AeroElectric-Archive.digest.vol-mv
June 26, 2015 - August 19, 2015
      Does the VP-X have an alarm channel for Over-Voltage?=C2- If so, was that
       alarm triggered?
      -Jeff
           On Friday, June 26, 2015 10:16 AM, donjohnston <don@velocity-xl.com> w
      rote:
      m>
      As it has been explained to me, the voltage regulator is determining the fa
      ult. The VP-X is reporting the fault.
      My meter has a hold feature but it's manual, not a peak hold.
      http://forums.matronics.com/viewtopic.php?p=444069#444069
      S -
      =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin.
Subject: GNS430W and TruTrak AP
Date: Jun 26, 2015
What happens to the voltage on the essential buss if it is loaded too heavily and the diode does not have a heat sink installed? I am having my radio and my autopilot reset from time to time in flight and I suspect that the voltage on the essential buss is dropping to a level that causes this. I plan to check the voltage on the buss next time I am at the airport to try and confirm the voltage idea. What can cause the voltage to drop if that is the problem? High resistance connections? What else should I check? Bill ________________________________________________________________________________
Subject: Re: GNS430W and TruTrak AP
Date: Jun 26, 2015
If the diode is too hot to touch, it should have a heat sink. It is unlikely that normal current through a diode will drop the voltage enough to cause avionics to reboot. More likely is a loose connection. Does the problem occur while the ebus switch is on? Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=444074#444074 ________________________________________________________________________________
Date: Jun 26, 2015
At 01:56 PM 6/26/2015, you wrote: > > >What happens to the voltage on the essential buss if it is loaded too >heavily and the diode does not have a heat sink installed? > >I am having my radio and my autopilot reset from time to time in flight and >I suspect that the voltage on the essential buss is dropping to a level that >causes this. I plan to check the voltage on the buss next time I am at the >airport to try and confirm the voltage idea. > >What can cause the voltage to drop if that is the problem? High resistance >connections? What else should I check? Diodes don't do that. Your data acquisition and diagnosis problem is not unlike that described in another thread on this forum theorizing about root cause of an OV trip. Transient events are . . . just that . . .SHORT. Probability of capturing data with the ordinary shop tools that will flashlight a path to discovery is slim. Does your diode get too hot to touch? What is it mounted to and what kind of diode? Try flying with the alternate feed switch ON thus bypassing the normal feed through the diode. In the mean time, I'll continue a recently resurrected notion of devising some data capture tools that can be easily acquired or perhaps mailed around. Playing 'swap-tronics' until the problem goes away is not very professional or satisfying. Bob . . . ________________________________________________________________________________
Date: Jun 26, 2015
Subject: Re: Alternator problem?
At 12:05 PM 6/26/2015, you wrote: > >As it has been explained to me, the voltage regulator is determining >the fault. The VP-X is reporting the fault. > >My meter has a hold feature but it's manual, not a peak hold. If we were conducting this investigation in B-31 at Beech (Flight Test) we would get out a data acquisition system capable gathering 5 channels of voltage at 2% or better accuracy for 100 samples per second or faster. Monitor battery voltage at the battery Monitor B-terminal voltage at the alternator Monitor Alternator Field voltage at the alternator Monitor Bus Sense voltage at the regulator Monitor Bus Voltage at the Regulator. Then go fly and see if the problem will duplicate. The data traces will reveal how the major players behave before, during and after the event . . . and probably narrow the options for root cause. That regulator has 'selective ov trip'. When an ov condition is detected, the field voltage from the regulator MUST be high for the ov trip to be triggered. This logic allows more than one alternator to parallel on a bus and avoid an ov trip for both alternators should only one of them mis-behave. Knowing what I do about the hardware, it seems most likely that the ov sensing system is being irritated by some phenomenon in the system. In the early days of crowbar ov system development, we were chagrined to discover that SOME airplanes had extra-ordinarily significant transient sources that would nuisance trip our regulators. Regulars with years of satisfactory service on thousands of airframes. I'm not aware of recent examples of 'extra ordinary irritation' but I wouldn't discount it. Can you pair the ov trip even with any particular action elsewhere in the system? Bob . . . ________________________________________________________________________________
Date: Jun 27, 2015
> If we were conducting this investigation in B-31 at Beech (Flight Test) we would get out a data acquisition system... Hey Bob, Yeah, my kingdom for a DAQ that I could put on this. :( > Can you pair the ov trip even with any particular action elsewhere in the system? No. Like I said, the engine runs thus far have all been short (~5 min) and I've been focusing on fuel and temp related indicators. The engine issues have been resolved so now the engine runs should be longer and I should be able to better monitor the electrical side to identify if there's an event which precedes it or if it's random. Right now I'm trying to decide if I should pull the alternator or wait and see. Thanks, Don Read this topic online here: http://forums.matronics.com/viewtopic.php?p=444084#444084 ________________________________________________________________________________
Date: Jun 27, 2015
> As it has been explained to me, the voltage regulator is determining the fault. The VP-X is reporting the fault. Looking at the LR3C documentation, there is no output terminal dedicated to providing an over-voltage warning. Therefore the only way that the LR3C can indicate over-voltage is by the crowbar circuit shorting out terminal 6. If terminal 6 gets its power from the VP-X and not from a circuit breaker, then the VP-X should report over-current, not over-voltage. I do not know how the VP-X works, but expect that it monitors system voltage independently from the LR3C. If the VP-X reports over-voltage, a troubleshooter might ask, is it telling the truth or lying? What is the over-voltage setpoint? How long must the voltage be over the setpoint before tripping? Can the pilot change the over-voltage setpoint? Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=444085#444085 ________________________________________________________________________________
Date: Jun 27, 2015
On Sat, Jun 27, 2015 at 7:04 AM, donjohnston <don@velocity-xl.com> wrote: > don@velocity-xl.com> > > > > If we were conducting this investigation in B-31 at Beech (Flight Test) > we would get out a data acquisition system... > > Hey Bob, > > Yeah, my kingdom for a DAQ that I could put on this. :( > > > > Can you pair the ov trip even with any particular action elsewhere in > the system? > > > No. Like I said, the engine runs thus far have all been short (~5 min) and > I've been focusing on fuel and temp related indicators. > > The engine issues have been resolved so now the engine runs should be > longer and I should be able to better monitor the electrical side to > identify if there's an event which precedes it or if it's random. > > Right now I'm trying to decide if I should pull the alternator or wait and > see. > > Thanks, > Don > > Pardon my density, but with an externally regulated alternator, how is it possible for the alternator itself to be the cause of overvoltage? Isn't it just a few coils of wire on some iron? It can't produce any significant voltage at all without field current supplied by the regulator, right? It's hard for me to envision any fault within the alternator that would produce *higher* than design voltage. Any short or open circuit inside the alternator should produce either lower or no voltage output, unless I'm missing something. Charlie ________________________________________________________________________________
Date: Jun 27, 2015
Good question Charlie. I also want to know what can go wrong with an externally regulated alternator that would cause over voltage. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=444088#444088 ________________________________________________________________________________
Date: Jun 27, 2015
At 08:35 AM 6/27/2015, you wrote: > >Good question Charlie. I also want to know what can go wrong with >an externally regulated alternator that would cause over voltage. >Joe > >-------- >Joe Gores Cogent questions gentlemen. The short answer is, it can't. The long answer is that the transfer function of voltage control in some regulators doesn't handle brush-bounce well. This can COMBINE with poor design of the OV trip system to create some vexing symptoms. I can relate a first hand-experience with OV trips in brand new airplanes that go back over 30 years . . . with engineers in three institutions pointing fingers at each other while your's truly kept reminding them of the obvious. That problem was only recently solved by a long recommended replacement of a regulator that should not have been qualified onto the airplane in the first place. If and LR3 is manifesting poor response to brush-bounce, this will be a first in my experience. It would be the collision of THREE conditions, each at the extremes of their production tolerances, or perhaps a manufacturing error. I think this quite improbable but easy to check with the swapping of one of the two waring factions. The regulator probably being the easiest. There are some peek, poke and ponder exercises to conducted before we play swap-tronics. Bob . . . ________________________________________________________________________________
Date: Jun 27, 2015
At 07:04 AM 6/27/2015, you wrote: > > > > If we were conducting this investigation in B-31 at Beech (Flight > Test) we would get out a data acquisition system... > >Hey Bob, > >Yeah, my kingdom for a DAQ that I could put on this. :( The Force is in sympathy with you. Paul Fisher and I will be stirring this into the list of things to do . . . as soon as we clear the decks of another commitment . . . probably after OSH. The availability of off-the-shelf DAS hardware and supporting graphical user interface leaves no excuses for not crafting a suite of hardware that addresses capabilities we've dreamed about here on the List for 20 years. There's no 'hard' work to be done here . . . only assemble off the shelf stuff into useful tools. It's all about the packaging. By the way, this is not a state secret project. If any members on the List have ECB layout capabilities and reasonable skills at slinging solder, contact me off-list and we'll see how your skill-set offer might fit into this project. I'm contemplating this becoming a tool for DIY efforts, perhaps a tool that could be rented and shipped around the country as needed, and it certainly has possibilities as an article for KitPlanes. The time for OBAM aviation to acquire routine access to low cost measurement tools arrived a few years ago and we were asleep at the keyboard. Bob . . . ________________________________________________________________________________
Date: Jun 27, 2015
I'll try an answer with either what I know or what I've been told: The VP-X monitors the system voltage. When it hits 32v, it shuts off the power to the field and reports an overvoltage fault. (see attached) I don't know exactly where it's monitoring the system voltage. I would guess at it's connection to the system bus. The only "adjustment" to the overvoltage trigger level is whether it's installed in a 14v or 28v system. On a 28v system, the OV trigger is hard set at 32v. Vertical Power offered to bench check the VP-X. But since this is early in the game, I was hoping to get some more ideas and data before going down that road. Speaking of data, I did run across this little guy: DataQ Instruments DI-149 http://www.dataq.com/products/di-149/index.html?gclid=Cj0KEQjwk7msBRCJj67khY2z_NIBEiQAPTFjv9iqePcOkNiAMApB_amhAfmVZ-fp0KOI3tHOgpWA9VoaAnUa8P8HAQ I'm wondering if it would be helpful to identify what's happening. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=444092#444092 ________________________________________________________________________________
Date: Jun 27, 2015
From: Etienne Phillips <etienne.phillips(at)gmail.com>
Hi Bob Have you considered using the Red Pitaya as a base for signal gathering? It's an open source DAQ that already has a lot of the hard work done. It's not dirt cheap ($320) but may offer a quick route to a portable, rentable or EAA chapter own-able device that would fit the bill. Check out www.redpitaya.com Thanks Etienne On 27 June 2015 at 16:39, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 07:04 AM 6/27/2015, you wrote: > > don@velocity-xl.com> > > > > If we were conducting this investigation in B-31 at Beech (Flight Test) > we would get out a data acquisition system... > > Hey Bob, > > Yeah, my kingdom for a DAQ that I could put on this. :( > > > The Force is in sympathy with you. Paul Fisher > and I will be stirring this into the list of > things to do . . . as soon as we clear the decks > of another commitment . . . probably after > OSH. The availability of off-the-shelf DAS > hardware and supporting graphical user > interface leaves no excuses for not crafting > a suite of hardware that addresses capabilities > we've dreamed about here on the List for 20 > years. > > There's no 'hard' work to be done here . . . > only assemble off the shelf stuff into > useful tools. It's all about the packaging. > > By the way, this is not a state secret project. > If any members on the List have ECB layout > capabilities and reasonable skills at slinging > solder, contact me off-list and we'll see how > your skill-set offer might fit into this > project. > > I'm contemplating this becoming a tool for > DIY efforts, perhaps a tool that could be rented > and shipped around the country as needed, and > it certainly has possibilities as an article > for KitPlanes. > > The time for OBAM aviation to acquire routine > access to low cost measurement tools arrived a few > years ago and we were asleep at the keyboard. > > > Bob . . . > > * > > > * > > ________________________________________________________________________________
Date: Jun 27, 2015
At 06:34 AM 6/26/2015, you wrote: I'm in the process of trying to track down an over voltage fault. So far the engine runs that I've been doing have been relatively short duration (mostly around 5-10min) while I'm getting the engine dialed in. On about 4 occasions I've noticed the alternator circuit has faulted for "over voltage". I'm running a 28v electrical system VP-X Pro B&C LR3C voltage regulator Kelly Aerospace 50a alternator Continental IO-550 engine. Vertical Power and B&C have had me check a number things. All checks have shown voltage levels, drops and wire resistance to be well within parameters. How are your LR3 and VPX system configured? The LR3 is fitted with crowbar OV protection. If I understand your symptoms, it's an OV sense and protection function within the VPX that tripping? Can you de-program the VPX ov function? Or raise it's trip point to some big number? You don't need TWO ov protection systems. >B&C is recommending to pull the alternator and have it checked. In the great spaghetti-mix that is aviation accessories, marketing and business models, it's difficult to keep track of who's alternator is being built by whom and with what, if any, improvements. The alternators involved in the three-decade saga of new airplane OV trips were the occasionally-unfair targets of accusatory assertions . . . but they DID demonstrate varying degrees of brush-bounce that often faded to acceptable levels after the first 20 hours or so of operation. For a time, brand new alternators were being pulled off engines to be 'broke in' on a test stand before being re-installed. A poorly understood work-around for what was a fundamental design flaw in the regulator. The whole legacy family of gear-driven alternators for Continental engines have been the subject of numerous 'investigations' . . . to this very day . . . in spite of the fact that the car-builders put those issues to bed three or four decades ago. Such is the plight of consumers deprived of choices outside the bounds of the cookie-cutter TC airplane business. Given what I DO KNOW about that family of alternators and what I DO NOT know about the VPX OV sense and response philosophy, it may well be that your symptoms have root cause in conditions not unlike those I've described earlier in this thread. The problem may have nothing to do with the LR3 and everything to do with a discontinuity in assembly of simple-ideas that govern performance. >I"m just wondering if anyone has run into anything similar with >these alternators before I pull it ship it out. I have seen NO requirements that quantify, put limits on or offer diagnosis tools for the detection of brush bounce in airplane alternators. I've never been able to measure it on the test bench . . . the only way I could strengthen the hypothesis that it existed was to add a filter to the field terminals of the alternator and demonstrating that the problem went away. The filter only protected the poorly designed ov sense system from a noise that was common to and present in most alternators as a matter of simple physics . . . noise so small that it was difficult to detect amongst the other noises (All well within MIL-STD-704 recommendations). Just for grins, we could craft a little filter assembly to jury-rig to the back of your alternator. This experiment is not without risk of the various participants 'relaxing' because your particular manifestation went away. If brush noise is indeed root to your symptoms, it's indication of a fundamental design deficiency in the ov sense system . . . NOT THE ALTERNATOR. Bob . . . ________________________________________________________________________________
Date: Jun 27, 2015
At 10:06 AM 6/27/2015, you wrote: Instead of impossible, I'd venture 'incredibly unlikely'. As in more probable that I'll be hit by lightning before I send this. However I can envision a scenario where a stray bit of internal debris shorts some alternator output over to the field coil. Even less likely here where the situation appears to be intermittent. The question was asked but since it is not even worth consideration at this point, I'm going to add Actually, Mooney experienced just such an event back about 1980. I recall peering into the teardown of an alternator that should have got some combination of craftsmen and inspectors fired. So it's not totally outside the realm of possibility. But yes . . . in this ISO9000 world of 'perfection' it should be exceedingly remote. I wish I could remember the name of the engineer I interacted with at Mooney. A solidly grounded, common sense fellow with an airs of personality that put a lot of people off. He had a small, red, rubber coated steel mallet on which he inscribed the non de plume, "PATIENCE". I never witness it personally, but he was renowned for expressing occasional bouts of frustration by abusing the corner of his desk with "Patience". Indeed, there were markings in the finish that attested to his vice. He proved to be one of my most valuable collaborators over those years. On numerous occasions since, I have wondered if there would be value in acquiring a "Son of Patience". On further reflection, pounding on a conference room table with a red hammer these days would probably get me a visit from a host of stern faced folks 'concerned' about my ability to integrate in the modern culture. Bob . . . ________________________________________________________________________________
Date: Jun 27, 2015
At 11:04 AM 6/27/2015, you wrote: >Hi Bob > >Have you considered using the Red Pitaya as a >base for signal gathering? It's an open source >DAQ that already has a lot of the hard work >done. It's not dirt cheap ($320) but may offer a >quick route to a portable, rentable or EAA >chapter own-able device that would fit the bill. > >Check out <http://www.redpitaya.com>www.redpitaya.com=C2 > >Thanks >Etienne To be sure, you've discovered one of a host of potential possibilities. My current thoughts are based on a VERY low cost DAS device I mentioned here on the List a few days ago. http://tinyurl.com/nvduk9x For what ever it may lack in capability, you sure can't argue about the price . . . especially since it comes with a capable graphical user interface and writes data to tabular files for analysis with other tools. I'm thinking of dropping this device onto a 'mother board' fitted with, what we'll have to deduce, a useful collection of signal conditioners for voltage, current, pressure, temperatures, etc. Theres a REALLY handy current transducer with great accuracy and frequency response http://tinyurl.com/p9fk8po The 6A version is easily adapted to sense currents from hundreds of milliamps to hundreds of amps. Voltage signal conditioning is easy. Temperature is easy in the realm of solid state tranducers up to 100C, but a channel of K thermocouple data would probably be good too. Pressure 4-20 mA pressure transducers are COTS items. I've got $hundreds$ in DAS equipment on the shelf that I've used to great advantage in the TC world . . . but too complex to install/operate/ resolve in the OBAM world. This is an exercise in extracting lab grade data from a KISS box. Need to make this so $low$ and simple that fewer folk in the OBAM market are put off by the expense risk and willing to try it for themselves. This is the rolling-stock-consist for a train of ideas in the current pot of idea-stew. I'm 'seeing' a board about 2.5 x 3.5 inches that would mount the pic-stick and 5-8 channels of signal conditioning for a BOM cost on the order of $50-60. Bob . . . ________________________________________________________________________________
Date: Jun 27, 2015
nuckolls.bob(at)aeroelect wrote: > > In the great spaghetti-mix that is aviation > accessories, marketing and business models, > it's difficult to keep track of who's alternator > is being built by whom and with what, if any, > improvements. All I can say with certainty is that the P/N of the alternator is 646843. According to what I've been able to determine it's a TCM 60a alternator. I was told that line of business was sold to Kelly Aerospace. > The alternators involved in the three-decade saga of new airplane OV trips were the occasionally-unfair targets of accusatory assertions . . . but they DID demonstrate varying degrees of brush-bounce that often faded to acceptable levels after the first 20 hours or so of operation. You just went over my head with "brush-bounce". :( > Given what I DO KNOW about that family of alternators and what I DO NOT know about the VPX OV sense and response philosophy, it may well be that your symptoms have root cause in conditions not unlike those I've described earlier in this thread. The problem may have nothing to do with the LR3 and everything to do with a discontinuity in assembly of simple-ideas that govern performance. If this means that it's possible that I did something wrong putting this system together, there is absolutely no doubt about that! :) If so, can you give me some idea of where I may have a disconnection in the "discontinuity in assembly of simple-ideas that govern performance" > Just for grins, we could craft a little filter assembly to jury-rig to the back of your alternator. This experiment is not without risk of the various participants 'relaxing' because your particular manifestation went away. If brush noise is indeed root to your symptoms, it's indication of a fundamental design deficiency in the ov sense system . . . NOT THE ALTERNATOR. I'm all for grins! Can you give me an idea where to get or how to build this filter? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=444101#444101 ________________________________________________________________________________
Date: Jun 27, 2015
Directions for making a filter: http://www.sanantoniohams.org/tips/whine.htm > You just went over my head with "brush-bounce". Alternators have bushes that ride on slip rings. If the rings are not concentric, the brushes will move up and down in their holders. > can you give me some idea of where I may have a disconnection in the "discontinuity in assembly of simple-ideas that govern performance I get the impression that Bob is inferring that he does not trust the VP-X. I suggest that instead of pulling the alternator, that you replace the voltage regulator with a generic Ford VR166 or equivalent. There is a list in Bob's book. The over-voltage and low voltage features of the LR3 are not needed in your application if the VP-X provides over-voltage and the EFIS gives low voltage warning. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=444104#444104 ________________________________________________________________________________
From: Verso Electronics <versoelectric(at)GMAIL.COM>
Date: Jun 27, 2015
On Jun 27, 2015, at 4:40 PM, "user9253" wrote: > The over-voltage and low voltage features of the LR3 are not needed in your application if the VP-X provides over-voltage and the EFIS gives low voltage warning. Does the VP-X initiate a crowbar in the presence of over-voltage, or simply report it through alarm output? Eric ________________________________________________________________________________
Date: Jun 27, 2015
Bob, In our '70's Cardinals, Cessna installed an electrolytic capacitor across the OV unit to minimize such trips... Paul ________________________________________________________________________________
Subject: Re: User name
Date: Jun 28, 2015
If you're posting a message... doesn't that mean you're logged in? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=444122#444122 ________________________________________________________________________________
Date: Jun 28, 2015
> >You just went over my head with "brush-bounce". :( The term "bounce" is probably inappropriate . . . "discontinuity" is probably a better description. Brush bounce is a real phenomenon usually promoted by out-of-round slip rings or gross contamination of the surface. An artfully crafted slip ring receives final finish with the armature shaft captured between centers and cut with a diamond tipped tool with cutting depth and rates so tiny that the finish is mirror smooth. Now, press a chunk of carbon to that surface while it romps along at 200 inches per second . . . and that 'smoothness' can take on a new character as tiny bits of material transfers from the brush to the slip-ring. Over time measured in hours, a 'film' is formed on the copper. The charcater and rate of deposition is a function of current magnitude and direction in the brush, moisture, brush material makeup, pressure, and probably a few other things the sub-microscopic/ molecular level. See: http://tinyurl.com/q9q62eb It ALWAYS happens and is built into the nature of machines with brushes. Problems can manifest when some feature of associated electronics is sensitive to the discontinuity. The 30 year arm wrestling match with the TC regulator has roots in just such a sensitivity >I'm all for grins! Can you give me an idea where to get or how to >build this filter? What is the center-to-center distance for the F1 to F2 terminals on your alternator? I crafted a filter to conduct some experiments on the problem aircraft that seemed to 'fix' the problem . . . more appropriately 'mask' the problem. It didn't fix the design descrepancy in the regulator . . . only broke the propagation mode between the antagonist (perfectly normal brush behavior) and the victim (an uber-sensitive OV sense mechanism). As a quick, interim experiment, try connecdting a high quality, 1 uF capacitor from F1 to F2 on your alternator. NOT an electrolytic but a some form of metal-film device. I've got a few hundred laying around . . . can send you one of those right away. Bob . . . ________________________________________________________________________________
Subject: Audio Noise
Date: Jun 28, 2015
Below is a quote from a RV-12 builder in Australia, as posted on VansAirforce: > I've had a constant `bzzt....bzzt...bzzt' sound in my headset repeated at exactly one second intervals. Both pilot and co-pilot sides were affected. The sound level stayed constant despite adjusting the intercom squelch and volume knobs, and was unaffected by the transponder, radio, autopilot or lights. At first I thought the sounds were related to the flashing warning signs on the Dynon, but later realised they were exactly timed to the digital clock on the display. The noise would start as soon as the boot sequence got to `starting network manager'. If I unplugged the GPS antenna from the AV5000 module so that the system couldn't pick up the time signal from the satellites, the clock would not appear and neither would the noise. Dynon initially thought it might be related to the transponder, but neither disconnecting the transponder, the EMS, or anything else seemed to make any difference. If the clock was active, so was the noise. The only way to get rid of it was to disconnect the GPS antenna, which wasn't really a good solution. However, flying with the noise wasn't an option either as it was as irritating as a dripping tap. > However, I got lucky this afternoon when a local electronics guru happened to be at the field. He spent a couple of hours trouble-shooting the system, checking the Skyview settings, the radio, tracing the wiring diagram, pulling pins, etc, until he eventually discovered that the noise was apparently being generated by interference between the music jack wires and the tunnel harness, which runs to the ADAHRS mounted in the tail cone. When the GPS antenna was connected, it appears that EMF generated in the network cable was being fed into the audio wires that run close to the cable in the tunnel, and was therefore audible in the headsets. Disconnecting the two audio wires fixed the problem. It was a simple solution, but tracking down the cause has been a very frustrating exercise. Glad it's been fixed now. The length of the shared wire harness is five feet. We will never know the true cause. But is it more likely that the audio interference was due to the proximity of wires, or due to the fact that the stereo music input jack was grounded locally to the airframe (without isolating washers) instead of having a dedicated ground wire running back to the instrument panel ground? Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=444125#444125 ________________________________________________________________________________
Date: Jun 28, 2015
At 06:40 PM 6/27/2015, you wrote: Directions for making a filter: http://www.sanantoniohams.org/tips/whine.htm > You just went over my head with "brush-bounce". Alternators have bushes that ride on slip rings. If the rings are not concentric, the brushes will move up and down in their holders. . . . and under some conditions, experience periodic disconnections from the slip ring . . . Which is probably not the phenomenon were working with here . . . as described in my recent post, the discontinuity of interest may have more to with quality of brush-track than from mechanical imperfections in surface or concentricity . . . but in any case SHOULD NOT be a component of root cause for OV trips in a well design OV sense system. By the way, it's been a persistent notion in some circles for decades that 'automotive' hardware with brushes are ill-suited to use on aircraft due to effects of altitude leading to mis-interpreted assumptions that atmospheric pressure has a profound effect on brush performance. As pointed out in the the article I cited earlier, MOISTURE is a high-influence predictor of brush performance . . . and failure to perform at altitude has a lot to do with humidity and nearly nothing to do with altitude. "Altitude rated" brushes are really "low humidity rated" devices with chemistry added to the brush-makeup that compensates for reduced atmospheric moisture at altitude. But even those effects are much more pronounced on high current density brushes that ride on commutators as opposed to 3A max, 1A normal loads on alternator slip-rings. The collective experience of both TC and OBAM aviation communities have demonstrated that altitude effects are VERY low on the totem-pole of stresses that raise risk. > can you give me some idea of where I may have a disconnection in the "discontinuity in assembly of simple-ideas that govern performance I get the impression that Bob is inferring that he does not trust the VP-X. Didn't say that. What I'm saying is that I do not have enough information about the VP-X OV protection philosophy to discount the possibility that NORMAL alternator-noises are participating in nuisance trips. I suggest that instead of pulling the alternator, that you replace the voltage regulator with a generic Ford VR166 or equivalent. There is a list in Bob's book. The over-voltage and low voltage features of the LR3 are not needed in your application if the VP-X provides over-voltage and the EFIS gives low voltage warning. An excellent experiment. If the VR-166 style regulators are presently fitted with OV protection, it's performance benchmarks are certainly going to be different than an LR3. If the nuisance trips go away with THAT regulator, then there is reason to investigate the LR-3 more closely. If they continue, then the difficulty will be have root cause in features found elsewhere. Bob . . . ________________________________________________________________________________
Date: Jun 28, 2015
> I suggest that instead of pulling the alternator, that you replace the voltage regulator with a generic Ford VR166 or equivalent. There is a list in Bob's book. The over-voltage and low voltage features of the LR3 are not needed in your application if the VP-X provides over-voltage and the EFIS gives low voltage warning. > > An excellent experiment. If the VR-166 style > regulators are presently fitted with OV protection, > it's performance benchmarks are certainly going > to be different than an LR3. If the nuisance > trips go away with THAT regulator, then there > is reason to investigate the LR-3 more closely. > If they continue, then the difficulty will be > have root cause in features found elsewhere. I thought that voltage regulators were voltage specific? Are these generic VR's available in 28v versions? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=444130#444130 ________________________________________________________________________________
Date: Jun 28, 2015
>I thought that voltage regulators were voltage specific? Are these >generic VR's available in 28v versions? OOPS! You caught us with our perceptions down . . . yes, the VR166 is 14v only. Scratch that idea. Bob . . . ________________________________________________________________________________
Date: Jun 28, 2015
> I thought that voltage regulators were voltage specific? Are these generic VR's available in 28v versions? Oops, my mistake. I forgot about the 28 volt system. I do not know of any generic 28 volt regulators. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=444134#444134 ________________________________________________________________________________
Date: Jun 28, 2015
Subject: Re: Audio Noise
On 6/28/2015 12:24 PM, user9253 wrote: > > Below is a quote from a RV-12 builder in Australia, as posted on VansAirforce: > >> I've had a constant `bzzt....bzzt...bzzt' sound in my headset repeated at exactly one second intervals. Both pilot and co-pilot sides were affected. The sound level stayed constant despite adjusting the intercom squelch and volume knobs, and was unaffected by the transponder, radio, autopilot or lights. At first I thought the sounds were related to the flashing warning signs on the Dynon, but later realised they were exactly timed to the digital clock on the display. The noise would start as soon as the boot sequence got to `starting network manager'. If I unplugged the GPS antenna from the AV5000 module so that the system couldn't pick up the time signal from the satellites, the clock would not appear and neither would the noise. Dynon initially thought it might be related to the transponder, but neither disconnecting the transponder, the EMS, or anything else seemed to make any difference. If the clock was active, so was the noise. The only way to get rid of it was to di! > sconnect the GPS antenna, which wasn't really a good solution. However, flying with the noise wasn't an option either as it was as irritating as a dripping tap. >> However, I got lucky this afternoon when a local electronics guru happened to be at the field. He spent a couple of hours trouble-shooting the system, checking the Skyview settings, the radio, tracing the wiring diagram, pulling pins, etc, until he eventually discovered that the noise was apparently being generated by interference between the music jack wires and the tunnel harness, which runs to the ADAHRS mounted in the tail cone. When the GPS antenna was connected, it appears that EMF generated in the network cable was being fed into the audio wires that run close to the cable in the tunnel, and was therefore audible in the headsets. Disconnecting the two audio wires fixed the problem. It was a simple solution, but tracking down the cause has been a very frustrating exercise. Glad it's been fixed now. > The length of the shared wire harness is five feet. We will never know the true cause. But is it more likely that the audio interference was due to the proximity of wires, or due to the fact that the stereo music input jack was grounded locally to the airframe (without isolating washers) instead of having a dedicated ground wire running back to the instrument panel ground? > Joe > > -------- > Joe Gores For noise problems, I always look at ground issues first. In my opinion, he needs to fix the ground issue whether that particular problem was caused by it or not. And if that jack was grounded, then there may be others that have similar issues..... Charlie ________________________________________________________________________________
Date: Jun 28, 2015
On 6/28/2015 3:34 PM, user9253 wrote: > > >> I thought that voltage regulators were voltage specific? Are these generic VR's available in 28v versions? > Oops, my mistake. I forgot about the 28 volt system. I do not know of any generic 28 volt regulators. > > -------- > Joe Gores They are out there; just not so easy to find. 1st hit I got: http://www.ebay.com/itm/NEW-24-VOLT-POSITIVE-OR-NEGITIVE-GROUND-REGULATOR-D2152-FARM-INDUSTRIAL-/151618159386 ________________________________________________________________________________
Subject: Z-11 Diagram and E-bus feeder length
Date: Jun 28, 2015
Z-11 has a note of 6" max write length to the diode and again to the E-bus. Is this purely a function of the particular write size sunken (16 ga) or is there and underlying reason to keep this run short? Tia, Gary -------- Gary Read this topic online here: http://forums.matronics.com/viewtopic.php?p=444142#444142 ________________________________________________________________________________
Date: Jun 28, 2015
Subject: Re: Z-11 Diagram and E-bus feeder length
At 06:37 PM 6/28/2015, you wrote: > >Z-11 has a note of 6" max write length to the diode and again to the >E-bus. Is this purely a function of the particular write size sunken >(16 ga) or is there and underlying reason to keep this run short? This is a legacy hand-me-down rule-of-thumb that goes back a few years . . . at least 50 that I know about. The GENERAL RULE for protection of wires is defined in AC43-12 and the FARS. But . . . suppose you wanted to feed some device in very close proximity to the high current feeder. The rule of thumb (which I don't recall having ever been articulated in regulation) was any wire of 6" or less that can be 'burned' without putting the airframe and passengers at risk, does not need to be protected (meaning fuse, circuit breaker, fusible link, etc.). The first time I recall this r-o-t being exercised was in the wiring of a fat electrolytic capacitor to the bus (ostensibly for spike/noise/gremlim protection) and later for the wiring of a 50W zener to the bus for the same purpose. In retrospect, I am amazed at the thrashing and agonizing brought on by worries about spikes, noises and things that go "bump in the night" when in fact, DO-160/MIL-STD-704 suggestions applied with understanding made all those concerns evaporate. So you will find SOME wires on my drawings marked with an (*) wherein no protection is shown upstream of the potential fault path for burning the wire. In some places I use the symbol (*) to suggest that the devices so connected should be in close proximity to each other. So the rationale behind the symbol may not be immediately obvious . . . but there is one. Bob . . . ________________________________________________________________________________
Date: Jun 28, 2015
>For noise problems, I always look at ground issues first. In my >opinion, he needs to fix the ground issue whether that particular >problem was caused by it or not. And if that jack was grounded, then >there may be others that have similar issues..... > >Charlie Yes . . . this is excellent advice on airframes where no particular philosophy for grounding has been adopted BEFORE wires were strung. Over the years, places like Beech, Cessna, et. als. developed design and process specs for the construction of new systems in their products. Noise issues were rare because lessons learned (some of them painful and expensive) were core knowledge for development of those specs. To be sure, the first question to be explored on discovery of any noise problem in an OBAM aircraft is, "What does your ground system architecture look like?" Bob . . . ________________________________________________________________________________
Date: Jun 28, 2015
24 volt Voltage regulator, eBay item number:151689173831, is only $10. Has anyone ever tried to adapt an internal voltage regulator for external use? Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=444149#444149 ________________________________________________________________________________
Date: Jun 28, 2015
On 6/28/2015 9:42 PM, user9253 wrote: > > 24 volt Voltage regulator, eBay item number:151689173831, is only $10. Has anyone ever tried to adapt an internal voltage regulator for external use? > Joe > > -------- > Joe Gores I wondered about that, as well. Shouldn't be too big a deal for someone handy with a soldering iron. Charlie ________________________________________________________________________________
Date: Jun 29, 2015
I converted a Denso alternator to external using the instructions published on the EAA site. It is not difficult, but takes a bit of time. Roger Sent from: YOGA TABLET 10 HD+ Charlie England wrote: > >On 6/28/2015 9:42 PM, user9253 wrote: >> >> 24 volt Voltage regulator, eBay item number:151689173831, is only $10. Has anyone ever tried to adapt an internal voltage regulator for external use? >> Joe >> >> -------- >> Joe Gores >I wondered about that, as well. Shouldn't be too big a deal for someone >handy with a soldering iron. > >Charlie > > ________________________________________________________________________________
Date: Jun 29, 2015
In rereading the posts, It appears that the conversation was referring to removing an internal regulator and using it externally. I don't know of anyone doing this. Roger Sent from: YOGA TABLET 10 HD+ rnjcurtis wrote: I converted a Denso alternator to external using the instructions published on the EAA site. It is not difficult, but takes a bit of time. Roger ________________________________________________________________________________
Date: Jun 29, 2015
I think Joe is referring to actually using the regulator that's made for internal regulation as an external regulator. A bit more involved than adapting an external regulator to a '1-wire' alternator (but not a lot more). Charlie On Mon, Jun 29, 2015 at 7:04 AM, rnjcurtis wrote: > > I converted a Denso alternator to external using the instructions > published on the EAA site. It is not difficult, but takes a bit of time. > > Roger > > > Sent from: YOGA TABLET 10 HD+ > > Charlie England wrote: > > ceengland7(at)gmail.com> > > > >On 6/28/2015 9:42 PM, user9253 wrote: > >> > >> 24 volt Voltage regulator, eBay item number:151689173831, is only $10. > Has anyone ever tried to adapt an internal voltage regulator for external > use? > >> Joe > >> > >> -------- > >> Joe Gores > >I wondered about that, as well. Shouldn't be too big a deal for someone > >handy with a soldering iron. > > > >Charlie > > > > > > > > > > ________________________________________________________________________________
Date: Jun 29, 2015
I appreciate the suggestions. But I'm not sure if trying to MacGuyver a voltage regulator is good way to troubleshoot my current issue. [Laughing] Vertical Power has offered to bench check the VP-X but removing it won't be the easiest thing and I'm looking at a 10-day turnaround. So buying a new LR3C-28 at $198 may be a relatively easy and timely (although not very cost effective) step. If it turns out not to be the VR, I guess I'll have a spare. At that point, it would most likely be the VP-X and then I could send that out. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=444161#444161 ________________________________________________________________________________
Subject: Re:_AeroElectric-List:_Re:_Alternator_problem=3F?
