AeroElectric-Archive.digest.vol-mp
November 23, 2014 - December 24, 2014
      assuming the radio (normal current 500mA or less - only 3A on tx), txpdr
      & smoke pump are switch separately. 600mA should be tolerable for just
      about any switch, and even 8 or 10A occasionally for any reasonable
      quality switch.
      Wobble pumps seem popular, but to my mind are only useful for starting.
      A friend with a Laser ended up in a field when his mech pump failed and
      he couldn't wobble enough to keep airborne. An electric pump will at
      least get you home.
      Peter
      On 23/11/2014 09:01, Ryan wrote:
      > Thanks Bob,
      > The whole system is reasonably low load although I do have an EFIS and
      > engine sensors (approx. 600mA total), Trig radio (approx. 3.2A) and
      > transponder (approx. 1.5A), these are the only things running
      > continuously. Also have starter and smoke pump (approx. 3-4A
      > for 8-10min max), no electric fuel pump (wobble only), no lights.
      > Battery is a Shorai LFX18A1-BS12 LiFe (18Ah Pb 270CCA equiv. supposedly).
      >     "As far as compliance with legacy notions of seeking
      >     'Max Cold' conditions in the wiring with all switches
      >     OFF, you COULD use a battery master relay that did not
      >     carry starter current while locating the external
      >     starter contactor adjacent to the battery too."
      > This is how I was likely to do the wiring, I could just go for a
      > reasonably low current relay as a master contactor in this situation
      > given my relatively low overall requirement.
      > No MOV's then but will use starter contactor with diode close to battery?
      > Cheers,
      > Ryan
      > Date: Tue, 18 Nov 2014 14:31:58 -0600
      > To: aeroelectric-list(at)matronics.com
      > From: nuckolls.bob(at)aeroelectric.com
      > Subject: AeroElectric-List: Re: Wiring schematic question
      > At 03:41 2014-11-17, you wrote:
      >  Hi Bob,
      > I have been in email discussion with Greg Jones at B&C about a few
      > things on my Pitts Special and he suggested you would be best to speak
      > with about the Aerobatic Aircraft wiring schematic on their website,
      > it was made mention that you drew it up.
      > Drawing number 420-506
      > http://www.bandc.biz/pdfs/420-506_Indexed_Diagram_with_BOM.pdf
      > http://www.bandc.biz/pdfs/420-506_REVB.pdf
      > <http://www.bandc.biz/pdfs/420-506_REVB.pdf>I had a couple of
      > questions, hopefully you can assist a little.
      >     My apologies, I didn't 'scope out the rest of the diagram.
      >     No, that general architecture was not suggested by me but
      >     the diagram does have some features borrowed from the z-figures
      >     of that era. For one thing, the MOV's as transient suppressors
      >     was NOT a good idea. We abandoned that recommendation in
      >     the AeroElectic Connection . . . oh . . .I forget. But a long
      >     time ago.
      >     With an SD-8, one is indeed strapped for 'surplus energy'
      >     so elimination of the battery contactor is a useful thing
      >     from the energy management perspective. Do you KNOW what
      >     your ship's running loads are? How big is your battery?
      >     What kind of strobe system . . . and current draw?
      >     As long as your battery is in good condition and fully
      >     charged at engine start, the probability of a contactor
      >     sticking is very low. It's the tentative closures when
      >     a soggy battery is trying to grunt the starter that
      >     gets you a stuck contactor. At the same time, the
      >     modern intermittent duty starter contactors are much
      >     more resistant to sticking under all conditions . . . again
      >     assuming that you 'drive 'em hard' . . . 20AWG wire
      >     to the 5A coil is a good idea.
      >     However, your risks are low using the diagram as published.
      >     The only changes I would recommend are using diodes
      >     across the contactor coils . . . and the starter
      >     contactor that B*C sells already has one installed. *
      >     *Ditch the MOVs. Does this cover 'the rest of the story?'*
      >   Bob . . .
      > _blank">www.aeroelectric.com
      > " target="_blank">www.buildersbooks.com
      > ="_blank">www.homebuilthelp.com
      > ="_blank">www.mypilotstore.com
      > ank">www.mrrace.com
      > ="_blank">http://www.matronics.com/contribution
      > -List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
      > http://forums.matronics.com
Date: Nov 23, 2014
Subject: Re: EMC lab look-see on HID lamps
At 11:39 AM 11/22/2014, you wrote: We installed the very first Duckworks HID light kit sold for a Sportsman. We had to modify the kit and make our own lens since Duckworks had never sold a kit for a Sportsman so we were told. We installed the largest bulbs available, I think 75w. We've turned them on several times, but since we are still not flying don't know how they will work for takeoff and landing. They are really, really bright. However, since we have a super-loaded 3-screen panel with all sorts of other electrical goodies for our electrically dependent Subaru engine, we are thinking we should have waited much longer to install landing light and chosen LED so the current draw woud be much lower. Landing lights, in every era of aviation, have significant influence on issues of POWER (breaker, switch and wire sizing) but very little influence on ENERGY (alternator, battery sizing). They're an intermittent load really useful for mere seconds of every flight cycle. Have you done a load analysis on your project? One of my partners is worried that the Duckworks HIDs will give super light for take-off and landing, but maybe not for taxiing. We'll see. MOST of the HID after-market targets were focused on down-the-road visibility, not much interest in seeing around corners, therefore, tightly beamed. A further thought suggesets that very little light is needed to avoid taxiing onto the grass . . . but even if the 'scatter' from your landing light is sufficient to the task, the thing could make you unpopular on the airport. We were taught at Mid Continent to minimize the use of any lights on the GA ramps and taxiways . . . having a bond-fide retina-burner for a landing/taxi light could draw some unkindly words from others out and about in their airplanes after dark. Is the Sportsman a tail dragger? Is the Duckworths installation dual . . . one on each wing? You may find that it's quite sufficient to leave one side fitted with HID and replace the other side's lamp with an LED flood for taxi. Bob . . . ________________________________________________________________________________
Date: Nov 23, 2014
From: DeWitt Whittington <dee.whittington(at)gmail.com>
Thanks for the comments, Bob. We have a tri-gear Sportsman and dual just-inside-the-wingtips Duckworks HID lights. We have discussed the possibility of installing a basic 100w halogen light in the cowl to use for taxiing, but we were going to defer that decision until we test our installation when we move to the airport from the 3-car garage where we are building. I'm sure you are right about current draw problems since we'll not be using the HID lights when we have the pitot heat on which is our heaviest single draw. And yes, we have done a basic load analysis which is what showed us we were indeed loading the system to at least within 20% of the full 75amp output of the alternator at times. We have dual Odyssey 680 batteries to support our 3.6L Subaru. And we have the Vertical Power VP-200 system to control most of our electrical system except the direct powering of the ECU to the Subaru to make sure even with a total VP-200 failure the engine would continue to operate. Dee DeWitt (Dee) Whittington Richmond, VA 804-677-4849 iPhone 804-358-4333 Home On Sun, Nov 23, 2014 at 11:07 AM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > nuckolls.bob(at)aeroelectric.com> > > > At 11:39 AM 11/22/2014, you wrote: > We installed the very first Duckworks HID light kit sold for a Sportsman. > We had to modify the kit and make our own lens since Duckworks had never > sold a kit for a Sportsman so we were told. We installed the largest bulbs > available, I think 75w. We've turned them on several times, but since we > are still not flying don't know how they will work for takeoff and landing. > They are really, really bright. However, since we have a super-loaded > 3-screen panel with all sorts of other electrical goodies for our > electrically dependent Subaru engine, we are thinking we should have waited > much longer to install landing light and chosen LED so the current draw > woud be much lower. > > Landing lights, in every era of aviation, have > significant influence on issues of POWER (breaker, > switch and wire sizing) but very little influence > on ENERGY (alternator, battery sizing). > > They're an intermittent load really useful for > mere seconds of every flight cycle. Have you > done a load analysis on your project? > > > One of my partners is worried that the Duckworks HIDs will give super > light for take-off and landing, but maybe not for taxiing. We'll see. > > MOST of the HID after-market targets were > focused on down-the-road visibility, > not much interest in seeing around corners, > therefore, tightly beamed. A further thought > suggesets that very little light is needed to avoid > taxiing onto the grass . . . but even if the > 'scatter' from your landing light is sufficient > to the task, the thing could make you unpopular > on the airport. We were taught at Mid Continent > to minimize the use of any lights on the GA > ramps and taxiways . . . having a bond-fide > retina-burner for a landing/taxi light could > draw some unkindly words from others out and > about in their airplanes after dark. > > Is the Sportsman a tail dragger? Is the Duckworths > installation dual . . . one on each wing? You may > find that it's quite sufficient to leave one > side fitted with HID and replace the other side's > lamp with an LED flood for taxi. > > Bob . . . > > ________________________________________________________________________________
Date: Nov 23, 2014
Subject: Voltage regulator recommendation?
I'm in the market for a new "Ford-type VR166" voltage regulator. My existing one produces occasional "switching noise" that's audible in my intercom. Worse yet, with the onset of cooler weather the charging voltage has been creeping upward (15.0 volts after start settling down to 14.7 in a few minutes). There are no adjustments so I'd like to replace it with one of proven quality. Can anyone give me a first-hand recommendation for a voltage regulator that they're happy with and doesn't cost an arm-and-a-leg? Not a "just Google VR166 regulator" or look on eBay please. Thanks, Joe Independence, OR ________________________________________________________________________________
Date: Nov 23, 2014
Subject: Just A Few Days Left...
Dear Listers, There are just a few days left for this year's List Fund Raiser. If you've been putting off making a Contribution until the last minute, well, this is it! The last minute, that is... :-) There are some GREAT new gift selections to choose from this year. I personally want at least three of them! There's probably something you can't live without too! And, best of all it supports your Lists! Please remember that there isn't any sort of commercial advertising on the Lists and the *only* means of keeping these Lists running is through your Contributions during this Fund Raiser. Let's make this a "Black Friday" for the Lists! Please make a Contribution today! http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 23, 2014
I built medical lighting systems for decades. These included halogens, HIDs, xenon arcs, flashing xenon gas tubes, even flashing short-arcs, HP Sodiums and some other esoteric systems such as mercury arc UV systems. I am also a giant proponent of LEDs. But I could easily make the case for HIDs being the premier light source as far as optics go, because they have the highest source luminance of any possible (okay, non-nuclear) light source. This is to say, they are very small and very brilliant, which makes possible the design of optics sending the most light down range most effectively. So why doesn't the whole world use HIDs? Two reasons: 1) It's because they require power supplies (ballasts + starters) that are specifically designed for them. These power supplies used to be relatively expensive, but not so now. Although HIDs have remarkably long lifetimes (5000 hours is typical), the power supplies have shorter lifetimes than that, especially if they are abused. 2) They are still relatively new. We have seen small HIDs only since 1990. Even though LEDs will be everywhere, we will still see HIDs where long searchlight beams are required. Xenons will be a player too, mostly where color rendition is critical and cost isn't. My experience has never been that HIDs are noisy. The trick is to keep the electrodes in thermionic emission (hot). A cool electrode makes a noisy lamp. Since I sell wig-wags where people want to use them with HIDs, I offer the following abbreviated advice: --everything I know says not to wig-wag HID lamps because they will have shorter lamp lifetimes. Everything that is an advantage of HID lamps disappears quickly if one abuses them by, oh let's say 2500 restarts per hour! ... Furthermore, switched mode power supplies and starters are particularly failure-prone when abused. I can promise you that the manufacturer of the lamp-supply and starter DO NOT warranty their devices to be used in this fashion. But here is what it takes if you want to do it. Here are the basic issues with HID lamps used with Perihelion Designs Wig-Wags: 1: The high-voltage ignition can feed back through the wiring and destroy solid-state electronics. Everything might be okay, then on some rainy nightka-pow! To prevent this I have added a bidirectional Zener, near the ballast. DO NOT put it between the HV ignitor and the lamp. These parts are P6KE18CA (for 14V systems) which I also sell as SnapJacks. 2: The sudden negative resistance of the lamp induces a large current, which if it comes from the Wig-Wag, will destroy the device. A CL-21 Inrush current limiter will prevent this for HID lamps up to 50 W. For larger HID lamps use CL-11. The current limiters will get hot, as they are supposed to, and should be placed where they dont get air-cooled. So I still love LEDs, but if you really need to see the deer at the other end of the runway, HIDs will do the job. If you want to wig-wag them, expect shorter lamp lifetimes, and shorter ballast lifetimes. ps: Bob, my last (175W) xenon short arc system was so EMC/RFI quiet that the test technician could not tell if it was on or off unless he opened the test chamber door and LOOKED to see if it had light coming out. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=434465#434465 ________________________________________________________________________________
Date: Nov 23, 2014
>I'm sure you are right about current draw problems since we'll not >be using the HID lights when we have the pitot heat on which is our >heaviest single draw. And yes, we have done a basic load analysis >which is what showed us we were indeed loading the system to at >least within 20% of the full 75amp output of the alternator at times. I'd like to see that analysis . . . Did an analysis on a full-up IFR outfitted RV some years back and came up with a 27A max continuous load . . . it would be enlightening to see your list of loads. Bob . . . ________________________________________________________________________________
Date: Nov 23, 2014
Subject: Re: Voltage regulator recommendation?
At 11:10 2014-11-23, you wrote: I'm in the market for a new "Ford-type VR166" voltage regulator. My existing one produces occasional "switching noise" that's audible in my intercom. Worse yet, with the onset of cooler weather the charging voltage has been creeping upward (15.0 volts after start settling down to 14.7 in a few minutes). There are no adjustments so I'd like to replace it with one of proven quality. Can anyone give me a first-hand recommendation for a voltage regulator that they're happy with and doesn't cost an arm-and-a-leg? Not a "just Google VR166 regulator" or look on eBay please. You sound 'cautious' as to your selection of devices. The modern incarnation of that product line is 40+ years old and it seems that everyone still making them should have figured out how to do it. The best recommendation anyone can make is "I got an XXX by YYY and it's not given me any trouble for ZZZ hours." But I'm pretty sure that 99% of what's offered out there would deliver to the same observation. Regulators are not critical for comfortable continuation of flight, therefore, sampling from the range of offerings is a low risk experiment and the odds are very much in your favor. Go to a local auto parts store and get one of their VR166 (or clone) . . . with $20 price point. Here's a few of many possibilities. http://tinyurl.com/puzalge http://tinyurl.com/l9jvymv http://tinyurl.com/l9jvymv The Wells VR749 and Motorcraft GR540 are alternative numbers to cross reference. Bob . . . ________________________________________________________________________________
Date: Nov 24, 2014
Bob, would you happen to have any part numbers for an ADJUSTABLE voltage regulator for use with 12 volt 60 A Ford type alternators? Thanks. -------- Jerry King Read this topic online here: http://forums.matronics.com/viewtopic.php?p=434484#434484 ________________________________________________________________________________
Date: Nov 24, 2014
At 07:47 2014-11-24, you wrote: > >Bob, would you happen to have any part numbers for an ADJUSTABLE >voltage regulator for use with 12 volt 60 A Ford type alternators? Thanks. No, I've never seen one in the wild. Some years ago, I explored the idea of adding a trim pot to the board of an existing design. I bonded a ten-turn pot to the top surface of a the ECB aligned with an access hole in the lid. Then added some jumper wires and one resistor to the assembly so that I could 'tug' on the regulator's voltage sampling node. Worked just fine. Took about 40 minutes labor and $3 parts to install . . . didn't seem like a marketable idea so I didn't pursue it. These regulators are consistent and well within the 'satisfactory' operations range of the svla battery. The notion of being able to control it seems like adding an adjustment to the tension spring on a windshield wiper . . . intellectually satisfying perhaps . . . but AutoZone probably couldn't sell it. B&C has an adjustable 'stone simple' regulator for their PM alternators . . . but we're finding that contemporary off-the-shelf PM rectifier/regulators have achieved the no-hassles/no-worries stature of their cousins in the wound field regulator world . . . that adjustment is probably going to go away. Bob . . . ________________________________________________________________________________
Date: Nov 24, 2014
Subject: Fund Raiser Behind By 20% - Please Contribute Today!
Dear Listers, The percentage of members making a Contribution to support the Lists this year is currently behind last year by at this time by roughly 20%. Please take this opportunity to show your support for the Matronics Lists and Forums! Please remember that it is *solely* your direct Contributions that keep these Lists and Forums up and running and most importantly - AD FREE! If the members don't want to support the Lists directly, then I might have to add advertisements to offset the costs of running the Lists. But I don't want to have to do that. I really like the non-commercial atmosphere here and I think that a lot of the members appreciate that too. Please take a moment to make a Contribution today in support of the continued ad-free operation of all these Lists: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I want to send out a word of appreciation to all of the members that have already made their generous Contribution to support the Lists! Thank you! Matt Dralle Email List and Forums Administrator ________________________________________________________________________________
Date: Nov 24, 2014
Thanks for the links and part numbers, Bob. Yes, the auto parts stores are full of them but I was trying to prevent a repeat of what happened with my first one. I suppose I'll just gamble another $20 since the odds are 99:1 in my favor unless someone can give a recommendation for "XXX by YYY". -- Joe Robert L. Nuckolls, III wrote, On 11/23/2014 18:46: > > > At 11:10 2014-11-23, you wrote: > > I'm in the market for a new "Ford-type VR166" voltage regulator. My > existing one produces occasional "switching noise" that's audible in my > intercom. > Worse yet, with the onset of cooler weather the charging voltage has > been creeping upward (15.0 volts after start settling down to 14.7 in a > few minutes). There are no adjustments so I'd like to replace it with > one of proven quality. > > Can anyone give me a first-hand recommendation for a voltage regulator > that they're happy with and doesn't cost an arm-and-a-leg? Not a "just > Google VR166 > regulator" or look on eBay please. > > You sound 'cautious' as to your selection > of devices. The modern incarnation of that > product line is 40+ years old and it seems > that everyone still making them should > have figured out how to do it. > > The best recommendation anyone can make > is "I got an XXX by YYY and it's not > given me any trouble for ZZZ hours." > But I'm pretty sure that 99% of what's > offered out there would deliver to the > same observation. > > Regulators are not critical for comfortable > continuation of flight, therefore, sampling > from the range of offerings is a low risk > experiment and the odds are very much in > your favor. > > Go to a local auto parts store and get > one of their VR166 (or clone) . . . with > $20 price point. Here's a few of many > possibilities. > > http://tinyurl.com/puzalge > > http://tinyurl.com/l9jvymv > > http://tinyurl.com/l9jvymv > > The Wells VR749 and Motorcraft GR540 > are alternative numbers to cross > reference. > > > > > Bob . . . ________________________________________________________________________________
Date: Nov 24, 2014
wow, "thermionic emission" - I like that!=0A=0ADoes it have anything to do with tachyon fields or photon torpedoes? ;)=0A=0A-Jeff=0A=0Ado not archiv e=0A=0A=0A=0AOn Sunday, November 23, 2014 11:24 AM, Eric M. Jones =0A=0AI built medical lighting systems f or decades. These included halogens, HIDs, xenon arcs, flashing xenon gas t ubes, even flashing short-arcs, HP Sodiums and some other esoteric systems such as mercury arc UV systems. =0A=0AI am also a giant proponent of LEDs. =0A=0ABut I could easily make the case for HIDs being the premier light sou rce as far as optics go, because they have the highest source luminance of any possible (okay, non-nuclear) light source. This is to say, they are ver y small and very brilliant, which makes possible the design of optics sendi ng the most light down range most effectively. =0A=0ASo why doesn't the who le world use HIDs? Two reasons: =0A=0A1) It's because they require power su pplies (ballasts + starters) that are specifically designed for them. These power supplies used to be relatively expensive, but not so now. Although H IDs have remarkably long lifetimes (5000 hours is typical), the power suppl ies have shorter lifetimes than that, especially if they are abused.=0A=0A 2) They are still relatively new. We have seen small HIDs only since 1990. =0A=0AEven though LEDs will be everywhere, we will still see HIDs where lon g searchlight beams are required. Xenons will be a player too, mostly where color rendition is critical and cost isn't.=0A=0AMy experience has never b een that HIDs are noisy. The trick is to keep the electrodes in thermionic emission (hot). A cool electrode makes a noisy lamp.=0A=0ASince I sell wig- wags where people want to use them with HIDs, I offer the following abbrevi ated advice:=0A=0A--everything I know says not to wig-wag HID lamps because they will have shorter lamp lifetimes. Everything that is an advantage of HID lamps disappears quickly if one abuses them by, oh let's say=C3=A2 =82=AC=C2 2500 restarts per hour! ... Furthermore, switched mode power s upplies and starters are particularly failure-prone when abused. I can prom ise you that the manufacturer of the lamp-supply and starter DO NOT warrant y their devices to be used in this fashion. =0A=0ABut here is what it takes if you want to do it. Here are the basic issues with HID lamps used with P erihelion Design=C3=A2=82=AC=84=A2s Wig-Wags:=0A=0A1: The high-voltag e ignition can feed back through the wiring and destroy solid-state electro nics. Everything might be okay, then on some rainy night=C3=A2=82=AC=C2 ka-pow=C3=A2=82=AC=C2! To prevent this I have added a bidirectiona l Zener, near the ballast. DO NOT put it between the HV ignitor and the lam p. These parts are P6KE18CA (for 14V systems) which I also sell as SnapJack s.=0A=0A2: The sudden negative resistance of the lamp induces a large curre nt, which if it comes from the Wig-Wag, will destroy the device. A CL-21 In rush current limiter will prevent this for HID lamps up to 50 W. For larger HID lamps use CL-11. The current limiters will get hot, as they are suppos ed to, and should be placed where they don=C3=A2=82=AC=84=A2t get air -cooled.=0A=0ASo I still love LEDs, but if you really need to see the deer at the other end of the runway, HIDs will do the job. If you want to wig-wa g them, expect shorter lamp lifetimes, and shorter ballast lifetimes.=0A=0A ps: Bob, my last (175W) xenon short arc system was so EMC/RFI quiet that th e test technician could not tell if it was on or off unless he opened the t est chamber door and LOOKED to see if it had light coming out.=0A=0A------- -=0AEric M. Jones=0Awww.PerihelionDesign.com=0A113 Brentwood Drive=0ASouthb ridge, MA 01550=0A(508) 764-2072=0Aemjones(at)charter.net=0A=0A=0A=0A=0ARea d this topic online here:=0A=0Ahttp://forums.matronics.com/viewtopic.php?p =========================0A =========== ________________________________________________________________________________
Date: Nov 24, 2014
From: Henador Titzoff <henador_titzoff(at)yahoo.com>
Date: Nov 24, 2014
Subject: Re: alternator / generator
Ken, I've been off the forum for a few weeks and just saw your request for info on the Rotax alternator (dynamo). Can you quote chapter and verse of the manual you are referencing? One of my custormers has a 912 in a JA Highlander that was down for months fixing a long list of defects found during the annual conditional inspection and the battery started the engine just fine when we were done. The 582 on my Kolb has the same basic alternator. I did a major rebuild on the airplane and it was down for over 18 months. The engine started right up when I took it out and that was with a five year old 18 AH SLA battery. Rick Girard On Wed, Nov 12, 2014 at 12:47 PM, Ken Ryan wrote: > Thanks Bob, > > I was wondering about that 80 amp fuse. It seems better to connect the bus > directly to the battery. With regards to the 1 amp fuse that you say is > unnecessary, why do you say that? Isn't it there to protect the wire that > runs from the battery to relay 58? I think the reasoning behind wiring one > fuel pump to the generator, is because the 914 relies on an electric fuel > pump, and they are trying to provide two independent power sources for each > pump. > > On Wed, Nov 12, 2014 at 9:18 AM, Robert L. Nuckolls, III < > nuckolls.bob(at)aeroelectric.com> wrote: > >> At 11:01 2014-11-12, you wrote: >> >> Thanks Bob. I do have the book. I am building a Just Aircraft SuperSTOL. >> A previous lister said that the IG wire from the external alternator needs >> to be disconnected to avoid drawing down the battery, which it is on the >> Rotax diagram (via the master switch). Are you saying that you disagree >> with this and that the IG wired does not need to be disconnected to avoid >> drawing down the battery? >> >> >> Ooops . . . sorry 'bout that. We're talking about the wound-field >> alternator . . . not the PM machine. That light doesn't work with much >> more >> intelligence than that annunciator on the PM rectifier/regulator. >> It's definitely dark when the alternator is working but may >> not light when the alternator is inadequate to system >> needs. I don't use those outputs either. >> >> If you're planning on ACTIVE NOTIFICATION OF LOW VOLTS then >> you can simply leave the light off the panel and leave the >> terminal disconnected. >> >> But you're correct, when wired per the Rotax drawing, IG gets >> disconnected when the big-alternator switch is OFF . . . so if >> you plan to use the light, wired as shown eliminates the >> concern. >> >> An interesting feature of their wiring gives you no control >> over the little alternator . . . it is automatically switched >> ON via relay (58) with an unnecessary, 1A fuse in the coil >> lead. This relay closes as soon as you turn on the master >> switch and will stay closed as long as the engine is running >> even if battery relay (38) is opened. Bringing engine >> rpm down will slowly drop voltage on the bus . . . and >> might cause the little-alternator relay to drop but >> this raises all kinds of questions about the behaviors >> of the ship's accessories. >> >> The relay will certainly drop after the engine is shut >> down. >> >> Another interesting feature uses the little-alternator >> output to power up one of two fuel pumps whether or not >> the master switch is ON. >> >> The 80A breaker is, in US TC aircraft philosophy, not >> necessary or useful. >> >> >> [image: Emacs!] >> >> >> Bob . . . >> > > -- Believe those who are seeking the truth, doubt those who find it. -Andre Gide ________________________________________________________________________________
Date: Nov 24, 2014
Rick, It's the wiring diagram from the Installation Manual for the 914. On Mon, Nov 24, 2014 at 7:08 PM, Richard Girard wrote: > Ken, I've been off the forum for a few weeks and just saw your request for > info on the Rotax alternator (dynamo). Can you quote chapter and verse of > the manual you are referencing? > One of my custormers has a 912 in a JA Highlander that was down for months > fixing a long list of defects found during the annual conditional > inspection and the battery started the engine just fine when we were done. > The 582 on my Kolb has the same basic alternator. I did a major rebuild on > the airplane and it was down for over 18 months. The engine started right > up when I took it out and that was with a five year old 18 AH SLA battery. > > Rick Girard > > On Wed, Nov 12, 2014 at 12:47 PM, Ken Ryan wrote: > >> Thanks Bob, >> >> I was wondering about that 80 amp fuse. It seems better to connect the >> bus directly to the battery. With regards to the 1 amp fuse that you say is >> unnecessary, why do you say that? Isn't it there to protect the wire that >> runs from the battery to relay 58? I think the reasoning behind wiring one >> fuel pump to the generator, is because the 914 relies on an electric fuel >> pump, and they are trying to provide two independent power sources for each >> pump. >> >> On Wed, Nov 12, 2014 at 9:18 AM, Robert L. Nuckolls, III < >> nuckolls.bob(at)aeroelectric.com> wrote: >> >>> At 11:01 2014-11-12, you wrote: >>> >>> Thanks Bob. I do have the book. I am building a Just Aircraft SuperSTOL. >>> A previous lister said that the IG wire from the external alternator needs >>> to be disconnected to avoid drawing down the battery, which it is on the >>> Rotax diagram (via the master switch). Are you saying that you disagree >>> with this and that the IG wired does not need to be disconnected to avoid >>> drawing down the battery? >>> >>> >>> Ooops . . . sorry 'bout that. We're talking about the wound-field >>> alternator . . . not the PM machine. That light doesn't work with much >>> more >>> intelligence than that annunciator on the PM rectifier/regulator. >>> It's definitely dark when the alternator is working but may >>> not light when the alternator is inadequate to system >>> needs. I don't use those outputs either. >>> >>> If you're planning on ACTIVE NOTIFICATION OF LOW VOLTS then >>> you can simply leave the light off the panel and leave the >>> terminal disconnected. >>> >>> But you're correct, when wired per the Rotax drawing, IG gets >>> disconnected when the big-alternator switch is OFF . . . so if >>> you plan to use the light, wired as shown eliminates the >>> concern. >>> >>> An interesting feature of their wiring gives you no control >>> over the little alternator . . . it is automatically switched >>> ON via relay (58) with an unnecessary, 1A fuse in the coil >>> lead. This relay closes as soon as you turn on the master >>> switch and will stay closed as long as the engine is running >>> even if battery relay (38) is opened. Bringing engine >>> rpm down will slowly drop voltage on the bus . . . and >>> might cause the little-alternator relay to drop but >>> this raises all kinds of questions about the behaviors >>> of the ship's accessories. >>> >>> The relay will certainly drop after the engine is shut >>> down. >>> >>> Another interesting feature uses the little-alternator >>> output to power up one of two fuel pumps whether or not >>> the master switch is ON. >>> >>> The 80A breaker is, in US TC aircraft philosophy, not >>> necessary or useful. >>> >>> >>> [image: Emacs!] >>> >>> >>> Bob . . . >>> >> >> > > > -- > > > Believe those who are seeking the truth, doubt those who find it. > -Andre Gide > > ________________________________________________________________________________
Date: Nov 25, 2014
Subject: Make Sure You're Listed! List of Contributors Coming
Soon! Dear Listers, There's just a few more days left in this year's List Fund Raiser and that means the List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 25, 2014
Ken, I don't know how far along you are in crafting your airplane's electrical architecture, but may I suggest you use Bob's Figure Z-16 that is designed for the 912/914. It is a more capable architecture than the Z-17 that I have used twice with Rotax 582 powered airplanes and with which I have been very satisfied. it is crafted to accomplish what you are asking about by using a contactor to control the alternator. In addition, by using an S700-2-10 On-On-On switch you get the effect of a master switch and have a battery only mode for system testing (or to run on but locking out the starter) and a run mode that actuates the starter. I also appreciate that it does away with a bulky key switch to control the mags and starter by using a push button for the starter and SPST toggle switches to control the "mags". This is particularly handy when you wish to crank the engine over with the ignition off and top plugs out to charge the oil system before first engine start (Rotax ignition modules do not tolerate being fired while the plugs are not grounded. All the current is forced through one little diode that promptly burns up, cannot be replaced, and the cost of two new ignition modules is about $2500 plus installation. Not a mistake you want to make). Well, those are just a few of my reasons for recommending the Z-16. There are others on here who have used it and can chime in. Rick On Tue, Nov 25, 2014 at 12:20 AM, Ken Ryan wrote: > Rick, It's the wiring diagram from the Installation Manual for the 914. > > On Mon, Nov 24, 2014 at 7:08 PM, Richard Girard > wrote: > >> Ken, I've been off the forum for a few weeks and just saw your request >> for info on the Rotax alternator (dynamo). Can you quote chapter and verse >> of the manual you are referencing? >> One of my custormers has a 912 in a JA Highlander that was down for >> months fixing a long list of defects found during the annual conditional >> inspection and the battery started the engine just fine when we were done. >> The 582 on my Kolb has the same basic alternator. I did a major rebuild on >> the airplane and it was down for over 18 months. The engine started right >> up when I took it out and that was with a five year old 18 AH SLA battery. >> >> Rick Girard >> >> On Wed, Nov 12, 2014 at 12:47 PM, Ken Ryan wrote: >> >>> Thanks Bob, >>> >>> I was wondering about that 80 amp fuse. It seems better to connect the >>> bus directly to the battery. With regards to the 1 amp fuse that you say is >>> unnecessary, why do you say that? Isn't it there to protect the wire that >>> runs from the battery to relay 58? I think the reasoning behind wiring one >>> fuel pump to the generator, is because the 914 relies on an electric fuel >>> pump, and they are trying to provide two independent power sources for each >>> pump. >>> >>> On Wed, Nov 12, 2014 at 9:18 AM, Robert L. Nuckolls, III < >>> nuckolls.bob(at)aeroelectric.com> wrote: >>> >>>> At 11:01 2014-11-12, you wrote: >>>> >>>> Thanks Bob. I do have the book. I am building a Just Aircraft >>>> SuperSTOL. A previous lister said that the IG wire from the external >>>> alternator needs to be disconnected to avoid drawing down the battery, >>>> which it is on the Rotax diagram (via the master switch). Are you saying >>>> that you disagree with this and that the IG wired does not need to be >>>> disconnected to avoid drawing down the battery? >>>> >>>> >>>> Ooops . . . sorry 'bout that. We're talking about the wound-field >>>> alternator . . . not the PM machine. That light doesn't work with >>>> much more >>>> intelligence than that annunciator on the PM rectifier/regulator. >>>> It's definitely dark when the alternator is working but may >>>> not light when the alternator is inadequate to system >>>> needs. I don't use those outputs either. >>>> >>>> If you're planning on ACTIVE NOTIFICATION OF LOW VOLTS then >>>> you can simply leave the light off the panel and leave the >>>> terminal disconnected. >>>> >>>> But you're correct, when wired per the Rotax drawing, IG gets >>>> disconnected when the big-alternator switch is OFF . . . so if >>>> you plan to use the light, wired as shown eliminates the >>>> concern. >>>> >>>> An interesting feature of their wiring gives you no control >>>> over the little alternator . . . it is automatically switched >>>> ON via relay (58) with an unnecessary, 1A fuse in the coil >>>> lead. This relay closes as soon as you turn on the master >>>> switch and will stay closed as long as the engine is running >>>> even if battery relay (38) is opened. Bringing engine >>>> rpm down will slowly drop voltage on the bus . . . and >>>> might cause the little-alternator relay to drop but >>>> this raises all kinds of questions about the behaviors >>>> of the ship's accessories. >>>> >>>> The relay will certainly drop after the engine is shut >>>> down. >>>> >>>> Another interesting feature uses the little-alternator >>>> output to power up one of two fuel pumps whether or not >>>> the master switch is ON. >>>> >>>> The 80A breaker is, in US TC aircraft philosophy, not >>>> necessary or useful. >>>> >>>> >>>> [image: Emacs!] >>>> >>>> >>>> Bob . . . >>>> >>> >>> >> >> >> -- >> >> >> Believe those who are seeking the truth, doubt those who find it. >> -Andre Gide >> >> > -- Believe those who are seeking the truth, doubt those who find it. -Andre Gide ________________________________________________________________________________
Date: Nov 25, 2014
I think that it would be a worthwhile text to measure the voltage between the regulator "S" terminal and the regulator case to see if it agrees with the electrical system voltmeter. If the two voltages are different, then there could be a high resistance connection in the regulator circuit. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=434698#434698 ________________________________________________________________________________
Subject: Aircraft flight instruments
From: "Pable Mackenzie" <PableMackenzie(at)gmail.com>
Date: Nov 26, 2014
Hi,Dear Friend, I like to share my knowlege with you and want to gain more if you are have same interest related Aircraft's Spare Parts Modern passenger jets not only have sophisticated Aircraft flight instruments systems, they go a step further and transmit accumulated data (via satellite feed ) at regular intervals to ground stations that have been setup and monitored by the engine manufacturers. This helps engine manufacturers make appropriate notations and pay special attention to under-performing engine parts during the next maintenance overhaul or, they may even recommend an early overhaul. The Aircraft sensor systems in a modern jet also sends critical performance related information to the aircraft flight recorder (black box). In the unfortunate event of a crash, such information plays a big hand in helping determine the cause of the crash. BestRegards Pable Mackenzie -------- I am here for to know all about latest news about Auttomobile technology,spare parts and to discuss and share with friend those are concious about automobile related news. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=434699#434699 Attachments: http://forums.matronics.com//files/aircraft_sensor_systems8_123.jpg http://forums.matronics.com//files/aircraft_sensor_systems8_146.jpg http://forums.matronics.com//files/aircraft_sensor_systems1_375.gif http://forums.matronics.com//files/aircraft_sensor_systems0_219.gif ________________________________________________________________________________
Date: Nov 26, 2014
Subject: Giving Thanks - Your List Contribution...
