AeroElectric-Archive.digest.vol-me
December 29, 2013 - January 13, 2014
      > Here's more detail in what I'm trying to accomplish in trying to use
      the VPX and its flap
      > control features with the motor breaking circuitry of the Lancair
      Legacy flap control
      > mechanism.
      > The good things the VPX does for flap control is not allow deployment
      above the
      > maximum flap extended speed, incremental deployment/retraction with
      flap momentary
      > switch activation, and read/display its position.
      > The VPX controls the flap motor by changing the polarity of the
      outputs driving the flap
      > motor.
      > The Legacy's flap control circuitry, with motor braking (grounding
      both sides) when not
      > driving the motor or at its deploy and retraction limits, drives the
      motor in different
      > direction at the flap switch (DPDT (Retract) Off (Deploy)) with the
      positive electrical
      > connection to both the retract and deploy circuits. See attachment.
      This is much the way
      > Bob N. showed how to do it where he was switching the ground.
      > So it seems that with the VPS sending out motor commands just directly
      changing the
      > polarity that it could be hooked up to a Relay replacing the manual
      flap switch function
      > DPDT (On) Off (On). But as some have pointed out, there's apparently
      no such animal.
      > I'm not sure how to take the changing flap control polarity coming out
      of the VPX and
      > set up two relays to achieve the same result in the Lancair wiring of
      the DPDT flap
      > control switch. I'm at novice at this but will think about it some
      more tomorrow. If
      > anyone can suggest a specific solution to this interesting challenge
      I=C3=A2=82=AC=84=A2d sure
      > appreciate it.
      > Thanks,
      > Valin
      > http://forums.matronics.com/viewtopic.php?p=416309#416309
      http://forums.matronics.com//files/lancair_flap_drive_wiring_drawing_111.
      jpg
      <http://forums.matronics.com/files/lancair_flap_drive_wiring_drawing_111.
      jpg>
      > _-
      > This Month --
      > Get Some AWESOME FREE Gifts!)
      >                   -Matt Dralle, List Admin.
      > _-
      > AeroElectric-List Email Forum -
      > _-
      >    - MATRONICS WEB FORUMS -
      > _-
      <http://www.aeroelectric.com>
      <http://www.buildersbooks.com>
      <http://www.homebuilthelp.com>
      <http://www.mypilotstore.com>
From: "Valin & Allyson Thorn" <thorn(at)starflight.aero>
Subject: Re: AeroElectric-List Re: Source for Relay DPDT (On)
Off (On)
Date: Dec 29, 2013
Thanks Bob N and Jeff Page for pointing this out . This detail isn't in the VPX Installation Manual and I assumed, maybe incorrectly, that the flap motor power lines just went dead to stop the flap motor. The manual does specially say that the VPX doesn't work with the Lancair flap circuitry because it uses limit switches to stop the flaps rather than the position sensor. So Marc may have thought of how to work around the VPX flap commanding and polarity changes vs. the Lancair Legacy's flap circuitry with motor braking but rejected it because he didn't think the position sensor could sync closely enough with the limit switches... Thanks for asking Marc A at VPX for the specifics! Valin -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Sunday, December 29, 2013 2:29 PM Subject: Re: AeroElectric-List: AeroElectric-List Re: Source for Relay DPDT (On) Off (On) nuckolls.bob(at)aeroelectric.com> At 01:38 PM 12/29/2013, you wrote: jpx(at)qenesis.com> > >Valin, > >You may have already looked into this, and I am not at all familiar >with the VPX, but if the VPX has flap control functionality, perhaps >it already incorporates shorting the flap motor for braking ? Good questions. I've dropped Marc a note to inquire into the flap motor output characteristics . . . Bob . . . www.buildersbooks.com www.homebuilthelp.com http://www.matronics.com/contribution http://www.matronics.com/Navigator?AeroElectric-List ________________________________________________________________________________
Subject: Re: RE:_AeroElectric-List:_Re:_Sourc?= =?UTF-8?Q?e_for_Relay___=C3=A2=82=AC=9C_DPDT_=28On=29_Off_?=
=?UTF-8?Q?=28On=29_=3F?
Date: Dec 29, 2013
Thanks Bob N. Yea, the Kendle looks nice. I think when you see the Lancair flap circuitry drawing it will be more clear why connecting the VPX motor drive lines directly to the limit switches won't work. Both lines running through the retracted and extended limit swtiches need positive feeds... Thanks again, Valin -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Sunday, December 29, 2013 12:37 PM Subject: Re: AeroElectric-List: Re: Source for Relay DPDT (On) Off (On) ? At 11:35 PM 12/28/2013, you wrote: > >Here's more detail in what I'm trying to >accomplish in trying to use the VPX and its flap >control features with the motor breaking >circuitry of the Lancair Legacy flap control mechanism. > >The good things the VPX does for flap control is >not allow deployment above the maximum flap >extended speed, incremental >deployment/retraction with flap momentary switch >activation, and read/display its position. >The VPX controls the flap motor by changing the >polarity of the outputs driving the flap motor. > >The Legacy's flap control circuitry, with motor >braking (grounding both sides) when not driving >the motor or at its deploy and retraction >limits, drives the motor in different direction >at the flap switch (DPDT (Retract) Off (Deploy)) >with the positive electrical connection to both >the retract and deploy circuits. See attachment. >This is much the way Bob N. showed how to do it >where he was switching the ground. > >So it seems that with the VPS sending out motor >commands just directly changing the polarity >that it could be hooked up to a Relay replacing >the manual flap switch function DPDT (On) Off >(On). But as some have pointed out, there's apparently no such animal. >I'm not sure how to take the changing flap >control polarity coming out of the VPX and set >up two relays to achieve the same result in the >Lancair wiring of the DPDT flap control switch. >I'm at novice at this but will think about it >some more tomorrow. If anyone can suggest a >specific solution to this interesting challenge Id sure appreciate it. My first response to this thread was without benefit of capable image viewing . . . got a Kindle for xmas . . . pretty amazing but limited. No special changes needed. The wiring shown is what I suggested earlier . . . a pair of spdt relays for extend, retract and dynamic braking. Output from the VPX is going to + and ground or ground and + . . . you can wire these outputs directly to the limit switches depicted in the Lancair drawing. Bob . . . ________________________________________________________________________________
Subject: Re: -1?Q?RE:_AeroElectric-List:_Re:_Source_for_Relay_=3F=22_DP?=
=?iso-8859-1?Q?DT_=28On=29_Off_=28On=29_=3F?
Date: Dec 29, 2013
Thanks Roger, that is a viable approach for that feature without the VPX. What I like about the VPX flap control most is just pressing the flap button and it automatically moving to the next programmed flap extension setting. The Legacy circuitry doesn't have that so pilots hold the flap's momentary switch until they get the setting they'd like. Thanks again, Valin -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Roger & Jean Sent: Sunday, December 29, 2013 2:49 PM Subject: Re: AeroElectric-List: Re: Source for Relay ?" DPDT (On) Off (On) ? mrspudandcompany(at)verizon.net> >>The good things the VPX does for flap control is not allow deployment >>above the maximum flap extended speed > No special changes needed. The wiring shown is > what I suggested earlier . . . a pair of spdt > relays for extend, retract and dynamic braking. I believe that you could add the feature of not deploying the flaps above a given airspeed by adding a pressure switch activated by the pito air pressure system. This would be a normally closed switch inserted in series between the flap down position switch and its relay. It will then be adjusted to open at the maximum flap deployment speed. With this mod you can retract the flaps above the max deployment speed but would be unable to deploy at the high speed. Roger www.aeroelectric.com www.buildersbooks.com www.homebuilthelp.com www.mypilotstore.com http://www.matronics.com/contribution http://www.matronics.com/Navigator?AeroElectric-List ________________________________________________________________________________
Subject: E-bus diode
Date: Dec 29, 2013
Would this Schottky Diode be suitable for E-bus Feed? http://www.mouser.com/ProductDetail/IXYS/DSA300I200NA/?qs=sGAEpiMZZMtQ8nqTKtFS%2fAkrg%2fe%2fM1X2RJuduJKKNsI%3d It appears to be very robust with easy mounting. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=416356#416356 ________________________________________________________________________________
From: "Roger & Jean" <mrspudandcompany(at)verizon.net>
Subject: Re: E-bus diode
Date: Dec 29, 2013
> Would this Schottky Diode be suitable for E-bus Feed? > http://www.mouser.com/ProductDetail/IXYS/DSA300I200NA/?qs=sGAEpiMZZMtQ8nqTKtFS%2fAkrg%2fe%2fM1X2RJuduJKKNsI%3d > It appears to be very robust with easy mounting. The spec sheet says the forward voltage drop is 0.98V. Do you think that is acceptable? Roger ________________________________________________________________________________
Date: Dec 29, 2013
The voltage drop is dependent on the current. It is 0.98 volt at 300 amp. At 30 amps it is less than 0.5 volts. See the graph on the data sheet: http://ixapps.ixys.com/DataSheet/DSA300I200NA.pdf Under the picture of the device on the data sheet, it says, "Backside: Isolated". So the base does not have to be electrically insulated from the airframe. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=416361#416361 ________________________________________________________________________________
Date: Dec 30, 2013
This posting on VansAirforce by Mike Bullock http://www.vansairforce.com/community/showpost.php?p=838578&postcount=2 led to this Schottky diode that costs $18 http://www.mouser.com/ProductDetail/IXYS/DSS2x61-0045A/?qs=%2fha2pyFadujmk%2fL9W%2fwlAGfqAiDlU%252bQn5Rt4HdD41QuAEJC6k4uxOg%3d%3d It has two diodes inside of one package. I believe the Mouser Mounting Style listed as SMD/SMT is incorrect. Digikey lists it as Chassis Mount. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=416376#416376 ________________________________________________________________________________
Date: Dec 30, 2013
At 06:33 PM 12/29/2013, you wrote: > >Would this Schottky Diode be suitable for E-bus Feed? >http://www.mouser.com/ProductDetail/IXYS/DSA300I200NA/?qs=sGAEpiMZZMtQ8nqTKtFS%2fAkrg%2fe%2fM1X2RJuduJKKNsI%3d >It appears to be very robust with easy mounting. >Joe > >-------- >Joe Gores > > Yes, but you may want to seek anohter source. Mouser seems to want to sell these in lots of 10 minimum. Bob . . . ________________________________________________________________________________
Date: Dec 30, 2013
At 08:04 PM 12/29/2013, you wrote: > > >>Would this Schottky Diode be suitable for E-bus Feed? >>http://www.mouser.com/ProductDetail/IXYS/DSA300I200NA/?qs=sGAEpiMZZMtQ8nqTKtFS%2fAkrg%2fe%2fM1X2RJuduJKKNsI%3d >>It appears to be very robust with easy mounting. > > >The spec sheet says the forward voltage drop is 0.98V. Do you think >that is acceptable? That's a worst case condition which is almost never realized in the manner in which we use them. Furhter, as explained in other narratives concerning drops in the e-bus normal feed diodes, there's no chance that a diode offers an 'unacceptable' voltage drop. The normally expected drops in all forms of diode will produce an alternator-operating e-bus voltage no less than 13v and probably HIGHER. While operating the e-bus battery-only, available voltage will be 12.5 volts or LOWER . . . and we expect things to work just fine at that level too. Don't get wrapped about the "oh-my-gosh-there's- a-voltage-drop" axle. It the grand scheme of things its immaterial. This is why we've offered and recommended the plain-vanilla, bridge rectifier with fast-on tabs for nearly 20 years . . . cheap, easy to mount and you can get the things at Radio Shack. Bob . . . ________________________________________________________________________________
Date: Dec 30, 2013
Subject: Re: Source for Relay DPDT (On) Off (On ? --
VPX to Lancair Flap Motor Integration At 06:00 PM 12/29/2013, you wrote: >Thanks Bob McC, you have an excellent >memory.=C2 I=99ve corrected those labels now.=C2 > >I=99ve worked up a drawing with yours and the >other=99s suggestion to just use two relays to >interface between the VPX and Lancair flap motor >circuitry.=C2 I=99ve attached the drawing.=C2 If >anyone sees any problems or can suggest how to >make it simpler please let me know. > >I expect Marc at VPX will be concerned the VPX >will use the position senor to stop the flaps >and if a limit switch stops it first the VPX >will see it as a fault.=C2 So for it to work this >way the VPX stop settings using the position >sensor (not as accurate) will have to be in sync >with the limit switches.=C2 And the position >sensor may not be accurate enough to sync with the limit switches. > >A big thanks for everyone=99s help! > >Valin I think you're making this much more complicated than it needs to be. See: http://tinyurl.com/lel2jep You don't want to ground the flap motor power on the instrument panel ground bus . . . that goes to the firewall ground. As you've noted, pins 5 & 6 need to be identified for which one is +extend and +retract. You want to disable the VP-X limit switch functions or nullify them by programming them outside the points where the limit switches operate. Bob . . . ________________________________________________________________________________
Date: Dec 30, 2013
I recently purchased just a few from Mouser...=0A=0A=0A=0A=0A______________ __________________=0A From: "Robert L. Nuckolls, III" <nuckolls.bob@aeroele ctric.com>=0ATo: aeroelectric-list(at)matronics.com =0ASent: Monday, December 30, 2013 7:55 AM=0ASubject: Re: AeroElectric-List: E-bus diode=0A =0A=0A--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" =0A=0AAt 06:33 PM 12/29/2013, you wrote:=0A>--> AeroEle ctric-List message posted by: "user9253" =0A>=0A>Would t his Schottky Diode be suitable for E-bus Feed?=0A>http://www.mouser.com/Pro ductDetail/IXYS/DSA300I200NA/?qs=sGAEpiMZZMtQ8nqTKtFS%2fAkrg%2fe%2fM1X2RJ uduJKKNsI%3d=0A>It appears to be very robust with easy mounting.=0A>Joe=0A> =0A>--------=0A>Joe Gores=0A>=0A>=0A=0A- Yes, but you may want to seek a nohter source.=0A- Mouser seems to want to sell these in lots=0A- of =- - - - - - - - - - - - - - - -Matt Dralle === ________________________________________________________________________________
Date: Dec 30, 2013
Joe, How about the IXYS DSS 2x81-0045A ? It is in the same SOT-227B package. It is a lower current device, but still capable of much larger currents than those likely seen on the E-Bus. According to the graph, it has a typical forward drop of 0.34V at 10A. Even better - you can buy 1 instead of minimum quantity 10 and they are 25% cheaper :-) Jeff Page Dream Aircraft Tundra #10 http://ca.mouser.com/ProductDetail/IXYS/DSS2x61-0045A/?qs=%2fha2pyFaduhdMr45WqeM8mDZl76obrBu5hnr8BNQ46k%3d > Would this Schottky Diode be suitable for E-bus Feed? > http://www.mouser.com/ProductDetail/IXYS/DSA300I200NA/?qs=sGAEpiMZZMtQ8nqTKtFS%2fAkrg%2fe%2fM1X2RJuduJKKNsI%3d > It appears to be very robust with easy mounting. > Joe > > -------- > Joe Gores ________________________________________________________________________________
Date: Dec 30, 2013
Jeff, did you mean DSS2x61-0045A? It has the characteristics that you mentioned. I could not find DSS 2x81-0045A. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=416389#416389 ________________________________________________________________________________
Date: Dec 30, 2013
Thanks Bob =93 that=99s much simpler and elegant. As I looked at your design I just kept saying =9CBob=99s a genius=9D :) I think I was stuck on preserving the Lancair circuitry instead of just solving the problem. Thank you very much! Valin From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Monday, December 30, 2013 9:45 AM Subject: RE: AeroElectric-List: Re: Source for Relay DPDT (On) Off (On ? -- VPX to Lancair Flap Motor Integration At 06:00 PM 12/29/2013, you wrote: Thanks Bob McC, you have an excellent memory.=C3=82 I=C3=A2=82=AC=84=A2ve corrected those labels now.=C3=82 I=C3=A2=82=AC=84=A2ve worked up a drawing with yours and the other=C3=A2=82=AC=84=A2s suggestion to just use two relays to interface between the VPX and Lancair flap motor circuitry.=C3=82 I=C3=A2=82=AC=84=A2ve attached the drawing.=C3=82 If anyone sees any problems or can suggest how to make it simpler please let me know. I expect Marc at VPX will be concerned the VPX will use the position senor to stop the flaps and if a limit switch stops it first the VPX will see it as a fault.=C3=82 So for it to work this way the VPX stop settings using the position sensor (not as accurate) will have to be in sync with the limit switches.=C3=82 And the position sensor may not be accurate enough to sync with the limit switches. A big thanks for everyone=C3=A2=82=AC=84=A2s help! Valin I think you're making this much more complicated than it needs to be. See: http://tinyurl.com/lel2jep You don't want to ground the flap motor power on the instrument panel ground bus . . . that goes to the firewall ground. As you've noted, pins 5 & 6 need to be identified for which one is +extend and +retract. You want to disable the VP-X limit switch functions or nullify them by programming them outside the points where the limit switches operate. Bob . . . <http://www.aeroelectric.com> <http://www.buildersbooks.com> <http://www.homebuilthelp.com> <http://www.mypilotstore.com> ________________________________________________________________________________
Date: Dec 30, 2013
For several years I have sold: IXYS DSSX61-0045A with a heatsinks, mounting hardware, shipping and manual. It's a good choice. Eric M. Jones PerihelionDesign.com -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=416393#416393 ________________________________________________________________________________
Date: Dec 30, 2013
VPX to Lancair Flap Motor Integration At 01:25 PM 12/30/2013, you wrote: >Thanks Bob ' that=99s much simpler and >ellegant.=C2 As I looked at your design I just >kept saying =9CBob=99s a genius=85=9D=C2 J=C2 =C2 I >think I was stuck on preserving the Lancair >circuitry instead of just solving the problem.=C2 > >Thank you very much! > >Valin My pleasure. I'll explore the details with Marc but at the present, I'm 99.8% certain that we're golden. Bob . . . ________________________________________________________________________________
Date: Dec 30, 2013
-Of course a higher voltage drop leads to a higher heat generated and,- hence, for many of us, the attraction of the Schottky diodes.- I've been searching for single diodes to use in a modified version of -Bob's new Z- 07.- I'll have 12-15 amps-of current through one diode.-I'm wondering about a diode in the ITO-220 case, like =0Ahttp://www.digikey.com/product- detail/en/VFT4045BP-M3%2F4W/VFT4045BP-M3%2F4W-ND/3102977=0A=0AWith a forwar d of current of around 0.5V, the power to be thermally accommodated is less than 8W. and many heat sinks are available for the-TO-220 configuration. - The connections on the TO-220-must be soldered, but I'm less concerne d about soldered connections after reading Bob's recent article in Kitplane .- =0A=0AAre there other reasons for rejecting a diode like this?=0A=0ATo m=0A=0A=0A=0A=0A>________________________________=0A> From: "Robert L. Nuck olls, III" =0A>To: aeroelectric-list@matroni cs.com =0A>Sent: Monday, December 30, 2013 9:01 AM=0A>Subject: Re: AeroElec tric-List: E-bus diode=0A> =0A>=0A>--> AeroElectric-List message posted by : "Robert L. Nuckolls, III" =0A>=0A>At 08:04 oger & Jean" =0A>> =0A>>> Would this Schottky Diode be suitable for E-bus Feed?=0A>>> http://www.mouser.com/ProductDetai l/IXYS/DSA300I200NA/?qs=sGAEpiMZZMtQ8nqTKtFS%2fAkrg%2fe%2fM1X2RJuduJKKNsI %3d=0A>>> It appears to be very robust with easy mounting.=0A>> =0A>> =0A>> The spec sheet says the forward voltage drop is 0.98V.- Do you think tha t is acceptable?=0A>=0A>- That's a worst case condition which is almost n ever=0A>- realized in the manner in which we use them. Furhter,=0A>- as explained in other narratives concerning drops=0A>- in the e-bus normal feed diodes, there's no chance=0A>- that a diode offers an 'unacceptable' voltage drop.=0A>=0A>- The normally expected drops in all forms of diode =0A>- will produce an alternator-operating e-bus voltage=0A>- no less t han 13v and probably HIGHER. While operating=0A>- the e-bus battery-only, available voltage will be 12.5=0A>- volts or LOWER . . . and we expect t hings to work=0A>- just fine at that level too.=0A>=0A>- Don't get wrap ped about the "oh-my-gosh-there's-=0A>- a-voltage-drop" axle.- It the g rand scheme of=0A>- things its immaterial. This is why we've offered=0A> - and recommended the plain-vanilla, bridge rectifier=0A>- with fast-on tabs for nearly 20 years . . . cheap,=0A>- easy to mount and you can get the things at=0A>- Radio Shack.=0A>=0A>=0A>=0A>=0A>- Bob . . . =0A>=0A =============0A>=0A>=0A>=0A>=0A>=0A> ________________________________________________________________________________
Date: Dec 31, 2013
Subject: Re: Making fat wire fatter
At 06:04 PM 11/21/2013, you wrote: >I need to terminate a piece of #2 or #4 (not sure which) welding >cable with a #0 wire terminal. So I want to increase the diameter >of the stranded copper a little bit so that it fits snugly within >the #0 wire terminal. > >I'm thinking about inserting the copper from some #12 solid wire >into the center of the #2 (or #4) to fatten it up and then crimping >it... Or maybe using a #6 brass machine screw inserted the same way. > >Suggestions? > >-Jeff http://tinyurl.com/ct36xen Bob . . . ________________________________________________________________________________
Date: Dec 31, 2013
At 10:39 PM 12/30/2013, you wrote: Of course a higher voltage drop leads to a higher heat generated and, hence, for many of us, the attraction of the Schottky diodes. Yes . . . but how much heat . . . and what's the difference between the two technologies? I've been searching for single diodes to use in a modified version of Bob's new Z-07. I'll have 12-15 amps of current through one diode. That's a really BIG e-bus load . . . what's your anticipated alternator-out endurance for the battery you plan to carry? I'm wondering about a diode in the ITO-220 case, like http://www.digikey.com/product-detail/en/VFT4045BP-M3%2F4W/VFT4045BP-M3%2F4W-ND/3102977 With a forward of current of around 0.5V, the power to be thermally accommodated is less than 8W. and many heat sinks are available for the TO-220 configuration. The connections on the TO-220 must be soldered, but I'm less concerned about soldered connections after reading Bob's recent article in Kitplane. Heatsink? What's your airplane made of? If there's a few square inches of aluminum handy . . . why not simply sink it to the airplane? Are there other reasons for rejecting a diode like this? Suggest you sift the premises under which your procurement study is being conducted. This diode . . . http://tinyurl.com/nx5st6p will carry 15A handily simply bolted down to local sheet metal . . . but it's my fondest wish that it never sees even 1/2 that load. Not because the diode is at risk for overheating but because the battery is not being well conserved for alternator-out operations. Were it my airplane, a high-priority design goal would be to carry enough battery loaded so lightly by the e-bus that I could depart, punch through a cloud layer, suffer a failed alternator and still comfortably continue flight to airport of intended destination. The "e" in e-bus is for ENDURANCE. Bob . . . ________________________________________________________________________________
Date: Dec 31, 2013
Opps. Stuck foot in mouth when I wrote: Were it my airplane, a high-priority design goal would be to carry enough battery loaded so lightly by the e-bus that I could depart, punch through a cloud layer, suffer a failed alternator and still comfortably continue flight to airport of intended destination. The "e" in e-bus is for ENDURANCE. You said Z-07 . . . electrically dependent engine. Okay, nice fat endurance numbers are simply not practical for battery-only ops. Okay, your quest for the "golden diode" is still no big deal. Suggest you consider the dual, TO-247 package devices, parallel the diodes for improved thermal resistance and simply mount to the airframe as suggested in the product literature I cited. Bob . . . ________________________________________________________________________________
Date: Dec 31, 2013
Thanks Bob.- Just the kind of advice I was looking for.- -Glad I didn 't rush to respond to you earlier message.=0A=0ATom=0A=0A=0A=0A>___________ _____________________=0A> From: "Robert L. Nuckolls, III" <nuckolls.bob@aer oelectric.com>=0A>To: aeroelectric-list(at)matronics.com =0A>Sent: Tuesday, De cember 31, 2013 9:38 AM=0A>Subject: Re: AeroElectric-List: E-bus diode=0A> =0A>=0A>Opps. Stuck foot in mouth when I wr ote:=0A>=0A>Were it my airplane, a high-priority design goal would be to ca rry enough battery loaded=0A>so lightly by the e-bus that I could depart, p unch through a cloud layer, suffer a failed=0A>alternator and still comfort ably continue flight to airport of intended destination. The=0A>"e" in e-bu s is for ENDURANCE.=0A>=0A>- You said Z-07 . . . electrically dependent =0A>- engine.- Okay, nice fat endurance numbers are simply=0A>- not practical for battery-only ops.=0A>=0A>- Okay, your quest for the "gold en diode" is still=0A>- no big deal. Suggest you consider the dual, TO-2 47=0A>- package devices, parallel the diodes for improved=0A>- therma l resistance and simply mount to the airframe=0A>- as suggested in the p - - - - - - - - - - - - - - -Matt Dralle, List =======0A>=0A>=0A>=0A>=0A>=0A> ________________________________________________________________________________
Subject: Viking engine duel battery setup
Date: Jan 02, 2014
Hi Robert, I know you have concerns about the Viking engine's electrical system. But I purchased a Zenith aircraft with this engine and want to make the plane as safe as I can. The engine is an "aircraftized" Honda Fit with fuel injection. Since the engine will stop is a fuel pump fails Jan Eggenfeller specified duel redundant fuel pumps and the ability to switch pumps. However, there are no previsions for a duel battery circuit or a way to isolate the battery in case of an alternator fault. I would like to install two batteries that are both charged from the 55-Amp alternator and also be able to select the battery that powers the plane's electricals and to isolate the batteries by disconnecting a faulty alternator in flight. I previously built a plane with a Rotax 912 using your wiring diagram, (after attending your great seminar). The Rotax diagram had battery isolation capabilities and was wondering of any of your wiring diagrams describe how to do this for my Viking engine or, if not, can you explain how I can do this properly or at least specify the diodes I need to install in the attached diagram. Thank you for your help, Les Goldner ________________________________________________________________________________
Date: Jan 03, 2014
Subject: Re: Viking engine duel battery setup
At 12:35 PM 1/2/2014, you wrote: Hi Robert, I know you have concerns about the Viking engine's electrical system. The Viking engine a derivative of the Eggenfellner venture which has suffered a checkered history from the perspectives of both business model and engineering . . . http://tinyurl.com/qclebez http://tinyurl.com/qclebez Yes, I have come 'concerns' that extend far beyond the 'electrical system'. But I purchased a Zenith aircraft with this engine and want to make the plane as safe as I can. The engine is an "aircraftized" Honda Fit with fuel injection. Since the engine will stop is a fuel pump fails Jan Eggenfeller specified duel redundant fuel pumps and the ability to switch pumps. However, there are no previsions for a duel battery circuit or a way to isolate the battery in case of an alternator fault. Your premise for needing two batteries or needing to 'isolate them' from a faulted alternator begs more detailed examination. Alternator 'faults' are exceedingly rare these days and are generally limited to mechanical issues (belts and mounts) and wiring (the thing simply shuts down). There's a small risk for an overvoltage condition which is classically managed with a legacy o.v. sense and response system that has been part and parcel of aircraft alternator and generator systems for 60+ years. There is even a smaller probability of a shorted/ open diode array that will either (1) reduce the alternator's output severely or (2) short the battery to ground. The both cases will probably manifest with a low voltage warning with the second case opening the b-lead fuse. In other words, there are no demonstrated alternator faults that go beyond simple failure to function . . . a condition that does not propagate damage or operational stress to other parts of the system. Hence, no additional form of 'isolation' is indicated. There was some discussions and analysis conducted on the aviation special interest groups about 18 years ago concerning the use of diode isolation (ala RV and boat batteries) for dual batteries on airplanes. http://tinyurl.com/oss5t4u I would like to install two batteries that are both charged from the 55-Amp alternator and also be able to select the battery that powers the plane's electricals and to isolate the batteries by disconnecting a faulty alternator in flight. I previously built a plane with a Rotax 912 using your wiring diagram, (after attending your great seminar). The Rotax diagram had battery isolation capabilities and was wondering of any of your wiring diagrams describe how to do this for my Viking engine or, if not, can you explain how I can do this properly or at least specify the diodes I need to install in the attached diagram. You would be well advised to search out, study, and understand all of the failure modes that might cause this engine to cease operation . . . both electrical AND mechanical. Then rank them in order of probability. Yes there will be a pile of "don't know" for probability but at least you have the item on the list. The only time I've seen an Eggenfellner design installed on an aircraft gave me an opportunity to take this picture . . . http://tinyurl.com/p5dgz43 The installation gives rise to concerns for gross complexity (failure risk proportional to parts count) as well as operational reliability. Relays generally don't find their way into the control of critical circuits on any engine installation, aviation or otherwise. The fact that this engine seemed to be 'blessed' with over a dozen such devices is cause for further examination and understanding. The point to being offered here is that past history for Eggenfellner designs suggests that there may be numerous failure modes that go beyond simple concerns for keeping the fuel pumps powered. We've had some discussions here recently on electrical system reliability for the electrically dependent engine . . . exploring the notion that a well maintained, single battery/alternator system has a very low failure rate on a par with other components that might cause engine failure. A new Z-figure . . . http://tinyurl.com/kbn6bys . . . is in it's 5th refinement iteration and I'm pretty confident that it's final configuration will be suited to your installation as well without suffering the weight and cost of ownership penalties for carrying two batteries . . . just to address one of many failure modes. Are the wiring diagrams provided with your engine available on the 'net? If not, can you scan your documents for sharing? Bob . . . ________________________________________________________________________________
Date: Jan 03, 2014
Minor point and I have not dealt with anything newer than 2002, but every EFI vehicle I've worked on had at least one relay that controlled essential engine circuits. My aircraft backup EFI does not have any relays but my primary oem soob efi has the same two as it had in the car. As far as I could determine, the oem relays have outstanding reliability. Have newer vehicles gone to solid state relays? Ken On 03/01/2014 7:57 AM, Robert L. Nuckolls, III wrote: > Relays generally don't find their way into the control of critical > circuits on any engine installation, aviation or otherwise. The fact > that this engine seemed to be 'blessed' with over a dozen such > devices is cause for further examination and understanding. ________________________________________________________________________________
Date: Jan 03, 2014
At 07:57 AM 1/3/2014, you wrote: > >Minor point and I have not dealt with anything newer than 2002, but >every EFI vehicle I've worked on had at least one relay that >controlled essential engine circuits. My aircraft backup EFI does >not have any relays but my primary oem soob efi has the same two as >it had in the car. As far as I could determine, the oem relays have >outstanding reliability. > >Have newer vehicles gone to solid state relays? I don't know . . . but it's coming. Waaayyyyy back when, I was finishing up the qualification paperwork for a pitch trim control system on the Lears. One of my colleagues was working the Mil-Hdbk- 217 MTBF studies on the design. He had factored in all the jelly-beans, solder joints, integrated circuits, and transistors . . . so far so good . . . MTBF was running about 9,000 hours. THEN he factored in a mil-spec, hermetically sealed, power relay . . . whoops! MTBF dropped to about 900 hours! Seems relays are not highly regarded devices in terms of impact on reliability. However, the study protocols did not consider the manner in which I was using the device . . . it was energized before any current was allowed to flow in the contacts . . . and de-energized after current flow ceased. In other words, it never SWITCHED a load, only carried a load but was available for responding to the Wheel-Master-Disconnect switch shutting system down in case of a runaway. To my knowledge, 30+ years later, no relays have ever been replaced. The speed control system has proven very robust also but the monitor system (4x parts count) and some mechanical environmental issues (box is mounted in vertical fin under the trim actuator) have required attention. Ergo, my statement about the use of relays was perhaps too broad . . . or at least lacking details. We attempt to reduce numbers of these things to a minimum . . . they are after all a mechanical device with moving, arcing parts. However, there are design concessions for de-rating, dry-switching, duty-cycle, etc. that go a long way toward boosting relay reliability. To be sure, nobody has more interest in component reliability than the automotive industry. An AD against an airplane generally involves fewer than 100 airplanes . . . recalls on cars can number in the millions. I helped some guys qualify an automotive seat heater onto a Hawker some years back . . . the specs to which the seat had already been qualified were impressive! But you wanna put it on our airplane? Guess what? There's that 80v surge thingy . . . I helped them craft an automatic disconnect circuit that isolated their vulnerable components during the surge event. So your observation is on-point. Relays are not to be shunned out of hand . . . but consider also the lengths that talented users of relays will exercise to make them capable players in the game. Track records for the purveyors is important. Just because it's used on a car is not an automatic pass. A fuse block in my wife's AMC Pacer damned near set the car on fire . . . twice . . . before I replaced it. So let me re-qualify my original reaction to the photo of Eggenfellner's installation. Given the gross numbers of relays combined with his track record, I will suggest that there is cause for placing ALL of his intellectual and physical product under the microscope. Bob . . . ________________________________________________________________________________
Date: Jan 03, 2014
On 1/3/2014 7:57 AM, Robert L. Nuckolls, III wrote: > > The only time I've seen an Eggenfellner > design installed on an aircraft gave me an > opportunity to take this picture . . . > > http://tinyurl.com/p5dgz43 Are you sure that is a picture of an Eggenfellner installation? It doesn't look like any Eggenfellner setups that I've seen, but it does resemble an older NSI setup that I saw at OSH or Sun-n-Fun some years back. At any rate, it is certainly not typical of what is being installed to support Subaru engines (Eggenfellner or otherwise) these days. The Aeroelectric Connection is often used as a reference on the Subaru lists, but if you want to see the last recommended electrical design that came from Eggenfellner before they went out of business, you can download the installation guide from: http://subenews.deej.net/wiki/index.php/EggH6 Click on the "Eggenfellner Engine Installation Guide" (top link under the under the Howto Guides section), and go to page 45, and page 51 has the electrical schematic. Please note this is not an endorsement, just an informational posting. :-) fyi -Dj -- Dj Merrill - N1JOV - VP EAA Chapter 87 Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Date: Jan 03, 2014
=0AIt should be noted that the primary reason for such circuitry is to prev ent paralleling the two independent batteries thru the charging system.=0A =0A=0A=0A=0A________________________________=0A From: Les Goldner <lgold@qu antum-associates.com>=0ATo: Aeroelectric list <aeroelectric-list@matronics. com> =0ASent: Thursday, January 2, 2014 10:35 AM=0ASubject: AeroElectric-Li st: Viking engine duel battery setup=0A =0A=0A=0AHi Robert,=0AI know you ha ve concerns about the Viking engine=99s electrical system. But I purc hased a Zenith aircraft with this engine and want to make the plane as safe as I can. The engine is an =9Caircraftized=9D Honda Fit with f uel injection. Since the engine will stop is a fuel pump fails Jan Eggenfel ler specified duel redundant fuel pumps and the ability to switch pumps. Ho wever, there are no previsions for a duel battery circuit or a way to isola te the battery in case of an alternator fault. =0AI would like to install t wo batteries that are both charged from the 55-Amp alternator and also be a ble to select the battery that powers the plane=99s electricals and t o isolate the batteries by disconnecting a faulty alternator in flight. I p reviously built a plane with a Rotax 912 using your wiring diagram, (after attending your great seminar). The Rotax diagram had battery isolation capa bilities and was wondering of any of your wiring diagrams describe how to d o this for my Viking engine or, if not, can you explain how I can do this p roperly or at least specify the diodes I need to install in the attached di agram.=0AThank you for your help, =0ALes Goldner=C2- ________________________________________________________________________________
Date: Jan 03, 2014
At 11:28 AM 1/3/2014, you wrote: >It should be noted that the primary reason for such circuitry is to >prevent paralleling the two independent batteries thru the charging system. Why would one want to do that? Bob . . . ________________________________________________________________________________
Date: Jan 03, 2014
Are you sure that is a picture of an Eggenfellner installation? It doesn't look like any Eggenfellner setups that I've seen, but it does resemble an older NSI setup that I saw at OSH or Sun-n-Fun some years back. Actually, I'm not. I saw the airplane on display at an airport where I was giving a weekend seminar. I snapped the picture to use in the seminar as an example of an installation that would benefit from some judicious review. At any rate, it is certainly not typical of what is being installed to support Subaru engines (Eggenfellner or otherwise) these days. The Aeroelectric Connection is often used as a reference on the Subaru lists, but if you want to see the last recommended electrical design that came from Eggenfellner before they went out of business, you can download the installation guide from: Thanks for the heads-up! With all due respect to Jan's work, my apologies for any errors of attribution. http://subenews.deej.net/wiki/index.php/EggH6 Click on the "Eggenfellner Engine Installation Guide" (top link under the under the Howto Guides section), and go to page 45, and page 51 has the electrical schematic. Please note this is not an endorsement, just an informational posting. And good information it is my friend. I'll study the drawings and incorporate the information into a follow-up posting. This dovetails nicely with the discussions we're having about Fred's incorporation of the ExpBus in his electrically dependent airplane. Fred provided some asked-for info on his installation which I've not yet had time to consider . . . but it's on the list. Bob . . . ________________________________________________________________________________
Subject: Battery or Contactor Issue?
Date: Jan 03, 2014
RV-8A, Z-13/8 architecture with Off-Batt-Batt/Alt switch to get electrons f lowing. 380 hours over 3 =BE years, original Odyssey PC 680 battery. Flew for 1.3 hours 1 Jan with no problems. On 2 Jan when I turned on Batt/A lt switch, nothing happened. Removed cowl and got out voltmeter - 12.8 volt s to hot side of main contactor. Turned off switch, then back on - same results - nothing. A couple minutes later as I was digging out the electrical diagrams and ref erences with Batt/Alt switch still on, contactor clicked and system operati on was normal with 11.5 volts on the cockpit voltmeter. I am going to replace the battery, but wonder if there is an issue with the contactor. Tried to search Aeroelectric files for contactor troubleshootin g, but couldn't get system to respond. Paul Valovich IYK ________________________________________________________________________________
Date: Jan 03, 2014
Thanks for the information Robert. There is nothing in the Viking engine that looks anything as complex as the picture you included in your last email. In fact, the physical electricals provided with the Viking engine look very "clean". You asked to see the Viking wiring diagrams so I attached two diagrams Jan Eggenfeller provided for the Viking engine. The diagram named "Backup System" is a very nice looking module provided with the Viking engine for redundancy to control two fuel pumps (I think it also controls a duel ECUs) in case one fails. The other diagram is more relevant to my questions to you about having two batteries. It shows recommended power provisions, including a second battery. I would appreciate your comments about employing this two-battery arrangement? Best regard, Les -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Friday, January 03, 2014 4:57 AM Subject: Re: AeroElectric-List: Viking engine duel battery setup --> At 12:35 PM 1/2/2014, you wrote: Hi Robert, I know you have concerns about the Viking engine's electrical system. The Viking engine a derivative of the Eggenfellner venture which has suffered a checkered history from the perspectives of both business model and engineering . . . http://tinyurl.com/qclebez http://tinyurl.com/qclebez Yes, I have come 'concerns' that extend far beyond the 'electrical system'. But I purchased a Zenith aircraft with this engine and want to make the plane as safe as I can. The engine is an "aircraftized" Honda Fit with fuel injection. Since the engine will stop is a fuel pump fails Jan Eggenfeller specified duel redundant fuel pumps and the ability to switch pumps. However, there are no previsions for a duel battery circuit or a way to isolate the battery in case of an alternator fault. Your premise for needing two batteries or needing to 'isolate them' from a faulted alternator begs more detailed examination. Alternator 'faults' are exceedingly rare these days and are generally limited to mechanical issues (belts and mounts) and wiring (the thing simply shuts down). There's a small risk for an overvoltage condition which is classically managed with a legacy o.v. sense and response system that has been part and parcel of aircraft alternator and generator systems for 60+ years. There is even a smaller probability of a shorted/ open diode array that will either (1) reduce the alternator's output severely or (2) short the battery to ground. The both cases will probably manifest with a low voltage warning with the second case opening the b-lead fuse. In other words, there are no demonstrated alternator faults that go beyond simple failure to function . . . a condition that does not propagate damage or operational stress to other parts of the system. Hence, no additional form of 'isolation' is indicated. There was some discussions and analysis conducted on the aviation special interest groups about 18 years ago concerning the use of diode isolation (ala RV and boat batteries) for dual batteries on airplanes. http://tinyurl.com/oss5t4u I would like to install two batteries that are both charged from the 55-Amp alternator and also be able to select the battery that powers the plane's electricals and to isolate the batteries by disconnecting a faulty alternator in flight. I previously built a plane with a Rotax 912 using your wiring diagram, (after attending your great seminar). The Rotax diagram had battery isolation capabilities and was wondering of any of your wiring diagrams describe how to do this for my Viking engine or, if not, can you explain how I can do this properly or at least specify the diodes I need to install in the attached diagram. You would be well advised to search out, study, and understand all of the failure modes that might cause this engine to cease operation . . . both electrical AND mechanical. Then rank them in order of probability. Yes there will be a pile of "don't know" for probability but at least you have the item on the list. The only time I've seen an Eggenfellner design installed on an aircraft gave me an opportunity to take this picture . . . http://tinyurl.com/p5dgz43 The installation gives rise to concerns for gross complexity (failure risk proportional to parts count) as well as operational reliability. Relays generally don't find their way into the control of critical circuits on any engine installation, aviation or otherwise. The fact that this engine seemed to be 'blessed' with over a dozen such devices is cause for further examination and understanding. The point to being offered here is that past history for Eggenfellner designs suggests that there may be numerous failure modes that go beyond simple concerns for keeping the fuel pumps powered. We've had some discussions here recently on electrical system reliability for the electrically dependent engine . . . exploring the notion that a well maintained, single battery/alternator system has a very low failure rate on a par with other components that might cause engine failure. A new Z-figure . . . http://tinyurl.com/kbn6bys . . . is in it's 5th refinement iteration and I'm pretty confident that it's final configuration will be suited to your installation as well without suffering the weight and cost of ownership penalties for carrying two batteries . . . just to address one of many failure modes. Are the wiring diagrams provided with your engine available on the 'net? If not, can you scan your documents for sharing? Bob . . . ________________________________________________________________________________
Date: Jan 03, 2014
-Bob,=0A=0AYou wrote: =0A"There's a small risk=0A- for an overvoltage condition which is classically=0A- managed with a legacy o.v. sense and response system=0A- that has been part and parcel of aircraft alternator =0A- and generator systems for 60+ years."=0AYes, but the Viking has an auto-based system, with an integrated regulator.--You make the comment: =0A"In other words, there are no demonstrated alternator=0A- faults that go beyond simple failure to function . . .=0A- a condition that does no t propagate damage or operational=0A- stress to other parts of the syste m. Hence, no additional=0A- form of 'isolation' is indicated."=0AIs this true?- Is there some recent information that suggests that the "runaway" auto regulator is too unlikely to be an issue.- I've been planning for a "crowbar" and an expensive contactor for this potential event.- Am I ove rreacting?- =0A=0ATom=0A=0A-=0A=0A=0A>________________________________ =0A> From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>=0A>To: aeroelectric-list(at)matronics.com =0A>Sent: Friday, January 3, 2014 5:57 AM =0A>Subject: Re: AeroElectric-List: Viking engine duel battery setup=0A> =0A>=0A>At 12:35 PM 1/2/2014, you wrote:=0A> =0A>Hi Robert,=0A>=0A>I know you have concerns about the Viking engine's el ectrical system.=0A>=0A>- The Viking engine a derivative of=0A>- the Eggenfellner venture which has=0A>- suffered a checkered history from=0A >- the perspectives of both business=0A>- model and engineering . . . =0A>=0A>http://tinyurl.com/qclebez=0A>=0A>http://tinyurl.com/qclebez=0A>=0A >- Yes, I have come 'concerns' that extend far beyond=0A>- the 'elect rical system'.=0A>=0A>But I purchased a Zenith aircraft with this engine an d want to make the plane as safe as I can. The engine is an "aircraftized" Honda Fit with fuel injection. Since the engine will stop is a fuel pump fa ils Jan Eggenfeller specified duel redundant fuel pumps and the ability to switch pumps. However, there are no previsions for a duel battery circuit o r a way to isolate the battery in case of an alternator fault.=0A>=0A>- Your premise for needing two batteries or needing=0A>- to 'isolate them' from a faulted alternator begs=0A>- more detailed examination. Alternat or 'faults' are=0A>- exceedingly rare these days and are generally limit ed=0A>- to mechanical issues (belts and mounts) and wiring=0A>- (the thing simply shuts down). There's a small risk=0A>- for an overvoltage c ondition which is classically=0A>- managed with a legacy o.v. sense and response system=0A>- that has been part and parcel of aircraft alternato r=0A>- and generator systems for 60+ years.=0A>=0A>- There is even a smaller probability of a shorted/=0A>- open- diode array that will eit her (1) reduce the=0A>- alternator's output severely or (2) short the ba ttery=0A>- to ground. The both cases will probably manifest with=0A>- a low voltage warning with the second case opening=0A>- the b-lead fuse .=0A>=0A>-- In other words, there are no demonstrated alternator=0A>- faults that go beyond simple failure to function . . .=0A>- a conditio n that does not propagate damage or operational=0A>- stress to other par ts of the system. Hence, no additional=0A>- form of 'isolation' is indic ated.=0A>=0A>-- There was some discussions and analysis conducted on=0A >- the aviation special interest groups about 18 years=0A>- ago conce rning the use of diode isolation (ala RV=0A>- and boat batteries) for du al batteries on airplanes.=0A>=0A>http://tinyurl.com/oss5t4u=0A>=0A>=0A>I w ould like to install two batteries that are both charged from the 55-Amp al ternator and also be able to select the battery that powers the plane's ele ctricals and to isolate the batteries by disconnecting a faulty alternator in flight. I previously built a plane with a Rotax 912 using your wiring di agram, (after attending your great seminar). The Rotax diagram had battery isolation capabilities and was wondering of any of your wiring diagrams des cribe how to do this for my Viking engine or, if not, can you explain how I can do this properly or at least specify the diodes I need to install in t he attached diagram.=0A>=0A>- You would be well advised to search out, s tudy,=0A>- and understand all of the failure modes that=0A>- might ca use this engine to cease operation . . .=0A>- both electrical AND mechan ical.=0A>=0A>- Then rank them in order of probability. Yes=0A>- there will be a pile of "don't know" for=0A>- probability but at least you ha ve the item=0A>- on the list.=0A>=0A>- The only time I've seen an Egg enfellner=0A>- design installed on an aircraft gave me an=0A>- opport unity to take this picture . . .=0A>=0A>http://tinyurl.com/p5dgz43=0A>=0A> - The installation gives rise to concerns=0A>- for gross complexity ( failure risk proportional=0A>- to parts count) as well as operational=0A >- reliability. Relays generally don't find=0A>- their way into the c ontrol of critical circuits=0A>- on any engine installation, aviation or =0A>- otherwise. The fact that this engine seemed=0A>- to be 'blessed ' with over a dozen such devices=0A>- is cause for further examination a nd understanding.=0A>=0A>- The point to being offered here is that past =0A>- history for Eggenfellner designs suggests=0A>- that there may b e numerous failure modes=0A>- that go beyond simple concerns for keeping =0A>- the fuel pumps powered.=0A>=0A>- We've had some discussions her e recently on=0A>- electrical system reliability for the electrically=0A >- dependent engine . . . exploring the notion=0A>- that a well maint ained, single battery/alternator=0A>- system has a very low failure rate on a par with=0A>- other components that might cause engine failure.=0A >=0A>- A new Z-figure . . .=0A>=0A>http://tinyurl.com/kbn6bys=0A>=0A>- . . . is in it's 5th refinement iteration=0A>- and I'm pretty confiden t that it's final configuration=0A>- will be suited to your installation as well without=0A>- suffering the weight and cost of ownership penalti es=0A>- for carrying two batteries . . . just to address=0A>- one of many failure modes.=0A>=0A>- Are the wiring diagrams provided with your engine=0A>- available on the 'net? If not, can you scan your=0A>- doc ==================0A>=0A>=0A>=0A>=0A>=0A> ________________________________________________________________________________
Subject: RG400/RG142 BNC Male crimp connector
Date: Jan 03, 2014
Hi I need urgently in the UK a couple of RG400/RG142 BNC Male crimp connectors. Trying to find anything suitable on the various (RS, Farnell, Mouser) websites seems impossible. Can anyone let me have a manufacturers part number? Thanks Peter ________________________________________________________________________________
Subject: Re: RG400/RG142 BNC Male crimp connector
Date: Jan 03, 2014
The impossible... Male: http://www.mouser.com/ProductDetail/Amphenol/31-4427/?qs=%2fha2pyFadujw HJP4JrCewP8N91dF1XIvIecgTsyr48I%3d Female: http://www.mouser.com/ProductDetail/Amphenol-Connex/112513/?qs=sGAEpiMZ ZMuLQf%252bEuFsOrjqedbXhavPYNFuAbFgsolY%3d Now...for the UK part, you are on your own. -----Original Message----- From: Peter Mather Sent: Friday, January 03, 2014 12:34 PM Subject: AeroElectric-List: RG400/RG142 BNC Male crimp connector Hi I need urgently in the UK a couple of RG400/RG142 BNC Male crimp connectors. Trying to find anything suitable on the various (RS, Farnell, Mouser) websites seems impossible. Can anyone let me have a manufacturers part number? Thanks Peter ________________________________________________________________________________
Date: Jan 03, 2014
I use Pasternack a lot for RF connectors. They don't always have the lowest cost but they have about everything, it's all good quality and they ship fast. http://www.pasternack.com/bnc-male-standard-rg55-rg141-rg142-rg223-rg400-connector-pe4044-p.aspx Bill On 1/3/14, 10:34 AM, Peter Mather wrote: > > Hi > > I need urgently in the UK a couple of RG400/RG142 BNC Male crimp connectors. > Trying to find anything suitable on the various (RS, Farnell, Mouser) > websites seems impossible. Can anyone let me have a manufacturers part > number? > > Thanks > > Peter > > ________________________________________________________________________________
Date: Jan 03, 2014
for many of the same reasons that (I imagine) you put a "buss tie" contacto r in the Z-14 drawings.=0A=0A=0A=0A=0A________________________________=0A F rom: "Robert L. Nuckolls, III" =0ATo: aeroel ectric-list(at)matronics.com =0ASent: Friday, January 3, 2014 10:11 AM=0ASubje ct: Re: AeroElectric-List: Viking engine duel battery setup=0A =0A=0A--> Ae roElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob@ aeroelectric.com>=0A=0AAt 11:28 AM 1/3/2014, you wrote:=0A=0A> It should be noted that the primary reason for such circuitry is to prevent paralleling the two independent batteries thru the charging system.=0A=0A- Why would =- - - - - - - - - - - - - - - -Matt Dralle === ________________________________________________________________________________
Date: Jan 04, 2014
Subject: Re: Battery or Contactor Issue?
At 12:28 PM 1/3/2014, you wrote: >RV-8A, Z-13/8 architecture with >Off-Batt-Batt/Alt switch to get electrons >flowing. 380 hours over 3 years, original Odyssey PC 680 battery. > >Flew for 1.3 hours 1 Jan with no problems. On 2 >Jan when I turned on Batt/Alt switch, nothing >happened. Removed cowl and got out voltmeter >12.8 volts to hot side of main contactor. > >Turned off switch, then back on same results nothing. > >A couple minutes later as I was digging out the >electrical diagrams and references with Batt/Alt >switch still on, contactor clicked and system >operation was normal with 11.5 volts on the cockpit voltmeter. > >I am going to replace the battery, but wonder if >there is an issue with the contactor. Tried to >search Aeroelectric files for contactor >troubleshooting, but couldnt get system to respond. > >Paul Valovich Unfortunately, you didn't take enough voltage readings. While the battery master was ON but with the contactor NOT energized, you needed to know the voltage on the ground-side terminal of the coil that goes off to the battery switch. Had this voltage ALSO been 12.8 volts, then you would know that causation for failure to close was downstream of the master switch control path either in wiring, the switch or it's ground path. Had the voltage been zero, then you would know that either (1) the battery-master and associated wiring was good and (a) the contactor coil had an intermittent condition or (b) the contactor's moving parts were 'sticking'. If you could get the problem to duplicate, having the extra voltage reading would be helpful. A second reading for contactor coil current would be definitive too. Put your multimeter in the current mode and use it to ground the master switch terminal of the contactor with the master switch OFF. This will emulate the switch path to ground and will either show about 1 amp of contactor coil current (coil good, contactor not closing, therefore sticking) or zero current which says coil is open. If coil current is good, rap the housing of the contactor with a screwdriver handle and see if it drops closed with the aid of some mechanical encouragement. Before you replace the battery, it would be interesting to do a load test on it. Do you have a Battery Minder or a Schumacher 1562 charger? I would bench charge the battery overnight and then load test it at 9 volts to see what the engine cranking dump rate is. 200A will get you started, 500-700A is what you expect from a new battery. This is a classic example of opportunity to make measurements and KNOW what the problem is before turning any wrenches. KNOWING the problem is critical to fixing it with confidence. If you cannot get it to duplicate for the purpose of conducting a detail diagnostic, then there are no concrete assurances that you've identified and fixed the real problem. Bob . . . ________________________________________________________________________________
Date: Jan 04, 2014
At 12:29 PM 1/3/2014, you wrote: > Bob, > >You wrote: > "There's a small risk > for an overvoltage condition which is classically > managed with a legacy o.v. sense and response system > that has been part and parcel of aircraft alternator > and generator systems for 60+ years." >Yes, but the Viking has an auto-based system, with an integrated >regulator. You make the comment: > > "In other words, there are no demonstrated alternator > faults that go beyond simple failure to function . . . > a condition that does not propagate damage or operational > stress to other parts of the system. Hence, no additional > form of 'isolation' is indicated." >Is this true? Is there some recent information that suggests that >the "runaway" auto regulator is too unlikely to be an issue. I've >been planning for a "crowbar" and an expensive contactor for this >potential event. Am I overreacting? The statements I made were in the context of the discussion for 'isolation diodes' in the b-lead. The incorporation of diodes external to the alternator for the purpose of 'isolation' has no foundation in the physics. OV conditions are another matter. There ARE failure modes within built in regulators which are not sufficiently detailed to allow incorporation of STOCK internally regulated alternators into aircraft under the LEGACY design goals. If one embraces those goals then some understanding of the options for ADDING ov protection to the system is necessary. See: http://tinyurl.com/nexuekf http://tinyurl.com/cx6426c There have been some interesting discussions about design goals for system robustness and the implementation of failure tolerance in OBAM aircraft over the years. Some positions were adopted by individuals unable to demonstrate an understanding of failure tolerant design goals . . . http://tinyurl.com/7lhbbah http://tinyurl.com/nexuekf http://tinyurl.com/omnuypr My goals and those of my employers over the years has been to first reduce probability of malfunction with robust designs backed up by further reduction of risks with failure tolerant designs. Alternators are but one of many components with an ability to elevate your concerns while airborne . . . but easily managed. Bob . . . ________________________________________________________________________________
Date: Jan 04, 2014
Subject: Re: Relays on Lear jets
At 12:55 PM 1/3/2014, you wrote: Bob, On an earlier post today, you mentioned a project where you energized a relay before any current flowed thru it, and de-energized it after current flow stopped. Can you tell me how you did this and why. If the relay was not used as a switch, then why was a relay used in this solution? This was a design requirement unique to a system that moves flight control surfaces with a motor. This is common to trim systems, autopilots, flaps and more recently fly-by-wire systems. In the conduct of an analysis for failure mode effects, any fault that causes anomalous or unintended motion of a flight control surface needs to be fitted with a means for rapid manual or perhaps automatic shutdown. In a flap system design for Eclipse some years ago, we incorporated a crowbar system that opened the motor supply breaker to effect a shutdown. In the trim system for the Lear, a hard-contacts relay was used in series with the motor power path to the solid state electronics that controlled motor speed and direction. The fault monitoring system needed to watch the both control and shut down components for failure so it was necessary that the series relay be exercised to demonstrate functionality. Obviously, if the relay fails to close, the trim doesn't run. But if it failed to open, then some means for detecting and annunciating the event was called for. The technique chosen in this application was to have the disconnect relay operate every time the pilot called for trim. But in the interest of long relay life, it was advantageous to close the relay milliseconds before the motor was energized through solid state electronics. Similarly, the motor was de-energized through solid state switching milliseconds before the relay was commanded open. Hence, the relay contacts were preserved for carrying out a single, important task . . . offer mechanical disconnect of trim system power when commanded by the pilot's Wheel Master Disconnect system. By making the relay offer both closed and open conditions for each trim event, the monitor system could watch for and detect both failure to close and failure to open events. Also, since solid state relays are immune from the failure modes of mechanical relays, what are the "typical" causes of failures in solid state relays? They short, they fail to close. They are no different than their electro-mechanical counterparts for how failure manifests . . . different only in the physics that precipitates the failure. Solid state relays are immune to the effects of contact arcing that produces erosion and/or sticking . . . but they can still be degraded by inappropriate application and/or extra-ordinary external stresses. Thanks for all your efforts with the aeroelectric list, I'm not there yet but pedaling as fast as I can. You're welcome . . . I'm pleased that you find value in the effort. Bob . . . ________________________________________________________________________________
Date: Jan 04, 2014
Peter - I've got a couple, email me off list. Peter On 03/01/2014 18:34, Peter Mather wrote: > > Hi > > I need urgently in the UK a couple of RG400/RG142 BNC Male crimp connectors. > Trying to find anything suitable on the various (RS, Farnell, Mouser) > websites seems impossible. Can anyone let me have a manufacturers part > number? > > Thanks > > Peter > > ________________________________________________________________________________
Date: Jan 04, 2014
At 01:49 PM 1/3/2014, you wrote: >for many of the same reasons that (I imagine) you put a "buss tie" >contactor in the Z-14 drawings. But what might those reasons be? In other words, we add a component to a system to effect some desired functionality that figures into the overall performance, failure tolerance and risks. If diodes were incorporated in the manner suggested to feed the two batteries, how would we expect these to operate and for what purpose? I'm not trying to be obtuse here my friend. I AM encouraging all of my readers to understand the application of every component they choose to add to their system. Suppose I offered a description for the buss-tie contactor like, "This contactor offers pilot control of the phramistat to prevent inadvertent operation of the whatsadozit and potential damage to the dingusfuzzy." The inquiring builder would probably want some detailed expansion on that statement . . . un- fortunately, others will assume the statement correct and useful based on the reputation (deserved or otherwise) of the writer. I encourage yourself and others to KNOW why a part is included and UNDERSTAND what useful things it will do for you. Hence my question as to any value you perceive for having those diodes in place as suggested. Bob . . . ________________________________________________________________________________
Date: Jan 04, 2014
Not a problem Bob...I'm busying myself attempting to master the techniques necessary to assemble a 25 pin D-sub w/ mostly shielded wires...Fred Okay, I presume you've looked at this piece on the website. http://tinyurl.com/87lea6o The shields do not have to come together inside the connector back-shell. If there are a lot of them, you can have a couple inches of un-shielded wires allowing all the shield terminations to happen outside the back-shell. Bob . . . ________________________________________________________________________________
Date: Jan 04, 2014
Emacs! Okay, referring to the abbreviated power distribution diagram from the Viking installation literature, we see two batteries, both 'protected' buy current limiters and paralleled onto the system with independent contactors. One of the two batteries is fitted with an always hot feeder routed to a 4-pole engine power selection switch. Years ago, I proposed a similar two-battery system which could be automated to some degree with what was at that time called the Aux Battery Management Module. http://tinyurl.com/l353p5m http://tinyurl.com/mrxbrtw Back in those days, the notion was that at least one of two electronic ignition systems and perhaps a boost pump could be supported on an independent battery automatically isolated from the rest of the airplane when an alternator failure was detected (low voltage). Let's revisit those notions in light of the Viking installation documents that speak to a 'requirement' for a second battery capable of running the engine for a minimum of 30 minutes. First, how does one KNOW that battery #2 is capable of meeting that requirement? It has to be sized -AND- maintained such that the necessary energy available when needed. Okay, what conditions would FORCE the use of #2 battery? (a) no doubt the alternator is off line for what ever reason and (b) and we KNOW that #1 battery is not capable of carrying the engine + other endurance loads for at least 30 minutes. Hmmmm . . . if we KNOW that #1 battery is overtaxed for the task of supplied combined energy needs but that #1 plus #2 battery WILL rise to the occasion, then what is the value in having two batteries? Would a single battery with a KNOWN capacity for the combined loads not be a simpler, lighter and lower cost choice? In other words, what combination of conditions pose such risk that a second battery is needed to mitigate the risk? Two batteries DOUBLES your battery maintenance expenses and adds empty weight . . . all intended to mitigate a rather rare event . . . alternator failure. This line of reasoning is germane to the discussions we were having on Fred's Exp-Bus integration which prompted the crafting of Figure Z-7. It also applies to Les's question about diodes suitable for battery isolation. Obviously, the golden solution will include some assessment of loads over and above those required to run the engine . . . along with some decisions as to whether you're expecting to keep the panel all lit up . . . or have crafted a plan-B that matches your skills and confidence levels for getting down with a bare minimum of panel equipment combined perhaps with flight bag back-up hardware. If Figure Z-7 were substituted for the figure above, are there any unforeseen risks? Comments on the Viking drawing, Figure Z-7 and perceptions of your individual FMEAs are solicited . . . Bob . . . ________________________________________________________________________________
Date: Jan 04, 2014
Subject: Solid state DC/DC relay follow-up.
The exemplar relay I ordered in last week arrived and the performance is . . . shall we say . . . disappointing. I set up to switch a 12A load and voltage drop across the 'contacts' was about 2.1 volts for an on-state resistance of 0.175 ohms. Clearly way too high to be a practical relay for more than a couple amps . . . much less the 'rated' 100A. I'm in a conversation with the supplier now . . . perhaps I have an anomalous specimen . . . watch this space. Bob . . . ________________________________________________________________________________
Date: Jan 04, 2014
Bob, As someone who has a Viking engine and who has been looking to modify Z-7 fo r my electrical system, I'm very interested in this thread. First, where di d you get the diagram at the top of your last posting? It's clearly differe nt then the one sent by Les Goldner, which I also got from the Viking websit e. It appears to be a system for Vikings unreleased turbo version. I hesitate to make the following comment, since you chose not to answer my l ast question about alternators running without batteries; but you asked for c omments on Z-7 for this application. Viking claims that the alternator can r un with the batteries disconnected and I believe that the diagram provided b y Les allows for that. Your comment in an earlier thread that you wouldn't s witch off the battery/batteries unless you were also disconnecting the alter nator is a strong position. I understand that batteries that are properly m aintained don't usually fail in a catastrophic manner, but is that never? C an we quantify? Hard to separate failures due to inadequate maintenance and others. In the absence of numbers but anecdotal experiences of failures (m ine for one), why not have an allowance for running off the alternator only? Seems prudent to me, so I'd like to understand why it isn't to you. Thank s. Tom Sent from my iPad > On Jan 4, 2014, at 9:13 AM, "Robert L. Nuckolls, III" <nuckolls.bob@aeroel ectric.com> wrote: > > > > > Okay, referring to the abbreviated power distribution diagram > from the Viking installation literature, we see two batteries, > both 'protected' buy current limiters and paralleled onto > the system with independent contactors. One of the two batteries > is fitted with an always hot feeder routed to a 4-pole engine power > selection switch. > > Years ago, I proposed a similar two-battery system which > could be automated to some degree with what was at that > time called the Aux Battery Management Module. > > http://tinyurl.com/l353p5m > > http://tinyurl.com/mrxbrtw > > Back in those days, the notion was that at least one of > two electronic ignition systems and perhaps a boost pump > could be supported on an independent battery automatically > isolated from the rest of the airplane when an alternator > failure was detected (low voltage). > > Let's revisit those notions in light of the Viking installation > documents that speak to a 'requirement' for a second battery > capable of running the engine for a minimum of 30 minutes. > > First, how does one KNOW that battery #2 is capable of > meeting that requirement? It has to be sized -AND- maintained > such that the necessary energy available when needed. > > Okay, what conditions would FORCE the use of #2 battery? > (a) no doubt the alternator is off line for what ever > reason and (b) and we KNOW that #1 battery is not capable > of carrying the engine + other endurance loads for at least > 30 minutes. > > Hmmmm . . . if we KNOW that #1 battery is overtaxed for > the task of supplied combined energy needs but that > #1 plus #2 battery WILL rise to the occasion, then what > is the value in having two batteries? Would a single > battery with a KNOWN capacity for the combined loads not > be a simpler, lighter and lower cost choice? > > In other words, what combination of conditions pose such > risk that a second battery is needed to mitigate the risk? > Two batteries DOUBLES your battery maintenance expenses > and adds empty weight . . . all intended to mitigate a > rather rare event . . . alternator failure. > > This line of reasoning is germane to the discussions > we were having on Fred's Exp-Bus integration which prompted > the crafting of Figure Z-7. It also applies to Les's question > about diodes suitable for battery isolation. Obviously, the > golden solution will include some assessment of loads over and > above those required to run the engine . . . along with > some decisions as to whether you're expecting to keep the panel all lit > up . . . or have crafted a plan-B that matches your skills > and confidence levels for getting down with a bare minimum > of panel equipment combined perhaps with flight bag back-up > hardware. > > If Figure Z-7 were substituted for the figure above, are > there any unforeseen risks? Comments on the Viking drawing, > Figure Z-7 and perceptions of your individual FMEAs are solicited . . . > Bob . . . ________________________________________________________________________________
Date: Jan 04, 2014
Subject: Proposed new Z diagram?
