AeroElectric-Archive.digest.vol-mk
July 10, 2014 - August 05, 2014
      >>> and why some things were done . . . waayyyyy back when.
      >>>> I'm a vfr only pilot and am considering surface mounting an I-pad
      mini on the dash as a backup.  It would run Foreflight and communicate
      with a Stratus Two.  I've heard the pads tend to overheat and was
      thinking about installing a cooling fan behind it in the panel.  Do you
      have any thoughts on this?  What type fan should I use to avoid RFI,
      etc?  How many cfm?  Do you have a simpler idea, or am I needlessly
      worrying about the overheating problem?
      >>> Folks on the List can better sources of information
      >>> on this than I. I'm surprised about 'heat issues' . . .
      >>> these things draw about 3-5 watts in operation, the
      >>> vast majority of which gets turned into heat. Unless
      >>> there are items with localized heat-dissipation issues
      >>> (doubtful for a hand-held device), I would not expect
      >>> there to be any problems for operational heating.
      >>> However, these things are not designed to RESIDE on a
      >>> panel of an airplane parked out in the sun. I sure
      >>> wouldn't leave one in a parked airplane.
      >>>> The other thing I was looking for was 12v usb port I could hardwire
      near my panel (not a cigarette lighter adapter) so the pad would be
      charged while in flight.  Blue Sea makes usb ports for marine
      application that looks good, but didn't know if you had any.
      >>> That's a popular topic on the List. A number of
      >>> builders have tried various commercial off the self
      >>> 12v/USB power adapters with varying degrees of
      >>> success.  Depending on how handy you are with
      >>> a soldering iron, you could craft an airplane-
      >>> friendly, 14V to 5VUSB adapter starting with
      >>> a reasonably robust assembly as a core . . .
      >>> something like these . . .
      >>> http://tinyurl.com/ovowqbu
      >>> http://tinyurl.com/px42t7f
      >>> . . . mounted in a metal enclosure and fitted with
      >>> sure-to-work filters and over-load protection.
      >>> Alternatively, something like this . . .
      >>> http://tinyurl.com/pbvmbb3
      >>> . . . might be just fine in terms of performance
      >>> and noise . . . you'd just have to try it.
      >>>> I also read your article on using shielded cable for the LIghtspeed
      electronic ignition instead of the coax.  The use of epoxy to seal the
      wiring seemed like a pain and was wondering if using a tighter fitting,
      larger shielded wire with shrink wrapping would be ok.  Are the reasons
      for not using larger cable expense, flexibility, and weight?
      >>> Klaus had a cow when I wrote that article . . . seems
      >>> that coax cable was necessary if the system were going
      >>> to generate 2" long sparks between coil towers. Going
      >>> to shielded wire dropped the output to 1.5" sparks.
      >>> Still about 100x more than needed to make the engine run
      >>> but I'll have to concede a 'drop in performance'.
      >>> The original problem with coax was his recommendation
      >>> for using RG-58 . . . with insulation that drips off
      >>> the wire when you try to solder it. He has since revised
      >>> his recommendation to RG-400 coax . . . modern, hi-temp
      >>> insulation.
      >>> Bob . . .
      href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.m
      href="http://www.matronics.com/contribution">http://www.matronics.com/co
      ntribution
Date: Jul 10, 2014
Subject: Re: sundry questions
On 7/9/2014 5:16 PM, Robert L. Nuckolls, III wrote: > >> I'm a vfr only pilot and am considering surface mounting an I-pad >> mini on the dash as a backup. It would run Foreflight and >> communicate with a Stratus Two. I've heard the pads tend to overheat >> and was thinking about installing a cooling fan behind it in the >> panel. Do you have any thoughts on this? What type fan should I use >> to avoid RFI, etc? How many cfm? Do you have a simpler idea, or am >> I needlessly worrying about the overheating problem? > As others have and will point out, you won't really want to 'hard mount' your iPad but rather install it so it can removed and replaced as you enter and exit the plane. Left in a closed cockpit in the sun they will overheat. Practically speaking, I think you'll find that you'll want to keep the iPad with you for Foreflight flight planning, weather checking and general usage. Many possible solutions. I used a RAM mount which let's you slip the iPad in and out with just a bit of finger pressure. Having RAM mount on a center console lets me have the iPad right over my lap - ideal for me. Kitlog - O2 Console for RV10 <http://www.mykitlog.com/users/display_log.php?user=MauleDriver&project=224&category=8533&log=163121&row=2> > >> The other thing I was looking for was 12v usb port I could hardwire >> near my panel (not a cigarette lighter adapter) so the pad would be >> charged while in flight. Blue Sea makes usb ports for marine >> application that looks good, but didn't know if you had any. > You might try experimental avionics supplier/builder Steinair. They have a USB unit that mounts to the panel quite nicely and it works. ________________________________________________________________________________
Subject: Re: iPod shocks
Date: Jul 10, 2014
Bob, Electrocution seems to be normal with these devices! Google "IPod electric shocks" and see the many Apple Devotees who don't think it is a big deal. Some get tingles across their ear-buds. Remarkable. As for the one you tested, the transformer is always the problem. It looks like there is room in there for a legal transformer. Double-bobbin is best. I can't see how Apple doesn't have a class-action suit pending. Perhaps they are using the Pinto lawsuit calculator--fixing 4.5 billion units vs X dead victims' lawsuits per year...who probably were on Ecstasy and had weak hearts anyway. Hmmmmm. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426425#426425 ________________________________________________________________________________
Subject: Noisy USB Charger
Date: Jul 10, 2014
Thanks, Bob, for your thoughts on my experience with USB chargers that produced noise on my comm radio. I bought the noisy charger from a major supplier of airplane stuff and they are sending me a free replacement. I'll give it a try. In the meantime, I took your advice and tried a different brand of charger. I bought it at Wal-Mart and I'm happy to report that it is working fine. It is black, comes in a bubble pack, and can plug into both a 120 VAC wall outlet and a 12 VDC cigar lighter outlet. It cost less than $20. It has two, 2.1 amp USB receptacles. Regarding the comments about iPads overheating, that is a common problem. A good friend estimated that an iPad generates about 5 watts in use and that the glass display, when exposed to direct sunlight, absorbs the equivalent of 50 watts. I know from experience that at 17,000', where there isn't a lot of air to help cool it, my iPad shuts down from overheating if I leave it exposed to direct sunlight for half an hour. There is also some belief that charging in flight adds to the heat load, but I have not tested that. So long as I don't put my iPad in the direct sun for half an hour, I have no overheating problems. It also helps to remove the iPad from its case to allow the aluminum back panel to dissipate heat. Regarding panel mounting a USB charging port vs. a cigar lighter receptacle, I went the cigar lighter route. Mainly it was because I knew that some USB chargers were too noisy to use in an airplane and the cigar lighter method makes it simple to swap one charger for another until I find one that works. If I were going to hard wire a USB charger in the panel, I would be sure to thoroughly test it before cutting holes in the panel and soldering a bunch of wires. Dennis ________________________________________________________________________________
Date: Jul 10, 2014
On 07/09/2014 06:40 PM, Tim Andres wrote: > I think you'll be unhappy with a panel mounted Ipad, they will heat soak from the sun in a hurry and simply turn off. I use one however and love it, but I stow it out of the sun (and thieves) view when parked and just set it on my legs in flight. > FWIW > Tim FWIW, I am very happy with my panel mounted iPad2, and have never had any heat issues with it. I use a RAM mount so that I can easily remove it and take it with me when not using the airplane. Here are some old pics before my panel upgrade: http://deej.net/glastar/pics/ipad/ The new panel is still under construction, but here is a recent picture: http://deej.net/glastar/pics/panel/install/photob-3181.jpg The iPad will be mounted vertically (rather than horizontally as it was in the previous pictures) and will be running WingX for moving map and IFR charts. You could easily mount a simple paper shade behind/above the iPad if you needed to keep the sun off the backside. -Dj -- Dj Merrill - N1JOV - VP EAA Chapter 87 Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Date: Jul 10, 2014
I agree a ram mount would be fine, but mounted on the panel so you can't move it to adjust for glare or direct sun was what I thought he had in mind. Also, if you leave one in the sun with or even without the canopy closed, both of mine will overheat and shut down. iPhone also for that matter. Your mileage may vary! Tim > On Jul 10, 2014, at 7:58 AM, Dj Merrill wrote: > > >> On 07/09/2014 06:40 PM, Tim Andres wrote: >> I think you'll be unhappy with a panel mounted Ipad, they will heat soak from the sun in a hurry and simply turn off. I use one however and love it, but I stow it out of the sun (and thieves) view when parked and just set it on my legs in flight. >> FWIW >> Tim > > > FWIW, I am very happy with my panel mounted iPad2, and have never had > any heat issues with it. I use a RAM mount so that I can easily remove > it and take it with me when not using the airplane. > > Here are some old pics before my panel upgrade: > > http://deej.net/glastar/pics/ipad/ > > The new panel is still under construction, but here is a recent picture: > > http://deej.net/glastar/pics/panel/install/photob-3181.jpg > > The iPad will be mounted vertically (rather than horizontally as it was > in the previous pictures) and will be running WingX for moving map and > IFR charts. > > You could easily mount a simple paper shade behind/above the iPad if you > needed to keep the sun off the backside. > > -Dj > > > -- > Dj Merrill - N1JOV - VP EAA Chapter 87 > Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ > Glastar Flyer N866RH - http://deej.net/glastar/ > > > > ________________________________________________________________________________
Date: Jul 10, 2014
Subject: Tablets as flight instruments
At 05:40 PM 7/9/2014, you wrote: > >I think you'll be unhappy with a panel mounted Ipad, they will heat >soak from the sun in a hurry and simply turn off. I use one however >and love it, but I stow it out of the sun (and thieves) view when >parked and just set it on my legs in flight. >FWIW >Tim Tim's comments highlight the need to differentiate the two energy sources of potential overheating. Given that these devices draw about 1A at 5.0V (unless charging a dead battery), the power going into internal heat-gain is only 5 watts. Bolt a 5w resistor to a similarly sized sheet of aluminum, power it up, an the piece of aluminum will get noticeably warmer than ambient . . . but you can comfortably hold it. And so it would be with your tablet. It is, after all, a hand-held device. Even when charging a dead battery (perhaps 10W total draw) a majority of the additional 5W goes into electrical->chemistry conversion with perhaps a watt or less showing up as more heat on the case. But lay that same piece of aluminum out in the sun and temperature rise is another matter entirely. It seems well advised to have the handy device attached to the panel only while in use . . . and perhaps stored in your flight bag in the shade . . . or completely out of the airplane. To be sure, there are many examples of commercial-off- the shelf products having truly amazing capability to augment a pilot's tasks in the cockpit. But approach with caution with an understanding that capability does not correlate with reliability. If the desired capability offers any risk for venturing into situations where functionality is NECESSARY, then do your FMEA and ASSUME the critter is going to go T.U. The reason for failure doesn't matter. Have a Plan-B. Bob . . . ________________________________________________________________________________
Date: Jul 10, 2014
Subject: Re: RV-7 wireing questions
At 01:17 PM 7/10/2014, you wrote: Hey Bob, I have your book Aeroelectric Connection 2005 and I am building an RV-7. Great book by the way (I am a super beginner). I am going to use your figure Z-11 generic light aircraft electrical system diagram for pretty much all of my system but have a few questions. I want a master switch and an avionics switch on my panel so I can start my engine before I power up my avionics Okay, why do you want to do this? No such feature is suggested on any of the Z-figures . . . the value for an avionics master switch was poorly perceived when it was birthed (about 1968). Today, rudimentary design skills make virtually every appliance immune to what ever the system might throw at it . . . including the cranking of engines. Some readers have proffered the idea that turning avionics loads off will enhance cranking performance. . . an idea without foundation in physics for an airplane with a properly maintained battery. If you're willing to go flying with a battery that might not get the engine started if it were presented with a few amps additional load, then I suggest there's value in a review of your design goals as they drive risks. Don't get me wrong, if you WANT any switch in the airplane for ANY purpose, fine by me. I suggest there is value in understanding the exactly what the switch will (or will not) do for you . . . and how it figures into your assessment of risks. Bob . . . ________________________________________________________________________________
Date: Jul 10, 2014
Subject: Re: RV-7 wireing questions (OOPS)
I hit the 'send' button too quick. Check out the articles on avionics master switches at http://tinyurl.com/mr2jk8g Also, I recommend you join us on the AeroElectric-List, http://tinyurl.com/57wytb . . . it's a good thing to share a conversation about such matters with lots of other builders who may ponder such issues themselves . . . ----------------------------------------------------------- At 01:17 PM 7/10/2014, you wrote: Hey Bob, I have your book Aeroelectric Connection 2005 and I am building an RV-7. Great book by the way (I am a super beginner). I am going to use your figure Z-11 generic light aircraft electrical system diagram for pretty much all of my system but have a few questions. I want a master switch and an avionics switch on my panel so I can start my engine before I power up my avionics Okay, why do you want to do this? No such feature is suggested on any of the Z-figures . . . the value for an avionics master switch was poorly perceived when it was birthed (about 1968). Today, rudimentary design skills make virtually every appliance immune to what ever the system might throw at it . . . including the cranking of engines. Some readers have proffered the idea that turning avionics loads off will enhance cranking performance. . . an idea without foundation in physics for an airplane with a properly maintained battery. If you're willing to go flying with a battery that might not get the engine started if it were presented with a few amps additional load, then I suggest there's value in a review of your design goals as they drive risks. Don't get me wrong, if you WANT any switch in the airplane for ANY purpose, fine by me. I suggest there is value in understanding the exactly what the switch will (or will not) do for you . . . and how it figures into your assessment of risks. Bob . . . ________________________________________________________________________________
Date: Jul 10, 2014
DJ, You need 10 lbs of ballast in the baggage to fly solo????! Where is your battery mounted? Bill -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Dj Merrill Sent: Thursday, July 10, 2014 9:58 AM Subject: Re: AeroElectric-List: Re: sundry questions On 07/09/2014 06:40 PM, Tim Andres wrote: > I think you'll be unhappy with a panel mounted Ipad, they will heat soak from the sun in a hurry and simply turn off. I use one however and love it, but I stow it out of the sun (and thieves) view when parked and just set it on my legs in flight. > FWIW > Tim FWIW, I am very happy with my panel mounted iPad2, and have never had any heat issues with it. I use a RAM mount so that I can easily remove it and take it with me when not using the airplane. Here are some old pics before my panel upgrade: http://deej.net/glastar/pics/ipad/ The new panel is still under construction, but here is a recent picture: http://deej.net/glastar/pics/panel/install/photob-3181.jpg The iPad will be mounted vertically (rather than horizontally as it was in the previous pictures) and will be running WingX for moving map and IFR charts. You could easily mount a simple paper shade behind/above the iPad if you needed to keep the sun off the backside. -Dj -- Dj Merrill - N1JOV - VP EAA Chapter 87 Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Date: Jul 10, 2014
On 7/10/2014 7:33 PM, Bill Bradburry wrote: > You need 10 lbs of ballast in the baggage to fly solo????! Where is your > battery mounted? > Hi Bill, No, I do not. My guess is the original builder didn't weigh the plane properly, because when I used a set of calibrated scales to do it, my results were somewhat different. No ballast needed other than my butt in the front seat. :-) Those are old pics taken shortly after I bought the plane a few years ago, and that label hasn't been in the plane for a long time. Nice catch though! :-) -Dj -- Dj Merrill - N1JOV - VP EAA Chapter 87 Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Date: Jul 11, 2014
Z-11 is a good choice. An avionics switch is not recommended because if it fails, all of the avionics stop working. And any switch will eventually fail. I would question the qualifications of anyone who warns about damaging voltage spikes during engine start. Have they written a book on aircraft wiring? Dynon states in their Pilots User Guide for both the D-180 and SkyView that it is OK to have their units powered on during engine start. The real problem during engine cranking is not voltage spikes, but rather voltage slump, aka brownout. That is an annoyance, not a danger to avionics. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426498#426498 ________________________________________________________________________________
Date: Jul 11, 2014
About once every 50 engine starts my Gemini ADI (glass stand alone ADI) will freeze up. The only indication of that before takeoff is that the gps heading does not change during taxi. For aircraft without brown out protection, it might be convenient to have a switch of some kind, or an accessible circuit breaker, to reboot any devices that don't have their own on-off switch. Sure the battery master will also do it but I choose not to test the load dump capability of my internally regulated alternator, or my PM alternator, by deliberately cycling the master with a running engine. My John Deer PM regulator does not like load dumps. Ken On 11/07/2014 11:24 AM, user9253 wrote: > > > Z-11 is a good choice. An avionics switch is not recommended because > if it fails, all of the avionics stop working. And any switch will > eventually fail. I would question the qualifications of anyone who > warns about damaging voltage spikes during engine start. Have they > written a book on aircraft wiring? Dynon states in their Pilots User > Guide for both the D-180 and SkyView that it is OK to have their > units powered on during engine start. The real problem during engine > cranking is not voltage spikes, but rather voltage slump, aka > brownout. That is an annoyance, not a danger to avionics. Joe > > -------- Joe Gores > > ________________________________________________________________________________
Date: Jul 11, 2014
Subject: Re: Aeronautical idiosyncrasies
I recently inspected an RV-6A with a vertical engine control setup running from panel to fuel selector. This is per plans, though many have dispensed with it and arranged their controls horizontally along the bottom of the panel. This one had throttle at the top and mixture at the bottom with carb heat in between. I noticed the non-standard setup and it still got me. I did a run up and the engine quit when I thought I was actuating carb heat. I'm sure it never happens to the owner because he's used to it. A new owner would have to be wary until he got used to it. I was once working on a one-off motorglider that had yet to fly and found throttle, prop, and mixture all rigged backwards. People don't always put a lot of thought into what they do. Best to be wary in a new to you experimental. Remember the non-standard placement of fuel selector (along with poor condition of same) that contributed to John Denver's demise. Ed Holyoke On 7/8/2014 12:48 AM, GLEN MATEJCEK wrote: > > > >Re: > > > >=C2 =C2 Yes, attention has been paid to human factors > >=C2 =C2 in cockpit design and layout since day-one . . . > > > >Just as a curious data point, in the WWII plane > >I fly on the side throttles forward is more > >power, props forward is more power, blowers > >forward is more power, mixtures forward is > >suddenly silent. =C2 Every departure requires a > >quiet moment reviewing the several gotchas in > >the cockpit lest reflex cause a debacle. > > Interesting! I've never encountered a 'variance' > with so much perceived significance and > potential risk. > > Which airplane? > > > Bob . . > > Lockheed PV-2 Harpoon. There are other issues, as well... Alternate > air forward is hot, and the landing gear and flap levers are > identical and symmetrically located. Keeps you on your toes! > > * > > > * > ________________________________________________________________________________
Date: Jul 11, 2014
At 10:58 AM 7/11/2014, you wrote: > >About once every 50 engine starts my Gemini ADI (glass stand alone >ADI) will freeze up. The only indication of that before takeoff is >that the gps heading does not change during taxi. For aircraft >without brown out protection, it might be convenient to have a >switch of some kind, or an accessible circuit breaker, to reboot any >devices that don't have their own on-off switch. The Gemini ADI installation manual does speak to an ADI Master Switch downstream of a 1A breaker. This is a very low power consumption device! How a bout a miniature, normally closed push button next to the instrument in series with the power input that would allow you to do a 'hard' reset? >Sure the battery master will also do it but I choose not to test the >load dump capability of my internally regulated alternator, or my PM >alternator, by deliberately cycling the master with a running >engine. My John Deer PM regulator does not like load dumps. >Ken Don't you have positive alternator control? For a PM alternator, a set of relay contacts in series with the AC output winding will offer a way to shut it off without undue stress. Bob . . . ________________________________________________________________________________
Date: Jul 12, 2014
Hi Dennis, In the meantime, I took your advice and tried a different brand of charger. I bought it at Wal-Mart and I'm happy to report that it is working fine. It is black, comes in a bubble pack, and can plug into both a 120 VAC wall outlet and a 12 VDC cigar lighter outlet. It cost less than $20. It has two, 2.1 amp USB receptacles. Just for reference, can post a link to the item on Walmart.com? There are dozens of UBS chargers there. sacha ________________________________________________________________________________
Subject: Dual master solenoids
Date: Jul 12, 2014
Working my way through Nuckoll's Z-13 wiring diagram. I'm building an 8-a VFR with single battery, single alternator. I'm not excited about the use of his "always hot" main bus because of the additional wire runs it would create from the buss mounted close to the rear mounted battery and difficulty accessing fuses for those wires. I'd like to run all electrical busses from the always hot side of the starter solenoid (always hot when master solenoid is hot). Given this scenario, it seems that the really significant system weakness is the failure of the master solenoid. I was thinking that a second master solenoid, with a separate wire and switch, wired in parallel at the battery, would address this issue. Does this make sense or am I missing something obvious (or not so obvious)? Thanks, Tom H. Sent from my iPad ________________________________________________________________________________
Date: Jul 12, 2014
Subject: Re: Dual master solenoids
At 04:14 PM 7/12/2014, you wrote: > >Working my way through Nuckoll's Z-13 wiring diagram. >I'm building an 8-a VFR with single battery, single alternator. > >I'm not excited about the use of his "always hot" main bus because >of the additional wire runs it would create from the buss mounted >close to the rear mounted battery and difficulty accessing fuses for >those wires. That's not a "MAIN BUS" . . . it's the MAIN BATTERY always-hot with exceedingly limited but often important tasks in getting power distributed to your airplane. GA airplanes have had always-hot busses since the clock and hour-meter fuses were mounted right next to the battery master contactor in the tail . . . in Cessnas I worked on in 1965. Study Z-13 again (or perhaps Z-11 which is a single alternator version). Also the notes for the z-figures along with the chapter on system reliability. >I'd like to run all electrical busses from the always hot side of >the starter solenoid (always hot when master solenoid is hot). Not sure what's driving this . . . The Z-figures are the culmination of over 45+ years experience in TC aviation enhanced by 25+ years in OBAM aviation exploiting the freedoms not enjoyed by TC aviation . . . to craft an architecture that meets YOUR mission requirements . . . not those of a bureaucracy most of whom do not build or fly airplanes. >Given this scenario, it seems that the really significant system >weakness is the failure of the master solenoid. I was thinking that >a second master solenoid, with a separate wire and switch, wired in >parallel at the battery, would address this issue. > >Does this make sense or am I missing something obvious (or not so obvious)? It's not clear that you understand the philosophy behind the various architectures and functionality of their several features. Suggest you PLAN for Z-13/8 by having all the WIRES in place to have a second alternator . . . unless you're going to have a vacuum pump, the consider NOT plugging a perfectly good source of mechanical energy with a cover plate. Print out copies of http://tinyurl.com/7jqypwj one for each bus. It generally takes three. List each load services by the various busses along with their magnitudes and flight configurations that the loads are expected/necessary. You may not need a battery bus . . . but get all your loads defined first . . . then decide what bus structures are needed. Do you plan any sort of electronic ignition. The RV8 is low wing so you no doubt have electric fuel pumps. Does any of your proposed electrics need memory keep-alive power? I single alternator, what's your goal for battery-only endurance? The load analysis study will let you set necessary battery size based on predicted loads. There's lot of sifting of requirements that will drive what gets powered from which busses. Go with Z-13/8 with second 4-pound alternator and your alternator-out endurance deliberations get a WHOLE LOT easier. Bob . . . ________________________________________________________________________________
Date: Jul 13, 2014
TOM, Then you may as well have two of everything. Remember the cardinal rule..." build in simplicity and lightness" Bob Verwey On 12 Jul 2014 11:22 PM, "Tomhanaway" wrote: > > > > Working my way through Nuckoll's Z-13 wiring diagram. > I'm building an 8-a VFR with single battery, single alternator. > > I'm not excited about the use of his "always hot" main bus because of the > additional wire runs it would create from the buss mounted close to the > rear mounted battery and difficulty accessing fuses for those wires. > > I'd like to run all electrical busses from the always hot side of the > starter solenoid (always hot when master solenoid is hot). > > Given this scenario, it seems that the really significant system weakness > is the failure of the master solenoid. I was thinking that a second master > solenoid, with a separate wire and switch, wired in parallel at the > battery, would address this issue. > > Does this make sense or am I missing something obvious (or not so obvious)? > > Thanks, > Tom H. > > Sent from my iPad > > ________________________________________________________________________________
Date: Jul 13, 2014
I understand that but it doesn't answer my question. Is there anything from an electrical point of view that keeps this from work ing. I.e., the backup master solenoid would have 12 vdc at both terminals wh enever the primary master solenoid is turned on even if the aux master solen oid switch is not on. My goal is to have the aux solenoid sitting idle unle ss activated by a switch. Tom Sent from my iPad > On Jul 13, 2014, at 1:50 AM, Bob Verwey wrote: > > TOM, > Then you may as well have two of everything. > > Remember the cardinal rule..." build in simplicity and lightness" > > Bob Verwey > >> On 12 Jul 2014 11:22 PM, "Tomhanaway" wrote: m> >> >> Working my way through Nuckoll's Z-13 wiring diagram. >> I'm building an 8-a VFR with single battery, single alternator. >> >> I'm not excited about the use of his "always hot" main bus because of the additional wire runs it would create from the buss mounted close to the rea r mounted battery and difficulty accessing fuses for those wires. >> >> I'd like to run all electrical busses from the always hot side of the sta rter solenoid (always hot when master solenoid is hot). >> >> Given this scenario, it seems that the really significant system weakness is the failure of the master solenoid. I was thinking that a second master s olenoid, with a separate wire and switch, wired in parallel at the battery, w ould address this issue. >> >> Does this make sense or am I missing something obvious (or not so obvious )? >> >> Thanks, >> Tom H. >> >> Sent from my iPad >> >> ========== >> - >> ric-List" target="_blank">http://www.matronics.com/Navigator?AeroElectr ic-List >> ========== >> MS - >> k">http://forums.matronics.com >> ========== >> e - >> -Matt Dralle, List Admin. >> t="_blank">http://www.matronics.com/contribution >> ========== > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Jul 13, 2014
I don't see a problem with a dual master although I wonder if it really achieves your goal or achieves it as elegantly as one of the Z architectures. The failures of contactors that I've seen are failures to activate not failures during flight. I do agree that any truly essential system such as engine power should not be tied to a single contactor but the battery buss and/or essential buss concept seem like a better solution where applicable. Don't forget that a backup has little value unless tested regularly. For example, I test my backup EFI during taxi on every flight and it has always worked perfectly. I happened to test it in flight yesterday and discovered that it has started to miss at high power which pretty much means it has been useless dead weight for some undetermined length of time as I do not often test it at high power settings. Ken On 13/07/2014 6:55 AM, Tomhanaway wrote: > I understand that but it doesn't answer my question. > > Is there anything from an electrical point of view that keeps this from > working. I.e., the backup master solenoid would have 12 vdc at both > terminals whenever the primary master solenoid is turned on even if the > aux master solenoid switch is not on. My goal is to have the aux > solenoid sitting idle unless activated by a switch. > > Tom > > Sent from my iPad > > On Jul 13, 2014, at 1:50 AM, Bob Verwey > wrote: > >> TOM, >> Then you may as well have two of everything. >> >> Remember the cardinal rule..." build in simplicity and lightness" >> >> Bob Verwey >> >> On 12 Jul 2014 11:22 PM, "Tomhanaway" > > wrote: >> >> > >> >> Working my way through Nuckoll's Z-13 wiring diagram. >> I'm building an 8-a VFR with single battery, single alternator. >> >> I'm not excited about the use of his "always hot" main bus because >> of the additional wire runs it would create from the buss mounted >> close to the rear mounted battery and difficulty accessing fuses >> for those wires. >> >> I'd like to run all electrical busses from the always hot side of >> the starter solenoid (always hot when master solenoid is hot). >> >> Given this scenario, it seems that the really significant system >> weakness is the failure of the master solenoid. I was thinking >> that a second master solenoid, with a separate wire and switch, >> wired in parallel at the battery, would address this issue. >> >> Does this make sense or am I missing something obvious (or not so >> obvious)? >> >> Thanks, >> Tom H. >> ________________________________________________________________________________
Date: Jul 13, 2014
On Jul 13, 2014, at 6:55 AM, Tomhanaway wrote: > Is there anything from an electrical point of view that keeps this from working. There is no electrical reason why your idea won't work but why do it? Master solenoids don't typically fail in-flight. They typically don't fail at all if installed as Bob suggests, unless the posts are tightened incorrectly and twist the internal contacts. If one does fail, you can find a replacement at a FLAPS. If your engine has magnetos, an inflight failure won't matter. If you are using EIs, you'll probably have ignition power straight off the battery so it still won't matter. Put the cost and the weight-cost of an additional heavy solenoid, additional foot or so of heavy AWG 2-4 wire, additional panel switch and wiring against the low chance you'll ever need it. -Kent Cozy IV ________________________________________________________________________________
Date: Jul 13, 2014
At 06:47 AM 7/13/2014, you wrote: > > > >On Jul 13, 2014, at 6:55 AM, Tomhanaway wrote: > > > Is there anything from an electrical point of view that keeps > this from working. > >There is no electrical reason why your idea won't work but why do >it? Master solenoids don't typically fail in-flight. . . . and even if they did, the battery-bus/e-bus architectures are crafted to keep things comfortable in the cockpit even if it DID fail . . . in fact, the germinating idea behind the dual-feedpath e-bus was to facilitate a deliberate opening of the battery master contactor as part of load shedding protocol for battery-only operations. Suggest you do your own failure mode effects analysis where you consider the risks for a failure of any single component of your electrical system. If you discover a failure that puts comfortable termination of flight at risk, then let's talk about it. I'm certain that with judicious selection of accessories and distribution of power, you can craft a system where worries about the battery master contactor are at the bottom of the risk assessment list. Bob . . . ________________________________________________________________________________
Date: Jul 13, 2014
Subject: Learning
Hi All, I am installing a Bendix KX155 transceiver, a Bendix KT 76A transponder, a Dynon EFIS D100 and a PM500EX intercom in a Kitfox Series 7 with a Continental IO240. Can anyone supply me with a wiring diagram for this configuration? It has to be plain to a 6 year old; I have all the installation manuals, and they are mostly Greek to the uninformed; I am floundering around like a beginner, which I am. I may have bitten off more that I can chew, but I'll be a monkey's uncle if I'll it give up. At least I'm learning a whole lot. Thanks, Jim Gilliatt Rhode Island ________________________________________________________________________________
Subject: Re: Learning
Date: Jul 13, 2014
Hi I take it that 8.33 radios, and mode S transponders are not a (I presume your in) USA requirement for new fits John Sent from my iPad ----x--O--x---- > On 13 Jul 2014, at 04:21 pm, Jim Gilliatt wrote: > > > Hi All, > I am installing a Bendix KX155 transceiver, a Bendix KT 76A transponder, a Dynon EFIS D100 and a PM500EX intercom in a Kitfox Series 7 with a Continental IO240. Can anyone supply me with a wiring diagram for this configuration? It has to be plain to a 6 year old; I have all the installation manuals, and they are mostly Greek to the uninformed; I am floundering around like a beginner, which I am. I may have bitten off more that I can chew, but I'll be a monkey's uncle if I'll it give up. > At least I'm learning a whole lot. > Thanks, > Jim Gilliatt > Rhode Island > > > > ________________________________________________________________________________
Date: Jul 13, 2014
Hi John, Not to my knowledge, and I have talked to many people who are well aware of the requirements. I hope I'm not showing my ignorance here. Jim On 7/13/2014 11:33 AM, John Tipton wrote: > > Hi > > I take it that 8.33 radios, and mode S transponders are not a (I presume your in) USA requirement for new fits > > John > > Sent from my iPad > > ----x--O--x---- > >> On 13 Jul 2014, at 04:21 pm, Jim Gilliatt wrote: >> >> >> Hi All, >> I am installing a Bendix KX155 transceiver, a Bendix KT 76A transponder, a Dynon EFIS D100 and a PM500EX intercom in a Kitfox Series 7 with a Continental IO240. Can anyone supply me with a wiring diagram for this configuration? It has to be plain to a 6 year old; I have all the installation manuals, and they are mostly Greek to the uninformed; I am floundering around like a beginner, which I am. I may have bitten off more that I can chew, but I'll be a monkey's uncle if I'll it give up. >> At least I'm learning a whole lot. >> Thanks, >> Jim Gilliatt >> Rhode Island >> >> >> >> > > ________________________________________________________________________________
Date: Jul 13, 2014
You are so lucky Jim: over here (UK/Europe) we have to fit to new builds 8.33 radios, and Mode S transponders, and all aircraft by the end of 2015 are to be so equipped - a lot of surplus equipment will be available !!! John Sent from my iPad ----x--O--x---- > On 13 Jul 2014, at 04:45 pm, Jim Gilliatt wrote: > > > Hi John, > Not to my knowledge, and I have talked to many people who are well aware of the requirements. > I hope I'm not showing my ignorance here. > Jim > >> On 7/13/2014 11:33 AM, John Tipton wrote: >> >> Hi >> >> I take it that 8.33 radios, and mode S transponders are not a (I presume your in) USA requirement for new fits >> >> John >> >> Sent from my iPad >> >> ----x--O--x---- >> >>> On 13 Jul 2014, at 04:21 pm, Jim Gilliatt wrote: >>> >>> >>> Hi All, >>> I am installing a Bendix KX155 transceiver, a Bendix KT 76A transponder, a Dynon EFIS D100 and a PM500EX intercom in a Kitfox Series 7 with a Continental IO240. Can anyone supply me with a wiring diagram for this configuration? It has to be plain to a 6 year old; I have all the installation manuals, and they are mostly Greek to the uninformed; I am floundering around like a beginner, which I am. I may have bitten off more that I can chew, but I'll be a monkey's uncle if I'll it give up. >>> At least I'm learning a whole lot. >>> Thanks, >>> Jim Gilliatt >>> Rhode Island > > > > > ________________________________________________________________________________
Date: Jul 13, 2014
If you don't find what you want, contact SteinAir.com and tell them exactly what instruments you'll be installing. They will provide a complete schematic showing where each wire connects to each pin. Great company to do business with. Worth it's weight in gold for those doing their own wiring. Plus, it gives you and any future operator a reference chart for the future. I made a copy of mine and marked off each wire as I installed them Sent from my iPad > On Jul 13, 2014, at 12:21 PM, John Tipton wrote: > > > You are so lucky Jim: over here (UK/Europe) we have to fit to new builds 8.33 radios, and Mode S transponders, and all aircraft by the end of 2015 are to be so equipped - a lot of surplus equipment will be available !!! > > John > > Sent from my iPad > > ----x--O--x---- > >> On 13 Jul 2014, at 04:45 pm, Jim Gilliatt wrote: >> >> >> Hi John, >> Not to my knowledge, and I have talked to many people who are well aware of the requirements. >> I hope I'm not showing my ignorance here. >> Jim >> >>> On 7/13/2014 11:33 AM, John Tipton wrote: >>> >>> Hi >>> >>> I take it that 8.33 radios, and mode S transponders are not a (I presume your in) USA requirement for new fits >>> >>> John >>> >>> Sent from my iPad >>> >>> ----x--O--x---- >>> >>>> On 13 Jul 2014, at 04:21 pm, Jim Gilliatt wrote: >>>> >>>> >>>> Hi All, >>>> I am installing a Bendix KX155 transceiver, a Bendix KT 76A transponder, a Dynon EFIS D100 and a PM500EX intercom in a Kitfox Series 7 with a Continental IO240. Can anyone supply me with a wiring diagram for this configuration? It has to be plain to a 6 year old; I have all the installation manuals, and they are mostly Greek to the uninformed; I am floundering around like a beginner, which I am. I may have bitten off more that I can chew, but I'll be a monkey's uncle if I'll it give up. >>>> At least I'm learning a whole lot. >>>> Thanks, >>>> Jim Gilliatt >>>> Rhode Island > > > > > ________________________________________________________________________________
Date: Jul 13, 2014
Jim, To connect your equipment just take it one step at a time. Draw wiring diagrams to figure out what needs to go where and then talk to your local technical counsellor to understand how it all wires together. Reading Bob's book (the Aeroelectric Connection) is also one of the best ways to better understand the 'Greek'. Start radios, leave the Dynon till later, and begin with the power and grounds. Figure out the current draw and the size of the fuses. Ask yourself the following questions, and keep asking until you have figured out what is required to provide all the functions you plan to use. Identify the pin number on the connector of the source device and where that signal will go to on the receiving box (connector and pin number). How will you provide the altitude information to the KT76A? Do you have an encoder or do you plan to use the Dynon? Do you plan to use the VOR in the KX155? Besides the KX155 what audio inputs do you plan to the intercom? What are you doing for a GPS? Does the EFIS need a GPS input? We were all a beginner at one point, this stuff is not intuitive to most, you haven't bitten off more than you can chew - just take it one bite at a time. There are enough folks here who understand 'Greek' to help you figure it all out. Peter On 13/07/2014 16:21, Jim Gilliatt wrote: > > > Hi All, > I am installing a Bendix KX155 transceiver, a Bendix KT 76A > transponder, a Dynon EFIS D100 and a PM500EX intercom in a Kitfox > Series 7 with a Continental IO240. Can anyone supply me with a wiring > diagram for this configuration? It has to be plain to a 6 year old; > I have all the installation manuals, and they are mostly Greek to the > uninformed; I am floundering around like a beginner, which I am. I > may have bitten off more that I can chew, but I'll be a monkey's uncle > if I'll it give up. > At least I'm learning a whole lot. > Thanks, > Jim Gilliatt > Rhode Island > > ________________________________________________________________________________
