AeroElectric-Archive.digest.vol-lj
September 22, 2012 - October 06, 2012
      >> On 20/09/2012 12:00 AM, Kelly McMullen wrote:
      >>> On the ACK E-04 it is 10 yrs on lithium main, remote and alarm
      >>> batteries. 5 yrs on remote alkaline if you go that route.
      >>> On 9/19/2012 3:34 PM, Ed Holyoke wrote:
      >>>> Don't forget the battery in the remote. It has an expiration of 8yrs,
      >>>> lithium or 4yrs, alkaline if I remember correctly. If you don't have a
      >>>> record of what battery was installed in the remote and when, you
      >>>> should replace it and record the due date in your logbook.
      >>>> Pax,
      >>>> Ed Holyoke
      >>>> A&P
      >>>> On 9/19/2012 1:39 PM, bob noffs wrote:
      >>>>> thanks all,
      >>>>> i did change the duracell batteries in my elt today. the elt mfgr
      >>>>> specifies duracell. the new set of d batteries have an expiration
      >>>>> date of 2022!. don't think i will wait 10 yrs.
      >>>>> bob noffs
      >>>>> On Wed, Sep 19, 2012 at 7:28 AM, Bill Watson >>>> > wrote:
      >>>>> My old ELT (10 years old) required new batteries every 24 months.
      >>>>> My new ACK 406Mh ELT specifies 5 years for the lithium batteries.
      >>>>> Bill
      >>>>> On 9/19/2012 7:47 AM, R. curtis wrote:
      >>>>>> starting on my first annual.
      >>>>>> do i remember correctly........the d batteries in the elt
      >>>>>> must be changed every year?
      >>>>>> thanks bob noffs
      >>>>>> Normally the manufacturer specifies that you use date
      >>>>>> coded alkaline batteries, and they are to be changed before
      >>>>>> the end of the coded period. They do not have to be changed
      >>>>>> each year.
      >>>>>> Roger
      > No virus found in this message.
      > Checked by AVG - www.avg.com
Subject: Misprint in Z-16, v.12/ OV with Rotax generators?
Date: Sep 22, 2012
Hello listers, Seems like there is a small misprint in Z16 v.12: the wire between the 5A breaker (or is it a fuse?) and the S1 switch should be 18AWG not 22AWG since its the same size as the fuse link. I was chatting to my favorite automotive mechanic the other day and telling him I was planning to include an alternator disconnect relay (as per Z16 or maybe Z17) in my electrical system. He said that he's never heard of a Ducati regulator going in over voltage, he says they usually just stop working. Does anyone know of anyone who's experienced an OV problem with the inbuilt Rotax generator? Another question: can anyone explain why the alternator disconnect wiring is more complex in Z16 than in Z17? What is the advantage of doing it the Z16 way? Sacha Rebuilding a Kitfox IV with Rotax 80hp, almost there Sicily, Italy ________________________________________________________________________________
From: Bob McCallum <robert.mccallum2(at)sympatico.ca>
Date: Sep 22, 2012
Actually the 22ga wire is perfectly adequate to trip the 5A breaker. The purpose of the fuse link is to protect the 18ga wire between the buss and the breaker should it inadvertently short to ground. So the drawing is correct as shown. The "normal" failure might be to "stop working" i.e. shut down, but what about the case of the one in a million "abnormal" failure where an OV occurs?? Not familiar with it happening, but it might, it is electronics after all ? Bob McC > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list- > server(at)matronics.com] On Behalf Of s > Sent: Saturday, September 22, 2012 5:53 PM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Misprint in Z-16, v.12/ OV with Rotax generators? > > > Hello listers, > > Seems like there is a small misprint in Z16 v.12: the wire between the 5A breaker (or > is it a fuse?) and the S1 switch should be 18AWG not 22AWG since its the same size as > the fuse link. > > I was chatting to my favorite automotive mechanic the other day and telling him I > was planning to include an alternator disconnect relay (as per Z16 or maybe Z17) in > my electrical system. He said that he's never heard of a Ducati regulator going in over > voltage, he says they usually just stop working. Does anyone know of anyone who's > experienced an OV problem with the inbuilt Rotax generator? > > Another question: can anyone explain why the alternator disconnect wiring is more > complex in Z16 than in Z17? What is the advantage of doing it the Z16 way? > > Sacha > Rebuilding a Kitfox IV with Rotax 80hp, almost there > Sicily, Italy > > _- > ==================================================== > ====== > _- > ==================================================== > ====== > _- > ==================================================== > ====== > _- > ==================================================== > ====== > > ________________________________________________________________________________
Subject: Re: Pitot tube slightly plugged...
Date: Sep 22, 2012
I flew one of those flights where you just KNEW we already had two strikes. And gosh I learned a lot. I took off from Furnace Creek into a rapidly approaching (astonishing!) black sandstorm. But the sandstorm quickly outran and engulfed us. Made a 180 out of the sandstorm to find I had no airspeed indicator. The winds were ferocious and making Santa Monica with fuel onboard was dicey, KWJF Fox Field (our normal fuel stop) was closed due to winds. So we stopped in Aqua Dulce...using the stall warning. We tried to clear the pitot tube with a coat-hangar wire but no dice. We had inadequate tools. Next day the mechanic cleared it. Analysis--Mud dauber wasp. Jeeeze....the thing you learn and shouldn't do again. But three points: Cover the pitot tube when parked--always. Unless you have one of those airspeed-operated flapper valves. A way of ram-rodding the tube would be a step forward in design. But the problem is usually only discovered after getting airborne. So glancing at the ASI during the takeoff run will be in my scan, even if Cessnas easily fly themselves off the ground. Some bug biologist-psychologist should invent a neat way to keep out dauber wasps. It would make a good science project. Mud daubers bring down heavy iron too. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=383801#383801 ________________________________________________________________________________
Date: Sep 22, 2012
Subject: pitot tube
Bob, I'm interested, but I'm unwilling to take on any more projects at this time. Maybe a couple of years down the road. When I decide to take on another project I'll drop you a note. Just a couple of quick questions How many amps at what voltage would be available and what would you imagine the overall dimensions to be? I'll keep my eyes out for stainless steel electrical properties and drop you a note if I see anything that might be useful. > So, perhaps there's an opportunity for somebody > out there with some metal working skills and > a curious nature. I'd be willing to stroke > the electronics if some one of you could acquire, > bend and weld alloys of steel that might make > good heaters cum pitot tube. > > It would be interesting to see if this ball > would at least bounce. Could we learn to "build > the better pitot tube" for MUCH less than > $600? -- Raymond Julian Kettle River, MN. "And you know that I could have me a million more friends, and all I'd have to lose is my point of view." - John Prine ________________________________________________________________________________
Date: Sep 22, 2012
Hi Eric Thx. for sharing your experience. You mentioned "Unless you have one of those airspeed-operated flapper valves". I owned a 1948 Cessna 170 ragwing for 19 years. Twice I got mud dapper nest in the Pitot tube. The second time it happened, the wind was howling and I noticed right after take off, so landed and cleared it. When putting tools away and a little worried the plane may roll in a pretty big gust (even though I had wheel chocks in place), I just happened to notice that the airspeed actuated flapper Pitot cover was fully opened, hmm. Then a few seconds later I observed a dapper wasp somehow manage in this wicked gusty wind to land on and crawl inside! I replaced flapper with a cover and never had another problem. Ron Parigoris ________________________________________________________________________________
Date: Sep 22, 2012
We have a bad problem with the mud daubers around here. If I leave an air tool outside for a day, they find it, and build in the inlet. Got me to thinking, Has anyone had problems with them building in static intake ports, fuel vents on gas caps, or the drains on collators. Starting to think my preflight should include all the above. Raymond Julian Kettle River, MN. "And you know that I could have me a million more friends, and all I'd have to lose is my point of view." - John Prine On 09/22/2012 07:13 PM, rparigor(at)suffolk.lib.ny.us wrote: > > Hi Eric > > Thx. for sharing your experience. > > You mentioned "Unless you have one of those airspeed-operated flapper > valves". > > I owned a 1948 Cessna 170 ragwing for 19 years. Twice I got mud dapper > nest in the Pitot tube. > > The second time it happened, the wind was howling and I noticed right > after take off, so landed and cleared it. When putting tools away and > a little worried the plane may roll in a pretty big gust (even though > I had wheel chocks in place), I just happened to notice that the > airspeed actuated flapper Pitot cover was fully opened, hmm. Then a > few seconds later I observed a dapper wasp somehow manage in this > wicked gusty wind to land on and crawl inside! > > I replaced flapper with a cover and never had another problem. > > Ron Parigoris > ________________________________________________________________________________
Date: Sep 22, 2012
On 9/22/2012 8:42 PM, rayj wrote: > Has anyone had problems with them building in static intake ports, > fuel vents on gas caps, or the drains on collators. Yes, multiple times I've had bugs build a nest in my fuel drains and vents. My cheap solution: Go to Walmart and buy a 100 pack of bright orange "fuzzy sticks" for $0.99. Used to be commonly known as "pipe cleaners". You can find them in the fabric and crafts section. http://www.walmart.com/ip/Kids-Craft-100pk-Fuzzy-Sticks-Neon/19525338 Cut off a 4 inch section. Fold in half, then on each leg halfway up fold outward. You end up with something shaped like this: _/\_ Stick the "V" end up in the hole in the fuel drain, gascolator, fuel vent, etc, with the legs sticking out to the side. Remove before flight, but in theory air would be able to pass if you accidentally left them in the fuel vent. Been doing this for a few years now and no more bug problem in the fuel drains. -Dj -- Dj Merrill - N1JOV Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Subject: Re: Misprint in Z-16, v.12/ OV with Rotax generators?
Date: Sep 23, 2012
Thanks Bob, I almost didn't mention it as I thought it was "obviously wrongh but now I'm glad I did as I learnt something! (Is there a detailed discussion of how each Z figure works somewhere that beginners can read?). Still wondering about the diff between the Z16 and Z17 alternator disconnect wiring. On 23/set/2012, at 00:50, Bob McCallum wrote: > > Actually the 22ga wire is perfectly adequate to trip the 5A breaker. The > purpose of the fuse link is to protect the 18ga wire between the buss and > the breaker should it inadvertently short to ground. So the drawing is > correct as shown. > The "normal" failure might be to "stop working" i.e. shut down, but what > about the case of the one in a million "abnormal" failure where an OV > occurs?? Not familiar with it happening, but it might, it is electronics > after all ? > > Bob McC > >> -----Original Message----- >> From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list- >> server(at)matronics.com] On Behalf Of s >> Sent: Saturday, September 22, 2012 5:53 PM >> To: aeroelectric-list(at)matronics.com >> Subject: AeroElectric-List: Misprint in Z-16, v.12/ OV with Rotax > generators? >> >> >> Hello listers, >> >> Seems like there is a small misprint in Z16 v.12: the wire between the 5A > breaker (or >> is it a fuse?) and the S1 switch should be 18AWG not 22AWG since its the > same size as >> the fuse link. >> >> I was chatting to my favorite automotive mechanic the other day and > telling him I >> was planning to include an alternator disconnect relay (as per Z16 or > maybe Z17) in >> my electrical system. He said that he's never heard of a Ducati regulator > going in over >> voltage, he says they usually just stop working. Does anyone know of > anyone who's >> experienced an OV problem with the inbuilt Rotax generator? >> >> Another question: can anyone explain why the alternator disconnect wiring > is more >> complex in Z16 than in Z17? What is the advantage of doing it the Z16 > way? >> >> Sacha >> Rebuilding a Kitfox IV with Rotax 80hp, almost there >> Sicily, Italy >> >> _- >> ==================================================== >> ====== >> _- >> ==================================================== >> ====== >> _- >> ==================================================== >> ====== >> _- >> ==================================================== >> ====== >> >> > > > > > > ________________________________________________________________________________
Subject: ACF-50 Anti-corrosion between block and alternator
mount...
Date: Sep 23, 2012
Michael, Since nobody has responded yet...I will offer my .02 It is my understanding that products like ACF-50 are used to prevent oxidation/corrosion from developing. If the part is already corroded, I would suggest removing the corrosion and then use the ACF-50 to prevent it from returning anytime soon. You may also look for a electrically conductive paste that will seal out the oxygen. There should be plenty of electrical pathway capacity through the mounting bolts regardless. Bevan -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Michael Burbidge Sent: Saturday, September 22, 2012 1:03 PM Subject: AeroElectric-List: ACF-50 Anti-corrosion between block and alternator mount... --> When I took the old alternator mount off the engine, I noticed there was some corrosion on the engine block under the alternator mount. My new alternator (B&C) gets its ground through the mount. Can I use and anti-corrosion film such as ACF-50 on the block before bolting the mount to the engine? Or will that place resistance in the ground path for the alternator? Thanks, Michael- ________________________________________________________________________________
Date: Sep 23, 2012
Not Ducati but I had a similar John Deere regulator for a 20 amp permanent magnet alternator fail full on. My fault as I started the engine with a dead battery. The voltage went high as the dead battery was not immediately ready to accept current which is not unusual for a fully discharged AGM battery. The regulator failed and thereafter let unregulated full alternator output through. The regulator failed even though the overvoltage disconnect relay was between the alternator and the regulator so the voltage must have risen faster than the relay could open when the engine started. I credit Bob's crowbar ovm for keeping the buss voltage clamped though and preventing any further damage. I guess the main point is that sometimes solid state devices can indeed fail ON instead of OFF. Ken On 22/09/2012 5:52 PM, s wrote: > --> AeroElectric-List message posted by: s > > Hello listers, > > Seems like there is a small misprint in Z16 v.12: the wire between > the 5A breaker (or is it a fuse?) and the S1 switch should be 18AWG > not 22AWG since its the same size as the fuse link. > > I was chatting to my favorite automotive mechanic the other day and > telling him I was planning to include an alternator disconnect relay > (as per Z16 or maybe Z17) in my electrical system. He said that he's > never heard of a Ducati regulator going in over voltage, he says they > usually just stop working. Does anyone know of anyone who's > experienced an OV problem with the inbuilt Rotax generator? > > Another question: can anyone explain why the alternator disconnect > wiring is more complex in Z16 than in Z17? What is the advantage of > doing it the Z16 way? > > Sacha Rebuilding a Kitfox IV with Rotax 80hp, almost there Sicily, > Italy > > ________________________________________________________________________________
Subject: Re: ACF-50 Anti-corrosion between block and alternator
mount...
Date: Sep 23, 2012
That's what I did. I cleaned off the corrosion and then put ACF-50 in between before bolting the new mount to the block. Sounds like that should be ok. Mike Sent from my iPhone On Sep 23, 2012, at 1:32 AM, "B Tomm" wrote: > > Michael, > > Since nobody has responded yet...I will offer my .02 > > It is my understanding that products like ACF-50 are used to prevent > oxidation/corrosion from developing. If the part is already corroded, I > would suggest removing the corrosion and then use the ACF-50 to prevent it > from returning anytime soon. You may also look for a electrically > conductive paste that will seal out the oxygen. There should be plenty of > electrical pathway capacity through the mounting bolts regardless. > > Bevan > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Michael > Burbidge > Sent: Saturday, September 22, 2012 1:03 PM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: ACF-50 Anti-corrosion between block and > alternator mount... > > --> > > When I took the old alternator mount off the engine, I noticed there was > some corrosion on the engine block under the alternator mount. My new > alternator (B&C) gets its ground through the mount. Can I use and > anti-corrosion film such as ACF-50 on the block before bolting the mount to > the engine? Or will that place resistance in the ground path for the > alternator? > > Thanks, > > Michael- > > > > > > > > ________________________________________________________________________________
Subject: Start Solenoid Orientation
Date: Sep 23, 2012
Group, I'm preparing some electrical hardware for my RV7 & this question came up: How should I orient the start solenoid, terminals up or down? I'm curious how G loading will affect the plunger. I'm planning to use this solenoid http://www.autopartswarehouse.com/sku/Standard/Starter_Solenoid/SISS581.html (a generic automotive type) because it is inexpensive & should be easily found in the future. In the picture at the above link, the solenoid appears "terminals down". Is that how it should be mounted in the airframe? In that orientation, any positive G loading will try to keep the contacts apart or open which is what I want. (don't want starter to inadvertently engage at the bottom of a hard pull). I think that the return spring in this device is pretty strong therefore it would take more than 6 Gs to get it to move but I thought I would pose the question to the group. Also, this solenoid has an "I" terminal which gets B+ when the solenoid is energized. (I think it is used to bypass an ignition ballast resistor in older cars) Does anyone have a schematic of the wiring inside this device? I'm curious how this "I" terminal is wired internally. ( I googled for about 20 minutes but could not find any info on this, which I though was odd ) So, I'm looking specifically for feedback on the following 2 questions: 1. applicability of this device for cranking a Lycoming 2. mounting orientation 3. internal schematic TIA, Jeff Luckey ________________________________________________________________________________
Date: Sep 23, 2012
mount... At 03:03 PM 9/22/2012, you wrote: When I took the old alternator mount off the engine, I noticed there was some corrosion on the engine block under the alternator mount. My new alternator (B&C) gets its ground through the mount. Can I use and anti-corrosion film such as ACF-50 on the block before bolting the mount to the engine? Or will that place resistance in the ground path for the alternator? The only way to you add resistance to the joint with such treatments is when the higher resistance contaminant is as hard or harder than base materials (alternator bracket and engine crankcase). For example, we've discussed the manner in which anti-corrosion dopes work in crimped terminals on aluminum wire. A wire grip and wire strands might appear to be full of dope but after the crimp, the PRESSURES applied to deform metal parts with intent to create gas-tight junctures is so much higher the compression strength of the 'contaminant' that it's extruded out of spaces where the metal hits the road. As you transition out of those metal upset spaces, the remaining dopant is squished out and remains in the voids becomes a barrier to moisture laden air. Back in my two-way-radio-days we used to pack coax cable connectors on tower joints with Dow Corning DC-4, a silicone grease the consistency of wheel-bearing grease. The connectors were then wrapped with 3+ layers of plastic tape (which would only stick to itself due to slickness of the coax and connectors underneath!), Such joints opened years later might have the tape nearly falling off due to UV and weather effects but the joints inside were as-new pristine. Suitable dopant used on the brightly cleaned and ready to mate surfaces of your alternator bracket and engine is incapable of raising joint resistance where adequate metal-to-metal contact and pressures are achieved. Remnants of the dopant not extruded out of the joint remain in non-contact areas and provide the desired barrier for ingress of moisture. There's a host of suitable materials. Electronic grade RTV (no corrosive type) comes to mind as a material with high operating temperatures but soft enough not to 'glue' things together. Chemical conversion coatings will only protect a surface and have no ability to fill gaps and preclude moisture incursion. You use those chemical conversion before assembly then use gap-filing dopants on top of that for the golden joint. Bob . . . ________________________________________________________________________________
Date: Sep 23, 2012
Subject: Re: What crimper to use for B&C alternator field
terminals... At 03:06 PM 9/22/2012, you wrote: > >Does anyone know what kind of crimper I use for the terminals used >on the field wire for the B&C alternators? Does one of the crimpers >from B&C work? Which one? > >Thanks, >Michael- Those are b-crimp terminals http://tinyurl.com/8j73sbp http://tinyurl.com/8hf6mo9 applied with a tool like the one shown from B&C I discovered this tool on eBay which appears to be the right one but there's not enough details in the ad to be sure. http://tinyurl.com/8hn8vxe I've ordered one for evaluation and will report my findings here on the List. Bob . . . ________________________________________________________________________________
Date: Sep 23, 2012
Subject: Re: Why did this AMP crimp on connection get singed
and fail? At 04:08 PM 9/22/2012, you wrote: > >Bill, > >Search "switches with faston tabs" in the AeroElectric archives. >They discuss the discoloration of the faston insulation as the >result of switch failure. Time frame of sept 08. Yes . . . there was a 'rash' of failures manifesting in 'smoked joints' that started with loose rivets on the Carling switches. This prompted a lot of discussion and failure-analysis/tear-downs back about that time. Something to keep in mind as folks are unhappily blessed with such events. Look for a the loci of failure . . . sorta like a arson investigation. See which parts got hottest. These usually point to the area off poor connection where the degradation of the joints began. Several examples of over-heating in poor conduction areas are explored here: http://tinyurl.com/8d63v8x http://tinyurl.com/8zzkfbb http://tinyurl.com/8zzkfbb Whether bolting alternator brackets to crank-cases or keeping all the connections tight through a switch, the path to failure is the same. Increase in resistance increases heating and VOLTAGE DROP across a joint These two antagonists team up regeneratively to damage and perhaps fail the joint. Bob . . . ________________________________________________________________________________
Date: Sep 23, 2012
Subject: Re: pitot tube
At 06:58 PM 9/22/2012, you wrote: > >Bob, > > I'm interested, but I'm unwilling to take on any more projects > at this time. Maybe a couple of years down the road. When I > decide to take on another project I'll drop you a note. > >Just a couple of quick questions How many amps at what voltage would >be available and what would you imagine the overall dimensions to be? > >I'll keep my eyes out for stainless steel electrical properties and >drop you a note if I see anything that might be useful. Good. I've got about 100 back-burner projects, some of which get tid-bits of useful information added from time to time. It's that expansion of situational awareness that contributes to understanding of the whole . . . holler if you get either inspired or motivated . . . and thanks for the offer. Bob . . . ________________________________________________________________________________
Date: Sep 23, 2012
> >Stick the "V" end up in the hole in the fuel drain, gascolator, fuel >vent, etc, with the legs sticking out to the side. > >Remove before flight, but in theory air would be able to pass if you >accidentally left them in the fuel vent. > >Been doing this for a few years now and no more bug problem in the >fuel drains. An elegant solution Dj . . . how about some photos of these critters in place. Let's do a little one-pager for the AEC website archives. Bob . . . ________________________________________________________________________________
Date: Sep 23, 2012
mount... At 03:32 AM 9/23/2012, you wrote: > >Michael, > >Since nobody has responded yet...I will offer my .02 > >It is my understanding that products like ACF-50 are used to prevent >oxidation/corrosion from developing. If the part is already corroded, I >would suggest removing the corrosion and then use the ACF-50 to prevent it >from returning anytime soon. You may also look for a electrically >conductive paste that will seal out the oxygen. There should be plenty of >electrical pathway capacity through the mounting bolts regardless. > >Bevan Bingo! You get the gold star for this topic my friend. The paste or "dopant" need not be conductive for reasons I cited in the other posting. But their function is necessary to joint longevity and goes beyond repairs and protection of surfaces. Chemical treatment thicknesses are measured in diameters of molecules. Gap fillers have a much larger and equally important role to play . . . Bob . . . ________________________________________________________________________________
Date: Sep 23, 2012
Subject: Re: Start Solenoid Orientation
At 12:02 PM 9/23/2012, you wrote: Group, I'm preparing some electrical hardware for my RV7 & this question came up: How should I orient the start solenoid, terminals up or down? I'm curious how G loading will affect the plunger. I'm planning to use this solenoid http://www.autopartswarehouse.com/sku/Standard/Starter_Solenoid/SISS581.html (a generic automotive type) because it is inexpensive & should be easily found in the future. In the picture at the above link, the solenoid appears "terminals down". Is that how it should be mounted in the airframe? In that orientation, any positive G loading will try to keep the contacts apart or open which is what I want. (don't want starter to inadvertently engage at the bottom of a hard pull). I think that the return spring in this device is pretty strong therefore it would take more than 6 Gs to get it to move but I thought I would pose the question to the group. Exactly. The g-load closing of starter contactors is one of those hanagar myths that has been around for a very long time . . . and repeated often enough it morphs into fact. That contactor mounted on the firewall orients the the terminals forward. A study of these pieces and parts http://tinyurl.com/96wy5mq shows that the contact bar is pushed against the insulated lid which retains the terminals. G-forces tending to close the contacts in this orientation would be achieved only if you flew into a mountainside. When oriented on a horizontal surface, you'd have to be in a wing-stripping push-over to close the contacts. I was working the B&C booth at OSH when one of the air-show famous showed up to buy a new starter and a starter contactor. After completing a performance it was discovered that his starter ring gear was trashed and the pinion on the starter damaged. The starter contactor was "stuck shut" which common wisdom of excited moment suggest was victim of daring-do g-loads. I didn't get to see the as-installed carcasses nor were we asked to do autopsies on the damaged parts. After some reflection in following months I concluded that he most likely suffered a stuck contactor at engine start up. But given the cockpit noise of these hi-performance machines and attention to upcoming demands on pilotage, the event went unnoticed. He probably flew his routine with a starter engaged and running. Also, this solenoid has an "I" terminal which gets B+ when the solenoid is energized. (I think it is used to bypass an ignition ballast resistor in older cars) Does anyone have a schematic of the wiring inside this device? I'm curious how this "I" terminal is wired internally. ( I googled for about 20 minutes but could not find any info on this, which I though was odd ) You're correct. This feature isn't used in cars with electronic ignition but would still be useful on a '57 Chevy. Few cognizant enthusiasts today are even aware of this feature or its significance. There are two popular form factors for this contactor. http://tinyurl.com/8my46tv There's a number of I-terminal references in this document http://tinyurl.com/9looejm So, I'm looking specifically for feedback on the following 2 questions: applicability of this device for cranking a Lycoming Works good, lasts a long time mounting orientation Doesn't really matter much but you'd have to go out of your way to mount it such that flight g-loads tended to close contacts. This is unlike popular starter contactors of yesteryear http://tinyurl.com/8fwygp4 which featured large area, low pressure contacts and massive solenoid armatures. Even in the "continuous duty" versions were not well suited to high-inrush duty of spinning up cranking motors. That's the best we had in 1960 but have not been seen in that service for many decades. But even these parts are exceedingly unlike to get closed under g-loads of flight. Now, there WAS a good reason for mounting them upside down on the firewall but that was for moisture reasons . . . that's another story of a CFD and hat-dance carried out at the Cessna Single Engine facility about 1980. internal schematic See figure 11-21 in the 'Connection. Functionally accurate. The "I" terminal in modern incarnations of a starter contactor is bridged in one stroke with the main terminals of the device. In this picture http://tinyurl.com/96wy5mq the "thin and light moving contacts" are propped up on a spring strut at right angles to the main current pathway. The end of this strut contacts the "I" terminal simultaneously with closure of the main terminals. Bob . . . ________________________________________________________________________________
Date: Sep 23, 2012
At 11:18 PM 9/22/2012, you wrote: Thanks Bob, I almost didn't mention it as I thought it was "obviously wrongh but now I'm glad I did as I learnt something! (Is there a detailed discussion of how each Z figure works somewhere that beginners can read?). Still wondering about the diff between the Z16 and Z17 alternator disconnect wiring. Just variations on a theme. Primary design goal is to achieve absolute control over energy from the alternator as seen by the rest of the airplane. Opening the DC pathway out of the rectifier-regulator does that. Opening the AC power into the regulator does too. AC is generally easier to control than DC for considerations of contact arcing. But given the low duty cycle of stressful events in these systems, either will do fine and last a long time. As Ken noted, the RR can be placed at risk for high rpm ops without having the battery connected. So while the control schemes presented in Z-16/17 are golden for the rest of the airplane, Z-17 carries the protection further back toward the alternator and would perhaps have saved Ken's RR from untimely demise due to the unloaded condition. I've not taken the time to really thrash through the physics of a PM regulator. Seems it SHOULD be designed to handle worst case failures including unloaded operations. It can probably be done but Z-17 is a work-around until the golden PM rectifier regulator comes along. Bob . . . ________________________________________________________________________________
Subject: Yesterday's Project - Show & Tell
Date: Sep 23, 2012
How about a little show-and-tell. I'm not sure that the embedded picture will come thru, (if it does not, I will re-post) Picture of a panel of containing a master solenoid, start solenoid, shunt, shunt fuses & ANL current limiter for the engine battery in my RV-7. Design Goals: 1. as compact as practical ( the mounting plate dimensions are 6" wide x 5.5" tall) 2. easy to install - (mounts to airframe w/ 4 screws) 3. easy to work on (all of the interconnections were made while sitting at my workbench as opposed to working in-position on the airframe) 4. easy to maintain (all fastenings are tapped into the base-plate thus not requiring access to the back of the panel after installation for maintenance) Mounting: To be mounted <~12" from the battery on the firewall Exercise for the reader: See if you can identify input & all outputs Any & all questions, comments, & constructive criticisms welcome. Jeff Luckey ________________________________________________________________________________
Date: Sep 23, 2012
Thanks Bob for your usual thorough mini-dissertation (I don't know how you find the time to deliver such thoughtful answers to the group but it is much appreciated! - If you are ever in Southern California, the cervezas are on me) -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Sunday, September 23, 2012 13:28 Subject: Re: AeroElectric-List: Start Solenoid Orientation At 12:02 PM 9/23/2012, you wrote: Group, I'm preparing some electrical hardware for my RV7 & this question came up: How should I orient the start solenoid, terminals up or down? I'm curious how G loading will affect the plunger. I'm planning to use this solenoid http://www.autopartswarehouse.com/sku/Standard/Starter_Solenoid/SISS581.html (a generic automotive type) because it is inexpensive & should be easily found in the future. In the picture at the above link, the solenoid appears "terminals down". Is that how it should be mounted in the airframe? In that orientation, any positive G loading will try to keep the contacts apart or open which is what I want. (don't want starter to inadvertently engage at the bottom of a hard pull). I think that the return spring in this device is pretty strong therefore it would take more than 6 Gs to get it to move but I thought I would pose the question to the group. Exactly. The g-load closing of starter contactors is one of those hanagar myths that has been around for a very long time . . . and repeated often enough it morphs into fact. That contactor mounted on the firewall orients the the terminals forward. A study of these pieces and parts http://tinyurl.com/96wy5mq shows that the contact bar is pushed against the insulated lid which retains the terminals. G-forces tending to close the contacts in this orientation would be achieved only if you flew into a mountainside. When oriented on a horizontal surface, you'd have to be in a wing-stripping push-over to close the contacts. I was working the B&C booth at OSH when one of the air-show famous showed up to buy a new starter and a starter contactor. After completing a performance it was discovered that his starter ring gear was trashed and the pinion on the starter damaged. The starter contactor was "stuck shut" which common wisdom of excited moment suggest was victim of daring-do g-loads. I didn't get to see the as-installed carcasses nor were we asked to do autopsies on the damaged parts. After some reflection in following months I concluded that he most likely suffered a stuck contactor at engine start up. But given the cockpit noise of these hi-performance machines and attention to upcoming demands on pilotage, the event went unnoticed. He probably flew his routine with a starter engaged and running. Also, this solenoid has an "I" terminal which gets B+ when the solenoid is energized. (I think it is used to bypass an ignition ballast resistor in older cars) Does anyone have a schematic of the wiring inside this device? I'm curious how this "I" terminal is wired internally. ( I googled for about 20 minutes but could not find any info on this, which I though was odd ) You're correct. This feature isn't used in cars with electronic ignition but would still be useful on a '57 Chevy. Few cognizant enthusiasts today are even aware of this feature or its significance. There are two popular form factors for this contactor. http://tinyurl.com/8my46tv There's a number of I-terminal references in this document http://tinyurl.com/9looejm So, I'm looking specifically for feedback on the following 2 questions: applicability of this device for cranking a Lycoming Works good, lasts a long time mounting orientation Doesn't really matter much but you'd have to go out of your way to mount it such that flight g-loads tended to close contacts. This is unlike popular starter contactors of yesteryear http://tinyurl.com/8fwygp4 which featured large area, low pressure contacts and massive solenoid armatures. Even in the "continuous duty" versions were not well suited to high-inrush duty of spinning up cranking motors. That's the best we had in 1960 but have not been seen in that service for many decades. But even these parts are exceedingly unlike to get closed under g-loads of flight. Now, there WAS a good reason for mounting them upside down on the firewall but that was for moisture reasons . . . that's another story of a CFD and hat-dance carried out at the Cessna Single Engine facility about 1980. internal schematic See figure 11-21 in the 'Connection. Functionally accurate. The "I" terminal in modern incarnations of a starter contactor is bridged in one stroke with the main terminals of the device. In this picture http://tinyurl.com/96wy5mq the "thin and light moving contacts" are propped up on a spring strut at right angles to the main current pathway. The end of this strut contacts the "I" terminal simultaneously with closure of the main terminals. Bob . . . ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Sep 23, 2012
On 9/23/2012 2:07 PM, Robert L. Nuckolls, III wrote: > > An elegant solution Dj . . . how about some photos > of these critters in place. Let's do a little one-pager > for the AEC website archives. > Hi Bob, I did a quick little write-up on my website at: http://deej.net/aviation/bug-plug/ Feel free to use the pictures and info on that page if you want to put something up on the AEC site. -Dj -- Dj Merrill - N1JOV Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Date: Sep 23, 2012
Can you convert the document to PDF format so it can be easily saved Thanks, Dick In a message dated 9/23/2012 7:11:01 P.M. Central Daylight Time, deej(at)deej.net writes: --> AeroElectric-List message posted by: Dj Merrill On 9/23/2012 2:07 PM, Robert L. Nuckolls, III wrote: > > An elegant solution Dj . . . how about some photos > of these critters in place. Let's do a little one-pager > for the AEC website archives. > Hi Bob, I did a quick little write-up on my website at: http://deej.net/aviation/bug-plug/ Feel free to use the pictures and info on that page if you want to put something up on the AEC site. -Dj -- Dj Merrill - N1JOV Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Date: Sep 24, 2012
I have Firefox, and am not sure how to do it with other browsers, but it allows me to download and save the page directly as it is in two steps. First, when on the page, select "File" then "Save Page As...", and select the location where you want to put it. It will sutomatically save the text and html code as an htm file. Second step, go back to the online page, select ANY image, RIGHT click on it and select "Download All Images". Firefox will pick the folder that you last saved to by default, which is probably the one where you put the htm file, and download all the images there as well. To view it, simply click on the htm file on your computer and it will load offline in your browser just as the original page did. Harley ----------------------------------------------------------------- On 9/23/2012 8:40 PM, RGent1224(at)aol.com wrote: > Can you convert the document to PDF format so it can be easily > saved > Thanks, > Dick > In a message dated 9/23/2012 7:11:01 P.M. Central Daylight > Time, deej(at)deej.net writes: > > > > On 9/23/2012 2:07 PM, Robert L. Nuckolls, III wrote: > > > > An elegant solution Dj . . . how about some photos > > of these critters in place. Let's do a little one-pager > > for the AEC website archives. > > > > Hi Bob, > I did a quick little write-up on my website at: > > http://deej.net/aviation/bug-plug/ > > Feel free to use the pictures and info on that page if > you want to > put something up on the AEC site. > > -Dj > > -- > Dj Merrill - N1JOV > Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ > Glastar Flyer N866RH - = Use ilities ay - > MATRONICS WEB FORUMS - List Contribution Web > Site p; > > > * > > > * > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > Date: 09/23/12 > ________________________________________________________________________________
Date: Sep 24, 2012
Mud dauber wasps are the bane of small holes everywhere. I want to suggest that an enterprising individual do the following long-term experiment (Actually, you might try searching the USPTO first): Let's see what attracts mud dauber wasps. Do many experiments with enough time to allow the wasps to build nests (and taking the weather into account.): 1) Drill a grid of different size holes in a board. Mount the board in a location know for having a known problem with the wasps. Do the WMDs (Wasps, Mud Dauber) prefer a hole size? Log the result. 2) Repeat with a spectrum of different colors. Do the WMDs prefer a color? How about in the UV? Log the result. 3) Repeat with various contrasting patterns around the holes (e.g. starburst, concentric circles, snowflake, spirals, flower petals, angry jagged shapes...whatever you can think of). Log the result. 4) Put a colored LED behind a series of the same size holes. Log the result. 5) Put a blinking LED behind a series of the same size holes. Try various colors. Log the result. 6) Keep going until you find a solution. 7) Patent it. "Method of Preventing Aircraft Pitot Tube Obstruction by Mud Dauber Wasp." 8) Pick up your Nobel prize in Stockholm. 9) Your MacArthur Genius Prize will be waiting when you return home. Okay, perhaps that is going too far. But the airlines and pitot tube makers would be very happy to pay for any workable results. Remember, every jet engine you see has that curly snake on the nose cone. This reliably prevents birds from nesting in the inlet. A bird will never come near anything that (in its tiny bird brain) might possibly be a snake. I put a rubber snake on my rear deck which absolutely keeps bird and their mess away. The goal is to find something in the WMDs brain that works similarly. There are myriad odd insect habits. Perhaps they won't ever come near a yellow pitot probe, or one with UV-bright flower petals or a blinking LED...nobody knows. Several solutions might be possible. This would be a great science project, even for a whole classroom. Good luck, and tell us what happens. Addendum: See my website for a pitot tube of interest: http://www.periheliondesign.com/downloads/thermopitot.pdf -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=383883#383883 ________________________________________________________________________________
Date: Sep 24, 2012
Very interesting idea, Eric! As a start to whoever wants to attempt this, I had several two foot long pieces of 3/16 inch shrink tubing hanging from a shelf in my garage. The daubers plugged up the black tubing, but NOT the yellow, white or red! Not very definitive, but all the openings were hanging in the same location, bunched together. The black looked like it had several years of nests in it, going a couple of inches up the tubing on both ends, but the others were absolutely clear. Harley ----------------------------------------------------------------- On 9/24/2012 9:23 AM, Eric M. Jones wrote: > > Mud dauber wasps are the bane of small holes everywhere. I want to suggest that an enterprising individual do the following long-term experiment (Actually, you might try searching the USPTO first): > > Let's see what attracts mud dauber wasps. Do many experiments with enough time to allow the wasps to build nests (and taking the weather into account.): > > 1) Drill a grid of different size holes in a board. Mount the board in a location know for having a known problem with the wasps. Do the WMDs (Wasps, Mud Dauber) prefer a hole size? Log the result. > 2) Repeat with a spectrum of different colors. Do the WMDs prefer a color? How about in the UV? Log the result. > 3) Repeat with various contrasting patterns around the holes (e.g. starburst, concentric circles, snowflake, spirals, flower petals, angry jagged shapes...whatever you can think of). Log the result. > 4) Put a colored LED behind a series of the same size holes. Log the result. > 5) Put a blinking LED behind a series of the same size holes. Try various colors. Log the result. > 6) Keep going until you find a solution. > 7) Patent it. "Method of Preventing Aircraft Pitot Tube Obstruction by Mud Dauber Wasp." > 8) Pick up your Nobel prize in Stockholm. > 9) Your MacArthur Genius Prize will be waiting when you return home. > > Okay, perhaps that is going too far. But the airlines and pitot tube makers would be very happy to pay for any workable results. Remember, every jet engine you see has that curly snake on the nose cone. This reliably prevents birds from nesting in the inlet. A bird will never come near anything that (in its tiny bird brain) might possibly be a snake. I put a rubber snake on my rear deck which absolutely keeps bird and their mess away. > > The goal is to find something in the WMDs brain that works similarly. There are myriad odd insect habits. Perhaps they won't ever come near a yellow pitot probe, or one with UV-bright flower petals or a blinking LED...nobody knows. Several solutions might be possible. > > This would be a great science project, even for a whole classroom. > > Good luck, and tell us what happens. > > Addendum: See my website for a pitot tube of interest: > http://www.periheliondesign.com/downloads/thermopitot.pdf > > -------- > Eric M. Jones > www.PerihelionDesign.com > 113 Brentwood Drive > Southbridge, MA 01550 > (508) 764-2072 > emjones(at)charter.net > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=383883#383883 > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Sep 24, 2012
Similar here. They like the black but not the clear transparent tubing. Ken On 24/09/2012 9:33 AM, Harley wrote: > Very interesting idea, Eric! As a start to whoever wants to attempt > this, I had several two foot long pieces of 3/16 inch shrink tubing > hanging from a shelf in my garage. The daubers plugged up the black > tubing, but NOT the yellow, white or red! Not very definitive, but all > the openings were hanging in the same location, bunched together. The > black looked like it had several years of nests in it, going a couple of > inches up the tubing on both ends, but the others were absolutely clear. > > Harley > ------------------------------------------------------------------------ > On 9/24/2012 9:23 AM, Eric M. Jones wrote: >> --> AeroElectric-List message posted by: "Eric M. Jones" >> >> Mud dauber wasps are the bane of small holes everywhere. I want to suggest that an enterprising individual do the following long-term experiment (Actually, you might try searching the USPTO first): >> >> Let's see what attracts mud dauber wasps. Do many experiments with enough time to allow the wasps to build nests (and taking the weather into account.): >> >> 1) Drill a grid of different size holes in a board. Mount the board in a location know for having a known problem with the wasps. Do the WMDs (Wasps, Mud Dauber) prefer a hole size? Log the result. >> 2) Repeat with a spectrum of different colors. Do the WMDs prefer a color? How about in the UV? Log the result. >> 3) Repeat with various contrasting patterns around the holes (e.g. starburst, concentric circles, snowflake, spirals, flower petals, angry jagged shapes...whatever you can think of). Log the result. >> 4) Put a colored LED behind a series of the same size holes. Log the result. >> 5) Put a blinking LED behind a series of the same size holes. Try various colors. Log the result. >> 6) Keep going until you find a solution. >> 7) Patent it. "Method of Preventing Aircraft Pitot Tube Obstruction by Mud Dauber Wasp." >> 8) Pick up your Nobel prize in Stockholm. >> 9) Your MacArthur Genius Prize will be waiting when you return home. >> >> Okay, perhaps that is going too far. But the airlines and pitot tube makers would be very happy to pay for any workable results. Remember, every jet engine you see has that curly snake on the nose cone. This reliably prevents birds from nesting in the inlet. A bird will never come near anything that (in its tiny bird brain) might possibly be a snake. I put a rubber snake on my rear deck which absolutely keeps bird and their mess away. >> >> The goal is to find something in the WMDs brain that works similarly. There are myriad odd insect habits. Perhaps they won't ever come near a yellow pitot probe, or one with UV-bright flower petals or a blinking LED...nobody knows. Several solutions might be possible. >> >> This would be a great science project, even for a whole classroom. >> >> Good luck, and tell us what happens. >> >> Addendum: See my website for a pitot tube of interest: >> http://www.periheliondesign.com/downloads/thermopitot.pdf >> >> -------- >> Eric M. Jones >> www.PerihelionDesign.com >> 113 Brentwood Drive >> Southbridge, MA 01550 >> (508) 764-2072 >> emjones(at)charter.net >> > ________________________________________________________________________________
Subject: Looking to Buy a Stein Air Large Terminal Crimping
Tool
Date: Sep 24, 2012
Stein Air used to sell a crimping/swaging tool for #2, 4, and 6 AWG terminals, product ID was TERMTOOL. I guess they're no longer able to get them. If someone is done with theirs and would like to sell it I can promise it a good home. Dan Jones warbirds(at)shaw.ca Read this topic online here: http://forums.matronics.com/viewtopic.php?p=383893#383893 ________________________________________________________________________________
Date: Sep 24, 2012
Bob/Ken/Bob, Thanks a lot for your replies. BobMc> what about the case of the one in a million "abnormal" failure where an OV occurs? You're right... I have to keep reminding myself it's not how unlikely the event is that counts, it's how bad the consequences could be (vs how easy it is to design a redundant system to avoid those bad consequences... In this case it's easy so should be done). Ken> The regulator failed even though the overvoltage disconnect relay was between the Ken> alternator and the regulator so the voltage must have risen faster than the relay Ken> could open when the engine started. I credit Bob's crowbar ovm for keeping the buss Ken> voltage clamped though and preventing any further damage. I'm not clear to me how the OVM could have achieved that. I thought the way the OVM module works is that it grounds the number 4 pole in the S1 switch in Z16/Z17 and therefore causes the breaker to open and disconnects the OV relay. BobN> I've not taken the time to really thrash through BobN> the physics of a PM regulator. Seems it SHOULD BobN> be designed to handle worst case failures including BobN> unloaded operations. It can probably be done but BobN> Z-17 is a work-around until the golden PM rectifier BobN> regulator comes along. I think you mean Z-16 is golden... Z-17 is the simplified version. I would also be interested in how the RR as well as the permanent magnet generator in the Rotax works. I'll dig around... Thanks again! Sacha -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: domenica 23 settembre 2012 22:37 Subject: Re: AeroElectric-List: Misprint in Z-16, v.12/ OV with Rotax generators? --> At 11:18 PM 9/22/2012, you wrote: Thanks Bob, I almost didn't mention it as I thought it was "obviously wrongh but now I'm glad I did as I learnt something! (Is there a detailed discussion of how each Z figure works somewhere that beginners can read?). Still wondering about the diff between the Z16 and Z17 alternator disconnect wiring. Just variations on a theme. Primary design goal is to achieve absolute control over energy from the alternator as seen by the rest of the airplane. Opening the DC pathway out of the rectifier-regulator does that. Opening the AC power into the regulator does too. AC is generally easier to control than DC for considerations of contact arcing. But given the low duty cycle of stressful events in these systems, either will do fine and last a long time. As Ken noted, the RR can be placed at risk for high rpm ops without having the battery connected. So while the control schemes presented in Z-16/17 are golden for the rest of the airplane, Z-17 carries the protection further back toward the alternator and would perhaps have saved Ken's RR from untimely demise due to the unloaded condition. I've not taken the time to really thrash through the physics of a PM regulator. Seems it SHOULD be designed to handle worst case failures including unloaded operations. It can probably be done but Z-17 is a work-around until the golden PM rectifier regulator comes along. I think you mean Z-16 is golden... Z-17 is the simplified version. Bob . . . ________________________________________________________________________________
Date: Sep 24, 2012
Subject: Re: Yesterday's Project - Show & Tell
Very nice. Easy to fashion a cover for as well, if you're so inclined. Also really handy for an aeroplane with a wooden firewall, as it reduces the number of firewall bolts. Makes me wonder why I didn't think of doing the same thing! James On 23 September 2012 22:45, Jeff Luckey wrote: > ** ** > > How about a little show-and-tell I=99m not sure that the embedded picture > will come thru, (if it does not, I will re-post)**** > > ** ** > > Picture of a panel of containing a master solenoid, start solenoid, shunt , > shunt fuses & ANL current limiter for the engine battery in my RV-7.**** > > ** ** > > Design Goals:**** > > ** ** > > 1. as compact as practical ( the mounting plate dimensions are 6 =9D wide > x 5.5=9D tall)**** > 2. easy to install =93 (mounts to airframe w/ 4 screws)**** > 3. easy to work on (all of the interconnections were made while > sitting at my workbench as opposed to working in-position on the airfr ame) > **** > 4. easy to maintain (all fastenings are tapped into the base-plate > thus not requiring access to the back of the panel after installation for > maintenance) **** > > ** ** > > ** ** > > Mounting:**** > > ** ** > > To be mounted <~12=9D from the battery on the firewall**** > > ** ** > > ** ** > > Exercise for the reader:**** > > ** ** > > See if you can identify input & all outputs**** > > ** ** > > ** ** > > Any & all questions, comments, & constructive criticisms welcome **** > > ** ** > > ** ** > > **** > > ** ** > > ** ** > > Jeff Luckey**** > > ** ** > ________________________________________________________________________________
Date: Sep 24, 2012
Hi Sacha I might be a bit optimistic with that comment. My thoughts are that when my OVM activates it immediately shorts out the relay but it is still connected to the buss and is clamping the buss voltage until the circuit breaker pops. So you are correct that with a slow opening relay and a fast acting CB there could be a few milliseconds delay during which time the voltage will be rising again. Probably shouldn't mention it since I can't claim they are significant but I also have a few TVS diodes on the buss. Since they are fast acting and cheap they seemed like a good idea (several years ago) with an electrically dependent engine. Ken On 24/09/2012 11:01 AM, s wrote: > --> AeroElectric-List message posted by: "s" > > Bob/Ken/Bob, > > Thanks a lot for your replies. > > BobMc> what about the case of the one in a million "abnormal" failure > where an OV occurs? > > You're right... I have to keep reminding myself it's not how unlikely the > event is that counts, it's how bad the consequences could be (vs how easy it > is to design a redundant system to avoid those bad consequences... In this > case it's easy so should be done). > > Ken> The regulator failed even though the overvoltage disconnect relay was > between the > Ken> alternator and the regulator so the voltage must have risen faster than > the relay > Ken> could open when the engine started. I credit Bob's crowbar ovm for > keeping the buss > Ken> voltage clamped though and preventing any further damage. > > I'm not clear to me how the OVM could have achieved that. I thought the way > the OVM module works is that it grounds the number 4 pole in the S1 switch > in Z16/Z17 and therefore causes the breaker to open and disconnects the OV > relay. > > BobN> I've not taken the time to really thrash through > BobN> the physics of a PM regulator. Seems it SHOULD > BobN> be designed to handle worst case failures including > BobN> unloaded operations. It can probably be done but > BobN> Z-17 is a work-around until the golden PM rectifier > BobN> regulator comes along. > > I think you mean Z-16 is golden... Z-17 is the simplified version. > > I would also be interested in how the RR as well as the permanent magnet > generator in the Rotax works. I'll dig around... Thanks again! > > Sacha > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. > Nuckolls, III > Sent: domenica 23 settembre 2012 22:37 > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Misprint in Z-16, v.12/ OV with Rotax > generators? > > --> AeroElectric-List message posted by: "Robert L. Nuckolls, III" > --> > > > At 11:18 PM 9/22/2012, you wrote: > --> AeroElectric-List message posted by: U > > Thanks Bob, > I almost didn't mention it as I thought it was "obviously wrongh but now > I'm glad I did as I learnt something! (Is there a detailed discussion of > how each Z figure works somewhere that beginners can read?). Still wondering > about the diff between the Z16 and Z17 alternator disconnect wiring. > > Just variations on a theme. Primary design > goal is to achieve absolute control over energy > from the alternator as seen by the rest of the > airplane. Opening the DC pathway out of the > rectifier-regulator does that. Opening the AC > power into the regulator does too. > > AC is generally easier to control than DC for > considerations of contact arcing. But given > the low duty cycle of stressful events in these > systems, either will do fine and last a long > time. > > As Ken noted, the RR can be placed at risk for > high rpm ops without having the battery connected. > So while the control schemes presented in Z-16/17 > are golden for the rest of the airplane, Z-17 > carries the protection further back toward the > alternator and would perhaps have saved Ken's > RR from untimely demise due to the unloaded > condition. > > I've not taken the time to really thrash through > the physics of a PM regulator. Seems it SHOULD > be designed to handle worst case failures including > unloaded operations. It can probably be done but > Z-17 is a work-around until the golden PM rectifier > regulator comes along. > > I think you mean Z-16 is golden... Z-17 is the simplified version. > > Bob . . . > > ________________________________________________________________________________
Date: Sep 24, 2012
At 12:28 PM 9/24/2012, you wrote: Hi Sacha I might be a bit optimistic with that comment. My thoughts are that when my OVM activates it immediately shorts out the relay but it is still connected to the buss and is clamping the buss voltage until the circuit breaker pops. Actually, it's a healthy battery that "clamps the bus". During OVM reaction time the alternator goes into max v current limited output with the ship's accessories taking part of the load and the battery working to soak up the rest. Once the OVM trips, the current draw on the bus WILL go up to 50+ amps . . . so I suppose there's some additional clamping going on. A 5A breaker with typical OVM loads opens in 15 to 50 milliseconds so it's all over in a blink of an eye. So you are correct that with a slow opening relay and a fast acting CB there could be a few milliseconds delay during which time the voltage will be rising again. Relay, cb and ovm timing 'races' don't figure into system functionality at all. Your electro-whizzies manufactured to DO-160 design goals will stand off 20 volts for 1 second. The battery will keep bus volts down to 17 volts or so. This give the OVM and associated components all the time in the world to do their intended job. Probably shouldn't mention it since I can't claim they are significant but I also have a few TVS diodes on the buss. Since they are fast acting and cheap they seemed like a good idea (several years ago) with an electrically dependent engine. They don't hurt a thing . . . don't do anything useful either. The TVS is designed to mitigate low energy, fast rise, high voltage transients that do not exist on your ship's DC bus . . . and again, devices built to DO-160 intent are designed to stand off the classic 'transient spike test'. Years ago I spent a fist full of the boss's money for my man Cecil to build a test fixture required for GENERATION of the DO-160 test spikes. Cool gadget. When we got it finished and calibrated, I began to explore vulnerability for my favorite bus power conditioning circuits. I was astounded to find that when the device under test had a simple capacitor of 1uF or more across the incoming line . . . Cecil's Evil Spike Thrower couldn't put a spear past it. From that time onward, the fixture was never again pulled down from the shelf . . . 'cause all our products already featured the necessary capacitor. Had I endeavored to analyze the fact mathematically (or simply brass-boarded the circuit) I could have used Cecil's time more productively. Short answer is that the much dreaded and poorly understood 'spikes' are already being run to ground by MULTIPLE input capacitors that already exist in your system. I have chased the elusive 'spike' in airplanes from C-150 to Beechjets and have never been able to capture one in the wild. The ones I generated on the bench turned out to be wimps. Bob . . . ________________________________________________________________________________
Subject: Need Help Troubleshooting
Date: Sep 24, 2012
I've got a situation that appeared rather suddenly and I'm not sure where to start. I was doing some tough-n-goes the other day when one of my low voltage lights started flashing on downwind. I've got a dual electrical system based on Z-14 with two LR3C-14s installed. For the last 60 hours, everything has been running perfect. I fire up the engine and I get 2 readings of 14.2 volts at idle. Suddenly, one of the systems will not deliver any alternator voltage at idle. If I bring the engine back to idle at any point, whether it be on the ground or in the air, the voltage drops to 12.2 and begins a slow fall from there. As I increase the RPMs, the voltage again rises to 14.2. The second system holds 14.2 volts the entire time. Is there a way to figure out whether my problem is with the LR3C-14 or with the alternator itself? Or possibly with my field circuit breaker? Or with the alternator switch? I haven't a clue where to even begin. Suggestions welcome. Steve Thomas ________________________________________________________________________ ________________________________________________________________________________
Date: Sep 24, 2012
I assumed that Sacha was referring to my example that I think effectively had no battery in the circuit Bob. My little AGM battery was completely flat. Afterwards it seemed that I could run the voltage up and the battery would not absorb any current until it sat on the charger for quite some time. thanks for the review though. I for one really appreciate your real world info and stories. Ken On 24/09/2012 2:57 PM, Robert L. Nuckolls, III wrote: > > > At 12:28 PM 9/24/2012, you wrote: > > Hi Sacha > > I might be a bit optimistic with that comment. My thoughts are that when > my OVM activates it immediately shorts out the relay but it is still > connected to the buss and is clamping the buss voltage until the circuit > breaker pops. > > Actually, it's a healthy battery that "clamps > the bus". During OVM reaction time the alternator > goes into max v current limited output with the > ship's accessories taking part of the load > and the battery working to soak up the rest. > > Once the OVM trips, the current draw on the bus > WILL go up to 50+ amps . . . so I suppose there's > some additional clamping going on. A 5A breaker > with typical OVM loads opens in 15 to 50 milliseconds > so it's all over in a blink of an eye. > > So you are correct that with a slow opening relay and a fast acting CB > there could be a few milliseconds delay during which time the voltage > will be rising again. > > Relay, cb and ovm timing 'races' don't figure into > system functionality at all. Your electro-whizzies > manufactured to DO-160 design goals will stand off > 20 volts for 1 second. The battery will keep bus > volts down to 17 volts or so. This give the OVM and > associated components all the time in the world to > do their intended job. > > Probably shouldn't mention it since I can't claim they are significant > but I also have a few TVS diodes on the buss. Since they are fast acting > and cheap they seemed like a good idea (several years ago) with an > electrically dependent engine. > > They don't hurt a thing . . . don't do anything > useful either. The TVS is designed to mitigate > low energy, fast rise, high voltage transients > that do not exist on your ship's DC bus . . . and > again, devices built to DO-160 intent are designed > to stand off the classic 'transient spike test'. > > Years ago I spent a fist full of the boss's money for > my man Cecil to build a test fixture required for > GENERATION of the DO-160 test spikes. Cool gadget. > > When we got it finished and calibrated, I began to > explore vulnerability for my favorite bus power > conditioning circuits. > > I was astounded to find that when the device under > test had a simple capacitor of 1uF or more across > the incoming line . . . Cecil's Evil Spike Thrower > couldn't put a spear past it. > > From that time onward, the fixture was never again > pulled down from the shelf . . . 'cause all our products > already featured the necessary capacitor. Had I > endeavored to analyze the fact mathematically > (or simply brass-boarded the circuit) I could have > used Cecil's time more productively. > > Short answer is that the much dreaded and poorly > understood 'spikes' are already being run to ground > by MULTIPLE input capacitors that already exist > in your system. I have chased the elusive 'spike' > in airplanes from C-150 to Beechjets and have > never been able to capture one in the wild. The > ones I generated on the bench turned out to be > wimps. > > > Bob . . . > > ________________________________________________________________________________
Date: Sep 24, 2012
and fail? Fascinating story with the switches. I could almost see Sherlock with his magnifying glass examining the teeter-totter If I understand correctly, you are saying that if there is heating/singeing/burning going on in properly configured circuit, the problem will be at the same location as the excess heating. Therefore, a singed crimp suggests that the high resistance point is in the crimp. Also, any voltage drop in a circuit will occur in the same place. In my case, I had a splice-free line running from my fuse panel to the strobe unit. Having detected the voltage drop, I imagined a chafed wire but didn't expect that the hidden crimp barrel on one connector would be the smoking culprit. Increased resistance with a non-trivial current = voltage drop and heat In my case, the voltage drop was enough to cause the strobe unit to intermittently fire and there was enough heat to singe the crimp. I knew that but now I "get it" a bit better in a real life situation. Bill "it's elementary" Watson On 9/23/2012 1:59 PM, Robert L. Nuckolls, III wrote: > > > At 04:08 PM 9/22/2012, you wrote: >> >> Bill, >> >> Search "switches with faston tabs" in the AeroElectric archives. They >> discuss the discoloration of the faston insulation as the result of >> switch failure. Time frame of sept 08. > > Yes . . . there was a 'rash' of failures manifesting > in 'smoked joints' that started with loose rivets on > the Carling switches. This prompted a lot of discussion > and failure-analysis/tear-downs back about that > time. Something to keep in mind as folks are unhappily > blessed with such events. > > Look for a the loci of failure . . . sorta like a > arson investigation. See which parts got hottest. > These usually point to the area off poor connection > where the degradation of the joints began. Several > examples of over-heating in poor conduction areas > are explored here: > > http://tinyurl.com/8d63v8x > > http://tinyurl.com/8zzkfbb > > http://tinyurl.com/8zzkfbb > > Whether bolting alternator brackets to crank-cases > or keeping all the connections tight through > a switch, the path to failure is the same. Increase > in resistance increases heating and VOLTAGE DROP > across a joint These two antagonists team up > regeneratively to damage and perhaps fail the > joint. > > > Bob . . . ________________________________________________________________________________
Date: Sep 24, 2012
Subject: Re: Looking to Buy a Stein Air Large Terminal Crimping
Tool Have you tried Bob Avery at Avery Tools? Try http://www.averytools.com/prodinfo.asp?number=461 http://www.averytools.com/prodinfo.asp?number=TT5000 Peter On 24/09/2012 15:52, stearman456 wrote: > > Stein Air used to sell a crimping/swaging tool for #2, 4, and 6 AWG terminals, product ID was TERMTOOL. I guess they're no longer able to get them. If someone is done with theirs and would like to sell it I can promise it a good home. Dan Jones warbirds(at)shaw.ca > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=383893#383893 > > ________________________________________________________________________________
Date: Sep 24, 2012
Subject: Re: Need Help Troubleshooting
Steve, this is just a shot in the dark. A fully charged battery with no load should be producing over 12.6 volts. I'm wondering if you've lost a battery. Bill Watson RV10 - Z-14 On 9/24/2012 3:41 PM, Steve Thomas wrote: > > I've got a situation that appeared rather suddenly and I'm not sure where to start. I was doing some tough-n-goes the other day when one of my low voltage lights started flashing on downwind. > > I've got a dual electrical system based on Z-14 with two LR3C-14s installed. For the last 60 hours, everything has been running perfect. I fire up the engine and I get 2 readings of 14.2 volts at idle. Suddenly, one of the systems will not deliver any alternator voltage at idle. If I bring the engine back to idle at any point, whether it be on the ground or in the air, the voltage drops to 12.2 and begins a slow fall from there. As I increase the RPMs, the voltage again rises to 14.2. The second system holds 14.2 volts the entire time. > > Is there a way to figure out whether my problem is with the LR3C-14 or with the alternator itself? Or possibly with my field circuit breaker? Or with the alternator switch? I haven't a clue where to even begin. Suggestions welcome. > > > Steve Thomas > ________________________________________________________________________ > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Tool
Date: Sep 24, 2012
Thanks Peter - I'll look into that. Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=383929#383929 ________________________________________________________________________________
Tool
Date: Sep 24, 2012
I've got the Terminal Tool and it does a great job if you can put it in a vice. Used as a portable tool it is pretty awkward. I made it work and the results were fine but, as I say, it was a little awkward. Maybe if you had a vice on a roll around bench that you could set beside the plane . . . Allen Fulmer RV7 still building -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Peter Pengilly Sent: Monday, September 24, 2012 5:12 PM Subject: Re: AeroElectric-List: Looking to Buy a Stein Air Large Terminal Crimping Tool Have you tried Bob Avery at Avery Tools? Try http://www.averytools.com/prodinfo.asp?number=461 http://www.averytools.com/prodinfo.asp?number=TT5000 Peter On 24/09/2012 15:52, stearman456 wrote: > > Stein Air used to sell a crimping/swaging tool for #2, 4, and 6 AWG terminals, product ID was TERMTOOL. I guess they're no longer able to get them. If someone is done with theirs and would like to sell it I can promise it a good home. Dan Jones warbirds(at)shaw.ca > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=383893#383893 > > ________________________________________________________________________________
Date: Sep 24, 2012
Tool I got a hydrolic crimper from harbor freight that works pretty well. I have one from either Steinair or B&C. It is basically a whack-it with the hammer till it looks right so of machine. I like the control from the HF unit. Regards, Michael Wynn RV 8 Finishing San Ramon, CA In a message dated 9/24/2012 3:12:36 P.M. Pacific Daylight Time, peter(at)sportingaero.com writes: --> AeroElectric-List message posted by: Peter Pengilly Have you tried Bob Avery at Avery Tools? Try http://www.averytools.com/prodinfo.asp?number=461 http://www.averytools.com/prodinfo.asp?number=TT5000 Peter On 24/09/2012 15:52, stearman456 wrote: > --> AeroElectric-List message posted by: "stearman456" > > Stein Air used to sell a crimping/swaging tool for #2, 4, and 6 AWG terminals, product ID was TERMTOOL. I guess they're no longer able to get them. If someone is done with theirs and would like to sell it I can promise it a good home. Dan Jones warbirds(at)shaw.ca > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=383893#383893 > > ________________________________________________________________________________
Subject: Re: Misprint in Z-16, v.12/ OV with Rotax generators?
Date: Sep 25, 2012
> I for one really appreciate your real world info and stories. Me too, thanks again to both of you. Sacha ________________________________________________________________________________
Date: Sep 24, 2012
At 02:41 PM 9/24/2012, you wrote: I've got a situation that appeared rather suddenly and I'm not sure where to start. I was doing some tough-n-goes the other day when one of my low voltage lights started flashing on downwind. I've got a dual electrical system based on Z-14 with two LR3C-14s installed. For the last 60 hours, everything has been running perfect. I fire up the engine and I get 2 readings of 14.2 volts at idle. Suddenly, one of the systems will not deliver any alternator voltage at idle. If I bring the engine back to idle at any point, whether it be on the ground or in the air, the voltage drops to 12.2 and begins a slow fall from there. As I increase the RPMs, the voltage again rises to 14.2. The second system holds 14.2 volts the entire time. Do you not know which of the two systems is powered by the SD-20 and which is powered by the main alternator? Is there a way to figure out whether my problem is with the LR3C-14 or with the alternator itself? Or possibly with my field circuit breaker? Or with the alternator switch? I haven't a clue where to even begin. Suggestions welcome. I'm not sure anything is wrong. The SD-20 alternator is DE-RATED to 20A due to limitations in RPM available at the vacuum pump pad. The alternator begins life as a 40A ND which is disassembled for salvage of useful components and reassembled with new front end bell, shaft mods, sheer coupling and removal of built in regulator. Borrowing from the B&C website we see this data table: Emacs! Assuming 1:1.4 step up gearing for the vacuum pump pad, a ramp taxi RPM of say 1000 yields alternator RPM of 1400 where it can be expected to deliver less than 15A. If bus loads on the Aux alternator are significant, bus voltage on that side can be expected to drop below 13.0v warning value and the battery will be expected to pick up some slack at voltages similar to those you cited. I would recommend that ground ops be conducted with the cross-feed contactor closed except to check Aux Alternator output during pre-flight run up. After take off, add "Cross-feed Contactor-OPEN" to your post departure checklist. You would also reclose the cross-feed contactor during pre-landing checklist. The fact that you USED to get 14.2 at ground idle before suggests that the cross-feed contactor was closed. Now that you're seeing this disparity of voltage between the two busses suggests that the cross-feed contactor is open and the Aux Alternator is performing pretty much as expected. I wonder if -either- you've changed your modus operandi for cross-feed management -or- the contactor has become unavailable for some reason. In any case, you should KNOW which of the two alternators is used to power which suite of goodies on the panel. This is an essential component of plan-B development for operations with the Main Alternator crapped. Bob . . . ________________________________________________________________________________
Date: Sep 25, 2012
Subject: Good news . . . and bad news
I picked up the latest version of Schumacher's SEC1562 charger at Wallyworld last week. Got it on a site-to-store free of shipping charges for about $21. The first plot for a charge cycle demonstrated the highly recommended bulk charge ramp capped off with an absorption charge plateau. http://tinyurl.com/9s7kpww I did a series of charge discharge cycles alternating between the 1562 and my 10+ year old Battery Tender. Wasn't paying much attention to details of the data. Each test cycle took 14+ hours. When I merged the data on to a common plot, it became obvious that the test battery, while relatively young, was incapable of delivering closely matched pairs of charge/discharge cycle. Normally, one expects a new SVLA battery to be good for several dozen deep discharges before demonstrated capacity begins to fall. Not so with the test article I've been using. Test results: I'm unable to resolve the difference between recharge performance of the 1562 versus the BT. Both chargers seem to put about as much snort into the battery but any real differences are buried in the uncertainties generated by the degrading battery. I can confidently assert that the SEM51562 is still an exceptional value. It now features 6/12 auto-switching, it charges at a rate about 2x that of the Battery Tender. I see that the BT Jr sells on Ebay for about $25 with free shipping, so cost differential has dropped markedly over the past few years. Conclusion: I cannot claim that one device is superior to the other based on measurements. The recharge voltage profiles for the BT are markedly shy of the idealized profiles cited by industry. Just how much difference it makes remains unmeasured. Using a chemical conversation system as a 'transfer standard' for evaluation of charger performance is fraught with risk . . . which rose up and bit me. Anywho, I've got a shiny new 1562 that's going out to the wood shop to maintain some batteries I have stored out there. Next time I get my hands on a fresh, mid-sized SLVA battery, I'll try again. Don't throw out your Battery Tenders! I'm keeping all three of mine. Bob . . . ________________________________________________________________________________
Date: Sep 25, 2012
I should have been more specific. What I have is a Mazda 2 rotor with two 70 amp alternators. The batteries, two each, are Panasonic LC-RD 1217P. I never start with the cross-feed closed. In fact, I don't ever recall ever using the cross-feed. The starter is connected to system 1, the system that is now failing. The last start, while running the test, was sharp and crisp. The alternators are Bosh with the internal regulators removed. The split of devices running on each system is well known, but I don't see the relevance. The cross-feed is a backup position that, until now, has not been needed. And, since I was in the pattern when it failed, there was no need to engage - even if I had remembered. I don't know the RPMs of the alternators at idle, but, it was working fine. Steve Thomas ________________________________________________________________________ On Sep 24, 2012, at 5:42 PM, "Robert L. Nuckolls, III" wrote: > At 02:41 PM 9/24/2012, you wrote: > > I've got a situation that appeared rather suddenly and I'm not sure where to start. I was doing some tough-n-goes the other day when one of my low voltage lights started flashing on downwind. > > I've got a dual electrical system based on Z-14 with two LR3C-14s installed. For the last 60 hours, everything has been running perfect. I fire up the engine and I get 2 readings of 14.2 volts at idle. Suddenly, one of the systems will not deliver any alternator voltage at idle. If I bring the engine back to idle at any point, whether it be on the ground or in the air, the voltage drops to 12.2 and begins a slow fall from there. As I increase the RPMs, the voltage again rises to 14.2. The second system holds 14.2 volts the entire time. > > Do you not know which of the two systems is > powered by the SD-20 and which is powered by > the main alternator? > > Is there a way to figure out whether my problem is with the LR3C-14 or with the alternator itself? Or possibly with my field circuit breaker? Or with the alternator switch? I haven't a clue where to even begin. Suggestions welcome. > > I'm not sure anything is wrong. The SD-20 alternator > is DE-RATED to 20A due to limitations in RPM available > at the vacuum pump pad. The alternator begins life as > a 40A ND which is disassembled for salvage of useful > components and reassembled with new front end bell, > shaft mods, sheer coupling and removal of built in > regulator. > > Borrowing from the B&C website we see this data > table: > > > > Assuming 1:1.4 step up gearing for the vacuum > pump pad, a ramp taxi RPM of say 1000 yields > alternator RPM of 1400 where it can be > expected to deliver less than 15A. If bus > loads on the Aux alternator are significant, > bus voltage on that side can be expected to > drop below 13.0v warning value and the battery > will be expected to pick up some slack at voltages > similar to those you cited. > > I would recommend that ground ops be conducted > with the cross-feed contactor closed except to > check Aux Alternator output during pre-flight > run up. After take off, add "Cross-feed Contactor-OPEN" > to your post departure checklist. You would also > reclose the cross-feed contactor during pre-landing > checklist. > > The fact that you USED to get 14.2 at ground idle > before suggests that the cross-feed contactor > was closed. Now that you're seeing this disparity > of voltage between the two busses suggests that > the cross-feed contactor is open and the Aux > Alternator is performing pretty much as expected. > > I wonder if -either- you've changed your modus > operandi for cross-feed management -or- the contactor > has become unavailable for some reason. > > In any case, you should KNOW which of the two > alternators is used to power which suite of goodies > on the panel. This is an essential component of > plan-B development for operations with the Main > Alternator crapped. > > Bob . . . > ________________________________________________________________________________
Date: Sep 25, 2012
Subject: Fwd: Terminal Tool
(Apologies for the first one which quoted the entire Digest... Inadvertently sent before I cleaned it up...) A friend of mine (one of my copilots) designed this, and it works absolutely perfectly. Needs a vise too, but I've made quite a few perfect crimps on my big cables with production serial number 1. Check it out. http://www.theterminaltool.com/ All US-Made components, too. I bought the hydraulic Harbor Freight tool, too, and it works OK for portability, but this thing makes much nicer crimps by far. They look factory-made. Ron Cox Glasair Super II F/T > From: Peter Pengilly <peter(at)sportingaero.com> > Subject: Re: AeroElectric-List: Looking to Buy a Stein Air Large Terminal Crimping > Tool > > > Have you tried Bob Avery at Avery Tools? Try > > http://www.averytools.com/prodinfo.asp?number=461 > > http://www.averytools.com/prodinfo.asp?number=TT5000 > > Peter > ________________________________________________________________________________
Subject: Re: Fwd: Terminal Tool
Date: Sep 25, 2012
Thanks, Ron - that's EXACTLY the tool I was looking for. Just ordered one from him! Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=383988#383988 ________________________________________________________________________________
Date: Sep 25, 2012
At 12:18 PM 9/25/2012, you wrote: >I should have been more specific. What I have is a Mazda 2 rotor >with two 70 amp alternators. The batteries, two each, are Panasonic >LC-RD 1217P. I never start with the cross-feed closed. In fact, I >don't ever recall ever using the cross-feed. The starter is >connected to system 1, the system that is now failing. The last >start, while running the test, was sharp and crisp. The alternators >are Bosh with the internal regulators removed. > >The split of devices running on each system is well known, but I >don't see the relevance. The cross-feed is a backup position that, >until now, has not been needed. And, since I was in the pattern >when it failed, there was no need to engage - even if I had >remembered. I don't know the RPMs of the alternators at idle, but, >it was working fine. Sorry. The vast majority of two-alternator systems we work with are on aircraft engines where one alternator is driven from the now vacant vacuum pump pad. Okay, we're troubleshooting a single alternator/ battery combination. Have you run the traps on the LR3 regulator per B&C documents? http://tinyurl.com/bowymay Knowing how the FIELD output voltage from the LR-3 is behaving when you're experiencing a problem is critical to deciding whether the difficulty lies with the alternator or regulator. Bob . . . ________________________________________________________________________________
Date: Sep 25, 2012
Not yet. Will do ASAP and reply. Steve Thomas ________________________________________________________________________ On Sep 25, 2012, at 12:50 PM, "Robert L. Nuckolls, III" wrote: > Have you run the traps on > the LR3 regulator per B&C documents? ________________________________________________________________________________
Tool
Date: Sep 25, 2012
Hi Allen Short report: I have almost completed the installation of the huge E-cowl cowl flap and it is turning out pretty well if I do say so. Had to beef up the trailing edge of the cowl flap so the center mounted actuater can move the huge area without distortion and it is setting up tonight as I type. Tomorrow I start the last cowl project. The NACA duct to the air fi lter to turbo inlet. Will do something similar to your installation. Tryi ng to figure out how to tie the duct to the filter box and get it set up so the cowl can be put on while alowing for the connection of the turbo inlet fixed to the engine and the cowl mounted duct and filter box fixed to the removable cowl. Tricky...but=2C I think I have figured out a way to do it. will take a lot of trial and error but I am still actually kind of enjoyin g the fiber glass work. Will try to send you some pics. I'm having a hard time finding a new memory stick for my ancient sony sure shot digital cam era and the current ones are full up. need to get busy and transfer them a ll to my computer then figure out how to delete all the shots on the little memory card to make room for more shots. The cowl flap looks pretty neat a nd will give me a huge exit area when needed and a pretty streamlined low d rag exit when cooling is not needed. It rained and hailed today. We nee ded the rain and we got lots of it. Turned really chilly this afternoon. A bout 48.... after what must have been cold front passage. Look forward to each days accomplishments as I can see the progress each day. It is getting to be fun again working on the RV-7. No real work on the horizon so don't know how I will pay for the Aero classic upholstery set-up yet which is abo ut the only un-funded project on the horizon. Attended a really good men' s prayer breakfast early this morning=2C then was at the hangar by 8:30 am. Chao for now. Bill > From: afulmer(at)charter.net > To: aeroelectric-list(at)matronics.com > Subject: RE: AeroElectric-List: Looking to Buy a Stein Air Large Terminal Crimping Tool > Date: Mon=2C 24 Sep 2012 17:56:32 -0500 > net> > > I've got the Terminal Tool and it does a great job if you can put it in a > vice. Used as a portable tool it is pretty awkward. I made it work and the > results were fine but=2C as I say=2C it was a little awkward. Maybe if y ou had > a vice on a roll around bench that you could set beside the plane . . . > > Allen Fulmer > RV7 still building > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Peter > Pengilly > Sent: Monday=2C September 24=2C 2012 5:12 PM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Looking to Buy a Stein Air Large Terminal > Crimping Tool > > > > Have you tried Bob Avery at Avery Tools? Try > > http://www.averytools.com/prodinfo.asp?number=461 > > http://www.averytools.com/prodinfo.asp?number=TT5000 > > Peter > > On 24/09/2012 15:52=2C stearman456 wrote: a> > > > > Stein Air used to sell a crimping/swaging tool for #2=2C 4=2C and 6 AWG > terminals=2C product ID was TERMTOOL. I guess they're no longer able to get > them. If someone is done with theirs and would like to sell it I can > promise it a good home. Dan Jones warbirds(at)shaw.ca > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=383893#383893 > > > > > > > > > > > > > > > > > > > > > > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Sep 26, 2012
Go to Ebay and search "Hammer Crimper". For big cables they seem ideal. And so cheap it is hard to believe. Must be Elbonian labor. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=384015#384015 ________________________________________________________________________________
From: "Bill Bradburry" <bbradburry(at)bellsouth.net>
Subject: Waiver on Ethanol!
Date: Sep 26, 2012
The US government, until October 11, 2012, is asking for public comment on the proposed waiver to the Renewable Fuel Standard, the regulation that mandates ethanol in U.S. fuel stocks, due to reduced corn crops from this summer's drought. Go <http://www.regulations.gov/#!documentDetail;D=EPA-HQ-OAR-2012-0632-0001> HERE on regulations.gov, where you can view the document, EPA-HQ-OAR-2012-0632. Click the "Comment Now!" button to add your comment. It's easy, so do it now! http://www.regulations.gov/#!documentDetail;D=EPA-HQ-OAR-2012-0632-0001 ________________________________________________________________________________
Subject: Re: Switch confusion
Date: Sep 26, 2012
Folks, In studying the various Z Architecture diagrams, I notice in some cases the S700-2-3 switch is used and in others the S700-2-10 is used. I understand the functionality differences. Can anyone tell me if there are operational reasons for using an S700-2-10 switch over the S700-2-3 switch? Or vice versa? S700-2-3 = OFF - BATT + ALT ON S700-2-10 = OFF - BATT ON - BATT + ALT ON Right now I have the S700-2-3 switch in my design with the ALT FLD 5A breaker to . I have a B&C L60amp primary alternator, with LR3C-14 Voltage regulator. I also have the SD-8 amp as my backup alternator. Thanks, Howard nuckollsr(at)cox.net wrote: > > A Back in the "good 'ol days" when airplanes were getting their first > generators, batteries and a few lights, the battery master and generator control switches could be and were separate switches. This is because a generator will start and run by itself whether or not a battery was on > line to go with it. When alternators came along, they needed (and still do > need) a battery to get them to come up reliably. Further, alternators do not run well without a battery on line. None the less, it was desirable to have some degree of independent control of the battery and alternator > insofar as system performance requirements would permit. This is when the > split-rocker master switch was conceived. This switch has acquired almost magical attributes. > . . I've seen the red-rocker enshrined in prominent locations on the panels of many homebuilts even when all other switches were a different style. > > A little study of the split rocker shows us that the battery can be on by > itself, but the alternator cannot. The same functionality is provided by our DP3T, on-on-on toggle switch (S700-2-10). Lower position is ALL OFF, mid position is BAT ONLY, upper position is BAT+ALT. It's true that you could replace the S700-2-10 with an S700-2-3 and turn on BOTH devices with a single throw of the DC master switch. It's a rare in-flight condition that the > alternator NEEDS to be off. If you're doing some battery-only ground maintenance, then you could pull the breaker. We recommend the S700-2-10 as an alternative to the split-rocker switch to provide equivalent functionality. The three positions offer ALL OFF, BATTERY ONLY, and BATTERY + ALTERNATOR functionality while making sure that the alternator is not allowed to be ON when the battery is OFF - I.e. emulation of the split rocker > switch. > > Bob . . . -------- Howard Plevyak GlaStar / North Bend, Ohio hplevyak(at)mac.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=384025#384025 ________________________________________________________________________________
Date: Sep 26, 2012
Subject: Wiring advice
I have a question regarding wiring my Sonex/Great Plains VW engine. The system has 1 battery (PC625 Odyssey) a CD Solenoid, A regulator/rectifier, and a 3 phase 35 Amp alternator. I am using a MAG and a secondary ignition and coil system. Instrument panel is rather simple with a Stratomaster Ultra Horizon, and a Radio (not sure if I will use panel mounted or my Icom A-22 handheld). I may use a GPS, or might just use my ipad. I plan on installing a cigarette lighter power outlet or 2 and that is about the extent of the panel electrics. I have no lights. If I use the panel radio I will be mounting headset jacks on the panel as well and that might require me to use a ground isolation, even though it would be easier and probably more convenient to just ground straight to the firewall without isolation. I was planning on grounding on the engine side with a bolt through the firewall (need isolators?) where the negative battery, engine ground strap, and alternator ground will attach. On the inside I wanted to use a forest of tabs, but I think I would rather bring a negative buss closer to the panel and locate it there. I also plan on running a positive buss close to the panel as well. I have reviewed the appendix from the book and none are really close to what I am looking for. I am trying to figure out the best method to do this and also avoid radio noise later as well. The fewer wires through the firewall the better. Aside from the main power and ground wire penetrating the firewall I will also have the CD Solenoid power wire, the starter solenoid wire Please offer any info/help you can. Thanks! Eric M. ________________________________________________________________________________
Subject: Re: Need for an Alternator switch
Date: Sep 26, 2012
I've got something similar to Z-8, with the SD-8 section deleted and a diode maintained emergency battery that feeds the essential bus through a switch labeled "critical"(actually it is a double pole, paralleled for capacity and reliability). When I say "diode maintained battery" I mean the battery is fed from the main bus, through a fuse rated at 150% of the 40A alternator capacity, then a diode of similar capacity. The essential bus is fed through a second diode at the fuse diode junction just as shown on Z-8 except for the addition of the already mentioned fuse between the main and essential buss. Z-8 switches the main alternator with the master but it seems redundant to have the main bus switched from the contactor and at the same time switch the field, especially when you consider they are mechanically tied to each other. With Z-8, as it is, you're breaking/making the field circuit twice. Why? Didn't make any sense to me so I deleted the main alternator switch. I have a 5A pull breaker for the LR-3 regulator. That is the only breaker I have. If I'm "on short final for the rocks" I just turn off the master and critical switches that's everything including the alternator field. I didn't know what that switch would add so I deleted it. As an FYI, I'm also running dual electronic ignition. Those are fed via fuselink directly from each battery. I have no vacuum pump, my instruments are electric, although a GPS and the ADHRS have internal battery backups. I do fly IFR in this plane. I don't really care if certified aircraft have the alternator switch or not, the question for everything I put in my plane is do I need it? What am I getting? Bill Judge N84WJ, RV-8 817 hrs http://rv-8.blogspot.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=384036#384036 ________________________________________________________________________________
Date: Sep 26, 2012
Subject: AIRCAM Schematic or ideas
I am beginning to work up an electrical plan for a friends Aircam project, twin Rotax 912's with single battery. Anybody out there have a schematic they would like to share for a twin engine rotax or similar to give me a starting point to look over. I looked at the TECNAM P2006T but I don't think I need the complexity of its system and I do not quite understand the Cross bus switch logic they have. I attached for anyone who wants to comment on it. Thanks Chris Lucas N919AR RV-10 and Aircam helper ________________________________________________________________________________
Date: Sep 26, 2012
At 09:02 AM 9/26/2012, you wrote: > >Folks, >In studying the various Z Architecture diagrams, I notice in some >cases the S700-2-3 switch is used and in others the S700-2-10 is >used. I understand the functionality differences. > >Can anyone tell me if there are operational reasons for using an >S700-2-10 switch over the S700-2-3 switch? Or vice versa? 2-10 is progressive transfer that emulates the split-rocker functionality. If you use 2-3 switch, then alternator and battery come on and off together, alternator can only be turned off by pulling the field breaker. Either works. Bob . . . ________________________________________________________________________________
Date: Sep 26, 2012
Subject: Re: AIRCAM Schematic or ideas
At 01:57 PM 9/26/2012, you wrote: >I am beginning to work up an electrical plan for a friends Aircam >project, twin Rotax 912's with single battery. Anybody out there >have a schematic they would like to share for a twin engine rotax or >similar to give me a starting point to look over. I looked at the >TECNAM P2006T but I don't think I need the complexity of its system >and I do not quite understand the Cross bus switch logic they have. Obviously, this is a day, fair-weather, vmc fun machine. There's no obvious value srtiving for a very failure tolerant system. Suggest you wire like figure Z16 http://tinyurl.com/7vp9g4e Except you have two-fat wire feeders to the starter contactors at the engines. These same feeders just happen to be a good way to bring each alternator in to the battery. Run one alternator at a time with second for back up. > I attached for anyone who wants to comment on it. Busy . . . Bob . . . ________________________________________________________________________________
Date: Sep 26, 2012
Subject: Re: Pitot tube slightly plugged...
>> I'm please to hear that you were able to salvage an otherwise useless piece of expensive hardware! Let me warn that there appears to be an error in the repair description. The OP wrote battery acid, HCl. But of course, battery acid is H2SO4. I can believe a weak (3 molar?) solution of HCl, as is often used as swimming pool acid or brick cleaning acid might dislodge organic material from a pitot tube without dissolving the pitot tube itself. I would be very surprised (would not likely believe) that battery acid, full strength, undiluted sulfuric acid was able to do anything but significantly dissolve a pitot tube... Hopefully the OP can clarify what he meant, since his acid description was internally inconsistent. Paul ________________________________________________________________________________
Date: Sep 26, 2012
Thanks, Paul. I stand corrected. The acid used was obtained directly from a surplus supply left over from filling a new dry lead-acid car battery. The container had been capped, but was at least one year old. I do not know the strength of the solution. FWIW: The vinegar actually brightened the visible copper more than the battery acid. And thanks to all who contributed their improvised techniques to thwarting insects from creating homes in small holes. Especially interesting was the comment about using different colored tubing. With a bug-plugged scupper-ring at the fuel fill port on a C337, the rain-water level will rise above the lip of the fuel cap neck. Until the owner [me] realizes that he has a plugged scupper vent line, the appearance of water in the fuel tank/test is an interesting and humbling mystery. My fix in 2001 was to add 2 inches of clear Tygon tubing to each vent outlet. I figured that if the bugs were there, I'd at least see them the next time. However, they never returned. Now I know why. Thanks guys. Mike ----- Original Message ----- From: "Paul Millner" <millner(at)me.com> Sent: Wednesday, September 26, 2012 2:05 PM Subject: Re: AeroElectric-List: Re: Pitot tube slightly plugged... > > >> I'm please to hear that you were able to salvage an otherwise > useless piece of expensive hardware! > > Let me warn that there appears to be an error in the repair description. > The OP wrote battery acid, HCl. But of course, battery acid is H2SO4. > > I can believe a weak (3 molar?) solution of HCl, as is often used as > swimming pool acid or brick cleaning acid might dislodge organic material > from a pitot tube without dissolving the pitot tube itself. I would be > very surprised (would not likely believe) that battery acid, full > strength, undiluted sulfuric acid was able to do anything but > significantly dissolve a pitot tube... > > Hopefully the OP can clarify what he meant, since his acid description was > internally inconsistent. > > Paul > > > ________________________________________________________________________________
Date: Sep 26, 2012
Thanks Bob, Z16 is where I was headed but wondered if I was missing something with "twin engines". Definitely not a machine with a need for complexity. One clarification... when you say run one alternator at a time do you mean just switch one of the alternators off? How does keeping the designated backup off improve system reliability or procedures? Busy is a good word for the Tecnam. -Chris ----- Original Message ----- From: Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> Subject: Re: AeroElectric-List: AIRCAM Schematic or ideas At 01:57 PM 9/26/2012, you wrote: >I am beginning to work up an electrical plan for a friends Aircam >project, twin Rotax 912's with single battery. Anybody out there >have a schematic they would like to share for a twin engine rotax or >similar to give me a starting point to look over. I looked at the >TECNAM P2006T but I don't think I need the complexity of its system >and I do not quite understand the Cross bus switch logic they have. Obviously, this is a day, fair-weather, vmc fun machine. There's no obvious value srtiving for a very failure tolerant system. Suggest you wire like figure Z16 http://tinyurl.com/7vp9g4e Except you have two-fat wire feeders to the starter contactors at the engines. These same feeders just happen to be a good way to bring each alternator in to the battery. Run one alternator at a time with second for back up. > I attached for anyone who wants to comment on it. Busy . . . Bob . . . ________________________________________________________________________________
Date: Sep 26, 2012
At 06:14 PM 9/26/2012, you wrote: > >Thanks Bob, Z16 is where I was headed but wondered if I was missing >something with "twin engines". Definitely not a machine with a need >for complexity. >One clarification... when you say run one alternator at a time do >you mean just switch one of the alternators off? How does keeping >the designated backup off improve system reliability or procedures? > >Busy is a good word for the Tecnam. Those alternators are designed to run in parallel on a single bus. Given the sledge-hammer approach to voltage regulation, it probably wouldn't hurt anything. At the same time, if one alternator crapped and both were on, you wouldn't get a low voltage warning annunciating the failure. You might land with a dead alternator and not know it until next preflight. Better to run one alternator at a time. If it craps, you've got a second alternator which you'll turn on when the low voltage warning light flashes . . . you DO plane active notification of low voltage? Bob . . . ________________________________________________________________________________
Date: Sep 26, 2012
CORRECTION >Those alternators are NOT designed to run in parallel on a >single bus. Bob . . . ________________________________________________________________________________
Date: Sep 27, 2012
Subject: Re: Wiring advice
>If I use the panel radio I will be mounting headset jacks on the >panel as well and that might require me to use a ground isolation, >even though it would be easier and probably more convenient to just >ground straight to the firewall without isolation. I do not understand this statement. > >I was planning on grounding on the engine side with a bolt through >the firewall (need isolators?) where the negative battery, engine >ground strap, and alternator ground will attach. On the inside I >wanted to use a forest of tabs, but I think I would rather bring a >negative buss closer to the panel and locate it there. I also plan >on running a positive buss close to the panel as well. What are you calling a 'positive bus'? Are you using breakers or fuses? The bus that distributes power to either of those devices is a component of their fabrication and installation. > I have reviewed the appendix from the book and none are really > close to what I am looking for. I am trying to figure out the best > method to do this and also avoid radio noise later as well. The > fewer wires through the firewall the better. Aside from the main > power and ground wire penetrating the firewall I will also have the > CD Solenoid power wire, the starter solenoid wire > >Please offer any info/help you can. Please review the grounding philosophies illustrated in Figure Z-15, View A http://tinyurl.com/6m3bk8k and Chapter 5 of the 'Connection. Then let us know in what manner the techniques suggested present an extra-ordinary problem for the assembly of your airplane -or- do not meet new design goals. If you have a design goals issue, we need to understand what it is before well considered advice can be offered. Bob . . . ________________________________________________________________________________
Subject: SD-8 S704-1 relay with or without Diode when using
OVM-14?
