AeroElectric-Archive.digest.vol-lr
March 26, 2013 - April 21, 2013
      chose were to an specs. I ended up ordering a big assortment of small AN
      screws.  If I could have gotten an stuff with 6 lobe recess, I would have
      prefered it.  Definitely preferable to Phillips.
      Raymond Julian
      Kettle River, MN.
      "And you know that I could have me a million more friends,
      and all I'd have to lose is my point of view." - John Prine
      On 03/26/2013 07:20 AM, William Schertz wrote:
      Also note that they carry 100 degree flat head with Torx drive, much nicer
      for avoiding stripouts like phillips
      Bill Schertz
      -----Original Message----- From: Werner Schneider
      Sent: Tuesday, March 26, 2013 5:41 AM
Subject: Re: Blind riveting ground to airframe?
Ray checkout http://www.microfasteners.com/catalog/products/SSC.cfm I replaced nearly all of my Phillips with the 6 lobe screws Cheers Werner On 25.03.2013 22:21, rayj wrote: Agreed. I was looking for some "blessed" #10 hex head bolts because I prefer a hex head over slotted or phillips screw heads. <="" span=""> http://www.matronics.com/Navigator?AeroElectric-List <="" span=""> <="" span=""> http://forums.matronics.com <="" span=""> http://www.matronics.com/contribution ================================== st">http://www.matronics.com/Navigator?AeroElectric-List ================================== cs.com ================================== matronics.com/contribution ================================== ________________________________________________________________________________
Date: Mar 26, 2013
Stainless and aluminum don't play nice together. The aluminum will donate ions and corrode. Cad plated steel is the AN way. The cadmium is more anodic than the aluminum and acts as a sacrificial barrier. Eventually, it has no more ions to donate and loses it's value as a corrosion preventative. Time then for new hardware. Another approach would be to prime your hardware and install it wet. Ed Holyoke On 3/26/2013 7:25 AM, Jay Hyde wrote: > > Hello Sacha, > > I have the same problem in South Africa. For non structural parts I > simply use Metric sized bolts and nuts; usually stainless steel ones > to protect against corrosion. Stainless steel and aluminium have > relatively close galvanic potentials as far as I can see. I have > given up trying to source, or even understand (!) the imperial nut and > bolt thread system; its far easier to walk into a bolt store and ask > for M6 x 25mm bolts and M6 nuts. J > > For structural parts you must however use AN fasteners and they are > not too difficult to understand (unless you need to order a tap or > die) ; I order them directly from Aircraft Spruce in the US. > > Johannesburg Jay > > *From:*owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of *Sacha > *Sent:* 26 March 2013 03:58 PM > *To:* aeroelectric-list(at)matronics.com > *Subject:* Re: AeroElectric-List: Blind riveting ground to airframe? > > Does anyone know what the METRIC equivalent of an AN fastener is and > where I can buy some? I'm in Italy, so preferably somewhere in > Europe, though I'm willing to order from the US if necessary. I've > been going nuts (no pun intended) trying to look for some but can only > find a few manufacturers, nothing for the retail buyer. > > > On Mar 26, 2013, at 13:42, rayj > wrote: > > Looks like a great source for fasteners. I wanted to be sure the > ones I chose were to an specs. I ended up ordering a big > assortment of small AN screws. If I could have gotten an stuff > with 6 lobe recess, I would have prefered it. Definitely > preferable to Phillips. > > Raymond Julian > > Kettle River, MN. > > > > "And you know that I could have me a million more friends, > > and all I'd have to lose is my point of view." - John Prine > > On 03/26/2013 07:20 AM, William Schertz wrote: > > > > Also note that they carry 100 degree flat head with Torx > drive, much nicer for avoiding stripouts like phillips > Bill Schertz > > -----Original Message----- From: Werner Schneider > Sent: Tuesday, March 26, 2013 5:41 AM > To: aeroelectric-list(at)matronics.com > > Subject: Re: AeroElectric-List: Blind riveting ground to > airframe? > > > > Ray checkout > http://www.microfasteners.com/catalog/products/SSC.cfm > > I replaced nearly all of my Phillips with the 6 lobe screws > > Cheers Werner > > On 25.03.2013 22:21, rayj wrote: > > Agreed. I was looking for some "blessed" #10 hex head bolts > because I > prefer a hex head over slotted or phillips screw heads. > > > * * > > * * > > * * > > * * > * * > ** > ** > ** > ** > ** > ** > ** > *http://www.matronics.com/Navigator?AeroElectric-List <3D%22http:/www.matronics.com/Navigator?AeroElectric-List>* > ** > ** > ** > ** > ** > *http://forums.matronics.com <3D%22http:/forums.matronics.com>* > ** > ** > ** > ** > ** > *http://www.matronics.com/contribution <3D%22http:/www.matronics.com/contribution>* > ** > * * > * > > > * ________________________________________________________________________________
Date: Mar 27, 2013
Subject: Re: LED similar to EL strip
At 08:58 PM 3/26/2013, you wrote: Saw this item and thought of the EL strips that were so noisy. This is listed as a flat LED. http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&productId=2153174&catalogId=10001&CID=PDF I get the impression from some of the recent posts that some seem to think that LED lights are noisy. THEY ARE NOT NOISY! The high power leds need to have a current regulated supply, and one of the more efficient methods of producing a regulated current is to use a switching supply, which has an oscillator built in. This oscillator is often the culpret that radiates the RF which gets into our radio receivers. These regulators can be designed quite easily to be quiet. Most of the ones that we experimental aircraft builders are having a noise problem with were originally built for automotive use where noise in the 120mhz range was not an issue. Roger Cool find Roger . . . I'll pursue it. EL (electroluminescent) lights are essentially capacitors with a dielectric that emits light when excited by an alternating electro-static field of generally 40-200 volts range and 200 to 1000 Hz. LED lights are solid state diode junctions that emit light when excited by a current flow in the forward direction across the junction. Neither light technology is inherently noisy. The EL technology requires a DC to AC converter. It's usually variable to adjust for relative lamp brightness. LED's run happily on DC excitation taken directly from the bus . . . again paired with some technology for varying the current to the lamp. Rudimentary controls comprised of series resistance are inefficient but tolerable for small loads. The high power LEDs perform best when supplied by constant current DC to DC sources. These can be variable under pilot control or fixed depending on application of the lights. ALL of our discussions here on the List about "noisy lights" have centered on high power applications for LEDs as position lights and more recently, landing and taxi lights. The solid state lamps are not inherently noisy but the power supplies needed for efficient utilization can be and often are objectionably noisy for use on airplanes. The discussions have pondered techniques for adapting commercial off the shelf examples of such products to our airplanes by first determining if there noise levels are acceptably low and then applying additional filters as necessary. It's easy to build power supplies that are airplane friendly . . . but suppliers of the attractive COTS products probably couldn't care less about getting their products onto airplanes. The item featured in the Jameco catalog has an interesting form factor reminiscent of an EL light panel. I'll get one and see what it's all about. Emacs! Several readers have noted the proliferation of led strip lights fitted with multiple surface mounted LEDs. Here's one of many examples: http://tinyurl.com/chsx9j2 These are assemblies 3LED/1Resistor modules about 2" in length. Long strips can be cut to length between modules. These are very user friendly. I've got plans to use about 100 feet of these strips in an overhaul of room and counter lighting in my kitchen. Bob . . . ________________________________________________________________________________
Subject: Re: vhf transponder interference
Date: Mar 27, 2013
Thank you Bob I did my soldering last weekend with RG-142 but I installed the impedance bushing not knowing better, anyhow, I don't think it will be harmfull. JP Read this topic online here: http://forums.matronics.com/viewtopic.php?p=397176#397176 ________________________________________________________________________________
Subject: Blind riveting ground to airframe?
Date: Mar 27, 2013
How does the the stainless firewall riveted with aluminum rivets to aluminum sheet and angle stock play nice together? Bevan _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ed Holyoke Sent: Tuesday, March 26, 2013 9:35 PM Subject: Re: AeroElectric-List: Blind riveting ground to airframe? Stainless and aluminum don't play nice together. The aluminum will donate ions and corrode. Cad plated steel is the AN way. The cadmium is more anodic than the aluminum and acts as a sacrificial barrier. Eventually, it has no more ions to donate and loses it's value as a corrosion preventative. Time then for new hardware. Another approach would be to prime your hardware and install it wet. Ed Holyoke On 3/26/2013 7:25 AM, Jay Hyde wrote: Hello Sacha, I have the same problem in South Africa. For non structural parts I simply use Metric sized bolts and nuts; usually stainless steel ones to protect against corrosion. Stainless steel and aluminium have relatively close galvanic potentials as far as I can see. I have given up trying to source, or even understand (!) the imperial nut and bolt thread system; its far easier to walk into a bolt store and ask for M6 x 25mm bolts and M6 nuts. J For structural parts you must however use AN fasteners and they are not too difficult to understand (unless you need to order a tap or die.) ; I order them directly from Aircraft Spruce in the US. Johannesburg Jay From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Sacha Sent: 26 March 2013 03:58 PM Subject: Re: AeroElectric-List: Blind riveting ground to airframe? Does anyone know what the METRIC equivalent of an AN fastener is and where I can buy some? I'm in Italy, so preferably somewhere in Europe, though I'm willing to order from the US if necessary. I've been going nuts (no pun intended) trying to look for some but can only find a few manufacturers, nothing for the retail buyer. On Mar 26, 2013, at 13:42, rayj wrote: Looks like a great source for fasteners. I wanted to be sure the ones I chose were to an specs. I ended up ordering a big assortment of small AN screws. If I could have gotten an stuff with 6 lobe recess, I would have prefered it. Definitely preferable to Phillips. Raymond Julian Kettle River, MN. "And you know that I could have me a million more friends, and all I'd have to lose is my point of view." - John Prine On 03/26/2013 07:20 AM, William Schertz wrote: Also note that they carry 100 degree flat head with Torx drive, much nicer for avoiding stripouts like phillips Bill Schertz -----Original Message----- From: Werner Schneider Sent: Tuesday, March 26, 2013 5:41 AM Subject: Re: AeroElectric-List: Blind riveting ground to airframe? Ray checkout http://www.microfasteners.com/catalog/products/SSC.cfm I replaced nearly all of my Phillips with the 6 lobe screws Cheers Werner On 25.03.2013 22:21, rayj wrote: Agreed. I was looking for some "blessed" #10 hex head bolts because I prefer a hex head over slotted or phillips screw heads. http://www.matronics.com/Navigator?AeroElectric-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Date: Mar 28, 2013
At 01:16 AM 3/28/2013, you wrote: >How does the the stainless firewall riveted with aluminum rivets to >aluminum sheet and angle stock play nice together? > >Bevan I seem to recall some conversations many Many MANY moons back about monel rivets used on firewall assemblies. Wasn't my area of interest at the time. It would be interesting to dig out a Cessna Service Parts catalog of the 1960's and see what attaching parts are called out for oowl attach brackets. Bob . . . ________________________________________________________________________________
Date: Mar 28, 2013
At 11:16 AM 3/27/2013, you wrote: >At 08:58 PM 3/26/2013, you wrote: > >Saw this item and thought of the EL strips that were so noisy. This >is listed as a flat LED. > >http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&productId=2153174&catalogId=10001&CID=PDF > I've got one of these critters on order. They're back-ordered for about 10 days. Must be a popular item. Here's the manufacturer's data sheet http://www.aeroelectric.com/Mfgr_Data/Lamps/JKL_Lamps/ZLP-MULTI.pdf The item stocked by Jameco is 3.5" long by .48" wide and draws 350 ma at it's rated 10.2 volts. It's also said to have a max operating voltage of 12 volts. 3.5 watts dissipated into this area and volume suggests it's a POWER device with no particular power conditioning capabilities built in. I.e. it would best be driven by a constant-current power source (like the buck-pucks). Will know more about it when we can get our hands on one. Bob . . . ________________________________________________________________________________
Date: Mar 28, 2013
From: DeWitt Whittington <dee.whittington(at)gmail.com>
Yes, Bob, that is the answer. Our Sportsman kit came with a supply of Monel rivets for the thin, stainless firewall. Dee On Thu, Mar 28, 2013 at 10:07 AM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 01:16 AM 3/28/2013, you wrote: > > How does the the stainless firewall riveted with aluminum rivets to > aluminum sheet and angle stock play nice together? > > Bevan > > > I seem to recall some conversations many Many MANY moons > back about monel rivets used on firewall assemblies. Wasn't > my area of interest at the time. It would be interesting to > dig out a Cessna Service Parts catalog of the 1960's and see > what attaching parts are called out for oowl attach brackets. > > ** > > ** Bob . . . > > * > > * > > -- DeWitt (Dee) Whittington 804-677-4849 iPhone 804-358-4333 Home www.VirginiaFlyIn.org Building Glasair Sportsman with 3 partners ________________________________________________________________________________
Date: Mar 28, 2013
At 11:47 AM 3/28/2013, you wrote: >Yes, Bob, that is the answer. Our Sportsman kit came with a supply >of Monel rivets for the thin, stainless firewall. > >Dee I think it was in the booth at OSH that an EAA'er said they were "harder than the hubs of hell", was that you? Bob . . . ________________________________________________________________________________
Date: Mar 28, 2013
Yet there are many thousands of RV-x's flying with regular A/N aluminum rivets holding stainless firewalls to aluminum *and steel* structure. Many of them for several decades. Aluminum is primed; steel is either primed or powder coated (depending on the age of the kit). Things get bent or cracked occasionally, but I've never seen anyone on any of the user groups complain about rivet or aluminum corrosion in the firewall area. Charlie On 03/28/2013 11:47 AM, DeWitt Whittington wrote: > Yes, Bob, that is the answer. Our Sportsman kit came with a supply of > Monel rivets for the thin, stainless firewall. > > Dee > > > On Thu, Mar 28, 2013 at 10:07 AM, Robert L. Nuckolls, III > > > wrote: > > At 01:16 AM 3/28/2013, you wrote: >> How does the the stainless firewall riveted with aluminum rivets >> to aluminum sheet and angle stock play nice together? >> >> Bevan > > I seem to recall some conversations many Many MANY moons > back about monel rivets used on firewall assemblies. Wasn't > my area of interest at the time. It would be interesting to > dig out a Cessna Service Parts catalog of the 1960's and see > what attaching parts are called out for oowl attach brackets. > > Bob . . . > > ________________________________________________________________________________
Date: Mar 28, 2013
No, don't remember that. Ours were -3s and yes, and even then they were not easy to drive. Two of us did it holding the firewall horizontal over a bucking bar clamped in a vise. Dee On Thu, Mar 28, 2013 at 1:01 PM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > nuckolls.bob(at)aeroelectric.com**> > > > At 11:47 AM 3/28/2013, you wrote: > >> Yes, Bob, that is the answer. Our Sportsman kit came with a supply of >> Monel rivets for the thin, stainless firewall. >> >> Dee >> > > I think it was in the booth at OSH that > an EAA'er said they were "harder than the > hubs of hell", was that you? > > > Bob . . . > > -- DeWitt (Dee) Whittington 804-677-4849 iPhone 804-358-4333 Home www.VirginiaFlyIn.org Building Glasair Sportsman with 3 partners ________________________________________________________________________________
Subject: Re: Wires in wing
Date: Mar 28, 2013
Pix of Panduit LHMSs. These really are better than what you can make. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=397214#397214 Attachments: http://forums.matronics.com//files/lhms_186.jpg http://forums.matronics.com//files/lhmscloseup_853.jpg ________________________________________________________________________________
Date: Mar 28, 2013
With primer barriers, particularly on the aluminum. Most sheet stock in use on kitplanes is alclad and doesn't generally need primer. All extruded angle and bar stock is not clad and needs to be primed to prevent corrosion. Many folks prime all faying surfaces (where two pieces fit together) and it should certainly be done at dissimilar metal joints. Ed Holyoke On 3/27/2013 11:16 PM, B Tomm wrote: > How does the the stainless firewall riveted with aluminum rivets to > aluminum sheet and angle stock play nice together? > Bevan > > ------------------------------------------------------------------------ > *From:* owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of > *Ed Holyoke > *Sent:* Tuesday, March 26, 2013 9:35 PM > *To:* aeroelectric-list(at)matronics.com > *Subject:* Re: AeroElectric-List: Blind riveting ground to airframe? > > Stainless and aluminum don't play nice together. The aluminum will > donate ions and corrode. Cad plated steel is the AN way. The cadmium > is more anodic than the aluminum and acts as a sacrificial barrier. > Eventually, it has no more ions to donate and loses it's value as a > corrosion preventative. Time then for new hardware. Another approach > would be to prime your hardware and install it wet. > > Ed Holyoke > > On 3/26/2013 7:25 AM, Jay Hyde wrote: >> >> Hello Sacha, >> >> I have the same problem in South Africa. For non structural parts I >> simply use Metric sized bolts and nuts; usually stainless steel ones >> to protect against corrosion. Stainless steel and aluminium have >> relatively close galvanic potentials as far as I can see. I have >> given up trying to source, or even understand (!) the imperial nut >> and bolt thread system; its far easier to walk into a bolt store and >> ask for M6 x 25mm bolts and M6 nuts. J >> >> For structural parts you must however use AN fasteners and they are >> not too difficult to understand (unless you need to order a tap or >> die...) ; I order them directly from Aircraft Spruce in the US. >> >> Johannesburg Jay >> >> *From:*owner-aeroelectric-list-server(at)matronics.com >> [mailto:owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of >> *Sacha >> *Sent:* 26 March 2013 03:58 PM >> *To:* aeroelectric-list(at)matronics.com >> *Subject:* Re: AeroElectric-List: Blind riveting ground to airframe? >> >> Does anyone know what the METRIC equivalent of an AN fastener is and >> where I can buy some? I'm in Italy, so preferably somewhere in >> Europe, though I'm willing to order from the US if necessary. I've >> been going nuts (no pun intended) trying to look for some but can >> only find a few manufacturers, nothing for the retail buyer. >> >> >> On Mar 26, 2013, at 13:42, rayj > > wrote: >> >> Looks like a great source for fasteners. I wanted to be sure the >> ones I chose were to an specs. I ended up ordering a big >> assortment of small AN screws. If I could have gotten an stuff >> with 6 lobe recess, I would have prefered it. Definitely >> preferable to Phillips. >> >> Raymond Julian >> >> Kettle River, MN. >> >> >> >> "And you know that I could have me a million more friends, >> >> and all I'd have to lose is my point of view." - John Prine >> >> On 03/26/2013 07:20 AM, William Schertz wrote: >> >> >> >> Also note that they carry 100 degree flat head with Torx >> drive, much nicer for avoiding stripouts like phillips >> Bill Schertz >> >> -----Original Message----- From: Werner Schneider >> Sent: Tuesday, March 26, 2013 5:41 AM >> To: aeroelectric-list(at)matronics.com >> >> Subject: Re: AeroElectric-List: Blind riveting ground to >> airframe? >> >> >> >> Ray checkout >> http://www.microfasteners.com/catalog/products/SSC.cfm >> >> I replaced nearly all of my Phillips with the 6 lobe screws >> >> Cheers Werner >> >> On 25.03.2013 22:21, rayj wrote: >> >> Agreed. I was looking for some "blessed" #10 hex head bolts >> because I >> prefer a hex head over slotted or phillips screw heads. >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> * * >> >> * * >> >> * * >> >> * * >> * * >> ** >> ** >> ** >> ** >> ** >> ** >> ** >> *http://www.matronics.com/Navigator?AeroElectric-List <3D%22http:/www.matronics.com/Navigator?AeroElectric-List>* >> ** >> ** >> ** >> ** >> ** >> *http://forums.matronics.com <3D%22http:/forums.matronics.com>* >> ** >> ** >> ** >> ** >> ** >> *http://www.matronics.com/contribution <3D%22http:/www.matronics.com/contribution>* >> ** >> * * >> * >> >> >> * > * > > href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > * > * > > > * ________________________________________________________________________________
Date: Mar 29, 2013
Ed, Drifting somewhat from the theme of this list, but to say that alclad doesn't need priming is a bold statement. In Texas maybe, but in a cool maritime climate it isn't really adequate protection against the dreaded metal worm in the long term. For grounding studs I have seen bright zinc plated bolts used with the primer removed from the structure they were inserted into. To make it clear what they are the paint finish was restored with a contrasting colour (blue in this case I'm thinking of against puke yellow primer), but leaving the nut holding the stud in unpainted for good electrical connection. Peter On 29/03/2013 02:57, Ed Holyoke wrote: > With primer barriers, particularly on the aluminum. Most sheet stock > in use on kitplanes is alclad and doesn't generally need primer. All > extruded angle and bar stock is not clad and needs to be primed to > prevent corrosion. Many folks prime all faying surfaces (where two > pieces fit together) and it should certainly be done at dissimilar > metal joints. > > Ed Holyoke > > On 3/27/2013 11:16 PM, B Tomm wrote: >> How does the the stainless firewall riveted with aluminum rivets to >> aluminum sheet and angle stock play nice together? >> Bevan >> >> ------------------------------------------------------------------------ >> *From:* owner-aeroelectric-list-server(at)matronics.com >> [mailto:owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of >> *Ed Holyoke >> *Sent:* Tuesday, March 26, 2013 9:35 PM >> *To:* aeroelectric-list(at)matronics.com >> *Subject:* Re: AeroElectric-List: Blind riveting ground to airframe? >> >> Stainless and aluminum don't play nice together. The aluminum will >> donate ions and corrode. Cad plated steel is the AN way. The cadmium >> is more anodic than the aluminum and acts as a sacrificial barrier. >> Eventually, it has no more ions to donate and loses it's value as a >> corrosion preventative. Time then for new hardware. Another approach >> would be to prime your hardware and install it wet. >> >> Ed Holyoke >> >> On 3/26/2013 7:25 AM, Jay Hyde wrote: >>> >>> Hello Sacha, >>> >>> I have the same problem in South Africa. For non structural parts I >>> simply use Metric sized bolts and nuts; usually stainless steel ones >>> to protect against corrosion. Stainless steel and aluminium have >>> relatively close galvanic potentials as far as I can see. I have >>> given up trying to source, or even understand (!) the imperial nut >>> and bolt thread system; its far easier to walk into a bolt store and >>> ask for M6 x 25mm bolts and M6 nuts. J >>> >>> For structural parts you must however use AN fasteners and they are >>> not too difficult to understand (unless you need to order a tap or >>> die...) ; I order them directly from Aircraft Spruce in the US. >>> >>> Johannesburg Jay >>> >>> *From:*owner-aeroelectric-list-server(at)matronics.com >>> [mailto:owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of >>> *Sacha >>> *Sent:* 26 March 2013 03:58 PM >>> *To:* aeroelectric-list(at)matronics.com >>> *Subject:* Re: AeroElectric-List: Blind riveting ground to airframe? >>> >>> Does anyone know what the METRIC equivalent of an AN fastener is and >>> where I can buy some? I'm in Italy, so preferably somewhere in >>> Europe, though I'm willing to order from the US if necessary. I've >>> been going nuts (no pun intended) trying to look for some but can >>> only find a few manufacturers, nothing for the retail buyer. >>> >>> >>> On Mar 26, 2013, at 13:42, rayj >> > wrote: >>> >>> Looks like a great source for fasteners. I wanted to be sure >>> the ones I chose were to an specs. I ended up ordering a big >>> assortment of small AN screws. If I could have gotten an stuff >>> with 6 lobe recess, I would have prefered it. Definitely >>> preferable to Phillips. >>> >>> Raymond Julian >>> >>> Kettle River, MN. >>> >>> >>> >>> "And you know that I could have me a million more friends, >>> >>> and all I'd have to lose is my point of view." - John Prine >>> >>> On 03/26/2013 07:20 AM, William Schertz wrote: >>> >>> >>> >>> Also note that they carry 100 degree flat head with Torx >>> drive, much nicer for avoiding stripouts like phillips >>> Bill Schertz >>> >>> -----Original Message----- From: Werner Schneider >>> Sent: Tuesday, March 26, 2013 5:41 AM >>> To: aeroelectric-list(at)matronics.com >>> >>> Subject: Re: AeroElectric-List: Blind riveting ground to >>> airframe? >>> >>> >>> >>> Ray checkout >>> http://www.microfasteners.com/catalog/products/SSC.cfm >>> >>> I replaced nearly all of my Phillips with the 6 lobe screws >>> >>> Cheers Werner >>> >>> On 25.03.2013 22:21, rayj wrote: >>> >>> Agreed. I was looking for some "blessed" #10 hex head bolts >>> because I >>> prefer a hex head over slotted or phillips screw heads. >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> * * >>> >>> * * >>> >>> * * >>> >>> * * >>> * * >>> ** >>> ** >>> ** >>> ** >>> ** >>> ** >>> ** >>> *http://www.matronics.com/Navigator?AeroElectric-List <3D%22http:/www.matronics.com/Navigator?AeroElectric-List>* >>> ** >>> ** >>> ** >>> ** >>> ** >>> *http://forums.matronics.com <3D%22http:/forums.matronics.com>* >>> ** >>> ** >>> ** >>> ** >>> ** >>> *http://www.matronics.com/contribution <3D%22http:/www.matronics.com/contribution>* >>> ** >>> * * >>> * >>> >>> >>> * >> * >> >> href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List >> href="http://forums.matronics.com">http://forums.matronics.com >> href="http://www.matronics.com/contribution">http://www.matronics.com/c >> * >> * >> >> >> * > * > > > * ________________________________________________________________________________
Date: Mar 29, 2013
Will any old primer do or are there products that work better than others on certain materials (I'm thinking Al and Stainless in particular since my Cro moly frame is already primed. On Mar 29, 2013, at 10:19, Peter Pengilly wrote: > Ed, > > Drifting somewhat from the theme of this list, but to say that alclad does n't need priming is a bold statement. In Texas maybe, but in a cool maritime climate it isn't really adequate protection against the dreaded metal w orm in the long term. > > For grounding studs I have seen bright zinc plated bolts used with the pri mer removed from the structure they were inserted into. To make it clear wha t they are the paint finish was restored with a contrasting colour (blue in t his case I'm thinking of against puke yellow primer), but leaving the nut ho lding the stud in unpainted for good electrical connection. > > Peter > > On 29/03/2013 02:57, Ed Holyoke wrote: >> With primer barriers, particularly on the aluminum. Most sheet stock in u se on kitplanes is alclad and doesn't generally need primer. All extruded an gle and bar stock is not clad and needs to be primed to prevent corrosion. M any folks prime all faying surfaces (where two pieces fit together) and it s hould certainly be done at dissimilar metal joints. >> >> Ed Holyoke >> >> On 3/27/2013 11:16 PM, B Tomm wrote: >>> >>> How does the the stainless firewall riveted with aluminum rivets to alum inum sheet and angle stock play nice together? >>> >>> Bevan >>> >>> From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroele ctric-list-server(at)matronics.com] On Behalf Of Ed Holyoke >>> Sent: Tuesday, March 26, 2013 9:35 PM >>> To: aeroelectric-list(at)matronics.com >>> Subject: Re: AeroElectric-List: Blind riveting ground to airframe? >>> >>> Stainless and aluminum don't play nice together. The aluminum will donat e ions and corrode. Cad plated steel is the AN way. The cadmium is more anod ic than the aluminum and acts as a sacrificial barrier. Eventually, it has n o more ions to donate and loses it's value as a corrosion preventative. Time then for new hardware. Another approach would be to prime your hardware and install it wet. >>> >>> Ed Holyoke >>> >>> On 3/26/2013 7:25 AM, Jay Hyde wrote: >>>> >>>> Hello Sacha, >>>> I have the same problem in South Africa. For non structural parts I si mply use Metric sized bolts and nuts; usually stainless steel ones to protec t against corrosion. Stainless steel and aluminium have relatively close ga lvanic potentials as far as I can see. I have given up trying to source, or even understand (!) the imperial nut and bolt thread system; its far easier to walk into a bolt store and ask for M6 x 25mm bolts and M6 nuts. J >>>> For structural parts you must however use AN fasteners and they are not too difficult to understand (unless you need to order a tap or die=81c) ; I order them directly from Aircraft Spruce in the US. >>>> Johannesburg Jay >>>> From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroel ectric-list-server(at)matronics.com] On Behalf Of Sacha >>>> Sent: 26 March 2013 03:58 PM >>>> To: aeroelectric-list(at)matronics.com >>>> Subject: Re: AeroElectric-List: Blind riveting ground to airframe? >>>> Does anyone know what the METRIC equivalent of an AN fastener is and wh ere I can buy some? I'm in Italy, so preferably somewhere in Europe, though I'm willing to order from the US if necessary. I've been going nuts (no pun intended) trying to look for some but can only find a few manufacturers, no thing for the retail buyer. >>>> >>>> On Mar 26, 2013, at 13:42, rayj wrote: >>>> >>>> Looks like a great source for fasteners. I wanted to be sure the ones I chose were to an specs. I ended up ordering a big assortment of small AN sc rews. If I could have gotten an stuff with 6 lobe recess, I would have pref ered it. Definitely preferable to Phillips. >>>> >>>> Raymond Julian >>>> Kettle River, MN. >>>> >>>> "And you know that I could have me a million more friends, >>>> and all I'd have to lose is my point of view." - John Prine >>>> On 03/26/2013 07:20 AM, William Schertz wrote: mcast.net> >>>> >>>> Also note that they carry 100 degree flat head with Torx drive, much ni cer for avoiding stripouts like phillips >>>> Bill Schertz >>>> >>>> -----Original Message----- From: Werner Schneider >>>> Sent: Tuesday, March 26, 2013 5:41 AM >>>> To: aeroelectric-list(at)matronics.com >>>> Subject: Re: AeroElectric-List: Blind riveting ground to airframe? >>>> net> >>>> >>>> Ray checkout http://www.microfasteners.com/catalog/products/SSC.cfm >>>> >>>> I replaced nearly all of my Phillips with the 6 lobe screws >>>> >>>> Cheers Werner >>>> >>>> On 25.03.2013 22:21, rayj wrote: >>>> >>>> Agreed. I was looking for some "blessed" #10 hex head bolts because I >>>> prefer a hex head over slotted or phillips screw heads. >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> http://www.matronics.com/Navigator?AeroElectric-List >>>> http://forums.matronics.com >>>> http://www.matronics.com/contribution >>> >>> >>> href="http://www.matronics.com/Navigator?AeroElectric-List">http://www .matronics.com/Navigator?AeroElectric-List >>> href="http://forums.matronics.com">http://forums.matronics.com >>> href="http://www.matronics.com/contribution">http://www.matronics.com/ c > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Mar 29, 2013
Good Morning Ed, Care to comment as to how well Anodizing works? I Anodize all small parts before painting. Happy Skies, Old Bob In a message dated 3/28/2013 10:00:08 P.M. Central Daylight Time, bicyclop(at)pacbell.net writes: With primer barriers, particularly on the aluminum. Most sheet stock in use on kitplanes is alclad and doesn't generally need primer. All extruded angle and bar stock is not clad and needs to be primed to prevent corrosio n. Many folks prime all faying surfaces (where two pieces fit together) and i t should certainly be done at dissimilar metal joints. Ed Holyoke On 3/27/2013 11:16 PM, B Tomm wrote: How does the the stainless firewall riveted with aluminum rivets to aluminum sheet and angle stock play nice together? Bevan ____________________________________ From: _owner-aeroelectric-list-server(at)matronics.com_ (mailto:owner-aeroelectric-list-server(at)matronics.com) [_mailto:owner-aeroelectric-list-server(at)matronics.com_ (mailto:owner-aeroel ectric-list-server(at)matronics.com) ] On Behalf Of Ed Holyoke Sent: Tuesday, March 26, 2013 9:35 PM (mailto:aeroelectric-list(at)matronics.com) Subject: Re: AeroElectric-List: Blind riveting ground to airframe? Stainless and aluminum don't play nice together. The aluminum will donate ions and corrode. Cad plated steel is the AN way. The cadmium is more anodic than the aluminum and acts as a sacrificial barrier. Eventually, it has no more ions to donate and loses it's value as a corrosion preventative. Time then for new hardware. Another approach would be to prime your hardwa re and install it wet. Ed Holyoke On 3/26/2013 7:25 AM, Jay Hyde wrote: Hello Sacha, I have the same problem in South Africa. For non structural parts I simply use Metric sized bolts and nuts; usually stainless steel ones to pr otect against corrosion. Stainless steel and aluminium have relatively close galvanic potentials as far as I can see. I have given up trying to source , or even understand (!) the imperial nut and bolt thread system; its far easier to walk into a bolt store and ask for M6 x 25mm bolts and M6 nuts. J For structural parts you must however use AN fasteners and they are not too difficult to understand (unless you need to order a tap or die ) ; I order them directly from Aircraft Spruce in the US. Johannesburg Jay From: _owner-aeroelectric-list-server(at)matronics.com_ (mailto:owner-aeroelectric-list-server(at)matronics.com) [_mailto:owner-aeroelectric-list-server(at)matronics.com_ (mailto:owner-aeroel ectric-list-server(at)matronics.com) ] On Behalf Of Sacha Sent: 26 March 2013 03:58 PM (mailto:aeroelectric-list(at)matronics.com) Subject: Re: AeroElectric-List: Blind riveting ground to airframe? Does anyone know what the METRIC equivalent of an AN fastener is and where I can buy some? I'm in Italy, so preferably somewhere in Europe, though I'm willing to order from the US if necessary. I've been going nuts (no pu n intended) trying to look for some but can only find a few manufacturers, nothing for the retail buyer. On Mar 26, 2013, at 13:42, rayj <_raymondj(at)frontiernet.net_ (mailto:raymondj(at)frontiernet.net) > wrote: Looks like a great source for fasteners. I wanted to be sure the ones I chose were to an specs. I ended up ordering a big assortment of small AN screws. If I could have gotten an stuff with 6 lobe recess, I would have prefered it. Definitely preferable to Phillips. Raymond Julian Kettle River, MN. "And you know that I could have me a million more friends, and all I'd have to lose is my point of view." - John Prine On 03/26/2013 07:20 AM, William Schertz wrote: --> AeroElectric-List message posted by: "William Schertz" __ (mailto:wschertz(at)comcast.net) Also note that they carry 100 degree flat head with Torx drive, much nicer for avoiding stripouts like phillips Bill Schertz -----Original Message----- From: Werner Schneider Sent: Tuesday, March 26, 2013 5:41 AM (mailto:aeroelectric-list(at)matronics.com) Subject: Re: AeroElectric-List: Blind riveting ground to airframe? __ (mailto:glastar(at)gmx.net) Ray checkout _http://www.microfasteners.com/catalog/products/SSC.cfm_ (http://www.microfasteners.com/catalog/products/SSC.cfm) I replaced nearly all of my Phillips with the 6 lobe screws Cheers Werner On 25.03.2013 22:21, rayj wrote: Agreed. I was looking for some "blessed" #10 hex head bolts because I prefer a hex head over slotted or phillips screw heads. _http://www.matronics.com/Navigator?AeroElectric-List_ (mip://09277f20/3D"http:/www.matronics.com/Navigator?AeroElectric-List) _http://forums.matronics.com_ (mip://09277f20/3D"http:/forums.matronics.com) _http://www.matronics.com/contribution_ (mip://09277f20/3D"http:/www.matronics.com/contribution) href=_"http://www.matronics.com/Navigator?AeroElectric-List"_ (http://www.matronics.com/Navigator?AeroElectric-List) >_http://www.matronics.com/Navigator?AeroElectric-List_ (http://www.matronics.com/Navigator?AeroElectric-List) href=_"http://forums.matronics.com"_ (http://forums.matronics.com/) >_http://forums.matronics.com_ (http://forums.matronics.com/) href=_"http://www.matronics.com/contribution"_ (http://www.matronics.com/contribution) >_http://www.matronics.com/c_ (http ://www.matronics.com/c) (http://www.matronics.com/Navigator?AeroElectric-List) (http://www.matronics.com/contribution) ________________________________________________________________________________
Date: Mar 29, 2013
Good morning Bob, I think you are referring to using the chemical chromate Alodine process. Anodizing I believe requires equipment that most of us don't have. From Wikipedia "*Anodizing* (also spelled 'Anodising', particularly in the UK) is an electrolytic <http://en.wikipedia.org/wiki/Electrolyte> passivation <http://en.wikipedia.org/wiki/Passivation_%28chemistry%29> process used to increase the thickness of the natural oxide <http://en.wikipedia.org/wiki/Oxide> layer on the surface of metal parts. The process is called "anodizing" because the part to be treated forms the anode <http://en.wikipedia.org/wiki/Anode> electrode of an electrical circuit <http://en.wikipedia.org/wiki/Electrical_circuit>. " Kelly On 3/29/2013 6:18 AM, BobsV35B(at)aol.com wrote: > Good Morning Ed, > Care to comment as to how well Anodizing works? > I Anodize all small parts before painting. > Happy Skies, > Old Bob > In a message dated 3/28/2013 10:00:08 P.M. Central Daylight Time, > bicyclop(at)pacbell.net writes: > > With primer barriers, particularly on the aluminum. Most sheet > stock in use on kitplanes is alclad and doesn't generally need > primer. All extruded angle and bar stock is not clad and needs to > be primed to prevent corrosion. Many folks prime all faying > surfaces (where two pieces fit together) and it should certainly > be done at dissimilar metal joints. > > Ed Holyoke > > On 3/27/2013 11:16 PM, B Tomm wrote: >> How does the the stainless firewall riveted with aluminum rivets >> to aluminum sheet and angle stock play nice together? >> Bevan >> >> ------------------------------------------------------------------------ >> *From:* owner-aeroelectric-list-server(at)matronics.com >> [mailto:owner-aeroelectric-list-server(at)matronics.com] *On Behalf >> Of *Ed Holyoke >> *Sent:* Tuesday, March 26, 2013 9:35 PM >> *To:* aeroelectric-list(at)matronics.com >> *Subject:* Re: AeroElectric-List: Blind riveting ground to airframe? >> >> Stainless and aluminum don't play nice together. The aluminum >> will donate ions and corrode. Cad plated steel is the AN way. The >> cadmium is more anodic than the aluminum and acts as a >> sacrificial barrier. Eventually, it has no more ions to donate >> and loses it's value as a corrosion preventative. Time then for >> new hardware. Another approach would be to prime your hardware >> and install it wet. >> >> Ed Holyoke >> >> On 3/26/2013 7:25 AM, Jay Hyde wrote: >>> >>> Hello Sacha, >>> >>> I have the same problem in South Africa. For non structural >>> parts I simply use Metric sized bolts and nuts; usually >>> stainless steel ones to protect against corrosion. Stainless >>> steel and aluminium have relatively close galvanic potentials as >>> far as I can see. I have given up trying to source, or even >>> understand (!) the imperial nut and bolt thread system; its far >>> easier to walk into a bolt store and ask for M6 x 25mm bolts and >>> M6 nuts. J >>> >>> For structural parts you must however use AN fasteners and they >>> are not too difficult to understand (unless you need to order a >>> tap or die) ; I order them directly from Aircraft Spruce in the US. >>> >>> Johannesburg Jay >>> >>> *From:*owner-aeroelectric-list-server(at)matronics.com >>> [mailto:owner-aeroelectric-list-server(at)matronics.com] *On Behalf >>> Of *Sacha >>> *Sent:* 26 March 2013 03:58 PM >>> *To:* aeroelectric-list(at)matronics.com >>> *Subject:* Re: AeroElectric-List: Blind riveting ground to airframe? >>> >>> Does anyone know what the METRIC equivalent of an AN fastener is >>> and where I can buy some? I'm in Italy, so preferably somewhere >>> in Europe, though I'm willing to order from the US if necessary. >>> I've been going nuts (no pun intended) trying to look for some >>> but can only find a few manufacturers, nothing for the retail >>> buyer. >>> >>> >>> On Mar 26, 2013, at 13:42, rayj >> > wrote: >>> >>> Looks like a great source for fasteners. I wanted to be >>> sure the ones I chose were to an specs. I ended up ordering >>> a big assortment of small AN screws. If I could have gotten >>> an stuff with 6 lobe recess, I would have prefered it. >>> Definitely preferable to Phillips. >>> >>> Raymond Julian >>> >>> Kettle River, MN. >>> >>> >>> >>> "And you know that I could have me a million more friends, >>> >>> and all I'd have to lose is my point of view." - John Prine >>> >>> On 03/26/2013 07:20 AM, William Schertz wrote: >>> >>> Schertz" >>> >>> >>> Also note that they carry 100 degree flat head with Torx >>> drive, much nicer for avoiding stripouts like phillips >>> Bill Schertz >>> >>> -----Original Message----- From: Werner Schneider >>> Sent: Tuesday, March 26, 2013 5:41 AM >>> To: aeroelectric-list(at)matronics.com >>> >>> Subject: Re: AeroElectric-List: Blind riveting ground to >>> airframe? >>> >>> Schneider >>> >>> Ray checkout >>> http://www.microfasteners.com/catalog/products/SSC.cfm >>> >>> I replaced nearly all of my Phillips with the 6 lobe screws >>> >>> Cheers Werner >>> >>> On 25.03.2013 22:21, rayj wrote: >>> >>> Agreed. I was looking for some "blessed" #10 hex head >>> bolts because I >>> prefer a hex head over slotted or phillips screw heads. >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> * * >>> >>> * * >>> >>> * * >>> >>> * * >>> * * >>> ** >>> ** >>> ** >>> ** >>> ** >>> ** >>> ** >>> *http://www.matronics.com/Navigator?AeroElectric-List * >>> ** >>> ** >>> ** >>> ** >>> ** >>> *http://forums.matronics.com * >>> ** >>> ** >>> ** >>> ** >>> ** >>> *http://www.matronics.com/contribution * >>> ** >>> * * >>> * >>> >>> >>> * >> * >> >> href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List >> href="http://forums.matronics.com">http://forums.matronics.com >> href="http://www.matronics.com/contribution">http://www.matronics.com/c >> * >> * >> >> >> * > > * > > ist href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List > s.matronics.com/">http://forums.matronics.com > p://www.matronics.com/contribution">http://www.matronics.com/contribution > > * > > * > > > * ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Mar 29, 2013
The concerns for forestalling environmental effects on assembled parts and attach hardware are quite germane to our mission for doing the best we know how to do . . . so don't feel that this topic has run off into the weeds. At the same time, recall that making good electrical connection between a wire and some surface of the airframe is dependent on that ring of terminal material around the hole and the surface to which it comes in contact. Having the equivalent of hermetic or gas- tight contact in this critical area is where the magic happens for getting your electrons from point A to point B over the lifetime of the airplane. Gas tightness is a function of FORCE used to mate up and maintain the terminal's intimate contact with the airframe. The proper force may be secured with a variety of materials . . . materials that have to live with their surroundings too. But you can enjoy excellent electrical performance even if the screw is crusted with rust . . . as long as that 'magic donut' of contact is still good. Where the messiness of silicone grease migration can be tolerated, doping the mating surfaces of terminal and airplane with Dow Corning DC4 or equal goes to filling any voids in the final mate-up to the exclusion of moisture. These are separate but related issues, each with their own recipes for success. Bob . . . ________________________________________________________________________________
Date: Mar 29, 2013
Subject: (no subject)
Bob, You've "got plans to use about 100 feet of these strips in an overhaul of room and counter lighting in (your) kitchen." How about sharing the plans? How does the brightness compare to the thin tube 5 to 10 watt fluorescents and starters that I constantly have to replace? ________________________________________________________________________________
Date: Mar 29, 2013
Subject: Re: (no subject)
At 12:24 PM 3/29/2013, you wrote: >Bob, > >You've "got plans to > use about 100 feet of these strips in an overhaul > of room and counter lighting in (your) kitchen." > >How about sharing the plans? How does the brightness compare to the >thin tube 5 to 10 watt fluorescents and starters that I constantly >have to replace? I've already stuck a couple of strips on the underside of one cabinet to replace a single 12W tube lamp. Illumination is very nice. Light is nearly 'flat' i.e. shadow free. 40+ years ago, Dad put canister lamps for general lighting over the counters and an array of flourescent tubes for work lights. One strip of lamps is not enough but two side-by-side seem adequate. Sticking these strips up on the bottom of cabinets in straight lines and then wiring them up is problematic. I'm building twin-row strip lamps on pieces of Formica about 1.5" wide. Complete assemblies of pre-wired lamps on thin, rigid substrates will make installation MUCH easier. There are decorative features in the woodwork that minimizes direct visibility of the leds. I'm planning to replace the canister lamps with a similar process. There will be another array of accent lights to illuminate the ceiling over the cabinets. Hence, a whole bunch of LEDs! Bob . . . ________________________________________________________________________________
Date: Mar 29, 2013