Date: Jul 13, 2014
IMO the audio panel to NAV/ comm harness is where you'll most likely have trouble, but it's easy to make once you have the info you need. PSE once had a .ppt on their website depicting how to build that harness. I notice they took it down and I know they won't warrant their panels unless a harness is purchased from a dealer. I have a copy of that ppt if needed. Bob's cartoons showing how to treat the shields and daisy chain them is good info for you, and you need to understand shields are not used for anything but shields, so no audio on them and they ground at one end only to prevent ground loops. The other thing you'll run into is differing terminology between the various brands, especially "audio low" . The Dynon is pretty much self contained with no remote magnetometers or AHRS units, so that simplifies things also. You'll have to plow through each install manual several times and make some inquiries when you can't figure it out, but it's all there. I have my schematic for a 5000EX to Garmin stack, if you would like a copy it may get you started in designing yours. Or maybe someone has the same equipment as you and can supply a drawing. One tip on the audio harness, since all the shields terminate at the audio panel, you'll have to terminate those to wire and then D-sub pins per Bob's pics or the .ppt. There may be too many to get them into the connector shells so you may want to make those terminations a bit longer so all the splices can be just outside the shell. Pm if interested in the drawings or ppt. Tim > On Jul 13, 2014, at 2:36 PM, Peter Pengilly wrote: > > > Jim, > > To connect your equipment just take it one step at a time. Draw wiring diagrams to figure out what needs to go where and then talk to your local technical counsellor to understand how it all wires together. Reading Bob's book (the Aeroelectric Connection) is also one of the best ways to better understand the 'Greek'. > > Start radios, leave the Dynon till later, and begin with the power and grounds. Figure out the current draw and the size of the fuses. Ask yourself the following questions, and keep asking until you have figured out what is required to provide all the functions you plan to use. Identify the pin number on the connector of the source device and where that signal will go to on the receiving box (connector and pin number). > How will you provide the altitude information to the KT76A? Do you have an encoder or do you plan to use the Dynon? > Do you plan to use the VOR in the KX155? > Besides the KX155 what audio inputs do you plan to the intercom? > What are you doing for a GPS? Does the EFIS need a GPS input? > > We were all a beginner at one point, this stuff is not intuitive to most, you haven't bitten off more than you can chew - just take it one bite at a time. There are enough folks here who understand 'Greek' to help you figure it all out. > > Peter > > >> On 13/07/2014 16:21, Jim Gilliatt wrote: >> >> Hi All, >> I am installing a Bendix KX155 transceiver, a Bendix KT 76A transponder, a Dynon EFIS D100 and a PM500EX intercom in a Kitfox Series 7 with a Continental IO240. Can anyone supply me with a wiring diagram for this configuration? It has to be plain to a 6 year old; I have all the installation manuals, and they are mostly Greek to the uninformed; I am floundering around like a beginner, which I am. I may have bitten off more that I can chew, but I'll be a monkey's uncle if I'll it give up. >> At least I'm learning a whole lot. >> Thanks, >> Jim Gilliatt >> Rhode Island > > > > > ________________________________________________________________________________
Date: Jul 13, 2014
Subject: Manual for Vision microsystems EPI-800 engine monitor
Does anyone have a digital copy of the manual for the Vision microsystems EPI-800 engine monitor? I bought a plane with an EPI-800 installed, but most of the installation manual was lost. I'm particularly interested in the wiring associated with the backlighting system. At present, the backlighting doesn't work at all. It's supposed to sense the voltage on the lighting bus. My plane has no lighting bus, and the builder disconnected the lighting wiring for the VOR head and the transpondes, so I assume he disconnected wiring for the EPI-800 as well. ________________________________________________________________________________
Date: Jul 13, 2014
> I'm not excited about the use of his "always hot" main bus because of the additional wire runs it would create from the buss mounted close to the rear mounted battery and difficulty accessing fuses for those wires. > I'd like to run all electrical busses from the always hot side of the starter solenoid (always hot when master solenoid is hot). Schematics do not indicate how wires are routed in an aircraft. They show the logic of a circuit, not necessarily the physical layout. The heavy wire that supplies power to the main power distribution bus can be connected to either end of the wire between the two contactors (main battery and start). Your idea of connecting to the always hot side of the starter contactor is identical (electrically speaking) to Bob's schematic. > I was thinking that a second master solenoid, with a separate wire and switch, wired in parallel at the battery, would address this issue. Like Bob said, the E-bus circuit addresses this issue. If you would rather backup the main battery contactor, it can be done with an automotive 30 or 40 amp relay at a fraction of the weight. The relay must be disabled during engine cranking, maybe like the attached circuit. But keep in mind that the more complicated and the more components , the more to go wrong. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426609#426609 Attachments: http://forums.matronics.com//files/backup_relay_497.pdf ________________________________________________________________________________
Date: Jul 13, 2014
Folks on the List can better sources of information on this than I. I'm surprised about 'heat issues' . . . these things draw about 3-5 watts in operation, the vast majority of which gets turned into heat. Unless there are items with localized heat-dissipation issues (doubtful for a hand-held device), I would not expect there to be any problems for operational heating. My experience with the Ipad is similar to Tim Andres'. I set it in my lap (out of its case) and unless I have a fresh air vent directly blowing on the device it will shut down with an over temp announcement within 30 minutes of operation. My IT friend believes the Blue Tooth communication with the Stratus ADS-B receiver creates a larger drain than the Ipad would normally produce. I fly with another older handheld moving map as backup. The Foreflght + Stratus has tremendous capability when it's working but I don't trust it as a sole nav source. Reliability needs improvement. Larry Ford Glasair I RG N149LF ________________________________________________________________________________
Date: Jul 14, 2014
Thanks Joe, Once I started thinking in terms of a relay, this came pretty close to what I was looking for. Interesting use of a starter enable/disable switch to ensure no cranking current through relay. Interesting question ( to me, anyway), are heavy duty continuous service relays any less reliable than mechanical relays? If about the same reliability, what are the reasons that they aren't used more often for a master solenoid? As you stated, the weight differential is pretty significant. Thanks again, Tom -------- RV-10. Built and sold RV-8a. Building Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426622#426622 ________________________________________________________________________________
Date: Jul 14, 2014
If you don't find what you want, contact SteinAir and tell them exactly what instruments you'll be installing. They will provide a complete schematic showing where each wire connects to each pin. Great company to do business with. Worth it's weight in gold for those doing their own wiring. Plus, it gives you and any future operator a reference chart for the future. I made a copy of mine and marked off each wire as I installed them Sent from my iPad > On Jul 13, 2014, at 12:21 PM, John Tipton wrote: > > > You are so lucky Jim: over here (UK/Europe) we have to fit to new builds 8.33 radios, and Mode S transponders, and all aircraft by the end of 2015 are to be so equipped - a lot of surplus equipment will be available !!! > > John > > Sent from my iPad > > ----x--O--x---- > >> On 13 Jul 2014, at 04:45 pm, Jim Gilliatt wrote: >> >> >> Hi John, >> Not to my knowledge, and I have talked to many people who are well aware of the requirements. >> I hope I'm not showing my ignorance here. >> Jim >> >>> On 7/13/2014 11:33 AM, John Tipton wrote: >>> >>> Hi >>> >>> I take it that 8.33 radios, and mode S transponders are not a (I presume your in) USA requirement for new fits >>> >>> John >>> >>> Sent from my iPad >>> >>> ----x--O--x---- >>> >>>> On 13 Jul 2014, at 04:21 pm, Jim Gilliatt wrote: >>>> >>>> >>>> Hi All, >>>> I am installing a Bendix KX155 transceiver, a Bendix KT 76A transponder, a Dynon EFIS D100 and a PM500EX intercom in a Kitfox Series 7 with a Continental IO240. Can anyone supply me with a wiring diagram for this configuration? It has to be plain to a 6 year old; I have all the installation manuals, and they are mostly Greek to the uninformed; I am floundering around like a beginner, which I am. I may have bitten off more that I can chew, but I'll be a monkey's uncle if I'll it give up. >>>> At least I'm learning a whole lot. >>>> Thanks, >>>> Jim Gilliatt >>>> Rhode Island > > > > > ________________________________________________________________________________
Date: Jul 14, 2014
> are heavy duty continuous service relays any less reliable than mechanical relays? If about the same reliability, what are the reasons that they aren't used more often for a master solenoid? There are several ways that a relay or contactor can fail. The contacts can develop a high resistance, the coil can burn open, springs or other mechanical parts can break, and etc. I do not know which type is more likely to fail. The current carrying capability determines which relay or contactor to use. Starters can draw a few hundred amps initially to get the engine rotating. A 30 amp automotive relay would not last very long carrying that much current. So why have the starter current go though the master contactor? The starter contactor could be wired directly to the battery. I think the reason is that contactors have been known to fail closed. Having two contactors in series makes sure that the circuit can be opened. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426626#426626 ________________________________________________________________________________
Date: Jul 14, 2014
At 07:06 AM 7/14/2014, you wrote: > > > > are heavy duty continuous service relays any less reliable than > mechanical relays? If about the same reliability, what are the > reasons that they aren't used more often for a master solenoid? "Reliability" is a rather soggy concept. It can mean different things to most speakers in a group of conversants. If you write to Stancore/White-Rogers and ask, just HOW reliable is your 70-110 contactor? . . . they MIGHT fire back with a laboratory study that cites cycle-life of the contactor under various loads and perhaps environmental conditions. Write to Tyco about reliability of their Kilovac contactors and you MIGHT get another report. Okay, Tyco's numbers are better than S/W-R numbers . . . now what? As I've been explaining in my writing and presentations for the past 30 years, the elegant design has little, if any, interest in those numbers. Lessons-learned in over a century of building airplanes have demonstrated that the designer's prime directive is to reduce risk for a bad day in the cockpit. To be sure, if money, weight, $time$ to market and cost of ownership were of no concern, then there are virtually limitless ways that hedges against risk can be applied to the system. But applied without the confidence that comes from understanding there is a larger risk that the end-product is burdened with "safety features" that degrade performance to far greater degrees than protecting the airframe and crew. Emacs! My teachers would ask, "Okay, you've selected a whiz-bang part for that location in the airplane, make your case for the decision." Had I whipped out the reliability data sheets for the constellation of choices and said, "See here, look at THOSE numbers!" they might have banished me to purchasing support or perhaps the EMC lab. The first bit of guidance germane to your decision resides in lessons-learned. Question: How many times have pilots experienced a bad day in the cockpit due to in-flight failure of the battery master contactor? I haven't a clue . . . because the incidents have been so few in numbers and so benign as to become completely buried in COMPONENT failures that put the whole SYSTEM at risk . . . The aviation journals are replete with what I have called "dark n stormy night" stories . . . most of which are so lacking in data as to defy understanding of root cause . . . or more illustrative of human weaknesses than those of the airplane. Consider that EVERY contactor is RATED and TESTED in the lab to perform as advertised for tens of thousands of cycles at rated lioad. YOUR battery contactor is going to close/open once per flight cycle . . . perhaps 100 times per YEAR and under nearly zero-load conditions. Were you to conduct laboratory reliability testing for conditions in YOUR airplane, it's unlikely that you would ever see a failure. We HAVE seen some failures here on the List. Detailed analysis revealed failure due to a variety of reasons including manufacturing defects Emacs! moisture ingress, and installation error . . . but in no case were the failures first detected in flight. Carrying lessons-learned a step further we can conduct a failure effects study. You do this by ASSUMING that every part will fail at some point in time. You then analyze how that failure will affect system performance. For failures that pose unacceptable risk, you make some design changes. Except for things like wing struts and prop bolts, the elegant design drives more toward failure TOLERANCE than failure PROOF. See: http://tinyurl.com/ozum5u9 If your studies for optimal design are driving you toward the purchase of high-dollar hardware -OR- adding backup components, then perhaps your confidence born of lessons-learned and artful conduct of failure analysis is shaky. I suggest that crafting any of the Z-Figures chosen to match your mission profiles and hardware will produce an exceedingly failure tolerant system. I suggest further that Z13/8 has more bang for the buck/pound/volume than systems flying in some pretty sophisticated airplanes. The very first example of Z13-8 flying in an OBAM aircraft was in an RV-8 in Connecticut about 25 years ago . . . the father-son build team were delighted with its performance and confidence levels. They could loose a battery master contactor every few months and not suffer a bad day in the cockpit . . . but I'll bet that the Model 70 contactor installed day-on is still flying. Bob . . . ________________________________________________________________________________
Date: Jul 14, 2014
Subject: Re: Battery choice
On 05/22/2014 09:18 PM, Dj Merrill wrote: > $44 including shipping from Amazon for the UB12220 battery, 12v 22Ah in > the same form factor. > A plus is that it is 9 lbs lighter than the 25 Ah battery it will be > replacing (a B and C model BC110-1). > > Bob, > I will report back to the list as to how it performs. I have a low > compression 150hp Lycoming O-320 with a light weight starter, so it > should hopefully turn it over with no difficulty. Finally got the plane back together yesterday from the panel upgrade, and am reporting back to the list with the results. I installed one of these as the main battery: http://www.amazon.com/gp/product/B001G8FY38/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1 and one of these as the aux battery: http://www.amazon.com/gp/product/B004J2TAZQ/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1 I was only able to do taxi testing yesterday due to weather, however, the UB12220 battery turned the engine over just as fast as the previous B&C battery, so no issues with cranking power (in summer at least). I'll let you know more as I test further. On a somewhat related note, do contactors normally get very hot when in use? After running the engine and taxiing around for 15-20 mins yesterday, I stuck my hand back behind the baggage area to feel the battery and listen to see if I could hear it "boiling" (it was not hot or boiling). I happened to touch the contactor, and it was very hot, almost to the point of burning my hand, but not quite. Hot enough so that it was very uncomfortable keeping my hand on it for more than a few seconds. Is this is normal? Thanks, -Dj -- Dj Merrill - N1JOV - VP EAA Chapter 87 Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Date: Jul 14, 2014
On a somewhat related note, do contactors normally get very hot when in use? After running the engine and taxiing around for 15-20 mins yesterday, I stuck my hand back behind the baggage area to feel the battery and listen to see if I could hear it "boiling" (it was not hot or boiling). I happened to touch the contactor, and it was very hot, almost to the point of burning my hand, but not quite. Hot enough so that it was very uncomfortable keeping my hand on it for more than a few seconds. Is this is normal? Yes. "Hot" is a relative term. While the outside surface of the contactor may become too warm to keep your fingers on it, this condition is normal. http://tinyurl.com/mpcgp3t http://tinyurl.com/k6bwdqo Internal components of the contactor are rated for much higher levels. An RG battery in distress doesn't 'gurgle' but it does whistle. Finished some tests on a really big RG battery a few months ago wherein a Schumacher charger failed to perform as advertised . . . the battery was 'singing' as pressures exceeded settings on the vent valves. Bob . . . ________________________________________________________________________________
Date: Jul 14, 2014
On 07/14/2014 12:18 PM, Robert L. Nuckolls, III wrote: > Yes. "Hot" is a relative term. While the outside > surface of the contactor may become too warm to > keep your fingers on it, this condition is normal. Excellent, thank you! > An RG battery in distress doesn't 'gurgle' but > it does whistle. I was listening for any sort of weird noise coming from the battery. I've also had a Schumacher charger go wonky on me (it is sitting on my bench right now), and from one RG battery I could clearly hear what sounded like "boiling/bubbling", and from another the "hissing/singing" as you describe. The voltage from the charger was getting up to 15.7 or so. I haven't had the time to tear it apart to see if it can be adjusted down. The other charger that seems to be working correctly puts out 14.5 volts. The UB12220 battery has a label on the top that says it can handle up to 14.7 volts, and my alternator is putting out 14.2, so I am hopeful this battery will work fine in the plane. The essential bus diode is dropping 0.6v across it, giving 13.6 v on the e-bus, which seems reasonable. -Dj -- Dj Merrill - N1JOV - VP EAA Chapter 87 Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Date: Jul 14, 2014
The UB12220 battery has a label on the top that says it can handle up to 14.7 volts, and my alternator is putting out 14.2, so I am hopeful this battery will work fine in the plane. The essential bus diode is dropping 0.6v across it, giving 13.6 v on the e-bus, which seems reasonable. -Dj Some weeks ago, a Lister published a reply from Odyssey in response to a query about his PC680 battery life. The response spoke to the holy-watered manner in which Odyssey batteries should be recharged . . . the letter also stated that "no Schumacher chargers are approved". I've been a follower of SOME Schumacher products for a dozen years or more. In particular, I've owned a number of 1562, 2A charger/maintainers. For the most part, every 1562 I've tested produced a recharge profile that mirrored this plot. Well within the recommended profile suggested by Hawker-Enersys. http://tinyurl.com/pwo2oxv I do have a 1562 charger around here that was sent to me for testing . . . but it got 'swallowed up' in a re-organization of my shop digs perpetrated by a grandma/grand-daughter conspiracy . . . the charter is not lost, I just don't know where it is right now . . . the shop looks nice. A few weeks ago I spoke to my disappointment for the demonstrated performance of a new Schumacher XC75W charger with lots of push buttons and a digital display. Three successive recharge cycles of the same battery produced these profiles . . . Emacs! The first recharge was in the "AGM" mode, consistent with the configuration of battery. As you can see, this profile peaked at over 15.5 volts . . . The next time I tried the "STD" mode with similar results. Finally a recharge cycle in the "GEL" mode produced a perfectly acceptable performance . . . I forwarded this data to Schumacher asking for an opportunity to talk with an engineer . . . I have yet to hear from them. From this experience I must conclude that any tendency toward blind faith in Schumacher's ability to produce a well crafted recharge profile is not well placed. I was surprised that Odyssey put the evil eye on Schumacher some years ago . . . they did the same thing to Battery Minder. I would like to see the data upon which their displeasure stands but the data above suggests that Odyssey's displeasure may be standing on solid physics . . . You spoke to an observed output of 14.2 volts . . . which is in no way abusive to the battery. But the Rest Of the Story speaks to the complete recharge profile as plotted in the data cited above. I'm doing a study of both lithium batteries and suitable chargers . . . watch this space. I have no doubt that the 12220 battery will perform well when knew. If it suffers any weakness, it will manifest in poor service ilfe . . . Bob . . . ________________________________________________________________________________
Subject: Noisy USB Charger
Date: Jul 14, 2014
Hi Sacha, You asked for a Wal-Mart.com link to the USB charger that I'm using that doesn't create "noise" on my comm radio. Sorry, but I can't find it on Wal-Mart's web site. I bought it in the store. Here is the info printed on the charger; you might be able to find it on eBay or locally from a different store. I think it's manufactured by ONN Model #: ONA12WI268 Input: 100-240 VAC Input: 12-24 VDC Output: 5.0VDC 2.1A There is an additional number that might be some kind of certification: E347649 It has two input specs because it can be plugged into a cigar lighter or into a house wall socket. It also has two USB sockets that can charge both at 2.1 A simultaneously. Dennis ________________________________________________________________________________
Subject: Re: Noisy USB Charger
Date: Jul 15, 2014
Thanks Dennis for that. I guess the different Walmart stores carry different products cos I couldn't find it in the one I went to. ________________________________________________________________________________
Date: Jul 15, 2014
It's also a safety issue with some starter configurations. For instance if you had a momentary push button for the starter instead of a key switch, even with the master off you would still be able to push the button and turn the prop. I have this configuration and as an added safety while the aircraft is stopped and the master needs to be on, I always pull the starter CB. Sacha > On 14 Jul 2014, at 14:06, "user9253" wrote: > > Having two contactors in series makes sure that the circuit can be opened. ________________________________________________________________________________
Date: Jul 15, 2014
Aside from some anecdotal references that are oft repeated at hangar flying sessions and on the interwebs, have you or do you know of a specific instance where a master contactor/solenoid of standard design failed repeatedly? All mechanical things have "been known to fail", but we build airplanes around the 99th percentile, not the 1th percentile. If you built a perfectly safe airplane, it would be one that wouldn't leave the ground....so to that end you design in for the 99th, but also take into account the 1th percentiles without doing crazy things like putting in two master contactors or two tachometers (unless of course you have two batteries, or two busses, etc..). If you are going to put in two of those, why not two starter buttons, or two circuit breakers for each circuit, or two throttle cables, or two rudders, or two elevator pushrods, (after all, those have also been known to fail)? You still do only have one camshaft and one propeller and one crankshaft and one carb/fuel injector, one brain, etc.. My point is that the probability of failure of that specific components is likely less than the probability of other equally as important mechanical things in your plane. There is no reason to randomly pick one particular component and focus on it over another when it has not proven to be a weak point in the entire aerospace vehicle system design. Just my 2 cents as usual, but one could come up with all sorts of 1th percentile "possibilities" that are really not worth expending energy, time, money, weight or complexity on as the return on all of that in actuality becomes a negative. Remember, adding things for "redundancy" does not necessarily and automatically translate into reliability - many times it has the inverse effect (increased complexity = decreased reliability). Cheers, Stein -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of user9253 Sent: Monday, July 14, 2014 7:07 AM Subject: AeroElectric-List: Re: Dual master solenoids > are heavy duty continuous service relays any less reliable than mechanical relays? If about the same reliability, what are the reasons that they aren't used more often for a master solenoid? There are several ways that a relay or contactor can fail. The contacts can develop a high resistance, the coil can burn open, springs or other mechanical parts can break, and etc. I do not know which type is more likely to fail. The current carrying capability determines which relay or contactor to use. Starters can draw a few hundred amps initially to get the engine rotating. A 30 amp automotive relay would not last very long carrying that much current. So why have the starter current go though the master contactor? The starter contactor could be wired directly to the battery. I think the reason is that contactors have been known to fail closed. Having two contactors in series makes sure that the circuit can be opened. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426626#426626 ________________________________________________________________________________
Date: Jul 15, 2014
At 08:57 AM 7/15/2014, you wrote: > >It's also a safety issue with some starter configurations. For >instance if you had a momentary push button for the starter instead >of a key switch, even with the master off you would still be able to >push the button and turn the prop. Irrespective of the kind of switch that energizes the starter, I'm aware of no TC aircraft, or any OBAM aircraft wired per a Z-figure where this is the cased. The general rule of thumb for all airplanes is that opening the battery master contactor removes ALL power from the aircraft except for those items wired to a battery bus. Starters should be dead-in-place with the battery master off. >I have this configuration and as an added safety while the aircraft >is stopped and the master needs to be on, I always pull the starter CB. How was it that you came to wire your airplane this way? Bob . . . ________________________________________________________________________________
Date: Jul 15, 2014
My point is that the probability of failure of that specific components is likely less than the probability of other equally as important mechanical things in your plane. There is no reason to randomly pick one particular component and focus on it over another when it has not proven to be a weak point in the entire aerospace vehicle system design. Precisely . . . When opening the seminar segment on reliability, I like to put a z-figure up on the screen, point to a component and ask, "What do you need to do if THIS part malfunctions?" At least one participant will suggest that it be replaced with a 'better part'. That's the segment where I pose the notion that the flight SYSTEM consists of an airframe, pilot, environment and expendable resources. From the time the wheels break ground until you're parked at the destination, the design goal is not break a sweat . . . irrespective of any component failure. The last few ideas offered at the end of the segment suggests that it doesn't matter if you buy electrical parts from Autozone, $high$ parts from Honeywell or TC aircraft parts from the Cessna warehouse . . . it is possible to ARCHITECTURE the electrical system such that no single component failure will induce an in-flight sweat. In the final analysis, you're more likely to have a bad day in the cockpit driven by events and conditions far removed from things electrical. #1 cause of engine stoppage is fuel starvation. #1 cause for unplanned arrivals with the earth are most often based on human factors for dealing with environment: weather, mountains, night ops, etc.) As we have studied many times here on the List . . . mishaps that included electrical issues were FIRST driven by lapses in assembly skills, failure tolerant design or poor maintenance. See: http://tinyurl.com/ky7szec In other words, "two parts" or a "better part" would not have produced a better outcome. Bob . . . ________________________________________________________________________________
Date: Jul 15, 2014
>It's also a safety issue with some starter configurations. For instance >if you had a momentary push button for the starter instead of a key >switch, even with the master off you would still be able to push the >button and turn the prop. Irrespective of the kind of switch that energizes the starter, I'm aware of no TC aircraft, or any OBAM aircraft wired per a Z-figure where this is the cased. The general rule of thumb for all airplanes is that opening the battery master contactor removes ALL power from the aircraft except for those items wired to a battery bus. Starters should be dead-in-place with the battery master off. Hi Bob, I was referring to the hypothetical situation that Joe brought up where the starter contactor would be always hot, i.e. wired to the battery bus. >I have this configuration and as an added safety while the aircraft is >stopped and the master needs to be on, I always pull the starter CB. How was it that you came to wire your airplane this way? My apologies, I wasn't very clear... My electrical setup is essentially Z-16, but the starter button is a push button. So whenever I am tinkering around on the ground and the master needs to be on, I pull the starter CB just to be safe. Another situation is when my three year old wants to sit next to me in the a/c and see the panel light up and pretend he's flying the aircraft... :) ________________________________________________________________________________
Date: Jul 15, 2014
My apologies, I wasn't very clear... My electrical setup is essentially Z-16, but the starter button is a push button. So whenever I am tinkering around on the ground and the master needs to be on, I pull the starter CB just to be safe. Another situation is when my three year old wants to sit next to me in the a/c and see the panel light up and pretend he's flying the aircraft... :) Understand . . . thanks! Bob . . . ________________________________________________________________________________
Date: Jul 15, 2014
> I was referring to the hypothetical situation that Joe brought up > where the starter contactor would be always hot, i.e. wired to the battery > bus. I did not bring that up. I was referring to tomhanaway's post where he wrote, "the always hot side of the starter solenoid (always hot when master solenoid is hot)". It is much easier to understand each other when talking face to face compared to email or forum postings. :-) Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426748#426748 ________________________________________________________________________________
Date: Jul 15, 2014
> > It is much easier to understand each other when talking face to > face compared to email or forum postings. I'm wrestling with a similar phenomenon in crafting recommendations for crafting requirements documents. I use as many drawings and pictures as I can . . . a picture is worth 10,000 words. The flip side is not true . . . 10,000 words interpreted by ten different readers will NOT create identical images in the minds of the readers. My clients a loath to ask their charges to learn to draw . . . That's why I use my scanner, cameras and links to posted illustrations to augment the words . . . you can't have too many pictures but more words you have, the fuzzier the ideas become. Bob . . . ________________________________________________________________________________
Subject: Z-13/8 and SD-8
Date: Jul 16, 2014
A little clarification required on the Z-13/8 schematic. I'm building this into a Long-Ez and have the SD-8 with all the bits from B&C. The Z-13/8 schematic shows something that is marked as W10 that appears to be between the Dynamo and the Regulator! This does NOT appear on the schematic from B&C. Any info on this would be appreciated. Regards MikeD (UK) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426799#426799 ________________________________________________________________________________
Date: Jul 16, 2014
I say "ditto" to everything Stein said. I firmly believe that one well-built system is better than a poor one with a backup... or a couple backups. My philosophy even extents to Ballistic Parachute Systems (which have been around for almost a century). My analysis says that a set of well-built and tested wings on a GA aircraft with no backup is a better way to go. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426803#426803 ________________________________________________________________________________
Subject: P Lead Wires Adjacent to Headset Jack Wires
Date: Jul 16, 2014
In the interests of killing two birds with one stone, could I run my headset and mic jack wires in the same 3/8" dia aluminum conduit as my mags' P lead wires without screwing up my audio signals? Inasmuch as the P lead wires need to be shielded I'm thinking this is probably a really bad idea and would probably cripple my audio but as it would make such a slick installation in my case I thought I'd ask. (Plain, old, Bendix mags, Garmin SL40 com). Thanks. Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426817#426817 ________________________________________________________________________________
Date: Jul 17, 2014
Subject: Re: P Lead Wires Adjacent to Headset Jack Wires
At 11:43 PM 7/16/2014, you wrote: > >In the interests of killing two birds with one stone, could I run my >headset and mic jack wires in the same 3/8" dia aluminum conduit as >my mags' P lead wires without screwing up my audio >signals? Inasmuch as the P lead wires need to be shielded I'm >thinking this is probably a really bad idea and would probably >cripple my audio but as it would make such a slick installation in >my case I thought I'd ask. Not a problem as long as you pay due homage to the physics gods . . . the shields for the p-leads should not come to ground at any location but the engine-end. Shields for the audio system terminate at the 'radio end'. But I'm curious, how is it that locations of the various and sundry components made this conduit an attractive option for holding this combination of wires? Bob . . . ________________________________________________________________________________
Date: Jul 17, 2014
Thanks Bob, I really appreciate the advice and help. I'm restoring a Stearman. The headset & mic jacks and intercom PTT for the front seat all reside on the front instrument panel. The radio and txdr are in a box in the rear cockpit mounted to the back of the front seat ahead of the stick. The mag switch is on the rear instrument panel on the extreme left and the airplane's main DC wiring harness runs down the right hand side of the fuselage from the rear cockpit to the firewall J box. I wanted to keep as much room as possible between the main harness and the audio harnesses so the front seat harness is going to run down the left hand side of the front cockpit and then downwards once abeam the rear instrument panel to the radio box. To protect the audio harness I want to run it in a small aluminum conduit and as that will parallel the P leads anyway I thought wouldn't it be slick if the P leads could be in there as well? A zinc chromate painted conduit of that size will be nicely camouflaged amongst all the link rods over there anyway and won't look as out of place as a bundle of small, 21st Century wiring would. And all the fat wires and fuses are up on the firewall inside the junction box and well away from the avionics in the back. The only CB's in the system are for the VHF, txdr, and the Alt field. The design goal for the airplane from the beginning was airline quality VHF radio - something that in an old open cockpit biplane is abit of a rarity! Thanks for the help! Dan Jones On 7/17/2014 7:13 AM, Robert L. Nuckolls, III wrote: > > > At 11:43 PM 7/16/2014, you wrote: >> >> >> In the interests of killing two birds with one stone, could I run my >> headset and mic jack wires in the same 3/8" dia aluminum conduit as >> my mags' P lead wires without screwing up my audio signals? Inasmuch >> as the P lead wires need to be shielded I'm thinking this is probably >> a really bad idea and would probably cripple my audio but as it would >> make such a slick installation in my case I thought I'd ask. > > Not a problem as long as you pay due > homage to the physics gods . . . the > shields for the p-leads should not > come to ground at any location but the > engine-end. Shields for the audio system > terminate at the 'radio end'. > > But I'm curious, how is it that locations > of the various and sundry components made > this conduit an attractive option for > holding this combination of wires? > > > Bob . . . > > ________________________________________________________________________________
Date: Jul 17, 2014
Thanks Bob, I really appreciate the advice and help. I'm restoring a Stearman. The headset & mic jacks and intercom PTT for the front seat all reside on the front instrument panel. The radio and txdr are in a box in the rear cockpit mounted to the back of the front seat ahead of the stick. The mag switch is on the rear instrument panel on the extreme left and the airplane's main DC wiring harness runs down the right hand side of the fuselage from the rear cockpit to the firewall J box. I wanted to keep as much room as possible between the main harness and the audio harnesses so the front seat harness is going to run down the left hand side of the front cockpit and then downwards once abeam the rear instrument panel to the radio box. To protect the audio harness I want to run it in a small aluminum conduit and as that will parallel the P leads anyway I thought wouldn't it be slick if the P leads could be in there as well? A zinc chromate painted conduit of that size will be nicely camouflaged amongst all the link rods over there anyway and won't look as out of place as a bundle of small, 21st Century wiring would. And all the fat wires and fuses are up on the firewall inside the junction box and well away from the avionics in the back. The only CB's in the system are for the VHF, txdr, and the Alt field. The design goal for the airplane from the beginning was airline quality VHF radio - something that in an old open cockpit biplane is abit of a rarity! Thanks for the help! Dan Jones Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426837#426837 ________________________________________________________________________________
Date: Jul 17, 2014
> >And all the fat wires and fuses are up on the firewall inside the >junction box and well away from the avionics in the back. The only >CB's in the system are for the VHF, txdr, and the Alt field. The >design goal for the airplane from the beginning was airline quality >VHF radio - something that in an old open cockpit biplane is abit of a rarity! Nothing in your narrative suggests any potential for 'gotchas' . . . but in any case, your risks are low . . . the worst case says you'll discover some effect we've not considered. Let us know the outcome! Bob . . . ________________________________________________________________________________
Date: Jul 18, 2014
Subject: Are 'serial' contactors really needed?
Someone's recent question/comment about master & starter contactors caused my ARADD (aviation related attention deficit disorder) to kick in. I'm just beginning the wiring process on an electrically dependent auto engine conversion in an RV-7. Given the typical automotive starter with self-contained contactor/bendix, and a starter contactor, could a case be made for switching the cockpit loads with smaller (lower coil current draw) contactors or even heavy duty switches, and using only the heavy starter contactor between the battery & starter? I'm envisioning the starter button activating both the contactor and the starter's built-in contactor. This way, if either sticks, current would still be removed from the starter when the button is released. There would be no voltage available on the starter's heavy wire except during starting, as is current practice (pardon the pun). The only failed-on single point should be the momentary push-to-start button. Motivation is saving a few ounces of contactor weight, and more importantly, saving the 2+amps of draw by the normal master contactor. If I elect to go with a single alternator (weight, simplicity), the 2 amp draw of the main contactor is a significant percentage of load in a failed alternator situation. Note that similar engine installs have flown for 45 minutes or more (typically plenty of time to find a runway) while operating 'battery only' using common 18-20 AH SLA battery installations. Thoughts? Charlie ________________________________________________________________________________
Date: Jul 18, 2014
Subject: Re: battery choice
>Finally got the plane back together yesterday from the panel upgrade, >and am reporting back to the list with the results. I installed one of >these as the main battery: > http://www.amazon.com/gp/product/B001G8FY38/ref=oh_aui_>>detailpage_o07_s00?.ie=UTF8&psc=1 <http://www.amazon.com/gp/product/B001G8FY38/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1> ... > >...I was only able to do taxi testing yesterday due to weather, however, >the UB12220 battery turned the engine over just as fast as the previous >B&C battery, so no issues with cranking power (in summer at least). >I'll let you know more as I test further. FWIW, I installed a pair of those in my as yet unfinished -8. It seems my battery tender jr smoked them.... ________________________________________________________________________________
Date: Jul 19, 2014
Subject: Re: Are 'serial' contactors really needed?
