AeroElectric-Archive.digest.vol-ku
December 28, 2011 - January 21, 2012
      first.  BUT, there is power and utility in those options.  If you use them to
      your advantage, you can probably do more, better on the GRT compared to the Dynon.
      The displays on the GRT don't have the "3D-y", "Windows-y" look to them.
      BUT, I think I'm preferring that at this point.  Doing a scan on the GRT looking
      for something out of the ordinary is quicker and more accurate.  I also like
      the PFD layout and operation on the GRT better.  It feels more "accurate"
      and "believable" to me for some reason.  I never quite "trust" what I'm seeing
      on the Dynon for some reason and I don't know why.  Maybe I just need more time
      on the Dynon.
      So, the Dynon has it for Installation and Configuation, but the GRT has it for
      Operation and Presentation as far as I'm concerned.  If I was building a new plane,
      I think that I would probably go with the GRT.  But its a close race.  I
      really like the Dynon system too.
      I guess I'm saying if you're in the market for a full-featured EFIS system, give
      GRT and Dynon both very close look before you make your selection.  In my opinion,
      it comes down to personal preferences in a few select areas on which way
      to go.  Both systems are top notch.
      BTW, Dynon's autopilot add-on for the Skyview which I have in the RV-6 works well.
      Its a good autopilot that does the job.  The servos are the same as with
      the TruTrak system.  In the RV-8, I have the TruTrak Digiflight II VSGV system.
      The TruTrak is a smoother, more accurate autopilot in my opinion, and I would
      go that route again.  But, it also costs quite a bit more than just adding
      servos to the Dynon or GRT.
      $.02
      Matt "Red Dawg" Dralle
      Status: 170+ Hours TTSN - Rebuilding Fuselage After Landing Mishap...
      Status: 42+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode
Date: Dec 28, 2011
Subject: Re: First Engine Start Problem
Howdy- Re: we decided to >then let the starter do the work. The starter turned the engine over well, >however, I was dismayed when my whole panel of avionics went dead. I of cou >rse quit cranking and began troubleshooting. It didn't take long to find th >at the fuseable link off the Batt Contactor (heading to the E-Bus) burned t >hrough. I went ahead and bypassed the link with 16 AWG and was able to comp >lete a successful first engine start. I'm on the road at the moment (beautiful dowtown Bahrain...) and don't have the relevant docs with me, but if Z-16 has the E bus fed through a diode down stream from the battery contactor and / or through the E bus switch from upstream of the battery contactor, and the diode were installed reverse biased..... Without other explicit details, this and the idea about engine flail bringing a grounded chunk of hardware into physical contact with an energized bit of the E bus architecture are all I can think of. Glen Matejcek ________________________________________________________________________________
Date: Dec 28, 2011
Subject: Re: Dynon Skyview Airspeed Calibration...
You could just cut the head off the pop rivet that Van's recommends and stick that on with epoxy (or double sided tape to start with)? Peter On 28/12/2011 05:12, Matt Dralle wrote: > At 07:39 PM 12/26/2011 Monday, Matt Dralle wrote: >> Dear Listers, >> >> I've been flying the new 10" Dynon Skyview in the RV-6 for a few weeks now and it seems like the airspeed is reading maybe 10mph fast. The GS always reads 10mph or more slower than the True airspeed, no matter which way I fly with respect to the current wind. Looking through the configuration options on the Skyview, I'm not seeing parameters to calibrate the airspeed. If the airspeed were *slow* compared to the GS, I could envision making adjustments to the Pitot tube to get it in better alignment with slipstream. But *fast* is a head scratcher. If there's no electronic configuration parameters to adjust, what do you do? Are there Pitot line "attenuators" like for RF in coax? ;-) >> >> Matt > > Listers, > > Thank you for all the great suggestions on resolving this airspeed issue! I took a look at the static ports on the RV-6 today and found that they are done using a flush head screw with a hole drilled in the center on either side of the fuselage. They do *not* protrude from the side of the plane at all. They are totally flush (see attached picture). Just for fun, I whipped up a couple of quick test deals using a 3/16" washer and some electrical tape. I poked a 1/16" hole in the center of the tape and then put the washer centered over the static ports on both sides of the fuselage (see attached pictures). Then, I went flying on this beautiful December 27 day in California! > > I didn't have time to do any real scientific multi-leg testing, but I was amazed that the True Airspeed is now falling in a much more believable range compared to the GPS-derived ground speed. On one cross-country leg, I had an exactly 90 degree crosswind component and the True Airspeed and GPS Ground Speed were tracking exactly the same. Yahoo! > > Obviously I need to do some additional, more scientific measurements and probably come up with a slightly more "permanent" washer arrangement, but the early returns are very promising! :-) > > Thanks again for all the great feedback! > > Matt > > > - > Matt "Red Dawg" Dralle > > RV-8 #82880 N998RV "Ruby Vixen" > http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log > http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel > Status: 170+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... > > RV-6 #20916 N360EM "The Flyer" > http://www.mattsrv6.com - Matt's RV-6 Revitalization Log > Status: 42+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode ________________________________________________________________________________
Date: Dec 28, 2011
Subject: Relays
At 10:48 PM 12/27/2011, you wrote: >Picture #1 is the old system that approximates mine, though there are some >additional C.B. switches and fuses in some lines. #2 is what I would like >to go with. The DPST Master Switch would be replaced with a SPST 5 Amp C.B. >switch and 16 would be a simple Master Switch connected to the battery >relay. Any thoughts, suggestions, or warnings would be appreciated. >Bill Okay, the first thing I would do is put those two drawings in the round-file. These are typical "how things work" illustrations produced by individuals who are very good at what they do . . . build engines . . . but are not cogent system integrators. The drawings are not incorrect . . . but they fall far short of the details and reasoning processes that should be applied to the vetting of your electrical system. Suggest you start with Figure Z-12 . . . http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z12M.pdf . . . and see where it doesn't meet YOUR design goals for how the electrical system should function. If you have no particular wish for an operating feature that is not addressed by Z-16, then you're good to go. If there are questions, let's talk about them here on the List. The externally regulated alternator can be replaced with the internally regulated alternator depicted in the Rotax drawings. The 18A PM alternator can replace the 20A standby alternator depicted in Z-12. But the architecture shown in Z-12 is a good starting point. I could do a new Z-figure that is seeded from the Rotax drawing for dual alternators. Bob . . . ________________________________________________________________________________
Subject: Dynon Skyview Airspeed Calibration...
Date: Dec 28, 2011
12/28/2011 Hello Matt, I think that you are on the right track. The correct approach is to use a semi circular wedge either before or aft of the static port in order to achieve the results required. Here is the sequence that I went through with my two static ports (one on each side of the fuselage) in order to lower my airspeed indicator airspeed indication before I was satisfied with the results: 1) Taped over one side static port and test flew. 2) Removed the first tape, taped over the other side static port and test flew. 3) Put wedges aft of both side static ports using double sided sticky tape and test flew. 4) Removed wedge from one side static port and test flew. 5) Switched the single wedge from one side static port to the other side static port and test flew. 6) Declared victory and installed the single wedge more permanently. Note that my focus was on good airspeed indication at landing approach airspeeds, not at cruise airspeeds. On a calm / no wind day a check between my airspeed indicator airspeed and my GPS ground speed on landing approach are very nearly identical. I see no significant altimeter change indication with airspeed change. The next time I am out at the airport (if I remember) I will take a photo or two of the single aluminum wedge on one of my static ports and email it to you. Good luck. 'OC' Baker Says: "The best investment we can make is the time and effort to gather and understand knowledge." ===================================================== Listers, Thank you for all the great suggestions on resolving this airspeed issue! I took a look at the static ports on the RV-6 today and found that they are done using a flush head screw with a hole drilled in the center on either side of the fuselage. They do *not* protrude from the side of the plane at all. They are totally flush (see attached picture). Just for fun, I whipped up a couple of quick test deals using a 3/16" washer and some electrical tape. I poked a 1/16" hole in the center of the tape and then put the washer centered over the static ports on both sides of the fuselage (see attached pictures). Then, I went flying on this beautiful December 27 day in California! I didn't have time to do any real scientific multi-leg testing, but I was amazed that the True Airspeed is now falling in a much more believable range compared to the GPS-derived ground speed. On one cross-country leg, I had an exactly 90 degree crosswind component and the True Airspeed and GPS Ground Speed were tracking exactly the same. Yahoo! Obviously I need to do some additional, more scientific measurements and probably come up with a slightly more "permanent" washer arrangement, but the early returns are very promising! :-) Thanks again for all the great feedback! Matt ________________________________________________________________________________
Date: Dec 28, 2011
I'm on the road at the moment (beautiful dowtown Bahrain...) and don't have the relevant docs with me, but if Z-16 has the E bus fed through a diode down stream from the battery contactor and / or through the E bus switch from upstream of the battery contactor, and the diode were installed reverse biased..... Good call Glen. I did not pick up on the fact that the fusible link in question was in series with the ALTERNATE feed switch . . . which should be OPEN for all but pre-flight tests -OR- in-flight, alternator-out operations. Combine this closed switch with a reversed NORMAL feed path diode could account for the severe overload of the link. Dan, do your e-bus feed accessories work with the alternate feed switch OFF? If not, check the normal feed path diode for proper polarity. Bob . . . ________________________________________________________________________________
Date: Dec 28, 2011
From: Dan Billingsley <dan(at)azshowersolutions.com>
=0A=0A=0A=0A=0A>________________________________=0A> From: "Robert L. Nucko lls, III" =0A>To: aeroelectric-list@matronic s.com =0A>Sent: Wednesday, December 28, 2011 7:03 AM=0A>Subject: Re: AeroEl ectric-List: Re: First Engine Start Problem=0A> =0A>--> AeroElectric-List m essage posted by: "Robert L. Nuckolls, III" =0A>=0A>=0A>=0A>I'm on the road at the moment (beautiful dowtown Bahrain... ) and don't have the relevant docs with me, but if Z-16 has the E bus fed t hrough a diode down stream from the battery contactor and / or through the E bus switch from upstream of the battery contactor, and the diode were ins talled reverse biased.....=0A>=0A>- Good call Glen. I did not pick up on the=0A>- fact that the fusible link in question was=0A>- in series with the ALTERNATE feed switch . . .=0A>- which should be OPEN for all but pr e-flight=0A>- tests -OR- in-flight, alternator-out operations.=0A>=0A>- Combine this closed switch with a reversed=0A>- NORMAL feed path diode c ould account for the=0A>- severe overload of the link.=0A>=0A>- Dan, do your e-bus feed accessories work with=0A>- the alternate feed switch OFF ? If not, check=0A>- the normal feed path diode for proper polarity.=0A> =0A>No, the E-Bus switch must be ON in order for any of the accessories to operate. I will take another look at the diode polarity as well. One of the guys I am working with suggested I not turn on the E-Bus switch until Afte r I start the engine. That could become a practice, yet it does go against the grain of how things "should" work. Will get back with the info soon.- - - - - - - - - - - - - -Matt Dralle, List Admin. =====0A>=0A>=0A>=0A>=0A>=0A> ________________________________________________________________________________
Date: Dec 28, 2011
> No, the E-Bus switch must be ON in order for any of the accessories to operate. I will take another look at the diode polarity as well. One of the guys I am working with suggested I not turn on the E-Bus switch until After I start the engine. The E-Bus should be energized with the E-Bus switch off and the master switch on. If not, the diode is backwards. Although it will not hurt anything to fly with the E-Bus switch turned on, it is intended to be turned on only in the event that power is not available through the diode. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361838#361838 ________________________________________________________________________________
Subject: 12v to 24v DC-DC converter circuit
Date: Dec 28, 2011
Before I go off and reinvent the wheel.... does anyone have a DC-DC converter circuit design they can share with me? A off-the-shelf unit would be fine too. I have a small altimeter on my natively 12v aircraft that requires 28v (as spec'ed) for internal lighting (two tiny bulbs) and a vibrator. It does not specify a current draw, but it cant be very much given the usage. Thanks in advance. -James Berkut/Race13 www.berkut13.com ________________________________________________________________________________
Date: Dec 28, 2011
Have aloo0k for a LM2577 DC-DC step-up DC converter board on ebay Best Regards Peter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of berkut13(at)berkut13.com Sent: 28 December 2011 15:56 Subject: AeroElectric-List: 12v to 24v DC-DC converter circuit Before I go off and reinvent the wheel.... does anyone have a DC-DC converter circuit design they can share with me? A off-the-shelf unit would be fine too. I have a small altimeter on my natively 12v aircraft that requires 28v (as spec'ed) for internal lighting (two tiny bulbs) and a vibrator. It does not specify a current draw, but it cant be very much given the usage. Thanks in advance. -James Berkut/Race13 www.berkut13.com ________________________________________________________________________________
Date: Dec 28, 2011
Subject: Re: 12v to 24v DC-DC converter circuit
At 09:56 AM 12/28/2011, you wrote: > >Before I go off and reinvent the wheel.... does anyone have a DC-DC >converter circuit design they can share with me? A off-the-shelf unit >would be fine too. > >I have a small altimeter on my natively 12v aircraft that requires 28v (as >spec'ed) for internal lighting (two tiny bulbs) and a vibrator. It does >not specify a current draw, but it cant be very much given the usage. There are perhaps hundreds of possibilities. One such device is illustrated here: http://search.digikey.com/us/en/products/UEI15-120-Q12P-C/811-1868-5-ND/1980326 It's an ISOLATED output dc-dc converter rated for 9-36v input and 12v out at 1.3A. You can wire this such that it's in series with the 14v input giving you a total of 26v output. CAUTION As supplied, it MIGHT need a metallic enclosure + RF filters to keep internal thrashings from radiating into other systems. You'll want to survey the operation of your radios with this device ON vs OFF and make sure it is not engaged in nepharious behaviors. Bob . . . ________________________________________________________________________________
Date: Dec 28, 2011
Subject: Relays
Bob, Thanks for the response and the schematic. But as I look at it I pinked out everything that my setup doesn't have and ended up with over half the diagram pinked out. Your diagram does show me where and how the two relays (contactors) fit into the system though and that is helpful. I've also got the rotary ACS starter switch to work with rather then just a simple switch or push button. What makes the most sense is adding the battery relay (connected to battery, master switch, power bus and starter relay) and having the starter relay connected to battery relay, starter, internal alternator 20 amp capacitor to internal alternator, starter switch, and external alternator 60 amp fuse to external alternator. Then schematic #2 that I sent you seems to make the most sense to me. Any other comments are greatly appreciated. Thanks again. Bill On Wed, Dec 28, 2011 at 5:04 AM, Robert L. Nuckolls, III wrote: > > > At 10:48 PM 12/27/2011, you wrote: >> Picture #1 is the old system that approximates mine, though there are >> some >> additional C.B. switches and fuses in some lines. #2 is what I would >> like >> to go with. The DPST Master Switch would be replaced with a SPST 5 >> Amp C.B. >> switch and 16 would be a simple Master Switch connected to the >> battery >> relay. Any thoughts, suggestions, or warnings would be appreciated. >> Bill > > Okay, the first thing I would do is put those two drawings > in the round-file. These are typical "how things work" illustrations > produced by individuals who are very good at what they do . . . > build engines . . . but are not cogent system integrators. > > The drawings are not incorrect . . . but they fall far short > of the details and reasoning processes that should be > applied to the vetting of your electrical system. > > Suggest you start with Figure Z-12 . . . > > http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z12M.pdf > > . . . and see where it doesn't meet YOUR design goals > for how the electrical system should function. > > If you have no particular wish for an operating feature that > is not addressed by Z-16, then you're good to go. If there > are questions, let's talk about them here on the List. The > externally regulated alternator can be replaced with the > internally regulated alternator depicted in the Rotax drawings. > The 18A PM alternator can replace the 20A standby alternator > depicted in Z-12. But the architecture shown in Z-12 is a > good starting point. I could do a new Z-figure that is seeded > from the Rotax drawing for dual alternators. > > > Bob . . . ________________________________________________________________________________
Date: Dec 28, 2011
Bob and Joe, thank you for pointing out both over loading ( I went back and read note 12) and the fact that the E-bus should be working with the Alter nate switch off. To tell the truth, I have not tried it that way (w/just th e Master on). If it does not work I do see that would mean the diode betwee n the two buses is in backwards. I did check the diode position on the Batt Contactor and it IS installed the right way. I now have at the very least, some changing of circuits over to the Main bus. Will report back on findin gs after tomorrow.-=0ADan=0A=0A=0A=0A>________________________________=0A > From: user9253 <fran4sew(at)banyanol.com>=0A>To: aeroelectric-list@matronics .com =0A>Sent: Wednesday, December 28, 2011 8:25 AM=0A>Subject: AeroElectri c-List: Re: First Engine Start Problem=0A> =0A>--> AeroElectric-List messag e posted by: "user9253" =0A>=0A>=0A>> No, the E-Bus switch must be ON in order for any of the accessories to operate. I will ta ke another look at the diode polarity as well. One of the guys I am working with suggested I not turn on the E-Bus switch until After I start the engi ne.=0A>=0A>The E-Bus should be energized with the E-Bus switch off and the master switch on.- If not, the diode is backwards.=0A>- Although it wil l not hurt anything to fly with the E-Bus switch turned on, it is intended to be turned on only in the event that power is not available through the d iode.=0A>Joe=0A>=0A>--------=0A>Joe Gores=0A>=0A>=0A>=0A>=0A>Read this topi c online here:=0A>=0A>http://forums.matronics.com/viewtopic.php?p=361838# =========================0A - - - - - - - - - - - - -Matt Dralle, List Admin. =====0A>=0A>=0A>=0A>=0A>=0A> ________________________________________________________________________________
Date: Dec 28, 2011
At 07:39 PM 12/28/2011, you wrote: >Bob and Joe, thank you for pointing out both over loading ( I went >back and read note 12) and the fact that the E-bus should be working >with the Alternate switch off. To tell the truth, I have not tried >it that way (w/just the Master on). If it does not work I do see >that would mean the diode between the two buses is in backwards. I >did check the diode position on the Batt Contactor and it IS >installed the right way. I now have at the very least, some changing >of circuits over to the Main bus. Will report back on findings after tomorrow. Blowing a fusible link is a rather non-trivial event. 22AWG wire is capable of considerable more current than the legacy rating in wire bundles of 5A would suggest. It would be interesting to get a real current measurement of all your goodies before you start moving things. Clip an ammeter across the alternate feed switch while the master switch is off. Bob . . . ________________________________________________________________________________
Date: Dec 28, 2011
Subject: Main Battery Contactor
Hey Bob... I'm looking at Z-12! Can you tell me the difference between the Battery Contactor(no number) on Z-12 and B&C's - S701-1? Are they the same... and Can the S701-1 be used for the main battery contactor? Thanks Ron ________________________________________________________________________________
Date: Dec 29, 2011
Subject: Re: Main Battery Contactor
At 08:32 PM 12/28/2011, you wrote: > >Hey Bob... > >I'm looking at Z-12! Can you tell me the difference between the >Battery Contactor(no number) >on Z-12 and B&C's - S701-1? Are they the same... and Can the >S701-1 be used for the main >battery contactor? The S701-1 and variants are offered as continuous duty contactors suitable for use as a battery master, cross-feed, or other service that does not require SWITCHING of heavy loads. I.e, the contactor will provide a useful service life CARRYING large loads (100+ amps) after the contacts are closed and stable. S702-1 style contactors are intermittent duty devices quite unsuited to tasks outlined above but optimized to manage the large switching loads associated with starter and landing gear pump motors. Bob . . . ________________________________________________________________________________
Date: Dec 29, 2011
At 08:32 PM 12/28/2011, you wrote: > >Hey Bob... > >I'm looking at Z-12! Can you tell me the difference between the >Battery Contactor(no number) >on Z-12 and B&C's - S701-1? Are they the same... and Can the >S701-1 be used for the main >battery contactor? Why z-12 and not Z-13/8? What kind of airplane are you building and how do you intend to use it? Bob . . . ________________________________________________________________________________
Date: Dec 29, 2011
Just got back from the airport and found the following:=0A1.I took the amme ter reading across the Alternate switch (with the Master switch off). I was reading at 5.2 A with everything on and that was without keying the mic fo r transmission. I assume that would bump it up even more (didn't get a chan ce to try that).-=0A2. The Diode between the two buses WAS backwards. I c hanged it and now my panel lights up when the Master switch is on. Would th is have had any bearing on why my fuseable link burned or do you think I ne ed to move some things to the Main bus? The components I have on the E-bus are as follows:=0ADynon D100, Garmin 396, EIS (engine monitor), SL40 radio, Transponder, LED Becon and tail position light, Intercom, HZ Stab trim ser vo. I don't have wing tip position/Nav lights yet but can probably put them on the main bus along with the other lights when I get them. The other thi ng I was toying with is moving the D-100 and the 396 over as they both have back-up batteries Thoughts or suggestions welcome.=0AThanks,=0ADan=0A=0A =0A=0A>________________________________=0A> From: "Robert L. Nuckolls, III" =0A>To: aeroelectric-list(at)matronics.com =0A >Sent: Wednesday, December 28, 2011 6:54 PM=0A>Subject: Re: AeroElectric-Li st: Re: First Engine Start Problem=0A> =0A>--> AeroElectric-List message po sted by: "Robert L. Nuckolls, III" =0A>=0A>A t 07:39 PM 12/28/2011, you wrote:=0A>> Bob and Joe, thank you for pointing out both over loading ( I went back and read note 12) and the fact that the E-bus should be working with the Alternate switch off. To tell the truth, I have not tried it that way (w/just the Master on). If it does not work I do see that would mean the diode between the two buses is in backwards. I d id check the diode position on the Batt Contactor and it IS installed the r ight way. I now have at the very least, some changing of circuits over to t he Main bus. Will report back on findings after tomorrow.=0A>=0A>- Blowi ng a fusible link is a rather non-trivial=0A>- event. 22AWG wire is capa ble of considerable=0A>- more current than the legacy rating in wire=0A> - bundles of 5A would suggest.=0A>=0A>- It would be interesting to ge t a real current=0A>- measurement of all your goodies before you=0A>- start moving things. Clip an ammeter across=0A>- the alternate feed swi tch while the master=0A>- switch is off.=0A>=0A>=0A>- Bob . . . =0A> ================0A>=0A>=0A>=0A>=0A>=0A> ________________________________________________________________________________
Date: Dec 29, 2011
The diode being backwards was the reason the fusible link burned open. Part of the starter current was going through the E-Bus circuit. There is a saying that electricity takes the path of least resistance. Even though there is a big fat wire going from the battery to the starter, that path is not the least resistance for ALL of the current. Some of the current will find it easier to take parallel paths. An analogy is highway traffic. Most cars will take the multi-lane expressway. But when traffic is very heavy and slows down, some cars will take side streets. For them it is the path of least resistance. Your lighting circuit could be moved to the main bus. The E-Bus should handle 5 amps OK. The additional 2 amps while transmitting is of short duration and should not burn open the fusible link. I will not be offended if Bob or anyone corrects me. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361963#361963 ________________________________________________________________________________
Date: Dec 30, 2011
At 09:45 PM 12/29/2011, you wrote: The diode being backwards was the reason the fusible link burned open. Part of the starter current was going through the E-Bus circuit. There is a saying that electricity takes the path of least resistance. Even though there is a big fat wire going from the battery to the starter, that path is not the least resistance for ALL of the current. Some of the current will find it easier to take parallel paths. An analogy is highway traffic. Most cars will take the multi-lane expressway. But when traffic is very heavy and slows down, some cars will take side streets. For them it is the path of least resistance. Your lighting circuit could be moved to the main bus. The E-Bus should handle 5 amps OK. The additional 2 amps while transmitting is of short duration and should not burn open the fusible link. I will not be offended if Bob or anyone corrects me. You are right on my friend. I will remind readers that the e-bus (while once erroneously called an "essential bus") was crafted for the purpose of keeping an alternator- out event from becoming an emergency. Hence, it was re-named the Endurance Bus. Successful and worry free application of the e-bus is dependent upon TWO things. (1) Knowing the minimum amount of energy stored in the battery and (2) knowing how many hours of flight are possible while being a good student of Energy Economics. One of my most cherished teachers, Thomas Sowell told me that economics is the study of scarce resources for which there are multiple uses. In this case, the scarce resource is watt-seconds of electrical energy available to run JUST the electro- whizzies most useful or en route operations. Once you have the airport of intended destination in sight, the scarcity of watt-seconds disappears. My personal design goal for sizing and powering the e-bus is to have more hours of en-route ops available from the electro- whizzies than I have fuel aboard. Everybody plans for there to be enough fuel for the mission leg . . . it seems that having a properly crafted e-bus is a good move for making a dead alternator a maintenance event as opposed to an emergency. Some years ago at Oshkosh, I suggested in one of my forums that system reliability is achieved when you can deal with any single failure without breaking a sweat. Since the people who own the airplanes I rent would not let me re-arrange their bus structures, my personal e-bus is powered by alkaline cells. http://tinyurl.com/4xjhgly Whether I'm flying a J-3 or an A-36, I can confidently get where I want to go on an exceedingly austere budget of self contained watt-seconds. I recommend that the builder craft a Plan-B for alternator out-ops that includes periodic capacity checks to make sure that their battery's current state will carry e-bus loads for the duration of their personal design goals. Whether that's 1 hour or duration of fuel aboard is your decision. But knowing WHAT it is an maintaining it is essential to the no-sweat management of an alternator-out event. You can obviously have more than necessary goodies on the e-bus . . . as long as they have ON-OFF switches. The goal is to have a plan for load-shedding in place that re-configures energy consumption to meet electrical endurance design goals. Over the years I've studied many "Dark-n- Stormy Night" stories and deduced that most if not all would never have been written had the pilot/author had (1) understanding and (2) an artfully crafted and maintained Plan-B. Bob . . . ________________________________________________________________________________
Date: Dec 30, 2011
At 08:33 PM 12/29/2011, you wrote: >Just got back from the airport and found the following: >1.I took the ammeter reading across the Alternate switch (with the >Master switch off). I was reading at 5.2 A with everything on and >that was without keying the mic for transmission. I assume that >would bump it up even more (didn't get a chance to try that). Okay, how does 5.2A fit into your Plan-B? >2. The Diode between the two buses WAS backwards. I changed it and >now my panel lights up when the Master switch is on. Would this have >had any bearing on why my fuseable link burned or do you think I >need to move some things to the Main bus? The components I have on >the E-bus are as follows: >Dynon D100, Garmin 396, EIS (engine monitor), SL40 radio, >Transponder, LED Becon and tail position light, Intercom, HZ Stab >trim servo. I don't have wing tip position/Nav lights yet but can >probably put them on the main bus along with the other lights when I >get them. The other thing I was toying with is moving the D-100 and >the 396 over as they both have back-up batteries Thoughts or >suggestions welcome. See my earlier posting about Plan-B. You don't necessarily need to move anything. But you SHOULD have a check-list driven plan of action for responding to a low-voltage warning light. 5.2A may not be the Plan-B number. The lower you can make it, the more secure you are in dealing with an alternator failure. Bob . . . ________________________________________________________________________________
From: Bob McCallum <robert.mccallum2(at)sympatico.ca>
Date: Dec 30, 2011
Dan; While the reversed diode is definitely the cause of the fused fusible link (in combination with having the alternate feed switch on) and installing the diode correctly will prevent the link failing in the future, (your loads are well within what the link will handle) this might also be an indication that there is a higher than desirable resistance in the "fat wire" circuit. Normally the resistance of the large wires and their connections is very very low and they should present the most attractive path for the starter current. However if one of the connections in this circuit is displaying relatively high resistance due to being loose or dirty or???? Then the parallel path through the miswired e-buss circuit might become more attractive and draw an unusually larger percentage of the starter current aggravating the scenario explained by Joe. It might be worth a simple voltage drop test across the fat wire circuit components while cranking to see if there are any joints or portions of that circuit displaying higher than normal resistance. If wired precisely per Z-16 then the likely source for the high resistance, if it exists, would be one of the connections to the battery contactor or the contactor itself. The other possibility of course is that if you tried to crank the engine with the reversed diode, the alternate feed "on" and the master switch "off" then full cranking current was attempting to pass through your fusible link and "poof". Correctly installing the diode absolutely cures this possibility as well. Bob McC > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list- > server(at)matronics.com] On Behalf Of user9253 > Sent: Thursday, December 29, 2011 10:46 PM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Re: First Engine Start Problem > > > The diode being backwards was the reason the fusible link burned open. Part of the > starter current was going through the E-Bus circuit. There is a saying that electricity > takes the path of least resistance. Even though there is a big fat wire going from the > battery to the starter, that path is not the least resistance for ALL of the current. > Some of the current will find it easier to take parallel paths. An analogy is highway > traffic. Most cars will take the multi-lane expressway. But when traffic is very heavy > and slows down, some cars will take side streets. For them it is the path of least > resistance. > Your lighting circuit could be moved to the main bus. The E-Bus should handle 5 > amps OK. The additional 2 amps while transmitting is of short duration and should > not burn open the fusible link. I will not be offended if Bob or anyone corrects me. > Joe > > -------- > Joe Gores > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=361963#361963 > > > > > > > > _- > ==================================================== > ====== > _- > ==================================================== > ====== > _- > ==================================================== > ====== > _- > ==================================================== > ====== > _- > ==================================================== > ====== > > ________________________________________________________________________________
Subject: Audio out for Aera 560 GPS?
Date: Dec 30, 2011
I'm looking for a sanity check on wiring a Garmin Aera 560 into my panel. My main objective is to get the GPS alerts to my headset. The Garmin documentation for the aviation bare wire mount was not helpful and essentially just says the audio out is: White (Audio Right), Brown (Audio Left) and Green (Audio Common) . Reference http://www8.garmin.com/manuals/aera500_PilotsGuide.pdf page 140 of the manual. Writing and calling Garmin did not prove fruitful as they say the audio out is for a "Marine Sounder" and that I should use the Audio Out stereo out on the side and not these three wires for proper XM music quality. I could find no other documentation. I also have a Sigtronics SPA-4S so in my quest for information I called them. The person at Sigtronics was very helpful and the summary of his advice was this: Connect a 220 ohm 0.25 W resistor to the audio right, another to audio left and then connect the other ends of the resistor together and splice into the J1 connector, Blue wire from radio headphone audio. This should give the proper priority to the GPS audio warnings (Terrain, Airspace, etc.). Adjust the resistor down if needed to increase GPS volume but this will also decrease volume from the radio. Reference diagram at http://www.sigtronics.com/pdf/air_pdf/SPA-4S_King_KY-97A_Inst.pdf So, my questions are; Does this strategy and resistor value sound right to convert this to a mono output? I'm assuming I still connect the Audio common, green wire of the GPS to ground, correct? If I want XM radio, then I would plug into the audio out stereo port on the side of the GPS to the Music Input jack that is wired into intercom. Correct? Any additional guidance or advice would be greatly appreciated! Don Ingalls ________________________________________________________________________________
Date: Dec 30, 2011
Subject: flashing landing lights.
are there any bad effects to my elect. system if i install 2 small halide ''landing lights'' of 55 watts each and wire in 2 automotive flashers so i can use them flashing in the pattern for traffic avoidance..i have a jab 3300. bob noffs ________________________________________________________________________________
Date: Dec 30, 2011
No, no adverse effects, but it's more effective if you use one flasher which alternates the lights rather than two flashers which would have the lights completely random. Suitable flashers are readily available from automotive parts stores and are typically used for such things as the alternating lights on school buses. "Wigwag" flashers are also available from any number of aviation sources. Go to the archives and search "wigwag" for several discussions on the topic. Bob McC _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of bob noffs Sent: Friday, December 30, 2011 5:05 PM Subject: AeroElectric-List: flashing landing lights. are there any bad effects to my elect. system if i install 2 small halide ''landing lights'' of 55 watts each and wire in 2 automotive flashers so i can use them flashing in the pattern for traffic avoidance..i have a jab 3300. bob noffs ________________________________________________________________________________
Date: Dec 30, 2011
I would like to thank all who responded to the issue at hand. I learned many things here, most importantly, how my electrical system is designed to work along with howI need to work. In the world of reading schematics and interpreting how they are to be used...I am STILL learning. My assumptions believing the E-switch was to be on sifted back to when I was flying the rented 172 and of course, there IS a switch that needed to be on for the radios, intercom, Etc... So much for the ASSuming. I was quite surprised when I found my diode in backwards as I am usually quite anal when building circuits, yet, I am now actually glad it happened in this manner as I would have been utilizing my system incorrectly. Thank you Joe for bringing up the possibility of the reversed diode...Spot On Sir. And Thanks again to Bob N. for pointing my brain cell (the one that is still working) to the possible overloading as well as taking a better look at what my Plan_B needs to look like. I will most likely move any lights over to the Main, but more importantly take a close look at how much time a given instrument (as well as combined gizmos) should take me. I will most likely leave my D-100, GPS and the radio where they sit. knowing I can turn one or two off to get my butt to the safety line will always be there. I Wish everyone a Happy New Year! Dan ________________________________ From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Sent: Fri, December 30, 2011 9:26:38 AM Subject: Re: AeroElectric-List: Re: First Engine Start Problem At 08:33 PM 12/29/2011, you wrote: > Just got back from the airport and found the following: > 1.I took the ammeter reading across the Alternate switch (with the Master >switch off). I was reading at 5.2 A with everything on and that was without >keying the mic for transmission. I assume that would bump it up even more >(didn't get a chance to try that). Okay, how does 5.2A fit into your Plan-B? > 2. The Diode between the two buses WAS backwards. I changed it and now my panel >lights up when the Master switch is on. Would this have had any bearing on why >my fuseable link burned or do you think I need to move some things to the Main >bus? The components I have on the E-bus are as follows: > Dynon D100, Garmin 396, EIS (engine monitor), SL40 radio, Transponder, LED >Becon and tail position light, Intercom, HZ Stab trim servo. I don't have wing >tip position/Nav lights yet but can probably put them on the main bus along with >the other lights when I get them. The other thing I was toying with is moving >the D-100 and the 396 over as they both have back-up batteries Thoughts or >suggestions welcome. See my earlier posting about Plan-B. You don't necessarily need to move anything. But you SHOULD have a check-list driven plan of action for responding to a low-voltage warning light. 5.2A may not be the Plan-B number. The lower you can make it, the more secure you are in dealing with an alternator failure. Bob . . . ________________________________________________________________________________
From: "earl_schroeder(at)juno.com" <earl_schroeder(at)juno.com>
Date: Dec 30, 2011
Subject: Re: flashing landing lights.