Date: Sep 27, 2012
Guys, I'm trying to finish up wiring of the backup SD-8amp alternator. In Z-10/8 the S704-1 relay shows a jumper wire from COM to the + relay coil. The CROWBAR OVM is then wired also across the coil (+) & (-) tabs. B&C has a drawing that shows the S704-1 relay being wired with a Diode across the coil. Reference: http://www.bandc.biz/pdfs/S704-1_Installation.pdf Am I correct in leaving the Diode OUT? The reason being that I'm using the OVM-14 across the coil and adding the Diode would defeat the OVM's function. Thanks for your guidance. Howard -------- Howard Plevyak GlaStar / North Bend, Ohio hplevyak(at)mac.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=384086#384086 Attachments: http://forums.matronics.com//files/s704_1_relay_bandc_625.gif http://forums.matronics.com//files/z10_sd8_arch_snipit_197.gif ________________________________________________________________________________
Subject: Re: Good news . . . and bad news
Date: Sep 27, 2012
Bob, The graph did not show V and A legends on the pic that you included. The 1562 that I recently purchased and put on a standard open cell 12v auto battery had the following. I monitored the batt. voltage with a DVM. The max chg. voltage went to just under 14.1 v. The stabilized float voltage was just under 13.1 v. Does this seem about what you viewed on your tests...?? Dave ____________________________________________________________ ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Sent: Tuesday, September 25, 2012 10:08 AM Subject: AeroElectric-List: Good news . . . and bad news > > > I picked up the latest version of Schumacher's SEC1562 > charger at Wallyworld last week. Got it on a site-to-store > free of shipping charges for about $21. > > The first plot for a charge cycle demonstrated the highly > recommended bulk charge ramp capped off with an absorption > charge plateau. > > http://tinyurl.com/9s7kpww > > I did a series of charge discharge cycles alternating between > the 1562 and my 10+ year old Battery Tender. Wasn't paying > much attention to details of the data. Each test cycle > took 14+ hours. > > When I merged the data on to a common plot, it became obvious > that the test battery, while relatively young, was incapable > of delivering closely matched pairs of charge/discharge cycle. > > Normally, one expects a new SVLA battery to be good for > several dozen deep discharges before demonstrated capacity > begins to fall. Not so with the test article I've been > using. > > Test results: > > I'm unable to resolve the difference between recharge > performance of the 1562 versus the BT. Both chargers > seem to put about as much snort into the battery but > any real differences are buried in the uncertainties > generated by the degrading battery. > > I can confidently assert that the SEM51562 is still > an exceptional value. It now features 6/12 auto-switching, > it charges at a rate about 2x that of the Battery > Tender. I see that the BT Jr sells on Ebay for about $25 > with free shipping, so cost differential has dropped markedly > over the past few years. > > Conclusion: > > I cannot claim that one device is superior to the other > based on measurements. The recharge voltage profiles > for the BT are markedly shy of the idealized profiles > cited by industry. Just how much difference it makes > remains unmeasured. > > Using a chemical conversation system as a 'transfer > standard' for evaluation of charger performance is > fraught with risk . . . which rose up and bit me. > > Anywho, I've got a shiny new 1562 that's going out > to the wood shop to maintain some batteries I have > stored out there. Next time I get my hands on a fresh, > mid-sized SLVA battery, I'll try again. Don't throw > out your Battery Tenders! I'm keeping all three of > mine. > > > Bob . . . > > > ________________________________________________________________________________
Date: Sep 27, 2012
I ran the tests and it looks like I have a bad regulator. Test #4, where you check the voltage of pin #4, failed. It was showing only 2.8 volts. I'll contact B & C and figure out where to go. Thanks for the help, Bob. Steve Thomas ________________________________________________________________________ On Sep 25, 2012, at 2:34 PM, Steve Thomas wrote: > > Not yet. Will do ASAP and reply. > > > Steve Thomas > ________________________________________________________________________ > > > > > On Sep 25, 2012, at 12:50 PM, "Robert L. Nuckolls, III" wrote: > >> Have you run the traps on >> the LR3 regulator per B&C documents? > > > > > > ________________________________________________________________________________
Date: Sep 27, 2012
Subject: Resurrecting a battery
Greetings list, I have a couple of dead batteries. Not discharged but killed. They show only approx 10.5-11 volts when taken off the charger. Ron was discussing his experience with putting 15V at .5 amps on some batteries and resurrecting them to some degree. I have a bench supply that I could set at 15 V and .5 amps. My question is whether it will likely damage the bench supply to hook it to a battery. My limited knowledge says that it shouldn't make any difference to the power supply what is hooked to it as long as it doesn't feed electrons to the supply. I've got nothing to loose as far as the batteries are concerned, but I'd hate to cook my bench supply. It's an old Heathkit IP-28 and says 30V and 1amp so it shouldn't tax the supply too hard. Just checking with the experts so I don't kill my power supply. Thanks -- Raymond Julian Kettle River, MN. "And you know that I could have me a million more friends, and all I'd have to lose is my point of view." - John Prine ________________________________________________________________________________
Date: Sep 27, 2012
Correction noted. thanks Chris -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Wednesday, September 26, 2012 11:47 PM Subject: Re: AeroElectric-List: AIRCAM Schematic or ideas --> CORRECTION >Those alternators are NOT designed to run in parallel on a single bus. Bob . . . ________________________________________________________________________________
Subject: Angular Hall Effect Sensor
Date: Sep 27, 2012
Bob N, The N305 Hall effect sensor is no longer available. It was specified in this article: "Angle of Attack Indicator" by Dave Barker. http://www.aeroelectric.com/articles/Angle_of_Attack/2008_12_21.pdf The author has substituted part number SS49. His updated article is available here: http://www.barkeraircraft.com/files/AOA_rDisplay.pdf Now for my question: Can the SS49 HALL sensor be used to sense the angular position of a control surface, specifically the horizontal stabilizer position on a Kitfox? The total angular movement is only about 10 degrees. Ray Allen sells a linear POT for $35 that could be used. But I thought that a Hall Effect sensor would be a more elegant solution with no moving parts, except for a magnet attached to the control surface. The Specs for the SS49 are available here: http://sensing.honeywell.com/index.php?ci_id=3108&la_id=1&pr_id=36530 My friend who is building the Kitfox intends to install a Dynon SkyView EFIS. It has 5VDC available to power the SS49. The SkyView also has a dedicated input pin for elevator trim. Can the SS49 Hall sensor output be connected directly to the SkyView 0 to 5vdc input without any buffering or amplifying circuitry? The SkyView utilizes onscreen wizards for calibrating sensors. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=384114#384114 ________________________________________________________________________________
Date: Sep 27, 2012
Subject: Re: Resurrecting a battery
Hi Ray How many aH battery are they? If close to 12 to 18aH aqnd AGM, the good bet would be to try and use the 500mA transformers and circuit board I sent along with the batteries I offered. They limit current to ~ 500mA and the control board will turn off once they reach ~ 15.4 volts. I would try a few cycles where you bring down the batteries to ~ 12.4 volts. It may take several days to get the control board to turn off, especially the first time. If you have an adjustable power supply, set it to constant current ~ 350 to 500mAs and monitor the voltage. This is not going to be a very fast process, it may take days to get to 15 volts. Once you get to 15.4 volts, let it dwell there for 2 hours at least. I Please report back if you were able to revive. I did this with AGM batteries, if you have a flooded cell battery, you don't have much to lose, but listen carefully and decrease current if things get too bubbly. I tried putting two of the 500mA chargers in parallel on the 12ah batteries and didn't like the noises too much when the voltage got to the upper 14s on some of the batteries. Using only one 5600mA charger kept things happy. I have a sneaky suspicion that when I took two of the bad batteries I had, after they reached the 15.4 volts and the controller turned off and put them in parallel on just one 500mA charger and let them reach 15.4 volts (which took a long time) it may have helped a little, the first time anyway. I didn't run a capacity test, but the voltage seemed to hold up better after I let the batteries sit for several days. Ron Parigoris ________________________________________________________________________________
Date: Sep 27, 2012
Ron, these are flooded cell auto batteries. One I think is a deep-cycle. I put one of your transformers across the terminals and "It don't work no more". That is what leads me to worry about the power supply. I don't think that the power supplies I have are constant current. I think the current setting is a max allowable setting, but I'm not sure. By the way. I'm getting good use out of those batteries. Thanks again for offering them here, even though it was more headache for you. Raymond Julian Kettle River, MN. "And you know that I could have me a million more friends, and all I'd have to lose is my point of view." - John Prine On 09/27/2012 09:01 PM, rparigor(at)suffolk.lib.ny.us wrote: > > Hi Ray > > How many aH battery are they? > > If close to 12 to 18aH aqnd AGM, the good bet would be to try and use > the 500mA transformers and circuit board I sent along with the > batteries I offered. They limit current to ~ 500mA and the control > board will turn off once they reach ~ 15.4 volts. I would try a few > cycles where you bring down the batteries to ~ 12.4 volts. It may take > several days to get the control board to turn off, especially the > first time. > > If you have an adjustable power supply, set it to constant current ~ > 350 to 500mAs and monitor the voltage. This is not going to be a very > fast process, it may take days to get to 15 volts. Once you get to > 15.4 volts, let it dwell there for 2 hours at least. > > I Please report back if you were able to revive. > > I did this with AGM batteries, if you have a flooded cell battery, > you don't have much to lose, but listen carefully and decrease current > if things get too bubbly. I tried putting two of the 500mA chargers in > parallel on the 12ah batteries and didn't like the noises too much > when the voltage got to the upper 14s on some of the batteries. Using > only one 5600mA charger kept things happy. > > I have a sneaky suspicion that when I took two of the bad batteries I > had, after they reached the 15.4 volts and the controller turned off > and put them in parallel on just one 500mA charger and let them reach > 15.4 volts (which took a long time) it may have helped a little, the > first time anyway. I didn't run a capacity test, but the voltage > seemed to hold up better after I let the batteries sit for several days. > > Ron Parigoris > > * > > > * ________________________________________________________________________________
Date: Sep 28, 2012
Hi Ray You mention that the transformer no longer works after you put it across the battery. Was that with the circuit board connected to the transformer? All you need to do is connect the board in reverse to the battery for a split second and it fries the board. If that's the case, I would say there is a good chance the transformer is still good. You can connect the transformer directly to the battery without the board. Just to make sure, connect a volt meter to the transformer to see it's working and you get the polarity correct, if you have a meter that can measure current, make sure you are pumping in 500m As or there about. You will need to monitor the voltage, once you get to ~15.4, let it go for another two hours. How many amp hours are the batteries? If they are 35aHs, put two of the 500mA transformers on them in parallel. Ron Parigoris ________________________________________________________________________________
Date: Sep 28, 2012
Subject: Re: Angular Hall Effect Sensor
At 08:59 PM 9/27/2012, you wrote: > >Bob N, >The N305 Hall effect sensor is no longer available. It was >specified in this article: "Angle of Attack Indicator" by Dave Barker. >http://www.aeroelectric.com/articles/Angle_of_Attack/2008_12_21.pdf >The author has substituted part number SS49. His updated article is >available here: http://www.barkeraircraft.com/files/AOA_rDisplay.pdf > Now for my question: >Can the SS49 HALL sensor be used to sense the angular position of a >control surface, specifically the horizontal stabilizer position on >a Kitfox? The total angular movement is only about 10 degrees. Ray >Allen sells a linear POT for $35 that could be used. But I thought >that a Hall Effect sensor would be a more elegant solution with no >moving parts, except for a magnet attached to the control >surface. The Specs for the SS49 are available here: >http://sensing.honeywell.com/index.php?ci_id=3108&la_id=1&pr_id=36530 >My friend who is building the Kitfox intends to install a Dynon >SkyView EFIS. It has 5VDC available to power the SS49. The SkyView >also has a dedicated input pin for elevator trim. Can the SS49 Hall >sensor output be connected directly to the SkyView 0 to 5vdc input >without any buffering or amplifying circuitry? The >SkyView utilizes onscreen wizards for calibrating sensors. >Joe > >-------- >Joe Gores A few months ago there was some discussion on the List about incorporating some precision, non-contact, rotary motion transducers to some of our applications on OBAM aircraft. Well, I'm aware of one company who has already packaged the Austria-Microsystems magnetic sensors into a potentiometer like package. http://tinyurl.com/73sb7tc They sell for less $ than I can afford to make them. We'll be considering them to replace LVDT's in a new design for a flap actuator. Parts count for the new versus old system will drop by 30% or more. Further, the ball bearing version of this device is tailor made for low-friction sensing of vanes driven by slip-stream. The article cited could be easily converted to a uC based product that would probably fit into our 15-pin, A15 Package http://tinyurl.com/9ydoldk The same sort of philosophy and packaging could be used for trim and/or flap position idication. I.e. one set of hardware with options for firmware would fit 3 different systems on the airplane. Bob . . . ________________________________________________________________________________
Date: Sep 28, 2012
At 08:51 PM 9/27/2012, you wrote: > >Correction noted. >thanks >Chris If it were my airplane . . . http://tinyurl.com/cf2ppmx http://tinyurl.com/cg8falj Bob . . . ________________________________________________________________________________
Date: Sep 28, 2012
At 05:33 PM 9/27/2012, you wrote: > >Bob, >The graph did not show V and A legends on the pic that you included. Not sure which one you're referring to. I think this is the plot I originally published. http://tinyurl.com/d8yc8rw >The 1562 that I recently purchased and put on a standard open cell >12v auto battery had the following. >I monitored the batt. voltage with a DVM. The max chg. voltage went >to just under 14.1 v. >The stabilized float voltage was just under 13.1 v. > >Does this seem about what you viewed on your tests...?? I need to spend some time building an interface for one of the DAS modules I've acquired . . . to plot both battery current and voltage. This will let me do an integration by parts summation of watt-seconds IN versus watt-seconds OUT. By the way, I just became aware of a product from Dataq http://tinyurl.com/93obako Price is hard to beat! One would need an instrumentation amplifier to read current shunts . . . but the AD628 makes that really simple. Just need a 36-hour day . . . Bob . . . Bob . . . ________________________________________________________________________________
Date: Sep 28, 2012
At 07:09 PM 9/27/2012, you wrote: Greetings list, I have a couple of dead batteries. Not discharged but killed. They show only approx 10.5-11 volts when taken off the charger. Ron was discussing his experience with putting 15V at .5 amps on some batteries and resurrecting them to some degree. I have a bench supply that I could set at 15 V and .5 amps. My question is whether it will likely damage the bench supply to hook it to a battery. My limited knowledge says that it shouldn't make any difference to the power supply what is hooked to it as long as it doesn't feed electrons to the supply. Correct. Charging batteries with a bench supply is not without some risk . . . depending on the design of the supply. I was charging a 24 v battery with a big HP 40A supply when the power went off. The HP's crowbar ov protection circuitry lost its reference voltage and triggered. Unfortunately the crowbar system assumed that the energy to be stood-off was coming from AC mains, not from the load. Hence, the fuse was on the wrong side of the crowbar and I burned some circuitry. I now charge batteries through a fuse. I'm not aware of any specific instances of potential hazard to small bench supplies . . . I suspect it's very low. I've got nothing to loose as far as the batteries are concerned, but I'd hate to cook my bench supply. It's an old Heathkit IP-28 and says 30V and 1amp so it shouldn't tax the supply too hard. A brief look-see at the IP-28 schematic http://tinyurl.com/ydhkrky reveals no sneak paths that might make the supply vulnerable to battery back-feed. Just checking with the experts so I don't kill my power supply. No biggie . . . but since you're not depending on the supply for anything but boosting . . . don't really need accurate regulation . . . putting a diode in series with the supply totally eliminates any risk. Now, probability for successful recovery with ANY supply is problematic. The OVERVOLTAGE boost technique described in Concorde literature and elsewhere is designed to stir up chemistry that refuses to accept a charge at standard voltage levels. You can put a 100w light bulb in series with a diode bridge rectifier and use this as a current limited source of high voltage to hook to your battery(ies). Watch the voltage across the battery. If the chemistry is coming awake, the voltage should begin to drop and ultimately level off at normal levels expected for a 1 amp constant current charge. If the voltage doesn't show signs of dropping, the chemistry isn't asleep but dead. By the way, the ol' light-bulbs and rectifier ploy has an ancient history going back to selenium rectifier days. The rectifier need not be rated at any voltage greater than terminal voltage for the battery. Charging current is controlled by how many/big the light bulbs are. I once built a battery charger with 4 bulb sockets on a board along with a selenium bridge rectifier. With 200, 200, 100, and 50 watt bulbs in the sockets, I could set charge rate between .5 and 5.5 amps by seating/unseating the lamps in their sockets. Of course, this is NOT regulated so you have to watch terminal voltage and shut the critter off when charge is complete. Left unattended it will boil off a battery. Bob . . . ________________________________________________________________________________
Date: Sep 28, 2012
I had just taken a battery charger off the battery and used just the transformer, with correct polarity. They don't give an amp/hr rating but it is 675 cold cranking amps. It's a marine starting/deep cycle battery. Raymond Julian Kettle River, MN. "And you know that I could have me a million more friends, and all I'd have to lose is my point of view." - John Prine On 09/28/2012 01:21 AM, rparigor(at)suffolk.lib.ny.us wrote: > > Hi Ray > > You mention that the transformer no longer works after you put it > across the battery. Was that with the circuit board connected to the > transformer? All you need to do is connect the board in reverse to the > battery for a split second and it fries the board. If that's the case, > I would say there is a good chance the transformer is still good. You > can connect the transformer directly to the battery without the board. > Just to make sure, connect a volt meter to the transformer to see it's > working and you get the polarity correct, if you have a meter that can > measure current, make sure you are pumping in 500m As or there about. > You will need to monitor the voltage, once you get to ~15.4, let it go > for another two hours. > > How many amp hours are the batteries? If they are 35aHs, put two of > the 500mA transformers on them in parallel. > > Ron Parigoris > > * > > > * ________________________________________________________________________________
Date: Sep 28, 2012
On 09/28/2012 01:12 PM, Robert L. Nuckolls, III wrote: > You can put a 100w light bulb in series with a diode > bridge rectifier and use this as a current limited source of > high voltage to hook to your battery(ies). Watch the voltage across > the battery. If the chemistry is coming awake, the voltage > should begin to drop and ultimately level off at normal > levels expected for a 1 amp constant current charge. Here's where my ignorance starts showing. Is this setup using mains voltage? Rectified and current limited? 120+ volts DC, current limited to 1-2 amps? Raymond Julian Kettle River, MN. "And you know that I could have me a million more friends, and all I'd have to lose is my point of view." - John Prine ________________________________________________________________________________
Date: Sep 28, 2012
Subject: Re: Flap Control Schematic - will it work?
Bob Sorry I was out of the country on business trip, did not see your reply. I totally agree with the KISS approach. The problem is that the moment you ask for preset flap controller, it becomes hard to keep it simple, (unless you employ some simple electronics) See the simpler version of four positions flap controller that uses no electronics beside few relays and diodes and it is not so confusing and convoluted that the first one. Will be happy to discuss. Nati On Wed, Sep 19, 2012 at 12:06 PM, Robert Reed wrote: > Nati, > > I looked at your diagram and was adimttedly very confused by it. It > seemed to lose much of the desired KISS goal that I was trying to achieve > but I didn't have the time to give it the attention it deserved. In > subsequent discussions with a friend who has a plane like the one I am > building the subject has turned to an even simpler design that didn't rel y > on step switches at all but simply used them for indicator lights. Sever al > people I have talked with preferred only the absolute limit switches with a > momentary switch for up and down only. They were recommending putting th e > switch on the stick so that it could be more easily activated without > having to reach for a console switch. That has certain appeal but I have > always found the switched on the controls to be somewhat unreliable and > tried to stay away from them. > > I am still considering all alternatives and would be interested in seeing > what you worked up though. > > Bob Reed > > ------------------------------ > *From:* Nati Niv > *To:* aeroelectric-list(at)matronics.com > *Sent:* Wed, September 19, 2012 12:30:03 AM > > *Subject:* Re: AeroElectric-List: Flap Control Schematic - will it work? > > Bob > > > Couple of days ago Ii sent you a diagram of a design that should work. I > understand from your silence that you are shocked from the complex and > convoluted design J..... Since then I cleaned the diagram and came up > with simplified design (only three relays, two of them are small, light > duty ones) > > > Let me know if you are interested > > > Nati > > On Sun, Sep 16, 2012 at 10:30 AM, Nati Niv wrote: > >> Bob >> >> >> >> Here is something that will work for you: from any to any (position), >> with limit switches and based on electromechanical (relays 7 of them >> they can be very small) and 11 diodes, more complex but it will work >> . >> >> For that to work properly you will need to modify the mechanical design >> in a way that only one micro switch is make at a time, you will also hav e >> different LED indication compared to your design: only one LED will be l it >> at a time indicating current flap position. >> >> >> >> Have fun >> >> Nati >> On Sat, Sep 15, 2012 at 11:41 AM, Nati Niv wrote: >> >>> Bob >>> >>> >>> >>> Now, that I understand the mechanical design I have a solution includin g >>> to the =93moving from any position to any position up/down=94 can you s end me >>> the diagram in a format other than PDF and I will returned it corrected ? >>> Now that I understand I really the simplicity of it. >>> >>> >>> >>> Nati >>> >>> >>> On Sat, Sep 15, 2012 at 10:39 AM, Robert Reed wrot e: >>> >>>> Nati, >>>> >>>> Sorry, I only showed the electrical and did not explain the mechanics >>>> of the operation. >>>> >>>> The micro-switches will be located in a channel with the ability to >>>> move them to adjust the positions. A slide bar will be attached to th e >>>> trim control arm. The slide bar will close each switch in line during the >>>> retract operation and open each in line during the extend. During the >>>> retract operation only the retract circuit will be powered by the rota ry >>>> switch with the intent of full retraction and not stepped retraction. >>>> During extension, only one circuit can be active at any time and that >>>> circuit will close as soon as the slide bar passes the switch allowing it >>>> to open. The indicator lights will only light when the desired circui t is >>>> active and the switch is open. It should allow for either stepped fla p >>>> extension or full extension with one operation. >>>> >>>> Bob >>>> >>>> >>>> >>>> >>>> ------------------------------ >>>> *From:* Nati Niv >>>> *To:* aeroelectric-list(at)matronics.com >>>> *Sent:* Fri, September 14, 2012 10:14:26 PM >>>> *Subject:* Re: AeroElectric-List: Flap Control Schematic - will it >>>> work? >>>> >>>> Rob >>>> >>>> >>>> >>>> It will not work. >>>> >>>> I understand the KIS approach that leads you to use relays/micro >>>> switches only. Unfortunately designing such thing will require some le vel >>>> of electronic involves and the reason for it is that you need to know *at >>>> all times* what the position of the flaps is because you need to tell >>>> the motor to which direction to go, up/down. Using micro switch as a >>>> location sensing lacks this capability, it =93senses=94 at only one po sition, >>>> the position to which you set it mechanically along the motor travel. The >>>> moment the motor moves from that position you have no indication of wh ere >>>> you are. The most common sense to use as sensing device would be a >>>> potentiometer, and then you need some electronics to sense and compare >>>> (comparators). I would even think basing the design on the LM3914 10 L ED >>>> driver. >>>> >>>> When it was time for me to change the flap system on my RANS 6 from >>>> manual to electric I thought, as an electronic fan about deferent desi gns >>>> but eventually find myself using this: >>>> >>>> >>>> >>>> http://www.e-motionllc.com/Feedback_actuator_p/fa-po-150-12-2.htm >>>> >>>> >>>> >>>> As the actuator (it has built in potentiometer) >>>> >>>> >>>> >>>> And this as a controller. >>>> >>>> >>>> >>>> >>>> http://www.aircraftspruce.com/catalog/elpages/electronicsflapcontrolle r.php >>>> >>>> >>>> >>>> A little pricy, I know but works, I love every second flying the 6 wit h >>>> this arrangement >>>> >>>> >>>> >>>> Nati >>>> >>>> RANS 6 >>>> >>>> Illinois >>>> >>>> >>>> >>>> >>>> On Sat, Sep 15, 2012 at 6:51 AM, Robert Reed wrote : >>>> >>>>> All, >>>>> >>>>> >>>>> >>>>> Attached is my plan for a flap control system using a Rotary 4 >>>>> position switch to control the flaps with LED indicators to show the >>>>> position settings. The rotary switch will have a lever that not only gives >>>>> a tactile feel indicating position but will point to the LED. I beli eve >>>>> this setup will work but would like some review. I have also include d >>>>> absolute limit switched to ensure that an over-run will not occur due to a >>>>> bad relay. >>>>> >>>>> >>>>> >>>>> Bob Reed >>>>> >>>> >>>> * >>>> >>>> om/Navigator?AeroElectric-List" rel=nofollow target=_blank>http:// www.mhref="http://forums.matronics.com/" rel=nofollow target=_blank>h ttp:/========= >>>> * >>>> >>>> * >>>> >>>> ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric -List >>>> ttp://forums.matronics.com >>>> _blank">http://www.matronics.com/contribution >>>> * >>>> >>>> >>> >> > **http://www.matronics="http://forums.matronics.com/" rel=nofollow ta rget=_blank>http://for======== > > > * > =========== =========== =========== =========== > * > > ________________________________________________________________________________
Date: Sep 28, 2012
>Here's where my ignorance starts showing. Is this setup using mains >voltage? Rectified and current limited? 120+ volts DC, current >limited to 1-2 amps? Yes. Suppose the power coming into the back of your house was being supplied by one of the honorable T.A. Edison power stations . . . 120 volts DC. Okay, 150 watt bulb will draw about 1.30 amps. Now hook a 12v battery in series with this setup such that current flowing through the lamp tends to CHARGE the battery. Voltage across the lamp drops by 12v or so the current drops a bit. But the lamp still burns brightly and current through the lamp is charging the battery . . . the lamp becomes a 100W resistor. Emacs! Horribly inefficient? Yes . . . unless you want to sit down and read a book while the battery is charging and can make use of the light output. Now, consider a similar design goal but the power delivered to the back of the house is AC. We can add the rectifier such that reversal in the applied voltage is rectified so that it always charges the battery irrespective of line polarity . . . the lamp(s) still limits the current . . . want a stronger charge rate? More or bigger lamps. Emacs! Again, only 10% of total energy consumed goes into the battery . . . but it IS current limited. Probably not a charger you want to build for routine battery maintenance but it is an option for generating a current limited VOLTAGE source that will RISE to what ever level the injured battery will accept. If it goes to more than 2X battery rating and/or if it doesn't begin to fall in a few minutes, then this resuscitation gambit is futile and should be discontinued. Bob . . . ________________________________________________________________________________
Date: Sep 28, 2012
Subject: Re: SD-8 S704-1 relay with or without Diode when
using OVM-14? >Am I correct in leaving the Diode OUT? The reason being that I'm >using the OVM-14 across the coil and adding the Diode would defeat >the OVM's function. The diode will not affect OVM operation. Resistors in the OVM are across the relay coil and provide some damping action making the diode unnecessary. Bob . . . ________________________________________________________________________________
Date: Sep 28, 2012
Date: Sep 28, 2012
Date: Sep 29, 2012
/9j/4AAQSkZJRgABAQAAAQABAAD/2wBDAAEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEB AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQH/2wBDAQEBAQEBAQEBAQEBAQEB AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQH/wAAR CAFHAicDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAA AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkK FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWG h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl 5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREA AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYk NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOE hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk 5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD+/iiiigAooooAKKKKACiiigAooooAKKKK ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAo oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKK ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAo oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoorw/9oj9 pT4C/sl/CvXfjb+0l8VfB/wc+FfhyWytdU8ZeNNTXT9OW/1Kb7Ppuk6fBGk+o61repTBo9O0 TRrLUNXvjHKbSymEMpQA9worhfhj8T/h38afh/4R+K3wl8a+GviN8NvHuiWniPwb438H6vZ6 74b8R6JfKWt9Q0rVLCWa2uYiyvDMquJba5intLmOG6gmhTuqACiiigAooooAKKKKACiiigAo oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACo5ZYoIpJ55I4YYY3lmmldY4ooo1LyS SSOQiRogLO7EKqgsxABNSV8Z/tz/AAF8Lftvfsh/tV/seW/jTw7pXiH4x/Brxn8N7S+k1EXr eCvGXiXQNXk8AeIPEGkaTeR6u+n6R4o0e21260n9xLrWm6Fq1km6IXOwA+kLz4qfDDT9bt/D V/8AEfwHY+I7u70iwtPD954w8PW2t3V9r/2MaDZW+lTail/Nd62dR08aRbxwNNqX26z+xpN9 qg395X+YR/wTN+Gn/BslpP7EXwI8X/8ABSbRvE3ib9tLxRf/ABV8I/ED4PeGPGH7Umu+I5dV 0H4n+OLbwRrS/Dz9nPxQNV8HXupeCNG8NaFHp/i648NNqGuXt7qw8MroWoaN4iP6S+E2/wCD KzxZceHPhd4g+EU/wmfXNNuvEGhal8YIP+Cgvw1N9plobrVbG/uPidqPi9Lo6br32zW4tDut U8ULpmqPoH9gGZbiDwhpl8Af3nGWISpAZIxNJHJLHCXUSvFC0STSJGTvaOJ54FkdQVRpolYg yIDJX85XwB/4I4/8G2Xx78OaLL+zp8Cv2UPjbpEmkWt5p8/gX9oPxt8TtYbT5IWljl1aeH4x a74k+2IiSrejXn/tS3nhuINQEdzbzxx/UOif8G93/BGHw/qlrq9h/wAE/PgrcXdp53lRa3N4 48TaW/2i3ltZPtWieJPF+q6Le7Y5naH7bYXH2a4WK7t/Ku7eCaMA/W/xL408HeDILa68YeLP DXhO2vZXgs7jxLrul6FBdzxp5kkNtLql1axzypGQ7xxM7qh3MoXmuKk+PvwJhe3jm+NXwlik upWt7VJPiP4OR7mdYJrpobdW1kNNKttbXFw0cYZxBBNMV8uJ2X4BT/ghr/wSCRpWX/gnZ+yy TNIJHD/DHSZFDCKOECJJAyQR7IlJigWOIymScoZpppH9Z/4dO/8ABLL/AKRp/sAf+Ib/ALOv /wA7mgD6B8R/tX/steDljfxd+0p8AfCyStCsT+I/jH8O9DWVrgXRgWNtT8R2odpxZXhhCkmQ Wl0UDC3l2cn/AMN2fsQ/9Hkfsq/+JDfCP/5r68vg/wCCUv8AwS5tZ4bq1/4Js/sC21zbSxz2 9xB+x3+zxDPBPC4kimhlj+HSyRSxSKrxyIyujqGVgwBr8fP2/wD/AINUP+Cf/wC218YvBnxY 8C6nf/sYafoHg6w8EeIvhZ+y98JPgV8Pvhl4ksdL17VNctvEtt4e8PeANBFh8Qb4a/q+ma94 v12bxfLqmlWXg/ToLDTrDwrHa6kAfuuf25/2JREkx/bE/ZYEMkkkUcp/aD+EoieWFYnljSQ+ LtjSRJPC0iKSyLNEzACRCfaPh78Vvhd8W9Kudd+FPxJ8A/E3RLO5Szu9Y+HvjHw7400q1vJb aK8jtbnUPDeo6laQXMlpPBdJBLMsr200U6oYpEZv5PNe/wCDLz/gmreeJ/h3e+HvjR+1bofh Dw1GqePfD194r+H+ua78S2g+zGGWTxSPh9pVn4PkuWglGqjQvCzxXEd5cLpUeiSJaTWv01o/ /Bpz/wAEr/B/iCHxR8MdY/a++EWtRaQujSah8Nf2kta8P391A2w3ss+qz6BqGsK2qPFBLf2d vqNvpLyQQm3023VAtAH9M9Ffz96J/wAEBovB+m6LYeCP+Cyf/BdTw9H4W0u20zwtpsv7eem6 v4S0uLTIGt9EtZ/Bl18G49Cu9D0u3S0so/D0ENhpr6ZZQ2caW7Frg5tj/wAEev8Agoj4Rtru 6+HX/Bf39uGy8Sy3Ojy2198Ufhf8KPjT4bgi0/Vba7vIpvCPiy8toZmvtOW9ska31SygW5nt brVbXW9Ps5NGvQD+haiv52vEH/BPb/g4EsLSD/hDf+Dg/wAP69dvdzNdweKf+CXf7KnhqCCC YyztLbX1jceNri4cXDiOOye0s7a3tiFgnSOGK2OMv7JP/By94W8R22raH/wVm/Y5+KmkSOZ7 3wz8Tf2OfDXgjRbQxm1EdlZP8OPB03iW9tLlYp3uZrjxVZXcD3EiW7spt2swD+j6iv5rJvhr /wAHYcNyUtP2hv8AgjJe2dv59vBPfeHf2mLK51CLzIxb6hf2lp8HLmKzvmiiLyWtjevZQyXV xEDcrHbSx1rH4Af8HU/iK6nuPFH7d3/BML4bwi5jFtY/Dj4O+PvHVrLaysTcPM/jz4N6Le28 tmFVbO3S8uhdK7/aryFkRiAf0uUV/M9af8E5v+DiLx1Jotr8Vf8AgvV4R8GaM99/amvW/wAH /wBhz4KLqWmSpbXgTS9D1m30H4barrWmmS4WzU69f20KIYtXu9M1K/061tpuwT/gi5/wUH1K 7u38Vf8ABwN+3ve2FklppfhC28J+DvBPge707w3YwBYLbxde2HiPUIfHXih7qS5mvPGdxYaL qWowPbW1/bXMlml1IAf0Y0V/Of8A8OQ/20fL8r/h/v8A8FMNvn/ac/2z4f8AM8z7V9r2+d/a Pm+R5vyfZd/2X7L/AKF5P2P/AEeuD/4cpf8ABWHQvEmqax4C/wCDjj9q7TtOmkji0XS/iF+z vonxUk0/TXgIvodUOs/HnS9A1fUpbtYZrLVrTwvocmn2yzWgtrh7hrtQD+myiv5rP+HRn/Ba n/pZC+Kv/iAfwr/+fzWgv/BJ/wD4LZLa3lmP+Dj34imG+WwWZ2/4J2/BZ7pBpylbc2d8/wAb GvdPaQH/AE9rC4tm1RsNqZu2AIAP6Q6K/m607/gk7/wWx0u6F5bf8HH3xHlmEF5bhNR/4J3/ AAY1i18u+s57GdjY6v8AG6+sWnSC5kezumtzc6deLBqOnzW2oWtrcw9P4O/4JN/8FZLGaZvi B/wcMftFeJ7dru0eCLwd+yD8DvAs0diljrEd9bzT634v+IiTXdxqU+gXdpepb28NnY6ZrGnz WF/ca5Zan4eAP6HqK/npuP8AgjP+3Tf2k0Gpf8F8/wDgoW097qcmuX8+k6L8ONCU6pcxMl0m mLYBbrRtBLvI9l4Xsr0aFp48sW1mJIUlrovC/wDwQr8VLeWet/FD/gs9/wAFtPHuup5/9p2X hr9t7UvhN4E1LzbaWGLyvCfg/wAINqWlfZp5TeRfYPFke+WG2hufPtI5re4AP30ryXxl8fvg T8Oprm3+IPxq+EngWezvbbTruDxl8R/B3hia11C92GzsLmPW9ZsXgvbsSIba1lVZ596eVG+4 Z/FC8/4NqP8Agnj4qtdQsfi545/bf+PFlrOq3ur69Z/F/wDbM+Mmv2viC4v5LSaddat9G1bw 7Ff5mhv5Wu5U/tS4k1zVXvL+5b+zTp3T+Av+DZj/AIIjfD6CJbL9iHQ/E18ILSG61Px78W/j z42nvpLN2kW6l07X/ihd+HrOed2P2tdH0XTLa6TbDNbtCqxgA/QPxL/wU1/4JveDYkm8Wf8A BQH9ifw2ksmoQ241r9qj4G6bLdXGkrbtqdrZwXXjqKa8u7AXdoLq0tY5bmFru1R4g9zCr+GX X/BcT/gkLZ3JtZv+Civ7Kbyi5ltS1r8VdCvrbzYVmZ3F5ZS3Fm1sRA4ivFnNnOzQpBPI9xbr LesP+CJn/BIzTjKbf/gnN+yLIZlCv9v+C/g/VQAFkTMQ1PT7wQNiViWgEbFhG5JeKJk9e+G/ /BMP/gnB8IJrW8+GX7BX7HngzVbOxuNMi8Q6L+zh8I4PFL6fdyrPdWd34rk8JS+JL+CeRIzL HfarcB1hgjbMcEKoAfNtz/wXw/4I42mtWmgS/wDBQv8AZ5e+vZ5LeGe28Q6peaKkkVpb3rNd +JLPR5/DunwGG6iSO6v9Vtraa7W5sIpnvrO7toOp/wCH4H/BIf7HY33/AA8W/ZQ8jUYnmt0/ 4W14d+2Roj+Wy32nfaP7Q0uUtylvqdraTyJ+8jjaP5q+qvFv7DX7E/j7RJ/DXjv9j39lrxr4 cupbee50Dxb+z78JvEeiXE9pKs9pNPpWseEbyxmltZ0Sa3kkgZ4ZVWSNldQw811X/gln/wAE x9d1G71fW/8AgnN+whrOrX8puL7VNV/ZD/Z+1DUb2dgFM13e3fw9mubmUqqgyTSu5AALYAoA 8fv/APguB/wSH006eLj/AIKLfsoSf2nKsNt9g+LXh3VRG7aVHrIbUDpdxeDSYvscqwtcaqbK BdVEmgtINchm06Orcf8ABcz/AIJA20E1xJ/wUT/ZaaOCKSZ1t/iXpd1OyRIzssNraia5uZSq kR29vDLPM+2OGN5GVT61/wAOnf8Agll/0jT/AGAP/EN/2df/AJ3NcZrX/BGH/gktr2rw63ff 8E4f2M4LyBbZUh0b9n74ceHNIYWshliM3h/w9oOl6DcszMRctcabK15HiK7M8SqgAL37Lv8A wV9/4Jt/to/EjxP8I/2ZP2rvAnxT8f8Agz4dX/xZ8S6NY6P468O2mmfD3StWtNE1fxG3iLxj 4T8O+GbqLRr/AFCwGtWFlrFzq2j2V9ZapqVha6XdQXkn8tX/AAUc/wCDjf8Aa3/bJ+O/iX/g nr/wQb+HPif4g+J0k1fS/EH7UfgTR7Txh4r8V6bpRgsvFV98GdJ1nSX8K/Dz4eaVPOdKn+Pf i+9uZNUbU7XUvAp8DyQeGfGfiL6i/wCCyX7Gf7Ln7EPhr4Kfs6f8E5v2d/gx+yp+0j/wWJ/a K8D/ALEHjf496DZ3Oi/8IH8DfF15penfE/w94Kn1S51PRfhxaePxrXhnw54i8M/DvTdFn8da JPq1va6D4h8X2vhqXT/3T/4J6f8ABID9ir/gmbqHiTxN+zT4EutL8eeOfhb8KPhZ468a61dw X2p+IbD4W2F5DJrkESWsMeiax8QtZvP+Eo+I39nSJZ+Jdd07Qrqa2jGiWCRAH8xn7D3/AAUR /wCC1H/BF74XWsn/AAWf/ZN/aQ+Nn7JvxF+Jmla1L+1d4g+Nuh/Hn4ufs9W3jOHRdNu7Txqm geNfirqD+AYJrWG90PwV42v/AIbaro/iHVNY0fRNS1O/1HS/CMP9xPw/8eeEPip4D8E/E/4f a7aeKPAXxH8I+G/HngjxLYLcJY+IvCHi/RrLxD4a12yS7htrpLTVtG1Gyv7dbm3guFhuEE0M UgZF/Fv/AIOOfj/8Gfgt/wAEkf2sfC3xRvtBvfE3x6+H138Hvg34Av57mTX/ABv8SvE+qaPa aLd+GdI05v7RvrnwBdT2vjy5utn9lWMmh2EGqSOdRs7C/wDvX/gmp8DvGH7NP/BPr9jH4CfE G6luvHPwo/Zs+EXg3xcs1tc2j6f4i0rwZpKavoQgvJZblIvDl602gQGbyHkg02OU2Wn7xY24 B9u0UUUAFfkh/wAFqv2a/wBn39tL/gnT+0D8FPi/4y+F/hfUB8Pdb+LfwY8Y+PfEdlpVh4N+ KngTw3r2s+BvHNhdrq+m3a2TINW0LVb2ye8huPCuueIbSax1WzuLnTrnyH/gs1/wRl8Qf8Fd x8AtF/4bT+J37M3w8+FU/jOD4i/Djwn4Pbxp4Z+MWj+MNQ8E3mL+yT4g+A7HSfEmiQeE7q10 fW/Eun/ETSrH+11uLLwxaPBqa698D+Pf+DW//gix+y1+zP8AGn4o+MfhX8Y/jBL8Hfgd8V/i De+Kfib8e/GmnatO3gvwXrfioa3eWvwt1X4NeETfaZHpTNbQf2fpGgSqCNXtpYi8yAH01/wb w/8ABQ39nv4u/wDBKb9jbwb4t+KfwN+GfxW+FvgK5+AuofDC++J/w80XxXfQfBS4vvCmjeKv +EQk1HSddjuPFvgrRdK8Z6tJdaOLq4vr/VtUnvNUhkOs3v8ARXX8T3/BCf8A4IA/8EzP2of+ CSf7PXxs/at/ZVl8b/HL9oDS/iL4i8XeN9T+J/xe8Oa5b6JpPxq+I+i/C+88H2vg/wAfaFo3 hSzm+H+keFNWZ9K02GbxILxj4pbV7KVNOg/q9/Y//ZI+Hn7E3wbs/gP8J/Fnxf8AE/w50TWr 3UfCFh8ZPid4i+K+q+BtGubDStPtPAfhHX/FUtzrGmeANDTSvP8AD/hmW7u7fR7jUdTFpKlv cR28AB9SUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABXyR+3 J+2h8Hv2AP2aPiH+0/8AG6fV5vCfge2srPSfC/hizXU/GXxD8b6/dppXgz4deCdLeSGPUPFP i/XJ7bTNOW4ntrCxje51bV7yx0fTr+9t/rev5qfgppcX/BUf/gqN8Xv29PiH4ilm/YJ/4JR+ N/E/7Pf7KHgLWrfVLbw347/a18C+HhqP7Rf7UfiHwxqhSAy/Ce/8SJ4G+GfiL7FqVnqB8OaH 4q8Ot4c8S+F9cXUgDH0/9hz/AIKA/wDBZ3RZvHf/AAVJ8cePv2F/2TL7UNP8VfA//gn/APsx eK4vC3xbu7O5tdVbTvEH7X3xZ1vwvqGt3vinTtM1Wztf+FcaHY6Ho8GqwyajqfhfwVr2lG01 Hwj43f8ABu7/AMEXrH4PfE7QP2K5dR8Eftv+EvhZ8Wdb+A3iD4WfthePPEXxmvfi5pXgbxD4 k8E2w8EX/wAVL7TtRit7u0t7K90vQ9A8M3d/4Ye/F3rFpcyHXrbx74Xap+2X/wAHQXjb4jfE HTP2hPih+wb/AMEhPg98TNQ+E+jfD34P32raV8af2zrjTZrPUfFcnjnxHDe6HZ6Jot74M1rR GuLTWbPx54E8Ha3eWGg2PgPxr4n0vxL4w0z8zf8AgsH/AMGxXxV/Z9+Fum2H/BOb9mbSv2iv CGrfH+58VReMdC174g6v+114C8FeIfAunaLB8JvFnhvUvEP/AArDx98J9L8Y6bf+IrD4heHt C0XxzoMmo6TpOu6Q+nReJvGGugH1f/wZtaX+0D4QuP2o/D/jf9i7w1a/Dy6+JHxJ8P8Aij9t a+fw3ZfHTwt+0F8NLL4Qx+LP2Xfidpmva/J8Q5fCceheOrXxp4cNloGkWOjeNp/HEN2PFl1q +v3fw+/vEuLeC6gmtbqGK5trmKS3uLe4jSaCeCZGjmhmhkVo5YpY2ZJI3VkdGZWUqSK/NP8A 4I9/sgeKf2Gv+CdP7NP7PvxI0rwpp/xi0bwa/if413fhWCZv7Y+KHjLULrxBrtx4j1u7vtTv vFvivRLG70nwbrHim41Ce11P/hF7dPD9vpHhW20HQ9M/TGgD8xv2pf8Agjt/wTw/a1Ww1fxz +zv4V+HvxP0G8l1Xwh8eP2fo1+A/xz8Ha7LeWl8Nd0f4jfDaLQ9Uv9Rt7m0WW0TxTH4i061e 5v5ILBJb+7km+P8Axh8e/wBr/wD4I53E2v8A7X/xE8Xftwf8ExLeDw/otv8AtXano2jXP7ZX 7JupXmoReHtKi/ac0Twhovhrw/8AtB/CnWb+90DT4PjZ4L0LS/iPpGtXmot4+8J6jAdK1fWP 35rn/FnhPwx498K+JvA3jbw/o3i3wZ4z8P6z4T8XeFfEWnWmseH/ABN4Y8Radc6Pr/h/XdIv 4p7HVNG1nSry703VNOvYJrS+srme2uIpIZXQgDvCvinw1458L+G/G3gzXtI8VeD/ABhoOj+K fCnijw/qFrq2g+JPDXiDT7fVtC17RNVspZrLU9I1jS7u11DTdQtJpbW9s7iG5t5ZIpEY71fh x/wRRj8Q/Aa3/bi/4Jqa/quqa5o3/BOr9qGTwP8ABDUtf1bU9b8Rw/sufH3wXovx/wDgB4b1 zU77VvEcF7L4M8N+MdS8KaPLb68lxb+F9I0HTdR8KeELjT10+f8AcegAooooAKKKKACiiigA ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAPz9/4KSf8ABOj4 Mf8ABTH9nr/hR/xW1TxN4F8Q+GPFug/Ez4MfGr4f3Q074k/BP4qeF5mfRfG/g2/LxxvI9pNe 6PrGl3TiC/0vUJbixn0jxLp3h3xHof5r+C/2Gf8Ag4S8H2elfDiP/gs98C9Y8AeGtCn8M6L8 U/FX7DvhXxh8adSsdJ0S4s/DGteKNM13xDJpeueKLq7g0yDX9Y13xz4hv5t954i1i+8ZawLm 21j+iqigD8NP2Kv+CGfwm/Z9+OSftiftZ/H74w/8FHv22IW8/Qvjn+0vLBd+FvhVftqk2rtf fAX4QzX/AIl0n4VyxXT2yaKf+Ek8TP4Is7C1074cS+DNOl1G0v8A9y6KKACiiigAr4u/4KN/ C/4v/HD9gb9sj4J/APSdD1v4wfGb9m74v/CTwLpniPWx4b0q41T4l+CdY8Ezs+uvJFBpd9ba brl9daPd3k0Onx6xBYf2jNFYm4kX7RooA+Ff+CY3wF8X/suf8E9v2Of2ePiH4P0rwH8Qvg98 APh34F+IHhrRPFz+OtLg8d6LodvB4y1W18StHHDd/wDCS+JDqfiaax08z6PoVxq8ug6HeX2j 6ZY3k/3VRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAHn /wAWfEOqeEfhZ8S/Feic614Y+H/jLxDpH7u3m/4mmi+HNS1LT/3N48dpL/pdtD+7upI7eT7s 7rEWYfht/wAGuUdtd/8ABEv9lHxXNM+oeK/Hviv9p7xh8QdfvL2fUdc8T+Mrr9qn4z6Tca/4 k1C7nuLy/wBcu9E0fQobm8vJWurq3tbWeZpHkMsn9BNfyifsy/FbTv8AggJ+2h8Tf2FP2lri 68O/8E6P2zvjXr/x0/YX/acvtPk0n4W/Afx38Sr4R+O/2XvipqMNvdaV4K0vSte/sCPwt4mv NR0vwtp2mTp458RHR7Dxf4m/4QQA/Or/AIKC+BPi5/wSO/4KO/C39mX/AIIJfGX4oeGv2kv+ CguoX/xM+I3/AAT81Dwd4D+Jv7OGlWV4PGSxfF3Qtf8AibPNF8JGhbwb4m1TUNHs7Of+x/BP hDV9W1bx54S+G/h3w94H1ez+0t/wRp/4OpP2z9VW4+N//BS39n/S9C1bTdP1efwL4D+P/wAc /hB8NdGvLZ7drPw7qHgb4Nfs36Hoeq67pL/v/wC17mx8S2zz2st0viu9u2hln/Z7/gpD/wAE p/2ifjd+2F8B/wDgrJ/wS+/aA+D/AMLv2vfhr8PLbwhqOi/FnRdQ8TfBT9oj4bXEd3d6Ml94 t8MnX7rQ/wC0fC+tat4Tu7jSPDd2PFvhvWNEn0/xn4FufDUGq6r8i6n/AMFmv+C8GuePfGf7 Gfwv/wCCKHhLxJ+2d8P9HtrzxT8XE+N2tXH7IljdSWOkeJpfKvPFWjfC/wAG3kn/AAjmv6Tp sei2f7W09/J4je5gtLq+vLW78P2oB+XXwP8A+DXH/guH8KPE3h/xL4U/4KdfCz4C3ng+4sp/ Cb/Bb48/tcavFohnOoWuvLZ2OreBfBUUdrfWM7Ne6ZLcXWmeIhreuaPqVtZ6T8uof31fCnw3 4t8HfC74beEfH/jNviN478K+AfB3hvxr8Qm019Gbx34t0Pw7p2meJPGbaPJf6q+lN4o1m1vd bOmvqmpPYm+Nq1/eGI3En8j37Hf/AAWU/wCC0vwz/wCCnP7N3/BPD/gq9+yJ8Afh9J+1ZZ+I NU8Fav8AD3U7Cz8WeHLOPTtZvdM8RWXiPwF8X/jZ8OPFPhbT7jwP4j0O+8HXdlovjFtS1m11 W68ZWljpUOj6v/Y/QAUVUv7+x0qxvdT1O9tNO03TrS4v9Q1C/uIbOxsLGzhe4u729u7h47e1 tLW3jknuLieSOGCGN5ZXVFZh+AX7XX/BWzxb8eNb+In7D3/BGHQ7L9rL9si/8N3WleIv2g/D mpaJdfsl/shwapPPo+p+NviJ8YLi5ufCXiP4heGbYXF94S+H3h5PFH2vxGtmupaf4hm0jU/A mrAFz/gj/wDEVv2g/wBuT/guf+0noNkP+Fb+Kf21fhV8BfCWuwWuqQWGvax+yX8A/D3wa8W3 VlNqFrAlyrtZaHqMsltLLGX1XzI44rKaxkuP38r8+v8Agl1+wX4c/wCCbP7FPwj/AGVdH8RS eN/EXhe31fxR8UviHMt0kvxB+LfjfU5/EPj3xTHDeSy3NvpkurXf9k+Hbe5dr2DwzpOjRanN d6ot7eXP6C0AFFfzj/8ABXj9pb4+/skf8FPv+CHfi/4b/F74g2nwh/aP/aG8WfsifG39n+Lx CLf4W+NLb4s+IvhN4R8K+PNR8Lw6fHHqfivwfeeOL/V4Na1nUr+50geHtCsvCNtoUWseOW8U fTv/AAXt/wCCiPxB/wCCZX/BOX4kftBfB/TbG6+MXiXxP4Y+DPwr1fVtN/tjRvBXi/x/DrEv /Ce6lpU1le6XqUnhHQdC1zV9C07xBEfDmpeKYNB0/XLfU9Oup9F1IA/Zuiv4k/2IP+CPf/BT f/go38Efhn+2H+3N/wAFs/2vfDFn8dfA+n/ELwZ8IP2aPiTq2jaX4d0Dxtofn2dxq2o+G/Fu lfCjw/rd1per6jpHiPwZ4O+GDpp1rI2i6j4lS6j1DQdN4z4pftDeOv8Ag3T/AGsrH4e+FP29 f2x/+CyXjr4yfD248I+FP+CZvxG8T+KPEvif4O6VFeaB4s0L4q6p8Wrbxd8XH8FeKBoWn6za eFfA/hT9mqC48deEdY1zV9b/ALF0rSPDmvkA/ufor+cn/gnZ/wAF2/iX+0N+174b/wCCen7d /wCwZ8Uv2Df2ufGnw+1L4hfDax8SaxPrHgb4qaLofhrUfGGrzaLB4j0Dwj4i0O6/4R/RvEd1 Y2elt8RNME/g/wAXaXrXibRdf0S60SP98fi/8VvA3wJ+E/xM+NvxO1lfD3w4+EPgHxf8TPHm utBNdHSPB/gbQL/xL4j1BLS2SS6vZrXSdNu5YLK1jluryZUtraKSeWNGAPRaK/Pv/gmp/wAF I/gb/wAFT/2dLr9pv9nzwp8WvB3gO0+Ivif4Yy6T8Z/Dnhjwz4tfX/CmneHtU1G8t7Twf408 faDd6JNb+JbCOzvrbxFLK11Df2lza2s9nIh8+/4KQfs3/wDBSD9puL4dfD79iP8Abk8G/sN/ DXUNO8Y2Hx68eW/wiHxL+NupJqcWl23hmP4Z3t9qek2Xh2OytxrbXmo6L4i8B+LrC/msL/Sf Fh8v7NbAH6i0V/IP4Z1b/gpJ/wAEMP2xv2IPg/8AH/8Abz8Vf8FM/wBjb/goN+0npn7MlhB8 drfU7X9on4J/E34ia34c0PwV4u0Txf4t8c/ETxR4l8MaRda1pw8T20ni248IyaTba1Fp/gbw l4l17w9qZ/r4oAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACivP/AAP8WfhX8TbnxNZf Db4l/D/4g3ngrVToXjK08D+MvDniy58Ja4sl1E2jeJoNB1K/l0HVVlsryI6dqqWl2JLS6Qw7 reUJ6BQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFABRRRQAUUUUAFRkS+ahDxiERyCSMxsZWlLRGF0mEoRI0QTrJG0EjStJEyywiF0n kooAK4r4ifDX4c/F7wdrnw7+LPgDwV8UPh/4mtGsPEngX4ieFdC8a+DvEFixDNZ654Y8S2Gp 6Jq1ozAFre/sbiEkAlMgV2tFAH4L+Gv+CLPxC/ZM1bV9V/4Jbf8ABQv9oH9jfwvqsNzE/wCz h8WdF0n9sn9lLTIG1S91a3sfBPw1+K2saR4v+GjLLfy2z634S+I8esyQQWC30up2UOo6ZrEV tc/8HLHw503UtJn0n/gkJ+0hDpT2CaF4wk1r9qL4M+OfE9rdvP8AbJfEHhODRtZ8CWOpaZIB 5o0jW9LsH0v7C9rHqOqS38Vt+9tFAH+fj+3b4+/4LEN/wW+/4JI6t8dbj9gP4FftJahofxM+ GP7PT+AdW+Jnxm+D/h7U/iJ4c1jwv468Q/E/wjrM2neM7XXNY0/4g6doHg6zspbbTJ9c0fTt Qi1y5sLG61GP+nDVf2Gv+CtXjT+17Dxt/wAFtLvw34e1m7mSew+AH/BPH4AfDDXLXQNT+2Q6 vouleL/iJ49+Ouu6PdxWNzFD4W8T6VNZeJPDl5bLqlxqOt3nlNB/Lz/wW3/Yh8NfsSf8F/P+ CbX/AAUC0HWfF2m/Cn9qb9tz9nTxt8X7lPCfjK78M/DXxx8Oviz8ILfxkqeObafWotan+KPh OLX/ABXD8P7G3t9XsoND8VQaVpF7oFzYWdj/AKElAH4ZaT/wb8fsUeLPFml+Pv2wfiB+1r/w UQ8X6RdtrWnH9tX9o/xv8SPA2keJrmW4k1DWNB+FXhh/A/w60+xuIbqXS7Twld+HtT8I6Tos Vnp+n6LE1pHdH9mvAHw4+Hnwn8Lad4H+FngLwX8NPBWkKy6T4P8AAHhbQ/BvhbS1YKGXTvD/ AIdsdN0myVgihhbWkQIVcg4GOzooAKKKKAP5hf8Ag5OZPC3iH/giv8XbXT9Nvdc+HP8AwWC/ ZibS/tttA0rpeX114mn0/wC3JPHqdtpt/eeBdM/tK2skMF21tZTXM8FxY2Al/cz9rqz/AGOP iX8MPEX7MP7Zvib4OD4dftBeDvFGmaj8Mvir8RtG8BXXxB8J+Gr7wunifUvDLXHiTw14o8zw TrXiXwRdy+LPB99aat4G8Ra14O1O01fRtavNBun7L9oH9l34B/tUaT8NdD/aB+GujfE3Sfg/ 8Z/h7+0J8OLHWrrWbSHwz8YPhXe3d94G8Ywf2NqemPfyaU+o6lZ3mias1/4b8Q6PqeqaD4l0 fV9E1K+0+45z9p39ir9kv9tHQ/Dnh39qz9nn4VfHrS/B13q194QX4j+E9N16+8KXWvWcFjrk vhnWJol1jQf7Yt7PTxqiaVf2kd/NpWj3V0kt1o+lzWgB/Bv8Tda/Z1/4JZ/8FQf2H/h1/wAG +37ZvjL40237Snx1sPDn7UX7GPgL4xW/7RP7PbaPeeLPAmj6HYya5btqHha41K/8J6x4+0q5 1zxF4u8U/Ej4U2Phi48R3PjfwdbPcSXn0z+zr+zj/wAF1P8AgnJ/wUY/4KJ/GT4Zf8E1PAn7 b/xe/a++LOta18Pf2tvHXxl8BeE/B+ifCyTx94w8Z6zZW0dx448Kx+HNO8c6bqXgyKXwRf3v gC+8L3vgDRdD0fSvEejW2i6fF/Xb+yv/AME1P2CP2JLy81f9lf8AZQ+DXwc8SagtzFd+NPD/ AIVg1D4gTWd4ix3Ol/8ACwvEcmteN00SVV50OPX00dWaR0sVeWRn+3ZZYoIpJ55I4YYY3lmm ldY4ooo1LySSSOQiRogLO7EKqgsxABNAH88P7Cn/AAS8/bC8V/t3p/wVl/4Kv/Ev4TeJP2uP Cnw/u/hR+zv8Dv2bItXX4FfAD4ea1oviTS9eLah40sb3xRqni69h8b+NLKCCw8RapY6fF4m8 SXmo+K/GEmtafaeFv2U/bE+Ctz+0l+yR+1F+zxYmxTUPjt+zx8aPg/psup3Uljp9vqfxJ+HP iPwfpt1d38Njqc1hBa32sW9y9/Bp1/cWIi+1QWdzNCkLs/Zm/bB/Zf8A2y/CniTxx+yx8cvh 58dfCfg/xdqfgTxNrvw812DWrLRvFOkrHJc6beFBHKsdxazQahpGpJG+la/pNxbavoV9qOmX EF3J9I0Af5jHiv4L/wDB0D8Nf2Cv2dP2NfhF+x18bv2efg7+xBfeKPF+q6v+zn4n8OXHxR+N fijxx8XvEXj3QdU1ux8G/EXxB4o+IFp4L17V9ZkTwZ8LNI1LR706td+L/iHper2cnhKXQP6k fCH/AAdc/wDBJ9rG70v49a1+0R+yh8WvD2sTeG/HPwR+N37O3xKf4geDNesINU/ta31aP4c6 R470mC3stQ02HT1g1DUNM8Sl9a0iW/8ADGmBNeTQv6Vqo/2Xpn9oPq39nWP9qywWdrJqf2S3 /tCS2086mbC3e98v7S8Fida1k2cLSGO2OramYVQ3915oB/IPrOuftCf8HAn/AAUJ/YR+K/w/ /Zo+KPwE/wCCWP7BHxntf2lNP+Pv7QPhjU/BHif9q34heGLjw9rXhqx+HPw21cfZ9Z8D3Xiz wpZeGLfU431Cys/B95471zxFr+l+K5NM+FT/ANg1FFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABXI+PfG3gP4c+D9f8bfE/xd4R8B+ANAsWuvFPi7x7r+jeF/B+iaZNLHZtca/r3iG7sdF0 2xlmuYbVptRu4bd5Z44CxeVVb8wP2mP+CmmuWnxa1n9kD/gnn8E5/wBtz9snRtSTQPiXa2mv SeDv2Zv2Q31CC0Nl4q/ay+OJsL/TdDntYLy913Tvgx4Ei8QfFrxxbeEPFPhvT7Hw3rzaM9/+ evxc/YZ/Zi/Zv8Ef8Nyf8HDf7cPiT9sC9j8QW1vB8PfiTZ+J7f8AYI+FXjvWYzqmh6B8Bv2P vAeg61P4n8T2nh/wzqPh5tZ8R6Z4lvfiFo9je65rvgi18Q3N1dUAfzY2lx4E/Yp/a48Q/G3/ AINYfjH8fv2pvEOsa9r3wv8A2jf2Ll/Zr+PXx5+EeieENA8U3LaV43j+MqeFtP8ACXiX4SXe rw6XY+Atb1TxrcfEPQrLV9R1rT/i7caZ42vtGg/X/wCK/wDwXe/4LxfsvfAzxP8AGr9qn/gj 78GvhX4N0fSzcx/Efxh8ddO+GHhbT7+50ia60zSpvCXij4ha34k8S+JdRu7eY6V4C0TV7Txl 4hnVfDOjadNrjxu/svwm/wCCp3/BQP8A4KZeHpfhB/wRG/YU039kH9mJNZ1LwnpX/BQr9ofR vCug/DPwV4d0LVotP1DVvhD8BNP8K33hDxT4qtY9PvdLs/DVhN8TtP03VLyzsfGOieFobS/1 PT/r34N/8G7vwP8AEnjPT/jh/wAFPfj78aP+CqHx9t7mTWLW4/aA8R67onwC8F6ze3EFzfw/ D74AaD4il8L2Hh0rAmnr4U1+813wRLaDzIvB2nsmnw6YAfzRfsWf8HMv/BZr9vb/AIKL/s7/ AAb+FPgP4JnwP8Rfin4M0rxb8DvAnwqlv9KsfhPZarby/E/xXq/j7xR4h1XxppDaB4JGs+It S8SL4l0zSLG6021a10MxyHRdQ/0ga8m+FfwE+BfwK0uPQ/gj8F/hN8HNEhtIrCHR/hX8OfB/ w90uKxhS3jhso9P8I6NpFolpFHaWkcVusIhjS1t1RAsMYX1mgAooooAKKKKACiiigAooooAK KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gD+aH/g7AbUdA/4JVWfxa0NbFvEXwE/a1/Zr+MHhr+0vNks117RfEuq+HNONxZxR51GAyeKi tzZNdacJLRp5VvRLDHb3H9L1fzWf8HaH/KFb44f9lV/Z9/8AVqaDX9IOjaaujaRpWjpe6lqS aVptjpq6jrN7LqWr362NrFare6rqM376/wBSuhEJ769l/e3V1JLPJ88hoA0qKKKACiiigAr+ VD/guR/wUJ/4KhfAb/goP+wF+w9/wTv8afBXw3qP7YGhNaLF4s8C6Z418X6Z4rTx5d6FrHin xg3iCHVtP0P4VaJ4TMHiC1u9E0R9cnfwv8QpJpL9LDTbAf1X1/Kj/wAFd/2F/wDgqGv/AAVy /Yv/AOCsn/BO/wCDXwo/aXuv2cfgDdfBfUvgl43+J3h/4d6rLqGral+0DpXi3VbiXxx4l+H/ AIbOka34C+PstroeqaT4zuda0zxJ4ae61Xw3e6db6fa6uAf1R2CX0djZR6ncWl5qUdpbpqF3 