I'd like to start off by saying please be gentle. I'm not an expert and this could be completely boneheaded. I've been looking through the various Z diagrams, and although there are parts of some that I like, I could not find one that is exactly what I am (or think I am) looking for. From being on this list for a decade or more, I know that Bob's first question will be along the lines of "What are you looking for" followed by "What elements do you want that aren't addressed by the current diagrams". It is hard to put into words, but I'm going to try. My aircraft will have an electrically dependent engine (electronic ignition, gravity feed so no fuel pump) and an electrically dependent panel (GRT HX EFIS and EIS). It will be used for IFR. I know recently that we have been talking about how statistically reliable alternators and batteries are, and have been considering a Z-7 based on a single alt and battery. Physics and statistics aside, I am just not comfortable with this, and I want a dual battery configuration. This is a personal choice. That led me to Z-19. What I do not like about Z-19 is that it has two always hot power buses. I want a system that when the contactor is off, the battery is isolated except for the wires going to the contactor. Again, physics and logic aside, this what I "want". What I like about Z-19 is the redundancy providing power to the ECU and Fuel Pump, and that it is an automatic redundancy. Both power buses are providing power to the ECU at the same time from independent sources. This led me to realize that I really do not care about having an "endurance" bus, but what I really care about is having a "redundant" bus, in other words there are a few devices in my setup that I want to have the same automatic redundant power as offered by the engine part of Z-19. Taking parts of Z-19 that I like, and leaving parts out, I've attempted to create a "redundant bus" diagram. It also incorporates an "alternator only" operation simply by the fact of isolating the two charging circuits and having the alternator on its own switch, although I can't picture running in this mode. Please excuse the crudeness of the drawing. I did it by hand, and just took a picture of the paper afterwards. Some parts I am not even sure are feasible, such as the diodes that separate the two charging circuits (located just above the primary bus in the drawing). I don't even know if diodes exist that will be able to handle those loads, but I am sure that some sort of electro-whizzy would probably do it. Some notes: I will be using a Fly EFII electronic ignition. Manufacturer recommendation is a 10 amp CB/fuse for the coil charging circuit, and 5 amp for the ECU. I am told that overall the ignition draws 1.2 amps on average for power usage purposes, but the coil charging currents can be up to 10 amps. This current only flows for a few milliseconds. Gravity feed for the fuel, so no fuel pump. The GRT HX EFIS and the GRT EIS have multiple, internal diode isolated power feeds built in which is why there are Pow "A" and Pow "B" feeds for each of these devices. This is a first pass, but I am thinking that I want GPS, NAV, COM, and the Intercom to also have redundant power. I want enough to make an instrument approach if needed, so usage and/or recommendations may change this list. Everything else is wired to the primary bus only (no access to the secondary bus). Not completely sure yet, but I anticipate the Aux battery to be smaller, and mounted under the panel. It will be sized appropriately to offer at least an hour of battery-only operation for items on the redundant bus and to support the ignition. The main battery will be larger and mounted in the tail for CG purposes. Please critique, but be nice! :-) Small version: http://deej.net/glastar/pics/electrical/redundant.jpg Larger picture: http://deej.net/glastar/pics/electrical/redundant-large.jpg -Dj -- Dj Merrill - N1JOV - VP EAA Chapter 87 Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Date: Jan 04, 2014
At 12:19 PM 1/4/2014, you wrote: Bob, As someone who has a Viking engine and who has been looking to modify Z-7 for my electrical system, I'm very interested in this thread. First, where did you get the diagram at the top of your last posting? It's clearly different then the one sent by Les Goldner, which I also got from the Viking website. It appears to be a system for Vikings unreleased turbo version. I got it from the Viking website using a link forwarded to me by one of the list readers. The exact version is insignificant at the moment as the points to ponder deal with the rationale for two batteries as opposed to one. I hesitate to make the following comment, since you chose not to answer my last question about alternators running without batteries; but you asked for comments on Z-7 for this application. My apologies . . . didn't mean to ignore your question. Never hesitate to jump right in the middle of my lap if you believe some important link of communication has broken. This list isn't about feelings, it's about ideas . . . and even though GMCJetpilot found the assertion incredible, I cannot be insulted and I welcome logical persuasion. Viking claims that the alternator can run with the batteries disconnected and I believe that the diagram provided by Les allows for that. Okay, that doesn't surprise me. I'm wondering to what extent that operating mode has been tested. Your comment in an earlier thread that you wouldn't switch off the battery/batteries unless you were also disconnecting the alternator is a strong position. . . . yes . . . based on the legacy design goals of yesteryear when the split-rocker master switch was king. But that was several generations ago in both alternator and battery design. Odds are that most airplanes will continue operating sans battery . . . but I suspect there are limits that should be explored. I had some plans to acquire a variable speed drive stand some years ago. The goal was to explore the new alternator-only paradigm. I understand that batteries that are properly maintained don't usually fail in a catastrophic manner, but is that never? Can we quantify? I'll have to ask Skip about that. Concorde has done countless failure analysis over the course of battery evolution in aircraft and can probably offer us some quantitative assessment. Hard to separate failures due to inadequate maintenance and others. In the absence of numbers but anecdotal experiences of failures (mine for one), why not have an allowance for running off the alternator only? Seems prudent to me, so I'd like to understand why it isn't to you. Thanks. I absolutely agree. But just as I was loath to RECOMMEND the internally regulated alternator some years back, my reluctance is not based on hard negative data but a lack of hard positive data. If Viking says they can run alternator only, I rather suspect that they have at least determined that the engine doesn't quit and the panel stays lit with the batteries OFF. I wonder to what extent any testing has been accomplished and documented upon which a gray beard stuck in such traditions can offer confident recommendation. Thanks for asking . . . Bob . . . ________________________________________________________________________________
Date: Jan 04, 2014
Subject: Re: Proposed new Z diagram?
My aircraft will have an electrically dependent engine (electronic ignition, gravity feed so no fuel pump) and an electrically dependent panel (GRT HX EFIS and EIS). It will be used for IFR. How is the engine dependent? Ignition? Fuel Injection? Do you have the energy requirement numbers? I know recently that we have been talking about how statistically reliable alternators and batteries are, and have been considering a Z-7 based on a single alt and battery. Physics and statistics aside, I am just not comfortable with this, and I want a dual battery configuration. This is a personal choice. That led me to Z-19. One can ALWAYS add a second battery. Our builders have been doing this for decades and the techniques have been discussed at length on the List. What I do not like about Z-19 is that it has two always hot power buses. I want a system that when the contactor is off, the battery is isolated except for the wires going to the contactor. Again, physics and logic aside, this what I "want". Any always hot busses are battery busses and they're part and parcel of a considered FEMA and meeting design goals. It's my wish that we can assist with the crafting of your design goals based more on understanding and planning and not so much on worries that drive your discomfort. What I like about Z-19 is the redundancy providing power to the ECU and Fuel Pump, and that it is an automatic redundancy. Both power buses are providing power to the ECU at the same time from independent sources. This led me to realize that I really do not care about having an "endurance" bus, but what I really care about is having a "redundant" bus, in other words there are a few devices in my setup that I want to have the same automatic redundant power as offered by the engine part of Z-19. Redundant to meet what failure event. There's nothing that prevents one from having as many batteries, alternators, busses and switches as their creativity and physical space allows . . . but in the TC aircraft world, the first goal is to minimize weight, parts count, system complexity and cost of ownership. At the same time, risk assessment must necessarily drive all the above goals in the wrong direction. The elegant design adds just enough but no more. Taking parts of Z-19 that I like, and leaving parts out, I've attempted to create a "redundant bus" diagram. It also incorporates an "alternator only" operation simply by the fact of isolating the two charging circuits and having the alternator on its own switch, although I can't picture running in this mode. Please excuse the crudeness of the drawing. I did it by hand, and just took a picture of the paper afterwards. Some parts I am not even sure are feasible, such as the diodes that separate the two charging circuits (located just above the primary bus in the drawing). I don't even know if diodes exist that will be able to handle those loads, but I am sure that some sort of electro-whizzy would probably do it. Some notes: I will be using a Fly EFII electronic ignition. Manufacturer recommendation is a 10 amp CB/fuse for the coil charging circuit, and 5 amp for the ECU. I am told that overall the ignition draws 1.2 amps on average for power usage purposes, but the coil charging currents can be up to 10 amps. This current only flows for a few milliseconds. So have you arrived at a ball-park number for total electrical system energy requirements? You speak to a 60 minute battery-only ops goal but can/should it be longer? Gravity feed for the fuel, so no fuel pump. The GRT HX EFIS and the GRT EIS have multiple, internal diode isolated power feeds built in which is why there are Pow "A" and Pow "B" feeds for each of these devices. This is a first pass, but I am thinking that I want GPS, NAV, COM, and the Intercom to also have redundant power. I want enough to make an instrument approach if needed, so usage and/or recommendations may change this list. Everything else is wired to the primary bus only (no access to the secondary bus). Not completely sure yet, but I anticipate the Aux battery to be smaller, and mounted under the panel. It will be sized appropriately to offer at least an hour of battery-only operation for items on the redundant bus and to support the ignition. The main battery will be larger and mounted in the tail for CG purposes. Please critique, but be nice! You have described adjustments to an architecture but it's not clear as to the reasoning behind those moves. It seems as if you don't want any single failure to cause to you drop to an energy efficient, endurance mode . . . are you trying to keep everything lit up no matter what? You speak of a large main battery and a smaller auxiliary battery. What's the physics behind these sizing decisions? Larger picture: http://deej.net/glastar/pics/electrical/redundant-large.jpg Z-7 elects to drive a single engine bus through diodes from two power paths. What in your knowledge or experience suggests that charging batteries through diodes offers more attractive options? Bob . . . ________________________________________________________________________________
Subject: Re: Viking engine duel battery setup
Date: Jan 04, 2014
Hi All This is the Eggenfellner Aircraft Engines wiring diagram for a Subaru engine (turbo'd). This where the E6T engine reference comes from. Cheers Les Sent from my iPhone > On Jan 4, 2014, at 9:13 AM, "Robert L. Nuckolls, III" <nuckolls.bob@aeroel ectric.com> wrote: > > > > > Okay, referring to the abbreviated power distribution diagram > from the Viking installation literature, we see two batteries, > both 'protected' buy current limiters and paralleled onto > the system with independent contactors. One of the two batteries > is fitted with an always hot feeder routed to a 4-pole engine power > selection switch. > > Years ago, I proposed a similar two-battery system which > could be automated to some degree with what was at that > time called the Aux Battery Management Module. > > http://tinyurl.com/l353p5m > > http://tinyurl.com/mrxbrtw > > Back in those days, the notion was that at least one of > two electronic ignition systems and perhaps a boost pump > could be supported on an independent battery automatically > isolated from the rest of the airplane when an alternator > failure was detected (low voltage). > > Let's revisit those notions in light of the Viking installation > documents that speak to a 'requirement' for a second battery > capable of running the engine for a minimum of 30 minutes. > > First, how does one KNOW that battery #2 is capable of > meeting that requirement? It has to be sized -AND- maintained > such that the necessary energy available when needed. > > Okay, what conditions would FORCE the use of #2 battery? > (a) no doubt the alternator is off line for what ever > reason and (b) and we KNOW that #1 battery is not capable > of carrying the engine + other endurance loads for at least > 30 minutes. > > Hmmmm . . . if we KNOW that #1 battery is overtaxed for > the task of supplied combined energy needs but that > #1 plus #2 battery WILL rise to the occasion, then what > is the value in having two batteries? Would a single > battery with a KNOWN capacity for the combined loads not > be a simpler, lighter and lower cost choice? > > In other words, what combination of conditions pose such > risk that a second battery is needed to mitigate the risk? > Two batteries DOUBLES your battery maintenance expenses > and adds empty weight . . . all intended to mitigate a > rather rare event . . . alternator failure. > > This line of reasoning is germane to the discussions > we were having on Fred's Exp-Bus integration which prompted > the crafting of Figure Z-7. It also applies to Les's question > about diodes suitable for battery isolation. Obviously, the > golden solution will include some assessment of loads over and > above those required to run the engine . . . along with > some decisions as to whether you're expecting to keep the panel all lit > up . . . or have crafted a plan-B that matches your skills > and confidence levels for getting down with a bare minimum > of panel equipment combined perhaps with flight bag back-up > hardware. > > If Figure Z-7 were substituted for the figure above, are > there any unforeseen risks? Comments on the Viking drawing, > Figure Z-7 and perceptions of your individual FMEAs are solicited . . . > Bob . . . ________________________________________________________________________________
Date: Jan 04, 2014
Hi Bob, Thank you for your comments. Based on your response and questions asked, I think you may have missed some points that I presented in my initial post. I will try to elaborate and present my thoughts more clearly. You ask several questions concerning the "why". As I mentioned, ultimately, it is because I "want", not solely based on any particular design based on physics, simple ideas, or statistical likelihood of any component failing. When building or modifying an OBAM aircraft, "want" is an important factor. This is why most of us build/fly experimental aircraft versus spam cans, and as with most experimental aircraft, one size does not necessarily fit all. I want dual batteries and am not comfortable with just one. This is not physics, these are those messy human "wants" and "feelings", which can't be quantified easily, if at all. I do not want an always hot power bus. I want a system that when the contactor is off, the battery is isolated except for the wires going to the contactor. I want automatic redundancy to certain devices similar to that offered in the engine section of Z-19. Essentially, the "why" of the above doesn't really matter. These are things that I "want" in my aircraft, and I'm trying to figure out the best way to accomplish these goals safely. I am hoping that you and others on the list are willing to help me to achieve this. The diagram I presented is my first draft towards this goal, and is my first ever attempt at an electrical design. It might be total felgercarb, which is why I am asking for help. I do have a few guidellines in my thinking. One is that from others' experience, we know that in a one battery situation, the EFIS and EIS can "brown out" and reboot when cranking the engine. I desire to have the EFIS and EIS up and running before cranking the engine, thus a second power source is required at least for these two items, which is one small part of the design goals. > How is the engine dependent? Ignition? Fuel Injection? > Do you have the energy requirement numbers? As mentioned, the engine is electrically dependent upon the ignition system, comprised of the ECU and coil circuits. There is no fuel pump (and no fuel injection). In particular, it is a Lycoming O-320 in a Glastar, using gravity for fuel feed into a Rotec TBI (Throttle Body Injector), which uses no electrical power. As outlined in the initial post, the energy requirements are 1.2 amps to keep the ignition running, but simply keeping the engine running is only part of the goal. > Any always hot busses are battery busses and they're > part and parcel of a considered FEMA and meeting > design goals. It's my wish that we can assist with > the crafting of your design goals based more on > understanding and planning and not so much on worries > that drive your discomfort. I have no desire or need for an always hot battery bus. When power is turned off, I do not wish to have any parasitic load that can drain the battery between flights, and I do not want to have any live buses. These are design goals that I consider important for my electrical system, but I fully agree that others may not share these same goals. That's okay. :-) > Redundant to meet what failure event. There's nothing > that prevents one from having as many batteries, alternators, > busses and switches as their creativity and physical space > allows . . . but in the TC aircraft world, the first goal > is to minimize weight, parts count, system complexity > and cost of ownership. At the same time, risk assessment > must necessarily drive all the above goals in the wrong > direction. The elegant design adds just enough but no more. All that is true, however, the most elegant design from an engineering perspective may not be the most desired design from a user perspective. I've stated up front that parts of the design are based on what I "want", not just what is the most practical design based on physics or simple ideas. As long as the engineering can support it, including the "wants" can be just as important in meeting a design goal as "elegance". I am sitting here with Z-19 in one hand, and my proposed drawing in the other, and to me my drawing looks much simpler than Z-19 with less parts count, and in my mind seems to offer similar yet slightly different functionality to incorporate my "wants" versus the Z-19 boilerplate. As I said, this is my first attempt ever at a design, so I might be way off on this, and please, do not take this as an attack on Z-19. I am simply using it as a comparison to your comment about parts count and system complexity, especially since my diagram was based off Z-19 initially. > > So have you arrived at a ball-park number > for total electrical system energy requirements? > You speak to a 60 minute battery-only ops goal > but can/should it be longer? The hour was picked as my personal comfort level. An hour should be adequate to get the plane safely on the ground even in IFR conditions. I do not have the exact numbers on all of the installed equipment in the entire airplane, however, the total load on the redundant bus is about 6 amps including the electronic ignition (COM not transmitting). Unless I am missing something, I don't believe that having those exact numbers at this time will change the basic design of the electrical system. It will have an impact on the size of the batteries chosen, and the values of fuses/CBs, though. Would you agree, or have I misunderstood something? Bear in mind that if the alternator fails, I have two separate batteries that can provide power, so the total time should actually be much longer than an hour especially if I turn off "extra" loads on the main bus, but should be at least an hour from the aux battery if I don't turn off anything. If one or the other battery or associated wiring and circuitry should fail, the alternator and single battery remaining should be able to run everything until the completion of the flight, although more than likely I would make a precautionary landing in the event of any type of problem. > You have described adjustments to an architecture > but it's not clear as to the reasoning behind those > moves. It seems as if you don't want any single failure > to cause to you drop to an energy efficient, endurance > mode . . . are you trying to keep everything lit up > no matter what? I thought I described this clearly, but apparently I've not communicated well. I'm trying to keep everything on the redundant bus lit up as those are what I consider the critical items, and I mentioned that this list of items may change as I use the system and/or receive recommendations from others. In particular, in my initial email I listed the electronic ignition, GPS, NAV, COM, and the Intercom to have redundant power. At the moment, these are what I would consider minimum to get the airplane safely on the ground in IFR conditions. > You speak of a large main battery and a smaller > auxiliary battery. What's the physics behind these > sizing decisions? Partly because I am rewiring an existing electrical system on an already flying airplane. The main battery is located just behind the baggage area, and I do not desire to relocate this. The aux battery only needs to be large enough to run the redundant bus for an hour, and will be mounted under the panel for CG reasons, so it is helpful to have it be as small as practical from a physical perspective. As stated earlier, the electrical sizing of the batteries will be made after all of the electrical loads are calculated, and are located on either the main or redundant buses. Again, I'm not sure how the size of the batteries will have any impact on the basic design of the electrical system. Will selecting a 10ah versus a 12ah battery for the aux, for example, have any effect at all on the basic electrical design as depicted in the diagram? > Z-7 elects to drive a single engine bus > through diodes from two power paths. What in > your knowledge or experience suggests that > charging batteries through diodes offers > more attractive options? None, which is why I indicated diodes in the initial design. As I stated, "I don't even know if diodes exist that will be able to handle those loads". If they will, excellent, I chose correctly the first time and I really have learned some things from following this list for the past decade or so. If not, I was sure someone on here would point that out and offer an alternative. Bear in mind that I'm still learning... So we've gone through a couple of pages of questions and answers, but I feel like I haven't really gotten any feedback at all on the diagram itself as presented. Will it work? Are there any obvious or not so obvious flaws? What are your concerns, if any, in the diagram as presented? Have I communicated the basic design goals clearly enough to follow, taking in to account the end-user "wants" in addition to ensuring that the basic design will function properly? http://deej.net/glastar/pics/electrical/redundant-large.jpg Thanks, -Dj -- Dj Merrill - N1JOV - VP EAA Chapter 87 Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Subject: Illuminated Rocker switches - revisited
Date: Jan 05, 2014
Guys You remember my before-Christmas query about those Honeywell illuminated rocker switches. They are DPST switches, and with your help I came to the conclusion that the 2 upper vertical tabs are the 2 (independent) lamp contacts. So, I just have to use one pair of the lower horizontal tabs (one pole) to control the circuits I need, and the 2 upper vertical tabs to illuminate the lamp. Right! Now, the reason why I am now posting again about these switches is the way I am going to use them. Apologizing for the quality of the drawing, I designed the circuits in 3 versions: I have no doubt that version A and version B above are going to do what they are supposed to (explained below each version). My problem is version C, if I want the switch lamp to lit in both situations : - In night operation, the switch lamp will illuminate when I turn On the Panel Lights (through the Dimmer), and/or - Whenever I turn On the switch itself (for example, when I turn On the Landing Light in day operation, and want the switch lamp to be lit to warn me the LND Light is On when taxiing) I suppose that the version C above will give a nice short-circuit .. L So I need you electron experts to help me design the correct circuits for version C. Thanks Carlos ________________________________________________________________________________
From: Bob McCallum <robert.mccallum2(at)sympatico.ca>
Date: Jan 05, 2014
Simply place a diode in the lead from the dimmer to avoid back feeding the rest of the dimmed lamps. (This circuit "C" will illuminate the switch at full brightness whenever the switch is "on" regardless of dimmer position.) Bob McC _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Carlos Trigo Sent: Sunday, January 05, 2014 7:00 AM Subject: AeroElectric-List: Illuminated Rocker switches - revisited Guys You remember my before-Christmas query about those Honeywell illuminated rocker switches. They are DPST switches, and with your help I came to the conclusion that the 2 upper vertical tabs are the 2 (independent) lamp contacts. So, I just have to use one pair of the lower horizontal tabs (one pole) to control the circuits I need, and the 2 upper vertical tabs to illuminate the lamp. Right! Now, the reason why I am now posting again about these switches is the way I am going to use them. Apologizing for the quality of the drawing, I designed the circuits in 3 versions: I have no doubt that version A and version B above are going to do what they are supposed to (explained below each version). My problem is version C, if I want the switch lamp to lit in both situations : - In night operation, the switch lamp will illuminate when I turn On the Panel Lights (through the Dimmer), and/or - Whenever I turn On the switch itself (for example, when I turn On the Landing Light in day operation, and want the switch lamp to be lit to warn me the LND Light is On when taxiing) I suppose that the version C above will give a nice short-circuit .. :-( So I need you electron experts to help me design the correct circuits for version C. Thanks Carlos ________________________________________________________________________________
Date: Jan 05, 2014
Thanks Bob McC So, in version "C", what changes should I make in the circuits, if I want the panel lights dimmer to dim the switch lamp whenever the switch is "On"? Carlos From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bob McCallum Sent: domingo, 5 de Janeiro de 2014 14:13 Subject: RE: AeroElectric-List: Illuminated Rocker switches - revisited Simply place a diode in the lead from the dimmer to avoid back feeding the rest of the dimmed lamps. (This circuit "C" will illuminate the switch at full brightness whenever the switch is "on" regardless of dimmer position.) Bob McC _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Carlos Trigo Sent: Sunday, January 05, 2014 7:00 AM Subject: AeroElectric-List: Illuminated Rocker switches - revisited Guys You remember my before-Christmas query about those Honeywell illuminated rocker switches. They are DPST switches, and with your help I came to the conclusion that the 2 upper vertical tabs are the 2 (independent) lamp contacts. So, I just have to use one pair of the lower horizontal tabs (one pole) to control the circuits I need, and the 2 upper vertical tabs to illuminate the lamp. Right! Now, the reason why I am now posting again about these switches is the way I am going to use them. Apologizing for the quality of the drawing, I designed the circuits in 3 versions: I have no doubt that version A and version B above are going to do what they are supposed to (explained below each version). My problem is version C, if I want the switch lamp to lit in both situations : - In night operation, the switch lamp will illuminate when I turn On the Panel Lights (through the Dimmer), and/or - Whenever I turn On the switch itself (for example, when I turn On the Landing Light in day operation, and want the switch lamp to be lit to warn me the LND Light is On when taxiing) I suppose that the version C above will give a nice short-circuit .. L So I need you electron experts to help me design the correct circuits for version C. Thanks Carlos ________________________________________________________________________________
Date: Jan 05, 2014
Not quite sure what it is you're trying to achieve. Circuit "A" gives night time illumination of the switch controlled by the dimmer but no indication if the switch is on or off. Circuit "B" gives full brightness indication of whether the switch is on or off but no night time illumination to identify the switch if it's off. Circuit "C" (with the addition of the diode) gives night time identification of the switch controlled by the dimmer and also full brightness indication of the on/off state day or night. (basically the functionality of both "A" & "B" combined) Are you asking for "C" to give night time illumination of the switch controlled by the dimmer, day time ONLY indication of the on/off state at full brightness and no indication of the on/off state at night???? This seems a bit odd as the illumination of the switch would indicate different things at different times depending upon the position of other switches. Could be confusing??? OR Are you asking that the "ON" condition of the switch is indicated by illumination of the lamp but also dimmed by the dimmer???? If this is the case then use circuit "B" but supply the lamp power from the dimmer circuit rather than B+ as you've shown. Bob McC _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Carlos Trigo Sent: Sunday, January 05, 2014 9:54 AM Subject: RE: AeroElectric-List: Illuminated Rocker switches - revisited Thanks Bob McC So, in version "C", what changes should I make in the circuits, if I want the panel lights dimmer to dim the switch lamp whenever the switch is "On"? Carlos From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bob McCallum Sent: domingo, 5 de Janeiro de 2014 14:13 Subject: RE: AeroElectric-List: Illuminated Rocker switches - revisited Simply place a diode in the lead from the dimmer to avoid back feeding the rest of the dimmed lamps. (This circuit "C" will illuminate the switch at full brightness whenever the switch is "on" regardless of dimmer position.) Bob McC _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Carlos Trigo Sent: Sunday, January 05, 2014 7:00 AM Subject: AeroElectric-List: Illuminated Rocker switches - revisited Guys You remember my before-Christmas query about those Honeywell illuminated rocker switches. They are DPST switches, and with your help I came to the conclusion that the 2 upper vertical tabs are the 2 (independent) lamp contacts. So, I just have to use one pair of the lower horizontal tabs (one pole) to control the circuits I need, and the 2 upper vertical tabs to illuminate the lamp. Right! Now, the reason why I am now posting again about these switches is the way I am going to use them. Apologizing for the quality of the drawing, I designed the circuits in 3 versions: I have no doubt that version A and version B above are going to do what they are supposed to (explained below each version). My problem is version C, if I want the switch lamp to lit in both situations : - In night operation, the switch lamp will illuminate when I turn On the Panel Lights (through the Dimmer), and/or - Whenever I turn On the switch itself (for example, when I turn On the Landing Light in day operation, and want the switch lamp to be lit to warn me the LND Light is On when taxiing) I suppose that the version C above will give a nice short-circuit .. :-( So I need you electron experts to help me design the correct circuits for version C. Thanks Carlos ________________________________________________________________________________
Date: Jan 05, 2014
Subject: Re: Wiring Verification
Hi Bob, I attended one of your seminars in Nashville, TN some years ago as well as purchased a second updated copy of your book which I refer to often. However, not being an electrical engineer, I'd like to verify my wing rewiring plan for my 12 volt all metal Luscombe if possible. Hi Ron . . . it's been some time! I'm sure we can sort out your concerns . . . The wing run is approximately 16 feet to the wing root from the wing tip, 14 feet from the landing light to wing root, and another 6+ feet to the switches on each side from the wing root. I plan to install a disconnect of some sort at each wing root to allow for an uncomplicated removal of the wing. Also, by the way, I will be installing a Plane Power Alternator and a B&C Starter in this rebuild if that should make any difference. I am wiring an Aeroflash power supply, (1.8 amp-23.4 watts) in each wingtip . . . Okay, a power wire coming in from each load to join at the panel switch for STROBES. 4A total load with half carried by the individual wires. I would recommend 20AWG for these conductors . . . not so much for electrical capability but for mechanical robustness. The difference in weight has no demonstrable down-side . . . piggybacking onto my 26 watt Whelen position lights, . . . again, 20AWG conductors to each fixture brought all the way to the POSITION LTS switch. and a 100 watt landing light in each wing. These are about 8A each. Is one adjusted for taxi illumination with the other directed for landing? Suggest 16AWG wire to each fixture. Control each with its own switch. I plan to switch to LED landing lights in the future but not anytime soon. My plan is to run three wires adjacent to one another up to the landing light where they will divide and separate. They will not run in a conduit but will run bundled only by a periodic small wedge clamp through the wing leading edge. I am utilizing Tefzel 22759 wire. Use the same wires and switches for the LED fixtures. There is no sin in having wires that are 'too heavy' . . . only in having wires that are 'too light'. I have determined the plan through my mathmatical calculations utilizing your book. To be on the safe side, I expect to be using a 16 gauge wire for my power supply and position lights and a 14 gauge wire for my landing lights. None of these wires are to be shielded at this point. Aeroflash indicated that if the power supply was mounted in the wing tip, it was unnecessary to utilize a shielded wire in the run. I do not know if I need shielding on the landing lights and need your advice. The 20AWG wire is 10 milliohms per foot. Your proposed 20-foot runs to the nav and strobe lights offers a .010 x 20 x 2 = .4 volt drop in each segment for 3% in your 14-volt system. Entirely within practical guidelines. Going the next step larger in wire would only drop your losses by 40% of 3% to just under 2% . . . an unobservable difference. 16AWG on the landing lights is more like 0.004 x 20 x 8 for a drop of 0.64 volts or 4.5% . . . again quite within limits for legacy design goals of 5% max loss in wiring. Of course, that will become a non-issue with the LED upgrade. Let me also indicate that I am in the group who wants to get it correct the first time so I am seeking qualified advice prior to pulling the wire. If possible, please advise your recommendations or if my plan is solid. Also, what sort of disconnect would you install at each wing root? Do you plan to remove the wings often? The most robust service connections are knife splices covered in heat- shrink. Given the small number of wires, I'd personally go that route. Emacs! I may have other wiring questions and will be happy to pay for this service. Not necessary. Let's carry out the conversation here on the List for sharing . . . Wishing you the very best in 2014 and thanking you in advance for your reply, I remain, You too my friend! Nice airplane by the way . . . got a lot of time in a 120+ (electrical system added) flying Young Eagles. Real blast . . . Bob . . . ________________________________________________________________________________
Date: Jan 05, 2014
So we've gone through a couple of pages of questions and answers, but I feel like I haven't really gotten any feedback at all on the diagram itself as presented. Clearly, your design goals are substantially different than those which drive the z-figures . . . which is not a bad thing . . . just different. Will it work? I've never encountered an alternative approach that did not function as intended . . . where function is defined as, "flip that switch and expect this action to follow." You can easily confirm functionality with some judicious ground tests. Get an ac mains power supply to emulate the alternator and do the electrical system 'Walter Mitty' thing with the wheels on the ground. Are there any obvious or not so obvious flaws? The z-figures are evolutionary . . . they form a kind of pyramid that spans the simplest to most complex, each tailored to a combination of aircraft/ mission/pilot. When useful 'tweaks' were identified the figures evolved independently as well. What are your concerns, if any, in the diagram as presented? As with any new adventure in design, some 'gotchas' may be discovered by analysis and comparison with lessons learned . . . others may not bubble up until the system is operated either as laboratory mock up (which we do in TC aircraft) or fly on the test-bed aircraft (like Burt Rutan does it). Those-who-know-more-about-airplanes-than-we-do are fond of the 75-hour test stand runs for engines and 40-hour fly-offs for airframes. But BOTH protocols presume that the person conducting the test isn't just along for the ride but is also getting answers to questions. The risks associated with discovery of glitches are low. Only a the smallest fraction of sad days in aviation have roots in failure of a component of the electrical system. Your development process will be refined on the flying test-bed . . . so flight into marginal environment for the first hundred hours or so is discouraged . . . with experiments conducted to validate every design goal. The highest risks will arise not from design and selection of components but from craftsmanship . . . as illustrated by numerous NTSB narratives on unhappy events. These were not based on the massaging of a 'z-figure' but more for lack of understanding of processes. Have I communicated the basic design goals clearly enough to follow, taking in to account the end-user "wants" in addition to ensuring that the basic design will function properly? Based on inspection of your work-product and review of your design goals I have no particular concerns with respect to either risk or functionality. You've embarked on a new "z-figure" with a design philosophy based not so much on economies of energy, weight, functionality and risk but on decisions and desires personal to you. This makes your project more a one-of-a-kind work of art as opposed to a competitively merchantable collection of ideas. There is nothing 'golden' about either . . . they just need to satisfy the end-user's perceptions for return on investment. As with any such endeavor, cautious and introspective experimentation is the key to your success. Bob . . . ________________________________________________________________________________
Date: Jan 05, 2014
It occurs to me that this topic gets pretty design-specific in a hurry and without specifying a design, this will turn into an exercise in arm waving. - =0A=0A=0ATherefore, I have included some general comments sprinkled amo ng Bob's remarks, below.=0A=0A=0A-Jeff=0A=0A_______________________________ _=0A From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>=0ATo: aeroelectric-list(at)matronics.com =0ASent: Saturday, January 4, 2014 5:15 AM =0ASubject: Re: AeroElectric-List: Viking engine duel battery setup=0A =0A olls.bob(at)aeroelectric.com>=0A=0AAt 01:49 PM 1/3/2014, you wrote:=0A> for ma ny of the same reasons that (I imagine) you put a "buss tie" contactor in t he Z-14 drawings.=0A=0A- But what might those reasons be? In other words, we=0A- add a component to a system to effect some desired=0A- function ality that figures into the overall performance,=0A- failure tolerance an d risks.=0A=0A- If diodes were incorporated in the manner suggested=0A- to feed the two batteries, how would we expect these=0A- to operate and for what purpose?=0A=0AThe diodes are to isolate the batteries and their sy stems from each other.- If you simple run a wire from the alternator B te rminal to batt A and then to batt B you have paralleled the batteries when your intent was only to charge them.- It could be an unintended side-effe ct.- If your mission is to charge the batts then make sure your circuit d oes that.- If your mission is to parallel the batts then do that, but don 't let one just happen as a side effect of the other.=0A=0A- I'm not tryi ng to be obtuse here my friend. I=0A- AM encouraging all of my readers to understand=0A- the application of every component they choose=0A- to a dd to their system. Suppose I offered a description=0A- for the buss-tie contactor like, "This contactor=0A- offers pilot control of the phramista t to prevent=0A- inadvertent operation of the whatsadozit and=0A- poten tial damage to the dingusfuzzy."=0A=0A- The inquiring builder would proba bly want some=0A- detailed expansion on that statement . . . un-=0A- fo rtunately, others will assume the statement=0A- correct and useful based on the reputation=0A- (deserved or otherwise) of the writer.=0A=0AIt is d ifficult to control the assumptions made by readers.=0A=0A- I encourage y ourself and others to KNOW why=0A- a part is included and UNDERSTAND what useful=0A- things it will do for you. Hence my question=0A- as to any value you perceive for having those=0A- diodes in place as suggested.=0A -=0AI know why - been there done that - and repaired the damage from some ===== ________________________________________________________________________________
Date: Jan 05, 2014
Subject: Re: Illuminated Rocker switches - revisited
Carlos, based on my experience with these switches (350+ hours, <10% @night), I'd suggest taking a different approach to using the lights. I know you aren't necessarily looking for a different approach so I'll first mention 2 problems with using the lights to indicated on/off functionality: 1) The lights at full brightness are blinding at night. I'd suggest that they must be (adjustably) dimmed in all modes unless they are intended to signify a fault of some sort. I think that's what you are trying to accomplish in Version C. In that case, I'm not sure how you would accomplish full bright during daytime versus on and dimmed at night. Additionally, the dimmer would need to be setup so that at it's lowest setting, it would still be visible during day and night (difficult). 2) The switch lights are subject to a high frequency of failure. If the application was for gear retract and 'light-on' meant 'all green', I'm sure one would want to use a Honeywell series with an integrated lamp wired to indicate on/off status. What's the problem with this series? Well, once you've switched to LEDs, you've eliminated incandescent bulb failures and that's good. None of my LED bulbs have failed. But the bulbs do not seat reliably in these switches, at least not reliably enough on our vibrating panels . If used for landing gear status - you'd end up aborting the occasional landing for lamp socket unseats. They may be okay for indicating a landing light is on but my experience is that they will occasionally unseat. In my case, I use some un-switched indicators with the same lamp socket. For my low oil fault indicator, I glued the lamp in place to prevent unseats and avoid missing a fault indication. That said, I'm very happy with my panel switches but I took a slightly different approach that aligns well with the switches' characteristics. On my panel, the occasional bulb unseat is just a nuisance that is easily detected and corrected. The lighting on these switches are just 'back lighting' on my panel. At night, their backlighting completely eliminates the need for post lights or map lights to find, monitor and operate switches. At high intensity, they look great in full daylight though they are not really needed. Dimmed at night they are simply GREAT! The key point is that the labeling on the switches makes each switch's function and status clearly visible, day or night. When 'off', the word 'off' appears at the top of the switch. When 'on', only the function label is visible on the switch. There's no real need to have a light come on or off to indicate status. The status is visible and 'touchable'. The backlighting combined with the switch design and switch labeling make it east to find, monitor and operate each switch. And when a bulb unseats, I can easily see that one of my switches is unlit and needs to be tweaked. But otherwise, the (mal)functioning of the back light is meaningless. So, to anyone using this good looking series of Honeywell rockers, I suggest the following: - Using the lamps only for backlighting the switch top. It must be dimmable. Use LEDs with integral resistors. - Get custom labeling for each switch top. For simple on/off function, put 'off' at the top of each switch. - Consider using the good looking AML41 series of indicators for indicator lamps. They visually match the AML34 switch series, use the same lamps, etc. The indicator tops are available in colors (green, yellow, red). A two bulb model can be used for stuff like "Door L/R" open indications. For 'Door' and 'Oil Pressure', I used red tops, left the indicators undimmed and glued the LED bulbs in place. For 'Master Warn', 'Low Voltage', and 'Boost Pump', I used yellow and green indicator tops and made them dimmable since they may come on and stay on at night. Sources for these switches, indicators, LED bulbs, and labeling have all been listed on this forum. I had to do some additional searching for the switch models I needed for AP Nav Source switching and Flaps. Having the Flap switch physically resemble all my other switches looks good, but some will prefer a different type of switch. Works well for me though. Carlos, I know you weren't necessarily looking for that much input but hope it's useful. Bill "N215TG is halfway thru year 3" Watson ________________________________________________________________________________
Date: Jan 05, 2014
> > > If diodes were incorporated in the manner suggested > to feed the two batteries, how would we expect these > to operate and for what purpose? > >The diodes are to isolate the batteries and their systems from each >other. If you simple run a wire from the alternator B terminal to >batt A and then to batt B you have paralleled the batteries when >your intent was only to charge them. It could be an unintended >side-effect. If your mission is to charge the batts then make sure >your circuit does that. If your mission is to parallel the batts >then do that, but don't let one just happen as a side effect of the other. Agreed. I can deduce no practical purpose for these diodes. As long as the alternator is operating normally, it charges both batteries. If alternator fails, you get a low-voltage warning light and you then separate the batteries onto their respective tasks. In other words, the system can service as many batteries in parallel as dictated by the alternator-out operating conditions. Simply parallel through hard contacts for normal ops; separate for alternator-out ops. A 'dead' battery will not accept 'charge' from a fully charged battery. If the batteries are remarkably different in size, the smaller one might want to be OFF during cranking. Bob . . . ________________________________________________________________________________
Date: Jan 05, 2014
... cautious and introspective experimentation is the key to your success.. .=0A=0Asounds like something you'd find in a fortune cookie, grasshopper - ;)=0A=0A=0A=0A=0A________________________________=0A From: "Robert L. N uckolls, III" =0ATo: aeroelectric-list@matro nics.com =0ASent: Sunday, January 5, 2014 10:33 AM=0ASubject: Re: AeroElect ric-List: Proposed new Z diagram?=0A =0A=0A--> AeroElectric-List message po sted by: "Robert L. Nuckolls, III" =0A=0A=0A So we've gone through a couple of pages of questions and answers, but I fee l like I haven't really gotten any feedback at all on the diagram itself as presented.=0A=0A- Clearly, your design goals are substantially different than=0A- those which drive the z-figures . . . which is not a bad=0A- thing . . . just different.=0A=0AWill it work?=0A=0A- I've never encounte red an alternative approach that did=0A- not function as intended . . . w here function is defined=0A- as, "flip that switch and expect this action to follow."=0A- You can easily confirm functionality with some judicious =0A- ground tests. Get an ac mains power supply to emulate=0A- the alte rnator and do the electrical system 'Walter Mitty'=0A- thing with the whe els on the ground.=0A=0AAre there any obvious or not so obvious flaws?=0A =0A- The z-figures are evolutionary . . . they form a=0A- kind of pyram id that spans the simplest to most=0A- complex, each tailored to a combin ation of aircraft/=0A- mission/pilot. When useful 'tweaks' were identifie d=0A- the figures evolved independently as well.=0A=0AWhat are your conce rns, if any, in the diagram as presented?=0A=0A- As with any new adventur e in design, some 'gotchas' may=0A- be discovered by analysis and compari son with lessons=0A- learned . . . others may not bubble up until the sys tem=0A- is operated either as laboratory mock up (which we do=0A- in TC aircraft) or fly on the test-bed aircraft (like=0A- Burt Rutan does it). =0A=0A- Those-who-know-more-about-airplanes-than-we-do are=0A- fond of the 75-hour test stand runs for engines=0A- and 40-hour fly-offs for airf rames. But BOTH protocols=0A- presume that the person conducting the test isn't=0A- just along for the ride but is also getting answers=0A- to q uestions.=0A=0A- The risks associated with discovery of glitches are low. =0A- Only a the smallest fraction of sad days in aviation=0A- have root s in failure of a component of the electrical=0A- system. Your developmen t process will be refined on=0A- the flying test-bed . . . so flight into marginal=0A- environment for the first hundred hours or so is=0A- disc ouraged . . . with experiments conducted to=0A- validate every design goa l.=0A=0A- The highest risks will arise not from design and=0A- selectio n of components but from craftsmanship=0A- . . . as illustrated by numer ous NTSB narratives=0A- on unhappy events. These were not based on the ma ssaging=0A- of a 'z-figure' but more for lack of understanding of=0A- p rocesses.=0A=0AHave I communicated the basic design goals clearly enough to follow, taking in to account the end-user "wants" in addition to ensuring that the basic design will function properly?=0A=0A- Based on inspection of your work-product and review of=0A- your design goals I have no partic ular concerns with=0A- respect to either risk or functionality.=0A=0A- You've embarked on a new "z-figure" with a design philosophy=0A- based no t so much on economies of energy, weight, functionality=0A- and risk but on decisions and desires personal to you. This=0A- makes your project mor e a one-of-a-kind work of art as=0A- opposed to a competitively merchanta ble collection of=0A- ideas. There is nothing 'golden' about either . . . =0A- they just need to satisfy the end-user's perceptions for=0A- retur n on investment.=0A=0A- As with any such endeavor, cautious and introspec tive=0A- experimentation is the key to your success.=0A=0A=0A- Bob . . ============== ________________________________________________________________________________
Date: Jan 05, 2014
At 04:59 PM 1/5/2014, you wrote: >... cautious and introspective experimentation is the key to your success... > >sounds like something you'd find in a fortune cookie, grasshopper ;) That would be a good one for the cookie . . . but in fact a simple reality taught and practiced by every competent practitioner of both the arts and sciences. It's the hammer-n-tongs for implementation of spontaneous order, a concept that has been around for better than 2300 years . . . Bob . . . ________________________________________________________________________________
Date: Jan 05, 2014
At 03:47 PM 1/5/2014, you wrote: Bob, Thanks for your consideration and kind reply. I was figuring a total of 24 feet of wire run for the wing tip lamps and power supply to the switch including the disconnect at the wing root, and a 20 foot run for the landing lights including the disconnect at the wing root. Perhaps I was vague on this measurement and did not explain it very well or perhaps the wires don't add together for the total drop. I confess my knowledge about wiring is lacking in general although I am attempting to come up to speed with respect to this task at hand. I neglected to include both runs together for the total of .8 volt drop. However using the 24 foot run, I come up with .96 volt or near 1 volt. Divided by a 13 volt system, I read that as .076 or beyond the 5% legacy. The Aeroflash documentation suggested the use of an 18 AWG but I'm not aware of what wire length run was used for the calculation. Luscombes have a 35 foot wingspan. So I figured a 16 gauge would include my margin of error. If this is a metal airplane, grounding the devices locally provides a much lower ground path resistance . . . essentially negligible . . . I do not plan on removing the wings often, perhaps not at all, however, I'd like to provide for it now to eliminate a random cutting when it occurs, because it will occur. In looking at the old Luscombe documentation, initially some sort of junction block was located at each wing root but those connections have long ago been changed when the wings were swapped out. If you can wire it up without junctions, so much the better. Just put a service loop of wire at the wing root . . . 3-4 inches in diameter. This will offer 'slack' from which future splices can be implemented should it become necessary. I was thinking of a using a triple Seal-All type conductor for the disconnect at the wing root but hadn't considered the knife splices. Actually, to my knowledge, I have never employed a knife splice in any of my wiring. The ideal configuration is no connector at all. Once you break the wires, putting them back together is pretty much a toss-up. Cessna started using Mate=n=Lok plastic connectors at the root and other locations as a production aid back about 1967. The car-guys have been doing it too for decades. Risks are low no matter what technology you choose. This leading edge location is very tight also providing for the aileron control cables and fuel lines coming in through the leading edge with a pulley positioned right at the juncture of the leading edge carrying the control cables. So, I anticipated bringing the three wires into the fuselage through the leading edge and securing on the last wing root rib and positioning my disconnect at that location. The wires would then reconnect through the splice and continue on through and around the front door upright and down to the rear of the instrument panel. You did not mention anything about shielded wiring. Would the total wire runs as I have listed above adjust your recommendations on the wire sizing? None of those wires would benefit from shielding. When I purchased radios I also purchased a wiring harness to connect to my buss and fuses or switches as appropriate. Hopefully, that will be more straight forward but I'm sure I'll have questions there. No problem . . . that's what we're here for . . . Thanks again for your reply on this cold winter afternoon in Kansas. You got that right. It was about 4F when I got up this morning . . . supposed to get down to 0F tonight. But looking at the nation-wind chill-indexes, we've got it easy. Bob . . . ________________________________________________________________________________
Date: Jan 05, 2014
When I decided to post my draft diagram on the list, my hope was to get a peer review from others, and an independent verification that the circuit design would function properly and as desired. In a basic sense, I would really like to have someone with far more experience than I to go over the diagram, and reply with a clear "YES, it will work as you expect", or "NO, you missed (blah), or you will smoke the circuit because of (blah)." I believe I have learned a lot on this list over the years, enough to feel confident to post a circuit diagram, but I am far from an expert and am still learning. A "look over the shoulder" from a guru now and then is a great help to a student to tell if they are on the right track, or not, much the same as constructing a wing or installing critical flight controls. In other words, I am pleading for a technical review if there are people out there willing to do so. Bob, I've read through your recent response several times, and it is not clear to me if you did a review of the circuit diagram, or are simply telling me in a sense, "good luck" in far more elegant and lengthy prose (which I do appreciate! :-) ). Based on one sentence, I think you have looked it over, ie "Based on inspection of your work-product and review of your design goals I have no particular concerns with respect to either risk or functionality." I think what you are saying here is that yes, the circuit should work as desired, but I'm not certain (You could simply be saying that you have no concerns about it working, which is not quite the same thing). Would you be willing to answer the question with a simple "yes" or "no", will this circuit diagram work properly and as desired given the guidelines and design goals that we've talked about over the past few messages? An interesting and unexpected side effect - I've received emails direct from others that say they are also interested in this type of architecture, specifically the automatic "redundant" bus feature for critical devices to get power from either the primary or secondary power buses. Since this appears to have an interest going beyond my personal implementation, I'd be honored if you would consider pursuing this further, and possibly entertaining the idea of including something like this as a Z diagram in a future version of the Connection. Thank you, -Dj On 1/5/2014 1:33 PM, Robert L. Nuckolls, III wrote: > > > > So we've gone through a couple of pages of questions and answers, but > I feel like I haven't really gotten any feedback at all on the diagram > itself as presented. > > Clearly, your design goals are substantially different than > those which drive the z-figures . . . which is not a bad > thing . . . just different. > > Will it work? > > I've never encountered an alternative approach that did > not function as intended . . . where function is defined > as, "flip that switch and expect this action to follow." > You can easily confirm functionality with some judicious > ground tests. Get an ac mains power supply to emulate > the alternator and do the electrical system 'Walter Mitty' > thing with the wheels on the ground. > > Are there any obvious or not so obvious flaws? > > The z-figures are evolutionary . . . they form a > kind of pyramid that spans the simplest to most > complex, each tailored to a combination of aircraft/ > mission/pilot. When useful 'tweaks' were identified > the figures evolved independently as well. > > What are your concerns, if any, in the diagram as presented? > > As with any new adventure in design, some 'gotchas' may > be discovered by analysis and comparison with lessons > learned . . . others may not bubble up until the system > is operated either as laboratory mock up (which we do > in TC aircraft) or fly on the test-bed aircraft (like > Burt Rutan does it). > > Those-who-know-more-about-airplanes-than-we-do are > fond of the 75-hour test stand runs for engines > and 40-hour fly-offs for airframes. But BOTH protocols > presume that the person conducting the test isn't > just along for the ride but is also getting answers > to questions. > > The risks associated with discovery of glitches are low. > Only a the smallest fraction of sad days in aviation > have roots in failure of a component of the electrical > system. Your development process will be refined on > the flying test-bed . . . so flight into marginal > environment for the first hundred hours or so is > discouraged . . . with experiments conducted to > validate every design goal. > > The highest risks will arise not from design and > selection of components but from craftsmanship > . . . as illustrated by numerous NTSB narratives > on unhappy events. These were not based on the massaging > of a 'z-figure' but more for lack of understanding of > processes. > > Have I communicated the basic design goals clearly enough to follow, > taking in to account the end-user "wants" in addition to ensuring that > the basic design will function properly? > > Based on inspection of your work-product and review of > your design goals I have no particular concerns with > respect to either risk or functionality. > > You've embarked on a new "z-figure" with a design philosophy > based not so much on economies of energy, weight, functionality > and risk but on decisions and desires personal to you. This > makes your project more a one-of-a-kind work of art as > opposed to a competitively merchantable collection of > ideas. There is nothing 'golden' about either . . . > they just need to satisfy the end-user's perceptions for > return on investment. > > As with any such endeavor, cautious and introspective > experimentation is the key to your success. > > > Bob . . . > -- Dj Merrill - N1JOV - VP EAA Chapter 87 Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Subject: Proposed new Z diagram?
Date: Jan 05, 2014
First; it would appear that what you have drawn will function. Is that function what you intend?? Or expect?? I'm not sure. It will power the components you mention from either of two sources redundantly, but is it what you want?? My second point below may be the gotcha you're alluding to and may not have considered but I don't know. Second; turning off either the primary or secondary power (master?) switch, as the circuit is drawn, will not turn off the respective primary or secondary buss so long as the alternator is functioning. The alternator will support the buss directly without benefit of the corresponding battery. The master switches only serve to disconnect the batteries not turn off the buss. If this is your desired goal then it will work. This is not necessarily any sort of functional problem, just that you may turn off one of these two master switches expecting the corresponding buss to shut down and it won't. As long as you know that this is "normal" for the way you've wired the circuit and are expecting this result then all is well. Is there any conceivable instance when you would wish to shut down a buss utilizing the corresponding master switch?? I so, then you need to be aware that for this to happen you must also shut down the alternator. The down side is that in the case (heaven forbid) of a "crash" or "accident" turning off the master switches does not "kill all power" as the electrical system is still kept alive by the alternator if it is functioning and the engine is turning. (even wind milling). Your wiring requires the manipulation of three switches to fully shut down electrical power. Bob McC > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list- > server(at)matronics.com] On Behalf Of Dj Merrill > Sent: Sunday, January 05, 2014 8:56 PM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Proposed new Z diagram? > > > When I decided to post my draft diagram on the list, my hope was to > get a peer review from others, and an independent verification that the > circuit design would function properly and as desired. In a basic > sense, I would really like to have someone with far more experience than > I to go over the diagram, and reply with a clear "YES, it will work as > you expect", or "NO, you missed (blah), or you will smoke the circuit > because of (blah)." I believe I have learned a lot on this list over > the years, enough to feel confident to post a circuit diagram, but I am > far from an expert and am still learning. A "look over the shoulder" > from a guru now and then is a great help to a student to tell if they > are on the right track, or not, much the same as constructing a wing or > installing critical flight controls. In other words, I am pleading for > a technical review if there are people out there willing to do so. > > Bob, I've read through your recent response several times, and it > is not clear to me if you did a review of the circuit diagram, or are > simply telling me in a sense, "good luck" in far more elegant and > lengthy prose (which I do appreciate! :-) ). Based on one sentence, I > think you have looked it over, ie "Based on inspection of your > work-product and review of your design goals I have no particular > concerns with respect to either risk or functionality." I think what > you are saying here is that yes, the circuit should work as desired, but > I'm not certain (You could simply be saying that you have no concerns > about it working, which is not quite the same thing). Would you be > willing to answer the question with a simple "yes" or "no", will this > circuit diagram work properly and as desired given the guidelines and > design goals that we've talked about over the past few messages? > > An interesting and unexpected side effect - I've received emails > direct from others that say they are also interested in this type of > architecture, specifically the automatic "redundant" bus feature for > critical devices to get power from either the primary or secondary power > buses. Since this appears to have an interest going beyond my personal > implementation, I'd be honored if you would consider pursuing this > further, and possibly entertaining the idea of including something like > this as a Z diagram in a future version of the Connection. > > Thank you, > > -Dj > > > On 1/5/2014 1:33 PM, Robert L. Nuckolls, III wrote: > > > > > > > > So we've gone through a couple of pages of questions and answers, but > > I feel like I haven't really gotten any feedback at all on the diagram > > itself as presented. > > > > Clearly, your design goals are substantially different than > > those which drive the z-figures . . . which is not a bad > > thing . . . just different. > > > > Will it work? > > > > I've never encountered an alternative approach that did > > not function as intended . . . where function is defined > > as, "flip that switch and expect this action to follow." > > You can easily confirm functionality with some judicious > > ground tests. Get an ac mains power supply to emulate > > the alternator and do the electrical system 'Walter Mitty' > > thing with the wheels on the ground. > > > > Are there any obvious or not so obvious flaws? > > > > The z-figures are evolutionary . . . they form a > > kind of pyramid that spans the simplest to most > > complex, each tailored to a combination of aircraft/ > > mission/pilot. When useful 'tweaks' were identified > > the figures evolved independently as well. > > > > What are your concerns, if any, in the diagram as presented? > > > > As with any new adventure in design, some 'gotchas' may > > be discovered by analysis and comparison with lessons > > learned . . . others may not bubble up until the system > > is operated either as laboratory mock up (which we do > > in TC aircraft) or fly on the test-bed aircraft (like > > Burt Rutan does it). > > > > Those-who-know-more-about-airplanes-than-we-do are > > fond of the 75-hour test stand runs for engines > > and 40-hour fly-offs for airframes. But BOTH protocols > > presume that the person conducting the test isn't > > just along for the ride but is also getting answers > > to questions. > > > > The risks associated with discovery of glitches are low. > > Only a the smallest fraction of sad days in aviation > > have roots in failure of a component of the electrical > > system. Your development process will be refined on > > the flying test-bed . . . so flight into marginal > > environment for the first hundred hours or so is > > discouraged . . . with experiments conducted to > > validate every design goal. > > > > The highest risks will arise not from design and > > selection of components but from craftsmanship > > . . . as illustrated by numerous NTSB narratives > > on unhappy events. These were not based on the massaging > > of a 'z-figure' but more for lack of understanding of > > processes. > > > > Have I communicated the basic design goals clearly enough to follow, > > taking in to account the end-user "wants" in addition to ensuring that > > the basic design will function properly? > > > > Based on inspection of your work-product and review of > > your design goals I have no particular concerns with > > respect to either risk or functionality. > > > > You've embarked on a new "z-figure" with a design philosophy > > based not so much on economies of energy, weight, functionality > > and risk but on decisions and desires personal to you. This > > makes your project more a one-of-a-kind work of art as > > opposed to a competitively merchantable collection of > > ideas. There is nothing 'golden' about either . . . > > they just need to satisfy the end-user's perceptions for > > return on investment. > > > > As with any such endeavor, cautious and introspective > > experimentation is the key to your success. > > > > > > Bob . . . > > > > > -- > Dj Merrill - N1JOV - VP EAA Chapter 87 > Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ > Glastar Flyer N866RH - http://deej.net/glastar/ > > _- > ===================================================== > ===== > _- > ===================================================== > ===== > _- > ===================================================== > ===== > _- > ===================================================== > ===== > > ________________________________________________________________________________
Date: Jan 05, 2014
Subject: Re: Proposed new Z diagram?