Date: Jun 29, 2015
DQoNCg0KDQoNCg0KDQoNCg0KSSB0aGluayBKb2UgaXMgcmVmZXJyaW5nIHRvIGFjdHVhbGx5IHVz aW5nIHRoZSByZWd1bGF0b3IgdGhhdCdzIG1hZGUgZm9yIGludGVybmFsIHJlZ3VsYXRpb24gYXMg YW4gZXh0ZXJuYWwgcmVndWxhdG9yLiBBIGJpdCBtb3JlIGludm9sdmVkIHRoYW4gYWRhcHRpbmcg YW4gZXh0ZXJuYWwgcmVndWxhdG9yIHRvIGEgJzEtd2lyZScgYWx0ZXJuYXRvciAoYnV0IG5vdCBh IGxvdCBtb3JlKS4NCg0KDQoNCg0KDQpJbiBkb2luZyB0aGlzLCB3b3VsZG7igJl0IG9uZSBiZSBq dXN0IG1vdmluZyB0aGUgcHJvYmxlbXMgdGhhdCBoYXZlIGJlZW4gZGlzY3Vzc2VkIGluIGdyZWF0 IGRldGFpbCwgb2Ygd2h5IHdlIHNob3VsZCBub3QgdXNlIGludGVybmFsbHkgcmVndWxhdGVkIGFs dGVybmF0b3JzLiAgVGhlIGludGVybmFsIHJlZ3VsYXRvcnMgZG8gbm90IHJlYWN0IGtpbmRseSB0 byB0dXJuaW5nIHRoZSBhbHRlcm5hdG9yIG9uIGFuZCBvZmYuDQoNCg0KDQpSb2dlcg= ________________________________________________________________________________
Date: Jun 29, 2015
At 07:31 AM 6/29/2015, you wrote: > >In rereading the posts, It appears that the conversation was >referring to removing an internal regulator and using it >externally. I don't know of anyone doing this. There was an article, I think in Sport Aviation some years ago about making electrical connections to a dis-mounted replacement for an I-R alternator regulator for use as a stand-alone external regulator. A straight-forward task . . . sometimes. Some internal regulators utilize and AC voltage sense path connected to on of the windings. Without specific knowledge of this feature, the activity is problematic. The article spoke to a particular OEM part that was not so equipped . . . finding one in 28v and knowing it's pedigree would be difficult. Bob . . . ________________________________________________________________________________
Date: Jun 29, 2015
At 07:45 AM 6/29/2015, you wrote: > >I appreciate the suggestions. But I'm not sure if trying to >MacGuyver a voltage regulator is good way to troubleshoot my current >issue. [Laughing] > >Vertical Power has offered to bench check the VP-X but removing it >won't be the easiest thing and I'm looking at a 10-day turnaround. > >So buying a new LR3C-28 at $198 may be a relatively easy and timely >(although not very cost effective) step. If it turns out not to be >the VR, I guess I'll have a spare. > >At that point, it would most likely be the VP-X and then I could >send that out. It's all most a given that both the LR3 and the VPX will bench check okay . . . as would the alternator. Everything is probably performing as their designers intended. Let's do the filter thingy first. Need a mailing address. Bob . . . ________________________________________________________________________________
Date: Jun 29, 2015
Bob, I couldn't figure out how to do a private message here. So I sent you an email yesterday with my mailing address. -Don Read this topic online here: http://forums.matronics.com/viewtopic.php?p=444170#444170 ________________________________________________________________________________
Date: Jun 29, 2015
I had the exact problem. The sound was caused by an unshelled RS-232 output of my GPS that was putting out NMEA sentences every one second. It was being picked up by a nearby unconnected music input to my audio panel. Grounded the audio input and all was fine. John Snapp +1.303.810.0600 (sent from iPhone) > On Jun 28, 2015, at 11:24 AM, user9253 wrote: > > > Below is a quote from a RV-12 builder in Australia, as posted on VansAirforce: > >> I've had a constant `bzzt....bzzt...bzzt' sound in my headset repeated at exactly one second intervals. Both pilot and co-pilot sides were affected. The sound level stayed constant despite adjusting the intercom squelch and volume knobs, and was unaffected by the transponder, radio, autopilot or lights. At first I thought the sounds were related to the flashing warning signs on the Dynon, but later realised they were exactly timed to the digital clock on the display. The noise would start as soon as the boot sequence got to `starting network manager'. If I unplugged the GPS antenna from the AV5000 module so that the system couldn't pick up the time signal from the satellites, the clock would not appear and neither would the noise. Dynon initially thought it might be related to the transponder, but neither disconnecting the transponder, the EMS, or anything else seemed to make any difference. If the clock was active, so was the noise. The only way to get rid of it was to di! > sconnect the GPS antenna, which wasn't really a good solution. However, flying with the noise wasn't an option either as it was as irritating as a dripping tap. >> However, I got lucky this afternoon when a local electronics guru happened to be at the field. He spent a couple of hours trouble-shooting the system, checking the Skyview settings, the radio, tracing the wiring diagram, pulling pins, etc, until he eventually discovered that the noise was apparently being generated by interference between the music jack wires and the tunnel harness, which runs to the ADAHRS mounted in the tail cone. When the GPS antenna was connected, it appears that EMF generated in the network cable was being fed into the audio wires that run close to the cable in the tunnel, and was therefore audible in the headsets. Disconnecting the two audio wires fixed the problem. It was a simple solution, but tracking down the cause has been a very frustrating exercise. Glad it's been fixed now. > > The length of the shared wire harness is five feet. We will never know the true cause. But is it more likely that the audio interference was due to the proximity of wires, or due to the fact that the stereo music input jack was grounded locally to the airframe (without isolating washers) instead of having a dedicated ground wire running back to the instrument panel ground? > Joe > > -------- > Joe Gores > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=444125#444125 > > > > > > > > > > ________________________________________________________________________________
Subject: Ground loop proves to be mighty painful!
Date: Jun 29, 2015
Hi group I never thought much about it before today, but I found out ground loop can be mighty painful! I have done a fair share amount of TIG welding over the years. I have done a fair amount of milling 304 Stainless steel as well. No matter how careful with Stainless milling, once in a while you end up getting a microscopic splinter. I have pretty good close up vision and sometimes have a hard time even with magnifier. I never did a little milled, do a little TIGing, mill, TIG etc. many times before. Well, today a few times I had a microscopic splinter in my left wire feed hand that managed to touch the welding rod with my elbow resting on the aluminium welding table: "WOW"! I guess the splinter however small was more connected to my biological saline solution. That minute amount of electron flow really got my attention. To add insult to injury, I couldn't find the darn splinter one time by sight. It took three iterations of using ground loop to find it! As far as ground loops go: I'll take a little static listening to the radio anytime over TIG splinters ;-) Ron Parigoris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=444177#444177 ________________________________________________________________________________
Date: Jun 29, 2015
Cheap troubleshooting by substitution (only), as implied by the previous suggestion of using a COTS Ford regulator to substitute for the existing unit (not possible due to existing unit being 28v instead of 14v). Turning alternators on/off is a completely different issue, and begs the question: Why? On Mon, Jun 29, 2015 at 7:47 AM, wrote: > > > I think Joe is referring to actually using the regulator that's made for > internal regulation as an external regulator. A bit more involved than > adapting an external regulator to a '1-wire' alternator (but not a lot > more). > > In doing this, wouldn=99t one be just moving the problems that have been > discussed in great detail, of why we should not use internally regulated > alternators. The internal regulators do not react kindly to turning the > alternator on and off. > > Roger > > ________________________________________________________________________________
Date: Jun 29, 2015
Subject: Re: Ground loop proves to be mighty painful!
Ron thats funny! On Monday, June 29, 2015, rparigoris wrote: > rparigor(at)suffolk.lib.ny.us > > > Hi group > > I never thought much about it before today, but I found out ground loop > can be mighty painful! > > I have done a fair share amount of TIG welding over the years. I have done > a fair amount of milling 304 Stainless steel as well. No matter how careful > with Stainless milling, once in a while you end up getting a microscopic > splinter. I have pretty good close up vision and sometimes have a hard time > even with magnifier. > > I never did a little milled, do a little TIGing, mill, TIG etc. many times > before. > > Well, today a few times I had a microscopic splinter in my left wire feed > hand that managed to touch the welding rod with my elbow resting on the > aluminium welding table: "WOW"! I guess the splinter however small was more > connected to my biological saline solution. > > That minute amount of electron flow really got my attention. To add insult > to injury, I couldn't find the darn splinter one time by sight. It took > three iterations of using ground loop to find it! > > As far as ground loops go: I'll take a little static listening to the > radio anytime over TIG splinters ;-) > > Ron Parigoris > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=444177#444177 > > -- Best... Bob Verwey ________________________________________________________________________________
Date: Jun 30, 2015
>In doing this, wouldn=99t one be just moving the >problems that have been discussed in great >detail, of why we should not use internally >regulated alternators.=C2 The internal regulators >do not react kindly to turning the alternator on and off. It's not a matter of 'not taking kindly' . . . its the conditions surrounding a failure modes. Off the shelf, internally regulated alternators have a runaway failure mode wherein the alternator CANNOT be shut off from outside. This is why some folks remove the built in regulator (B&C) and others wire around the regulator (Plane-Power) to effect positive external control of field excitation for the purpose of turning it ON or OFF at will, or shutting it down if the regulator goes TU. A myth commonly circulated throughout the vehicular DC power systems world is that it is undesirable, dangerous, deleterious, or (as has been articulated here on the List) just plain stupid to turn an operating alternator ON and OFF at will. It's a well circulated, overly fertilized myth easily demonstrated to be horse-pucky. The desirability for and effects of random or purposeful control of an alternator at will are completely benign to the alternator and equipment it powers. But if the regulator wanders into the weeds, you gotta have a method to turn the thing OFF (or disconnect it from the airplane) in a timely fashion while minimizing smoke and flames. Bob . . . ________________________________________________________________________________
Subject: Diode Reverse Voltage Leak or Invalid Measurement Setup?
Date: Jul 04, 2015
Hello, We're getting set to do power on testing of our electrical system and avionics. We're using the (Bob's) Z-12 power grid at 28 VDC with a 12 VDC bus and 12VDC hot battery bus. We have schottkey diodes isolating the various buses. With the positive battery terminal connected and the 12 VDC hot battery lead connected, but NOT the battery ground to the single point ground, I checked the voltage at various points and saw the 12+ VDC where it should be but was surprised to measure about 3.5 VDC on the Main Bus and even the Ground Bus. The meter set up was with the VOM meter ground lead to the battery ground (not connected to the airplane's ground bus) and then the positive prove to the various measurement locations. At first I thought we must have a pin out wrong in a connector somewhere - and maybe we do. After some trouble shooting, I was able to determine that the voltage seems to be leaking in reverse past the diode from the 12 VDC Hot Batt Bus to the 12VDC Bus and then through the 24 to 12 VDC converter to the Main Bus. But somehow, when I put the meter's positive probe on the ground bus, it also shows 3.5 VDC. So not even sure this is a valid way to test that I'm using. Here's our Power Grid. Sorry Bob that it is in my pictogram format. The anode side of Diode B is where I'm seeing 3.5 VDC with 12VDC on the cathode side, as expected, coming from the hot battery bus. I did a test of a spare diode of the same model on the bench with a single 12 VDC battery and measure 4.9 VDC on the anode side of the diode with the cathode connected to the battery's positive terminal. See photo below. My questions. 1. Is this even a valid voltage measurement setup? Is this real? If both the positive and negative side of the electrical system are showing 3.5 VDC relative to the unattached battery ground, then there is no electrical potential difference/voltage between them. 2. Are these the wrong diodes for this application? (spec sheet attached) 3. What should I do? I'd sure appreciate some help with this. Oh, and Happy Independence Day! Thanks! Valin (Confused) ________________________________________________________________________________
Date: Jul 04, 2015
Subject: Re: Diode Reverse Voltage Leak or Invalid Measurement
Setup?
Not really relevant to your question, but the spec sheet has the wrong symbol for the diodes (zener instead of Schottky). In general, if you leave the ground side of a circuit floating and measure from the floating ground to the actual supply ground, you will see some voltage (in some cases, the full voltage of the supply). For your voltage test of the diode pack, try inserting a 12V load (light, etc) in series with the diode, connected from the diode anode (your red test lead point) to the battery ground terminal. Measure voltage on the same points shown in your pic. I'll bet that the load (light) won't illuminate, and you won't see any voltage. All semiconductors have some leakage, but won't supply significant current because the leakage is so low. Your spec sheet says IsubR is 2 mA at 45 volts, so would be much lower at 12 volts. My terminology probably isn't precise (I was a repair grunt; not an engineer), but hopefully the idea is still there. Charlie On Sat, Jul 4, 2015 at 2:03 PM, Valin Thorn wrote: > Hello, > > > We=99re getting set to do power on testing of our electrical system and > avionics. We=99re using the (Bob=99s) Z-12 power grid at 28 VDC with a 12 > VDC bus and 12VDC hot battery bus. > > > We have schottkey diodes isolating the various buses. > > > With the positive battery terminal connected and the 12 VDC hot battery > lead connected, but NOT the battery ground to the single point ground, I > checked the voltage at various points and saw the 12+ VDC where it should > be but was surprised to measure about 3.5 VDC on the Main Bus and even th e > Ground Bus. > > > The meter set up was with the VOM meter ground lead to the battery ground > (not connected to the airplane=99s ground bus) and then the positiv e prove to > the various measurement locations. > > > At first I thought we must have a pin out wrong in a connector somewhere =93 > and maybe we do. After some trouble shooting, I was able to determine > that the voltage seems to be leaking in reverse past the diode from the 1 2 > VDC Hot Batt Bus to the 12VDC Bus and then through the 24 to 12 VDC > converter to the Main Bus. But somehow, when I put the meter=99s p ositive > probe on the ground bus, it also shows 3.5 VDC. So not even sure this is > a valid way to test that I=99m using > > > Here=99s our Power Grid. Sorry Bob that it is in my pictogram form at The > anode side of Diode B is where I=99m seeing 3.5 VDC with 12VDC on t he cathode > side, as expected, coming from the hot battery bus. > > > I did a test of a spare diode of the same model on the bench with a singl e > 12 VDC battery and measure 4.9 VDC on the anode side of the diode with th e > cathode connected to the battery=99s positive terminal. See photo below. > > > My questions. > > > 1. Is this even a valid voltage measurement setup? Is this real? I f > both the positive and negative side of the electrical system are showing > 3.5 VDC relative to the unattached battery ground, then there is no > electrical potential difference/voltage between them > > 2. Are these the wrong diodes for this application? (spec sheet > attached) > > 3. What should I do? > > > I=99d sure appreciate some help with this Oh, and Happy I ndependence Day! > > > Thanks! > > > Valin > (Confused) > > ________________________________________________________________________________
Setup?
Date: Jul 04, 2015
Setup?
Date: Jul 05, 2015
This is the Schottky diode that I sell with an appropriate heat sink, and it's a great part. You could have contacted me, but this is a general interest anyway, so an answer helps everyone. All standard voltmeters have a built-in load. This is as it should be. If they did not, then nothing would make much sense. For special purposes, voltmeters can be built with arbitrarily high resistance (or a tiny load, called impedance in meters, etc.), but they all still have some load. All electronic parts, even relays and switches, have "leakage". Insulation can still be measured in ohms, no matter how good, (millions and billions of ohms...) So if you built a simple switch with nearly perfect insulation and applied a voltage to it, a voltmeter with infinite ohms resistance would still measure a voltage "through" the switch...whether or not the switch was on or off! That's why voltages are not measured through switches, relays, and any other parts. I note this in some of my literature, that a voltage measurement without a load will give meaningless results. A Schottky diode has a very low Vf forward voltage drop (lower than P-N diodes). This saves power, but the Schottky also has a greater reverse current "leakage". The reverse current typically won't leak enough power to light even the smallest LED, but some builders worry that this is a defect. It really isn't. It's just reality. For those who are mystified by electrons. Check the attached. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=444394#444394 Attachments: http://forums.matronics.com//files/dabbling_with_electricity_103.pdf ________________________________________________________________________________
Setup?
Date: Jul 05, 2015
Thanks Charlie and Eric! Very helpful. Though after reading your article, Eric, I'm even more uncertain of how electro-physics works. :) Valin From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Valin Thorn Sent: Saturday, July 04, 2015 1:03 PM Subject: AeroElectric-List: Diode Reverse Voltage Leak or Invalid Measurement Setup? Hello, We're getting set to do power on testing of our electrical system and avionics. We're using the (Bob's) Z-12 power grid at 28 VDC with a 12 VDC bus and 12VDC hot battery bus. We have schottkey diodes isolating the various buses. With the positive battery terminal connected and the 12 VDC hot battery lead connected, but NOT the battery ground to the single point ground, I checked the voltage at various points and saw the 12+ VDC where it should be but was surprised to measure about 3.5 VDC on the Main Bus and even the Ground Bus. The meter set up was with the VOM meter ground lead to the battery ground (not connected to the airplane's ground bus) and then the positive prove to the various measurement locations. At first I thought we must have a pin out wrong in a connector somewhere - and maybe we do. After some trouble shooting, I was able to determine that the voltage seems to be leaking in reverse past the diode from the 12 VDC Hot Batt Bus to the 12VDC Bus and then through the 24 to 12 VDC converter to the Main Bus. But somehow, when I put the meter's positive probe on the ground bus, it also shows 3.5 VDC. So not even sure this is a valid way to test that I'm using. Here's our Power Grid. Sorry Bob that it is in my pictogram format. The anode side of Diode B is where I'm seeing 3.5 VDC with 12VDC on the cathode side, as expected, coming from the hot battery bus. I did a test of a spare diode of the same model on the bench with a single 12 VDC battery and measure 4.9 VDC on the anode side of the diode with the cathode connected to the battery's positive terminal. See photo below. My questions. 1. Is this even a valid voltage measurement setup? Is this real? If both the positive and negative side of the electrical system are showing 3.5 VDC relative to the unattached battery ground, then there is no electrical potential difference/voltage between them. 2. Are these the wrong diodes for this application? (spec sheet attached) 3. What should I do? I'd sure appreciate some help with this. Oh, and Happy Independence Day! Thanks! Valin (Confused) ________________________________________________________________________________
Subject: SL-15 Unswitched Audio Connection
Date: Jul 09, 2015
I have a SL-15 Audio Selector Panel that has two "unswitched" audio connections. One is hooked up to my AOA warning. I would like to use the other for the audio of the Advanced Flight System 5600 EFIS I am installing. The SL-15 uses Molex 08-05-0301 connectors which are discontinued and I cannot find them anywhere. My three options seem to be: Find someone who has a connector I can purchase (failed so far but maybe one of you has an extra) Take out the connector that is in there for a speaker I am not using and use it. (Suggestions on how to remove the connector without buying the specified tool please) Hook the EFIS audio line with the AOA audio line which may not work at all if one is loading the wire all the time. Thanks so much, Ross Mickey N9PT ________________________________________________________________________________
Date: Jul 09, 2015
Subject: Re: SL-15 Unswitched Audio Connection
the Molex 08-05-0301 itself is not a connector but refers to the finger spring contacts. They are , I believe gold plated and indeed are not available. Newark lists the following substitutes. * _39X7518_ (http://www.newark.com/molex/08-50-0187/contact-socket-20-18awg-crimp/dp/39X7518) - Product Range:6838 Series; For Use With:KK 6442, 41695 Series Crimp Terminal Housings; Contact Gender:Socket; Contact Material:Brass; Contact Plating:Tin; Contact Termination Type:Crimp ;RoHS Compliant: Yes * _20H0074_ (http://www.newark.com/molex/08-50-0187/contact-socket-20-18awg-crimp/dp/20H0074) - Product Range:6838 Series; For Use With:KK 6442, 41695 Series Crimp Terminal Housings; Contact Gender:Socket; Contact Material:Brass; Contact Plating:Tin; Contact Termination Type:Crimp ;RoHS Compliant: Yes * _01E9145_ (http://www.newark.com/molex/08-55-0103/contact-female-24-18awg-crimp/dp/01E9145) - Product Range:KK Series; For Use With:KK Series Crimp Terminal Housings; Contact Gender:Socket; Contact Material:Brass; Contact Plating:Gold; Contact Termination Type:Crimp; Wire Size AWG Min:24AWG ;RoHS Compliant: Yes The connector body , itself is also available and are listed with the above. Since they are not gold plated (with the exception of the 01E9145, if the housing is not appropriate, I would use a slight smear of an anti oxidation grease on the connector. The connector body is readily available. If you look up the below numbers at digikey, I believe when you look at one of the selections, the bottom of the description will list what connector bodies are appropriate for that contact. You just have to do a little detective work. In a message dated 7/9/2015 11:02:34 A.M. Central Daylight Time, rossmickey(at)comcast.net writes: Molex 08-05-0301 ________________________________________________________________________________
Date: Jul 09, 2015
If I recall correctly, the SL-15 is equivalent to the PS Engineering PMA7000 series (I have one of those). I'll look to see if I have any additional/spare connectors as I wired mine. I recall they were on a metal tape and I simply cut off the ones I needed..... -----Original Message----- From: Ross Home Sent: Jul 9, 2015 11:59 AM Subject: AeroElectric-List: SL-15 Unswitched Audio Connection I have a SL-15 Audio Selector Panel that has two unswitched audio connections. One is hooked up to my AOA warning. I would like to use the other for the audio of the Advanced Flight System 5600 EFIS I am installing. The SL-15 uses Molex 08-05-0301 connectors which are discontinued and I cannot find them anywhere. My three options seem to be: Find someone who has a connector I can purchase (failed so far but maybe one of you has an extra) Take out the connector that is in there for a speaker I am not using and use it. (Suggestions on how to remove the connector without buying the specified tool please) Hook the EFIS audio line with the AOA audio line which may not work at all if one is loading the wire all the time. Thanks so much, Ross MickeyN9PT ________________________________________________________________________________
Date: Jul 09, 2015
Yes, that is the one. Thanks. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ralph E. Capen Sent: Thursday, July 09, 2015 9:49 AM Subject: Re: AeroElectric-List: SL-15 Unswitched Audio Connection --> If I recall correctly, the SL-15 is equivalent to the PS Engineering PMA7000 series (I have one of those). I'll look to see if I have any additional/spare connectors as I wired mine. I recall they were on a metal tape and I simply cut off the ones I needed..... -----Original Message----- From: Ross Home Sent: Jul 9, 2015 11:59 AM Subject: AeroElectric-List: SL-15 Unswitched Audio Connection I have a SL-15 Audio Selector Panel that has two unswitched audio connections. One is hooked up to my AOA warning. I would like to use the other for the audio of the Advanced Flight System 5600 EFIS I am installing. The SL-15 uses Molex 08-05-0301 connectors which are discontinued and I cannot find them anywhere. My three options seem to be: Find someone who has a connector I can purchase (failed so far but maybe one of you has an extra) Take out the connector that is in there for a speaker I am not using and use it. (Suggestions on how to remove the connector without buying the specified tool please) Hook the EFIS audio line with the AOA audio line which may not work at all if one is loading the wire all the time. Thanks so much, Ross MickeyN9PT ________________________________________________________________________________
Date: Jul 09, 2015
On 7/9/2015 10:59 AM, Ross Home wrote: > > I have a SL-15 Audio Selector Panel that has two unswitched audio > connections. One is hooked up to my AOA warning. I would like to use > the other for the audio of the Advanced Flight System 5600 EFIS I am > installing. The SL-15 uses Molex 08-05-0301 connectors which are > discontinued and I cannot find them anywhere. > > My three options seem to be: > > Find someone who has a connector I can purchase (failed so far but > maybe one of you has an extra) > > Take out the connector that is in there for a speaker I am not using > and use it. (Suggestions on how to remove the connector without > buying the specified tool please) > > Hook the EFIS audio line with the AOA audio line which may not work at > all if one is loading the wire all the time. > > Thanks so much, > > Ross Mickey > > N9PT > > Is this it? 08-05-0301 Molex Connector Corporation | WM6390CT-ND DigiKey Electronics If so, and I owned it, I'd solder wires to the edge connector to make a 'pigtail' connector using a dSub connector, with a strain relief to protect the wires. Those things are perfect examples of 'Aviation Quality'. If you have that spare that can be moved, there's usually a little tab on the back side that prevents it from backing out. If you have something thin and narrow enough, you should be able to slide it in from the 'front' (non-wire) end and push the tab away from it's mating lock point in the shell. Charlie ________________________________________________________________________________
Date: Jul 09, 2015
Yes, that is it. Thanks. From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Charlie England Sent: Thursday, July 09, 2015 11:16 AM Subject: Re: AeroElectric-List: SL-15 Unswitched Audio Connection On 7/9/2015 10:59 AM, Ross Home wrote: I have a SL-15 Audio Selector Panel that has two "unswitched" audio connections. One is hooked up to my AOA warning. I would like to use the other for the audio of the Advanced Flight System 5600 EFIS I am installing. The SL-15 uses Molex 08-05-0301 connectors which are discontinued and I cannot find them anywhere. My three options seem to be: Find someone who has a connector I can purchase (failed so far but maybe one of you has an extra) Take out the connector that is in there for a speaker I am not using and use it. (Suggestions on how to remove the connector without buying the specified tool please) Hook the EFIS audio line with the AOA audio line which may not work at all if one is loading the wire all the time. Thanks so much, Ross Mickey N9PT Is this it? If so, and I owned it, I'd solder wires to the edge connector to make a 'pigtail' connector using a dSub connector, with a strain relief to protect the wires. Those things are perfect examples of 'Aviation Quality'. If you have that spare that can be moved, there's usually a little tab on the back side that prevents it from backing out. If you have something thin and narrow enough, you should be able to slide it in from the 'front' (non-wire) end and push the tab away from it's mating lock point in the shell. Charlie ________________________________________________________________________________
Date: Jul 09, 2015
Date: Jul 12, 2015
At 10:59 AM 7/9/2015, you wrote: >I have a SL-15 Audio Selector Panel that has two "unswitched" audio >connections. One is hooked up to my AOA warning. I would like to >use the other for the audio of the Advanced Flight System 5600 EFIS >I am installing. The SL-15 uses Molex 08-05-0301 connectors which >are discontinued and I cannot find them anywhere. > >My three options seem to be: > >Find someone who has a connector I can purchase (failed so far but >maybe one of you has an extra) How many pins are in these connectors? That style of connector was received with considerable excitement at Cessna . . . waaayyyy back when. For a few years, we made up our own audio switching and signal routing junction box utilizing the .156 spaced, card edge connectors. They were the "Amp Leaf" from Amp-Inc. http://tinyurl.com/qbqndka http://tinyurl.com/p2dfvfs Later, others jumped in with their own offerings . . . one of which was the KK series from Molex http://tinyurl.com/7t6jjsc Cessna got out of that activity after a few years in favor of exploiting off-the-shelf devices . . . that first experiment into rudimentary avionics manufacturing had some reliability issues. I wasn't directly involved in the engineering gyrations . . . but I got to observe it and write about it. There proved to be other form-factors for bringing wires off pc boards that were a quantum jump in reliability for black-boxes on airplanes. Nonetheless, King radio, Narco and others produced a goodly number of devices with this technology. The .156" card-edge has been 'not recommended for new design' for a very long time. This poses problems for exploiting the utility of these venerable devices. Quite often, extending the air-worthiness of these devices goes beyond finding pins for adding features. What's a OBAM'er to do when the existing connector has degraded to one step above trash . . . or worse. I've stroked new service life into several devices by replacing the crimped pin connector with solder flag connectors. Like this . . . http://tinyurl.com/nbuab2a Unfortunately, not ALL sizes are available but with some creative application of time/effort and JB weld, you can fabricate a connector of any desired size that offers you all new pins. Check out all the images in the third link above. Bob . . . ________________________________________________________________________________
Date: Jul 12, 2015
>If you have that spare that can be moved, there's usually a little >tab on the back side that prevents it from backing out. If you have >something thin and narrow enough, you should be able to slide it in >from the 'front' (non-wire) end and push the tab away from it's >mating lock point in the shell. Here's a DIY extraction tool for the leaf-style card edge connector pins. http://tinyurl.com/nknv4bk Made this from a pocket screwdriver sacrificed to the task while on a field-trip . . . A little creating grinding will get you the right dimensions for your target connector. Bob . . . ________________________________________________________________________________
Date: Jul 15, 2015
Subject: Insulation displacement connectors????
Anyone know if any type of insulation displacement crimp connectors have ever been used in aircraft applications? I used hundreds (thousands?) of EA-7759 Plain B Wire Connectors, similar to http://www.ebay.com/itm/371364009928?rmvSB=true in burglar alarm & other data cable installations, & never have had a failed connection in 3 decades (though admittedly, I was stripping & twisting the wires prior to crimping). For those who haven't seen these, they have 'teeth' inside that pierce the insulation when crimped. I'm looking at the need to 'daisy chain' several signal grounds from a single dSub pin (in this case, an intercom), and these tiny connectors really look attractive to stagger the joints over several inches of wire near the pin. I tested one by opening the closed end with a pair of pliers, running the 'trunk' wire through the connector, inserting the 'branch' wire, and crimping (no wire stripping involved). Seems to work fine in penetrating the tefzel insulation, and I can't budge the wires with a manual tug test. I have no desire to do this for high current applications, but for signal wires, it sure makes an attractive package due to it's small size. Not sure about the type of insulation, but I'm pretty sure it won't spontaneously combust & drag the plane out of the sky. Thoughts? Charlie ________________________________________________________________________________
Date: Jul 15, 2015
Subject: Re: Insulation displacement connectors????