I'm using two 55 watt 'halide' (one on each landing gear) and using heav y duty truck flashers seem to work OK. EE ---------- Original Message ---------- From: bob noffs <icubob(at)gmail.com> Subject: AeroElectric-List: flashing landing lights. Date: Fri, 30 Dec 2011 16:05:28 -0600 are there any bad effects to my elect. system if i install 2 small halid e ''landing lights'' of 55 watts each and wire in 2 automotive flashers so i can use��them flashing in the pattern for traffic avo idance..i have a jab 3300.� ________________________________________________________________________________
Subject: Wiring Harness
Date: Dec 30, 2011
What are thoughts on creating the electrical wiring harness? I've attached the embrionic schematic (lot's of final design, editing and cleanup to do) just to convey the simplicity of my Zenith CH750 electrical system. Specifically, should I: 1.. mock-up (chalk) an outline of the plane, run the requisite wires, label and bundle them (using expandable sleeving or spiral wrap)? ie. complete an entire harness.... 2.. or, just run wires one at a time and tie wrap and sheath with an expandable sleeve or spiral wrap them once all of the circuits are wired and tested? 3.. what's best to use in as far as a spiral wrap or expandable sleeve? I've heard the term "snakeskin" used.... Much of the drawing/design/symbols in the attached was gleaned from the AeroElectric Connection.... Regards, Dan Sherburn ________________________________________________________________________________
Date: Dec 30, 2011
> The guys that were working with me asked me why that link was there...I did not have a good answer for them. . . .So...I am now reluctant to put another fuseable link in place . . . Without a fusible link and in the event of a short circuit or heavy overload, the full length of the circuit wire could become red hot or even white hot. Think of a fusible link as a robust, slow blowing, fuse. Having a fusible link will ensure that heat and smoke from a circuit fault will occur at a known safe location rather than at a random location in the wire harness. The diode might have been conducting more current than it was designed to carry. A simple test will confirm that it is still blocking reverse current. With the master switch off and the E-Bus switch on, the main bus should not be energized and anything connected to it should not be powered. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362053#362053 ________________________________________________________________________________
Date: Dec 30, 2011
Now that I know why and how the fuseable link burned, I will be replacing it. I have already called my buddies and gave them the answer I was (at the time) unsure about. Joe, I'm glad you addressed the integrity of the diode. It re-affirmed my thoughts as well and I have already decided to replace it (cheap insurance). Thanks again for the assistance. Dan ________________________________ From: user9253 <fran4sew(at)banyanol.com> Sent: Fri, December 30, 2011 5:48:09 PM Subject: AeroElectric-List: Re: First Engine Start Problem > The guys that were working with me asked me why that link was there...I did not >have a good answer for them. . . .So...I am now reluctant to put another >fuseable link in place . . . Without a fusible link and in the event of a short circuit or heavy overload, the full length of the circuit wire could become red hot or even white hot. Think of a fusible link as a robust, slow blowing, fuse. Having a fusible link will ensure that heat and smoke from a circuit fault will occur at a known safe location rather than at a random location in the wire harness. The diode might have been conducting more current than it was designed to carry. A simple test will confirm that it is still blocking reverse current. With the master switch off and the E-Bus switch on, the main bus should not be energized and anything connected to it should not be powered. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362053#362053 ________________________________________________________________________________
Subject: Re: Wiring Harness
Date: Dec 30, 2011
In my case I ran the wires one at a time, building a bundle with wrapping th read ties as necessary to keep the wires parallel. I doubt you would save an y time by trying to make a separate harness like the production companies us e, unless you are going to start producing them. On Dec 30, 2011, at 19:16, "Dan Sherburn" wrote: > What are thoughts on creating the electrical wiring harness? I've attached the embrionic schematic (lot's of final design, editing and cleanup to do) j ust to convey the simplicity of my Zenith CH750 electrical system. > Specifically, should I: > mock-up (chalk) an outline of the plane, run the requisite wires, label a nd bundle them (using expandable sleeving or spiral wrap)? ie. complete an e ntire harness.... > or, just run wires one at a time and tie wrap and sheath with an expandabl e sleeve or spiral wrap them once all of the circuits are wired and tested? > what's best to use in as far as a spiral wrap or expandable sleeve? I've h eard the term "snakeskin" used.... > Much of the drawing/design/symbols in the attached was gleaned from the Ae roElectric Connection.... > > Regards, > Dan Sherburn > > > > ________________________________________________________________________________
Date: Dec 30, 2011
At 06:48 PM 12/30/2011, you wrote: > The guys that were working with me asked me why that link was there...I did not have a good answer for them. . . .So...I > am now reluctant to put another fuseable link in place . . . Without a fusible link and in the event of a short circuit or heavy overload, the full length of the circuit wire could become red hot or even white hot. Think of a fusible link as a robust, slow blowing, fuse. Having a fusible link will ensure that heat and smoke from a circuit fault will occur at a known safe location rather than at a random location in the wire harness. Which is the function of all protective devices for wire. Fuses are very fast comparted to circuit breakers. Circuit breakers are very fast compared to 'current limiters' which are manufactured versions of fusible links. See: http://aeroelectric.com/Mfgr_Data/Fuses_and_Current_Limiters/Bussman/ANL_Specs.pdf Note that an ANL35 will carry 80 amps indefinitely at room temperature. Say what???? A 35 amp fuse needs to be operated at no more than 75% of rating to avoid long term weakening of the fusible element. The difference in these two devices is their application. A line fault where a fuse is wired upstream of a breaker will probably open a fuse several times the size of the breaker. Current limiters (and fusible links) are used upstream of both fuses and breakers in cars and airplanes. They have VERY long time constants compared to the downstream devices . . . yet they provide the same 'weak link in chain' that guarantees a predictable failure. The provide an orderly failure location for a faulted feeder that is robust enough not to compromise the performance of downstream protection. This is exactly what YOUR fusible link did. Had it not been installed, you would have probably overheated if not smoked the protected wire . . . possibly damaging other wires in the bundle. If you wanted to put a 20A, in-line fuse holder in its place, that would be fine too as long as you don't have BREAKERS downstream. I'm working an accident case right now that involved poor choice and placement of fuses and breakers combined with an architecture that offered several single points of failure for all ignition to the engine . . . not good. We'll discuss it in detail once the dust settles on the legal tug-of-war. The lesson here is that the 'rating' of a fuse, breaker, limiter, or link is only roughly tied to performance. Until you trade of TIME to OPERATE values, you don't know the whole story. The diode might have been conducting more current than it was designed to carry. A simple test will confirm that it is still blocking reverse current. With the master switch off and the E-Bus switch on, the main bus should not be energized and anything connected to it should not be powered. Replacing it is a good idea. It's easier to simply install a new one than it is to test the old one for changes in performance due to the fault condition. Bob . . . ________________________________________________________________________________
Date: Dec 31, 2011
1. Seems like more work than necessary. Getting all the physical position relationships seem tough. Remember not all the wires have the same end point locations. 2. This is what I did and worked quite well. Just remember to add a little extra for service loops and to give you some flexibility when you go back to start tying up your bundles and installing adel clamps to hold them in place. I used nylon tie wraps with large open loops so that it would hold the bundles in their relative position and it was easy to insert additional wire. When I was done, I came back with lacing and tied the bundles and cut the tie wraps. Then I installed a few adel clamps to keep the bundles secured. bob From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Dan Sherburn Sent: Friday, December 30, 2011 7:17 PM Subject: AeroElectric-List: Wiring Harness What are thoughts on creating the electrical wiring harness? I've attached the embrionic schematic (lot's of final design, editing and cleanup to do) just to convey the simplicity of my Zenith CH750 electrical system. Specifically, should I: 1. mock-up (chalk) an outline of the plane, run the requisite wires, label and bundle them (using expandable sleeving or spiral wrap)? ie. complete an entire harness.... 2. or, just run wires one at a time and tie wrap and sheath with an expandable sleeve or spiral wrap them once all of the circuits are wired and tested? 3. what's best to use in as far as a spiral wrap or expandable sleeve? I've heard the term "snakeskin" used.... Much of the drawing/design/symbols in the attached was gleaned from the AeroElectric Connection.... Regards, Dan Sherburn ________________________________________________________________________________
Date: Dec 31, 2011
Hi Dan, I find drawing different views helps. You already have a schematic, a location drawing could be useful to allow you to site the components and figure out where the wires will run. You will likely place the starter and master solenoids close together, so it will also give you a feel for how long each wire will be. Draw what the bus bars will look like (will you use a fuse block?), to give yourself an idea of the lay out. I start by mounting the fuse blocks/buses/breakers and start running wires. It always takes more wire than you think once it is tied down, so do that as you go - very frustrating to cut a wire too short! I have used expandable sleeve, but don't really like spiral wrap unless anti chafe protection is needed. If using expandable sleeve you may have to start feeding wires from the beginning as it may not be possible to feed it over any spurs. If you don't use a sleeve you could use spring clips to hold things in place until everything is run and then tie up with lacing cord. Hope this helps, Peter BTW, I'm not sure your alternator output will be very useful wired in as shown - perhaps it should go to the main bus or battery contactor? On 31/12/2011 00:16, Dan Sherburn wrote: > What are thoughts on creating the electrical wiring harness? I've > attached the embrionic schematic (lot's of final design, editing and > cleanup to do) just to convey the simplicity of my Zenith CH750 > electrical system. > Specifically, should I: > > 1. mock-up (chalk) an outline of the plane, run the requisite wires, > label and bundle them (using expandable sleeving or spiral wrap)? > ie. complete an entire harness.... > 2. or, just run wires one at a time and tie wrap and sheath with an > expandable sleeve or spiral wrap them once all of the circuits are > wired and tested? > 3. what's best to use in as far as a spiral wrap or expandable > sleeve? I've heard the term "snakeskin" used.... > > Much of the drawing/design/symbols in the attached was gleaned from > the AeroElectric Connection.... > Regards, > Dan Sherburn ________________________________________________________________________________
Date: Dec 31, 2011
12/31/2011 Hello Matt, Attached are pictures of the two static ports on the foward fuselage sides of my KIS TR-1: 0599 is the plain static port on the right side of the fuselage. 0602 is the same basic static port on the left side of the fuselage, but with a self made aluminum wedge installed on it. Since the wedge is installed aft of the opening in the static port it has the effect of slightly increasing the static pressure that this port is sensing and sending to the rest of the static portion of the pitot static system. This slight increase in static pressure, in the airspeed indicator, balances out or reduces the effective force being applied to the indicator by the air pressure coming in from the pitot tube. The result is that the airspeed indicator indicates a slightly lower airspeed than it would without the wedge. A wedge applied before the static port opening would have the opposite effect. Plan on doing a lot of test flying to get your wedge(s) fine tuned to accomplish what you want in the way of airspeed reading without significantly adversely affecting your altimeter readings. My thinking is that it is more important to have the airspeed reading what it should be in the approach speed arena rather than the cruise speed arena. 'OC' Baker Says: "The best investment we can make is the time and effort to gather and understand knowledge." ________________________________________________________________________________
Date: Dec 31, 2011
=0A=0A=0A=0A=0A>________________________________=0A> From: "Robert L. Nucko lls, III" =0A>To: aeroelectric-list@matronic s.com =0A>Sent: Friday, December 30, 2011 8:14 PM=0A>Subject: Re: AeroElect ric-List: Re: First Engine Start Problem=0A> =0A>--> AeroElectric-List mess age posted by: "Robert L. Nuckolls, III" =0A >-This is exactly what YOUR fusible link did. Had it not been=0A>- inst alled, you would have probably overheated if not smoked=0A>- the protecte d wire . . . possibly damaging other wires in=0A>- the bundle.-=0A>Whic h is something that concerns me due to my knee jerk reaction of sticking an 18 Ga wire in and starting my engine 3 times that day. The total time I ra n the engine between the three starts was about 10 min. -My thinking that the running of the engine may not have been so bad but the starts- put s train on the circuit with that diode reversed. I will certainly inspect tha t complete circuit looking for any sign of where the wire got too hot. I al so have a concern for the wires up stream of the main bus going to the swit ch. The 5A circuit breaker did not fail, but I will check that fuse link as well. Is there anything else I might be missing that needs a look?=0A>Than ks again,=0A>Dan=0A>=0A>=0A>=0A>=0A>=0A>=0A>=0A>=0A>=0A>=0A>=0A>=0A>== =============0A>=0A>=0A>=0A>=0A>=0A> ________________________________________________________________________________
Date: Dec 31, 2011
I just did all this on my plane, the GRT equipment has a calibration utility built in that makes it a snap. Just fly the heading displayed and push a button for a given airspeed. Very simple &easy. I would imagine the Dynon has something similar. Tim Sent from my iPad On Dec 31, 2011, at 5:00 AM, wrote: > 12/31/2011 > > Hello Matt, Attached are pictures of the two static ports on the foward fuselage sides of my KIS TR-1: > > 0599 is the plain static port on the right side of the fuselage. > > 0602 is the same basic static port on the left side of the fuselage, but with a self made aluminum wedge installed on it. > > Since the wedge is installed aft of the opening in the static port it has the effect of slightly increasing the static pressure that this port is sensing and sending to the rest of the static portion of the pitot static system. This slight increase in static pressure, in the airspeed indicator, balances out or reduces the effective force being applied to the indicator by the air pressure coming in from the pitot tube. The result is that the airspeed indicator indicates a slightly lower airspeed than it would without the wedge. > > A wedge applied before the static port opening would have the opposite effect. > > Plan on doing a lot of test flying to get your wedge(s) fine tuned to accomplish what you want in the way of airspeed reading without significantly adversely affecting your altimeter readings. > > My thinking is that it is more important to have the airspeed reading what it should be in the approach speed arena rather than the cruise speed arena. > > 'OC' Baker Says: "The best investment we can make is the time and effort to gather and understand knowledge." > <100_0599.jpg> > <100_0602.jpg> ________________________________________________________________________________
Date: Dec 31, 2011
Peter, Oops....you are correct on the alternator wire. The drawing should have had the output wire of the alternator going to the other side of the starter contactor. Thanks for the catch! In as far as wiring, I'm thinking you are correct, in as far as the bundle. I'm using a fuse block as the buss and will start running device wires individually from there and then bundle. As Bob suggests in his book, I'm creating a "wire-book" that has component location drawings, as well as detailed connection drawings I get from manufacturers (like the strobe/ position lights). Thanks again for the note. Dan ----- Original Message ----- From: Peter Pengilly To: aeroelectric-list(at)matronics.com Sent: Saturday, December 31, 2011 6:26 AM Subject: Re: AeroElectric-List: Wiring Harness Hi Dan, I find drawing different views helps. You already have a schematic, a location drawing could be useful to allow you to site the components and figure out where the wires will run. You will likely place the starter and master solenoids close together, so it will also give you a feel for how long each wire will be. Draw what the bus bars will look like (will you use a fuse block?), to give yourself an idea of the lay out. I start by mounting the fuse blocks/buses/breakers and start running wires. It always takes more wire than you think once it is tied down, so do that as you go - very frustrating to cut a wire too short! I have used expandable sleeve, but don't really like spiral wrap unless anti chafe protection is needed. If using expandable sleeve you may have to start feeding wires from the beginning as it may not be possible to feed it over any spurs. If you don't use a sleeve you could use spring clips to hold things in place until everything is run and then tie up with lacing cord. Hope this helps, Peter BTW, I'm not sure your alternator output will be very useful wired in as shown - perhaps it should go to the main bus or battery contactor? On 31/12/2011 00:16, Dan Sherburn wrote: What are thoughts on creating the electrical wiring harness? I've attached the embrionic schematic (lot's of final design, editing and cleanup to do) just to convey the simplicity of my Zenith CH750 electrical system. Specifically, should I: 1.. mock-up (chalk) an outline of the plane, run the requisite wires, label and bundle them (using expandable sleeving or spiral wrap)? ie. complete an entire harness.... 2.. or, just run wires one at a time and tie wrap and sheath with an expandable sleeve or spiral wrap them once all of the circuits are wired and tested? 3.. what's best to use in as far as a spiral wrap or expandable sleeve? I've heard the term "snakeskin" used.... Much of the drawing/design/symbols in the attached was gleaned from the AeroElectric Connection.... Regards, Dan Sherburn ________________________________________________________________________________
Date: Dec 31, 2011
Subject: KX155/165 Crimp Contacts
Hello! Does anyone know the actual part number of the contacts used for the KX155 connectors? I know they're AMP or Molex, but not the manufacturer part number....want to avoid paying the exorbitant prices when buying them thru avionics channels. Appreciate any info! Want to stock up. Thanks David -- Thanks! David Jensen djensen(at)ieee.org ________________________________________________________________________________
Subject: charging a battery assistance
Date: Dec 31, 2011
List members, I'm restoring a Honda CL125 Scrambler, and I have a dilemma. It has a brand new 6 volt battery, but it's very low, and I need to recharge it. I have a regular 12V car battery charger, and a 12V Float Charger, neither of which is appropriate to charge a little 6V dinky M/C battery. Is there a way I can charge this little 6V battery with a home-made modification to that Float Charger, or could I use one of those "Wall Chargers"? I've got tons of them from ALL kinds of electric goodies over the years (I bet I have about 30 of them in all kinds of outputs). The Float Charger says "INPUT 120VAC 14W---OUTPUT 15VAC 600mA, and it has some sort of little rectangular box inline in the battery cable to the leads. I realize this isn't directly airplane related, but maybe the electric pointers and theory will be helpful to many list members, like me. Thanks for your help!! Mike Welch ________________________________________________________________________________
Subject: Re: KX155/165 Crimp Contacts
Date: Dec 31, 2011
Sure...and the extractor too: http://www.berkut13.com/extractor.htm From: David Jensen Sent: Saturday, December 31, 2011 12:41 PM Subject: AeroElectric-List: KX155/165 Crimp Contacts Hello! Does anyone know the actual part number of the contacts used for the KX155 connectors? I know they're AMP or Molex, but not the manufacturer part number....want to avoid paying the exorbitant prices when buying them thru avionics channels. Appreciate any info! Want to stock up. Thanks David -- Thanks! David Jensen djensen(at)ieee.org ________________________________________________________________________________
Date: Dec 31, 2011
Mike - Schumacher's 1562A will fit your need. http://www.amazon.com/Schumacher-SEM-1562A-Speed-Charge-Maintainer/dp/B0009I BJAS Neal -----Original Message----- List members, I'm restoring a Honda CL125 Scrambler, and I have a dilemma. It has a brand new 6 volt battery, but it's very low, and I need to recharge it. I have a regular 12V car battery charger, and a 12V Float Charger, neither of which is appropriate to charge a little 6V dinky M/C battery. Is there a way I can charge this little 6V battery with a home-made modification to that Float Charger, or could I use one of those "Wall Chargers"? I've got tons of them from ALL kinds of electric goodies over the years (I bet I have about 30 of them in all kinds of outputs). The Float Charger says "INPUT 120VAC 14W---OUTPUT 15VAC 600mA, and it has some sort of little rectangular box inline in the battery cable to the leads. I realize this isn't directly airplane related, but maybe the electric pointers and theory will be helpful to many list members, like me. Thanks for your help!! Mike Welch ________________________________________________________________________________
Subject: Re: charging a battery assistance
Date: Jan 01, 2012
When faced with a similar situation, I use a resistance connected in series with my (old technology) charger to limit the charging current; especially initially with a dead small battery. I use an old automotive ceramic ignition resistor to limit current, but paralled incandescent light bulbs could also be used. -------- Jerry King Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362186#362186 ________________________________________________________________________________
Date: Jan 01, 2012
Limiting the current is key of course. But, if you are going to risk this method of charging, you must stand by to stop the charging at the limit of a 6 v. battery. Otherwise, even thou current limited, it will just keep charging up to the voltage this 12 v. charger would normally put out. The poor 6 v. battery would be gassed out of existence and probably do some type of internal "melt down". Just have a good volt meter standing by and test the battery every 15 min. or less and kill the charge when it gets to about 6.8 volts, or 7 volts max. ____________________________________________________ ----- Original Message ----- From: "racerjerry" <gki(at)suffolk.lib.ny.us> Sent: Sunday, January 01, 2012 11:50 AM Subject: AeroElectric-List: Re: charging a battery assistance > > > When faced with a similar situation, I use a resistance connected in > series with my (old technology) charger to limit the charging current; > especially initially with a dead small battery. I use an old automotive > ceramic ignition resistor to limit current, but paralled incandescent > light bulbs could also be used. > > -------- > Jerry King > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=362186#362186 > > > ________________________________________________________________________________
Date: Jan 01, 2012
Thanks guys for the replies. I found a Shumacher 1562A I was going to buy at a good price. But before I committed to buy it, I thought I'd let the battery sit overnight, and see if it would recharge itself. Today is had enough plenty of power to allow me to kickstart the bike. I would prefer not to buy another charger unless I REALLY have to. I have one Sears big unit and 3 Harbor Freight battery tenders/maintainers (for rarely used equipment). At this point, I think I have enough info & help, thanks to you guys. I should be in good shape....unless I leave the key on again. If I do, I'll buy the Schumacher! Mike Welch On Jan 1, 2012, at 6:30 PM, David Lloyd wrote: > > Limiting the current is key of course. But, if you are going to risk this method of charging, you must stand by to stop the charging at the limit of a 6 v. battery. Otherwise, even thou current limited, it will just keep charging up to the voltage this 12 v. charger would normally put out. The poor 6 v. battery would be gassed out of existence and probably do some type of internal "melt down". Just have a good volt meter standing by and test the battery every 15 min. or less and kill the charge when it gets to about 6.8 volts, or 7 volts max. > > ____________________________________________________ > ----- Original Message ----- From: "racerjerry" <gki(at)suffolk.lib.ny.us> > To: > Sent: Sunday, January 01, 2012 11:50 AM > Subject: AeroElectric-List: Re: charging a battery assistance > > >> >> When faced with a similar situation, I use a resistance connected in series with my (old technology) charger to limit the charging current; especially initially with a dead small battery. I use an old automotive ceramic ignition resistor to limit current, but paralled incandescent light bulbs could also be used. >> >> -------- >> Jerry King >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=362186#362186 >> >> >> >> >> >> >> >> >> > > > > > > ________________________________________________________________________________
From: "dougshep(at)netzero.com" <dougshep(at)NetZero.com>
Date: Jan 01, 2012
Subject: Re: Audio out for Aera 560 GPS?
I also am interfacing a panel mount 560 with my avionics (PMS6000B audio panel). I use their bare wires cable 010-11385-03. Your questions: Does this strategy and resistor value sound right to convert this to a mono output? Yes. I contacted Garmin (phone 1-866 739-5687). They told me "The Audio Left and Right outputs on the bare wires cable 010-11385-03, outputs both Aviation Alerts and XM Radio. To connect to a mono audio panel, they suggest using either two 100 or 120 ohm resistors, each in series with the audio outputs, then connecting them together to an audio panel input. " I tried this on the bench and it worked OK. I'm assuming I still connect the Audio common, green wire of the GPS to ground, correct? Yes. This is their common, or return, lead. If I want XM radio, then I would plug into the audio out stereo port on the side of the GPS to the Music Input jack that is wired into intercom. Correct? The 010-11385-03 cable has all the necessary connections, except antennas, to interface to other avionics equipment. This includes the AERAs RS-232 output, and its power input. Also note, the Left and Right audio outputs have an 8 ohm source impedance. Doug Shepard, RV-9A, Avionics wiring ________________________________________________________________________________
Date: Jan 01, 2012
I'd try asking a few neighbors about their battery chargers. I've got one that's only about 20 years old that has a 6 volt setting. (You'd still have to monitor it when using one of those older chargers, but at least you wouldn't be feeding it 16-18 volts as it comes up to full charge. On 01/01/2012 06:30 PM, David Lloyd wrote: > > > Limiting the current is key of course. But, if you are going to risk > this method of charging, you must stand by to stop the charging at the > limit of a 6 v. battery. Otherwise, even thou current limited, it > will just keep charging up to the voltage this 12 v. charger would > normally put out. The poor 6 v. battery would be gassed out of > existence and probably do some type of internal "melt down". Just > have a good volt meter standing by and test the battery every 15 min. > or less and kill the charge when it gets to about 6.8 volts, or 7 > volts max. > > ____________________________________________________ > ----- Original Message ----- From: "racerjerry" <gki(at)suffolk.lib.ny.us> > To: > Sent: Sunday, January 01, 2012 11:50 AM > Subject: AeroElectric-List: Re: charging a battery assistance > > >> >> >> When faced with a similar situation, I use a resistance connected in >> series with my (old technology) charger to limit the charging >> current; especially initially with a dead small battery. I use an >> old automotive ceramic ignition resistor to limit current, but >> paralled incandescent light bulbs could also be used. >> >> -------- >> Jerry King >> ________________________________________________________________________________
Subject: Capacitive Fuel Level Sensor - How do they work?
Date: Jan 01, 2012
How do capacitive fuel sensors work? Can someone give me the general theory of operation, what type of signal does the transducer produce? Why do I want one? Etc? TIA ________________________________________________________________________________
Date: Jan 01, 2012
Dan, I am just starting my wiring diagram on a Tundra w/ IO-360. I have decided to follow Bob's suggestion to use the Z-12 schematic (dual alternators, single battery) and I'm assembling the various parts. While I have worked on the wiring of two Glastars I have never done anything like this and I am looking to our group for ideas. I have Bob's book and continue to study it. His statement about the difference between a 'Schematic' drawing and a 'mechanical' drawing has really hit home. Just knowing which components belong in the engine compartment (contactors, shunts, current limiters, ??) and which to mount on the cockpit side of the firewall and then which to mount on the panel itself would be a great start on doing a mechanical drawing. These thoughts may seem vary 'logical' to those with experience but no so to this novice. Anyway, I sure appreciate your questions and the answers that have come forth. Since I could not find your schematic on the list I look forward to you sending it direct. I will begin to check the archives for topics on this. Jim Kinninger jimk(at)hdiss.net ________________________________________________________________________________
Subject: Re: Capacitive Fuel Level Sensor - How do they work?