Bob, When I worked for Hawkers (that's the real Hawkers of Hurricane, Sea Fury, Hunter and Harrier fame) we anodized every aluminium part that wasn't clad, and then epoxy primed the lot with a 2 pack chromate primer. There is a very slight loss of ductility in the surface layers with anodizing, but most manufacturers take the view that that is a small price to pay for the long term prevention of corrosion. To answer an earlier question, for AB aircraft (that typically lead a fairly cosseted life) I think that any corrosion preventing primer will be much better than none at all - but I really am not looking to start primer wars here! Peter On 29/03/2013 13:18, BobsV35B(at)aol.com wrote: > Good Morning Ed, > Care to comment as to how well Anodizing works? > I Anodize all small parts before painting. > Happy Skies, > Old Bob > In a message dated 3/28/2013 10:00:08 P.M. Central Daylight Time, > bicyclop(at)pacbell.net writes: > > With primer barriers, particularly on the aluminum. Most sheet > stock in use on kitplanes is alclad and doesn't generally need > primer. All extruded angle and bar stock is not clad and needs to > be primed to prevent corrosion. Many folks prime all faying > surfaces (where two pieces fit together) and it should certainly > be done at dissimilar metal joints. > > Ed Holyoke > > On 3/27/2013 11:16 PM, B Tomm wrote: >> How does the the stainless firewall riveted with aluminum rivets >> to aluminum sheet and angle stock play nice together? >> Bevan >> >> ------------------------------------------------------------------------ >> *From:* owner-aeroelectric-list-server(at)matronics.com >> [mailto:owner-aeroelectric-list-server(at)matronics.com] *On Behalf >> Of *Ed Holyoke >> *Sent:* Tuesday, March 26, 2013 9:35 PM >> *To:* aeroelectric-list(at)matronics.com >> *Subject:* Re: AeroElectric-List: Blind riveting ground to airframe? >> >> Stainless and aluminum don't play nice together. The aluminum >> will donate ions and corrode. Cad plated steel is the AN way. The >> cadmium is more anodic than the aluminum and acts as a >> sacrificial barrier. Eventually, it has no more ions to donate >> and loses it's value as a corrosion preventative. Time then for >> new hardware. Another approach would be to prime your hardware >> and install it wet. >> >> Ed Holyoke >> >> On 3/26/2013 7:25 AM, Jay Hyde wrote: >>> >>> Hello Sacha, >>> >>> I have the same problem in South Africa. For non structural >>> parts I simply use Metric sized bolts and nuts; usually >>> stainless steel ones to protect against corrosion. Stainless >>> steel and aluminium have relatively close galvanic potentials as >>> far as I can see. I have given up trying to source, or even >>> understand (!) the imperial nut and bolt thread system; its far >>> easier to walk into a bolt store and ask for M6 x 25mm bolts and >>> M6 nuts. J >>> >>> For structural parts you must however use AN fasteners and they >>> are not too difficult to understand (unless you need to order a >>> tap or die) ; I order them directly from Aircraft Spruce in the US. >>> >>> Johannesburg Jay >>> >>> *From:*owner-aeroelectric-list-server(at)matronics.com >>> [mailto:owner-aeroelectric-list-server(at)matronics.com] *On Behalf >>> Of *Sacha >>> *Sent:* 26 March 2013 03:58 PM >>> *To:* aeroelectric-list(at)matronics.com >>> *Subject:* Re: AeroElectric-List: Blind riveting ground to airframe? >>> >>> Does anyone know what the METRIC equivalent of an AN fastener is >>> and where I can buy some? I'm in Italy, so preferably somewhere >>> in Europe, though I'm willing to order from the US if necessary. >>> I've been going nuts (no pun intended) trying to look for some >>> but can only find a few manufacturers, nothing for the retail >>> buyer. >>> >>> >>> On Mar 26, 2013, at 13:42, rayj >> > wrote: >>> >>> Looks like a great source for fasteners. I wanted to be >>> sure the ones I chose were to an specs. I ended up ordering >>> a big assortment of small AN screws. If I could have gotten >>> an stuff with 6 lobe recess, I would have prefered it. >>> Definitely preferable to Phillips. >>> >>> Raymond Julian >>> >>> Kettle River, MN. >>> >>> >>> >>> "And you know that I could have me a million more friends, >>> >>> and all I'd have to lose is my point of view." - John Prine >>> >>> On 03/26/2013 07:20 AM, William Schertz wrote: >>> >>> Schertz" >>> >>> >>> Also note that they carry 100 degree flat head with Torx >>> drive, much nicer for avoiding stripouts like phillips >>> Bill Schertz >>> >>> -----Original Message----- From: Werner Schneider >>> Sent: Tuesday, March 26, 2013 5:41 AM >>> To: aeroelectric-list(at)matronics.com >>> >>> Subject: Re: AeroElectric-List: Blind riveting ground to >>> airframe? >>> >>> Schneider >>> >>> Ray checkout >>> http://www.microfasteners.com/catalog/products/SSC.cfm >>> >>> I replaced nearly all of my Phillips with the 6 lobe screws >>> >>> Cheers Werner >>> >>> On 25.03.2013 22:21, rayj wrote: >>> >>> Agreed. I was looking for some "blessed" #10 hex head >>> bolts because I >>> prefer a hex head over slotted or phillips screw heads. >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> * * >>> >>> * * >>> >>> * * >>> >>> * * >>> * * >>> ** >>> ** >>> ** >>> ** >>> ** >>> ** >>> ** >>> *http://www.matronics.com/Navigator?AeroElectric-List * >>> ** >>> ** >>> ** >>> ** >>> ** >>> *http://forums.matronics.com * >>> ** >>> ** >>> ** >>> ** >>> ** >>> *http://www.matronics.com/contribution * >>> ** >>> * * >>> * >>> >>> >>> * >> * >> >> href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List >> href="http://forums.matronics.com">http://forums.matronics.com >> href="http://www.matronics.com/contribution">http://www.matronics.com/c >> * >> * >> >> >> * > > * > > ist href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List > s.matronics.com/">http://forums.matronics.com > p://www.matronics.com/contribution">http://www.matronics.com/contribution > > * > > * > > > * ________________________________________________________________________________
Date: Mar 29, 2013
Good Afternoon Kelly, As Usual you are correct. My lack of education is showing again. Thanks for the correction. Happy Skies, Old Bob In a message dated 3/29/2013 9:40:19 A.M. Central Daylight Time, kellym(at)aviating.com writes: --> AeroElectric-List message posted by: Kelly McMullen Good morning Bob, I think you are referring to using the chemical chromate Alodine process. Anodizing I believe requires equipment that most of us don't have . >From Wikipedia "*Anodizing* (also spelled 'Anodising', particularly in the UK) is an electrolytic <http://en.wikipedia.org/wiki/Electrolyte> passivation <http://en.wikipedia.org/wiki/Passivation_%28chemistry%29> process used to increase the thickness of the natural oxide <http://en.wikipedia.org/wiki/Oxide> layer on the surface of metal parts. The process is called "anodizing" because the part to be treated forms the anode <http://en.wikipedia.org/wiki/Anode> electrode of an electrical circuit <http://en.wikipedia.org/wiki/Electrical_circuit>. " Kelly On 3/29/2013 6:18 AM, BobsV35B(at)aol.com wrote: > Good Morning Ed, > Care to comment as to how well Anodizing works? > I Anodize all small parts before painting. > Happy Skies, > Old Bob > In a message dated 3/28/2013 10:00:08 P.M. Central Daylight Time, > bicyclop(at)pacbell.net writes: > > With primer barriers, particularly on the aluminum. Most sheet > stock in use on kitplanes is alclad and doesn't generally need > primer. All extruded angle and bar stock is not clad and needs to > be primed to prevent corrosion. Many folks prime all faying > surfaces (where two pieces fit together) and it should certainly > be done at dissimilar metal joints. > > Ed Holyoke > > On 3/27/2013 11:16 PM, B Tomm wrote: >> How does the the stainless firewall riveted with aluminum rivets >> to aluminum sheet and angle stock play nice together? >> Bevan >> >> ------------------------------------------------------------------------ >> *From:* owner-aeroelectric-list-server(at)matronics.com >> [mailto:owner-aeroelectric-list-server(at)matronics.com] *On Behalf >> Of *Ed Holyoke >> *Sent:* Tuesday, March 26, 2013 9:35 PM >> *To:* aeroelectric-list(at)matronics.com >> *Subject:* Re: AeroElectric-List: Blind riveting ground to airframe? >> >> Stainless and aluminum don't play nice together. The aluminum >> will donate ions and corrode. Cad plated steel is the AN way. The >> cadmium is more anodic than the aluminum and acts as a >> sacrificial barrier. Eventually, it has no more ions to donate >> and loses it's value as a corrosion preventative. Time then for >> new hardware. Another approach would be to prime your hardware >> and install it wet. >> >> Ed Holyoke >> >> On 3/26/2013 7:25 AM, Jay Hyde wrote: >>> >>> Hello Sacha, >>> >>> I have the same problem in South Africa. For non structural >>> parts I simply use Metric sized bolts and nuts; usually >>> stainless steel ones to protect against corrosion. Stainless >>> steel and aluminium have relatively close galvanic potentials as >>> far as I can see. I have given up trying to source, or even >>> understand (!) the imperial nut and bolt thread system; its far >>> easier to walk into a bolt store and ask for M6 x 25mm bolts and >>> M6 nuts. J >>> >>> For structural parts you must however use AN fasteners and they >>> are not too difficult to understand (unless you need to order a >>> tap or die) ; I order them directly from Aircraft Spruce in the US. >>> >>> Johannesburg Jay >>> >>> *From:*owner-aeroelectric-list-server(at)matronics.com >>> [mailto:owner-aeroelectric-list-server(at)matronics.com] *On Behalf >>> Of *Sacha >>> *Sent:* 26 March 2013 03:58 PM >>> *To:* aeroelectric-list(at)matronics.com >>> *Subject:* Re: AeroElectric-List: Blind riveting ground to airframe? >>> >>> Does anyone know what the METRIC equivalent of an AN fastener is >>> and where I can buy some? I'm in Italy, so preferably somewhere >>> in Europe, though I'm willing to order from the US if necessary. >>> I've been going nuts (no pun intended) trying to look for some >>> but can only find a few manufacturers, nothing for the retail >>> buyer. >>> >>> >>> On Mar 26, 2013, at 13:42, rayj >> > wrote: >>> >>> Looks like a great source for fasteners. I wanted to be >>> sure the ones I chose were to an specs. I ended up ordering >>> a big assortment of small AN screws. If I could have gotten >>> an stuff with 6 lobe recess, I would have prefered it. >>> Definitely preferable to Phillips. >>> >>> Raymond Julian >>> >>> Kettle River, MN. >>> >>> >>> >>> "And you know that I could have me a million more friends, >>> >>> and all I'd have to lose is my point of view." - John Prine >>> >>> On 03/26/2013 07:20 AM, William Schertz wrote: >>> >>> Schertz" >>> >>> >>> Also note that they carry 100 degree flat head with Torx >>> drive, much nicer for avoiding stripouts like phillips >>> Bill Schertz >>> >>> -----Original Message----- From: Werner Schneider >>> Sent: Tuesday, March 26, 2013 5:41 AM >>> To: aeroelectric-list(at)matronics.com >>> >>> Subject: Re: AeroElectric-List: Blind riveting ground to >>> airframe? >>> >>> Schneider >>> >>> Ray checkout >>> http://www.microfasteners.com/catalog/products/SSC.cfm >>> >>> I replaced nearly all of my Phillips with the 6 lobe screws >>> >>> Cheers Werner >>> >>> On 25.03.2013 22:21, rayj wrote: >>> >>> Agreed. I was looking for some "blessed" #10 hex head >>> bolts because I >>> prefer a hex head over slotted or phillips screw heads. >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> * * >>> >>> * * >>> >>> * * >>> >>> * * >>> * * >>> ** >>> ** >>> ** >>> ** >>> ** >>> ** >>> ** >>> *http://www.matronics.com/Navigator?AeroElectric-List * >>> ** >>> ** >>> ** >>> ** >>> ** >>> *http://forums.matronics.com * >>> ** >>> ** >>> ** >>> ** >>> ** >>> *http://www.matronics.com/contribution * >>> ** >>> * * >>> * >>> >>> >>> * >> * >> >> href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.ma tronics.com/Navigator?AeroElectric-List >> href="http://forums.matronics.com">http://forums.matronics.com >> href="http://www.matronics.com/contribution">http://www.matronics.com/c >> * >> * >> >> >> * > > * > > ist href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.ma tronics.com/Navigator?AeroElectric-List > s.matronics.com/">http://forums.matronics.com > p://www.matronics.com/contribution">http://www.matronics.com/contribution > > * > > * > > > * ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Subject: Can Antenna problems damage a com transmitter?
Date: Mar 31, 2013
I intend to do some experimenting with homemade com antennas connected to my IC-A200. Is there a danger of damaging the transmitter if the antenna is either open or short circuited or otherwise unsuitable? Thanks, Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=397423#397423 ________________________________________________________________________________
Subject: Re: Can Antenna problems damage a com transmitter?
Date: Mar 31, 2013
Hi Joe, yes there is the possibility of damage if not built correctly. I assume you are building a 1/2 wave dipole or 1/4 wave vertical according to some published plans and if so, and the elements are cut to the correct length and it should be ok. Just make sure you have continuity at the radio connector, from the coax connector center conductor to the individual correct element and from the connector shield out the the other element. Also ensure you have NO conductivity between the elements. Then try the receiver, then the transmitter. The SWR of the antenna can also be influenced by proximity to other stuff, like you or your airplane. To be safe, buy yourself a SWR meter or borrow one. Then you will know you are presenting a suitable impedance to the radio. Good luck Tim Sent from my iPad On Mar 31, 2013, at 9:28 AM, "user9253" wrote: > > I intend to do some experimenting with homemade com antennas connected to my IC-A200. > Is there a danger of damaging the transmitter if the antenna is either open or short circuited or otherwise unsuitable? > Thanks, > Joe > > -------- > Joe Gores > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=397423#397423 > > > > > > > > > > ________________________________________________________________________________
Date: Mar 31, 2013
At 11:28 AM 3/31/2013, you wrote: > >I intend to do some experimenting with homemade com antennas >connected to my IC-A200. >Is there a danger of damaging the transmitter if the antenna is >either open or short circuited or otherwise unsuitable? >Thanks, >Joe The very first solid state VHF transmitter I crossed paths with was indeed vulnerable to high SWR loading. But that was 1968 and the transistors were germanium PNP devices. A lot of improvements have been made over the years not only in the efficiency of transistors suited to the task but in their relative ruggedness as well. Nowadays, it is so easy to build a reflectometer right into a transceiver. The reflected power function is used to reduce drive to the transmitter's final amplifiers such that the transceiver is self protecting in extreme SWR situations (shorted or open coax). When using your transceiver for exploratory measurements, look at SWR first and excited the test setup for only long enough to see that your SWR readings are not really out of whack. The IC-A200 manual allows normal operations at SWR as high as 3:1 but is silent as to any cautions for still higher numbers. Open and shorted coaxes are part and parcel of living in the real world. Your transceiver is not at risk for the short duration measurements you're needing to accomplish. When ever we needed to make extended tests on a transmission line/antenna combo with high SWR, we would stick a 6 db attenuator in the line (100 feet of RG-58 coax works good too. The losses through the attenuator/coax are so great that TERRIBLE swr at the far end has no great effect on the energy source. The attenuator would keep the transmitter's auto-power down circuit happy. Bob . . . ________________________________________________________________________________
Date: Apr 01, 2013
Thanks for the info, Bob. I will proceed with caution. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=397516#397516 ________________________________________________________________________________
From: "R. curtis" <mrspudandcompany(at)verizon.net>
Subject: Failed contactor
Date: Apr 01, 2013
Bob, Just checking to see if you got the junk contactor? Roger -- Do you have a slow PC? Try a Free scan http://www.spamfighter.com/SLOW-PCfighter?cid=sigen ________________________________________________________________________________
Subject: Dolphin Electrical Wire Connectors
Date: Apr 01, 2013
4/1/2013 Hello Bob Nuckolls, It has been suggested that I use these Dolphin DC-100- P or -S insulation piercing type electrical wire connectors for low amperage wire connection usage, such as a Ray Allen trim servo, in my experimental amateur built airplane: http://dolphincomponents.com/catalogs/Section%20A%20-%20Super%20B%20stand ard-3207.pdf What do you think? Thank you. Owen C. Baker PS: This is not intended as an April Fools Day joke. ________________________________________________________________________________
Date: Apr 01, 2013
Subject: Re: Blind riveting ground to airframe?
Howdy Peter, Right you are. Alclad isn't perfect, but for most of us it will be good enough. Here in California and hangared there really isn't a lot of concern about corrosion. This will not be true everywhere and in all conditions. That said, how many of our homebuilt airplanes will be flying in fifty years? For many of us the aircraft will likely outlive us whether or not we prime everything and if we spend so much time obsessing about the future life of the aircraft that it doesn't get finished until our medicals are no longer renewable..... Well, you get the picture. Gotta balance serviceability and utility with getting done in time to fly it. Another factor is of course weight. Priming everything could add say five pounds, maybe more. Doesn't seem like much but it tends to add up. Folks really like the deep shine of a base/clear coat paint job and those tend to be ten or more pounds heavier than single stage to color. Can't really see the difference from ten feet, let alone a thousand. Some of us pad the whole interior with leather and/or carpet. Looks great and reminds of of a luxury car but doesn't improve the way the airplane flies. The great thing about homebuilding is that you can choose what you want in a way that certificated aircraft will never do. Maybe you've got grandkids who will keep the airplane flying a long time and would appreciate having everything primed. If you want to load the panel with every possible goodie and don't care about the weight, hey - it's your airplane. I'm looking to keep it light while being maintainable. I doubt that the alclad skins will show any sign of corrosion in my lifetime and then there's always CorrosionX. Ed Holyoke On 3/29/2013 2:19 AM, Peter Pengilly wrote: > Ed, > > Drifting somewhat from the theme of this list, but to say that alclad > doesn't need priming is a bold statement. In Texas maybe, but in a > cool maritime climate it isn't really adequate protection against the > dreaded metal worm in the long term. > > For grounding studs I have seen bright zinc plated bolts used with the > primer removed from the structure they were inserted into. To make it > clear what they are the paint finish was restored with a contrasting > colour (blue in this case I'm thinking of against puke yellow primer), > but leaving the nut holding the stud in unpainted for good electrical > connection. > > Peter > > On 29/03/2013 02:57, Ed Holyoke wrote: >> With primer barriers, particularly on the aluminum. Most sheet stock >> in use on kitplanes is alclad and doesn't generally need primer. All >> extruded angle and bar stock is not clad and needs to be primed to >> prevent corrosion. Many folks prime all faying surfaces (where two >> pieces fit together) and it should certainly be done at dissimilar >> metal joints. >> >> Ed Holyoke >> >> On 3/27/2013 11:16 PM, B Tomm wrote: >>> How does the the stainless firewall riveted with aluminum rivets to >>> aluminum sheet and angle stock play nice together? >>> Bevan >>> >>> ------------------------------------------------------------------------ >>> *From:* owner-aeroelectric-list-server(at)matronics.com >>> [mailto:owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of >>> *Ed Holyoke >>> *Sent:* Tuesday, March 26, 2013 9:35 PM >>> *To:* aeroelectric-list(at)matronics.com >>> *Subject:* Re: AeroElectric-List: Blind riveting ground to airframe? >>> >>> Stainless and aluminum don't play nice together. The aluminum will >>> donate ions and corrode. Cad plated steel is the AN way. The cadmium >>> is more anodic than the aluminum and acts as a sacrificial barrier. >>> Eventually, it has no more ions to donate and loses it's value as a >>> corrosion preventative. Time then for new hardware. Another approach >>> would be to prime your hardware and install it wet. >>> >>> Ed Holyoke >>> >>> On 3/26/2013 7:25 AM, Jay Hyde wrote: >>>> >>>> Hello Sacha, >>>> >>>> I have the same problem in South Africa. For non structural parts >>>> I simply use Metric sized bolts and nuts; usually stainless steel >>>> ones to protect against corrosion. Stainless steel and aluminium >>>> have relatively close galvanic potentials as far as I can see. I >>>> have given up trying to source, or even understand (!) the imperial >>>> nut and bolt thread system; its far easier to walk into a bolt >>>> store and ask for M6 x 25mm bolts and M6 nuts. J >>>> >>>> For structural parts you must however use AN fasteners and they are >>>> not too difficult to understand (unless you need to order a tap or >>>> die...) ; I order them directly from Aircraft Spruce in the US. >>>> >>>> Johannesburg Jay >>>> >>>> *From:*owner-aeroelectric-list-server(at)matronics.com >>>> [mailto:owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of >>>> *Sacha >>>> *Sent:* 26 March 2013 03:58 PM >>>> *To:* aeroelectric-list(at)matronics.com >>>> *Subject:* Re: AeroElectric-List: Blind riveting ground to airframe? >>>> >>>> Does anyone know what the METRIC equivalent of an AN fastener is >>>> and where I can buy some? I'm in Italy, so preferably somewhere in >>>> Europe, though I'm willing to order from the US if necessary. I've >>>> been going nuts (no pun intended) trying to look for some but can >>>> only find a few manufacturers, nothing for the retail buyer. >>>> >>>> >>>> On Mar 26, 2013, at 13:42, rayj >>> > wrote: >>>> >>>> Looks like a great source for fasteners. I wanted to be sure >>>> the ones I chose were to an specs. I ended up ordering a big >>>> assortment of small AN screws. If I could have gotten an stuff >>>> with 6 lobe recess, I would have prefered it. Definitely >>>> preferable to Phillips. >>>> >>>> Raymond Julian >>>> >>>> Kettle River, MN. >>>> >>>> >>>> >>>> "And you know that I could have me a million more friends, >>>> >>>> and all I'd have to lose is my point of view." - John Prine >>>> >>>> On 03/26/2013 07:20 AM, William Schertz wrote: >>>> >>>> >>>> >>>> Also note that they carry 100 degree flat head with Torx >>>> drive, much nicer for avoiding stripouts like phillips >>>> Bill Schertz >>>> >>>> -----Original Message----- From: Werner Schneider >>>> Sent: Tuesday, March 26, 2013 5:41 AM >>>> To: aeroelectric-list(at)matronics.com >>>> >>>> Subject: Re: AeroElectric-List: Blind riveting ground to >>>> airframe? >>>> >>>> >>>> >>>> Ray checkout >>>> http://www.microfasteners.com/catalog/products/SSC.cfm >>>> >>>> I replaced nearly all of my Phillips with the 6 lobe screws >>>> >>>> Cheers Werner >>>> >>>> On 25.03.2013 22:21, rayj wrote: >>>> >>>> Agreed. I was looking for some "blessed" #10 hex head bolts >>>> because I >>>> prefer a hex head over slotted or phillips screw heads. >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> * * >>>> >>>> * * >>>> >>>> * * >>>> >>>> * * >>>> * * >>>> ** >>>> ** >>>> ** >>>> ** >>>> ** >>>> ** >>>> ** >>>> *http://www.matronics.com/Navigator?AeroElectric-List <3D%22http:/www.matronics.com/Navigator?AeroElectric-List>* >>>> ** >>>> ** >>>> ** >>>> ** >>>> ** >>>> *http://forums.matronics.com <3D%22http:/forums.matronics.com>* >>>> ** >>>> ** >>>> ** >>>> ** >>>> ** >>>> *http://www.matronics.com/contribution <3D%22http:/www.matronics.com/contribution>* >>>> ** >>>> * * >>>> * >>>> >>>> >>>> * >>> * >>> >>> href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List >>> href="http://forums.matronics.com">http://forums.matronics.com >>> href="http://www.matronics.com/contribution">http://www.matronics.com/c >>> * >>> * >>> >>> >>> * >> * >> >> >> * > > * > > > * ________________________________________________________________________________
Date: Apr 01, 2013
Epoxy primer is the gold standard. It's also sort of a pain to mix, spray, and clean up after. For long term between dissimilar metals, probably worth doing. For little parts when I don't want to go through all the trouble, I've been using self etching primer in the rattle can. Rustoleum brand is available at Lowe's and HD. It's dark green. Looks a bit like the old zinc chromate only it doesn't clog the nozzle up like that stuff always did. Ed Holyoke On 3/29/2013 6:18 AM, Sacha wrote: > Will any old primer do or are there products that work better than > others on certain materials (I'm thinking Al and Stainless in > particular since my Cromoly frame is already primed. > > On Mar 29, 2013, at 10:19, Peter Pengilly > wrote: > >> Ed, >> >> Drifting somewhat from the theme of this list, but to say that alclad >> doesn't need priming is a bold statement. In Texas maybe, but in a >> cool maritime climate it isn't really adequate protection against the >> dreaded metal worm in the long term. >> >> For grounding studs I have seen bright zinc plated bolts used with >> the primer removed from the structure they were inserted into. To >> make it clear what they are the paint finish was restored with a >> contrasting colour (blue in this case I'm thinking of against puke >> yellow primer), but leaving the nut holding the stud in unpainted for >> good electrical connection. >> >> Peter >> >> On 29/03/2013 02:57, Ed Holyoke wrote: >>> With primer barriers, particularly on the aluminum. Most sheet stock >>> in use on kitplanes is alclad and doesn't generally need primer. All >>> extruded angle and bar stock is not clad and needs to be primed to >>> prevent corrosion. Many folks prime all faying surfaces (where two >>> pieces fit together) and it should certainly be done at dissimilar >>> metal joints. >>> >>> Ed Holyoke >>> >>> On 3/27/2013 11:16 PM, B Tomm wrote: >>>> How does the the stainless firewall riveted with aluminum rivets to >>>> aluminum sheet and angle stock play nice together? >>>> Bevan >>>> >>>> ------------------------------------------------------------------------ >>>> *From:* owner-aeroelectric-list-server(at)matronics.com >>>> [mailto:owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of >>>> *Ed Holyoke >>>> *Sent:* Tuesday, March 26, 2013 9:35 PM >>>> *To:* aeroelectric-list(at)matronics.com >>>> *Subject:* Re: AeroElectric-List: Blind riveting ground to airframe? >>>> >>>> Stainless and aluminum don't play nice together. The aluminum will >>>> donate ions and corrode. Cad plated steel is the AN way. The >>>> cadmium is more anodic than the aluminum and acts as a sacrificial >>>> barrier. Eventually, it has no more ions to donate and loses it's >>>> value as a corrosion preventative. Time then for new hardware. >>>> Another approach would be to prime your hardware and install it wet. >>>> >>>> Ed Holyoke >>>> >>>> On 3/26/2013 7:25 AM, Jay Hyde wrote: >>>>> >>>>> Hello Sacha, >>>>> >>>>> I have the same problem in South Africa. For non structural parts >>>>> I simply use Metric sized bolts and nuts; usually stainless steel >>>>> ones to protect against corrosion. Stainless steel and aluminium >>>>> have relatively close galvanic potentials as far as I can see. I >>>>> have given up trying to source, or even understand (!) the >>>>> imperial nut and bolt thread system; its far easier to walk into a >>>>> bolt store and ask for M6 x 25mm bolts and M6 nuts. J >>>>> >>>>> For structural parts you must however use AN fasteners and they >>>>> are not too difficult to understand (unless you need to order a >>>>> tap or die) ; I order them directly from Aircraft Spruce in the US. >>>>> >>>>> Johannesburg Jay >>>>> >>>>> *From:*owner-aeroelectric-list-server(at)matronics.com >>>>> [mailto:owner-aeroelectric-list-server(at)matronics.com] *On Behalf >>>>> Of *Sacha >>>>> *Sent:* 26 March 2013 03:58 PM >>>>> *To:* aeroelectric-list(at)matronics.com >>>>> *Subject:* Re: AeroElectric-List: Blind riveting ground to airframe? >>>>> >>>>> Does anyone know what the METRIC equivalent of an AN fastener is >>>>> and where I can buy some? I'm in Italy, so preferably somewhere >>>>> in Europe, though I'm willing to order from the US if necessary. >>>>> I've been going nuts (no pun intended) trying to look for some but >>>>> can only find a few manufacturers, nothing for the retail buyer. >>>>> >>>>> >>>>> On Mar 26, 2013, at 13:42, rayj >>>> > wrote: >>>>> >>>>> Looks like a great source for fasteners. I wanted to be sure >>>>> the ones I chose were to an specs. I ended up ordering a big >>>>> assortment of small AN screws. If I could have gotten an >>>>> stuff with 6 lobe recess, I would have prefered it. >>>>> Definitely preferable to Phillips. >>>>> >>>>> Raymond Julian >>>>> >>>>> Kettle River, MN. >>>>> >>>>> >>>>> >>>>> "And you know that I could have me a million more friends, >>>>> >>>>> and all I'd have to lose is my point of view." - John Prine >>>>> >>>>> On 03/26/2013 07:20 AM, William Schertz wrote: >>>>> >>>>> >>>>> >>>>> Also note that they carry 100 degree flat head with Torx >>>>> drive, much nicer for avoiding stripouts like phillips >>>>> Bill Schertz >>>>> >>>>> -----Original Message----- From: Werner Schneider >>>>> Sent: Tuesday, March 26, 2013 5:41 AM >>>>> To: aeroelectric-list(at)matronics.com >>>>> >>>>> Subject: Re: AeroElectric-List: Blind riveting ground to >>>>> airframe? >>>>> >>>>> >>>>> >>>>> Ray checkout >>>>> http://www.microfasteners.com/catalog/products/SSC.cfm >>>>> >>>>> I replaced nearly all of my Phillips with the 6 lobe screws >>>>> >>>>> Cheers Werner >>>>> >>>>> On 25.03.2013 22:21, rayj wrote: >>>>> >>>>> Agreed. I was looking for some "blessed" #10 hex head >>>>> bolts because I >>>>> prefer a hex head over slotted or phillips screw heads. >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> * * >>>>> >>>>> * * >>>>> >>>>> * * >>>>> >>>>> * * >>>>> * * >>>>> ** >>>>> ** >>>>> ** >>>>> ** >>>>> ** >>>>> ** >>>>> ** >>>>> *http://www.matronics.com/Navigator?AeroElectric-List <3D%22http:/www.matronics.com/Navigator?AeroElectric-List>* >>>>> ** >>>>> ** >>>>> ** >>>>> ** >>>>> ** >>>>> *http://forums.matronics.com <3D%22http:/forums.matronics.com>* >>>>> ** >>>>> ** >>>>> ** >>>>> ** >>>>> ** >>>>> *http://www.matronics.com/contribution <3D%22http:/www.matronics.com/contribution>* >>>>> ** >>>>> * * >>>>> * >>>>> >>>>> >>>>> * >>>> * >>>> >>>> href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List >>>> href="http://forums.matronics.com">http://forums.matronics.com >>>> href="http://www.matronics.com/contribution">http://www.matronics.com/c >>>> * >>>> * >>>> >>>> >>>> * >>> * >>> >>> >>> * >> >> * >> >> ================================== >> st">http://www.matronics.com/Navigator?AeroElectric-List >> ================================== >> cs.com >> ================================== >> matronics.com/contribution >> ================================== >> >> * > * > > > * ________________________________________________________________________________
Date: Apr 01, 2013
Subject: Corrosion prevention was Blind riveting ground to
airframe? Howdy Bob, I think you're referring to alodine which is a conversion coating. The proper (by the book) way to prep aluminum for paint is to wet scrub it with alumaprep and scotchbrite, rinse thoroughly, and soak it in alodine until it starts to get that golden color and rinse again. Then it should be primed as soon as it is completely dry. The alumaprep cleans the surface. The alodine corrodes the surface layer (a few atoms deep) so that a barrier to further corrosion is created and provides a bit of "tooth" for the primer to follow. A problem with this process on completed structures is the difficulty of getting the phosphoric acid based alumaprep and alodine rinsed out from between riveted structures and every little nook and cranny. It especially tends to rear its ugly head on repaints and will later show up as filoform corrosion under the paint around rivet heads and lap joints. I did it this way for much of my early build and used the solvent base Akzo epoxy primer that you can't get anymore. It would be an interesting experiment to compare the areas that I did that way to the stuff that I've just wiped with acetone and sprayed with self etching primer in twenty or thirty years. Alodined aluminum without primer will probably perform about like alclad since both processes work by creating a very thin layer of aluminum oxide on the surface as a barrier to more damaging corrosive processes. As a prep process for paint, it used to be the only real way to get primers to grab onto aluminum. This was before epoxy primers. The instructions for these are now mostly about cleaning and sanding the surface before application. Completely cured epoxy primer is extremely tough and very difficult to remove which makes it a good long term undercoating for paint. By the way, the wash primer that Van's sprays quickbuild kits with is a form of self etching primer and is a lousy moisture barrier. It is intended to be painted over within hours, not left to stand on it's own. Corrosion only occurs in the presence of an electrolyte, usually moisture contaminated with dirt, dust, and whatever airborne acids are around. The whole purpose of any of the available treatments to prevent or stop the spread of corrosion is to exclude air and the moisture it contains from the vulnerable metal. The barrier can be a few molecules thick or a nice coat of paint over well adhered primer. The latter is obviously more robust and less susceptible to tiny breaches. Another approach is to spray the interior with CorrosionX or equivalent every few years (after painting the aircraft please - it weeps from between joints for a long time). Between joints is the hardest area to protect and that's why I recommend that if you're going to prime any aluminum, faying surfaces and extrusions are the best places to spend your energy. All steel, except for stainless, must be primed and painted in any case. Powder coating works well on steel, too. Pax, Ed Holyoke On 3/29/2013 6:18 AM, BobsV35B(at)aol.com wrote: > Good Morning Ed, > Care to comment as to how well Anodizing works? > I Anodize all small parts before painting. > Happy Skies, > Old Bob > In a message dated 3/28/2013 10:00:08 P.M. Central Daylight Time, > bicyclop(at)pacbell.net writes: > > With primer barriers, particularly on the aluminum. Most sheet > stock in use on kitplanes is alclad and doesn't generally need > primer. All extruded angle and bar stock is not clad and needs to > be primed to prevent corrosion. Many folks prime all faying > surfaces (where two pieces fit together) and it should certainly > be done at dissimilar metal joints. > > Ed Holyoke > > On 3/27/2013 11:16 PM, B Tomm wrote: >> How does the the stainless firewall riveted with aluminum rivets >> to aluminum sheet and angle stock play nice together? >> Bevan >> >> ------------------------------------------------------------------------ >> *From:* owner-aeroelectric-list-server(at)matronics.com >> [mailto:owner-aeroelectric-list-server(at)matronics.com] *On Behalf >> Of *Ed Holyoke >> *Sent:* Tuesday, March 26, 2013 9:35 PM >> *To:* aeroelectric-list(at)matronics.com >> *Subject:* Re: AeroElectric-List: Blind riveting ground to airframe? >> >> Stainless and aluminum don't play nice together. The aluminum >> will donate ions and corrode. Cad plated steel is the AN way. The >> cadmium is more anodic than the aluminum and acts as a >> sacrificial barrier. Eventually, it has no more ions to donate >> and loses it's value as a corrosion preventative. Time then for >> new hardware. Another approach would be to prime your hardware >> and install it wet. >> >> Ed Holyoke >> >> On 3/26/2013 7:25 AM, Jay Hyde wrote: >>> >>> Hello Sacha, >>> >>> I have the same problem in South Africa. For non structural >>> parts I simply use Metric sized bolts and nuts; usually >>> stainless steel ones to protect against corrosion. Stainless >>> steel and aluminium have relatively close galvanic potentials as >>> far as I can see. I have given up trying to source, or even >>> understand (!) the imperial nut and bolt thread system; its far >>> easier to walk into a bolt store and ask for M6 x 25mm bolts and >>> M6 nuts. J >>> >>> For structural parts you must however use AN fasteners and they >>> are not too difficult to understand (unless you need to order a >>> tap or die) ; I order them directly from Aircraft Spruce in the US. >>> >>> Johannesburg Jay >>> >>> *From:*owner-aeroelectric-list-server(at)matronics.com >>> [mailto:owner-aeroelectric-list-server(at)matronics.com] *On Behalf >>> Of *Sacha >>> *Sent:* 26 March 2013 03:58 PM >>> *To:* aeroelectric-list(at)matronics.com >>> *Subject:* Re: AeroElectric-List: Blind riveting ground to airframe? >>> >>> Does anyone know what the METRIC equivalent of an AN fastener is >>> and where I can buy some? I'm in Italy, so preferably somewhere >>> in Europe, though I'm willing to order from the US if necessary. >>> I've been going nuts (no pun intended) trying to look for some >>> but can only find a few manufacturers, nothing for the retail >>> buyer. >>> >>> >>> On Mar 26, 2013, at 13:42, rayj >> > wrote: >>> >>> Looks like a great source for fasteners. I wanted to be >>> sure the ones I chose were to an specs. I ended up ordering >>> a big assortment of small AN screws. If I could have gotten >>> an stuff with 6 lobe recess, I would have prefered it. >>> Definitely preferable to Phillips. >>> >>> Raymond Julian >>> >>> Kettle River, MN. >>> >>> >>> >>> "And you know that I could have me a million more friends, >>> >>> and all I'd have to lose is my point of view." - John Prine >>> >>> On 03/26/2013 07:20 AM, William Schertz wrote: >>> >>> Schertz" >>> >>> >>> Also note that they carry 100 degree flat head with Torx >>> drive, much nicer for avoiding stripouts like phillips >>> Bill Schertz >>> >>> -----Original Message----- From: Werner Schneider >>> Sent: Tuesday, March 26, 2013 5:41 AM >>> To: aeroelectric-list(at)matronics.com >>> >>> Subject: Re: AeroElectric-List: Blind riveting ground to >>> airframe? >>> >>> Schneider >>> >>> Ray checkout >>> http://www.microfasteners.com/catalog/products/SSC.cfm >>> >>> I replaced nearly all of my Phillips with the 6 lobe screws >>> >>> Cheers Werner >>> >>> On 25.03.2013 22:21, rayj wrote: >>> >>> Agreed. I was looking for some "blessed" #10 hex head >>> bolts because I >>> prefer a hex head over slotted or phillips screw heads. >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> * * >>> >>> * * >>> >>> * * >>> >>> * * >>> * * >>> ** >>> ** >>> ** >>> ** >>> ** >>> ** >>> ** >>> *http://www.matronics.com/Navigator?AeroElectric-List * >>> ** >>> ** >>> ** >>> ** >>> ** >>> *http://forums.matronics.com * >>> ** >>> ** >>> ** >>> ** >>> ** >>> *http://www.matronics.com/contribution * >>> ** >>> * * >>> * >>> >>> >>> * >> * >> >> href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List >> href="http://forums.matronics.com">http://forums.matronics.com >> href="http://www.matronics.com/contribution">http://www.matronics.com/c >> * >> * >> >> >> * > * > > ist href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List > s.matronics.com/">http://forums.matronics.com > p://www.matronics.com/contribution">http://www.matronics.com/contribution > > * > > * > > > * ________________________________________________________________________________
Date: Apr 01, 2013
Subject: Re: Failed contactor
At 08:16 AM 4/1/2013, you wrote: > > >Bob, > >Just checking to see if you got the junk contactor? Yes I did. Thank! Haven't had time to open it up yet. Bob . . . ________________________________________________________________________________
Date: Apr 01, 2013
Subject: Re: Corrosion prevention was Blind riveting ground
to ai... Good Afternoon Ed, Thanks for the message! Obviously, I was thinking Alodine and wrote Anodize! Alumaprep and Alodine is just what I use. And that is only on parts BEFORE they are assembled. I also have the high pressure, fine mist, fogger recommended by Corrosion X. Gotta keep those molecules from heading back to dust! Happy Skies, Old Bob In a message dated 4/1/2013 12:36:20 P.M. Central Daylight Time, bicyclop(at)pacbell.net writes: Howdy Bob, I think you're referring to alodine which is a conversion coating. The proper (by the book) way to prep aluminum for paint is to wet scrub it with alumaprep and scotchbrite, rinse thoroughly, and soak it in alodine until it starts to get that golden color and rinse again. Then it should be primed as soon as it is completely dry. The alumaprep cleans the surface. The alodine corrodes the surface layer (a few atoms deep) so that a barrier to further corrosion is created and provides a bit of "tooth" for the primer to follow. A problem with this process on completed structures is the difficulty of getting the phosphoric acid based alumaprep and alodine rinsed out from between riveted structures and every little nook and cranny. It especially tends to rear its ugly head on repaints and will later show up as filoform corrosion under the paint around rivet heads and lap joints. I did it this way for much of my early build and used the solvent base Akzo epoxy primer that you can't get anymore. It would be an interesting experiment to compare the areas that I did that way to the stuff that I've just wiped with acetone and sprayed with self etching primer in twenty or thirty years. Alodined aluminum without primer will probably perform about like alclad since both processes work by creating a very thin layer of aluminum oxide on the surface as a barrier to more damaging corrosive processes. As a prep process for paint, it used to be the only real way to get primers to grab onto aluminum. This was before epoxy primers. The instructions for these are now mostly about cleaning and sanding the surface before application. Completely cured epoxy primer is extremely tough and very difficult to remove which makes it a good long term undercoating for paint. By the way, the wash primer that Van's sprays quickbuild kits with is a form of self etching primer and is a lousy moisture barrier. It is intended to be painted over within hours, not left to stand on it's own. Corrosion only occurs in the presence of an electrolyte, usually moisture contaminated with dirt, dust, and whatever airborne acids are around. The whole purpose of any of the available treatments to prevent or stop the spread of corrosion is to exclude air and the moisture it contains from the vulnerable metal. The barrier can be a few molecules thick or a nice coat of paint over well adhered primer. The latter is obviously more robust and less susceptible to tiny breaches. Another approach is to spray the interior with CorrosionX or equivalent every few years (after painting the aircraft please - it weeps from between joints for a long time). Between joints is the hardest area to protect and that's why I recommend that if you're going to prime any aluminum, faying surfaces and extrusions are the best places to spend your energy. All steel, except for stainless, must be primed and painted in any case. Powder coating works well on steel, too. Pax, Ed Holyoke ________________________________________________________________________________
Date: Apr 01, 2013
Hi Ed, I agree with most of what you say. I'm in England, there is nowhere here that is > 50 miles from the sea, and for a lot of the year it is damp and not very warm. Quickbuild RVs suffer corrosion inside their wings here and need to be treated with CorrosionX or ACF50 after painting. There aren't many old C150s or Cherokees either as most of them have rotted away! So priming is definitely required to protect your investment ... It takes quite a bit longer, uses nasty chemicals, weighs more and I hate all the prep and spraying, but there isn't really an option in this climate. Peter On 01/04/2013 17:17, Ed Holyoke wrote: > Howdy Peter, > > Right you are. Alclad isn't perfect, but for most of us it will be > good enough. Here in California and hangared there really isn't a lot > of concern about corrosion. This will not be true everywhere and in > all conditions. That said, how many of our homebuilt airplanes will be > flying in fifty years? For many of us the aircraft will likely outlive > us whether or not we prime everything and if we spend so much time > obsessing about the future life of the aircraft that it doesn't get > finished until our medicals are no longer renewable..... Well, you get > the picture. Gotta balance serviceability and utility with getting > done in time to fly it. > > Another factor is of course weight. Priming everything could add say > five pounds, maybe more. Doesn't seem like much but it tends to add > up. Folks really like the deep shine of a base/clear coat paint job > and those tend to be ten or more pounds heavier than single stage to > color. Can't really see the difference from ten feet, let alone a > thousand. Some of us pad the whole interior with leather and/or > carpet. Looks great and reminds of of a luxury car but doesn't improve > the way the airplane flies. > > The great thing about homebuilding is that you can choose what you > want in a way that certificated aircraft will never do. Maybe you've > got grandkids who will keep the airplane flying a long time and would > appreciate having everything primed. If you want to load the panel > with every possible goodie and don't care about the weight, hey - it's > your airplane. I'm looking to keep it light while being maintainable. > I doubt that the alclad skins will show any sign of corrosion in my > lifetime and then there's always CorrosionX. > > Ed Holyoke > > On 3/29/2013 2:19 AM, Peter Pengilly wrote: >> Ed, >> >> Drifting somewhat from the theme of this list, but to say that alclad >> doesn't need priming is a bold statement. In Texas maybe, but in a >> cool maritime climate it isn't really adequate protection against the >> dreaded metal worm in the long term. >> >> For grounding studs I have seen bright zinc plated bolts used with >> the primer removed from the structure they were inserted into. To >> make it clear what they are the paint finish was restored with a >> contrasting colour (blue in this case I'm thinking of against puke >> yellow primer), but leaving the nut holding the stud in unpainted for >> good electrical connection. >> >> Peter >> >> On 29/03/2013 02:57, Ed Holyoke wrote: >>> With primer barriers, particularly on the aluminum. Most sheet stock >>> in use on kitplanes is alclad and doesn't generally need primer. All >>> extruded angle and bar stock is not clad and needs to be primed to >>> prevent corrosion. Many folks prime all faying surfaces (where two >>> pieces fit together) and it should certainly be done at dissimilar >>> metal joints. >>> >>> Ed Holyoke >>> >>> On 3/27/2013 11:16 PM, B Tomm wrote: >>>> How does the the stainless firewall riveted with aluminum rivets to >>>> aluminum sheet and angle stock play nice together? >>>> Bevan >>>> >>>> ------------------------------------------------------------------------ >>>> *From:* owner-aeroelectric-list-server(at)matronics.com >>>> [mailto:owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of >>>> *Ed Holyoke >>>> *Sent:* Tuesday, March 26, 2013 9:35 PM >>>> *To:* aeroelectric-list(at)matronics.com >>>> *Subject:* Re: AeroElectric-List: Blind riveting ground to airframe? >>>> >>>> Stainless and aluminum don't play nice together. The aluminum will >>>> donate ions and corrode. Cad plated steel is the AN way. The >>>> cadmium is more anodic than the aluminum and acts as a sacrificial >>>> barrier. Eventually, it has no more ions to donate and loses it's >>>> value as a corrosion preventative. Time then for new hardware. >>>> Another approach would be to prime your hardware and install it wet. >>>> >>>> Ed Holyoke >>>> >>>> On 3/26/2013 7:25 AM, Jay Hyde wrote: >>>>> >>>>> Hello Sacha, >>>>> >>>>> I have the same problem in South Africa. For non structural parts >>>>> I simply use Metric sized bolts and nuts; usually stainless steel >>>>> ones to protect against corrosion. Stainless steel and aluminium >>>>> have relatively close galvanic potentials as far as I can see. I >>>>> have given up trying to source, or even understand (!) the >>>>> imperial nut and bolt thread system; its far easier to walk into a >>>>> bolt store and ask for M6 x 25mm bolts and M6 nuts. J >>>>> >>>>> For structural parts you must however use AN fasteners and they >>>>> are not too difficult to understand (unless you need to order a >>>>> tap or die...) ; I order them directly from Aircraft Spruce in the US. >>>>> >>>>> Johannesburg Jay >>>>> >>>>> *From:*owner-aeroelectric-list-server(at)matronics.com >>>>> [mailto:owner-aeroelectric-list-server(at)matronics.com] *On Behalf >>>>> Of *Sacha >>>>> *Sent:* 26 March 2013 03:58 PM >>>>> *To:* aeroelectric-list(at)matronics.com >>>>> *Subject:* Re: AeroElectric-List: Blind riveting ground to airframe? >>>>> >>>>> Does anyone know what the METRIC equivalent of an AN fastener is >>>>> and where I can buy some? I'm in Italy, so preferably somewhere >>>>> in Europe, though I'm willing to order from the US if necessary. >>>>> I've been going nuts (no pun intended) trying to look for some but >>>>> can only find a few manufacturers, nothing for the retail buyer. >>>>> >>>>> >>>>> On Mar 26, 2013, at 13:42, rayj >>>> > wrote: >>>>> >>>>> Looks like a great source for fasteners. I wanted to be sure >>>>> the ones I chose were to an specs. I ended up ordering a big >>>>> assortment of small AN screws. If I could have gotten an stuff >>>>> with 6 lobe recess, I would have prefered it. Definitely >>>>> preferable to Phillips. >>>>> >>>>> Raymond Julian >>>>> >>>>> Kettle River, MN. >>>>> >>>>> >>>>> >>>>> "And you know that I could have me a million more friends, >>>>> >>>>> and all I'd have to lose is my point of view." - John Prine >>>>> >>>>> On 03/26/2013 07:20 AM, William Schertz wrote: >>>>> >>>>> >>>>> >>>>> Also note that they carry 100 degree flat head with Torx >>>>> drive, much nicer for avoiding stripouts like phillips >>>>> Bill Schertz >>>>> >>>>> -----Original Message----- From: Werner Schneider >>>>> Sent: Tuesday, March 26, 2013 5:41 AM >>>>> To: aeroelectric-list(at)matronics.com >>>>> >>>>> Subject: Re: AeroElectric-List: Blind riveting ground to >>>>> airframe? >>>>> >>>>> >>>>> >>>>> Ray checkout >>>>> http://www.microfasteners.com/catalog/products/SSC.cfm >>>>> >>>>> I replaced nearly all of my Phillips with the 6 lobe screws >>>>> >>>>> Cheers Werner >>>>> >>>>> On 25.03.2013 22:21, rayj wrote: >>>>> >>>>> Agreed. I was looking for some "blessed" #10 hex head >>>>> bolts because I >>>>> prefer a hex head over slotted or phillips screw heads. >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> * * >>>>> >>>>> * * >>>>> >>>>> * * >>>>> >>>>> * * >>>>> * * >>>>> ** >>>>> ** >>>>> ** >>>>> ** >>>>> ** >>>>> ** >>>>> ** >>>>> *http://www.matronics.com/Navigator?AeroElectric-List <3D%22http:/www.matronics.com/Navigator?AeroElectric-List>* >>>>> ** >>>>> ** >>>>> ** >>>>> ** >>>>> ** >>>>> *http://forums.matronics.com <3D%22http:/forums.matronics.com>* >>>>> ** >>>>> ** >>>>> ** >>>>> ** >>>>> ** >>>>> *http://www.matronics.com/contribution <3D%22http:/www.matronics.com/contribution>* >>>>> ** >>>>> * * >>>>> * >>>>> >>>>> >>>>> * >>>> * >>>> >>>> href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List >>>> href="http://forums.matronics.com">http://forums.matronics.com >>>> href="http://www.matronics.com/contribution">http://www.matronics.com/c >>>> * >>>> * >>>> >>>> >>>> * >>> * >>> >>> >>> * >> >> * >> >> >> * > * > > > * ________________________________________________________________________________
Subject: Blind riveting ground to airframe?