Charlie, I know splicers use to love these things but even the telco's outlawed these in the 70's (i think). I'm surprised you can even find them on eBay. I guess you can use whatever you want to bet your life on in experimental but I'd stick with what's in common aeronautical use. Bill On 7/15/15 3:12 PM, Charlie England wrote: > Anyone know if any type of insulation displacement crimp connectors > have ever been used in aircraft applications? I used hundreds > (thousands?) of EA-7759 Plain B Wire Connectors, similar to > http://www.ebay.com/itm/371364009928?rmvSB=true > > in burglar alarm & other data cable installations, & never have had a > failed connection in 3 decades (though admittedly, I was stripping & > twisting the wires prior to crimping). For those who haven't seen > these, they have 'teeth' inside that pierce the insulation when crimped. > > I'm looking at the need to 'daisy chain' several signal grounds from a > single dSub pin (in this case, an intercom), and these tiny connectors > really look attractive to stagger the joints over several inches of > wire near the pin. I tested one by opening the closed end with a pair > of pliers, running the 'trunk' wire through the connector, inserting > the 'branch' wire, and crimping (no wire stripping involved). Seems to > work fine in penetrating the tefzel insulation, and I can't budge the > wires with a manual tug test. > > I have no desire to do this for high current applications, but for > signal wires, it sure makes an attractive package due to it's small > size. Not sure about the type of insulation, but I'm pretty sure it > won't spontaneously combust & drag the plane out of the sky. > > Thoughts? > > Charlie > * > > > * ________________________________________________________________________________
Date: Jul 15, 2015
At 05:12 PM 7/15/2015, you wrote: >Anyone know if any type of insulation >displacement crimp connectors have ever been >used in aircraft applications? I used hundreds >(thousands?) of EA-7759 Plain B Wire Connectors, similar to=C2 ><http://www.ebay.com/itm/371364009928?rmvSB=true>http://www.ebay.com/itm/ 371364009928?rmvSB=true > >in burglar alarm & other data cable >installations, & never have had a failed >connection in 3 decades (though admittedly, I >was stripping & twisting the wires prior to >crimping). For those who haven't seen these, >they have 'teeth' inside that pierce the insulation when crimped Suggest you use bussed d-sub connectors http://tinyurl.com/nzm3e2f I've got some bussing boards available if you want them. Bob . . . ________________________________________________________________________________
Date: Jul 16, 2015
Outlawed in the '70s? Maybe so on that particular connector, but I've watched AT&T techs use http://www.specialized.net/Specialized/3M-Scotchlok-IDC-UR2-Connectors-1926-AWG-100Pk-4051.aspx as recently as a few weeks ago. I appreciate the 'be safe' sentiment, but 'bet your life' on the signal wires in an intercom? Isn't that a bit of a knee-jerk reaction to anything unfamiliar? If I'm not mistaken, this list came out of the desire to find products and techniques that are *not* 'in common aeronautical use', so we can improve on the products and/or techniques. We wouldn't have composite airframes (or even aluminum ones) if someone hadn't been the 1st to use something that was not 'in common aeronautical use'. It would be more helpful to me if you could say something at least marginally quantified, like, 'That terminal fails in 0.05% of connections, vs a 0.00004% failure rate for PIDG terminals'. Thanks, Charlie On Wed, Jul 15, 2015 at 5:57 PM, Bill Putney wrote: > Charlie, > > I know splicers use to love these things but even the telco's outlawed > these in the 70's (i think). I'm surprised you can even find them on eBay. > > I guess you can use whatever you want to bet your life on in experimental > but I'd stick with what's in common aeronautical use. > > Bill > > On 7/15/15 3:12 PM, Charlie England wrote: > > Anyone know if any type of insulation displacement crimp connectors have > ever been used in aircraft applications? I used hundreds (thousands?) of > EA-7759 Plain B Wire Connectors, similar to > http://www.ebay.com/itm/371364009928?rmvSB=true > > in burglar alarm & other data cable installations, & never have had a > failed connection in 3 decades (though admittedly, I was stripping & > twisting the wires prior to crimping). For those who haven't seen these, > they have 'teeth' inside that pierce the insulation when crimped. > > I'm looking at the need to 'daisy chain' several signal grounds from a > single dSub pin (in this case, an intercom), and these tiny connectors > really look attractive to stagger the joints over several inches of wire > near the pin. I tested one by opening the closed end with a pair of pliers, > running the 'trunk' wire through the connector, inserting the 'branch' > wire, and crimping (no wire stripping involved). Seems to work fine in > penetrating the tefzel insulation, and I can't budge the wires with a > manual tug test. > > I have no desire to do this for high current applications, but for > signal wires, it sure makes an attractive package due to it's small size. > Not sure about the type of insulation, but I'm pretty sure it won't > spontaneously combust & drag the plane out of the sky. > > Thoughts? > > Charlie > > > * > > > * > > ________________________________________________________________________________
Date: Jul 16, 2015
On Wed, Jul 15, 2015 at 8:25 PM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 05:12 PM 7/15/2015, you wrote: > > Anyone know if any type of insulation displacement crimp connectors have > ever been used in aircraft applications? I used hundreds (thousands?) of > EA-7759 Plain B Wire Connectors, similar to=C3=82 > http://www.ebay.com/itm/371364009928?rmvSB=true > > in burglar alarm & other data cable installations, & never have had a > failed connection in 3 decades (though admittedly, I was stripping & > twisting the wires prior to crimping). For those who haven't seen these, > they have 'teeth' inside that pierce the insulation when crimped > > > Suggest you use bussed d-sub connectors > > http://tinyurl.com/nzm3e2f > > I've got some bussing boards available if > you want them. > > > Bob . . . > > Thanks, Bob; I've already got one of those dSub avionics GND busses mounted in the plane. My specific application for those crimps is the signal ground terminal in a DRE intercom (it has two ground pins in the 25pin dSub which are electrically common internally). My intent was to run one of the gnd pins to the avionics GND bus and the other to the gnd terminals of the various inputs/outputs (mic, headset, music, etc) to the intercom. The crimps would have been used to bring the various signal ground wires to within the 1st few inches of dSub connector on the DRE. Would it work as well to just take all those signal grounds to the avionics dSub ground bus? I was trying to take the signal grounds directly to the intercom to keep ground loop possibilities to an absolute minimum, and an additional dSub bus for just 3 or 4 wires seems to be overkill (and bulky). Thanks, Charlie ________________________________________________________________________________
Date: Jul 16, 2015
I know a lot of guys have the old beans squirreled away but they tend to make noisy connections and are corrosion prone. The Scotchloks are what the telco's moved to after they outlawed the beans. I take things about my airplane very seriously. If nothing else I use the "How stupid would I feel" rule. Like how stupid would I feel if my intercom quit on short final to a busy towered airport in marginal weather because I didn't take the time to strip the wires and use the right connectors? It's a human factors thing. People can handle about 3 things going wrong before they completely unravel. If the weather suddenly gets bad you can turn around and go the other way, add strong winds in that reverse direction now depleting your fuel faster than you planned. If the intercom goes out and you can't contact Flightwatch or ATC to find out where the closest open airport is and you've got a real problem It wouldn't have been a big problem in CAVU but this day it's the third thing. I don't mean to say that every shortcut you take is going to kill you but you never know what the third thing is going to be. There are old pilots and there are bold pilots but there are very few old bold pilots. Bill On 7/16/15 05:52, Charlie England wrote: > Outlawed in the '70s? Maybe so on that particular connector, but I've > watched AT&T techs use > http://www.specialized.net/Specialized/3M-Scotchlok-IDC-UR2-Connectors-1926-AWG-100Pk-4051.aspx > as recently as a few weeks ago. > > I appreciate the 'be safe' sentiment, but 'bet your life' on the > signal wires in an intercom? Isn't that a bit of a knee-jerk reaction > to anything unfamiliar? If I'm not mistaken, this list came out of the > desire to find products and techniques that are *not* 'in common > aeronautical use', so we can improve on the products and/or > techniques. We wouldn't have composite airframes (or even aluminum > ones) if someone hadn't been the 1st to use something that was not 'in > common aeronautical use'. > > It would be more helpful to me if you could say something at least > marginally quantified, like, 'That terminal fails in 0.05% of > connections, vs a 0.00004% failure rate for PIDG terminals'. > > Thanks, > > Charlie > > On Wed, Jul 15, 2015 at 5:57 PM, Bill Putney > wrote: > > Charlie, > > I know splicers use to love these things but even the telco's > outlawed these in the 70's (i think). I'm surprised you can even > find them on eBay. > > I guess you can use whatever you want to bet your life on in > experimental but I'd stick with what's in common aeronautical use. > > Bill > > On 7/15/15 3:12 PM, Charlie England wrote: >> Anyone know if any type of insulation displacement crimp >> connectors have ever been used in aircraft applications? I used >> hundreds (thousands?) of EA-7759 Plain B Wire Connectors, similar to >> http://www.ebay.com/itm/371364009928?rmvSB=true >> >> in burglar alarm & other data cable installations, & never have >> had a failed connection in 3 decades (though admittedly, I was >> stripping & twisting the wires prior to crimping). For those who >> haven't seen these, they have 'teeth' inside that pierce the >> insulation when crimped. >> >> I'm looking at the need to 'daisy chain' several signal grounds >> from a single dSub pin (in this case, an intercom), and these >> tiny connectors really look attractive to stagger the joints over >> several inches of wire near the pin. I tested one by opening the >> closed end with a pair of pliers, running the 'trunk' wire >> through the connector, inserting the 'branch' wire, and crimping >> (no wire stripping involved). Seems to work fine in penetrating >> the tefzel insulation, and I can't budge the wires with a manual >> tug test. >> >> I have no desire to do this for high current applications, but >> for signal wires, it sure makes an attractive package due to it's >> small size. Not sure about the type of insulation, but I'm pretty >> sure it won't spontaneously combust & drag the plane out of the sky. >> >> Thoughts? >> >> Charlie >> * >> >> >> * > > * > > ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > * > > > * > > > * ________________________________________________________________________________
Date: Jul 16, 2015
> >It would be more helpful to me if you could say something at least >marginally quantified, like, 'That terminal fails in 0.05% of >connections, vs a 0.00004% failure rate for PIDG terminals'. How about, "I used ID connectors and ribbon cable in a pitch trim project on a Lear waaayyy back when. At about the 15-year mark, I inquired of the field service guys who were supporting that product. Failure rates were pleasingly low; that product was a fleet retrofit of about 500+ airplanes and the pitch trim controllers came in for attention about 5x a year . . . so about 1%/year for the design. The ID connection devices accounted for about 50% of the service issues. Further, that box was located in the vertical fin, just under the leading edge of the stabilizer . . . hence, subject to about the worst of the sheltered environs on the aircraft. From that experience I would deduce that while the failure rates for ID connections were low, they still accounted for the majority of field failures in the design. Keep in mind also that the teleco's and network communities have been using ID connections for decades . . . of course the environments are not nearly as severe as the interior of a biz-jet's vertical fin . . . but still subject to humidity, temperature cycles and exposure to noxious atmosphere. It would seem that an ID connector used with wires in the connector's design window is a low risk venture. Bob . . . ________________________________________________________________________________
Date: Jul 16, 2015
> >Thanks, Bob; I've already got one of those dSub avionics GND busses >mounted in the plane. My specific application for those crimps is >the signal ground terminal in a DRE intercom (it has two ground pins >in the 25pin dSub which are electrically common internally). My >intent was to run one of the gnd pins to the avionics GND bus and >the other to the gnd terminals of the various inputs/outputs (mic, >headset, music, etc) to the intercom. The crimps would have been >used to bring the various signal ground wires to within the 1st few >inches of dSub connector on the DRE. > >Would it work as well to just take all those signal grounds to the >avionics dSub ground bus? I was trying to take the signal grounds >directly to the intercom to keep ground loop possibilities to an >absolute minimum, and an additional dSub bus for just 3 or 4 wires >seems to be overkill (and bulky). The core idea for the AGB was to craft a single point ground for all signals, power and shields. If it's just 3-4 wires and just shields, why not solder and heat-shrink? In reliability studies, a connector drives up parts count . . . a soldered joint is calculated as the joining of several parts into one part such that there is better than 10 to the minus bazillion reliability. Solder and shrink is almost never a bad idea. Is is frowned upon in the factories because solder is a skill-driven process with tools that burn fingers, upholstery, carpets, etc. But for the OBAM aircraft crowd, solder should represent no unsurmountable hazard. Bob . . . ________________________________________________________________________________
Date: Jul 16, 2015
One additional data point. I used IDCs very similar to those in the OP's qu estion (mine were blue and slightly smaller) to wire an alarm system in my l ast home in 2004. Those connections were in an attic in Phoenix, where unde r-roof temperatures were regularly above 120 deg F (no mechanical stress or v ibration, and very low humidity). The alarm system was functioning perfectl y when I sold the house in March, almost eleven years after installation. Eric > On Jul 16, 2015, at 7:59 AM, Robert L. Nuckolls, III <nuckolls.bob@aeroele ctric.com> wrote: > >> >> It would be more helpful to me if you could say something at least margin ally quantified, like, 'That terminal fails in 0.05% of connections, vs a 0. 00004% failure rate for PIDG terminals'. > > How about, "I used ID connectors and ribbon cable > in a pitch trim project on a Lear waaayyy back when. > At about the 15-year mark, I inquired of the field > service guys who were supporting that product. Failure > rates were pleasingly low; that product was > a fleet retrofit of about 500+ airplanes and the > pitch trim controllers came in for attention about > 5x a year . . . so about 1%/year for the design. > The ID connection devices accounted for about 50% of the > service issues. > > Further, that box was located in the vertical fin, > just under the leading edge of the stabilizer . . . > hence, subject to about the worst of the sheltered > environs on the aircraft. > > =46rom that experience I would deduce that while > the failure rates for ID connections were low, > they still accounted for the majority of field > failures in the design. > > Keep in mind also that the teleco's and network > communities have been using ID connections for > decades . . . of course the environments are not nearly > as severe as the interior of a biz-jet's vertical fin . . . > but still subject to humidity, temperature cycles and > exposure to noxious atmosphere. It would seem that > an ID connector used with wires in the connector's > design window is a low risk venture. > > Bob . . . ________________________________________________________________________________
Subject: Radio Buzz
Date: Jul 16, 2015
I know that asking about the cause of a buzz in your radios is like asking a mechanic about a noise you hear when you are driving but since you are all here and know way more than me I will describe my situation and how I plan to proceed. Set-up RV-6A GX-60 Com SL-30 Com SL-15 Intercom Two COMANT VHF COMMUNICATIONS <http://www.aircraftspruce.com/catalog/avpages/comant122.php> antenna mounted on the centerline of the belly (one below the seat, one below the baggage compartment) I am getting significant static like noise when I connect either radio to the front antenna. I have switched the antennas with no change. The front antenna connection goes pretty much straight down to the floor with a short male-male piece of coax (which I have changed with no result) to connect the female ends of the antenna and radio coax. The antenna wire crosses a bunch of wires at a 90 degree angle and goes right next to where I have a temporary battery placed. My conclusions: The radios, antennas and cables are all ok so I must be picking up interference from either the wires or the battery. Solution: Move the battery and see if it helps (I would have last night but ran out of time) What do you think? Also, I get a very slight hum when I put my hand near (1 inch away) or touch the SL-30. It doesn't bother me but I find it interesting that I just have to get near the radio for the noise to happen. Thanks all, Ross Mickey N9PT RV-6A ________________________________________________________________________________
Date: Jul 16, 2015
wrote: > >> >>Thanks, Bob; I've already got one of those dSub avionics GND busses >>mounted in the plane. My specific application for those crimps is >>the signal ground terminal in a DRE intercom (it has two ground pins >>in the 25pin dSub which are electrically common internally). My >>intent was to run one of the gnd pins to the avionics GND bus and >>the other to the gnd terminals of the various inputs/outputs (mic, >>headset, music, etc) to the intercom. The crimps would have been >>used to bring the various signal ground wires to within the 1st few >>inches of dSub connector on the DRE. >> >>Would it work as well to just take all those signal grounds to the >>avionics dSub ground bus? I was trying to take the signal grounds >>directly to the intercom to keep ground loop possibilities to an >>absolute minimum, and an additional dSub bus for just 3 or 4 wires >>seems to be overkill (and bulky). > > The core idea for the AGB was to craft a single > point ground for all signals, power and shields. > If it's just 3-4 wires and just shields, why > not solder and heat-shrink? > > In reliability studies, a connector drives up > parts count . . . a soldered joint is calculated > as the joining of several parts into one part > such that there is better than 10 to the minus > bazillion reliability. Solder and shrink is almost > never a bad idea. Is is frowned upon in the factories > because solder is a skill-driven process with tools > that burn fingers, upholstery, carpets, etc. But > for the OBAM aircraft crowd, solder should represent > no unsurmountable hazard. > > > Bob . . . Solder/shrink is what I've done in other places, so that's no problem. But a 10 second operation vs a 10 minute one surely is tempting. :-) ________________________________________________________________________________
Date: Jul 16, 2015
In a word, no. B connectors are ugly, but work well given two conditions: (a) DC sealing current to re-establish connection when compromised by oxidation, and (b) no vibration. The later jelly-B connectors try to solve the oxidation problem by immersing the pierces wire in vaseline to keep air out. Not in my airplane. ________________________________________________________________________________
Date: Jul 16, 2015
Subject: RE: Radio Buzz
Date: Jul 16, 2015
More info. My plane is not in a state that allows me to start the engine (wings are off) so this is occurring with just the master switch on. No strobes or landing lights on, just panel instruments on. The main change since I last used the radios is the installation of a Advanced Flight System 5600 EFIS but the only wiring from that which are near my antenna cable are the GPS, Comm Radio and Autopilot serial/ARINC wires. Ross From: Ross Home [mailto:rossmickey(at)comcast.net] Sent: Thursday, July 16, 2015 8:57 AM Subject: Radio Buzz I know that asking about the cause of a buzz in your radios is like asking a mechanic about a noise you hear when you are driving but since you are all here and know way more than me I will describe my situation and how I plan to proceed. Set-up RV-6A GX-60 Com SL-30 Com SL-15 Intercom Two COMANT VHF COMMUNICATIONS <http://www.aircraftspruce.com/catalog/avpages/comant122.php> antenna mounted on the centerline of the belly (one below the seat, one below the baggage compartment) I am getting significant static like noise when I connect either radio to the front antenna. I have switched the antennas with no change. The front antenna connection goes pretty much straight down to the floor with a short male-male piece of coax (which I have changed with no result) to connect the female ends of the antenna and radio coax. The antenna wire crosses a bunch of wires at a 90 degree angle and goes right next to where I have a temporary battery placed. My conclusions: The radios, antennas and cables are all ok so I must be picking up interference from either the wires or the battery. Solution: Move the battery and see if it helps (I would have last night but ran out of time) What do you think? Also, I get a very slight hum when I put my hand near (1 inch away) or touch the SL-30. It doesn't bother me but I find it interesting that I just have to get near the radio for the noise to happen. Thanks all, Ross Mickey N9PT RV-6A ________________________________________________________________________________
Subject: Re: Radio Buzz
Date: Jul 16, 2015
Is the temporary battery powering the avionics? Is the negative battery terminal grounded to the airframe? Turn everything on, then measure the voltage between the negative battery terminal and the radio case. How many millivolts? Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=444845#444845 ________________________________________________________________________________
Date: Jul 16, 2015
Subject: Re: RE: Radio Buzz
Ross, What you are picking up is probably some sort of RFI or EMI. I doubt it will be coming from your battery unless you have some grounding issues, and may not even be coming from your wires. That leaves the noise generators which includes all of your other avionics and electrical devices and systems including strobes, engine/ignition system, etc. And that is assuming there is no noise generated because of ground loops in your aircraft. So the process is to eliminate noise generators, one by one, assuming there is no noise in your antenna/cable/radio when tested with ALL other electrical equipment turned off. If your radio still generates noise when you put your hand near it, I would consider grounding the case. Then, turn on one electrical device at a time to see if it generates any noise. With my GX-60, I noticed the Dynon D10A introduced some hum in the system when turned on. The strobe circuit also introduced some noise. Test each electrical system sequentially to find the biggest "offenders". This process will give you some idea of where to look to attempt to reduce noise in the com system. I recently had my transponder checked and asked about noise in the radio system. He commented that some noise tended to "go with the territory". Not necessarily related, I queried him about very loud feedback when attempting to transmit. Turns out that a setting in the GX-60 for the microphone was set to the maximum as shipped from the factory. The point here is to also check you GX-60 setup parameters. Some adjustments there might assist in correcting your issues. Doug Windhorn ________________________________________________________________________________
Date: Jul 16, 2015
http://www.warbirdinformationexchange.org/phpBB3/viewtopic.php?f=3&t= 52024 From: Ross Home Sent: Thursday, July 16, 2015 6:19 PM Subject: AeroElectric-List: RE: Radio Buzz More info My plane is not in a state that allows me to start the engine (wings are off) so this is occurring with just the master switch on. No strobes or landing lights on, just panel instruments on. The main change since I last used the radios is the installation of a Advanced Flight System 5600 EFIS but the only wiring from that which are near my antenna cable are the GPS, Comm Radio and Autopilot serial/ARINC wires. Ross From: Ross Home [mailto:rossmickey(at)comcast.net] Sent: Thursday, July 16, 2015 8:57 AM Subject: Radio Buzz I know that asking about the cause of a buzz in your radios is like asking a mechanic about a noise you hear when you are driving but since you are all here and know way more than me I will describe my situation and how I plan to proceed. Set-up RV-6A GX-60 Com SL-30 Com SL-15 Intercom Two COMANT VHF COMMUNICATIONS antenna mounted on the centerline of the belly (one below the seat, one below the baggage compartment) I am getting significant static like noise when I connect either radio to the front antenna. I have switched the antennas with no change. The front antenna connection goes pretty much straight down to the floor with a short male-male piece of coax (which I have changed with no result) to connect the female ends of the antenna and radio coax. The antenna wire crosses a bunch of wires at a 90 degree angle and goes right next to where I have a temporary battery placed. My conclusions: The radios, antennas and cables are all ok so I must be picking up interference from either the wires or the battery. Solution: Move the battery and see if it helps (I would have last night but ran out of time) What do you think? Also, I get a very slight hum when I put my hand near (1 inch away) or touch the SL-30. It doesn=99t bother me but I find it interesting that I just have to get near the radio for the noise to happen. Thanks all, Ross Mickey N9PT RV-6A ________________________________________________________________________________
Date: Jul 16, 2015
On 7/16/2015 6:19 PM, Ross Home wrote: > My plane is not in a state that allows me to start the engine (wings are > off) so this is occurring with just the master switch on. No strobes or > landing lights on, just panel instruments on. Just a random thought, but is this inside your hangar? Is there anything on in the hangar, like lights, a refrigerator, etc? The noise might not be coming from anything in the plane. -Dj -- Dj Merrill - N1JOV - EAA Chapter 87 Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Subject: Double Trouble
Date: Jul 16, 2015
The last couple of days I have been getting duplicates of every msg from the Aeroelectric list. Is anyone else having this problem? I don't think it is on my end since only the list emails are affected. Bill ________________________________________________________________________________
Date: Jul 16, 2015
Excellent thought. I had squelch break of sorts on my SL30 until I realized it came and went with the light switch. One florescent tube was causing its ballast to put out a bunch of RFI. New tube, noise gone. On 7/16/2015 6:20 PM, Dj Merrill wrote: > > On 7/16/2015 6:19 PM, Ross Home wrote: >> My plane is not in a state that allows me to start the engine (wings are >> off) so this is occurring with just the master switch on. No strobes or >> landing lights on, just panel instruments on. > > Just a random thought, but is this inside your hangar? Is there > anything on in the hangar, like lights, a refrigerator, etc? > > The noise might not be coming from anything in the plane. > > -Dj > ________________________________________________________________________________
Date: Jul 17, 2015
Subject: Re: Double Trouble
Tm8gcHJvYmxlbSBoZXJlLiBJIGFtIG9ubHkgcmVjZWl2aW5nIG9uZSBjb3B5Lg0KDQo+IE9uIDE3 IEp1bCAyMDE1IDE2OjA0LCAiQmlsbCBCcmFkYnVycnkiIDxiYnJhZGJ1cnJ5QHZlcml6b24ubmV0 PiB3cm90ZToNCj4+DQo+PiBUaGUgbGFzdCBjb3VwbGUgb2YgZGF5cyBJIGhhdmUgYmVlbiBnZXR0 aW5nIGR1cGxpY2F0ZXMgb2YgZXZlcnkgbXNnIGZyb20NCnRoZSBBZXJvZWxlY3RyaWMgbGlzdC4g IElzIGFueW9uZSBlbHNlIGhhdmluZyB0aGlzIHByb2JsZW0/ICBJIGRvbuKAmXQgdGhpbmsNCml0 IGlzIG9uIG15IGVuZCBzaW5jZSBvbmx5IHRoZSBsaXN0IGVtYWlscyBhcmUgYWZmZWN0ZWQuDQo+ Pg0KPj4NCj4+DQo+PiBCaWxsDQo+Pg0KPj4gXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCj4+IF8tPSAgICAgICAgICAtIFRoZSBB ZXJvRWxlY3RyaWMtTGlzdCBFbWFpbCBGb3J1bSAtDQo+PiBfLT0gVXNlIHRoZSBNYXRyb25pY3Mg TGlzdCBGZWF0dXJlcyBOYXZpZ2F0b3IgdG8gYnJvd3NlDQo+PiBfLT0gdGhlIG1hbnkgTGlzdCB1 dGlsaXRpZXMgc3VjaCBhcyBMaXN0IFVuL1N1YnNjcmlwdGlvbiwNCj4+IF8tPSBBcmNoaXZlIFNl YXJjaCAmIERvd25sb2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwNCj4+IF8tPSBQaG90b3No YXJlLCBhbmQgbXVjaCBtdWNoIG1vcmU6DQo+PiBfLT0NCj4+IF8tPSAgIC0tPiBodHRwOi8vd3d3 Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP0Flcm9FbGVjdHJpYy1MaXN0DQo+PiBfLT0NCj4+IF8t PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09DQo+PiBfLT0gICAgICAgICAgICAgICAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0NCj4+IF8t PSBTYW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFibGUgdmlhIHRoZSBXZWIgRm9ydW1zIQ0K Pj4gXy09DQo+PiBfLT0gICAtLT4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tDQo+PiBfLT0N Cj4+IF8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09DQo+PiBfLT0gICAgICAgICAgICAgLSBMaXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0 ZSAtDQo+PiBfLT0gIFRoYW5rIHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQ0KPj4gXy09 ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgLU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLg0K Pj4gXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24NCj4+IF8t PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09DQo+Pg0K ________________________________________________________________________________
Date: Jul 17, 2015
I have a handheld radio in my hanger that I listen to while doing my preflight. Battery chargers for electronic devices often cause noise. Hal Benjamin RV4, Long Island, NY Sent from my iPad > On Jul 17, 2015, at 1:16 AM, Kelly McMullen wrote: > > > Excellent thought. I had squelch break of sorts on my SL30 until I realized it came and went with the light switch. One florescent tube was causing its ballast to put out a bunch of RFI. New tube, noise gone. > >> On 7/16/2015 6:20 PM, Dj Merrill wrote: >> >>> On 7/16/2015 6:19 PM, Ross Home wrote: >>> My plane is not in a state that allows me to start the engine (wings are >>> off) so this is occurring with just the master switch on. No strobes or >>> landing lights on, just panel instruments on. >> >> Just a random thought, but is this inside your hangar? Is there >> anything on in the hangar, like lights, a refrigerator, etc? >> >> The noise might not be coming from anything in the plane. >> >> -Dj > > > > > ________________________________________________________________________________
Date: Jul 17, 2015
On Thu, Jul 16, 2015 at 10:38 PM, Bill Bradburry wrote: > The last couple of days I have been getting duplicates of every msg from > the Aeroelectric list. Is anyone else having this problem? I don =99t think > it is on my end since only the list emails are affected. > > > Bill > > It's probably a glitch with your ISP, or some intermediate transfer point in the interwebs. :-) I've had similar things happen in the past, and they typically resolve themselves in a few days. Charlie ________________________________________________________________________________
Date: Jul 17, 2015
At 10:57 AM 7/16/2015, you wrote: >I know that asking about the cause of a buzz in your radios is like >asking a mechanic about a noise you hear when you are driving but >since you are all here and know way more than me I will describe my >situation and how I plan to proceed. > >Set-up >RV-6A >GX-60 Com >SL-30 Com >SL-15 Intercom >Two ><http://www.aircraftspruce.com/catalog/avpages/comant122.php>COMANT >VHF COMMUNICATIONS antenna mounted on the centerline of the belly >(one below the seat, one below the baggage compartment) > >I am getting significant static like noise when I connect either >radio to the front antenna. This sounds like a radiated noise issue which is almost never an issue with grounding or other installation errors . . . it's usually some device that is not designed to live in harmony on airplanes. Find a hand-held radio. Adjust to unused frequency and open the squelch so you can hear the background 'hiss'. Then use it to 'probe' about the various devices on the airplane. Hand-held vhf transceivers and 9v transistor am radios have been quite useful for probing noise sources of all stripe. Also, conduct a power-down study. Pull all fuses/breakers that power up the ship's accessories. If noise is gone, replace fuses one at a time until the noise comes back. Bob . . . ________________________________________________________________________________
Subject: Radio Buzz
Date: Jul 17, 2015
I will try this. What is puzzling is that the antenna connection that leads to the rear antenna is at the firewall about 18 inches and level with my GX-60. I can easily unhook the GX-60 cable from the front antenna (which is under the floor directly beneath the GX-60) and hook it to the rear antenna connection which is at the same height as the GX-60 and the noise goes away. All of the wires that the GX-60 cable passes are the same in either case except, when it is connected to the front antenna, it crosses these wires at a 90 degree angle instead of running parallel to them when it goes the rear antenna connection. Like I said earlier, I switched the two antenna to see if one was bad with no change. I am using a ground block for all grounding as suggested by Bob and the battery is attached to it. This also occurred out of the hangar so it isn't noise being generated outside of the airplane. Thank you all Ross From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Friday, July 17, 2015 7:30 AM Subject: Re: AeroElectric-List: Radio Buzz At 10:57 AM 7/16/2015, you wrote: I know that asking about the cause of a buzz in your radios is like asking a mechanic about a noise you hear when you are driving but since you are all here and know way more than me I will describe my situation and how I plan to proceed. Set-up RV-6A GX-60 Com SL-30 Com SL-15 Intercom Two COMANT VHF COMMUNICATIONS <http://www.aircraftspruce.com/catalog/avpages/comant122.php> antenna mounted on the centerline of the belly (one below the seat, one below the baggage compartment) I am getting significant static like noise when I connect either radio to the front antenna. This sounds like a radiated noise issue which is almost never an issue with grounding or other installation errors . . . it's usually some device that is not designed to live in harmony on airplanes. Find a hand-held radio. Adjust to unused frequency and open the squelch so you can hear the background 'hiss'. Then use it to 'probe' about the various devices on the airplane. Hand-held vhf transceivers and 9v transistor am radios have been quite useful for probing noise sources of all stripe. Also, conduct a power-down study. Pull all fuses/breakers that power up the ship's accessories. If noise is gone, replace fuses one at a time until the noise comes back. Bob . . . ________________________________________________________________________________
Date: Jul 17, 2015
Since you have ruled out external sources, it sort of points to the front antenna cable. I thought you said you had tried swapping cables. Try removing antenna from airframe, connecting it directly to radio and see if there is noise. I can't explain it, but I know of one case where noise was coming via ground, and isolating the antenna from ground cured the problem. Perhaps a ground loop between coax shield and the airframe ground. On 7/17/2015 7:51 AM, Ross Home wrote: > > I will try this. > > What is puzzling is that the antenna connection that leads to the rear > antenna is at the firewall about 18 inches and level with my GX-60. I > can easily unhook the GX-60 cable from the front antenna (which is > under the floor directly beneath the GX-60) and hook it to the rear > antenna connection which is at the same height as the GX-60 and the > noise goes away. All of the wires that the GX-60 cable passes are the > same in either case except, when it is connected to the front antenna, > it crosses these wires at a 90 degree angle instead of running > parallel to them when it goes the rear antenna connection. > > Like I said earlier, I switched the two antenna to see if one was bad > with no change. > > I am using a ground block for all grounding as suggested by Bob and > the battery is attached to it. > > This also occurred out of the hangar so it isnt noise being generated > outside of the airplane. > > Thank you all > > Ross > > *From:*owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of > *Robert L. Nuckolls, III > *Sent:* Friday, July 17, 2015 7:30 AM > *To:* aeroelectric-list(at)matronics.com > *Subject:* Re: AeroElectric-List: Radio Buzz > > At 10:57 AM 7/16/2015, you wrote: > > I know that asking about the cause of a buzz in your radios is > like asking a mechanic about a noise you hear when you are driving > but since you are all here and know way more than me I will > describe my situation and how I plan to proceed. > > Set-up > RV-6A > GX-60 Com > SL-30 Com > SL-15 Intercom > Two COMANT VHF COMMUNICATIONS > <http://www.aircraftspruce.com/catalog/avpages/comant122.php> > antenna mounted on the centerline of the belly (one below the > seat, one below the baggage compartment) > > I am getting significant static like noise when I connect either > radio to the front antenna. > > > This sounds like a radiated noise issue which is almost > never an issue with grounding or other installation > errors . . . it's usually some device that is not > designed to live in harmony on airplanes. > > Find a hand-held radio. Adjust to unused frequency > and open the squelch so you can hear the background > 'hiss'. Then use it to 'probe' about the various > devices on the airplane. > > Hand-held vhf transceivers and 9v transistor am radios > have been quite useful for probing noise sources of > all stripe. > > Also, conduct a power-down study. Pull all fuses/breakers > that power up the ship's accessories. If noise is gone, > replace fuses one at a time until the noise comes back. > > > Bob . . . > > ** > ** > ** > ** > ** > ** > ** > *http://www.matronics.com/Navigator?AeroElectric-List* > ** > ** > *http://forums.matronics.com* > ** > ** > ** > ** > *http://www.matronics.com/contribution* > ** > ** > http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jul 17, 2015
Bob's idea is probably right, but with two basically identical antennas I would vote for a problem with the problem antenna, probably the coax- connector-or connection to the antenna or a faulty antenna, if it is store bought. Connect your portable to each antenna to re re re varify that the front antenna is indeed the one that is giving the problem. Then do a continuity check to see if somewhere the cable has been kinked and is intermittently shorting (move as much of it as you can around. If the noise is coming from inside of the aircraft, shutting all things off (with the exception of the errant radio and listening would probably be a good first test. If quiet, turn on each separate one (disconnect them via their fuses/CBs, not just their switches. If it is coming from the hanger, merely reverse the location of the aircraft and the problem may go to the other antenna. A better test is to take the beast out of the hanger and try to duplicate the problem. My vote is the antenna or its lead/connectors, etc. By the way. communication waves are vertically polarized your antennas are horizontally polarized. I dont know how much of a problem this is. That is for others to comment about Rich In a message dated 7/17/2015 9:34:07 A.M. Central Daylight Time, nuckolls.bob(at)aeroelectric.com writes: At 10:57 AM 7/16/2015, you wrote: I know that asking about the cause of a buzz in your radios is like asking a mechanic about a noise you hear when you are driving but since you are all here and know way more than me I will describe my situation and how I plan to proceed. Set-up RV-6A GX-60 Com SL-30 Com SL-15 Intercom Two _COMANT VHF COMMUNICATIONS_ (http://www.aircraftspruce.com/catalog/avpages/comant122.php) antenna mounted on the centerline of the belly (one below the seat, one below the baggage compartment) I am getting significant static like noise when I connect either radio to the front antenna. This sounds like a radiated noise issue which is almost never an issue with grounding or other installation errors . . . it's usually some device that is not designed to live in harmony on airplanes. Find a hand-held radio. Adjust to unused frequency and open the squelch so you can hear the background 'hiss'. Then use it to 'probe' about the various devices on the airplane. Hand-held vhf transceivers and 9v transistor am radios have been quite useful for probing noise sources of all stripe. Also, conduct a power-down study. Pull all fuses/breakers that power up the ship's accessories. If noise is gone, replace fuses one at a time until the noise comes back. Bob . . . ________________________________________________________________________________
Date: Jul 17, 2015
I just looked up your antenna-- forget the part of polarization in the last post..It is possible that you have an infant mortality. Rich In a message dated 7/17/2015 9:34:07 A.M. Central Daylight Time, nuckolls.bob(at)aeroelectric.com writes: At 10:57 AM 7/16/2015, you wrote: I know that asking about the cause of a buzz in your radios is like asking a mechanic about a noise you hear when you are driving but since you are all here and know way more than me I will describe my situation and how I plan to proceed. Set-up RV-6A GX-60 Com SL-30 Com SL-15 Intercom Two _COMANT VHF COMMUNICATIONS_ (http://www.aircraftspruce.com/catalog/avpages/comant122.php) antenna mounted on the centerline of the belly (one below the seat, one below the baggage compartment) I am getting significant static like noise when I connect either radio to the front antenna. This sounds like a radiated noise issue which is almost never an issue with grounding or other installation errors . . . it's usually some device that is not designed to live in harmony on airplanes. Find a hand-held radio. Adjust to unused frequency and open the squelch so you can hear the background 'hiss'. Then use it to 'probe' about the various devices on the airplane. Hand-held vhf transceivers and 9v transistor am radios have been quite useful for probing noise sources of all stripe. Also, conduct a power-down study. Pull all fuses/breakers that power up the ship's accessories. If noise is gone, replace fuses one at a time until the noise comes back. Bob . . . ________________________________________________________________________________