Charlie, I believe the driver for a master contacted has been the airworthiness regs - FAR23 and CS23 - which require one switch to shut off all electrical power, or words to that effect. If the load is 10s of amps (heated pitot, incandescent landing light, stack of old radios, etc) then a contactor was the only sensible way to go. There are now good reasons to question that kind of requirement, and do what you suggest. In my aeroplane, that has a conventional engine. The typical current draw is 8amps, which could be switched by a regular switch. Some aerobatic aeroplanes do that, by they often only use an SD-8. Also the load switched on first operation is likely to be small if all the services are switched off on shut down. I see no fundamental reason not to do what you suggest, although you may have to be a little more careful in how you operate. The only draw back is the stuck starter relay scenario. Using a double pole momentary may work, but you could also consider a separate switch in the line to the starter piggy-back solenoid. That way if the starter relay fails closed at least it will be obvious. Peter On Jul 18, 2014 8:35 PM, "Charlie England" wrote: > Someone's recent question/comment about master & starter contactors caused > my ARADD (aviation related attention deficit disorder) to kick in. > > I'm just beginning the wiring process on an electrically dependent auto > engine conversion in an RV-7. > Given the typical automotive starter with self-contained contactor/bendix, > and a starter contactor, could a case be made for switching the cockpit > loads with smaller (lower coil current draw) contactors or even heavy duty > switches, and using only the heavy starter contactor between the battery & > starter? > > I'm envisioning the starter button activating both the contactor and the > starter's built-in contactor. This way, if either sticks, current would > still be removed from the starter when the button is released. There would > be no voltage available on the starter's heavy wire except during starting, > as is current practice (pardon the pun). The only failed-on single point > should be the momentary push-to-start button. > > Motivation is saving a few ounces of contactor weight, and more > importantly, saving the 2+amps of draw by the normal master contactor. If I > elect to go with a single alternator (weight, simplicity), the 2 amp draw > of the main contactor is a significant percentage of load in a failed > alternator situation. Note that similar engine installs have flown for 45 > minutes or more (typically plenty of time to find a runway) while operating > 'battery only' using common 18-20 AH SLA battery installations. > > Thoughts? > > Charlie > > * > > > * > > ________________________________________________________________________________
Date: Jul 19, 2014
you may have replied to me by accident! that wasn't my question. my question was on a overvoltage module (ovm) from B&C using 60 amp breaker i nstead of a 5 amp will it hurt the ovm and will it work properly? you may want to refer to my email again for all details thank you ! John Sent from my iPhone > On Jul 19, 2014, at 2:53 AM, Peter Pengilly wrote : > > Charlie, > I believe the driver for a master contacted has been the airworthiness reg s - FAR23 and CS23 - which require one switch to shut off all electrical pow er, or words to that effect. If the load is 10s of amps (heated pitot, incan descent landing light, stack of old radios, etc) then a contactor was the on ly sensible way to go. > > There are now good reasons to question that kind of requirement, and do wh at you suggest. In my aeroplane, that has a conventional engine. The typical current draw is 8amps, which could be switched by a regular switch. Some ae robatic aeroplanes do that, by they often only use an SD-8. Also the load sw itched on first operation is likely to be small if all the services are swit ched off on shut down. I see no fundamental reason not to do what you sugges t, although you may have to be a little more careful in how you operate. > > The only draw back is the stuck starter relay scenario. Using a double pol e momentary may work, but you could also consider a separate switch in the l ine to the starter piggy-back solenoid. That way if the starter relay fails c losed at least it will be obvious. > > Peter >> On Jul 18, 2014 8:35 PM, "Charlie England" wrote: >> Someone's recent question/comment about master & starter contactors cause d my ARADD (aviation related attention deficit disorder) to kick in. >> >> I'm just beginning the wiring process on an electrically dependent auto e ngine conversion in an RV-7. >> Given the typical automotive starter with self-contained contactor/bendix , and a starter contactor, could a case be made for switching the cockpit lo ads with smaller (lower coil current draw) contactors or even heavy duty swi tches, and using only the heavy starter contactor between the battery & star ter? >> >> I'm envisioning the starter button activating both the contactor and the s tarter's built-in contactor. This way, if either sticks, current would still be removed from the starter when the button is released. There would be no v oltage available on the starter's heavy wire except during starting, as is c urrent practice (pardon the pun). The only failed-on single point should be t he momentary push-to-start button. >> >> Motivation is saving a few ounces of contactor weight, and more important ly, saving the 2+amps of draw by the normal master contactor. If I elect to g o with a single alternator (weight, simplicity), the 2 amp draw of the main c ontactor is a significant percentage of load in a failed alternator situatio n. Note that similar engine installs have flown for 45 minutes or more (typi cally plenty of time to find a runway) while operating 'battery only' using common 18-20 AH SLA battery installations. >> >> Thoughts? >> >> Charlie >> >> >> ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-Li st >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Jul 19, 2014
In regards to electric dependent engines, it is common to NOT feed it through a battery "contactor" anyway. My engine runs off the battery bus and will keep running if the master switch/contactor is off. My battery contactors draw less than an amp each. Do consider the architectures here that would de-energize them in a dead alternator situation anyway. Note that unlike continuous duty battery contactors, starter contactors draw several amps, are rated for intermittent use only, and are designed to interrupt large starter currents. There has been some question as to whether a battery contactor will in fact open if the starter is running. I will test that if my starter solenoid ever sticks on as my subaru starter is wired through the battery contactor with no separate starter contactor other than the integral starter solenoid. That seemed reasonable to me and hopefully slightly safer than how all my cars are wired. It also seemed reasonable to try preserve much of the intent of killing all non essential electrical wiring with a contactor located at the battery. The battery, with its ability to deliver large currents, is the most dangerous electrical item on board. Ken On 19/07/2014 2:53 AM, Peter Pengilly wrote: > Charlie, > I believe the driver for a master contacted has been the airworthiness > regs - FAR23 and CS23 - which require one switch to shut off all > electrical power, or words to that effect. If the load is 10s of amps > (heated pitot, incandescent landing light, stack of old radios, etc) > then a contactor was the only sensible way to go. > > There are now good reasons to question that kind of requirement, and do > what you suggest. In my aeroplane, that has a conventional engine. The > typical current draw is 8amps, which could be switched by a regular > switch. Some aerobatic aeroplanes do that, by they often only use an > SD-8. Also the load switched on first operation is likely to be small if > all the services are switched off on shut down. I see no fundamental > reason not to do what you suggest, although you may have to be a little > more careful in how you operate. > > The only draw back is the stuck starter relay scenario. Using a double > pole momentary may work, but you could also consider a separate switch > in the line to the starter piggy-back solenoid. That way if the starter > relay fails closed at least it will be obvious. > > Peter > > On Jul 18, 2014 8:35 PM, "Charlie England" > wrote: > > Someone's recent question/comment about master & starter contactors > caused my ARADD (aviation related attention deficit disorder) to > kick in. > > I'm just beginning the wiring process on an electrically dependent > auto engine conversion in an RV-7. > Given the typical automotive starter with self-contained > contactor/bendix, and a starter contactor, could a case be made for > switching the cockpit loads with smaller (lower coil current draw) > contactors or even heavy duty switches, and using only the heavy > starter contactor between the battery & starter? > > I'm envisioning the starter button activating both the contactor and > the starter's built-in contactor. This way, if either sticks, > current would still be removed from the starter when the button is > released. There would be no voltage available on the starter's heavy > wire except during starting, as is current practice (pardon the > pun). The only failed-on single point should be the momentary > push-to-start button. > > Motivation is saving a few ounces of contactor weight, and more > importantly, saving the 2+amps of draw by the normal master > contactor. If I elect to go with a single alternator (weight, > simplicity), the 2 amp draw of the main contactor is a significant > percentage of load in a failed alternator situation. Note that > similar engine installs have flown for 45 minutes or more (typically > plenty of time to find a runway) while operating 'battery only' > using common 18-20 AH SLA battery installations. > > Thoughts? > > Charlie > > ________________________________________________________________________________
Date: Jul 19, 2014
At 07:59 AM 7/19/2014, you wrote: >you may have replied to me by accident! >that wasn't my question. >my question was on a overvoltage module (ovm) from B&C using 60 amp >breaker instead of a 5 amp will it hurt the ovm and will it work properly? Need to see your schematic . . . how do you propose to use the crowbar ovm in conjunction with a 60A breaker? These devices are not intended to be used in any manner other than what's depicted in AEC or B&C drawings. Bob . . . ________________________________________________________________________________
Date: Jul 19, 2014
In regards to electric dependent engines, it is common to NOT feed it through a battery "contactor" anyway. My engine runs off the battery bus and will keep running if the master switch/contactor is off. Feeders from an always-hot bus are allowed in TC aircraft when protected at 5A or less. This is a crash-safety concern. For the OBAM aircraft, one is free to wire it like any other vehicle including automobiles that generally don't included battery disconnect switching (except for some racing jurisdictions). Note that unlike continuous duty battery contactors, starter contactors draw several amps, are rated for intermittent use only, and are designed to interrupt large starter currents. There has been some question as to whether a battery contactor will in fact open if the starter is running. Was that question posed here on the List? The answer is YES . . . it will break the power path to a stuck starter contactor . . . The battery, with its ability to deliver large currents, is the most dangerous electrical item on board. Precisely. I recall a conversation with an accident investigator some years back who made the anecdotal observation that when the airplane burned after impact, it's battery was more likely to be still inside a rather compact arrangement of wreckage. When the wreckage was widely scattered with the battery separated from the rest of the airplane, the incidences of post crash fire seemed lower. The typical current draw is 8amps, which could be switched by a regular switch. Some aerobatic aeroplanes do that, by they often only use an SD-8. Also the load switched on first operation is likely to be small if all the services are switched off on shut down. I see no fundamental reason not to do what you suggest, although you may have to be a little more careful in how you operate. The battery master disconnect does not have to be a contactor. The first airplane in which I took dual instruction had a fat toggle switch and a fat starter push-button . . . no contactors at all. I'm envisioning the starter button activating both the contactor and the starter's built-in contactor. This way, if either sticks, current would still be removed from the starter when the button is released. There would be no voltage available on the starter's heavy wire except during starting, as is current practice (pardon the pun). The only failed-on single point should be the momentary push-to-start button. Incidences of starter contactor sticking are rare . . . the risk goes up markedly when the pilot attempts to get the engine going with a seriously discharged or perhaps an un-flightworthy battery. Render due diligence in the maintenance of your battery and don't worry about 'sicking contactors'. There'no prohibition for using the starter's bui9lt in contactor-solenoid but be aware of the extra abusive nature of pull-in spikes with increased ware on the starter switch cnotacts. This over-looked feature was root cause for an AD against ACS-510 key-switches in a bit of bureaucratic paper-thrashing that at first produced a worthless 'fix' and was later revised to add a spike suppression diode to the contactor. Bill and I pondered this phenomenon at length in the early days of the B&C lightweight starters and elected to side-step the issue in it's entirety by suggesting an EXTERNAL contactor with a lower operating current and BUILT IN suppression diode. This was a one-solution fits all contingency installations and had nothing to do with worries for contactors sticking shut. Bob . . . ________________________________________________________________________________
Date: Jul 19, 2014
See http://tinyurl.com/ott27no for an explanation of the extra-ordinarily abusive inrush currents for the built-in contactor-solenoid. This phenomenon has been extra-ordinarily hard on key-starts switches in cars too. Bob . . . ________________________________________________________________________________
Date: Jul 19, 2014
On 7/19/2014 9:34 AM, Robert L. Nuckolls, III wrote: > > In regards to electric dependent engines, it is common to NOT feed it > through a battery "contactor" anyway. My engine runs off the battery > bus and will keep running if the master switch/contactor is off. > > * Feeders from an always-hot bus are allowed in TC > aircraft when protected at 5A or less. This is > a crash-safety concern. For the OBAM aircraft, > one is free to wire it like any other vehicle > including automobiles that generally don't included > battery disconnect switching (except for some > racing jurisdictions). > * > Note that unlike continuous duty battery contactors, starter > contactors draw several amps, are rated for intermittent use only, and > are designed to interrupt large starter currents. There has been some > question as to whether a battery contactor will in fact open if the > starter is running. > > * Was that question posed here on the List? > The answer is YES . . . it will break the > power path to a stuck starter contactor . . . > * > The battery, with its ability to deliver large currents, is the most > dangerous electrical item on board. > > *Precisely. I recall a conversation with an accident > investigator some years back who made the > anecdotal observation that when the airplane > burned after impact, it's battery was more > likely to be still inside a rather compact arrangement > of wreckage. > > When the wreckage was widely scattered with > the battery separated from the rest > of the airplane, the incidences of post crash > fire seemed lower. > * > The typical current draw is 8amps, which could be switched by a regular > switch. Some aerobatic aeroplanes do that, by they often only use an > SD-8. Also the load switched on first operation is likely to be small if > all the services are switched off on shut down. I see no fundamental > reason not to do what you suggest, although you may have to be a little > more careful in how you operate. > > *The battery master disconnect does not have to be > a contactor. The first airplane in which I took > dual instruction had a fat toggle switch and > a fat starter push-button . . . no contactors > at all. > * > I'm envisioning the starter button activating both the contactor and > the starter's built-in contactor. This way, if either sticks, > current would still be removed from the starter when the button is > released. There would be no voltage available on the starter's heavy > wire except during starting, as is current practice (pardon the > pun). The only failed-on single point should be the momentary > push-to-start button. > > *Incidences of starter contactor sticking are > rare . . . the risk goes up markedly when the > pilot attempts to get the engine going with > a seriously discharged or perhaps an un-flightworthy > battery. Render due diligence in the maintenance > of your battery and don't worry about 'sicking > contactors'. > > There'no prohibition for using the starter's > bui9lt in contactor-solenoid but be aware of > the extra abusive nature of pull-in spikes > with increased ware on the starter switch > cnotacts. This over-looked feature was root cause > for an AD against ACS-510 key-switches in > a bit of bureaucratic paper-thrashing that > at first produced a worthless 'fix' and was > later revised to add a spike suppression > diode to the contactor. > > Bill and I pondered this phenomenon at > length in the early days of the B&C lightweight > starters and elected to side-step the > issue in it's entirety by suggesting an > EXTERNAL contactor with a lower operating > current and BUILT IN suppression diode. > > This was a one-solution fits all contingency > installations and had nothing to do with > worries for contactors sticking shut. > > > * > > Bob . . . > > Just read your article (from link in subsequent post)on dual windings in starter solenoids; very helpful. From your comments above, it sounds like I could simply wire the starter like the B&C design in fig 6 of the article, but directly from the battery to run the starter. This would remove the need for the typical heavy (and high coil current) master contactor, allowing a lighter duty relay or switch for the in-cabin loads. Thanks, Charlie ________________________________________________________________________________
Date: Jul 19, 2014
why am I getting everybody's questions and answers to me from other people Sent from my iPhone > On Jul 19, 2014, at 10:36 AM, "Robert L. Nuckolls, III" <nuckolls.bob@aero electric.com> wrote: > > See http://tinyurl.com/ott27no > > for an explanation of the extra-ordinarily > abusive inrush currents for the built-in > contactor-solenoid. This phenomenon has been > extra-ordinarily hard on key-starts switches in > cars too. > > > Bob . . . > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Jul 19, 2014
Jon, You must have subscribed to the AeroElectric connection email list. Anytime a n email is sent to "aeroelectric-list(at)matronics.com" you will receive a copy of that email. It is sort of a think tank with some very knowledgeable people that read and respond to questions. Hope this answers your question. Justin On Jul 19, 2014, at 7:15, jon molek wrote: > why am I getting everybody's questions and answers to me from other people > > Sent from my iPhone > > On Jul 19, 2014, at 10:36 AM, "Robert L. Nuckolls, III" <nuckolls.bob@aero electric.com> wrote: > >> See http://tinyurl.com/ott27no >> >> for an explanation of the extra-ordinarily >> abusive inrush currents for the built-in >> contactor-solenoid. This phenomenon has been >> extra-ordinarily hard on key-starts switches in >> cars too. >> >> >> Bob . . . >> > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Jul 19, 2014
yes thank you that explains it I know how to stop it but my main question wa s never answered maybe you can answer it originally wrote I'm installing a overvoltage module (Ovm 14) from B&C and wiring it as sugge sted in the external regulatored diagram. (of B&C) problem is the regulator IN shows it's hooked to a 5 amp breaker my system i s the Cessna type system that has a 60 amp breaker only will the 60 amp brea ker work properly meaning if I hook to that will it kick it when overloaded ? & or will it burnout the Ovm? or do you have another means of hooking the Ovm up ?(normally they use the f ield it has a 5amp) john Sent from my iPhone > On Jul 19, 2014, at 11:56 AM, Justin Jones wr ote: > > Jon, > > You must have subscribed to the AeroElectric connection email list. Anytim e an email is sent to "aeroelectric-list(at)matronics.com" you will receive a c opy of that email. > > It is sort of a think tank with some very knowledgeable people that read a nd respond to questions. > > Hope this answers your question. > > Justin > > >> On Jul 19, 2014, at 7:15, jon molek wrote: >> >> why am I getting everybody's questions and answers to me from other peopl e >> >> Sent from my iPhone >> >>> On Jul 19, 2014, at 10:36 AM, "Robert L. Nuckolls, III" <nuckolls.bob@ae roelectric.com> wrote: >>> >>> See http://tinyurl.com/ott27no >>> >>> for an explanation of the extra-ordinarily >>> abusive inrush currents for the built-in >>> contactor-solenoid. This phenomenon has been >>> extra-ordinarily hard on key-starts switches in >>> cars too. >>> >>> >>> Bob . . . >>> >> >> >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> lectric-List"">http://www.matronics.com/Navigator?AeroElectric-List >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> //forums.matronics.com >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> ot;">http://www.matronics.com/contribution >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Jul 19, 2014
Just read your article (from link in subsequent post)on dual windings in starter solenoids; very helpful. From your comments above, it sounds like I could simply wire the starter like the B&C design in fig 6 of the article, but directly from the battery to run the starter. This would remove the need for the typical heavy (and high coil current) master contactor, allowing a lighter duty relay or switch for the in-cabin loads. Thanks, Charlie You wrote: Motivation is saving a few ounces of contactor weight, and more importantly, saving the 2+amps of draw by the normal master contactor. Actually, 1A or less . . . See http://tinyurl.com/mpcgp3t and . . . http://tinyurl.com/k6bwdqo If I elect to go with a single alternator (weight, simplicity), the 2 amp draw of the main contactor is a significant percentage of load in a failed alternator situation. What size alternator do you anticipate installing? Note that similar engine installs have flown for 45 minutes or more (typically plenty of time to find a runway) while operating 'battery only' using =C2 common 18-20 AH SLA battery installations. Is this a day-vfr fun machine or do plan to travel? Is 45 minutes your battery-only endurance target . . . or would fuel endurance be more attractive? Have you crafted a load analysis for the purpose of sizing the battery to your battery- only endurance target? Bob . . . ________________________________________________________________________________
Date: Jul 19, 2014
>\ I'm installing a overvoltage module (Ovm 14) from B&C and wiring it as suggested in the external regulatored diagram. (of B&C) problem is the regulator IN shows it's hooked to a 5 amp breaker my system is the Cessna type system that has a 60 amp breaker only will the 60 amp breaker work properly meaning if I hook to that will it kick it when overloaded ?& or will it burnout the Ovm? or do you have another means of hooking the Ovm up ?(normally they use the field it has a 5amp) If the system to which you are adding ov protection is a 'Cessna type', then there are two breakers. The 60A is the alternator b-lead on the panel, Recommend that be replaced with 60A current limiter on the firewall. Also 5A breaker for the alternator field supply. This breaker would feed one side of the split-rocker battery-master/alternator switch. The OVM would mount right at them master to the feedpoint that's wired to the 5A breaker. Bob . . . Bob . . . ________________________________________________________________________________
Date: Jul 19, 2014
On 7/19/2014 12:01 PM, Robert L. Nuckolls, III wrote: > Just read your article (from link in subsequent post)on dual windings > in starter solenoids; very helpful. > > From your comments above, it sounds like I could simply wire the > starter like the B&C design in fig 6 of the article, but directly from > the battery to run the starter. This would remove the need for the > typical heavy (and high coil current) master contactor, allowing a > lighter duty relay or switch for the in-cabin loads. > > Thanks, > > Charlie > > *You wrote: > > *Motivation is saving a few ounces of contactor weight, and more > importantly, saving the 2+amps of draw by the normal master contactor. > > * Actually, 1A or less . . . See > > http://tinyurl.com/mpcgp3t > > <http://tinyurl.com/mpcgp3t> and . . . > > http://tinyurl.com/k6bwdqo > > <http://tinyurl.com/k6bwdqo>*If I elect to go with a single alternator > (weight, simplicity), the 2 amp draw of the main contactor is a > significant percentage of load in a failed alternator situation. > > > * What size alternator do you anticipate > installing? > > *Note that similar engine installs have flown for 45 minutes or more > (typically plenty of time to find a runway) while operating 'battery > only' using common 18-20 AH SLA battery installations. > > * Is this a day-vfr fun machine or > do plan to travel? Is 45 minutes > your battery-only endurance > target . . . or would fuel endurance > be more attractive? Have you > crafted a load analysis for the purpose > of sizing the battery to your battery- > only endurance target? > > * > > Bob . . . > Wow; to speak Mississippi, who'd a thunk that <11 watts could heat that chunk of metal to 160 degrees in free air. Alternator is a Denso off a Suzuki Samurai; 60 A. Total continuous load is ~25A; calculated load can reduce to <16A for engine-only operation, but I suspect that it goes significantly lower in the real world. The reason is, as I've mentioned, similar engines (Mazda rotary with electronic injection/ignition & automotive high pressure electric fuel pump), have flown for >45 minutes on battery-only using 'typical' 18-20AH SLA batteries. The plane will be used day-vfr initially, but will have a panel that's capable of IFR flight (if I ever become capable). Load for IFR would go up by ~15A max (heated pitot). Yes, I'd like to have the fuel endurance option. I actually have a 2nd Denso alternator, and a 20A dynamo, one of which may yet find its way onto the engine as 2nd source of energy. But it's really hard to add the weight & complexity for a vfr only a/c. Charlie ________________________________________________________________________________
Date: Jul 19, 2014
Subject: Re: Test
At 02:18 PM 7/19/2014, BobsV35B(at)aol.com wrote: >Good Afternoon Bob, > >I still am not getting a copy of anything I send to the AE list. >Gotta find a good techie to see why my machine is blocking my messages! > >Happy Skies, > >Old Bob > Any pc byte thrashers out here? Ol' Bob is wrestling with a peculiar problem. Seems he gets all the list traffic to his mailbox EXCEPT those which he sends to the list. We all see them but he doesn't. Any suggestions as to where to look? He didn't mention any changes to hardware or software but that doesn't preclude some kind of an upgrade related bug. Bob, give us a top level rundown of your machine and email application software. Also, is this the ONLY machine you have? Do you perhaps have a laptop that might still be functioning as desired? Bob . . . ________________________________________________________________________________
Subject: Re: Test
Date: Jul 19, 2014
I can't offer a solution, but I have the same issue. Anything I send to the server is not echoed back to me, but everyone else's posts come through. D oesn't bother me too much, as long as I see the replies. Unfortunately, I don't: One annoying issue that could perhaps be solved on t he server end is that many emails from the list end up in my email account's spam folder. If the server sent all emails with a common "From" address, w e could put that address in our address book or whitelist and stop this prob lem immediately. But, since the server echoes each message with the origina l sender's address in the "From" field, there's no way I can stop the spam f ilter from grabbing them. At least no way that I've been able to discover. Eric > On Jul 19, 2014, at 3:20 PM, "Robert L. Nuckolls, III" <nuckolls.bob@aeroe lectric.com> wrote: > > At 02:18 PM 7/19/2014, BobsV35B(at)aol.com wrote: >> Good Afternoon Bob, >> >> I still am not getting a copy of anything I send to the AE list. Gotta fi nd a good techie to see why my machine is blocking my messages! >> >> Happy Skies, >> >> Old Bob > > Any pc byte thrashers out here? Ol' Bob is wrestling with a peculiar probl em. Seems he gets all the list traffic to his mailbox EXCEPT those which he s ends to the list. We all see them but he doesn't. > > Any suggestions as to where to look? He didn't mention any changes to hard ware or software but that doesn't preclude some kind of an upgrade related b ug. > > Bob, give us a top level rundown of your machine and email application sof tware. Also, is this the ONLY machine you have? Do you perhaps have a laptop that might still be functioning as desired? > > Bob . . . ________________________________________________________________________________
Date: Jul 19, 2014
Subject: Re: Test
Same for me, even when just using gmail. I assumed that was how the list works. On Sat, Jul 19, 2014 at 6:20 PM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 02:18 PM 7/19/2014, BobsV35B(at)aol.com wrote: > > Good Afternoon Bob, > > I still am not getting a copy of anything I send to the AE list. Gotta > find a good techie to see why my machine is blocking my messages! > > Happy Skies, > > Old Bob > > > Any pc byte thrashers out here? Ol' Bob is wrestling > with a peculiar problem. Seems he gets all the list > traffic to his mailbox EXCEPT those which he sends to > the list. We all see them but he doesn't. > > Any suggestions as to where to look? He didn't > mention any changes to hardware or software but > that doesn't preclude some kind of an upgrade > related bug. > > Bob, give us a top level rundown of your machine > and email application software. Also, is this the > ONLY machine you have? Do you perhaps have a laptop > that might still be functioning as desired? > > > Bob . . . > > * > > > * > > ________________________________________________________________________________
Subject: Re: Test
Date: Jul 19, 2014
Maybe you are not really sending your message to the AE list but to an original poster or to a bogus address. I have noticed one thing in the Apple email program. If I click "reply" at the top of the mail window, it will insert the AE address. If I click on the AE address in the message and select "reply to sender" it will insert the original poster's address. My wife often starts an email. As she begins to type the recipient's address, the mail program searches through all the old saved emails and address book and shows her a bunch of options for that address. Unfortunately, some of the addresses are out of date so she will sometimes send it to a bad address. Usually she'll get a "could not deliver message" though, that's when she calls the expert . . . :-) -Kent On Jul 19, 2014, at 6:20 PM, Robert L. Nuckolls, III wrote: > At 02:18 PM 7/19/2014, BobsV35B(at)aol.com wrote: >> Good Afternoon Bob, >> >> I still am not getting a copy of anything I send to the AE list. Gotta find a good techie to see why my machine is blocking my messages! >> >> Happy Skies, >> >> Old Bob >> > > Any pc byte thrashers out here? Ol' Bob is wrestling > with a peculiar problem. Seems he gets all the list > traffic to his mailbox EXCEPT those which he sends to > the list. We all see them but he doesn't. > > Any suggestions as to where to look? He didn't > mention any changes to hardware or software but > that doesn't preclude some kind of an upgrade > related bug. > > Bob, give us a top level rundown of your machine > and email application software. Also, is this the > ONLY machine you have? Do you perhaps have a laptop > that might still be functioning as desired? > > > Bob . . . > > > > http://www.matronics.com/Navigator?AeroElectric-List > > http://forums.matronics.com > > http://www.matronics.com/contribution > > > ________________________________________________________________________________
Date: Jul 19, 2014
Subject: Re: Test
On 7/19/2014 6:36 PM, William Greenley wrote: > > On Sat, Jul 19, 2014 at 6:20 PM, Robert L. Nuckolls, III > > > wrote: > > At 02:18 PM 7/19/2014, BobsV35B(at)aol.com > wrote: >> Good Afternoon Bob, >> >> I still am not getting a copy of anything I send to the AE list. >> Gotta find a good techie to see why my machine is blocking my >> messages! >> >> Happy Skies, >> >> Old Bob > > Any pc byte thrashers out here? Ol' Bob is wrestling > with a peculiar problem. Seems he gets all the list > traffic to his mailbox EXCEPT those which he sends to > the list. We all see them but he doesn't. > > Any suggestions as to where to look? He didn't > mention any changes to hardware or software but > that doesn't preclude some kind of an upgrade > related bug. > > Bob, give us a top level rundown of your machine > and email application software. Also, is this the > ONLY machine you have? Do you perhaps have a laptop > that might still be functioning as desired? > > > Bob . . . > > Same for me, even when just using gmail. I assumed that was how > the list works. > I've had it happen to me, as well, but it doesn't seem to be consistent and I'm pretty sure I've had it happen with other, non-Matronics lists. For troubleshooting purposes, it might be useful to supply info on what email client (if any) is being used. I use Thunderbird, but sometimes check mail using Gmail's web interface using the computer in the shop. For a while, I assumed that the host(s)'s list server software had changed the way it distributed email, but since it's not consistent, I'm mystified as to the cause. Charlie ________________________________________________________________________________
Date: Jul 19, 2014
Subject: Re: Test
While that can happen, I've sent messages to various lists, not received a copy, then gotten replies from another member quoting my message. Charlie On 7/19/2014 6:55 PM, Kent or Jackie Ashton wrote: > > Maybe you are not really sending your message to the AE list but to an original poster or to a bogus address. > > I have noticed one thing in the Apple email program. If I click "reply" at the top of the mail window, it will insert the AE address. If I click on the AE address in the message and select "reply to sender" it will insert the original poster's address. > > My wife often starts an email. As she begins to type the recipient's address, the mail program searches through all the old saved emails and address book and shows her a bunch of options for that address. Unfortunately, some of the addresses are out of date so she will sometimes send it to a bad address. Usually she'll get a "could not deliver message" though, that's when she calls the expert . . . :-) > -Kent > > > On Jul 19, 2014, at 6:20 PM, Robert L. Nuckolls, III wrote: > >> At 02:18 PM 7/19/2014, BobsV35B(at)aol.com wrote: >>> Good Afternoon Bob, >>> >>> I still am not getting a copy of anything I send to the AE list. Gotta find a good techie to see why my machine is blocking my messages! >>> >>> Happy Skies, >>> >>> Old Bob >>> >> Any pc byte thrashers out here? Ol' Bob is wrestling >> with a peculiar problem. Seems he gets all the list >> traffic to his mailbox EXCEPT those which he sends to >> the list. We all see them but he doesn't. >> >> Any suggestions as to where to look? He didn't >> mention any changes to hardware or software but >> that doesn't preclude some kind of an upgrade >> related bug. >> >> Bob, give us a top level rundown of your machine >> and email application software. Also, is this the >> ONLY machine you have? Do you perhaps have a laptop >> that might still be functioning as desired? >> >> >> Bob . . . >> ________________________________________________________________________________
Date: Jul 20, 2014
> my question was on a overvoltage module (ovm) from B&C using 60 amp breaker instead of a 5 amp will it hurt the ovm and will it work properly? A 60 amp breaker will most likely damage the OVM. No, it will not work properly and could cause a fire. An alternator has two separate circuits: field circuit and stator circuit. The 60 amp breaker protects the battery and wiring from a shorted alternator stator winding. A 5 amp breaker protects the electrical system from a shorted alternator field. The crowbar type OVM is designed to trip a 5 amp breaker. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426989#426989 ________________________________________________________________________________
Date: Jul 20, 2014
I was replying to Charlie's questions about using a switch instead of a contactor - that's why it is addressed to Charlie. Why try to re-design the B&C implementation? Circuit breakers are reasonably cheap, just go buy a 5a c/b! I don't know how the B&C circuit was designed, but using a 60A c/b will probably mean it doesn't work properly (takes too long to work) so I suspect something expensive you are trying to protect will be damaged. Peter On 19/07/2014 13:59, jon molek wrote: > you may have replied to me by accident! > that wasn't my question. > my question was on a overvoltage module (ovm) from B&C using 60 amp > breaker instead of a 5 amp will it hurt the ovm and will it work properly? > you may want to refer to my email again for all details thank you ! > John > > > Sent from my iPhone > > On Jul 19, 2014, at 2:53 AM, Peter Pengilly > wrote: > >> Charlie, >> I believe the driver for a master contacted has been the >> airworthiness regs - FAR23 and CS23 - which require one switch to >> shut off all electrical power, or words to that effect. If the load >> is 10s of amps (heated pitot, incandescent landing light, stack of >> old radios, etc) then a contactor was the only sensible way to go. >> >> There are now good reasons to question that kind of requirement, and >> do what you suggest. In my aeroplane, that has a conventional engine. >> The typical current draw is 8amps, which could be switched by a >> regular switch. Some aerobatic aeroplanes do that, by they often only >> use an SD-8. Also the load switched on first operation is likely to >> be small if all the services are switched off on shut down. I see no >> fundamental reason not to do what you suggest, although you may have >> to be a little more careful in how you operate. >> >> The only draw back is the stuck starter relay scenario. Using a >> double pole momentary may work, but you could also consider a >> separate switch in the line to the starter piggy-back solenoid. That >> way if the starter relay fails closed at least it will be obvious. >> >> Peter >> >> On Jul 18, 2014 8:35 PM, "Charlie England" > > wrote: >> >> Someone's recent question/comment about master & starter >> contactors caused my ARADD (aviation related attention deficit >> disorder) to kick in. >> >> I'm just beginning the wiring process on an electrically >> dependent auto engine conversion in an RV-7. >> Given the typical automotive starter with self-contained >> contactor/bendix, and a starter contactor, could a case be made >> for switching the cockpit loads with smaller (lower coil current >> draw) contactors or even heavy duty switches, and using only the >> heavy starter contactor between the battery & starter? >> >> I'm envisioning the starter button activating both the contactor >> and the starter's built-in contactor. This way, if either sticks, >> current would still be removed from the starter when the button >> is released. There would be no voltage available on the starter's >> heavy wire except during starting, as is current practice (pardon >> the pun). The only failed-on single point should be the momentary >> push-to-start button. >> >> Motivation is saving a few ounces of contactor weight, and more >> importantly, saving the 2+amps of draw by the normal master >> contactor. If I elect to go with a single alternator (weight, >> simplicity), the 2 amp draw of the main contactor is a >> significant percentage of load in a failed alternator situation. >> Note that similar engine installs have flown for 45 minutes or >> more (typically plenty of time to find a runway) while operating >> 'battery only' using common 18-20 AH SLA battery installations. >> >> Thoughts? >> >> Charlie >> >> * >> >> ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> >> * >> >> * >> >> >> * > * > > > * ________________________________________________________________________________
Subject: Test
Date: Jul 20, 2014
I don't have a complete answer for you as a couple of you were using aol addresses but I do know that if you're using a gmail address and send a message or reply to a group which contains your gmail address then gmail does not display your message in your Inbox. Here's a link to a gmail forum that confirms this is how gmail is designed to work, it does offer a workaround https://productforums.google.com/forum/#!topic/gmail/RPxyd7uW4Hc Tony Babb -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Charlie England Sent: Saturday, July 19, 2014 5:18 PM Subject: Re: AeroElectric-List: Test --> While that can happen, I've sent messages to various lists, not received a copy, then gotten replies from another member quoting my message. Charlie On 7/19/2014 6:55 PM, Kent or Jackie Ashton wrote: > --> > > Maybe you are not really sending your message to the AE list but to an original poster or to a bogus address. > > I have noticed one thing in the Apple email program. If I click "reply" at the top of the mail window, it will insert the AE address. If I click on the AE address in the message and select "reply to sender" it will insert the original poster's address. > > My wife often starts an email. As she begins to type the recipient's address, the mail program searches through all the old saved emails and address book and shows her a bunch of options for that address. Unfortunately, some of the addresses are out of date so she will sometimes send it to a bad address. Usually she'll get a "could not deliver message" though, that's when she calls the expert . . . :-) > -Kent > > > On Jul 19, 2014, at 6:20 PM, Robert L. Nuckolls, III wrote: > >> At 02:18 PM 7/19/2014, BobsV35B(at)aol.com wrote: >>> Good Afternoon Bob, >>> >>> I still am not getting a copy of anything I send to the AE list. Gotta find a good techie to see why my machine is blocking my messages! >>> >>> Happy Skies, >>> >>> Old Bob >>> >> Any pc byte thrashers out here? Ol' Bob is wrestling >> with a peculiar problem. Seems he gets all the list >> traffic to his mailbox EXCEPT those which he sends to >> the list. We all see them but he doesn't. >> >> Any suggestions as to where to look? He didn't >> mention any changes to hardware or software but >> that doesn't preclude some kind of an upgrade >> related bug. >> >> Bob, give us a top level rundown of your machine >> and email application software. Also, is this the >> ONLY machine you have? Do you perhaps have a laptop >> that might still be functioning as desired? >> >> >> Bob . . . >> ________________________________________________________________________________
Date: Jul 20, 2014
I tried using five amp breaker it won't kick the alternator in have to have a 60 amp I guess Sent from my iPhone > On Jul 20, 2014, at 6:14 AM, Peter Pengilly wrote : > > I was replying to Charlie's questions about using a switch instead of a co ntactor - that's why it is addressed to Charlie. > > Why try to re-design the B&C implementation? Circuit breakers are reasonab ly cheap, just go buy a 5a c/b! > I don't know how the B&C circuit was designed, but using a 60A c/b will pr obably mean it doesn't work properly (takes too long to work) so I suspect s omething expensive you are trying to protect will be damaged. > > Peter > >> On 19/07/2014 13:59, jon molek wrote: >> you may have replied to me by accident! >> that wasn't my question. >> my question was on a overvoltage module (ovm) from B&C using 60 amp break er instead of a 5 amp will it hurt the ovm and will it work properly ? >> you may want to refer to my email again for all details thank you ! >> John >> >> >> Sent from my iPhone >> >> On Jul 19, 2014, at 2:53 AM, Peter Pengilly wrot e: >> >>> Charlie, >>> I believe the driver for a master contacted has been the airworthiness r egs - FAR23 and CS23 - which require one switch to shut off all e lectrical power, or words to that effect. If the load is 10s of amps (heated pitot, incandescent landing light, stack of old radios, etc) then a contact or was the only sensible way to go. >>> >>> There are now good reasons to question that kind of requirement, and do w hat you suggest. In my aeroplane, that has a conventional engine. The typica l current draw is 8amps, which could be switched by a regular switch. Some a erobatic aeroplanes do that, by they often only use an SD-8. Also the load s witched on first operation is likely to be small if all the services are swi tched off on shut down. I see no fundamental reason not to do what you sugge st, although you may have to be a little more careful in how you operate. >>> >>> The only draw back is the stuck starter relay scenario. Using a double p ole momentary may work, but you could also consider a separate switch in the line to the starter piggy-back solenoid. That way if the starter relay fail s closed at least it will be obvious. >>> >>> Peter >>>> On Jul 18, 2014 8:35 PM, "Charlie England" wrote : >>>> Someone's recent question/comment about master & starter contactors cau sed my ARADD (aviation related attention deficit disorder) to kick in. >>>> >>>> I'm just beginning the wiring process on an electrically dependent auto engine conversion in an RV-7. >>>> Given the typical automotive starter with self-contained contactor/bend ix, and a starter contactor, could a case be made for switching the cockpit l oads with smaller (lower coil current draw) contactors or even heavy duty sw itches, and using only the heavy starter contactor between the battery & sta rter? >>>> >>>> I'm envisioning the starter button activating both the contactor and th e starter's built-in contactor. This way, if either sticks, current would st ill be removed from the starter when the button is released. There would be no voltage available on the starter's heavy wire except du ring starting, as is current practice (pardon the pun). The only failed-on s ingle point should be the momentary push-to-start button. >>>> >>>> Motivation is saving a few ounces of contactor weight, and more importa ntly, saving the 2+amps of draw by the normal master contactor. If I elect t o go with a single alternator (weight, simplicity), the 2 amp draw of the ma in contactor is a significant percentage of load in a failed alternator situ ation. Note that similar engine installs have flown for 45 minutes or more ( typically plenty of time to find a runway) while operating 'battery only' us ing common 18-20 AH SLA battery installations. >>>> >>>> Thoughts? >>>> >>>> Charlie >>>> >>>> >>>> ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric- List >>>> tp://forums.matronics.com >>>> _blank">http://www.matronics.com/contribution > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Jul 20, 2014
you're saying instead of hooking it to the reg in from the alternator to th e regulator ,Hook it to the field which has a five amp that's what I thought I would do but didn't know if it would work do I still need to change to a voltage limiter on the firewall ?if so what i s it ?where do I get one? Thank you John Sent from my iPhone > On Jul 19, 2014, at 1:26 PM, "Robert L. Nuckolls, III" <nuckolls.bob@aeroe lectric.com> wrote: > >> \ > > > > I'm installing a overvoltage module (Ovm 14) from B&C and wiring it as sug gested in the external regulatored diagram. (of B&C) problem is the regulato r IN shows it's hooked to a 5 amp breaker my system is the Cessna type syste m that has a 60 amp breaker only will the 60 amp breaker work properly meani ng if I hook to that will it kick it when overloaded ?& or will it burnout t he Ovm? or do you have another means of hooking the Ovm up ?(normally they u se the field it has a 5amp) > > > If the system to which you are adding > ov protection is a 'Cessna type', then there > are two breakers. The 60A is the alternator > b-lead on the panel, Recommend that be replaced > with 60A current limiter on the firewall. > > Also 5A breaker for the alternator field supply. > This breaker would feed one side of the > split-rocker battery-master/alternator switch. The > OVM would mount right at them master > to the feedpoint that's wired to the 5A > breaker. > > Bob . . . > > > Bob . . . > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Jul 20, 2014
that's my thinking also but according to the drawing it says to hook to the regulator and not the field if he wanted to hook it to the field it would've said so so I'm confused do I split the regulator in or split the field the field has the breaker on & the regulator in doesn't Sent from my iPhone > On Jul 20, 2014, at 5:25 AM, "user9253" wrote: > > > >> my question was on a overvoltage module (ovm) from B&C using 60 amp breaker instead of a 5 amp will it hurt the ovm and will it work properly? > > A 60 amp breaker will most likely damage the OVM. No, it will not work properly and could cause a fire. An alternator has two separate circuits: field circuit and stator circuit. The 60 amp breaker protects the battery and wiring from a shorted alternator stator winding. A 5 amp breaker protects the electrical system from a shorted alternator field. The crowbar type OVM is designed to trip a 5 amp breaker. > Joe > > -------- > Joe Gores > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=426989#426989 > > > > > > > > > > ________________________________________________________________________________
Date: Jul 20, 2014
it sounds to me it's saying hook it to a five amp breaker the controls the system Sent from my iPhone > On Jul 20, 2014, at 5:25 AM, "user9253" wrote: > > > >> my question was on a overvoltage module (ovm) from B&C using 60 amp breaker instead of a 5 amp will it hurt the ovm and will it work properly? > > A 60 amp breaker will most likely damage the OVM. No, it will not work properly and could cause a fire. An alternator has two separate circuits: field circuit and stator circuit. The 60 amp breaker protects the battery and wiring from a shorted alternator stator winding. A 5 amp breaker protects the electrical system from a shorted alternator field. The crowbar type OVM is designed to trip a 5 amp breaker. > Joe > > -------- > Joe Gores > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=426989#426989 > > > > > > > > > > ________________________________________________________________________________
Date: Jul 20, 2014
Subject: Re: Test
How odd. I have gmail and get the digest, and have no such issues. However, on another venue that is hosted on yahoo, I will sometimes get peoples replies without ever having gotten the original post. Gotta love technology. ________________________________________________________________________________
Date: Jul 20, 2014
Test Too! Old Bob ________________________________________________________________________________
Subject: Re: Test
Date: Jul 20, 2014
Bob- This is Old Bob's son Bob, and I have been trying to look into why he does not receive the emails that he sends to the list. According to a help page on AOL, the contents of which are attached, it seems to be associated with the way that AOL handles messages from mailing list servers. I do not see a ny work-around, but if someone else has some insight I will try to help Old Bob make whatever changes that might be required. Regards, Bob Siegfried, II -----Original Message----- From: Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> @aol.com> Sent: Sat, Jul 19, 2014 5:22 pm Subject: Re: AeroElectric-List: Test At 02:18 PM 7/19/2014, BobsV35B(at)aol.com wrote: Good Afternoon Bob, I still am not getting a copy of anything I send to the AE list. Gottafind a good techie to see why my machine is blocking my messages! Happy Skies, Old Bob Any pc byte thrashers out here? Ol' Bob is wrestling with a peculiar problem. Seems he gets all the list traffic to his mailbox EXCEPT those which he sends to the list. We all see them but he doesn't. Any suggestions as to where to look? He didn't mention any changes to hardware or software but that doesn't preclude some kind of an upgrade related bug. Bob, give us a top level rundown of your machine and email application software. Also, is this the ONLY machine you have? Do you perhaps have a laptop that might still be functioning as desired? Bob . . . ________________________________________________________________________________
Date: Jul 20, 2014
John, Is the O.V. module being installed in an experimental airplane? What make and model is it? Are we talking about an alternator or dynamo or generator? Is there an external voltage regulator? Is this an existing electrical system that you are adding an O.V. module to? If there is an existing alternator and external voltage regulator, then there should also be a fuse or circuit breaker that supplies power to the voltage regulator. The O.V. module needs to be connected between the 5 amp circuit breaker and the voltage regulator (which is part of the field circuit). Good advice can not be given without knowing all of the facts. It is better to not install an O.V. module than to install it incorrectly. > . . . .you may want to refer to my email again for all details thank you ! I can not find your original posting. > why am I getting everybody's questions and answers to me from other people Because you are posting in someone else's thread. > > do I still need to change to a voltage limiter on the firewall ?if so what is it ? Do you mean current limiter? It is sort of a robust very slow blow fuse. Search for MIDI fuse or ANL fuse. A current limiter is a good idea, but is unrelated to the O.V. module. > do I split the regulator in or split the field the field has the breaker on & the regulator in doesn't Sorry, I do not understand that. If installing an O.V. module to an existing electrical system, no splitting is necessary. Connect the O.V. module to the wire that goes between the 5 amp breaker and the voltage regulator. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427018#427018 ________________________________________________________________________________
Date: Jul 20, 2014
At 06:13 AM 7/20/2014, you wrote: >I tried using five amp breaker it won't kick the alternator in >have to have a 60 amp I guess > >Sent from my iPhone A picture may be worth 10,000 words . . . but 10,000 words never describes the same picture in the minds of all readers. Are you wiring to a published schematic that we can download and all pray over at the same time? If you've modified a published schematic, then a scanned copy of your changes will offer all of us a reasonable chance of understanding your design goals and offering a solution. Bob . . . ________________________________________________________________________________
Date: Jul 20, 2014
Subject: Test
Date: Jul 20, 2014
Glen, I=99d guess that=99s why. You=99re getting the digest and not individual messages so gmail can=99t tell that the incoming message was sent by you as it=99s just one of many messages with the digest. From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of GLEN MATEJCEK Sent: Sunday, July 20, 2014 6:00 AM Subject: Re: AeroElectric-List: Test How odd. I have gmail and get the digest, and have no such issues. However, on another venue that is hosted on yahoo, I will sometimes get peoples replies without ever having gotten the original post. Gotta love technology. ________________________________________________________________________________
Subject: Re: Are 'serial' contactors really needed?
