AeroElectric-Archive.digest.vol-ng
June 17, 2016 - July 06, 2016
      this stuck-on behaviour is because the contact has tried to open due to low coil
      voltage and welded itself shut because of an overcurrent condition.
      > Twice overall I have seen it enter this failure mode during cranking and while
      the prop is turning: the prop stops and bounces back against the cylinder compression,
      the bus voltage drops out and the contactor starts to buzz.
      > This is all consistent with a dead short either in, or downstream of the starter
      contactor. I would be looking very hard at the starter motor, but I've already
      had this overhauled, new springs, brushes etc., just yesterday.
      > Has anyone seen a failure like this in their experience? Anywhere else I could
      look? It's really a very simple circuit and it must be drawing several hundred
      amps somewhere...
Subject: Re: Problem with starting
Date: Jun 17, 2016
I did do a capacity check with a hand held device (basically it had a big heating element in it) that runs for ten seconds and gives a go/no-go result - it said the battery was "go". The bit that confuses me about a failing battery being responsible is that on one start the battery will produce enough current to pull the bus voltage down to 6 volts and significantly heat the battery grounding strap (but in this scenario not turn the prop), and on the very next try the bus voltage only drops to 10 volts while the prop spins freely. On 17Jun2016, at 4:56 PM, Kelly McMullen wrote: Most likely your battery is on its last legs, or it has not achieved a full charge. After being charged, and sitting overnight, the battery resting voltage should be at least 12.7. If it is closer to 12.5, the battery is either weak or didn't get fully charged. You could do, or have done a capacity check. On 6/17/2016 1:44 PM, Alec Myers wrote: > > Fresh on the heels of asking for help with the low bus voltage with the engine running in my C182, I now have an issue with intermittent cranking on start. > > Symptoms: > > About 5 times out of 10 turning the key switch to start elicits no prop movement. Not even a tiny bit. The other times the cranking is healthy. > > During a no-turn start, I can hear the starter contactor oscillate on/off at about 5Hz, the bus voltage drops to 6 volts or below, and after a few seconds the earth braid from the battery to the fuselage gets warm/hot to touch. > > Yesterday I had the alternator overhauled, and replaced: no change in behaviour. Sometimes it cranks well 10 times in a row, sometimes it fails to turn, 10 times in a row. > > After a few trial starts today the battery was dead. So I gave it an external charge 20A for an hour. The next start failed. The one after that was fine, then it went sulky and failed a few times. > > Twice in maybe 40 trial starts (been working on this at various times over two days now) the main (battery) contactor has remained shut and I have been unable to shut off the power by turning off the master switch. The second time this happened I gently tapped the battery contactor with a rubber tool and the contact was successfully broken. I have now replaced this contactor. I imagine this stuck-on behaviour is because the contact has tried to open due to low coil voltage and welded itself shut because of an overcurrent condition. > > Twice overall I have seen it enter this failure mode during cranking and while the prop is turning: the prop stops and bounces back against the cylinder compression, the bus voltage drops out and the contactor starts to buzz. > > This is all consistent with a dead short either in, or downstream of the starter contactor. I would be looking very hard at the starter motor, but I've already had this overhauled, new springs, brushes etc., just yesterday. > > Has anyone seen a failure like this in their experience? Anywhere else I could look? It's really a very simple circuit and it must be drawing several hundred amps somewhere... > > > > > > > ________________________________________________________________________________
Date: Jun 17, 2016