Date: Apr 01, 2013
Same here. Sicily is not as damp as England, but my hangar is only 100m from the sea. If I leave a screwdriver out of its' box it will rust in a couple of weeks! Thanks Ed for the tips From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Peter Pengilly Sent: Monday, 01 April, 2013 21:42 Subject: Re: AeroElectric-List: Blind riveting ground to airframe? Hi Ed, I agree with most of what you say. I'm in England, there is nowhere here that is > 50 miles from the sea, and for a lot of the year it is damp and not very warm. Quickbuild RVs suffer corrosion inside their wings here and need to be treated with CorrosionX or ACF50 after painting. There aren't many old C150s or Cherokees either as most of them have rotted away! So priming is definitely required to protect your investment ... It takes quite a bit longer, uses nasty chemicals, weighs more and I hate all the prep and spraying, but there isn't really an option in this climate. Peter On 01/04/2013 17:17, Ed Holyoke wrote: Howdy Peter, Right you are. Alclad isn't perfect, but for most of us it will be good enough. Here in California and hangared there really isn't a lot of concern about corrosion. This will not be true everywhere and in all conditions. That said, how many of our homebuilt airplanes will be flying in fifty years? For many of us the aircraft will likely outlive us whether or not we prime everything and if we spend so much time obsessing about the future life of the aircraft that it doesn't get finished until our medicals are no longer renewable..... Well, you get the picture. Gotta balance serviceability and utility with getting done in time to fly it. Another factor is of course weight. Priming everything could add say five pounds, maybe more. Doesn't seem like much but it tends to add up. Folks really like the deep shine of a base/clear coat paint job and those tend to be ten or more pounds heavier than single stage to color. Can't really see the difference from ten feet, let alone a thousand. Some of us pad the whole interior with leather and/or carpet. Looks great and reminds of of a luxury car but doesn't improve the way the airplane flies. The great thing about homebuilding is that you can choose what you want in a way that certificated aircraft will never do. Maybe you've got grandkids who will keep the airplane flying a long time and would appreciate having everything primed. If you want to load the panel with every possible goodie and don't care about the weight, hey - it's your airplane. I'm looking to keep it light while being maintainable. I doubt that the alclad skins will show any sign of corrosion in my lifetime and then there's always CorrosionX. Ed Holyoke On 3/29/2013 2:19 AM, Peter Pengilly wrote: Ed, Drifting somewhat from the theme of this list, but to say that alclad doesn't need priming is a bold statement. In Texas maybe, but in a cool maritime climate it isn't really adequate protection against the dreaded metal worm in the long term. For grounding studs I have seen bright zinc plated bolts used with the primer removed from the structure they were inserted into. To make it clear what they are the paint finish was restored with a contrasting colour (blue in this case I'm thinking of against puke yellow primer), but leaving the nut holding the stud in unpainted for good electrical connection. Peter On 29/03/2013 02:57, Ed Holyoke wrote: With primer barriers, particularly on the aluminum. Most sheet stock in use on kitplanes is alclad and doesn't generally need primer. All extruded angle and bar stock is not clad and needs to be primed to prevent corrosion. Many folks prime all faying surfaces (where two pieces fit together) and it should certainly be done at dissimilar metal joints. Ed Holyoke On 3/27/2013 11:16 PM, B Tomm wrote: How does the the stainless firewall riveted with aluminum rivets to aluminum sheet and angle stock play nice together? Bevan _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ed Holyoke Sent: Tuesday, March 26, 2013 9:35 PM Subject: Re: AeroElectric-List: Blind riveting ground to airframe? Stainless and aluminum don't play nice together. The aluminum will donate ions and corrode. Cad plated steel is the AN way. The cadmium is more anodic than the aluminum and acts as a sacrificial barrier. Eventually, it has no more ions to donate and loses it's value as a corrosion preventative. Time then for new hardware. Another approach would be to prime your hardware and install it wet. Ed Holyoke On 3/26/2013 7:25 AM, Jay Hyde wrote: Hello Sacha, I have the same problem in South Africa. For non structural parts I simply use Metric sized bolts and nuts; usually stainless steel ones to protect against corrosion. Stainless steel and aluminium have relatively close galvanic potentials as far as I can see. I have given up trying to source, or even understand (!) the imperial nut and bolt thread system; its far easier to walk into a bolt store and ask for M6 x 25mm bolts and M6 nuts. J For structural parts you must however use AN fasteners and they are not too difficult to understand (unless you need to order a tap or die.) ; I order them directly from Aircraft Spruce in the US. Johannesburg Jay From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Sacha Sent: 26 March 2013 03:58 PM Subject: Re: AeroElectric-List: Blind riveting ground to airframe? Does anyone know what the METRIC equivalent of an AN fastener is and where I can buy some? I'm in Italy, so preferably somewhere in Europe, though I'm willing to order from the US if necessary. I've been going nuts (no pun intended) trying to look for some but can only find a few manufacturers, nothing for the retail buyer. On Mar 26, 2013, at 13:42, rayj wrote: Looks like a great source for fasteners. I wanted to be sure the ones I chose were to an specs. I ended up ordering a big assortment of small AN screws. If I could have gotten an stuff with 6 lobe recess, I would have prefered it. Definitely preferable to Phillips. Raymond Julian Kettle River, MN. "And you know that I could have me a million more friends, and all I'd have to lose is my point of view." - John Prine On 03/26/2013 07:20 AM, William Schertz wrote: Also note that they carry 100 degree flat head with Torx drive, much nicer for avoiding stripouts like phillips Bill Schertz -----Original Message----- From: Werner Schneider Sent: Tuesday, March 26, 2013 5:41 AM Subject: Re: AeroElectric-List: Blind riveting ground to airframe? Ray checkout http://www.microfasteners.com/catalog/products/SSC.cfm I replaced nearly all of my Phillips with the 6 lobe screws Cheers Werner On 25.03.2013 22:21, rayj wrote: Agreed. I was looking for some "blessed" #10 hex head bolts because I prefer a hex head over slotted or phillips screw heads. http://www.matronics.com/Navigator?AeroElectric-List http://forums.matronics.com http://www.matronics.com/contribution href= "http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics. com/Navigator?AeroElectric-List href= "http://forums.matronics.com">http://forums.matronics.com href= "http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Subject: Ebus Diode
Date: Apr 02, 2013
The drawing http://www.bandc.biz/pdfs/Diode_Installation.pdf =46rom B and C shows both ~ (I don't have the correct symbol horizontal s wi th -) terminals powered from the main bus with the + going to the Ebus and - unused. Question: I could run power from the main bus to either ~ terminal and power the Ebus? Powering both ~ terminals gains a little redundancy to power the Ebus? Thanks, Andy Sent from my iPhone ________________________________________________________________________________
Subject: Re: Ebus Diode
Date: Apr 02, 2013
Andy, << Question: I could run power from the main bus to either ~ terminal and power the Ebus? >> Yes, but this misses the purpose of connecting both AC terminals (~) to the source. The package has 4 diodes. It is used everywhere as an AC to DC rectifier. In theory you could use one high current diode but the cost of the same capacity is much higher than the 4 diode package due to the very high economy of scale from the 4 diode configuration even though we are "wasting" diodes. The mounting for this package is also simpler. The main enemy of semiconductors is heat. With the connection to two divides in parallel the current between them is divided, not evenly divided but still shared between the two. This spreads out the heat generation which makes the device more robust. << Powering both ~ terminals gains a little redundancy to power the Ebus? >> As is hopefully explained above, the reason for using both ~ terminals is spreading out the heat generation, not redundancy. If you have an Ebus current of 15 amps, even if one diode carries 10 amps and the other only 5 amps, you are stressing the part less than having all 15 amps going through 1 diode. In other words, there is a good reason for connecting the source to both ~ terminals which is what you should do. Tom Kuffel ________________________________________________________________________________
Date: Apr 02, 2013
Great explanation! Thanks, Andy Sent from my iPhone On Apr 2, 2013, at 11:13 AM, "The Kuffels" wrote: > > Andy, > > << Question: I could run power from the main bus to either ~ terminal and power the Ebus? >> > > Yes, but this misses the purpose of connecting both AC terminals (~) to the source. The package has 4 diodes. It is used everywhere as an AC to DC rectifier. In theory you could use one high current diode but the cost of the same capacity is much higher than the 4 diode package due to the very high economy of scale from the 4 diode configuration even though we are "wasting" diodes. The mounting for this package is also simpler. > > The main enemy of semiconductors is heat. With the connection to two divides in parallel the current between them is divided, not evenly divided but still shared between the two. This spreads out the heat generation which makes the device more robust. > > << Powering both ~ terminals gains a little redundancy to power the Ebus? >> > > As is hopefully explained above, the reason for using both ~ terminals is spreading out the heat generation, not redundancy. If you have an Ebus current of 15 amps, even if one diode carries 10 amps and the other only 5 amps, you are stressing the part less than having all 15 amps going through 1 diode. In other words, there is a good reason for connecting the source to both ~ terminals which is what you should do. > > Tom Kuffel > > > > ________________________________________________________________________________
Date: Apr 02, 2013
At 09:56 AM 4/2/2013, you wrote: >The drawing ><http://www.bandc.biz/pdfs/Diode_Installation.pdf>http://www.bandc.biz/pdfs/Diode_Installation.pdf > From B and C shows both ~ (I don't have the correct symbol > horizontal s with -) terminals powered from the main bus with the + > going to the Ebus and - unused. >Question: I could run power from the main bus to either ~ terminal >and power the Ebus? >Powering both ~ terminals gains a little redundancy to power the Ebus? No 'redundancy' just a potential tiny improvement in thermal modeling. Not a big deal one way or another. Run main bus power to either one or both AC input terminals, one wire from (+) to e-bus. Bob . . . Bob . . . ________________________________________________________________________________
Date: Apr 02, 2013
Subject: LED strip lighting for panels
If your airplane has a glare shield, you can consider the used of LED strip lights similar to these. http://tinyurl.com/c3wozbj These strips are assembled from an array of LED trios in series fitted with the appropriate series resistor to provide max illumination with 12vdc applied. Each trio occupies about 2" of length. Three white lights in series do not begin to output until applied voltage rises to 7.5 volts or so. At 12 volts, each group of 3 lamps (about 2" in length) draws about 25 milliamps. Assume you need 36" of strip to stretch across the glare shield (18 trios). You'll need a dimmer control capable of carrying 18 x .025 or 0.45 amps. This relatively low current draw makes the noise-free, linear regulators more attractive. Referring to this drawing http://tinyurl.com/ccrpzfa You see the architecture for a dimmer set up for incandescent lamps. I.e. 4.5 volts minimum. For service with these strips, the minimum needs to be raised to 7.5 volts. Further, we want to fix the adjustment range at 7.5 - 12v or a delta-V of 3.5 volts. Since our stock "pot" is 2.5K, then to get 3.5 volts dropped across the pot at max resistance, we need a divider current of 3.5/2500 or 1.4 milliamps. The voltage across the upper resistor is fixed at 1.25 volts by internal characteristics of the 317 regulator. 1.25V/0.0014A = 892 (910 ohms is close enough and a standard 5% value). Okay, with the pot at min resistance, we need 7.5 volts total output. (7.5 - 1.25)/0.0014 equals 4464 ohms (4700 is also a standard value and sufficiently close). So, if you'd care to build your own dimmer the 390 ohm resistor is replaced with a 910 ohm resistor; the 910 ohm resistor is replaced with a 4700 ohm resistor. The TO220 plastic package version of the LM317 on a modicum of heatsink would be 'fat' enough and entirely free of noise. That 15-foot chunk of strip lighting for $20 is delivered toyour door at that price and is probably enough lighting to do 5 airplanes. I've copied B&C on this posting to see if they'd be interested in offering an LED strip light version of their DIM5-14 product. http://tinyurl.com/dylkufj Bob . . . ________________________________________________________________________________
Date: Apr 02, 2013
Subject: Re: LED strip lighting for panels
Bob, Do I understand correctly that you are controlling LED brightness by varying the voltage? My understanding was that a PWM was needed to dim LEDs. Of course, I've been wrong before. :>) Raymond Julian Kettle River, MN. "And you know that I could have me a million more friends, and all I'd have to lose is my point of view." - John Prine On 04/02/2013 02:12 PM, Robert L. Nuckolls, III wrote: > If your airplane has a glare shield, you can > consider the used of LED strip lights similar > to these. > > http://tinyurl.com/c3wozbj > > <http://tinyurl.com/c3wozbj>These strips are assembled from an array > of LED trios in series fitted with the appropriate > series resistor to provide max illumination with > 12vdc applied. Each trio occupies about 2" of > length. > > Three white lights in series do not begin to > output until applied voltage rises to 7.5 volts > or so. At 12 volts, each group of 3 lamps > (about 2" in length) draws about 25 milliamps. > > Assume you need 36" of strip to stretch > across the glare shield (18 trios). You'll > need a dimmer control capable of carrying > 18 x .025 or 0.45 amps. This relatively > low current draw makes the noise-free, linear > regulators more attractive. Referring to this > drawing > > http://tinyurl.com/ccrpzfa > > You see the architecture for a dimmer set up for > incandescent lamps. I.e. 4.5 volts minimum. For service > with these strips, the minimum needs to be raised to > 7.5 volts. Further, we want to fix the adjustment > range at 7.5 - 12v or a delta-V of 3.5 volts. > > Since our stock "pot" is 2.5K, then to get 3.5 > volts dropped across the pot at max resistance, > we need a divider current of 3.5/2500 or 1.4 milliamps. > > The voltage across the upper resistor is fixed at > 1.25 volts by internal characteristics of the > 317 regulator. 1.25V/0.0014A = 892 (910 ohms > is close enough and a standard 5% value). > > Okay, with the pot at min resistance, we need > 7.5 volts total output. (7.5 - 1.25)/0.0014 > equals 4464 ohms (4700 is also a standard > value and sufficiently close). > > So, if you'd care to build your own dimmer the > 390 ohm resistor is replaced with a 910 ohm > resistor; the 910 ohm resistor is replaced with > a 4700 ohm resistor. The TO220 plastic package > version of the LM317 on a modicum of heatsink > would be 'fat' enough and entirely free of noise. > > That 15-foot chunk of strip lighting for $20 is > delivered toyour door at that price and is probably > enough lighting to do 5 airplanes. I've copied B&C > on this posting to see if they'd be interested in > offering an LED strip light version of their DIM5-14 > product. > > http://tinyurl.com/dylkufj > > <http://tinyurl.com/dylkufj> > > Bob . . . > > * > > > * ________________________________________________________________________________
Date: Apr 02, 2013
Subject: Re: Dolphin Electrical Wire Connectors
It might not have been intended as an April Fools joke, but it should be. Those are "B" connectors, aka "beans" used by the telephone company since the 1950s and intended for use in splicing telephone wires. They do not work reliably for stranded wire. For their intended purpose, which is joining *solid* conductors that don't ever move, they are fine if you use the correct tool (formerly known as a "beaner.") I cannot think of an airworthy use anywhere in an airplane (unless in your tool bag going somewhere to fix a telephone line.) On 4/1/13 11:58 PM, AeroElectric-List Digest Server wrote: > From: "Owen Baker "<bakerocb(at)cox.net> > Subject: AeroElectric-List: Dolphin Electrical Wire Connectors > > 4/1/2013 > > Hello Bob Nuckolls, It has been suggested that I use these Dolphin > DC-100- P or -S insulation piercing type electrical wire connectors for > low amperage wire connection usage, such as a Ray Allen trim servo, in > my experimental amateur built airplane: > > http://dolphincomponents.com/catalogs/Section%20A%20-%20Super%20B%20stand > ard-3207.pdf > > What do you think? Thank you. > > Owen C. Baker > > PS: This is not intended as an April Fools Day joke. ________________________________________________________________________________
From: "Fisher Paul A." <FisherPaulA(at)johndeere.com>
Date: Apr 02, 2013
I'm doing exactly that in my plane using red LED's instead of white. I've got them installed by not wired yet (been too cold at the hanger!). I'm pl anning to use one of Eric's dimmers (http://www.periheliondesign.com/egpavr .htm). I've tested the lights and dimmer in the shop and it all seems to w ork well. I'll have to wait for some dark night to see how effective they actually are in the plane. I'm actually more concerned about having too m uch light. But so far it appears that I can dial it down far enough to not overpower my night vision. Paul A. Fisher RV-7A N18PF From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectr ic-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Tuesday, April 02, 2013 2:12 PM Subject: AeroElectric-List: LED strip lighting for panels If your airplane has a glare shield, you can consider the used of LED strip lights similar to these. http://tinyurl.com/c3wozbj ... snip ... ________________________________________________________________________________
Date: Apr 02, 2013
At 02:35 PM 4/2/2013, you wrote: >Bob, > >Do I understand correctly that you are controlling LED brightness by >varying the voltage? > >My understanding was that a PWM was needed to dim LEDs. Of course, >I've been wrong before. :>) Not necessarily. The LED strip lights come with resistors built in . . . these resistors combined with minimum voltage necessary to get first light offers an opportunity to dim either way. You wouldn't necessarily want to do this to 'dim' high power leds . . . but the sum total of power for a few feet of strip lets us consider the linear, noise free option. Bob . . . ________________________________________________________________________________
Date: Apr 02, 2013
I used very similar lighting strips in my RV7A. At the the time the only place I found them was on Ebay from HongKong, but shipping was cheap. These work well with a two channel dimmer I already had from Steinair. One channel is used for the incandescent and the other for the LED strips as they dim as a different rate. I'm very happy with the results and would have bought from B n C if they stocked it. I would also have bought the dropping resistors from B no for the wigwag flasher but they don't stock them. nudge nudge. Bevan _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Tuesday, April 02, 2013 12:12 PM Subject: AeroElectric-List: LED strip lighting for panels If your airplane has a glare shield, you can consider the used of LED strip lights similar to these. http://tinyurl.com/c3wozbj These strips are assembled from an array of LED trios in series fitted with the appropriate series resistor to provide max illumination with 12vdc applied. Each trio occupies about 2" of length. Three white lights in series do not begin to output until applied voltage rises to 7.5 volts or so. At 12 volts, each group of 3 lamps (about 2" in length) draws about 25 milliamps. Assume you need 36" of strip to stretch across the glare shield (18 trios). You'll need a dimmer control capable of carrying 18 x .025 or 0.45 amps. This relatively low current draw makes the noise-free, linear regulators more attractive. Referring to this drawing http://tinyurl.com/ccrpzfa You see the architecture for a dimmer set up for incandescent lamps. I.e. 4.5 volts minimum. For service with these strips, the minimum needs to be raised to 7.5 volts. Further, we want to fix the adjustment range at 7.5 - 12v or a delta-V of 3.5 volts. Since our stock "pot" is 2.5K, then to get 3.5 volts dropped across the pot at max resistance, we need a divider current of 3.5/2500 or 1.4 milliamps. The voltage across the upper resistor is fixed at 1.25 volts by internal characteristics of the 317 regulator. 1.25V/0.0014A = 892 (910 ohms is close enough and a standard 5% value). Okay, with the pot at min resistance, we need 7.5 volts total output. (7.5 - 1.25)/0.0014 equals 4464 ohms (4700 is also a standard value and sufficiently close). So, if you'd care to build your own dimmer the 390 ohm resistor is replaced with a 910 ohm resistor; the 910 ohm resistor is replaced with a 4700 ohm resistor. The TO220 plastic package version of the LM317 on a modicum of heatsink would be 'fat' enough and entirely free of noise. That 15-foot chunk of strip lighting for $20 is delivered toyour door at that price and is probably enough lighting to do 5 airplanes. I've copied B&C on this posting to see if they'd be interested in offering an LED strip light version of their DIM5-14 product. http://tinyurl.com/dylkufj Bob . . . ________________________________________________________________________________
Date: Apr 03, 2013
Robert L. Nuckolls, III a crit : > If your airplane has a glare shield, you can > consider the used of LED strip lights similar > to these. Hi Bob and all, Just for the fun, this is what we did. (Hope attachments are allowed). Best regards, -- Gilles http://contrails.free.fr ________________________________________________________________________________
Date: Apr 03, 2013
On a related note, is there a way to determine if a heatsink is large enough? I made a heatsink out of some scrap .020" aluminium -- half a dozen pieces of varying lengths, stacked and folded up at the ends to form fins. I've bolted it under the rectifier with some heatsink paste. Seems like quite a lot of aluminium, and plenty of surface area, but it would nice to find a way of evaluating its effectiveness... other than waiting for the smell of burning semiconductor... Many thanks, James On 2 April 2013 16:38, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 09:56 AM 4/2/2013, you wrote: > > The drawing http://www.bandc.biz/pdfs/Diode_Installation.pdf > From B and C shows both ~ (I don't have the correct symbol horizontal s > with -) terminals powered from the main bus with the + going to the Ebus > and - unused. > Question: I could run power from the main bus to either ~ terminal and > power the Ebus? > Powering both ~ terminals gains a little redundancy to power the Ebus? > > > No 'redundancy' just a potential tiny improvement in > thermal modeling. Not a big deal one way or another. > Run main bus power to either one or both AC input > terminals, one wire from (+) to e-bus. > > Bob . . . > > ** > > ** Bob . . . > > * > > * > > ________________________________________________________________________________
Date: Apr 03, 2013
At 07:31 AM 4/3/2013, you wrote: >On a related note, is there a way to determine >if a heatsink is large enough? > >I made a heatsink out of some scrap .020" >aluminium -- half a dozen pieces of varying >lengths, stacked and folded up at the ends to >form fins. I've bolted it under the rectifier with some heatsink paste. > >Seems like quite a lot of aluminium, and plenty >of surface area, but it would nice to find a way >of evaluating its effectiveness... other than >waiting for the smell of burning semiconductor... What are your e-bus normal running loads? I would not expect loads of 10A or less to call for anything other than to simply mount the diode a metal surface in the airplane. I could run some tests here for higher currents but keep in mind that the e-bus is for 'endurance' loads . . . minimal equipment to conduct the en route phase of flight . . . reduced energy demands to save the battery for approach to landing. I suggested that big fat diode because of it's convenience for mounting and wiring. The fact that it is rated for 25 or 35 amps was in no way intended to suggest that e-bus loads should/could be that large. The e-bus is a risk reduction feature that is not likely to be needed more than once over the lifetime of your airplane. It's a feature that offers a degrees of System Reliability that reduces probability that a main alternator failure will cause you to break a sweat. As a renter, I have never enjoyed access to features that we're building into OBAM aircraft. My personal endurance package was carried around in the flight bag. http://tinyurl.com/d5mrjgh In fact, I've not turned a VOR receiver on in nearly 20 years. Not since I discovered the capabilities of hand-held GPS receivers that were so cheap I could give them away as door prizes at my seminars! My last cross-country sojourns were managed with dual GPS receivers stuck between the glare-shield and windshield with little wads of windshield sealant. It didn't matter if the airplane was a J-3 or A-36, I was confident in my ability to get from point A to Point B whether the ship's electrical system was fully functional or not. That's a high degree of failure tolerance and system reliability. Bob . . . ________________________________________________________________________________
Date: Apr 03, 2013
Thanks Bob, I have a theoretical max load of a little under 7A. I agree with your sentiments about the essential bus. I don't anticipate needing it... but it's nice to know that it's there... James On 3 April 2013 14:52, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > nuckolls.bob(at)aeroelectric.com**> > > At 07:31 AM 4/3/2013, you wrote: > >> On a related note, is there a way to determine if a heatsink is large >> enough? =C3=82 >> >> I made a heatsink out of some scrap .020" aluminium -- half a dozen >> pieces of varying lengths, stacked and folded up at the ends to form fin s. >> =C3=82 I've bolted it under the rectifier with some heatsink paste. =C3 =82 >> >> >> Seems like quite a lot of aluminium, and plenty of surface area, but it >> would nice to find a way of evaluating its effectiveness... other than >> waiting for the smell of burning semiconductor... >> > > What are your e-bus normal running loads? > I would not expect loads of 10A or less to > call for anything other than to simply mount > the diode a metal surface in the airplane. > > I could run some tests here for higher currents > but keep in mind that the e-bus is for 'endurance' > loads . . . minimal equipment to conduct the > en route phase of flight . . . reduced energy > demands to save the battery for approach to > landing. > > I suggested that big fat diode because of it's > convenience for mounting and wiring. The fact that > it is rated for 25 or 35 amps was in no way intended > to suggest that e-bus loads should/could be > that large. > > The e-bus is a risk reduction feature that is > not likely to be needed more than once over the > lifetime of your airplane. It's a feature that > offers a degrees of System Reliability that > reduces probability that a main alternator failure > will cause you to break a sweat. > > As a renter, I have never enjoyed access to features > that we're building into OBAM aircraft. My personal > endurance package was carried around in the flight > bag. http://tinyurl.com/d5mrjgh > > In fact, I've not turned a VOR receiver on in nearly > 20 years. Not since I discovered the capabilities > of hand-held GPS receivers that were so cheap I could > give them away as door prizes at my seminars! My last > cross-country sojourns were managed with dual > GPS receivers stuck between the glare-shield and > windshield with little wads of windshield sealant. > > It didn't matter if the airplane was a J-3 or A-36, > I was confident in my ability to get from point A to > Point B whether the ship's electrical system was > fully functional or not. That's a high degree of > failure tolerance and system reliability. > > > Bob . . . > > =====**=================== ===========**= /www.matronics.com/Navigator?AeroElectric-List> =====**=================== ===========**= =====**=================== ===========**= com/contribution> =====**=================== ===========**= > > ________________________________________________________________________________
Date: Apr 03, 2013
James, One of these should give you some numbers to play with to see how well your heatsink is working as you ebuss is loaded up. http://www.harborfreight.com/infrared-thermometer-with-laser-targeting-non- contact-69465.html Harbor Freight has a coupon out this month that reduces the price a further $10 to $25.99. Just a thought Rick Girard On Wed, Apr 3, 2013 at 9:41 AM, James Kilford wrote: > Thanks Bob, I have a theoretical max load of a little under 7A. > > I agree with your sentiments about the essential bus. I don't anticipate > needing it... but it's nice to know that it's there... > > James > > On 3 April 2013 14:52, Robert L. Nuckolls, III < > nuckolls.bob(at)aeroelectric.com> wrote: > >> nuckolls.bob(at)aeroelectric.com**> >> >> At 07:31 AM 4/3/2013, you wrote: >> >>> On a related note, is there a way to determine if a heatsink is large >>> enough? =C2 >>> >>> I made a heatsink out of some scrap .020" aluminium -- half a dozen >>> pieces of varying lengths, stacked and folded up at the ends to form fi ns. >>> =C2 I've bolted it under the rectifier with some heatsink paste. =C2 >>> >>> >>> Seems like quite a lot of aluminium, and plenty of surface area, but it >>> would nice to find a way of evaluating its effectiveness... other than >>> waiting for the smell of burning semiconductor... >>> >> >> What are your e-bus normal running loads? >> I would not expect loads of 10A or less to >> call for anything other than to simply mount >> the diode a metal surface in the airplane. >> >> I could run some tests here for higher currents >> but keep in mind that the e-bus is for 'endurance' >> loads . . . minimal equipment to conduct the >> en route phase of flight . . . reduced energy >> demands to save the battery for approach to >> landing. >> >> I suggested that big fat diode because of it's >> convenience for mounting and wiring. The fact that >> it is rated for 25 or 35 amps was in no way intended >> to suggest that e-bus loads should/could be >> that large. >> >> The e-bus is a risk reduction feature that is >> not likely to be needed more than once over the >> lifetime of your airplane. It's a feature that >> offers a degrees of System Reliability that >> reduces probability that a main alternator failure >> will cause you to break a sweat. >> >> As a renter, I have never enjoyed access to features >> that we're building into OBAM aircraft. My personal >> endurance package was carried around in the flight >> bag. http://tinyurl.com/d5mrjgh >> >> In fact, I've not turned a VOR receiver on in nearly >> 20 years. Not since I discovered the capabilities >> of hand-held GPS receivers that were so cheap I could >> give them away as door prizes at my seminars! My last >> cross-country sojourns were managed with dual >> GPS receivers stuck between the glare-shield and >> windshield with little wads of windshield sealant. >> >> It didn't matter if the airplane was a J-3 or A-36, >> I was confident in my ability to get from point A to >> Point B whether the ship's electrical system was >> fully functional or not. That's a high degree of >> failure tolerance and system reliability. >> >> >> >> Bob . . . >> >> >> ====**=================== ===========**= >> - >> ric-List" target="_blank">http://www.matronics.com/** >> Navigator?AeroElectric-List >> ====**=================== ===========**= >> MS - >> k">http://forums.matronics.com >> ====**=================== ===========**= >> e - >> -Matt Dralle, List Admin. >> t="_blank">http://www.matronics.com/**contribution >> ====**=================== ===========**= >> >> >> >> > * > =========== =========== =========== =========== > * > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Apr 03, 2013
At 09:41 AM 4/3/2013, you wrote: >Thanks Bob, I have a theoretical max load of a little under 7A. > >I agree with your sentiments about the essential >bus. I don't anticipate needing it... but it's >nice to know that it's there... Very good. No 'extra' heat sinking necessary. Just bolt it to a metallic surface. Bob . . . ________________________________________________________________________________
Date: Apr 03, 2013
Well, that's more tricky. The firewall on this plane (Jodel) is a sandwich of plywood and balsa... so I'm hoping the heatsink will suffice. Worse-case scenario -- I could move the diode to the engine compartment side of the firewall, which is covered with a thin sheet of stainless steel. James On 3 April 2013 17:29, Robert L. Nuckolls, III wrote: > > > At 09:41 AM 4/3/2013, you wrote: >> >> Thanks Bob, I have a theoretical max load of a little under 7A. >> >> I agree with your sentiments about the essential bus. I don't anticipate >> needing it... but it's nice to know that it's there... > > > Very good. No 'extra' heat sinking necessary. > Just bolt it to a metallic surface. > > > Bob . . . > > ________________________________________________________________________________
Date: Apr 03, 2013
Subject: heat treat problem
I've got a project that hit a bit of a snag. I'm building a recovery parachute control system that uses a t-handle to deploy the parachute. I found a really handy size T-handle in McMaster-Carr and proceed with my endeavors. One of the last operations during assembly called for cutting the shaft of the t-handle to length and then drilling a 3/16" hole in the last 1/2". The hole accepts a roll-pin that runs in the slot on a guide collar to set stroke of the handle and to restrain rotation. Emacs! When I cut the shaft with an abrasive cut-off wheel, the it turned out to bet harder than the hubs-of-you-know-what. It's the right length but now I need to drill the hole. No chance with any tools I have. I think I recall that steel can be heated to some pretty ordinary temperatures (less than incandescent) and cooled slowly to remove the heat treat. Strength in this area is very un-critical. I can put a thermocouple on it and heat with a torch. I've browsed some heat-treat documents but the without some time consuming study, no immediate notions of process jumped out. I need to soften this part so that I can drill it with ordinary high-speed drills. Are there any folks on the list with some practical experience in this area? Hoping to deliver this thing tomorrow but it ain't gonna happen without the pin installed. Any suggestions from the List? Bob . . . ________________________________________________________________________________
Date: Apr 03, 2013
Subject: Re: heat treat problem
I don't do a lot of this but if it is carbon steel just heat it up to a nice red color and air cool it. The hardening only occurs if it is shock cooled in oil or water or the attached heat sink is relatively massive. A room temperature slow cool should take out the hardness. A good carbide masonry bit running slow will sometimes go through pretty hard steel. A hardware store cobalt bit is dramatically better than an High Speed Steel bit. Ken > > > I've got a project that hit a bit of a snag. I'm > building a recovery parachute control system that > uses a t-handle to deploy the parachute. I found > a really handy size T-handle in McMaster-Carr > and proceed with my endeavors. > > One of the last operations during assembly called for > cutting the shaft of the t-handle to length and then > drilling a 3/16" hole in the last 1/2". The hole > accepts a roll-pin that runs in the slot on a guide > collar to set stroke of the handle and to restrain > rotation. > > Emacs! > > > When I cut the shaft with an abrasive cut-off wheel, the > it turned out to bet harder than the hubs-of-you-know-what. > It's the right length but now I need to drill the hole. No > chance with any tools I have. > > I think I recall that steel can be heated to some pretty > ordinary temperatures (less than incandescent) and cooled > slowly to remove the heat treat. Strength in this area is > very un-critical. I can put a thermocouple on it and heat > with a torch. I've browsed some heat-treat documents > but the without some time consuming study, no immediate > notions of process jumped out. I need to soften this part > so that I can drill it with ordinary high-speed drills. > > Are there any folks on the list with some practical experience > in this area? Hoping to deliver this thing tomorrow but > it ain't gonna happen without the pin installed. Any > suggestions from the List? > > Bob . . . > ________________________________________________________________________________
Date: Apr 03, 2013
EDM aka Electrical Discharge Machining. Google it for a machine shop that has that capability in your area. EDM easily penetrates any conductive material. Good luck, Bob -------- Jerry King Read this topic online here: http://forums.matronics.com/viewtopic.php?p=397758#397758 ________________________________________________________________________________
Date: Apr 03, 2013
Date: Apr 03, 2013
At 11:45 AM 4/3/2013, you wrote: > >Well, that's more tricky. The firewall on this plane (Jodel) is a >sandwich of plywood and balsa... so I'm hoping the heatsink will >suffice. Worse-case scenario -- I could move the diode to the engine >compartment side of the firewall, which is covered with a thin sheet >of stainless steel. Hmmmm . . . okay. The heat sink you built up from sheet metal will be fine. Don't move it to the other side of the firewall. Bob . . . ________________________________________________________________________________
Date: Apr 03, 2013
Is EDM an option?=0A=0A=0AFrom: "Robert L. Nuckolls, III" <nuckolls.bob@aer oelectric.com>=0ATo: aeroelectric-list(at)matronics.com =0ASent: Wednesday, Ap ril 3, 2013 10:32 AM=0ASubject: AeroElectric-List: heat treat problem=0A=0A =0AI've got a project that hit a bit of a snag. I'm=0Abuilding a recovery p arachute control system that=0Auses a t-handle to deploy the parachute. I f ound=0Aa really handy size T-handle in McMaster-Carr=0Aand proceed with my endeavors.=0A=0AOne of the last operations during assembly called for=0Acut ting the shaft of the t-handle to length and then=0Adrilling a 3/16" hole i n the last 1/2".- The hole=0Aaccepts a roll-pin that runs in the slot on a guide=0Acollar to set stroke of the handle and to restrain=0Arotation.=0A =0A=0A=0AWhen I cut the shaft with an abrasive cut-off wheel, the=0Ait turn ed out to bet harder than the hubs-of-you-know-what.=0AIt's the right lengt h but now I need to drill the hole. No=0Achance with any tools I have.=0A =0AI think I recall that steel can be heated to some pretty=0Aordinary temp eratures (less than incandescent) and cooled=0Aslowly to remove the heat tr eat. Strength in this area is=0Avery un-critical. I can put a thermocouple on it and heat=0Awith a torch. I've browsed some heat-treat documents=0Abut the without some time consuming study, no immediate=0Anotions of process j umped out. I need to soften this part=0Aso that I can drill it with ordinar y high-speed drills.=0A=0AAre there any folks on the list with some practic al experience=0Ain this area? Hoping to deliver this thing tomorrow but=0Ai t ain't gonna happen without the pin installed. Any=0Asuggestions from the List?=0A=0A- Bob . . . ________________________________________________________________________________
Date: Apr 03, 2013
There are many people that will say duh, but there may be a few that will later thank me. I have heard many complain about drilling the stainless firewall and taking an hour and one drill bit per hole. I will share what I learned the hard way. I am able to drill the stainless in less that one minute and not dull a bit. It is all about removing heat from the drill bit and the part you are drilling. If you use a high speed and it doesn't cut it will burn up the bit. In order to remove the heat you need to have chips flying. Aluminum is soft so the 4000rpm air drills we use work fine. The chips are a flying carring the heat away. For harder metals you need to increase the pressure and slow the bit down until the chips fly. It is as easy as that. Slow the drill speed down and increase the pressure until the heat is removed by flying metal chips. Now I have not tried anything too hard since I learned this but I sure have made butter out of the stainless that other people complain about. Mark W ________________________________________________________________________________
Date: Apr 03, 2013
Good Afternoon Bob, Maybe this will jog a few memories. Back when I was in High School (Seventy Years Ago) My shop teacher taught us how to make great hunting knives out of worn out files, We heated them with an acetylene torch to bright red then stuck them into some sort of powder to cool. Once they had cooled they were very easy to grind to the knife shape. We then heated them back up again and quenched them in a light oil to harden the edge. My thought is that the powder we slow cooled them in was ordinary baking flour. Anyone know for sure? I am also fuzzy on just what liquid we used for the quick cool. May have been something other than light oil. All very far back in my faulty memory, but maybe that will jog some one else's memory. Worked like a champ to turn those files in hunting knives. Happy Skies, Old Bob In a message dated 4/3/2013 1:13:38 P.M. Central Daylight Time, nuckolls.bob(at)aeroelectric.com writes: I've got a project that hit a bit of a snag. I'm building a recovery parachute control system that uses a t-handle to deploy the parachute. I found a really handy size T-handle in McMaster-Carr and proceed with my endeavors. One of the last operations during assembly called for cutting the shaft of the t-handle to length and then drilling a 3/16" hole in the last 1/2". The hole accepts a roll-pin that runs in the slot on a guide collar to set stroke of the handle and to restrain rotation. When I cut the shaft with an abrasive cut-off wheel, the it turned out to bet harder than the hubs-of-you-know-what. It's the right length but now I need to drill the hole. No chance with any tools I have. I think I recall that steel can be heated to some pretty ordinary temperatures (less than incandescent) and cooled slowly to remove the heat treat. Strength in this area is very un-critical. I can put a thermocouple on it and heat with a torch. I've browsed some heat-treat documents but the without some time consuming study, no immediate notions of process jumped out. I need to soften this part so that I can drill it with ordinary high-speed drills. Are there any folks on the list with some practical experience in this area? Hoping to deliver this thing tomorrow but it ain't gonna happen without the pin installed. Any suggestions from the List? Bob . . . ________________________________________________________________________________
Date: Apr 03, 2013
Old Bob Probably that far back in our high school days it was sand any how that is what my dad taught me to use when converting the worn out file to something useful Older Dick In a message dated 4/3/2013 1:54:16 P.M. Central Daylight Time, BobsV35B(at)aol.com writes: Good Afternoon Bob, Maybe this will jog a few memories. Back when I was in High School (Seventy Years Ago) My shop teacher taught us how to make great hunting knives out of worn out files, We heated them with an acetylene torch to bright red then stuck them into some sort of powder to cool. Once they had cooled they were very easy to grind to the knife shape. We then heated them back up again and quenched them in a light oil to harden the edge. My thought is that the powder we slow cooled them in was ordinary baking flour. Anyone know for sure? I am also fuzzy on just what liquid we used for the quick cool. May have been something other than light oil. All very far back in my faulty memory, but maybe that will jog some one else's memory. Worked like a champ to turn those files in hunting knives. Happy Skies, Old Bob In a message dated 4/3/2013 1:13:38 P.M. Central Daylight Time, nuckolls.bob(at)aeroelectric.com writes: I've got a project that hit a bit of a snag. I'm building a recovery parachute control system that uses a t-handle to deploy the parachute. I found a really handy size T-handle in McMaster-Carr and proceed with my endeavors. One of the last operations during assembly called for cutting the shaft of the t-handle to length and then drilling a 3/16" hole in the last 1/2". The hole accepts a roll-pin that runs in the slot on a guide collar to set stroke of the handle and to restrain rotation. When I cut the shaft with an abrasive cut-off wheel, the it turned out to bet harder than the hubs-of-you-know-what. It's the right length but now I need to drill the hole. No chance with any tools I have. I think I recall that steel can be heated to some pretty ordinary temperatures (less than incandescent) and cooled slowly to remove the heat treat. Strength in this area is very un-critical. I can put a thermocouple on it and heat with a torch. I've browsed some heat-treat documents but the without some time consuming study, no immediate notions of process jumped out. I need to soften this part so that I can drill it with ordinary high-speed drills. Are there any folks on the list with some practical experience in this area? Hoping to deliver this thing tomorrow but it ain't gonna happen without the pin installed. Any suggestions from the List? Bob . . . ________________________________________________________________________________