Date: Jul 21, 2014
yes I'm using the B&C schematic with an external regulator ,(no changes) it says to hook the ovm to regulator in & to the master switch . I want to hook it to the field which has a five amp breaker . I'm asking why I can't do that instead of the regulator in? Sent from my iPhone > On Jul 20, 2014, at 4:41 PM, "Robert L. Nuckolls, III" wrote: > > > At 06:13 AM 7/20/2014, you wrote: >> I tried using five amp breaker it won't kick the alternator in >> have to have a 60 amp I guess >> >> Sent from my iPhone > > A picture may be worth 10,000 words . . . but 10,000 > words never describes the same picture in the > minds of all readers. > > Are you wiring to a published schematic that > we can download and all pray over at the same > time? If you've modified a published schematic, > then a scanned copy of your changes will > offer all of us a reasonable chance of understanding > your design goals and offering a solution. > > > > Bob . . . > > > > ________________________________________________________________________________
Date: Jul 21, 2014
this is an alternator with an external regulator (system by Interav, using their schematic and B&C schematic ) it's a Motorola Alternator previously installed an experimental RV8 my intention is to use the field instead of the regulator in ,being how the field already has a 5 amp breaker to kick , (it is also controlling the regulator ) Thank You for your time & advice it's greatly appreciated and very helpful! John Sent from my iPhone > On Jul 20, 2014, at 4:31 PM, "user9253" wrote: > > > John, > Is the O.V. module being installed in an experimental airplane? > What make and model is it? > Are we talking about an alternator or dynamo or generator? > Is there an external voltage regulator? > Is this an existing electrical system that you are adding an O.V. module to? > If there is an existing alternator and external voltage regulator, then there should also be a fuse or circuit breaker that supplies power to the voltage regulator. The O.V. module needs to be connected between the 5 amp circuit breaker and the voltage regulator (which is part of the field circuit). > Good advice can not be given without knowing all of the facts. > It is better to not install an O.V. module than to install it incorrectly. > >> . . . .you may want to refer to my email again for all details thank you ! > > I can not find your original posting. > >> why am I getting everybody's questions and answers to me from other people > > Because you are posting in someone else's thread. > >> >> do I still need to change to a voltage limiter on the firewall ?if so what is it ? > > Do you mean current limiter? It is sort of a robust very slow blow fuse. > Search for MIDI fuse or ANL fuse. A current limiter is a good idea, but is unrelated to the O.V. module. > >> do I split the regulator in or split the field the field has the breaker on & the regulator in doesn't > > Sorry, I do not understand that. If installing an O.V. module to an existing > electrical system, no splitting is necessary. Connect the O.V. module to the wire that goes between the 5 amp breaker and the voltage regulator. > Joe > > -------- > Joe Gores > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=427018#427018 > > > > > > > > > > ________________________________________________________________________________
Date: Jul 21, 2014
> it says to hook the ovm to regulator in & to the master switch No it doesn't. B&C schematic link: http://www.bandc.biz/pdfs/OVM_wiringdiagram.pdf The B&C schematic shows the black wire of the O.V. module connected to ground. They just happened to use the same ground that the master switch is connected to. You can connect the black wire to any convenient ground. I think that B&C drew the schematic that way for two reasons: 1. It is easy to draw. 2. It is easy to wire directly at the master switch because both ground and the alternator field circuit are available there (if your master switch is wired like B&C's switch is wired). As for the colored wire (orange?) of the O.V., B&C shows it connected to the alternator-field half of the master switch. Electrically speaking, this is the same as connecting to the voltage regulator input. In either case, power is coming from the 5 amp breaker. Now if you want to connect the O.V. module directly to the 5 amp breaker, I see no reason why that will not work. I hope others will correct me if wrong. Just make sure that it is connected to the down stream side and not the always hot side of the breaker. In summary, connect the O.V. black wire to ground. And connect the other wire to some point between the 5 amp breaker and the input to the voltage regulator. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427062#427062 ________________________________________________________________________________
Date: Jul 21, 2014
Subject: Crowbar OV module placement
At 07:25 AM 7/21/2014, you wrote: > >yes I'm using the B&C schematic with an external regulator ,(no >changes) it says to hook the ovm to regulator in & to the master switch . >I want to hook it to the field which has a five amp breaker . >I'm asking why I can't do that instead of the regulator in? The crowbar ov module functions by creating a high current (artificial fault) on the field voltage supply line for the purpose of forcing the field supply breaker open . . . thus depriving the alternator of field excitation an shutting it down. That 'fault' may be applied anywhere along the supply line between the breaker and the regulator's input terminal. What kind of regulator are you using? You mentioned something to the effect that a 5A breaker seemed inadequate to getting the alternator to come alive? You need to get the alternator working first using details from the B&C drawing . . . the breaker sizes cited are correct. After the alternator is working, then add the OV module at any point along the field excitation power path. Bob . . . ________________________________________________________________________________
Date: Jul 21, 2014
Subject: Re: COZY: Phantom audio return path (Narco 12MKE)
Subject: Re: Crowbar OV module placement
Date: Jul 21, 2014
The regulator is the solid-state supplied from InterAv as a kit to work with the Motorola Alternator i'm using the schematic of the interAv system and hooking up the OVM from the B&C system if I can hook to the field on the InterAv system then all my troubles are over that's what I wanted to do the mention of the 5 amp not kicking the regulator in just disregard ! that was a whole Nother scenario! do you still recommend me to change to a voltage limiter on the firewall as suggested before? if not I'm done ,I have it accomplished! Thank you again!! John Sent from my iPhone > On Jul 21, 2014, at 11:01 AM, "Robert L. Nuckolls, III" wrote: > > > At 07:25 AM 7/21/2014, you wrote: >> >> yes I'm using the B&C schematic with an external regulator ,(no changes) it says to hook the ovm to regulator in & to the master switch . >> I want to hook it to the field which has a five amp breaker . >> I'm asking why I can't do that instead of the regulator in? > > The crowbar ov module functions by creating > a high current (artificial fault) on the field > voltage supply line for the purpose of > forcing the field supply breaker open . . . > thus depriving the alternator of field > excitation an shutting it down. > > That 'fault' may be applied anywhere along > the supply line between the breaker and > the regulator's input terminal. > > What kind of regulator are you using? > > You mentioned something to the effect that > a 5A breaker seemed inadequate to getting > the alternator to come alive? You need > to get the alternator working first using > details from the B&C drawing . . . the > breaker sizes cited are correct. > > After the alternator is working, then add > the OV module at any point along the field > excitation power path. > > > > Bob . . . > > > > ________________________________________________________________________________
Date: Jul 21, 2014
I understand !! I thank you very very very much you guys are lifesaver it's a please dealing with you and your staff !! Thank You John Sent from my iPhone > On Jul 21, 2014, at 10:40 AM, "user9253" wrote: > > > >> it says to hook the ovm to regulator in & to the master switch > > No it doesn't. > B&C schematic link: http://www.bandc.biz/pdfs/OVM_wiringdiagram.pdf > The B&C schematic shows the black wire of the O.V. module connected to ground. They just happened to use the same ground that the master switch is connected to. You can connect the black wire to any convenient ground. > I think that B&C drew the schematic that way for two reasons: 1. It is easy to draw. 2. It is easy to wire directly at the master switch because both ground and the alternator field circuit are available there (if your master switch is wired like B&C's switch is wired). > As for the colored wire (orange?) of the O.V., B&C shows it connected to the alternator-field half of the master switch. Electrically speaking, this is the same as connecting to the voltage regulator input. In either case, power is coming from the 5 amp breaker. > Now if you want to connect the O.V. module directly to the 5 amp breaker, I see no reason why that will not work. I hope others will correct me if wrong. Just make sure that it is connected to the down stream side and not the always hot side of the breaker. > In summary, connect the O.V. black wire to ground. And connect the other wire to some point between the 5 amp breaker and the input to the voltage regulator. > Joe > > -------- > Joe Gores > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=427062#427062 > > > > > > > > > > ________________________________________________________________________________
Subject: Transmitting with no antenna?
Date: Jul 21, 2014
I'm working on an audio panel/radio problem and I was told that pressing the PTT (transmitting) without an antenna will fry the radio. [Embarassed] Is this correct or is it an OWT? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427077#427077 ________________________________________________________________________________
Subject: Z13 fusible link, circuit breaker, same circuit?
Date: Jul 21, 2014
Something puzzles me . . . Drawing Z-13/8 rev T dated 1/17/2014 shows both a 22AWG fusible link and a 5A circuit breaker between the main bus and terminal 5 of the Bat/Alt DC Po wer switch. When the Bat/Alt DC Power switch is closed and the alternator i s making power, the 5A circuit breaker will open if the crowbar over voltag e protection module connected to terminal 4 of the Bat/Alt DC Power switch, senses an over voltage condition and grounds the circuit. This functionali ty I understand. The wire between the fusible link and the circuit breaker is called out as 18AWG, thus the four size smaller 22AWG fusible link makes sense to me. Thr ee questions: 1. What is the function of the 22AWG fusible link in this circuit? 2. Shouldn't the wire from the 5A circuit breaker to the Bat/Alt DC Pow er switch and the wire from the Bat/Alt DC Power switch terminal 4 to the v oltage regulator terminal A also be 18AWG? 3. Alternatively, assuming the 20AWG wire is sufficient to carry the lo ad, shouldn't all wires in this circuit be 20AWG and the fusible link be 16 AWG, i.e. 4 sizes smaller? Thanks in advance for unpuzzling me. ________________________________________________________________________________
Date: Jul 21, 2014
Subject: Re: Transmitting with no antenna?
It's not a good idea; transmitting into an open circuit can damage that final power amplifier stage as the signal is reflected back into it. But most radios built in the past 20-30 years will have built-in foldback protection to detect this condition and dial the power back to avoid damage. Henry On Mon, Jul 21, 2014 at 1:27 PM, donjohnston <don@velocity-xl.com> wrote: > > I'm working on an audio panel/radio problem and I was told that pressing the PTT (transmitting) without an antenna will fry the radio. [Embarassed] > > Is this correct or is it an OWT? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=427077#427077 > > ________________________________________________________________________________
Subject: Re: Z13 fusible link, circuit breaker, same circuit?
Date: Jul 21, 2014
Just to clarify: Question 3 : four sizes smaller than 20awg, is 24awg, not 16 John Sent from my iPad ----x--O--x---- > On 21 Jul 2014, at 09:55 pm, "Bower, Bob" wrote: > > Something puzzles me . . . > > Drawing Z-13/8 rev T dated 1/17/2014 shows both a 22AWG fusible link and a 5A circuit breaker between the main bus and terminal 5 of the Bat/Alt DC Po wer switch. When the Bat/Alt DC Power switch is closed and the alternator is making power, the 5A circuit breaker will open if the crowbar over voltage p rotection module connected to terminal 4 of the Bat/Alt DC Power switch, sen ses an over voltage condition and grounds the circuit. This functionality I u nderstand. > > The wire between the fusible link and the circuit breaker is called out as 18AWG, thus the four size smaller 22AWG fusible link makes sense to me. Thr ee questions: > > 1. What is the function of the 22AWG fusible link in this circuit? > 2. Shouldn=99t the wire from the 5A circuit breaker to the Bat/A lt DC Power switch and the wire from the Bat/Alt DC Power switch terminal 4 t o the voltage regulator terminal A also be 18AWG? > 3. Alternatively, assuming the 20AWG wire is sufficient to carry the l oad, shouldn=99t all wires in this circuit be 20AWG and the fusible li nk be 16AWG, i.e. 4 sizes smaller? > > Thanks in advance for unpuzzling me. > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Jul 21, 2014
henry(at)pericynthion.org wrote: > It's not a good idea; transmitting into an open circuit can damage > that final power amplifier stage as the signal is reflected back into > it. But most radios built in the past 20-30 years will have built-in > foldback protection to detect this condition and dial the power back > to avoid damage. > > Henry > > On Mon, Jul 21, 2014 at 1:27 PM, donjohnston wrote: > Thanks! What should I do to prevent any potential problem? Would a 50 ohm terminating resistor be a good idea? I'm not going to be able to connect the antennas for a while and I'd like to not have to worry about any problems. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427085#427085 ________________________________________________________________________________
Date: Jul 21, 2014
Is it an OWT (old wives tale): I don't know but where are those 'ouput watts' going, if you don't have an aerial connected John Sent from my iPad ----x--O--x---- > On 21 Jul 2014, at 09:27 pm, "donjohnston" <don@velocity-xl.com> wrote: > > > I'm working on an audio panel/radio problem and I was told that pressing the PTT (transmitting) without an antenna will fry the radio. [Embarassed] > > Is this correct or is it an OWT? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=427077#427077 > > > > > > > > > > ________________________________________________________________________________
Date: Jul 21, 2014
TXkgbWlzdGFrZSwgeW91IGFyZSBvZiBjb3Vyc2UsIGNvcnJlY3QuDQoNCkZyb206IG93bmVyLWFl cm9lbGVjdHJpYy1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tIFttYWlsdG86b3duZXItYWVyb2Vs ZWN0cmljLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb21dIE9uIEJlaGFsZiBPZiBKb2huIFRpcHRv bg0KU2VudDogTW9uZGF5LCBKdWx5IDIxLCAyMDE0IDI6NDggUE0NClRvOiBhZXJvZWxlY3RyaWMt bGlzdEBtYXRyb25pY3MuY29tDQpTdWJqZWN0OiBSZTogQWVyb0VsZWN0cmljLUxpc3Q6IFoxMyBm dXNpYmxlIGxpbmssIGNpcmN1aXQgYnJlYWtlciwgc2FtZSBjaXJjdWl0Pw0KDQpKdXN0IHRvIGNs YXJpZnk6DQoNClF1ZXN0aW9uIDMgOiBmb3VyIHNpemVzIHNtYWxsZXIgdGhhbiAyMGF3ZywgaXMg MjRhd2csIG5vdCAxNg0KDQpKb2huDQoNClNlbnQgZnJvbSBteSBpUGFkDQoNCiAgICAgLS0tLXgt LU8tLXgtLS0tDQoNCk9uIDIxIEp1bCAyMDE0LCBhdCAwOTo1NSBwbSwgIkJvd2VyLCBCb2IiIDxC b2IuQm93ZXJAaGRyaW5jLmNvbTxtYWlsdG86Qm9iLkJvd2VyQGhkcmluYy5jb20+PiB3cm90ZToN ClNvbWV0aGluZyBwdXp6bGVzIG1lIC4gLiAuDQoNCkRyYXdpbmcgWi0xMy84IHJldiBUIGRhdGVk IDEvMTcvMjAxNCBzaG93cyBib3RoIGEgMjJBV0cgZnVzaWJsZSBsaW5rIGFuZCBhIDVBIGNpcmN1 aXQgYnJlYWtlciBiZXR3ZWVuIHRoZSBtYWluIGJ1cyBhbmQgdGVybWluYWwgNSBvZiB0aGUgQmF0 L0FsdCBEQyBQb3dlciBzd2l0Y2guIFdoZW4gdGhlIEJhdC9BbHQgREMgUG93ZXIgc3dpdGNoIGlz IGNsb3NlZCBhbmQgdGhlIGFsdGVybmF0b3IgaXMgbWFraW5nIHBvd2VyLCB0aGUgNUEgY2lyY3Vp dCBicmVha2VyIHdpbGwgb3BlbiBpZiB0aGUgY3Jvd2JhciBvdmVyIHZvbHRhZ2UgcHJvdGVjdGlv biBtb2R1bGUgY29ubmVjdGVkIHRvIHRlcm1pbmFsIDQgb2YgdGhlIEJhdC9BbHQgREMgUG93ZXIg c3dpdGNoLCBzZW5zZXMgYW4gb3ZlciB2b2x0YWdlIGNvbmRpdGlvbiBhbmQgZ3JvdW5kcyB0aGUg Y2lyY3VpdC4gVGhpcyBmdW5jdGlvbmFsaXR5IEkgdW5kZXJzdGFuZC4NCg0KVGhlIHdpcmUgYmV0 d2VlbiB0aGUgZnVzaWJsZSBsaW5rIGFuZCB0aGUgY2lyY3VpdCBicmVha2VyIGlzIGNhbGxlZCBv dXQgYXMgMThBV0csIHRodXMgdGhlIGZvdXIgc2l6ZSBzbWFsbGVyIDIyQVdHIGZ1c2libGUgbGlu ayBtYWtlcyBzZW5zZSB0byBtZS4gVGhyZWUgcXVlc3Rpb25zOg0KDQoNCjEuICAgICAgIFdoYXQg aXMgdGhlIGZ1bmN0aW9uIG9mIHRoZSAyMkFXRyBmdXNpYmxlIGxpbmsgaW4gdGhpcyBjaXJjdWl0 Pw0KDQoyLiAgICAgICBTaG91bGRu4oCZdCB0aGUgd2lyZSBmcm9tIHRoZSA1QSBjaXJjdWl0IGJy ZWFrZXIgdG8gdGhlIEJhdC9BbHQgREMgUG93ZXIgc3dpdGNoIGFuZCB0aGUgd2lyZSBmcm9tIHRo ZSBCYXQvQWx0IERDIFBvd2VyIHN3aXRjaCB0ZXJtaW5hbCA0IHRvIHRoZSB2b2x0YWdlIHJlZ3Vs YXRvciB0ZXJtaW5hbCBBIGFsc28gYmUgMThBV0c/DQoNCjMuICAgICAgIEFsdGVybmF0aXZlbHks IGFzc3VtaW5nIHRoZSAyMEFXRyB3aXJlIGlzIHN1ZmZpY2llbnQgdG8gY2FycnkgdGhlIGxvYWQs IHNob3VsZG7igJl0IGFsbCB3aXJlcyBpbiB0aGlzIGNpcmN1aXQgYmUgMjBBV0cgYW5kIHRoZSBm dXNpYmxlIGxpbmsgYmUgMTZBV0csIGkuZS4gNCBzaXplcyBzbWFsbGVyPw0KDQpUaGFua3MgaW4g YWR2YW5jZSBmb3IgdW5wdXp6bGluZyBtZS4NCg0KDQoNCg0KDQpEPTNEPTNEPTNEPTNEPTNEPTNE PTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNE PTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNE PTNEDQoNCmxlY3RyaWMtTGlzdCIiPmh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/ QWVyb0VsZWN0cmljLUxpc3QNCg0KRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0z RD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0z RD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRA0KDQovL2ZvcnVtcy5t YXRyb25pY3MuY29tDQoNCkQ9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9 M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9 M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0QNCg0Kb3Q7Ij5odHRwOi8vd3d3 Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uDQoNCkQ9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9 M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9 M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0QNCg0K DQoNCg0KDQoNCg0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT0NCg0KXy09ICAgICAgICAgIC0gVGhlIEFlcm9FbGVjdHJpYy1MaXN0 IEVtYWlsIEZvcnVtIC0NCg0KXy09IFVzZSB0aGUgTWF0cm9uaWNzIExpc3QgRmVhdHVyZXMgTmF2 aWdhdG9yIHRvIGJyb3dzZQ0KDQpfLT0gdGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMgc3VjaCBhcyBM aXN0IFVuL1N1YnNjcmlwdGlvbiwNCg0KXy09IEFyY2hpdmUgU2VhcmNoICYgRG93bmxvYWQsIDct RGF5IEJyb3dzZSwgQ2hhdCwgRkFRLA0KDQpfLT0gUGhvdG9zaGFyZSwgYW5kIG11Y2ggbXVjaCBt b3JlOg0KDQpfLT0NCg0KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0 b3I/QWVyb0VsZWN0cmljLUxpc3QNCg0KXy09DQoNCl8tPT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQoNCl8tPSAgICAgICAgICAgICAg IC0gTUFUUk9OSUNTIFdFQiBGT1JVTVMgLQ0KDQpfLT0gU2FtZSBncmVhdCBjb250ZW50IGFsc28g YXZhaWxhYmxlIHZpYSB0aGUgV2ViIEZvcnVtcyENCg0KXy09DQoNCl8tPSAgIC0tPiBodHRwOi8v Zm9ydW1zLm1hdHJvbmljcy5jb20NCg0KXy09DQoNCl8tPT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQoNCl8tPSAgICAgICAgICAgICAt IExpc3QgQ29udHJpYnV0aW9uIFdlYiBTaXRlIC0NCg0KXy09ICBUaGFuayB5b3UgZm9yIHlvdXIg Z2VuZXJvdXMgc3VwcG9ydCENCg0KXy09ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgLU1h dHQgRHJhbGxlLCBMaXN0IEFkbWluLg0KDQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3Mu Y29tL2NvbnRyaWJ1dGlvbg0KDQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PQ0KDQoNCg= ________________________________________________________________________________
Date: Jul 21, 2014
It depends on the radio design. The problem is that the radio is meant to have an antenna connected to it that is designed to operate on the frequency the transmitter is transmitting at. When that doesn't happen all the power that the transmitter is producing is "reflected" back into the transmitter. That can fry things. Most well designed modern transmitters have protection circuits that reduce the transmitter power or disable the transmitter when it detects that condition. It's still a bad idea to transmit with no antenna (or the wrong antenna) connected. This goes for Comm radios, Transponders, Radio Altimeters, TCAS boxes... Bill On 7/21/14, 1:27 PM, donjohnston wrote: > > I'm working on an audio panel/radio problem and I was told that pressing the PTT (transmitting) without an antenna will fry the radio. [Embarassed] > > Is this correct or is it an OWT? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=427077#427077 > > ________________________________________________________________________________
Date: Jul 21, 2014
Most 50 Ohm terminating resistors are rated for a half watt or less. Most Comm radios put out 5 watts or more. The terminating resistor won't last long. 1) Keep the radio turned off when you're working on things. 2) Disconnect the PTT wire from the radio connector if that's feasible. Termination resistors are made to keep a constant impedance connection on something like a spare antenna diplexer port, not dissipate the power from a transmitter. You can get 50 dummy loads that are designed to be transmitted into all day long. They're a lot more expensive than a terminator and much bulkier. Even a dummy load will only operate at it's rated power for a limited time. Make sure you look at all the specs for what you buy. Most of the time you're going to be transmitting without you knowing it because a wiring short or sitting on the mic (or something like that). You're likely to be transmitting for a long time or until the stuck mic circuit in the transmitter shuts it down. Bill On 7/21/14, 2:50 PM, donjohnston wrote: > > > henry(at)pericynthion.org wrote: >> It's not a good idea; transmitting into an open circuit can damage >> that final power amplifier stage as the signal is reflected back into >> it. But most radios built in the past 20-30 years will have built-in >> foldback protection to detect this condition and dial the power back >> to avoid damage. >> >> Henry >> >> On Mon, Jul 21, 2014 at 1:27 PM, donjohnston wrote: >> > > > Thanks! > > What should I do to prevent any potential problem? Would a 50 ohm terminating resistor be a good idea? I'm not going to be able to connect the antennas for a while and I'd like to not have to worry about any problems. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=427085#427085 > > ________________________________________________________________________________
From: John MacCallum <john.maccallum(at)bigpond.com>
Date: Jul 22, 2014
As per some other post in reply yes it can lead to damage to the output stage of the connected radio. The high SWR presented to the Output side by no Antenna or the wrong antenna causes significant heating to the output transistors and can cause their internal junctions to fail. You can go to your local Ham Radio shop and purchase a small 50 Ohm dummy load for a few dollars to protect the connected radios or indeed test the Radios without an antenna. You will need a VHF, 50 Ohm Dummy Load Capable of handling 25 watts (less if you keep the transmissions short say 4-5 seconds). Cheers John MacCallum VH-DUU RV10 41016 -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of donjohnston Sent: Tuesday, 22 July 2014 6:28 AM Subject: AeroElectric-List: Transmitting with no antenna? --> <don@velocity-xl.com> I'm working on an audio panel/radio problem and I was told that pressing the PTT (transmitting) without an antenna will fry the radio. [Embarassed] Is this correct or is it an OWT? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427077#427077 ________________________________________________________________________________
Date: Jul 21, 2014
Alternatively, you could build this dummy load: http://bit.ly/1wSMtI1 ...using 20 of these (buy 25 for the price break): http://bit.ly/1lnVgfM Note: Do *not* substitute wire-wound resistors! Eric > On Jul 21, 2014, at 5:22 PM, John MacCallum wrote: > > You can go to your local Ham Radio shop and purchase a small 50 Ohm dummy load for a few dollars to protect the connected radios or indeed test the Radios without an antenna. You will need a VHF, 50 Ohm Dummy Load Capable of handling 25 watts (less if you keep the transmissions short say 4-5 seconds). > > Cheers > John MacCallum > VH-DUU > RV10 41016 > > > I'm working on an audio panel/radio problem and I was told that pressing the > PTT (transmitting) without an antenna will fry the radio. [Embarassed] > > Is this correct or is it an OWT? ________________________________________________________________________________
Date: Jul 21, 2014
At 12:27 PM 7/21/2014, you wrote: The regulator is the solid-state supplied from InterAv as a kit to work with the Motorola Alternator i'm using the schematic of the interAv system and hooking up the OVM from the B&C system if I can hook to the field on the InterAv system then all my troubles are over that's what I wanted to do Very good. the mention of the 5 amp not kicking the regulator in just disregard ! that was a whole Nother scenario! do you still recommend me to change to a voltage limiter on the firewall as suggested before? if not I'm done ,I have it accomplished! Thank you again!! If you have a 60A breaker already installed and wired, leave it. Pleased to have a clearer picture of what you were wrestling with. Bob . . . ________________________________________________________________________________
Date: Jul 21, 2014
At 03:27 PM 7/21/2014, you wrote: I'm working on an audio panel/radio problem and I was told that pressing the PTT (transmitting) without an antenna will fry the radio. [Embarassed] Is this correct or is it an OWT? I wouldn't make a habit of it . . . there's no good reason to do it. If you need to listen to your transmitted signal without radiating it more than a few dozen yards, build yourself a dummy load to put on the transmitter's coax connector. http://tinyurl.com/cchp3pf This load is good for 2W continuous and will handle 10W transmitters for the few seconds necessary to make a vocal test transmission to deduce audio quality. If you need a bigger load, it too can be fabricated from R-S parts. But the caveat about keying a transmitter into an open antenna jack is a carry-over from the state of solid state radios of the 60-70's. It didn't take the industry long to figure out ways to build protections into their products . . . so keying an unloaded transmitter no longer represents a serious hazard. Bob . . . ________________________________________________________________________________
Subject: Alternator and Battery ON & OFF
Date: Jul 22, 2014
7/22/2014 Hello Joe (Unknown) and Bob Nuckolls, The B&C wiring diagram accessed by the link given below by Joe has this warning: =9CImportant =93 Battery contactor and alternator should come on and off together.=9D Can someone please explain to me why that is important? What bad things will happen if they don=99t come on and off together? Thank you, OC 'O C' Baker says "The best investment you can make is the effort to gather and understand information." PS: My procedure: On start up, Turn the alternator ON after engine is running. On shut down, Turn the alternator OFF while engine is still running to get a flashing low voltage light to confirm that my low voltage warning system is working. I have entirely separate Battery (battery contactor) and Alternator switches. =========== Subject: AeroElectric-List: Re: Are 'serial' contactors really needed? From: "user9253" <fransew(at)gmail.com> > it says to hook the ovm to regulator in & to the master switch No it doesn't. B&C schematic link: http://www.bandc.biz/pdfs/OVM_wiringdiagram.pdf The B&C schematic shows the black wire of the O.V. module connected to ground. They just happened to use the same ground that the master switch is connected to. You can connect the black wire to any convenient ground. I think that B&C drew the schematic that way for two reasons: 1. It is easy to draw. 2. It is easy to wire directly at the master switch because both ground and the alternator field circuit are available there (if your master switch is wired like B&C's switch is wired). As for the colored wire (orange?) of the O.V., B&C shows it connected to the alternator-field half of the master switch. Electrically speaking, this is the same as connecting to the voltage regulator input. In either case, power is coming from the 5 amp breaker. Now if you want to connect the O.V. module directly to the 5 amp breaker, I see no reason why that will not work. I hope others will correct me if wrong. Just make sure that it is connected to the down stream side and not the always hot side of the breaker. In summary, connect the O.V. black wire to ground. And connect the other wire to some point between the 5 amp breaker and the input to the voltage regulator. Joe ________________________________________________________________________________
Date: Jul 22, 2014
Subject: Re: Alternator and Battery ON & OFF
At 07:45 AM 7/22/2014, you wrote: 7/22/2014 Hello Joe (Unknown) and Bob Nuckolls, The B&C wiring diagram accessed by the link given below by Joe has this warning: "Important Battery contactor and alternator should ccome on and off together." Can someone please explain to me why that is important? What bad things will happen if they don't come on and off together? Hmmmm . . . hadn't noticed that. It's a not-so-accurate acknowledgement of the history of alternators in airplanes. When our vehicles with big fans and wings carried generators, there were two relatively independent sources of power. A battery and a generator. Generators were by nature self-exciting (after the field was 'flashed') and output from the machine was relatively smooth. Ship's electro-whizzies would run well on battery, generator or both. When we pressed the Ford alternators into service on airplanes in the 60's, two noteworthy differences in the alternator's characteristics took center stage. Alternators were reluctant to self-excite; you couldn't simply turn a spinning alternator ON and expect it to come on line. Further, voltage regulation dynamics for alternators was a fledgling technology . . . having a battery on line aided in the task stabilizing bus voltage and the battery prevented the alternator from suffering a stalling event should it be hit with a large inrush like klieg-lights on the wings or an electro-hydraulic landing gear system. It was clear that the legacy separation of BATTERY and GENERATOR switches was fraught with some risk for confusing pilots familiar with how the electrical system worked in the older airplanes. What's an itty-bitty airplane factory to do? The airplanes at Cessna were already being fitted with the stylish rocker switches from Carling. The pilots, engineers and switch-guys put their heads together and the split-rocker DC MASTER switch was birthed. Mechanical linkage between the rockers allowed you to operate battery-only but that the alternator could not be on without having the battery on also. EARLY in the history of AeroElectric Connection architectures, the split-rocker was replaced with a two-pole, ON-OFF switch to operated battery and alternator together. The crowbar OVM called for use of a field supply breaker . . . which could be pulled for battery-only operations either airborne or ground test. Later, I discovered the Carling catalog and sources for the three position 2-10 switch that would emulate the split-rocker functionality . . . http://tinyurl.com/q9pbjks Over the years, the simple DPDT+breaker configuration was replaced with the DP3T, ON-ON-ON (2-10) switch. Now that you have the history, I can explain that the admonition on the B&C drawing is an artifact of the "days before 2-10 switches" and was further mis-interpreted as an imperative . . . don't recall now who wrote those words but they are in error. Now that you have the "Rest of the Story" you are free to select from the whole array of available switches including (1) simple, DPDT+breaker (2) DP3T ON-ON-ON, or (3) a living artifact of the early days of alternators in light aircraft, the split rocker switch. Bob . . . ________________________________________________________________________________
Date: Jul 22, 2014
> Important Battery contactor and alternator should come on and off together. > Can someone please explain to me why that is important? What bad things will happen if they dont come on and off together? I think that it is good operating practice to turn the master contactor and alternator on and off simultaneously. But I do not think that bad things will happen if not operated that way. TC aircraft have a split master switch and the Z figures have a progressive transfer master switch that allows the alternator to be shut off. Most pilots expect the the master switch will shut off every single electrical circuit on the airplane. If the master contactor and alternator are controlled by separate switches and if only the contactor is shut off, then it is possible (or even likely, depending on the alternator) for the alternator to keep supplying power to the aircraft. This is not necessarily a bad thing, but could be if the pilot does not understand how the aircraft is wired. Another consideration is flying with the master contactor on and the alternator off. The battery will not be recharged. If the alternator is then turned on, could there be a voltage surge? I do not know. Maybe Bob N will answer that. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427139#427139 ________________________________________________________________________________
Date: Jul 22, 2014
At 08:43 PM 7/21/20, you wrote: > > > At 03:27 PM 7/21/2014, you wrote: > >I'm working on an audio panel/radio problem and I was told that >pressing the PTT (transmitting) without an antenna will fry the >radio. [Embarassed] > >Is this correct or is it an OWT? After crafting my reply last night I was curious as to modern approaches to crafting SWR ruggedness into a VHF transmitter. The last time I dug through the innards of a solid state vhf transmitter, the output stage was crafted from NPN silicon junction transistors . . . about 4 of them in push-pull for 100W of output at 145MHz. The antenna matching network was fitted with a directional coupler (SWR meter) that sampled reverse-voltage as a product of high SWR . . . that voltage was used to reduce drive to the output stage for the purpose of protecting the transistors should the transmitter be presented with a high swr. Works good, lasts a long time. Just for grins, I got a copy of the KX165 transceiver service manual to bone up on contemporary design philosophies. Got an interesting surprise. Here is an excerpt from the transmitter schematic . . . Yup . . . there it is . . . the expected directional coupler. But when I read the accompanying text, I was informed that the directional coupler output was used to sample FORWARD power for the purpose of leveling the transmitter's output power. No mention was made for 'high SWR protection' . . . In fact, a search of the entire service manual for "standing" or "SWR" produced no hits. Say what???? Emacs! Here are some excerpts from the manufacturer's data sheets on the KX165 powuer output transistor. Emacs! This is a MOSFET rated at 80W of output in VHF operation. Further we read the following . . . Emacs! Down in the tabulation of characteristics we also find . . . Emacs! I was pleased to find that my original assertion was correct but for the wrong reasons. It seems the MOSFET is immune to damage from the stresses that would have shot its ancestors out of the saddle. Hence no wrap-around protection was needed. The directional coupler was still there but pressed into service other than output stage protection. Another interesting feature from the schematic excerpt: Notice the "stub" depiction on the antenna output line. A search of the manual doesn't speak to its existence or purpose. Given that this is a deign from the hallowed halls of the Nav/Comm gods, I suspect that 'stub' is an shunt filter element tuned to reject transmitter harmonics that fall on or close to GPS frequencies. Garmin used to offer a 330-00067-00 Notch Filter intended to be 'scabbed on' to the nav/comm antenna connector. Emacs! Bob . . . ________________________________________________________________________________
Date: Jul 22, 2014
> What is the function of the 22AWG fusible link in this circuit? The wire (if very long) between the main power bus and the circuit breaker needs to be protected against short circuits. A fusible link provides this protection. The circuit breaker does not offer protection because short circuit current in this wire will not pass through the circuit breaker. A fuse can not be used because, in case of over voltage, a fuse will blow before the circuit breaker trips. > Shouldn't the wire from the 5A circuit breaker to the Bat/Alt DC Power switch and the wire from the Bat/Alt DC Power switch terminal 4 to the voltage regulator terminal A also be 18AWG? No, heavier wire is not needed because O.V. module current does not flow through the 20 AWG wire. > shouldn't all wires in this circuit be 20AWG and the fusible link be 16 AWG, i.e. 4 sizes smaller? If the fusible link is made from smaller wire, then it might burn open before the 5 amp breaker trips. So leave it at 22 AWG. The wire attached to the fusible link must be 4 sizes bigger, thus 18 AWG. 20 AWG is adequate downstream from the circuit breaker because it is protected by the circuit breaker. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427156#427156 ________________________________________________________________________________
Date: Jul 22, 2014
Most of the split alt/bat switches that I have experience with allow the battery to be on without the alternator but not the alternator on without the battery. The function is an internal mechanical function in the switch itself. I like to call it army proof. On Jul 22, 2014, at 7:09, "user9253" wrote: > > >> Important Battery contactor and alternator should come on and off together. >> Can someone please explain to me why that is important? What bad things will happen if they dont come on and off together? > > I think that it is good operating practice to turn the master contactor and alternator on and off simultaneously. But I do not think that bad things will happen if not operated that way. TC aircraft have a split master switch and the Z figures have a progressive transfer master switch that allows the alternator to be shut off. > Most pilots expect the the master switch will shut off every single electrical circuit on the airplane. If the master contactor and alternator are controlled by separate switches and if only the contactor is shut off, then it is possible (or even likely, depending on the alternator) for the alternator to keep supplying power to the aircraft. This is not necessarily a bad thing, but could be if the pilot does not understand how the aircraft is wired. > Another consideration is flying with the master contactor on and the alternator off. The battery will not be recharged. If the alternator is then turned on, could there be a voltage surge? I do not know. Maybe Bob N will answer that. > > -------- > Joe Gores > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=427139#427139 > > > > > > > > > > ________________________________________________________________________________
Date: Jul 22, 2014
nuckolls.bob(at)aeroelect wrote: > At 03:27 PM 7/21/2014, you wrote: > > > I'm working on an audio panel/radio problem and I was told that > pressing the PTT (transmitting) without an antenna will fry the > radio. [Embarassed] > > Is this correct or is it an OWT? > > > I wouldn't make a habit of it . . . there's no > good reason to do it. If you need to listen to > your transmitted signal without radiating it more > than a few dozen yards, build yourself a dummy > load to put on the transmitter's coax connector. > > http://tinyurl.com/cchp3pf > > This load is good for 2W continuous and will handle > 10W transmitters for the few seconds necessary to make > a vocal test transmission to deduce audio quality. > If you need a bigger load, it too can be fabricated > from R-S parts. > > But the caveat about keying a transmitter into > an open antenna jack is a carry-over from the state > of solid state radios of the 60-70's. It didn't > take the industry long to figure out ways to build > protections into their products . . . so keying > an unloaded transmitter no longer represents > a serious hazard. > > > Bob . . . Using the logic of "if some is good, more must be better", I picked up some 10w, 100ohm resistors. :) Checked with the manufacture (Val) and they said that I'm probably okay: > In regards to circuit protection, the COM 2KR doesn't have any active protection against keying the unit without a proper load attached. As such, you run a small risk of damaging your radios keying them up without an antenna. However, the radios are resistant to damage from being keyed without an antenna and should be fine. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427184#427184 ________________________________________________________________________________
Date: Jul 22, 2014
Don, Just be sure the resistors you sourced are not wire-wound types. At a 10W rating, most are. These are inductive and will make a very poor dummy load. Examples to avoid: http://bit.ly/1A3zd7U -or- http://bit.ly/1rImumj Bob's 2W-10W dummy load appears to be built with Metal Film or Metal Oxide resistors. Eric > On Jul 22, 2014, at 7:42 PM, "donjohnston" <don@velocity-xl.com> wrote: > > Using the logic of "if some is good, more must be better", I picked up some 10w, 100ohm resistors. :) ________________________________________________________________________________
Date: Jul 23, 2014
edpav8r(at)yahoo.com wrote: > Don, > > Just be sure the resistors you sourced are not wire-wound types. At a 10W rating, most are. These are inductive and will make a very poor dummy load. > > Examples to avoid: http://bit.ly/1A3zd7U -or- http://bit.ly/1rImumj > > Bob's 2W-10W dummy load appears to be built with Metal Film or Metal Oxide resistors. > > Eric > > > > > On Jul 22, 2014, at 7:42 PM, "donjohnston" wrote: > > > > Using the logic of "if some is good, more must be better", I picked up some 10w, 100ohm resistors. :) > > > > > Yep... They're wire wound. I can't get anything right lately. :( Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427203#427203 ________________________________________________________________________________
Date: Jul 23, 2014
>Yep... They're wire wound. > >I can't get anything right lately. :( I was skeptical and disappointed when your conversation with VAL suggested that 'your were probably going to be okay' with the 10W resistors. It would have been nice if the design I posted was a little beefier . . . but getting resistors with low inductance at VHF frequencies isn't a trivial task. The venerable carbon composition resistor popular to this legacy DIY task are not easy to find and not cheap when you do find them. The 2W design proved to be the best I could do with limited resources . . . although suited to the task as long as you don't get into long-winded test transmissions. As I recall, I produced that suggestion as a test tool for proving that some appliance sensitivity to transmitters was a function of energy radiated from the antenna. Short transmissions would suffice. If you want to acquire a more robust load, finding suitable resistors then stacking fab-time on top of the project is problematic. Suggest you consider commercial-off-the-shelf products like this: http://tinyurl.com/k5w4vth You'll need and adapter to attach this N-connector load to your BNC-connector transceiver http://tinyurl.com/mxjgusn Hard to beat for price but it does take a bit of time to ship them over the big pond. Bob . . . ________________________________________________________________________________
Date: Jul 23, 2014
At 08:07 PM 7/21/2014, you wrote: Alternatively, you could build this dummy load: http://bit.ly/1wSMtI1 ...using 20 of these (buy 25 for the price break): http://bit.ly/1lnVgfM Note: Do *not* substitute wire-wound resistors! Eric This is a time-honored and relatively easy methodology for crafting a low SWR dummy load. Built one of these when I was in high-school . . . my can was salvaged from some painting project around the house and I used Havoline motor oil . . . but as you can see, the time to fabricate this thing is not trivial. Be sure to store this thing rihgt-side-up . . . if it lays over then atmospheric breathing will push oil past connectors that are not liquid tight. The commercial-off-the shelf alternative may prove more attractive. Bob . . . ________________________________________________________________________________
Date: Jul 23, 2014
nuckolls.bob(at)aeroelect wrote: > > I was skeptical and disappointed when your conversation > with VAL suggested that 'your were probably going to be > okay' with the 10W resistors. > > It would have been nice if the design I posted was > a little beefier . . . but getting resistors > with low inductance at VHF frequencies isn't a trivial > task. The venerable carbon composition resistor popular > to this legacy DIY task are not easy to find and not cheap > when you do find them. The 2W design proved to be the > best I could do with limited resources . . . although > suited to the task as long as you don't get into long-winded > test transmissions. As I recall, I produced that suggestion > as a test tool for proving that some appliance sensitivity > to transmitters was a function of energy radiated from > the antenna. Short transmissions would suffice. Uh... Val didn't say I would be fine with 10W resistors. They said that the radios should be fine. > In regards to circuit protection, the COM 2KR doesn't have any active protection against keying the unit without a proper load attached. As such, you run a small risk of damaging your radios keying them up without an antenna. However, the radios are resistant to damage from being keyed without an antenna and should be fine. I'm going to redo with the proper resistors. I'm only tracking down an audio panel switching issue. As such, I'm only keying the mic long enough to see if I get a transmit indicator on the display. So about a half second whenever I hit the PTT. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427227#427227 ________________________________________________________________________________
Date: Jul 23, 2014
Subject: one-wire alternators- the subject that just won't die
Hi Bob, Please forgive me, but I need a refresher on why one-wire (internally regulated) alternators are no longer recommended for a/c; even banned from 'the Book'. I do remember (scratch that; know from experience) that if the B-lead contactor opens while the alternator is under load, there can be a 'load dump' (high voltage spike) issue that can kill the electronics (the regulator) in the alternator. Makes sense. But if the only way the B-lead contactor is allowed to open is due to an overvoltage fault, does it matter? At that point, it's a given that the regulator is already toast, and the entire alternator will be swapped out to fix it. Given the very high reliability of modern automotive alternators, and that the only time the B-lead contactor would need to open under load is during a true OV fault event, what's the compelling reason to keep the 'not recommended' philosophy? I've had a couple of different career paths involving running a soldering iron & modifying stuff (both consumer and industrial electronics maintenance), so I'm not 'afraid' to dig into an alternator to modify it for external regulation. But I'm of the 'if it ain't broke, don't fix it' school. I'd like to be educated on what I'm overlooking in terms of risk, failure modes (fire?), etc. If it's reasonable to bring the one-wire alternator (with contactor style OV protection)back into the mix, the next question will be about integrating a backup dynamo style alternator without spending close to half an Aviation Unit for the hardware. :-) Many thanks, Charle ________________________________________________________________________________