Date: Jan 02, 2012
http://www.discovercircuits.com/PDF-FILES/capgage.pdf A capacitor is constructed of two parallel conductors insulated from each other. The amount of capacitance is related to the distance between the conductors and the type of insulation. The insulation between the conductors of a capacitance fuel level probe consists of air and/or fuel. As the fuel lever changes, so does the capacitance. The capacitance is part of an oscillator circuit. As the capacitance changes, so does the oscillator frequency. The frequency is converted to a voltage that is displayed with a fuel gauge. The advantage of a capacitance type fuel level probe is that there are no moving parts. The disadvantage is that the gauge must be calibrated each time that the type of fuel is changed because unleaded fuel and leaded fuel and gasohol each have different insulating properties. When the fuel tank is almost full, the capacitance fuel gauge will display different levels depending on the type of fuel in the tank. When the tank is almost empty, the fuel gauge will be more accurate because air is now the insulating medium and the probe does not know or care what type of fuel used to be in the tank. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362211#362211 ________________________________________________________________________________
Date: Jan 02, 2012
You just make a capacitor where the gap between the two plates of the cap (or the gap between a central wire and an outer tube, or whatever the geometry of the cap is) is open to the gasoline in the tank. The gasoline serves as the electrolyte in the capacitor. If the cap. is completely submerged, then the gap between the 2 parts of the cap is completely full of electrolyte and the capacitance of the the thing is maximized. As the gasoline level drops, the portion of the gap that is filled with fuel , and hence has elevated capacitance, decreases. So the overall capacitance of the capacitor changes with fuel level. So you put this cap. into a circuit that allows you to measure the capacitance. The easiest way is to make an oscillator circuit and measure the frequency of the oscillator. The frequency of the oscillator will change with the fuel level. The problem is that it's hard to make a cap. whose capacitance varies a lot with the presence or absence of the gas. The variation in capacitance is usually in the range of a few hundred picofarads - not much. So the circuit that measures the capacitance has to be right there at the capacitor because if it was 10 feet away, the wires going to the cap would have way more capacitance than the capacitor itself. (I understand they actually made this mistake on the A-10 fuel systems. Made them very flaky and failure prone.) I have the Princeton capacitive fuel sensors in my 6A and wish that I didn't. (They're the tube with central wire type of design) They show full until you get down to the last 5 or 6 gallons of gas. So if I see them "off the peg" much at all it means I have very little fuel left. Fortunately my fuel flow integrator in the VM-1000 engine monitor I have is accurate. Also, I understand they get badly confused if any water gets into them. If I were to change from 100LL to auto gas they would have to be recalibrated because autogas has significantly different electrolyte properties. (Recalibrating is doable but kind of a pain since you have to drain the tank.) If I had it to do over, I'd use the ancient float with potentiometer style of fuel level transducer. The Princeton probes sold by Aircraft spruce were designed by a guy named Todd who actually works for Grand Rapids, or at least did the last time I talked to him. Well, I inferred that he designed them. I'm guessing he did that before he joined (or formed?) GRT and still performs as "Princeton" on the side. - just a theory on my part, having been in the electronics business. On Sun, Jan 1, 2012 at 10:13 PM, Jeff Luckey wrote: > JLuckey(at)pacbell.net> > > > How do capacitive fuel sensors work? > > Can someone give me the general theory of operation, what type of signal > does the transducer produce? Why do I want one? Etc? > > TIA > > -- Tom Sargent ________________________________________________________________________________
Subject: Fuel
Date: Jan 02, 2012
Sent from my iPad On Jan 2, 2012, at 1:31 AM, user9253 wrote: > unleaded fuel and leaded fuel and gasohol each have different insulating properties I can understand ethanol, being polar, having a quite different dielectric constant. It seems unlikely that adding a very small amount of non-conducting tetra ethyl lead to gasoline would change the dielectric properties. Do you have a reference? Paul ________________________________________________________________________________
Date: Jan 02, 2012
The electronics have been explained by Joe and Sarg, and Sarg elaborated on his experience with Princeton probes. But the reason for installing cap probes has gone unanswered. Cap probes allow for fuel measurement of irregularly shaped tanks. My fuel bays in the wing change in taper, both in depth and width, in addition to the whole tank sitting at an angle (dihedral), making any kind of accurate measurement impossible over the tank range when using a linear type (float) sensor. I have installed 8' Centroid probes. Haven't fueled them yet. They come with two small potentiometers built in to adjust the empty and full points. Available in 0-5v output and various resistance output so you can use them with your existing gauge. http://www.centroidproducts.com/tableofc.htm Not a recommendation, just a resource, as I have no real world experience with this product, . YMMV. John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362237#362237 ________________________________________________________________________________
Date: Jan 02, 2012
At 12:41 PM 12/31/2011, you wrote: >Hello! > >Does anyone know the actual part number of the contacts used for the >KX155 connectors? I know they're AMP or Molex, but not the >manufacturer part number....want to avoid paying the exorbitant >prices when buying them thru avionics channels. > >Appreciate any info! Want to stock up. This style connector was very popular from the time that etched circuit boards became commonplace and up until about 20 years ago. The really cool thing about this connector technology was the ability to fabricate the male portion of the wiring mate-up right onto the etched circuit board. This often added a demand for special treatment of the male "pins" to have them gold plated for resistance to corrosion. AMP, Molex, Cinch, and dozens of others rose to the opportunity and offered mating female connectors in a variety of pitches . . . but 0.156" spacing was popular. This technology is still used in computers as many of the accessory boards we plug into a mother board have card edge connectors but they tend to be much finer pitch. This configuration of connector fell out of favor for airframe harnesses due to the lack of environmental robustness. No new radios have been built with this style harness connector in quite some time. As one might expect, most if no all producers of this connector have discontinued manufacturing new parts. Due to past popularity, there are still many parts of the style in new-old-stock inventories but specific parts are becoming more difficult to find every year. The pins are much easier to find than some sizes of housing. The pins you're looking for are Molex 4366 series p/n 08-05-0302 20-18AWG pins with gold flash. http://tinyurl.com/6nkcv5n Mouser still seems to have these on hand in some quantity. http://tinyurl.com/6sfazya For individuals looking for a work-around to replace one of these connectors (many popular radios using 156 card edge connectors are still in service) consider this or some similar work around. http://tinyurl.com/6s949t3 http://tinyurl.com/7zqx4r6 http://tinyurl.com/6towcwh 156 pitch connectors in various sizes and styles are readily available as new-old-stock and can often be adapted to your task of keeping a serviceable radio airworthy. For a general posting of data on the Molex/Waldom series of connectors see: http://tinyurl.com/7t6jjsc Bob . . . ________________________________________________________________________________
Date: Jan 02, 2012
work? Are they reliable and relatively accurate? David user9253 wrote: > --> AeroElectric-List message posted by: "user9253" > > http://www.discovercircuits.com/PDF-FILES/capgage.pdf > A capacitor is constructed of two parallel conductors insulated from each other. The amount of capacitance is related to the distance between the conductors and the type of insulation. The insulation between the conductors of a capacitance fuel level probe consists of air and/or fuel. As the fuel lever changes, so does the capacitance. The capacitance is part of an oscillator circuit. As the capacitance changes, so does the oscillator frequency. The frequency is converted to a voltage that is displayed with a fuel gauge. > The advantage of a capacitance type fuel level probe is that there are no moving parts. The disadvantage is that the gauge must be calibrated each time that the type of fuel is changed because unleaded fuel and leaded fuel and gasohol each have different insulating properties. When the fuel tank is almost full, the capacitance fuel gauge will display different levels depending on the type of fuel in the tank. When the tank is almost empty, the fuel gauge will be more accurate because air is now the insulating medium and the probe does not know or care what type of fuel used to be in the tank. > Joe > > -------- > Joe Gores > > > -- Tell the truth. Be honest. Be responsible to and for yourself. I liked America when it was free and it's people were responsible and had morals. Every gram of cocaine you buy from elsewhere contributes to an innocent being murdered in Central and South America. Grow your own or Stop taking it. ________________________________________________________________________________
Date: Jan 02, 2012
On 2012-01-02, at 10:31 AM, Robert L. Nuckolls, III wrote: > At 12:41 PM 12/31/2011, you wrote: > >> Hello! >> >> Does anyone know the actual part number of the contacts used for the KX155 connectors? I know they're AMP or Molex, but not the manufacturer part number....want to avoid paying the exorbitant prices when buying them thru avionics channels. >> >> Appreciate any info! Want to stock up. > > This style connector was very popular from the > time that etched circuit boards became commonplace > and up until about 20 years ago. The really cool thing > about this connector technology was the ability to > fabricate the male portion of the wiring mate-up > right onto the etched circuit board. This often > added a demand for special treatment of the male > "pins" to have them gold plated for resistance to > corrosion. > > AMP, Molex, Cinch, and dozens of others rose to the > opportunity and offered mating female connectors > in a variety of pitches . . . but 0.156" spacing > was popular. This technology is still used in computers > as many of the accessory boards we plug into a > mother board have card edge connectors but they tend > to be much finer pitch. > > This configuration of connector fell out of favor for airframe > harnesses due to the lack of environmental robustness. > No new radios have been built with this style harness > connector in quite some time. > > As one might expect, most if no all producers of this > connector have discontinued manufacturing new parts. Due > to past popularity, there are still many parts of the style > in new-old-stock inventories but specific parts are becoming > more difficult to find every year. > > The pins are much easier to find than some sizes of > housing. The pins you're looking for are Molex 4366 series > p/n 08-05-0302 20-18AWG pins with gold flash. > > http://tinyurl.com/6nkcv5n > > Mouser still seems to have these on hand in some > quantity. > > http://tinyurl.com/6sfazya > > For individuals looking for a work-around to replace one of > these connectors (many popular radios using 156 card edge > connectors are still in service) consider this or some > similar work around. > > http://tinyurl.com/6s949t3 > http://tinyurl.com/7zqx4r6 > http://tinyurl.com/6towcwh > > 156 pitch connectors in various sizes and styles are readily > available as new-old-stock and can often be adapted to > your task of keeping a serviceable radio airworthy. > > For a general posting of data on the Molex/Waldom series > of connectors see: > > http://tinyurl.com/7t6jjsc > > Bob . . . > > > > ________________________________________________________________________________
Date: Jan 02, 2012
work? Wow. That site refuses to allow me a connection, even to their home page. David M. jonlaury wrote: > --> AeroElectric-List message posted by: "jonlaury" > > The electronics have been explained by Joe and Sarg, and Sarg elaborated on his experience with Princeton probes. > > But the reason for installing cap probes has gone unanswered. > Cap probes allow for fuel measurement of irregularly shaped tanks. My fuel bays in the wing change in taper, both in depth and width, in addition to the whole tank sitting at an angle (dihedral), making any kind of accurate measurement impossible over the tank range when using a linear type (float) sensor. > I have installed 8' Centroid probes. Haven't fueled them yet. > They come with two small potentiometers built in to adjust the empty and full points. Available in 0-5v output and various resistance output so you can use them with your existing gauge. > > http://www.centroidproducts.com/tableofc.htm > > Not a recommendation, just a resource, as I have no real world experience with this product, . YMMV. > > John > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=362237#362237 > > > -- Tell the truth. Be honest. Be responsible to and for yourself. I liked America when it was free and it's people were responsible and had morals. Every gram of cocaine you buy from elsewhere contributes to an innocent being murdered in Central and South America. Grow your own or Stop taking it. ________________________________________________________________________________
Date: Jan 02, 2012
work? At 10:41 AM 1/2/2012, you wrote: The electronics have been explained by Joe and Sarg, and Sarg elaborated on his experience with Princeton probes. But the reason for installing cap probes has gone unanswered. Cap probes allow for fuel measurement of irregularly shaped tanks. My fuel bays in the wing change in taper, both in depth and width, in addition to the whole tank sitting at an angle (dihedral), making any kind of accurate measurement impossible over the tank range when using a linear type (float) sensor. I have installed 8' Centroid probes. Haven't fueled them yet. They come with two small potentiometers built in to adjust the empty and full points. Available in 0-5v output and various resistance output so you can use them with your existing gauge. http://www.centroidproducts.com/tableofc.htm Not a recommendation, just a resource, as I have no real world experience with this product, . YMMV. Capacitively sensed liquid level measurement has been around for a very long time. This patent dated in 1937 speaks to liquid level control by exploiting the variability of capacitance due to presence or absence of liquid between two plates: http://tinyurl.com/8xqfqlo This fuel level meter patent dated 1945 goes to the idea of calibrating a pointer on an instrument to show liquid level in the fuel tanks http://tinyurl.com/6qwfdyr This idea patented in 1952 speaks to the technique of tailoring a probe to compensate for tank shape with the idea of providing a change in capacitance that is linear and proportional to useable volume of liquid in the tank. http://tinyurl.com/6ogp4ve This one patented in 1965 was aimed at the automotive market. Too bad it didn't catch on. The float style gauge in my 2002 Kia is no better than the one in my 1941 Pontiac. http://tinyurl.com/86mseoz This 1973 patent speaks to one of dozens of techniques for resolving differences in small changes of capacity into corresponding changes of current to some panel mounted indicator. http://tinyurl.com/73dgo2n The first time I saw a delta-C fuel gaging system was on the B-52 and 1962. I didn't work that system but knew fellow techs who did. Got to peek inside one of the black boxes in the lab . . . lots of vacuum tubes. Here's an exemplar schematic for a system several generations newer than the one in 1960's B-52. These are hand-built, and a gazillion parts most of which can affect stability and accuracy of the gaging system. This configuration went into production in the early 1980's. http://tinyurl.com/7hbwkr6 http://tinyurl.com/6mpgdeo The very last new design study I did for Hawker-Beech was to explore ways to replace the schematics above. This prompted a study that continues to this day . . . that has poor likelihood of finding its way onto an HBC aircraft. Nonetheless, I can report to you that it takes less than 3% of the parts count to craft a capacitance fuel gaging system that uses simple, non-compensated capacity probes. It can be calibrated to the volume vs. shape variances in software. The system can include a reference probe in the bottom of the tank that allows the system to measure dielectric properties of the current load of fuel that varies with mix and temperature. The best thing is that there are less than 5 components that have a strong influence on calibration drifts with temperature and time. The project is on a back burner but the client hasn't abandoned the program . . . if and when the aviation community climbs out of the crapper, I'm hoping that we can spool this effort up again. In any case, know that most of what's being offered today has roots that go back many decades. Do a search of http://freepatentsonline.com and you'll find a wealth of history along with examples that range from rather practical to bizarre in terms of performance. But devices as simple as a $1 PIC micro-controller . . . fitted with well crafted software can do a very good job of telling you how much fuel is in the tank. Further, cost of manufacturing is a tiny fraction of that invested in systems flying on virtually all GA aircraft today. Bob . . . ________________________________________________________________________________
Subject: Composite aircraft grounding systems.
Date: Jan 02, 2012
For Bob Nuckolls (or anyone else with knowledge of composite aircraft grounding systems), I have recently bought your book, 'The AeroElectric Connection' (12th Edition) and have also looked at all the FAQ documents and archive posts such as 'Airframe Grounding' etc. Very, very interesting reading. I'm starting the electrical system on a Rutan Long-EZ project (all composite as you will already know). The original builder had built in one copper 1/2 inch ID tube from front to back and I'm contemplating using it for possibly two purposes, a) a main earth rail. b) a conduit to carry the main power cable to the starter. The battery is in the nose and the distance from battery to starter (B&C light weight) is 14 ft (4.3 metre). Cable suppliers in the U.K. shows #4 as being suitable for starters but B&C responded to my question saying for a Long-EZ use #2, presumably for voltage drop reasons. I've settled on the Z-12 setup with a automotive alternator and B&C LR-3 controller as primary power with a B&C SD-8 system for secondary power. I would like to seek valued opinions on the following: Questions: 1. Would having a main power cable inside a copper ground tube generate unforseen problems (besides lots of sparks if shorted out!). 2. Can I use welding cable instead of the very heavy and very expensive #2 Tefzel coated aviation cable (circa $15 per foot in the U.K.) 3. Should the Starter solenoid be close to the battery or on the firewall (live power in the cable only at starting or all the time) My main concern and objective at the moment is to establish a suitable and reliable earthing system before moving on to other matters. Bob, many thanks for your excellent book and resources. Regards Mike Dunlop (U.K.) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362258#362258 ________________________________________________________________________________
Date: Jan 02, 2012
At 12:02 AM 1/2/2012, you wrote: Dan, I am just starting my wiring diagram on a Tundra w/ IO-360. I have decided to follow Bob's suggestion to use the Z-12 schematic (dual alternators, single battery) and I'm assembling the various parts. While I have worked on the wiring of two Glastars I have never done anything like this and I am looking to our group for ideas. I have Bob's book and continue to study it. His statement about the difference between a 'Schematic' drawing and a 'mechanical' drawing has really hit home. Just knowing which components belong in the engine compartment (contactors, shunts, current limiters, ??) and which to mount on the cockpit side of the firewall and then which to mount on the panel itself would be a great start on doing a mechanical drawing. These thoughts may seem vary 'logical' to those with experience but no so to this novice. Anyway, I sure appreciate your questions and the answers that have come forth. Since I could not find your schematic on the list I look forward to you sending it direct. I will begin to check the archives for topics on this. Jim Kinninger Consider this also: I don't think I've written about this before but it was offered in most if not all of my weekend seminars. One problem with crafting bundles 'in place' is getting the first few wires to hold the shape and routing in the airplane. Lay out your complex bundle pathways by laying down supporting guide-wires fabricated from 10AWG single strand copper from Home Depot or similar supplier. Support the guide-wire on small plastic clamps using the same holes that will ultimately mount the final compliment of support clamps. Build your bundles onto these guide wires using tye-wraps to bring it all together. Cut of the older wraps as new ones are added. When you're all done, it's a simple matter to put the final set of wraps or ties on the bundle after you've cut the guide-wire from the bundle interior. The temporary support clamps for the guide-wire are replaced with the real clamps using the same mounting holes. Building on top of a guide-wire "skeleton" can go a long way to having your finished wire bundles look like they came off a well crafted form board. Bob . . . ________________________________________________________________________________
Date: Jan 02, 2012
work? You're not along Dick In a message dated 1/2/2012 12:53:43 P.M. Central Standard Time, ainut(at)knology.net writes: --> AeroElectric-List message posted by: David Wow. That site refuses to allow me a connection, even to their home page. David M. jonlaury wrote: > --> AeroElectric-List message posted by: "jonlaury" > > The electronics have been explained by Joe and Sarg, and Sarg elaborated on his experience with Princeton probes. > > But the reason for installing cap probes has gone unanswered. > Cap probes allow for fuel measurement of irregularly shaped tanks. My fuel bays in the wing change in taper, both in depth and width, in addition to the whole tank sitting at an angle (dihedral), making any kind of accurate measurement impossible over the tank range when using a linear type (float) sensor. > I have installed 8' Centroid probes. Haven't fueled them yet. > They come with two small potentiometers built in to adjust the empty and full points. Available in 0-5v output and various resistance output so you can use them with your existing gauge. > > http://www.centroidproducts.com/tableofc.htm > > Not a recommendation, just a resource, as I have no real world experience with this product, . YMMV. > > John > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=362237#362237 > > > -- Tell the truth. Be honest. Be responsible to and for yourself. I liked America when it was free and it's people were responsible and had morals. Every gram of cocaine you buy from elsewhere contributes to an innocent being murdered in Central and South America. Grow your own or Stop taking it. ________________________________________________________________________________
Subject: Re: Composite aircraft grounding systems.
Date: Jan 02, 2012
Hi Mike I'm building a composite Europa. There's a builder in Canada that put Eric Jones copper clad wire: http://www.periheliondesign.com/fatwires.htm inside a copper pipe as you suggest. I don't think he's flying yet, but here are a few pics: http://www.europaowners.org/forums/gallery2.php?g2_itemId=78200 I think the yellow with green is heat shrink he added. The aluminium wire is expensive but will save you some weight. It is not very flexable and fatugues more easily than thin stranded copper. If you need to make hard turns, best use welding cable for that area? I looked into welding cable and www.mcmaster is one resource. The #2 CCA is thicker in diameter compared to Tefzel, but has approx the same resistance. Ron Parigoris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362262#362262 ________________________________________________________________________________
From: Etienne Phillips <etienne.phillips(at)gmail.com>
Subject: Headset microphone level reducer
Date: Jan 02, 2012
Hi All I have two dissimilar headsets that have very different microphone output levels. The one headset is an oldish basic Avcomm model, and the other is a new child-sized one. My MGL radio/intercom doesn't have the ability to reduce the volume of the new headset adequately. I've never worked with electret microphones before, so am not sure how to build a signal reducer. I have noticed that they are polarity sensitive, which leads me to expect some phantom power is required...? I need to reduce the volume by about 15dB (according to the MGL radio) to match the Avcomm. Ideally, I'd like to be able to build a passive circuit that I can squeeze into the headset itself, rather than an interface box or off-the-shelf device. This will allow me to use the new headset in other aircraft as the Avcomm's seem to play nicely with other major brands. If anyone has some insight, I'd be most appreciative! Thanks Etienne ________________________________________________________________________________
Date: Jan 02, 2012
work? The boat people deal with crazy shaped tanks. Here is one example that uses a low tech float/resistor and a smart meter head. http://www.cruzpro.com/products.html#HEADINGE PaulW ===== >At 10:41 AM 1/2/2012, you wrote: > >The electronics have been explained by Joe and Sarg, and Sarg >elaborated on his experience with Princeton probes. > >But the reason for installing cap probes has gone unanswered. >Cap probes allow for fuel measurement of irregularly shaped tanks. >My fuel bays in the wing change in taper, both in depth and width, >in addition to the whole tank sitting at an angle (dihedral), making >any kind of accurate measurement impossible over the tank range when >using a linear type (float) sensor. >I have installed 8' Centroid probes. Haven't fueled them yet. >They come with two small potentiometers built in to adjust the empty >and full points. Available in 0-5v output and various resistance >output so you can use them with your existing gauge. > >http://www.centroidproducts.com/tableofc.htm > >Not a recommendation, just a resource, as I have no real world >experience with this product, . YMMV. ________________________________________________________________________________
Date: Jan 02, 2012
M: Bob, I've just joined the AeroElectric-List and will post the following when the acount is activated... I have recently bought your book, 'The AeroElectric Connection' (12th Edition) and have also looked at all the FAQ documents and archive posts such as 'Airframe Grounding' etc. Very, very interesting reading. Thank you. I'm starting the electrical system on a Rutan Long-EZ project (all composite as you will already know). The original builder had built in one copper 1/2 inch ID tube from front to back and I'm contemplating using it for possibly two purposes, a) a main earth rail. b) a conduit to carry the main power cable to the starter. The battery is in the nose and the distance from battery to starter (B&C light weight) is 14 ft (4.3 metre). Cable suppliers in the U.K. shows #4 as being suitable for starters but B&C responded to my question saying for a Long-EZ use #2, presumably for voltage drop reasons. Correct. I've settled on the Z-12 setup with a automotive alternator and B&C LR-3 controler as primary power with a B&C SD-8 system for secondary power. I would like to seek your valued opinion on the following: Then you don't want Z-12 but Z-13/8. Questions: 1. Would having a main power cable inside a copper ground tube generate unforseen problems. No, But you do want to craft your tube-to-wiring connections by soldering copper wrap-around flag terminals to the copper tube. 2. Can I use welding cable instead of the very heavy and expensive #2 Tefzel coated aviation cable (circa $15 per foot in the U.K.) Absolutely. In fact I prefer it. 3. Should the Starter solinoid be close to the battery or on the firewall (live power in the cable only at starting or all the time) Close to the starter. Then use the same feeder to bring b-lead power up front from the main alternator. But a current limiter in the b-lead connecting right were it attaches to the hot-side of the starter contactor on the firewall. My main concern and objective at the moment is to establish a suitable earthing system before moving on to other matters. I could go on asking questions like this all day but I'm sure you have other things to do and I need to concentrate on getting this bit sorted first. The conduit ground system is fine. Many thanks for your excellent book and resources. I'm pleased that you find it a good value . . . Bob . . . ________________________________________________________________________________
From: Bob McCallum <robert.mccallum2(at)sympatico.ca>
work?
Date: Jan 02, 2012
The Centroid Products site works perfectly for me by following the link provided by John. Here is the link he provided again in case this works better for someone than the original. http://www.centroidproducts.com/tableofc.htm and here is their home page if this helps. http://www.centroidproducts.com Good luck Bob McC _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of RGent1224(at)aol.com Sent: Monday, January 02, 2012 2:14 PM Subject: Re: AeroElectric-List: Re: Capacitive Fuel Level Sensor - How do they work? You're not along Dick In a message dated 1/2/2012 12:53:43 P.M. Central Standard Time, ainut(at)knology.net writes: Wow. That site refuses to allow me a connection, even to their home page. David M. jonlaury wrote: > --> AeroElectric-List message posted by: "jonlaury" > > The electronics have been explained by Joe and Sarg, and Sarg elaborated on his experience with Princeton probes. > > But the reason for installing cap probes has gone unanswered. > Cap probes allow for fuel measurement of irregularly shaped tanks. My fuel bays in the wing change in taper, both in depth and width, in addition to the whole tank sitting at an angle (dihedral), making any kind of accurate measurement impossible over the tank range when using a linear type (float) sensor. > I have installed 8' Centroid probes. Haven't fueled them yet. > They come with two small potentiometers built in to adjust the empty and full points. Available in 0-5v output and various resistance output so you can use them with your existing gauge. > > http://www.centroidproducts.com/tableofc.htm > > Not a recommendation, just a resource, as I have no real world experience with this product, . YMMV. > > John > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=362237#362237 > > > -- Tell the truth. Be honest. Be responsible to and for yourself. I liked America when it was free and it's people were responsible and had morals. Every gram of cocaine you buy from elsewhere contributes to an innocent being murdered in Central and South America. Grow your own or Stop taking Use ilities ay - MATRONICS WEB FORUMS - List Contribution Web Site p; ________________________________________________________________________________
Date: Jan 02, 2012
Subject: Re: Headset microphone level reducer
At 12:29 PM 1/2/2012, you wrote: Hi All I have two dissimilar headsets that have very different microphone output levels. The one headset is an oldish basic Avcomm model, and the other is a new child-sized one. My MGL radio/intercom doesn't have the ability to reduce the volume of the new headset adequately. I've never worked with electret microphones before, so am not sure how to build a signal reducer. I have noticed that they are polarity sensitive, which leads me to expect some phantom power is required...? Are both microphones intended for interface to an aviation transmitter/intercom inputs? 15 db is a BIG difference. I need to reduce the volume by about 15dB (according to the MGL radio) to match the Avcomm. Ideally, I'd like to be able to build a passive circuit that I can squeeze into the headset itself, rather than an interface box or off-the-shelf device. This will allow me to use the new headset in other aircraft as the Avcomm's seem to play nicely with other major brands. An aviation microphone, is powered by a bias current applied to a combination of ELECTRONICS as an amplifier and the electret microphone element. If anyone has some insight, I'd be most appreciative! The goal is to reduce magnitude of signal voltage without materially upsetting the DC power that is supplied to the microphone's electronics. I would suggest a resisteor in series with say a 100uF/10v capacitor tied right across the microphone's signal/ power wires. We know that the microphone's AC output impedance is some finite value. Let's assume 1000 ohms. Okay, you're wanting to attenuate the AC signal by about 2/3. So the resistor in series with the capacitor will be 500 ohms or less. This is just an guess/example and but it's in the ballpark. You can fiddle with the value of the fixed resistor until the two microphones demonstrate near equal performance. Having a capacitor in series with the resistor will keep the AC load resistor from also affecting the DC power that comes out of the radio or intercom to power the microphone. Bob . . . ________________________________________________________________________________
Subject: Re: Wiring Harness
Date: Jan 02, 2012
Great idea on how to construct the wire harnes.....Thanks for the information! Dan ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Sent: Monday, January 02, 2012 2:14 PM Subject: Re: AeroElectric-List: Wiring Harness > > > At 12:02 AM 1/2/2012, you wrote: > Dan, > I am just starting my wiring diagram on a Tundra w/ IO-360. I have decided > to follow Bob's suggestion to use the Z-12 schematic (dual alternators, > single battery) and I'm assembling the various parts. While I have worked > on the wiring of two Glastars I have never done anything like this and I > am looking to our group for ideas. I have Bob's book and continue to study > it. His statement about the difference between a 'Schematic' drawing and a > 'mechanical' drawing has really hit home. Just knowing which components > belong in the engine compartment (contactors, shunts, current limiters, > ??) and which to mount on the cockpit side of the firewall and then which > to mount on the panel itself would be a great start on doing a mechanical > drawing. These thoughts may seem vary 'logical' to those with experience > but no so to this novice. > Anyway, I sure appreciate your questions and the answers that have come > forth. Since I could not find your schematic on the list I look forward to > you sending it direct. I will begin to check the archives for topics on > this. > Jim Kinninger > > Consider this also: > > I don't think I've written about this before but > it was offered in most if not all of my weekend > seminars. > > One problem with crafting bundles 'in place' is > getting the first few wires to hold the shape and > routing in the airplane. Lay out your complex bundle > pathways by laying down supporting guide-wires fabricated from > 10AWG single strand copper from Home Depot or similar > supplier. Support the guide-wire on small plastic clamps > using the same holes that will ultimately mount the > final compliment of support clamps. > > Build your bundles onto these guide wires using tye-wraps > to bring it all together. Cut of the older wraps as new ones > are added. When you're all done, it's a simple matter to > put the final set of wraps or ties on the bundle after > you've cut the guide-wire from the bundle interior. The > temporary support clamps for the guide-wire are replaced > with the real clamps using the same mounting holes. > > Building on top of a guide-wire "skeleton" can go a > long way to having your finished wire bundles look like > they came off a well crafted form board. > > > Bob . . . > > ________________________________________________________________________________
Date: Jan 03, 2012
work?