Bob, I've read through your recent response several times, and it is not clear to me if you did a review of the circuit diagram, or are simply telling me in a sense, "good luck" in far more elegant and lengthy prose (which I do appreciate! :-) ). Based on one sentence, I think you have looked it over, ie "Based on inspection of your work-product and review of your design goals I have no particular concerns with respect to either risk or functionality." DJ, what you ask is not unlike somebody laying a recipe in front of an experienced chef and asking, will this accomplish what I want? But without articulating exactly what it is you want and why. When we produced system designs for the military we first offered a proposal . . . followed by a preliminary design review . . . followed by a critical design review. I had to stand in front of a team of sharp reviewers and defend my work product twice. I think what you are saying here is that yes, the circuit should work as desired, but I'm not certain (You could simply be saying that you have no concerns about it working, which is not quite the same thing). Would you be willing to answer the question with a simple "yes" or "no", will this circuit diagram work properly and as desired given the guidelines and design goals that we've talked about over the past few messages? Define "properly" . . . I believe your drawing accurately illustrates the goals you've cited . I'm looking at your drawing without benefit of knowing the foundation for your design goals which becomes a task not unlike reverse-engineering . . . attempt to deduce original intent from a document . . . we can all sit around and talk about it, like visitors to an art gallery and hypothesize about the mind-set, tools and techniques of the artist . . . who has probably been dead for a few hundred years. You've said you don't want any always hot busses . . . in spite of the fact that a quarter million airplanes were built with the benefit of always hot busses. Okay, defend the design goal. You've got some power diodes for which I can deduce no value . . . defend the decision to put them in. Trade off the pros and cons of your proposal with the features of other proven philosophies, mine or anyone else. Do you have a reason to be different or just want to be different? An interesting and unexpected side effect - I've received emails direct from others that say they are also interested in this type of architecture, specifically the automatic "redundant" bus feature for critical devices to get power from either the primary or secondary power buses. Since this appears to have an interest going beyond my personal implementation, I'd be honored if you would consider pursuing this further, and possibly entertaining the idea of including something like this as a Z diagram in a future version of the Connection. I had a builder reject a proposal for a system on his proposed light jet because "it didn't have a big enough circuit breaker panel." I was a bit stunned . . . the most I could offer was the idea that he could make the panel as large as he wanted, nobody would demand that all the breakers were hooked up to do anything. He got p@#$Sd off and fired me . . . for which I was thankful. If others are finding value in your proposal, then perhaps they can defend its features . . . or perhaps they are captivated by colors and brush strokes . . . I don't know. We're not producing works of art or recipes for gourmet meals . . . I'm always interested in ideas that advance the state of our art and science but it shouldn't be just one more page in a 1000-page cookbook. Bob . . . ________________________________________________________________________________
Date: Jan 06, 2014
Bob I am probably asking for too much, but my idea is: - To have the switch lamp as a "normal" illumination feature, which lits together with the Panel lights, and is dimmed by the Panel lights dimmer - To have the switch lamp as a warning feature, which lits whenever I turn On that particular circuit, and - be able to dim the lamp, in both ocasions. Independently of this being or not a good operation choice, how can this be achieved? What changes should I make in circuit B or C to achieve the features above? Thanks Carlos From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bob McCallum Sent: domingo, 5 de Janeiro de 2014 16:48 Subject: RE: AeroElectric-List: Illuminated Rocker switches - revisited Not quite sure what it is you're trying to achieve. Circuit "A" gives night time illumination of the switch controlled by the dimmer but no indication if the switch is on or off. Circuit "B" gives full brightness indication of whether the switch is on or off but no night time illumination to identify the switch if it's off. Circuit "C" (with the addition of the diode) gives night time identification of the switch controlled by the dimmer and also full brightness indication of the on/off state day or night. (basically the functionality of both "A" & "B" combined) Are you asking for "C" to give night time illumination of the switch controlled by the dimmer, day time ONLY indication of the on/off state at full brightness and no indication of the on/off state at night???? This seems a bit odd as the illumination of the switch would indicate different things at different times depending upon the position of other switches. Could be confusing??? OR Are you asking that the "ON" condition of the switch is indicated by illumination of the lamp but also dimmed by the dimmer???? If this is the case then use circuit "B" but supply the lamp power from the dimmer circuit rather than B+ as you've shown. Bob McC _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Carlos Trigo Sent: Sunday, January 05, 2014 9:54 AM Subject: RE: AeroElectric-List: Illuminated Rocker switches - revisited Thanks Bob McC So, in version "C", what changes should I make in the circuits, if I want the panel lights dimmer to dim the switch lamp whenever the switch is "On"? Carlos From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bob McCallum Sent: domingo, 5 de Janeiro de 2014 14:13 Subject: RE: AeroElectric-List: Illuminated Rocker switches - revisited Simply place a diode in the lead from the dimmer to avoid back feeding the rest of the dimmed lamps. (This circuit "C" will illuminate the switch at full brightness whenever the switch is "on" regardless of dimmer position.) Bob McC _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Carlos Trigo Sent: Sunday, January 05, 2014 7:00 AM Subject: AeroElectric-List: Illuminated Rocker switches - revisited Guys You remember my before-Christmas query about those Honeywell illuminated rocker switches. They are DPST switches, and with your help I came to the conclusion that the 2 upper vertical tabs are the 2 (independent) lamp contacts. So, I just have to use one pair of the lower horizontal tabs (one pole) to control the circuits I need, and the 2 upper vertical tabs to illuminate the lamp. Right! Now, the reason why I am now posting again about these switches is the way I am going to use them. Apologizing for the quality of the drawing, I designed the circuits in 3 versions: I have no doubt that version A and version B above are going to do what they are supposed to (explained below each version). My problem is version C, if I want the switch lamp to lit in both situations : - In night operation, the switch lamp will illuminate when I turn On the Panel Lights (through the Dimmer), and/or - Whenever I turn On the switch itself (for example, when I turn On the Landing Light in day operation, and want the switch lamp to be lit to warn me the LND Light is On when taxiing) I suppose that the version C above will give a nice short-circuit .. L So I need you electron experts to help me design the correct circuits for version C. Thanks Carlos ________________________________________________________________________________
Date: Jan 06, 2014
Bill Thank you for all your comments, and information on your experience. It's always important to be aware of everyone's "hands on" experience, which helps in making decisions. For sure I will take it in consideration. Nevertheless, even being only a theoretical knowledge, I would like to know how could I achive my initial idea . Carlos "thru year 2 building the -10" Trigo -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bill Watson Sent: domingo, 5 de Janeiro de 2014 19:42 Subject: Re: AeroElectric-List: Illuminated Rocker switches - revisited --> < Mauledriver(at)nc.rr.com> Carlos, based on my experience with these switches (350+ hours, <10% @night), I'd suggest taking a different approach to using the lights. I know you aren't necessarily looking for a different approach so I'll first mention 2 problems with using the lights to indicated on/off functionality: 1) The lights at full brightness are blinding at night. I'd suggest that they must be (adjustably) dimmed in all modes unless they are intended to signify a fault of some sort. I think that's what you are trying to accomplish in Version C. In that case, I'm not sure how you would accomplish full bright during daytime versus on and dimmed at night. Additionally, the dimmer would need to be setup so that at it's lowest setting, it would still be visible during day and night (difficult). 2) The switch lights are subject to a high frequency of failure. If the application was for gear retract and 'light-on' meant 'all green', I'm sure one would want to use a Honeywell series with an integrated lamp wired to indicate on/off status. What's the problem with this series? Well, once you've switched to LEDs, you've eliminated incandescent bulb failures and that's good. None of my LED bulbs have failed. But the bulbs do not seat reliably in these switches, at least not reliably enough on our vibrating panels . If used for landing gear status - you'd end up aborting the occasional landing for lamp socket unseats. They may be okay for indicating a landing light is on but my experience is that they will occasionally unseat. In my case, I use some un-switched indicators with the same lamp socket. For my low oil fault indicator, I glued the lamp in place to prevent unseats and avoid missing a fault indication. That said, I'm very happy with my panel switches but I took a slightly different approach that aligns well with the switches' characteristics. On my panel, the occasional bulb unseat is just a nuisance that is easily detected and corrected. The lighting on these switches are just 'back lighting' on my panel. At night, their backlighting completely eliminates the need for post lights or map lights to find, monitor and operate switches. At high intensity, they look great in full daylight though they are not really needed. Dimmed at night they are simply GREAT! The key point is that the labeling on the switches makes each switch's function and status clearly visible, day or night. When 'off', the word 'off' appears at the top of the switch. When 'on', only the function label is visible on the switch. There's no real need to have a light come on or off to indicate status. The status is visible and 'touchable'. The backlighting combined with the switch design and switch labeling make it east to find, monitor and operate each switch. And when a bulb unseats, I can easily see that one of my switches is unlit and needs to be tweaked. But otherwise, the (mal)functioning of the back light is meaningless. So, to anyone using this good looking series of Honeywell rockers, I suggest the following: - Using the lamps only for backlighting the switch top. It must be dimmable. Use LEDs with integral resistors. - Get custom labeling for each switch top. For simple on/off function, put 'off' at the top of each switch. - Consider using the good looking AML41 series of indicators for indicator lamps. They visually match the AML34 switch series, use the same lamps, etc. The indicator tops are available in colors (green, yellow, red). A two bulb model can be used for stuff like "Door L/R" open indications. For 'Door' and 'Oil Pressure', I used red tops, left the indicators undimmed and glued the LED bulbs in place. For 'Master Warn', 'Low Voltage', and 'Boost Pump', I used yellow and green indicator tops and made them dimmable since they may come on and stay on at night. Sources for these switches, indicators, LED bulbs, and labeling have all been listed on this forum. I had to do some additional searching for the switch models I needed for AP Nav Source switching and Flaps. Having the Flap switch physically resemble all my other switches looks good, but some will prefer a different type of switch. Works well for me though. Carlos, I know you weren't necessarily looking for that much input but hope it's useful. Bill "N215TG is halfway thru year 3" Watson www.buildersbooks.com www.homebuilthelp.com http://www.matronics.com/contribution http://www.matronics.com/Navigator?AeroElectric-List ________________________________________________________________________________
Date: Jan 06, 2014
> An interesting and unexpected side effect - I've received > emails direct from others that say they are also interested in this > type of architecture, specifically the automatic "redundant" bus > feature for critical devices to get power from either the primary > or secondary power buses. Not sure what the term "automatic redundant" feature is all about . . . for what kind of failure is there value in offering an 'automatic' response? Let's try another tack . . . You said you wanted dual batteries and no always hot busses. Okay. Consider this variant on the Z07 work-in-process . . . http://tinyurl.com/mevf3n8 What failures in this architecture pose any unacceptable/unmanageable risks? In what way are your design goals yet to be realized? Bob . . . ________________________________________________________________________________
Date: Jan 06, 2014
Hi Bob McC, Thank you for looking things over and offering feedback. You make a very good point, and I'll have to think about this for a bit. The original intent was to have a system that could run specific critical equipment from either of two completely redundant power buses and battery power sources, and that both batteries would be charging when the alternator is enabled. Recently on the list we've been talking about running in an alternator-only mode, and I thought it a nice feature that my proposed architecture would allow this. However, I missed the fact that in doing so I now had no way to disable each of the separate buses if the alternator were running. Thank you for highlighting that! :-) Bob M offered a new dual battery Z-7 diagram this morning that offers more food for thought. I haven't had time to look at it with any detail, but I look forward to doing so later. If I am reading it correctly, at first glance it also seems to share a similar characteristic whereas both the main power bus and the endurance bus are always powered if the alternator is powered, with no way to individually remove power from each bus separately. A difference is that there is a single switch that controls the alternator and main battery contactor, and is wired such that the alternator will always be turned off first before the main battery contactor is turned off (ie, no alternator-only mode). With either the aux or main contactors on, both power buses will be enabled and there is no independent control to turn each bus off individually. Dual-Bat Z-7 requires two switches to shut down all power, and mine requires three, as you indicate. I could replace the alternator and main switches with a combined switch similar to Z-7, removing the alternator-only mode, which may be a good thing to do and simplifies the user experience, as well as allowing for each power bus to be separated and powered independently. I think the chances of both batteries failing and requiring an alternator-only mode are so remote that it is not worth worrying about. Thank you! -Dj On 01/05/2014 10:06 PM, Bob McCallum wrote: > > First; it would appear that what you have drawn will function. > > Is that function what you intend?? Or expect?? I'm not sure. It will power > the components you mention from either of two sources redundantly, but is it > what you want?? My second point below may be the gotcha you're alluding to > and may not have considered but I don't know. > > Second; turning off either the primary or secondary power (master?) switch, > as the circuit is drawn, will not turn off the respective primary or > secondary buss so long as the alternator is functioning. The alternator will > support the buss directly without benefit of the corresponding battery. The > master switches only serve to disconnect the batteries not turn off the > buss. If this is your desired goal then it will work. > This is not necessarily any sort of functional problem, just that you may > turn off one of these two master switches expecting the corresponding buss > to shut down and it won't. As long as you know that this is "normal" for the > way you've wired the circuit and are expecting this result then all is well. > Is there any conceivable instance when you would wish to shut down a buss > utilizing the corresponding master switch?? I so, then you need to be aware > that for this to happen you must also shut down the alternator. > > The down side is that in the case (heaven forbid) of a "crash" or "accident" > turning off the master switches does not "kill all power" as the electrical > system is still kept alive by the alternator if it is functioning and the > engine is turning. (even wind milling). Your wiring requires the > manipulation of three switches to fully shut down electrical power. > > Bob McC -- Dj Merrill - N1JOV - VP EAA Chapter 87 Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Date: Jan 06, 2014
Theoretically, I think the only way to get the logic you describe is with 2 lamps. That is, use the AML24G series instead of the AML24F that I assume you are looking at now. The 'G' has two lamps. Additionally you would need to two separate dimmers, one for each lamp circuit. I in fact have 3 dimmers on my panel - one for switches, one for indicators and one for the map light. You would in effect have the same configuration of dimmers. Interestingly enough, Perihelion Design sells the dimmers individually or as a discounted pack of 3 as I recall. Bill On 1/6/2014 3:57 AM, Carlos Trigo wrote: > > Bill > > Thank you for all your comments, and information on your experience. > > It's always important to be aware of everyone's "hands on" experience, > which helps in making decisions. For sure I will take it in consideration. > > Nevertheless, even being only a theoretical knowledge, I would like to > know how could I achive my initial idea ... > > Carlos "thru year 2 building the -10" Trigo > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of > Bill Watson > Sent: domingo, 5 de Janeiro de 2014 19:42 > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Illuminated Rocker switches - revisited > > > --> > > > Carlos, based on my experience with these switches (350+ hours, <10% > @night), I'd suggest taking a different approach to using the lights. > > I know you aren't necessarily looking for a different approach so I'll > first mention 2 problems with using the lights to indicated on/off > > functionality: > > 1) The lights at full brightness are blinding at night. I'd suggest > that they must be (adjustably) dimmed in all modes unless they are > intended to signify a fault of some sort. I think that's what you are > trying to accomplish in Version C. In that case, I'm not sure how you > would accomplish full bright during daytime versus on and dimmed at > night. Additionally, the dimmer would need to be setup so that at > it's lowest setting, it would still be visible during day and night > (difficult). > > 2) The switch lights are subject to a high frequency of failure. If > the application was for gear retract and 'light-on' meant 'all green', > I'm sure one would want to use a Honeywell series with an integrated > lamp wired to indicate on/off status. What's the problem with this > series? > > Well, once you've switched to LEDs, you've eliminated incandescent > bulb failures and that's good. None of my LED bulbs have failed. But > the bulbs do not seat reliably in these switches, at least not > reliably enough on our vibrating panels . If used for landing gear > status - you'd end up aborting the occasional landing for lamp socket > unseats. > > They may be okay for indicating a landing light is on but my > experience is that they will occasionally unseat. In my case, I use > some un-switched indicators with the same lamp socket. For my low oil > fault indicator, I glued the lamp in place to prevent unseats and > avoid missing a fault indication. > > That said, I'm very happy with my panel switches but I took a slightly > different approach that aligns well with the switches' characteristics. > > On my panel, the occasional bulb unseat is just a nuisance that is > easily detected and corrected. > > The lighting on these switches are just 'back lighting' on my panel. > At night, their backlighting completely eliminates the need for post > lights or map lights to find, monitor and operate switches. At high > intensity, they look great in full daylight though they are not really > needed. > > Dimmed at night they are simply GREAT! > > The key point is that the labeling on the switches makes each switch's > function and status clearly visible, day or night. When 'off', the > word 'off' appears at the top of the switch. When 'on', only the > function label is visible on the switch. There's no real need to have > a light come on or off to indicate status. The status is visible and > 'touchable'. The backlighting combined with the switch design and > switch labeling make it east to find, monitor and operate each switch. > > And when a bulb unseats, I can easily see that one of my switches is > unlit and needs to be tweaked. But otherwise, the (mal)functioning of > the back light is meaningless. > > So, to anyone using this good looking series of Honeywell rockers, I > suggest the following: > > - Using the lamps only for backlighting the switch top. It must be > dimmable. Use LEDs with integral resistors. > > - Get custom labeling for each switch top. For simple on/off > function, put 'off' at the top of each switch. > > - Consider using the good looking AML41 series of indicators for > indicator lamps. They visually match the AML34 switch series, use the > same lamps, etc. The indicator tops are available in colors (green, > yellow, red). A two bulb model can be used for stuff like "Door L/R" > > open indications. For 'Door' and 'Oil Pressure', I used red tops, > left the indicators undimmed and glued the LED bulbs in place. For > 'Master Warn', 'Low Voltage', and 'Boost Pump', I used yellow and > green indicator tops and made them dimmable since they may come on and > stay on at night. > > Sources for these switches, indicators, LED bulbs, and labeling have > all been listed on this forum. I had to do some additional searching > for the switch models I needed for AP Nav Source switching and Flaps. > > Having the Flap switch physically resemble all my other switches looks > good, but some will prefer a different type of switch. Works well for > me though. > > Carlos, I know you weren't necessarily looking for that much input but > hope it's useful. > > Bill "N215TG is halfway thru year 3" Watson > > www.aeroelectric.com > > www.buildersbooks.com > > www.homebuilthelp.comwww.mypilotstore.com > > www.mrrace.comhref="http://www.matronics.com/contribution">http://www.matronics.com/contribution > > http://www.matronics.com/Navigator?AeroElectric-List > > http://forums.matronics.com > > * > > * > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > ________________________________________________________________________________
Date: Jan 06, 2014
Attached is one more recipe to help fill the 1000 page cookbook of electrical architectures. :-) To keep it simple, this schematic has only one bus which is fed from both ends. The failure of any one wire or terminal or switch or relay will not interrupt power to the bus. In the event of low voltage, the pilot should shut off master switch #1. Doing so will shut off power to the alternator field and master contactor coil, thus conserving battery energy. It is up to the pilot to shut off any other unnecessary loads. Although this architecture is intended for a simple aircraft, the single bus could supply power to an IFR instrument panel or to an electrically dependent engine without danger of power loss due to the failure of any one component. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=416653#416653 Attachments: http://forums.matronics.com//files/simple_elect_system_102.pdf ________________________________________________________________________________
From: Bob McCallum <robert.mccallum2(at)sympatico.ca>
Subject: Illuminated Rocker switches - revisited
Date: Jan 06, 2014
Carlos; The simplest way to achieve what you're asking would be to use version "C" with the diode in the lead coming from the panel light dimmer then add another dimmer between your B+ supply at the bottom of the switch and the switch also through a diode to prevent back feed between the two dimmers. This way your panel light dimmer will control the intensity of the identification illumination and the dimmer in the B+ supply will control the intensity of the "on" indication. These two uses of the lamp will however lead to uncertainty as to what the lamp indicates because there will no way to differentiate between background illumination and "on" indication. Depending on the relative dimmer settings the brightness might change between the two functions but either function could override the other in terms of brightness. This will function as you've asked, but not too useful in my humble opinion because of the uncertainty in what is being indicated. Bob McC _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Carlos Trigo Sent: Monday, January 06, 2014 3:48 AM Subject: RE: AeroElectric-List: Illuminated Rocker switches - revisited Bob I am probably asking for too much, but my idea is: - To have the switch lamp as a "normal" illumination feature, which lits together with the Panel lights, and is dimmed by the Panel lights dimmer - To have the switch lamp as a warning feature, which lits whenever I turn On that particular circuit, and - be able to dim the lamp, in both ocasions. Independently of this being or not a good operation choice, how can this be achieved? What changes should I make in circuit B or C to achieve the features above? Thanks Carlos From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bob McCallum Sent: domingo, 5 de Janeiro de 2014 16:48 Subject: RE: AeroElectric-List: Illuminated Rocker switches - revisited Not quite sure what it is you're trying to achieve. Circuit "A" gives night time illumination of the switch controlled by the dimmer but no indication if the switch is on or off. Circuit "B" gives full brightness indication of whether the switch is on or off but no night time illumination to identify the switch if it's off. Circuit "C" (with the addition of the diode) gives night time identification of the switch controlled by the dimmer and also full brightness indication of the on/off state day or night. (basically the functionality of both "A" & "B" combined) Are you asking for "C" to give night time illumination of the switch controlled by the dimmer, day time ONLY indication of the on/off state at full brightness and no indication of the on/off state at night???? This seems a bit odd as the illumination of the switch would indicate different things at different times depending upon the position of other switches. Could be confusing??? OR Are you asking that the "ON" condition of the switch is indicated by illumination of the lamp but also dimmed by the dimmer???? If this is the case then use circuit "B" but supply the lamp power from the dimmer circuit rather than B+ as you've shown. Bob McC _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Carlos Trigo Sent: Sunday, January 05, 2014 9:54 AM Subject: RE: AeroElectric-List: Illuminated Rocker switches - revisited Thanks Bob McC So, in version "C", what changes should I make in the circuits, if I want the panel lights dimmer to dim the switch lamp whenever the switch is "On"? Carlos From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bob McCallum Sent: domingo, 5 de Janeiro de 2014 14:13 Subject: RE: AeroElectric-List: Illuminated Rocker switches - revisited Simply place a diode in the lead from the dimmer to avoid back feeding the rest of the dimmed lamps. (This circuit "C" will illuminate the switch at full brightness whenever the switch is "on" regardless of dimmer position.) Bob McC _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Carlos Trigo Sent: Sunday, January 05, 2014 7:00 AM Subject: AeroElectric-List: Illuminated Rocker switches - revisited Guys You remember my before-Christmas query about those Honeywell illuminated rocker switches. They are DPST switches, and with your help I came to the conclusion that the 2 upper vertical tabs are the 2 (independent) lamp contacts. So, I just have to use one pair of the lower horizontal tabs (one pole) to control the circuits I need, and the 2 upper vertical tabs to illuminate the lamp. Right! Now, the reason why I am now posting again about these switches is the way I am going to use them. Apologizing for the quality of the drawing, I designed the circuits in 3 versions: I have no doubt that version A and version B above are going to do what they are supposed to (explained below each version). My problem is version C, if I want the switch lamp to lit in both situations : - In night operation, the switch lamp will illuminate when I turn On the Panel Lights (through the Dimmer), and/or - Whenever I turn On the switch itself (for example, when I turn On the Landing Light in day operation, and want the switch lamp to be lit to warn me the LND Light is On when taxiing) I suppose that the version C above will give a nice short-circuit .. :-( So I need you electron experts to help me design the correct circuits for version C. Thanks Carlos ________________________________________________________________________________
Date: Jan 06, 2014
> the alternator will always be turned off first >before the main battery contactor is turned off (ie, no alternator-only >mode). With either the aux or main contactors on, both power buses will >be enabled and there is no independent control to turn each bus off >individually. Assuming that the Viking engine with the as- proposed alternator does run gracefully in an alternator only mode, then the whole inter-linked switch philsosopy for battery and alternator is moot. This figure illustrates the opptions for being relieved of that constraint . . . http://tinyurl.com/mhblorq > Dual-Bat Z-7 requires two switches to shut down all power, and mine >requires three, as you indicate. I could replace the alternator and >main switches with a combined switch similar to Z-7, removing the >alternator-only mode, which may be a good thing to do and simplifies the >user experience, as well as allowing for each power bus to be separated >and powered independently. I think the chances of both batteries >failing and requiring an alternator-only mode are so remote that it is >not worth worrying about. How does a battery fail? If such a failure occurs in flight, how do you know it has happened? What light comes on to say, "Battery X Fail"? You have articulated some goals for addressing a constellation of failures as yet not clearly defined. When conducting an FMEA on a system or product the following questions are posed and answers sought: How might this part fail? How will I know that it failed? Can the effects of the failure be immediately known and dealt with in a simple, prescribed manner? Is the failure pre-flight detectable? If not can it be made detectable. I that's not possible/ practical . . . what sort of testing is called for and at what intervals? How does any particular failure impact probability of comfortable termination of a flight? (a) Will any identified failure produce an immediate risk to ship's systems? (b) Will any identified failure over-tax my abilities to manage the event while maintaining competent control of the airplane? I have split the DC POWER MASTER into two switches which increases the number of power management controls to a total of 6. That gives you 36 possible combinations of switch positions some small number of which will result in the engine stopping . . . so those are easy to eliminate. Of the remaining combinations, what are the criteria for selecting/rejecting any combination that keeps the engine running and at least some stuff lit on the panel? At some point, after all the colors are laid down with the favorite brush strokes, you need to craft the pilot's operating handbook for how the switches are used. Do all those options serve a predictable, useful purpose? It's one thing to have so many options and control over those options . . . consider that each option should be deduced and prescribed in advance. Lots of options can work against you should one become reduced to a game of "flipping switches until things work better" while distracting concentration from your duties as a pilot. Bob . . . ________________________________________________________________________________
Date: Jan 07, 2014
At 09:01 PM 1/6/2014, you wrote: > While considering the size and utilization of batteries, add the following into your deliberations: If the batteries are of different size, will the smaller be capable of cranking the engine? I.e. 17 a.h. or larger? If so, then you can alternate between batteries for starting the engine. This philosophy offers a pre-flight test of battery health and integrity of associated wiring (contactors etc.) If it's never used to crank the engine, then consider the philosophy for assurance of continued airworthiness. If the batteries are the same size, then one has the option of simply rotating a new battery into the more strenuous/critical slot (probably supporting the motive power bus) and moving the original battery into the other slot. This alleviates any need to accomplish more introspective testing. All you need is to craft a change-out philosophy tailored for the most economical outcome. Perhaps a yearly rotation of a low cost battery as opposed to a premium device. I noticed a suggestion in the Viking drawings for using lithium batteries. Obviously NOT low cost and probably not candidates for periodic rotation . . . now you'll need a more introspective protocol for assuring continued air worthiness. If rotation is not a viable option, then periodic inspection for quantifying capacity is indicated. System reliability and failure tolerance is built on KNOWING limits . . . Something to factor into crafting and implementing the grand-plan . . . Bob . . . Bob . . . ________________________________________________________________________________
Date: Jan 07, 2014
Subject: Re: Illuminated Rocker switches - revisited
I agree Bob McC. Carlos, one might think that the AML24G series with two lamps would provide a path forward from what Bob described, that is, using 2 dimmers on 2 two different lamps on a single switch. At least I know I would think that the 24G would be a solution. However, I used a couple of 2 lamp indicators in this product family to try and indicate closure of the left and right doors and ran into a slight problem. A problem that I'm thinking you might run into with the 2 lamp switches as well. I used the AML41 series of indicators that match up nicely with the AML24 series of switches. Just like in the switches, there are 1 lamp (AML41C) and 2 lamp (AML41D) versions. The 2 lamps are side by side and I figured they could be used with the proper indicator top label, to signify whether the Left and/or Right doors are closed properly on my RV10. (I also used such an indicator for dual 'low voltage' indications on my Z-14 dual battery/dual bus electrical system). What I found is that the 2 lamp version easily facilitates such wiring, but one cannot visually distinguish between the left and right lights easily. When both are on, the indicator is just brighter. With either 1 lamp on, it's 'normal' brightness without any clear indication of which lamp is on. This was only a minor problem however. I was able to modify the cap top with a plastic insert to block the lamp light from leaking over light up the entire indicator so that one could easily tell which lamp was lit; uncertainty changed to certainty. My sense is that the 2 lamp AML24G series will work the same way. That is, it's not designed so that the 2 lamps are easily distinguishable from one another. Rather the design relies on the rocker position and the labeling on the switch top to make such distinctions. Furthermore, the fix I did on the indicator will not work on the switch. So in the end, I think you will be exactly in the uncertain situation Bob McC describes below. Bill "really missing the electrical and panel development tasks from the build" Watson (I would add that Honeywell does have switch series where the lamp is designed to indicate function rather than just back lighting. From what I recall however, those switches are not backlit. There may be other lines that do both.) On 1/6/2014 9:21 PM, Bob McCallum wrote: > > *Carlos;* > > ** > > *The simplest way to achieve what you're asking would be to use > version "C" _with_ the diode in the lead coming from the panel light > dimmer then add _another_ dimmer between your B+ supply at the bottom > of the switch and the switch _also through a diode_ to prevent back > feed between the two dimmers. This way your panel light dimmer will > control the intensity of the identification illumination and the > dimmer in the B+ supply will control the intensity of the "on" > indication. These two uses of the lamp will however lead to > uncertainty as to what the lamp indicates because there will no way to > differentiate between background illumination and "on" indication. > Depending on the relative dimmer settings the brightness might change > between the two functions but either function could override the other > in terms of brightness. This will function as you've asked, but not > too useful in my humble opinion because of the uncertainty in what is > being indicated.* > > ** > > *Bob McC* > > ** > > ________________________________________________________________________________
Date: Jan 07, 2014
At 09:01 PM 1/6/2014, you wrote: > Discussions about the Viking installation have raised heretofore unconsidered questions. Since the earliest days of the change-over from generators to alternators, the GENERAL consensus and design philosophies have held that alternators should be only operated with a battery on line. There have been the odd exception . . . Bonanzas and Barons have always offered alternator operation independently of batteries . . . there may be others about which I have no knowledge. If Viking has officially asserted that their product will function alternator-only, then there are interesting questions to be explored for crafting a new design philosophy. Obviously, the engine driven power source is at the foundation of energy pyramid. IF the current generation of alternators and system loads are amenable to alternator-only operations, then the legacy design goal for taking an alternator off line before the battery (split rocker philosophy) forces a waste of a potentially valuable resource. I'm going to noodle out some experiments to be conducted, probably at B&C on their test stand, to gather data on the quality and integrity of energy available from an alternator running barefoot. No doubt inquiring minds would like to KNOW . . . In the mean time, you Viking customers have solid justification for asking the supplier, "Are alternator-only operations 'approved' under your design goals? Are there risks to alternator- only operations. If I hit the system with a hydraulic pump motor or 250 watt landing light, can the alternator be stalled? What tests have been conducted to support your assertions?" Bob . . . ________________________________________________________________________________
Date: Jan 07, 2014
I did have a car-sized battery in my boat explode once. It was happy with the current draw to tilt the motor, but the starter current draw did something to it. It had responded normally to the battery charger and had normal voltage before I put it in the boat in the spring. It was a heck of a mess to clean up. A fully enclosed battery box is recommended ! I agree the switches will be complex to operate in the air when a failure occurs. For my design, I had to write out the checklist sequence for various scenarios before I greatly simplified my design (not electrically dependent engine). For this proposed Z diagram, I suggest considering using a progressive switch to combine the main battery and alternator into a single switch. In the event of a fire, shutting off the two battery switches will take away all power from the main bus. The engine switches are not symmetrical in operation. That is, the Normal switch works without the main battery switch on. The Aux switch does not provide power to the engine unless the Aux Battery switch is also on. This could be confusing while handling a failure in flight. Although a diode could be connected to the Endurance bus, my preference would be to have the Aux engine independent of the Endurance bus switch as well, which means adding another relay. Jeff Page Dream Aircraft Tundra #10 > From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> > Subject: Re: AeroElectric-List: Proposed new Z diagram? > > >> the alternator will always be turned off first >> before the main battery contactor is turned off (ie, no alternator-only >> mode). With either the aux or main contactors on, both power buses will >> be enabled and there is no independent control to turn each bus off >> individually. > > Assuming that the Viking engine with the as- > proposed alternator does run gracefully in > an alternator only mode, then the whole inter-linked > switch philsosopy for battery and alternator is > moot. This figure illustrates the opptions for > being relieved of that constraint . . . > > http://tinyurl.com/mhblorq > > >> Dual-Bat Z-7 requires two switches to shut down all power, and mine >> requires three, as you indicate. I could replace the alternator and >> main switches with a combined switch similar to Z-7, removing the >> alternator-only mode, which may be a good thing to do and simplifies the >> user experience, as well as allowing for each power bus to be separated >> and powered independently. I think the chances of both batteries >> failing and requiring an alternator-only mode are so remote that it is >> not worth worrying about. > > How does a battery fail? If such a failure occurs > in flight, how do you know it has happened? What > light comes on to say, "Battery X Fail"? > > You have articulated some goals for addressing > a constellation of failures as yet not clearly > defined. > > When conducting an FMEA on a system or product > the following questions are posed and answers > sought: > > How might this part fail? > > How will I know that it failed? Can the effects > of the failure be immediately known and > dealt with in a simple, prescribed manner? > > Is the failure pre-flight detectable? If not can > it be made detectable. I that's not possible/ > practical . . . what sort of testing is called > for and at what intervals? > > How does any particular failure impact probability > of comfortable termination of a flight? > > (a) Will any identified failure produce an immediate > risk to ship's systems? > > (b) Will any identified failure over-tax my abilities > to manage the event while maintaining competent > control of the airplane? > > I have split the DC POWER MASTER into two switches > which increases the number of power management controls > to a total of 6. That gives you 36 possible combinations > of switch positions some small number of which will > result in the engine stopping . . . so those are > easy to eliminate. Of the remaining combinations, > what are the criteria for selecting/rejecting any > combination that keeps the engine running and at least > some stuff lit on the panel? > > At some point, after all the colors are laid down > with the favorite brush strokes, you need to craft > the pilot's operating handbook for how the switches > are used. Do all those options serve a predictable, > useful purpose? > > It's one thing to have so many options and control > over those options . . . consider that each option > should be deduced and prescribed in advance. Lots > of options can work against you should one become reduced > to a game of "flipping switches until things work better" > while distracting concentration from your duties as a > pilot. > > > Bob . . . ________________________________________________________________________________
Date: Jan 07, 2014
Thank you again Bob McC I understand your critique, and I even agree with it, referring to night operations. However, on day operations, the light indication feature would be usefull, since the background illumination will be Off. Well, your recommendation and Bill Watson=92s experience and descriptions will surely contribute for my final decision. Thanks Carlos From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bob McCallum Sent: ter=E7a-feira, 7 de Janeiro de 2014 02:22 Subject: RE: AeroElectric-List: Illuminated Rocker switches - revisited Carlos; The simplest way to achieve what you=92re asking would be to use version "C" with the diode in the lead coming from the panel light dimmer then add another dimmer between your B+ supply at the bottom of the switch and the switch also through a diode to prevent back feed between the two dimmers. This way your panel light dimmer will control the intensity of the identification illumination and the dimmer in the B+ supply will control the intensity of the =93on=94 indication. These two uses of the lamp will however lead to uncertainty as to what the lamp indicates because there will no way to differentiate between background illumination and =93on=94 indication. Depending on the relative dimmer settings the brightness might change between the two functions but either function could override the other in terms of brightness. This will function as you=92ve asked, but not too useful in my humble opinion because of the uncertainty in what is being indicated. Bob McC _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Carlos Trigo Sent: Monday, January 06, 2014 3:48 AM Subject: RE: AeroElectric-List: Illuminated Rocker switches - revisited Bob I am probably asking for too much, but my idea is: - To have the switch lamp as a =93normal=94 illumination feature, which lits together with the Panel lights, and is dimmed by the Panel lights dimmer - To have the switch lamp as a warning feature, which lits whenever I turn On that particular circuit, and - be able to dim the lamp, in both ocasions. Independently of this being or not a good operation choice, how can this be achieved? What changes should I make in circuit B or C to achieve the features above? Thanks Carlos From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bob McCallum Sent: domingo, 5 de Janeiro de 2014 16:48 Subject: RE: AeroElectric-List: Illuminated Rocker switches - revisited Not quite sure what it is you=92re trying to achieve. Circuit =93A=94 gives night time illumination of the switch controlled by the dimmer but no indication if the switch is on or off. Circuit =93B=94 gives full brightness indication of whether the switch is on or off but no night time illumination to identify the switch if it=92s off. Circuit =93C=94 (with the addition of the diode) gives night time identification of the switch controlled by the dimmer and also full brightness indication of the on/off state day or night. (basically the functionality of both =93A=94 & =93B=94 combined) Are you asking for =93C=94 to give night time illumination of the switch controlled by the dimmer, day time ONLY indication of the on/off state at full brightness and no indication of the on/off state at night???? This seems a bit odd as the illumination of the switch would indicate different things at different times depending upon the position of other switches. Could be confusing??? OR Are you asking that the =93ON=94 condition of the switch is indicated by illumination of the lamp but also dimmed by the dimmer???? If this is the case then use circuit =93B=94 but supply the lamp power from the dimmer circuit rather than B+ as you=92ve shown. Bob McC _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Carlos Trigo Sent: Sunday, January 05, 2014 9:54 AM Subject: RE: AeroElectric-List: Illuminated Rocker switches - revisited Thanks Bob McC So, in version =93C=94, what changes should I make in the circuits, if I want the panel lights dimmer to dim the switch lamp whenever the switch is =93On=94? Carlos From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bob McCallum Sent: domingo, 5 de Janeiro de 2014 14:13 Subject: RE: AeroElectric-List: Illuminated Rocker switches - revisited Simply place a diode in the lead from the dimmer to avoid back feeding the rest of the dimmed lamps. (This circuit =93C=94 will illuminate the switch at full brightness whenever the switch is =93on=94 regardless of dimmer position.) Bob McC _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Carlos Trigo Sent: Sunday, January 05, 2014 7:00 AM Subject: AeroElectric-List: Illuminated Rocker switches - revisited Guys You remember my before-Christmas query about those Honeywell illuminated rocker switches. They are DPST switches, and with your help I came to the conclusion that the 2 upper vertical tabs are the 2 (independent) lamp contacts. So, I just have to use one pair of the lower horizontal tabs (one pole) to control the circuits I need, and the 2 upper vertical tabs to illuminate the lamp. Right! Now, the reason why I am now posting again about these switches is the way I am going to use them. Apologizing for the quality of the drawing, I designed the circuits in 3 versions: I have no doubt that version A and version B above are going to do what they are supposed to (explained below each version). My problem is version C, if I want the switch lamp to lit in both situations : - In night operation, the switch lamp will illuminate when I turn On the Panel Lights (through the Dimmer), and/or - Whenever I turn On the switch itself (for example, when I turn On the Landing Light in day operation, and want the switch lamp to be lit to warn me the LND Light is On when taxiing) I suppose that the version C above will give a nice short-circuit =85. L So I need you electron experts to help me design the correct circuits for version C. Thanks Carlos ________________________________________________________________________________
Date: Jan 08, 2014
Bob, You wrote: > Assuming that the Viking engine with the as- > proposed alternator does run gracefully in > an alternator only mode, then the whole inter-linked > switch philsosopy for battery and alternator is > moot. This figure illustrates the opptions for > being relieved of that constraint . . . > > http://tinyurl.com/mhblorq The split of the "master" switch also allows the engine to be operated from the aux battery and alternator. Why would you? I can imagine my battery monitor on the main battery indicating very high charging current and low voltage. I would interpret this as something wrong with the main and switch to the aux. Because the alternator for the Viking is an internally regulated ND, I would use a contactor with a "crow bar" for a disconnect, in the event of an o.v. runaway. I would also connect the alternator sense wire without a switch to the "motive" bus, so it can't be accidentally shut down while the engine is running and destroy the permanent-magnet alternator. I would still be able to pull the alternator CB in the event of an emergency. Hope these make sense. Tom Sent from my iPad > On Jan 6, 2014, at 8:01 PM, "Robert L. Nuckolls, III" wrote: > > > > >> the alternator will always be turned off first >> before the main battery contactor is turned off (ie, no alternator-only >> mode). With either the aux or main contactors on, both power buses will >> be enabled and there is no independent control to turn each bus off >> individually. > > Assuming that the Viking engine with the as- > proposed alternator does run gracefully in > an alternator only mode, then the whole inter-linked > switch philsosopy for battery and alternator is > moot. This figure illustrates the opptions for > being relieved of that constraint . . . > > http://tinyurl.com/mhblorq > > >> Dual-Bat Z-7 requires two switches to shut down all power, and mine >> requires three, as you indicate. I could replace the alternator and >> main switches with a combined switch similar to Z-7, removing the >> alternator-only mode, which may be a good thing to do and simplifies the >> user experience, as well as allowing for each power bus to be separated >> and powered independently. I think the chances of both batteries >> failing and requiring an alternator-only mode are so remote that it is >> not worth worrying about. > > How does a battery fail? If such a failure occurs > in flight, how do you know it has happened? What > light comes on to say, "Battery X Fail"? > > You have articulated some goals for addressing > a constellation of failures as yet not clearly > defined. > > When conducting an FMEA on a system or product > the following questions are posed and answers > sought: > > How might this part fail? > > How will I know that it failed? Can the effects > of the failure be immediately known and > dealt with in a simple, prescribed manner? > > Is the failure pre-flight detectable? If not can > it be made detectable. I that's not possible/ > practical . . . what sort of testing is called > for and at what intervals? > > How does any particular failure impact probability > of comfortable termination of a flight? > > (a) Will any identified failure produce an immediate > risk to ship's systems? > > (b) Will any identified failure over-tax my abilities > to manage the event while maintaining competent > control of the airplane? > > I have split the DC POWER MASTER into two switches > which increases the number of power management controls > to a total of 6. That gives you 36 possible combinations > of switch positions some small number of which will > result in the engine stopping . . . so those are > easy to eliminate. Of the remaining combinations, > what are the criteria for selecting/rejecting any > combination that keeps the engine running and at least > some stuff lit on the panel? > > At some point, after all the colors are laid down > with the favorite brush strokes, you need to craft > the pilot's operating handbook for how the switches > are used. Do all those options serve a predictable, > useful purpose? > > It's one thing to have so many options and control > over those options . . . consider that each option > should be deduced and prescribed in advance. Lots > of options can work against you should one become reduced > to a game of "flipping switches until things work better" > while distracting concentration from your duties as a > pilot. > > > > Bob . . . > > > > ________________________________________________________________________________
Date: Jan 08, 2014
At 07:57 AM 1/8/2014, you wrote: > > >Bob, > >You wrote: > > Assuming that the Viking engine with the as- > > proposed alternator does run gracefully in > > an alternator only mode, then the whole inter-linked > > switch philsosopy for battery and alternator is > > moot. This figure illustrates the opptions for > > being relieved of that constraint . . . > > > > http://tinyurl.com/mhblorq > >The split of the "master" switch also allows the engine to be >operated from the aux battery and alternator. Why would you? I can >imagine my battery monitor on the main battery indicating very high >charging current and low voltage. I would interpret this as >something wrong with the main and switch to the aux. I'm not suggesting ANY particular mode of operation . . . yet. DJ has proposed an architecture for which he requested a considered critical review. My input to this discussion goes toward understanding the rationale for each proposed feature that states, "when this happens, do this." At the same time, there is idea that alternator-only ops MIGHT be a good thing to review. Our current paradigm is rooted in the 1960's. The drill for crafting any system is to do the FMEA and then add/adjust features to minimize workloads and risks for the catalog of failures. Without such debate, we can only assess DJ's efforts from the standpoint of being a work of art or a photograph that is pleasant to look at . . . but of unknown value for a pilot that is wrestling with what could become a bad day in the cockpit. Bob . . . ________________________________________________________________________________
Date: Jan 08, 2014
At 07:16 PM 1/6/2014, you wrote: > >Attached is one more recipe to help fill the 1000 page cookbook of >electrical architectures. :-) >To keep it simple, this schematic has only one bus which is fed from >both ends. The failure of any one wire or terminal or switch or >relay will not interrupt power to the bus. In the event of low >voltage, the pilot should shut off master switch #1. Doing so will >shut off power to the alternator field and master contactor coil, >thus conserving battery energy. It is up to the pilot to shut off >any other unnecessary loads. > Although this architecture is intended for a simple aircraft, the > single bus could supply power to an IFR instrument panel or to an > electrically dependent engine without danger of power loss due to > the failure of any one component. >Joe > >-------- >Joe Gores What you have offered my friend is certainly appropriate to say Figure Z-0 . . . a base line from which our systems have evolved since the first battery/ generator system was installed in an airplane. A boat-load of airplanes were successfully flown for millions of hours with this architecture which was unchanged until that pesky germanium transistor showed up for work and scared the pants off of too many system integrators who were happy with the status quo . . . the avionics master switch was born and things took off from there. It has evolved from there in many ways . . . some good . . . some not so good. But your suggestion is an excellent reminder of the idea that the best systems are crafted on a solid foundation that's 99% golden . . . adding only those features which address a tiny but risky fraction of the rest. Thanks! Bob . . . ________________________________________________________________________________
Date: Jan 08, 2014
Subject: Re: Proposed new Z diagram?
On 01/08/2014 09:12 AM, Robert L. Nuckolls, III wrote: > The drill for crafting any system is to do the FMEA > and then add/adjust features to minimize workloads > and risks for the catalog of failures. > > Without such debate, we can only assess DJ's > efforts from the standpoint of being a work of > art or a photograph that is pleasant to look at . . . > but of unknown value for a pilot that is wrestling > with what could become a bad day in the cockpit. I apologize for not getting back to you on this and your other questions. This thing called "work" keeps getting in the way... :-) I will work on refining and clarifying my "feature" list and we can definitely discuss! :-) -Dj -- Dj Merrill - N1JOV - VP EAA Chapter 87 Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Date: Jan 08, 2014
Bob, I think I am getting a glimmer of understanding of the underlying message you've been trying to communicate. I've been looking at this as a top-down approach, and I presented a draft in roughly step 3 of my design process and you've been asking about things back in step 1 that I've attempted to communicate, but have failed to do so successfully. You've also been asking about things in step 5, but we aren't there yet... :-) In rough terms, my "steps" are along the lines of: 1) List features and design goals. 2) Draft a circuit to reflect step 1. Note this is to illustrate a functional representation, and is not intended as a implementation diagram, thus specific values for components are not indicated at this time. 3) Review the circuit and verify functionality, checking for undesired behaviour, etc. (This is where I submitted my first post to the mailing list asking for peer review) 4) Spec each individual load and determine the appropriate location for each load in the circuit. Examples would be to finalize the list of which devices would be on the redundant bus, which would be on the main bus, etc. 5) Fill in specific values for components in the circuit diagram and draft an implementation diagram. 6) Review, verify, finalize. 7) Build the circuit and test, test, test. Here is my list of features and design goals: 1) There are devices that are considered critical to the safe operation of the aircraft. These devices should be able to draw power from two completely independent power buses and battery sources. This shall be known as the "redundant" bus. 2) When everything is on, devices on the redundant bus should be able to automatically draw power from either source, with no user intervention required. Ie, if one of the bus/batteries fails or is turned off, the devices on the redundant bus will remain powered on using the other source. 3) Bonus feature if alternator-only mode can be optionally supported. 4) Minimize "always-hot" wires. 5) No parasitic loads on the battery when everything is "off" (ie, clocks, etc.). 6) Each battery and associated bus should be able to be switched "off" and isolated from the rest of the circuit. 7) With special regard to the engine ignition, the ability to switch off independently of the other devices for pre-flight equivalent of "mag checks". Notes: The EFIS has three built-in diode isolated power inputs. This implies that it can be wired directly to the primary and secondary power buses directly using two of those inputs. Devices having only one power input and that are considered critical are wired to the redundant bus. Other non-critical devices will be wired to the primary bus. The aircraft will initially have one mag and one Electronic Ignition (EI). Eventually the second mag will likely be replaced with a second Electronic Ignition. Based on discussions that we've had so far on the list, I've already realized a change to be made from my initial drawing with regards to how the ECU is connected. There will be one switch for the mag, and one switch for the EI (versus the two switches for the single EI as shown currently). When the mag is swapped for the second EI, the switch will be swapped as well, leaving one switch for each EI, allowing them to be switched on and off independently. Physical layout: My panel is laid out such that the engine switches are separate from the rest. The three will be laid out as Mag (or 1st EI), 2nd EI, Starter. Electrical would be Primary Power, Alternator, Secondary Power, followed by the switches for the lights, etc. Operations: Normal operations are Primary, Alternator, and Secondary switches in the on position before engine start, and until engine shutdown. In the event of "smoke", Primary and Alternator would be turned off by hitting the two leftmost switches. This cuts power to all but the flight critical devices and has the highest chance of cutting power to whatever is "smoking". If "smoke" continues, turn on Primary power and turn off Secondary. If "smoke" still continues, get on the ground ASAP - one or the other power bus must remain on to power the engine and EFIS. Note there is a good argument to be made to replace the two separate Alternator and Primary power switches with a combined three position switch. This would reduce the total DC power switch count to 2, and slightly reduce operations complexity while only giving up alternator-only mode, which has dubious value in a two redundant bus arrangement. After further thought, I am going to make this change in my diagram. -Dj -- Dj Merrill - N1JOV - VP EAA Chapter 87 Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
From: "Roger & Jean" <mrspudandcompany(at)verizon.net>
Subject: DIY Marker beacon antenna
Date: Jan 08, 2014
I have a wooden airplane in which I will be installing a Marker beacon receiver. My question is: Is it relatively simple to fabricate an antenna, or should I consider purchasing one? I assume it can be put on the inside of the airframe without a significant loss of signal strength. Roger ________________________________________________________________________________
From: "R. curtis" <mrspudandcompany(at)verizon.net>
Subject: Re: DIY Marker beacon antenna
Date: Jan 08, 2014
> I have a wooden airplane in which I will be installing a Marker beacon > receiver. > > My question is: Is it relatively simple to fabricate an antenna, or > should I consider purchasing one? > > I assume it can be put on the inside of the airframe without a significant > loss of signal strength. After posting the above, I searched the archives and found lots of info to answer my question. Looks like I will run a coax to a convenient place and then a 40" piece of wire for the antenna, or just strip the braid off the last 40" of the coax and attach it inside the fuselage. Marker beacons will most likely disappear in the near future anyway. Just thought that since I already have the receiver, there is no reason not to put it to use. Roger -- Do you have a slow PC? Try a Free scan http://www.spamfighter.com/SLOW-PCfighter?cid=sigen ________________________________________________________________________________
Subject: Thoughts on a few electrical system configurations?
Date: Jan 08, 2014
I'm nearing the point in my RV-10 build where I need to make some decisions about the electrical system architecture. Also, like any good engineer, I've got a serious case of analysis paralysis going. In an effort to help clear the logjam, would the list share its collective thoughts? Background - I fly in IMC fairly regularly. - The engine doesn't require power to keep running, but the attitude instruments are all electrically powered. Thus keeping at least some power running is important. (i.e.: AI, GPS, COM) - The planned avionics configuration is such that in a split bus design, one set/bus of units could be depowered without loss of overall functionality. (i.e.: EFIS, GPS1, COM1 on Bus A; AI, GPS2, COM2 on Bus B) - Any LiFePO4 batteries mounted firewall forward in stainless steel enclosures for fire containment (included in weight estimates). System objectives - Provide 4.5A of power for at least 4 hours in the event of any component failure (unless we can point to a *very* established track record of performance for that component) - Minimize weight - Minimize complexity and component count Configuration options and my thoughts: (weights given are nominal relative to configuration 1) 1. 60A alternator, 27Ah lead acid battery, e-bus. +0 lbs. Standard configuration on this type of aircraft. According to Bob, complete battery failure is very rare. Even fairly degraded battery has capacity to provide sufficient reserve power. E-bus protects against wiring faults. Simple architecture is a plus. Configuration is (relatively) heavy. 2. 60A alternator, 8A alternator, 17Ah lead acid battery, e-bus. -9 lbs. Addition of backup alternator allows battery to be reduced in size, saves some weight. 3. 60A alternator, 12Ah LiFePO4 primary battery, 12Ah LiFePO4 backup battery, split bus. -18lbs. Alternator charges primary battery and, through diode, secondary battery. Split bus design because LiFePO4 batteries have low reliability compared to lead acid. Cost/availability limits backup battery to 12Ah which falls short of endurance requirement, may be possible to reduce power consumption. Relatively simple architecture. Lightest configuration. 4. 60A alternator, 8A alternator, 12Ah LiFePO4 primary battery, 2Ah lead acid secondary battery, split bus. -17lbs. 60A alternator + 12Ah LiFePO4 power Bus A. 8A alternator + 2Ah lead acid power Bus B. Busses are not interconnected. May be safe to mount 2Ah lead acid under panel to reduce firewall penetrations and wiring complexity. Dual alternator, dual battery, split bus provides high availability and unlimited endurance. Medium/high complexity. Relatively light. 5. Same as configuration 4, except with 4Ah LiFePO4 secondary battery. -16lbs. Presented in case there are issues with using/charging such small lead acid batteries with 8A alternator. Thanks for your thoughts, David Read this topic online here: http://forums.matronics.com/viewtopic.php?p=416700#416700 ________________________________________________________________________________
Date: Jan 08, 2014
Yeah I started to answer your question but I'm not an avionics expert, but have a bit of experience. So my input is a marker beacon will work off a wet noodle, you can actually just put a rubber duck or length of wire out the back and it will receive. They are rather large if made resonant, but if you want I can get you the dimension for a foil antenna if that will work. And your right, already an approach certified GPS will serve for those approaches that use a MB for a fix. Tim > On Jan 8, 2014, at 10:06 AM, "R. curtis" wrote: > > >> I have a wooden airplane in which I will be installing a Marker beacon receiver. >> >> My question is: Is it relatively simple to fabricate an antenna, or should I consider purchasing one? >> >> I assume it can be put on the inside of the airframe without a significant loss of signal strength. > > > After posting the above, I searched the archives and found lots of info > to answer my question. > > Looks like I will run a coax to a convenient place and then a 40" > piece of wire for the antenna, or just strip the braid off the last 40" > of the coax and attach it inside the fuselage. > > Marker beacons will most likely disappear in the near future anyway. > Just thought that since I already have the receiver, there is no reason > not to put it to use. > > Roger > > -- > > Do you have a slow PC? Try a Free scan http://www.spamfighter.com/SLOW-PCfighter?cid=sigen > > > > > > ________________________________________________________________________________
Date: Jan 08, 2014
Updated "Z-redundant-B" diagram at http://deej.net/glastar/pics/electrical/Z-redundant-B.jpg Changes: Removed alternator-only operation by combining the separate Alt and Primary bus switches into a single three position switch (Off, Bat, Bat+Alt). Reduced operational complexity by removing separate Alt switch. Now has 2 DC power switches (Primary/Alt and Secondary) versus 3. In the event of "smoke", turn the left most switch (Primary/Alt) off. This cuts power to all but the flight critical devices and has the highest chance of cutting power to whatever is "smoking". Reflects two EI ECUs with independent switching to allow pre-flight equivalent of "mag checks" -Dj -- Dj Merrill - N1JOV - VP EAA Chapter 87 Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Date: Jan 08, 2014
Subject: Re: Thoughts on a few electrical system configurations?
David, I'm attaching the main power distribution diagram and Fuse/Breaker diagram for my RV10 (2.3 years and 350+ hours). It is an Aeroelectric Z-14 design with (2) 17aH Odysseys, 2 alternators, and dual buses. The panel, designed around 2008, includes 3 GRT/HX EFIS with dual AHRS, a G430w, SL30, PM audio panel, and TT AP. I like the whole setup. I would be glad to answer any questions about it. Bill "the electrical and avionics design & build was the most fun part of the project" Watson On 1/8/2014 1:19 PM, digidocs wrote: > > I'm nearing the point in my RV-10 build where I need to make some decisions about the electrical system architecture. Also, like any good engineer, I've got a serious case of analysis paralysis going. In an effort to help clear the logjam, would the list share its collective thoughts? > > Background > - I fly in IMC fairly regularly. > - The engine doesn't require power to keep running, but the attitude instruments are all electrically powered. Thus keeping at least some power running is important. (i.e.: AI, GPS, COM) > - The planned avionics configuration is such that in a split bus design, one set/bus of units could be depowered without loss of overall functionality. (i.e.: EFIS, GPS1, COM1 on Bus A; AI, GPS2, COM2 on Bus B) > - Any LiFePO4 batteries mounted firewall forward in stainless steel enclosures for fire containment (included in weight estimates). > > System objectives > - Provide 4.5A of power for at least 4 hours in the event of any component failure (unless we can point to a *very* established track record of performance for that component) > - Minimize weight > - Minimize complexity and component count > > Configuration options and my thoughts: > (weights given are nominal relative to configuration 1) > > 1. 60A alternator, 27Ah lead acid battery, e-bus. +0 lbs. > Standard configuration on this type of aircraft. According to Bob, complete battery failure is very rare. Even fairly degraded battery has capacity to provide sufficient reserve power. E-bus protects against wiring faults. Simple architecture is a plus. Configuration is (relatively) heavy. > > 2. 60A alternator, 8A alternator, 17Ah lead acid battery, e-bus. -9 lbs. > Addition of backup alternator allows battery to be reduced in size, saves some weight. > > 3. 60A alternator, 12Ah LiFePO4 primary battery, 12Ah LiFePO4 backup battery, split bus. -18lbs. > Alternator charges primary battery and, through diode, secondary battery. Split bus design because LiFePO4 batteries have low reliability compared to lead acid. Cost/availability limits backup battery to 12Ah which falls short of endurance requirement, may be possible to reduce power consumption. Relatively simple architecture. Lightest configuration. > > 4. 60A alternator, 8A alternator, 12Ah LiFePO4 primary battery, 2Ah lead acid secondary battery, split bus. -17lbs. > 60A alternator + 12Ah LiFePO4 power Bus A. 8A alternator + 2Ah lead acid power Bus B. Busses are not interconnected. May be safe to mount 2Ah lead acid under panel to reduce firewall penetrations and wiring complexity. Dual alternator, dual battery, split bus provides high availability and unlimited endurance. Medium/high complexity. Relatively light. > > 5. Same as configuration 4, except with 4Ah LiFePO4 secondary battery. -16lbs. > Presented in case there are issues with using/charging such small lead acid batteries with 8A alternator. > > Thanks for your thoughts, > David > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=416700#416700 > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Jan 08, 2014
From: John W Livingston <livingjw(at)earthlink.net>
How do you know that each feed going into your diodes is working? On 1/8/2014 2:53 PM, Dj Merrill wrote: > > Updated "Z-redundant-B" diagram at > > http://deej.net/glastar/pics/electrical/Z-redundant-B.jpg > > > Changes: > > Removed alternator-only operation by combining the separate Alt and > Primary bus switches into a single three position switch (Off, Bat, > Bat+Alt). > > Reduced operational complexity by removing separate Alt switch. Now has > 2 DC power switches (Primary/Alt and Secondary) versus 3. In the event > of "smoke", turn the left most switch (Primary/Alt) off. This cuts > power to all but the flight critical devices and has the highest chance > of cutting power to whatever is "smoking". > > Reflects two EI ECUs with independent switching to allow pre-flight > equivalent of "mag checks" > > > -Dj > ________________________________________________________________________________
Date: Jan 08, 2014
> > >In rough terms, my "steps" are along the lines of: > >1) List features and design goals. Let's concentrate on this step. Take the Z-figure that comes closest to what you want. Describe which features do not address a design goal and articulate what you would do different . . . speak to the design goal either in terms of (1) a perceived risk that is mitigated by a proposed change or (2) "just because." There is no wrong motivation . . . but features in the 1-bucket can be evaluated against legacy lessons-learned and technical/economic trade-offs; stuff in the 2-bucket are not technically debatable. The feature offers functionality that is easily confirmed by looking at the diagram and no sifting of simple-ideas is needed. The change is justified "just because". This is an important exercise . . . if there are compelling revelations of shortcoming in any of the Z-figures, I'm intently interested in knowing what they are. At the same time I am reluctant to publish pretty-variations-on-a-theme that offer no demonstrable increase in utility or reduction of risk. I just received a drawing from another reader who has crafted a one-battery, two-alternator configuration loosely based on Z-12 but with a avionics master switch and some errors in functionality. My question to him will be similar, "How does Z-12 fall short of your expectations for risk management and what information do you have indicating that an avionics master is useful/ necessary?" Bob . . . ________________________________________________________________________________
Date: Jan 08, 2014
David, Suggest you also consider 60A primary alt. and 20A secondary alt. Set the regulator on the secondary 0.5V lower than primary regulator. I have this in my all glass RV10. After 3 years, I had a primary alt. failure due to spun bearing shorting out the winding. Bus voltage dropped 0.5V as expected; the secondary alt. picked up the slack and we completed our flight at our leisure. With 20A I can keep everything lit up indefinitely except my heated pitot and landing lights. No bus switching or load shedding necessary. Jim Berry RV-10 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=416712#416712 ________________________________________________________________________________
Date: Jan 08, 2014
If I may be so bold, are you sure you wish to go to the trouble of installing a Marker Beacon receiver and an Antenna? The trouble of installing the Marker Beacon Receiver is minimal. It is already installed in my audio panel, so the only effort is to add the antenna. Bob N. in an old post said a "wet string" would work as an antenna, but I discarded that as too much trouble to keep the string moist on an approach. I am only installing it because it is there and can be activated with very little effort and could possibly be used as a backup indicator. If it wasn't there, I would NOT go out and purchase one. Roger ________________________________________________________________________________
Date: Jan 08, 2014
On 1/8/2014 4:56 PM, John W Livingston wrote: > > > How do you know that each feed going into your diodes is working? Hi John, Excellent question. The GRT HX EFIS monitors each power input, and will notify you if either of the two power inputs lose power. This will verify that the Primary and Secondary buses are getting power. I do not have any monitoring in the diagram to tell if each of the diodes is working, however, a pre-flight check turning off each of the buses before enabling the alternator could be an option. If any of the critical devices power down, one of the diodes has failed (or some other issue). -Dj -- Dj Merrill - N1JOV - VP EAA Chapter 87 Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Date: Jan 08, 2014
Dj, I cannot find your latest drawing.- Can you send a link or attach it? =0A=0Athx=0A=0A=0A=0A________________________________=0A From: Dj Merrill < deej(at)deej.net>=0ATo: aeroelectric-list(at)matronics.com =0ASent: Wednesday, Ja nuary 8, 2014 5:15 PM=0ASubject: Re: AeroElectric-List: Re: Proposed new Z @deej.net>=0A=0AOn 1/8/2014 4:56 PM, John W Livingston wrote:=0A> --> AeroE lectric-List message posted by: John W Livingston =0A> =0A> How do you know that each feed going into your diodes is working? =0A=0AHi John,=0A- - Excellent question.- The GRT HX EFIS monitors ea ch power input, and will notify you if either of the two power inputs lose power. This will verify that the Primary and Secondary buses are getting po wer.=0A=0A- - I do not have any monitoring in the diagram to tell if ea ch of the diodes is working, however, a pre-flight check turning off each o f the buses before enabling the alternator could be an option.- If any of the critical devices power down, one of the diodes has failed (or some oth er issue).=0A=0A-Dj=0A=0A-- Dj Merrill - N1JOV - VP EAA Chapter 87=0ASports man 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/=0AGlastar Flyer N =========================0A - - - - - - - - - - - - - -Matt Dralle, List Admi ======================= ________________________________________________________________________________
Date: Jan 08, 2014
On 1/8/2014 3:11 PM, Robert L. Nuckolls, III wrote: >> 1) List features and design goals. > > Let's concentrate on this step. Take the Z-figure > that comes closest to what you want. Describe which > features do not address a design goal and articulate > what you would do different . . . speak to the design > goal either in terms of (1) a perceived risk that is > mitigated by a proposed change or (2) "just because." The closest from the Connection is Z-19. Using my list of features/design goals from the previous email (for reference they are included at the end of this email) and comparing to Z-19: 1) For avionics, Z-19 offers power from two separate batteries, but it does not offer it from two independent power buses. However, it DOES have both of these features in the engine section of the circuit. (Because if we can do it with the critical EI, it makes sense to also do it with other equally critical devices. Non-critical devices in Z-redundant-B are on the Primary bus just like Z-19) 2) Z-19 offers this feature with regards to the batteries. 3) No alternator-only mode, but since I've also removed this from Z-redundant-B this is a null. 4) Z-19 does not minimize "always hot" wiring. (Because I don't like it, and it is easy to create a circuit that does minimize "always hot" wiring. I have nothing in my plane that requires "always hot" power other than the contactors.) 5) Z-19 has parasitic loads. (Because I don't like my battery being drained between flights, and I have nothing in the plane that requires a constant power source. The GRT EFIS will sync its time via the GPS signal after power-up.) 6) Z-19 does not offer this feature. (This is a cross between "just because I want to" and safety. In general bus wiring is "safe", with the common cause of failure being installation error as we've discussed on the list. I'm not perfect, and could inadvertently crimp a bad connection or make a bad solder joint. Additionally, being able to switch off and isolate the two separate buses allows me to easily turn off all non-critical devices with a single switch if there are issues in flight) 7) As written, Z-19 supports a single EI which can be turned off, but requires modification to support two EIs that can be turned off independently. (This is a safety feature to ensure both ignitions are working correctly during the pre-flight checks) What I would do different (ie, what I did) was take the features that I liked from the Z-19 diagram and use it as a basis to create Z-redundant-B. You can see many of the features of Z-19 in the Z-redundant diagram, with emphasis on the redundant engine bus concept in Z-19 extended to support flight critical devices. As an exercise, let's flip this around. Suppose hypothetically Z-redundant-B had been around for awhile, and someone proposed Z-19. Why would you choose to use Z-19 over Z-redundant-B? What features/design goals exist in Z-19 that you desire compared to Z-redundant-B? :-) -Dj > Here is my list of features and design goals: > > 1) There are devices that are considered critical to the safe operation > of the aircraft. These devices should be able to draw power from two > completely independent power buses and battery sources. This shall be > known as the "redundant" bus. > > 2) When everything is on, devices on the redundant bus should be able to > automatically draw power from either source, with no user intervention > required. Ie, if one of the bus/batteries fails or is turned off, the > devices on the redundant bus will remain powered on using the other source. > > 3) Bonus feature if alternator-only mode can be optionally supported. > > 4) Minimize "always-hot" wires. > > 5) No parasitic loads on the battery when everything is "off" (ie, > clocks, etc.). > > 6) Each battery and associated bus should be able to be switched "off" > and isolated from the rest of the circuit. > > 7) With special regard to the engine ignition, the ability to switch off > independently of the other devices for pre-flight equivalent of "mag > checks". -- Dj Merrill - N1JOV - VP EAA Chapter 87 Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Date: Jan 08, 2014
On 1/8/2014 9:09 PM, Jeff Luckey wrote: > Dj, I cannot find your latest drawing. Can you send a link or attach it? > > Hi Jeff, It can be found at: http://deej.net/glastar/pics/electrical/Z-redundant-B.jpg -Dj -- Dj Merrill - N1JOV - VP EAA Chapter 87 Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Date: Jan 09, 2014
At 04:37 PM 1/8/2014, you wrote: > >David, > >Suggest you also consider 60A primary alt. and 20A secondary alt. >Set the regulator on the secondary 0.5V lower than primary >regulator. I have this in my all glass RV10. After 3 years, I had a >primary alt. failure due to spun bearing shorting out the winding. >Bus voltage dropped 0.5V as expected; the secondary alt. picked up >the slack and we completed our flight at our leisure. With 20A I can >keep everything lit up indefinitely except my heated pitot and >landing lights. No bus switching or load shedding necessary. This philosophy is described in Figure Z-12 which is representative of standby alternator installations on what must now be more than a thousand TC Bonanzas, Mooneys, Pipers and Cessnas. Bob . . . ________________________________________________________________________________
Date: Jan 09, 2014
At 03:56 PM 1/8/2014, you wrote: > > >How do you know that each feed going into your diodes is working? A cogent question. Any feature added to a system intended to mitigate risk due to some failure needs to be 'monitored' for functionality. This can be a pre-flight test procedure, a data acquisition system that watches for anomalous conditions, a periodic investigation during 100 hr inspections, etc. etc. The thrust of John's question may not be obvious . . . it's important that 'failed features' not be allowed to persist as latent failures. The inability to detect such failures has a tendency to negate their benefits. Bob . . . ________________________________________________________________________________
Date: Jan 09, 2014
Subject: Intercom Install
Hello to the group,=0A=0AI'm in the planning phase of installing a PS Engin eering PM3000 Intercom in the panel.=0A=0AThis unit has one switched Auxili ary Stereo Input for music, plus couple un-switched inputs for warnings, et c=0A=0AI however have two Stereo sources, a harwired Garmin AERA 560 and a music Aux input jack that i plan to install in the panel as well for extern al music players such Iphone, etc.=0A=0AThe AERA Audio has XM Stereo music, MP3 player Stereo music as well as warnings, that's the reason i like to =0Amaintain it as a stereo music/warning source and not just a mono warning source =0A=0AI like to have both sources to feed the PM3000 switched Stere o Aux Input simultaneously, not thru an A/B =0Aswitch.- =0A=0AI was wonde ring what you will=0A recommend that i use to properly combine and isolate the two inputs. =0A=0AI'm debating if i should just =0Ause passive combinin g/isolation circuit (resisters in line with both =0Asources) or if i should consider using an active circuit similar to the =0AAMX-4A (previously VX E ngineering)- or something=0A similar if such a thing exist in the market. =0A=0AJust seeking input from people that may had to cross this bridge befo re and have some recommendations=0A=0A=0AThanks=0A=0ASaad ________________________________________________________________________________
Date: Jan 09, 2014
Subject: DYI Marker Beacon Antena
Roger, I followed Bob's advice when building my RV-6A. ran a piece of cable from my radio to the firewall and used a bulkhead BNC connector to get to the front side of the firewall. I then took a piece of cable about 48" long and attached a female end on that for the forward connection and proceeded to strip 40" of the sheath from the cable. Subsequently I fiberglassed that to the inside of my cowling running forward horizontally. Works fine and I've not ever forgotten to disconnect the cable from the firewall when removing the cowling. YMMV Marty, RV-6A N826ME From: "Roger & Jean" <mrspudandcompany(at)verizon.net> Subject: AeroElectric-List: DIY Marker beacon antenna I have a wooden airplane in which I will be installing a Marker beacon receiver. My question is: Is it relatively simple to fabricate an antenna, or should I consider purchasing one? I assume it can be put on the inside of the airframe without a significant loss of signal strength. Roger ________________________________________________________________________________
From: "Valin & Allyson Thorn" <thorn(at)starflight.aero>
Subject: How to Toggle Speed Brakes with Momentary On Switch?