Date: Jul 23, 2014
>Indeed. I always seem to forget that you can buy virtually anything >cheaply on eBay! For $19, the economics of building one yourself, >in $ and time, make little sense. But we won't talk about the things we do, buy, read or just dream about . . . 'cause it's FUN! It's probably cheaper than a gambling habit . . . Bob . . . ________________________________________________________________________________
Date: Jul 24, 2014
Subject: Re: one-wire alternators- the subject that just won't
die At 02:58 PM 7/23/2014, you wrote: Hi Bob, Please forgive me, but I need a refresher on why one-wire (internally regulated) alternators are no longer recommended for a/c; even banned from 'the Book'. I've never 'banned' anything from the book. But in the interest of brevity and shortest path to demonstrated success at low risk levels, I have focused AeroElectric efforts on a limited range of ideas and products that embrace the best-we-know-how-to-do . . . Far too many over-excited people have morphed my recommendations into warnings: "DON'T DO THAT lest you fall out of the sky an die!" I have never worked on or read about an accident that had root cause in failure of electrical parts to perform as advertised . . . EVERY case I'm aware of had roots in human failings to understand limits imposed by poor craftsmanship or operation of those parts. I do remember (scratch that; know from experience) that if the B-lead contactor opens while the alternator is under load, there can be a 'load dump' (high voltage spike) issue that can kill the electronics (the regulator) in the alternator. Makes sense. Only on certain alternators that fall short of the- best-we-know-how-to-do. Consider this excerpt from the chapter 3 of the 'Connection http://tinyurl.com/nchenmr [] But if the only way the B-lead contactor is allowed to open is due to an overvoltage fault, does it matter? =C2 At that point, it's a given that the regulator is already toast, and the entire alternator will be swapped out to fix it. Given the very high reliability of modern automotive alternators, and that the only time the B-lead contactor would need to open under load is during a true OV fault event, what's the compelling reason to keep the 'not recommended' philosophy? Not a 'big deal' as you have deduced. The 'problem' is rooted in legacy cockpit protocols that do not prohibit turning off a loaded alternator. You can do it in any TC aircraft without risk of damage. You can do it in any aircraft fitted with an alternator of the quality cited in the narrative about MPA. But unlike the cookie-cutter conformity control offered by the TC aircraft world, we have no way to KNOW what quality of alternator was being offered by Van's . . . it seems that one or more of his customers experienced a untimely demise of his alternator by switching it on and off with the b-lead contactor. I've had a couple of different career paths involving running a soldering iron & modifying stuff (both consumer and industrial electronics maintenance), so I'm not 'afraid' to dig into an alternator to modify it for external regulation. But I'm of the 'if it ain't broke, don't fix it' school. By all means, dig in. Photograph every step. Show us what you found and how you dealt with it . . . you're not 'fixing' it, you're adapting it to higher design goals. I'd like to be educated on what I'm overlooking in terms of risk, failure modes (fire?), etc. If it's reasonable to bring the one-wire alternator (with contactor style OV protection)back into the mix, the next question will be about integrating a backup dynamo style alternator without spending close to half an Aviation Unit for the hardware. :-) Yeah . . . but. The same project economics are in play here as for the dummy-load conversation we had earlier this week. The $parts$ are cheap but the $time$ is significant. Further, there are $risks$ for not being aware of all the design subtleties. Not risks of life, limb and airplane . . . but of future $time$ expended to 'fix' something overlooked. You can purchase an ND cored reman for a very reasonable price. But check installation dimensions so that you can use a commonly available bracket. You may need to find a new pulley. Doing the 'mod' is straightforward and low risk. The PM alternator is a bit harder. You need either a pulley on the engine and brackets to hold the alternator . . . or the machining resources to craft a pad-friendly spline drive. I think the SD-8 is pretty attractively priced given the effort it would take to DIY. Bob . . . ________________________________________________________________________________
Date: Jul 24, 2014
Hello Out there....=0AWhat can I do to subscribe to the List / Group?=0A- =0ATodd Bristol=0AInteractive Entertainment DJs and Events,=0ACasino Partie s and Game Shows.=0AMesa, Arizona=0A480-755-4200=0Awww.djs4u.com=0Awww.game showsamerica.com=0Awww.condopenasco.com=0A=0A=0ASport Pilot...=0A=0A- - - - - - - - - -_|_-=0A-------- Todd ___ /===\___ Bristol=0A----- \__________(- .- )___________/ -=0A---------- (*)--- \___/--- (*) ________________________________________________________________________________
Subject: Re: Unsubscribe
Date: Jul 24, 2014
i wanted to unsubscribe to the email forms , (i'm getting to many to keep up with & then erase) ----- Original Message ----- From: Todd Bristol To: aeroelectric-list(at)matronics.com Sent: Thursday, July 24, 2014 10:40 AM Hello Out there.... What can I do to subscribe to the List / Group? Todd Bristol Interactive Entertainment DJs and Events, Casino Parties and Game Shows. Mesa, Arizona 480-755-4200 www.djs4u.com www.gameshowsamerica.com www.condopenasco.com Sport Pilot... _|_ Todd ___ /===\___ Bristol \__________( . )___________/ (*) \___/ (*) ________________________________________________________________________________
Date: Jul 24, 2014
Nobody can do this for you, log onto the Matronics site and adjust your set tings. The link is in every email.=0A=0ATim=0A=0A=0A=0AOn Thursday, July 24 , 2014 8:54 AM, Jon Molek wrote:=0A =0A=0A=0A =0Ai wanted to unsubscribe to the email forms =0A,=0A(i'm getting to many to keep up w ith- & =0Athen erase) =0A----- Original Message ----- =0A>From: Todd Bris tol =0A>To: aeroelectric-list(at)matronics.com =0A>Sent: Thursday, July 24, 20 14 10:40 AM=0A>=0A>=0A>Hello Out there....=0A>What can I do to subscribe to the List / Group?=0A>-=0A>Todd Bristol=0A>Interactive Entertainment DJ s and Events,=0A>Casino Parties and Game Shows.=0A>Mesa, Arizona=0A>480-755 -4200=0A>www.djs4u.com=0A>www.gameshowsamerica.com=0A>www.condopenasco.com =0A>=0A>=0A>=0A>Sport Pilot...=0A>=0A>=0A>- - - - - - - - - -_|_-=0A>-------- Todd ___ /===\___ Bristol =0A>----- \__________(- .- )___________/-=0A>---- ------ (*)--- \___/--- (*)=0A>=0A>-=0A>-=0A>hr ef="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matr onics.com/Navigator?AeroElectric-List=0Ahref="http://forums.matronics.com ">http://forums.matronics.com=0Ahref="http://www.matronics.com/contributi == ________________________________________________________________________________
Date: Jul 24, 2014
there's no place in it I can find it says to unsubscribe unless there's a difference site I'm not looking at,maybe you can send me th at site and I'll do it thank you John Sent from my iPad > On Jul 24, 2014, at 12:05 PM, Tim Andres wrote: > > Nobody can do this for you, log onto the Matronics site and adjust your se ttings. The link is in every email. > Tim > > > On Thursday, July 24, 2014 8:54 AM, Jon Molek wrote: > > > i wanted to unsubscribe to the email forms , > (i'm getting to many to keep up with & then erase) > ----- Original Message ----- > From: Todd Bristol > To: aeroelectric-list(at)matronics.com > Sent: Thursday, July 24, 2014 10:40 AM > > Hello Out there.... > What can I do to subscribe to the List / Group? > > Todd Bristol > Interactive Entertainment DJs and Events, > Casino Parties and Game Shows. > Mesa, Arizona > 480-755-4200 > www.djs4u.com > www.gameshowsamerica.com > www.condopenasco.com > > Sport Pilot... > > _|_ > Todd ___ /===\___ Bristol > \__________( . )___________/ > (*) \___/ (*) > > > > > href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.m atronics.com/Navigator?AeroElectric-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > http://www.matronics.com/Navigattarget="_blank" href="http://forums.ma tronics.com/">http://forums.matro --> > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Jul 24, 2014
Subject: GNS430 Microphone/Sidetone Problem
Today when I started my flight, all seemed well. Shortly after takeoff I tried to make a radio call, but when I held the mic key, instead of getting the usual sidetone, I got a series of clicks. I don't recall it doing that when I made my departing radio calls. I plugged a second headset into the other front seat and got the same results when I pushed the other PTT. I put the second headset back into the original side and tried again with the same result, as to help ensure that the headset wasn't the problem. The first headset was a Bose X through a LEMO plug (which is wired to the adjacent two-plugs per Bose instructions), and the second was a David Clark through the usual two plugs. I'm away from my usual shop and tools, so I wonder if anyone might have any tips about where to focus my troubleshooting? Has anyone encountered this type of behavior before out of the 430 or another radio? This is a single-radio installation with a Flightcom 403 intercom. The left and right PTT keys are consolidated in the intercom, but with the behavior being the same on both sides, I'm doubtful that the problem would be there. ________________________________________________________________________________
Date: Jul 24, 2014
won't die ________________________________________________________________________________
Date: Jul 25, 2014
Subject: Re: GNS430 Microphone/Sidetone Problem
At 12:40 PM 7/24/2014, you wrote: >Today when I started my flight, all seemed well. > Shortly after takeoff I tried to make a radio >call, but when I held the mic key, instead of >getting the usual sidetone, I got a series of >clicks. I don't recall it doing that when I >made my departing radio calls. I plugged a >second headset into the other front seat and got >the same results when I pushed the other PTT. >I put the second headset back into the original >side and tried again with the same result, as to >help ensure that the headset wasn't the problem. >The first headset was a Bose X through a LEMO >plug (which is wired to the adjacent two-plugs >per Bose instructions), and the second was a >David Clark through the usual two plugs. I'm >away from my usual shop and tools, so I wonder >if anyone might have any tips about where to >focus my troubleshooting? Has anyone >encountered this type of behavior before out of >the 430 or another radio? This is a >single-radio installation with a Flightcom 403 >intercom. The left and right PTT keys are >consolidated in the intercom, but with the >behavior being the same on both sides, I'm >doubtful that the problem would be there. Does the intercom work? Can you talk between two headsets? Do people hear your transmissions? Do you hear their transmissions? ________________________________________________________________________________
Date: Jul 25, 2014
> Does the intercom work? Can you talk between > two headsets? Do people hear your transmissions? > Do you hear their transmissions? Yes, yes, it doesn't seem so, and yes. ________________________________________________________________________________
Date: Jul 25, 2014
At 01:33 PM 7/25/2014, you wrote: > > > > Does the intercom work? Can you talk between > > two headsets? Do people hear your transmissions? > > Do you hear their transmissions? > >Yes, yes, it doesn't seem so, and yes. When you push the PTT, does the transceiver go into transmit mode? Bob . . . ________________________________________________________________________________
Date: Jul 25, 2014
> When you push the PTT, does the transceiver > go into transmit mode? I'll have to check Monday, but it seemed to. I should modify my description of the sound to "Static with clicks" when I key the mic, since there is a static element to it also. ________________________________________________________________________________
Date: Jul 26, 2014
At 05:22 PM 7/25/2014, you wrote: > > > > When you push the PTT, does the transceiver > > go into transmit mode? > >I'll have to check Monday, but it seemed to. I should modify my >description of the sound to "Static with clicks" when I key the mic, >since there is a static element to it also. Okay. If the intercom is working then the AUDIO paths to the two microphone inputs to the intercom are intact. Without having a schematic of the IC . . . I have no way to deduce how the PTT commands are processed going though the IC. In one of the Flightcom installation manuals I found a suggested tool for bypassing the IC . . . which is also useful for trouble- shooting. Emacs! Suggest you check your manual for such a recommendation and have the tool on hand. With the IC bypassed the radio should work normally as if only the pilot's headset is connected directly to the radio. Whether or not this produces improved behavior is an important clue for tracking down root cause of your problem. Bob . . . ________________________________________________________________________________
Date: Jul 26, 2014
Wasn't there some discussion awhile back about how the GNS has two power fee d paths and that if one of them opened, the radio would appear to work but i t wouldn't transmit? I think someone had this issue when their radio wasn't fully inserted into the tray/rack. Might not be the case here, but could be worth checking out. Regards, Matt- Sent from my iPhone > On Jul 26, 2014, at 6:43 AM, "Robert L. Nuckolls, III" <nuckolls.bob@aeroe lectric.com> wrote: > > At 05:22 PM 7/25/2014, you wrote: m> >> >> >> > When you push the PTT, does the transceiver >> > go into transmit mode? >> >> I'll have to check Monday, but it seemed to. I should modify my descripti on of the sound to "Static with clicks" when I key the mic, since there is a static element to it also. > > Okay. If the intercom is working then the > AUDIO paths to the two microphone inputs to > the intercom are intact. Without having > a schematic of the IC . . . I have > no way to deduce how the PTT commands > are processed going though the IC. > > In one of the Flightcom installation manuals > I found a suggested tool for bypassing > the IC . . . which is also useful for trouble- > shooting. > > <227d876f.jpg> > > Suggest you check your manual for such a > recommendation and have the tool on hand. > With the IC bypassed the radio should > work normally as if only the pilot's headset > is connected directly to the radio. Whether > or not this produces improved behavior is > an important clue for tracking down root cause > of your problem. > > Bob . . . ________________________________________________________________________________
Date: Jul 26, 2014
The 430 does have separate comm and NAV power feeds, but I believe most ofte n they are on a single fuse/CB/wire and simply "Y" into the two pins inside t he D-sub connector. If the comm side is not powered the comm info display on the RHS of the screen will not be there. Tim > On Jul 26, 2014, at 9:01 AM, Matthew Prather wrote : > > Wasn't there some discussion awhile back about how the GNS has two power f eed paths and that if one of them opened, the radio would appear to work but it wouldn't transmit? I think someone had this issue when their radio wasn 't fully inserted into the tray/rack. Might not be the case here, but could b e worth checking out. > > Regards, > Matt- > > Sent from my iPhone > >> On Jul 26, 2014, at 6:43 AM, "Robert L. Nuckolls, III" <nuckolls.bob@aero electric.com> wrote: >> >> At 05:22 PM 7/25/2014, you wrote: om> >>> >>> >>> > When you push the PTT, does the transceiver >>> > go into transmit mode? >>> >>> I'll have to check Monday, but it seemed to. I should modify my descript ion of the sound to "Static with clicks" when I key the mic, since there is a static element to it also. >> >> Okay. If the intercom is working then the >> AUDIO paths to the two microphone inputs to >> the intercom are intact. Without having >> a schematic of the IC . . . I have >> no way to deduce how the PTT commands >> are processed going though the IC. >> >> In one of the Flightcom installation manuals >> I found a suggested tool for bypassing >> the IC . . . which is also useful for trouble- >> shooting. >> >> <227d876f.jpg> >> >> Suggest you check your manual for such a >> recommendation and have the tool on hand. >> With the IC bypassed the radio should >> work normally as if only the pilot's headset >> is connected directly to the radio. Whether >> or not this produces improved behavior is >> an important clue for tracking down root cause >> of your problem. >> >> Bob . . . >> > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Jul 26, 2014
I had that problem. The GNS430 wasn't fully inserted into its slot and although the RX and TX button lit up it did not seem to transmit (or receive as I remember). See http://forums.matronics.com/viewtopic.php?t=98650&view=next&sid=a9694aaf0de05619e08664647aea1483 > On 26 Jul 2014, at 18:01, Matthew Prather wrote: > > I think someone had this issue when their radio wasn't fully inserted into the tray/rack. Might not be the case here, but could be worth checking out. ________________________________________________________________________________
Date: Jul 26, 2014
Subject: Garmin 430W - Comm & Nav Power from Separate Busses
99, Using the AeroElectric Z-11 schematic, I plan to supply the Nav side of the Garmin 430W from the Essential buss and the Comm side from the Main buss. The Garmin install manual shows the comm and nav functions of the 430W to be powered by separate wires with separate circuit breakers. With my equipment list I don't need the comm function of the 430W during battery only operations but I do need to power the nav side. In an alternator failed situation with the master switch off and the Essential buss alternate switch on, any reason why the 430W nav (GPS & VOR/LOC) will not work with the comm side receiving no power? Thanks, William Buckley ________________________________________________________________________________
Date: Jul 26, 2014
Sacha makes a very good point. . The 430 chassis to box-chassis connector fit is finicky. I know. . .I have the "T-shirt" If the box-chassis is mounted in the aircraft panel a little to deep, this causes a problem. For when the 430 is slid into the box, it will not seat back deep enough to fully engage some connector pins. The fix is to loosen up the panel mounted box chassis and pull it forward to be flush with the panel or even a tad ( 1/16") out in front of the panel and then re-bolt it back to the panel framing. Another point. . .I do not recommend that you use the 430 locking jack mechanism to pull the 430 back into its locked position. If something is not aligned correctly you will not know it using the this method and could damage pins. I suggest that you get the 430 inserted by hand, fingers on each end of the the 430 panel. Gently rock it back in place feeling for any obstruction. Get it started in, turn the jacking system just enough to take up the slack. Then, using fingers only, rock the 430 further back into place and again feel for any odd resistance, then, using the jack, take up the slack. Continue this until you "feel" it seat properly with it rear connectors. Stop if you feel any odd resistance and start over after checking for any bent pins, etc. David ----- Original Message ----- From: "Sacha" <uuccio(at)gmail.com> Sent: Saturday, July 26, 2014 11:20 AM Subject: Re: AeroElectric-List: GNS430 Microphone/Sidetone Problem > > I had that problem. The GNS430 wasn't fully inserted into its slot and > although the RX and TX button lit up it did not seem to transmit (or > receive as I remember). See > > http://forums.matronics.com/viewtopic.php?t=98650&view=next&sid=a9694aaf0de05619e08664647aea1483 > > >> On 26 Jul 2014, at 18:01, Matthew Prather wrote: >> >> I think someone had this issue when their radio wasn't fully inserted >> into the tray/rack. Might not be the case here, but could be worth >> checking out. > > > ________________________________________________________________________________
Subject: Schematic symbol
Date: Jul 26, 2014
OK, I give in. I've looked everywhere for a schematic symbol for a switch-breaker. I have every type of switch known to humankind, and standard circuit breakers, but not a switch-breaker. Any clues, or is it just drawn like a standard circuit breaker? -------- Mike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427390#427390 ________________________________________________________________________________
Date: Jul 26, 2014
Subject: Re: Schematic symbol
Mike,=0A=0AI'm not aware of any special symbol for a switch/circuit breaker .- I would use the standard breaker symbol.- Whether or not it is used as the normal operating switch is probably not germane at the schematic lev el.- What is important is that it can protect the wire, so show it as a s tandard breaker.=0A=0A-Jeff=0A=0A=0A=0AOn Saturday, July 26, 2014 8:09 PM, mmayfield wrote:=0A =0A=0A=0A--> AeroElectric-Li st message posted by: "mmayfield" =0A=0AOK, I giv e in. I've looked everywhere for a schematic symbol for a switch-breaker. I have every type of switch known to humankind, and standard circuit breaker s, but not a switch-breaker.=0A=0AAny clues, or is it just drawn like a sta ndard circuit breaker?=0A=0A--------=0AMike=0A=0A=0A=0A=0ARead this topic o nline here:=0A=0Ahttp://forums.matronics.com/viewtopic.php?p=427390#42739 = ________________________________________________________________________________
Date: Jul 27, 2014
Mike, I have used this symbol. I believe I found it in the "The Aeroelectric Connection" on page 1-10 in Figure 1-13. -Michael Garmon On Sat, Jul 26, 2014 at 9:54 PM, mmayfield wrote: > mmayfield(at)ozemail.com.au> > > OK, I give in. I've looked everywhere for a schematic symbol for a > switch-breaker. I have every type of switch known to humankind, and > standard circuit breakers, but not a switch-breaker. > > Any clues, or is it just drawn like a standard circuit breaker? > > -------- > Mike > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=427390#427390 > > ________________________________________________________________________________
Date: Jul 27, 2014
At 07:49 AM 7/27/2014, you wrote: >Mike, >I have used this symbol. I believe I found it in the "The >Aeroelectric Connection" on page 1-10 in Figure 1-13. > >-Michael Garmon I don't think there is any 'industry recognized' symbol unique to this device so as Mike has noted, I made one up. If you're doing AutoCAD drawings, the symbol is included in the library of symbols on the website. I recall a few years back that there was no 'industy recognized' symbol for the DPDT-ON-ON-ON toggle switch. At least not in the 'approved' mil-spec symbology that had been adopted by Cessna. One such switch was used in an autopilot installation I had to write about. I crafted a symbol not unlike those found in the 'Connection publications today. Got a bucket of flack from my super and was told to use the symbol for a DP3T ON-OFF-ON . . . which happened to be the way that ARC Radio supplied the schematic to us!. "But boss!", sez I. "That doesn't help me explain how it works to my readers. "Don't you never mind son . . . it's ARC's product and we'll treat them with respect." "Oh," sez I. "Okay". I had to write a bunch of words explaining how the switch functioned in the system hoping that my words would over-ride the 'jump off the page' misunderstanding that was published in the drawing. A few years later, alternators started finding their way onto our airplanes, the great DC Master Switch Conundrum rose up whereupon the split-rocker was born. Hmmm . . . how to show THAT thing on a drawing? One of the guys over in the electrical group came up with this: Emacs! Push the bottom switch to ON and it forces the top switch ON too. But with both on, you can turn the bottom switch OFF and leave the top switch ON. "Cool" thinks I. "A schematic symbol that COMMUNICATES functionality with little if any head-scratching on the part of the observer." Guess what? THAT switch wasn't in the mil-specs either . . . but the guy heading up the electrical group understood the value of jump-off-the-page understanding better than my boss . . . who was in the business of publishing. The point to be taken away from this missive and Jeff's comment is that what ever symbol you do use should first NOT CONFUSE any future readers of your work product. After that, speak (or draw) to operational nuances in ways that jump-off-the- page at you. I've seen breakers depicted thusly on various drawings over the years Emacs! and all three of these pictures 'make sense' when more than one style appears in the same publication. It helps when either a table of symbols or accompanying text speaks to the existence of more than one style of breaker in the system . . . but as Jeff points out, were you to use ANY of the three to speak to the ELECTRICAL functionality of any circuit breaker in a schematic, no valuable information is lost. Adding the little nuances to depict MECHANICAL operation is just icing on the cupcake. Bottom line is, make a drawing that YOU understand first but keeping in mind that it may be useful that somebody else understands it in the future. Bob . . . ________________________________________________________________________________
Date: Jul 27, 2014
Sound like the voice of experience! -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of David Lloyd Sent: Saturday, July 26, 2014 6:02 PM Subject: Re: AeroElectric-List: GNS430 Microphone/Sidetone Problem --> Sacha makes a very good point. . The 430 chassis to box-chassis connector fit is finicky. I know. . .I have the "T-shirt" If the box-chassis is mounted in the aircraft panel a little to deep, this causes a problem. For when the 430 is slid into the box, it will not seat back deep enough to fully engage some connector pins. The fix is to loosen up the panel mounted box chassis and pull it forward to be flush with the panel or even a tad ( 1/16") out in front of the panel and then re-bolt it back to the panel framing. Another point. . .I do not recommend that you use the 430 locking jack mechanism to pull the 430 back into its locked position. If something is not aligned correctly you will not know it using the this method and could damage pins. I suggest that you get the 430 inserted by hand, fingers on each end of the the 430 panel. Gently rock it back in place feeling for any obstruction. Get it started in, turn the jacking system just enough to take up the slack. Then, using fingers only, rock the 430 further back into place and again feel for any odd resistance, then, using the jack, take up the slack. Continue this until you "feel" it seat properly with it rear connectors. Stop if you feel any odd resistance and start over after checking for any bent pins, etc. David ----- Original Message ----- From: "Sacha" <uuccio(at)gmail.com> Sent: Saturday, July 26, 2014 11:20 AM Subject: Re: AeroElectric-List: GNS430 Microphone/Sidetone Problem > > I had that problem. The GNS430 wasn't fully inserted into its slot and > although the RX and TX button lit up it did not seem to transmit (or > receive as I remember). See > > http://forums.matronics.com/viewtopic.php?t=98650&view=next&sid=a9694aaf0de0 5619e08664647aea1483 > > >> On 26 Jul 2014, at 18:01, Matthew Prather wrote: >> >> I think someone had this issue when their radio wasn't fully inserted >> into the tray/rack. Might not be the case here, but could be worth >> checking out. > > > ________________________________________________________________________________
Subject: Lithium Battery Experience - Sept. Kitplanes Article
Date: Jul 27, 2014
Bob requested in his recent article that those experimenting with Lithium batteries relate their experiences. I built a Zenith STOL CH750 with a Jabiru 3300 engine - a day/VFR, non-electrically dependent aircraft - perfect for experimentation! I originally installed a PC680 and it worked flawlessly. As I accumulated hours and increased empty weight from various modifications, I looked to using a LiFePO4 battery to gain back some useful load. I had heard that the Aerovoltz 12-cell would readily crank the Jab 3300, so I purchased a Ballistic 12-cell (same battery but cheaper!). Initially, things were fine - it spun the 3300 as good or better than the PC680 (and saved about 12-13 lbs doing it!). However, I began to get erratic tach readings and looked at the alternator leads where the tach picks up and the Jabiru OEM female spade leads appeared burned! After consulting Jabiru USA, I replaced the rather flimsy leads with quality AMP female spade connectors. THEN, my 20 amp alternator breaker began to trip! At this point, I did a lot of research and found that since the Jab 3300 doesn't output charging current 'til about 1800-1900 rpm, my theory was that the connectors were frying due to the surge of charging current after take off and low internal resistance of the battery, and once the connectors were corrected, the little Ballistic battery was getting hit with a surge of charging current in excess of 20 amps and tripping the breaker. I did two things - I reviewed my wiring and found I was good for up to a 35 amp breaker to protect it, so I replaced the breaker with a 35A, and switched to an EarthX ETX36D which supposedly has close to the capacity of the PC680. I'm really happy so far (several months) with the ETX36D - it seems to function just as well as the PC680. It spins the prop for starts as well or better as the PC680 and although the Jab 3300 is not charging during ground operations, there is negligible voltage drop when powering-up the EFIS, transponder, radio, etc. (The PC680 found a happy home in my '82 911SC Porsche, which was a weight savings vs a conventional auto battery!) The Ballistic will be re-purposed in my UTV. Time will tell as to durability and performance of the EarthX, but for now I'm a happy camper! John N750A Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427414#427414 ________________________________________________________________________________
Date: Jul 28, 2014
Ah thanks Mike. I could've sworn I looked at every schematic in the AEC library but must've missed it. Yes Bob, that's the exact reason I want a different symbol for it. I have mainly conventional breakers however I also have 2 switch breakers which power a couple of low-cycle non flight-critical system circuits. I want to make sure the circuit diagram accurately represents the system components for the benefit of anyone who may happen to be working on it other than myself. -------- Mike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427429#427429 ________________________________________________________________________________
Date: Jul 28, 2014
There really are standards for this sort of thing; many many standards. Ugh... See: http://symbols.radicasoftware.com/category/Circuit-Breakers.html But you'd do almost as good drawing a little box with a label in it. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427437#427437 ________________________________________________________________________________
Subject: tachometer question
Date: Jul 28, 2014
This is a non-aviation question but I hope relevant to this lists' interest. The needle of my pickup truck's tachometer has started to vibrate significantly more than it used to. Whereas it used to be only a few km/h, now it goes from 50km/h to 60km/h and back incessantly with a period of about 1 second. It seems excessive and I was wondering if it's the sign of something wrong. Where would I start looking? ________________________________________________________________________________
Date: Jul 28, 2014
Subject: Re: tachometer question
On 07/28/2014 11:22 AM, Sacha wrote: > Whereas it used to be only a few km/h, > now it goes from 50km/h to 60km/h and back incessantly with a period of > about 1 second. It seems excessive and I was wondering if it's the sign of > something wrong. Where would I start looking? My Audi's speedometer does something similar. My guess is that it is either the servo motor that controls the needle (common in the TT), or the speed sensor on the transmission. Might be something similar with your tach. -Dj -- Dj Merrill - N1JOV - VP EAA Chapter 87 Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Date: Jul 28, 2014
Subject: Re: Lithium Battery Experience - Sept. Kitplanes
Article At 05:00 PM 7/27/2014, you wrote: Bob requested in his recent article that those experimenting with Lithium batteries relate their experiences. I built a Zenith STOL CH750 with a Jabiru 3300 engine - a day/VFR, non-electrically dependent aircraft - perfect for experimentation! Thank you for taking the time to share . . . I purchased a Ballistic 12-cell. Initially, things were fine - it spun the 3300 as good or better than the PC680 (and saved about 12-13 lbs doing it!). However, I began to get erratic tach readings and looked at the alternator leads where the tach picks up and the Jabiru OEM female spade leads appeared burned! After consulting Jabiru USA, I replaced the rather flimsy leads with quality AMP female spade connectors. According to the Jabiru wiring diagram for this engine http://tinyurl.com/mpsmquh the tachometer drives from a variable reluctance pickup that looks at features on the flywheel . . . gear teeth, bolt heads, etc. This is a TINY signal that is unlikely to burn anything. What you may have observed in terms of discoloration is corrosion. But in any case, if you have spade terminal females getting loose or corroded, be aware of the potential for similar problems every other place you used this same terminal . . . this particular failure would not have been related to your battery change-out. THEN, my 20 amp alternator breaker began to trip! Where was this breaker installed? At this point, I did a lot of research and found that since the Jab 3300 doesn't output charging current 'til about 1800-1900 rpm, . . . typical of ALL brands and sizes of permanent magnet 'dynamos' . . . . . . my theory was that the connectors were frying due to the surge of charging current after take off and low internal resistance of the battery, and once the connectors were corrected, the little Ballistic battery was getting hit with a surge of charging current in excess of 20 amps and tripping the breaker. Those connectors were not associated with any part of the battery recharging current. I did two things - I reviewed my wiring and found I was good for up to a 35 amp breaker to protect it, so I replaced the breaker with a 35A, and switched to an EarthX ETX36D which supposedly has close to the capacity of the PC680. Why the battery change? When I'm informed as to the location of 20/35A breakers, we can begin to figure out root cause of the tripping phenomenon you observed. It's not clear that the trip is related to the differences in batteries. The alternator is rated for 200W continuous which is 200/14 or about 14A. It MIGHT be that the lithium battery's willingness to accept charge at 14v is greater than the Lead-Acid . . . I'll need to explore that with some lithium cells on the bench. If that's true, then substitution of lithium for lead in your particular installation may be putting your rectifier/regulator/ alternator at risk. These systems are generally not current limited like wound-field alternators. So while up-sizing the breaker may have fixed a symptom, it doesn't answer the question as to why the 20A breaker was popping. Do you have an alternator loadmeter . . . if not, would you be willing to install one temporarily to sort out the questions? Time will tell as to durability and performance of the EarthX, but for now I'm a happy camper! It's not clear that the AeroVoltz would not be performing as well as the EarthX . . . But the EarthX does feature a full-up battery management system not unlike that installed in the TrueBlue products presently finding their way onto TC aircraft. Bob . . . ________________________________________________________________________________
Date: Jul 28, 2014
Sacha, Can't help without knowing if the tach is driven by cable or electronics. If cable, then lubricating the cable would probably stop the tach needle from whipping. _________________________________________________________________________ ----- Original Message ----- From: "Sacha" <uuccio(at)gmail.com> Sent: Monday, July 28, 2014 8:22 AM Subject: AeroElectric-List: tachometer question > > This is a non-aviation question but I hope relevant to this lists' > interest. > The needle of my pickup truck's tachometer has started to vibrate > significantly more than it used to. Whereas it used to be only a few > km/h, > now it goes from 50km/h to 60km/h and back incessantly with a period of > about 1 second. It seems excessive and I was wondering if it's the sign > of > something wrong. Where would I start looking? > > > ________________________________________________________________________________
Subject: Wiring a 2 dash 7 Two pole Switch for my flaps
Date: Jul 28, 2014
Bob, I've read your explanation on wiring various switches several times now and am still not certain what I should be using in my plane. I recently flew a few hours in a Remos G3. The flap switch installed as standard used a "bump down, or hold down" to deploy the flaps and a single "bump up" to retract fully. (Spring loaded both directions.) The flap switch in my Zenith 601XL requires bumping both directions (or holding) to extend or retract. I would like to duplicate the Remos switch. My flap motor has limit switches in both directions if that makes any difference. Do I need a different two pole switch or need to wire my 2-7 differently? Thanks, Mike -------- Mike Miller @ millrml(at)aol.com 601 XL-B, 3300, Dynon Remember, "the second mouse gets the cheese"! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427446#427446 ________________________________________________________________________________
Date: Jul 28, 2014
You're talking about 2 different things. Tachometer-measures engine rpm Thing that measures in Km/h - speedometer (drive train rpm) Please clarify which system you're talking about. Raymond Julian Kettle River, MN The things we admire in men, kindness and generosity, openness, honesty, understanding and feeling are the concomitants of failure in our system. And those traits we detest, sharpness, greed, acquisitiveness, meanness, egotism and self-interest are the traits of success. And while men admire the quality of the first they love the produce of the second. -John Steinbeck, novelist, Nobel laureate (1902-1968) On 07/28/2014 10:22 AM, Sacha wrote: > > This is a non-aviation question but I hope relevant to this lists' interest. > The needle of my pickup truck's tachometer has started to vibrate > significantly more than it used to. Whereas it used to be only a few km/h, > now it goes from 50km/h to 60km/h and back incessantly with a period of > about 1 second. It seems excessive and I was wondering if it's the sign of > something wrong. Where would I start looking? > > ________________________________________________________________________________
Date: Jul 28, 2014
Thanks for all of the troubleshooting tips! I removed the 430, visually inspected the pins carefully, and reseated it as David suggests, and it is fixed! > On Jul 26, 2014, at 21:02, "David Lloyd" wrote: > > > Sacha makes a very good point. . > The 430 chassis to box-chassis connector fit is finicky. > I know. . .I have the "T-shirt" > > If the box-chassis is mounted in the aircraft panel a little to deep, this causes a problem. For when the 430 is slid into the box, it will not seat back deep enough to fully engage some connector pins. > > The fix is to loosen up the panel mounted box chassis and pull it forward to be flush with the panel or even a tad ( 1/16") out in front of the panel and then re-bolt it back to the panel framing. > > Another point. . .I do not recommend that you use the 430 locking jack mechanism to pull the 430 back into its locked position. If something is not aligned correctly you will not know it using the this method and could damage pins. > > I suggest that you get the 430 inserted by hand, fingers on each end of the the 430 panel. Gently rock it back in place feeling for any obstruction. Get it started in, turn the jacking system just enough to take up the slack. Then, using fingers only, rock the 430 further back into place and again feel for any odd resistance, then, using the jack, take up the slack. > Continue this until you "feel" it seat properly with it rear connectors. Stop if you feel any odd resistance and start over after checking for any bent pins, etc. > David > > ----- Original Message ----- From: "Sacha" <uuccio(at)gmail.com> > To: > Sent: Saturday, July 26, 2014 11:20 AM > Subject: Re: AeroElectric-List: GNS430 Microphone/Sidetone Problem > > >> >> I had that problem. The GNS430 wasn't fully inserted into its slot and although the RX and TX button lit up it did not seem to transmit (or receive as I remember). See >> >> http://forums.matronics.com/viewtopic.php?t=98650&view=next&sid=a9694aaf0de05619e08664647aea1483 >> >> >>> On 26 Jul 2014, at 18:01, Matthew Prather wrote: >>> >>> I think someone had this issue when their radio wasn't fully inserted into the tray/rack. Might not be the case here, but could be worth checking out. > > > > > ________________________________________________________________________________
Date: Jul 28, 2014
Subject: Re: Wiring a 2 dash 7 Two pole Switch for my flaps
At 11:36 AM 7/28/2014, you wrote: Bob, I've read your explanation on wiring various switches several times now and am still not certain what I should be using in my plane. I recently flew a few hours in a Remos G3. The flap switch installed as standard used a "bump down, or hold down" to deploy the flaps and a single "bump up" to retract fully. (Spring loaded both directions.) The flap switch in my Zenith 601XL requires bumping both directions (or holding) to extend or retract. I would like to duplicate the Remos switch. Okay, the DPDT, (ON)-off-(ON) with both sides loaded to center is the 2-7. My flap motor has limit switches in both directions if that makes any difference. Do I need a different two pole switch or need to wire my 2-7 differently? To get a DPDT (ON)-off-ON with only one side loaded to center you need a 2-5. http://tinyurl.com/9xh3dhq Bob . . . ________________________________________________________________________________
Date: Jul 28, 2014
Subject: Re: Is Bob at Oshkosh?
At 02:22 PM 7/28/2014, you wrote: >I heard that our fearless moderator was at OSH. >Anyone know the details? Booth, forum, etc? I wish . . . Bob . . . ________________________________________________________________________________
Subject: Re: speedometer, not tachometer question
Date: Jul 28, 2014
> Tachometer-measures engine rpm > > Thing that measures in Km/h - speedometer (drive train rpm) Thanks for correcting me Raymond. I meant the speedometer. It's a 1990 Toyota Hilux so I expect it's driven by cable not electronics (but I'm no expert here so correct me if I'm wrong). ________________________________________________________________________________
Date: Jul 28, 2014
Great to hear! David's tips are very useful (found out the hard way...) > On Jul 28, 2014, at 19:41, Jared Yates wrote: > > it is fixed! ________________________________________________________________________________
Date: Jul 28, 2014
Sacha, If, indeed it is cable drive, that is probably the problem. The cable drive interior gets dry over time and lots of friction develops. Figure out a way to disconnect the top end of the cable and spray a silicon based spray or similar down the interior of it. It will take some time to work the lubricant down a tight cable. Don't use WD-40. It congeals after time and in a long cable drive that is bad situation. David ______________________________________________________________________________ ----- Original Message ----- From: "Sacha" <uuccio(at)gmail.com> Sent: Monday, July 28, 2014 1:05 PM Subject: Re: AeroElectric-List: speedometer, not tachometer question > > >> Tachometer-measures engine rpm >> >> Thing that measures in Km/h - speedometer (drive train rpm) > > Thanks for correcting me Raymond. I meant the speedometer. > > It's a 1990 Toyota Hilux so I expect it's driven by cable not electronics > (but I'm no expert here so correct me if I'm wrong). > > > ________________________________________________________________________________
Subject: Re: LiFePo Battery
Date: Jul 28, 2014
Guido, Did you ever receive a reply to your battery question? Sometimes questions get lost if Bob and others are busy sorting out other issues. Ask again. I am also curious about the new batteries. Eric lapulce(at)sunrise.ch wrote: > Hello Bob and who it may concerne, > I am quite new to this group. I recently bought in Friedrichshafen at > the Aero 2014 a new LiFePo battery from AeroAkku ( model LFP450 D > Starter Battery for Lyc 0-320 ) The vendor told me that these > batteries are built with A123 Systems elements APR 18650M1. Do you > know this product ( it looks like a german assembly ) and has someone > of this list some or even extended experience with this type of > battery in general aviation especially concerning how to recharge and > reliability. > Thanks in advance > Guido Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427486#427486 ________________________________________________________________________________
Date: Jul 29, 2014
Thanks for the tip David. Knowing nothing about how these things are built I assumed that this was an electrical problem (I was imagining it was the sign of a faulty ground connection) but I guess I was a long way off the mark. Apologies for the off topic post and thanks again for everybody's help. Sacha > On Jul 28, 2014, at 23:29, "David Lloyd" wrote: > > If, indeed it is cable drive, that is probably the problem. > The cable drive interior gets dry over time and lots of friction develops. > Figure out a way to disconnect the top end of the cable and spray a silicon based spray or similar down the interior of it. > It will take some time to work the lubricant down a tight cable. > Don't use WD-40. It congeals after time and in a long cable drive that is bad situation. David ________________________________________________________________________________
Date: Jul 28, 2014
Subject: Ni-Cad?