I've been using a Westach cap sender in a plastic fuel tank for the last 6 years. http://www.westach.com/ It has low and high pots on the top of the sender and, once set, seems to work consistently from fill to fill. I changed out tanks during an extended annual three years ago (old ones were yellowed and had bottom taps that I didn't trust) and I had to shorten the probe a tad, but well within Westach's specs. Adjusted the pots for the new length and flew on. Because of the height of the body of the sender unit they aren't easily utilized in a wing tank, but for a fuselage or header tank where you have ~1" of space above the tank top they would be fine. Sorry I have no info on how well they would deal with another vendor's gauge, but a sample of their instruction sheet is here. http://www.westach.com/instructions/395-240OHM-P1.jpg Rick Girard On Mon, Jan 2, 2012 at 5:14 PM, Bob McCallum wrote: > ** ** ** > > *The Centroid Products site works perfectly for me by following the link > provided by John.* > > * * > > *Here is the link he provided again in case this works better for someone > than the original.* > > * * > > *http://www.centroidproducts.com/tableofc.htm* > > * * > > *and** here is their home page if this helps.* > > * * > > *http://www.centroidproducts.com* > > * * > > *Good luck* > > *Bob McC* > > * * > ------------------------------ > > *From:* owner-aeroelectric-list-server(at)matronics.com [mailto: > owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of * > RGent1224(at)aol.com > *Sent:* Monday, January 02, 2012 2:14 PM > *To:* **aeroelectric-list(at)matronics.com** > *Subject:* Re: AeroElectric-List: Re: Capacitive Fuel Level Sensor - How > do they work?**** > > ** ** > > You're not along**** > > Dick**** > > **** > > In a message dated 1/2/2012 12:53:43 P.M. Central Standard Time, > ainut(at)knology.net writes:**** > > > Wow. That site refuses to allow me a connection, even to their home page. > > David M. > > > jonlaury wrote: > > --> AeroElectric-List message posted by: "jonlaury"< > jonlaury(at)impulse.net> > > > > The electronics have been explained by Joe and Sarg, and Sarg elaborated > on his experience with **Princeton** probes. > > > > But the reason for installing cap probes has gone unanswered. > > Cap probes allow for fuel measurement of irregularly shaped tanks. My > fuel bays in the wing change in taper, both in depth and width, in addition > to the whole tank sitting at an angle (dihedral), making any kind of > accurate measurement impossible over the tank range when using a linear > type (float) sensor. > > I have installed 8' Centroid probes. Haven't fueled them yet. > > They come with two small potentiometers built in to adjust the empty and > full points. Available in 0-5v output and various resistance output so you > can use them with your existing gauge. > > > > http://www.centroidproducts.com/tableofc.htm > > > > Not a recommendation, just a resource, as I have no real world > experience with this product, . YMMV. > > > > John > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=362237#362237 > > > > > > > > > > > > > > > > > > > > > > > > > > -- > Tell the truth. Be honest. Be responsible to and for yourself. > > I liked ****America**** when it was free and it's people were responsible > and had morals. > > Every gram of cocaine you buy from elsewhere contributes to an innocent > being murdered in Central and **South America**. Grow your own or Stop > taking = Use ilities ay - MATRONICS WEB FORUMS - > List Contribution Web Site p; > > ** > ****** > > * * > > * * > > * - The AeroElectric-List Email Forum -* > > ** > > ** > > *--> http://www.matronics.com/Navigator?AeroElectric-List* > > ** > > * - MATRONICS WEB FORUMS -* > > * - List Contribution Web Site -* > > * -Matt Dralle, List Admin.* > > ** > > * * > > * > > * > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Jan 03, 2012
Radio Shack sels (or usedc to, anyway...) temporary velcro wire bundle tie straps. Very, very convenient and reuseable. Glen Matejcek ________________________________________________________________________________
Date: Jan 03, 2012
Mike and the group: Regarding the the placement of the starter solenoid there is, as usual, more than one way to skin this cat. There are some trade-offs. Bob's recommendation to put the solenoid back by the starter and use the one big feed line for both the starter supply and Alternator B lead, which I think is a good one for many people, eliminates an otherwise needed additional wire (#8 in my case) for the alternator B lead running from the alternator back to the bus and thus saves it's weight. My LongEz was flying when purchased but I immediately grounded it and spent ~4 years reworking it before putting it back in the air again. It's been flying it since August '11. When I totally replaced the electrical system in the my LongEz, I read the book, considered all the options, posted lots of question on the forum and I ended up with the planned location for the starter solenoid up front. Here's why: My goal, in recognition that I was new to experimentals in general and LongEzs in particular, was to stick pretty close to the plans and owners manual authored by Burt unless they had been superseded by CPs, or a perceived (and well reasoned) consensus on the yahoo group canardaviators. With that in mind, I wanted all my initial flight testing without a starter (even though it had one when I bought it) to keep the CG as far forward as I could and keep it as light as possible. I haven't yet installed the heavy feed or return cables back to the firewall that will be required if I later reinstall the starter. I did, keeping a future installation in mind, reserve space up front for the starter solenoid and I kept the #8 firewall return (i.e. ground) wire separate from the laced bundle going back to the firewall so that it would be easy to replace it with welding wire (or CCA) later if required. The two biggest reasons I went this route is that, when I am running without the starter as I am now, I'm not carrying around the heavier wire and it allowed me to protect the #8 B-wire with an ANL up near the master relay and battery so that I didn't have an unprotected high-current feed running from the master relay (or buss) all the way back to the firewall. As I understand it (and Bob is the authority here, not me) there is nothing wrong with having the unprotected feed from the buss going all the way back to the firewall but I was more comfortable not doing so. Another benefit was that I could keep all this stuff together up in the nose (which is also where I moved the regulator) rather than back on the firewall (which is already crowded enough on a LongEz, esp. if you have electronic ignition as I do). If and when I do re-install the starter, the downside for going the route that I did is that I'll be carrying around a single extra #8 wire running from back to front. That wasn't a problem for me given that I'll also be adding two long lines of welding wire and a starter at that time as well... A purest might reconfigure at that time to the configuration Bob recommended to save the weight of the #8 wire. I won't. btw: I recommend both the canardaviators forum and Central States Association. There is a lot of good information out there on LongEzs beyond the plans and CPs but it takes some digging to get to it. In completing your LongEz be sure to be more concerned about "completion drag" than "aerodynamic drag". Anything you do that hasn't already been done before, and been well documented in the process, will cost you more time (i.e. be a drag on getting your bird flying) than you imagine... Steve Stearns Boulder/Longmont, Colorado CSA,EAA,IAC,AOPA,PE,ARRL,BARC (but ignorant none-the-less) Restoring (since 1/07) and flying again (8/11!): N45FC O235 Longeze Cothern/Friling CF1 (~1000 Hrs) Flying (since 9/86): N43732 A65 Taylorcraft BC12D ________________________________________________________________________________
Date: Jan 03, 2012
How about building the harness on a template. That way it can be built outside the aircraft tested and inspected before instalation. Regards Ron Raby Lancair ES ----- Original Message ----- From: "Glen Matejcek" <aerobubba(at)earthlink.net> Sent: Tuesday, January 03, 2012 9:33 AM Subject: AeroElectric-List: Re: Wiring Harness > > > Radio Shack sels (or usedc to, anyway...) temporary velcro wire bundle tie > straps. Very, very convenient and reuseable. > > Glen Matejcek > > > ________________________________________________________________________________
Date: Jan 03, 2012
I sell lots of Copper-Clad Aluminum cable to 300 mph fuel dragster and racecar builders, weird groups doing strange things where the weight is important. I even sell the stuff to the companies building remote-controlled drones. Predator drones and the more advance secret stuff... Airbus and Boeing use similar CCA configurations. I sell Super-2-CCA, Super-4-CCA, AWG-6-CCA (same dimensions as AWG-6 but CCA with Tefzel insulation), and Super-CCA RG+142 See my website. CCA is 60% the weight of copper for the same conductivity. If you have the battery on the firewall, you are okay. Otherwise, use CCA. Also see Bob's most excellent article, http://www.aeroelectric.com/articles/economics_of_weight_reduction.html and on my website: http://www.periheliondesign.com/fatwires_files/Coppercables.pdf -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362332#362332 ________________________________________________________________________________
Date: Jan 03, 2012
Home Depot and Lowes have them Dick In a message dated 1/3/2012 8:37:11 A.M. Central Standard Time, aerobubba(at)earthlink.net writes: temporary velcro wire bundle tie straps ________________________________________________________________________________
From: "ROGER & JEAN CURTIS" <mrspudandcompany(at)verizon.net>
Date: Jan 03, 2012
In a message dated 1/3/2012 8:37:11 A.M. Central Standard Time, aerobubba(at)earthlink.net writes: temporary velcro wire bundle tie straps I have found that the hook and loop straps used by many supermarkets to wrap leaf lettuce and other produce are great for temporary bundle ties, and they are cheap. =98=BA Roger ________________________________________________________________________________
Date: Jan 03, 2012
At 09:37 AM 1/3/2012, you wrote: > >How about building the harness on a template. That way it can be >built outside the aircraft tested and inspected before instalation. That IS how the 'big' guys do it. But they often build the proof of concept harness in the airplane, take it out and build a form-board to match it. Even with full 3-D CAD systems, it's difficult to build a first-article that really fits the airplane the way the craftsmen would like it. Bob . . . ________________________________________________________________________________
From: "mark donahue" <markdonahue(at)earthlink.net>
Subject: Diodes on soleniods
Date: Jan 03, 2012
I am building an RV 9, and wiring per Van's wiring diagram. The diagram does not show diodes on the starter or master relay, but the accessories catalog lists "protection" Diodes to be installed to protect the master and starter switches for surge protection. Sounds like this is a good thing to install. Any thoughts? Thanks, Mark Donahue ________________________________________________________________________________
Date: Jan 03, 2012
Thanks Bob! That's exactly the kind of circuit I was looking for. I'll get back to you on it's effectiveness. The new child headset is supposedly an aviation one, and the destination is an aviation MGL radio, so one would have hoped that there wouldn't be such a large discrepancy in levels! Thanks again Etienne ________________________________________________________________________________
Date: Jan 04, 2012
Subject:
seems what this world[or at least me] needs is a gps driven directional gyro. i know that most gps units have part of a compass rose displayed but for the price of a mechanical one i would think a plain simple dg that mounts in a conventional 3'' hole and is gps driven would be cheap and popular. or at least a program to drive a palm pilot, tapping off the gps of another unit. bob noffs ________________________________________________________________________________
Date: Jan 04, 2012
Subject: Re: ectric-List:
Bob (Noffs),=0A=0AMost GPS units made over the last 10 years, or so, have t hat exact feature.- The difference being that they don't display on a sep arate instrument.=0A=0AOf course, the likely reason that this hasn't been m arketed as a replacement for the old DG is that it's not really the same as a DG.- A DG shows heading, while a GPS only knows track (derived from su ccessive positions).- Depending on wind conditions and your airspeed, tho se two can differ by a considerable amount.=0A=0A-=0ADoug Ilg=0AGrumman T iger N74818, College Park-Airport (KCGS), Maryland=0AChallenger II LSS LW (N641LG-reserved)-- kit underway at Laurel Suburban (W18)=0Ado not arc hive=0A=0A-=0A=0A=0A=0A>________________________________=0A> From: bob no ffs =0A>To: aeroelectric list =0A>Sent: Wednesday, January 4, 2012 6:59 AM=0A>Subject: AeroElectri c-List:=0A> =0A>=0A>seems what this world[or at least me] needs is a gps dr iven directional gyro. i know that most gps units have part of a compass ro se displayed but for the price of a mechanical one i would think a plain si mple dg that mounts in a conventional 3'' hole and is gps driven would be c heap and popular. =0A>- or at least a program to drive a palm pilot, tapp ing off the gps of another unit.=0A>-- bob noffs=0A> ________________________________________________________________________________
Date: Jan 04, 2012
Good Morning Ken, You said: "Several degrees of error can become problematical for things like an RNAV NDB approach." While this is getting quite far away from a subject for the Aeroelectric list, I would like to comment. If we are flying IFR, it would seem we need a legal method of shooting an NDB approach and the only method currently legal is to use an ADF combined with a legal compass heading. Once upon a time, we were legal to shoot that approach with just a fixed or manually rotatable loop and compass. No longer true. We must have an ADF and a compass. If we are cheating and want to use a GPS, even a legal GPS, to execute the approach, it would be pertinent to set the airport location as the 'go to' destination and fly the track to the airport. While heading is always nice to know, (it helps us determine where to look when visibility is marginal,) it pales in importance to staying on track toward the airport. Just sayin' nothin' else Happy Skies, Old Bob In a message dated 1/4/2012 10:01:16 A.M. Central Standard Time, klehman(at)albedo.net writes: Several degrees of error can become problematical for things like an RNAV NDB approach. ________________________________________________________________________________
Date: Jan 04, 2012
Hmmm.... I thought we could substitute an ifr gps for adf in ndb approaches. When you say compass, do you mean magnetically derived heading? On Jan 4, 2012, at 11:27, BobsV35B(at)aol.com wrote: > Good Morning Ken, > > You said: > "Several degrees of error can become problematical for things like an RNAV NDB approach." > > While this is getting quite far away from a subject for the Aeroelectric l ist, I would like to comment. > > If we are flying IFR, it would seem we need a legal method of shooting an N DB approach and the only method currently legal is to use an ADF combined wi th a legal compass heading. > > Once upon a time, we were legal to shoot that approach with just a fixed o r manually rotatable loop and compass. > > No longer true. We must have an ADF and a compass. > > If we are cheating and want to use a GPS, even a legal GPS, to execute the approach, it would be pertinent to set the airport location as the 'go to' d estination and fly the track to the airport. While heading is always nice to know, (it helps us determine where to look when visibility is marginal,) it pales in importance to staying on track toward the airport. > > Just sayin' nothin' else > > Happy Skies, > > Old Bob > In a message dated 1/4/2012 10:01:16 A.M. Central Standard Time, klehman@a lbedo.net writes: > Several degrees of error can become problematical for > things like an RNAV NDB approach. > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Jan 04, 2012
The sensors are in fact just two rings of metal like a sleeve one inside the other. Fuel has a particular dielectric value so with increase in fuel level the capacitance of the sleeves one to the other changes. Why you would want one? There are several reasons. One is by varying the shape of the rings you can make a sensor that will compensate for an odd shape of tank. You can also wire more than one sensor in parallel to give accurate readings on a tank that can hold a fair amount of fuel and still have one end of the tank completely dry. For instance in an aircraft that has considerable dihedral and wet wings. Finally in all capacitive systems there is a calibration probe which has to be installed at the bottom of the tank. Water has a completely different dielectric constant from fuel so if any water gets into your tanks and even partially submerges this probe a light will immediately alert you. Noel -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Jeff Luckey Sent: January 2, 2012 1:44 AM Subject: AeroElectric-List: Capacitive Fuel Level Sensor - How do they work? How do capacitive fuel sensors work? Can someone give me the general theory of operation, what type of signal does the transducer produce? Why do I want one? Etc? TIA ________________________________________________________________________________
Date: Jan 04, 2012
In other words, using a template or form board is a mass production technique. Kind of the opposite of what we are doing in the OBAM world. Conversely, it would seem reasonable to think we can do a superior job with our hand built, single craftsman approach. Of course our amateur skills may cancel out any skilled craftsman advantage. Bill "reflecting on the joys of OBAM aircraft" Watson >> >> How about building the harness on a template. That way it can be >> built outside the aircraft tested and inspected before instalation. > > That IS how the 'big' guys do it. But they often build the proof > of concept harness in the airplane, take it out and build > a form-board to match it. Even with full 3-D CAD systems, it's > difficult to build a first-article that really fits the airplane > the way the craftsmen would like it. > > > Bob . . . ________________________________________________________________________________
Date: Jan 04, 2012
Yes, what Bob said. I'm thinking that track is better than heading. And if I recall correctly, when many of those NDB approaches had GPS overlays a few years ago, you didn't require an ADF (or the ability to fly a mag heading), you just used a certified GPS to fly the NDB tracks. (do any of those still exist - the ones I used to fly are all replaced by RNAV T approaches) I guess what you are getting at is that you'd like to avoid having to install a DG by using a GPS driven instrument. My glass panel gives me mag headings from the EFIS's AHRS system and allows me to easily follow vectors. Otherwise, I don't have a whiskey compass or vacuum driven heading instrument. The key question is what happens with an electronics failure... well I have a GRT ADI instrument with a GPS and an independent backup battery. It just gives me a digital track readout along with turn coordinator function and a quasi-horizon. I can't follow a mag heading but I can fly a track pretty darn accurately. Bill "not completely off-topic" Watson On 1/4/2012 11:27 AM, BobsV35B(at)aol.com wrote: > Good Morning Ken, > You said: > "Several degrees of error can become problematical for things like an > RNAV NDB approach." > While this is getting quite far away from a subject for the > Aeroelectric list, I would like to comment. > If we are flying IFR, it would seem we need a legal method of shooting > an NDB approach and the only method currently legal is to use an ADF > combined with a legal compass heading. > Once upon a time, we were legal to shoot that approach with just a > fixed or manually rotatable loop and compass. > No longer true. We must have an ADF and a compass. > If we are cheating and want to use a GPS, even a legal GPS, to execute > the approach, it would be pertinent to set the airport location as the > 'go to' destination and fly the track to the airport. While heading is > always nice to know, (it helps us determine where to look when > visibility is marginal,) it pales in importance to staying on track > toward the airport. > Just sayin' nothin' else > Happy Skies, > Old Bob > I ________________________________________________________________________________
Subject: Hall Effect Current Sensor with Z13/8
From: "Bob Marshall" <marshall6916(at)sbcglobal.net>
Date: Jan 04, 2012
My RV6A is being built based on Z13/8 with dual Dynon EFIS and an SD-8 back up alternator. Dynon has just updated its EFIS to allow installation of the GRT CS-01 Hall Effect Current Sensor (in addition to the standard loadmeter shunt at the alternator) and I was wondering what the consensus was as to where to place it. I want to read total amps being used when the main alternator is off line. So, my initial thought would be to place it on the main (#2 AWG) conductor from the Battery to the Battery Contactor. This would give me total amps with the Main Alternator on-line and total amps with the main off-line and the SD8 on- line? I could also place it exactly where the shunt is shown for the SD-8 and that would just give me SD8 output? Thanks for any thoughts on this. Bob -------- RV-6A construction resumed. Planning electrical and building wing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362405#362405 Attachments: http://forums.matronics.com//files/amp_he_rev_b_156.pdf ________________________________________________________________________________
Date: Jan 04, 2012
Hi Bill, Bob Actually we build both high volume and low volume harnesses at my company. Almost all of the harnesses we build use a harness board. Non of the harness drawings, of the thousands we build were developed with 3d cad, all were done in 2d. Attached is a small harness drawing with a wire run list in pdf format for everyone to look at. Qty 2, 4 x 8 sheets of plywood end to end could simulate the fusalage of most planes. My intension is to give people ideas that may help. I am not trying to sell anything. the link is to my website and shows some pictures of completed harnesses. http://www.advanceddesign.com/products_harnesscable.html Regards Ron Raby ----- Original Message ----- From: "Bill Watson" <Mauledriver(at)nc.rr.com> Sent: Wednesday, January 04, 2012 12:15 PM Subject: Re: AeroElectric-List: Re: Wiring Harness > > > In other words, using a template or form board is a mass production > technique. Kind of the opposite of what we are doing in the OBAM world. > > Conversely, it would seem reasonable to think we can do a superior job > with our hand built, single craftsman approach. Of course our amateur > skills may cancel out any skilled craftsman advantage. > > Bill "reflecting on the joys of OBAM aircraft" Watson >>> >>> How about building the harness on a template. That way it can be built >>> outside the aircraft tested and inspected before instalation. >> >> That IS how the 'big' guys do it. But they often build the proof >> of concept harness in the airplane, take it out and build >> a form-board to match it. Even with full 3-D CAD systems, it's >> difficult to build a first-article that really fits the airplane >> the way the craftsmen would like it. >> >> >> Bob . . . > > > ________________________________________________________________________________
Date: Jan 04, 2012
Good Morning Bill, Just a little bit more off topic if I may. The overlay program was instituted to get a lot of early use out of GPS approaches. When you executed an overlay approach. all the guidance was strictly via GPS. The only thing used from the ADF approach was the minima. Many divisions of the FAA were strongly against the overlay program and the FAA is now removing the overlays as fast as practical. Very few still exist. In most cases, the new approach which replaces the overlay will have better minima, bit not always. To pat myself on the back just a bit, I do have some expertise on that program. I was an early adopter and fought hard for the use of GPS In Lieu of ADF and DME. With the help of Randy Kenagy and Phil Boyer of ALPA . We got it done. I was contacted by a gentleman named Bob Wright who was in the position within the FAA to get the job done. It took almost a year, but we did get that permission and I am VERY proud of what we got done. If you get to the correct FAA FED, things can work correctly Happy Skies. Old Bragging Bob In a message dated 1/4/2012 11:39:45 A.M. Central Standard Time, Mauledriver(at)nc.rr.com writes: Yes, what Bob said. I'm thinking that track is better than heading. And if I recall correctly, when many of those NDB approaches had GPS overlays a few years ago, you didn't require an ADF (or the ability to fly a mag heading), you just used a certified GPS to fly the NDB tracks. (do any of those still exist - the ones I used to fly are all replaced by RNAV T approaches) I guess what you are getting at is that you'd like to avoid having to install a DG by using a GPS driven instrument. My glass panel gives me mag headings from the EFIS's AHRS system and allows me to easily follow vectors. Otherwise, I don't have a whiskey compass or vacuum driven heading instrument. The key question is what happens with an electronics failure... well I have a GRT ADI instrument with a GPS and an independent backup battery. It just gives me a digital track readout along with turn coordinator function and a quasi-horizon. I can't follow a mag heading but I can fly a track pretty darn accurately. Bill "not completely off-topic" Watson On 1/4/2012 11:27 AM, _BobsV35B(at)aol.com_ (mailto:BobsV35B(at)aol.com) wrote: Good Morning Ken, You said: "Several degrees of error can become problematical for things like an RNAV NDB approach." While this is getting quite far away from a subject for the AeroElectric list, I would like to comment. If we are flying IFR, it would seem we need a legal method of shooting an NDB approach and the only method currently legal is to use an ADF combined with a legal compass heading. Once upon a time, we were legal to shoot that approach with just a fixed or manually rotatable loop and compass. No longer true. We must have an ADF and a compass. If we are cheating and want to use a GPS, even a legal GPS, to execute the approach, it would be pertinent to set the airport location as the 'go to' destination and fly the track to the airport. While heading is always nice to know, (it helps us determine where to look when visibility is marginal,) it pales in importance to staying on track toward the airport. Just sayin' nothin' else Happy Skies, Old Bob I (http://www.matronics.com/Navigator?AeroElectric-List) (http://www.matronics.com/contribution) ________________________________________________________________________________
Date: Jan 04, 2012
Yeah, until the 4G phones get installed. bob noffs wrote: > seems what this world[or at least me] needs is a gps driven > directional gyro. i know that most gps units have part of a compass > rose displayed but for the price of a mechanical one i would think a > plain simple dg that mounts in a conventional 3'' hole and is gps > driven would be cheap and popular. > or at least a program to drive a palm pilot, tapping off the gps of > another unit. > bob noffs > * > > > * -- Tell the truth. Be honest. Be responsible to and for yourself. I liked America when it was free and it's people were responsible and had morals. Every gram of cocaine you buy from elsewhere contributes to an innocent being murdered in Central and South America. Grow your own or Stop taking it. ________________________________________________________________________________
Date: Jan 04, 2012
Good Morning -- Is it Jared? The GPS cannot be used in lieu of an ADF for an ADF approach. It can be used for all other functions of the ADF, but not when the ADF is the basis for the approach. If there is a published overlay, then the overlay approach can be executed. We tried to get permission to use it as you suggest, but the FEDs were firm. They told us that all ADF approaches would either get an overlay or a GPS approach that had better minima. While most have been handled that way, many have not. Does NOT make sense, but them's the rules. Happy Skies, Old Bob PS Incidentally, there are no longer any NDB approaches. They were all converted to ADF. In a message dated 1/4/2012 11:07:31 A.M. Central Standard Time, email(at)jaredyates.com writes: Hmmm.... I thought we could substitute an ifr gps for adf in ndb approaches. When you say compass, do you mean magnetically derived heading? On Jan 4, 2012, at 11:27, _BobsV35B(at)aol.com_ (mailto:BobsV35B(at)aol.com) wrote: Good Morning Ken, You said: "Several degrees of error can become problematical for things like an RNAV NDB approach." While this is getting quite far away from a subject for the Aeroelectric list, I would like to comment. If we are flying IFR, it would seem we need a legal method of shooting an NDB approach and the only method currently legal is to use an ADF combined with a legal compass heading. Once upon a time, we were legal to shoot that approach with just a fixed or manually rotatable loop and compass. No longer true. We must have an ADF and a compass. If we are cheating and want to use a GPS, even a legal GPS, to execute the approach, it would be pertinent to set the airport location as the 'go to' destination and fly the track to the airport. While heading is always nice to know, (it helps us determine where to look when visibility is marginal,) it pales in importance to staying on track toward the airport. Just sayin' nothin' else Happy Skies, Old Bob In a message dated 1/4/2012 10:01:16 A.M. Central Standard Time, _klehman(at)albedo.net_ (mailto:klehman(at)albedo.net) writes: Several degrees of error can become problematical for things like an RNAV NDB approach. ________________________________________________________________________________
Date: Jan 04, 2012
Good Afternoon, Just realized you asked a second question which I failed to address. ADF approaches are based on having good magnetically derived heading information. The approaches are not based on true courses as back when such approaches were developed, there was no practical way to get other than a magnetically derived heading in the airplane. When we use a Directional Gyro, we set it by the magnetic compass. Many modern units use a flux gate compass, but that is still magnetic. The DGs just provide stability that is difficult to get using a pure magnetic compass. Happy Skies, Old Bob In a message dated 1/4/2012 11:07:31 A.M. Central Standard Time, email(at)jaredyates.com writes: Hmmm.... I thought we could substitute an ifr gps for adf in ndb approaches. When you say compass, do you mean magnetically derived heading? On Jan 4, 2012, at 11:27, _BobsV35B(at)aol.com_ (mailto:BobsV35B(at)aol.com) wrote: Good Morning Ken, You said: "Several degrees of error can become problematical for things like an RNAV NDB approach." While this is getting quite far away from a subject for the Aeroelectric list, I would like to comment. If we are flying IFR, it would seem we need a legal method of shooting an NDB approach and the only method currently legal is to use an ADF combined with a legal compass heading. Once upon a time, we were legal to shoot that approach with just a fixed or manually rotatable loop and compass. No longer true. We must have an ADF and a compass. If we are cheating and want to use a GPS, even a legal GPS, to execute the approach, it would be pertinent to set the airport location as the 'go to' destination and fly the track to the airport. While heading is always nice to know, (it helps us determine where to look when visibility is marginal,) it pales in importance to staying on track toward the airport. Just sayin' nothin' else Happy Skies, Old Bob In a message dated 1/4/2012 10:01:16 A.M. Central Standard Time, _klehman(at)albedo.net_ (mailto:klehman(at)albedo.net) writes: Several degrees of error can become problematical for things like an RNAV NDB approach. D========= (mip://0aa914f8/3D"http://www.matronics.com/Navigator?AeroElectric-List") D========= (mip://0aa914f8/3D"http://forums.matronics.com") D========= (mip://0aa914f8/3D"http://www.matronics.com/contribution") D========= ________________________________________________________________________________
Date: Jan 04, 2012
Well thanks Bob! I for one fully exploited the overlay program. It allowed me to upgrade my Maule panel with a G300XL and not include an ADF. I did my training without ever having to learn to use and ADF and yet was able to take great advantage of all the ADF/overlay approaches for both training and travel. Now they seem quaint with RNAV T approaches, WAAS, and a 2 axis AP. Bill > Good Morning Bill, > Just a little bit more off topic if I may. > The overlay program was instituted to get a lot of early use out of > GPS approaches. When you executed an overlay approach. all the > guidance was strictly via GPS. The only thing used from the ADF > approach was the minima. Many divisions of the FAA were strongly > against the overlay program and the FAA is now removing the overlays > as fast as practical. Very few still exist. In most cases, the new > approach which replaces the overlay will have better minima, bit not > always. > To pat myself on the back just a bit, I do have some expertise on that > program. I was an early adopter and fought hard for the use of GPS In > Lieu of ADF and DME. With the help of Randy Kenagy and Phil Boyer of > ALPA . We got it done. I was contacted by a gentleman named Bob Wright > who was in the position within the FAA to get the job done. It took > almost a year, but we did get that permission and I am VERY proud of > what we got done. If you get to the correct FAA FED, things can work > correctly > Happy Skies. > Old Bragging Bob > In a message dated 1/4/2012 11:39:45 A.M. Central Standard Time, > Mauledriver(at)nc.rr.com writes: > > Yes, what Bob said. > > I'm thinking that track is better than heading. And if I recall > correctly, when many of those NDB approaches had GPS overlays a > few years ago, you didn't require an ADF (or the ability to fly a > mag heading), you just used a certified GPS to fly the NDB > tracks. (do any of those still exist - the ones I used to fly are > all replaced by RNAV T approaches) > > I guess what you are getting at is that you'd like to avoid having > to install a DG by using a GPS driven instrument. > > My glass panel gives me mag headings from the EFIS's AHRS system > and allows me to easily follow vectors. Otherwise, I don't have a > whiskey compass or vacuum driven heading instrument. The key > question is what happens with an electronics failure... well I > have a GRT ADI instrument with a GPS and an independent backup > battery. It just gives me a digital track readout along with turn > coordinator function and a quasi-horizon. I can't follow a mag > heading but I can fly a track pretty darn accurately. > > Bill "not completely off-topic" Watson > > On 1/4/2012 11:27 AM, BobsV35B(at)aol.com wrote: >> Good Morning Ken, >> You said: >> "Several degrees of error can become problematical for things >> like an RNAV NDB approach." >> While this is getting quite far away from a subject for the >> AeroElectric list, I would like to comment. >> If we are flying IFR, it would seem we need a legal method of >> shooting an NDB approach and the only method currently legal is >> to use an ADF combined with a legal compass heading. >> Once upon a time, we were legal to shoot that approach with just >> a fixed or manually rotatable loop and compass. >> No longer true. We must have an ADF and a compass. >> If we are cheating and want to use a GPS, even a legal GPS, to >> execute the approach, it would be pertinent to set the airport >> location as the 'go to' destination and fly the track to the >> airport. While heading is always nice to know, (it helps us >> determine where to look when visibility is marginal,) it pales in >> importance to staying on track toward the airport. >> Just sayin' nothin' else >> ** > ________________________________________________________________________________
Date: Jan 04, 2012
Good Afternoon Bill, That GNC300XL is a very good box at a reasonable price. Garmin did discontinue production about a year ago, but it is still supported and current data base updates are available. I have one in my Stearman and am very happy with it. You can still shoot all of the LNAV approaches. Every WAAS approach I know of has either an LNAV associated with it or there is a standalone LNAV to the same runway. Those Advisory Only glide paths are fun to fly, but it is my contention that the classic dive and drive technique will result in many more safely completed approaches. Check out the Advisory Only glide path on the N23 Rwy 7 approach. If someone should happen to follow that glide path below the MDA, they will hit solid rock prior to the runway threshold. The 300XL should be good for several more years. Happy Skies, Old Bob In a message dated 1/4/2012 1:53:06 P.M. Central Standard Time, Mauledriver(at)nc.rr.com writes: Well thanks Bob! I for one fully exploited the overlay program. It allowed me to upgrade my Maule panel with a G300XL and not include an ADF. I did my training without ever having to learn to use and ADF and yet was able to take great advantage of all the ADF/overlay approaches for both training and travel. Now they seem quaint with RNAV T approaches, WAAS, and a 2 axis AP. Bill Good Morning Bill, Just a little bit more off topic if I may. The overlay program was instituted to get a lot of early use out of GPS approaches. When you executed an overlay approach. all the guidance was strictly via GPS. The only thing used from the ADF approach was the minima. Many divisions of the FAA were strongly against the overlay program and the FAA is now removing the overlays as fast as practical. Very few still exist. In most cases, the new approach which replaces the overlay will have better minima, bit not always. To pat myself on the back just a bit, I do have some expertise on that program. I was an early adopter and fought hard for the use of GPS In Lieu of ADF and DME. With the help of Randy Kenagy and Phil Boyer of ALPA . We got it done. I was contacted by a gentleman named Bob Wright who was in the position within the FAA to get the job done. It took almost a year, but we did get that permission and I am VERY proud of what we got done. If you get to the correct FAA FED, things can work correctly Happy Skies. Old Bragging Bob In a message dated 1/4/2012 11:39:45 A.M. Central Standard Time, _Mauledriver(at)nc.rr.com_ (mailto:Mauledriver(at)nc.rr.com) writes: Yes, what Bob said. I'm thinking that track is better than heading. And if I recall correctly, when many of those NDB approaches had GPS overlays a few years ago, you didn't require an ADF (or the ability to fly a mag heading), you just used a certified GPS to fly the NDB tracks. (do any of those still exist - the ones I used to fly are all replaced by RNAV T approaches) I guess what you are getting at is that you'd like to avoid having to install a DG by using a GPS driven instrument. My glass panel gives me mag headings from the EFIS's AHRS system and allows me to easily follow vectors. Otherwise, I don't have a whiskey compass or vacuum driven heading instrument. The key question is what happens with an electronics failure... well I have a GRT ADI instrument with a GPS and an independent backup battery. It just gives me a digital track readout along with turn coordinator function and a quasi-horizon. I can't follow a mag heading but I can fly a track pretty darn accurately. Bill "not completely off-topic" Watson On 1/4/2012 11:27 AM, _BobsV35B(at)aol.com_ (mailto:BobsV35B(at)aol.com) wrote: Good Morning Ken, You said: "Several degrees of error can become problematical for things like an RNAV NDB approach." While this is getting quite far away from a subject for the AeroElectric list, I would like to comment. If we are flying IFR, it would seem we need a legal method of shooting an NDB approach and the only method currently legal is to use an ADF combined with a legal compass heading. Once upon a time, we were legal to shoot that approach with just a fixed or manually rotatable loop and compass. No longer true. We must have an ADF and a compass. If we are cheating and want to use a GPS, even a legal GPS, to execute the approach, it would be pertinent to set the airport location as the 'go to' destination and fly the track to the airport. While heading is always nice to know, (it helps us determine where to look when visibility is marginal,) it pales in importance to staying on track toward the airport. Just sayin' nothin' else ________________________________________________________________________________
Subject: Re: Capacitive Fuel Level Sensor - How do they
work?
Date: Jan 04, 2012
When a boat or ship leaves port the skipper and the navigator know exactly how much fuel is on board...All they need is a flow meter to calculate how much fuel they have on board. Aircraft however also like to know exactly how much fuel is in each tank even if there is a break in a fuel line. That requires an accurate method of measuring the fuel in the tank, in the air. There are only two recognized methods; Capacitance fuel gauges and drip sticks.... Drip sticks don't work in the air. Noel -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of paul wilson Sent: January 2, 2012 4:40 PM Subject: Re: AeroElectric-List: Re: Capacitive Fuel Level Sensor - How do they work? The boat people deal with crazy shaped tanks. Here is one example that uses a low tech float/resistor and a smart meter head. http://www.cruzpro.com/products.html#HEADINGE PaulW ===== >At 10:41 AM 1/2/2012, you wrote: > >The electronics have been explained by Joe and Sarg, and Sarg >elaborated on his experience with Princeton probes. > >But the reason for installing cap probes has gone unanswered. >Cap probes allow for fuel measurement of irregularly shaped tanks. >My fuel bays in the wing change in taper, both in depth and width, >in addition to the whole tank sitting at an angle (dihedral), making >any kind of accurate measurement impossible over the tank range when >using a linear type (float) sensor. >I have installed 8' Centroid probes. Haven't fueled them yet. >They come with two small potentiometers built in to adjust the empty >and full points. Available in 0-5v output and various resistance >output so you can use them with your existing gauge. > >http://www.centroidproducts.com/tableofc.htm > >Not a recommendation, just a resource, as I have no real world >experience with this product, . YMMV. ________________________________________________________________________________
Date: Jan 04, 2012
Subject: 14 volt bus / voltage regulator?
Looking for a voltage regulator recommendation: I need a small 14 volt bus bar in order to service ray allen servos and maybe a couple other 14 volt devices. I will be running a 28 volt system and would prefer to have a separate 14 volt bus. If anyone has any recommendations, or tips on how to go about servicing disparate voltage components, I=B9m much obliged -- Thank you, Andy ________________________________________________________________________________
Date: Jan 04, 2012
Nice! What strikes me about your low volume capabilities is what a colleague of mine coined some years ago, "Mass Customization". The ability to take advantage of specialization and mass production down to quantity = 1. Bill On 1/4/2012 1:15 PM, Ron Raby wrote: > Hi Bill, Bob > > Actually we build both high volume and low volume harnesses at my > company. Almost all of the harnesses we build use a harness board. Non > of the harness drawings, of the thousands we build were developed with > 3d cad, all were done in 2d. Attached is a small harness drawing with > a wire run list in pdf format for everyone to look at. Qty 2, 4 x 8 > sheets of plywood end to end could simulate the fusalage of most > planes. My intension is to give people ideas that may help. I am not > trying to sell anything. > the link is to my website and shows some pictures of completed harnesses. > > http://www.advanceddesign.com/products_harnesscable.html > > Regards > > Ron Raby > > > ----- Original Message ----- From: "Bill Watson" <Mauledriver(at)nc.rr.com> > To: > Sent: Wednesday, January 04, 2012 12:15 PM > Subject: Re: AeroElectric-List: Re: Wiring Harness > > >> >> >> In other words, using a template or form board is a mass production >> technique. Kind of the opposite of what we are doing in the OBAM world. >> >> Conversely, it would seem reasonable to think we can do a superior >> job with our hand built, single craftsman approach. Of course our >> amateur skills may cancel out any skilled craftsman advantage. >> >> Bill "reflecting on the joys of OBAM aircraft" Watson >>>> >>>> How about building the harness on a template. That way it can be >>>> built outside the aircraft tested and inspected before instalation. >>> >>> That IS how the 'big' guys do it. But they often build the proof >>> of concept harness in the airplane, take it out and build >>> a form-board to match it. Even with full 3-D CAD systems, it's >>> difficult to build a first-article that really fits the airplane >>> the way the craftsmen would like it. >>> >>> >>> Bob . . . >> >> >> >> >> >> >> ________________________________________________________________________________
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Date: Jan 04, 2012
Subject: Re: 14 volt bus / voltage regulator?