Date: Apr 03, 2013
From: "H. Marvin Haught" <handainc(at)madisoncounty.net>
Date: Apr 03, 2013
Bob - If the part is not critical, just heat it up red hot, hold it there for a minute or so, and let it air cool. Here is a fair discussion of the process. http://www.efunda.com/processes/heat_treat/softening/annealing.cfm Alternatively, a very sharp drill bit, turned very slowly will also work with lots of cooling fluid. I set up my drill press for that very purpose (had to drill some spring steel with out having to re-treat it) by installing a secondary motor with small pulley. Liked it so well that way that I just left it set up. Doesn't do well on soft metals, but is not nearly as hard on drill bits, and works for nearly any type of steel. M. Haught On Apr 3, 2013, at 1:51 PM, BobsV35B(at)aol.com wrote: > Good Afternoon Bob, > > Maybe this will jog a few memories. > > Back when I was in High School (Seventy Years Ago) My shop teacher taught us how to make great hunting knives out of worn out files, We heated them with an acetylene torch to bright red then stuck them into some sort of powder to cool. Once they had cooled they were very easy to grind to the knife shape. > > We then heated them back up again and quenched them in a light oil to harden the edge. > > My thought is that the powder we slow cooled them in was ordinary baking flour. Anyone know for sure? > > I am also fuzzy on just what liquid we used for the quick cool. May have been something other than light oil. All very far back in my faulty memory, but maybe that will jog some one else's memory. Worked like a champ to turn those files in hunting knives. > > Happy Skies, > > Old Bob > > In a message dated 4/3/2013 1:13:38 P.M. Central Daylight Time, nuckolls.bob(at)aeroelectric.com writes: > I've got a project that hit a bit of a snag. I'm > building a recovery parachute control system that > uses a t-handle to deploy the parachute. I found > a really handy size T-handle in McMaster-Carr > and proceed with my endeavors. > > One of the last operations during assembly called for > cutting the shaft of the t-handle to length and then > drilling a 3/16" hole in the last 1/2". The hole > accepts a roll-pin that runs in the slot on a guide > collar to set stroke of the handle and to restrain > rotation. > > <1efc966e.jpg> > When I cut the shaft with an abrasive cut-off wheel, the > it turned out to bet harder than the hubs-of-you-know-what. > It's the right length but now I need to drill the hole. No > chance with any tools I have. > > I think I recall that steel can be heated to some pretty > ordinary temperatures (less than incandescent) and cooled > slowly to remove the heat treat. Strength in this area is > very un-critical. I can put a thermocouple on it and heat > with a torch. I've browsed some heat-treat documents > but the without some time consuming study, no immediate > notions of process jumped out. I need to soften this part > so that I can drill it with ordinary high-speed drills. > > Are there any folks on the list with some practical experience > in this area? Hoping to deliver this thing tomorrow but > it ain't gonna happen without the pin installed. Any > suggestions from the List? > > Bob . . . > ________________________________________________________________________________
Date: Apr 03, 2013
Subject: Re: heat treat problem (solved)
Heated to barely incandescent (turned lights out to detect threshold) with Propane torch and then let cool in air. Was delighted to find that my center punch actually made a mark on it! Was able to drill the necessary hole with no difficulty. Bob . . . ________________________________________________________________________________
Date: Apr 03, 2013
From: "wynaire(at)citlink.net" <wynaire(at)citlink.net>
Subject: LED heatsink material?
Hello All,=0AYour thoughts or lessons from experience: =0AI am mounting two (2) each 10Watt LED's (R/G color and -white [6500k] in each wing tip, un der a clear tip lens. The mounting plate (polished for reflectivity) can be copper or SS or aluminum. Which material is the best choice for conducting the LED heat away from the LED's?=0AThanks in advance for your suggestions . Any other bits of related info are also appreciated.=0AMike W.=0ALNC2 360 @ 88% finished... with 88% to go ;)=0A=0AFrom: James Kilford <james@etrave l.org>=0A>To: aeroelectric-list(at)matronics.com =0A>Sent: Wednesday, April 3, 2013 6:31 AM=0A>Subject: Re: AeroElectric-List: Ebus Diode=0A>=0A>=0A>On a related note, is there a way to determine if a heatsink is large enough? - =0A>=0A>=0A>I made a heatsink out of some scrap .020" aluminium -- half a dozen pieces of varying lengths, stacked and folded up at the ends to fo rm fins. -I've bolted it under the rectifier with some heatsink paste. -=0A>=0A>=0A>Seems like quite a lot of aluminium, and plenty of surface a rea, but it would nice to find a way of evaluating its effectiveness... oth er than waiting for the smell of burning semiconductor...=0A>=0A>=0A>Many t hanks,-=0A>=0A>=0A>James=0A>=0A>=0A>=0A>On 2 April 2013 16:38, Robert L. Nuckolls, III wrote:=0A>=0A>At 09:56 AM 4/2 /2013, you wrote:=0A>>=0A>>The drawing http://www.bandc.biz/pdfs/Diode_Inst allation.pdf=0A>>>From B and C shows both ~ (I don't have the correct symbo l horizontal s with -) terminals powered from the main bus with the + going to the Ebus and - unused.=0A>>>=0A>>>Question: I could run power from the main bus to either ~ terminal and power the Ebus?=0A>>>=0A>>>Powering both ~ terminals gains a little redundancy to power the Ebus?=0A>>- No 'redund ancy' just a potential tiny improvement in=0A>>- thermal modeling. Not a big deal one way or another.=0A>>- Run main bus power to either one or bo th AC input=0A>>- terminals, one wire from (+) to e-bus.=0A>>=0A>>- Bob . . .=0A>>=0A>>=0A>>- Bob . . . =0A>>ist" target="_blank">http://www.m atronics.com/Navigator?AeroElectric-Listtp://forums.matronics.com_bla -======================== =========== =0A>=0A> ________________________________________________________________________________
Date: Apr 03, 2013
On 4/3/2013 11:51 AM, BobsV35B(at)aol.com wrote: > the powder we slow cooled them in was ordinary baking flour. Anyone > know for sure? Flour is combustible, and if you generate flour dust, explosive... probably not a good thing to put very hot metal objects into. Paul ________________________________________________________________________________
Date: Apr 03, 2013
From: Henador Titzoff <henador_titzoff(at)yahoo.com>
Subject: Re: LED heatsink material?
Hello Mike W.,=0A=0AThe short answer is copper.- This is evidenced by eac h material's thermal conductivity, shown below in SI units:=0A=0A--- - Copper - 401 Watt/(meter x Kelvin)=0A---- Aluminum - 237 Watt/( meter x Kelvin)=0A---- Stainless steel - 16.7 Watt/(meter x Kelvin) =0A=0A=0AThe above data came from: http://en.wikipedia.org/wiki/List_of_the rmal_conductivities=0A=0AThermal conductivity is the property of a material to conduct heat. As you can see, copper conducts heat 1.7 times better tha n aluminum and 24 times better than a certain type of stainless steel. Ther e are other things to consider but since your mounting plate is your reflec tor and you are stuck with its dimensions, form factor and coating.- If y ou are looking for the best conductor, copper is the choice.- This also a ssumes that you are not concerned with weight or corrosion.=0A=0A-=0AHena dor Titzoff=0A=0A=0A=0A________________________________=0A From: "wynaire@c itlink.net" =0ATo: "aeroelectric-list(at)matronics.com" < aeroelectric-list(at)matronics.com> =0ASent: Wednesday, April 3, 2013 4:43 PM =0ASubject: AeroElectric-List: LED heatsink material?=0A =0A=0AHello All, =0AYour thoughts or lessons from experience: =0AI am mounting two (2) each 10Watt LED's (R/G color and -white [6500k] in each wing tip, under a clea r tip lens. The mounting plate (polished for reflectivity) can be copper or SS or aluminum. Which material is the best choice for conducting the LED h eat away from the LED's?=0AThanks in advance for your suggestions. Any othe r bits of related info are also appreciated.=0AMike W.=0ALNC2 360 @ 88% fin ished... with 88% to go ;)=0A=0A=0AFrom: James Kilford <james(at)etravel.org> =0A>To: aeroelectric-list(at)matronics.com =0A>Sent: Wednesday, April 3, 2013 6:31 AM=0A>Subject: Re: AeroElectric-List: Ebus Diode=0A>=0A>=0A>On a relat ed note, is there a way to determine if a heatsink is large enough? - =0A >=0A>=0A>I made a heatsink out of some scrap .020" aluminium -- half a doze n pieces of varying lengths, stacked and folded up at the ends to form fins . -I've bolted it under the rectifier with some heatsink paste. -=0A> =0A>=0A>Seems like quite a lot of aluminium, and plenty of surface area, bu t it would nice to find a way of evaluating its effectiveness... other than waiting for the smell of burning semiconductor...=0A>=0A>=0A>Many thanks, -=0A>=0A>=0A>James=0A>=0A>=0A>=0A>On 2 April 2013 16:38, Robert L. Nuckol ls, III wrote:=0A>=0A>At 09:56 AM 4/2/2013, you wrote:=0A>>=0A>>The drawing http://www.bandc.biz/pdfs/Diode_Installati on.pdf=0A>>>From B and C shows both ~ (I don't have the correct symbol hori zontal s with -) terminals powered from the main bus with the + going to th e Ebus and - unused.=0A>>>=0A>>>Question: I could run power from the main b us to either ~ terminal and power the Ebus?=0A>>>=0A>>>Powering both ~ term inals gains a little redundancy to power the Ebus?=0A>>- No 'redundancy' just a potential tiny improvement in=0A>>- thermal modeling. Not a big de al one way or another.=0A>>- Run main bus power to either one or both AC input=0A>>- terminals, one wire from (+) to e-bus.=0A>>=0A>>- Bob . . . =0A>>=0A>> =0A>>- Bob . . . =0A>>ist" target="_blank">http://www.matron ics.com/Navigator?AeroElectric-List=0Atp://forums.matronics.com=0A_blank">h -======================== =========== ________________________________________________________________________________
Date: Apr 03, 2013
Copper is best, then Aluminum then Steel. Dick Tasker wynaire(at)citlink.net wrote: > Hello All, > Your thoughts or lessons from experience: > I am mounting two (2) each 10Watt LED's (R/G color and white [6500k] in each wing tip, under a clear tip lens. The > mounting plate (polished for reflectivity) can be copper or SS or aluminum. Which material is the best choice for > conducting the LED heat away from the LED's? > Thanks in advance for your suggestions. Any other bits of related info are also appreciated. > Mike W. > LNC2 360 @ 88% finished... with 88% to go ;) ________________________________________________________________________________
Date: Apr 03, 2013
Subject: Opinion on fuse block
Bob, Do you have any opinion on a fuse block with a built-in "forest of ground tabs" such as this one? http://www.starmarinedepot.com/Sierra+Fuse+Block+ATO-ATC+14+Gangs.html?gclid=CKSR4vDDr7YCFQUHnQodHBAAMA Ed Godfrey 40717 ________________________________________________________________________________
Date: Apr 03, 2013
Date: Apr 03, 2013
At 02:35 PM 4/3/2013, you wrote: >Bob - > >If the part is not critical, just heat it up red hot, hold it there >for a minute or so, and let it air cool. Here is a fair discussion >of the process. ><http://www.efunda.com/processes/heat_treat/softening/annealing.cfm>http://www.efunda.com/processes/heat_treat/softening/annealing.cfm Essentially that's what I did. >Alternatively, a very sharp drill bit, turned very slowly will also >work with lots of cooling fluid. I set up my drill press for that >very purpose (had to drill some spring steel with out having to >re-treat it) by installing a secondary motor with small >pulley. Liked it so well that way that I just left it set >up. Doesn't do well on soft metals, but is not nearly as hard on >drill bits, and works for nearly any type of steel. I tried that earlier but the stuff was so hard my center punch wouldn't even mark it! Couldn't get a bit to set still in one spot long enough to remove any material. Softening it up worked great. Bob . . . ________________________________________________________________________________
Date: Apr 03, 2013
Based on the old articles I've read about heat treating and tempering it could have been sifted wood ash,or asbestos. Just things I've read about people using. It was probably oil you dipped in to quench. Raymond Julian Kettle River, MN. "And you know that I could have me a million more friends, and all I'd have to lose is my point of view." - John Prine On 04/03/2013 01:51 PM, BobsV35B(at)aol.com wrote: > Good Afternoon Bob, > Maybe this will jog a few memories. > Back when I was in High School (Seventy Years Ago) My shop teacher > taught us how to make great hunting knives out of worn out files, We > heated them with an acetylene torch to bright red then stuck them into > some sort of powder to cool. Once they had cooled they were very easy > to grind to the knife shape. > We then heated them back up again and quenched them in a light oil to > harden the edge. > My thought is that the powder we slow cooled them in was ordinary > baking flour. Anyone know for sure? > I am also fuzzy on just what liquid we used for the quick cool. May > have been something other than light oil. All very far back in my > faulty memory, but maybe that will jog some one else's memory. Worked > like a champ to turn those files in hunting knives. > Happy Skies, > Old Bob > In a message dated 4/3/2013 1:13:38 P.M. Central Daylight Time, > nuckolls.bob(at)aeroelectric.com writes: > > I've got a project that hit a bit of a snag. I'm > building a recovery parachute control system that > uses a t-handle to deploy the parachute. I found > a really handy size T-handle in McMaster-Carr > and proceed with my endeavors. > > One of the last operations during assembly called for > cutting the shaft of the t-handle to length and then > drilling a 3/16" hole in the last 1/2". The hole > accepts a roll-pin that runs in the slot on a guide > collar to set stroke of the handle and to restrain > rotation. > Image removed > > When I cut the shaft with an abrasive cut-off wheel, the > it turned out to bet harder than the hubs-of-you-know-what. > It's the right length but now I need to drill the hole. No > chance with any tools I have. > > I think I recall that steel can be heated to some pretty > ordinary temperatures (less than incandescent) and cooled > slowly to remove the heat treat. Strength in this area is > very un-critical. I can put a thermocouple on it and heat > with a torch. I've browsed some heat-treat documents > but the without some time consuming study, no immediate > notions of process jumped out. I need to soften this part > so that I can drill it with ordinary high-speed drills. > > Are there any folks on the list with some practical experience > in this area? Hoping to deliver this thing tomorrow but > it ain't gonna happen without the pin installed. Any > suggestions from the List? > > Bob . . . > ________________________________________________________________________________
Date: Apr 03, 2013
Subject: Re: Opinion on fuse block
At 05:22 PM 4/3/2013, you wrote: > >Bob, > Do you have any opinion on a fuse block with a built-in "forest > of ground tabs" such as this one? > >http://www.starmarinedepot.com/Sierra+Fuse+Block+ATO-ATC+14+Gangs.html?gclid=CKSR4vDDr7YCFQUHnQodHBAAMA > >Ed Godfrey >40717 Yeah, I looked at those when I started selling the fuse blocks. It SEEMS like a good idea. So do switch/breakers. It's a matter of architecture. Do you WANT your single point ground to be right next to the bus, or does it fit better elsewhere? Also, the products I has available to me then offered fewer grounds that bus feeders. In my experience you need about 1.5 times more grounds than feeders. Same thing with switch/breakers. The notion of combining control and protection functions into a single device FORCES some portion of the bus structure to be located right behind the panel. It can also make for some interesting looking bus structures when the switches located for human factors reasons don't lend themselves to being grouped with their respective busses. I think the fuse block, toggle switch and forest of tabs ground block as separate products gives the builder a low cost, minimum parts count, architecturally elegant solution to doing the best we know how to do. Bob . . . ________________________________________________________________________________
From: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net>
Subject: RE: Ebus Diode
Date: Apr 03, 2013
If you want true redundancy then just use two rectifiers in parallel. When I built my panel I ended up with a full IFR radio stack on the Ebus and some other items that, together, take quite a bit of current. Not wanting to risk over-taxing the single rectifier or reduce its life by running it near maximum all the time, I simply installed a second one in parallel with the first. I also mounted them to 1/16 inch thick aluminum brackets fastened to the bulkhead behind the instrument panel to keep them as cool as possible. Probably overkill but, so far so good. Dean Psiropoulos RV-6A N197DM -----Original Message----- From: "The Kuffels" <kuffel(at)cyberport.net> Subject: Ebus Diode Andy, << Question: I could run power from the main bus to either ~ terminal and power the Ebus? >> Yes, but this misses the purpose of connecting both AC terminals (~) to the source. The package has 4 diodes. It is used everywhere as an AC to DC rectifier. In theory you could use one high current diode but the cost of the same capacity is much higher than the 4 diode package due to the very high economy of scale from the 4 diode configuration even though we are "wasting" diodes. The mounting for this package is also simpler. The main enemy of semiconductors is heat. With the connection to two divides in parallel the current between them is divided, not evenly divided but still shared between the two. This spreads out the heat generation which makes the device more robust. << Powering both ~ terminals gains a little redundancy to power the Ebus? >> As is hopefully explained above, the reason for using both ~ terminals is spreading out the heat generation, not redundancy. If you have an Ebus current of 15 amps, even if one diode carries 10 amps and the other only 5 amps, you are stressing the part less than having all 15 amps going through 1 diode. In other words, there is a good reason for connecting the source to both ~ terminals which is what you should do. Tom Kuffel ________________________________________________________________________________
Date: Apr 03, 2013
Bob, Thanks for the tip on heat treating and details... Dave _____________________________________________________ ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Sent: Wednesday, April 03, 2013 1:11 PM Subject: Re: AeroElectric-List: heat treat problem (solved) > > > Heated to barely incandescent (turned lights out > to detect threshold) with Propane torch and then > let cool in air. > > Was delighted to find that my center punch actually > made a mark on it! Was able to drill the necessary > hole with no difficulty. > > > Bob . . . > > > ________________________________________________________________________________
Date: Apr 04, 2013
I've been selling these for a decade. My newest version can be used as two parallel, a Y-configuration or just a big diode. Heatsink included. See attached. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=397835#397835 Attachments: http://forums.matronics.com//files/power_deuce_schottky_manual_200.pdf ________________________________________________________________________________
Date: Apr 04, 2013
> Seems like quite a lot of aluminium, and plenty of surface area, but it would nice to find a way of evaluating its effectiveness... other than waiting for the smell of burning semiconductor... Tape this into your toolbox. These are for surfaces touched with a non-calloused finger, not ambients. Cool: 100 degC You can estimate between these numbers quite well. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=397842#397842 ________________________________________________________________________________
Date: Apr 04, 2013
Subject: Re: RE: Ebus Diode
At 08:25 PM 4/3/2013, you wrote: > > >If you want true redundancy then just use two rectifiers in parallel. Actually, if you want redundancy for a failed diode, you would want to wire them in series. Diodes generally fail shorted. So having a good diode in parallel would a bad one would not mitigate the failure. But of course, diodes in series doubles the voltage drop and that's not high on our list of design goals. As long as they're adequately heat-sinked, the diode will outlast the airplane. If not heat adequately sinked, life expectancy is short. The first 'crowbar' ov protection system to go into a TC aircraft can be found on the AA-1 Yankee. Alternator field was supplied through a 3 or 5 amp glass cartridge fuse. I don't recall which right now. Downstream of the fuse they wired a 15 volt, 1-watt, glass zener to ground. In an ov condition, the zener was driven into destructive conduction, it's junction melted and shorted the field supply downstream of the fuse. Crude but it did work . . . with limitations. I ran some tests on this configuration at Electro-Mech after an OEM engineer asked me about it . . . I think it was a guy at Mooney. Sure 'nuf. Fault the regulator, bus votlage jumps, zener discolors and turns black, fuse pops, event over. MUCH slower than legacy OV protection systems that operate in tens of milliseconds . . . but certainly better than no OV protection. I heard of variations on the theme that proved unsatisfactory . . . like replacing the fast-fuse with a slow-blow. Or replacing the zener with its plastic cousin. Plastic zeners and diodes like to blow apart when fused. There was an alternator supplier at OSH one year who advertised "built in OV protection". Some guy came by the B&C booth to tell me about it . . . he was skeptical. I walked over to see what was being offered. Without introducing myself I asked the vendor to tell me all about it. It pointed to a plastic, 1-w zener wired across the alternator's B-terminal to ground. I took some literature and thanked him for the info. Some time later, somebody on the Compuserve AVSIG forum was asking about this same product. He said his alternator went bad and his OV protection 'disappeared' without having done it's job. Upon further inquiry, he said the little wires were still there . . . just the black plastic part was gone. This was an internally regulated alternator and could not be easily fitted with OV protection. Certainly the little glob of plastic was not up to the task. Bob . . . ________________________________________________________________________________
From: "Roger & Jean" <mrspudandcompany(at)verizon.net>
Subject: Re: Ebus Diode
Date: Apr 04, 2013
> I've been selling these for a decade. My newest version can be used as two > parallel, a Y-configuration or just a big diode. Heatsink included. See > attached. > > -------- > Eric M. Jones Eric, In looking at your attached diagram, it is my assumption that you are using the diodes to supply power to critical for flight devices. My thought is that you would be much better off using 2 fuel pumps and 2 ECU's each running through their own switches to separate batteries and eliminate the diodes. This is a little more costly but my thinking is that it will increase your safety factor by an order of magnitude. Am I wrong on this approach? Roger ________________________________________________________________________________
Date: Apr 04, 2013
Bob, Is the DIM5-14 the same item as in your drawing and can be modified for dimming the led strip lights by replacing resistors as you suggest? Ed Holyoke On 4/2/2013 12:12 PM, Robert L. Nuckolls, III wrote: > If your airplane has a glare shield, you can > consider the used of LED strip lights similar > to these. > > http://tinyurl.com/c3wozbj > > These strips are assembled from an array > of LED trios in series fitted with the appropriate > series resistor to provide max illumination with > 12vdc applied. Each trio occupies about 2" of > length. > > Three white lights in series do not begin to > output until applied voltage rises to 7.5 volts > or so. At 12 volts, each group of 3 lamps > (about 2" in length) draws about 25 milliamps. > > Assume you need 36" of strip to stretch > across the glare shield (18 trios). You'll > need a dimmer control capable of carrying > 18 x .025 or 0.45 amps. This relatively > low current draw makes the noise-free, linear > regulators more attractive. Referring to this > drawing > > http://tinyurl.com/ccrpzfa > > You see the architecture for a dimmer set up for > incandescent lamps. I.e. 4.5 volts minimum. For service > with these strips, the minimum needs to be raised to > 7.5 volts. Further, we want to fix the adjustment > range at 7.5 - 12v or a delta-V of 3.5 volts. > > Since our stock "pot" is 2.5K, then to get 3.5 > volts dropped across the pot at max resistance, > we need a divider current of 3.5/2500 or 1.4 milliamps. > > The voltage across the upper resistor is fixed at > 1.25 volts by internal characteristics of the > 317 regulator. 1.25V/0.0014A = 892 (910 ohms > is close enough and a standard 5% value). > > Okay, with the pot at min resistance, we need > 7.5 volts total output. (7.5 - 1.25)/0.0014 > equals 4464 ohms (4700 is also a standard > value and sufficiently close). > > So, if you'd care to build your own dimmer the > 390 ohm resistor is replaced with a 910 ohm > resistor; the 910 ohm resistor is replaced with > a 4700 ohm resistor. The TO220 plastic package > version of the LM317 on a modicum of heatsink > would be 'fat' enough and entirely free of noise. > > That 15-foot chunk of strip lighting for $20 is > delivered toyour door at that price and is probably > enough lighting to do 5 airplanes. I've copied B&C > on this posting to see if they'd be interested in > offering an LED strip light version of their DIM5-14 > product. > > http://tinyurl.com/dylkufj > > Bob . . . > > * > > > * ________________________________________________________________________________
Date: Apr 04, 2013
Subject: Re: LED strip lighting for panels
FWIW: There are Ebay sites {China} now offering inexpensive LED dimmers, fo r stirp lighting.-One is one it's way here. If it smokes, I-will post t he peticulars. As always, thanks for your advice.-=0AMike W.=0APS: Now lo oking for an "inexpensive" CS prop governor for a Lyc IO-360 AV. Anyone bui lding one in his -shop? ;))=0A***********=0A=0AFrom: Ed Holyoke <bicyclop (at)pacbell.net>=0A>To: aeroelectric-list(at)matronics.com =0A>Sent: Thursday, Ap ril 4, 2013 1:29 PM=0A>Subject: Re: AeroElectric-List: LED strip lighting f or panels=0A>=0A>=0A>Bob,=0A>=0A>Is the DIM5-14 the same item as in your dr awing and can be modified for dimming the led strip lights by replacing res istors as you suggest?=0A>=0A>Ed Holyoke=0A>=0A>On 4/2/2013 12:12 PM, Rober t L. Nuckolls, III wrote: =0A>If your airplane has a glare shield, you can =0A>>consider the used of LED strip lights similar=0A>>to these.=0A>>=0A>>h ttp://tinyurl.com/c3wozbj=0A>>=0A>>These strips are assembled from an array =0A>>of LED trios in series fitted with the appropriate=0A>>series resistor to provide max illumination with=0A>>12vdc applied. Each trio occupies abo ut 2" of=0A>>length.=0A>>=0A>>Three white lights in series do not begin to =0A>>output until applied voltage rises to 7.5 volts=0A>>or so.- At 12 vo lts, each group of 3 lamps=0A>>(about 2" in length) draws about 25 milliamp s.=0A>>=0A>>Assume you need 36" of strip to stretch=0A>>across the glare sh ield (18 trios). You'll=0A>>need a dimmer control capable of carrying=0A>>1 8 x .025 or 0.45 amps. This relatively=0A>>low current draw makes the noise -free, linear=0A>>regulators more attractive. Referring to this=0A>>drawing =0A>>=0A>>http://tinyurl.com/ccrpzfa=0A>>=0A>>You see the architecture for a dimmer set up for=0A>>incandescent lamps. I.e. 4.5 volts minimum. For ser vice=0A>>with these strips, the minimum needs to be raised to=0A>>7.5 volts . Further, we want to fix the adjustment=0A>>range at 7.5 - 12v or a delta- V of 3.5 volts.=0A>>=0A>>Since our stock "pot" is 2.5K, then to get 3.5=0A> >volts dropped across the pot at max resistance,=0A>>we need a divider curr ent of 3.5/2500 or 1.4 milliamps.=0A>>=0A>>The voltage across the upper res istor is fixed at=0A>>1.25 volts by internal characteristics of the=0A>>317 regulator. 1.25V/0.0014A = 892 (910 ohms=0A>>is close enough and a stand ard 5% value).=0A>>=0A>>Okay, with the pot at min resistance, we need=0A>>7 .5 volts total output. (7.5 - 1.25)/0.0014=0A>>equals 4464 ohms (4700 is al so a standard=0A>>value and sufficiently close).=0A>>=0A>>So, if you'd care to build your own dimmer the=0A>>390 ohm resistor is replaced with a 910 o hm=0A>>resistor; the 910 ohm resistor is replaced with=0A>>a 4700 ohm resis tor. The TO220 plastic package=0A>>version of the LM317 on a modicum of hea tsink=0A>>would be 'fat' enough and entirely free of noise.=0A>>=0A>>That 1 5-foot chunk of strip lighting for $20 is=0A>>delivered toyour door at that price and is probably=0A>>enough lighting to do 5 airplanes. I've copied B &C=0A>>on this posting to see if they'd be interested in=0A>>offering an LE D strip light version of their DIM5-14=0A>>product.=0A>>=0A>>http://tinyurl ========= =0A>=0A> ________________________________________________________________________________
From: Holger Selover-Stephan <holger-d(at)shadowbrush.com>
Date: Apr 04, 2013
I have two of those $6 dimmers on order also. Others have already reported success using them in the RV forum. Holger On Apr 4, 2013, at 10:14 PM, wynaire(at)citlink.net wrote: > FWIW: There are Ebay sites {China} now offering inexpensive LED dimmers, for stirp lighting. One is one it's way here. If it smokes, I will post the peticulars. As always, thanks for your advice. > Mike W. > PS: Now looking for an "inexpensive" CS prop governor for a Lyc IO-360 AV. Anyone building one in his shop? ;)) > *********** ________________________________________________________________________________
Date: Apr 04, 2013
This is what was recommended by other builders, Kick KR6 $15-$20 on ebay. I haven't "fired" it up yet....=0Ahttp://www.kicklighting.com/Kick-Lighting- KR6.pdf=0A=0A=0A________________________________=0AFrom: "wynaire(at)citlink.n et" =0ATo: "aeroelectric-list(at)matronics.com" =0ASent: Thursday, April 4, 2013 3:14 PM=0ASubject : Re: AeroElectric-List: LED strip lighting for panels=0A=0A=0AFWIW: There are Ebay sites {China} now offering inexpensive LED dimmers, for stirp ligh ting.-One is one it's way here. If it smokes, I-will post the peticular s. As always, thanks for your advice.-=0AMike W.=0APS: Now looking for an "inexpensive" CS prop governor for a Lyc IO-360 AV. Anyone building one in his -shop? ;))=0A***********=0A=0A=0A=0A>_______________________________ _=0A>From: Ed Holyoke <bicyclop(at)pacbell.net>=0A>To: aeroelectric-list@matro nics.com =0A>Sent: Thursday, April 4, 2013 1:29 PM=0A>Subject: Re: AeroElec tric-List: LED strip lighting for panels=0A>=0A>=0A>Bob,=0A>=0A>Is the DIM5 -14 the same item as in your drawing and can be modified for dimming the le d strip lights by replacing resistors as you suggest?=0A>=0A>Ed Holyoke=0A> =0A>On 4/2/2013 12:12 PM, Robert L. Nuckolls, III wrote: =0A>If your airpla ne has a glare shield, you can=0A>>consider the used of LED strip lights si milar=0A>>to these.=0A>>=0A>>http://tinyurl.com/c3wozbj=0A>>=0A>>These stri ps are assembled from an array=0A>>of LED trios in series fitted with the a ppropriate=0A>>series resistor to provide max illumination with=0A>>12vdc a pplied. Each trio occupies about 2" of=0A>>length.=0A>>=0A>>Three white lig hts in series do not begin to=0A>>output until applied voltage rises to 7.5 volts=0A>>or so.- At 12 volts, each group of 3 lamps=0A>>(about 2" in le ngth) draws about 25 milliamps.=0A>>=0A>>Assume you need 36" of strip to st retch=0A>>across the glare shield (18 trios). You'll=0A>>need a dimmer cont rol capable of carrying=0A>>18 x .025 or 0.45 amps. This relatively=0A>>low current draw makes the noise-free, linear=0A>>regulators more attractive. Referring to this=0A>>drawing=0A>>=0A>>http://tinyurl.com/ccrpzfa=0A>>=0A>> You see the architecture for a dimmer set up for=0A>>incandescent lamps. I. e. 4.5 volts minimum. For service=0A>>with these strips, the minimum needs to be raised to=0A>>7.5 volts. Further, we want to fix the adjustment=0A>>r ange at 7.5 - 12v or a delta-V of 3.5 volts.=0A>>=0A>>Since our stock "pot" is 2.5K, then to get 3.5=0A>>volts dropped across the pot at max resistanc e,=0A>>we need a divider current of 3.5/2500 or 1.4 milliamps.=0A>>=0A>>The voltage across the upper resistor is fixed at=0A>>1.25 volts by internal c haracteristics of the=0A>>317 regulator. 1.25V/0.0014A = 892 (910 ohms=0A >>is close enough and a standard 5% value).=0A>>=0A>>Okay, with the pot at min resistance, we need=0A>>7.5 volts total output. (7.5 - 1.25)/0.0014=0A> >equals 4464 ohms (4700 is also a standard=0A>>value and sufficiently close ).=0A>>=0A>>So, if you'd care to build your own dimmer the=0A>>390 ohm resi stor is replaced with a 910 ohm=0A>>resistor; the 910 ohm resistor is repla ced with=0A>>a 4700 ohm resistor. The TO220 plastic package=0A>>version of the LM317 on a modicum of heatsink=0A>>would be 'fat' enough and entirely f ree of noise.=0A>>=0A>>That 15-foot chunk of strip lighting for $20 is=0A>> delivered toyour door at that price and is probably=0A>>enough lighting to do 5 airplanes. I've copied B&C=0A>>on this posting to see if they'd be int erested in=0A>>offering an LED strip light version of their DIM5-14=0A>>pro duct.=0A>>=0A>>http://tinyurl.com/dylkufj=0A>>=0A>>=0A>>- Bob . . . =0A> ===================== ________________________________________________________________________________
Subject: Dolphin Electrical Wire Connectors
Date: Apr 05, 2013
4/5/2013 Hello Again Bob Nuckolls, I am still hoping for some response from you to my posting copied below. Thanks, =98OC=99 Baker === 4/1/2013 Hello Bob Nuckolls, It has been suggested that I use these Dolphin DC-100- P or -S insulation piercing type electrical wire connectors for low amperage wire connection usage, such as a Ray Allen trim servo, in my experimental amateur built airplane: http://dolphincomponents.com/catalogs/Section%20A%20-%20Super%20B%20stand ard-3207.pdf What do you think? Thank you. Owen C. Baker PS: This is not intended as an April Fools Day joke. ________________________________________________________________________________
Date: Apr 05, 2013
Hi Eric, I'm missing something I think... Is there some more to be sent? Many thanks, James On 4 April 2013 14:15, Eric M. Jones wrote: > > >> Seems like quite a lot of aluminium, and plenty of surface area, but it would nice to find a way of evaluating its effectiveness... other than waiting for the smell of burning semiconductor... > > > Tape this into your toolbox. These are for surfaces touched with a non-calloused finger, not ambients. > > Cool: 100 degC > > You can estimate between these numbers quite well. > > -------- > Eric M. Jones > www.PerihelionDesign.com > 113 Brentwood Drive > Southbridge, MA 01550 > (508) 764-2072 > emjones(at)charter.net > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=397842#397842 > > ________________________________________________________________________________
Date: Apr 05, 2013
What Eric Jonez is saying, James, is to use your calibrated finger to deter mine if the heat sink is working. If you can touch the component without bu rning your finger, it's most likely okay. This must be done during a real t est where the Essential Bus is loaded to its max. Wait for the current to h eat the junction and stabilize the temp, meaning that it's reached a maximu m temperature because heat is flowing from it to ambient air through severa l interfaces such as junction to leads and case, case to heat sink, and hea t sink to air.=0A=0AYou could instrument the diode case to get a more accur ate reading, but a calibrated finger is almost good enough.- If it burns the hell out of you, then maybe you need a bigger heat sink.=0A=0A-=0AHen ador Titzoff=0A=0A=0A________________________________=0A From: James Kilfor d =0ATo: aeroelectric-list(at)matronics.com =0ASent: Friday , April 5, 2013 8:09 AM=0ASubject: Re: AeroElectric-List: Re: LED heatsink es(at)etravel.org>=0A=0AHi Eric,=0A=0AI'm missing something I think...- Is t here some more to be sent?=0A=0AMany thanks,=0A=0AJames=0A=0A=0AOn 4 April 2013 14:15, Eric M. Jones wrote:=0A> --> AeroElectric -List message posted by: "Eric M. Jones" =0A>=0A>=0A>> Seems like quite a lot of aluminium, and plenty of surface area, but it wo uld nice to find a way of evaluating its effectiveness... other than waitin g for the smell of burning semiconductor...=0A>=0A>=0A> Tape this into your toolbox. These are for surfaces touched with a non-calloused finger, not a mbients.=0A>=0A> Cool: 100 degC=0A>=0A> You can estimate between these numb ers quite well.=0A>=0A> --------=0A> Eric M. Jones=0A> www.PerihelionDesign .com=0A> 113 Brentwood Drive=0A> Southbridge, MA 01550=0A> (508) 764-2072 =0A> emjones(at)charter.net=0A>=0A>=0A>=0A>=0A> Read this topic online here :=0A>=0A> http://forums.matronics.com/viewtopic.php?p=397842#397842=0A> - - - - - - - - - - - - - - -Matt Dralle, List ====== ________________________________________________________________________________
Date: Apr 05, 2013
> Tape this into your toolbox. These are for surfaces touched with a non-calloused finger, not ambients. > > Cool: 100 degC > > You can estimate between these numbers quite well. There was some sort of error in this posting which involved the "more than" and "less than" symbols. I tried to delete it but it got through anyway. Here it is again (without the symbols): Tape this into your toolbox. These are for metal surfaces touched with a non-calloused finger, not ambients. Cool: 30 degC Warm: 40 degC Uncomfortably Hot: 50 degC As hot as you can touch: 60 degC Immediately painful: 70 degC Will blister skin: 100 degC You can estimate between these numbers quite well. Matt: If you can delete the previous post I'd appreciate it. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=397893#397893 ________________________________________________________________________________
Date: Apr 05, 2013
Wow! That's another amazing bit of information. Thanks Eric! I'm guessing that HTML formatting hid the middle bit of content with the less than and greater than signs. Did it originally say: "Cool less than 30C" and "Will blister skin greater than 100C"? Thanks again. James On 5 April 2013 14:07, Eric M. Jones wrote: > > >> Tape this into your toolbox. These are for surfaces touched with a non-calloused finger, not ambients. >> >> Cool: 100 degC >> >> You can estimate between these numbers quite well. > > > There was some sort of error in this posting which involved the "more than" and "less than" symbols. I tried to delete it but it got through anyway. Here it is again (without the symbols): > > Tape this into your toolbox. These are for metal surfaces touched with a non-calloused finger, not ambients. > > Cool: 30 degC > Warm: 40 degC > Uncomfortably Hot: 50 degC > As hot as you can touch: 60 degC > Immediately painful: 70 degC > Will blister skin: 100 degC > > You can estimate between these numbers quite well. > > Matt: If you can delete the previous post I'd appreciate it. > > -------- > Eric M. Jones > www.PerihelionDesign.com > 113 Brentwood Drive > Southbridge, MA 01550 > (508) 764-2072 > emjones(at)charter.net > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=397893#397893 > > ________________________________________________________________________________
Subject: Re: Dolphin Electrical Wire Connectors
Date: Apr 05, 2013
Owen, As someone else stated, the Dolphin DC-100 connectors are intended for use i n telephone and alarm system wiring. They are suitable for use only with sm all diameter solid wire, and are totally unsuitable for aircraft wiring. Al so, they're smaller than they appear in the manufacturer's photos; I'd be su rprised if you could get two wires of more than 22-gauge into them. I used the exact connectors you're looking at when I installed the alarm sys tem in my home. I used about 80-90 of the things, and had to remove and rea pply about half a dozen because they didn't make a connection on the first t ry. Not the kind of reliability we need in aircraft wiring (and very annoyi ng when working in an attic, in Phoenix, in June!). I would stick with M22759/16 wire in a gauge appropriate for the load being s erved, stripped with a quality stripper like the Ideal Stripmaster, and with terminations made using PIDG crimp connectors and a quality full-cycle ratc heting crimper. That's what's been proven to work. Cheers, Eric On Apr 5, 2013, at 4:52 AM, "Owen Baker " wrote: > > Hello Again Bob Nuckolls, I am still hoping for some response from you to m y posting copied below. > > Thanks, > > =98OC=99 Baker > > ========================= === > > 4/1/2013 > > Hello Bob Nuckolls, It has been suggested that I use these Dolphin DC-100- P or -S insulation piercing type electrical wire connectors for low amperage wire connection usage, such as a Ray Allen trim servo, in my experimental a mateur built airplane: > > http://dolphincomponents.com/catalogs/Section%20A%20-%20Super%20B%20standa rd-3207.pdf > > What do you think? Thank you. > > Owen C. Baker > > PS: This is not intended as an April Fools Day joke. ________________________________________________________________________________
Date: Apr 05, 2013
Subject: Diagnostic Help Please: Audio is Weak and Scratchy
I've been testing my audio system and have encountered poor performance. Does anyone have any suggestions for what to check? Here is the problem: All audio through the headsets is too quiet, and pretty scratchy. This applies to radio reception, intercom audio, Dynon voice out, and music input. With the intercom volume, headset volume, and individual device volume all the way up, the total volume is about where I would want to have it with 25% volume selected instead. The issue seems to afflict each of the various inputs to a similar degree. Here is the setup: New construction, wired by me (a non-professional, so anything is possible) The airframe is a steel tube 4-place fuselage with the mic and audio headset jacks isolated from ground, as verified by voltmeter continuity checks. I used shielded cables to connect the intercom and the mic and stereo phone jacks, with the shields connected at intercom end to each other and not connected to anything at the jacks. I have a self-assembled AEC 9009 Audio Iso Amp handling VHF nav audio on one channel, dynon warnings on one channel, left music in on one channel, and right music in on one channel, with the 9009's output going into the intercom aux input The intercom is a Flightcom 403, with the pilot wires going to the left front seat, copilot wires to the right front seat, and passenger jacks to the back two seats. The GNS430 is the only radio, with com audio routed directly to the intercom per the intercom directions. I'm testing with two known-good David Clark headsets (one stereo, one mono) and one brand new Lightspeed headset, all with freshly buffed, shiny connectors. I'm using battery power only, since the engine is not installed presently. I've tried the battery by itself and the battery with the charger connected. The voltage range is about 13v to 14v for those two cases, but I can't see that changing from one to the other makes any difference in the audio system issues. Here is what I have tried so far with no improvements: First, I unplugged aec9009. I lost the channels that run through it, but the remaining intercom and VHF com audio were still the same. Then I swapped intercom for the bypass plug that I built per the intercom manual. this plug is designed to connect the pilot seat jacks directly to the radio, so that the airplane can still function as a single-place if the intercom is removed entirely. As with the 9009, I lose intercom function in this configuration (as I should), but the vhf com audio is still weak and scratchy. I tried changing the Headsets around in various combinations to various seats with no appreciable change. I changed out the volume resistors in the AEC9009 to increase the volume of those channels, and the volume did go up on the channel in question, but the quality really suffered. I'm not really sure what to try next. Does anyone have any suggestions for what to check? ________________________________________________________________________________
Date: Apr 05, 2013
Subject: Re: Diagnostic Help Please: Audio is Weak and Scratchy