> >Great article 9/14 Kitplanes Thank you . . . I'm gathering info for the 4th chapter . . . > >Will you be doing a NiCad comparison article? The NiCal seems to take a lot >more punishment without problems and Air Bus said they were looking at >them. There are very few companies that offer ni-cads suited to engine cranking. The legacy wet-cells are still made for replacement and refurbishment of an existing installation but they're not well liked in the general aviation community. I suggested that the OBAM aviation community take a look at wet ni-cads back about 1988 . . . but that was based on the availability of surplus cells that could be sorted and assembled into a DIY battery. Next time I talk to Skip Koss at Concorde, I'll ask him what his take is on the current state of the Ni-Cad market . . . Bob . . . ________________________________________________________________________________
Date: Jul 29, 2014
Eric, no I never got an answer or comment to my question. I installed the below mentioned battery into our Tailwind recently and saved 12,2 kg in weight ! Our old lead acid battery ( Sonnenschein ) was 14 kg and the new one is only 1,8kg ! The cranking power is excellent even better than with the lead acid battery. Up to now we had no problems but is only one month and 5 starts with run ups away. Guido On 29.07.2014, at 03:38, eschlanser wrote: > > > > Guido, > Did you ever receive a reply to your battery question? > Sometimes questions get lost if Bob and others are busy sorting out > other issues. > Ask again. I am also curious about the new batteries. > Eric > > > lapulce(at)sunrise.ch wrote: >> Hello Bob and who it may concerne, >> I am quite new to this group. I recently bought in Friedrichshafen at >> the Aero 2014 a new LiFePo battery from AeroAkku ( model LFP450 D >> Starter Battery for Lyc 0-320 ) The vendor told me that these >> batteries are built with A123 Systems elements APR 18650M1. Do you >> know this product ( it looks like a german assembly ) and has someone >> of this list some or even extended experience with this type of >> battery in general aviation especially concerning how to recharge and >> reliability. >> Thanks in advance >> Guido > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=427486#427486 > > ________________________________________________________________________________
Subject: WD-40 As a Lubricant
Date: Jul 29, 2014
7/29/2014 Hello All, David Lloyd wrote: =9CDon't use WD-40. It congeals after time and in a long cable drive that is bad situation.=9D Amen to that. In fact don=99t use original plain WD-40 as a lubricant, that is a self defeating action. It is true that original plain WD-40 may free up some mechanism initially (as would almost any low viscosity fluid, even water), but the longer term effect will not be lubricating in nature. Spraying original plain WD-40 may even wash away what little lubrication that remains in the mechanism making the longer term situation worse. Original plain WD-40 is a great product for doing just exactly what it was designed to do, displace water. That is why it is called W(ater) D(isplacing) =93 40. When people began to mistakenly spray it as a lubricant and initially got some lubricating effect the WD-40 marketing people jumped on the bandwagon and began to claim lubricating properties for that product in their advertisement and labeling. Now the WD-40 company has some specialty products that may be suitable for your lubrication use. See here: http://www.wd40specialist.com/products But don=99t be sucked into using original plain WD-40 as a lubricant, use a true lubricating product. OC ====== From: "David Lloyd" <skywagon(at)charter.net> Subject: Re: AeroElectric-List: speedometer, not tachometer question Sacha, If, indeed it is cable drive, that is probably the problem. The cable drive interior gets dry over time and lots of friction develops. Figure out a way to disconnect the top end of the cable and spray a silicon based spray or similar down the interior of it. It will take some time to work the lubricant down a tight cable. Don't use WD-40. It congeals after time and in a long cable drive that is bad situation. David ________________________________________________________________________________
Date: Jul 29, 2014
At 10:32 PM 7/28/2014, you wrote: > >Thanks for the tip David. >Knowing nothing about how these things are built I assumed that this >was an electrical problem (I was imagining it was the sign of a >faulty ground connection) but I guess I was a long way off the >mark. Apologies for the off topic post and thanks again for everybody's help. > >Sacha The warnings for WD40 are on point. This is VERY useful product for a narrow range of applications none of which included long term lubrication . . . ESPECIALLY high pressure (gears and chains). One interesting use of WD40 was in the after-dunking refurbishment of this target . . . http://tinyurl.com/qaxjmk9 Many missions for this aircraft were flown over water where it was recovered on a parachute at the end of the mission. After hoisting out of the water, the engine was removed and submerged in a barrel of WD40 . . . the rest of airplane's components were rinsed off (avionics was in a water-tight compartment), checked for operation and the whole airplane re-assembled for the next mission. Broken parts were replaced (missiles would often damage parts of the airframe due to direct hits). Every MQM-107 operations base had a 'bone yard' of targets from which serious replacement parts could be salvaged. The engine would be spun up with air to clear the WD-40 (and bits of seaweed) and reinstalled. The airplane was ready for the next mission! Flex drives are quite common in modern aircraft. Most notably flap systems where a centrally mounted power unit's energy is 'piped' out to ball-screw actuators in the wings. Each system designer probably has their 'favorite' lubrication material based on temperatures, speeds and shaft loads. A web search will produce a bucket full of first hand advice most of which is probably adequate to the task. EVERY kind of 'slick' stuff has been used at one time or another on a flex shaft. See: http://tinyurl.com/mmkushv Checked the service manual for my '87 GMC p/u. It says: Emacs! In another GM service manual I found this reference: Emacs! Didn't find any specifics on the makeup of this product but some inferences that it was a special graphite bearing lubricant specific to speedometer cables. Flex shafts are common in single engine tachometer drives as well. The core of the shaft can be pulled out of the jacket. You can wipe down the flex shaft with a rag and solvent. Flush the jacket with a can of carb or brake cleaner squirted down the upper opening. Follow with compress air to get it DRY. Get a small bottle of graphite. Autoparts stores used to offer a bottle of graphite that could be screwed onto the speedometer (upper end) of a cable and left in place while you "drive some miles" with some notion that the graphite would distribute down the shaft with time and motion. The better technique is to squirt about 5CC of graphite into the empty jacket then push it through with strokes of clean and dry flex shaft. Flex shafts with high torque on them WILL run harder against the jacket wall and graphite is not a high pressure lubricant. But for speedo and tach shafts, I suspect that graphite is never wrong. Bob . . . ________________________________________________________________________________
Date: Jul 29, 2014
At 02:16 PM 7/6/2014, you wrote: Hello Bob and who it may concerne, I am quite new to this group. I recently bought in Friedrichshafen at the Aero 2014 a new LiFePo battery from AeroAkku ( model LFP450 D Starter Battery for Lyc 0-320 ) The vendor told me that these batteries are built with A123 Systems elements APR 18650M1. Do you know this product ( it looks like a german assembly ) and has someone of this list some or even extended experience with this type of battery in general aviation especially concerning how to recharge and reliability. These are tough questions to answer. There is virtually zero long term history of A123 or any other product in OBAM aircraft from which one might offer anecdotal observations . . . much less comparative studies for return on investment to be realized by selecting this or any other lithium product. As to 'recharge' recommendations, I'll note that even the pronouncements of the manufacturers is all over the map. Some folks bundle up some cells in a nice case an say, "Here's a drop in replacement for lead-acid." This is demonstrably not true. Others will include a nifty connector for a 'smart charger' on their product with words like, "You don't NEED our supper-whippy charger but . . . using it could double your battery life." Say what? By the way, they DON'T tell you the operational protocols under which the supper-whippy charger yields the best battery service life. Still others (EarthX most notably) have build advanced battery management systems electronics INTO their battery. These are probably as close as you will come to a drop-in replacement for lead-acid. The fact that lithium batteries have been demonstrated to benefit from such advanced electronics is a BOLD statement that argues with any other products that claim to replace a lead-acid battery with their simple assembly of cells into a nice case. The jury is still out but evidence will being to mount as the willing experimenters in the market sample the range of products and begin to report their experiences. Guido my friend, YOU are positioned to become the authority as one of hopefully many participants in this grand experiment. Operate your battery as close as possible to the manufacturer's recommendations . . . and then you tell US of your experience. Bob . . . ________________________________________________________________________________
Date: Jul 29, 2014
Subject: NiCd batteries that
V2hlbiBJIGZsZXcgUFQtNiBwb3dlcmVkIHBsYW5lcyBpbiB0aGUgJzgwcyB0aGV5IGhhZCBOaUNh ZHMuIMKgV2hlbiBleGVjdXRpbmcgYSBiYXR0ZXJ5IHN0YXJ0IHdlIHdhdGNoZWQgdGhlIGdlbmVy YXRvciBjdXJyZW50IGxpa2UgYSBoYXdrIGFuZCB3aGVuIGl0IHRhcGVyZWQgZG93biB3ZSBjb3Vs ZCBzdGFydCB0aGUgb3RoZXIgZW5naW5lLiDCoFRoaXMgd2FzIGJlY2F1c2UgZGVlcGx5IGN5Y2xp bmcgdGhlIGJhdHRlcnkgY291bGQgY2F1c2UgYSB0aGVybWFsIHJ1bmF3YXktdGhlIGJhdHRlcnkg Y291bGQgbWVsdC1yaWdodCB0aHJvdWdoIHRoZSBib3R0b20gb2YgdGhlIGFpcmNyYWZ0LiDCoFRo aXMgd2FzIHRha2VuIHNvIHNlcmlvdXNseSB0aGF0IG5vdGhpbmcgZXNzZW50aWFsIHdhcyBpbnN0 YWxsZWQgb3Igcm91dGVkIHVuZGVyIHRoZSBiYXR0ZXJ5LsKgCkJlaW5nIE5pQ2FkcyB0aGV5IHdl cmUgYWxzbyBzdWJqZWN0IHRvIGNoYXJnZSBtZW1vcnkuCkF0IHRoZSAxMDBociBjaGVjayB0aGV5 IHdlcmUgcmVtb3ZlZCBhbmQgZWFjaCBjZWxsIHdhcyBjb21wbGV0ZWx5IGRpc2NoYXJnZWQgaW4g YSB3YXRlciBiYXRoLW5vdGhpbmcgY291bGQgcnVuYXdheSBpbiBhIGhlYXQgc2luayB0aGF0IGxh cmdlLgpXZSBtb25pdG9yZWQgYmF0dGVyeSB0ZW1wcyBpbiBmbGlnaHQuIMKgTWFpbnRlbmFuY2Ug dG9vayBoaWdoZXIgdGhhbiBub3JtYWwgdGVtcHMgdmVyeSBzZXJpb3VzbHkuwqAKSXQgd2FzIHdv cnRoIGFsbCB0aGlzIGJlY2F1c2UgeW91IGNvdWxkIGdldCBhIGxvdCBvZiBjdXJyZW50IG91dCBh bmQgYmFjayBpbiB2ZXJ5IHF1aWNrbHksIGJ1dCB3ZSB1c2VkIGEgY2FydCB0byBzdGFydCB3aGVu ZXZlciBwb3NzaWJsZS7CoAoKU2VudCBmcm9tIG15IEdhbGF4eSBTwq5JSUkKCjxkaXY+LS0tLS0t LS0gT3JpZ2luYWwgbWVzc2FnZSAtLS0tLS0tLTwvZGl2PjxkaXY+RnJvbTogQWVyb0VsZWN0cmlj LUxpc3QgRGlnZXN0IFNlcnZlciA8YWVyb2VsZWN0cmljLWxpc3RAbWF0cm9uaWNzLmNvbT4gPC9k aXY+PGRpdj5EYXRlOjA3LzI5LzIwMTQgIDAyOjU5ICAoR01ULTA1OjAwKSA8L2Rpdj48ZGl2PlRv OiBBZXJvRWxlY3RyaWMtTGlzdCBEaWdlc3QgTGlzdCA8YWVyb2VsZWN0cmljLWxpc3QtZGlnZXN0 QG1hdHJvbmljcy5jb20+IDwvZGl2PjxkaXY+U3ViamVjdDogQWVyb0VsZWN0cmljLUxpc3QgRGln ZXN0OiAxOCBNc2dzIC0gMDcvMjgvMTQgPC9kaXY+PGRpdj4KPC9kaXY+KgoKPT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KICAgT25saW5lIFZlcnNpb25z IG9mIFRvZGF5J3MgTGlzdCBEaWdlc3QgQXJjaGl2ZQo9PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PQoKVG9kYXkncyBjb21wbGV0ZSBBZXJvRWxlY3RyaWMt TGlzdCBEaWdlc3QgY2FuIGFsc28gYmUgZm91bmQgaW4gZWl0aGVyIG9mIHRoZSAKdHdvIFdlYiBM aW5rcyBsaXN0ZWQgYmVsb3cuICBUaGUgLmh0bWwgZmlsZSBpbmNsdWRlcyB0aGUgRGlnZXN0IGZv cm1hdHRlZCAKaW4gSFRNTCBmb3Igdmlld2luZyB3aXRoIGEgd2ViIGJyb3dzZXIgYW5kIGZlYXR1 cmVzIEh5cGVybGlua2VkIEluZGV4ZXMgCmFuZCBNZXNzYWdlIE5hdmlnYXRpb24uICBUaGUgLnR4 dCBmaWxlIGluY2x1ZGVzIHRoZSBwbGFpbiBBU0NJSSB2ZXJzaW9uIApvZiB0aGUgQWVyb0VsZWN0 cmljLUxpc3QgRGlnZXN0IGFuZCBjYW4gYmUgdmlld2VkIHdpdGggYSBnZW5lcmljIHRleHQgZWRp dG9yIApzdWNoIGFzIE5vdGVwYWQgb3Igd2l0aCBhIHdlYiBicm93c2VyLiAKCkhUTUwgVmVyc2lv bjoKCiAgICBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vZGlnZXN0L2RpZ2VzdHZpZXcucGhwP1N0 eWxlPTgyNzAxJlZpZXc9aHRtbCZDaGFwdGVyPTIwMTQtMDctMjgmQXJjaGl2ZT1BZXJvRWxlY3Ry aWMKClRleHQgVmVyc2lvbjoKCiAgICBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vZGlnZXN0L2Rp Z2VzdHZpZXcucGhwP1N0eWxlPTgyNzAxJlZpZXc9dHh0JkNoYXB0ZXI9MjAxNC0wNy0yOCZBcmNo aXZlPUFlcm9FbGVjdHJpYwoKCj09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PQogICBFTWFpbCBWZXJzaW9uIG9mIFRvZGF5J3MgTGlzdCBEaWdlc3QgQXJjaGl2 ZQo9PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KCgogICAg ICAgICAgIC0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0t LS0tLS0tLS0KICAgICAgICAgICAgICAgICAgICAgICAgICAgQWVyb0VsZWN0cmljLUxpc3QgRGln ZXN0IEFyY2hpdmUKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAtLS0KICAg ICAgICAgICAgICAgICAgICAgVG90YWwgTWVzc2FnZXMgUG9zdGVkIE1vbiAwNy8yOC8xNDogMTgK ICAgICAgICAgICAtLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0t LS0tLS0tLS0tLS0tCgoKVG9kYXkncyBNZXNzYWdlIEluZGV4OgotLS0tLS0tLS0tLS0tLS0tLS0t LS0tCgogICAgIDEuIDAyOjQwIEFNIC0gUmU6IFNjaGVtYXRpYyBzeW1ib2wgIChtbWF5ZmllbGQp CiAgICAgMi4gMDg6MTIgQU0gLSBSZTogU2NoZW1hdGljIHN5bWJvbCAgKEVyaWMgTS4gSm9uZXMp CiAgICAgMy4gMDg6MjQgQU0gLSB0YWNob21ldGVyIHF1ZXN0aW9uICAoU2FjaGEpCiAgICAgNC4g MDg6MzkgQU0gLSBSZTogdGFjaG9tZXRlciBxdWVzdGlvbiAgKERqIE1lcnJpbGwpCiAgICAgNS4g MDg6NTcgQU0gLSBSZTogTGl0aGl1bSBCYXR0ZXJ5IEV4cGVyaWVuY2UgLSBTZXB0LiBLaXRwbGFu ZXMgQXJ0aWNsZSAgKFJvYmVydCBMLiBOdWNrb2xscywgSUlJKQogICAgIDYuIDA5OjIxIEFNIC0g UmU6IHRhY2hvbWV0ZXIgcXVlc3Rpb24gIChEYXZpZCBMbG95ZCkKICAgICA3LiAwOTozNyBBTSAt IFdpcmluZyBhIDIgZGFzaCA3IFR3byBwb2xlIFN3aXRjaCBmb3IgbXkgZmxhcHMgIChBWkZseWVy KQogICAgIDguIDEwOjMzIEFNIC0gUmU6IHRhY2hvbWV0ZXIgcXVlc3Rpb24gIChyYXlqKQogICAg IDkuIDEwOjQ0IEFNIC0gUmU6IEdOUzQzMCBNaWNyb3Bob25lL1NpZGV0b25lIFByb2JsZW0gIChK YXJlZCBZYXRlcykKICAgIDEwLiAxMjoyNCBQTSAtIElzIEJvYiBhdCBPc2hrb3NoPyAgKERhdmlk IFNheWxvcikKICAgIDExLiAwMTowNiBQTSAtIFJlOiBXaXJpbmcgYSAyIGRhc2ggNyBUd28gcG9s ZSBTd2l0Y2ggZm9yIG15IGZsYXBzICAoUm9iZXJ0IEwuIE51Y2tvbGxzLCBJSUkpCiAgICAxMi4g MDE6MDYgUE0gLSBSZTogSXMgQm9iIGF0IE9zaGtvc2g/ICAoUm9iZXJ0IEwuIE51Y2tvbGxzLCBJ SUkpCiAgICAxMy4gMDE6MDcgUE0gLSBSZTogc3BlZWRvbWV0ZXIsIG5vdCB0YWNob21ldGVyIHF1 ZXN0aW9uICAgKFNhY2hhKQogICAgMTQuIDAxOjIzIFBNIC0gUmU6IEdOUzQzMCBNaWNyb3Bob25l L1NpZGV0b25lIFByb2JsZW0gIChTYWNoYSkKICAgIDE1LiAwMjozMCBQTSAtIFJlOiBzcGVlZG9t ZXRlciwgbm90IHRhY2hvbWV0ZXIgcXVlc3Rpb24gICAoRGF2aWQgTGxveWQpCiAgICAxNi4gMDY6 NDAgUE0gLSBSZTogTGlGZVBvIEJhdHRlcnkgIChlc2NobGFuc2VyKQogICAgMTcuIDA4OjUyIFBN IC0gUmU6IHNwZWVkb21ldGVyLCBub3QgdGFjaG9tZXRlciBxdWVzdGlvbiAgKFNhY2hhKQogICAg MTguIDA5OjA3IFBNIC0gTmktQ2FkPyAgKFJvYmVydCBMLiBOdWNrb2xscywgSUlJKQoKCgpfX19f X19fX19fX19fX19fX19fX19fX19fX19fX19fXyAgTWVzc2FnZSAxICBfX19fX19fX19fX19fX19f X19fX19fX19fX19fX19fX19fX19fCgoKVGltZTogMDI6NDA6MDMgQU0gUFNUIFVTClN1YmplY3Q6 IEFlcm9FbGVjdHJpYy1MaXN0OiBSZTogU2NoZW1hdGljIHN5bWJvbApGcm9tOiAibW1heWZpZWxk IiA8bW1heWZpZWxkQG96ZW1haWwuY29tLmF1PgoKCkFoIHRoYW5rcyBNaWtlLiBJIGNvdWxkJ3Zl IHN3b3JuIEkgbG9va2VkIGF0IGV2ZXJ5IHNjaGVtYXRpYyBpbiB0aGUgQUVDIGxpYnJhcnkKYnV0 IG11c3QndmUgbWlzc2VkIGl0LgoKWWVzIEJvYiwgdGhhdCdzIHRoZSBleGFjdCByZWFzb24gSSB3 YW50IGEgZGlmZmVyZW50IHN5bWJvbCBmb3IgaXQuIEkgaGF2ZSBtYWlubHkKY29udmVudGlvbmFs IGJyZWFrZXJzIGhvd2V2ZXIgSSBhbHNvIGhhdmUgMiBzd2l0Y2ggYnJlYWtlcnMgd2hpY2ggcG93 ZXIgYSBjb3VwbGUKb2YgbG93LWN5Y2xlIG5vbiBmbGlnaHQtY3JpdGljYWwgc3lzdGVtIGNpcmN1 aXRzLiBJIHdhbnQgdG8gbWFrZSBzdXJlIHRoZQpjaXJjdWl0IGRpYWdyYW0gYWNjdXJhdGVseSBy ZXByZXNlbnRzIHRoZSBzeXN0ZW0gY29tcG9uZW50cyBmb3IgdGhlIGJlbmVmaXQgb2YKYW55b25l IHdobyBtYXkgaGFwcGVuIHRvIGJlIHdvcmtpbmcgb24gaXQgb3RoZXIgdGhhbiBteXNlbGYuCgot LS0tLS0tLQpNaWtlCgoKUmVhZCB0aGlzIHRvcGljIG9ubGluZSBoZXJlOgoKaHR0cDovL2ZvcnVt cy5tYXRyb25pY3MuY29tL3ZpZXd0b3BpYy5waHA/cD00Mjc0MjkjNDI3NDI5CgoKX19fX19fX19f X19fX19fX19fX19fX19fX19fX19fX18gIE1lc3NhZ2UgMiAgX19fX19fX19fX19fX19fX19fX19f X19fX19fX19fX19fX19fXwoKClRpbWU6IDA4OjEyOjU1IEFNIFBTVCBVUwpTdWJqZWN0OiBBZXJv RWxlY3RyaWMtTGlzdDogUmU6IFNjaGVtYXRpYyBzeW1ib2wKRnJvbTogIkVyaWMgTS4gSm9uZXMi IDxlbWpvbmVzQGNoYXJ0ZXIubmV0PgoKClRoZXJlIHJlYWxseSBhcmUgc3RhbmRhcmRzIGZvciB0 aGlzIHNvcnQgb2YgdGhpbmc7IG1hbnkgbWFueSBzdGFuZGFyZHMuIFVnaC4uLgoKU2VlOiBodHRw Oi8vc3ltYm9scy5yYWRpY2Fzb2Z0d2FyZS5jb20vY2F0ZWdvcnkvQ2lyY3VpdC1CcmVha2Vycy5o dG1sCgpCdXQgeW91J2QgZG8gYWxtb3N0IGFzIGdvb2QgZHJhd2luZyBhIGxpdHRsZSBib3ggd2l0 aCBhIGxhYmVsIGluIGl0LgoKLS0tLS0tLS0KRXJpYyBNLiBKb25lcwp3d3cuUGVyaWhlbGlvbkRl c2lnbi5jb20KMTEzIEJyZW50d29vZCBEcml2ZQpTb3V0aGJyaWRnZSwgTUEgMDE1NTAKKDUwOCkg NzY0LTIwNzIKZW1qb25lcyhhdCljaGFydGVyLm5ldAoKClJlYWQgdGhpcyB0b3BpYyBvbmxpbmUg aGVyZToKCmh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbS92aWV3dG9waWMucGhwP3A9NDI3NDM3 IzQyNzQzNwoKCl9fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fICBNZXNzYWdlIDMgIF9f X19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX18KCgpUaW1lOiAwODoyNDowNSBBTSBQ U1QgVVMKRnJvbTogIlNhY2hhIiA8dXVjY2lvQGdtYWlsLmNvbT4KU3ViamVjdDogQWVyb0VsZWN0 cmljLUxpc3Q6IHRhY2hvbWV0ZXIgcXVlc3Rpb24KCgpUaGlzIGlzIGEgbm9uLWF2aWF0aW9uIHF1 ZXN0aW9uIGJ1dCBJIGhvcGUgcmVsZXZhbnQgdG8gdGhpcyBsaXN0cycgaW50ZXJlc3QuClRoZSBu ZWVkbGUgb2YgbXkgcGlja3VwIHRydWNrJ3MgdGFjaG9tZXRlciBoYXMgc3RhcnRlZCB0byB2aWJy YXRlCnNpZ25pZmljYW50bHkgbW9yZSB0aGFuIGl0IHVzZWQgdG8uICBXaGVyZWFzIGl0IHVzZWQg dG8gYmUgb25seSBhIGZldyBrbS9oLApub3cgaXQgZ29lcyBmcm9tIDUwa20vaCB0byA2MGttL2gg YW5kIGJhY2sgaW5jZXNzYW50bHkgd2l0aCBhIHBlcmlvZCBvZgphYm91dCAxIHNlY29uZC4gIEl0 IHNlZW1zIGV4Y2Vzc2l2ZSBhbmQgSSB3YXMgd29uZGVyaW5nIGlmIGl0J3MgdGhlIHNpZ24gb2YK c29tZXRoaW5nIHdyb25nLiAgV2hlcmUgd291bGQgSSBzdGFydCBsb29raW5nPwoKCl9fX19fX19f X19fX19fX19fX19fX19fX19fX19fX19fICBNZXNzYWdlIDQgIF9fX19fX19fX19fX19fX19fX19f X19fX19fX19fX19fX19fX18KCgpUaW1lOiAwODozOTowNCBBTSBQU1QgVVMKU3ViamVjdDogUmU6 IEFlcm9FbGVjdHJpYy1MaXN0OiB0YWNob21ldGVyIHF1ZXN0aW9uCkZyb206IERqIE1lcnJpbGwg PGRlZWpAZGVlai5uZXQ+CgoKT24gMDcvMjgvMjAxNCAxMToyMiBBTSwgU2FjaGEgd3JvdGU6Cj4g V2hlcmVhcyBpdCB1c2VkIHRvIGJlIG9ubHkgYSBmZXcga20vaCwKPiBub3cgaXQgZ29lcyBmcm9t IDUwa20vaCB0byA2MGttL2ggYW5kIGJhY2sgaW5jZXNzYW50bHkgd2l0aCBhIHBlcmlvZCBvZgo+ IGFib3V0IDEgc2Vjb25kLiAgSXQgc2VlbXMgZXhjZXNzaXZlIGFuZCBJIHdhcyB3b25kZXJpbmcg aWYgaXQncyB0aGUgc2lnbiBvZgo+IHNvbWV0aGluZyB3cm9uZy4gIFdoZXJlIHdvdWxkIEkgc3Rh cnQgbG9va2luZz8KCk15IEF1ZGkncyBzcGVlZG9tZXRlciBkb2VzIHNvbWV0aGluZyBzaW1pbGFy LiAgTXkgZ3Vlc3MgaXMgdGhhdCBpdCBpcwplaXRoZXIgdGhlIHNlcnZvIG1vdG9yIHRoYXQgY29u dHJvbHMgdGhlIG5lZWRsZSAoY29tbW9uIGluIHRoZSBUVCksIG9yCnRoZSBzcGVlZCBzZW5zb3Ig b24gdGhlIHRyYW5zbWlzc2lvbi4KCk1pZ2h0IGJlIHNvbWV0aGluZyBzaW1pbGFyIHdpdGggeW91 ciB0YWNoLgoKLURqCgotLSAKRGogTWVycmlsbCAtIE4xSk9WIC0gVlAgRUFBIENoYXB0ZXIgODcK U3BvcnRzbWFuIDIrMiBCdWlsZGVyICM3MTE4IE40MjFESiAtIGh0dHA6Ly9kZWVqLm5ldC9zcG9y dHNtYW4vCkdsYXN0YXIgRmx5ZXIgTjg2NlJIIC0gaHR0cDovL2RlZWoubmV0L2dsYXN0YXIvCgoK X19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX18gIE1lc3NhZ2UgNSAgX19fX19fX19fX19f X19fX19fX19fX19fX19fX19fX19fX19fXwoKClRpbWU6IDA4OjU3OjAzIEFNIFBTVCBVUwpGcm9t OiAiUm9iZXJ0IEwuIE51Y2tvbGxzLCBJSUkiIDxudWNrb2xscy5ib2JAYWVyb2VsZWN0cmljLmNv bT4KU3ViamVjdDogUmU6IEFlcm9FbGVjdHJpYy1MaXN0OiBMaXRoaXVtIEJhdHRlcnkgRXhwZXJp ZW5jZSAtIFNlcHQuICAgS2l0cGxhbmVzCkFydGljbGUKCkF0IDA1OjAwIFBNIDcvMjcvMjAxNCwg eW91IHdyb3RlOgoKQm9iIHJlcXVlc3RlZCBpbiBoaXMgcmVjZW50IGFydGljbGUgdGhhdCB0aG9z ZSBleHBlcmltZW50aW5nIHdpdGggCkxpdGhpdW0gYmF0dGVyaWVzIHJlbGF0ZSB0aGVpciBleHBl cmllbmNlcy4gSSBidWlsdCBhIFplbml0aCBTVE9MIApDSDc1MCB3aXRoIGEgSmFiaXJ1IDMzMDAg ZW5naW5lIC0gYSBkYXkvVkZSLCBub24tZWxlY3RyaWNhbGx5IApkZXBlbmRlbnQgYWlyY3JhZnQg LSBwZXJmZWN0IGZvciBleHBlcmltZW50YXRpb24hClRoYW5rIHlvdSBmb3IgdGFraW5nIHRoZSB0 aW1lIHRvIHNoYXJlIC4gLiAuCkkgcHVyY2hhc2VkIGEgQmFsbGlzdGljIDEyLWNlbGwuIEluaXRp YWxseSwgdGhpbmdzIHdlcmUgZmluZSAtIGl0IApzcHVuIHRoZSAzMzAwIGFzIGdvb2Qgb3IgYmV0 dGVyIHRoYW4gdGhlIFBDNjgwIChhbmQgc2F2ZWQgYWJvdXQgMTItMTMgCmxicyBkb2luZyBpdCEp LgoKSG93ZXZlciwgSSBiZWdhbiB0byBnZXQgZXJyYXRpYyB0YWNoIHJlYWRpbmdzIGFuZCBsb29r ZWQgYXQgdGhlIAphbHRlcm5hdG9yIGxlYWRzIHdoZXJlIHRoZSB0YWNoIHBpY2tzIHVwIGFuZCB0 aGUgSmFiaXJ1IE9FTSBmZW1hbGUgCnNwYWRlIGxlYWRzIGFwcGVhcmVkIGJ1cm5lZCEgQWZ0ZXIg Y29uc3VsdGluZyBKYWJpcnUgVVNBLCBJIHJlcGxhY2VkIAp0aGUgcmF0aGVyIGZsaW1zeSBsZWFk cyB3aXRoIHF1YWxpdHkgQU1QIGZlbWFsZSBzcGFkZSBjb25uZWN0b3JzLgoKQWNjb3JkaW5nIHRv IHRoZSBKYWJpcnUgd2lyaW5nIGRpYWdyYW0gZm9yIHRoaXMKZW5naW5lICBodHRwOi8vdGlueXVy bC5jb20vbXBzbXF1aAp0aGUgdGFjaG9tZXRlciBkcml2ZXMgZnJvbSBhIHZhcmlhYmxlCnJlbHVj dGFuY2UgcGlja3VwIHRoYXQgbG9va3MgYXQgZmVhdHVyZXMKb24gdGhlIGZseXdoZWVsIC4gLiAu IGdlYXIgdGVldGgsIGJvbHQgaGVhZHMsCmV0Yy4KVGhpcyBpcyBhIFRJTlkgc2lnbmFsIHRoYXQg aXMgdW5saWtlbHkgdG8KYnVybiBhbnl0aGluZy4gV2hhdCB5b3UgbWF5IGhhdmUgb2JzZXJ2ZWQg aW4KdGVybXMgb2YgZGlzY29sb3JhdGlvbiBpcyBjb3Jyb3Npb24uIEJ1dCBpbiBhbnkKY2FzZSwg aWYgeW91IGhhdmUgc3BhZGUgdGVybWluYWwgZmVtYWxlcyBnZXR0aW5nCmxvb3NlIG9yIGNvcnJv ZGVkLCBiZSBhd2FyZSBvZiB0aGUgcG90ZW50aWFsIGZvcgpzaW1pbGFyIHByb2JsZW1zIGV2ZXJ5 IG90aGVyIHBsYWNlIHlvdSB1c2VkIHRoaXMKc2FtZSB0ZXJtaW5hbCAuIC4gLiB0aGlzIHBhcnRp Y3VsYXIgZmFpbHVyZQp3b3VsZCBub3QgaGF2ZSBiZWVuIHJlbGF0ZWQgdG8geW91ciBiYXR0ZXJ5 CmNoYW5nZS1vdXQuClRIRU4sIG15IDIwIGFtcCBhbHRlcm5hdG9yIGJyZWFrZXIgYmVnYW4gdG8g dHJpcCEKV2hlcmUgd2FzIHRoaXMgYnJlYWtlciBpbnN0YWxsZWQ/CkF0IHRoaXMgcG9pbnQsIEkg ZGlkIGEgbG90IG9mIHJlc2VhcmNoIGFuZCBmb3VuZCB0aGF0IHNpbmNlIHRoZSBKYWIgCjMzMDAg ZG9lc24ndCBvdXRwdXQgY2hhcmdpbmcgY3VycmVudCAndGlsIGFib3V0IDE4MDAtMTkwMCBycG0s Ci4gLiAuIHR5cGljYWwgb2YgQUxMIGJyYW5kcyBhbmQgc2l6ZXMgb2YgcGVybWFuZW50Cm1hZ25l dCAnZHluYW1vcycgLiAuIC4KLiAuIC4gbXkgdGhlb3J5IHdhcyB0aGF0IHRoZSBjb25uZWN0b3Jz IHdlcmUgZnJ5aW5nIGR1ZSB0byB0aGUgc3VyZ2UgCm9mIGNoYXJnaW5nIGN1cnJlbnQgYWZ0ZXIg dGFrZSBvZmYgYW5kIGxvdyBpbnRlcm5hbCByZXNpc3RhbmNlIG9mIHRoZSAKYmF0dGVyeSwgYW5k IG9uY2UgdGhlIGNvbm5lY3RvcnMgd2VyZSBjb3JyZWN0ZWQsIHRoZSBsaXR0bGUgQmFsbGlzdGlj IApiYXR0ZXJ5IHdhcyBnZXR0aW5nIGhpdCB3aXRoIGEgc3VyZ2Ugb2YgY2hhcmdpbmcgY3VycmVu dCBpbiBleGNlc3Mgb2YgCjIwIGFtcHMgYW5kIHRyaXBwaW5nIHRoZSBicmVha2VyLgpUaG9zZSBj b25uZWN0b3JzIHdlcmUgbm90IGFzc29jaWF0ZWQgd2l0aCBhbnkgcGFydCBvZgp0aGUgYmF0dGVy eSByZWNoYXJnaW5nIGN1cnJlbnQuCkkgZGlkIHR3byB0aGluZ3MgLSBJIHJldmlld2VkIG15IHdp cmluZyBhbmQgZm91bmQgSSB3YXMgZ29vZCBmb3IgdXAgCnRvIGEgMzUgYW1wIGJyZWFrZXIgdG8g cHJvdGVjdCBpdCwgc28gSSByZXBsYWNlZCB0aGUgYnJlYWtlciB3aXRoIGEgCjM1QSwgYW5kIHN3 aXRjaGVkIHRvIGFuIEVhcnRoWCBFVFgzNkQgd2hpY2ggc3VwcG9zZWRseSBoYXMgY2xvc2UgdG8g CnRoZSBjYXBhY2l0eSBvZiB0aGUgUEM2ODAuCldoeSB0aGUgYmF0dGVyeSBjaGFuZ2U/IFdoZW4g SSdtIGluZm9ybWVkIGFzIHRvIHRoZQpsb2NhdGlvbiBvZiAyMC8zNUEgYnJlYWtlcnMsIHdlIGNh biBiZWdpbiB0byBmaWd1cmUKb3V0IHJvb3QgY2F1c2Ugb2YgdGhlIHRyaXBwaW5nIHBoZW5vbWVu b24geW91IG9ic2VydmVkLgoKSXQncyBub3QgY2xlYXIgdGhhdCB0aGUgdHJpcCBpcyByZWxhdGVk IHRvIHRoZSBkaWZmZXJlbmNlcwppbiBiYXR0ZXJpZXMuIFRoZSBhbHRlcm5hdG9yIGlzIHJhdGVk IGZvciAyMDBXIGNvbnRpbnVvdXMKd2hpY2ggaXMgMjAwLzE0IG9yIGFib3V0IDE0QS4gSXQgTUlH SFQgYmUgdGhhdCB0aGUgbGl0aGl1bQpiYXR0ZXJ5J3Mgd2lsbGluZ25lc3MgdG8gYWNjZXB0IGNo YXJnZSBhdCAxNHYgaXMgZ3JlYXRlcgp0aGFuIHRoZSBMZWFkLUFjaWQgLiAuIC4gSSdsbCBuZWVk IHRvIGV4cGxvcmUgdGhhdCB3aXRoCnNvbWUgbGl0aGl1bSBjZWxscyBvbiB0aGUgYmVuY2guIElm IHRoYXQncyB0cnVlLCB0aGVuCnN1YnN0aXR1dGlvbiBvZiBsaXRoaXVtIGZvciBsZWFkIGluIHlv dXIgcGFydGljdWxhcgppbnN0YWxsYXRpb24gbWF5IGJlIHB1dHRpbmcgeW91ciByZWN0aWZpZXIv cmVndWxhdG9yLwphbHRlcm5hdG9yIGF0IHJpc2suIFRoZXNlIHN5c3RlbXMgYXJlIGdlbmVyYWxs