YWU2nWN1fLCi3dxZafcX+q3FhaT3Aklt7KfU9RmtYWSCW/vHja4k/GL/AILmf8FVfhf/AMEt f2SbnxF4z8H+MPHPjv8AaDsviH8Ifg/onhiw0G60uy8ZTfD7WruHxL46n8Q6rp1vb+DNFup9 KTVYNPtdc1fUHv4LW10aa2N7d2fxX4dvP+DsL9o9PsXiPTv+CZP/AATz8PXN5ALnXLey8V/G n4uaLomrT2d1LJpOkQ+L/j58KfFXinwlZwzadLDql34L8Pa3fXN/LBcNavpt5p345/tyf8Ee v+C537Y37ff7Mf7JP7YP7QHir9uT9gPwf8SNN+LNx+0/bfDb4O/Anw/4b8LeONQ0y/8Ajrp/ ijwX4K1nSPEVh420mS21vwf8OfCg8aeM00vwhf6JefDRfC2j32v+FPDYB8Rf8E3/ANorQv8A ghDpH7Jn7Zvwq/a4+GP7YP7IP7XPwo+G9v8A8FHP2WPhL8VPhNrfx3/Zl+M/ibSNd1nwVqTf Ca48QweMNPv/AANb6he6AL+9tdFtNZ1vw7458EeMNX0aDxB8L9eP9mP/AAVv/wCCl/jr9mj/ AIJC+M/+CiX7DK/D/wCKq6ro3wQ8QeAvHniRxqngrQ/AXxl8eeDfCsHxAuPDS6jo2oeKL6Ie LNO0DT/DMd9a3WjeJtdtNZ8RaffaR4X1/Qb36H0D/gjR/wAEnvDHhO+8GaR/wTq/Y8TStR03 X9JudSv/AIDfD7WvGYsPE1leadrEVr8Rda0TUPiBYSTWN/d2tpc2Hia2utKhlC6TNYiOLZ/N l8Bf+Caf/BSKf/gj5/wWU/4JUeJPhN4g8V+B/A/x81Pwx/wTbtPiHq3h/wAHXHxM8GaB8b4P ibc3vhHV/F2vaZpWn+A9Sv8Awr4Y+I3gnVvEus2WlS+L/Gniiym1hRZ3kGnAH0V/wRt/4OpP 2dP2tPCMnwt/4KF+M/hd+yl+0f4dUzQ/EPX9UtfAP7PPxY0aa8jt7e70vxJ4n1m4sfh14x0z 7RHFr3hrxXrEOjX9oia/4a165STWNA8M/NP7Qv8AwW9/aM/b6/4Lc/shfsQf8Eiv2kG8OfAn wn4pvtG+NXxHh8G+GvFfw2+Mt34Vv9X8afGTU9PfVvDfiO98RfDPw98M/BM/hrwR4s0258P2 PibxRrOrar4a1aHQLzwt43v/AL5/4Jyf8G9n7LXiL/gmV+yV8E/+Con7DHwdu/2lfhLD8YZP E1z4Z8XappfjqCLx98T/AIh61pNn41+LvwM8d6Xd+Or2Dwl4j0t7fT5PG/irwt4T1GKyl8ID SLzSLI2GB+1D/wAE7/H37Gf/AAWG/wCCUn7ZX7AX7E0Gr/sx+A/h/rX7H/7QXgz9n3Rvh/4Y Hgbw145n8ceHvC/j/wASaLqGuabf39rov/C09S8ceKfiK2lxSSp8PRpvxD+IUf8AwkejRkA/ EH/gqn8R/wDgut4Z/wCC3E37D3h39sD9orUvBv7Tni6f4u/syfDb9mL4zeA/2er7U/2btR1n xlfaD8PvDnifX9W+H/gzwX8Q/COg/C/xL4A1TXPHerT3Wv8AiHQJfGVzZeM/+Ezs9P8AE3Mf Fr9jz/g4g0z4s/DPwz+xR4V/4LafCHUNSvH1fxT4t/at/wCCqXw0/aD+HuqDxLM+vWdxq0fw 48OfDH4c+EF0bUdS8Wa14utPG3iD4g6rrOqa4I28L+H/ABJHPb+IP2F/4OJfEmg/szf8FU/+ CA37Zd1FBo9lpHx88e/Cz4o+M9S12DQdD0jwBJ4z+CMFp/bGozWd+bDTdM0D4l/FzWdTuPsk 0U2lwXltJNYsYrmv7DKAPBf2WtD+P3hn9m/4HaB+1V408O/EX9pPSfhf4Nsvjp448Jabp+k+ GPE/xRh0S0HjLVdCsNJ0HwrpkOmXGt/a/sj6f4X8NWVxEq3Nt4e0WGZNMtfeqKKACiiigAoo ooAKKKKACiiigAr8EvjX+198bf8Ago58fviJ+wR/wTS+J0nwr8BfBDxBaaF+3r+3tZ6VeXsP gWwvV0WaT4BfsdeJNMmvNH139pHXrW81m08T+NNWj0/Q/g7o+k6pquk6jd+Nn8MxHuf23vjn 8a/2xfjL4g/4JdfsL+K/E/gDVodMsx+3z+2t4IvdPif9jT4c+LNBvdX8O/DLwDNcz2kus/tL fGrTbc6fpMfh6+XWfg/4U1W38e3MdveXljqvhv8ATj9l/wDZj+Cv7HHwJ+Hf7N37PXg6DwL8 JfhfozaP4X0CO8vdTuv9Iu7jUtU1XV9Y1Oe61LWdc1vVry91bWNVv7iW4vL+8mfMcXlQxAHN fsjfsZfs3fsL/CSx+Cv7Mfw00v4deC4L251nWJkutQ1zxX408T37tLqni/x94z1661HxP4z8 U6nO7vc6vr2p3ksEHlabpyWOk2llp9t6D8c/2fvgd+058PNS+E37Q/wm+H/xp+GmrXdjqF/4 I+JPhbSfFvh2XUtMlM2mapFp+sW11Fa6rpsrPJp+qWgg1CyZ5DbXMXmPu9gooA5nwZ4L8IfD nwn4e8B+APC+geCvBPhLSbLQfC/hLwtpNjoXh3w9ounQrb2OlaNo+mQW1hp1haQoscFrawRR RqPlUZJPTUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAH89f8Awcl+G5fid+xx+y7+z2iWV9F+ 0/8A8FMP2JPgBdeHdSBi07xbb+NPHWr348OahqSQvNotld3GgQXd1qlvcafNFBYyWy3m26a1 uv6FK/ns/wCC0niCx8Z/tm/8EFf2Wrt7GN/Hf/BSqy/algee21Vbzf8AsX+AbzxFFHbapZ3A sbaCa++KljHcabe2c8+rXTaaYbqz06w1lLv+hOgAooooAKKKKACiiigAooooAKKKKACiiigD 5O/aq/Ya/ZT/AG3Lb4TWn7Ufwg0r4rxfAz4naR8YfhW99r3jDw3c+FfiBocbxWWqJe+CvEXh u81jSplaM6t4Q8QT6r4O1+S002XXtA1KXS9Ne1+saKKACiiigAooooAKKKKACiiigAr80/8A gpl+2p40/ZW+G3gP4bfs8eE4vih+27+1f4pvvhF+yN8K307U9XtbvxbDYw3vjT4veM7HSrae eP4S/AHwxej4i/E3ULmfTNOj0q2sdKvNY0hdaTUbb75+JHxC8H/CT4eePfit8Q9cs/DHgD4Z eC/FPxC8c+JdRkEWn+HvB/gvQ77xJ4m1y+lYgRWek6Lpt7f3UhICQW7sTgV+Pf8AwSt8D+K/ 2oPG3xR/4K+/tB+AvEPg/wCJ37UenR+Av2QfAvi7VFvbr4Hf8E+tGfSdX+GtjZ6KNPtV8PeM v2g/FMWq/HD4i3Au9RTUNL1b4e2FgulDTdXXVwD7K/4J4fsJeCf2AP2frP4VaP4j1H4ofFHx br+sfEv9oj9oHxTalPiB+0F8bPFt1JqHi/4keM7ue81O+kknnlXSvDul3Wq6l/YHhrT9M0z7 bfXUV5qN9920UUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRR QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAfzm/tmtrnxQ/4OOv+ COvw805rb+yv2af2Zf23/wBpPxCrtpTXA0v4veCb/wCBsBihud127P4k8O+GFRlhneOIXdzp gtp7W+vrT+jKv55PhL4V1H41f8HMv7XfxheGxuvDX7E//BNL9n79meZvNsBead44/aO+JGt/ HzwzdLFBqi37SN4S0/4jWkwutLnjS21K1e4lsVfQ31T+hugAooooAKKKKACiiigAooooAKKK KACiiigAooooAKKKKACiiigAooooAKKK4P4pfE/wB8E/ht49+MHxV8Uab4J+Gnww8I+IPHfj zxdq5nGm+HPCfhbTLnWdd1e7S1hubyeOy060nmW1sba6vruRUtbG1ubuaGCQA/EH/gqnqfjf 9t79qb9mX/gjr8JPEunab4L+INhYftd/8FHL2DUDpevaZ+xX8KPid4LsdA+F2j61BHLf6drn 7QPxNaPw81v4de28Sw6J4de41SWP4e6t4oi1H99be3gtYIbW1hitra2ijt7e3t40hggghRY4 YYYY1WOKKKNVSONFVERVVVCgCvxV/wCCK/wO8Vz/AA1+M/8AwUc+Mx1MfH7/AIKk+N9I/aU1 XQNZ0yzsbv4S/s/Jp15a/su/BO0uINb8QTX9l4T+GGqw+I5bq4utMuYr3xlLouoaFaanod3f al+iv7Z37UPg39ir9lL4/wD7Vvj6zl1Xwz8CPhf4o+IE2gW1zJY3fizV9JsHXwv4KsdQSw1N NM1Dxt4on0bwnp+qXNjcWGmXuswX+pKlhb3MiAH01RX+XD+2Lr37ZP7VP/BO6/8A+CmH7af/ AAUo+O/hv4hfth/FuRP+Cd//AATQ+D/iPxNL4X8UQab8Vb3wKuqL4B8NeINN0nTNL8KeG7jx dpnh/XrfwO3ivVbez8Oy+IPG3iDxX8QLHQLz/QS/4JOfCz47/Bb/AIJufsZ/Db9pvxX4w8Yf HjQfgZ4TuviRe/ECW+n8a6BrXiSOfxTb/DrxNc6lfanfXer/AAo0nW9O+F93eXF7M94/hD7S PKSVYYwD9DKKKKACiiigAooooAKKKKACiiigD8Ev2PP+CvHxo/ab/wCCxf7cn/BNnW/2ZdG8 EfC39lDwxq2saT8WR40+1+MrybQdc8C6Bp9/4l0JGudFvdG+KUfjJvFPg630Saw1jwpoVpaW Xie11DUrvUG0b9I/2+f26Pgl/wAE4v2X/Hn7WX7QMHjW/wDhz4Cu/DWmXOi/DrQbLxH411/W fFviCw8OaHo/h/TtW1nw3oX2u5vtQSWW51/xHoOk21pb3Dz6kk32eCf8Gv8Ag2z8P2Pxz+NH /BY//gpUNNj0+3/an/b48bfDb4fWyXN7JBb/AA6+El3qni+y1KwW40u3gv49eT4uaLYat4gt tXv7XVNe8H6hb2eh+FE06eHV/wCojxl4J8GfEbw1qngv4heEfDHjvwdrkdvFrXhPxloGleKP DWsRWl5b6hax6poWt2l9peoR21/aWl9bpd2syw3lrb3MYWaGN1AP5SbH/g4j/wCCg/7Q0I+K 37Bf/BCr9qf43fst/wBmXWt6D8VPiVrmo/DvXfiXpFtfpps154G0nw74F8ceFtSe2vjLZNa+ CPF/xUnuri11JY1gOjamsP6Y/wDBFL/gtJ8OP+Cynwk+KvjPw78G/FHwG+I/wR8UaBoHxI+H ereIn+IPhuCw8bReILzwLrvhP4nReEvBFl4nTV7Lwvraa5o0nhnRta8K6lYiG+s7nSNU8O67 rnzh/wAFhf8Ago18WbDxd4d/4JGf8Ex/Dt38Qv2+P2jfCn/CP+KPFvgLU4bTw5+w38INc+ya Te/Ev4harpWn6jB4N8SS+GJ7+68MWM0+g6p4M0NtO8eRyxalqXwz0fxr+kP/AASw/wCCbvwk /wCCWX7IHgb9l/4YXK+JNZtpZvF/xg+J8+mppWqfFr4t63aWMHibxpd6ctze/wBkaWlvp+ne HfCPh/7dfv4f8HaHoWmXmp61q0Opa7qgB+jVFfwG/wDBTX4+T/tC/wDBxHqn7AXxJ/a2/wCC nGn/AAU1T/hm/wCFngv4Z/sAeNbT4dW3wi8ffErwL4Q1vxhrvi+ya38WW3jrwj4fHiDRPif4 78bQeDtQ8UeH9IuvE/hmKyMHgawa8/Q79pT/AIIyftz/ALBPwj+Kn7T/APwTh/4LC/t/at4o +Bvg7xJ8XrP9nT9qXx7Y/HvwB8WI/B2g2+t+JfDd/bahL4Q+Htrr+t6b4fuE0jVtY+F2uvOs Fh4Wln02O8l8S2QB/XJRX5xf8Em/2/8ASf8Agpt+wh8E/wBrm18OW3gvxN4ys9c8N/EzwTZT T3Nh4U+J3gXXL7wv4ustJnuZLieTw7q91p8Pivwotzd3uoW/hXxDotrrFy2tQajHH+jtAH8/ 3/Bwr/wU6/as/wCCUv7O37P/AO0L+zn8OfhP478K+Iv2iNE+Hfxll+Jb65Pe22h3Xh7WfF2j eGvClhouqaSbG48b2vhHxTpWp+M7ptYHhNLWxW08O395rUN/pH70eHNe03xV4e0LxPo0sk2k eI9G0vXtKmlie3ll03WLGDULGWSCULJDJJa3ETvFIoeNiUcBlIr86v8AgsN+xnJ+3z/wTa/a v/Zo0jR7XWvH3ij4aX/in4QWs8Vp9of4x/De5tviB8NLCw1G7urFNDl8SeKfDlh4P1DWBeQx 22heItXivo77S7i/029/mQ/Z9/4LT/tQ/tbf8E2/2Cf+Cev7Attqvj7/AIKcfG34W618Ffjx 8U9LF1ptn+xL8L/hD4luPhLdfH/4p6tLHff2P4y8UeArDQPF2haws9uy6jqd3qWjCL4h3/gf wRq4B9x/teftCftEf8FMv+C0H7OX7DP/AAT9/aB+KXwm+CH/AATg8YT/ABj/AOCinxx+EPi6 907wZqHjJdb0ODTf2d9Yl0TUbHTPGPiK0h8NeJfhbqPg3V7/AFjSV13x58V7bxf4F1y3+C/i vTk+0f8AgvL+3D/wUq/4J4/Ajwr+1D+xP8JP2cfip8EPAU9zP+1PJ8XtP8a6r478G6beeJvB umeCNZ8G6d4b+JHgKyuPCmrXGoa14d8a3QtPEuv6M+o6Lq2n2Njp9vqmr6f93/8ABOH/AIJ3 fA//AIJqfs3eGfgN8I7SLXPEcsVvrvxo+NGqaVDZ+Pvj18VLtJJ/E3xH8cXz3eq6nLLqGp3d /wD8I7oN9rutw+D9AktPD1jqN6lrNf3vzB/wcL6i+l/8EXv+CgNylrp940vwasdOMOp2UGoW yJq/xA8GaTJdRwXCvHHqFjHete6TeqBPpmq29lqNqyXNrC6gH5yf8E+P+Dsn9h39pfTPA3hn 9rzQfEX7D3xO8Y6nb+H9G8V+OYLzWf2ZvGOrGeDT7640L4zw2sMfg6y0jUpo08UXXxO0nwz4 U8I2l9pdxqHju9jk1KTS/wCqTSdW0rX9K0zXdC1PT9a0TWtPstW0bWdJvbbUdK1bStRto7zT 9T0zULOSa0v9Pv7SaG6sr21mltrq2ljngkkikVj+HP8AwTE/4J/fss/Ff/gh5/wT6/Z2/aD+ C/w2+Onwy8Tfsr/D34tSaD4+8IaNqKaN4l/aG8NXPxg8R614Wv4rO11Xwh4sstR+KOt2tl43 8K3uj+MLadpNUt9eXVJpb+T8jPjbqn7SX/Bq14k8N/EbwF4v8SftYf8ABGz4wfFTV/Atj+zB 4n1e4X4u/sieNvG0XiTx5pMPwq8ca3batBqnhIxaL4kNnaa9rGnaX4ouPtWneKLPT/HGr2/x N1AA/sk8Z+NPB3w58JeJPH3xC8WeGvAngXwbompeJfF/jTxnrul+F/CXhXw5o9rLfavr/iTx Hrd1Y6PoeiaVZQzXmparql5a2NjaxS3F1PFDG7j52+AX7dn7F/7VXi3xh4E/Zn/ao+Afx98X eAdNstZ8WaH8Ifil4P8AiDdaVot/cCzt9a3+GNW1K3v9G+2vDYXGraZNeafZX9zZ2N7c293e WsM38oP7CP7L37R3/Byjpepft4f8FKfj9468N/sB33xk8RWHwH/4JtfBbxrqPhn4Z+I9E+HO oppiX/xZ8UeFdS0TXdUbS9dg1DRm17U9Psvirrmpx+JfEHhHXfhT4M1Pwvo13/R7+xv/AMEe P+Cbv/BP74na78Zf2RP2Y9E+EPxM8SeBYvhrq3iuLx98W/G13J4LS40G7m0mys/iR4/8YaXp Eup3nhnQ73XdX0ixsdb8Q3tl9r13UtRubm7luAD9L6K+Z/2n/wBsr9lv9i3wnoXjr9qr44eA /gZ4S8T6zdeHfDuuePNTfTbTW9es9Hv9fn0fTBFBcz3mpDSdMvbqKzgiee5MS29skt1NBBLp /szftYfs4ftlfDSD4w/svfGHwZ8avhvNql7ob+JvBmoSXMNhrenrC97o2safeQWer6Hq9vDc W1zJpms6fYX32S6tbtYDbXVvLIAfQtFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAH87H/B EjWbz4tftk/8F7P2jNUsbxdQ8R/8FK9T/Zrg1i5ZNVh1Lw5+x74Qb4a+Era08Trp9k19bWmg 61aX9p4cDXMHhDTNZ06zgnulvW1LUf6J6/ml/wCDZNrk/Bn/AIKlI8MC2a/8Fov20GgnW4ka 5kuW8K/A4XcM1obVIoIIIksnt7hL24kupLi6iltbNbOKW+2vD3/B1r/wRxuPHPxC8BfEb4tf F74H6n8PPEuveFbnUPiR8AviPrGl+I9S8Paq2kXsnh5fg/pnxV1eG2kuYrl7f/hKdI8M3XlW k32m1tpmt4ZwD+kCiv4UdN/4Ocv2StS/4LW/FH4u+OP2lvizb/8ABNv4Z/sgWfwn/Z90jwJo 37QMHgn4r/HrX/Evw58Z+Jvi945+B9xpvhq6PifRLDWvil8LdIv/AB14LuLO10Pwn4e1zQ1s 9T1GC/k/cr9nr/g5B/4JhftMfFbwH8Jfh14t+O8N/wDFPx34L+GHw08ZeIP2b/i3afDvxn8Q fHutw+GPD/haz8U6X4e1hNEuW8SXdho2oap4vs/Dnh7TZ76O8u9Yj0i01PUbAA/eSiiigAoo ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACvwg/wCDg2/1v4h/sj/Bb9hXwd4hfw34 w/4KU/tjfs8/seSa3p9zpMmu+Efhpr3imT4i/F74gwaFqF/ZXGt6D4b8F/D640jxDBYlmceK tO0t5Ip9YtBL+79fzh/tsBvib/wccf8ABG74c6rZ3N5oPwG/Zw/bX/aDsovsVrdWA13x/wCD b34cRXN5KtqLy0XTdQ8G+G9Rtrq5vJLWPV7bRobGC2uLm8e9AP6KNE0TSPDWi6R4c8P6bZ6N oOgaXYaJomkadbx2mn6VpGlWkVjpum2FrEqxW1nY2cENra28SrHDBEkaKFUCv42P+Cyv/BSn 9sn9sHxD+1d/wRO/Ze/4JV/GLx7488dX/wDwrXUfjd49l1uL4cp8PrfUtC1+z+MOiWMXhfQP D2j6PeSW1nqXg7xz4t+Jth4W0fUo9Gvbiz8T3dzH4ck/s7ooA/zTv+CaXgzRv+CLf7TWleO/ +CzH/BP7/goH47+O/wALrtPh5+yd+0T4W02L9ov9l74W/D+HToxpunfD7T7XUrTRF1nww2oe Ndd0+/8ACfjbx7d+GtN8WWsOlfCHwL4s0698Rat/T/ff8HN37D2oadqEfwt/Z6/4KGfGvxxF bLJonw2+Hn7IHjWbxT4ine5t7Yx2ba5qGj6TbW1oLgXuo3V3qCPDYW9wbG21LUjZaXe/0ZUU AfzGaJ/wUk/4LpftYfHr4FWH7Lf/AASQ1v8AZa/Zhf4i+GLb47fEj9uzU7Dw148k+G99r+ip 4m1bSvhvdeLfhl4t8LXeh+F7q+uoLPQdG+Kmtalq5EEGnIuk39rL/TnRWNr3iPw94V02XWfE +u6N4c0iGSKKbVde1Sx0fTYpbhxFBHLfahPb2sck0rLHEjyhpHIRAzECgDZoqOKWKeKOeCSO aGaNJYZonWSKWKRQ8ckciEo8boQyOpKspDKSCDX85X7av/B0t/wS1/Yl+Mniv4D6/qPxz+PH xD8Aa9d+FvH9v+zv4A8K+JdA8IeI9PijfUNGvfFfxE+Ivwv8Oa1e6bcSHTdSXwfqXiSLTdXg vNKv5be/sb2C3AP6OaK+bPh3+018Ovjd+yV4X/a6+FfijQbH4Z/ET4EW3xy8IeJ/iBPHpuhe HvD+reCj4vtpviSdHvr86CvhVGa1+IVha6hPd+HrrS9b055/tlg5H8cH/BEP/g5C/bR+NX7U 3wd+A3/BS3QNDi+F/wC2v/bGk/sk/Hew+G1j8KdFvPiZoPie98HJ4N0/VYpNL8L+OfDHiTxb pmpfDm2l0xNT8W6R8VJPDXhuZ76LxCyacAf3ZUUUUAFeP/tC+KvEngX4BfHHxv4N0vUtb8X+ Dvg/8S/FXhTRdGSSXV9X8SeHvBet6voel6VFDY6pNJqV/qlna2likWm6jI91LEqWN2xFvJ7B RQB/Mh/waMT+G5f+CMvw3j0OGxi1O1+OXx6g8YvaRzpcXHiRvF8dzazam0xMct8vhG48K28c lqFgGmwadEw+0xXDN/TPdrdva3KWE1vbXz28y2dxd20l7awXbRsLea5s4buwmu7eKYo81tFf 2Uk8atEl3bM4mTE8L+D/AAl4H0yTRfBXhbw54Q0aXU9W1qXSfC+iaZ4f0yXWNe1C41fXNWks NJtbS1fU9a1W7u9T1a/aI3Wo6hdXF7eSzXM0krdHQB/nX/8ABK79sz4tf8EWP2i/27NL/wCC j3/BPn9uj41fts/tNfGjWNZu/jv8FvhLbePIPixbaRNruua5D4UvtZv/AALoWt+D/EPjnWpP GcXib4cNq2najpOu6e1xolkPC2j6XP8AtN4t/wCC/wD+398TfButH9j3/ggf/wAFBPEPiDVP DV1H4R8cfHjwh4j+GfgTSvEuox6vp+la3LZW/gLV7fx9oOg6rDpl/qei6R408M3Wr266jpc+ u+FNltrU39VVFAH+cH/wQJ/bc/Yo/wCCYHx3/b/+I/8AwWA8S+I/2c/+ChPxI+KKWM978TP2 efjh4l8br4Y8RanrvjD4onStQ+G3gPxxaaLa+M/iNLZ6rr0R0vQLTXoNG8L6jpGseKNKEcWh ftN8fP8Agtf+1x/wUk0bUP2Yv+CGf7Kf7Q174g+JVrp2ian/AMFBfjR8P9U+E/wF+DPh7WNP vNU1zxB4e1vxDpepWkXiKXwz9iufCWra81n4imkvby58D+AfFeu2ugtdf1rUUAfBf/BMv9g/ wN/wTZ/Yo+CX7I3gjUP+Egl+Hvh+S+8feNGgNs/j74q+KLiTXviN4xjtnBnsdK1PxNe3sPhb SLqa8u9A8IWfh/w/c6jqculNqFz96UUUAfnb/wAFXf26v+Hbn7A37QP7X9r4Ut/G/iP4a6Fo mn+BvC2ox6x/YOq+P/HfinRfAngweKLrRIHurLwvY6/4istT11jeaM2o6fZS6HYa3pmsarpt yv8ACb/waaeIP+CiNr+2/wDEz4gfCX9nTw38Rv2bP2j7zS3/AGs/2j/GPggeC/D3w+tdC1Lx N4qmX4S+NII/Cmlz+L7zxV4nu9D1f4SeA9I8RaXqNy+iaxqPh/SvC/gy08VaJ/pH/Ef4bfD3 4weBvE/wx+K3gjwp8SPhz410qfQ/F/gbxxoOmeJ/CniXR7kq02na3oOsW15puo2jPHHKIrq3 kWOeKKePZNFG6z+AfAHgX4VeC/DHw4+GXg7wx8Pvh94K0ay8O+D/AAT4L0PTfDPhTwvoOmxC Cw0fQdA0e2s9L0rTbSFQlvZ2VtDBGM7UBJJAOur4x/4KK/s4TftefsJftb/s0WWowaRrXxk+ AfxJ8H+FtWvIdYutP0vxpdeG7268Eajqtn4c0PxN4jvtGsvF1potzrNh4d8P6z4gvtLiu7TQ 9OutUmtIm+zqKAP4Wv8Agj9/wXI/b+8C/sc/Dv8AZCuv+COH7Y37TPxK/Za8M+HPgb4Z8e/D vS/E3grwPe6B4PgvtF8K+Fvi1rHjD4cXem/CXxJ4L8LWHhjwuqy6l4jPiK30/UNYm0zwwbA2 F57/APFL/gmf/wAFtf8AguNH4KT/AIKhfEz4PfsBfsaad460Hxsn7GnwX02x+I3xd1eLQJJV i1PxV4og1TWtG0zxLrvh/Ub7TtF1rV/ib4it/Buo391qmo/AvTr+wfRNU/smooA/lp+Df/BD v/go1/wT2v8AxH8Pf+CVv/BVq1+EP7J3ifx5qnxEX4AftH/s2fDv423vhjxB4g0mz0bWDY/E O4sF1vULRIdK0m8srPQoPh9bXFzZQtrsWsXz6rq2t/Q0X/BPv/gu546kS1+J3/BeDQ/AvhsX 2iDUtG+Bv/BPL4DWeua3pNldWdxqq2XjvxBrVprfg7Wb1bNkgvbG01zTRJfXP23R7vSlOiXH 9CFFAH85vjz/AINzPhr+0udOn/b1/wCCif8AwUo/bOt7TVH1O6+HfjT46eG/AvwFuZU1GC9t XsPhF4N8Aww+HLxYbaG0vNQ8P+JtPnuQBPbfYJLfT/sX7A/sc/sM/spfsAfC6++DH7IPwd0b 4MfDnVfE93401fQ9M1rxb4nvNZ8U32l6Rolzrms+JfHXiDxR4q1e+fSdC0iwSTUtbulgtrGJ IEjzIX+saKACiiigAooooAKKKKACiiigAooooAKKK/m9/wCCn/wk/wCDiq+/bE8LfFr/AIJl /Hb4B2n7M9j4G0/Q0+B3jZvCtjt8TWVtO3iTXviRb+N/BWoS6/P4j1DW3Hhq98G+M7MaTpnh awt7zSdHvhPqHiYA/pCor+dv4XfG/wD4ObrDwlo+sfFz9iH/AIJoeLdYk1DVdK1Dwp4S/aD+ I3w28Ww21laWEmmeJb+5u774t+BU0/VJri6hWDSPEl9qs11ZXhuvD/hqxOnTX62P7en/AAcK aJ4j1iy8R/8ABBX4deO9CspdQsNO1LwL/wAFL/2bfB8GrS218kVpr1jd+MDrGqHRL+zinntt O1bwnoWtlLy0kvo9LuLW602UA8Z/4IY6y/wd/wCCln/Bfv8AY78cXek6P8Qj+3TrP7XnhDwp b29zb3WpfCn9oXU/EPizSdesnubezaez0vwt4j+E6apbx2cdnpt54q086dfavYajBdr/AEcT fA74KXN1f31x8H/hbcXuqalqWs6neTfD/wAJy3Wo6vrN/c6rrGq39xJpDS3eparql5d6lqV9 cPJdX1/dXN5dSy3E8sjfwpfG34Lf8HCPib/gs/8ADT/gqH8Gv+CVPiz9n7xDJ4e+GfhL4p/B fwx+2z+zP4y8N/HD4ZeA5rRPHvgT4h/Gm31/RvBuiW3xH8KeHdK0Cxi1/wAG3T+F9U8P+D/E ukaVrfiPSNGeT9xNX/4Krf8ABbfRDai9/wCDcTx5N9sjuJIf7I/4KP8AwL8QBFtrueykF0dB +DWpCxkaa3ke3ivTby3do0GoWqTWF1bXMoB8Wf8ABvH4g8FQ/wDBX7/g5A8Iw32g2/iQftZ6 ND4O0KDTNJ0W/h8D/Dj44/tZ+D/EdtoOmabZWUUPh3wpe6p4B0G+ltoUW5kuPDt3qMl3fXK3 T/2G1/I38L/2sv8AgoZ8FvjP8av2iPhV/wAGqGs+B/jd+0Td6be/Gj4laH+3P8K4PE3jy40s FoG1G6l+BcsVjHd3R/tPWoNGh02DxDrSx67r8WpazHHfL7H/AME1/wDgvf8Atcf8FCP28p/2 SdY/4JXeMf2ePAvw2u/i54c/aT+K+qfGTVPiRZ/BXxl8MrfxTo8ega1fN8Gvhr4Zk1XUfid4 ft/hq3huy1TVNdbUbzUdbs4ptI8N65LZgH9QNFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUAFfzXftvPbfD7/g5M/wCCM/jvV3ubbS/jB+zh+2b8FLC8u7RoNIi1vwl4F8Ue M7SC01R5Y4rnVNQvfFukaRPYRLPNaSanoheILq8U0X9KNfzvf8HGGnah8HfgH+yj/wAFKPCv he98T+Lv+CZ37Y/wd+Oes6fpstjBfax8E/HHiPS/hr8XfB6XFxcW95bW/iufVvA0F3daet/9 iisft2p6a+jWuoajpYB/RDRWVoOu6N4o0PRvE3hzVLHXPD3iLStO13Qda0u5ivNN1fRtXs4d Q0vVNOvIGeG7sdQsbiC7tLmF2int5o5Y2ZHBPkf7Tfgb4q/E79nP47fDf4G/EaD4QfGTx/8A CP4heDPhh8Vbi31O5Hw58c+JvCuqaN4b8awLo19p+qW994a1S9ttW03UbGaWfStQtbbU10/V RaHS7wA/zw/+Cyv7dn/BRi7/AOCrP7dH7S//AATO/aC/aOm/Z6/4Jz6N+z1oHx+1jwF8UNSv P2e/BHiaO60XwRqHh/XfhXquvnwP460a5+MF/wCJvDniTwVceDvEw1DWPCvxO8aX+kS+D/Dm veKLH1648RftV/8AB1/+2T+yhr/gbwp8Zv2ev2DP2S/Cvwqf9prxy3iu78I+Cv8Aho22t18X /FzVPghptjqfimyj+J9yNat/BPwombVvFnjDwf8AD+30D4g+O73wcvjCPww/7x/8Enf2DvgZ /wAG+f7MHx0tP2+P21f2eJPEn7S/jyLxV4w1rxv4j03wH4FuND8OaTfeHtN8LaIvxM1m2134 larqqa7q2q+I5o/D1lPc3GvxeHk0fUY9MXWdY+sf2QP+C2X/AASF+M/xl8N/sbfsWePJ9Z1O 9naw8MaZ8H/2WfjX4a+EEHiW8vNemvNAXVtM+E2jeG/DkhsdA1bxRc+LdXtNI+HV5osUt/be Nby5hvLa2AP27r+TP/g6U0bVf2trX/gml/wSr+GEN9q3xm/a+/bGsPH7W+hzPdXXg74TfCHw V4n8OePPHHibTLK5e5t/DeiaZ8U9R8bte6npd7pT6R8MfGepW6PeeGJGt/6zK/l6+AVva/tj f8HQf7ZHxnl1DTdb8Ff8Ewv2PPhV+zJ4HuNCjku7GL4n/HBdU8aeIbnUtWgn1HSo9c8OnxL8 ePh9rent/Y2ste6Xb6cbeWPwjq7XQB/Sl8OPh/4X+E/w88BfCzwPZXOm+Cvhp4L8L/D/AMIa de6nqet3lh4X8G6HY+HPD9ld6zrV3f6xq9za6TptpBPqerX17qd/LG91f3dzdSyzP/ky/wDB a/47/sRn/goD8Rf2Wvg9+w7/AMMw/s/fCz9sbUvEn7VHizSPt9v+0j+0P4p03XJdC+IHijwd qnxL0nxFc/Az4eXHh3VfGF18IPhd4ehuPh5qlzrelfFjXvCiahq1l4Y8N/6knx0+I/7U3gz4 xfs3eH/gj+znovxj+Cvi+/8Ai5P+058Q7j4oeFvBnir4QaL4S+Hc+t/Cyy8DeDPEt7pS+P8A X/ir49KeE4JE1K30jwzPaWo8VT6D4f1+88c+Df5S/iN/wTl/4KOf8HA/7Tvg/wCIP/BRT4Ca H/wTj/YS/Z6+IGo6l4d+ClnNa6v+0b+0R/alxp9jqbeK/EGj6xJGmpQeEfCmj+Ef+Fj6xZ+H tM8J6XrMkHwt8JeLXvfE2s6eAXP+C/8A/wAFJPht8H/+CfP7N3/BKv8A4Jp6N41vPiz+2Z8E fgr4T8BfBbwL8N/iLfePvB37DvjTwVPofhjwLF4b1i2bx5ZfE34wadp2ifDC2+HOuaJr3xBm 8E3HxHbxhp/h3X77wnf63/NV8cfht/wWT8I/8ERvhl4Y/aO/Ys1X4bfsufsYftHeG/id8Ff2 mPiOl18Nv2p/g6nxG1LUNItfDGieGda8VaZ8R7H4Rah8QPHugSW2sS+CdLgXxVqPgSDTNR1K 38F2beE/73f2bf8Agg7+zP8As7/8FNPjB/wUz/4Tbxr8R/HPjHTb3T/g18L/ABna2Oo+D/2d m1zR9K8PazeeCtZ1C51XxDdyaV4Z0688DfDXToJ9A8P/AA4+HfiLXPB9ho2p28fh698P+7/8 Fh/+Cb/ir/gqp+yDN+yX4f8A2kNQ/Zp0jWPiT4I8beMfEdj8O4/iZb+M9D8GXF5fWvgjXfD0 njXwI0miLr0+keM4Ta63bXX/AAlHg/ww7XCafFqFteAH3p+z58SF+MnwE+CHxeS5trxPir8I fhr8SEu7O2FnZ3S+OfBmi+J1ubWzW81FbS2nGqCWC2GoX4giZYheXQTz39er5x/ZA/Zx0P8A ZA/Zb+AP7LnhrxPrnjTQvgJ8KvBvwu0zxZ4kjs4Na8QW3hLR7bS11S9tbBEs7H7U0DSW2nW5 mj060MFiLq7Nubqb6OoAKKKKACiivz+/4Kv674g8K/8ABMX/AIKC+LPCXjvxF8M/FnhL9jf9 ozxb4W8ceEtduPDHifQvEvhf4U+Kde0B9C8QWc9rf6Tql9q2n2el2l7pl1barFLeqdLnh1A2 0igHyd/wSf8A+C1Pw7/4KlfFH9sn4OaZ8FfFPwI8e/sk/Ey48Nf2H4u8V2eu6h4++Hdx4i8S +FtE8cTaPc+HfB3iHwX4ph1nwnqdp46+Htzo/iCz8Cz6h4atZPHWuX2sva2H7ZV/mN/8G/n/ AATN/wCCpviP4SH/AIKv/wDBPL9ob4WfD3413PxX+L/wd1/4WftM6d4om+Hn7Q3wh0nSfhr4 l1K+vvFPh6x8V6jrjeJvii/iXw9fafq2n+EbrTPE3gHTvEWn/EPSrppri1/qh8Xfs3f8HGn7 aOgnwX8c/wBsD9iz/gm/8N5/Ed+2o3v7CPhT4x/EP9orxF4UXV9Q09tE1Tx98TvEdho/guRt ItLHXPDfin4X694f8QXM2qq3iTT9Ga1ufCsYB9rfAD/gtP8AsZftNf8ABQX4z/8ABNr4Rx/G PW/jv8B5PiJZeO/E138NpNP+E0Wt/CPxNL4N+Jeh2fieXWW8QRT+EvFaRaBNrWteENG8I67q V7p0PhPxH4gXULR5vzb/AOCy3/ByuP8Agkd+1ToX7L837D2vfHK71r4UeGvizB471L4+ad8I tH1DRPFOseI9Bsh4c0u1+EfxXvtVtrPWPCXiLSNSvdUn8Oyw6ppVxDa6feWhiv5PhP8A4M6P gz4Y+H/gf/gpp8ffENt/bvjGx+P9n8Gbrx7qGm6h4l8bt4Y+GWka3408SW1vq8VrcapqH/CT 6p4t0zWde03Q9Oh1DxLq+i6Jdara6lcWHhyDTvxr8Zf8Fhv2B/22/wDgvz4R/wCChn7WFn41 8FfsYfs5fCCPwt8GvAPi34bv8QvGPxJ1HwdpXiEeFNC8X+DfDt74u8PaN/afxK+KXjj4kxQy ak/h230rw3pOj6vejV9VupZwD/Rg/Yg/bP8Agl/wUB/Zm+Gn7VPwA1mfU/h/8SNNuJP7N1T7 FD4n8HeJNKupdO8S+CPGOnWV5fRaV4n8OapBNaX1qLmaC6tmstY024vNH1PTb66+sa/zPPgB /wAFZP2R/wDgkT/wUV+NXxK/4JheIfHn7Yv/AATN/ai0rS/iR8f/AIC+G/hb8Sfhxqv7KHiG HxPf3s9x4Bk+JXgrwjp+pyeAfDtz4rt/Ctm0uieDtd8GarpPg7xf43n1TwXo/jHTf6QPBv8A wdc/sVfFOwfWPgp+xT/wVP8AjroNpFpcWs+IPhB+yv4H8Z6J4e8QX+kWWr3ng/Wr+1+OsEdv 4l0KO+ittVggF1pkso+16JqusaRPZ6ncgH6Y/B3/AILJ/sR/HD9vz4nf8E1/BviH4k2f7Tfw rufHGnaxpniv4X+J/C/hLW9Y+HBD+MdK8MeINUgin1BtOsUutZ07WL3StM8MeKtCtDrXhDXd f06+0i41L84f+Dmb/gpj+2V/wTN+D/7JHj79kDxf8P8AwpqPxK+OOteE/Hsfjrwf4W8VRa/p mi6FpviLSNCM/inU7eHQPDepm31jTvFuq6dZW2pwWV7ZzWPjPwXeW9tPqn54/sPftUeCf+Ch H/B1Fq3x68E/BL42fC7Svh1/wTtksZPDfx4+H178Ovih4a1sad4JttS1zxh4OW51AeHlgX4t N4Atru61TVtH1h1tNS0HVtQ03WdAuZPCP+D17x/4p8dfEH/gm5+yR8P4/EfiLxJr8/xf8fz/ AA60Cym1S58YeKfGet/DX4Z/B2PTNKs4Jr/U/EYv7H4laFo1lZh5riTxHJbRwSzXEIAB/Sh4 9/4Krar8Q/8Agmt8V/2uv+CcHhb4c/8ABQj44fCDSrLw5438CfCrxJeaN4E8NfEfSfDGjeI/ ibqsln4outE8ceKvCXgrSdRn8R6D4U8HnUvGHxGtG0nQfDOoCe91DXtI7X/gid/wUw1z/gq5 +w9o/wC1B4s+F1j8JfGdh8R/Gnwr8YeHND1K81Xwpf654Pg0LUh4h8IXWpD+1Y9C1PSvEulo 9jqklzeabrVrrGni+1G2tre/uf5//wDgjJ/wUg/Yn/Y7/wCCQn7Rn7H/AIqu7j9kb9uD9kL4 W/tKeMPjv8Gfj0154H+IXxD+McumeMb+LxV4Nt7i20fXvFupmPTfCvhSbwZoWnf8J94IstG0 TSbrT7+wi0fxZrv6Kf8ABpP4C1Dwf/wRb+DniG8n0yW2+Knxe+P/AI90mOwtb+3u7bT9O+JG p/DCSDW5byNLe+1NtV+HGp3MV1pTS2CaNcaRZSSDU7PUYogDhv8Ag4V/4LJfta/8E5vil+yZ +zf+zPonwT+GEn7VttrKX/7W/wC0hpvirV/hl8NprDxboHhS+j0610KCfTLGXwHH4g0Xxd8Q 9f1vRPiJb6N4U8RaQyeBJJ7qC+fyL4Wf8E6f+CnH7ePw38K/Gbw7/wAHRHijxnef8JDZeK49 U/ZG+D/hOD4T2t1p19froem6jB8I/jR8HINf069sftFxr3g3xZ4T0zw7eXkiaZqvhjWIPD1r f3n7uft6/tD/APBLz4f6foHwe/4KQ+OP2U7HR/HWl3mv+Gfh/wDtRab4L1zRvEOnWN5FY32r aPovjjS9T064awv0t45bu1iFzZ3ItJN8Tm3c/wAp/wC1n40/4NAvB9tq+s/DVfFt98U/EOqQ +Frfwz/wTj8T/tJeHPF3iC60JtSu7PTdE8O2Hi3wh+z1eQ6/qnleHNK1S9UNrF9rumy6Zqaa XDd63pIB/Ur/AMEq/Av/AAUv+Gv7O+v+Cf8AgqR8VPhV8avjZoHxO1+y+H/xJ+GMVpBP4i+D cOj+HovDU3jmPTPBXgLSZPFUetx+Jdl3b6F/ad3oT6PJ4kvdQ8Q/2jfXH6Y1/nV/8Em/2df+ CxHx5/4KAfB34sfsz+M/+Cn37JH/AAS98B/ETw94s1LTv23/ANo7xV47sPFnws0C+eTxR8PN A+HfiPw74K8H/EAfEC0k1vwx4S+y/C7xfoPwylvxr2q+P9d8R+H7TVNS/wBFSgAooooAKKKK ACiiigAooooAKKKKACiiigAooooAKKKKAPCv2nf2gfCf7KX7PXxj/aS8eeH/ABz4q8GfBL4f +IviN4m8O/DXw/F4p8d6vo3hqxkv76z8M6Hc6jo9jeak8MbFX1TWNH0eyiWW/wBZ1fS9Ltby /t/5Z7v/AIOt/iR4u8D33xC/Z/8A+CK37d/xe8I6XZy6jqni67h17QvA+m6dLqL2ml3994w8 FfB74r6ZaWd9bT6U8t1cLFBBqN++m28l/HDbX9//AGG0UAfI/wCwh+0f8Qv2uv2Svgx+0f8A FT9njxl+yl45+K2h6zrurfATx/qd3rPivwLaWni3xBoegSajqWoeFPA9/dQeLfDmlaT440hr 7wloN5Ho3iXT4bqwjnjkZ/riiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAryH4/wDwO+Hv7TPwP+LX7PPxY0251f4a/Gr4e+K/hp43sLG7fTtRl8O+MNGu9F1KXStS jSSTTdXtILs3mk6lGjy6fqUFreRozwKD69RQB/Pr/wAG/wD+0T4ztfg18Xf+CX37RGr28v7V X/BKvx1J+zdrDSxW2mSfET9nTTHng/Zw+Knh7SFSCVPDNx8P7XTvCVkqpfXUGg6J4P1zxDqM mq+Mo/M/oKr8K/8Agqp+xl8fdK+K3wr/AOCrP/BPiwivf22f2UfDGreHPHvwUs9M06G0/bi/ Zk1LVtH1bxv8APEurLazaknizSNP07U9a+E+oR2ut3UHiGUWOk6TJ4l/4RDUtD+/v2Bv2+f2 e/8Ago3+z34e/aE/Z78QzXWmXUz6B4+8A6+kOnfEX4O/EXToYW8R/DP4meHFmln0HxToM8q4 O6XS9e0uWw8R+HL/AFXw/qum6lcgH8a37VfwE/4JC/8ABOf9vX426r+2Uf2qP+C2n/BSP4ye Kbbx98Kv2W9Y8A6t4msPC2g/ECTUNY8IeHfE9taXGpeF/Het6boNrdQxWtzaeJtN0zwdL4VT wt8BfD8VvHq1fsD8LfHn/Bxh8SIfhrb/ALOv7B//AATu/wCCav7K2keIPB7+H/gv8XvEuo+I filZ/DLVtWv9f1MTaH8GfM8FeA4F8PzWtnrngl/h34L8f6H4q1G5BtknfUoPD/8AS0vg7wgn imbxynhXw2vja40q30Kfxguh6YvimfQ7Oa6uLTRpvEAtRq0mlWtxfXs9vpz3bWkE15dSxQq9 xKz9JQAV+cv/AATh/YCtP2DfCf7SR1nxzp/xY+Ln7VP7XXx5/av+L3xTtvBtl4LufEWufFnx fc6loOjHSbS91JLDT/DXhyKyA0myu00Ky8Sar4rvtEsLOHWJzcfo1RQAUUUUAFFFFABRRRQA UUUUAFfH37ff7GHw5/4KF/sg/G39jr4r6x4i8O+CfjRoOjafd+I/Ck0EWveHdd8JeLvD3xB8 F+ILFLuOS0vl0Pxr4S8PareaRdhbXWrC0utIuZoIb554/sGigD84P+CUn/BOnwz/AMEtP2NP Bn7I/hv4k6r8Xv8AhHfFfj7xjrfxD1bw5B4Pk8Qax438TXmrr9l8K22t+JY9DtNJ0X+xtD8j +39Ua+utNutZMlp/aY02y+h/2z/jxB+y9+yR+0p+0TPBqty/wY+CPxJ+Ilja6JpF3reqXWse GvCmp6hodra6faaTrn/HzrMVhBNfX2lXWjaVbyTarr/kaHZahcw/TFFAH8pn/Bs9+zd8bvgB /wAEGPEXi74T6No2l/tJ/tL6l+0t8e/hBo/xL03WPD2k2/j5dDb4QfA6PxwdRsXvV8Fa/e/C Twv4yh1DT7K40278F+LYda02G8bUJZrvov8Ag2k/4I7/ABe/4J1/BT43eKP21/g98L9I/aX+ JXxptNe8MaxHqvhL4n+NvDngLwt4VXStIlbxto0uuaZotzqmv6/431GO28P63JqE1lqfma9M lxNHp9l/UjRQBUv7Cx1WxvdM1OytNR03UbS4sNQ0+/t4byxv7G8he3u7K9tLhJLe6tLq3kkg uLeeOSGeGR4pUZGZT/JN+0Z/wSN/bz/4JzftdaV+1R/wb8Q+HtE8B/HvU5rb9qr9iv4geKPC eg/s16fd2Go2l9pPjHw3oXifxN4fGnaJdx6hrFrYaL4Mt18XfDFY9as/h/q8Pg3xfJ4F0z+u SigD5B8J/sP/AAK8Fftq/FX9vnw9beM7P4+/Gf4PeE/gl8QCfG2ty/D/AFfwp4L1HTb/AEPV B4CeY6JH4stodG0jSoteZJJLDSrS8g0iDTZ/Efi251/5u/a3/wCCRH7M37Z/7a37IP7dXxX8 SfFrTvip+xfqfhzW/ht4c8HeIPCuneAvEuq+DPiHZfE7wfL4703WvBfiDW7220TxTb3N0YfD ev8Ahi5v47iCK4vQlmiy/qfRQB+S/wC3d/wRA/4Js/8ABRz4g6T8W/2nvgGus/FbS9Lg0O4+ I3gXxf4r+G3inxHotnCkGnab4yuvB2q6ZaeMF0iCKC10bUPEVlqGsaPYQRaVpmpWukhrFv0c +DPwb+GP7PPwo+HvwO+C/g7S/AHwp+FXhPRvBHgLwdo7XctloPhvQbOOy0+0+2ajc32q6pev HGbnVNb1q/1HXdd1Oe81jXNS1HVr68vZ/TKKAOK8b/DX4c/Eyxs9M+JHgDwV8QdN067N/p+n +N/CuheK7Gxvmhe3a9s7TXrC/t7a7NvJJAbiCNJjDI8RfY7KeZ8JfAH4E+ANbg8S+BPgp8JP BXiO1iuLe21/wl8OPB3hvW7eC7iaC7hg1XRtGsr6GK6gdobiOOdUmiZo5FZGKn1uigAooooA KKKKACiiigAooooAKKKKACiiigAooooAK/Mz/gqN+25+0j+wr8FvCPxO/Zo/YJ+LX7fnifW/ H2meG/Enw/8AhLqerWOq+D/DVxsMniK6svC3gL4n+MdYm1O+ktdA0u20PwTf2thc3sut63eW 9jpgsNV/TOigD+Zj4R/8Fxv+CiWu6DoF98XP+DfX/goD4bvdQ0+e+1GTwCn9trbm4nlm0aCH QPHvgz4d63aSvpj2Y1i21p9O1HS9S+12r6e5iCD0m2/4LY/tj+KrLTn+HP8AwQS/4Kaahqd/ I0v2T4oaH4P+DFhBpsWk3OqTzT6l4mkv5rXUgI7e2t9J1LTNOe7uppbCK5GsQwaXd/0PUUAf zv3X/BXD/gqfeaGNT8Kf8G9n7UOoX06lrTT/ABV+1B8GfBUbBWkRvtjT+FdX1nT23oNqTeH2 Z42EygxmMyO1j/goX/wX6vtNdvC3/BvVo2j308dlJZ3PiL/gqZ+yhrdvApd5LsXmk22neE71 5J7doYoImvrGWwnSWS5S73i2h/oerwrxX+1H+zN4E0n+3vHH7RXwK8G6H/bK+HP7Z8V/FzwB 4d0n/hIXvY9NTQv7R1fxBZ2f9svqMsVgul+d9ua9kjtRAZ3WMgH4jP8AtW/8HKfivw7NqPh3 /glP+xh8Jtas5bqNtE+KX7Y2k+PdQ1ZDpNhe2lxpkfw016z0S0hS/urrSZl1TxVDPc3+nXhW Gy0ltP1vUvir4Uftl/8AB178bf2mvgfoWu/8E/f2c/2bvgxL4g0K0+LN/wCMra3n8FSeG4rs XPi/XNZ8SD4z+M/H2mzvpSXFt4Y0vwTpN9fx6o9il3ba3E1zIv8AXjo2s6R4i0jSvEHh/VdN 13Qdd02x1nRNb0a+tdT0jWdI1O1ivdN1XStSspZ7LUNN1Cynhu7G+tJprW7tZori3lkikRzp UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABX4Uft4/8E1/jz4c+ N1z/AMFHv+CTni7wp8E/24bHT2f43fBvxJFJafs+f8FAfCehwTXmneAPjTokGpaPo2l/Ezd9 q0rwZ8W2n0XVLeTWZLXXPF/hjy9L8c+E/wB16KAPxU/Y7/4LafAX4z+LJP2dP2xPCmtf8E5P 249BmsdN8Qfsz/tR6jZeDoPGN1dW2mrb+IPgP8T9YTSPBfxd8J67qd5c2PhiPSb208X6smnX eo2vhe58Ptp+val+1dfLf7XH7FH7K/7d/wALv+FNftb/AAW8KfGz4eRaomu6dpHiJtX03UvD +ux2d3pya74T8WeGNT0Lxh4Q1saff32ntrHhfXtI1J7G8urN7lraeWJvx9P/AASi/wCCin7G Wn+F9D/4JQ/8FL9c8P8Awc8G2V5Y6B+yP+3r4Wsfj38INH0wTaQ+keEvB3xT0Tw9D8XvAfgv S0t9Uhs9J07+1rvTbSe00/TNQtbf7U8oB/RNRX4H6d+09/wcM/CTTNW0/wCKv/BLj9jH9r/x DaR2r6d4l/ZL/bj/AOGdPDGotJrerW1zFa+Gv2oPBvinXXkh0eTRLtjqWu6JEiWWpXUMl7e6 vb+HNC9BT9u3/gsDeXVlbWf/AAQh8RWEdzbau9zqHif/AIKVfsd2Gn6ddQtNFoNvc/8ACNL4 y1KWLUZFhm1m5stMum0OwleWxt/EV9ENNlAP2vr5K/bK/bm/Za/YC+Eeo/Gn9qr4ueGPhf4S gg1VfD9hqd/bP4u+IOt6Vpk+qv4S+HHhRZl1fxn4qureDFvpOkQS+T5sdxqM9hYCW8i/Lnx5 4a/4ORfj7qGpnwn4/wD+CbP/AAT88B6tBc2ukW+hRfE79rX47+E1n1SSSLUb7WPGXw78K/Bj XtVsNJW2trXyvDMWkahc/bri80mz+02kWm3PgR/wQQ+DsnxH8NftH/8ABSL48fFr/gqZ+1L4 Yulv/DXi/wDaKuZtL+Bnw2nj1K21OCz+Ev7NWk6vqPgPwrpP2mztri/0bWrvxT4e1DVo5dct tB0i9uWSMA5r/giR+2p/wUp/4KB+Pv2s/wBqH9or4Y2nwj/YA8deI7GD9hXwZ418H6f4S+Ll vomkarqdpLqML6bENR8U+GNU8Nf2dd+M/Fniq91TS7/4hP8AYPhNfnwxpfiKztP6FKKKACii igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAoor8/P+Cg3/BTr9kT/gmH4G8A/EL9rjxn4k8JaD8TfF1x4L8HJ4X8DeJ/HGoa jq1hpravqk01v4esLqKwsdMsBHNczXtxBPOZ44tNtr6VZkhAP0Dor+fvSP8Ag6F/4IpeIzBY eF/2qPGHijxXqDW1vofgTw9+y5+1Zqvi7xHqd1a288WjaHZ23wXbT7vUzczyaYIZdUt4Zb60 uGt55rB7S+uu90z/AIL9fsneL79tH+E37OH/AAUo+N+vw6fc6te+HfhP/wAE/f2hfEOt6dpV rd6bYy6nfWGo+GtFeLTxdapawG9jaW2imeO3uJIbi6sIbsA/Yf4s/DrS/jB8LPiX8Jdb1rxX 4b0X4o/D/wAZfDrV/EXgTXrjwr440HS/G3hzUvDV/rXg3xPaJJd+HPFel2mpy33h7XrWN7jR 9Xgs9QhRpLdVP8yPwt/4M7/+CS3giHU2+IGo/tQ/HbUtTuZpxf8AxB+MOneH104PcSSRjT4P hT4L+HkksrwGNb2fWrvWWurrz7qBbKOaO0t/t7xX/wAFYv21vEIl/wCGaf8Aghr+338Q/Ne1 0vSp/wBobxT8BP2SLW/8RT6gsTrdp4l8dfEPVdD8I/2VdafqEXjDVtJt1jvJdQ0vVdH0j+x7 29Xzu8/aa/4OQ/iEqW/gL/gmR+wz+zrcal9subXUP2gv2wrn4yaf4bgmlVdO0zxBZ/AxdCvt W1LT45A+pXugSf2fqQt52s1055IIWAP29+BXwT+G/wCzb8Gvhh8Afg/oLeGPhd8HvBHh34e+ A9Ak1DUNXn0zwz4Y06DS9Lt7rVtWub3VNVvDb26yXupajd3N9f3ck13dTyTzO59Xr+cGf9mr /g52+IGhTR+Jv+Ckf/BPv9n/AF6/8QSXch+Bf7M+q/FGDQtD+2NLFYaNqXxu8DpFqERtZDA1 prXhmXUUS3gT/hKZp5Z78/md+3j+wl/wc9eBPDPgO0/Z9/4KWftD/tl/FPx7faj4g8baD8Jv ht+zJ+yb8KvhxHp2JNStz8XvEfx38Ca3cT3N7qlqnhjwlpXwt0TQtX0xL+VJNLfQE0sgH9t9 Ffhr/wAESP2RP+Cpn7Mnw++Lmtf8FRP2xdT/AGjfHXxG1Twr/wAK++G7eLLv4jaZ8ItJ8Np4 hj1nUrjx7rWg6TqN7rvjeXVNLE/h/Qnl8M6Lp/h+0u5L7VtY1m4g0D9xjIolSEiTe8ckikRS mILE0SsHnCGGOQmZDHFJIssyiV4UdIJ2jAJKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKwI9EuY/FN54 k/4SPX5LO80DTdE/4RGR9Jbwta3Onajqt+fEdnH/AGQNdh1+/i1QaZqTnXn0m507TdKUaRFe WjXku/QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABXP+JP CfhXxjYxaZ4v8M+H/FWmwXcd/Bp/iTRtO1yxhvooZ7eK9itNTtrq3ju47e6uYI7hIxMkNxPE rhJpFboKKAOf8N+E/Cvg6xl0zwh4Z8P+FdNnu5L+fT/DejadodjNfSwwW8t7LaaZbWtvJdyW 9rbQSXDxmZ4beCJnKQxqvQUUUAFfyy/t1f8AByF8Tf2Jv23Pin+yg3/BLH9pX4veE/A2m6Q3 hX4p+HNU8S6Bd/Em7nsTqeqa/wCEfCs/wd1yw1n4eLEb/TrDxXpniy7EmpeF9bJtJ7adn0j+ pqv5nv8Ag7ZEcv8AwRn+J1kNVvrO/wBS+N37P1jpGkWOrXNg3izUpPHtvKnh6bS7aeL/AISm NLSG78QQaDLBfJHf6DZ+II7UXWg291agH1X/AMEwP+Chf/BRL9ub4sfEa9/aN/4JceN/2Ef2 YNM8Arqvw28b/Fzxvqf/AAtHxH8QU1/QrO28MX/w+8VeC/h54kudI8Q+GL/XvE6eIbLwhYaN 4Wm8OwaBc6v4kuvEdjeWn6++L/if8Nfh9Bf3Pj34h+BvBFtpWlf29qlx4v8AFugeGoNN0Pfd x/2zfy6zqFlHZ6V5lhfJ/aNw0dnvsrtfO3W0wTB+A3hjxJ4J+BvwZ8GeMrnU7zxf4R+FHw78 MeKrvW9fHivWbrxJoHhDR9K1y51fxQsFqviTU59TtLqW/wBfW2txrF20uoiCEXPlr+Hv7Wn/ AAbL/wDBOb9tn9tD4gftuftA69+014l8bfFC98L33jX4Yaf8WtE0f4S6pL4S8C+HPh/pkMAt vADfFjS7JtG8L6XM1jpXxXs7SxuVa00WHStCis9GtAD7s/4fLf8ABJ8+LE8Er/wUS/ZAfxC+ qx6IkUXx18BS6U2pSyrAkC+JI9Zbw2YzMwhN2NW+xrLmN51dWA/SmKWKeKOeCSOaGaNJYZon WSKWKRQ8ckciEo8boQyOpKspDKSCDX5g6F/wRO/4JG+HfDdz4U0//gnN+yHcaXdWlhZS3Wu/ BTwb4p8SLDp0aRW723jLxNp2r+L7O7kVFN/f2euQX2qyF5tTuLyWSR2/TewsLHSrGy0zTLK0 07TdOtLew0/T7C3hs7GwsbOFLe0srK0t0jt7W0tbeOOC3t4I44YIY0iiRUVVABbooooAKKKK ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiivNvj B8X/AIZ/AH4YeN/jN8ZPGvh34d/DH4daDd+JPGPjLxVqtlo2h6LpVpsQPc31/Nb2/wBpvbqW 203S7JZDdapqt5ZaXYRXF9eW0EoB6TRX8U3xS/4KJ/8ABcf/AILI+JNW8Wf8EN/B2pfszfsN +ELTUfB03x/+O+h/B/wr4q+OXxA0y88TjXr/AMG3vxB034g3un+FUt7fQdC0i3+H+iNq/h3x Jb3kvjvxpolxqkvhjwv6Lov/AAUm/wCCyX/BFq0+Cg/4LYeC/hZ+1L+yR8TfEVp4G1T9r79n i7vL34nfAjxPq85vrC3+LWkaZ4H8HaB45srPSor2K00vSfBOhaxrVpp2p6hpXxF8aeItKi8J eIAD+xSiuc8H+LvDHxA8JeFvHvgnXdM8UeDPG/hzRPF3hHxNot1HfaP4i8MeJNMtdZ0DXdJv YS0V5pmr6Ve2moWF1ETHcWtxFKhKuDXR0AFFFfhp+0j/AMHEH/BN39mn44fEv9m7Wde+O/xS +N/wh1uLw38QPAHwV/Z8+JHje/0LXTNbw3Wnf2rdaXoPh2/awa7tftN5p2sXemyyXEdrp97e 3oktkAP3Lor+bO5/4OIvFPi21v7z4C/8EVf+CynxWsrKO6shqmrfsozeDdEk8RpJbR2eky6r ouu/EKO2tJRqOlXd/eSRHVNJ0y8l1S48PyWdpLI36W/8E8v2v/2tv2trH4w6n+1D/wAE7viJ +wHaeBvEHhzS/hnD8R/iz4e+JGr/ABd0zVodfuNa1ZdH0fwd4RuvBsnhaKw8PJfQXB1/TNRu vEptdI128k0LUyAD9H6KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAC iiigAooooAKKKKACv5mP+C2njiD4q/8ABRn/AIIVfsIRWOpanb+Mf207H9rfxzpjXUH/AAjm qeGP2arR9b0rTNc0kSXjaxBPu8WX1xaapox0uSz0ya3jv0e5vZLH+mev873/AIKE/wDBXyb4 f/8ABzv4F+KfgD9lH4tftG3v7Evws8Y/sgeG/gr4ct7uy+I3jj4h6zo3xWuvHHxG+G+jWfhX xtqhV7P4m3Wk6Y1hpAufFngXw4msrd2Ol6yYwAf6IVFfzW/D3/gol/wcBftOW3h3Ufg//wAE Vfhh+yr4d1Oz03UrvxT+2l+1fJNi31BrYiyuPh14b8DfDT4x+G9ThtNTt9TvbbVvh9dy6XDo muaVfQL4iuNP0geu6n8Nv+Dlr4iHTI9Z/aV/4JKfs6QQXusw30vwP+Dv7R/xav5tLvltRpl7 dS/G+8t7LUNX0YwTfZbXT9P8L6dM95dS6nJqkZsrTTwD99aK/ANv+Ccn/BarxelsvxH/AODg HxDpunTWVhPfeHfg9/wTl/Zo8Az2GuQWVvFMNP8AHknibU/EWoaSbr7ZLPDeafZJqck0dwLH SYYoNOt7Un/BGL9p3xGYB8QP+C53/BU/UEvbNrTxSPhx45+GPwje++2LMdXl8LSaB4D1H/hC 5Zp7q5fRri2XVL3w/B9jtrS8mGnWsqAH75UV+I3w8/4IQ/s8aBqL6t8Zv2wP+Cp/7XGoiK4t LS8/aK/4KJ/tB/a9O06UW72ml2V58DNd+CF4un6VdrqOoWEFxPcE3uu6s9897CdPg0/ov+If n/gkrcT6nPrf7MnifxoNZjuU1Wz+I/7Uv7YHxN0q/ku7iO6uLu50b4hfHzxNpMmpSzoWbVDZ f2kEmu4VuhDe3cc4B+wWt69ofhnS7rW/Ems6V4f0Wy8n7bq+t6jZ6Vpdp9puIrS3+1X9/Nb2 lv8AaLu4gtYfNlTzbiaKGPdJIit4Vc/tgfslWe77X+1H+zpa7LS6v3+0/G34aQbbGx8n7deN 5viZdtpZ/aLf7VcHENv58PnOnmpu/PrQ/wDg30/4IyeHroXlh/wT7+CFxMGjbZrg8ZeJ7XMT FlBsfEvivVrIqSx8xDb7JlwsyuqqB6Fa/wDBEL/gkRaXNvdxf8E6f2TnltZ4biJLr4R+G762 aSCRZUW4sr22uLO7gZlAmtbuCe2uIy0U8MkTujAHoWof8FcP+CVemWkl7c/8FKP2DJIYmhVk 0/8Aa3+AurXZM80duhjsNK8e3t9MqySq0zQ2zrbwiS5nMVvDLKnBeJv+C2//AASK8J29zdar /wAFGP2SbqK1s7q/lXwz8Y/CnjS4aC0hM8qW1n4Ovdeu7y8dBttdOtIJ9QvpsW1la3FwREfS f+HTv/BLL/pGn+wB/wCIb/s6/wDzua9Zi/YY/Ylgljmh/Y7/AGWIZoZElili/Z8+EscsUsbB 45I5E8Ih0kRwGR1IZWAZSCAaAPhjXf8Ag4I/4Iy+Hb240/UP+CgvwOuJ7b7L5kmhSeL/ABRZ N9rhkmi+z6l4Z8Lavp11sSNluvst1N9imMdve/Z55Yo3w/8AiIq/4Irf9H+/Cr/wnPip/wDM BX6k2H7PXwC0qxstM0z4HfB/TtN060t7DT9PsPhp4Ls7GwsbOFLe0srK0t9Fjt7W0tbeOOC3 t4I44YIY0iiRUVVHonh7wx4a8I6f/ZPhTw9ofhjSvPkuv7M8PaTYaLp/2mYIs1x9j023trbz 5VjjEk3l+ZII0DMQq4APxe8O/wDBxX/wSX8d+GtT8U/C/wCOnxe+LOmaXc3OnSN8N/2K/wBt zxLFPrNra2l7Loceqx/s8W/h+21dbS/sblrTU9Y08RW97aTzyRQ3EMj9BoX/AAXF/Zy8b6Fe +JPhX+yz/wAFPfjFpFhLeWNxe/DD/gnD+1J4jsl1uyGkTP4dfU5PAthpNvrb2Gswaqtrd6hb xQ6fE0t5cWst5pMOpfs7RQB+PKf8Fgbe8sftei/8Ew/+Cw2sXLWOn6lDpT/sN6n4WvprO/1W bSj+98fePvCOlW19YG1utR1DRb7UrXXINKihvU02ZdT0ZNRZff8ABUr9oS/8My614G/4Iyf8 FP8AVtSudkuiaV440X9kr4cx3Vq1uhZ9bNz+1T4g8Q+HbtbzzoBYzeFb2Q2qRXjPG8xtIv2J ooA/CvV/+Ci3/BXnUrXR9U+F/wDwQB+KviDSL+01V75vib/wUK/Y1+D+u2N9ZyS22n28Xhi5 1Lxhqklpe3ULi4vNUXQ5rezaLUNPsNZt7iAyW9P/AGnv+C93iWS/1C2/4JYfsh/DfTxGJ9P8 PePv+CgS+JvECj7NbyNZTaz4A+DN7od3dm4eaITfZ9Ls1aJ1MjQrFeXX7k0UAfhxpnj7/g4x 1+7dB+zp/wAEkPAdrHbTTh/GX7QP7Umt+fK+qX621nDL4K+FWpyJc2+lDT/tLz2KWdzMs17D dW73f9iaY/QvCf8AwcdeKtBktvH3xo/4I4fCTWzrcapefCP4Kfth/FB10COK0c3IvPiV8VvC FiNQuJ5L+GbR28MSRJBaWU8HiSKW+uINP/cSigD8gPEf7Kn/AAWS1tIV0z/grz8APB5inkme Tw5/wSw0K6e4jeCCJbWYeLf2zPFKLBDJDJcxtbpBcme6nWW4ltltre31ta/Y6/4Kjapp81nY /wDBY/VfDdzJjZq2i/sBfswz6hb8MP3MfiK71/SmySGPn6ZPyq4wpYN+tNFAH48w/sI/8FOl +zef/wAFzPjxJsgtVvPJ/Ya/4J9wefcp5X26a23/AAOuPskFxib7Lby/bZLPzIvOur7yX8/f P7BP7d51hdd/4fVfte/bV0x9JEA/Zu/4J8DRzayXUd40reHR+ywPD76mJo1RNafTG1iO1Mlj HfrZSy27/rPRQB+LWof8EyP23tU0ddHvP+C3/wC3SkaXmsSrc6X8Lv2Q9Evvsuta5qOr3Nu+ q6T8DrTXJZ7eHU57HTJ31ZrfRIobC20Gw0rQ9K0nQrDlB/wSK/av8pwf+C4v/BS4zGSMxyC7 +AoiWILKJUeI/Cku8juYWjkWaNYljlVopjMjwfuhRQB+Ff8Aw6J/a0/6Tkf8FKv+/wD8B/8A 511V/E3/AAQz1Pxbe2t/qv8AwWf/AOC7lpPZ6ZZaTFH4Z/bs8JeCrJ7WwRkglutN8G/ADQdO vtTkDk3utXtrcaxqThZNRv7p0Rl/dyigD8Af+HBf/Waj/gv9/wCLG/8A8Tdda/8AwSA/acsx DZaB/wAFwP8AgqHa6PZWllZWEPiHxN8DfFWtrDaWkFuX1PxHdfCKyu9Zu5pI3mkv72A30/mB r24vLrzryf8AdGigD8PtM/4Ji/8ABQ3wa1x/wrv/AILsfthWkchtriFfij+z/wDsnfGp4r4r eW+pu8njH4cxh7C5sn05NP0uGO2g0u/tb3U2kv7jUIV05df/AGWf+C7fhfVor34df8FXP2Yf inpckWrRvoXxq/4J+aL4H+wj7Zpg0NpNX+FPxXurnXdQOnvqzanqEVr4X06O+tLRbbw5Pb6u 58PfuBRQB/ON4h8Sf8HU/wANJENh8P8A/gjb+0fo1rcu5XwrqH7TXgDxxrGmWsttZwxSt4z8 X+C/Buha3qtur6tMkKa7pWn3Ul/bRXc8EenWr/zL/wDBUf8Aaw/4Ktf8FCv+ChH7Jf8AwSI/ bP8A2XfBnhjSdC+PXwg+JHxN/Z//AGWNd8R+KbP4zeCNWktNS1Txpq3xAi8RajrGneF/B3wp vfH1zcXdvqfhjTfCLnW/E/iUQX/hvSNS0b/Shr8cv+ClH/BE79mL/gpH48+G3x11zxx8Z/2a /wBqX4SWkOj+Cf2lv2bvF1v4J+JS+Fo5tTkHhPX7i603UYdU0qzOua3caJqGntofijRbzUZ4 rXxC2g3er6BqoB+t/hXwt4c8DeF/Dfgrwdoel+GPCPg/QdH8LeFfDeiWcGnaL4e8OeH9Pt9J 0PQ9I0+2SO3sdL0nTLS1sLCzt40gtbS3igiRY0UD+az/AIOZf2+fgv8ADv8AYp8f/wDBPvwj N4X+Mv7aH7bFx4M+CPwv/Z5063Xxb4l0lPF3i7wpO3jnxJpFlMkfhbU7aK40tPhMNbvLDV9Z +Imr+FNb8PaTrmieHfE9zpRZ/wDBBz9vzTtMfQLL/g4f/wCCjp0NFkW0Opz6rrXiaMTX11ey m78Z6l8Xp/EF8376GGBmuoWtYYWtoGWwNtZWf3b+wB/wQ+/Yc/YA8T6j8YfDvhrxL8f/ANqn xFez6r4q/ay/aT1yT4pfGrUNXvEnW/1Hw/qWrxto/ga91E3uoDVdZ8J6XpvirxBBfSWXijxJ r1jbafb2QB9Nf8EyP2YfF/7GP/BP79kn9l74heIP+Em8ffBz4K+EvDHjjUotQfVtPt/F8ts+ seJdB0DU5YreS/8ACnhTWtUvfC/hG7ktbR5/DGj6RI9nZsxtovuqiigAooooAKKKKACiiigA ooooAKKKKACiiigAooooAKKKKACiiigAooooA82+L3wt0D41fDrxL8MPFGt/ELw74f8AFcWn 22q6t8K/iX48+D3jyC10/V9P1g2+h/Ej4YeIPCvjzwyuoPpyadq0vh3xDpd1qOiXepaPcTtY 6hdQyT/Cn4XeDvgr8O/Cfwr+H9vr1r4N8E6YNH8PweKPGvjX4i+IUshPPcn+1/HHxG8Q+K/H Hia8ee4meTU/E3iPV9Tl3BZbx0SNV9CooAKKKKACiiigAooooAKKKKACuXHgfwWPFQ8dDwh4 XHjcWU2mjxiNA0keKhp1wlpHPp48Q/ZP7XFlPHYWMc1r9s8iRLO0V42W3hCdRRQAUUUUAFFF FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUV84ftj/ABv1X9mX9kP9qn9pHQtD0/xP rf7Pn7N/xx+N+jeGtWuLmz0rxDqvwo+GPijx5p+h6nd2YN3a6fq13oENhe3FqDcwW1xJLADK q1/Pl8LP+CLGn/8ABVv9m/8AZo/ao/4Kjftl/tvfHnxx8b/2evgT8UNZ+BOmeL/BXwC/Z/8A h9feLvA3hbxvdeH9L+Cvw88DQafaa1aXt79i1zxLJe6br2tXMB1G+0/RdThsrLRgD+kPU/j3 8C9FFydY+NHwm0kWU4tbw6n8RvB9gLS5NwtoLe5N1rMXkTm6dbYQy7JPtDLDt8whT4Zr/wDw Ub/4J6+FYXuPFH7eH7Gfhu3jiS4kn1/9qD4I6PDHBLcR2cczy6j44t0SKS7litUkZgj3EkcC sZXVT8BfDf8A4NtP+CKHwwsbi00j9hfwV4kuL600m31LU/iR4++MXxMvrybSYbmJL+3j8cfE TXNN8P3d+93cXGrJ4U0/QLHUJjbLPZG307TILL7q8Ff8EzP+Ccnw4sTp/gX9gj9jXwtbyWmn WV3Jo/7M/wAGrW+1OHSYZYNPfWtTXwadS1y7t0nuGF/rF3fX0s11d3E1xJcXVxLIAeT+NP8A gtJ/wST8BR20uuf8FHP2OL5bu3u7mIeC/j38PviRIkdld6VZzLcw/DvWvFM1lcPNrNo9paXi QXeoWkOq39hDc2Oha3cadj6d/wAFtP8AglnrUUs+hftg+BfEMEOnjVJZvDnhn4l+IYkspIIL q1cyaL4IvkMuo2txFc6TaAm71eDzZtLgu44J2j/QHwj8E/gz8P5NKl8B/CP4Y+CZdCge10OX wj4C8K+G5NGtpLaWykt9KfRtJsm06CSznntHhtDDG1tNLAymKR0b06gD8ch/wXx/4JdT65H4 a0r4z/GPxFrtxfTafZab4Y/Yi/bq8RyapJbXk9ndXGiT6N+zZeWevWMDWl5OL7Rbm/tru2tJ 5tPkvB5Yk1bn/gtj+yBNqL6d4R+Gv7fHxGMFit/eXXgn/gm/+3DcwWEMmsLosIvINd+Begal F513caUIrgae9kz65pNl9qGqzz6fbfrxRQB+TKf8Fg/gzcxTS6Z+yL/wVR1gW13e2F0umf8A BL/9s+c219YLOLqyuGk+E0MUV3FdQiwltnkE1vdzRrdJBClxPB1Nn/wU6g1dIrvQP+Cf3/BT 3VtKurk21jqd5+yJqPgl7orZm9aeXw78S/GXgnxlo1sESSATeIvDWjLJeILSLfPNbJN+ntFA H5tR/wDBRbWpUuHX/gnj/wAFJQttEs0gk+AngGF2Rp4bcLbxzfGhJLqXzJ0Zre1WadYFmumj FtbXE0Wnp3/BQDxJqlpe3tt/wT2/4KJRQ2FxpltOmo/B74U6RdySatcSW1q1lp+rfHayv9St 4pImbU7vTra6tNFtzHd6zNYWssUz/olRQB+Zdr/wUb8bG10+71r/AIJj/wDBTTw4mp2UN9bR XXwn/Z88RXUYns9Pvha6ha+AP2nvGM+kXsUOpRRzWurx2LxXlvqFg3+nade28Gkv/BRPW3tZ rwf8E8v+CkQhguLa2dG+A/w+S7aS7ju5YmhsH+NS31zbotlMLm7t7eW0spHtIbyaCa/sEuf0 iooA/LvWP+CpGi+FjbN4w/YM/wCCouhW96zJZXGj/sR+P/iuJZY5rZJ0ubP4F6h8UtT0dYYb k3a3GvWOlWl5Db3MOnXF7fxizc0r/grF8GtQ1G0srv8AZZ/4KiaFbXMojm1fVf8Aglh+3nNp 1ghBJuLuLRPgRrOrPEpAUrY6Xez5YYhK7iP1EooA/Lm//wCCx37DGlSrBql7+1xps7faNsN/ /wAE1f8AgpPZyt9lvbrTbrbHcfslRufs2o2N7YXGF/c3tndWsm2e3mjTDuP+C3X/AATj02/0 aw8Q/E344+DDr+pR6Tpeo/EH9hn9vD4d+Hpb+VWdYrnxR45/Zo8P+G9NjWNHlmudS1W0tbeF GlnmjjVmH6xUUAfmBqX/AAWg/wCCYGjyQRav+194A0qW6g1C6totS0T4gWMlxbaTbG91W4gS 58HxNNBplmDd6hNGGjsrYGe5aOL56j8K/wDBbL/gkf4x+w/2V/wUU/ZL08ajdXlpaP4v+MXh X4fxu9haNeT3Ekvjy98Nx22nMsclra6rctDpl/qkU2jWN3c6vDLZJ+odFAHwJF/wVd/4JbTy xww/8FKP2A5pppEiiii/bG/Z3klllkYJHHHGnxFLvI7kKiKCzMQqgkgV6HY/8FAP2DtTtrC9 039tn9kfULPVbGPVNLu7H9pH4N3dtqWmTR28sWo2E9v4zkivLGWK7tZY7u3eS3eO5t3WQrNG W/M74Yf8Fev+CSvxo/4KF/FD/gnBH4Kg0L9p/wAG/FXxb8J7K88YfAfwrqPgT4tfEzwcmuXf j7R/Bfjrwe/jNrW+8NXHh/X7bWbr4qWPw6F3rGnXOm6XJqmpyQW8/wCg37U//BN79iz9sf4P eKvgj8bPgH4Du/CviqxhsZNa8H6DpfgT4geH1h1nRdeM3hDx/wCF7LTvFHhmS8v/AA/pcesw aZqEVj4j0mG48PeI7PVvD+oahpd0Adre/t4/sOabaSahqP7Zn7KNhYRWk9/Le3v7RHwhtbSO xtjMLm9kuZ/GEcKWluba4E9wziGIwTCR18p9v1Pa3VtfW1ve2VxBeWd5BDdWl3azR3FtdW1x GssFxbzxM8U8E8TpLDNE7RyRsrozKwJ/l/8AHP8Awamf8EZ/BXwr+I2taf8AA74k6tr+h/DP xZd6Nq2v/tB/FOI2mvaV4fur2w8QzR6d4m0TRzeR3lmss0N7at4d2z3Am0oQLCLfa/4NMPjf +0B8df8AglFHrPx/+J2tfFObwN+0J4++F3wk1PxJfzav4g8NfBvwZ4B+E8Ph3wVqWr3drFf6 hFoHiS88YHRGv73WJrDw1eaLo8F/FYadZ6VpgB/TbRRRQAUUUUAFFFFABRRRQAUUUUAFFFFA BRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUVBBdWt1532a5guPs8 8lrceRNHN5F1Djzbaby2byp4ty+ZC+2RNw3KMip6ACiiigAooooAKKKKACiiigAooooAKKKK APxn/wCDhXx3qnw6/wCCL/8AwUC8QaPLdw3eofBm08CTPZRPNM2l/FLx94N+GWuROiSRMLS4 0TxdqEF/KWKQWMlxPJHNHG0Mn6Hfsf8Ah+fwl+yV+y54Vup47q68M/s6/BLw/c3MUNzbxXE+ jfDTwzps08dveRQXcEc0ls0iQ3UENzErBJ4o5VZB+N//AAdSeIdP0X/ghv8Atfabeef9p8Xa 5+zd4e0nyYxJGNQtv2nvg94rk+1MXUwwf2V4Y1PbIqyE3P2eHYFlMkf7Z+BPDerXn7PHg3wh YeJb7wlrt18GPD3huy8YeHY9Kv8AU/DOrT+B7PS7bxLoUWt6fqeiXt9ot4yappker6XqGlXF xbQLqGn3do8ttIAeq6drOkau2oppOq6bqj6RqU+jasunX1retper2sUE1zpWorbSymy1K3hu raWexuRFdQxXEEkkSpLGWZrevaH4Z0u61vxJrOleH9FsvJ+26vreo2elaXafabiK0t/tV/fz W9pb/aLu4gtYfNlTzbiaKGPdJIit/C5/wSx/4Je/tKftFftTf8FRPAfxW/4LHf8ABTXw74d/ Zo/bO1HwB4hm/Z5+PXi34J+IPjd4zn8NSx3nxQ8Z6hP4k8faTpurXujaP4R8Oz6bp/h+4lXQ /DNjpsOtx2Vn4ftvDvun7QX7Ef8Awaq/BTV08S/tuftiz/tKeM49N8SX88vxU/bu+OPx/wDi UbY6imo3815of7O3i5/G9vdy6hf3EmlWR0y2uPE142rzW9pruoWOpTWoB/XJ4I/aF+AXxM15 vC3w3+OPwf8AiD4nXTZNZbw54I+JfgvxXry6RFObaXVW0jQdbv8AUBpsdyrW8l8bf7Kk6mJp RICtePft8/tX3X7Dv7I3xm/aps/g546+Psnwf0XSNeuPhX8OAyeKde0u98UaHoeualDef2dq sOmaR4P0TVNR8aeJdTubGeGy8O+HtUlCPOIY3/jD8C/tQf8ABnh8CP2nvgh+0d8Bbn4wfC/x 9+zx4rXX/B+rfDzwh+1sfAvinVLTTxpWkaz4t0Xx9Zat4l1W00lf+JjFBDD4eu9ZuWuF8WWP iC3vb2wuv7oNM1b4Y/tP/AyLU9HuT4u+D/x5+GlwLS6u9G1LSP8AhI/AHxD8Oy2zPPoXivSb HVLFNU0PVH36fr2i29xGk3lX2nj54SAfIn/BLP8A4KMeDP8AgqV+yXoX7V/gT4W+PPhFoer+ LvFHgiTwt4+m0q+upNX8Htp8Gs6j4e1rRpTZ+IPDB1G9n0uy1hrTS7qa/wBL1S2utKsZ7R4q l/b/AP8Agqf+xb/wTW8IQ63+0x8V9P07xxrulnUfh78DfCSp4p+N/wAT2lvX0qxj8G/D6wm/ tOTT73V4pdLXxRrR0fwlbXsNxbXeuw3ELQ1/J1/wST/4KiQf8EuP+De/40eJtZ8NWXj344fB n9vL42/sj/s+/CW/ka0b4lfGbxBpvw58eWtsbDSJP+Ei1bw54Xm8f694o8UWlg1vrV/YaHN4 Y03UtLvdX0O/j/cj/glz/wAEcbn4a+OtQ/4KMf8ABSbUdG/ag/4Ki/Gi+s/HeteNfEtiupeE P2YbS506yTQ/hj8GvD91nQNJ13wZp0Nvok3jbTNIsp/Dtpar4L+HZ0nwza6tq3jUA+qP+CYf /BTf4i/8FEV+KUvjn/gnz+11+xVp3gSLw9qPhLxL+0R4K1fQfB/xW0jxBda1ZN/whWv6z4d8 Kf2nr2hz6LI/iLSNIsdbsNJtr7TpJ9e867htn/Wiiv5J/gT8fP20vFH/AAdoftefs23/AO0h 8UL39lj4WfsxaR49h+BGueIbuL4UN4Y1f4Nfs6XWnyeEPAVxOPDcHinS/ix8Vlvrvx1oun/8 JjqVnpuv6ZqeryaPLqenxAH9XviXxHong/w5r/i3xLqEWk+HPC2iar4j1/VbhZXg0zRNEsZ9 T1XUJkgjmneKysbWe5kWGKWVkjYRxu5VT+EEv/B0V/wQqhlkif8AbnjLxSPGxi/Zq/a/niLI xVjHND8AJIZoyQSksUjxSLh43ZCGPzD/AMHHmoft3fslfCPxV/wUZ/Zs/wCCkvib4HfD34X+ HvhT8Pk/Yt1L4G+CviD4B+Lnj3xh8Sz4a8Ravd+MfEE2p2cFnqfgjxBb3l34R8WfDvxPpkh8 E6uLbxNpR8VQ2+j/AM8n/BAX9vT4yf8ABMz9rv4hfs2ft0/tMfCj9nv9jvwH+xm/7WXiT4Ve NLTw/wCHgdd+PHgr4I/tEfDnwv8AC7TrTwhY/Erxb8fk8N/Gy3E/wa06TWdUj06x+Ifh7QND 1a88NaPtAP6+vhT/AMHHX/BFj40+OtA+G/gL9uTwtL4u8UahY6ToVp4v+E37Qfwz0rUNT1PU LPStP09PFPxM+EnhDwrBeXl/f20FvbXOtQSyB5JlQwW9xLF9f/8ABSX9rnx/+x3+yl8Ufif8 Bfhdp/7RX7Ten6Ron/Ckf2Z7fWbqPxn8WtY1jx34R8H6vL4X8JeH7fUfG/jhfA+keKLrxtqn hfwbpU+teILTQW8PWV/o15q9tqtp/H38GPgX8dP+Dnr9t/wf/wAFEf2i/hRafsg/8Evf2YNS 1EfDKaCS30X4lfHl/CGq6dda7a3nxNe206bXov7b8IWtn8S/iTpUOneFPhvoOgN8J/h/fX/j zSPFnjvTfyy/4Oy/2lfhr+2J/wAFQfhb4T/Zj+LGmftFaB8Mf2bPAvwuurL4T6tD8QvC+n/G nWPiZ8U/Evibwv4RvvCg1HSfEviGbw3rnw5tfEZ8PXes3Frr1q/hDUp4Nb8M3ui6UAfvZ8DP +Cxv/Bcf9pTxPqvw/wDiO/8AwSN/4JbeLb7UIP8AhE/hx+37pf7T/wAGP2jPEmgWE0T63rfw 88D+NvGdxoni9bOW2uLO90/XtG8LatJpt02p6Zph06OLxLH+rmk/D7/g4u8T2fgzxn4Z/bW/ 4JQ65oj+GdNC2mh/AX406p4I8diO2hhtvF9x4ktPFd7qt3deJYJ5tav5fCOoeHPDUN9b2dvo WiW2lXc8cP5yeHv21v8AgqD/AMFRv2L/AIe/ADxH/wAECbP406dqvgrwN4f+Mfxa/bp+K+i/ Bz4O6z8R/CmlQaB4p+JvhX4W+KvD/hT4syLceMLHXdX0fVPAPiifxf4N84W1ld6hcNJfp8vf 8E8P+Dff/guh+xV+0b4L+LHwq/bJ/Ze/ZN+Cuv8AxM0HXPi38A/gz8Uvj58UfDGnfDDUdVI8 deFvD/w0+OXwj+IHgjxb4lsvDM97p3g+/wDHPjzXtTtdWls9a/4WHZatpdpqwAP2ovJ/+Dmr 4CeF4PEH2P8A4Je/t5pp/iSHWPEPw90Nfi7+zx8Z/EHhkJY2114O+HHi3XtS8P8AwR02+ufL ur+08R+P7ZDoVw10Li28XW97YaboX9BenTXlzp9hcajZLpuoT2VrNfact0l8theSwI91ZLex xxR3i2s7PALqOKNLgRiVI0VwouUUAFfy/f8ABcD/AILQeOPg/wCLNO/4Je/8E09MvvjP/wAF Nf2gf+KFt7fwRLZ3Vx+zjb+I9J03V4dW1Ce+ms9ItviXqvgzUtQ8R+Gn1HU7XQ/hpotjL8Tf iDc6fotjpNlrv9OeqWUmpaZqOnRahfaTLf2N3ZRarpbWyanpkl1byQJqGnPe2t7ZpfWbSC5t Gu7K7tluI4zPa3EQeJ/5/wD/AIJDf8G9/wADP+CWnxM+Jf7RPiT4v+Jf2rv2oviFc6xa2fxo 8YeFpPAI8GeGfEN5qF94m07QvCVp408Zw33iLxrcXlrL418YeINb1W+1BtJtI/D1l4Vtb3X7 XWQD+ZLw9+z83/BvF/wWv/4JgaTafH658Y+Jv2wvg94X8KftzfEP4twWmvaZqWufG/47alo/ xG1jQNQGdZ8NaI/iDQfCMmkeJtZ1TUtRgvvC2o+JfFGv32l63r+m23+j3X+ah/wcWeC/F/7b f/BVz9vrxr4M8TW3glf+CQ37BPwD8TWt/pXh9fEt18QtY/4Wb8PviINFeZPEy/2Dc6G/7VXi 7Vr7xR/Y+oWelN8Ko/DGq+Fozq0/iu2/0Gv2M/jvH+1F+yL+y/8AtIJ9kWb47fs//CH4s6hb WT2rQ6brHj3wFoPiXW9GdLK7vra2u9E1jUb7SL+xS8uG0++srixllaW3egD37xBolh4m0HW/ Deqo0mmeINI1LRNSjTy98lhq1lNYXiL5scsW5re4kVfMikjyRvjdcqf5V/8Ag0Nv7rwd+wn+ 1H+zD4ogisPiT+y/+3f8Y/AXjPTkdjIDceGfANvFfTQybZrVpPEugeMtISFkKmPQllErSyTx Qf1f1/MN+w7ruofst/8ABx7/AMFUf2RTpunWHw3/AGzvgh8JP29fh9dz/Zv7UHjPwzb+GfA3 xEtLSSxit/Mi8X+MPHHxO1u6ttShmltbbwJYT208dxfapc60Af080UUUAFFFFABRRRQAUUUU AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFFFABRRRQAUUUUAFFFFAH81H/B2nLFH/wRY+NaSSRo8/xZ/Z+igV3VWmlHxQ0W cxxKxBkkEMM0xRAWEUUkhGxGI/pXr+af/g7Vacf8EWfjQIY4njb4tfs/rdNJM8Twwf8ACzdH ZZLdFt5luZTcrbwtDJJaosEs1wLhpIEtbn+iH4Za/H4r+G/w+8UQ3Ol3kPiTwR4U1+K80QON Fuo9Y0Gw1FLnSBLa2Mg0udbkS2AksrNxaNEHtbdsxIAfyZ/scfsRfBv/AIKMfGT/AIL+fs3/ ABl8dfF7wx4Cb/gqtaeMdft/gb8Ub34b694gOjeDPGGi2nhvxjc6db6jB4i8EXF9eXt/d+Ft c0+70q48T+GtF1YRJq3hmzltv3C/Zp/4It/8Esf2TPDWkeHvhD+w7+z9JfaPeTanB49+JngH RvjP8VpNUu7Wztb27PxR+LNv4y8c2Vtc/YkuI9A0jXNN8LaXcTXj6HoWlx3dxG/wl/wTC+DH 7Qv7P/8AwWU/4Lj6X4w+EHxX0b9nj4/+NP2e/jz8JPi7q2h+J7L4LeJPFF74Z8QX/jXTPAWv 615eheJPFl/N8Q47DxqfCTagdEu/h2mieIJdLWz8OWM39F1AHNWvgvwdY6Mvhyy8J+GrPw8t zZ3i6Da6Fpdvoy3mn3NpeafdLpcVqliLmxu7CxurOcQCW2ubK0nhdJbaFk6WiigD/Je/Z/0T 48T6l4Z/4KCeDfDXjf4s/wDBPz9h7/guH4z/AGgvjt8JvAmn6V451rwboXivxR+zz4jk+Klt 4QgbTbTxtLe/Dz4enwjba/easNC8IatbaPPDJ4e0rxd4h1ab+nr/AILKf8F6f2Jv2k/+CSnx ob9gz/goLD8Of2g/F1v8P7jQfB2i3Hj74W/HLUdAh+J/h/TfiB4CFqngyXxRoN7qfh9dXW7m 0fWPDdlquiQS3E3jG48B6nqUOuf1y/Dz4SfCn4R2viCx+FHwy+HvwxsvFviXUvGniqz+Hngv w34LtfE3jHWFhXV/FniC38N6bpsOs+JdVW2t11LXdRS51S+WCEXN1KIk2+fS/sk/spz+LZPH 837Mv7Pk3jubWX8RS+NZfgx8OJPFsviCS4N3JrsniR/DZ1l9Ze7Jun1Rr03rXBMzTmQlqAP5 uP8Ag06/4KbfEj9s39lT4o/s2ftG/EXxn8R/2h/2UfFlukHiTx3b69rHirXvgl4286XwjP4s +IWt6rqV94o8WeG/GOn+NfClza6xb6fqmmeFdP8ABii8195NQbR7/wDwUa/4Jj/8FG/gz/wV QtP+Cxv/AASZ0T4RfGT4u/EP4faR8MPjv+z18atci8P6Zq40rwTpXw+HinS9X1jx98PNHuvD 2oeC/BXw/wBPm0Kz8W+GtY0LxZ4ah8R23/CSWuvanaaP5z/wbaWtr+0D+3j/AMFyP+Chvw/0 ye2/Z1+Pn7VX/CFfA7xPHZSWmm/EWLSvG3xQ8ceJvEsEF5Z6VqNjdy+H/FPw08UX1nd6aJor z4g3NheXU+paVeSzf2A0AfyZp/wSs/4Ke/8ABWL9pP4QfF7/AILda/8AAf4Yfsk/s965L4u8 BfsAfs1674i8Q+GviT43trzVYbHW/jHrN5rev6Xdedpc2nafq2txeLfFF5qPhU694Q8JeFvh OvjXxhqmofkB/wAHVH7D/wAK3/4KpfsAfFPxdpXxZ8OfBr9rPTfAHwH+Mmv/AAm8D/29faNf +BvHGm+ELK4+HlvHZapZ618QD8OvFujxab8O4dHa5vrLwZYf2Jbajc6rdQ2P+iXRQB/K58L/ APg0j/YF0HRtG8NfHX9oH9tr9prwb4ZlWLwv8MvHfxth8LfCzQNKhtDDa2OmeF/AvhzRdY0+ aC5lnuvtGleKtNttqWVvDp8CQ3z6lzX7e/8AwbP6HL4y/Zp/aP8A+CN2vfBH9hT9pb9la70a TwVpfinwpqGrfDjxpd6d4ln1yx8a+OPFWpaB8Xtb1Px54XW9u10/U/F3w++Iw8VWUdn4d8Qz 2thZ6XfaV/WRRQB/LBoPhH/g7yu7L/hDNQ+KP/BKLTJ7bT9RsP8AhbWvaf8AEGS91G5S3W1t tb/s3wx8OtQ05NQmkQ6lp0X/AArOx0oXEzR6tpEVoFsIoPij/wAEU/8AgsP+2j8P9H8Dft0f 8F1fER8JTPqmoeJ/hd+zX+y14G+GWgvqEs1hLpOny/EDwNrnwf1zx7oVo9ubhbbxz4OmWwkt UWxtmuNTvdQh/qmooA+Ff+CcX7C/h3/gnN+yh4C/ZY8M/Fv4q/Gyx8Gz6nqM/jv4ua42ra1d X+sSQyXOm+HdMR5LDwZ4G0sQR23hfwXpctza6LaCR7i/1XVbzUtWvvuqiigAr4G/bB/4Kh/s E/sC+NvhB8Ov2vf2jvCvwU8X/Haa/j+G+ma5oPjnW7e8tdM1fQ9Cvdc8Vaz4P8LeItD+GvhW LVPENjbr4v8AiXqXhDwtOlrr91b6xLZ+FfFFxo/3zXwd+2b/AMExf2Df+ChMvhK7/bE/Zv8A Bvxo1XwLpuuaN4S8Qahqfi/wn4p0XSPEULxappVt4r+H/iPwn4kk00ySPqGn2Nzqk9ro2st/ bujRWGtYvwAf54P7aP8AwU4+BXwj/wCChn/BwfofhzxzZ/F/4R/8FAv2bJfhD8JfiN8CdW8I /EXwVq/xSi8J/DC38Kahc+L9P123sJvAlrpOpfE7RPEms+GNV1wR6xDbWA0TWY2+2aZ+63/B NX/g5J/4Jq/si/8ABL39jP4F+MvHnxV+MP7S3wz+DFh4D8RfAv4MfBb4ha34qtNd8P8A9rto mhReJfFvhX4cfDfVJLnTItLsBceH/FfiCO0uZGF1qGqRW1zrVz+rfw//AODYL/giv8Nvip4f +K2hfsmT6pd+Fdd07xHoXgjxt8Xfi/8AED4aw6ppNxbXdgNY8HeNPG2uWnjHSUu7ZZrvw544 n8S+HNYjlnsda0nUdMlNkP2w+H/wT+DPwm83/hVfwj+GPwz86B7Wb/hX/gLwr4M822k+xeZb y/8ACOaTpvmQSf2bp2+F8xt9gstyn7LB5YBk/s8/GBv2gPgd8LPja3w2+JfweHxR8F6J40j+ GXxj0G08L/FDwZBrlqt3b6N428O2OqaxBoutxQPHNPpzahLdW0c0Ud9DZ3ouLK3/AJwv255Y /hN/wdHf8EfvietrBbWfxz/Zc/aC+AXiK8tWuZ9R1OPw14e+NniDw9bXFj9ogsreCx8V+O/D UraoEluZrB7+G4SZdL0xYP6oa/j7/wCDpD4t+Bf2V/j5/wAEV/2zdVfR7nxR+zj+2Pqev6vo KTTR+J9e+EMl78M/E/xBht0t7XU9unLaeB10u31CfR9UvdK1XXop9Bt2lm1S3ugD+wSis/Sd W0rX9K0zXdC1PT9a0TWtPstW0bWdJvbbUdK1bStRto7zT9T0zULOSa0v9Pv7SaG6sr21mltr q2ljngkkikVjoUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUVxPw+k+I83h2S b4qWfgnTvFkniHxc0Wn/AA+1LXdZ8O2fhQeKtYTwHFJrHiPStB1LUvEL+CF8P3Hi6ddD0rTY /FU2sWmjW0ukW1le3ZQB21FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUUAFFFFAH5k/8ABX/9j34C/tx/sFfF34G/tKfHW2/Zm+FLXvgzx1rHx11TxD4f 8OeHPh1d+CPFWl6vYat4quvF2s6B4RuvDt3Ir6Ne2fiTVrKxWXUra/tLm11qx0q7t/oz9hz4 UfBv4Efsg/s6/BL9n3x7Y/FL4PfCP4VeFvht4K+I+neKNL8ZW/ja08E2S+HdT8SyeIdDvb/Q 7q+1XXdO1S61S00OaPRdH1OS70bSLHTNO0+2020g/bb/AGK/gT/wUF/Zx8b/ALLX7R2j65rH wu8dz6Bf6iPDGv3fhjxHpmseFtcsfEXh/WdE1m0WYW19p2q6fbyiK8tL/TbyAz2eoWF3aTyw t+RvwT/4NpP2Mf2aYNUtf2cv2ov+Cl/wAttblkn1q3+Cf7afi34VQavPMljHLNqkXgTw9oMe oSyx6ZpqSSXazO6afYqzFbS3EYB/RHRX4l65/wAEVG1RNBt9K/4K2f8ABbTwnYeG5IbrT7LQ /wBu+LUXudRi1S41Rr/XtY8ZfCbxX4j8VRzfaDp02h+J9a1fwr/ZcVvaR6BH5KyVqQ/8EefG cEUsKf8ABY7/AILQMkzBnM37TPwEuJQVgurYCKef9lKSeBfLvJWKwSRq06Wt0wN1Y2U1uAft BRX5DWX/AAS4+NelabYWWmf8Fjf+Cqf2iCFor261rxl+yF4iF0xttSkR7f8Atb9j6bULcrrN 7b3bNd6pqUz6PanQhOgGn6jpeNYf8E0P2yraK7trn/gtl+3vc28sdqlr5fw+/Y2ju4HTxJqU t689/efs66jczi48C6rc6BaiBrGSz8YRab46llvrDR9H8E2AB+yVRyxRTxSQTxxzQzRvFNDK iyRSxSKUkjkjcFHjdCVdGBVlJVgQSK/GTV/+CX37X03jCzvdB/4Laf8ABQnTfAKXelPqHhrV /C/7JOt+MLmxhkhOt29n44sv2ffD+i2N3qES3CaVezfD3UYdHklhku7DXVgeK59Xsf8Agmp8 QI5hLrn/AAVT/wCCpHiiKNoHt7W++Kn7MnhyGCWG7t7lnL/Dz9kvwVd3q3CW5sp7fVLm/tPs lxcCG3huHW4QA/QH4UfB34RfAbwRpnwz+Bvws+HHwY+G+iz6jdaN8PvhR4H8M/DrwRpNzrF/ carq9xpnhTwhpej6DYT6pql3dalqM1rYRSX1/c3F5ctLcTSSN6PX5b3H/BMG7u4LW2uP+Cjf /BUgw2Kslp9n/am0bT50idIVaO6vdN+FlnfasxkhMy3GtXOpXkTzTRw3EdsUgjpx/wDBJ3wL cpcN4l/bg/4KqeKb6eeKQahJ/wAFFf2i/BL29vBAYYLG30v4T+Jvh54eWBHkuLiW4fRpNTvZ 7gf2hf3cNlpkNiAfqpRX5e6F/wAEkP2bdH1K+8Q3nxl/4KJeIvGN9o8vh6TxxrP/AAVD/wCC hNt4tTQFnW+0vQxqvhv9pDw+J9H0DVJdW1fSNMvbe6so9T1/WLm9gvhLaJZ8pL/wQ6/4Jx3k z3OtfD79oPxNc3F3f6hqMnir9vb9vvxJDrOpauiJrWo61p2sftOXelapd60Y0fVnvLGWO/dE M8bLHGqAH6215rf/ABn+D2lX17pmp/Fj4a6dqWnXdxYahp9/478L2d9YX1nM9vd2V7aXGqx3 Frd2txHJBcW88cc0E0bxSorqyj8pIv8Ag3Z/4IsQyxyp+wD8Ji8UiSKJdf8AihPEWRgyiSGb x7JDNGSAHiljeKRcpIjISp9Wg/4If/8ABIe2nhuI/wDgnT+yg0kEscyLP8JfDt1AzxOHVZrW 6t5ra5iLKBJBcRSwTJujljeNmUgH1Dr37eP7DnhWfUbXxP8Atmfso+HLrR5L2LVrbXv2ifhD o8+ly6bcpZ6jHqMOoeMLeSyk0+7kjtb1LlYmtbmRIJxHKyqfC/Ev/BYz/gk/4Utre71T/gpF +xHdRXU5t408NftL/CPxncrII2lLXFl4P8V67eWkG1SBdXcENsZCsQmMrojeleDP+Can/BOf 4c3N1feAP2Bv2LvBWoX2jT+HdQ1Lwt+y78EdC1PUtBupLWa70fUtS03wPbX2o6beT2NlPeWd 7cTwXdxaW89yks0Mbr9R+C/hr8OfhvYyaZ8O/AHgrwFpst3eX8un+C/CuheFrGS+1CHTbe/v ZLTQ7Cxt3u7630bR4Ly4aMzXMOlabFM7pY2qxAH5wf8AD7v/AIJVXHzaH+2b8OPGsC8TXvw2 0b4g/E/TLOXqLXUNU+Hfg7xPp2nXxTbMthf3VtetbvHcC3MEscjQXf8AwWp/YDEF9LoHiX9p Xx29t9thsV+H37A/7efjGx8QajYvNbvpPh7xLov7Nlx4Q1O+k1GCTSA6eIY7C21VJbLUL2ye 2ujB+rdFAH483X/BZXwFDbXE1p/wT5/4LDandRQTSW2m2v8AwTI/aUtLnULhI2aGxt7rWvDm laPbT3cgW3huNW1TTdMhkkWS/v7O1WW4j+QP2rv+CrX7VXxp/Zh+I/gr9lH/AIJuf8Fov2af jl478OaNB8O/jV4k/YV+CXi+T4fC71vRL7Xby48AeIv2qNIuItcv/Bya7oGnnVIrfUPCWu6p aa3Lp019ov8AZ0v9ItFAH+fb4S+Bf7Rvju80jUf2yfCv/B3X8atesr68u9T1H4d+K/hV8LPh zflNO06ytX0P4IN8SPER8ER6tJbXFxqtpoPxcd7JRaJ/aOuXX2y/ufYde8Ofsd2thceHPEP/ AATZ/wCDvJbZJNX0XW9d8v48eI7Ge2eXTpb261JtG/ac13w/faLZWDT2cF5pmkz6ZqenXurq BrF/Zwzad/djRQB/n3/tPat/wTV8JfCaHxH8Ef8AgnP/AMFgf22fjlofiLw3Nf6H+1f4y/4K t/C3UtX+FGqySi+07w38QPAnir/hHdAvdKvNY0zX9BbXfBc2l3+nXmuhry91W+0S2uPh74Ka B/wbzftR/tDeCPhH+1x+yN/wU7/Yp+PfxL+Inhjwb4P8CeO/iz8Qvi34TvtT8e65deE/DXw+ h8TeKNBn+M1v4e0XxD4g0tdNu9T8KQ6oZLKyfVPEl6h1uz1T/TxrC1Xwt4Z13UNB1fXPDmha zqvhW9m1Pwxqeq6Rp+o6h4c1K5tZLK41DQb27t5rnR724spZbSa70+W3nltZJLeSRonZCAc1 8JPhb4J+Bvwp+GXwU+GmktoHw4+D/wAPfBfwt+H+hPe3upPovgn4f+G9N8J+FNJbUdSnutRv 203QtIsLNr2/ubm9ujCZ7qeaeSSRvQqKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigA ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigA ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA//Z /9j/4AAQSkZJRgABAQAAAQABAAD/2wBDAAEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEB AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQH/2wBDAQEBAQEBAQEBAQEBAQEB AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQH/wAAR CAH2AkQDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAA AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkK FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWG h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl 5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREA AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYk NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOE hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk 5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD+/iiiigAooooAKKKKACiiigAooooAKKKK ACiiigAoor8aP+Cof/Bdj9hT/gk5qfg3wd8f9U8efEL4s+OLG71jTvg38C9M8H+LviFoXhyD yY7XxX44sfE/jjwRpXg3w3rN3M1p4fudX1ZNS8SPZazL4c0nV4NB1mSxAP2Xor8if+CXH/Bb P9ib/grfB8RrH9my++IXg7x/8LVstQ8T/CH436N4Q8JfE2XwnqMqWdr4+0DSPCXjrx9o/iLw ZHq0keh6tqmka/dXPhrWLvRrPxRYaKfE3hZ9b/XagAooooAKKKKACisbT/Efh7VtS1jRtL13 RtS1fw9JaxeINK0/VLG81LQ5b5JZbGPWLG3nkutMkvIoJ5LVL2KBrhIZXhDrG5GzQAUUUUAF FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRR QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFAH+dz+yh+w3+0n8ef+Dg3/gq98AvhV/wU4/bc/Z30z4eaprnxd8Z/FDwxrEmkfEH4rX+t ar4R07wv4Q8baFpvjmHwVrnh7wHZfEXVNJ8AeIL3QLuym8JeGdA1HQvBXwyl1a18PeG/6PL3 /glr/wAFdNAv45vhP/wcKfHDQdPbSZdHurT4s/sPfs5fHG7kgdbHbcWt7q3iHwta2eopJaSs dYGlz63snMcepxb717/50/4IW2dj8Zf+Cnv/AAcA/ti2yafcaPrn7Xvhj9mXwPf2beW81j8B j460PxXqQhXUNRWbT/E9rD8OdW0/UPOi+2GC6uEs9NEz6ZZf1K0AfzzH9hL/AIOCvDGoQx+H v+C7Hww+I+jCzst7/Ef/AIJsfATwpeW93bz3Cz2sdv4L1LUri9tp7VbQzale6/8AbZpZJ0S1 tHg+23vQQfssf8HDlhdabOn/AAVX/Y+12GLV9PudQs9Y/YXsLG3n0y2aWS7si2jeKILyeK/J hguYLe80i+MO6Sx13S5oyZ/35ooA/n01D9mT/g45ht4tH0n/AIKc/sPahbveQXk/jDVP2Nrj SvFVvFLDdR3elW2iWd9q/hW40+zks9LmsppoYNUvZNc1z7VfWsOjaTBqFe4/ZQ/4ONF0oTWv /BWH9kCbXPsMkh064/Yh0S20oamLGWSK0GsxzXd4bF9TWC0k1E6ELiOxkl1FdLluIU0uf+hO igD+Sn9tr4Wf8HFH7L37NH7R/wC1J4l/4LNfBG28H/Ar4MeL/ixN4R8BfsL/AAZj1PxJqPhn wteXM/gbT7/xR4G8QXOh2moahpOmJpHiyXUdRvY9T8Wa5dahp+naRoOj2rf5tvxr+On7SPxI +MnjL49/HzxRr/jP4yfHPwzPq3ifx98Q9D0XWdV8YeGPHHhMeFodX0o6ro8+mWNrJ4SjXw/4 f1Pwxa6dL4Ys7FdN8PXGjzaWsNr/ALc/7V/7Ongz9rr9mf47/sw/EF2t/CHx2+FnjT4ZatqU Vnb395oB8VaJd6bp3inS7S6ZLeXW/CeqzWPiXQzK6LFrGlWM29DGGH+YR4Q/4NzNW+L/APwW /wD2kf8Aglh8NPjddeH/AIRfsy+EvCPxZ8d/HLxhoMniLxSvwy8VeBfg34q03SdJ0XRNN8O+ G9T+Jesan8Y9H0mz0rUdQ8NaJaaXpPirX4b/AF0+Go9L14AT/g2y/Zo/4Kh6N8bNZ/4KB/sG /s5fDP44eGvh5F4w+APiO1+LnxcsvhT4Zv8AVfGOgaHrGqQ2rrqtnrGst4dtJ/D+q3Pladqe mRzXVsiwPqkUEtj/AGRaH+1B/wAHRWly6vH4u/4Jl/sB+MEuPEEyaBN4L/aUfwbFpPh12ZbZ daHiX4r+KZtdu7cKHudW0+Lw+9ysiCHwrbOHVf28/Y8/ZA+A37CX7PPw+/Zi/Zu8IDwf8Lvh 3YTw2EFzdPqev+Ida1K4k1DxD4w8X65MiT674r8T6rPcanrGoPHb2sbyxabo9hpOg6fpWkWH 03QB/M03/BTT/g4I+FukXup/GT/g37sfiFFdaza6Xoc3wM/bq+D89zbbrXULiWXVPDHh6x+O fiWexuFs98WuT2fh7TNOkNvp98Xv9TsImytI/wCC33/BVY+IYPC/ir/g3E/a/wBK1S+tYtT0 +58N/HG38V+HG0m3uHt9abVfGFx+z54b8J6Jrlt5llJovhu+1kap4hjlvZoVsrbT2uJ/6eqK AP5fB/wX4/byOt69oH/EO5/wUv8At3huLxDNqE58P+LBolwnhiK7m1JdB8Sn4KDw54qluUsp l8PQeF9V1ifxdK9pB4Uj1qe/sY7j4l/bo/4Odv2q/h7+zJ448NWX/BKD9u39iz9o/wCMMf8A wrL9m34hfH34Y+IbLwL/AMJxrs+n2l3e6N/wl3gTwVfeJfHmiaFd6tqnhHwpo+geJY7zxJba C2r28ukzX0K/2u1+F/8AwXq/4JA6v/wV4/Zj8D+Bfh18StD+Ffx3+B/jm8+IPwj1/wAYQak3 gTWbnWNHOi+IfCPjDUdA07VvE/hvTdVji0jU7bxP4f0jX7zStR0K1STw5q0N2zWYB/lffs2f 8FIf25P2QfF/xE+Jv7NH7QvxE+FPjn4upFH8aPGunai3inVfizrcniTxH4ttfEnxCm8fR+Lb HVvF4v8AXdaFvrsdrZajJbyanOzy6hq/iW/1f+lv/glh/wAHcn7U/wAKPjCngX/gp94im+PP wI8X6xeJqvxS0b4d+EvDfxa+C+p3l3qd4+pWvh34eaF4R0Xxp4JXVL2O21nwrLog8R+HdGt4 D4JuJYNGt/BesfnP8XP+DeH9tv8AY5/bi/4J7fsp/HD4rfAiyu/20vi9faJ8LPid8KNX8a/E /wAKeE73wHq/w+l+IOrat4Q8YfDjwNq9zq+haX4p8L39np99oEfhnxLILaw1XxHp2k2Wrahp X96P7Df/AAbwfsn/ALJf7RFt+2V8XPin8c/24f2vLW8u9csPjL+054ksfE1v4e8XX4hlufGn hnwslnNJD4ptr59Vu9B1nxR4i8XX3hqXVGu9Ens9ZsrLWIgBPBP/AAdC/wDBD/xr/Zlv/wAN nf8ACJarqf23/iU+N/gT+0ZoP9n/AGL7W/8AxM/EP/Cp7vwZafa7a0+02X/FTyef9ptLH5NV m/s9f0E+HX/BVX/gmb8WE0//AIV9+3/+x14hvNUW3NloiftFfCnTvE8jXVmL+GGTwpq/inT/ ABLbXP2Yu0trdaVDc28tveW1xFFc2V3DB9WeJvgn8GfGkmry+MfhH8MfFkviCCe116XxN4C8 K69JrdtdW32K5t9XfVNJum1KC4sybSeG9M0c1sfIkVovkr4j8a/8Ea/+CTfj7w7e+GNc/wCC b/7Fdhpt/wCX59z4K/Zy+Fvw28RR+U29fsXi/wCHXhrwt4s03JGJP7O1q185fkl3oStAH6Fe G/FnhXxjYy6n4Q8TeH/FWmwXclhPqHhvWdO1yxhvooYLiWylu9Mubq3ju47e6tp5Ld5BMkNx BKyBJo2boK/nK13/AINXf+CRq3dzqXwj8E/tC/s26xM1nJb618D/ANp74u2Wq6dNZQTRRT2V 38Rde+I7NKZp2vN16t55NyMWgt7V5raWDS/+CGv7ZPwiiv1/Zh/4L2/8FIfBTLLpkPhyw/aJ uvDH7XHhjQNG0M6jBpGkx+E/G+o+E9GWK2029gs7pNDh8OabqL2VvNe6TJDaaTaaUAf0eUV/ Nyvw1/4On/hMpl8OftH/APBKP9qu0tXuGEfxg+Gvxj+FviLUY20bTo4kOn/CXQvB3h+N01WL U5Yl/wCEksgJpLa5uLiWwvDo+g35f22/+DjD4S3t2vxL/wCCM37PH7Smi22h2+qya/8Asy/t v+B/hjbQXc0I8/R00T4vzeL/ABvq2q6fNDLJc22keELmzuY7u0g0vVL+S3uZnAP6N6K/nh1j /g4Cb4C6Fcan+3n/AMEtv+ClP7IsOno8+reOrb4NaP8AHP4B6dDb6RBqt9HL8afA/iLTLM31 nb2virVZrWTwvDEnhbwvda7Ndw3M0ujWXq/wi/4ORv8Agiz8ZLeBtH/bh8EeC9Sazhur3Rvi 74P+JvwmuNLllhMz2E+r+O/Bei+FNQvLba0Ux8P+ItZs2mAjt7uffGXAP3Horwr4HftQ/s1f tN6Pda/+zj+0F8Ffj1oun+UNS1L4O/FDwT8SbXSpJlVkt9Xfwhrer/2Td/MFks9RFrdRSZil hSVWQe60AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUU AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAfzcf8Gs ccXiD/gml41+N40PXtMuv2nP21/2qfjzqGs+ILe8trrxpea74u0vwYfE8UUlxc6QqxW3gW28 L6gvheT+wYtd8M6vApl1aLVp5v6R6/m//wCDVzWNVg/4JVQfCDxHrl9q/iz9mz9qn9qH4H+M LPUZJftPh3xPp/xGm+IWq6M9pd6Vpmq6a9xL8RF8R3FjrMmp6ot5r9zc3F7bpcw6PpX9IFAB RRRQAUUUUAFfyh/8ExUg+K3/AAcrf8F2/jjapbCD4feBf2evgNI0VjaTMLq38K/DzwpcgarD ql89m0l1+z1cveacoJ1C5UT30Gi3ekrpS/1eV/MZ/wAG4cGj/FXxt/wWg/bS0LWbHXdB/aV/ 4KqfHHQPBmorp+hrrF38Nfhbc3HiP4fXN9rekm4uL3Tf7D+MostH0i5v7qz0prDUdU07efEl 5f6iAf050UUUAFFFFABRRRQB/Nj/AMFMPDsXxk/4L3f8ECfhgtvqFrH8JNP/AG6v2g/EGs2l 9ogC6dZ/DfwTdeGbIWF1dNqTRT+Mvhhpmkaq6WJM+neIzLpUryaXq8+mf0nV/NLqNlpfxD/4 OzNBna0vo7v4Ef8ABF2a9Sb7SkNvPqmsftN6zp5u/KjmDXViui/GVrH7NMjOupQ/bBCI7aK4 X+lqgAooooAKKKKACiiigAr5n+Jf7Fv7Hvxm0280j4t/srfs6/ErT7+0vLK6g8cfBf4deJi1 tfyLNdrHNq/hy6uLaSa4jiuvPtpYZ0u4YbuOVLmGKVPpiigD8LPiV/wbYf8ABGH4kStqUX7H Gk/DLxRBdTajovi/4L/E34wfCzV/DWrSXNndxatomm+FfHln4RS8sJ7GCTSY9S8M6lY6O5mf TLO1kuJnf5bj/wCDa64+E0l/efsbf8Fe/wDgqb+zVdzfa59O0i8+OcHxD8B2F1ealLeNb3fg 7RbD4WjX9Ct7aeSC203XNYvb83qw6td63eXcbCT+neigD+avQv8Agmt/wX4+DMf2b4Tf8F5t E+LelwWtpcW+j/tG/sUfD/UJLu80jUIr2z0TUfFk/iP4meMF0zXLO2Oh+I/EFjq9vq/9n6tq N9Yacuu2WjanZ9/4m+P3/Byv8HYbyHWv2BP+CdP7YdwZbZdP1D9mD9pLxr8DIRBdXF8TJe6R +1DqlnJ5un2kNmupQ2+tlBcXUb6XPqsX2lLH+hWigD+cPRf+Cy//AAUw8P6vY6L8bf8Ag3u/ bP8AD0r2V7cahqHwU+LXgT49WMbxyLbaaLO607wd4R0WRr+5g1Jr6zuPEUF5pFpHpt1CmtW+ qxTRdjpv/Bw/8GdB1xNA/aF/4J4/8Fb/ANlhrTRIdX8QeKvjF+w/4kn8B6Si6jBpWoT2uq/D /wAUeNPFGr6DbXA1a7tPE0HguDS9S0zQtQkgaPVJLDSLv+guigD8a/h5/wAHB/8AwRp+Jmp6 jo2jft5/CrwvqukarNomp2Hxh0L4mfAK5stUt7i3tbm1uIvjn4F+HbJ9kublYbub/j3tZIL5 biWI6bqH2X7t+FX7c/7Evx31i38O/A/9sT9lj4yeILu7NhaaF8Kv2g/hL8Q9Yur5YRctZW+m eEfF2sXs92Lcic28UDTCEiUpsIavV/ih8EPgv8b9KXQvjT8Ifhf8XtEXT9a0ldH+KHgDwp4/ 0pdK8SW0Fn4i0xdP8V6Tq1oNP1+0tba11qyEIttVtreCC+jnihjVfym+LP8Awbtf8EZfjDpN /pet/sJfCrwjLe+a8WsfCa88X/CTVtOuJGgYXFhL8PfEnh+zHlNbxmOzu7G70wK08b2LxXVy kwB+1NFfhJ4f/wCDf79m74Z6bpujfs6ftif8FRv2WdE0Wx0qy0fQPgP+3b8S9I8M6cNHksVt JI/Cvjez8eeGbqA6dpWj6HNomo6Re+GZdE0jTrH+wwsDO+T4s/4Ji/8ABV7SLptW+BP/AAX4 +P3hvUIxrCLYfG79j79mD446TeWdwEfSLFoDpvgnTdNvbeSNYr/xENB1WZ0keXT9IsMSW9wA fvjRX85Fp8Df+Dof4daJZ6R4Z/bd/wCCXv7Rd9JaOmo+Kfj78EPij8Kdes7q70y3jlextfgR 4K/4RjUP7J1JJ5dLluPD+nR3oc3Wp2LQvHo1rh+Hf2qP+Dnf4Wz2Fj8Vv+CW37FX7Vdva6rH Ffav+zj+1d4f+AcuqaG2g2bxuG+O3j3xGtnqsOti8/tPVYvD/wBjuWcWOmeEbWyt0127AP6U 6K/nm17/AILE/wDBQ74WpqR+N/8AwQB/bl02XQLbSW15P2eviX8LP2roxd6vHZmCDwvL8MLC BvGttBLqVimo3Xh+KeXR4xqkutWemNompwweWSf8HNfw88ITalpXxr/4JR/8FifhT4j0qO71 PUdJvf2SNJuU0rwxZWOl3134i1p/EvxK8D6tptpZQapDdaiToVxaWem3GmX39oS/2lHbxAH9 NlFfzx6V/wAHQv8AwSaitrTUPib4z/aJ+A+lXlyLGPV/i5+yn8c7PTFv3046jDYG68EeEPHI mvLgRXltDb2i3EjTafe3DBdNjjv5frD4a/8ABeL/AII7/Fe00a98L/8ABQ79m3S4ddvbjT7J PiV4xl+DF3BPa+HrbxPLJrNh8YbDwLfeHbJtNuora31PxBb6Zpt54hW58I2l3P4rs7zRYAD9 bKK8f8K/tC/ALx1DpNx4I+OPwf8AGNvr92thoU/hX4l+C/EMOtXz3z6YllpMuka1eJqN22pR vp629m00zXyPaBDcKYx7BQAUUVg+KfFXhfwN4c1zxj418SaD4P8ACPhjS7zW/EnirxTrGn+H /Dnh7RdOhe51DV9c1zVri00zSdLsbeN7i8v7+6t7S1hR5Z5UjUsADeor+bXx3/wdg/8ABGjw L8WNS+F//C5PiZ4x03R9XfRNS+LfgT4PeKPEPwnS7tpJLfULnTdW3WfirxLpFjdQyW6a74V8 Ha5o2tx+XqXhe/13Rrm11Kb7Gg/4L/f8EarmCG4j/wCCg/wFWOeKOZFn1DxJazqkqB1Wa1uv DsNzbShWAkguIop4X3RyxpIrKAD9hKK8M+DH7UH7NH7R9pdX/wCzz+0R8DPjzY2KzNe3vwY+ LfgH4o2lmtvNDbXDXVx4H8Qa5DbrBcXEEExldBFNPDE5V5EVvc6ACiiigAooooAKKKKACiii gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigD+UX/ggT458DfCL/gop/wAF 5/2LL/xL4Y8PeLLL9vzxV8evhj4C1HUdN0XxR4m8DfEjXPiLcatP4P0DVNZfxR4q0b4e6Ppf gO18S6rYaTNpuixeKPC+oXepMPFljDF/V1X8Tv8AwSh+H3jfw1/wdjf8FlL/AMS+E28Mw2nw Q+Jd1NC17oUxbT/ip8W/2UfiB8NtZEWk3s+9fHfga3HjJMI15pyXy2fiZdO1+SWyb+2KgAoo ooAKKKKAOI+Jni9fh98N/iD49cWRTwR4I8V+L3Go3As9PK+GtBv9ZYX92WQWtkRZEXVwWUQQ eZKWAXI/nA/4NGNDurD/AII7+E/Ed9q9xrF98Qv2h/j54xvJbtJGure6XxDpvhK4jub2a6uZ tUuLubwq+rzX8ot5Gk1NrZ4ZGtjd3X7y/tla9qXhX9kH9qvxPo0scGr+HP2bvjlr2lTSxR3E UOpaP8MPFGoWMskEoaKaOO6t4neKRWjkUFHBViK/GD/g1K1PTL//AIIh/svWthZwWt1ovjL9 ozTNanh0u30+TUdTl/aD+JGsxXl1dw313Jrk6aPq2k6euqXdvpdxDbWNvoq2Mlro9tqWogH9 GFFFFABRRRQAUUUUAfzUfD92X/g7K+OKrFJIJP8Agi1pCO6GILAo/ag+D8gllEkiOYy6LABA s0vmzRkxiETTRf0r1/M/4z1LWtJ/4Oz/AISWsmp6gtj4n/4Ix6lptva2C3Ztn0W3/aV+JusN pmtmwsYYV08eIvD0+sxNrc93aHVV0hYr5b5tI021/pgoAKKKKACiiigAooooAKKKKACiiigA ooooAKKKKACiiigAooooAKKKKACiiigAr89/iX/wSY/4Jg/GC4v7/wCIf/BPz9j7XdZ1W8TU NU8SQ/s+/DLQvFup3cdlJp6Saj4v8O+HNJ8T3ypaSCNYbrVpYQ8FnOI/PsbKWD9CKKAPwW+I n/Bsp/wRO+Imkw6ZJ+xfpXgue2n8+31r4d/FP4z+E9WTc0fnQzNa/EGbTtQgmSMRmPVNOvvs 6tJJYtazyNMeN0j/AINv/wBm3wA2pr8Af28P+Ctn7L9prOuy6/qmn/AH9ubXfCdlf3OzU4bC G9XW/BHiia+TSLXWdUtNNv72e41xbbUL6O71a7+3XjXH9DdFAH8qH7RH/Btr8eNdvtc8X/sn /wDBb3/gpx8JfHGvaToA8T3Pxv8Ajr8QvjO/xB1zwt4Q1/wnYT+IvFvgnx18FPEFgNS0/UrX ThqF5Z+MovCmmX/jCw0LQLjQ9d07w7oP46/8EKv+CeX7Z/8AwVA8O3uk/wDBRv8Aai8XftC/ 8Exf2ZPiz8U/hxH+zbqn7QHxA8QXXxC/aN+GzeFrXRdN1650O50rxG/wg8JWHia58X+Hl1bx 6ojv7LQbDQPBkXh7xNq2pwf6HNfg38YP+CB3wOn/AGhviB+15+xJ+0Z+0Z/wTl/aQ+KFy9/4 /wBa/Zu1vw3P8IvHOpXck1xq2p+Mvgj4p0O88P6rc6tfTPq17a6ZrGg6NLrs9/r8mkya1qmo 39yAfRk3/BDX/gkFP4Cf4bv/AME7P2WV8PPJaSNqMPwx0m38ehrK2tbSEJ8VYBH8UI43itIn u4o/GCxX9y91e3yXN5fXs9x9i2X7Gf7IOn6LaeHbL9lf9nODQbHS4NFtNIX4J/DY6fDpFtaJ Ywaatq/hpojZx2aJai3ZWjMCiMqVyK/JXU/2TP8Ag4Y8MwPoHg//AIK3/sp/FKwez09h49+K H7BPhv4eeN4r+FNTjvoY/DXw88S+IPBRtrj7VY3D3kiPJLNp1qltp2lQDUU1fq7r9hL/AILN /FK0sYPi9/wWs0j4YaLqkssvjDwV+yn+wb8J/COqQ2z30Msek+EPjZ8SPHPjfxfpUUFrbD7P q6eEbLVRLdz29+2p2UbR3YB+P3/Bff8AYl/Y9/4J96T8Bf2t/wDgnD4f0r9j7/gp34o+PHwk +F/7Nnw0/ZZ1mP4X/wDC9Ytb8Uf2d4o8KH4AeDbvSfDWueG7+31Wy0XxlfaZ4asdC8Q/2r4f 8B+OpdVtPFWmaZc/2j6cdQOn2B1cWS6qbK1OprpzTvp66h5CfbRYPcqly1kLnzRatcIk7QbD KqyFgPyZ/Yr/AOCLP7If7GHxc1P9pVNa+Of7UH7WOuaRBo+r/tR/tefFfVvjZ8YWtVheC5TS tU1C20zRtGa6gMNkb200U61HplnZ6f8A2u8K3Juv1yoAKKKKACiiigAooooAKKKKACiiigAo oooAKKKKACiiigAooooAKKKKACiiigAoor88/wDgoz/wUP8Ahz/wT5+FHhjXNS8O6v8AFv49 /Gvxvo/wa/ZY/Zt8FzQP4/8Ajv8AG7xeJ7Xwj4WsI3L/APCP+E11JbceL/HuowHRvDdtcWVj GNS8Ua74X8Oa6AfQv7Sv7Wn7M/7HPgB/ij+1F8cPhx8DfA3nvZ2WtfEHxLY6LJrmpRxee+j+ FtId5Nc8Xa4LfdcjQvDGm6vrDW0ctytkYIpZE/ADUP8Ag6o/ZS8Vx6tc/sy/sP8A/BSv9qnQ NN1C3tLb4h/C/wDZtsB8M9bt3jlF3c6Xrl145n8Vwy2V/Bd6U1lrngXRpZr7TtSEb/Z7eG4u vmL9p7/gln8aNYv/ANmn/gql/wAFk/jx8Bfj/wCI/gX8VY/E37Tf7MXxS8YD4cfsF/BD9lrx X4QvdBvfA/wT8Lnwl4r1Dx98ZPBHxAvfDHjm60/xHquoWP7SGv8Ahnw78K7lNYZbHWPFPj/7 Vv8Awda/tGeAvAp+Ln7Fv/BKP4uv+xToif8ACNeFv2sf2hvA/wAUPCPwg8TSzzWegeDT4fg8 DeFrTwH4Y0AX0f2bSdKuPivqGseI7W/0vTo9N8GalZzWVyAfKv8AwRs/4Lo/8E+fAP7f/wDw VD/av/ba8W+MfgL8T/21fjb4Zj+FOq+NfBXjjx3b+Avgx4Nn8Sad4a+HHizXfBWmeKLzw1qe n2UvgrRNa8/R7fwxYr4Q00tqemaNpMS2/wDb5+zx+3j+xV+1rc3mnfsy/tWfs/8Axz1rTYDd 6n4a+GnxV8G+KfFulWfmXEaX2q+EdN1eXxNpljO1pdG1vb/Sre0u0t5pbaaWONnH8of/AAb9 fsG/sc/8FRf+CGHiP4W/tNfCqLxNrOp/tX/tHar4i+KVv4bs/DnxO8NfFvxVpXgCe6+J3ws8 d6tYa1bx62/gmTwHol7q+l6UfCeoXHhaLwp4i8N6w/he7+0/rT4R/wCDZH/gkdoX7O3wo+BH iT4CXnjLxP8ACS11CTSP2lIfE2pfDT9pDXPEeo+J/EPi0eKPFfxC+Dh+Hsfiy/0PUvElxp/h K18V6Tr9h4d8N6P4U0OGC4i8L6RPAAf0CUV/Lj8U/il/wUt/4IT3d98XvjX8U/Hf/BT/AP4J S2ur2Fp458VeMDpl7+3f+yjYa9e6Ppdl4s1nxLdHRdN+OvgWLX7+XT7l9a1E6uovtOa61DwJ punTXes/0hfBj4xfDb9oT4TfDr44/B7xVp/jf4XfFfwfoXjvwJ4q0zzVtdZ8N+IrCHUdOuGt 7mOG90+9jim+z6npOo29rquj6lDd6VqtnZ6jZ3VtEAemUUV89ftRftXfs7fsWfB3xB8ff2o/ iv4a+Dvwm8My2lpqPirxH/aN091qd/5v9n6F4d8PaFY6t4o8X+JdRW3uZdP8MeE9E1rxBfQW l7cWmmzQWd1JEAaH7UemaTrX7M37RWja9HHLoerfAr4uaZrMUv23ypNJv/AHiC11GOT+zbmz 1Hy3s5Zlf7Bd2t7tJ+y3ME/lyr+B/wDwaQ6jFe/8EX/hRbRz6bK+kfGf4+6dNHY6it7dWssv j251YQazbLBCdI1JodUiuYtOeS6aXSLjStWE6pqi21v8p/tc/wDBxZ40/aM/ZR/agn/Yb/4J Z/ti/G/4CXH7O/xgi8ZftW/FbS7f4KfBjwf4K1T4f+K9H1v4kaS83hz4i2PxE0vwoRd6lc+E n1zwprGu2Wkatb7tN8hpT5B/wZmftn+CdW/Z6+KX/BPnVPDHiLw38VvA2qeJv2q/Dms6oYU0 T4i/C3xrrXhf4e65qHh62kSC/VfBPivT9B0zUr1VvdNv5fE1vFb3UFzp91bsAf24UUUUAFFF FABRRRQB/NN4G0i4+Lv/AAdXfHDxfOdUh0n9k3/glT4B+HcTI81tb3Pib4pfFaw8baTBL5aX 1pf6IfD/AI68aTvBc3Gh3o8QWNpcWen39rp15ey/0s1/Lt/wQy8YeDP2iv8AgoN/wW2/bubx loZu/jf+1/4e/ZY+E3g/V9YWy8dyeDf2QPAJ0q/8SJ4eutWW8u9G8W+GfEPgG402B9E+0+HY vBurWa3iRnUbW3/qJoAKKKKACiiigAoorkfHvxA8B/Crwd4i+IvxQ8beEfhv8PvCGmy6z4s8 dePfEmjeD/B3hfSICqz6r4i8T+Ib3TtE0XTYWdFlvtSvra1jLqHlUsMgHXUVh+GPE/hrxv4a 8PeM/BniHQ/F3g/xdoek+J/Cfizwxq1hr/hrxP4a1+wt9V0LxD4e13Sri70vWtD1rS7u11LS dW026ubDUrC5t7yzuJreaORtygAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKAPMfjR8Zvhh+zv8ACjx/8cfjT4w03wB8Kfhb4Y1Pxj488Y6tHfXFjoHh7SITNeXj2ml2 l/quoTkbILLTNJsL/VtUvZrfT9Msby/ube2l/Gv/AIJlfs2fE/8AaT+Luuf8Fif25PDFtb/H H41+GItC/Yk+Cev6Zp0//DGP7GuqSS654I046fPp8kmh/tC/Fmz1m98TfFrxHFqup61p2k63 F4Mt7/w/Z33ibwXp7v8Agsdq2kfHT48/8Er/APgl94k0XUNT8A/t2ftQ+MPiX8a4Pt8dt4a8 X/Aj9g/wPaftCeN/g94oshNDcajp/wAT/FE/w9S6jXzIf7C8NeILWIWutXuh6lY/u5FFFBFH BBHHDDDGkUMMSLHFFFGoSOOONAESNEAVEUBVUBVAAAoA/mC/4Op/gZ8afid+xl8Avin8P/h1 4k+Nnwf/AGYP2n/Bnxu/an+C3ht/FOqSeM/gfoNhfLr+q634I8PanpsXivwp4XAkbxZeSvHq Hgvw3q+q+L4tU8P+G9K8W63ZfqL8Ev8AgoL/AMEp/wBuT9lPxp4k8FfHT9lvx5+zB4c+Hdja /Gv4f/FO78C+F/C/wu+HF8JfD9pofx2+E3xQj0mD4f8Agy4k0260PTo/HHh+w8Ha3Dp0i+H7 vVtLSG4ff/4Kz/t4w/8ABNb9gj46ftdj4fxfFLVvANn4X0Hwv4Gvb/8AsvRta8V/EPxfofgL QG8SXyRT3EfhrS7/AMQx6xr1vZRG/wBS03T7jSrGayur6K/tf5av2Rv+DST4Zftb/DzSP2uv +ChP7Q/xH0X4xftO6Vb/ABz1n4XfsjeGvhZ8G/BHw6ufiglr4y0/QZT4q+FXi6xutSsNK1VY fEmmaJ4J8L2GneIpbyzs9T8Qwae3iDXwD+w39j/4sfsZfFH4OaZb/sJ+Of2d/F3wI+H15ceB 9L0j9mTVfAFz8NvAGoWiRatP4Ph0D4cumheDbyO31a21keHzYaXO1jq9nrEdo1nqltdXH1LX 4P8A/BIz/ggn8C/+CQHxV/aB+JXwd+PXxw+KFp8bNE0Pwjp/hL4i3Hh2y0nwx4V0DWbjXLCT X4fCenaNpPjvxvbXU72th4yk0Hw3HpGl3uvWGk6BZJ4i1R5f3goAz9W0nStf0rU9C13TNP1r RNa0+90nWdG1ayttR0rVtK1G2ks9Q0zU9PvI5rS/0+/tJprW9srqGW2uraWSCeOSKRlP8u3/ AAT30nxH/wAEi/8Agrb8aP8AglprE62/7Ev7dOn+Mf2uf+CdrySzRaT8PfH+jol58dP2dtIW 8trKxsG02xttR1mz8M6Je6xbad4Y8OeAPEhis9e+J3iS1s/6ma/mc/4LD6XH4t/4LG/8G6vh /wAJ67C/xN0D49ftVeK5/Ctpe6uuor8LbTwR8J/EfjzxFf2/h+1mv7XTxofw/wBXsbJ9Su7L RdXEWu2mo2+paBp/iabRwD96/wBp79pb4Ofsd/AL4oftMfH/AMWQeCvhF8IfDbeJPF+vSxNc ziOa9s9H0XRdIsYyJtV8SeKfEWp6R4X8LaLbkXOteJNZ0rSbb/SLyOvwL/ZL/wCCanxO/wCC lPxm0P8A4Kh/8Fl/hzs8VxvND+x//wAE6tZn0bxF8APgB8E5rMz+D/Fvxi8E38/iiDx58ePF yanc+JvEll4jvbG20LUriJfFHg/TdS0/wt8Pfg96x8bfsf8AwU2/4LB+HP2PfEOkR6/+xz/w Su8OeDv2mf2hdFnmudU8J/Gj9sr4o6Z5n7NXwv8AGmnWc9lYnw/8GfCMut/GQWF/f6vaeI/F MD+EvF/g688Ph5pfmz/g5U/a0+JPgjUf2KP2FJPitqH7IH7L/wC2/wDEm78PftRftvQSeKbE /D74c+FtS0R9Y+F2k65o2ltpmhah440zUbm61S61HV47e80qyTTfEaaX4AuvGGqMAYf/AAcE f8FkP+Cc3w+/YK/av/Yf8BfHf4dfEj9oT4j/AAo1f4P+GvhZ8J7d/HWheC719Q8M6RqOn+Kv EPhCK48E+Bb3wxoV7eXemaNqOs22oWupaFJpyaV9qsJbMfzqf8ERvFf/AAVl+Pnx0i/aC/4J nfs8/s4eFtU/Z4/4Jv8Awq/YY1/xT+1Lq3jJvhz4h8LX/wASL7xBF8TPA3/CLHwRcap8Q/EX xE+EPim6+yrb+LfB3huLQvEOkeLJdb1y7srif+pX4R/Cb/g1y/Y0+Bw+w+Lf+CWnj/w/oHh3 SPCvi34pfFPx5+zb+0r8WfiDc6t4bh+2T+INX1C48ZeI9f174g6TLP4m1vwz4L0TTtC1Wzvb y/0rwlY+HIIbez+x/wBgX/gsR/wR4/aa8Y+E/wBjz9g345fD2HXdE0HUYPhn8EPC3wO+J/wH 8Onwz4a0W58R6pZfDjQPF/ws+HnhUWeh6Va6vf3Ph/QUgvrS00vVNSXShpkS30wB4b/wSx/4 K0/tFfHP9o74qf8ABOr/AIKY/s+eHf2Vv+Cgfww8LJ8S/D+heCZL64+FXxv+EyyW1je+K/AF /deJfG9r/aGlXkqXktvYeNfEFhr+jz31/oz2s3hTxbpmj/0CV/Mj+3beaJ8OP+Dlb/gi14y0 2y0TSNe+MHwF/bC+D/jzX7jzbW78ReF9B+HPjTxF4D0C4uYYbnzZdL8a65cTaHG9uBcXuryW Fxd2ttcJd2P9N1ABX5pft1fte/td/BrX/DnwZ/Yg/YG+Jf7X3xy8X+H7XxWfF/iHxFoHwX/Z T+GfhW41LXNBudQ8c/HDxde21hr/AI90vVNNsNQHwU8JxDxhq/hPUJPEC6tpQXSrTW/0tr8n v22v+Ck2r/CP4w+D/wBiL9jH4Y6Z+1Z/wUH+JVnbaza/CmTxDJonwu/Z3+HM9xpkd98df2sf G2kwalf/AA7+HWlWWrWup6R4csrGfx18Q5ZdO0bwrYpda/od3eAH41/tu/8ABTv/AIL3fsN+ D9D8Y/GrSP8Agin4H8V/Ei7uNI+Bv7K2nN+3L8a/2qfjZ4k0+HRba68N/DDwh8L9QXR/Ft/c 61rNjZLqM914b8NaHcarpWn+Idesjd2Woal8Mf8ABSj4xf8AB2F49/YW8VfGv4q+Cv2e/wBi /wCDHhfwFrvxB+MWl/sueNV8A/HjS/AWnWKvdR+LNS8VfF/4neJ9Eku9N1R71/D/AMMPGGme KohpU+meIrOx1BTpF9+12lL/AME3/wDgixc6b+0P/wAFJv2t9A+Nn/BRz4u6TqF/4l/aK+Ku mX/xC/aO8X2Grz6nbnwR+zx8H/BekeJPEPwj+BGnXS33g/w5oPw98LeGPA7Th9P1q+t2mt9K 0783f+Ch3/Byd4g1j9kn49Jo/wDwRu/bT1f9mz4s/Drxf8MPD/7Q37Tnw31v4bfs+a5F8RTr PgTw9r+tHUPhr428Ka3oN9He2Osad4bufFVpeeJdW3eDjcaPMRrqAH8W/wCwV8LP2U/jL8Af 21rv45+Ff2s9K/aF+Heg+DviJ+zd+078B/A3j34j/Cz4T+MdnjG4ntP2rD4PtfEWreDfBHir xRpHhKDQvHGieFtS8T2Kz+NtXs5rvUPD2kaJqv8Aq9/8E5v2/wD9k79sb4JfDTSPgp+2D8KP 2m/if4P+Fnw/s/inceG9avtK8eX/AIntPDVnp3iDxhrnw18baV4S+Jvh+z8Sa/pms6lbzeJf BehyybpVltreaOWCP8Qf+DNj4Y/B/wAP/wDBLnxd8TvB66DrHxW+IP7TXxP0/wCLmvpoujx+ KvDlx4X8P/D+w8J/DG78RQafBrd34a07wmdF+I+k6JqGoX1lpur/ABM1+/sUt31a5jH6+fti /wDBFv8AYI/bCt9e8UXnwh0r4BftEXkD3HhX9rD9mq1svg3+0D4L8SqAtv4lt/GPg+301fFF 21sZtI1C38Z2mvR3mg3t9psElhM9pfWQB+r9FfzVeEf24v2yP+CQ/wAX/g/+yr/wVT8UQ/tQ fsp/GbxRofw3/Zx/4KjeH9JtPBWs+G/Fms301vp/w0/bd8KarqY8P+HtYtYCzaZ8VNA8Q6gu q+F9JtPEGvP4y8QXvj+7+Hv9KtABRRRQAV/ML/wWl8dfED/gov8AtD/Dj/ggV+zrBJaWnxd0 vwJ8fv8AgoL8c7Zobu3/AGf/ANmjwV470XxhoPhm1sZdIvon+IHxB8ReHvDt9oUb6lprJdXP gTRdRt7nwn488Sat4d/oQ/aU+M2l/s4/s6fH39obW7P+0dF+A/wV+Knxm1fT99xF9u0v4X+B dd8b39n5lpaX93H9ptNDlh32tje3Cb90FpcyBYX/AB5/4N5fgPr2i/sZat+3T8Y9UsfF/wC1 T/wU78a3/wC1p8bfHEGoz6zKnhbX9Q1r/hRfwysdUuLq4ki8MfDj4f6m1xo/hkR20PgbVfGH iXwdZxtp2jWbEA/ZT4A/BHwB+zT8D/hF+z18KtOn0v4b/BP4ceDvhd4Js7yaK61IeHPBGg2P h7S7jWL6K3tV1PXL62sEvtd1d7eKfV9Yub3U7lftF3KT3PjHxb4f8A+EfFXjvxZqMGj+FvBX hvXPFviXVrp1jttL8P8AhzTLrWNZ1G4kdkSOCy06zubmZ3ZVWOJmZgASOjr+S7/g60/4K0aJ +x9+yZqn7EPwu1fS9Q/aM/bE8Ga34b8WW9prUsOr/Cn9njVxNoni3xTqFhYKZxefE+OPWPh1 4Utr64sILuwPjbWY2um8OJY3oB+dfw6/4Ox/jn4z/wCChmgfFTWfhRqPgD/gjD4p+L+kfs4z ePfG/wALtUXWPA2van4Wa/t/H3ib4ueGIta0S1+IUVzj4k6/8IbK98SNYfCKC90zTLC+1q0/ 4Tyf++C3uILqCG6tZorm2uYo7i3uLeRJoJ4JkWSGaGaNmjliljZXjkRmR0ZWVipBr/PQ/ZW/ bX/Zz+Mf/BKS1/4JZ/sdf8EZP27P26fhbqfgHU9P8b/FjUvAvhD4M6D4w+Ol3b2d7r3xum8Y +FdR+O2g+BPFmh/FOfTJfDD3XjHXr/wl4Y0bw9p91e6jY6VNosnff8EjP2xv+C93h3VNf/4I k2dj+yd8J/2jf2WPB0F/p/jD9t3V/iB4l+KHgr4I3dvpV7oOk+AbH4d614k8LfGLSvAOl6zo lj4HmjutS0fRvB3iDwlpUX2zwd4YkfSAD+/avnH4f/tf/ss/Fb43/E79mr4bftB/CPxv+0B8 GIJLv4o/Bzw3450DVPiJ4Ms7a40ix1K+1bwvbXr6p9h0LVNf0PQ/Et7a29xaeGPEWsaZ4d8Q zaZrl9bafJ+OmofsNf8ABwd43g8OJr3/AAXB+D3wmF7p+uw+N7H4T/8ABOv4PeKItOuNRlvb 7T4vDur+PtXt9a1tdON5H4csdUjuPh9fWWiabYaxcwaz4la9u7v/ADDdH+Mf7VHw3/a++N3x 2+CPxv8AjrpnxAt/ix8RLv4m/tD/ALM9nrXw08Ra5oviXx/quteLPEjaT8M73w/oPh3w/wCN 5dKvPEsfgGa/07wSy20ekmNNK00NbgH+4XXmPxs8VePfAvwZ+Lnjb4V+Af8Aha3xP8HfDHx7 4q+HHwu/tZdA/wCFk+PfD3hXVtX8H+Af7de2vU0X/hMfENnp3h7+1ns7tdO/tH7Y1tOITE/8 tP7Rv/B1r4Mtfgt4x+J/7D3/AAT9/bM/aE0Tw/4U1zxBd/HD4jfCbWvhx+zX4Ls9PvZNJi8T +K/GOiyeLNQvtAtL+40Ke6tJm8HR3ya/pGiJ4k0vxBe/Y7fyL/g3K/Z1/bC+LfxO+P8A/wAF 6f23Pjp4g0fQP2ofDnxNuvA/wZ8N+JfFV/4S1jwZD4pe/u/G2s+HIPFHiEaT8OPhdH4e8QeB fgh8LdWtvEHiGw0+CfxE0mnCx8O3PisA5j4T/wDBx3/wWG+MHxj+I/7L3gf/AIIvab4k/aY+ CnhzQdY+L/w0/wCFreIvCXiDwbFry+H4NP1zVfC3izRbO803RtSufE2h6hbWZ13UJrXRtUtr u51SSxSbVR9uaR/wV9/4Lp6TY6vP4y/4N1/iBr02kb7+eTwl+1t4X0bfpcenTXBtNO02T4X+ N73xBqpnjEiLocl5cS4XSY9IbULiGWvxa/4IWf8ABbH/AIJlfBb42f8ABT39s79t3406p+z/ APtCftt/tQXvjTw54Jn+E/xi+JmiaB8Do7zxD4s8JaFpPin4O+APFmn3mqaRrPjPVvDXiBvE Hh3w1qN1aeFPDOt297rc2t6tDo/6xeK/+C7v7XX/AAUo0TxF8Df+CJv7CP7Rs/iHxwdU8HWH 7eX7SfhTSfht+zv8HLcpPHqXxF067YeOvDOu6xa6LLa6/wCB/D/inVrTxPdzXNvdTfCnxVdW Mng/VAD7v/4I5f8ABbOf/gqj4/8A2sPgz4+/ZK8Wfse/G79knXtB0Txx8OvE3xFf4kzyT6jr Xi7wr4g0zVLu4+Gvwt1Hwr4s8FeLfBuo6F4i8Man4fneJ7i1lt9Slni1Oy0794K/LH/glJ/w S4+Gv/BMn4M+JNKtfEWrfFr9pr48atZfET9r79pPxTqOran4s+Ovxae78Q6xd6tczavd3Vza eG9C1fxj4qTwvZSH+0Z11jVPEHiS61TxXr+u6refqdQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQB+Dv/ AAWt+Fnxw8FeI/2Hf+Con7PPga7+Lfjf/gl/8Tvib47+IPwd0KC7vfHPxH/Zo+PvhLQ/hh+0 bpvw409bS+0q88a6R4DsP7esjqdvDLYaXp+r6tpF42qWEGkaz+jv7E/7fH7KX/BQn4O6F8a/ 2Vfi54a+Inh7UtPtLjxB4Zh1GwtfiN8NdWuPNjn8KfFLwJ9rm17wP4lsriC4jFrqtuthrVml v4g8Lalr/hbVNH13UfsWvxu/bG/4ISf8E/P2wvHq/G0+CvGX7MH7SkUl1dRftKfseeLpPgF8 WbrVLu5uL+bXPEc/h2wuPCXjHxHNfzpPceLfFfhXV/GMsFraacviKLTraG1jAP0g/aW+EPwQ +PXwC+LXwj/aT8N6J4s+BHjXwTrNh8UdE8RTXNrpMnhWzg/ta91GXULKe11DSLrQX0+HXtM1 3TLq01TQtU02z1jS7u11CxtriP8AgU/4Jr/HX/gsf43+IHxI+EX/AAQV+L/xU/aE/wCCZ3wZ 15vBPgXxf/wUn8D/AAs0bw58NrzT4LeS0+HXhbxnba7qPxF8Q+H7Pw0fDuq+GNA8K2vg6fQP DXiXS28R/Bb4c3E0F3qv9Iemf8Exv+CwfwO8LX/hb9nj/guN4p+KHg23s5rXRvh1+3N+yZ8O f2gdX1NtW1uCTWH8WftE3fihvirqdtF4f+0Wdjpl/o+t6bJI11Zpa6bBqVte6D/P18Cf+DVz /gsj8HfF3xP8R/DD/gpT8JP2NLTxl4lvNesdD/Y7+LX7WPhjQ7uHVr3U57jTLzTNN0P4W3Oh 6ZoNmdK03w9ZT6144uG07fZ3mqxnS4bnVQD668cfs1/8HnvifUo9bi/bR/Zn0VdPuzd6d4b8 Dj4E6Fp0TTJDbyQSLd/s1pNrdooQ3ItvFWsavHC7TNahXdIj/TV/wT/8QfttaB+x14T17/gq Te/Brwt+0jo1z4tuPiFrXgDWdHsvBlt4UttevP8AhFtV8TXtn9l8GaPrx0Uwf2uvhu+uPDq2 62F19otdSudS02w/gv8A2mP+CRf7eH7NP/BRf/glz+xl8QP+CsP7SnxV1v8Aa1vvGhh+IXhn xj8WfDOp/s/2+gT2kvxIHw8uPFHxj8Qy61/aGgPJfx6lCvgifWLi1axv9BdvIab+uPwZ/wAG 7f7EE+saf4l/ar+KH7Z//BRLX9OWSa1l/bp/aj8efGHQLbUrjS30a41GLwhpP/CG+HLyVNO+ y2mnr4gsdebTItK0We1mGpaZBqFAHR/tB/8ABfj9iX4f+OpPgP8Asqjx1/wUd/alvFs4NC+B /wCxPoVx8W9NF/qUqwWjeLvjRosN58I/CmkWEgun8W3lv4l8Q6v4KtdPvrnxJ4esVhVZOT/4 JzfsGftT+Lf2ufiX/wAFYf8Agp7Y/Dmy/az8deBdO+Ef7M3wF8C3EHibQf2Lv2eYr3xJq1x4 Kk8YfYoLfxH8TfEVx4q1WLxLr2lS38FrDqniw2+ty23jm78K+Ef2d+EnwL+CXwA8Nf8ACF/A f4O/Cz4J+DvNFx/wifwk+HvhL4b+GvPVSizf2F4N0jRtL81VZlEn2XeFJAbBIr1OgD+ej/gk P4qjX/gpP/wX5+HHiPVLFfiLpP7ZXwj8eTaBCuorNH8NvGPwhNh8ONajmv4xDd/a9H8Nm31K GwuZ/wCyr2GIT29jp+p6Eb3x7/g6q/a8+Kn7NH7Avhf4feBvhF8OvFfg79qH4ix/CL4m/Gf4 wfD6H4rfDX4BaTHDY61pet6l4D1HwN470S98TeIZYdQk8La9qOi6vf8AhlvDGq6h4T8Ma74x bQbrRex/4KV/Ar9oz9hr9urwt/wWx/Yv+EuofHjTX+Etx8Dv+Cjn7Pvh9rWfxx43/Z20K88M a5pvxc+FGnXt9ZnUviL8PbLwhp0M+n6f9o1C507w9oVqtp/wjd942u4f53f+CvH/AAXGT/gp 58d/Bn7EH7O/xG+KcP8AwTA+IPw68B+Nf2jvFv7MXwHv/ix+094stft1v4h1nw94k8D+LD4T 1LwVpngj4gad4R8I6voukapY2t0s1z4ovtc+I3hvXtE8D3oB7T+zD/wTb/4NPP2U/gp4c+L/ AO1B/wAFAvg5+2v4nvvD+m6rqsurfHi+05LDV4NOv9euLjwv+yh+zxrMfxu0OC5sdPksZvCH xX/4WPqP9qNbaM0UOu6xpWjt+on/AASB17/g2a+I/wC2xK//AAS8+Gtno37WHw++HXizVfDP iO98P/tSaLbXXw+sUXwR4s1zwhF8Y9Vm8KxahfaV4vhttSmv9I0jx5q+jaxJLcwXC6dqY038 ZP2XvCv/AAQ1+A2oajH8Av8Aghd/wV9/4KK/FTwv4a0W9tvEHxr/AGXdT+KHhrUJjfWaarJ4 n+HMHiRPAOiWTXNpZTHWbj4Da/591e3Xh+zNno95drfa2v8A/ByH8HP+Cb37Z+ofDz4cf8EG vgt+wzZ6K3hXwv8AtEaRYeCvh38Gf2rNS8GeItJ0PxqkMVj8Pvhh4J8P6XFDaavoni3wx4Y8 Uar4r0Txlp9tpGpHXfCp8QwX3h0A/dz4trqf7Sn/AAdJ/soeHPDVvfS+F/8Agm/+wd8V/i/8 Qtajj8rTrTx1+0tZ+K/hPp/hC9uTpc0cl3eeEfHXg3xRpNi2q2t1qEdprt3ZQJa+G9XGpf0y 1+Af/BAf9nf406Z8If2hv+ChP7WfhO88J/tW/wDBTn40Xn7RPiLw7rNzHf638PPgLHava/s6 /CyS4l83UrDTPDXhHUtQ1PQ9D1Ga11PQfDGueG/Dmu6Lomv6BqOnW/7+UAfl9/wVs/bx1D9g /wDZcg1n4cWdt4i/ak/aI+IPhf8AZf8A2OfBFzZRala+Jv2kfi19s0vwJda9Zy3FrBH4P8KS Q3HiXxJeX09vp9wLDT/DZuBqviXSLa6i/wCCf/8AwT2j/YA+APxA1SPVbH4//t0/Gex1f4i/ tL/tMeKobk+K/wBof43PbaxqWiWWq6rrWrR3+mfDjwvf6iPDHgfwpb6roGg6Lo32rVYrDRdW 1zWriT86P+DgPWH+Bnx6/wCCM/7cHjfT7i4/Zu/ZX/blltf2gtdXQL/XdL+HOi/GPTPC3hzw x8U/Er6akNxo2heDL3w/qjR6tcajBZDxJqfhywGl+I9Vv9I0S6/pVtLu0v7W2v7C5t72xvbe G7s7y0mjubW7tLmNZre5triFnhnt54XSWGaJ3jljdXRmVgSAfyBf8Gxej/s7/tU+Hfi3+3d+ 0vrnh/42/wDBXPW/jj8UtC+MPij4x6hpV/8AG74SeHPD9t4c0Hw5oHw8+G+p3KXHwu8FWHhm a30G01Xwx4T8PDTo5tc+GlnfW/hzw/H4ftP3i/4Ki2X7APxZ/ZU+Kn7Kf/BQL9o74XfAL4Tf HfwxZWmo3vjL41fDT4QeMAvhvxRo3ivw94k8CXXxGnuLG71zw74x8NaLqmjmTw74isZtW06C zutJ1GOSSym/FP8A4Oav+CVX7LPij9h39pv9vr4R/swWNl+298L08A/EUfGj4U6prXgfxHHo GjfEvwfc/FDx/wCO/Dvh3WNL8MePr7QvhxF4i1G98Wa3oOpeN9Eg0+21mz16Cy0W4gk/CT9j H/glP/wbQ/tX/AD4bfFr4xf8FePiz4G+OfiPwjoV98bPDXxZ/ab/AGYP2fNV0f4pS6XYy+Nt N07wz8d/glc+JL/RrHXbi6tNJ1q28W+NLDWLKBby08R6iPPaEA/rT/4IW+C/+CSH7PPwJ8c/ s5f8Evf2qvDv7RFg3xE1b4ofEu48QfFHwj4w+NV54h1fw94U8OprOvaFo/hnwBfWXg620bw9 o2l6Dd6X4G03wodRt9cW2u7rX5PELn916/g//Zp8V/8ABrT/AMEO/wBpe6+O3wc/bV+MH7RP xwsfh/qPgLSYfDfiBv2ivB/h601HT4YPEmv6F4n+DHwq8GfC/UfEnjOG1XTr3+1PHmvaLYS3 0r6DoPhm2Vru0/tD/Zc/ab+Dn7ZPwC+Gv7TP7P8A4jvfFnwh+LGj3mteDde1Lw74g8J393Bp mtan4b1aC80DxRpuk61Y3Gm6/ouq6XK01kLS8ayN/pN3qOkXVjqN0AfMP/BX34NeGfj9/wAE uP2+/hj4rstKvrHUP2VfjH4o0f8AtyTydI07xz8NfB2pfEz4beIL+cW149vB4Y+IfhDwv4ja 5itZp7dtLWe3Tz44yOe/4IufGfxv+0H/AMEq/wBhb4t/EjWdR8ReOvE3wC8LWfifxDq4iGp6 9qfhSa+8Gy61ftDYaak11qieH476a5+ys9085uZLzUZJX1G6/PD/AILAftveJ/2nL7xn/wAE Vv8AgnbYaZ8b/wBrf9pLwtr/AMM/2ovGGj30t78PP2JP2ePEp0jw58VPGnxk1a0s5dITXtb8 J+I9S8JWHg4a7Ya/pl1rNu0ttc+KNS8F+EfF/wC7H7Mf7PvgT9lD9nf4Kfs0/DJLweAvgZ8M /B/wx8M3Gptbvq+p6f4R0W00n+3NcltILW1uNe1+4t59b125trW2gutXv724it4UlWJQD3Oi iigDzj4xfCnwZ8d/hF8U/gf8R7CfVfh58Zfhx44+FPjzS7W7m0+51LwZ8RPDOqeEPFFhb39u RcWU95oesX1vDdwETW0kizREOimv5bvhV/wRo/4LffsG+HtR/Z9/4Jv/APBXD4WeHP2QdL1D xpqnwo+Hvx+/Z68HeIvF/wAL08b+Ltc8VXOlWWqX/wAOfinHqtzpt3q0uoXes2uqeH/DHifx Jqmv69L8L9Ae+FrX9bFFAH8s+t/8EtP+Dh74q6dbWvxT/wCC/ll4Qkl0yOK/T4Nfso+BvCT2 15BcpfxW9lq/gCH4M6jdxPdRrDPrEi6fqE1gXsp7Saxlksm8I/4J3/8ABrT/AMIJ+058Sf2q P+CtXxh8K/8ABRnx3qVpoaeArLxvqnxJ+IOnazr1taSaNqHjH42T/FOSS++I99pPhjTfD3h3 wf4Z8Rz+JvDFjZm8mv7W5udH8Mvp/wDX1c69odnrGl+HrvWdKtdf1y01S/0XQ7nUbODWNYsd DbT11u90vTJZlvdQtNHbVtKXVLi0gmh09tT08Xbwm9thJq0AZ+k6TpWgaVpmhaFpmn6Lomi6 fZaTo2jaTZW2naVpOladbR2en6Zpmn2ccNpYafYWkMNrZWVrDFbWttFHBBHHFGqj+PDwl4p8 f/Hf/g7ah+K3we/Zc/aB8JfCX4Ffs5+PP2Zf2kfi74i+GHiX4feDPFHivwzofxROl/ES+17U lXSPF3g/xHqlz8OPB/w41C6ubGfxtonhTRfF3hbS9T0TSdN1O+/sfooA+Gv+CmvxE8cfCj/g nl+2p8QPhp4L8U/EHx94d/Zo+L8vhPwx4MiafxFNrV/4L1bSrPWLOCJ0uprbws9+fFWrR6cs +rPo+i366RaXuqG0tJvwv/4NBP2VtX+AH/BNLxp8R/Hnwd1v4Z/E39oX9oHxR4mn1/xj4bj0 Dxj43+FXgzwz4W8MfDYqLrTNP8QjwLo+vP8AEu98I6frbXMS6p4l8YeJNFkGleK4Wk/q1ooA /CT/AIOYdI8ba7/wRD/bn07wFpuq6jqy+HPhHq+rDRrw2d5Y+CfDH7QXwn8U/EDUpissL3Ol WngrRddbXrNHxPobaiJori3E1vL8Q/8ABPD/AIKZ/wDDQX/BKLxd8Kf2Zv2Uvj14X+Gv7IX/ AASQPh+7/ab+I1r4W8L/AAo1j9pD4a/sz6bpEnwo+G41RJtY+J9tp+saZ4ifxJ8TY/DFnplv rfh+Q6p4Sk0nxPoer6j/AFc1R/svTP7M/sX+zrH+x/sP9l/2T9kt/wCzP7M+z/ZP7O+weX9l +w/Zf9G+yeV9n+z/ALny/L+WgD+Zb/g0t+IX7NOv/wDBJP4VfDz4R6z8PZfjr8P9Z+Imp/tT +GfDx0sfELSPE3jb44fGST4Xa38TvslhYahdN4l+Gvh3TIvA9/qX21U8L6FDoVpqFw2gXax/ 071+an/BO7/gkr+xN/wS4tfi9D+yN8P9d8M3fxs8RafrXjPWvF3jDWvG+urpGgHVG8JeBtH1 PWpXnsfB3hJtc1t9Kgm+169qE+qT3PijX/EN1b6fNZfpXQAUUUUAFFfn58df+CqX/BPn9mb9 pb4dfsgfHf8Aag8B/Db9oj4pwaLceEfAOuWfiuW3WPxJd3Vj4cXxb420zw7f/D74dT+Ibq0k j0K1+Ifirwtc6wJrGTTobmLUtPe6/QOgAooooAKKKKACiiigAooooAKKKKACiiigAooooAKK KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA/mK/4KQ+FH 8Yf8HF3/AAQUsMXIh0vwZ+2v4ruJrcECBPCHwk1vxLbm4k+zXSRW1zf6ZZ2Dl0jEz3cdqlzb TXEU8f8ATrX85niqy8IfFv8A4On/AIV6XqsFpf3/AOyp/wAEdvGPxU8LXCacn27R/iX8Rv2l JvhZq0dzeatZXSNaD4T/ABInNldeF20y/jm1+/0++1y7sJtW0Bv6M6ACiiigAr8af2u/+CCv /BN79rvxKfibcfCvXv2avj7HqC6rZftGfsfeKH+APxdtdQZrA3F/czaDp9/4D8R6pcpplnF/ bPjDwJ4j1qwVZ30jUdOnvb2a4/ZaigD+ayw/4IFftOeEp4tF+HP/AAXq/wCCregfDloItOuf DHij4sS+O/EVpo1qk1nY6d4U8Y3us6Xb+DfsekvDZwy6L4XSKO5t476C1g8u1trX8Rf2Dv8A gl/8DX/4Od/2wv2YP2q9T+IP7e+kfAP9kLw78brD4hftrXo+L3in4k/EPUtN/ZEi0TxL4tl1 xX07xpp/g3QPitqngjQ7PxRb+ItNt7fw5DbPbGXTrEab/oG1/CBrf7WHiD9mX/g8m+LVrF4D 8RfFl/j18MPhF+zBrXh34J6Fcah4n8PaD4/+EHwC8b6T4r8aWHiHUobW50/wGnhDw74z+IOr aLe2VlpvgOwk1a0tJ7/TrzTL0A/u7iiigijggjjhhhjSKGGJFjiiijUJHHHGgCJGiAKiKAqq AqgAAVJRRQB5j8aPgx8LP2ifhT49+B/xt8D6H8SPhR8TvDd/4T8c+CfEcEk+la7omooBLCz2 8tvfaffWk6Qaho+taVd2Ot6BrFpYa3oeo6dq+n2V9b/zf6F8Df8Agr5/wRO0S68KfsfeGYv+ CtH/AATx8P3K2vw2/Zt8a+NrH4dftk/s1+GJrjVNRbQ/CPjqXw1qWlfFv4faHGttoml6VZWG t+KbeXUNHsfC3wz8MeGNH1rU2/qOooA/nU8I/wDBx78EIXu9A/aC/wCCf3/BVL9mP4iabpFv rl74M+Iv7GPjPVHvNKnvJLWXVNBn8O3t3rk+kab5+hrqeqeJPC3hO2W88RaZZ6Z/amZp4/zH /af+JX/BCv8AbF1rwv4+tf8Agg7/AMFEP2mPHAE3jT7T+yz/AME/vip8H73xNZR6asGk6t8T tY8A+Mfg5L448K6jc6zpRh1a4PjKTNppUN3HNpH2fTdR/tjooA/ybv8AgnL+yn41/al/4KMf tNftG/sg/wDBHW0/ae/Zs+HfxD8deGfBn7Lnx/8Ait8PPhX8JPgLrni26uLHwhp3xytvivbe IZfiFP8AD7QYdXvtR+GOiXY1+HXo7C7l1e9XS49L1z+13xF/wTk/4LAfteaH4c8D/tPf8FDv hV+wl+z1pPh+LwrN+zP/AMEqfhr4l8HXVx4PtbO2s9G8ND9oL4m6nbeLvDn9j6VFF4dutO8L eEk8BX2kWTWNr4PtrLUWjtPGP+DT1NS0r9k3/goJ4U8U69Za3488Pf8ABWH9pxPGM0OnReHr u71J/hr8AtNudel8J/btQufDdlrms6Lrj2GnTXd3FayWV9psN9eSaZcSD+pugD4//Y1/YM/Z S/YF+G0fwx/Zc+EPhz4d6ddR20vi/wAVrANW+JPxN1qDzXl8T/FD4h6iJ/FPjnxBdXNzeXX2 nWtQntNNN3LY6DY6TpKW2nQfYFFFABRRRQAVyPj/AMfeC/hV4F8Y/E34j+J9G8FfD74feGNc 8aeNvF/iK9i03QfDHhTwzptzrGv69rF/Oyw2mm6Vpdnc3t5cOcRwQu2CQAeur+PT/g44/ah/ aR/ay+LXw0/4IL/sBeH4/F3xm/aK0fwx8Qv2ofFel69dW9l8L/hHFro1DSvCvxEv9M067Hgb wpqCWOk/EL4j6vfXZ1SfwM3hPwvp/hvxAvxR0/TdXAPyg/aB+AH/AAUg/aivfi//AMHTXwH8 U6p8NtX+HXxY03xr+y3+zklhr+v65rP7B/wT0B/hzqvxHMl7qmrSaJpXjbS9H1vxR42+Fl74 L0vQ/Eeh698WviSH0/RfEOgW+sf3j/sU/tX/AA2/bh/ZX+CH7VHwo1XTdS8JfGLwHo3iaS00 2+/tD/hFvFBgFn428CanOYbeRdc8B+LrXWvCOtxS28Drqej3JWPymjdv4t/+CcXwE/4OMv8A glpF8bP+Ccv7J/7CX7KfxX+ESfGLx/8AFLXv2nP2iX8XwfC/4kzeKvDfhPwbp2t+G9Rtvjt8 OFvPD+u+DPh34a0dvh9pPg7X/FWia5qNxd+LWstKF9cR+A/8Ek/gT/wWw+CP7X/7Z3/BG34C /wDBQX4Nfsnal+zY1n+0Z4yv/D/wd8KftG/D281L4iaf8N5P7D+Edj8YfAdpqHhjwfqukfED w1rur2sXh7w+1jr2nrH/AGet1qmq3N4Af6K+s6xpXh7SNV1/XdQtNJ0TQ9NvtY1jVb+ZLax0 zStMtZb3UNQvbiQrHBaWdpBNc3E0hCRQxu7EKpNfw+fszf8ABa//AILnf8FhfH/xwvf+CYfw m/Yf+Dnwh+Gl/o3hqDRvjt4rTXvi3o2n+JNdt9T0zx9rMJ8UfatTmtdH0KbRNVutN+GP/CE2 tt4r1fSdHj8V+MNN0/W/Dn0N/wAFO/2Qv+CzfwR/4J6fthfG745/8FzPE/xf8K+APgP44gvv hL8O/wBh79n/AOBMPjrQ/FkegeHtf0nXviD4L1Bdc06C802/1nTYptM0dtb06KWO/wBG8QaU 99qdhN+Pv/BPTxH+wl/wQf8A+CX37L3/AAV68UeA/E/7S/7f/wC2p/wuDwJ8EfCtt4+13wj4 I8BeHdA17xz4a8VQpp76ZpFifDGj2nh7wVZfFLXdZ8PePvEr+NfEukaT8MZ7LwjNqfimcA/V v4i/8Fof+C2P/BK34uy69/wV/wD2JfhN45/ZC+IPxD8P+FNE+Pf7Jeo3Np4I+Gsd9JI+o3Og XM+q+PvEesQNYSXNxoXgX412Pw58ceJJ/DupLoniO6tt8tf1++GPiZ4B8ZfDXw98Y/DvizRr 74XeKvA2k/EzQvHMt0NO8PXngHXNAt/FOl+LJL3VBZLYaNceHbqDWHutRW0FrYuZbsQBJAn8 AXh34kfCX/gqz428J/HX/gun/wAFkv2SfA/wH8N+J9C8f+C/+CYX7OHxT0ODwBBpiabpOswa N8UfHvhLxJNqb6vG82qaD4itYNW+JfxGJv8AVbXwz8VPAUUFhodv9Df8F2P+DjT9lbxn+yNf fsN/8Ervivrfjf4nfGJfDPws1/xn8KfBGreCvAXgP4N6vp15pGv/AA78I3/i3wlpFxqPiLxV pTaF4JsrH4f6XaWPh7QNe1JrTxnpWv6I3h6YA7XTP+DkL/gql+3N8YP2hfCn/BIX/gn38Bfj f8Ofgx4iktNM1f4m+Po9f+I+qeCYtf8A7A0r4h6v8PtP+NXwW1BdM8at5N/p1n4c/t6x8Li6 fT77xJ4hfS729b9L/wDgh1/wWv8A2g/+Cjvx4/bF/ZV/a6/Z48Dfs7/H39lWezkvPDfgi98T Nk6f4y8QeAviF4a8TaX4l1TX2s9d8DeJrHQLJtS03XbjT9b/ALYungsbKKwimvf5Mf2ev2av jt/wQx8feAfhx4FiufiR/wAF2P29fhVN8JvgZ8EPBupeHPEXwl/Yo+FHxm1DSbW8+J3xb1sC W28cftKpq3hS+g8CeGNPuNZ+BXgXQ9F8XeP/AIg6j480e38K6brX9nX/AATz/YA+Af8AwRF/ ZK+L/j/45ftK+A/+Gkfjncah8S/2rf2zfjh4nsNB0PxR8T7lNY1DTbG01Hxrqljf33gzwr4g 8Save2UesahL4t8feJNe8Q+JtVWyvfEmn+GfDwB+vf7Q/wAfPhd+y38D/ih+0N8afFekeCfh f8I/B+reMvFviHW76CwtYbPTocWemWbTHffa94i1SWw8O+F9Dso7nVvEfiXVdJ0DRbK/1fUr Gyn/AM939kf/AIObv+CqelftQ/Dr9qb9sTwXdwf8Ewf2j/jc/wALA3/ClofD3wi+EOlDV7LS dWvvhR8bLfwzp+ueKvEHwvtLr+1PFFj4t8YeKU8Uw6X4os0sNL1S3jm8PfBnxM/4KNf8Fov+ C2Xw/X/gmRp+heG/23P+FSfEvxP8Ufit8RfgB4N0TwJe/HvwN4F8X29j4Q1LxPr8OlfDrwJ4 b+HekarqG7wVqmm+AvhzqviZNT8DyeJNDvvF2jzTar9rf8F1Pjv/AMFDvHf/AATA+Ef7Ofxj /wCCO03/AATz/ZO/Z48ffBB/CHi6z/aI8P8AxC0vS9a8G+CPGfwx8M+CrLw/Z2Gk6nfaJrGm +Lb64s7LUJPEes2FzpUWsaxrutXVvc6qoB/Sf/wXT/4Lw+Iv+CQH7QH7C3gfQ/hz4I+KvgD4 xy/ETxZ+01oN9Fqx+K2gfCnw/rXgPQPC+qfCC8tfGXh/w1p3iXU7nUviLcpF460bWdD1658J WWiQX3h0T6jrdl+v/wAbP25vhd8Bf2E9d/bx+JWnap8PfBmm/s/QfHKx+HXxQ1Pw74L8ez6t q3w+/wCE48M/BnU1stU8UaHa/FPWr+W18Ef2N4f1PxZB/wAJVLLbaPca9bRRz3H8q3jH/g3Y /wCCg/8AwVr/AOFY/tbf8FJP+Chng/4YfFiD4bfC0/Bb4f8AwE+D1z440z4OeC7iHT/GF34b 1XxbrHjjwJrep+M7e6vrqa78QDxH48uI/Gl5fa9H468T6PaafYXXyx+2h/wRl1/xx/wUz/4J uf8ABPb4tf8ABTL9sD9vjxl8V/EnjL9oj9o7Q/2h/iB4u1Xwt8Gf2VPhgx1KS+8PaPqOsePV 8M+LPjJLpvxO+GngTVLHU307SfECQLq2jaRo+qW97dgHyZ/wbm/8E2vjv/wVA/4KB6t/wVj/ AGo73xDH8L/hJ+0E3x6/4S+7t7i1k+OP7UFn4nfx5omheE7i7kl8jwd8MvFK6N4k8VT2y3Nj awWfh/4f6Zta91O68O/6bNcb8O/h34F+EfgPwf8AC/4Y+E9C8CfDv4f+HNJ8I+CvBvhjTrfS fD/hnw1oVlFp+kaNpGnWqJBa2VjZwRQwxouSFLuzyM7t2VABRRRQAUUUUAFFFFABRRRQAUUU UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQB/njQ/8ABUj9pLXv+Drn4s6B+xP4Z+Gvjyw+K/jzwF+wx4t0f4meHfE9mH+FfwAttJu/ 2gdZsb6LVvC2qaL4n8LeIvA/xW8ReH9ems9R0z7Jo2jwS6F4n0vfHq/+hzX8l37EvwE+BPxM /wCDoL/gpN8avhd8Ffh14P8ADn7GHwF8E+CNW8T+CotQibxp+1Z+1VcD4kfEj40+KUM0dnB8 TNQ0/U/jf8I/ECQRPp+oabokmqywNrktzer/AFo0AFFFFABRRRQBHLLFBFJPPJHDDDG8s00r rHFFFGpeSSSRyESNEBZ3YhVUFmIAJr+WT/g3U8IaJ+1B8Z/+CnP/AAWS1HSma+/bR/al8bfD L4A3uo6bLpGraJ+zN8KdVt00OJ9P+xQwR6h4q2+C9K8Y3Uep6vHe6/8ACq3aOLR7uHVI9R/b L/gqL8S7r4O/8E2f2+PibpurSaHrng/9jz9ozVPC+qxJftLZ+MT8JvFdr4MeNtM23sMkniq4 0eFLqGW3Fm0gu5ruzghluoflj/g3w+HOhfC//gjL+wB4f8PpttNZ+Cv/AAsa9ciQSTa78WfF /ij4neIHkaae5kk2az4tvoISZRGltDBDbQWdpFBZ24B+ylFFFABRRRQAUUUUAf5oP/BQrTf+ CmX/AATz+Jf/AAcU2vgTwl8V/gn+yZ+1B8SfA/xqtv2gLWbx34c0TW/F3xQ/af8Ah5q9n4b+ CXxU0+aHw1d+IfiN8Pfjp8R9K+Mvgzw/cL4hTwt4YXRfEOp6Xp/hI+H/ABB/fr/wTy+GHxQ+ DX7D/wCy58N/jX8TvHvxj+Lnh/4N+D5fiN8QvideHUPGur+L9dsF8R63p2rXjyT3E9v4VvdX l8I6Ib+71DVF0DQtLTVdT1TUlutQufxq/wCDqrWLSy/4J2fBjQL/AFCOC08dft+fsseE7jR5 5iLTxXAt3418T3Hh++sWP2fV7T7P4al1uXTruOe2J0VbxojJZxOn9L1ABRRRQAUUVla9r2h+ FtD1nxP4n1nSvDnhvw5pWo694h8Q69qNnpGh6FoekWc2oatrOs6tqE1vYaXpWl2FvcX2o6jf XEFnZWcE1zczRQxO6gHBfHCb4u2/wY+LE37P9l4R1L46RfDjxq/wcsfH99d6d4HufiePDuo/ 8ILF4vvbC0vb2Dw4fEv9mnWTbW7TPYCeNJLcv9oi/DP/AIIGf8En/jN+wj4S/aA/aT/bj1Pw 54//AOChH7XfxI13xb8VvH+na7H4v1HQPAd7Pp2tW3gi68Sx2Fpp82t6545/4SDxp4zfwu7+ Gboy+DdHszPH4PtrmT9DPi1/wVy/4JffA6wkvviX+37+ybo8kdvp15/YmkfG/wAB+NPF8tjq 9i2p6XqNv4I8D6z4j8Y3WmahYBbqz1K20KWxuIp7Ux3DG7tRN+VXxd/4O2/+CN3ww1XV9K8P fEf40/G9tK0+S8iv/hF8F9aOlaxdpa2lzHo+kX3xQ1H4YxS6hcNdSWkc94LHRY7qyu1utWt4 RbTXIB/TPX8+n7Bf/BLX9sX4Cf8ABYb/AIKG/wDBSj9o344/Bbxx4H/aq8O6x4B+GPgf4cW3 jf8A4S608G6b4w+Hf/Cp7jx5F4i0HRtD8Nah8PPhV8M9H8Dy6VoGs+PY9dvtSuNU/wCEg06P T/s+q+UaR/wXS/bt+Nvgi08Zfsmf8EGv22/iFpniSBtc8D+IvjP4w8H/AAH8J+IPBZv3tLfx Euo6toniEyX2oQtaXem6Fp73kWpWVxNqmm65faPaLf3fK+Pf+C2//BXH4RfDHxd4/wDip/wb v/HzSLXw34ct3tdU8D/tO+HfivFc+KrvUdL0y2bV/Bfgj4LX3jTS/CKi7v8AUr/VNJh8T3Ol raWljfRxWF5e+JdIAP10/wCCuP7PPxd/aw/4Jtftffs6fAbRND8SfFz4tfCe88LeCdC8R+JL fwhpWqajJrWjX1zaN4hvbS70+wvpNMs77+x11T7BpF7rAsNP1bW/D2m3V1runfFf/BMf/gkr 4Q8N/wDBHL9kr9g7/gpV+zt8Hfir4s+FUnxQ8W+IvAfii38PfEnTPAvijx58dvir8TdFk8Oe LtPE0el+K9M8KePLPw/4h1rwPrIt5Xn8Q+H7TXdb8OXk0+pfFHwu/wCDj347/Cr9qX4Sfs1/ 8FRv+Cd+ofsbWHxv1vw34U8KfFTwR8bPD/xq07wb4z8aRaLJ4R8M/FLwf4a0i5ufCkuoLrUL 69De+J7Txt4OIEerfDqaC21y+0P+sOgD80Phx/wRo/4JSfCfWtP8R+CP+Ce/7KFnr2kXK32k avrfwc8I+M9Q0jUYtWg1u01XSbnxpp/iCTTNX03UraCfSNWsWg1LR4oltNKurOyzbn+V79qP /gnj+0P+19/wdQfCTSk/Z91PwP8AsW/sd2f7Nfjzwd400n4b614I+Ct18Jvhdpfh/wDaG17w xpXiO08Lav4C1bW/Fn7SnxC+IXhm+8P6RHosmrfadetZ59I1Ky1fxQn96FfzA/8AB0P/AME+ /wBvz/god+zT+z58Mv2HvCv/AAsa18KfFXxB4n+MPwzj+JfgT4azeJbJ9B0+18D6rJdfEXxH 4O8M65Y+GdSXW7mbS7rxJFNDe32m6la6VqN1ZQXGmAH1h/wU/wD+CBP7J3/BTz4p+GP2ifFn xD+OHwB/aV8EeFtF8JeGPi98EfE2j6ZK+l+HtV1fVdFXxHoOtaFqTahc6VNr2pjT9U8P614S 16HNjE+sTWNkLGb4Y+I3/BtH8OtI+AvxS8c+J/jJ+0Z/wU1/bJ8BfCzxpN+ylp37cnxw1zXv gv4d+JWj+F2i+FGlN8P73U/+Eb1TSNN1XTtMs28NfEvX9d+F2vxeTovi/RbTwk90tr8o/wDB mp4I/at8WfA/9of9p34u/tJ/Fjxr8C9V8Q6R8APhD8DfGfjXW/GXhnStb+G+l6Dr3iD4iaTa +JLzVW8IRaZpXiPRvAHh7TvCs+j2eq2sHiFfEunX0fh/wRPp/wDYt8UPjX8Gvghpuh6z8afi 38MvhDo/ibxHpng/w3qvxQ8e+FfAGm+IPFutS+To/hbQ77xXquk2ureI9Wm/daZolhLcanfy /u7W1lfigD+f/wD4Nuv+CP3xC/4Ji/s//Frxj+1D4a8PWn7Yfx7+IWoTeMtW0rxbZeO59H+F Ph1bVPBvhh/EWnrNp7Xur+IpfFPjXXn0/UtS/tD+2PD6apdLqGjmysfgz/g7r/aDvfiN4T/Y /wD+CT3w18B6j4k+On7XHxy+Fnjnwhr02qabaeHrQJ4n8RfCXwr4VNok0+strnijx34t0tYr +exi0i10mx1Hypr6/Yw2X9oFcH4l+Ffww8Z+KPBnjjxh8OPAfivxr8OLu9v/AIeeL/Evg/w9 rvijwHfalFHBqN74M8Qapp11q3he7v4Ioob240O7sZrqKOOOd5ERQADp9B0TS/DOh6N4b0S1 +xaL4f0rTtE0iy864ufsml6VZw2Fha/aLuW4u7j7PaW8UXnXU81xLs8yaWSRmdv5P/2XPGMP jH/g8A/4KO6H4qsZb7Ufhf8A8E9Ph74Z+Gd5qt7pksfhrRZtK/Yu8Xa5Z6Hp6ac8yXOuaj8T Ne1OC+TVhqNhp914itbmKW112Wy0X+tWvhD4Of8ABM/9in4C/tY/GT9uT4ZfBpdI/ao+PcXi S1+JvxZ1Lx18R/E17q+n+LdZ0HXtd07SvC/iTxdqvgfwpbXepeGdFcSeFfDOjXsVpZ/2ZHdr pc1xZygH3fRXwp+0x/wU6/4J8fsdXEmnftKfthfAb4WeIobyGym8Ear490nV/iPDJO06LPL8 NPDEuuePotOiktpYrvVn8NrpdjN5UN7eW8s8CSfi98Sv+Dvz/gjx4Dlv4fDmu/tHfGJrLzxG 3w1+CZs4tQkgvXtBHYTfFTxZ8MYn8+Jf7QgmuXtbZ7JkDzpeE2YAP6jK+E/+Ckv7fPws/wCC aH7HvxW/a4+K1hc+I7DwLZ2Wl+DfAGnana6PrPxN+JXiW5Gl+CfAWl6ldW98umrq2pyfa9f1 uLS9am8MeENN8ReKl0LWk0N9MuvDf+CS3/BVzwT/AMFa/hF8SPjP8O/gB8b/AIJ+DfA3xBPg vQdW+LGlacND+I9m1ibltX8GeJtEuLrQ9Wv9Eu4LrS/Geg6fdah/wil6+kRz6retq6JbfJ37 dH/BMf8AaU/by/4Kz/sbfE/43zfDTxz/AMEtP2Y/Ctx47ufgne/ELxjoGv6v+0XbWfjS80Tx hr3gHStBm0fx/NZeKYfhrZi01vxJpnhsfD228TaVLHdHWfE/hzxgAdj+1Z/wXC8O/slf8EkP gt/wU3+If7OPiDSvHPx30r4RL4G/ZN8YfEBvA3iO78X/ABJf+1dX8PH4gX/w81K/bSvDngPS /Fnj3SfEg+Fyv4q0XSdF83Q/DcfiQXWlftL8MPFmqePfhr8PPHOt+GZ/BWteNPA3hLxZq/g2 61K31i58Jap4j0DT9Yv/AAzcavaQ29pqs+g3d5LpU2pWtvBb30lo11DDFHKqL/Mn+0/8KdN/ 4Kv/APBwJ8C/gxqK6H8TP2MP+CSvwci+Mn7QGkyWd5qvg++/bC+KviDUZPBXwa8VtJdaj4S8 R6laaD4a+GXjibQLnRRHaaR4R+LPg3xPfyXOppokH9UtABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAV558XfiDH8JPh R8TvirN4X8W+OIfhl8PPGnxBl8F+ANEuvE3jvxfH4M8N6l4jfwv4K8OWKSX3iDxbr66adJ8O aJZxvdarrN3ZWFujTXCKfQ6KAP8ANK/4Iwf8HC/7L37Gn7U//BS74lftnfCn4ueCdf8A28v2 mNZ+OVz4j8B6FpvjdfhlLaeIvir4jt/hV400vV9S8OeOjpvhi88e6h4f8OXWm23iFrG9nNre eHfD9i+p6sn9Zfhf/g5z/wCCHfiv7DHa/txaXpF3eC3V7PxR8D/2lPDX2G4n0+91Fra+1LWP g7a6Ihto9Puba4vINVuNLGoGysIb+a61bSI7/wDeW4t4LqCa1uoYrm2uYpLe4t7iNJoJ4Jka OaGaGRWjliljZkkjdWR0ZlZSpIrwT/hk39lj/o2j9n//AMM18Ov/AJnKAPzhT/g4d/4IuSWN xqC/8FAPg+Le1u7KyljfSviNHfNNfw388D2+mSeCF1K8tI0064W9v7S0nsdOmksLfULi1uNV 0yK8zbn/AIOMv+CKVpA9xL+338MXjj27ltvCPxevZzvdUGy2s/h1Pcy4ZgW8uJ9iBpH2xozL +kZ/Y7/ZGOorrB/ZZ/ZyOrpZPpqaofgh8MzqKadLPHdSaet9/wAIx9pWykuYorh7USiB54o5 mjMiKw0of2Vf2X7Z2kt/2b/gJBI0Vxbs8Pwf+HsTtBdQSWt1CzJ4dVjFc2001vcRk7JoJZIZ FaN2UgH5I3H/AAc5/wDBDu3m1mIftufbE8Pztb6vfaV+zZ+13rWk2hF7/ZyT/wBtaR8Ar3SL ixub0pBY6la3s2n6g0sLWNzcRzwu+f4l/wCDmD/glLp+naBq/gTx5+0L8adJ1+K9nTVPhh+y D+0qdOsILU2q201ze/ED4a+Aba+i1Rp7hbCTw9LraIdNvRqLaeWsftv7yaFoOh+F9H07w94a 0bSvDugaPaRWGkaHoWnWek6PpdjAu2Cy07TLCG3srG0hX5Yre2gihjXhEA4rVoA/z0P+Cz// AAdbfBv4/wDwS+Mf7GX7H/wP8Q+MPAnxv+EHij4a/E34ufGe2vvh9rfhHU/E8OqaNqel+D/h ysWq3eoXujWpsrmTW/EmoaKbXVRdWNpotx5NvrKeg/8ABE3/AIOg/h18Pv2cf2eP2AfH/wCx F+2H8afi98Ivhrpfw1+Fw/Y98NeGv2hfG3xf0zwPpvifWNQmPwn1DV/hh4i8M/8ACHfD7RbC 6mi0DUfiN9q03SPEGt6k/h7T9J3XP4Q/tlf8Evf+Cm/7An7ef7UsfgD9iD4o/H7wP8Vbr49e Hfhr8SdP+BHi79qzwX4h+DX7QF/4o8PpqFj410PwnqUGg/Gh/A2s33hvWr28j8PfEnwrquq6 hrOl2unrq/hzxBefJ/8AwTA/4JtftUftBf8ABUn4L/shwan4w/Y5+Pnw98W6F8XPFXiPx7of iDwR8VPgdpvw2t9C+KY8UaN4P1XT7TxDB8UNP0ttG1fwDoOqW2kLJ4gu9Fm1vUNC0ZNQ1axA P9HOD/gv3KILL+0f+CK3/BfO0v7mOJJLWD/gne1zAL77M1xc2tlcz/Fuwmvo4RFcPFM1jazT W0DXElpbgPHHmW3/AAcUfDoahNba7/wSj/4LgeEdN0zV7PSfFXiPxH+wJHHovgg3V/pVhPfe K10n4vatrFjbaa+taZLe2tppF/rLre2cGn6Vf399YWd1+qX7Hv7FPhL9jjRPFNho/wAc/wBr X9obxH40j8NW/iL4ifteftI/ET9ojxvNY+Ev7ebQ9N0afxhfjw74Q02C58Ua/e3ln4M8OeHo dWvNQE2rLe/YdLWx+yqAP57T/wAHMH/BPCw1m30HxV4C/bh8C6n9psbbWLTxb+xv8W7O78Mt eCB5X13T9PsdU1NF0+GcXF3HpllqdzLCjNp0F+zwJN1Ot/8ABzh/wRE8M6pdaJ4k/bN1Xw/r Vl5P23SNb/ZV/bP0rVLT7TbxXdv9qsL/APZ3t7u3+0WlxBdQ+bEnm280U0e6ORGb96a4/wAb fDzwB8StKt9C+I3gbwf4/wBEtNQi1a10bxt4Z0XxVpVtqsFtd2cGp2+n67ZX9pDqENpf31rF exwrcx217dwJIIriZXAPyE07/g4s/wCCKuqLYPbft+/CyIaitq1uNR8M/FfR3jF2EMQv01b4 fWL6WyCRftSamtm9iQ4vVtzFKE63xP8A8F+P+CNvhL7D/av/AAUJ/Z/u/wC0PtPkf8IxrGu+ NfL+yfZ/N+3f8IboOvf2Zv8AtMf2b+0vsn23bcfY/P8Asl15O98TP+CFn/BIH4t6ymveL/8A gnt+zZa6mrXDu/gLwSPhNaXUt0Lfz57/AEz4U3ngvS9RuZGtkkNzf2dzOs0l1OkizX17JcbX h3/giV/wSL8LyafLpv8AwTn/AGR7ltM+z/Zh4i+DPhLxfHL9ltprSL+0IvFlhrcWr7opne4/ tVL37ZcrDe3fn3lvBPGAfx3/APBzV/wXI/Yp/bC8Cfsu/s8/shfEjWvjM3wj/aU8D/tNeOfH WjeEJ7L4Xj/hEfCfjXw3ofhuxvPFH/CMeL9d8V2w8Z6hc3VnpttpPhiOxuJLe81651f7Omi/ 6F/gnxdpHj/wZ4R8d+H3kk0Hxt4Y0DxdokkrWryyaR4k0q01nTXkeyub2yeR7K9hZ2tLy7tW Yk29zPEUlf8AOXxF/wAEUP8Agkd4o1Pwtq+pf8E5f2Qra78HtG2kxeHfgl4L8IaZdmKW2mUe KdE8J6ZomjeOVL2kSyL41sPECzRPcwSh4L28jn/Ty3t4LWCG1tYYra2too7e3t7eNIYIIIUW OGGGGNVjiiijVUjjRVREVVVQoAoAlooooAK8x+NPwa+Gn7RHwk+I/wACvjJ4Xg8a/Cn4t+Dd e8AfEHwncahq+kR6/wCFPE2nzaZrGnLq/h7UNJ1/SJ57S4kFrq+harpms6XciG/0rULK/t7e 5i9OooA/Cj4H/wDBvD/wRS/ZB0zUfHj/ALIHw18cyeGfDfiC88U+OP2oda1z46aJF4etvt+s 6jrGs+Dfipq2ufCDSP7B0rfDHruleAdHvrTTNOiubq9mvlu9QuPyp/Y6/Yf+Cn/Bcz9qy2/b ++IPwQ+Fngb/AIJP/sp+LPiL8G/2BP2TdC+FukeCNB/aE1fRNW0+Dx9+0f8AEuz8Oaf4asb7 wDrvjnSQtj8PJ7S/0jV77wpbeCPFmlx2PhPxz/wtb3D/AIO2f234f2eP2Lvgz+ypb+MvFHgC T9un4sT+Dfif4q8KaJ/bGsab+y/8MT4b1L47Jo6Pe6XFc63qV942+GmkJ4dl1bS4/F3hnUPF egXV9Dpt1qBP9NvwU+DXw3/Z3+Efw4+Bnwf8L6f4M+GPwo8H6H4G8EeGtMiSO20zQdAsYrG0 WV1VXvNQuvLa91bVLkyX+r6rc3uq6jPcX95czyAHothYWOlWNlpmmWVpp2m6daW9hp+n2FvD Z2NhY2cKW9pZWVpbpHb2tpa28ccFvbwRxwwQxpFEioqqP5pP2v8A/gof+0r/AMFDf2kviT/w So/4I7+JND0XUvB2jx6Z+2//AMFIYdYvpPCX7IOnajqGr2V74J+Eg0a40y78YfHDW/8AhHtR 8KaPqvhTVry40TX7vVLbRbjw1eeDvG3xQ+Ev7E/8FJfhx+0h8X/2EP2p/hb+yJrVv4e/aO8f /CLxH4U+FmszeK9Q8CzWWs60ILLUH0rxlplxaXfhjxFL4fl1e38L62byytNO8Ry6Xc6je2en JdXMX8iv/BM3wP8A8HEn7N37Ir/sUfsmf8ExP2ef2RvFKarqU3xB/ba+P/izw2vinxP418Ue JL65vviX4g8NXGveJ7/4k+JtH0m9j03R9XPg74meFtD8MeHbHSINBvIjoehzgHhH/BTD/gkN +yZ+xX/w7p/4J7fst3/i/wDaH/4KQ/ti/t7fDT43/FH41+PtR0vxn8XZ/hn8NvD/AI10nxlr niHw1pt7YSfDv4UX3if4k6h8RYPttzDP4ntfh1471Xxj8Q/Fsvw6XVfD3+h9X4X/APBMb/gj TP8AsjfF/wAb/txfthftCeLv21v+Cjnxc0a90Lxr8dvFMtzZ+C/AHhjUp4ZbnwN8HPCMqQjR dGW2tbHRf7Snt9PtLLw/ptn4e8DeEfh34bm1bQtU/dCgAooooA/n5/4KZ/tXfs4f8G7f7CPj n4ofsxfs8+EbPxR+0D+0VrEngb4S2et6zYeA9Q+PvxO8IanrniX4keINGl1ubUdH+H+jaJ8N re513wr8O18O6Vc6rJomh6cfCd14quPEVv8An3p3/Btr8Sv+CjWq/DP9rz/gr3+3h8Yfi78Y fFC6B8Qrj9n74Qf8IfpfwL+CnhnxOdO8Vat8Afh7rc+r/EzSL7wtZytHo194w+Ho0Ky16CH7 bb3vie+WHxzq39C/7dv7MH7DH7e/g3w/+xZ+2ZB4F8aP4y1Rvin8Ofhde/EhvBPxUn1zwBp+ q2M/xC+G1noXiHRfG9xL4W0jxBrWnazqejQ3ulRaNrWp6Xr8U+l6jdWs38jX/BSD/gn38ff+ Dc/4JS/ti/8ABLz/AIKT/FD4b/BfR/HfhxfFP7Gv7RXjHwv4z0X4h+IvFniTw/4dZfhf4RvN E03wj491COx1C81Pxnph8F2vj/R/Aeian4qtPHUp8PNPYgH7Gf8ABz/8Z/hx+zb/AMEc/iP8 KtN8c+NfhV4q+Ll98OPgf8B/CPwk1ibw1qfiv+zta0a81/wHqLWEE1z/AMKtj+F+i6/Z+M9J ie1t9c0w6f4QnuSniJLS7/Dv4Uf8Gqf7enif9j/4B/EXTP8AgqH8Vvgd8fNQ+FGneJ5/2c/H um/FXQvBXwq8SfE3SbOe6+Fx8a6B8VF17wLqml6Rf2Xgv4hw6f8AC3XhqPiO01HT7azn02G1 S4+Qv+C6uh/8Fgv2+/Dv/BOL/gop4d+Bvxa1P4Fap+yl8GPjD4B0z9nXSfEfifTvgZ8d/H0+ neKfF3ia18L6Fb3/AMTvCsviWdPhpqfg3xt4g/trT9Q0i08Ow6F4umubS7sbX82ovAnxa/aH i0Hxr/wUx+F//Beb9sb4h6FZaHoum+GbDwZrvh/QdK8PaLpohs9HtPid8YNG+P2vOlnqd/r1 9dXln8NNEu/EMmqanqN3JpviLX9X1tgD+hP/AII2/s2fCj9sb9rb9rr9mX4rfEb9s/wt8c/2 KrLwtY63+01+yn/wVb+MfxN+Efxgvzrd14ak1jSPFdpa+FfE2j6gLnRU1fwzb6fKY7eG68V6 F4t8PeA/EvhSy0W7/uj8A/D6w+H/AMOPDHw0tvEXjzxVp/hnwxZeFx4r8feOfEvjH4j+II7S yFnPrvifx/q+oS+JtX8T6k3mXt7rjX8Nyl7K0mnixhitYLf83P8Agjd+yX+y/wDsz/sXfC7x R+zl+x74k/Y1v/j14G8D+P8A4m/D74nane+Jfjlc6zb6PNbaG3xb8VarcTapeazHYXl3rVr4 fe08NWPhibxPq1vD4G8F6pe61oNt+RP/AAclf8FlLT9l6b4Z/wDBOr4H/tBxfs4/G79oS50K 9/aD/aT/AOEZ8a+JF/ZZ/Zt8Q3c+l3mvaXYeC/C3iLxNqnj7x5FFqx0mPwDa6j4z8L+G9B1K 9tU8Na54r8D+KrAA/F34Zf8ABL34IeIf2kvjx+wr/wAE2PDun/t+ftAah8QdTg/ax/4Kz/tb fDWy+IXwU/Yaja/1l9c+H/gDwrr0Os+BPiv+0tqeoaTrNxdePRH4gv7/AMReILN/DkuizeE/ FniXwX/V9/wTt/4N/wD/AIJ2/wDBPTRbfVtG+E2g/H3483sVvP4p/aB+Onh3RPGPim51YJFL ezeBPDOpW9/4T+FWmTagLq7gtvCFhFr7QXY0/XfFPiCC0sjB9rf8E5P2Uf2XP2N/2P8A4PfC X9j7Q/7P+C+o+GNH+Iml+Jb6wvrHxX8TtR8daHpOrTfE7x22r6fpWuXHi7xXpv8AZMl5HrWn afeaLptppXheDTNI0zQdP0iw+46ACiiigDzX4bfBr4TfBxPGyfCn4b+Cvh2fiV8Q/F/xb+Ik vg/w3pWg3Pjv4oePtUl1nxl8QPGF1p1tBc+JPF3iLUJfM1HXtYlvNRlghs7FZ0sLGytrf0qi igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAooooAKKKKACiiigAooooAKKKKACv4tfFPg6T4D/8AB6N8K9Q0fTdPsrP9sL9k 3W/GOtGQyWJuI9H/AGdPif4YuNS0uCO8vIL7ULvXf2ZLJb4C30eOVW1jUJrO41CGXVNW/tKr +Q79qizPij/g8e/4JrT6Lc2d2Phz/wAE9PHd54tiFwon0wX3hb9vzT7a2aLBLXkh8d+GbwW/ DDT9QW7zsXBAP68aKKKACiiigAooooAKKKKACiiigAooooA8q+I/wJ+CHxi1TwTrfxc+Dfwq +KetfDTVb3Xvhxq/xH+HnhHxxqnw/wBc1K3htNR1nwTf+JtH1S78Karf2lvb2t7qOhS2F5dW 8EMM80kcSKvqtFFABRRRQAUUUUAFFFfAf7bv/BUT9g7/AIJ1aJa6p+1z+0Z4K+GOr6raG88P fD2D+1PGXxW8T27/AGlLe70P4YeCrDX/ABtNo1xd2r6e3im70az8IaffPHDq+v6cr+YAD+eK w/4NW/2iB+0B46/ai1f/AILk/thxfH/xnJqtifjN4D8GeIPh18Vo/CWrXjXdx4Q1Xx3o/wC0 PdarfaGBFp8MWi6GvhXwpaxafBb6f4YsrKGys7H7Q8A/8GwP7D198Q/DHxh/bM+Nv7ZX/BRj 4oeG5LKeLUf2vfjxqnjTwpJJpmrjVrG0OgabYaZ4g1Dw+0kUMeqeFPFnjbxZ4b1tXvotU0y4 sL6TT08W8B/8HdX7BHxK/aI+EXwE8Lfs4fttwr8YfFfhrwh4b8ZeIfhn8PdOF5c+N9VGjeC/ EOh+DtK+Kev+KfEHhDxBdXOmXUOpW9paawul3c91B4evLmz+wXH9JPx//aM+BP7Kvwy1n4zf tG/FfwR8GfhfoEtpa6n408e65aaHpC3+oO0WnaTZtcP9o1XW9TkR49M0TSoL3V9RkR0srKdk YAA9kt7eC1ghtbWGK2traKO3t7e3jSGCCCFFjhhhhjVY4ooo1VI40VURFVVUKAKlr+cj4nf8 HW3/AARU+HjxwaN+0T45+Ld0bnRoZ7f4Y/Ar4syJawas8n2i+k1Hx74Y8BaPcW2h26wXesxa fqV7qCpdR2mm2Opapb6hp9l+0H7Iv7X37Pf7dPwI8IftI/sw/EGz+I/wo8ZtqVrYavFY6nou q6VrWiXsum694a8T+HNctNP13w54i0a+haK703VbG3e4tJbHWdMkv9B1XSdUvgD6Xr8tda/4 Iv8A/BN3xR+21q3/AAUG8X/s56V43/aW1yRNR1TW/Hfinxn458D3fiiHQrbwtY+Mz8L/ABbr +s+AIvEek+GbKx0jQmg0CLR9AksbHxBouj2Hi2ztvEEX6lVHLLFBFJPPJHDDDG8s00rrHFFF GpeSSSRyESNEBZ3YhVUFmIAJoAkorwr4E/tP/s6ftQaV4t1z9nP44fC3446N4D8Xah4D8Y6r 8LfGugeNtO8O+L9LSKW70PU7zQL29t7e7FvNDdWzGQ29/ZyxXlhNc2sizH3WgAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKACiiigAooooAK/k5/Z/g0H4n/APB3x+3RqOvRxarqP7N3/BPD 4e6H4Ji1Lz5Z/DmueL9J/Zi1e81jw6Rsitok8NfFfxZpF4jecrv4x1J0Alkcw/1jV/Jr/wAE 8jDP/wAHTn/BbK4tdywRfs/fAW2kWe00zS5zdL4H/ZrjuWjsLBlW4tjc2tyU1Ty3utQia21L WZF1XU5fNAP6yqKKKACiiigAooooAKKKKACiiigAoor8BP8Agvx+33+0R+yJ8Kf2ZfgB+yi3 hvwh8ev+Cg/x4079lfwX8ePGt9Lp/hX4B/8ACXy6L4eufHZuY/3Vn4nt7rxdptx4e1jUBPpn hu207XPEtzp+qTaRa2E4B+g37aX/AAU+/YK/4J7aR9v/AGt/2mvhx8K9amsbHU9L+HJv7rxb 8YNf03VLm+sNN1bQfg/4KtPEPxJ1Lw/dajpt7p8niqHwwPCmm3VvKusa3p0cUsqfh58YP+Do ubwj4Wb4r/Cn/gkJ/wAFLvH/AOz3BbefcfHz4hfCTU/hB8O7mOULcafqOka/ZaD8TfDtzoOr aZLbarp2o6t4h0G/ks7q3abRoC52/pn+wN/wRJ/Y0/Yfgg8fa34cb9qv9rjW5NO1v4l/tkft J2o+Jfxm8XeM7WGHz9c8NXvjO88Uv8NLAXESjTrDwzqL659gt9Ot/E3ivxZf6dDqrfsLQB8H f8E1/wBurSP+Cj/7I3w7/az0H4OfE74HaR8QJ9btrHwb8UrO1j1C6i0O/fT28R+FdYsjHa+L PA2sSpIfD/imGy0xdTNvexnTrdrU7/HP+CoP/BYj9kb/AIJJaH8F9Y/agh+J2t3Px18Va34c 8HeHPhH4d8MeKPEtppvha00268V+ONc03xN418EpD4N8NSa54esNTuNJutZ16W/1/TYNL8P6 iPtklp+inxR+LHww+CHgbX/id8ZPiH4K+Ffw58LWhvvEfjn4heJ9G8IeFNEtQcLLqWva9eWO m2vmuRFAktwslxMyQQJJM6I38Lv/AATZ/aP/AGAv+Cln7WH7VX/BYH/grX8ev2b9Dh+EvxaT 4IfsLfs7ftDfFTwb4R8M/CP4X6Jo2peK9G16L4TeJfFMCfEzxDqOj+KWazl1HQ/EukXnxHs/ iP4w0jR01/SPDkng0A/o3/4KB/s6ft0f8FF7n9mLwR+y/wDtcN+yP+wT8SfB7fEL9pP4l/Cx Nc0f9rTxnpOq2ulan4W+HPgXUJpLCw8JeGvHPhTV7i2vtbivUv8Aw9q6XF54o8P+M9DtYPBe u/mn/wAEHNE+LPwD/wCCnX/BWL9hn4d/tV/Fj9qz9hD9lmX4aWXh3xP8adUh+Ivivwz+0P4t sNGfxP4Pt/iZZajY6XY6v4Jn0X4l/Dz4leFtM8KWNnrHizwXZ6udL8Eajoup2PirvPj3/wAF zPi7+3f4o1v9kH/ggd8KvE37Q/xSvAmk/En9uTxl4OvvCn7Ln7Ougavp4Nz4g0XVPGraFN4n +IWnRNqUmhWXizSNI0W61PSrefwhoXxhiuLnSrT9l/8AgnH/AME+/gn/AMEuv2WdP+AHwy17 WPEkUWsa98Tfi/8AGDx7LpsHiv4pfE7xDbWcnjP4jeL7y3SG3tIpLfS7PT9JtLu71CXQPCuj 6Tpl/rmt3dld63fgHzH/AMF3v+Cm3hD/AIJjfsEfE3x5F4gvdO/aA+Mnh3xd8IP2XdK0WSFd eT4seIfDV7a23xFT7RY6jaQaD8HoLyLx9rM+o2q2Go3unaH4QF1bar4s0lz/AAq/8EVPjB8c /jb48+M3xE+G37F3jn/gpz/wVf8Ai7qt7YeBf2pv2tdRuvFf7O/7JPgfw94Mmtbzxz418feP NY1u21/xzqi6iulW2ha0PB0ljo9r4G8KeBfF+oXfinVfBGoeNf8ABSL43ftrf8HF/wDwVR8f fC79k7wjcfGvwj8HZvil4W/ZZ+Gfhzxl4N8O+EdN+B/gTXo7LXvjFdeJvHeu+DfBllrHxdns dB8W69q+r61HdznU/BPw803UdbtfDfhaKT+tf9lnS/8Ag5L+CHwU+E/7PH7Nf/BN7/glT+xd 8JvhxollpGm+G/iZ8VvHvxFMFvBqFikk+q6j8I/jd4s1HU/EWreXqWs+N/FOp3Hi3xB4rl1O 51WTWo/E/mPdgH1Z+yR/wSF+Gn7InjHxx/wVS/4KtftA2n7W/wC3P4K03xZ8V/GX7SXjSbV9 F+Cv7Ofgnw54Yv59QsfhR8PEFhoNpo3gjQV1260jXrrwjpg0KGaFPAPgvwVdWjS6j/Jr4r/4 Lz/sIftm/wDBSLxb+0d/wU7+Bnxo/aO/Zc+Fviyx8K/sIfs5WujeB734M/BvwJf6pb2vjn4w fGj4Z6r4msE+L3xI8Y2OjaDr2p+FvEEnifw4A2oeGrmHWNK0bwLZeF/qz/gvZ42/4L+/D/4O fBz9ln9sH9q39kDxFpX/AAUC+JyfBfw5+z3+x54L1Wzu/G1r4V1j4b6kkmr+Pvid8MfC/wAQ tL0q58d6/wCCdK1vS/C+spa6lDrUOj65e3fhvXdQ8Oy/g/8A8EZvB3/BIvwX+058TPEf/BZn x54t8A6B8E9X0G1+GXwOvPh58T/HPg34hePbPVfFsHi+2+Mdx8IvB3ivxA+ifDe78PeHbZvB TafpekePtX8SCPXrm78KaD4h8M68Af1DftCaRp//AAXF8F3H7D3/AARV/YJ+Af7Pn7BtprJu /iZ/wUc+If7Lfhj4M/CvWYtE1bV9Yu/AX7NvhCb4SaT4sh1m68ZwRXmva94QsrPx/Z6nciz8 U2Pw10TVb/Xdf+yf+Cifj7Wf+CDv/BPj9iz/AIJqf8Eor24tP21f2mfi3pHw7+Ci3Hg3SviF 4o8da1caho5+NHxZ1CP4l3OvfDjw1rvjDx94r8D6Jpln4yGq+G9H0/xXeWHhnRLbw34K1DW/ B/0boX/BzX/wTO19rD4S/sP/AAw/az/bM+INhojp4M+BP7JH7J3jefWU0XSdNike5ttB8U2X gKLQvBnhxpLex13UrHTrpNDtg93a6Tf2aQGf+Pz9rH9rX/gph/wWE/4K/W/xT+AH7Hn7R3wy +Jn7FGjH4JeIPgh+z98TrDSfjh8FPDOh+NfFPgT4zGT9onV/h2PDfwr+MHijX/Gnjfw9oPxA l+H+pf8ACsruDSNR0zRvFM3gK91i/AP6ef8Agr//AMFwf+Cin/BID9oP9lnRfF/7KPw2+OX7 KfiD4H+A7r43/GWw0r4ieHpPH/x1ml8Q6X8R/Dnw4+JVleP4D+F15pM+k6N4i8P+DvF/w/8A F+p6roGrzXDS28WpWsnhfxr9rr/g4v8A2nNV/wCCf/x2+Keu/wDBFr9rH4Q/B34j/C3Xvhro nxu+NHiG08OfDqwu/jT4Ti8L+B/GEujeJ/hZp2peNfBWoz+NtFvNLvdKsLjwx4waQ6Ja6/E0 l3cWU/7b/wC2v/wWF/aQ/YR/aK/ZJ8Wf8G9fxc0zw18SPgdqPwzi+IXiz9rzwb8dNZ8JpcaH baZonxF1Tw//AMKhsdY+I/jnwjr+mxeO7XU4dc0nVbTxBYaTr95cW9xZ/wBp3f8AOp+3R+0D +1Z+yv8A8Eh/+CUP7CH7ZXgO50Hxh4Q/aM8fftIaL8PLT4jaOPE+ufsofDnUtOT4QaN8VrSx bxlbaJr2veO/iJ8ZvDHhCz1CxktfBvhT4W+Go9W8J3/iGG9tNMAPv7/g04/a50/9hD9qb4y/ 8E0P2q/g18bvg38fv2rvE/w+8QfD+08deANa8J3Hh/WfCXw28V+LLHw54/8ACHie00bxp4Zj 8beENYttf8H+IDol7pN/BNYyXjWGl6ja6u3p3/Bxf+yN+2l/wTN+KXjX/gpn+yL/AMFE/wBo fw4n7c/7Slp8KPFXwF8F6x4v8HeJdD8T+OfhRrVzo7+HNZ8J+LZNM8c6LY6J8Irfwp4fS48F 6B4u8DpZ+ALTRda167totQ0rxXwT+zt/wXavvjl4E/4ObIvgJ4V+MnxV8Y+OdY1yy/Yl07wp 4qu/jJY/sy+IPAifCbwWvw78BWPg3V9WsfD998Mr/VtE0q+0O6f4t/2K+h/E3UtN8f8A/Cwf Gxg+rvFH7aHxQ/4Oa/21P+Cf3wQ+C37L3xW+Ef7Iv7G/xf8ACH7SX7cN78W4NEGk2HxP8IS6 XHqvw8t/EFpb6zperxaTaN4r8B+BdM1PR9A8Y+O4vGus+IfE3gTwVpOjXv8AYoB97fAn/ghH /wAFiZ/CtppX7TX/AAcI/tYaYh0u50y/8MfAnWfiZruqxlkKWl3afHT4gfEXw74vluIgA9zc TeA4dWnZiItYt3j86Twn/goh8Fv2L/8Agm9Z2vhz4pf8F1/+Dg74nftC+I2sbXwD+yb8Dv8A gotp/j/9obxhf6zEz6HLL4Gs/hZDP4P8O6ptd7TxN4wl0ew1WO3u7bwuniTWoE0af9Jv+Cx3 7b37UevfHT4Lf8Ee/wDgnObnQ/2vP2ufCc3in4sfHtdP/tHSv2Uf2Wr3UNa8N+L/AIoJf6Zr MV/4U8ZyJpOpw6RrmpaZHLY209jaeA7xfij4p8B3em/bH/BNf/gj/wDsm/8ABMrw7q978MbH xD8V/j544Zrr4qftUfGq407xd8cvHd5cpGbzTovEv2C3bwp4MWZALHwloPlJPBBZXHivVPFv iC2k8QXIB/Kl+yP/AMEu/wDg5d/aqs9W8WeL/wDgo1+1z+wb+zv4s1nxDF4L8JftKftN/Fv4 q/tfaF8P/wC0dUTwjHr2k+EdO+HzS+KrTT0tNP8AEniLXdf+B+vaxeq3iTTvA2m6feWWnW39 GX/BJP8A4JN/tM/8E7PiH8cfG37QX/BTD4/ft3WvxI0TSvD/AIQ0D4mzeOrDw54a3eJNU8e+ J/F154e8cfFn4vunjPVvGPiPxK8d/o+vWsU8Ou+JNZ1b7fq/ii4TSv3OooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAr+VP8A4J/6fqlt/wAHSH/BbqTWy+r36fs//svNb67HLb21vp2j 6p8LP2dr/Q/D8un29jaJczx6GulWUd+cTRf8I7cm7m1O61KTUG/qsr+SX/glFq761/wcjf8A BeO705ftOjw6H8I9Jvr2K7n0+GDWfD6eFNBFlJ4fGoWMGpzmfT9cQ69J4f1OWzewuDb65p0f iSePxGAf1tUUUUAFFFFABRRRQAUUUUAFFFFABXwX/wAFFP8AgnD+zT/wU8+AUn7P/wC0to2v nStO1+18Z+AfHngfV4/D3xF+F/jqwsr3TrPxb4L1q4stU05bv+ztSv8AT77Sdf0fXPDmqWl1 uv8AR5r2y0u9sPvSigD+dzwX/wAEof8Agrt8GfCPh34Z/Aj/AIOEvi1oXw18J6e+n6Dpvxs/ YJ/Z1/aV8eW0BvbueG3u/iv8SfGQ8Z6vp9lZS2en6bYatc3qaXb2f2bTJLTSfsOk6dveKv8A gjz+3b8etNstC/aw/wCC7/7cfjHQBYx6frem/ss/DT4HfsQNrts8l4uo2t5dfCnR9da8sdRs 72aznstei8QRzR7I9QbUbSC2s4P6BaKAPxG+B3/Bvf8A8E1/hB4q0/x74z8EfFf9qzx1pGvW PinSvEf7YHxq8d/Ha1svElhJNLDr8ngTWdQ0/wCFuq62JJdyavrngXVNStArx6fdWcV3qCXk Gp/8G3//AARY1v4ua/8AGvWP2HfB9/4x8ReM7jx7eaV/wsT40WPw1t9fvb6TU7+Gw+EGlfEe w+Flv4avNQllnfwU3g+XwbbQv/Zmn6DZ6OkWnJ+4FFAHn/ww+E3wr+CPgzSvhx8GPhp8P/hF 8PNC+0f2J4D+GHg3w54B8GaP9qma4uv7K8L+FNN0nQ9P+03DvPcfZLGHzpnaWTc7Fj4T+3x8 JPit8fP2Iv2tfgd8Ddb0vw58XvjB+zv8Xfhl8PtZ1m+udK0yz8S+OPA+teG7EXWsWcFzeaGt ydSe0j160t57rQ5p49Wt4nms0U/W1FAH81v/AAbi/wDBEzxR/wAEn/gv8TvHP7Qd14Z1b9rH 