This sounds like an internal problem inside the starter or possibly a chaffing wire (insulation rubbing thin or thru and grounding out) on the starter side on the main contactor. The problem with high current draws is that it can harm the components in the system. The battery, wires, and both contactors can be destroyed. Begin at the starter and trace the big wire all the way back to the battery looking for any signs of chaffing or shorts. Do a continuity check between ground and the main wire on the starter side of the contactors with the battery switch off and battery disconnected from the airframe. If you can't find an issue with the wire, try trying to disconnect the main wire from the starter, insulate it (electricity isolating it) and attempt to crank the starter as you would on a normal start (battery connected). If the battery grounding braid gets hot, the starter isn't the issue and you have a short to ground. If nothing happens, try a different starter. Let us know. Justin > On Jun 17, 2016, at 16:56, Kelly McMullen wrote: > > > Most likely your battery is on its last legs, or it has not achieved a full charge. After being charged, and sitting overnight, the battery resting voltage should be at least 12.7. If it is closer to 12.5, the battery is either weak or didn't get fully charged. You could do, or have done a capacity check. > >> On 6/17/2016 1:44 PM, Alec Myers wrote: >> >> Fresh on the heels of asking for help with the low bus voltage with the engine running in my C182, I now have an issue with intermittent cranking on start. >> >> Symptoms: >> >> About 5 times out of 10 turning the key switch to start elicits no prop movement. Not even a tiny bit. The other times the cranking is healthy. >> >> During a no-turn start, I can hear the starter contactor oscillate on/off at about 5Hz, the bus voltage drops to 6 volts or below, and after a few seconds the earth braid from the battery to the fuselage gets warm/hot to touch. >> >> Yesterday I had the alternator overhauled, and replaced: no change in behaviour. Sometimes it cranks well 10 times in a row, sometimes it fails to turn, 10 times in a row. >> >> After a few trial starts today the battery was dead. So I gave it an external charge 20A for an hour. The next start failed. The one after that was fine, then it went sulky and failed a few times. >> >> Twice in maybe 40 trial starts (been working on this at various times over two days now) the main (battery) contactor has remained shut and I have been unable to shut off the power by turning off the master switch. The second time this happened I gently tapped the battery contactor with a rubber tool and the contact was successfully broken. I have now replaced this contactor. I imagine this stuck-on behaviour is because the contact has tried to open due to low coil voltage and welded itself shut because of an overcurrent condition. >> >> Twice overall I have seen it enter this failure mode during cranking and while the prop is turning: the prop stops and bounces back against the cylinder compression, the bus voltage drops out and the contactor starts to buzz. >> >> This is all consistent with a dead short either in, or downstream of the starter contactor. I would be looking very hard at the starter motor, but I've already had this overhauled, new springs, brushes etc., just yesterday. >> >> Has anyone seen a failure like this in their experience? Anywhere else I could look? It's really a very simple circuit and it must be drawing several hundred amps somewhere... > > > > ________________________________________________________________________________
Date: Jun 17, 2016
Alec, this is typical behavior of a short. See my last post to trouble shoot and find the issue. > On Jun 17, 2016, at 17:18, Alec Myers wrote: > > > I did do a capacity check with a hand held device (basically it had a big heating element in it) that runs for ten seconds and gives a go/no-go result - it said the battery was "go". > > The bit that confuses me about a failing battery being responsible is that on one start the battery will produce enough current to pull the bus voltage down to 6 volts and significantly heat the battery grounding strap (but in this scenario not turn the prop), and on the very next try the bus voltage only drops to 10 volts while the prop spins freely. > > > > > On 17Jun2016, at 4:56 PM, Kelly McMullen wrote: > > > Most likely your battery is on its last legs, or it has not achieved a full