On 04/05/2013 03:40 PM, Jared Yates wrote: > > I've been testing my audio system and have encountered poor > performance. Does anyone have any suggestions for what to check? > Here is the problem: > > All audio through the headsets is too quiet, and pretty scratchy. This > applies to radio reception, intercom audio, Dynon voice out, and music > input. With the intercom volume, headset volume, and individual device > volume all the way up, the total volume is about where I would want to > have it with 25% volume selected instead. The issue seems to afflict > each of the various inputs to a similar degree. > > Here is the setup: > New construction, wired by me (a non-professional, so anything is possible) > The airframe is a steel tube 4-place fuselage with the mic and audio > headset jacks isolated from ground, as verified by voltmeter > continuity checks. > I used shielded cables to connect the intercom and the mic and stereo > phone jacks, with the shields connected at intercom end to each other > and not connected to anything at the jacks. > I have a self-assembled AEC 9009 Audio Iso Amp handling VHF nav audio > on one channel, dynon warnings on one channel, left music in on one > channel, and right music in on one channel, with the 9009's output > going into the intercom aux input > The intercom is a Flightcom 403, with the pilot wires going to the > left front seat, copilot wires to the right front seat, and passenger > jacks to the back two seats. > The GNS430 is the only radio, with com audio routed directly to the > intercom per the intercom directions. > I'm testing with two known-good David Clark headsets (one stereo, one > mono) and one brand new Lightspeed headset, all with freshly buffed, > shiny connectors. > I'm using battery power only, since the engine is not installed > presently. I've tried the battery by itself and the battery with the > charger connected. The voltage range is about 13v to 14v for those > two cases, but I can't see that changing from one to the other makes > any difference in the audio system issues. > > Here is what I have tried so far with no improvements: > First, I unplugged aec9009. I lost the channels that run through it, > but the remaining intercom and VHF com audio were still the same. > Then I swapped intercom for the bypass plug that I built per the > intercom manual. this plug is designed to connect the pilot seat > jacks directly to the radio, so that the airplane can still function > as a single-place if the intercom is removed entirely. As with the > 9009, I lose intercom function in this configuration (as I should), > but the vhf com audio is still weak and scratchy. > I tried changing the Headsets around in various combinations to > various seats with no appreciable change. > I changed out the volume resistors in the AEC9009 to increase the > volume of those channels, and the volume did go up on the channel in > question, but the quality really suffered. > I'm not really sure what to try next. Does anyone have any > suggestions for what to check? The fuzzy part sounds like some segment in the audio chain is being overdriven by a source, or is being asked to supply more than it's capable of giving. The low level could be too much of a load on the output (load impedance too low). A partial short to ground (from an audio 'hi' to an audio 'Lo', or to the chassis) is the 1st thing that comes to mind. Having both fuzzy & low volume from multiple sources *might* mean that you have two or more outputs trying to feed into each other, with no isolation resistors between them. (This will make all affected outputs 'think' that they are effectively shorted to ground because each is trying to drive a very low impedance load.) So to proceed, 'Divide & conquer.' It's extremely unlikely that you have the same problem with every source, so job one is eliminating the known-good items. I'd get a set of clip leads, and extra phone jack, & start testing each source by itself, without it connected to any other component. Isolate the output line (typically 'audio hi' on the hookup diagram) from the rest of the plane. Hook a clip lead from that wire to the tip terminal of your spare jack. Hook another clip lead from the ground ('audio Lo') to the shield (ground) terminal of the jack. Plug in a known-good headset & listen to that source. Sound ok? If not troubleshoot settings, ground paths, etc. If good, move to the next source & repeat. Annddd repeat, until you've checked all or until you find a bad component. If all is good, hook one (and only one) source to the iso amp & move your test jack to the iso amp's output (with it hooked to nothing else). If bad, there's your problem. All good? that means the iso amp is almost certainly good, too. Hook the iso amp to the intercom's input again (with nothing else hooked to the input). Move the test jack to the intercom's output (with nothing else hooked up to the output lead). Listen again. If bad, check intercom settings (especially if there is an internal gain setting or aux input volume control in the intercom). All good? Without hooking up the 430, add one component to the iso amp & check for level/quality at the intercom output. (We've actually skipped a few steps by doing this, but if one iso input is good, odds are high that all will be good.) All sources (except 430) good? Use your test jack to check the 430, with its output connected to nothing but the test jack. Bad? There's your problem. Good? Proceed. Now look at how the 430 ties to the intercom. In your message, you say that the iso amp is hooked direct to the intercom. Is this a separate input on the intercom? It probably is, but if it's tied to the same input with the iso amp, that might well be your problem. Different input? Move your test jack to the intercom output & listen to the 430 through the intercom. Bad? Re-check wiring & intercom settings, then check the intercom itself, if possible. Still good? Re-check your headphone wiring harness in the plane. Having said all that, I'll say this: I've worked on a couple of 430 installations for friends, & they can be real snakes to troubleshoot. The most common issue is ground pins on the d-Sub connectors. There are quite a few, & if you miss one, stuff isn't going to work (not every ground terminal is common to every other ground terminal in those d-Sub connectors). On one system, I spoke with directly to a Garmin factory tech while holding the installation manual in my hand, and read off the pins that were connected. Even the Garmin tech failed to mention a (ground) pin that needed to be connected. Charlie (pro audio tech, consumer electronics tech and industrial electronics tech in various former lives) ________________________________________________________________________________
Date: Apr 06, 2013
Thank you very much Charlie, I'll try those procedures and report back when complete. On Apr 5, 2013, at 20:46, Charlie England wrote: > > On 04/05/2013 03:40 PM, Jared Yates wrote: >> >> I've been testing my audio system and have encountered poor >> performance. Does anyone have any suggestions for what to check? >> Here is the problem: >> >> All audio through the headsets is too quiet, and pretty scratchy. This >> applies to radio reception, intercom audio, Dynon voice out, and music >> input. With the intercom volume, headset volume, and individual device >> volume all the way up, the total volume is about where I would want to >> have it with 25% volume selected instead. The issue seems to afflict >> each of the various inputs to a similar degree. >> >> Here is the setup: >> New construction, wired by me (a non-professional, so anything is possible) >> The airframe is a steel tube 4-place fuselage with the mic and audio >> headset jacks isolated from ground, as verified by voltmeter >> continuity checks. >> I used shielded cables to connect the intercom and the mic and stereo >> phone jacks, with the shields connected at intercom end to each other >> and not connected to anything at the jacks. >> I have a self-assembled AEC 9009 Audio Iso Amp handling VHF nav audio >> on one channel, dynon warnings on one channel, left music in on one >> channel, and right music in on one channel, with the 9009's output >> going into the intercom aux input >> The intercom is a Flightcom 403, with the pilot wires going to the >> left front seat, copilot wires to the right front seat, and passenger >> jacks to the back two seats. >> The GNS430 is the only radio, with com audio routed directly to the >> intercom per the intercom directions. >> I'm testing with two known-good David Clark headsets (one stereo, one >> mono) and one brand new Lightspeed headset, all with freshly buffed, >> shiny connectors. >> I'm using battery power only, since the engine is not installed >> presently. I've tried the battery by itself and the battery with the >> charger connected. The voltage range is about 13v to 14v for those >> two cases, but I can't see that changing from one to the other makes >> any difference in the audio system issues. >> >> Here is what I have tried so far with no improvements: >> First, I unplugged aec9009. I lost the channels that run through it, >> but the remaining intercom and VHF com audio were still the same. >> Then I swapped intercom for the bypass plug that I built per the >> intercom manual. this plug is designed to connect the pilot seat >> jacks directly to the radio, so that the airplane can still function >> as a single-place if the intercom is removed entirely. As with the >> 9009, I lose intercom function in this configuration (as I should), >> but the vhf com audio is still weak and scratchy. >> I tried changing the Headsets around in various combinations to >> various seats with no appreciable change. >> I changed out the volume resistors in the AEC9009 to increase the >> volume of those channels, and the volume did go up on the channel in >> question, but the quality really suffered. >> I'm not really sure what to try next. Does anyone have any >> suggestions for what to check? > The fuzzy part sounds like some segment in the audio chain is being overdriven by a source, or is being asked to supply more than it's capable of giving. The low level could be too much of a load on the output (load impedance too low). A partial short to ground (from an audio 'hi' to an audio 'Lo', or to the chassis) is the 1st thing that comes to mind. Having both fuzzy & low volume from multiple sources *might* mean that you have two or more outputs trying to feed into each other, with no isolation resistors between them. (This will make all affected outputs 'think' that they are effectively shorted to ground because each is trying to drive a very low impedance load.) > > So to proceed, 'Divide & conquer.' > > It's extremely unlikely that you have the same problem with every source, so job one is eliminating the known-good items. I'd get a set of clip leads, and extra phone jack, & start testing each source by itself, without it connected to any other component. Isolate the output line (typically 'audio hi' on the hookup diagram) from the rest of the plane. Hook a clip lead from that wire to the tip terminal of your spare jack. Hook another clip lead from the ground ('audio Lo') to the shield (ground) terminal of the jack. Plug in a known-good headset & listen to that source. Sound ok? If not troubleshoot settings, ground paths, etc. If good, move to the next source & repeat. Annddd repeat, until you've checked all or until you find a bad component. > > If all is good, hook one (and only one) source to the iso amp & move your test jack to the iso amp's output (with it hooked to nothing else). If bad, there's your problem. All good? that means the iso amp is almost certainly good, too. > > Hook the iso amp to the intercom's input again (with nothing else hooked to the input). Move the test jack to the intercom's output (with nothing else hooked up to the output lead). Listen again. If bad, check intercom settings (especially if there is an internal gain setting or aux input volume control in the intercom). > > All good? Without hooking up the 430, add one component to the iso amp & check for level/quality at the intercom output. (We've actually skipped a few steps by doing this, but if one iso input is good, odds are high that all will be good.) > > All sources (except 430) good? Use your test jack to check the 430, with its output connected to nothing but the test jack. Bad? There's your problem. Good? Proceed. > > Now look at how the 430 ties to the intercom. In your message, you say that the iso amp is hooked direct to the intercom. Is this a separate input on the intercom? It probably is, but if it's tied to the same input with the iso amp, that might well be your problem. Different input? Move your test jack to the intercom output & listen to the 430 through the intercom. Bad? Re-check wiring & intercom settings, then check the intercom itself, if possible. Still good? Re-check your headphone wiring harness in the plane. > > Having said all that, I'll say this: I've worked on a couple of 430 installations for friends, & they can be real snakes to troubleshoot. The most common issue is ground pins on the d-Sub connectors. There are quite a few, & if you miss one, stuff isn't going to work (not every ground terminal is common to every other ground terminal in those d-Sub connectors). On one system, I spoke with directly to a Garmin factory tech while holding the installation manual in my hand, and read off the pins that were connected. Even the Garmin tech failed to mention a (ground) pin that needed to be connected. > > Charlie > (pro audio tech, consumer electronics tech and industrial electronics tech in various former lives) > > > > ________________________________________________________________________________
Date: Apr 06, 2013
From: Christopher Cee Stone <rv8iator(at)gmail.com>
Jared... One other potential low impedance fault is if using stereo headphone jacks and connecting both tip and ring to audio high. When a mono headphone plug is used it shorts the ring to audio lo (ground) and results in low or no audio from the connected source(s). Chris Stone RV-8 On Sat, Apr 6, 2013 at 4:52 AM, Jared Yates wrote: > > > > Thank you very much Charlie, I'll try those procedures and report back > when complete. > > > On Apr 5, 2013, at 20:46, Charlie England wrote: > > ceengland7(at)gmail.com> > > > > On 04/05/2013 03:40 PM, Jared Yates wrote: > email(at)jaredyates.com> > >> > >> I've been testing my audio system and have encountered poor > >> performance. Does anyone have any suggestions for what to check? > >> Here is the problem: > >> > >> All audio through the headsets is too quiet, and pretty scratchy. This > >> applies to radio reception, intercom audio, Dynon voice out, and music > >> input. With the intercom volume, headset volume, and individual device > >> volume all the way up, the total volume is about where I would want to > >> have it with 25% volume selected instead. The issue seems to afflict > >> each of the various inputs to a similar degree. > >> > >> Here is the setup: > >> New construction, wired by me (a non-professional, so anything is > possible) > >> The airframe is a steel tube 4-place fuselage with the mic and audio > >> headset jacks isolated from ground, as verified by voltmeter > >> continuity checks. > >> I used shielded cables to connect the intercom and the mic and stereo > >> phone jacks, with the shields connected at intercom end to each other > >> and not connected to anything at the jacks. > >> I have a self-assembled AEC 9009 Audio Iso Amp handling VHF nav audio > >> on one channel, dynon warnings on one channel, left music in on one > >> channel, and right music in on one channel, with the 9009's output > >> going into the intercom aux input > >> The intercom is a Flightcom 403, with the pilot wires going to the > >> left front seat, copilot wires to the right front seat, and passenger > >> jacks to the back two seats. > >> The GNS430 is the only radio, with com audio routed directly to the > >> intercom per the intercom directions. > >> I'm testing with two known-good David Clark headsets (one stereo, one > >> mono) and one brand new Lightspeed headset, all with freshly buffed, > >> shiny connectors. > >> I'm using battery power only, since the engine is not installed > >> presently. I've tried the battery by itself and the battery with the > >> charger connected. The voltage range is about 13v to 14v for those > >> two cases, but I can't see that changing from one to the other makes > >> any difference in the audio system issues. > >> > >> Here is what I have tried so far with no improvements: > >> First, I unplugged aec9009. I lost the channels that run through it, > >> but the remaining intercom and VHF com audio were still the same. > >> Then I swapped intercom for the bypass plug that I built per the > >> intercom manual. this plug is designed to connect the pilot seat > >> jacks directly to the radio, so that the airplane can still function > >> as a single-place if the intercom is removed entirely. As with the > >> 9009, I lose intercom function in this configuration (as I should), > >> but the vhf com audio is still weak and scratchy. > >> I tried changing the Headsets around in various combinations to > >> various seats with no appreciable change. > >> I changed out the volume resistors in the AEC9009 to increase the > >> volume of those channels, and the volume did go up on the channel in > >> question, but the quality really suffered. > >> I'm not really sure what to try next. Does anyone have any > >> suggestions for what to check? > > The fuzzy part sounds like some segment in the audio chain is being > overdriven by a source, or is being asked to supply more than it's capable > of giving. The low level could be too much of a load on the output (load > impedance too low). A partial short to ground (from an audio 'hi' to an > audio 'Lo', or to the chassis) is the 1st thing that comes to mind. Having > both fuzzy & low volume from multiple sources *might* mean that you have > two or more outputs trying to feed into each other, with no isolation > resistors between them. (This will make all affected outputs 'think' that > they are effectively shorted to ground because each is trying to drive a > very low impedance load.) > > > > So to proceed, 'Divide & conquer.' > > > > It's extremely unlikely that you have the same problem with every > source, so job one is eliminating the known-good items. I'd get a set of > clip leads, and extra phone jack, & start testing each source by itself, > without it connected to any other component. Isolate the output line > (typically 'audio hi' on the hookup diagram) from the rest of the plane. > Hook a clip lead from that wire to the tip terminal of your spare jack. > Hook another clip lead from the ground ('audio Lo') to the shield (ground) > terminal of the jack. Plug in a known-good headset & listen to that source. > Sound ok? If not troubleshoot settings, ground paths, etc. If good, move to > the next source & repeat. Annddd repeat, until you've checked all or until > you find a bad component. > > > > If all is good, hook one (and only one) source to the iso amp & move > your test jack to the iso amp's output (with it hooked to nothing else). If > bad, there's your problem. All good? that means the iso amp is almost > certainly good, too. > > > > Hook the iso amp to the intercom's input again (with nothing else hooked > to the input). Move the test jack to the intercom's output (with nothing > else hooked up to the output lead). Listen again. If bad, check intercom > settings (especially if there is an internal gain setting or aux input > volume control in the intercom). > > > > All good? Without hooking up the 430, add one component to the iso amp & > check for level/quality at the intercom output. (We've actually skipped a > few steps by doing this, but if one iso input is good, odds are high that > all will be good.) > > > > All sources (except 430) good? Use your test jack to check the 430, with > its output connected to nothing but the test jack. Bad? There's your > problem. Good? Proceed. > > > > Now look at how the 430 ties to the intercom. In your message, you say > that the iso amp is hooked direct to the intercom. Is this a separate input > on the intercom? It probably is, but if it's tied to the same input with > the iso amp, that might well be your problem. Different input? Move your > test jack to the intercom output & listen to the 430 through the intercom. > Bad? Re-check wiring & intercom settings, then check the intercom itself, > if possible. Still good? Re-check your headphone wiring harness in the > plane. > > > > Having said all that, I'll say this: I've worked on a couple of 430 > installations for friends, & they can be real snakes to troubleshoot. The > most common issue is ground pins on the d-Sub connectors. There are quite a > few, & if you miss one, stuff isn't going to work (not every ground > terminal is common to every other ground terminal in those d-Sub > connectors). On one system, I spoke with directly to a Garmin factory tech > while holding the installation manual in my hand, and read off the pins > that were connected. Even the Garmin tech failed to mention a (ground) pin > that needed to be connected. > > > > Charlie > > (pro audio tech, consumer electronics tech and industrial electronics > tech in various former lives) > > > > > > > > > > ________________________________________________________________________________
Date: Apr 06, 2013
Subject: transmitter power attenuator
I saw a recent post from Bob discussing using a 100 ft piece of coax connected to the comm antenna serving as an attenuator allowing for bench testing of a comm radio (xmit) without connecting to a conventional antenna. My question is, will this also work for a transponder? I am testing a new panel but do not have any antennas mounted to the the airframe and need to verify proper operation of each radio. I do have a dipole antenna (tuned for 118-136 Mhz) mounted on the roof of the shop I use for testing operation of the comms. But I haven't found any procedure for testing the transponder and ADS-B UAT which are 1090 Mhz and 978 Mhz without using their respective antennas. Chris Stone RV-8 GNS 430, AFS EFIS, Navworx ADS-B, Val comm, PMA 4000 ________________________________________________________________________________
Date: Apr 06, 2013
Subject: Re: transmitter power attenuator
At 02:30 PM 4/6/2013, you wrote: >I saw a recent post from Bob discussing using a >100 ft piece of coax connected to the comm >antenna serving as an attenuator allowing for >bench testing of a comm radio (xmit) without >connecting to a conventional antenna. > >My question is, will this also work for a transponder? Even better yet. Attenuation at 1050 is a LOT higher than at 126. >I am testing a new panel but do not have any >antennas mounted to the the airframe and need to >verify proper operation of each radio. I do >have a dipole antenna (tuned for 118-136 Mhz) >mounted on the roof of the shop I use for >testing operation of the comms. But I haven't >found any procedure for testing the transponder >and ADS-B UAT which are 1090 Mhz and 978 Mhz >without using their respective antennas. Hmmmm . . . that's a bigger problem and I'm not conversant with those systems. Waaayyy back when I used to have one of those AirSport eavesdroppers to check a transponder for gross functionality. You could lay a 110v drill motor on the ground under the xponder antenna and tie it into the ON position with a rubber band. Noise from the motor would tickle the transponder into fits of apoplexy . . . it would begin to squirt out mode c replies which could be read on the AirSport faceplate. Kinda handy sometimes. But all that newfangled stuff . . . I don't know. Bob . . . ________________________________________________________________________________
Date: Apr 06, 2013
Here's the AirSport Corporation electro-whizzy. Looks like they are still in business. Haven't had any direct contact with them in 10-15 years. http://tinyurl.com/ca8mgkv Bob . . . ________________________________________________________________________________
Date: Apr 06, 2013
Date: Apr 06, 2013
Good Evening Bob, I bought one a year or so ago. The main thing I use it for is to be sure what my transponder is sending to the FEDs.. I set it on top of my glareshield and I can see what my stuff is telling the FED! I like it, but would prefer that it be smaller. Happy Skies, Old Bob In a message dated 4/6/2013 8:50:35 P.M. Central Daylight Time, nuckolls.bob(at)aeroelectric.com writes: --> AeroElectric-List message posted by: "Robert L. Nuckolls, III" Here's the AirSport Corporation electro-whizzy. Looks like they are still in business. Haven't had any direct contact with them in 10-15 years. http://tinyurl.com/ca8mgkv Bob . . . ________________________________________________________________________________
Date: Apr 07, 2013
4/7/2013 Hello Again Bob Nuckolls, I thank you for your response copied below and I accept your recommendation. As an alternate means of connecting individual small wires together I seem to recall a technique of using D sub pins and sockets crimped onto the ends of the two wires and heat shrink tubing used to help hold the wires together. Is there anything published on using that technique? Thank you, =98OC=99 Baker === Bob Nuckolls wrote: I think somebody else on the list commented on those. Those are intended to telecommunications wiring in buildings. Except for ribbon cable connectors INSIDE black boxes, insulation displacement technology has never taken a foothold in aviation. I don't think I'd recommend them for airframe systems wiring. Oh yea, one of the ELT manufacturers used RJ series ID connectors on ordinary telephone wire to connect their panel mounted controls with the remote mounted transmitter. Haven't heard anything about lack of success for that decision . . . but still . . . their suitability to task is limited. Bob . . . ________________________________________________________________________________
Date: Apr 07, 2013
At 11:16 PM 4/6/2013, you wrote: >4/7/2013 > >Hello Again Bob Nuckolls, I thank you for your response copied below >and I accept your recommendation. > >As an alternate means of connecting individual small wires together >I seem to recall a technique of using D sub pins and sockets crimped >onto the ends of the two wires and heat shrink tubing used to help >hold the wires together. > >Is there anything published on using that technique? Not much to publish . . . I think there are some photos of wires joined with d-bub crimp pins on the website. You just put mating pins on the wires to be joined, stick them together and cover with heatsrhink. You've created one-pin connectors with soft housings. I think this thread started with a stated goal of dealing with the Ray Allen actuator wires. I gave up trying to convince first father and then sons of the value of 22 awg leads -AND- replacing two white motor wires with separate colors so that the builder had a 100% chance of wiring it right the first time! Check out this article http://tinyurl.com/cmq7epd Bob . . . ________________________________________________________________________________
Date: Apr 07, 2013
> From: Christopher Cee Stone <rv8iator(at)gmail.com> > But I haven't found any procedure > for testing the transponder and ADS-B UAT which are 1090 Mhz and 978 Mhz > without using their respective antennas. Zaon makes two portable collision avoidance systems, the MRX and XRX. Likely a local pilot will have one of these you could borrow. Both will display the transponder code and altitude of what it is transmitted by the local transponder. Jeff Page Dream Aircraft Tundra #10 ________________________________________________________________________________
Subject: Butt Splice for #4 wire
Date: Apr 07, 2013
I have a #4 wire I need to put a new ring terminal on. It will make a tight reach. I think it will work, but I considered a #4 butt splice - they make 'em. If my new ring terminal makes it too short, my choice is adding a few inches of new #4 with a butt splice, or replacing the entire 5 foot length (which won't be easy to do). Opinions, please John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=398043#398043 ________________________________________________________________________________
Date: Apr 07, 2013
At 09:07 PM 4/6/2013, you wrote: >Good Evening Bob, > >I bought one a year or so ago. The main thing I use it for is to be >sure what my transponder is sending to the FEDs.. I set it on top of >my glareshield and I can see what my stuff is telling the FED! > >I like it, but would prefer that it be smaller. If the original designer/manufacturer were still in business, it might have become smaller by now. I met Daryl and Pat Phillips in OSH about 1990. Their mom-n-pop business in Salisaw OK was rather young then. Daryl was the one and only designer and software writer. He was using Motorola 6800 series chips as I recall. The thing uses a rather large battery. They sold the business to one of their employees some years ago. To be sure, more modern processors, components and materials offer opportunity for shrinking the size down . . . and even making it run on three or four AA cells. But I don't think that's going to happen now. It IS a pretty slick gizmo. Bob . . . ________________________________________________________________________________
Date: Apr 07, 2013
Subject: Re: Butt Splice for #4 wire
At 09:40 AM 4/7/2013, you wrote: > > >I have a #4 wire I need to put a new ring terminal on. It will make >a tight reach. I think it will work, but I considered a #4 butt >splice - they make 'em. If my new ring terminal makes it too short, >my choice is adding a few inches of new #4 with a butt splice, or >replacing the entire 5 foot length (which won't be easy to do). How much original wire is easily accessible? It would be decidedly unhandy to have a splice in close proximity to the terminal end. Can you cut the original wire back before splicing on the extension? What kind of #4 wire? Bob . . . ________________________________________________________________________________
Date: Apr 07, 2013
Subject: Encapsulating connectors (Quest. for Bob)
Bob, reading your on-line article (URL below) reminded me of a long-standing question. In your article you use a specialty adhesive for "potting" or encapsulating the soldered pins on a 9-pin D-sub-miniature connector. Unable to locate that particular connector, I have used clear RTV. However later I read that because of the acid in the RTV compound, RTV can attack soldered joints (e.g. http://en.wikipedia.org/wiki/RTV_silicone#Disadvantages). What compound, readily available, would you recommend for sealing or encapsulating connectors? On Sun, Apr 7, 2013 at 6:42 AM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > nuckolls.bob(at)aeroelectric.com> > > http://tinyurl.com/cmq7epd > > ________________________________________________________________________________
Date: Apr 07, 2013
Subject: Re: Encapsulating connectors (Quest. for Bob)
At 09:59 AM 4/7/2013, you wrote: >Bob, reading your on-line article (URL below) reminded me of a >long-standing question. > >In your article you use a specialty adhesive for "potting" >or encapsulating the soldered pins on a 9-pin D-sub-miniature >connector. Unable to locate that particular connector . . . Did you mean to say 'connector' or 'adhesive'? The d-sub is ubiquitous and available about everywhere not the least of which is Radio Shack as suggested in the article. > I have used clear RTV. However later I read that because of the > acid in the RTV compound, RTV can attack soldered joints (e.g. > <http://en.wikipedia.org/wiki/RTV_silicone#Disadvantages>http://en.wikipedia.org/wiki/RTV_silicone#Disadvantages). "RTV" has been around for many years. I think I first encountered one variant for the first time while working at Hughes Aircraft back about 1963. It smelled decidedly vinegar (acetic acid). RTV, Room Temperature Vulcanizing, is a generic term that speaks to hundreds of similar products. If one needs the high temperature chemical resistance of silicon encapsulants, there are 'electronic grade' RTVs. They do not include acetic acid in their chemistry. I'm pretty sure there are other forms equally free of acid. One could also consider some of the acrylic caulking compounds used for bathtubs and window frames. Give it a sniff and avoid anything that smells like pickles. Sometime during "The Great Transition" from generators to alternators at Cessna (about 1965) the regulator of choice was a two-relay electro-mechanical regulator from Ford. http://tinyurl.com/d7ln4mt Things moved along right smartly for a time until field reports concerning alternator runaway events. Failure analysis of the regulators revealed that the plastic bobbin on which the voltage regulation wires were wound was loose on the pole core. The bobbin 'bounced' about on the core causing failure of the small lead wires. Deprived of any sense of voltage, the regulator went balls-to-the-wall. Somebody suggested that we pull all regulators from stock, remove covers and spot-tack the bobbins in place with RTV. Yeah, cool idea. I don't recall if we did a field service bulletin for doing the same thing on delivered aircraft or perhaps the drill called for exchanging regulators. Again, things smoothed out until a short time later, brand new 'modified' regulators from stock failed to come alive in flight test. Seems that fumes from curing RTV put enough corrosion on the regulator contacts to disable it. If the modification process had only left the covers off for a few days to allow all the fumes to dissipate, all would have been right with the universe. Needless to say, this triggered the Second Great Thrashing to remove covers and buff contacts. Ford eventually fixed this fundamental design flaw. >What compound, readily available, would you recommend for sealing or >encapsulating connectors? The E6000 adhesive I've cited is everywhere. Check the Walmart crafts and housewares adhesive displays. ShoGoo sold in shoe stores is the same stuff. Hardware and automotive parts stores sell it under various sizes and trade names. The common thread is water clear and smells like dry cleaners. Bob . . . ________________________________________________________________________________
Date: Apr 07, 2013
On 04/07/2013 11:57 AM, Robert L. Nuckolls, III wrote: > At 09:59 AM 4/7/2013, you wrote: >> Bob, reading your on-line article (URL below) reminded me of a >> long-standing question. >> >> In your article you use a specialty adhesive for "potting" >> or encapsulating the soldered pins on a 9-pin D-sub-miniature >> connector. Unable to locate that particular connector . . . > > Did you mean to say 'connector' or 'adhesive'? > > The d-sub is ubiquitous and available about everywhere > not the least of which is Radio Shack as suggested in > the article. > >> I have used clear RTV. However later I read that because of the acid >> in the RTV compound, RTV can attack soldered joints (e.g. >> http://en.wikipedia.org/wiki/RTV_silicone#Disadvantages >> <http://en.wikipedia.org/wiki/RTV_silicone#Disadvantages>). > > "RTV" has been around for many years. I think I > first encountered one variant for the first time > while working at Hughes Aircraft back about 1963. > It smelled decidedly vinegar (acetic acid). RTV, > Room Temperature Vulcanizing, is a generic term that > speaks to hundreds of similar products. If one needs > the high temperature chemical resistance of silicon > encapsulants, there are 'electronic grade' RTVs. They > do not include acetic acid in their chemistry. I'm > pretty sure there are other forms equally free of > acid. One could also consider some of the acrylic > caulking compounds used for bathtubs and window > frames. Give it a sniff and avoid anything that > smells like pickles. > > Sometime during "The Great Transition" from generators > to alternators at Cessna (about 1965) the regulator > of choice was a two-relay electro-mechanical > regulator from Ford. > > http://tinyurl.com/d7ln4mt > > Things moved along right smartly for a time > until field reports concerning alternator > runaway events. Failure analysis of the regulators > revealed that the plastic bobbin on which the > voltage regulation wires were wound was loose > on the pole core. The bobbin 'bounced' about > on the core causing failure of the small lead > wires. Deprived of any sense of voltage, the > regulator went balls-to-the-wall. > > Somebody suggested that we pull all regulators > from stock, remove covers and spot-tack the > bobbins in place with RTV. Yeah, cool idea. > I don't recall if we did a field service bulletin > for doing the same thing on delivered aircraft > or perhaps the drill called for exchanging > regulators. > > Again, things smoothed out until a short time > later, brand new 'modified' regulators from > stock failed to come alive in flight test. > Seems that fumes from curing RTV put enough > corrosion on the regulator contacts to disable > it. If the modification process had only > left the covers off for a few days to allow > all the fumes to dissipate, all would have been > right with the universe. > > Needless to say, this triggered the Second Great > Thrashing to remove covers and buff contacts. > Ford eventually fixed this fundamental design flaw. > >> What compound, readily available, would you recommend for sealing or >> encapsulating connectors? > > The E6000 adhesive I've cited is everywhere. > Check the Walmart crafts and housewares adhesive > displays. ShoGoo sold in shoe stores is the > same stuff. Hardware and automotive parts stores > sell it under various sizes and trade names. > The common thread is water clear and smells like > dry cleaners. > > Bob . . . > > If an auto supply house is more convenient, look for 'sensor safe' on the package of RTV. ________________________________________________________________________________
Date: Apr 07, 2013
>If an auto supply house is more convenient, look for 'sensor safe' >on the package of RTV. I've not heard of that label. To be sure, in spite of the acetic RTV capabilities it has for sure been the source of some consternation. It's akin to "test this product on some insignificant or hidden surface before proceeding". Thanks for the heads-up. Bob . . . ________________________________________________________________________________
Date: Apr 07, 2013
On 04/07/2013 12:33 PM, Robert L. Nuckolls, III wrote: >> If an auto supply house is more convenient, look for 'sensor safe' on >> the package of RTV. > > I've not heard of that label. To be sure, in spite > of the acetic RTV capabilities it has for sure > been the source of some consternation. It's akin > to "test this product on some insignificant or > hidden surface before proceeding". > > Thanks for the heads-up. > > Bob . . . > > * * Googling 'RTV sensor safe' will yield a lot of hits. Here's one: http://www.permatex.com/products/product-categories/gasketing/gasket-makers/permatex-sensor-safe-blue-rtv-silicone-gasket-maker-detail The text on the Permatex web site says 'now with low odor formula'. That's usually another tell that the acetic acid isn't in that particular product. Even the old-school looking Permatex clear RTV now claims to be good for sealing electrical wire, but I'm not sure I'd rely on that. Charlie ________________________________________________________________________________
Date: Apr 07, 2013
Another product to consider is "aquarium safe" RTV. I don't know if it is safe for electrical components, but it is labeled as non toxic. Raymond Julian Kettle River, MN. "And you know that I could have me a million more friends, and all I'd have to lose is my point of view." - John Prine On 04/07/2013 12:33 PM, Robert L. Nuckolls, III wrote: >> If an auto supply house is more convenient, look for 'sensor safe' on >> the package of RTV. > > I've not heard of that label. To be sure, in spite > of the acetic RTV capabilities it has for sure > been the source of some consternation. It's akin > to "test this product on some insignificant or > hidden surface before proceeding". > > Thanks for the heads-up. > > Bob . . . > > * > > > * ________________________________________________________________________________
Date: Apr 07, 2013
Bob, Bob et al, Thanks for the info... My primary concern at this time was to insure I wouldn't damage the xponder upon power up if I inadvertently hit the ident button. As far as test equipment goes the shop should be able to verify operation when I get my pitot/static check. The ADS-B checkout is another matter. The Navworx box does have a self test that validates it is receiving the serial data from the alt. encoder and displays the output on the EFIS screen. Still need to learn the procedure for validating communication with the ground station. The technology is still in it's infancy as the FEDs are in process of adding ground stations to re-transmit traffic and weather data. I'm still learning... but that's the idea isn't it! Chris On Sun, Apr 7, 2013 at 6:49 AM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 09:07 PM 4/6/2013, you wrote: > > Good Evening Bob, > > I bought one a year or so ago. The main thing I use it for is to be sure > what my transponder is sending to the FEDs.. I set it on top of my > glareshield and I can see what my stuff is telling the FED! > > I like it, but would prefer that it be smaller. > > > If the original designer/manufacturer were still > in business, it might have become smaller by now. > I met Daryl and Pat Phillips in OSH about 1990. > Their mom-n-pop business in Salisaw OK was rather > young then. Daryl was the one and only designer and > software writer. He was using Motorola 6800 series > chips as I recall. > > The thing uses a rather large battery. > > They sold the business to one of their employees > some years ago. To be sure, more modern processors, > components and materials offer opportunity for > shrinking the size down . . . and even making it run > on three or four AA cells. But I don't think > that's going to happen now. > > It IS a pretty slick gizmo. > > > ** > > ** Bob . . . > > * > > * > > ________________________________________________________________________________
Date: Apr 07, 2013
Jeff, Thanks... Great tip! I think my local FBO has them in a couple of rentals. chris On Sun, Apr 7, 2013 at 7:00 AM, Jeff Page wrote: > > From: Christopher Cee Stone <rv8iator(at)gmail.com> >> But I haven't found any procedure >> for testing the transponder and ADS-B UAT which are 1090 Mhz and 978 Mhz >> without using their respective antennas. >> > > Zaon makes two portable collision avoidance systems, the MRX and XRX. > Likely a local pilot will have one of these you could borrow. > > Both will display the transponder code and altitude of what it is > transmitted by the local transponder. > > Jeff Page > Dream Aircraft Tundra #10 > > ________________________________________________________________________________
Date: Apr 07, 2013
Most RTV contains arsenic to prevent mold from forming. You can't use arsenic on an aquarium because it will kill the fish. Also, don't use regular RTV on things like a dishwasher because you could get arsenic poisoning. ----- Lynn Cole LynnCole(at)foxvalley.net On Apr 7, 2013, at 1:15 PM, rayj wrote: > Another product to consider is "aquarium safe" RTV. I don't know if it is safe for electrical components, but it is labeled as non toxic. > Raymond Julian > Kettle River, MN. > > "And you know that I could have me a million more friends, > and all I'd have to lose is my point of view." - John Prine > On 04/07/2013 12:33 PM, Robert L. Nuckolls, III wrote: >>> If an auto supply house is more convenient, look for 'sensor safe' on the package of RTV. >> >> I've not heard of that label. To be sure, in spite >> of the acetic RTV capabilities it has for sure >> been the source of some consternation. It's akin >> to "test this product on some insignificant or >> hidden surface before proceeding". >> >> Thanks for the heads-up. >> >> Bob . . . >> >> >> >> > > > > ________________________________________________________________________________
Date: Apr 08, 2013
Bob, It's #4 welding wire. I have access to about 18" of it before it passes behind the engine to the alternator. I get what you are saying - don't put a butt splice close to the terminal. I worked on it yesterday and the break was very close to the terminal. I was able to put a new terminal on, losing only an inch or so of wire. I had to make a minor reroute change, but made it fit. My biggest issue was keeping it away from the exhaust pipes. I got it 2" away from the pipes and put a leftover piece of firesleeve on it. My biggest surprise was how the cable fatigued so fast. Obviously, engine vibration took it's toll. John PS: I like your new book being bound, but I still like the ability to remove a page for immediate reference. I keep both copies at the hangar. -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=398134#398134 ________________________________________________________________________________
Date: Apr 08, 2013
John, Are you saying that engine vibration caused a metal fatigue break in #4 welding wire while you were flying off your Phase 1? Bill B On 4/8/2013 9:37 AM, johngoodman wrote: > > Bob, > It's #4 welding wire. I have access to about 18" of it before it passes behind the engine to the alternator. I get what you are saying - don't put a butt splice close to the terminal. > I worked on it yesterday and the break was very close to the terminal. I was able to put a new terminal on, losing only an inch or so of wire. I had to make a minor reroute change, but made it fit. My biggest issue was keeping it away from the exhaust pipes. I got it 2" away from the pipes and put a leftover piece of firesleeve on it. > > My biggest surprise was how the cable fatigued so fast. Obviously, engine vibration took it's toll. > John > PS: I like your new book being bound, but I still like the ability to remove a page for immediate reference. I keep both copies at the hangar. > > -------- > #40572 Phase One complete and flying. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=398134#398134 > > ________________________________________________________________________________
Date: Apr 08, 2013
[quote="bbradburry(at)bellsouth.n"]John, Are you saying that engine vibration caused a metal fatigue break in #4 welding wire while you were flying off your Phase 1? Bill B On 4/8/2013 9:37 AM, johngoodman wrote: [quote] Bill, No, I've been flying for almost 2 years. The wire was unsupported for the last 7" to 9" and I figure it was like a hand shake that wouldn't stop.... John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=398139#398139 ________________________________________________________________________________
Date: Apr 08, 2013
Sorry, I meant adhesive of course. You and others correctly interpreted my intent and I got lots of great answers... Thanks everybody, Ralph On Sun, Apr 7, 2013 at 9:57 AM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > > Did you mean to say 'connector' or 'adhesive'? > * * > > ________________________________________________________________________________
Date: Apr 08, 2013
Subject: Charging System Debug steps and success...