Date: Jan 10, 2014
Hello Bob N or anyone that can help, I'd like to toggle our speed brakes/spoilers up or down by the press of a momentary on button on our Tosten control sticks. In my circuit diagram below, this arrangement will deploy (raise up) the Precise Flight Speed Brakes when the left button is pressed on the stick. Note a positive voltage on SB control unit's pin 6 deploys them up and positive on pin 7 retracts them down. I'd like to be able to press and release it and have it change states up/down. I know the easiest would be if I could change the switch on the stick to lock closed when pressed and unlock when pressed - but, that's not an option for this control stick. Is there a simple way to achieve this capability with these contraints? Thanks, Valin Thorn Lancair Legacy Project Boulder, Colorado ________________________________________________________________________________
From: Bob McCallum <robert.mccallum2(at)sympatico.ca>
Date: Jan 10, 2014
Valin=3B Use the stick output to energize a bi-stable spdt relay. Each time the coil is energized the relay switches and the opposite wire becomes energized. ( also referred to as a "latching relay") This assumes the speed brake contro ller is happy with a maintained input. Bob McC From: thorn(at)starflight.aero Subject: AeroElectric-List: How to Toggle Speed Brakes with Momentary On Sw itch? Date: Fri=2C 10 Jan 2014 11:14:48 -0700 Hello Bob N or anyone that can help=2C I=92d like to toggle our speed brake s/spoilers up or down by the press of a momentary on button on our Tosten c ontrol sticks. In my circuit diagram below=2C this arrangement will deploy (raise up) the Precise Flight Speed Brakes when the left button is pressed on the stick. Note a positive voltage on SB control unit=92s pin 6 deploy s them up and positive on pin 7 retracts them down. I=92d like to be able to press and release it and have it change states up/down. I know the easi est would be if I could change the switch on the stick to lock closed when pressed and unlock when pressed ' but=2C that=92s not an option for this control stick. Is there a simple way to achieve this capability with these contraints? Thanks=2C Valin ThornLancair Legacy ProjectBoulder=2C Colorado /9j/4AAQSkZJRgABAQEAcwBzAAD/2wBDAAoHBwkHBgoJCAkLCwoMDxkQDw4ODx4WFxIZJCAmJSMg IyIoLTkwKCo2KyIjMkQyNjs9QEBAJjBGS0U+Sjk/QD3/2wBDAQsLCw8NDx0QEB09KSMpPT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT3/wAARCARvBPYDASIA AhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQA AAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3 ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWm p6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/8QAHwEA AwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSEx BhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElK U1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3 uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD2aiii gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAMzW3xbxr/eaq2irm7Zv7q0/W2zJEvoCa foa/LM/uBQBrUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFABRRRQAUUUUAJS1zPjm38SXOkwr4TmWG8EwMjMyj5MH+8PXFeU+Hte+I3iTUruz0/VQ 8lkwE4fy1A+Yjg456GgD3ulrzPxl4m1jS/iR4d0y0vGitLoR+fEFUh8uQecZ6V0fxI1W80TwPfX2 nTmC5i2bJAAcZcA9fY0AdRRXK+EvEDP8OLTW9audxEDSzzEAZAJ7D6VwMfiXx38Rbud/DGNM0yJt qyFgufq+CSfYdKAPaKWvFZvEHj74dXEM/iJhqemSNtdtwcD6PgEH0zwa9C8QeIvN+HF5rmi3BXda GaCXAyp+h7jpQB1FJXg2neIPiVdeHH8Q2t8s9hFuLbljJwp+b5cZrtR46utZ+EN9r1qRa6hAhRig yFcMASM9iD+tAHolFeY/Cb4iT+I/O0rWp/M1FMyQykAeancYHcfy+lSeIfE+r2fxi0jRre8ZNPnW MyQhRhs7s84z2FAHpdFJXlvxM8Xa3D4nsPDHh+dbOa5VWa4YhdxYkABj0HFAHqVFee+A/wDhObLW 7nTfEwF1YxpuW7ZgTk9ArY+b3B6VlnxxL/wuc2f9txf2FsHHmr5W7ys/e/3vfrQB6vRVS+1Oz0y1 NzfXUNtAP+WkrhR+tU4PFehXNo11Dq9i0CkK0nnqApPQHnigDXpKovremxfZ/M1C0UXIzAWmUeaP 9nnnr2rhviZ45t4PCFwPD+s25vDOsLmCUF1H8WP05HrQB6RSV4Teajq2i/CaC/tfE891c3N5ESY5 iXtwY2JjJyT1wccdK3/Ew8Q6honhK407xBDZM9vG83n3YiaRyFO85+/16e/vQB6xRVeW6isbTzr2 4iijRfnlkYIv15rPtPFug38cr2usWMiwjMhEy/KPU+3vQBsUVx3xB1tk+HOoalot/hl2eXcW0mf+ WgBww/EVX8G+L7K28DaTceINZhS6nRiWuZhvf5iM880AdzSVmanq9rBoE9+t7AkJiYxT+YNpODtw enWuH+Dviu713Tr2PWdTFzeif90kjKH2BRnA9M0AemUlMnYrbyMpwQpIP4V558IPEuq+JLXVn1e7 a5aCZFjLKBtBBz0HtQB6PRUc9xFawtNcSJFEgyzuwVVHuTWXZ+LdB1Ayi01ixlMQLOFmX5QOp+nv QBsUVSj1jT5rF72K+tntI87p1lBRcdct0qrc+LNCs7aO4uNYsUhkOEfz1IbHXHPNAGvRUNrd299b pcWk0c8LjKyRsGU/iKp6p4h0nRcf2nqNrak9FlkAJ/DrQBpUVT07V7DV4fN068t7qMdWhkDY+uOl Jqesafo0Im1K9t7WM9GmcLn6etAF2krKTxVoclot0ur2H2d22iQzqFJ6469a4/4lxa1dX2jSaLr1 tp8JYsVkuhDvORhhn74wenv70AejUVnSa1p1nI1vd6jaR3EUe+RHlVWAxyxGeBU+n6laaraJdWFx HcW752yRnKnHB5oAtUV538YfEmq+GtI06bSLtraSW4KOQoORtz3Fd5Yu0un28jnLvErE+pIoAsUV napr+l6KqnVNQtrTd90SyBSfoOtTadqtjq0Hn6ddwXUXdoXDAflQBboqve39rp1s1xe3EVvCvWSV wqj8TVC18V6Fe20txbavYyQxf6xxMuE7c+lAGvRUNvdwXdstxbzRywMMrIjAqR6g1mw+LdBuL/7F Dq9i9znHlrMuSfQetAGxRVOz1ax1F5Esry3uGi4kEUgYp9cdKj1PXtM0VQ2p39tag9PNkCk/QdaA NCiqGm63p2sxmTTb63u1HUwyBsfUdqfZ6tYahLJHZXtvcSRf6xYpAxT6gdKALlFU77VrDTNn2+9t 7bzOE86QJu+metWwcgEdDQAtFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFA BRRRQAUUUUAFFFFABRRRQAUUUUAFIeaWigDlZkMczp3ViK6W2fzLaNvVRWDqSbL+UepzWvpT77CP /ZyKALlFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFFFFABRRRQAUUUUAYGrtm+I/uqBV/Rk22Zb+8xrL1B999MfRsVtaau2wi9xmgC1RRR QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFA BRRRQAV498Gv+Ry8Vf7/AP7UevYa80+GfhXV9A8TeILrUrQww3bZhYup3fOx7H0IoA574uw3lx8S NCh02Xybx4kWGQnG1zIcHP1qh4w8O+PrDwzdXGva0lzp67fNiE5bd8wxxtHfFdl408LavqvxK0DV LK0MtlaeX50m8DbhyTwTnpXQ/EbSbzXPBF9YadCZrmUpsTIGcMCeT7CgDg9TEx/ZytPI3YwnmY/u +af64ruPhgbX/hXmkfY9m3yv3m3/AJ6ZO7PvmneEvDzxfDq00TWrbDGBop4SQeCT3H1rgF8KeOvh 7fTr4VcahpkrbhGcNj6oSMH3HWgD0P4im1/4QDWftu3y/s527v7/APDj33YrgfDPnf8ADPeq+du2 bZvKz/dyOn47qhm8NePviFdQw+JSNN02NtzKAFB+igkk/XpXofiDw75fw6vNC0W3zi1MMEWRkn6n uetAHz/b6j4hs/DtjY/2jJa6LqLOi4Pyfew+7Az3yR6V6/rPhmDwn8FdS06CXzyIfMklxgOzMuSP bpis+1+HV7ffCFdHvrYQ6tbyyT26swOGyTjI4+YcflV+20rxJffCG90PUrB11OOIQQAyKfNQEEc5 6gcc+lAHnkfhu5sfAejeM9D3R3lm7fadvoHIV8fofatJPElv4r+LnhjU7f5TJHEssf8AzzkG7cP8 9q9N+H2hXOl+ArXStYtgko8xZYWIYFWY8HHHINcFp3wu1Xw/8ULS7srcy6PFciVZt4yiEHgjOcjp QB7TXHfELwBD4zsEkhcQanbA+RMehHXa3t79q7GvNPHujeMoPE1vr3hi5luo402/Y9wxHxg/KeGB /OgCD4d+N9Ug1o+EfFSOuoRZWCZz8zYGdrHvxyG71zB8G6N/wu46Cbdv7O2B/L8w5z5W/r161veF PCnifXfHkXijxXCtp9mH7uMAAsQCFAAJwBnOTWofC+rf8LvOvfZD/ZnlhfO3Dr5IXpnPWgDm9bsj 49+MjaFfzyR6bp6ELGhxwqgnHuSevpTPip8ONI8OeHk1TRlkt9sqxSxGQsrg5weec5Fb/jjwTrkH iuPxX4QYNegDzoCQCxAxkZ4II4IrA8TaR8R/G+lKNR06G3ggcFbWMqhkbpuOSenue9AGV45h+0eH /AEIYqZLMJuHUZ8sVv8AxS8D6H4c8Cwy6ZaGKWK5VQ5cktuGGJz67RUniTwTr1/p/guO2sC76bAq 3Q3qPLIKe/PQ9K6z4q6FqHiLwh9i0q3M9x9oR9m4DgA5PP1oA4Dxdodjo3wU0uSxiKNe3EE8xLE7 nMTZPPSo/iD/AMgPwB/17J/KOur8ZeFNY1T4V6NpFnZmS+t2hMsW9Rt2xsDyTjqRVHxl4M1zVNK8 IQ2diZJNPhVbkb1GwgJ6nnoelAFb4lmfxN8TNI8LSXDw2LBGYL3Zskn3OBgVY8d/CrQdK8H3d/pK zW1zZx7yxlLCUZ5DZ7/Sr/xO8MR6vqllqOlataWWv2oUJFLcLG0ozlcZ6EHOOxrl/Fx+IF34Vuv+ EmltbLT4VBcAoGuGyML8pOeeew4oAuwf8m2SfU/+lFN8GfDDSNZ+Hh1PUBM97cRyNE4kIEQUkLgd +nOa0NH0W+1b9n9NPsYDLdT5aNMgbh52ep9hXY+C9JvNK+Htppt7CY7uOCRWjyDgktjkcdxQB538 MbGHxB8N9e03U981rby+bGm4jawTdxj3GasfAfRLKe3vNXeMm9gmMMb7jgKVGRjpWx8MfCmseH/D OuWuqWhgnuSfKXep3fIR2PrVv4QeGtU8M6Jfwavam3lluA6KWDZG0DsaAO9uf+PaX/cP8q8p+An/ AB467/18R/yavV51LQSKoySpA/KvCvDvh/4k+E1uk0fT0jS4cM+8xNkjOOp96ANr4tXF1rfi/Q/C kc5gtbko8hB+8zMVBPrgDj3NWfFvwj0HT/CV3daUJre8s4GlErSk+YAMkMOnIz0xU/i3wPrfinw/ o+rBlh8TWUYMi5C7znOARwCDyO3NZOoR/E7xVo02lXthBaQeWfNk+VGnxyF6nr7YFAEXhb/k33W/ 96X/ANlpnw3+Gmj+I/Br6jqgmlnnZ0i2yFRCFOMgDqc561uaB4S1mz+DuqaJcWZTUZ2kMcO9Tuzt xznHY10fw00a+0HwRb2GpweTco8hKbgeCxI5FAHA/CPV5tH8LeKnyZEsF86ND03bW/ntFHw58D2f ji2uvEfieWa9mmnZFjMhA4xkkjnvwO2K3fhh4N1LSIdft9esjFBf4VQXB3r8wPQ+hrJtPD3jr4dX lzB4bgi1TS5n3or4OPqMgg4xnHBxQB2fh34Z6R4Y8QSappk94m5dotzL8gz1z3b8elcDZaUvxL+K 2rrrU0pstOLKkKtj5VbaFHoOpNdn4LPjy71iW88TfZ7awZcC12jdnttwePfJNYfiTwZ4k8O+MZfE vgtVnF1kz2xx1P3hg4ypPPqDQBzXxb8BaZ4VtrO90fzIYZ5THJAzlgGxkMM8+taHxc+/4L/65f8A xqq/irw58Q/Gtvb3OpafEixMVjtImVduRyxBPtjrXRfEXwhrWuN4YOnWZm+xR4n+dRsPyep5+6aA MTxVo0Gv/HqLTrvcbaZI/NVTgsojzjPvivY9L0u00bTobHT4hDbQjCICTjnPU/WuCuvC+rSfGyDX UtCdNWMAzbhwfLK9M5616RQB5R8fv+QBpP8A19N/6DXpME32bQIpiMiK2D49cLmuL+L/AIZ1XxNp Gnw6Pam4khnLuAwXA247mq3hOT4iHWbS28Q2sS6QEKS4WPptIHQ564oA800jWNL1fV73V/Fum6lq 880nyJAcRqPQ4IPHGBWh4f1WDRviHY3fhqx1S0065kWG5t7hSRhjg4PcDIIz0rqU8N+Mvh3qt2fC dvFqWk3T7xBJyUPYEZByOmQea6PwY/ju91aW88TfZrSwYfLaBBuz2xgkgeuSaAOR8YW8vjf4w2/h u7uHi0+2QHap6/JvYj3PTPpUvxH+GGi6J4Sn1PRlltpbXaJFMpZZVLAc575IP4VofEPwwb3xRbax 4c1ayt9fh2hrZ7hUeQj7pAJ644weormPHJ8c3nhiSXxXLa2VlC67IEKhrh84AwpOccn04oAn8Qa3 daZ8EPDtnaOY/t+6OR1ODsBJI/HIrqLD4LeH28ORRymc6g8Qc3ayEbXIzwvTANR2vgr/AIS34M6P YllhvIohPbu3QEknB9iD/Ks2wb4pxWC6CLOGNFXyRfSFSUTpndnnA74zQBV+C7nSv+Eqkk/eNaoG bH8RXf8A4VF8PfClv8RrrUvEHieWa6YT+WsQcqM4zzjnABAAFdD8JvB2reHJdaj1u02R3IRUYuGE gG7PQ+/esyPwt4z+HmrXbeE4Y9R0y5bd5T4JX0BGQcjpkdaAOu0X4W6N4f8AEi6vpk15BtXC26y/ JnvnuR7E1yeoD/hAPjRBeKPL0zWhh8cKCxw35Phvxrf8Iv8AEHUNf+2eIFtrLTduGtigyfTaASQf cn8Kr/HG2spPBkU9w4S6huF+zerE/eH0wM/gKAMY/wDFxfjJ2fSdE/FXKn+r/otexVw3wk8M/wBg eDop5lIu9QxcSZHIUj5B+XP413VABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFA BRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQBh60m26Rv7y1Z0R828i/wB1qbrafJE/oSKi0R8T yp2K5oA2qKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKK ACiiigAooooAKKKKACiiigApOlLUczbIXb0UmgDmZW3yyN6sTXTW67LeNfRQK5iMbpEHqRXVDigB aKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAo oooAKKKKACiiigAooooAKKKKACikpaACiiigAooooAKKKKACiiigAooooAKKKKACiiigDlfGfw+0 vxpHG92ZILuIYjuIsbgPQg9RXK2/wNtGnjOpa7fXkCHPlbdufbJJx+FeqUUAQWdpBYWkNraxLFBC gSNFHCqOgqeiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA4/xn8NtL 8ZSx3MzyWl9GNouIQMsOwYd8Vz1l8D7IXkcurazeahFGciEjaD7E5Jx9MV6jRQAyGFIIUiiUJGih VUDgAdBT6KKACiiigArk/F3gODxhqWnz317MlvZHcLZFG2Q5BOT7gAV1lFACKoUAAAAdAKWiigAo oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii igAooooAo6uu6wY/3WBrM0p9l+n+0CK2r1PMs5V/2TXPWr7LqJvRhQB1FFFFABRRRQAUUUUAFFFF ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAVW1Bt ljMf9nFWaoaw22xI/vMBQBk2K776Ef7Wa6Wuf0ld1+nsCa6CgAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigCOeeO2t 5JpnCRRqXdj0UDkmvAPF3xk1fU7+SLQZmsLBDhHUDzJB/eJPT6CvYvHsM8/gXWo7UEytavgDqRjn 9M182eE59Lt/FFhLrkYk05ZP3ykZGMcEjuAcE0Aaen/E3xXp84lXWJ5hnJSfEin8D/SvbvAHxEtP Gts0TILbUoVzLBnIYf3lPp7dqi8S/Dnw/wCLNEDabBaWlwU3W11bIFU+mdvDKa0PBPgXT/BmneXA omvZAPPumHzOfQei+1AHUUVzPjXxta+CLK2uby2muFuJDGoiIBBAz3rH0b4waFqdhfXlysthDaBc +cQWkLZwFAOSeKAO+oryG6/aAtEnK2miTSRA/eknCE/gAf5103hL4r6J4puVtDvsb1/uQzkYc+it 0J9jigDuKKTNV76/tdMs5Lu9njgt4hl5JDgAUAWaK8p1T49aXbTtHpum3F4oOPMdxED9Bgn88UzT /j7p00ypqGk3Fsh6yRyCTH4YFAHrNFUtK1ey1uwjvdNuY7i3k6Oh7+h9D7GrtABRXLeLfiFovg8C O+laa7YZW2hwXx6nsB9a4Zv2gYfN+TQJDH73QB/9BoA9iorh/CvxY0LxPcpaZksbx+EiuMYc+isO Cfriu3oAWiquoajaaVZS3l/cRwW8Qy8jnAFeYal8fNOguGj07Sp7qMHAlkkEYP0GCfzoA9Yr5Z1D xTrya/dRrrWpKi3TqFF0+ANx4xmvYPDnxq0TWruO1v4ZNNlkOFeRg0ZPoW4x+IxXhWokHxHdEEEG 7fBH++aAPriE5gjJ5JUfyqSo4P8Aj3j/AN0fyqSgBDXzdefFnxdDfXEaamAqSMoHkp0B+lfSJr4/ vADrM4IyDcNn/vqgDsbX4z+LbeRWkure4UdVkgXB/LBr1bwD8TbTxkzWc8ItNSRd3lBsrIvcqfb0 qt4n+F3hebw3dzW1lHYXEMDSpPGxABC55BOCK8V8CSzxeOdFa1LCQ3ca/L6E4b9M0AfVtFUNb1RN E0W71KaNpI7WIysidSB2FcRo/wAatE1SedZbW5s4oIGmeWUqRgY4ABySc8UAejUV5r4d+MUXiXxR BpNpo04SdiFmMwyoAyWK46YHrXoN9f22m2ct3ezpBbxDc8jnAUUAWaK8o1T49abb3DR6bpc93Gpx 5skgjB+gwT+eKu+Hvjbour3SW2oW8umyOcLI7B48+7cY/EUAelVFdEi1mIOCEbBH0rzS6+Ouk2t7 NbHTL1zFI0e9WTDYOMjnpXpEsnm6c8gGA0RbH1FAHy/oninXpde0+OTWtSZGuY1ZWunIILDgjNfV FfIWgf8AIxab/wBfUX/oYr68YhQSTgDqTQAtFea6r8cND07Up7SG1urxIm2+dEV2Me+Mnp7113hT xG3inShqK6fcWVu5/deeRmQf3gB2oA3KKzdc1/TvDmnte6pdJBCOBnksfRR1JrzW9+P9lHKVsdGn mjHR5ZghP4AH+dAHrlFeX6N8ddGvrhIdSsrjTwxx5u4SoPrgA/pXpdtcw3ltHcW0qSwyKGR0OQw9 QaAJaKztc12w8O6ZJf6nOIbePv1LHsAO5NeYT/tAWy3JEGhyvADwzzhWP4YP86APYKK5Pwh8RtG8 Ykw2rvb3ijJtpsBiPVT0IrrKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAGsu5SPUYrlWBRyO6musrmb1Nl5Mv+0a AOkjbdGreoBp1VrB/MsYj/s4/KrNABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAVl6437qJfVia1KxdbbM8S+ik0AGiLm4kb0XFb VZWhr8kzepArVoAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKACiiigAooooARgGUggEHqDXgHxO+GM2h3E2r6NCZNMclpYl5NuT7f 3f5V7/UKXFtdNNCkkUrRnZKgYNtJHRh9PWgD5x8AfEq98H3C21xvudKc/PDnmP8A2k/w6GvojStV s9a06G+0+dZreYZV1/kR2PtXjXxW+GUOlW8uv6GgjtgQbm2HRMnG5fbJ5HaqPwR8Rz2Pig6M8jG0 vkYqh6LIozkfUAj8qAOo+P3/ACANK/6+m/8AQa8o8IeFLzxhra6fZkRqF3yysMrGvr7+wr1f4/f8 gDSv+vlv/Qaz/wBn94A2tIdv2giIj12fNn8M4oA2P+FDaD9i8v7ff/acf67K4z/u4/rXkfi/wpe+ Ctd+x3D7gQJIJ04DrnqPQg19V141+0A8ONFT5fP/AHp99vy/1oA7P4XeKJfFHhGOW7YteWreRMx6 uQAQ34gj8c15Z8ZPFk2reJpNIhlIsdPO0qOjy/xE+uOn4Guq+AAb+yNYJ+558ePrtOf6V5H4lV/+ Eq1VZOH+2S5z/vmgD0rwT8IdOvdLh1DxJdsHnUOlrFIF2qem49c+w6Vf8T/BnR306SXw7dmG7jUl YZpgyS+2eoNcWnwi8YyorpaRlWAIIuk5H507/hT/AIz/AOfOP/wKT/GgCP4X+K7jwv4shtZnYWV5 IIJ4yeAxOA31B/Svd/GniEeF/Ct7qYwZY02wqe8h4X9efwrw6D4QeMYriOX7DFlHDZ+0J2P1r0X4 5B/+EEgx0F2m7/vlqAPHfD+i3/jrxQYZLn97MxluLmU/dXuff0Ar2G3+DXg+K1Ec1xcTS45lNyFJ P0HFeMeGvCureKrieDRo0klhQO6tKE4zjv1rof8AhT/jP/nzj/8AApP8aAK3xA8CN4MvYZbS7F1Y Tk+VJuG9GHO1sfoa9g+E3iybxP4W2Xjl72xYQyOerrj5WPvjj8K8nPwd8ZN1soj9blP8a9E+Efgz W/Cd1qZ1iBIY7hIxHtlV8kE56H3oA4j4y+K59W8TSaRE7LZaedpQdHkxyx+mcD8ateAPhCPEWmR6 rrVxLBazcwwxYDuv94k9B6cVxPjUOPG2tCT732yXr/vGvqDw88Mnh3TWtypiNrHs29MbRQB5T4r+ B0Ftpst14dup3liUsbachvMA67WAHPtXj0IIuYweocfzr7HOK+R9ZeJ/FV81vgwteOU29MbzjFAH 1rB/x7x/7o/lUlRwf8e8f+6P5VJQAhr49v2K6rcsOonYj/vo19hGvkC7GdanB6faG/8AQqANfV/i B4k12xNlqGqSPbNw0aqqBh77QM10XwcuvD1n4j83VpXj1Jjssy4HlAkYPPZj0GeK9luPAvhm/twt xolidy9UiCH8xg187eO/D8XhbxfeabayM0EZV4yx5CsAQCfbNAH0T4+/5ELW/wDr0f8AlXzDpGnT avq1rp9sf3t1KsS56cnGTXvo1KXV/gRLd3DFpm011dj1Yrlc/pXkPwuUN8R9GBGcSsf/ABxqAPcP Cnwz0fwjqK31i1xJc+SYmaVgQc4ywGODxXmPxp8Vz6j4ibRIZSLKxxvVTw8pGST9AcfnXv1fKfjw OvjvWxJ977XJ/PigDr/h98I/+El06PVdYuJbezlJ8mKLG+QDjdk9B+Fbfif4F28WnyXHh26uGnjU t9nuCG8zHYMAMGvTPCjwSeE9Ja1K+SbSLbt6fdH9a1qAPjfaVlCsCCGwQeor6+H/ACBx/wBcP/Za +VPErwv4t1NrbHkm8kKY6Y3mvqsf8gcf9cP/AGWgD5N0D/kYtM/6+4v/AEMV6r8WviVuM3h7Q5uB lby4Q/nGp/mfwryKxhlub+3ggbbNLIqI2cYYnAOfrU99Y3Gi6xJa6nbMJreTEsTkjdz6+h9fegDt /hf8OG8T3S6nqkbLpMLcKePtDDsP9n1P4V9BqiQRKqhUjRcADgKBWF4J1/SvEHhy2m0dEhhiURtb DgwED7pH8j3rV1cMdGvdn3vs8mPrtNAHzT458TXXjPxbK8bO9usnkWcXoucD8Sea9H8O/BfQ4bCN 9fvWuLx1BeOKYIkZ9ARyfrXi2n2U2o6hBZ2wBnnkEcYZto3E4HJ6V2f/AAp/xn/z5x/+BSf40Abv jz4S2OmaXLqfh27LrAu6W2lkDHaOpU+3pTfgl4tmtdXPh66lLW1yGe3B/gkAyQPYgH8RWJ/wp/xn /wA+Uf8A4FJ/jWv4P+F3inRvF2mX91ZxJBbzq8jCdCQvfgGgC98f5rn7Zo8JLfZfLkcDsXyAf0x+ dYfw78FeGvFulzx3+qywatvISFWVcL2YAj5vwNe1eLvCVj4w0drG+BVlO6GZR80Teo9vUV8+eKPh 5r/hCUzTwNNaocrd2+So9z3U/WgD0/wJ8If+Ed159S1W4S4e3k/0NY8gf77e/tXqVeHfDL4p366p baJrsxube4YRQ3Dn542PABPcHpzzXuFAC0UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAVgaum2+J/vKDW/WNraYlif1 BFAFrR23WWP7rEVfrJ0NuJk+hrWoAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACsDV23XxH91QK365vUG3X8x9GxQBqaMu2yz/eY mtCqmmLtsIvcZq3QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQByXxKTXD4QuZPD1w8VxF80qxj53j/iCnqD34968C 8JeNdS8H6s95aMJlm4nhlJxKPc+vvX1TXCeJvhDoHiK5e6iEmn3TnLtb42ufUqeM/TFAHnHjL4xX HifQpNLtNOFnFPgTO0u9iAc4HAx0pvwT0Ge/8YjU/Lb7LYIxL44LsCoX8iT+FdhY/ATSIZ1e81O7 uYwcmNVWPP1PJr0jSdIstE0+Oy023S3t4/uog/UnufegDzT4/f8AIA0r/r5b/wBBryLwz4i1Dwrq 8ep6cRvT5HVhlHU9VP5fpXrvx+/5AGlf9fTf+g1hfBTSLHXLTX7HUrZLi3dYco46H5uQex9xQBq/ 8L/tvsmf7Em+07ennDZn64zivLdd1zVPGviD7VcgzXUxEcUMY4UdlUV7Dd/AbQprgvbX99bxn/ln lXx9CRmun8K/DvQvCTCaxgaW7xg3M53P+HYfhQAvw88LHwl4UgspQPtch864IOfnPb8AAK8q+Mvg y407XZNdtYi9jeEGVlGfKk759AeufXNe+0yeCK5geGeNJYpBtZHGQw9CKAPCPBvxom0LS4tO1eze 8hgUJFNG2HCjoCDwcfhWhr/x5eezaLQdPe3nbjz7ghtn0UcE/Wul1f4I+HNQnMto91YEnJSJgyfg G6fnVex+BGg284e7vL26Uf8ALMlUB+uBn9aAJPhh8Q9Y8WzSWmo6errAuXvovlUHsGX1Pt+Vdh4u 8Pp4n8MXulsQrTJmNz/C45U/mKvaXpNjo1ilnp1rHbW6dEjGB9T6n3NW6APlTTdQ1j4e+KjKIjDe 2xKSRSD5XU9QfUHqD9K9Rg+P2nG3U3Gj3azY5VJFK59icH9K77xJ4N0bxXEq6tZrI6DCTIdsi/Rh 29q4eT4BaO0hMeq3yoTwpVDj8cUActcfHPXpNaE9ra2yWQ+UWjLuLe5brn6ce1e3aHf3GqaPbXl1 ZSWM0ybmgkbLJ9a53w38LPDvhqdLmK3e7u05Wa5O4qfUDGB+VdjQB4P8afB01lrJ8QWkRa0u8C4K jPlyDjJ9ARj8c1neBPizd+E7MadfW5vbBcmIB9rxewPce1fQs9vFcwPDPGksUg2ujjIYehFed6t8 DvD1/cmazmurAMcmOMhk/AHkfnQByXir433Gq6bJZaNYtZecpSSeR9zgHqFA6fWvLYRi5jB6hx/O vo7w78IvDvh+4S5aOW+uYzuR7kgqp9lHH55qOb4NeF57p7h0vfMdzIcT8ZJz6UAd1B/x7x/7o/lU lNRdiKo6AYp1ACGvj6+bZq1yw6idj/48a+wTXAy/BbwrNM8rpe7nYsf3/c/hQB55L8dfETQ7IrXT 4mxgMI2JH5muIZtU8XeIcnzLzUb2TsOSf6AfoK93HwS8Jgg+Xen2Nx/9aum8P+DtE8MK39k2EcLt 96U/M5/4EecUAYusaMPD/wAHrzTAwY22nMjMOhbGSfzJrxX4W/8AJSNH/wCujf8AoDV9KarpsGsa Xc6fdbvIuYzHJtODg+hrl9F+FPh3QNXt9SsVuxcW7Fk3zZGSCORj3oA7OvDfjZ4Png1QeIrSMvbT qqXO0f6twMBj7EY/Ee9e51HNDHPE8UsayRuNrKwyGHoRQB87eA/ireeEbX7BdwG908EmNN214ieu 0+ntW14m+OU+o6bJaaJYtZtKpV55XDMoP90Dofeur1f4IeHtRuTNZy3On7jkxxEMn4A9Pzq54e+D /h3QblLmRJb+4jbcjXJBVT/ujj880AfOIz5gznOe9fX4/wCQOP8Arh/7LXGXPwa8L3V1LcSJeeZK 5kbE+BknJ7V3Pkr9m8nnZt2decYxQB8j6B/yMWm/9fUX/oYr6F+I/wAPYPGGnm4tQkWrQL+6k6CQ f3G/oe1Q2vwa8L2l1DcRJe+ZC6yLmfuDkdq72gD5X8NeItU8BeI2lWN0eNvLurWTjeAeVPv6Gvpb QdesfEujw6hp8gkglHIPVD3Vh6isfxJ8ONA8VX63uowSLcBdpeF9hcds+tTeGPAml+EZ5ZNJkvFW YYeOSbcjehxjr70AeD/ELwhdeDvEsjxI62M0hltJl6DnO3PZhXZ6D8ePIsEh1zTpJ50GPPt2A3+5 U9D9DXr+paZZ6vZPZ6hbR3FvJ96OQZH19jXnmofAnQLmcvaXd7aKf+WYYOB9MjP60Acz4i+Ot9dB I/D9oLJQQWlnw7t7Y6Afn+FegfDjxnqPjHS5bi/0z7MIiFFwh/dzHvtB5479RWXpXwQ8OWE4lu5L q/IOQkrBU/EKMn869Dt7aG0t44LeJIoYxtREXCqPQCgDzL4t/EG/8OyQ6TpIkt7mVRK90V4C5+6u evTn8qyLT48Rvo7Q6ro3nXRQoxjcCKTjuDyAe45r1TX/AA1pfiay+y6taJPGOVboyH1VhyK4Cb4B 6M8xaLU7+OMnhCEYj8cUAeR+FNNuNb8Yafb2UeHe5WQhRxGobJP0AFfV9c94V8D6N4PicaZA3nSD Ek8p3Ow9M9h7CuioAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigA ooooAKKKKACiiigAooooAKKKKACiiigAooooAKzdbTNsjejVpVU1RN9hJ7YNAGboz7bxl/vLW7XO ac2y/i9ziujoAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigAooooAKKKKAErl523zyt6sTXTSHbGx9ATXLKN7AdyaAOntl2W0a+iipaRRhQPSloA KKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAo oooAKKKKACiiigAooooAKKKKACiiigDgPiz4T1TxbpVhb6REkkkM5dw8gTA2471T+EfgvWPCMmpn WII4xcCPy9kofON2en1Fel0lAC0UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRR QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFA BRRRQAVFcp5ltIvqpqWkIyMUActCxSaNvRga6muVkXZI6/3WIrp4H8yCNvVQaAJKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAIL1t llMf9k1z9ou+7hX1YVtas23T39yB+tZWmLu1CL2yf0oA6KiiigAooooAKKKKACiiigAooooAKKKK ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAo oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA5u/T ZfTD1bP51taa2+wiPoMVl6wm2+z/AHlBq7or5tGX+6xoA0aKKKACiiigAooooAKKKKACiiigAooo oAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAM7WmxaKvq9Z2nTx29z5kp wNpA4q3rjf6lfqaoW9pLc7vKXO3rzigDZ/ta1/vn/vk0f2ta/wB9v++TWX/ZV3/zzH/fQo/sq7/5 5j/voUAan9rWv99v++TR/a1r/fb/AL5NZf8AZV3/AHF/76FL/ZV3/cX/AL6FAGl/a9r/AH2/75NH 9r2v99v++TWb/ZN1/cX/AL6FH9k3f9xf++hQBpf2va/3m/75NH9r2v8Aeb/vk1m/2Td/3F/76FH9 k3f9xf8AvoUAaX9r2v8Aeb/vmj+17X+83/fJrN/sm6/uL/31R/ZN1/cX/vqgDS/te1/vN/3yaP7X tf7zf981m/2Tdf3F/wC+qP7Juv7q/wDfVAGl/a9r/eb/AL5o/te1/vN/3zWb/ZN1/dT/AL6o/sm6 /up/31QBpf2va/3m/wC+aP7Xtf7zf981nf2Rdf3V/wC+qP7Iuv7q/wDfVAGj/a9r/eb/AL5o/te1 /vN/3zWd/ZF1/dT/AL6o/si7/up/31QBo/2va/3m/wC+aP7YtfV/++azv7Iuv7qf99Uf2Rdf3U/7 6oA0f7YtfV/++aP7YtfVv++azv7Iuv7qf99Uf2Rdf3U/76oA0f7YtfV/++aP7YtfV/8Avms7+yLr 0T/vqj+yLr0T/vqgDR/ti19X/wC+aP7YtfV/++azv7IuvRP++qP7IuvRP++qAND+2LX1f/vmj+2L X1f/AL5rP/si69E/76o/si69E/76oA0P7YtfV/8Avmj+2bX1f/vms/8Asi69E/76o/se69E/76oA 0P7ZtfV/++aP7ZtfV/8Avms/+x7r0T/vql/se69E/wC+qAL/APbFr6v/AN80f2za+r/981Q/se69 E/76o/se6/2P++qAL/8AbNr/ALf/AHzR/bFr/t/981Q/se5/2P8Avqj+x7r/AGP++qAL/wDbNr/t /wDfNH9s2vq//fNUP7Huf9j/AL6o/se5/wBj/vqgC/8A2za/9NP++aT+2bX/AKaf981R/se5/wBj /vqj+x7n/Y/76oAv/wBs23/TT/vmk/tm2/6af981R/se5/2P++qP7Huf9j86AL39s23pJ/3zR/bN t6Sf981R/se5/wBj86P7HufVPzoAvf2zbekn/fNH9s23pJ/3zVL+xrn1T86P7GufVPzoAu/2zbek n5Uf2zbekn5VS/sa59Y/zo/sa59Y/wA6ALv9s23pJ+VH9tW3pJ+VUv7GufWP86P7GufWP86ALv8A bVt6SflR/bVv6SflVL+xrn1j/Oj+xrn1j/OgC7/bVv6SflR/bVv6SflVL+xrn1j/ADo/sa59Y/zo Au/21b/3ZPypP7at/wC7J+VU/wCxrj+9H+dH9jXH96P86ALn9tW/92T8qX+2rf8AuyflVL+xrj+9 H+dH9jXH96P86ALn9tW/92T8qP7at/7sn5VT/sa4/vR/nR/Y1x/ej/OgC5/bVv8A3ZPyo/tq3/uy flVP+xrj+9H+dL/Y1x/ej/OgC3/bVv8A3ZPyo/tq3/uyflVT+xbj+9H+dH9i3H96P86ALf8AbVv/ AHZPyo/tq3/uSfkKqf2Lcf3o/wA6P7FuP70f5mgC3/bUH9yT8hR/bUH9yT8hVT+xbj+9H+Zo/sW4 /vR/maALX9twf3JPyFH9twf3JPyFVf7FuP78f50f2Lcf34/zNAFr+24P7kn5Cj+24P7kn5D/ABqr /Ytx/fj/ADNH9iz/AN+P9aALX9twf3JPyH+NH9twf885PyFVf7Fn/vx/rR/Ys/8Afj/WgC1/bcH/ ADzk/IUf23B/zzk/IVV/sWf+/H+tH9iz/wB+P9aALX9twf8APOT8hR/bcH/POT8hVX+xZ/78f60f 2LP/AH4/1oAtf23D/wA85P0o/tuH/nnJ+lVv7Fn/AL8f60f2LP8A34/1oAs/23D/AM85P0pP7bh/ 55yfpVf+xZ/+ekf60f2LP/z0j/WgCx/bcP8Azzk/Sj+24f8AnnJ+lV/7Fn/56R/rR/Ys/wDz0j/W gCx/bcP/ADyk/Sj+24f+eUn6VX/sWb/npH+tH9iTf89I/wBaALH9txf883/Sj+24v+eT/pVf+xJv +eifrR/Ys3/PRP1oAsf23F/zyf8ASj+24v8Ank/6VX/sSb/npH+tH9iTf89I/wBaALH9txf88n/S j+24v+eT/pVf+xJv+ekf60f2JN/z0T9aALH9txf88n/Sj+24/wDnk/5iq/8AYk3/AD0T9aX+xJv+ ekf60ATf25H/AM8n/MUf25H/AM8n/MVD/Yk3/PSP9aP7Em/56p+tAE39uR/88n/MUf25H/zyf8xU P9iTf89U/Wj+xJv+eqfrQBN/bkf/ADxf8xR/bkf/ADyf8xUP9iTf89U/Wj+xJv8Anqn60ATf25H/ AM8X/MUf25H/AM8W/MVD/Ykv/PVPyNH9iS/89U/I0ATf25H/AM8W/Oj+3E/54t+dQ/2JL/z1T8jR /Ykv/PVPyNAE39uJ/wA8W/Oj+3E/54t+dQ/2JL/z1T8jR/Ykv/PVPyNAE39uJ/zxb86P7cT/AJ4t +dQ/2JL/AM9U/I0f2JL/AM9U/I0AS/24n/PFvzo/txP+eLfnUX9iS/8APVPyNL/Ykn/PVPyoAk/t xP8Ani3/AH1R/bif88G/76qP+xJP+eqfkaP7Dk/56p+RoAk/txP+eDf99Uf24v8Azwb/AL6qP+xJ P+eqfkaP7Ek/57L+RoAk/txf+eDf99Uf24v/ADwb/vqo/wCw5P8Ansv5Uf2JJ/z2X8qAJP7cX/ng 3/fVH9uL/wA8G/76qP8AsR/+ey/lR/Yj/wDPZfyoAk/txf8Ang3/AH1R/bi/88G/76qP+xH/AOey /wDfNH9iP/z2X8qAJP7cX/ng3/fVH9uL/wA8D/31Uf8AYb/89l/75o/sR/8Ansv/AHzQBJ/bi/8A PA/99Un9uL/zwP8A31TP7Ef/AJ7L/wB80f2G/wDz2X/vmgCrfXgvHRghXaMcnOauaG/+uT6Gq13p rWkPmGQMM4wBT9GbF4V/vKaAN2iiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii igAooooAKKKKACiiigAooooAKKKKACiiigDE1ps3KL6LVjRFxBI3q1UtVbdfv7ACtHR1xYg/3mJo Av0UUUAFFFFABRRRQAUUUUAFFFFABRRRQAVFLPHDjzHAJ6VLVWFQ13OWGSMAZoAd9ut/+en6Ufbr f/np+lT7R6D8qNo9B+VAEH263/56D8qPt1v/AM9B+VT7R6D8qNo9B+VAEH263/56D8qPt1v/AM9B +VT7R6D8qNo9B+VAEH263/56D8qPt1v/AM9B+VT7R6D8qNo9B+VAEH263/56D8qPt1v/AM9B+VT7 R6D8qNo9B+VAEH263/56D8qPt1v/AM9B+VT7R6D8qNo9B+VAEH263/56D8qPt1v/AM9B+VT7R6D8 qNo9B+VAEH263/56D8qPt1v/AM9B+VT7R6D8qNo9B+VAEH263/56D8qPt1v/AM9B+VT7R6D8qNo9 B+VAEH263/56D8qPt1v/AM9B+VT7R6D8qNo9B+VAEH263/56D8qPt1v/AM9B+VT7R6D8qNo9B+VA EH263/56D8qPt1v/AM9B+VT7R6D8qNo9B+VAEH263/56D8qPt1v/AM9B+VT7R6D8qNo9B+VAEH26 3/56D8qPt1v/AM9B+VT7R6D8qNo9B+VAEH263/56D8qPt1v/AM9B+VT7R6D8qNo9B+VAEH263/56 D8qPt1v/AM9B+VT7R6D8qNo9B+VAEH263/56D8qPt1v/AM9B+VT7R6D8qNo9B+VAEH263/56D8qP t1v/AM9B+VT7R6D8qNo9B+VAEH263/56D8qPt1v/AM9B+VT7R6D8qNo9B+VAEH263/56D8qPt1v/ AM9B+VT7R6D8qNo9B+VAEH263/56fpR9ut/+eg/Kp9o9B+VG0eg/KgCD7db/APPQflR9ut/+eg/K p9o9B+VG0eg/KgCD7db/APPQflR9ut/+eg/Kp9o9B+VG0eg/KgCD7db/APPQflR9ut/+eg/Kp9o9 B+VG0eg/KgCD7db/APPQflR9ut/+eg/Kp9o9B+VG0eg/KgCD7db/APPQflR9ut/+eg/Kp9o9B+VG 0eg/KgCD7db/APPQflR9ut/+eg/Kp9o9B+VG0eg/KgCD7db/APPQflR9ut/+eg/Kp9o9B+VG0eg/ KgCD7db/APPQflR9ut/+eg/Kp9o9B+VG0eg/KgCD7db/APPQflR9ut/+eg/Kp9o9B+VG0eg/KgCD 7db/APPQflR9ut/+eg/Kp9o9B+VG0eg/KgCD7db/APPQflR9ut/+eg/Kp9o9B+VG0eg/KgCD7db/ APPQflR9ut/+eg/Kp9o9B+VG0eg/KgCD7db/APPQflR9ut/+eg/Kp9o9B+VG0eg/KgCD7db/APPQ flR9ut/+eg/Kp9o9B+VG0eg/KgCD7db/APPQflR9ut/+eg/Kp9o9B+VG0eg/KgCD7db/APPQflR9 ut/+eg/Kp9o9B+VG0eg/KgCD7db/APPT9KPt1v8A89P0qfaPQflRtHoPyoAg+3W//PQflR9ut/8A noPyqfaPQflRtHoPyoAg+3W//PQflR9ut/8AnoPyqfaPQflRtHoPyoAg+3W//PQflR9ut/8AnoPy qfaPQflRtHoPyoAg+3W//PQflR9ut/8AnoPyqfaPQflRtHoPyoAg+3W//PQflR9ut/8AnoPyqfaP QflRtHoPyoAg+3W//PQflR9ut/8AnoPyqfaPQflRtHoPyoAg+3W//PQflR9ut/8AnoPyqfaPQflR tHoPyoAg+3W//PQflR9ut/8AnoPyqfaPQflRtHoPyoAg+3W//PQflR9ug/56fpU+0eg/KjaPQflQ A2OZJhmNgRT6qgBdRG0Y3Jz+dWqACiiigAooooAKKKKACiiigAooooAKKKKACiiigCpqi7tPk9sG sbTn2X8R9Tit+5XfbSL6qa5qFtk8bejCgDqqKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAoqulyXu5YNmPLVTuz1zU9AC0UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAc1ftuvpj/tYrb0 5dthEP8AZzXPzNumkb1Ymultl2W0a+iigCWiiigAooooAKKKKACiiigAooooAKKKKACq1v8A8fNx 9R/KrNVrf/j5uPqP5UAWapzanawahBYyShbmcFo0x1A61crjL/StYvby71OGGFHSVWt0kz5u2PoF 7Ddz19aAOy3D1FQWd7He2yzxh1RiQBIpU8HHQ1g/2Zdza5GNjppszreyBjysoGNn4nB/Cs6PTblI LQ6np91d2yxyqIIz8ySFyQxGR1GMHtQB2xYDqRUEV5HLdz26q4eDbuJUhTkZGD3rk/7Bu7kRLqUM szRaa6qd5OJd3yjOeWA70h03U3t5DLBcPGRamaINhpVVMOoOeucZ9aAOz3DGcjHrmoL6/g061a4u WKxggcDJJPAAA6muZ1HT0n8PGOy02+tx9o3rBjdkgdSu77p9M+9al7E8nhmOO606SZjGgkt4X+ZO mSpPUigC3DrdpcNahGcG63+WGQqfl+9nPTFXywHORiuQh0y81RtKXVbeaWGJ5wTLw2zHyb8dzVGX SNSNpp4uYbl4IoZE8sR+aVbccEqWH8OMHtQB1l/rtnpzzJcM+6GNZGCrnIZtox6nNaCPvRWwRkZw RgiuIvdBvJY1jlgmuQtvbrucDJIkyQcHqFNduiqiKqjCqMAegoAdRRRQAUUUUAFFFFABRRRQAUUU UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAVj/wAhFf8Arn/WrNVm/wCQiv8A1z/rVmgA ooooAKKKKACiiigAooooAKKKKACiiigAooooAQjIx61ysilJGXuCRXV1zV8u2+mH+1mgDoYW3wo3 qoNSVV0599hEfQYq1QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAUYM/2vdemxP61dqlASdW u/TYn9au0ALRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABTZDtjY+gNOqC8bZZzH/YNAHNKNzgeprqw MACuYtl3XUS+riuooAKKKKACiiigAooooAKKKKACiiigAooooAKrW/8Ax83H1H8qs1Wt/wDj5uPq P5UAWaKKKAEpaKKAEopaKAEpaKKAEpaKKAEpaKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKACsnxN4gtvC+hXGqXas6RYAROrsTgKPxrWrhPjF/yIjf9fUP/AKFQBz3/AAtXxM/z JounIp5CvMxYfWj/AIWl4o/6A+l/9/Xrn6KAOg/4Wl4o/wCgPpf/AH9ej/haXij/AKA+l/8Af165 +igDoP8AhaXij/oD6X/39ej/AIWl4o/6A+l/9/Xrn6KAOg/4Wl4o/wCgPpf/AH9ej/haXij/AKA+ l/8Af165+igDoP8AhaXij/oD6X/39ej/AIWl4o/6A+l/9/Xrn6KAOg/4Wl4o/wCgPpf/AH9ej/ha Xij/AKA+l/8Af165+igDoP8AhaXij/oD6X/39ej/AIWl4o/6A+l/9/Xrn6KAOg/4Wl4o/wCgPpf/ AH9ej/haXij/AKA+l/8Af165+igDoP8Ahafij/oD6Z/39ej/AIWn4o/6BGl/9/Xrn6KAOg/4Wl4o /wCgPpf/AH9ej/haXij/AKA+l/8Af165+igDoP8AhaXij/oD6X/39ej/AIWl4o/6A+l/9/Xrn6KA Og/4Wl4o/wCgPpf/AH9ej/haXij/AKA+l/8Af165+igDoP8AhaXij/oD6X/39ej/AIWl4o/6A+l/ 9/Xrn6KAOg/4Wl4o/wCgPpf/AH9ej/haXij/AKA+l/8Af165+igDoP8AhaXij/oD6X/39ej/AIWl 4o/6A+l/9/Xrn6KAOg/4Wl4o/wCgPpf/AH9ej/haXij/AKA+l/8Af165+igDoP8AhaXij/oD6X/3 9euy8D+NR4tguY57X7Jf2bATw7ty4PRlPocV5bXSfCX/AJG3xB/1wg/rQB6xRRRQAUUUUAFFFFAB RRRQAUUUUAFFFFABRRRQAUUySVIULyuqIvVmOAPxprXMClw00YKLuYFh8o9T6CgCWioorqC4eRYZ o5GjIDhGBKkjIzjpxRBcwXUfmW80cqZK7o2DDI4IyKAJaKSmySxwoXldUQdWY4A/GgB9FME0Zk8s SL5m3dtzzj1x6U7IoAWikzRmgBaKTNGaAFooooArN/yEV/65/wBas1Wb/kIr/wBc/wCtWaACiiig AooooAKKKKACiiigAoopKAFopKWgAooooAKwNXTbfk/3lBrfrG1tcSxN6qRQBZ0Zt1lj+6xFaFZO hv8ALMnoQa1qACiiigAooooAKKKKACiiigAooooAKKKKACiiigDPt/8AkNXvB+5H9O9X6z7fH9tX o77I/wCtaAoAWiiigAooooAKKKKACiiigAooooAKKKKACqmqNt0+T3wP1q3WfrLYsgP7zigDM01d 1/F7En9K6OsDSFzfA+imt+gAooooAKKKKACiiigAooooAKKKKACiiigAqtb/APHzcfUfyqzVa3/4 +bj6j+VAFmiiigAooooAKKKKACkzQa8k8Z3usWfiDU9G024uBLPJHqkLB2wkSRsZF+hZBx70Aet5 ozXlNhrc2pw2GuOZWXUNbdoEaRgI40hIUAA4IypyOlOHirUytlrt2lubp9Fub2JIi4RQNuFK5wT7 0AeqUV51J461zTLe8GoQafJcfZLe5t2i3LGnnOEw5J6AnJNbXhzXNWuPE+oaPq0lhMbW2imWW0DA MWJ6gk46UAdXmivJdX1fXIrHxRHbwM1kurhTefa9rwDfH8qp1xz2Pc1s6x4z1yGPV9QsBpkdjpt5 9jME+4zOwZQW4OBndwO4oA9Corz/AFDxjrkK6rNbJYlLbVI9Nt0dGyxYrlmOemG7VDc+O9bsoJrG W2tptUXU/sKywRs0ePLD7tmck4OMZoA9Gorzu88aeI7bw+t2+nxQPDdNHc3EsLbfKC58wRg7sdm5 O3rWpZeKb+fxsunXP2SPT7iLfZuqsxufkDEq+cA8/dIBxzQB2FFJS0AFFFFABRRRQAUUUUAFFFFA BRRSZoAWuE+MX/IiN/19Q/8AoVd1XC/GL/kRG/6+of8A0KgDz6iiigAooooAKKKKACiiigAooooA KKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigArpPhL/wAjb4g/64Qf 1rm66T4S/wDI2+IP+uEH9aAPWKKKKACiiigAooooAKKKKACiiigAooooAKKKKAM7xBpq6x4f1Cwc ZFxbvGPYkcH88V4gk+ranFDqMgIHiErozqOihPLBb8dsn617lq+r2eiWDXmoTeVApC52liWPAAA5 JPpVew1jSdQ0Y6laOjWcO52byyDGVzuyuMgjntmgDhHvLyLxjcabYXX2GOfWEt3eCNAxjFsGxkjn p1NVtJvdTuv7O06x1JtOimOoyytbxJljHL8vUY+pr0BPEWhS3ESpdQGWW1+3odvJix9/OPT8ak0z WNL1S4MdiNzLCk4bySoKSDIIJHegDzweLtSu7PT5dR15tJRtKFzFKkKkXc+WBHIOcAD5Ryc1qavf XGp/A37ZeS+Zcz2kTvIwHLF15Irpta8Iafrksck015blYzHttZzGrL6EDj8RzWra2FrZafDZQQot tCgjSPGQFHQUAeZ6jd6/oviLVruae1utRj0NDE9tbsoRDOAWKkkkqMt+FQXfim9s11hNL8UvqsVv piXEc5RP3cplVTyBg8Hp2zivQLrxXoVnr6aXPdIt85WM4jJCluVVmxgE9gTUdl4j8O3esSaPayQG 6UsmwQ4R2XllDYwSO4FAHH65f69Y3GuLba/cqujafBcqGjQ+c7bid3HQ46CoNU8VeIZPEd1HBfQW TwyRLaW0syRpMGUHJVlLOGJIypGK9Gj1TS7nVbzTUlhe9t41e4i28hT0zxz/APXqrB4h0G+uNM8q 4gkmvldrMmM7mC/ewSOMfhQBx8/iXU4fFWuWb63EhFrK9uFCtDaFVX/WjG5SCTzyGz+FdH8PdWl1 fw35lxcy3U0U7xPLIVYMRj7rKAGXng/4VYufFfh6002LVJLmMw3hMcTJEWecqSCAoG5uhq5oGt6X rdmz6RKrRwtseMRmMxt1wVIBFAGrRRRQBWb/AJCK/wDXP+tWarN/yEV/65/1qzQAUUUUAFFFFABR RRQAUyR1jRndgqqMsxOAB60+vOPjPrc1j4ct9NtnKSajIVkYH/lmoyw/HgfnQNK7sjP8R/GGQXEl v4atoZIkypvbjOwn/ZXjI9zXM2vxZ8UpcAm/sbnB5ie3CqfoRg1xioPskc05Lg8JEvAp8qyLEDcW 8flf7HVa53Udz2IYGmormXS/X9NvxPd/BnxItPE8wsLuH7DqgGRETlJR3KH+ldqDmvlNnubC6tpb SdhJEfNhf+JCvI5r6c8P6n/bXh+w1HGDcwJIQOxI5/WtYS5lc87FUPY1HE0aKKKs5wrM1tcwRt6N itOqWrLusGP90g0AUdFbF06/3lrbrndLbbfx++RXRUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFAGfp+kwaYZTAZmaTG5pZWkPHTkmr4paKACiiigAooooAKKKKACiiigAooooAKKKKACsrXG/dR L6sTWrWNrbZliX0BNACaIuZ5W9FxW1WToa/LM3uBWtQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA VWt/+Pm4+o/lVmq1v/x83H1H8qALNFFFABRRRQAUUUUAFYUN34c1XxFKIZ7K41a3iaFwrAyKhPzL 9M9a3DkA4GT6V5B4KSZfF2lf695o3vPtFi1qUXTg5LZ8zHz5IA5J68UAd+9r4Y0+zFpILKCDSCJf LZ8C2L5wx54zk9fWorq38J2saWtyLJFhgW0WMtykUpwqY9Gx+lcz480G61LxlaWVukn2LXIVhvJE B+QQsXBJ7ZBA5rN0OHWP+EdfUbyOZL241aztmAQ7jFCVTJGOh+Y0Aeh6p4Xsr+zuYoVW1nntha+e sYciMHIUq2QR7VQ8H+CIfCs91cees1xcKsZ8uERIqrnACjPPPJJrj7qTXYvC9hc/a79UutRmF9JI 8uY41ZxGvygsqHA5UelM1C71q38KadPJqt9Ni7kaGK3SdXuI+NqFyu7cDnaWGGHWgD0HVbPw/pul Xr6oltBZXMwmuTKcLJJkYJ9TlR+VZesW/gW4EOt6t/ZbC7wI7l3GJcdOh5I9e1TeNNUs9M0K2vrr TJb67jdZLSDy2crLt4ZsdMZOT+XNcbPc6dpPhOwhtYWvdUuxNGbx7KXy7UStmVtm3OMnAGOcelAH oN3Y+H7e1Mt4lpHb3V2lxvd8LJOcbGBzyTgYqPUNP8NONQtdQjs8yAXt2kjYOBwJTzkYxjIriNe0 u412DS9E0Oxm1DTNO08NvlkNtmRlKxtlhyVALYx3FQa5Fqeu2OgTC3mS8v420XUgUI2DepZj7fKx z05oA7g6F4TvbO00z7LYSwJGbu3hDZ+Q9ZBzkg55PeotMufBlz4mefTZtMfWNuwmJxvIAwdvY8DH FcVonh/WbjRPFNt5cq3VpbjSrLdlTJEjMxAP+0CBmtKPXvtur6HZeHNJs/LhZFktrmwkSWxxw7bi AowOBgkk0AemClpBS0AFFFFABRRRQAUUUUAFFFFABVBBJeXM+ZZEiify1VDgk4BJJ/Gr9UrJgr3p Y4AnJJ/4CtAEc/2W2YC41B4ieQJLjbn864j4uM0PhDyfNaWKaeJ0LHJBDjPPcHIqj4ibTrjxXd6l 9p8KX0FzDEIl1K4O5AoPK4BABz+lWfi3j/hDbDaIwMx4Ef3fvJ09vSgDkKKKKACiiigAooooAKKv aNot3rl59ns1XKjczscKo96ua54Tv9ChWecxzW7Hb5kR4B9CKAMWiiigAooooAKKKKACiitO80Ce y0O01R5Y2iujhUGdw69fyoAzKKfbwNc3MUCEBpXCKT0yTiukufh9rNvC0i+RNtGdiOdx+mRQBzFF BBBIIII4IPaigAoorT0PQZ9eluEt5Y4zAm9t+eR+FAGZRSUtABRRRQAUUUUAFFFFABRRRQAV0Hwt guZPE+vvBIsSCKBWYruPc4A6Vz9dZ8JP+Q34i+lv/wCgtQB6J9muv+f6T/v2n+FML3NpcQiWbzop n8vlArIcEg8dRxiuX8a2Wo3mt6e0NneX2mxwyCaC2vxbfvCRtJO4E4GeK19Ni8jRdLj+yzWuJx+5 mn8515bq+Tn86AN+loooAKKKKACiiigAooooAKKKKACiiigDkviNa3N3oNstvDcyRx3sUs7Wi7p4 o1JO+Mf3gcfhmmfD6ynj0C9ivIblbee8leFrxds80bdWkH94kn8MV19GKAPDJ/BniFdKnnitbn7X b3H9lQKEOWsyrKWx6fMOfaum17QNQk1ua0htrx9PMmmxAxbgpjUsJMEdABjNem4qnql9/Z1n5ojM js6xxoDjc7EKoz2GT1oA8y1Dw/rD+LrpSb6GQ3Sf2fcQ2zypDCMbcOHCqBgggjn3zW54es7y1+I2 qyG0v5LadXZ7q5VkCNkYVDna6nnGACtdHLq1zpRY6wsHleU8oktgxxsGWUqeTx0I646Us/ie1t4m lktr0RxqDMwhyIs9A3PXBB4zjIzigDldfnlvvF8FgdC1GPSorhLi5ubeyLfa5lxsyw/gXglvbFNt LyW88aLPc6Bqdnp+nGU2EUdiwSSRgd8rsOATyAPfPWuvj8SWTyMGWeOJTIPOkjwhKZ3AHrxg9ucU xvFFlErm5jurYrH5oE0W3euQoxz1JIGOvrigDg9J0fxLpur6f4kutOhL3Fy7Xiwl2uTHMQNrpjGE wvQ8YNZeoeENegn1m9sbe4MmkXH/ABKVVDl0kdmfb64D9q9b0zVrbVo5Dbkh4m2yRsRuQ4yM4JHI 9DV7FAHn76Xc+FrnQNQjsJ7y0s9MNjKlvHvkt3OD5gTvnBBxzWn4Gl166k1C61h3No7qLXzrRbeV 8D5mZRyOwGfSutxS0AFFFFAFZv8AkIr/ANc/61Zqs3/IRX/rn/WrNABRRRQAUUUUAFFFFABXlfxw spPsGlakqkxW8rxSY7bxwfzFep15v8bZ3HhqwswxEd1eqJMdwFJx+ePypPYunfnXLueNRkTWcKxk edCQ2w8ZqSWeS5iMSQOhbhi3QVHJEYxtuI2kUfdlT7w+tM8xH+WSaeVR0QLg/jXJZPVH0fPOC5Ja XVn8v66XFup40kiEbb/LRlJHrjAr6U8GWEmmeDdJtJgRJFapvB7EjJH6181zRzLB56gQCEh41Xrk Hqa+p9Pna6062nf70sKOfqQDW9K1tDycx5/aJyVr7fl+hZooorU88KgvV32cw/2TU9NddyMvqCKA OatH2XcLejCunrk/uN/umuqQ7lB9RQA6iiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKK KKACiiigAooooAKKKKACiiigAooooAKwdYbN6B6IK3q53VG3ahJ7YH6UAaOiri0Y+rmtGqWlLtsE 9yT+tXaACiiigAooooAKKKKACiiigAooooAKKKKACq1v/wAfNx9R/KrNVrf/AI+bj6j+VAFmiiig AooooAKKKKACkxS0UAJiilpDQBlTa04uJltLGa6it22zyRso2nGSFBOWI70//hINL2O322LCKrvz yobpn3OenWmf2Zd20lyLC5ijiuXMjCSMs0bH7xXkdeuD3qCLw59kiAs5lV451nj8xMjiPy8Nzzxn ntQBYPiXR1iEn9oQbSSOGyeMZ468ZGfTNS3Ou6bZyKlxewxll3jLcbexz0Ge3rVGw8OyW2pz309x HJJMZSVWLaF3hBxz22fjms290XUIrC50yzTelzHGhlaNSuQoUnO7IGF6YPtQB0i6pZPfNZrcIbhe qf0z0z7Vb61gWvhhLbUFmDo8SXDXC7gxfc2T/e29Sece1b9ABijFLRQAUUUUAFFFFABRRRQAUUUU AFFFFABWfblguoGMbnEzbQe52ritCqNo4j+3Oc4WdicdfurQB51oA8S6dctJq3hq+1KOWBd6ym3O ybJz5fIwmMACrHxhO7wnZkxmIl0Pln+H5k449KQ/Fa6uElks9LswkNsb1vNvhuMIONuAOJP9k0fF 6cXXhCxnUFVlZHAPUAshoA4+iiigAooooAKKKKAN/wAH67DouoSpeD/RbpdkjDqnofpzU3irQrnS bVHtbqS40d23RfPkRk+v9DVXw1HotxJcW+tFo2kXEM27Cof8frWxrN3puj+EJNFs7/7fLK+QRghB kHtwOlAFi8s/D2jaHpl7eaf5000a4jRiPMO0Elqo6tpmlap4ZfW9GgNq0DbZoO3b/EHitrV7PTL7 w3osGpXZs3MQMMuMrnaMg1j6vf6Xo/hiTRNKuPtclw26eYdPf+QGKAL1n4ZttJ0q2mm0ebVryddz KD8kYPaqXibw1BHpEeq2NnLZNuCy2sh6ZOAR+NXINbtte021R9bm0m9t02OA2Ek96x/El7FFFFb2 eu3moNwZt7Zj45H69qAN2Pw1a6LZwK+iTavdSLulYEbE9hmsvxR4Zht7S11DT7eW1WeQRPbS9Y2P T9a0jrVr4itoJV16bSLqNNssW7Ct7isLxFfxxSwRWOs3moCNleTzWzHuHIIoA1dRt/DvhVIbG809 r+7dA0rk4K59PTv0p/i77L/whWlfYCxtfMHl7uoGDwaTUToHi1Yb+fUhp9yiBZkcDJx6Z/HkVX8U 6hpUvhbT7PS7pZBC4whPzgYPJFAHM6R/yGbH/r4j/wDQhXqRtoI/F010uohrowBVsS+3PHBP/wCq vK9NkSLVbOSRgqJOjMx6ABhmu+vZfDUviBNbl1hWkiClYo2yCQOOnNAGV4c0a31DVNbXWrUCSLLF c/6skknFQ6Ppum+JNXuLpbX7HpdnEC0Snlzz1P4Vd0jxJZXGra9eXE0dutzGFhWQ4LAAgfjWN4P1 y30m5nt78H7JdpskYDO0+v05NAGxpc3hXXNXis00prc5PlNnAlx2YCrXhm1jtfFniC2towkaJtRB 29qr6VY+GtC1iG7/ALZWfk+UvGEyOrEUaPrNhB4r125kvIkhnX91IW4f6UAU5dJ0/wAMaJ5urwJd ancjMUDE4jHvj9fyp3hnw7by6M+r3lnLfMzlYbWLgHBxk0kOr2HibRzZa7OlvfQDMF2/G76/1p2g 6zbf2O+iXeovYyRSEw3cLfKec4z6UAXL3wzbarpFzPBpE2k3duu5UY/LIBzjimaHpGlp4Yt75tMb VJJSfP2HLReuB7e3NVdXuYbDTXWLxRe3t23CpG2UI9D6fnTvCq6ZaW8F3Hrz2dwrZuYHwFcemD/O gDldQNsdQn+wxyR2+47EkPzAe9V61PE19bal4gurmzXELkYOMbiBgn8ay6ACiiigAooooAK6z4Sf 8hvxF9Lf/wBBauTrrPhJ/wAhvxF9Lf8A9BagCle3VrL4yuP7b0EXFh9rmRkXS5GZAANsokH3ixGC K77TzYHRtM/sq2a2s/PHlxNEYyv3s/KeRzmqN58QLaLVH02y0zUL2685rePy0VUlkQZdQzED5Ryc 1o2mrwa7pOmajbK6xTzqdsgwykbgQfcEEUAblFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABVe 9s4r+1aCdSUbB4OCCDkEHsQQDVikoAx7rSraQOmo30krSxNChkdVKqeu0ADk8c0690CK+W5jN1cx Q3WPOjjYAMQAM5xkZAAOOtULgRW97qn9o24llnINvI9u0qNHtA2ADuDu44znNVJG1mO1mkBkt1Uw R+UoO2GPaC5XGSTnAJ5xzQBuT6DBJYi3GWCGRlDnglw2c47fMelUI/Dtxdzl9UnLhYRFGBJvIIYN u+6B1UdQc96oyXOri2ti1yws2lk3TBJA2ABsGQN2M7ucc4H4yo2sGznuZLi6aaFYTFGse0Pk/Nlc ZOQeR2oA6HT9OTT43VXLtI25mIA9uAAABVykFLQAUUUUAFFFFAFZv+Qiv/XP+tWarN/yEV/65/1q zQAUUUUAFFFFABXP+KfEdnpFk0LaxbaffSY8rzIzK3v+7HJ4qLx1dX1poUb2UlxDGbmNbua2TdLF AT8zKMHnp24BNZPw5sIFuNZvII5ri3luQba/vIyLiZdo3ZLAEqD04FADfBHjkX8Ii8Q6rbpqE7fu rd7ZrfaASMZbhieDxWd8bf8AkFaL/wBfv/shrtPF1oLvwtqKjT4r+Vbd2igkTcGYDjHv9K8N8UXv +haJY2mt3WrWce15PtEfNvLjGzdjPTPynJGKmfws1ofxY+qM6gcUGivJP0KyK+of8eE3+7X0XDqt lo/heyudRu4bWEW0fzytgZ2jp6/QV86X/wDx4Tf7temeDLS31LxNpFxG9/qnlWBF42ownZaPhdgj yAAScjAzxzmu/C/Cz5TPv48fQuaH8QJV8QXC61rtudKjwIZv7PkiWYkf3zwu08c9a9JgniuYUlgk SWJxlXRgVYexFK8aSRGORFZCMFWGQR9K8k0u5n0TxBNBp15NbXsuseX/AGEkX7n7OWwZAMfKNvzb gcZ4rpPDPXqKKKAOXul2XUq+jGuhs332cTeqisTU02X8nvg1q6U27T09iRQBdooooAKKKKACiiig AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACuZvG3Xkx/wBs10tc tKd0rn1Y0AdFYLssYR/s5qxUcI2wRr6KBUlABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABVa3/wCP m4+o/lVmq1v/AMfNx9R/KgCzRRRQAUUUUAFFFFABRRRQAUUUUAY/iCVoxZpJK8FnJPtuZUbaVXac At/CC2AT7+9Z32x7W/ez0ttoeeJC7SmaNAc5wM/KxAzjOO9dQyq6lWAKnggjg1kf2tZWuoPp6WzI Y3C5VFCbim8YGc9O+KAMi28S6m5aZ7VGBSZvswdd67AcDAJOcgA5HeiHxBqr25I+ytK6wlWJUhC8 gXopPGCcZ54rfsb6xurdL6HykM4XJOA2WAIU+/I4p9tPp7zSQWrWxkB3OkeM5Hc4oAi0m7nmmvre 5dZHtJxGJFXbvBRWHHr82PwrSpoUAkgAE9SB1p1ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABVOw /wBZef8AXwf/AEFauVTsP9Zef9fB/wDQVoA5u+m8E/2zc6fqltpVvdWrJOxuUjQOXGdwJ6njn8Kx vjIyv4XtWjIKNIhUr0I3JjFQeOL3y9f1PzrqGzltbaKTT4GtI5Pt7nOQSyktyAuARjOaf8XC7eDr AyRiJy0ZaMdEO5Mj8KAOQooooAKKKKACiiigBKMcYpaKANTVdfn1bT7K0mijRLQbUK5y3AHP5VlU tFAAAWIAGSTgCrV5pV/p6K95ZzwIxwGdCAfxqCD/AI+Yv+ui/wAxXdazqltJ4il0b7PNJ9pvIROZ pNyYGOEXtmgDgaK7S0sNNn1XWZHtIVWwYRwwLGzrjcQXZQctS/2VpUuoyS29m0ksVmZvsZjaNZXz wVB5xjtQByFraT304htYmllIJCqOcDrUVdXpKC78R2Zn0hbDfDKcIGRZMKeQD0xRLplrceFIZYbN IHj2G4mlRlfDNjerdGX2oA5Op7Syub+UxWcEk8gG4qgycetdnqul6Naw3dsbYokEWY5o7Z94bHDF +hBrH8FusV3qDyByi2MhYI20kcdD2oAy/wCxdR8wobKYOrrGVI5DNyB+NVJYngmeKVCkiEqynqCO 1dpoklvf2btCkywSanbjbLKXbpzlqjewht7Zp7bSU1KW4vpYpd25vJAbgDHQkd6AORS1me1kuUiY wRMFdx0UnoKIrWa4jmkhiZ0hXdIw/hHqa7a+FppFr4hVLGGSCK5t9sDZ2AkDrileO2019fS2s4RE 1jFNsbJA3dV+negDg6KBS0AJRS0UAJS0UUAFFFFABRRRQAV1nwk/5DfiL6W//oLVyddZ8JP+Q34i +lv/AOgtQB0up+FvC95rhS4hEOq3KmdXileOTjAZ1IOAeQDjk1qLp9rpVhptlYxiO2gmVUUHOBg9 +9cv48sYNX8Q6ZpxisIrhreWZby8DFUVSMooDDk5yTngCiLUzD8MtMvtOgSzYSKVjQl1B3EEqWyS DyRnsacVd2FJ2VzvqWvK/wDhNNc/5+R/36FH/Caa5/z8j/v0K6vqdTyOX65Dsz1SivK/+E01z/n5 H/foUo8a62rAm5U4PQxjmj6nU8g+uQ8z1KlrM0LWodbsFuIvlccSJnlWrTrlacXZnVGSkroKKKKQ wooooAKKKKACiiigAooooAp6tenTdLubwIHMMZfaTgH8ayLfxXE4R5Vj8kGYSSxuWUeWFORwD/Fj p2rY1O2jvrGWzkl8sTqUDAjP4ZrN/wCEaguHkkurqW4lkV1lf5V3blC9AMDAAoAvXWsWdm7pM58x dg2BSSxbO0D16H8qmsr6DUITLbsSFYowIwVYdQR2NZknhtZ43a6vJJrourrO8afLtBAG3GCMMc/W tDTbNLC18lZPMO4lm2quWPXgAAfSgC5RRRQAUUUUAFFFFAFZv+Qiv/XP+tWarN/yEV/65/1qzQAU UUUAFFFFACUUtFACV5l8bQBpWjYAGb7Jx/uGvTq8x+N3/IK0X/r9/wDZDUz+FmtD+LH1R53pdg2q arbWSuENxII9zdFzXXw/DhPtc1rdakYJ3Z1s0aLmUIOWb0FcdYCFtQgFzO9vDvG+ZBlkHqPeu2tt Ps9X1Bzo/iy8n1VoWVPPjILrjlc1wUoprVH12PqVYSXLLlVu1/xPOdSUpZ3CnqoI4r6W0X/kB2H/ AF7R/wDoIr5p1IFbKdWGCAQRX0tov/IDsP8Ar2j/APQRXRhvhZ4+efxo+hdpNo3ZwM4xmnUV0niB RRRQBhayuLtW/vJVvRGzbOv91qi1xf8AUt9RSaG3zTJ6gGgDYooooAKKKKACiiigAooooAKKKKAC iiigAooooAKSlpKAClpKWgAooooAKKKKACiiigAooooAKKKKAGSnbE59ATXLKNzKPUiulvG22cx/ 2DXPWq7rqFfVhQB04GABS0UUAFFFFABTJJFiRnkZVRRksxwAPc04kAZJwK8A8deOJfFmsy2FrJMd KgcxxW0Gd10w4LNjt6CgD1m5+JHhO1mMUuuWu8HB2EuB+IBFa2k6/peuxtJpV/b3ar97ynBK/UdR Xz8nh6dEX7dfadozMMxW8hUu3+96Cqs8OpeHLyK7aN7C5U5ivrU5if647H0NAH05RXL+APFy+L/D y3LhUvIW8q5Regb1HsRzXUUAFFFFABRRRQAVWt/+Pm4+o/lVmq1v/wAfNx9R/KgCzRRRQAUUUUAF FFFABRRRQAUUUUAFc3d+GprnXpr1WtkSR0cShD5ybV2lQemD39ia2tSJXTLsqSGELkEdc7TXF2F7 