eSBub3QKY3VycmVudCBsaW1pdGVkIGxpa2Ugd291bmQtZmllbGQgYWx0ZXJuYXRvcnMuIFNvIHdo aWxlCnVwLXNpemluZyB0aGUgYnJlYWtlciBtYXkgaGF2ZSBmaXhlZCBhIHN5bXB0b20sIGl0CmRv ZXNuJ3QgYW5zd2VyIHRoZSBxdWVzdGlvbiBhcyB0byB3aHkgdGhlIDIwQSBicmVha2VyCndhcyBw b3BwaW5nLiBEbyB5b3UgaGF2ZSBhbiBhbHRlcm5hdG9yIGxvYWRtZXRlciAuIC4gLgppZiBub3Qs IHdvdWxkIHlvdSBiZSB3aWxsaW5nIHRvIGluc3RhbGwgb25lIHRlbXBvcmFyaWx5CnRvIHNvcnQg b3V0IHRoZSBxdWVzdGlvbnM/ClRpbWUgd2lsbCB0ZWxsIGFzIHRvIGR1cmFiaWxpdHkgYW5kIHBl cmZvcm1hbmNlIG9mIHRoZSBFYXJ0aFgsIGJ1dCAKZm9yIG5vdyBJJ20gYSBoYXBweSBjYW1wZXIh Ckl0J3Mgbm90IGNsZWFyIHRoYXQgdGhlIEFlcm9Wb2x0eiB3b3VsZCBub3QgYmUgcGVyZm9ybWlu ZwphcyB3ZWxsIGFzIHRoZSBFYXJ0aFggLiAuIC4gQnV0IHRoZSBFYXJ0aFggZG9lcyBmZWF0dXJl CmEgZnVsbC11cCBiYXR0ZXJ5IG1hbmFnZW1lbnQgc3lzdGVtIG5vdCB1bmxpa2UgdGhhdAppbnN0 YWxsZWQgaW4gdGhlIFRydWVCbHVlIHByb2R1Y3RzIHByZXNlbnRseSBmaW5kaW5nCnRoZWlyIHdh eSBvbnRvIFRDIGFpcmNyYWZ0LgoKICAgQm9iIC4gLiAuIAoKX19fX19fX19fX19fX19fX19fX19f X19fX19fX19fX18gIE1lc3NhZ2UgNiAgX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19f X19fXwoKClRpbWU6IDA5OjIxOjM4IEFNIFBTVCBVUwpGcm9tOiAiRGF2aWQgTGxveWQiIDxza3l3 YWdvbkBjaGFydGVyLm5ldD4KU3ViamVjdDogUmU6IEFlcm9FbGVjdHJpYy1MaXN0OiB0YWNob21l dGVyIHF1ZXN0aW9uCgoKU2FjaGEsCgpDYW4ndCBoZWxwIHdpdGhvdXQga25vd2luZyBpZiB0aGUg dGFjaCBpcyBkcml2ZW4gYnkgY2FibGUgb3IgZWxlY3Ryb25pY3MuCklmIGNhYmxlLCB0aGVuIGx1 YnJpY2F0aW5nIHRoZSBjYWJsZSB3b3VsZCBwcm9iYWJseSBzdG9wIHRoZSB0YWNoIG5lZWRsZSAK ZnJvbSB3aGlwcGluZy4KCl9fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19f X19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX18KCi0tLS0tIE9yaWdpbmFsIE1lc3NhZ2Ug LS0tLS0gCkZyb206ICJTYWNoYSIgPHV1Y2Npb0BnbWFpbC5jb20+ClNlbnQ6IE1vbmRheSwgSnVs eSAyOCwgMjAxNCA4OjIyIEFNClN1YmplY3Q6IEFlcm9FbGVjdHJpYy1MaXN0OiB0YWNob21ldGVy IHF1ZXN0aW9uCgoKPgo+IFRoaXMgaXMgYSBub24tYXZpYXRpb24gcXVlc3Rpb24gYnV0IEkgaG9w ZSByZWxldmFudCB0byB0aGlzIGxpc3RzJyAKPiBpbnRlcmVzdC4KPiBUaGUgbmVlZGxlIG9mIG15 IHBpY2t1cCB0cnVjaydzIHRhY2hvbWV0ZXIgaGFzIHN0YXJ0ZWQgdG8gdmlicmF0ZQo+IHNpZ25p ZmljYW50bHkgbW9yZSB0aGFuIGl0IHVzZWQgdG8uICBXaGVyZWFzIGl0IHVzZWQgdG8gYmUgb25s eSBhIGZldyAKPiBrbS9oLAo+IG5vdyBpdCBnb2VzIGZyb20gNTBrbS9oIHRvIDYwa20vaCBhbmQg YmFjayBpbmNlc3NhbnRseSB3aXRoIGEgcGVyaW9kIG9mCj4gYWJvdXQgMSBzZWNvbmQuICBJdCBz ZWVtcyBleGNlc3NpdmUgYW5kIEkgd2FzIHdvbmRlcmluZyBpZiBpdCdzIHRoZSBzaWduIAo+IG9m Cj4gc29tZXRoaW5nIHdyb25nLiAgV2hlcmUgd291bGQgSSBzdGFydCBsb29raW5nPwo+Cj4KPiAK CgpfX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fXyAgTWVzc2FnZSA3ICBfX19fX19fX19f X19fX19fX19fX19fX19fX19fX19fX19fX19fCgoKVGltZTogMDk6Mzc6MDQgQU0gUFNUIFVTClN1 YmplY3Q6IEFlcm9FbGVjdHJpYy1MaXN0OiBXaXJpbmcgYSAyIGRhc2ggNyBUd28gcG9sZSBTd2l0 Y2ggZm9yIG15IGZsYXBzCkZyb206ICJBWkZseWVyIiA8bWlsbHJNTEBhb2wuY29tPgoKCkJvYiwK CkkndmUgcmVhZCB5b3VyIGV4cGxhbmF0aW9uIG9uIHdpcmluZyB2YXJpb3VzIHN3aXRjaGVzIHNl dmVyYWwgdGltZXMgbm93IGFuZCBhbQpzdGlsbCBub3QgY2VydGFpbiB3aGF0IEkgc2hvdWxkIGJl IHVzaW5nIGluIG15IHBsYW5lLgoKSSByZWNlbnRseSBmbGV3IGEgZmV3IGhvdXJzIGluIGEgUmVt b3MgRzMuICBUaGUgZmxhcCBzd2l0Y2ggaW5zdGFsbGVkIGFzIHN0YW5kYXJkCnVzZWQgYSAiYnVt cCBkb3duLCBvciBob2xkIGRvd24iIHRvIGRlcGxveSB0aGUgZmxhcHMgYW5kIGEgc2luZ2xlICJi dW1wIHVwIgp0byByZXRyYWN0IGZ1bGx5LgooU3ByaW5nIGxvYWRlZCBib3RoIGRpcmVjdGlvbnMu KSAgVGhlIGZsYXAgc3dpdGNoIGluIG15IFplbml0aCA2MDFYTCByZXF1aXJlcyBidW1waW5nCmJv dGggZGlyZWN0aW9ucyAob3IgaG9sZGluZykgdG8gZXh0ZW5kIG9yIHJldHJhY3QuICBJIHdvdWxk IGxpa2UgdG8gZHVwbGljYXRlCnRoZSBSZW1vcyBzd2l0Y2guCgpNeSBmbGFwIG1vdG9yIGhhcyBs aW1pdCBzd2l0Y2hlcyBpbiBib3RoIGRpcmVjdGlvbnMgaWYgdGhhdCBtYWtlcyBhbnkgZGlmZmVy ZW5jZS4KCkRvIEkgbmVlZCBhIGRpZmZlcmVudCB0d28gcG9sZSBzd2l0Y2ggb3IgbmVlZCB0byB3 aXJlIG15IDItNyBkaWZmZXJlbnRseT8KClRoYW5rcywKTWlrZQoKLS0tLS0tLS0KTWlrZSBNaWxs ZXIgQCBtaWxscm1sQGFvbC5jb20KNjAxIFhMLUIsIDMzMDAsIER5bm9uCgpSZW1lbWJlciwgICZx dW90O3RoZSBzZWNvbmQgbW91c2UgZ2V0cyB0aGUgY2hlZXNlJnF1b3Q7IQoKClJlYWQgdGhpcyB0 b3BpYyBvbmxpbmUgaGVyZToKCmh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbS92aWV3dG9waWMu cGhwP3A9NDI3NDQ2IzQyNzQ0NgoKCl9fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fICBN ZXNzYWdlIDggIF9fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX18KCgpUaW1lOiAx MDozMzoxOSBBTSBQU1QgVVMKRnJvbTogcmF5aiA8cmF5bW9uZGpAZnJvbnRpZXJuZXQubmV0PgpT dWJqZWN0OiBSZTogQWVyb0VsZWN0cmljLUxpc3Q6IHRhY2hvbWV0ZXIgcXVlc3Rpb24KCgpZb3Un cmUgdGFsa2luZyBhYm91dCAyIGRpZmZlcmVudCB0aGluZ3MuCgpUYWNob21ldGVyLW1lYXN1cmVz IGVuZ2luZSBycG0KClRoaW5nIHRoYXQgbWVhc3VyZXMgaW4gS20vaCAtIHNwZWVkb21ldGVyIChk cml2ZSB0cmFpbiBycG0pCgpQbGVhc2UgY2xhcmlmeSB3aGljaCBzeXN0ZW0geW91J3JlIHRhbGtp bmcgYWJvdXQuCgpSYXltb25kIEp1bGlhbgpLZXR0bGUgUml2ZXIsIE1OCgpUaGUgdGhpbmdzIHdl IGFkbWlyZSBpbiBtZW4sIGtpbmRuZXNzIGFuZCBnZW5lcm9zaXR5LCBvcGVubmVzcywgaG9uZXN0 eSwgCnVuZGVyc3RhbmRpbmcgYW5kIGZlZWxpbmcgYXJlIHRoZSBjb25jb21pdGFudHMgb2YgZmFp bHVyZSBpbiBvdXIgc3lzdGVtLiAKQW5kIHRob3NlIHRyYWl0cyB3ZSBkZXRlc3QsIHNoYXJwbmVz cywgZ3JlZWQsIGFjcXVpc2l0aXZlbmVzcywgbWVhbm5lc3MsIAplZ290aXNtIGFuZCBzZWxmLWlu dGVyZXN0IGFyZSB0aGUgdHJhaXRzIG9mIHN1Y2Nlc3MuIEFuZCB3aGlsZSBtZW4gCmFkbWlyZSB0 aGUgcXVhbGl0eSBvZiB0aGUgZmlyc3QgdGhleSBsb3ZlIHRoZSBwcm9kdWNlIG9mIHRoZSBzZWNv bmQuIAotSm9obiBTdGVpbmJlY2ssIG5vdmVsaXN0LCBOb2JlbCBsYXVyZWF0ZSAoMTkwMi0xOTY4 KQoKT24gMDcvMjgvMjAxNCAxMDoyMiBBTSwgU2FjaGEgd3JvdGU6Cj4KPiBUaGlzIGlzIGEgbm9u LWF2aWF0aW9uIHF1ZXN0aW9uIGJ1dCBJIGhvcGUgcmVsZXZhbnQgdG8gdGhpcyBsaXN0cycgaW50 ZXJlc3QuCj4gVGhlIG5lZWRsZSBvZiBteSBwaWNrdXAgdHJ1Y2sncyB0YWNob21ldGVyIGhhcyBz dGFydGVkIHRvIHZpYnJhdGUKPiBzaWduaWZpY2FudGx5IG1vcmUgdGhhbiBpdCB1c2VkIHRvLiAg V2hlcmVhcyBpdCB1c2VkIHRvIGJlIG9ubHkgYSBmZXcga20vaCwKPiBub3cgaXQgZ29lcyBmcm9t IDUwa20vaCB0byA2MGttL2ggYW5kIGJhY2sgaW5jZXNzYW50bHkgd2l0aCBhIHBlcmlvZCBvZgo+ IGFib3V0IDEgc2Vjb25kLiAgSXQgc2VlbXMgZXhjZXNzaXZlIGFuZCBJIHdhcyB3b25kZXJpbmcg aWYgaXQncyB0aGUgc2lnbiBvZgo+IHNvbWV0aGluZyB3cm9uZy4gIFdoZXJlIHdvdWxkIEkgc3Rh cnQgbG9va2luZz8KPgo+CgoKX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX18gIE1lc3Nh Z2UgOSAgX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fXwoKClRpbWU6IDEwOjQ0 OjA3IEFNIFBTVCBVUwpGcm9tOiBKYXJlZCBZYXRlcyA8ZW1haWxAamFyZWR5YXRlcy5jb20+ClN1 YmplY3Q6IFJlOiBBZXJvRWxlY3RyaWMtTGlzdDogR05TNDMwIE1pY3JvcGhvbmUvU2lkZXRvbmUg UHJvYmxlbQoKClRoYW5rcyBmb3IgYWxsIG9mIHRoZSB0cm91Ymxlc2hvb3RpbmcgdGlwcyEgIEkg cmVtb3ZlZCB0aGUgNDMwLCB2aXN1YWxseSBpbnNwZWN0ZWQKdGhlIHBpbnMgY2FyZWZ1bGx5LCBh bmQgcmVzZWF0ZWQgaXQgYXMgRGF2aWQgc3VnZ2VzdHMsIGFuZCBpdCBpcyBmaXhlZCEKCgo+IE9u IEp1bCAyNiwgMjAxNCwgYXQgMjE6MDIsICJEYXZpZCBMbG95ZCIgPHNreXdhZ29uQGNoYXJ0ZXIu bmV0PiB3cm90ZToKPiAKPiAKPiBTYWNoYSBtYWtlcyBhIHZlcnkgZ29vZCBwb2ludC4gLgo+IFRo ZSA0MzAgY2hhc3NpcyB0byBib3gtY2hhc3NpcyBjb25uZWN0b3IgZml0IGlzIGZpbmlja3kuCj4g SSBrbm93LiAuIC5JIGhhdmUgdGhlICJULXNoaXJ0Igo+IAo+IElmIHRoZSBib3gtY2hhc3NpcyBp cyBtb3VudGVkIGluIHRoZSBhaXJjcmFmdCBwYW5lbCBhIGxpdHRsZSB0byBkZWVwLCB0aGlzIGNh dXNlcwphIHByb2JsZW0uICBGb3Igd2hlbiB0aGUgNDMwIGlzIHNsaWQgaW50byB0aGUgYm94LCBp dCB3aWxsIG5vdCBzZWF0IGJhY2sKZGVlcCBlbm91Z2ggdG8gZnVsbHkgZW5nYWdlIHNvbWUgY29u bmVjdG9yIHBpbnMuCj4gCj4gVGhlIGZpeCBpcyB0byBsb29zZW4gdXAgdGhlIHBhbmVsIG1vdW50 ZWQgYm94IGNoYXNzaXMgYW5kIHB1bGwgaXQgZm9yd2FyZCB0bwpiZSBmbHVzaCB3aXRoIHRoZSBw YW5lbCBvciBldmVuIGEgdGFkICggMS8xNiIpIG91dCBpbiBmcm9udCBvZiB0aGUgcGFuZWwgYW5k IHRoZW4KcmUtYm9sdCBpdCBiYWNrIHRvIHRoZSBwYW5lbCBmcmFtaW5nLgo+IAo+IEFub3RoZXIg cG9pbnQuIC4gLkkgZG8gbm90IHJlY29tbWVuZCB0aGF0IHlvdSB1c2UgdGhlIDQzMCBsb2NraW5n IGphY2sgbWVjaGFuaXNtCnRvIHB1bGwgdGhlIDQzMCBiYWNrIGludG8gaXRzIGxvY2tlZCBwb3Np dGlvbi4gIElmIHNvbWV0aGluZyBpcyBub3QgYWxpZ25lZApjb3JyZWN0bHkgeW91IHdpbGwgbm90 IGtub3cgaXQgdXNpbmcgdGhlIHRoaXMgbWV0aG9kIGFuZCBjb3VsZCBkYW1hZ2UgcGlucy4KPiAK PiBJIHN1Z2dlc3QgdGhhdCB5b3UgZ2V0IHRoZSA0MzAgaW5zZXJ0ZWQgYnkgaGFuZCwgZmluZ2Vy cyBvbiBlYWNoIGVuZCBvZiB0aGUgdGhlCjQzMCBwYW5lbC4gIEdlbnRseSByb2NrIGl0IGJhY2sg aW4gcGxhY2UgZmVlbGluZyBmb3IgYW55IG9ic3RydWN0aW9uLiBHZXQgaXQKc3RhcnRlZCBpbiwg dHVybiB0aGUgamFja2luZyBzeXN0ZW0ganVzdCBlbm91Z2ggdG8gdGFrZSB1cCB0aGUgc2xhY2su IFRoZW4sCnVzaW5nIGZpbmdlcnMgb25seSwgcm9jayB0aGUgNDMwIGZ1cnRoZXIgYmFjayBpbnRv IHBsYWNlIGFuZCBhZ2FpbiBmZWVsIGZvciBhbnkKb2RkIHJlc2lzdGFuY2UsIHRoZW4sIHVzaW5n IHRoZSBqYWNrLCB0YWtlIHVwIHRoZSBzbGFjay4KPiBDb250aW51ZSB0aGlzIHVudGlsIHlvdSAi ZmVlbCIgaXQgc2VhdCBwcm9wZXJseSB3aXRoIGl0IHJlYXIgY29ubmVjdG9ycy4gU3RvcAppZiB5 b3UgZmVlbCBhbnkgb2RkIHJlc2lzdGFuY2UgYW5kIHN0YXJ0IG92ZXIgYWZ0ZXIgY2hlY2tpbmcg Zm9yIGFueSBiZW50IHBpbnMsCmV0Yy4KPiBEYXZpZAo+IAo+IC0tLS0tIE9yaWdpbmFsIE1lc3Nh Z2UgLS0tLS0gRnJvbTogIlNhY2hhIiA8dXVjY2lvQGdtYWlsLmNvbT4KPiBUbzogPGFlcm9lbGVj dHJpYy1saXN0QG1hdHJvbmljcy5jb20+Cj4gU2VudDogU2F0dXJkYXksIEp1bHkgMjYsIDIwMTQg MTE6MjAgQU0KPiBTdWJqZWN0OiBSZTogQWVyb0VsZWN0cmljLUxpc3Q6IEdOUzQzMCBNaWNyb3Bo b25lL1NpZGV0b25lIFByb2JsZW0KPiAKPiAKPj4gCj4+IEkgaGFkIHRoYXQgcHJvYmxlbS4gVGhl IEdOUzQzMCB3YXNuJ3QgZnVsbHkgaW5zZXJ0ZWQgaW50byBpdHMgc2xvdCBhbmQgYWx0aG91Z2gK dGhlIFJYIGFuZCBUWCBidXR0b24gbGl0IHVwIGl0IGRpZCBub3Qgc2VlbSB0byB0cmFuc21pdCAo b3IgcmVjZWl2ZSBhcyBJIHJlbWVtYmVyKS4KU2VlCj4+IAo+PiBodHRwOi8vZm9ydW1zLm1hdHJv bmljcy5jb20vdmlld3RvcGljLnBocD90PTk4NjUwJnZpZXc9bmV4dCZzaWQ9YTk2OTRhYWYwZGUw NTYxOWUwODY2NDY0N2FlYTE0ODMKPj4gCj4+IAo+Pj4gT24gMjYgSnVsIDIwMTQsIGF0IDE4OjAx LCBNYXR0aGV3IFByYXRoZXIgPG1hcHJhdGhlcmlkQGdtYWlsLmNvbT4gd3JvdGU6Cj4+PiAKPj4+ IEkgdGhpbmsgc29tZW9uZSBoYWQgdGhpcyBpc3N1ZSB3aGVuIHRoZWlyIHJhZGlvIHdhc24ndCBm dWxseSBpbnNlcnRlZCBpbnRvCnRoZSB0cmF5L3JhY2suIE1pZ2h0IG5vdCBiZSB0aGUgY2FzZSBo ZXJlLCBidXQgY291bGQgYmUgd29ydGggY2hlY2tpbmcgb3V0Lgo+IAo+IAo+IAo+IAo+IAoKCl9f X19fX19fX19fX19fX19fX19fX19fX19fX19fX19fICBNZXNzYWdlIDEwICBfX19fX19fX19fX19f X19fX19fX19fX19fX19fX19fX19fX18KCgpUaW1lOiAxMjoyNDo0MiBQTSBQU1QgVVMKU3ViamVj dDogQWVyb0VsZWN0cmljLUxpc3Q6IElzIEJvYiBhdCBPc2hrb3NoPwpGcm9tOiBEYXZpZCBTYXls b3IgPHNheWxvci5kYXZlQGdtYWlsLmNvbT4KCkkgaGVhcmQgdGhhdCBvdXIgZmVhcmxlc3MgbW9k ZXJhdG9yIHdhcyBhdCBPU0guIEFueW9uZSBrbm93IHRoZSBkZXRhaWxzPwpCb290aCwgZm9ydW0s IGV0Yz8KCi0tRGF2ZQoKRG8gbm90IGFyY2hpdmUKCl9fX19fX19fX19fX19fX19fX19fX19fX19f X19fX19fICBNZXNzYWdlIDExICBfX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX18K CgpUaW1lOiAwMTowNjoxNyBQTSBQU1QgVVMKRnJvbTogIlJvYmVydCBMLiBOdWNrb2xscywgSUlJ IiA8bnVja29sbHMuYm9iQGFlcm9lbGVjdHJpYy5jb20+ClN1YmplY3Q6IFJlOiBBZXJvRWxlY3Ry aWMtTGlzdDogV2lyaW5nIGEgMiBkYXNoIDcgVHdvIHBvbGUgU3dpdGNoIGZvciAgIG15IGZsYXBz CgoKQXQgMTE6MzYgQU0gNy8yOC8yMDE0LCB5b3Ugd3JvdGU6CgpCb2IsCgpJJ3ZlIHJlYWQgeW91 ciBleHBsYW5hdGlvbiBvbiB3aXJpbmcgdmFyaW91cyBzd2l0Y2hlcyBzZXZlcmFsIHRpbWVzIApu b3cgYW5kIGFtIHN0aWxsIG5vdCBjZXJ0YWluIHdoYXQgSSBzaG91bGQgYmUgdXNpbmcgaW4gbXkg cGxhbmUuCgpJIHJlY2VudGx5IGZsZXcgYSBmZXcgaG91cnMgaW4gYSBSZW1vcyBHMy4gIFRoZSBm bGFwIHN3aXRjaCBpbnN0YWxsZWQgCmFzIHN0YW5kYXJkIHVzZWQgYSAiYnVtcCBkb3duLCBvciBo b2xkIGRvd24iIHRvIGRlcGxveSB0aGUgZmxhcHMgYW5kIAphIHNpbmdsZSAiYnVtcCB1cCIgdG8g cmV0cmFjdCBmdWxseS4gKFNwcmluZyBsb2FkZWQgYm90aCBkaXJlY3Rpb25zLikKCgpUaGUgZmxh cCBzd2l0Y2ggaW4gbXkgWmVuaXRoIDYwMVhMIHJlcXVpcmVzIGJ1bXBpbmcgYm90aCBkaXJlY3Rp b25zIAoob3IgaG9sZGluZykgdG8gZXh0ZW5kIG9yIHJldHJhY3QuICBJIHdvdWxkIGxpa2UgdG8g ZHVwbGljYXRlIHRoZSBSZW1vcyBzd2l0Y2guCgogICBPa2F5LCB0aGUgRFBEVCwgKE9OKS1vZmYt KE9OKSB3aXRoIGJvdGggc2lkZXMKICAgbG9hZGVkIHRvIGNlbnRlciBpcyB0aGUgMi03LgoKTXkg ZmxhcCBtb3RvciBoYXMgbGltaXQgc3dpdGNoZXMgaW4gYm90aCBkaXJlY3Rpb25zIGlmIHRoYXQg bWFrZXMgYW55IApkaWZmZXJlbmNlLgoKRG8gSSBuZWVkIGEgZGlmZmVyZW50IHR3byBwb2xlIHN3 aXRjaCBvciBuZWVkIHRvIHdpcmUgbXkgMi03IGRpZmZlcmVudGx5PwoKICAgVG8gZ2V0IGEgRFBE VCAoT04pLW9mZi1PTiB3aXRoIG9ubHkgb25lIHNpZGUKICAgbG9hZGVkIHRvIGNlbnRlciB5b3Ug bmVlZCBhIDItNS4KCmh0dHA6Ly90aW55dXJsLmNvbS85eGgzZGhxCgoKICAgQm9iIC4gLiAuIAoK Cl9fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fICBNZXNzYWdlIDEyICBfX19fX19fX19f X19fX19fX19fX19fX19fX19fX19fX19fX18KCgpUaW1lOiAwMTowNjoyMCBQTSBQU1QgVVMKRnJv bTogIlJvYmVydCBMLiBOdWNrb2xscywgSUlJIiA8bnVja29sbHMuYm9iQGFlcm9lbGVjdHJpYy5j b20+ClN1YmplY3Q6IFJlOiBBZXJvRWxlY3RyaWMtTGlzdDogSXMgQm9iIGF0IE9zaGtvc2g/CgoK QXQgMDI6MjIgUE0gNy8yOC8yMDE0LCB5b3Ugd3JvdGU6Cj5JIGhlYXJkIHRoYXQgb3VyIGZlYXJs ZXNzIG1vZGVyYXRvciB3YXMgYXQgT1NILiAKPkFueW9uZSBrbm93IHRoZSBkZXRhaWxzPyAgQm9v dGgsIGZvcnVtLCBldGM/CgogICBJIHdpc2ggLiAuIC4KCgogICBCb2IgLiAuIC4gCgoKX19fX19f X19fX19fX19fX19fX19fX19fX19fX19fX18gIE1lc3NhZ2UgMTMgIF9fX19fX19fX19fX19fX19f X19fX19fX19fX19fX19fX19fXwoKClRpbWU6IDAxOjA3OjAyIFBNIFBTVCBVUwpTdWJqZWN0OiBS ZTogQWVyb0VsZWN0cmljLUxpc3Q6IHNwZWVkb21ldGVyLCBub3QgdGFjaG9tZXRlciBxdWVzdGlv biAKRnJvbTogU2FjaGEgPHV1Y2Npb0BnbWFpbC5jb20+CgoKCj4gVGFjaG9tZXRlci1tZWFzdXJl cyBlbmdpbmUgcnBtCj4gCj4gVGhpbmcgdGhhdCBtZWFzdXJlcyBpbiBLbS9oIC0gc3BlZWRvbWV0 ZXIgKGRyaXZlIHRyYWluIHJwbSkKClRoYW5rcyBmb3IgY29ycmVjdGluZyBtZSBSYXltb25kLiBJ IG1lYW50IHRoZSBzcGVlZG9tZXRlci4gCgpJdCdzIGEgMTk5MCBUb3lvdGEgSGlsdXggc28gSSBl eHBlY3QgaXQncyBkcml2ZW4gYnkgY2FibGUgbm90IGVsZWN0cm9uaWNzIChidXQKSSdtIG5vIGV4 cGVydCBoZXJlIHNvIGNvcnJlY3QgbWUgaWYgSSdtIHdyb25nKS4gCgoKX19fX19fX19fX19fX19f X19fX19fX19fX19fX19fX18gIE1lc3NhZ2UgMTQgIF9fX19fX19fX19fX19fX19fX19fX19fX19f X19fX19fX19fXwoKClRpbWU6IDAxOjIzOjA2IFBNIFBTVCBVUwpTdWJqZWN0OiBSZTogQWVyb0Vs ZWN0cmljLUxpc3Q6IEdOUzQzMCBNaWNyb3Bob25lL1NpZGV0b25lIFByb2JsZW0KRnJvbTogU2Fj aGEgPHV1Y2Npb0BnbWFpbC5jb20+CgoKR3JlYXQgdG8gaGVhciEgRGF2aWQncyB0aXBzIGFyZSB2 ZXJ5IHVzZWZ1bCAoZm91bmQgb3V0IHRoZSBoYXJkIHdheS4uLikKCj4gT24gSnVsIDI4LCAyMDE0 LCBhdCAxOTo0MSwgSmFyZWQgWWF0ZXMgPGVtYWlsQGphcmVkeWF0ZXMuY29tPiB3cm90ZToKPiAK PiBpdCBpcyBmaXhlZCEKCgpfX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fXyAgTWVzc2Fn ZSAxNSAgX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fCgoKVGltZTogMDI6MzA6 MjYgUE0gUFNUIFVTCkZyb206ICJEYXZpZCBMbG95ZCIgPHNreXdhZ29uQGNoYXJ0ZXIubmV0PgpT dWJqZWN0OiBSZTogQWVyb0VsZWN0cmljLUxpc3Q6IHNwZWVkb21ldGVyLCBub3QgdGFjaG9tZXRl ciBxdWVzdGlvbiAKCgpTYWNoYSwKCklmLCBpbmRlZWQgaXQgaXMgY2FibGUgZHJpdmUsIHRoYXQg aXMgcHJvYmFibHkgdGhlIHByb2JsZW0uClRoZSBjYWJsZSBkcml2ZSBpbnRlcmlvciBnZXRzIGRy eSBvdmVyIHRpbWUgYW5kIGxvdHMgb2YgZnJpY3Rpb24gZGV2ZWxvcHMuCkZpZ3VyZSBvdXQgYSB3 YXkgdG8gZGlzY29ubmVjdCB0aGUgdG9wIGVuZCBvZiB0aGUgY2FibGUgYW5kIHNwcmF5IGEgc2ls aWNvbiAKYmFzZWQgc3ByYXkgb3Igc2ltaWxhciBkb3duIHRoZSBpbnRlcmlvciBvZiBpdC4KSXQg d2lsbCB0YWtlIHNvbWUgdGltZSB0byB3b3JrIHRoZSBsdWJyaWNhbnQgZG93biBhIHRpZ2h0IGNh YmxlLgpEb24ndCB1c2UgV0QtNDAuICBJdCBjb25nZWFscyBhZnRlciB0aW1lIGFuZCBpbiBhIGxv bmcgY2FibGUgZHJpdmUgdGhhdCBpcyAKYmFkIHNpdHVhdGlvbi4gIERhdmlkCgpfX19fX19fX19f X19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19f X19fX19fX19fX18KLS0tLS0gT3JpZ2luYWwgTWVzc2FnZSAtLS0tLSAKRnJvbTogIlNhY2hhIiA8 dXVjY2lvQGdtYWlsLmNvbT4KU2VudDogTW9uZGF5LCBKdWx5IDI4LCAyMDE0IDE6MDUgUE0KU3Vi amVjdDogUmU6IEFlcm9FbGVjdHJpYy1MaXN0OiBzcGVlZG9tZXRlciwgbm90IHRhY2hvbWV0ZXIg cXVlc3Rpb24KCgo+Cj4KPj4gVGFjaG9tZXRlci1tZWFzdXJlcyBlbmdpbmUgcnBtCj4+Cj4+IFRo aW5nIHRoYXQgbWVhc3VyZXMgaW4gS20vaCAtIHNwZWVkb21ldGVyIChkcml2ZSB0cmFpbiBycG0p Cj4KPiBUaGFua3MgZm9yIGNvcnJlY3RpbmcgbWUgUmF5bW9uZC4gSSBtZWFudCB0aGUgc3BlZWRv bWV0ZXIuCj4KPiBJdCdzIGEgMTk5MCBUb3lvdGEgSGlsdXggc28gSSBleHBlY3QgaXQncyBkcml2 ZW4gYnkgY2FibGUgbm90IGVsZWN0cm9uaWNzIAo+IChidXQgSSdtIG5vIGV4cGVydCBoZXJlIHNv IGNvcnJlY3QgbWUgaWYgSSdtIHdyb25nKS4KPgo+Cj4gCgoKX19fX19fX19fX19fX19fX19fX19f X19fX19fX19fX18gIE1lc3NhZ2UgMTYgIF9fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19f X19fXwoKClRpbWU6IDA2OjQwOjE4IFBNIFBTVCBVUwpTdWJqZWN0OiBBZXJvRWxlY3RyaWMtTGlz dDogUmU6IExpRmVQbyBCYXR0ZXJ5CkZyb206ICJlc2NobGFuc2VyIiA8ZXNjaGxhbnNlckB5YWhv by5jb20+CgoKR3VpZG8sCkRpZCB5b3UgZXZlciByZWNlaXZlIGEgcmVwbHkgdG8geW91ciBiYXR0 ZXJ5IHF1ZXN0aW9uPyAKU29tZXRpbWVzIHF1ZXN0aW9ucyBnZXQgbG9zdCBpZiBCb2IgYW5kIG90 aGVycyBhcmUgYnVzeSBzb3J0aW5nIG91dCBvdGhlciBpc3N1ZXMuCkFzayBhZ2Fpbi4gSSBhbSBh bHNvIGN1cmlvdXMgYWJvdXQgdGhlIG5ldyBiYXR0ZXJpZXMuIApFcmljCgoKbGFwdWxjZShhdClz dW5yaXNlLmNoIHdyb3RlOgo+IEhlbGxvIEJvYiBhbmQgd2hvIGl0IG1heSBjb25jZXJuZSwKPiBJ IGFtIHF1aXRlIG5ldyB0byB0aGlzIGdyb3VwLiBJIHJlY2VudGx5IGJvdWdodCBpbiBGcmllZHJp Y2hzaGFmZW4gYXQgIAo+IHRoZSBBZXJvIDIwMTQgYSBuZXcgTGlGZVBvIGJhdHRlcnkgZnJvbSBB ZXJvQWtrdSAoIG1vZGVsIExGUDQ1MCBEICAgCj4gU3RhcnRlciBCYXR0ZXJ5IGZvciBMeWMgMC0z MjAgKSBUaGUgdmVuZG9yIHRvbGQgbWUgdGhhdCB0aGVzZSAgCj4gYmF0dGVyaWVzIGFyZSBidWls dCB3aXRoIEExMjMgU3lzdGVtcyBlbGVtZW50cyBBUFIgMTg2NTBNMS4gRG8geW91ICAKPiBrbm93 IHRoaXMgcHJvZHVjdCAoIGl0IGxvb2tzIGxpa2UgYSBnZXJtYW4gYXNzZW1ibHkgKSBhbmQgaGFz IHNvbWVvbmUgIAo+IG9mIHRoaXMgbGlzdCBzb21lIG9yIGV2ZW4gZXh0ZW5kZWQgZXhwZXJpZW5j ZSB3aXRoIHRoaXMgdHlwZSBvZiAgCj4gYmF0dGVyeSBpbiBnZW5lcmFsIGF2aWF0aW9uIGVzcGVj aWFsbHkgY29uY2VybmluZyBob3cgdG8gcmVjaGFyZ2UgYW5kICAKPiByZWxpYWJpbGl0eS4KPiBU aGFua3MgaW4gYWR2YW5jZQo+IEd1aWRvCgoKUmVhZCB0aGlzIHRvcGljIG9ubGluZSBoZXJlOgoK aHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tL3ZpZXd0b3BpYy5waHA/cD00Mjc0ODYjNDI3NDg2 CgoKX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX18gIE1lc3NhZ2UgMTcgIF9fX19fX19f X19fX19fX19fX19fX19fX19fX19fX19fX19fXwoKClRpbWU6IDA4OjUyOjI2IFBNIFBTVCBVUwpT dWJqZWN0OiBSZTogQWVyb0VsZWN0cmljLUxpc3Q6IHNwZWVkb21ldGVyLCBub3QgdGFjaG9tZXRl ciBxdWVzdGlvbgpGcm9tOiBTYWNoYSA8dXVjY2lvQGdtYWlsLmNvbT4KCgpUaGFua3MgZm9yIHRo ZSB0aXAgRGF2aWQuIApLbm93aW5nIG5vdGhpbmcgYWJvdXQgaG93IHRoZXNlIHRoaW5ncyBhcmUg YnVpbHQgSSBhc3N1bWVkIHRoYXQgdGhpcyB3YXMgYW4gZWxlY3RyaWNhbApwcm9ibGVtIChJIHdh cyBpbWFnaW5pbmcgaXQgd2FzIHRoZSBzaWduIG9mIGEgZmF1bHR5IGdyb3VuZCBjb25uZWN0aW9u KQpidXQgSSBndWVzcyBJIHdhcyBhIGxvbmcgd2F5IG9mZiB0aGUgbWFyay4gIEFwb2xvZ2llcyBm b3IgdGhlIG9mZiB0b3BpYyBwb3N0CmFuZCB0aGFua3MgYWdhaW4gZm9yIGV2ZXJ5Ym9keSdzIGhl bHAuIAoKU2FjaGEKCj4gT24gSnVsIDI4LCAyMDE0LCBhdCAyMzoyOSwgIkRhdmlkIExsb3lkIiA8 c2t5d2Fnb25AY2hhcnRlci5uZXQ+IHdyb3RlOgo+IAo+IElmLCBpbmRlZWQgaXQgaXMgY2FibGUg ZHJpdmUsIHRoYXQgaXMgcHJvYmFibHkgdGhlIHByb2JsZW0uCj4gVGhlIGNhYmxlIGRyaXZlIGlu dGVyaW9yIGdldHMgZHJ5IG92ZXIgdGltZSBhbmQgbG90cyBvZiBmcmljdGlvbiBkZXZlbG9wcy4K PiBGaWd1cmUgb3V0IGEgd2F5IHRvIGRpc2Nvbm5lY3QgdGhlIHRvcCBlbmQgb2YgdGhlIGNhYmxl IGFuZCBzcHJheSBhIHNpbGljb24gYmFzZWQKc3ByYXkgb3Igc2ltaWxhciBkb3duIHRoZSBpbnRl cmlvciBvZiBpdC4KPiBJdCB3aWxsIHRha2Ugc29tZSB0aW1lIHRvIHdvcmsgdGhlIGx1YnJpY2Fu dCBkb3duIGEgdGlnaHQgY2FibGUuCj4gRG9uJ3QgdXNlIFdELTQwLiAgSXQgY29uZ2VhbHMgYWZ0 ZXIgdGltZSBhbmQgaW4gYSBsb25nIGNhYmxlIGRyaXZlIHRoYXQgaXMgYmFkCnNpdHVhdGlvbi4g IERhdmlkCgoKX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX18gIE1lc3NhZ2UgMTggIF9f X19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fXwoKClRpbWU6IDA5OjA3OjA2IFBNIFBT VCBVUwpGcm9tOiAiUm9iZXJ0IEwuIE51Y2tvbGxzLCBJSUkiIDxudWNrb2xscy5ib2JAYWVyb2Vs ZWN0cmljLmNvbT4KU3ViamVjdDogQWVyb0VsZWN0cmljLUxpc3Q6IE5pLUNhZD8KCgoKPgo+R3Jl YXQgYXJ0aWNsZSA5LzE0IEtpdHBsYW5lcwoKICAgVGhhbmsgeW91ICAuIC4gLiBJJ20gZ2F0aGVy aW5nIGluZm8gZm9yIHRoZSA0dGggY2hhcHRlciAuIC4gLgoKPgo+V2lsbCB5b3UgYmUgZG9pbmcg YSBOaUNhZCBjb21wYXJpc29uIGFydGljbGU/ICBUaGUgTmlDYWwgc2VlbXMgdG8gdGFrZSBhIGxv dAo+bW9yZSBwdW5pc2htZW50IHdpdGhvdXQgcHJvYmxlbXMgYW5kIEFpciBCdXMgc2FpZCB0aGV5 IHdlcmUgbG9va2luZyBhdAo+dGhlbS4KCiAgIFRoZXJlIGFyZSB2ZXJ5IGZldyBjb21wYW5pZXMg dGhhdCBvZmZlciBuaS1jYWRzCiAgIHN1aXRlZCB0byBlbmdpbmUgY3JhbmtpbmcuIFRoZSBsZWdh Y3kgd2V0LWNlbGxzCiAgIGFyZSBzdGlsbCBtYWRlIGZvciByZXBsYWNlbWVudCBhbmQgcmVmdXJi aXNobWVudAogICBvZiBhbiBleGlzdGluZyBpbnN0YWxsYXRpb24gYnV0IHRoZXkncmUgbm90CiAg IHdlbGwgbGlrZWQgaW4gdGhlIGdlbmVyYWwgYXZpYXRpb24gY29tbXVuaXR5LgogICBJIHN1Z2dl c3RlZCB0aGF0IHRoZSBPQkFNIGF2aWF0aW9uIGNvbW11bml0eQogICB0YWtlIGEgbG9vayBhdCB3 ZXQgbmktY2FkcyBiYWNrIGFib3V0IDE5ODggLiAuIC4KICAgYnV0IHRoYXQgd2FzIGJhc2VkIG9u IHRoZSBhdmFpbGFiaWxpdHkgb2Ygc3VycGx1cwogICBjZWxscyB0aGF0IGNvdWxkIGJlIHNvcnRl ZCBhbmQgYXNzZW1ibGVkIGludG8KICAgYSBESVkgYmF0dGVyeS4KCiAgIE5leHQgdGltZSBJIHRh bGsgdG8gU2tpcCBLb3NzIGF0IENvbmNvcmRlLCBJJ2xsCiAgIGFzayBoaW0gd2hhdCBoaXMgdGFr ZSBpcyBvbiB0aGUgY3VycmVudCBzdGF0ZQogICBvZiB0aGUgTmktQ2FkIG1hcmtldCAuIC4gLgoK CiAgIEJvYiAuIC4gLiAKCgoKCgpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT0gICAgICAgICAgLSBUaGUgQWVyb0VsZWN0cmlj LUxpc3QgRW1haWwgRm9ydW0gLQpfLT0gVXNlIHRoZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJlcyBO YXZpZ2F0b3IgdG8gYnJvd3NlCl8tPSB0aGUgbWFueSBMaXN0IHV0aWxpdGllcyBzdWNoIGFzIExp c3QgVW4vU3Vic2NyaXB0aW9uLApfLT0gQXJjaGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkg QnJvd3NlLCBDaGF0LCBGQVEsCl8tPSBQaG90b3NoYXJlLCBhbmQgbXVjaCBtdWNoIG1vcmU6Cl8t PQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9BZXJvRWxlY3Ry aWMtTGlzdApfLT0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT0KXy09ICAgICAgICAgICAgICAgLSBNQVRST05JQ1MgV0VCIEZPUlVN UyAtCl8tPSBTYW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFibGUgdmlhIHRoZSBXZWIgRm9y dW1zIQpfLT0KXy09ICAgLS0+IGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQpfLT0KXy09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0K Xy09ICAgICAgICAgICAgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUgLQpfLT0gIFRoYW5r IHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQpfLT0gICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uCl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1h dHJvbmljcy5jb20vY29udHJpYnV0aW9uCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09CgoKCgo ________________________________________________________________________________
Date: Jul 29, 2014
Subject: Re: Garmin 430W - Comm & Nav Power from Separate
Busses Subject: Re: AeroElectric-List: Garmin 430W - Comm & Nav Power from Separate Busses At 04:24 PM 7/26/2014, you wrote: 99, Using the AeroElectric Z-11 schematic, I plan to supply the Nav side of the Garmin 430W from the Essential buss and the Comm side from the Main buss. The Garmin install manual shows the comm and nav functions of the 430W to be powered by separate wires with separate circuit breakers. With my equipment list I don't need the comm function of the 430W during battery only operations but I do need to power the nav side. In an alternator failed situation with the master switch off and the Essential buss alternate switch on, any reason why the 430W nav (GPS & VOR/LOC) will not work with the comm side receiving no power? Not that I know of . . . This excerpt from 430W install manual states that COM power is mere milliamps in receive and significant only in transmit. Emacs! How did your ENDURANCE load analysis come to suggest that Com functions need not be part of an extended battery-only ops scenario? Bob . . . ________________________________________________________________________________
Date: Jul 29, 2014
I have used powdered graphite to lube speedometer cables since the '70s with good success. I'd check with the mfgr and see what they recommend. Raymond Julian Kettle River, MN The things we admire in men, kindness and generosity, openness, honesty, understanding and feeling are the concomitants of failure in our system. And those traits we detest, sharpness, greed, acquisitiveness, meanness, egotism and self-interest are the traits of success. And while men admire the quality of the first they love the produce of the second. -John Steinbeck, novelist, Nobel laureate (1902-1968) On 07/28/2014 04:29 PM, David Lloyd wrote: > > > Sacha, > > If, indeed it is cable drive, that is probably the problem. > The cable drive interior gets dry over time and lots of friction develops. > Figure out a way to disconnect the top end of the cable and spray a > silicon based spray or similar down the interior of it. > It will take some time to work the lubricant down a tight cable. > Don't use WD-40. It congeals after time and in a long cable drive that > is bad situation. David > > ______________________________________________________________________________ > > ----- Original Message ----- From: "Sacha" <uuccio(at)gmail.com> > To: > Sent: Monday, July 28, 2014 1:05 PM > Subject: Re: AeroElectric-List: speedometer, not tachometer question > > >> >> >>> Tachometer-measures engine rpm >>> >>> Thing that measures in Km/h - speedometer (drive train rpm) >> >> Thanks for correcting me Raymond. I meant the speedometer. >> >> It's a 1990 Toyota Hilux so I expect it's driven by cable not >> electronics (but I'm no expert here so correct me if I'm wrong). >> >> >> >> > > ________________________________________________________________________________
Date: Jul 29, 2014
Subject: Re: Ni-Cad?