Greetings All, From time-to-time people have posted assorted problems, and gotten answers to, charging system issues. Many of these are of the wandering or oscillating voltage nature. As my charging system (LongEz, externally regulator "ford-style" charging with regulator and battery in the nose) developed an oscillating attitude I had the "opportunity" to collect, review and then apply the information Bob has generously provided and thought an overview might prove useful for the next guy down the road. I'll start with key summary points for those who don't have the current need or desire to read through the details. My symptoms were an oscillating (2 - 6 Hz maybe?) charging voltage visible with the old (WesTach) panel meter. It was sufficient to pop the over-voltage crowbar once. It might also be related to an transient undervoltage alarm I got once. After isolating the problem, I fixed it by replacing the store-bought regulator connector (which had pig-tails, the bad connection was on the factory-made regulator +V crimp) with good-quality Fast-ons direct to the regulator. This dropped the alternator B+ to regulator V+ resistance from 528mOhms to ~140mOhms which fixed the problem. btw: the 140 ohms, which is still higher than I would like, seems to be roughly evenly shared by the fuse-link, breaker and switch (and associated wiring). The details and references for "the next guy": The debug strategy was to start by checking the resistance (using techniques appropriate for milliohm measurments), without doing any disconnecting of the current loop path from alternator B+ to the regulator and then back from the regulator ground (i.e. case) to the alternator ground (i.e. case). My plan was to keep dividing the problem in half to minimize debug time (i.e. binary search). I wanted to do as much testing as I could without taking anything apart as I didn't want to inadvertently change the problem (i.e. wiggle something and have the problem go away...) In the case that no problems were uncovered via the milliohm measurements, I then planned to follow Bob's charging component problem isolation technique which is in chapter 3 of the Aeroelectric connection book. This involves making measurements while the engine is running but I didn't need go to that step and I certainly didn't want to start there. For lots of charging system background and debug information, search Bob's site (www.aeroelectric.com) for "charging" and ignore all the stuff on plug-in-the-wall battery chargers. Bob has written articles and has product related to making good milliohm measurements using an applied current. I prefer having the current source (whether a bench supply or other similar to Bob's milliohm probes) separate rather than combining it with the volt-meter probes. Also, as Bob has covered in his articles, you don't need a regulated-to-a-known-value current source. It suffices to have an unregulated current source (like a D-cell, in a pinch) if you are using a second meter to measure the current. For more information on accurate milliohm measurements, search Bob's site for "milliohm". I conceptually divided the loop in half (ground side vs power side) and picked the ground side first. I put a current source (bench supply with an accurate current limit set to 1A (and set the voltage limit to be 2V though I didn't expect it to ever run in voltage mode regulation)) between the alternator case and the regulator case (which, on my LongEz is the length of the entire aircraft). I then measured the voltage (using separate wires) between the two cases and got 33.9mV which, at one amp, means 33.9mOhms. This is well below the ~200mOhms threshold area of concern (per Bob's annotations contained in "Know_Your_Charging_System.pdf"). Therefore the problem is in the V+ side. I repeated this on the V+ side which is a little bit trickier to measure as the "master" progressive switch needs to be in the "Alternator on" position which can add more currents to deal with (though, it turns out, not much). With the switch on, I measured the voltage from alternator B+ to regulator V+ both with the current source connected, and not connected. The value I care about is the connected value minus the not connected value. (though it still applies, I won't repeat this detail from now on). I measured 528mV (=528mOhms) which is well above the 200mOhm area of concern. So I've identified one (but maybe only the first?, it turned out to be only) problem. I then listed all (well, sort of, I didn't list both side of each wire...) of the connections between Alternator B+ and regulator V+. For me, starting from B+: Near side of load-meter shunt, near side of ANL, near side of fuse-link, near side of over-voltage breaker, nearside of alternator switch, V+ at the regulator. I kept the current source running between B+ on the alternator and regulator V+ (no reason to move it) and picked the point in the middle (near side ANL), B+ to near side ANL was only 11mV (=11mOhms). I continued the divide (roughly in half) and conquer approach (continuing to measure from B+ to my point of interest) which led me quickly to the crimp at the regulator. In the future I *might* start by measuring any connections I didn't personally make (of which there are very very few) before switching to the more disciplined binary search approach. In this case I would have gotten lucky but, in truth, it would not have saved much time. The time was spent going through Bob's articles and developing a plan. The execution of the plan went very fast. Repair and run-up test showed success. Specific Bob articles I found helpful (in addition to those on milliohm measurement): Know_Your_Charging_System.pdf 03_Alternator_12A2.pdf (i.e. the current chapter 3 in the aeroelectric connection, start at page 3-7 for debug info) Happy debugging! Steve Stearns Boulder/Longmont, Colorado Restoring (since 1/07) and flying again (8/11!): N45FC O235 Longeze Cothern/Friling CF1 (~1000 Hrs) Flying (since 9/86): N43732 A65 Taylorcraft BC12D ________________________________________________________________________________
Date: Apr 08, 2013
At 08:37 AM 4/8/2013, you wrote: Bob, It's #4 welding wire. I have access to about 18" of it before it passes behind the engine to the alternator. I get what you are saying - don't put a butt splice close to the terminal. I worked on it yesterday and the break was very close to the terminal. I was able to put a new terminal on, losing only an inch or so of wire. I had to make a minor reroute change, but made it fit. My biggest issue was keeping it away from the exhaust pipes. I got it 2" away from the pipes and put a leftover piece of firesleeve on it. My biggest surprise was how the cable fatigued so fast. Obviously, engine vibration took it's toll. Did you put heat-shrink over the wire-grip and wire? More specifically, double-walled heatshrink . . . very stiff? Whether crimped or soldered, stranded wires experience a stress concentration at the transition point from solid to stranded. When we sold terminal kits for installation by soldering http://tinyurl.com/ct36xen the kit included a 2" piece of double-wall heatshrink to provide insulation support. John PS: I like your new book being bound, but I still like the ability to remove a page for immediate reference. I keep both copies at the hangar. Many builders have expressed a preference for the 3-ring format. You can take your bound book to a copy/print shop like Kinkos and have it drilled for ring binder. They also have a paper cutter that will shear off the spine. Cut the spine off first so that the drilled holes have the right edge margins. Do you still have the terminal that broke off? I'd like to have it if you could see fit to mail it to me. Bob . . . ________________________________________________________________________________
Date: Apr 08, 2013
> Did you put heat-shrink over the wire-grip and > wire? More specifically, double-walled > heatshrink . . . very stiff? > > Whether crimped or soldered, stranded wires > experience a stress concentration at the > transition point from solid to stranded. When > we sold terminal kits for installation > by soldering > > http://tinyurl.com/ct36xen > > the kit included a 2" piece of double-wall > heatshrink to provide insulation support. > Bob, I'm pretty sure it's regular heatshrink, although I have a couple of pieces of the double-wall stuff laying around. > Do you still have the terminal that broke off? > I'd like to have it if you could see fit to > mail it to me. Bob, Yes, I do still have it. My e-mail is johngoodmanATearthlink.net Send an address, and I'll mail it. The fatigue point is very close to the terminal. John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=398187#398187 ________________________________________________________________________________
Date: Apr 08, 2013
John, Did I miss it - I am sorry, but can you explain how you discovered the problem? Was it complete disconnect? Was the break on the alternator end or firewall end? Thanks Chris Lucas N919AR 40072 -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of johngoodman Sent: Sunday, April 07, 2013 10:41 AM Subject: AeroElectric-List: Butt Splice for #4 wire --> I have a #4 wire I need to put a new ring terminal on. It will make a tight reach. I think it will work, but I considered a #4 butt splice - they make 'em. If my new ring terminal makes it too short, my choice is adding a few inches of new #4 with a butt splice, or replacing the entire 5 foot length (which won't be easy to do). Opinions, please John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=398043#398043 ________________________________________________________________________________
Date: Apr 08, 2013
Subject: Re: Charging System Debug steps and success...
At 12:04 PM 4/8/2013, you wrote: Greetings All, From time-to-time people have posted assorted problems, and gotten answers to, charging system issues. Many of these are of the wandering or oscillating voltage nature. Yes. The "galloping ammeter" syndrome is almost exclusive to alternator/regulator systems wherein the wire with duties to sense bus voltage ALSO carries alternator field current. This is a VERY common configuration in tens of millions of cars and tens of thousands of airplanes. A typical at-risk system uses the legacy FORD regulator featured in many of my writings and schematics. As my charging system (LongEz, externally regulator "ford-style" charging with regulator and battery in the nose) developed an oscillating attitude I had the "opportunity" to collect, review and then apply the information Bob has generously provided and thought an overview might prove useful for the next guy down the road. I'll start with key summary points for those who don't have the current need or desire to read through the details. My symptoms were an oscillating (2 - 6 Hz maybe?) charging voltage visible with the old (WesTach) panel meter. It was sufficient to pop the over-voltage crowbar once. It might also be related to an transient undervoltage alarm I got once. After isolating the problem, I fixed it by replacing the store-bought regulator connector (which had pig-tails, the bad connection was on the factory-made regulator +V crimp) with good-quality Fast-ons direct to the regulator. This dropped the alternator B+ to regulator V+ resistance from 528mOhms to ~140mOhms which fixed the problem. btw: the 140 ohms, which is still higher than I would like, seems to be roughly evenly shared by the fuse-link, breaker and switch (and associated wiring). Of course the ideal supply loop resistance is zero ohms. However a Bode plot of the closed-loop response of the alternator-regulator-aircraft system usually shows that several hundred mOhms can be tolerated before control loop stability margin becomes risky. The details and references for "the next guy": The debug strategy was to start by checking the resistance (using techniques appropriate for milliohm measurments), without doing any disconnecting of the current loop path from alternator B+ to the regulator and then back from the regulator ground (i.e. case) to the alternator ground (i.e. case). My plan was to keep dividing the problem in half to minimize debug time (i.e. binary search). I wanted to do as much testing as I could without taking anything apart as I didn't want to inadvertently change the problem (i.e. wiggle something and have the problem go away...) In the case that no problems were uncovered via the milliohm measurements, I then planned to follow Bob's charging component problem isolation technique which is in chapter 3 of the Aeroelectric connection book. This involves making measurements while the engine is running but I didn't need go to that step and I certainly didn't want to start there. For lots of charging system background and debug information, search Bob's site (www.aeroelectric.com) for "charging" and ignore all the stuff on plug-in-the-wall battery chargers. Bob has written articles and has product related to making good milliohm measurements using an applied current. I prefer having the current source (whether a bench supply or other similar to Bob's milliohm probes) separate rather than combining it with the volt-meter probes. Also, as Bob has covered in his articles, you don't need a regulated-to-a-known-value current source. It suffices to have an unregulated current source (like a D-cell, in a pinch) if you are using a second meter to measure the current. For more information on accurate milliohm measurements, search Bob's site for "milliohm". I conceptually divided the loop in half (ground side vs power side) and picked the ground side first. I put a current source (bench supply with an accurate current limit set to 1A (and set the voltage limit to be 2V though I didn't expect it to ever run in voltage mode regulation)) between the alternator case and the regulator case (which, on my LongEz is the length of the entire aircraft). I then measured the voltage (using separate wires) between the two cases and got 33.9mV which, at one amp, means 33.9mOhms. This is well below the ~200mOhms threshold area of concern (per Bob's annotations contained in "Know_Your_Charging_System.pdf"). Therefore the problem is in the V+ side. I repeated this on the V+ side which is a little bit trickier to measure as the "master" progressive switch needs to be in the "Alternator on" position which can add more currents to deal with (though, it turns out, not much). With the switch on, I measured the voltage from alternator B+ to regulator V+ both with the current source connected, and not connected. The value I care about is the connected value minus the not connected value. (though it still applies, I won't repeat this detail from now on). I measured 528mV (=528mOhms) which is well above the 200mOhm area of concern. So I've identified one (but maybe only the first?, it turned out to be only) problem. I then listed all (well, sort of, I didn't list both side of each wire...) of the connections between Alternator B+ and regulator V+. For me, starting from B+: Near side of load-meter shunt, near side of ANL, near side of fuse-link, near side of over-voltage breaker, nearside of alternator switch, V+ at the regulator. I kept the current source running between B+ on the alternator and regulator V+ (no reason to move it) and picked the point in the middle (near side ANL), B+ to near side ANL was only 11mV (=11mOhms). I continued the divide (roughly in half) and conquer approach (continuing to measure from B+ to my point of interest) which led me quickly to the crimp at the regulator. In the future I *might* start by measuring any connections I didn't personally make (of which there are very very few) before switching to the more disciplined binary search approach. In this case I would have gotten lucky but, in truth, it would not have saved much time. The time was spent going through Bob's articles and developing a plan. The execution of the plan went very fast. Repair and run-up test showed success. Specific Bob articles I found helpful (in addition to those on milliohm measurement): Know_Your_Charging_System.pdf 03_Alternator_12A2.pdf (i.e. the current chapter 3 in the aeroelectric connection, start at page 3-7 for debug info) Happy debugging! The phenomenon we're exploring is the twin brother of a 'ground loop'. In a ground loop, a potential noise current shares a conduction path with a potential victim (audio system, radio, etc). In our 'buss-loop', a noisy current (field supply) shares a pathway with a potential victim (voltage regulator). Operating currents for the alternator field can be anywhere between a few hundred milliamps (very light load, high rpm) to 3 or 4 amps (low rpm, high, load). The number and kind of accessories turned on at the time have a second order effect on control loop stability. If you have 500 milliohms of field supply resistance feeding a moderately loaded alternator current of say 2 amps, then the 2 amp x 0.5 ohms or 1 volt 'modulation' of voltage at the regulator's A/S terminals presents as a 1 volt error in the desired regulation set point. This is not a guarantee for unstable operation but the risks are very high. Wire resistance in the rest of the system has very low to zero risk for setting up the same condition. This problem came to light early on for single engine Cessnas. I addition to conductors that ran from bus to regulator, there were ohmic joints, (crimped pins, engaged pins, fast-ons, switch saddles, switch contacts, etc). I forget the exact number but I think I recall something like 19 ohmic joints in the Cessnas, far more than any other TC aircraft. About once a year I get an email from a TC Cessna owner asking about fixes for the 'galloping ammeter". Quite often, replacing one item in the constellation of system components provides relief . . . but it is temporary. My advice is to start at the bus and replace EVERYTHING with ohmic joints starting with breaker, master switch and it's fast-on terminals, and crimped on pins in all the Mate-n-Lok connectors. This 'shotgun' approach will reduce total path resistance to a value close to factory original values. Assuming the modern regulators have similar stability models, this approach should set the system up for another 40 years of stable operation. Steve, thank you so much for the validation of the simple-ideas offered as to root cause and remedy for this unique phenomenon. Good work my friend! Bob . . . ________________________________________________________________________________
Date: Apr 09, 2013
toaster73(at)embarqmail.c wrote: > John, > Did I miss it - I am sorry, but can you explain how you discovered the > problem? Was it complete disconnect? Was the break on the alternator end or > firewall end? > Thanks > Chris Lucas > N919AR > 40072 > > -- The break was on the starter power lug. I have two wires on that lug - a #2 from the rear battery, and a #4 that goes around the engine to the lug on an ANL type fuse connected to the alternator - that's how the battery recharges. A couple of flights ago I noticed that I only had about 12V on the battery after start, but my backup battery was fine. I figured the battery was beginning to fail, or there was some kind of grounded lead. I was getting large amp draws during start, so I figured that it had something to do with the starter/solenoid. I pulled the cowling and concentrated on the positive lead on the solenoid, but the big cables were getting in my way. I decided to remove them to get more room. The #4 looked fine as I removed the nut, but as soon as a pulled it off the lug, the terminal was only hanging on by a couple of thin wires and a small piece of the heatshrink. The only thing that had been keeping it together was the heatshrink and the natural propensity of the wire to stay in place. My only explanation is that the 7", or so, of cable between the terminal end and the first adel clamp, had enough weight and motion to respond to vibrations, and eventually fatigue the cable. Hope this explains it. John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=398235#398235 ________________________________________________________________________________
Date: Apr 09, 2013
Subject: Re: Diagnostic Help Please: Audio is Weak and Scratchy
Here's an update. I took the very nicely detailed instructions from Charlie to the hangar today and tried running the various inputs directly to the headset. The good news is that the 430 and iso amp worked perfectly. When I got down to testing the intercom by itself, I still had the problem, so I ran new temporary wires to my temporary test jack, and everything worked. I started rebuilding from there, with the pilot's mic jack first. When I added the phone jack, the problem came back. I started checking continuity from the jack to the intercom connector and found the problem- I had not grounded the jacks. To verify the problem, I ran a jumper from the jack's ring to the ground tab, and the problem went away immediately. Back when I did the initial install, I had the phone jacks grounded locally to the airframe. Some time later I read that it was better to isolate the headset jacks from the airframe and ground them up front with the rest of the avionics grounds, so I drilled the holes up to size and installed the insulating washers. Then I omitted the step of running the ground wires! Fortunately my jacks were wired with a 3-conductor shielded cable, so I had an idle wire in the cable already. I spent a few hours today getting those cables adjusted so that i could connect the idle conductor. I had to leave before I could get it all wired up to test, but I think this was one of my biggest problems. Thanks again to Charlie for the strategy. Now that I have the equipment and systems in place, I can test the rest of the wiring as I go, adding one source at a time to make sure that I don't have any other problems. This wasn't an option during the initial wiring, because I didn't have the avionics on hand yet. One thing that I haven't done yet is to run a separate ground wire for the 3.5mm audio in and audio out jacks, which are mounted in the panel. Should I try to isolate their grounds? I'm not sure if I'll be able to find an insulating washer in that size anyway. Chris's concern is a good one, which Flightcom addresses by installing a little toggle switch at each jack station. In mono mode it opens the circuit between the second audio output and the intercom. In stereo mode it closes the circuit. If you configure it incorrectly, the result is either a tone or a non-stereo output, depending on the situation. That function appears to be working. On Sat, Apr 6, 2013 at 3:14 PM, Christopher Cee Stone wrote: > Jared... > > One other potential low impedance fault is if using stereo headphone jacks > and connecting both tip and ring to audio high. When a mono headphone plug > is used it shorts the ring to audio lo (ground) and results in low or no > audio from the connected source(s). > > Chris Stone > RV-8 > > > On Sat, Apr 6, 2013 at 4:52 AM, Jared Yates wrote: >> >> >> >> Thank you very much Charlie, I'll try those procedures and report back >> when complete. >> >> >> >> On Apr 5, 2013, at 20:46, Charlie England wrote: >> >> > >> > >> > On 04/05/2013 03:40 PM, Jared Yates wrote: >> >> >> >> >> >> I've been testing my audio system and have encountered poor >> >> performance. Does anyone have any suggestions for what to check? >> >> Here is the problem: >> >> >> >> All audio through the headsets is too quiet, and pretty scratchy. This >> >> applies to radio reception, intercom audio, Dynon voice out, and music >> >> input. With the intercom volume, headset volume, and individual device >> >> volume all the way up, the total volume is about where I would want to >> >> have it with 25% volume selected instead. The issue seems to afflict >> >> each of the various inputs to a similar degree. >> >> >> >> Here is the setup: >> >> New construction, wired by me (a non-professional, so anything is >> >> possible) >> >> The airframe is a steel tube 4-place fuselage with the mic and audio >> >> headset jacks isolated from ground, as verified by voltmeter >> >> continuity checks. >> >> I used shielded cables to connect the intercom and the mic and stereo >> >> phone jacks, with the shields connected at intercom end to each other >> >> and not connected to anything at the jacks. >> >> I have a self-assembled AEC 9009 Audio Iso Amp handling VHF nav audio >> >> on one channel, dynon warnings on one channel, left music in on one >> >> channel, and right music in on one channel, with the 9009's output >> >> going into the intercom aux input >> >> The intercom is a Flightcom 403, with the pilot wires going to the >> >> left front seat, copilot wires to the right front seat, and passenger >> >> jacks to the back two seats. >> >> The GNS430 is the only radio, with com audio routed directly to the >> >> intercom per the intercom directions. >> >> I'm testing with two known-good David Clark headsets (one stereo, one >> >> mono) and one brand new Lightspeed headset, all with freshly buffed, >> >> shiny connectors. >> >> I'm using battery power only, since the engine is not installed >> >> presently. I've tried the battery by itself and the battery with the >> >> charger connected. The voltage range is about 13v to 14v for those >> >> two cases, but I can't see that changing from one to the other makes >> >> any difference in the audio system issues. >> >> >> >> Here is what I have tried so far with no improvements: >> >> First, I unplugged aec9009. I lost the channels that run through it, >> >> but the remaining intercom and VHF com audio were still the same. >> >> Then I swapped intercom for the bypass plug that I built per the >> >> intercom manual. this plug is designed to connect the pilot seat >> >> jacks directly to the radio, so that the airplane can still function >> >> as a single-place if the intercom is removed entirely. As with the >> >> 9009, I lose intercom function in this configuration (as I should), >> >> but the vhf com audio is still weak and scratchy. >> >> I tried changing the Headsets around in various combinations to >> >> various seats with no appreciable change. >> >> I changed out the volume resistors in the AEC9009 to increase the >> >> volume of those channels, and the volume did go up on the channel in >> >> question, but the quality really suffered. >> >> I'm not really sure what to try next. Does anyone have any >> >> suggestions for what to check? >> > The fuzzy part sounds like some segment in the audio chain is being >> > overdriven by a source, or is being asked to supply more than it's capable >> > of giving. The low level could be too much of a load on the output (load >> > impedance too low). A partial short to ground (from an audio 'hi' to an >> > audio 'Lo', or to the chassis) is the 1st thing that comes to mind. Having >> > both fuzzy & low volume from multiple sources *might* mean that you have two >> > or more outputs trying to feed into each other, with no isolation resistors >> > between them. (This will make all affected outputs 'think' that they are >> > effectively shorted to ground because each is trying to drive a very low >> > impedance load.) >> > >> > So to proceed, 'Divide & conquer.' >> > >> > It's extremely unlikely that you have the same problem with every >> > source, so job one is eliminating the known-good items. I'd get a set of >> > clip leads, and extra phone jack, & start testing each source by itself, >> > without it connected to any other component. Isolate the output line >> > (typically 'audio hi' on the hookup diagram) from the rest of the plane. >> > Hook a clip lead from that wire to the tip terminal of your spare jack. Hook >> > another clip lead from the ground ('audio Lo') to the shield (ground) >> > terminal of the jack. Plug in a known-good headset & listen to that source. >> > Sound ok? If not troubleshoot settings, ground paths, etc. If good, move to >> > the next source & repeat. Annddd repeat, until you've checked all or until >> > you find a bad component. >> > >> > If all is good, hook one (and only one) source to the iso amp & move >> > your test jack to the iso amp's output (with it hooked to nothing else). If >> > bad, there's your problem. All good? that means the iso amp is almost >> > certainly good, too. >> > >> > Hook the iso amp to the intercom's input again (with nothing else hooked >> > to the input). Move the test jack to the intercom's output (with nothing >> > else hooked up to the output lead). Listen again. If bad, check intercom >> > settings (especially if there is an internal gain setting or aux input >> > volume control in the intercom). >> > >> > All good? Without hooking up the 430, add one component to the iso amp & >> > check for level/quality at the intercom output. (We've actually skipped a >> > few steps by doing this, but if one iso input is good, odds are high that >> > all will be good.) >> > >> > All sources (except 430) good? Use your test jack to check the 430, with >> > its output connected to nothing but the test jack. Bad? There's your >> > problem. Good? Proceed. >> > >> > Now look at how the 430 ties to the intercom. In your message, you say >> > that the iso amp is hooked direct to the intercom. Is this a separate input >> > on the intercom? It probably is, but if it's tied to the same input with the >> > iso amp, that might well be your problem. Different input? Move your test >> > jack to the intercom output & listen to the 430 through the intercom. Bad? >> > Re-check wiring & intercom settings, then check the intercom itself, if >> > possible. Still good? Re-check your headphone wiring harness in the plane. >> > >> > Having said all that, I'll say this: I've worked on a couple of 430 >> > installations for friends, & they can be real snakes to troubleshoot. The >> > most common issue is ground pins on the d-Sub connectors. There are quite a >> > few, & if you miss one, stuff isn't going to work (not every ground terminal >> > is common to every other ground terminal in those d-Sub connectors). On one >> > system, I spoke with directly to a Garmin factory tech while holding the >> > installation manual in my hand, and read off the pins that were connected. >> > Even the Garmin tech failed to mention a (ground) pin that needed to be >> > connected. >> > >> > Charlie >> > (pro audio tech, consumer electronics tech and industrial electronics >> > tech in various former lives) >> > >> > >> > >> > >> >> >> ========== >> - >> ric-List" >> target="_blank">http://www.matronics.com/Navigator?AeroElectric-List >> ========== >> MS - >> k">http://forums.matronics.com >> ========== >> e - >> -Matt Dralle, List Admin. >> t="_blank">http://www.matronics.com/contribution >> ========== >> >> >> > > ________________________________________________________________________________
Date: Apr 10, 2013
Subject: Re: Ebus Diode
Thanks Bob. I'll give it a check with the Eric finger temperature scale too. On 3 April 2013 19:14, Robert L. Nuckolls, III wrote: > > > At 11:45 AM 4/3/2013, you wrote: >> >> >> >> Well, that's more tricky. The firewall on this plane (Jodel) is a >> sandwich of plywood and balsa... so I'm hoping the heatsink will >> suffice. Worse-case scenario -- I could move the diode to the engine >> compartment side of the firewall, which is covered with a thin sheet >> of stainless steel. > > > Hmmmm . . . okay. The heat sink you built > up from sheet metal will be fine. Don't > move it to the other side of the firewall. > > > Bob . . . > > ________________________________________________________________________________
Date: Apr 10, 2013