c2kK+SRPsZJkWGRnj/493+Qk85yuSPcUAbFl4au7NIbUXEBtBLFPI20796KowO2CVHPUc1LpPh2S wvIWlMLw2oYQsGcud3GSCcDj06+1Un1+7guZI4r+3vUFkLgusX+rYuq5OP4QCTjrxUGr6pdWt/p5 ttQS9CyOHkSPIhUxHLOF4YDrgf8A16AO0FLUcJDQowcSAqDvHRvepKACiiigAooooAKKKKACiimS OsaM7sFVRkk9hQBFe3sNhaSXNw4SOMZJrkT8SIc8afLj3kFYnijxBJr18tva7jao2I1HWRvX/Cug 0jwJZiwRtTV3uW+ZgrkBfauyNKnTjzVd2cTq1KkrUtkR/wDCyIf+gdL/AN/BR/wsiH/oHS/9/BWl /wAILov/ADxl/wC/ho/4QXRf+eMv/fw0c2G7MfLie6Mz/hZEP/QOl/7+Ctrw3qQ1rTrq6jRofMuH ABOSuABmoP8AhBdF/wCeMv8A39NXtBsINMgura1UrElw2ATnqFNZVZUWv3a1NaSqp++9DiprbUrH UtdkuvF19IumwxTuVsY3MYKseARgHAz8uPemfF1xJ4PsXEhlDNGRIRjf8yc/jT/Gl1oMHiWaC7ud WhN1CE1EWePKeNVZlV8jOdob7vOKb8XjEfCFibfHklk8vHTbuTH6VgbnH0lLXR+DoIYZrzV7tN9v YRFtuM7nPAFAHN0tdJ4l0tJfEdtJaskdvqYSSNjwFJwD/n3pmteH9O0i7gga/uN5lCSh4MYX++p6 EUAc9RXRL4SYa/d2U1wyWtrEZnuAoPyYyDjpk/0pLPw/pzaHDqt/qUlvBJK0e0RbicHjFAHPUV17 eDdNg1OKyuNXYS3Q3WyrFkkdi3aqVr4Xg+yX9xqN+bZbG48mTbHu3fT3oA52iurm8K6TbNazT6w4 tLwD7ORF85J9fQcioIvBznV7+2muCttZANJMkZZmB5ACjvQBzYJBBBwRyDUj3Nw119oklkNxkN5j E7s9jmugvPDNtBBDfwXVz9h85Y5/OgKSRZ74PUVt674es9Y8RXP+nPC8NossgEWQoGMfmM0AcNFe XUNybqKeZJiSTKrEEk9eaGvrp7sXTXMxuAciUud3510L2rT+ETFp9w0tq+oiKFHiAZiQOSe3XpTL jw/otlI9pd62UvkHz4hJjVsfdzQBiPqV7Jci5kvJ2nA2iQudwHpmmPfXUtqts9zM1upyIi5Kj8Kg fgMAcgZ59a6TxjGBNpKxoAWsY+FHU0AYj6jeyWgtXu52tx0iLnb+VRRTywb/ACZHj3qUbacbgeoP tXSHwtpttPFYX+rGLUpQDsWLKIT0BNV7Pwvh7+TVrkWltYv5cjqNxZuwUfl+dAGLDd3FumyGeWNd 4fCsR8w6H61q6Z4i/s6GSOey86Rn3NIJniZj6Nj7341YudAs7fSodV07UXuEN0kSq0WNpz3HqKu6 roUmo+JtSkvr1I7a0RGnuPLx1AwAo70Ac5f6rdajc3MsshVblw8kan5SR049qia+unMha5lPmIEf LH5lHQH2q5qlnpUMCS6XqT3BLbWikiKsPf6VZ8Jabb6hqksl4u+3tIWneP8Av46CgDC6DPb17Utd Mvjq5aXEtjZPYnj7N5QAC+mfWqmnaNbX9tc6pfT/AGHTkk2qEXcST/Cv0oAxKK35/DUPn6dJZXhn sL6URLNswyN3BFXJfCNgXv7S11Vpb+zQyGMxYXA7Z9aAOU59Dg0V22oabY3ug+HLaO8kBlbZG3lc sCfmJ9MVmP4Vt5NcbTbS+Zvs6s93NJHtWMD0HegDm6U5HUEfWt270Gwm0u5vNF1B7oWozNHJHtbb /eHtVnx0AL/TtoA/0FOn1NAHMUtdx4Ps7J/D81zPawOqSt9qknjLHywv8HvXEymMzSGEERFjsB6g Z4oAbXWfCT/kN+Ivpb/+gtXJ11nwk/5DfiL6W/8A6C1AF/xJp+uar4kh0+6k8Oz2bxyS29vdwOzY Uj5j3yAeoIHtXQadL9r0DSZHks5laVcNaIVhIG4DaDyBgVmeNpLfTdV03U49Zi03USrWsQkgMyyo 5GflHIwcc9K0NGs7Sw8OaPb2FyLq3WVSs4/5aE7izfiSaAN/7PF/zyT/AL5FH2eL/nkn/fIqWinc VkRfZ4v+eSf98is/WtCttXsHt3RUfqjqOVatWkoUmndCcU1Znk1jeXvhTW2EikMh2yx9nX1H9DXq Njew6hZx3Ns4eKQZB/pWP4q8OLrVp5kIAvIh8h/vD+6a47wz4gl0C/aC6DC2dtsqHrG3r/jXbNLE Q54/Etzji3h58svhZ6lRTI3WSNXRgysMgg8EU+uE7gooooAKKKKACiiigAooooA5PxjbNPeQFRgr ay7G8gyEvuQhVI+6xxwabDJcpI63T3VhbzXM0jvEmW3/AC7Vzg4H3ucc4rpdRuTZabdXSqHMELyB ScZwCcfpWLpviyO5s3ubgRmD92I5YCSsjtn5BkDLDHPbmgChY319PbxnVL2/tiIy0LJBhpm3sPmX aeQAvy8dat6I15H4g1CO5EsVs1y7wYT5ZjtXJY9sdhwDz1rSj8Q2cyqIfNklZ2TyUXLgqATkdMAE c57iptG1H+1dPF1sKAySIFIIOFcryD0PFAF4UtFFABRRRQAUUUUAVm/5CK/9c/61Zqs3/IRX/rn/ AFqzQAUUUUAFFFFABRRUVzcw2du89zKkMMY3PJIwVVHqSelAEteY/G3/AJBWi/8AX7/7Ia9AsNa0 zVWddO1C0uzGAXEEyvtB6ZweK8/+Nv8AyCtF/wCv3/2Q1M/hZrQ/ix9Ued6aUXUIXmtXu4kbdJCm cuvpxXaW2sRWtlLqfh7wfJCyqyi7Zi4j7EioPBOrafpuh3yPqkem6hNKuyZofMOwDpj866dvE2iH WLa7HiRVtooDG9osRCSserH8a5KcUo3ufR46tKdVx9m2l62fyWh4zqLFrGdickjJNfS2i/8AIDsP +vaP/wBBFfNerFTb3RT7hJ2/TPFfSmjf8gOw/wCvaP8A9BFaYb4WcWefxY+heorMg8SaNdXYtLfV bGW5LFRClwpckdRgHPGK0q6TxBaKKKAM7WlzaK391xVLR2xekf3lNaeqLu0+X2wax9OfZfxH1OKA OjooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiikoAWkoooABS0lLQAUUUUAFFFFABRR RQBU1Ntuny++B+tY+nLuv4fY5rU1lsWOPVhWfpC7r9T/AHVJoA36KKKACiiigDL8SyyweGNUlgz5 qWkrLjsdhrwn4cjZqN40aguLFGX65r6HmiSeF4pF3I6lWHqDwa+Z28/wl4u1Cy0u/jMlvKYVLjMc qA5Cn0IoA9I+HfhzRtb8MnUtStINQ1G7lk+1POm4xtuI2AH7vGPzrAjiitLTxdpllJ52mWhkW2JO 4LlCWUHvg1iDV9Leaea+XU9IupRmVLGU+Xcn2x3NVrzXZo9JaysYF0rSypUqfnmmz1z7mgDrvgZI 6axqcKE+U9nDIw7bug/QmvaK8z+B+m28Hhm61COVZLi5n2SL3iCcKp9+c/iK9MoAKKKKACiiigAq tb/8fNx9R/KrNVrf/j5uPqP5UAWaKKKACiiigAooooAKKKKACiiigBCM1j3uu2+mXUlu1s+yERs7 oVAG9iowM5PI7CtmsO88PLc62NVR4xdRiMQl03bQu7cD7EN+BANAF5L6wW5e2SaBZgTuUYHPU/jU Vpq2n3F6lnZtG5MbS5jxgAEDP47utZknhMTyzRTPEbR3kkBAbzQz599owWPOParthpl7FqMNzeXF s4gt2t0WGIrkEqdxJP8As9BxQBsAADAGB6UtJS0AFFFFABRRRQAUUUlAAa8/8aeJvtDtptk/7pTi d1P3j/dHt61qeMvEv9nxGws3/wBKkHzsP+Wa/wCJrE8G+Gv7QmF/eJ/o0Z+RT/y0b1+grro01CPt Z/I461Rzl7KHzNTwX4Z+zqupXqfvWGYUYfcHqfeuzoAxS1z1KjqS5mdNOmqceVBRRRUFiVUsP9be f9fB/wDQVq5VOw/1t5/18H/0FaAPPPGWlafq/i+VYbfXZ7mFIzex6eiGNgVYKCWIwSpYcdqf8XlV fCFiqRmJQyARt1Qbk4P0qbxDYx6j4zv00/S9RuL2KGL7TLDqv2RcEHaAM89DUPxeUp4QsVZSpDRg qzbiPmTgnv8AWgDj66Sy8UDRfD0FppYBunkaS5aSPK+wHr2rm6KAOlvvElvrmjwRasrC7guAytAg AMZ6geh/wp3iDXdPutBj0+1murtll3rLcqA0S4+7nvXMUlAHaa7qs1v4M0+1nXbe3kSiRv4jEvTP 14/WsO51S3l8JWemrv8AtEM7SNkfLg571lzXE1ywaeV5WUbQXbOB6VasdGvNStbq5tY1aK1XdKS2 DjBPHr0oA2LrxBZzeKNKv08zyLWONZMrzkA5wPxpl/rtpc6Xq9vH5nmXl758WV425HX0NZWnaNea rBczWkatHbLvkJbGBgnj16VRyMUAbmp6vbXenaJBFv32S4lyvHUdPXpWt/wl9r/bmpOGuY7O9VAJ YvlkjZRjIFcla273l1DbxY8yZwi5PGScU++s5NOvprScr5sLbW2nIzQBs63rMM9rHb2up6leZbMp uCAhHYBfWtCXxTp76vqdyPO8u6sRbx/Jzux39q47IozQBu2eux2XhmG0j3fbIr4XK5X5cADvVq+u vDOpXMuoTm/jnmG57dAMb8dQ3pWbpPhvUNbhklsUiZI22sXkC81Bqmj32jSrHfwGIt91s5VvoRQB RbnOPwzXVatquh6lZW0okvV1C1tkjiAUBNy+v41g6Xpk2rzyQ2zRKyRmQ+Y2BgVTBzQB1susaBqN /Dq98t2l4gUyW8agpIy9Dn0qfSb6XxAmri8sZZ7O5kEjfZ2BkhYfdwOp4A/KuLyPWpbe6mtJfNtZ pIpOm6NiDQB2esw2mleDraCGG5gDXqyBbgASOB1bHaqs3ijT7nV9US4jmfTNQVAWUYdGUcHFc6Pt +tXqR7p7u4fhQzFj/wDWFak/gjWoIGk8mKUqMtHHIGcfhQBS1RNFjgjTS5buabcS8kyhVx6Ypuha u+iamtyqCSMqUljP8anqKjOlzjR/7SJjEHm+Vt3fNn6VSzQB1HmeD45jdLHfyfxC0IwufTPp+NV9 O1fTpdMudK1KOWGzkm86F4fmaI+nPUVz+Qe9GRQB08mv6fbPpVnp6zfYLK4E8kkg+eRvXFJZ+ILO DxHq98/meTdxyLHhect0yO1Y0OlTz6TLqCNF5McgiILfMSfb8aTVdMn0e+NpdFPNChjsORg9KANd NetFt/DqHzM6c5af5e2c8etEHiO3t/E+oXbRPJY325JF6NsPf61zmQaKAOjl1LSNK0i9tdFa6nnv V8t5J12iNPQepqv4o1a31e6s5LXfthtlibcuPmBP+NYlLQB2OkeJ9OtdM09JpbuCWyDBoYUBSfPr msbxNqFhqd7DPpsflRiIIYvKCbSPcdax6KACus+En/Ib8RfS3/8AQWrk66z4Sf8AIb8RfS3/APQW oAufE2ysp7vT5W1UWd8FKpEbZ5/MQOr52pyMMo5/Ct3w/BbW3hjRorOWWWFZh+8liMbMxLFjtPI5 J4rN8a+SniLTZYLvWI9TEEixx6ZbrKzR5G4tuGMZxW1pzTPo2mNcNevKZxuN7GqTfxfeVeBQBv0U UUAFFFFACVxvjTwz9pRtSsk/fKP3qAffHr9RXZ0hGRV06jpy5kRUpqpHlZ594L8TfZXTTbx/3LnE Lk/dP936V6CK868ZeGfsErahZp/ozn94o/5Zt6/Q1seDfE326MafeP8A6TGP3bn/AJaL/iK6K1NT j7Wn8zmo1HCXsp/I66ikpa5DsCiiigAooooAKKKKAK95DHeWk9rI2FliZH2nkBgRms19As/Ke3Wd 497JJGuVOyRRjeARjJ7joeag8Q6XcXl9brbIxivI2tbx1bGyLO7P14ZR/v1mRaTfXE1s92J4Zxee S0sZ58qOJ1VgewYknPvQBsnRYYhCE1CSK8hJInGwNhyAQVxtwcDAx2FaGmafHpdkttHJJIAzOXlO WJZixyfqa5e6s7+8h8qY3Z8ue3AkUYd1W4PJOOcLg/rVjS5NYbXENzM/zSSefEUcoqDO3GQFHbBB OeaAOropBS0AFFFFABRRRQBWb/kIr/1z/rVmqzf8hFf+uf8AWrNABRRRQAUUUUAU9U1S00bT5b2/ lEVvEMsxGfYAAdST2rk4vEup+MLm7s9Atba0tbfCXE2pxMZMkZGIeOPdjXR+I9DXxBpD2ZnaBw6S xSqASjowZTg9eR0qr4e8P3Om3t7qOqXy3uo3oRZHSLy0VEBCqq5Pqec0AYWmeGPEPg+3mfSbrTNQ jd2mlgmthbsxJJO2RScdTgEYHtXHfEbxlpvirRNG+xmSK4W73SQSqQVG0gkHowzxkGvZ7y2S9sp7 aTISaNo2wecEYP8AOvE/iNoOq6PpugRahfWtxa2kv2a1EMGx9u3q5z1woHH1qZfCzWh/Fj6o5yyt Gv76G1jdEeZwis54BPrVu88N6tZXUlvLp9yzRsVLJExU+4OORVfSxdnVLVdPZlu2kAiZeoY9K9Fu rLxKhtYLXxVLPdSmVHXACKyLkqDjk9q8+nBSR9jjMXOhUSTVmut/0PJ9RBFjMCMEDBFey2Pjxr2D S9I8OWgnvJbcBbi8DRW/yqN204zIR6D0rxzUyxtLgvkvzuz655r2vwx4Ru400S51DVftVpp0Iayg WAIylkx87Z+bAOB0rpw3ws8TPXetH0I4PBWvWmry61b6rpX9oSqFaM6cBFgZxghtwPJyetXdM8fW 41J9I1+NNP1SKRYm2MZIHZvu4fHBPo2DXXdq4nUPAt9dXOoWkOowJo2pXQu7qNoczhsglUfOMEqO SMiuk8Q7alpKWgCG6TzLWVfVTXOW7bLiJvRhXUMMqR61yhGxz6qaAOsopsbb41b1ANOoAKKKKACi iigAooooAKKKKACiiigAooooAKKKKACkNLSUAFFFFABS0lLQAUUUUAFFFFABRRRQBl622II19W/p UGiDNzIfRP60/XG+aFfYml0NeZm+goA16KKKACiiigBrHCk+gr5iggjvraZrhQ5knkdieudx5zX0 7J/q2+hr5l0z/j0P/XR//QjQBGNNlj+WG+nVOysA2Pxp8OmRRyiWVnnlHRpDnH0FbVjo2oals+x2 ryh92CMAfLjdyfTIqnJG8MrxyKVdCVZT1BHagDvPgs5E/iKH+ATROB7lTn+Vep15V8F/+P7xH/10 h/8AQWr1WgAooooAKKKKACq1v/x83H1H8qs1Wt/+Pm4+o/lQBZooooAKKKKACiiigAooooAKKKKA KupW73em3MEUjxySRlUdDgq2OCD9a5JNQ1PUfJdmuYoNWZUjAXb9mEfLn23gN+ldXqV+NPhjcxPK 0kixKiEAknpyeKht9b0+4t4pPtEcfmRecEkIVlT1I7Dg89KAOdsr+/j0XTkvJY50ubeOReGVkIeM ctnLZDfmPSmw6vqdpbrCLiNi011IbiRVAwspAQbmH169O1dVb3tjdKnkTQuDkKAR26jHbHFMub3T Yo0NzPbBW+dN5X5vcev4UAT2E8lzYW80yCOSSNWZVOQCR2NWKit54rmFZYJFkjcZVlOQaloAKKKK ACiiigBKxPE3iGPQ7L5cNdSjESf1PsKu6vq0Gj2D3NweBwqjq7egrzOGK+8Wa6cnMkhyzfwxJXRQ oqXvS2RzV6zj7sd2TeH9En8Sam8twzmANunlPVj6D3NeoQwpbwpFEoSNBtVR0AqDTdOg0uxjtbZc Ig692Pcn3q3U1qzqPyKoUVTXmLRRRWJuFFFFABVOw/1t5/18H/0FauVQtXEX29yCQszMQPZVoA8/ 8ZwWdzr+sXQ0XTbg6VbRzXkl1LIskysCQqbSAMBep78UvxaaN/BmntChSJjGUU9VG5MCrN6keu+A x4t1DStOn1KKBrmEOG2+UG3BWweTtHfjNV/i7OLrwdYTqu0StG4U9sshxQByFFFFABRRRQAld34O uo9L8PJJMqlL6+Fu2fQriuEq7Lq1zLpVtp52LBbuZEKjDbj3JoA9B0azTw/5WkSKvmajLOSf9gDC /piuZ0qGDR/D15qz2kV1dR3P2dFlG5Yvcis+fxPqFzq9tqUrRm4t1CoAvy456jPvTbLxHe2F1czR CFkumLTQOmY2J9qAOitmt520PXI7G3guJ7r7PJGq/I/beB2Iqa9FvJq+vapcWUM76aFSKHbw5P8A Gw7muWu/Ed9e31tdSGNfsrBoYkXEaY9qIfEd/Bq8+oxugmnP71NuUcehFAG4n2fX9Hj1Oayt7a5t 7yOImFNqTKWHGPxqh41njXW5bG3tbeCG3bI8tApYkDOTVS/8TX1+bcMIYYbdxIkMKbU3DnJHeqWo 382qX8t5cbPNlILbBgdMUAbVgSvgDVCCQftMfT8K0dLD3PhKzGoguo1KNbfzeSVyMjnt1rB0fxNf aHbyw2iwMkjbm8xN3P502+8SajqN7b3NzKrG3YPFGFwike1AHUg29x4wv7EWVrHb2tvLsVIgMkgZ JqlpujweJ9K0yWKKOOS1l8m82ALuTqGPvx+tYSeIbyPVrnUVEXn3KMj5X5cHrgZ9qg0/V7vS4rqO 1cKtzH5cmR29R70Adbp0em393rGreVZxR2rLFbrKn7pB03MB1zVDxH/Zdzo6Tpc6e+pJIB/oalVk T3HqKwtK1e60eZ3tShWRdskci7kcehFSarrlzqyRRyx28MMWSkUEYVQaANbwd5otNaaz/wCP4W37 nHXHfH6Vg2Ut+t2TZNc/acHPlk7unOabZXtxp10lzaSmKZOjD+Vbc/jnVZYXSMW0EjjDSxRYc/jQ Be0K1gl8Pae8kMbu+rKjMygkjHQ+1WFtrTUfFV/BJZQLa6VHI8cESbfNOR19ea5m11+8s7SG2j8s xxXIuVLLkl/c56UxNavYtZfVIpBHdO5clR8pz1GPSgCzqXiJdUsHik0qyifdmOWFCpjHp71s31nb L4j8MIlvEI5oYi6hBhznnPrWLqXia71Oza2aC0gidgziGIKXPqTUtl4v1Gxs47dFt5PJBEMsse54 x7GgDbu47eztdZuI7W3YwaqgQNGMAccfT2rX1CSCfxFqS3NlbTLaaf5q7owSx68n8K8/XWLoafPZ sUeO4mE8jMPmLD3q1L4p1Ca8urlhB5l1B9nkwnG32560AaVnD/wluh3UcdvBHqUE6yKYowu5G4I+ gqh4ra1h1JLCyjRYrKMRM6qAZH/iJPeneFtRt9Ga+vpJts6wFIIRn94x/oMVhszSOzuSWYksT3NA CUUUUAFFFFABXWfCT/kN+Ivpb/8AoLVyddZ8JP8AkN+Ivpb/APoLUAa/je3ju9e02K0ttQudXEEj RLa3v2YJECNxLe5wAK1NDube88N6PPayXTxPMDm6ffKDlgwZu5ByPwqlcW8XjK51GVIrq1m0md7W 2ura48uSY7R5iZxwpOB+tWvDk9rc+EtCksbY2sG9VEBOTGw3BgT35B570AdRRRRQAUUUUAFFFFAE c0STxPFKoZHBVlPQivLvEWhzeHNSSW3ZhAzboZB1U+h+leq1U1HT4NTspLa5XdG4/EHsRW1Gs6cv IxrUfaLzM3wx4hTW7LD4W6iGJF9f9oe1bleSzw33hPXQVJDxnKN/DIlel6Nq0Gs2CXMBxnh07o3c Gqr0VH3o7MjD1nL3Zbo0KKSlrnOkKKKKACiikNAGHc+Ijb+IU00xxMGdE++Q/wAylt2MYwMY61Kv iWyeFJUW4ZGj844hOVj7OR1APPvwadc6Il1fPO9zIIpHjd4QFwzJ93nGfT8qjfQFjRVt7yW3Bt1t pSAp8xF4HXo3J596ALS63YNLHH9pQPLKYUB43OF3ED8Oagg8SWNxKFiMzLuVDJ5R2KW+7k++R+Yq K68J6XemZ3jcGaBIco+NoXoV9G4Az6AVaOjW4SVFLIkkscu1cYXYFAA9vlFAGiKWkFLQAUUUUAFF FFAFZv8AkIr/ANc/61Zqs3/IRX/rn/WrNABRRRQAUUUUAFFFFABXmPxt/wCQVov/AF+/+yGvTq8x +Nv/ACCtF/6/f/ZDUz+FmtD+LH1R57pE9zbaxaTWUZluI5Q0cYGdxHau8u/G+kWUSyw6ZeQ6mjyy rDMNqpJIMMfcVwOliRtVtlhultJDINs7HAjPrmvV9VP2DQEGqWcniZmXInjhTav/AAIc/jXFRvyu zPp8z9n7aHPG/wA7f8A8W1IlrKdm5JBJNfS2i/8AIDsP+vaP/wBBFfNOpnNncELtBBwvp7V9LaL/ AMgOw/69o/8A0EVthvhZ52efxo+heooorpPECiiigArmLtdl3Mvo5rp653VF26hJ74P6UAbVi26y hP8AsirFUtJbdYIP7pIq7QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUlFLQAUUUUAFFFJQAtFJS 0AFFFFABRRRQAUUUUAYmtNm6QeiVY0RcW8h9WqlqzZv2HooFaOjjFiD6sTQBfooooAKKKQkAEk4A oAST/Vt9DXzLpv8Ax6H/AK6P/wChGvo231jT7+C6e0vbeZLclJmSQEIwGcE1846YQbMlSDmR8f8A fRoA7Pw9c+bpX9m/2jcW5uJtoRLLzRyRxvzkAkDI9qwtTWZNVu0uXV51mcSMvRmzyRXoWn6K+lWI htbjU5Iy6K0cV0kaNvALSLjnA6YNeealbCz1S7t1kMiwzMgc/wAWD1oA7P4L/wDH94j/AOukP/oL V6rXk3wYuIV1XxBC0qCZ3iZULDcwAbJA9q9K07XNN1aSeOwvYZ5LdzHKiN8yMDg5HWgC/RSUtABR RRQAVWt/+Pm4+o/lVmq1v/x83H1H8qALNFFFABRRRQAUUUUAFFFFABRRRQBm63pzanaxRqIWMcyS lZhlWC9jWVF4VeO2lTz4t7JFsHlnYhSVpAmM/c+YDHoK0PET3dvZJdWEoSaKRV2P9xw5CfN9CQR9 Pes59YvrC6ls41SVLQxRlp3UPOWAy2Swx14wDyKAJ7rw7PqCzyT3K29zNKjhrcHCqBtIyeSWUsCf p6Ulp4TisriJ45d6Q3KyRI658qJVYLGvsCxOf8Kz49YurbUlQTAiXMe6ZiUizPINx/BQB+FW5vEl 3aoR5EV0zSvawvDkLJNgFATztByQfQqaANzTrM2UMkZYNumeQYGMbmJx+tW6ytD1aXWIpZzB5UKM IwGBDFx/rPwDcfga1aACiiigBKiurqKztpJ53CRRjczHtUjMFBJIAHJJrzPxZ4jbWboWloSbSNsD H/LVvX6ela0aTqyt0Ma1VU436lXV9Tu/FOsIsKMVLbIIvQep9/WvQfD2hRaHYCJcNM3Msn94/wCF UPCPhoaTbfablQbyUc5/5Zj0+vrXS1pXqp/u4bIzoUmv3k92LRRRXMdQUUUUAFFFFABWejmzubgS RyGOV/MV0QsOQAQcdOlaFFAHFN4P05jJb/bdXXSpJDK2mqCISSckfd3bSeducVl/Fwef4SEiRvHF DNEqll27iXHQHsAP1r0muE+MX/IiN/19Q/8AoVAHn1FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABXSfCu+htvEevwzNsMiQMGbheA 3GfXmubro/hMA3i3xACMjyIOv40AdRc6LeW+oXsug+Irayt79/NnikjWQpIRgvGcjBOB1zzWnYWN rp1jpmlaa/mx2rAlt24hQDlmPqSf1rb8qP8AuL+QpVRV+6APoKAHUUUUAFFFFABRRRQAUUUUAZPi DQ4tcsDC+FmXmKT+6f8ACvPNK1K78Lay6yowAO2eL+8PUf0r1iub8W+Gxq9t9otlAvIhx/00H93/ AArpoVUvcnszlr0m/fhujetLqK9tY7i3cPFIMqwqevMPCniJ9Fuza3ZYWkjYYH/lk3r/AI16arBl DKQQRkEd6zrUnTlboaUaqqRv1HUUUVkbBRRRQBy97ZXEGtX0lkrSCO2N3BCw+Q3J3Ln8gOPUk96o i6vL6yYNO9zGrwlvkbKvu5Gdq9uo5xXa4oxQBx8d9eW9vFC01xDOsEAs4Fiys3yLu3ceuQeRgDNS PfeIllaJYCVVjZiTYMlycif/AHAuBj1zXWYoxQAiLtQAksQOSe9OoooAKKKKACiiigCs3/IRX/rn /WrNVm/5CK/9c/61ZoAKKKKACiiigAqrqN8NOspLloLicJj93bxmR25xwo61S8Ra5/YVlFIls91c 3M621vArBfMkboCTwBwST7VzOlpq/i/UdRh1rUbrSzYSiJ9P099gwygqxm6tkemKAOl8PeJLbxNZ vdWUF3HADtV7iExh+udueuCCK4n42/8AIK0X/r9/9kNa1/4Uh8KaPPfaJrV/pkdnG0rRySG4gYDk go3r7EHmuF+IniS/1bSdCt9Y0mTTrxpRcL84ZJEKkZGDkHkfKeRmpn8LNaH8WPqjnLE2638JvI5J bcOPMjjOGYegr0S6vfEei6Kx0Lw8mmWAXcxJEsoHqRnj8q4HRbyKw1yyu7hN8MMyu4xngGvQomh0 7xHe+JLjxBbz6dMjlIFlLPIGHCbPauKjs9T6nMv4kbq+nW9m+3qeUakxeynZjksCSfevpbRzjQrA 4zi2j4/4CK+adSYNZ3BAwDkgenNet2Op6/rE+jaRcM+gWd3Z+ZBLAyyzXARVyN3SPg56H61thvhZ 5mefxo+h1Ok+MbTWNXl02Cy1OKeEfvTPalFj4yMntkdPWt+uSHw8soHkuLPVNZt7+TBe7F4zO5HT cD8rfTFZ+ieNdQtpZINXtnu7CO++wJq8ShA752jfHnI+bjcOM10niHfUUlLQAVh60uLtW/vJW5WR ri8wt9RQBJojZtpF9GrTrH0NsPMvqAa2KACiiigAooooAKKKKACiiigAooooAKKKKAEpaSigBaKS loAKKKSgBaKSloAKKKKACiiigAooooA5vUTu1Cb64rZ0xdunxe4z+tYV2266mPq5rorNdtpCP9gU ATUUUUAJXj3xSk8XJcv9sZ18OnPzWGen/TXv/SvYqayK6lWAZSMEEZBFAHy9Gb6PSCsxmXQGm622 fJaTA++RznGOtX4ViWJRCFEeONvSvf7Tw5pOmWl5BZ2EEUN2xkmiC5VyRjp0/CvnjS1C2ZCjAEj8 D/eNAHWQeC7u5ijlh1HS2SVxGh+09X67enX2rDuYGtLqW3kKl4nKMVOQSDg4rqPDcck2jRG5sbaa 2t7oy20k14IP3uBkc/eHArmtQeWXUrqS4ZGmeVmcxnKkk84I6igDMmQSX0KWaTvqZb9wLTPm59sU 21g1tteZLf7S/iISHm0P7xWzz5jDj616N8GIYzqfiGUxoZFeFQ+OQCGyAa9K07RdP0lp20+zht2u JDJKyLgux5JJoAqeFo9di0aJfEk1tLfdzAuMD/a7E/TitmiigAooooAKrW//AB83H1H8qs1Wt/8A j5uPqP5UAWaKKKACiiigAooooAKKKKACiiigBrorrtdQw9CM1HJZ28s6TyQRPNH9yRkBZfoeoqai gCF7S3kRkeCJlcbWBQEMM5wfxp0dvFDEscUSJGn3UVQAv0FSUUAIFC9ABn0paKKACkNFcx4v8SjS rc2lq3+mSjqP+Wa+v19KqEHOSiiJzUI8zMvxr4m3b9Msn46TyA/+Oj+tP8FeGcBNTvU56wRsOn+0 f6VmeEfDh1a5+2Xik2kbZwf+Wrf4etelKAAAOAOgrqqzVKPsofM5aMHVl7WfyFpaKK4ztCiiigAo oooAKKKKACiiigArhPjF/wAiI3/X1D/6FXd1wnxi/wCREb/r6h/9CoA8+ooooAKKKKACiiigAooo oAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK6T4S/8jb4 g/64Qf1rm66T4S/8jb4g/wCuEH9aAPWKKKKACiiigAooooAKKKKACiiigApDS0UAcP418M7w+p2S fMOZ4wOo/vD+tReCvE2wppl6/wAp4gkJ6f7J/pXdlQwwRkGvNvF/hs6XcG9s1ItZG5A/5ZN/hXZR mqsfZT+RxVoOlL2sPmelClrlvB/iX+1IBZ3bf6XEvBP/AC0X1+vrXUVyzg4S5WdUJqceZC0UUVJY UUUUAFFFFABRRRQAUUUUAFFFFAFZv+Qiv/XP+tWarN/yEV/65/1qzQAUUUUAFFFFAFDWdGs9d09r O+RmjLB1ZGKsjDkMpHII9aj0Pw/ZeH7eSKzErNM/mTTTSGSSVvVmPXitOigCC8s4L+zmtbqNZYJk MciN0ZSMEV458UPCttoNlpE8d3fXUhuRChupzJ5UYUkKvoK9qrzH42/8grRf+v3/ANkNTP4Wa0P4 sfVGH4P0e2l0K/1WbSX1aeKVYYrUHjnqab4q8FXcGsB9G0q5NrLEsu1V3CNj1XPtXN2es6jp0bR2 N9cW6McssUhUE+tWP+Eq1zn/AInN7/3/ADXBzwceVo+vlhsTGu6sZK3Z3MPUQUspwRggYIr3vwj4 S03Sba01CH7RLcNaoqGeZpBCpAJVAfugmvBNRJaynZjkkZJ9a+ltF/5Adh/17R/+giujC/Czx89/ jR9C7XNf8IJpn9rG9Et55RuPtZsvOP2fzuu/Z6559M101FdJ4YUUUUAFZ2tLm0Vv7r1o1T1Vd2ny e2D+tAGdozYvSP7yGt2uc01tuoRe5Iro6ACiiigAooooAKKKKACiiigAooooAKKKKAEopaSgBaSl ooAKSlooASlpKWgAooooAKKKKACkPAJ9KWmSnbC59FNAHLudzsfUmuoiG2JB6KK5eMbpEHqwrqqA FooooAKKKKAGyf6tvoa+ZdN/49D/ANdH/wDQjX01J/q2+hr5l0z/AI9D/wBdH/8AQjQB2nh+4jm0 hLGWTRHJnLRw3wffuOBwRwAa56+jeLULmOWJIZEkZWiT7qEHoPaul8NSSWmlQSSXsNotxdGG2b7E sz+ZxyWPIAyK5q/img1G5iuW3zpKyyNnOWzyaAO0+C//AB/eI/8ArpD/AOgtXqteVfBf/j+8R/8A XSH/ANBavVaACiiigAooooAKrW//AB83H1H8qs1Wt/8Aj5uPqP5UAWaKKKACiiigAooooAKKKKAC iiigAooooAKKKKACkpapapqUGlWMl1cthEHAHVj2AppNuyE2krsp+I9ei0OwMnDXD8RR+p9T7CuA 0XSbrxPq7vM7FN2+eU/yHvTGa+8Wa76ySHgfwxJ/9b9a9N0nS4NIsEtrccL95j1Y9ya7W1hoWXxM 4lfETu/hRYtreK1t0hgQJGg2qo7CpqSlrhO61gooooAKKKKACiiigAooooAKKKKACuE+MX/IiN/1 9Q/+hV3LMFBLEADua434pWkuq+B7mOxCzTRSRzeWrDLKrZOPwoA83orLHiPTSATcbT3BU5FL/wAJ Fpn/AD9D/vk/4UAadFZn/CRaZ/z9D/vk/wCFH/CRaZ/z9D/vk/4UAadFZn/CRaZ/z9D/AL5P+FH/ AAkWmf8AP0P++T/hQBp0Vmf8JFpn/P0P++T/AIUf8JFpn/P0P++T/hQBp0Vmf8JFpn/P0P8Avk/4 Uf8ACRaZ/wA/Q/75P+FAGnRWZ/wkWmf8/Q/75P8AhR/wkWmf8/Q/75P+FAGnRWZ/wkWmf8/Q/wC+ T/hR/wAJFpn/AD9D/vk/4UAadFZn/CRaZ/z9D/vk/wCFH/CRaZ/z9D/vk/4UAadFZn/CRaZ/z8j/ AL5P+FH/AAkWmf8AP0P++T/hQBp0Vmf8JFpn/P0P++T/AIUf8JFpn/P0P++T/hQBp0Vmf8JFpn/P 0P8Avk/4Uf8ACRaZ/wA/Q/75P+FAGnRWZ/wkWmf8/Q/75P8AhR/wkWmf8/Q/75P+FAGnRWZ/wkWm f8/Q/wC+T/hR/wAJFpn/AD9D/vk/4UAadFZn/CRaZ/z9D/vk/wCFH/CRaZ/z9D/vk/4UAadFZn/C RaZ/z9D/AL5P+FH/AAkWmf8AP0P++T/hQBp0Vmf8JFpn/P0P++T/AIUf8JFpn/P0P++T/hQBp10n wl/5G3xB/wBcIP61xH/CRaZ/z9D/AL5P+Fd38IIXkv8AWNXI8u0uRHFAz8GTbnJA9ORQB6pRSZpC wBAyMntQA6imq6uMqwI9jmnUAFFFFABRRRQAUUUUAFFFFABUVxbx3UDwzIHjcbWU9xUtFAbnlGua Rc+GdWSSB2Ee7dBKO3sfeu+8Oa/HrlgH4W4j4lT0PqPY1c1XS4NWsZLW4XKt0YdVPYivMf8ATvCW u+kkZ/4DKn/1/wBK7k1iYWfxI4Wnh53Xws9apapaVqcGrWEd1btlW6jup7g1driaadmdqaaugooo pDCiiigAooooAKKKKACiiigCs3/IRX/rn/WrNVm/5CK/9c/61ZoAKKKKACiiigAooprOqKWYhQOp JwBQA6vMfjb/AMgrRf8Ar9/9kNelRzxSkiORHI67WBrzX42/8grRf+v3/wBkNTP4Wa0P4sfVHAaF bwXevWMF0rNBLOquFHJGa7XWb6fTdUuLS28FWbwRMVjkNszbl7HIGK5LR0sYfs92+qyWd4lwAAkO 7y0/vg+vtXYnXrbB/wCK/vj/ANuY/wAK46StH/hj6bHzbrJ2uktve/Q8w1Qk2tySu0nPy+nPSvpX Rf8AkB2H/XtH/wCgivmrVTm1uTuLZz8x789a+ldG40Ow/wCvaP8A9BFa4b4Wefnn8aPoXqKiW5hd tizRs390MCalrpPECiiigAqG8XfaSr6qamprruRl9RigDmbVtl1E3owrqK5P7re4NdUh3KD6jNAD qKKKACiiigAooooAKKKKACiiigAooooASiqlrqVpfOyWt1DMyDLBHBIFWhQAtLSUtABRRRQAlLRR QAUUUUAFFFFABUF622zmP+yanqpqjY0+X3wP1oAw7Rd13CPVxXT1zmnLuv4fY5ro6ACiiigApGYI pZiAAMknoKDXjHxQHi1blzqjsfD5J2/YMhAO3m/xf0oA9Xt9c02/s7m4tL63mgt2aOWVXG1GA5BP TvXzpphDWZKnIMj4I/3jUKrfLpCfa/O/sEzHyzb/APHuZOM78c56dauxBBDiILs/h29KAOu8PTPF oZ+yara21wkxkeK6hMixjAAkXCna3vXNXOftUuZlnO85lUkh+eozzzXe2ralFriXGlWsbabdW0Ea 3IwI4olwX3HpnhgQa4bUWgbVLtrQYtzM5ix/dycUAdd8GLiFdU8QwmVBK7xFULDcwAbJA9q9J0vX tM1ppl029huGgcpKqN8yEHByOv4186tGbjUYYtOjnk1TP7kWmRKD65HT8abp9prc+uGLT/tEniBZ Dl7RsMhzyZGHHXrQB9O0VwOn3vxItrNIrvStIu5V4MpuNhb6gcZqz/anxA/6AGkf+BhoA7WiuJ03 xT4iXxdY6Lr2l2NsLuKSVHgnLnCCu2oAKrW//HzcfUfyqzVa3/4+bj6j+VAFmiiigAooooAKKKKA CiiigAooooAKKKKACiimkgDJ6UAMnnjtoHmmcJGg3Mx7CvLdd1i48S6qkdurGINtgiHf3Puau+MP Ep1Oc2NmxNrG3zEf8tW/wFb/AIO8M/2bAL27T/S5B8qn/lmv+NdtOKoR9pLd7HDUk68/Zx26mj4b 0CPQ7EKcNcycyv7+g9hWzRS1xyk5O7OyMVFWQUUUUigooooAKKKKACiiigAooooAKKKKAKE6LPq0 UUqh40iaQKem7IGcfSrP2W3/AOeEX/fAqu5Yayu0An7OeCcfxCrO6X/nmv8A31/9agBn9n2Z5+yQ f9+x/hSf2dZ/8+lv/wB+1/wqTdL/AM81/wC+v/rUbpf+ea/99f8A1qAI/wCzrP8A59Lf/v2v+FH9 nWf/AD6W/wD37X/CpN0v/PNf++v/AK1G6X/nmv8A31/9agCnf/2Rpdo91fpZ29un3pJFVVH403TX 0bV7NbrThZXNuxwJIlUjPpVDxZe6db2EEWtJbKs8wS3e4TzIkmwdjNxgAH1rB+F7tGuvWx8i4nj1 AtNdW7YhmZgD8gAwMdMCgDt/7Os/+fS3/wC/a/4Uf2dZ/wDPpb/9+1/wqTdL/wA81/76/wDrUbpf +ea/99f/AFqAI/7Os/8An0t/+/a/4Uf2dZ/8+lv/AN+1/wAKk3S/881/76/+tRul/wCea/8AfX/1 qAI/7Os/+fS3/wC/a/4Uf2dZ/wDPpb/9+1/wqTdL/wA81/76/wDrVU1bVF0bSbrULpAILaMyPtbJ IHYcUATfYbHdt+y227rjy1zS/wBnWf8Az6W//ftf8K8j8Ca2+q/E0aldX8E9xqNi7iBJCVg+YbYv qFGTXsG6X/nmv/fX/wBagCP+zrP/AJ9Lf/v2v+FH9nWf/Ppb/wDftf8ACpN0v/PNf++v/rUbpf8A nmv/AH1/9agCP+zrP/n0t/8Av2v+FH9nWf8Az6W//ftf8Kk3S/8APNf++v8A61G6X/nmv/fX/wBa gCP+zrP/AJ9Lf/v2v+FH9nWf/Ppb/wDftf8ACpN0v/PNf++v/rUbpf8Anmv/AH1/9agCP+zrP/n0 t/8Av2v+FH9nWf8Az6W//ftf8Kk3S/8APNf++v8A61G6X/nmv/fX/wBagCP+zrP/AJ9Lf/v2v+FB 0+yAybS3x/1zWpN0v/PNf++v/rVyvxD1W+tNBTT9NQDUNWlFnbtvwFLdTntxn86AOlSxsXUMtrbF TyCI1waX+zrP/n0t/wDv2v8AhXOeANRS48OixhshayaVIbKaEy7wHXGSGxyDnNdPul/55r/31/8A WoAj/s6z/wCfS3/79r/hTJbXToE3TQWsa5xl0UD9an3S/wDPNf8Avr/61ZPieLTpdCuJdetIJ7G2 UzukhyMqP59vxoAuwwaZcZ8iKzkx12Kpx+VS/wBnWf8Az6W//ftf8K5D4Y6CdJ0CTUPscVvPqshu TEpwIoz/AKtB9Ac/jXZ7pf8Anmv/AH1/9agCP+zrP/n0t/8Av2v+FRSwaZbkedFZxk9N6qM/nVnd L/zzX/vr/wCtXmfxAsbyfX5NZn07S9R0rSrEiW3uJ/mBLZYgDo2AMZoA9HWwsXUMtrblSMgiNeae bK2K7TbxbcYxsFVtKnWfSLKWzt1itpII2ijJxtQqCBjHYVb3S/8APNf++v8A61AEOnjZbtHklY5G RcnJwDxXM3N9a6h8StMhtrmOYw2V2k6Rvkod0Yw2Oh6101hkxzZ6+c/86WHTLK2vJbuC0gjuZv8A WSpGA7/U9TQBzfw9t4rODXba3XZDDrFwkaA5CgbcCutqOK3it9/kxJH5jF32KBuY9SfU+9Yl41q+ uTpq0wjiWFTbrJIURhzvPUAtnH0GKAN+lrlZtZktkm+x3ibIEjNtBKCz3Yb3PJyflGOmOafNq2pQ QS3bSxlPOuIkhEX3QiuVJPc5UZ7c0AdPRXH3Ou6tZm1iZopTcwxSvNtCLBuJDdeMZwBn1qxBrV1K LZLi8t7aORpf9LGGV9pGFz90Hk/988UAdPmlrkpdRu4L2W5jvUlikgt1MojxHGGdgZcZ9v19BVm0 1S9udXhtI7qKW2Ekga4WMfvQqqcDsCCxBI9KAOkopBS0AFFFFACVj+JNAi1yxKcLcR8xSeh9D7Gt mkNOMnF3RMoqSszynQ9XufDOrPHOrCPdsniPb3HuK9St7iO6gSaFw8bjcrDuK5rxh4a/tOA3lov+ lxDkD/lovp9a57wh4kOlXAsrxiLSRsAn/lm3+FdlSKrx9pHdbnHTk6EvZy2ex6XRTQQRkdPWnVxH cFFFFABRRRQAUUUUAFFFFAFZv+Qiv/XP+tWarN/yEV/65/1qzQAUUUUAFFFFAEF3eW9hayXN3MkE ES7nkkbCqPc1yFx4qPi6O60/w1pkOq2o/d3NxdSGK3GeduMbm/AVueK9Dk8Q6FJZwypFMJI5ozIu 5CyMGAYd1OOaq+GtC1Cy1PUtV1Z7Rbu+EamGzBEaKgIByeSxz1+lAHOeHtB17wJFPJBoumX8czl5 vsUzLOFySFUOMMFzgDINYXxO8UaV4l0LRpdMu0kZbzMkJOJIvlIwy9RXrt7b/a7G4txI0ZmjaPev VcjGRXhnj3QdS0fTtAjv7PTII7R/s0c1pnfccZ3NkDH3c455JqZfCzWh/Fj6oo+GBnxRpoLIoNwo y4yOvcV6ZaaxqFx4xvdMm0a3hsY1fbOYPugDhi3Qg1554e8H6r4jjefTxEI4n2l3k24br9a6i8g1 JLNrDWPG9nFGBteJTucj0J4NcdHmUdj6TMfZVKtlJXta2t156Hmmqndb3RyDknkdOte1WnjyzNrY aVoMf9r6qbZP3EThUjwoBLueAB7ZNeKakAtpcBTlQCAfUV7H4V8J6oP+Efm1CXT1s9KhL25tY2WW YumPnzwAAecdTWuG+FnDnn8WPoU7Hwbr2ma/Lr9vpHh/7Q4G22WaUbDzllbGNxzzxiuo0fxpY396 2m34OmavGQr2Vy4DEnkFD0cH2ro+1ee6p4I1S6v9RtoU09rPUbxbs38hP2m3wVJVRjkjbwc8ZrpP EPQ6KQdKWgAooooA5e5XZcSr6Ma6K0bfaxN6qKwtRXZfzD1Oa2NLbdp8ftkUAW6KKKACiiigAooo oAKKKKACiiigAooooAyIYoY/FExjRVc2iZ2jGRvNa1ZSY/4Smbjn7In/AKGa1aAFooooAKKKKACi iigAooooAKKKKACqGsNixI9WFX6zNbb/AEeNfVv6UAU9IGb8H0Umt+sPRVzdufRP61uUAFFFFABT WRXUqyhlYYIIyCKdRQBmWvh/S9Nsbq2tLCCK3uWaSWIJlGYjng8dulfO2lgLZkKMASOAB/vGvpqT /Vt9DXzLpv8Ax6H/AK6P/wChGgDp4/D9yYCiaxpYiYbmQXwA/EVjTR+TM8W9H2MV3Icqcdwe4rsf B2qaZbaLc211cwW0xYtJ5qZ81fl2445xhuPeuTv5Yp9RuZbdNkLys0aYxtUngUAdl8F40/tHxE+x d4eEBscgENnmvStO0iw0lZV0+0htxK5kk8tcFmJyST3rzf4L/wDH94j/AOukP/oLV6rQAlLRRQBx Ws/8lc8Of9eVz/IV2tcXrH/JXfDv/Xlc/wBK7SgAqtb/APHzcfUfyqzVa3/4+bj6j+VAFmiiigAo oooAKKKKACiiigAooooAKKKSgArifGvibyw+mWT/ADkYndT90f3R7+tafi3xINHtfIt2BvJR8o/u D+8f6VyfhXw6+t3puboMbSNsuW/5aN6f4110KaS9rPY5K9Ryfsobml4K8M+ayanep8g5gQjqf7x/ pXeikRAihVACgYAHanVhVqOpLmZvSpqnGyCiiiszQKKKKACiiigAooooAKKKKACiiigAooooApH/ AJDa/wDXuf8A0IVdqvcWvnMrrI0UqfddfTuCD1FN+z3X/P4f+/S0AWqKq/Z7r/n8P/ftaPs91/z+ H/v2tAFqiqv2e6/5/D/37Wj7Pdf8/h/79rQA69sbbUbV7a9t4riB/vRyoGU/gaSx0+00y1W2sLaG 2gXpHEgVR+ApPs91/wA/h/79LWVod3f6kb7zbpV+z3LQrtiHIHr71Si2m+xLkk0u5v0VV+z3X/P4 f+/a0fZ7r/n8P/ftakotUVV+z3X/AD+H/v2tH2e6/wCfw/8AftaALVNeNJUKSKrq3BVhkGq/2e6/ 5/D/AN+1o+z3X/P4f+/a0AVE8N6bHryavHbLHeJAYFKDChSc9PX3rVrk9C1jUtU8UeINNmuUWHTZ IkiZYhlgy5Oa6L7Pdf8AP4f+/a0AWqKq/Z7r/n8P/ftaPs91/wA/h/79rQBaoqr9nuv+fw/9+1o+ z3X/AD+H/v2tAFqiqv2e6/5/D/37Wj7Pdf8AP4f+/a0AWqKq/Z7r/n8P/ftaPs91/wA/h/79rQBa rO1rQrDxDYGz1OATQ7g45IZWHQgjkGp/s91/z+H/AL9rTJYrpIXYXhyqk/6oUAN0bRbHQNPWy02A QwKS2MkliepJPJPvV+szT/tl3YQzvd4Z1yQIhirP2e6/5/D/AN+1oAtVS1XSrPWrB7LUYRNbSEFk JIBwcjp7in/Z7r/n8P8A37WmSxXUcLuLw5VSf9UtAFtVCqFUAADAA7U6sLw7dX2r6Fa3s90FklBL BYhgYJH9K0/s91/z+H/v2tJO6uNqzsWa5/VvAuga3qYv7+wWS4OA5DsokA6bwDhvxrX+z3X/AD+H /v2tZNxeX0Piaz05bpfKmheRmMQzkdKG7DjFy2N5VCKFUAADAA7U6qv2e6/5/D/36WkNtcsCDesA e6xrmmSLY/cm/wCuz/zrgrTxbr1x4+uNOhf7Raxagbd7cWhxHDtz5hlHGQexr0K3gW2hEaZwO5OS T3JPrVLStEh0mfUJYZHc31ybmQNjCsQBge3FAGZ4f1HUpvFGv6dqFzHPHZtC0BSIJtV1LYPrjjmu ieKOVQJEVwDnDDPNULLRYbLWtR1JJHaW/wDL8xT91dgwMfnWlQA0xozKzIpZfukjkfSjap/hH5U6 igBrRowIZVIIwQR1FNaGJo/LaNCg/hKjH5VJRQA3YpBBUYIweO1IsaIoVEVQvQAYxT6KACiiigAo oooAKKKKAEIrg/GvhnYX1OyT5TzPGo6f7Q/rXe01lDKVYAgjBB71pSqOnLmRnVpqpGzOJ8FeJt4T TL1/mHEDk9R/dP8ASu3rzHxX4dfRbwXVoCLSRsqR/wAsm9P8K6rwl4kGr232e5YC8iHP/TQeo/rW 9empL2sNjChUcX7Ke50tFJS1yHWFFFFABRRRQAUUUUAVm/5CK/8AXP8ArVmqzf8AIRX/AK5/1qzQ AUUUUAFFFFABRRRQAV5j8bf+QVov/X7/AOyGvTq8x+Nv/IK0X/r9/wDZDUz+FmtD+LH1RzHg7SPE l87z6BcNbxo+2SQy7Uz7r3/Kut1TUtGs7J7fxV5Gq3q97a0KFT6b6850/XNS0kMNPvZrdWOSEbAJ +lbMHxF8QRrtluIblcYxPCp/UYrihUjGNj6nFYKvVq86tby0f32OR1MqbO4KDCkHAPYZ4r6V0X/k B2H/AF7R/wDoIr5p1Ni9ncOcAsCePrX0tov/ACA7D/r2j/8AQRW2G+FnmZ5/Gj6F2jFLRXSeIFFF FABRRRQBg6wuL3P95RV3RWzZlf7rmq+uLiWJvVSKfobfLMvuDQBrUUUUAFFFFABRRRQAUUUUAFFF FABRRRQBlID/AMJTN6fZE/8AQjWpWaj/APFSzLjpaoc/8CNaVAC0UUUAFFFFABRRRQAUUUUAFFFF ABWRrh/1K/U1r1i622biNfRaAHaGvzTN7AVsVl6GP3Mp9WFalABRRRQAUUU13VELMQqqMkk4AFAB J/q2+hr5l03/AI9D/wBdH/8AQjX0Tba/peoWNzc2l/by29uzRyyq42IwHIJ6dxXztpjBrIkEEGRy CP8AeNAHfeG5pf8AhGxDaTalazC4Z2ms7LzQ4wMKTntXKX+7+0bjzHkkfzGy8i7WY56kdj7V0+kX X9m6JZJfz3+lrHd/akdImK3S4Hyj3478c1zF/ci81G5uVTYs0rSBc9ATnFAHafBf/j+8R/8AXSH/ ANBavVa8l+DFzCuq+IIGljEzvEyxlhuYAHJA74r0jSvEOl620yadewzvA5SVFPzIQcHI6/jQBpUU UUAcXrH/ACV3w7/143NdpXFax/yV3w7/ANeVzXaUALVa3/4+bj6j+VWaqsksU7yRKHV8ZBOMGgC1 RVbzbn/ngv8A33R5tz/zwX/vugCzRVbzbn/ngv8A33R5tz/zwX/vugCzRVbzbn/ngv8A33R5tz/z wX/vugCzRVbzbn/ngv8A33R5tz/zwX/vugCzRVbzbn/ngv8A33R5tz/zwX/vugCzWVr+tw6JYNNJ hpW4ijzyx/wqS/1NtNs5Lm6jVI0HPz8n2HvXmt1cX3izWwFUl3OI07Rr/nrXRQo875pbI569bkXK t2O0zT7vxVrTNK7Hcd08vZR6D+gr1KztIbG1jt7dAkUYwoFZ2jaYdFsEtre3U45dy3Lt6mr/AJtz /wA8F/77pV63tHZbIdCj7NXe7LNFVvNuf+eC/wDfdHm3P/PBf++6wNyzRVbzbn/ngv8A33R5tz/z wX/vugCzRVbzbn/ngv8A33R5tz/zwX/vugCzRVbzbn/ngv8A33R5tz/zwX/vugCzRVbzbn/ngv8A 33R5tz/zwX/vugCzRVbzbn/ngv8A33R5tz/zwX/vugCzRVbzbn/ngv8A33R5tz/zwX/vugCzRVbz bn/ngv8A33R5tz/zwX/vugCzRVbzbn/ngv8A33R5tz/zwX/vugCzRVbzbn/ngv8A33R5tz/zwX/v ugCzRVbzbn/ngv8A33R5tz/zwX/vugCxXPeEvvav/wBf8n9K2fNuf+eC/wDfdYPhZ5gdV2RBs3z5 +bp0rWH8OXyMZ/xI/M6eiq3m3P8AzwX/AL7o825/54L/AN91kbFmiq3m3P8AzwX/AL7o825/54L/ AN90AWaKrebc/wDPBf8Avujzbn/ngv8A33QByPg//koHjT/rvb/+i67euD8JPMPH3jMrECTPBkbu n7uuz825/wCeC/8AfdAFmiq3m3P/ADwX/vujzbn/AJ4L/wB90AWaKrebc/8APBf++6PNuf8Angv/ AH3QBZoqt5tz/wA8F/77o825/wCeC/8AfdAFmiq3m3P/ADwX/vujzbn/AJ4L/wB90AWaiuf+PaX/ AHD/ACqPzbn/AJ4L/wB91HPLcm3lzAoGw/x+1ACaL/yB7X/cq9WVpEk40q2CQhl2cHd1q55tz/zw X/vugCzUVz/x6y/7h/lUfm3P/PBf++6juJLk28uYFxsP8ftSew1uZvgj/kULD/db/wBCNb9c14Le dfCVgEhDLtbndj+I1uebc/8APBf++6UPhRU/iZZrnL7/AJH3TP8Ar1l/mK2vNuf+eC/991gXjzf8 JzppMQ3/AGWXC7veiRdHd+j/ACOnparebc/88F/77o825/54L/33VGJZoqt5tz/zwX/vujzbn/ng v/fdAFmiq3m3P/PBf++6PNuf+eC/990AWaKrebc/88F/77o825/54L/33QBZoqt5tz/zwX/vujzb n/ngv/fdAFmiq3m3P/PBf++6PNuf+eC/990AWaKrebc/88F/77o825/54L/33QBZoqt5tz/zwX/v ujzbn/ngv/fdAFmiq3m3P/PBf++6PNuf+eC/990AWaKrebc/88F/77o825/54L/33QA67tYr22kt 7hA8UgwymvLdV0278LayjROwCnfBKO49D/WvUPNuf+eC/wDfdUdX006zYPbXFuozyjhuUb1Fb0K3 s3Z7Mwr0faK63Qvh/XItc08SphZl4lj/ALp/wrWryS3nvvCeuHcuJE4dP4ZFr0mw1Q6nZx3NrGrR uP7/ACD6H3p16PI+aOzFQrc65Zbo0qKrebc/88F/77o825/54L/33XOdBZoqt5tz/wA8F/77o825 /wCeC/8AfdAFmiq3m3P/ADwX/vujzbn/AJ4L/wB90AB/5CK/9c/61ZqtDHI05mlAU42hQc1YoAWi o5Jo4QDLIiA9NzAZqP7da/8APzD/AN/BRcdmyxRVf7da/wDPzD/38FH261/5+Yf+/gouHK+xYqpq WpW2k2Ml5eyeVbx43PtLYycdBzVXWPENpo+ni6k33G+RYYorcB3lkboqj1rmtO1HX/GN5exxXZ8P wWUoie3EIkuiSMgsW+VQQeMZ+tAjptE8SaZ4iikl0m6FxHEQrsEZQCfqBmuF+Nv/ACCtF/6/f/ZD Wp/wjmq+DdIebSPERe0tEaRrbUY1MRXlm+dQGXvzzXFfEXxdF4j0bQ0ksbywu/PE5huIyoZSpG5G /iGamXws1ofxY+qORNFBoryT9DK+of8AHhN/u19LaOduhWBPQW0f/oIr5pv/APjwm/3a9g0/xPrG sPpejaZbtoyzWYkS8vYtzTKoAPlJnGec/Menau/C/Cz5PPv48fQ6jTPGmhaxqP2DT74TXQBJjEbg jHXqK3a4yLwNqVndXF/Z+Kr5b+42mV5IImjkKjC5TA4A9DTNE8fE3j6frlsyTR3X2MX9tGxtJZPT cfunPGD3710nhnbUUUUAFFFFAGXri5hib0YiodEbFxIvqv8AWresLuss/wB1gaztJbF+o9VIoA6C iiigAooooAKKKKACiiigAooooAKKKKAMmMH/AISmc9vsif8AoRrVFZiE/wDCSzL2+yqf/HjWmKAF pKWkoAKWkpaACiiigAooooAKKKKACsHWDm/x6KK3q53VGzqEntgfpQBo6KuLMn1c1o1S0pcafH75 P61doAKKKKAErxj4oQeLBdO+qSPL4f5wLEEIo7eaOv8ASvaKayB1KsAQRgg9DQB8vrHfDSEe885t B84+WYP+PcScfeA5z061dh8sxDytvl9tvTFfQdtoOmadZXVvaWMEUFyzSSxKnyuxHJI6dq+ddLUL ZkKAAJHAA/3jQB2d34xtr+3eC80dZUdkdh9qcfMq7RgduOwrmpmR5naKPy42YlUznaPTPeu10tIt V0aBhoekxW8bSNJNK0m1cbRzg5ySRxn8K4+/iMGo3MTRpEySspSMkquD0GecUAZrRG71GGDTop5t UzmEWuRIp9cjp+NQ2Gm69deIyumy3Euuo53m1ODGc8l3HHXrXpXwXjT+0fETbV3B4QGxzjDd69Ls NJsdKSRbC1htxK5kfy1A3MeSTQBxuneDfFz2aNqXjW7juSPmSCFWVfbJxmrX/CF+If8AoedS/wDA eOu0ooA8k1LwzrMfxF0a0fxVeyXEtrMyXRhTdEB1UDpzXQ3PhPxZaQNPp/jC5urqL5kguYEEcpH8 LEdAal1f/kr3h/8A68biu1oA53wr4th8Qxy21xC1lq1r8t1ZSfeQ+o9VPY10Vc14p8IrrTxahp85 sdbtebe7Qdf9hx/EpqPwt4ubU7mTSNZgFjr1sP3tuT8so/vxnup/SgDqaKSloAKKKKACiiigAooo oAKjllSGJpJGCogyzHoBTycV534z8TfbZW0+zf8A0dD+9df429PoK1pUnUlZGVWqqcbsoeI9dm8R akkNsrG3VtsMY6ufWu28L+HU0Sz3SYa7lGZGHb/ZHtWd4M8M/Yo11C8T/SHH7tCP9Wvr9TXXVrXq q3s4bIxoUnf2k92FLRRXKdYUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFACVz3hL72r/9f8n9K6Gue8J/e1f/AK/5P6VrD4JfIxn/ABI/M6KiiisjYKKKKACiiigDiPB/ /JQPGn/Xe3/9F129cT4P/wCSgeNP+u9v/wCi67agAooooAKKKKACiiigAooooAKiuP8Aj2l/3D/K paiuXjjtZXndY4lQl3Y4CjHJzQBW0X/kD2v+5V6sTw5r2j6rbm30i9W4+zABgQVbB6HBAyD69K26 ACqGtanaaRpU93fyGOBRtJVSxJbgAAckkkDFX6wfGlidR8M3FuLe5uAWRiltKscmFYHKs3GRjP4U AR+Dry2bTFsLWDUY1tV+/eWrQ7sknjPWuirj/Amp6fqYuzY6xqt88ZCSxX5yYSM9MDGfoT0rsKEr A3cK5y+/5H3TP+vWX+Yro65y+/5H3TP+vWX+YqZGtHd+j/I6KlpKWqMgooooAKKKKACiiigAoooo AKKKKACiiigAooooAKKKKACiiigApKWigDC8T+Hk1yyygC3UQzE57/7J9jXD+Hdcm8Oam0NwrCBm 2zRnqh9R716pXJeMvDX26I39mn+kxj94o/5aL/iK6qFVW9nPZnJXpO/tIbo6qGVJ4lljYMjjKsOh FPrznwb4l+wTLp94/wDozn92x/5Zt6fQ16MDmsqtJ05WZtRqqpG6FooorI1CiiigApruEUsxAUDJ J7Utc34huZdTvY9BsmIaUb7qRf8AlnH6fU0m7IunDnlYrWloni7Upb+8jL6bDmK1jPSQ93rT/wCE P0P/AKB8X61q2ttFaW0cEChIo1Cqo7CpaSiupcq8r+47Ixf+EO0L/oHxfrR/wh+h/wDQPi/M1tUU cq7E+2qfzP7zDvvCOnXWlCygWSzCTLcRS27YeKUdGBOeam0Dw9FoS3L/AGme7u7uQSXFzORvkIGB 0AAAHQCr1/drY6fc3T/dgiaQ/QDP9K5Twj4zl1jQbvVtTudN8q3iEskNsjq8HyliH3nnjoRxVENt u7Oq1PT7fVtMubC7UtBcxtFIAcHBGODXjvxP8Nz6Ta6NcXmr3Gouk/2eHzY1QRxhSe3U8Dk+lei+ CfE9z4is7kalaCzvoHUtAM/6t1DRtz6g/mDWZ8WtFn1XwiJ7SNpJtPnW52KMkqAQ2PwOfwpSV0y6 UlGpFvo0eOUVWN/DgeXukYjO1Bmk+2MvMlvKq+uM15ns5dj7r67Q/mHah/x4Tf7te8eFfCiWaadq VzqN7fSxWipbLcMpW3VlG4LgDJ4Ayc8V4bZ2cniG9ttL0/Mk124XgfcXPzMfQAV9NW8K29vHCn3I 0CL9AMV2YaLUdT5nOqsKldcjvZElcn/wgaC/JGp3I0s3n246fsXb527d9/rt3c7fWutoroPHCiii gAooooAq6iu6wm+maxdPbbfwn/axW/crvtpV9VNc1A22aNvRhQB1VFFFABRRRQAUUUUAFFFFABRR RQAUUUUAZiZ/4SWYdvsq8/8AAjWkKy0/5Gib/r0X/wBCNagoAKKKKAFopKWgBKWiigAooooAKKKK ACuZvm3Xsx/2jXTVys53TyH1Y0AdDp422MI/2as1FbLttoh6KP5VLQAUUUUAFFFFADZP9W30NfMu m/8AHof+uj/+hGvpqT/Vt9DXzLpn/Hof+ur/APoRoA7jQdMM/hjzo7O6v2e6Ktbx3nkqu0DDY7nP euZvVK39wrRtEwkbMbPvK89C3f61oLrVmFAPh7S2IGMnzef/AB+suVxJM7rGsSsxIRM7V9hntQB3 PwX/AOP7xH/10h/9BavVa8q+C/8Ax/eI/wDrpD/6C1eq0AFFFFAHFav/AMle8P8A/XjcV2tcVq// ACV7w/8A9eNxXa0AFYHinwnbeJbeNvMa11G2O+1vIuHhb+o9RW/RQBx/hvxXcrqH/CP+J0W11lB+ 7kHEd4v95D6+orr6x/Enhmx8T6d9lvVZXQ74J4ziSB+zKawtD8TX2i6nH4e8XMoum4s9Q6R3g7A+ j+3f+YB21FJmloAKKKKACkNFYHinxGmiWflxENdyj92v90f3jVRi5vlRM5qCuzO8aeJvssbadZP+ /cfvXX+Aen1NZvgvw19rddSvE/cIcwof4z/e+lZ/hrQZfEGoNPcljbI26Vz1dvTP869QjjSKNUjU KijAA6AV11ZKjH2cN+pyUoutL2k9ug4ClooriO0KKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooASue8J/e1f/r/k/pXQ1z3hP72r/wDX/J/StYfBL5GM/wCJH5nR UUUVkbBRRRQAUUUUAcT4P/5KB40/672//ouu2rifB/8AyUDxp/13t/8A0XXbUAFFFFABRRRQAUUU UAFFFFABXN+O7ix/4Ri80+81C0spL6FooWuZNik49faukrG8QabqWoLCNNuLKAoTvN1a+cD6Y5GK AOP8PNrepa/FqdnfeGb029qlnItrO52puBJwB1OOM8V6QK5nQfC93Ya3JqupXltPctB9nRbW2ECB d24kjJyc109ABWB42jil8KXq3FtBcQ7RvS4uDDGBkZYuORjrx16Vv1y3j64sG0L7Dd3TQ3Nw6tap HC0zu6MHH7teWGQM+1AFD4Xw/Z9Gmij1uG/hjYKlvHEU+y99uWAY8dyO1dxXG+BpP7T1HVdZuLuC S/n8uCa3hheLyAgOAyv8245JyfwrsqAENcvr1wdN8UWGpTQzPaRwOjvGhbaSe9dTTSuRg9KTVy6c +R3aKlhqtlqce+zuY5h6KeR9RVzNYt/4V069k85I2trjtNbtsb9OtVBH4i0f7jR6rbjs3ySgfXoa V2ty/Zwl8D+T/wAzpqKwrLxbYXEoguS9jc9DFcrtOfY9DW2GDKCpBB7g0009jOUJQ+JDqKQUtMkK KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigApCKWigDz3xp4Z+zO+pWSfuWOZkA+4f730q /wCC/E32lF029f8AfKP3Lsfvj0+tdhJGsqMjqGVhgg9CK8w8T6BJoF+s9qWFs7bonHWNvT/Cu2lJ Vo+ynv0OKrB0Ze0ht1PUQc0tc94V8RrrVp5cxC3kQ+cf3h/eFdBXJOLg+VnXCamuZC0lLTXYIpZi ABySe1SUZ+t6tHo+mvcMN0h+WKMdXc9BVfw5pL2Fq892d9/dHzJ39z0X6CqGnKfEmtnU5AfsFoxS 0U9Hbu/+FdRioWrubz/dx5OvX/IKWiirMAooooAq6jayXthPbw3D20kiFVmQAlD64PBrlD4BuLy2 vxqurme41AwpcyRW4iDQxnPlgA8Zzya7WigDmtH8E2Xh/Xf7Q0mSWGOSAwzQO7SCTnKtuYkjHI/G sn4reLJfDnh5LexcrfX5MaMBkogHzsPfBAH1ru68Z+OSONX0mRv9WbaZVPbdx/Sk9i6ceaSTPNow yW4K4t4O7HlmpI/LDjyJZY3b/noOGqSTi2tHYZiUjdT76aKWAJGyvIxGwLyRXJe7PpPZxjHfZL1f p2Lvh7xHceE/ElvqKRbcfLcooyJYifm/Hv8AhX0xBKk8EcsTBo5FDKw7g8ivla/IV/n/AOeLA19L eFY5IvCekpNnzFtIg2fXaK6KTvE8bMKahWdjXooorQ4QooooAKKKKAEIyCPWuVb5XI9DXV1y90uy 6mX0Y0AdNG26NT6gGnVBZNvs4T/sip6ACiiigAooooAKKKKACiiigAooooAykP8AxVEw3D/j0Tjv 981qA1lxx/8AFUTyYXm0Vc9/vGtQUAFFFFABS0lLQAUUUUAFFFFABRRRQAjHCk+grlD8zH3NdRO2 23kb0U1zEQ3SRj1YUAdSgwgHoKdSUtABRRRQAUUUUANk/wBW30NfMunELZsWIAEj5J7fMa+myQAS eAOua+W9QW0vPEd/DpouLmya6dra3Rcs+T1OO1AE76xZI2POBx/dBIqxb3cF0Mwyq/sDyPwqQaG8 Cgapqtjo8hXMVsMM3tv9qoarpN1p4WW8twg6xX9p80bemcUAemfBcH7b4jPbzIf/AEFq9VrzP4If Z38OahMsu+9kuj9oGMBcD5ce2M/rXplABRRRQBxerf8AJXvD/wD14XFdpXF6t/yV7QP+vC4rtKAC iiigArN13QbDxFpkljqUAlhfkHoyN2ZT2IrSooA4LTNcv/BmoxaJ4qmM1jKdlhqzdG9I5fRveu8B BAIOc1V1PS7TWNPlstQgSe3lGGRh+vsfeuJttQvvhxdx2OsSyXfhyVtlrft8z2hPRJf9n0NAHoNJ TY5EljV42V0YZVlOQR6g1Fe3sNhayXFw4SKMZJo3Bu2rKut6zDotg1xMQW6Rp3dvSvNrO1vfFmuM XYlnO6WTtGvt/Sl1C+vPFetIsaEljthi7Ivqf6mvRtB0WHRLBYI/mkPMj45Zq7tMND+8/wADh1xM /wC6i3YWMGnWcdtbIFjjGAPX3PvVmkpa4W77nalbRBRRRQMKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKACiiigAooooASue8J/e1f/r/k/pXQ1z3hP72r/wDX/J/StYfBL5GM /wCJH5nRUUUVkbBRRRQAUUUUAcT4P/5KB40/672//ouu2rifB/8AyUDxp/13t/8A0XXbUAFFFFAB RRRQAUUUUAFFFFABUc5K28hBwQpIP4VJUVz/AMe0v+4f5UAQaTI82l28kjFnZMlj1NXKo6L/AMge 1/3KvUAFc1rWhapceJbfWNKvLKGSG1a323UDSDDMGJGGXB4Arpaiuf8Aj2l/3D/KgDA8P6JqNrrt /q2p3tncSXkUcWLWFo1GzPPLNk8/pXSVgeCP+RQsP91v/QjW/STurjkrOwUUUUxCYoxS0UAVb3Tr TUYjHeW8cyHs65rEbwxc6exfQtRlt+/kTfPGfz5FdJRScUzSNWUdE9Dmx4jvtMO3XNNkjUf8vFt8 8f4jqK2bHVLPUohJZ3MUy/7Lcj6irZUEYIyD61i3/hXTruTzoka0uByJrc7D+OOtKzRV6ct1b0Nr NLXMgeI9H+6YtWtl7H5JgP5GrVl4s0+5lEFwz2Vz0MVyuw59j0NHMuonRla8dV5G5RTQwYAggg9C KWqMhaKSloAKKKKACiiigAooooAKKKKACiiigAooooAKrX1lDqFnJbXCbo5Bgj+tWaShO2qE1fQ8 mvrO98Ka2pjYhkO6KTHDr7/yIr0fQ9Zh1vT1uIvlccSJnlG9KNc0WDW9PaCXhxzG/dGrziwvb3wp rbCRCCh2yx9nX1H9DXdpiYf3l+Jxa4ef91nrJNc54iupdQu49BsXIknG65kX/llF3/E1cvfEVrb6 F/aUTCVXGIlHVnPRfrmmeG9KksbaS5vTuv7s+ZO3p6KPYV58r35T1KVox9o/l/XkalpaxWVrFbwK EjiUKoHpU9JS1Rk3fVhRRRQIKKKKACiiigArlviB4RXxf4ea1jKpeQt5ts7dN390+xHH5V1NJigD 5Xns7jTruS0nV7S6jOJLaccfh7VGPMGSscNt6yE/yr6a1fw5pOvIqarYW90F+6ZF+YfQ9RWPa/DD wnaTeamjxO2cgSuzgfgTisnSPRhj2opNfj/VvkeR+BPA0nizVobiSOT+yoHDzXEg/wBcR/AvqPU1 9DKAAABgDoKZFDHBGscKLHGgwqIMAD2FSVolZWOKpUdSXMwooopmYUUUUAFFFFABXO6ku2/l98Gu irB1hcXuf7yigDS0tt2nx+2R+tXKztFbNow9HNaNABRRRQAUUUUAFFFFABRRRQAUUUUAZaZ/4SWf 0+yr/wChGtMVlxj/AIqac8f8eqfX7xrUFABRRiigApaSigBaKKKACiiigAooooAr3x22Mx/2TWBZ ruvIR/tCtzVG26fL74H61j6aM38Xsc/pQB0dFFFABRRRQAUUUUAZfiaSWLwvqrwf61bSUrj12GvC fhzlNQvDGAWFihUepz/jX0PLGs0TxyDKOCrA9wa+c9W0bUvAHima3t7loA/NrLIuY54s5Cn3FAHf /DXRtI1Pwu19eW1ve6jcyyfbWnjDsrbiNuD0GMfnXOxJDbWvi+x05/M0q2Mi2xzuCkoSyg+gNYLa rpc00s2q2d/YXco/eHT5SI7n2I96hvdbuf7M+w2kKaVprAosEfzTTZ7E+poA674GO66zqUaE+U1n C7Dtu7fpmvaK4T4UeEpvDXh5575Cl7fMJHjPWNAMKp98cn613dABRRRQBxerf8le0D/rwuK7SuL1 b/kr2gf9eFxXaUAFFFFABRRRQAVDdWsF7ayW11Ek0EqlXjcZDD0IqakNAHnub74Yz4/fXvhSRv8A ek08k/mU/l/PP8SeJD4juo47Fi9kD+62f8tT/e/wrS8beJRcmTS7RgYRxO46P/s/T1rntH0PUfA7 Q+IVsTeaS2WmtQMy2yn/AJaoP6V104+xXtJL0OSpL2z9nFnoHhTw4ujWnnTqDeSj5z/cH90V0NVN M1O01fT4r2wnSe2lGUdD/nB9quVzTk5vmZ0wgoLlQUUUVJQUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAJXPeE/vav/1/yf0roa57wn97V/8Ar/k/pWsP gl8jGf8AEj8zoqKKKyNgooooAKKKKAOJ8H/8lA8af9d7f/0XXbVxPg//AJKB40/672//AKLrtqAC iiigAooooAKKKKACiiigAqK5/wCPaX/cP8qlqK5/49pf9w/yoAraL/yB7X/cq9VHRf8AkD2v+5V6 gAqK5/49Zf8AcP8AKpaiuf8Aj2l/3D/Kk9hrcxfBH/IoWH+63/oRrfrA8Ef8ihYf7rf+hGt+lD4U VP4mFFFFUQFFFFABRRRQAUlLRQAmKrXum2moxGO8t45lP99c/rVqiiw02ndHNHwzdacxfQtRkgH/ ADwn/eRn+ooHiS900hNd02SJf+fiD95Gfr3FdJSFQRgjI9DU8ttjX23N8av+ZWstTtNSiElncxzK f7rcj6irQNYl94U0+6l86BXs7nqJrc7D+PY1W/4qPR/+eerW6/8AAJQP5Gi7W4ezhL4H950tFYdl 4r0+6l8iZ3s7nvFcrsP+BraDAgEHI9aaaexnKEoO0kOooopkhRRRQAUUUUAFFFFABRRRQAUUUUAJ iuf8WeHU1iyM0QC3cIJRjxuH9010BrnPEV3NfXMWhWLETXA3TuP+WUXf8TTVR03zIaoqt7j2OF0D UIbLVbZr4M9rFIWC5+VGPG7HtXrcbrIiujBlYZBHQiuJ8U+EI0skutMiwYECyRr/ABKO/wBareC/ E32Z1028f9yxxC5P3T/d+npXXUgq0faw36nFCo6U/ZTenQ9CopAc0tcZ2BRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABWNri4lib1BFbNZeuL+6hb0YigBNDb5Jl9wa1axdEbFxIvq ua2qACiiigAooooAKKKKACiiigAooooAyox/xU8/XP2Rf/QjWoKzk/5GGY8f8ey/+hGtEUAFLRSU ALRRRQAUUUUAFFFFABRRRQBQ1hsWOPVgKz9JGb9fZSaua2cW0Y9Xqtoq5unPon9aANyiiigAoooo AKKKKACqGsaJp+v2DWeqWsdxA38LjlT6g9QfcVfooA82m+CulmUmz1bU7aI/8sw6sB9CRW34d+Gm g+HblbuOKW8vF+7PdNvKn1UdAa66igBKWiigAooooA4rVf8Akr+g/wDYPuP512tcVqv/ACV/Qf8A sH3H867WgAooooAKKKSgANcp4y8Tf2fCbGzf/SpB87D/AJZr/ia0PE3iCPQ7LKkNdScRJ/U+wrhd A0WfxJqjy3DOYQ26eU9WPoPc11UKSt7SeyOWvVd/Zw3Ze8HeGjqMwv7xD9mjbKKf+Wjev0FejbRj GBj0psEMdvCkUSBI0G1VHQCpKyq1XUldmtGkqcbI4LU9Dv8AwXqEut+FoTPYSnff6SvRvWSL0b2r q9D12x8RaZHfabMJYX4I6Mh7qw7EVo4ridc8NX2ialJ4h8IqBct815p+cR3Y7kej+/f+eRqdvRVT Sr46lpdveNbzWxmQOYZlw6Z7EVboAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigAooooAKKKKAErnvCf3tX/AOv+T+ldDXPeE/vav/1/yf0rWHwS+RjP+JH5nRUUUVkb BRRRQAUUUUAcT4P/AOSgeNP+u9v/AOi67auJ8H/8lA8af9d7f/0XXbUAFFFFABRRRQAUUUUAFFFF ABUVz/x7S/7h/lUtRXP/AB7S/wC4f5UAVtF/5A9r/uVeqjov/IHtf9yr1ABUVz/x7S/7h/lUtRXP /HtL/uH+VJ7DW5i+CP8AkULD/db/ANCNb9YHgj/kULD/AHW/9CNb9KHwoqp8TCiiiqICiiigAooo oAKKKKACiiigAooooASjFLRQBUvtMs9RjMd5bRzKf768j8axT4bvNNJfQtRkhX/n3uP3kZ+ncV0t JScUzSNWUdE9Dmx4lu9OITXdOkgHT7RB+8j/AMRW1ZalaajEJLO4jmT/AGW6fhVllDAggEHsaxL3 wpp9zKZ7cPZ3PUS27bDn3HQ0tUVenPdW/I3M0Vytze654bi827kh1GyDBS5+SVcnH0NdSh3KD6jN NO5M6bik73THUUUUzMKKKKACiiigApKKRiACTwB3oAo6zqsekadJdScleEQdXY9AKp+G9LltIJLy ++a/vD5kx/u+ij2FUrQf8JNrxvnGdOsWK24PSWTu30FdRioWrubz/dx5Or3/AMgwK858ZeGvsEza hZp/o0h/eKv/ACzb1+hr0amTQpPE0cqh0cYZT0IropVXTldHHVpKpGzOV8G+Jvt8QsLx/wDSYx8j H/lov+Irra8r8Q6JP4c1NJbdnEDNugkHVT6H3ruPDHiFNcsvnIW6iGJU9f8AaHsa1r0lb2kNmY0K rv7Oe6N2ikpa5TrCiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKz9ZXNln+6wrQqpqa7 tPl9hmgDL0hsX4HqpFb9c5pzbb+I+pxXR0AFFFFABRRRQAUUUUAFFFFABRRRQBmR/wDIyT8/8uq8 f8CNaQrMQ/8AFSzDA/49V5/4Ea06ACiiigApaKKACiiigAooooAKKKKAMnXG4hX3Jpuhj95MfYCm 62f38Q9FJqXQx+7mPuKANWiiigAooooAKKKKACiiigAooooAKKKKACiiigDitV/5K/oP/YPuP512 tcXqv/JYNB/7B9x/Ou0oAKKKKACqGr6rBo9g9zcHgcKo6u3YCrN1dRWdtJPcOEijG5mPYV5brGqX fijWESFGKltkEXoPU/1rehR9o9dkYV63s1ZbsZFHfeLddOTmSQ5Zv4Yk/wAK9P0zToNLso7W2XCI