Date: Jul 17, 2015
At 11:05 AM 7/17/2015, you wrote: >Since you have ruled out external sources, it sort of points to the >front antenna cable. I thought you said you had tried swapping cables. >Try removing antenna from airframe, connecting it directly to radio >and see if there is noise. >I can't explain it, but I know of one case where noise was coming >via ground, and isolating the antenna from ground cured the problem. >Perhaps a ground loop between coax shield and the airframe ground. > >On 7/17/2015 7:51 AM, Ross Home wrote: >>I will try this. >> >>What is puzzling is that the antenna connection that leads to the >>rear antenna is at the firewall about 18 inches and level with my >>GX-60. I can easily unhook the GX-60 cable from the front antenna >>(which is under the floor directly beneath the GX-60) and hook it >>to the rear antenna connection which is at the same height as the >>GX-60 and the noise goes away. All of the wires that the GX-60 >>cable passes are the same in either case except, when it is >>connected to the front antenna, it crosses these wires at a 90 >>degree angle instead of running parallel to them when it goes the >>rear antenna connection. Routing of coax cables to antennas is NEVER a component of received noise . . . in the heavy iron we route coaxes where there is opportunity and room. The whole idea behind the industry standard practices for (1) limiting noise from antagonists, (2) improving resistance to noise by judicious design of potential victims and last (3) reducing risk of over-whelming propagation path (mounting an antenna under the cowl will probably pick up ignition noise). When a noise coming in through the receiver's antenna port is detected, placement of the coax isn't even a distant finisher in the quest for resolution. Assuming you have paid due diligence to standard practices for installing the two antennas then the fact that the forward-most antenna seems to be the key propagation port, then the noise source is most likely forward ON the aircraft. If it were off the aircraft, both antennas would hear it. This problem has a lot in common with Col_Mustard- did-it-in-the-library-with-a-rope . . . you gotta gather all the clues available to you BEFORE picking up hammers-n-saws . . . or screwdrivers. Antennas don't go BAD in a manner that makes one a source of noise while others are not. They either work good . . . or they don't . . . but they're never 'noisy'. Start with a 'cold' panel and bring up equipment one item at a time . . . then confirm your preliminary findings with a sniffer receiver. Only THEN will hammers, saws and screwdrivers contribute to resolution of the problem. Bob . . . ________________________________________________________________________________
Subject: Radio Buzz
Date: Jul 17, 2015
Thanks so much, Bob. I will do as you suggest when I get back out to the hangar. Just for my education. Since the location of the coax is not an issue, am I to understand that the interference I am experiencing is being picked up by the forward antenna itself? In surfing the web about comm antenna, I read about the importance of having good electrical bonding of the antenna to the aircraft ground. The electrical bonding of the antennas to the aircraft skin is best accomplished by direct metal-to metal contact of the antenna base to the aircraft skin. To accomplish this, the aircraft paint in the mounting area will need to be removed and the surface alodined to protect aluminum against corrosion. An alternate method for providing electrical bonding is through the mounting screws, which attach to a backing plate inside the aircraft skin. Remove any interior paint in the area where the backing plate is placed to assure a good ground. Coat this area with alodine to minimize corrosion. To test the electrical bonding of the blade to the aircraft, a reading of .003 ohms between the antenna base plate and ground should be achieved. I am using the second method and will have to check if my installation meets the .003 ohm test. If the front antenna does not meet this, would this cause a buzz or just degrade the performance of the antenna? Ross From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Friday, July 17, 2015 11:45 AM Subject: Re: AeroElectric-List: Radio Buzz At 11:05 AM 7/17/2015, you wrote: Since you have ruled out external sources, it sort of points to the front antenna cable. I thought you said you had tried swapping cables. Try removing antenna from airframe, connecting it directly to radio and see if there is noise. I can't explain it, but I know of one case where noise was coming via ground, and isolating the antenna from ground cured the problem. Perhaps a ground loop between coax shield and the airframe ground. On 7/17/2015 7:51 AM, Ross Home wrote: I will try this. What is puzzling is that the antenna connection that leads to the rear antenna is at the firewall about 18 inches and level with my GX-60. I can easily unhook the GX-60 cable from the front antenna (which is under the floor directly beneath the GX-60) and hook it to the rear antenna connection which is at the same height as the GX-60 and the noise goes away. All of the wires that the GX-60 cable passes are the same in either case except, when it is connected to the front antenna, it crosses these wires at a 90 degree angle instead of running parallel to them when it goes the rear antenna connection. Routing of coax cables to antennas is NEVER a component of received noise . . . in the heavy iron we route coaxes where there is opportunity and room. The whole idea behind the industry standard practices for (1) limiting noise from antagonists, (2) improving resistance to noise by judicious design of potential victims and last (3) reducing risk of over-whelming propagation path (mounting an antenna under the cowl will probably pick up ignition noise). When a noise coming in through the receiver's antenna port is detected, placement of the coax isn't even a distant finisher in the quest for resolution. Assuming you have paid due diligence to standard practices for installing the two antennas then the fact that the forward-most antenna seems to be the key propagation port, then the noise source is most likely forward ON the aircraft. If it were off the aircraft, both antennas would hear it. This problem has a lot in common with Col_Mustard- did-it-in-the-library-with-a-rope . . . you gotta gather all the clues available to you BEFORE picking up hammers-n-saws . . . or screwdrivers. Antennas don't go BAD in a manner that makes one a source of noise while others are not. They either work good . . . or they don't . . . but they're never 'noisy'. Start with a 'cold' panel and bring up equipment one item at a time . . . then confirm your preliminary findings with a sniffer receiver. Only THEN will hammers, saws and screwdrivers contribute to resolution of the problem. Bob . . . http://www.matronics.com/Navigator?AeroElectric-List http://www.matronics.com/contribution ________________________________________________________________________________
Subject: Re: Young Aviators & B-25 intercom
Date: Jul 17, 2015
With a tremendous amount of work by the EAA Mile High Chapter 43 Young Aviators group, and many volunteers, the mock-up of a B-25 cockpit will be at KidVenture/Oshkosh this year. I want to thank Bob Nuckolls for the part he played in generously donating parts & his expertise to the intercom part of this tremendous undertaking. Thank you again, Bob!!! It is still somewhat a work in progress, but it looks very good, and a large group of the kids & their parents, as well as other Chapter 43 volunteers will be there to conduct tours and tell the B-25 story. They are a pretty excited and proud bunch of young people! -------- John Evens Thorp T-18 N71JE (built & flying) Kitfox SS7 N27JE (building) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=444883#444883 ________________________________________________________________________________
Date: Jul 17, 2015
Subject: Voltage reducer
This is not aircraft related (but I do have an RV6) but is electronic related. Many years ago I converted an old Porsche 356 from 6V to 12V. There were no 12V windshield wiper motors available so I had to use the original 6V wiper motor which drew about 5-10A. Speed was controlled with a rheostat, but adding another dropping resistor generated heat and made the speed control ineffective. Someone assembled a transistor circuit for me that dropped the 12V supply to a constant 6V (independent of current draw) and everything worked well. I am now restoring this car and this device became lost. Does anyone of you electronic experts (maybe Bob N) know of a circuit I can build or purchase a device that will give me the constant 6V at 5 or 10A? Jurgen Amtmann ________________________________________________________________________________
Date: Jul 17, 2015
Subject: Shopping at AirVenture
=0AFolks,=0A =0AI am building a BD-4C (4 place, high wing) and plan to buil d the electrical system between this AirVenture and the next. If you were i n my shoes, is there anything that you would buy at AirVenture this summer? Tools? Wire? Etc?=0A =0AMy impression of the fly-mart is not great. And I have not been bowled over by tremendous deals in past years, as I wandered hangars A-D. But maybe I just don't know what I'm looking for so I figured I would ask here.=0A =0AThanks,=0A -- Art Z.=0A =0A--[ http://CheerfulCu rmudgeon.com/ ]( http://CheerfulCurmudgeon.com/ )"If I am not for myself, w ho is for me? And if I am only for myself, what am I? And if not now, when? " Hillel ________________________________________________________________________________
Date: Jul 18, 2015
Subject: Re: Shopping at AirVenture
Hi Art,You have to determine what you need for your airplane.=C2- Most ai rcraft supplies companies will give a 10% discount on major purchases.=C2 - Take your order to several places and see where you get the best deal. =C2- On Friday, July 17, 2015 8:37 PM, Art Zemon wrote: Folks,=C2-I am building a BD-4C (4 place, high wing) and plan to build t he electrical system between this AirVenture and the next. If you were in m y shoes, is there anything that you would buy at AirVenture this summer? To ols? Wire? Etc?=C2-My impression of the fly-mart is not great. And I have not been bowled over by tremendous deals in past years, as I wandered hang ars A-D. But maybe I just don't know what I'm looking for so I figured I wo uld ask here.=C2-Thanks,=C2- =C2- -- Art Z.=C2--- http://CheerfulCurmudgeon.com/ "If I am not for myself, who is for me? And if I am only for myself, what a m I? And if not now, when?" Hillel ________________________________________________________________________________
Date: Jul 17, 2015
The only real electrical score I ever made at OSH was for a used tefzel wire stripper from one of the outside stalls. Non aviation strippers nick the wire when used on thin tefzel insulation. Ken On 17/07/2015 9:37 PM, Art Zemon wrote: > > Folks, > > I am building a BD-4C (4 place, high wing) and plan to build the > electrical system between this AirVenture and the next. If you were in > my shoes, is there anything that you would buy at AirVenture this > summer? Tools? Wire? Etc? > > My impression of the fly-mart is not great. And I have not been bowled > over by tremendous deals in past years, as I wandered hangars A-D. But > maybe I just don't know what I'm looking for so I figured I would ask > here. > > Thanks, > > -- Art Z. > > -- > http://CheerfulCurmudgeon.com/ > > /"If I am not for myself, who is for me? And if I am only for myself, > what am I? And if not now, when?" Hillel/ > > http://www.matronics.com/contribution ________________________________________________________________________________
Subject: Re: Voltage reducer
Date: Jul 17, 2015
Search for PWM Motor Speed Controller. Maybe something like this will work: http://www.ebay.com/itm/9-60V-40A-DC-Motor-Speed-Control-PWM-HHO-RC-Controller-12V-24V-48V-1500W-MAX-/261421453931?pt=LH_DefaultDomain_0&hash=item3cddeed26b The rated capacity of some items from China are exaggerated, so get 2 or 3 times the expected load capacity. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=444901#444901 ________________________________________________________________________________
Date: Jul 17, 2015
Art The fly market,over the last sever years, with few exceptions can really be c alled the flam market. If your electrical installation is anything other than real basic get a good quality automatic wire stripper (grabs the wire and strips it) make sure it is for tefzel wire. Standard strippers that look the same will not cut the t efzel smoothly--or at all They are not cheap. I got mine from pegasus racing (a rv builder) comes with a replacement set of cutters The other thing you will need is a good ratchet type crimper for terminals Additionally if you are going to use sub-d plugs get a crimped for the pins/ sockets B&c might be a one stop shop for you and will be located in one of the main b ooths For your terminals use PIDG. And don't use hardware store types If you can find a good used ratchet type terminal crimper that would probabl y be ok as they don't wear much but I would stay away from a used stripper a nd sub-d crimpr. Use machined pins Other things to get are heat shrink tubing of various sizes See what they have for wire marking Be careful about the wire that is being offered Make sure it is tefzel. Lots of places try to sell old stocks of obsolete w ire Just some thoughts Rich Sent from my iPhone > On Jul 17, 2015, at 8:37 PM, Art Zemon wrote: > > Folks, > > I am building a BD-4C (4 place, high wing) and plan to build the electrica l system between this AirVenture and the next. If you were in my shoes, is t here anything that you would buy at AirVenture this summer? Tools? Wire? Etc ? > > My impression of the fly-mart is not great. And I have not been bowled ove r by tremendous deals in past years, as I wandered hangars A-D. But maybe I j ust don't know what I'm looking for so I figured I would ask here. > > Thanks, > -- Art Z. > > -- > http://CheerfulCurmudgeon.com/ > > "If I am not for myself, who is for me? And if I am only for myself, what a m I? And if not now, when?" Hillel > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Jul 18, 2015
> On Jul 17, 2015, at 9:37 PM, Art Zemon wrote: > is there anything that you would buy at AirVenture this summer? Tools? Wire? Etc? Shrink-wrap! A fistfull of 1/4 down to 3/32 and all the colors of the rainbow. Clear version too, if you want to make wire labels and shrink-wrap them. The ordinary stuff works OK. There are some special tough irradiated versions that are desirable in some areas. -Kent ________________________________________________________________________________
Date: Jul 18, 2015
Subject: Instrument lights
Dear All, After a minor panel re-build I'm trying to provide lighting for a couple of round instruments. I have found a pair of eyebrow lights in my spares box, but they have 24v bulbs. Does anyone know of a 12v alternative to a CM327 instrument bulb? Thanks, Peter ________________________________________________________________________________
Date: Jul 18, 2015
Subject: Re: Instrument lights
Peter, That would be a #330 lamp (probably CM330 is a specific manufacturer). Bill On 7/18/15 09:39, Peter Pengilly wrote: > > Dear All, > After a minor panel re-build I'm trying to provide lighting for a > couple of round instruments. I have found a pair of eyebrow lights in > my spares box, but they have 24v bulbs. Does anyone know of a 12v > alternative to a CM327 instrument bulb? > Thanks, Peter > > * > > > * ________________________________________________________________________________
Date: Jul 18, 2015
Peter, Mouser Electronics (mouser.com) lists the CM327 as a T-1 3/4 midget flange base incandescent bulb. The 14 volt equivalent is either the CM330 ($0.55@) or the long life (15,000 hours) CM382 ($0.80@). Tom ________________________________________________________________________________
Date: Jul 18, 2015
At 09:57 PM 7/17/2015, you wrote: > >Search for PWM Motor Speed Controller. Maybe something like this will work: >http://www.ebay.com/itm/9-60V-40A-DC-Motor-Speed-Control-PWM-HHO-RC-Controller-12V-24V-48V-1500W-MAX-/261421453931?pt=LH_DefaultDomain_0&hash=item3cddeed26b >The rated capacity of some items from China are exaggerated, so get >2 or 3 times the expected load capacity. I've used several similar products and they seemed to be of good value. You will want to limit the 'travel' on the control potentiometer such that output never exceeds 7v on a 14v system. The stock controller will allow output all the way up to what ever the bus voltage is. You can do this with a mechanical stop on a pointer knob . . . or perhaps add a resistor in series with the potentiometer body such that full travel on the pot represents only 1/2 of the original electrical travel. Bob . . . ________________________________________________________________________________
From: "Ross Mickey (home)" <rossmickey(at)comcast.net>
Date: Jul 19, 2015
I have identified that the buzz/static is coming from the new AFS 5600 EFIS I just installed. I have lessened the static sound some by re routing some wi res. I also now can see that the rear antenna is being slightly affected als o. All of the grounds look good going to a common ground block attached to t he battery. Now what do I do? Ross Mickey > On Jul 17, 2015, at 12:43 PM, Ross Home wrote: > > Thanks so much, Bob. I will do as you suggest when I get back out to the h angar. > > Just for my education. Since the location of the coax is not an issue, am I to understand that the interference I am experiencing is being picked up b y the forward antenna itself? > > In surfing the web about comm antenna, I read about the importance of havi ng good electrical bonding of the antenna to the aircraft ground. > > The electrical bonding of the antennas to the aircraft skin is best accomp lished by direct metal-to metal contact of the antenna base to the aircraft s kin. To accomplish this, the aircraft paint in the mounting area will need t o be removed and the surface alodined to protect aluminum against corrosion. An alternate method for providing electrical bonding is through the mountin g screws, which attach to a backing plate inside the aircraft skin. Remove a ny interior paint in the area where the backing plate is placed to assure a g ood ground. Coat this area with alodine to minimize corrosion. To test the e lectrical bonding of the blade to the aircraft, a reading of .003 ohms betwe en the antenna base plate and ground should be achieved. > > I am using the second method and will have to check if my installation mee ts the .003 ohm test. If the front antenna does not meet this, would this c ause a buzz or just degrade the performance of the antenna? > > Ross > > From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelect ric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III > Sent: Friday, July 17, 2015 11:45 AM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Radio Buzz > > At 11:05 AM 7/17/2015, you wrote: > > Since you have ruled out external sources, it sort of points to the front a ntenna cable. I thought you said you had tried swapping cables. > Try removing antenna from airframe, connecting it directly to radio and se e if there is noise. > I can't explain it, but I know of one case where noise was coming via grou nd, and isolating the antenna from ground cured the problem. Perhaps a groun d loop between coax shield and the airframe ground. > > On 7/17/2015 7:51 AM, Ross Home wrote: > > I will try this. > > What is puzzling is that the antenna connection that leads to the rear ant enna is at the firewall about 18 inches and level with my GX-60. I can easi ly unhook the GX-60 cable from the front antenna (which is under the floor d irectly beneath the GX-60) and hook it to the rear antenna connection which i s at the same height as the GX-60 and the noise goes away. All of the wires that the GX-60 cable passes are the same in either case except, when it is c onnected to the front antenna, it crosses these wires at a 90 degree angle i nstead of running parallel to them when it goes the rear antenna connection. > > Routing of coax cables to antennas is NEVER > a component of received noise . . . in the > heavy iron we route coaxes where there is opportunity > and room. The whole idea behind the industry standard > practices for (1) limiting noise from antagonists, > (2) improving resistance to noise by judicious > design of potential victims and last (3) reducing > risk of over-whelming propagation path (mounting > an antenna under the cowl will probably pick up > ignition noise). When a noise coming in through > the receiver's antenna port is detected, placement > of the coax isn't even a distant finisher in the > quest for resolution. > > Assuming you have paid due diligence to standard practices > for installing the two antennas then the fact that > the forward-most antenna seems to be the key propagation > port, then the noise source is most likely forward ON > the aircraft. If it were off the aircraft, both > antennas would hear it. > > This problem has a lot in common with Col_Mustard- > did-it-in-the-library-with-a-rope . . . you gotta > gather all the clues available to you BEFORE picking > up hammers-n-saws . . . or screwdrivers. > > Antennas don't go BAD in a manner that makes one > a source of noise while others are not. They either > work good . . . or they don't . . . but they're never > 'noisy'. Start with a 'cold' panel and bring up > equipment one item at a time . . . then confirm > your preliminary findings with a sniffer receiver. > > Only THEN will hammers, saws and screwdrivers > contribute to resolution of the problem. > > > Bob . . . > > > > http://www.matronics.com/Navigator?AeroElectric-List > http://forums.matronics.com > http://www.matronics.com/contribution > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Jul 19, 2015
On 7/19/2015 3:15 PM, Ross Mickey (home) wrote: > I have identified that the buzz/static is coming from the new AFS 5600 > EFIS I just installed. > > Now what do I do? First thing I'd do is contact AFS and see if they have any thoughts. Others might have reported similar issues and they may have some ready ideas to try. -Dj -- Dj Merrill - N1JOV - EAA Chapter 87 Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Date: Jul 19, 2015
Turn the EFIS off with circuit breaker. See if the noise goes away. Then call AFS/Dynon for advice if that proves to be the source of the noise. On 7/19/2015 12:15 PM, Ross Mickey (home) wrote: > I have identified that the buzz/static is coming from the new AFS 5600 > EFIS I just installed. I have lessened the static sound some by re > routing some wires. I also now can see that the rear antenna is being > slightly affected also. All of the grounds look good going to a common > ground block attached to the battery. > > Now what do I do? > > Ross Mickey > > > On Jul 17, 2015, at 12:43 PM, Ross Home > wrote: > >> Thanks so much, Bob. I will do as you suggest when I get back out to >> the hangar. >> >> Just for my education. Since the location of the coax is not an >> issue, am I to understand that the interference I am experiencing is >> being picked up by the forward antenna itself? >> >> In surfing the web about comm antenna, I read about the importance of >> having good electrical bonding of the antenna to the aircraft ground. >> >> The electrical bonding of the antennas to the aircraft skin is best >> accomplished by direct metal-to metal contact of the antenna base to >> the aircraft skin. To accomplish this, the aircraft paint in the >> mounting area will need to be removed and the surface alodined to >> protect aluminum against corrosion. An alternate method for providing >> electrical bonding is through the mounting screws, which attach to a >> backing plate inside the aircraft skin. Remove any interior paint in >> the area where the backing plate is placed to assure a good ground. >> Coat this area with alodine to minimize corrosion. To test the >> electrical bonding of the blade to the aircraft, a reading of .003 >> ohms between the antenna base plate and ground should be achieved. >> >> I am using the second method and will have to check if my >> installation meets the .003 ohm test. If the front antenna does not >> meet this, would this cause a buzz or just degrade the performance of >> the antenna? >> >> Ross >> >> *From:*owner-aeroelectric-list-server(at)matronics.com >> >> [mailto:owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of >> *Robert L. Nuckolls, III >> *Sent:* Friday, July 17, 2015 11:45 AM >> *To:* aeroelectric-list(at)matronics.com >> >> *Subject:* Re: AeroElectric-List: Radio Buzz >> >> At 11:05 AM 7/17/2015, you wrote: >> >> Since you have ruled out external sources, it sort of points to >> the front antenna cable. I thought you said you had tried >> swapping cables. >> Try removing antenna from airframe, connecting it directly to >> radio and see if there is noise. >> I can't explain it, but I know of one case where noise was coming >> via ground, and isolating the antenna from ground cured the >> problem. Perhaps a ground loop between coax shield and the >> airframe ground. >> >> On 7/17/2015 7:51 AM, Ross Home wrote: >> >> I will try this. >> >> What is puzzling is that the antenna connection that leads to >> the rear antenna is at the firewall about 18 inches and level >> with my GX-60. I can easily unhook the GX-60 cable from the >> front antenna (which is under the floor directly beneath the >> GX-60) and hook it to the rear antenna connection which is at >> the same height as the GX-60 and the noise goes away. All of >> the wires that the GX-60 cable passes are the same in either >> case except, when it is connected to the front antenna, it >> crosses these wires at a 90 degree angle instead of running >> parallel to them when it goes the rear antenna connection. >> >> >> Routing of coax cables to antennas is NEVER >> a component of received noise . . . in the >> heavy iron we route coaxes where there is opportunity >> and room. The whole idea behind the industry standard >> practices for (1) limiting noise from antagonists, >> (2) improving resistance to noise by judicious >> design of potential victims and last (3) reducing >> risk of over-whelming propagation path (mounting >> an antenna under the cowl will probably pick up >> ignition noise). When a noise coming in through >> the receiver's antenna port is detected, placement >> of the coax isn't even a distant finisher in the >> quest for resolution. >> >> Assuming you have paid due diligence to standard practices >> for installing the two antennas then the fact that >> the forward-most antenna seems to be the key propagation >> port, then the noise source is most likely forward ON >> the aircraft. If it were off the aircraft, both >> antennas would hear it. >> >> This problem has a lot in common with Col_Mustard- >> did-it-in-the-library-with-a-rope . . . you gotta >> gather all the clues available to you BEFORE picking >> up hammers-n-saws . . . or screwdrivers. >> >> Antennas don't go BAD in a manner that makes one >> a source of noise while others are not. They either >> work good . . . or they don't . . . but they're never >> 'noisy'. Start with a 'cold' panel and bring up >> equipment one item at a time . . . then confirm >> your preliminary findings with a sniffer receiver. >> >> Only THEN will hammers, saws and screwdrivers >> contribute to resolution of the problem. >> >> >> Bob . . . >> >> ** >> ** >> ** >> ** >> ** >> ** >> ** >> **http://www.matronics.com/Navigator?AeroElectric-List**** >> **** >> **** >> ***http://forums.matronics.com***** >> ****** >> ****** >> ****** >> ****** >> ****http://www.matronics.com/contribution****** >> ****** >> ****** >> ** >> *D============================================= >> lectric-List"">http://www.matronics.com/Navigator?AeroElectric-List >> D============================================= >> //forums.matronics.com >> D============================================= >> ot;">http://www.matronics.com/contribution >> D============================================= >> * >> ** > http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jul 19, 2015
Is the AFS 5600 EFIS wired according to the installation manual? Usually shielded cables are grounded at the source end only, but not always. Can you identify one or more wires from the AFS 5600 EFIS that are causing the noise? Is the squelch on the com radio adjusted too sensitive? Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=444951#444951 ________________________________________________________________________________
Date: Jul 19, 2015
At 02:24 PM 7/19/2015, you wrote: > >On 7/19/2015 3:15 PM, Ross Mickey (home) wrote: > > I have identified that the buzz/static is coming from the new AFS 5600 > > EFIS I just installed. > > > > Now what do I do? A number of appliances with LCD screens were notorious radiators. I think the problems were centered around the micro-watt dc to ac converter used to bias up the screen. I'd not heard of any difficulties in years . . . I assumed that everyone had figured it out by now . . . but apparently not. The fact that moving wires made difference suggests that the noises MAY be radiated from wire bundles as opposed to from the LCD face. Again, the hand-held transceiver can be used to 'sniff' around the box . . . much like you would use a freon leak detector to find a bad joint. You may want to make a 'special' antenna for the hand held that is only an inch or so long so that its not terribly efficient . . . Bob . . . ________________________________________________________________________________
Date: Jul 19, 2015
I identified it was the EFIS by pulling the fuse. Ross Mickey 541-954-7521 > On Jul 19, 2015, at 2:10 PM, Kelly McMullen wrote: > > > Turn the EFIS off with circuit breaker. See if the noise goes away. Then call AFS/Dynon for advice if that proves to be the source of the noise. > >> On 7/19/2015 12:15 PM, Ross Mickey (home) wrote: >> I have identified that the buzz/static is coming from the new AFS 5600 EFIS I just installed. I have lessened the static sound some by re routing some wires. I also now can see that the rear antenna is being slightly affected also. All of the grounds look good going to a common ground block attached to the battery. >> >> Now what do I do? >> >> Ross Mickey >> >> >> >>> On Jul 17, 2015, at 12:43 PM, Ross Home > wrote: >>> >>> Thanks so much, Bob. I will do as you suggest when I get back out to the hangar. >>> >>> Just for my education. Since the location of the coax is not an issue, am I to understand that the interference I am experiencing is being picked up by the forward antenna itself? >>> >>> In surfing the web about comm antenna, I read about the importance of having good electrical bonding of the antenna to the aircraft ground. >>> >>> The electrical bonding of the antennas to the aircraft skin is best accomplished by direct metal-to metal contact of the antenna base to the aircraft skin. To accomplish this, the aircraft paint in the mounting area will need to be removed and the surface alodined to protect aluminum against corrosion. An alternate method for providing electrical bonding is through the mounting screws, which attach to a backing plate inside the aircraft skin. Remove any interior paint in the area where the backing plate is placed to assure a good ground. Coat this area with alodine to minimize corrosion. To test the electrical bonding of the blade to the aircraft, a reading of .003 ohms between the antenna base plate and ground should be achieved. >>> >>> I am using the second method and will have to check if my installation meets the .003 ohm test. If the front antenna does not meet this, would this cause a buzz or just degrade the performance of the antenna? >>> >>> Ross >>> >>> *From:*owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of *Robert L. Nuckolls, III >>> *Sent:* Friday, July 17, 2015 11:45 AM >>> *To:* aeroelectric-list(at)matronics.com >>> *Subject:* Re: AeroElectric-List: Radio Buzz >>> >>> At 11:05 AM 7/17/2015, you wrote: >>> >>> Since you have ruled out external sources, it sort of points to >>> the front antenna cable. I thought you said you had tried >>> swapping cables. >>> Try removing antenna from airframe, connecting it directly to >>> radio and see if there is noise. >>> I can't explain it, but I know of one case where noise was coming >>> via ground, and isolating the antenna from ground cured the >>> problem. Perhaps a ground loop between coax shield and the >>> airframe ground. >>> >>> On 7/17/2015 7:51 AM, Ross Home wrote: >>> >>> I will try this. >>> >>> What is puzzling is that the antenna connection that leads to >>> the rear antenna is at the firewall about 18 inches and level >>> with my GX-60. I can easily unhook the GX-60 cable from the >>> front antenna (which is under the floor directly beneath the >>> GX-60) and hook it to the rear antenna connection which is at >>> the same height as the GX-60 and the noise goes away. All of >>> the wires that the GX-60 cable passes are the same in either >>> case except, when it is connected to the front antenna, it >>> crosses these wires at a 90 degree angle instead of running >>> parallel to them when it goes the rear antenna connection. >>> >>> >>> Routing of coax cables to antennas is NEVER >>> a component of received noise . . . in the >>> heavy iron we route coaxes where there is opportunity >>> and room. The whole idea behind the industry standard >>> practices for (1) limiting noise from antagonists, >>> (2) improving resistance to noise by judicious >>> design of potential victims and last (3) reducing >>> risk of over-whelming propagation path (mounting >>> an antenna under the cowl will probably pick up >>> ignition noise). When a noise coming in through >>> the receiver's antenna port is detected, placement >>> of the coax isn't even a distant finisher in the >>> quest for resolution. >>> >>> Assuming you have paid due diligence to standard practices >>> for installing the two antennas then the fact that >>> the forward-most antenna seems to be the key propagation >>> port, then the noise source is most likely forward ON >>> the aircraft. If it were off the aircraft, both >>> antennas would hear it. >>> >>> This problem has a lot in common with Col_Mustard- >>> did-it-in-the-library-with-a-rope . . . you gotta >>> gather all the clues available to you BEFORE picking >>> up hammers-n-saws . . . or screwdrivers. >>> >>> Antennas don't go BAD in a manner that makes one >>> a source of noise while others are not. They either >>> work good . . . or they don't . . . but they're never >>> 'noisy'. Start with a 'cold' panel and bring up >>> equipment one item at a time . . . then confirm >>> your preliminary findings with a sniffer receiver. >>> >>> Only THEN will hammers, saws and screwdrivers >>> contribute to resolution of the problem. >>> >>> >>> Bob . . . >>> >>> ** >>> ** >>> ** >>> ** >>> ** >>> ** >>> ** >>> **http://www.matronics.com/Navigator?AeroElectric-List**** >>> **** >>> **** >>> ***http://forums.matronics.com***** >>> ****** >>> ****** >>> ****** >>> ****** >>> ****http://www.matronics.com/contribution****** >>> ****** >>> ****** >>> ** >>> *D============================================= lectric-List"">http://www.matronics.com/Navigator?AeroElectric-List D============================================= //forums.matronics.com D============================================= ot;">http://www.matronics.com/contribution D============================================= * >>> ** >> http://www.matronics.com/contribution > > > > > ________________________________________________________________________________
Date: Jul 19, 2015
I will try to rig a short antenna. As it is, I get about 6-9 inches from the EFIS to set off the sniffer (a handheld radio) Ross Mickey 541-954-7521 > On Jul 19, 2015, at 3:22 PM, Robert L. Nuckolls, III <nuckolls.bob@aeroele ctric.com> wrote: > > At 02:24 PM 7/19/2015, you wrote: >> >> On 7/19/2015 3:15 PM, Ross Mickey (home) wrote: >> > I have identified that the buzz/static is coming from the new AFS 5600 >> > EFIS I just installed. >> > >> > Now what do I do? > > A number of appliances with LCD screens > were notorious radiators. I think the problems > were centered around the micro-watt dc to ac > converter used to bias up the screen. I'd not > heard of any difficulties in years . . . I > assumed that everyone had figured it out by > now . . . but apparently not. > > The fact that moving wires made difference > suggests that the noises MAY be radiated from > wire bundles as opposed to from the LCD face. > Again, the hand-held transceiver can be used > to 'sniff' around the box . . . much like you > would use a freon leak detector to find a bad > joint. You may want to make a 'special' antenna > for the hand held that is only an inch or so long > so that its not terribly efficient . . . > > > Bob . . . > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Subject: Re: Radio Buzz
Date: Jul 19, 2015
Everything wired as shown in diagrams. My antenna on my handheld is to good so I can't differentiate wires. Ross Mickey 541-954-7521 > On Jul 19, 2015, at 3:06 PM, user9253 wrote: > > > Is the AFS 5600 EFIS wired according to the installation manual? Usually shielded cables are grounded at the source end only, but not always. Can you identify one or more wires from the AFS 5600 EFIS that are causing the noise? > Is the squelch on the com radio adjusted too sensitive? > Joe > > -------- > Joe Gores > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=444951#444951 > > > > > > > > > > ________________________________________________________________________________
Date: Jul 19, 2015
Try it with no antenna at all. If you don't get any noise that way, just stick a short piece of safety wire into the center of the antenna connector & try that. (Don't transmit. :-) ) On 7/19/2015 6:18 PM, Ross Mickey (home) wrote: > > Everything wired as shown in diagrams. My antenna on my handheld is to good so I can't differentiate wires. > > Ross Mickey > 541-954-7521 > > >> On Jul 19, 2015, at 3:06 PM, user9253 wrote: >> >> >> Is the AFS 5600 EFIS wired according to the installation manual? Usually shielded cables are grounded at the source end only, but not always. Can you identify one or more wires from the AFS 5600 EFIS that are causing the noise? >> Is the squelch on the com radio adjusted too sensitive? >> Joe >> >> -------- >> Joe Gores >> ________________________________________________________________________________
Date: Jul 19, 2015
If I dim my Dynon D-180 screen, it makes noise in the headset. I leave the screen on full bright (never fly at night) and the noise is not noticeable. Joe > A number of appliances with LCD screens > were notorious radiators. I think the problems > were centered around the micro-watt dc to ac > converter used to bias up the screen. I'd not > heard of any difficulties in years . . . I > assumed that everyone had figured it out by > now . . . but apparently not. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=444958#444958 ________________________________________________________________________________
Date: Jul 20, 2015
At 05:06 PM 7/19/2015, you wrote: > >Is the AFS 5600 EFIS wired according to the installation >manual? Usually shielded cables are grounded at the source end >only, but not always. Can you identify one or more wires from the >AFS 5600 EFIS that are causing the noise? > Is the squelch on the com radio adjusted too sensitive? As a general rule, no appliance slated to use in airplanes should require ANY special attention on the part of the installer to mitigate a noise issue. The qualification testing for TC aircraft puts your black box out on a copper-top table, wires it up to function stand-alone with no less than 2 meters of "ship's wiring" and it should be neither sensitive to or an emitter of unfriendly energy sources. If any manufacturer suggests 'adding filters, moving wires, adjusting antenna locations, etc. . . they are admitting to their lack of due diligence in design/fabrication of their product. Bob . . . ________________________________________________________________________________
Date: Jul 20, 2015
At 06:16 PM 7/19/2015, you wrote: >I will try to rig a short antenna. As it is, I get about 6-9 inches >from the EFIS to set off the sniffer (a handheld radio) > >Ross Mickey Your zeroing in on the root cause . . . I have an h-t antenna that's only about an inch long with a 1/2" disk soldered to the end. This can be used to probe wires, openings in enclosures, lcd screens, etc. Of course, this only works with noise sources that have strong amplitude modulated components . . . but if you can 'hear' it in your nav-comm, you can generally 'sniff it' with a hand-held. Bob . . . ________________________________________________________________________________
Date: Jul 20, 2015
At 08:00 PM 7/19/2015, you wrote: > >If I dim my Dynon D-180 screen, it makes noise in the headset. I >leave the screen on full bright (never fly at night) and the noise >is not noticeable. >Joe Unfortunately, all too common . . . Bob . . . ________________________________________________________________________________
Subject: Radio Buzz
Date: Jul 20, 2015
With my dumbed down handheld sniffer I have identified the major culprit and perhaps a second. The main interference (80%-90%) is from an 18" piece of unused OAT wire that is plugged into the main harness with pos, signal and shield all pinned in the harness. In talking with AFS tech support, the three options are, 1) connect the pos and signal wires together 2) connect the signal and shield together or 3) unpin all three wires from the harness and remove the whole thing. The second culprit is a couple of the serial port wires (2 of the 4). These are emanating some interference which is probably caused by my error. I connected a black the wire coming out of the premade harness (which is connected to the four shield wires for the serial ports) to ground rather than to the chassis of the EFIS. The new harnesses from AFS (mine is two years old) do not have this but take care of connecting the serial shields to the chassis in the pinning of the harness. I will check these out on Weds when I get back to the hangar. Thank you all for your help. Ross From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Monday, July 20, 2015 6:12 AM Subject: Re: AeroElectric-List: Radio Buzz At 06:16 PM 7/19/2015, you wrote: I will try to rig a short antenna. As it is, I get about 6-9 inches from the EFIS to set off the sniffer (a handheld radio) Ross Mickey Your zeroing in on the root cause . . . I have an h-t antenna that's only about an inch long with a 1/2" disk soldered to the end. This can be used to probe wires, openings in enclosures, lcd screens, etc. Of course, this only works with noise sources that have strong amplitude modulated components . . . but if you can 'hear' it in your nav-comm, you can generally 'sniff it' with a hand-held. Bob . . . http://www.matronics.com/Navigator?AeroElectric-List http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jul 20, 2015