Dear Listers, Here in the United States, Thursday is our National day of Thanksgiving. Many of us will be traveling to be with our families and friends to share in generous feasts of plenty and giving thanks for the many blessings that have been bestowed upon us. Many Listers have expressed over the last couple of weeks how thankful they are for the Email Lists and Forums here on the Matronics servers and for all of the assistance and comradery they have experienced being a part of the Lists. One of my favorite comments is when someone writes to me and says something like, "Its the first thing I do in the morning while I'm having my morning coffee!". That's a wonderful tribute to the purpose and function of these Lists. Its always great to hear I'm not the only one that jumps out of bed each morning to check my List email!! Won't you take a minute today and show your appreciation for these Lists and for their continued operation and upgrade? The List Contribution Site is: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you in advance for your kind consideration, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 26, 2014
Date: Nov 26, 2014
Rick, I will be incorporating Robert Paisley's Bus Manager, along with two lithium batteries, and am trying to figure out how the Rotax wiring diagram relates to that. Info on Bus Manager can be found here if interested: http://flyefii.com/bus_manager/Bus_Manager_Installation_Instructions.pdf On Tue, Nov 25, 2014 at 5:49 PM, Richard Girard wrote: > Ken, I don't know how far along you are in crafting your airplane's > electrical architecture, but may I suggest you use Bob's Figure Z-16 that > is designed for the 912/914. It is a more capable architecture than the > Z-17 that I have used twice with Rotax 582 powered airplanes and with which > I have been very satisfied. it is crafted to accomplish what you are asking > about by using a contactor to control the alternator. In addition, by > using an S700-2-10 On-On-On switch you get the effect of a master switch > and have a battery only mode for system testing (or to run on but locking > out the starter) and a run mode that actuates the starter. I also > appreciate that it does away with a bulky key switch to control the mags > and starter by using a push button for the starter and SPST toggle switches > to control the "mags". This is particularly handy when you wish to crank > the engine over with the ignition off and top plugs out to charge the oil > system before first engine start (Rotax ignition modules do not tolerate > being fired while the plugs are not grounded. All the current is forced > through one little diode that promptly burns up, cannot be replaced, and > the cost of two new ignition modules is about $2500 plus installation. Not > a mistake you want to make). Well, those are just a few of my reasons for > recommending the Z-16. There are others on here who have used it and can > chime in. > > Rick > > On Tue, Nov 25, 2014 at 12:20 AM, Ken Ryan wrote: > >> Rick, It's the wiring diagram from the Installation Manual for the 914. >> >> On Mon, Nov 24, 2014 at 7:08 PM, Richard Girard >> wrote: >> >>> Ken, I've been off the forum for a few weeks and just saw your request >>> for info on the Rotax alternator (dynamo). Can you quote chapter and verse >>> of the manual you are referencing? >>> One of my custormers has a 912 in a JA Highlander that was down for >>> months fixing a long list of defects found during the annual conditional >>> inspection and the battery started the engine just fine when we were done. >>> The 582 on my Kolb has the same basic alternator. I did a major rebuild on >>> the airplane and it was down for over 18 months. The engine started right >>> up when I took it out and that was with a five year old 18 AH SLA battery. >>> >>> Rick Girard >>> >>> On Wed, Nov 12, 2014 at 12:47 PM, Ken Ryan >>> wrote: >>> >>>> Thanks Bob, >>>> >>>> I was wondering about that 80 amp fuse. It seems better to connect the >>>> bus directly to the battery. With regards to the 1 amp fuse that you say is >>>> unnecessary, why do you say that? Isn't it there to protect the wire that >>>> runs from the battery to relay 58? I think the reasoning behind wiring one >>>> fuel pump to the generator, is because the 914 relies on an electric fuel >>>> pump, and they are trying to provide two independent power sources for each >>>> pump. >>>> >>>> On Wed, Nov 12, 2014 at 9:18 AM, Robert L. Nuckolls, III < >>>> nuckolls.bob(at)aeroelectric.com> wrote: >>>> >>>>> At 11:01 2014-11-12, you wrote: >>>>> >>>>> Thanks Bob. I do have the book. I am building a Just Aircraft >>>>> SuperSTOL. A previous lister said that the IG wire from the external >>>>> alternator needs to be disconnected to avoid drawing down the battery, >>>>> which it is on the Rotax diagram (via the master switch). Are you saying >>>>> that you disagree with this and that the IG wired does not need to be >>>>> disconnected to avoid drawing down the battery? >>>>> >>>>> >>>>> Ooops . . . sorry 'bout that. We're talking about the wound-field >>>>> alternator . . . not the PM machine. That light doesn't work with >>>>> much more >>>>> intelligence than that annunciator on the PM rectifier/regulator. >>>>> It's definitely dark when the alternator is working but may >>>>> not light when the alternator is inadequate to system >>>>> needs. I don't use those outputs either. >>>>> >>>>> If you're planning on ACTIVE NOTIFICATION OF LOW VOLTS then >>>>> you can simply leave the light off the panel and leave the >>>>> terminal disconnected. >>>>> >>>>> But you're correct, when wired per the Rotax drawing, IG gets >>>>> disconnected when the big-alternator switch is OFF . . . so if >>>>> you plan to use the light, wired as shown eliminates the >>>>> concern. >>>>> >>>>> An interesting feature of their wiring gives you no control >>>>> over the little alternator . . . it is automatically switched >>>>> ON via relay (58) with an unnecessary, 1A fuse in the coil >>>>> lead. This relay closes as soon as you turn on the master >>>>> switch and will stay closed as long as the engine is running >>>>> even if battery relay (38) is opened. Bringing engine >>>>> rpm down will slowly drop voltage on the bus . . . and >>>>> might cause the little-alternator relay to drop but >>>>> this raises all kinds of questions about the behaviors >>>>> of the ship's accessories. >>>>> >>>>> The relay will certainly drop after the engine is shut >>>>> down. >>>>> >>>>> Another interesting feature uses the little-alternator >>>>> output to power up one of two fuel pumps whether or not >>>>> the master switch is ON. >>>>> >>>>> The 80A breaker is, in US TC aircraft philosophy, not >>>>> necessary or useful. >>>>> >>>>> >>>>> [image: Emacs!] >>>>> >>>>> >>>>> Bob . . . >>>>> >>>> >>>> >>> >>> >>> -- >>> >>> >>> Believe those who are seeking the truth, doubt those who find it. >>> -Andre Gide >>> >>> >> > > > -- > > > Believe those who are seeking the truth, doubt those who find it. > -Andre Gide > > ________________________________________________________________________________
Date: Nov 26, 2014
That was a great reminder, Joe. Thanks. I don't know why I fixated on replacing the voltage regulator; it was even easier to troubleshoot the wiring. Long story short: I found a sizable drop along a 6-inch wire connecting the alternator field circuit breaker and the alternator switch. Visually it looked good and tested very close to 0 ohms but there was about 0.25V drop across that short wire. Replaced it and the voltage on the "S" terminal came up almost 0.5V I don't understand that arithmetic but there may have been intermittent issues. Until I fly I won't know it's fixed for sure but if the charging voltage is 0.5V lower than the present (15.0 decreasing to 14.7 in a few minutes) I'll be a happy camper. Thanks again, Joe user9253 wrote, On 11/25/2014 20:20: > > I think that it would be a worthwhile text to measure the voltage between the regulator "S" terminal and the regulator case to see if it agrees with the electrical system voltmeter. If the two voltages are different, then there could be a high resistance connection in the regulator circuit. > Joe > > -------- > Joe Gores ________________________________________________________________________________
Date: Nov 27, 2014
At 03:12 PM 11/26/2014, you wrote: >Rick, > >I will be incorporating Robert Paisley's Bus >Manager, along with two lithium batteries, and >am trying to figure out how the Rotax wiring >diagram relates to that. Info on Bus Manager can >be found here if interested:=C2 ><http://flyefii.com/bus_manager/Bus_Manager_Installation_Instructions.pdf>h ttp://flyefii.com/bus_manager/Bus_Manager_Installation_Instructions.pdf That's a LOT of hardware for what would otherwise be a simple system. What are your anticipated missions that would benefit from dual batteries and the automation offered by the Bus Manager? Your continuous loads are minimal. Even the 3.2A value for the radio is probably more like 0.2A receive, 3.2A transmit . . . which pushes its energy requirements down to insignificant . . . about 1/4th power it takes to keep one battery contactor closed. How, and under what circumstances, would dual batteries mitigate perceived risks for the operation of your system? Bob . . . ________________________________________________________________________________
Date: Nov 27, 2014
Subject: Fw: Noise Cancelling headphones
On Thursday, November 27, 2014 8:19 AM, rv7a.builder <rv7a.builder@ya hoo.com> wrote: Hi Bob, =C2-=C2- I just got myself some Lightspeed Sierra ANR and plugged them into my RV-7A this morning. Prior to this I just had a couple of sets of re gular headphones. The headphones worked without the noise canceling turned on (push button, 2AA batteries). When I push the button the noise level got reduced and it sounded real good. When I key the transmitter there is a lo ud squeal. With the nose cancelling off, there is no squeal when I keyed th e transmitter. I think this only happened when the engine was running. I th ink I checked the transmitter and headphones=C2-before I started the engi ne this morning? I have my jacks wired through a Flightcom 403mc and my rad io is a GNC300XL. I had to fly this morning with the noise cancelling off b ut I should wanted it on! Any thoughts would be appreciated. John Robinson. RV-7A Phase 1. ________________________________________________________________________________
Date: Nov 27, 2014
Being in Alaska, many landings are remote, off airport. The engine must start. If it doesn't the only option is to trigger search and rescue. Two batteries mitigates the risk of the engine not starting 150 miles from the nearest civilization. How, and under what circumstances, would dual batteries mitigate perceived risks for the operation of your system? Bob . . . On Thu, Nov 27, 2014 at 6:51 AM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 03:12 PM 11/26/2014, you wrote: > > Rick, > > I will be incorporating Robert Paisley's Bus Manager, along with two > lithium batteries, and am trying to figure out how the Rotax wiring diagr am > relates to that. Info on Bus Manager can be found here if interested:=C3 =82 > http://flyefii.com/bus_manager/Bus_Manager_Installation_Instructions.pdf > > > That's a LOT of hardware for what would otherwise be > a simple system. > > What are your anticipated missions that would benefit > from dual batteries and the automation offered by > the Bus Manager? Your continuous loads are minimal. > Even the 3.2A value for the radio is probably more like > 0.2A receive, 3.2A transmit . . . which pushes its > energy requirements down to insignificant . . . about > 1/4th power it takes to keep one battery contactor > closed. > > How, and under what circumstances, would dual batteries > mitigate perceived risks for the operation of your > system? > > Bob . . . > > * > =========== m> ldersbooks.com> .com> com> om/contribution> =========== www.matronics.com/Navigator?AeroElectric-List> =========== =========== > > * > > ________________________________________________________________________________
Subject: Copper bus bar
Date: Nov 27, 2014
Hi Guys I have access to some 1.2mm (C101 grade) copper bar, is this what one can use for a circuit breaker bus bar Regards John Sent from my iPad ----x--O--x---- ________________________________________________________________________________
Date: Nov 27, 2014
At 10:58 AM 11/27/2014, you wrote: >Being in Alaska, many landings are remote, off airport. The engine >must start. If it doesn't the only option is to trigger search and >rescue. Two batteries mitigates the risk of the engine not starting >150 miles from the nearest civilization. Okay, how often has the 'unavailable battery' syndrome presented itself . . . and what was root cause for the failure? A battery can and should be the single most reliable source of energy on your airplane. This presumes, of course, that you give it the same level of attention to airworthiness that is bestowed upon fuel, oil, tires, continuity of flight controls, fuel filters and sumps, prop blade nicks, etc. etc. Batteries tend to be the oft neglected step-child of flight systems. The predominant public perception of battery consumerism is to run it until it wont crank the engine any more . . . Walmart sells a gizillion batteries every year that are replaced in response to that same symptom. Some years ago I corresponded with a Cessna 206 floatplane owner in S. America who was wanting to add a second battery to his ship. We pondered useful volume to exploit for several exchanges of e-mails. We finally decided that inside one of the floats was the best location. The battery could be positioned right on C.G. and it occupied volume that had no other purpose. After we had corresponded a few times, he agreed that his REAL worry was for loss of a battery contactor. He conceded that in the grand scheme of things, battery maintenance was not a big adder to cost-of- ownership, his big worry was for loss of battery contactor that would make the battery unavailable. I suggested then than he add a piece of welding cable to run from downstream side of battery contactor to the battery box (accessible while standing on a float). Should preflight testing before tossing the mooring lines showed that the battery contactor was "iffy", he could make a manual connection to the battery (+) terminal with the short jumper. He decided that was a much less expensive, lighter and lower cost plan-C for dealing with a failed battery contactor. We also discussed simply carrying a spare contactor and tools . . . but that didn't cover the potential loss of wiring and/or battery master switch. So he opted for the jumper-cable and a pair of pliers. The point to ponder is how best to accommodate or modify a system that is a direct descendant from systems common to garden tractors: PM alternator, simple rectifier/regulator and a lead acid battery. It seems that the elegant design goal is to craft a combination of architecture, preventive maintenance\ and operating procedures that accommodates low risk failures -OR- drives specific failure rates down to insignificance. I believe this can be achieved without adding the weight, cost or complexity of burdening a garden-tractor-style electrical system with concepts holy-watered by the FAA and embraced by Boeing and Airbus. This requires a simple but thorough thought process that goes through the steps of considering EVERY part of your electrical system from crimped terminals to alternators and batteries. How can this part fail? Is failure pre-flight detectable? If it fails in flight, how will I know about it? How would in-flight failure affect comfortable termination of flight? What are the lowest cost, lightest weight, simplest mitigations for the failure? Due diligence to Failure Mode Effects Analysis (FMEA) offers the short-path to the simpler, lightest weight, lowest cost, lowest risk (elegant) design easily understood and managed by the cognizant pilot. Bob . . . ________________________________________________________________________________
Subject: Re: Copper bus bar
Date: Nov 27, 2014
Not sure if it was the best option, but I cut the bus bars from copper pipe purchased at Home Depot. Justin > On Nov 27, 2014, at 9:39 AM, John Tipton wrote: > > > Hi Guys > > I have access to some 1.2mm (C101 grade) copper bar, is this what one can use for a circuit breaker bus bar > > Regards > > John > > Sent from my iPad > > ----x--O--x---- > > > > ________________________________________________________________________________
Date: Nov 27, 2014
An argument can be made both for and against the second battery. I have considered both and determined that in my case the extra battery is justified. Your points are nevertheless well taken. On Nov 27, 2014 10:54 AM, "Robert L. Nuckolls, III" < nuckolls.bob(at)aeroelectric.com> wrote: > At 10:58 AM 11/27/2014, you wrote: > > Being in Alaska, many landings are remote, off airport. The engine must > start. If it doesn't the only option is to trigger search and rescue. Two > batteries mitigates the risk of the engine not starting 150 miles from the > nearest civilization. > > > Okay, how often has the 'unavailable battery' syndrome > presented itself . . . and what was root cause for the > failure? > > A battery can and should be the single most reliable > source of energy on your airplane. This presumes, of > course, that you give it the same level of attention > to airworthiness that is bestowed upon fuel, oil, tires, > continuity of flight controls, fuel filters and sumps, > prop blade nicks, etc. etc. > > Batteries tend to be the oft neglected step-child > of flight systems. The predominant public perception > of battery consumerism is to run it until it wont > crank the engine any more . . . Walmart sells > a gizillion batteries every year that are replaced > in response to that same symptom. > > Some years ago I corresponded with a Cessna 206 > floatplane owner in S. America who was wanting to add a > second battery to his ship. We pondered useful volume > to exploit for several exchanges of e-mails. We > finally decided that inside one of the floats was > the best location. The battery could be positioned > right on C.G. and it occupied volume that had > no other purpose. > > After we had corresponded a few times, he agreed > that his REAL worry was for loss of a battery contactor. > He conceded that in the grand scheme of things, > battery maintenance was not a big adder to cost-of- > ownership, his big worry was for loss of battery > contactor that would make the battery unavailable. > > I suggested then than he add a piece of welding cable > to run from downstream side of battery contactor to > the battery box (accessible while standing on a > float). Should preflight testing before tossing > the mooring lines showed that the battery contactor was > "iffy", he could make a manual connection to the > battery (+) terminal with the short jumper. > > He decided that was a much less expensive, lighter > and lower cost plan-C for dealing with a failed > battery contactor. We also discussed simply carrying > a spare contactor and tools . . . but that didn't > cover the potential loss of wiring and/or battery > master switch. So he opted for the jumper-cable > and a pair of pliers. > > The point to ponder is how best to accommodate or > modify a system that is a direct descendant from > systems common to garden tractors: PM alternator, > simple rectifier/regulator and a lead acid battery. > > It seems that the elegant design goal is to craft > a combination of architecture, preventive maintenance\ > and operating procedures that accommodates low risk failures > -OR- drives specific failure rates down to insignificance. > > I believe this can be achieved without adding the > weight, cost or complexity of burdening a > garden-tractor-style electrical system with > concepts holy-watered by the FAA and embraced > by Boeing and Airbus. > > This requires a simple but thorough thought > process that goes through the steps of considering > EVERY part of your electrical system from crimped > terminals to alternators and batteries. > > How can this part fail? > > Is failure pre-flight detectable? > > If it fails in flight, how will I know about > it? > > How would in-flight failure affect comfortable > termination of flight? > > What are the lowest cost, lightest weight, > simplest mitigations for the failure? > > Due diligence to Failure Mode Effects Analysis > (FMEA) offers the short-path to the simpler, > lightest weight, lowest cost, lowest risk > (elegant) design easily understood and managed by the > cognizant pilot. > > Bob . . . > > * > > > * > > ________________________________________________________________________________
Date: Nov 27, 2014
Well, having flown for 20 yrs in Alaska, I would take starter motor failure as a higher risk than battery failure. Adding electronic ignition to a plane in that environment IMHO adds risk over a dead simple pair of magnetos. Most of time there is a means to hand prop if lack of battery presents itself. Needing electrons to fire the ignition as well as crank the engine creates more potential risk. On 11/27/2014 12:32 PM, Ken Ryan wrote: > > An argument can be made both for and against the second battery. I > have considered both and determined that in my case the extra battery > is justified. Your points are nevertheless well taken. > > On Nov 27, 2014 10:54 AM, "Robert L. Nuckolls, III" > > > wrote: > > At 10:58 AM 11/27/2014, you wrote: >> Being in Alaska, many landings are remote, off airport. The >> engine must start. If it doesn't the only option is to trigger >> search and rescue. Two batteries mitigates the risk of the engine >> not starting 150 miles from the nearest civilization. > > > Okay, how often has the 'unavailable battery' syndrome > presented itself . . . and what was root cause for the > failure? > > A battery can and should be the single most reliable > source of energy on your airplane. This presumes, of > course, that you give it the same level of attention > to airworthiness that is bestowed upon fuel, oil, tires, > continuity of flight controls, fuel filters and sumps, > prop blade nicks, etc. etc. > > Batteries tend to be the oft neglected step-child > of flight systems. The predominant public perception > of battery consumerism is to run it until it wont > crank the engine any more . . . Walmart sells > a gizillion batteries every year that are replaced > in response to that same symptom. > > Some years ago I corresponded with a Cessna 206 > floatplane owner in S. America who was wanting to add a > second battery to his ship. We pondered useful volume > to exploit for several exchanges of e-mails. We > finally decided that inside one of the floats was > the best location. The battery could be positioned > right on C.G. and it occupied volume that had > no other purpose. > > After we had corresponded a few times, he agreed > that his REAL worry was for loss of a battery contactor. > He conceded that in the grand scheme of things, > battery maintenance was not a big adder to cost-of- > ownership, his big worry was for loss of battery > contactor that would make the battery unavailable. > > I suggested then than he add a piece of welding cable > to run from downstream side of battery contactor to > the battery box (accessible while standing on a > float). Should preflight testing before tossing > the mooring lines showed that the battery contactor was > "iffy", he could make a manual connection to the > battery (+) terminal with the short jumper. > > He decided that was a much less expensive, lighter > and lower cost plan-C for dealing with a failed > battery contactor. We also discussed simply carrying > a spare contactor and tools . . . but that didn't > cover the potential loss of wiring and/or battery > master switch. So he opted for the jumper-cable > and a pair of pliers. > > The point to ponder is how best to accommodate or > modify a system that is a direct descendant from > systems common to garden tractors: PM alternator, > simple rectifier/regulator and a lead acid battery. > > It seems that the elegant design goal is to craft > a combination of architecture, preventive maintenance\ > and operating procedures that accommodates low risk failures > -OR- drives specific failure rates down to insignificance. > > I believe this can be achieved without adding the > weight, cost or complexity of burdening a > garden-tractor-style electrical system with > concepts holy-watered by the FAA and embraced > by Boeing and Airbus. > > This requires a simple but thorough thought > process that goes through the steps of considering > EVERY part of your electrical system from crimped > terminals to alternators and batteries. > > How can this part fail? > > Is failure pre-flight detectable? > > If it fails in flight, how will I know about > it? > > How would in-flight failure affect comfortable > termination of flight? > > What are the lowest cost, lightest weight, > simplest mitigations for the failure? > > Due diligence to Failure Mode Effects Analysis > (FMEA) offers the short-path to the simpler, > lightest weight, lowest cost, lowest risk > (elegant) design easily understood and managed by the > cognizant pilot. > > Bob . . . > > * > > _blank">www.aeroelectric.com > .com" target="_blank">www.buildersbooks.com > ="_blank">www.homebuilthelp.com > ="_blank">www.mypilotstore.com > ank">www.mrrace.com > _blank">http://www.matronics.com/contribution > ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List > tp://forums.matronics.com > > * > > * > > > * ________________________________________________________________________________
Date: Nov 27, 2014
Have you considered this: http://www.aircraftspruce.com/catalog/elpages/bussbars.php?clickkey=4696 On Thursday, November 27, 2014 11:45 AM, Justin Jones wrote: Not sure if it was the best option, but I cut the bus bars from copper pipe purchased at Home Depot. Justin > On Nov 27, 2014, at 9:39 AM, John Tipton wrote: > > > Hi Guys > > I have access to some 1.2mm (C101 grade) copper bar, is this what one can use for a circuit breaker bus bar > > Regards > > John > > Sent from my iPad > > ----x--O--x---- > > > > ________________________________________________________________________________
Date: Nov 27, 2014
I also fly in Alaska. I agree that a battery failure isnt as likely as a starter failure, but if having two batteries on the aircraft is an acceptable risk mitigation step for him, then he is justified having the extra battery. I will have two alternators. One gear driven and one belt driven. I will also carry a battery jump starter pack and a solar cell that is capable of charging it when I plan on spending any time in the bush. I understand the added weight of the pack, however after using it just a single time, it will have been worth it. If my starter does die and the battery still has at least 6 volts (EFII system minimum), the ignition and injection systems will still operate, making hand propping much easier than a healthy magneto. I will still need enough voltage to excite the alternator for continued 12v operation. One pass of the flywheel magnets past the crank trigger should start the engine. I disagree with the statement that electronic ignition adds risk. There are many reasons. 1st reason is the massive amount of time electric ignition has been in operation. Nearly every vehicle manufactured since the mid 70s has electronic ignition, meaning there are MANY MANY more hours of operation on electronic ignition units than magnetos. They have been proven VERY reliable and need very little maintenance. 2nd reason is there are solid state units that require no moving parts (crank trigger systems). It is true that there are different electric systems out there, however they all run on the same principal. There are also redundant systems available that can keep the engine running in the extremely unlikely event that one fails. Choose the one that is satisfactory to you and go with it. 3rd reason that electronic ignition doesnt add risk is the complexity and unreliability of magnetos. They have moving parts that wear. They have TBOs on them because they are known to wear and malfunction. They are heavy, expensive, and do not provide the same amount of energy that an electronic ignition does. I have personally had 3 magneto failures. Thankfully both have never quit on me at once. A good friend in a Maule M4 just had one fail last week. 4th reason is the correct 12v system architecture that electronic ignition requires is very reliable. The Z-diagrams that Bob has authored have the capability to mitigate most risk involved with the 12v system. I have personally chosen to go with a dual alternator system. I will carry small light solar panels that can recharge a battery in a matter of days. There is a good compromise out there. Look at the G3i ignition system. It adds an MSD electronic ignition box and runs it through the magneto (if you feel that you MUST have the unreliable mags). If the MSD box fails or if the battery dies, the magnetos will still act like magnetos. The thing to keep in mind regardless of how many batteries that you have on the aircraft is watching your battery health. If your battery or batteries show any sign of ill health, replace them. Dont push it. Batteries seldom fail overnight. Some people even replace them every annual. I feel that a properly installed and maintained redundant electronic ignition system will actually REDUCE the risk that the legacy magneto systems offer. Respectfully, Justin > On Nov 27, 2014, at 11:10 AM, Kelly McMullen wrote: > > > Well, having flown for 20 yrs in Alaska, I would take starter motor failure as a higher risk than battery failure. Adding electronic ignition to a plane in that environment IMHO adds risk over a dead simple pair of magnetos. Most of time there is a means to hand prop if lack of battery presents itself. Needing electrons to fire the ignition as well as crank the engine creates more potential risk. > > On 11/27/2014 12:32 PM, Ken Ryan wrote: >> >> An argument can be made both for and against the second battery. I have considered both and determined that in my case the extra battery is justified. Your points are nevertheless well taken. >> >> On Nov 27, 2014 10:54 AM, "Robert L. Nuckolls, III" > wrote: >> >> At 10:58 AM 11/27/2014, you wrote: >>> Being in Alaska, many landings are remote, off airport. The >>> engine must start. If it doesn't the only option is to trigger >>> search and rescue. Two batteries mitigates the risk of the engine >>> not starting 150 miles from the nearest civilization. >> >> >> Okay, how often has the 'unavailable battery' syndrome >> presented itself . . . and what was root cause for the >> failure? >> >> A battery can and should be the single most reliable >> source of energy on your airplane. This presumes, of >> course, that you give it the same level of attention >> to airworthiness that is bestowed upon fuel, oil, tires, >> continuity of flight controls, fuel filters and sumps, >> prop blade nicks, etc. etc. >> >> Batteries tend to be the oft neglected step-child >> of flight systems. The predominant public perception >> of battery consumerism is to run it until it wont >> crank the engine any more . . . Walmart sells >> a gizillion batteries every year that are replaced >> in response to that same symptom. >> >> Some years ago I corresponded with a Cessna 206 >> floatplane owner in S. America who was wanting to add a >> second battery to his ship. We pondered useful volume >> to exploit for several exchanges of e-mails. We >> finally decided that inside one of the floats was >> the best location. The battery could be positioned >> right on C.G. and it occupied volume that had >> no other purpose. >> >> After we had corresponded a few times, he agreed >> that his REAL worry was for loss of a battery contactor. >> He conceded that in the grand scheme of things, >> battery maintenance was not a big adder to cost-of- >> ownership, his big worry was for loss of battery >> contactor that would make the battery unavailable. >> >> I suggested then than he add a piece of welding cable >> to run from downstream side of battery contactor to >> the battery box (accessible while standing on a >> float). Should preflight testing before tossing >> the mooring lines showed that the battery contactor was >> "iffy", he could make a manual connection to the >> battery (+) terminal with the short jumper. >> >> He decided that was a much less expensive, lighter >> and lower cost plan-C for dealing with a failed >> battery contactor. We also discussed simply carrying >> a spare contactor and tools . . . but that didn't >> cover the potential loss of wiring and/or battery >> master switch. So he opted for the jumper-cable >> and a pair of pliers. >> >> The point to ponder is how best to accommodate or >> modify a system that is a direct descendant from >> systems common to garden tractors: PM alternator, >> simple rectifier/regulator and a lead acid battery. >> >> It seems that the elegant design goal is to craft >> a combination of architecture, preventive maintenance\ >> and operating procedures that accommodates low risk failures >> -OR- drives specific failure rates down to insignificance. >> >> I believe this can be achieved without adding the >> weight, cost or complexity of burdening a >> garden-tractor-style electrical system with >> concepts holy-watered by the FAA and embraced >> by Boeing and Airbus. >> >> This requires a simple but thorough thought >> process that goes through the steps of considering >> EVERY part of your electrical system from crimped >> terminals to alternators and batteries. >> >> How can this part fail? >> >> Is failure pre-flight detectable? >> >> If it fails in flight, how will I know about >> it? >> >> How would in-flight failure affect comfortable >> termination of flight? >> >> What are the lowest cost, lightest weight, >> simplest mitigations for the failure? >> >> Due diligence to Failure Mode Effects Analysis >> (FMEA) offers the short-path to the simpler, >> lightest weight, lowest cost, lowest risk >> (elegant) design easily understood and managed by the >> cognizant pilot. >> >> Bob . . . >> >> * >> >> _blank">www.aeroelectric.com >> .com" target="_blank">www.buildersbooks.com >> ="_blank">www.homebuilthelp.com >> ="_blank">www.mypilotstore.com >> ank">www.mrrace.com >> _blank">http://www.matronics.com/contribution >> ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List >> tp://forums.matronics.com >> >> * >> >> * >> >> >> * > > > > > ________________________________________________________________________________
Date: Nov 27, 2014
Well, I had two electronic ignitions stone cold fail in Alaska. One at 40 below. The other in summer, but just as inconvenient. You don't hear about the failures much because they just pull over to roadside and call a tow truck. Typically when they fail it is a hard failure, not just rough running like a mag on its way out. I may install electronic in place of one mag, but definitely not two. On 11/27/2014 2:04 PM, Justin Jones wrote: > > I also fly in Alaska. I agree that a battery failure isnt as likely as a starter failure, but if having two batteries on the aircraft is an acceptable risk mitigation step for him, then he is justified having the extra battery. I will have two alternators. One gear driven and one belt driven. I will also carry a battery jump starter pack and a solar cell that is capable of charging it when I plan on spending any time in the bush. I understand the added weight of the pack, however after using it just a single time, it will have been worth it. If my starter does die and the battery still has at least 6 volts (EFII system minimum), the ignition and injection systems will still operate, making hand propping much easier than a healthy magneto. I will still need enough voltage to excite the alternator for continued 12v operation. One pass of the flywheel magnets past the crank trigger should start the engine. > > I disagree with the statement that electronic ignition adds risk. There are many reasons. > > 1st reason is the massive amount of time electric ignition has been in operation. Nearly every vehicle manufactured since the mid 70s has electronic ignition, meaning there are MANY MANY more hours of operation on electronic ignition units than magnetos. They have been proven VERY reliable and need very little maintenance. > > 2nd reason is there are solid state units that require no moving parts (crank trigger systems). It is true that there are different electric systems out there, however they all run on the same principal. There are also redundant systems available that can keep the engine running in the extremely unlikely event that one fails. Choose the one that is satisfactory to you and go with it. > > 3rd reason that electronic ignition doesnt add risk is the complexity and unreliability of magnetos. They have moving parts that wear. They have TBOs on them because they are known to wear and malfunction. They are heavy, expensive, and do not provide the same amount of energy that an electronic ignition does. I have personally had 3 magneto failures. Thankfully both have never quit on me at once. A good friend in a Maule M4 just had one fail last week. > > 4th reason is the correct 12v system architecture that electronic ignition requires is very reliable. The Z-diagrams that Bob has authored have the capability to mitigate most risk involved with the 12v system. I have personally chosen to go with a dual alternator system. I will carry small light solar panels that can recharge a battery in a matter of days. > > There is a good compromise out there. Look at the G3i ignition system. It adds an MSD electronic ignition box and runs it through the magneto (if you feel that you MUST have the unreliable mags). If the MSD box fails or if the battery dies, the magnetos will still act like magnetos. > > The thing to keep in mind regardless of how many batteries that you have on the aircraft is watching your battery health. If your battery or batteries show any sign of ill health, replace them. Dont push it. Batteries seldom fail overnight. Some people even replace them every annual. > > I feel that a properly installed and maintained redundant electronic ignition system will actually REDUCE the risk that the legacy magneto systems offer. > > Respectfully, > > Justin > > >> On Nov 27, 2014, at 11:10 AM, Kelly McMullen wrote: >> >> >> Well, having flown for 20 yrs in Alaska, I would take starter motor failure as a higher risk than battery failure. Adding electronic ignition to a plane in that environment IMHO adds risk over a dead simple pair of magnetos. Most of time there is a means to hand prop if lack of battery presents itself. Needing electrons to fire the ignition as well as crank the engine creates more potential risk. >> >> On 11/27/2014 12:32 PM, Ken Ryan wrote: >>> An argument can be made both for and against the second battery. I have considered both and determined that in my case the extra battery is justified. Your points are nevertheless well taken. >>> >>> On Nov 27, 2014 10:54 AM, "Robert L. Nuckolls, III" > wrote: >>> >>> At 10:58 AM 11/27/2014, you wrote: >>>> Being in Alaska, many landings are remote, off airport. The >>>> engine must start. If it doesn't the only option is to trigger >>>> search and rescue. Two batteries mitigates the risk of the engine >>>> not starting 150 miles from the nearest civilization. >>> >>> Okay, how often has the 'unavailable battery' syndrome >>> presented itself . . . and what was root cause for the >>> failure? >>> >>> A battery can and should be the single most reliable >>> source of energy on your airplane. This presumes, of >>> course, that you give it the same level of attention >>> to airworthiness that is bestowed upon fuel, oil, tires, >>> continuity of flight controls, fuel filters and sumps, >>> prop blade nicks, etc. etc. >>> >>> Batteries tend to be the oft neglected step-child >>> of flight systems. The predominant public perception >>> of battery consumerism is to run it until it wont >>> crank the engine any more . . . Walmart sells >>> a gizillion batteries every year that are replaced >>> in response to that same symptom. >>> >>> Some years ago I corresponded with a Cessna 206 >>> floatplane owner in S. America who was wanting to add a >>> second battery to his ship. We pondered useful volume >>> to exploit for several exchanges of e-mails. We >>> finally decided that inside one of the floats was >>> the best location. The battery could be positioned >>> right on C.G. and it occupied volume that had >>> no other purpose. >>> >>> After we had corresponded a few times, he agreed >>> that his REAL worry was for loss of a battery contactor. >>> He conceded that in the grand scheme of things, >>> battery maintenance was not a big adder to cost-of- >>> ownership, his big worry was for loss of battery >>> contactor that would make the battery unavailable. >>> >>> I suggested then than he add a piece of welding cable >>> to run from downstream side of battery contactor to >>> the battery box (accessible while standing on a >>> float). Should preflight testing before tossing >>> the mooring lines showed that the battery contactor was >>> "iffy", he could make a manual connection to the >>> battery (+) terminal with the short jumper. >>> >>> He decided that was a much less expensive, lighter >>> and lower cost plan-C for dealing with a failed >>> battery contactor. We also discussed simply carrying >>> a spare contactor and tools . . . but that didn't >>> cover the potential loss of wiring and/or battery >>> master switch. So he opted for the jumper-cable >>> and a pair of pliers. >>> >>> The point to ponder is how best to accommodate or >>> modify a system that is a direct descendant from >>> systems common to garden tractors: PM alternator, >>> simple rectifier/regulator and a lead acid battery. >>> >>> It seems that the elegant design goal is to craft >>> a combination of architecture, preventive maintenance\ >>> and operating procedures that accommodates low risk failures >>> -OR- drives specific failure rates down to insignificance. >>> >>> I believe this can be achieved without adding the >>> weight, cost or complexity of burdening a >>> garden-tractor-style electrical system with >>> concepts holy-watered by the FAA and embraced >>> by Boeing and Airbus. >>> >>> This requires a simple but thorough thought >>> process that goes through the steps of considering >>> EVERY part of your electrical system from crimped >>> terminals to alternators and batteries. >>> >>> How can this part fail? >>> >>> Is failure pre-flight detectable? >>> >>> If it fails in flight, how will I know about >>> it? >>> >>> How would in-flight failure affect comfortable >>> termination of flight? >>> >>> What are the lowest cost, lightest weight, >>> simplest mitigations for the failure? >>> >>> Due diligence to Failure Mode Effects Analysis >>> (FMEA) offers the short-path to the simpler, >>> lightest weight, lowest cost, lowest risk >>> (elegant) design easily understood and managed by the >>> cognizant pilot. >>> >>> Bob . . . >>> >>> * >>> >>> _blank">www.aeroelectric.com >>> .com" target="_blank">www.buildersbooks.com >>> ="_blank">www.homebuilthelp.com >>> ="_blank">www.mypilotstore.com >>> ank">www.mrrace.com >>> _blank">http://www.matronics.com/contribution >>> ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List >>> tp://forums.matronics.com >>> >>> * >>> >>> * >>> >>> >>> * >> >> >> >> > > ________________________________________________________________________________