Ovdj3J96qeHtCi0OwES4aZ+ZZPU/4CtanXrc75Y7IVCjyLmluwpaKK5zoCkpaSgDA1/xRpWmiaxm 1u206/KZUyDeyZ6Nt71m+F/F6SwvFrOpW7b7gxWFzIogN6mB8wQ+5IyODitzVfDljq15Z3kytHd2 cgeKeLAfHdT6qe4NcKPD+q6u19p19pLpeX1yTfatPtKLAGyiQc5+7gAcYOSaAPT6Wq9xd22nwB7q 4igiGFDyuFH5mpwc0ALRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUVznivxPP4fk0+C1sVu 7i+laOMSTCJAQM43HjcegHegDo6Kwr3xnoukyrBqt9HZ3XlrI8D5LIG9SBjHv0qfUfFOjaSYBfah DEZ13x8lty/3uM4X3PFAGtRWRqPivRdKkhjvdRhiaZd6DJb5ezHGcL7niq3iDxnpGgQyLcXsH2sQ NNFAWPzjGRyMgAngE0AdBRVTSrw6jpNneFNhuIUl2Zzt3KDj9at0AFFFFACVz3hP72r/APX/ACf0 roa57wn97V/+v+T+law+CXyMZ/xI/M6KiiisjYKKKKACiiigDifB/wDyUDxp/wBd7f8A9F121cT4 P/5KB40/672//ouu2oAKKKKACiiigAooooAKKKwtR1K7sddyo8ywjtg88arl1yxG8euMcj0+lAG7 UVx/x7S/7h/lXNaHd3Gs29mtxfypmyjnHlEK0xYnLZx0GBwPXmtLSrua70i6Mz+b5UksSTYx5qqS A3p7cccUAWtF/wCQPa/7lXqo6J/yBrX/AHKvUAFRXP8Ax7S/7h/lUtRXP/HrL/uH+VJ7DW5i+CP+ RQsP91v/AEI1v1y/hmR4fh7FJG210t5GVvQgtg1Wk8QajBJawTYF2lnNM4VfknwqlXHtknI7H8KU PhRU/iZ2NFZdlB5Zt5f7VmuPNXOGZSs3GcqMcevFaYqiBaKKKACiiigAopDXNeJfG1l4fzCo+03m P9UpwF/3j2q4U5VJcsVdkTnGCvJnS0teNXvxC167cmO4S2TPCxIOPxOapDxhrwfcNVuM+5GPyxXd HLKrWrRxvMaaeiZ7lRXk2lfEvVLWVRqCpdw9yBtcfQjg16TpGs2et2a3NjLvjJwQeCp9CK5q+FqU fiWh0UcTTq/CzQooornNwooooAKSlooA5/xt/wAi3L/10j/9CFbsf+rT6CsPxr/yLcv/AF0j/wDQ hW5H/q0+gqV8TNpfwo+r/QfRRRVGIUUUUAFFFIaACsbxHFf3dpHZWAKi5fZNMD/q07n8elN1u5u5 L6y0yxn+zSXW93nwCURcZCg9zmo9J1m8uNfutPurYxxRxh4WY/OQDtJYdsnkVLd9DWEXH30a9jZx afZxW1ugWOJdqgVZpKWqM223dhRRRQIqalp0GqWUlrcpmNx17g+o968vnhvvCeujacPGco38MiV6 3WT4g0OHXLAxNhZk5ik/un/CuihW5Hyy2Zz16POuaO6JtH1aDWbBLm3PXh0PVG9DWhXk2lald+Ft ZdZkYANsniPceo/pXqVpdRXttHPbuHikG5WFKvR9m7rZjoVvaKz3RPRRRWBuFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABUN2u+0lX1Q1NTXG5GHqCKAOZtW23MR9HFdRXJg7WB9DXVqcqD60ALR RRQAUUUUAFFFFABRRRQAUUUUAZiA/wDCRTccfZV/9CNaQrPT/kYJv+vZf/QjWgKAFooooAKKKKAC iiigAooooAKKKKAMLWTm9A9EFXNFGLRj6uaoaq27UH9gBWlpAxYL7sTQBeooooAKKKKACiiigAoo ooAKKKKACiiigAooooA4vVP+SwaF/wBg6f8AnXaVxeqf8lg0L/sHT/zrtKAEpGYKpLHAHJJpTXC+ NfE2S+mWT8dJ3B/8dH9a0p03Ulyozq1FTjdmb4t8RtrF19ktCTaRtgY/5at6/T0rp/CPhoaTb/ab pQbyVe//ACzX0+vrWX4K8M42anepz1gQjp/tH+ldzW9eoor2VPbqYUKbk/az3CloorkOsKKKKACi iigAqG6ilmtZY4JjBKykLKFDFD64PBqaigDyzVPCE/8AwmOmWOoXH9rxXkouGubskzW6RYZ1AHyh GO0cAHkiug07x/ZTalP9ruoI7W4uha6bEgLTTYO1nIH8JbofQV1GpWCalYz2zu8XnRtH5sRw6gjB we1eZ33gq40TxBbtoFpBp2maXavLJqdwBK5cg7mA6syqDgHgE0AerUtcBo/iO90DQ7a71DSr7+xp WDm/uLsSzqHPEkiY+VTkcD7ua75WDqGUggjII70ALRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABXNe NdH1PW9MFpp6afNDJuWeG8DY5HyurDkFTzXS1l+Jr+bSvDOpX1tt8+3t3kTcMjIGRkUAcTFofiK2 8RXltY/Y7hv7JtrWa6vkfbIQGBZSOpHcHrxUlz8OLy1ktW02aG5VbCOxlFzNLFgJn5h5Z5BycqaT w98SJ306eTUk+3yLcwW8H2OExvI8qEgFGPABGN3Q1s33xCtrGS6J0vUZre0kWG4uYkUxxynGUznt kAnpmgDK1H4d3KXwk0v7K9vLZxWkkM080axhBjjacspB6Gp73wXqlo2ow6E+nfZNSs47aRbsOWh2 JsG085GPXoauWXjIjxJqOkzq1zcLfiC3hhUbki8tWZ3PZQWPJ+gp9l8RtJvdVjtESZYJpzbw3TFN kkg4xjO4AkEAkYNAHQaPZvp+i2NnKys9vbpExXoSqgHH5VdoooAKKKSgArnvCf3tX/6/5P6VD4q8 e6R4YtrgSXCTX0UZZbWMlmJ7bsZ2j3Nee+APixH/AGrd2+twxW0Fy7TiaJWIRu4I5496uMkoyRnK Lc4y7HtVFV7K+ttRtUubKeK4gcZWSNgyn8RVioNAooooAKKKKAOJ8H/8lA8af9d7f/0XXbVxPg// AJKB40/672//AKLrtqACiiigAooooAKKKKACmeUnmmXYvmFdpbHOPSn0UAU7nSbG7hjhntIXjj+4 pQYX6elQanqlnolvHE6kNIrLBDHEW3bRnACjgVp1g6z/AMjNon+7c/8AoAoA8g8IfELxRJ46iivp Z5bZ5CtxaiElYU7kKBkba9k/4SnTv+nv/wABJf8A4muX8MAD4ieL2wM7rfnHP3K7HJ9aAK3/AAlO nel3/wCAkv8A8TXn/wAV/HGpWdhZpoD3NvBIzfaLgwMhB42rlh35/KvScn1rlfifz8O9Vzz8qdf9 8UAUvhv4oEvgqGLWIJlYM6oEtXZXjPQ8AjuRXV/8JHpWUPl3OYxhD9ik+Ueg+WpbHjT7UDgCFOB/ uip8n1oC9zKttT8P2dw09tZyxSt1dLGQH/0Hirn/AAlOnel3/wCAkv8A8TVnJ9aMn1oArf8ACU6d 6Xf/AICS/wDxNH/CU6d6Xf8A4CS//E1ZyfWlBORzQBNYX0GpWUV3aPvglG5GwRkfQ1YrE8F/8ilY f7rf+htW3QBi+LdbOg6DNdJgzN+7iB/vHv8Ah1rxGWWSeV5ZnZ5HO5mY5JNesfEDQdT12Gyj06JZ FiZmfLhecYHX8a4n/hXniLtaR5/67LXs5fOjTp3k0mzycbGrUnZLRFHQvDGo+IXb7FGBEhw0shwo Pp7mt24+F+rRRF4ri1mYDOwEqT+dejaDpq6TolrZqgRo4xvA7t3/AFrRrnqZlVc/c2NqeAp8vvbn zzc2s1lcvb3MTRTIcMjDkVseENek0LW4n3H7NOwSdO2D0P1Fa/xRMJ8RW4jx5otx5mPqcZriz04r 1oNYiheS3R5sk6Fa0XsfRY5AparaeXOnWxk++Yl3fXAqzXzLVmfQp3VwooopDCiiigDA8a/8i3L/ ANdI/wD0IVuR/wCrT6CsPxr/AMi3L/10j/8AQhW5H/q0+gqV8TNpfwo+r/QfRRRVGIUUUUAFVb+5 e2tJXgjE0yqWSHdguR2FWTXGaxrNld3FxBq2j3OLOURrNFIN6lvulcENz7Um7F04OTMiPUo7/UIZ pbbUobO5lLLKMlrSY8Ha4z8p6FT0rutL0e30vzWiaWWaYgyzTNud8dMn09qzfC+kLYPc3NtdXjW1 yc+RdR7WVx1bnnmuipRXc0rTTdo7C0UUVRgFFFFABSYpaKAOa8XeGxq9t9otlAvIhx/00Hp/hXLe E/Eb6Ldm1uywtJGwwP8Ayyb1/wAa9NNcR418M7g+p2SfMOZ41HUf3h/WuuhUUl7KexyV6bi/aQ3O 2Rg6hlIIIyCO9Org/BXibYU0y9f5TxA5P/jp/pXd5rCrTdOXKzelUVSN0LRRRWZoFFFFABRRRQAU UUUAFFFFABRRRQAUUUUAFFFFAHKzrsmkX0Y10ts262jb1UVz9+u2+mH+1mtzTm3WEJ/2cUAWaKKK ACiiigAooooAKKKKACiiigDMRv8AipJlx/y6qc/8CNaQrNT/AJGSX/r1X/0I1pCgBaKKKACiiigA ooooAKKKKACiiigDm9QOb+Y/7WK2dMGNPi9wT+tYd2d13Mf9s10FmNtnCP8AYFAE9FFFABRRRQAU UUUAFFFFABRRRQAUUUUAFFFFAHF6p/yWDQv+wdP/ADrs64zU/wDksGh/9g6f+dbniLXotDsDIcNO /EUfqfU+wpxi5OyJlJRV2Z/i/wASjSrc2lq3+mSjqP8Almvr9fSub8I+G21e5+2Xak2kbZwf+Wrf 4etU9G0q68T6u7zOxTdvnlP8h716lbW0VpBHBAgSKMbVUdhXZUkqEPZx3e5xwi68+eWy2JFAUAAY A6U6iiuI7gooooAKKKKACiiigAooooAKgvLSK+sp7W4XdDPG0bj1UjBqeigDhbLwjr8Gq2kN1qNp c6PbwfZZElVma5h/hV4z8u4f3gee4rf1HxNpuharY6Ze77f7WNsExTEORwE3dAfQVt1R1jRrHXtM lsNSgWa3lGCp6g9iD2I9aALtLXAWOrX/AIBvItK8RTPc6NI2yy1RusfpHL/Q/wCR3qsHUMpBBGQQ eDQA6iiigAooooAKKKKACiiigAooooAKpazpqazo93p0kjRpdRNEzqOVBGMiuL1uyi1Px1qqXmrX lhFa6bDLE8N00SxsWfLEZweg61mWvj/xDPY6dBa2iy3S6cl3cSNbtJ5pJIXgEbQQuS3vQB0Vn8O4 beeC5udVu7u7hngkEsiqPlhzsTAGMfMeetO1PwAL+W+WHWb21sb6YXE9pGFKNJkEnJGQCQMiqM3i rxDeahPBYx6dY/Z9OivZY74NvBYHcnB6cde1Zi+MrhNRu9Xt4cPfWFgIoZnIjieV2G5vYevfigDq X8D2w1mfVre7mg1CW6+0CZVHC7VVoiP4kIXoe/Ipmk+A7fR9TWa3u2NnHI0kdq0EZ2ljn/WY3EAn jnis2XxfrGmHUYNQSyuJdKeCa6ltlba9vISGwCfldevuKr3nj7VJFtm0y1R49TupUsZBC0h8mMcv sBBYsc4GRxQB6JS1wMPi7Xr46Xp8dnbWGpXbTFpbxWETJHjlVBzls9M8YNaPw3mnuPDty91Isk39 oXIZlYsv3z90nt6UAdbXKeLNXu5L620DR5jDeXSGW4uV5NtADgsP9ongfia6quJsAJvG/ia4cHzI 3t7dc9kEYb9SxNc2MrOjRlOO5UVd2J7LQdM0zTJbOK2jFvIpE5k5Muepdjyc+9clZaFYeCdci1HS ZIbmw1CdbSVDhmt9/wB3awPTI5Bre8cQwT+G3FzdLbosqMNyF1lYHiMqOWB6YFcEkUS63ply0EFj eJdxCOwisZIBOC2Cx3cHaOR6V4uDhOpCU5Set7o0lZOx3WoWcnhW4k13Qoysandf2MfCXCd3UdnH XI613lpdQ3tpDc2ziSGZBIjDoykZBrHZFk3I3KtlT9Kp/DZ2Pgm0jJJWGSaFD/srIwH6CuzKcROr BwnrYmorHVUUUV65mFFFFAHE+D/+SgeNP+u9v/6Lrtq4nwf/AMlA8af9d7f/ANF121ABRRRQAUUU UAFFFFABRRRQAVhaz/yMmi/7tx/6AK3awtZ/5GTRfpcf+gCgDyPxp4k1zwd4u1qXT4TbpqMkZW6k iyGCJyFzweTXofw/8Q3fifwpDf38apP5jRsyjAkx/EB/npWnqkUF8htb3ShewAhsOgZc/jV6CGK3 gjigiSKJFwsaLgKPQCgDI8Z6wdD8JaheJkzeX5UIHUu/yr/PP4V4VB4r8Salpn/CLKDcxTAQLbmP 95uDZ69c5HevWPFs7at400PQlhklhtmOoXKKfvBeEz+NdZDpGnxX7ahHYW0d5IPnmWIBznrzQBNb kQ2dukpVGWJVIYgcgDNSedF/z1j/AO+xWF4k0HT/ABA8Mep6ZcXawZMbRyFAM9ehHpVBfhZ4VZQT pswyOn2mTj9aAOs86L/nrH/32KPOi/56x/8AfYri7j4a+GYZNqaJdSjGdy3MmP51YX4WeFWUE6ZM CRnBuZOP1oA6zzov+esf/fYpyOjt8rq30Oa5L/hVfhT/AKBsv/gTJ/jWtoPhLSfDUsr6VbPC04Cu WlZ8gdOpoAueC/8AkU7H6N/6G1blYfgz/kU7H6P/AOhtW5QAlFLSUAFcz4u8YQ+HoPJh2y38g+SP PCD+83+FaPiTWk0HRprxgGcDbGp/ic9BXh91dTXt1Jc3Mhkmlbc7Hua78DhPbPmlsjhxmJ9kuWO4 l1dTXt1Jc3MjSTSHc7N3NafhfRX13XYLYKfKVhJM3oo/x6VW0fRrvXL9bSyTLHlmP3UHqa9l8O+H bXw7YCC3G6RuZZSOXP8Ah7V6WMxUaEOSO/5HDhcPKtLmlsayjAAA4FOpKWvnj3AooooAKKKKAMDx r/yLcv8A10j/APQhW5H/AKtPoKw/Gv8AyLcv/XSP/wBCFbkf+rT6CpXxM2l/Cj6v9B9FFFUYhSGl rP1y6ubLSLieyi824VfkXGec4zjvjrQNK7sVL3xLBZ3s1v8AZbuZbcAzyxJuWLIyM85PHPAplxpV vq+qaZrNo0T+UcluokQg4P1BPH41hTG4stblSfUzHqLiJYpUgBFyrZGHj77SDyO1dXoumLpGmpaL IZCCzM5GMsxycDsMnpUrU2klBXW5fFLRRVGAUUUUAFFFFABRRRQAlDAEEEZBpaKAPNPF/hs6VcG8 tFItJG5A/wCWTf4V0Xg/xL/akAs7tv8AS4hwT/y0X1+vrXR3NvFdQPDMgeNxtZT3FeXa3pFz4Y1Z JIGYR7t8Eo/kfeu2nJV4ezlutjhqRdCXPHbqerUtY3hvX49csA/C3EfEqeh9R7GtiuOUXF2Z2Rkp K6FooopFBRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAHPaqu2/f3ANaekNmwUejEVR1pcXaH1SrWiN/ ozj0f+lAGlRRRQAUUUUAFFFFABRRRQAUUUUAZaZ/4SWUZ4+yLx/wM1pisxCP+EnmGOfsi8/8DNaY oAWiiigApKWkoAWikpaACiiigApDS02Q4jY+gNAHLSndI59WP866iEYgjHoorlhyw9zXVqMKB6Cg BaKKKACiiigAooooAKKKKACiiigAooooAKKKinnjt4HmmcJGg3Mx6AUAcL4l1CHS/ilpF1cHCR6b PwOpOeAKw3a+8W67xzJIeB/DElZvibVZfEvxCsPs8RK/Z3jgQDk89T9a9S8NaBHodjtOGuZOZX/o PYV2QaoRbfxHHUi68kl8Jd0jSoNIsEtrccLyzHqx7k1epKWuRtt3Z1pJKyCiiikMKKKKACiiigAo oooAKKKKACiiigAooooArX9hbanZS2l7Ck9vKu143GQRXCxXF98M7lba9eW98KyNthuDlpLAn+Fv VPQ16HUU9vFdQPDPGskUilXRxkMD1BFACwTx3MCTQyLJFIoZHU5DA9CDUleeSwX3wzuWuLNJr3wr I2ZbcfNJYE/xL6p6jtXd2N9balZxXdlMk1vKu5JEOQwoAsUUUUAFFFFABRRRQAUUUUAY2peEtD1i /W91LTLe5uVUKHlXPA6D070az4e0PUIkn1axtpEtUOHcYCIOSOP4eOnStms7xEjSeG9URFLM1pKA oGSTsNAHOXfh3wzqXiGG+1B7W7XU4I47K3ZflIjBbKEdQQRx04rfvNI0dILy4vLS28qS3Edwzr8p iQEgEeg5rg7HVrq60/wtBpCXS3FnbSwzLLbuiiUW/wAoJYAY3Dr0rKh1CaWaytor/XJ7i5028N9B eh9hlEJ4UEYPP93I6UAd7daRolp4HvYtLlg0zTruAs91GmRsYctzycqe/rWlJ4d0i+0W10+ezhns oEUQqw+6AMAgjkcV5ld6XqNt4amsFuNVnt7nw4lw0UhZgsyuoCqMccHG30FbtrJeWHxA0u0S61O5 tjbRxmA+YFgxHncxI2uCepzkGgDsLjwpot1pkGnT6bbvZ253RRbcBD6g9RVvTdKstHtfs2nW0dtA GLeXGMDJ6nFWxS0AJXEa0P8AhH/G66hN8un6xGkEkh6Rzp9zd6BlOM+oruKq6jp1rqtjLZ30KT20 y7XjYcEVlWpRrU3CWzGnZ3MDVNLttXsmtL1C0ZIYbWKsrDkMCOQRXF6tpOmLq1lZ6fdXd/raXUbB pblpTaxqwZyey5Ax75rY1zTvEfg/RLyfSbqLU7GCIskd2CZ4B7MOHA6888VwHw21/wAS6j4gvLSw Ftcy3m6eaS5BCo3HzkqM+2K8ihgMRR5rS06LuaOaZ6l4j1caTprvEplvJz5NpAv3pZW4AH06n2Fb vhjR/wCwfDljpxYO8EYEjj+Jzyx/Mms/Q/CX2K//ALU1a7bUdVK7VlZdscCnqsa/wj36mukrvwOE WGhZ7vciUri0UUV2khRRRQBxPg//AJKB40/672//AKLrtq4nwf8A8lA8af8AXe3/APRddtQAUUUU AFFFFABRRRQAUUUUAFYOtf8AIyaJ/wBvH/out6sHWv8AkY9D/wC3j/0XQBeqhres2nh/SJ9Rv2K2 8IGdoyWJ4AHuTV+s3xBolr4i0S50293eTMv3l6qRyCPxFAHG/DjXrXxP4n8Q6t8yXMvlrFC/VIBw Ofr1r0SvO/g94etbDQJNVRne6u3eJi3RVRiAB9cZNeiUAZOv6E2uwwxrqd9p/lMW3Wkm0vnsa5mX wjawXgtJvHGsx3JQyCJ7xQ20dTj0rpPEviS38MWEN3c289wJp1gSOAAsWYHHX6V5p4njkvPD1/qN 1pckd/qeqb4EuU2ypBFHkj2BCsPxoA27bR9Ju9Oub+Dx9rL2tqcTSfagAnpnjPPb17UXGjaTaadb 38/j7WVtLk4hl+1Ahz3xx27+nem+J/7L/wCEx8HTrb7YbtUM0aDEbINvlbh0O1mGKbbDSrH4j+JY JIA8UFjJNFC4zGjMoaYKOg3cfrQBaTw3YSasNMj8d6y18U3iFbsFiMZ9PTnFdP4e8NvoU8sjaxqW oeaoXbdybgmD1Fed+HIjH8N4rq3siL/SdUjuX8pd0kinafqfkfGPavRvDviux8Sy3SWMV1E9qyiV LiLYwz04/CgC74M/5FOx+j/+htW5WH4M/wCRTsvo/wD6G1blABSUtIaAPNvitek3FhZA8BWmYfoP 6156TxXq3jHwXe+I9Wiura4gjRIRHtkznOSe31rAPwr1Qgj7bZ8/73+Fe5hMTRpUVFvU8bE4erUq uSWh2XgfRo9J8OW7BR59wollbuSeg/AV0VR20XkW0UX/ADzQLx7DFS141SbnJyfU9anFQiooKKKK gsKKKKACiiigDA8a/wDIty/9dI//AEIVuR/6tPoKw/Gv/Ity/wDXSP8A9CFbkf8Aq0+gqV8TNpfw o+r/AEH0UUlUYhVR9Stk1KOwMn+kyIXCAZ4Hr6Umq6lDpWny3c5+SMcDux7AVm+G9NmRZdT1AZvr w7mB/wCWafwqKlvWxpGC5XKXy9TRk0q1l1aLUnjzcxRmJGPQAnJ/GrtFLVENthRRRQIKKKKACiii gAooooAKKKKACqOraZBq9i9rcLlW6MOqnsRV6kpptO6E0mrM8lBv/CWu+kkZ/wCAyp/n8q9O0vU4 NWsY7q2bKt1B6qe4NU/EmgR65YleFuY+Yn9D6H2NcDoesXPhnVXjnVhFu2zxHt7j3rtaWIhdfEji TeHnZ/Cz1alqK3uI7mBJoXDxuNysO4qWuE7twooooAKKKKACiiigAooooAKKKKACiiigDH1xfnhb 1BFLojczL9DUmtrmCJvRsVX0RsXMg9V/rQBt0UUUAFFFFABRRRQAUUUUAFFFFAGUh/4qmYf9Oa/+ hmtQVmIP+Kom/wCvRf8A0M1pigBaKKKACiiigBKWiigAooooAKiuW220p9FNS1XvztsZj/s0Ac9A N08Q9WFdTXM2Qzewj/aFdNQAUUUUAFFFFABRRRQAUUUUAFFFFABRRSUABOBmvN/GHiQ6lObGzY/Z Y2wxH/LRv8K0/GvibylfTLJ/nIxO4P3R/dHvVbwV4Z81k1O9T92vMCEdT/eP9K7KMFTj7WfyOKtN 1Jeyh8zJ0DR5dL+JWiG5GJZ9Pnk2Efc5wPxr1SuL1L/ksOi/9g2f/wBCrta5Zyc5OTOuEVCKigoo oqSgooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAGugdSrAFSMEEZBFcDfaTf+ALyXVfD0 L3OiytvvdMXrF6yRf1H+R6BSEZoApaPrNlrumRX+mzrNbyjhh1B7gjsR6VerhNX8O3/hfU5tf8JR b0kO6/0scJP6uno/866bw94isPE2mre6fLuXO2SNuHiburDsaANWiiigAooooAKKKKACkpaKAGyR rLGySKGRgQykZBHpWPpXhHRtFvGutPshHOVKqzSM+xT1VQxO0ewxW1RQAlFLRQAUUUUAFFFFACEA jBGQe1cN8NLeGJ/EpiijQjWJkG1QPlGMD6V3VcV8N/v+Jv8AsNT/ANKAO1ooooAKKKKACiiigDif B/8AyUDxp/13t/8A0XXbVxPg/wD5KB40/wCu9v8A+i67agAooooAKKKKACiiigAooooAKwdb/wCR j0P6z/8Aout6srWNIm1G4tLi1vPss9qzlWMQkBDLggg0AS0jfcb6GqX9j61/0HY//ABP8awvGreI /D/hW81Cz1RLmWIDKiyUbVJALZz2BzQBH8Lf+RFt/wDrvP8A+jDXX15T8KG8RTm90j7atvZ2yiZZ Ps6ygs5zgE468mvSP7H1r/oOx/8AgAn+NA2mnZnNfEv/AJB+h/8AYZtv/Zq2fFPhqHxPaxQy3M1s 8MhZJYsFsMpVhz6gmvOfijqHiG11e10vz0uYbYJqCS/Z1j+dSQO/OPSu98Mf2/r/AIcstTuNVjtp bmPe0X2FTt5Pv+NFwcWlcfqXg3T9TudJmkeeP+ywqxqjcSKpBCt+Kg0P4M06TxLea07TNNdwNDJF n5PmXazDvkgYrS/sfWv+g7H/AOACf40f2PrX/Qdj/wDABP8AGgRU8M+GrbwtYyW1pNPN5km9pJiC xwAoHHYAAVkeEjnx94x/6+IP/QK277T9bs7C4uF1lJDDE0gRbBMtgZwOa8g8A+L9b1Px5LEksUUm sSBriRbcPtKqcEAngcc0Ae0eDP8AkVLL/gf/AKG1blUNF00aRpMFiJTL5IIMhGCxJJJx261foAKQ 0tIelAHE+M/HEmi3P2DTkRroANJI4yIwegx3Nc1p/wAStYt7lWvTFcwZ+ZdgVsexFU/H1nNa+Lrp 5QdlxiSNj0IwB+mK5uvfw+EoSoptXueHXxNVVXZ7H0HYXkOoWUN3btuimUOp9qs1heDLKaw8K2MN wCJNm4qf4cknH61u14U0oyaR7UG3FNhRRRUlBRRRQAUUUUAYHjX/AJFuX/rpH/6EK3I/9Wn0FYfj X/kW5f8ArpH/AOhCtyP/AFafQVK+Jm0v4UfV/oPppPvTq5/xJfzExaTp5/0284LD/llH/Expt2Ih BzlZFVf+Ko8QbzzpmnPhfSaX1+grqRVTTdPh0uwitLdcRxrj6n1NWxSirDqTUnaOy2FoooqjMKKK KACiiigAooooAKKKKACiiigAooooAQ1y3jDw1/acBvLRP9LiHKj/AJaL6fX0rqqQ1cJuEuaJE4Kc eVnm3hDxIdLuBZXjEWkjcFv+WTf4V6QCCMg5FcJ418M+WX1OyT5TzOgHT/aH9am8FeJt4TTL1/mH EEjHqP7p/pXTWgqsfaw+Zy0ZulL2U/kdvRSUtcZ2hRRRQAUUUUAFFFFABRRRQAUUUUAUNZXNjn0Y Vn6Q22/Uf3lIrU1Nd2ny+wzWNpzbb+H64oA6SiiigAooooAKKKKACiiigAooooAykz/wlE3p9kT/ ANDNagrMTH/CSyjnd9kX/wBDNadAC0UUUAFFFFABRRRQAUUUUAFU9VONPk98D9auVQ1g4sT7sKAM vTRu1CL2JP6V0dYGkDN+D6Ka36ACiiigAooooAKKKKACiiigAooooASuc8WeJBo1r5FuwN5KPl/2 B/eP9Kv6/rcOiWDTSYaRuIo+7H/CvO9M0+88Va07Sux3HdNL2Ueg/oK6aFJP357I5a9Vr3Ibss+F fDz65em5utxtY2y5PWRvT/GvTURUUKoAUDAA7VFZ2cNjax29ugSKMYUCrFRWqupK/Q0o0lTjbqcX qX/JYdF/7Bs//oVdpXF6l/yWHRf+wbP/AOhV2lYmwUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUU UAFFFFABRRRQAUUUUAJXG+IfC17Y6m3iPwkVi1LH+lWh4ivl9COz+hrs6SgDE8MeKbPxPZNJb7ob mE7Lm1l4kgfuCP61uVyXifwjNc3q654cmWy12EcN/wAs7lf7kg759at+FfF0PiFJba4hay1a1O26 spPvIfUeqnsaAOiopKWgAooooAKKKKACiiigAooooAKKKKACiiigArivhv8Af8Tf9hqf+ldrXFfD f7/ib/sNT/0oA7WiiigAooooAKKKKAOJ8H/8lA8af9d7f/0XXbVxPg//AJKB40/672//AKLrtqAC iiigAooooAKKKKACiiigAooooAKayhlIYAgjBB706koA5nS0XRvFV3pygJbXi/aIFAwAw4YCumrn /FlvIltBqlspM+nyeZgfxJ0YflWvDf282nrerIvkMnmb+wFRHTQ3qe+lNej9Tm/EOnw+I/EkGlTK DDDbPJKR1Bbhf8an8E6hM9hNpN8f9O0t/Ikz/Gv8DfiKf4VRryS91mUENeyYiB7RrwKpeJlPh/xD ZeI4RiByLW+A/uE/K5+hqdveN/i/cdtvX/g7HYUtNVgyhlIIIyCO9OrU4RDXK+E7CyXVtauY7G1i nS7aISRwqrbeDjIrqq53wp/x+a7/ANf7fyFXFe6yJP3kdHRRRUFhRRRQBQ1XRbHWrbydQgWVRypP BU+oPasrTvAeiaZcieK2aWRTlTM5YKfYV0lFWqk4rlT0IdODd2tRAMUtFFQWFFFFABRRRQAUUUUA YHjX/kW5f+ukf/oQrcj/ANWv0FYXjX/kW5f+ukf/AKEK3Yz+7T6CpXxM2l/Cj6v9CtqeoQ6XYS3d wcJGM49T2ArL8N6fN+91XUB/p15820/8sk/hUVVP/FUa/jrpenP+E0v+ArqcUl7zuOX7uHL1e/8A kFLRRVmAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFADXUOpVgCCMEHvXmXivw6+i3Yur UMLSRsqR/wAsm9P8K9OqC7tIb22kt7hA8Ug2sDWtGq6cr9DGtSVSPmYXhLxINYtvs9wwF5EOf+mg /vf410leT6ppt34V1lGidgAd8Ev94eh/rXofh/XIdcsFmTCzLxLHn7p/wrSvSS9+GzM6FVv3J7o1 qKSlrmOoKKKKACiiigAooooAKKKKAILxd1nMP9g1z1q226hb0cV0sq7onHqpFcsp2sp9DQB1lFID kA0tABRRRQAUUUUAFFFFABRRRQBkp/yNcv8A15L/AOhmtWs2102WHU5L24ujNI8IhwIwgABJ9fet KgBaKKKAEpaKKACiiigAooooAKzdbbFtGvq9aVZOuHiEe5NAEOijN259ErcrG0MfvZj7AVs0AFFF FABRRRQAUUUUAFFFFABVXUL+DTbKS5uX2xoM/U9gPeppZUhiaSRgqKMsx6AV5f4j12bxDqKw2wY2 6tthjHVz61tRoupLyMa9ZU15kF1c33izXAFUl3O2NO0a/wCetelaLo8Oi2CW8Iyerv3dvWqPhfw6 miWe6QBruUZkb0/2RW/V16ql7kdkRQouPvy3YlLRRXMdJxepf8li0b/sGT/+hV2lcXqP/JYtG/7B k3/oVdpQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABXM+KvCA1 p4tR06c2Ot2ozb3ad/8AYf1U101JQBy/hbxc2qXMukazALDXbYfvbcn5ZR/fjPdT+ldRWB4p8J23 iWCNxI1rqNsd9rexcPE39R6is3w94vnivjoXisR2erxDKSk4iu0/voemfUf/AKqAOyoqp/alh/z+ 23/f1f8AGj+1LD/n9tv+/q/40AW6Kqf2pYf8/tt/39X/ABo/tSw/5/bb/v6v+NAFuiqn9qWH/P7b f9/V/wAaP7UsP+f22/7+r/jQBboqp/alh/z+23/f1f8AGj+1LD/n9tv+/q/40AW6Kqf2pYf8/tt/ 39X/ABo/tSw/5/bb/v6v+NAFuiqn9qWH/P7bf9/V/wAaP7UsP+f22/7+r/jQBbrivhv9/wATf9hq f+laXirxlY+G/D1zqSyw3MkYAjhSUZdicDp29a8u+GPxIaHxHcWGoQwpDq1285lU48qRu3P8PGKA PdKKqf2pYf8AP7bf9/V/xo/tSw/5/bb/AL+r/jQBboqp/alh/wA/tt/39X/Gj+1LD/n9tv8Av6v+ NAFuiqn9qWH/AD+23/f1f8aP7VsP+f22/wC/q/40Acp4P/5KB40/672//ouu2rhvBU0c/jvxlJDI kkbTwYZGBB/d+tdzQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA11DqVYAqRgg965tvBkRLQrfXSa ez7zZhvl+meuPaumopOKe5cKkofCyOKFII1jjUKiAKqjoBUOpWEOqadcWVwoaKdCjD696tUhp2JT adzl/BF/N9juNGvmze6W/ktnq8f8DflXUZrmta0DUZNch1fQriC3u/KMMwmUlZF7cDuKi+zeNv8A n+0j/vy1Qm46WOmcI1HzqSV+nmdVXOeFP+PzXf8Ar/b+QqD7N42/5/8ASP8Avy1ZGhQeJ2uNT+wX enI4umE5kjYhnwMlfQVpGXuy0MJUfej7yPQc0Zrlfs3jb/n+0j/vy1H2bxt/z/aR/wB+WqObyNPY r+ZHVZozXK/ZvG3/AD/aR/35aj7N42/5/tI/78tRzeQexX8yOqzRmuV+zeNv+f7SP+/LUfZvG3/P 9pH/AH5ajm8g9iv5kdVmjNcr9m8bf8/2kf8AflqPs3jb/n+0j/vy1HN5B7FfzI6rNGa5X7N42/5/ tI/78tR9m8bf8/2kf9+Wo5vIPYr+ZHVZozXK/ZvG3/P9pH/flqPs3jb/AJ/tI/78tRzeQexX8yOq zRmuV+zeNv8An+0j/vy1H2bxt/z/AGkf9+Wo5vIPYr+ZFnxxKieGpS7qo8yP7xx/EKTXdUd7a207 S5Fe7vlwrqchE7vXnPxEg8QJdWra1JHNDtIja3UiMHvketdH8JtNmSxur24iZVchIGcfw98e2ax5 3KbjY9B4WFLCxrOSdnsdzpenQ6Vp8VpbjCRjr3Y9yfrV2kpa6NjyW23dhRRRQIKKKKACiiigAooo oAKKKKACiiigAooooAKKKKACiiigAooooAz9Z0iDWbB7acYJ5Rx1RuxFeaW8994S10hlIeM4dP4Z E/z0r1qsPxP4eTW7LKYW7iGY29f9k+1dFCqo+5LZnNXouXvx3Rp6dqEGp2Ud1bPujcfiD6H3q1Xl Xh3XJvDupNDcBhbs22aM9UPr9a9RhlSeJZI2DI4yrDoRU16Lpy8iqFZVF5klFFFYm4UUUUAFFFFA BRRRQAVyko2yuPRjXV1zF4u27mH+2aAOjhO6FD6qP5VJVewbdYwn/ZqxQAUUUUAFFFFABRRRQAUU UUAJilopKAFooooAKKKKACiiigAooooAKxtcP72EexNbNYetHN2g9E/rQBPoY+WY+4FatZuiDFtI fV60qACiiigAooooAKKKKACkJozXH+NPE32SNtOsn/fuP3rg/cHp9TV04OpLlRFSoqceZmX4z8Tf bZW06zf/AEdD+9cfxn0+grV8GeGfsUa6heJ/pDj92h/5Zr6/U1l+C/DP2uRdRvE/cIcxIf4z6/Sv QwMV01pqEfZQ+ZzUabnL2s/kFLRRXGdgUUUUAch4v0PVDqln4j8Pskmo2EbRm0k+7cRE5ZQezela nhnxTY+KLAz2u6OeI7Li2lGJIH7qw/rW1iuR8TeEZ5b8a94blWz1yIc9o7pf7kg/rQB19Fc74V8X QeI4pYJYms9VtTtu7KXh429R6qexroqACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigAooooAKzdY8PaX4ggSHVrGG6jjbcgkH3T7Ec1pUUAct/wAKz8I/9AK2/Nv8aP8AhWfh H/oBW35t/jXU0UAct/wrPwj/ANAK2/Nv8aP+FZ+Ef+gFbfm3+NdTRQBy3/Cs/CP/AEArb82/xo/4 Vn4R/wCgFbfm3+NdTRQBy3/Cs/CP/QCtvzb/ABo/4Vn4R/6AVt+bf411NFAHLf8ACs/CP/QCtvzb /Gj/AIVn4R/6AVt+bf411NFAHLf8Kz8I/wDQCtvzb/Gj/hWfhH/oBW35t/jXU0UAchd/Czwnc2ss K6RFCzqQJI2YMh9RzWJoXwR0TS7159Qnl1JMEJDKuxR7nB5NelUUAct/wrPwj/0Arb82/wAaP+FZ +Ef+gFbfm3+NdTRQBy3/AArPwj/0Arb82/xo/wCFZ+Ef+gFbfm3+NdTRQBy3/Cs/CP8A0Arb82/x o/4Vn4RHP9hWv5t/jXU0UAZmj+HNK8PiUaTYw2gmIMnljG7HT+dadFFABRRRQAUUUUAFFFFABRRR QAUUUUAFFFFABRRRQAUUUlAC0maiubuCzgaa5lSKJOWZzgCucbWdS8QMYtBi+z2nRr6dev8AuL3+ tVGLZMpJGrq+v2Wjqv2iQtM/3IIxukc+wqn4UtLuGO+ubyA27XlwZliLZZQR396s6T4cs9Kdphuu Lx/v3Mx3O349vwrWxTbSVkJJt3kLRRRUFhRRRQAUUUUAFFFFABRRRQAUUUUAFFFFADHjSRdsiKy+ jDIpVUKAFAAHYUtFAC0UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFA BSEZpaKAOQ8ZeGft0TahZp/pMY/eIP8Alov+IrI8G+JfsMq6feP/AKNIf3bN/wAs29Poa9FIrz7x p4Z+zSPqVmn7ljmZAPuH+99DXZRqKcfZT+Rx1qbhL2sPmegg5orjvBfib7Ui6dev++QfunY/fHp9 RXYiuapTdOXKzpp1FUjzIWiiioLCiiigAooooASue1Ndt/L74P6V0VYGsDF8T6qKANPSmzp8ftkf rVys/RmzZEejGtCgAooooAKKKKACiiigAooooAKSlooAKKKSgApaKSgBaKSloAKKKKACsDVzm/b2 UVv1zupnOoS+2B+lAGnowxY59WNX6p6Wu3T4/fJ/WrlABRRRQAUUUUAFJS1m63rEOi2D3E3LdI07 u3pTSbdkJtRV2UfFPiJdEs9kRBu5R+7X+6P7xrjPDWgy+INQaa5LG2Rt0rnq59Kr2lre+LNcYuxL ud0knaNfb+leo2FhBp1nHbWyhY0GB7+5rtk1h4csfiZxQTxE+Z/CieOJIY1jjUKijAUdAKfRRXCd wUUUUAFFFFABSUtFAHMeKvCA1iWLU9Mn+wa5bD9xdJ/F/sOO6mm+FvF51S4k0nWIPsOvWw/e2zdJ B/fjPdT+ldRWB4q8JW3iW3icSNaajbHfaXsXDxN/UeooA36WuO8NeLbkaj/wj/iiNbXWkH7uQcRX i/3kPr7f/qrsKAFooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKK ACiiigAooooAKSjNZ2ra5ZaNEGu5cO33IlG53PoBTSb0Qm0tzRzWBqHihEuTZaTC2oX3QpGfkj92 boKq/ZtY8S83jPpenH/lgh/fSj/aP8I9q39P0y00u2EFlAkMY7KOT7k96qyjvqyLyltojFtvDMt9 Ot54iuBdzA5S3XiGL8O/1NdGqBFCqAFAwABwKWlqXJvcqMVHYSloopFBRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFMkjWVGR1DIwwQehFPooA8t8TaBJoGoLPbFhbO26Jx1jb0/wAK7Hwr4jXWrTy5iBeR D51/vD+8K2L6xh1GzktrhA0cgwR/Ue9eXXtpe+FNbUoxDId0UnZ19/6iu6DWIhyy+JbHDNPDz5l8 LPWaWs3Q9Zg1rT1uIThhxIndG9K0q4mmnZnbFqSugooopDCiiigArE1tcXMZ9U/rW3WTrg/1LfUU AO0M/uZR6MDWpWPobfNMv0NbFABRRRQAUUUUAFFFFABRRRQAUUUUAFJS0lABRRS0AJS0lLQAUUUU AJXN3xzfTH/arpa5a4bdPKfVjQB0GnjFjD/u1ZqG1G21iH+wKmoAKKKKACkpaa7rGhZyAqjJJ6Cg CG9vIbC0kuLhwkUYySa8t1G/vPFWtKsaEljthi7Ivqf6mrPinxDJrl6Le13G1jbCKOsjev8AhXXe E/Da6NaedOoN5KPnP9wf3RXbBLDw55fE9jhm3iJ8kfhRf0HRIdEsFgjw0jcySd2b/CtSkpa45Nyd 2dsYqKsgooopDCiiigAooooAKKKKACiiigDH8S+GLHxRp32W9VldDvgnjOJIX7Mp7VgaH4mvtD1O Pw/4wZRcN8tnqI4jux2B9H/n/Pt6ztc0Kw8RaZJYalCJYX6dmQ9mU9iKANClrgNM1zUPBF/Fovim Zp9OkOyw1VuntHL6H3rvlYMAQQQehFAC0UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUUAFFFJmgAqOe4itoXlnkWONRlmY4ArG1LxRDb3H2LT4mv78/8souie7N0FV4PDlxq ky3XiScXDA5S0j4hj+v94/WrULay0Ic76RGvrt/rrtD4dh2wZw1/OuEH+4P4qvaT4atdNlNzIz3d 8337mc7m/D0H0rXSNY0CIqqq8AAYAp3Shz6LQFDrLUKWsW+1ue31qLT7az85mjEjEyBDtzj5c9cd TVga/phvBaC8iM+8x7M/xDt9anlY+ZGlRVBdb09742S3UZuQSNgPcdRnpn2oi1vT5r42cd3E1wMj YD3HUA9CaOV9h8y7l+isS68T2SXMNtayx3FxJcLCUDfdyeTnvijTPE9nfyvDJLHFOJXjSPdywU4z 9eOlPkla9hc8b2ubdFZf/CSaV9m+0fbY/KLbAwzyfQetQz+JLUGza1kjmhuJmjaQNhUCqSxz7Yo5 X2Dnj3NqisyXxFpkEMUst5GscoyhOfmHr9PerF5qUFlp0l7I2YUXdled3pj1zSsx8yLdFYKa7ewz 251HTfs1vcuI0cShmRj90MMcZq7b69pt3di2t7uOSY5wgPXHX8qbi0JSTNGisi715LT7W7RM6QOk KBOWllb+ED8RVf8At+5s5kXWLEWscqsY5El3jKjJVuODgUKLYOaRv0Vy2j+LZdX1C3tktYl8xDK5 8w5VO3br7VcOuXa65LYvYxrFEokedpwAsZON2Me3Sm4STsxKpFq5u0Vn22u6deRyyQXcTLCMyHON o9ee3vTbbxDpl2zCC8iYopdh0wo7nPap5X2HzLuaVFYV14t02OynltbiO4lijLrECQWxj9ORzVz+ 3LBLpLSW5iS6bA8vPRj2z0zT5X2Dnj3NGikFLUlBRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAVma7osOt2DW8uA45jfujVp0mKabi7oUoqSszyawvb3w prbLIhBQ7Zo+zr6j+YNeo2N7DqFpHc27h45BkGsbxX4cXWbTzYQBeRD5D/eH901x/hjxBJoN81vd bhau2JFPWNvX/Gu2aWIhzx+JbnFBvDz5H8LPUqKYkiyIrowZWGQR0Ip9cJ3BRRRQAVma2ubeM+jf 0rTqhrC5sc+jA0AUtFbF249U/rW5WBpBxfqPVSK36ACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAKKKKAEPANcq/wAzN7k11Eh2xOfQGuXQZdR6kUAdRGMRIPRRT6QUtABRRSUABOK4Dxr4 m8930yyf92pxO6n7x/uj29a1PGPib+z4TY2b/wClSD52H/LNf8TWH4O8Nf2jOL68X/Roz8in/lo3 +FdlGmoR9rP5HHWqOcvZQ+Zp+CvDPkKup3qfvWGYUYfdH94+9dpQBgUtc1So6kuZnRTpqnHlQUUU VBoFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAVNS0211ewlsr+BJ7aUYdHHB/wPvXDwXt98NbqOz1S SW88MyNtt70/M9kT0ST1X0P/AOqvQ6hubaG8tpILmJJYZFKujjIYehFADoZo54UlhdXjcBldTkMD 0INSV526X3wxuDLCs174UkbLx8tJp5J6j1T/AD9e8sr231G0iurOZJreVdySIchhQBYooooAKKKK ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAooooAKKKKACiiigAooooAKKKSgBaTNMlmSGNpJXVEUZLMcAVzkviG81mVrfw3AHQH D30oxEv+6P4jVKLZMpJGvqutWWjwebezBM/dQcs59AO9Yvl6z4l/1hk0nTW/hH+vlHv/AHRV/S/D NvZT/a7qR72/b71xNyR/ujoBW1indR2J5XL4inpmkWekW4hsoFiXuR1Y+pPermKKWobvqy0ktEFJ S0UDMDVNLv77VbeTdbC2glWVJACJUx95R2Oay9J0XUb2yiS5EMNrJdm7fKETZDkgenpz6V2WKQ1a qNKxm6abuctp3hSa2vUFwYZLaKVpUcSPvLEkg7c7QeaTS/Cc1rcRrdNC8EBdo5FkffuOcHGdoPPN WrTxQhsY5bqN3mmaRo4reMu3lqxG4j8KuL4j09lL+dhBb/aQ5GAUzg49we1U5TIUaZl2Xh7UYZNN hnezNrp8jMhRTvk4IBPYdeajtvDWpraW9rPNZ+VbyNOrxg73kOcA+2Tye9a6eI7SS6W3WO5MrRCU jyj8oIJGfQkCsvTPFTTxx3F66QQiF5pFMRyRv2oQff07mmnO1wahfclXw/eWSaXJYvbGazgMLrMD tOcZYY75FVW8GzXNjaW1zNEPJ86RmjH/AC1dsqQPQelaF94lCaPd3NvBNFNCF2rcxFASxwD7itPT 9Rh1KJ5Lfe0aNt8wrhXPcr6j3pc01qPlg3YwL3w5qF1drdFrVpZLdYZkLuqrjPK7cZBz0Na17oiX GgDTrdhCI1XyjyQrKQR9RkVQ/tjUbyN7yzaxgtFkZIluWIafBwTnOF6HHWrF94jht4p4kYi5itxM zqheNMjgkjqM/nQ+d2BciuMOn6rqM9udTa1jgt3EoSAkmVx90knoAecVFZ6DcaemnSHy5DYpM7qn WSR/SrH/AAlNnbs0Nx5xeEok8qQny0YgHk9hzW2DkZqW5IajFmC+iTzaJbKjpFfxzC73MMqZckkH 25xUdzpOq6oTLfvbRGKNxBFESR5jKV3MT6A9KraX4tmvLm8SRbcxxRSygx5ygRsDdn168VoWfiSH +y2mvSRNBBHNOEQ4G8ZAFU1OIk4SH6PosmnXryyOjILWG3jA6jYDkn6k1DqHh+a/m1ZjMifbIo44 jjO3bzz7E1PP4o0+3vDbu0mVZUeQISiMegJ9ak1fVG02ax4TyZ5SkrN/CNpOR+VL3rj9yxi6lol5 cWl1d6g0YmEKRRxWkZcYVg3I6nJHT0qkbW91pNUvLyFo1NqsMRit2G4htxwp5I4q5a+MJ7yEYhji mM75DgnZAq7t5Hrgj860bPxPbfZSbt2MkEKyTyrEQg3AEficjir99dDO0JdTDi0/UfEd3LPPFHCi RRxI3lNGCN4ZgA3PQfSr6+FZv7UlaXyJbOW5NwSzuHz1AwDjIPetrTNatdVeVIRIksWC8cqbWAPQ 49DWjUyqSvbYuNOLV9wFLRRWRsFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUUUAFFFFABRRRQAhrjPGnhn7QjalZJ+9UZmRf4x6/UV2lIRmrp1HTlzIipTVSPKzz/ AMF+Jvs7rpt6/wC6Y4hdj90/3T7elegA15z4y8Nf2fM1/Zp/o0h/eKP+Wbev0NbPg3xN9viFheP/ AKVGPkY/8tF/xFdFampx9rD5nNRqOEvZT+R11FIKWuQ7Aqpqgzp8vsAf1q3Ve+XdZTD/AGTQBiac 22/i9ziujrmLRtt3Cf8AbFdPQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQBDd NttJT/sGuctxuuIh6sK6DUDiwm/3aw7Ebr6Ef7VAHS0UUlABWJ4m8QR6HZZXDXUgIiT+p9hV7V9V g0ewe6uDwvCqOrN2ArzKOO+8W66cnMkhyx/hiSuihRU/elsjmr1uX3Y7sl0DRZ/EmqPLcM5hDbp5 T1Y+g9zXqMMMdvCkUKBI0AVVHQCoNM02DS7GO1tlwiDr3Y9yferdTWre0fkVQo+zWu4tFFFYm4UU UUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFADXRZEZXUMrDBBGQR6VwF5pV98PbuXU/D8L3W gyNvvNNXloPWSL+o/wAj0GkoApaRrFlrumxX+nTrPbSjKsvb1BHYj0q9XCat4dv/AArqcuveEovM ikO+/wBKHCTDu8Y7P/P9K6bw94isPE2mLe6dLuT7rxtw8Td1YdjQBq0UUUAFFFFABRRRQAUUUUAF FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRSVT1LVrPSLfzr2dY17DqWPoB3oSvsJu25czWJqnia3sp/slrG17ft923h5I/3j0Aqj v1nxN/qw+laa38R/18o9v7orb0vRbLR4PLsoQmfvOeWc+pPerso/ERzOXwmPF4eu9YlW48RzB0By ljEcRL/vH+I10cUKQRrHEioijCqowAKfilpSk2VGKQUUUVJQUUUUAFFFFACVT1K1ubq3C2d39mkB zu2BgR6EVdpKE7Cauc+nhmW1W1On6g1vLDb/AGd3MYfeuc5x2Oc1Wn8MpNf6XaCFvsVihZ5Wb/Wk nIX355NdTRir55E+ziYtzoElzrH25r0qBGyIixgEblxgt3HfB71W/wCEQjNuY/tb5EEUMbBBlDGd wb3ye1dExwCT2rnLfxIbTw3BqF+fMluZGWJVwu7LHaM9BwOpppyexLjBblm40K5v7FrbUtQ+0K0q SECEKu1Tnbj3q7pWnHS7drdZ2kgDEwqw5jX+7nuB2rnrvxRc6nbWsWmRvFcS3XkylWVioA3Haehy O/tWhoF3f6podxNNI0MryyCKUhW2qDgcdDjBpyjLl1EpR5tCG48JNNE9ol6q2DuXETwBnjz1CMem cn6VYk8LxNb3sEc5SO68pQAn3EjxhffOD+dUtK1q+j022mune/ur4t5ECIseApOST6Yweat/8JTv jt1hsJpLqaV4Wg3AFGQZbJ6Y96HzguQqW3h29uxfC7ungtrq6aSS3CAllBGMN2BAFdBax3P2Mrcu glO7HljhR2HvgYqvY6ut/pk1z5TQvCXSSN+qMvUZrntD8U3RtLy41BzMkFstxtMXltk5+Ueo6c+p pNSlfyBOMbLuW4PBrR27RS6iz4t3t4ysIXaH6k8/N+NTz+FfNuH23rJbTCITQ+WCX8vGMN2HFRa7 4jmgtLiKzhdblYYnD5HymRsAc96ZZeIrtJL5ru2kc/aVtraBWUkuF+YZ/Umq9+1xfu07E58IxHVZ LrzYmhll854pLdWOfQMegq9ruhx67ZR20sjRokqyEqMkgdR+NVG8U7IMNYTfaxci2a3DDIYjIOeh GK0dI1P+1rRpvJaFkkaJ0Yg4ZTg8jrUtzWrKSg9EZ03hSCS91C6SYxveW4twAvEQxgkfXApW8KxP pt5aNOxFzIjhto+TaFCjHcfKK3qMUueXcr2cexl6Loq6UJWZoXlkPLRwLHgenFatJS1Ld3dlJJKy CiiikMKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAC iiigAooooAjmhSeJ4pVDxuMMp6EV5b4h0Sfw3qaS27MIGbdBKOqn0PuK9VqrqWnQapZSWtyu5HH4 g9iPetqFZ05eRhXoqovMzfDPiFNcsvnwt1GMSp6/7Q9jW5Xks0V94T1wbTiSM5Rv4ZUr07SdRj1b TYbuIFVkHKnse4qq9JR96OzJw9Vy92W6LtMmG6CQeqkU+kPIIrnOk5aI7ZEPowrqa5VvlY+xrqYz ujU+oBoAdRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAFPVDjT5PfA/WsnTBnUIv bJ/StPWDixx6sBWfpAzfr7KaAN+obq5is7eSedwkUY3Mx7Cpq5zx1/yLE3/XRP51UI80lEicuWLk cVrGqXXijV0SFGKltkEXp7n3r0Hw9oMWh2AjGGnfmWT1Pp9BXN/Dm1ic3lwyAyoVRW9ARzXdV04m dn7KOyOfDQv+9luwpaKK5DrCiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiig BK4zxD4VvbDVG8ReEisWpY/0m0PEV6vcEdm9DXaUhoAxPDHiqz8T2TSQBobqE7Lm1l4kgfuCPT3r crkvFHhGa6vV1zw9MtlrsA4f/lncr/ckHf61Z8KeL4fECy2tzC1jq9r8t1ZSfeQ+q+qn1oA6Siii gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigCvfytBYXEqHDpEzL9QK57wvo8F3Z22s37Pd386b/Mm5Efso6Ct7Vf8A kE3n/XF//QTVHwl/yKum/wDXEVonaDsZtXnqbGKWiiszQKKKKACiiigAooooAKKKKACiiigAoooo AZNGJonjJIDqVJHUZrEj8J26WKWpvLx1iYNCzOuYSP7vHv3zW9RTUmthOKe5lxaFDG1ozT3Ej2xd lZ2BLFhgk8dh0qxZaZFYaWljCz+UiFAxPzc98+vNXKKHJsFFLYx5PDdsbOygimuIGsl2wzRsA4GM HPGDn6VSl8Lf8TC0NvPNDBbxyHzUk/emVyMsSRzkZrpaSmpyRLhFlCDR7e30qSwiMgjlVg7lsuxb qxPrzVODwpZxW80Us1zcCWEW+6VwSkY6KuAMc1uUUczHyJmLF4YtljIknuJpGljlaWRgWbZ91Tx0 HpTpPDdq9qYVlnR/tDXKzKwDo5PJBx74+lbFFHM+4ckTIg8OWkDwPvmeSKYzl3bJkcrty3Hoe2Ku adp0WmWxhhZ2Uu0hLnJJY5P86t0UnJvcailsFFFFIYUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABSUtJQBw/wASAANPPu/9 K2fBH/Ir23+83/oRrG+JH3dP+sn9K2fBH/Ir23+83/oRrrn/ALtH1OOH+8S9DoKKKK5DsOWuF2zy j0Y10dq261iPqgrAvxi+mH+1W5p5zYQn/ZoAs0UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQBm62cW0Y9X/pVXRVzdsfRKn1w/JCPc1HoY/fSn/ZAoA2a5zx3/yLEv8A10T+ddHXOeO/ +RYl/wCuifzrWj/Ej6mVb+GzM+G//Hvf/wC+v8jXbVxPw3/497//AH1/ka7aqxP8WROG/hIKKKKw NwooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAErmvFXhBNcaK/sJz Y61a8294nX/df1U101JQByvhbxe+oXUmja7ALDXrYfvIT92df78Z7g+ldVnNYXinwnaeJrWPe721 9bnfa3kXEkLex7j1FZfh3xZdW+pDw94rVLbVlH7mccRXq/3lP971H/6qAOyopgkT++v50u9f7w/O gB1FJuX1H50ZHqKAFopKWgAooooAKKKKACiiigAooooAY0iIyqzqpboCcZ+lM+2W+AfPiwwBB3jk Zxn8+KyvFNrdT6dHJYRl7qGUFAOuCCrfoaxIdAvIbO/t/KlKwtDb2rD7xjEgcsPpn9KAOxluYYTi WVEON2GYDj1/UVJmuL1HTNSmF1blbuaJRIImY5YjdGQM9T/F+VXbaHWF8SESSXAgWQ4JBaNoscDO cZ/DOaAOka4hUkNKgIIUgsOp6D60i3MLyeWksbPgnaGBPBwf1rlfEWjX13rLvaI3kmEXGR3mjzsH 45qP+z9VhtLNYknSV4d0zR8FXeVWYZ9cE/lQB2WabJKkSF5HVEXqzHAH41zHk6yPEDr5lysAc7GA LIYtvTrjdn15zV3Q4rqTRZ4tQjndizKv2jlpBjrg5xz2oA2YZ4rhN8MiSJnG5GBH6UskscMZeV1R F6sxwB+NciLTULTS7CKKC8jVbUgJa4UrP2L+1aurWtzLbadNNb/axbuHubdMHeduMgHg4POKANiG 4huYw8EqSof4kYEfpT81ytvDqU0Y/wBG+yQyXiE+RH5TsmDuLDJx2FJbxay/npm8W4MEolaRv3Zk /g8v0/zmgDq6RnVFLOwVVGSTwAK5VI9V1C8hLi/trVnRHG7YwxG24+wLY5qvdw6tJpscdymoybrR 0VYTyZdxA8z1G3H60AdkrB1DKQVIyCO4p1Z8V1BpekWpvpo7cLEinzG284HFXIJ4rmJZYJEkjYZV kOQaAJKKKKACiiigAooooAqar/yCbz/ri/8A6Cao+Ev+RV03/riKvar/AMgm8/64v/6Cao+Ev+RV 03/riKv7HzI+38jZoooqCwooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKACiiigApKWkoA4f4kfd076yf0rZ8Ef8ivbf7zf+hGsb4kfd076yf0 rZ8E/wDIr23+83/oRrrn/u8fU44f7xL0OgooorkOw53VBjUJPfB/SprTVfs9ukRiLbe+abrC4vs+ qiqNAHVg5APrS01PuL9KdQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFJQBzuokm+l5JA PSruhjiY+4qhfHN9N/vmtHRB+4lPq39KANSuc8d/8ixL/wBdE/nXR1znjv8A5FiX/ron861o/wAS PqZVv4bMz4b/APHvf/76/wAjXbVxPw3/AOPe/wD99f5Gu2qsT/FkThv4SCiiisDcKKKKACiiigAo oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKy9d8OaX4lsxa6vaJcRK25ck hlPqCORWpRQBxR+EXhD/AKBsg+l1L/8AFUf8Ki8JdrKcfS7l/wDiq7WigDiv+FSeFh0t7sfS8k/x o/4VL4ZHSO+H0vJP8a7WigDiv+FT+HR0Ooj6Xsn+NL/wqnQR0m1QfS+f/Gu0ooA4v/hVeiDpdauP pfPR/wAKt0ftfayPpfvXaUUAcX/wq7Se2o62PpfvR/wq/TO2q68P+39q7SigDiv+FX6f21nXx9L9 v8KP+FYWXbXfEI/7f2/wrtaKAOK/4VjbDp4h8RD/ALfz/hSf8Kzi7eJPEY/7fj/hXbUUAcT/AMK1 A6eKPEY/7ff/AK1H/Ct3HTxX4jH/AG9j/Cu2ooA4n/hXM46eL/EY/wC3kf4Uf8K8ux08Y+Iv/Ahf 8K7aigDi/wDhX98OnjPxD/3+X/Cj/hAtR7eNNf8AxlX/AArtKKAOK/4QPVe3jbXPxZaP+EF1odPG +sfiqmu1ooA4n/hCNeH3fHGqfjEho/4QvxGPu+OdQ/G2Q121FAHE/wDCG+KB93x1efjZxn+tJ/wi Pi4dPHc/46fGf6129FAHEf8ACKeMh08dOfrpsX+NL/wjHjUdPHAP10yKu2ooA8y8QeFPE7QRy32p HWihONkCxGMf7o6/Wt/wTb3Oi6T5eoKY0nffHk5CdsH0zXWkVRtkVZJ7OQAoDuUHupoAvA5paz8S 6ccruktvTun/ANarsUqTRh42DKehFAD6KKKACiikoA5fxx4ibRNOWGOIPLdhky3RVxyf1qP4e6yN R0QWpTa9kFTOfvA9DUet6dF4q8Uf2bOXFrYwb5Chwd7dBn6Com0iDwPe2d7ZGT7FIfs93vbJ5Pyv +BrqXs/Zcn2jkvP2vP8AZO2opAQQCDkHvS1ynWFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFJS0lAHD/Ej7unfWT+lbPgj/kV7b/e b/0I1jfEj7unfWT+lbPgn/kV7b/eb/0I11z/AN3j6nHD/eJeh0FFFFch2GJrY/0mM+qf1rNNauuD 5oT7EVlGgDqoTmFD6qKfUFm26zhP+wKnoAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACkpaQ nAJ9KAOYuTuuZT6ua2NGGLMn1c1iMdzsfUk1vaSMWCe5J/WgC7XOeO/+RYl/66J/OujrnPHf/IsS /wDXRP51rR/iR9TKt/DZmfDf/j3v/wDfX+Rrtq4n4b/8e9//AL6/yNdtVYn+LInDfwkFFFFYG4UU UUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRR QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAVSvv3MsNyP 4Dtf/dNXajmjE0Lxt0YYoAf1FU5LWS3czWeOfvRHo309DTtPlL2+x/vxHY34VboAgt7pLlSVyGH3 lPUVPVW5s/MYSxN5cw6MO/saS3vCz+TOvlzDt2b3FAFuo55kgheWQ4RFLMfQCpK57xlcP/ZCWMB/ f6hKtuvsD94/lTiruxMnZXG+DYmlsLjU5gfN1CZpsn+50UflWzf2UWo2M1pOuY5kKtUlrbpa2sUE YwkSBF+gGKlpyleVwjG0bHP+FL6U202l3rf6Zp7eU2erp/C35V0ArmfESNo+qWuvwg+WuILwDvGT w34GulR1dAynKkZBHcU5/wAy6ig7e6+g6iiioLCiiigAooooAKKKKACiiigAooooAKKKKACiiigA ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKSlpKAOH+JH3dO+sn9K2fBH/Ir23+83/oRr G+JH3dO+sn9K2fBP/Ir23+83/oRrrn/u8fU44f7xL0OgooorkOwy9cH7qI/7RFY9betDNop9HFYl AHQaU27T4/bI/WrlZmiPm3dP7rfzrToAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACobptlr K3opqaqWrSbLBx3YhaAOf7V0emjGnxfSucrprEbbKEf7AoAnrnPHf/IsS/8AXRP510dc547/AORY l/66J/OtaP8AEj6mVb+GzM+G/wDx73/++v8AI121cT8N/wDj3v8A/fX+RrtqrE/xZE4b+EgooorA 3CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigDL1a5ube5skt5EVZ5fLbcmccZz+lUpPEqKRKYZhGok4yuH28H3rauLSK5eF5QS0L70 wcYNU30CxeMI0bbRv43n+I5NAEDeIlj8zzLSdfKKeZyPlDdD1q5qV3La6RPcooWVE3ANzg0S6Raz CYOjHzgof5jzt6VNLZxT2bWsoZomXaQWOSPrQBzVzr9/HbNuV0kKFopAgUMBjJIPPGa2INXectHH aTO0QCysCuFYj681PdaRa3gQTozBIzGuGI+U4/wFDaTatP52xlc43bXIDY6ZA60AUdF1mS4W3guk cyzB2WU4w2002LWp31x7ZmgFujEFicDAHY9znqK0YNKtrZoGjQgwBhH8x4Ddary6Fp0kuHjO5mMi rvOA3cgUAM1fULzTpkaGNZopx5aDoVk7ZPoaR9aa1imDwvcPaqPtEiYVQxGcAGtG4s4roRiYFvKc OvOOR0qC60azvJJHljbMgw+1yob6gdaAKCeLLNvK3K670Z2yR8hGeD7nFbFrMbi1jmKGMuoba3UZ qifD2nFXUwcOyu3zHqOlaYGBigBaKKKACiiigAooooAKKKKACiiigAooooApH/RtTB6JOMf8CFXa rX8JltmK/fT51+oqS3mE8CSL/EM0AS1DcW0dym1xyOjDqDU1FAFFLiS0cRXZyp4WXsfrWOSNW8dD +KDS4c+3mv8A/WrfvZIobOaWcAxIhZs+gGa5rwnHPZ6UdQlj3LfSGdwPvID936jFXHRORnLVpHVi lpkUiTIHjYMp6EU+oNCG6tory1lt51DRSqUYHuDWD4VuZLYXGiXbZuLBsIx/jiP3T/SujrmvFET6 ddWuv2yktaHZcKP44T1/LrVw190znp7x0tLUcMyTwpLEwZHUMpHcGpKg0CiiigAooooAKKKKACii igCtfX0Wn2/nT7/LBwSqk4+tJ9viMSOufnI+U4DDPcg0zV7SS+0ue3iKh5Bgbjx1rKvdAnubi4lU RbneIqSeQFGDQBvfaIiCfNTA5PzCnB1IJBBA64Nc5D4aZUgDxwErbyRyf7Tn7p98Vr6ZayWumxwT KgkVQpKnO7jrQBDHr9nMD5RckDOCu3IzgkZ6irVpqEF3Zx3COFSTpuIB+lYZ8Mt/ZkUe2M3QkBdm Ykbck4H50+DQJrdbcmG1n2QmN45CQobP3hxQBs2+oQ3E88Kkh4X2EN3OM8Uy61e0s7lYJ5CsjYPC kgZOBk9uayjoE5lklCwrKbmOVGB+6gHIFP1PSL271P7VC8JKbfJLnhMdcjHOaANa5vobSSFJ2K+c 21WI4z6E9qS21C3u4TLE/wC73FQzcBiPTPWq1/Yz3+hPbS7GuWQcnpu9ar3OjyNJatFFBLHFD5Xk yEhVP94UAa4niYAiRCCduQw6+lOV1fO0g4ODg9DXJReFr6OIJ50aqv71QpPEo6fhiui0myawsUjk IaViXkYd2JyaALtFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUU UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABSUtJQBw/xI+7p31k/pWz4I/5Fe2/3m/9CNY3 xI+7p31k/pWz4J/5Fe2/3m/9CNdc/wDd4+pxw/3iXodBRRRXIdhR1cZsG9iDWDXQ6mM6fL7DP61z ygscDrQBo6LJtuXT+8uR+FbdczZS+TeRP2zg/jXS0ALRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAVka3J/qox7sa1q53UZvOvXOeF+UfhQBVPSupgGIIx6KP5Vy/pXVIMIo9qAHVznjv/kWJf+ui fzro65zx3/yLEv8A10T+da0f4kfUyrfw2Znw3/497/8A31/ka7auJ+G//Hvf/wC+v8jXbVWJ/iyJ w38JBRRRWBuFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABVe7jZ4g8YzLGdyfX0/HpVikoAbFIssSuhyrDIp9 VIf3F08HGx8yR/8Asw/r+NW6ACiiigAooooAKKKKACiiigAooooAKKKKACiiigBDVOz/AHFzNbHo DvT6GrtUr8GF4rpf+WbYb/dNAF2ikByOKKAOd8ZTNJp8GmQkibUJlh4/u9WP5VvwQpBAkUYwiKFU egFc7D/xNPHMsvWHTIfLX/ro/J/IV0oq5aJRM46tyKUlrJbuZrPv96Ls309DU9tdJcqSuQw+8p6i p6q3Np5jCWJvLmHRh39jUGhaqOaFJ4nilUMjqVYHuDUFveFn8mdfLmHbs3uKtUAc14YlfTrm60C5 YlrU77dj/HCen5dK6Wuc8VW0lt9n1u0XNxYNlwOrxH7w/rW9a3Md5bRXELBo5VDKfUGrnr7xnDT3 SaiiioNAooooAKKKKACiiigAooooAKKKKACiiigBKiuRJ5LGE/OvzAeuO341NSUANikWWJZF+6wy KdVaD/R7l4OiPmSP+o/Pn8atUAFFFFABRRRQAUUUUAFFFFABRSUUALRSUUALRSUtABRRRQAUUlLQ AUUUUAFFJRQAtFJRQAtFJRQAtFJS0AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFJS0lAHD/Ej7un fWT+lbPgj/kV7b/eb/0I1jfEj7unfWT+lbPgj/kV7b/eb/0I11z/AN3j6nHD/eJeh0FFFFch2EF6 u6ymH+ya5+0x9rhz0LAV0dwM28g9VP8AKuZhO2aM+jCgBbiIwTvGf4TxXQ2U/wBotI374wfrWdrM GJFnUcN8rfWk0a42StCx4flfrQBtUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAQXk4t7V5O4H H1rm1Uu2ByTV/V7rzZhCp+VOvuabYQf6PcXDDgIVWgClGN0iD1YV1VcxajddRD1cV09AC1znjv8A 5FiX/ron866Ouc8d/wDIsS/9dE/nWtH+JH1Mq38NmZ8OP+Pe/wD99f5Gu2rifhv/AMe9/wD76/yN dtVYn+KycN/CQUUUVgbhRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUU UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABSUE15v41+IxgkfTtDkUuMrLcjkD2X396AOv1 nxbpGhHZfXQEv/PNBub8q5TUfiZcNbvLp2nrDH/DJcty30Uf41wehWf227e4nYv5ZycnJY+9T+I5 MTwJ2AJoFcuX3jrWdQZftN15SdMQLsxnvnrWSuvanDJvW/uQVPBEhrIvJdsR9axY5Z/P+ZmKg9KA uepWPxM1y2EaytBcoOpkTBI+orrbD4maeWWPVbeWyZsbZB88bfiOR+VePQOWjHpium0uJL7Q/JlG VJZc+nNAHtVreW99As1rNHNEwyGRsip6+eNK13UfCmpyNYTY2na8bco/1FexeEvGdp4ptiFHk3kY HmQsevuvqKBnS0UlLQAUUUUAFFFFABRRRQAUUUUAFMljEsTI3Rhin0UAVNPkLW/lv9+I7G/pT766 SxsprmU4SJC5P0FQv/o+pK38E42n/eHSsnxhI1xbWekxHD6hOI29kHLGqiruxM3ZXJPB1q8WiC6n B+0XztcyE9fmPH6YroKZGixRqiDCqAAPanUpO7uEVZWFooopFENxbR3KbXHI6MOo+lV0uJLRxFd8 qeFl7H61eprxrIhV1DKeoNACMqyRlWAZWGCD0Irm/DjnR9UutAmPyJmezJ7xk8r+BrXIl0/7u6W2 9P4k/wDrVmeJ7Z5rODV9P+a6sG81Nv8AGn8S/lVw1919SJr7S6HRUtVtPvYtRsYbqBsxTIGWrNRs WncKKKKACiiigAooooAKKKKACiiigAooqhq+s2eh2LXd/KI4hwO5Y+gHc0AXqpXutadppAvb2CBj 0V3AJ/CvKdY+IOr67erb6YzWMBJVQjfOw9Saz763TTrRpmZpbqQ4MrnJz3oFc7/VfiLo0ez7I0lz MjgqyrtUevJ9qzX+LHlyFG0rBBwf33/1q8zlkwhNZkutETbTHvPTduoC57ppnxN0e7UC98yzf/aG 5fzFdJYazp2qZ+w3kFwR1COCR+FfO1vN5kQPrW7pMX2uJpI5HguoCNk8ZwwoC57zS149o3xJ1TRL w2mtbr2BWwXJ/eKPUHv9DXqek6xZa5ZLdadOs0R4JHBB9CO1Ay9RRRQAUUUUAVtQvYtPsprqc4ji Usf8K52HxHfSaK8k0UcOoLeJbmPGQoYgjj/dNbOraRHrCQxXEjfZ0ffJEOkvoCfTvVBfCNtFcl7a aSKIyxzeV94bkBwcnnuPyrSPJbXcynz30LGl6rJPo1zf3RUJHJLtIGBsUkD+VYTeNLlPDkFw0aDU JZ/LMe04VQRkkZ9CPzre/sFR4cOkCdwhQoZccnJyePeqtx4PtZ572USurXKoowARGFIJx9dopxcL u4mqllYtXniO0sp5InSeRYcefJHHlIc9NxqO78V2VncSxPHcuIWVZJEjyilhkc/jTbvwz9pubkre zR2t2we4t1UfOQMHDdRnHNPbw5E6SqZmxLeLdMNo/hxhPpwKXuD98T/hKrJbeSSSO4jkjmEHksmH LkZAA+lA8V2LWsUyJcO0kxt/KVMuHAzgio7vwrFdGZ/tBWZ7k3KuYwwU7du0qeCMVNb+HY4GsWM2 5rV3kOIlQSMwxkgelHuB+8KreJ/tF7pa2kUghuGk87enKBODnnjB6+1S/wDCX2W6PMN0scu7ypTF hJAASSD6YFOtPDENs8Jad5BFHLGQQBu8xsk/0qqfCDyRRQy6pO8METxQoY1GwMu38SBT9wX7wuw+ KLKVN8izQIYDcK0ybQyDqR+Yq3JqkUejNqTpIkaxGXY4w2MZxj1rL1LQP7Q1DS4Hi/0OyXc8hP38 AAJj04ya0Nfspb/Qrq2twPNdPkBOASCCB+lS1HSxSctbmXa6hrV/L9kia3hnSNZp5XjJEe/lYwM8 nHUmpIPEptkkg1KJnu4rkW2LZCwkJXcCB24/Kp30i5luBf2l29hczRKs8ewSKcDjj1HTNOtvDkVt PaS+fJJJBI8rs+CZXYY3H6dqbcSbTITr7Tz6XNbAi2up3t5Y5Ew6sAf5EEUeKdbm0eO08iSGMzOw Z5ULAKFJ6DnrgUyx0OaHULSN8taWO+VZGxmaVycnA6AAn86uavosmpXNtPDeNbPAHAIjV87hg9fa j3E0P33F9yO08Rwvao1zG0cwsheSKvIVfr61l3/iu5Q6i9tA/lQW0TxFo+jv0zz0watP4PTy0it7 6aGL7OLaZdoJlQHPU9DyelWpvDcUq3S+cyrcSxOQF+6seML9OP1ppwTE/aNCf8JRaxMqSxXGFKxz SiP5InOPlY+vP4U7/hJ7P7ebXyrjif7OZfL+QP2Gaik8MCW4lBvZRZTT+fJahRhmyD97rjIzipF8 OIoTNw523jXh+Ucsc4H4Zpe4P94WtL1qDVmm+zxzBYmK73TCsQSDg/UVo1k6Poh0u4up3unuJLkg sSgUcd8DjPqa1qiVr6FxvbUKKKKRQUUUUAFFFFABRRRQAUUUUAFJS0lAHD/Ej7unfWT+lbPgj/kV 7b/eb/0I1jfEj7unfWT+lbPgj/kV7b/eb/0I11z/AN3j6nHD/eJeh0FFFFch2DXGUYeorlRwR7Gu rrlZBiRx6E0AdLPCtzbGNujDr6GubZXt5iD8rof1rp4TmFD6qKo6nYeePNiH7xRyP7woAsWV2t3A GHDDhh6GrNcvb3ElrLvjOD3B71uWupQ3IA3bH/utQBcooooAKKKKACis7+2rf+7J+VH9tW/92T8q ANGis7+2rf8AuyflR/bVv/dk/KgDRorO/tq3/uyflQ2tQAcJIT9KANGs/UdQFupjjOZT/wCO1TuN YllBWJfLHr1NUoYZLmXbGCzHqf8AGgBbeB7mcRpyT1Pp71uXUa2+lyInChMCnWVklnHgcufvN60z VTjT5PfH86AMewGb6Ef7VdLXO6YM6hF+J/SuioAK5zx3/wAixL/10T+ddHXOeO/+RYl/66J/OtaP 8SPqZVv4bMz4b/8AHvf/AO+v8jXbVxPw3/497/8A31/ka7aqxP8AFkThv4SCiiisDcKKKKACiiig AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAC iiigAoopKAOB+JfixtNthpVjIyXU6hpHX+BPT6mvJQK0PEE1zceIb971i0/nuG9sHGB7VBYafPqU 5itwMgZYnoBQJmj4evY7eZ4ZDgS42ntmpPE0L7VnUZCDke1JP4aeFBm5Td6EYqlLcX2nr5Uw8yM9 A3IP0NMRz8l0kykZ5+v+NQc/3fxq5e29rdOWMTwsf+efIqiNNhLf66cj02UgLkd2oIRPmJ446mu2 