Ray Allen makes a 12V regulator just for 28V aircraft, P/N REG-1. Otherwise we've installed something like this for 12V items: http://www.wmjmarine.com/vtc60-24-12.html These days you can't really get by without a few 12V outlets. When we had the luxury, we've gone so far as to install a complete 12V battery and alternator, but that was on a turbine with lots of spare drive pads. Dave Saylor AirCrafters 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell On Wed, Jan 4, 2012 at 2:17 PM, Andy Hawes wrote: > Looking for a voltage regulator recommendation: > > I need a small 14 volt bus bar in order to service ray allen servos and > maybe a couple other 14 volt devices. I will be running a 28 volt system > and would prefer to have a separate 14 volt bus. If anyone has any > recommendations, or tips on how to go about servicing disparate voltage > components, I=99m much obliged -- > > Thank you, > > Andy > > * > =========== =========== =========== =========== > * > > ________________________________________________________________________________
Date: Jan 04, 2012
work?
For those of us with a high-wing, we also get to use a third option of optical quantity indication. On Wed, Jan 4, 2012 at 4:41 PM, Noel Loveys wrote: > noelloveys(at)yahoo.ca> > > When a boat or ship leaves port the skipper and the navigator know exactly > how much fuel is on board...All they need is a flow meter to calculate how > much fuel they have on board. Aircraft however also like to know exactly > how much fuel is in each tank even if there is a break in a fuel line. > That > requires an accurate method of measuring the fuel in the tank, in the air. > There are only two recognized methods; Capacitance fuel gauges and drip > sticks.... Drip sticks don't work in the air. > > Noel > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of paul > wilson > Sent: January 2, 2012 4:40 PM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Re: Capacitive Fuel Level Sensor - How do > they work? > > > The boat people deal with crazy shaped tanks. Here is one example > that uses a low tech float/resistor and a smart meter head. > http://www.cruzpro.com/products.html#HEADINGE > PaulW > ===== > > >At 10:41 AM 1/2/2012, you wrote: > > > > > >The electronics have been explained by Joe and Sarg, and Sarg > >elaborated on his experience with Princeton probes. > > > >But the reason for installing cap probes has gone unanswered. > >Cap probes allow for fuel measurement of irregularly shaped tanks. > >My fuel bays in the wing change in taper, both in depth and width, > >in addition to the whole tank sitting at an angle (dihedral), making > >any kind of accurate measurement impossible over the tank range when > >using a linear type (float) sensor. > >I have installed 8' Centroid probes. Haven't fueled them yet. > >They come with two small potentiometers built in to adjust the empty > >and full points. Available in 0-5v output and various resistance > >output so you can use them with your existing gauge. > > > >http://www.centroidproducts.com/tableofc.htm > > > >Not a recommendation, just a resource, as I have no real world > >experience with this product, . YMMV. > > ________________________________________________________________________________
Date: Jan 04, 2012
You are correct, we can't substitute GPS unless the approach title includes "or GPS," indicating that it is an overlay. On Wed, Jan 4, 2012 at 2:19 PM, wrote: > ** > Good Morning -- Is it Jared? > > The GPS cannot be used in lieu of an ADF for an ADF approach. > > It can be used for all other functions of the ADF, but not when the ADF is > the basis for the approach. > > If there is a published overlay, then the overlay approach can be > executed. We tried to get permission to use it as you suggest, but the FEDs > were firm. They told us that all ADF approaches would either get an overlay > or a GPS approach that had better minima. While most have been handled that > way, many have not. > > Does NOT make sense, but them's the rules. > > Happy Skies, > > Old Bob > > PS Incidentally, there are no longer any NDB approaches. They were all > converted to ADF. > > In a message dated 1/4/2012 11:07:31 A.M. Central Standard Time, > email(at)jaredyates.com writes: > > Hmmm.... I thought we could substitute an ifr gps for adf in ndb > approaches. When you say compass, do you mean magnetically derived heading? > > > On Jan 4, 2012, at 11:27, BobsV35B(at)aol.com wrote: > > Good Morning Ken, > > You said: > "Several degrees of error can become problematical for things like an RNAV > NDB approach." > > While this is getting quite far away from a subject for the Aeroelectric > list, I would like to comment. > > If we are flying IFR, it would seem we need a legal method of shooting an > NDB approach and the only method currently legal is to use an ADF combined > with a legal compass heading. > > Once upon a time, we were legal to shoot that approach with just a fixed > or manually rotatable loop and compass. > > No longer true. We must have an ADF and a compass. > > If we are cheating and want to use a GPS, even a legal GPS, to execute the > approach, it would be pertinent to set the airport location as the 'go to' > destination and fly the track to the airport. While heading is always nice > to know, (it helps us determine where to look when visibility is marginal,) > it pales in importance to staying on track toward the airport. > > Just sayin' nothin' else > > Happy Skies, > > Old Bob > In a message dated 1/4/2012 10:01:16 A.M. Central Standard Time, > klehman(at)albedo.net writes: > > Several degrees of error can become problematical for > things like an RNAV NDB approach. > > * > > * > > ** > > * > > > * > > ________________________________________________________________________________
work?
Date: Jan 04, 2012
True if your seat is close to the wing as in my Kitfox...You got me! Noel From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Jared Yates Sent: January 4, 2012 8:24 PM Subject: Re: AeroElectric-List: Re: Capacitive Fuel Level Sensor - How do they work? For those of us with a high-wing, we also get to use a third option of optical quantity indication. On Wed, Jan 4, 2012 at 4:41 PM, Noel Loveys wrote: When a boat or ship leaves port the skipper and the navigator know exactly how much fuel is on board...All they need is a flow meter to calculate how much fuel they have on board. Aircraft however also like to know exactly how much fuel is in each tank even if there is a break in a fuel line. That requires an accurate method of measuring the fuel in the tank, in the air. There are only two recognized methods; Capacitance fuel gauges and drip sticks.... Drip sticks don't work in the air. Noel -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of paul wilson Sent: January 2, 2012 4:40 PM Subject: Re: AeroElectric-List: Re: Capacitive Fuel Level Sensor - How do they work? The boat people deal with crazy shaped tanks. Here is one example that uses a low tech float/resistor and a smart meter head. http://www.cruzpro.com/products.html#HEADINGE PaulW ===== >At 10:41 AM 1/2/2012, you wrote: > >The electronics have been explained by Joe and Sarg, and Sarg >elaborated on his experience with Princeton probes. > >But the reason for installing cap probes has gone unanswered. >Cap probes allow for fuel measurement of irregularly shaped tanks. >My fuel bays in the wing change in taper, both in depth and width, >in addition to the whole tank sitting at an angle (dihedral), making >any kind of accurate measurement impossible over the tank range when >using a linear type (float) sensor. >I have installed 8' Centroid probes. Haven't fueled them yet. >They come with two small potentiometers built in to adjust the empty >and full points. Available in 0-5v output and various resistance >output so you can use them with your existing gauge. > >http://www.centroidproducts.com/tableofc.htm > >Not a recommendation, just a resource, as I have no real world >experience with this product, . YMMV. -List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List ========== http://forums.matronics.com ========== le, List Admin. ="_blank">http://www.matronics.com/contribution ========== ________________________________________________________________________________
Subject: 25 stainbless cable ties for 5$
Date: Jan 04, 2012
Hi group For what it's worth I just visited a Harbor freight that just opened by my home and saw they are selling 25 cable ties for 5$: http://www.harborfreight.com/3-16-inch-x-12-inch-25-piece-stainless-steel-cable-ties-92515.html They look OK but I didn't test them. Ron Parigoris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362459#362459 ________________________________________________________________________________
Date: Jan 05, 2012
Andy, I used a Collins PWC-150. It has two independent channels, either of which will handle all of the Ray Allen servos. I put an "on-off-on" toggle swit ch so that I had both a primary and a back up 14vdc output. Protect the c ircuit with a circuit breaker, and you are all set. You can also use a Ki ng KA-39, although if I remember correctly, it is only one channel. Either unit is available on E-bay for around $100 or less. Most avionics shops a re littered with these units. On a side note, I just powered up my panel, everything works, no smoke, no components changed color, and no thermal events! Good Luck, David Vorsas Radial Rocket N385BV From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectr ic-list-server(at)matronics.com] On Behalf Of Andy Hawes Sent: Wednesday, January 04, 2012 5:18 PM Subject: AeroElectric-List: 14 volt bus / voltage regulator? Looking for a voltage regulator recommendation: I need a small 14 volt bus bar in order to service ray allen servos and may be a couple other 14 volt devices. I will be running a 28 volt system and would prefer to have a separate 14 volt bus. If anyone has any recommendat ions, or tips on how to go about servicing disparate voltage components, I' m much obliged -- Thank you, Andy This message has been processed via your triumphgroup.com e-mail address. ________________________________________________________________________________
Date: Jan 05, 2012
ok, that sounds like the ticket =8B thank you. I found this part number afte r matching up the converter specs you gave me with DigiKey that should save you a few bucks if you need this again in the future: http://search.digikey.com/scripts/DkSearch/dksus.dll?WT.z_header=search_go& l ang=en&site=us&keywords=102-2273-ND&x &y=15 digikey part number: 102-2273-ND this is a smaller device and 12.5 amperage output. Just wondering if you guys use an inline fuse with this type of device? Or would you rather have a breaker available to the pilot just in case the device ever has an issue in flight? Thanks for the recommendation -- Andy On 1/4/12 5:23 PM, "Dave Saylor" wrote: > Ray Allen makes a 12V regulator just for 28V aircraft, P/N REG-1. > > Otherwise we've installed something like this for 12V items: > > http://www.wmjmarine.com/vtc60-24-12.html > > These days you can't really get by without a few 12V outlets. > > When we had the luxury, we've gone so far as to install a complete 12V ba ttery > and alternator, but that was on a turbine with lots of spare drive pads. > > Dave Saylor > AirCrafters > 140 Aviation Way > Watsonville, CA 95076 > 831-722-9141 Shop > 831-750-0284 Cell > > > On Wed, Jan 4, 2012 at 2:17 PM, Andy Hawes wrote: >> Looking for a voltage regulator recommendation: >> >> I need a small 14 volt bus bar in order to service ray allen servos and maybe >> a couple other 14 volt devices. -I will be running a 28 volt system and would >> prefer to have a separate 14 volt bus. -If anyone has any recommendation s, or >> tips on how to go about servicing disparate voltage components, I=B9m much >> obliged --- >> >> Thank you, >> >> Andy >> >> >> ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-Lis t >> >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> > > > > > ________________________________________________________________________________
Subject: Re: First Engine Start Problem
Date: Jan 06, 2012
On Dec 30, 2011, at 7:14 PM, Robert L. Nuckolls, III wrote: > If you wanted to put a 20A, in-line fuse holder in its > place, that would be fine too as long as you don't have > BREAKERS downstream. Bob, can you explain what is bad about having circuit breakers downstream of fuses? I wired my Lightspeed Plasma II ignition through a fuse on the battery bus to the breaker on the panel because I didn't want such a long, always-hot wire from the battery directly to the panel. Should I rewire this? thanks, jason ________________________________________________________________________________
Date: Jan 06, 2012
If the current ratings are similar, the fuse will always blow first, so the breaker serves no purpose. If the fuse current rating is some significant multiple of the breaker rating that might work - which might be okay to protect against shorts in the wire up to the breaker - but what is the point. Dick Tasker Jason Beaver wrote: > --> AeroElectric-List message posted by: Jason Beaver > > > On Dec 30, 2011, at 7:14 PM, Robert L. Nuckolls, III wrote: > >> If you wanted to put a 20A, in-line fuse holder in its >> place, that would be fine too as long as you don't have >> BREAKERS downstream. > Bob, can you explain what is bad about having circuit breakers downstream of fuses? I wired my Lightspeed Plasma II ignition through a fuse on the battery bus to the breaker on the panel because I didn't want such a long, always-hot wire from the battery directly to the panel. Should I rewire this? > > thanks, > > jason > > ________________________________________________________________________________
Date: Jan 06, 2012
At 02:16 AM 1/6/2012, you wrote: On Dec 30, 2011, at 7:14 PM, Robert L. Nuckolls, III wrote: > If you wanted to put a 20A, in-line fuse holder in its > place, that would be fine too as long as you don't have > BREAKERS downstream. Bob, can you explain what is bad about having circuit breakers downstream of fuses? I wired my Lightspeed Plasma II ignition through a fuse on the battery bus to the breaker on the panel because I didn't want such a long, always-hot wire from the battery directly to the panel. Should I rewire this? Probably. Put the one and only protective device (5A breaker or fuse) at the battery bus with no further devices downstream. If THAT protection opens, it is because the ignition system is hurt bad . . . and you'll need to rely on the second, totally independent system to bring your flight to an orderly conclusion. To have a 'breaker' downstream of a fuse turns the breaker into a switch. Breakers are so much slower than a fuse that a 5A fuse upstream of the 5A breaker will always open first. In fact, a 10A fuse upstream of a 5A breaker will still open before the 5A breaker. The "fuse" symbol often found upstream of breakers in aircraft power distribution diagrams is a CURRENT LIMITER, a robust, special kind of fuse with fusing dynamics that are very unlike their little plastic, plug-in cousins. For example: http://aeroelectric.com/Mfgr_Data/Fuses_and_Current_Limiters/Bussman/ANL_Specs.pdf Note that a '35 Amp' ANL will carry 80 amps about indefinitely which is a 200% overload. The ANL and close cousins are suited for protecting fat-wire feeders to busses downstream that might mount circuit breakers. Here we see: http://aeroelectric.com/Mfgr_Data/Fuses_and_Current_Limiters/Bussman/ATC_Specs.pdf that a 200% overload on a 5A ATC plastic fuse is expected to open it in something on the order of 300 milliseconds. In the last data sheet we see: http://aeroelectric.com/Mfgr_Data/Breakers/Eaton/Eaton_4200.pdf that a Series 4200 miniature breaker under 200% overload can take from 2 to 20 seconds to open and still be "in spec". As a matter of simple design goals, a single feeder needs only one protective device located as near to the power source (bus) as practical. Any device upstream of a breaker needs to be robust enough to stay closed during operation of the downstream device. Finally, all robust fuses and indeed any protective device over 5A is discouraged for use on always hot feeders. This design rule is cited in the FARS and generally refers to circuit breakers. We know that a 5A breaker will open a 10A fuse . . . so it follows that one COULD consider 10A ATC fuses on battery bus feeders without presenting potential fault energy worst than a 5A breaker. Bob . . . ________________________________________________________________________________
Subject: Z-12, Z-13/8 or a bit of both!
Date: Jan 08, 2012
Initially I was going to use Z-12 for my Long-EZ system because it shows the LR-3 controller and I have the following: B&c LR-3 alternator controller B&C SD-8 and all the associated bits I'm using two Bendix mags Most probable going to use an auto alternator with the LR-3 (undecided on make as yet) then I was advised to use Z-13/8 (quite correctly) which shows the B&C SD-8 setup, so my question is would it be O.K. to use a mixture of both from Z-12 and Z-13/8. It would be helpful to find out any pitfalls before starting this project. Regards Mike (U.K.) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362749#362749 ________________________________________________________________________________
Date: Jan 08, 2012
Subject: Re: Z-12, Z-13/8 or a bit of both!
At 12:41 PM 1/8/2012, you wrote: > >Initially I was going to use Z-12 for my Long-EZ system because it >shows the LR-3 controller and I have the following: The z-figures are intended to show ARCHITECTURE. Parts are exemplar but not unique to that architecture. Why Z-12? The Z-13/8 was designed to max maximum use of the limited output of the SD-8 (no battery contactor). >B&c LR-3 alternator controller >B&C SD-8 and all the associated bits >I'm using two Bendix mags >Most probable going to use an auto alternator with the LR-3 >(undecided on make as yet) It needs to be an alternator compatible with external regulation. >then I was advised to use Z-13/8 (quite correctly) which shows the >B&C SD-8 setup, so my question is would it be O.K. to use a mixture >of both from Z-12 and Z-13/8. What features of 12 need to be incorporated into 13? The style of ignition systems is irrelevant to the discussion. >It would be helpful to find out any pitfalls before starting this project. I am certain that there have been dozens of 'variations on a theme' wherein items from various documents and architectures were cherry-picked and assembled into a new architecture. Most perform as advertised . . . assuming the 'chef' really understands the significance of the cherry-picking. Start with Z-13/8 and tell us what items depicted don't fit your planned suite of hardware. Bob . . . ________________________________________________________________________________
Subject: Noise in damp weather
Date: Jan 08, 2012
Hi, I am hoping someone can give me some pointers in finding and eliminating a problem. I have a french built wooden aircraft with 0-200, B&C starter and 30Amp alternator. Narco radio and transponder with intercom. The intercom is wired with shielded wiring as per the manufacturers instructions. This aircraft uses a negative earth, with a switch that is cable actuated. The B&C Alternator is wired as per the manufacturers diagram, using a large capacitor on the DC Output. All of the lighting and as many earths as I could find have been wired independently to a "forest of earth" on the inside of the firewall, connected by a brass bolt to another earth forest on the engine side of the firewall. A heavy earth cable then runs from the 5/16" brass bolt to the engine. There is a skyflash strobe with strobe heads top and bottom of fuz. On most frequencies there is a sharp crack through the radio as ea ch strobe discharges. Never got to the bottom of this problem, despite various attempts. The few times, including today that I have been caught in rain or very damp weather and have put the nav and/or landing light on I am getting a loud buzz / shriek through the radio into the headsets. This is normally silent in dry weather. On finals today, the radio went dead, I thought a fuse had blown, so I switched it off. When landed and clear the active I switched it back on and it worked ok. I would appreciate any ideas on where to start looking for the source of this noise in the wet weather. There is never any noise from the mags or the alternator. Thanks Gavin Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362765#362765 ________________________________________________________________________________
Date: Jan 09, 2012
Subject: Re: Noise in damp weather
At 03:06 PM 1/8/2012, you wrote: > > >Hi, > >I am hoping someone can give me some pointers in finding and >eliminating a problem. >I have a french built wooden aircraft with 0-200, B&C starter and >30Amp alternator. Narco radio and transponder with intercom. The >intercom is wired with shielded wiring as per the manufacturers instructions. > >This aircraft uses a negative earth, with a switch that is cable actuated. > >The B&C Alternator is wired as per the manufacturers diagram, using >a large capacitor on the DC Output. >All of the lighting and as many earths as I could find have been >wired independently to a "forest of earth" on the inside of the >firewall, connected by a brass bolt to another earth forest on the >engine side of the firewall. A heavy earth cable then runs from the >5/16" brass bolt to the engine. > >There is a skyflash strobe with strobe heads top and bottom of fuz. >On most frequencies there is a sharp crack through the radio as ea >ch strobe discharges. Never got to the bottom of this problem, >despite various attempts. This style of noise is usually RADIATED . . . I.e. comes directly from the strobe tube and is received through the receiver antenna. This is an easy thing to confirm but a TOUGH nut to crack. Check out chapter in the 'Connection on interference analysis. In this case, I'm pretty sure the noise you hear is affected by volume control on receiver which means the noise is coming in through the antenna. Proximity of the antenna to flash tube can be widened. Sometimes a fine wire, coarsely woven wire mesh shield over the flash tube grounded to base helps. This is one of the hardest noise issues to eliminate. >The few times, including today that I have been caught in rain or >very damp weather and have put the nav and/or landing light on I am >getting a loud buzz / shriek through the radio into the headsets. >This is normally silent in dry weather. >On finals today, the radio went dead, I thought a fuse had blown, so >I switched it off. When landed and clear the active I switched it >back on and it worked ok. > >I would appreciate any ideas on where to start looking for the >source of this noise in the wet weather. > >There is never any noise from the mags or the alternator. Man! Don't know where to even begin. Intermittent and/or special-conditions events can be very $hard$ to track down. One of my most satisfying victories involved tracking down a pushed back pin in a pressure bulkhead connector that would only manifest failure at very low outside ambient temperatures and in-flight. I had to develop an instrumentation system that we could read in the cabin to make measurements back in the un-pressurized 'hell-hole' while in flight. I found that I could tape ribbon-cable to the side of the fuselage and slip it through the door gaskets at each end to extend test signals to the cabin. Even then, we made several test flights to 41,000 feet in an airplane that cost a LOT of money to operate. I would have to hear the nature of your noise to even begin to identify its source. You might carry a hand held radio to see if the noise can be heard it in as well. Do the diagnostics steps defined in the chapter on noise. Is the squeal affected by volume control . . . position of switches power on intercom (does your intercom do a auto-bypass when powered down so you can still use the radio?). This can be a challenge but the problems you've observed DO have explanations in simple physics. Bob . . . ________________________________________________________________________________
Date: Jan 09, 2012
Chinesespaceman-- You DO have the ability to dry airplane and then wet one section at a time. Also, remember that WD-40 is really made for Water Displacement. It works extremely well at driving off water and displacing it with a non-conductive oil. There is not much downside to spraying electrical connections where leakage to ground or other connections might occur. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362815#362815 ________________________________________________________________________________
Date: Jan 10, 2012
The part about the shriek with an applied load that is corrected by cycling the master sounds a lot like an experience I once had with a balky reverse current relay. On landing roll out, just when no one would ever be looking at the electrical gauges, the bus voltage would go way low and the avionics would start to howl. Clearly an RCR isn't the problem here, but perhaps transient very low bus voltage is... Glen Matejcek ________________________________________________________________________________
Date: Jan 10, 2012
work? On 1/2/2012 8:41 AM, jonlaury wrote: > Cap probes allow for fuel measurement of irregularly shaped tanks. My fuel bays in the wing change in taper, both in depth and width, in addition to the whole tank sitting at an angle (dihedral), making any kind of accurate measurement impossible over the tank range when using a linear type (float) sensor. I believe the capacitive probe will be linear over its length as well; it won't "know" about the cross sectional area of the tank at any given sensing point, just whether or not fuel is present there. The advantage may be that a long capacitive probe can extend through a tank designed such that a float type sensor, on one end or the other, will 'range out', because when one end of the tank is full, the other end is still not full, or vice versa. It's also possible, though difficult, to custom bend a capacitive probe so that there's more range (flatter slope) in greater cross-sectional areas of the tank, and less range (steeper slope) in smaller areas of the tank; that tends to linearize the output. But it's a tough thing to accomplish with high resolution. Generally, linearizing a broad range signal is a problem that's been solved many times in electronics technology with signal conditioners, even before the advent of microprocessors. Whether anyone offers such a product, beyond the full/empty adjustments Jon mentioned, I do not know. But the all-in-one EI and JPI solutions, as well as AerospaceLogic's standalone indicators offer such lindearization built into their displays. In the 80's in process instrumentation industry, there were a number of well-designed (non-interactive adjustment) signal conditioners, for under $100, that had three or four linearization adjustments across an input range. Paul ________________________________________________________________________________
Date: Jan 11, 2012
work? >I believe the capacitive probe will be linear over its length as >well; it won't "know" about the cross sectional area of the tank at >any given sensing point, just whether or not fuel is present there. True for off-the-shelf probes . . . wherein the designer has no first-hand knowledge of tank geometry for the proposed installation. It is possible to build a capacitive probe that presents an output that is not linear with relation to liquid level. This patent speaks to some examples: http://tinyurl.com/6ogp4ve The advantage may be that a long capacitive probe can extend through a tank designed such that a float type sensor, on one end or the other, will 'range out', because when one end of the tank is full, the other end is still not full, or vice versa. It's also possible, though difficult, to custom bend a capacitive probe so that there's more range (flatter slope) in greater cross-sectional areas of the tank, and less range (steeper slope) in smaller areas of the tank; that tends to linearize the output. But it's a tough thing to accomplish with high resolution. Until the micro-controller came along. The last trade study I did for HBC spoke to a system with a self calibrating feature. You put the signal conditioner for a pure linear probe into a calibrate mode, put unusable fuel in tank and then tell the signal conditioner "this is zero fuel". Then fill the tank with 10% steps for capacity stopping each time to tall the signal conditioner to "remember this value as x%" ending up at 100% or full. When taken out of the calibrate mode, the signal conditioner does a linear interpolation of the fuel level across the constellation of calibrated data points to offer a very close representation of available fuel irrespective of tank and probe geometry. The approach to sensing and signal conditioning would produce a device that's adaptable to virtually any airplane and combination of probes. This produces a gage that is "too accurate" in that substantial uncertainty in calibration points is introduced by dielectric constant of various loads of fuel and temperatures. The "ultimate" system includes a calibration probe at the bottom of the tank that is always submerged and offers the signal conditioner a real-time sample of variables for that particular load of fuel. The electronics becomes so simple that it costs more to build an install a sturdy set of probes in something like a Hawker 4000 than the electronics which processes data from those probes! Bill of materials for the electronics came in at about $10 in production lots. >In the 80's in process instrumentation industry, there were a number >of well-designed (non-interactive adjustment) signal conditioners, >for under $100, that had three or four linearization adjustments >across an input range. I took a whack at such a device for Cessna about that time. They were proposing a spring cartridge in the elevator controls that could be 'wound up' to offer a constant stick-force-per-G under the range of flight conditions of airspeed and CG. Made my head get real tight! The last iteration drove a non linear cam to 'get the curve'. The system we proposed never made it into the airplane. Don't recall how they solved the problem. A couple years later, we (Electro-Mech) did what I belive is the first micro-processor driven trim system that flew on the aborted Mooney M30 program. This did use the lookup table I described for fuel level signals to drive the pivot location actuator for a servo/anti-servo tab. That showed more promise but the project got canceled (prototype missed target weights by about 500 pounds!). In any case, it proved the future utility of software for slaying such dragons. Bob . . . Bob . . . ________________________________________________________________________________
Date: Jan 11, 2012
Subject: Re: ectric-List:
On 1/4/2012 7:55 AM, Ken Lehman wrote: > Some rnav units that have airspeed inputs calculate drift and simply use > a lookup table to convert track to magnetic dg info. How would that work, Ken? Seems like knowing only airspeed and groundspeed, you don't know if the headwind/tailwind component is directly ahead/behind you or off a wingtip... so how does airspeed and groundspeed and track allow you to calculate heading? Paul -- Please note my new email address! millner(at)me.com ________________________________________________________________________________
Subject: HID light noise
Date: Jan 12, 2012
Hi Bob, I've got a set of 50w HID lights that are extremely noisy. There is so much static on either the SL 30 or the 480 that they are practically useless. I don't dare turn them on in a high traffic area because of the poor radio reception I get when they are on. A hand held VHF radio also picks up the static and the amount of static varies with the distance from the lights. The vendor is Plane Lights and they said they would take them back if I can't solve the problem. I tried their solution of running a ground directly to the battery and that didn't help at all. Is this a winnable battle worth the trouble or should I just send them back? Is there anything simple that can be done? Thanks! Sheldon Olesen ________________________________________________________________________________
Subject: Re: HID light noise
Date: Jan 12, 2012
Are they DS1 style? Those are supposed to be less noisy. That's how I ended up with Duckworks. Tim On Jan 12, 2012, at 11:32 AM, Sheldon Olesen wrote: > > Hi Bob, > > I've got a set of 50w HID lights that are extremely noisy. There is so much static on either the SL 30 or the 480 that they are practically useless. I don't dare turn them on in a high traffic area because of the poor radio reception I get when they are on. A hand held VHF radio also picks up the static and the amount of static varies with the distance from the lights. The vendor is Plane Lights and they said they would take them back if I can't solve the problem. I tried their solution of running a ground directly to the battery and that didn't help at all. Is this a winnable battle worth the trouble or should I just send them back? Is there anything simple that can be done? > > Thanks! > > Sheldon Olesen > > > > > ________________________________________________________________________________
Date: Jan 12, 2012
I have the same problem with Plane Light HIDs. Love the lights, hate the noise. My SL-30 is unusable with the lights on. I've tried all the simple fixes including making a filter per someone's instructions (I forget who but it was on this list). The filter consisted of a choke and capacitor. I followed the instructions explicitly but the filter didn't have any effect on the noise. I think I'm asking alot since the comm antenna on the radio that's affected is a Bob Archer in the wingtip right next to the light. The other comm is has a belly-mounted antenna that isn't affected at all. Good thing Dave Saylor AirCrafters 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell On Thu, Jan 12, 2012 at 9:32 AM, Sheldon Olesen wrote: > saolesen(at)sirentel.net> > > Hi Bob, > > I've got a set of 50w HID lights that are extremely noisy. There is so > much static on either the SL 30 or the 480 that they are practically > useless. I don't dare turn them on in a high traffic area because of the > poor radio reception I get when they are on. A hand held VHF radio also > picks up the static and the amount of static varies with the distance from > the lights. The vendor is Plane Lights and they said they would take them > back if I can't solve the problem. I tried their solution of running a > ground directly to the battery and that didn't help at all. Is this a > winnable battle worth the trouble or should I just send them back? Is > there anything simple that can be done? > > Thanks! > > Sheldon Olesen > > ________________________________________________________________________________
Date: Jan 12, 2012
Don't know. They fit in the MR16 wingtip kit for halogen lamps that Van's sells. They look like this: As far as I can tell, there's nothing "less noisy" about them! I'm lucky in that they only affect my Comm2 so it's not that big a deal but for someone with a single comm they'd be a showstopper. Dave Saylor AirCrafters 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell On Thu, Jan 12, 2012 at 10:33 AM, Tim Olson wrote: > > Are they DS1 style? Those are supposed to be less noisy. That's how I > ended up with Duckworks. > Tim > > > On Jan 12, 2012, at 11:32 AM, Sheldon Olesen > wrote: > > saolesen(at)sirentel.net> > > > > Hi Bob, > > > > I've got a set of 50w HID lights that are extremely noisy. There is so > much static on either the SL 30 or the 480 that they are practically > useless. I don't dare turn them on in a high traffic area because of the > poor radio reception I get when they are on. A hand held VHF radio also > picks up the static and the amount of static varies with the distance from > the lights. The vendor is Plane Lights and they said they would take them > back if I can't solve the problem. I tried their solution of running a > ground directly to the battery and that didn't help at all. Is this a > winnable battle worth the trouble or should I just send them back? Is > there anything simple that can be done? > > > > Thanks! > > > > Sheldon Olesen > > > > > > > > > > > > ________________________________________________________________________________
Date: Jan 12, 2012
I've Bob Archer nav antennas in each wing tip. With the ballast so close to the antennas is there any hope a different HID system? With my wings paint ed I don't want to be cutting holes in the leading edge. I'm doing the annu al and the weather is crappy so now is a good time to be dealing with the pr oblem. Sheldon Olesen Sent from my iPad On Jan 12, 2012, at 12:54 PM, Dave Saylor wrote: > Don't know. They fit in the MR16 wingtip kit for halogen lamps that Van's sells. They look like this: > > > > As far as I can tell, there's nothing "less noisy" about them! > > I'm lucky in that they only affect my Comm2 so it's not that big a deal bu t for someone with a single comm they'd be a showstopper. > > Dave Saylor > AirCrafters > 140 Aviation Way > Watsonville, CA 95076 > 831-722-9141 Shop > 831-750-0284 Cell > > > On Thu, Jan 12, 2012 at 10:33 AM, Tim Olson wrote: > > Are they DS1 style? Those are supposed to be less noisy. That's how I en ded up with Duckworks. > Tim > > > On Jan 12, 2012, at 11:32 AM, Sheldon Olesen wrote : > el.net> > > > > Hi Bob, > > > > I've got a set of 50w HID lights that are extremely noisy. There is so m uch static on either the SL 30 or the 480 that they are practically useless. I don't dare turn them on in a high traffic area because of the poor radio r eception I get when they are on. A hand held VHF radio also picks up the s tatic and the amount of static varies with the distance from the lights. T he vendor is Plane Lights and they said they would take them back if I can't solve the problem. I tried their solution of running a ground directly to t he battery and that didn't help at all. Is this a winnable battle worth the trouble or should I just send them back? Is there anything simple that can be done? > > > > Thanks! > > > > Sheldon Olesen > > > > > > > > > > > > > ========== > - > ric-List" target="_blank">http://www.matronics.com/Navigator?AeroElectri c-List > ========== > MS - > k">http://forums.matronics.com > ========== > e - > -Matt Dralle, List Admin. > t="_blank">http://www.matronics.com/contribution > ========== > > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Jan 12, 2012