Subject: Re: alternator / generator
Date: Nov 27, 2014
Nothing that we do in aviation, experimental aviation especially, is without risk. It is merely a game of acceptable risk. For me, having 2 independent and completely redundant electronic ignition units provides an acceptable level of risk. This is because there isnt a single point of failure in the system. I feel that the benefit of having both electronic units is the added performance of an adaptable timing curve and a much hotter spark. Others, such as yourself, feel comfortable with one electronic unit and one magneto. Both are correct because the system meets the designers acceptable amount of risk and both for different reasons. Cheers Justin > On Nov 27, 2014, at 12:15 PM, Kelly McMullen wrote: > > > Well, I had two electronic ignitions stone cold fail in Alaska. One at 40 below. The other in summer, but just as inconvenient. You don't hear about the failures much because they just pull over to roadside and call a tow truck. Typically when they fail it is a hard failure, not just rough running like a mag on its way out. I may install electronic in place of one mag, but definitely not two. > > On 11/27/2014 2:04 PM, Justin Jones wrote: >> >> I also fly in Alaska. I agree that a battery failure isnt as likely as a starter failure, but if having two batteries on the aircraft is an acceptable risk mitigation step for him, then he is justified having the extra battery. I will have two alternators. One gear driven and one belt driven. I will also carry a battery jump starter pack and a solar cell that is capable of charging it when I plan on spending any time in the bush. I understand the added weight of the pack, however after using it just a single time, it will have been worth it. If my starter does die and the battery still has at least 6 volts (EFII system minimum), the ignition and injection systems will still operate, making hand propping much easier than a healthy magneto. I will still need enough voltage to excite the alternator for continued 12v operation. One pass of the flywheel magnets past the crank trigger should start the engine. >> >> I disagree with the statement that electronic ignition adds risk. There are many reasons. >> >> 1st reason is the massive amount of time electric ignition has been in operation. Nearly every vehicle manufactured since the mid 70s has electronic ignition, meaning there are MANY MANY more hours of operation on electronic ignition units than magnetos. They have been proven VERY reliable and need very little maintenance. >> >> 2nd reason is there are solid state units that require no moving parts (crank trigger systems). It is true that there are different electric systems out there, however they all run on the same principal. There are also redundant systems available that can keep the engine running in the extremely unlikely event that one fails. Choose the one that is satisfactory to you and go with it. >> >> 3rd reason that electronic ignition doesnt add risk is the complexity and unreliability of magnetos. They have moving parts that wear. They have TBOs on them because they are known to wear and malfunction. They are heavy, expensive, and do not provide the same amount of energy that an electronic ignition does. I have personally had 3 magneto failures. Thankfully both have never quit on me at once. A good friend in a Maule M4 just had one fail last week. >> >> 4th reason is the correct 12v system architecture that electronic ignition requires is very reliable. The Z-diagrams that Bob has authored have the capability to mitigate most risk involved with the 12v system. I have personally chosen to go with a dual alternator system. I will carry small light solar panels that can recharge a battery in a matter of days. >> >> There is a good compromise out there. Look at the G3i ignition system. It adds an MSD electronic ignition box and runs it through the magneto (if you feel that you MUST have the unreliable mags). If the MSD box fails or if the battery dies, the magnetos will still act like magnetos. >> >> The thing to keep in mind regardless of how many batteries that you have on the aircraft is watching your battery health. If your battery or batteries show any sign of ill health, replace them. Dont push it. Batteries seldom fail overnight. Some people even replace them every annual. >> >> I feel that a properly installed and maintained redundant electronic ignition system will actually REDUCE the risk that the legacy magneto systems offer. >> >> Respectfully, >> >> Justin >> >> >>> On Nov 27, 2014, at 11:10 AM, Kelly McMullen wrote: >>> >>> > >>> Well, having flown for 20 yrs in Alaska, I would take starter motor failure as a higher risk than battery failure. Adding electronic ignition to a plane in that environment IMHO adds risk over a dead simple pair of magnetos. Most of time there is a means to hand prop if lack of battery presents itself. Needing electrons to fire the ignition as well as crank the engine creates more potential risk. >>> >>> On 11/27/2014 12:32 PM, Ken Ryan wrote: >>>> An argument can be made both for and against the second battery. I have considered both and determined that in my case the extra battery is justified. Your points are nevertheless well taken. >>>> >>>> On Nov 27, 2014 10:54 AM, "Robert L. Nuckolls, III" > wrote: >>>> >>>> At 10:58 AM 11/27/2014, you wrote: >>>>> Being in Alaska, many landings are remote, off airport. The >>>>> engine must start. If it doesn't the only option is to trigger >>>>> search and rescue. Two batteries mitigates the risk of the engine >>>>> not starting 150 miles from the nearest civilization. >>>> >>>> Okay, how often has the 'unavailable battery' syndrome >>>> presented itself . . . and what was root cause for the >>>> failure? >>>> >>>> A battery can and should be the single most reliable >>>> source of energy on your airplane. This presumes, of >>>> course, that you give it the same level of attention >>>> to airworthiness that is bestowed upon fuel, oil, tires, >>>> continuity of flight controls, fuel filters and sumps, >>>> prop blade nicks, etc. etc. >>>> >>>> Batteries tend to be the oft neglected step-child >>>> of flight systems. The predominant public perception >>>> of battery consumerism is to run it until it wont >>>> crank the engine any more . . . Walmart sells >>>> a gizillion batteries every year that are replaced >>>> in response to that same symptom. >>>> >>>> Some years ago I corresponded with a Cessna 206 >>>> floatplane owner in S. America who was wanting to add a >>>> second battery to his ship. We pondered useful volume >>>> to exploit for several exchanges of e-mails. We >>>> finally decided that inside one of the floats was >>>> the best location. The battery could be positioned >>>> right on C.G. and it occupied volume that had >>>> no other purpose. >>>> >>>> After we had corresponded a few times, he agreed >>>> that his REAL worry was for loss of a battery contactor. >>>> He conceded that in the grand scheme of things, >>>> battery maintenance was not a big adder to cost-of- >>>> ownership, his big worry was for loss of battery >>>> contactor that would make the battery unavailable. >>>> >>>> I suggested then than he add a piece of welding cable >>>> to run from downstream side of battery contactor to >>>> the battery box (accessible while standing on a >>>> float). Should preflight testing before tossing >>>> the mooring lines showed that the battery contactor was >>>> "iffy", he could make a manual connection to the >>>> battery (+) terminal with the short jumper. >>>> >>>> He decided that was a much less expensive, lighter >>>> and lower cost plan-C for dealing with a failed >>>> battery contactor. We also discussed simply carrying >>>> a spare contactor and tools . . . but that didn't >>>> cover the potential loss of wiring and/or battery >>>> master switch. So he opted for the jumper-cable >>>> and a pair of pliers. >>>> >>>> The point to ponder is how best to accommodate or >>>> modify a system that is a direct descendant from >>>> systems common to garden tractors: PM alternator, >>>> simple rectifier/regulator and a lead acid battery. >>>> >>>> It seems that the elegant design goal is to craft >>>> a combination of architecture, preventive maintenance\ >>>> and operating procedures that accommodates low risk failures >>>> -OR- drives specific failure rates down to insignificance. >>>> >>>> I believe this can be achieved without adding the >>>> weight, cost or complexity of burdening a >>>> garden-tractor-style electrical system with >>>> concepts holy-watered by the FAA and embraced >>>> by Boeing and Airbus. >>>> >>>> This requires a simple but thorough thought >>>> process that goes through the steps of considering >>>> EVERY part of your electrical system from crimped >>>> terminals to alternators and batteries. >>>> >>>> How can this part fail? >>>> >>>> Is failure pre-flight detectable? >>>> >>>> If it fails in flight, how will I know about >>>> it? >>>> >>>> How would in-flight failure affect comfortable >>>> termination of flight? >>>> >>>> What are the lowest cost, lightest weight, >>>> simplest mitigations for the failure? >>>> >>>> Due diligence to Failure Mode Effects Analysis >>>> (FMEA) offers the short-path to the simpler, >>>> lightest weight, lowest cost, lowest risk >>>> (elegant) design easily understood and managed by the >>>> cognizant pilot. >>>> >>>> Bob . . . >>>> >>>> * >>>> >>>> _blank">www.aeroelectric.com >>>> .com" target="_blank">www.buildersbooks.com >>>> ="_blank">www.homebuilthelp.com >>>> ="_blank">www.mypilotstore.com >>>> ank">www.mrrace.com >>>> _blank">http://www.matronics.com/contribution >>>> ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List >>>> tp://forums.matronics.com >>>> >>>> * >>>> >>>> * >>>> >>>> >>>> * >>> >>> >>> >>> >> >> >> >> >> > > > > > > > ________________________________________________________________________________
Date: Nov 28, 2014
Thanks for a very interesting thread, guys! Justin, I tend to agree with you on the reliability of the electronic systems. Where I think the problem comes in, is the inconsistency of the install, and the integration into the existing system. Best... Bob Verwey ________________________________________________________________________________
Date: Nov 28, 2014
Subject: Just Two Days Left! - Still Behind...
Dear Listers, There are just two more days left in this years List Fund Raiser. We are still way behind last year in terms of the number of contributions and total contribution amount. I really want to keep providing these services to the homebuilt community, but it take resources. Since there's no advertising budget or deep pockets to keep the operation a float, its solely your generosity during the Fund Raiser that keeps things going. Please make a Contribution today. If you've been putting off showing your support for the Lists, now is the time to do it! Make a contribution with a Credit Card or though PayPal at that Matronics Contribution web site: http://www.matronics.com/contribution Or, drop a check in the mail: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you in advance for your support! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 28, 2014
At 13:32 2014-11-27, you wrote: >An argument can be made both for and against the second battery. I >have considered both and determined that in my case the extra >battery is justified. Your points are nevertheless well taken. Can you share your battery selection and maintenance program? If you have only one engine driven power source, then do we presume correctly that you've gathered and massaged some numbers from which you've developed a Plan-B . . . a battery only endurance requirement that will be guarded with periodic measurement? If you plan to maintain and verify battery(ies) at some minimum energy content (the general rule of thumb is 80% of new capacity), is it not likely that you'll replace batteries before they become incapable of cranking the engine? This is the major difference between aviation and automotive where the battery is often tasked with two purposes . . . the very utilitarian purpose of getting the fan running and the Plan-B purpose of keeping the panel lit up sans alternator . . . sometimes for duration of fuel aboard. This is the core concept for my assertion that under artfully crafted circumstances, the battery will become the most robust device in your suite of engine cranking hardware . . . contrary to legacy consumer perceptions of battery dependability. Bob . . . ________________________________________________________________________________
Date: Nov 28, 2014
Date: Nov 29, 2014
At 09:52 2014-11-11, you wrote: >The Rotax 914 wiring diagram shows an integrated generator with >external regulator-rectifier and an external alternator with built >in regulator. It looks like the integrated generator is disconnected >from the battery (by relay) when the master is off but the external >alternator remains connected. The text indicates the integrated >generator will run the battery down if not disconnected, but does >not say that for the external alternator. Does this make sense? Sure. The alternators on ALL vehicles are controlled to a quiescent state when not in use. They present no load on the battery. Wire per Rotax instructions and it has a 99.99% probability of functioning as they intended. Bob . . . ________________________________________________________________________________
Date: Nov 29, 2014
Subject: Make Sure You're Listed! List of Contributors Coming
Soon! Dear Listers, There's just two more days left in this year's List Fund Raiser and that means the List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 30, 2014
Subject: Re: Touchy!
At 20:22 2014-11-28, you wrote: > >For any question or problem there are a number of ways to skin the >cat, including it may not be a problem at all. >To object to folks questioning whether he needs to do what he wants >is just as valid a discussion and learning point as assuming he has >correctly parsed his situation, already knows the best solution and >just needs to know how to implement it. Exactly. There's another important component to this discussion. The List is not just a place to ask, "what's 2 + 3 and where do I buy some 3's?" It's a classroom where about 1400 individuals watch the proceedings and take away buckets of simple-ideas along with a few recipes for their utilization. Whether we're cooking stuff up on the stove, writing software, or configuring an electrical system, the elegant solution will be elusive unless the 'chef' understands exactly how all the ingredients behave as individual components and then in combination with each other. In this class room environment there is, and should be, a high probability that any questioner may be asked to stand up in front of the class and defend his/her recipe for success. My bosses called this process preliminary, critical, and qualification design review. A means by which ideas could oscillate between any constellation of extremes as collegial argument deduces the elegant, lowest risk way to meet customer design goals. There is a risk that some questioner will feel picked on or belittled. I'm probably as guilty as any for not always making sure that the questioner understands this process along with his own, important role in this sharing of knowledge. Mr. Ryan has states some ideas and goals and he has been asked to share his supporting thought processes. Of course, nobody will be insulted or even disappointed if he declines. At the same time, everyone interested in the conversation may harvest and exploit any number of simple-ideas supported with examples of how they fit together. Bob . . . ________________________________________________________________________________
Date: Nov 30, 2014
Subject: [Please Read] - Last Official Day of List Fund Raiser!
Dear Listers, It's November 30th and that always means a couple of things. Its my birthday again - 51, so don't reminde me! :-) But it also means that it's that last official day of the Matronics Email List Fund Raiser! If you been thinking about picking up one of those really nice incentive gifts now is the time to jump on it!! If you've been meaning to make a Contribution this month but have been putting it off for some reason, NOW is the time! I will be posting the List of Contributors in a few days, so you'll probably want to be known as a person that supported the Lists! I want to thank everyone that has so generously made a Contribution this year in support of our Lists. It is your generosity that keeps this operation running and I don't ever forget it. The List Contribution Web Site is fast and easy. Please support our habit by making your Contribution right now: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you to all in advance! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 30, 2014
Hi I have a Rotax 914 with dual Lithium batteries and instead of the Rotax Ducati regulator use the Schicke GR6 regulator as it a more robust device. My aircraft French DynAero MCR-4S is advanced avionically and uses as it base Bob's infamous architecture. I do not have the external alternator as it is unnecessary (for me). On the primary bus I use a Vertical Power VP-X (serial connect for laptop control) and good old automotive fuses on the endurance bus. The VP-X controls the relay for alternator disconnect. This is a very stable environment with no problems of any sort. Happy to share my schematics. Cheers Peter -------- Peter Armstrong Auckland, New Zealand DynAero MCR-4S (Do not shoot me :) ). Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435182#435182 ________________________________________________________________________________
Subject: Slick magneto switch shield ground
Date: Nov 30, 2014
I am about to connect the magneto switch wires for Slick mags on a Lycoming O320 engine. I have the Z-34 set-up of two (2-3) magneto switches and a push button for the starter. Note 3 for Z34 advises grounding the shield to engine ground at the mag end. On a previous post I found this: I recommend each mag switch get grounded through the shield of the p-lead where only the mag end of the p-lead shield goes to the crankcase or other handy fastener on the engine. Bob . . . On the mag case an inch from the P lead post there is a handy #8 screw labelled GND. The case is intimately attached to the engine. Can this GND screw be the handy fastener on the engine where the P lead shield is grounded when wiring a mag switch per Z34? On the switch end, the same P lead shield gets attached to terminal 3 of the switch, right? Eric S. The mag pictured is not mine but is like the one I have and is for illustration only. No advertisement intended. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435191#435191 Attachments: http://forums.matronics.com//files/slick_magneto_596.jpg ________________________________________________________________________________
Date: Nov 30, 2014
Subject: Re: Slick magneto switch shield ground
On the mag case an inch from the P lead post there is a handy #8 screw labelled GND. The case is intimately attached to the engine. Can this GND screw be the handy fastener on the engine where the P lead shield is grounded when wiring a mag switch per Z34? Yes . . . or to any other 'handy' ground to crankcase . . . doesn't have to be on the mag nor is it prohibited to extend the shield ground with a pig-tail long enough to find a more remote ground. But it looks like your best option is nicely located. On the switch end, the same P lead shield gets attached to terminal 3 of the switch, right? Yes . . . Bob . . . ________________________________________________________________________________
Date: Dec 02, 2014
Subject: Re: B&C alternator question
At 09:08 2014-10-27, you wrote: >What is your opinion on the Zeftonici regulators? I had nothing but >trouble with regulators when I got my Pacer, and then heard about >Zeftronics. They got an STC for the Pacer PA20, and I put one >on. It has been absolutely trouble free for 20+ years, and I don't >remember it being very expensive. I knew the guy who started Zeftronics. We had many enjoyable conversations at OSH. He was a capable designer and manufacturer. I think the company is in new hands now but I've heard nothing to indicate that Zeftronics products are not of good value. Zeftronics shows up on the qualified suppliers lists for several devices at Cessna. Bob . . . ________________________________________________________________________________
Subject: Re: Touchy
Date: Dec 02, 2014
Bill, I understand your unanswered requests for help. It=99s not that they are uninteresting. It=99s because I don=99t have an answer and I don=99t want to be one of the ones cluttering up the list with speculation or proposing alternatives you don=99t need. Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop (75 hrs). Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com On Dec 2, 2014, at 8:13 AM, Bill Bradburry wrote: Stan, Very well said. A similar problem with the list is when there is no response at all. This happens to me quite frequently. I suppose it would help if I had more interesting problems. :>) Bill ________________________________________________________________________________
Date: Dec 02, 2014
Subject: Re: Touchy
While I see the value of the "why" type questions, I have to agree with Stan and Tim. I've been on the receiving end of this myself trying to get a relatively straight answer to an electrical question only to continually get derailed with exactly the types of comments that Tim mentions (and on the same topic as it turns out. :-) ) While the "why" can make for an interesting and thought provoking discussion, there are times when people just need a little help with decisions that they've made for their aircraft, which may not be the same decisions that someone else might have made. That's okay, and one of the reasons why we are in experimental aviation. In my case I ended up going elsewhere for help because I could not get the help I needed on the Aeroelectric list, even after doing as Tim suggested and indicating I didn't want to discuss the "why" any longer, but needed help with the "how". Even more frustrating, I brought my solution back to the List in an attempt to share with others, and was again berated for "why do you need to do that". I am happy to report that my solution was implemented and has been working fine for the past several months. Bob Nuckolls wrote, "The List is not just a place to ask, "what's 2 + 3 and where do I buy some 3's?". While I agree that the list is not *just* a place to ask the "how", the implication from previous discussions is that the List is a place where you can't ask the "how" without also providing a thesis on the "why". Is this the overall intent of the List? Again, I can absolutely see the value of the "why" discussions, to a point. I can also see the value in helping someone with the "how" once they have made their decision, and am hopeful that we could accommodate these types of discussions as well. My hope is that this message is taken as constructive feedback, and not as a complaint. My half cents, fwiw, -Dj On 12/02/2014 09:50 AM, Tim Olson wrote: > > Stan, > > While maybe a bit harsh, I get exactly what you're saying. > When you bring up Brownout protection, instead of getting > solutions, you get "why do you need brownout protection", > and "manufacturers should be building things tolerant of > starter-inrush brown-out events". While the fact remains, > there are systems that really should have brownout > protection and it can be a very useful thing. I could fill > a page on why brownout protection is important to me, > but nobody would want to spend the time to read through > that long enough to help with a solution. Sometimes you > just want it to be "ok" that you require it and you want > to get help with solutions. So I know what you mean. > I think if you just know some of the sticky topics going in, > maybe you can ask the pointed question and try to get > an answer from at least someone on the list. Like > > "I am building a panel and absolutely require brownout > protection. I'm not interested in debating the NEED > for brownout protection, but would like to know some of > the best options for those items requiring it?" > Maybe at least that would bypass some of the frustration > causing portions of the discussion. > > There are solutions out there for everything. I've been > very happy with my panel in my RV-10, and since I built > that, there are "out of the box" solutions from vendors > like TCW Tech that make things easier for the builder too. > So getting to what you need isn't impossible. > > Tim > > > > On 12/1/2014 11:30 PM, speedy11(at)aol.com wrote: >> Kelley, >> First of all, let me apologize for including all of the emails in my >> reply. That was a mistake. >> Secondly, perhaps I am being a bit touchy, but I consistently see the >> same crap on the aeroelectric list. >> Someone asks for advice on a relatively simple subject and gets skewered >> by several people who believe they are personally responsible for >> teaching the writer the wrongs of his ways. Some people get off on >> rants implying that their ideas and/or procedures must be followed or >> the writer has not adequately researched the subject and made the proper >> decisions. It is the reason this list is dying a slow painful death. >> Many of us have been around GA airplanes for 40 years (I own an aircraft >> maintenance company), but we may not know the best solution to a problem >> (or as Bob likes to think - perhaps a non-problem) especially as new >> innovative solutions are being tried. >> From personal experience you don't like full electronic ignition. >> Personally I like full electronic ignition. But, when a writer asks a >> question about something, he/she doesn't care our individual >> preferences. They are interested in a response that may give them >> greater insight into how to solve the particular problem for their >> particular airplane. >> The response they often get is no response at all or a response telling >> them how wrong they are. They aren't wrong! Just because someone >> decides to stray from the classical norms doesn't necessarily mean they >> are wrong. >> Justin may have given up on this forum to glean the information he >> desired. Can't say I blame him. He is on the cutting edge of potential >> improvements. His ideas may not work - then again they may work >> perfectly. I understand his reasons for choosing to use two batteries >> for remote AK operations. >> I agree with you that he may not be choosing the simplest solution, but >> it is his decision. He was simply asking for advice on how he might >> implement his decision. I'm surprised he didn't contact Paisley, Rotax >> and the battery manufacturer on how to best design his system instead of >> coming to the aeroelectric list for help (who knows, maybe he did). >> Nonetheless, I believe the response to him should have been something >> like this: >> 1. Contact the manufacturers and follow their advise. >> 2. You can probably implement your chosen equipment in this manner ... >> 3. However, have you considered doing this instead ... >> In other words, provide advice on how his idea might be accomplished and >> then give him advice on other considerations (one of which might be >> "don't do it because ..."). >> You said " If the best solution was so obvious, he would also know how >> to implement". There may not be a best solution. You implied that in >> your first sentence when you said "there are a number of ways to skin a >> cat". Justin has chosen a way to skin the cat. It may not be the best >> way, but it is his way. He was asking for advice on how to implement >> his skinning method - not advice on whether his method is the best, or >> even desirable. >> I find myself as frequently frustrated by responses on the aeroelectric >> list as I am satisfied with them. >> Touchy? Perhaps. >> Maybe I've become a grumpy old man. >> Safe flying to all, >> Stan Sutterfield >> Reno Race 84 -- Dj Merrill - N1JOV - VP EAA Chapter 87 Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Subject: Fusible links
Date: Dec 02, 2014
I can't find the detail in the book. When making a fusible link, the inner "fuse" wire is 22 AWG in this case. Is it necessary to strip the insulation off? Thanks Bevan ________________________________________________________________________________
Date: Dec 02, 2014
Subject: Re: Fusible links
At 11:44 2014-12-02, you wrote: > > >I can't find the detail in the book. When making a fusible link, the inner >"fuse" wire is 22 AWG in this case. Is it necessary to strip the insulation >off? I presume you're asking about the insulation on the 22AWG wire? No, in fact, you ADD insulation over it See http://tinyurl.com/msx5ofe Where are you considering the use of a fusible link? I crafted that comic-book waaayyy back when we were wrestling with the notion of extending the BUS in a fuse block up to a one-terminal-BUS at the input side of the alternator field breaker. A breaker upstream of a crow-bar ov protection module. I think we also dabbled with the use of fusible links on the meter-leads to a shunt. As a general rule, the fusible link is attractive only when a fuse holder is a little 'messy' . . . The TC fleet has used two fuses in clips to protect ammeter wires for decades. Emacs! The last time I was able to walk down the A36 production line (about 10 years ago) the clipped-in fuses for various 'minor' tasks were quite visible. The need to extend the bus to accommodate the only circuit breaker in the airplane was a special case. Like Figure Z-13/20, and to some extend Z-19, I've regretted having published the ideas. While useful and appropriate to the special cases, they've morphed into other forms that may or may not have been through PCQDR (preliminary, critical and qualification design review). Can or should we talk about it? Bob . . . ________________________________________________________________________________
Date: Dec 02, 2014
Thanks Bob, I had done it on mine a couple years back, but the other day I was helping a hangar neighbour make some improvements. He has a rear mounted battery on a BD4 (engine in front). He has one electronic ignition which was powered by an 18 awg wire connected on the firewall at the input power terminal at the starter solenoid. This fat wire was only powered when the master solenoid (located in back next to the battery) was active. Not ideal for electrically dependant ignition. There was a spare 18 awg wire already running all the way back to the battery and the owner wanted to use that. I suggested that we fuse it but that fuse would have to activate "slower" than the breaker on the panel. I therefore suggested a fusible link and that is where I crossed the line. Since it was such a good idea, and I had suggested it, it was suggested that I do it :) Not a problem since I had materials left over. Just couldn't remember if the 22awg wire (now hidden under the silicone impregnated sleeve) on my RV7 had been stripped or not. My thinking initially was that it must have been stripped because we really don't want any combustible material "inside" the fuse if possible. It didn't strip well, so I re-did it without stripping as you have confirmed. Thank you. Bevan _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Tuesday, December 02, 2014 11:41 AM Subject: Re: AeroElectric-List: Fusible links At 11:44 2014-12-02, you wrote: I can't find the detail in the book. When making a fusible link, the inner "fuse" wire is 22 AWG in this case. Is it necessary to strip the insulation off? I presume you're asking about the insulation on the 22AWG wire? No, in fact, you ADD insulation over it See http://tinyurl.com/msx5ofe Where are you considering the use of a fusible link? I crafted that comic-book waaayyy back when we were wrestling with the notion of extending the BUS in a fuse block up to a one-terminal-BUS at the input side of the alternator field breaker. A breaker upstream of a crow-bar ov protection module. I think we also dabbled with the use of fusible links on the meter-leads to a shunt. As a general rule, the fusible link is attractive only when a fuse holder is a little 'messy' . . . The TC fleet has used two fuses in clips to protect ammeter wires for decades. Emacs! The last time I was able to walk down the A36 production line (about 10 years ago) the clipped-in fuses for various 'minor' tasks were quite visible. The need to extend the bus to accommodate the only circuit breaker in the airplane was a special case. Like Figure Z-13/20, and to some extend Z-19, I've regretted having published the ideas. While useful and appropriate to the special cases, they've morphed into other forms that may or may not have been through PCQDR (preliminary, critical and qualification design review). Can or should we talk about it? Bob . . . ________________________________________________________________________________
Date: Dec 03, 2014
Subject: Touchy
There is an old saying, "Beggars can't be choosy." That applies to the AeroElectric List where replies are posted by volunteers. If I volunteered to help someone who then complained about my work, I would stop giving help. There is one very knowledgeable volunteer on the AeroElectric list who sometimes gives long winded and philosophical responses. Sometimes his response answers my question and sometimes not. Regardless, I appreciate it that he has volunteered his precious time to address my issue. There are many other participants on this forum who are also very knowledgeable. Some of them might not post a response to a question because they are afraid of getting flamed. So please treat everyone with respect. Do not post something that you would not say face to face. As for a question not being answered, maybe the question needs to be rephrased or needs to be more specific. Joe Gores ________________________________________________________________________________
Date: Dec 03, 2014
At 15:53 2014-12-02, you wrote: Thanks Bob, I had done it on mine a couple years back, but the other day I was helping a hangar neighbour make some improvements. He has a rear mounted battery on a BD4 (engine in front). He has one electronic ignition which was powered by an 18 awg wire connected on the firewall at the input power terminal at the starter solenoid. This fat wire was only powered when the master solenoid (located in back next to the battery) was active. Not ideal for electrically dependant ignition. There was a spare 18 awg wire already running all the way back to the battery and the owner wanted to use that. I suggested that we fuse it but that fuse would have to activate "slower" than the breaker on the panel. I therefore suggested a fusible link and that is where I crossed the line. Since it was such a good idea, and I had suggested it, it was suggested that I do it :) Not a problem since I had materials left over. Just couldn't remember if the 22awg wire (now hidden under the silicone impregnated sleeve) on my RV7 had been stripped or not. My thinking initially was that it must have been stripped because we really don't want any combustible material "inside" the fuse if possible. It didn't strip well, so I re-did it without stripping as you have confirmed. Thank you. Okay, this is a situation similar to the "bus extension" to panel mounted breaker for a crowbar ov protection system. Keep in mind that circuit protection is to keep the smoke in wires. Further, the 'rule of thumb' for always hot wires from a battery bus is to protect at 5A or less Given that fuses are MUCH faster than breakers . . . 7A fuse is a comfortable alternative to the 5A breaker. This is a convention driven by concerns for crash safety. Limit the energy available on an always-hot wire for the purposes of reducing risk of post crash fire. I don't believe for a minute that anyone did any tests combined with statistical analysis to come up with that 5A number . . . but intuitively, one finds comfort in protecting an always-hot wire at the lowest practical value. I suspect that the electronic ignition runs on MUCH less than 5A. What size is the panel mounted breaker? If it were my airplane, I'd drive the ignition supply wire from the battery through a 7A fuse and eliminate the panel mounted breaker. If that breaker EVER trips, then there's something seriously wrong with either the ignition system or the power pathway feeding it . . . the notion of resetting it is does not stand on favorable probabilities for recovery-by-reset. A 7A fuse, 5A breaker, or fusible link in the tail does not alter the probabilities . . . Bob . . . ________________________________________________________________________________
Date: Dec 03, 2014
Subject: Toroid beads VOR antenna vs. Active VOR antenna
> > >All perfectly doable. I just need to get a better understanding of >the necessities of your request. > >Thanks again, >James Understand. My current vision of this antenna suggests that it will look like a piece of RG coax with a little "lump" of a splice onto a 6-inch piece of wire. The 'lumpy splice' will contain a handful of components that allows the relatively poor antenna to deliver energy into the 50-ohm coax (end impedance of too-short element is WAAayyyy to high). A little background: Active antennas have been around for a long time. Adding some form of amplifier with a high input impedance to the antenna-end of a low impedance coax allows the 'crippled' but still quite serviceable antenna to deliver its energy into the low impedance feed line. Here are some examples: http://tinyurl.com/npdmnsw In particular, I'll call your attention to one of many versions described. Check out the "AA7" . .. Active Antenna AA-7 HF/VHF/UHF, 3-3000MHz It has an HF, VHF 'band' switch. You'll note that in the VHF position, the active circuitry consists of the single transistor and a couple of passive components. The circuit I posted earlier . . . Emacs! was an adaptation of the AA7 configuration. Most active antenna designs bring rf energy down the feed line and send dc power up to the antenna on the same feed line. I decided to keep coax installation as pristine as possible and not mess with the feed line after it leaves the antenna. So, the ready-to-install antenna assembly takes on the form described above where you hopefully will be able to offer a conduit through which the antenna can be extended into the wing. To eliminate the 'monkey motion' at the receiver end of the coax, dc power will have to be brought out to the amplifier on a separate, 22 awg wire that can be fed from the same breaker as the radio . . . The ferrite transformer cores came in last week. I need to brass-board this thing on the bench and verify performance before I squish it down into that 'lump' described earlier. An interesting and important feature of this experiment is to not glass the critter into place so that any future fiddling with the design doesn't take a hack saw to the airplane. I may mount one of this things on my roof and see how it compares with monitor antennas I have for listening to local city, police and fire services. I have one HF active antenna up there already. http://tinyurl.com/ou2ezdy The 'antenna' part of this critter is only a few inches long. I don't have any other HF optimized antennas up yet to compare it to . . . but this 'lump' on the end of a piece of coax hears 'lots of stuff'. Given that the 'stuff' of which VOR is made (high power, line of sight) it seems that our little experiment has a high probability of success for replacing the legacy dipoles and whiskers so favored by our TC brothers. Bob . . . ________________________________________________________________________________
Date: Dec 03, 2014
On 12/3/2014 10:26 AM, Robert L. Nuckolls, III wrote: > > > > At 15:53 2014-12-02, you wrote: > Thanks Bob, > > I had done it on mine a couple years back, but the other day I was > helping a hangar neighbour make some improvements. He has a rear > mounted battery on a BD4 (engine in front). He has one electronic > ignition which was powered by an 18 awg wire connected on the firewall > at the input power terminal at the starter solenoid. This fat wire was > only powered when the master solenoid (located in back next to the > battery) was active. Not ideal for electrically dependant ignition. > There was a spare 18 awg wire already running all the way back to the > battery and the owner wanted to use that. I suggested that we fuse it > but that fuse would have to activate "slower" than the breaker on the > panel. I therefore suggested a fusible link and that is where I > crossed the line. Since it was such a good idea, and I had suggested > it, it was suggested that I do it :) Not a problem since I had > materials left over. Just couldn't remember if the 22awg wire (now > hidden under the silicone impregnated sleeve) on my RV7 had been > stripped or not. My thinking initially was that it must have been > stripped because we really don't want any combustible material > "inside" the fuse if possible. It didn't strip well, so I re-did it > without stripping as you have confirmed. Thank you. > > Okay, this is a situation similar > to the "bus extension" to panel mounted > breaker for a crowbar ov protection > system. > > Keep in mind that circuit protection is > to keep the smoke in wires. Further, the > 'rule of thumb' for always hot wires from > a battery bus is to protect at 5A or less > Given that fuses are MUCH faster than > breakers . . . 7A fuse is a comfortable > alternative to the 5A breaker. > > This is a convention driven by concerns > for crash safety. Limit the energy available > on an always-hot wire for the purposes of > reducing risk of post crash fire. I don't > believe for a minute that anyone did any > tests combined with statistical analysis > to come up with that 5A number . . . but > intuitively, one finds comfort in protecting > an always-hot wire at the lowest practical > value. > > I suspect that the electronic ignition runs > on MUCH less than 5A. What size is the panel > mounted breaker? If it were my airplane, > I'd drive the ignition supply wire from the > battery through a 7A fuse and eliminate the > panel mounted breaker. > > If that breaker EVER trips, then there's > something seriously wrong with either > the ignition system or the power pathway > feeding it . . . the notion of resetting it > is does not stand on favorable probabilities > for recovery-by-reset. A 7A fuse, 5A breaker, > or fusible link in the tail does not alter > the probabilities . . . > > > Bob . . . Probably a safe assumption for 'traditional' a/c engines with stock fuel delivery, but different for 'alternative' (automotive-based) engines and increasingly, a/c engines, more current is required. Most automotive-based engines use high pressure fuel injection which must be included in current calculations. There's now a growing wave of automotive style injection on a/c engines, as well. High pressure gerotor or roller-vane fuel pumps typically draw 6-10 amps continuous. Even the little turbine style pumps (which must be installed inside the fuel tank; the input must be kept flooded) typically draw 3-4 amps. So total current demand to keep an 'electronic' engine running usually exceeds 10 amps; often as high as 15. So what's the solution? Dedicated fuse bus at the battery to distribute power to the various engine control components? Charlie ________________________________________________________________________________
Subject: Re:_AeroElectric-List:_Fusible_links?