charge. After being charged, and sitting overnight, the battery resting voltage should be at least 12.7. If it is closer to 12.5, the battery is either weak or didn't get fully charged. You could do, or have done a capacity check. > >> On 6/17/2016 1:44 PM, Alec Myers wrote: >> >> Fresh on the heels of asking for help with the low bus voltage with the engine running in my C182, I now have an issue with intermittent cranking on start. >> >> Symptoms: >> >> About 5 times out of 10 turning the key switch to start elicits no prop movement. Not even a tiny bit. The other times the cranking is healthy. >> >> During a no-turn start, I can hear the starter contactor oscillate on/off at about 5Hz, the bus voltage drops to 6 volts or below, and after a few seconds the earth braid from the battery to the fuselage gets warm/hot to touch. >> >> Yesterday I had the alternator overhauled, and replaced: no change in behaviour. Sometimes it cranks well 10 times in a row, sometimes it fails to turn, 10 times in a row. >> >> After a few trial starts today the battery was dead. So I gave it an external charge 20A for an hour. The next start failed. The one after that was fine, then it went sulky and failed a few times. >> >> Twice in maybe 40 trial starts (been working on this at various times over two days now) the main (battery) contactor has remained shut and I have been unable to shut off the power by turning off the master switch. The second time this happened I gently tapped the battery contactor with a rubber tool and the contact was successfully broken. I have now replaced this contactor. I imagine this stuck-on behaviour is because the contact has tried to open due to low coil voltage and welded itself shut because of an overcurrent condition. >> >> Twice overall I have seen it enter this failure mode during cranking and while the prop is turning: the prop stops and bounces back against the cylinder compression, the bus voltage drops out and the contactor starts to buzz. >> >> This is all consistent with a dead short either in, or downstream of the starter contactor. I would be looking very hard at the starter motor, but I've already had this overhauled, new springs, brushes etc., just yesterday. >> >> Has anyone seen a failure like this in their experience? Anywhere else I could look? It's really a very simple circuit and it must be drawing several hundred amps somewhere... > > > > > > > > > > ________________________________________________________________________________
Date: Jun 17, 2016
---- Alec Myers wrote: > > I did do a capacity check with a hand held device (basically it had a big heating element in it) that runs for ten seconds and gives a go/no-go result - it said the battery was "go". > > The bit that confuses me about a failing battery being responsible is that on one start the battery will produce enough current to pull the bus voltage down to 6 volts and significantly heat the battery grounding strap (but in this scenario not turn the prop), and on the very next try the bus voltage only drops to 10 volts while the prop spins freely. That the ground braid gets hot suggests a poor connection. I would disconnect the braid and clean or replace and try again. jrh ________________________________________________________________________________
Date: Jun 17, 2016
The wire between the contactor and the starter is only six inches long no chafing anywhere or even contact with anything else. I can be confident there's no short upstream of the starter contactor because the bus voltage dips out only when the starter contactor is energized. I have disconnected the starter from its contactor and hit the start switch. The contactor closes but there is no drop in bus voltage. As you would expect. The only thing that makes me hesitate from blaming the starter motor 100% is that the fault is intermittent so not seeing it on a few tests without the starter in the circuit isn't entirely dispositive that the starter is the problem. I could have just got lucky, and without the starter and engine turning there's no vibration to shake things up. Is it at all possible the contactor is intermittently shorting to the can? I am going to try to find a DC clamp-on current meter. If while stalled there's about 200+ amps in the contactor-starter wire