Thanks Rick. A handy device and good price too. Not sure it would make sense getting it across the pond, but I note that similar devices are available for about the same money. It could be a useful and interesting investment. James On 3 April 2013 16:35, Richard Girard wrote: > James, One of these should give you some numbers to play with to see how > well your heatsink is working as you ebuss is loaded up. > > http://www.harborfreight.com/infrared-thermometer-with-laser-targeting-non-contact-69465.html > > Harbor Freight has a coupon out this month that reduces the price a further > $10 to $25.99. > Just a thought > > Rick Girard > > > On Wed, Apr 3, 2013 at 9:41 AM, James Kilford wrote: >> >> Thanks Bob, I have a theoretical max load of a little under 7A. >> >> I agree with your sentiments about the essential bus. I don't anticipate >> needing it... but it's nice to know that it's there... >> >> James >> >> On 3 April 2013 14:52, Robert L. Nuckolls, III >> wrote: >>> >>> >>> >>> At 07:31 AM 4/3/2013, you wrote: >>>> >>>> On a related note, is there a way to determine if a heatsink is large >>>> enough? >>>> >>>> I made a heatsink out of some scrap .020" aluminium -- half a dozen >>>> pieces of varying lengths, stacked and folded up at the ends to form fins. >>>> I've bolted it under the rectifier with some heatsink paste. >>>> >>>> >>>> Seems like quite a lot of aluminium, and plenty of surface area, but it >>>> would nice to find a way of evaluating its effectiveness... other than >>>> waiting for the smell of burning semiconductor... >>> >>> >>> What are your e-bus normal running loads? >>> I would not expect loads of 10A or less to >>> call for anything other than to simply mount >>> the diode a metal surface in the airplane. >>> >>> I could run some tests here for higher currents >>> but keep in mind that the e-bus is for 'endurance' >>> loads . . . minimal equipment to conduct the >>> en route phase of flight . . . reduced energy >>> demands to save the battery for approach to >>> landing. >>> >>> I suggested that big fat diode because of it's >>> convenience for mounting and wiring. The fact that >>> it is rated for 25 or 35 amps was in no way intended >>> to suggest that e-bus loads should/could be >>> that large. >>> >>> The e-bus is a risk reduction feature that is >>> not likely to be needed more than once over the >>> lifetime of your airplane. It's a feature that >>> offers a degrees of System Reliability that >>> reduces probability that a main alternator failure >>> will cause you to break a sweat. >>> >>> As a renter, I have never enjoyed access to features >>> that we're building into OBAM aircraft. My personal >>> endurance package was carried around in the flight >>> bag. http://tinyurl.com/d5mrjgh >>> >>> In fact, I've not turned a VOR receiver on in nearly >>> 20 years. Not since I discovered the capabilities >>> of hand-held GPS receivers that were so cheap I could >>> give them away as door prizes at my seminars! My last >>> cross-country sojourns were managed with dual >>> GPS receivers stuck between the glare-shield and >>> windshield with little wads of windshield sealant. >>> >>> It didn't matter if the airplane was a J-3 or A-36, >>> I was confident in my ability to get from point A to >>> Point B whether the ship's electrical system was >>> fully functional or not. That's a high degree of >>> failure tolerance and system reliability. >>> >>> >>> >>> Bob . . . >>> >>> >>> =================================== >>> - >>> ric-List" >>> target="_blank">http://www.matronics.com/Navigator?AeroElectric-List >>> =================================== >>> MS - >>> k">http://forums.matronics.com >>> =================================== >>> e - >>> -Matt Dralle, List Admin. >>> t="_blank">http://www.matronics.com/contribution >>> =================================== >>> >>> >>> >> >> >> >> ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> > > > -- > Zulu Delta > Mk IIIC > Thanks, Homer GBYM > > It isn't necessary to have relatives in Kansas City in order to be unhappy. > - Groucho Marx > > ________________________________________________________________________________
Date: Apr 10, 2013
From: Henador Titzoff <henador_titzoff(at)yahoo.com>
Everyone,=0A=0AIt isn't given on the website below what this device's tempe rature range is, so I downloaded the manual.- Here are the specs:=0A* Measurement Range: -36F to 968F (-38C to 520C)=0A* Accuracy: =B12% above 32F, =B14.5% below 41F=0A=0AIf you have uncalibrated fingers, this may be the way to go. :)=0A-=0AHenador Titzoff=0A=0A=0A_________________________ _______=0A From: James Kilford <james(at)etravel.org>=0ATo: aeroelectric-list@ matronics.com =0ASent: Wednesday, April 10, 2013 8:38 AM=0ASubject: Re: Aer ames Kilford =0A=0AThanks Rick.- A handy device and go od price too.- Not sure it would=0Amake sense getting it across the pond, but I note that similar devices=0Aare available for about the same money. - It could be a useful and=0Ainteresting investment.=0A=0AJames=0A=0A=0A =0AOn 3 April 2013 16:35, Richard Girard wrote:=0A> J ames, One of these should give you some numbers to play with to see how=0A> well your heatsink is working as you ebuss is loaded up.=0A>=0A> http://ww w.harborfreight.com/infrared-thermometer-with-laser-targeting-non-contact-6 9465.html=0A>=0A> Harbor Freight has a coupon out this month that reduces t he price a further=0A> $10 to $25.99.=0A> Just a thought=0A>=0A> Rick Girar d=0A>=0A>=0A> On Wed, Apr 3, 2013 at 9:41 AM, James Kilford <james@etravel. org> wrote:=0A>>=0A>> Thanks Bob, I have a theoretical max load of a little under 7A.=0A>>=0A>> I agree with your sentiments about the essential bus. - I don't anticipate=0A>> needing it... but it's nice to know that it's t here...=0A>>=0A>> James=0A>>=0A>> On 3 April 2013 14:52, Robert L. Nuckolls , III=0A>> wrote:=0A>>>=0A>>> --> AeroElect ric-List message posted by: "Robert L. Nuckolls, III"=0A>>> <nuckolls.bob@a eroelectric.com>=0A>>>=0A>>> At 07:31 AM 4/3/2013, you wrote:=0A>>>>=0A>>>> On a related note, is there a way to determine if a heatsink is large=0A>> >> enough? =C2=0A>>>>=0A>>>> I made a heatsink out of some scrap .020" alum inium -- half a dozen=0A>>>> pieces of varying lengths, stacked and folded up at the ends to form fins. =C2=0A>>>> I've bolted it under the rectifier with some heatsink paste. =C2=0A>>>>=0A>>>>=0A>>>> Seems like quite a lot o f aluminium, and plenty of surface area, but it=0A>>>> would nice to find a way of evaluating its effectiveness... other than=0A>>>> waiting for the s mell of burning semiconductor...=0A>>>=0A>>>=0A>>>- - What are your e- bus normal running loads?=0A>>>- - I would not expect loads of 10A or less to=0A>>>- - call for anything other than to simply mount=0A>>>- - the diode a metal surface in the airplane.=0A>>>=0A>>>- - I coul d run some tests here for higher currents=0A>>>- - but keep in mind th at the e-bus is for 'endurance'=0A>>>- - loads . . . minimal equipment to conduct the=0A>>>- - en route phase of flight . . . reduced energy =0A>>>- - demands to save the battery for approach to=0A>>>- - la nding.=0A>>>=0A>>>- - - I suggested that big fat diode because of it 's=0A>>>- - convenience for mounting and wiring. The fact that=0A>>> - - it is rated for 25 or 35 amps was in no way intended=0A>>>- - to suggest that e-bus loads should/could be=0A>>>- - that large.=0A>> >=0A>>>- - The e-bus is a risk reduction feature that is=0A>>>- - not likely to be needed more than once over the=0A>>>- - lifetime of your airplane. It's a feature that=0A>>>- - offers a degrees of System Reliability that=0A>>>- - reduces probability that a main alternator failure=0A>>>- - will cause you to break a sweat.=0A>>>=0A>>>- - As a renter, I have never enjoyed access to features=0A>>>- - that we' re building into OBAM aircraft. My personal=0A>>>- - endurance package was carried around in the flight=0A>>>- - bag. http://tinyurl.com/d5m rjgh=0A>>>=0A>>>- - In fact, I've not turned a VOR receiver on in near ly=0A>>>- - 20 years. Not since I discovered the capabilities=0A>>>- - of hand-held GPS receivers that were so cheap I could=0A>>>- - g ive them away as door prizes at my seminars! My last=0A>>>- - cross-co untry sojourns were managed with dual=0A>>>- - GPS receivers stuck bet ween the glare-shield and=0A>>>- - windshield with little wads of wind shield sealant.=0A>>>=0A>>>- - It didn't matter if the airplane was a J-3 or A-36,=0A>>>- - I was confident in my ability to get from point A to=0A>>>- - Point B whether the ship's electrical system was=0A>>> - - fully functional or not. That's a high degree of=0A>>>- - fai lure tolerance and system reliability.=0A>>>=0A>>>=0A>>>=0A>>>- Bob . . .=0A>>>=0A>>>=0A>>> ================== ===================0A>>> -=0A>>> ric-Li st"=0A>>> target="_blank">http://www.matronics.com/Navigator?AeroElectric -List=0A>>> ===================== ================0A>>> MS -=0A>>> k">http://fo rums.matronics.com=0A>>> ================ =====================0A>>> e -=0A>> >- - - - - -Matt Dralle, List Admin.=0A>>> t="_blank">http://ww w.matronics.com/contribution=0A>>> ============= ========================0A>>> =0A>>>=0A>>>=0A>>=0A>>=0A>>=0A>> ist" target="_blank">http://www.matronic s.com/Navigator?AeroElectric-List=0A>> tp://forums.matronics.com=0A>> _blan k">http://www.matronics.com/contribution=0A>>=0A>=0A>=0A>=0A> --=0A> Zulu D elta=0A> Mk IIIC=0A> Thanks, Homer GBYM=0A>=0A> It isn't necessary to have relatives in Kansas City in order to be unhappy.=0A>- - Groucho Marx=0A> = ________________________________________________________________________________
Date: Apr 10, 2013
I think my audio problems are just about resolved. The only problem left is when I connect the AEC amp to the intercom inputs, the sound is loud and distorted. When I connect those outputs directly to the aviation headset jack instead, it sounds great. Flightcom says that they are expecting the input to be from something like an mp3 player. I'm taking the output from the AEC's pins 6 and 6. What do I need to put in those lines to bring the AEC's output to something similar to an mp3 player? Flightcom suggests "dual 10k audio taper" potentiometers when connecting 8 ohm speaker inputs, but I'm not sure if the output from the AEC is 8 ohm. On Apr 5, 2013, at 16:40, Jared Yates wrote: > I've been testing my audio system and have encountered poor > performance. Does anyone have any suggestions for what to check? > Here is the problem: > > All audio through the headsets is too quiet, and pretty scratchy. This > applies to radio reception, intercom audio, Dynon voice out, and music > input. With the intercom volume, headset volume, and individual device > volume all the way up, the total volume is about where I would want to > have it with 25% volume selected instead. The issue seems to afflict > each of the various inputs to a similar degree. > > Here is the setup: > New construction, wired by me (a non-professional, so anything is possible) > The airframe is a steel tube 4-place fuselage with the mic and audio > headset jacks isolated from ground, as verified by voltmeter > continuity checks. > I used shielded cables to connect the intercom and the mic and stereo > phone jacks, with the shields connected at intercom end to each other > and not connected to anything at the jacks. > I have a self-assembled AEC 9009 Audio Iso Amp handling VHF nav audio > on one channel, dynon warnings on one channel, left music in on one > channel, and right music in on one channel, with the 9009's output > going into the intercom aux input > The intercom is a Flightcom 403, with the pilot wires going to the > left front seat, copilot wires to the right front seat, and passenger > jacks to the back two seats. > The GNS430 is the only radio, with com audio routed directly to the > intercom per the intercom directions. > I'm testing with two known-good David Clark headsets (one stereo, one > mono) and one brand new Lightspeed headset, all with freshly buffed, > shiny connectors. > I'm using battery power only, since the engine is not installed > presently. I've tried the battery by itself and the battery with the > charger connected. The voltage range is about 13v to 14v for those > two cases, but I can't see that changing from one to the other makes > any difference in the audio system issues. > > Here is what I have tried so far with no improvements: > First, I unplugged aec9009. I lost the channels that run through it, > but the remaining intercom and VHF com audio were still the same. > Then I swapped intercom for the bypass plug that I built per the > intercom manual. this plug is designed to connect the pilot seat > jacks directly to the radio, so that the airplane can still function > as a single-place if the intercom is removed entirely. As with the > 9009, I lose intercom function in this configuration (as I should), > but the vhf com audio is still weak and scratchy. > I tried changing the Headsets around in various combinations to > various seats with no appreciable change. > I changed out the volume resistors in the AEC9009 to increase the > volume of those channels, and the volume did go up on the channel in > question, but the quality really suffered. > I'm not really sure what to try next. Does anyone have any > suggestions for what to check? ________________________________________________________________________________
Date: Apr 10, 2013
I bought one of these on eBay not too long ago for even less (delivered) than HF's price. The one I got has a lighted display, C and F temp displays, on/off selectable laser aiming spot, display hold button and temp range of -50C to 380C. It even came with a 9V battery. Works beautifully. Make and model are "SainSonic SS5380". This [http://bit.ly/10LgGez ] and this [ http://bit.ly/10V8tnP ] have different markings but appear otherwise identical, right down to the brand of battery. Eric On Apr 10, 2013, at 5:38 AM, James Kilford wrote: > Thanks Rick. A handy device and good price too. Not sure it would make sense getting it across the pond, but I note that similar devices are available for about the same money. It could be a useful and interesting investment. > > James > > > On 3 April 2013 16:35, Richard Girard wrote: >> James, One of these should give you some numbers to play with to see how well your heatsink is working as you ebuss is loaded up. >> >> http://www.harborfreight.com/infrared-thermometer-with-laser-targeting-non-contact-69465.html >> >> Harbor Freight has a coupon out this month that reduces the price a further $10 to $25.99. >> Just a thought >> >> Rick Girard ________________________________________________________________________________
Date: Apr 10, 2013
Thanks Eric. Appreciate the update. On 10 April 2013 17:27, Y! edpav8r wrote: > > I bought one of these on eBay not too long ago for even less (delivered) than HF's price. The one I got has a lighted display, C and F temp displays, on/off selectable laser aiming spot, display hold button and temp range of -50C to 380C. It even came with a 9V battery. Works beautifully. > > Make and model are "SainSonic SS5380". > > This [http://bit.ly/10LgGez ] and this [ http://bit.ly/10V8tnP ] have different markings but appear otherwise identical, right down to the brand of battery. > > Eric > > > On Apr 10, 2013, at 5:38 AM, James Kilford wrote: >> Thanks Rick. A handy device and good price too. Not sure it would make sense getting it across the pond, but I note that similar devices are available for about the same money. It could be a useful and interesting investment. >> >> James >> >> >> On 3 April 2013 16:35, Richard Girard wrote: >>> James, One of these should give you some numbers to play with to see how well your heatsink is working as you ebuss is loaded up. >>> >>> http://www.harborfreight.com/infrared-thermometer-with-laser-targeting-non-contact-69465.html >>> >>> Harbor Freight has a coupon out this month that reduces the price a further $10 to $25.99. >>> Just a thought >>> >>> Rick Girard > > ________________________________________________________________________________
Date: Apr 10, 2013
Scratchy At 10:58 AM 4/10/2013, you wrote: > >I think my audio problems are just about resolved. The only problem >left is when I connect the AEC amp to the intercom inputs, the sound >is loud and distorted. When I connect those outputs directly to the >aviation headset jack instead, it sounds great. Flightcom says that >they are expecting the input to be from something like an mp3 >player. I'm taking the output from the AEC's pins 6 and 6. What do >I need to put in those lines to bring the AEC's output to something >similar to an mp3 player? Flightcom suggests "dual 10k audio taper" >potentiometers when connecting 8 ohm speaker inputs, but I'm not >sure if the output from the AEC is 8 ohm. Sounds like the gain of the amplifier is too high. The 150 ohm resistors shown on each of the audio input lines are suggested starting points. You can adjust these for independent control of audio level from each source. The gain needs to be controlled at the input to the amplifier. Adding a potentiometer after the amplifier would reduce the intensity of the signal but it may well still be distorted if the amplifier is being over driven. How does the audio sound if you hook a headset directly to the isolation amplifier before it goes into the intercom? Bob . . . ________________________________________________________________________________
Scratchy
Date: Apr 10, 2013
It sounds great when I bypass the intercom. On Apr 10, 2013, at 14:11, "Robert L. Nuckolls, III" wrote: > > At 10:58 AM 4/10/2013, you wrote: >> >> I think my audio problems are just about resolved. The only problem left is when I connect the AEC amp to the intercom inputs, the sound is loud and distorted. When I connect those outputs directly to the aviation headset jack instead, it sounds great. Flightcom says that they are expecting the input to be from something like an mp3 player. I'm taking the output from the AEC's pins 6 and 6. What do I need to put in those lines to bring the AEC's output to something similar to an mp3 player? Flightcom suggests "dual 10k audio taper" potentiometers when connecting 8 ohm speaker inputs, but I'm not sure if the output from the AEC is 8 ohm. > > Sounds like the gain of the amplifier is > too high. The 150 ohm resistors shown > on each of the audio input lines are > suggested starting points. You can adjust > these for independent control of audio > level from each source. > > The gain needs to be controlled at > the input to the amplifier. Adding a > potentiometer after the amplifier would > reduce the intensity of the signal but > it may well still be distorted if the > amplifier is being over driven. > > How does the audio sound if you hook > a headset directly to the isolation > amplifier before it goes into the intercom? > > > > Bob . . . > > > > ________________________________________________________________________________
Scratchy
Date: Apr 10, 2013
Also, I just found that the amp ics are getting very hot. On Apr 10, 2013, at 14:11, "Robert L. Nuckolls, III" wrote: > > At 10:58 AM 4/10/2013, you wrote: >> >> I think my audio problems are just about resolved. The only problem left is when I connect the AEC amp to the intercom inputs, the sound is loud and distorted. When I connect those outputs directly to the aviation headset jack instead, it sounds great. Flightcom says that they are expecting the input to be from something like an mp3 player. I'm taking the output from the AEC's pins 6 and 6. What do I need to put in those lines to bring the AEC's output to something similar to an mp3 player? Flightcom suggests "dual 10k audio taper" potentiometers when connecting 8 ohm speaker inputs, but I'm not sure if the output from the AEC is 8 ohm. > > Sounds like the gain of the amplifier is > too high. The 150 ohm resistors shown > on each of the audio input lines are > suggested starting points. You can adjust > these for independent control of audio > level from each source. > > The gain needs to be controlled at > the input to the amplifier. Adding a > potentiometer after the amplifier would > reduce the intensity of the signal but > it may well still be distorted if the > amplifier is being over driven. > > How does the audio sound if you hook > a headset directly to the isolation > amplifier before it goes into the intercom? > > > > Bob . . . > > > > ________________________________________________________________________________
Scratchy
Date: Apr 10, 2013
I think I might have found one problem with some incorrect resistors on the 317. On Apr 10, 2013, at 14:11, "Robert L. Nuckolls, III" wrote: > > At 10:58 AM 4/10/2013, you wrote: >> >> I think my audio problems are just about resolved. The only problem left is when I connect the AEC amp to the intercom inputs, the sound is loud and distorted. When I connect those outputs directly to the aviation headset jack instead, it sounds great. Flightcom says that they are expecting the input to be from something like an mp3 player. I'm taking the output from the AEC's pins 6 and 6. What do I need to put in those lines to bring the AEC's output to something similar to an mp3 player? Flightcom suggests "dual 10k audio taper" potentiometers when connecting 8 ohm speaker inputs, but I'm not sure if the output from the AEC is 8 ohm. > > Sounds like the gain of the amplifier is > too high. The 150 ohm resistors shown > on each of the audio input lines are > suggested starting points. You can adjust > these for independent control of audio > level from each source. > > The gain needs to be controlled at > the input to the amplifier. Adding a > potentiometer after the amplifier would > reduce the intensity of the signal but > it may well still be distorted if the > amplifier is being over driven. > > How does the audio sound if you hook > a headset directly to the isolation > amplifier before it goes into the intercom? > > > > Bob . . . > > > > ________________________________________________________________________________
Date: Apr 10, 2013
Scratchy At 02:24 PM 4/10/2013, you wrote: > >I think I might have found one problem with some incorrect resistors >on the 317. oops . . . that could be a problem. After the correct resistors are in place, measure the voltage at pin 6 of the amplifier chips should be about 9v. Voltage on pin 5 should be about half that. Bob . . . ________________________________________________________________________________
Scratchy
Date: Apr 10, 2013
Thanks Bob, I'll check that and report back. It turns out the resistors were correct, but my EE friend thought at first that they weren't. On Apr 10, 2013, at 17:17, "Robert L. Nuckolls, III" wrote: > > At 02:24 PM 4/10/2013, you wrote: >> >> I think I might have found one problem with some incorrect resistors on the 317. > > oops . . . that could be a problem. After the > correct resistors are in place, measure the > voltage at pin 6 of the amplifier chips > should be about 9v. Voltage on pin 5 should > be about half that. > > > > Bob . . . > > > > ________________________________________________________________________________
Date: Apr 10, 2013
Subject: Terminals to fit crimper
Greetings, I have a Lawson crimper (95102 old style)<http://www.lawsonproducts.com/lawson/TermCrimp-Frame/95102.lp?_requestid=146002> with dies (95103) <http://www.lawsonproducts.com/lawson/TermCrimp-Die-22-10-AWG/95103.lp>. The dies have the undesirable .116 space between the crushing surfaces. I have tried PIDG terminals but the stress relief crimp is unacceptable, per Bob's information. Is there a terminal available that can be crimped onto 22ga. tezfel wireproperly. I'm not going to have alot of wiring on my aircraft, so I'm looking at options. Thanks, -- Raymond Julian Kettle River, MN. "And you know that I could have me a million more friends, and all I'd have to lose is my point of view." - John Prine ________________________________________________________________________________
Date: Apr 10, 2013
and Scratchy At 05:02 PM 4/10/2013, you wrote: > >Thanks Bob, I'll check that and report back. It turns out the >resistors were correct, but my EE friend thought at first that they weren't. Hmmm . . . the only other thing that could cause a hot-chip is to have it soldered in backwards. Bob . . . ________________________________________________________________________________
Date: Apr 10, 2013
Subject: Re: Terminals to fit crimper
At 05:42 PM 4/10/2013, you wrote: >Greetings, > >I have a Lawson crimper (95102 old >style)<http://www.lawsonproducts.com/lawson/TermCrimp-Frame/95102.lp?_requestid=146002> >with dies (95103) ><http://www.lawsonproducts.com/lawson/TermCrimp-Die-22-10-AWG/95103.lp>. >The dies have the undesirable .116 space between the crushing >surfaces. I have tried PIDG terminals but the stress relief crimp >is unacceptable, per Bob's information. > >Is there a terminal available that can be crimped onto 22 ga. tezfel >wire properly. > >I'm not going to have a lot of wiring on my aircraft, so I'm looking >at options. > >Thanks, I presume the insulation support is too 'open'. It might be best to just put 1/2-1" piece of heatshrink over the 22AWG to build it up. When the famous Red/Blu_T-head Tool by AMP was king of the toolbox, nylon over pvc was the popular airframe wire . . . fortunately, the insulation grip cam had one more down-size notch on the cam so it works good for Tefzel. It won't grab a Kynar wire . . . Bob . . . ________________________________________________________________________________
and Scratchy
Date: Apr 11, 2013
It looks like I have the audio troubleshooting solved. I replaced the amplifier chips because I had some extras locally and they are cheap. Then I tested the intercom input by connecting my mp3 player directly to the intercom, bypassing the 9009 all together. All was well. Next I removed all of the inputs to the 9009 except the music, and plugged it in. All was well. Next I connected the Dynon voice circuit. It was acceptable, but a little bit loud. I took out the 300 ohm resistor for that channel and tried a 500. The change was small, so I swapped a few more times, arriving eventually at 1.8k. This really surprised me, since I misunderstood and thought of 300 to be near the top end of the scale. Next I reconnected the 430 nav audio to the 9009 and it was way too loud. I jumped right to the 1k, but it was still very loud. After several steps along the way, each astonishingly higher, I settled on 68k. Now everything works well and the chips aren't getting hot. I mention all of this for the benefit of anyone else who will be using the 9009 with these systems- start much higher than 150 ohms! This whole process has given me much more understanding of my audio system, and also a real appreciation for the design of the 9009. Thanks Bob for making it available! I don't know how other folks are getting by without it. On Apr 10, 2013, at 18:21, "Robert L. Nuckolls, III" wrote: > > At 05:02 PM 4/10/2013, you wrote: >> >> Thanks Bob, I'll check that and report back. It turns out the resistors were correct, but my EE friend thought at first that they weren't. > > Hmmm . . . the only other thing that > could cause a hot-chip is to have it > soldered in backwards. > > Bob . . . > > > > > ________________________________________________________________________________
and Scratchy
Date: Apr 12, 2013
Bob's design is the grandaddy of several commercial audio mixers, including at least one other open-source device. It's probably a good idea to have variable inputs (see the AMX-2A or AMX-4B at http://store.makerplane.org/avionics/). You haven't mentioned any objectional audio noise in the system, but in my experience the Dynon EFIS is a fairly noisy device. There are a couple of easy fixes for this, so if you have this problem, let me know. Thanks, Vern -----Original Message----- From: Jared Yates Sent: Thursday, April 11, 2013 8:03 PM Subject: Re: AeroElectric-List: Re: Diagnostic Help Please: Audio is Weak and Scratchy It looks like I have the audio troubleshooting solved. I replaced the amplifier chips because I had some extras locally and they are cheap. Then I tested the intercom input by connecting my mp3 player directly to the intercom, bypassing the 9009 all together. All was well. Next I removed all of the inputs to the 9009 except the music, and plugged it in. All was well. Next I connected the Dynon voice circuit. It was acceptable, but a little bit loud. I took out the 300 ohm resistor for that channel and tried a 500. The change was small, so I swapped a few more times, arriving eventually at 1.8k. This really surprised me, since I misunderstood and thought of 300 to be near the top end of the scale. Next I reconnected the 430 nav audio to the 9009 and it was way too loud. I jumped right to the 1k, but it was still very loud. After several steps along the way, each astonishingly higher, I settled on 68k. Now everything works well and the chips aren't getting hot. I mention all ! of this for the benefit of anyone else who will be using the 9009 with these systems- start much higher than 150 ohms! This whole process has given me much more understanding of my audio system, and also a real appreciation for the design of the 9009. Thanks Bob for making it available! I don't know how other folks are getting by without it. On Apr 10, 2013, at 18:21, "Robert L. Nuckolls, III" wrote: > > > At 05:02 PM 4/10/2013, you wrote: >> >> >> Thanks Bob, I'll check that and report back. It turns out the resistors >> were correct, but my EE friend thought at first that they weren't. > > Hmmm . . . the only other thing that > could cause a hot-chip is to have it > soldered in backwards. > > Bob . . . > > ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Apr 12, 2013
From: "wynaire(at)citlink.net" <wynaire(at)citlink.net>
Subject: Re: LED heatsink material?
Hernandor, et al... ;)=0ASorry forlate note of appreciated advice. Your rep lies had been routed to a seldom opened spam box.=0AThanks again,=0AMike W. =0A=0AFrom: Henador Titzoff <henador_titzoff(at)yahoo.com>=0A>To: "aeroelectri c-list(at)matronics.com" =0A>Sent: Wednesday , April 3, 2013 3:48 PM=0A>Subject: Re: AeroElectric-List: LED heatsink mat erial?=0A>=0A>=0A>=0A>Hello Mike W.,=0A>=0A>=0A>The short answer is copper. - This is evidenced by each material's thermal conductivity, shown below in SI units:=0A>=0A>=0A>---- Copper - 401 Watt/(meter x Kelvin)=0A> ---- Aluminum - 237 Watt/(meter x Kelvin)=0A>---- Stainless steel - 16.7 Watt/(meter x Kelvin)=0A>=0A>=0A>=0A>The above data came from : http://en.wikipedia.org/wiki/List_of_thermal_conductivities=0A>=0A>=0A>Th ermal conductivity is the property of a material to conduct heat. As you ca n see, copper conducts heat 1.7 times better than aluminum and 24 times bet ter than a certain type of stainless steel. There are other things to consi der but since your mounting plate is your reflector and you are stuck with its dimensions, form factor and coating.- If you are looking for the best conductor, copper is the choice.- This also assumes that you are not con cerned with weight or corrosion.=0A>=0A>=0A>Henador Titzoff=0A>=0A>=0A>=0A> =0A>From: "wynaire(at)citlink.net" <wynaire(at)citlink.net>=0A>To: "aeroelectric- list(at)matronics.com" =0A>Sent: Wednesday, April 3, 2013 4:43 PM=0A>Subject: AeroElectric-List: LED heatsink material? =0A>=0A>=0A>Hello All,=0A>Your thoughts or lessons from experience: =0A>I a m mounting two (2) each 10Watt LED's (R/G color and -white [6500k] in eac h wing tip, under a clear tip lens. The mounting plate (polished for reflec tivity) can be copper or SS or aluminum. Which material is the best choice for conducting the LED heat away from the LED's?=0A>Thanks in advance for y our suggestions. Any other bits of related info are also appreciated.=0A>Mi ke W.=0A>LNC2 360 @ 88% finished... with 88% to go ;)=0A>=0A>=0A>From: Jame s Kilford =0A>>To: aeroelectric-list(at)matronics.com =0A>> Sent: Wednesday, April 3, 2013 6:31 AM=0A>>Subject: Re: AeroElectric-List: Ebus Diode=0A>>=0A>>=0A>>On a related note, is there a way to determine if a heatsink is large enough? - =0A>>=0A>>=0A>>I made a heatsink out of som e scrap .020" aluminium -- half a dozen pieces of varying lengths, stacked and folded up at the ends to form fins. -I've bolted it under the rectifi er with some heatsink paste. -=0A>>=0A>>=0A>>Seems like quite a lot of al uminium, and plenty of surface area, but it would nice to find a way of eva luating its effectiveness... other than waiting for the smell of burning se miconductor...=0A>>=0A>>=0A>>Many thanks,-=0A>>=0A>>=0A>>James=0A>>=0A>> =0A>>=0A>>On 2 April 2013 16:38, Robert L. Nuckolls, III <nuckolls.bob@aero electric.com> wrote:=0A>>=0A>>At 09:56 AM 4/2/2013, you wrote:=0A>>>=0A>>>T he drawing http://www.bandc.biz/pdfs/Diode_Installation.pdf=0A>>>>From B an d C shows both ~ (I don't have the correct symbol horizontal s with -) term inals powered from the main bus with the + going to the Ebus and - unused. =0A>>>>=0A>>>>Question: I could run power from the main bus to either ~ ter minal and power the Ebus?=0A>>>>=0A>>>>Powering both ~ terminals gains a li ttle redundancy to power the Ebus?=0A>>>- No 'redundancy' just a potentia l tiny improvement in=0A>>>- thermal modeling. Not a big deal one way or another.=0A>>>- Run main bus power to either one or both AC input=0A>>> - terminals, one wire from (+) to e-bus.=0A>>>=0A>>>- Bob . . .=0A>>> =0A>>>=0A>>>- Bob . . . =0A>>>ist" target="_blank">http://www.matronics .com/Navigator?AeroElectric-Listtp://forums.matronics.com_blank">http ========= =0A>=0A> ________________________________________________________________________________
