors used in this case are rather small as is the inductor. The inductor was not selected for it's ability to function as a high quality resonance but as a lossy impedance. It was desirable that any VHF+ RF appearing across the terminals was converted to heat! It seems likely that the AeroLED study will produce a similar finding. But until that finding is verified, moving forward with any filter experiments could be a poor use of time or offer a risk of less than optimal performance. Bob . . . ________________________________________________________________________________
Date: Oct 02, 2011
Subject: Re: AeroLED lights - and an alternative
At 04:10 PM 10/2/2011, you wrote: > > I have followed the thread on these lights for a while, and > thought I would toss my .02 in - take a look at Ztron Labs > (www.ztronlabs.com). They have a suite of excellent LED lights that > will be a world beater, in my opinion. The tail light is $89.00 and > the pair of wingtip lights is $249.00 (all LED and sun-bright). The > real killer as far as I am concerned is this - the wig-wag is built > in and programmable with a button push. Each light has 3 wires - > pwr, grd, and sync. Taking the sync wire to grd disables the > strobes, leaving the position lights on. Very reponsive company. > Definitely worth a look IMHO. Good news . . . but be sure to ask if the devices contain active electrics (a pretty sure bet) and if so, have they been investigated for potential emissions above those allowed under DO-160 qualifications for TC aircraft? Bob . . . ________________________________________________________________________________
Date: Oct 02, 2011
Yes. I have a composite aircraft and installed the units using an old wiring diagram that came in the box - I too had lots of noise in the headsets and radio reception. There is a NEW wiring diagram on the website that the tech guys at AeroLEDs pointed out...sure enough, the radio transmitted noise went away. Problem one solved. However, (after LOTS of hunting) the rest of the line transmitted noise was being picked up somewhere in the XM audio output of the Garmin 396 GPS that was being fed into the intercom. This even happened with the GPS on battery power...it was very weird. I tried power filters on all ends (LED end, GPS, and intercom) - no luck. the only thing that fixed the problem was upgrading to the Garmin 496. It seems that the audio output grounding is different on the 496 and is not susceptible to the noise, or floating ground issue, or whatever that real problem was. Noise free and loving it...and the LEDs. Hope that helps! -James Berkut/Race13 www.berkut13.com -----Original Message----- From: Sam Marlow Sent: Saturday, October 01, 2011 9:17 AM Subject: AeroElectric-List: Aero LED'S I have 2 friends that have installed the new Aero Led Nav and strobes, and both have noise in the headset at all times, even with the strobes turned off. Has anyone else experienced this? I'm trying to trouble shoot this, and don't have a clue. ________________________________________________________________________________
Date: Oct 03, 2011
Robert L. Nuckolls, III wrote: > > > At 11:13 AM 10/2/2011, you wrote: >> >> >> I sell some LED tail lights and used to supply them with commercial >> constant current supplies--Power Pucks from Luxdrive. But making them >> quiet was another matter. I know Bob N. put together a fix for these. >> It would be interesting to see how they worked in the field... > > We've just about used up the initial stocking order of > filter boards for the AEC9051 filtered driver boards. > Individuals who ordered boards to add to their existing > BukPucks never got back to me . . . further, I've not > had any complaints/returns from customers who ordered the > fully assembled devices. It's a fair assumption that > the product is producing the expected result in the > field. I did get into the RFI lab to take a peek at > DO160 conducted emissions for the AEC9051 and found it > to be well within limits. > > The reason I asked about TSO/STC on the AeroLED products > is because a holy-watered product would have been tested > to DO-160 requirements. > > Sam Marlow wrote: > > No, it's all the time, but worse with the strobes on. And no this is not > an STC'ed or TSO'ed product. > > I'm mystified as to why anyone might offer a non-qualified > device that is any less capable than their qualified device. > The delta-dollars to manufacture two different products > is pretty small . . . further, the risks of having an unhappy > customer due to "cutting of corners" can be hard on business. > Nothing travels faster than "bad news" about a product or > the services of the company that made it. > > Having offered that, the question to be asked and answered > by AeroLed is, "Is there a difference in electromagnetic > compatibility between your certificated and