9oHUdNtPF1t4UvV1vw98Mvhp4PutQPhXwHpHiEKqa3qmuaje3ni/xpq1hDZ6bPPL4Z8OwW95 /wAIcNd1n+lKiigD+SH/AIK6/wDBPT9uv9pX/gu5/wAEjv2j/h58PLv4jfsg/Arxd8EPEHij xBZa3p2k6f8AB3xL8M/jzqHxX+J2qeKbR7i71Ty9f8JaF4HuvDepQ6Utn4q1rTIfA091pk1v bajN/Tdrf7Mn7Nvibxk/xG8Sfs+fA/xB8QpZvtEnjvW/hP4C1XxlJP5ckXnv4ov9AuNbebyp ZY/Ma+L+XJIm7a7A+4UUAc/4b8J+FfB1jLpnhDwz4f8ACumz3cl/Pp/hvRtO0OxmvpYYLeW9 ltNMtrW3ku5Le1toJLh4zM8NvBEzlIY1X+Xf9q//AIII/tc+BP26fit/wUg/4I6/tweGf2Qv j3+0DeXUPxq+G3xS+HWj+I/hnrf/AAnOrjXPiz4u03WZPCPxL0u7uPEeu6ZoPjGLwJ4q+Deu vdeP21zxXB8TvDclzYWNj/VRRQB/JX8Zv+CJ/wDwWy/bg0nWfhX+3D/wW+tW+AHiHTr218S+ AfgF+zh4e8Fx+L7G51SxuG8HeI9O8Gy/Bq01jw3NaLclrzxhqXjgxPZWdlc6BqkN/d3lp9l+ H/8Ag2V/4JWw+Ff2QvDvxI+HfxH+N13+xx4N1DwD4L1r4l/EvWZ0+IPhG++L3xJ+O8Phr4re FPDEXhvwN4i8P6R8Tfi3481bT9M0zwzoX9oaLq8PhHxdceKfDGn2elx/0E0UAQWtrbWNtb2V lbwWdnZwQ2tpaWsMdvbWttbxrFBb28ESpFBBBEiRQwxIsccaqiKqqAJ6KKAPxV/ZK/Zb+L3h j/gtN/wVp/aw+KvhTU08CfEX4V/sLfDr9lnx7cWNoujaj4D034Z+IJPjd4P0S9ntZdTiutB+ J/hHw/qniCzstSTTbq41zTtRvIJ7iTTrXQf2qoooAKKKKACiiigAooooAKKKKACiiigAor+d j4O/8HDP7OK/G/8A4Kc+DP2x9Y+Fn7KHwj/YO/aMk+AXw7+IWteOdX8S+KPj1qeh6t8SPD3j S18MfDjSfDVx4t8TeKfDF78OU1rWNA8AaR4kvdH0zxr4d025tLqaFtW1Dya4/wCDk+9+Nmse K4f+CcX/AASx/bv/AG+/Anh3V7rTNN+NvhfwPrfwu+DPi63sZ5rO41XRPFOp+CvGWsadFcXt pewaXpHi3wx4a8UXS2V39s0HTbm1u7S3AP6gKK/jn/a3/wCC8f8AwW1/ZZ+Afi/9pj4nf8ES /DXwG+DGg6voWmy+Nfif+0jpPjxvCbeIde8OaLo8Hivwh4Qj8IeNbldWvvEmmaDZauuh+HdN /ty9KMHk0nVNNj/WTwf/AMFkdL0X/gkL8OP+CpP7R3wB8T/CjWPiZ4f0R/A37N/h7xAnjPxt 8VPGHjXxjceDvhP4f+GE/wDYul6hq8nxhhSx8b+F7SfQmv8ASfBWoyavqAvtP0m61WcA/bSi v4hPg/8A8F1P+CvP/BS74i/Fzwt/wT68Nf8ABOj4L+O/2dNH1n4qaz+x98avEHxv+J37SXxb 8EeF9QiiudA0rxb4a8H6N8EtYe6l1LQPC/iPw94Y8ZeCPG/h3xRqcdlqXiDww8rLYfv5/wAE Vv8Agqhp/wDwVf8A2Tr/AOL+u+BbT4S/HL4X/EDXfhL8fPhRZ3OpXFl4V8Z6SkGo6Xqmif23 Db65H4f8T+Hr6yvIbTV4nvdE8QWnibwrNe6s/h1tYvwD9f6K+fPF37WP7M3gH46/D79mLxp8 dvhb4Y/aG+K2m3GsfDn4M6z4x0ax+Ini/S7aHV521DRvDE10upT2kyaBri2MzQxpqU2kajba ebq4s54k+EP+Cx//AAVx+Gn/AAR8/Z28F/G3xr8Nda+M/ij4lfFDS/hn4D+F/h/xVpfgy71J zpOqeI/FXinVfEWp6brrab4d8K6DpDQyyaf4d128vfFGu+EtEltdN03V9Q8R6GAfrlRX5Cft hfHn/gpP8U/2Tf2aP2mf+CPXgj9mn4oXHxJ8J+E/jp4i8D/tHazrmj6z48+FvjjwDovi/wAC eD/h2bfVPB3hG31nxAmvmXX9Y8X/ABF8DRaSthpcWm30yajqUth+Z3w7/wCDnjw58EvHGnfA z/grp+w5+0j/AME8fjE0ehvN4sl8Lal8Sfgbq2k6pq9xoMnjmz1q3tNK8Xw+EZNStL5bO88G 6H8WNGkOjeItOj8WXer6QtlfAH9VlFfMf7OP7af7I37X2ktrP7L/AO0n8FfjvbwWK6lqNl8M /iL4Y8UeINBtGa0UnxR4W0/UZPE3hSeNr+wWaz8SaRpV5A19ZrPBGbqASfTlABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAV/KB/wSI1Wy1n/g4M/wCDgW7sLtr2 CHV/gPpUkzG3JS90K31XQ9StAbULFtsNR066sUDD7QEtlF2WuxMx/q/r+Sn/AIJqSWmm/wDB 0F/wXA0TRNa1LUNI1D4P/BjW72Pzza6c+vJ4f+Bk+owXWmRPNBd3fh3Vtf13RNJ1KSVJ4LM6 j+5jbVriKEA/rWooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK8U/aU1ebw/+zp8fdet7PStQuNE +CnxU1eDT9e0qx13Q76bTfAuu3sVnrOianDc6brGlXLwrDqOlahbz2OoWbzWl3DLbzSIwB/H T/wQw/4I3fsQ/wDBTL9iKH9v39vj4LWfxu+O37SX7Y/7Sf7Q7+LJPiF430C+utLvfHEvhHU/ A3i+18CeLNAt9c8OzfEXwh4v8bHS/ElgmpzXmvTTJIvhvWZbLUv7EdV1T9n39jb4A3eqag/w 6/Z6/Zw+AngQyy/Z7TSvBXw5+G3gPwzaBIrax07T4LXT9N0+0hWO10/TNOtTcXt5NBY2FrdX 93DBN+Rv/Bsnpen6R/wQ3/YStNM1mDXbaXQ/jlqkl9bwiCODUNb/AGnvjZrWraMyC4uQ0/hz Vb+98PXU3mKbi50ua4NvaGU2sP42f8F1v2hvh58b/wDgsr+xf/wTr/4KCeO7z9nb/gl94L8K r+0P8RNa16+13wh4S/aO8eyeGfGN14Y07XfF+mG5to/Beh+JvD9l8OIronQptHvta+Iyf2pa 61qHg/VdPAPY20P9pf8A4OdPiZpGseItM8X/ALNf/BCP4a+P5LzTNGu7mbwt8cf2+fF/gG+M llq7wpE2oeF/hMuqzW6rdpItppDadf2uhajrHxMhutR+E/o3/BZP4h/G/wDab/ad/Zj/AODf T/gnnq3gb4DW/i/4Pj4j/tK/FPStFsRD+z7+zRomjaj4F8P/AA/8D6Lp15pLaFHc+C4tRs9R 8NeGW0nXta0XxJ8OvCOn+IPCfgvxH4xvZv1h1H/gsp/wRg+AXw/0fTNJ/bz/AGMPD/gDwdoO i6R4b8GfBz4ieC/GFr4d8O2tra2Wi6F4b+HvwdPiK/0/T9Jsvs1nDoej6BGmiW0Bt5bOzitJ Uh/iL/Yw+GX/AAWC/wCCyH/BVP8Aay/4KffsHfGnwj+zPpen/ENPBVn+014z0jUNA8Dy/C7R L3wp4W8CfCrwZ8ONT8H/ABMm8e+JF+FPgvwv4o8YeD/EGjW/hC9vLK5g+I/ivQtU8a6Xaa6A f07/ABF+Gf8AwTQ/4NlP2Tb/AOJP7OfwSs/GH7XPxO8L6Z8BPg7pl9qGo+NP2iv2rfilq+oy aj4e8P3kFvcvq1r4OufGUml614+h+HWgaNpMVnp3hnRLHSr/AMQweAtIl+lP+CAH/BM/xT/w Tr/Y3vdT+OIluv2vv2rvFX/C/P2oLu5ns57nQPFOuQT3Hh74ZM+kzzaHNL4Cs9U1SXXrvSvO tLrx14k8ZHTtRvvD0eg/Z+L/AGB/+CBHw3/Zu+O/hn9tT9sH9pL42/8ABQ39t3w9pg/4R74r fHrxBqWpeB/hdrl22rzX9/8ACnwRqup69f2Mtmdcv7XQLjxR4k16w8POseueDvD3g3WWjktf 6CKAP5Of+C1/7NHhHS/+Czf/AAQP/a60DRtI07xl4s/ahj+AvxN1dLm9i1bxPpnhjWPC/jf4 SEabHbtpMy+GxrHxWtdU1qe5t9Zmg1fwvpZTUtN0u2Gjcb/weNfs6+Cfix+w9+zf8S9U+IHi nw98UvAn7TWg/Cj4HfDjR/DEPiHRPjT40+P9nDb6x4S1nUZdU0WLwPqmgeD/AIb65428N+MN RvLnRJ5fD2peBL7TUvvHWk+I/DXr/wDwcp/FWy/Z2+JX/BFD9pTxbe6h4Z+FPwX/AOCnPw31 74qeO4tCu9Z0rwx4LK6TqniyG8EGn6gp1DUvh7oHju60zTreJtbvrbRtWutBia80t5rbhfjx 8bPA3/BbP/gsX+xH+z1+yf450r4n/skf8EtPiGP2zf2svjP4WGqX3gDU/jx4T8SSaZ8EfhX4 T1yS0h8O+ObseIvCjMutaDf3/hXX/Bnij4h6n4f13XG8EajpV2Af1PfDX4eeEPhF8OfAHwn+ Hui2nhvwD8MPBXhX4eeB/DthGkNjoPhDwVoVh4b8NaLZwxJHHFaaXoumWVjbxxoiJDAioiqA B/IL8PPgrY/Eb/g8R/aoHinW9c+IXh7wn+wla+Pdb8L+L7jw9rfhi10PxD8OvgV8L1+H0vhy bS7bTz4Dtj8Q7bXLfw99iu9Qu/Ed3/wk+s3epXF9q19P/XZ8XvHOpfDD4T/E/wCJejeBPF3x S1f4efDzxr450r4Y/D+yTUvHnxG1Lwl4a1PX7HwJ4J06V44tQ8XeL7rT4vD/AIbspJI0utZ1 Cygd0WQsP8/T4V/tF/8ABaT4rf8ABYTTP+Cvn7Pf/BGr9o7wx4Z+MPwR0H4O+OfgV8QdcstB 8P8AxL+GVt4c0CO3m0b48/Fn4KeAYfh/Y6zrXhH4feONG8S2Hgtrm7XQptNttd1bwp4n1Kxl AP6Tv2gP+DaP/glv8WvENn8R/g98OPG/7Evxr0K81DWvCnxa/Y68fa38I9U8N+I57eUaVqum eFEk1XwNoy6JfSC9s4/CPh7wrflA9imqwWjRpD/N18Wf+C53/BT7/gkj+1Z8Tv8AgmT4k/aj /Z0/4KV69odr8OPht8Lf2kPif4P8VeFtb+DfjnxbdeG7dYPjlb+B0vtc+IOveFdHvb3/AITP w+fGvxJ8S22q6noupap8TdU8RaN4r+GI/eTx1+2x/wAHK/xH0rxbpfwb/wCCMPwO/Z6vrjSt at/Dniz4w/twfBH4vS6RqdvY3GjK1ppHhLxN4ITWdVTxC6+ItCutX0ey8IXujaebK7m1CDUL LVbr+Nj/AIJe/AH/AIJ3fBP9srxL47/4L2/Gz9pr9nz9qv4Y/GHTfiZoPwS+NPwX+Iv/AAif xW8YWXjFPFH/AAsr4n/GWx074meJviBpmv8Ai3Stfk8RWGueG/AHhrxOVtddtPix8QbPXdY0 PTgD+gn4vf8ABuX/AMFrf2r9Zh+Jf7T3/BayW7+JEsrwN4c8DwfGGD4a+GNNnGntcQ+DdN8O 658KdA0lZZFuvtFnpfw30FdQbT9OutQvZ7q9nfTv7P8A4TeCb74a/Cz4afDnU/FWq+OtS8Af D/wb4J1DxtrpmOueMb7wr4c03QrvxVrJuLzUbg6r4huLCTV9RM+oX8xvLybzby6fdO/5t6Z/ wXZ/4I96tareWv8AwUQ/ZlihZioTU/HkOiXQIVWJax1m2sL1Fwww726oWDKGLI4XLuv+C+H/ AARxtLbXbuX/AIKF/s8vF4dnjt9QS18Q6pe3NxJJHBIraFZWej3F54ogC3MYkuvDMGr20Uiz xSzJLa3SQgH68UV/On8Uv+Dqz/gih8N4NT/sf9pbxd8XdV0y01uZtD+FvwK+MVzPe32k26TW mkaZrnjrwf4E8GX134hmZrLRL+HxR/wjy3Ebya1rej2JjvH/AGP/AGMv2rPAv7cP7MPwf/av +GXhP4m+CPAHxs8OXXirwl4b+MPhW38F/EK10WDXNW0O1vdZ0Cy1fxBpyWWuDSTrvhnVtI13 WNE8SeFdS0TxJomp32k6tZ3MgB9O0UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABX 8lP/AASr0VZv+Dk7/gu94gnu5Dd6Z4Y+D2jwW0Ojy/ZJbTX7XwTfmWfV2E6WN3ZJ4dsrdLBr qE66bm91CG0EejtHZ/1rV/JH/wAEXdbvvF3/AAXv/wCDhTxC9pci1034hfDDwjNc/wBn6na2 8MvhfxH478KadFK2o3N7Ist9aeFbm4tJRcR2eqQ21xqGi2VnpHkWVoAf1uUUUUAFFFFABRRR QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFABRRRQAUUUUAFeVfHb4Wx/HH4IfGT4KTeKfEHgaH4wfCr4h/C2Xxt4Te1j8VeD4/iB4R1 jwm/inwzJfQ3NlH4g8Prq51bRnvLee1XUbS2a4hliDo3qtFAH8//APwRb/4Iv/Ff/gmBceId X+Nf7bPxC/aoudI+Htz8EvgP4FMfifwt8H/gt8JNW8aW/wASvFcOg+BNa8X+K7NfFni3xva2 N1calZmyTRdH0xdJtp9RttRMem/p/wDtc/sAfsZ/t46F4e8O/td/s8fD7442PhGW/m8J3nim yvrTxF4XOqi2Gqx+HfF3h6/0bxXodtqn2KybUrTTNatbXUHsrKS7hmktLdo/sGigD8oPhX/w Qu/4JB/Bq9tdR8Ff8E+P2brm+sngms7r4g+C/wDhcEttPawrDb3MDfFy88ceXdw7Fnju1AuV vVXUBL9uUXA/UjQPD+g+FNF0zw34X0TSPDfh3RLODTtG0DQNNstH0XSNPtkEdtYaZpWnQ21j YWdugCQWtpBFBEgCxooGK16KACiiigD4+/bl/YT/AGbf+CivwE1P9m/9qbwZc+MfhxfeItB8 YWB0rV73w74k8M+LvDT3Q0nxN4W8Qaewu9I1eGx1DV9GnmRZYb3Q9b1nSLyCex1K5hc/Yl/Y M/ZW/wCCeHwbtfgZ+yb8LNM+Gngo3iaz4hu1ur7W/FnjrxQbG10+68W+OvFmsXF3rPiLXryC 0hQNcXEemaVbKml+H9M0fRre0023+waKACiiigArzX4lfBj4PfGex0zTPjD8J/hr8V9N0W7m v9H0/wCJXgTwv46sdJvriEW897plp4o0rVbewu57cCCa4tY4ppIQIndkG2vSqKAPgu//AOCV n/BMDVb691PU/wDgnB+wXqOpajd3F/qGoX/7H/7Pd5fX99eTPcXd7e3dx8PJLi6u7q4kknuL ieSSaeaR5ZXZ2Zj13h//AIJ2f8E/PCdnJp3hb9hb9jnw1p804uprHw/+zH8FNGs5blbW1sVu JLbTvBFtA862NjZWYmZDILWztbcN5NvEifY1FAHz437JP7Kb3/hvVH/Zl/Z8fU/Btiul+ENR b4MfDhr/AMK6YiwImneG7w+GzcaHYolrbKtppklrbqtvAojAhjC+/wAUUUEUcEEccMMMaRQw xIscUUUahI4440ARI0QBURQFVQFUAACpKKACiiigAooooAKKKKACiiigAooooAKKKKACiiig AooooAK/lK/4IoeEpNA/4Lc/8HGsmswyxa5H8bPgFf6eINOkvLH/AIR/x3f/AB08YW8lx4gh tpLPTLy409/D08OiT31td6luv5Y7O6/4Ry+k0/8Aq1r+D/8AYu/4KWfsVf8ABO//AILy/wDB cWb9rH46XXwX8JfGn4weC9A8GXfiPw78RfHdtrvjjwp4h8R/27HdS/CzwP4t0nw/o2jT+JtQ Ol6n4xn0OPQNAvIdPurya6i1yW1AP7wKKo6Xqmma5pmna1ouo2Or6Pq9jaappOraXd2+oaZq mmahbx3dhqOnX9pJNa3tje2s0VzaXdtLLb3NvLHNDI8bqxvUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUU AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFU9Q1HT9JtJL/Vb+y0yxhaFZr3ULqCytImuJo7aBZLm5kjhRp7iaK3hDODLNLH EgaR1U3KACiivyj/AOCpH/BWL4N/8E2Ph7pdgNB1j49/tZ/FQXGi/s3fsi/DSHUNe+KXxa8V uI4bWe40nw9p2u6x4e8E6fPPHPrHiGTSLq6vI4ptL8K6Z4g8QPDpjAH5mf8AB0P/AMFfviR/ wTb/AGavh98Fv2cdUvvC37Sf7WX/AAmNho3xN08WhvPg/wDC/wAEnw9B428TaG1ys5t/Hnie 58UaZ4X8FajHaO2g2x8WeKLG/wBK8S+H/DU83+Vpe6k3iG78SeIPFOva9qfinVbmXWG1C9jO uXfiTXtT1VLnWr3xJrmo6xBqMNzcxXGoapLqpttdvdS1UJBdwwreT6nbf6HfxX/4Nlv27P8A gqxpun/tb/8ABR79uO5+Ev7X3xJ8WW+pS/CHSvCP/C4/hF+zV8AbjQr+80b4K+DvDsHjTwdY 2njPQfEl1Yzazb+EfF8XgYXUvijVr3VvHvi/XNQ8Z6l+lv7O/wDwaVf8Ekfg18OPFXhH4keC fiV+0p408Z+F5vDmo/FD4n+PtU0TWPCsl0xmuNW+GXh34dnwn4Z8J6nHeR2Nxp+p6xY+Ltes YrAab/bdxpOq+IrHWgD9If8AgiH4q8OeLv8Agkz+wTd+GvjJpvx3t9H/AGcfh/4S1bx7ph1I QweJfCWlJ4f8R+BZYtaEWtxT/DDV7C6+HJOsWmm391F4Xhv5dK0xLuOxg/VGv4O/2O/2lf2h f+DW34yeLv2Gv+Cgnh/4gfFb/gmp8S/FU/j79mz9qv4aeHPEPjnRfhbrnjTVHtLrQtWS7XSo NGsb+x0HVfEXxI+Eug283ifQvGNpq/xA+H3hrxnpnj+/1TWv7eNC+NPwf8TfCeP48eH/AIpf D3V/glJ4T1Hx5/wt2x8YaBN8NYvBOj2d3qGs+LLnxst//wAI7aeHdFsrC/utZ1e61GGx0mGw vn1Ge2Fnc+UAemUV/nGf8Fo/+DoPT/j3L+zL4g/4JW/H79oX4Iat+z18d/FviD4maF4n8L3n gLSP2gNNtLTwzcfDPxA1toHirXtL8b/BazuNI8Zad4w+Fnxgs/Deo+IZPF/hy5vvAVzFpN7c aT/o50AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRUcssUEUk88kcMMMbyzTSuscUUU al5JJJHIRI0QFndiFVQWYgAmvjTQP+CkH/BPDxXPqlr4W/b0/Yw8S3OiSxQa1b6B+1H8D9Zn 0ied7mOGHVItO8c3MmnyzSWV4kUd2sTyPaXKopaCUIAfZ9FfBd//AMFU/wDgmBpV9e6Zqf8A wUf/AGC9O1LTru4sNQ0+/wD2wP2e7O+sL6zme3u7K9tLj4hx3Frd2txHJBcW88cc0E0bxSor qyjJv/8Agrd/wSs06xvdQuP+ClP7BclvYWlxezx2H7XXwD1W+khtYXnlSy0zTPH15qWo3bJG y29hp9pdX15MUt7S3nuJI4mAP0Kor8kNW/4Ly/8ABHXRdV1PRrz/AIKG/s4TXek6he6ZdTaT 4tuNf0qW5sLmS1nk0zXdC03UdE1rT5JYmay1bRtQv9K1G2Md5p97dWk0M8mzon/BcD/glF4l na28Ofts/CnxBco1ij2+iW3jPVZ0fVNPvNW0xWisPC08itqOladqGp2KlQbvT7G8vbcSW1tP KgB+q1Ffl0v/AAWj/wCCZTapf6N/w1FpK3+nDTWmEnw1+NMVpcJqkkcUMulalL8OE03W4bSS aFdan0a7v4vDvnQtr76as0Zbx9P+DhP/AIJNyLK8fx++LLpBGJZmT9iD9vNlhiMscIklZf2Z SI4zNNFEHchTLLHGDvdQQD9paK/JfTf+C3v/AATs1mw0/VdH8a/tLarpmrLu0rUtN/4J3/8A BRW+sNTXy5pd2n3lr+ynLb3q+VbzyZtpJB5cEz52xuVu3P8AwWo/YKggeWLVP2sb2RNu22tv +CcX/BRZJ5dzqp2Nefsr2lsNisZG8y4jyiME3yFUYA/Vuivyig/4LU/sFyrbNJqP7WdsZ7bz 5Un/AOCcf/BRNmspcQH7Fcm2/ZZuEe5zLIN9m93Z5tp/9Lw1sbiVP+C0v7BDNKraz+1dGI5A iO//AATh/wCCjZWdTFHIZYhH+yk7iMO7QETrDL5sMhEZhMM0oB+rFFfkzc/8Fuv+Cd9nqWm6 Nd+M/wBpi11fWY7+XR9Kuf8Agnd/wUWg1LVYtLjhl1OTTbGX9lNbq+j06K5t5L97WKVbSO4h e4MayxltK5/4LU/8E7dNsbTU/EHxM+NXg7Tb/wAVeHPBdrqHj79iX9uX4fWMmv8AiqHWbjSo zd+Nv2cNAt4tKit9A1OfXPEksieG/C0MdpL4n1bR01PTGvAD9VKK/Ms/8Fj/APgmsLW4uz+1 F4f8q2+1+Yg8CfFlrpvsUk0U32eyHgE3t3vaBzafZbeb+0I2hmsPtMVxA8lDR/8AgtH/AMEw 9eSVtL/ay8IzzWsenvqGny+D/ijZaxo76pptrq9jaa9od94FttY0DUptMvrS8Ol61Y2GpQw3 ERntYi2KAP1Dor8tZv8Agtf/AMEsrfWG8O3H7ZXw1g8QLaT37aFNpnjqLWFsbWGO5ub1tMfw kt6LS3t5Yrie4MHkwwyxyyOsbqx4y+/4L2/8Ej7XTG1bTv2yfC3jO1WKW48n4YfDn42fFrVG ggvrDTp5o9D+GPwz8W61LFb3mpWcdxJHp7pbpJJPMyW9tcywgH6+0V+KUn/Bw3/wSZRQy/H3 4szEyRIUj/Yk/btDBZJUjeUmb9mqJPLgRmnlAYymKNxBHNMY4X+J/jN/wdVfsh+AruZfhR+y D/wUG+Pvh6zvrDT734h+Hv2eLnwH8PRe6jZ395b6VaX/AMRNb0Pxa+uGLT7mUadqfgvSIbi0 hubuxvrxLS4RAD+oWiviX/gnl+2von/BQj9lPwB+1LoHwp+JPwVsvG+oeL9Jl+HfxV0+Gw8W aLfeDfFWreFbyR2tj9n1DS9Qm0o32l6hFHB51tOIp7a3uYJ4k+jPil8a/g78DtN8N618aPip 8PPhLovjDxdpvgDwtrPxK8ZeH/BGj6/441nT9W1TR/COlar4l1DTbC88R6vYaFrFxpejQ3DX +orp1ylnBNKmwgHp1FRxSxTxRzwSRzQzRpLDNE6yRSxSKHjkjkQlHjdCGR1JVlIZSQQakoAK KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK/j5/bu /wCDsbw9+wX/AMFD/jD+x14//Yg8deI/hx8F9X8PeF/EnxCtfiRaeGfiRqV/q2i6N4rl8X+G vhzrvg0aHqnhPUfDniDTrvwbbX3jfRX8TadJZeJV16y03WbaztAD+nj9rr9lb4Rftufs2/Fz 9lX476Xfat8K/jP4Y/4RrxPHpFxZ2euadJaalp+v+H/Enhy91DT9WsbDxP4S8T6PovinwzqF 5pepW1hr2j6deT2F3HC1vJ/Op/wTz/b4+OX/AAS9+P8Apf8AwSD/AOCufjCz03Q915pv/BOj 9t3xfqZPhz9of4U6b4iudE8MeA/iT4oN7qemeGPG2j6ZLoulaM3i2+0S70uUWfgjX5766vfA PiLxxl2X/B5j/wAEmLrwbq3iefwL+2fp2t6dqEdlZ/Dq9+D/AMM5PGWv20kmmI2raTfaf8cr /wCH0Onwrf3Uskeu+O9F1Ux6LqYh0yWWXR49W/Gz/grV/wAHOH/BNT/goj+yl8TP2ez+wB8Y Pij4hvLS7ufgj4v+OmpeB/AA+Fnj690u40ex+Kmn33w08beNfE+l674Uj1C6vrfw3pWrzaL4 1S1i8OeLLseHtU1G3UA/rA/4Kk/8FVtT/ZJ1Pwj+yh+x98Nl/at/4KXfHO2hk+DX7Nmh2+q6 ta+EfDE0ssepfGb41XGhmFPCXw68PWtveX0Ues614afxAtleXQ1bSfDWkeIfEWkef/8ABLT/ AIIv6N+yV4+8V/tv/ti/EG7/AGuP+Cmfxt+2a18Tfjv4xVNS8P8Awtm155JL/wAEfAjR7yEp 4Y0zT9Ley8Iv4khS2uf+Eb0mPwx4J03wH4Bu7vwfcf5m/wCyB/wVt/bN/Yuk+NPxK+CzeDdc +PPxV8P+H/AXiD9r/wCK/hjxD8Zf2gfAHgPT/Dd74a0H4e+BPGvj3xNrnhLwf4cm+yaPqyW8 /g681XUr/wABeDtOm1O58MeF7bw6P9UP/gh18ZP2rv2hv+CX/wCy98cf2zvHXhv4lfGz4q+H vEvjeTxt4etPB+nza34C17xn4gvfhufE+nfD3SNC8E6b4r0/wbJpOlavp2h6TZXNgtja2fiu NvHMPiiVwD9ZaKKKAPx0/wCCt/8AwUq/4JbfscfDi4+BX/BRzVdP8Zad8dfAPiTUtO/Z4j+F viP4p6z8SvCel3CaZeSra2Okv4S8LTPq0iW3hnW/GXi3wUX1qyub7w7q8d14e1G90v8AygfF n/BQD476T8D/AIw/sW/s9fEz4tfCP9gL4mfGXWPi1Z/s1614y8P+L9Tia7htLDT9B8Y/FLR/ A3gjxN4u0SOw0vRp9X8JpDo3w/1vxBpGmeKtS8HXXiiwt9bH+uB/wU8/4JB/se/8FW/hza+F v2ifC+o6X8Q/Cuk6lYfCv44+CrpNO+I3w0m1CVLySLT3uo7nR9f8OXl/DBNrPhbxBp95YX8S ytYzaRqhttXtP49fiF/wZRftP+Bdautd/Zv/AG2/2dviNNaS3iaFp37QPwY1zwfp0llqGntZ zJrllZ2v7Qmg3N5aLe3sVpdnw1dbLm1sNfsItH1MwQ6UAfxtaP8AssftAeJLPxbqPhn4Z614 psPAXwJsf2mPG974Wu9G8S2vhH4G6hdaJZQ/EDxJPoWp6hFothBd+I9Ht9S0zUGt9f0eW7ZN W0myNrefZ/8AZi0//gpJ+zh8Pf8AgnF8Gv8Agop+0X8UdB+H3we8d/Aj4OfFDWfEr2N3dz3H iH4neEtB1SLwloHhLw7/AMJBrep+LJtf1S50geENGj1fU9Nu7LUYr0pbaPqd7bf5v37T37G3 /BV3/g3g+Bv7QXwq8b6R+z349/Z3/wCCjPgKD4IfFX4p/D/TPFHxN8K239ieH/HdvpHhWy8W +KfCnwy8VfDfxmlv4/1/xHo0d1ov9l+JtQ8NWd3GuuWnhi8sz7J/wQ1+Bvxv/wCC1nxP/Zn/ AGSv2wfjHN8Uf+Cen7B3h7xh4mf9mrR/iZ4S+G/iTS4NJa0fwJda74T0Ww0n4jeP/CXi3xB4 +vPAM3j3RLvUdd8GeFtN17wo/jb4bT674Q/4S8A/0Lv2DP8AgqV+w3/wUu0Txhq/7Hfxrtfi VefDtNDf4geFtR8K+MfA/jDwcviV9VTQ5dV8P+NdB0G6urLUX0XU44NX0M6voxmtXt21Fbgr Ef0Fr5u/Zx/Y6/ZT/ZA8PXPhf9l39nb4OfAXSNQgsINaHwv+H/hvwnqfib+zIvIsbrxfr+l6 fDr3jHUreLKLqvinU9X1N8sZLt2Yk/SNABRRRQAUUUUAFFFFABRRRQBjeH77VtS0i0vdc0OT w3qk32j7Vosuo2WqvZeXdTRQbr/T2azuPtNvHDdjyWPlCcQyYljcDZoooAKKK+fv2qf2Yfg/ +2d+z58UP2Yfj5oWoeI/hJ8XdBh0DxdpWk69q/hnVWjsdW07xBo+oaZreiXVpf2WoaL4h0fS dassyT6fc3Onx2esWGqaRcX2m3YB6/4v8I+F/H/hPxR4D8ceH9I8WeC/G3h3W/CPi/wr4gsL fVdB8TeF/Emm3Oja/wCH9b0y8jltNS0jWdJvbvTtSsLqKS3vLO5mt543ikZT+SfwM/4N+P8A gjd+zxrH9vfD79gn4O6tqy3smoW9z8X5/Gn7QcVlckOtu+n6f8efFXxH0zTzYIyGxezsoJbe 5gg1JZDqsf24/D//AAbJ+Ovix4J+C/7aP/BOj4w+JV8X6z/wTN/a68dfs/eCfEN/Jq8fiS++ Feo6t4hu/CjajYX0mqafaaDJrGg+K7zwOuleIr6Kz8MXln4eXTNO03w9pOo69/RT8VPjB8Jf gX4Nv/iN8bvij8Ovg58PdKltrfVPHfxU8beGvh74N02e8k8qzhv/ABR4t1PSNEs5buUGO2ju L6N55BsiV24oA8Wi/YO/Ycgijgg/Yz/ZRhhhjSKGGL9nf4QxxRRRqEjjjjTweESNEAVEUBVU BVAAAr2TTPgx8HtFjMWj/Cf4aaTE1pcWDR6Z4E8L2EbWN3pt5o11ZFLXSolNpc6RqOoaVcWx HkzabfXljIjWt1PE/wCWvin/AIODf+CN/hTxFH4Tk/bp+HHi3xBPY3eoWmn/AAo8JfFn41G+ isrm0tZ7bTrn4P8Aw+8cWeo6qWvY57fRLG4uNZvNPg1DVLSwn03StTu7Ty7xD/wcOfsdRxT3 vws/Z4/4KPftEaIJroab4i+C/wCwf8bbnRNd0/Tra7n1nW9JufiNpnw5mbS9DewvrbV2v7aw vrSeyu3+wva201ygB+7VhYWOlWNlpmmWVpp2m6daW9hp+n2FvDZ2NhY2cKW9pZWVpbpHb2tp a28ccFvbwRxwwQxpFEioqqLdfzs3P/Bx18HtG1u10rxl/wAEyv8Ags58PrSfRLfXX1jxr+wp JpltDZ3kNrcWsosbL4n6nq81m0Ul95upw6e2nF9Okaxub+2miuT+grf8FLvhN8TP+CfvxQ/b +/Y68L+LP2t/DXw/8H+Mdc0z4VeEdI8T+DviL4j8V+A2RPFfw4utB17wneeJ/D/izQZPtA1S zbwnq0/l2zXOk2ur21zYzXQB+kNFflN/wRt/4KbQ/wDBWT9jSx/alb4Q3nwT1ix+Inin4VeJ /BsniVvF+kzeIvB+leGdTvde8L+IJND8O3F54e1WDxNaG3gu9LS60q+g1DR57zUnsP7Ruvln /goV/wAHE/7H/wCwn8e4/wBk/wAM/Dv43/td/tO6bqOj2vjr4Sfs6+FF1y5+HsGs2emahZ2m u63qUttaap4svbLWtKlsPCfhO28QXMM92lj4mvfDF7JawXQB+/8ARXmN18X/AALo3wZuPj54 z1Kf4cfDPSfhjN8X/FesfEWyufCFz4D8C2PhVvGmu6l4603VUiu/C8/hfQIrq68T2WpRx3Oi SWN9BeIkttIo86/Zs/bC/Zi/bA+DKftC/s2fGrwR8V/g2LzXtNvvHOh381jY6BqfhdVm8QaX 4ssNet9I1rwdqmlWUtpq91pvirTNHvV0HUdJ8QrA2iavpmoXYB9J0V8/fBf9rT9lb9pHUPEm k/s7/tMfs/fHvVfBywv4v0z4L/Gb4c/FLUPCqXM8ttbt4ksvA3iTXbnQ1uLmCa3hbU4rUSzw yxRlpI3UbX7Q/wC0H8IP2U/gr8Q/2hvj34zsfh/8IvhZof8AwkHjTxZqEF5dw6bYyXtppdjD BZadb3eoajqWraxqGnaNo+mWFrcXup6tqFlYWkMlxcRoQD2eiv5Tvhr/AMHP2o/tPWGsXf7E P/BIz/goR+1Cmmy6l5Wt6R4b0PQfAc9pY397YR3F3440CH4h2GmXNy8NoDpk9pJfRXEuoWqx TyaWxuuR/Z1/4OgfHP7Ufxh+J/7GHg7/AIJpfFr4aft56F8PvjbceB/hP8RPiv4TT4d2Hxh+ C3w+8Z+ONd8DfGnxr4q0T4San8MtF8zwfN4dsfEGp6JFaah4u1LRPD2vXXgTS9Un8YaSAf1v 0V/CD4j/AOCzn/B1H4s8I694x+HX/BKb4Sw+DrHxLPYwap4A+Bnxi+K/i63Phiaw1/VNGhsN H/aL8QN4kttW0uNtDudX0fwGF1OHU7m18JXVj4nFhdWXin7M/wDwVT/4KC/tt+Obv4LftUf8 FxNB/wCCRfxj26F4aX4GfET/AIJx+AvCuo674invft0F9afEv4k69oLeGpbnUIrzQLhdX+In gl9StrDw5ZWfg+4u/EniC3tAD/Qpor+ebwv/AMEP/wBonXzp+q/Gz/gu7/wVr8aXcEtxq9rc fAz40+HP2etFudQu7myu7eaXR7LQfiRp+o6CsMdyi+H7w3elslzALQWlpDcWl/8Aux4m8F6v qnwq8QfDvw3468SeFte1H4fat4L0H4lmVNc8X+HNXu/Dlxoel+OjNetDHrHiTSLySDXzLdvE moapb77hkWZyAD0GvnT9rD9lz4Xftm/Abxx+zn8ZZPG0Pw98fJop1ib4eeO/E3w58VW114c1 7TfE+h3uneJfCt/YX8b6fruj6bqH2G8+3aPfvapBqumX9qWgb+dDwP8A8EMf+Cx8NjMfHP8A wcdftOWdzPPd+Zp3hn4V+JvEcYhmvYb9Z4fEPiX9oXTLu1kaT7RCtlb6HHFYWvk2lpdnT99h Xz5/wVC+Fv8AwVV/4JX/ALOnj39r7Tf+Dhfxr4l1nQ/7H0/4e/Av4w/ss/BG41D4u+LdRuLT w/N4V8GPe6p400W81n7Bqcmrw2Fn8Ir20sTZvrWtalpv2c69ZgH9Cf7Hf/BKz9nP9hvxTa+K vgj8QP2sbkW3h+48PSeEPiT+1n8c/iP8Mr6CdZAuo6h8LvEvjC6+H91rNlJcX9xpGoN4dD6L c6nqM+kJZSXTtX4zf8HJfwxh/bX/AGkv+CMX/BMtILu+sf2kv2s/GnxT+Jn9lX0trquifB74 JeFNHi+I2o2ptre7uLfUpvhn42+JmpeH71rU2kd94Vuvtt1Y2yy3KfvV/wAE4fjJ+0T+0L+w 1+zP8bP2sfhvp3wk/aD+Jnw00/xV8RfAOl6dq+i2mkXWoX2oHQb06Br81xrXhm88SeFE0LxR qXhXVLie+8LajrN34fuJpZNNLt+P3xwR/il/wdSfsU+GLZf7Us/2Xv8AgmP8YfjdeNFcz6xb +HNZ+K3jn4kfBi88/TbdTb+D9Vm0nW/DAutavZRLrel+INE0t4Ill0ia7AP6QfDnh/R/CXh7 QvCvh2xj0zw/4Z0bS/D+habFJNLFp+j6NYwabpljHLcyTXEkdpZW0Fukk80szrGGlkkcsx2a KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACv4gP +Dmv9nT4pfsm/tbfAT/gtH8EfBFl4g8N6L8M/EP7M/7Q7WGg6H4nv/CXiDxN4Q+JPhb4XfHH UPCuu+GtQ0nUZvDdh4xitLPxBrWrW1nZeKvh38J9BguvC95qNp4gP9v9fzAf8HDn/BZTxZ+x 34Y8K/sH/sUaPZ/F7/goH+1RayeENP8ABGieGL/4i+IPhX4C8dadqPhzTvEFn4L0qK7TXvit 401S8hs/hX4P1Oy1ezeK11HxT4l8Pajo0WhaR4qAP80n9oSx+LvwT1mbTE/a58F/HXQ/2gvB mnfEPxX4m+APxz8T+MfDfiqPU7zWdEuPDnxe8P6ra+EfGGgeONGn0y+ttQ8HfFDwXo+qR6Pd aZq+lW194Y1vSNTvfHfgv8EvGv7Rfxv+GHwB+Cumah4t8ffGDxv4T+HvgjT7nT3spbrxH4rv rLTEfUIdNm102Gi6XeXU91qmr+ZPFZaBY3Ot30NnDDcW9v8A2LfDn/g0gurb/glL8Rv2lv2g PE3xa8Aft9aV8LPiB8YfB3wS0nxn8P4PhXomjaF4cPibwp4G+KGl6x8MbjxNp3j67sLHUB4p i0r4kR6bod9eWGlyGG8sNUUfMP8AwZ4fsmeJ/i1/wUq1T9pXVPh5qGp/Cr9mf4P+P721+Ieo aRPJ4V0j4y+OItE8E+FvDVhqkttLYy+M7jwT4n8da/bWUci3Gn6RpdzqUsttLLpSXwB/an8I P+CCX7I/wc/4Jb/FP/gml4Pl1Lw2n7QXgLS9L+Pn7Q2j6P4bvfih8RviVps9jrNn431BvEWl atYnQfDviKzKeCvBOyO18JeG5ru20HU9O8XalqnjW7+5v+Ccf7A/wq/4Jo/smfDz9kn4PeIf GXi7wt4In17Wr/xX47vrS61/xJ4r8XarPrvijVza6ba2WlaHpt1qt1N/ZOgaZbeTpenJbw3V 5q+qG/1nUfuaigAooooAK8V/aL/aJ+DX7J3wU+If7Q37QHjnSvhz8I/hb4fufEfjDxXq/nyp a2kLJBa2Gm6dZRXOp674g1rUJrXRvDnhzRbO+1zxFrl9YaNo1he6le21tJ7VX8q2k/sy/th/ 8FuP24NR+JX/AAUA+DPxI/Zp/wCCVv7HnxI8TaV8Cf2Lvidaa54J8T/tf/FPw1rtqmk/F79o DwDJcXOmeMvh3Y21mt7o0t3dXvgyWwmj8I/Dl/EmheLPjD4m8QgHjfwT/Zw+NP8Awci/GJv2 u/28fD3j/wCGP/BIb4eeL7rWv2H/ANjDV3u/AHi/4/Xo8O23h+H48/FfxB4VOleJH8JanYXW s6l4fl0TxPJLLdeIb/wz4L8RL4M0vXNe+JXyV4b+C3xR/wCDS39qvxv8cbTwXF+0X/wSP/as 8YeCfhz4q+Itnp/h/Vv2qvgNqttpmr6p4Vi8V6hbaD4Tj1Ow0/VZ/FdvbWNndt4G8c6Zb6bN K3gj4jXmm6Vqv929hYWOlWNlpmmWVpp2m6daW9hp+n2FvDZ2NhY2cKW9pZWVpbpHb2tpa28c cFvbwRxwwQxpFEioqqPGf2k/2cvg9+1v8DfiT+zn8e/CFn45+E/xW8N3fhjxb4fupJbaZ7a4 2y2mp6RqNuyXui+IdD1CG01nw9runyw6hous2NlqVlNHcW0bAA9O8HeL/DPxB8I+FfHvgrWr HxL4N8b+G9D8X+EvEWly+fpmv+GfEumWutaDrWnTFVM1jqulXtpfWkpVfMt5432jOK6Ov49/ +Dcf4++Pf2Mv2h/2uv8AggR+1N4isZPiT+yx4y1j4ifssaxctaxXHj34ReK4bbxx4h0W3ktd RvbCCR/DfivwP8a/CfhlbnU/EdvovxA+IdnqM0GnfD+O1s/7CKACiiigAooooAKKKKACiiig AooooAKKKKAP5qP+CXGj3Xwg/wCC6/8AwcCfBxbDWRoPjvWf2LP2h9DvJbi/j0CK88cfDPxd 4k8WXGnWWqXVxJc3eueIPiLLp95qulZ05bnwRd6UwtYrHTdOs/2i/bJ/YW/ZU/4KB/DPw78H f2v/AITWnxk+G3hP4h6J8VtA8L3vivx54QgsvHvh3RfEnh3SNce/+H3inwlq19Hb6J4v8Sab Po+oahd6Ff2+qzDUNMumjt2h/JX9m25XQ/8Ag5W/4KSaDplra29p47/YF/ZR8c+Jptsz3d94 i8JavYeDtHulkeZo4I08P6ibK4ghhWOb7HZTYWZJ3uP6H6AP5qvgr8Xv2VP2Dv8AgtX48/YJ +EPgv9kn9kn9k3wN/wAExbP49eM7+18E/Cr4T61/w0Z4n/ab8G+Fwde+Ml6+meI9cs/EXwt1 3wNE/hvxTrl4bq70LQLixhSHSrJpffPjv/wci/8ABJP4JeMR8NtF/aE1T9pD4lvLLDB4I/ZR 8AeKvjrc3klveXFpcxab4u8NWUXw11W5tY7HUdRuLHTPHF5fxaVYPqDWv2e90ltR/NL4VfsI /sp/t/f8F5/+C8ngL9tT4eeHPibpXhfTf+CdWreE/hZd654n0KTUrKD4BeG7u08eW2veC/E3 hzxNAuh2Xh3wZY+INHi1FtG1T/hPZNL12zmtEjspf6k/gv8Aswfs2fs46eNL/Z9/Z/8Agt8E LD+z49Kkt/hN8MPBfw+Fxp0UqTraXj+FdF0qW9iNxGl1ILt5zNdL9qmL3BMhAPx08Mf8Fhf2 0v2j4buX9if/AIIm/toeMdLW4iNp43/bJ8Y/C/8AYZ8Ez6LIt1ZTeINOm8aXnj/W/FT2uu2z 26eHfC2l6hqVzpG3VL250RpPskf1f/wT+0r/AIKlWPjj4pXn7bnwr/4J4fBD4J6vBdar8N/h 3+yD/wALY1X4nSfETUdZtLnW/FHxM8UeJ10zwDq9jqulG8W5vtG0O38Q6tq6WE93BpVvY3B1 v9T6KAP83P8A4Jxf8FGfjd/wTv8A+Dcv46+G/hmjR/tWeP8A/gpt8TP2JP2bYIzp1/J4A8Ze NPg78FvFvijxVE8t6+iXWoeD5dQ8bT+FryW4utBTx9rXg+51Wz1bQE1O3u/1qHxL/YQ/4NTP C3wFt/jp8Dfj/wDtKftX/tlaL4g8Q/tNftueG9K0Pxtrninxha6x4V1j4s6DpXxC+JeteDtT uPDx8WasnifR/hzZS2es6/Zad4f8XfFDVNQ8XX1rrs35If8ABMT/AIJ3aX/wVo/4Jjft4/sv +APjD4f+G37ZH7LH/BUnxn+1d8LteudC1C30GLVfG3wm0jwH4Q0fxvcQ3+t6hpfw/wDiXr3w y8aQWWo6Tp2seIfh9rngi18QLH4z0+TUvC2q/p7+3N8BP+DmH/gof+ztf/sO/Hv9iv8A4JqN 4X8R23hiLV/2pl8WaNrOoaFrnhzWYWvfHXgLSfEnjnxRqnw+8YeJ9Iil0u/1/wAO/Bq51HR/ D+t+L4vCS+GdW1XRP+EdAP6EbT/goL+yn+2p/wAE0v2kf2tf2avH/h34r/CLSP2f/j/P4jtd e8IW91ceH9a8G/DDxFqnibwL8Tfhd8RNINv9stLVYzqPhnxbol74X8W+H7+z1OzbxH4K8Q6d qep/mp/wav8AwF8Exf8ABCn4XWevaXoniDw9+1B4w/ac8TfETQW0OHTYtYsrv4leLfgBquj+ I7y1umuPE8upeEvhZYWsmsXIsruHRLjT/DkcX2XQbS7uPy7/AODS39meDQrr/gt98Az48fx1 8Ef+E/8Ahz+zJpvxN8Kh7G38ez+EY/2nvBXir4ieB4NUS9tfD0HiLw5r2geJtLstU0jWriCz 1rw7Z6jeah/Yc7al6x+y3+zh/wAHI/8AwSY+HvxA/YG/Yz/Zx/Zq/aq/ZssPiP8AEDUv2e/2 o/iX8SvAvhHVfAXh3x5qE96mr618NdW+N3hzWofsup3MvjG+8Iw+E/FdtYeKb/xBBb6n4t0m 7tY2AOP+J/7Hn7On7H//AAci/wDBMj4Cf8Eo/BKfAvxinw+8Z/ET9uPw98NvGHxG1rwonwKn W71RdC+KVvrPiDxjoPh6LxH4Y8I6gLDw5f2eipf+JvEvwh1y5MWs6/4A1yP9QP8Ag7K+I1t4 I/4Io/HzwzPatcS/GH4mfs9/DmzlCsRZXOmfGDwv8W2unIdQqvZ/C26sgzLIu67VQgZlkT6J /wCCOH/BJTXf2AbP4y/tF/tNfFMftFf8FCf2vdWi8W/tM/GkKx0LTZp76fXn+HPw78+x0yVf C9nrt7Neapq0ej+HIPEU9hoFvZ+F/Dnh/wAL+G9E075d/wCDpX9jH9sP9vL9iL4FfAn9j/4J y/GbX7b9q/wl8QPGsFh4v8PeGdS8MaLovw0+KXhPS9Te28Uax4f0nUdBn1Tx1s1u8k1OaXRG t9OuV0i6guLjVNEAP4Ef+CcH/BSr9sbwF421P4A3H/BUPxj+wZ+y98V49Eb4y/ERfCmr+P7f 4feDvAej6jplnafAfwR4J8BeLvGHw/8AGl1ompSaD4e0n4Jp8NrXWLq18NN4o1u207whod5o 30v/AMFPv2h/+CUfgv8AY28M/stf8Ej9O+MPjafxz8VLLXf20v2vfjB4L8TQeN/j03hizuNd +H/hTWPHHjeDSdWsNM1zxiLv4iXnw+8L+Cvh/wCF7rWPAeg+J7/Rr/xDZXeozf6bXgH/AIJ0 fsVeFfBfwL0DXv2U/wBnHxt4l+Afwj8AfB7wL478afBj4deNfG+heFvAHhfS/DGl6dpfjfxP 4XvfFEVolrpcTHbfQNcSFrieMTSPWt+2d+wX+zZ+3Z+yv42/Y/8Ajh4HtG+Evi20tJNJTwlF Z+G9c+HPinRrw6p4Y8dfDu+s7QweHPE/hzVi11A8dpPpWtafdax4Y8UaZrnhLxF4h0LVAD/N T/4Npf2if+Chn7OfxF/afn/YX/Y6+L/7ZXiL4o/Caz8J6T4E/wCE+sPhf+y74L8dW2tpceHf jB8YvEniaysvDmr+IfB9wq6D4b8KW/jz4d6p4g8J+KviNZDxZpDR2uq6V/Sj+0H/AMEZ/wDg sd/wWaX4aH/gq58f/wBi39mb4T+DtUu/E+l/CP8AZX+Clt8Rviv4d1aNr/TTYp8T/G7X2u+H LfX9Nvbh9S03QPjp428D3EVp4X1TXvBmt+JdMt20L6Z+DP8AwbvftN/sv+H3+Hv7L3/Bcn9v H4S/CK0g0+18N/DO90fw9438P+E7ayW6mmt/DWnat4ps/DPhmC91LUdSvbuHwj4W8NR3yy2U Wrrqlxplrejyr4y/8Gpdn+1ZPZ6v+2T/AMFZf2+/2mPEelarr2paBdeOda0LU/DvhVPENxHd 6jZ+DvCXjK68d6d4NtLi4jHm2HhabR9FW2hsrKz0iytbGCIAH9PX7OXwQ8Ofs0fAH4K/s8eD 9Y8T+IfCvwP+FvgX4U+Htd8aaxPr3ivWNH8B+G9O8NWGpa9qk+1Z9SvbbTo7i4hs4bPSrIyC x0bTtN0m2srC29cv7+x0qxvdT1O9tNO03TrS4v8AUNQv7iGzsbCxs4XuLu9vbu4eO3tbS1t4 5J7i4nkjhghjeWV1RWYfPn7In7Nfh39jz9mn4N/sx+EvGnxA+Ifhv4MeDbTwbo/jL4pa3beI fHeuWdrc3V0k+u6pZafpdnJ9na7ay0yzs9PtrXStGttP0q2Qw2SO385f/ByN/wAE6P8AgrH/ AMFAPE37P+hfscap4M+IP7J/hXTLO5+Kv7NWtfFh/hOvjX4mr4r1K4vPEvxCkF/4FPjH4fP4 LfQ9DsdPsPiQniPw9dR+KL7wzo2larqsetXQB9f/ABc/4Lq6D8Uvi7r37Jv/AASV+A3iP/go 5+0jp8bWWufE7wrqtr4f/Yg+Cd1dxeIrOPX/AIuftCW0moQarb6JqWlWWow+HvCVjb6L8Q9P nm0Lwt8U9N8TSWts21+zF/wRv8TeK/jX4N/be/4K1/Gmy/bq/bO8C3o1L4R+GtPsbrQf2Sv2 V5bTXTrWlj4FfC+Sw0Jdd8RW93baXqM3j3x7ox1JtS0vQr+DQ4PEfhqw8V3Pxh8C73/g4t+A Pww8PfBD9mX/AIJO/wDBJ/8AZc8B6WsR0XStP+J+oJ4A8PXU32aTVtV8ReGfht8VrLW/EWva xFbPFq/iGK+1HXdW1ydNc1rUdZcXb3Posmjf8Ha3xPOoGTxd/wAEgf2cYZYNIhj/ALNsPjj4 kvbXzXd7+70ODUtD+NNpcalaRwiO+t/EF9Hpkz3cK6SSBPc2YB/TnX8537Mmmx/Ej/g5j/4K ZfEeKzuLg/s0/sG/sp/s33Op2MV1baZpk/xwufDXx+j0rXReBk1LXdUtvDMV/o1/pLR6dbaP p17p9xHJqkV3Iv37/wAEuP2T/wBsz9kr4N/EHwz+29+234m/bc+Kvj74s+JfiNa+Kda06e00 X4f6Vr0dt5vg/wAHS6t5muQeHpdQiudVtPDMTaX4J8GQ3EHh7wH4W0DSrW4fU/zv/wCCP/im ++JP/BXP/g4s+JWq3Nqmov8AtFfsifB4aRajR2W10f8AZ++GPxZ+Gnh7VZJtJ8Q60Wm1nSbC 3FzDdwafc293p9yL6G01p9Y8P+HQD+kSiiigAooooAKKKKACiiigAooooAKKKKACiiigAooo oAKKKKACiiigAooooAKKK+eP2m/2s/2a/wBjL4X6t8Zf2pPjR4D+CXw50iC+kOu+NtZjs7nW rvT9OutVl0Hwb4dtlu/E/j3xdc2Nlcy6V4L8EaN4g8W63JEbbRtFv7pkhYA+h64j4k/Ev4d/ BzwL4n+J/wAWfHPhP4afDjwVpcuteLvHXjrxBpfhbwn4a0qF44nv9a1/Wrqz0zTrYzSw28cl zcxia5ngtot880Ub/wAXv7a3/B6Z+zn4EvB4Z/YQ/Z98ZfHvUbHXHt9W+JHxrEnwo+G2oaHF beYl74H8P6deav8AEjWZL64kSDf4z0X4cXGm/Zp3Ok6mk8Dp+Pf7KHxW8Yf8HSH/AAWn+F9p +2pBoPg/9m34V/BvWfGup/sz+GPiP400Dw3q3g/4b2sFjP4Z8G3kGs6Xr19448efEj4gWWv+ Nde0GfRfFsXwv07W7TT9Wtrfwdpl5AAf0wfEb/gs/wDtN/8ABTDxx47/AGT/APghT8Fb3xxo sdnqvgb4p/8ABTD4ux6z4E+AfwB1PVUudPbW/h7pGo6DPqfjrxXpul3EHiPwmLu3m1q5vDZ6 hafCvxR4Xhu9bi/RX/gmH/wRs+BH/BO+PxB8WvFHiDVP2pf25/ilearrfxw/bV+LtpLqvxR8 Watr8jy6xpfg6TXNU8S6h4B8J3bSEanaWOu3+v8Ai2cR3HjLxDrdvYeH9O0H9SPhX8Kfhp8D vh54T+Evwd8B+FPhl8MvAmlR6J4P8CeCdEsPDvhjw7pccstwbXTNI02G3tLf7Rd3FzfXswjN xf6hdXeoXstxe3VxPL6BQB8sftxaR8avEX7G/wC1H4c/Zy8IaH4/+O3iP4DfFHw78KPBXiXV LLRdE8UeNte8H6rpOi6Lf6rqeueGNMsI7+5vFhiuNT8SaBpqXDRf2hrOmWZmvYfyZ/4Nof2G /wBoT9gX/gm4vwm/af8AhR4d+EPxZ8XfHL4gfFC78P6ZruneIPE954c8Q6D4I0jQL/4j3Gjr NpOneMIB4evdIi0XTdY1+3svCumeGZ7nULXV73U9F0r+g2igAooooAKKKKACiiigAooooA/j r/4OPf2Zf2sv2dv2ov2M/wDgtV/wTx8F3ni348/A7W7P4N/GXwJ4R8B+JPGmq+O/Ct7Hr194 Q1Xxn4T8C6fb634u+H2s6DfeN/g38Vb5vEWleK9P0HxN8NbXwhqGmPpp8QeFv1H/AOCIf/Ba P4b/APBVn4ARN42uPBvwu/bK+HWq3/hP44/Ai2mt/DT3eqWNsupw+PvhN4Q1zxr4v8b6h8Md R0+WTTp5teu217w74t8PeLNF1e3bTbPQvEHiH9za/ng/4KWf8G//AMKf2o/iVefts/sTfEPX P2Ff+ClPhy8u/F/g/wCPPw11bVfDngj4geNmtjbTn4w+HfD8E93bXHijS5tW8O+IvH/gm2t9 e1Gy8SapefEHw98W9OjHhS7AP6H6K/l3/wCCQ3/BZP8AaI1z9pfxx/wSb/4K7aJpXw4/4KG/ Dm+1H/hXvxItNJ8PeFfBH7Sfhu20+01i1itLbQf7M8Lt481PRpbzxj4Q1LwNoGi+DPHvgWKZ LXQ/DXivw3d2fin+oigAooooAKKKKACiiigAooooAKKKKAP5r/8Agn9q03xA/wCDiv8A4Lp+ K4nn1/Rfht8Lv2EPhNout3NlLjwkt18H9N1TxB4M025vLeK5sLHVPHHhzxdq89pbkWOsahpV xq0TXcMVpc1/ShX8sf8AwRB8Qwax/wAFj/8Ag5OEusrqN637SH7M1lbrcail5eNZ+FJv2o/D lxbwBreymNn4eaOw0UwpbyRaQgsdNe8vCIby7/qcoA/KDwn/AME+fiB4F/4LL/E//gpJ4c+I Xh9fhB8bf2J9I/Z7+JHwqnvPFcXie4+L3hD4g+CtW8IfEC2sVS58H6ho1l4B8Ky+HYrme603 V9Eu9S1aOw0y8j8RarqI/V+iigAoorzHx58bPgz8LI7mX4nfFz4Y/DiKygtLq8l8eePfCvhC O0tr+5Sysbi5fxDq2nLBBe3kiWlpNKUjubl0ghZ5WCEAg+G3wJ+CXwb1Lx/rXwj+EHwx+GGt fFfxXeeOvijrPw/8CeGPB+rfEjxrf3F3dXni3x7qegaXp994v8Rzz396za14gn1DUFW5mjS4 WJylega9ps+s6HrOkW2qX2iXOq6VqOm2+taW6R6npE99ZzWsWqadJIrol9YSSrd2jurItxFG WVgCD8q63/wUJ/YF8M6Xda34k/bh/ZA8P6LZeT9t1fW/2lvgvpWl2n2m4itLf7Vf3/jW3tLf 7Rd3EFrD5sqebcTRQx7pJEVvFPGP/BZT/gk34F0f+3Nb/wCCkH7Fd9Zfa4LLyPB37Rvwt+Iu sedcLI0b/wDCPfD7xL4n18WiiJhPfnTPsNsxjW5uImmhDgHn3/BHn/gk/wCD/wDgkZ8AviZ8 FfDvxg8RfHfV/ip8bNf+MniT4jeKfDFt4S1eV9T8M+FPC+l+G20u08QeJIriLSLfwzPqc2sT aibzVdX8QatcSw2tsLOztv1rr8cZf+C+P/BLybxBL4Z8O/Gn4reP9WW1nubQfDP9jz9sz4i6 ZrBSO0ms4vD2veDvgDrGheIY9VjvFfTtU0TUr7Q3EUn2nVbUtAJ8uT/guV+zjqfnw/Dn9lb/ AIKf/GPUbWcC70f4Zf8ABOT9p7UtTtNObzlGuXMXiHwV4Zgh0rz0gtdz3AvzcX1qosCguZLY A/aKivyD0f8A4KzeKvFNzYR+EP8Agkx/wV81yx1K4srO01XWP2a/g38KbZbq+Fvtjv8AT/jl +0r8LvEOj29sbmJb3VNZ0XT9HtSLgyaiEs7xrfpNJ/bm/bs8YaTaan4N/wCCOf7TOkpqeh6T qumy/GX9pH9ib4ZQm8uIdOfVtK1jStE+OvxH8d+H57OabU49K/tPwNFd6jFYWkmsWHhifUZL XTwD9WKK/MX/AIaV/wCCnl7YrLpn/BL/AOHVhqLXIg+xeMf+CgfgfSbVIn0G71OO8lv/AAj8 BfH7i2j1iOz8N3aRWM15FdXU2pWlrf6VaLc3OZa/tCf8Fd7i5t4Jf+CZX7J1jFPPDDLe3X/B UHxI9taRySKj3Vwll/wT5u7xoLdWMsy2lpdXLRowgt55SkTAH6m0V+QH/CR/8F9P+iN/8EgP /Elf2z//AKE+uEhs/wDg5Cu7Ga6uPEP/AARF0DUjG/2fQ4fB37d/i6xWaKBVjM3ip/HXgmd4 725V5nCeDUbTIJltlOryWxu7oA/bqivxG1LT/wDg5At7W5k0jxd/wRG1i9WzujZ2WpfDr9u/ w3ay6gRGlktzqdr8UfFU0FnGzy3V00Wk3M8oto7CJITfNqOn8TIn/Bz5d6X4osLpP+CFlhea p4Uu9M8Ma34c179vKy1Hwt4uuY7KKLxXNB4i8DeLdH1+wsAuqXFn4ZutLs0a7uNKa/1i+s9N vrHXAD976K/lwGuf8HdPwzs72I+Dv+CSX7Q82kWNhpcFwbr4raJeeKLiO5ijuPEdko8VfA2w t76eKZ57+DUIPDumC2tJV0vQobtoIbnm/H//AAUO/wCDnb4L6HZ3/jf/AIIyfs//ABUWO106 yv8AXfgL8bLfxTDe661nql/qNxY+ANI+K/jT4h6bpTQWSQxLeabfWdjfCGxPiXVb3WdMtgAf 1Z1/MZ/wRq1ubRv+Cx3/AAcX/DLU7q00aVv2gP2Y/iR4d8IXcNjpesXlv4l8M/GNvE3i+xsJ IrfWNS0q/trrwDc3epgXOlxNrmi3qPDL4kSbUfgf9nf/AIOGf+C2H7T/AO0B4n/ZZ+Gv/BH7 wTpPx88HeA9V+I3iP4b/ABb8WfEf4Ga1o/hvTZBaW0mqyfGGPwVYaNd69qjLo/h2HWbzTo9U 1AXASeO00/U7uy1P+CN3wz/4LWW3/BcH9rf9qn9sj9k3VfgF8Kf2rPCniSL47SatqGla94H0 mf4T2ej+FfgX4c+Gfi3T/G2vxeKNR8Nx2WmeG9L1fTrnW9E1rwVJ4n1fSbe0002E+nAH9q9F FFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAV/A/wD8HsnwV13U tT/4J4fHfW/Fs9p8H7LXPip8FfE+mR2sVzdeDtd8TXHgvxiPFujWKzfatcn8ReF/DeuW+p2o jt4rCTwLoEKTXEmvFbT++Cv5+/8Ag54/Zbtv2nf+COf7TFzY+Fx4k8efs6Dwr+014BnFxc2z +Hf+FYa3AnxW8QEWySG8hsvgBrnxcEljco1m8z295KYZrG3urcA/M3wh/wAGUX7BWjeL9D1n xX+09+1H408J6bqWlX2qeDG/4Vp4ePiK1sruS41HRr7xFpfhFtRsdN1m3W2sJ5dIhsNXsrf7 dLY6rDeXNpc6bp/thf8ABs7bfsneMvBH7en/AAQx1HXvg7+1j+zteaf4p8J/s+eN/HF143+G /wAR7ew0jVdI8W6b4e8R/FW617xHYeLPHnh/U9R0DVdA8X+O08B6/Y6nd6ZZXvgESLeyf0Rf 8Ep/2il/aw/4Ju/sUfH6XULbU9a8e/s7/DhfGd5Z3F1dWz/EfwpocHgn4mwxT39/qmostp8Q vDfiazK6lqWoalG0Bi1G8ub1J5n/AEBoA/DH/gl1/wAFx/gZ+3XqMv7Nvx10yL9kX/goz8Pt Q1PwX8Xf2R/iddSeGtW1bxz4YGqHxBP8FZ/Er2d745082GjX3iLUPBsYuPHfgiwh1JNWtNc8 NaVZ+PvEP7nV+Uf/AAUw/wCCQ/7Nv/BSHwnaa5q63/wL/av8AXFl4k+Av7ZHwijXwx8b/hV4 48PNFeeFL2fxLo0ulax4t8J6fqNpaNceGNR1e3ubGAS3/gnXPBniuPTvE+n/AJ3/ALDP/BV3 9of9lT9oDS/+CXn/AAW0HhvwL+0LDYo/7Pn7dEF/p2g/s8ftdeHrm8gtPD+mXOvalpfg/TdD +KMz3B0ixmTS9Nh8T6lpt5oPibRfCnjqDTT8QgD+myivE/2hv2kPgT+yd8J/E/xy/aQ+Kfg/ 4O/CjwfbGfXPGXjTU00+xWZo5XtNI0q0jWfVPEfiXVmhe10Dwp4csNV8TeItQMem6FpOo6hN DbP/ABO/FT/g8O+Mnhv9qT4BXVl+xI/wf/4J+fEXxdolzqfxM+OPhX4lXnxt+J/wOn8Sado/ ij4ufBsaHrHhb4fW8nh2wk1XULXw9aWnxbsNZvbO00aTxPpN3eSNagH951Ffxp/8G1fxl/av /ai/b4/4K7fGLx5+2b8Vf2kv2XPAfxRvfhv8JbXxJ4o8V+IPhP421PxN8UfGt74P+Jnwp0XW 9Ul0TwFY6B8J/hxo1iNB8PaPpv2zw18SPCsd+Amg2EY/ssoAKKKKACiivzw/4KkftdfHj9hv 9j3xv+0d+zv+y/rf7WvjjwXrfheLU/hloOq6jp13pfgzUtR+z+JfHVxa6FofiPxHren+GoBA L7TtA0m4u7OHUD4hv3t9A0PWZ4wD9D6K+Ev+Ccf7f3wW/wCCkv7Kfww/aW+EOv8Ahh77xN4Y 0Nvin8NdH8XaT4o8Q/BT4my6dFJ4p+GfjSOx+z6lpupaNqQuX0W51zRtBuvFPhaXRfF9lpUG la5ZE/XHxI+JHgL4P+AvF/xS+KXi/wAP+APhz4A8P6n4q8aeNPFWp22j+HfDXh3R7Z7zUtW1 bUrt47e1tLW3jZmZm3SNsiiSSaSONgDta/nT/bB/4Lc+JvGnxi1L9g3/AII4fC3Tv24v23E1 LX/DnxN8ayHW9O/Zq/ZAh0PWIPDur+Nfi/40l02w0Txg+l6s91p0GieHvE9noyapbPb3HiDV vEcel/DzxX8Oa3+1r+3H/wAHGPxD8W/s/wD7BWpfEb9hz/glJ4V1bV9K+Mf7el74e1bTfi3+ 023hnWbezb4afAu1nn0K98Lab4tNxBqd/Yw3Vlrej+FtPnuvivrmiz6vH8A/Gv8ASv8AsXfs L/svf8E/fgvoPwL/AGWfhV4b+HPhPS7HTItf1qz0zTT46+Jeu6daG1fxr8U/GFvY2mq+OvGV 8HmabV9Xd49PtpI9G0Cz0bw7Y6Zo9iAfxeftg/8ABqT+3R+0Tof/AA2J8cf+ClHgvx5+2l4g 1RPHv7QEnj/wj43034TeAfD0bah4k8Q2Pwe8Y+CoPEXig2fwzXzYvBHhDSfhJ4L8M6pAPsmi WvgC3tLWC7+uP+DOO7/bp+IPwF/aY+N3x8+N/jb4lfs0eJ/G3h/4f/Bjw38U/G3jjxz4r0z4 ifD/AE9r34geJvB0viq4vbLQPAGoaV4u8P8Ahu8TS9Rul17xV4au4nsdIk8Kzza3/Tr/AMFH Z9Ztf+CeX7eV14cs/wC0fENt+xj+1FPoWn4lb7drMPwQ8cyaXZ7YNR0ec/ab5YIMQ6vpcp34 j1GxfFzF+VX/AAaqW+gQf8EPP2TZdHuIp9RvPEv7R9x4rijeJ3s9fX9pL4rWltbzrHGjRSt4 XtfDd2EmaWUwXUMgkEMkUUYB/RHRRRQAUUUUAFFFFABRRRQAUUUUAfx3Wf8Awai+P9G/aO+O Hxx8Hf8ABYf9rb4Z6R8cvivffFPxPo/wq8Lal8PfiTqmo3HivXPEmnv4x+Knh/41QaX4z8Ra CnifxHb6H4mn+GWkjTL7WL3UrLRreK6vNNuv0Ot/+CBM6wQrdf8ABaz/AIL8zXKxRrcTW/8A wUVe2glnCKJpIbeT4R3UkETybmjhe6uXiQqjXEzKZG/oDooA/BbRP+CDdnpWqWt/f/8ABYv/ AIL0+JrS387zdE1v/gpDrlvpd75tvLDH9ql8N/DTw/rSfZpJEu4fsWr2m64t4luPtFo09rNv H/g3+/ZA1Wx1mz8ffH7/AIKNfFWTxFLeTa/ffEL9vz9ofUrrW5NRuJ7m/bV4tH8UaFp2ptey zsbt76wuJLllEs7yTyTyzfuXRQB+FUv/AAbZ/wDBHrV9G0nRvG/7N/xC+JkWkXkOpRzfEL9r f9sLxAl1qdsbhbfULzRl+PFn4Xa5it7qeyH2bQbaF7OWa3mikW4ufO+r/hx/wRy/4JT/AAnm S68Ff8E8v2Q7e/hntrq11XxF8DPAXjrWtPubOW6nt7jS9a8daN4k1bSp0kvJd02m3lrJKiWk UzSRWFilv+k1FAHzr4b/AGP/ANkrwdfS6n4Q/Zd/Z18K6lPaSWE+oeG/gl8NNDvprGWaC4ls pbvTPDNrcSWklxa208lu8hhea3glZC8MbL7H4b8E+DPBq3KeEPCPhjwql5HbxXa+G9A0rQ1u orSW8mtI7ldMtLUTx2s2oX8tukoZYZb68kjCvczF+nooAKKKKACiiigAooooAKKKKACiiigA ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK5T x34L8P8AxI8D+Mvh34stP7Q8LePfCniLwX4lsMqv23w/4p0i80PWbTc6SIPtOnX1zDl45FG/ LIwyp6uigD+WL/g0a8ZeIbf/AIJw/F39mrxzLaWnjz9kD9s744/BnVvDsWoC8utK0+8g8KeN pLp4Da2slpYXnj7xH8R9NsTJ5/2ufQdQuRLGXa0tf6na/lE/4Nh31vxJ47/4LX/FC5gS10Dx 5/wVB+LL6bZ3Hj3RfHesWut22seK/EOvwalqlpDFrGtpFZeMfDkUPj29C6L45uo9RuNChiut K14N/V3QAV+KX/BfC+/4Jx2/7Afi+0/4KR+EL74h+BdR1yzs/gn4D8B34sPj/wCI/j5fWGoa P4JX9nmWG7trxPiHYrq17c3E1xHqPhOPw0NZi8faJ4g8H3GraBqf62/FnxF408IfCv4l+LPh v4Hk+J3xE8L/AA/8ZeIvAXw2i1ex8Py/ELxponhzUtS8LeB49e1Nk03RJPFmuW1joKavqDpY 6a2oC9u2WCCQj/Me8b/sS/8ABwz/AMHDH7QD/tB/GD4U3P7PukfDyOb4deEpvi7beP8A9mH4 K/Ce01B2TxLpPwy+H/ilfF3xe1n+05DMfH3ivRdA8dapqMlhaeHfEniOd9H0DQbMA+A/Gv7b Hxy+Dktt8O/+ClHgj/h4d8TPgN8CvBOgfsj+Dfil+0XafEH9n/8AYt8VeJ7d471vj78GvA2h 61ovxj+MOmaFpXhvR9T+HPxN+IumS+FLvQZPCPxb0DxjqENpo/gT8/8Axt8UP2uv+CqH7WHg xPib8R5/ir8cvilqui/DPwLL448T6B4I8AeA/DjanqV/o/gvwtFqVzofw9+D3wj8IS6trmr2 vhzQoPD/AIQ8OxXetalBYLfahfTXf9w37JX/AAZrXPhrwtB4P/bF/wCCg/xP8TfCnV9esPF/ jf8AZr/ZosNU8D/DrX/Fuk2bW+l6xqXjHx3q3iCw165gxb2bam/wU0LxHDpEM9npWu6Xc3dv e6Z+Nf8AwUC/4IZ/DD/gjx8e/EfxB/ah+FnxN/an/wCCY/xhPiTwf8L/AI3/AAp8Z6l4e+Ov 7MHjbUFjv/h5/wALb0210zS/AXiO8W8E/hy8+1adH4c+Ieix3HiDw3c+DfGVpH8PL8A/oh/4 M3f2d/CXwh/4JwfF79qi+1LXdN1v9ov4u6ra+Jptf8TaY3gXTvA37PcWuaJoGt6NpaRQDwxc HVPFfj6PxdqWs3slzqdvpGjTstppOm6e839IX7If/BQX9jb9vWH4p3P7IXx48LfHG1+C/iyz 8E/Ei88L6f4nsrPQ9d1K0ub3Sms7vxHoWiW3ibQdYtrK/fRfF3hSXXPCWsvp2pQaXrd3Pp17 HB/k/wD/AARi139pv9oD422H/BM3wV+3z4w/Y7/Zx/bI1u18K/FzS7e/8U3GmfEKJ7S9h1H4 deA7bSdB1nTvD3xH+J3hmXXNAQarrnw88J+O9Osz4Z8Za/4ieLw14M1v/WC/Yo/YC/ZK/wCC eHwuuvhD+yL8H9G+FPhLV9Stdc8U3EF/rPiHxR408Q2ul2mkJr3i7xZ4m1HVtf1q++yWiiC3 mv00nTHuL0aNpumxXlxFIAfY1FFFABRX853/AAWb+Pv/AAXC/Zl+NPwo+LX/AATx0P8AZJ8W fsk6f4B0nSfif4a/aO8efBf4bRXnxm1HxH4+iuv+Ei8VfF74ufAq5g8Jy+Fj4AHhi08B/ErT 9dufE1vra6jZXGmZSX+cL9t7/g5u/wCC+f7EPxIH7P37T/7Lv7CvwD+Ld54U8OePrWy8OeG/ E/xHvR4R8RXF+mjalba34Y/a5+K/gGSDV20nUIXtpJZtTgii81obMzW0zgH66/t8f8Exv2gf +CSfj34uf8FXP+CKXi3wD8HvCek+FtR+If7bn7E3xBvmT4IfFnwN4N1e78ZeIPEXge11yb+y fCy6LYX/AIk1a78L2HiX4dz+DfD48Qx/BfxVoEmqn4eeIPyB8bf8Fnvgj/wXn+NngT4Ift6f Gbwn/wAE5/8Agmj8IfCng74rfF/4UnxprOo/Ej9q744aBYvrV54Lj8c6P4PeSw+GOiahZa3b 6FpFnbaRr08FrpOtwz6h8TfFngfSvht+D37WP/Bdj/gov/wUPto/g/8AthftR+LNH/Za8X+N /Dd98Rvhf8CPhl8OPDNhZ+D7bXdHvtSgsND05/A2vfFVtAXTl8R+FvBvxY+LV1od54r0/TJb rXtEdItXsP0f/wCCaP8AwbK+J/2y/wDgnt8Xf2+Pi38SvHfgnTNZ+Enxq8U/si/Cj4feErTV PH/xE1/4dW+uW/hXxX460rUINVnPhXxh4l8M6toeh+APDCweKPFdlPpniTRvGVlpeoaQNaAP 9MX9mXVv2ddZ+AXwpuf2SdX+F2t/s22fhDT9B+D178FtU0HWPhhF4P8ADBl8N2uleEr7wzcX WjNaaDc6VdaHeWtvM0+napp1/p2orFqVreRJ7pX89n/BsN+zj+1R+y9/wSd+Gnw+/at0jWPB +ua78RviJ8SvhL8NPEsk0Pin4ZfBfx/Jouu6H4c8T6FPp1jN4R1rXvGsvj74kzeFLu41HVdJ tvHlqPEEmjeIptW8KeHf6E6AMTxLodt4m8OeIPDd4ImtPEGiarod0s8LXEDW2rWE9hOJrdZr dp4jFcOJIVuIGlTcgmiLB1/lQ/4M1/FN3rH/AASm+IvhPUbS50+/+GH7afxh8GS2d7dyyXaJ d/Dn4KeNJHk02eCCbRFj1HxZqOnvp7CYPe6de3plWe6ntbb+sqv5LP8Ag1CWTwp4I/4Kq/B0 +If7Yi+Gv/BSn4pqkHmW1tmS90jTvC0viH+wkv7280r/AISFfAUSeZPvtrj+yPsdpf38ul3v 2cA/rTooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooqOUSmKQQPHHMY3EMksbTRJKVIjeSFJYHljV8M8azws6gqssZIcAH8kv/AAaIS+FP HH7M3/BQr49eGX1Xyvi7/wAFHvivLZxalYz2mzwpY+APht4z8KvId81kuquvxL1VdVsbaeae x8uz+0O0VxZu/wDW9X8h3/BlnbQwf8Eq/jXLHdxXL3v7efxWubiGMYewmT4C/syWa2k/JzK8 FpBfAgL+4vYRjILN/XjQAUUUUAfE/wDwUZ/bR0H/AIJ4/sUfH79snxH4Pk+IOn/BHwxpGr2/ gaPxJB4Pbxdr3ibxf4c8CeFvDx8UXGj+IY9Cj1bxP4p0iyl1JdB1ue2imd7bSNRuRFZzfwEf 8Eu/2cf+CnH/AAcQfG/9pL40ftTfHfx74H/Yo+LXi/4a6H+1H4w8MzXfhQfEDw58IZvEnijw J+yX+ztopgvvDum+CdA1TxTYeIfGNnc29/onh/UToHxD8XN4z+Jd5FH4o/av4rf8EV/+Cun/ AAUT/wCCgXj7TP8Agp3+2NH4g/4Jc+H/AIq658SPB/wd+Cfj7UvCfhj4o+CR4sfWfhd8IW+F nh3SvCknhu+8K+H4dJ0Xxj8QfH8vi/xtoL2mqp4D8e+MPEHiC6+JUH9bvwi+D/wt+AXw18If B34KeAPCnwu+FvgHSl0Twd4D8E6NZ6D4a0DTvtE95NHY6bYxRQie+1C6vNU1W+lEt/q+r31/ q+qXN3qV9d3UwB/C7+x7+wD8Df8Agg3/AMHE/wAPdE+L0Us37NP7X/w6+Kngz/gnb8Z/F9zp d2/gv4ueJdT8AWGp/DXxPdSXdxqFn4l0XSPEupfBey8YSW1rN4mg+J3gi7mNpB4r8VWui/30 1+Lv/Bd7/gmrrX/BTH9hnWvAPwsuNN0L9pv4K+K9K+Ov7NHi2ea40nU7P4h+ELa8S98I2Pif T7iz1DQI/H2gXV7ottdPcnR7HxdD4N8T6pbmXwvp99p/8eXxM/4O+v8Agp58HdU+C3wh8b/s tfCv4dfFz4DOPDX7WOmfFPSPGC+Ivjfrun/ZLYSJ4VePwnffAm8u9E3alfx6dd+NItQ8T3tv 4k0t7Dwi0fgqcA/0r6K5/wAJ+K/Dfjzwr4Z8ceDdb03xN4P8ZeH9G8V+FPEmjXUd7pHiDw34 i0621fQtb0q9hLRXem6rpd5a39jdRM0dxa3EUqEq4NdBQB8C/wDBSD/gn7+yZ/wUb/Zy1D4L /tiafqCfDTwpq8vxP0vxroni8eA9e+GPiTQfC/iXRv8AhPtN8UXCT6NZrofh/wARa9LeQeLN O1rwfNCwuNf0W/gsohF/lL/EP/gnf+05+2TP+2J+0N+xBqfx1/bX/Yb/AGGVvPBmh/tDfGbW 9O8P+MT8IfA+h3/jD+xvCXhDxp4qj1vV9P8ABXh+XV/FH/CI+B9Li1Cw8M6po2u3ngXwnrHj Oy8Kj+1b/gpX+0T8ff8Agtb+2VqP/BFj9gXxdd+CP2WfhxqVlq//AAUb/bV8EXk3ifw2NDh0 iR7r4C+H9f8ACHiB/Dlxb3N/eal4U8R/D/xDJb+IvHvxQ8PNodz/AMI58NPh18R77xV/Ur+z R+zR8Ef2Qfgp4F/Z7/Z58AaD8NvhX8PNIg0rQvD+g2FrZm6nWNP7S8Ra9dW8EMuveLPEd4Jd X8T+JdS8/Vtf1m6utS1G5muZ3egD/FY/ZR1/wZ8Qdd/4ZK8ReB/g74W0/wDbA/aE/ZW8Eaj+ 0D4u0bS77xJ+zf4H0z4iarp3i67+G/izxcmqar4FtPE7+MdD1Hx7r48RxW934W8Ey6Jrdpqd hqS3Gj/7d3w98AeDfhR4A8D/AAt+HPh7T/CPw9+Gvg/wz4A8CeFNJSSPSvDHg3wbotl4d8L+ HtMjlkllTT9F0TTrHTbJJJZZFtraNXkdgWP+SV/wcXfsl/s5/AT/AIK+fHj4N/su6XZ+BLDX /CngL4kX/wALdCMviXSLb44fFWwtvFV/8N/h34R8E+GJL/4d2virT9d0PXPCfgHUotR07TdQ 12IaPqXhzwLr/hbQvDH9/H/BuL+zL+3h+yt/wTp07wB/wUB1vxf/AMLK1f4qeLfF3w1+HPjj xjp/jjxL8I/gxq2i+FY/DvhHXNVs5tWl0zVtU8VWvjTxnL4Ul8T62PC2l+JdH0m8s/DHiSHx H4c08A/e2iiigAr+RL/ggRqX/Ckv+Cuv/BwN+yH4s1TRdQ8X6z+03b/tLeEZfDH9nXOjXXgr xP8AEH4pavqi3k2kwWmm6Nrej6V8XfhPY6r4XtbZYdD1648SaHGkJ0KTz/67a/k58M3WkfDL /g8H+IUWl22l6ZeftEf8EybK18SS2Wj373fiLV9EvvA97Bc6terPfW8WqQaF8DNAtI9Ykj0a wOi6Hpnh8QS6pIlzqoB/WNRRRQAUUVHFIs0UcyCQJLGkiiWKWCUK6hlEkE6RzQyAEB4po0lj bKSIrgqACSiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKK ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAo oooA/kU/4MyNPvdF/wCCbH7Tnh+/8P674autE/4KI/F/T7rSPEapHrGkXtp8Bf2Y7K88P6xD JbaXfxa7ocloLbWVu9D0hBdSBIraKZLuzsv666/js/4NGfAGofCjQ/8Agq78LdW1jT/EOq/D X9unUPAGp6/pOlXehaVrmoeDrTxL4dvdY0zRL9nvtH0/U7nTpL2y0q9d7vT7aeO0uGaaFyf7 E6ACiiigAooooAK/m6/4OL/+CV/wz/az/Yi/ad+P3wa/ZE8P/GX/AIKA6F8OPh3pXw48YeGd I1S8+LV74O8H/FjwjrvjTT/DGg6RcpD468XWvwv/AOE70/w3pj6Vqvi/U4J4fDfhYX+of2Ho Nx/SLRQB/lz/APBNH/g5w/bE/wCCXHwv1f8AY0/ay+Bes/GPwp8Hfhxf+G/gT4X8bWep/Cv4 y/CXxFHp9tqfw98C+Ob7WrBb3Vvg/BZ3kUVpZan4cbxv4Z8O3mlx+GtZv/DOmaL4Xg/NLx7/ AMHAv/BZX42fFfxr4o0r9sT4ueHdQ+L2pX2i2fwj+FSJZ/D/AEe28ULDoth4M+G3w/ltNefT PJt2tdJ0O7tpdQ8a3N2x1G78Q6n4l1C/1W9/0XP+C/v/AASz/Zk/b+/Yw+J/xO+Kn27wD8Vf 2V/hj8Vvjb8Pfi74O0vw+fEfk+Cvh/q3iHWPA3jGW/0q5vvEPw/8RW/h+zN5pNvqGm32napp +k6vpl/H9ju9O1P8T/8Ag1k/4Ic/s23HwE+A3/BVb466TrPxG+NHi+++IGrfBX4e+MdO0tvh t8MLXwl4+8U/D/RfiTD4bvdLkvfEXjy7fwxdeIvBWv6retpHhq31DSvE3hzSj4it9C8S6aAf 0yf8EkP+Cb3ww/4JefsXfDb9nTwPFpmr+Nriyt/Gfxz+Jdtpd3pmofFH4ua5Z28niHX7iHU7 e11e10PR40tvC3gvR9StrS70fwnoulwahajXJtYurz9NaKKAPij4k/8ABOT9h34w/tPeB/2z Pif+zV8NvG37TPw40/SNN8H/ABU12xv7rUtNi8PTahceHby60MagnhPXNb8OTancSeHvEWv6 Bqmv6E0Om/2TqVmNH0gWP2vRRQAUUUUAFfyb+CrO81b/AIPCPi9PHrMF9D4Y/wCCZemXk9jd 6tbeZo1ncXnww08aNpdnKlvL58t/4hh8QyaTbNe3P2bVdR11nS08+O0/rIr+ODwTqumaB/we b/GC0vbu9a68bfsRaZpWkQyGa5gTU7T4M/C7W5bSAAFNPsjo/hHVL5gxWF9RaY5+0XwUgH9j 9FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFAH8cf/Bs7qPiDwt/wUT/AODhr4O+KINb8OXOk/tlaV4v0jwJqV94i1+20WS9+MX7Wem+ ItSi8R63JqNzq02paavgGKPX9Y1i71bxjpdpputxXWrRQ3l8n9jlfxk/8EqI5Ph3/wAHUf8A wWk+F403xPZweNvg/rPxejk8QQ3WmGUz/EL9nbW3uItOutO05r7StRufi3d3PhHWI4pLebw5 HFcWt9qsGprqVx/ZtQAUUUUAFFFFABRRRQB+EX/Bx9+0ja/AX/glZ8a/AOmaRr3ib4pftlah on7FnwU8JeHLe6n1HxL4/wDjlBqlrfWEhs5Ungtk+H+h+N54Ayy22ra1Ho3hi4THiBCP02/Y f/Zm0z9jT9j/APZs/ZX0rUoNbi+BHwc8C/Dm/wBftbb7Fb+JPEOg6Haw+KvE8NoVVrWPxL4m bVtdW3k3TQjUPLmkllV5H/GP9vvw7eftnf8ABdr/AIJV/sn6TcLqXgD9hvwR8S/+ClX7Qmmr eJFYWOqWuuaL4A/ZkunOJI7zxhovxc8PWl5aeHvMs9Rg8G+K9Z8SvFdWCW+P6Q6ACiiigAoo ooAKKKKACv5F/AR0vxB/weM/GwaD4f3Xfgb/AIJ16SPGuo2l1cazs1S70H4RtaeINUi8t4/C WdF8YeEvC0dqGit7ndp175hu/Exhk/ror+RP/gnLbW3jT/g6q/4LRfEnU3v7XxB4O/Z5+G3w v0mwvNW8Mytd+HrrTv2Y7O71Caz0HQLM6hFGfhd4cOi3M2ow6p4c0bUYNC8Vr4j1+dtV04A/ rsooooAKKKKACiiigAooooAKKw/EPifw14R0/wDtbxX4h0PwxpXnx2v9p+IdWsNF0/7TMHaG 3+2alcW1t58qxyGOHzPMkEblVIVsfOPxA/bs/Yh+EyNJ8U/2yP2Vfhoizw2rP8QP2hvhH4NR bm4gS5t7dm8R+L9NAnntpI7iGEkSSwSJKitG6sQD6qor8oPiN/wXT/4I/fC2x/tDxN/wUR/Z g1O3/wCEfufE3l/Dn4h2Xxhvv7OtIZp5bb+zPhJF431I+IHSB1tvCYtP+EqvZmht7PRp7i5t 4pflm6/4Ok/+CFlvbXE8X7bk99LBBNNFZWv7NH7XSXN5JHGzpa273vwFs7NZ7hlEULXd3a2y yOpnuIIg8qgH9AtFfy6wf8HXX7FXxL16PwZ+yJ+yd/wUL/bM8bXEoitdE+Bv7O1rqschSA3l xHJby+M5PGAuVsIr28ggtfBV4kken3T3E1nboty3rlt/wUv/AOC3vxn8P6Rrf7PP/BBXXPAe heIWsrnTPGH7WH7Z3wh+GWs6bYvb/a7mLxV8BL/SvCnxV0C7lilt7eEXVwLyxvWmgvtHZ7a5 SAA/ouor+XnVPiZ/wdrePlvToX7Of/BK74FWlvNZrZwa34v+IHi/xFej7Hb/AG2X+0tO+KPj Pw/JZvfR3Lwxy6Jo97bW9xFalr97c6lNWtNM/wCDum5sXu5vEX/BJKwuETVHXTLuD4rPfStp 8Omy2kSSWOhXumh9ce+urfSzJqEccM2j6k2tyaPby6RPqoB/UfRX8rkXhT/g701q9tC/xM/4 JTeEYNUs302ZZbDx5c2Xhydbi4nXxBdmH4feJ9RnvHit47NIbFte08W97bvJoiXaXV3aVrv9 lX/g7g8VXrnU/wDgpt/wTu+Fdi11HIv/AArX4Q2vjGRLfytWkkgW2+JP7HMzbPtM2l2wV9Sk ne2g+0/bYZ7W4t9cAP6rKK/mBn/4Jrf8HF/jNNBTx1/wXz8K+Hg0+h3GvH4e/sWfCHT302S3 gv7fUF0uTw/oHw5fxJBax63qbQ2uqNoFt4jntNEudXhsLnSNGl0bUi/4JJ/8FxzrV1BP/wAH F/j6Pw6lnC9lqsX7D3w3m1q41BnUT2t1oD/FmCxs7ONNzQ38PiS+nncKj6dbhjIoB/TVRX87 njr/AIJHf8FU9bm04+C/+DhX9p7wxa2V/dahLF4h/Zb+DXiS4uXisNPXQoWuvC3i74bJJa2e sR6te63Y6hbalpviLS73TtHNjpk2lXGravxf/DoP/gs7HM11b/8AByB8Y1ubmCGO/wDtP7Cv w0u7N5reW58mXTtPk+PC2ulRm1mhiuY7dHlvLmF7u5uZA9vb2gB/SvRX83+mf8Eq/wDgt94e uIdU0f8A4ONvG97qOnrfzWFr4i/4Jz/A3XNJuLm7smtPK1Oy174va/p91bbdpha90nUl0ucn UdPtVv0WRvI7v9gz/g6S0nFn4Y/4Lc/s76vp6XOoOlz4l/ZJ+DNrqLRTX009u8jS/s4+LJ2a WOUu1o2pSW+ljZp1jLPZW8DqAf1OUV/Mrb/sof8AB0pBcQTS/wDBU/8AYXvI4VcSWlx+zNpC 290XstPtVadrT4JWt2rRz2dxqSC2urdTe6tqEciyadHpdhptaH9j/wD4OkrO8lu1/wCCt37G WrxXN3p11/ZWqfsreDLPT9PitdPaO80yxm0r4ExancWOo6hdzSXc1/fS6jjSdLuNPvNKivtT 0ogH9OdFfzHW37I3/B0qs3+k/wDBWD9iV4JW8NK5/wCGX/DMr2sei3aTatLbRJ8CrPzpfFsA a08QRXFx5cMDH/hFH8J3RW9j7Ox/Zt/4OeNN1iK7b/go7/wT18R6ba3buum65+zVrVja6paq zrEmopoHgew1K181CkksWm67HJFIPLjvpUBdwD+j6iv5s9Y8Jf8AB17oFnqN3pHxS/4IyeOj BPDPZ6edE/aa0fW72C21GVVs7WO58H6RoMP9p2DQS6mNQ12N7XE9rpeopNDFe33Jw/FX/g7Z 0iHWXuf2Z/8AgkN4qXSdTae2t7bxJ8atP1TxRYajcJqTWPhq5m+O2laVY22hQXz+HrW48WW+ lagyaN9quj4hmddW1gA/p4or+ZO0/bN/4OgYNP1vUNR/4I6fsnajPHqt/wD2JoWm/tgfDXTd WbR4J9GsrSKa5vfjVqGiahd3bXeqazDqMup+HFbStOubO70PTdWi06HX/lv4+f8ABXH/AIOY PhlrnhPwjpX/AAQt8Oaf4g8Ral4fhXUdC1bxb+1F4RNq1sBrcOqeKfgD8QofCfgV9Ruop5tP 1fxh4qt9P8MQSW9pq9vrc2y6uAD+xCv89H/g4j/4OHf2yPgz+2nrv7KP7C37RngP4Z/B/wCF fhHQLzX/AIkfBS0+HHxY8Z/ED4la9ptpqms+F/F/izXJPE+l+B7HwFfwDw+fDPhSy0XxNZ3s mvXnjG48S2upaFofhvznSf8Ags7/AMFmP+Cwnxu8O/8ABLq98AWX7I9l4k/aTj+DP7YXxZ/Z A+Hvje48YfDf4Rz6td+FvGng3xb4m8YeNPiPZeApdHl8PeN7rVfF/h7xh4Rm8ZHSIvDFkp0F PEej+Lv7ff2Pf+CX37BH7B3gxvBf7MP7Mfwy8BJe29nB4i8YX2iR+MPiZ4xNlLHdW7eL/iV4 wOueNdet4NQR9T0/R7rWv+Ef0O+uLmTw/pGkxzNFQB+DX/Bv1/wXb/aM/bE+J0H7BH/BQ34f XPhP9qu0+Cen/HL4cfF7UtAtfh9efH/wR4htNK8d6RJqfwy0nwp4b8N+HtXufhb4x8O+NPC2 t+EYbXw14x8G6fqmqrpGk3tosms/1uV/IV+0Bp+l+Lv+Dxr9hyf4XaZDfan8Lf2CPGuq/tJX +h29uE0kan4B/ax0bwvP4wS30mK4XVlg+IPwYsV1q/1S9+1aRr/gbRIPsKabHb3n9etABRRR QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQB/HT8AlvtG/4PMv23TBqOq2 dv4t/YZ8Jte201itrZ6rY23wl/ZEVNOtZ7zWJTqWlR6n4ZtNWa+0qytmj1zTbjTZNHZLDUvE Fx/YtX8YvwVsfEdp/wAHnv7V1xqN7aXVtqn7Huj31nB9l1S3XTfDkfwJ/Zz0y0srKW7toIL6 7k1bTjqN7dWUt5paS6hqVklyuoWc9pa/2dUAFFFFABRRRQAUUUUAfy/f8Ei/GGi/Hf8A4Lm/ 8HDPxinvJNb1r4X+Nf2TP2cPC+oSyafOmg+HfBmi/F3wH418Nad9kmvlsLQ+L/gfp095Z213 aNcapZ3V9r+mx6/Lcx2f7z/Fn9tb9jX4B3smm/HX9rX9mX4LajDqA0mWw+LPx5+Ffw5vYtVa 0F+umSWvjDxXo06agbEi9Fk0YuTaEXIj8k76/iJ+DP8AwaV/ta/E79uv9qLUv22P2mta8Mfs lfEHxh4v+JmpePP2efHkd18Rf2ndY8eeI/GWraPpGtaf42069i8A694VbxDN4g+IWsePfAXx C0ubUNRv/CPgSfxNb+IdR+IPhv8Ao18Bf8G0f/BFLwF4X07w0v7E/hzxjJZRj7V4l8e/EX4u +JvFGsXRRElvdRv5vHlvaRSTeWrmy0jT9K0i3cubLTbUSSBgD7Kg/wCCu/8AwSouDZrH/wAF J/2ElN99s8jz/wBq/wCBlqE+wv5c/wBsa58cQrp29ubP+0Da/wBop+90/wC0x/PXpnhj/goj /wAE/vG93pth4M/bn/Y68XX2tafqGraPZeGP2m/gpr93q2laTenTdV1PTbbSvG13Nf6fpmog 2GoXtqkttZ3oNrcyRzgx182Rf8ENf+CQUMUcKf8ABOz9lkpFGkamX4Y6TPKVRQqmSecSTTSE AF5ZpHlkbLyOzksfPtV/4N6P+CL2s6jd6pd/8E/vg1Dc3spmmi0q98f6FpyOQAVtNI0Txnp+ k2EWAMW9jZW0CnLCMMzEgH6M/wDDWX7LH/Ry/wCz/wD+Hl+HX/zR1q3f7Sn7OlhDbXF98ffg pZ295pUOvWk938VPAtvDdaHcXzaZb6zbSza6iT6VPqSPp8OoxM1nLfK1okzXCmMfmD/xDq/8 EVv+jAvhV/4UfxU/+b+j/iHV/wCCK3/RgXwq/wDCj+Kn/wA39AH6U/8ADWX7LH/Ry/7P/wD4 eX4df/NHWfqv7ZH7Iehadd6vrf7VP7N+jaTYRG4vtU1X44/DHT9OsoFIUzXd7d+KIba2iDMo Mk0qICQC2SK/PF/+DeL/AIIuSWNvp7f8E/8A4Pi3tbu9vYpE1X4jR3zTX8NhBOlxqcfjddSv LSNNOt2srC7u57HTppL+40+3tbjVdTlvOj8O/wDBAv8A4I3+F5dSl03/AIJ6/s+XL6rJDJdD xFoeseL4omga5ZBpsPizW9bh0aNjdSiaLSI7GK5VbZLhJUs7RYAD6c8T/wDBTb/gm34J1i58 PeM/+Cg/7EHhLX7PH2vQ/E/7V/wG0HWLXLMo+06Zqvj60vYMsjqPNgXLIwHKnH8aX/BG3/gp h/wT2+Cn/BVX/gun+1t+07+1L8OvAunfGD9oiXQP2aPG13aXp0f4l/BnUvjV8d9Sn1Twzp/h DwpeXep20Hhjwr8ELt9Ykt7e6voNTj1bXH1PVdRudQj/AKuP+HHP/BIT/pHX+yr/AOGs0T/4 3X83v/BpZ+z5+z/8a9K/4KY/GTxX8BfgB4x8O6h+1ppukfC2e8+Gng3xFp3hDRLOx8Z+In0H wFHr+lavd+GvB1tpXjLQI9DsbG9Fu1mFhzI1q0jAH6669/wdVf8ABDvSELaf+1p4k8UsPIxH oP7N/wC0rbu3nQapLJg+J/hP4cj/ANFk0+0tp9zrun1vS2tvtFtDrVxpGXof/B0n/wAEu/HM OtS/CS1/a2+Nr+HotKk1e3+FH7KvxK8Szae+s3F7BY2981xb6Zb6bLNFp19eQtqc9lBe29nd Lp017d21xaxf0QaJoOh+GdLtdE8N6NpXh/RbLzvsWkaJp1npWl2n2m4lu7j7LYWENvaW/wBo u7ie6m8qJPNuJpZpN0kjs2rQB/O5d/8ABcj9p74gWFlqX7Mf/BCj/gqJ8QrHW9ES68O3/wAe /BXg/wDZd0zU9blS4u7eGfUdV1X4lW2n+D7vTG027sfG7NcxX815cWtnos4tILjUPP77/gqb /wAF6fE8lnaeAf8Ag3i1fw3di5jivZvH37d3wiu7K4W8kjt7QW0134O+HFtYLDMXe+vLi9vr aC3YTXIsYIpLh/6Y6KAP5kZf2vf+Do7xSPEE/hz/AIJKfsYfCuMRCDw7Y/E/9qrwh48vY7t9 OVRqF7c/Dj432Fnq+nw6oHnlsf8Ailb17R00+K5MiNq75+sw/wDB2/8AEPUG0+yuv+CQPwKt rnSpbQa3oy/G3V9PsLuM3M6aosPiC3+MeqvqtwJYrOKNtIvdDUW9s0+nQM13dT/0/UUAfzOW 3/BL7/gvB8bEtr39pr/gvPf/AAwjhGqRnwP+yN+yz4D8LWMNvr+kWqXtvafEuyufhJ4nuDpG r28aaJe+I/DHiPVLfToLi60u/wDDupa3e/ZsG0/4Ns/GfiWXRZ/jX/wW1/4K9/E6ayjEWqzW n7Seq6LLdxRtePbx6LJ4sm+JT6FHC12zBLk64paS8aMRG8Plf1A0UAfzJ6J/waUf8Ei4rV5P iDpH7THxs8VXEkL6h8QPil+0N4jm8Y6ottYWWnW8WoT+BtN8DaHNHbwWSeQU0GKWISNbpItl DZ2tr9kfA/8A4N3/APgjJ8Abm01Dwl+wZ8JfF+qW8UK3F78cLvxl+0Hbajcx6Vc6TNe3fhz4 2eJvHfg+GW7ivLi8mtdM8O6fpUOqm21Ox06zvNN0uWy/aSigD4w8P/8ABN//AIJ4eEkMfhX9 gv8AYw8MxmI25Tw/+y58D9FQwGeS6MJXTfA1spiNzNLcGPGwzyyTbfMdmPsqfs1/s6RJZxxf AL4KRpp0bRaeifCvwKiWETXtlqTR2aroQFrG2o6bp1+yQBFN7YWV0QZ7WCSP2qigAooooAKK KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA/z0f8Agh5/wWH/AGQv+CPnwz/b g/Zq/wCCj0XxZ+Hv7Z837b/xR8afE9NE+G2oeOF8WTN4d8G+FptOs9a0WSOG3n0Xxn4b8dam Idaa20m+sPFNh4g8P6/q9vrdzZ6L+qHif/grd/wVw/4Kl2vh/wAO/wDBFX9h/wAe/s2fCPW9 K0zX9V/bn/b28L+GfB+iXNnfyRRfZPhf4PdviN4C8QWNp59rfyeJPD158btR1nTJ7uOLwH4Y fTo9T1L+q7Ufh74A1fX7XxXq3gfwfqniixlsriy8Saj4Z0W91+zn02VZtOmtdYubKXUbeXT5 kSWykhuUe1lRZIGjZQR2FAH45/8ABJT/AIJH+Gv+Cbmg/FL4l/Eb4s+Jv2ov22/2mL/T/EH7 TX7UHjqXUrjV/FN7YXOoahp/hDwfb65qWs6no3hDSbrVJ5NQvrrUH1zx5qltYa14hWx07RvB vhHwZ+xlFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQB/Fz+zF4 TTUv+D0T/goTfxa22nJ4R/ZJ8K+LGs73Up5Z/ET6r+zz+xN4cl0S2N611NcrazeMG16202GW CDT9P0ArZrBYabFZ1/aNX8b37DelzeHP+Dxn/grBpwlvtZF/+xJoWqS3rrYw/wBmw+ItC/4J 5eKY4rhGuLd5LHTXvofD9m1nFeX0v+gz3NuITf3lt/ZDQAUUUUAFFFFABRRRQAUUUUAFFFFA BRRRQAUUUUAYfijXE8M+GvEXiSS0n1CPw9oWra49havBHc3qaTYXF+1pbyXMkVuk9yLcwwvc SxQLI6tLIkYZh/IL/wAGUVgY/wDgml+0hqn2C0jF5+3N42sBqaajdy314dN+AX7PFwbC40l7 RLCytNO/tUXFlqNtf3N3qk2q39te2llDpGnzX/8AVZ+0n4s0vwF+zp8ffHOt6X/bmi+C/gr8 VPFmr6Li4P8Aa+l+HPAuu6xf6Xi01TRLs/2haWctpi11rSLj99+51Swk23cX82n/AAZxaXBp /wDwSL1i7huWnk1z9rf4z6pdRMqKLKeHwp8KtFW2QraWzOr22j294Wkmv3D3bILtI0SwsgD+ rWiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAo oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKK ACiiigD+K39hiKLTf+Dx3/gp9a6NL4g1myvP2VbmXUr201HSru106W+8MfsSavqUXiGTTptQ gfw/pviBv+Ef07ThcW2q6bq//COWusw2Wo2GpaWn9qVfxE/sU37zf8HlX/BRY3N7feKJZv2e dYsIdVFxPbLoyWPw4/ZMSCyu4YXuo76x8P2liPBtrb3UsEAkisL5Ut7m1t7If27UAFFFFABR RRQAUUV/G5+0lN8ff2nv+Duv9kj4Tw2vizwh8Gv2K/2dLX4xyPpviv7Tovibw7N4B+JWp6n8 UW8PTW9jbaZL4l+Jvxb8Mfs563ZwtrOoSaDoNxrEN9Bbapdadp4B/ZHRRXyf+3h8IF+P37Ff 7VvwXfxd4j8Bf8LL/Z++K/hNPGPhTVZtH1vw/NqngzV4re/hvIb7TfNsUnEces6XcX9pYa3o smoaLqU8en6hdNQB9IeFvFnhXxzoNj4p8E+JvD/jDwxqn2r+zPEfhbWdO8QaDqP2K8uNOvfs Or6Tc3en3f2TULS7sbr7PcSfZ7y1uLWXZPDIi9BX8p3/AAZy2+uw/wDBInU5NWW5Wwu/2s/j RceFzPbXMET6Evhj4XWtw1nLPq+pRXlsPEtt4iRrmys/D9st4l3aPpE15a3eva3/AFY0AfnT +33/AMFOPgH/AME5tV/Zh0f43+E/jF4pvP2sfjRpvwM+HJ+E/hXw54kg0fxXqdzo9rFqXjSb xH4z8HLpugxy65Y5Gif8JF4iukW7bTPDt+LO42fotX8sf/BzjpsOp6h/wRqtjexWN1d/8FYP gDpsM9/cmz0a3h1Cdo573VLppxBbRWckds5uZbSc29o97Is9sgliu/6nKACiiigD5I/b91PW 9F/YQ/bX1jw1b3N34j0n9kj9o/U9AtbO7isLu51uw+DnjO60q3tb6e806CzuZr6KCOC7m1Cx it5WWaS8tkQzp+F3/BoL4Zk0H/gjn4Z1RzlfGn7RXxz8TQjz7qXEdrf+HvBxHl3F7dRW377w nKfIsYNNtWz9peykvbi81G//AGh/4Kf6bq2r/wDBNf8A4KC6boL60utXn7FH7UkWlx+Hb2x0 3W7y9/4Uj43a30zTNT1Gw1K10261aRRpiaibOSewF213ZyW15DBdQ/jj/wAGininSPEH/BGj 4faTpsssl74G+O/x58LeIUkgkhS31e78UWvjWGK3kcBbqJtA8YaHO08RMazzTWxPm28oAB/T rRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFA BRRRQB/D9+yjBceHf+D0H9uzTdQ/srTrjWPgJdT29rpuiGe3v7fWPgB+y/4rsP363ZGi6rda Z5Wr6zrbC4GoalHqWnm0t310Naf3A1/n0/sK/ER/jd/weV/tTePfDNzout6Hot1+0L4R1LVP BRMnh8aP8KfgxofwWiur2aK0sYbi6/t3w3pNjr14sVxa3ni+a4ubfUNVWeDVbv8A0FqACiii gAoor8K/+Dgz/gp58Vv+CV37EWi/Gz4Cw/BzVPjH44+MHhz4aeH9E+Ll5fXG3w7qPhzxXq3i TxV4R8HaTqmj6j4z1nw1e6X4bgvLGS/tdG0vTNcuNW1SaaS3sNL1MA/dSv5lf+CarQftEf8A Bfz/AILeftUWk+l33hv4E6D+zx+w74KvPO0nVNRtb3QtDs7n4w6HY6hpeo3TadZaf8TPg9Nd 63pt5bx3D6lqen6fctbat4Z1ewt/2w/YK+Jf7Sfxi/Y9+APxM/bA+EkXwL/aW8XeBYNQ+Lvw tggWyg8NeJYtR1Gxjmh0o694nutBi8RaTaab4pj8M6prd7rvhhNbXw/4gFprem6hZW/4m/8A BsnBF4u+Gv8AwVG/aDsx4gg0T4+f8Fbf2rfE/hW18TXy6xrUvhe2j8HanY6pq2uMY7nV9Zud Q8Uatpes3d1aWktxqGhzXwi23uFAP6bK+c/2wvHZ+Fv7JH7UvxND6fGfhz+zn8bvHYfVtMXW 9KQ+Efhn4n8QB9T0Z5IU1fT1On5vdMeaJb+2Elq0iCUsPoyvxb/4OJPG2peAP+CLH7f2u6Ud QF1f/CXQvBMv9mDUDc/2b8Svid4E+HOsiUaaVuP7POkeKr4asZD/AGeulG9bVQ2li8UgHFf8 G0vwmPwh/wCCKf7E+mXMcQ1bxv4a+IfxZ1W4hOohLwfE/wCLfjvxd4dkaHUSPIltfBWo+F9L nFjDDp1zPp8l/ai4F497dfuzXw3+xTqHhb4O/wDBNT9krVWt5bDwV8LP2GvgNqDWkE4uJ7Lw t4I+AfhS5NvDc6vfRieW30nTPKjn1TUoxI6CS9vk3S3A/K7/AINq/wDgpf8AtPf8FQf2Vv2h vjJ+1Nr3gjWPFngz9p3WvAvhKz8G+FNK8JL4f8ES/Dn4feKbDRbm00y8aTUbOz1LX9Ui0rVt V09dVuhHexXet601uIdJAOK/4OGNO0q9+P8A/wAEDHvrNrq5P/BZL9mHTkE0N3Np76VqPjXw qdWs7xNraVI15Jaad5cN8rXcsEN2LFTbDUxX9NVfyuf8HI2t+K4f2gf+CDPhX4fXmkaT8Qte /wCCqXwh1LwTrfiPT59R8NaZ4i0nxh8NtG0mTxJbabd6frd7oLap4tsJdZ0nS7+yfVdKtr23 a5huBZyp8+/Bv4vf8Hknwl+IHxCtvid+yh+zB+1R4V8Tzu3hS88T/ED9l74feEfhvPa3F48L eEJ/hp8Wvhf8Q9Y8OX8Eiw3Vh8RdC8U+I38rR5bfXNFeLWk1EA/slor+TfVPj7/weA+Ibvwx 4Ytf2KP+CaXw/TxHJKuqfEOw8U3+qWHgyWzH21Rr1nfftWeNL1bTUrctp6NoXg3xgwurS5LX mnve6YJfmPxd/wAEA/8AguF+3j8YvD/xQ/4KTf8ABWvwf4PsvBu6bwPpf7JsHjeZvCgkmk1O CDQPDGl+Df2Z/BnhnV7LUk06GTxc0fjHxPf2un2z6hrWoz2dpMAD+xn40eCtB+JPwd+LHw68 VPfR+F/H3w08d+CvEj6WC2ppoPirwtquhaw+nAPGTfLp9/cG0AdCbgRgOp5H8nf/AAZSJqQ/ 4Jk/tFSS3CNpDft2+PksbQWUcckGpR/s/wD7NzarcPqAv5JbpLq1k0aKOyfTLOOwazlnjv8A UW1GW30tf2w/+DfT/grJ8RfhZ4nuvhX/AMF7P2ufil8Q5/D11YXfwo+KHiX4lfCH4P8AxIt5 XkuLzQ7xvhj8WtW0bw0L03N9HbHVvAHi60u0fTNF1G80zSrJNQtvd/8Ag2D/AOCWX7dX/BL/ AOGf7Wvhn9sa58OaDoPxf8a/CnxD8LPhd4Z+Ilt47s/Des+FdF8caX8SPHF1FohuPC+k33j2 w1T4baK8thf3Osala/Du0TWobW103RPOAP6l6KKKACiiigAooooAKKKKACiiigAooooAKKKK ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAo oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAP8AP0H/AAaDft9/BT9o6f45fsl/8FNf DfhXX7LxJ4j8TeGvi7rsXxY8B/HK0utWutZu0TxBq3gubxJbeI77WVl06z8Z6rJrllZ+Ihqe v3F54dntUTSNU+7NT/4Ib/8ABf8A8X3+q3nir/g4J+Jmjm/8O6JoS/8ACFXHxl0KBorfT4or 9oNL8M+MvBen6HqlrcwrDF4t0lB4n8RIZNU1e7sb2ee3f+x+igD+SLwv/wAG4f8AwUImeJPi r/wce/8ABR/xhpi3Wh6iuleF/EPxt8LvbX2kalbaqs8Wo+I/2t/H1vNdWd7aWl1oeojRLWbS 9StLbVBBNNFHBF2o/wCDYO+uLrULrVf+CyP/AAVUv5bvdNFMPjlNHdC+lv7ie4utQubmS+bU fPs5IYWVUs5jfpcajJcyRXCafb/1UUUAfysr/wAGuWgxy3txF/wVx/4KrR3NytreRXC/HuyE o16Oz07TLvVr2RdGWS+WbSra7021hV7W9s7OXTreXVL2202WDUP5Kv8Agrt/wR813/gjJ8d/ 2S/jz8dP2l9c/bJ+F/xe/aNvfEniDS9S8HeItL8f6j4S+D2ufDvXdZt/Fera94z8Q+Hte8Ve JvCGtN4fhNz4g0V7iWxke0Y6Wl62jf6vdfnn/wAFB/8Agl1+x7/wU+8M/Crwl+134J8ReMNG +D3je48b+EU8M+N/Enge6aXU7KHTvEXh7VL3w5e2lzc+HfE1naafFqyW0llrdu2nWk2ha3o0 /wBolnAPrX4EfGfwT+0b8E/hH+0B8NZdXn+Hfxt+G3gr4reBbjX9GvfD+s3HhHx94d0/xR4d udR0bUES6sLm40nU7SZ4m82Fg4ltbi6tZIbmX+e//g1G0/VdJ/4Js/FPSteltptc0z9uv9p7 T9ZmsrA6VZy6rZXHgu21GW00sljpttJeRzPBYFmNnEUtyT5ea/pC8F+DPCXw58HeE/h74B8N 6J4N8C+BPDWheDPBfhDw1ptro/hzwr4S8L6Xa6J4c8N6BpFjFDZaVomh6PY2el6VptnDFa2N jawWtvFHDEiD+XL/AIN5fHWgfBH9sr/gt7/wTf1GLTPBWvfDD/goB8Vv2mvhP8P7nUtBXWdZ +DHxU1tPCNr4l0TR9Ks4pH0LQPCnhj4HS6tPFeS2ejt8SPCmmz6N4c1C7mi1IA/LL4hfCP46 fs4f8Hfv7PPhbwp+178SPjJc/tL+JvE37RvjLw8ILjRbT4WfDnxhon7QlxP+zXq2h3HiHxlo nijw14B+CvgTTW0jxFLo/hq7h8Ma1pOoadpHh3X9HtfFMv73/wDB05Y3N3/wQx/bNng1O7sI tM1L9mu+vLW3WBodatpP2rPglpq6ZfmaKSRLSK71C11hGtXhnN9pNkjSm2e5hm+2viv/AMEo f2ZPi7/wUg+AX/BUDWpvG+g/tC/ADwLqXgjS7Lwnq2maL4Q8cJJY+K9H8P6x4+s49Hl1XWNQ 8P6F498X6OZINVs59Z05vCmlandSaD4Uj0bUvnT/AIORtN8Har/wRJ/b2tfHOovpeixeAvh1 qVlcpcfZml8Y6P8AHT4W6v8ADzTjJ5M+5NX+IFj4Z0mS32L9rjvWtfOtvO+0RAH35+xx4f07 xZ/wT+/ZW8Lausr6T4l/Y6+B3h/VEglME76drPwV8L6derDMoLQytbXMojlAJjcq4BIxXyJ/ wSR/4Ix/s8/8Ee/Dnx10H4FfET4vfEmb49eKfCOt+I9W+K+raBdT6XpHgGx8QWXhDQ9L0zwr oPhzQYrm1bxb4kuda1+LS7e/197zT7e5jhs9E0y3h8d/4NvP25NN/bi/4JU/Aa9e08SQeOP2 YtN0f9kX4m3uvWkhtdc8UfBzwL4MGheIdG1xry9bxDHrvw38QeBNV129vWtNWg8VXmu295YG 1XTtV1b94qAP5Mf+Dl688SeC/wBpv/ggl8YNFtorm0+Hn/BSDwtDOlzbW0lnPq+r+NfgjrWk afdXJI1GCLULDwdr8MkViyRyxLJPNJFd2emuv9Z1fx+f8HVXxI8F6N8Tf+CK3w08RzRQ3viL 9vnRviRcXGo6h9n8OWPgv4c+IPhXoHiqbxDaXMi6R5UsvxJ0d7fUNUUfZLGx12O3kW1uNUB/ r+t7iC6ghurWaK5trmKO4t7i3kSaCeCZFkhmhmjZo5YpY2V45EZkdGVlYqQaAJaKKKACiiig AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKK KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiig AooooAKKKKACiiigAooooAK/hg8M/s3/APBQ3xT/AMHefxf+Pfgz4Q/FD4XfA7SL3wanxj+N WgeH9Z0/4SeOv2fdH/Z4+GujeGvD974+8Wabq3g3xLrXxC1Hwt4G0bV/Bfg65HiG21nQvEsm nWmh33gfxP4h0T+5+igAr5w/ax/ZK+AH7b/wN8Xfs4/tNeAofiP8I/Gx06bWvDkms6/4euF1 DRb6HVND1fTdb8Mano+t6Zqmjapb2+oWF1Z38W2eFUnjntnmgk+j6KAPkX9iX9hb9mL/AIJ4 fA+2/Z5/ZO+HMXw3+GsfiXWvGup2kmsaz4j1zxL4y8Qxafaav4q8U+JPEF7qOs67rdzpuj6L o0VzeXbR2GhaHouh6dDaaVpNhZwfXVFFAH4xf8FS/wDgh3+y5/wVu8ffs++Ov2j/AIi/Hrw5 F+z+viHTtN8H/DLxb4Z0fwl4s8O+LL/StV8R6fq9n4g8G+JNQ0jV9VvPD2g2dz4l8Malo+oS 6FZy6bPHPeRaDq3h/wDY3SdJ0rQNK0zQtC0zT9F0TRdPstJ0bRtJsrbTtK0nStOto7PT9M0z T7OOG0sNPsLSGG1srK1hitrW2ijggjjijVRoUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRR QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRR QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFABRRRQAUUUUAFFFFAH//Z