Date: Dec 03, 2014
DQoNCg0KDQoNCg0KDQpQcm9iYWJseSBhIHNhZmUgYXNzdW1wdGlvbiBmb3IgJ3RyYWRpdGlvbmFs JyBhL2MgZW5naW5lcyB3aXRoIHN0b2NrIGZ1ZWwgDQpkZWxpdmVyeSwgYnV0IGRpZmZlcmVudCBm b3IgJ2FsdGVybmF0aXZlJyAoYXV0b21vdGl2ZS1iYXNlZCkgZW5naW5lcyBhbmQgDQppbmNyZWFz aW5nbHksIGEvYyBlbmdpbmVzLCBtb3JlIGN1cnJlbnQgaXMgcmVxdWlyZWQuIE1vc3QgDQphdXRv bW90aXZlLWJhc2VkIGVuZ2luZXMgdXNlIGhpZ2ggcHJlc3N1cmUgZnVlbCBpbmplY3Rpb24gd2hp Y2ggbXVzdCBiZSANCmluY2x1ZGVkIGluIGN1cnJlbnQgY2FsY3VsYXRpb25zLiBUaGVyZSdzIG5v dyBhIGdyb3dpbmcgd2F2ZSBvZiANCmF1dG9tb3RpdmUgc3R5bGUgaW5qZWN0aW9uIG9uIGEvYyBl bmdpbmVzLCBhcyB3ZWxsLiBIaWdoIHByZXNzdXJlIA0KZ2Vyb3RvciBvciByb2xsZXItdmFuZSBm dWVsIHB1bXBzIHR5cGljYWxseSBkcmF3IDYtMTAgYW1wcyBjb250aW51b3VzLiANCkV2ZW4gdGhl IGxpdHRsZSB0dXJiaW5lIHN0eWxlIHB1bXBzICh3aGljaCBtdXN0IGJlIGluc3RhbGxlZCBpbnNp ZGUgdGhlIA0KZnVlbCB0YW5rOyB0aGUgaW5wdXQgbXVzdCBiZSBrZXB0IGZsb29kZWQpIHR5cGlj YWxseSBkcmF3IDMtNCBhbXBzLiBTbyANCnRvdGFsIGN1cnJlbnQgZGVtYW5kIHRvIGtlZXAgYW4g J2VsZWN0cm9uaWMnIGVuZ2luZSBydW5uaW5nIHVzdWFsbHkgDQpleGNlZWRzIDEwIGFtcHM7IG9m dGVuIGFzIGhpZ2ggYXMgMTUuDQoNClNvIHdoYXQncyB0aGUgc29sdXRpb24/IERlZGljYXRlZCBm dXNlIGJ1cyBhdCB0aGUgYmF0dGVyeSB0byBkaXN0cmlidXRlIA0KcG93ZXIgdG8gdGhlIHZhcmlv dXMgZW5naW5lIGNvbnRyb2wgY29tcG9uZW50cz8NCg0KDQoNCg0KTWluZSBpcyBzZXQgdXAgd2l0 aCBkdWFsIGVsZWN0cm9uaWMgaWduaXRpb24gYW5kIGR1YWwgZnVlbCBwdW1wcy4gIFdpdGggbXkg ZHVhbCBiYXR0ZXJ5IHN5c3RlbSBJIGhhdmUgMiBmdXNlZCBjaXJjdWl0cyBvZmYgdGhlIG1haW4g YmF0dGVyeSBidXMgZ29pbmcgdG8gaWduaXRpb24gIzEgYW5kIGZ1ZWwgcHVtcCAjMS4gIEZyb20g bXkgQXV4aWxpYXJ5IGJhdHRlcnkgYnVzIEkgaGF2ZSBhbm90aGVyIDIgZnVzZWQgY2lyY3VpdHMg Z29pbmcgdG8gSWduaXRpb24gIzIgYW5kIGZ1ZWwgcHVtcCAjMi4gIFdpdGggdGhpcyBzeXN0ZW0g eW91IGhhdmUgdG90YWwgcmVkdW5kYW5jeSBhbmQgbGltaXRlZCBjdXJyZW50IGluIGVhY2ggd2ly ZS4NCg0KDQpSb2dlcg= ________________________________________________________________________________
Date: Dec 03, 2014
Probably a safe assumption for 'traditional' a/c engines with stock fuel delivery, but different for 'alternative' (automotive-based) engines and increasingly, a/c engines, more current is required. Most automotive-based engines use high pressure fuel injection which must be included in current calculations. There's now a growing wave of automotive style injection on a/c engines, as well. High pressure gerotor or roller-vane fuel pumps typically draw 6-10 amps continuous. Even the little turbine style pumps (which must be installed inside the fuel tank; the input must be kept flooded) typically draw 3-4 amps. So total current demand to keep an 'electronic' engine running usually exceeds 10 amps; often as high as 15. So what's the solution? Dedicated fuse bus at the battery to distribute power to the various engine control components? He was talking about an ignition system. Energy to light the fires is quite nominal. Not aware of any ignition that requires more than 3A. Lightspeed's flame throwing CD ignition runs 2.6A at 2700 rpm on a 6 cyl engine. Fuel delivery is another matter and, as you've noted, can be all over the map. TBI systems run on a few amps while some 40+ psi rail fed injector systems can be MUCH higher. I'd treat this like the heavy duty e-bus feeder illustrated in Z-32 . . . except the e-bus alt feed switch becomes a fuel system control switch. The relay could be a solid state device or one of the sealed electro-mechanical critters. This comports nicely with the TC aircraft philosophy for achieving a Max-Cold state of all wires when crew operated switches are placed to OFF. Bob . . . ________________________________________________________________________________
Date: Dec 03, 2014
DQoNCg0KDQoNCg0KDQogTm90IGF3YXJlIG9mDQogICAgYW55IGlnbml0aW9uIHRoYXQgcmVxdWly ZXMgbW9yZSB0aGFuIDNBLiBMaWdodHNwZWVkJ3MNCiAgICBmbGFtZSB0aHJvd2luZyBDRCBpZ25p dGlvbiBydW5zIDIuNkEgYXQgMjcwMCBycG0gb24NCiAgICBhIDYgY3lsIGVuZ2luZS4NCg0KDQoN CklmIHlvdSBhcmUgdXNpbmcgYSBQU1JVIChwcm9wZWxsZXIgc3BlZWQgcmVkdWN0aW9uIHVuaXQp IG9uIGEgNiBjeWxpbmRlciBlbmdpbmUgeW91IHdpbGwgaGF2ZSBhIGhpZ2hlciBlbmdpbmUgUlBN LCBwZXJoYXBzIGluIHRoZSByYW5nZSBvZiA0IC0gNSBrIHJwbS4gIFRoaXMgaGlnaGVyIHNwZWVk IHdpbGwgdHJhbnNsYXRlIHRvIGEgaGlnaGVyIGN1cnJlbnQgZmxvdyB0byB0aGUgZWxlY3Ryb25p YyBDRCBpZ25pdGlvbi4gIEFuIE1TRCA2QSBhdXRvbW90aXZlIENEIGlnbml0aW9uIG1vZHVsZSBp cyBzcGVjaWZpZWQgYXQgMUEgLyAxSyBSUE0sIHdoaWNoIHRyYW5zbGF0ZXMgdG8gcGVyaGFwcyA1 QSB3b3JzdCBjYXNlLg0KDQoNClJvZ2Vy ________________________________________________________________________________
Subject: Always on supply
Date: Dec 03, 2014
The GPS manufacturer suggests connecting a second, always on, supply (they call it "clock power") which will improve GPS position acquisition time. What is the preferred way of providing this power? Run a fused line (they recommend a .1a fuse) directly from a battery terminal (or battery side of the master solenoid) to the GPS? IIRC, the EFIS would like one of these always on supplies also. So maybe run a fused wire from the battery to the panel and create an "always on" bus with fused branches off of that? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435279#435279 ________________________________________________________________________________
Date: Dec 03, 2014
At 14:08 2014-12-03, you wrote: > Not aware of > any ignition that requires more than 3A. Lightspeed's > flame throwing CD ignition runs 2.6A at 2700 rpm on > a 6 cyl engine. > > >If you are using a PSRU (propeller speed reduction unit) on a 6 >cylinder engine you will have a higher engine RPM, perhaps in the >range of 4 - 5 k rpm. This higher speed will translate to a higher >current flow to the electronic CD ignition. An MSD 6A automotive CD >ignition module is specified at 1A / 1K RPM, which translates to >perhaps 5A worst case. Hmmmm . . . that's too bad. There's no good reason for ignition systems to draw that much current. I've talked with the guys at EmagAir about this several times. A take-away from those conversations says that it's most important to get an adequate spark delivered right on time. Magnetos have proven their ability to deliver adequate sparks while running . . . and they're certainly not flame throwers. Certainly hard to fiddle with the timing . . . and you need some kind of monkey motion like impulse couplers or shower-of-sparks to effect nice starts . . . but there's hundreds of thousands flying with few critical issues. Being able to advance the spark at low manifold pressures gets you some benefit . . .but the spark doesn't need to be any hotter . . . in fact, worst case sparking requirements are at max cylinder pressure which probably means a boosted engine at max retard timing. The legacy Kettering coil, condenser, points system delivers about 30-40 mJ per spark. For a 6-cyl engine running 2400 rpm, 40 rev/sec, 3 sparks per rev, energy at the plugs comes to about 120 mJ per rev or 4800 mJ per second. Assume a really lousy system efficiency of say 50% and we need to draw 9.6 watts from the ship's bus or about 700 mA. Now, deliver that energy even while cold and with a soggy battery . . . and be able to advance the timing at low manifold pressures, and you've got a perfectly adequate ignition system. So be curious and skeptical when someone says their 'flame throwing ignition system' is going to do great things for your airplane. If you're flying a racer, maybe. If you've got a nice point-a to point-b transportation machine that carries battery energy to implement Plan-B, perhaps all that flame at the spark plugs suggests a need to re-think the planning. Elegant solutions benefit from good stewardship of energy. It starts with the airfoils and extends down to batteries and fuel aboard. Bob . . . ________________________________________________________________________________
Date: Dec 03, 2014
Thanks Bob, The literature that came with the LightSpeed says the breaker should be 7.5 amp. (IO-540) You still recommend a 5 amp breaker (since he really wants some form of disconnect on the panel) and a (??? Value fuse, fusible link, breaker)at the rear for the feed from the battery. Perhaps I should suggest a 5 or 7.5 amp slow blo fuse at the battery, and a simple switch on the panel in place of the breaker if he must have a disconnect. Bevan -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Wednesday, December 03, 2014 8:27 AM Subject: RE: AeroElectric-List: Fusible links --> At 15:53 2014-12-02, you wrote: Thanks Bob, I had done it on mine a couple years back, but the other day I was helping a hangar neighbour make some improvements. He has a rear mounted battery on a BD4 (engine in front). He has one electronic ignition which was powered by an 18 awg wire connected on the firewall at the input power terminal at the starter solenoid. This fat wire was only powered when the master solenoid (located in back next to the battery) was active. Not ideal for electrically dependant ignition. There was a spare 18 awg wire already running all the way back to the battery and the owner wanted to use that. I suggested that we fuse it but that fuse would have to activate "slower" than the breaker on the panel. I therefore suggested a fusible link and that is where I crossed the line. Since it was such a good idea, and I had suggested it, it was suggested that I do it :) Not a problem since I had materials left over. Just couldn't remember if the 22awg wire (now hidden under the silicone impregnated sleeve) on my RV7 had been stripped or not. My thinking initially was that it must have been stripped because we really don't want any combustible material "inside" the fuse if possible. It didn't strip well, so I re-did it without stripping as you have confirmed. Thank you. Okay, this is a situation similar to the "bus extension" to panel mounted breaker for a crowbar ov protection system. Keep in mind that circuit protection is to keep the smoke in wires. Further, the 'rule of thumb' for always hot wires from a battery bus is to protect at 5A or less Given that fuses are MUCH faster than breakers . . . 7A fuse is a comfortable alternative to the 5A breaker. This is a convention driven by concerns for crash safety. Limit the energy available on an always-hot wire for the purposes of reducing risk of post crash fire. I don't believe for a minute that anyone did any tests combined with statistical analysis to come up with that 5A number . . . but intuitively, one finds comfort in protecting an always-hot wire at the lowest practical value. I suspect that the electronic ignition runs on MUCH less than 5A. What size is the panel mounted breaker? If it were my airplane, I'd drive the ignition supply wire from the battery through a 7A fuse and eliminate the panel mounted breaker. If that breaker EVER trips, then there's something seriously wrong with either the ignition system or the power pathway feeding it . . . the notion of resetting it is does not stand on favorable probabilities for recovery-by-reset. A 7A fuse, 5A breaker, or fusible link in the tail does not alter the probabilities . . . Bob . . . ________________________________________________________________________________
Subject: Re: Touchy
Date: Dec 03, 2014
I was being "cute" with the uninteresting comment, Bob. I suspect that everything on the list is interesting to someone on the list, although maybe not to everybody on the list. I think I get something even from the posts that I don't quite understand and for sure from the posts counseling the need for something someone wants to do. Sometimes I agree and sometimes not, but an opinion not your own can sometimes turn on a light bulb. When my questions get ignored I just assume that no one reading that day has a suggestion that he feels strongly about enough to post. It is disappointing though, when you really kinda want a suggestion and don't get anything and then some fairly basic thing will get 10 hits. :>) But I am not criticizing the list, because God knows, I am flying an airplane the parts of which would still be scattered all over the hangar if it had not been for the good and generous graces if Bob N. and the others on this list. Bill _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert Borger Sent: Tuesday, December 02, 2014 9:15 AM Subject: Re: AeroElectric-List: Re: Touchy Bill, I understand your unanswered requests for help. It's not that they are uninteresting. It's because I don't have an answer and I don't want to be one of the ones cluttering up the list with speculation or proposing alternatives you don't need. Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop (75 hrs). Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com On Dec 2, 2014, at 8:13 AM, Bill Bradburry wrote: Stan, Very well said. A similar problem with the list is when there is no response at all. This happens to me quite frequently. I suppose it would help if I had more interesting problems. :>) Bill ________________________________________________________________________________
Date: Dec 03, 2014
Hi, I've been involved in electronics for some 30 years. I know what a fusible link is in an automobile. They do come in a variety of designs, some very much like a fuse as we know them. I have always questioned the value of a fusible link such as is used in automobiles. They are a length of wire, usually 4 wire gauges smaller than the wire they are protecting. They are most often a hassle to replace. Why would not a common fuse perform the same function and be much more easily replaced? Inquiring minds want to know, Lyle On 12/3/2014 4:14 PM, Robert L. Nuckolls, III wrote: > > > At 14:08 2014-12-03, you wrote: > > >> Not aware of >> any ignition that requires more than 3A. Lightspeed's >> flame throwing CD ignition runs 2.6A at 2700 rpm on >> a 6 cyl engine. >> >> >> If you are using a PSRU (propeller speed reduction unit) on a 6 >> cylinder engine you will have a higher engine RPM, perhaps in the >> range of 4 - 5 k rpm. This higher speed will translate to a higher >> current flow to the electronic CD ignition. An MSD 6A automotive CD >> ignition module is specified at 1A / 1K RPM, which translates to >> perhaps 5A worst case. > > -- Lyle Sent from my Gateway E4610D desktop ________________________________________________________________________________
Date: Dec 03, 2014
The advantages of the fusible link in this case is: Must be slower acting than the breaker. I blew quite a few fuses until I found that I needed a fuse of about double the value to ensure the breaker trips first. This would suggest a 15 amp fuse which is larger than desired. Robust (although a fuse in an inline holder is equally suitable in this regard.) There's no place to mount a breaker near the battery where it is easily accessible and yet not in the way for battery access through the small panel where it is located. Cost and availability. We're trying to get this airplane back in the air so it can go home. They can make more permanent changes there. Bevan -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Lyle Peterson Sent: Wednesday, December 03, 2014 7:08 PM Subject: Re: AeroElectric-List: Fusible links --> Hi, I've been involved in electronics for some 30 years. I know what a fusible link is in an automobile. They do come in a variety of designs, some very much like a fuse as we know them. I have always questioned the value of a fusible link such as is used in automobiles. They are a length of wire, usually 4 wire gauges smaller than the wire they are protecting. They are most often a hassle to replace. Why would not a common fuse perform the same function and be much more easily replaced? Inquiring minds want to know, Lyle On 12/3/2014 4:14 PM, Robert L. Nuckolls, III wrote: > > > At 14:08 2014-12-03, you wrote: > > >> Not aware of >> any ignition that requires more than 3A. Lightspeed's >> flame throwing CD ignition runs 2.6A at 2700 rpm on >> a 6 cyl engine. >> >> >> If you are using a PSRU (propeller speed reduction unit) on a 6 >> cylinder engine you will have a higher engine RPM, perhaps in the >> range of 4 - 5 k rpm. This higher speed will translate to a higher >> current flow to the electronic CD ignition. An MSD 6A automotive CD >> ignition module is specified at 1A / 1K RPM, which translates to >> perhaps 5A worst case. > > -- Lyle Sent from my Gateway E4610D desktop ________________________________________________________________________________
Subject: Sending two msgs to the list
Date: Dec 03, 2014
I seem to be sending two msgs to the list each time I post. I am using Outlook. Does anyone know why this may be happening? It appears to have started a couple of days ago. The msgs are about 12 minutes apart and I am only hitting send one time. AFAIK it is only happening with msgs to the Aeroelectric list. Thanks for any ideas. Bill ________________________________________________________________________________
Date: Dec 04, 2014
Subject: Fusible links NOW VARIATION ON A THEME
So I have a fat wire (00) running from the battery behind pilot seat, to the firewall, from whence the starter fat wire is connected on the engine side, and a 4 awg behind the firewall to the bus through a contactor. Its a Chevy V6, so the starter contactor is built into the starter. The fat wire is always hot at this stage, and I am looking for a solution in the form of a fuse/ fusible link near the battery so that in the event of an accident induced short, or an engaged starter hangup, that there is protection. Best... Bob Verwey On 2 December 2014 at 23:53, B Tomm wrote: > Thanks Bob, > > I had done it on mine a couple years back, but the other day I was helping > a hangar neighbour make some improvements. He has a rear mounted battery > on a BD4 (engine in front). He has one electronic ignition which > was powered by an 18 awg wire connected on the firewall at the input power > terminal at the starter solenoid. This fat wire was only powered when the > master solenoid (located in back next to the battery) was active. Not > ideal for electrically dependant ignition. There was a spare 18 awg wire > already running all the way back to the battery and the owner wanted to use > that. I suggested that we fuse it but that fuse would have to activate > "slower" than the breaker on the panel. I therefore suggested a fusible > link and that is where I crossed the line. Since it was such a good idea, > and I had suggested it, it was suggested that I do it :) Not a problem > since I had materials left over. Just couldn't remember if the 22awg wire > (now hidden under the silicone impregnated sleeve) on my RV7 had been > stripped or not. My thinking initially was that it must have been stripped > because we really don't want any combustible material "inside" the fuse if > possible. It didn't strip well, so I re-did it without stripping as you > have confirmed. Thank you. > > Bevan > > ------------------------------ > *From:* owner-aeroelectric-list-server(at)matronics.com [mailto: > owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of *Robert L. > Nuckolls, III > *Sent:* Tuesday, December 02, 2014 11:41 AM > *To:* aeroelectric-list(at)matronics.com > *Subject:* Re: AeroElectric-List: Fusible links > > At 11:44 2014-12-02, you wrote: > > > I can't find the detail in the book. When making a fusible link, the inner > "fuse" wire is 22 AWG in this case. Is it necessary to strip the > insulation > off? > > > I presume you're asking about the insulation on the > 22AWG wire? No, in fact, you ADD insulation over it > > See http://tinyurl.com/msx5ofe > > Where are you considering the use of a fusible link? > I crafted that comic-book waaayyy back when we were > wrestling with the notion of extending the BUS in a > fuse block up to a one-terminal-BUS at the input side > of the alternator field breaker. A breaker upstream > of a crow-bar ov protection module. > > I think we also dabbled with the use of fusible links > on the meter-leads to a shunt. As a general rule, the > fusible link is attractive only when a fuse holder > is a little 'messy' . . . The TC fleet has used two > fuses in clips to protect ammeter wires for decades. > > [image: Emacs!] > > The last time I was able to walk down the A36 > production line (about 10 years ago) the clipped-in > fuses for various 'minor' tasks were quite visible. > > The need to extend the bus to accommodate the only > circuit breaker in the airplane was a special case. > > Like Figure Z-13/20, and to some extend Z-19, I've > regretted having published the ideas. While useful > and appropriate to the special cases, they've > morphed into other forms that may or may not > have been through PCQDR (preliminary, critical > and qualification design review). > > Can or should we talk about it? > > Bob . . . > ________________________________________________________________________________
Subject: Re: Fusible links NOW VARIATION ON A THEME
Date: Dec 03, 2014
Bob, If you don=99t want to run your starter through the master contractor, I suggest you use a device like this. A location closer to the battery is better. A cable can be used in place of the push tube if you need. http://www.jegs.com/i/Flaming+River/898/FR1003-2/10002/-1 <http://www.jegs.com/i/Flaming+River/898/FR1003-2/10002/-1> During a run-on or stuck starter situation, it will take a while for the fusable link to burn through. This switch will also allow you to shut off the power to the starter any time you don=99t need it, such as the aircraft sitting on the ground or while doing maintenance. The last thing you want is to be working on the engine and accidentally short out the contacts of the starter and have that prop come swinging through. If you are doing maintenance on the starter itself, I would still disconnect the battery from the starter cable. Hope this helps. Justin > On Dec 3, 2014, at 11:19 PM, Bob Verwey wrote: > > So I have a fat wire (00) running from the battery behind pilot seat, to the firewall, from whence the starter fat wire is connected on the engine side, and a 4 awg behind the firewall to the bus through a contactor. > > Its a Chevy V6, so the starter contactor is built into the starter. > > The fat wire is always hot at this stage, and I am looking for a solution in the form of a fuse/ fusible link near the battery so that in the event of an accident induced short, or an engaged starter hangup, that there is protection. > > > > Best... > > Bob Verwey > > > On 2 December 2014 at 23:53, B Tomm > wrote: > Thanks Bob, > > I had done it on mine a couple years back, but the other day I was helping a hangar neighbour make some improvements. He has a rear mounted battery on a BD4 (engine in front). He has one electronic ignition which was powered by an 18 awg wire connected on the firewall at the input power terminal at the starter solenoid. This fat wire was only powered when the master solenoid (located in back next to the battery) was active. Not ideal for electrically dependant ignition. There was a spare 18 awg wire already running all the way back to the battery and the owner wanted to use that. I suggested that we fuse it but that fuse would have to activate "slower" than the breaker on the panel. I therefore suggested a fusible link and that is where I crossed the line. Since it was such a good idea, and I had suggested it, it was suggested that I do it :) Not a problem since I had materials left over. Just couldn't remember if the 22awg wire (now hidden under the silicone impregnated sleeve) on my RV7 had been stripped or not. My thinking initially was that it must have been stripped because we really don't want any combustible material "inside" the fuse if possible. It didn't strip well, so I re-did it without stripping as you have confirmed. Thank you. > > Bevan > > From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com ] On Behalf Of Robert L. Nuckolls, III > Sent: Tuesday, December 02, 2014 11:41 AM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Fusible links > > At 11:44 2014-12-02, you wrote: > >> >> >> >> I can't find the detail in the book. When making a fusible link, the inner >> "fuse" wire is 22 AWG in this case. Is it necessary to strip the insulation >> off? > > I presume you're asking about the insulation on the > 22AWG wire? No, in fact, you ADD insulation over it > > See http://tinyurl.com/msx5ofe > > Where are you considering the use of a fusible link? > I crafted that comic-book waaayyy back when we were > wrestling with the notion of extending the BUS in a > fuse block up to a one-terminal-BUS at the input side > of the alternator field breaker. A breaker upstream > of a crow-bar ov protection module. > > I think we also dabbled with the use of fusible links > on the meter-leads to a shunt. As a general rule, the > fusible link is attractive only when a fuse holder > is a little 'messy' . . . The TC fleet has used two > fuses in clips to protect ammeter wires for decades. > > <400400db.jpg> > > The last time I was able to walk down the A36 > production line (about 10 years ago) the clipped-in > fuses for various 'minor' tasks were quite visible. > > The need to extend the bus to accommodate the only > circuit breaker in the airplane was a special case. > > Like Figure Z-13/20, and to some extend Z-19, I've > regretted having published the ideas. While useful > and appropriate to the special cases, they've > morphed into other forms that may or may not > have been through PCQDR (preliminary, critical > and qualification design review). > > Can or should we talk about it? > > Bob . . . > > ________________________________________________________________________________
Date: Dec 04, 2014
Thanks Justin, I have a very similar device lying on the shelf in my shop, used in boating applications. I guess I was just looking for some re-assurance that it is a good solution . Thanks! Best... Bob Verwey On 4 December 2014 at 10:49, Justin Jones wrote: > Bob, > > If you don=99t want to run your starter through the master contract or, I > suggest you use a device like this. A location closer to the battery is > better. A cable can be used in place of the push tube if you need. > > http://www.jegs.com/i/Flaming+River/898/FR1003-2/10002/-1 > > During a run-on or stuck starter situation, it will take a while for the > fusable link to burn through. This switch will also allow you to shut of f > the power to the starter any time you don=99t need it, such as the aircraft > sitting on the ground or while doing maintenance. The last thing you wan t > is to be working on the engine and accidentally short out the contacts of > the starter and have that prop come swinging through. If you are doing > maintenance on the starter itself, I would still disconnect the battery > from the starter cable. > > Hope this helps. > > Justin > > > On Dec 3, 2014, at 11:19 PM, Bob Verwey wrote: > > So I have a fat wire (00) running from the battery behind pilot seat, to > the firewall, from whence the starter fat wire is connected on the engine > side, and a 4 awg behind the firewall to the bus through a contactor. > > Its a Chevy V6, so the starter contactor is built into the starter. > > The fat wire is always hot at this stage, and I am looking for a solution > in the form of a fuse/ fusible link near the battery so that in the event > of an accident induced short, or an engaged starter hangup, that there is > protection. > > > Best... > > Bob Verwey > > > On 2 December 2014 at 23:53, B Tomm wrote: > >> Thanks Bob, >> >> I had done it on mine a couple years back, but the other day I was >> helping a hangar neighbour make some improvements. He has a rear mounte d >> battery on a BD4 (engine in front). He has one electronic ignition whic h >> was powered by an 18 awg wire connected on the firewall at the input pow er >> terminal at the starter solenoid. This fat wire was only powered when t he >> master solenoid (located in back next to the battery) was active. Not >> ideal for electrically dependant ignition. There was a spare 18 awg wir e >> already running all the way back to the battery and the owner wanted to use >> that. I suggested that we fuse it but that fuse would have to activate >> "slower" than the breaker on the panel. I therefore suggested a fusibl e >> link and that is where I crossed the line. Since it was such a good ide a, >> and I had suggested it, it was suggested that I do it :) Not a proble m >> since I had materials left over. Just couldn't remember if the 22awg wi re >> (now hidden under the silicone impregnated sleeve) on my RV7 had been >> stripped or not. My thinking initially was that it must have been strip ped >> because we really don't want any combustible material "inside" the fuse if >> possible. It didn't strip well, so I re-did it without stripping as you >> have confirmed. Thank you. >> >> Bevan >> >> ------------------------------ >> *From:* owner-aeroelectric-list-server(at)matronics.com [mailto: >> owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of *Robert L. >> Nuckolls, III >> *Sent:* Tuesday, December 02, 2014 11:41 AM >> *To:* aeroelectric-list(at)matronics.com >> *Subject:* Re: AeroElectric-List: Fusible links >> >> At 11:44 2014-12-02, you wrote: >> >> >> >> >> I can't find the detail in the book. When making a fusible link, the >> inner >> "fuse" wire is 22 AWG in this case. Is it necessary to strip the >> insulation >> off? >> >> >> I presume you're asking about the insulation on the >> 22AWG wire? No, in fact, you ADD insulation over it >> >> See http://tinyurl.com/msx5ofe >> >> Where are you considering the use of a fusible link? >> I crafted that comic-book waaayyy back when we were >> wrestling with the notion of extending the BUS in a >> fuse block up to a one-terminal-BUS at the input side >> of the alternator field breaker. A breaker upstream >> of a crow-bar ov protection module. >> >> I think we also dabbled with the use of fusible links >> on the meter-leads to a shunt. As a general rule, the >> fusible link is attractive only when a fuse holder >> is a little 'messy' . . . The TC fleet has used two >> fuses in clips to protect ammeter wires for decades. >> >> <400400db.jpg> >> >> The last time I was able to walk down the A36 >> production line (about 10 years ago) the clipped-in >> fuses for various 'minor' tasks were quite visible. >> >> The need to extend the bus to accommodate the only >> circuit breaker in the airplane was a special case. >> >> Like Figure Z-13/20, and to some extend Z-19, I've >> regretted having published the ideas. While useful >> and appropriate to the special cases, they've >> morphed into other forms that may or may not >> have been through PCQDR (preliminary, critical >> and qualification design review). >> >> Can or should we talk about it? >> >> Bob . . . >> > > > * > =========== m> ldersbooks.com> .com> com> om/contribution> =========== www.matronics.com/Navigator?AeroElectric-List> =========== =========== > > * > > ________________________________________________________________________________
Date: Dec 04, 2014
Subject: Re: Touchy
On 12/3/2014 10:13 AM, Joe wrote: > > There is an old saying, "Beggars can't be choosy." That applies to > the AeroElectric List where replies are posted by volunteers. If I > volunteered to help someone who then complained about my work, I would > stop giving help. There is one very knowledgeable volunteer on the > AeroElectric list who sometimes gives long winded and philosophical > responses. Sometimes his response answers my question and sometimes > not. Regardless, I appreciate it that he has volunteered his precious > time to address my issue. There are many other participants on this > forum who are also very knowledgeable. Some of them might not post a > response to a question because they are afraid of getting flamed. So > please treat everyone with respect. Do not post something that you > would not say face to face. As for a question not being answered, > maybe the question needs to be rephrased or needs to be more specific. > Joe Gores > I'd second that. Regarding 'brownout protection' in particular; I too am a builder that wanted/needed such protection for my 'kitchen sink' panel. Bob never 'liked it', always challenged it and I learned a lot along the way but in the end, it's my plane, I fly it, I got it and am very happy. Oh, forgot to mention, he was right on every point I can recall not that it really matters since the points of disagreements only involved personal operating practices, not electrons, systems or products. But I valued every interaction with every single person, particularly Bob, on this list. From my perspective, this is Bob's playpen, school, blog, whatever. It's his personality and expertise that has attracted the group of volunteers who have decided to play here. Without Bob, this doesn't work on any useful level, at least not in it's current form. It could be better, it could be worse but it is what it is. If you want to play, jump in. You can contribute, you can take away, or you can do a little of both. Or one can just walk away. It's free and not required reading. ...just one lister's opinion, nothing personal intended and I totally respect the OP's opinion Bill "a couple of on/off switches would have been cheaper than TCW brownout protection but I did it my way and I like it" Watson ________________________________________________________________________________
Subject: Re: Sending two msgs to the list
Date: Dec 04, 2014
A disk failed on the web server a couple of days ago but has been fixed. If you still have problems, the cause could be at your end. Instead of using email to post, I use this link: http://forums.matronics.com/viewforum.php?f=3 and enter my message directly onto the AeroElectric website. There is no issue with email program compatibility or concerns about rich text or formatting. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435317#435317 ________________________________________________________________________________
Date: Dec 04, 2014