non-certificated > products?" If the answer is yes, the next question is, "How > was it determined that the owner of an OBAM aircraft would > be any more tolerant of noise in the radios than the owner > of a TC aircraft?" > > Sam, I'm not sure I asked my question of you clearly. You > spoke of landing lights and strobes. I understand that the > noise increased with strobes on versus off. But if there > is some form of noise with the strobes off . . . does this > noise go away when the landing lights are off? We need > to be REALLY sure that the offending noises are coming from > both products. > > In the unfathomable wisdom of HBC management, they sold > all their investigative and qualification test facilities > to Wichita State University. I used to be able to sneak in > and get a quick look-see on the EMC performance of various > devices. Now, even though the cost of doing a 5 minute test > is quite reasonable, the cost and time delays for doing a > purchase order, awaiting a quote, exercising a contract > and getting on a schedule has built a very effective > barrier between WSU as a supplier and myself as a potential > customer. > > I've got a broad-band receiver and conductive emissions > pickup transformers to do the work on my bench . . . but > no time in the foreseeable future to get the setup > calibrated. > > So tackling the problem before us is reduced to cut-n-try > processes on the airplane. Fortunately, after 45 years > of shepherding various products through the labs . . . we're > not operating completely in the dark. Let's work to identify > the players first, then the propagation paths, and finally > some first-pass experiments to identify a solution. > > Bob . . . > > I'll research further, and get back to you. Thanks. ________________________________________________________________________________
Subject: Review of LEDs for aircraft lighting
Date: Oct 03, 2011
I see dozens of newbies patching together LEDs for aircraft lighting and am frequently mortified. Remember, when your family gets called and told that another plane with homemade night-lighting killed you, everybody carries some blame for letting it happen. Item: It is theoretically impossible to build a tail light using LEDs that draws 200 mA and cost $89. Strobe too! And it won't even be possible when my now preschool grand-kid graduates from MIT. Item: It is theoretically impossible to adjust 26 tiny LEDs to form a position light, even if the peak candelas times 26 comes out to some kind of legal-sounding number. Item: I quit selling LED position lights (but still sell a few tail lights), that really are legal. I just could not compete with the claims of the poor quality stuff. In fact one of my customers, having lost his regular landing lights, landed at night using ONLY the LED position lights for illumination. This might have been a historic landing. See attached. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=353875#353875 Attachments: http://forums.matronics.com//files/led_lighting_article_draft_13may08_182.pdf ________________________________________________________________________________
Date: Oct 03, 2011
So I changed them all to tomb-silent LM317-based constant current supplies and never heard another peep. I will send you the documentation for a Roll Your Own version (attached), and am considering making a slicker version later (also attached). Eric M. Jones Attachments: http://forums.matronics.com//files/current_regulator_194.pdf http://forums.matronics.com//files/canopy_latches_for_bipolar_leds_876.pdf The second attachment does not open for me! ________________________________________________________________________________
Date: Oct 03, 2011
Subject: Re: Review of LEDs for aircraft lighting
Did you ever take a look at "Jeff's" LED wing tip position lights (and regular strobe) for RVs? If so, what did you think? http://www.jeffsrv-7a.com/LEDPROJECT.htm No specs here. "Jeff's lights are no longer available as far as I know. On 10/3/2011 10:02 AM, Eric M. Jones wrote: > --> AeroElectric-List message posted by: "Eric M. Jones" > > I see dozens of newbies patching together LEDs for aircraft lighting and am frequently mortified. Remember, when your family gets called and told that another plane with homemade night-lighting killed you, everybody carries some blame for letting it happen. > > Item: It is theoretically impossible to build a tail light using LEDs that draws 200 mA and cost $89. Strobe too! And it won't even be possible when my now preschool grand-kid graduates from MIT. > > Item: It is theoretically impossible to adjust 26 tiny LEDs to form a position light, even if the peak candelas times 26 comes out to some kind of legal-sounding number. > > ________________________________________________________________________________
Date: Oct 03, 2011
Subject: Re: Noisey Power Supplies.