Subject: The book
Date: Sep 29, 2012
Hello Bob, As of today I have not received my book. Do you have an estimate as to when I would be getting it? Please let me know. Regards Walter Jazun Parker, Colorado ps, paypal shows already collected. -----Original Message----- From: Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> Sent: Fri, Sep 28, 2012 8:37 pm Subject: Re: AeroElectric-List: Resurrecting a battery Here's where my ignorance startsshowing. Is this setup using mains voltage? Rectified and currentlimited? 120+ volts DC, current limited to 1-2 amps? Yes. Suppose the power coming into the back of your house was being supplied by one of the honorable T.A. Edison power stations . . . 120 volts DC. Okay, 150 watt bulb will draw about 1.30 amps. Now hook a 12v battery in series with this setup such that current flowing through the lamp tends to CHARGE the battery. Voltage across the lamp drops by 12v or so the current drops a bit. But the lamp still burns brightly and current through the lamp is charging the battery . . . the lamp becomes a 100W resistor. Horribly inefficient? Yes . . . unless you want to sit down and read a book while the battery is charging and can make use of the light output. Now, consider a similar design goal but the power delivered to the back of the house is AC. We can add the rectifier such that reversal in the applied voltage is rectified so that it always charges the battery irrespective of line polarity . . . the lamp(s) still limits the current . . . want a stronger charge rate? More or bigger lamps. Again, only 10% of total energy consumed goes into the battery . . . but it IS current limited. Probably not a charger you want to build for routine battery maintenance but it is an option for generating a current limited VOLTAGE source that will RISE to what ever level the injured battery will accept. If it goes to more than 2X battery rating and/or if it doesn't begin to fall in a few minutes, then this resuscitation gambit is futile and should be discontinued. Bob . . . ________________________________________________________________________________
Subject: Re: Good news . . . and bad news
Date: Sep 29, 2012
Hi Bob, > Price is hard to beat! One would need an instrumentation > amplifier to read current shunts . . . but the AD628 makes > that really simple. Just need a 36-hour day . . . I have two partial solutions to your dilemma of a 36-hour day. ;-) Unfortunately nobody I have talked to likes my ideas: (1) This idea is made obsolete by modern electronic clocks and watches. Design a pair of elliptical gears into your clock so that the hour hand goes zipping around during the night-time hours of 10 pm until 6 am, but it moves slooowly during the day-time hours of 6 am until 10 pm. (2) Noting that there are 168 hours in a week (7 days times 24 hours per day), rearrange the week to have 6 days of 28 hours, each. The week would still be 168 hours long, but each day would have an extra block of 4 hours that you could use however you wish. Just a thought... ----- Lynn Cole LynnCole(at)foxvalley.net ________________________________________________________________________________
Date: Sep 29, 2012
Subject: Re: Resurrecting a battery
At 12:34 AM 9/29/2012, you wrote: >Very clear now. 1 picture=1k words. I had the lamp on the DC side >in my mind. I'll report back when I have something to report. > >I assume there is no reason to put in a cap to try to limit ripple. Naw . . . those molecules of lead and acid aren't picky. There's some school of thought that impressing clumped up molecules with bursts of high frequency energy tends to break them up and increase surface area . . . i.e. restore active chemistry. This prompted a constellation of product development in 'battery de-sulfators'. http://tinyurl.com/9c4gwk8 I've yet to see a well crafted laboratory study that confirms any claimed efficacy for such devices. Actually, about 1965 there was a rash of articles in popular 'technical' publications suggesting that one could recharge the carbon-zinc cell if the energy replacement profile was half-wave rectified DC (Figure 2 with only one diode). This 'rattling' of the chemistry was suppose to make things happen that the original designers of the carbon-zinc cell never imagined. I'll forward a copy of the previous post to Skip Koss along with this one . . . he may have additional insights to contribute. Bob . . . ________________________________________________________________________________
Date: Sep 29, 2012
Subject: Re: The book
At 09:41 AM 9/29/2012, you wrote: >Hello Bob, > >As of today I have not received my book. > >Do you have an estimate as to when I would be getting it? I show a mailing label printed on the 22nd. You should have received it by now. Another copy will go out today. Bob . . . ________________________________________________________________________________
Date: Sep 29, 2012
At 10:21 AM 9/29/2012, you wrote: >Hi Bob, >>Price is hard to beat! One would need an instrumentation >>amplifier to read current shunts . . . but the AD628 makes >>that really simple. Just need a 36-hour day . . . >I have two partial solutions to your dilemma of a 36-hour day. >;-) Unfortunately nobody I have talked to likes my ideas: I'll bet you could get a patent on it . . . the patent office is exceedingly accepting of ideas irrespective of efficacy or merchantability. But having a patent preserves the idea in perpetuity! Bob . . . ________________________________________________________________________________
Date: Sep 29, 2012
Subject: Crowbar OVM adjustment/test fixture
The crowbar ovm has been in production for OBAM aircraft since 1985 and has been incorporated in to light airplanes in about a dozen configurations. I'm getting an increasing number of queries for a means by which they can be tested either on an airplane or on the bench. Here's the fixture I have used here for some years. http://tinyurl.com/8e552q9 A 6v relay is wired to work like a buzzer (coil in series with N.C. contacts). A 10 ohm resistor tied across the coil to increase it's apparent 'draw' to make sure the crowbar scr latches well. In the airplane, you open the field supply breaker and switch and clip the fixture across the ovm to be tested. Increase applied voltage until the relay begins to 'buzz' and then back the voltage off until it clicks at about one per second rate. THAT voltage is the current calibration point for the OVM. On the bench, I set the power supply for 16.3 volts and adjust the calibration pot for 1 click per second. This is MUCH more precise and convenient than the technique described in the DIY crowbar literature. Bob . . . ________________________________________________________________________________
Date: Sep 29, 2012
At 09:41 AM 9/29/2012, you wrote: >Hello Bob, > >As of today I have not received my book. > >Do you have an estimate as to when I would be getting it? I show a mailing label printed on the 22nd. You should have received it by now. Another copy will go out today. P.S. The PostOffice reports delivery as of today. It's media mail so it doesn't get the same attention as more expensive services. 9449009699939129201366 Package Services Sorting Complete September 29, 2012, 11:07 am PARKER, CO 80134 Delivery Confirmation=99 Bob . . . <http://www.matronics.com/Navigator?AeroElectric-List>http://www.matronics.c om/Navigator?AeroElectric-List <http://www.matronics.com/contribution>http://www.matronics.com/contribution No virus found in this message. Checked by AVG - <http://www.avg.com>www.avg.com Bob . . . ________________________________________________________________________________
Date: Sep 29, 2012
Thank you, looking forward to it Walt -----Original Message----- From: Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> Sent: Sat, Sep 29, 2012 1:58 pm Subject: Re: AeroElectric-List: The book At 09:41 AM 9/29/2012, you wrote: HelloBob, As of today I have not received my book. Do you have an estimate as to when I would be getting it? I show a mailing label printed on the 22nd. You should have received it by now. Another copy will go out today. P.S. The PostOffice reports delivery as of today. It's media mail so it doesn't get the same attention as more expensive services. 9449009699939129201366 Package Services Sorting Complete September 29, 2012, 11:07 am PARKER, CO 80134 Delivery Confirmation=C2=99 Bob . . . AeroElectric-List Email Forum - http://www.matronics.com/Navigator?AeroElectric-List ; - MATRONICS WEB FORUMS - http://forums.matronics.com ; - List Contribution Web Site - ; -Matt Dralle, List Admin. http://www.matronics.com/contribution No virus found in this message. Checked by AVG - www.avg.com 09/29/12 Bob . . . ________________________________________________________________________________
Subject: AIRCAM Schematic or ideas
Date: Sep 29, 2012
Thank you Bob, that is very helpful. Can you explain what happens if the "standby" alternator is activated while the "main" is active? Thanks Chris -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Friday, September 28, 2012 11:52 AM Subject: RE: AeroElectric-List: AIRCAM Schematic or ideas --> At 08:51 PM 9/27/2012, you wrote: >--> > >Correction noted. >thanks >Chris If it were my airplane . . . http://tinyurl.com/cf2ppmx http://tinyurl.com/cg8falj Bob . . . ________________________________________________________________________________
Date: Sep 29, 2012
Subject: Re: Crowbar OVM adjustment/test fixture
This might work with just a heavy automotive light bulb instead of the relay and resistor. Perhaps a brake light or maybe a headlight. The bulb might well drop insignificant voltage prior to tripping. It would have to be heavy enough to keep the scr conducting so that it stayed lighted when the ovm activates. Ken On 29/09/2012 3:48 PM, Robert L. Nuckolls, III wrote: > > > The crowbar ovm has been in production for OBAM > aircraft since 1985 and has been incorporated in to > light airplanes in about a dozen configurations. > > I'm getting an increasing number of queries for a > means by which they can be tested either on an airplane > or on the bench. Here's the fixture I have used here > for some years. > > http://tinyurl.com/8e552q9 > > A 6v relay is wired to work like a buzzer (coil > in series with N.C. contacts). A 10 ohm resistor > tied across the coil to increase it's apparent > 'draw' to make sure the crowbar scr latches > well. > > In the airplane, you open the field supply breaker > and switch and clip the fixture across the ovm > to be tested. Increase applied voltage until the > relay begins to 'buzz' and then back the voltage > off until it clicks at about one per second rate. > > THAT voltage is the current calibration point for > the OVM. On the bench, I set the power supply for > 16.3 volts and adjust the calibration pot for > 1 click per second. This is MUCH more precise > and convenient than the technique described in > the DIY crowbar literature. > > > Bob . . . > ________________________________________________________________________________
From: "nuckollsr" <bob.nuckolls(at)aeroelectric.com>
Date: Sep 29, 2012
Sure. This is what I've shown in the DIY crowbar instructions . . . but the supply needs to be manually reset after each trip. An adjustment procedure or QA check on the bench is tedious. This fixture resets the ovm each time the contacts open. By seeking that once-per-second sweet spot, the test establishes the near infinite trip time setpoint by simply listening. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=384289#384289 ________________________________________________________________________________
Subject: Re: AIRCAM Schematic or ideas
Date: Sep 29, 2012
Probably nothing serious. But it might mask failure of one alternator when the second one shoulders the loads. A failure that become latent and unnoticed until next preflight. Better that you know it before you land as opposed to just before you wanted to take off. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=384290#384290 ________________________________________________________________________________
Date: Sep 30, 2012
Right, but I was picking up on your comment that the "alternators are not designed to run parallel on a single bus". I have been wondering if there is a load sharing problem that would be encountered or any other electrical gremlins I am not smart enough to know about. Thanks Chris -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of nuckollsr Sent: Saturday, September 29, 2012 11:02 PM Subject: AeroElectric-List: Re: AIRCAM Schematic or ideas --> Probably nothing serious. But it might mask failure of one alternator when the second one shoulders the loads. A failure that become latent and unnoticed until next preflight. Better that you know it before you land as opposed to just before you wanted to take off. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=384290#384290 ________________________________________________________________________________
Subject: Re: SD-8 S704-1 relay with or without Diode when using
OVM-14?
Date: Sep 30, 2012
Bob, Thank-you very much for the replies. I was able to calibrate my OVMs and get them both (SD-8 Alternator, and Ground Power) installed yesterday. I greatly appreciate all you do for our OBAM community. Without AEC I'd be lost. My electrical system installation is coming right along. Sincerely, Howard -------- Howard Plevyak GlaStar / North Bend, Ohio hplevyak(at)mac.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=384316#384316 ________________________________________________________________________________
Date: Sep 30, 2012
Let me know when this gets sorted out - I'm still trying to come to terms with the "buttered-cat array". On Sat, Sep 29, 2012 at 12:15 PM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > nuckolls.bob(at)aeroelectric.com**> > > > At 10:21 AM 9/29/2012, you wrote: > >> Hi Bob, >> >>> Price is hard to beat! One would need an instrumentation >>> amplifier to read current shunts . . . but the AD628 makes >>> that really simple. Just need a 36-hour day . . . >>> >> I have two partial solutions to your dilemma of a 36-hour day. ;-) >> Unfortunately nobody I have talked to likes my ideas: >> > > I'll bet you could get a patent on it . . . the > patent office is exceedingly accepting of ideas > irrespective of efficacy or merchantability. > > But having a patent preserves the idea > in perpetuity! > > > Bob . . . > > ________________________________________________________________________________
Date: Sep 30, 2012
Subject: Compatable Shunt
My RV9-A uses the Z-12 drawing. I installed a G3X unit (two Garmin GDU's 37x). The ammeter does not read but the voltmeter does. Reviewing the schematic provided by Garmin for connecting the two instumentation wires to the Shunt and comparing this to the Z-12 schematic I see both are essentially the same. The shunt sent to me by the Avionics shop for use with the Garmin is 100 amp/50mv and the one B & C supplied and installed in the plane is 60 amp at 50mv. My confusion and question concerns the schematic from Garmin that says the shunt is rated at 0.0005 Ohm. The B & C supplied system with its shunt is 50mv/60 amp gives me 0.00083 Ohm. First are my calculations correct and second does this have any bearing on the inability to display the ammeter reading ? If the above is not contributing to the problem should I look elsewhere in the system for the problem ? (Prior to turning on the field of the 60 amp alternator I get the main volts waring light flashing and goes off after the field is activated. Remainder of G3X works fine) ________________________________________________________________________________
Date: Oct 01, 2012
Subject: Re: Compatable Shunt
> The shunt sent to me by the Avionics shop for use with the Garmin > is 100 amp/50mv and the one B & C supplied and installed in the > plane is 60 amp at 50mv. My confusion and question concerns the > schematic from Garmin that says the shunt is rated at 0.0005 > Ohm. The B & C supplied system with its shunt is 50mv/60 amp gives > me 0.00083 Ohm. > >First are my calculations correct and second does this have any >bearing on the inability to display the ammeter reading ? If the >above is not contributing to the problem should I look elsewhere in >the system for the problem ? (Prior to turning on the field of the >60 amp alternator I get the main volts waring light flashing and >goes off after the field is activated. Remainder of G3X works fine) The size of the shunt is relative only to calibration of the display. If you have no display, then the problem is not with the shunt. If the display is present but inaccurate, THEN you probably have a shunt problem. A shut is just a high power resistor . . . abeit a special resistor manufactured from amazium alloy with a near zero temperature coefficient of resistance. The material is actually Manganin. http://tinyurl.com/3f79fgy When your current display is a LOADMETER calibrated in 0-100%, then the shunt is sized to what ever that 100% value is . . . in case of the 60A alternator, you would use a 60A shunt. If it were a 100A alternator, then a 100A shunt. Interestingly enough, using a 100A shunt in ALL installations converts the 0-100% display to a 0-100A display. I suspect that the 100A shunt recommended by the avionics shop is based on some knowledge that the EFIS calls 50mv drop 100Amps and that size shunt will read ANY practical current up to 100A accurately. Substitution of a 60A shunt would simply mean that your 100A display was really a 100% display. Looking past calibration issues, if your display is non-reading, the difficulty lies elsewhere. Bob . . . ________________________________________________________________________________
Date: Oct 01, 2012
using OVM-14? At 10:17 AM 9/30/2012, you wrote: Bob, Thank-you very much for the replies. I was able to calibrate my OVMs and get them both (SD-8 Alternator, and Ground Power) installed yesterday. Did they require re-adjustment? I greatly appreciate all you do for our OBAM community. Without AEC I'd be lost. My electrical system installation is coming right along. My pleasure sir. It's what we do here. It's very much a two-way street. The AeroElectric-List is a vehicle for me to practice many of the critical thought and creativity skills I was unable to fully explore as an employee with direction supplied down from on-high. Not that the tasks were devoid of growth in my chosen discipline . . . I WAS able to participate in a lot of rewarding endeavors. At the same time, few original ideas offered were given any elbow room for exploration as to potential benefit to my employer. I can point to $millions$ in demonstrable lost opportunities over the 40 years. If Walter, Duane, and Willy had still been in charge, who knows? Their legends may not be accurate portrayals of their true sense of adventure either. I'm still sitting on a product idea that would replace a 1970's, $20K black box on a fleet of Hawkers with a 2012 design that can be manufactured for under $100 . . . but the differences are so profound that I don't think they believe it can be true. In the mean time, let us all continue to grow in the things we do best. Bob . . . ________________________________________________________________________________
Date: Oct 01, 2012
Subject: Grounding blocks
I am curious as to what a home made grounding block should be made of. I realize that B and C makes theirs out of brass but I wonder why when it seems there are other more easily obtained metals with better conductivity, according to the charts on this site: http://metaldetectingworld.com/conductive_order_metals.shtml I have seen grounding blocks made of aluminum, copper, brass, etc. What is the benefit of one over the other? -- Eric M. ________________________________________________________________________________
Date: Oct 01, 2012
Subject: Re: Grounding blocks
I suppose that brass is a good all-rounder -- easy to solder, mechanically robust, reasonable conductor, fairly inexpensive -- whereas the others have their trade-offs, e.g. gold & silver being expensive, aluminium being difficult to join, copper being soft and work-hardening etc. Just a guess, but brass seems like a great compromise. On 1 October 2012 15:21, Eric Marenyi wrote: > > I am curious as to what a home made grounding block should be made of. > I realize that B and C makes theirs out of brass but I wonder why when > it seems there are other more easily obtained metals with better > conductivity, according to the charts on this site: > > http://metaldetectingworld.com/conductive_order_metals.shtml > > I have seen grounding blocks made of aluminum, copper, brass, etc. > What is the benefit of one over the other? > > -- > Eric M. > > ________________________________________________________________________________
Date: Oct 01, 2012
Subject: Renewing old data . . .
A few days ago there was some discussion about heated pitot tubes and some ideas about directly heated tubes as opposed to assemblies with embedded heating elements. I was trying to recall some things I explored in years past . . . a bit fuzzy so I went to the bench and did the following exploration. Emacs! Dug out my Weller 8400, a descendant of the very first soldering tool I ever purchased (from Burnstein-Applebee in KC for about $5). The snap-on ammeter showed just over 300 amps in the 'tip wire' while the trusty John Fluke multimeter gave me 250 millivolts as the potential delivered to the tip. The snap-on confirmed a 120VAC current draw of 1.2A or right at 140 watts power consumed. Measurement of the tip material confirmed that the cross-section was on a par with 10AWG wire . . . I used to make replacement tips from 10AWG scrap provided by a journeyman electrician up the street from my house. The experiment confirmed my recollection that soldering guns are horribly inefficient tools. The actual heating power delivered to the working tip is tiny compared to the total power consumed. My Metcal irons deliver a much greater proportion of their power to the tip . . . a 30W Metcal will install terminals on 2AWG wire! The Weller 8400 puts about .250 x 310 or 75 watts of total consumption into the tip wire . . . and that's spread all along the tip's length. Local heating at the tip plus conduction from behind the tip might put half the total heat to good use? In the case of a directly heated pitot tube, the feature that gives a soldering gun such poor marks turns out to be exactly what the DHPT needs . . . hot on every surface prone to collection of ice that would render IAS inoperable. Food for thought . . . Bob . . . ________________________________________________________________________________
Date: Oct 01, 2012
Your calculations look correct to me. What is the aircraft electrical load? It might be too small to show up on the ammeter. Turn on the landing light or other heavy load. The engine needs to be running for the following test. Measure the voltage drop across the shunt with a milli-voltmeter. With a 60amp shunt and a 10amp load, the voltage drop will be about 8mv. Then measure the voltage drop across the ammeter input. It should be the same as at the shunt. If there is a millivolt input signal to the ammeter but it still does not display, perhaps the ammeter needs to be calibrated. See Page 12-20 G3X Installation Manual - Engine Sensor Configuration Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=384385#384385 ________________________________________________________________________________
Date: Oct 01, 2012
At 09:38 AM 10/1/2012, you wrote: >I suppose that brass is a good all-rounder -- >easy to solder, mechanically robust, reasonable >conductor, fairly inexpensive -- whereas the >others have their trade-offs, e.g. gold & silver >being expensive, aluminium being difficult to >join, copper being soft and work-hardening etc. > >Just a guess, but brass seems like a great compromise. . . . correct . . . and further re-enforced by availability of parts/materials for fabrication. Don't know where one might get fast-on tabs fabricated from a "better" material. Yes, materials in the grounding tab ADDS to total loop resistance. But so to do the terminals, crimp joints, bolted joints, wire, plating on the wire, pin-to-pin interface, etc. etc. Research the "galloping ammeter" phenomenon common to older airplanes and discussed here on the list at length. Some owners of nice old 172's complained that a costly new master switch fixed the problem for only a short time. This is because the SUM TOTAL of all resistances in the regulator sense wiring between bus and regulator has increased over time. Replacing the switch dropped total loop resistance below the stability threshold . . . but steadily increasing resistance in the new switch or (more likely) other components drove the resistance up past the stability threshold. I've advised owner/operators to replace/renew ALL joints and components in that pathway to achieve the same resistance as delivered from the factory. Only then can one expect the repair to last as long as the as-new condition. The design goal is two-fold (1) keep total loop resistance so low as to be insignificant to system performance and (2) make sure is STAYS low by the fabrication of gas-tight or other fabrication techniques that keep moisture laden with corrosives out of the joints. Meeting these two goals with skill goes toward a more pleasurable, low cost-of-ownership experience with your airplane. Bob . . . ________________________________________________________________________________
Date: Oct 01, 2012
Does it help that brass is relatively soft and allows for some deformation at the point of contact with a fast-on? It seems like I remember reading that this was part of the gas-tight equation. I used the $1 terminal strips from Stein combined with a small piece of brass stock from the local hobby shop to make mine, so brass was very available. Are those sources available to you Eric, or are you somewhere far away? On Mon, Oct 1, 2012 at 11:33 AM, Robert L. Nuckolls, III wrote: > > > At 09:38 AM 10/1/2012, you wrote: >> >> I suppose that brass is a good all-rounder -- easy to solder, mechanically >> robust, reasonable conductor, fairly inexpensive -- whereas the others have >> their trade-offs, e.g. gold & silver being expensive, aluminium being >> difficult to join, copper being soft and work-hardening etc. >> >> Just a guess, but brass seems like a great compromise. > > > . . . correct . . . and further re-enforced by > availability of parts/materials for fabrication. > Don't know where one might get fast-on tabs fabricated > from a "better" material. > > Yes, materials in the grounding tab ADDS to total > loop resistance. But so to do the terminals, crimp joints, > bolted joints, wire, plating on the wire, pin-to-pin > interface, etc. etc. > > Research the "galloping ammeter" phenomenon common to > older airplanes and discussed here on the list at > length. Some owners of nice old 172's complained that > a costly new master switch fixed the problem for only > a short time. > > This is because the SUM TOTAL of all resistances in the > regulator sense wiring between bus and regulator has increased > over time. Replacing the switch dropped total loop resistance > below the stability threshold . . . but steadily increasing resistance > in the new switch or (more likely) other components drove > the resistance up past the stability threshold. I've > advised owner/operators to replace/renew ALL joints and components > in that pathway to achieve the same resistance as delivered > from the factory. Only then can one expect the repair to last > as long as the as-new condition. > > The design goal is two-fold (1) keep total loop resistance > so low as to be insignificant to system performance and > (2) make sure is STAYS low by the fabrication of gas-tight > or other fabrication techniques that keep moisture laden with > corrosives out of the joints. Meeting these two goals with > skill goes toward a more pleasurable, low cost-of-ownership > experience with your airplane. > > > Bob . . . > > ________________________________________________________________________________
Date: Oct 01, 2012
Subject: Thermocouple testing
A few weeks ago we had some discussion about troubleshooting a thermocouple temperature indicator system. I was curious about current offerings on eBay and elsewhere for K-type thermocouple readout devices useful as test tools. I ordered these two items for further study. A TM902C hand-held readout instrument powered by internal battery http://tinyurl.com/9v8w6d2 and a panel mounted 12vdc externally powered device http://tinyurl.com/8c3ngdq The second one was a disappointment. I was initially encouraged when I saw a diode mounted between two terminals on the back of the instrument adjacent to locations for the thermocouple wire . . . this was no doubt part of the cold-junction compensation. The critter was pretty close at 0C but off by 5-6 degrees at 100C. I opened it up and didn't find any calibration provisions. The TM902 was a pleasant surprise. Not only was it within one degree at 0C (stirred ice bath) it was equally close at 100C (boiling distilled water). Even better yet, a peek inside revealed not only an active cold-junction correction device but two calibration pots. Emacs! Bottom line is that this particular instrument is a great value as a test tool for in-flight temperature surveys, it's easily re-calibrated should this be necessary in the future. It comes with a K-type thermocouple about 3' long. Uses standard T/C connectors. The K-type wire is readily available from sources like eBay and Omega. The low cost and re-calibration convenience of this critter puts good temperature measurement and test capability in everybody's hands. Bob . . . ________________________________________________________________________________
From: "Roger & Jean Curtis" <mrspudandcompany(at)verizon.net>
Date: Oct 01, 2012
A TM902C hand-held readout instrument powered by internal battery http://tinyurl.com/9v8w6d2 Bob, Thanks for the tip. I have one on order. Roger ________________________________________________________________________________
Date: Oct 01, 2012
The G3X manual you refer to lists the calibration procedure for Hall effect sensor on page 12020. Cn this be used with the Shunt ? I suspect there is no calibration for the shunt. Thanks for the reference, I have to keep up on the manual revisions as they add new devices all the time. After initial test flights I will have to update the software as well. ----- Original Message ----- From: user9253 <fran4sew(at)banyanol.com> Subject: AeroElectric-List: Re: Compatable Shunt Your calculations look correct to me. What is the aircraft electrical load? It might be too small to show up on the ammeter. Turn on the landing light or other heavy load. The engine needs to be running for the following test. Measure the voltage drop across the shunt with a milli-voltmeter. With a 60amp shunt and a 10amp load, the voltage drop will be about 8mv. Then measure the voltage drop across the ammeter input. It should be the same as at the shunt. If there is a millivolt input signal to the ammeter but it still does not display, perhaps the ammeter needs to be calibrated. See Page 12-20 G3X Installation Manual - Engine Sensor Configuration Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=384385#384385 ________________________________________________________________________________
Date: Oct 01, 2012
again thanks for the pointers so I can proceed with some confidence. ----- Original Message ----- From: Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> Subject: Re: AeroElectric-List: Compatable Shunt > The shunt sent to me by the Avionics shop for use with the Garmin > is 100 amp/50mv and the one B & C supplied and installed in the > plane is 60 amp at 50mv. My confusion and question concerns the > schematic from Garmin that says the shunt is rated at 0.0005 > Ohm. The B & C supplied system with its shunt is 50mv/60 amp gives > me 0.00083 Ohm. > >First are my calculations correct and second does this have any >bearing on the inability to display the ammeter reading ? If the >above is not contributing to the problem should I look elsewhere in >the system for the problem ? (Prior to turning on the field of the >60 amp alternator I get the main volts waring light flashing and >goes off after the field is activated. Remainder of G3X works fine) The size of the shunt is relative only to calibration of the display. If you have no display, then the problem is not with the shunt. If the display is present but inaccurate, THEN you probably have a shunt problem. A shut is just a high power resistor . . . abeit a special resistor manufactured from amazium alloy with a near zero temperature coefficient of resistance. The material is actually Manganin. http://tinyurl.com/3f79fgy When your current display is a LOADMETER calibrated in 0-100%, then the shunt is sized to what ever that 100% value is . . . in case of the 60A alternator, you would use a 60A shunt. If it were a 100A alternator, then a 100A shunt. Interestingly enough, using a 100A shunt in ALL installations converts the 0-100% display to a 0-100A display. I suspect that the 100A shunt recommended by the avionics shop is based on some knowledge that the EFIS calls 50mv drop 100Amps and that size shunt will read ANY practical current up to 100A accurately. Substitution of a 60A shunt would simply mean that your 100A display was really a 100% display. Looking past calibration issues, if your display is non-reading, the difficulty lies elsewhere. Bob . . . ________________________________________________________________________________
Date: Oct 01, 2012
At 09:43 PM 10/1/2012, you wrote: > >The G3X manual you refer to lists the calibration procedure for Hall >effect sensor on page 12020. Cn this be used with the Shunt ? I >suspect there is no calibration for the shunt. >Thanks for the reference, I have to keep up on the manual revisions >as they add new devices all the time. After initial test flights I >will have to update the software as well. I downloaded the g3x manual. A search of the book cites 82 instances of the word "shunt" where the expected device is a 50mv/100A device. There are also 8 instances of Hall Effect where it appears you can use AmpLoc KEY100 style sensors. Paragraph 8.3 speaks to the use of either. I was unable to find any schematic references to hall devices. They have 3 wire connections and need a source of clean power. Also, hall effect sensors are noted for their variability in both offset and scale factor . . . they require individual calibration for accuracy. Shunts are precision, two wire devices that are very predictable. Suggest you stay with the 100A shunt. Bob . . . ________________________________________________________________________________
Date: Oct 02, 2012
> The G3X manual you refer to lists the calibration procedure for Hall effect sensor on page 12020. Cn this be used with the Shunt ? I suspect there is no calibration for the shunt. I do not know if the calibration procedure is for only Hall Effect sensors or for both Hall Effect and Shunts. The manual is not clear on this point. You could ask Garmin support. If there is no calibration procedure for shunts, then only a +/-50mV, 100amp shunt can be used, if you want the display to be accurate. Easier than calling Garmin would be to try calibrating per page 12-20. What do you have to lose except a little time? If it doesn't work, you can reset the parameters back to default. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=384452#384452 ________________________________________________________________________________
Date: Oct 02, 2012
At 05:52 AM 10/2/2012, you wrote: > > > > The G3X manual you refer to lists the calibration procedure for > Hall effect sensor on page 12020. Cn this be used with the Shunt ? > I suspect there is no calibration for the shunt. > >I do not know if the calibration procedure is for only Hall Effect >sensors or for both Hall Effect and Shunts. The manual is not clear >on this point. You could ask Garmin support. If there is no >calibration procedure for shunts, then only a +/-50mV, 100amp shunt >can be used, if you want the display to be accurate. In a customer's airplane, cutting wires and splicing back requires different levels of inspection than simply Pushing the pin out of a connector to route a wire through the hall device. The AMPLOC hall sensors are really handy. I've used them many times especially when I needed to measure current in a wire for which I was discouraged from doing damage. Over the years, I developed some tools that offered a quick-n-dirty access to current-in-the-wire . . . http://tinyurl.com/8n6fo2n http://tinyurl.com/8zqqetc The KEY series AMPLOC devices http://tinyurl.com/8gtrsru Are more user friendly for getting electrons-per-second counted in fat wires. They do have the disadvantage of needing power to operate . . . and it must be well regulated since the output is ratiometric to the supply voltage. They are bi-directional devices . . . meaning that zero amps is some value close to 1/2 that of the applied power. Hence the need for a wide range of offset programming to move from shunts (zero volts at zero amps) to hall effect sensors (some volts at zero amps). http://tinyurl.com/8suspug I suspect that the Garmin display value for AMPS is derived from analog data which is then massaged for offset and scale factor. Given the extensive references for 50mv/100A shunts for both wiring and discussion of AMPS sensing, I'd bet that the default programming assumes a 50mv/100A shunt. The resolution of their a/d system would allow the 100A shunt to be used virtually anywhere . . . even in series with an SD-8, without adjustment to default offset and scale factors. I don't recall if the subject problem was "no reading" or inaccurate reading. Of course, no reading could be either wiring error . . . or there's no actual current flowing to be measured and displayed. Inaccurate reading could be due to 60A shunt being used without re-calibration for the higher scale-factor value. A more detailed study of symptoms and conditions is called for. I suspect that either of the shunts in hand will do the job . . . just need to learn the correct incantation and wave of the wand to get the hardware's attention. Bob . . . ________________________________________________________________________________
Date: Oct 02, 2012
Hello Bob, Got the book, good job, I'm really enjoying it. Quick question, how do I un-suscribe from the forum??? I get about 30 email s an hour! hard to keep up with it. Thanks Regards Walter -----Original Message----- From: Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> Sent: Mon, Oct 1, 2012 9:54 pm Subject: Re: AeroElectric-List: Re: Compatable Shunt At 09:43 PM 10/1/2012, you wrote: > >The G3X manual you refer to lists the calibration procedure for Hall >effect sensor on page 12020. Cn this be used with the Shunt ? I >suspect there is no calibration for the shunt. >Thanks for the reference, I have to keep up on the manual revisions >as they add new devices all the time. After initial test flights I >will have to update the software as well. I downloaded the g3x manual. A search of the book cites 82 instances of the word "shunt" where the expected device is a 50mv/100A device. There are also 8 instances of Hall Effect where it appears you can use AmpLoc KEY100 style sensors. Paragraph 8.3 speaks to the use of either. I was unable to find any schematic references to hall devices. They have 3 wire connections and need a source of clean power. Also, hall effect sensors are noted for their variability in both offset and scale factor . . . they require individual calibration for accuracy. Shunts are precision, two wire devices that are very predictable. Suggest you stay with the 100A shunt. Bob . . . ________________________________________________________________________________
Date: Oct 02, 2012
> Of course, no reading could be > either wiring error . . . or there's no actual current > flowing to be measured and displayed. It is too bad that we are so far from the aircraft. It would be fun to do some troubleshooting in person. The original posting said that there was zero amperage displayed. And he said that the 60amp shunt was installed. If anything, the 60 amp shunt should read higher current than a 100amp shunt. It would be helpful to know the millivolts across the shunt compared to the millivolts at the input to the G3X. If those voltages are equal and above zero and there is no amperage displayed, then the problem is the G3X, perhaps a software setup problem. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=384503#384503 ________________________________________________________________________________
Date: Oct 02, 2012
With the 80 pin (read delicate) connector I am reluctant to pull it. The information I have from Garmin implies that the G3X will not read unless it has 5 milliohm resister (rather than 8.3) Job one is to test fly with voltmeter. andswap out the shunt in the next few weeks. will recheck wiring tomorrow ----- Original Message ----- From: user9253 <fran4sew(at)banyanol.com> Subject: AeroElectric-List: Re: Compatable Shunt > Of course, no reading could be > either wiring error . . . or there's no actual current > flowing to be measured and displayed. It is too bad that we are so far from the aircraft. It would be fun to do some troubleshooting in person. The original posting said that there was zero amperage displayed. And he said that the 60amp shunt was installed. If anything, the 60 amp shunt should read higher current than a 100amp shunt. It would be helpful to know the millivolts across the shunt compared to the millivolts at the input to the G3X. If those voltages are equal and above zero and there is no amperage displayed, then the problem is the G3X, perhaps a software setup problem. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=384503#384503 ________________________________________________________________________________
Date: Oct 02, 2012
The readout has a red "X" through it meaning inoperable, no scale is displayed ----- Original Message ----- From: user9253 <fran4sew(at)banyanol.com> Subject: AeroElectric-List: Re: Compatable Shunt > Of course, no reading could be > either wiring error . . . or there's no actual current > flowing to be measured and displayed. It is too bad that we are so far from the aircraft. It would be fun to do some troubleshooting in person. The original posting said that there was zero amperage displayed. And he said that the 60amp shunt was installed. If anything, the 60 amp shunt should read higher current than a 100amp shunt. It would be helpful to know the millivolts across the shunt compared to the millivolts at the input to the G3X. If those voltages are equal and above zero and there is no amperage displayed, then the problem is the G3X, perhaps a software setup problem. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=384503#384503 ________________________________________________________________________________
Date: Oct 02, 2012
At 02:36 PM 10/2/2012, you wrote: >Hello Bob, > >Got the book, good job, I'm really enjoying it. > >Quick question, how do I un-suscribe from the forum??? I get about >30 emails an hour! hard to keep up with it. > >Thanks > >Regards > >Walter 30 an hour? I don't think I get 30 a day. In any case, they're very easy to delete if the topic is uninteresting to you. I have submitted an un-subscription request. When it arrives in your email, click on the link within the e-mail to confirm your request. Bob . . . ________________________________________________________________________________
Date: Oct 03, 2012
Walter, If you are really enjoying it, then don't unsubscribe. Rather, change your setting to receive a daily digest rather than individual e-mail messages. That way you will receive only one message per day. Eric cwjazun(at)aol.com wrote: > Hello Bob, > > Got the book, good job, I'm really enjoying it. > > Quick question, how do I un-suscribe from the forum??? I get about 30 emails an hour! hard to keep up with it. > > Thanks > > Regards > > Walter > > > > > > > -- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=384551#384551 ________________________________________________________________________________