Does the disk make the the "detector" directionally sensitive, like I'm guessing a loop would? Raymond Julian Kettle River, MN The things we admire in men, kindness and generosity, openness, honesty, understanding and feeling are the concomitants of failure in our system. And those traits we detest, sharpness, greed, acquisitiveness, meanness, egotism and self-interest are the traits of success. And while men admire the quality of the first they love the produce of the second. -John Steinbeck, novelist, Nobel laureate (1902-1968) On 07/20/2015 08:12 AM, Robert L. Nuckolls, III wrote: > At 06:16 PM 7/19/2015, you wrote: >> I will try to rig a short antenna. As it is, I get about 6-9 inches >> from the EFIS to set off the sniffer (a handheld radio) >> >> Ross Mickey > > Your zeroing in on the root cause . . . I have > an h-t antenna that's only about an inch long with > a 1/2" disk soldered to the end. This can be used > to probe wires, openings in enclosures, lcd screens, > etc. > > Of course, this only works with noise sources that have > strong amplitude modulated components . . . but if you > can 'hear' it in your nav-comm, you can generally 'sniff > it' with a hand-held. > > > Bob . . . > > * > > > * > ________________________________________________________________________________
Date: Jul 20, 2015
Subject: Radio Buzz
At 11:14 AM 7/20/2015, you wrote: With my dumbed down handheld sniffer I have identified the major culprit and perhaps a second. The main interference (80%-90%) is from an 18" piece of unused OAT wire that is plugged into the main harness with pos, signal and shield all pinned in the harness. In talking with AFS tech support, the three options are, 1) connect the pos and signal wires together 2) connect the signal and shield together or 3) unpin all three wires from the harness and remove the whole thing. I would vote for removing any unused wires from the connector. The second culprit is a couple of the serial port wires (2 of the 4). These are emanating some interference which is probably caused by my error. I connected a black the wire coming out of the premade harness (which is connected to the four shield wires for the serial ports) to ground rather than to the chassis of the EFIS. The new harnesses from AFS (mine is two years old) do not have this but take care of connecting the serial shields to the chassis in the pinning of the harness. Hmmmm . . . there's no good reason for serial wires to radiate. Single wire data at the higher speeds (20-100 kBits/sec) were subject to some electro-static coupling issues but the designers of RS232 transmitters offered connections for a capacitor to slow the transition edges of the data. Twisted pair data architectures eliminated this risk. I'm disappointed that the EFIS designers didn't do a better job of managing this but yes, at VHF, the long pig-tail on the shield ground could add enough impedance to allow those pesky edges to couple out. This may well be an instance where the long pigtail not only added the series impedance, it became the VHF friendly radiator for the noise. I will check these out on Weds when I get back to the hangar. Let us know what you discover . . . be sure to let the supplier know too . . . they MIGHT see fit to fix this at the next upgrade opportunity. Bob . . . ________________________________________________________________________________
Date: Jul 21, 2015
Thanks, everybody=2E =C2- =C2- -- Art Z=2E Sent from my LG tablet so please excuse typos and brevity=2E ________________________________________________________________________________
Subject: Radio Buzz.......................NO More
Date: Jul 23, 2015
Yesterday, I unpinned the 18" piece of unused OAT cable as well as three unused "input" wires that were connected to my AFS 5600 main harness as well as grounding the serial port shield to the chassis. I am happy to say that both radios are clear as a bell. Thank you all for your help in identifying the problem. One step closer to getting my baby back into the air. Ross Mickey From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ross Home Sent: Monday, July 20, 2015 9:14 AM Subject: RE: AeroElectric-List: Radio Buzz With my dumbed down handheld sniffer I have identified the major culprit and perhaps a second. The main interference (80%-90%) is from an 18" piece of unused OAT wire that is plugged into the main harness with pos, signal and shield all pinned in the harness. In talking with AFS tech support, the three options are, 1) connect the pos and signal wires together 2) connect the signal and shield together or 3) unpin all three wires from the harness and remove the whole thing. The second culprit is a couple of the serial port wires (2 of the 4). These are emanating some interference which is probably caused by my error. I connected a black the wire coming out of the premade harness (which is connected to the four shield wires for the serial ports) to ground rather than to the chassis of the EFIS. The new harnesses from AFS (mine is two years old) do not have this but take care of connecting the serial shields to the chassis in the pinning of the harness. I will check these out on Weds when I get back to the hangar. Thank you all for your help. Ross From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Monday, July 20, 2015 6:12 AM Subject: Re: AeroElectric-List: Radio Buzz At 06:16 PM 7/19/2015, you wrote: I will try to rig a short antenna. As it is, I get about 6-9 inches from the EFIS to set off the sniffer (a handheld radio) Ross Mickey Your zeroing in on the root cause . . . I have an h-t antenna that's only about an inch long with a 1/2" disk soldered to the end. This can be used to probe wires, openings in enclosures, lcd screens, etc. Of course, this only works with noise sources that have strong amplitude modulated components . . . but if you can 'hear' it in your nav-comm, you can generally 'sniff it' with a hand-held. Bob . . . http://www.matronics.com/Navigator?AeroElectric-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jul 23, 2015
At 09:42 AM 7/23/2015, you wrote: >Yesterday, I unpinned the 18" piece of unused OAT cable as well as >three unused "input" wires that were connected to my AFS 5600 main >harness as well as grounding the serial port shield to the >chassis. I am happy to say that both radios are clear as a bell. > >Thank you all for your help in identifying the problem. One step >closer to getting my baby back into the air. > >Ross Mickey Thank you for bringing this to the List . . . this has been a useful demonstration of the value for tracking down root cause, propagation mode and mitigation of an unfriendly transfer of energy from one system to another. It's all physics . . . when boiled down to the controlling simple-ideas, the fix becomes simple as well. Our science and art of building and operating successful aircraft is burdened with a lot of guessing, too little understanding and most important, a lack of interest. For most of my tenure at Beech, I was chartered and financed independently of project budgets to track down and identify such things. I wrote perhaps a dozen white papers describing the efforts, discoveries, deductions and remedies for a variety of antagonists . . . some of costing hundreds of thousands of dollars in warranty, re-certification and/or lost customer confidence. But as of this writing, I'll bet any one of those situations could pop up again at the new Textron . . . and nobody would remember that we had been there, done that. They'll struggle through it all over again. This is why it is so important that the any 'new' problem be approached with the same kind of inquiry and deduction that folks are expected to exercise when figuring out that Col-Mustard-did-it-in-the-library-with-a-gun. The processes are identical. Bob . . . ________________________________________________________________________________
Date: Jul 23, 2015
Subject: VOR antenna question
At 06:47 AM 7/22/2015, you wrote: Hi, Bob - I have a 1962 Skylane, and I am not satisfied with its VOR/GS performance at all. Add to that the fact that the autopilot won't track worth a damn, and I'm wondering if the Nav receiver/antenna setup is at fault. How steady is the CDI display when receiving VOR? Are the CDI warning flags lifted? Could you hand-fly the airplane accurately using the display? If so, then it seems unlikely that quality of data from VOR Rx to AP is probably not the issue. If the CDI warning flags are not dropping, then your tracking problem is probably centered elsewhere. I've decided to do a little troubleshooting before I send the S-Tec 55x in for a major (expensive) overhaul.=C2 At the very least, I want to replace the VOR/GS coax and balun (The antenna is a horizontal dipole on the top of the vertical stabilizer, like many 182s). The balun is a typical made-from-coax affair that has never been changed since the airplane was new in 1962, as far as I can tell.=C2 I'm sure it has drowned in water - or at least moisture - for a very long time.=C2 The dipole is then just connected directly to the balun. My questions are these: 1. The first thing is to replace the long run of coax. What coax do you recommend? I know RG 58 will work (50 ohm), but I've heard there are much better, lower-loss cables for this application. Yes. A much more robust and lower loss product like RG141/142/400 is never a bad bet. There are less expensive 50-ohm coaxes with better performance than RG58 like the LMR195, same size and connectors as RG58, similar outside insulation but better shield construction and lower loss insulation around the center conductor . . . but a little fussier to work with than the double-shield, Tef-like products cited earlier. I'd go with 141/142/400 but the 195 is fine too. 2. From what I read, the only purpose of the balun is to keep RF off the braid on the coax; the balun's matching function really doesn't do much for performance. Yes. "Keeping RF of the braid" is a transmitting issue . . and yes, it takes laboratory grade instrumentation and observation methods to deduce any benefits for adding the balun to a VOR antenna. All other things being equal, the pilot would not be able to tell whether or not a balun was installed. Since this is a receive-only setup, do I even need to worry about a balun, or could I just connect my new coax (unbalanced) to the antenna and forget about it? We built thousands of airplanes at Cessna in the 60's and 70's that were wired that way . . . and VOR performance of vacuum tube receivers was deemed adequate. And again, all things being equal, the pilots would not know if a balun was present or not. 3. If you think a balun is worth it, where can I find a decent 1:1 potted balun, so I don't have to worry about fabricating a new coax one? If the airplane's factory-delivered configuration included a balun, then there's always risk of running afoul of the TC-rule-gods. They're easy to build, especially from RF141/142/400 coaxes that will readily stand off the effects of soldering. http://tinyurl.com/yytxwd3 So it's kinda your choice. A fresh hunk of modern coax simply tied to the VOR whiskers will perform nicely. Whether or not this produces better VOR/AP performance is problematic. Bob . . . ________________________________________________________________________________
Date: Jul 23, 2015
Subject: Re: VOR antenna question
Give Kenny Poyner=C2- a call at 817-215-7637 (Cobham) and explain the sit uation to him.=C2- He is a whiz at the S-Tec a/p's and can be very helpfu l.=C2- Bill On Thursday, July 23, 2015 11:05 AM, "Robert L. Nuckolls, III" wrote: At 06:47 AM 7/22/2015, you wrote: Hi, Bob - I have a 1962 Skylane, and I am not satisfied with its VOR/GS performanceat all. Add to that the fact that the autopilot won't track worth a damn,and I'm wondering if the Nav receiver/antenna setup is at fault. =C2-=C2- How steady is the CDI display when receiving VOR? Are =C2-=C2- the CDI warning flags lifted? Could you hand-fly the =C2-=C2- airplane accurately using the display? If so, then =C2-=C2- it seems unlikely that quality of data from VOR Rx =C2-=C2- to AP is probably not the issue. If the =C2-=C2- CDI warning flags are not dropping, then your =C2-=C2- tracking problem is probably centered elsewhere. I've decided to do a little troubleshooting before I send the S-Tec 55xin f or a major (expensive) overhaul.=C3=82=C2- At the very least, I want tore place the VOR/GS coax and balun (The antenna is a horizontal dipole onthe t op of the vertical stabilizer, like many 182s). The balun is a typical made-from-coax affair that has never been changedsin ce the airplane was new in 1962, as far as I can tell.=C3=82=C2- I'm sure it has drowned in water - or at least moisture - for a very longtime.=C3=82 =C2- The dipole is then just connected directly to thebalun. My questions are these: 1. The first thing is to replace the long run of coax. What coax do youreco mmend?=C2- I know RG 58 will work (50 ohm), but I've heard thereare much better, lower-loss cables for this application. =C2-=C2-=C2- Yes. A much more robust and lower loss product =C2-=C2-=C2- like RG141/142/400 is never a bad bet. There =C2-=C2-=C2- are less expensive 50-ohm coaxes with better =C2-=C2-=C2- performance than RG58 like the LMR195, same =C2-=C2-=C2- size and connectors as RG58, similar outside =C2-=C2-=C2- insulation but better shield construction and =C2-=C2-=C2- lower loss insulation around the center =C2-=C2-=C2- conductor . . . but a little fussier to work =C2-=C2-=C2- with than the double-shield, Tef-like products =C2-=C2-=C2- cited earlier. I'd go with 141/142/400 but the =C2-=C2-=C2- 195 is fine too. 2. From what I read, the only purpose of the balun is to keep RF off thebra id on the coax; the balun's matching function really doesn't do muchfor per formance. =C2-=C2-=C2- Yes. "Keeping RF of the braid" is atransmitting =C2-=C2-=C2- issue . .=C2- and yes, it takes laboratorygrade =C2-=C2-=C2- instrumentation and observation methods to =C2-=C2-=C2- deduce any benefits for adding the balun to =C2-=C2-=C2- a VOR antenna.=C2- All other things beingequal, =C2-=C2-=C2- the pilot would not be able to tell whether =C2-=C2-=C2- or not a balun was installed. Since this is a receive-only setup, do I even need to worry about abalun, o r could I just connect my new coax (unbalanced) to the antennaand forget ab out it? =C2-=C2-=C2- We built thousands of airplanes at Cessna in the60's =C2-=C2-=C2- and 70's that were wired that way . . . and VORperforman ce =C2-=C2-=C2- of vacuum tube receivers was deemed adequate. And =C2-=C2-=C2- again, all things being equal, the pilots wouldnot =C2-=C2-=C2- know if a balun was present or not. 3. If you think a balun is worth it, where can I find a decent 1:1 pottedba lun, so I don't have to worry about fabricating a new coaxone? =C2-=C2- If the airplane's factory-delivered configuration =C2-=C2- included a balun, then there's always risk of running =C2-=C2- afoul of the TC-rule-gods. =C2-=C2- They're easy to build, especially from RF141/142/400 =C2-=C2- coaxes that will readily stand off the effects of =C2-=C2- soldering. http://tinyurl.com/yytxwd3 =C2-=C2- So it's kinda your choice. A fresh hunk of modern =C2-=C2- coax simply tied to the VOR whiskers will perform =C2-=C2- nicely. Whether or not this produces better VOR/AP =C2-=C2- performance is problematic. =C2- Bob . . . ________________________________________________________________________________
Date: Jul 23, 2015
At 11:46 AM 7/23/2015, you wrote: >Give Kenny Poyner a call at 817-215-7637 (Cobham) and explain the >situation to him. He is a whiz at the S-Tec a/p's and can be very helpful. >Bill Thanks for the heads-up Bill, I've forwarded the suggestion to Jim . . . >On Thursday, July 23, 2015 11:05 AM, "Robert L. Nuckolls, III" > wrote: > > >At 06:47 AM 7/22/2015, you wrote: >Hi, Bob - > > >I have a 1962 Skylane, and I am not satisfied with its VOR/GS >performance at all. Add to that the fact that the autopilot won't >track worth a damn, and I'm wondering if the Nav receiver/antenna >setup is at fault. Bob . . . ________________________________________________________________________________
Date: Jul 26, 2015
Subject: ARINC 429 wiring practices
I'm in the process of wiring my panel, which includes an old Garmin 430 (non-WAAS), an AFS AF4500S EFIS, AFS ARINC module, and AFS Pilot autopilot. I'm using the AF3000-4000 Installation Guide, v7.4. Looking through the AFS docs, their wiring diagrams are a bit...inconsistent... on how to treat the ARINC and serial port data wiring. So I did some digging in the InterWebs to find the 'proper' way to wire ARINC 429 stuff. Two different sources say to ground the ARINC 429 shield at source, destination, and at every 'break point' where additional receivers are added, in daisy chain fashion. Easy enough; I can handle that. There are 3 ARINC data runs between the ARINC module and the 430. Should each get its own shielded twisted pair, or would it be kosher to run 3 pairs in one shielded cable (and/or variations on that theme)? In various places, there are both single and bi-directional serial runs between/among the EFIS, 430, and other devices. In one case, they specify that a ground return *isn't needed* (obviously depending on system ground(s) between the EFIS & the 430). In most cases, they show a separate ground return wire, *within* the shield of the cable. Now, I'd understand that if the serial lines were 'balanced' (floating return), but all the serial ground returns are electrically bonded to the chassis of the AF4500S. Any noise imposed on the shield goes to exactly the same place inside the unit as the separate ground return. Seems silly to run an extra ground wire that's at the same potential as the shield. Any thoughts on this from those who have either designed or done the actual work on a/c using ARINC 429 and/or serial port technology? Thanks, Charlie ________________________________________________________________________________
Date: Jul 27, 2015
Subject: Re: ARINC 429 wiring practices
From: Christopher Cee Stone <rv8iator(at)gmail.com>
Hello Charlie, My -8 panel is holds a 430W, AF4500, ARINC module, AF3500 and AF-pilot. I followed the AFS wiring schematic exactly. No shielded cables except for the run to the magnetometer and serial port connections. All remaining connections between the ARINC 429 module, the 430 and the AF4500 are AWG22 single wire bundled into a harness with zip ties. I attached the ARINC 429 box to the underside of the AF4500 with self adhering velcro. Thus all signal wire runs are short, less than 24 inches. System works flawlessly. [image: Inline image 2] [image: Inline image 3] Chris Stone RV-8 80802 On Sun, Jul 26, 2015 at 12:11 PM, Charlie England wrote: > I'm in the process of wiring my panel, which includes an old Garmin 430 > (non-WAAS), an AFS AF4500S EFIS, AFS ARINC module, and AFS Pilot > autopilot. I'm using the AF3000-4000 Installation Guide, v7.4. Looking > through the AFS docs, their wiring diagrams are a bit...inconsistent... on > how to treat the ARINC and serial port data wiring. > > So I did some digging in the InterWebs to find the 'proper' way to wire > ARINC 429 stuff. Two different sources say to ground the ARINC 429 shield > at source, destination, and at every 'break point' where additional > receivers are added, in daisy chain fashion. Easy enough; I can handle > that. > > There are 3 ARINC data runs between the ARINC module and the 430. Should > each get its own shielded twisted pair, or would it be kosher to run 3 > pairs in one shielded cable (and/or variations on that theme)? > > In various places, there are both single and bi-directional serial runs > between/among the EFIS, 430, and other devices. In one case, they specify > that a ground return *isn't needed* (obviously depending on system > ground(s) between the EFIS & the 430). In most cases, they show a separate > ground return wire, *within* the shield of the cable. Now, I'd understand > that if the serial lines were 'balanced' (floating return), but all the > serial ground returns are electrically bonded to the chassis of the > AF4500S. Any noise imposed on the shield goes to exactly the same place > inside the unit as the separate ground return. Seems silly to run an extra > ground wire that's at the same potential as the shield. > > Any thoughts on this from those who have either designed or done the > actual work on a/c using ARINC 429 and/or serial port technology? > > Thanks, > > Charlie > > * > > > * > > ________________________________________________________________________________
Date: Jul 27, 2015
I built nav processors for survey planes using several ARINC 429 devices tied together. Twisted pair wire was sufficient although we used shielded. Shielding for differential serial data like that is to reduce electromagnetic interference (transmitted and received) among the other systems, so tying the shield to chassis at one end should be fine. EMI was the only place where we had problems, and in some cases we needed to swap which end was shielded to get the quietest results. Some of our signals used multiple pairs inside one shield and that worked fine. No use for a separate ground wire. David Josephson ________________________________________________________________________________
Date: Jul 27, 2015
> >Any thoughts on this from those who have either designed or done the >actual work on a/c using ARINC 429 and/or serial port technology? ARINC 429 is implemented on aircraft of all sizes wherein local grounds for appliances can be yards apart and serial data is conducted on wires that traverse the wild and wooly environs for all manner of potential antagonist and victim. The short story is that for a single-engine, light aircraft with all the goodies mounted on the panel and sharing local grounds, the risks for loss of serial data signal integrity are zero. There is no value in adding any sort of ground external to a shielded-twisted-pair . . . why anyone would suggest such at thing is a mystery. There is no value in grounding a shield at both ends . . . shields on STP data lines are just that, stop-gaps for electrostatically coupled noises into or out of the lines which are already protected by the physics of twisted, balanced signal paths. Telephone companies have successfully exploited this particular physics in the fabrication and operation of phone lines in bundles with hundreds of other signals and traversing horrible environs over many miles. The twisted, balanced pair is about as bullet proof as you can get without shielding. Ground the shields at either end and only once. Bob . . . ________________________________________________________________________________
Date: Jul 27, 2015
Thanks for the pics. I suspected that the elaborate shielding described in the ARINC docs was a bit of overkill, but I went ahead with actual shielded twisted pair. I'm about 75% done at this point; should have waited a couple of days. :-) Charlie On Mon, Jul 27, 2015 at 9:16 AM, Christopher Cee Stone wrote: > Hello Charlie, > > My -8 panel is holds a 430W, AF4500, ARINC module, AF3500 and AF-pilot. > > I followed the AFS wiring schematic exactly. No shielded cables except > for the run to the magnetometer and serial port connections. All remaining > connections between the ARINC 429 module, the 430 and the AF4500 are AWG22 > single wire bundled into a harness with zip ties. > > I attached the ARINC 429 box to the underside of the AF4500 with self > adhering velcro. Thus all signal wire runs are short, less than 24 inches. > > System works flawlessly. > > > Chris Stone > RV-8 > 80802 > > On Sun, Jul 26, 2015 at 12:11 PM, Charlie England > wrote: > >> I'm in the process of wiring my panel, which includes an old Garmin 430 >> (non-WAAS), an AFS AF4500S EFIS, AFS ARINC module, and AFS Pilot >> autopilot. I'm using the AF3000-4000 Installation Guide, v7.4. Looking >> through the AFS docs, their wiring diagrams are a bit...inconsistent... on >> how to treat the ARINC and serial port data wiring. >> >> So I did some digging in the InterWebs to find the 'proper' way to wire >> ARINC 429 stuff. Two different sources say to ground the ARINC 429 shield >> at source, destination, and at every 'break point' where additional >> receivers are added, in daisy chain fashion. Easy enough; I can handle >> that. >> >> There are 3 ARINC data runs between the ARINC module and the 430. Should >> each get its own shielded twisted pair, or would it be kosher to run 3 >> pairs in one shielded cable (and/or variations on that theme)? >> >> In various places, there are both single and bi-directional serial runs >> between/among the EFIS, 430, and other devices. In one case, they specify >> that a ground return *isn't needed* (obviously depending on system >> ground(s) between the EFIS & the 430). In most cases, they show a separate >> ground return wire, *within* the shield of the cable. Now, I'd understand >> that if the serial lines were 'balanced' (floating return), but all the >> serial ground returns are electrically bonded to the chassis of the >> AF4500S. Any noise imposed on the shield goes to exactly the same place >> inside the unit as the separate ground return. Seems silly to run an extra >> ground wire that's at the same potential as the shield. >> >> Any thoughts on this from those who have either designed or done the >> actual work on a/c using ARINC 429 and/or serial port technology? >> >> Thanks, >> >> Charlie >> >> * >> >> ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List >> tp://forums.matronics.com <http://forums.matronics.com> >> _blank">http://www.matronics.com/contribution >> >> * >> >> > ________________________________________________________________________________
Date: Jul 27, 2015
Thanks to David & Bob. Bob, My question about the 'extra' ground wire was related to the serial port(s), not ARINC. IIRC, serial stuff is typically unbalanced, with a signal line and a shield/ground return. In the case of the AFS docs, they show in one case (to external GPS) a pair of signal wires (bi-directional data), and a ground wire, all wrapped in a shield. In another case (magnetometer) they show a pair of RS422 signal wires, a power wire, and a ground wire, all wrapped in a shield. That's the practice of embedding an extra ground wire inside a shield (when the shield can serve as ground) that I was really questioning. Charlie On Mon, Jul 27, 2015 at 10:23 AM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > > Any thoughts on this from those who have either designed or done the > actual work on a/c using ARINC 429 and/or serial port technology? > > > ARINC 429 is implemented on aircraft of all > sizes wherein local grounds for appliances > can be yards apart and serial data is conducted > on wires that traverse the wild and wooly environs > for all manner of potential antagonist and victim. > > The short story is that for a single-engine, > light aircraft with all the goodies mounted > on the panel and sharing local grounds, the > risks for loss of serial data signal integrity > are zero. > > There is no value in adding any sort of ground > external to a shielded-twisted-pair . . . why > anyone would suggest such at thing is a mystery. > There is no value in grounding a shield at both > ends . . . shields on STP data lines are just that, > stop-gaps for electrostatically coupled noises > into or out of the lines which are already > protected by the physics of twisted, balanced > signal paths. Telephone companies have successfully > exploited this particular physics in the fabrication > and operation of phone lines in bundles with > hundreds of other signals and traversing horrible > environs over many miles. > > The twisted, balanced pair is about as bullet > proof as you can get without shielding. Ground > the shields at either end and only once. > > Bob . . . > > * > > > * > > ________________________________________________________________________________
Date: Jul 30, 2015
At 04:34 PM 7/27/2015, you wrote: Thanks to David & Bob.=C2 Bob, My question about the 'extra' ground wire was related to the serial port(s), not ARINC. IIRC, serial stuff is typically unbalanced, with a signal line and a shield/ground return. In the case of the AFS docs, they show in one case (to external GPS) a pair of signal wires (bi-directional data), and a ground wire, all wrapped in a shield. In another case (magnetometer) they show a pair of RS422 signal wires, a power wire, and a ground wire, all wrapped in a shield. That's the practice of embedding an extra ground wire inside a shield (when the shield can serve as ground) that I was really questioning. The 'extra' wire you're describing . . . is it bare? . . . and what is the nature of the shield material? . . . what you are describing is reminiscent of a product from Belden Wire called "Beldfoil" shielded wire. Instead of braiding strands of wire over the bundle, they wrap an aluminum foil shield over it. VERY effective shielding but electrical connection to thin aluminum is hard to make up. The solution was to bundle a bare stranded wire in with the other wires. Given that it is not insulated, it makes connection with the shielding at innumerable places along the length of the cable. http://tinyurl.com/nhpjmup Given that electro-static shield currents are very low, it matters not that the ground connection to the foil is not gas-tight. Hence, the shield ground has a hi order of integrity to the task and the foil shielding is electro-statically superior and much less expensive than braid . . . a kind of win-win. Unfortunately, this technology is not generally offered in combination with our favorite insulations so you don't see this wire used in TC or military aircraft . . . but it's fine for our purposes. That 'extra' wire CAN be used as a part of the power path as long as it's 22AWG current ratings are observed . . . with the caveat that the return path power wire be included in the bundle so that you get parallel path cancellation for electro-magnetic coupling. But as a general rule, you're almost never wrong to use the shield for electro-static decoupling and attach it to ground one time only at either end. Bob . . . ________________________________________________________________________________
Date: Jul 30, 2015
Understand about Belfoil shielded wire; I've built my share of cables using it in one of my previous lives as a sound engineer & audio tech. It's unrelated to my question. As a reminder, my question is about the AFS *documents*, not actual wire. I should have attached an image of the diagram with the 1st post. Image attached now. See the wiring from the 'EFIS Main Cable' connector to the Nav Radio, Altitude Encoder Output to Transponder, GPS, and Magnetometer. All are shown with a separate ground wire, drawn within the shield. None of the devices draw significant current, and all the 'ground' return pins shown in the EFIS Main Connector are electrically common to the chassis of the EFIS itself. My question is about the 'extra' ground wire, drawn within the shield for each of these destinations. The only connection that does make sense to me is the 'EFIS Audio Output', which logically shows a signal wire and a shield return, without the extra ground wire. On Thu, Jul 30, 2015 at 8:48 AM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 04:34 PM 7/27/2015, you wrote: > Thanks to David & Bob.=C3=82 > > Bob, > > My question about the 'extra' ground wire was related to the serial > port(s), not ARINC. IIRC, serial stuff is typically unbalanced, with a > signal line and a shield/ground return. In the case of the AFS docs, they > show in one case (to external GPS) a pair of signal wires (bi-directional > data), and a ground wire, all wrapped in a shield. In another case > (magnetometer) they show a pair of RS422 signal wires, a power wire, and a > ground wire, all wrapped in a shield. That's the practice of embedding an > extra ground wire inside a shield (when the shield can serve as ground) > that I was really questioning. > > > The 'extra' wire you're describing . . . is it bare? > . . . and what is the nature of the shield material? > > . . . what you are describing is reminiscent > of a product from Belden Wire called "Beldfoil" > shielded wire. Instead of braiding strands of wire > over the bundle, they wrap an aluminum foil shield > over it. VERY effective shielding but electrical > connection to thin aluminum is hard to make up. > > The solution was to bundle a bare stranded wire > in with the other wires. Given that it is not > insulated, it makes connection with the shielding > at innumerable places along the length of the cable. > > http://tinyurl.com/nhpjmup > > Given that electro-static shield currents are > very low, it matters not that the ground connection > to the foil is not gas-tight. Hence, the shield ground > has a hi order of integrity to the task and the foil > shielding is electro-statically superior and much > less expensive than braid . . . a kind of win-win. > Unfortunately, this technology is not generally > offered in combination with our favorite insulations > so you don't see this wire used in TC or military > aircraft . . . but it's fine for our purposes. > > That 'extra' wire CAN be used as a part of the > power path as long as it's 22AWG current ratings > are observed . . . with the caveat that the > return path power wire be included in the bundle > so that you get parallel path cancellation for > electro-magnetic coupling. But as a general rule, > you're almost never wrong to use the shield > for electro-static decoupling and attach it > to ground one time only at either end. > > > Bob . . . > > * > =========== www.matronics.com/Navigator?AeroElectric-List> =========== =========== om/contribution> =========== > > * > > ________________________________________________________________________________
Date: Jul 30, 2015
I just got done installing a 5600. I wired it as shown. Each Serial Port bundle has a RX, TX, Gnd and shield. The shields for the four ports are all connected together at the main harness connector with a black wire coming out of the connector that gets grounded to the chassis. I used whatever TX, RX wires I needed for the particular instrument. I ran all of the Gnd wires to my ground block since that is where all of my instruments are grounded. Everything works great ever since I got rid of the 18=9D length of unused OAT cable. If your question is why they want us to ground each serial port, I can=99t tell you. I just did it. Have you called AFS and asked them? Ross N9PT From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Charlie England Sent: Thursday, July 30, 2015 12:47 PM Subject: Re: AeroElectric-List: ARINC 429 wiring practices Understand about Belfoil shielded wire; I've built my share of cables using it in one of my previous lives as a sound engineer & audio tech. It's unrelated to my question. As a reminder, my question is about the AFS *documents*, not actual wire. I should have attached an image of the diagram with the 1st post. Image attached now. See the wiring from the 'EFIS Main Cable' connector to the Nav Radio, Altitude Encoder Output to Transponder, GPS, and Magnetometer. All are shown with a separate ground wire, drawn within the shield. None of the devices draw significant current, and all the 'ground' return pins shown in the EFIS Main Connector are electrically common to the chassis of the EFIS itself. My question is about the 'extra' ground wire, drawn within the shield for each of these destinations. The only connection that does make sense to me is the 'EFIS Audio Output', which logically shows a signal wire and a shield return, without the extra ground wire. On Thu, Jul 30, 2015 at 8:48 AM, Robert L. Nuckolls, III > wrote: At 04:34 PM 7/27/2015, you wrote: Thanks to David & Bob.=C3=82 Bob, My question about the 'extra' ground wire was related to the serial port(s), not ARINC. IIRC, serial stuff is typically unbalanced, with a signal line and a shield/ground return. In the case of the AFS docs, they show in one case (to external GPS) a pair of signal wires (bi-directional data), and a ground wire, all wrapped in a shield. In another case (magnetometer) they show a pair of RS422 signal wires, a power wire, and a ground wire, all wrapped in a shield. That's the practice of embedding an extra ground wire inside a shield (when the shield can serve as ground) that I was really questioning. The 'extra' wire you're describing . . . is it bare? . . . and what is the nature of the shield material? . . . what you are describing is reminiscent of a product from Belden Wire called "Beldfoil" shielded wire. Instead of braiding strands of wire over the bundle, they wrap an aluminum foil shield over it. VERY effective shielding but electrical connection to thin aluminum is hard to make up. The solution was to bundle a bare stranded wire in with the other wires. Given that it is not insulated, it makes connection with the shielding at innumerable places along the length of the cable. http://tinyurl.com/nhpjmup Given that electro-static shield currents are very low, it matters not that the ground connection to the foil is not gas-tight. Hence, the shield ground has a hi order of integrity to the task and the foil shielding is electro-statically superior and much less expensive than braid . . . a kind of win-win. Unfortunately, this technology is not generally offered in combination with our favorite insulations so you don't see this wire used in TC or military aircraft . . . but it's fine for our purposes. That 'extra' wire CAN be used as a part of the power path as long as it's 22AWG current ratings are observed . . . with the caveat that the return path power wire be included in the bundle so that you get parallel path cancellation for electro-magnetic coupling. But as a general rule, you're almost never wrong to use the shield for electro-static decoupling and attach it to ground one time only at either end. Bob . . . ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jul 30, 2015
I haven't asked them yet, because I already have a strong suspicion of what their answer will be: 'to shield the ground from noise'. Serial data needs a ground return, but since the ground return pins in the connector are all bonded to the case of the EFIS, any noise on the shield is also on those ground return pins. Which begs the question: why have the extra ground wire? My suspicion is that they are following some 'certified aircraft' practice that was started back in mythological times and hasn't been updated with current knowledge. That's why I've been asking here; we've seen other 'stuff' in certified a/c that can be done better or simpler, based on current knowledge. Glad to hear that you've got yours working noise-free. Charlie On Thu, Jul 30, 2015 at 3:48 PM, Ross Home wrote: > I just got done installing a 5600. I wired it as shown. Each Serial Por t > bundle has a RX, TX, Gnd and shield. The shields for the four ports are > all connected together at the main harness connector with a black wire > coming out of the connector that gets grounded to the chassis. I used > whatever TX, RX wires I needed for the particular instrument. I ran all of > the Gnd wires to my ground block since that is where all of my instrument s > are grounded. Everything works great ever since I got rid of the 18 =9D > length of unused OAT cable. > > > If your question is why they want us to ground each serial port, I can =99t > tell you. I just did it. Have you called AFS and asked them? > > > Ross > > N9PT > > > *From:* owner-aeroelectric-list-server(at)matronics.com [mailto: > owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of *Charlie > England > *Sent:* Thursday, July 30, 2015 12:47 PM > *To:* aeroelectric-list(at)matronics.com > *Subject:* Re: AeroElectric-List: ARINC 429 wiring practices > > > Understand about Belfoil shielded wire; I've built my share of cables > using it in one of my previous lives as a sound engineer & audio tech. It 's > unrelated to my question. As a reminder, my question is about the AFS > *documents*, not actual wire. I should have attached an image of the > diagram with the 1st post. Image attached now. > > > See the wiring from the 'EFIS Main Cable' connector to the Nav Radio, > Altitude Encoder Output to Transponder, GPS, and Magnetometer. All are > shown with a separate ground wire, drawn within the shield. None of the > devices draw significant current, and all the 'ground' return pins shown in > the EFIS Main Connector are electrically common to the chassis of the EFI S > itself. My question is about the 'extra' ground wire, drawn within the > shield for each of these destinations. > > > The only connection that does make sense to me is the 'EFIS Audio Output' , > which logically shows a signal wire and a shield return, without the extr a > ground wire. > > > On Thu, Jul 30, 2015 at 8:48 AM, Robert L. Nuckolls, III < > nuckolls.bob(at)aeroelectric.com> wrote: > > At 04:34 PM 7/27/2015, you wrote: > Thanks to David & Bob.=C3=82 > > Bob, > > My question about the 'extra' ground wire was related to the serial > port(s), not ARINC. IIRC, serial stuff is typically unbalanced, with a > signal line and a shield/ground return. In the case of the AFS docs, they > show in one case (to external GPS) a pair of signal wires (bi-directional > data), and a ground wire, all wrapped in a shield. In another case > (magnetometer) they show a pair of RS422 signal wires, a power wire, and a > ground wire, all wrapped in a shield. That's the practice of embedding an > extra ground wire inside a shield (when the shield can serve as ground) > that I was really questioning. > > > The 'extra' wire you're describing . . . is it bare? > . . . and what is the nature of the shield material? > > . . . what you are describing is reminiscent > of a product from Belden Wire called "Beldfoil" > shielded wire. Instead of braiding strands of wire > over the bundle, they wrap an aluminum foil shield > over it. VERY effective shielding but electrical > connection to thin aluminum is hard to make up. > > The solution was to bundle a bare stranded wire > in with the other wires. Given that it is not > insulated, it makes connection with the shielding > at innumerable places along the length of the cable. > > http://tinyurl.com/nhpjmup > > Given that electro-static shield currents are > very low, it matters not that the ground connection > to the foil is not gas-tight. Hence, the shield ground > has a hi order of integrity to the task and the foil > shielding is electro-statically superior and much > less expensive than braid . . . a kind of win-win. > Unfortunately, this technology is not generally > offered in combination with our favorite insulations > so you don't see this wire used in TC or military > aircraft . . . but it's fine for our purposes. > > That 'extra' wire CAN be used as a part of the > power path as long as it's 22AWG current ratings > are observed . . . with the caveat that the > return path power wire be included in the bundle > so that you get parallel path cancellation for > electro-magnetic coupling. But as a general rule, > you're almost never wrong to use the shield > for electro-static decoupling and attach it > to ground one time only at either end. > > > Bob . . . > > > *ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-L ist <http://www.matronics.com/Navigator?AeroElectric-List>* > > *tp://forums.matronics.com <http://forums.matronics.com>* > > *_blank">http://www.matronics.com/contribution * > > > * > =========== www.matronics.com/Navigator?AeroElectric-List> =========== =========== om/contribution> =========== > > * > > ________________________________________________________________________________
Date: Jul 31, 2015
Subject: grounding mag p lead shield...which side?