ROGER & JEAN CURTIS wrote: > --> AeroElectric-List message posted by: "ROGER& JEAN CURTIS" > > > So I changed them all to tomb-silent LM317-based constant current supplies > and never heard another peep. I will send you the documentation for a Roll > Your Own version (attached), and am considering making a slicker version > later (also attached). > Eric M. Jones > > Attachments: > > http://forums.matronics.com//files/current_regulator_194.pdf > http://forums.matronics.com//files/canopy_latches_for_bipolar_leds_876.pdf > > > The second attachment does not open for me! > > Won't open for me either! ________________________________________________________________________________
Date: Oct 03, 2011
Sorry, the second attachment was supposed to be deleted because I never referred to it. But here it is anyway. It is self explanatory. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=353924#353924 Attachments: http://forums.matronics.com//files/canopy_latches_for_bipolar_leds_291.pdf ________________________________________________________________________________
Date: Oct 03, 2011
Jeff's look very nice--they probably are per FAA specs position lights. I'm less sure of the strobes, but they could be okay. Exquisite workmanship. Can't tell more without closer inspection and specs. Some images don't want to load on my computer from his website. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=353926#353926 ________________________________________________________________________________
Date: Oct 03, 2011
Thanks. I know there wasn't much info there but appreciate the reply. Those images don't load on mine either. I think these pages have been un-maintained for awhile. I'm happy with them except for the noise from the pucks. Will be installing Bob's quiet power supplies to fix the noise. On 10/3/2011 4:49 PM, Eric M. Jones wrote: > --> AeroElectric-List message posted by: "Eric M. Jones" > > Jeff's look very nice--they probably are per FAA specs position lights. I'm less sure of the strobes, but they could be okay. Exquisite workmanship. > > Can't tell more without closer inspection and specs. Some images don't want to load on my computer from his website. > > -------- > Eric M. Jones > ________________________________________________________________________________
Date: Oct 04, 2011
Subject: Audio systems and "output impedance"
At 10:53 PM 10/3/2011, a reader wrote: >Bob, the audio out on this beast is rated at 500 ohms. I don't >think my Bose headsets are the same? What's the best way of tying >this into my audio system, I have a cheap aviar intercom I was >planning on using but open to suggestions? I also have your Audio >Isolation amplifier. See the description of audio systems and the concept of 'output impedance' in the audio chapter of The Connection. There's not a single audio device with a real output impedance of 500 ohms . . . or any similar value. By definition, a source of energy with an output impedance of 500 ohms would see a drop in output by 50% when loaded with a 500 ohm headset. Two such headsets in parallel would drop the output further to 33%. So when an audio output is 'rated' for 100 mW into 500 ohms, they're only speaking to the ability of the amplifier to deliver a VOLTAGE along with a citation as to POWER delivered into a typical load. Interestingly enough, the same output, when presented with TWO headsets of load would deliver 200 mW. My audio isolation amplifier has an output impedance of less than 1 ohm . . . but it's capable of delivering about 8 volts pk-pk into what ever load you wish to tie onto it. The smaller the resistance . . . the higher the current . . . the higher the power. Further, because the true output impedance is so low, you can drive 1, 2 or 10 headsets with no perceivable drop in ouput. Your radio(s) and intercom are similarly configured. Just know that the term "output impedance" is quite often used in a manner that does not contribute to understanding. Bob . . . Bob . . . ________________________________________________________________________________
Subject: Headsets Redux-was "Warning - New Bose Line Power Cable
Date: Oct 04, 2011