Here is how I won the battle with noise from the cheap HID lights... http://www.vansairforce.com/community/showthread.php?t=67875&highlight=Hid Read this topic online here: http://forums.matronics.com/viewtopic.php?p=363475#363475 ________________________________________________________________________________
Date: Jan 12, 2012
Hello Paul The GPS gives groundspeed, track, and position. You can go into a lookup table to find the magnetic variation at your position. If you know the TAS because you have pitot static info and temperature, you should be able to solve for the wind vector I believe. Same as can be done with an E6B computer. I think it goes heading vector plus wind vector equals track vector. So if you know any two vectors you can compute the third vector. Mostly I was just pointing out that many glass PFD/ADI systems already have all the sensor info they need to display a magnetic heading if the designer wishes to display it. I often fly an aircraft that does just that. It has no magnetic sensors but it computes and displays magnetic heading. Of course variation does change slightly over a multi year period so minor changes in the lookup table might be appropriate every few years if high accuracy is desired. Ken > S> > > On 1/4/2012 7:55 AM, Ken Lehman wrote: > > Some rnav units that have airspeed inputs calculate drift and simply use > > a lookup table to convert track to magnetic dg info. > How would that work, Ken? Seems like knowing only airspeed and > groundspeed, you don't know if the headwind/tailwind component is > directly ahead/behind you or off a wingtip... so how does airspeed and > groundspeed and track allow you to calculate heading? > > Paul > > -- > ________________________________________________________________________________
Date: Jan 12, 2012
No, you're missing the heading. Your lookup table is just giving you the magnetic adjustment to a 'true' track. Most GPS's do just that when you tell them you want a magnetic track. You said your aircraft has no access to magnetic information. Without that it can't tell your plane is pointing in a direction other than the ground track - magnetic or not. Your heading will only match your track in no wind conditions. You still need something to tell you which way the plane is pointing, not tracking. However if the EFIS has access to magnetic heading data, then you can calculate wind speed and direction in the EFIS. Bob Meyers Flying my Sonex N982SX - Building log at http://n982sx.com Sent from my iPad On Jan 12, 2012, at 6:36 PM, "Ken Lehman" wrote: > > Hello Paul > > The GPS gives groundspeed, track, and position. > You can go into a lookup table to find the magnetic variation at your > position. If you know the TAS because you have pitot static info and > temperature, you should be able to solve for the wind vector I believe. > Same as can be done with an E6B computer. I think it goes heading vector > plus wind vector equals track vector. So if you know any two vectors you > can compute the third vector. > > Mostly I was just pointing out that many glass PFD/ADI systems already > have all the sensor info they need to display a magnetic heading if the > designer wishes to display it. I often fly an aircraft that does just > that. It has no magnetic sensors but it computes and displays magnetic > heading. > > Of course variation does change slightly over a multi year period so > minor changes in the lookup table might be appropriate every few years > if high accuracy is desired. > > Ken > >> S> >> >> On 1/4/2012 7:55 AM, Ken Lehman wrote: >>> Some rnav units that have airspeed inputs calculate drift and simply use >>> a lookup table to convert track to magnetic dg info. >> How would that work, Ken? Seems like knowing only airspeed and >> groundspeed, you don't know if the headwind/tailwind component is >> directly ahead/behind you or off a wingtip... so how does airspeed and >> groundspeed and track allow you to calculate heading? >> >> Paul >> >> -- >> > > > > > ________________________________________________________________________________
Date: Jan 12, 2012
I tried copying your setup exactly, from your post to this list back in February. I was pretty excited since your symptoms seemed identical to mine, even the Dynon dropping offline. But, no luck... What antenna are you using, and where is it? I have an Archer antenna in each wingtip, one nav and one comm. Dave Saylor AirCrafters 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell On Thu, Jan 12, 2012 at 4:05 PM, Brantel wrote: > > Here is how I won the battle with noise from the cheap HID lights... > > http://www.vansairforce.com/community/showthread.php?t=67875&highlight=Hid > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=363475#363475 > > ________________________________________________________________________________
Date: Jan 12, 2012
I have an archer Nav in the left wingtip and use it with a 430w. The hid lights have no effect on them with my filters installed. Keep in mind that these ballast for these cheap HID lights are not all created equal or the same. I may have just gotten lucky with the ones I need up with. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=363547#363547 ________________________________________________________________________________
Subject: Falcon amp/volt gauge hookup
Date: Jan 12, 2012
Ive just gotten a combo Falcon amp/volt gauge. It has four connections on the back. Two connect to either side of the shunt. The third to ground. But the fourth is supposed to connect to the ignition switch. But I have an ACS rotary switch with multiple connections. The gauges are not reading though and I assume it's because this fourth connection is not right. Does anyone know how this last wire should be attached to the ignition switch? Bill Read this topic online here: http://forums.matronics.com/viewtopic.php?p=363548#363548 ________________________________________________________________________________
Subject: Re: Falcon amp/volt gauge hookup
Date: Jan 12, 2012
Bill, << Falcon amp/volt gauge. .. four connections .. But the fourth is supposed to connect to the ignition switch. .. how this last wire should be attached to the ignition switch? >> Believe it goes to the BAT terminal which is at about 11 o'clock viewed from the back on the ACS switch. You will need to crimp the proper sized ring terminal onto the wire. The BAT terminal is the source of power for the starter solenoid. Tom Kuffel ________________________________________________________________________________
Subject: Inexpensive Runway lighting
Date: Jan 13, 2012
This question is slightly off topic but is aircraft and electro related, albeit somewhat loosely. Years ago I read an article in an aviation magazine about how a small group put in runway lights using industrial porch light fittings from a home store and compact fluorescent lights, they were simple to install and had lower use and maintenance cost. My question is does anyone know if this has been done with the latest LEDs? I am based at an airport that is currently unlit and a small group of us are exploring this option and we dont want to re-invent the wheel so to speak. The fittings and mechanical is easy enough but was wondering about the types of LED/drivers, and power transmission. Runway is 2200 ft. Although the CFL option is viable I cant help but wonder if the power use and life expectancy of the LED wouldnt make them a better candidate for something like this. Ill listen to any ideas/advice on this and if anyone is interested in working with us email me off list. Forming the light configuration with proto boards is easy enough but curious about wiring for the long runs down the runway. For example, would it be better to run standard voltage and have a driver in each fitting, or have a driver in a central location that sends the required voltage to each light fitting. I would guess that it would be easier to send higher voltage down the length and set up each light with its own driver. Then again there is the cost to calculate. Im Just getting started on this idea so any advice would be welcome. Thanks, Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=363573#363573 ________________________________________________________________________________
Date: Jan 13, 2012
Subject: Re: Inexpensive Runway lighting
From: Etienne Phillips <etienne.phillips(at)gmail.com>
Hi Chris Have you considered retro-reflective lighting? Seems to be the cheapest and easiest maintenance-free option, as far as I've seen. No experience with it though (day/vfr pilot only), but I do see that Virgin uses is when they land in Nigeria! I've seen old vehicle number-plates folded in half in an inverted V shape and secured to the ground too... Thanks Etienne ________________________________________________________________________________
Date: Jan 13, 2012
Just another data point. I have a variety of solar lights along the "taxiway" from my parking area to my house. The original poster didn't say where they lived, but I have found that when it's cold the useful illumination time for most of the solar lights is < 3hrs. Also, if it is cloudy for more than 1/2 the day the illumination time is significantly reduced, even in the summer. I think a cost effective solar powered system could be built, but my experience with off the shelf items has been unsatisfactory. Obviously, testing the unit you are considering using is a must. Raymond Julian Kettle River, MN "And you know that I could have me a million more friends, and all I'd have to lose is my point of view." - John Prine On 01/13/2012 08:49 AM, n801bh(at)netzero.com wrote: > > In a situation like yours with a small unlit strip the easiest way is to > use individuel solar lights at each location.... No wires to run and > most of the new generation light fixtures are darn cheap to buy and work > good.... snipped DNA > Ben Haas > N801BH > www.haaspowerair.com > > ---------- Original Message ---------- > From: "checkn6" <checkn6(at)yahoo.com> > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Inexpensive Runway lighting > Date: Fri, 13 Jan 2012 06:11:41 -0800 > > > This question is slightly off topic but is aircraft and electro related, > albeit somewhat loosely. Years ago I read an article in an aviation > magazine about how a small group put in runway lights using industrial > porch light fittings from a home store and compact fluorescent lights, > they were simple to install and had lower use and maintenance cost. My > question is does anyone know if this has been done with the latest LEDs? > snip ________________________________________________________________________________
Date: Jan 13, 2012
At 08:37 AM 1/13/2012, you wrote: Hi Chris Have you considered retro-reflective lighting? Seems to be the cheapest and easiest maintenance-free option, as far as I've seen. No experience with it though (day/vfr pilot only), but I do see that Virgin uses is when they land in Nigeria! I've seen old vehicle number-plates folded in half in an inverted V shape and secured to the ground too.. Absolutely the lowest cost-of-ownership solution. The airport Dr. Dee and I used to own had "approved" runway lights . . . or at least approved when they were installed 20 years ago. They used a 10w sewing machine bulb and had a domed cylinder cover/lens which may have be optimized for concentrating light in the 'right' directions but I suspect not. Given the age of the installation, they were a real maintenance headache. One thing I discovered was that fixtures with missing globes were less likely to corrode . . . fresh rain water keeps them free of dust accumulation and taking the globe off allowed the guts of the fixture to dry out quickly. Leaving the globe on trapped moisture inside to rot away at the metal parts. Since we were a privately owned airport, the only risk for having 'non approved' fixtures was to risk loosing the notation in the AFM for "low intensity lighting". One night while driving down a section of highway under repair, the striping was temporarily replaced with low profile reflectors robust enough to withstand the effects of inattentive driving. Their performance when illuminated with headlights was pretty amazing. It was easy to imagine how these critters would look down the edges of a runway while in a flare maneuver. Here's one example of many: http://tinyurl.com/7seqaey http://tinyurl.com/85b2daj If I were building a runway out on the farm, I would certainly consider this technology as an alternative to powered lighting systems. Further, efficient reflectors of some larger size and shape could be used to create a poor-boy's VASI system. They can be placed at the bottom of a deep box with geometry that controls the angle of illumination/reflection of the colors. Combined with your own tested non-precision approach for setting up a track and speed past a gps fix off the approach end of the runway would get you set up to maximize performance of the reflectors. No bulbs to wear out, low cost replacement of damaged components, no electric bill, exceedingly weather resistant. Bob . . . ________________________________________________________________________________
Date: Jan 13, 2012
At 06:05 PM 1/12/2012, you wrote: > >Here is how I won the battle with noise from the cheap HID lights... > >http://www.vansairforce.com/community/showthread.php?t=67875&highlight=Hid This is a good example of why this and similar discussions need to be brought to this List. We've had many discussions over the years concerning the system integration risks for systems that perform as advertised at very attractive prices but without the support of studies showing suitability to task in airplanes. One good example is the popular LuxDrive product for LED lighting. Emacs! While it performed as advertised, it was a noise generator. I crafted a repackaged product that made it easier to mount, easier to wire, and added a filter for noise mitigation. It strikes me that this HID ballast package might well benefit from a similar repackaging effort. Bob . . . ________________________________________________________________________________
Date: Jan 13, 2012
But reflective-only lights are zero help when you're trying to just FIND the airport at night! That is no fun at all. David M. Robert L. Nuckolls, III wrote: > > > At 08:37 AM 1/13/2012, you wrote: > Hi Chris > > Have you considered retro-reflective lighting? Seems to be the > cheapest and easiest maintenance-free option, as far as I've seen. No > experience with it though (day/vfr pilot only), but I do see that > Virgin uses is when they land in Nigeria! > <<>> ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Jan 13, 2012
Where do we start? Dave Saylor AirCrafters 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell On Fri, Jan 13, 2012 at 9:07 AM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 06:05 PM 1/12/2012, you wrote: > > > Here is how I won the battle with noise from the cheap HID lights... > > http://www.vansairforce.com/community/showthread.php?t=67875&highlight=Hid > > > This is a good example of why this and similar discussions > need to be brought to this List. We've had many discussions > over the years concerning the system integration risks for > systems that perform as advertised at very attractive prices > but without the support of studies showing suitability to > task in airplanes. One good example is the popular LuxDrive > product for LED lighting. > [image: Emacs!] > > While it performed as advertised, it was a noise generator. I crafted > a repackaged product that made it easier to mount, easier to wire, > and added a filter for noise mitigation. > > It strikes me that this HID ballast package might well benefit > from a similar repackaging effort. > > > ** > > ** Bob . . . > ________________________________________________________________________________
From: "ROGER & JEAN CURTIS" <mrspudandcompany(at)verizon.net>
Date: Jan 13, 2012
Combined with your own tested non-precision approach for setting up a track and speed past a gps fix off the approach end of the runway would get you set up to maximize performance of the reflectors. No bulbs to wear out, low cost replacement of damaged components, no electric bill, exceedingly weather resistant. Bob . . . Just remember that in the northern climate, snow, ice, and frost can compromise these reflective devices more than an incandescent bulb, which generates some heat to melt the frozen surface. With any runway lighting system design, it is imperative that all probable weather conditions be taken into account. Roger ________________________________________________________________________________
Date: Jan 13, 2012
I am in the market for HID lights for my RV-9. I am finishing the wings and am about to pull the trigger on the purchase of the Duckworks install kit and a cheap HID kit. Something like this for the HID would be much appreciated. Mark Wesson _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Friday, January 13, 2012 12:08 PM Subject: Re: AeroElectric-List: Re: HID light noise At 06:05 PM 1/12/2012, you wrote: Here is how I won the battle with noise from the cheap HID lights... http://www.vansairforce.com/community/showthread.php?t=67875 <http://www.vansairforce.com/community/showthread.php?t=67875&highlight=Hid> &highlight=Hid This is a good example of why this and similar discussions need to be brought to this List. We've had many discussions over the years concerning the system integration risks for systems that perform as advertised at very attractive prices but without the support of studies showing suitability to task in airplanes. One good example is the popular LuxDrive product for LED lighting. Emacs! While it performed as advertised, it was a noise generator. I crafted a repackaged product that made it easier to mount, easier to wire, and added a filter for noise mitigation. It strikes me that this HID ballast package might well benefit from a similar repackaging effort. Bob . . . ________________________________________________________________________________
Date: Jan 13, 2012
If Bob is going to offer some "tutoring & mentoring", I want to play on this project! (However, logistically participation could be problematic since I'm in Southern California - perhaps an excuse to fly to Watsonville more often.) -Jeff Luckey _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Dave Saylor Sent: Friday, January 13, 2012 09:52 Subject: Re: AeroElectric-List: Re: HID light noise Where do we start? Dave Saylor AirCrafters 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell On Fri, Jan 13, 2012 at 9:07 AM, Robert L. Nuckolls, III wrote: At 06:05 PM 1/12/2012, you wrote: Here is how I won the battle with noise from the cheap HID lights... http://www.vansairforce.com/community/showthread.php?t=67875 <http://www.vansairforce.com/community/showthread.php?t=67875&highlight=Hid> &highlight=Hid This is a good example of why this and similar discussions need to be brought to this List. We've had many discussions over the years concerning the system integration risks for systems that perform as advertised at very attractive prices but without the support of studies showing suitability to task in airplanes. One good example is the popular LuxDrive product for LED lighting. Emacs! While it performed as advertised, it was a noise generator. I crafted a repackaged product that made it easier to mount, easier to wire, and added a filter for noise mitigation. It strikes me that this HID ballast package might well benefit from a similar repackaging effort. Bob . . . ________________________________________________________________________________
Date: Jan 13, 2012
And if GPS is out or a 4G cell tower is nearby??? David M. ROGER & JEAN CURTIS wrote: > > Combined with your own tested non-precision approach for > setting up a track and speed past a gps fix off the approach > end of the runway would get you set up to maximize performance > of the reflectors. No bulbs to wear out, low cost replacement > of damaged components, no electric bill, exceedingly weather > resistant. > > > Bob . . . > > Just remember that in the northern climate, snow, ice, and > frost can compromise these reflective devices more than an incandescent > bulb, which generates some heat to melt the frozen surface. With any runway > lighting system design, it is imperative that all probable weather > conditions be taken into account. > > Roger > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Jan 13, 2012
Subject: NO POLITICS Was: I signed a petition against aviation
user fees and got this response How about we stop posting political junk on these lists. RF ________________________________________________________________________________
Date: Jan 13, 2012
Subject: Re: NO POLITICS Was: I signed a petition against aviation
user fees and got this response Amen! We've been through this absurd cycle before. Let's not start again. John Grosse Ralph Finch wrote: > How about we stop posting political junk on these lists. > RF > > * > > > * ________________________________________________________________________________
Date: Jan 13, 2012
aviation user fees and got this response This particular text is important to the entire aviation community and is relevant to our usage here. It is money out of our pockets, directly. David M. John Grosse wrote: > > > Amen! We've been through this absurd cycle before. Let's not start again. > John Grosse > > Ralph Finch wrote: >> How about we stop posting political junk on these lists. >> RF >> >> * >> >> >> * > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Jan 13, 2012
Agreed, Didn't Uncle Bob create a new forum for this sort of commentary last summer?? I'm all for political discourse, let's just do it in the appropriate place. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of John Grosse Sent: Friday, January 13, 2012 12:49 Subject: Re: AeroElectric-List: NO POLITICS Was: I signed a petition against aviation user fees and got this response Amen! We've been through this absurd cycle before. Let's not start again. John Grosse Ralph Finch wrote: > How about we stop posting political junk on these lists. > RF > > * > > > * ________________________________________________________________________________
Date: Jan 13, 2012
And I certainly don't think it has anything to do with any 'aviation community' outside of the US John ----- Original Message ----- From: "DavidM" <ainut(at)knology.net> Sent: Friday, January 13, 2012 9:07 PM Subject: Re: AeroElectric-List: NO POLITICS Was: I signed a petition against aviation user fees and got this response > > This particular text is important to the entire aviation community and is > relevant to our usage here. It is money out of our pockets, directly. > > David M. > > > John Grosse wrote: >> >> >> Amen! We've been through this absurd cycle before. Let's not start again. >> John Grosse >> >> Ralph Finch wrote: >>> How about we stop posting political junk on these lists. >>> RF >>> >>> * >>> >>> >>> * >> >> >> >> >> >> >> ----- >> No virus found in this message. >> Checked by AVG - www.avg.com >> >> > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > > ________________________________________________________________________________
Date: Jan 13, 2012
aviation user fees and got this response Is this really the ONLY place you guys have to complain? Let's just please stick to the purpose of this list. None of us joined because we thought this was a political chat line. John Grosse ________________________________________________________________________________
Date: Jan 14, 2012
Thank you Bob and Paul for taking the time to point this out and correct my understanding. The documentation that I have is incomplete and I believed it without thinking it through. It may not have any external magnetic sensor but I agree that it must at least have an unmentioned internal sensor. Ken On 12/01/2012 8:10 PM, Bob Meyers wrote: > --> AeroElectric-List message posted by: Bob > Meyers > > No, you're missing the heading. Your lookup table is just giving you > the magnetic adjustment to a 'true' track. Most GPS's do just that > when you tell them you want a magnetic track. > > You said your aircraft has no access to magnetic information. Without > that it can't tell your plane is pointing in a direction other than > the ground track - magnetic or not. Your heading will only match your > track in no wind conditions. > > You still need something to tell you which way the plane is pointing, > not tracking. However if the EFIS has access to magnetic heading > data, then you can calculate wind speed and direction in the EFIS. > > Bob Meyers > > Flying my Sonex N982SX - Building log at http://n982sx.com > > Sent from my iPad > > On Jan 12, 2012, at 6:36 PM, "Ken Lehman" > wrote: > >> --> AeroElectric-List message posted by: "Ken >> Lehman" >> >> Hello Paul >> >> The GPS gives groundspeed, track, and position. You can go into a >> lookup table to find the magnetic variation at your position. If >> you know the TAS because you have pitot static info and >> temperature, you should be able to solve for the wind vector I >> believe. Same as can be done with an E6B computer. I think it goes >> heading vector plus wind vector equals track vector. So if you know >> any two vectors you can compute the third vector. >> >> Mostly I was just pointing out that many glass PFD/ADI systems >> already have all the sensor info they need to display a magnetic >> heading if the designer wishes to display it. I often fly an >> aircraft that does just that. It has no magnetic sensors but it >> computes and displays magnetic heading. >> >> Of course variation does change slightly over a multi year period >> so minor changes in the lookup table might be appropriate every few >> years if high accuracy is desired. >> >> Ken >> >>> --> AeroElectric-List message posted by: Paul >>> Millner S> >>> >>> On 1/4/2012 7:55 AM, Ken Lehman wrote: >>>> Some rnav units that have airspeed inputs calculate drift and >>>> simply use a lookup table to convert track to magnetic dg >>>> info. >>> How would that work, Ken? Seems like knowing only airspeed and >>> groundspeed, you don't know if the headwind/tailwind component >>> is directly ahead/behind you or off a wingtip... so how does >>> airspeed and groundspeed and track allow you to calculate >>> heading? >>> >>> Paul >>> ________________________________________________________________________________
Date: Jan 14, 2012
FWIW, I recently confirmed that accurate calibration of the mag sensor has a significant impact on wind calculations. After carefully running the calibration routine on my GRT EFIS, the displayed wind direction and speeds are now spot on. Bill Sent from my iPad On Jan 14, 2012, at 10:10 AM, Ken wrote: > > Thank you Bob and Paul for taking the time to point this out > and correct my understanding. > > The documentation that I have is incomplete and I believed it without thinking it through. It may not have any external magnetic sensor but I agree that it must at least have an unmentioned internal sensor. > > Ken > > On 12/01/2012 8:10 PM, Bob Meyers wrote: >> --> AeroElectric-List message posted by: Bob >> Meyers >> >> No, you're missing the heading. Your lookup table is just giving you >> the magnetic adjustment to a 'true' track. Most GPS's do just that >> when you tell them you want a magnetic track. >> >> You said your aircraft has no access to magnetic information. Without >> that it can't tell your plane is pointing in a direction other than >> the ground track - magnetic or not. Your heading will only match your >> track in no wind conditions. >> >> You still need something to tell you which way the plane is pointing, >> not tracking. However if the EFIS has access to magnetic heading >> data, then you can calculate wind speed and direction in the EFIS. >> >> Bob Meyers >> >> Flying my Sonex N982SX - Building log at http://n982sx.com >> >> Sent from my iPad >> >> On Jan 12, 2012, at 6:36 PM, "Ken Lehman" >> wrote: >> >>> --> AeroElectric-List message posted by: "Ken >>> Lehman" >>> >>> Hello Paul >>> >>> The GPS gives groundspeed, track, and position. You can go into a >>> lookup table to find the magnetic variation at your position. If >>> you know the TAS because you have pitot static info and >>> temperature, you should be able to solve for the wind vector I >>> believe. Same as can be done with an E6B computer. I think it goes >>> heading vector plus wind vector equals track vector. So if you know >>> any two vectors you can compute the third vector. >>> >>> Mostly I was just pointing out that many glass PFD/ADI systems >>> already have all the sensor info they need to display a magnetic >>> heading if the designer wishes to display it. I often fly an >>> aircraft that does just that. It has no magnetic sensors but it >>> computes and displays magnetic heading. >>> >>> Of course variation does change slightly over a multi year period >>> so minor changes in the lookup table might be appropriate every few >>> years if high accuracy is desired. >>> >>> Ken >>> >>>> --> AeroElectric-List message posted by: Paul >>>> Millner S> >>>> >>>> On 1/4/2012 7:55 AM, Ken Lehman wrote: >>>>> Some rnav units that have airspeed inputs calculate drift and >>>>> simply use a lookup table to convert track to magnetic dg >>>>> info. >>>> How would that work, Ken? Seems like knowing only airspeed and >>>> groundspeed, you don't know if the headwind/tailwind component >>>> is directly ahead/behind you or off a wingtip... so how does >>>> airspeed and groundspeed and track allow you to calculate >>>> heading? >>>> >>>> Paul >>>> > > > > ________________________________________________________________________________
Subject: Electrical Gremlins
Date: Jan 14, 2012
1.) I installed an EyeBeam Mini as a cabin light. It's in a housing that also contains the radio speaker. It gets its power from the battery bus. Whenever I turn on the PS Engineering 7000B audio panel, or key the mike, the EBM starts flashing and is unresponsive to its on/off switch or built-in dimmer. The only way to get it to stop is to pull the power. The dimming/switching are by capacitance sensing (touch). Everything in the airplane is connected to a single point ground. Suggestions much appreciated :D 2.) I installed an AEC 9005 LVW module per instructions but the LVW lamp flashes (blinking LED) when I power the system from my bench 13.6v power supply. 3.) Same as 2 above for my B&C LR3 regulator. I did all of their troubleshooting diagnostics and everything was to spec. Thanks for any help, John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=363739#363739 ________________________________________________________________________________
Date: Jan 14, 2012
Hi Ken, Yes, you probably have an internal compass. I assume you don't have an inertial navigation system with ring laser gyros!!! Not too many of those in the OBAM market. The accelerometers and gyro pkgs in our EFIS units are pretty good though. Bob Meyers Flying my Sonex N982SX - Building log at http://n982sx.com Sent from my iPad On Jan 14, 2012, at 9:10 AM, Ken wrote: > > Thank you Bob and Paul for taking the time to point this out > and correct my understanding. > > The documentation that I have is incomplete and I believed it without thinking it through. It may not have any external magnetic sensor but I agree that it must at least have an unmentioned internal sensor. > > Ken > > On 12/01/2012 8:10 PM, Bob Meyers wrote: >> --> AeroElectric-List message posted by: Bob >> Meyers >> >> No, you're missing the heading. Your lookup table is just giving you >> the magnetic adjustment to a 'true' track. Most GPS's do just that >> when you tell them you want a magnetic track. >> >> You said your aircraft has no access to magnetic information. Without >> that it can't tell your plane is pointing in a direction other than >> the ground track - magnetic or not. Your heading will only match your >> track in no wind conditions. >> >> You still need something to tell you which way the plane is pointing, >> not tracking. However if the EFIS has access to magnetic heading >> data, then you can calculate wind speed and direction in the EFIS. >> >> Bob Meyers >> >> Flying my Sonex N982SX - Building log at http://n982sx.com >> >> Sent from my iPad >> >> On Jan 12, 2012, at 6:36 PM, "Ken Lehman" >> wrote: >> >>> --> AeroElectric-List message posted by: "Ken >>> Lehman" >>> >>> Hello Paul >>> >>> The GPS gives groundspeed, track, and position. You can go into a >>> lookup table to find the magnetic variation at your position. If >>> you know the TAS because you have pitot static info and >>> temperature, you should be able to solve for the wind vector I >>> believe. Same as can be done with an E6B computer. I think it goes >>> heading vector plus wind vector equals track vector. So if you know >>> any two vectors you can compute the third vector. >>> >>> Mostly I was just pointing out that many glass PFD/ADI systems >>> already have all the sensor info they need to display a magnetic >>> heading if the designer wishes to display it. I often fly an >>> aircraft that does just that. It has no magnetic sensors but it >>> computes and displays magnetic heading. >>> >>> Of course variation does change slightly over a multi year period >>> so minor changes in the lookup table might be appropriate every few >>> years if high accuracy is desired. >>> >>> Ken >>> >>>> --> AeroElectric-List message posted by: Paul >>>> Millner S> >>>> >>>> On 1/4/2012 7:55 AM, Ken Lehman wrote: >>>>> Some rnav units that have airspeed inputs calculate drift and >>>>> simply use a lookup table to convert track to magnetic dg >>>>> info. >>>> How would that work, Ken? Seems like knowing only airspeed and >>>> groundspeed, you don't know if the headwind/tailwind component >>>> is directly ahead/behind you or off a wingtip... so how does >>>> airspeed and groundspeed and track allow you to calculate >>>> heading? >>>> >>>> Paul >>>> > > > > > ________________________________________________________________________________
Date: Jan 14, 2012
EyeBeam Mini URL: http://aveogroup.com/aveoshop/product.php?id_product=40 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=363764#363764 ________________________________________________________________________________
Date: Jan 14, 2012
Guys, thanks for the input. Given that the battery was too low today to crank the motor, I guess the voltage was indeed low at the end of the last flight. I have listed below the checks I made and corrections before flying today. (it was -5.5C this morning here in the UK) My aircraft has a cable operated master switch that serves to break the negative lead from the battery. It has a 30Amp B&C Alternator, that feeds 3 phase to the regulator rectifier: Flew today and made a few tests and observations. I haven't as yet checked the battery. When I arrived I checked all the terminals and connections related to the alternator. Tightened the screws that secure the DC + and - through the large capacitor. They weren't hanging off, but not as tight as should have been. There was a very loose connection from 1 of the output phases into the fuse box. I checked and tightened up all of the terminals of the 3 phase output each side of their fuses. Battery terminals both secure. Earth lead battery to negative master switch secure. Main earth lead from forest of earth on firewall to engine mount secure and clean. Checked the negative master switch (cable operated) to ensure it was functioning correctly, all appeared good, with no high resistance when closed. No continuity through the master switch when open. Hand to hand start the engine as the battery was a bit low, I expect it hasn't been charging on the return leg of it's last journey due to the loose connection from the alternator. Flew for total of 1:20 without any electrical issues, turning lights on etc did not cause any noise. When landed and parked up, I pulled the master switch while the engine was running. Got a severe noise blast through the headsets via the intercom. This got worse if I turned for example the nav lights on. If I switched the alternator off by it's switch then all went quiet. Battery voltage after flight was 13.7 volts. I measured the voltage between battery + and the - after the master switch and that too was 13.7v, so doesn't seem to be a master switch problem. I am guessing that when I disconnect the master switch, i.e. the primary earth return, then there still exists an earth return through the panel, cable outers etc. However, even if they make their way back to the engine, the negative master switch should prevent it getting back to the battery? So, the current from the alternator is somehow providing electrical power + and - even with the master switch off? When I got the aircraft all of the earths ran everywhere, lots through the panel, mostly low current stuff like fuel gauges etc. There are still some of these remaining, although 90% + do run to the forest of earth inside the firewall. With the engine off and the master switch turned off, there is no current flow. Maybe I don't have anything to worry about? Your thoughts appreciated Gavin Read this topic online here: http://forums.matronics.com/viewtopic.php?p=363769#363769 ________________________________________________________________________________
Date: Jan 14, 2012
Subject: Wire Bundle Wrapping Tape?
Wire bundles in my Cessna are in some places spiral wrapped in a white translucent tape. The tape is not the plastic spiral wrap that is commonly available for wire harnesses; nor is it regular electrical tape. The thickness and "stickiness" is somewhere in between - the tape sticks to itself enough that the wrap holds, but it can be readily unwrapped. It's roughly 1" wide. I estimate the thickness at somewhere between 5 and 10 mils. What is this, and where can I purchase some? Thanks, Jon McLin ________________________________________________________________________________
Date: Jan 15, 2012
Subject: Re: Wire Bundle Wrapping Tape?