Date: Apr 11, 2013
At 01:01 PM 4/11/2013, you wrote: >I'm just getting ready to order an assortment of terminals. I was >hoping to avoid having to fiddle with every wire. Thanks for the suggestion. Sorry I couldn't be more specific. There's always a need to do an integration study for tool->terminal->wire. It's not uncommon that a particular trio of elements fail to 'come together'. I recall being approached by a company who claimed to offer PIDG equivalent terminals at about 1/2 the price . . . brought in some samples and tried them in my legacy tools. http://tinyurl.com/bwdqu4r . . . close but no cigar. But good on you that you checked the fits before you crimped a bunch of terminals on the wires! Bob . . . ________________________________________________________________________________
Date: Apr 15, 2013
and Scratchy At 10:03 PM 4/11/2013, you wrote: It looks like I have the audio troubleshooting solved. Now everything works well and the chips aren't getting hot. I mention all of this for the benefit of anyone else who will be using the 9009 with these systems- start much higher than 150 ohms! This whole process has given me much more understanding of my audio system, and also a real appreciation for the design of the 9009. Thanks Bob for making it available! I don't know how other folks are getting by without it. Good to hear. I considered putting potentiometers on the board during the development process but discarded the idea in favor of the fixed resistors on a socket. As you've discovered, it takes a bit of fiddling to get them right but it's a once-in-an-installation process that would not benefit much from future adjustability. Thanks for the feedback. Bob . . . ________________________________________________________________________________
Date: Apr 17, 2013
Subject: Re: Butt Splice for #4 wire
At 07:49 AM 4/9/2013, you wrote: >The #4 looked fine as I removed the nut, but as soon as a pulled it >off the lug, the terminal was only hanging on by a couple of thin >wires and a small >piece of the heatshrink. The only thing that had >been keeping it together was the heatshrink and the natural >propensity of the wire to stay in place. >My only explanation is that the 7", or so, of cable between the terminal >end and the first adel clamp, had enough weight and motion to respond >to vibrations, and eventually fatigue the cable. John sent me the carcass and we've had a chance to peek inside the failure . . . Emacs! 95% of the strands failed right outside the crimp . . . a telltale for insufficient insulation support like that offered by PIDG style terminals. A cross-section of the wire grip . . . Emacs! . . . showed good crush . . . no voids. I'm pretty sure that a piece of that extra stiff, two-walled heat-shrink over this assembly would have produced a better story. Bob . . . ________________________________________________________________________________
Date: Apr 20, 2013
Subject: microair transponder/encoder hookup question
Has anyone successfully installed a Microair T2000SFL-01rev8 transponder combined with their EC2002-01rev3 encoder, using serial connection? The manual for the xp rev8 at > http://www.microair.com.au/admin/uploads/documents/T2000SFLInstallationManual01R80.pdf shows *2* data lines between the components: encoder pin6data receive to xp pin 5data transmit, and encoder pin 7data transmit to xp pin 4data receive. *But*... note 7 on the hookup page (pg 13) says that the diagram is applicable to revs 5,6, & 7. I can't find an install manual for the 01rev3 encoder on their web site, but the manual for the 01rev12 shows pin 6 of the encoder (labeled rs232in) as unconnected. However.... Looking at the page on their pre-wired harnesses at http://www.microair.com.au/index.aspx?page=186&productID=36 The diagram for wiring their xp to their encoder shows encoder pin 6 (data receive) to be *grounded*. So, various docs on the Microair website show the encoder pin 6 to be: open, tied to transponder pin 5, and grounded (through the harness) to the case of the transponder. Anyone have any words of wisdom on the *right* way to do it? Thanks, Charlie <http://www.microair.com.au/index.aspx?page=186&productID=26> ________________________________________________________________________________
Date: Apr 21, 2013
Subject: Li-Ion Battery Failure Analysis
I ran across this document by the Exponent Failure Analysis Associates that speaks to one of many studies being conducted on Li-Ion battery failures. http://tinyurl.com/cbxqa6e The words 'shorts' + 'shorting' appear 44 times with particular interest in micro-shorts that arise from failures and/or manufacturing defects in separators. Seems there are no process or inspection controls that will keep these defects from finding their way into finished cells . . . but there's a possibility that cells can be screened for such defects before being assembled into finished goods. It's pretty heavy reading . . . I'm going to keep it on the laptop for the next time I have to sit on an airplane for several hours. BTW . . . there's a rumor running around that the Cessna ramp fire in the Citation battery was precipitated by connection of the wrong ground power cart . . . I'm still looking for credible confirmation/explanation of the assertion. Bob . . . ________________________________________________________________________________
Date: Apr 21, 2013
Subject: Re: microair transponder/encoder hookup question
Looking at the page on their pre-wired harnesses at http://www.microair.com.au/index.aspx?page=186&productID=36 The diagram for wiring their xp to their encoder shows encoder pin 6 (data receive) to be *grounded*. So, various docs on the Microair website show the encoder pin 6 to be: open, tied to transponder pin 5, and grounded (through the harness) to the case of the transponder. Anyone have any words of wisdom on the *right* way to do it? Is this the drawing that has you confused? Emacs! It appears that pin 6 and 15 on the encoder are both ground pins that are tied to harness shield. I doubt that it matters a great deal whether one or both pins are tied to the shield. Bob . . . ________________________________________________________________________________
Date: Apr 21, 2013
On 04/21/2013 07:17 AM, Robert L. Nuckolls, III wrote: > > Looking at the page on their pre-wired harnesses at > http://www.microair.com.au/index.aspx?page=186&productID=36 > > <http://www.microair.com.au/index.aspx?page=186&productID=36>The > diagram for wiring their xp to their encoder shows encoder pin 6 (data > receive) to be *grounded*. > > So, various docs on the Microair website show the encoder pin 6 to be: > open, tied to transponder pin 5, and grounded (through the harness) to > the case of the transponder. > > Anyone have any words of wisdom on the *right* way to do it? > > > *Is this the drawing that has you confused? > > Emacs! > > It appears that pin 6 and 15 on the encoder are both ground > pins that are tied to harness shield. I doubt that it matters > a great deal whether one or both pins are tied to the shield. > > * > > Bob . . . > It would appear that way from the drawing, but pin 6 is, in fact, *not* tied to ground in the encoder; it is floating with respect to ground. And in the xp manual, it mentions that the xp can tell the encoder what data format to use in serial mode, implying a need for a comm line to move data from the xp to the encoder. When wired as shown above, the xp reports 'no altitude' in its display (it will show encoder altitude) even when the comm format DIP switches are set properly in the encoder. Note that there's no drawn connection between encoder pin 7 & xp pin 5, both of which are labeled 'serial alt data TX'. On similar drawings in other docs, they show what's apparently connections between encPin7 TX-xpPin4RX and encPin6RX-xpPin5TX (but again, no actual connection in the drawings; just the order of the pins in the drawings. Note the different pin in the xp tied to the encoder's pin7TX. The image below was clipped from the transponder install manual. (Sorry for the blurry image; I'm using Linux & Adobe Reader seems to be a bit buggy in Linux.) Charlie /9j/4AAQSkZJRgABAQAAAQABAAD/2wBDAAEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEB AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQH/2wBDAQEBAQEBAQEBAQEBAQEB AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQH/wAAR CACUBZ4DASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAA AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkK FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWG h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl 5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREA AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYk NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOE hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk 5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD+/iiiigAooooAKKKKACiiigAoqGfd5Z2M QwIYBQWdtvzhUAkiG4lRwzGMjKyKyFhX5J/tJeIfi14B/wCCmH7Fc/gH4veO9G+Gfjn4M/tQ eNvjr8IbrX9U1v4d/EhfCnxY/YO/Zy+Hc2maDrt3qGmfD298B3f7U+qfEO91XwbDo1n4kvvD Jj19LltZv5yAfrlRX4wan8S/iB8ef+Cqvhn4WS/EX4iaL+yz4e/Zr/bA0W08D+BPHPi/4Z2/ jz47fs6/FD9g6w8U/E+48YfD/wAQeGPEuraH4UX9qbxT8GG0OTXH06x8b/Cj4hTzadPM1ky9 R8PfEnj3UbH9gT9nPRfiz8VtIu/2iP2ffG/7Wfxv+K+reNNY8bfEHxF4d+D3h79mnwz4n+G/ hfxP41l8Rj4fL8Q/H37SngTV77UPCFlpEvhnwd4J+IFt4Qh0HxL4mHjXQQD9d6K/FL9uH4Y/ H34A/s6f8FQvjh4X/aT+Ltt8NvBP7B1z8Vf2WdF/4XB4+uviB8E/2i/gP8P/ANrDxh8RNYfW LmGLWPFPw/8AHFp4g+B9xaaT8SfGnxOfUNe8Na5p19o+laP4e8AxSa+iftq6L4G+H/7c/wAe PhB4V/a18SfBD9kn9nDx18T/ABVoX7UXg343/DzVNQ+Lvw6+H+sfFS08AfDbS/2o/D/h79o2 2u9a8BLY6p8SJPGtl/whOmWeu/CTUvAElrNrfjpHAP2Wor8uPjVY/EX9lf8AY8+JX7VHjT45 /FH4ofG/9nj4T+JP2hviDer4un0H4efEhPhh4Xufid8R/hX4X+DWlzD4Z+HvBPifw74d8T+E PBk8nhfWPH+g6PqWla5J8Qtc8T6Z/wAJPJN/wUV+IH7R8knwe+Bv7IXi278MfHXxL/wtX9oe 4FqmmStrnwz/AGW/BSeII/AF8dW0y78rQ/i5+0B4x/Z0+Evi5rNk1WTwN438evp8o/s66MYB +oNFflz+1BrB8e/Fb/gmT4g8E/Er4u+HPBv7R37RGreBPHOl+Avir4/8DaX45+FC/sHftp/t C+HtNvNL8K+JbCx0rVF+Ivwz+HusXniPw9Np3i59N01NB1TWpPDzTWo8St/i/wCIfCX7YOs/ s3fA68/a18b/ABX0j9pbwAdTtviE/wAe/FH7OOi/snzfCn9nvxh8dLvxL8XfjDDqHw41XV/B ll8TPEFz4Hs/hR4t1v4x6f8AF/xD8LvCHxBjsvA+qatbUAftnRUELM2csGx8vX5shUJMibB5 cjFidgO0JsKg7jtnoAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKhuCy xMUJDBo+Qu4geYu4hd6FiFycAuTjAinOIZPzR1v/AIKGeNtM+PXxe/Z50f8A4J5/t1eN/Fnw X8O+FfHXifxF4Tu/2HZPB2r/AAy8eeJ/ix4R+HfxM8H3PiP9tnwr4n8Q6J8QdQ+CvxDu9F8L ReEbL4oabaaHHa+Kfh14T8QahaaZKAfppRX5lfE3/gpNYeCLr9m2PwP+yL+2B8edI/aou7/w t8LvEnw60/8AZo8ERWfxW0HwZ8XfiN4w+C/xF8M/tIftMfs/eP8A4bfFH4f+CPgZ8Rdf8c6Z 418E6J4V0ifRLjwhH4ruvHNrqnhWD2yP9sPw3efCVfiB4c+GXxh8XeP3+IV58G5/2cPD+nfD 6f466P8AGjSrHUNW8QfCvXjqPxF0/wCDXh7XfDvhzTb3xnqHi/W/i5D8K77wZDbeMfDvjrWv C/iDwpfauAfZNFfDzftv+GL74QP8SvB3wd+OPjvx/bfE6L4H6j+y7oenfDXR/wBoTRvjNFLp 99rHw71uz8b/ABR8MfCbT7vw94KvD8VL/wAZT/FyH4Y6t8IoY/iZ4T8c+KfCev8AhTU9b+pv hn4s8QeOPA2geK/FPwz8cfB3X9Yhu59R+GvxJv8A4b6p438KvDqN5aQ2fiC/+EXjz4n/AA4u Lm6treDUoG8LePfEtmlle2sdxex6gl5aW4B3dFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFfNn7Uf7Uvw h/Y9+F2rfGv47an498P/AAv0CZx4n8V+B/gz8ZvjTF4Q0600fVPEep+JfGWlfBfwH8RdZ8G+ A9L0Xw7qb6/8RfE2j6T4J8PzzafZahr9pqmq2Nte8d8Nv25/2dfi1p3xKm8Ha98S28RfCPwZ L8Q/Hvwo8T/s9/tEfD39oPT/AAStnqFzb+IdK/Zv+IPwt8KftBeKdO146bqFl4Mbwl8MtWuv HOu2Mnh/wRb+IdfZNJoA+xKK+LP2bv29f2a/2s7+90n4IeLPiHqOo6W3jD9z8TP2f/2gfgI2 vn4aeNZ/hx8UovBz/Hf4WfC2L4gz/Czx8kfgf4nw/D8eIT8M/GU+meHPiD/wj2o6zpkF56VZ /tUfs/6r+0Zqv7JGkfFbwzq37R3h34d3nxZ8S/CbSZr6/wDEHhn4fWeo+BtLm1vxRPaWNzpf h67ef4leBryx8P6zqml+IL7RfFGm6/ZabPoCyatGAfRNFfLPhP8Aa7+DXjv43678A/Btx8Wf EvjPwjrWu+G/FfiDSP2dP2hr74HaN4m8P6PZ69rPhW//AGmoPhXH+ztb+L9CguodO1bwunxT k1fTPEX27wVqenx+LrcaQv1NQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFfGP7fP 7RXxb/ZK/Zb+Lv7S3wn+D/gb44N8CvBXjH4tfEXwN43+Nep/A15fhR8OvA/inxp4y1Hwb4k0 74N/GiDWvHMI0CxtNJ8H65o3hTRdXsLzVbw+PNJ1PTrDSdZAPs6ivzO+On/BRnRPgt/wTb8Y f8FDYfhj4g8Xf8In8ILr4g3PwHj1mHRPFtp4+0M/2L4z+D/iDxB/Y+uDRtV+HfjK08RaJ8Sd YtvDWuzeEovBni+/Gj6sNJWxfil/bI/by8MftJfBv4B/F39jz9k/wVpnxN+GHxW+O/if4h+G v2/vid4ztfh18IPgP43+APg/4xXkmgap/wAE/PAzeJPH2hwftE+DtT8LeGP7Y0Lwf4hFlqw1 P4jeHbe3/tVwD9ZqK/H747/8FEP2rfgz+zL8VP2z7P8AYFtvF/7PHgP4N+NfjHoekzftNWPg 39pXUPDXhjwrqXiu0174ifBfVvgzfeBfhj4Qm0jT5fEPiv7D8evHnxZ8C+G0uY7/AOD2o+N9 OvPAabw/b7/aA0Dx1+2FqfxF/Zs+EHhr9mP9iT4w6h8O/jH8YNG/am8V698VYPAkPwT+Ef7R tn8Y7T4J6z+yz4K8KS6Dpfwa+OHgnXPiF4UtfjfJ400LxJpHxD8K/D3SPirc+HfDN142AP1j or5M+M/xj+O+ieNbb4Z/s2/BDwR8YvHdr4Z0zxt4yvPiz8cdQ+A3wy8G+HNf13WtC8KW114p 8NfBz4++NNa8U+K7nwn4wTTtK8O/C++0PS4vDd3ceK/Evh+bVvDaaxo/AP8AaGu/it/wnvhP x54MvfhD8aPhDqGkaT8V/hpqviLSPFFho3/CQaK/iTwx428HeOdIsrHSvGnwr8ZaMLm48L+L 5NN0LUnfR9e8P+KvCvg/x34Y8R+GbQA+oqK+Af2QP22b79tX9nDxv8avhZ8M7Xw94z0fxF45 8PeCvht8RvHV1oWj+IoLzQrD4lfs2eLPFXjzQ/h/4p1fwV4S/aC+Bvjr4KfFsXOn/DXxtrfg LQvifHp0WhfEDUNFSXWPllP28P8Agowll+yJeXf7CX7IkCftreKj4R+Fyv8A8FGfi4D4X1KT 9nH4uftO2o8f+R/wTSuDpkF38Ovgv4ttYJfCsvjy5Pi2fSLG4t7PQ7y51rSwD9pKK8T+C/xK 8Q/Erwpc3PjHwnb+APiH4X1/U/BvxF8E6b4rsfG2k+H/ABdpkWn6g0OgeMbHS9Oi8TaBqvh7 VdH8W+GtRu9H8M6xJoWu6VY+LPDHhrxPBr/h7Q/z1+GH7Zf/AAUV+IPxM+Jfgab9gr9m86X8 A/2rPhR+zT8ddU8Ef8FBvFHiHxJomkfEL4f/ALO/xk8U/GX4eeFfHn7DXwr0Dx54W+HHwe/a K8P+LbzwrrHxG8BeN/EWreG/EfhXw9oGqaq2htrQB+u1Ffn/AOL/ANrb426p4n+JkH7NP7L8 H7QHgL4HeItQ8KfFDxPqHxp074V+JPE/i7QbKG98VeAf2cPCWoeBfF2mfFrxp4VuZj4Y12T4 k+Mf2fPh1D48i1XwLY/Ea+1vwn4sXQ+K8EftrftEfGL9nX9mf9oP4H/sfDx5Y/Gj9mD4M/tT /EDw1rvxxi8FP4W0b4xeCbLxrZ/CL4LeIpfhXq1h8cfjNpNlNqEB0HxLY/A7wZ9kt/D1/r3x B8OXfi6wt7cA/TWivzN+If8AwUObw7qnijxV8P8A4VWvxC/Zu+Cnhf4U+MP2nfjdefEOXwdq /wAL9A+LuhaP430y+8F/DN/AniOT4mf8K9+E3iTw38afjDbav46+GM/hT4c6/o0/hR/iB4pu L3wlp/p/jb9rLxb4E+OFj4S1f4Uaa3wEb4pfDz9n7xB8aoPiUX8XeE/jj8WPD3hzxB8OtN1b 4O/8IM9lcfDDxJeeOPh94Ag+INj8XpfEX/CxvGmn6O/wyj8O2954wtgD7jor4xtv2mPHGmfH rwv8NPiJ8IE+Hfwv+LXjfxz8I/gH8S9W+IFze+O/iR8V/h14Q8YfEPxBo2s/CKHwBaaX4K8I eIPh78M/ip4w+F3jj/haHiZ/GOi+BZb3WfC3hQ+IPCx1j7GhZnYvuLIUG3rtPcSAlV3GRCm9 duIZFdQTvJIBYooooAKKKKACiiigAooooAKKKKACiivij9pX9j1P2mPi38FfGfiX49/tGfDz 4a/Cbwp8YtM8R/B74BftAfHv9nGy+Lnir4i3XwqbwZ4o8feOP2ffir8MfF97B8KNO8EeNLbw 3oDXV3Bdaj8Sp75p7O003UdK8TgH2vRX8+n/AAT8/Yc8RfFf9mb9hb9pfW/20f28Wsfjz/wT p+B8/wC0n8ONa/bO/ar8b2vxS+KXxS8Ofs/fF+5+MnhDxt4z+OniHW/gF4ysNU8OeKvC+rp8 H7Xwsms+B/iBq/hnw5feC9LGswav7Prd18cvDXhz4b/soa18SPimnwy+Ov8AwUM1L9m/4R/G 6Xx/44sf2gLv9lLwd+yx46/am8UWGr/F9tRi+JS+Kr34g/Ar4u/syeFPjMNeb4jeJPhFc+Df iRb/ABIn+JutxfEiQA/aSivwv+GfxB+I37UEn7I37K3xD+JvxY03R5bj/gpefi78Tfht8SPG PwY+JXxj0/8A4JsftXeEv2KfBMV58Tvg9qvgTxj4cf4r6x8R9A+OnipvhxrXgYeIL/wadJuC fAeo+IvCOtXvCtl8U/2oPiVq/wCzh4k/aF+NvguT9kr9lrw54i074qfDj4k+Ifhjr3xR+Ofi v9ov9q79njwb8aPiJJ8P5/DelfEix8Ead+xffeMtQ+F/ifTdU+B/i3UfjFqTeNfhT4rgg8KW nh8A/bm6VmjAClxvCuoaQZjkDRPlU++MP8wYMEGZVRpI0U/mn8bP2NPj98aP2vPDvxx1P9o3 4UaJ8CPDfwL+Nf7OY+Cdn+zV4xuPiVqHw0/aLf4D6z8VbmX9oaP9qKz0+x+Idj4+/Z48JeIP hn4x0/4FadYeDdGvb3QdQ8NeONYQeLK8z8O/EHxH+1X+z9+yb8d/iTqf7QfwP0H4x/sh/A34 4eF/jD+zx428W6Do3wZ+NXxX+G8/iPx0nxg8DaXr174f8b+ErPQvEvhaXwbJ8e/hL8T/AIM+ E5/DPibUvGs/hXU7nQrrWfzs/aU0X4X/ALJvjT9izWvjb+0L/wAFOv2rfA+qf8EwP2hPF3xJ 1r9jj9pD/go5reoftJ/F/wDZYsf+CeXgr4ffHrQvh9+zR8fZvCvwqf4keEfHvxW1vxL471rx h4N+CniXxp8SrbxV8ZviFqfjLXNP8Z6gAfe2j/8ABPb9sf4bfFr4K/Ef4M/tm/s/6Xp/wM+B vxl+DWkaJ8W/2HvH3xP8R+P9X/ac8W/Aj4r/ALSXxb+K/izwf+3D8HbXxB47+Jfx7+B9v8R9 Nbwt4Z8B+H/DmneKde8L6jp/i2ZZ/G1z7d4C/Y4+PGjfBn4PaF48/aN8B6t+0d+zYl9of7P3 x8+GH7O2ofDfRtN+Hl34L8OeDLz4b/FX4R+K/j/8Y7f4n+HvGMGgjUPG50v4h/D+DWm03wLr Gg2fw+8dfDfS/HM3z7N+yrpfgL/gof8AsLeAW/aK/bg8YaLpn7En7QHjHxTZ+L/23v2pJdB+ K/xP/Y78a/8ABN74S/CP4jfFn4eeFvij4Y+FHiTVtX8OfEvx7q3xh0Oy8A6B8N/jP4x8V6z4 k+J/gbxBrWs3wvP0U/as+Amu/tKfBDXvg14e+NXxS/Z/u/Efir4TX9/8Tfgz4r8T+CPihp3h LwV8WfAnxC8c+FPC/jTwfr3hXxN4Wufih4M8LeIPhfda7petwto+meMb/UZbLWo7RPD84B8k fHn9i39rT49fsp/tIfBDxJ+2N8NYPiT+1b4W8T/CP4ofEL/hmb4i6v8ACPwj8BfE3w38b/Dz UvCPwG/Zzk/bFCfDz4g6m3i278Tat8WPEHxP+Jms+JdSmutJ8QeGtU0jT/h9afDX2yz/AGdf jjq8vgrWPif8Wvgf4w8Q+IPBniD4T/tfWml/s0eKdD8BftL/AAvluvEMvgDSfDPgjUv2j/HF 38HPFPgrTvFWv6VqWv6r4n+MWieKYfE/jNr7wdZ6PceDtN8F/FGn/wDBNLw78QPjP4om0T9r f/gol4G8F/BT9oO50TxL4DsP+Cjv/BQTxDpnxT+H3ij9kL4fX2k+ELrXvEf7Vl54n8J3fgz4 0fEKx+MOn+I9Hury71KPTLn4eeIYNY8F6/CfD3nX/BFH4o6V48+FP7NtxoPiP9uLxx4u8Vfs D/BD4m/tR+MP2r/Ev7aPifwjr/x38QeGPhfLpnin4Kat+2NdXmi67onjTU9Q+M1/ceKP2Yr2 6+BmraTpOg3FvdTaQ/hG4uAD7j0f9j3492ekaB8Cdd/ai8M+Of2N9Bj0DQbj4Z+M/gLqGsft C+LPh74eaB7L4U+MP2kJfjgng7xJ4HuYrOy8NeJdS1H9nG4+JPizwML3RvFHxF1rxdqmpeMX 4nxV/wAE3NH+PH7XvxH+Pn7akH7Jf7X3wg1b4ceH/hz8DvgV8WP2KdD8Raz+z9a+HfFV94jO peH/AImeP/i98T/DGsax4zt/EOsr8WLmw+D/AIRuvGl5pXw8udNvPDvhv4f3HhbXfJ/GH7T2 v3//AAVL0DT/AA18edD034N/BW98Ffsh/FD4IP490OyTxh8VP2hvBPir4t6p8QIPAq6gbvxB 4k+FfiCx/Y++H/hXWmsnOjWvxq+Ouju9vJYXcWq1p/GfxU/Zf/4KK/tMt4O8QfF34l/sq6N+ z3+yL8Z/jr8KfFPxG+MXx28UfDzxN+0X8b/29/Dfiv46/A61+JXizx/rfh3wR8PNL+BvgaLx z+zn8KItB8Ft8PRrHif4XeFIvFPgW18A/EYAvXX7BP7f6ad+xxo+m/txfspWOn/sV+Nrjxt8 K7f/AId1fEWW21e5X4IfF/8AZs0PRfGdnYf8FEbCa88I+Hvgx8b/ABB4YsbLw7H4a1t9d07R /FWreICltNp1z7doX7I37V95o/xq1L4pftW/B/WfjL4q+Inhv40/Aj4r/Bv9kzxT8LLb4H/E XS/h5pXwr1W28S+CvGP7Wfxqn+L3w08XeBvDPh3w3rngdNe+H+rXuiHxyi+N28T+IPCes+A/ lj9inwX8S9A/Zc8ZfED4QeM/2h/2j4vFv7b/AO2x8PPipp/xD/bC+N3xg+I+ufstfAr9r39s f4C/C7wx+yv4w+Pvxu1HwD8LvG+g6Bpfwludc8Y2Gv8AgbUfib4D0DxBqV547b4oR/D7xb4V 4b9sH4TeBfBH7JjfEey/a0/bp0nwt4R/bv8A2ItHifUv2tv2zvhL8Tvgp8H/AI3/ALSP7C/w G+PPwV+K2r6Z8XvD/wASfiBa6n8PL7xb8RPDOr/GNtZ8feEV+LGoeKfhvrVtaana+I9cAP3n +Htl4407wh4csfiZ4j8M+L/iBb6TBH4u8UeC/BmqfDrwlr+tosUd7qnh/wAC6346+Jus+FdM uXQPbaLq3xA8WXtgpeBtYuURRH21fhEPHfj3wT4u079nT9nT4xfFW+/Zv/aC+Onwe+Afwv8A 2kfiT8QPHfx78e/DnxrJ8IP2rf2h/wBqaw+FnxW+PZ+Jup/E3wzD8JfgZ8JfBHwe8feKtY+L Hg3Svjn8X/F3h+HUvE0HgC78AaP7n8ZPhCv7G9v8PviL8Mvi9+074p8G/Ef48/Az9nv42/DH 4t/tQ/H/AON48X+HP2p/if4b/Z9svGPw78UfFL4jeLvH/wAFPHfw28ZfE7w5480/VPgh4j8I eF7Pwh4a8dWt54ZOpSaD4m8EgH61UV+CH7KHjHxb4i+EnxA/Zw/as+IXxivPgL8S/wBrD9uT 4Nfs2/tDaJ8efjh4H+K/gmL9nH9vf45/B34f/s5fFD9pfwz8QtI+NEHjC/8AD3wp8JX/AMLv ij4h+J0t38cNNPiv4KfEK/1TXI9JsPi98ufsW/s52fxZl/4JIXHj/wDaS/4KC+IP+Gm/+CRH xM/ae+N8Un/BSv8A4KC6bB4z+O+gN/wTUOgeOjb6L+0zYXOixW6/tH/FlZPCnhGfRPBmoHW7 JNT8Oy3GiaebMA/qSor+cv8Aba8D+IvhR8G/FXh74hftJ/tk+LdL/Zy/at/4J+3nw88cfB/4 +/tWeG/jjd/s6ftiftm/AP4QfGb4FfE7S/2UPGHhPxr+0/4103w1p3xS0P4V6zeeDPEPx1sv A/jvwTZ+AZ5/iRqV/wCM/HHlXxUj+CNx+zD8f/jf8G/ih/wWW8DeBfBX/BQH/gmt8DPF/gn4 z/tB/wDBTbQfiI+kp+0n8BfDnxm1P9nfwJ4q8eS/t0Xei/HH4JftmeJ/hx4i8C3Twaj4/wDi N8O/BOpfDn4Uad408BeA/F2vAH9RNFfmX/wT28c3/i5vjhp3gK1/aMf9lvwdr/hfwx8Gda/a 6vPi+fj7f/EO0Hie5+NujyWf7QMSftFQfCjw35/w8t/B11+0DDB8Tbjxtc/FbSPJT4caH4Ba T9NKACiiigAooooAKKKKACiiigAooooAKKKKAI5t3lvtBZsAqoYIWIIIUMQVBY8AOChJw4KF hX4nWn7Wfhf4df8ABSP9r3xfrPwP/bj1TwnqX7MP7H/wI8NeLvCv/BPj9uDxd4N8bfFP9n/4 6f8ABQHXviVofhfxl4f+BF54WvfD1np/xv8AhzNoXxJutZh+FnjCx8Qf274Z8d69oNrqWpS/ trRQB/Ot+194n8Y6eP8Agnb4VuvDP7ffwQ8Y6P8AtkfHT9sn4jeO/wBmD9i/4i/tO+Nf2ePh f8bvgv8A8FENC8M6R4h8R+FP2aP2v/2br34mt4u+N/gf4X/Eb4cWOk/FfxJoNj4o1fxVpiWn hxPD/wAS5fof9jL4hn9mL4OfH/xx460b9sL4o/Dfxd+0bF4k8JfF34h/sS/tFzftf/GfxB41 8IaBbeI/E3xT+Avws+FWt/Fy58P+EF8M6T8P/BPxHvP2e/gV4d0fwLoHhX4a6T8KdL8M+AvC Xib4hftFRQB+Ps99+yP8Vvgj8TPH3xc/ZK/aX8feHPif+17qHiu70z4g/sRftCRfFHxz8WNK +GWheCfBHxZ8MfBiHwHdfGb4Z+DPD3wp8K+H/gJoHxc+IHg34UWsaeEWk8ZXGlaD4uPiHX/r /wDYG+H3xV+Ff7Jnwp8A/GS88U3Xi/w83j2LSbTx74li8ZfELw38Lb74m+M9U+BngX4j+K7f UNYtPEXxI+HvwSvvh94F+IWsWOu+ItOv/Gfh3XLjTvEviOye31y/+w6KACiiigAooooAKKKK ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAo oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKK ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAo oooAKKKKAPy0/wCC0nxg+Ffwk/4Jd/t4r8U/iR4F+HQ+Jf7I/wC038I/h4njfxXovhSX4gfF Dxz+zz8Urfwd8M/BK61e2v8AwlHj/wAVz2d9/wAI74S0mK+1rVYLDVLmwsLtNLvfs3BeJ/2j P2eP2lf2jv2avjv+zz8YPhp4t+Ef7H1r8dPij+03+1f4b8T6Xc/s9+F/2e/E/wABfH3hjWPg 9f8Ax9tnPw71DW9Q+KI+D/xy8VaBp/i2az+G/hb9nu/8WfE6bwzdXXgG11v9iKKAP5Jf2Kf2 mfC3xC+NPwd8R/Df9qD9nP8Aav0nw/8A8FNP+Cjup/CH9j79n+3uLP49/Dvw1+07+3j+0zoe tftc/F34kaB8SvihZ+PfhB4M+BPxL8e/F/w5p2r/AA6+AHwu1v4d+NtGZdd+I/xX0f4Sapcf s58R/iL4At/+Cvn7Hvw5l8ZeFY/iOn/BPn/goXqkngaTxHpX/CZJpHi39of/AIJ0Hwlqr+HI 72TVYtN8U2/wj+KV3oFyLSOLW/8AhW/j57BjP4U8Sw2n6fUUAfhV+zPcfBTw/wDtS/A/Qf8A gm5+014p+OXwN8SeKv2hPFP7YHwysvjj4j/aU+D/AML9D8f6H4u+JejeNLjxj4p8QePtV+D/ AMcNa/aRv9E+xfDi68X6P4i+IHh/4mfGTxX4i8LXA8G/bdN/dWiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAK/PX/AIKk6F8YPHv7Bv7VXwW+BXwI8e/tA/Ez9oj4E/Gb9n7w14Y8 DeJfg74Vi8M6l8XPg7498IaV438a6x8a/ir8JtEt/AWla5e6ZpniQ+EtX8ReOLca3YX2meDr 3TYNZ1fS/vTUruzsILu+1K9gsdPs7ea7u7y6nFra2NtaW5urq7vbx5IoLKztbeF5pri4kgih UktdKJ9i/nx+zr+2p8Qv2tv2Y/GXxm+AnwM0G2+LOgeO9V0Hwz8E/jf8VvEfwp0PxD4RvbvR vGXwu8aa38TdC+DfxH13wnD8Wv2afG3w/wDjf4d0pPhB4kg0fWPFVh8MdT1GGKxu/iNaAHwr +2b8Gv2sviz+yD+0v4L+Dn7HvxVWD9qb4a/tYa/pfwF174mfst6b8Ufgt8fvjf8AAz4ifs3X uj63PafH2f4FXHwl+I2t/EfUv2pNY8SeCPjZ458XWmt3Xj7TdR8Dy+I/FNp4a0fuPiVqP7Vf 7Rn7VXwa8R6l/wAE6P2t/hP8L5/2Qf2yf2R/H/jzxb8Sv+Cft+/gPVf2ufiF+xrd6N8Rj4e8 Aft0eNPE+ueBvh5pHwB8b6p46TRbHVPHdstx4etfCfgPxXqV1dR2nuHw6/bh/av+JP8AwTm+ Hv7bPh39iXwr4n+LHxys/wBm/wAX/A79l/4fftLeI/F6eIPhn+0r4i+DemaD4t+JvxavP2Xv DqfDm88EeHPid4j8ffFCx0X4Y+PvDHhTwd4KvNWv/HBiutZuvCPj17+3n/wUpbWvi/oHg7/g nD+zn8RNX+B/7VPwc/ZU+Idl4A/4KBfFrWJtN174yeAP2dfihY/FJLC7/wCCbmhX7/Bj4b+E v2m/BN/8TdeZLbxD4Vt9A+IviRvBOseGfDf/AAkupgH3HbfGz9qtPEWl/DeT9inxNJq8X9kQ 6v8AGWX40/AjRv2YiiR2j6ld+H9StfFfiX9pkkq10NH0/Wv2UrCK71a1j0y41DSLKRNfj/NP Sv2L/iB8X/21P20fih8Uv2UPj9omm6l+1t4J/aJ+BOp/FT9p3QJf2Lvjt4U+Cn7Ov7K37P2l +HfHP7Nnwi/ax8aafYfEnxf4y+E3jX4v/C34h/Ef9la713QfD/h74Xy/FTVLO/0Cb4IXWfp/ /BWH/goJqX7NXij9rg/8EzPgtpPwL8Pf8E//AAv/AMFD38Z6n+358QI7LWfht4r8C/EL4m2/ wj8N6gP+Ce91pOtfH/RvBngOTxH4i8K22oXXgTwzp/iv4fwav4709vE7paewaz+3l/wUq8N/ E/wN8J/En/BN79nHw9qnxE/af1f9lPwP4i1L9v8A+LFj4M8X+I9G/ZO8TftiN8UPDWq3X/BN 5dQ1z4QjwJ4G8eeBbfxLpcA8QW/xh8JeJfBuqeFtOisG8QRgH09p/wAT/wBozStQ1H9oib9h j9oG/wBU+IPgD4f/AA31r9n3TPiR+yGnxv8AB+ofDbxh8YtXTxPc31/+0xo37Put+EfE9l8T omtLnTvj5Y+NNOutLie78CW0uqXVnpPy7+1b8Kv2xPEnwy/bI+NPwq+A/jGb47/tj/Aj9nz9 kTQPhV4L8cfA3UvHvwL+FHgnVf2kdQ8T/HTxZqHjf4yfBX4W+IfipoVh+0h8QDpXgbwJ8YL7 TNT8Q6B8MNH03x/p+jXHizxt4V7X9qD9ub9ur9m6z/bB8bQ/sV/sv+NvhR+yT8HPEH7R1xrs n7enxL8O+OPHHwT023+L2qade6P4Ig/4J+6/oWgfERvDvwa8S3PiPwHrHxJn0DSdevLDRPD3 xG8TWBXWh9B+Hf2g/wBsjTfEFl4H+N/7Jnwd8BeLfiL4Y8Wn4Ga38Pf2tPEvxZ+Emt/F/QfC GveM9I+Efxb8W6v+yz8NPiN8LbnXtL0DXtYHjvwh8HPjB4S0fRPDmulDf65YaB4e8UgHyT8O fCn7d/7HX7TniPXNS+BNr+2H8IPiv+z78OfDuq6h+xj8LPgx+yj4W+E3jT4BN4p0X4eaafAX 7VH/AAUf8ba34+8U+OvAmu23gzxLrmgX3hDwn4b8OeAfhJa2l1qoHi678NfPnxf8N/tXfG/4 X/8ABOH4VeLf+CY37f8ApGh/sq/Evw94w+M958Mf2tf2KPgn4z1jRdA/Yl/aP/ZwjX4SfFT4 L/8ABSX4f/Eqx1Q/ED4t+Eb/AFe0Pi34bW2s+AIPF+k6sdbsr2fwtq31t8Fv24v28PixYeAP FT/sQ/st6V4P8RftU/EX9mLxJpfh3/gop4h1L4r6BH8Cv2l/iD+zj8eviH4M8DeOf2GfhZ4O +JGh/D2y+FfxE+Mml+ErH4q6X4x8ZfDvw/Cmj6Lp/ii7Oi6d7p+1r+0t+1P8Dfi/+zZ8Nvgn +zj8Bvi34d/aZ8aaz8I/DvjD4o/tYeO/gZeeGfipoPwZ+PP7QmsWfiPwl4X/AGRPj6h8CP8A DP4Ca2mleKtF8Rz67qPjXXU0DVfA3h3QtJTxzeAHb/shfDfVf2dNAvf2YLH4OeJ9F8C/DZLn W/DPx8ufFfg/xD4d+OF74z8T6n4j1nWtfj1b4oeJfjjd/Gh9V1m51r4w+J/HfhOw0Txh4mvb vxL4W8UXUeq2/hTQvx+8MfBP9o7Uv23/AIiftj6r/wAE0/29dO+It/8AtkeHvjR8AtK8R/tt /se+FP2ZND8E65/wT1+EH7AvifW/2ifhL4V/bN+O3huz8S+HYIvjD47/AOE1+Dn7P/jv43X/ AIYtfh54bh8Z+IdHTVPhg33PrP8AwUD+Pnwd8R/Ao/tPfszfBvwR8Ivjd8dfEn7NcPxK/Z3/ AGsPFf7RuoeGfiD4V+Hnxn+KeqeMrzwncfsqfB6zg+Bnh/wh8DPGWn/Erx9rPinwr46+F2ua Vr0mo/DO68D+H5PHbfQPiD9pb4ueFP2hNN0LWvhr+zrp37HN38H/AB58dn/arf8Aam8Tt4m0 v4b/AAy8JeBbvxXq1/8ABJf2cIvAltbxeJfiLo9tZamf2jJ9Af4XRXXxMvNWh1nS7P4YXgBy HgbSfj/+yPpXiv4V+Bv2d/E37RugfET9oL9pj4x+D/iD4T+I3wi8EeH/AAa/7S3x9+IP7Qeo 6T8eovir4r8MeNtC0TwZ4l+KuueHbLWfgz4K+Pus3Pgzw7Z6rL4OXVm/4RU+nftDfF741+Et FsvBvhT9jX9oz48TeMfBNzb+K/FH7OXxI/ZW0PRfBut30L6ZfeGLLxD+0j+0r+zp4sm1ZLc3 T6f4t0rwRfWFuH07UH8rXoG8PxeZWn7V37V2of8ACvfiJa/sTWY/Z6+JXxB+EXhXSNY1L4+y 6T+0noHhf4vfEXwr4Hsfid8Q/wBm7VPgRa+G/C3hPw7pni5fHGtaBZfH7VfidpGg2dzYeL/A /hrxLa+IdJ0PqNf/AGmPj7468W+OdD/ZF/Z3+H/xq8JfCrxbq/gH4gfEf4w/tB6j8AvA2rfE HQLu2tfHXgL4THwx8CfjxrvxA1f4e3ss3h7xXrGt6L8PvANp4xsdd8GR+KdZ8U+G/FEOggHy j8Y/2Zfjxqfhf9vj9nHwJ8E9QuPAv/BTXQRA/wAWNH8Z/DTSfBn7KaeKf2LPgl+xr498NfEP QtZ8W6V4/wDEEfhnwn8HLDxh8M5Pgr4I8fWXirxBrV54a8V3vw40zSo/Fk/tPxx+Dnxh+Kfx I1/4OaZ8LNZtfhp4u/a3/Y7/AGxdV/aEu/EXw+XwDo2ifsr+MP2Z/iE/wrtfCUPi9vjFqHxW 8S+L/wBmLT9HUQfDeL4aad4P8Zprs3xAk8QabP4KucL4v/tzftDWOs/shx/s4/s0fBT4weEf 2tfHGv8AwX0zV/in+1t4r+CPiX4YfHv4f/DD9o34p/E/4cfELwl4N/ZK/aI0qLS/AWjfs5+N /CWr+IPDvjDVdZf4qW2qeCL/AMF2Ph3Rl8Uau343ft5ftA/BT9mP9pz4t3H7Mfwl1P46fsa+ Fte+Lnx/+Ad7+1d4k0Xw5d/ATRfh144+I9j8Vfgh8XLX9l/xHq3xFHjSHwVrHhPwj4e8d/Bz 4LpqXizwr8TNN1TxJp934LsJfEwB9HRfEH4leNf2htF8Ja9+xV8afDvg74d6r41vfDX7Rfjb xj+y7cfCtriXw3qGjWvirwZ4X8FftE+OfjtJ4m8TWl7qHg7RZPEXwo8CTW/hrxf4pbxDeack w0fVvseAFpN5O9RGdkgcsMSlXYg/KsglCo6sieUhDRxHAYH8fv2gP22v2/v2cvg9+0H8WvGf 7E/7H3iew/Zt+CPij9oLx5o/w9/4KRfEDVr1Ph74M8OeL/FGu2K2Gu/8E9/CniPTfGl/Y+Eb y5+H9nN4XPg3xTbaR4va9+JfhvXvDFhoviv7B+BX7Q3xM8QfFPWPgP8AtF/DX4Y/Cb41L4Iu fif4d0H4NfHXWP2hPAmveANJ1nQvCuuahN4o8R/Bn4B+MPCHiLRda8ReGYbrw94s+F2iabrd nrsF74D17xdJoXj9fDIB9l0UAgjIII9RyKKACiiigAooooAKKKKAGllXAZlUtkKCQMkAsQMn nCgscdACTwDTv6da/ML/AILQ+MfGfw7/AOCWH7c3j74d+NPGXw78ceDP2fvGXiXwt42+H/ij XvBXjLw1r2kR219pWreHvFPhnVNI1vRL+zvoLeY3lheCVrRbu08uVboqfzS+Cf8AwQ78dfE3 4NfCT4ja1/wWy/4Lm2WsePfhl4C8aatbaZ+3hq0Omw6l4r8K6T4gvodOin8IXd1HY29zqMlv aJeXd1dLBCgmuZ2HmMAf01V5h8XPAniL4keBPEPg7wt8V/iL8Dtc1mLTorH4pfCez+GF78QP Cy2uqWd/fyeHbb4xfDb4t/DxrnV9OtLrw5eXGveANfktdJ1vUJtB/sLxHFpXiXSvwy/4cB+K P+k3v/Bdr/xPTUv/AJiaP+HAfij/AKTe/wDBdr/xPTUv/mJoA/Rr4NfsN678Bv2S/Cn7H/w9 /bF/aqtfDHw803wj4S+GXxa1bSP2Qte+L3w4+GXgTw34W8K+GPhForal+ybJ8JfEXge10Tw9 JZS6l8Q/hB47+IF7Fr2ui+8fxRQaHZ6R0S/sT21/8HNZ+GXjv9pT9p74reMb/wCKun/GrQf2 gvHPif4ZR/GT4dfEbQW0N/CGqfDPT/Bfwo8EfA/wboHhMaDbQQfD6w+DD/DjxPp2p+LdM8f+ D/GNv408Vx6z+Yf/AA4D8Uf9Jvf+C7X/AInpqX/zE0f8OA/FH/Sb3/gu1/4npqX/AMxNAH6i eI/2Ifh9efDD4K/Dr4d+Ofi58CtX/Z+Mp+Ffxd+F2s+ELn4t6ENc0LUNF8fjX9X+KPg/4o+E PHX/AAs6PUrvUviH/wAJh4H8QnxB4wew8cqbfxjoui+JtK5rxx/wT5+GXizwx8NPC3hr4j/H j4QW/gP4TXnwD13Wvhj4z8O2niv4t/A/V00tvEHw4+Lnibxn4S8e6rrMmt6hZ3muH4i+EJ/B vxd8Pa9rni/V/BXxI8Kah4t1641f84P+HAfij/pN7/wXa/8AE9NS/wDmJo/4cB+KP+k3v/Bd r/xPTUv/AJiaAP1D8Y/sV+HNf+JOmfEnwL8Yvj58ChH8Lvhl8EvEngT4QeIPh/pHw/8AHHwl +E2vfErXvC3g7VdE8WfDbxrqXgl2n+J/ia1l8efB7Wfhr8WNN059Hh8NeNvDN3pMU55qT9g2 wh/am+FX7Tnh/wDaP/aE8F2PwR+HWv8Awb+GH7N3g7SP2ZNI/Zu8J/B3xjb/AAj/AOE1+Gdh oR/Zrl+K/wDwjnjDWfgb8M/Ed1M/xfn8R+GL/wAN2mj+DPEPhfwcD4XP5w/8OA/FH/Sb3/gu 1/4npqX/AMxNH/DgPxR/0m9/4Ltf+J6al/8AMTQB+hXxi/YN8VfFX9pfSf2n9D/bo/bG+DHj Dwp8PvGXwv8Ah/4U+Fuk/sY3vw7+HngX4kzfCHVfiZ4e0XS/i/8Asf8Axa8S6+3j7xZ8F/Af jLVdR8e+I/Gt5o+q6XNp/hG88KaAtnotv9T/AAL+Cfhz4AfCPwZ8IPCeo+JPEGl+FbXU59T8 VeM7rSb3xr478V+JNY1XxX48+Ifje+0bR9B0XUfHHxJ8ca94g8a+M7nQ9D8M6NeeIvEmuXWn aVo9nLb6XB+J3/DgPxR/0m9/4Ltf+J6al/8AMTR/w4D8Uf8ASb3/AILtf+J6al/8xNAH6S+B v2M/iP4F8IfHjw9H+3v+2X4l8WfHnxJ4Q8W3nxb8RaJ+xK3xA+GGv+GtM0fw1qt98LbLQP2M fDfwyt/+E88HeGPDfgfxJZePPhz4+03RtC0S01nwBafD/wAYXWpeKNR4r4Vf8E6774K/Ar4E /Av4eftq/tlaXbfs5DTPDfwo+Is8v7J134/0T4M6T4F8L+B7P9njWYZv2VIvhv4s+EEVv4N8 N6ymoeI/htqfxktfEWlQXth8UIdPhsrGx+D/APhwH4o/6Te/8F2v/E9NS/8AmJo/4cB+KP8A pN7/AMF2v/E9NS/+YmgD9A/AX/BPW3+H/wCyv49/Zasf2tP2tvEUXjr4q6r8ZoPj/wCJtR/Z 5uP2h/BvjPxD8VtN+Net3PhjxDp/7O+kfDq9e6+JVjqviWPUvHnwt8WeJ9Nfxbq+n6T4lttI 0XwHpXgvQ+Ef7CfiX4XftQeIf2qdT/be/a++LXirxn4L8LfDPxv4B+I+mfsf23wy8XfDr4e3 3xa1j4W+F7/Tfhx+yV8NPGWjQ/DXxT8b/H/izSNY8K+OtC8UeINUvI4fHWseMNDZ9Bl/Oz/h wH4o/wCk3v8AwXa/8T01L/5iaP8AhwH4o/6Te/8ABdr/AMT01L/5iaAPv7xd/wAExf2d/EXw r+B/wf0bUPi38MvCH7PP7VnxP/bD+F5+EfxBuPAGtaJ8XvijeftE67ep/b+l6dd6tD4G0HxR +0x411rR/B+lvpmlXE2i+GPD/ii28R/DtfFXhDxVT+Mf/BPLU/jf8MPBXw08Tftsftj+H7nw 58WfCXxv8ZfEXwfZfscaZ48+MnxQ+Fvj/wCF/wAT/gp4o+JA1H9kLXfBGny/BnxJ8JPBA8Ga J8JvBfwz8K65baM9r8TNN8eyvbzJ8G/8OA/FH/Sb3/gu1/4npqX/AMxNH/DgPxR/0m9/4Ltf +J6al/8AMTQB+z/jH4CeGviZ8G9P+Dnxc1fxb8S7W10zwUbr4g6lqGmeD/idqHjzwHd6XrPh /wCLVprvwi0L4b6b4H+Jdp4y0TTvHtjr3wz0bwHpOheKzJdeGNB8K6Vb2ujReI+F/wBidrHx Vpnjz4l/tN/tO/tDeJ/CFtrTfCC6+MF98C4dI+C2ua34fv8Awy3jnwd4I+GHwH+F/g3xR8Q9 M0bVNSstE8ZfGnQPir4l0my1HVrSG/WDVdR0/UPzO/4cB+KP+k3v/Bdr/wAT01L/AOYmj/hw H4o/6Te/8F2v/E9NS/8AmJoA/Rn9nH9gPw78BfhJ8afgf4w+OHxx/as+Fnxx8QfFDxR4m8B/ tN23wC1TRbPV/jt42+I3xJ+OR0qf4PfAr4R6hJpvxZ8a/FXxRrHirSPF19400nR7uGzb4f6d 4Tsp9Z0/XPHrb/gldD4T8W/AnxR8If24v21vgxpv7M37Ntl+yl8CPAvgmP8AYz13wf8AD/4L f8I98CtB8SeF1Hxa/Y2+KvifxJe/EHUf2ePhf4s8WeIvG2v+LdUsNe0W/j8JXPhTwve2/huy +R/+HAfij/pN7/wXa/8AE9NS/wDmJo/4cB+KP+k3v/Bdr/xPTUv/AJiaAPtj4lf8ExfDXjr4 b+E/hx4e/am/a4+F8WnfGfwb+0Z8RPHHhHWvgL4y+Jn7QHx2+Gfjj4W/Ej4U/Ev40eK/j9+z 98Z2vrr4XeLPgr4Bn8G+DPBFr8OPhtb+HtK0/wAC6r4P1XwVoPhXwpoPnXxK/wCCR9v8Xtbm 8afE/wDb9/b38a/EiO++Cdx4a+Ilyv7E+l614D0X4FfGLSP2hPCnhPwT4Z0D9ibRfhppOmeI vjl4R+EfxJ+I2qXfgaXxP421f4KfDHR9c8RSeBNJ8VeFPEPzZ/w4D8Uf9Jvf+C7X/iempf8A zE0f8OA/FH/Sb3/gu1/4npqX/wAxNAH6xWf7LuoaZ8Ufh98XdO/aF+Pum+KfDvgrw74Q+Llv prfBuDwl+1bL4a0ePR9J8V/HrwO/wcn8O2HjpJJLu+uPFnwF0/4A6n9nuLTwtJPP4D8PeGvD fhz66r+eP/hwH4o/6Te/8F2v/E9NS/8AmJo/4cB+KP8ApN7/AMF2v/E9NS/+YmgD+hykJA5J AGQOTjkkAD6kkADuSAOa/nk/4cB+KP8ApN7/AMF2v/E9NS/+Ymmv/wAEBPFAVj/w+7/4Lsvw cqf289RYMMcqVPgpVYMMjDEKc4b5SaAP6GxJGWCh0LMJCFDKWIiZUlIGckRuypIQPkZlVsEg F9fyFf8ABsz8S/j5rv7XP/Bbf4F/GT9p39pP9pvw5+yx+0F8Kvgz8K9e/aU+Mvjb4u+JtH8M +FfiP+2L4Pe9hn8Vaxf6Zo2r+JrPwboVz4nHhjS9GsNQvtPhkeN4razRf639e17Q/C2iav4l 8Taxpfh7w54f0y+1rXtf1y/tdK0TQ9G0u1lvtT1fWNVvpYLHS9K02ygnvNQ1G+ngs7K1hluL maKGN3ABrUVy/gvxv4L+JHhbQvHPw78XeGPHvgnxRplnrXhnxj4L17SvFPhXxHo2oQpc2Gra D4i0O7vtI1jTb22kjuLS+0+8uLa4gkjmileORGbqKACiiigAooooAKKKKACio/NTj7wLAEAo 4Yg4/hKhsjILjGUHLhaUSRsSFdTgsODxlGKOAehKOCrgcqcBgMjIA+ikyPUfmKMj1H5igBaK TI9R+YpC6KCWYADGWJwoJIABY/KCSQAM5ORgc0AOoqHz4izLu+ZWKkbX5KhSxT5fnVSwjLpu QTZgLecrIHmROec44O0FsHCnB2g/MQy7V+82RtBNAD6KKKACkJA6kD6nH86Wo5DhejnLIP3Y ywyw+b/dUfM2eqggAkhSAP3LlhuXKgFhkZUEZBYdgQCRnGQKQso6soyCwyQMqoBLcnoAQSeg BGa/j6/4OB/+Djz4s/8ABMz44eHP2SP2VPhT8OfE3xdn8BeH/iN8Q/ij8XrLxPrnhbwZY+L4 vF1jp3hHwd4P0TV/CP8AavjUW9roPjFfGWo+IdZ8I6Vpt3F4bn8H+KL3Wb648Jd3/wAG6/8A wcC/F/8A4KtfEH4wfs2/tNfDf4aeGvjT8NvhzH8Y/CnjT4RWPirQtC8cfD7Sta8EeAfEdv4l 8Ma/rHiyz03xpofirxZ4d1S51/TPE2laN4g03xWNI03wD4ei8HX2pa8Af1lgg5AIJBwcHocA 4PocEHB7EHoaWo4z8pyNpDyAgnP8ZIb23ghwD0DADjFSUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFABRRRQAUUUzzFJxk5+bgqwPysVzgjOCQSh/wCWihmTcoJAA4MpOAwJ54BGflID cf7JIB9CQDyaAQcYIORkYIOQehGOo5HI4r+HT/guH/wdA/tDfsNftp/EX9jL9k34QfB+a/8A gZrfw1uPH3xY+Ks+sePLLx9e+IPA3hD4j3/gnR/CfhbVvBcPhXRtJi8TW/hDxdqlz4m1jxbJ c2eu2WinwdfpBrNh+z3/AAQb/wCC0Nt/wWH+BnxI1/xh8O/Dvwi+P37PmveAPDXxY8HeD9Z8 V+I/C3iHTvHXg6bUvDvxR8Kt4g8NWCeEtG8b+L/C3xU0fTvhs3jD4neJvB+meB3l8R+LtRi1 vQdTvAD97qKYJEJAyQSSAHVkLELuO0OFLYXklcgYIJyCA+gAooooAKKKY8iR5LNjG3OAWwGb aGYKCVXOSznCqqu7EIjsoA+imCVG+627gMNoJ3KQCGXAO9SCMMuVJyASQQHBlPQjqR6dDg9f cfj1HFAC0UmR6j8xRkeo/MUALRSFlAJyOOetNMirgkkZx/C3Ge7YHyqMcs2FXjJGRkAfRUaS xyAGNw4ZQ6svKshJAZW6MpxkFSQVKsDtZSZKACk3LnbkbgASuRnB3YOOuDtbB77Wx0NLXyx+ 1R+0DrXwJ0j4WaZ4K8E6b8QPin8dvizp3wS+EvhvxV42m+F/w6ufHN74B+I/xOaX4i/FG38I fEO78CeGYvB/ws8Xx2mpaZ8PPHWr6z4zn8HeDtL8NX1/4nttgB9Sh0YkKysRjIDAkZJAzg8Z IIGepBHY0wTwEkCaIkeXkCRCR5ztFFkZ482RWjjz991ZFywIHgH7N/xim/aD+EWi/Em68H3P gLX4vFXxP+HfjDwhdapJrVp4d+InwS+J/jL4LfEaz8O+JG0zRpPGHgtviB8PfER8C+Om0Dwz ceNfAkuheKm8N+HpNak0ezk+EPxX8QfEvxD8c9B134b+I/hzP8GfjXd/CXTpvEPiHwnrc/xD 0iD4bfC/4haZ8TtLsPB2va7beHNA8SRfEOa30Dw7rupDxZFo2jjVPFml+H9TvJfDGngHv4IO cEHBIOCDgjqD7juO1DMqqzMwVVBZmYgKqgZLMTgAAAkknAHJr4Y+Av7aXhf9of8AaX/aY+Av gjwfrFr4Y/Z18C/BDxLpHxjvdRhXw98Xbv4q+Pv2mvhp4kh8BaQts9wvhb4b+PP2Z/E3gh/F 1/duPGfiu38Sx6L4b/4RLQPD3izxp9yyf6uT7/3H/wBWVEn3T9wsQof+6WIUHGSBmgBdy8/M vBAPI4LY2g88FsjGeuRjrS5HqPzFfEP7Z/xZ+NPwvt/2b/DHwAuvhZoXj/48/tKaP8D4/FHx g8DeKPiP4O8LaLqHwn+MXxM1TWl8IeC/iV8JNc1HU7mT4ZWuj2pTxpZW9s9/JLNZXUChl53/ AIQf/gqZ/wBHNfsCf+IPftEf/TCaAP0AyPUfmKMj1H5ivz//AOEH/wCCpn/RzX7An/iD37RH /wBMJo/4Qf8A4Kmf9HNfsCf+IPftEf8A0wmgD9AMj1H5ijI9R+Yr8/8A/hB/+Cpn/RzX7An/ AIg9+0R/9MJo/wCEH/4Kmf8ARzX7An/iD37RH/0wmgDmf+CpVj+0J44/Zi8Q/Ar9n34A/Fr4 2XH7Qs1t8Jfixrnwi8Z/s2+EPEfwp+A3ifUNN0z41+ItCi/aS+K3wx8M+JPH/iH4Y33izwv8 N9Gik1PR4/FN7bap4vudH0XT/K1zzrw/oX7UP7Hfxe+IL6V8Lv2zv+CjXhXx58Gvhfc6V8TB 4g/4JmfDDVvBvjbwJ4n8eaT/AMKoj8NaZefsGabc6ZdeGvEGheIrvxXe+DPEU9vpujW3h8+J ta8nSfCPh72v/hB/+Cpn/RzX7An/AIg9+0R/9MJo/wCEH/4Kmf8ARzX7An/iD37RH/0wmgD5 5/4Jy+IP2wfhv+z1+wR+yZ8SP2FfjH8FoPgX+zv8JvhD8ffi98S/iN+yR4h8BT/8Kb/Z7TwT FB8K7X4H/tR/FL4j6xqHij4qaJ4ZeyuvF3w98O6VB4KuPENxqP2LUpbJLXQ/ZC8V/tR+Hviv /wAFFfHHxI/YA/aQ+GekfGX4up+078HLfX/id+xDr+qeN4PBX7Hf7Jf7O9r8FWj8A/ta+L9N 8NfF7xt4p+BXiPUPCd54nn0/4Sad4Zu7RfF/xf8AC17IIJfdv+EH/wCCpn/RzX7An/iD37RH /wBMJo/4Qf8A4Kmf9HNfsCf+IPftEf8A0wmgD87/APhXX7YP/DhA/sWN+wj8cz+07/wwaf8A gnyPhqPin+xmbP8A4SWH9kZvhIvx7bxqP2pF8GSfAeTxfK9rDby6/L8b4rxZp4fgzDpBttel /QH4/eFfjL8W/Bn7I/7RXhP4JeLNG+Kv7Nfx5tP2hbv9mLxr4m+EcPxE8QWOr/Af4+/s2eMf h1H450L4i+LvgzD440zwj+0L4k8deEr9vilH4I1vxH4V0Tw3q3jLwnY+I9T8UaNf/wCEH/4K mf8ARzX7An/iD37RH/0wmj/hB/8AgqZ/0c1+wJ/4g9+0R/8ATCaAPkP9r/Q/2wPj3+xh+3rN pH7EXxW/4XB+1v8AADxn+x98H/gJB8Wf2UX8ceBPB2rfCD406ToPxj+OXizWPjxpHwc8P6Xd fED4q+ItM8QeGfhJ8Vfi74vs/Dkng/ULLTtRub/xHD4M+obH4j/tK/GDxV4N8b+If2GvjJ8E
March 26, 2013 - April 21, 2013
AeroElectric-Archive.digest.vol-lr