then the motor has to be the issue. Unfortunately sourcing another starter just to try is infeasible. On Jun 17, 2016, at 17:32, Justin Jones wrote: This sounds like an internal problem inside the starter or possibly a chaffing wire (insulation rubbing thin or thru and grounding out) on the starter side on the main contactor. The problem with high current draws is that it can harm the components in the system. The battery, wires, and both contactors can be destroyed. Begin at the starter and trace the big wire all the way back to the battery looking for any signs of chaffing or shorts. Do a continuity check between ground and the main wire on the starter side of the contactors with the battery switch off and battery disconnected from the airframe. If you can't find an issue with the wire, try trying to disconnect the main wire from the starter, insulate it (electricity isolating it) and attempt to crank the starter as you would on a normal start (battery connected). If the battery grounding braid gets hot, the starter isn't the issue and you have a short to ground. If nothing happens, try a different starter. Let us know. Justin > On Jun 17, 2016, at 16:56, Kelly McMullen wrote: > > > Most likely your battery is on its last legs, or it has not achieved a full charge. After being charged, and sitting overnight, the battery resting voltage should be at least 12.7. If it is closer to 12.5, the battery is either weak or didn't get fully charged. You could do, or have done a capacity check. > >> On 6/17/2016 1:44 PM, Alec Myers wrote: >> >> Fresh on the heels of asking for help with the low bus voltage with the engine running in my C182, I now have an issue with intermittent cranking on start. >> >> Symptoms: >> >> About 5 times out of 10 turning the key switch to start elicits no prop movement. Not even a tiny bit. The other times the cranking is healthy. >> >> During a no-turn start, I can hear the starter contactor oscillate on/off at about 5Hz, the bus voltage drops to 6 volts or below, and after a few seconds the earth braid from the battery to the fuselage gets warm/hot to touch. >> >> Yesterday I had the alternator overhauled, and replaced: no change in behaviour. Sometimes it cranks well 10 times in a row, sometimes it fails to turn, 10 times in a row. >> >> After a few trial starts today the battery was dead. So I gave it an external charge 20A for an hour. The next start failed. The one after that was fine, then it went sulky and failed a few times. >> >> Twice in maybe 40 trial starts (been working on this at various times over two days now) the main (battery) contactor has remained shut and I have been unable to shut off the power by turning off the master switch. The second time this happened I gently tapped the battery contactor with a rubber tool and the contact was successfully broken. I have now replaced this contactor. I imagine this stuck-on behaviour is because the contact has tried to open due to low coil voltage and welded itself shut because of an overcurrent condition. >> >> Twice overall I have seen it enter this failure mode during cranking and while the prop is turning: the prop stops and bounces back against the cylinder compression, the bus voltage drops out and the contactor starts to buzz. >> >> This is all consistent with a dead short either in, or downstream of the starter contactor. I would be looking very hard at the starter motor, but I've already had this overhauled, new springs, brushes etc., just yesterday. >> >> Has anyone seen a failure like this in their experience? Anywhere else I could look? It's really a very simple circuit and it must be drawing several hundred amps somewhere... ________________________________________________________________________________
Date: Jun 17, 2016