Jon, Sounds like Silicone tape. (aka rescue tape) Aircraft Spruce carries it. Good luck! Hal Benjamin - RV-4 Long Island, NY Starting engine soon - Should be flying this year! ----- Original Message ----- From: Jon McLin Date: Saturday, January 14, 2012 8:53 pm Subject: AeroElectric-List: Wire Bundle Wrapping Tape? > > Wire bundles in my Cessna are in some places spiral wrapped in a > white translucent tape. The tape is not the plastic spiral wrap > that is commonly available for wire harnesses; nor is it regular > electrical tape. The thickness and "stickiness" is somewhere in > between - the tape sticks to itself enough that the wrap holds, > but it can be readily unwrapped. It's roughly 1" wide. I > estimate the thickness at somewhere between 5 and 10 mils. > > What is this, and where can I purchase some? > > Thanks, > Jon McLin > > > > > > ________________________________________________________________________________
Date: Jan 15, 2012
> Sounds like Silicone tape. (aka rescue tape) Aircraft Spruce carries it. Good luck! > Thanks, but no, it's not silicone tape. That stuff fuses together permanently. This stuff is easily unwrapped. I found some earlier notes I made - the Cessna stuff is apparently 12 mils thick. Where it was used in the cabin it (installed perhaps 34 years ago) it remains flexible, and could probably be reused. Under the cowl it was pretty hard, and cracked when I unwrapped it. Online I find "dry vinyl" tape for wire harnesses, which apparently sticks to itself but can be easily unwrapped. That's the desired behavior. The dry vinyl tape that I can find is only available in opaque black or yellow, and is much thinner (4 mils). ________________________________________________________________________________
Date: Jan 15, 2012
Sure doesn't sound like it would pass legal inspection. Adhesive tapes are not supposed to be used at all. Not for connecting wires or binding them together in bundles. For that there is coraseal nylon ties and wax cord. Noel From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of halbenjamin(at)optonline.net Sent: January 15, 2012 2:02 AM Subject: Re: AeroElectric-List: Wire Bundle Wrapping Tape? Jon, Sounds like Silicone tape. (aka rescue tape) Aircraft Spruce carries it. Good luck! Hal Benjamin - RV-4 Long Island, NY Starting engine soon - Should be flying this year! ----- Original Message ----- From: Jon McLin Date: Saturday, January 14, 2012 8:53 pm Subject: AeroElectric-List: Wire Bundle Wrapping Tape? > > Wire bundles in my Cessna are in some places spiral wrapped in a > white translucent tape. The tape is not the plastic spiral wrap > that is commonly available for wire harnesses; nor is it regular > electrical tape. The thickness and "stickiness" is somewhere in > between - the tape sticks to itself enough that the wrap holds, > but it can be readily unwrapped. It's roughly 1" wide. I > estimate the thickness at somewhere between 5 and 10 mils. > > What is this, and where can I purchase some? > > Thanks, > Jon McLin > > > > > > ________________________________________________________________________________
Date: Jan 15, 2012
i don't talk to many pilots that use the wax cord but i do and it is worth a look. as i understand it is still used in military planes. it has a tensile strength of 80 lbs compared to a wire tie at 18 lbs. a spool will last a lifetime and several wraps will secure about anything. its cross section is about the same as flat rib lacing. bob noffs On Sun, Jan 15, 2012 at 1:38 PM, Noel Loveys wrote: > Sure doesn=92t sound like it would pass legal inspection. Adhesive tape s > are not supposed to be used at all. Not for connecting wires or binding > them together in bundles. For that there is coraseal nylon ties and wax > cord.**** > > ** ** > > Noel**** > > ** ** > > *From:* owner-aeroelectric-list-server(at)matronics.com [mailto: > owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of * > halbenjamin(at)optonline.net > *Sent:* January 15, 2012 2:02 AM > *To:* aeroelectric-list(at)matronics.com > *Subject:* Re: AeroElectric-List: Wire Bundle Wrapping Tape?**** > > ** ** > > Jon,**** > > Sounds like Silicone tape. (aka rescue tape) Aircraft Spruce carries it. > Good luck!**** > > **** > > Hal Benjamin - RV-4**** > > Long Island, NY**** > > Starting engine soon - Should be flying this year! > > ----- Original Message ----- > From: Jon McLin > Date: Saturday, January 14, 2012 8:53 pm > Subject: AeroElectric-List: Wire Bundle Wrapping Tape? > To: aeroelectric-list(at)matronics.com > > > > > Wire bundles in my Cessna are in some places spiral wrapped in a > > white translucent tape. The tape is not the plastic spiral wrap > > that is commonly available for wire harnesses; nor is it regular > > electrical tape. The thickness and "stickiness" is somewhere in > > between - the tape sticks to itself enough that the wrap holds, > > but it can be readily unwrapped. It's roughly 1" wide. I > > estimate the thickness at somewhere between 5 and 10 mils. > > > > What is this, and where can I purchase some? > > > > Thanks, > > Jon McLin > > > > > > http://www.matronics.com/Navigator?AeroElectric-List > > http://www.matronics.com/contribution > > ========== > > > > > > > > **** > > * > =========== =========== =========== =========== > * > > ________________________________________________________________________________
Date: Jan 15, 2012
I use the wax cord as well. There is something nostalgic and relaxing about lacing up a section of wiring. I use tie wraps, loosely positioned to hold them in position until the loom is ready. Mike > i don't talk to many pilots that use the wax cord but i do and it is > worth a look. as i understand it is still used in military planes. it > has a tensile strength of 80 lbs compared to a wire tie at 18 lbs. a > spool will last a lifetime and several wraps will secure about > anything. its cross section is about the same as flat rib lacing. > bob noffs ________________________________________________________________________________
Subject: Re: Noise in damp weather
Date: Jan 15, 2012
Gavin, It seems that you have found the problem with the loose alternator connection. The AC ripple voltage is much larger when one of the alternator wires is not connected. It has been my experience that a threaded fastener that is 1/4 turn loose can cause problems. It is not a good idea to run the engine and alternator with the battery disconnected. The battery helps to stabilize the alternator output. You asked, > "Maybe I don't have anything to worry about?" Not if everything is working to your satisfaction. The vast majority of electrical problems are due to bad connections. Good job fixing it. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=363890#363890 ________________________________________________________________________________
Date: Jan 15, 2012
Hi Jon Is it perhaps Teflon Tape? See Aircraft Spruce and Ssearch Teflon Tape, it is adhesive backed. You can also have a look at www.mcmaster.com. Ron Parigoris > > >> Sounds like Silicone tape. (aka rescue tape) Aircraft Spruce carries it. >> Good luck! >> > Thanks, but no, it's not silicone tape. That stuff fuses together > permanently. This stuff is easily unwrapped. > > I found some earlier notes I made - the Cessna stuff is apparently 12 mils > thick. Where it was used in the cabin it (installed perhaps 34 years ago) > it remains flexible, and could probably be reused. Under the cowl it was > pretty hard, and cracked when I unwrapped it. > > Online I find "dry vinyl" tape for wire harnesses, which apparently sticks > to itself but can be easily unwrapped. That's the desired behavior. The > dry vinyl tape that I can find is only available in opaque black or > yellow, and is much thinner (4 mils). > > > > > ________________________________________________________________________________
Date: Jan 15, 2012
At 07:37 PM 1/14/2012, you wrote: > >Wire bundles in my Cessna are in some places spiral wrapped in a >white translucent tape. The tape is not the plastic spiral wrap >that is commonly available for wire harnesses; nor is it regular >electrical tape. The thickness and "stickiness" is somewhere in >between - the tape sticks to itself enough that the wrap holds, but >it can be readily unwrapped. It's roughly 1" wide. I estimate the >thickness at somewhere between 5 and 10 mils. At Boeing in 1961 we called that stuff "Irvolite". I'm sure this was a trade name. I've also heard it referred to as "Sirco". Also a trade name. Given that we were using this stuff on the B-52, it's a certainty that it has a generic name further identified by a mil-spec. The stuff came in both flat wrap (tape) and sleeve (tubing) forms and the material of choice for adding extra insulation and/or scuff protection. The stuff was mildly self-bonding to itself but we always secured the end of the wrap with a string-tie. It's not as chemically and thermally robust as the soft silicone tape in common use today, at the same time it's mechanical robustness is superior to silicone. I've not seen a 'fresh' roll of it in a very long time. I've not observed its use on any airplane at Beech in many years. Its pedigree is from the Polyurethane/Vinyl era . . . not something we would see on a modern TC aircraft. Bob . . . ________________________________________________________________________________
Date: Jan 15, 2012
Velcro works great as a temporary wrap; just peel it open to add wire. (Don't tell anyone, but it can work fine as a permanent wrap, too.) Charlie On 01/15/2012 03:03 PM, Mike Nellis wrote: > > I use the wax cord as well. There is something nostalgic and relaxing > about lacing up a section of wiring. I use tie wraps, loosely > positioned to hold them in position until the loom is ready. > > Mike > >> i don't talk to many pilots that use the wax cord but i do and it is >> worth a look. as i understand it is still used in military planes. it >> has a tensile strength of 80 lbs compared to a wire tie at 18 lbs. a >> spool will last a lifetime and several wraps will secure about >> anything. its cross section is about the same as flat rib lacing. >> bob noffs > ________________________________________________________________________________
Date: Jan 16, 2012
My preference is the wax cord but as with a lot of things it does take some practice to get to install it properly. It has other pluses over the nylon tie wraps You will never slice a hand open while rooting around in an engine bay that has coraseal and wax cord used. I am one of the ones who has received my fair share of slices on tie wraps. One easy way to tell if it will pass inspection is to check and see if tape of any kind is listed in the Maintenance Manual.. If it's not there and you use it without an STC you may find your plane grounded and according to Mr. Murphy it will only happen at the worst possible time. I've seen large aircraft grounded for a $0.11 item. Noel From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of bob noffs Sent: January 15, 2012 4:38 PM Subject: Re: AeroElectric-List: Wire Bundle Wrapping Tape? i don't talk to many pilots that use the wax cord but i do and it is worth a look. as i understand it is still used in military planes. it has a tensile strength of 80 lbs compared to a wire tie at 18 lbs. a spool will last a lifetime and several wraps will secure about anything. its cross section is about the same as flat rib lacing. bob noffs On Sun, Jan 15, 2012 at 1:38 PM, Noel Loveys wrote: Sure doesn't sound like it would pass legal inspection. Adhesive tapes are not supposed to be used at all. Not for connecting wires or binding them together in bundles. For that there is coraseal nylon ties and wax cord. Noel From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of halbenjamin(at)optonline.net Sent: January 15, 2012 2:02 AM Subject: Re: AeroElectric-List: Wire Bundle Wrapping Tape? Jon, Sounds like Silicone tape. (aka rescue tape) Aircraft Spruce carries it. Good luck! Hal Benjamin - RV-4 Long Island, NY Starting engine soon - Should be flying this year! ----- Original Message ----- From: Jon McLin Date: Saturday, January 14, 2012 8:53 pm Subject: AeroElectric-List: Wire Bundle Wrapping Tape? > > Wire bundles in my Cessna are in some places spiral wrapped in a > white translucent tape. The tape is not the plastic spiral wrap > that is commonly available for wire harnesses; nor is it regular > electrical tape. The thickness and "stickiness" is somewhere in > between - the tape sticks to itself enough that the wrap holds, > but it can be readily unwrapped. It's roughly 1" wide. I > estimate the thickness at somewhere between 5 and 10 mils. > > What is this, and where can I purchase some? > > Thanks, > Jon McLin > > > http://www.matronics.com/Navigator?AeroElectric-List > http://www.matronics.com/contribution > ========== > > > > ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List ttp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jan 16, 2012
Another thing about the use of tape is it will hold heat in a bundle so if it is used not only may it dry out and fall off but it will also change the wire spec for current carried on any particular wire in a bundle. Noel -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Mike Nellis Sent: January 15, 2012 5:34 PM Subject: Re: AeroElectric-List: Wire Bundle Wrapping Tape? I use the wax cord as well. There is something nostalgic and relaxing about lacing up a section of wiring. I use tie wraps, loosely positioned to hold them in position until the loom is ready. Mike > i don't talk to many pilots that use the wax cord but i do and it is > worth a look. as i understand it is still used in military planes. it > has a tensile strength of 80 lbs compared to a wire tie at 18 lbs. a > spool will last a lifetime and several wraps will secure about > anything. its cross section is about the same as flat rib lacing. > bob noffs ________________________________________________________________________________
Date: Jan 15, 2012
At 09:39 PM 1/15/2012, you wrote: >My preference is the wax cord but as with a lot of things it does >take some practice to get to install it properly. It has other >pluses over the nylon tie wraps You will never slice a hand open >while rooting around in an engine bay that has coraseal and wax cord >used. I am one of the ones who has received my fair share of slices >on tie wraps. > Here's a link to a tread on the topic a few years ago: http://tinyurl.com/7a89njo The "waxed cord" commonly found in military and domestic production aircraft is probably Mil-T-43435 as described below in the Aircraft Spruce Catalog Emacs! . . . and the Braden Emacs! Bob . . . ________________________________________________________________________________
Date: Jan 15, 2012
At 11:42 AM 1/13/2012, you wrote: > >But reflective-only lights are zero help when you're trying to just >FIND the airport at night! That is no fun at all. There's where your GPS comes in. While I was still flying a lot off of 1K1, I crafted a GPS aided approach that always put me 1/2 mile off the approach end of the runway on an aligned heading. Had the runway lights been out or non- existent, reflectors would have sufficed to complete the approach and landing. Bob . . . ________________________________________________________________________________
Date: Jan 16, 2012
Subject: Re: HID light noise
At 11:51 AM 1/13/2012, you wrote: >Where do we start? Are we all talking about the same kit? Where do I put my hands on one of them? I just ordered a plug-n-play HID conversion for my minivan off of Ebay. http://tinyurl.com/6q7pueo I'll evaluate this kit for noise before I put it on the car. Bob . . . ________________________________________________________________________________
Date: Jan 16, 2012
Subject: Re: Electrical Gremlins
> >2.) I installed an AEC 9005 LVW module per instructions but the LVW >lamp flashes (blinking LED) when I power the system from my bench >13.6v power supply. > >3.) Same as 2 above for my B&C LR3 regulator. I did all of their >troubleshooting diagnostics and everything was to spec. Do the lights go out when the alternator comes on line? Why two separate LV warning systems? Bob . . . ________________________________________________________________________________
Date: Jan 16, 2012
At 01:38 PM 1/13/2012, you wrote: > >And if GPS is out or a 4G cell tower is nearby??? Not sure what 4G has to do with it . . . are these known GPS antagonists? I've never experienced a GPS outage but it's been a few years. If your needing really robust lighting on the subject field, perhaps reflectors are not for you. I'm my experience here in flyover country, they would have sufficed for every night-time arrival I've ever made to my home field. One could craft some LED, solar powered REIL fixtures too. This would get you oriented with the most rudimentary of navigation devices. It doesn't take much light to be seen from 5 miles away. Hence, not much energy needs to be stored to keep a few LEDs flashing. Bob . . . ________________________________________________________________________________
Date: Jan 16, 2012
I think he's talking about the pending LightSquared issues -- they purchased bandwidth that was reserved for satellite communication some time ago, but the plans for using that spectrum was scrapped as impractical (by LightSquared), so then they began pursuing using the band as land-based 4G network spectrum. That's all well and good, except that the band is adjacent to the GPS band, and its power due to proximity tends to overwhelm the input circuitry of GPS receivers, because they were never designed to be selective enough to filter out such a thing. My personal feeling is that this will never actually see the light of day, regardless of all the lobbying LS can muster. As a suggestion to your failure analysis, I think it would be a bad idea to rely on home-grown runway lighting in a critical way -- which means diverting to a lighted muni airport would always need to be an option anyway. Thoughts? On Jan 16, 2012, at 12:21 AM, Robert L. Nuckolls, III wrote: > > At 01:38 PM 1/13/2012, you wrote: >> >> And if GPS is out or a 4G cell tower is nearby??? > > Not sure what 4G has to do with it . . . are these > known GPS antagonists? I've never experienced a GPS > outage but it's been a few years. If your needing > really robust lighting on the subject field, perhaps > reflectors are not for you. I'm my experience here in > flyover country, they would have sufficed for every > night-time arrival I've ever made to my home field. > > One could craft some LED, solar powered REIL fixtures > too. This would get you oriented with the most rudimentary > of navigation devices. It doesn't take much light to be > seen from 5 miles away. Hence, not much energy needs to > be stored to keep a few LEDs flashing. > > > Bob . . . > > > > ________________________________________________________________________________
Date: Jan 16, 2012
yes, LightSquared. Multiple tests prove that their 4G cell systems do in fact render GPS unusable. One would think the FCC would stop them out of hand but LS gave the obamanation several million dollars so now he is also behind their financial success, which does not bode well for us GPS users. Even the heavies (airliners) have trouble and they are supposed to be "interference hardened." This is politics but it GREATLY interferes with my safety. David M. Daniel Hooper wrote: > --> AeroElectric-List message posted by: Daniel Hooper > > I think he's talking about the pending LightSquared issues -- they purchased bandwidth that was reserved for satellite communication some time ago, but the plans for using that spectrum was scrapped as impractical (by LightSquared), so then they began pursuing using the band as land-based 4G network spectrum. > That's all well and good, except that the band is adjacent to the GPS band, and its power due to proximity tends to overwhelm the input circuitry of GPS receivers, because they were never designed to be selective enough to filter out such a thing. > > My personal feeling is that this will never actually see the light of day, regardless of all the lobbying LS can muster. > > As a suggestion to your failure analysis, I think it would be a bad idea to rely on home-grown runway lighting in a critical way -- which means diverting to a lighted muni airport would always need to be an option anyway. > > Thoughts? > > > On Jan 16, 2012, at 12:21 AM, Robert L. Nuckolls, III wrote: > >> --> AeroElectric-List message posted by: "Robert L. Nuckolls, III" >> >> At 01:38 PM 1/13/2012, you wrote: >>> --> AeroElectric-List message posted by: DavidM >>> >>> And if GPS is out or a 4G cell tower is nearby??? >> Not sure what 4G has to do with it . . . are these >> known GPS antagonists? I've never experienced a GPS >> outage but it's been a few years. If your needing >> really robust lighting on the subject field, perhaps >> reflectors are not for you. I'm my experience here in >> flyover country, they would have sufficed for every >> night-time arrival I've ever made to my home field. >> >> One could craft some LED, solar powered REIL fixtures >> too. This would get you oriented with the most rudimentary >> of navigation devices. It doesn't take much light to be >> seen from 5 miles away. Hence, not much energy needs to >> be stored to keep a few LEDs flashing. >> >> >> Bob . . . >> >> >> >> > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Jan 16, 2012
I've experienced a GPS outage once, but fortunately I was only on a motorcycle at the time. David Robert L. Nuckolls, III wrote: > > > At 01:38 PM 1/13/2012, you wrote: >> >> And if GPS is out or a 4G cell tower is nearby??? > > Not sure what 4G has to do with it . . . are these > known GPS antagonists? I've never experienced a GPS > outage but it's been a few years. If your needing > really robust lighting on the subject field, perhaps > reflectors are not for you. I'm my experience here in > flyover country, they would have sufficed for every > night-time arrival I've ever made to my home field. > > One could craft some LED, solar powered REIL fixtures > too. This would get you oriented with the most rudimentary > of navigation devices. It doesn't take much light to be > seen from 5 miles away. Hence, not much energy needs to > be stored to keep a few LEDs flashing. > > > Bob . . . > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Jan 16, 2012
Gentlemen, thank you for all of your input and ideas. Our little group of intrepid night flyers is now leaning towards the solar lights with the addition of reflective tape on flexible poles. The field is seldom used and although someone in trouble may look down and see a few twinkly lights and find salvation it is not the intent. At one point we had considered getting the PCL switching system, and have it done up to the highest standards but for our little field is just seems too impractical so started looking for less expensive home grown options. We determined that we all know our way and could find it by landmarks (with a little help from our GPS) even at night due to the proximity to a busy highway, and an small but well lit business a mile from the end of the runway so the final consensus is that the lighting would primarily be for an early evening straggler that stayed out a little later than anticipated so LED solar would give ample service, and for departing earlier in the morning than the suns desire to get out of bed then reflectors would light the way while departing. Thanks again for the input and ideas. Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=363983#363983 ________________________________________________________________________________
From: "Bill Bradburry" <bbradburry(at)bellsouth.net>
Subject: Weak and Static on Transmission
Date: Jan 16, 2012
I have a GNS430W radio and Advanced Aircraft Electronics high gain antenna model 5T in my Lancair Legacy (fiberglass fuselage). The antenna is mounted vertically behind the rear bulkhead on the right side of the fuselage. Although I didn't need that much length to reach the antenna, I made the coax the recommended 13 feet or so length. (right now I cant remember the exact length recommended). This antenna is designed to be mounted inside plastic airplanes and doesn't require a ground plane. I get a "weak and lots of static but usable" reports from radio checks and on occasion, while airborne, static gets so great that I can not hear approach at all. I have had to make two NORDO landings at a Class C airport that is located under an overhanging Class B airspace due to the receiving static. The controllers are beginning to take exception to this and I need to get this fixed! :>) I have checked the SWR on the antenna and it was around 1.5 which I understand to be fine. Any ideas as to where I should begin my investigation on the source of this static? Bill B ________________________________________________________________________________
Date: Jan 16, 2012
fwiw, your idea sounds good. my wife enjoys all these solar lights available and has them around her gardens. i think some variety would work for you. bob noffs On Mon, Jan 16, 2012 at 7:41 AM, checkn6 wrote: > > Gentlemen, thank you for all of your input and ideas. > > Our little group of intrepid night flyers is now leaning towards the sola r > lights with the addition of reflective tape on flexible poles. The field is > seldom used and although someone in trouble may look down and see a few > twinkly lights and find salvation it is not the intent. At one point we h ad > considered getting the PCL switching system, and have it done up to the > highest standards but for our little field is just seems too impractical so > started looking for less expensive home grown options. > > We determined that we all know our way and could find it by landmarks > (with a little help from our GPS=92) even at night due to the proximity t o a > busy highway, and an small but well lit business a mile from the end of t he > runway so the final consensus is that the lighting would primarily be for > an early evening straggler that stayed out a little later than anticipate d > so LED solar would give ample service, and for departing earlier in the > morning than the suns desire to get out of bed then reflectors would ligh t > the way while departing. > > Thanks again for the input and ideas. > > Chris > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=363983#363983 > > =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Jan 16, 2012
This sounds a lot like rib-lacing cord. Is that an acceptable substitute? http://www.aircraftspruce.com/catalog/cspages/threads2.php James On 16 January 2012 05:22, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 09:39 PM 1/15/2012, you wrote: > > My preference is the wax cord but as with a lot of things it does take > some practice to get to install it properly. It has other pluses over the > nylon tie wraps You will never slice a hand open while rooting around in an > engine bay that has coraseal and wax cord used. I am one of the ones who > has received my fair share of slices on tie wraps. > > > Here's a link to a tread on the topic a few years > ago: > > * http://tinyurl.com/7a89njo* > > The "waxed cord" commonly found in military and domestic > production aircraft is probably Mil-T-43435 as described > below in the Aircraft Spruce Catalog > [image: Emacs!] > > . . . and the Braden > [image: Emacs!] > > > ** > > ** Bob . . . > ________________________________________________________________________________
Date: Jan 16, 2012
I missed most of this thread...but, wanted to add a comment. Those solar powered lights should work well for your specific application. However, they have a tendency for a short life span. Even the expensive units. I suspect the typical NiCad cells in them go bad. And, bugs, usually spiders can squeeze into a lot of the designs and their activity kills the circuitry. So. find units that are 100% sealed, use standard sized rechargeable cells, maybe a better quality, etc. Buy spares and install them closer in spacing than you originally guesstimated..... Make sure that whoever is in charge of mowing (grass..?) is sober and had excellent vision. D ------------------------------------------------------------------------- ------- ----- Original Message ----- From: bob noffs To: aeroelectric-list(at)matronics.com Sent: Monday, January 16, 2012 6:13 AM Subject: Re: AeroElectric-List: Re: Inexpensive Runway lighting fwiw, your idea sounds good. my wife enjoys all these solar lights available and has them around her gardens. i think some variety would work for you. bob noffs On Mon, Jan 16, 2012 at 7:41 AM, checkn6 wrote: Gentlemen, thank you for all of your input and ideas. Our little group of intrepid night flyers is now leaning towards the solar lights with the addition of reflective tape on flexible poles. The field is seldom used and although someone in trouble may look down and see a few twinkly lights and find salvation it is not the intent. At one point we had considered getting the PCL switching system, and have it done up to the highest standards but for our little field is just seems too impractical so started looking for less expensive home grown options. We determined that we all know our way and could find it by landmarks (with a little help from our GPS=92) even at night due to the proximity to a busy highway, and an small but well lit business a mile from the end of the runway so the final consensus is that the lighting would primarily be for an early evening straggler that stayed out a little later than anticipated so LED solar would give ample service, and for departing earlier in the morning than the suns desire to get out of bed then reflectors would light the way while departing. Thanks again for the input and ideas. Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=363983#363983 ========== -List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List ========== http://forums.matronics.com ========== le, List Admin. ="_blank">http://www.matronics.com/contribution ========== ________________________________________________________________________________
Subject: Inexpensive Runway lighting
Date: Jan 16, 2012
LED-based pavement markers from BrightPortal Resources were recently installed at 18FD to supplement the existing pilot-controlled incandescents. VERY impressive. The individual lights are stuck to concrete blocks plopped in the dirt beside the existing light fixtures. Relatively inexpensive, zero maintenance, no wires to string and appropriate colors for side and end-markers are readily available. Neal -----Original Message----- One could craft some LED, solar powered REIL fixtures too. This would get you oriented with the most rudimentary of navigation devices. It doesn't take much light to be seen from 5 miles away. Hence, not much energy needs to be stored to keep a few LEDs flashing. Bob . . . ________________________________________________________________________________
Date: Jan 16, 2012
Thanks Bob; I knew you would have the right link to a certified product. Noel From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: January 16, 2012 1:52 AM Subject: RE: AeroElectric-List: Wire Bundle Wrapping Tape? At 09:39 PM 1/15/2012, you wrote: My preference is the wax cord but as with a lot of things it does take some practice to get to install it properly. It has other pluses over the nylon tie wraps You will never slice a hand open while rooting around in an engine bay that has coraseal and wax cord used. I am one of the ones who has received my fair share of slices on tie wraps. Here's a link to a tread on the topic a few years ago: http://tinyurl.com/7a89njo The "waxed cord" commonly found in military and domestic production aircraft is probably Mil-T-43435 as described below in the Aircraft Spruce Catalog Emacs! . . . and the Braden Emacs! Bob . . . ________________________________________________________________________________
Date: Jan 16, 2012
Subject: Re: Inexpensive Runway lighting
Good Evening Neal, Just wondering what you mean when you say the lights are stuck in a concrete block near the existing lights. A concrete block on the surface could be a rather dangerous item if it is even partially above the ground. If the block were completely buried, I think that would be alright. Whatever supports the light, it should be frangible as determined by the type aircraft involved. I have read some big airport specifications where frangible was deemed to mean frangible by a 36 inch wheel. I would think a Bonanza could get some serious damage if it hit a concrete block on the surface. 36 inch diameter wheel on a heavy jet might be no problem at all. Any comments? Happy Skies, Old Bob In a message dated 1/16/2012 6:14:55 P.M. Central Standard Time, n8zg(at)att.net writes: --> AeroElectric-List message posted by: "Neal George" LED-based pavement markers from BrightPortal Resources were recently installed at 18FD to supplement the existing pilot-controlled incandescents. VERY impressive. The individual lights are stuck to concrete blocks plopped in the dirt beside the existing light fixtures. Relatively inexpensive, zero maintenance, no wires to string and appropriate colors for side and end-markers are readily available. Neal ________________________________________________________________________________
Date: Jan 16, 2012
Good points Bob - I wasn't involved in the install, but it appears that the LED fixtures are bonded (some sort of glue/putty/epoxy/caulk) to the blocks. Standard block is nominally 8" high x 10" wide x 8" thick, actually 7.5" x 9.5" x 7.5". The blocks in this situation are half-thick standard concrete block, so approximately 7.5" x 9.5" x 3.5". It also appears that the blocks were inset slightly in an effort to get them close to level. The result is the blocks are less than 3" proud of the ground, immediately adjacent to the existing runway edge- and end-marker light fixtures, which stand knee high. Low enough to not be a prop strike hazard, but probably not friendly to wheel pants. But if one strays into the lights, chances are good the lights and their mounts are the least of one's troubles. To paraphrase the old cartographers, "Here there be Dragons." neal From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of BobsV35B(at)aol.com Sent: Monday, January 16, 2012 7:28 PM Subject: Re: AeroElectric-List: Inexpensive Runway lighting Good Evening Neal, Just wondering what you mean when you say the lights are stuck in a concrete block near the existing lights. A concrete block on the surface could be a rather dangerous item if it is even partially above the ground. If the block were completely buried, I think that would be alright. Whatever supports the light, it should be frangible as determined by the type aircraft involved. I have read some big airport specifications where frangible was deemed to mean frangible by a 36 inch wheel. I would think a Bonanza could get some serious damage if it hit a concrete block on the surface. 36 inch diameter wheel on a heavy jet might be no problem at all. Any comments? Happy Skies, Old Bob In a message dated 1/16/2012 6:14:55 P.M. Central Standard Time, n8zg(at)att.net writes: LED-based pavement markers from BrightPortal Resources were recently installed at 18FD to supplement the existing pilot-controlled incandescents. VERY impressive. The individual lights are stuck to concrete blocks plopped in the dirt beside the existing light fixtures. Relatively inexpensive, zero maintenance, no wires to string and appropriate colors for side and end-markers are readily available. Neal ________________________________________________________________________________
Date: Jan 17, 2012
1/17/2012 Hello Bill Bradburry, You wrote: 1) "Although I didn't need that much length to reach the antenna, I made the coax the recommended 13 feet or so length." It may not have a direct bearing on your "weak and lots of static but usable" problem, but it sounds like you are a bit confused about the antenna requirements of the GNS 430W. The specific coax length that you referred to in your posting refers to the GPS antenna for the 430W. High quality coax such as RG400 is required. Here is what AAE says about the cable length for one of their VHF comm antennas: "Q. What cable length is recommended for the antenna ? A. Any length can be used. This antenna is impedance matched to 50 ohms to allow you to use any length required." 2) "Any ideas as to where I should begin my investigation on the source of this static?" You could narrow down the source of the problem a bit if you could borrow a GNS 430W from a fellow builder or shop and install it temporarily for testing. If the problem goes away the problem is inside your 430W box and not the aircraft installation. 'OC' Baker Says: "The best investment we can make is the time and effort to gather and understand knowledge." PS: Pull out and reseat your 430W box before going to the bother of borrowing another unit -- the problem may just be a reseating or mis aligned pin condition. ============================================================ From: "Bill Bradburry" <bbradburry(at)bellsouth.net> Subject: AeroElectric-List: Weak and Static on Transmission I have a GNS430W radio and Advanced Aircraft Electronics high gain antenna model 5T in my Lancair Legacy (fiberglass fuselage). The antenna is mounted vertically behind the rear bulkhead on the right side of the fuselage. Although I didn't need that much length to reach the antenna, I made the coax the recommended 13 feet or so length. (right now I cant remember the exact length recommended). This antenna is designed to be mounted inside plastic airplanes and doesn't require a ground plane. I get a "weak and lots of static but usable" reports from radio checks and on occasion, while airborne, static gets so great that I can not hear approach at all. I have had to make two NORDO landings at a Class C airport that is located under an overhanging Class B airspace due to the receiving static. The controllers are beginning to take exception to this and I need to get this fixed! :>) I have checked the SWR on the antenna and it was around 1.5 which I understand to be fine. Any ideas as to where I should begin my investigation on the source of this static? Bill B ________________________________________________________________________________
Date: Jan 17, 2012
As far as the runway lights, I guess it depends on how much you trust your runway lights. If you're willing to trust your work on your OBAM aircraft, I wouldn't think there would be a problem trusting your OBAM runway lights. Raymond Julian Kettle River, MN Excellent point! I've been wrestling semantics with some lawyers who would like for the public to believe that "experimental" aircraft are labeled such because they are fraught with heretofore unproven and potentially dangerous features of design and fabrication. I offered the notion that "experimental" is synonymous with "exploration" and "discovery". For students in the chemistry lab, the treatment of certain substances is indeed an "experiment". For the teacher, it's a recipe for a successful teaching moment. The outcome of the experiment is known to the teacher . . . just as the outcome of a kit airplane built to instructions and common sense. When the kit is completed and flying, that builder can now be a teacher in that they've "been there, done that". It is the job of a teacher to make sure that deviations from instructions are well thought out, perhaps "explored or discovered", and proven to be useful, non-hazardous changes whereupon the changes are no longer experimental. Experimentation is a process by which a useful design goal is achieved. When one sets out to fabricate DIY runway lights, it's almost a certainty that individuals who choose to experiment in public will sort through the ideas and potential pitfalls in places like this List-Server. Even then, I would expect the developer to use the system many times under ever-increasing levels of degradation due to environmental effects . . . and report back as to the limits he/she personally places on the utility of that system. TC aviation has processes and procedures for advancing the state of the art and reducing risk. TC aviation is famous for what I call the $1000 meeting where useful advances are slow and cumbersome. OBAM aviation has a process too. It's different but no less effective . . . and a whole lot more satisfying. We who sit at our keyboards with a cup of coffee collaborate and advance an idea further and faster to the benefit of hundreds who read now and that many more who read the archives later. This is the process by which WE choose to reduce risk. Keep it up folks! We're doing good work here. Bob . . . ________________________________________________________________________________
Date: Jan 17, 2012
At 08:48 AM 1/16/2012, you wrote: >This sounds a lot like rib-lacing cord. Is that an acceptable substitute? Not sure which direction the substitution is taking place. Are you asking if you can use the recommended rib lacing cord to tie wire bundles? The answer would be certainly. Use the flat-lace described to tie fabric to ribs? Don't know. I'd be inclined to stick with the legacy, 'been there, done that' materials. Bob . . . ________________________________________________________________________________
Date: Jan 17, 2012
At 06:38 PM 1/16/2012, you wrote: Thanks Bob; I knew you would have the right link to a certified product. Let's not be too quick to call it 'certified' . . . it's certainly a material built to known quality and performance standards and suited to the task on certified airplanes. But no part or accessory gets holy-watered by the FAA with any sort of certification, only complete airframes get type certificates. Once ANY part or material shows up on the bill of materials for a TC aircraft, it is 'qualified' for such service irrespective of its pedigree. There are many products built to rigorous specifications that may or may no be suited to task aboard an airplane. So just because it's 'mil-spec' doesn't make it holy. In this case, the flat lace cited has a long and successful history in TC aircraft and elsewhere. Bob . . . ________________________________________________________________________________
Date: Jan 17, 2012
Subject: Re: Weak and Static on Transmission
At 08:07 AM 1/16/2012, you wrote: . . . I get a "weak and lots of static but usable" reports from radio checks and on occasion, while airborne, static gets so great that I can not hear approach at all. I have had to make two NORDO landings at a Class C airport that is located under an overhanging Class B airspace due to the receiving static. The controllers are beginning to take exception to this and I need to get this fixed! :>) Bob's points are well taken. I can expand by suggesting that you are committed to the classic "divide and conquer" ploy . . . you need to separate the potential for an antenna system problems from the radio's potential problems. It's difficult to sift the sands of potential problems without hearing the nature of the "static". If you were getting a signal report from a grey-bearded ham radio operator he would qualify the report with "weak to the point of inducing pop-corn noise", or succumbing to atmospheric noises like lightning crashes, or scratching noise reminiscent of a loose connection. Further, such noises heard by experienced ears could probably tell if it was in the RF or audio chain of your transmission system. But alas, I've never heard a cogent signal report from a tower operator and seldom from other pilots in their own airplanes. I'd recommend a series of experiments. Plug a hand held into the antenna system and get signal reports from other pilots. You can start on the ground but they should probably be airborne so that they can fly outbound and get some sense of signal strength along with judgement of audio quality. If it doesn't repeat on the ground, then you go flying too. If the other guy reports noises, do YOU hear any noises? Open the radio's squelch control and tune in stations some distance away. Does the complaining controller repeat the complaint while the hand-held is being used? If the antenna system seems okay, this leaves the radio. "Weak and static" suggests one or more issues combining to reduce power output and introduction of noises reminiscent of loose connections. Probably nothing you can do about it personally except to confirm poor performance by getting a measurement of output power during an SWR check. This takes a unique kind of instrument not often found in the OBAM aviation toolbox. Emacs! Also, check with someone else in another airplane or even on the ground who overhears both sides of your conversation with the controllers. Does that third party agree with the controller's assessment? Can they refine the description of "static"? I assisted in a similar exercise many years ago where the builder left a tape recorder running with the mic in front of the Unicom receiver in his hangar. One could hear both sides of the conversation. In this case, both sides of the conversation were clear. We then did a frequency check on the airplane radio and found that it was at the high end of the spec . . . enough off center to be at the edge of the government's receiver bandwidth but still inside the bandwidth of the lower cost receiver in the hangar. Replacing one of the transmitter's crystals fixed the problem. In your modern, frequency synthesized radio, this is an exceedingly remote possibility. The point is that you need GOOD data that tests a host of possibilities. "Weak and static" from one observer is insufficient data. Bob . . . ________________________________________________________________________________
From: "earl_schroeder(at)juno.com" <earl_schroeder(at)juno.com>
Date: Jan 17, 2012
Subject: Account hacked
Please ignore any emails from my yahoo account.. I am NOT in England or anywhere else and do NOT send money anywhere!! We are working hard to correct this. Thanks! ________________________________________________________________________________
Date: Jan 17, 2012
I was wondering if there was anything special about the electrical type that would preclude me from using the spare flat waxed rib cord I have -- it came on a reel with about 2 miles of cord, so there's quite a bit left over from when I did the covering! Thanks for the advice. James On 17 January 2012 15:18, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > nuckolls.bob(at)aeroelectric.com**> > > At 08:48 AM 1/16/2012, you wrote: > >> This sounds a lot like rib-lacing cord. =C3=82 Is that an acceptable >> substitute?=C3=82 >> > > Not sure which direction the substitution is taking > place. Are you asking if you can use the recommended > rib lacing cord to tie wire bundles? The answer would > be certainly. Use the flat-lace described to tie > fabric to ribs? Don't know. I'd be inclined to > stick with the legacy, 'been there, done that' materials. > > > Bob . . . > > =====**=================== ===========**= /www.matronics.com/Navigator?AeroElectric-List> =====**=================== ===========**= =====**=================== ===========**= com/contribution> =====**=================== ===========**= > > ________________________________________________________________________________
Date: Jan 17, 2012
At 02:54 PM 1/17/2012, you wrote: I was wondering if there was anything special about the electrical type that would preclude me from using the spare flat waxed rib cord I have -- it came on a reel with about 2 miles of cord, so there's quite a bit left over from when I did the covering! Thanks for the advice. I think that's a safe substitution. In fact, does your spool of flat lace have any numbers on it . . . like Mil-T-$#@%? It may well be that the stuff we tie wires with is exactly the same as that used to stitch ribs. In any case, wire ties are not highly stress nor subject to the effects of exposure to the environment. Using it to tie wires is not a high-risk decision. Bob . . . ________________________________________________________________________________
Date: Jan 17, 2012
Subject: Crimping to component leads?