switch side or mag side? ________________________________________________________________________________
Subject: Re: grounding mag p lead shield...which side?
Date: Jul 31, 2015
On 7/31/2015 6:01 AM, Bob Verwey wrote: > switch side or mag side? > Suspend normal thought about shields when looking at magnetos. The shield is the return path to short out the mag when the mag switch is 'off' (note the quotes). http://www.aeroelectric.com/articles/MagnetoSwitchOptions.pdf Center conductor to the points in the mag, shield grounded to the mag case. At the other end, center conductor to one terminal of your mag switch, and the shield to the other terminal. When the switch is *closed* (continuity across the terminals), the mag is *off*. When the switch is *open* (off, in normal terminology), the mag is *on*. ________________________________________________________________________________
Date: Jul 31, 2015
Correct: that is why we are told (this side of the pond anyway) during our t raining to treat the prop as always being live, just in case the grounded ( mag switches in the off position) wire 'isn't' grounded John Sent from my iPad ----x--O--x---- > On 31 Jul 2015, at 02:43 pm, Charlie England wrote: > >> On 7/31/2015 6:01 AM, Bob Verwey wrote: >> switch side or mag side? > Suspend normal thought about shields when looking at magnetos. > > The shield is the return path to short out the mag when the mag switch is ' off' (note the quotes). > http://www.aeroelectric.com/articles/MagnetoSwitchOptions.pdf > > Center conductor to the points in the mag, shield grounded to the mag case . > > At the other end, center conductor to one terminal of your mag switch, and the shield to the other terminal. When the switch is *closed* (continuity a cross the terminals), the mag is *off*. When the switch is *open* (off, in n ormal terminology), the mag is *on*. > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Jul 31, 2015
I should have added: Be sure to check the switch for 'closed' position (continuity between terminals) *before* hooking up the mag wires. A regular ohm meter can't tell the difference between shorted terminals of the switch turned on, and the very low DC resistance of the mag's coil primary winding (that's where the P-leads are connected) when the switch is switched open. If you're using regular SPST toggle switches as mag switches, just mount them 'upside down' so that the switch's 'on' label is on the bottom. On 7/31/2015 8:59 AM, John Tipton wrote: > Correct: that is why we are told (this side of the pond anyway) during > our training to treat the prop as always being live, just in case the > grounded (mag switches in the off position) wire 'isn't' grounded > > John > > Sent from my iPad > > ----x--O--x---- > > On 31 Jul 2015, at 02:43 pm, Charlie England > wrote: > >> On 7/31/2015 6:01 AM, Bob Verwey wrote: >>> switch side or mag side? >>> >> Suspend normal thought about shields when looking at magnetos. >> >> The shield is the return path to short out the mag when the mag >> switch is 'off' (note the quotes). >> http://www.aeroelectric.com/articles/MagnetoSwitchOptions.pdf >> >> Center conductor to the points in the mag, shield grounded to the mag >> case. >> >> At the other end, center conductor to one terminal of your mag >> switch, and the shield to the other terminal. When the switch is >> *closed* (continuity across the terminals), the mag is *off*. When >> the switch is *open* (off, in normal terminology), the mag is *on*. >> ** > --> http://www.matronics.com/Navigator?AeroElectric-List > http://www.matronics.com/contribution > <3D%22http://www.matronics.com/contribution%22> > * ________________________________________________________________________________
Date: Aug 01, 2015
Thats why I love this list! Thanks Charlie! On Friday, July 31, 2015, Charlie England wrote: > On 7/31/2015 6:01 AM, Bob Verwey wrote: > > switch side or mag side? > > Suspend normal thought about shields when looking at magnetos. > > The shield is the return path to short out the mag when the mag switch is > 'off' (note the quotes). > http://www.aeroelectric.com/articles/MagnetoSwitchOptions.pdf > > Center conductor to the points in the mag, shield grounded to the mag case. > > At the other end, center conductor to one terminal of your mag switch, and > the shield to the other terminal. When the switch is *closed* (continuity > across the terminals), the mag is *off*. When the switch is *open* (off, in > normal terminology), the mag is *on*. > > * > > > * > > -- Best... Bob Verwey ________________________________________________________________________________
Subject: Re: RG400 Splice
Date: Aug 02, 2015
I may have a need to lengthen two of the four antenna cables to my Ryan TCAD9900B by approximately 6. Short of fabricating an extension with connectors on each end, would it be preferable to splice directly to the existing cables? Thanks N4ZQ ________________________________________________________________________________
Date: Aug 02, 2015
If you can't find 6" of slack to pull from somewhere in the airframe you're stuck. You might be able to reroute the cables to get the extra 6". Here's a whole lot of technical reasons why you should replace all your cables (not splice them) if that's what you need to do; 1) According to the installation manual all four cables MUST be the same length. Changing the length of just two of the cables is going to make target bearing inaccurate. The TCAD uses signal arrival time (phase) to determine the bearing to the target. changing a cables length will change the length of time it takes a signal to get through that cable retaliative to the time the same signal takes to get through the other cables. The cables need to have 3.0 dB of loss +/-0.5 dB. The TCAD uses relative signal strength to determine the range to the target. Without using connectors it is nearly impossible to keep a constant impedance. A soldered splice just won't work well at these frequencies. In addition, the reflections caused by the impedance mismatch is going to add additional loss and may create ghost aircraft. I'm not sure about the ghosts but seems like a possibility given what the TCAD is trying to do. Splicing the additional cable will add 4 more connectors per cable. Good quality connectors rated for operation at these frequencies that are properly installed will add about 0.11 dB per connector for a total of 0.44 dB. Getting real close to the 0.5 dB tolerance you have in the spec for the cables. Of course you don't know how much of that tolerance (or in which direction, + or -) has been used by the original installer. The installation manual doesn't talk about fabricating these cables but rather lists prefabricated cable sets that are compatible. My guess that they want the cables manufactured and tested as a set with a network analyzer so that they know that the cables are of equal length (electrical phase-wise) and equal loss at the 3 dB spec. Piecing out the cable length with homemade extensions seems like a bad idea to me. You're taking a very expensive piece of avionics and sacrificing it's accuracy for the price of a new cable set. Bill On 8/2/15 06:42, Greenbacks, UnLtd. wrote: > > I may have a need to lengthen two of the four antenna cables to my Ryan TCAD9900B by approximately 6. > Short of fabricating an extension with connectors on each end, would it be preferable to splice directly to the existing cables? > > Thanks > > N4ZQ > > ________________________________________________________________________________
Subject: Contactor or master switch problem?
Date: Aug 02, 2015
I have been having some starting and electrical issues which I think may involve the master switch or the battery contactor. My son and I were going out flying one day last week, had preflighted the plane, and after we pulled the plane from the hanger we switched on the master switch. The electronics came on briefly and then faded away. There was no power for the starter. I thought that was odd because the plane normally has charger attached while in the hanger. The Odyssey specific charger indicated the battery was charged. After a quick trip home to find a volt meter we tested the voltage which was 13+v. We had the charger on while we gone so the reading was skewed because of that. We pulled the plane out and the electronics and starter worked normally. On Sat., I flew 8 trips of Young Eagles with no starting or electrical problems. After the event was over, a trip to the fuel pump had the electronics working but the starter contactor clicking but no prop rotation. I cycled the master switch several times and finally the engine turned over like nothing was wrong. I have a 1200 nm trip coming up soon so I need an answer so there are no problems along the way. The battery is a PC680 about 2 years old. The master switch (Carling) and battery contactor (B&C) are about 7 years old and have around 630 hours. Apparently the volts and amps are there but getting choked off before they can do their work. Right now, my thought is to replace them both, but especially the master switch, due to my impending trip. Any thoughts, better ideas or am I missing something? Sheldon Olesen Sent from my iPad ________________________________________________________________________________
Subject: Re: Q?Re:_AeroElectric-List:_Contactor_or_master_switch_problem=3F?
Date: Aug 02, 2015
DQoNCg0KDQoNCg0KDQpJIGhhdmUgYmVlbiBoYXZpbmcgc29tZSBzdGFydGluZyBhbmQgZWxlY3Ry aWNhbCBpc3N1ZXMgd2hpY2ggSSB0aGluayBtYXkgaW52b2x2ZSB0aGUgbWFzdGVyIHN3aXRjaCBv ciB0aGUgYmF0dGVyeSBjb250YWN0b3IuDQoNCk15IHNvbiBhbmQgSSB3ZXJlIGdvaW5nIG91dCBm bHlpbmcgb25lIGRheSBsYXN0IHdlZWssIGhhZCBwcmVmbGlnaHRlZCB0aGUgcGxhbmUsIGFuZCBh ZnRlciB3ZSBwdWxsZWQgdGhlIHBsYW5lIGZyb20gdGhlIGhhbmdlciB3ZSBzd2l0Y2hlZCBvbiB0 aGUgbWFzdGVyIHN3aXRjaC4gIFRoZSBlbGVjdHJvbmljcyBjYW1lIG9uIGJyaWVmbHkgYW5kIHRo ZW4gZmFkZWQgYXdheS4gIFRoZXJlIHdhcyBubyBwb3dlciBmb3IgdGhlIHN0YXJ0ZXIuICBJIHRo b3VnaHQgdGhhdCB3YXMgb2RkIGJlY2F1c2UgdGhlIHBsYW5lIG5vcm1hbGx5IGhhcyBjaGFyZ2Vy IGF0dGFjaGVkIHdoaWxlIGluIHRoZSBoYW5nZXIuICBUaGUgT2R5c3NleSBzcGVjaWZpYyBjaGFy Z2VyIGluZGljYXRlZCB0aGUgYmF0dGVyeSB3YXMgY2hhcmdlZC4gIEFmdGVyIGEgcXVpY2sgdHJp cCBob21lIHRvIGZpbmQgYSB2b2x0IG1ldGVyIHdlIHRlc3RlZCB0aGUgdm9sdGFnZSB3aGljaCB3 YXMgMTMrdi4gIFdlIGhhZCB0aGUgY2hhcmdlciBvbiB3aGlsZSB3ZSBnb25lIHNvIHRoZSByZWFk aW5nIHdhcyBza2V3ZWQgYmVjYXVzZSBvZiB0aGF0LiAgV2UgcHVsbGVkIHRoZSBwbGFuZSBvdXQg YW5kIHRoZSBlbGVjdHJvbmljcyBhbmQgc3RhcnRlciB3b3JrZWQgbm9ybWFsbHkuICANCg0KT24g U2F0LiwgIEkgZmxldyA4IHRyaXBzIG9mIFlvdW5nIEVhZ2xlcyB3aXRoIG5vIHN0YXJ0aW5nIG9y IGVsZWN0cmljYWwgcHJvYmxlbXMuICBBZnRlciB0aGUgZXZlbnQgd2FzIG92ZXIsIGEgdHJpcCB0 byB0aGUgZnVlbCBwdW1wIGhhZCB0aGUgZWxlY3Ryb25pY3Mgd29ya2luZyBidXQgdGhlIHN0YXJ0 ZXIgY29udGFjdG9yIGNsaWNraW5nIGJ1dCBubyBwcm9wIHJvdGF0aW9uLiAgSSBjeWNsZWQgdGhl IG1hc3RlciBzd2l0Y2ggc2V2ZXJhbCB0aW1lcyBhbmQgZmluYWxseSB0aGUgZW5naW5lIHR1cm5l ZCBvdmVyIGxpa2Ugbm90aGluZyB3YXMgd3JvbmcuICBJIGhhdmUgYSAxMjAwIG5tIHRyaXAgY29t aW5nIHVwIHNvb24gc28gSSBuZWVkIGFuIGFuc3dlciBzbyB0aGVyZSBhcmUgbm8gcHJvYmxlbXMg YWxvbmcgdGhlIHdheS4NCg0KVGhlIGJhdHRlcnkgaXMgYSBQQzY4MCBhYm91dCAyIHllYXJzIG9s ZC4gIFRoZSBtYXN0ZXIgc3dpdGNoIChDYXJsaW5nKSBhbmQgYmF0dGVyeSBjb250YWN0b3IgKEIm QykgYXJlIGFib3V0IDcgeWVhcnMgb2xkIGFuZCBoYXZlIGFyb3VuZCA2MzAgaG91cnMuICBBcHBh cmVudGx5IHRoZSB2b2x0cyBhbmQgYW1wcyBhcmUgdGhlcmUgYnV0IGdldHRpbmcgY2hva2VkIG9m ZiBiZWZvcmUgdGhleSBjYW4gZG8gdGhlaXIgd29yay4gUmlnaHQgbm93LCBteSB0aG91Z2h0IGlz IHRvIHJlcGxhY2UgdGhlbSBib3RoLCBidXQgZXNwZWNpYWxseSB0aGUgbWFzdGVyIHN3aXRjaCwg ZHVlIHRvIG15IGltcGVuZGluZyB0cmlwLiAgQW55IHRob3VnaHRzLCBiZXR0ZXIgaWRlYXMgb3Ig YW0gSSBtaXNzaW5nIHNvbWV0aGluZz8NCg0KDQoNCg0KSSBoYWQgYSBzaW1pbGFyIHByb2JsZW0g YSBjb3VwbGUgb2YgeWVhcnMgYmFjay4gIEkgd291bGQgaGF2ZSB0byB0dXJuIHRoZSBtYXN0ZXIg b24gYW5kIG9mZiBzZXZlcmFsIHRpbWVzIHRvIGdldCBwb3dlciB0byB0aGUgc3RhcnRlciBhbmQg ZWxlY3Ryb25pY3MuICBPbmNlIHRoZSBwb3dlciBjYW1lIHVwIGl0IHdvdWxkIHJ1biBmbGF3bGVz c2x5IHVudGlsIHRoZSBuZXh0IHRpbWUgSSB0cmllZCB0byBzdGFydCBpdC4NCg0KDQpUaGUgcHJv YmxlbSB0dXJuZWQgb3V0IHRvIGJlIGEgYmFkLCBpbnRlcm5hbCBjb250YWN0IGNvcnJvc2lvbiwg bWFzdGVyIHNvbGVub2lkLiAgSSByZXBsYWNlZCBpdCBhbmQgdGhlIHByb2JsZW0gd2VudCBhd2F5 IGNvbXBsZXRlbHkuICBBZnRlciBJIHJlcGxhY2VkIGl0IEkgc2VudCB0aGUgZGVmZWN0aXZlIHVu aXQgdG8gQm9iIE4gYW5kIGhlIGRpc3NlY3RlZCBpdCwgdG9vayBwaWN0dXJlcywgYW5kIHBvc3Rl ZCBvbiB0aGlzIGZvcnVtLiAgSXQgaXMgbGlrZWx5IHRoYXQgeW91IGhhdmUgYSBzaW1pbGFyIHBy b2JsZW0uDQoNCg0KUm9nZXI ________________________________________________________________________________
Date: Aug 03, 2015
Hello Sheldon, Before changing anything, I suggest you carry out a thorough check of the connections to all of the relevant components, especially those of the battery terminals, the starter and the ground returns. Look particularly at the braided grounding strap between the engine and the battery negative. Your time of 630 hours is not particularly high for the master switch and battery contactor, but if the connections all check out then you could change the component that is more difficult to access in the field and take with you a spare for the other. This would give you a chance to find out which is giving the trouble without having too much of a problem to fix on your long trip. Good luck! Mike -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Sheldon Olesen Sent: 02 August 2015 22:10 Subject: AeroElectric-List: Contactor or master switch problem? --> I have been having some starting and electrical issues which I think may involve the master switch or the battery contactor. My son and I were going out flying one day last week, had preflighted the plane, and after we pulled the plane from the hanger we switched on the master switch. The electronics came on briefly and then faded away. There was no power for the starter. I thought that was odd because the plane normally has charger attached while in the hanger. The Odyssey specific charger indicated the battery was charged. After a quick trip home to find a volt meter we tested the voltage which was 13+v. We had the charger on while we gone so the reading was skewed because of that. We pulled the plane out and the electronics and starter worked normally. On Sat., I flew 8 trips of Young Eagles with no starting or electrical problems. After the event was over, a trip to the fuel pump had the electronics working but the starter contactor clicking but no prop rotation. I cycled the master switch several times and finally the engine turned over like nothing was wrong. I have a 1200 nm trip coming up soon so I need an answer so there are no problems along the way. The battery is a PC680 about 2 years old. The master switch (Carling) and battery contactor (B&C) are about 7 years old and have around 630 hours. Apparently the volts and amps are there but getting choked off before they can do their work. Right now, my thought is to replace them both, but especially the master switch, due to my impending trip. Any thoughts, better ideas or am I missing something? Sheldon Olesen Sent from my iPad ________________________________________________________________________________
Subject: Re: Contactor or master switch problem?
Date: Aug 02, 2015
On 8/2/2015 5:58 PM, rnjcurtis(at)charter.net wrote: > > > ** > > I have been having some starting and electrical issues which I think > may involve the master switch or the battery contactor. > > My son and I were going out flying one day last week, had preflighted > the plane, and after we pulled the plane from the hanger we switched > on the master switch. The electronics came on briefly and then faded > away. There was no power for the starter. I thought that was odd > because the plane normally has charger attached while in the hanger. > The Odyssey specific charger indicated the battery was charged. After > a quick trip home to find a volt meter we tested the voltage which was > 13+v. We had the charger on while we gone so the reading was skewed > because of that. We pulled the plane out and the electronics and > starter worked normally. > > On Sat., I flew 8 trips of Young Eagles with no starting or > electrical problems. After the event was over, a trip to the fuel > pump had the electronics working but the starter contactor clicking > but no prop rotation. I cycled the master switch several times and > finally the engine turned over like nothing was wrong. I have a 1200 > nm trip coming up soon so I need an answer so there are no problems > along the way. > > The battery is a PC680 about 2 years old. The master switch (Carling) > and battery contactor (B&C) are about 7 years old and have around 630 > hours. Apparently the volts and amps are there but getting choked off > before they can do their work. Right now, my thought is to replace > them both, but especially the master switch, due to my impending > trip. Any thoughts, better ideas or am I missing something? > > I had a similar problem a couple of years back. I would have > to turn the master on and off several times to get power to > the starter and electronics. Once the power came up it would > run flawlessly until the next time I tried to start it. > > The problem turned out to be a bad, internal > contact corrosion, master solenoid. I replaced it and the > problem went away completely. After I replaced it I sent the > defective unit to Bob N and he dissected it, took pictures, > and posted on this forum. It is likely that you have a > similar problem. > > Roger > I'd probably vote with Roger. If you hear the master contactor 'clack' with its normal sound every time you flip the master switch, then the switch is almost certainly doing its job properly. The 'clack' means that the master switch is sending activation current to the contactor, and the solenoid in the contactor is moving the contacts together (the clack). That leaves the contacts themselves, assuming that you've checked all the connections, including ground side connections. Charlie ________________________________________________________________________________
Date: Aug 02, 2015
My guess is the contactor is at fault. Once a contactor is energized, it does not take as much current to hold it closed. If the master switch conducted enough current to energize the contactor, then the switch should be able to hold the contactor closed. But if you replace both, there is no guessing. Also check the terminals on the fat wires, including the battery ground. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=445525#445525 ________________________________________________________________________________
Date: Aug 03, 2015
I'm with everyone else, and bet your problems are related to the contactor. I have had numerous contractors fail over the years. This is the reason I decided to go with the solid state master relay. Cost was higher but the weight is similar and it works flawlessly so far. No more "click" means no more arcing and worn out mechanical components. Solid state relays are known to last for millions of cycles. More than we could ever do. The peace of mind alone is worth the added cost. By the time you buy 2 contactors, you have paid for this unit. I was worried at first that it would not charge the battery through the relay but that proved to be no factor. It charges fine. So far, I am very happy with it. Rated at: 12.5V DC 300A continuous 500A (1sec) inrush Seems robust enough so far. http://www.waytekwire.com/item/44407/300A-Solid-State-Battery/ Data Sheet: http://www.waytekwire.com/datasheet/44407.pdf Justin > On Aug 2, 2015, at 23:14, user9253 wrote: > > > My guess is the contactor is at fault. Once a contactor is energized, it does not take as much current to hold it closed. If the master switch conducted enough current to energize the contactor, then the switch should be able to hold the contactor closed. But if you replace both, there is no guessing. > Also check the terminals on the fat wires, including the battery ground. > Joe > > -------- > Joe Gores > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=445525#445525 > > > > > > > > > > ________________________________________________________________________________
Date: Aug 03, 2015
> I may have a need to lengthen two of the four antenna cables to my Ryan TCAD9900B by approximately 6. Short of fabricating an extension with connectors on each end, would it be preferable to splice directly to the existing cables? N4ZQ I'd follow Bill's suggestions, but if it absolutely has to be lengthened there are connectors to do it properly. There are good You Tube videos online regarding this. But whatever you do, remember that the RF signal is carried in the insulation, NOT the center conductor nor the shield! This makes all other joining schemes problematic. See my attached "Dabbling with Electricity" for this and other matters. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=445533#445533 Attachments: http://forums.matronics.com//files/dabbling_with_electricity_868.pdf ________________________________________________________________________________
Subject: crimping question
Date: Aug 05, 2015
Best practices or caveats? When needing to put multiple wires to a single Faston type connector... do you butt splice multiple wires then use single lead to Faston spade or bring multiple wires into the Faston female connector and crimp? Thanks for indulging me... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=445622#445622 ________________________________________________________________________________
Subject: Re: crimping question
Date: Aug 05, 2015
Like many things, it depends. Two, three or maybe four (depends on the wire size), and I'll put them all in a single connector. If they don't fit, I like to splice the wires into a single lead. But again, it depends on the size of the wires and their purpose. Six 20AWG wires supplying devices that are on all the time probably wouldn't work well spliced into a single 20AWG wire. But something like ground wires going to momentary switches would be okay. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=445624#445624 ________________________________________________________________________________
Date: Aug 05, 2015
> But whatever you do, remember that the RF signal is carried in the insulation, NOT the center conductor nor the shield! This is the kind of stuff that makes my head explode. :( You're saying the signal is carried by the thing that is not supposed to conduct electricity? And I'm not doubting you. It's just that makes as much sense (to me) as my car battery being jammed full of AAA's. [Laughing] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=445625#445625 ________________________________________________________________________________
Date: Aug 05, 2015
> You're saying the signal is carried by the thing that is not supposed to conduct electricity? Don Johnson The signal (which is obviously the important stuff) is DRIVEN by the "wave guide" which is the metal parts, but transmitted inside the wave guide...which is the insulation. It turns out that the wave velocity is exactly the same as the speed of light inside the insulating material-- Vacuum, Teflon or PE for example. I point this out to make sure that builders understand the reason for proper termination (which includes joints) of the coaxial cable. I can't be "pig-tailed" at high frequencies without enormous loss of signal strength. At low frequencies (like audio) it just doesn't matter. Electricity is strange. Please read my "Dabbling with Electricity". -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=445627#445627 ________________________________________________________________________________
Date: Aug 06, 2015
Those videos are great. This is what prompted my statement. https://www.youtube.com/watch?v=s_8n2Qgguto Read this topic online here: http://forums.matronics.com/viewtopic.php?p=445641#445641 ________________________________________________________________________________
Date: Aug 06, 2015
I think it depends on the type/size of wire and type/size of fastener. A better solution might be ring type fasteners on a post ---- blues750 wrote: > > Best practices or caveats? When needing to put multiple wires to a single Faston type connector... do you butt splice multiple wires then use single lead to Faston spade or bring multiple wires into the Faston female connector and crimp? > > Thanks for indulging me... > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=445622#445622 > > ________________________________________________________________________________
Date: Aug 06, 2015
At 06:56 PM 8/5/2015, you wrote: > > > > You're saying the signal is carried by the thing that is not > supposed to conduct electricity? Don Johnson > > >The signal (which is obviously the important stuff) is DRIVEN by the >"wave guide" which is the metal parts, but transmitted inside the >wave guide...which is the insulation. It turns out that the wave >velocity is exactly the same as the speed of light inside the >insulating material-- Vacuum, Teflon or PE for example. There is no parallel between coaxial transmission lines and waveguide. Transmission lines are metallic conductors with predictable surge impedance and velocity factor that is constant with frequency. Waveguides are as their name suggests, pipes for the conduct of electromagnetic energy, a constriction of free space that allows one to direct the energy from the antenna (a little radiator at one end of the 'pipe' over some distance and around corners before it is launched into free space . . . usually at the focal point of some reflective dish. A wave traversing the length of a guide literally reflects from wall-to-wall and in a manner that is influenced by the size and shape of the guide with respect to the operating frequency. Waveguide also exhibits a 'velocity factor' which is a function size and operating frequency. As one squirts energy down a wave guide in lower frequencies, the velocity factor increases until at some lower limit (cutoff frequency) the velocity factor is for all practical purposes infinite and no energy makes it down the pipe. Coax cable exhibits no such characteristic in that it's a conductor constrained within a die-electric and waveguide is a simple constriction of free space. Losses in waveguide and coax are separate operators. Bob . . . ________________________________________________________________________________
Date: Aug 06, 2015
At 03:25 PM 8/5/2015, you wrote: > >Best practices or caveats? When needing to put multiple wires to a >single Faston type connector... do you butt splice multiple wires >then use single lead to Faston spade or bring multiple wires into >the Faston female connector and crimp? > >Thanks for indulging me... See http://tinyurl.com/l67uj8h The practical limits for multiple wires into single joints are driven by TOTAL cross section of copper in the wire-grip must be within the terminal's design limits. TOTAL cross section of insulation in cannot exceed terminal design limits but ther is a lot of leeway there. Some tools feature user adjustments to the insulation-grip dies to accommodate a range of volumes. http://tinyurl.com/93yweyd Finally, TOTAL current through the pathway's highest resistance MIGHT be a factor for temperature rise in the conductor . . . but this is rarely a concern. It matters not what kind of device is accepting multiple wires, they're all constrained by the same factors. Bob . . . ________________________________________________________________________________
Date: Aug 06, 2015
At 04:10 PM 8/2/2015, you wrote: > > >I have been having some starting and electrical issues which I think >may involve the master switch or the battery contactor. > >My son and I were going out flying one day last week, had >preflighted the plane, and after we pulled the plane from the hanger >we switched on the master switch. The electronics came on briefly >and then faded away. There was no power for the starter. I thought >that was odd because the plane normally has charger attached while >in the hanger. The Odyssey specific charger indicated the battery >was charged. After a quick trip home to find a volt meter we tested >the voltage which was 13+v. We had the charger on while we gone so >the reading was skewed because of that. We pulled the plane out and >the electronics and starter worked normally.\ The legacy "beer-barrel" contactors are large area, low pressure switching devices. Emacs! http://tinyurl.com/5uh3b8 The highest risk for failure is corrosion since these are not a sealed device and the contacts are pure . . . or nearly pure copper. http://tinyurl.com/pw342c3 We've had discussions like this on the List for decades . . . invariably, the conversations morph into reliability discussions wherein there is no distinction made between "system reliability" (relative criticality and risks imposed by failure) and "service life" (the critter has simply used up all it's nine lives). This style of contactor is the LEAST expensive product suited to our task but as such, it can be expected to have a shorter service life than say a hermetically sealed, $high$ contactor. As I've suggested for years, your decisions need to be tempered with trade offs for cost of ownership, impacts on system performance and risks associated with failure to perform. Obviously, for the time any of us expect to own and operate a single-engine, light aircraft, the cost-of-ownership question is a no-brainer. The $24 contactor http://tinyurl.com/nzern26 Is guaranteed to offer a lower cost per flight-hour than these oft recommened upgrades . . . Tyco EV200 . . . which is a bit 'noisy' http://tinyurl.com/qyexahd http://tinyurl.com/p2uwagu or a Gigavac GX-11 noise free . . . http://tinyurl.com/qa9m9ne http://tinyurl.com/pdknjb2 How about performance? Hmmm . . . they have few differences to offer in terms of weight savings or fuel consumption. They either work . . . or not. Okay, how about risk? There's a constellation of reasons why a contactor may fail to perform including wiring and control switches. Prudent failure mode effects analysis dictates that we ASSUME the contactor is going to fail, irrespective of it's pedigree or price. That thinking is what prompted the creation of the E-bus many years ago and the two-layered, three energy sourced architecture illustrated in Figure Z-13/8 http://tinyurl.com/kgg8nva Once you're homework is done, the loss of ANY contactor is at worst an inconvenience on the order of having a flat tire or having lots of bird-poop to clean off the airplane before you can go flying. Risks to airframe and occupants are zero. The key to comfortable flight in a complex machine is a three-legged stool. 1. absolute reliability (wing spars, prop bolts, well maintained batteries, etc) 2. failure tolerance (e-bus, two alternators) 3. understanding of how any failure critical to comfortable termination of flight will manifest and crafting a plan-b to deal with it. See: http://tinyurl.com/kqo7jx8 http://tinyurl.com/lrjlhhq I owned an airport back about 1989. Had occasion to replace two beer-barrel contactors in the rental fleet in six months . . . both had been in service for many years. They only cost about $18 back then. It was less time consuming to replace the contactors than to get the bird-poop off an airplane that had been sitting a pole-barn hangars for a few weeks. Then there is the ultimate fall-back position: Whether flying the J-3 or an A-36 with all the goodies, this collection of stuff in my flight bag has a 99.9 probability of getting me where I want to go even if the whole panel is dark. http://tinyurl.com/ok7sjzt Just make sure the batteries are all FRESH. I put new cells in at the beginning of every long x-c flight . . . they're cheap. Bob . . . ________________________________________________________________________________
Date: Aug 06, 2015
Thanks so very much for the replies and links...I have a sense on how to proceed now. This forum is an amazing asset to have available!! Dave Read this topic online here: http://forums.matronics.com/viewtopic.php?p=445650#445650 ________________________________________________________________________________
Date: Aug 06, 2015
Subject: Alternator B-lead circuit protection
Date: Aug 07, 2015
Hi everyone. I have a quick question with regards to protecting alternator B-leads. A lot of people do so with ANL fuses, yet I know some aircraft (like my C150) do so with a circuit breaker. Of course, a disadvantage of the ANL is that if it blew while on a trip, after fixing whatever caused the problem, a person would have to source a new fuse which could result in the aircraft being grounded waiting for one to be shipped (are ANL fuses that easy to find? I'm in Canada, so my usual sources of parts are Aircraft Spruce, which doesn't seem to carry them, or "chain" stores like Canadian Tire, which doesn't seem to either. Though it does appear that Digikey carries them, so at least there is a source here without having to go through the customs hassles of ordering from somewhere like B&C). The natural advantage of a circuit breaker, of course, is that it can be reset without replacing things once the problem is fixed. But I don't like much the idea of bringing B-leads into the area behind the panel, or even into the cockpit for that matter, and am unsure as to whether a circuit breaker would cause more problems than it prevents due to nuisance trips. I know it's not "conventionally" done, but is there any problem with locating a B-lead circuit breaker under the cowling in the engine compartment if a person were to go the circuit breaker route? After all, if a B-lead were to have a current spike tripping the fuse or breaker, the cowling would likely have to be pulled anyway to see what's going on. Or is it better to just go the fuse route? And if so, any advantages of ANL over MIDI style? Thanks for any advice! Dan --- Dan Charrois President, Syzygy Research & Technology Phone: 780-961-2213 ________________________________________________________________________________
Date: Aug 07, 2015
Subject: Re: Alternator B-lead circuit protection
My tool bag carries them! They are cheap enough and small enough to bring a spare or two along, as to help mitigate that concern. could result in the aircraft being grounded waiting for one to be shipped > (are ANL fuses that easy to find? I'm in Canada, so my usual sources of > parts are Aircraft Spruce, which doesn't seem to carry them, or "chain" > stores like Canadian Tire, which doesn't seem to either. ________________________________________________________________________________
Date: Aug 07, 2015
I used a CB mounted in the engine compartment. I had a 60 amp alternator and went to a 70 amp alternator. I did not change the CB (you see what is coming). On a long trip back East (from Utah), I had the CB trip twice in flight. I did not think I could draw 60 amps......but I can. So when I got back I upgraded to a 70 amp CB.....no trips since. I have two batteries on board and on reduced load can go an entire flight without the alternator. Rene' 801-721-6080 -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Dan Charrois Sent: Friday, August 07, 2015 2:41 AM Subject: AeroElectric-List: Alternator B-lead circuit protection Hi everyone. I have a quick question with regards to protecting alternator B-leads. A lot of people do so with ANL fuses, yet I know some aircraft (like my C150) do so with a circuit breaker. Of course, a disadvantage of the ANL is that if it blew while on a trip, after fixing whatever caused the problem, a person would have to source a new fuse which could result in the aircraft being grounded waiting for one to be shipped (are ANL fuses that easy to find? I'm in Canada, so my usual sources of parts are Aircraft Spruce, which doesn't seem to carry them, or "chain" stores like Canadian Tire, which doesn't seem to either. Though it does appear that Digikey carries them, so at least there is a source here without having to go through the customs hassles of ordering from somewhere like B&C). The natural advantage of a circuit breaker, of course, is that it can be reset without replacing things once the problem is fixed. But I don't like much the idea of bringing B-leads into the area behind the panel, or even into the cockpit for that matter, and am unsure as to whether a circuit breaker would cause more problems than it prevents due to nuisance trips. I know it's not "conventionally" done, but is there any problem with locating a B-lead circuit breaker under the cowling in the engine compartment if a person were to go the circuit breaker route? After all, if a B-lead were to have a current spike tripping the fuse or breaker, the cowling would likely have to be pulled anyway to see what's going on. Or is it better to just go the fuse route? And if so, any advantages of ANL over MIDI style? Thanks for any advice! Dan --- Dan Charrois President, Syzygy Research & Technology Phone: 780-961-2213 ________________________________________________________________________________
Date: Aug 07, 2015
I've used a circuit breaker or maxi fuse with 40 amp alternators when the battery is in the fuselage. I would hesitate to use a C/B on the hot side of the FW since they are likely more sensitive to the surrounding environment than fuses or an ANL. Many automotive audio system vendors stock ANLs and they can always be hotwired making them into essentially a fusable link. Ken On 07/08/2015 4:41 AM, Dan Charrois wrote: > > Hi everyone. I have a quick question with regards to protecting alternator B-leads. > > A lot of people do so with ANL fuses, yet I know some aircraft (like my C150) do so with a circuit breaker. Of course, a disadvantage of the ANL is that if it blew while on a trip, after fixing whatever caused the problem, a person would have to source a new fuse which could result in the aircraft being grounded waiting for one to be shipped (are ANL fuses that easy to find? I'm in Canada, so my usual sources of parts are Aircraft Spruce, which doesn't seem to carry them, or "chain" stores like Canadian Tire, which doesn't seem to either. Though it does appear that Digikey carries them, so at least there is a source here without having to go through the customs hassles of ordering from somewhere like B&C). The natural advantage of a circuit breaker, of course, is that it can be reset without replacing things once the problem is fixed. > > But I don't like much the idea of bringing B-leads into the area behind the panel, or even into the cockpit for that matter, and am unsure as to whether a circuit breaker would cause more problems than it prevents due to nuisance trips. I know it's not "conventionally" done, but is there any problem with locating a B-lead circuit breaker under the cowling in the engine compartment if a person were to go the circuit breaker route? After all, if a B-lead were to have a current spike tripping the fuse or breaker, the cowling would likely have to be pulled anyway to see what's going on. > > Or is it better to just go the fuse route? And if so, any advantages of ANL over MIDI style? > > Thanks for any advice! > > Dan > --- > Dan Charrois > President, Syzygy Research & Technology > Phone: 780-961-2213 > > ________________________________________________________________________________
Date: Aug 07, 2015
If the ANL fuse is sized right and the terminals are kept tight, it should never blow unless there is a bigger problem. There is less to go wrong with a fuse compared to a circuit breaker. I would use a fuse located near the contactors. The protective device does not have to be resetable for once in a lifetime event. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=445669#445669 ________________________________________________________________________________
Date: Aug 07, 2015
I agree that if a properly sized ANL fuse blows, you've probably got bigger problems. However, I just carry a spare one in my kit Sent from my iPad > On Aug 7, 2015, at 9:23 AM, user9253 wrote: > > > If the ANL fuse is sized right and the terminals are kept tight, it should never blow unless there is a bigger problem. There is less to go wrong with a fuse compared to a circuit breaker. I would use a fuse located near the contactors. > The protective device does not have to be resetable for once in a lifetime event. > Joe > > -------- > Joe Gores > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=445669#445669 > > > > > > > > > > ________________________________________________________________________________
Date: Aug 07, 2015