It would be a lot cheaper, lighter, and easier to just put a regular starter solenoid in series with the heavy starter wire at the source. The same control signal can activate the solenoid and the 'trigger' terminal on the starter itself. We had a similar discussion here a few months ago, and I think there's an example in the book. IIRC, the B&C starters are controlled this way. Charlie On 12/4/2014 3:24 AM, Bob Verwey wrote: > Thanks Justin, > > I have a very similar device lying on the shelf in my shop, used in > boating applications. > > I guess I was just looking for some re-assurance that it is a good > solution. > > Thanks! > > > Best... > > Bob Verwey > > > On 4 December 2014 at 10:49, Justin Jones > wrote: > > Bob, > > If you dont want to run your starter through the master > contractor, I suggest you use a device like this. A location > closer to the battery is better. A cable can be used in place of > the push tube if you need. > > http://www.jegs.com/i/Flaming+River/898/FR1003-2/10002/-1 > > During a run-on or stuck starter situation, it will take a while > for the fusable link to burn through. This switch will also allow > you to shut off the power to the starter any time you dont need > it, such as the aircraft sitting on the ground or while doing > maintenance. The last thing you want is to be working on the > engine and accidentally short out the contacts of the starter and > have that prop come swinging through. If you are doing > maintenance on the starter itself, I would still disconnect the > battery from the starter cable. > > Hope this helps. > > Justin > > >> On Dec 3, 2014, at 11:19 PM, Bob Verwey > > wrote: >> >> So I have a fat wire (00) running from the battery behind pilot >> seat, to the firewall, from whence the starter fat wire is >> connected on the engine side, and a 4 awg behind the firewall to >> the bus through a contactor. >> >> Its a Chevy V6, so the starter contactor is built into the starter. >> >> The fat wire is always hot at this stage, and I am looking for a >> solution in the form of a fuse/ fusible link near the battery so >> that in the event of an accident induced short, or an engaged >> starter hangup, that there is protection. >> >> >> >> Best... >> >> Bob Verwey >> >> >> On 2 December 2014 at 23:53, B Tomm > > wrote: >> >> Thanks Bob, >> I had done it on mine a couple years back, but the other day >> I was helping a hangar neighbour make some improvements. He >> has a rear mounted battery on a BD4 (engine in front). He >> has one electronic ignition which was powered by an 18 awg >> wire connected on the firewall at the input power terminal at >> the starter solenoid. This fat wire was only powered when the >> master solenoid (located in back next to the battery) was >> active. Not ideal for electrically dependant ignition. There >> was a spare 18 awg wire already running all the way back to >> the battery and the owner wanted to use that. I suggested >> that we fuse it but that fuse would have to activate >> "slower" than the breaker on the panel. I therefore >> suggested a fusible link and that is where I crossed the >> line. Since it was such a good idea, and I had suggested it, >> it was suggested that I do it :) Not a problem since I had >> materials left over. Just couldn't remember if the 22awg >> wire (now hidden under the silicone impregnated sleeve) on >> my RV7 had been stripped or not. My thinking initially was >> that it must have been stripped because we really don't want >> any combustible material "inside" the fuse if possible. It >> didn't strip well, so I re-did it without stripping as you >> have confirmed. Thank you. >> Bevan >> >> ------------------------------------------------------------------------ >> *From:* owner-aeroelectric-list-server(at)matronics.com >> >> [mailto:owner-aeroelectric-list-server(at)matronics.com >> ] *On >> Behalf Of *Robert L. Nuckolls, III >> *Sent:* Tuesday, December 02, 2014 11:41 AM >> *To:* aeroelectric-list(at)matronics.com >> >> *Subject:* Re: AeroElectric-List: Fusible links >> >> At 11:44 2014-12-02, you wrote: >>> > >>> >>> >>> >>> I can't find the detail in the book. When making a fusible >>> link, the inner >>> "fuse" wire is 22 AWG in this case. Is it necessary to strip >>> the insulation >>> off? >> >> I presume you're asking about the insulation on the >> 22AWG wire? No, in fact, you ADD insulation over it >> >> See http://tinyurl.com/msx5ofe >> >> Where are you considering the use of a fusible link? >> I crafted that comic-book waaayyy back when we were >> wrestling with the notion of extending the BUS in a >> fuse block up to a one-terminal-BUS at the input side >> of the alternator field breaker. A breaker upstream >> of a crow-bar ov protection module. >> >> I think we also dabbled with the use of fusible links >> on the meter-leads to a shunt. As a general rule, the >> fusible link is attractive only when a fuse holder >> is a little 'messy' . . . The TC fleet has used two >> fuses in clips to protect ammeter wires for decades. >> >> <400400db.jpg> >> >> The last time I was able to walk down the A36 >> production line (about 10 years ago) the clipped-in >> fuses for various 'minor' tasks were quite visible. >> >> The need to extend the bus to accommodate the only >> circuit breaker in the airplane was a special case. >> >> Like Figure Z-13/20, and to some extend Z-19, I've >> regretted having published the ideas. While useful >> and appropriate to the special cases, they've >> morphed into other forms that may or may not >> have been through PCQDR (preliminary, critical >> and qualification design review). >> >> Can or should we talk about it? >> ________________________________________________________________________________
Date: Dec 04, 2014
At 02:19 2014-12-04, you wrote: >So I have a fat wire (00) running from the battery behind pilot >seat, to the firewall, from whence the starter fat wire is connected >on the engine side, and a 4 awg behind the firewall to the bus >through a contactor. You mean that your battery contactor is not mounted adjacent to the battery? Bob . . . ________________________________________________________________________________
Subject: Re: Always on supply
Date: Dec 04, 2014
Is GPS position acquisition time a concern? I never noticed a delay problem with my Garmin GPS 496. If an always hot supply is really needed, then a 5 amp (or less) ATC inline fuse can be connected directly to the battery or battery side of the master contactor. Smaller fuses located in the instrument panel could be tapped off from the always-hot 5 amp circuit, but I do not think that the extra fuses are necessary. Maybe others can offer their opinion. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435321#435321 ________________________________________________________________________________
Date: Dec 04, 2014
Assuming a very low current for a "keep alive circuit", you could also just use a 10k ohm resistor installed at the source end of the wire instead of a fuse. Tim > On Dec 4, 2014, at 8:12 AM, user9253 wrote: > > > Is GPS position acquisition time a concern? I never noticed a delay problem with my Garmin GPS 496. If an always hot supply is really needed, then a 5 amp (or less) ATC inline fuse can be connected directly to the battery or battery side of the master contactor. Smaller fuses located in the instrument panel could be tapped off from the always-hot 5 amp circuit, but I do not think that the extra fuses are necessary. Maybe others can offer their opinion. > Joe > > -------- > Joe Gores > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435321#435321 > > > > > > > > > > ________________________________________________________________________________
Subject: Re: Touchy
Date: Dec 04, 2014
> He was asking for advice on how to implement his skinning method - not advice on whether his method is the best, or even desirable. > I find myself as frequently frustrated by responses on the aeroelectric list as I am satisfied with them. I suppose some people act like they know everything and some people do know almost everything, and frequently telling those two types apart is difficult. Some people withhold their advice for fear that it may be thought too forward, or that they might be considered a "know-it-all". This is basically what Richard Hofstadter described in his book "Anti-Intellectualism in American Life.". "Intellect needs to be understood not as some kind of claim against the other human excellences for which a fatally high price has to be paid, but rather as a complement to them without which they cannot be fully consummated." I find that I feel wrong when I withhold opinions (or actions) that I feel would be beneficial to a group or an individual. Do I sometimes stick my opinions in when I should be quiet? Sure. Sometimes my wife tells me that. So if you post on the Aeroelectric, I might have a technical answer as to how something can be accomplished, or advice not to do it. Expect either or sometimes both. Xmas story: I once knew a guy who, every holiday season would wrap up a pack of cigarettes together with a bottle of cheap fortified wine, drove down to skid row and donated these gifts to homeless people living in alleyways and cardboard boxes on the streets of Los Angeles.... I have to admit that I thought this was a pretty irresponsible and uncharitable idea and said so, until a mutual friend told me that the guy had been homeless on the street himself for five years, and I was certainly in no position to pass judgment on his actions. I was humbled. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435332#435332 ________________________________________________________________________________
Date: Dec 04, 2014
> > Is GPS position acquisition time a concern? I never noticed a delay problem with my Garmin GPS 496. If an always hot supply is really needed, then a 5 amp (or less) ATC inline fuse can be connected directly to the battery or battery side of the master contactor. Smaller fuses located in the instrument panel could be tapped off from the always-hot 5 amp circuit, but I do not think that the extra fuses are necessary. Maybe others can offer their opinion. > Joe > > I'd guess not. While it may be for a device that's constantly being powered on and off for ad hoc use, it would seem to me that GPS acquisition time matches up favorably with normal aircraft 'run up time'. That is, the GPS can find itself quite easily long before you are ready to depart. Conversely, an always on clock power circuit for the GPS or EFIS does not match up well with common aircraft cycle times. That is, many aircraft sit unused for extended periods. I'm sure someone can explain that the typical clock power drain is so minimal that extended down times aren't be an issue (?). It certainly gave me fits on my (3) GRT HX installation. Ironically I think they decided to pick-up the time from the GPS if that's possible. ________________________________________________________________________________
Date: Dec 04, 2014
If a GPS has been off more than 30 minutes it needs to download a second data table from the satellites before it can get a fix, that takes longer then to get a position. GRT made a software change a while back to pick up current time from the gps, so you can D/C the keep alive circuit if you have current software and not worry about the parasitic drain on the battery. Haven't tried it yet myself, but that's what I've been told. Tim > On Dec 4, 2014, at 11:03 AM, Bill Watson wrote: > > >> >> Is GPS position acquisition time a concern? I never noticed a delay problem with my Garmin GPS 496. If an always hot supply is really needed, then a 5 amp (or less) ATC inline fuse can be connected directly to the battery or battery side of the master contactor. Smaller fuses located in the instrument panel could be tapped off from the always-hot 5 amp circuit, but I do not think that the extra fuses are necessary. Maybe others can offer their opinion. >> Joe > I'd guess not. While it may be for a device that's constantly being powered on and off for ad hoc use, it would seem to me that GPS acquisition time matches up favorably with normal aircraft 'run up time'. That is, the GPS can find itself quite easily long before you are ready to depart. > > Conversely, an always on clock power circuit for the GPS or EFIS does not match up well with common aircraft cycle times. That is, many aircraft sit unused for extended periods. I'm sure someone can explain that the typical clock power drain is so minimal that extended down times aren't be an issue (?). It certainly gave me fits on my (3) GRT HX installation. > > Ironically I think they decided to pick-up the time from the GPS if that's possible. > > > > ________________________________________________________________________________
Date: Dec 04, 2014
Thanks, Joe. It is probably resolved, I noticed that my request for help only showed up once. Bill -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of user9253 Sent: Thursday, December 04, 2014 9:33 AM Subject: AeroElectric-List: Re: Sending two msgs to the list A disk failed on the web server a couple of days ago but has been fixed. If you still have problems, the cause could be at your end. Instead of using email to post, I use this link: http://forums.matronics.com/viewforum.php?f=3 and enter my message directly onto the AeroElectric website. There is no issue with email program compatibility or concerns about rich text or formatting. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435317#435317 ________________________________________________________________________________
Subject: Re: AeroElectric-List Digest: 15 Msgs - 12/03/14
Date: Dec 04, 2014
=0A Joe,=0AGood points. I suspect virtually everyone who freq uents this list has been a volunteer at one time or anothe r. We rarely get our panties in a wad and quit voluntee ring because someone complains. Rather we generally listen to the complaint and ponder whether the complaint is valid and , if so, how we can improve our volunteer work so as to create a satisfied customer (beggar). Doing volunteer work sh ould not mean that you can only have my volunteer informatio n if you jump through my hoops in order to get it.=0AI a m as grateful as anyone for the information obtained from th is list. I've learned a lot about building and maintaining aircraft electrical systems. Much of it is information that would have been difficult to get any other way. Learning about aeroelectricity required hours of study, hours spent on this list, and hours of practice. It was time well spent. I sincerely appreciate what Bob and others have voluntaril y done to assist.=0ASometimes the question does need to be r ephrased. It seems that more often the question needs more supporting information or qualifying information in order to be answered. That is true of the recent question regarding fus able links. Once the questioner better explained his situatio n, his question was clarified to the point that even I cou ld understand.=0AOften it is convenient to anomyously send comme nts to the list thinking that nobody is reading it. In fact, there are hundreds of people reading this list. Howev er, nothing said here would be unsuitable for in-person conver sation.=0AI have long been, and still am, of the opinion tha t getting an answer to a question posed to the list is p ainfully frustrating.=0AIn all of this, I mean no disrespect t o any of the list volunteers who donate their time to educ ate, inform and assist those of us who are less capable. Indeed, I appreciate their efforts.=0ARegards,=0AStan Sutterfield=0ADo not archive=0A=0A=0AThere is an old saying, "Beggars can't be choosy." That applies to the =0AAeroElectric List where re plies are posted by volunteers. If I =0Avolunteered to help someone who then complained about my work, I would =0Astop giving help. There is one very knowledgeable volunteer on t he =0AAeroElectric list who sometimes gives long winded and ph ilosophical =0Aresponses. Sometimes his response answers my que stion and sometimes =0Anot. Regardless, I appreciate it that he has volunteered his precious =0Atime to address my issue. There are many other participants on this =0Aforum who are also very knowledgeable. Some of them might not post a =0Are sponse to a question because they are afraid of getting flam ed. So =0Aplease treat everyone with respect. Do not pos t something that you =0Awould not say face to face. As for a question not being answered, maybe =0Athe question needs to be rephrased or needs to be more specific.=0AJoe Gores=0A =0A=0A=0A=0A =0A ________________________________________________________________________________
Date: Dec 04, 2014
Subject: Dreamliner lithium fire final report
See: http://tinyurl.com/pl97rqj Bob . . . ________________________________________________________________________________
Date: Dec 04, 2014
Bob , Was that photo of the fuses/wiring in the engine compartment? Bevan _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Tuesday, December 02, 2014 11:41 AM Subject: Re: AeroElectric-List: Fusible links At 11:44 2014-12-02, you wrote: I can't find the detail in the book. When making a fusible link, the inner "fuse" wire is 22 AWG in this case. Is it necessary to strip the insulation off? I presume you're asking about the insulation on the 22AWG wire? No, in fact, you ADD insulation over it See http://tinyurl.com/msx5ofe Where are you considering the use of a fusible link? I crafted that comic-book waaayyy back when we were wrestling with the notion of extending the BUS in a fuse block up to a one-terminal-BUS at the input side of the alternator field breaker. A breaker upstream of a crow-bar ov protection module. I think we also dabbled with the use of fusible links on the meter-leads to a shunt. As a general rule, the fusible link is attractive only when a fuse holder is a little 'messy' . . . The TC fleet has used two fuses in clips to protect ammeter wires for decades. Emacs! The last time I was able to walk down the A36 production line (about 10 years ago) the clipped-in fuses for various 'minor' tasks were quite visible. The need to extend the bus to accommodate the only circuit breaker in the airplane was a special case. Like Figure Z-13/20, and to some extend Z-19, I've regretted having published the ideas. While useful and appropriate to the special cases, they've morphed into other forms that may or may not have been through PCQDR (preliminary, critical and qualification design review). Can or should we talk about it? Bob . . . ________________________________________________________________________________
Date: Dec 04, 2014
Very interesting read. Sound like a thorough investigation. One thing I noticed that there was no discussion (that I could find) of changing to a more traditional battery type or another version of Lithium such as LiFePo. Bevan -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Thursday, December 04, 2014 8:40 PM Subject: AeroElectric-List: Dreamliner lithium fire final report --> See: http://tinyurl.com/pl97rqj Bob . . . ________________________________________________________________________________
Date: Dec 05, 2014
On 12/04/2014 04:04 PM, Tim Andres wrote: > GRT made a software change a while back to pick up current time from the gps, so you can D/C the keep alive circuit if you have current software and not worry about the parasitic drain on the battery. Haven't tried it yet myself, but that's what I've been told. That's the way mine (HX and Mini-X) are setup (no keep alive circuit for either), and it works well. Picks up the time shortly after powerup. No issues so far that I've noticed. -Dj -- Dj Merrill - N1JOV - VP EAA Chapter 87 Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Date: Dec 05, 2014
On 12/5/2014 9:52 AM, Dj Merrill wrote: > > On 12/04/2014 04:04 PM, Tim Andres wrote: >> GRT made a software change a while back to pick up current time from the gps, so you can D/C the keep alive circuit if you have current software and not worry about the parasitic drain on the battery. Haven't tried it yet myself, but that's what I've been told. > That's the way mine (HX and Mini-X) are setup (no keep alive circuit for > either), and it works well. Picks up the time shortly after powerup. > No issues so far that I've noticed. > > -Dj > Same here. When they made the change I disco'd the stay alive circuits, the HXs pick up the time before I go looking for it and a nagging battery problem went away. ________________________________________________________________________________
Date: Dec 05, 2014
Then problem solved! One less wire to run. :D Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435380#435380 ________________________________________________________________________________
Date: Dec 07, 2014
At 00:26 2014-12-05, you wrote: > >Very interesting read. Sound like a thorough investigation. One thing I >noticed that there was no discussion (that I could find) of changing to a >more traditional battery type or another version of Lithium such as LiFePo. Not the NTSBs job. Incident investigations are limited to deduction of root cause and chain of events that followed. The FAA will (and in some respects already has) responded with enhanced (read more educated) certification criteria. True Blue has been marching to the new drum and has been holy watered. I'm hoping to visit with the guys in Wichita that manufacture and market the True Blue line in the near future. I don't think the FAA has mumbled anything about banning one chemistry in favor of another . . . again, not part of their charter. But they have said that if you choose to incorporate a new product or process into your design, you need to demonstrate either (1) exceedingly improbable or (2) total mitigation for worst case events. There are a number of youtube videos but one in particular where the producer-director subjects the LiFePo cells to spectacular abuse yet fails to produce more than a few sparks or a little smoke. Clearly, the LiFePo chemistry is the most attractive product for future consideration in OBAM aircraft. Given that a series string of 4 cells cannot be abused by over-charging in a 14v system, it seems that the most challenging issues will focus on cost of ownership. If a cell is severely discharged (much below 2.8v) it's trashed. An array of cells subject to repeated deep discharge/recharge events is at risk for charge imbalance in one or more cells which places them at risk for early failure. We're fortunate to have access to a HUGE testing laboratory for rapidly growing numbers of LiFePo products . . . motorcycles and recreational vehicles. A market that is probably 100x larger than aviation applications. I do periodic web searches on motorcycle+lithium+fire and to date, I've not discovered any instances of mishap unique to or exacerbated by the application of lithium. If anyone runs across an incident of interest on the web, I'd like to get a note on it. Here is one interesting battery narrative from the motorcycle world http://tinyurl.com/3uccevs These guys are wrestling with the same performance and system integration issues we face. We would do well to study their experience for expanded lessons- learned. Bob . . . ________________________________________________________________________________
Date: Dec 08, 2014
Subject: Re: Touchy
Eric, nice post, kinda reminds me of the Warren Buffet quote: *Wall Street is the only place that **people ride to in a Rolls Royce to get advice from those who take the subway. * Best... Bob Verwey On 4 December 2014 at 20:48, Eric M. Jones wrote: > emjones(at)charter.net> > > > > He was asking for advice on how to implement his skinning method - not > advice on whether his method is the best, or even desirable. > > I find myself as frequently frustrated by responses on the aeroelectric > list as I am satisfied with them. > > > I suppose some people act like they know everything and some people do > know almost everything, and frequently telling those two types apart is > difficult. > > Some people withhold their advice for fear that it may be thought too > forward, or that they might be considered a "know-it-all". This is > basically what Richard Hofstadter described in his book > "Anti-Intellectualism in American Life.". "Intellect needs to be understo od > not as some kind of claim against the other human excellences for which a > fatally high price has to be paid, but rather as a complement to them > without which they cannot be fully consummated." > > I find that I feel wrong when I withhold opinions (or actions) that I fee l > would be beneficial to a group or an individual. Do I sometimes stick my > opinions in when I should be quiet? Sure. Sometimes my wife tells me that . > > So if you post on the Aeroelectric, I might have a technical answer as to > how something can be accomplished, or advice not to do it. Expect either or > sometimes both. > > Xmas story: I once knew a guy who, every holiday season would wrap up a > pack of cigarettes together with a bottle of cheap fortified wine, drove > down to skid row and donated these =9Cgifts=9D to homeless pe ople living in > alleyways and cardboard boxes on the streets of Los Angeles.... > > I have to admit that I thought this was a pretty irresponsible and > uncharitable idea and said so, until a mutual friend told me that the guy > had been homeless on the street himself for five years, and I was certain ly > in no position to pass judgment on his actions. I was humbled. > > -------- > Eric M. Jones > www.PerihelionDesign.com > 113 Brentwood Drive > Southbridge, MA 01550 > (508) 764-2072 > emjones(at)charter.net > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435332#435332 > > =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Dec 08, 2014
Correct Bob N, I have only a 70amp relay to feed the bus. [image: Inline images 1] Best... Bob Verwey On 4 December 2014 at 17:58, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > nuckolls.bob(at)aeroelectric.com> > > At 02:19 2014-12-04, you wrote: > >> So I have a fat wire (00) running from the battery behind pilot seat, to >> the firewall, from whence the starter fat wire is connected on the engine >> side, and a 4 awg behind the firewall to the bus through a contactor. >> > > You mean that your battery contactor is not > mounted adjacent to the battery? > > > Bob . . . > > ________________________________________________________________________________
Date: Dec 08, 2014
BobV, The rule of thumb is to keep the fat wires that are bolted directly to B+ as short as possible. My personal rule is less than 18 inches. Is there a reason not to add a traditional start solenoid right at the battery? In your case is may be redundant but it keeps the un-protected feeder length short. You would have to move the master relay to that position also - so that's another few feet of #4. This is probably less expensive than the manual disconnect & it keeps the big starter cable inert except during cranking. -Jeff On Monday, December 8, 2014 3:25 AM, Bob Verwey wrote: Correct Bob N, I have only a 70amp relay to feed the bus. Best... Bob Verwey On 4 December 2014 at 17:58, Robert L. Nuckolls, III wrote: > >At 02:19 2014-12-04, you wrote: > >So I have a fat wire (00) running from the battery behind pilot seat, to the firewall, from whence the starter fat wire is connected on the engine side, and a 4 awg behind the firewall to the bus through a contactor. >> > You mean that your battery contactor is not > mounted adjacent to the battery? > > > Bob . . . > >=================================== >br> fts!) >r> > /www.aeroelectric.com" target="_blank">www.aeroelectric.com >w.buildersbooks.com" target="_blank">www.buildersbooks.com >p.com" target="_blank">www.homebuilthelp.com >e.com" target="_blank">www.mypilotstore.com >" target="_blank">www.mrrace.com >target="_blank">http://www.matronics.com/contribution > -Matt Dralle, List Admin. >=================================== >- >Electric-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List >=================================== >FORUMS - >_blank">http://forums.matronics.com >=================================== > > ________________________________________________________________________________
Date: Dec 08, 2014
At 05:08 2014-12-08, you wrote: >Correct Bob N, I have only a 70amp relay to feed the bus. Oh yeah, I seem to recall this condition from an earlier thread . . . one of the 70A rated plastic relays with fast-on tabs? You're probably aware of the variances in your system when compared with the legacy design philosophies harvested from the TC aircraft world. One of those ideas goes toward making ship's wiring max-cold when crew operated controls are placed at OFF. This generally calls for placing disconnects in major conductors (meaning protected at more than 5A) as close to the source as practical. Hence the oft repeated picture below (Cessna 150 1962 and before) where we see the battery contactor mounted right on the battery box. Emacs! If your design goals dictate alternate configurations for managing power in your major wires, then it's a good thing to take a mental expedition through the woods and briar patches of Failure Modes Effects Analysis. If you're considering fault protection for any conductor, fat wires, bus feeders, wires of any size . . . consider all the circumstances under which that circuit protection might be expected to operate. Two conditions which are high on the list in the TC aircraft world call for minimizing risk for post-crash fire -AND- making sure that some mechanic doesn't swing a wrench against an always hot fat-feeder terminal when he/she erroneously believes that ship's wiring is max-cold. A guy I worked with right out high school was under a oil-patch truck routing cables for a two-way radio we were installing. I was working in the cab and stuffing a wire down through a grommet that he was going to attach to the starter contactor. At some point I heard this loud yell followed by his wristwatch flying out from under the truck in a smoking trajectory that hit the wall. Seems he'd forgotten one if his check-list items for disconnecting battery ground cable before starting the job. Burned him pretty bad . . . destroyed a new watch he was really proud of. Unfortunately, oil patch trucks don't have battery contactors. The point is, if you choose to do something different, please think through the hazards and then be aware of them as part of the risk management for the use and maintenance of your airplane. Speaking of battery contactors . . . A couple weeks ago I expressed some skepticism for a statement from SkyTec literature asserting that Cessna's starter contactors were of the continuous duty type and therefore, ill suited to the task. I didn't start there until '64 and the first couple of years were spent learning to write, illustrate and publish accessory kits for radio installations. The electrical group was right across the isle from me and we had a lot of conversation but I was oblivious to many details of the electrical systems both present and historical. So, I've been digging up service and parts catalogs on the older Cessnas. The image above was captured from a 1962 and prior service manual were we're shown a Cutler-Hammer 6041 style contactor used as a battery contactor. I'm discovering that the wine-barrel RBM controls devices familiar to me came along sometime in the early/mid 60's. The oldest airplane I've flown fitted with an electrical system was a '46 120-1/2 . . . the system was added after it left the factory . . . I think it had a wine-barrel battery contactor. Didn't need a starter contactor (had cockpit pull- handle, mechanical engagement). All of the catalog/service data I've gathered so far calls out Cessna source control drawings for all contactors . . . so I'm not yet privy to manufacturer's source data. I'm compiling a list of source control numbers. Next time I'm inside the hallowed halls of Textron, I'll put the microscope to SkyTec's somewhat startling assertions. When I began writing narratives for the service manuals, I'm recalling that there were distinctions made between battery (continuous) and starter (intermittent) duty wine-barrel contactors. I'll go find out . . . Bob . . . ________________________________________________________________________________
Subject: For sale
Date: Dec 08, 2014
I am offering the following aviation tools for sale. If you are interested, make a reasonable offer. Whitney hand punch Tubing cutter Hole flanging tool Seaming tool Fly-cutter Micro stop countersink Aviation snips-left-right & straight 3X rivet gun Safety wire twister Magnetic base protractor Rivet spacer Air grinder Pop rivet tool Rivet gauges Cleco pliers Deburring tool Countersink Fluting plier Bucking bar Rivet squeezer with 1-1/2 yoke 3 In. yoke Pneumatic Rivet squeezer with 1-1/2 in. yoke Rivet squeezer dies Dimpleing dies Blind rivet kit Air drill Clecos Hand seamer ____________________________________________________________ NetZero now offers 4G mobile broadband. Sign up now. http://www.netzero.net/?refcd=NZINTISP0512T4GOUT1 ________________________________________________________________________________
Subject: Re:_AeroElectric-List:_For_sale?
Date: Dec 08, 2014
QW5kLiAuIC4gIFdoYXQgbWlnaHQgeW91IGNvbnNpZGVyIGEg4oCccmVhc29uYWJsZSBvZmZlcuKA nT8gIFdpdGhvdXQgcGljdHVyZXMgb3IgZGVzY3JpcHRpb25zIGl0IGlzIGRpZmZpY3VsdCB0byBr bm93IE1hbnVmYWN0dXJlciwgY29uZGl0aW9uLCBldGMuICBJcyB0aGlzIGEgTG90IFNhbGUgb3Ig aW5kaXZpZHVhbCBwaWVjZXM/DQoNCg0KUm9nZXINCg0KDQoNCg0KDQoNCkZyb206IExhcnJ5IE1h YyBEb25hbGQNClNlbnQ6IOKAjk1vbmRheeKAjiwg4oCORGVjZW1iZXLigI4g4oCOOOKAjiwg4oCO MjAxNCDigI4z4oCOOuKAjjA14oCOIOKAjlBNDQpUbzogYWVyb2VsZWN0cmljLWxpc3RAbWF0cm9u aWNzLmNvbQ0KDQoNCg0KDQoNCi0tPiBBZXJvRWxlY3RyaWMtTGlzdCBtZXNzYWdlIHBvc3RlZCBi eTogTGFycnkgTWFjIERvbmFsZCA8bG00QGp1bm8uY29tPg0KDQpJIGFtIG9mZmVyaW5nIHRoZSBm b2xsb3dpbmcgYXZpYXRpb24gdG9vbHMgZm9yIHNhbGUuDQpJZiB5b3UgYXJlIGludGVyZXN0ZWQs IG1ha2UgYSByZWFzb25hYmxlIG9mZmVyLg0KDQpXaGl0bmV5IGhhbmQgcHVuY2gNClR1YmluZyBj dXR0ZXINCkhvbGUgZmxhbmdpbmcgdG9vbA0KU2VhbWluZyB0b29sDQpGbHktY3V0dGVyDQpNaWNy byBzdG9wIGNvdW50ZXJzaW5rDQpBdmlhdGlvbiBzbmlwcy1sZWZ0LXJpZ2h0ICYgc3RyYWlnaHQN CjNYIHJpdmV0IGd1bg0KU2FmZXR5IHdpcmUgdHdpc3Rlcg0KTWFnbmV0aWMgYmFzZSBwcm90cmFj dG9yDQpSaXZldCBzcGFjZXINCkFpciBncmluZGVyDQpQb3Agcml2ZXQgdG9vbA0KUml2ZXQgZ2F1 Z2VzDQpDbGVjbyBwbGllcnMNCkRlYnVycmluZyB0b29sDQpDb3VudGVyc2luaw0KRmx1dGluZyBw bGllcg0KQnVja2luZyBiYXINClJpdmV0IHNxdWVlemVyIHdpdGggMS0xLzIgeW9rZQ0KMyBJbi4g eW9rZQ0KUG5ldW1hdGljIFJpdmV0IHNxdWVlemVyIHdpdGggMS0xLzIgaW4uIHlva2UNClJpdmV0 IHNxdWVlemVyIGRpZXMNCkRpbXBsZWluZyBkaWVzDQpCbGluZCByaXZldCBraXQNCkFpciBkcmls bA0KQ2xlY29zDQpIYW5kIHNlYW1lcg0KDQoNCg0KX19fX19fX19fX19fX19fX19fX19fX19fX19f X19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fDQpOZXRaZXJvIG5vdyBvZmZlcnMgNEcg bW9iaWxlIGJyb2FkYmFuZC4gU2lnbiB1cCBub3cuDQpodHRwOi8vd3d3Lm5ldHplcm8ubmV0Lz9y ZWZjZD1OWklOVElTUDA1MTJUNEdPVVQxDQoNCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQpfLT0NCl8tPSAgICAgICAtLSBQbGVh c2UgU3VwcG9ydCBZb3VyIExpc3RzIFRoaXMgTW9udGggLS0NCl8tPSAgICAgICAgICAgKEFuZCBH ZXQgU29tZSBBV0VTT01FIEZSRUUgR2lmdHMhKQ0KXy09DQpfLT0gICBOb3ZlbWJlciBpcyB0aGUg QW5udWFsIExpc3QgRnVuZCBSYWlzZXIuICBDbGljayBvbg0KXy09ICAgdGhlIENvbnRyaWJ1dGlv biBsaW5rIGJlbG93IHRvIGZpbmQgb3V0IG1vcmUgYWJvdXQNCl8tPSAgIHRoaXMgeWVhcidzIFRl cnJpZmljIEZyZWUgSW5jZW50aXZlIEdpZnRzIHByb3ZpZGVkDQpfLT0gICBieToNCl8tPSAgIA0K Xy09ICAgICAqIEFlcm9FbGVjdHJpYyB3d3cuYWVyb2VsZWN0cmljLmNvbQ0KXy09ICAgICAqIFRo ZSBCdWlsZGVyJ3MgQm9va3N0b3JlIHd3dy5idWlsZGVyc2Jvb2tzLmNvbQ0KXy09ICAgICAqIEhv bWVidWlsdEhFTFAgd3d3LmhvbWVidWlsdGhlbHAuY29tDQpfLT0gICAgICogTXkgUGlsb3QgU3Rv cmUgd3d3Lm15cGlsb3RzdG9yZS5jb20NCl8tPSAgICAgKiBSYWNlIENvbnN1bHRpbmcgd3d3Lm1y cmFjZS5jb20NCl8tPQ0KXy09ICAgTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGU6DQpfLT0NCl8t PSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uDQpfLT0NCl8tPSAg IFRoYW5rIHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQ0KXy09DQpfLT0gICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uDQpfLT0NCl8tPT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 DQpfLT0gICAgICAgICAgLSBUaGUgQWVyb0VsZWN0cmljLUxpc3QgRW1haWwgRm9ydW0gLQ0KXy09 IFVzZSB0aGUgTWF0cm9uaWNzIExpc3QgRmVhdHVyZXMgTmF2aWdhdG9yIHRvIGJyb3dzZQ0KXy09 IHRoZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sDQpf LT0gQXJjaGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0LCBGQVEsDQpf LT0gUGhvdG9zaGFyZSwgYW5kIG11Y2ggbXVjaCBtb3JlOg0KXy09DQpfLT0gICAtLT4gaHR0cDov L3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9BZXJvRWxlY3RyaWMtTGlzdA0KXy09DQpfLT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PQ0KXy09ICAgICAgICAgICAgICAgLSBNQVRST05JQ1MgV0VCIEZPUlVNUyAtDQpfLT0gU2FtZSBn cmVhdCBjb250ZW50IGFsc28gYXZhaWxhYmxlIHZpYSB0aGUgV2ViIEZvcnVtcyENCl8tPQ0KXy09 ICAgLS0+IGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQ0KXy09DQpfLT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ= ________________________________________________________________________________
Subject: Bad overvoltage module?
Date: Dec 08, 2014
I have a Z-13/8 electrical system on my RV-7A. While finishing up a remode l of my panel, I tested my new switches and found that when I turned on the backup PM alternator with engine off, my 5 amp circuit breaker instantly t ripped. Checked the switch and traced out my wiring and both seem fine, s o I now suspect that either the crowbar over-voltage module or the associat ed S8005-1 relay from B&C is bad. I removed the over-voltage module and my multimeter indicates continuity between the two wires. Im thinking that s hould only occur when there is an over-voltage event, so my module must be bad, letting the current bypass the relay altogether and tripping my breake r. Am I thinking this through correctly? Thanks erich This e-mail and any attachments contain URS Corporation confidential inform ation that may be proprietary or privileged. If you receive this message in error or are not the intended recipient, you should not retain, distribute , disclose or use any of this information and you should destroy the e-mail and any attachments or copies. ________________________________________________________________________________
Date: Dec 08, 2014
Subject: Re: Bad overvoltage module?