Back in the early 90s the Royal Navy fleet of SeaKing helicopters (S-61 derivative) used NiCad batteries. We were pretty much banned from using them to start and made sure ground power was always available. They didn't turn the engine over quickly enough to get a reliable start - usually too much fuel and not enough rpm resulted in a hot start with sheets of flame out the exhaust - and potentially an overheated turbine. The batteries were a lot of trouble, I remember several being float tested after aircraft landed back on-board with over heating or smoking battery compartments (now not an option as nothing is allowed over the side). We could also swap out individual cells if a battery went down. I guess the technology has moved on in 20 years, but I still would not be rushing to fit one. Peter On 29/07/2014 05:06, Robert L. Nuckolls, III wrote: > > > >> >> Great article 9/14 Kitplanes > > Thank you . . . I'm gathering info for the 4th chapter . . . > >> >> Will you be doing a NiCad comparison article? The NiCal seems to >> take a lot >> more punishment without problems and Air Bus said they were looking at >> them. > > There are very few companies that offer ni-cads > suited to engine cranking. The legacy wet-cells > are still made for replacement and refurbishment > of an existing installation but they're not > well liked in the general aviation community. > I suggested that the OBAM aviation community > take a look at wet ni-cads back about 1988 . . . > but that was based on the availability of surplus > cells that could be sorted and assembled into > a DIY battery. > > Next time I talk to Skip Koss at Concorde, I'll > ask him what his take is on the current state > of the Ni-Cad market . . . > > > Bob . . . > > ________________________________________________________________________________
Date: Jul 29, 2014
Subject: Re: GNS430 Microphone/Sidetone Problem
Cool! Matt- On Mon, Jul 28, 2014 at 11:41 AM, Jared Yates wrote: > > > > Thanks for all of the troubleshooting tips! I removed the 430, visually > inspected the pins carefully, and reseated it as David suggests, and it is > fixed! > > > > On Jul 26, 2014, at 21:02, "David Lloyd" wrote: > > > skywagon(at)charter.net> > > > > Sacha makes a very good point. . > > The 430 chassis to box-chassis connector fit is finicky. > > I know. . .I have the "T-shirt" > > > > If the box-chassis is mounted in the aircraft panel a little to deep, > this causes a problem. For when the 430 is slid into the box, it will not > seat back deep enough to fully engage some connector pins. > > > > The fix is to loosen up the panel mounted box chassis and pull it > forward to be flush with the panel or even a tad ( 1/16") out in front of > the panel and then re-bolt it back to the panel framing. > > > > Another point. . .I do not recommend that you use the 430 locking jack > mechanism to pull the 430 back into its locked position. If something is > not aligned correctly you will not know it using the this method and could > damage pins. > > > > I suggest that you get the 430 inserted by hand, fingers on each end of > the the 430 panel. Gently rock it back in place feeling for any > obstruction. Get it started in, turn the jacking system just enough to take > up the slack. Then, using fingers only, rock the 430 further back into > place and again feel for any odd resistance, then, using the jack, take up > the slack. > > Continue this until you "feel" it seat properly with it rear connectors. > Stop if you feel any odd resistance and start over after checking for any > bent pins, etc. > > David > > > > ----- Original Message ----- From: "Sacha" <uuccio(at)gmail.com> > > To: > > Sent: Saturday, July 26, 2014 11:20 AM > > Subject: Re: AeroElectric-List: GNS430 Microphone/Sidetone Problem > > > > > >> > >> I had that problem. The GNS430 wasn't fully inserted into its slot and > although the RX and TX button lit up it did not seem to transmit (or > receive as I remember). See > >> > >> > http://forums.matronics.com/viewtopic.php?t=98650&view=next&sid=a9694aaf0de05619e08664647aea1483 > >> > >> > >>> On 26 Jul 2014, at 18:01, Matthew Prather > wrote: > >>> > >>> I think someone had this issue when their radio wasn't fully inserted > into the tray/rack. Might not be the case here, but could be worth checking > out. > > > > > > > > > > > > ________________________________________________________________________________
Busses
Date: Jul 29, 2014
It will work just fine with no power to the comm side, I do it all the time o n my plane. It's set up to power the NAV side and one EFIS from a small aux b att circuit so they don't reboot after start, and as a backup for loss of th e main bus. Tim > On Jul 29, 2014, at 10:17 AM, "Robert L. Nuckolls, III" <nuckolls.bob@aero electric.com> wrote: > > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Garmin 430W - Comm & Nav Power from Separa te Busses > > > At 04:24 PM 7/26/2014, you wrote: > oo.com> > > 99, > Using the AeroElectric Z-11 schematic, I plan to supply the Nav side of th e Garmin 430W from the Essential buss and the Comm side from the Main buss. T he Garmin install manual shows the comm and nav functions of the 430W to be p owered by separate wires with separate circuit breakers. With my equipment l ist I don't need the comm function of the 430W during battery only operation s but I do need to power the nav side. In an alternator failed situation wit h the master switch off and the Essential buss alternate switch on, any reas on why the 430W nav (GPS & VOR/LOC) will not work with the comm side receivi ng no power? > > Not that I know of . . . > > This excerpt from 430W install manual states > that COM power is mere milliamps in receive > and significant only in transmit. > > > <32eb7351.jpg> > > How did your ENDURANCE load analysis come to suggest > that Com functions need not be part of an extended > battery-only ops scenario? > > > Bob . . . ________________________________________________________________________________
Date: Jul 30, 2014
Busses Bob, To your question: As currently designed, the equipment list in my panel has the comm side of the 430 as comm#2 and the nav functions of the 430 as the primary navigation source. With an alternator failure, I want comm#2 to be among the equipment that gets dropped while keeping the navigation functio ns. The comm functions will be handled by a different transceiver as comm#1 . And why not make the 430 the primary comm and nav source? ...Budget. I'd li ke to have the full compliment of panel equipment on day one but its likely that the 430 will be added later. Starting out with only VFR capability an d I'm planning for the full enchilada later. Thanks, William B. --- On Tue, 7/29/14, Robert L. Nuckolls, III wrote: > From: Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> > Subject: Re: AeroElectric-List: Garmin 430W - Comm & Nav Power from Sep arate Busses > To: aeroelectric-list(at)matronics.com > Date: Tuesday, July 29, 2014, 1:17 PM > > > To: aeroelectric-list(at)matronics.com > > Subject: Re: AeroElectric-List: Garmin 430W - Comm & Nav > Power from > Separate Busses > > - How did your ENDURANCE load analysis come to suggest > > - that Com functions need not be part of an extended > > - battery-only ops scenario? > > - Bob . . . > > ________________________________________________________________________________
Date: Jul 30, 2014
Separate Busses At 06:26 AM 7/30/2014, you wrote: >Bob, >To your question: As currently designed, the equipment list in my >panel has the comm side of the 430 as comm#2 and the nav functions >of the 430 as the primary navigation source. With an alternator >failure, I want comm#2 to be among the equipment that gets dropped >while keeping the navigation functions. The comm functions will be >handled by a different transceiver as comm#1. But comm#2 doesn't draw any significant power unless you talk on it . . . so what is the ENDURANCE advantage for shutting it down and making comm#2 unavailable except by bringing the main bus back up? >And why not make the 430 the primary comm and nav source? ...Budget. >I'd like to have the full compliment of panel equipment on day one >but its likely that the 430 will be added later. Starting out with >only VFR capability and I'm planning for the full enchilada later. Okay, you're planning ahead . . . good show. Do you have an battery-only endurance target? Is your engine electrically dependent? Have you run the numbers on battery-only flight at end of battery life? Bob . . . ________________________________________________________________________________
Date: Jul 30, 2014
At 02:10 PM 7/29/2014, you wrote: >Pengilly > >Back in the early 90s the Royal Navy fleet of >SeaKing helicopters (S-61 derivative) used NiCad >batteries. We were pretty much banned from using >them to start and made sure ground power was >always available. They didn't turn the engine >over quickly enough to get a reliable start - >usually too much fuel and not enough rpm >resulted in a hot start with sheets of flame out >the exhaust - and potentially an overheated >turbine. The batteries were a lot of trouble, I >remember several being float tested after >aircraft landed back on-board with over heating >or smoking battery compartments (now not an >option as nothing is allowed over the side). We >could also swap out individual cells if a >battery went down. I guess the technology has >moved on in 20 years, but I still would not be rushing to fit one. The hot-start phenomenon would not have root cause in the chemistry of the batteries, only the sizing- to-task irrespective of chemistry. The volumetric and power density numbers for ni-cad are superior to lead-acid . . . i.e. a PROPERLY SIZED ni-cad will be smaller and lighter than the lead-acid capable of the same starting performance. But as others have noted, ni-cads are not very friendly to the cost of ownership. Their alkaline electrolyte is antagonistic to lead-aced which prompts maintenance operators to have separate shops for dealing with the two technologies . . . which could probably be dispensed with today . . . nobody has to 'maintain' electrolyte in a lead-acid battery any more. The thermal runaway thing was the byproduct of some rather un-creative design decisions. The smaller, lighter cells were very capable of cranking engines but when those engines started, generators rated at hundreds of amps would stuff energy back into the little batteries causing them to warm up. Ni-Cad temperature coefficient of voltage causing them to draw more current from a fixed voltage bus as their temperature rises . . . which causes them to warm up still faster . . . you get the picture. Quoting from Wikipedia at: http://tinyurl.com/7zm7xee "One of the biggest disadvantages is that the battery exhibits a very marked negative temperature coefficient. This means that as the cell temperature rises, the internal resistance falls. This can pose considerable charging problems, particularly with the relatively simple charging systems employed for <http://en.wikipedia.org/wiki/Lead%E2%80%93acid_battery>lead'acid type batteries. Whilst lead'acid batteries can be charged by simply connecting a <http://en.wikipedia.org/wiki/Dynamo>dynamo to them, with a simple electromagnetic cut-out system for when the dynamo is stationary or an over-current occurs, the Ni'Cd battery under a similar charging scheme would exhibit thermal runaway, where the charging current would continue to rise until the over-current cut-out operated or the battery destroyed itself." People who understood batteries published reams of data on how to get the best performance from Ni-Cads . . . data which said "constant current charge" . . . but those- who-know-more-about-airplanes-than-we-do decided that it would be too much to expect an air-framer to install ni-cad friendly starter-generator controllers. They decreed that thermometers be added to ni-cads with displays on the panel along with warning lights for battery overheat. Instead of crafting a battery management system totally transparent to the pilots . . . the pilots were burdened with rudimentary system management duties to offset poor regulatory judgement. Hence, the ni-cad gets this bad rap for being higher risk . . . risks driven by inelegant design. As a chemical energy storage system, ni-cads have a lot going for them. But as we've discussed here on the List . . . there is no such creature as an alternative chemistry, drop-in lead-acid replacement. THERE ARE DIFFERENCES that beg understanding and deference in design, fabrication, installation, operation and maintenance. Whether lead-acid, ni-cad or lithium-ion . . . failure to pay homage to the physics gods is at best just expensive . . . at worst it sets airplanes on fire. Every technology comes with its own constellation of challenges. http://tinyurl.com/kxu3s6j Bob . . . ________________________________________________________________________________
Subject: Ni-Cad?
Date: Jul 31, 2014
Well Said! -john- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Wednesday, July 30, 2014 8:15 AM Subject: Re: AeroElectric-List: Ni-Cad? .. People who understood batteries published reams of data on how to get the best performance from Ni-Cads . . . data which said "constant current charge" . . . but those- who-know-more-about-airplanes-than-we-do decided that it would be too much to expect an air-framer to install ni-cad friendly starter-generator controllers. They decreed that thermometers be added to ni-cads with displays on the panel along with warning lights for battery overheat. Instead of crafting a battery management system totally transparent to the pilots . . . the pilots were burdened with rudimentary system management duties to offset poor regulatory judgement. Hence, the ni-cad gets this bad rap for being higher risk . . . risks driven by inelegant design. As a chemical energy storage system, ni-cads have a lot going for them. But as we've discussed here on the List . . . there is no such creature as an alternative chemistry, drop-in lead-acid replacement. THERE ARE DIFFERENCES that beg understanding and deference in design, fabrication, installation, operation and maintenance. Whether lead-acid, ni-cad or lithium-ion . . . failure to pay homage to the physics gods is at best just expensive . . . at worst it sets airplanes on fire. Every technology comes with its own constellation of challenges. http://tinyurl.com/kxu3s6j Bob . . . ________________________________________________________________________________
Date: Aug 01, 2014
Subject: Panel mounted USB power ports for Apple devices?
Can anybody recommend panel-mounted USB ports to supply power for Apple devices (iPhone/iPad)? I'm not sure if the Apple devices require some special signaling circuitry of the USB port to accept power. I could use a cigarette lighter receptacle and then a plug-in adapter, but I prefer to plug directly into a USB port to charge. Thanks, Ralph Finch Davis, CA USA RV-9A ________________________________________________________________________________
Date: Aug 01, 2014
Subject: Re: Panel mounted USB power ports for Apple devices?
On 8/1/2014 10:17 AM, Ralph Finch wrote: > Can anybody recommend panel-mounted USB ports to supply power for > Apple devices (iPhone/iPad)? I'm not sure if the Apple devices require > some special signaling circuitry of the USB port to accept power. > > I could use a cigarette lighter receptacle and then a plug-in adapter, > but I prefer to plug directly into a USB port to charge. > > Thanks, > Ralph Finch > Davis, CA USA > > RV-9A > iphone 4 & under seem to work ok with any usb supply. The ipads won't charge unless the usb port signals that it's capable of 2.1 amps. It's done with a specific value resistor between two of the pins.There are some inexpensive units on ebay & amazon, but most don't tell you whether they will work with ipads. I've been considering the same issue. Dedicated ports would look nicer, but there is something to be said for the cig lighter socket with plugin adapter. That way, the port on the panel could be temporarily re-purposed for generic automotive devices, if needed. Charlie ________________________________________________________________________________
Date: Aug 01, 2014
On Aug 1, 2014, at 8:17 AM, Ralph Finch wrote: > Can anybody recommend panel-mounted USB ports to supply power for Apple de vices (iPhone/iPad)? As I've mentioned a couple of times in the past, I'm working on just such a p roduct. I admit that with the passage more than a year it probably looks li ke vapor-ware, but I'm getting close. As of about a month ago, I have a ful ly functional final prototype on my bench: It has input over-voltage and reverse-voltage protection, output short circu it protection, USB device sensing so that it automatically configures itself to charge whatever you plug into it, noise filtering so that it plays well w ith other avionics, and it automatically shuts itself off when the aircraft' s alternator is offline. It will rapid-charge two devices simultaneously (i n this photo, the board was charging both my iPad 4 and iPhone 3GS). The bo ard measures 3" x 2" (~76 x 51mm) and uses a rugged panel-mount dual USB rec eptacle. Now I need to get production worked out. I'm a commuting airline guy, and I 'm on reserve with minimum days off, so my time at home has been very limite d. I have the second half of Aug off, so I'm hoping to make some real progr ess then. I can't promise a delivery date, but stay tuned... Eric
Date: Aug 02, 2014
Stein has a panel mount USB port product that works for me. The amps are the issue as others have pointed out. The Stein unit charges up an iPhone fast but also gains ground on an iPad even if it's on and flying... but it does it slowly. That's all I need. I also have a cig lighter with 2 ports that works. One port has the amps required for the iPad, the other doesn't. Why? Don't know. Don't know the brand offhand. On 8/1/2014 11:17 AM, Ralph Finch wrote: > Can anybody recommend panel-mounted USB ports to supply power for > Apple devices (iPhone/iPad)? I'm not sure if the Apple devices require > some special signaling circuitry of the USB port to accept power. > > I could use a cigarette lighter receptacle and then a plug-in adapter, > but I prefer to plug directly into a USB port to charge. > > Thanks, > Ralph Finch > Davis, CA USA > > RV-9A > * > > > * > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > ________________________________________________________________________________
Date: Aug 02, 2014
I have both a phone (an LG) and a tablet (a Nexus 7) that I use in my plane. They both came with the cig lighter adapters for the power supply...and both had USB ports in the adapters instead of a cable connection for the device. The tablet's unit had the higher available output current, so I dismantled the case and removed the circuit board. I mounted the circuit board on the forward side of the instrument panel with a hole through the IP big enough to accept the USB plug from the devices. I only have the one port, but I never need to use the two devices at the same time...I only need it to charge the devices, so I can use either one without being plugged in. I can't remember how I mounted the circuit board to the IP, but I'll take some pictures the next time I'm at the hangar if anyone is interested. Harley ----------------------------------------------------------------- On 8/2/2014 12:50 AM, Bill Watson wrote: > Stein has a panel mount USB port product that works for me. > The amps are the issue as others have pointed out. The Stein > unit charges up an iPhone fast but also gains ground on an iPad > even if it's on and flying... but it does it slowly. That's > all I need. > > I also have a cig lighter with 2 ports that works. One port > has the amps required for the iPad, the other doesn't. Why? > Don't know. Don't know the brand offhand. > > On 8/1/2014 11:17 AM, Ralph Finch wrote: >> Can anybody recommend panel-mounted USB ports to supply power >> for Apple devices (iPhone/iPad)? I'm not sure if the Apple >> devices require some special signaling circuitry of the USB >> port to accept power. >> >> I could use a cigarette lighter receptacle and then a plug-in >> adapter, but I prefer to plug directly into a USB port to charge. >> >> Thanks, >> Ralph Finch >> Davis, CA USA >> >> RV-9A >> * >> * ________________________________________________________________________________
Date: Aug 02, 2014
You cannot ignore DX.Com who sells these for $1.99 with FREE Airfreight Shipping. Search Ipod Adapter. They also have a large number of user-reviewed similar devices. How anyone can sell and ship these for $1.99 is a mystery, but they do. While you're at it grab the LED flashlights. Don't cheap-out on these. The cheap ones are good, the more expensive ones are astonishing. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427831#427831 ________________________________________________________________________________
Date: Aug 02, 2014
Subject: icom A210 upgrade
Icom and their vendors state that the A210 com radio is a slide in replacement for the A200 as long as you are not using the built in intercom. However the A210 also outputs rs232 data on pin 1 of the card edge connector and that pin is grounded to make the panel light work on the A200. I can spend a lot of time trying to disconnect that pin and hope nothing else gets interfered with in the tight space behind my panel but I've been trying to determine if leaving that pin grounded will actually harm the data output circuitry on the A210? I'm not likely to ever use the data output but if someone knows that there is little risk of leaving it grounded, I'd sure appreciate hearing about it. thanks Ken ________________________________________________________________________________
Date: Aug 03, 2014
Subject: Re: icom A210 upgrade
At 11:47 AM 8/2/2014, you wrote: > >Icom and their vendors state that the A210 com radio is a slide in >replacement for the A200 as long as you are not using the built in >intercom. However the A210 also outputs rs232 data on pin 1 of the >card edge connector and that pin is grounded to make the panel light >work on the A200. I can spend a lot of time trying to disconnect >that pin and hope nothing else gets interfered with in the tight >space behind my panel but I've been trying to determine if leaving >that pin grounded will actually harm the data output circuitry on >the A210? I'm not likely to ever use the data output but if someone >knows that there is little risk of leaving it grounded, I'd sure >appreciate hearing about it. It appears that Pin 1 on the A200 was ground for the panel lighting. The A210 Service Manual says the RS232 input/output is managed by an Analog Devices ADM202. In the data sheet for this part we find the statement: Emacs! It appears that nothing untoward will happen if you don't unground pin 1. Bob . . . ________________________________________________________________________________
Date: Aug 04, 2014
Ralph, Could you find a suitable automotive version, and simply take it out of the cigar lighter package and hard wire into the plane? I think that's what I would do. It gives you a chance to try all sorts of low-cost items and then pick a couple of the right ones. For the presentation at the instrument panel, I would go for a USB extension cable for ease of mounting. This can then plug into your power supply. FWIW. James On 1 August 2014 16:17, Ralph Finch wrote: > Can anybody recommend panel-mounted USB ports to supply power for Apple > devices (iPhone/iPad)? I'm not sure if the Apple devices require some > special signaling circuitry of the USB port to accept power. > > I could use a cigarette lighter receptacle and then a plug-in adapter, but > I prefer to plug directly into a USB port to charge. > > Thanks, > Ralph Finch > Davis, CA USA > > RV-9A > > * > > > * > > ________________________________________________________________________________
Date: Aug 04, 2014
Date: Aug 04, 2014
At 06:07 AM 8/4/2014, you wrote: >Ralph, > >Could you find a suitable automotive version, >and simply take it out of the cigar lighter >package and hard wire into the plane? I think >that's what I would do. It gives you a chance >to try all sorts of low-cost items and then pick a couple of the right ones. > >For the presentation at the instrument panel, I >would go for a USB extension cable for ease of >mounting. This can then plug into your power supply. > >FWIW. > >James There are hundreds of options. The greatest risk for most options are (1) expenditure of $time$ to integrate the device into the airplane (2) performance to requirements and (3) radiated and conducted EMC. The technology is mature . . . 2 and 3 are relatively low value risks. But one can spend a lot of hammer-n-tongs effort making a 'clean' and robust installation. Condider products tailored to the task like these http://tinyurl.com/m8kfz6h http://tinyurl.com/qhdwgdl This would be a good value at 3x the price due to it's ease of installation. No sheet metal work what so ever except to cut usb connector clearance holes. Bob . . . ________________________________________________________________________________
Date: Aug 04, 2014
On 03/08/2014 12:29 PM, Robert L. Nuckolls, III wrote: > At 11:47 AM 8/2/2014, you wrote: >> >> Icom and their vendors state that the A210 com radio is a slide in >> replacement for the A200 as long as you are not using the built in >> intercom. However the A210 also outputs rs232 data on pin 1 of the >> card edge connector and that pin is grounded to make the panel light >> work on the A200. I can spend a lot of time trying to disconnect that >> pin and hope nothing else gets interfered with in the tight space >> behind my panel but I've been trying to determine if leaving that pin >> grounded will actually harm the data output circuitry on the A210? I'm >> not likely to ever use the data output but if someone knows that there >> is little risk of leaving it grounded, I'd sure appreciate hearing >> about it. > > > It appears that Pin 1 on the A200 was > ground for the panel lighting. > > The A210 Service Manual says the RS232 > input/output is managed by an Analog Devices > ADM202. In the data sheet for this part > we find the statement: > > Emacs! > > It appears that nothing untoward will > happen if you don't unground pin 1. > > > Bob . . . > Many thanks Bob. Your post gave me the hint I needed to sleuth out the rest of the story. The standard card edge connector on my radio is different from the schematic and board diagrams in the service manual that I have (with Feb 2008 addendum). The data sheet for the ADM202 does indeed show continuous short circuit as an absolute maximum condition but it also says "Exposure to absolute maximum rating conditions for extended periods may affect device reliability." The icom manual shows a 1K resistor in series with the rs232 line out if you fit the optional Dsub back panel to the radio. It shows no connection to pin 2 for the standard card edge back panel but it does show a 100R resistor to the separate data out jack. I was able to confirm that my radio in fact has a 1K resistor in series with pin 2. So I can interchange the A200 and A210 without modifying the aircraft tray and without any worries since I'm not using the intercom function. thanks again Ken ________________________________________________________________________________
Date: Aug 04, 2014
One of the OSH aviation vendors had a two usb port black plastic jack that looked like a drop in replacement for a cigarette lighter panel hole. I don't have any other details other than it had a flip up plastic cover and I believe it was intended to be wired directly to 12 volt power. Ken On 04/08/2014 10:32 AM, Robert L. Nuckolls, III wrote: > > > At 06:07 AM 8/4/2014, you wrote: >> Ralph, >> >> Could you find a suitable automotive version, and simply take it out >> of the cigar lighter package and hard wire into the plane? I think >> that's what I would do. It gives you a chance to try all sorts of >> low-cost items and then pick a couple of the right ones. >> >> For the presentation at the instrument panel, I would go for a USB >> extension cable for ease of mounting. This can then plug into your >> power supply. >> >> FWIW. >> >> James > > There are hundreds of options. The greatest risk for > most options are (1) expenditure of $time$ to integrate > the device into the airplane (2) performance to requirements > and (3) radiated and conducted EMC. > > The technology is mature . . . 2 and 3 are relatively > low value risks. But one can spend a lot of hammer-n-tongs > effort making a 'clean' and robust installation. Condider > products tailored to the task like these > > http://tinyurl.com/m8kfz6h > > http://tinyurl.com/qhdwgdl > > This would be a good value at 3x the price due to > it's ease of installation. No sheet metal work > what so ever except to cut usb connector clearance > holes. > > > Bob . . . > > ________________________________________________________________________________
Date: Aug 04, 2014
On 8/4/2014 10:32 AM, Robert L. Nuckolls, III wrote: > > The technology is mature . . . 2 and 3 are relatively > low value risks. But one can spend a lot of hammer-n-tongs > effort making a 'clean' and robust installation. Condider > products tailored to the task like these > > http://tinyurl.com/m8kfz6h > FYI, I installed this very unit in my aircraft, only to find out that it does not have the proper resistors installed for the iPad to charge (I note now that the listing has a reference "can't be used for iphone" which was not there when I bought mine). I ended up hacking the end of the iPad's USB cable to add the resistors (actually I added a micro-sized potentiometer adjusted to the proper resistance), which is now dedicated to the airplane, and it charges the ipad just fine. Not difficult, but not as "clean" an installation as I had originally envisioned. -Dj -- Dj Merrill - N1JOV - VP EAA Chapter 87 Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Date: Aug 04, 2014
repost with pin number 1 correction in last comment (pin 2 ref. is corrected to pin 1) On 04/08/2014 11:07 AM, Ken wrote: > > On 03/08/2014 12:29 PM, Robert L. Nuckolls, III wrote: >> At 11:47 AM 8/2/2014, you wrote: >>> >>> Icom and their vendors state that the A210 com radio is a slide in >>> replacement for the A200 as long as you are not using the built in >>> intercom. However the A210 also outputs rs232 data on pin 1 of the >>> card edge connector and that pin is grounded to make the panel light >>> work on the A200. I can spend a lot of time trying to disconnect that >>> pin and hope nothing else gets interfered with in the tight space >>> behind my panel but I've been trying to determine if leaving that pin >>> grounded will actually harm the data output circuitry on the A210? I'm >>> not likely to ever use the data output but if someone knows that there >>> is little risk of leaving it grounded, I'd sure appreciate hearing >>> about it. >> >> >> It appears that Pin 1 on the A200 was >> ground for the panel lighting. >> >> The A210 Service Manual says the RS232 >> input/output is managed by an Analog Devices >> ADM202. In the data sheet for this part >> we find the statement: >> >> Emacs! >> >> It appears that nothing untoward will >> happen if you don't unground pin 1. >> >> >> Bob . . . >> > Many thanks Bob. Your post gave me the hint I needed to sleuth out the > rest of the story. > > The standard card edge connector on my radio is different from the > schematic and board diagrams in the service manual that I have (with Feb > 2008 addendum). > > The data sheet for the ADM202 does indeed show continuous short circuit > as an absolute maximum condition but it also says "Exposure to > absolute maximum rating conditions for extended periods may > affect device reliability." > > The icom manual shows a 1K resistor in series with the rs232 line out if > you fit the optional Dsub back panel to the radio. It shows no > connection to pin 1 for the standard card edge back panel but it does > show a 100R resistor to the separate data out jack. I was able to > confirm that my radio in fact has a 1K resistor in series with pin 1. So > I can interchange the A200 and A210 without modifying the aircraft tray > and without any worries since I'm not using the intercom function. > > thanks again > Ken > > ________________________________________________________________________________
Date: Aug 04, 2014
>Many thanks Bob. Your post gave me the hint I needed to sleuth out >the rest of the story. > >The standard card edge connector on my radio is different from the >schematic and board diagrams in the service manual that I have (with >Feb 2008 addendum). > >The data sheet for the ADM202 does indeed show continuous short >circuit as an absolute maximum condition but it also says "Exposure to >absolute maximum rating conditions for extended periods may >affect device reliability." Yes, but reliability only for that function which takes a specialized GPS based mapping/data base product . . . does anyone offer such a thing? Not sure I'd want any 'automatic' gizmo twisting my radio knobs anyhow. >The icom manual shows a 1K resistor in series with the rs232 line >out if you fit the optional Dsub back panel to the radio. It shows >no connection to pin 2 for the standard card edge back panel but it >does show a 100R resistor to the separate data out jack. I was able >to confirm that my radio in fact has a 1K resistor in series with >pin 2. So I can interchange the A200 and A210 without modifying the >aircraft tray and without any worries since I'm not using the >intercom function. Didn't see how the intercom function came into consideration . . . are those two pins not limited to panel lighting in the A200? Bob . . . ________________________________________________________________________________
Date: Aug 04, 2014
On 04/08/2014 12:11 PM, Robert L. Nuckolls, III wrote: > > > >> Many thanks Bob. Your post gave me the hint I needed to sleuth out the >> rest of the story. >> >> The standard card edge connector on my radio is different from the >> schematic and board diagrams in the service manual that I have (with >> Feb 2008 addendum). >> >> The data sheet for the ADM202 does indeed show continuous short >> circuit as an absolute maximum condition but it also says "Exposure to >> absolute maximum rating conditions for extended periods may >> affect device reliability." > > Yes, but reliability only for that function which > takes a specialized GPS based mapping/data base > product . . . does anyone offer such a thing? > Not sure I'd want any 'automatic' gizmo twisting > my radio knobs anyhow. > >> The icom manual shows a 1K resistor in series with the rs232 line out >> if you fit the optional Dsub back panel to the radio. It shows no >> connection to pin 1 for the standard card edge back panel but it does >> show a 100R resistor to the separate data out jack. I was able to >> confirm that my radio in fact has a 1K resistor in series with pin 1. >> So I can interchange the A200 and A210 without modifying the aircraft >> tray and without any worries since I'm not using the intercom function. > > Didn't see how the intercom function came into > consideration . . . are those two pins not limited > to panel lighting in the A200? > > > Bob . . . > I don't expect to use the GPS data base either (nor do I know if it is available) but strange things happen and I did not want to give icom any excuses to void the warranty. There is actually a warning on the icom site about changes in the intercom and GPS connections on the A210. The vendor and icom both mentioned intercom connection changes. I just didn't want steer anyone wrong with my conclusion since some folks probably are using the intercom function. Ken ________________________________________________________________________________
Date: Aug 04, 2014
> >I don't expect to use the GPS data base either (nor do I know if it >is available) but strange things happen and I did not want to give >icom any excuses to void the warranty. > >There is actually a warning on the icom site about changes in the >intercom and GPS connections on the A210. The vendor and icom both >mentioned intercom connection changes. I just didn't want steer >anyone wrong with my conclusion since some folks probably are using >the intercom function. Understand. Bob . . . ________________________________________________________________________________
Date: Aug 04, 2014
These are worth a look: http://commitlift.com/ The supplier is an excellent source of information. Richard Lyon On 4 August 2014 16:49, Dj Merrill wrote: > > > On 8/4/2014 10:32 AM, Robert L. Nuckolls, III wrote: > >> >> The technology is mature . . . 2 and 3 are relatively >> low value risks. But one can spend a lot of hammer-n-tongs >> effort making a 'clean' and robust installation. Condider >> products tailored to the task like these >> >> http://tinyurl.com/m8kfz6h >> >> > FYI, I installed this very unit in my aircraft, only to find out that it > does not have the proper resistors installed for the iPad to charge (I note > now that the listing has a reference "can't be used for iphone" which was > not there when I bought mine). > > I ended up hacking the end of the iPad's USB cable to add the resistors > (actually I added a micro-sized potentiometer adjusted to the proper > resistance), which is now dedicated to the airplane, and it charges the > ipad just fine. > > Not difficult, but not as "clean" an installation as I had originally > envisioned. > > -Dj > > -- > Dj Merrill - N1JOV - VP EAA Chapter 87 > Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ > Glastar Flyer N866RH - http://deej.net/glastar/ > > ________________________________________________________________________________
From: "H. Marvin Haught" <handainc(at)madisoncounty.net>
Date: Aug 04, 2014
Just what I was looking for....Thanks for the reference. M. Haught On Aug 4, 2014, at 4:01 PM, Richard Lyon wrote: > These are worth a look: > > http://commitlift.com/ > > The supplier is an excellent source of information. > > Richard Lyon > > > On 4 August 2014 16:49, Dj Merrill wrote: > > > On 8/4/2014 10:32 AM, Robert L. Nuckolls, III wrote: > > The technology is mature . . . 2 and 3 are relatively > low value risks. But one can spend a lot of hammer-n-tongs > effort making a 'clean' and robust installation. Condider > products tailored to the task like these > > http://tinyurl.com/m8kfz6h > > > FYI, I installed this very unit in my aircraft, only to find out that it does not have the proper resistors installed for the iPad to charge (I note now that the listing has a reference "can't be used for iphone" which was not there when I bought mine). > > I ended up hacking the end of the iPad's USB cable to add the resistors (actually I added a micro-sized potentiometer adjusted to the proper resistance), which is now dedicated to the airplane, and it charges the ipad just fine. > > Not difficult, but not as "clean" an installation as I had originally envisioned. > > -Dj > > -- > Dj Merrill - N1JOV - VP EAA Chapter 87 > Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ > Glastar Flyer N866RH - http://deej.net/glastar/ > > > ======================== =========== > - > ric-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List > ======================== =========== > MS - > k">http://forums.matronics.com > ======================== =========== > e - > -Matt Dralle, List Admin. > t="_blank">http://www.matronics.com/contribution > ======================== =========== > > > > > > > ________________________________________________________________________________
Date: Aug 05, 2014
Subject: USB "tester"
I don't know anything about this item: http://www.mpja.com/08-05-14.asp?r=376592&s=4 It looks like it might be useful for those installing usb power outlets. My experience with this supplier has been positive. FWIW -- Raymond Julian Kettle River, MN The things we admire in men, kindness and generosity, openness, honesty, understanding and feeling are the concomitants of failure in our system. And those traits we detest, sharpness, greed, acquisitiveness, meanness, egotism and self-interest are the traits of success. And while men admire the quality of the first they love the produce of the second. -John Steinbeck, novelist, Nobel laureate (1902-1968) ________________________________________________________________________________
Date: Aug 05, 2014
On 8/4/2014 11:49 AM, Dj Merrill wrote: > I ended up hacking the end of the iPad's USB cable to add the > resistors (actually I added a micro-sized potentiometer adjusted to > the proper resistance), which is now dedicated to the airplane, and it > charges the ipad just fine. > > Not difficult, but not as "clean" an installation as I had originally > envisioned. I had an inquiry about how I did this and thought I would share with the group. The micro-sized potentiometer I grabbed from my junk bin and don't remember the exact value, probably 100 ohms or 1K. It isn't critical. Here is the guide I used: http://www.instructables.com/id/THE-Simplest-iPod-iPad-iPhone-charger-circuit/?ALLSTEPS You'll want to read through it for the general idea. I used the "trim pot" method shown in step 4. If you are using the power supply that Bob sent out (http://tinyurl.com/m8kfz6h), all you need is the the trim pot, and none of the other parts mentioned in the article. All you are doing is connecting the middle connection on the trim pot to pins 2 and 3 of the USB cable, and the other two pins on the trim pot go to pin 1 and pin 4 respectively. Then adjust the trim pot until you get a value of 2 volts between the center pin on the trim pot and pin 4 on the USB (which is GND). The right half of this diagram sums it up nicely: http://cdn.instructables.com/FOD/L2X9/HJKBMVWW/FODL2X9HJKBMVWW.LARGE.jpg I added this to the USB cable itself rather than the power supply because the power supply and plugs are all molded plastic and there wasn't an easy way to get inside without making a mess. The USB cable simply had a plastic cover that slid back along the cable and was much easier to work with. When I was finished adjusting the trim pot I put some heat shrink over the entire assembly (USB cable, connector, potentiometer and all) so it is sealed up and won't be accidentally turned. This is similar to the micro-potentiometer that I used: http://www.ebay.com/itm/Horizontal-PCB-Mount-Micro-Potentiometer-Japan-VTG-271-280-Archer-Radio-Shack-/191238164441 -Dj -- Dj Merrill - N1JOV - VP EAA Chapter 87 Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Subject: Half wave copper foil dipole transponder antenna
Date: Aug 05, 2014
I hope this isn't a duplicate, but I was unable to find sufficient info on this topic in the archives. I have successfully built and tested several copper foil/tape comm antennas for my Cozy MkIV and would like to build a transponder antenna the same way. Will the following work for a Mode S transponder: 1. Vertically oriented 1/2 wave dipole. 2. 1/2" copper tape with ferrites 3. Each leg 6.25" long Thanks. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=428048#428048 ________________________________________________________________________________
Subject: Re: Half wave copper foil dipole transponder antenna
Date: Aug 05, 2014
See. http://www.cozybuilders.org/ref_info/RST_82704.pdf The transponder is a little different than the other antennae. The reference discusses it. Keep the coax run short and put it on the bottom of the airplane. Mine is under removable front seats. You can make the antenna from an AN bolt but they are very cheap on ebay. -kent > On Aug 5, 2014, at 3:23 PM, "rnbraud" wrote: > > > I hope this isn't a duplicate, but I was unable to find sufficient info on this
July 10, 2014 - August 05, 2014
AeroElectric-Archive.digest.vol-mk