Bought 2 pairs of Beyerdynamic HS 800 headsets by 8/31/11 to make it through the $200/set trade-in window they offered. Got the BD's and they are a very nice German-built headset. In the back of my mind, I figured that I would go through the motions of due diligence comparison and probably buy Bose, then return the BD HS 800's in the 30 day trial period. I went to a Bose store to compare headsets with the Bose display simulating cockpit noise in a single engine piston plane. First, the Bose earcups were not as generous as the BD cups and were more difficult to get a good seal. I did manage to get them on correctly. I felt that the Bose head band was awkward in using a multi-segment, pivoting mechanism and it didn't feel secure on my noggin, and caused doubt about it's ability to stay on if encountering heavy turbulence or rapid head movement. The BD uses a traditional spring steel type band, with slightly more clamp pressure than Bose and felt very secure on my head. Inspite of Bose specs claiming lighter weight by an ounce, the BD felt lighter when wearing it. The BD earcup seals also seem to seal around my wire frame sunglasses more effectively than the Bose. The actual noise reduction comparison was interesting. When switching back and forth between brands with the simulated noise on, the Bose was obviously quieter...initially. After doing this a few times, I noticed that when the BD's were on for about 3-4 seconds, the noise attenuation would increase from the initial covering of my ears. BD calls their system Digital Adaptive NR and I attribute the attenuation lag to that "adaptive" feature. Once internal earcup sensors adapted to the particular frequencies being sensed and subsequently reduced the sound level, I found the sound of the BD's more natural than the Bose. The Bose had less sound, but I found that I prefer a little aural feedback. The sound level difference between the two is pretty minor, but detectable and in favor of Bose. To explain what I mean by aural feedback, I can give you the analog of my choice in cars. When I was deciding brand and model the last time I bought one, I chose one that gave me more road feel at the expense of minor cabin noise. I found that driving a car that isolated me from the road, both in feel through the steering wheel and tomb-like quiet in the cabin, made me slightly nauseous, and imparted the feeling of a slight lack of control over the car. Moving on, the BD electrical cording is high quality and about 6' long. The audio box is about the same size as Bose but much simpler and BD provides the various adapters for music players and cellphones to plug right in to the audio box. I confess that I don't use a cell phone much and I hardly think of an aircraft cockpit as a concert hall, so having Bluetooth is not much of a selling point for me. After my brief comparison, I'd opt for the BD's even without the $200/headset trade-in for my 24 year old DC's. With it, it was a no-brainer. Thanks to Gerry Van Dyk for turning me on to the BD's John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=354062#354062 ________________________________________________________________________________
Date: Oct 05, 2011
Subject: Re: Headsets Redux-was "Warning - New Bose Line Power
Cable John, I concur with all of your comments. Stan Sutterfield Long time Bose user In a message dated 10/5/2011 3:01:15 A.M. Eastern Daylight Time, aeroelectric-list(at)matronics.com writes: Bought 2 pairs of Beyerdynamic HS 800 headsets by 8/31/11 to make it through the $200/set trade-in window they offered. Got the BD's and they are a very nice German-built headset. In the back of my mind, I figured that I would go through the motions of due diligence comparison and probably buy Bose, then return the BD HS 800's in the 30 day trial period. I went to a Bose store to compare headsets with the Bose display simulating cockpit noise in a single engine piston plane. First, the Bose earcups were not as generous as the BD cups and were more difficult to get a good seal. I did manage to get them on correctly. I felt that the Bose head band was awkward in using a multi-segment, pivoting mechanism and it didn't feel secure on my noggin, and caused doubt about it's ability to stay on if encountering heavy turbulence or rapid head movement. The BD uses a traditional spring steel type band, with slightly more clamp pressure than Bose and felt very secure on my head. Inspite of Bose specs claiming lighter weight by an ounce, the BD felt lighter when wearing it. The BD earcup seals also seem to seal around my wire frame sunglasses more effectively than the Bose. The actual noise reduction comparison was interesting. When switching back and forth between brands with the simulated noise on, the Bose was obviously quieter...initially. After doing this a few times, I noticed that when the BD's were on for about 3-4 seconds, the noise attenuation would increase from the initial covering of my ears. BD calls their system Digital