Sounds like a good diagnosis to me Erich. Especially if the circuit breaker does not trip with the module disconnected. Ken On 08/12/2014 4:59 PM, Weaver, Erich wrote: > > I have a Z-13/8 electrical system on my RV-7A. While finishing up a > remodel of my panel, I tested my new switches and found that when I > turned on the backup PM alternator with engine off, my 5 amp circuit > breaker instantly tripped. Checked the switch and traced out my > wiring and both seem fine, so I now suspect that either the crowbar > over-voltage module or the associated S8005-1 relay from B&C is bad. > I removed the over-voltage module and my multimeter indicates > continuity between the two wires. Im thinking that should only occur > when there is an over-voltage event, so my module must be bad, letting > the current bypass the relay altogether and tripping my breaker. Am I > thinking this through correctly? > > Thanks > > erich > > ________________________________________________________________________________
Date: Dec 08, 2014
At 15:59 2014-12-08, you wrote: >I have a Z-13/8 electrical system on my RV-7A. While finishing up a >remodel of my panel, I tested my new switches and found that when I >turned on the backup PM alternator with engine off, my 5 amp circuit >breaker instantly tripped. Checked the switch and traced out my >wiring and both seem fine, so I now suspect that either the crowbar >over-voltage module or the associated S8005-1 relay from B&C is >bad. I removed the over-voltage module and my multimeter indicates >continuity between the two wires. Im thinking that should only >occur when there is an over-voltage event, so my module must be bad, >letting the current bypass the relay altogether and tripping my >breaker. Am I thinking this through correctly? Sounds right. Did you get it from B&C or from me? Doesn't matter. Drop it to me in an envelope and I'll repair/replace it as appropriate. Bob . . . ________________________________________________________________________________
Subject: Re: For sale
Date: Dec 09, 2014
> On Dec 8, 2014, at 3:05 PM, Larry Mac Donald wrote: > > I am offering the following aviation tools for sale. EAA Chapter 384 in Brighton MI has started a project to have students and adults build an RV12 kit. Our offer for 100 of your 3/32=9D clecos, cleco pliers and hand seamer is $50 (shipped to Brighton Airport, 8664 Hyne Rd, Brighton MI 48114) . Thanks for considering our offer! Jack H. 810.629.1870 RV6A ________________________________________________________________________________
Date: Dec 09, 2014
Quote: I have a Z-13/8 electrical system on my RV-7A. While finishing up a remodel of my panel, I tested my new switches and found that when I turned on the backup PM alternator with engine off, my 5 amp circuit breaker instantly tripped. Checked the switch and traced out my wiring and both seem fine, so I now suspect that either the crowbar over-voltage module or the associated S8005-1 relay from B&C is bad. I removed the over-voltage module and my multimeter indicates continuity between the two wires. Im thinking that should only occur when there is an over-voltage event, so my module must be bad, letting the current bypass the relay altogether and tripping my breaker. Am I thinking this through correctly? Sounds right. Did you get it from B&C or from me? Doesn't matter. Drop it to me in an envelope and I'll repair/replace it as appropriate. Bob . . . Thanks guys. It came from B&C and I went ahead and ordered a replacement f rom them. Who knows when it went bad - haven't had a need to switch on the back up alternator. I noticed on a OVM doc available on the Aeroelectric Connection website a r ecommendation that the OVM be checked every year as part of the annual insp ection. Im wondering if I shouldn't just remove the OVM entirely. I shoul d be notified if my voltage starts climbing from my EIS/EFIS warning lights and be able to manually turn off a faulty alternator anyway. Bad idea? Erich This e-mail and any attachments contain URS Corporation confidential inform ation that may be proprietary or privileged. If you receive this message in error or are not the intended recipient, you should not retain, distribute , disclose or use any of this information and you should destroy the e-mail and any attachments or copies. ________________________________________________________________________________
Date: Dec 09, 2014
Subject: regulator-rectifier questions
Rotax wiring diagram shows the regulator-rectifier for the integrated generator to have four terminals (in addition to the two that connect to the generator). These terminals are marked R,B+,L and C. I am trying to figure out what they all do. So far I think I have managed to figure out three of them: C is the one that "turns on" the regulator/generator and it also supplies current to the warning light. L is the ground path for the warning light. B+ delivers the charging current to the battery/bus. Question 1: Have I correctly identified the function of C,L and B+ ? Question 2: What is the function of the R terminal? I do know that the R terminal must connect to the positive battery terminal, but I would like to know its function. Thanks in advance for your direct answers. ________________________________________________________________________________
Date: Dec 09, 2014
I'd vote for bad idea! You might browse through Chapter 6 of the AEC again . On Tue, Dec 9, 2014 at 4:18 PM, Weaver, Erich wrote: > *Quote:* > > I have a Z-13/8 electrical system on my RV-7A. While finishing up a > remodel of my panel, I tested my new switches and found that when I > turned on the backup PM alternator with engine off, my 5 amp circuit > breaker instantly tripped. Checked the switch and traced out my > wiring and both seem fine, so I now suspect that either the crowbar > over-voltage module or the associated S8005-1 relay from B&C is > bad. I removed the over-voltage module and my multimeter indicates > continuity between the two wires. Im thinking that should only > occur when there is an over-voltage event, so my module must be bad, > letting the current bypass the relay altogether and tripping my > breaker. Am I thinking this through correctly? > > > * Sounds right. Did you get it from B&C or from me? Doesn't matter. Drop > it to me in an envelope and I'll repair/replace it as appropriate. Bob . . > .* > > > *Thanks guys. It came from B&C and I went ahead and ordered a replacemen t > from them. Who knows when it went bad =93 haven=99t had a ne ed to switch on > the back up alternator.* > > *I noticed on a OVM doc available on the Aeroelectric Connection website > a recommendation that the OVM be checked every year as part of the annual > inspection. Im wondering if I shouldn=99t just remove the OVM enti rely. I > should be notified if my voltage starts climbing from my EIS/EFIS warning > lights and be able to manually turn off a faulty alternator anyway. Bad > idea?* > > > *Erich * > > > This e-mail and any attachments contain URS Corporation confidential > information that may be proprietary or privileged. If you receive this > message in error or are not the intended recipient, you should not retain , > distribute, disclose or use any of this information and you should destro y > the e-mail and any attachments or copies. > > * > =========== m> ldersbooks.com> .com> com> om/contribution> =========== www.matronics.com/Navigator?AeroElectric-List> =========== =========== > > * > > ________________________________________________________________________________
Date: Dec 09, 2014
>Thanks guys. It came from B&C and I went ahead >and ordered a replacement from them. Who knows >when it went bad ' haven=92t had a need to switch on the back up alternator. I'd still like to get the bad one even if you don't want it back. Bob . . . ________________________________________________________________________________
Date: Dec 09, 2014
On 12/9/2014 3:18 PM, Weaver, Erich wrote: > > *Quote:* > > I have a Z-13/8 electrical system on my RV-7A. While finishing up a > remodel of my panel, I tested my new switches and found that when I > turned on the backup PM alternator with engine off, my 5 amp circuit > breaker instantly tripped. Checked the switch and traced out my > wiring and both seem fine, so I now suspect that either the crowbar > over-voltage module or the associated S8005-1 relay from B&C is > bad. I removed the over-voltage module and my multimeter indicates > continuity between the two wires. Im thinking that should only > occur when there is an over-voltage event, so my module must be bad, > letting the current bypass the relay altogether and tripping my > breaker. Am I thinking this through correctly? > > * > Sounds right. Did you get it from B&C or from me? > Doesn't matter. Drop it to me in an envelope and > I'll repair/replace it as appropriate. > > Bob . . .* > > ** > > *Thanks guys. It came from B&C and I went ahead and ordered a > replacement from them. Who knows when it went bad -- haven't had a > need to switch on the back up alternator.* > > ** > > *I noticed on a OVM doc available on the Aeroelectric Connection > website a recommendation that the OVM be checked every year as part of > the annual inspection. Im wondering if I shouldn't just remove the > OVM entirely. I should be notified if my voltage starts climbing from > my EIS/EFIS warning lights and be able to manually turn off a faulty > alternator anyway. Bad idea?* > > ** > > *Erich * > > Only snag with that plan is if the failure happens while the pilot is in a high-workload situation. If the pilot doesn't react quickly enough, he could lose all the avionics to overvoltage just when he needs them most. ________________________________________________________________________________
Date: Dec 09, 2014
In AEC v12, page 6-7, Bob explains that the Crowbar OV module is designed to work on a 5 millisecond interval. I don't think it matters much what the pilot's workload is, he or she is not going to beat 5 milliseconds! Also on that page and the page before, he writes about how the method that the crowbar system uses to disconnect the circuit is special, so that it doesn't break an inductive circuit. It's a really good chapter that makes the case for why the Crowbar OVM is important. I would copy and paste it, but in version 12, those pages are optically scanned. ________________________________________________________________________________
Subject: Re: regulator-rectifier questions
Date: Dec 10, 2014
Yes, you have correctly identified the function of C, L and B+ The R terminal is connected to the B+ terminal. Why, I do not know, either for increased ampacity or redundancy. According to a schematic of the regulator that I have seen, terminals R and B+ are also connected together inside of the regulator. On page 18-3 of this document, http://www.vansaircraft.com/pdf/revisions/RV-12/User_Manuals/MM.pdf is a wiring diagram of the regulator in Van's RV-12. The warning light is not needed if an EFIS indicates a low voltage condition. The regulator should be mounted in a cool location. It is notoriously prone to failure from overheating. Heat conductive grease should be applied to the mounting base. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435556#435556 ________________________________________________________________________________
Date: Dec 10, 2014
I agree with others that not having over-voltage protection is a bad idea. High voltage can damage expensive avionics in much less time than a human can react to shut it off. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435558#435558 ________________________________________________________________________________
Date: Dec 10, 2014
> when I turned on the backup PM alternator with engine off, my 5 amp circuit breaker instantly tripped. With the over-voltage module removed from the circuit, does the relay energize (click) when the aux alt switch is turned on? And does the circuit breaker not trip? If both true, then the fault must be the O.V. module. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435559#435559 ________________________________________________________________________________
Date: Dec 10, 2014
I noted the recommendation that the OVM be checked annually. I have not done that in the nearly eight years my RV has been flying. Nor has the OVM ever shut down the alternator. Nor have I had any voltage surge that damaged anything. Just lucky? What is the best (easiest) method to check the OVM operation? Charlie Brame RV-6A N11CB San Antonio ________________________________________________________________________________
Date: Dec 10, 2014
Thanks Joe. On Wed, Dec 10, 2014 at 6:03 AM, user9253 wrote: > > Yes, you have correctly identified the function of C, L and B+ > The R terminal is connected to the B+ terminal. Why, I do not know, > either for increased ampacity or redundancy. According to a schematic of > the regulator that I have seen, terminals R and B+ are also connected > together inside of the regulator. > On page 18-3 of this document, > http://www.vansaircraft.com/pdf/revisions/RV-12/User_Manuals/MM.pdf > is a wiring diagram of the regulator in Van's RV-12. > The warning light is not needed if an EFIS indicates a low voltage > condition. > The regulator should be mounted in a cool location. It is notoriously > prone to failure from overheating. Heat conductive grease should be > applied to the mounting base. > Joe > > -------- > Joe Gores > > ________________________________________________________________________________
Date: Dec 10, 2014
> What is the best (easiest) method to check the OVM operation? Page 1 of his document http://www.aeroelectric.com/DIY/DIY_Crowbar_OVP_F.pdf shows how to test an over-voltage module. The best way is on a workbench using an adjustable DC power supply. The easy way is in the aircraft using alligator clips and a battery. Bob says to use a 6 volt lantern battery, but 4 D cells in series might work too. Notice that the negative alligator clip is attached to the aircraft power bus. I recommend that all avionics and any polarity sensitive devices be shut off prior to doing this test. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435567#435567 ________________________________________________________________________________
Date: Dec 11, 2014
Subject: downloadable notes that go with the "Z" diagrams...
Greetings, Anyone have a link or a .pdf for the notes that go with the architecture drawings? I couldn't find them on the aeroelectric website. Thanks, Steve Stearns LongEz N45FC, currently working on a Quickie... ________________________________________________________________________________
Date: Dec 11, 2014
Subject: Alternator Disconnect Z17 vs Z20...
Greetings, I'm currently working on wiring up a Quickie with a Rotax 503 (and a glass panel, go figure...). The two architecture diagrams that look appropriate to start from are Z17 "Small Rotax System" (sounds right...) and Z20 "Small Jabiru System". They are basically the same EXCEPT they way the alternator is disconnected (Z17 is downstream of regulator, Z20 is upstream of the regulator). I might be mistaken (please correct me...) but it also appears both diagrams are assuming more of a diode bridge than a real regulator as they both show a 20,000uF cap on the output of the regulator. My questions: 1) What's the significance, if any, of the different approaches to the alternator disconnect? 2) If I use Rotax 264 870 regulator (as opposed to the 866 080 bridge) is the cap still appropriate (it's not shown in Rotex's wiring diagrams? All thoughts welcome. Thanks, Steve Stearns LongEz N45FC (working on a Quickie) ________________________________________________________________________________
Date: Dec 11, 2014
Subject: fuse or breaker for OVP?
I read on another forum that the B&C over voltage protection thingy must only be used to trip a breaker, not to blow a fuse. Yet, I just re-read the chapter on over voltage protection and did not see that mentioned. So the question is, should the OVP device be used to: a) trip a breaker b) blow a fuse c) either is okay ? ________________________________________________________________________________
Date: Dec 11, 2014
Subject: Overvoltage crowbar availability?
Greetings, It looks like B and C no longer carries the stand-alone overvoltage crowbar (at least I think that's where I bought the one in my LongEz). I know Bob is trying to get out of the parts distribution business. Does anyone else know of a source or should I just plan on building my own. (and if you have the link handy to Bob's schematic that would be great but don't search if you don't as I'm sure I can find it...). Thanks, Steve Stearns LongEz N45FC (and currently working on a Quickie). ________________________________________________________________________________
Date: Dec 11, 2014
Subject: Re: Never mind... Re: Overvoltage crowbar availability?
Found it. It's still available at B&C if you search by it's part number OVM-14... Sorry for the distraction, Steve. On 12/11/2014 7:43 PM, Steve Stearns wrote: > Greetings, > > It looks like B and C no longer carries the stand-alone overvoltage > crowbar (at least I think that's where I bought the one in my > LongEz). I know Bob is trying to get out of the parts distribution > business. Does anyone else know of a source or should I just plan on > building my own. (and if you have the link handy to Bob's schematic > that would be great but don't search if you don't as I'm sure I can > find it...). > > Thanks, > > Steve Stearns > LongEz N45FC (and currently working on a Quickie). ________________________________________________________________________________
Date: Dec 11, 2014
Subject: Re: fuse or breaker for OVP?
The idea behind feeding the Regulator with a circuit breaker is that it gives the pilot the ability to shut-down the alternator (by pulling the breaker) if that becomes necessary. A few reasons you might want to shut down the alternator are: 1. a failed regulator that is giving full field (if you don't have an over voltage module) 2. a failed over-voltage module 3. testing purposes A breaker is simply more practical in this situation. On Thursday, December 11, 2014 3:35 PM, Ken Ryan wrote: I read on another forum that the B&C over voltage protection thingy must only be used to trip a breaker, not to blow a fuse. Yet, I just re-read the chapter on over voltage protection and did not see that mentioned. So the question is, should the OVP device be used to: a) trip a breaker b) blow a fuse c) either is okay ? ________________________________________________________________________________
Date: Dec 12, 2014
Thanks Jeff. Are you saying that it would be okay to use the OVP device to blow a fuse? Would it be okay to use the bigger breaker in the charging circuit to accomplish a manual shutdown? On Thu, Dec 11, 2014 at 9:28 PM, Jeff Luckey wrote: > > > The idea behind feeding the Regulator with a circuit breaker is that it > gives the pilot the ability to shut-down the alternator (by pulling the > breaker) if that becomes necessary. > > A few reasons you might want to shut down the alternator are: > 1. a failed regulator that is giving full field (if you don't have an over > voltage module) > 2. a failed over-voltage module > 3. testing purposes > > A breaker is simply more practical in this situation. > > > On Thursday, December 11, 2014 3:35 PM, Ken Ryan > wrote: > > > I read on another forum that the B&C over voltage protection thingy must > only be used to trip a breaker, not to blow a fuse. Yet, I just re-read the > chapter on over voltage protection and did not see that mentioned. So the > question is, should the OVP device be used to: a) trip a breaker b) blow a > fuse c) either is okay ? > > > * > > > * > > ________________________________________________________________________________
Subject: Re: downloadable notes that go with the "Z" diagrams...
Date: Dec 12, 2014
The notes are in appendix Z of this document: http://www.aeroelectric.com/Book/AEC_R12A.pdf Not only that, but you get the whole book FREE! Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435649#435649 ________________________________________________________________________________
Date: Dec 12, 2014
Ken, To answer your question directly: Yes, it's okay to use a fuse w/ an OVM. It will just be more difficult to reset ( and it does not give you a convenient way to turn-off the alternator ). However, I'm not sure I'm following you... The best way to shut-down a standard, externally-regulated alternator is to turn-off its regulator. The regulator usually draws less than 1 amp, so you will commonly see a 1 or 2 amp Tyco Series 23 circuit breaker feeding the regulator. Like this: The Over Voltage Modules we've been talking about are designed to create a short circuit on the field breaker when high voltage is present, thus popping it and shutting-down an errant regulator/alternator. In this scenario, there is no big circuit breaker in the output of the alternator because it's not needed. The output of the alternator is controlled by the regulator & its circuit breaker. (And therein lies the beauty of this system: no big breaker required and no big wires running to that breaker in the panel.) So, I'm a little confused by your question: "... Would it be okay to use the bigger breaker in the charging circuit to accomplish a manual shutdown?" Perhaps I'm missing something? Are you referring to one of BobN's Z drawings? Do you have a schematic of the system you are talking about? (a schematic is worth a thousand words) -Jeff On Friday, December 12, 2014 8:23 AM, Ken Ryan wrote: Thanks Jeff. Are you saying that it would be okay to use the OVP device to blow a fuse? Would it be okay to use the bigger breaker in the charging circuit to accomplish a manual shutdown? On Thu, Dec 11, 2014 at 9:28 PM, Jeff Luckey wrote: > >The idea behind feeding the Regulator with a circuit breaker is that it gives the pilot the ability to shut-down the alternator (by pulling the breaker) if that becomes necessary. > >A few reasons you might want to shut down the alternator are: >1. a failed regulator that is giving full field (if you don't have an over voltage module) >2. a failed over-voltage module >3. testing purposes > >A breaker is simply more practical in this situation. > > >On Thursday, December 11, 2014 3:35 PM, Ken Ryan wrote: > > > >I read on another forum that the B&C over voltage protection thingy must only be used to trip a breaker, not to blow a fuse. Yet, I just re-read the chapter on over voltage protection and did not see that mentioned. So the question is, should the OVP device be used to: a) trip a breaker b) blow a fuse c) either is okay ? > > >_blank">www.aeroelectric.com .com" target="_blank">www.buildersbooks.com ="_blank">www.homebuilthelp.com ="_blank">www.mypilotstore.com ank">www.mrrace.com _blank">http://www.matronics.com/contribution ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List tp://forums.matronics.com ________________________________________________________________________________
Date: Dec 12, 2014
Thanks Jeff. Your reply is very helpful. I am developing schematics, but have no easy way of scanning them. My system (Rotax) will have two engine driven current producers. One of them is a more traditional alternator with the internal regulator, and the other a permanent magnet affair with an external regulator that the Z diagrams like to refer to as a "Dynamo." I understand how the over voltage protection device is (differently) wired for each of these two current producers, how for the alternator it cuts the field circuit and for the dynamo it disconnects the regulator. But I was unaware that the use of the OVP device eliminates the need for a breaker in the high current charging wire. Now, looking again at the Z drawings, I see that the "fuse" in the high current alternator wire is marked by "note 10" which makes reference to something called a "fuse like device called a current limiter." How is this "current limiter" different from a fuse or breaker and why is it preferable to a fuse or breaker? Now, when I look at the Rotax specific drawing, I see the high current wire from the "dynamo" seems to be protected by a 16 gauge fusible link. The "dynamo" is rated at 22 amps. Is the 16 gauge fusible link up to the task? Why would I want to use a fusible link, rather than a fuse or a breaker? Ken On Fri, Dec 12, 2014 at 12:18 PM, Jeff Luckey wrote: > > Ken, > > To answer your question directly: Yes, it's okay to use a fuse w/ an OVM. > It will just be more difficult to reset ( and it does not give you a > convenient way to turn-off the alternator ). > > However, I'm not sure I'm following you... > > The best way to shut-down a standard, externally-regulated alternator is > to turn-off its regulator. The regulator usually draws less than 1 amp, so > you will commonly see a 1 or 2 amp Tyco Series 23 circuit breaker feeding > the regulator. Like this: > > > The Over Voltage Modules we've been talking about are designed to create a > short circuit on the field breaker when high voltage is present, thus > popping it and shutting-down an errant regulator/alternator. > > In this scenario, there is no big circuit breaker in the output of the > alternator because it's not needed. The output of the alternator is > controlled by the regulator & its circuit breaker. (And therein lies the > beauty of this system: no big breaker required and no big wires running to > that breaker in the panel.) > > So, I'm a little confused by your question: "... Would it be okay to use > the bigger breaker in the charging circuit to accomplish a manual shutdown?" > > Perhaps I'm missing something? Are you referring to one of BobN's Z > drawings? Do you have a schematic of the system you are talking about? (a > schematic is worth a thousand words) > > -Jeff > > > On Friday, December 12, 2014 8:23 AM, Ken Ryan > wrote: > > > Thanks Jeff. Are you saying that it would be okay to use the OVP device to > blow a fuse? Would it be okay to use the bigger breaker in the charging > circuit to accomplish a manual shutdown? > > On Thu, Dec 11, 2014 at 9:28 PM, Jeff Luckey wrote: > > > The idea behind feeding the Regulator with a circuit breaker is that it > gives the pilot the ability to shut-down the alternator (by pulling the > breaker) if that becomes necessary. > > A few reasons you might want to shut down the alternator are: > 1. a failed regulator that is giving full field (if you don't have an over > voltage module) > 2. a failed over-voltage module > 3. testing purposes > > A breaker is simply more practical in this situation. > > > On Thursday, December 11, 2014 3:35 PM, Ken Ryan > wrote: > > > I read on another forum that the B&C over voltage protection thingy must > only be used to trip a breaker, not to blow a fuse. Yet, I just re-read the > chapter on over voltage protection and did not see that mentioned. So the > question is, should the OVP device be used to: a) trip a breaker b) blow a > fuse c) either is okay ? > > > * > > _blank">www.aeroelectric.com <http://www.aeroelectric.com> > .com" target="_blank">www.buildersbooks.com <http://www.buildersbooks.com> > ="_blank">www.homebuilthelp.com <http://www.homebuilthelp.com> > ="_blank">www.mypilotstore.com <http://www.mypilotstore.com> > ank">www.mrrace.com <http://www.mrrace.com> > _blank">http://www.matronics.com/contribution > ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List > tp://forums.matronics.com <http://forums.matronics.com> > > * > > > * > > > * > > ________________________________________________________________________________
Subject: Re: Alternator Disconnect Z17 vs Z20...
Date: Dec 12, 2014
The Z-17 and Z-20 diagrams that I have both show the relay between the regulator and the battery side of the starter contactor. Z-16 has the relay between the dynamo and the regulator, thus switching the AC current. Either way will work. The 20,000 microfarad capacitor helps to smooth out the pulsing DC from the single phase dynamo. Even if it is not required (but probably is), installing it will not hurt anything. Z-17 and Z-20 have voltage regulators which also rectify the AC into DC. I found this article: http://www.pra.org/publicdl/engines/477%20electrical%20output.pdf I think that a voltage regulator should be installed rather than just a bridge rectifier. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435658#435658 ________________________________________________________________________________
Date: Dec 12, 2014
I'm not Jeff, but, A very short length (4"-6") of wire will carry much more current than its 'rated' capacity (which is for much longer lengths), and that's the basis on which the fusible link idea arises. Fusible links are common in cars these days for wire runs that have a very low likelihood of overcurrent due to their load, but still need to be protected from catastrophic faults (like pinched insulation causing a short to ground). You can buy silicone-protected fusible link wire in bulk on line in various sizes for protecting heavier wire. Common practice is to make the link smaller by 4 numbers than the wire it protects (a 16ga link protects a 12ga wire). Like a fuse or breaker, it should be placed on the current source end of the wire. Properly installed, they are much less prone to defect-induced failure than circuit breakers or fuses (and much, much cheaper than a/c circuit breakers). Somewhere in 'the book' you should find a reference to making your own fusible link. It basically amounts to sliding a woven fiberglass sleeve over the smaller gauge wire link and the joint between link & wire. Download the book in digital form & use Acrobat Reader's search function to find the references. If that isn't clear, just ask for more detail. Charlie On 12/12/2014 4:27 PM, Ken Ryan wrote: > Thanks Jeff. Your reply is very helpful. I am developing schematics, > but have no easy way of scanning them. My system (Rotax) will have two > engine driven current producers. One of them is a more traditional > alternator with the internal regulator, and the other a permanent > magnet affair with an external regulator that the Z diagrams like to > refer to as a "Dynamo." > > I understand how the over voltage protection device is (differently) > wired for each of these two current producers, how for the alternator > it cuts the field circuit and for the dynamo it disconnects the regulator. > > But I was unaware that the use of the OVP device eliminates the need > for a breaker in the high current charging wire. Now, looking again at > the Z drawings, I see that the "fuse" in the high current alternator > wire is marked by "note 10" which makes reference to something called > a "fuse like device called a current limiter." > > How is this "current limiter" different from a fuse or breaker and why > is it preferable to a fuse or breaker? > > Now, when I look at the Rotax specific drawing, I see the high current > wire from the "dynamo" seems to be protected by a 16 gauge fusible > link. The "dynamo" is rated at 22 amps. Is the 16 gauge fusible link > up to the task? Why would I want to use a fusible link, rather than a > fuse or a breaker? > > Ken > > > On Fri, Dec 12, 2014 at 12:18 PM, Jeff Luckey > wrote: > > Ken, > > To answer your question directly: Yes, it's okay to use a fuse w/ > an OVM. It will just be more difficult to reset ( and it does not > give you a convenient way to turn-off the alternator ). > > However, I'm not sure I'm following you... > > The best way to shut-down a standard, externally-regulated > alternator is to turn-off its regulator. The regulator usually > draws less than 1 amp, so you will commonly see a 1 or 2 amp Tyco > Series 23 circuit breaker feeding the regulator. Like this: > > > The Over Voltage Modules we've been talking about are designed to > create a short circuit on the field breaker when high voltage is > present, thus popping it and shutting-down an errant > regulator/alternator. > > In this scenario, there is no big circuit breaker in the output of > the alternator because it's not needed. The output of the > alternator is controlled by the regulator & its circuit breaker. > (And therein lies the beauty of this system: no big breaker > required and no big wires running to that breaker in the panel.) > > So, I'm a little confused by your question: "... Would it be okay > to use the bigger breaker in the charging circuit to accomplish a > manual shutdown?" > > Perhaps I'm missing something? Are you referring to one of BobN's > Z drawings? Do you have a schematic of the system you are talking > about? (a schematic is worth a thousand words) > > -Jeff > > > On Friday, December 12, 2014 8:23 AM, Ken Ryan > > wrote: > > > Thanks Jeff. Are you saying that it would be okay to use the OVP > device to blow a fuse? Would it be okay to use the bigger breaker > in the charging circuit to accomplish a manual shutdown? > > On Thu, Dec 11, 2014 at 9:28 PM, Jeff Luckey > wrote: > > > The idea behind feeding the Regulator with a circuit breaker > is that it gives the pilot the ability to shut-down the > alternator (by pulling the breaker) if that becomes necessary. > > A few reasons you might want to shut down the alternator are: > 1. a failed regulator that is giving full field (if you don't > have an over voltage module) > 2. a failed over-voltage module > 3. testing purposes > > A breaker is simply more practical in this situation. > > > On Thursday, December 11, 2014 3:35 PM, Ken Ryan > > wrote: > > > I read on another forum that the B&C over voltage protection > thingy must only be used to trip a breaker, not to blow a > fuse. Yet, I just re-read the chapter on over voltage > protection and did not see that mentioned. So the question is, > should the OVP device be used to: a) trip a breaker b) blow a > fuse c) either is okay ? > > * > * > ________________________________________________________________________________
Date: Dec 12, 2014
I=99d like to down load =9Cthe book=9D if anyone can tell me what it is???? Jim Kale From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Charlie England Sent: Friday, December 12, 2014 5:39 PM Subject: Re: AeroElectric-List: fuse or breaker for OVP? I'm not Jeff, but, A very short length (4"-6") of wire will carry much more current than its 'rated' capacity (which is for much longer lengths), and that's the basis on which the fusible link idea arises. Fusible links are common in cars these days for wire runs that have a very low likelihood of overcurrent due to their load, but still need to be protected from catastrophic faults (like pinched insulation causing a short to ground). You can buy silicone-protected fusible link wire in bulk on line in various sizes for protecting heavier wire. Common practice is to make the link smaller by 4 numbers than the wire it protects (a 16ga link protects a 12ga wire). Like a fuse or breaker, it should be placed on the current source end of the wire. Properly installed, they are much less prone to defect-induced failure than circuit breakers or fuses (and much, much cheaper than a/c circuit breakers). Somewhere in 'the book' you should find a reference to making your own fusible link. It basically amounts to sliding a woven fiberglass sleeve over the smaller gauge wire link and the joint between link & wire. Download the book in digital form & use Acrobat Reader's search function to find the references. If that isn't clear, just ask for more detail. Charlie On 12/12/2014 4:27 PM, Ken Ryan wrote: Thanks Jeff. Your reply is very helpful. I am developing schematics, but have no easy way of scanning them. My system (Rotax) will have two engine driven current producers. One of them is a more traditional alternator with the internal regulator, and the other a permanent magnet affair with an external regulator that the Z diagrams like to refer to as a "Dynamo." I understand how the over voltage protection device is (differently) wired for each of these two current producers, how for the alternator it cuts the field circuit and for the dynamo it disconnects the regulator. But I was unaware that the use of the OVP device eliminates the need for a breaker in the high current charging wire. Now, looking again at the Z drawings, I see that the "fuse" in the high current alternator wire is marked by "note 10" which makes reference to something called a "fuse like device called a current limiter." How is this "current limiter" different from a fuse or breaker and why is it preferable to a fuse or breaker? Now, when I look at the Rotax specific drawing, I see the high current wire from the "dynamo" seems to be protected by a 16 gauge fusible link. The "dynamo" is rated at 22 amps. Is the 16 gauge fusible link up to the task? Why would I want to use a fusible link, rather than a fuse or a breaker? Ken On Fri, Dec 12, 2014 at 12:18 PM, Jeff Luckey > wrote: Ken, To answer your question directly: Yes, it's okay to use a fuse w/ an OVM. It will just be more difficult to reset ( and it does not give you a convenient way to turn-off the alternator ). However, I'm not sure I'm following you... The best way to shut-down a standard, externally-regulated alternator is to turn-off its regulator. The regulator usually draws less than 1 amp, so you will commonly see a 1 or 2 amp Tyco Series 23 circuit breaker feeding the regulator. Like this: The Over Voltage Modules we've been talking about are designed to create a short circuit on the field breaker when high voltage is present, thus popping it and shutting-down an errant regulator/alternator. In this scenario, there is no big circuit breaker in the output of the alternator because it's not needed. The output of the alternator is controlled by the regulator & its circuit breaker. (And therein lies the beauty of this system: no big breaker required and no big wires running to that breaker in the panel.) So, I'm a little confused by your question: "... Would it be okay to use the bigger breaker in the charging circuit to accomplish a manual shutdown?" Perhaps I'm missing something? Are you referring to one of BobN's Z drawings? Do you have a schematic of the system you are talking about? (a schematic is worth a thousand words) -Jeff On Friday, December 12, 2014 8:23 AM, Ken Ryan > wrote: Thanks Jeff. Are you saying that it would be okay to use the OVP device to blow a fuse? Would it be okay to use the bigger breaker in the charging circuit to accomplish a manual shutdown? On Thu, Dec 11, 2014 at 9:28 PM, Jeff Luckey > wrote: The idea behind feeding the Regulator with a circuit breaker is that it gives the pilot the ability to shut-down the alternator (by pulling the breaker) if that becomes necessary. A few reasons you might want to shut down the alternator are: 1. a failed regulator that is giving full field (if you don't have an over voltage module) 2. a failed over-voltage module 3. testing purposes A breaker is simply more practical in this situation. On Thursday, December 11, 2014 3:35 PM, Ken Ryan > wrote: I read on another forum that the B&C over voltage protection thingy must only be used to trip a breaker, not to blow a fuse. Yet, I just re-read the chapter on over voltage protection and did not see that mentioned. So the question is, should the OVP device be used to: a) trip a breaker b) blow a fuse c) either is okay ? <http://www.aeroelectric.com> <http://www.buildersbooks.com> <http://www.homebuilthelp.com> <http://www.mypilotstore.com> ________________________________________________________________________________
Date: Dec 12, 2014
Date: Dec 13, 2014
Here is a link to the book: http://www.aeroelectric.com/Book/AEC_R12A.pdf -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435682#435682 ________________________________________________________________________________
From: "Bob McCallum" <robert.mccallum2(at)sympatico.ca>
Date: Dec 13, 2014
Here it is. http://www.aeroelectric.com/Book/AEC_R12A.pdf Bob McC _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Jim Kale Sent: Friday, December 12, 2014 11:56 PM Subject: RE: AeroElectric-List: fuse or breaker for OVP? I'd like to down load "the book" if anyone can tell me what it is???? Jim Kale From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Charlie England Sent: Friday, December 12, 2014 5:39 PM Subject: Re: AeroElectric-List: fuse or breaker for OVP? I'm not Jeff, but, A very short length (4"-6") of wire will carry much more current than its 'rated' capacity (which is for much longer lengths), and that's the basis on which the fusible link idea arises. Fusible links are common in cars these days for wire runs that have a very low likelihood of overcurrent due to their load, but still need to be protected from catastrophic faults (like pinched insulation causing a short to ground). You can buy silicone-protected fusible link wire in bulk on line in various sizes for protecting heavier wire. Common practice is to make the link smaller by 4 numbers than the wire it protects (a 16ga link protects a 12ga wire). Like a fuse or breaker, it should be placed on the current source end of the wire. Properly installed, they are much less prone to defect-induced failure than circuit breakers or fuses (and much, much cheaper than a/c circuit breakers). Somewhere in 'the book' you should find a reference to making your own fusible link. It basically amounts to sliding a woven fiberglass sleeve over the smaller gauge wire link and the joint between link & wire. Download the book in digital form & use Acrobat Reader's search function to find the references. If that isn't clear, just ask for more detail. Charlie On 12/12/2014 4:27 PM, Ken Ryan wrote: Thanks Jeff. Your reply is very helpful. I am developing schematics, but have no easy way of scanning them. My system (Rotax) will have two engine driven current producers. One of them is a more traditional alternator with the internal regulator, and the other a permanent magnet affair with an external regulator that the Z diagrams like to refer to as a "Dynamo." I understand how the over voltage protection device is (differently) wired for each of these two current producers, how for the alternator it cuts the field circuit and for the dynamo it disconnects the regulator. But I was unaware that the use of the OVP device eliminates the need for a breaker in the high current charging wire. Now, looking again at the Z drawings, I see that the "fuse" in the high current alternator wire is marked by "note 10" which makes reference to something called a "fuse like device called a current limiter." How is this "current limiter" different from a fuse or breaker and why is it preferable to a fuse or breaker? Now, when I look at the Rotax specific drawing, I see the high current wire from the "dynamo" seems to be protected by a 16 gauge fusible link. The "dynamo" is rated at 22 amps. Is the 16 gauge fusible link up to the task? Why would I want to use a fusible link, rather than a fuse or a breaker? Ken On Fri, Dec 12, 2014 at 12:18 PM, Jeff Luckey wrote: Ken, To answer your question directly: Yes, it's okay to use a fuse w/ an OVM. It will just be more difficult to reset ( and it does not give you a convenient way to turn-off the alternator ). However, I'm not sure I'm following you... The best way to shut-down a standard, externally-regulated alternator is to turn-off its regulator. The regulator usually draws less than 1 amp, so you will commonly see a 1 or 2 amp Tyco Series 23 circuit breaker feeding the regulator. Like this: Image removed by sender. The Over Voltage Modules we've been talking about are designed to create a short circuit on the field breaker when high voltage is present, thus popping it and shutting-down an errant regulator/alternator. In this scenario, there is no big circuit breaker in the output of the alternator because it's not needed. The output of the alternator is controlled by the regulator & its circuit breaker. (And therein lies the beauty of this system: no big breaker required and no big wires running to that breaker in the panel.) So, I'm a little confused by your question: "... Would it be okay to use the bigger breaker in the charging circuit to accomplish a manual shutdown?" Perhaps I'm missing something? Are you referring to one of BobN's Z drawings? Do you have a schematic of the system you are talking about? (a schematic is worth a thousand words) -Jeff On Friday, December 12, 2014 8:23 AM, Ken Ryan wrote: Thanks Jeff. Are you saying that it would be okay to use the OVP device to blow a fuse? Would it be okay to use the bigger breaker in the charging circuit to accomplish a manual shutdown? On Thu, Dec 11, 2014 at 9:28 PM, Jeff Luckey wrote: The idea behind feeding the Regulator with a circuit breaker is that it gives the pilot the ability to shut-down the alternator (by pulling the breaker) if that becomes necessary. A few reasons you might want to shut down the alternator are: 1. a failed regulator that is giving full field (if you don't have an over voltage module) 2. a failed over-voltage module 3. testing purposes A breaker is simply more practical in this situation. On Thursday, December 11, 2014 3:35 PM, Ken Ryan wrote: I read on another forum that the B&C over voltage protection thingy must only be used to trip a breaker, not to blow a fuse. Yet, I just re-read the chapter on over voltage protection and did not see that mentioned. So the question is, should the OVP device be used to: a) trip a breaker b) blow a fuse c) either is okay ? www.aeroelectric.comhttp://www.matronics.com/contribution> http://www.matronics.com/c -Matt Dralle, List - The AeroElectric-List Email List utilities such as List Photoshare, and much much --> http://www.matronics.com/Navigator?AeroElectric-List http://forums.matronics.com==== ________________________________________________________________________________
Date: Dec 13, 2014
Subject: Re: Overvoltage crowbar availability?