Date: Oct 03, 2012
At 09:05 PM 10/2/2012, you wrote: With the 80 pin (read delicate) connector I am reluctant to pull it. The information I have from Garmin implies that the G3X will not read unless it has 5 milliohm resister (rather than 8.3) Job one is to test fly with voltmeter. andswap out the shunt in the next few weeks. will recheck wiring tomorrow The readout has a red "X" through it meaning inoperable, no scale is displayed Aha! Then the difficulty is not with the size of the shunt. Shunt size has only to do with scale factor . . . calibration. Substitution of a 60A vs. 100A shunt without re-calibrating the instrument means only that readings displayed will be 1.66 times higher than true. The fact that your display does not show a numerical value suggests that something in the software has detected an error in wiring or in setup. The instrument has no way to deduce shunt size, only that a shunt appears to be present. This strongly suggests a wiring problem. You can leave the 60A shunt in place and re-calibrate per instructions . . . or swap out for the 100A shunt where the instrument will probably read correctly . . . AFTER the big red X goes away. Bob . . . ________________________________________________________________________________
Subject: Adding a cell phone interface to Garmin 340
Date: Oct 03, 2012
Hello electron herder experts Has anyone wired an external cell phone interface to a Garmin GMA340? I would like to use a 3.5mm jack and cord. Would it work to wire it as Com 3? Any suggestions are appreciated Thanks -Rob Henderson ________________________________________________________________________________
Date: Oct 03, 2012
SUPRISE Bob A fellow EAA'r came out and we easily swapped out the 50mc 60amp shunt for the Garmin provided 50mv/100amp shunt and connected the wires back up as they were previously. Turned on master switch and the Garmin screens came up. Went to engine page on MFD screen and would you believe that the red "X" was gone and it was reading amp draw. Later I will do same for EBus shunt. It appears with Garmin its their way or the highway. You would think it would read with just any old shunt in there, but as I was advised by Tim Larberg at Garmin, that is not the case. ----- Original Message ----- From: Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> Subject: Re: AeroElectric-List: Re: Compatable Shunt At 09:05 PM 10/2/2012, you wrote: With the 80 pin (read delicate) connector I am reluctant to pull it. The information I have from Garmin implies that the G3X will not read unless it has 5 milliohm resister (rather than 8.3) Job one is to test fly with voltmeter. andswap out the shunt in the next few weeks. will recheck wiring tomorrow The readout has a red "X" through it meaning inoperable, no scale is displayed Aha! Then the difficulty is not with the size of the shunt. Shunt size has only to do with scale factor . . . calibration. Substitution of a 60A vs. 100A shunt without re-calibrating the instrument means only that readings displayed will be 1.66 times higher than true. The fact that your display does not show a numerical value suggests that something in the software has detected an error in wiring or in setup. The instrument has no way to deduce shunt size, only that a shunt appears to be present. This strongly suggests a wiring problem. You can leave the 60A shunt in place and re-calibrate per instructions . . . or swap out for the 100A shunt where the instrument will probably read correctly . . . AFTER the big red X goes away. Bob . . . ________________________________________________________________________________
Date: Oct 03, 2012
At 05:35 PM 10/3/2012, you wrote: SUPRISE Bob A fellow EAA'r came out and we easily swapped out the 50mc 60amp shunt for the Garmin provided 50mv/100amp shunt and connected the wires back up as they were previously. Turned on master switch and the Garmin screens came up. Went to engine page on MFD screen and would you believe that the red "X" was gone and it was reading amp draw. Later I will do same for EBus shunt. It appears with Garmin its their way or the highway. You would think it would read with just any old shunt in there, but as I was advised by Tim Larberg at Garmin, that is not the case. That's more than a surprise, it's a mind bender . . . I would REALLY like to understand the intelligence built into the system for making that determination. Low resistance measurements are not easy to do even when you can attach 4-wires directly to the shunt . . . http://tinyurl.com/4l3tuj6 . . . looking at a .0005 ohm resistor on the end of lead wires several feet long having a resistance of 0.010 to 0.015 ohms PER foot is magic. I may have occasion to enjoy some face-time with a Garmin techno-wienie next summer. I'll put this on my list of questions to ask. In any case, I'm delighted that your problem has been resolved . . . even if we don't understand just how it all came to pass. Must be pixie dust. Bob . . . ________________________________________________________________________________
Date: Oct 03, 2012
> >It appears with Garmin its their way or the highway. You would >think it would read with just any old shunt in there, but as I was >advised by Tim Larberg at Garmin, that is not the case. Do you have a phone number for Mr. Larberg. I'd like to talk to him. Bob . . . ________________________________________________________________________________
Date: Oct 03, 2012
Hope this is not a serious discussion. Garmin has their own way of setting up the software and when I install the next shunt for the auxillary alternator, if the red "X" is gone then I will be two for two. Tim Larberg 1-888- 606-5482 press 3 for the first phone prompt and then press 3 for the second phone prompt (G series glass panels) ----- Original Message ----- From: Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> Subject: Re: AeroElectric-List: Re: Compatable Shunt > >It appears with Garmin its their way or the highway. You would >think it would read with just any old shunt in there, but as I was >advised by Tim Larberg at Garmin, that is not the case. Do you have a phone number for Mr. Larberg. I'd like to talk to him. Bob . . . ________________________________________________________________________________
Date: Oct 03, 2012
At 10:04 PM 10/3/2012, you wrote: > >Hope this is not a serious discussion. Garmin has their own way of >setting up the software and when I install the next shunt for the >auxillary alternator, if the red "X" is gone then I will be two for >two. Tim Larberg 1-888- 606-5482 press 3 for the first phone >prompt and then press 3 for the second phone prompt (G series glass panels) Nothing tense. Just one techno wienie talking to another one. It behooves suppliers of any product to spread the knowledge around. Cuts down on calls to field service. An amazed and inquiring mind just wants to know . . . Bob . . . ________________________________________________________________________________
Date: Oct 04, 2012
Subject: Fwd: Craig's List Ad
/9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAMCAgICAgMCAgIDAwMDBAYEBAQEBAgGBgUGCQgK CgkICQkKDA8MCgsOCwkJDRENDg8QEBEQCgwSExIQEw8QEBD/2wBDAQMDAwQDBAgEBAgQCwkL EBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBD/wAAR CAHGAlwDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAA AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkK FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWG h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl 5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREA AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYk NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOE hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk 5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD9U6Q9DS01skYAoAytZtbZba41JreNri3t pdjMOcbTXy38LfgleeMdT0TxFJqdumg6RrtxqM9iqMskk4OUZW7BWxxxwD619N+L59RtfDmo z6ZYw3k6W0mIpZfLBXac/Ng15r+ztrYh8IWdhqFo1q+pXlybVgdyzbclj7d/yqH8RrRqSpqT iezRgqAD/Kn/AMX4UgIBwB04p2asxbd7sKKKKBhRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUU AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABX y98CPj14i8efDjT/ABJqLP59wzBsn2H+NfUNfDX7K6qPg1pICj7zdvZaAPuTIHegkY61QTTj BFKLe6nR5eQxffs+maf5F3HbFI7rfMB8skq8E+4GKAM7xkFbwlq6mdoR9il+cEZX5TXx5JL4 hl8LeHms/ENxaxBJpbVYJWjkguA7DnB53elfUnxamu7P4Z67Ncx29wq2EjTks0Yxjt1r5w8D eAvF3i/wP4b8aeFrCG9jihkiuLJ7kRzMwkIyqsNnQjnNZzu9EFPWVj6Q+EN/4n1Pwba3niq7 e4vWGTO8YTenbp1+td0CcHmuP+Hmnalo/hixsdUSS2uSpZ7aZlZohn7gKkjH412A+7inG60Z c1Z2QoJz0paKKsgKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACikJA60hcCgP IdRTSwAyRRvHpRcB1FICMZNLntQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABX w3+yv/yRrSf95v5LX3JXw3+yv/yRrSf95v5LQB9x4HpSP0GRTqQ4I5oA4L44IzfCjxMiIWLW DKFXqa5T9l3S7dPg3o8VxAVkilmCk9V+fIGfwrsvjI2PhnrzZ24tTz+Irlf2dbTULTwLp8r3 Ctp8sblINvzRzeYdzbs8hgRxjjFZ/aLjH3XI9cEMe4P5YLf3jUgz3oAIGBQM960M9RaKKKBh RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUU UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABSHpQTihiMYJ7UAMfG3APtxXzh+1d+0Jq Hwws7Twr4OvootavlMlxP99raHtx6tXfftAfE4fC7wG+p20rx3uoTrZWb+WXVXIJLH0+UH8c V8dfB/wGP2i/jLdr4xiu9Q0WygaW9kWfYxH8Cs2Q/Jz0rCpK8uRHVRpQt7SpsYnhr9rf4veE rpZovE8moWwdneG/XzFbcfz/AFr6D+Hv7eXhXVnSy8e6JJpku3AurZvMib329RXM/ED/AIJ1 WU5n1H4YeP7rT5mMki2Gpp50JP8AyzjVxyir6kMa+aPH/wCz78cPhbJLN4q8GXNzYx8DUNOb z4CPVtvI59cUvY1I/wANnW6OGraU2fqZ4W8c+EvGlmuoeFvEFnqELgNiKUM49ivUVv71U8j8 K/Gbwv491vw5qCT6Brl1p1zA+WKO0bK6+o/pX0r8Pv27vHnh1Y7HxdYwa/bKQglc+VLjH94A j8waXtZU3aaOargqkPhP0GDZOCKXPGcV5J8Nv2m/hL8TVittK8QCxv5Bj7FfDyXJx/CT8rfg a9YSRGjDq+5ccMDnNawqRnscjTW5JRTd65xS5FaCFooooAKKKKACiiigAooooAKKKKACiiig Ar4b/ZX/AOSNaT/vN/Ja+5K+G/2V/wDkjWk/7zfyWgD7kpD0paKAOE+NoJ+FviEbiv8Ao3b6 isr9nlluPhVpLiPbtMnGP9rrWp8b5Wi+FniGRV3Ytf6isz9nUl/hRpBIx/rP/QzWaVpGy/gs 9OyTg0tIOlLWhh0CiiigYUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUU UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAh7fWgjNB7fW g4IwaAPi7/gol4k1XSk8D6PbTlbS9a+nmjHRpIxGFb8nb86t/wDBPnRNPnsPFfiyWJ/7Sa4j sjIzcCILnbj61h/8FKFVZvh7c5PyPfrgfSL/AArov+CeGotd+G/GETvuMWoQkgDGMpWVv3h2 t/7NY+vdp4BHamywrIhSRFZWGCCMj8qlAHNIVHUVrdnEtNjxz4kfsrfBX4nRzPrfhC3tb2TP +mWC+RMCTlm+Xgk+pFfMHxG/4J6+MdFje6+FviuPVIg3FjqI8uULnosnTgV+gKDByWzn2pjp g8n9KHaXxq5008XVp9bn49+J/CPxC+HVw8Pjjwdq+hSQqGjn8ktC2Tj/AFi8djXoHwx/ah+J vgJY49K8TvqWnoBm2uX82PGPfla/TrUNI07V7Z7PVrCC7t5BhoriJXUj6GvB/iF+xB8C/HFy 1/ZaLdeGtQJ4uNHkES5x3jIKfpmspUIS+H3TqWKoVtKkTF+G37cXgzxJJFp/jfTJdDuJW2rP GfMgPpu7rX0npup2Or2EOpaZdx3NrcqJIpozlWX2r8pf2kvg34n/AGYtT0mC+16LxHpmrozR Xa2xglRoycqwyV6Ed/WvtD9g7x1L4z+DCW0rDGlXbRRDdl9jc/N+JP5VMeanLlkc+Ioxh78N j6YGcClpB0pa3OQKKKKACiiigAooooAKKKKACiiigAr4b/ZX/wCSNaT/ALzfyWvuSvhv9lf/ AJI1pP8AvN/JaAPuSiikJwM0Aef/AByZI/hXrxkPDW4X9RWf+zjsHwn0oJnAeXqOfvGk/aOu jbfCjU3UZ3vGuAcfxU79nEhvhRpjDu8vH/AjUfbNL/u7HqA4GKKRuhpkT7lyfWrMuhJRRmig YUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAh7fWggkcGlxmkJJBA+lAHw//wAFLXCR eAjj/lpfdPpHWt/wTiiCeHvGsxX/AFuoW5/8h1h/8FL3APw/QnrJfH9I66v/AIJ1Wpi8A+Ir s8+dqCc/RK5pztVikdk/93R9dilpB0zS10nGIAB0FGB6UZz0NAJPWgA4FGAeTUbyBFLyFQvr TI5454hJDIjo/wB1lbII+tAeZ8V/8FQY2l+G3heMKu06ueSOceWayf8AglzeSNofi7T2yFhe 3fH13Vtf8FPHcfDvwtErcvq5/wDRZrF/4JjILSHxhbTOiyTJbSJHn5tvzc1VW1onp1/9zgv6 3PvEe1LSZwopAxPWpPMHUUhOByRQCe9AC0UUUAFFFFABRRRQAUUUUAFfDf7K/wDyRrSf95v5 LX3JXw3+yv8A8ka0n/eb+S0AfclNbHAJpi8ZwfpXM3eva0njSz8N22nxtYNaPc3NyZBuU7sK oXOfxqJSUbXA4/8AadcJ8KL0E/fuYV/8eq1+zn5i/CjSllQKQ8oAB/2jWV+1VL5Pwju5F523 kH/oVbH7PKKPhVpLIc7zIxP/AAI0k1zFL4Gem9uKg3COUD+F+g96mJIGM1DPG7x5UfOh3LWh HQnAI4paZExdd59OafnPSgYUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRRSbhnFAC0Um4UbhQAtFJuFG4UALRSbhRuFAC0Um4UbhQAtFJuFG4UALRSbhRu FAC0Um4UgJPJz+VADqKTI6Zoz2zQAtFITjrRketAAc9qT6etKCD0pCQRwaBPY+C/+Cl90G1n wLZg/ciupPzKj+lejf8ABO+Nh8JtTkI+/qR5P0ryP/gplcbPG/g2IdPsEjf+RK9m/wCCeR3/ AANlnH8epy/0rmqRvVizrqO1GKPqUHI60Y96Og60HkYFdFzlEAHY0nHUA1S1IzixnS3n8iRo nCSbd2w4OGx3xX5u6r+258fPA/jS9srrxBbava2U01ukN3YJGkwViPMygDdvWm/dXMbUsPOq rxPuH9orx0nw7+DXibxH9qihuBZvBbGTJVppBtVRjnv2r4A+Bf7avi/4QTxafr7S674eZGMl i8uZY3PIaN26c/w15l8Y/wBoL4mfGrVHv/GOtsbMFWh063YpaW+M7cJ3bk8nJ965uw8N+Cbz 4ba14s1vx2tn4hsrlLbT9C+zGVr5Gx+88zPyKvPbtWLm5O51woRhT5JHtP7Vv7Xfh79oTw/o ulaX4Su9Lk0m8a8Z7mYOrDbj+Ee9ebfs9/H/AFH4JfEO08ZQKbmzOIL+0STAlgPUD3HDfUCv GZRK4Yh/mXrVGS4MfyLJ8zrzx3pSvLc1kuelGlLZH62+I/8AgoN8CrXwDd+JPD+sXNxqzBor TTJIGWYyEcMewX3z2rmv2Sv2zPE3xo8ap8O/EOk28rrazT/2jE2JGZeQGXp04r8tzM7x5Z/l HHStPwp428TeDNYTWPC+v3ekX0aNFFdWchjkj3dfmXms25J3ucsqC5bI/b/4n/GnwD8IV0v/ AITrV/sv9sXS21sqrubJ/ib0UdzXVeHPE2h+L9Jh1vw1qkOoWE+4RXELbkYqcECvw88f/GP4 qfEuaxuviF4kvtX/ALPgFtaNcLgbPXj7zf7R5r6m/Zr/AG//AAx8F/hxpXw98XeCdRubbT0l ZNQs5lZmlZydpQ4+XB+9n8K25rbkVKHLFJH6aggjIPajOOpr4K+CX7dnj/42ftE6N4Sg06x0 jwteiWMWir5kr4BKsznnd9MCvvIMWGR2p06inexzyi4uzJKKQH3pa0EFFFFABRRRQAV8N/sr /wDJGtJ/3m/ktfclfDf7K/8AyRrSf95v5LQB9uypJ5bGIrvwdoNeCePPGni238arplnapaXk mnyWSzRMrxW0jsD5s0h+4AvOD3xjrXuOopcyWMq2YBn2fIGcp83uRXx74y8Ty6F4gin8eT6f pc8Vzc+e95AvmvEQWVizBgwyo24Xqa83Hz9nBF04xbOv+PmvX2rfDmbRbW/imttDFnHeMJQz 3E7cYI9B1zXqX7OGF+Eujhc4Uyjn/fNfKFnDe33wi1vxL4mt9MTVNWv4XsS+1rx4s9Qw5VNv bp6Yr6u/ZsGfhJpCsP4pcZ/3jTwVX2q5pG048tPQ9SwDyRQQCMY9qDnsaUdK9E5iNE2fKo+W njjgUpOOTSDHUUALRRRQAUUUUAFJketBPHIqFJo3kZEmXcv3kyCVpNpAT0Um4dM0ZHrTAWik yAM5pAx9aAHUU0tgdRQpz3oAdRTSeehpRk9TSugFoOe1IMA9aMg85pgBIxwaQMD39q8e/aX+ Ifjj4X+BbTxn4NWx8m01SBdXa6Qvss2JB2LkZYttH0zXpOj69Yaro2na0lyiQ6lBFND5h27t 6ggAHvQOztc2qKahJHJp1AgoopMj1oAWmY5zTsj1ptABRRRQAUUUUAFFFFABRRRQAUUUUXQB RRRQAUjYxkHBz1zS1zPxC1/VvC3grWvEOg6S+p6hp9pJPb2i9ZWAyKAS5nYbrfxF8E+HfEml +E9c8S2VlrGshjY2skm15selas2t6RBqtvolxq1pHqN2jSwWrTqJZUH3mVepAr8WviZ8RvF/ j/xjdeNfEOo3J1l5iyliQYsfwAfwBfSueh8e+O7fWLPxXaeLdXlv7IbILlrp2mt06lFJOVU8 1g5STudbwkkj90/tVtkqLqLK8Ebxwf6VT1PxDoei2j32ra3ZWdugy0s9wiqB9Sa/FbUfGHjA QpqzeJ7uV74NLIyXDFt3/TTn71c1eeI/FOpRNLc+Ib+RE52PcuUP5mhVJMPqkj9sY/i58LpT ti+Ivhxj1IGpxf40k/xe+FdtGzS/Ebw6ijqf7QiP9a/DeTWdQBybqQdyQ1Ik95cL5kVyevPz U+aQ/qbS3PsX/gop8RfBvjTxh4Wm8IeJLHVUtrOSOZrclvLbfkHd0roP2RP2sfhr8F/hZJ4c 8Yx6rJdy6hJIv2SDzEXgcZJAFfCM87jCzAybGyfmpR4316PRbzwjHqEiaSblb2W2UhRJOBhW J6nAqF7z5jSdG8VFn6taj/wUP+BkdjFNpV1c3VyxxJbzL5Rj/wB4jIqbRf8AgoH8FLq1nbWJ 57OSI5VIv3odfXPFfj3FezSyOS/33yxq/HftG2WI20nGpbSRKw8Gz9SfGn7f3hPUgdK8AyNH O5xHJLbmR25/hX3FfGvxFn0/xd4j1C+g1WRbwNult5bUxNHuJPc+/avEL/X7bTbCGeEzPqBw xJbEcSg/Lxjn1qnN448WahcC98wu67SX+9vC/WsUqr3Z10lGkrRPQbjTbWSCSW1nu5HRlgYv bERo5/vNXMavbTWjtDcRstxC2xgwxgeo9qr6Z4ik1u1uleNrO5D+ZLFAxRblcfe/3lq9Nrmn +JSmiXE0iXgRVs7q5OGuPWNj/e9GrT3o/ENyjLc52e6dSCshU5xWfPdM8vy7vTirGt+RY3Ut u8MkJTC+U/31etXwV8N/EfjG886S3lstOVh5s0ylSf8AdrRu2pFpbEvhDw3Jr8/2qbcLOFvf 567caVpVs5EGnQA7TnK9a3ZE8L+HobXR4L2ONidsUK9/fiobuykjEiuM8fJXPzOT1NuRJHl/ jHVp7q/i0yx/1cZ27U/vk10On+FtJ02zjudULXEypvlSRvk+lcp400vUtE1sanBayPA7LLGy rlVauhm17SfFOhy20N/5d00W0xyNtYv7V0epg78xJ8NPH3jrwP8AEe18X+BLKGK+0mbzIkIB Qx5+6x9xX33/AMPNm0vT9OOtfCG4a8uikEqQ6iu5pDwzIuPu596/Nvwf4r/4Ru7urLW45YVl XCSNGefQZr0n4I6z4Q1z9ovwPN4ukFx4f/tGFdp+6Tu43Z7butZrmjL3TCrST99n7aeG9XbX tA03W3s5LR9QtYrn7PKPnh3qDtPuM1rjjimRBAgMZG3A27em3tinr06967E7o4OotFFFABRR RQAV8N/sr/8AJGtJ/wB5v5LX3JXw3+yv/wAka0n/AHm/ktAHvWufGSy8R2Fzp/grUng8R20E sg0S/RYJJdvVWLcDA56jNfJ/xF8Q6Xq9vY6vqDTT6ta3oe80+9kE6vCOqrKM/u+Tx9au/Fjx F4n06+tI/H93oU1xpFusNpdaXOol1NRwjGTB57leOtfOXjvW57m8a8tnne7urhRdwxy5wncr jpXyOPxVWpJRRrTSlL3T3h9R8Jal4Pub7Qzdz30pjZioAtYATztYflt9q+p/2fPFc2oeAdL8 MaFAUvbdXaa4njPk7d3IQ9zyK/PbR4Z9O8FmKOC3muzeI5aK4JkWLH3cZ9evy/jX1D+zR8X/ ABOpg0CO0uEsYLkIxWNRCNykBpDjJ/PsK0wWKlSlGm/wNpxufb0W8IolIL4G7396lHtUEEiu gIdXwBkr0+tSB89K+oT0RyDm5GKiicEMg/hbFSFgegzVWWZLd0mkbart5Z+vanzIPMuUUwHJ xn2pQwAovYB1FJu56UFgO9ADJOhx/OvmS9+IfxC8P/FnWr3TPDOpXWmT3EcMizRlFWMYUuPR Ovzd+cV9O7gfyrjvihpmm6v4M1GPUr6a1hhiMhkhYK25RlRk9ee1c+Ip+0V+xL0VzgviP8d7 jwh4z03RLCOCWxMYudQdULv5e3OEPTHI5rVuv2kPhZo/hFPF/izxLBocE25Ut7qVfOYj+6oO a+YdE8c2dw0ej+Lo7ZrOC1ulh1GJQt5DJg7F467unPY18RfGXS/iFqXjuW6vre91O2jk8yxc BniSLOVXHT/eHrmvNw+LlUrav3SaEvaTtI/SOb/goN4D1u6u9O+F3gbxP41ntIzJKNMsnkMS j+ORQMhfevNL7/goj8UL3whfeN/DvwVY6FZTtbS37SkrC47OvUYr5MtvF3xX0C4034m6Rb2/ w9uLJltJNU06M2f2rgHy5Igf3g4BIxg1hJb+LPHdxrut+EtX8R6pLqkrza9NBD5Fp5rnLNIA du0n2r0Pac0dGd8aKTuz6u8U/tv/ALWfhvwXpHj/AFT4Z6dZ+HvEZ2aZflPMWQ9cHB+UkdN2 M4OOlZ3jP9qH9sbw9q/hfQvFGhaf4cu/GLRrpTzXUbCRWIAZwpPljkfe59q+bNW8N/FjTdL0 Lwhe+DPGN94c0+UXZsEupJ7K5yeTCFGIyeefevQfh3+y38ffihaat4p0z4WRf2deRm206PWr yWKWwP8Afg3NklenPFbwwyl7z/Mqb5d0j1O0/aA/aYsPHniTwT4k+NXhqxtfDVu9zqGsQqLm ANj5YYRwZGycduhrQ+FPxr/bO+LetWegeHPEGnzPcK089wYtiWcQOFeTj5d3ULzWT8K/2Avi LJr2kr8VfBFvHpKkwX4sdRHmup484tuOWHXAGOMYr79+GXwj8A/CHQhoHgPQotPgYKZ5vvTX LKMBpHPLGl7BRldsh1IRj3ZofD3TPG2leHIbDx/4gttZ1ZD891b2/kqw+mTXUDGKRCMdaUnH Q1p6HK9Tyv8Aac03TdR+BHi8anafaYbTTnu0jHUyRncv6gV86/CT4o3nx4+L3wz0XSLm5tdJ 8H6F/aF7HES8MtyE2bJOBtI7fSvsTxTpo1nw1qukm3S5N3ZTQiKQfK5ZCAPzr4s/4J76NHov jPxpZTTRwaxaO0GpWbAtsRXITYenXOfwqX8R0U0nSl5H3avK5xS01OlOq7o5xG6U2nN0ptAB RRRQAUUHjrR7UAFFAOelGR0zQAUUHBGB3rndR8d+DdJuWs9U8TadbTKrO8bzqCqqQPzyRQB0 VFcBqPx0+EulSmG88daYJMjIWXdj8q15fiJ4Ht9In11vFGnPZW0TTyyLcK2Exnp1qPaRTFzR OozRXzLeft2/C9NQktrDTr++tkcKJ0woZfXBqhdft2eFEVxZ+FruWTzQI90gVWi/vfWo9tTv qLnWx9U0dK+PJ/8AgoBYW95dK/ghmtlUeR/pHzb/APa4ri/Ev7dPxAu9Uj1HRbCHSrKJebRo xKsv+0zn+mKXt4hc+9SAOBXkH7Rf7Qvhb4AeEH1TU50udZvEZNN0/PzzP/eYf3RXyxP/AMFA viLZOmp3mnaObKBw08caENIuPuryeTXyL8S/if4u+Lni288a+ONRN3eXTHyowcR28WflijX+ EKOtT7Tm+E6MNSdSXNIxvGHjG+8YeJdS8UatbW9rc6tdSXLpEvlpubsq1y0t0bed5Ibn5D8s 6q3K1D4puHxDLHMy/Z/n246/54qpPqyyWUb2Vmu12xMY1+anrY9OT1NvSPGl5YtdaNdyRcqy xzNj51bpVh7iylYxWgdPLG2eIncqt65/WsOz0rRtSBs9XdoiPmt5AdpX/eqpYXazK1s0wiuF LQeYGwj7T97NTqI3ZFtpflaROTt49Kq3V0YEMVvGwUDqBVGxuHDGUHzSm5GZW6r3qS8uLyVf OdGKZ2iQjtValcxE87hJC4/utmsppgb26fGV7VcmlEuIychVzwOtZN46NdXToP4FoJk9bhC6 A5c7S7ZFalhcQxvG9wm9Q2Aq1g2rF33jr2BFdFEmmwWS+ZcMskqbk+X5d1OUnbQmNilPLNqU oec4WN+jVfNzFbRsjlVVBkDbzVWxdZpGglXKv/GP4asT6LPMyiHULRsf89D8yis1Jrc1UW9i CO6BuRNBGSRFufadrYrT1e+vNU0OC2CxTxW6+bBOI8Sqv8S7h3XisPW5k0O2W3sgJZZf9bM3 Sm+FNXujM9oQko8wSRozbdx/jVf94cU4x+0ZyklKyO++GXinw5qGqpZeMLNJ9TSIxWN5IBiT +6rZ/i969A1l/GN8PsjXMVjCny437mVfwxmvn/xOmkf2k0mgpcQ2rLvSOZstDID8y7u/Nehf D74hPq6w+Htdu1iv4U22d27f64f3H/2v7prOpTe6KjU1tI6a38K6fpt0uoT3b3l0vzI8h+5+ FWrvUpnZjI+Pwqrf3ZilKElZE4dW52+9UpbqMqpaTBJ/76qUtDW5m+K/EltpsQa5nXdtykQb JY1zGgeFrnX706xq8f2KzZ/M8ofLu/wrq7mPT5JlnubKFnTlGkjDN+FK0v2uNooh07NWurVj KXkc9rt9P491SLQtOt47fSdNwrzhfnfb/P61t3em6LbabG0sKW72wBgmV9rr7r71XW8jty9o I0i2fw425/Kvsn9hP9nj4M/F2zPjvx7cS6tr3h7UWaLRHmH2YxYHlyvFj5+c98cciq390wqz UI2kd/8A8E8/Ev7Tnia3F94zmnufhwsDpYXWp5NxK6nCmIn5iv144r7oQDbnNQWttb2cCWlp bRwQRKFjijQIiL2AA4H0FThlPQe1bRhynmtroPopMj1oyOmasBaKTIzjNGRnGaAFr4b/AGV/ +SNaT/vN/Ja+48j1r4c/ZX/5I1pP+838loA+Tr3TrLxQtzaXPiKwt7farwxWspkdOMrIxBIV m/u9q5HxB8Pr+F7S08Ma5HK00eZLp5PMdW/2RkD8zTpPBWnQ6fd3Wntc3KQS7sRSfK6/w7u5 rz3W/HnibStXt0EN5bWNsWjG5DsX6NXwlJVK9TmpPQ7IcsNEdb4V8TXenx3A1XTrh7mzfyJ5 Cu3PP3s5B/Cvdfhd8a/EOjxxaarTxaY7iQxx4j8303fxV5TY+JtZ1S2tvt15Hd2N2nlsFmAK v/tCur03WfDXhi0gS4FrLdB90MUg3u3svb8aipU5Km3LIvc+3PAPxwj06DzvEXiu+VZcOtpD br5cYz91WY7m49hXZ237U2gXGopAuhzGzM7Rmbz180oB97Z+Xevh3SviZpXiHVIpbkm3ijb/ AFU0OfyroJ83t+bjRbplbpKTBtVR13LXoUc0rJcpHsIPc+pPHH7Wd5oWhTXvh7wvBcXkM43r NPlTBn7+Bj5qif8Aahj8X+Do9S07TIbOV3VppHl3eXtYEjb2NfOVxqtjLbveXV8qIigS7ozt bFcXD4y0nwvI97o92LmC5cpcW0Q+5/00UVUswxD0kb08JTqKx9yTftPW0DQKvhh5o5FRln+0 bVdSPvDimL+09J9t8qTwTL9lAbE63YPP8PGO/P6V8x6X4gk8R+FJBaXEIkhXzImPO5Px6VVt 9VupbaNLnWkhljkEjqBjzExinDMsRbllIznQpwnZn1On7TwEX2mTwoxR22p5dxux+lYw/aO8 RtrtpeXGimGwiSaO4tw4Czt/AVzyGXvXgNrqzxRLImoQkRNuRGA3Mf7rVFql9daoVN/c7Y4p d6qrY/D+VP8AtGv0kL2dDufS1p+08hkaHUfDq+e7jyYo59pK/jReftGQakJrC48DF7UoysZJ 1bMnb5cV8zXd66SQqY4d6NlSz9qlh1zVI7zz7Oe1jTy9rxKORz9761P9o12mrk+zobGtoaPo 3ifVNf1jwnY6ibt0McVxzFF82Q6qOdy15h4y8U2elX8um3MDrqLtM8zrKuyQO5ZWCgfLgHpX aPq2qmd55yNsh2nzGx8vrWNL4V0MT3WpPZwXN5cRuytM+8qxHNc3tnJcj2M3RpufLA+XfiP4 h1Xx/wCJBFNdzz21sRb2qMcDAwOnT8cV9U/D7RdR+DelaNo/hh4tTtblQ+sRtAI43YgMUcZP mD34r5o03QGtPEZmaHcYblnaMD73zfdr6d8N69quoQQ3rWsBwoiZGG07sV2YjEOlSjGmduIp KEE2fVejfGnwdpPheKDRtJgtNRCxytYGMLCTkbljz04Bx74rs7L45fDy7URtq8kBAGVkt2AB x93IHBr44OpXEMsrxsYpnAXJbcqVoSPJ9hG28IkzueZR8zbewqYZvWho0cbo02fYDfGn4cxR kvr7KuA3zW8g/mK04Pib4FuGVIfFlhl03oplC/zr4pWW5NwLrUXZlw2xVJ4LKPvetZd7rVxa zLNNZPLOi4VVVq3jnNR7xH7BJH3JZfFXwNe6rd6QniWwWS12ku06iOQEfwtnmta28Y+Frq4k s4PEOnvLEoZ1WccA9O9fn7f+KYYme3ga3sb1VBKSyKuFb61ak8YqkcQ+36c0n2fa6i4U8j6f erb+1Z78pCoeZ9+J4i0mTWG0Fb+J70RCdkRh8sTHAOffB/Kvjj9nbyfh1+1z438DWuu20tjq ks+/7Q4E7zlvMVU/vdT+ArjNN8RTXkxDXzQSvgxSRS7No4+XOfrXlL+Ite0v482Pii106aCa C+2Lfhwf4Nqtuz+dXTzL2kruJtQoStK5+swYqo+anlhjGa+ILT48eJ7DckvjpLa4RzuElwr7 l9eTSf8ADTnizT7jfa+ObGSKVefOkjbvz3+WtVmsL/CzH6vO9j7fLA8Uu5R2r4t1D9prWLvT JYLjxvZpHelSXSeNZI1/2Sp4rnNR+M93qBGlN8Wngt2XbGV1Bd5/3mzV/wBp0w+rVD7zM0Sg lpowAcEk9KYtzaM21bmEn0EgzX55XHiFNWtSW+LChX5kjOpA+c395st96sy3e1S+86z+I8UD pkPM9+oLDb6bvwrSOPpyI9hW/lP0bl1TT4iqPqFqpb7oMqjP60yLVNNmRnh1G2cKfvLMp/rX 5wSW2mTW7XD/ABEspJY/l2nUAGye/Ws86beRy7NP8e6TiRfnEmpKu0/99c1pHFU31J9lW/lP 0zW9sZEEqXkLIRlWEq4Pr3rmvEPxT+H/AIWnkttc8VWNpLFH5rRmTLbc47V8ApZSLFFFcfEb RlOfmH9ojH86zL7SdDW7ae8+IGnSK42MFuEcD8zUyxcdrh7Op2PoTxn+3loek+Ivs3hjSftW nWrSRzPOcNOf4WX0WvkT4mfEm98d6lda0hhs/tM8k/7uU/xY457dePeuX8X+Friwv5U07V9N uLRzvSX7Um5v+A5rlrLw3rWqJILW8sZliYllN4ifpmnGXNrcfspbGl/wkV5FAtzIQGzuOZAS adB401y7s2jW5k2OGR495wyfSsOTQtSJVJrux+Q/N/pK4+lU7pbyzLyJNbpkYG2YVtamxexd 9jaGr3n2JoI7RlX+NkHz0n9r3MVipVneWLkfP91P8a5+DU7mJmkjliI/idZVxUCaoJnbLRiN dzsVbrU8tPoHspdjpYdcuriRTNMyb/uD1rSGqXs0JgnfaGB2u3ICd64qXW7GVY4pXjDRrxhq m1jW7qys30q3kB81EM2wcp/shv51MoounRk56lXV7qe9umgtZiLOFvl5+8/96qck6r9+Zc4x ms57p41449h0qrKHkbnpVJO2h6UbRhymheT2At5DO4dsfLmsGXVNM06WNI2kAddxWMZXNNuX IJQA4HoKruY9uy5h3xfe3rwy0ahpY1JoorxFJclZVyrUy+vLKfS5NMu2jtpox+5RV/1v+0zV T0+78u4TT5TIUkGYpT0/3ata3opvbQSRqFmiH7tm/j/2KNA+yRQ6g8FtavNbCNQPLdRHgH/d bvW1pCwXDQ2uo3TWVpPLlpCNzbK46a4mKRgu0KAZEQPyrJ+NalqrSR28kksY3r8kWcsy/wB6 lN22LsjqfFuj+AtC02bU7LxFd3cpk2xWyoF/WvOZL2C6+0SQIyIyrnf9+trVksktootSlkS2 eXDPH95Pel1jw1o+l6O1zBfs8rgPBIvzLNF/7K1KN+pMuxj6RbSXkoEXQHLszbdq1f1CA29w I5pI3ZOmGDr+YqlpsslvaSSKColXbuI4RaijmYDaz7vTdWhGy1LTXLxN+76nnrVGR5w3nF33 /wB6pmcdT/Ooc7h1x7UcqZN2Q3lxPdjE0m6orcvA6yxybJIzvQ1PtAbGRTWSMPsznjFF0Sde lnD4mt2EN1b2t6sX2gRTnYJG/jCt0+bg9a5h4yCEHyOj8EHkfiKu6VdiWF9IuHDxyDfET/A3 9aZdWsttM2QVR/mUgdTUrsaL3tTvvDHi1fEduuj6nIiaxChW3nfpdoP4X/6aelWlu1hdo72Q RGP5HEvBT2+teYlJMpIsjRuCCroeQfWu0s74eObeO1uHEevWqcbm2x38a/yk/nWfK47msZGh e63ZS8K7St0QqNq/WqEniRLIbIyzy/7NUrCMzmWCaJkdCUKMcFDWGEd71oHf5g+0MeKuMSZG 7c655z/bbkKuw8n+ldR8Nv2gvEPwo8UWXi/wRcTQ3to43KX2xSp3Rl/iXrXnHiFILayhBlbO 7LPn5awVvrUfx8DjIXmqdNyMZK/xH6f/AA//AG3/AIk+NNQh8ZaPFa39spCXumySCNYc9Rtz n6GvUvHn7ZHi6SSzj+HnhyyQFI3uEvJ0Mhkz86Lzjb79a/JXwJ4/vPA+rxato19Irk7ZYgPk mTurfhXq8euC9kj8X+GtSeeyuZVMyyPuktJf7rD09DXHVnWpStHY5ZYd7xP0oi/bG8QXOkwM ngKK11FXCzLNdq8br324xitQ/tkgRl/+FeykoueL5OW9OlfGOk6zdXenwXbTgsyfPk/1rRj1 K8PCkfTdWH1ytbUiOGfWR9Raj+2H4vnlzofg3T7aJ0wiXdxvIb/aKkVx3jb9sn4naNZx6lJF penIg2ssKB1d/wASTXiaapdgFZAF29TurzL4o6hcandf2Ze3gFrsV0+b5l/yaIYqo37xUqHK viPabz/goL8YZwy22padEzAqhW1Df8Cr1P8AZX/5I1pP+838lr84rjS9Q07UVSaWR1Y/Ls53 1+jv7K//ACRrSf8Aeb+S16dBt3bZk7JJI/N68uPE+nyvc6G1zPEkCsogbBUkdxUGmePte8Qa fdaHrkflb4mVWZRhm/Gvo2z+EGgxTiW2gKsdwZFLD/vqrEnwg0Bo/LOkW7E/e3LnmvkFjsNH RxNfadT5o8MaXq73ovtQWSLTkBX7OjfMGHAPvXp2mabpF3epq02nNdyR22yNWm+UemVH8Vej xfCfTYVEMNkEXBym7G6p7D4fWdpNiC08og7g2SAf8ayr4ylUWgOpLeJP4C1K0twbK/tLaCEA MitCG/8AHm5r1CHxPpyxKsbqNwxuAXpXnP8AZMsUuyXy2/h+ZqvW+kWznEshUdhXNTqqGsGH 1it9k9ATXNLkiZ2kgCvxtaNSK5/xP4R8K+IrWe5gaG1vyuUlgwpPboKxbnSMrlLrCnooHNV0 0u6t5Y3S+ZtuAAa3/tCfwy1KjjK8C14Wu7nwDfx2ExW6tl2o+9fvJ/erv7zUNMiuGSRrUj5W V2jXBRuR/OvPL3Tbma1lkYSSzqrFPm68cLXG+EviFd2s9t4U1uzuBcYkaR5G3PbDPCt6qaVD EVIuU0ehTryxMLW945P4h+PfFNn8Rr3R9A1sNE0+YIYypj6dKRdZ+L91D50t0rLu3DOBVP4k WUFp8ZLK6ihiMjpHLIY+m3H32ArpL7X4VuvJ0+UNs4dVPBr3IVKThGXLeTFTpSatPQwrrVfi pIuZbkNv+UdKqxX/AMU/PURXLxsnG5ZRzW9P4pnMItopHgC8/KN53Vnjxk2no+pahAZxuyyq mKcdZWlTsaSoRatBpkEmqfFuaTL6hM4/u+aKcl98VIHZnLsR0bzgXpNB+IWj6nqUmqzN9itZ W+zpFJ13/wB6uwaaNJ1WP5mfncO9dEaEJacpz1H7GXwnAPp/xFCtILZ1LEsz+YN3zUR3PxT0 6DbA12qodoKzgk+/WvRZCZI5EcFffNU2tZn2gMwX3Na/V4rTlMfrKk/eOPTWPi+kO9Li+UOc vmYH+tSHxP8AGa3ClL6/3dl81T/WusVH5jaZtvWozLK6RujDKMw6c0/YLdxQvbQvexylx41+ MsJ8+51HUVC88sp/rTP+E4+M0Y857vUXDncG3gECutaX90jSr5gYlWVvWpTKrjDfMfLZSB6U ez7RRf1iO1jzHVdW8aaxeDUNbsri7miTerTAEFfeshfFGq3upCy0/S4W+zLucRxc7vzr2SaH z7C5iWNQzQ7E9eleO+ApEXxlqm9P9W20jHvirjFfDYpThJ7G5Jq/jkT+ZLpkrS47jgfhmmx+ KPF0T4m0yTcPWPdXoUUSTNGztul2kbqnltYCod1UHdj7vzNWNmnojZVopWR5j/wlGsyqpuNE t3b1a33f1p7zaxeweYfC9tt9UtQM/rXeGzsmg8lYVD8/NiorOMrbqHLKoZkpU0nLlaFOrFR5 jg38SX2mny5fC1go6fvLENTIvGF5es0UPhPTGP3tq6eua769tIHkEzoX+XvzXPadZb9SuZAW Re2P5U7rn5bFRnGUOY58+Kr2ZTanwxpq7/8ApwC1DOzXMWZPDcQK8/u7Rq9Bi0i3uH+VGZmb n/ZrQFq1tEwR8AdK35FvE51X1seRm/hifyl0KEv/ABhrdvlpXmMqrIvh9W9/srf4V6BoqCW8 mldEcszbmZeldYqRxNGghiUbN2ce1ZRk3sbTqRieKeY5XzF8PZIPLfZmqdtYukRs6AMP/Ctl Xr9sURZlKKNwyOKayIHaMJGdq7/mFaOL7GarxZ5INR1CdUK6D+Vkf8KdHeX0LSOnh5Qz/eJs j/QV68IlO1VVOVzlae9vGsWVhX1ANV71rBCtHqePS6tdwxrdXeixRxr/AHrUhf5VlxeKJJYg raVZt552/NbDp/s16n8RbpNN8E6ixgRd8YRG4+81eY/DxoLjV9IjnZJfKY/Ky9aObkj7xpFq XvFqHV3hiMEWk26qgOSbXn+VQrrVxEroumwKrKVcC3HzV7HNHateTRfZkC7c7sCmabYWM5wk SYZs5KZrD2kt+UuNSEjx9fFt9aQsYdNslDps8x7NSyey8VhG7nlDGdn3H74x1r3Y+H4Llrlp IoUhh5DSoB81Uf8AhIPCHheNnm0mxvrz1ZQybqn6y09Im0aSl7zPHNL8Nar4guxaaFp11eTH 5sIrEDHPXpXWwfA7xIrb9ev9P0rIyzzXqtj8FzTvE3xzvyn2LT5rfT4d254rRFQfTA5/WvOr rxdrGvzyRWqXl42PljBb9TW0ZVZ6vQzk6cNFqegn4c/DeymVNY+ICNIn30tkLo36g1pWej/A vTJt0mvajJn5dogBX9c15dbeG/FcjZu44LPf/eO5q6O18HxzTiO+1CRzleI1wuaJSt1Ek97H VfY/ggbrK67qluM5GIVKj36VsXGifBPWhb/8VfeLJGR8zIBu/wCAiuPn8E6eWKOJCnfBrktA 019Ul1FUba1jdGKH5eq/7VOF5apmcpJaHsD+ANGaeN/D2p+GNWheYN5d6nlSAL24Bz+lUtV+ GnhsXH27XvC13pjF9qX+nTedCF/3P4RXk81/dabdsjho5U+UNG23PvXQaR8TtY03y7dNZkaJ zgxStmiz3K5i341+DGqX9qLjwXfQ6tZBg7ZO2QD/AHfWuQbSdS0mwbR/E2nXduF3Km9OF716 Jp/iXQdTv1udRimsXd13zWcu1VP97aOM16Lp8WkalpzRT37arHcbjvugrOF/u+lHOP3bnyzd a0s0LWMEf7jj5cfK231qCBEdPMKc4ztNeweIfhr8PLzUXstF1WK1vhw0O/Kq3pXHal4C1PRZ Xa7smMSttWWI7lPvWsakepEoSTuzlFtUdM7PenMnkgP9mXcPmXJrYuNJSKVUQvz396hfT3kj YjeQh5qvawJ5epzcF8XuGEyJjOPlFPu5oAyxwnjdjPrXT6Z4PS/jeYx7R3zWv4a8BWTyPPcJ uVH+7R7WBEjiIPLhdZAudn8INb1wLm90eGGzcizi3SmNhuZJF+98305rR+I+nWenS2ENlZxw BlYuY127qxNEvJIg9ks6fvGUKjnChu9G+pcCjGcpnP4mhkeF4Z4ZGSVPnjdH5R6uakLZbyRI LV4EV9pUtu6d/wAarPvP+rHU9qe5Z1dleR+MA9w14bfW7aENLFGoAvUX+Jf7snr61wz29zLc yTTyuNztkscYP+NTB5reRLy3kaKeF96OrfMrf4V1K+T41g8+2jSHW4E3XVsF+W7TH+sj/wBr 1FHw6EyucO9rPOvks7skfJDVCumxeTK7/KUVmrbltzDN5ZyBnGD1HPSoJoke2u3PAROn41fN poZu3U51LcMMAkA9a6vwX4rv/B+opfaeqvH924gfmKdP7rL6+9c2M9VH5VNC+0dT9B1onHnj Ydj7f8LeIfh78SvDljdaPb3Fp9li2XlpbSfPC/v/ALPvXWXM62WkW+m+GfD8U+1/3lzeS7pH H5V8NeB/GmueCNfg1vQpf3g/1kTH5J0/ustfanwv8VeCfiVoaa7HqMttfj93Lp7SAPG/91f7 y14GLw9Si7rY55Qnze6db4evdPWZW1zSraIbsJHGnP8AwLNS6za/DTU5Y5bjwfb3kifKzFtv 8qLnQvD8c/mzXEzHZt3MV/LpWM+i+CrRtsSzK8xwx3A1wc9tpCvURjeJ/DumatcrbeHvCun2 OzhnLLlW/h+avev2V/8AkjWk/wC838lryo+EdHvQghv9QVG2/JDMvzV6r+yv/wAka0n/AHm/ kte3lMpSU+Z32/UxqOTtzHnyxSxLvYI0hyVZVxmm7FmUTXNjL5at8zrVY6wotIERrrbt2ruU U6LUWlh/eajc7Q21YlQba+F8yUpdhRHFMxQB1KA43DtUksl3b26OtvvjiGVZU3E1Rj1kXF2I 2lwYuHYjFWBrF0hZbeSR2KsIyp+XbUy97YOZxZDPLZkNJPaCRnG4HbioLdbB5TI9u6KjLj5s Us+oXKlUlHyrztkquySXTYEgdfQURgHNLoWJLGF3eWC/aPvs27v1psURG1jMs5H8Drtqvbta 2bNGGkbd/rE3VbOr25kUW9qFP8PmDP8AnpV8j6Meu5FON8bPFDIpZuu7Kn/ZWuA+IOihHbxX orGPULWPZcRhP9fF/wDFCvTZNXS+mgeWyjC2/G2LjcamtdQ0tGJ/stWZt+9HPyjj/wDVWlKp KnK5dOrKlLmifLM3iPUNS02516UJI6DyI4jCPNVc/wARPNQeFLqS4EkCu2d255CvLVs/GePU rfxuW8OaQfsc0SSTG3IZWlz0wKxPDM7aXOBqFvc232g7lWSPH4Cvs8vUeRTfU9GvVlXpqSO3 tNIR41Q9Sc4q5BpEMyNBKiMqnlTVrTFklTegLcZwRjir8Nr5UsmCoPfua9BuPVnBytLRHm3j rwtpUc2n3McewxToW2cDrXfxiNIlztZtgw22ua+IUZW0t5lHKzAketb+nq01rbzMzcp83pWE Ze/ob1Yv2akW4kcSZjT7w5O6mvK7uxfqi/MKtKC8ywYXbs696q3Fwi3n2UR4kT5X9q3lPlOW yuQtE5iBRfmI61XWJ4U8oytndluKhvtei069jtXQgu2xuaWfWLFTltylG2t6YrP20TT2Mmro sqxdWhyr5O4Hb6VJErlhI6KipweaTTnjurU3dv8AdCscf3qUhLiDzlwit8341SqQuSoOPxEm XSLzdmQ4PfivEfBFx9n8carAw/1srED8a9tBkFrsMZYgHGPpXhnhl2j8dagGO1vNLD86NOa6 NaX2j2a2eRgpQ8btvNXGeRlQkKV+brWJFqAheIpIPnYjDVfhvY5bz7KZl46pU3I5JMcrRsqg nv1U06ySOWGNC33pG3g81FBLE8kiqqjHHoKbbahbWss8M7qPLI6e9YS/iI2hCXK42J0toJ1l 2Fl+Yqf9msvTNK2XVymXYebnNaUd3HFMYifkmYk02Nyk0825kj3D7tOVvaaDg/ccTWtbe2hg cI/zZ+9iobu3WW3dDJ8xG5T04p1jPBcGWNJwdnzbKhuWlmW43uAqJx2raT0OZfHqY2mWKQX8 0STqxEu0spztOK27Zd+5yN7xDAO7tXP6GhWaZIEC/Nk5NaximikZEO3aq5PrzU4ZOzNMRZSR JJBMJfM2Myvz1qTZG7sHBVtmOe9RpdyTRqwUtsLJUavICCxx/DzW9n2MVsWFKErtRvlOF+lP umCxMkUjCmYJVXO7I4xRcP8Au1XfjdzTK0tocV8bXRPAIKzfN58a4/vGvPvhdIDr0DE58pSx +Wu1+OD/APFGx5/inWuJ+FSyvruyJdzeR90HjqKmpblOujrFntdu0k9287LkEbBgck0291vT /CFutxqDCS8Ubo7dD93/AK6H+lcv4h+IeneFxLZWcyTX44mnVspCP9n1avFfEfjG91e4cmVj GTuLk/M596wcZVPdRVOKgm2dx4o+Md/ezyIzg5ONi/Kg9687u9c1vX7nybYSSyO3yxxdqg0P QNV8U3fk2St5CnMsrfdUZ5+pr2nw94c0PwpZPFp8BeWWPDXLrlmNHKqO5oqrl7rOI8K/COa8 aK98STYWRv8Aj2j/AJs1dT8PILXTrXWNEMA86zuWDSbfmZP4RXSaXd7VUu3yr8tc2LgaZ46v U3ts1C2Vvl4+as/ayqR1G4xhJcpJfyGS6255Vc1etkHmwj7u77xzWffBDegHPvWlCIyI81nD U1qzcEXZAky4R23bulcF4OOy718D5W+2fj3rtr53jjBjfHzfw15fa68ultrrgK09xdtsFd0I 8sbnBG82Q+Nr2yF4IUAeZD+9b+7XN+ah5Y5V+hPrTSl1qV8U8zeztukZu1SX1ummsryfPGT3 q1Y1jLl90qy6zqWkNutHyd3zK33SK6PQviTcQSRo9xLZXHTKv8jVzck0N27PGm2NRk7vWs7B csxVGAalyxnsJc0Xc9y07WtA1kiDxTpwmMn3bu3bbKvvurobfQtfiNvH4e1pda0svl7W6ws0 af738X0rwPRteurC5iWdy9pnDpXpuheKL3S70y2NyFkj+cJu/h7VzVqUo7HRTl3NnXNA09tT a3k2Wd1jADnasn+7u4P4YPtWZc6Klks1uzIxUYDR/MprqNTsdD+JOkx2Ml5It2PnQ/dMcvr7 1xZHi/wlJ/ZOuWn9oWsIZYpcfMi+qt3rGL6FyUehsaJaxC28sfKdvp1rY0S2SNX/ALu75jXm d/r2v2LmeynkNqwyspj6f7JqiPHHii3Uol8yI/X5R+FdEaZzyiuU3viu6DVLOCJzxGxyR71w siFV81CM9Rx+tamo68+ot9q1mczSom1MCsWO6+0uwCFBjgiumOwl7pvRiDWESO4u47WdkJ3S Z2yBR/eArLcPGcEjrj5aksrgxbobht1vKu1kx3/vVLPYyWo8xon8tuFf+H2/GlsWVN2WPHuR jk06Ga6tJotQtLhobi3bfFIp+ZWqMgk48zB9BUiiMr8+cmjcDW1QHxfZtrdi/lanaHdf2yLj zV7SL6e9YUEgl03VJfM3N5C8Dp98VNHd3mm3SajYTNBPEPlYdCPQ+ua34rTTtVs7nVdJsybh 9o1DT16xtkHzE/vIf0pbOxDjzRucStvN5CTE7V3bDuqRbdYmy0ytj+72q7eW8n2jY5TCytvC fcqfTPDWuaxMsWm6bLNI8fnbVQn5N2M1XOirWSKsOIkR0VVO/wC8OW/+tV7w34t1XwnrMGs6 Vclbi3fcAD1HpXbWvwj/ALMQ3XjHUYLG1HZZB5oTH3gvevN9eXRbXV3h0K6kurRThJpV2lqH y1lyMmUddD608H+K/EPxS037T4OmEtxEmbi2klCvG/c4P3lrSvvAPxfltFibS32RfPvE6f8A oOc18l+DPG+veBNbh17w/ePbXUT8gN8jp3Vh3r7R8C/HzVviBoAvfD+mRTX8SbbiCScIVf8A mVryquXQjImOHjOXvM5m0uvijokKwP4f1NmjfdvWFmx+VfVn7K//ACRrSf8Aeb+S145beM/i Q2mNNP4ct4rsRMyK1wNm7/aOK9j/AGV/+SNaT/vN/Ja7MDQVHmt1t+phi6MaTXKeQR3M5IGV ZQ/A9KbDqSNdvGIWQp84yOKnUx7WmhhHllvK3YpYbq2kHli23H7ofpX50c8ZCz3EqFpJVi+Y DlVrB1BtYhmL295sD8YVe1bMkIuWULLlOgQHndTJLFHDC6WTfCOxrSL02BrmMJrjVmVpTMsr I20rJ396u2epXUuT53lHbl1VeKvnRi0akMeOaqxaJK1ywMx2MvQCjnRMU07ALuB7XyUmi86Q 7yWXDVJFeiFUju081ehdDVKfw9JJcfKGHPLDk471buNAR3C2EjLHxlj61V421K5pXJpdVheL ybPbsDc8/MKj+1iCbLoDxnhvnI70238OXPnbmlVEAy5b0rO8T2yaHo11q93PHutwzK6+uPlF Olac+RFLU8R+KWr6Xdy3d9ZW4srmJtkUUDsjO27lmx3rkNbN4lvaatpPiCYtEirLAZSx9+tQ a5N4h8Tav5MFm9w8g83ZBFl+v3uKq3miatav5N7plzBKPnKyRlWK/wBa+1w/LRpRhJnoqOiU Ts9G8Q3t+lsILuYM3yli+QprrI9X1m1fzIJ1dsfO+7G6vIdPlubSVUiklidn+TaMfP8ASu+8 F6s97cvpupFhIeFJ/vVpKnCrLU0nKdKNkg8QeKtVjTzrxo5IgeBLHu5qT/hOfEpghdYoDER8 qrABx+FWPGejo2jyOx+YN8uB+tO0rS4p9Mt3RPl2YzminThGfLEznWlKnzNElr8Sr3zY7a/0 u3ijHymdVf8AxqSf4iaZDJcBdHmuWZt4mWfy93H93aahvNGSRYwEB2dqpx6LHMXkkj+4v3Wr f2F9eYw+sU/5TT0+70LxK8mo3tzNYtEisuVEp3fmKJL3TNVijs7a/RfKkJeWaAqW/LNYS6OE 2qgKKw5amrYy2rlwWK87Qh61zyw1S/uyOiOLoWtNHpNg9hb6eltY38Nw+0LlQVX3+8BQ9m1q oD3FqDnciGYY2+9ecRy6rGkbx3Mi7DnbtqC+fVZZ5JpbnLbMDtURp4mLtoK+Em76na+IdQur XRriW3baXZYzIr/dDHHy141o9lqOj+Nnt3spZI4mKiZlYsx+tbuozXq2E4ckjAG5m461k2fx Eu9Hum0gpK0mQokVwe1b81SL1iVGnQlpGR6BeS3KCG5WF0kTrvX5ajtr0vcecjPvDbt3T8K5 oeKb67Cv507e0nzDNadh4r1ZF8id0CHhv3I61jJ1VtEuMKXw8xq3+oXMLxq0n3snFQxtd3E7 OFJ2L8yqadBrlgIVW5W1kk3sTuQ9O1SnV7TUAzGO0gaP5tqghq55VZr7J1U6dO3xF6zu5BGI 3jDOOjFskUDWb9GuIWRSGwF3dKjurzw9bWguhCs83y7gspWqdpdadd3EjOsyfMMRht1Sqzvz WH9WindWNqwvV08efL8rbeuc5NaS3aXsDTCXAdBvrNubvwo8mxXv+ixbmxtDetUJLqxhJjju 3WPb8zbeOtaRxDejMXheZ/CT2N463jxqdoX5W/vVoprQ82a1kt2fI27yD+FYsEuiI0dymvbm l3HaYfnz6Vdgs7pnQREs7jJZiV4qY140n8RVTC8ytyly98Q21sFtE4d9uZOymrljqKXgwCpx zlfWuXk8P3OoXIuVubJo+pRpCv61ajtzaXWYXhiQOsbbJc7q2hi1z/EYTy+8fdOwLjbvhbcM fPVe4yY43wrE/oKjeVLe3beQvYHP96mxRvcQSQwvA7/KdvnD5a61iKUveUjz3hakXax5/wDG +Uv4ZtIkiLN9pCbUGc1xdhcSeDdMdFl2arexZllz/wAe0X93/e4r0Lx5dafp9mlxfIryW0u6 2CNuzLj734V4XruqT6heSTPJv3NudverjNVdUdMY+yViHUNQ+0SNGrttJ3fP/Gf71S+GPC2q eL9S+yWTiOKLLSTNwq8VQsrG51e+hsLJS7ynZk87BXvHhHQ7Pw3YRaeLRlXZukkB+8+etVKr CDsTyTlqVvh5LbWUDeGrq0S2vLAssilf9dn+P3roNQiKWKIHX52bGawPEOn3jXieItLjkW+t csF2/wCtT+7V631Z/EFhFPYW8pUP++XbnY/pWE2pu9x2kuhYsIX8tY5du771c74zBsrzTtXj CoYpDE5HVlatow6ikyj7HOuzdn5D6VkeL7W8uNHkZ7OZRAiurMh4rKKVtzSScpaoW7DvPvCY 43fhV2FyiRl/m2rn0rAtL2eW2t7stt8yJSu7+Kma34mn0gxxmNW85dvzdqqlF31Q6vvKxt6p qS21rNcSoPLjXcAvWvGppXvdRuDDHtMspcc9Pet/xJ4mnu9sIfbCqbFQN8x/2q5uK5jt2kmz vkPTFdnSxjGPKzodK0+G2s2mRxI7H5n/APZayNfeOULGhQMjfdz0FNsNXNlBIh3tv52Z4qnb oLq5eRnJwNz5/hoIt71yrdA21tlP9ZcDJ/3aywziYKP19K0NR3ySqwOQx+QD+7UFvZSMrTy7 k2P8mapeYSZsxLLaskcVszxugYsACM10WizR3AyxCzkc47Vm2UsYRRjt+tWn0/UJJUl02dYm H380pR5hRm0dNZ6rc6deRyQyt5o9sK1ekeGvGdvqtu1jqqh2ZGVg46f7teKHUpLS1eLVVfzY jmN/759K1dKv7gxQzM+ybbuAVua5KlK2qOqjUW0ju9bitraCe0bT/wDQbo5QqOh/GuWvPh+8 UBuYpYrm1+U+Yv8ADu+7uWut0fxBa6vYyaLrluJUmiKRSL96OTs1QaALjT2m0W/WJ9jfunD/ ADPF70oScTWUYTPI/FOjQ6ZqC2ueXi3fjmsuOERZNdP8SlSPxOEjk+VIV9/WuaAJXcf/AK9d kGrXOfrZj1lLBTn7nA4rUgmmubOWK0dlUsvnxOcqzdmX2rKLDbiMZ59Ks6dMYpmlSTaOFdnX 5VNOVrgQlixIkTY2cA0pITvzVrV5YGuBPBa7H2AXG1tys394VRV9/fnr07VJpoTSuQFBzt6n 1zTrO/vNHv49S0+Vo5osEEdCO4qLc4GM5zSpnJD5244z3NAaHp/hbTfhdq1qfF9/JOktmH/t PS9uQS3RlP8Adqvr/wAd7TRbdNL8D6ZDaR20fkQykZkVf7u6vPLHULzRb0XdiN5KiN4W+7Mn 8St7U7VvDFlqFtJ4i8OsVsGY/aINnmSWkvdW/wBn0NRGmr3kHQyLnx3qeoax9v1tH1GB+JIJ Hb5k9j2q/rOg6bFZQ+JfD073Wj3DbXjZsyWkv/PNvb0Ncze2bW020OGXuy+n9a6LwPqRsdQk 0q62vYaqv2aZG9T91gK10j8Jgrt2ZmvO80zOwwo46dvetzwd4x1vwPrMesaJeNDKh5Ct99Po eDXWWHwD8TtptxrOrXUWmWke7yfM5eVR0+WuKHhm882RGuEVImwWb5SOfepcoz91GnLKOp9K 6f8AGXxP4r0b7bbeJZpY5U2y2xC7omr7P/ZX/wCSNaT/ALzfyWvzd+G1nbadZ3ksF4t08rhS yrjkV+kX7K//ACRrSf8Aeb+S1dOPLdHJi5NqN/M8eV7eECMSNtIb5V/vetSBrZWjYttz3xWf P4g0kRgG5T5flUbcn60ltrejrgNeRtt5Le9fmXJPsXaJoTukkoNmuWT7q/dqIPNFOJFWWRip 3rngmq8vinTIbhnlu1Ef3NwSsnX/AB1omiaPcagrs0iMViL/AC7mq4U5znyIajCexuXGvWen BJNYuYbJFYkNLJtVvaqcfxA8EXRxF4otFkY4wM7P++q+NfiD8R9X8V6vLNNqDyIrtt5O1f8A dXvV3w/4a1+ys9H8V6vcv/Z97fxwC2bhZU7tXtrJ4xpc9SRSVGD98+14r3T7y2EthqCXQbk+ SM/1FRLcXkXIuIpI5fvp9yRR/umvHIbZ7C7N/wCGLl7aJP8AWxMxK11XhrxTZa4ssl2mbh1M UpMnzbV7rXn/AFSMk+Tod1CjhMWuSDtI7RdTvgZGiRHhHyAueK4v4u6vL/wgF5BJFGwaWNTI rds1b1m+vNI8hNPuJHtiN4HBIri/H3iiDXPA18rTHe2x2UqNyMrfdb3xVYehKNWLPOxWDq4W rf7JwPwz+KHgjwDq+rXnimeeK7dFS3MUe7eq/wAPtXReL/2m/g94i04R3HhzXpr6JcxyrHHH t9y2T/KvCw2iHxxpcniAD+zvMV58+naj4rN4dl1W3m0L7ON0Z8z7Pjbj+HpX088JSq1VKSZq tFzo2r/4teGbiGSOLwxqRuXVvLna+RFRv4W27Cf1qTwrqmoW9wmpfbHkeUbom968mZgRt684 OK7bwlqsNlo2+6kaQRS7FVT8wruVFU4+4VGq6j94+hYlm1HwQJr+68yaUs+7byP9mrugRSJo 0QI8wKcbduK8j0z4n2jo+nNDOsf3WZP/AEKus0v4kW1jALZrjiLG3cnWudRnGfMOUb0+WJ3L WyvIwEfUZIqK5t8R42d8GuNi+I73F00izWyxt3fIrStfGkLyM8scdxGjZZoZM/8AjvWtvbdz m+rSsXprcxFwW3KnamrbIUBJU7eTTV8Qafep9sVkVWbDIe1WoYhcwEwlOcnGa2jUizCVKUXq U3t0Y5Bekltop1YK/wAyjABWrttDJFJ5rwg9jTZ4jHP5+zapXNLnQcj3MeXTraZZILqFWjcb X3V49qGkRWXj02NqmEVsqu7P417neQOY5HRFZMb3PcCvIPEEL2vj1NQlwkLMiltwo5zWimk9 DrdI0nERfDbskDPatI2Al2hyuAv93+KrkNwgt1eIKFdvvCrmI54N6FW+XFDqIzd4swjpkce0 NHlmarKaKgmkd0fe6cHPatVLfzoUcBflq3GqeUzueAn41MrMu8jmbjSkOwgPg/e3cinRabJI +6OTC9yK3ihMZJHy/wAJxUMsUluQFKjKbiKxlyWsaQc+5lrbXLQsquGGQ+6q5s7lUbcx2yDs 1XJ7hoS0Yk+U1ftIo5bbfj+HNZc8Dp5asY83Mc9Y6dsaSR+GR/velbMl7qU0Yie5IZP9nqPr V3TrJHkkQxthh9avR2SbGEx4TkDbVqlSnvExdepCXxHLG+1WyRordlaP7vzLWfNLqXnIwhUB W3bh/err5LBpVYMybM5FN/sVbmBgE/izgVfsKXSJf12t/Mc1JqetXKGG+uDNt+6udtNsZbyK YsWZVHyyHsE9a6FdLQox8nLJx+Ncp401X+zNLewijWOeRt7sW+8n+f5VP1enFe7EcMTVlLWR yvxJ8Ypq9yLe1CxxQrsVcfdWvPmmcJkccdMVJe3D3czSufmbjbT9GtTf34jMLyrCQ7hf7tdM FyxFOTc2dj4FFtoYj1K7gkkuZXVvlA+Va74+MNPuDNE0dyOMxKqjp1+b8axLCytr20W4tNnl sAMf3a0YdLtkkWTyzlolXI9ayqYaFR80hLFVKXu2LWneL9PtWkkvYbl027cKo61k2nie00nW JbrS4J/sN03+kwMfut6rU09gojchPm6YAqrNpkaWZhZAHfkVj9Th3LWMm+hszeNNLuHDpHeR Bj82SKzde8UWeoDBmkjT7iogGG/3s9K5pnTT2ZbtDKUGV+bpWHrWpWuoKEst+0/fYris6WDh B3ubPEVGJfale2r/AGZZSxifKKTj5c9qz9Qvry/YXNzu2J97aSzZq09uJzHID/yy+8e+2rcE JVVOc/7Nd8YpLQ5qk2YOlvHqF55aQMY0+9I5/SriwxqlxIg+ZHITjtWnHDGgkSONEz8/y1Ti i/0abHO56ozhJy2KbCQW007rv2rzupJgba0MgPzzYGR3WtDULNk0lmiQlmdRiq8iGVzcMg8v 7kePpS5rGsvi1Me4Z3SKZSqqnH4VYt2845ZwynoVNOvYYfszOwb5P7orGWUwzK1uXjDNV/FE yOgaVIoykLuxPcDqa1dO1MwqvmhlCLl+etY9uk8oUqmCBkn29afc3BlTyreLCoCCP7zf3qlB yxlqbp00+IYWubt5I424gVW5X/apG0250eMvEWmt1GHZj8y/7VLot06WUMMkg3RL85NbsEkN zA6OVeN1x1qZaoluzM7TdXSaTdYzhmXGCrdfeuwa/tdVgiuyVS+ssMsin76/xK1cy3hy1hUX Omotuyfw/wALU2xuvssimQYR2w6VjI7YSUtDW8baHbatpS6zFHtu7dMHb/EnavMuUbJP19jX sGnX1ldafJphuUedlYrG38a/w15l4jsDaXX2mKHZBJkHH97pirozfwk1I/aM3hEbY2KcrlEc E7t4wQtRpyrNipLW1vbuKR7SFpFT72K1em5nvsXoEjmg8m5fy9g8rcAeP96s25he0uDDG6y7 Bw6HKtU1nI9tOVDlhj50apruyktVM8UYeEkkN6L70FepXjmTYgfrzUi5wXG8r6YqmSYn8xTl asLcMgR45Cu77+BQA7lxwe3HPWrGl6vf+Hb/AO36fJ8si+VPER8sqfxKffFQuEMgkTpnrQUM m8AUadRx8y9L4F1fxJqMEngPTJ9Ut75vlQHJtX/iWT2969w8L/C/wT8HdLXxT46kt9R1xVDx W6/NBbN/8V714v4K8b658PNbGtaLM+xjtubcNhZV/wAa6HxPqOqeJr6TWtOuEurPU/8AUeaz EI//ADzZR/EKxm5SdvslPlLvjj4m694xvWMsjW1qy/JAJAsbL/vEDFcHJ/wkGsGfSdF0GS4d 2w8gQTLt7bXx+ua9k8G+DtNm0+y1LxZaj+0ZW+ziJ8CJ2/hyuOM12Fx4m8KeGojZ3U9lplvG WjcErHsdf9kc1588dUhLko07mTqTlojxrwhout+E7P7Brdv9meVvN2hvmr9KP2V/+SNaT/vN /Ja/OzxN8SfCfiDWYk0m1vtYu0iKRW9nF99v/Zvwr9E/2V/+SNaT/vN/Ja9bDym4+/ucuJ6H z6PhZrGi3E0NzaSX/lsdzKT+lZK+EtRtLkTQ+GdUkL/c8vLgtX1DLPDdv9pFqfNG4btxCv8A 7wqGGWaOZiissTrtZWX5Y/8Acr8/9uexLKoP7R802/hfxZK1xjRpplVtojkhw+5a8N+NviPU JJV0Jv3UsWI2jB27X7/4V+gOr3VxY2lzdpGqeTbvKxI+Z/lr80PiRqs2t+LdQu5n+YzSN79a 9LK6ca1XmOaeCWG1izH8G+GLnxNrKafa6ZJei3H2qWNB8whX7xr3Txto2vXfgmy1az0t20u3 lieOZlyq/MFWtz9iXw1ay3PiHxRd2ySrGkdmgZc5D8mux+Mmn3HgPwzrOmpZStoGsFJ7XHC2 dysgby/904rrxWI9pV9mtkaywUalNTZh6f4X+IpiSVfCzCEgYOAN4/vYrhtB0nxo/i/xMltp 1xvsLiJpUjX5YiwPy7R64/Svp6x+JXg+28P6dPq2rQtI9lFI6xsWYEqOOPpXh/hb4zWHhzxt 491LT7COeLUbqN1eY7VVVU1y0Yz5moxCOCp0J86ZBJqlveBLea8UCdSrx4YeWf8AGvPvHU99 oXh25S3eOWCWXfK7cs3+Rj8qksfFMHi7U76/toPszrO0uyPhdjVa1CG21LS7hJv3qzfMyk/d 4xXXRpuEk5I7avLiaevQ8A1O+g1CcO9qcdM7qqXcVkHU26cOnrV3U7BtK1GazI+SJzs45xVS WJ4wryRsqt93C19Ap7WPJcbaFMIirzGoq1p8oRmjUff5qPyXzhj1pUjaNlYHDHgVblYhRZoo 06K/2cqWPStaPXjYtEJYfNIQGQbeK5+WS+hXcIHhB6F1IBP1pk6XNxB5gnPmJ/CKm8ZaMu7S 1R0sfiiG6vHa8jWCN+E+XC1qW/iLTLGHfa2a3c0jfLMsxHl153I08oVZmcOiZw69vxrR8O2N 5Bew3gVvIdwrMTx9KUqUWgjUdz0U6pcyqJoCFWX7yYztenx+INRtZNxuSjfdwSV/Sjw9o2ia 14hsdL8QXE8FpL5vzxRu7xvjK/KnLV674Y8C/DfQYXmurbxZq9ySdrLoLuir6/NXBUrwos6I wlUZ5Yvi7Vyhf7ZyjdMnmp5PHmqTsodvuocivYx4a+EM0/23WPAvxCvlk+4sWjtAu7svFeGe IGh8L69PBqHgjUY9Nu5HewS+gkgnCZ+770qWKhVny2CdJwVzWHj68kt2jE21mXDtjGFrzHVN UudX1lr2Wbky7ju6BB0rWSW+1q1nh0nSZ5Znfy9kYJZV/wA8VSbwbrtvMr6hbR2RH/PzKsf5 5NdkOVGEklud3oPipmtVgcREov8AE1b1t4pjhhWBYVZ264PQV4+2r22jzvb3DhmXjdCyutTx +LNKblpnT3K1Mqb6C/dddz2H/hJbXJiLPH/EvHDVbsvFCxxyHZv3rg7k7V5DD4h0yfaYtUVc epxitG318ODHFqUbEc58yplGZcacGerJ4msHGyRtigYU4qGfWrWUsgkVsL8tedx6vclf3cnm K/PCZqxba88SqjRxt/tMOlYyir2/U2hSjFXZ1F/qEIlyhU+1XtN1KO4g2F9vy1xcmtQGNka1 Xfu+971HHr0S7o0hZe2Val7E0lKE1ynrWkPBjzI5ONpDKa0lK7doRW75rye28XJZW7SpJt/h 3NIPmP8Au1aT4gz26Kj3W2SQbEXbThGUWck6UWegSxksqkKBu3Y/ve1PtpkaR4wNm3muAsvH gJhjmuIvlf8AiU8irr+MoX3NBcRPnrlsbRTVWSlblF9X0ujrZV8qOaRTtAYF2rwT4iavNea1 dOk25ZH2Bc/wV6VqviiSXSrvy503bAF2sD2/SvDtUuTd37HzPu/KTXXD3lqKMeQji8homLlg /RDXX/DK1hE17LMm5sL8xP8ADzmuNaTYvl8cd66nwFdG2v5Fcja8eME1oKUdbnok2k/Ypvte kE7PvNF/C1a2nXVlcw/K4WQYV0I+ZTWfDrNtuEEM6t9aS9hhcx3tpcxrMv3x61nzJaGfJz/E aE0R89ioBHv3qheW8ko81UQtt+UetOj1JJo8Suomxj61k6/q2paXbi5jtg0Kja+37y0c19CF DllY5HV9aElw1pNbN5qvtZV+79aq2GmwyS+YXVo1O9Vx96qKF9V1NixdfNfexP8AClb0lm0K Lc2xH7v+H2o5eU3lN/CZ95GEkV0BxHJtx7NVuK1kcKSCp68in30Xm2Uk0T8hQ3/Aq07JJLuG 3liVdrJ85NaX0MJXsVDb7hhE+pxWPYojs6OeBOa6oW8ilsfwiuQspSLqaIY5lbNKfwl0NHqa erP5dpDAqKrXEuxR3x/eqC4t4oolgVvup196qXVw95rlq4P7uPcqehwKt3rupBJH3M1HwxuV OTlUsjF1OJI7CQkfw55rn1VppoI1QZZ+3QD1NdTqqGSx2R/O7jGzHasZ3h0zyrVAr3E2Czjo n+zWsXoJmysRliEEZKRjG9u7f/Wp97ZPbLG8ce8dsCtCwhjeNDJ931Fac1pGwjAPy7eKRjdJ 2ORe7uDGyKi5+6dvpW9YSxx2kYWTlB61m6lbHT7hpETKsPlNVzfPcTw2UI2K5DN60GiXNsdx Z3gBVJB8g9abqcEIH2iE/e4zjoazFnSAI88qxJ2LHlvwpbi/v7+DybSBYoww/eydcfSueZUP dlcjjtnkvku4JGiuojlZF7j0qSe3/tWzubIvvki3SqzDuvNRwSyOzTQuPlbYf+A1dvprPyYT bTL55X96qGhaM6m01ZnAyvMG2PGFz1q9pt7dwK8ETmIn5lZe/wBan1a3ia6EgkHm4+63yjFR zNNEiuUVX2/d4Py1s/eWhlH3HcsTWtzMjTNLJ6u2wVTie5lBW33rM37plDblZfpUY1Z4gYk3 b5fvDPy4pv2g2cJuZdyGV8JxzSh2Kl7xFcW91ayG3uYWilT7yle1MDhDn+HrQbh3nkn1C/iU 7Mq7Nn9KaNa0O3DDyri7dGA2/dWtNTGzvZGlZxSS4EKeaXHyqFrWtvDOpSR+dcRJarxkyuFF c2njPWY4zDpFrbWMRP3gu5vzqjPNq2pSebqGozz9cgsf5VHLPua3sdZew+EtNGzUdeWZ93zR Wy7qq2Xj2DR4rix0TRfOgulIdbpmwT/fABzu/GsOx8OXdzzb2bvk5B24/HJrqdI+Gmt6jfWu mJarFcXn/HvExO6X/dzUynCGk2P3p7GZqPxD8c6yGhfVWtYXRUaK0QR71X+9j5j9TWbdTaGJ o7m+sbq7uW+fBmYr/wACr2Dwb8ALnxPrFxoE809lqFmM3FvcxtFKYv7yr/EPevXPCv7LXhGK 882W01HVJbYA/OAqf/ZVwVsyoYbRDVOcVsfLtlr3iE6gl34V0WKwuAqqjW1uA+f97Ffqn+yv /wAka0n/AHm/kteK6d4R8P8Ahlo49M8NRQlGxxbbm3f7LYr2r9lf/kjWk/7zfyWtssx0cZz8 sbWt+NzhxfNpzLubbQEwSyX7KYt24tt2hKzNW1XQ9GsxeX2o2yLEeryBmC/Qc18v+J/jJ8Rx qd/4Y1nUpUW3do2dh5ZkPutecahq3xCm1eOxeG8mkmjzBBbo0srR+4XJr5ell6l8Uj6CWJj9 k+tPiF8QvC8fhLU0TVrNrp7ZkiWNtztuHf0r849TuETX7u6mRZUM7b1z/BX0B4f+Ffj3VtM1 PxHc2Fza2sEUhkW73K7MvBO3r+eK+etSgC6lewF85n2bscfSvXy6hClKSjI5cTJzlE95+EPj HUfB3hq4t/B2oRx2l9OJZGEYaVWx93B7U7xp4i8ReJNBvm1G+vr3YpL5DOiH8vlre/Z7b4Y6 b8JdV1TxtBEtx9uZEuRJ+8zgbVVa5Txp8ddXa5vdO0vU/K0WeP7M0K2qIZF/2iO9P2UpV24o uVWMYcrkaHhTwR4s1ySx0SHTfs97cWi3EQuZViSSHH3wT0rK8J/CrTvFXijxRZ+IPiBp2laV o8yC5uEPmG5k/uKAeV4PP0rzfVPH0sdksFvrl011KNgd5WZoYf7i+3tTfCfjnU/CV7PfaJFD cvcQ+SyXEatjnO4buAeK6I0KkLsyVWP2jUu9Y8NaJ8Qr2x8O6m11p/meRFIybfMWugbUrS2E iyTYEq/IjfxV5rfx3moa6+sXb2ccsz+ezJKjhf8AeUciug1m4hW0imD71Ubgy/xfjWs6O1ya VRLmXQsQfD6Hx74wXTpdbsdGhe2aeS5uidny/wAPH8VWz8DZNd1eLRPhvLqXiiVflkuFtTFb xv8A7+SNv1rd+D+neEPEXi6zHjMb9NjhaXYH272X+Fj719w+E/EfhXRdNh0jwrp9rZR+Usot oRswv99z3yP5VxYzHvCe6jSlCFTc+evhf+wlpVq0epfE+8bUJB839n2jlIV4/ifq34Yr2Dwh +zJ8K/Az3c2l+CLTUXvZTOr6iona2/uxx5+6o/E+9d1ceNdKsZEM2pW0SyNtVixY7vpj3HtV bR/iRY6pbateefHbR6dLtZ5cLxgfXdz/AHa8OrjsTX1cjuhHD02RX/wx8GazBb2Os+C9KvI7 Vg8cc1urqjf7NeT69+xh8Ita1y416G01G1N1I06wRSKtpG/ZQmN232zXt+g+LBrVmt9EsVzu 3FZVONyj+VWrvVXW+W28hX2xb0ywXd/dFYwxVentI0lCjUWp8T+OP2Pvi3q1ve6kuo6DJBaA /ZrG1jCy+Uv3Y1cgnp2Jrx7RvAnjHw1pU2oeL/AmqQaA0rFLuVdrxzchRmv07hvtTdPPks4o Ru+fB+8v+Ncd8XdJk8YfDLW9CNjBIrW7SxFTkQyLlt2PWvUw+cVYtQqHJVwUErwPiH4Lanpm h/FbwtqOrypHa/a2jkLnAQOjLkt+NffllceHNVSSLRdTtLjyhub7PcpJtHvzX5waT4cj8R+J dL8JXt0Yk1C/gtZJYWG5Fchfl9OtfSGo/sg6x4P8N6hb/CHxHewarqMP2S9bVZyoeLd95GX7 rcVrj6dOtKM5ztcrDylCNuU97v8AxZ4M0xZrnUfF9lbww9Ue6jKxOv45zXyh+1745+GHiay0 DVvCvi+DUtSs5mjnS3cMEibk9PevOPHn7I3xS8H6K9/dQ3fiG+uJ41RbCVpWj3dWkQ8lc981 HqHwUn+G/wANvtXxF+DWsya/f3Pk2eqWl6GjVm/1avCuTn69avCYXD0ZRqRqXMa9apKPLy2P JtR8QLm4+wTylpm3LIrMHHT0+n61U0bwv4u8XXkdnpGiapqk8rfKscbyNg9z6D610ej6uvg3 VtK1m78PfZ9U0W+WWe2uYdyTAN9xlb+VfYHwf/ah+Elna6v4i1nb4e1XU591wiWZ2QRqfkjT Axtx+pr1cRialCHNSjzHJGnGpK02fKep/sw/GXQvDU/i/wAQeFJNN0y3dUla5YCTLNgfKOa9 W0H9gLxVfaQus33jDT/LubRbm0FtG0hkZl3BGBxg1714j+O3w3+L58P6RY+JbYaGLya71Rnn 8kqIVwiyB/4SzIfqD6V1nwi+J/hyH4frZXfiPSoLbRbyezW7kv0dAobKEuTjp05rx62ZYuUb pWZ2wwtBa3PC/h/+xX8MfEHhCHWLrX9ZnvwzRXSoqRpbzqcNEycs2DnuOorjv2iPhP4T+Fun +HtN0fwxp1te3V0xkuUnkeWWJe7I5O39a9+1r9or4Q/DXx/Nex+L9MvLDXoPO1G2sH85IrlR 8ko2AjcwGDz2Br5T/aW+P+i/GDxzBrHh3TpV0/TrM2tqJV2Sb2OWZua0wcsXXqqUr2HW+r0q Xu7nqH7GWg2eueL/ABDqt5pMd3YRW3kIjRh41dmH9M19SXvwy+FkEEhv/AWiRN80ksrWsaIE /wB4/dr4B+CPxI+N2j6bd+Evg/ogZ9Ql/wBLuvLVju/hG9uI9v8AWvTj+zf+1X8Q720fx/8A EF7SO+Ro3jF95zon+0sZ2sOfWpxWGl7ZydRRHQxEPZ8qjzHqPjTQv2PfCbzR+Jn0xLgr55S0 vJHOP9kKf0rw3xb4r/ZCgu/N0D/hLLkSD/VWG1Av/fwZNeg+E/2LPhZpt2V8Z+JtQ1m8tZdk sRkWFJV5G5VJ3dq9m8PfAb4L+FVgutI8A6RIIEBt7m/kDOWY4x8x+aso16WH2nKRXLKr9lRP grUf+Ed1xpNS0fTL6xtFfbBFdyBpW9GyAPyrU8FfDXXviJ4ph0HwwFnvGj86TzX2rEq/xH06 19E/tY+BPBz2s3i228Qad4e1Ozs1EGi/Ioudp52p94H3r5x+E3xw174R+Lm8V6bodrfTfZmt miuWO1t2Du4+gr1qVaeIoc1H4jkajCfLUPYL/wDY8+I9qmLLUdN1GbZjyoSw2H/eOBWNcfss fGuyt2lbw1BKGXbiK4UtjI7E1f1T9vj4v+K5otA+H/gqxgvpSohENu08zP8AxbF/iHtVKfwT +218YQLvxDqV/o9jK3nRrcT/AGQBmz8uxfnHfgiuWMsXT1rySNZSoyVqZ5l4o0TWvCsM9jrM K2s5fY8YZThR/u152gDyZHQtmvUPif8AD3Uvg/cw+HtR1yHWdQlgW9uLhGLLvk/hO70ryt03 vvz1PbpXr0Jc0OZHFL4h09vOWVyrbc9RWpYXBtkUREZ6bmX5hWfHcPbN8915aj+Eru3+1dV4 M8J+K/iNerpnhnwbearKu3zZLI7Vhz93ex4H4kdKqdSEI3kKMSJdW1HGBKAQOixhTV2LWZxG qEKD1LBjnP512Vz+y18StCu4LrXoNVsbJl3TPb2y3kkXP8QQ/L+NeveCvgz+zbcabcaXdeI7 /U9Tdl2zXcotXi3KPuqcBufrXDPHUKcbr3jpjQlI+a4PEc0VywlXz134cBu1Wdbmk1DT99lI ZVJ+dFb/AFf+NfQXjz9l74a+EfDtz4kg1jxHqIViI7eyVHYDBIZu+33r5hN0dP1AfYy8aREh mfjj0Oa1w2Jp4n3qZFWkqe4+z+028rTWZ8xnXYy96fF4iktB5NxCU/vKy1s3Vno+qBX066hj 1JU82WBJgUZcfeVgfvf7NV54zJELfV7LzVHys2MSL71088VoY+z59UVbPVoZy0akFJB8y9lq xp2ux2EP9nOm6SJto2/xDrWW+hvDL9t0edLle8ZO1l/DvUOoGaGXzIo9rSqoP+we9Ve5PJ0O gvPFMFq+wI0sj8Mq/wANc/b3zqLif7GmJGbD/wBxqW3htraLz7hivOSwGSaALlJlW106W8j3 eY6Lx977tUHLyjI72aIwm5sNogX5dvf/AGqvDbrEmyO/jgKIzhZF6n+7Ve41NEk8vUNNubRz wu4ZWkcpFIHt2Xziu7fj7tG+hXL1GalfC0tPLTas+z524+Uf3a5ouFmt53k5L5I71tzpBdq0 ezfIo3v6tWDMFurxIrWBm/hVFG5qaXKTJHf6bOpiVA/UVuq++JERVcJ8u72ritN0y/tCiXs5 gz82xWDP/wDY/jV6TW/JD2tvc7EOQWT55P8ACkZ+zNfVre2mRkupI1OPlUHc34LXOJcQ2kge 3h2yLkebN95fwqaC/wBpzHCzt/z1kbL1RuQSzm4++5oLiuVFzTbkXF280oaRk/5aPzn/AHa3 zOGVSHxXIwPPaKwjmRIh2pr+IUhOHvE3d0UZpchn15i9pV+ItQvbaR/vSMyA/WrE88lhqC3y KrIRh1H8VcxBqlqt4syQzM0jfMzV0lu7SXsEkEfmusioqPwuD1pSia8xJq8lpeaQyOFFz5m5 ZGO0+XXMQ6pFpbKqzpOM7dq5O0fWtpZiZb/S50XfG7lT975f7tc5DpMySFzAFVecSfLThsOT L7eINMDM8Vjubv8AL3rPvtXfUYh5m4SJ9wKNu361JNp0NqnnXE5C5x8oxVJ9Rt7dsx2IGG6y HG6qUUtSOYW10+4mZSsDSN/umtePQHjVWvJILcfeO9q7LwR8Evjd8Q9JTxD4Y8GXsmlM3lLM xEKyeyhiN31FUvFPwxm8H6tDoPia+eLVhzeWm9GMDfwrvDEVj7aE5cvMaKEoLmMnT7bQJbhb b7XJcs3eJdq/99GrXiHUbPw4yRadpASYhXzPET8jdGG7r+WK1tJ8DeI/EOt2nhHQdGmguLiL 7VCZVEZljXktGGx5jf7I61T+IninxT418Y2Z1i1gg1LRLSPR5LXyBGxVM8sh/iyelLn952Y5 KVj0L4DW2s61Za/rmr6Xb+KdCt08rUdLQKL6CBv+W1uAOCvtXvfw/wBN0rxrpUPwxv725vo4 M6h4P8SwLieILz5cjD7skfRlPUVyX7O/wh8P3OmTeGU1DU/B/wAVbCT+0YpXc/vYmXcm1fuy Rnpt96+ovhv8Np/Culy3lzYWtrrWov8AaNUFqf3f2r7rSxL/AA7h94L3rwcdiVzSR34Sn7uo aF4c1WOx0+88TPaX+sWsTJLdRQD5z0GCRuG7jODW20MiyKj2mP4l8sbGX03Vrx2eoRz7XulY FeGyPmp0lteTxEyI6uknyhWHzV4c5c7uehZLQzRb3DDzy6tKzKfLZzt/+tUH7K//ACRrSf8A eb+S1tLYTy/ObnKfxtj7lYv7K/8AyRrSf95v5LX0vDzuqny/U8TObe5bz/Q+RdU1HT9eZNfv 9Ghk1fb5VxPKGdWPspyN3+1V3wr488U+EHmv9Et1Dzr5caOoJA/vZqit1P8AaJNtpnyujbtq t/tbame8u5nWRofLk2fKoTPHHavn1VfwyPGVWrz80pG5P8Y/H8MGoWV7brPHdWrRymUfMqn/ APXXyvraxW+rXMksu0SPuzt9+te83urOgR2k83qpdfm+qtXj3jKyjfVGktkVo3yvPrXrZZKP M7HThqk5z9+Rg3+pQ2ultHavLv8AMDmMH5f97FctqOtytI22VsHrXe+HrSyTWLe11CJXt7pP JYN2Nb2j+DfD+qeJ53i0iFtM0zNtnZ/r5m/+Jr1p4qFB3kVWk1I8x0S60iaHOoSn7QXwpYYW pr3RdWMsdsyNDHcvhJU+ZGWuo8ZeEtA0HWLm3soWktrmMC2IH3Jc1250tLDQIrPTmid7G3V1 jddxL8FqieNikpQ6h7SLj7xzfg74P6ZLeNf+KNcmWKMgxx2qf65vTcfu074i/Y7LUrmx0y2W K0UgQRKwby1x/ePWu10vVnms4JWg2rjA8sfJu78dq8/+IkkQ1OQQkuu1ScCsaNWpVq++Kk6i egvga5jXVLT7RJ+53FW+bHavcpPH+tq8LafqTwBLdYCqLsJiXp0+9+Oa+ffBkX2rUYLNn2rK +QG+lemwiS3fbDF/qEwxLVhmEYSnqFdy2idZZ+KdcguxeQ6iDdox25b+H3Xoary6zqsTlxev 5YfK5b+8KwBcebB5TugJOc9D+dMV50Z3+0fuwFIbryK872cbWRyr2i1PR9A+Jer6JBbNNqV2 62qPHFbxS7E+b+Jv71P1n4563d3UNy11INlwZo424VQPpXmr3c1xFveHGGxu/vf4U1LqFYZ4 7hPmxuRWqfYxOlVKrj8R6jeftF6+Z0S0cRuj+Y43Fl2sKzJfj74sEc0LXHmrcwmK4VFGNuMf 1rzVJLUx+coVedpAPzflSjUrCNJCYeF+XJpqjTvdRBV6q05ilaaRpltq8V7DO6eVOs4XOCWD Bq9p8EftJavo88sWqGW8gUbUSST7q/71eLMYlk3yRhcjcG3dVp8klqG8mGFSrpkfWtqkVVhZ omOJrRl7sj6Vt/2l9JYyC7ijjt7mDeIxJukVwSPLz/tdfauD1X9pxbi1aw0vRgtxBIXW7PzE qPuhgepFeQRpZAkfdYjd/u0wfYLdFWCPYzsdz/3v96s4YaC1R0SxtaUSHxrrOn+Mteg16+sr UXkgU3m5MR3DAY3Y6Zqk/h+z0tpEe0h1PQ5mEy2UkhVoHb7zKwIP4VZvIra+KRxeVjP8PRql jsJoEzAyufmU7+eD2rvjVnCHLExjXn9oS7uvh7q2jahozeG/sau0ENm9qxV2SPJkDls7txb/ AMdrnV8N+HLqzk0TT765sLW5dZ98g3kup+7jgGuiaxSKNngh3jC/Ntzz/nNQ2+li6fZb2Zju o+U3fdf/AApqcovVh7TucR4n8G+D/D2kyi31KW71OSRVRgNir03bh+dZ3g7wPN4mkmmlnFva ICvnhfvydlrrL/wBNrVw13eT4O9i+0/X5a6Tw5pX2G0NlBIkjRfcRRjB/wAa6ZYvkpe5LUOZ v4R3h/4b2/hu1vLqw8ZX6XU8G0rbAoAeMbufmq94J8Cav4X1X+3IfH2rRX3ln97bSurHJB25 J5HFadmkUEST3LPHNt+dWOd1X0R1aSSO4V1K7kVVPFeTWxFZ6thCU4anIjwD4oufGf8Awles /EK/ublZ/PiuhIxlx6ZPSp/Enw88S+Ktcj1DWfiJqV1ZK4FsZ5neeE5z8uDhRXWC6KET+Wzn ooYZUrVmKJpo2kSArHKNqgfL396x+uV+bYcp1jivG/wlvfG3i0ar/bUscPkokks0zzzMyjuX P93jrUUvwI0CWzeEa1f+Y+CkgA2r/wAB/OvQpBewxRmIMsMyM3zfe3L2pJmntXjJi8wSLj92 CSNw4WksfiU7Jkc03ucPp3gXxX4J8MXelaXrWn6m8MjTWcElqFlikwP3kcy4dH+h7VZ8E/ET 9oXwVqUupeIPFV5cQTQBAL8tcqrZHJbqjYz83vXXEQTSsUzlcM2Sfl/GiVb+KRjHL+6dhvRh uz/kVSx0pcyqR5ioV6ifKeLfE7xbf+MtUuNa1WZJZJlEQZZCy7V6bTXCqhKgYwfXvXdfE+yt tN1u7s7S1jjj+Vti8IpPPy1xUUAc7D0z9K+mwzg6UWjsi243Z3nwNsrabx0ZL3SrS9iitHYx XMYlX/ewa+o9F1//AIRz7VN4c0TTtCmvtrP9jiESvtPy7se2a+PPCvimXwPq0+uWpXzFgZIg yFi3+zXfaL8e5riz1LVNd0J42sE3wRowAmLcc5P8ga8bM8NXr1b03oc9SU4y90+lE8a6xfO6 tdM8k3zSIjFd3+961xHjPxt4WtrSVPFl1pkRRdsIaNTcBf7qkcjvXzPq3xm8e+LL230rS7yH S0nkWJPKbaw3H+J67fw78ABqMX9r+MvFf9oThstDBLn/AL6Y8/yrnjl8cL72Ilb/AAi9rO2s ircfGi8ttT+z+ALnUFizhzcXB8vZ6KP8a5W/utF8Sahcm8muIL27lIZkG5XdjzivojTfCvw4 0bTHSHRba2tVjHnF0DF2/wB6vm/WZLCHxZJ/ZxRbaK8Lx4GNsXmcfpXo4LEU5xkqUfhNIzco anqHgjwL8PvCgM2uafdtqMf3bi4X5Fz/AAgdKk8Y+DIZt+raBdRXNscnCtllH/xNek2kY1S3 RRCJ45FWRS+1l6Z/lVG78E6LM0k0Qa2Cgr+6cqN3oy150MwftueZnTqxhLmPnW/t3snaRj/q RuLiquk2F5qFkNQMO6HzWVpGPy816n458IaXoclpNe77y2uDsYMM4/3iP8K5jV/Dc91EE0x4 ra2Krsj3bQv4V9DSxMKseeJ1RfP76MyOxk0pE1GOVZIETbO0YyNv93JrOsdQvI4fMtImkmuJ dxQjGd3Ta1W9SutV0S3GiWg89HXcw27t1V4tK1NLUGZzFPtDpFnhfx/hq7tjZJqt7cwhrC/g Vro9Ff5jGK5jZeNeNbQxyTrKeqVu3MwDzX9y0mpXCpiUWw+Vcf3mP9Kwb/X7y4t9tuiwwt/D H8prSBlK5pRWNnp0izXlwzTf88oTub/gTVL9pmuWb7LBBZJ/eRf3jf8AAqxNOcyMo2ycjr61 dmvRYxMI7Z3b+ENkLmr5eiHzaFw6WWJZpHZj3f8AxqtcCCyGZ5o4l/MmsS78Sa/eL5BDRR5x tjjNZ7W17dndJbXDj+8UJFNJW94jmNyfxNplrg20LTt9dq0yDxD/AGkGgmtViPDLt71lrpd+ BzptwyqM4WE1PaaZrDXUYi0K9C9N5iIo5YdA5pMs6wtzMq+UjMv8Kr1rLTT5lIzGQfvEntXV XVprtvF/o+j3LMi44iNc1Po3irUpjI+m3e4D7uwqKqMrClEmgsEkI33IPf5a3xIjW/mLJ0Xd x/s1kaN4X1tm8uaMWwc7N0j5210+r6HZ6EY7Cz1aPUE8lXaVVx8/8S1EpR5uUcdjBuJfs2pQ X8XKyJhs1f03Spte8U2ujWAdo5xmSTGfLT+N/wDgNUJgJbVXcfcJQ16Z8M/D1zYaBe+LTcKk