It is unusual but, a contactor can go bad. Usually if it is mounted the wrong orientation and gets moisture inside causing fungus or electrolysis corrosion on the contact surfaces that carry the heavy current. Since you state that the contactor and lead cable get warm/hot then, this does not point to a failing ignition start switch usually. The starting circuit to activate the contactor is fairly low current; about 5 amps or less. Another unusual failure is in the starter motor windings. The winding could have a cracked armature heavy wire that makes or un-makes at random times. Usually when heat is involved. I have seen this failure in alternators also. Very difficult to chase down.. . . ------------------------------------------------------------------------------------ ----- Original Message ----- From: "Alec Myers" <alec(at)alecmyers.com> Sent: Friday, June 17, 2016 1:44 PM Subject: AeroElectric-List: Problem with starting > > Fresh on the heels of asking for help with the low bus voltage with the > engine running in my C182, I now have an issue with intermittent cranking > on start. > > Symptoms: > > About 5 times out of 10 turning the key switch to start elicits no prop > movement. Not even a tiny bit. The other times the cranking is healthy. > > During a no-turn start, I can hear the starter contactor oscillate on/off > at about 5Hz, the bus voltage drops to 6 volts or below, and after a few > seconds the earth braid from the battery to the fuselage gets warm/hot to > touch. > > Yesterday I had the alternator overhauled, and replaced: no change in > behaviour. Sometimes it cranks well 10 times in a row, sometimes it fails > to turn, 10 times in a row. > > After a few trial starts today the battery was dead. So I gave it an > external charge 20A for an hour. The next start failed. The one after that > was fine, then it went sulky and failed a few times. > > Twice in maybe 40 trial starts (been working on this at various times over > two days now) the main (battery) contactor has remained shut and I have > been unable to shut off the power by turning off the master switch. The > second time this happened I gently tapped the battery contactor with a > rubber tool and the contact was successfully broken. I have now replaced > this contactor. I imagine this stuck-on behaviour is because the contact > has tried to open due to low coil voltage and welded itself shut because > of an overcurrent condition. > > Twice overall I have seen it enter this failure mode during cranking and > while the prop is turning: the prop stops and bounces back against the > cylinder compression, the bus voltage drops out and the contactor starts > to buzz. > > This is all consistent with a dead short either in, or downstream of the > starter contactor. I would be looking very hard at the starter motor, but > I've already had this overhauled, new springs, brushes etc., just > yesterday. > > Has anyone seen a failure like this in their experience? Anywhere else I > could look? It's really a very simple circuit and it must be drawing > several hundred amps somewhere... > > > ________________________________________________________________________________
Subject: Wrong email address - Re-send pls
Date: Jun 18, 2016
I will no longer be checking franz(at)lastfrontierheli.com due to excessive and uncontrollable spam. Please re-send your email to my new address: franz.fux(at)lastfrontierheli.com and make a note of it for the future. Apologies for the inconvenience, Franz Fux Last Frontier Heliskiing - Go Beyond www.lastfrontierheli.com --- Head Office: PO Box 1237, Vernon, BC V1T 6N6, CANADA Tel: 250 558 7980 Fax: 250 558 7981 Reservations: 1-888-655-5566 ________________________________________________________________________________
From: Neal George <ngeorge(at)continentalmotors.aero>
Subject: Problem with starting
Date: Jun 18, 2016
Alec - Which starter motor is on your engine? If it is an ISKRA, you should take it out of service. Replace the starter adapter while you're at it - it is probably damages as well. ISKRA starters feature a planetary gear train that is subject to magnetization and binding. Catastrophic engine failure from starter adapter failure is a real possibility. I have a starter motor I'll let you borrow... Neal Continental Motors Tech Support ========== Unfortunately sourcing another starter just to try is infeasible. ________________________________________________________________________________
Date: Jun 18, 2016