Uh- Yep When discharged the battery will immediately take all of the available alternator current if you have underrated the breaker, it will break. The breaker, in any circuit should be sized to protect the wire, not the deliverer of electrons nor those things that use them. Rich In a message dated 8/7/2015 8:03:45 A.M. Central Daylight Time, rene(at)felker.com writes: --> AeroElectric-List message posted by: "Rene" I used a CB mounted in the engine compartment. I had a 60 amp alternator and went to a 70 amp alternator. I did not change the CB (you see what is coming). On a long trip back East (from Utah), I had the CB trip twice in flight. I did not think I could draw 60 amps......but I can. So when I got back I upgraded to a 70 amp CB.....no trips since. I have two batteries on board and on reduced load can go an entire flight without the alternator. Rene' 801-721-6080 -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Dan Charrois Sent: Friday, August 07, 2015 2:41 AM Subject: AeroElectric-List: Alternator B-lead circuit protection Hi everyone. I have a quick question with regards to protecting alternator B-leads. A lot of people do so with ANL fuses, yet I know some aircraft (like my C150) do so with a circuit breaker. Of course, a disadvantage of the ANL is that if it blew while on a trip, after fixing whatever caused the problem, a person would have to source a new fuse which could result in the aircraft being grounded waiting for one to be shipped (are ANL fuses that easy to find? I'm in Canada, so my usual sources of parts are Aircraft Spruce, which doesn't seem to carry them, or "chain" stores like Canadian Tire, which doesn't seem to either. Though it does appear that Digikey carries them, so at least there is a source here without having to go through the customs hassles of ordering from somewhere like B&C). The natural advantage of a circuit breaker, of course, is that it can be reset without replacing things once the problem is fixed. But I don't like much the idea of bringing B-leads into the area behind the panel, or even into the cockpit for that matter, and am unsure as to whether a circuit breaker would cause more problems than it prevents due to nuisance trips. I know it's not "conventionally" done, but is there any problem with locating a B-lead circuit breaker under the cowling in the engine compartment if a person were to go the circuit breaker route? After all, if a B-lead were to have a current spike tripping the fuse or breaker, the cowling would likely have to be pulled anyway to see what's going on. Or is it better to just go the fuse route? And if so, any advantages of ANL over MIDI style? Thanks for any advice! Dan --- Dan Charrois President, Syzygy Research & Technology Phone: 780-961-2213 ________________________________________________________________________________
Subject: Re: Ryan TCAD 9900B
Date: Aug 07, 2015
I am searching for a wiring schematic for the Ryan TCAD 9900B. Ryan was absorbed into Avidyne who has discontinued all support for the 9900B. Ive got at least one or more faulty suppression diodes on the incoming grey code lines and a diagram would be helpful. Thanks, Angier Ames N4ZQ ________________________________________________________________________________
Date: Aug 07, 2015
Angier, A quick Google search turned this up, on 'Lectric Bob's site. http://www.aeroelectric.com/Installation_Data/TAS6XX_Install%20Manual_Rev04 _Oct05.pdf Not a full schematic, but shows some detail you may or may not already have . Ron Cox Glasair Super II F/T *"Everyone wants to live at the expense of the state. They forget that the state lives at the expense of everyone." - French statesman Frederic Bastiat (1801-1850)* On Fri, Aug 7, 2015 at 6:41 PM, Greenbacks, UnLtd. wrote : > n4zq(at)verizon.net> > > I am searching for a wiring schematic for the Ryan TCAD 9900B. > Ryan was absorbed into Avidyne who has discontinued all support for the > 9900B. > I=99ve got at least one or more faulty suppression diodes on the in coming > grey code lines > and a diagram would be helpful. > > Thanks, > > Angier Ames > N4ZQ > =========== =========== =========== =========== > > ________________________________________________________________________________
Subject: 220vac diode?
Date: Aug 07, 2015
I'm powering a device with two 220vac sources, one main and one backup. What kind of diode, or other one-way device can I use to prevent backfeeding a source wire when it should be off? This project is taking place in Thailand that uses a neutral, 220 hot and a ground wire in household wiring. Thanks, John ________________________________________________________________________________
From: Bob McCallum <robert.mccallum2(at)sympatico.ca>
Date: Aug 07, 2015
John; Not quite sure what type of "device" you may be referring to, but this sounds similar (or identical) to a backup generator situation for a house service. The device "normally" used to make the changeover from one source to the other is a transfer switch. Functionally it is basically a single pole double throw relay with the coil attached to the "main" or "primary" source. The primary source is also attached to the NO contact while the load is connected to the moveable or common contact, and the secondary source is connected to the NC contact. Functionally while the primary source is live the relay is "closed" and supplies the load form the primary source. Should the primary source be lost, the relay drops out and connects the load to the secondary or backup source through the NC contact. With this method you do lose power for a few milliseconds during the transfer. Something to keep in mind if that would be critical to your use. When the primary source is restored the relay picks up and transfers the load back to the primary source. All automatically. Not sure if this is what you're trying to achieve, but from your original request it sounds like it is. Diodes won't do what you're trying to accomplish because they are DC devices and won't function in an AC circuit. If however your load is able to utilize DC power then you could rectify the AC through diodes (rectifiers) and then the paralleling of the sources through the diodes would work to prevent the back-feeding of one source into the other. Because you refer to household power I suspect that the relay/transfer switch method described above is what you're after. Bob McC _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of John Burnaby Sent: Friday, August 07, 2015 9:10 PM Subject: AeroElectric-List: 220vac diode? I'm powering a device with two 220vac sources, one main and one backup. What kind of diode, or other one-way device can I use to prevent backfeeding a source wire when it should be off? This project is taking place in Thailand that uses a neutral, 220 hot and a ground wire in household wiring. Thanks, John ________________________________________________________________________________
Date: Aug 07, 2015
Subject: Re: 220vac diode?
A diode won't work for AC, but something like a generator transfer switch would probably work. It's just a powered relay. Ron Cox On Aug 7, 2015 8:15 PM, "John Burnaby" wrote: > I=99m powering a device with two 220vac sources, one main and one b ackup. > What kind of diode, or other one-way device can I use to prevent > backfeeding a source wire when it should be off? > > > This project is taking place in Thailand that uses a neutral, 220 hot and > a ground wire in household wiring. > > > Thanks, > > John > > * > =========== www.matronics.com/Navigator?AeroElectric-List> =========== =========== om/contribution> =========== > > * > > ________________________________________________________________________________
Date: Aug 07, 2015
On 8/7/2015 8:10 PM, John Burnaby wrote: > > Im powering a device with two 220vac sources, one main and one > backup. What kind of diode, or other one-way device can I use to > prevent backfeeding a source wire when it should be off? > > This project is taking place in Thailand that uses a neutral, 220 hot > and a ground wire in household wiring. > > Thanks, > > John > > If it's an AC device, diodes won't help. For a single ended AC source/load, a double throw switch or relay would work to select source A or source B. A SPDT relay with the A pole NO and the B pole NC, with the 220 VAC coil powered by A, would switch and power the load from A until A power is lost. It would then 'drop out' to the NC (B) pole, powering the load from B. Charlie ________________________________________________________________________________
Date: Aug 07, 2015
If it's two generators, the general procedure is to use synchronizing lights (or some type of phasing meter). What you need to do is start the first gen erator and close the output breaker (not closing it to the load but to the g enerators bus of the transfer switch). Then start the second generator and a djust the speed until the second generator is in phase and close its output breaker. Both generators will stay in phase now on their own. You can paral lel nearly as many generators as you like in this manor. Now you can flop th e transfer switch to the generators. I did this every afternoon in Thailand d uring the rainy season in the mid '60's. If you are really talking about running a generator with the commercial main s, DON'T DO IT! That's called back feeding the grid and you can kill someone who thinks the l ine is dead when in actuality you are feeding power to the commercial grid. T his is illegal for good reason. There should always be a transfer switch bet ween any generator power and the commercial mains that physically isolates t wo with no possibility of one being tied to the other. Bill Sent from my iPad > On Aug 7, 2015, at 18:58, Ronald Cox wrote: > > A diode won't work for AC, but something like a generator transfer switch w ould probably work. > It's just a powered relay. > > Ron Cox > >> On Aug 7, 2015 8:15 PM, "John Burnaby" wrote: >> I=99m powering a device with two 220vac sources, one main and one b ackup. What kind of diode, or other one-way device can I use to prevent back feeding a source wire when it should be off? >> >> >> >> This project is taking place in Thailand that uses a neutral, 220 hot and a ground wire in household wiring. >> >> >> >> Thanks, >> >> John >> >> >> >> ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-Li st >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Aug 07, 2015
I'm pretty sure he knows that he shouldn't back feed the mains, and is trying to correctly prevent the situation your bringing up. I believe he's trying to switch safely between, not parallel, two sources. Ron Cox On Friday, August 7, 2015, Bill Putney wrote: > If it's two generators, the general procedure is to use synchronizing > lights (or some type of phasing meter). What you need to do is start the > first generator and close the output breaker (not closing it to the load > but to the generators bus of the transfer switch). Then start the second > generator and adjust the speed until the second generator is in phase and > close its output breaker. Both generators will stay in phase now on thei r > own. You can parallel nearly as many generators as you like in this manor . > Now you can flop the transfer switch to the generators. I did this every > afternoon in Thailand during the rainy season in the mid '60's. > > If you are really talking about running a generator with the commercial > mains, DON'T DO IT! > > That's called back feeding the grid and you can kill someone who thinks > the line is dead when in actuality you are feeding power to the commercia l > grid. This is illegal for good reason. There should always be a transfer > switch between any generator power and the commercial mains that physical ly > isolates two with no possibility of one being tied to the other. > > Bill > > Sent from my iPad > > On Aug 7, 2015, at 18:58, Ronald Cox > wrote: > > A diode won't work for AC, but something like a generator transfer switch > would probably work. > It's just a powered relay. > > Ron Cox > On Aug 7, 2015 8:15 PM, "John Burnaby" > wrote: > >> I=99m powering a device with two 220vac sources, one main and one backup. >> What kind of diode, or other one-way device can I use to prevent >> backfeeding a source wire when it should be off? >> >> >> >> This project is taking place in Thailand that uses a neutral, 220 hot an d >> a ground wire in household wiring. >> >> >> >> Thanks, >> >> John >> >> * >> >> ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-L ist <http://www.matronics.com/Navigator?AeroElectric-List> >> tp://forums.matronics.com <http://forums.matronics.com> >> _blank">http://www.matronics.com/contribution >> >> * >> >> * > > D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D > lectric-List"">http://www.matronics.com/Navigator?AeroElectric-List > D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D > //forums.matronics.com <http://forums.matronics.com> > D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D > ot;">http://www.matronics.com/contribution > D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D > > * > > * > =========== www.matronics.com/Navigator?AeroElectric-List> =========== =========== om/contribution> =========== > > * > > -- *"Everyone wants to live at the expense of the state. They forget that the state lives at the expense of everyone." - French statesman Frederic Bastiat (1801-1850)* ________________________________________________________________________________
Subject: 220 VAC Diode Functionality
Date: Aug 08, 2015
On 8/7/2015 7:53 PM, Bill Putney wrote: > If you are really talking about running a generator with the > commercial mains, DON'T DO IT! In general, Bill is of course correct, as he generally is. However, there is a safe way to do this... with a very robust reverse current relay that prevents a watt from ever exiting your on-premises system toward the mains. There are certification requirements, too, from the utility, which one ignores at one's own risk of course. But it can be done safely, and even legally... but it's not super inexpensive. Easier is an isolation relay that allows EITHER mains power or self-generation. But this is not a bumpless transfer (power fails and then is restored...) Paul ________________________________________________________________________________
Subject: Duplicate Messages
Date: Aug 08, 2015
Just to pass this on. I had done an upgrade to my Microsoft Office and somehow this upgrade made a duplicate of my rule to move aeroelectric messages to a folder. I discovered this rule duplication, removed it and now everything is fine. Bill ________________________________________________________________________________
Date: Aug 10, 2015
Subject: electrical system planning
I'm working on figuring out the system architecture for my plane. It's an rv9 with all glass panel and an O320 with electrically dependent fuel injection (EFII). The mission is typically cross countries including some night flight and IFR, though it would typically be going through a layer of clouds to VFR on top. Here's what I've got for my load analysis: Fuel pump: 5 A Ignition/Fuel injectors: 5 A So already the SD-8 is out. For minimal comfortable flight I'd add: Primary EFIS: 3.1 A Transponder: 0.4 A Total: 13.5 Add in the rest of the avionics for normal flight: gtn650 nav/com 2.2A intercom 0.1A adsb in 0.2A Backup efis 3.1 A (total 19.1) Then 10A for pitot heat, and lights: strobes 2.5A position lights 1.2A landing lights 1.8A I'm not including the motors for trim, flaps, or auto pilot here. Also I'm assuming the comms aren't transmitting. Are these the right assumptions for the load analysis? It seems like Z-12 is the best option for me here. I have to use a 20-30 amp backup alternator to keep the engine running. That gives me enough juice to keep nearly everything running, so Z-13/8 doesn't seem useful. Z-12 shows an SD-20 backup alternator with it's own switch. I'm assuming normal operation is with Master on ALT and Aux Alternator on OFF. When you get low volts warning, you switch Master to BAT and Aux Alternator to ON. Is there some advantage to wiring it this way instead of having the standby alternator take over automatically when the voltage drops? Or is that actually what Z-12 is showing, and you'd normally fly with Aux Alternator ON? Also I see that Z-12 shows Battery, Master, and Endurance busses. What's the point? It seems I'd put the minimum equipment on the battery bus, and everything else could be on master. It's probably just as many switch flips to shed load on the master bus as it is to reconfigure the endurance bus. I guess the endurance bus also give you an extra route to the battery if the master switch or battery contactor fails, but why not just put the important devices on the battery bus? ________________________________________________________________________________
Subject: Re: Newbie with PM alternator feed question
Date: Aug 10, 2015
Follow on questions... Having trouble reconciling the tinyurl link wiring that you posted versus the wiring diagram for the B&C OVPM package (505-500) I planned on using. Appear to be only one relay to control on/off of the alternator via the capacitor and R/R versus your sketch with two relays for two of three phases. Also, why the need to fuse each phase of the alternator prior to the R/R as depicted in the B&C diagram? I feel like I'm missing parts of the big picture [Embarassed] Thanks for indulging my queries! Dave Read this topic online here: http://forums.matronics.com/viewtopic.php?p=445797#445797 Attachments: http://forums.matronics.com//files/505_500_rev_j_191.pdf ________________________________________________________________________________
Date: Aug 10, 2015
Bob's drawing uses two relays because they switch the AC from the dynamo. B&C uses only one relay because it switches the rectified DC. Either way will work. It is not a good idea to put fuses or circuit breakers in series. The B&C drawing has 3 in series: the 40 amp battery fuse, the 30 amp breaker, and the 20 amp fuses. A short circuit that trips the 30 amp breaker is likely to also blow the 40 amp fuse. Not only would dynamo power be lost, but also the battery. The 20 amp fuses are not necessary because dynamo current is self limiting. What really needs protection are the dynamo wires and aircraft battery. The 30 amp breaker satisfies that requirement in the B&C drawing, as does the 40 amp fuse in Bob's drawing. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=445800#445800 ________________________________________________________________________________
Date: Aug 10, 2015
user9253 wrote: > Bob's drawing uses two relays because they switch the AC from the dynamo. B&C uses only one relay because it switches the rectified DC. Either way will work. > It is not a good idea to put fuses or circuit breakers in series. The B&C drawing has 3 in series: the 40 amp battery fuse, the 30 amp breaker, and the 20 amp fuses. A short circuit that trips the 30 amp breaker is likely to also blow the 40 amp fuse. Not only would dynamo power be lost, but also the battery. > The 20 amp fuses are not necessary because dynamo current is self limiting. What really needs protection are the dynamo wires and aircraft battery. The 30 amp breaker satisfies that requirement in the B&C drawing, as does the 40 amp fuse in Bob's drawing. > Joe Thanks Joe... (1) Is dynamo current "self limiting" a characteristic of all 3 phase PM type alternators? (dynamos?) Would gladly eliminate those three 20 amp c/b's if not required! (2) Was planning on a 40A ANL type fuse for the 10 ga wire from the relay to the primary bus. (3) Was not planning on fuse/circuit protection from the battery to the primary bus. Appreciate all thoughts and input. I hope to post my schematic as an attachment as soon as I have an idea of what I'm doing [Shocked] Dave Read this topic online here: http://forums.matronics.com/viewtopic.php?p=445801#445801 ________________________________________________________________________________
Date: Aug 10, 2015
All alternators and dynamos are self current limiting. They can only do so much work. If loaded to much more than their rated capacity, the voltage will start to drop. Another concern is heat. If fully loaded, an alternator could get too hot if not adequately ventilated. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=445802#445802 ________________________________________________________________________________
Subject: Re: electrical system planning
Date: Aug 11, 2015
Ryan, I have a very similar setup using the efii system and used the Z13/8 diagram (modified for the efii components). I am very happy with it and would be gl ad to share my diagram with you if you'd like. I used a standard aircraft pr imary alternator and used the B&C 410H on the vacuum pump as my backup. Keep in mind that it is unlikely that all of your electrical components will run continuously all the time. Also, you can manually load shed during oper ations that require the use of your backup alternator if needed. The 410H is a hefty alternator and will put plenty of amps to keep up with your system. A low voltage warning system is absolutely critical! Justin > On Aug 10, 2015, at 17:55, Ryan Brown wrote: > > I'm working on figuring out the system architecture for my plane. > It's an rv9 with all glass panel and an O320 with electrically dependent f uel injection (EFII). > The mission is typically cross countries including some night flight and I FR, though it would typically be going through a layer of clouds to VFR on t op. > > Here's what I've got for my load analysis: > Fuel pump: 5 A > Ignition/Fuel injectors: 5 A > > So already the SD-8 is out. > For minimal comfortable flight I'd add: > Primary EFIS: 3.1 A > Transponder: 0.4 A > > Total: 13.5 > > Add in the rest of the avionics for normal flight: > gtn650 nav/com 2.2A > intercom 0.1A > adsb in 0.2A > Backup efis 3.1 A > (total 19.1) > > Then 10A for pitot heat, and lights: > strobes 2.5A > position lights 1.2A > landing lights 1.8A > > I'm not including the motors for trim, flaps, or auto pilot here. Also I'm assuming the comms aren't transmitting. Are these the right assumptions for the load analysis? > > It seems like Z-12 is the best option for me here. I have to use a 20-30 a mp backup alternator to keep the engine running. That gives me enough juice t o keep nearly everything running, so Z-13/8 doesn't seem useful. > > Z-12 shows an SD-20 backup alternator with it's own switch. I'm assuming n ormal operation is with Master on ALT and Aux Alternator on OFF. When you ge t low volts warning, you switch Master to BAT and Aux Alternator to ON. > > Is there some advantage to wiring it this way instead of having the standb y alternator take over automatically when the voltage drops? Or is that actu ally what Z-12 is showing, and you'd normally fly with Aux Alternator ON? > > Also I see that Z-12 shows Battery, Master, and Endurance busses. What's t he point? It seems I'd put the minimum equipment on the battery bus, and eve rything else could be on master. It's probably just as many switch flips to s hed load on the master bus as it is to reconfigure the endurance bus. > I guess the endurance bus also give you an extra route to the battery if t he master switch or battery contactor fails, but why not just put the import ant devices on the battery bus? > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Subject: Bending copper (bus) bar
Date: Aug 16, 2015
Hi Guys I'll be using the almost (standard) method for connecting the battery contactor to starter contactor on a Rv9a with copper bar, also using a lighter gauge copper bar from the live feed to the ammeter shunt, this requires a bend in the copper bar: should copper bar be bent cold or with heat applied Regards John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=446020#446020 ________________________________________________________________________________
Date: Aug 16, 2015
Subject: Re: Bending copper (bus) bar
At 09:10 AM 8/16/2015, you wrote: > > >Hi Guys > >I'll be using the almost (standard) method for connecting the >battery contactor to starter contactor on a Rv9a with copper bar, >also using a lighter gauge copper bar from the live feed to the >ammeter shunt, this requires a bend in the copper bar: should copper >bar be bent cold or with heat applied What are the dimensions of the "bar"? I usually make such parts from 0.06 to 0.09 material and just bend it cold over a not-sharp radius . . . ~ 1/8" Bob . . . ________________________________________________________________________________
Date: Aug 16, 2015
> >(1) Is dynamo current "self limiting" a characteristic of all 3 >phase PM type alternators? (dynamos?) Would gladly eliminate those >three 20 amp c/b's if not required! the PM alternators will self-destruct if presented with a hard short on their windings generated by failure of the rectifier=regulator. Use in-line fuses. One for the single phase machines, two for the three phase machines. These need no be crew- accessible. >(2) Was planning on a 40A ANL type fuse for the 10 ga wire from the >relay to the primary bus. What is the rated output of your altenrator? An inline maxi-fuse of next-step higher value would be fine and a lot less bulky. >(3) Was not planning on fuse/circuit protection from the battery to >the primary bus. Most people do not . . . including hundreds of thousands of TC aircraft. Bob . . . ________________________________________________________________________________
Date: Aug 16, 2015
At 05:59 PM 8/10/2015, you wrote: > >Follow on questions... > >Having trouble reconciling the tinyurl link wiring that you posted >versus the wiring diagram for the B&C OVPM package (505-500) I >planned on using. Appear to be only one relay to control on/off of >the alternator via the capacitor and R/R versus your sketch with two >relays for two of three phases. Also, why the need to fuse each >phase of the alternator prior to the R/R as depicted in the B&C >diagram? I feel like I'm missing parts of the big picture [Embarassed] OV protection is a separate issue from the protection of wires. The single pole relay in series with the DC output of a R/R ALWAYS works to protect the ship's systems. However, that relay ALSO serves the legacy purpose of offering any time, any conditions, ON-OFF control of the engine driven power source from the pilot's position. If one embraces the goal of generating a MAX COLD power condition for ALT OFF then one is encouraged to open the power source as far upstream as practical. Hence, relay(s) in the AC winding leads. You need to break TWO leads of a 3-phase machine to bring it to heel. A two-pole relay would work . . . but inexpensive, automotive relays in 2-poles at that current are more rare and expensive that using two, robust single-pole devices to do the job. Two relays was a cost-of-ownership . . . not a functional design decision. Bob . . . ________________________________________________________________________________
From: Stuart Hutchison <stuart(at)stuarthutchison.com.au>
Date: Aug 16, 2015
If you bend thin material once with a blunt radius, say 1/8, then cold is fine. If you do more bending it will work harden and may crack under stress and vibration. In difference to steel, annealing copper is achieved by heating to cherry hot and quenching in water or oil. > On 16 Aug 2015, at 18:10, JOHN TIPTON wrote: > > > Hi Guys > > I'll be using the almost (standard) method for connecting the battery contactor to starter contactor on a Rv9a with copper bar, also using a lighter gauge copper bar from the live feed to the ammeter shunt, this requires a bend in the copper bar: should copper bar be bent cold or with heat applied > > Regards > > John > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=446020#446020 > > > > > > > > > > ________________________________________________________________________________
Date: Aug 16, 2015
If you bend thin material once with a blunt radius, say 1/8, then cold is fine. If you do more bending it will work harden and may crack under stress and vibration. In difference to steel, annealing copper is achieved by heating to cherry hot and quenching in water or oil. Cheers, Stu > On 16 Aug 2015, at 18:10, JOHN TIPTON wrote: > > > Hi Guys > > I'll be using the almost (standard) method for connecting the battery contactor to starter contactor on a Rv9a with copper bar, also using a lighter gauge copper bar from the live feed to the ammeter shunt, this requires a bend in the copper bar: should copper bar be bent cold or with heat applied > > Regards > > John > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=446020#446020 > > > > > > > > > > ________________________________________________________________________________
Date: Aug 16, 2015
At 04:55 PM 8/10/2015, you wrote: >I'm working on figuring out the system architecture for my plane. THE VERY FIRST TASK in crafting the elegant solution for architecture in a projet like yours is to download this form: http://tinyurl.com/7jqypwj and develop a load-picture for the various phases of flight. Do one page for each bus. Electrically dependent engine stuff on battery bus, plan-b loads on and E-bus, everything else on the main bus. THEN . . . set design goals for endurance under an alternator out condition and either size a WELL MAINTAINED battery to meet that goal or craft some combination of battery and second alternator to meet the goal. Then let's talk about the architecture that's most friendly to meeting your design goals. Are those 5A figures REAL, MEASURED current values? Breaker sizes from a wiring diagram are never indicative of ENERGY required to operate the system. This is a study the economics of energy management to achieve operational goals that determine whether a failure is an emergency or a ho-hum event. Bob . . . ________________________________________________________________________________
Date: Aug 16, 2015
> the PM alternators will self-destruct if presented > with a hard short on their windings generated by > failure of the rectifier=regulator. Bob, What self destructs, the winding or the magnets or both? I am guessing the magnets only but do not know. Was I wrong to state that all alternators are self current limiting? Thanks, Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=446059#446059 ________________________________________________________________________________
Date: Aug 17, 2015
Thanks Bob. The 5A figures are the estimates I got from the manufacturer for average consumption. I haven't measured it myself. The breaker size is 10A. I filled out a spreadsheet with the load analysis for each stage here: https://goo.gl/0FPFIQ I'm not entirely sure I have everything assigned to the right bus. I estimate the plane will hold 5.5 hours of fuel, so I guess that's what my endurance goal should be. That's over 70 amp hours just to keep the engine running, so it seems a backup alternator is a better bet than batteries. One question I have is if my endurance goal should be 5.5 hours with pitot heat on. I don't plan on tons of ifr flight, and I kind of doubt my brain could handle 5 hours of instrument flight. So it seems like lower endurance for ifr cruise could be acceptable. If I do want to keep the heater on with the backup alternator I need a little more than 20 amps. I'm a little confused looking at the alternators here. The SD-20 is described as a 20/30A alternator. What does that mean. I saw some mention that the vacuum pad on a continental spins faster, does that mean it's 30A on a continental and 20A on a lycoming? The plane power FS14 is just listed as 30A, so I assume it can actually put out 30A on a lycoming. On Sun, Aug 16, 2015 at 9:50 AM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 04:55 PM 8/10/2015, you wrote: > > I'm working on figuring out the system architecture for my plane. > > > THE VERY FIRST TASK in crafting the elegant solution > for architecture in a projet like yours is to download > this form: > > http://tinyurl.com/7jqypwj > > and develop a load-picture for the various > phases of flight. > > Do one page for each bus. Electrically dependent > engine stuff on battery bus, plan-b loads on > and E-bus, everything else on the main bus. > > THEN . . . set design goals for endurance under > an alternator out condition and either > size a WELL MAINTAINED battery to meet that > goal or craft some combination of battery and > second alternator to meet the goal. > > Then let's talk about the architecture that's > most friendly to meeting your design goals. > > Are those 5A figures REAL, MEASURED current > values? Breaker sizes from a wiring diagram > are never indicative of ENERGY required to > operate the system. > > This is a study the economics of energy > management to achieve operational goals > that determine whether a failure is > an emergency or a ho-hum event. > > Bob . . . > > * > > > * > > ________________________________________________________________________________
Date: Aug 17, 2015
At 10:04 PM 8/16/2015, you wrote: > > > > the PM alternators will self-destruct if presented > > with a hard short on their windings generated by > > failure of the rectifier=regulator. > >Bob, >What self destructs, the winding or the magnets or both? I am >guessing the magnets only but do not know. Was I wrong to state >that all alternators are self current limiting? This windings are at-risk. Browse through the various forums that feature engines with built in PM alternators, Jabiru in particular and you'll read builder stories of woe over smelly wires that don't look so good either . . . http://tinyurl.com/obudcwn The term 'current limited' is not necessarily applicable throughout the full spectrum of load conditions. I have a bench supply that is electronically current limited and will not self destruct for any load condition down to a dead short. But that kind of current limiting is seldom found in the wild. With respect to generators vs. alternators, the physics that drive performance and stresses to least robust components have prompted us to assert that 'inherent current limiting' in the physics of alternators makes the I-limit control relay common to generator controllers unnecessary . . . but you can burn windings in EITHER machine when you venture outside the condition of what one might call 'mild overloading'. I was appalled at my recent discovery of a kit or recommendation by the Jabiru factory that bi-filar (two wires in parallel) windings of their 3300 alternator be rewired in series to 'produce more output at lower rpm'. A very sad demonstration of . . . well . . . 'nuf said . . . http://tinyurl.com/obudcwn Yes, available VOLTAGE goes up by 2x for any given rpm . . . but available current drops by half . . . and loading on individual wires doubles. Given the strong positive temperature coefficient of resistance for copper, risk for destructive overheat goes up by more than half because the wires dissipate MORE energy as their operating temperature RISES. It's a positive feedback effect that hastens the march to self-destruction. I show fuses in these leads to do what fuses do best . . . protect wires from the hard-falut condition with would arise from shorted semi- conductors in the rectifier/regulator. But if those same wires are not properly sized and cooled to meet design goals they can probably be 'smoked' at current levels far below those expected in the hard-fault condition. In the mean time, the magnets are happily spinning in total ignorance of the havoc they can sow upon their copper brothers just a few millimeters away. Bob . . . ________________________________________________________________________________
Date: Aug 17, 2015
A t 11:29 PM 8/16/2015, you wrote: >Thanks Bob. >The 5A figures are the estimates I got from the >manufacturer for average consumption. I haven't >measured it myself. The breaker size is 10A. When you get this airplane flying, I'd REALLY like to get some data off it that describes ENERGY measurements . . . but 5A probably works for now. >I filled out a spreadsheet with the load >analysis for each stage here:=C2 https://goo.gl/0FPFIQ >I'm not entirely sure I have everything assigned to the right bus. > >I estimate the plane will hold 5.5 hours of >fuel, so I guess that's what my endurance goal should be. No guessing here . . . that's a number YOU pick based on how you intend to use the airplane. If you plan on frequent departures from airports often clagged in and surrounded by mountains, then the idea of endurance to carry you to demonstrably lower-risk haven is a part of solid reasoning. But if that comfortable termination of flight is never more than say 2 hours away, then designing and maintained that level of endurance is not unreasonable. The main thing is to know what the endurance numbers are, preventative maintenance to insure those numbers and risks go down markedly. >That's over 70 amp hours just to keep the engine >running, so it seems a backup alternator is a better bet than batteries. Bingo! A second engine driven power source is ALWAYS the best cost-weight-performance alternative to ANY chemical system. >One question I have is if my endurance goal >should be 5.5 hours with pitot heat on. I don't >plan on tons of ifr flight, and I kind of doubt >my brain could handle 5 hours of instrument >flight. So it seems like lower endurance for ifr cruise could be acceptable. Probably so . . . > >If I do want to keep the heater on with the >backup alternator I need a little more than 20 >amps. I'm a little confused looking at the >alternators here. The SD-20 is described as a >20/30A alternator. What does that mean. I saw >some mention that the vacuum pad on a >continental spins faster, does that mean it's >30A on a continental and 20A on a lycoming? I am not sure of the details . . . I've not had occasion to touch the phycics of that product in about 20 years but I do understand that under presently demonstrated conditions, its output can be that high. >The plane power FS14 is just listed as 30A, so I >assume it can actually put out 30A on a lycoming. Pitot heat was never a really good idea on light aircraft . . . yeah, it MAY have saved the bacon for a hand-full of pilots in years gone by but far more airplanes belabored with ice have gone down in spite of knowing exactly what their airspeed was before they hit the rocks. Having 'little chippers' to deal with some forms of ice (heated windshield patches, boots, pitot heat) have offered too many pilots a false sense of capability to deal with mother nature's vagaries. Modern weather observation and prediction systems are so capable that go-no go decision to launch is far wiser than any notion of being able to 'deal with a little ice' . . . same thing with those little yellow, orange and red areas on the radar . . . good reasons to just stay on the ground or take another route. My preference for conducting the FMEA says keeping the tube warm is at the bottom of the list with respect to other appliances on board. Just for grins, noodle through the plan-c for dealing with loss of airspeed indication. What do you KNOW about handling qualities, changes of trim and power that speak to impending stall? If that airspeed value becomes suspect for what you believe is high-probability of ice, I'll suggest that plans to seek warmer environs far outweighs any value of knowing exactly what your airspeed unless you think that climbing is the path to salvation . . . which is very seldom the case. IAS as a warning for impending stall is based on a CLEAN wing. I got a really big lesson in fouled aerodynamics when a landing in Hutchinson KS ended with the airplane plopping down hard in the flare while yours truly was patting himself on the butt for having kept the needles centered for over fifteen minutes in the clouds, outbound through procedure turns and then all the way back to the threshold. My instructor was grinning ear to ear and said, "Okay Nuckolls . . . while you were glued to the glass, your wings were taking on new shapes with unpredictable performance. None of that C-172- full-stall-flare stuff in instrument conditions. Fly it like a Grumman . . . carrier landings are called for unless you are CERTAIN that your wings are golden." You need to make up your own mind but it seems to me that a Z-12 system with a 15 a.h. SVLA battery would provide a comfortable reduction in risks . . . especially if you consider pitot heat to be more cosmetic than practical. Bob . . . ________________________________________________________________________________
Date: Aug 18, 2015
Subject: Anything 'unique' about incorporating EarthX?