At 20:43 2014-12-11, you wrote: > >Greetings, > >It looks like B and C no longer carries the stand-alone overvoltage >crowbar (at least I think that's where I bought the one in my LongEz). >I know Bob is trying to get out of the parts distribution business. >Does anyone else know of a source or should I just plan on building >my own. (and if you have the link handy to Bob's schematic that >would be great but don't search if you don't as I'm sure I can find it...). There is a replacement for the legacy crowbar modules in the works. Boards are laid out and software is nearly complete. Probably have some working hardware in the next two weeks. B&C can probably still sell you the older version as well. The new one is software based and much more immune to nuisance trips. It's also packaged to look more like an 'airplane part' than the legacy CBOVM modules. Emacs! Bob . . . ________________________________________________________________________________
Date: Dec 13, 2014
At 17:38 2014-12-12, you wrote: >I'm not Jeff, but, > >A very short length (4"-6") of wire will carry >much more current than its 'rated' capacity >(which is for much longer lengths), and that's >the basis on which the fusible link idea arises. >Fusible links are common in cars these days for >wire runs that have a very low likelihood of >overcurrent due to their load, but still need to >be protected from catastrophic faults (like >pinched insulation causing a short to ground). >You can buy silicone-protected fusible link wire >in bulk on line in various sizes for protecting >heavier wire. Common practice is to make the >link smaller by 4 numbers than the wire it >protects (a 16ga link protects a 12ga wire). >Like a fuse or breaker, it should be placed on >the current source end of the wire. Properly >installed, they are much less prone to >defect-induced failure than circuit breakers or >fuses (and much, much cheaper than a/c circuit >breakers). Somewhere in 'the book' you should >find a reference to making your own fusible >link.=C2 It basically amounts to sliding a woven >fiberglass sleeve over the smaller gauge wire >link and the joint between link & wire. Download >the book in digital form & use Acrobat Reader's >search function to find the references. If that >isn't clear, just ask for more detail. It's not described in the book . . . but a search at aeroelectric.com on "fusible link" will produce a comic book on its fabrication . . . Bob . . . ________________________________________________________________________________
Date: Dec 13, 2014
Greetings, I'm currently working on wiring up a Quickie with a Rotax 503 (and a glass panel, go figure...). The two architecture diagrams that look appropriate to start from are Z17 "Small Rotax System" (sounds right...) and Z20 "Small Jabiru System". They are basically the same EXCEPT they way the alternator is disconnected (Z17 is downstream of regulator, Z20 is upstream of the regulator). I might be mistaken (please correct me...) but it also appears both diagrams are assuming more of a diode bridge than a real regulator as they both show a 20,000uF cap on the output of the regulator. All z-figures for permanent magnet alternators depict rectifier/regulators as the device of choice for converting the PM alternator's output to DC and then controlling it in a manner friendly to batteries and avionics. Specifications for the 503 state: GENERATOR OUTPUT: 170 W AC at 6000 rpm and 13.5 V RMS RECTIFIER- REGULATOR: (optional) a.) #9103 requires min. load 12 W (1 amp) to regulate b.) #9251 requires no min. load Are you planning to use one of these two rectifier/regulators or some other product? 170 watts of output probably translate to about 14A maximum available output from the r/r . . . do you plan electric start? Have you conducted a load analysis of all planned accessories to determine that you have enough engine driven power to support the load? My questions: 1) What's the significance, if any, of the different approaches to the alternator disconnect? None 2) If I use Rotax 264 870 regulator (as opposed to the 866 080 bridge) is the cap still appropriate (it's not shown in Rotex's wiring diagrams? Where might I find data on these two products? They're not cited as one of the two options in the spec sheet I downloaded. I'm not sure why anyone would ever use an ordinary bridge rectifier between their PM alternator and any other accessory. Can you point me to any literature that describes/recommends this? The capacitor has been a legacy feature of Rotax installations on airplanes for decades. But the little testing I've been able to do on PM alternators and rectifier/regulators cannot confirm the value of adding this device. I'm planing to get another look at the question with more sophisticated equipment in the not too distant future. Bob . . . ________________________________________________________________________________
Date: Dec 13, 2014
On something like a generator charging wire that is connected to the battery, since either end of the wire can be the power source, would it make sense to put a fusible link at each end of the wire? On Sat, Dec 13, 2014 at 8:22 AM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > > At 17:38 2014-12-12, you wrote: > > I'm not Jeff, but, > > A very short length (4"-6") of wire will carry much more current than its > 'rated' capacity (which is for much longer lengths), and that's the basis > on which the fusible link idea arises. > Fusible links are common in cars these days for wire runs that have a ver y > low likelihood of overcurrent due to their load, but still need to be > protected from catastrophic faults (like pinched insulation causing a sho rt > to ground). You can buy silicone-protected fusible link wire in bulk on > line in various sizes for protecting heavier wire. Common practice is to > make the link smaller by 4 numbers than the wire it protects (a 16ga link > protects a 12ga wire). Like a fuse or breaker, it should be placed on the > current source end of the wire. Properly installed, they are much less > prone to defect-induced failure than circuit breakers or fuses (and much, > much cheaper than a/c circuit breakers). Somewhere in 'the book' you shou ld > find a reference to making your own fusible link.=C3=82 It basically amo unts to > sliding a woven fiberglass sleeve over the smaller gauge wire link and th e > joint between link & wire. Download the book in digital form & use Acroba t > Reader's search function to find the references. If that isn't clear, jus t > ask for more detail. > > > It's not described in the book . . . but a search at > aeroelectric.com on "fusible link" will produce a > comic book on its fabrication . . . > > > Bob . . . > > * > =========== m> ldersbooks.com> .com> com> om/contribution> =========== www.matronics.com/Navigator?AeroElectric-List> =========== =========== > > * > > ________________________________________________________________________________
Date: Dec 13, 2014
At 17:35 2014-12-11, you wrote: >I read on another forum that the B&C over voltage protection thingy >must only be used to trip a breaker, not to blow a fuse. Yet, I just >re-read the chapter on over voltage protection and did not see that >mentioned. So the question is, should the OVP device be used to: a) >trip a breaker b) blow a fuse c) either is okay ? Either device will function as-intended . . . open the alternator field circuit when an ov condition is detected. Suggest you review the discussions unique to "crowbar" ov protection on aeroelectric.com http://tinyurl.com/q48agpd You will discover both the reasoning behind adoption of this technique along with recommendations for its use on your airplane. If your project includes a circuit breaker panel, then the choice for fuse vs. breakers is moot. If your choice of circuit protection leans toward fuses, then the breaker is recommended for (1) convenient inflight reset (ONLY ONE TIME) in case of a nuisance trip, (2) ground maintenance operations where you'd like to stop a non-rotating alternator from draining the battery. The later is applicable only if you use the simple, two-pole, two-position DC master that brings battery and alternator on at the same time. If you choose to use the three-position, on-on-on switch shown on various z-figures, OFF, BAT, BAT+ALT then the pullable breaker for ground ops is not necessary. But in terms of OV protection, either fuse or breaker will do the job. Bob . . . ________________________________________________________________________________
Date: Dec 13, 2014
At 11:47 2014-12-13, you wrote: >On something like a generator charging wire that is connected to the >battery, since either end of the wire can be the power source, would >it make sense to put a fusible link at each end of the wire? Not normally needed. An alternator is magnetically incapable of blowing it's own b-lead protection. You need protect only the battery-end of the b-lead. Bob . . . ________________________________________________________________________________
Date: Dec 14, 2014
Bob N. asked: "Are you planning to use one of these two rectifier/regulators or some other product? 170 watts of output probably translate to about 14A maximum available output from the r/r . . . do you plan electric start? Have you conducted a load analysis of all planned accessories to determine that you have enough engine driven power to support the load?" Steve replies: The 264 870 regulator is listed in the engine manual (all I have is hard copy) and on line from rotax suppliers. I don't have a spec sheet on it but given the pictures (big module with a heat sink) it's more than a diode bridge. The engine manual says it doesn't require any load to be in regulation. Our configuration will have electric start and it looks like it needs a good bit of juice per the manual (16AH min battery 10mm2 wire, which looks to me like 2AWG. Engine up front, battery in back so 20' of heavy cable. . The load analysis shows there is plenty of juice (Dynon D60, low-power transponder, radio and engine monitor, LED tip lights and only one halogen on the tail). There are clearly (at least) two version of the 503 (as older one removed has one spark plug per cylinder and the newer one installed has two). If I run across a link for the manuals I have I'll forward them to you. New sanity-check question: The rotax documentation specifies a 16A fuse between the regulator and ship loads (including battery). I'm assuming the location of this fuse is determined by the same factors as an ANL on an alternator equipped ship and, as such, I've put the fuse next to the battery in back, not up front with the regulator. Is there anything about a PM dynamo/regulator combination that would drive putting the fuse up near the regulator? (I still would want something in back near the battery...) Thanks for your help, Steve. ________________________________________________________________________________
Date: Dec 14, 2014
P.S. Bob N., It looks like you have the same engine manual as I. Check http://www.aeroelectric.com/Mfgr_Data/Rotax/Rotax_503_Electrical.pdf page 18-5. Steve. ________________________________________________________________________________
Date: Dec 14, 2014
>Thanks for your help, Good data dump! Need to run a mini-van load of grandkids to ICT but will pray over your posting a bit this evening. Bob . . . ________________________________________________________________________________
Date: Dec 14, 2014
Perihelion Design sells lightweight copper-clad cable. http://www.periheliondesign.com/fatwires.htm > Is there anything about a PM dynamo/regulator combination that would drive putting the fuse up near the regulator? Alternators and dynamos are self current limiting. A dynamo rated at 13 amps will not put out much more than that even if the output is shorted. So there is no need to put a fuse near the dynamo or regulator. A fuse is needed near the battery to protect the wires from excessive battery current if a wire is ever shorted to ground. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435710#435710 ________________________________________________________________________________
Date: Dec 14, 2014
Subject: reset time for crowbar
How long does it take for the crowbar OVP device to reset, once the over voltage condition has been removed? ________________________________________________________________________________
Date: Dec 14, 2014
Subject: Re: reset time for crowbar
At 15:18 2014-12-14, you wrote: >How long does it take for the crowbar OVP device to reset, once the >over voltage condition has been removed? Power to activate an ov trip comes through the field supply circuit breaker. As soon as the crowbar 'trips' . . . voltage to the field drops to about 1.5v until the breaker opens 10-20 milliseconds later whereupon the field voltage falls to zero. The crowbar module 'latches' ON for as long as any substantial amount of current flows through it. So as soon as the breaker opens, the SCR current goes to zero, the crowbar module is then 'unlatched' or officially 'reset' depending on which term you prefer. Bob . . . ________________________________________________________________________________
Date: Dec 15, 2014
Subject: voltage drop across relay
I have scanned chapter 11 but was not able to find the answer to this question: What would be the typical voltage drop across a relay in a 12 volt system using 10 gauge wire to carry about 20 amps? ________________________________________________________________________________
Subject: Re: voltage drop across relay
Date: Dec 15, 2014
Should be in the range of a few millivolts, at most, if the contacts are in g ood shape. Wire size isn't relevant to voltage drop across the relay contact s. Sent from my iPhone > On Dec 15, 2014, at 2:44 PM, Ken Ryan wrote: > > I have scanned chapter 11 but was not able to find the answer to this ques tion: What would be the typical voltage drop across a relay in a 12 volt sys tem using 10 gauge wire to carry about 20 amps? > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Dec 15, 2014
At 14:44 2014-12-15, you wrote: >I have scanned chapter 11 but was not able to find the answer to >this question: What would be the typical voltage drop across a relay >in a 12 volt system using 10 gauge wire to carry about 20 amps? Charlie's right . . . but I'm curious as to what prompted the question. In the best of all worlds, two pieces of metal brought together to carry current (switch and relay contacts) would produce a zero-ohms joint but alas, we don't live in a perfect world. A relay in the same 'class' as you describe Emacs! Emacs! . . . has a published maximum resistance of 0.030 ohms Emacs! according to specs . . . a drop of 20A x 0.030 ohms = 600 millivolts or about 1.2 watts of dissipation at the contacts. I can guarantee that contacts of that mass dumping that much heat would not be long for this earth. As a practical matter, any time you measure more than 100 millivolts across any set of switch or small relay contacts at these kinds of loads, it's worth your time to see if the critter is getting into trouble. Bob . . . ________________________________________________________________________________
Date: Dec 15, 2014
The answer to "what prompted the question" as to typical voltage drop across a 12 volt relay is: The Rotax schematic has the regulator C wire (which measures voltage) going through a couple of relays on its way back to the battery. The text says that there should be no more than 0.2 volt difference between the battery and the C terminal. I was trying to get a handle on how much drop to expect from the two relays. On Mon, Dec 15, 2014 at 2:08 PM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > > At 14:44 2014-12-15, you wrote: > > I have scanned chapter 11 but was not able to find the answer to this > question: What would be the typical voltage drop across a relay in a 12 > volt system using 10 gauge wire to carry about 20 amps? > > > Charlie's right . . . but I'm curious as > to what prompted the question. > > In the best of all worlds, two pieces of > metal brought together to carry current > (switch and relay contacts) would produce > a zero-ohms joint but alas, we don't live > in a perfect world. > > A relay in the same 'class' as you describe > > [image: Emacs!] [image: Emacs!] > > . . . has a published maximum resistance of 0.030 ohms > > [image: Emacs!] > > according to specs . . . a drop of 20A x 0.030 ohms = 600 millivolts > or about 1.2 watts of dissipation at the contacts. I can > guarantee that contacts of that mass dumping that much > heat would not be long for this earth. > > As a practical matter, any time you measure more than > 100 millivolts across any set of switch or small relay > contacts at these kinds of loads, it's worth your time > to see if the critter is getting into trouble. > > > Bob . . . > ________________________________________________________________________________
Date: Dec 15, 2014
At 17:30 2014-12-15, you wrote: >The answer to "what prompted the question" as to >typical voltage drop across a 12 volt relay is: > >The Rotax schematic has the regulator C wire >(which measures voltage) going through a couple >of relays on its way back to the battery. The >text says that there should be no more than 0.2 >volt difference between the battery and the C >terminal. I was trying to get a handle on how >much drop to expect from the two relays. Oh . . . yeah . . . Suggest you consider an architecture like Z-16 that places no switches or relay contacts in series with the regulator's output (B&R) or sense lead (C) and the bus. Bob . . . ________________________________________________________________________________
Date: Dec 15, 2014
At 17:30 2014-12-15, you wrote: >The answer to "what prompted the question" as to >typical voltage drop across a 12 volt relay is:=C2 > >The Rotax schematic has the regulator C wire >(which measures voltage) going through a couple >of relays on its way back to the battery. The >text says that there should be no more than 0.2 >volt difference between the battery and the C >terminal. I was trying to get a handle on how >much drop to expect from the two relays. I'm surprised they did that. Here's an excerpt from another Rotax document that seems to avoid that pitfall nicely . . . Emacs! Bob . . . ________________________________________________________________________________
Date: Dec 16, 2014
The Rotax Installation Manual http://www.flyrotax.com/portaldata/5/dokus/d04967.pdf shows a battery contactor between the battery and main bus and a 25 amp circuit breaker between the main bus and the regulator. There are no small relays used in the regulator circuit. During normal flight, only battery charging current flows through the battery contactor. Any voltage drop across the battery contactor does not affect the output of the voltage regulator. The Rotax wiring diagram has a couple of issues: the master switch does NOT shut off the dynamo, and the starter contactor is connected directly to the battery instead of being in series with the master contactor like many E-AB aircraft are wired. The schematic that Bob posted is not from Rotax but is actually from Van's Aircraft RV-12. I recommend NOT using the Rotax schematic. Instead, wire the rectifier/regulator per Van's schematic with the addition of a 5 amp fuse in the terminal "C" circuit at the main bus. The regulator "C" sense circuit and "R+B" output circuit should be wired with separate paths to the main bus. Then the voltage drop to the "C" terminal will be minimized because only milliamps will flow in its circuit. Less current results in less voltage drop. Bob, please correct me if anything that I said is wrong. See attached picture of the Rotax wiring diagram. Below is the key to reference numbers on the Rotax wiring diagram: 1. Electronic modules (A and B) 2-3. plug connection for ignition switch 4. Integrated generator 5-6. External regulator - rectifier with plug connections 7. Electric starter 8-9. Starter relay with plug connection 10-12. External alternator with connections 13. Electric rev-counter 14. Capacitor 22,000 microfarad 15. Ignition switches 16. Master switch 17. Starter switch 18. Control lamp 19. Battery relay (contactor) 20. Battery 21. Bus bar 22. Capacitor 23. Plug connection for trigger coil assy. 24. Trigger coil assy. (tachometer) 25. Electrical fuel pump 26. Starting equipment at the electronic modules -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435773#435773 Attachments: http://forums.matronics.com//files/rotax_wiring_diagram_102.jpg ________________________________________________________________________________
Date: Dec 16, 2014
Joe, The Rotax diagram I'm looking at is for the 914 and it has the C wire going through one relay plus the battery contactor. [Reference Link] <http://www.flyrotax.com/portaldata/5/dokus/d04273.pdf> On Tue, Dec 16, 2014 at 7:56 AM, user9253 wrote: > > > The Rotax Installation Manual > http://www.flyrotax.com/portaldata/5/dokus/d04967.pdf > shows a battery contactor between the battery and main bus and a 25 amp > circuit breaker between the main bus and the regulator. There are no small > relays used in the regulator circuit. During normal flight, only battery > charging current flows through the battery contactor. Any voltage drop > across the battery contactor does not affect the output of the voltage > regulator. The Rotax wiring diagram has a couple of issues: the master > switch does NOT shut off the dynamo, and the starter contactor is connected > directly to the battery instead of being in series with the master > contactor like many E-AB aircraft are wired. > The schematic that Bob posted is not from Rotax but is actually from > Van's Aircraft RV-12. I recommend NOT using the Rotax schematic. Instead, > wire the rectifier/regulator per Van's schematic with the addition of a 5 > amp fuse in the terminal "C" circuit at the main bus. The regulator "C" > sense circuit and "R+B" output circuit should be wired with separate paths > to the main bus. Then the voltage drop to the "C" terminal will be > minimized because only milliamps will flow in its circuit. Less current > results in less voltage drop. Bob, please correct me if anything that I > said is wrong. > > See attached picture of the Rotax wiring diagram. > Below is the key to reference numbers on the Rotax wiring diagram: > 1. Electronic modules (A and B) > 2-3. plug connection for ignition switch > 4. Integrated generator > 5-6. External regulator - rectifier with plug connections > 7. Electric starter > 8-9. Starter relay with plug connection > 10-12. External alternator with connections > 13. Electric rev-counter > 14. Capacitor 22,000 microfarad > 15. Ignition switches > 16. Master switch > 17. Starter switch > 18. Control lamp > 19. Battery relay (contactor) > 20. Battery > 21. Bus bar > 22. Capacitor > 23. Plug connection for trigger coil assy. > 24. Trigger coil assy. (tachometer) > 25. Electrical fuel pump > 26. Starting equipment at the electronic modules > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435773#435773 > > > Attachments: > > http://forums.matronics.com//files/rotax_wiring_diagram_102.jpg > > ________________________________________________________________________________
Date: Dec 16, 2014
> Joe, The Rotax diagram I'm looking at is for the 914 and it has the C wire going through one relay plus the battery contactor. Ken, You are right. I was looking at the Rotax 912 schematic, not the 914 which has fuel injection. I can understand why the regulator "C" terminal is connected directly to the "R+B" terminals. They want the dynamo to supply power to the fuel pump with no way for the pilot to shut off the regulator. Therefore, I take back what I wrote about connecting terminal "C" according to the RV-12 schematic (unless all scenarios have been considered). If you wire the regulator according to Rotax's schematic and are concerned about the voltage drop across the regulator relay, then consider a double pole relay with the the poles connected in parallel. http://tinyurl.com/DPST-Relay -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435785#435785 ________________________________________________________________________________
Date: Dec 16, 2014
Joe, thanks for the DPST relay tip. The Rotax 914 isn't fuel injected (it's turbocharged) but like a fuel injected engine it must have the electrical fuel pump working in order to run. On Tue, Dec 16, 2014 at 1:19 PM, user9253 wrote: > > > > Joe, The Rotax diagram I'm looking at is for the 914 and it has the C > wire going through one relay plus the battery contactor. > > Ken, > You are right. I was looking at the Rotax 912 schematic, not the 914 > which has fuel injection. I can understand why the regulator "C" terminal > is connected directly to the "R+B" terminals. They want the dynamo to > supply power to the fuel pump with no way for the pilot to shut off the > regulator. Therefore, I take back what I wrote about connecting terminal > "C" according to the RV-12 schematic (unless all scenarios have been > considered). If you wire the regulator according to Rotax's schematic and > are concerned about the voltage drop across the regulator relay, then > consider a double pole relay with the the poles connected in parallel. > http://tinyurl.com/DPST-Relay > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435785#435785 > > ________________________________________________________________________________
Subject: Wiring dual fuel pumps to single switch
Date: Dec 16, 2014
How can I wire a single dual pole switch to control 2 fuel pumps, only one of which can operate at once with the switch being off bottom, pump 1 middle, pump 2 top. I also need each pump to have an independent power source. I thought I could do it with a 2-1, but I can only get it to go on-off-on. Is there a dual pole switch that will accomplish this? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435793#435793 ________________________________________________________________________________
Date: Dec 16, 2014
Subject: Re: Wiring dual fuel pumps to single switch
On 12/16/2014 8:03 PM, carrollcw wrote: > > How can I wire a single dual pole switch to control 2 fuel pumps, only one of which can operate at once with the switch being off bottom, pump 1 middle, pump 2 top. I also need each pump to have an independent power source. I thought I could do it with a 2-1, but I can only get it to go on-off-on. Is there a dual pole switch that will accomplish this? > > A mechanical failure of the switch could take out both pumps; is that acceptable? ________________________________________________________________________________
Subject: Buy 2 get 1 free,Apple Iphone 6/6 plus/5S/5C,Sony Xperia
Z3,
Date: Dec 16, 2014
For Quick Order contact US Skype :seling.source Whatsapp /call: +254773036008 Text/sms : +17075748774 Email.: selingsource(at)gmail.com Buy at affordable price Xmas Promotion sales Apple iPhone 6plus 128GB -$500usd Apple iPhone 6plus 64GB-- $450usd Apple iPhone 6plus 16GB-- $400usd Apple iPhone 6 16gb Apple iPhone 6 64GB Apple iPhone 6 128GB Apple iPhone 5s 64gb Gold Apple iPhone 5s 32gb Gold Apple iPhone 5s 16gb Gold Apple iPhone 5c 32gb Apple iPhone 5c 16gb Apple Iphone 5 64GB Apple Iphone 5 32GB Apple Iphone 5 16GB Apple iPad Air Wi-Fi 5th Gen Apple iPad Air 2 Apple iPad Mini 3 Wi-Fi 4G 64gb Apple iPad Mini 3 Wi-Fi 4G 32gb Apple iPad Mini 3 Wi-Fi 4G 16gb Microsoft Lumia 535 Samsung Galaxy Note 4 Samsung Galaxy S5 Samsung Galaxy Note 3 samsung Galaxy S4 Active LTE-A Samsung Galaxy S4 i9505 Samsung Galaxy Star Trios S5283 Samsung Galaxy Note 3 Neo Duos Samsung Galaxy Note 3 Neo Samsung Galaxy Tab 3 Lite 7.0 3G Samsung Galaxy Grand Neo Samsung Galaxy Note Pro 12.2 LTE Samsung Galaxy Tab Pro 10.1 LTE Sealed Sony Playstation 4 Console 500gb (ps4, Ntsc/usa, Jet Black) Blackberry Porsche Design P'9983 Blackberry Passport BlackBerry Porsche Design P9982 Blackberry Z3 Blackberry Z30 Blackberry Q10 BlackBerry Porsche Design P9981 Sony Xperia E3 Dual Sony Xperia Z3 Sony Xperia Z2 Sony Xperia E1 dual Sony Xperia E1 Sony Xperia T2 Ultra dual Sony Xperia T2 Ultra Sony Xperia Z1s Sony Xperia Z1 Compact Sony Xperia Z1 Motorola Moto G Dual SIM Motorola Moto G Motorola Moto X Motorola DROID Ultra Motorola DROID Maxx Motorola RAZR D3 XT919 Motorola RAZR D1 HTC Nexus 9 HTC One (M8) HTC Desire 310 HTC Desire 501 dual sim HTC Desire 700 dual sim HTC Desire 601 dual sim LG G Pro 2 LG Optimus L1 II Tri E475 LG Optimus F3Q Nokia X Nokia X+ Nokia Lumia Icon Nokia Lumia 525 Nokia Lumia 1520 Nokia Lumia 1320 Nokia Lumia 925 Nokia Lumia 928 Apple Macbook Air Apple MacBook Pro Nikon D800 36.3 MP FX-format CMOS Digital SLR Nikon D3X Digital SLR with 24.5 Mp Nikon D700 Digital SLR Camera with AF-S 24-70mm Nikon D4 16.2 megapixel digital SLR camera Nikon D90 Digital SLR with AF-S DX NIKKOR 18-105mm Nikon D300 Digital SLR Camera with 18-200mm DX AF-S Nikon D60 10.2MP Digital SLR Camera with 18-55mm Nikon D80 DSLR with AF-S DX 18-135mm .... $ 800 Nikon D7000 16.2MP DX Format CMOS Digital SLR with 3.0-inch Canon EOS 5D Mark III Digital SLR Camera with EF 24-105mm Canon EOS 5D Mark II Digital SLR Camera with EF 24-105mm Canon EOS-1D X Digital SLR Camera, 18.1 Mp Canon EOS 7D Digital SLR with EF 28-135mm Canon EOS 50D Digital SLR Camera with 28-135mm EF Canon EOS 40D Digital SLR Camera with EF 28-135mm Canon EOS 600D Digital SLR with 18-200mm IS lens Yamaha Tyros 5 61 Key Keyboard Cost $2,300usd Yamaha Tyros4 61-Key Arranger Workstation Keyboard cost $1,500usd Yamaha Tyros3 61-Key Arranger Workstation Keyboard TYROS3 cost $800usd Yamaha Cp300 cost $500usd Yamaha Motif XS8 Synthesizer 88 Key Demo cost $730usd Yamaha Arius YDP 160 Digital Piano $400usd Yamaha CP33 Stage Piano cost $380usd Yamaha PSR-S900 Portable Keyboard cost $400usd Yamaha MOTIF XS6 Synthesizer cost $940usd Korg M3 Workstation 61 Key Pro Keyboard cost $580usd Korg M3 88 Key Workstation Keyboard cost $750usd Korg M3-73 Workstation cost $760usd Korg Pa800 Synthesizer cost $780usd Rawlings 5' Classic Grand Piano (Walnut Polish) cost $1400usd Rawlings 50" Professional Upright Piano (Mahogany Polish) cost $700usd 5' Queen Anne Grand Piano (Ebony Polish) cost $1,800usd Roland RD700GX Digital Piano cost $750usd Clavia Nord Stage 88 EX cost $780usd For Quick Order contact info below Skype :seling.source Whatsapp /call: +254773036008 Text/sms : +17075748774 Email.: selingsource(at)gmail.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435803#435803 Attachments: http://forums.matronics.com//files/1x_204.jpg ________________________________________________________________________________
Date: Dec 17, 2014
Ceengland, if you posted a picture, it's not showing up for me. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435804#435804 ________________________________________________________________________________
Date: Dec 17, 2014
If you don=92t want to do it with 2 separate switches, I would suggest looking at a rotary switch. Pay attention to the switch amperage ratings as it may require a relay to drive a fuel pump. Keep in mind that with this option, you will not have the ability to turn both pumps on simultaneously. The 2 switches below may work. http://www.digikey.com/product-detail/en/MRT23-A/360-2376-ND/1046092 <http://www.digikey.com/product-detail/en/MRT23-A/360-2376-ND/1046092> http://www.digikey.com/product-detail/en/HS13Y-D/360-2350-ND/2039688 <http://www.digikey.com/product-detail/en/HS13Y-D/360-2350-ND/2039688> link to the knob for this switch ( http://www.digikey.com/product-detail/en/AT432/360-2366-ND/639088 <http://www.digikey.com/product-detail/en/AT432/360-2366-ND/639088> ) There are many more options out there for rotary switches. Hope this helps Justin > On Dec 16, 2014, at 5:03 PM, carrollcw wrote: > > > How can I wire a single dual pole switch to control 2 fuel pumps, only one of which can operate at once with the switch being off bottom, pump 1 middle, pump 2 top. I also need each pump to have an independent power source. I thought I could do it with a 2-1, but I can only get it to go on-off-on. Is there a dual pole switch that will accomplish this? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435793#435793 > > > > > > > > > > ________________________________________________________________________________
Date: Dec 17, 2014
What you want to do is achievable (I believe) with a 2-10, which is an ON-ON -ON - 2 Pole - so wire as you will see here: Ebay: 131380680747 Or 'Steinair' John Sent from my iPad ----x--O--x---- > On 17 Dec 2014, at 03:37 pm, Justin Jones wro te: > > If you don=99t want to do it with 2 separate switches, I would sugge st looking at a rotary switch. Pay attention to the switch amperage ratings as it may require a relay to drive a fuel pump. Keep in mind that with thi s option, you will not have the ability to turn both pumps on simultaneously . > > The 2 switches below may work. > > http://www.digikey.com/product-detail/en/MRT23-A/360-2376-ND/1046092 > > > http://www.digikey.com/product-detail/en/HS13Y-D/360-2350-ND/2039688 link to the knob for this switch ( http://www.digikey.com/product-detail/en/AT4 32/360-2366-ND/639088 ) > > > > There are many more options out there for rotary switches. > > Hope this helps > > Justin > > >> On Dec 16, 2014, at 5:03 PM, carrollcw wrote: >> m> >> >> How can I wire a single dual pole switch to control 2 fuel pumps, only on e of which can operate at once with the switch being off bottom, pump 1 midd le, pump 2 top. I also need each pump to have an independent power source. I thought I could do it with a 2-1, but I can only get it to go on-off-on. Is there a dual pole switch that will accomplish this? >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=435793#435793 > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Dec 17, 2014
On 12/17/2014 4:49 AM, carrollcw wrote: > > Ceengland, if you posted a picture, it's not showing up for me. > > No pic; just a reminder that using one switch means a potential single point of failure for both fuel pumps. Might be acceptably low risk, but should be considered. ________________________________________________________________________________
Date: Dec 17, 2014
At 10:38 2014-12-17, you wrote: > > >On 12/17/2014 4:49 AM, carrollcw wrote: >> >>Ceengland, if you posted a picture, it's not showing up for me. >> >No pic; just a reminder that using one switch means a potential >single point of failure for both fuel pumps. Might be acceptably low >risk, but should be considered. As John mentioned, you can wire a =10 style toggle switch to offer single pole, three position functionality as described in chapter 11 of the 'Connection. Here is one example of this technique. Emacs! A single-pole, three position, center-off will work too . . . but this makes the switch different from all the rest in that OFF is not fully down but mid-position. Charlie's question goes to the notion that if you have two such pumps, then we assume that one must be operational at all times to keep the engine running . . . hence a spare pump. If this is true, then consider the fact that the pump can fail to work for a host of reasons . . . broken wire, bad switch, blown fuse, etc. If one pump circuit goes bad and pops the fuse, then the single failure may take down both pumps. The legacy failure mode effects analysis suggests that the two pumps are best installed as totally separate entities with dedicated switches and power sources. Bob . . . ________________________________________________________________________________
Date: Dec 17, 2014
If you're taking a poll... I add my vote to what Charlie said. One switch is a single point of failure - if it fails you could lose both pumps. Just occurred to me: Do you have a situation where you want to prevent both pumps from being on simultaneously? Could use a mechanical interlock between 2 switches if that is the case. -Jeff On Wednesday, December 17, 2014 8:53 AM, Charlie England wrote: On 12/17/2014 4:49 AM, carrollcw wrote: > > Ceengland, if you posted a picture, it's not showing up for me. > > No pic; just a reminder that using one switch means a potential single point of failure for both fuel pumps. Might be acceptably low risk, but should be considered. ________________________________________________________________________________
Date: Dec 17, 2014
On Wed, Dec 17, 2014 at 10:54 AM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > > At 10:38 2014-12-17, you wrote: > > ceengland7(at)gmail.com> > > On 12/17/2014 4:49 AM, carrollcw wrote: > > > > > Ceengland, if you posted a picture, it's not showing up for me. > > No pic; just a reminder that using one switch means a potential single > point of failure for both fuel pumps. Might be acceptably low risk, but > should be considered. > > > As John mentioned, you can wire a =10 style toggle > switch to offer single pole, three position functionality > as described in chapter 11 of the 'Connection. > > Here is one example of this technique. > > > [image: Emacs!] > > > A single-pole, three position, center-off will > work too . . . but this makes the switch different > from all the rest in that OFF is not fully down > but mid-position. > > Charlie's question goes to the notion that if > you have two such pumps, then we assume that one > must be operational at all times to keep the engine > running . . . hence a spare pump. If this is > true, then consider the fact that the pump > can fail to work for a host of reasons . . . > broken wire, bad switch, blown fuse, etc. > If one pump circuit goes bad and pops the fuse, > then the single failure may take down both > pumps. > > The legacy failure mode effects analysis > suggests that the two pumps are best installed > as totally separate entities with dedicated > switches and power sources. > > Bob . . . > I think he spec'd separate power sources for each pump. But a mechanical failure (cracked housing allowing the switch to fall apart, etc), while admittedly rather low risk for a quality switch, could still take out both pumps. ________________________________________________________________________________
Date: Dec 17, 2014
Subject: stacking ring terminals on terminal post
What's the accepted practice for stacking ring terminals on a terminal post? Rotax 914 diagram shows 5 wires coming together at a capacitor. What's the best way to make that connection? ________________________________________________________________________________
Date: Dec 17, 2014
Subject: Re: stacking ring terminals on terminal post
With new star washers and noalox? 2/3 more than that?? uh uh.. One man's opinion On Wed, Dec 17, 2014 at 5:21 PM, Ken Ryan wrote: > > What's the accepted practice for stacking ring terminals on a terminal > post? Rotax 914 diagram shows 5 wires coming together at a capacitor. > What's the best way to make that connection? > > * > > > * > > ________________________________________________________________________________
Date: Dec 17, 2014
Don't know what is being taught these days, but when I went through Aviation Electricians Mate school in 1947 we were told no more than three ring terminals per post. No star washers were to be used because they interfered with good clean contact. Happy Skies, Old Bob Corporal USMC 646659 AEM In a message dated 12/17/2014 7:25:57 P.M. Central Standard Time, keninalaska(at)gmail.com writes: What's the accepted practice for stacking ring terminals on a terminal post? Rotax 914 diagram shows 5 wires coming together at a capacitor. What's the best way to make that connection? ________________________________________________________________________________