Hi Neal Tha > On Jun 18, 2016, at 9:51 AM, Neal George wrote: > > > Alec - > Which starter motor is on your engine? > If it is an ISKRA, you should take it out of service. Replace the starter adapter while you're at it - it is probably damages as well. ISKRA starters feature a planetary gear train that is subject to magnetization and binding. Catastrophic engine failure from starter adapter failure is a real possibility. > > I have a starter motor I'll let you borrow... > > Neal > Continental Motors Tech Support > > ========== > Unfortunately sourcing another starter just to try is infeasible. > > > > > > ________________________________________________________________________________
Date: Jun 18, 2016
Hi Neal That's very kind! The motor is an original Continental heavy one - direct drive. No evidence of slipping in the adapter. Changing the adapter involves partially removing the engine to gain clearance which I'd like to avoid if possible. Can you get me a stater to borrow to Canada where I am? > On Jun 18, 2016, at 10:45 AM, Alec Myers wrote: > > Hi Neal > > Tha > >> On Jun 18, 2016, at 9:51 AM, Neal George wrote: >> >> >> Alec - >> Which starter motor is on your engine? >> If it is an ISKRA, you should take it out of service. Replace the starter adapter while you're at it - it is probably damages as well. ISKRA starters feature a planetary gear train that is subject to magnetization and binding. Catastrophic engine failure from starter adapter failure is a real possibility. >> >> I have a starter motor I'll let you borrow... >> >> Neal >> Continental Motors Tech Support >> >> ========== >> Unfortunately sourcing another starter just to try is infeasible. >> >> >> >> >> >> ________________________________________________________________________________
Date: Jun 18, 2016
Canada and the cost/aggravation of Customs makes it tough. If you have a Hartzell Energizer, the probability of the starter motor being the problem is low unless it has been badly abused. Pull the motor and take it to your local automotive alternator & starter repair shop - they ought to be able to test it. Neal -----Original Message----- On Behalf Of Alec Myers Sent: Saturday, June 18, 2016 9:50 AM Hi Neal That's very kind! The motor is an original Continental heavy one - direct drive. No evidence of slipping in the adapter. Changing the adapter involves partially removing the engine to gain clearance which I'd like to avoid if possible. Can you get me a stater to borrow to Canada where I am? ________________________________________________________________________________
Date: Jun 18, 2016
. . . never tell an "auto" shop that a part is off an aircraft. . .! Tell them it is off a boat, tractor, etc. !! Most shops in US have a built alarm system that they cannot "touch" anything off of an aircraft, even to test it. . . Maybe the same in Canada. . . . Dave _____________________________________________________________________- ----- Original Message ----- From: "Neal George" <ngeorge(at)continentalmotors.aero> Sent: Saturday, June 18, 2016 12:09 PM Subject: RE: AeroElectric-List: Problem with starting > > > Canada and the cost/aggravation of Customs makes it tough. > > If you have a Hartzell Energizer, the probability of the starter motor > being the problem is low unless it has been badly abused. Pull the motor > and take it to your local automotive alternator & starter repair shop - > they ought to be able to test it. > > Neal > > -----Original Message----- > On Behalf Of Alec Myers > Sent: Saturday, June 18, 2016 9:50 AM > > > Hi Neal > > That's very kind! The motor is an original Continental heavy one - direct > drive. No evidence of slipping in the adapter. Changing the adapter > involves partially removing the engine to gain clearance which I'd like to > avoid if possible. Can you get me a stater to borrow to Canada where I am? > > > ________________________________________________________________________________
Date: Jun 18, 2016
It's an Energiser 12, with a TCM label. Is it possible that an intermittent open-circuit in the armature could cause this? If the rotor goes open circuit the motor stops, the back EMF disappears and the current rises, just like if the motor was stalled. That would draw a lot of current, right? I had the motor overhauled already this last week, after first seeing the problem. Perhaps they missed the fault, but when I take it back it would be good to know what to suggest, especially if looking for something intermittent. On Jun 18, 2016, at 15:09, Neal George wrote: Canada and the cost/aggravation of Customs makes it tough. If you have a