0fFlpKvOwUKCzE1x9iIbIhorfe/96StREvtWPU+UOuThFoAp3UoubqWYAgSMWANO0/ULnSb6K8sp TFPEflYfy+lbCeFzJGSl2pb2XisW8s5rG4MM64YdD2I9aB3PoDwv4hg8S6LFew/K/wByVO6OOorY rxv4RXEqeJri3WRhFJblmTPBIIwf1r2SgYUUUUAFFFFABRRRQAUUUUAFFFFAFPVPLSweSSRYxHhw 7HAB+tc/pVzHr3jCe9R1eKxt1ijweNzcsR/Kr/jUZ8Iah/uL/wChCuY+GH/H3qH+4n8zVKVrktXP QxS0UVJQUUUUAFFFFACVSltHgZpbQDDffiPRvpV6igDjfDepW2ma1d6P5yC3kcy2wLfcJPzR/UHt XY15BBz4+H/YQP8A6Ga9gqpPmdyYx5VYKKKKkoKKKKACiiigAooooAKKKKAKeqalBpGmz3t022KF Sx9T6Ae5rwfxH4ju/EupNc3LbYwcRRA/Kg/xrqPitrctzq6aQuVhtgJH/wBtmHH5CuCoEzU8PlRq ahupGF+tafiME2ansrc1z0aTIRIiSAjkMFNao1xJ4DDfIckY3AfzFMRz88u5cDH+NZbW+ZM8/kav 32myo5ks5lkQ8hSeRWY32sNgw5PrQBq2snloB09j/nium8MNuFwR0JArkLSxubhg1xIkUffnmulg 1aDTrQQ2SFmH8RHGaAIvEeDq77eyLn60nh/X7vw3qiXlm2cfK8bfdde4IqoY7i4d5SkjsxLM2081 XbIJBBB9DSGfR+javba5pcN9ZsTFKOh6qe4P0q/XiPw18RyaT4gSxkYtaXzBCueEfs39K9uoGFFF FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUU AFFFFABRRRQAUlLSUAcP8SPu6d9ZP6Vs+CP+RXtv95v/AEI1jfEj7unfWT+lbPgj/kV7b/eb/wBC Ndc/93j6nHD/AHiXodBRRRXIdgVy9yMXMo/2zXUVzV8MXsw/2jQBv2h3WkR/2B/Kpar6ed1hCf8A ZqzQBQvdMS4JeMhJO/oax5rWa3OJIyB69q6ekIzQBy6zyoMLK4Hs1L9qn/57Sf8AfVdG1tC33okP /ARSfZLf/njH/wB80Ac79qn/AOe0n/fVFdF9kt/+eMf/AHzRQBkf2Ncf3o/zo/sa4/vR/nW7RQBh f2Ncf3o/zo/sa4/vR/nW7RQBhf2Ncf3o/wA6UaNcf3ox+NblFAGVFoijBmkLeyjFaMUEcCbYlCj2 qSigAqhrBxY49WFX6zdaP+ioPV6AKWkDN+p9FNb9YeijN459ErcoAK5zx3/yLEv/AF0T+ddHXOeO /wDkWJf+uifzrWj/ABI+plW/hszPhx/x73/++v8AI121cT8N/wDj3v8A/fX+RrtqrE/xWThv4SCi iisDcKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKTNGaAFopKM0ALRSZooAWi kooAWikzRQAtFJRmgBaKSigBaKSopLqGL78qA+mefyoAmpDVf7XvGYoZX9Pl2j9cUZu3HCxRfUlj /SgDxj4g6U1h4nupMfJO3mjHv/8AXzVTwjdRQ38scpwZUAX3IPSu7+JGkt9hg1FnMjIfKk+UAbT0 6e/868puEMEgZCQAcqR2oJZ311GkkhHBB6VRudOW4gaJgMEfKT/Cfaufh8SP5YS6Ukjo6ipf+Er8 sj5i4HbbyaYjGdMMytwykqfqKj2jNI1yZZZJHxukYsQO2aXOT+FAyWNN8kca/edgo/Gu0i08QxLB GMRp+p7muIWdoJ4pkGTG4bHrit0eLA7HDhAexXkUCOlhiSHgYFcj4mu47nVMRnIiXYfrmm3XiORk KWoxnq7D+VZ9tD5pLyZK9fqaQ0ehfCDTm/tG9vmXhYhGD7k5/pXrFcz4Q0KfRdBhUSATy/vZY2GV yRwM9RgYrdS7AYJOphc9A3Q/Q9DQUWaKSloAKKKKACiiigAooooAKKKKAMPxp/yKOof7g/8AQhXL /DH/AI/b/wD65p/M11PjL/kUtQ/65j/0IVyvwx/4/r//AK5r/M0Aei0UUUAFFJS0AFFFJQAtFFFA Hj9rz49T/sIH/wBDNewV4/Y8+PI/e/P/AKGa9goAKKSigBaKKKACikpaACiikoAWikzUMl5BH96V c+gOT+QoA8g+KNm0PitrjB2zxIQfoMf0rndAhjuNat0mAK5Jwe5AyK9N+JFoL/SIbpYJMQsVZ2XH yt/9fFeTkyWN0jocMjblamSzvrxXXCoccdqxL3S1vARIoEv8MgH86fbeIYr6EbnEcw6ox6/Spv7W t+kikNQI4qa22uyOuGU4I96gNsmR1/OtTWLiKTV5zAwKHGSOm7HNUSckUDGpbovIArodJ0tBbrcT Rh2fmNT2Hqa5+VsQnFdtFqNkkUQDAqEG3bzQIs2wm/jbjsAMYrF8W28SLFMABMxwSO4rRl1mCEb5 HWNB0yeTXKanqEuq3hkwdv3UX+tIaNHwPYnUPGWmx4yqS+Y30UZ/pX0FXlHwt0swXc+pSQu0cSeW HUZwx68d8D+deqRSpMgaNwy+ooKH0UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABSUtJQBw/xI+7p31k/pWz4I/5Fe2/3m/8A QjWN8SPu6d9ZP6Vs+Cf+RXtv95v/AEI11z/3ePqccP8AeJeh0FFFFch2BXOakMahL9R/Kujrn9WG NQb3UUAamlnOnx+2f51cqjpBzYL7MavUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABWXrh/ dwj1YmtSsfXD88I9iaAG6IP38p/2RW1WRoY5mP0Fa9ABXOeO/wDkWJf+uifzro65zx3/AMixL/10 T+da0f4kfUyrfw2Znw3/AOPe/wD99f5Gu2rifhv/AMe9/wD76/yNdtVYn+LInDfwkFFFFYG4UUUU AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABSGlpDQByN14g1d/Fc2mWKWKLBsIiuCyvOh+8y npx6Vo3vjPRtOu5rW6umSeFgroI2YjIzngdPesfxLpmtavqAgTTbfEcqPaagk21oACN24dT34HFV rebUrXxj4gl0/TItQ3NHG+ZAjKdnHX+E966VCMlfyObnlF28zqbnxLpVrpsV/Lex/Zpv9Uy/MZD6 ADk1Su/FdrLpUN5pd1C6tdRwP5itldzYII6g/WsW28MarpEem38MEF3c27zPLaB9qr5hz8hPGRTL rw7q9+1xqMtnHBPdXls/2WNwdiRtyzHoW5pckO4OpU7G9pniPcmszapNFDBY3jQq54woAxn1PNT2 vizSb23uJoLkkWyGSRGQq4Ud9p5Irnb3wpqN/p2rxqnlyPqhu4FLgeaoHr2/GoLTwvqM8d/cXFpe xzi0khgE94spcsMY4HA/GjkptXuLnqLSx0qeNNGktVuI7l2Rn2IFiYsxxk4GMnA6mtm3uI7q3jnh JMcgDKSCMj6GuR1XQJ5/C+kwJp873lrEAr286xvA23HBPBGetdJosV7Bo1pHqcgkvFjAlYdzWc4x SvE1hKTdpHNR+KtQbwrDqBEPnvqP2Y/Lxs8wr09cVrXvjPRtPvJrW5umSeFgroI2JGRnPA6e9c+n h7WVSPRPskf2FNQ+1/bPNHKb92NvXPai3n1K18YeIZNO0uK/DPGjgyBGQ7OOv8PrWvJBmXPNHY/2 raNpLalFMslqsZk8xTkEAVzt3rGvGXRbW1a0iur+OSSTzoyVXABC8H0OKhtdKms9M0/QJ2Tzry4e 6uUj+6kYbcVHtnaPxNXfEkGox6/pOoafp7Xi2qyh0WRU+8AByamKipW9S5OTj9xLpPiOdZ76z19b e1ubFBK8iN+7eM9GGelTW3jPRbyOdoLssYIzKyeWwYoOrKCOR9Kwrrwzq2vR6lf3scNreXCxJBbl 9yhEbdhyPU1bi0/Vdc1vT7jUtMh0+3sA2cSB2lJXbtGOi/Wm4Q3uJTntY3V17T5ZbGJbgFr9C8Ax 99cZ/CqJ8V6HZ24m80Rw+e1sHERwXXqOnT3rk/8AhBtVigvpo2f7VZSBdKw4+4GLfhndjn0rbk8M T29l4ZtYYRKtnciW5PHGQST78mh06a63BTqO+h0Wk61Za3bNPYTeYittYFSpU+hB5FaFYGg6bcWW t67NND5cNzcK8JyPmG3BP51v1jJJPQ2g21qRXNvFd28kE6B4pFKsp7g14H4o0abw/q81lN8yfejc dGQ9K+ga5jx14YXxHox8sKLu3y8THuO6/jUlHgLybG9RSL5c3AbB9KW+t5LeRkcEEVnSDmmSaq24 QZBzTd2Hx7VlrczJwHOKDdyFutAGrvGKY0ij0rN86RurGnxnnJoA0IyGPP5V3/w38OtrOqfbrhAb K0bkH+N+w/Dqa5Hwv4eu/EuqJZ2g2qeZJSOI19TX0Lo+k22i6XBY2ibYolxnux7k+5pDRdpHRZFK uoZT1BHFOooGVfs8kH/Hs/yj/lm5yPwPUU6O6DOI5FaKQ9Fbv9D3qeggd6AFopKKAFopKWgAopKM 0ALRSUtAGL4w/wCRT1D/AK5/1Fcn8Mf+Qhfj/pkv8663xf8A8ipqH/XL+orkvhj/AMhG+/65L/Og D0akpaSgDK1jxJpuhGMahOUaTJVVQscDqSB0HvWjb3EV1bxzwOJIpFDI69CD3rkPGT2cWoRXMGpW 9pq9tAxWOf7k8R6o2eOazL7VU1PV9FNzqE+j2d1Yb3WOTyxnPC56D61vGlzJNGEqrjJo9GzUVzcx 2ltLcTEiOJC7kDOABk1502t3trY6hbWeqSz6bHdQwjUm+doUb7/zd8cc+9PnvfsE93Z6TrM+pWsm nzSzF5fM8hgvysGHTPpR7B9w9uux29prdne3otYHYymBbjBUgbG6H/61aGa86tr25trm6u7YGS6T QIXXIyS3r71Q0LVtUbVLBre5lnknceck1/HIJFP3sJ1UjrTdDdpkrEW3R0Nt4Dkg19NSN8rBbjzt nl++cZzXZ5rzjTrTUrvwpd39vq863LzvGqzT7U2CT7oJ6E4xn3rpfBV6L3RX+W5WSGdo5Fnm80qw 6gN3FROnyq9zSFXmdrGg2vWSNqIZ3zpwDXHyngYzx68VctbqO8tIriEkxyoHQkYyCMiuE1O+trC7 8Yw3c6RSzwoYkc4MmY8cevNQXcmzVdCsb3Vp9Mtn0tfM2SbNzehPY+/tVexvt/WhHtmn/Xc9IzWR f+J9O06Gead5NkEwgcpGW+cjOBjrWFoGtNZ2+tn7a+oafYEG3uHO4sSOU3fxc4H41Fr1qdM8J6WL pgJjqEM1w56b2bcxP5/pUqn71mU6nu3R0mj+JNN1t3Sxn3SxjLxOpR1Hrg81q5rhtY1G3u/Fdjca E0d3d2tvO87QncNu35VYj1bHFZUepmHTrDU7XxBPdavPKglsjICrFjhk8v8Ahx6+1V7K+q0J9tbR np2arvFNIT/pGxc8BEGfzOa851G91y1u7rQbF52ntbhr5ZWYkmADcFz354xUs+p3up+Fda19J5rd Lh44rVA5HlqpAJH1JNHsHZO4e3W1j0E2ULgCXfL/AL7E/p0qZI0jGEVVHsMVyOjR3WleMfsD6hc3 cM9j57Cd92H3YyPT6V2FZSjys2hLmVyC/s49QsZrWcZjmQo3tmvBfEOlyaPqlxp9xkmI/Kx/iXsa +gq474ieFxrekG7t1AvLRSwwOXXuv9RUjZ4e5AOD+BprtKw4kcj/AHqbcBkJDAgj1qn57xHKH8DT EW0STuMD0qXcRge9VU1XtIn5U176MkHPegC9nNRjfGf3cjoPQHiqZvh/CM0n2ln9hQBcLF3yzF29 Sa0tNtJLm6it7ZDJPMwRQOpJrHjfFey/DHwg1lAutahGy3EqkQRt/Ah/i+p/lSGjs9B0iPQ9HgsY zu8sfMx/iY8k1altEdzIhMcv99OD+Pr+NWKKBlXz5oP9em9P+ekY/mv+FTxypKgaNgynuDTqge0Q v5kZMcmeWTv9R3oAsUUgpaACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiig AooooAKKKKACiiigAooooAKKKKACkpaSgDh/iR93TvrJ/StnwR/yK9t/vN/6EaxviR93TvrJ/Stn wT/yK9t/vN/6Ea65/wC7x9Tjh/vEvQ6CiiiuQ7ArC1kYvR7oK3axNbH+lRn1T+tAFrRTmzYejmtG szRD+4lHo39K06ACiiigAooooAKKKKACiiigAooooAKKKKACiiigArF1s/6RGP8AZ/rW1WFrJzeq PRBQBZ0MfuZT6sK1KztFGLRj6ua0aACuc8d/8ixL/wBdE/nXR1znjv8A5FiX/ron861o/wASPqZV v4bMz4cf8e9//vr/ACNdtXE/Df8A497/AP31/ka7aqxP8Vk4b+EgooorA3CiiigAooooAKKKKACi iigAooooAKKKKACiiigAooooAKKKKAENQxWcEE800USJLMQZGA5cjgZqeigBMUUtFACUYpaKAExR S0UAJioYrOCCeaaKJEknIMjKOXI4GanooAZ5SeZ5m0b8Y3Y5x6Zp1LRQAlFLRQAlGKWigBKWiigA pKWigDxv4laOmn68ZUjHk3a+YABwG6N/j+NedXVsASY+noa9r+LFvv0myn7xysv5j/61eQywGQ8U CZhOMVH3rZfS5JASENUEs2e5MX8QpkkKDOK0LS1UkGQ5/wBmnjTpI/4TVm0gPnord2ApDR7h8O9A i0fw7HPtHn3iiViB0X+Ef59a62o4IxDbxxqAFRQoA7YFSUFGZr1+1hpxMJInlYRx4GSCe+PYVnaZ 4gkLR2lxh5l8zfI3ykhRlTj3rfkt4pZY5JI1Z4zlGI+79Kin0yzuZGkmto3dsZZl5OKAOestfujL c3LxqySeUqRlzhS3T8PWprzV7udooYQ0U63DQyCEghjtyME1ufYLXEg+zx4kADjbwwHShNPtYxGE t41ETbkwPun1oA5tdWuoNQjF4W3wbjOqNkOQmenapL/W7uX7NEiJFI7xyKUkyCpP3TXQ/YLUzmcw R+aTkvjnpj+VMTS7KMYS1iUbg/C9x0NAFS/uZ/7QtLNZRbrKrM0gAJJH8IzVJNavINTfTkEd2QTt lY7f4ckHHcVvT20N1HsuIkkXrhhmo0sLWPy/LgjXy87MLjbnrQBmLqkmoW1rLArKfLa4kRTyQuQF z7n+VVpNQu4dHi1Jb0SSSY/0faNvP8I75H9K3LWwgs2cwRhA2BgdAB0ApBptms5mW2iEh/iCjNAH PeH57251GIzzu6GDzSDIe5Izj+ldVUEFlb2zBoYUQhdgKj+HrirFAGP4t/5FXUf+uR/mK5D4Y/8A ITvv+uK/zrsPFnPhbUf+uJrjvhj/AMhS9/64j/0KgD0ikpaKAKt3plnf7DeWkE5Q5XzIw2Ppms67 8Ow3uvw304ikt47YwG3eMEHJzn0rbpKpSa2JcE90QR2NtDbfZ4reJIMY8tUAX8ulRQ6TYW8MkMFl bxxSgh0SMAMPfHWrtFK7HyorRWFrBL5kNvGjiMRblUA7B0X6VHBpNhbXDTwWVvFM3WRIlDH8cVdo ouwsjn4dT8Nzn+y4ntXEkhX7P5fysxPPGMZzW1bWsFnCIbaGOGJeiRqFA/AV5HoXPja2/wCvs/zN exUXCyKlxplndzJLc2kE0kf3HkjDFfoTWfd+Hor7xCmoXIilgFsYDBJHuBy2c81t0lNSa2E4p7mb daLbz21vbRosFtFKspijQBX28gY9M4P4Vau7G2v4PJvII54s52SKGGfpVmildj5UVbPTbPT1K2dr Dbq3URIFz+VNj0qxiujcx2Vulw3WVYwG/OrlFF2HKiH7LD9oNx5SecybDJt+Yr6Z9KjOm2Zsvsn2 aL7N/wA8tg29c9PrVqildhZEAtIPtIuPKTzwnliTHzBfTPpU1LRQMKSlooA8Z+JPhmLT9WE8YCw3 eXUAfdbuP1rzm6tWh+9yOxFfQHxI09LzwtLOw+e1YOp+pwf514dcKTn0oEzDYVGeoq9LbEkkCqbR sHx3oECirEMTSNhBk0kdu3BYGr1upXgDAoA7j4Z+D01TVTd3sYktbbllPRn7D39TXtoAA44Fcz8P dPjsfB9my/fuAZnPuf8A62K6egobI4jRnY4VRkn2rNsNftL5GbJh2uEAk43Z6Y+tWdTtJL6xkt4p REZOGYjPy96ybjwt+/iktLlowm3Ik+bJU5X8KAL763brqkdmHQlg25t33WHY0651m1hs5LiORZ1j IDCJgTycCqKeHGMzyTXAJlWUS7Vxy/p9KbL4clngkWW4j3mNIV2x4G1TnkdzQBLJ4liEbMkWWRgj Rs4DA7sdPTnrVy71e1tYZ2WaN5IVLGMOMnHaqN94cFxcK9s0cEYRV2BfR92aZL4aeSLyftC+UnmN F8nzZb+8e45oA0Tq0C6dFdsSVlwFVOSWP8I96auswJKYrtXtHxuAmwAw9iDiln0vz7G3hEmyW32t HIB0YD09Kp3uhXGoyJLd3MZkjI2BUwoGcnvyTQBoS6lCtm9xA6zBTtARs7m6AVA2tIPMZLeeWOE7 ZZIwCqkdcc5OPao4dJkj1F3YqbdpjcYHHzYwB+HJpf7KuYVnhtLpY7edixDJlkz1wc/zoArL4qil vRBDErq0mxZDIAD74xW9WFZeG/sN5FJHKpiilZwpHOCuMZrdoAWiiigAooooAKKKKACiiigAoooo AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACkpaSgDh/iR93TvrJ/StnwR/yK9t/vN/6Eaxvi R93TvrJ/StnwT/yK9t/vN/6Ea65/7vH1OOH+8S9DoKKKK5DsCsfXB+8hPsa2KydcHEJ9yKADQzxM PcVrVj6GfnmHsK2KACiiigAooooAKKKKACiiigAooooAKKKKACiiigArn9WOdQb2AFdBXOakc6hL 9R/KgDU0cYsR7sav1T0oY0+P3yf1q5QAVznjv/kWJf8Aron866Ouc8d/8ixL/wBdE/nWtH+JH1Mq 38NmZ8N/+Pe//wB9f5Gu2rifhv8A8e9//vr/ACNdtVYn+LInDfwkFFFFYG4UUUUAFFFFABRRRQAU UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAcZ8UMf8ACMJnr9oXH5GvLbMRqMtya9F+K12FsbK0BGXdpGHsOB/M15nGSMmmJmjLIgiO AAK5ZG26o0nbmtae4/dkd6xnHz7vegRsGYYptv8APqMAXvIo/WqSy5XFT20hjmSQdUYMPwNAH0tS 1DaTi6tIZ1IIlRXGPcZqakUFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAZHir/AJFfUf8Ari1cb8Mv +Qte/wDXAf8AoVdn4o/5FjUf+uDVxnwy/wCQvef9cB/6EKAPSaKKKACiiigAooooAKKKKAPHfD3P jS1/6+j/ADNexV474b58ZWn/AF8n+texUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAYXjVN/hDUh 6RZ/IivDorbz5CD0r3Dxu/l+ENQ94wv5kV4lE5RjigTLI0qBRkgE1z2oQpHqkYVRtyM10BucIea5 +9O+5L9waZJpeRCyg7RioJYljYbRTYpsxjJo3FzQM+gfCI2+E9LH/Tuv8q2ax/CUiyeFNMZen2dR +QxWxSKCiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiig AooooAKKKKACiiigAooooAKKKKACkpaSgDh/iR93TvrJ/StnwR/yK9t/vN/6EaxviR93TvrJ/Stn wT/yK9t/vN/6Ea65/wC7x9Tjh/vEvQ6CiiiuQ7ArL1sfuYj/ALX9K1KzdaGbVD6PQBX0Q/6RKPVf 61tVhaMcXrD1Q1u0AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFACVzd8c30x/2q6WuXuTuuZT /tmgDf08bbCEf7NWahtBi0iH+wKmoAK5zx3/AMixL/10T+ddHXOeO/8AkWJf+uifzrWj/Ej6mVb+ GzM+G/8Ax73/APvr/I121cT8N/8Aj3v/APfX+RrtqrE/xZE4b+EgooorA3CiiigAooooAKKKKACi iigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACimNKiEB3VSemTjNOoAWio5Z4oFDTS JGpOMscDNODqyBgQVIyD2xQA6imJKkmdjq2Ou05p1AC0UUlAC0VFLcwwnEsqIcZ+Y4qSgBaKKKAC mswRSzHAAySe1OrA8bXsth4TvZYSVcqEyOwJwaAPL/GWtjW9dmmjbdAn7uL/AHR3/E5NYaD5TTGb JqaJcrTJKNzkZ9KpuPlFXbsbSRVJz8tACRjmrUfGKghGTVjGKAPYvhpr39oaQdPmYGazACerR9vy 6flXbV4H4T1GbTvEdjLCcFpVjYZ4KscEV73SKFooooAKKKKACiiigAooooAKKKKACiiigDK8T/8A Is6j/wBcG/lXE/DL/kM3f/XD/wBmFdv4l58Naj/1wb+VcR8M/wDkNXf/AF7/APswoA9LooooAKKK KACiiigAoopD0oA8e8Mc+MrP/r4b+texV494W58ZWf8A13b+Rr2GgAooooAKKKKACiiigAooooAK KKKACiio55kt4JJpThI1LMfQAZNAHCfFHVfLtLbTo25lJkkHsOn6/wAq8xXrV/XNWk1jVbi7kJ/e MSoP8K9h+VUohkmmiWQXDFRWfIuQxrQuQRnNUD900AMjJ4FWY6rxj5qsqMUAexfC/WRd6G2nyMPN tD8o7lD/APXzXcV4D4Z1yTQNXhvUG5V+WRf7yHqK97hlWeFJYzlHUMp9QeRSKH0UUUAFFFFABRRR QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFA BRRRQAUlLSUAcP8AEj7unfWT+lbPgj/kV7b/AHm/9CNY3xI+7p31k/pWz4I/5Fe2/wB5v/QjXXP/ AHaPqccP94l6HQUUUVyHYFUNZGbL6OKv1S1YZsH9iP50AZukHF+PdTW/XPaUcahH9D/KuhoAKKKK ACiiigAooooAKKKKACiiigAooooAKKKKAENcrIdzufUmupc4Rj7Vyo5b6mgDqYRiFB6KKfSLwoHt S0AFc547/wCRYl/66J/OujrnPHf/ACLEv/XRP51rR/iR9TKt/DZmfDf/AI97/wD31/ka7auJ+HH/ AB73/wDvr/I121Vif4rJw38JBRRRWBuFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRRQAUUUUAc14rt555rYwQGXakmflzjgfr6VDcz38cE4jkvUZFQWypHkMuBkscda6ui gDi9RbUJ7BfO+1tdrNuMQiyigdCDirn2jVDtB8/zMRiKPy/3bqQN2444PX0rpZWZYnaNdzgEgZxk 1lRa8kotCECiZGkly3+qC9c/jxQBm2tvcW5RLdJIBJfSByiY+Tt26VDe3WrLahkkvRd+YfMjWL5F HOMHFbja5auE8qXaxdVIkRgSD0IH9alTWrJ95EjbFBJkKEIcdcHpQBhXM2rQOVWe6dBHHJxHksSO VBA4qWSTVGklkWW5QC5jRUKAjYQMnp2rcs9Ttr8stu5LKASpBBwehxVugDib9dTuJZbeQ3MkUbEK 2z72HGOceldlEnlxKu5mwANzdT9akooArMbzcdi2+3PGWOf5Umb7+5bf99N/hVqigCrm+/uW3/fT f4Vi+NLea68GX6yBA6KJMISRgEHvXSVXv4RcafcQkBvMiZcHvkUAfPIGatxL8lRLGUcow5U4NW41 +SmSY99kNVBzxWjqeN1ZjcigCe35NWiOKrWvWrjL8tAFvQUZ9f05FGSbmP8A9CFfQ9eD+CIhL4z0 xW6CXd+QJr3ikNBRRRQMKKKKACikooAWikzS0AFFJmloAKKKSgDN8Sf8i3qH/XBv5Vw3wz/5Dl1/ 17/+zCu68Rc+HdQ/64P/ACrhPhn/AMh25/69v/ZhQB6bRRRQAUUUUAFFFFABSN90/Slpr/cb6UAe QeE+fGVn/wBdm/k1ew14/wCERnxlZ/8AXV/5NXsFABRRRQAUUUUAFFFFABRRRQAUVDNK6YEcTSE+ hAA+pqPbdSdXjiHoo3H8z/hQBZJxWfq0qT6NqEcTq7i3fIU5/hNWPsMbNulZ5T/ttkfl0qYRIqFA ihTxgDAoA+chVq3WpNTszZatd2p6wzMn5GlhSmSUL3oazWPBrV1FPlJrIY8GgB0PLVbxVS3Pzir+ OKAGA4U19FaR/wAgax/694//AEEV864r6QtIxDZwRr0SNVH4CkMmooooGFFFFABRRRQAUUUUAFFF FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUlLS UAcP8SPu6d9ZP6Vs+CP+RXtv95v/AEI1jfEj7un/AFk/pVTQfGcGj6TFZyWksjITllYAHJzXdySn h4qK6nDzxhiG5M9EorjP+Fj2v/PhP/32KP8AhY9r/wA+E/8A32Kw+rVf5Tf6zS/mOzqpqYzp8v0H 865f/hY9r/z4T/8AfYqK5+INtPbvGLGYFhjO8UfVqv8AKH1ml/MaumnGoRfX+ldHXnNt4xgguI5T aykKc4DCtP8A4WPa/wDPhP8A99ij6tV/lD6zS7nZ0Vxn/Cx7X/nwn/77FH/Cx7X/AJ8J/wDvsUfV qv8AKH1ml/MdnRXGf8LHtf8Anwn/AO+xR/wse1/58J/++xR9Xq/yh9ZpfzHZ0Vxn/Cx7X/nwn/77 FFH1ar/KH1ml/Mb/APwkukf9BC3/AO+6P+El0j/oIW//AH3XH/8ACur7/n7tvyNH/Cur7/n7tvyN aeyofzmXta/8p2H/AAkukf8AQQt/++6P+El0j/oIW/8A33XH/wDCur7/AJ+7b8jR/wAK6vv+fu2/ I0eyofzh7Wv/ACnYf8JLpH/QQt/++6P+El0j/oIW/wD33XH/APCur7/n7tvyNH/Cur7/AJ+7b8jR 7Kh/OHta/wDKdh/wkukf9BC3/wC+6P8AhJdI/wCghb/991x//Cur7/n7tvyNH/Cur7/n7tvyNHsq H84e1r/ynWy+JNJMTgahb52nHz1gRatYeambuEDIz81Z03w/vYYnkN3bkKM8A1Ti8I3MsqotxDlj gcGmqVD+cPa1/wCU7/8A4SXSP+ghb/8AfdH/AAkukf8AQQt/++64/wD4V1ff8/dt+Ro/4V1ff8/d t+Rpeyofzh7Wv/Kdh/wkukf9BG3/AO+6w/GGtafe+H5Yba7hlkLqQqtk9ay/+FdX3/P3bfkaP+Fd X3/P3bfkaqEKEZKXOTOdeUXHlL3w3/497/8A31/ka7auf8K+H59AiuVuJY5DKwI2A8YHvW/XPXkp VG0dFCLjTSYtFFFZGwUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFA BRRRQAUUUUAJWVD4etY5Lxizut0CpU9FBOSB+Na1FAGMfDsUjI81xLLIhUKzAcKvReKkTQ0W2e1N zM1oylRCcYUH3xnitWigCjp2lx6cG2vvZgBuKKpx6cCr1FFABRRRQAUUUUAFJS0lAHh/iGzFl4n1 C3UYUTFh9Dz/AFqsq4U1t+PLc2/jK4Yj5Z0SRfyx/MVj4wlMkwdUPz4rKJ4rT1U/vDWUTQBeseWr RYcVmWDYetTqlAHSfDa1+0eMoXxkQRPJ+mB/OvZZHZFyqFz6Agfzry74TRA6zqEmOVgVQfq3/wBa vVKQ0QedL/z7P/30v+NHnS/8+z/99L/jU9FAyETSkgG3cA99y8frUtLRQBxcmpXkd1eqsshW7laG D5j8jBgOPTg0/Tteu4tNmjd0aePYId+S0hLEH611vkR5B8tODkfKOD60CCIEERoCvQ7RxQBylnql 3Y2UUaGNhLJKd8nAXB6ZJ71sXupSwaALh0C3MqhURTnLngY/nWmYIym0xoVznG0YzTmjVsblBxyM jpQBxcV3dW13a2lz9oeRJxKnm8M42nI/OrF14mvIbe3lSS0ZpslowpzH7HmuraJGcOyKWXoxHIpp toSSTFGSTk5UUAYB1jUFkcE2zBbpbf7hGdw69aS21+7bUUt7hrcKJjCSiksxB9M8D35rofJj/uL1 z0HX1oEMYbcI0Ddc7RmgCl4g58Pah/1wf+VcF8NDjXrj3tj/AOhCu+1//kX7/wD64P8AyrgPhr/y ME3/AF7n+YoA9PooooAKKKKACiiigApsn+rb6GnUyX/VP/umgDyPwf8A8jlZ/wDXR/8A0Fq9fryD wbz4xs/99/8A0Fq9foAw9d1mfTbuKKERnfGWAZSSzZwFGOmakl8QxwwyStaztHCwSR1xtVu469s9 atX2kWuoyB7lWZghQENjAzn86im8P2c+8OJdrkFlEhAYjuR60AZuqeI3S1guLZJo4HkI80op3qM5 wD/Wr39uxEBVWTbuWIzFRtVyOARnPem3Xh7TTAfPMiQIS23zSFT1wO1SjTdOFzE2fnch0TzPlcgc Njucd6AK1lrkvlRG6QSPNK8aCJcbdvUnJpbjxTBbwRzta3Hkyk+W+BhgO/WrQ02ytWtwdwKyMYwS Tlm65qKXwzp8yBHE2xSSqeYcL9B2oAa3iWFJPKe2uFkyBtIAwCMg5zinN4hiEpT7NcECbyAwAwX7 DrUs+hWdzI7yiQmQKHAcgMBwART10a1XbhWG2f7QPm/j/wAKAMe88SO0qLZiVX3qrxsq8fNgjPr2 rpVJKgkYJHQ9qzP+EdsfPMu195fefnPXO7+datABSUtJQB4z44svsnjC844mxKPxHP61lRLiuv8A ijAq6xp8w6yRMh/A/wD165NBhaZLMvUzhTWKW61s6seKwietAFm1OZBWnt+Wsq0P74VsLgrQA/S7 X7XrFnb4z5s6KR7ZFfRHCj0Arw3wTb/aPGenJ2WQyH/gIJr3FlDqVYAg9QaRSDev94fnRvX+8Pzq L7Hb/wDPCL/vkUfY7f8A54Rf98igCXev94fnS1D9jt/+eEX/AHyKmAAGB0oAyZ9bFvrq2Dx/IU3e ZnocE4x+FRaV4lhvzIssZidcsAMnKgZzUt/4fi1CWeR5nRpQuCoHy7fT65qP/hGYVneaG4kiZl2f KBgLtwRQAWniW3mlujISkEZXy32H5sj+ftWna3sF7CZYHDIDg9sH3rO/4Rm2EMkYd9rMjLkA7Sow PrVqPTFi0+W1jk2GQENIqAHn2HFAGY3igtFdtHbgeWu+EseJVDbSavSeILGBWMkjfJgMVQkBvTPr Ve48KWU1vFHEXhaMYLryWHvmnT+HElgkt0upY4JH8wxgAjd9ev4UASDxJp5APmSYK78+W33c4z9K efEOnh9nnMXJAChGyfcDHIqJfD0SQtGJnw1t9mzgdM5z9abceHIrmXebiRf3aR8KM4XoQexoA2Qd wBHQ0tNRdiBck4GMmnUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUlLRQBl6xoFnrgh+2eZ+6zt2Njr/+qs3/AIQDR/8Ap4/7+V01FaRqzirJmcqUJO7RzP8AwgOj /wDTx/38o/4QHR/+nj/v5XTUU/b1P5hewp/ynM/8IDo//Tx/38qK48CaTFbyOon3KpI/eV1dQ3Qz aSj/AGD/ACo9vU/mD2FP+U4WDwtp8k8asJcMwBw9bX/CA6P6XH/fymW5xcRf7w/nXU0e3qfzB7Cn 2OZ/4QHR/wDp4/7+Uf8ACA6P/wBPH/fyumoo9vU/mD2FP+U5n/hAdH/6eP8Av5R/wgOj/wDTx/38 rpqKPb1P5g9hT/lOZ/4QHR/+nj/v5RXTUUe3qfzB7Cn/AChRRRWRqFFFFABRRRQAUUUUAVdROLCb /drEsBm+h/3q2dVONPk98fzrJ0sZ1CL2yf0oA6GloooASilooAKKKKACiiigAooooAKKKKACiiig AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAC iiigAooooA82+KFvt1TTbns6NGT9Dn+tcmeENd18U4S2nafN2jmKn8R/9auFb/V/hTRLOb1Y/PWV mtXVz89Y+eaBF6yPz1sgfu6xLL/WCt1RmOgZ3/wjiGdVl7gxr/6Ea9Jrz34SRkWWpydmlQD8Af8A GvQqRQUUUUAFFFFABRRRQAUUUUAFFFFABRRRQBn67zoN/wD9cH/ka8++G3/Iwy/9e5/mK9C1z/kB X/8A1wf+Rrzz4b/8jE//AF7t/MUAepUUUUAFFFFABRRRQAUyb/Uv/umn1HP/AKiT/dP8qAPJfBfP jC0/3n/9BNevV5F4I58X2n/A/wD0E167QAUUUUAMmjWaF43GVdSpHsa5m1sNT8uY7Ck1rAYLZj/F zyw/DArqaKAOXEOq/aYjALpbfzFwJmywO05J/wBnOKkjh1H+z5BGt4L/AMv53kcFCc87efTpiuko oAytEhuokkNxJMykjasq4IPfuTWrRRQAUUUUAFFFFAHBfFO2LWOn3IH+rlKk+xH/ANauGQfLXqHx ChEvg+6PeNkcfnj+teXx8xA+1NEsxtY6GsEnmt3WPumufJ+agCzanEorbjyY6wrY/vBW9AP3YoA6 b4brnxrCSPuwyH9K9lryH4ZR7vFzt/ct2/UivXqRQUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUU UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AVHOMwSD1U/yqSmuMow9jQBy8XEqf7wrqq5ROGX6iuqHSgBaKKKACiiigAooooAKKKKACiiigAoo ooAKKKKAKGsHFifdhWfpAzfj2U1d1s4tUHq9VNGGbxj6IaAN2iiigAooooAKKKKACiiigAooooAK KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooA5H4lxb/Cu/wD55zo38xXmwObcH1Fep+P4/M8HXv8As7W/8eFeURNmyX6U 0SzntXb95WOTzWpq7fvTWTu60CL9if3orfT/AFX4Vztj/rBXRR/8e5oGeo/CqPb4anf+/ct+gFdv XJfDJNvg6I/3pZD+tdbSKCiiigAooooAKKKKACiiigAooooAKKKKAKOtc6Hff9cH/wDQTXnXw4P/ ABUjf9e7fzFejaz/AMgW+/64P/6Ca84+HP8AyMv/AG7t/SgD1SiiigAooooAKKKKACo7j/j3l/3D /KpKiuf+PaX/AHD/ACoA8o8Dc+LrX6P/AOgmvXK8k8Cc+Lrb/df/ANBNet0AFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAYfjSPzfCGpL6RbvyINeR2xzbj6V7VrcQm0O+jIyGgf8A9BNeI2LZtiM8g00J mTrB+UiufY/NW7rJxmsAnmgksWx/eL9a6K3/ANWK5u2P7xfrXSWvMf0oGdv8Ko92u6hJ/cgA/Nv/ AK1ep15v8Jovn1Wb3jT+Zr0ikUFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFIehpaQ0Acp0b8 a6tfuj6Vyr8O31NdTH/q1+goAdRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQBla4f3UI/2jUWi D/SJT6L/AFp+uHmEfWjQxzMfoKANeiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAx PGMfm+EtSX/pln8iDXjULf6F9K9t8Rp5nhzUV9bd/wCVeH25/wBFkHpTQmc9qRy5JrLzzWhqZ/eG szvQSX7M/vBXRxn/AEYn26VzNmcOK6NGzZk45xQNHsnw6Tb4Lsv9ouf/AB411Fc74CXb4K033Rj/ AOPGuipFBRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAFPV+dGvf+uD/APoJrzb4dH/iph7wP/SvStW5 0i8/64P/AOgmvNPh2f8AiqE/64P/AEoA9WooooAKKKKACiiigAqK6/49Jv8Acb+VS1Dd/wDHnP8A 9c2/lQB5X4CGfFtv/uSfyr1qvJvAPPi2D/rnJ/KvWaACiiigAooooAKKKKACiiigAooooAKKKKAI L1d9jcL6xsP0rwey+VZl9Gr32Qbo2X1BFeBRjbdXKf7Z/nTQmYmrvuYisI9TWzqxw7ViMctQSWbY /OK6WyP7quXtm+cV09if3PB6CgZ6Z8Jh/wAS/U29Z1H/AI7XoFcH8Jh/xJL1vW4/oK7ykUFFFFAB RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAHKS/6x/8AeNdRCcwof9kVzE/+uk/3j/Oultjm2iP+ wP5UAS0UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAYuuH99EP9k1NoY/dSn/aFV9aObxR6JVrR B/ozn1f+lAGlRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAUtaG7RL4etu/8A6Ca8 HgP7mUV71qo3aReD1gf/ANBNeCQ9JBTQmc1qJ/ems81e1E/vmFUKCS3anDiuhib/AEMj2rnLY/PX QRH/AEP60DR7v4LXZ4P0sf8ATEH9TW5WP4TGPCel/wDXsn8q2KRQUUUUAFFFFABRRRQAUUUUAFFF FABRRRQBV1TnSbz/AK4P/wCgmvMvh3/yNMf/AFwf+lem6n/yC7v/AK4v/wCgmvMfh5/yNMX/AFxf +lAHrFFFFABRRRQAUUUUAFQXv/HlP/1zb+VT1Bff8eFx/wBcm/lQB5b8Px/xVkP/AFyk/lXrNeT/ AA+/5GuH/rk/8q9YoAKKKKACiiigAooooAKKKKACiiigAooooAK8DuBs1m8X0lcf+PGvfK8I1hPK 8T6gnpO/8zTQmcrq5+dhWMeta+sHErfWscnmgkmtzhxXSaew8hs+lc1AfmFdDYH9y30oGet/Cf8A 5F65/wCvg/yFd1XDfCj/AJF24/6+D/IV3NIoKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKS gDl7ni4l/wB810doc2cP+4P5Vzt0P9Km/wB810NlzZQ/7goAnooooAKKKKACiiigAooooAKKKKAC iiigAooooAwNXOb8+yir+jDFln1c1naoc6hJ7Y/lWppQxp8fuT/OgC7RRRQAUUUUAFFFFABRRRQA UUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFFFABRRRQAUUUUAV78Z0+5HrE38jXz/Hw8o96+grsbrOYesbfyr59OFuJR700JnM6n xO31qhnrWhqv+vas0HrQSWbc/OK6JBizWuct+ZBXRg/6GtA0e/eFePCumf8AXsn8q1qy/DK7fDOm j0tk/lWpSKCiiigAooooAKKKKACiiigAooooAKKKKAK2o/8AIMuv+uL/AMjXl/w9/wCRqh/64v8A yFeo6h/yDbr/AK5P/I15d8Pv+Rqg/wCuT/yoA9ZooooAKKKKACiiigAqvf8A/IPuf+uTfyNWKr6h /wAg65/65P8AyNAHl/w9/wCRqi/64v8AyFesV5R8PP8AkaI/+uL/ANK9XoAKKKKACiiigAooooAK KKKACiiigAooooAK8K8R/L4t1H3nf+de614X4o+Xxbf/APXZv50ITOO1r/XtWQetbOtj96axM84p kk0J+cV0Nj/x7Ma5yI/MK6Oy4s2oA9h+FS48LO3964b+Qrtq474Wrjwch9Z3P8q7GkWFFFFABRRR QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFA BRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAHMXnF5N/vmt+w/48Yf8AdFYN7xezf7xrd0//AI8If92g CzRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQBzeoHN/N/vYra00Y0+H6VhXZ3Xcx/2zW/YjFjC P9kUAWKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAC iiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKZJKkSF5HVFHVmOBVXVr7+zNKurzZvMEZc LnGcV4dq/iPUdZuXkvp3IJysQOEX6CgD2SXxfocEhSTUodw64BI/MCmf8Jr4f/6CUf8A3y3+FeGG 4P8AeppuD/e/WgVz2vUfHmhw2EzRXizybSFjVWyxx9K8ZG+SaSTHysxNVJbk4PzVWi1CWAkBjtPa mJlHVj/pDYrNB61sXECXjbvMCk+tVxpJGf3qHI9aBFa1b94K6NgfsS4H41jR2IgIZpVOPSrrai7R CBOEHfFAz3Dwz450T+wbOK4u/s80MSxujqeoGMjA6VrDxroB/wCYlH/3y3+FeAW9wY161OLo+p/O kO576ni3Q3+7qdv+LY/nV611Kzvh/ol1DNj/AJ5uDXzr9pPrT4b+W3lWSCaSKQdGRiCKBn0jRXGf DnxHfa9YXCX+Ha1KqJf4nznr+VdnQAUUUUAFFFFABRRRQAUUUUAV7/8A5B9z/wBcm/ka8t+H/wDy NVt/1yf+Vep3v/Hhcf8AXJv5V5X4B48V23/XN/8A0GgD1uiiigAooooAKKKKACq2o/8AIMuv+uL/ AMjVmqupf8gu7/64v/6CaAPMvh3/AMjOn/XB/wCler15T8Ov+RmX/rg39K9WoAKKKKACiiigAooo oAKKKKACiiuF8S/EmDTriWz0yMT3EZ2tK33FPcD1IoA7qivFZ/iBrszbvtxT2jQAVA3jnXP+glP+ n+FAXPcK8I8WzK3i6+MbBlMrYI6HmifxprUsTI+pXBVhgjdjisFL6ITHzwTnvTQmyhrRIf61iZy1 bWrKZyWiBK1jiCTfgoaBDoT84ro7RsWbVzkUMgcfIa6G2ngisisxO49AKAPbPheyt4Kt9rAnzJNw B6fN3rr6+ctF1++0ov8AYbuW3VvvBGxmtoeO9cHTUpj9cf4UhnudFeJJ8QdeTpfsfqin+lWbf4m6 5DIpklhmUHlWiAz+IoGeyUVzXhbxrZeJcwqpgvEXLRMfvDuVPcV0tABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAc1f8X03+9W5p3/HhD/u1iah/wAf83+9W1p3/HhD/u0AWqKKKACiiigAooooAKKKKACi iigAooooAKKKQ9KAOWnOZpD6sa6W3GLaIeiD+Vcy3Lt7k11MYxGo9AKAHUUUUAFFFFABRRRQAUUU UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFABRRRQBV1KyXUtOuLORiqzxlCw6jPevDvEnhrUPDU4S7jElu5PlzLyrD39D7V73Uc0 EdxC0U0aSRuMMrjIP4UAfNDlSPlJB9DULMwr1zxF8JbS8/e6JMLOTvFJloz9O4rzLW/C2s6DMyXt lKqjpKi7kI9cimKxmNk1GyetRm4dfQj3o+3L/FF+RoEOEdP2GkW9tz1yPrT/ALXbno4zQBF5RpVi welO+224/ipp1CP+FGNAEwBFOBNVTdu33VCirmnWF/qswjsbaa5cnGIkJ59/SgYD/aOBV3T7O41G 7S2sIHlmc4AUZP8A9YV22hfCC6lZJdbukgjIyYYfmf6Fug/DNelaL4e07w/btDptssSscs2cs31J 5pDMrwL4Ym8NaXKl1IrXFw4d1XkLgYAz3rqKKKACiiigAooooAKKKKACiiigCG8/48p/+ubfyryn wHx4stf91/8A0E16vdf8ek3+438q8o8C8eLbX6P/AOgmgD1yiiigAooooAKKKKACqmqf8gm8/wCu D/8AoJq3VPVjjSL3/rg//oJoA82+HP8AyMo/64N/SvVa8r+HP/Iy/wDbBv6V6pQAUUUUAFFFFABR RRQAUUUUAFfPmv272uuXkVxE8MnnO2GGMgkkGvoOsfxB4Z0/xHaGG9jw4+5MgAdPofT2oA8AYsuS OR6ioTOa6zxH8O9X0QyTWqG9s158yMfMB7r/AIVxjykZDDkdaZI95SRVZ1LHNO8+PvkU4NG/3XFA EayyL0Y49Kk8+Q46flTxDn0pfKoAgaaQ57fQVFhmPJNWxFS+Wo5OBQAxDtAqUSGomliXguM+1IJl PTNAycSGpAGx8x2+3eksLW71K5W3sbeSeZjgJGuT/wDWr0Pwz8KrqSZZ9fYQxKQRAjBmf6kcAfSk Az4UWUkmvT3gjbyYoChfHG4kcZ9cA165UFpZ29hbpBaQpDCgwqIMAVPQMKKKKACiiigAooooAKKK KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigDm9R/4/5vr/StrTf+QfD9KxtR/wCQhN9f6Vs6b/yD4fp/WgC1RRRQAUUUUAFFFFAB RRRQAUUUUAFFFFABTZDiNj6A06org7baU+in+VAHMryw9zXVDoK5aEZljHqwrqqACiiigAooooAK KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKACiiigApGUMpVgCDwQe9LRQBzup+AfDmrMz3OlwrIw/1kWYz+lclq XwQ02cMdO1G5t27LKokX+hr0+igDxWT4FagB+71i1J9GiYVy+tfD6+8P6gLa5uraR9m8GMNjBz6/ SvpKvLfiR/yMa/8AXuv8zQKxzlh8EtVu7aKd9Tso0lQOAFZjgjNa1l8C3WUfbdZUx+kMPJ/M16lo /wDyBbH/AK4J/wCgirtAzidP+EvhmyA823mu29ZpDj8hiutsdPtNMt1gsbeK3iXokagCrNFACUtF FABRRRQAUUUUAFFFFABRRRQAUUUUAR3HNtL/ALh/lXk3gf8A5G+0/wCB/wDoJr1mf/USf7p/lXk3 gnjxfafV/wD0E0Aeu0UUUAFFFFABRRRQAVS1j/kDXv8A1wf/ANBNXao60caJff8AXu//AKCaAPOv hx/yMh/692/mK9Try34b/wDIxv8A9e7fzFepUAFFFFABRRRQAUUUUAFFFFABRRRQAlYOueCtE8QI ftlmqy9pofkf8x1/Gt+igDyTWfgo2S+jaiCP+edyOf8Avof4VyGpfC7xRYE40/7Sv963cP8Ap1r6 KooCx8oz6Vqtk5SayvImHZoWH9KksdPv7x3G94dmD+9UjP0r6prg/ih/qtO/3n/kKBWPDbyzvba6 aL97LgA7o1JHNS2Wg6xqLhbbTr2YnptibH54r6E+H3/IqQ/9dJP/AEKumoCx8/6d8JvE13Hukt4b Uek8uD+QzXaaH8GrK3RZNau5LmTOfLhOxPoT1P6V6ZRQMqWGl2WlwiKxtYbdAMYjQD8/WrVLRQAU UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQBzmo/8hCb6/wBK2dN/5B8X0/rWLqP/ACEJvr/StrTf +QfD9P60AWqKKKACiiigAooooAKKKKACiiigAooooAKr3xxZTf7pqxVXUTiwm/3aAMK0G68hH+2K 6eub08Zv4f8AerpKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACvLfiP/ AMjGv/Xuv8zXqVeW/Ef/AJGNf+vdf5mgD0XR/wDkC2P/AFwT/wBBFXapaP8A8gWx/wCuCf8AoIq7 QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAMl5if/dNeSeC+PF9p/vP/AOgmvXH+430ryPwb /wAjhaf77/yNAHr1FFFABRRRQAUUUUAFUNc40K//AOvd/wD0E1frP1440DUP+vd//QTQB598N/8A kYpP+vdv5ivUa8v+Gw/4qGX/AK9z/MV6hQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFcF8 UP8AU6d/vv8AyFd7XBfFD/U6d/vv/IUAa/w+/wCRUh/66Sf+hV01cz8Pv+RUh/66Sf8AoVdNQAUU UUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRR QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFJS0UAc3qP/H/ADfX+lbWm/8AIPh+lYuof8f8 3+9W1p3/ACD4f92gC1RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABVPVTjT5PfA/WrlUNYP+gn3YUAZ mmDOoR/j/Kuirn9JGdQT6GugoAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKK KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooo oAK8t+I//Ixr/wBe6/zNepV5b8SP+RjX/r3X+ZoA9F0f/kC2P/XBP/QRV2sHS/EWkxaTZxyajbK6 woGBkGQcCrX/AAkuj/8AQTtf+/goA1KKy/8AhJdH/wCgna/9/BR/wkuj/wDQTtf+/goA1KKy/wDh JdH/AOgna/8AfwUf8JLo/wD0E7X/AL+CgDUorL/4SXR/+gna/wDfwUf8JLo//QTtf+/goA1KKy/+ El0f/oJ2v/fwUf8ACS6P/wBBO1/7+CgDUorL/wCEl0f/AKCdr/38FH/CS6P/ANBO1/7+CgDUorL/ AOEl0f8A6Cdr/wB/BR/wkuj/APQTtf8Av4KANSisv/hJdH/6Cdr/AN/BR/wkuj/9BO1/7+CgDTPI NeQ+D/8AkcbT/ro/8jXpf/CS6N/0E7X/AL+CvNPCB/4rG0IPBkfH5GgD1+iiigAooooAKKKKACs7 xBx4e1H/AK9pP/QTWjWb4i48Oaj/ANe0n/oJoA4L4bf8jBN/17n+Yr0+vKfAN9bWGtTSXc8cKGAg M5wCcivQv+El0f8A6Cdr/wB/BQBqUVl/8JLo/wD0E7X/AL+Cj/hJdH/6Cdr/AN/BQBqUVl/8JLo/ /QTtf+/go/4SXR/+gna/9/BQBqUVl/8ACS6P/wBBO1/7+Cj/AISXR/8AoJ2v/fwUAalFZf8Awkuj /wDQTtf+/go/4SXR/wDoJ2v/AH8FAGpRWX/wkuj/APQTtf8Av4KP+El0f/oJ2v8A38FAGpRWX/wk uj/9BO1/7+Cj/hJdH/6Cdr/38FAGpRWX/wAJLo//AEE7X/v4KP8AhJdH/wCgna/9/BQBqVwXxQ/1 Onf77/yFdT/wkuj/APQTtf8Av4K4z4h6nZajFYCzuopyjPu8ts44FAHQ/D7/AJFSH/rpJ/6FXTVz Pw+/5FSH/rpJ/wChV01ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUlAHN3//AB/T f71bmn/8eEP+7WFe/wDH7N/vmt6w/wCPGH/doAsUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAVna1/ x5r/AL4rRrN1v/j1T/foAp6OP9PHsprerC0Yf6Yx9ErdoAKKKKACiiigAooooAKKKKACiiigAooo oAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiig AooooAKKKKACiiigAooooAK4zxX4Ovde1dbq2nt0QRBMSE5yCfQe9dnRQB5l/wAK01T/AJ+rP82/ wo/4Vpqn/P1Z/m3+Fem0UAeZf8K01T/n6s/zb/Cj/hWmqf8AP1Z/m3+FemZooA8z/wCFaap/z9Wf 5t/hR/wrTVP+fqz/ADb/AAr02koA8z/4Vpqn/P1Z/m3+FH/CtNU/5+rP82/wr02igDzL/hWmqf8A P1Z/m3+FH/CtNU/5+rP82/wr02koA8z/AOFaap/z9Wf5t/hR/wAK01T/AJ+rP82/wr0zNGaAPM/+ Faap/wA/Vn+bf4Uf8K01T/n6s/zb/CvTaKAPMv8AhWmqf8/Vn+bf4Uf8K01T/n6s/wA2/wAK9MzR mgDzP/hWmqf8/Vn+bf4VoaD4E1DStbtrya4tmjiYlghbJ4I9K7yjNABS0lGaAFooooAKKKTNAC1T 1a0kv9Ju7WIqrzRMilugJGKt0UAeZ/8ACtNU/wCfqz/Nv8KP+Faap/z9Wf5t/hXptJQB5n/wrTVP +fqz/Nv8KP8AhWmqf8/Vn+bf4V6ZRmgDzP8A4Vpqn/P1Z/m3+FH/AArTVP8An6s/zb/CvTaKAPMv +Faap/z9Wf5t/hR/wrTVP+fqz/Nv8K9MozQB5n/wrTVP+fqz/Nv8KP8AhWmqf8/Vn+bf4V6bRQB5 l/wrTVP+fqz/ADb/AAo/4Vpqn/P1Z/m3+FemZpaAPMv+Faap/wA/Vn+bf4Uf8K01T/n6s/zb/CvT M0tAHmX/AArTVP8An6s/zb/Cj/hWmqf8/Vn+bf4V6bRQB5l/wrTVP+fqz/Nv8KP+Faap/wA/Vn+b f4V6bRQBj+F9Im0TRY7O4dHkV2YlM45Oe9bFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAcxdnN3Mf8AbNdBZcWUP+4K525ObiU/7Z/nXR2gxaQj/YFAE1FFFABRRRQAUUUUAFFF FABRRRQAUUUUAFZut/8AHtH/AL/9K0qzNb/494/97+lAFfRP+PqT/c/rW3WJon/HzJ/uf1rboAKK KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooo oAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigDlfiLYyXXhG8uYb+ 8s5bKN7hGtpNhchTw3tWDoesv4T8F6PIHv8AWtV1wJJBbzTZO9kBYBj91B/Wu28RabJrPh3UNOhd Y5LqB4lduikjGTXO3vgi6l8O6BFZ30dvrGhoggnK7o2IUKwI67TigCMfEKexh1SHXNGks9TsLX7W LeOUSLNHnGVYehPNYfiTxfrGs/C/UL9NNW1BMYWe3vVcBCQSwI5yDgEe9btl4S117y/1nU9Ss21u e1+y2/lQkwQJnPQ8tk+tZVv8M9SOgeILae7sIbnV/LxFaxstvFtOSQOuT7UAXrn4gXdiLDTI9Ntz qz2qz3EdxfJFHCvQZc/eY9cD1ps3xTRPDkeow6Y0tyL4WE1qswO2Qgn5WGQwOOKl8QeAbi71eHVt NXS57oWy288GoweZE+3ow7hh/KkufAF3caBptn5umw3VvqEd5O1tbeTG4XPygDqcHGTQBpeG/F15 quv32jatpR06+tY1mCiYSK0bdOR35Fcx8UvEOpaT4o0X+zXm8qyja9uo43IDxh1B3DuMA9fWuvtf Ds8Hj6919pozBcWaW6xAHcCCDk9scVWv/Bzap4svtSvJY2tLnTDYLEAdy7jlm9KAOS17xfdS/FbR 1tLmRdIgkht5djEI7zKWG4dDwR+VN0XXbnTvFfi/Xdat7gW9gxTi73KnQLGE6Etxz2rQs/hdc2fg 2PTFvYG1FdQS9NyQ207OAPXpV7UfCCQaX4ufUzJcW2qyCdUtIy0sYUcEA9SDg49qAGL8QdatptKG q+GTaQapcJDBKLoNtDdNwxkHBzitjx/rt5oPhvzNOKreXM8drC7DIRnON34c15raX+peJtb8N6fH qx1NLC8jkZEsHh8pE/ilZuN2BjA461634m8P23ifQ5tNumeNXIZJE+9G4OVYfSgDmY/h3qFr5N3a +LNWGqKwaSWZ/Mik55HlntWN4uW8g8eK2sazqWmWEyxrp13bN+4jkGN6yL0yeev8q2YvD3juXybO 78T2qWcTDNxBBi4kA7HPH+e9Hivwd4i124vLa31uA6RfhBLBcxbmg2/888etAHZG+tYpktpLuETs BtjaRQ7fQe9eIeJPEV5F4n1eX+19RTUbbUEiszBJ/occeRkSdgcda9gj8KaQLizuprGKa8s40jiu ZFzIAgwpzXGXnw514pqWlWOr2aaFqVybiVZISZkyQSAeh6etAHpMZJiQkqSQMleh+lefWniQ6P4v 8cXeo3E72Nglu6RbiQuU6KOgJOK7O8sLkaC9lpd0LW5WERwzum/YQMAkd65Kw+Ht5d2PiEeJb6Ga 81oRrI9qmFjEY+UgHvnB/CgCey8eajHf6emv6E2m2epuI7W4+0LJ8x5VXH8JNSyfECO10nXLi8tD FeaVc/ZzbK+4zM3+rIOP4s+naqtt4N1/Ub7TB4m1OzuLDSpFlhjtoirTOowrOT0x7VU1Dw/Brnxh jljjkFvY28c972jkmBPlD3IBz+FAF5/HuoHxZHoUOiq06RxPcB7pUZd4BOwH74XPOPSuR1DWdTN3 49W+t7pLSLyixhvMNBggKF4P3hycD2rq/F3gnV/E+uQyfa9OisY5EkSXyCLqDb1CuOufel1PwFeX y+LQl3br/bnk+VuB/d7MZ3fXHagCSTxjfLdw6N4d0h9Tu7e0iluWmuAixBlBALHqxFUPFuvXaN4Q vdRil0jdqObqF5hhVA53EHBHers/g/XNM1dtU8M39lFcXNvHBeQ3cbGNyigB1I5zUuteDL/xFa6F HrF3a3b2Nx5t3mIosyngqAPbigDX8MeIJ/EtrNfCxe2sGci0kkb550H8e3+EHtXPa4dR8V+OJvDl vqM+nadY26T3L2zbZZi3RQ3YVueFtB1Dw4J7BrxLrSUObIPnzoV/uE9CB2qp4k8I3t3rUWu+HdQG n6tHH5LmRd0U6dgw9vWgDG8O3elaFrdxBY+MpdRiMbKunXMnmP5q5PD9uh4qjN4uufE9v4c1C60+ 5sLS41SKO2aC8wZG+YNuGPugjp3rW0f4f3v9sSaxrk+nterC8VvFZW4jiQuCC7cZY80tr8P72Dw7 4Y043luX0e+F1K4DYkXcxwvv83egBi/ELWbx9TOl+GGuoNMuHhnl+1BdwXrtGMk45xXYaFrFvr+i 2up2m4Q3Kb1DdR2IP0ORXmfhvS/FN4fEsei39rZ21xqk8ci3ULFlz1dD7g4/Cu20XS73w9LpOiae gbSbS1c3FzIPmkcnhV54OSWPtQBj/Fy51G30HTV0i5lt7ubUY4kaNyuSQ2AfbOKyoPF8+veIvBxE sltcedPBqForEASqnRh6dxXYeMPDc/iSHTEt5oojZ38V23mAncq54GO/NZd98PVk+I1j4nspo4VQ lrqEg/vG2lQy++Dz9KAIrn4hag7391o/h+S+0jTpGjuLrz1RmK/eKL3ArqY9Tg1Xw0dRsZCYZ7Yy xt0Iyv8AMVyMvgjxBYjUNO0LVrSDRtRkeSRZoi00G/74Qjg59666w0SHS/DcWkWZxFDb+SjN34xk /U80AeO+ANav7rWtETTtW1e+u5HY6pb3BLwRxf3gT+H412t/8TZEv75dL063urOwkMc0k18kLyMv 3vLQ8tj9aND+Hl9oEug3dneW63ljG1ve/KdlzCWLAeuRnjNV7v4b31vqN62kDQ5ba9mM27UbPzZb dicnYe49AaAEPiu3uPHdjq8dzMNKbQZLtkycDDHOV6bhjFPn+JmsWmlQardeF3j027kRbeU3SlsM eCy4yMjpWlc+ARda3HM8lulh/ZT6fJFFHsJLHJZQOAOc4rGvPAPiy/0S20S41vT206zkjMJELCSV VPyhz2wPSgDo5fG8NlceIYtSg+zto6LKPnz58bD5SOOCTxj1NZN18RtRi1LTdPi0JWvLu1S6eKW7 WPAY8IhYYZgOoqDxh4fg8SfEnRbVEkAjgMuoMoIVolYFEY9yWHSr/jrwdq3iuWOC3uNMSx2qMzwE zQMDktGw9RxjpQB2yElQWGD3HpTqhtYTb2sUJdnMaKm9urYGMn3qagAooooAKKKKACiiigAooooA KKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAo oooAKKKKACiiigAooooAKKKKACiikoA5ab/WyH/aP866aAYt4x6KP5VzD8u3uTXUxjEaj2FADqKK KACiiigAooooAKKKKACiiigAooooAKzNb/1Ef+9/StOszW/+PeP/AHv6UAQaJ/x8yf7n9a2qxdE/ 4+ZP9z+tbVABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUUUAFFFFABSUtFACYA7UtFFABRRRQAUUUUAFFFFABSYFLRQAUUUUAJS0UUAFFFFABS UtFACYFGKWigApKWigAooooAKKKKACiiigBMCloooAKKKKACiiigAooooAKKKKACiiigAooooAKK KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooo oAKKKKACiiigAooooAKRvun6UtMmO2CQ+imgDlhy31NdWOAK5WIZkQerCuqoAWiiigAooooAKKKK ACiiigAooooAKKKKACs3W/8Aj3j/AN7+laVZut/8eqf7/wDSgCton/H1J/uf1rbrD0U4vG90rcoA KKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAo oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKK ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACobw4s5 j/sGpqragcWM3+7QBz9sM3EQ/wBsfzrqa5qxG6+hH+1XS0AFFFFABRRRQAUUUUAf/9k ________________________________________________________________________________
From: "Valin & Allyson Thorn" <thorn(at)starflight.aero>
Subject: How to Toggle Speed Brakes with Momentary On Switch?
Date: Jan 10, 2014
Thanks Bob McC. I'm checking with Precise Flight if maintained input is okay. Seems like it would be. I didn't know that latching relays would toggle the switch without changing the polarity at the coil. What does the relay symbol look like for that? Does anyone know of a good source for a 24 VDC SPDT Bi-Stable/Latching Relay? Thanks again, Valin From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bob McCallum Sent: Friday, January 10, 2014 12:00 PM Subject: RE: AeroElectric-List: How to Toggle Speed Brakes with Momentary On Switch? Valin; Use the stick output to energize a bi-stable spdt relay. Each time the coil is energized the relay switches and the opposite wire becomes energized. (also referred to as a "latching relay") This assumes the speed brake controller is happy with a maintained input. Bob McC _____ From: thorn(at)starflight.aero <mailto:thorn(at)starflight.aero> Subject: AeroElectric-List: How to Toggle Speed Brakes with Momentary On Switch? Date: Fri, 10 Jan 2014 11:14:48 -0700 Hello Bob N or anyone that can help, I'd like to toggle our speed brakes/spoilers up or down by the press of a momentary on button on our Tosten control sticks. In my circuit diagram below, this arrangement will deploy (raise up) the Precise Flight Speed Brakes when the left button is pressed on the stick. Note a positive voltage on SB control unit's pin 6 deploys them up and positive on pin 7 retracts them down. I'd like to be able to press and release it and have it change states up/down. I know the easiest would be if I could change the switch on the stick to lock closed when pressed and unlock when pressed - but, that's not an option for this control stick. Is there a simple way to achieve this capability with these contraints? Thanks, Valin Thorn Lancair Legacy Project Boulder, Colorado ________________________________________________________________________________
Subject: Z-12 Essential Bus Questions
Date: Jan 10, 2014
Hello Bob N and anyone else with thoughts on this, We're working to implement your Z-12 power grid/distribution architecture (Prime Alt, Standby Alt, Single Battery, E-Bus) in our Lancair Legacy. I'm struggling a bit with whether or not to have an Essential Bus. I don't see it as saving that much time if the alternators go down to load shed with one switch vs. just powering down some boxes one by one. I see the main advantage of the Essential Bus is having a way to get power to critical boxes/functions even if the two alternators and the battery contactor fails. What's complicating my thinking on this architecture is my desire for an Avionics Bus. If I remember right, you're not a fan of Avionics Buses. My reasoning for one is that we have an EFIS system with no dedicated engine instruments. So, for engine start we'll have the minimum EFIS components on to monitor the engine health and not expose any other avionics to the engine start voltage drop and potential unnecessary power cycling. One key box I'd like to protect, as an example, is the $15,000 Garmin GTN 750 - of course there are others... So then when I think about what needs to be on the E-Bus, a bunch of avionics seems to belong there - which would expose them to the risk of the engine start power cycling. It seems like I'd need an E-Bus off the Main Bus and the Avionics Bus.? When I consider the low probability of both alternators and the battery contactor going down at the same time, I wonder if it's worth the complication. Would appreciate anyone's thoughts on this. Below is an excerpt from power grid hybrid schematic. Thanks, Valin Thorn Lancair Legacy Project Boulder, Colorado ________________________________________________________________________________
Date: Jan 11, 2014
Subject: Re: How to Toggle Speed Brakes with Momentary On Switch?
Date: Jan 11, 2014
(trying again - text in original was invisible) Latching relays can be had with one of (at least) the following modes of actuation: - a set coil and a reset coil, possibly with the + terminals in common - one coil with different polarity for set and reset - one coil with the same polarity for set and reset (toggle action) Jan de Jong ________________________________________________________________________________
From: Bob McCallum <robert.mccallum2(at)sympatico.ca>
Date: Jan 10, 2014
Valin; Here's a couple of examples; 1: Omron G4Q-212S-12VDC or G4Q-212S-24VDC Bob McC _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Valin & Allyson Thorn Sent: Friday, January 10, 2014 5:04 PM Subject: RE: AeroElectric-List: How to Toggle Speed Brakes with Momentary On Switch? Thanks Bob McC. I'm checking with Precise Flight if maintained input is okay. Seems like it would be. I didn't know that latching relays would toggle the switch without changing the polarity at the coil. What does the relay symbol look like for that? Does anyone know of a good source for a 24 VDC SPDT Bi-Stable/Latching Relay? Thanks again, Valin From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bob McCallum Sent: Friday, January 10, 2014 12:00 PM Subject: RE: AeroElectric-List: How to Toggle Speed Brakes with Momentary On Switch? Valin; Use the stick output to energize a bi-stable spdt relay. Each time the coil is energized the relay switches and the opposite wire becomes energized. (also referred to as a "latching relay") This assumes the speed brake controller is happy with a maintained input. Bob McC _____ From: thorn(at)starflight.aero Subject: AeroElectric-List: How to Toggle Speed Brakes with Momentary On Switch? Date: Fri, 10 Jan 2014 11:14:48 -0700 Hello Bob N or anyone that can help, I'd like to toggle our speed brakes/spoilers up or down by the press of a momentary on button on our Tosten control sticks. In my circuit diagram below, this arrangement will deploy (raise up) the Precise Flight Speed Brakes when the left button is pressed on the stick. Note a positive voltage on SB control unit's pin 6 deploys them up and positive on pin 7 retracts them down. I'd like to be able to press and release it and have it change states up/down. I know the easiest would be if I could change the switch on the stick to lock closed when pressed and unlock when pressed - but, that's not an option for this control stick. Is there a simple way to achieve this capability with these contraints? Thanks, Valin Thorn Lancair Legacy Project Boulder, Colorado ________________________________________________________________________________