Date: Dec 18, 2014
Currently being taught is no more than 4 terminals per post. If more connections are needed, then use two posts with a buss bar connecting the two of them - and no more than 3 terminals plus the buss bar per post. Reference is AC 43.13-1B Chapter 11 Sections 8 & 14. See also the section beginning at page 98 in this training manual: http://www.keybridgeti.com/videotraining/manualdl/25827.PDF (which includes a discussion about washers). So, to answer the question directly - in my mind, the standard method would be to terminate all five wires with a ring terminal. Use two adjacent terminal posts on a terminal strip, bridge them with a buss bar and attach two terminals to one post and three to the other. Alternatively you could make a short jumper wire with a terminal on each end, and use it to bridge two posts (you'll wind up with 4 terminals on one post and 3 on the other). *(Wires and/or buss bars sized appropriately for the current load.) Now I'm going to muddy the water a bit. 43.13-1B does say that more than 4 terminals can be placed on a post IF specifically authorized. In the Type-Certificated world that I live in, it's much easier to just wire it to the standard (4 or less per post) than it is to go get approval to do it differently - unless there is an "approved" source (such as an install manual for an STC'd item) telling me to do it differently. Chuck On 12/17/2014 8:02 PM, BobsV35B(at)aol.com wrote: > Don't know what is being taught these days, but when I went through > Aviation Electricians Mate school in 1947 we were told no more than > three ring terminals per post. No star washers were to be used because > they interfered with good clean contact. > Happy Skies, > Old Bob > Corporal USMC 646659 AEM > In a message dated 12/17/2014 7:25:57 P.M. Central Standard Time, > keninalaska(at)gmail.com writes: > > What's the accepted practice for stacking ring terminals on a > terminal post? Rotax 914 diagram shows 5 wires coming together at > a capacitor. What's the best way to make that connection? > > * > > * > > * > * ________________________________________________________________________________
Date: Dec 18, 2014
Is this a case where a pair of wires could be crimped together in a single r ing terminal? > On Dec 18, 2014, at 01:17, Chuck Birdsall wrote: > > Currently being taught is no more than 4 terminals per post. If more conn ections are needed, then use two posts with a buss bar connecting the two of them - and no more than 3 terminals plus the buss bar per post. > > Reference is AC 43.13-1B Chapter 11 Sections 8 & 14. > > See also the section beginning at page 98 in this training manual: http:/ /www.keybridgeti.com/videotraining/manualdl/25827.PDF (which includes a disc ussion about washers). > > So, to answer the question directly - in my mind, the standard method woul d be to terminate all five wires with a ring terminal. Use two adjacent term inal posts on a terminal strip, bridge them with a buss bar and attach two t erminals to one post and three to the other. Alternatively you could make a short jumper wire with a terminal on each end, and use it to bridge two pos ts (you'll wind up with 4 terminals on one post and 3 on the other). *(Wires and/or buss bars sized appropriately for the current load.) > > Now I'm going to muddy the water a bit. 43.13-1B does say that more than 4 terminals can be placed on a post IF specifically authorized. In the Type- Certificated world that I live in, it's much easier to just wire it to the s tandard (4 or less per post) than it is to go get approval to do it differen tly - unless there is an "approved" source (such as an install manual for an STC'd item) telling me to do it differently. > > Chuck > > >> On 12/17/2014 8:02 PM, BobsV35B(at)aol.com wrote: >> Don't know what is being taught these days, but when I went through Aviat ion Electricians Mate school in 1947 we were told no more than three ring te rminals per post. No star washers were to be used because they interfered wi th good clean contact. >> >> Happy Skies, >> Old Bob >> Corporal USMC 646659 AEM >> >> In a message dated 12/17/2014 7:25:57 P.M. Central Standard Time, keninal aska(at)gmail.com writes: >> What's the accepted practice for stacking ring terminals on a terminal po st? Rotax 914 diagram shows 5 wires coming together at a capacitor. What's t he best way to make that connection? >> >> >> > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Dec 18, 2014
Thanks for all the good answers. On Thu, Dec 18, 2014 at 3:25 AM, Jared Yates wrote: > > Is this a case where a pair of wires could be crimped together in a single > ring terminal? > > > On Dec 18, 2014, at 01:17, Chuck Birdsall wrote: > > Currently being taught is no more than 4 terminals per post. If more > connections are needed, then use two posts with a buss bar connecting the > two of them - and no more than 3 terminals plus the buss bar per post. > > Reference is AC 43.13-1B Chapter 11 Sections 8 & 14. > > See also the section beginning at page 98 in this training manual: > http://www.keybridgeti.com/videotraining/manualdl/25827.PDF (which > includes a discussion about washers). > > So, to answer the question directly - in my mind, the standard method > would be to terminate all five wires with a ring terminal. Use two adjacent > terminal posts on a terminal strip, bridge them with a buss bar and attach > two terminals to one post and three to the other. Alternatively you could > make a short jumper wire with a terminal on each end, and use it to bridge > two posts (you'll wind up with 4 terminals on one post and 3 on the other). > *(Wires and/or buss bars sized appropriately for the current load.) > > Now I'm going to muddy the water a bit. 43.13-1B does say that more than > 4 terminals can be placed on a post IF specifically authorized. In the > Type-Certificated world that I live in, it's much easier to just wire it to > the standard (4 or less per post) than it is to go get approval to do it > differently - unless there is an "approved" source (such as an install > manual for an STC'd item) telling me to do it differently. > > Chuck > > > On 12/17/2014 8:02 PM, BobsV35B(at)aol.com wrote: > > Don't know what is being taught these days, but when I went through > Aviation Electricians Mate school in 1947 we were told no more than three > ring terminals per post. No star washers were to be used because they > interfered with good clean contact. > > Happy Skies, > Old Bob > Corporal USMC 646659 AEM > > In a message dated 12/17/2014 7:25:57 P.M. Central Standard Time, > keninalaska(at)gmail.com writes: > > What's the accepted practice for stacking ring terminals on a terminal > post? Rotax 914 diagram shows 5 wires coming together at a capacitor. > What's the best way to make that connection? > > > * > > > * > > ________________________________________________________________________________
Date: Dec 18, 2014
At 09:44 2014-12-18, you wrote: >Thanks for all the good answers. > >On Thu, Dec 18, 2014 at 3:25 AM, Jared Yates ><email(at)jaredyates.com> wrote: >Is this a case where a pair of wires could be crimped together in a >single ring terminal? I've worked as a direct employee of 4 airframe companies and indirectly with a dozen others. I've observed no consistency in the rules-of-thumb adopted by the aviation community for configuring or limiting the mechanical architecture of terminal stacks on studs. When I've encountered company documents setting forth requirements, no explanation was offered to help anyone understand why that particular policy was put in force . . . the documents were so old that the authors were retired or dead. There was nobody to ask. Nonetheless, given that (1) they had been in place and enforced for decades and (2) no recorded problems having root cause with the practice, then the requirement must be golden. Obviously, every stud is good for one terminal and 20 terminals probably wouldn't fit . . . so someplace between 1 and 20, there must be an optimal number. In any case, the flower of wire-petals leaving the stud needs to fit without placing forceful interference between terminals. With the right terminals on small wires, one could imagine getting 8 wires to share the stud. I have seen a large cluster of wires stacked on a stud long enough to accommodate a spacer between two clusters. Worked good, lasted a long time but this wasn't on an airplane. One's personal quest for rational policy has to be founded in two sciences. (1) Compression forces for the purpose of obtaining gas-tight interfaces and (2) reverence for the inherent vulnerability of threaded fasteners to succumb to vibration . . . the bottom of every thread is a stress-riser. There is a huge window of opportunity between the requirements for compression loads that achieve gas-tightness and stress limits imposed by hanging mass on the end of a bending moment excited by local vibration. Bottom line is that as long as the stud is long enough to fully penetrate the nut and the wires are not all 2AWG, risks are very low. If the cluster fits and you've got 1-1/2 threads protruding from the nut, you're probably good to go. Bob . . . ________________________________________________________________________________
Date: Dec 18, 2014
Subject: crowbar placement in system
I notice in the Z diagrams that the crowbar seems to be placed in the system downstream from the bus. Since we are trying to protect against over voltage from the alternator, it seems more sensible to place it between the alternator output and the battery. Is there a reason it's not done that way? (such as nuisance trips) ________________________________________________________________________________
Date: Dec 18, 2014
Subject: Re: crowbar placement in system
Remember that the Crowbar's mission is to blow the breaker that feeds the regulator thus shutting-down the alternator. Therefore it needs to be placed on the load side of the regulator breaker. -Jeff On Thursday, December 18, 2014 4:11 PM, Ken Ryan wrote: I notice in the Z diagrams that the crowbar seems to be placed in the system downstream from the bus. Since we are trying to protect against over voltage from the alternator, it seems more sensible to place it between the alternator output and the battery. Is there a reason it's not done that way? (such as nuisance trips) ________________________________________________________________________________
Date: Dec 18, 2014
Oops! I knew that! Been staring at schematics too long. On Thu, Dec 18, 2014 at 3:28 PM, Jeff Luckey wrote: > > Remember that the Crowbar's mission is to blow the breaker that feeds the > regulator thus shutting-down the alternator. Therefore it needs to be > placed on the load side of the regulator breaker. > > -Jeff > > > On Thursday, December 18, 2014 4:11 PM, Ken Ryan > wrote: > > > I notice in the Z diagrams that the crowbar seems to be placed in the > system downstream from the bus. Since we are trying to protect against over > voltage from the alternator, it seems more sensible to place it between the > alternator output and the battery. Is there a reason it's not done that > way? (such as nuisance trips) > > > * > > > * > > ________________________________________________________________________________
Date: Dec 18, 2014
These discussions on how many connectors on a single bolt caused me to recall an accident that a good friend was in. It was a large 46,000 lb. Army Boeing CH-47 Chinook helicopter. The helicopter had 8 fuel boost pumps distributed in 6 tanks to pump the fuel up to the engine driven pumps. The helicopter was lost when both of the turbine engines flamed out due to fuel starvation (not fuel exhaustion). All of the 8 boost pumps had the ground wires connected to one bolt. The bolt did OK, but due to vibration, the sheet metal it was anchored in failed and the bolt broke free of the airframe mount and thus the ground was lost to all of the fuel pumps. Boeing learned from that and soon had 4 ground bolts with the wires distributed between them, and a connector bus between all 4 bolts. It was a single point failure that had been overlooked by the design engineers. History has shown us a few lessons where rather simple design features were overlooked by very talented designers. Bottom line, there is more to this question than just how many terminals may be connected to one bolt. I have seen several references to single point failures in these discussions. Food for thought. Jim . . . . From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Thursday, December 18, 2014 2:40 PM Subject: Re: AeroElectric-List: stacking ring terminals on terminal post At 09:44 2014-12-18, you wrote: Thanks for all the good answers. On Thu, Dec 18, 2014 at 3:25 AM, Jared Yates > wrote: Is this a case where a pair of wires could be crimped together in a single ring terminal? I've worked as a direct employee of 4 airframe companies and indirectly with a dozen others. I've observed no consistency in the rules-of-thumb adopted by the aviation community for configuring or limiting the mechanical architecture of terminal stacks on studs. When I've encountered company documents setting forth requirements, no explanation was offered to help anyone understand why that particular policy was put in force . . . the documents were so old that the authors were retired or dead. There was nobody to ask. Nonetheless, given that (1) they had been in place and enforced for decades and (2) no recorded problems having root cause with the practice, then the requirement must be golden. Obviously, every stud is good for one terminal and 20 terminals probably wouldn't fit . . . so someplace between 1 and 20, there must be an optimal number. In any case, the flower of wire-petals leaving the stud needs to fit without placing forceful interference between terminals. With the right terminals on small wires, one could imagine getting 8 wires to share the stud. I have seen a large cluster of wires stacked on a stud long enough to accommodate a spacer between two clusters. Worked good, lasted a long time but this wasn't on an airplane. One's personal quest for rational policy has to be founded in two sciences. (1) Compression forces for the purpose of obtaining gas-tight interfaces and (2) reverence for the inherent vulnerability of threaded fasteners to succumb to vibration . . . the bottom of every thread is a stress-riser. There is a huge window of opportunity between the requirements for compression loads that achieve gas-tightness and stress limits imposed by hanging mass on the end of a bending moment excited by local vibration. Bottom line is that as long as the stud is long enough to fully penetrate the nut and the wires are not all 2AWG, risks are very low. If the cluster fits and you've got 1-1/2 threads protruding from the nut, you're probably good to go. Bob . . . <http://www.buildersbooks.com> ________________________________________________________________________________
Date: Dec 20, 2014
At 22:49 2014-12-18, you wrote: These discussions on how many connectors on a single bolt caused me to recall an accident that a good friend was in. It was a large 46,000 lb. Army Boeing CH-47 Chinook helicopter. The helicopter had 8 fuel boost pumps distributed in 6 tanks to pump the fuel up to the engine driven pumps. The helicopter was lost when both of the turbine engines flamed out due to fuel starvation (not fuel exhaustion). All of the 8 boost pumps had the ground wires connected to one bolt. The bolt did OK, but due to vibration, the sheet metal it was anchored in failed and the bolt broke free of the airframe mount and thus the ground was lost to all of the fuel pumps. Boeing learned from that and soon had 4 ground bolts with the wires distributed between them, and a connector bus between all 4 bolts. It was a single point failure that had been overlooked by the design engineers. History has shown us a few lessons where rather simple design features were overlooked by very talented designers. Bottom line, there is more to this question than just how many terminals may be connected to one bolt. I have seen several references to single point failures in these discussions. Food for thought. Jim . . . . This illustrates the value of the FMEA. Don't suppose or calculate anything . . . assume the worst down to the fundamentals . . . the simple ideas. All those books full of rules-of-thumb are the top-layer attempt to avoid unhappy circumstances that can arise from an inability to look down into the layers of potential failure. I don't recall ever reading some words on bonding and/or limits to terminals on studs suggesting, "Oh, by the way, make sure that the thing you're bolting to isn't going to break/burn off as a consequence of stresses not addressed by this rule." The universe runs on physics. A huge puzzle of patterns that under ideal conditions, fit together with permanence and functionality. Most cases of a puzzle piece jammed into a less-than-best-fit is of little or no consequence. But sometimes, a 'hit' on the extreme end of the bell curve can cause the assembled puzzle to fall apart . . . and it's always a surprise. The artful component of our science is to be curious, cognizant and competent observers of how the most rudimentary of puzzle pieces have been assembled in the past . . . as a study in both success and failure. It's this knowledge of lessons-learned that offer foundation for future successes and minimizing risks in new adventures. In this endeavor, you cannot have too many observers nor is any intellectual exploration without value. This is how the potential for unhappy surprises are first resolved intellectually sitting at our keyboards . . . thus minimizing the risk of surprise at 5,000 feet . . . or on short final to the rocks. See: http://tinyurl.com/mwjbzt3 Bob . . . ________________________________________________________________________________
Subject: How does the Ducatti rectifier/regulator work?
Date: Dec 20, 2014
A fellow RV-12 builder asked me this: > From the the little that I have read concerning dynamos, they operate at full output all the time as they have no field current controlling them. > Does that mean that if one runs the strobes and landing light all the time, the Ducati reg/rectifier will have less heat to dissipate through the cooling fins, and perhaps stay cooler and last longer? I do not know the answer, thus am asking the experts on the AeroElectric List. How does the Rotax 912 rectifier/regulator work? Does it short out the dynamo output to control voltage? Or does it add a series resistance to drop the output voltage? Or what? Thanks, Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435942#435942 ________________________________________________________________________________
Date: Dec 20, 2014
Subject: Re: How does the Ducatti rectifier/regulator work?
At 13:51 2014-12-20, you wrote: > >A fellow RV-12 builder asked me this: > > From the the little that I have read concerning dynamos, they > operate at full output all the time as they have no field current > controlling them. > > Does that mean that if one runs the strobes and landing light all > the time, the Ducati reg/rectifier will have less heat to dissipate > through the cooling fins, and perhaps stay cooler and last longer? > >I do not know the answer, thus am asking the experts on the >AeroElectric List. How does the Rotax 912 rectifier/regulator >work? Does it short out the dynamo output to control voltage? Or >does it add a series resistance to drop the output voltage? Or what? >Thanks, Joe > >-------- Back 'in the day' when pm alternators were first being added to small bikes, the electrical output on the order of 5 amps did not offer a very challenging energy management problem. Earliest regulators simply used an SCR triggered on each of the alternator's half-cycle to simply short the AC output when the waveform was 'high enough' . . . this crude regulation philosophy caused the alternator to operated in a max-power-output mode all the time . . . with excess power being dissipated in the alternator's windings and the SHUNT mode, rectifier/regulator's heat sink. As the alternators go bigger and consumer design goals for more sophisticated electrical systems grew, there was a pretty popular shift to SERIES mode regulation. The B&C R/R products have always used this philosophy. The Ducatti regulators favored by Rotax were of this general design as well . . . http://aeroelectric.com/Pictures/Regulators/Rotax-Ducati_Rectifier-Regulator.jpg There are more modern versions of this design that use MOSFET transistors in the power control loop . . . designs that dissipate much less power as heat. Bob . . . ________________________________________________________________________________
Date: Dec 20, 2014
At 13:51 2014-12-20, you wrote: A fellow RV-12 builder asked me this: . . . From the the little that I have read concerning dynamos, they operate at full output all the time as they have no field current controlling them. True, FULL output voltage, but not necessarily full output POWER. It's the job of the rectifier regulator to tailor the wild-frequency, wild-voltage AC into some reasonably stable output at the desired voltage. Bob . . . ________________________________________________________________________________
Date: Dec 21, 2014
I assume that the SCRs conduct at low voltage and shut off when the voltage on terminal "C" reaches the set-point. And heat is generated due to the forward voltage drop across the SCRs. The battery symbol in the Rotax regulator/rectifier schematic looks upside down. According to this forum: http://www.edaboard.com/thread67699.html The "E" in resistor values stands for ohms. Thus I interpret 2E2 to be 2.2 ohms. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435958#435958 ________________________________________________________________________________
Date: Dec 21, 2014
At 18:43 2014-12-20, you wrote: > >Can we assume that 820E and 2E2 resistors in the schematic are 820 >ohm and 2R2 (2.2) ohm resistors? >Ken Yes . . . Are you contemplating a DIY clone? Bob . . . ________________________________________________________________________________
Date: Dec 21, 2014
work? On 21/12/2014 6:15 PM, Robert L. Nuckolls, III wrote: > > > At 18:43 2014-12-20, you wrote: >> >> Can we assume that 820E and 2E2 resistors in the schematic are 820 >> ohm and 2R2 (2.2) ohm resistors? >> Ken > > Yes . . . > > Are you contemplating a DIY clone? > Yes but not immediately. I did a one off many years ago for the positive side of a wound field alternator with a commercial IC that has worked out well. I'd like to regulate the charging on some small equipment that is hard on batteries and I also told myself that I'd roll my own if I ever need another John Deere unit for the airplane. I like more temperature compensation than commercial regulators incorporate (and my batteries seem to agree...) Ken ________________________________________________________________________________
Subject: Power stabilizer wiring
Date: Dec 22, 2014
Rather than a standby battery I am installing a 4 amp rated 'Intelligent Power Stabilizer' on my z-13/8 wired RV for brownout protection to one of my two EFIS screens during startup. The EFIS draws 1 amp. The manual says to install a 12 amp fuse on the power inlet to the IPS unit and a second 5 amp inline fuse on the wire providing power from the IPS to the secondary power inlet on the EFIS. First question: the 12 amp fuse can just be on my main bus so no hassle there but i would rather not have the 5 amp inline fuse buried behind the subpanel with the IPS if its not absolutely necessary. Do I definitely need both fuses for adequate protection? Second question: Any reason the IPS can't be used as the sole source of power to the EFIS rather than as backup? If I wired the IPS to the ebus I have the backup alternator I can use should the primary fail. Maybe the IPS is not intended for full time operation or perhaps it draws more current than practical for the ebus? Thanks Erich This e-mail and any attachments contain URS Corporation confidential information that may be proprietary or privileged. If you receive this message in error or are not the intended recipient, you should not retain, distribute, disclose or use any of this information and you should destroy the e-mail and any attachments or copies. ________________________________________________________________________________
Date: Dec 21, 2014
Subject: Re: Power stabilizer wiring
Eric wrote: Second question: Any reason the IPS can't be used as the sole source of power to the EFIS rather than as backup? ... If the IPS is the sole source of power & it fails then it takes-out your efis. Any component you add to the critical path decreases reliability. If you wire it as you described, then it helps w/ brownout and if it fails it's no big deal. -Jeff On Sunday, December 21, 2014 4:42 PM, "Weaver, Erich" wrote: Rather than a standby battery I am installing a 4 amp rated 'Intelligent Power Stabilizer' on my z-13/8 wired RV for brownout protection to one of my two EFIS screens during startup. The EFIS draws 1 amp. The manual says to install a 12 amp fuse on the power inlet to the IPS unit and a second 5 amp inline fuse on the wire providing power from the IPS to the secondary power inlet on the EFIS. First question: the 12 amp fuse can just be on my main bus so no hassle there but i would rather not have the 5 amp inline fuse buried behind the subpanel with the IPS if its not absolutely necessary. Do I definitely need both fuses for adequate protection? Second question: Any reason the IPS can't be used as the sole source of power to the EFIS rather than as backup? If I wired the IPS to the ebus I have the backup alternator I can use should the primary fail. Maybe the IPS is not intended for full time operation or perhaps it draws more current than practical for the ebus? Thanks Erich This e-mail and any attachments contain URS Corporation confidential information that may be proprietary or privileged. If you receive this message in error or are not the intended recipient, you should not retain, distribute, disclose or use any of this information and you should destroy the e-mail and any attachments or copies. ________________________________________________________________________________
Date: Dec 22, 2014
I should have stated previously that the manufacturer has indicated that failure of the IPS results in pass through of the bus voltage. Assuming that's true, operation of the EFIS should continue unless I was in a brownout situation. This e-mail and any attachments contain URS Corporation confidential information that may be proprietary or privileged. If you receive this message in error or are not the intended recipient, you should not retain, distribute, disclose or use any of this information and you should destroy the e-mail and any attachments or copies. ________________________________________________________________________________
Date: Dec 22, 2014
work? Yes but not immediately. I did a one off many years ago for the positive side of a wound field alternator with a commercial IC that has worked out well. I'd like to regulate the charging on some small equipment that is hard on batteries and I also told myself that I'd roll my own if I ever need another John Deere unit for the airplane. I like more temperature compensation than commercial regulators incorporate (and my batteries seem to agree...) Ken Understand. If that project bubbles to the top of your to-do list, lets talk. If you like, I could perhaps contribute to your project with an etched circuit board layout. Keep an eye on developments in the rectifier/regulator world for PM alternators. The Ducati design is now probably pushing 40 years old and there's been a lot of new ideas and products added to the mix in the interim. I'm exploring some of the COTS options for a client and may have some recommendations to share in the not too distant future. Then there's those lithium thingys getting a toe hold in the marketplace. They're here to stay. They're not the ticking time- bomb we've been let to imagine. BUT . . . they are NOT lead-acid drop-ins. Every kid and his dog wanted to get into the SVLA business wayyyyy back when and those unable to perform were a brief flash on the horizon. I suspect the lithium products will bubble up and be filtered in the marketplace as well. I'm working the 4th installment to the lithium saga for Kitplanes. I love this business . . . tomorrow . . . you can do more for $less$ with better performance, lower weight, smaller space than you can today. It's exciting. But just because the Ducati style is dated does not mean that it's unserviceable or unworthy of consideration for improvements. It's your kitchen chef . . . variations on a theme may be just what's needed to fit your design goals. Bob . . . ________________________________________________________________________________
Subject: SD8 output at 28V?
Date: Dec 22, 2014
Hello Aeroelectric, Does anyone have information about the SD8 output performance at 28V? B&C are advertising a 28V version, but were unable to provide any data when I asked. I also took Bob's 12.5V/13.8V output ratings at 3100 alternator RPM and built a Thevenin equivalent circuit. That shows open circuit voltage of only ~20V. Hopefully that's not an accurate way to model this device. David Read this topic online here: http://forums.matronics.com/viewtopic.php?p=436011#436011 ________________________________________________________________________________
Date: Dec 22, 2014
At 18:33 2014-12-21, you wrote: Rather than a standby battery I am installing a 4 amp rated 'Intelligent Power Stabilizer' on my z-13/8 wired RV for brownout protection to one of my two EFIS screens during startup. The EFIS draws 1 amp. The manual says to install a 12 amp fuse on the power inlet to the IPS unit and a second 5 amp inline fuse on the wire providing power from the IPS to the secondary power inlet on the EFIS. First question: the 12 amp fuse can just be on my main bus so no hassle there but i would rather not have the 5 amp inline fuse buried behind the subpanel with the IPS if its not absolutely necessary. Do I definitely need both fuses for adequate protection? Fuses should be part of your system for one reason only . . . to protect wires and to prevent a failure on one feeder from propagating into other systems. Hence the common-bus/multiple-feeder architectures with individual protection on each feeder. If the manufacturer calls for a fuse in the output lead, then it's very much worth your time and effort to inquire as to the circumstances under which that fuse might operate. Not being familiar with the design of his product, we're in a poor position to conduct an FMEA. I hope that his reply would state that the output fuse is unnecessary. If the device is rated at 4A output (56 watts) and assuming at LEAST 80% efficiency then input demand would be on the order of 75 watts. Under brown out conditions (8 volts or so) the current TRANSIENT would be on the order of 10A . . .so the 12A protection call-out seems reasonable for a FULLY loaded system. Your system loads as installed will be approximately 1/4 rated max values so you have plenty of headroom in terms of wire protection. 12A call-out is a bit funky . . . go for 10A . . . a fuse you can actually buy. Second question: Any reason the IPS can't be used as the sole source of power to the EFIS rather than as backup? If I wired the IPS to the ebus I have the backup alternator I can use should the primary fail. Maybe the IPS is not intended for full time operation or perhaps it draws more current than practical for the ebus? Energy is energy is energy. These switchmode power supplies are constant power systems meaning that as bus voltage falls, INPUT current will rise to maintain a constant power at the output terminals. Your 1A EFIS demand (14W) means normal bus (14.5v) draw is about 1.3A, at end of life on battery only ops (11v) the draw rises to about 1.5A. During brown out transient of say 8v, the draw rises to 2.2A. So 10A circuit protection from the bus seems quite adequate. Bob . . . ________________________________________________________________________________
Date: Dec 22, 2014
Subject: Re: SD8 output at 28V?
At 12:49 2014-12-22, you wrote: > >Hello Aeroelectric, > >Does anyone have information about the SD8 output performance at 28V? > >B&C are advertising a 28V version, but were unable to provide any >data when I asked. > >I also took Bob's 12.5V/13.8V output ratings at 3100 alternator RPM >and built a Thevenin equivalent circuit. That shows open circuit >voltage of only ~20V. Hopefully that's not an accurate way to model >this device. > >David Both 14 and 28v versions are wound by B&C. The 28v version would have more turns on it than the 14v. The alternator's output is roughly limited by the magnetics. This is a 100W alternator frame so I would imagine that the 28v performance for current is 1/2 that of the 14v version. I'll be at B&C in then next few weeks . . .I'll check for sure. Bob . . . ________________________________________________________________________________
Date: Dec 22, 2014
Bob, That's really helpful information. I currently have the 14V version and B&C told me that I could switch it to 28V by simply changing the regulator. It sounds like that may not be the case. (no pun intended) David Read this topic online here: http://forums.matronics.com/viewtopic.php?p=436018#436018 ________________________________________________________________________________
Date: Dec 23, 2014
I had a conversation with the manufacturer today. Given the low amp draw for my specific use, he was comfortable with reducing the 12 amp fuse to 7.5 amp and eliminating the downstream 5 amp fuse. Not sure a 7.5 amp fuse is readily available, but will go with 10 if not. There is also no reason why the IPS can't be used as the sole source of power to the EFIS. There are multiple redundant paths built into the unit so that the power stabilizing capability could essentially vaporize and the unit would default to passing through available buss voltage, so there is very little risk of losing power to my EFIS. I do like the fact that this unit is small and maintenance free, unlike a backup battery that is more often used for this anti brownout purpose. This e-mail and any attachments contain URS Corporation confidential information that may be proprietary or privileged. If you receive this message in error or are not the intended recipient, you should not retain, distribute, disclose or use any of this information and you should destroy the e-mail and any attachments or copies. ________________________________________________________________________________
Subject: N811HB analysis files
Date: Dec 23, 2014
Bob N. - In a recent post you referred us to http://www.aeroelectric.com/Re ference_Docs/Accidents/N811HB_Feb2008_LA-IVp/ for study. Many of the files in this folder are .wmv files, i.e. video files. Should t hese files be PDF files? Thanks. Bob Bower RV-6A builder ________________________________________________________________________________
Date: Dec 22, 2014
Erich, You appear to be interested in design and analysis so you may be interested in the attached document. It's a design where redundancy & brown-out prevention were initial design criteria and baked-in from the beginning - therefore it does not require bolting-on additional widgets. In addition it's surprisingly straight-forward. -Jeff On Monday, December 22, 2014 5:14 PM, "Weaver, Erich" wrote: I had a conversation with the manufacturer today. Given the low amp draw for my specific use, he was comfortable with reducing the 12 amp fuse to 7.5 amp and eliminating the downstream 5 amp fuse. Not sure a 7.5 amp fuse is readily available, but will go with 10 if not. There is also no reason why the IPS can't be used as the sole source of power to the EFIS. There are multiple redundant paths built into the unit so that the power stabilizing capability could essentially vaporize and the unit would default to passing through available buss voltage, so there is very little risk of losing power to my EFIS. I do like the fact that this unit is small and maintenance free, unlike a backup battery that is more often used for this anti brownout purpose. This e-mail and any attachments contain URS Corporation confidential information that may be proprietary or privileged. If you receive this message in error or are not the intended recipient, you should not retain, distribute, disclose or use any of this information and you should destroy the e-mail and any attachments or copies. ________________________________________________________________________________
Date: Dec 23, 2014
> Not sure a 7.5 amp fuse is readily available, . . . Van's Aircraft sells fuses that glow when blown (if the circuit has a load). Van's phone 503.678.6545 ES-00202 FUSE ATC 2 AMP (No glow) $0.40 ES-00203 FUSE ATC 3 AMP LIT $0.55 ES-00205 FUSE ATC 5 AMP LIT $0.55 ES-00207 FUSE ATC 7.5 AMP LIT $1.00 ES-00210 FUSE ATC 10 AMP LIT $0.85 ES-00230 FUSE ATC 30 AMP LIT $0.85 Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=436043#436043 ________________________________________________________________________________
Date: Dec 23, 2014
Subject: Re: N811HB analysis files
At 19:54 2014-12-22, you wrote: >Bob N. ' In a recent post you referred us to ><http://www.aeroelectric.com/Reference_Docs/Accidents/N811HB_Feb2008_LA-IVp />http://www.aeroelectric.com/Reference_Docs/Accidents/N811HB_Feb2008_LA-IVp / >for study. >Many of the files in this folder are .wmv files, >i.e. video files. Should these files be PDF files? Thanks. No, those are preliminary presentations that I prepared for my client. I fabricated a table-top demonstrator to show the Failure modes effects for the as-installed system on the accident aircraft. Those are 'rough' videos of the equipment and the concepts to be demonstrated for the discovery phase of the case. Depending on the course of the case development, I would have produced refined versions with better equipment. As it was, the case settled and courtroom presentations were unnecessary. The work I produced demonstrated that the designers diddling with proven recipes for success produced a system that WAS GOING TO FAIL . . . it was just a matter of time. Bob . . . ________________________________________________________________________________
Date: Dec 23, 2014
At 15:52 2014-12-22, you wrote: > >Bob, > >That's really helpful information. I currently have the 14V version >and B&C told me that I could switch it to 28V by simply changing the >regulator. It sounds like that may not be the case. (no pun intended) Hmmmm . . . I am surprised at that. I'll explore it further. I was involved in the SD-8 development wasssyyyy back when . . . in fact, that alternator was designed and produced at the request of Burt Rutan to Bill Bainbridge. Burt was alarmed at the heavy systems being installed on his designs and he was hoping that B&C could rise to the challenge of offering a 'tiny' system to run a few radios for day/vfr operations.
November 23, 2014 - December 24, 2014
AeroElectric-Archive.digest.vol-mp