Adaptive NR and I attribute the attenuation lag to that "adaptive" feature. Once internal earcup sensors adapted to the particular frequencies being sensed and subsequently reduced the sound level, I found the sound of the BD's more natural than the Bose. The Bose had less sound, but I found that I prefer a little aural feedback. The sound level difference between the two is pretty minor, but detectable and in favor of Bose. To explain what I mean by aural feedback, I can give you the analog of my choice in cars. When I was deciding brand and model the last time I bought one, I chose one that gave me more road feel at the expense of minor cabin noise. I found that driving a car that isolated me from the road, both in feel through the steering wheel and tomb-like quiet in the cabin, made me slightly nauseous, and imparted the feeling of a slight lack of control over the car. Moving on, the BD electrical cording is high quality and about 6' long. The audio box is about the same size as Bose but much simpler and BD provides the various adapters for music players and cellphones to plug right in to the audio box. I confess that I don't use a cell phone much and I hardly think of an aircraft cockpit as a concert hall, so having Bluetooth is not much of a selling point for me. After my brief comparison, I'd opt for the BD's even without the $200/headset trade-in for my 24 year old DC's. With it, it was a no-brainer. Thanks to Gerry Van Dyk for turning me on to the BD's John ________________________________________________________________________________
Subject: UMA fuel pressure sender wiring
Date: Oct 05, 2011
Hello! I just got a UMA N1EU07G fuel pressure sender. I am mounting this on the firewall, about 6" away from the MGL RDAC (where the signal wires from all the FWF probes connect) and about 18" away from the firewall ground. I will split off the power wire at ~6" from the sender, leaving the other two wires and braid (if needed) to run until they are 16" away from the sender. At that point, the signal wire will separate from the ground and shield and connect to the RDAC. The ground and shield would go the final 2" to the firewall ground. The easiest thing for me to do is to remove the insulated cover over the braid (and 3 wires) to the point where the power wire needs to separate. I imagine the braid will be a bit tight around the wires, so I could cut it off at the point where the power wire separates and splice a separate ground wire to it. Or does it need to shield the signal wire for that extra 10"? Lemme know how this sounds to you. Cheers, Dan -------- Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=354153#354153 Attachments: http://forums.matronics.com//files/uma_fuel_pressure_sender_wiring_625.jpg ________________________________________________________________________________
Date: Oct 06, 2011
Hello Dan, Why do you need to bring the power wire out so soon- I imagine that it is to be able to connect to your positive bus? I don't think that that should be a problem, however, instead of cutting the braid try this method. Hold the braid tightly around the cores just behind (towards the sensor) where you want to bring the wire out, say in your left hand. Lightly grasp the shield about 1 inch to the right with your right hand and slide the braid to the left like a sock. The braid should 'balloon' up between your fingers. Now take a sharp pencil and use the tip to work open one of the holes formed between the braiding. Work it open enough to be able to get the tip in under the wire that must come out. Now pull a loop of the wire out through the hole in the braid and then pull the whole wire out of the braid. Once its out pull the ballooned part of braid flat along the remaining wires. Voila! Now you have the wire out and no damage to the braid. Jay -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of messydeer Sent: 06 October 2011 04:54 AM Subject: AeroElectric-List: UMA fuel pressure sender wiring Hello! I just got a UMA N1EU07G fuel pressure sender. I am mounting this on the firewall, about 6" away from the MGL RDAC (where the signal wires from all the FWF probes connect) and about 18" away from the firewall ground. I will split off the power wire at ~6" from the sender, leaving the other two wires and braid (if needed) to run until they are 16" away from the sender. At that point, the signal wire will separate from the ground and shield and connect to the RDAC. The ground and shield would go the final 2" to the
September 09, 2011 - October 06, 2011
AeroElectric-Archive.digest.vol-kq