Hartzell Energizer, the probability of the starter motor being the problem is low unless it has been badly abused. Pull the motor and take it to your local automotive alternator & starter repair shop - they ought to be able to test it. Neal -----Original Message----- On Behalf Of Alec Myers Sent: Saturday, June 18, 2016 9:50 AM Hi Neal That's very kind! The motor is an original Continental heavy one - direct drive. No evidence of slipping in the adapter. Changing the adapter involves partially removing the engine to gain clearance which I'd like to avoid if possible. Can you get me a stater to borrow to Canada where I am? ________________________________________________________________________________
Date: Jun 19, 2016
From: Stephen Richards <stephencliverichards(at)gmail.com>
Date: Jun 19, 2016
VGhlc2UgYXJlIHNlcmllcyBtb3RvcnMgc28gaXQgd2lsbCBoYXZlIHRvIGJlIGEgc2hvcnQgY2ly Y3VpdCBjb3VsZCBiZSBhIGludGVybWl0dGVudCBzaG9ydCBvZiBmaWVsZCBpcyBhIGxpdmUgYnJ1 c2ggdGFpbCBncm91bmRpbmcgPyBBbHRlcm5hdGl2ZWx5IGlzIGl0IG1lY2hhbmljYWxseSBzZWl6 aW5nLg0KQ2xpdmUgDQoNCi0tLS0tT3JpZ2luYWwgTWVzc2FnZS0tLS0tDQpGcm9tOiAiQWxlYyBN eWVycyIgPGFsZWNAYWxlY215ZXJzLmNvbT4NClNlbnQ6IOKAjjE4L+KAjjA2L+KAjjIwMTYgMjI6 MzANClRvOiAiYWVyb2VsZWN0cmljLWxpc3RAbWF0cm9uaWNzLmNvbSIgPGFlcm9lbGVjdHJpYy1s aXN0QG1hdHJvbmljcy5jb20+DQpTdWJqZWN0OiBSZTogQWVyb0VsZWN0cmljLUxpc3Q6IFByb2Js ZW0gd2l0aCBzdGFydGluZw0KDQotLT4gQWVyb0VsZWN0cmljLUxpc3QgbWVzc2FnZSBwb3N0ZWQg Ynk6IEFsZWMgTXllcnMgPGFsZWNAYWxlY215ZXJzLmNvbT4NCg0KSXQncyBhbiBFbmVyZ2lzZXIg MTIsIHdpdGggYSBUQ00gbGFiZWwuDQoNCklzIGl0IHBvc3NpYmxlIHRoYXQgYW4gaW50ZXJtaXR0 ZW50IG9wZW4tY2lyY3VpdCBpbiB0aGUgYXJtYXR1cmUgY291bGQgY2F1c2UgdGhpcz8gSWYgdGhl IHJvdG9yIGdvZXMgb3BlbiBjaXJjdWl0IHRoZSBtb3RvciBzdG9wcywgdGhlIGJhY2sgRU1GIGRp c2FwcGVhcnMgYW5kIHRoZSBjdXJyZW50IHJpc2VzLCBqdXN0IGxpa2UgaWYgdGhlIG1vdG9yIHdh cyBzdGFsbGVkLiBUaGF0IHdvdWxkIGRyYXcgYSBsb3Qgb2YgY3VycmVudCwgcmlnaHQ/DQoNCkkg aGFkIHRoZSBtb3RvciBvdmVyaGF1bGVkIGFscmVhZHkgdGhpcyBsYXN0IHdlZWssIGFmdGVyIGZp cnN0IHNlZWluZyB0aGUgcHJvYmxlbS4gUGVyaGFwcyB0aGV5IG1pc3NlZCB0aGUgZmF1bHQsIGJ1 dCB3aGVuIEkgdGFrZSBpdCBiYWNrIGl0IHdvdWxkIGJlIGdvb2QgdG8ga25vdyB3aGF0IHRvIHN1 Z2dlc3QsIGVzcGVjaWFsbHkgaWYgbG9va2luZyBmb3Igc29tZXRoaW5nIGludGVybWl0dGVudC4N Cg0KT24gSnVuIDE4LCAyMDE2LCBhdCAxNTowOSwgTmVhbCBHZW9yZ2UgPG5nZW9yZ2VAY29udGlu ZW50YWxtb3RvcnMuYWVybz4gd3JvdGU6DQoNCi0tPiBBZXJvRWxlY3RyaWMtTGlzdCBtZXNzYWdl IHBvc3RlZCBieTogTmVhbCBHZW9yZ2UgPG5nZW9yZ2VAY29udGluZW50YWxtb3RvcnMuYWVybz4N Cg0KQ2FuYWRhIGFuZCB0aGUgY29zdC9hZ2dyYXZhdGlvbiBvZiBDdXN0b21zIG1ha2VzIGl0IHRv dWdoLiAgDQoNCklmIHlvdSBoYXZlIGEgSGFydHplbGwgRW5lcmdpemVyLCB0aGUgcHJvYmFiaWxp dHkgb2YgdGhlIHN0YXJ0ZXIgbW90b3IgYmVpbmcgdGhlIHByb2JsZW0gaXMgbG93IHVubGVzcyBp dCBoYXMgYmVlbiBiYWRseSBhYnVzZWQuICBQdWxsIHRoZSBtb3RvciBhbmQgdGFrZSBpdCB0byB5 b3VyIGxvY2FsIGF1dG9tb3RpdmUgYWx0ZXJuYXRvciAmIHN0YXJ0ZXIgcmVwYWlyIHNob3AgLSB0 aGV5IG91Z2h0IHRvIGJlIGFibGUgdG8gdGVzdCBpdC4gIA0KDQpOZWFsDQoNCi0tLS0tT3JpZ2lu YWwgTWVzc2FnZS0tLS0tDQpPbiBCZWhhbGYgT2YgQWxlYyBNeWVycw0KU2VudDogU2F0dXJkYXks IEp1bmUgMTgsIDIwMTYgOTo1MCBBTQ0KDQotLT4gQWVyb0VsZWN0cmljLUxpc3QgbWVzc2FnZSBw b3N0ZWQgYnk6IEFsZWMgTXllcnMgPGFsZWNAYWxlY215ZXJzLmNvbT4NCg0KSGkgTmVhbA0KDQpU aGF0J3MgdmVyeSBraW5kISBUaGUgbW90b3IgaXMgYW4gb3JpZ2luYWwgQ29udGluZW50YWwgaGVh dnkgb25lIC0gZGlyZWN0IGRyaXZlLiBObyBldmlkZW5jZSBvZiBzbGlwcGluZyBpbiB0aGUgYWRh cHRlci4gQ2hhbmdpbmcgdGhlIGFkYXB0ZXIgaW52b2x2ZXMgcGFydGlhbGx5IHJlbW92aW5nIHRo ZSBlbmdpbmUgdG8gZ2FpbiBjbGVhcmFuY2Ugd2hpY2ggSSdkIGxpa2UgdG8gYXZvaWQgaWYgcG9z c2libGUuIENhbiB5b3UgZ2V0IG1lIGEgc3RhdGVyIHRvIGJvcnJvdyB0byBDYW5hZGEgd2hlcmUg SSBhbT8NCg0KDQoNCg0KDQoNCg0KDQoNCg0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAgICAgICAgICAtIFRoZSBBZXJv RWxlY3RyaWMtTGlzdCBFbWFpbCBGb3J1bSAtDQpfLT0gVXNlIHRoZSBNYXRyb25pY3MgTGlzdCBG ZWF0dXJlcyBOYXZpZ2F0b3IgdG8gYnJvd3NlDQpfLT0gdGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMg c3VjaCBhcyBMaXN0IFVuL1N1YnNjcmlwdGlvbiwNCl8tPSBBcmNoaXZlIFNlYXJjaCAmIERvd25s b2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwNCl8tPSBQaG90b3NoYXJlLCBhbmQgbXVjaCBt dWNoIG1vcmU6DQpfLT0NCl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdh dG9yP0Flcm9FbGVjdHJpYy1MaXN0DQpfLT0NCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQpfLT0gICAgICAgICAgICAgICAtIE1B VFJPTklDUyBXRUIgRk9SVU1TIC0NCl8tPSBTYW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFi bGUgdmlhIHRoZSBXZWIgRm9ydW1zIQ0KXy09DQpfLT0gICAtLT4gaHR0cDovL2ZvcnVtcy5tYXRy