Date: Jan 11, 2014
Are you certain that momentary switch controlled speed brakes (latching up and down) are a good idea? I can see you getting in trouble during a go-around situation where you are busy applying power/setting flaps/killing carb heat/raising gear and losing track of speed brake position. During go-around, you are too darned close to the ground and eyes must be outside the airplane and control positioning must be achieved by feel. I have no experience with speed brakes and I could be dead wrong, but I think this is at least worthy of consideration. -------- Jerry King Read this topic online here: http://forums.matronics.com/viewtopic.php?p=416774#416774 ________________________________________________________________________________
From: "Dr. Andrew Elliott" <a.s.elliott(at)cox.net>
Subject: Really technical information
Date: Jan 11, 2014
For a very good reference document about relays, including latching ones, see http://tinyurl.com/7738cer Andy ------------------------ Andy Elliott, CL:480-695-9568 N601GE/Z601XL/TD/Corvair 555 hrs since 11/08 <http://servi-aero.com/n601ge/4sale/> Web Site Link ________________________________________________________________________________
Date: Jan 11, 2014
Subject: Re: Z-12 Essential Bus Questions
At 04:24 PM 1/10/2014, you wrote: >Hello Bob N and anyone else with thoughts on this, > >Were working to implement your Z-12 power >grid/distribution architecture (Prime Alt, >Standby Alt, Single Battery, E-Bus) in our >Lancair Legacy. Im struggling a bit with >whether or not to have an Essential Bus. I >dont see it as saving that much time if the >alternators go down to load shed with one switch >vs. just powering down some boxes one by one. I >see the main advantage of the Essential Bus is >having a way to get power to critical >boxes/functions even if the two alternators and the battery contactor fails. > >Whats complicating my thinking on this >architecture is my desire for an Avionics >Bus. If I remember right, youre not a fan of >Avionics Buses. My reasoning for one is that we >have an EFIS system with no dedicated engine >instruments. So, for engine start well have >the minimum EFIS components on to monitor the >engine health and not expose any other avionics >to the engine start voltage drop and potential >unnecessary power cycling. One key box Id like >to protect, as an example, is the $15,000 Garmin >GTN 750 of course there are others... > >So then when I think about what needs to be on >the E-Bus, a bunch of avionics seems to belong >there which would expose them to the risk of >the engine start power cycling It seems like >Id need an E-Bus off the Main Bus and the Avionics Bus? > >When I consider the low probability of both >alternators and the battery contactor going down >at the same time, I wonder if its worth the complication. > >Would appreciate anyones thoughts on >this. Below is an excerpt from power grid hybrid schematic. > >Thanks, > >Valin Thorn >Lancair Legacy Project >Boulder, Colorado You've expressed concerns for "unnecessary power cycling", "voltage drops", etc. Is it written anywhere that such stresses are to be avoided . . . particularly by the folks who manufactured and qualified the hardware? After all, they KNEW it was intended for use in an airplane. They were obligated to test to all the nasties that DO-160 would throw at it. If there were things that you should avoid . . . or adopt as specialized operating practice for their device . . . it seems that such words would be included in the installation or operating literature. I am not a fan of avionics busses because they were ill-conceived in the first place and are certainly unnecessary given the rigorous testing required to get a device onto a TC airplane. The Essential Bus is really an ENDURANCE bus . . . and yes, very unlikely to be needed to back up dual alternator failures. But it DOES offer a way to power up a minimal suite of electro-whizzies during pre-flight to get the ATIS and clearance delivery. Some people put a "clearance delivery" switch feature in the power to the comm radio for this purpose . . . but as long as you're going to add one more switch, it might just as well be the E-Bus Alt Feed switch. I would encourage you to produce drawings not unlike those found in the back of the service manuals for a Beech, Cessna, Piper or those found on the aeroelectric.com website. Wirebook schematics are a language intended to convey meaning . . . you've spent a significant amount of time and effort to produce the pictograms . . . and while they are accurate, they are the linguistic equivalent of ebonics or some other variant of the spoken word. The schematic processes cited above will convey the meat of your meaning in a heartbeat. The pictograms take some study and might give some folks pause to wonder if they should bother. Bob . . . ________________________________________________________________________________
Date: Jan 11, 2014
Switch? At 04:04 PM 1/10/2014, you wrote: >Thanks Bob McC. I'm checking with Precise Flight if maintained >input is okay. Seems like it would be. > >I didn't know that latching relays would toggle the switch without >changing the polarity at the coil. What does the relay symbol look >like for that? > >Does anyone know of a good source for a 24 VDC SPDT Bi-Stable/Latching Relay? > Don't think you want a bi-stable device. These are MECHANICALLY bi-stable with two coils and would still require some external electronics to achieve the P-ON/P-OFF behavior. I don't think you want a device that can remain in the ON state after power down. My favorite approach to this design problem is shown here . . . http://tinyurl.com/jwzaocy You need a DPDT relay rated at 1/2 your system voltage. If you've got a 24v system, then a 12v relay. Select resistors equal to the resistance of the relay. If power is shut off the relay relaxes and stays in that state. When power is applied, capacitor C charges to 1/2 system voltage through the voltage divider of the two resistors. Pushing the button discharges the capacitor into the relay coil causing it to energize and latch through the lower normally open contacts. In this state, the capacitor finishes discharging to zero volts through the paralleled resistor. Pushing the button again causes the capacitor to act like a momentary short across the relay coil causing it to de-energize, opening the latching contacts. If you HOLD the button closed for an OFF cycle the relay MIGHT re-energize on the approximately 1/3 system voltage applied to the relay coil . . . which . . . depending on the relay might cause it to re-close after the capacitor charges up. If this happens, adjust the resistor across the capacitor downward until this phenomenon stops. This generally isn't an issue if you keep the button pushes short. You will want to fiddle with this a bit and adjust R across the capacitor as needed. I've used this circuit many times . . . most recently to convert a momentary contact radio remote to Push-ON/Push-OFF for the driveway light on my garage. Suggest you purge the term "speed brake" from your language used to talk about this system. It's a spoiler system that kills lift . . . designed to INCRASE rate of descent without materially increasing forward velocity. A speed brake puts out DRAG intended to slow the forward velocity. A pilot flying a Lanceair IVP with Precise Flgiht found himself on short final to the rocks out in California a few years ago. Check out the narrative paragraph 3 here http://tinyurl.com/m3zxgpw His deployment of "speed brakes" in fact increased his downward velocity. The Precise Flight system is not a speed brake. Bob . . . ________________________________________________________________________________
Date: Jan 11, 2014
Hi Valin, If your Precise Flight speedbrakes are the same as mine, which I think they are, you need the function of an ON-On switch. That's because connecting ship's power to pin #6 extends the speedbrakes and keeps them extended; connecting ship's power to pin #7 retracts the speedbrakes. You can see this on the attached wiring diagram from my wiring book. (I drew it in AutoCAD and converting it to PDF screwed it up a little, but it's still readable.) I've seen at least one Legacy wired with an ON-OFF switch. It sort of works because the speedbrakes controller automatically snaps the speedbrakes closed if all power is removed. But instead of a smooth powering closed, they snap closed fast and hard from a strong spring inside them. To answer one of your questions, power is continuously connected either to pin #6 or pin #7 at all times. Disconnecting power will automatically (and almost violently) retract the speedbrakes. It sounds like an ON-ON latching relay will work fine. Contact me directly if you want more info on this. Thanks to Bob N. for his advice to create a Wire Book with one page per component. I've referred to mine many, many times. Best, Dennis Legacy, 680 hours ________________________________________________________________________________
Switch?
Date: Jan 11, 2014
Bob; Respectfully beg to differ on your comment below that bi-stable relays are dual coil devices requiring some additional electronics to operate with a single button. While this is correct for SOME bi-stable relays others are single coil devices simply changing state on each subsequent operation, while still others are single coil devices which change state when alternate polarities are applied to the coil. The Omron G4Q-212S-xxVDC series for example are ones which have a single coil which alternates the contacts each time the coil is momentarily energized. I don't disagree with the rest of your comment however, but the question posed was "How do I do this?" and the single coil bi-stable relay is one simple inexpensive solution. Granted it is one of many and the plusses and minuses of whatever method is chosen must be assessed before a "best solution" is decided upon. Bob McC > -big snip- > Don't think you want a bi-stable device. These are MECHANICALLY > bi-stable with two coils and would still require some external > electronics to achieve the P-ON/P-OFF behavior. > > I don't think you want a device that can remain in the ON state > after power down. My favorite approach to this design problem > is shown here . . . > -another big snip- > Bob . . . ________________________________________________________________________________
Switch?
Date: Jan 11, 2014
Thanks Bob and everyone for your most excellent help. I'm a novice at electrical circuit stuff as you can tell - but, eager to learn and willing to ask questions. And yes, I agree, "spoilers" is a more accurate term for these lift disturbing devices - I'll correct that. Thanks again, Valin -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Saturday, January 11, 2014 8:30 AM Subject: RE: AeroElectric-List: How to Toggle Speed Brakes with Momentary On Switch? nuckolls.bob(at)aeroelectric.com> At 04:04 PM 1/10/2014, you wrote: >Thanks Bob McC. I'm checking with Precise Flight if maintained >input is okay. Seems like it would be. > >I didn't know that latching relays would toggle the switch without >changing the polarity at the coil. What does the relay symbol look >like for that? > >Does anyone know of a good source for a 24 VDC SPDT Bi-Stable/Latching Relay? > Don't think you want a bi-stable device. These are MECHANICALLY bi-stable with two coils and would still require some external electronics to achieve the P-ON/P-OFF behavior. I don't think you want a device that can remain in the ON state after power down. My favorite approach to this design problem is shown here . . . <http://tinyurl.com/jwzaocy> http://tinyurl.com/jwzaocy You need a DPDT relay rated at 1/2 your system voltage. If you've got a 24v system, then a 12v relay. Select resistors equal to the resistance of the relay. If power is shut off the relay relaxes and stays in that state. When power is applied, capacitor C charges to 1/2 system voltage through the voltage divider of the two resistors. Pushing the button discharges the capacitor into the relay coil causing it to energize and latch through the lower normally open contacts. In this state, the capacitor finishes discharging to zero volts through the paralleled resistor. Pushing the button again causes the capacitor to act like a momentary short across the relay coil causing it to de-energize, opening the latching contacts. If you HOLD the button closed for an OFF cycle the relay MIGHT re-energize on the approximately 1/3 system voltage applied to the relay coil . . . which . . . depending on the relay might cause it to re-close after the capacitor charges up. If this happens, adjust the resistor across the capacitor downward until this phenomenon stops. This generally isn't an issue if you keep the button pushes short. You will want to fiddle with this a bit and adjust R across the capacitor as needed. I've used this circuit many times . . . most recently to convert a momentary contact radio remote to Push-ON/Push-OFF for the driveway light on my garage. Suggest you purge the term "speed brake" from your language used to talk about this system. It's a spoiler system that kills lift . . . designed to INCRASE rate of descent without materially increasing forward velocity. A speed brake puts out DRAG intended to slow the forward velocity. A pilot flying a Lanceair IVP with Precise Flgiht found himself on short final to the rocks out in California a few years ago. Check out the narrative paragraph 3 here <http://tinyurl.com/m3zxgpw> http://tinyurl.com/m3zxgpw His deployment of "speed brakes" in fact increased his downward velocity. The Precise Flight system is not a speed brake. Bob . . . www.buildersbooks.com www.homebuilthelp.com http://www.matronics.com/contribution http://www.matronics.com/Navigator?AeroElectric-List ________________________________________________________________________________
Date: Jan 11, 2014
Thanks Bob. I read your recent, excellent article on DO-160 testing. With EAB airplanes, can we count on all the devices installed having seen the same testing? I'm planning on a bunch of Garmin's experimental avionics offerings and I'm not sure those boxes see the same testing as their certified hardware. I've Googled it a few times but can't find anything. I need to ask Garmin's Team X about it. So that's why I'm a bit shy to risk putting all the avionics through engine start power cycling. Good point about the every flight usefulness of at least getting a radio up without bring all your avionics up - so yes, why not add a few other essentials and provide a path around the battery contactor as well... Sorry about my "pictogram schematics" sometimes requiring more study than a basic schematic. The power grid is a bad example of the benefits in my wiring drawings. I have about 10 drawing layers covering the various systems where the wiring schematic is laid out in a kind of topology of the airplane - a top down view of the airplane in cartoon form. It helps me visualize where components and wires need to be within the airplane and where connectors might be most useful. On these drawings are also included the basic wiring schematic and other key info related to that system like pin outs for connectors, part numbers, etc.. The power grid example in my email was an excerpt from its overall page and didn't include the ancillary stuff. Working them up helps me get my novice head around the problems involved and collect a lot of key related data in one place. Thanks again Bob and everyone for your help. Valin -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Saturday, January 11, 2014 8:12 AM Subject: Re: AeroElectric-List: Z-12 Essential Bus Questions nuckolls.bob(at)aeroelectric.com> At 04:24 PM 1/10/2014, you wrote: >Hello Bob N and anyone else with thoughts on this, > >We're working to implement your Z-12 power >grid/distribution architecture (Prime Alt, >Standby Alt, Single Battery, E-Bus) in our >Lancair Legacy. I'm struggling a bit with >whether or not to have an Essential Bus. I >don't see it as saving that much time if the >alternators go down to load shed with one switch >vs. just powering down some boxes one by one. I >see the main advantage of the Essential Bus is >having a way to get power to critical >boxes/functions even if the two alternators and the battery contactor fails. > >What's complicating my thinking on this >architecture is my desire for an Avionics >Bus. If I remember right, you're not a fan of >Avionics Buses. My reasoning for one is that we >have an EFIS system with no dedicated engine >instruments. So, for engine start we'll have >the minimum EFIS components on to monitor the >engine health and not expose any other avionics >to the engine start voltage drop and potential >unnecessary power cycling. One key box I'd like >to protect, as an example, is the $15,000 Garmin >GTN 750 - of course there are others... > >So then when I think about what needs to be on >the E-Bus, a bunch of avionics seems to belong >there - which would expose them to the risk of >the engine start power cycling. It seems like >I'd need an E-Bus off the Main Bus and the Avionics Bus.? > >When I consider the low probability of both >alternators and the battery contactor going down >at the same time, I wonder if it's worth the complication. > >Would appreciate anyone's thoughts on >this. Below is an excerpt from power grid hybrid schematic. > >Thanks, > >Valin Thorn >Lancair Legacy Project >Boulder, Colorado You've expressed concerns for "unnecessary power cycling", "voltage drops", etc. Is it written anywhere that such stresses are to be avoided . . . particularly by the folks who manufactured and qualified the hardware? After all, they KNEW it was intended for use in an airplane. They were obligated to test to all the nasties that DO-160 would throw at it. If there were things that you should avoid . . . or adopt as specialized operating practice for their device . . . it seems that such words would be included in the installation or operating literature. I am not a fan of avionics busses because they were ill-conceived in the first place and are certainly unnecessary given the rigorous testing required to get a device onto a TC airplane. The Essential Bus is really an ENDURANCE bus . . . and yes, very unlikely to be needed to back up dual alternator failures. But it DOES offer a way to power up a minimal suite of electro-whizzies during pre-flight to get the ATIS and clearance delivery. Some people put a "clearance delivery" switch feature in the power to the comm radio for this purpose . . . but as long as you're going to add one more switch, it might just as well be the E-Bus Alt Feed switch. I would encourage you to produce drawings not unlike those found in the back of the service manuals for a Beech, Cessna, Piper or those found on the aeroelectric.com website. Wirebook schematics are a language intended to convey meaning . . . you've spent a significant amount of time and effort to produce the pictograms . . . and while they are accurate, they are the linguistic equivalent of ebonics or some other variant of the spoken word. The schematic processes cited above will convey the meat of your meaning in a heartbeat. The pictograms take some study and might give some folks pause to wonder if they should bother. Bob . . . www.buildersbooks.com www.homebuilthelp.com http://www.matronics.com/contribution http://www.matronics.com/Navigator?AeroElectric-List ________________________________________________________________________________
Date: Jan 11, 2014
On 1/11/2014 10:12 AM, Robert L. Nuckolls, III wrote: > > > At 04:24 PM 1/10/2014, you wrote: >> Hello Bob N and anyone else with thoughts on this, >> >> Were working to implement your Z-12 power grid/distribution >> architecture (Prime Alt, Standby Alt, Single Battery, E-Bus) in our >> Lancair Legacy. Im struggling a bit with whether or not to have an >> Essential Bus. I dont see it as saving that much time if the >> alternators go down to load shed with one switch vs. just powering >> down some boxes one by one. I see the main advantage of the Essential >> Bus is having a way to get power to critical boxes/functions even if >> the two alternators and the battery contactor fails. >> >> Whats complicating my thinking on this architecture is my desire for >> an Avionics Bus. If I remember right, youre not a fan of Avionics >> Buses. My reasoning for one is that we have an EFIS system with no >> dedicated engine instruments. So, for engine start well have the >> minimum EFIS components on to monitor the engine health and not >> expose any other avionics to the engine start voltage drop and >> potential unnecessary power cycling. One key box Id like to protect, >> as an example, is the $15,000 Garmin GTN 750 of course there are >> others... >> >> So then when I think about what needs to be on the E-Bus, a bunch of >> avionics seems to belong there which would expose them to the risk >> of the engine start power cycling It seems like Id need an E-Bus >> off the Main Bus and the Avionics Bus? >> >> When I consider the low probability of both alternators and the >> battery contactor going down at the same time, I wonder if its worth >> the complication. >> >> Would appreciate anyones thoughts on this. Below is an excerpt from >> power grid hybrid schematic. >> >> Thanks, >> >> Valin Thorn >> Lancair Legacy Project >> Boulder, Colorado Valiln, I had some similar concerns with my RV10 panel. I built a Z-14 (dual batt, dual alt, dual bus - diagram attached) with an avionics panel containing a full complement of electro whiz-bangs. I had no avionics bus or additional power switching for any devices that did not include such a switch. Of note, I have 3 GRT/HX EFISs that power up with the master switch. > > You've expressed concerns for "unnecessary power cycling", "voltage > drops", > etc. Is it written anywhere that such stresses are to be avoided . . . > particularly by the folks who manufactured and qualified the hardware? GRT does not document any concerns about "unnecessary power cycling" or "voltage drops". However, in conversations with GRT I was warned that interruption of the EFIS boot procedure may result in problems. Nothing definitive beyond that. However, before hearing this, I did expose the 3 units to a number of interrupted boot sequences. And I did have to return the unit that experienced most of the interrupts for service during this period though no connection with the interrupts was necessarily made. (I'd add that I am many software updates past this experience and any boot/power issues may have been addressed.) > > After all, they KNEW it was intended for use in an airplane. They > were obligated to test to all the nasties that DO-160 would throw > at it. If there were things that you should avoid . . . or adopt as > specialized operating practice for their device . . . it seems that > such words would be included in the installation or operating literature. Agreed. The procedure I adopted was to insure that the 15sec+ boot procedure on all 3 units be complete before engine start. Seems obvious since a display is required for engine parameter display but early on I did expose 1 unit to cycling during the start because 1 unit would always lag behind the other 2 due to configuration differences... and I was unnecessarily impatient. My EFIS units were still occasionally being cycled during engine start due to some issues unrelated to the discussion here (thanks to Bob and GRT for working these thru with me). During the course of getting these issues under control, I added a TCW Technologies Intelligent Power Stabilizer (IPS) to my installation. It was connected to some unused backup power inputs on the EFIS units. Now, no matter how much I 'abuse' my system, I can rely on my EFIS units to stay up during engine start. What do I mean by 'abuse'? Running the EFIS units and some other avionics for an extended period on battery power only and then attempting a start of a cold engine, on a cold day, and perhaps forgetting to tie the buses and their batteries together for the start. At this point I think the IPS is unneeded, but for a period of time, it stopped some inadvertent power cycling of the units. You might consider one of these units for your installation to ease your concerns. I know that some Garmin units have backup power inputs in which case the addition of an IPS is similar to simply adding a backup battery that you never need to charge. It will also work with units that only have a single power input. > > I am not a fan of avionics busses because they were ill-conceived > in the first place and are certainly unnecessary given the rigorous > testing required to get a device onto a TC airplane. > > The Essential Bus is really an ENDURANCE bus . . . and yes, > very unlikely to be needed to back up dual alternator failures. > But it DOES offer a way to power up a minimal suite of electro-whizzies > during pre-flight to get the ATIS and clearance delivery. Some people > put a "clearance delivery" switch feature in the power to the comm > radio for this purpose . . . but as long as you're going to add one > more switch, it might just as well be the E-Bus Alt Feed switch. > > I would encourage you to produce drawings not unlike those found > in the back of the service manuals for a Beech, Cessna, Piper > or those found on the aeroelectric.com website. Wirebook schematics are > a language intended to convey meaning . . . you've spent a significant > amount of time and effort to produce the pictograms . . . and while > they are accurate, they are the linguistic equivalent of ebonics > or some other variant of the spoken word. This electrically challenged builder found the drawings clear and easy to read.... but then I'm probably fluent in ebonics. > The schematic processes cited above will convey the meat of your > meaning in a heartbeat. The pictograms take some study and > might give some folks pause to wonder if they should bother. > > > Bob . . . > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Switch?
Date: Jan 11, 2014
Hi Jerry, No I'm not certain having the spoilers on the control sick is the best approach for the reasons you described =93 especially with my flying to mostly be from high elevation airports in Colorado. I take some comfort in that a number of Lancair Legacy pilots have accidentally landed with the spoilers deployed and it was not an issue. I'm planning an annunciator high on the instrument panel to help make its clear they're deployed if the noise and vibration from them does not make it clear enough. I struggle with what=99s best to have on the control stick with few precious switches there. For the spoilers, I imagine that they=99ll be most useful when precise energy management is need on approach and landing. So a hand on the throttle to add energy and seems nice not have to move a hand to speed removing it with the spoilers (and higher AOA allowed to increase drag, to be technically precise on Bob N=99s recommendation :)). Although, I=99ll be moving my hand to deploy flaps The problem with putting flaps on the stick is if one accidentally hits the flaps button at high speed they will likely be damaged at the Legacy=99s cruise speeds. Full flaps max speed in the Legacy is 120 kts, where it cruises at over 200 kts I=99m still deliberating where the spoiler switch goes Thanks. Valin -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of racerjerry Sent: Saturday, January 11, 2014 4:54 AM Subject: AeroElectric-List: Re: How to Toggle Speed Brakes with Momentary On Switch? gki(at)suffolk.lib.ny.us> Are you certain that momentary switch controlled speed brakes (latching up and down) are a good idea? I can see you getting in trouble during a go-around situation where you are busy applying power/setting flaps/killing carb heat/raising gear and losing track of speed brake position. During go-around, you are too darned close to the ground and eyes must be outside the airplane and control positioning must be achieved by =C3=A2=82=AC=CB=9Cfeel.=C3=A2=82=AC=84=A2 I have no experience with speed brakes and I could be dead wrong, but I think this is at least worthy of consideration. -------- Jerry King Read this topic online here: <http://forums.matronics.com/viewtopic.php?p=416774#416774> http://forums.matronics.com/viewtopic.php?p=416774#416774 www.aeroelectric.com www.buildersbooks.com www.homebuilthelp.com www.mypilotstore.com http://www.matronics.com/contribution http://www.matronics.com/Navigator?AeroElectric-List ________________________________________________________________________________
Date: Jan 12, 2014
nuckolls.bob(at)aeroelect wrote: > > Suggest you purge the term "speed brake" from your > language used to talk about this system. It's > a spoiler system that kills lift . . . designed to > INCRASE rate of descent without materially > increasing forward velocity. A speed brake puts > out DRAG intended to slow the forward velocity. > > A pilot flying a Lanceair IVP with Precise Flgiht found > himself on short final to the rocks out in California > a few years ago. Check out the narrative paragraph > 3 here http://tinyurl.com/m3zxgpw > > His deployment of "speed brakes" in fact increased > his downward velocity. The Precise Flight system > is not a speed brake. > Unfortunately I'm going to have to disagree with Bob here! I'd suggest the term "speed brake" is quite appropriate when looking at how the Precise Flight system is designed to work. so it's no surprise that the company have named them "speed brakes". Spoilers are designed to reduce lift and moderately increase drag. They do so by creating a controlled stall over that section of the wing immediately behind them. Speedbrakes are primarily designed to increase drag with minimal effect on lift. On the Boeings and Airbuses I've flown in my day job you'll see the lever which actuates the spoiler panels labelled "speed brake". On the ground, they function as lift dumpers. In the air they function as speed brakes. The function is defined by how many spoiler panels extend and to what degree. On fighter jets the "speed brake" is normally a pure speed brake - panels extending from the fuselage and having minimal to no effect on lift. Going by the photos on their website, the Precise Flight system is narrow perforated flat plates extending perpendicularly from the wing. I'd suggest this is a classic speed brake design characteristic, not a spoiler design at all, even though it's on top of the wing. The increased drag of speed brakes, or reduced lift/increased drag of spoilers, can both be used to either increase descent rate or reduce forward speed. The dominant effect on flight path depends entirely on what the pilot does with the pitch attitude of the aircraft. It does not necessarily define whether they're primarily "spoilers" or "speed brakes". Food for thought. [Wink] -------- Mike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=416824#416824 ________________________________________________________________________________
Switch?
Date: Jan 12, 2014
Yes, in the version used in the Legacy they scissor up from the wings - see image below... -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of mmayfield Sent: Sunday, January 12, 2014 8:15 AM Subject: AeroElectric-List: Re: How to Toggle Speed Brakes with Momentary On Switch? mmayfield(at)ozemail.com.au> nuckolls.bob(at)aeroelect wrote: > > Suggest you purge the term "speed brake" from your > language used to talk about this system. It's > a spoiler system that kills lift . . . designed to > INCRASE rate of descent without materially > increasing forward velocity. A speed brake puts > out DRAG intended to slow the forward velocity. > > A pilot flying a Lanceair IVP with Precise Flgiht found > himself on short final to the rocks out in California > a few years ago. Check out the narrative paragraph > 3 here <http://tinyurl.com/m3zxgpw> http://tinyurl.com/m3zxgpw > > His deployment of "speed brakes" in fact increased > his downward velocity. The Precise Flight system > is not a speed brake. > Unfortunately I'm going to have to disagree with Bob here! I'd suggest the term "speed brake" is quite appropriate when looking at how the Precise Flight system is designed to work. so it's no surprise that the company have named them "speed brakes". Spoilers are designed to reduce lift and moderately increase drag. They do so by creating a controlled stall over that section of the wing immediately behind them. Speedbrakes are primarily designed to increase drag with minimal effect on lift. On the Boeings and Airbuses I've flown in my day job you'll see the lever which actuates the spoiler panels labelled "speed brake". On the ground, they function as lift dumpers. In the air they function as speed brakes. The function is defined by how many spoiler panels extend and to what degree. On fighter jets the "speed brake" is normally a pure speed brake - panels extending from the fuselage and having minimal to no effect on lift. Going by the photos on their website, the Precise Flight system is narrow perforated flat plates extending perpendicularly from the wing. I'd suggest this is a classic speed brake design characteristic, not a spoiler design at all, even though it's on top of the wing. The increased drag of speed brakes, or reduced lift/increased drag of spoilers, can both be used to either increase descent rate or reduce forward speed. The dominant effect on flight path depends entirely on what the pilot does with the pitch attitude of the aircraft. It does not necessarily define whether they're primarily "spoilers" or "speed brakes". Food for thought. [Wink] -------- Mike Read this topic online here: <http://forums.matronics.com/viewtopic.php?p=416824#416824> http://forums.matronics.com/viewtopic.php?p=416824#416824 http://www.matronics.com/Navigator?AeroElectric-List http://www.matronics.com/contribution ________________________________________________________________________________
Subject: Spoilers vs. Speed Brakes
Date: Jan 12, 2014
In my opinion, the Precise Flight speed brakes installed on many Lancairs, including on my Legacy, are correctly called "speed brakes" instead of "spoilers." I think the confusion comes from their installation on the top of the wings. Obviously, in that position, they do in fact "spoil" lift when extended. However, a classic spoiler is a narrow panel that extends across much of the span of the wings. A spoiler's primary purpose is to kill lift. Here's a photo of a typical airliner spoiler. You can see that it is much wider than it is tall. Precise Flight speed brakes, in contrast, extend far higher than would be appropriate for spoilers and are less than a foot wide; a tiny fraction of a Lancair's wingspan. As a spoiler, the speed brakes are terribly designed. Here is a photo of a typical Precise Flight speed brake. You can see that it is tall and narrow in comparison to a spoiler. On Lancairs, which are low drag airplanes, their primary purpose is to increase drag to slow down. Functioning like flat plate drag devices, they are dramatically more effective at high speed, when you need them, than at low speed. That's because drag increases with the square of airspeed. The thing that makes this confusing is that they are installed on the top of the wings, so they also reduce lift. At high airspeed, the drag effect is much more than the reduction in lift. At low airspeed, when the drag effect is relatively low, the effect of the loss of lift is more significant. If the speed brakes were primarily used for landing, to kill lift like a glider does, they should accurately be called "spoilers." If they are used primarily to increase drag to slow down from high speed, then they should accurately be called "speed brakes." In Lancairs, I don't know anyone who uses them to kill lift; they're used almost exclusively to slow down. Tomato, tomahto, Dennis
December 29, 2013 - January 13, 2014
AeroElectric-Archive.digest.vol-me