I recently ran across "crimp sleeves" or some such at a web site, associated with a leaded electrical component. Although it wasn't explicit, I gathered that this is simply a small metal tube which can be used to crimp a wire to the lead of the component. This approach would be convenient in a couple of cases: using resistors in lieu of fuses or circuit breakers for low-amperage circuit (for example, with LED lighting or indicators, one could put the current limiting resistor at the bus rather than the device, and no additional circuit protection would be necessary); or diode functions could be implemented in the wiring harness. I've found no other reference or source to anything like this. Is my interpretation correct? If so, where might one find "crimp sleeves", beyond that one site? I assume this would be limited to lead-to-wire vs. lead-to-lead (as might be used in cascading components) - is this the case? What components are suitable for this approach? The sample was actually an axially-leaded thermostat, but I'd hope/expect it would work with leaded resistors and beefy-bodied plastic-encapsulated diodes. And that leaded reed switches would be a really poor choice. Thoughts? Thx, Jon ________________________________________________________________________________
Date: Jan 17, 2012
Subject: Re: Crimping to component leads?
At 08:32 PM 1/17/2012, you wrote: I recently ran across "crimp sleeves" or some such at a web site, associated with a leaded electrical component. Although it wasn't explicit, I gathered that this is simply a small metal tube which can be used to crimp a wire to the lead of the component. This approach would be convenient in a couple of cases: using resistors in lieu of fuses or circuit breakers for low-amperage circuit (for example, with LED lighting or indicators, one could put the current limiting resistor at the bus rather than the device, and no additional circuit protection would be necessary); or diode functions could be implemented in the wiring harness. There are a number of such products that I saw in common usage at Beech. Installing in-line components was not allowed but they WERE used to splice wires and COULD be used to install components. Here's my own favorite technique for 'homeless' components. http://www.aeroelectric.com/articles/Homeless/Homeless_Components.htm The goal is (1) good electrical connection and (2) support of vibration prone solid wires including the solid-by-solder strands of the wires. I've found no other reference or source to anything like this. Is my interpretation correct? If so, where might one find "crimp sleeves", beyond that one site? I assume this would be limited to lead-to-wire vs. lead-to-lead (as might be used in cascading components) - is this the case? What components are suitable for this approach? The sample was actually an axially-leaded thermostat, but I'd hope/expect it would work with leaded resistors and beefy-bodied plastic-encapsulated diodes. Yup. And that leaded reed switches would be a really poor choice. You got that right! Bob . . . ________________________________________________________________________________
Date: Jan 18, 2012
> Do the lights go out when the alternator comes on line? > Why two separate LV warning systems? I've got a few days to go before engine start so I can't address the on-line alternator scenario. Re 2 LVW's, I have two alternators. The stby alternator uses a Ford-type regulator, hence the 9005 LVM. John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=364202#364202 ________________________________________________________________________________
Date: Jan 18, 2012
Just to make sure the obvious is not overlooked, are you sure that the location of the antenna is surrounded by fiberglass and not RF-opaque carbon fiber? IIRC, the Legacy uses a lot of CF in the airframe. John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=364203#364203 ________________________________________________________________________________
Date: Jan 18, 2012
I'm surprised no one has brought up the obvious of likely P-static. Does the aircraft have any static wicks? On 1/18/2012 10:30 AM, jonlaury wrote: > --> AeroElectric-List message posted by: "jonlaury" > > Just to make sure the obvious is not overlooked, are you sure that the location of the antenna is surrounded by fiberglass and not RF-opaque carbon fiber? > IIRC, the Legacy uses a lot of CF in the airframe. > > John > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=364203#364203 > > ________________________________________________________________________________
Date: Jan 19, 2012
>I've got a few days to go before engine start so I can't address the >on-line alternator scenario. >Re 2 LVW's, I have two alternators. The stby alternator uses a >Ford-type regulator, hence the 9005 LVM. Understand. Check the calibration of your bench test setup for the LV Warning trip points. To have both an LR3 and ABMM module to be off by the same direction and magnitude is curious. Both are set by design at 13.0 volts although being .5 V higher wouldn't hurt their utility. Bob . . . ________________________________________________________________________________
Date: Jan 19, 2012
At 11:30 AM 1/18/2012, you wrote: > >Just to make sure the obvious is not overlooked, are you sure that >the location of the antenna is surrounded by fiberglass and not >RF-opaque carbon fiber? >IIRC, the Legacy uses a lot of CF in the airframe. ???? Hmmm . . . didn't know that about the Legacy but I wondered when he made the reference to 'fiberglas'. I thought it curious that Lancair would use the carbon fiber in the IV and glass in the Legacy. Yeah, if the antenna is inside a carbon structure it's effectiveness is severely degraded. Bob . . . ________________________________________________________________________________
Date: Jan 19, 2012
At 10:18 PM 1/18/2012, you wrote: > >I'm surprised no one has brought up the obvious >of likely P-static. Does the aircraft have any static wicks? He didn't mention flying in precip and static wicks don't have anything to 'connect' to on a glass airplane. If it's a carbon fiber then wicks might be useful but my impression was that his poor signal reports were at low altitudes and probably slowed down for approach to landing and in clear weather. P-static wouldn't hurt a transmitted signal, only a received signal and he didn't mention not being able to hear . . . only be heard. This is why the differentiation between weak-signal static versus poor connection static is important. The presence of carbon would support the notion of it being the weak-signal variety. Bob . . . ________________________________________________________________________________
Date: Jan 20, 2012
Well, to further clarify this problem. I seem to be able to hear ok on the ground while taxiing around the airport, but after I leave the airport the reception gets really bad. At first I thought it was a problem with the approach frequency because that is where it would first start up. It was a loud hiss in the headphones so loud that I could not hear ATC. In fact, I have made two NORDO landings as a result on this loud hiss. I sent my radio back to have it checked out and nothing was found. All this trouble is at below 5000 ft and fine weather. I am flying off my 40 hours (22 so far) and am only flying in good weather. These radio problems at a Class C airport have made me afraid to fly. ATC could take some action against me if it continues. Lancair has an all carbon Legacy available but this one is all fiberglass with the exception of the horizontal stabilizer, which is carbon. The antenna is inside the fuselage about 4+feet forward of the stabilizer. The bottom and rear half of the plane is in primer. The rest of the plane is bare fiberglass. The primer ends just about at the location of the antenna on the fuselage. I don't know if this would have an effect on the static on the plane or not. I would have had to consider static wicks a long time earlier in the build in order to install bonding wire. It is too late now AFAIK. Bill B -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Thursday, January 19, 2012 9:10 AM Subject: Re: AeroElectric-List: Re: Weak and Static on Transmission At 10:18 PM 1/18/2012, you wrote: > >I'm surprised no one has brought up the obvious >of likely P-static. Does the aircraft have any static wicks? He didn't mention flying in precip and static wicks don't have anything to 'connect' to on a glass airplane. If it's a carbon fiber then wicks might be useful but my impression was that his poor signal reports were at low altitudes and probably slowed down for approach to landing and in clear weather. P-static wouldn't hurt a transmitted signal, only a received signal and he didn't mention not being able to hear . . . only be heard. This is why the differentiation between weak-signal static versus poor connection static is important. The presence of carbon would support the notion of it being the weak-signal variety. Bob . . . ________________________________________________________________________________
Date: Jan 20, 2012
Bill, Could this be interference from 1. Your EFIS? 2. Your electronic ignition at higher RPM? I have an SL-30 with the antenna behind my rear seat bulkhead, and a SL-40 with the antenna a homemade in the vertical stab. SL-30 is noisy like you describe, but the -40 works fine. I think it is the EFIS (was worse with Blue mountain, still present with Grand Rapids, but not as bad) Bill Schertz KIS Cruiser #4045 N343BS Phase one testing Completed -----Original Message----- From: Bill Bradburry Sent: Friday, January 20, 2012 7:38 AM Subject: RE: AeroElectric-List: Re: Weak and Static on Transmission Well, to further clarify this problem. I seem to be able to hear ok on the ground while taxiing around the airport, but after I leave the airport the reception gets really bad. At first I thought it was a problem with the approach frequency because that is where it would first start up. It was a loud hiss in the headphones so loud that I could not hear ATC. In fact, I have made two NORDO landings as a result on this loud hiss. I sent my radio back to have it checked out and nothing was found. All this trouble is at below 5000 ft and fine weather. I am flying off my 40 hours (22 so far) and am only flying in good weather. These radio problems at a Class C airport have made me afraid to fly. ATC could take some action against me if it continues. Lancair has an all carbon Legacy available but this one is all fiberglass with the exception of the horizontal stabilizer, which is carbon. The antenna is inside the fuselage about 4+feet forward of the stabilizer. The bottom and rear half of the plane is in primer. The rest of the plane is bare fiberglass. The primer ends just about at the location of the antenna on the fuselage. I don't know if this would have an effect on the static on the plane or not. I would have had to consider static wicks a long time earlier in the build in order to install bonding wire. It is too late now AFAIK. Bill B -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Thursday, January 19, 2012 9:10 AM Subject: Re: AeroElectric-List: Re: Weak and Static on Transmission At 10:18 PM 1/18/2012, you wrote: > >I'm surprised no one has brought up the obvious >of likely P-static. Does the aircraft have any static wicks? He didn't mention flying in precip and static wicks don't have anything to 'connect' to on a glass airplane. If it's a carbon fiber then wicks might be useful but my impression was that his poor signal reports were at low altitudes and probably slowed down for approach to landing and in clear weather. P-static wouldn't hurt a transmitted signal, only a received signal and he didn't mention not being able to hear . . . only be heard. This is why the differentiation between weak-signal static versus poor connection static is important. The presence of carbon would support the notion of it being the weak-signal variety. Bob . . . ________________________________________________________________________________
Date: Jan 20, 2012
Any chance that the kit has carbon material layered into the fiberglass for some reason like rigidity, or some other form of strength needed..? Sure sounds like the antenna is being blocked. Have you tried to temporary substitute a simple outside antenna..? At least that would eliminate the radio system as being the cause.... Dave ___________________________________________________________ ----- Original Message ----- From: "Bill Bradburry" <bbradburry(at)bellsouth.net> Sent: Friday, January 20, 2012 5:38 AM Subject: RE: AeroElectric-List: Re: Weak and Static on Transmission > > > Well, to further clarify this problem. I seem to be able to hear ok on > the > ground while taxiing around the airport, but after I leave the airport the > reception gets really bad. At first I thought it was a problem with the > approach frequency because that is where it would first start up. It was > a > loud hiss in the headphones so loud that I could not hear ATC. In fact, I > have made two NORDO landings as a result on this loud hiss. I sent my > radio > back to have it checked out and nothing was found. All this trouble is at > below 5000 ft and fine weather. I am flying off my 40 hours (22 so far) > and > am only flying in good weather. These radio problems at a Class C airport > have made me afraid to fly. ATC could take some action against me if it > continues. > > Lancair has an all carbon Legacy available but this one is all fiberglass > with the exception of the horizontal stabilizer, which is carbon. The > antenna is inside the fuselage about 4+feet forward of the stabilizer. > The bottom and rear half of the plane is in primer. The rest of the plane > is bare fiberglass. The primer ends just about at the location of the > antenna on the fuselage. I don't know if this would have an effect on the > static on the plane or not. I would have had to consider static wicks a > long time earlier in the build in order to install bonding wire. It is > too > late now AFAIK. > > Bill B > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert > L. > Nuckolls, III > Sent: Thursday, January 19, 2012 9:10 AM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Re: Weak and Static on Transmission > > > > At 10:18 PM 1/18/2012, you wrote: > >> >>I'm surprised no one has brought up the obvious >>of likely P-static. Does the aircraft have any static wicks? > > He didn't mention flying in precip and static > wicks don't have anything to 'connect' to on > a glass airplane. If it's a carbon fiber then > wicks might be useful but my impression was that > his poor signal reports were at low altitudes > and probably slowed down for approach to landing > and in clear weather. P-static wouldn't hurt > a transmitted signal, only a received signal and > he didn't mention not being able to hear . . . > only be heard. > > This is why the differentiation between weak-signal > static versus poor connection static is important. > The presence of carbon would support the notion of > it being the weak-signal variety. > > > Bob . . . > > > ________________________________________________________________________________
Subject: Burnt wire at Ducati Regulator
Date: Jan 20, 2012
I had originally posted this message on the Kitfox Forum and have since spoken to Bob on the phone and he suggested that I put this on the aero electrical forum as well. I believe that it was a bad connection done by the previous builder and have since replaced/repaired with a new connector and a proper crimp. -------------------------------------------------------------------------------- I had a forced landing today due to smoke in the cockpit. Fortunately I was nearby the airport and landed safely after shutting down all the electrical. After removing the foam donuts that my butt cut out of the seat pads, I started troubleshooting. I found that one of the wires from the coils/alternator where it goes into the regulator was fried. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=364387#364387 Attachments: http://forums.matronics.com//files/picture_063_rev_204.jpg http://forums.matronics.com//files/picture_061_rev_147.jpg ________________________________________________________________________________
Subject: RG 58 Connectors VS RG 400 Connectors
Date: Jan 20, 2012
I currently have RG 58 coax connecting my radio to the antenna. Picking up a lot of engine noise though. Would like to switch over to RG 400. But I see that RG 400 coax has BNC 400 connectors. Will the BNC 400 female connector fit on to a BNC 58 male connector? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=364410#364410 ________________________________________________________________________________
Date: Jan 20, 2012
Subject: Re: Burnt wire at Ducati Regulator
At 03:33 PM 1/20/2012, you wrote: Thanks for the follow-up Jerry and the pictures. It would be interesting to have the old cut-off terminal to examine. It MIGHT have been a failure of the fast-on terminal's grip on the tab but from your description of the crimps, failure at the wire-to-terminal connection seems more likely. In any case, peering at it under the microscope would still be an interesting exercise. As we discussed on the phone, if the new crimp tool you've purchased specifically covers "PIDG" terminals, then you're good to go with an inspection and perhaps some replacement of existing terminals. Bob . . . ________________________________________________________________________________
Date: Jan 20, 2012
Subject: Re: RG 58 Connectors VS RG 400 Connectors
At 07:01 PM 1/20/2012, you wrote: I currently have RG 58 coax connecting my radio to the antenna. Picking up a lot of engine noise though. Would like to switch over to RG 400. It is doubtful that a change of coax will fix any noise problem. But I see that RG 400 coax has BNC 400 connectors. Will the BNC 400 female connector fit on to a BNC 58 male connector? Yes, "BNC" is the designation for a series of connectors that will mate with each other irrespective of the style of coax in the connector. Bob . . . ________________________________________________________________________________
Date: Jan 20, 2012
Subject: HID Lights
Hi Bob - Though-this is not aircraft related,-you did mention-you were going t o install an HID light system in-your vehicle.- I just installed an aft ermarket system in a 2001 VW Passat.- No noticable noise/issues on the au dio system, although I haven;t held my handheld nav/com near the ballasts. - Bottom line, for about $100 Cnd, the lights are great compared to the halog ens I had previously. - Regards,- - Rick Vans #40956 Southampton, Ont ________________________________________________________________________________
Date: Jan 20, 2012
Subject: Re: HID Lights
At 08:14 PM 1/20/2012, you wrote: >Hi Bob > >Though this is not aircraft related, you did mention you were going >to install an HID light system in your vehicle. I just installed an >aftermarket system in a 2001 VW Passat. No noticable noise/issues >on the audio system, although I haven;t held my handheld nav/com >near the ballasts. > >Bottom line, for about $100 Cnd, the lights are great compared to >the halogens I had previously. Rick, Thanks for the input. I've not received the exemplar kit that folks are reporting as 'noisy' but I did get this kit from an advertiser on eBay. http://www.ebay.com/itm/120843597694?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649 The parts look good. My Sedona is in the transmission shop so I won't be able to try the new lights until Monday. Will let the group know what I discover as well. Let me know if your hand-held 'sniffer' smells anything. Bob . . . ________________________________________________________________________________
Subject: Grand rapids cs02 / cs01 amp sensor
From: "chris Sinfield" <chris_sinfield(at)yahoo.com.au>
Date: Jan 20, 2012
Hi all > I am installing a Grand Rapids J6000 EIS in my aircraft. > > Where have people wired the amp current sensor? and through whit size > > wire was it? > > There are 2 different current sensors and they are for different size > > wires? > > > > you can use the CS-01 or CS-02 or amps. the most important difference > > is the size wire that is allowed for each. > > the CS-01 100amp can fit up to a #4 wire and the CS-02 50amp can only > > fit up to #6 wire. so if you're using a big battery cable most > > people require the #4 wire and the CS-01. > > > > So which one to use and where did you fit it in the elec circuit on a > > Jab3300? > > > > Chris > > Zodiac XL > > Jab 3300 > > Read this topic online here: http://forums.matronics.com/viewtopic.php?p=364425#364425 ________________________________________________________________________________
Subject: Headset microphone level reducer
Date: Jan 21, 2012
Hi there Etienne, The MGL radio can have the microphone levels independently set- do you have the V10 or V6 radio? Jay -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Etienne Phillips Sent: 02 January 2012 08:29 PM Subject: AeroElectric-List: Headset microphone level reducer Hi All I have two dissimilar headsets that have very different microphone output levels. The one headset is an oldish basic Avcomm model, and the other is a new child-sized one. My MGL radio/intercom doesn't have the ability to reduce the volume of the new headset adequately. I've never worked with electret microphones before, so am not sure how to build a signal reducer. I have noticed that they are polarity sensitive, which leads me to expect some phantom power is required...? I need to reduce the volume by about 15dB (according to the MGL radio) to match the Avcomm. Ideally, I'd like to be able to build a passive circuit that I can squeeze into the headset itself, rather than an interface box or off-the-shelf device. This will allow me to use the new headset in other aircraft as the Avcomm's seem to play nicely with other major brands. If anyone has some insight, I'd be most appreciative! Thanks Etienne ________________________________________________________________________________
Date: Jan 21, 2012
1/21/2012 Hello Bill Bradburry, You wrote: "These radio problems at a Class C airport have made me afraid to fly." I consider the following items to be mandatory equipment in my experimental amateur built airplane both during phase one testing and subsequently: 1) One of the readily available, portable, battery powered hand held VHF communications radios along with both its original rechargeable battery (recently recharged) and a spare fitted battery case filled with alkaline batteries. 2) An adapter that allows me to plug my headset into the portable radio. 3) A means to temporarily connect the antenna connection of the portable radio into one of the airplane's more capable antennae. Note that: a) Actually using this temporary antenna connection is optional at the time of intended use and initial attempts at communication may be made using the antenna mounted on the portable radio itself. b) Using this temporary antenna connection and the hand held radio for trouble shooting may aid in locating the source of your communication problem. Following the above philosophy may take you out of the "afraid to fly category". When you eventually solve this problem please let us know what the problem was -- thanks. 'OC' Baker Says: "The best investment we can make is the time and effort to gather and understand knowledge." PS: You also wrote: "I sent my radio back to have it checked out and nothing was found." A "ground checks OK" result does not guarantee that the connection between the radio and your airplane is also OK. Have you been able to borrow an identical radio and test it in your airplane? ========================================================== From: "Bill Bradburry" <bbradburry(at)bellsouth.net> Subject: RE: AeroElectric-List: Re: Weak and Static on Transmission Well, to further clarify this problem. I seem to be able to hear ok on the ground while taxiing around the airport, but after I leave the airport the reception gets really bad. At first I thought it was a problem with the approach frequency because that is where it would first start up. It was a loud hiss in the headphones so loud that I could not hear ATC. In fact, I have made two NORDO landings as a result on this loud hiss. I sent my radio back to have it checked out and nothing was found. All this trouble is at below 5000 ft and fine weather. I am flying off my 40 hours (22 so far) and am only flying in good weather. These radio problems at a Class C airport have made me afraid to fly. ATC could take some action against me if it continues. Lancair has an all carbon Legacy available but this one is all fiberglass with the exception of the horizontal stabilizer, which is carbon. The antenna is inside the fuselage about 4+feet forward of the stabilizer. The bottom and rear half of the plane is in primer. The rest of the plane is bare fiberglass. The primer ends just about at the location of the antenna on the fuselage. I don't know if this would have an effect on the static on the plane or not. I would have had to consider static wicks a long time earlier in the build in order to install bonding wire. It is too late now AFAIK. Bill B ________________________________________________________________________________
Date: Jan 21, 2012
Subject: Re: Grand rapids cs02 / cs01 amp sensor
i put mine on the cable from the battery after the starter so it monitored supply to the panel. bob noffs On Fri, Jan 20, 2012 at 11:46 PM, chris Sinfield < chris_sinfield(at)yahoo.com.au> wrote: > chris_sinfield(at)yahoo.com.au> > > Hi all > > I am installing a Grand Rapids J6000 EIS in my aircraft. > > > Where have people wired the amp current sensor? and through whit size > > > wire was it? > > > There are 2 different current sensors and they are for different size > > > wires? > > > > > > you can use the CS-01 or CS-02 or amps. the most important difference > > > is the size wire that is allowed for each. > > > the CS-01 100amp can fit up to a #4 wire and the CS-02 50amp can only > > > fit up to #6 wire. so if you're using a big battery cable most > > > people require the #4 wire and the CS-01. > > > > > > So which one to use and where did you fit it in the elec circuit on a > > > Jab3300? > > > > > > Chris > > > Zodiac XL > > > Jab 3300 > > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=364425#364425 > > ________________________________________________________________________________
Subject: Re: Headset microphone level reducer
From: Etienne Phillips <etienne.phillips(at)gmail.com>
Date: Jan 21, 2012
Hi Jay I've got a V10 radio, and I've already maxed out the settings, turning the pax headset all the way down, and it still was too loud. I don't want to turn up the Pilot's mic, as it is set correctly, matching the incoming radio volume. I haven't gotten around to trying out Bob's suggestion yet, but I'm pretty sure it'll work. Thanks Etienne On 21 Jan 2012, at 10:43 AM, Jay Hyde wrote: > > Hi there Etienne, > > The MGL radio can have the microphone levels independently set- do you have > the V10 or V6 radio? > > Jay ________________________________________________________________________________
From: "ROGER & JEAN CURTIS" <mrspudandcompany(at)verizon.net>
Subject: SWR Meter
Date: Jan 21, 2012
I have a Vintage Sears SWR / FS meter which appears to be the same as the Cal Com Model 9856. Can this be used to check the antenna on aircraft nav com radios? If so, how do I set it up for use? Roger ________________________________________________________________________________
Date: Jan 21, 2012
Subject: Re: SWR Meter
At 12:57 PM 1/21/2012, ROGER & JEAN CURTIS wrote: > I have a Vintage Sears SWR / FS meter which appears to be >the same as the Cal Com Model 9856. Can this be used to check the antenna >on aircraft nav com radios? If so, how do I set it up for use? > > Roger > This is no doubt an excellent example of a transmission line sampling reflectometer. Dozens of products of this genre' were manufactured and they are quite common. Bob . . . ________________________________________________________________________________
Date: Jan 21, 2012
Subject: Re: SWR Meter OOPS
Sorry, hit the 'send' function before finishing the reply. Ignore the previous posting . . . At 12:57 PM 1/21/2012, ROGER & JEAN CURTIS wrote: > I have a Vintage Sears SWR / FS meter which appears to be >the same as the Cal Com Model 9856. Can this be used to check the antenna >on aircraft nav com radios? If so, how do I set it up for use? > > Roger This is no doubt an excellent example of a directional coupler sampling reflectometer. Dozens of products of this genre' were manufactured and they are quite common. Emacs! A general description of this device can be secured at: http://en.wikipedia.org/wiki/SWR_meter They are quite effective over the range of 2 to perhaps 30 MHz. To be useful, the length of transmission line inside must be a small fraction of a wavelength at the frequency of interest. In this case, 126 Mhz. When you study the design of a Watt/SWR meter suited for VHF . . . Emacs! The sampling is in a single "slug" that can be rotated to present complimentary forward and reverse power samples. Emacs! The slug contains a miniaturized version of the directional coupler sampling sampling loops found in your SWR meter. Here's a photo of a miniaturized version of your SWR meter optimized for VHF/UHF service. The loops are about 1/2" long. Emacs! So the short answer is the instrument you have is useful at Citizen's band frequencies and below. You need something tailored to VHF to do any serious work with your ship's antennas. Something like this Emacs! which can be had for about $60 off eBay. It's optimized for VHF and will produce more useful readings. For an more in-dept explanation you can browse a compendium of publications at: http://www.aeroelectric.com/articles/RF_PWR_Meter/ and in particular an article at: http://www.aeroelectric.com/articles/RF_PWR_Meter/Directional%20Coupler%20pa0nhc.pdf which describes a modification of instruments like yours that extends their useful range into VHF/UHF regions. Bob . . . ________________________________________________________________________________
Subject: SWR Meter
Date: Jan 21, 2012
I wouldn't use this type of SWR meter on anything north of 50 mHz. Find a ham or telco tech who used to work on microwave equipment to test your antenna. Such a person might also advise you on things like ground planes and antenna location. For certified aircraft the work should be signed off by a certified avionics shop. Noel -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: January 21, 2012 6:24 PM Subject: Re: AeroElectric-List: SWR Meter At 12:57 PM 1/21/2012, ROGER & JEAN CURTIS wrote: > I have a Vintage Sears SWR / FS meter which appears to be >the same as the Cal Com Model 9856. Can this be used to check the antenna >on aircraft nav com radios? If so, how do I set it up for use? > > Roger > This is no doubt an excellent example of a transmission line sampling reflectometer. Dozens of products of this genre' were manufactured and they are quite common. Bob . . . ________________________________________________________________________________
Subject: SWR Meter
Date: Jan 21, 2012
I forgot to say there was at least one Heathkit VHF SWR/FS meter on E-Bay a few minutes ago. Not the highest quality meter but it will put you in the ball park. Noel
December 28, 2011 - January 21, 2012
AeroElectric-Archive.digest.vol-ku