F4raVcShdzWsbgYmH0OM1z4uoqMOaJnKbjHQxU+Huka/YW9xp8t7eXV3rL2luSdsb2MfWRuP lZum6vYvgl8PPgz4a1S5uPFnhyXVNVjnZre01A7/ALHHxtyvST611ng3w9o/hzQLXRYrhGS0 i2C4YAs+Tuz9Kdrmh6Vq8hmmleK5jTdBdw/LLG2eh9Vr5jE5pVqv2cfdickMTNSPdrX4i6Jd aY+lqBb2yI8Ucds5jGzbjgD7pr54vv2aPC/iG21XVI/HU51CQPJZRTR5dZc7l8xudy8Yp2ne JpdFmTTPFqIplbbBqCcQT+it/daultdcjiMio21SPmYHDFMVxQxNfDL3Xc6XmFSStOJVl+IH w++I3wgubb4oaW9h4m8B2pUT2brBc288XEbwsOobA4r4z02WLxf4oSa/ursXl/dhZLwsZJZC zZZ2x/EBzmvVP2gNZ8NSeIodOsGaK7vYCt60TfKy/wAO71o/Zw8AxLet451ZB5NuWisVfjzW 7t/SvoYYhYXCOtPeRpWxd6cWfaXws0Cw0W303S9Q8VReI7vTYd+mavMNlzb2jAbonbq2Oete n22sWNxcPDHerO+7fxNuGOlfM2mapcI8s8Vy0P8AyydCuAyelWIPEVzZS+daXBjaLk4PJHtX y08V7SXNI0pZtyacp9LX+r6fZzRpNfR7W+U7W9enGatGSG3RT9vCqwYqfM718vX+rahqTLev cy9dw2t81WZvF/iH7LCgvW2od7IRy61P1iPQ1/tmPNrE+lBfW628k6zj910QnKu1ZX7K/wDy RrSf95v5LXzw3ijVnVi17NH5v71l3HYtfQ/7K/8AyRrSf95v5LX0/DdT2ntf+3f1OPG42OLU eVWtf8bHx4ZtVSFo2ZZgpx5si7fl/u05Uuw0dxcOY0dvL2V0aKl5FI7yoyO3ymFcfoaleySa MzPcKZEjK4UcbfX/AD714Mn2Rxe4YaaRbW9pMGid2TlFPCnd3NcD448OC1tY72NG2swV2x/F Xp0l+083ls6rEy4eMDkn61kavax6npVyjyI6AHCs3zKf4a6MLOVKrzF0l7/MjwbVZPstr9oA ZZUfEL46PXo/hCCyj8J200E0s82fNKAf8tG+8zH61zFzoqXl4kFwGVkbeg7bvSrOk3F1os72 plaG1uG2sMf6tq9zERVammjuqQ9rDQj8bMltNpsVzEPNaVrh1HO1M10Zjt4bZFt0kkE4y7L1 PtXNwvBquuax9qlWUJb/AGaOVv4T1zV3w3rjf2GIEia4kRjBtJ+6wrllFxikcso2hYl0uO9s 7mTSomSM7/PiLtxtrhfiLd51adgV3JtVgvTdXcXcskckOp+bHFLBu3qef3deR69qf9pX80yP nzZWbNduDp80udm0U7XOk+H3OsJLKceWjMfauylvROziN5Nzc7t2N1cp4LsniszesjLLK21X 6/LXS29jHDCslzMzM/ODgYrPEyjOozGqnJ3H2t3KAgvZPmC/3uFqU377GtbR38xvmOfu1Vaa 0cfZzDmL13fNmo5r6OMLNb27cDbu/ixXL7PUUdI6l6AahFM1y90jMwAVOw/CozJM8ZmmkB2u eKyZtXn8wYcLuXneuKbBdi4UJLMyAL97bV+yDmsS291Osvn71WTeTjsVpZr+eIA3UfyOOq96 po7lRCXV3LNgjrtqFZJhE0cwZwPusR09qrkJ5l1NZ7qGa1Wee5k+X5Nq/wAqgv7t3ZZ7e42R r29qzpZpCPL+9Gu0c8bafe3EKLCcKrL8vFHJ2K5kPM87XKosmcLtJ+tQ3N/dLJsDs275OnWo rO6jgkdJJGaTaWQ4p39oTS3fkmHbsHyHHfFaciWrFdj7a9SOGRXm2qH3c/w1cg1q2Q+YZ9z4 +VeorLe6gnKx3dt94Yf86SSTTFKiL5ecIPWnyRlsI27fX5ISFih4kXc7Y+7SHxPLBM8LxyLt +XctY13d2dvN9nQ5c7c46igamYZGjeHeGH39tZOgrgdRp1+jojgjdIpKgnqc9TVq3v4YkIIR pA247eK5VdRSCOMnGd+9D/7LTH1SIP555+bcdn3Kj2DKUuU76bU0FrHFMiOVVXwR938anGuL cKIYIY1fb/qy3WvPl8QJcSLCZGAiX53z97/ZqWDVrV5JFhdlk+8pz92o+rfzFe1PRbXxIsMX kTQZRn/1RHVqjh11Ulea4l2x+buCr02qc7fauEj195ZyIRulUYbnk1C+qXJl2vJsYfK67fep +rMPayPVh4xtZniEtr+6VdqbWz/nvU0/iOKzaObzBuHK/JnPoteZW1/9il3Kd8attUdV396t NrlpLMRI7HIZkKjGNorKWFe5XtT0y18TW9wUitoE8s7ll6dcUkWuWCtBISsn8DKB0Ned2mr7 ojNFN8xw4GcfpU1rrNs7mAttbqdw27WrCWHaeg+eO5zvxZhil8QTSiQMssStnGPm9K4eC3OA RIqlzx83Ndd42nXULwNsZQ6/KWOdp/u1ySW3k3Su67lX5a+lw2lKJ2Rlzx0Oj8CW1lF4lhk1 aKGWzlVopUcLJ+O2vWGufBupJHbz6Sk8FsNiubXK/wC7wK8RinFhrNjdq4i8uRQ7Y7V6za+I JYXYpLiMsGPG38a83MIyVSMk2ZVHGO5zcHw/+H9vqL3VrDfGQymWJRFlFfPTaR8341Brfgjx UTs0PU7mxWYlp3jRo/NP8PyqcdPavQF1xo7i3e2WP72XbhlPvUcHjC6uLyVY0SVo/m+b5awW JqKV2uYy54HH2Wg+LLXwhNp2ra9czRoW3+chdVC8/ezurirvTNBnAlGtwxCUjKEFjx74r2TW vEhW2MrqFaTaCFX5Of8AZryTxh4c/soLqIu0uQzYYou0fN7V24Kt7S8ZKxpCpB6HpQ+J/g7Q 7CztL7UmjIiVMxjduRVx+FWbT4k6NrVupsby4kikOd20fNXlPhfwx4U8TQq2sQyLcWMuGWJs CSM/3q6GTQ9Dh0+TTdAnvtwLJHBbDcoX3Y8Cs6uHw3Nyte8ZtQs7o6LxL4me7EWk2drKrysu xpOQWqrr3g7xBomnm5lvJHmZS7qvKKv07Vyl34d1XQ9Ntro6syrZP5qxu5Y7+q5b69sV1esf Giy1fQJ7O60/Zfy22xpUf5CR71UvaQcVQ+E9LCTo+ztI8+1TVL2OJZs7Zk+6vcVUvB4i1Jdr 27Ivlb3dnxu/2qwrq9ur+be0+6aVtxbOOPSpDr2oW8fkXCmSLGxxv5r2acbJNnNKSloiKLUp 9OEojbc3T2/H1obxDexx7Ehtz6ZiBq1FH4Y1aPZa37afMMDZcfdJ/wB6np4Vv7Z3mu7d5Y/+ XeSA+ZGT/ebHzY/Cr91GclJ/CLpmv6qzKEkjQ/7MS4qLUvE2srcRwrfsF3/NtUGq8cb2hYSj HODkYzXaeB5vBSaPNLrJhkvbqR4d8qfLHHjqvvU1qsaceZLUmUuWOpjanLqCW8d7oWuy6gqx brgBAvl+2anfTNZ1/R01fwT4imuJokzdWEuBLG/+x/eWqdzc6Z4J1oQ2erW2o6Xdj50hfLKn 91h61d1PRho0kHjDwDqnEvzvbb/3sf8AwGsm5NKUBycpRujjZPEPii2keG61G5hkX5XRhhlq aHWtWkeMPq1ye/8ArK786l4Q+Idq0errDY60yblK/KNwPVf8DXDw+FtRsvO1OZYns4pvJikD j5uf7vWtqdaM1yzVmZxlLqaU+oNHF5lzfTbm54laub1LWJppmFpd3SLjnEh+atq/09ryBold It46Oa5S60+S3umgeZCqDG/5tp/2a0iorccpS2NDRJZbqfM91cPt5CK5+eu0bRdT0izSfVLP 7NHP88C9X2+9dN8M/Buk6NYx67qVgwvJV3IZuka/7tXPiXqFtepa+TyiK2GxXn/XVVr+zijO nV5pcp5rKqeSdmeZSfevZ/gzqaXGlahotzbEwyICxI4bdxtYV4iWC+YIzn97jrXqnw+vJbSz uboPhmZVXn+6P/r1GZpqjYdWShDU9J8Na5c6U83hq+ljMtgc2spGTJAen/Al6VvXepTTo0iA jj727npXler3VxI0Wqxzr9os33qDwZB/Eua37fxRaXUavYyymKWPcTIOM9xXy9bDt2mjhl72 sTsp7uz1DT49Pu4ImhMZM4Zd24/0rkPFHiaz+G1gb5bqS40/GyG0mb9/E7DIIb+Jc9u1Y2qf EHSdCsJLi8ufLlLb9qnc0noMV4z4h8Qa98SPE6u+6V5TiKFR8kae/vXoYPAyf7yrsb0Y+7eR a0Dwz4h+K3jCS7mglSK5lMtzclPlVOwWvqrR9Ah0W2s9FslSCGONUVUb0Hv61w3hSZtB0i10 +3jUC3iCzNH8q7v61rR6yZIproXTSS/diUMPl/zmubMK0sVLlS91GUpe0OsIimufLlvP9UjM QP4f8abd31rA0ZiztdNuV/nXGwateW9359yyL8m5kY06TUmvGaGObbMy7kcn5Vrh+rKRjKL2 Owj1KdIv3MuV6Ke7VN9teWNSfmZFzj+LFcbYXt3DDsuAqhH+/mtCXXBHI0jK0E23auf4qn6r 5DjT6m6TcXVrvV3VpV2nJ6LX1d+yv/yRrSf95v5LXxrFrzxLIzujFtuws3Svsr9lf/kjWk/7 zfyWvpeHoKHtLL+X9SoK1z5Sa4eeJGmRhn5Tj+CkudRmhgE8Um6OIbMetUN0l3bTXsRa2WWT dgqWXn/aqN5FtoRbTRSH+PKsOvrXz0Y9zWUEg1W4u7RZfMsyjMwZC1czc6nJDdNYvgmcZdRn +GugeKa4EdzqUjyqg3fMeZPQVm/ajFbz3C20MkmWGeNyf71dNJa6hF/ZOT1Nr62u/tWx2X+6 33ttXJTBqGmTXiqdkSEsGHU4rWaRb+BpXEbMwAV1TpQUtbWNYbh4cudqxr/6FXo08Ty+6dVG v7P3ZHn+hwTWumSXNxEwS4dm3uv3R2ptjFLHqzQR3m1JV85fL6F69CkWKXdF5IaNfl8tk4NZ OraRBAZTYW0cVztARlX7u6tvbQmypTpy1Rxni/WzpVk2mrMsl3cridw33V9K4nQ9HvNauy0a MIk5LHvXTXHgO/vtUme7ud8eN+4t9/2rSsLG/tWW2jtBGm3bt29feuuNWMYcqJ5jZsrfULe0 EARIo4U7rTZzfxMi28Qmk25bb92nW0F65AktnlX7rZatJtDmNsvkSyYfBcr/AA/7NcT5Y6mT lzFd3RIoUktoz8u7YBzuqnIXlcB0ZET7qgVqf2RIzBlmdfK4wq/eNC2ckLtKgK7G2sX5oT6h IwZ9LnmZ5DGWjfGHx0qvcaMYYN808uxvmC10xt7m7ZjFMSgxiVlxt/ChNNkvN001zmNG/hX5 mP8Au9qftLE6dTBOjpbmOaKN3mxsJJ+6nXdVaawubo5gEiuDu2t0Irp4VLtsk/d/vFWXd6f3 aZfjT7Voy8zRfL2ao9pLoL4jjr6wnaZXHHm/MY891py2EskJSX7rngsOhreliS7tLq5W02pb hPKbd0OfvVHHIFsDPIpCl1Unb19609rdD5TDj0kxX6JKhjKqG/2SvrSXYjhmmumOY2G1COqt WvNIjztKsbsqKEVW71U1C3juZ/MYeVG/yhMZ2tThUUviDlMdIRMEYzuHZgvzd896bdWUSKA0 ybEfcu3qa24dLnluDp0cUbeZGrBiMlW/2f8APeqs+miMsJQrC33KSy4P0rRNJ6AYCRWpvXea bLOPkbNWRcxwp5COxPRCTUsWktcLGtshm8vceB/q+f1qF7aT7ciPGrhmAG0YUmtdGAD5bVQ2 fM35Ab/a70zzjbwGyeHCcs5q3bzs6B7iHKK+0ZHRl6Cqk8c11eM8q4V9y/7O7HSjlD1Kst3b ebG+wmPdz2qZRcxL9vV1hh3beW5YU+509BbLO8qJwpRcfK/vTLmGOaGJA/mBHyA3A96enUBy 6nIsymBN7q+0uF/h/Cg3t7eNJIr/ADpuByO1NjhWK6mlBZVcbsL8q47LTEEKKxM+HJGSP/Qa fIgFna9ihUNM+H/hU/NUkF1eIqNJL8u7G7qVqY3FmlwiShmSLDNu4IX0qBNSSSd2WLy4mDbh jqtK19ANCC9kkuBDDLtIwSfWlutWbepLtuSTnj71Z1rfiS8W4t0IDfw4+771Lq0PlTFcs4Zl dMdc1h7JcxUbGpqrpe2qvBIxeJsuD61miLzV3EEEDOKmktWtYlnuZ3Uvw0Y/vU6EDzEjIPz8 YxXXS+HlR3UJe6zN1NI3tgwOWHWum0y9e6s7eaaXkLsO7+IVkz25USQiPHvjPFUdPkngY27T Y27vvNwKmvS9pDUmrDmjzHcDVlhaOySZRHEPl2io49UgJMwkUb0wSOzLXP8Anx3xjRYG3w/x o3DVHssLJ/Lubp7iR3+SJPu/99VwRw/Y5eW5vvqToNwzMzdR2z9aw9XB1FI7a7YyBPm8qM8b v96pLi4nabylmjFuqbjFH92oJbzz4vkZFCKdqL8qrWtKHs5XRcZxi9DO0zWFt9QS1uLdIrRn 8uZVOCn+0f71dat7JZvM1vMscKsSQny4rhJLaSWfIRmkl/hHf3rTsrjzJI9MMyyeUMszNzI1 dOIo+0fOiprm946CO6a9uft13bPNBAMwQN/E3Xc3rXNeKdVgnmTS47RGWPc/yLt21s3F1PbW 5vZ54/kX/V7v/Ha40vNLMJ5hma5Z2Y46J6VWEpNO8gpq8rszIUe3kaZV+VhkY9KluLL7Xb/b IJPZ0H862NMW2hts3Ue95X8tBt4VaszWumWm6aCNt2MOoPy4rq9uublK5oc1jiJbQKRkZ9jz W7ouqXenSKYp38sjBVWNX10fT5Cs/nMsch+UKtOvNGskgZbF28xfl2t/F71Uqyk+UOfkkXJd UublleZbe9tHbY7vHhovyrSig8OWsIRNL2Rt0EcrFf51y1lcTWrNHt7fOrfxVt2c1rcW7CLf t/55fxKawrRna5U2pasYngfw7qGpS6kl9uhcbvIYkYb03VTvvCs1nO8kQcRS8KEQHbWnHIJA qJIqlm27CcUg1S9tS8ay7djd2zurP280tDLmSObsfC+nvZ7ZryZNRe4CohTEar/ezU82mXmk Xn2K6lSQffQKB931zW+2tWxQjUbCGRtud8Zw1Unt9G1BjLbX89tI/wB1J13L+dbUpyn70jSP vbCaHb6bObxNQTzJpV2w7m+7XQy6fo1lo0enWdtE4aWMs7L8w5BasODw9Mj/AGkuLlU+bMcg qW51A248pw6KeULj7tc9ZzlL3TCs3zaHotrf6ZMxaeZc2wACY+8K5fxzcWtzJGbVMJsY7F+6 tYUmoypE0zu/zLt3KMBveql5fO9kyMd4VPvYrHCUHCrzsVG3NcyNOVLi6bKfKjb32+lekeGL y3g0CN1jZ3kdvuDO35v8K870dHhtLmaMsvmc719f7ta9heXttGqSXLxwKuVWH5dzf7VdeOp+ 1jyl1I80bHot/qOgQ2cU2sanBAo3YJIL/lXA6r8QbOwW4h8Oh4o84iaVfm/2uP8Aa61zWq28 ks001ujuVx+8fnFWtO0/SbOY3F5N9rk2A/Op2q/pXNSw1PDwvLUhRjBFK20XxB4ovBM6SgP8 zTyj5Qtej+DdG0/w2v8Aots0s0vySXLL972WqVp4hhFtuYDciqOOBt9NtWpvEdm4DmSTcPmR BxjiorValWHJFWM5SlL0OytleC3eS9kUM77VVf4R61ZsrkyzMiWoCQjflm+8K4q28U+Yg8yK SQqM7T/EK17TxfbOxJhULFFgcc7q86VCaVjLksdXaXCvO6XNqqELv3Ov3l9KoyapbQM0IjVf NbGSOrVkNr11Li5CxuWHTmrs98lxbwosUaXDfMRjP/6qn2TJ0kS3WuCxRjG7SN919/NZ5vXu 2jlupGjEx3IBzu/OtJbWzLFDcndFtZVdM+YfrSXVvZ27G2eHDJ8xY8/gopWUSuljIOoTJctA 7lI1b71fon+yv/yRrSf95v5LXwFFFp93GXjgXzPuAM2d34V9+/sr/wDJGtJ/3m/ktexk1vft 5fqTG/U+Qo3uZbNUlSSGNm2oGbCttqCZY4g2Dt3r8xZqlnuS9qkrQhP41DNnC/SooJjemO1F su5yz7j90bRnrXzUYyKkk9jOu5dQluIYLe23Dbu+9UdvaIsUomVtzSYcla1t9rqUQuJg0WRt i2nbvFNuYIZbGaNY24+QbW5NVGXK9QjFr3jPuZYLOAlQiW8S+UjKP9Y9ZNnE91dFBZ7ioyGb Of8APNbkcen3J/stRG0cDI8Ykb94r/xVcurdGuXK3SxBdqkKc+27NaqcI6mnLze8jKYi3WMF 8MylnXbu5qmXtWknnvEaWTbhEHy84qzd28ltOTDI0vzFcDPerUsUAMEOF8zhnbp8wFVGV9UT y+ZRFvpktsJriFWmdFRI0H+qH+1TZdKh8yNVZWEY+Ve5rQDBJnZNrB+CwGDS29tFLNJCZj8h G1VH8Ro9rJG2xnLE00OxbYRAnB/2uau2FqlvHMSSBL8hVuy1cOkkRmPMajbvZid2w+lJdaXM tujqd/lKGk57U/aJmc4NPQoyLbwqpmcgM3y7e9E86TExxBWCNu6c9O9SXFta3k63MkckKou1 FyOW+lU3zb3vlwiTDNtdin3lo59R6iTwWbxI4diWXdKo4rOu1cKWiiby8g4B5rWn2xXAt4Ss xl52r+W3d2qlc3MMtrKvy+YCBuGQM+laRmuhLXc5u4S6up5bpTJ5aN/Dy3H8NWZrCO9tgTGe i9R71rR2lzLYx+SI440zJIVbLFs+lBWSaSOeHCwKjbzVOo3sK/UPLtYLGTTZAhjaJnJA+8f4 V/nWPdzWM1otvvw8ByiBePmxWqNGmuzFcF2RdpkQAHayj1/Ssq5tMXsU0EbHD5K7cq1OMW9S vadyrAlrOrtJIq9mC/w96jazs5JvtoY7lIDp/BVqSwjhMskkcZa4UhtmVxz3qrDeuga1ZMpJ uxtX71XcbkSXDImqm3t2jTysMrZ/rVzUtHtoSVu41c3GHZg3zVknT5HL3bFiRtYFc89Plqxb 29/Km6WV9uflD5+VO4o16ijISLTbfTLSa5t5HaS73bUB4jX/AD/Ksl7B9UlNvZyIPs+GY8Ct K/S/vVkjsWZYkVWQN93b6etLpdt9ls5ZJo1haHDSMwy7/wB0L/jWsZOKumPm11MuTRzcyR2S ROq72kZkP93P+NVrp1sofLso1l875Tu55FdbssDZfaXkZGlXch3ffz1PHTsPzqpqfhezKQXc N3I0kki4ix8rLxz/APqpqr1kU7S2OUj8OXV9KiXU3zKdpRVyNmM0+bw9fxI09tHJJIrbbUqu 5ccdq7FrWVpby5SLACRhlBwqsVA5/WormCfTjCQ+SsYaKIMcZ/nWnt0HKzz6WDVISkE1nJLL OuVYrgZ6f0qnaWF7ny7i2kyXyFXqzdK9I1SJN6akkISFQWSIv8wZv7x9jmqunWst5rVk1pAF 8pCzl/4l/iatPrHuXJ5Wcuumzanb3LSWTRzIAzYPYVQuLAWTvCUbKw7UU/3mr0IeHbbT5btY 75breFECyho2Z2P5bawNYsrq1vzbh/NywEUjL8r/AN7b7LRTrKSNOQz9Ds0S2lubqEorKqxM 3r3FOuEU+XNborlnZPm7fX0q/NYXEcQt5PJmKtsBikIy1ZUUs8b3NxdI0kafugidA/8AtflV XvsTyMdcKXtW5Xcm55GLfdPanQtJPBHcsD+8GM+1MaPzrFJY4wUklETqAetW9Qt5NPu2sw6t bx4Vf71XS912N6EnF2C4QGFJvMCY+Vxnt61l3AsIpftLxySF/lPGF+taE+mw3ybAxVlwcZqr cW8k6SWkse1kXhj3rfodjvayK+o3F4kSr56xQ9UjiG1W/Go0MYj+2PMm37uxT82fWoQZpbcW wO+WIsAv+x7USp9jlfzYWRtgCKwBb61lZL3TgnzKVmNZn8uWd1cyOvy89qdBcecFt4om64c+ 9VXvHkKxxxj7pVfmxVu1V9KAupHWS4li228Q6rn+JqcYIiPYlu5/sUSwAhbl12s452r/AHay N4t5kUF0ZW25/rU4jkeZku5NkmN5DfxVXYlJGVo9zdct61tTa+Fm0an2WXL+fzzBbId2753b +9VR1e6uGEDY445x8vpSwyOitNs4A2LxyGptuTbSMjpuD8bq2soxtE06e6XLacW1sgRMtyNz c7abJqDFMGFTg7fz71Aj4j2bFZssPvVVunu7cAgKN9cqj792cz0lc0bW5MY+zTOpXdlKllee KXb7EgmqkALlASqsFJ6d6lSZrhWtZQyzJyrf3var5Ls1krle6tvLVZIXXOzc2abDdTwypPA+ 116iopQzytGQ3yrg0LC6zbMdea2hJfDImMujNkNBrKLJA3lXKL8y9FY1WkMxIjl+T5wgpixb EWWE7GTqc1cFxBqcX2Ugx3C/dk9amVJXvY0lThIz55o5pfKtkYhG+ctURu2JeNNqp6Fakniu bO5+yKnllRnef4/eq8rvKrqyLxzVc3J7sSW+RWRYWe5t0Vradlk9FrTj8R3EcIN3BFclflKz KBxWEly4dWTHycZxTZ7jcAZiPn9KwlDmdzLml1OglvtHvYzDPbS2T9R5b7k21l6myQ2rxQyF o9vye4qvEyPIqMrBv7p6U7WsN5UCDduFa0o2dzWElKN0OtbyJNPt7SEFOd031q4t8sp2S4CO NoP9azdNs41djcrn0w1XpIRNOiRjcERsjGKzq6ysZVJ9ES23ktIUUb1Y0ot7QIw8uVnZtwx/ eqnDO6HATbs+7VqO8hdPLkf5/vL2way5ZGV+5Ya1RLQSNGFO7B9aFMhtVWFPm3fMx67aZaTl 2Ys5YZ+63Sora7RGYzbv4h7VGormvbOHfBIVVT15qWK8heVQka7UrFNxGU3xSMu/j61Yt547 BFzIcSDcSelZuPcDpV1K6jkj2RhY92PlGav2t1cyRM4KFmbBzwcVyK384VCZiuD/AN9f4VqR 3u/a0T/7LtWEoakHTPdKm2dLll2DCq1SwXkF8GkmnaKQfckz941yyCYzGB9xlX5twbK7abdz y2hZBdb43xt4+7WEqXYnqdUFuoInulkZpD80bRnPzV+iP7K//JGtJ/3m/ktfmRb6tfcwWzFl RfnYt90+tfpv+yv/AMka0n/eb+S16uVRcee/l+pV7nyRJBapdJCka7WTIb7w+lTxW8lvPFdT IVjRMbEA5Vsj+Wazbi9uYliMsflwuu4bR8y+1LPfFGijdi4f7gHOR/tV8hGUivM10utHlRlU KWWPakcg+7isi4tyY1k+zNJDI3zeVwVqewjSaO6uUgJOwhXztZX+la0FvCbeOdp2Ty4W81if m6fe20c3KzaEZNanNp4dkgl/tR4ZG3IzKGb5zu+7TlsdyKksDshVlkTPzB62tTluDbWZADTN Hu2L/c/hH9ayLq9mtZpLtVITdvUqM7WOKvm5lqKTUHYbeqjpHFZs0Lon73cM7azW0rUGud8V 3A6Mq/J1f5hVrUrl1lQuJJBKFkk8v+I+9RW02+ZFitDEIVZ2ct81bx92JOkidFaK4aJLYSy2 20uGbG6tWztzPBPdwwRBouZF3ZYc9vyqhFZPdSNdSlkA+8o+9LWnefY7KH/Rp8OQrusfJU/3 TUc7ZpyqGo+SyW8tWSOYIqfOzfx7aw7zV3tlLpAXQ/umQtt3D+9UEerzRXhUCZGZjuDjrUN9 c3l+0rzxrtBChsfxY9KrlZnN86uiK41JIg1s8I89VBRh9amju41cz3ZbKSBUUN/DWWJ3EoXy R5iAbt3zM1abJBFOJJoVn3wMx2/ws1Vy9xQ5miCVj9oMkCL5byFiCe9K725hWMRruLZfimXi Safb5mVFS4TCAHp7/WqnlzRCO4R2LcJyNtOLsE1y7ovXkVjHZJHbWrI+f3rbvvVWe5EFjHZo vmzbSvyrtX6+9UL69umfyBA7hz+9A9q1IorlVYwpEqeWPKLru+XHzVrGw4tSjaxBLc372Xlx XJEUWIkkwf4vvY9qoy3i2001sH+ZMI+01q2Ti7glRrgtFbrtCtwDn+6tZzWkNvcTDzlQqfNP GQ3tTuKyRI1mlwk3nR/u9oWNw33ed39MUttodpeStIzYtEZhA0nBU45qjJd3kki2FiBGVZS6 s2RWjp5ubq+Ng+4oCyuo5Ce9JtrU03RDqFnm02NIGjL7QiLt25GG5/KmrapPpeJnWJ0GDz26 VHrrXVnevaFIJtzKYgrfKy/1NSxagt3cw2Rswh2LuVucYrSM5SRlyiRJYWcUCI+WKsQ2Mgr/ AJFZGoXFtBN56eX87q6hz19q1biwgku1Wwe4a4K7Z+yxc8DisyTR2ku5orkIpjP3mbI/4Dxy 1EWRJCfYvtly1sEEcakbVVc7UzlttXFt547oxwW87wxDBdh909cA+tWNLX7FBKt7bM11dMqA h/8AVRfxHH97pWnd2cdjvMF0ZFwq/eypY/xf7NOU76DjcyNcJ02aTTbWEt5yqZVY7jux/wDX qBp4Z4Ft4PkwoSWU/M30qzbR3OtTXU11MkbryJPuBsD8+4qhp+i3h0qS7eFWIdmnZHPyop+9 SgaKpyj9RhjW22w2yyyLKWMan5tvvVW3tr1Z41lfBl+aVEO0oBytPs2urya7kgwyWxMplH3m T/2ar1i6ai6TTywrL5Ui+co2+ZxwrVr8Ogcxk/bHGqFNz+UZuGMe7dtHapNZi0t7OFQXklkD SpIx2hl/iX/Z5FRLZT2d0l8ZxiCSTyISd2WbjPtVHVJIUidX3NIqsu4fx89P+A0f4SfaOJBG knmC5b5I1+6hP3fx71du0sLXSRDlWmuz5rYX+Hp/jV2aC0fQEhvmjFwV3Rugwdh7Mv8AWs7V LNNJiWNblftE7bljdd37raCM/wB3rVRbHGct2TS/YdP0+K2NyhWQ+cjbcMcfw1h6u7XRNxND 5AVisWBzz/E1T3Frey6b++gX7Lv3IqnJ298NV2+Sf7Cbj+zYxBsCW8hf5l4G769a1hPl3ZcZ SM2BFC7o5PMPQ4PU1JPamb94gy54OTVX7RBB5MNpCzKkfzcVchuJFTeyK4xkLXbCeh6FKpzx MW8hawvIrzYZVVsOo64pdYkk1G2mvQAYjtjKKnzKpzzn61t3lvHcRKFh3b1+Yelc9PBLYq1v NcutruyAB/rP9mra5tSK1Pm1ZUtbO1t7VbmZC0e3CZPLlf8A2WnC3up7lbycLFlNzyH+Edgt WJrC4kkikmICbdyIq58tP7takTWupS757X92iqrrH/CnY1lKXKc2idjAS0k1GaeeWQeXvVEd 26im3WkXURYRTK0LyMEU9W21p67Lap/oVgNscOM56VHP5MyRyRRsqxRjcd3FEaktyYxTlcw7 yG4iWOCF90gXewB+8aS0d2K/a0KtySvrWzYxpEzTXcW5z+8h2j5l9qopZPc6izs/l7GJ3MK3 jW6MuNS07FMpGZWC/wALbhio7lTPtYONxPCt3p/lXLNKLT533kM391aeoaBC92jbf4f89q0V jWXLJ6j1t5kgkEYDt8roQearXSXqLHOFHmA5+U/NV3T7m2nbJtyrOpChXxUc0sDyLG0MinON 7NRCOovZRevMJLG91Ct7Cu12XbKh61HKhaNQg3dvlpV1OGC4EcUJ2n5WY+nrSai8kLLNbuGt nXcpXpTUdbscoRvzJkkspWNEmkRV7qtVbpiSr2zkR/7NV2l+1APINrfd6VUeZ4lBR2VVO3rw a15uhDqdEdDp+s21xGthrY3L92Ofoy1V1awudPm3yHfA/KSKfvLWHM7u/mJ8/TNa2ka+bfbY 6qrT2E3UFcsnbK1nKPUjm53ysruIs7UkyuRkZqORTLMFToB8q+laWs6BJaW63emsZrJjuWRe cezVnRv5U4Qcu47dBS8jOXPHc0NIto5ZGuZsjYmOv3mqKS5SW/kYnmNdqj3q45t9N07YiMsj Dc6t61jQybnZxGSerAVcfgubQXLA0kmjRTI2CzcYHamNO8UjKz/NjcMfyqGN8qjr8oP40XKY m5f037awOd3LEcwjly4259qUAJeMXC/d+QUxbdJbeRzPuYf5xVa481jDIh+Xb93/AGqLEluK 9CSgu4Xdx0q8wS4uBNs+TPK4+U1Xsre2KlLlMk4df9mrFpNJMJIANuxvvL/EtYiuKLUMhkRP k3fKn92rE0ULiNXkV2KMNo/hpkdxuPkOmFB+WmtKjtEyJt8p9xGPv0uYLkgTcJEj+VWVQN3z VJbTJaFoxcdD6cNTrsiO1dY0C+Z8+U6ismS2eKHzEeR3Dqz+w/pUOKkSbx1M25Csx3uNxZR9 2mpeQlVFwGdn5bFZCTRTRid2YqzMvWrcNvb3EDzRXI8zG0xuMf8AfNT7NA0aWnzWtudyu3ly v84z90V+ov7K/wDyRrSf95v5LX5RQRXO7DD5VX5sCv1d/ZX/AOSNaT/vN/Ja78DBQ5reX6iS sfIV/bixi8hZg03nbvnXGUpt6lzcfZ4IrNfusROflUcetauv2TXdzthlDBIdsan/AJZqP4eO 9ZjWkskKXfmKsdsMKgb5c/Q18VFovyQ61lgSIxToImhi/ekMcS/7XPfNRzT3L2nmWgH+kMq+ buzxSpZ3dzpYmhtGuZJPnl3H+D+7VtYwLWI20YgDhhHCp+5tHWnyqPvIulOW0iGaZbMqXla9 kRFTd0CVVW41S9EscVrFsH7vnsf7tXrawiSbz7qTejbV3Y5Y06S1t7uWSOGbykkXazKSfmH8 XFZx+LU1nGLepj6fJcy3qW80Bm2KWlVF+UKtNur4TXEljYwbIzw3y/pXU2ljaW3kx2flswUm V2ON1Pg8OWaxSajlGnkfDIsm0L/tYrbnewoRj8Jg2SvIViuVY7P7vpUdzayRvdTRynyfMSRG PBbvtroBFZKhuYSrzJ94FjnFY2o6pIkxuo4Vnc53RIRhaqNxVOVe6VrjSp7K5hk1LyiZA0rq D94N938qyVtpljUB921234HTFXptXknu4VlRZI0hZWU8vVCzumglkSGbzJpMlU7YqtSY6KxH BBNbzNd4Kxu2VYr8ta6QWt+FuJSkatHuKKdu9f71V9R1VpLeOOG1KhV6eXuJNV4pI52bzJHi +RVACjP0otzhz8r0Ne+SwkMMaOHwNyIRuVCOlULQ206XIdPljy4DD5t564qOHSnhgjvPtEgd ZMeV/e6066RpCsFoGd1IV1Hb8Ka918qHKSkUZoI5IxJZMUuZQylV+8w9cVCZrsaftti7SK2N 23G5fStJ0ms7yGzt2jWbO0y7cMqHqtRuLaZpotnkQszRRZOWfaPWqV+hlzKOxnxWt7BLIrny 5BF5jFV6rTbOyiuLiJ2Al818u20/L3rptbvNOjisrfTjsaODZM7euB8p/L9axTcNpUInS8Ik mPlf7HNVzvYz5rsSSxh+0Xc8CLschkOPu1bhu57CN7nTI4It8TLPI/Uqwwfxqis7EmGG6kaR lwVUZznj5RUCzXOnTTW19bb/ACEZYwz8j/aaok5G/Nyq8RE0myvbVrk+Y7RcQ552cUS6Hc2K K0t6ZWdVaR1wGxn7tO0y7imc3t/ISgjZWjT5fM98801rd2vo2huPNh3bUHT7388VcZMuHLy6 l++hMWm21zar9nMse53X70jZ+6fwFUpIrazhS8YC4nboJOVVv7wpl6DIPsqzlpbdHUZbjg9P rVaC4v7vRt80cQ2T4hdh8zDvRdmbemh0L2lnNcSXlrGPLijQQ7e3HzfrWdrOqafHZpptpZNF b/aYzNLuwzHv+FAuLm2sAjS+a0yjAxyw/vVi3c0+oSWsDRxlULM4D7d3vTWr1Jc+5o3kNtDE JCAkLKrblblm/wAKl03VikXlRWwaJ5GR13ADkfd/Gs/XYIdOWdbmZ3kIXy0L7fLixkLn+Lg1 lWpv57F7eGP1befl2qeF479a0sTuXriKw0zfb2bupaf94pbiSqV7tskljggLPKrFQoxsXr/S rmnK9rBi+gZ0jjIyzc7v4WxUiPM1pHfqXYSRSMrhFLNwQytV8+gFG2sLi60Zr08ySq21T8vl Lu61Wl0adjIqIzxkK6sB905Ab+n51r6S1xc2TwPIy7o8MSAc8cfQVUvzdRi1EcplkQbDECf3 g6/4VUaiBK7ILu6hkt7u6a2OYFWJWb+GsqJYL6Ka/lkaTI27WP8A47+la+q2d5FpSWFxMkS3 D72+XPp1o0jTNLEqtfTKEJZEAy2X24H0GcGteaK2NObSxmw3MkcC2DPyrI5Q8Js/u065vxcT LHI22CFdiQ4+Vucs39K0n0GGO1k+1XKu8ZyHHzZXtWfa6Utlex3k3zwLIJIkb58r/wDr/nR7 rLjvqZMsk1zcNDBCsW05OF/hpp8uzuRbo5lVlz83FXtage3k/tIxrLcTM0koC7VQ5+Uce1NE Gj3MqPcyeRGI/k5O4uV+b8M5ropVLGsJezkRve/Y2llO4qifIi9+KwV3azE1xck7/wCBf+ef vVqO7jAe1d2fY21JexqxNZwgAQnbNt3cH5fpXcnc7edTKNtqE0R/s28LbsfIW4rWCW1tZiyi nxPdKJAdv/jv0rH1C1N2UGT5q9MDFLaXDxRpZ6hBtmVtiTN/d5rKpRUveRzVaC+OI+G1a7SY yKEWNvnA6tReNDLLBDGnlRspYqfTtWjMth9mkhgTDMPnmL/MF9qyL+0K6eZirLcSuNibvmWL Hyms4XWhzxTSuxskzyl5IiPO5RU/CiAzzSLBbxowVv3p65qtbB7EBVYyyMPlLCpJZZ7e4t7R JoY1ZlZxGuW/Oq5UZxfvXZUXUPsxMEEIz5jb3x70kdqkiyNPIrpKSzO5+77Ulw8bN5JgO9nJ +U+5qLU3kmhaAKUYD50Qfe961HKXvEREK5mgONigRK3b3p97bfbDH5Z2jHmEVBcPB5UUaOFR QquyL81XrxUhit5mV1Ur5Of5VV7GkZe7ZGDNvSVwMY3bSM/w1e06WIN/ZNw+IZR8hxnZUOtx R28wgjk3bVGGx95qgTTruF1swWju5RvZ2Pyqla3RMZdGPlsn0+7NtI+Exuy3cVFZ20dzII2I CFy3zH+GtCCV9Vs/ssg3XNuuEZusi1Fa28Zi3upQquzay0c3RFSirXQyTTbWNWkVmAf5RxVa 1tzKpgcNwxK5q0/mS3Tp/wAsrcKD6VHHLICyRgfM/wB/sFo5mZvVlnR7/UNGmmjiBe1biWFz lTWyul2dvcjUbNAwdMtE6/drLsrR7idJmfMP/LRlp2uaqUPkwP1G3I7URvKV+h00/h98ztWv BfPiI/KjY/3mqJLW6tpPLkAAcKdy1e0iwFygnlVkVP19KuTwQTR3ImkaMx7cbf4qU6itymVS XYzoViVwQ2VTO8E1EhZS07j7/wAoBrYawhC7ERSGUAn/AGqjfTFRfn2tvXAX+7UKUTMpxiTy 2DBUDYarMh2qpTy2Z13Ff7tWZLBWiDKmwRR+Wp/vGli02BrorLKVQRbnZezVHNqSQCVpHVRE DG4+V6sWts3mtcCRI8LjGahlilmTfaIywq2F+XlqNt6trskh2722rn731qGLyJJFtnmmkZyB jGVPenQxOYCySZ2/KVHpVSOwu/LnBdCqrz61pJaeUsPlcCZRvqZ+69A5UVoLy5Eiwuf3Y+Xg ZxUy3xlSRRGqCdsMNvWpjaQWqIHl+++1mU/NSyJapcrbQxM0+7LZOTspa7hyqQ+CKxt1ztV4 kXLp0+b1psbwmSQkAM2HRyP/AB2iRmSQwxuERjncV+ZqLxIIrYtFK0uz5ie+aY5W6Ekl07Bd oRAnzHPFfqb+yv8A8ka0n/eb+S1+VnkpcrhkBLJucN2XFfqn+yv/AMka0n/eb+S114L7Xy/U g+QtRLOyz2sywrt2yqHz89VZNVigt2t5oFZpUxlvu/71U9XSSWOBIJFgZF3suPv45qoL9Fu8 yuImQBmUfMSp42/rXxEYxUQV4s1ZdZnlhUaZEyxyqY0RX/jqpu1TyYEvIWimQPuG75q17G9t reOY3doiwsymIiMbldhjcK1Vgt7jTbaxM6yy7mdYtvzgd+3saqOmiNehl2Ebv4eF3qMki3KM GjZOflz0xVvRzNHAUeMJHcNvLt97bSWiERM9zuFpG7BWUd8fLurKa7lldrWPa8kX7zpwqL/F +tVpzXY53+JDtXczm4On3DbYWVVKnHy/3aoTa3eWkJe5hnWRxhSx+VealmubO6t2tFjZbeU/ vnRsMz01LW1khlt4nM0UUSrscbjt5ya1hyGfv7kVtd6vPaDyYnkkctG4jOW+botVI9O1DSVi smna41K5LSyxr92IZ+Ubv9rn6YrcsoNE0uCSaQSSSO2AoP3eKvZs0tTeSxeW9wm75xyy/wCz VycYbFRjz6MzNO0+NVmn1Byj7cxxDn8KrW9pFaxskKL++Uu7yfeX/Z9qvAXlxeKscarsXI2r u3jFWZNHNhYz3V5Mn22VVZYZG3L5X+NZe0kPbQyoiIIDKxaWIkcrxs5x+Ip/m2UjfasoJVYK 0arn2zWhBam7tFkt7bzJY12LGBhWX6VFZWFvZSPLFbJE7swwzZ2lTRzFSSHajqENqsFhImJU 3L83DHcOtZReztkY28haYTZd1bllwNtaurWa6uZ57qVGmCjYUXG7p8vpWKtva2d0k7gtvbbL Eq/3eBRGWtyHG2wur3r20cVwkge4flmZfmAplnHd39yLedo4imWMh/u7R81Ok0zT7iee9mM4 RWXyV3fMz/8AxNWraNZNPkkV2Ks2yMSfe96ty5dQjFSIJ0sgVWVmfccqf4W96qT2LNM0MigR 7gyrIPlP+6auPa3dt5YkTzY2/wBSFULtWqWk2hYXqXp3NIf3RY7tp/pS51uONL3tRlrYu18t vbvHui+dmQHdH14z+tVby1N/ctc2xZ4ZysTuFIZyOtaUegz2atcrcuJxzJg9eg4/76/SksLW aFvNM8myG42gSr/EetJy6jUWtGUItLgS3zHPKGKfuY/7rZI+b9aZZQRI0bXTSrubPyt8yc/e rpbWwsb0RrHHI7A5k3EYZ9x5/KqckUGm7oXC+WZN7BW5bmlz6i5TJjh3yNfSyqdkuEIPzMnO 4mpLuO6u4kMUSvCGC/uT91akTVUkhmdYOBKsS/JllXJNaKrOsbT2xt0jaXLQqm0s3bitOYWi WhnPHcx2fnbUMioEhVMnHOOT27/lWDNNHFGty1spS0dy7L1PPT3rrF/s+S+SC5lA83lkjT7g A+UZ/vZz+dUb7SnkvLeBNNjAG5RsO3ax/ixVRmjPl5jFEsGqxvO9rJLHI65bO5ok42r/AL3N XYkhiu28mISMw8oLK21d1TxRzaT5VnaJnz2Uynb/ABZzu/QVFYNNFLIupoQZ5WUYbG3LYLL7 1bnfqVGBDqNpc3fnLDslljC5+YLn/d9altoEtdF+0TSNHdGbZ9mK428feqGy01NN1S7TUZDI bWRopGVuSAcD9BTysN3frdF2W0Q4RWXdv3HFT0sEvIqGaG0s2t54iDINylRyw/vcf3Txj61P pM0ZtJYFsxJOzLJbPIcNtzlm/IGp7+G3ttYuZJFaaC3GWMJwsZP8O360TF/sVvqcvmHcGQuw 6/7uPTirjblD4dWYOo38V4EWRy2xi0Sn5gx96mezeZ7Wz3ZZyHdozjb06VraAmlaW03miOXq YpJAu1m6kMDVOzfS72dmjk/0sv5kLAAJGueVrbmX2Sd9SNYWlsAJm2J55CiT7zemMVDqMV3F LDYrdM5R2+ZB+RX071cOq6bBfywwrG4ikHyuv3TSarciG9gWC48m3MvnggY+bHIX8qfPc2uZ 2oXdhavJcy28jyoNrRFutZVykF0sdzbW7RhPkLdeOp/nWlqVjFfSveKhcSfd6bi1SW2iX5kS 0S0ZUY7s7fbLd/Y1pGajuKT0MKPw5e/2Y2oxJlN2Y1P3mHqFqay0h57RZZkaIsuYwwxnk8n8 Qa6DxRqkLi30/So237MzbGziP/4qszSLK9e3GmpOWu0dmEjnCoDjKc8HiuqlVktGa0q0YfEZ iWU80xhePEiYJf8AvVYvdPglgYTQAsq4B3Vd0TVFmvJbO9jDMjPGrjj5u1XzNHfRSWb+W8Kh UlC8NK3/ANjWrrq9md0asJvQ4W8RbKaG0nfmYZYbv4Kq6nLqTXHmTp5caJhBj5cV1SaFJpep Tf2xa5iaTer/AOsVY1HA9jVO+0mTzZlsHafzQrFSu7cp7NQpcz0IqUo1Njlba7Uy5ljZxFz8 pq4ksd5fxgW/li1HDHnPf5qX+yo2uirLJasG2bFB+epLfTTIvkQqYlUmQ5/i21fU45UXSnqZ 0AkkuJJ7eEsY2ds7c/d5/EVAmsoWeSOzVZCWd5s8N9BVu2kd4pS8u2MsyKi/Kd3PNZ8Fozlp PlYKdu1j1qjNrVloC2S3+1XpUNMuVVVxgVFO5v0kRCzKiKU/rVTUrn/SPJ8zd5abeBTtHiuD OxZPLTbgbj1q7dx0d7sLRYxfQvdRF2DfulkNT6hI5laWWUK77hwMsvsKigEM1y7Xcr5VywKj 5jj+H9aju5VO8QyuW3AYYgsPako3In8VixCYbVYVBERj58xj8x9varcctlcf8TFVYpCG3xj+ J+1YMsBuUaOFHdlbc/8AvV0lpYXqactyiRpawL+/Vv491P4Temm9Dmj9pmYKCubpyXrSttCu prdJJgsUOSC1atpoNtBP9v2Oq7cru+7VLXNaSKD7HaTbiv8ADt71cffRoqPJ70hdTlttLshD aOq5X7pPeuf06CGa5DXrthvmxnvU9nZyXUqyTuGLDcqt3q9afZnklimVQU/i/u1UpKMeVGVS pzaRHXUT29wDGWiBG0DtuXvQ08csqK3DEjew53NUN+J2uygbMK/PFu6n2pxt1SW3khk5Yh37 7DWPK+UxNO7jNnPJCrNtjIVF9xTJJWnuVdF4KfP/AL1LqMj3RlEUwVmkLhj+tQAPI0cEb4iU bsr1Z/8ACs0u5BO9wH1AQRE7EOUVulaji1W2lNy4TfGfkA+Zv8KxIlKTiWc4aM7d6+ua0r82 9tex/atzRSIoHzfMzNUz/ulDLqJ4ZIbaDdh0X5VOcA1ftJIJZltXtt0kRYKS3FYuuTyJdKlr N8sSfdqTRbu7htVlcxsHkbywy/e24z/OnJe6SapsjbqZLNFKybvOR+1VBC7S+WjcAbv/ALGr NxeEwrEh2tKctjlWFU5Un8szORFCMhSDlmNZq/UCaK2SV41VY/tC8/MfutUFpYtb6pJqUxQO jbs7vvVYsre3NjGVLPOXy4Y/dpxREikWWMMyn5KOZ7EkF3LNcKyxx553Z+tJbWvnW7oPmEWC 7L/ezVeaby4NkU+DKcsp/gotNQEK70bY4+/j+JqNSjQEyMJYVRmZkwUVP03V+o/7K/8AyRrS f95v5LX5ZRXE0txHM1wEONzlh8w9q/U39lf/AJI1pP8AvN/Ja7sF9r5fqJHxxNAIrD7dcQyO 7LtUN/DyM7aLOwsLe9kurm183cMhpOsanHzVcsLlIEMV0xP/ADx3HLbe2fzqTUXknP2e5gRR HFl2hbDMP/Zq+H5jXRyuOmOnyQi4WFJSX3CMnaFx0P8AtVHbalDJfSXRlaIgbYxH93dg5bdV aO2TUJI0jmWOCFGZlZsFUaoLZRKJFgi27z5UaDhDjvTjpLUJBb6kGOo6feQnzCN0LsxVV/8A iqrWSF33TXLyTogHkopHmDptq7cRx2FsIdSYOyt8ybgePwqvNezG222hVEPKSd1x0/wrb4no JS6FOwtbcwTSKHQ52rG/y4b1X1q7Z29pby3Lxq1w8qrsz8qj/Z/z6VBaaEuoPHHc3akxfPKx HU/X2rR0yzeyuGkMk5whQNGcq43f/rpyl0K5StdOdQBFxsiuNy/LGuF+Wriq813DptwVcIql mboi+1SBQbiW8t0kVpEYPxnk/wDstLY2SXkkYkvEaaUYd4146/w0tHuFoQKV9BPYCSITsirL hNi8sjf7Xan21tcSW5he6EqgfM8gxjttFXNZtL6a8mghIMUS/Kfu79opgv72G1tYkbMMeGVl H3am4WildC2+tz6VLCViVZ7cbVRh2rKa9t2vV1CYYt7h2d92flLNWhrUrrcTNOrzPMA0bqMb elYt5a3zWv2aRGijLhY167mFOMeZk899A1nV4JZimnEtDFJtY5+X/dqEXtzBcs9wEkZ9u0Di rD6XHcLHZu7QyIMSIseOein9aYujwxFJxdr/AKHEfNPY8/w561UuVaIVpIiWCQKplLNKknn9 chV54p2lSXNtJJJcjbuf91vO7g/3RTrGCykguJ5bkvK6kxBmxjnpTbRHktVuy+ZbeVZVVem1 aFbaQ4N81zSivl1WZopXjZo28oj7rJ16e3NRxpZadJLDbiNnT74Lb9z/ANKbDcvc3k1zFbkS 3TYAjTjb6VBLY2sV2NVtpMW6RBRGx/1kv8TY9qOWMTfn925Nex3jzpJDII47gqqtvHy8/wCI pjvJEGgkDSli0mP9usW/t71LuBLedpVcqX5+73ArUSAXdnLLdyR/MwUQ5wX5qeW+plGb6mwG luYoLR0WKRR5aZO3aM8t79aybnSp7LUoLJ7xSJm+VkUtsTP3qdeGzMkN4EltmtwyvGH3KRtG Pm/Gs/Tpp2vJJo5zsCN5ZaTO5/7tChcHMlW3to7ie0MzuqytI7hcEbRxS6bPb6leiMyO25sk j7wSqds90t7fyX0X2iRUk6SbfmUD/Gs7QriazhurpXQfL86v/A2f5VpyaGV7nRotnbIytarJ HeuzJtb97lemf896tQQmW3m1aeYhYgY0lkPIbt+VQ6TO72Nxf367WVv9GZvmjU4PC/XArHst SnltJbC7jlT5Xl2+ZhP93H1pcupfMWbeee/j+1SRGFoDsQngEr3onkur6VppwsxhIcNFHmNG /hz+JqCSe9v4bMMdys6lSD83yj7u38aszXlxFK0DORPLgbB8uxf9o+lPlYSlyxLV9ZWl9dXL 3VqY7tyJCEbhmx8279arXt3ZRMtlZbYHtGVopcYVj3H4U6Gza7ggiRowsrtKpZ9rZ4/+vUN9 BALq9lSbzXEQRQqfKGz+tTGIotdRkUMbrcRmeBI5z5r3EhwzFuufr/CKp3r3K3FpoMMrLHG3 miRj8sf978cfyqtZxLKn2WTzpoVVmO852utV7G9NteZlEk+2H5I3/iLA/wB72roj5mcpXdhu pahHclYktkMyPtRwmM/734VDJLbRaeltbt/fd5lXDbf7nP8Ad/wqe5sIbu4hkhk8turyKuFT /ZpNUgvobJhbWSeUx3SAsf8AV/dZf5H8q2g4/ZKlEyhZvEYY3ufMkaMuxA3O/wDdWp7q6aKC GKSJ5Z0VnETD7n+f6Gr9tp8dre20xdpVgCNDtbdvXsvstSSwzX017bQObW6mZlkLruVuc7ar nXUCtZJem2lvYpRGETC7lztJ/hX1qa41ae6IGnW5nmkXGQc8/wAXA9s1WRJ4IbiwSRVkSQRl iCEx/eWtFrKws47e7julSGNsBl+87sDu6e/rTXLuwuZmnhLEvczRLKtx/q9rc7+m1cV0Oo6f PbaDFdXWnKrwIXYgfcZuV3f7Vc1qV6jSLZsFgkU7kbHRs9flrftb+7XRfst5qbCW/kaGWMDJ V2xz9OKty+0F0YWj2cOoW8t8xwsMilgeMq33tv8AtVPZXS6TJPf6dp/myBCkERTevXhvrjFR 32n22lQPpEUzNKjqcE7Vl/2hWo1x9m0poljUTkLtz/CO/wBOlDadifaOGpkzXmqeR52oQSfZ 7rAIKfKH+taemwzaZapewNG/mR5XA/i9P1rKhl1+WQ3ELkwRN5rb2/cyEDIUr/F9ad4j124N va7ZSqxhne3QbcPnq2Oo5pqcr2ibwxMlEvRW8OoSpea0gj8pjvCjG1/4VrEXQJXuJru2LrC2 9XXH3ak1e6mTTIRMiK86KzEZB83Of5DFWV1i9TT4EmhkjMiqGVTt8wY65/Ot4VJbs1liXK1z kdK0S8cx/wCjLLE0zBcdce9S3Ph6S2meJ4o+uU8uXdtrodMlt47F0iuFWCMsZxt+fyyc4/Sq R1rzZZGgi/cs275h81aKo73Zft4T0aOcTRdPSabUrhWl+bDKwwp3VBcaWd3nRTjYh3JFt6fr XoWrJZT6Lpsu+JZJmdpUVf4ui/yqpcf2Tbwqj2oeVRt4TNbRq825vCNBnnE0WJpGcfxB8irP 2aB4mjNgSzsrFx/Ot5JdPtL2a5ktyyyjCIy/KrelVdS8UWKRtGZoIkQ/cVf0rbf4QjSpfES6 LoCAefdxtbrnK8ruZav6tqGj2kawW6Rrbq24iRtzVw1545yzQ2qO5/vbvvVjXupPeqWeNix+ 8392rVFv4glVjCPuHT6z4te9UW1vHtizjzKwXuLWKTfF+92jl2qosM623ndA7fJ9RTYYps7d o+bk461aioaI5JVZz+I0ra+dU8xQCsStiohMQqyIGKyNuXimW9pJHbvI7Ku47kRm+ZqvaXZN PdwWcrtFG7b3z2jHzGok4rcx0WxGl3NIBucfL93irZmQRx/IvmN987sVT1B4Li9na0iWFCzM qr93bUskMwtvMlj4wvI/iqOURcZXlTMmEH8XfitHSIYZJVWYCMMNsW7jJxn/AAqhaWiSKzyT MxRQ2w1JLLIzhh0CcKv8FZyuST3sksEj209sI4kYLLtX73NTyJZTMs14G2y/LCM8r6NTUifU onn3KrIFBY1HcqjuYbdG+RVXd/eNRsPV6DltUdbmC4HXaoZ/51dRREYdN2JNJGmUbHyiq97p 2yO2zNskddzbm4X2p+lWs0qefj7OLfcpc87h/k0pMUo21G3kcz4OEi2KcxNxj/aqGyiu4Z4o bnBiul3Ju+63/wAT0pqRuks0tw7Sq53JI33vpWskkcthbRSDzdmVTb95TUOT6Ey8jNvJo4pm MMrRtJkbB2ppacFfMPlklVBz14rTZBGyxxCNyDtXfH/EapXFxCyG2kR0HQAD+P8A2auyFYfc afC1ncfY4SSGTn7xZf4qz7vTo/sCyxqFO7cwb5S3Par9vLPDE9rDIQiLulYfeNVTqMbR+XLH vXqrP93bStIqOo6ytN1jNIX+ZmVYg3DYr9U/2V/+SNaT/vN/Ja/K1Hdllnt5SF+XHP3k/u1+ qX7K/wDyRrSf95v5LXbgr+9fy/Uq1j4yM1g9r9pnYqS37pFPVPrUNrqs17dbLe2eKOQ+Wj7s 7vanXtvHATNdoqzyIqoPRqNGtljLw3Q3EsrM+0hs/wB0fhXxvLGIoPqzQhKQfaJEiU8srpIo H/Aax7fUpZ7w2cAkEavuLKPue1WpJbi2u5VtIWCRIxnDHdwSR/MVj6Y87JI0SDLOPNaT5ctn t+g/GqVPm1CFNync2W06znj3SoymKRizyMfnqv8AbVlTbZQNLI3yMqr8u70xWro2oQtbT6fP aLIZV+VSc/PWfPbvpUkZMMrNJu8zHduNuKWiRt7Io3d5ewXDWwi8tMgO+eUz/s1uX0v2EXFm 98rFYwYmVdu4sufz56VFbadFFf29vexsqSENKc5I543VpTxQnVpVVbc28kXlxb+VWQjAasZS 7DUb6SMqGTULezK5Z5DgJxgvmr0F2sAFq9sI7mOQ/KrelNlEumX4NxJEk0O1ol6qeO341FcR Je3xuEUpLcHzzz8u7+Jf5/nVRZF7e6ad9qoVo44bhpArbfK2j5f7wzRGltHG8yRIFlby0ik4 UHr83+e1cy99brc+ZGcKhO+Neqt61pW8y34Li5AiZWdJJD80h9NtOW4cy2ZavHlmf7OtyjMC quFUny8/xfl71T1eXTjeLb+bLbbQqRRs2drsMg7v4qkspUaB1vS3nkbEZeOKjvNLin/s9rmE y7VKvIp3CM5O0/TFNVOVByq90STqpZRqF68JVPMlljXJZY+f5CqKpC0gmVGura7j3wOvGFyc 5FaMxmlsJRLaRGO3QjzR12Uk8JisZJ7RYUhnT93tGNy+2f6UozjJ6jbdrMwNUjjmuV06zHCs rpGFw0oY+v4irV8t/ps0tghgfKEu68D/AHR24rRtRpjQ20huIzcW+1j5nT5edtUb2xR2Gr3E atLM7S7g3DL6bfrWsnGxPwoNFklfU4oryd4I1TaJlHG7bU17aRtCrxxqVZgkTIflaXvVWHUb g6XJK9w6qWURBj8vq1R6nf3NpYx3K3AnljcOsYjwn+9/vVir8w3NKBT1JorK1DvcKsrqGVl5 w4YbvyBqPTpLmWW3tkZpJ7hWXMgwo96S90+6vGRwF8q6iad9p/1fzAdO3QVXv0Gn+H5pmlm+ 1XNwtvEyt8uzpn1H0rojHoZ/FqQX+o3DQf2ck2eZI4jHzuXOcn8qnsnjSKyMU8j7D++Aj+4e 5rLj02STVhZ6fK/kRJxvb5MnB59+DW7faRcWTwR293GPNUvtjbcUboVaqtykyKuqi5tIEhij Zmuv+WquG28/xf73X8KqWGn30k01i6iaS6Uuj9FkZR92rrQajLeQaTawwxxxnZNJIMscLnct NCtYXfnSErGFIQD70belVGS5dSOaxts9tFpqQSR+QLeMcodx+Uj+H6559q5k3E+qatLEsDFo piw2J04/XNbFjayxRm+lk2vtZneQZUR9NtQLqEUV1Db2LtAJ5CFfG75m4ojytFcxraa8Fvdf aGSGNdPiLtE2S5Zuct/d9PwrNudUt7mZrqaBreE5VWYZaaRj9xf88Ul5BFpOtgtM9xOv+uhR tzFc/r/9as7UNTlvNVeWzeFhCfMt5P7nHzKy9zjipVIOZPRlo6xBb3jloVi8sMsqSDHGP4ar yvO8cVxYF/L3eZ5THc+3r+Aq1cRWgtzJMm9n5lYr8xH9Kr2sEc0zJBM0DRlVSR+VUZyOP4qu KtuJyfQdf2hs4re5sbaVPNzJIXPBfvnH3arNpAjm/tGZZJ12p5gz+73Z7N2xWrawXOqaybLV LxTatHJIxjbbhgcj6VVheG1uSZ1Ox3/0cFsptyNxo5k9BrXUT+yGS4urW6kCCNyAEkzu45q2 RJctLa28CtsUKD5m7K4/+tTXk0u9vlvIl8hpv3UsROfn/hZfwxVO3vDBeyQMmJo12lQ33QvO T+tKz6CjN82pat7KbSt17cCRY5m3IhUbtkY/8d5qjf3dpPZyahZ20iTq6yIhfHl7jhpG/l/w IVe1fVYrqOS4vLkSLHmOGAAld3U1gpLDcQvcO8btNhhFIOg4zzTjfqVzcr1NXURC9qbyyiEz Mpd9zbdhx2/vVm6ZcTLNBK0KTRRyATK2MJ/vD/PSrt9M95pgna3bybdliDx/Lurm9WleW4Bi VI1fhVizlunzH05B/WtoWluZ8xo6qr380YYIZRPshcDb8p+79a3pLUXN7a6Tb2xSaEsZZUYM 0hVcH+n4VhaMTczQXd5HJtEu0upxt7K2P1q/NrP9n6/Zuqs9uwSSTn779Nuf51V+b3QvqZ17 Fa3c1vavu+0xSBXbB2rFn1/z1q5d3FveN9imwyW4bIzt3/3fmqPVhDY3T300DyK0+EQjChWP qOuKqLZzaokkKW0Y8vcqEnDLtH3mquqB7FGa7uGZbiA+VaIrRQQK3zE4JzUNtfTCcR3AVmKZ +fH3s5qGdUVFtWVneE/dU+3NO/s+ezkSe88qVZ4w0Y9Bj/0KtNN4lRZopNHfao1xJHJIk8fm bX7MAflFSHUbm7sZNOtd7RIyjawX5OOfmpugrZG48/y52kjRliiX5irHjdVC+FvYP9kmuoxM /wA0qx87fb/epK49CksV3fJJp9nA7hJlaUxHO6MZ/PnFPGniSWTaJIwZtkTE4U49qnS1W2X7 RZSyoSPl+bkf7X86vasEsIII7Y+Y0sbTs0y/xGtefsKLtIzbqzmh0sQpc72gf7wP+1836/zN UZPFmp6fMsdmAdiMXZkDZqayQ3F0RPM8aYLPgYDcHp+Ipg0hHR7o7yTtRXC/w1rCaj8RpGXK Ubu91XVNONrcPFLCp8zAUKys3P3v9n+tc5L4bhvIXNs4llf53ctu212sOl2sMMsaXKthkCpj jn7349KakFrLdSQQQNFGHZZWjGD8vtWirKL90bn7pww8OWlnaloZpJJ5VwitHjB4qY+H7hI4 444GeRkG8ocqMda7K9tIHuI7cM7NmNSyLk/MPl/z7UsWnT6VquBdI8kfzyovLBenNX9ZlsQp nLP4evWlnWyxNbrhFUcfvM9PyqfTfD8IZJ2KSM/BRTwCvrXYT/a7yO51iSQRwWrbfMUY3ttO 3avesbRtMu7hRdLdv5ZV2Tj5dw6//qqVVlLUcpsy9P8ACs+s68/2W4t1MqloWbPlo1Rx6RqF sl0l2g8yRmgE4/2fvMPaui0l9WtbmGSeJztky7BQECY/+uKtpbjVdTa1aRlRtzsv/PIev40n WkpWkLmkcZLpsNqqTSwuxZss23+H2qYQvNFsgQct91j82K6XXpba71FdPhCvZrEsceD93b1a sy3tYLa3uSJgsi/KrH0b1q/aX2DmKgso0P2a3YyTbsfK3y4q6LJNPMkU8ymQr37U2CREhQBl jDIdjbeSaktbV4brabcnAUkN82/PelzWfvFEa2syq8Fqm9piCzsvAb+7VWZG09ogu4NNIykl e/eus0gWtnNcR4ldZG86JGP3f96sS8gsr69YedNCybtm7lFc1lGXNJk85SuooSUkknBa3++u 7K5atiK4jOmsflMbOvm7Rjilt/C9iFV5LlfNaPDqrbQzf3jTLSx+zy+RCftEPmNC7buvHp/d 96JSjcFJSIb+0t5oxLYpEkLfd6jc341Em+xtojcfN8zbcHH1rSuX03SLSSPUUFwYiFCxjIDV QnbzF+xJG3lnElq7fwZ+9mlCSaJ+EH1u2spo3ePdlPk2/M31qCQLcOskMqXJRchMbT3qX+zb W2uJpbsedMrL5W1vun0NRvE4vLiOIMdy7m2rjn+7/Ojm5XqVurIVrmBbGa9W2aCZ4xAIx82W zitXTPhD4qubWOaWS2torhdwEzNuPfjANbHw78H3XijX7aado/stiyu8Srj5v619SabokUNt bpvlcwFvKVF3eX9fWtOfsddHDOUdT5ftfgz47EqJH4Ze4s3UKZYm+8f9mv0V/ZX/AOSNaT/v N/Ja8dgg1eWJvs9xMZo/mRHAVBXsX7K//JGtJ/3m/ktdmAbblfy/UWIoqjaz3PjltKtJrq1k 1B5HkdWWIM23y/TfVC7Ms15gyugiYptj/hI757VNPKl9JJcz3Jjhm/iHL/7IpklzFp9ukUmW 25Jd0+bpypavjL8xHKuUR/Mt1d8uWeDakhP+syf8aF028ksVe3UHLbJY93ysyjO7PaponkvL TzEBAQbUj7hK09It0EkUbIUWKPLc7m+b+9SdTk0RpCS2GLY21rAlxaoUbCqHzuG/+Kq/2l2t 4ZJVkmbzGUxqvQ56/qK2mt9OuLc2cE+54BlIl+Vi2fmrMlvLexjjcB/PJLKCflU5/wDrVnza Cmyk8uoxh5bmzJZSVZs/fGf6Vn6bLNDf3Edxc+bDC+Ww3VTj7tauox3BuRO7KJM/NhvlXcPS qTW8UVr5cZT7TMNwAPzBQa1ilykX7k93azXCPPCJZfI+ZZCd3yDt9aptLIs0E9u8xkZQpErA AKwJO39KuPqFwbZbKIqIR88gPy/N/FVuS/tItOLSgM4fbGqj5kXGP1pcwe78TMXSLSEzzi7c I3kyM0vXce2arlZZbcwgiNoH3Bd20snX/vmrFu407U/sksDzLcRn5d2VIbtUVxpdsm+6CSNG iiPcD/D/AHarmTJ5epPHrDzwmCWMIttyrx872/wp1jrVzCZIIYlnjYebKRn5OtWo7GCLRIH8 lVDbmgRfvtzg5qpYRRytO1zA2zIcGNtvy/1pO9tB8kubQ1IrxrWFXmaOCK9H8X8XH/1+1U9V gkeJba3uZJ3iAePH8vQVWm1Uy3/2e4+YIu2FWTOxv7takxuGilnsFBERVWTA39cFv93ioWnx FayjYyVkhEj6kIH3iPDRMuecfeNaV9jTtDtbm9tWnTKgMjfdZucH+ePeqdsZ5FDByGmdVfHy qqgkVo+Lb/TptRhsJJPLUx7lRSAFyB+Facya5SYw01Ob1R4biwMMUgSRXDxRx9Mtx/WlvWv7 eKKG5jjSd5ERPmzGSvc+lSNoxs4Ib2YrFt+ZNrZZfm/wGfxqws1lJqCWl273CS8FyPu8/eYf 1q9tDPqQXsXlh5o7pvO3hHaNvkk/vbf0rJutSjGmtbzIrurNIWK8x8/e+tWtYkspYpHSDfBb XSQI0Z2k8nmn2Xhy6t5JILi13jUAz27H5jsxW0bJe8Tzdi/Zr4cnaLUrskF41dLNgQ0g6bmx 03YP41WuIbBtQl1Z4prMpPwgbduVvuqaxbV5xazXlki+XFOtqrMvzu2Tub6dqnsdTSS5kS7m ZpQ2x0bsv8NJRbehHNfcvLdo+sveM53WsW2TI2qrf5P6Vmwa3HN4ijg/s2RbdWaRnk+YP6t9 KtiK1uYRBJcyj7axhEoHVuefp0H4VFcaI9vdx6Xp11+/aEozEEhPWtbR6iir7lu6vymlXdnc oqwF2mEe852ccLWTfTzwAXUQKQyuFiiJUkcdfWpDZ3r3MNnHZyuyyeXJKTlSo6mrXiKyknu7 ZLmZ5YpHxLFA3zdMVHLym3KlEopZOI59bkuZVlmH2eAq2RG3+1TpLpdN02OdkVXOVUpENzuc 7s1t3Ph+xW3t9Me8SOK3ZnRWJViWAb8eDiibw5BdIksl5uJX5InG1R2z70e05SOX7RzVlcXE 9gJpIWa8unKFEk+RWx/ET9RXQWtk6LZ21xGEmRFkneQqVV8/e69MVctdHMN3cabp7W0cNhiS SVhlWbAqprkkDyXeo2d61zePCocGPaE5/wAM0+bmHLSJDZCBb6KCV0kUyt9odPvEY+7WVqNw JdQQ2xZIgdtvE3LAbvWpNJuLLS42fUbiRr2SRiqxj5lO3jaafczWlto/2gxNJdu+TcP2PeP+ XSqjGxiVLoX0F5JDFHGuZC8eesa5/nTY7GS1ebXNTaVXMxLFnG7GMKu38e9XtKuYktGjv180 TSeazMfnxn7v+79KbeaZqOqMtvLAYondnKufmLfw477cetUpR2Govcn0S3s7zR7uWZJJmjlW 5twq8v2YY/u1Us9HN1ev5sLNhSyxofmjj/vSenb8qku9Vi8KlbK3kh1G9mRVjkxlIk/iwoqh o+stJPqdwA4luINrFZNqv0+X9KzcZXuVIkspJW0nULGKeIQwDbLlmxu3feHFYuniYCWf7N5o nmEUW5v4Od1X7a7GmwqdQkSC3upcyKfmbb0Bx9ajn1B7LUBNa28JmnmxIjrnYMkqf1/Wtou6 5UHQ0t6rfx2Abd9niZsq21f93/ap8trLdw2sxMUcUkpZl/55sf6GoEh2LcajMqM3y4QHHzE/ dWrV4+mWlrG16krJdOjoYny6KvBXb9aV+gRjbcz5YtYuPtlpdupCSbIkJ+Uf7X5ZphsLqBXF 28jCXaqsjbdyt2X/AOvWrJren22pLa2untKWbZL5zf3h/hTvEl1p1nbA6f8AOo+eRlbbhh/D +FNS+yXKHucyOe1KeyjuInttNiigiVon/eFn3dPmNV9cVJFhnt4TIqsQ4PHyqoC4qvNd39xp hurXT23SHMvH+1979a1Z4E0eKxZLxJ5ruPdO7/8ALIf7tbr3TNbBZ2dzY2Ehs4XWW8i3+cW2 qi/3S3aqlpZ29vZST32nm5kmXdEysTg5/iYUt3qV9qt9Bp6XLSpC2yJnwoJJA5/2apXWsTw6 fg7Sxc/J/tDj8qIxcncYk9qIXKPO4YjKxn+L/ZrQu5baZbGfUpne3gAi2GPa3zfz2nNZLvNq 9kpabymZc88EOtSSSXGo3C2e11t0i2xlu7+tVZAkSanLDb23m28oeKJiqxMfm+9/+urmm6o0 KyGSJJYrqDy1jY4K88rWSthJJdNYywuwUb32j+LHHNbtxpuk6THZaebqV3I824i2jerf71U5 RtZlGPPpF59kXUrX91G07LgH7m3n/P0qzqkt3JNGlskAMkYYvH6f3T7sa0dbiGlQW+mQQjeq tcMSN3ysfl3fhWYkcc0E8kcwe42/IUyEGf61MZp6EykvhJBcAQ2chkBubRAt1JH90qOnP95R xVOfWoLezEmlQA3DFjLJ5e5tmem6myQI1tHa2aYZf3e1erEKNzfzp0FtZC4ilihby9ywyxbj +/b1x2q/h1F0LHi66azsNHR4WWdozcyxDON7/dyPUCs7QJLqUmzgYDEnnDB4D/3fxrV8R6jB qbtqE1q3nzbYYlDYVMfxVn6fptxptpOgRTOki7m+98rfxLV39zQNOU3tduLeytv7OtLhn1Vk 3yCEAxQf7NYkMdzo6hJuJLjLzTbuWP8AQUyKIaeDqrltrNyHbB3c1iJfyalqn2l3dl2lGG7P y0Ri3uOLsh6hLidbmSRljU7XQ/3O3IrUEVjesZGsZpIh/wAs4v4nHA3e1PJ0q2sJoYfmllVY 4t3SJ/eqkllqLQeWiMtzbDZcLuwsoPKtVLUgdc2JfUgHCmFWAYKRtX0HBqZCrXP2AM1tPGWe 3LH7wXGVrNspLZrZ2RXLA87f4TWpa3Gm6bcW8epo15MzbkmVdrRP2HvmqlG45XuVbqa+RyEj aXOQ7RnnZ6fWrEenmKyfUoMm3UAs0hyw/wDsqjvLW/03UZnDiS1f5lZOGTd1prX+6Ft87Qx7 THGjHg7v4mFT6FIm06Jb9ZpEkklabjb02j0qrqz3NsZrpbWSJY9qERn7vYfWltIV03yUgUuX +YuvetbUBO5jto7ZTG3Mq55YYxR6l83Kc1a3k808axPIS3JeQZU/8B7VLJqfnyLGSQsbZ2jj P+Fb1jptro9qkH2dpBeOdueXVaxzaiSU2gXy5S5VoyuSV571XuoI+9uRXN/DeF442MKp0bHy s/ru/pWndWl5e28GsXl6E83YkRgXbvxxuwcf5BpPDiaeLa60u6gJB/eW/mr/ABfxfpXVeDtC svE+vxW+qwskNk6vEpbaNq/d/U1M5aF0venys9u+DPgd/DHh6G6vJs315++dwAf93rXqFtbG GbzEumALcqy5/lXOCO20jQ57iCTa6wl1/ebtzY6VtaTcCaGMSStGCAwMgx2rn5mewocnum5J C6QeYjL6HbyWr0D9lf8A5I1pP+838lrzJob1GUSzN97eiK+Mj1r039lf/kjWk/7zfyWvUy37 fy/U5MYrcq9T4cmvLWN5ILG8cK8g8rA+bHWprWaPVjLFd3K7GO372W/WqusWNzEAl9GscpYf PGMc/wC7TpFsrQNZ2m04TmVht5yK+UXIclzUli1K5cHTmX7KzCIuF+Ybf/1VLpUvkXDxs80k EqHJX7xYH/J/Csc609q6XFnE0lv5kaEbvlb+9VzUEtgscumXkrYPmPuziLLfwmsnTvsDvH3j UvZxCI54ztkmT91JCeVb1b+7URmSe0llWT7TdEqu0ruH+8D9M/rWfbzW93etDco6LYgxv82C c/xVLcXz6NG8lpAJbG4bClT8zqBjK05Q5dBX5mPtJLi2lmnnVXeNdoVmzvHrUMOnPcwyahae YvGQFI+VP71X7O5sJbFZ721IYnAdeFHPpU63At1vbSC3Ty4ljWWTGN0fO7GO3eo5uht7so2O cW5ja+RI5zqE8owsUan5R3Jq5qEUiXUayFZFAUyqpztyPutjp2qaGyeadv7MKxQxMsk83l/w 5+4pqXTrQWc8sl9KspM7easY+Ujg/wCH5VopJijAfqd+kdiEigjjEjBFY8gf17Vzeo6q/mRt Z28xjWTymZW4zXVPcWuq35tIbDfEIsRLj5ifVu1ZL2N0Iy1tBGpZ2AjY/K3zY3fzFTH4rlSp c2qJp5gmkWaG7hZrTcZQh/ye9S2FlbSWN7cXdy627gJAdvzZ4KpjsPelgsLKNNrwqFE6kFl3 Mj45X/dq5aSxPBdR3EQuIkyyBz8m4n+GnKSvcPh0Mu208NYvqrSfvSWTjB2LjB6mrGlXF3b3 AmhtC8FyGjbPXOMmnXy3cM32GcmDzSrbeq/N92rGpPFp8DQ20ckk0MOVkboG/iaklzkkem3V pCkh1CwXy2JZVDdKyDZWVyz3dxHJIkTtIXI+8McLUdpq9nHZWq3czlp5SjRqnJJ/i+lRX095 LE0KK2NqiOIrnb/e+nHetVHk1MHUlsX7wzfZluLG1xMZNjK3Jij4GfRt39KgE0cUbSSYafYy FFB3GoNXvjplikkmotBdOixxFUyoj3fNWkujzTySaqt0Hht0j8udflB3DJPv1q+X7QRXVmTY /Z72dZZm2QOWDRIMgPjAzx/KtTUL1fD7KbS7a5igg+SVgTj1Vc81g32pC0laPTj8ySBkbHys /wDnNZ8tzqeq3eTGxZUJI24Ru9E4OTQc3N7pdF9HFJGARFvHnRqnzIzZyf51m3Fs9zrLXAbI LqNikI4Zj6d6238OnUy17BLbwQgI0qfeVOo49OlQxeGzPLNeDc4jZZQ7NgqnrW6lGCsHJfYi 1FdVs7K3IQzXUU5h8pE9QP8AD+dPvLi41aQWFptS4Hyv5bEPux931qCe+1OJWdy0cbLGsjdG VT/e/wB4CrC6PNYaw+thJLYGDzYGD5bdj5aLJxuyYxsS6RY3OnXUs1vdXDxqy7VkHyK+fmVm z1x7VptYwWsdzd3U0cEnmbo5CwdizDpWTbDUzBsW83pNm4fa/G/j5W/vd6n1O402VrWzi3vG hVps/wB7P3qyk5c2hSetmaL6hDfzyWtxBKFigRoUCbmL7VPX8Ke6vrE0N5dTw2enrHtLYIdT /s5rOv76eWSexE4tpYseS0YwX4GWb8Kwb++u75Y4LPe9og8rft/j5Jo5AkzRuL2ctd6RZXCR mWQRI2T88XXezetUb83JtltNLnWdvO5lzt4Ud/7xrVfTwkggRGllmiTa0Z+Xg85pRHpmnNcK Tsi3byue46n6VXTQnm0sVxoVpp+gTahr0JluLcNJbxPL09OnJ71xseq6jqMEdkqPKqPvWM+/ +f5V0l1fS3twdSjnk8kxrGFbps/iNGk6boGm+IJtQW+mn8kCWAA4xgcfr/KtYSjGOpBFDqMe gSwW0bNPcGP5Z3GVTcPvbfYUzTPFOpXf9oNJaRtB5Tw29zu2734+YE9Djn8az/E0/nW4giB+ 0rG0hlJ/1rM3zVX0231MaRFFFAuZc+WcgIEyN2P9rn+dVGKceYFpqQxXBt2uZCqGRYzHHjn0 +bNaOi28RhMurWoK28SpB8/3pGbKjr2Ht3PpVi5sBb6fa2gCOQ5Vt+DlewNW73T0lSxmtgu1 jJuRiPl29wPXsKcpc2wX5tTN1iH+0dTit75fNMibsj5VTHanWUNld6iJZI/9TEGd93DOD/eq 1fNeSLnTbhZy3yyIUG9Bj1rJhF0IZQJNlqFxMAvO9uP6ClH3gv0LMcl6xeCR45QjG5kmjYN8 vQBa1o7WG6iitp2CXjNuAPBWP7359KpaIdKsNFluLlJmumbbHGwwoi7tU8sryaVFqlpLFIZQ 7zuOWAVflH60KN5DZWWXTJtRnmyxuI3DMm773+1mlFiupX1qzu/ktI26Jvu5wa5CxuJo7oSS uQz7iX7MPSumtNRitI7QRfem+9vb7v8AkVTi4u6FfTlGWUqr51gXumnKsgjX7iAcj+VZN9b3 c0jG/DP5bbXl6blXtU9xql1p92Z2ZMSO2UUD7rHH3qdNsuJI5p7hUZydyL9yt47agxdOtze3 ZlCyRRSxbIyE+bb/AHv0qpNpMlxeKod2WFcSv0WP2H97NblvrOqHTnhkuhEu5YoXAVVx13Y/ CkUvKVtIrlJN7GQSN8ppXa1J50ZhtpZbe4UDc0OFiLD7q+v1q2s1n5KxoZGllKoxC859ae6q ZkgdgHiYozqflbuN361Vui51eBNOEQ2KEZixw395qPtD5kEl/Dbqba2yrLuWZZnPmOv+9jC1 e0uztysU907SXTc7pCBuT+9Rb6BC2LrWJ4ykjb4kRvmIz97+dMaIr5Qs0d97s8rO2HKfwrSl KL91D5iWS/mnnkNvci6DIySzuMKsXTaq/Q9fyqJbGW5HlwypDY2a+W+PmaaVuV247Va03SFt 76aCYgF4vNwDu4YY2j9Ke2m3l9bxvYQCCK3fGD8oO3+I+9EbRIemhiQTLdaqYLHzCtr88ki4 U/dO7PtUHhqS2v8AWZHvZJ4VhgllHlkYDL939a6DStIRL+6XT54/MePaTuG0SsDw3+zVaDT4 NPvmhQKJSRHIsYyu8jt/s1XPFq5cfdRiQQzLpu67VgDO0pzyy8Y4q9qEk2naFFdQxZkkj+Tn nbn7zUaxez3V66BIkW2AAiC43N03H8qLqCPUNBlV7hBdOVjiR327gv8A+utbp8tiDkdRujet bxyTS/vWaSRi3DHHT/PrVWxSZGk2zC327gH25z6V0er6Vd2lta2V1NEk7R7kjVPmRT3b0yBW U+nSzMsCQyBd3y9v+BVvFqRpzx2Ny30iK+mjtri4YLdxK6SbOkqripY9MuIbdINTmVolJiQq +HdfRqdBN5GnQxEMv2WXeszLjisi81e61W8+1F+GlaLYg46ferH3+gjX0a0ubW6mS7tbRQ0T QpFj/WSL92sq3XUNQMrTIqyB8ZiTLZ/+xrWs3kNnDfSuoniYJJu+83vTNQsPtSM1zJL5divn yzRPhXHO1cD+LJAojN7MF2ZDeCZNOijS4DFfmdcfvGHvWLqtqY4S8tzGyOA8cg67/wC7+VdP doHsXu4V/ePbKqg/eX2rLn0e3MgN3dqsccalYFGW6d/Skp6kbD/Cl9ckyWdtHtXau+6kXd5X 4VrlNQgv5GMNs8EIaV7qJt/nL/j7VnaE8j2L3FpGI1Z2Cqee3eq2k6udMvodLvLZ7mG4DfaA G5/4CBTceYq7Ll5cf2lKdTtpJUVVCbGH3f8A4mk1CS2jJjeJUuAFaEow+9/tMPx61dltI7QS Il6lxaTAHy2ba+P4V/4DVTWItPurNryyuftYjVUmi2bXX8B9761FmVdp2KLXMUi/Z7m6UPEv zzjoD/dqxpt5rdpcIDKUt8LH50nVh975agQWqyRW1rHbmLClvk3c9t1Xp7bU9TEsssyZkMax hRwifxKtVzraQKTU7o9D0zxJeto0xOpO0TW7uoMmfb7v41saf8VvEumxottc+fAsQDLKu7K/ 7NeWrA9pe3UFzPKhig2wrGvy7f8AIpNMtrm50k2z3cnyyNIki8MU9P51k5R2R1rFyjZHuVp8 a9bmmg1BRbyRKgjT5fuJnmvrf9lf/kjWk/7zfyWvzLttfv7a4aO2hE9o3yFW+V19j/er9NP2 V/8AkjWk/wC838lr1MtjyqXy/UmrVlVtc+KtaY3It4buNmdG2Cfdyzf7VUGiv55xYCJRMyM0 Spghlwc/y61fcBBmdpS7PtRlbK/71T2tzb295BMqAvbDYUC48xmP3d392vkoyj1I5Yla20W9 tro2sqCHEXnYkUHdu9v61paWrwwJYXFuv2dVeR4dvOP72fTiob3UHuLxdQSb5yVg2N95EA6H 2on1eH7WdLimWOcqoaXHysh/hqZSsOUg1MQrKt/aXEchdl3oEHzDA+VjVFVlur+yhJj33LlA kRz5ROdobstSXWl3lvbLaWciSMxJbavQ1Y8M2VlC5vrgLJdOu1v3m397/ex04GafMrcxtBc0 rh5z3txDaRj98srAKx2kMOCu3pU82mJZ2V7fxvEPLlVGXe24sDlg3atpNPtLrdLdRrDcNxFK OrMP4v8AZqnf6X5Qv9JhnDSzQiZGZtofjd+Lbh+tc8pczNJRsM1SaJLSSws4Q8kqLKSr44b6 fWqrtZGaG3gHJbcZVY/M+APu/wDAcVU0zSLuDVTeXMBeFAFlYMf3frxU9xDqTrLNpBDurszT uv3U4+7+tXaMVqJuy0QttbanZ6gJ5pfLUKyqV+XHtjvVu7ktrVBH9klM0OAVZQB+85Vl9/xq XTLS4uL+N7m0luC0mPLds/NjkmqOuX08stxB9mVoof3aupySwBx+WcfhS62iC5+XUp3rS2c0 lwYZH3MDsT5gueu6tS0ZLSAyQFdscf7tcZOGHp+VZVs09vY2qSblMwMkg3fNu7U67mnubyGF YzAYrTbKF69yG/LFbxivhOeppIiuojqZZbmYLLFh95kw/wCVZ97e3xnDSTys0hUKy907f/Xq O31LT57pTc/L8jpEW+YucfxVZttQ0TTtPYwxyO0RQzKRtkVO/XtW8acUN7kL6XDFfvqiXMkU dmMRMdu1mYcnn3qyhl+yrLbzPNO6eU5YDLDPX3qDW59OYW9xEZFg1EKUjdgw2A4+72ptm0Go Wz3EM7ebapIEjXhQBQ1dXIUfeNTXLPTICLQpJLfRwGSO7QfIFK/cCn64zWeNRktNJXS3nYIq 7olYbfnwM/Wo7uW9u76yj3sIYEQzytxtwN2P0p0+r6TqLx2ctg00kWZUP95c0R96JU4xtcq2 GnQxQaffy20iNEJPMWQfe+Y/N/vc8Ulnp8s91NHbTDcykKzrj5uvPOKszX0t1FIgLNmVVQZ/ 1Qbgfrip5dK1PSBBZG4QiVvLTaPv/wC9/jRz2+IytYitLmS40+UWsWxlDC4ZiFLRrgZUdOrV XuZ9SlktkntpIxIxgMm4Hci89vathYJtMsL2GGKDYqhZfM/i+YcqfTLAYqGW9TULZIZgkP2e RVABy5LZBC4pc0S4tQiZ7xpI8120OLYMsMMci/M6r0b3rS1NQ6wwxyDyrhF3K6lu3zKD1Wm3 80drbx20roxg2kITkq2SOtPubqGxs43u2iYh9wVW5IYdvWlJuashRlzGBrNlBZWkOn28kaJG u9JEySP9lvel08wmBb2J0lZ5PIRWXlvl6ilfT7rxJD9rtJ2MKS7VUYDbePvD/PetNl0nTLeR 7Z96woyqzcKJP4tvtVQ93cdrO5ajt9P+ypNdhU1C+gki2MAwiQD73X7zY6dqpJZ2Vrpsdtb3 A27t8zSfJ8+MfL+Gax9L1Gd5Ak03muxwshHQNz/OrAZjDdQyW7Tt/r4wTn7vT6c4o96OpN1e xesru+ktImsoUjXz3QSBS2yPA2/XPvWZZQHX9Yu11GdlSyU7Rj/WrjkdMDn+VX7aGZNMtLSE xxuF8ydVHfnpVKbVEQrYaZIW8yNo3lZfl9/97bxV81/hFyoZrt+s1v8A2dbW4it7eMLKUIQM v+8azZWVNHt5dIt0ufIPlSOJPm2N03Y/Kq17ptzOgurhZGmZwYlPCNF0I/Pmt/SNMPh92sri 4tYjfnaYHX5sdVZfStHGKjoZmZq9pDBc2cUY+1yoGKxRRtuGQOOa07Oxk06K1M0MVoIVEjJI dzBjg/d/nTLrUyk7RWtwYpyrbJYwC7baoSSwtbRTXIu33FmimcY+YL8ysfRjj8qFe1ieXmMn UZri6ikkuZkEsZYMMY+YnhlpLC+kFrBMYJdtq2I1J+ZuwY8fX86WNTrGnJrGovChkudikMPl QDA+tXbjULSfTZGsoTFLb7S+xd2YuR/hWsmvhL5bPlIWvtWsrZ70vDJdOhVZM/Nt/vbaw4Rf 31jNPI8jXIbMg34DNz/Q/pV2ORF1S1tp7s73TaFxztP96mXu+PZGrG3LDEiMMbtpwG/MU4qy sPl1si3oqK8sDakWlG0o0atl1XGc/wD1sUy4tr/T4Da2ku5JJwERh/BnDcVXV7iMNP5qySyy bAluPm2/xGtGOO9v9ZW3lkWDyIFnZm6sn+NN2iTK6ZVvbGytm8myeTzpwrsTHwntVORLh4Fm Nxbp87ESH7vy1ee/v7+UylP3bSMylRyqDj/vmq8kFs7LHDGsKs7fIx+TNEfMmO1yO7Se9NvJ 5MCC4dWBGNjBfX0qOe50+OKCdLUN+8KCJMt8/T8u9WJZ7yxu/spVGtXiLPGw3KPf/ZrQtZdM cxyWsEUGR5Txn8ty0OpbREuV2Uta07T7TTY1m1CSeYP8hVgMM3t/nis7RZ3S8jeZ9scTbvNP 9yneIdOePVo4FjeSIrv3J7fxVPdRx3V9b6Lpm1CYvLeVvuH/ADzWnPzRsh6vQ0tQgCay8wRZ EmRZnUt8rL/eWs57mK8vJJtPikijRdjMBu70LdSRs1oX85LNfIDbeT/dx+Z4qSwNmsj3dwxs 2DEOuONzfd+lEbC5DQmZJp4QhSO1hVghH32fr/3zUtmH823uJMyKrqTKqkKv/TNf/wBVU7Yz xXMpkgWa3iXO3d94cAN/Op9SmtbO4hmlvxc2UKNPEkJP7xv7jY9DWc1yq8R8ulkbzaVbxzXs s10Y5pJPMSSQjaqrk7e3r69qydVj1fV5NPTR5RLFN8qrC4H7zufesy/1Rb63i+0mTdLtiaNl z5e7rj9K6jwhokFvYz3ywmOWxVoLX5v4m431MbxjeROsTB2yw3VykYicW8WZmU43bTjd/vcU zRhM8sV/eTgCaTciLy2Perup2mm2iSWQ1Tz9QlG+UxL8qL1x+lZUFpei0a8sJGuAq8oF+ZfV ttar4bjvzO42OVJUv7pXV2S48tdw+8uelaNloltq01rc6kqx28LtLvIwB6LWFo8QfzYrlHaI /NGCPvPnP5VryX91cFoZHMVt5ZjhTpwoy1Utxo5rWLybWfEl1MbljukCKhGPkXhasqbi81Er CgghjRgzZzyBVRJ3vriaSe18icLypG3fzU1zJPFY/aLeNoWhzvH3tua1l2L0Ras7OSW3lN7c ssdqpHzfdNcrFeyRXYbT0VWeYjdt4biupmmubbw9HIyN5txIu1R8wYe9ZV3aW86Q3ETiGZZe UxRF+YRLGlyzG+htJ9zQ5Bdh91mrY1eCys2vYWuZBCw8+by2zuk/hX6dKzI9N1BYvNaHYkJV QAeGPrREg1hrmJGAe3IfHZ+zfXtS/vCH3epWsVvbSCZt7HzDkfKv92qL6nGXlnR90j9F/vVc 8V6TA0ttNJOsEU8Ss6Kv8WP4fSsfRYLJGkvoCxt4VaJ/O+/uyBVQjGcblcpqRXl8sQtks2SS aT/WD7qj8KsRxQxRzItwtvNF8rXTcq3t61l3pk0+B3N1JvILpEe6/So9yjSI49ShkkEr+czL ywH8NNRb2E/I0LuK0xFLHewvvX5WhLnJ/wBrI/lUNjHZWVxFd2OrurvOYJonj+VV7jOfrVO5 1NW1CxSxh3RqPKcYzuX/ANlanX6SR3DQm1MUUTCVNvzBmxzn/aqlFQ3GubqR6mbaw1a5j0u4 mETnbEgHU/7R+tdbp13HpMWnQ3Ow6heDM0XJSNcj5f8Ae71y0NvDJMbwWvntKxZYi33G966d Da2cscV0itdkNKjFt34VhW8iKl2Vru4d9Z/tTzvtVvcu6KwbaEYdj/KpNQlnSw8+0DM8RVtq t79PpUdkbd7aW0t4JYlR8Ms4439crV60isr+ORpVMUcI8t2jbq3pWTsmrgr7mfaP5t6t1Lpz Bjg/L/f9q/TP9lf/AJI1pP8AvN/Ja/L5tSe61WK8hnMMVtuhWP8Axr9Qf2V/+SNaT/vN/Ja9 bLU1zX8v1NYu7PiqPTbk38SR3arEImdYyp+9/d/3qgnuLOG0MFzA5uw7Rh2baqRN7d2z3p2o 6jdWMEUktwBGj/I7Hcq9v1rNuIbnWUWKGUxvKz70k/h4+bbXyZaky1d6jA00k2lxwwoQqBJM 7F+XDNuJO7nNbGlT6T4gs0DxRxXNqFAun4DdeOPvdK5pLQX1pZWUnlKUCrIqg9FPA+tb66Kl tYLDZQyiVQZURvlUbSf6UpRiojUeZ3ZPclpgp0pXygaB3Yldx/vVG1iYnkuYrB8KQNjOP3ox 8xWli1eeby4UBQeXh3U56Vv6ZeQX7W66kwjjaNvK2r0YcY/GsIvodENHdEEL2OowW0MsFzFe Q8/KcIR/c9+KtpaaVf3LzahctGLe2kn2E7WVlI2/73fiqj3MsmrSPYWny2cm913csxGNtQap dWQS1vri2ctFK2xUOWZeDlv7vORj3o6mrlGa5i1fXktlZRXkM4huLhS0oZhuk4+XjH6VTs5b q7mhubS7+zx7Sr749qM7fe/p+lC3cM8gHlKyzHe7zj5h7LVpJReala6RbOkESoVUv/srkn8S QPwqdXuZSdkrFbSk1PTNQuprd3vWiHny7Twnbd9KYLdb+dZLqMwR7/NLdA3qPemCO/sbeZLj dEbpjHNcjDKwzwuP7ucVUmkuILy33SeYhbcqbsiMdOlb3uKT90sx6jYm5mupLNnjkcRo44Cr 0+WuIvteuYtcmvJDKtr5nlFl/jQ8Bfeuj1ErNbTo1zsJ3wbY/uIG+7/wLNYGn2lhZ2kEDO97 LFGYo0Yfef8AvflXTTtE593qD6fbSW8k0No8wgdnR9x+7jmkn0+VbW6mM9uzzNG6oxGWTZ83 zH37etTpdXV1GdOB2LFktCvdc4q5quj22nwWZu7mN/NPnM2csFI+5VOauX8OpjPbLewLFKsj XUibI1jXOIlo0K7uJmmsbe2VD5eC38TL3rYjzZIbm0KySvA3kqiniLB3fRqi0/ThaW8GouPK N2siThG+bZu6/wCzTk/dFGcS7NDdXGmYeNpXDN521go27ScD3xVG0hazurQSpsEqFlVlx24S tAz20dojywMtrbM7RR7v9exGFqyHTWHW5mDhohsKBflirnU+XQXLzGTottNZ6s1zqNizRtmT aD13Y2569Dj8q6HUL+KGWYGUySeWJcMnzMcfpWZYzNbQvqjXS7WdoYFP3gq/5NVr3Woo5BeS DyrtwZfnPzMB22+9S4uTCV1oSaVb2+pIuoMZ2iETRFJH2ortzk5B+6aitba8s9UeWcQf6ODt 287x/fXNM0mWeW7tdMnmkt11Ng8+Of3fDcf7WP61ddItFupPP+YOR5KyP+8kT+6vpWztCNkT yvqN1Pw4UnhvWM0FtNH5sk8i5WVj90L9KpeIbp0021jtoVMLjBRsbx23+1T6hrNwWhsLi5li tgTIsZOU3ccCqC6oNRkmjuoEbK7Mn0pQ5nuXHl6FvR4rzR9Na8F7FFBMpgTb1bHJX9etV9c0 aG6t3vbe7hEKKsaxHJkJYfe4rQ1G4uhZ6fpeoWttGf3gt5I14CggMzflmqWiWkQ1YQS30YRm 3o5PyttzVWe5EtzOsNPWeeZoQ6/ZxjYF5zz/APXrVTGm6vZloUiiwHkaRDtYgZ+b2/Gsi71e 7u9ZmksI2AMcjrIvy+dJn71Tz6pre+2tNRlWeJkCTRt/yyVv7v8AtVUI3+Ih6ali48TxPd3M M1uiqruEVPlGAD7VVn0+CFNJjtpZJNQltzcSQKvyLuO5Pm9xVK2a21C6uUjgn8uJlbeyj/gX NXdV1EHU0t7CCS22RxmWUnKxbeF/nT0gKMuYyLyW6886c773t13gP95Oc4qzc39ubsajqFvJ cz+UNjOxVTgEnbj8utXfEdmb22XV55FS8iDAhU2+c3G1lP05rM1qFbrR7C9trmGK4gOyVGbo f/ss1pzX2FZmXZ3suqXst60DW8DJmNUXDFf7tWZ72VLAxl0mVJFKxFvuJ/dI+vP40mlXK3N3 9g1Jdlrbr5YVF+7n1arNtZW+l6k15HZpLawfK7M2773AqpSjayL5Uo3JYrPfaxXE8lqBbx/v IAuxWVidhXjrUU+/Sra+XTAWS4CqGddmI+p6/wBKma2nn1CcNGChRTaorD5ttNaTe6nU/ljB VpXb+JcfdRfx/Sp5rihbeRj22kapJG107RyzMFaGQkKze1Xdd0m7NrY6hewlo/LZJAW+VX35 /rW/LbXGo6fNdaegKo4+yqVxsWk1JPN0bT4VButiSeejfwyZGP51Sq9i5vlfumHZ6MdRmmv7 a5W2gt/naZzhVKj7n+1Ucsrs9pdTMf8ASeSFPULxj/61bemxtZ+H2thal3llYGJvvb6y0shD c/Z9QGLpWBiCthVapc+aRMveVxNMaLSVOoR3aSSESRC3K/d3DBFYeuoLPVmsogJHjEZG/ht2 Bn9asXDW0kVwjFjeLL8rZwir/wDXqvqP2iaa1BAaUv8ANkct/wAC+laRtzWMXoixdyX8Nyl5 GpkilXbMWTcuW4b/APVWNZ3F68z20iK3mNsVUUbv95a3BNFcWg03zJXBl3RMn3ty1Rt7S5uL lTbR7JIpPMYldvzVpTkr6hFX0Lk2oyR/8S7U1likVMQy7PnUf7VZb2Bs7nYl1IZCMoxO3NdR dTwXC25ulMk6SBZ7gHfu6YXFYs2nzTwTWcRMsUjl0Yj5ozVqT6G0Y8u5Clw+maNJqltDH9qm nEKhvvI3dl9c+tZk8d3cTLbq7yyBzNKSfmd/Q11Ftp9rd6ab/wAuRmS3YNE6/KrrkbvzIqlp 2jSXcyXlrGFuchpTKNqq6/w0RnGL1IsrlS3vXe2mtt+xQdyLu2sWYjcw/wDiafe3EYeO6SPy XCiOUBdqs309a2NS02NbCO6vPIEjys+0nDh1BP8A3y39Kp3enyajEsVtb7pfLWXB+4W7jNVK d9SLsbpWn6vq8x1iOAtaRzKAZCCHfgnj6Vvaj4puJLYafbwtaNvIcbMcfw8dqge7k0rS7S1u QHitg1wGQ7VaXpt98VFoEdpqzwS6zdNJc30zSgum35Bx8x+tYv3lcvl5o6lHS2Q3TTTwASRT iNWU437gfvH6ioEfWItRkjhc28vmtOGh5z2VR61oWcSWP2pzco2ycsoAyu3nH16VWtNVi0+0 eVQryM7MHbNaaNWISEnv7u4vYo4XXz5vkB2bVRf4mx+Bqv4h1e1a+lMUxWOzgEayhcZfv8vv WHHezXV7NcSXQTduLMrdfm6e1W4oDq8lzp1oTLPLh5W/2eBx+lXGKWpoox6DtLuxqN+0ksmy 3dAzS7eVYipbyc6jeJFao3lyrhivAC/3mrAiivIr1bHymUBzGVXgHb3rYEIhvkOpaqsaoi/J Fg/hVST5rkS2L2q21u0Cpd6raw+VtMQQsW+UelU7dbWIJCdTaZ5svvki2qv41TvJbG91CM6Z ZzTrEu5pZGx+GKmm0u9lZJljuEhX7rFcqvvRyxtoEY30NmxBg0gwveRtIZdv71ztZhWRFLHo 97NI8LebL/qP7u3+Ko4oJ5ZfsiXMdyyHzJGDYXOfWq/iCOZFVLrf5qfKHLfL838IqY0tbGsK fQu69qMV9LA5ffGirlf7tUGhs1iNpDCwSd2n83+9nt+HpVSCznkEflSKJM7HRj/B/erQNpLd eVZpOk/kv+4hVtm5v/Zq3jDlVkUkugxb2J4prS8hErxAKjTH5iP9k+lWItIt9ZsproaulrOw URpLJtjyvYU57Sz1HTrqAowv7Ft3zDGxf7rVzZvp4mMfl+XFJtUNjgt6gVcPIiKUnoadhpks Ba2lkKjfmd1cN+K10h0pkhlurieF4mxJC+8D+H72P6VnaBJfgzavcIiuImjSNhw4x1x61zz6 msUE1zDNIsTPgwSflWUozqSHy9jo9OsYI7yC6ywgR92Cc+bL/hUMGpQvrMzy/vp03KqBPuck 1HpFhresabLewRCC1h+RXZ9ip+fWtrT7TR9PszeWMqTXC2zQykHLF89aU49JBG/UowSG6lS7 ln/dsxQD+5xUeu640YtdPtY9kTjzFdW+U+tOv9Jgfw8lxpF21zNaM0s1tjEqe/8AtCq50pJn SSeVY4YAHV5PvdMsu2lFR3FZdCaKKyn23Cv9mlmG5d6/u+P4q/UH9lf/AJI1pP8AvN/Ja/KT W9REsqy2jP3VEP3MV+rH7Ks0b/BnSWVwRubn8Fr0sCrczXl+o4prcpfG/wDYr8NHUEtPAF+m g2LPve3kklugT9Zi5H5158n7Fmqqwk/4TmHft2lvs69O/wDBRRXR9Uw//PuP3IrbYWH9izVb di0HjqNCwwcQj/4irafsg+JUk81fiIu7yzFkwKflIwRynp360UUfU8P/AM+4/ch3ZVh/Yt1e AARePEAHQGIH+aVLF+xxr8MQhj+II2K28AxA4Oc90oopfU8N/wA+4/cg5n3JU/ZB8SRyzTR/ EKNZLjHmMLdATgY/ucfhVY/sYawV2Hx6uMlv9UOvr9yiij6nh/8An3H7kF3awsf7GWtRbdnj 5PlBAzCDx+KVJF+x14ghuVvI/iAglThWMCnH4FMUUUfU8N/z7j9yC7GSfsaa5K7vJ4+RjISW BhGMnrxswPwpJP2MdZlfzH8eR7tqrkQAcAYA4Siij6nhv+fcfuQXZWi/Yhvom3p44XO/zOUJ +b15WlT9iK+jaRo/G8YMoIbEXv8A7vH4UUU/quH/AJF9yEKf2JNQaf7QfHCeZsEe4R4+Udvu 1Nc/sXatd2v2O58cwvF0ANuueufvbM/rRRR9Uw//AD7X3Id2JH+xdq8Tl4/HaAlBGf3I+6O3 3KST9ivVZYfs8njqMx8ceSB099maKKf1Wh/IvuQhG/Yq1R4Ugbx2hSPBVTEOMdP4aen7GGsx sWTx8AT1/d9f/HaKKX1PD/8APuP3Id2Qn9iTUTEYT46GwgggIR1OT/DTJP2H7yaQyzeNo3cg Llos8DoBleKKKf1Wh/IvuQrsnX9ivVVnjuV8doJIlCoRCOBjHTZjpRcfsV6rdXH2u48do8oX aGMQ4GMYA24FFFH1Wg9XBfcguyCf9h27uShm8bI3lqFX93jAHT+Gki/YcuYZmuI/GsYdjkny 88/Tbiiij6tQ/kX3IB8/7EV/cyJLceOhI0e7YWUnGev8PtTov2JtShRI4/HYCxghBsJAyMH+ Giij6rQ/kX3IBi/sQ3quJF8bR7hjB8rOMDA/hol/Yhv5wRN45D5JPzISf/QaKKPqtD+Rfcg8 gj/YhvooJbaPxwginBEiiPg56/w8fhSJ+w/eJjb41j4x/wAss56dfl56DrRRR9VofyL7kKyF b9iC9aQyv44VmOMkx56e22oV/YUkRJY18ZptmILgoTk/988fhRRQsLQW0F9yGNP7CGXaT/hM IgWxuwhAOPbbinj9hWQFiPGUQ3rtYCPAI57bcd6KKf1aj/IvuQCr+wzOudvjSMbkEZ/dn7vp 92oZv2DFuHV5vGCMVAVeGGAOnaiil9WofyL7kKyLUP7EN9BGsUXjhVVF2KNh4H/fNI37D140 JgPjgbD1AUjvnrtzRRR9WofyL7kMlg/Yo1O2yYfHSKSQSfKyfzK5qpdfsJveXLXdx4yRpX+8 wQrn8AoFFFH1ah/IvuQDE/YMSNHRfF0WHILZjJzg5H8NLF+weYZPNi8ZKrYAzhug/Ciin9Xo /wAi+5CshkP7BEVu2+DxdGh3b8hW65znpUjfsJO5DN4yTIXaDtPAzn+7RRR9Xor7C+5AklsO H7CsoRkXxoqhhtYKpGR74XmmxfsINCweLxmqlRgcN/hzRRT9hS/lX3Ie+5Nb/sOXVogjg8ao qgscGMnr16rUf/DCku5n/wCE0XLSeaTtP3/X7tFFL6tRf2F9yFZEUv7BazyCWXxirMBgH5um c+nrVmD9h26toTbw+NUWM5yPLz+pXNFFP2FL+VfcgsinJ+wNBNb/AGWXxajRb/M2kN9716Zq X/hg/Fw10PGKCRl2EhWAx6AbcCiij2FL+Vfch2Gn9gtGjMR8XR7WXaRsPI/75qGT9gC0liSG TxYhSP7q/Pj+XP40UUewpfyr7kKy7EqfsEW0ZYp4lswWOTm2B5/74pqfsC20dw91F4qhjldd rNGhXj8F4ooo9jS/lX3BypbIZ/w7/tNzP/wlaZfG4/P/AIVD/wAO9NLyW/4SaLJ5J+f/AAoo p+xp/wAq+4LII/8AgnrpsWfL8VAZJJ+eTvVuL9gryIhDD42dEAxtEkmMZz6UUUeyp/yr7gsl sQp/wT+so5HkTxVGDIwduGwSOnGMVHdf8E9tOvWLXXioOScn55Bz+Aooo9lTX2V9wxI/+Cee mRSiaPxSA4G0EvIePxpsv/BO/SZphcSeJkMinIYNIMH8BRRT9lD+VfcBbb9gS3e8e/bxZGZ5 I1jdtrYZR0yMYP161A//AAT505444X8URskTF0U78KT17UUUvZU/5V9wJJbEyfsB26SpMni1 A8f3Gw2R+lV7n/gnppV5J5tz4lhdt27JD9c5z09aKKPZU1tFfcBZvf2BodQtVsrvxerwL0jG 9V/IAVBD/wAE99OgDCHxRGu8ANgvyB07UUUeyp/yr7gJIf8Agn/Z28pmh8VRo7dWAbJ/So5v +Ce+nXDs83ilXL/eJL/4UUUexpraK+4LIYf+Cd2jSDbJ4kjIAwBukGK+wvgr8DbbwP8AD+x8 OxagkqwMxDAHngf4UUVajGPwoLs//9k
Date: Oct 04, 2012
Subject: Re: Fwd: Craig's List Ad
At 04:05 PM 10/4/2012, you wrote: >For those of us that are familiar with farm equipment > Mr. Scott. It seems that the AeroElectric-List
September 22, 2012 - October 06, 2012
AeroElectric-Archive.digest.vol-lj