>When using a LR3C-14 regulator and SB1B-14 regulator in a Z-12 with >an EarthX battery, what is the closest we can have the two >regulators set at without the two fighting for the load? > >EarthX would like their battery charged between 13.8 and 14.6. I >was thinking that the customer could set the LR3C at 14.6 and the >SB1B at 13.8. Would this work? Not necessary. A STANDBY system is not intended to charge batteries . . . only support the bus such that what ever energy is in the battery is not taxed. The open circuit terminal voltage for an EarthX is 13.3v give or take. So set the SB1 for 13.5, the LR3 for 14.5 and all will be right with the universe. Bob . . . ________________________________________________________________________________
Date: Aug 18, 2015
Thanks. I agree pitot heat does seem optional for the type of flying I plan on doing. I'd much rather just stay away from ice than try to fly through it. So Z12 is what I was leaning towards. But I wonder what's the purpose of having the endurance bus if I have a 20 amp standby alternator? In alternator out conditions I can just keep the master on, and run just about anything I want. Why not just have an alternate feed switch for the master bus in case the master switch or battery contactor fails? On Aug 17, 2015 7:41 AM, "Robert L. Nuckolls, III" < nuckolls.bob(at)aeroelectric.com> wrote: > A t 11:29 PM 8/16/2015, you wrote: > > Thanks Bob. > The 5A figures are the estimates I got from the manufacturer for average > consumption. I haven't measured it myself. The breaker size is 10A. > > > When you get this airplane flying, I'd REALLY > like to get some data off it that describes > ENERGY measurements . . . but 5A probably > works for now. > > > I filled out a spreadsheet with the load analysis for each stage here:=C3 =82 > https://goo.gl/0FPFIQ > I'm not entirely sure I have everything assigned to the right bus. > > I estimate the plane will hold 5.5 hours of fuel, so I guess that's what > my endurance goal should be. > > > No guessing here . . . that's a number YOU pick > based on how you intend to use the airplane. If > you plan on frequent departures from airports > often clagged in and surrounded by mountains, then > the idea of endurance to carry you to demonstrably > lower-risk haven is a part of solid reasoning. But > if that comfortable termination of flight is > never more than say 2 hours away, then designing > and maintained that level of endurance is not > unreasonable. > > The main thing is to know what the endurance numbers > are, preventative maintenance to insure those > numbers and risks go down markedly. > > That's over 70 amp hours just to keep the engine running, so it seems a > backup alternator is a better bet than batteries. > > > Bingo! > > A second engine driven power source is ALWAYS the > best cost-weight-performance alternative to ANY > chemical system. > > > One question I have is if my endurance goal should be 5.5 hours with pito t > heat on. I don't plan on tons of ifr flight, and I kind of doubt my brain > could handle 5 hours of instrument flight. So it seems like lower enduran ce > for ifr cruise could be acceptable. > > > Probably so . . . > > > If I do want to keep the heater on with the backup alternator I need a > little more than 20 amps. I'm a little confused looking at the alternator s > here. The SD-20 is described as a 20/30A alternator. What does that mean. I > saw some mention that the vacuum pad on a continental spins faster, does > that mean it's 30A on a continental and 20A on a lycoming? > > > I am not sure of the details . . . I've not had occasion > to touch the phycics of that product in about 20 > years but I do understand that under presently > demonstrated conditions, its output can be that > high. > > The plane power FS14 is just listed as 30A, so I assume it can actually > put out 30A on a lycoming. > > > Pitot heat was never a really good idea on light > aircraft . . . yeah, it MAY have saved the bacon > for a hand-full of pilots in years gone by but > far more airplanes belabored with ice have gone down > in spite of knowing exactly what their airspeed > was before they hit the rocks. > > Having 'little chippers' to deal with some forms > of ice (heated windshield patches, boots, pitot > heat) have offered too many pilots a false sense > of capability to deal with mother nature's vagaries. > > Modern weather observation and prediction systems > are so capable that go-no go decision to launch > is far wiser than any notion of being able to 'deal > with a little ice' . . . same thing with those > little yellow, orange and red areas on the radar . . . > good reasons to just stay on the ground or take > another route. > > My preference for conducting the FMEA says > keeping the tube warm is at the bottom of the > list with respect to other appliances on board. > Just for grins, noodle through the plan-c for dealing > with loss of airspeed indication. What do you KNOW > about handling qualities, changes of trim and > power that speak to impending stall? If that > airspeed value becomes suspect for what you believe > is high-probability of ice, I'll suggest that > plans to seek warmer environs far outweighs > any value of knowing exactly what your airspeed > unless you think that climbing is the path to > salvation . . . which is very seldom the case. > > IAS as a warning for impending stall is > based on a CLEAN wing. I got a really big > lesson in fouled aerodynamics when a landing > in Hutchinson KS ended with the airplane plopping > down hard in the flare while yours truly was > patting himself on the butt for having kept > the needles centered for over fifteen minutes > in the clouds, outbound through procedure turns > and then all the way back to the threshold. > > My instructor was grinning ear to ear and said, > "Okay Nuckolls . . . while you were glued to the > glass, your wings were taking on new shapes with > unpredictable performance. None of that C-172- > full-stall-flare stuff in instrument conditions. > Fly it like a Grumman . . . carrier landings are > called for unless you are CERTAIN that your wings > are golden." > > You need to make up your own mind but it seems > to me that a Z-12 system with a 15 a.h. SVLA > battery would provide a comfortable reduction > in risks . . . especially if you consider pitot > heat to be more cosmetic than practical. > > Bob . . . > > * > =========== www.matronics.com/Navigator?AeroElectric-List> =========== =========== om/contribution> =========== > > * > > ________________________________________________________________________________
Date: Aug 18, 2015
> Why not just have an alternate feed switch for the master bus in case the master switch or battery contactor fails? Use a DPDT switch wired so that when the alternate feed in turned on, the starter circuit will be disabled. Not having that feature will risk burning up the alternate feed switch while starting the engine with the master contactor inadvertently shut off. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=446116#446116 ________________________________________________________________________________
Date: Aug 18, 2015
At 11:12 AM 8/18/2015, you wrote: >Thanks. I agree pitot heat does seem optional for the type of flying >I plan on doing. I'd much rather just stay away from ice than try to >fly through it. > >So Z12 is what I was leaning towards. But I wonder what's the >purpose of having the endurance bus if I have a 20 amp standby >alternator? In alternator out conditions I can just keep the master >on, and run just about anything I want. Why not just have an >alternate feed switch for the master bus in case the master switch >or battery contactor fails? there are dozens of variations on a theme . . . Z-12 is Z-11 with the addition of a standby alternator that auto-switches when fitted with the SB-1 regulator that does not give up any of the risk management features of Z-11. You may choose to have avionics busses and associated master switches. Extra batteries, or any number of variations. If you don't see a need for the e-bus and want to leave it off, by all means. If you have an alternative for dealing with a contactor failure, that's okay too. Bob . . . ________________________________________________________________________________
Date: Aug 18, 2015
Subject: The legacy "6-inch rule"
At 04:51 PM 8/18/2015, you wrote: >Bob, > >On drawing 001-510, the Alternator ANL fuse and 2amp fuse are noted >as to be located 6" or less from the starter contactor. Why is >this? Are there any concerns to extending that length? If the >length can be extended, by how much could one extend it? There is a legacy rule-of-thumb in TC aircraft that says it's okay to 'sacrifice' as much as 6" of wire in an unprotected hard-fault. A number of devices got hooked to Cessna busses back in the 60-70 time frame with no specific protection for wires because they were close. i.e. the at-risk wire was 6" or less. In honor of that rule-of-thumb, we try to put circuit protection as close as practical to the source of energy that's going to burn the wire. Given that 99.99+ percent of all circuit protection in airplanes goes the lifetime of the vehicle without having been called upon to protect wires, then the 'risk' for going beyond the 6" rule is vanishingly small . . . Also, suggest you look into stocking the mini-anl style limiters. MUCH less expensive, much more compact. Bob . . . ________________________________________________________________________________
Date: Aug 18, 2015
All of Bob's Z diagrams are phenomenal and do the job well. When deciding on the diagram to use, keep in mind the more batteries and more complexity, th e more weight you will add to your small aircraft. I'm sure anything you choose will suit you well and you will be happy about y our decision. I fly in remote Alaska and chose the Z13/8 (with a B&C 410H http://www.bandc .biz/alternator20ampshomebuilt1.aspx ) and am happy with it. The EFII system uses surprisingly small amperage when it's running, and when you wire the Z 13/8 to the EFII system you have redundancy and reliability with 2 alternato rs and a battery. The 410h alternator provides plenty of amperage to run the full EFII system. I wired my system, and set procedures with the ability to shut the master sw itch off, allowing the engine to continue to run (dual ECUs). I don't think I will ever have to do this, but it is nice to NOT have a master switch that w ill shut the engine off. I also used milspec lever-lock switches for all of the EFII components to pr ohibit inadvertent actuation. I am willing to share any pictures, part numbers, or drawings to anyone inte rested. I would like to take this opportunity to thank Bob Nuckolls for his knowledg e, patience, time, and willingness to help and teach us. Experimental aviat ion as a whole would not be as safe or the same without you. Justin > On Aug 18, 2015, at 18:30, Robert L. Nuckolls, III <nuckolls.bob@aeroelect ric.com> wrote: > > At 11:12 AM 8/18/2015, you wrote: > >> Thanks. I agree pitot heat does seem optional for the type of flying I pl an on doing. I'd much rather just stay away from ice than try to fly through it. >> >> So Z12 is what I was leaning towards. But I wonder what's the purpose of h aving the endurance bus if I have a 20 amp standby alternator? In alternator out conditions I can just keep the master on, and run just about anything I want. Why not just have an alternate feed switch for the master bus in case the master switch or battery contactor fails? > > there are dozens of variations on a theme . . . > > Z-12 is Z-11 with the addition of a standby > alternator that auto-switches when fitted with > the SB-1 regulator that does not give up > any of the risk management features of Z-11. > > You may choose to have avionics busses and > associated master switches. Extra batteries, > or any number of variations. If you don't see > a need for the e-bus and want to leave it off, > by all means. If you have an alternative for > dealing with a contactor failure, that's okay > too. > > > > Bob . . . > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Aug 18, 2015
SnVzdGluIC0KClRoZSBjb21wbGltZW50YXJ5IGZpbmlzaCBpcyByaWdodCBvbiAoYXMgaXMgdGhl IHJlc3QpLgoKVGhhbmsgeW91IEJvYiAtCgpCaWxsClNGIGJheSBhcmVhCkFFQyBzZW1pbmFyIEtM VksgKDE5OTg/KQpEbyBub3QgYXJjaGl2ZQoKClNlbnQgdmlhIHRoZSBTYW1zdW5nIEdhbGF4eSBO b3Rlwq4gSUksIGFuIEFUJlQgNEcgTFRFIHNtYXJ0cGhvbmUKCjxkaXY+LS0tLS0tLS0gT3JpZ2lu YWwgbWVzc2FnZSAtLS0tLS0tLTwvZGl2PjxkaXY+RnJvbTogSnVzdGluIEpvbmVzIDxqbWpvbmVz MjAwMEBtaW5kc3ByaW5nLmNvbT4gPC9kaXY+PGRpdj5EYXRlOjA4LzE4LzIwMTUgIDU6MTIgUE0g IChHTVQtMDg6MDApIDwvZGl2PjxkaXY+VG86IGFlcm9lbGVjdHJpYy1saXN0QG1hdHJvbmljcy5j b20gPC9kaXY+PGRpdj5TdWJqZWN0OiBSZTogQWVyb0VsZWN0cmljLUxpc3Q6IGVsZWN0cmljYWwg c3lzdGVtIHBsYW5uaW5nIDwvZGl2PjxkaXY+CjwvZGl2PkFsbCBvZiBCb2IncyBaIGRpYWdyYW1z IGFyZSBwaGVub21lbmFsIGFuZCBkbyB0aGUgam9iIHdlbGwuIFdoZW4gZGVjaWRpbmcgb24gdGhl IGRpYWdyYW0gdG8gdXNlLCBrZWVwIGluIG1pbmQgdGhlIG1vcmUgYmF0dGVyaWVzIGFuZCBtb3Jl IGNvbXBsZXhpdHksIHRoZSBtb3JlIHdlaWdodCB5b3Ugd2lsbCBhZGQgdG8geW91ciBzbWFsbCBh aXJjcmFmdC4gCgpJJ20gc3VyZSBhbnl0aGluZyB5b3UgY2hvb3NlIHdpbGwgc3VpdCB5b3Ugd2Vs bCBhbmQgeW91IHdpbGwgYmUgaGFwcHkgYWJvdXQgeW91ciBkZWNpc2lvbi4gCgpJIGZseSBpbiBy ZW1vdGUgQWxhc2thIGFuZCBjaG9zZSB0aGUgWjEzLzggKHdpdGggYSBCJkMgNDEwSCBodHRwOi8v d3d3LmJhbmRjLmJpei9hbHRlcm5hdG9yMjBhbXBzaG9tZWJ1aWx0MS5hc3B4ICkgYW5kIGFtIGhh cHB5IHdpdGggaXQuIFRoZSBFRklJIHN5c3RlbSB1c2VzIHN1cnByaXNpbmdseSBzbWFsbCBhbXBl cmFnZSB3aGVuIGl0J3MgcnVubmluZywgYW5kIHdoZW4geW91IHdpcmUgdGhlIFoxMy84IHRvIHRo ZSBFRklJIHN5c3RlbSB5b3UgaGF2ZSByZWR1bmRhbmN5IGFuZCByZWxpYWJpbGl0eSB3aXRoIDIg YWx0ZXJuYXRvcnMgYW5kIGEgYmF0dGVyeS4gVGhlIDQxMGggYWx0ZXJuYXRvciBwcm92aWRlcyBw bGVudHkgb2YgYW1wZXJhZ2UgdG8gcnVuIHRoZSBmdWxsIEVGSUkgc3lzdGVtLiAKCkkgd2lyZWQg bXkgc3lzdGVtLCBhbmQgc2V0IHByb2NlZHVyZXMgd2l0aCB0aGUgYWJpbGl0eSB0byBzaHV0IHRo ZSBtYXN0ZXIgc3dpdGNoIG9mZiwgYWxsb3dpbmcgdGhlIGVuZ2luZSB0byBjb250aW51ZSB0byBy dW4gKGR1YWwgRUNVcykuIEkgZG9uJ3QgdGhpbmsgSSB3aWxsIGV2ZXIgaGF2ZSB0byBkbyB0aGlz LCBidXQgaXQgaXMgbmljZSB0byBOT1QgaGF2ZSBhIG1hc3RlciBzd2l0Y2ggdGhhdCB3aWxsIHNo dXQgdGhlIGVuZ2luZSBvZmYuIAoKSSBhbHNvIHVzZWQgbWlsc3BlYyBsZXZlci1sb2NrIHN3aXRj aGVzIGZvciBhbGwgb2YgdGhlIEVGSUkgY29tcG9uZW50cyB0byBwcm9oaWJpdCBpbmFkdmVydGVu dCBhY3R1YXRpb24uIAoKSSBhbSB3aWxsaW5nIHRvIHNoYXJlIGFueSBwaWN0dXJlcywgcGFydCBu dW1iZXJzLCBvciBkcmF3aW5ncyB0byBhbnlvbmUgaW50ZXJlc3RlZC4gCgpJIHdvdWxkIGxpa2Ug dG8gdGFrZSB0aGlzIG9wcG9ydHVuaXR5IHRvIHRoYW5rIEJvYiBOdWNrb2xscyBmb3IgaGlzIGtu b3dsZWRnZSwgcGF0aWVuY2UsIHRpbWUsIGFuZCB3aWxsaW5nbmVzcyB0byBoZWxwIGFuZCB0ZWFj aCB1cy4gIEV4cGVyaW1lbnRhbCBhdmlhdGlvbiBhcyBhIHdob2xlIHdvdWxkIG5vdCBiZSBhcyBz YWZlIG9yIHRoZSBzYW1lIHdpdGhvdXQgeW91LiAKCkp1c3RpbgoKCgogCgpPbiBBdWcgMTgsIDIw MTUsIGF0IDE4OjMwLCBSb2JlcnQgTC4gTnVja29sbHMsIElJSSA8bnVja29sbHMuYm9iQGFlcm9l bGVjdHJpYy5jb20+IHdyb3RlOgoKQXQgMTE6MTIgQU0gOC8xOC8yMDE1LCB5b3Ugd3JvdGU6CgpU aGFua3MuIEkgYWdyZWUgcGl0b3QgaGVhdCBkb2VzIHNlZW0gb3B0aW9uYWwgZm9yIHRoZSB0eXBl IG9mIGZseWluZyBJIHBsYW4gb24gZG9pbmcuIEknZCBtdWNoIHJhdGhlciBqdXN0IHN0YXkgYXdh eSBmcm9tIGljZSB0aGFuIHRyeSB0byBmbHkgdGhyb3VnaCBpdC4KClNvIFoxMiBpcyB3aGF0IEkg d2FzIGxlYW5pbmcgdG93YXJkcy4gQnV0IEkgd29uZGVyIHdoYXQncyB0aGUgcHVycG9zZSBvZiBo YXZpbmcgdGhlIGVuZHVyYW5jZSBidXMgaWYgSSBoYXZlIGEgMjAgYW1wIHN0YW5kYnkgYWx0ZXJu YXRvcj8gSW4gYWx0ZXJuYXRvciBvdXQgY29uZGl0aW9ucyBJIGNhbiBqdXN0IGtlZXAgdGhlIG1h c3RlciBvbiwgYW5kIHJ1biBqdXN0IGFib3V0IGFueXRoaW5nIEkgd2FudC4gV2h5IG5vdCBqdXN0 IGhhdmUgYW4gYWx0ZXJuYXRlIGZlZWQgc3dpdGNoIGZvciB0aGUgbWFzdGVyIGJ1cyBpbiBjYXNl IHRoZSBtYXN0ZXIgc3dpdGNoIG9yIGJhdHRlcnkgY29udGFjdG9yIGZhaWxzPwoKICB0aGVyZSBh cmUgZG96ZW5zIG9mIHZhcmlhdGlvbnMgb24gYSB0aGVtZSAuIC4gLgoKICBaLTEyIGlzIFotMTEg d2l0aCB0aGUgYWRkaXRpb24gb2YgYSBzdGFuZGJ5CiAgYWx0ZXJuYXRvciB0aGF0IGF1dG8tc3dp dGNoZXMgd2hlbiBmaXR0ZWQgd2l0aAogIHRoZSBTQi0xIHJlZ3VsYXRvciB0aGF0IGRvZXMgbm90 IGdpdmUgdXAKICBhbnkgb2YgdGhlIHJpc2sgbWFuYWdlbWVudCBmZWF0dXJlcyBvZiBaLTExLgoK ICBZb3UgbWF5IGNob29zZSB0byBoYXZlIGF2aW9uaWNzIGJ1c3NlcyBhbmQKICBhc3NvY2lhdGVk IG1hc3RlciBzd2l0Y2hlcy4gRXh0cmEgYmF0dGVyaWVzLAogIG9yIGFueSBudW1iZXIgb2YgdmFy aWF0aW9ucy4gSWYgeW91IGRvbid0IHNlZQogIGEgbmVlZCBmb3IgdGhlIGUtYnVzIGFuZCB3YW50 IHRvIGxlYXZlIGl0IG9mZiwKICBieSBhbGwgbWVhbnMuIElmIHlvdSBoYXZlIGFuIGFsdGVybmF0 aXZlIGZvcgogIGRlYWxpbmcgd2l0aCBhIGNvbnRhY3RvciBmYWlsdXJlLCB0aGF0J3Mgb2theQog IHRvby4KICAgIAoKCiAgQm9iIC4gLiAuCgoKCj09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09CnN0Ij5odHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP0Flcm9FbGVjdHJp Yy1MaXN0Cj09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09CmNzLmNvbQo9PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PQptYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbgo9 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQoKCgpfLT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT0gICAgICAgICAg LSBUaGUgQWVyb0VsZWN0cmljLUxpc3QgRW1haWwgRm9ydW0gLQpfLT0gVXNlIHRoZSBNYXRyb25p Y3MgTGlzdCBGZWF0dXJlcyBOYXZpZ2F0b3IgdG8gYnJvd3NlCl8tPSB0aGUgbWFueSBMaXN0IHV0 aWxpdGllcyBzdWNoIGFzIExpc3QgVW4vU3Vic2NyaXB0aW9uLApfLT0gQXJjaGl2ZSBTZWFyY2gg JiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0LCBGQVEsCl8tPSBQaG90b3NoYXJlLCBhbmQg bXVjaCBtdWNoIG1vcmU6Cl8tPQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05h dmlnYXRvcj9BZXJvRWxlY3RyaWMtTGlzdApfLT0KXy09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KXy09ICAgICAgICAgICAgICAgLSBN QVRST05JQ1MgV0VCIEZPUlVNUyAtCl8tPSBTYW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFi bGUgdmlhIHRoZSBXZWIgRm9ydW1zIQpfLT0KXy09ICAgLS0+IGh0dHA6Ly9mb3J1bXMubWF0cm9u aWNzLmNvbQpfLT0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT0KXy09ICAgICAgICAgICAgIC0gTGlzdCBDb250cmlidXRpb24gV2Vi IFNpdGUgLQpfLT0gIFRoYW5rIHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQpfLT0gICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uCl8tPSAg IC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uCl8tPT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cgo ________________________________________________________________________________
Date: Aug 18, 2015
The battery contactor pulls nearly a full amp. Also it is very easy to shed unneeded load by shutting the main down and going with the "E" bus. On Aug 18, 2015 9:20 AM, "Ryan Brown" wrote: > Thanks. I agree pitot heat does seem optional for the type of flying I > plan on doing. I'd much rather just stay away from ice than try to fly > through it. > > So Z12 is what I was leaning towards. But I wonder what's the purpose of > having the endurance bus if I have a 20 amp standby alternator? In > alternator out conditions I can just keep the master on, and run just abo ut > anything I want. Why not just have an alternate feed switch for the maste r > bus in case the master switch or battery contactor fails? > On Aug 17, 2015 7:41 AM, "Robert L. Nuckolls, III" < > nuckolls.bob(at)aeroelectric.com> wrote: > >> A t 11:29 PM 8/16/2015, you wrote: >> >> Thanks Bob. >> The 5A figures are the estimates I got from the manufacturer for average >> consumption. I haven't measured it myself. The breaker size is 10A. >> >> >> >> When you get this airplane flying, I'd REALLY >> like to get some data off it that describes >> ENERGY measurements . . . but 5A probably >> works for now. >> >> >> I filled out a spreadsheet with the load analysis for each stage here: =C3=82 >> https://goo.gl/0FPFIQ >> I'm not entirely sure I have everything assigned to the right bus. >> >> I estimate the plane will hold 5.5 hours of fuel, so I guess that's what >> my endurance goal should be. >> >> >> No guessing here . . . that's a number YOU pick >> based on how you intend to use the airplane. If >> you plan on frequent departures from airports >> often clagged in and surrounded by mountains, then >> the idea of endurance to carry you to demonstrably >> lower-risk haven is a part of solid reasoning. But >> if that comfortable termination of flight is >> never more than say 2 hours away, then designing >> and maintained that level of endurance is not >> unreasonable. >> >> The main thing is to know what the endurance numbers >> are, preventative maintenance to insure those >> numbers and risks go down markedly. >> >> That's over 70 amp hours just to keep the engine running, so it seems a >> backup alternator is a better bet than batteries. >> >> >> Bingo! >> >> A second engine driven power source is ALWAYS the >> best cost-weight-performance alternative to ANY >> chemical system. >> >> >> One question I have is if my endurance goal should be 5.5 hours with >> pitot heat on. I don't plan on tons of ifr flight, and I kind of doubt m y >> brain could handle 5 hours of instrument flight. So it seems like lower >> endurance for ifr cruise could be acceptable. >> >> >> Probably so . . . >> >> >> If I do want to keep the heater on with the backup alternator I need a >> little more than 20 amps. I'm a little confused looking at the alternato rs >> here. The SD-20 is described as a 20/30A alternator. What does that mean . I >> saw some mention that the vacuum pad on a continental spins faster, does >> that mean it's 30A on a continental and 20A on a lycoming? >> >> >> I am not sure of the details . . . I've not had occasion >> to touch the phycics of that product in about 20 >> years but I do understand that under presently >> demonstrated conditions, its output can be that >> high. >> >> The plane power FS14 is just listed as 30A, so I assume it can actually >> put out 30A on a lycoming. >> >> >> Pitot heat was never a really good idea on light >> aircraft . . . yeah, it MAY have saved the bacon >> for a hand-full of pilots in years gone by but >> far more airplanes belabored with ice have gone down >> in spite of knowing exactly what their airspeed >> was before they hit the rocks. >> >> Having 'little chippers' to deal with some forms >> of ice (heated windshield patches, boots, pitot >> heat) have offered too many pilots a false sense >> of capability to deal with mother nature's vagaries. >> >> Modern weather observation and prediction systems >> are so capable that go-no go decision to launch >> is far wiser than any notion of being able to 'deal >> with a little ice' . . . same thing with those >> little yellow, orange and red areas on the radar . . . >> good reasons to just stay on the ground or take >> another route. >> >> My preference for conducting the FMEA says >> keeping the tube warm is at the bottom of the >> list with respect to other appliances on board. >> Just for grins, noodle through the plan-c for dealing >> with loss of airspeed indication. What do you KNOW >> about handling qualities, changes of trim and >> power that speak to impending stall? If that >> airspeed value becomes suspect for what you believe >> is high-probability of ice, I'll suggest that >> plans to seek warmer environs far outweighs >> any value of knowing exactly what your airspeed >> unless you think that climbing is the path to >> salvation . . . which is very seldom the case. >> >> IAS as a warning for impending stall is >> based on a CLEAN wing. I got a really big >> lesson in fouled aerodynamics when a landing >> in Hutchinson KS ended with the airplane plopping >> down hard in the flare while yours truly was >> patting himself on the butt for having kept >> the needles centered for over fifteen minutes >> in the clouds, outbound through procedure turns >> and then all the way back to the threshold. >> >> My instructor was grinning ear to ear and said, >> "Okay Nuckolls . . . while you were glued to the >> glass, your wings were taking on new shapes with >> unpredictable performance. None of that C-172- >> full-stall-flare stuff in instrument conditions. >> Fly it like a Grumman . . . carrier landings are >> called for unless you are CERTAIN that your wings >> are golden." >> >> You need to make up your own mind but it seems >> to me that a Z-12 system with a 15 a.h. SVLA >> battery would provide a comfortable reduction >> in risks . . . especially if you consider pitot >> heat to be more cosmetic than practical. >> >> Bob . . . >> >> * >> >> ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-L ist <http://www.matronics.com/Navigator?AeroElectric-List> >> tp://forums.matronics.com <http://forums.matronics.com> >> _blank">http://www.matronics.com/contribution >> >> * >> >> * > =========== www.matronics.com/Navigator?AeroElectric-List> =========== =========== om/contribution> =========== > > * > > ________________________________________________________________________________
Date: Aug 19, 2015
Subject: Thermocouple Questions...
Hello, Last night I started connecting my Type-K sensors up to the airplane instrumentation. Trimming the single conductor leads from the instrumentation to match the length of the leads on the thermocouple. Then in the process of crimping a wire I managed to cut one of the leads
June 26, 2015 - August 19, 2015
AeroElectric-Archive.digest.vol-mv