b25pY3MuY29tDQpfLT0NCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09DQpfLT0gICAgICAgICAgICAgIC0gTkVXIE1BVFJPTklDUyBM SVNUIFdJS0kgLQ0KXy09IEFkZCBzb21lIGluZm8gdG8gdGhlIE1hdHJvbmljcyBFbWFpbCBMaXN0 IFdpa2khDQpfLT0gICAtLT4gaHR0cDovL3dpa2kubWF0cm9uaWNzLmNvbQ0KXy09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAg ICAgICAgICAgICAtIExpc3QgQ29udHJpYnV0aW9uIFdlYiBTaXRlIC0NCl8tPSAgVGhhbmsgeW91 IGZvciB5b3VyIGdlbmVyb3VzIHN1cHBvcnQhDQpfLT0gICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uDQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRy b25pY3MuY29tL2NvbnRyaWJ1dGlvbg0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCg0KDQoNCg= ________________________________________________________________________________
Date: Jun 19, 2016
Neal I see from the TCM service manual that faults in the windings of the Energizer motor are not repairable. SIL02-04 says the TCM replacement is now the Iskra starter that you don't recommend. Given that I have the old-style starter adapter If I need a new motor which would you recommend? > On Jun 18, 2016, at 3:09 PM, Neal George wrote: > > > Canada and the cost/aggravation of Customs makes it tough. > > If you have a Hartzell Energizer, the probability of the starter motor being the problem is low unless it has been badly abused. Pull the motor and take it to your local automotive alternator & starter repair shop - they ought to be able to test it. > > Neal > > -----Original Message----- > On Behalf Of Alec Myers > Sent: Saturday, June 18, 2016 9:50 AM > > > Hi Neal > > That's very kind! The motor is an original Continental heavy one - direct drive. No evidence of slipping in the adapter. Changing the adapter involves partially removing the engine to gain clearance which I'd like to avoid if possible. Can you get me a stater to borrow to Canada where I am? > > > > > > > ________________________________________________________________________________
Date: Jun 19, 2016
Did I misunderstand that you just had the motor overhauled? All Continental starter adapters have the same motor interface. The current starter adapter for Sandcast engines is indeed different and is not interchangeable with the older version. If you have the old-style adapter, if it fails you will need to have it overhauled. Your engine can be modified to accept the new adapter, but requires splitting the crankcase. The Energizer starter motor from Hartzell Engine Technologies is the preferred unit. I'm still not convinced you have a motor problem. The chattering relay points more to circuit / system and low voltage issues. neal -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Alec Myers Sent: Sunday, June 19, 2016 7:40 AM Subject: Re: AeroElectric-List: Problem with starting Neal I see from the TCM service manual that faults in the windings of the Energizer motor are not repairable. SIL02-04 says the TCM replacement is now the Iskra starter that you don't recommend. Given that I have the old-style starter adapter If I need a new motor which would you recommend? ________________________________________________________________________________
Date: Jun 19, 2016
> >I'm still not convinced you have a motor problem. The chattering >relay points more to circuit / system and low voltage issues. > >neal Except that a contactor powered from the same battery that is being pulled down by what amounts to continuous stall current may well drop-out during closures only to re-close when the contacts break and stall-current goes away. 12v battery contactors drop at about 2v . . . and are not likely to be candidates for 'buzzing' but it's not impossible. A easy experiment would call for powering the starter contactor from a separate source . . . like another battery. It may well stop chattering. But the energies being circulated will be profound. I'm puzzled by the intermittent nature of the symptom. This implies a root cause that is transient or loose to rattle around. Having the starter motor come to rest on a bad pass in the armature windings could account for such behavior. It would sure be illuminating to put a data acquisition system on it to capture all the voltages/currents during the event. Bob . . . ________________________________________________________________________________
Date: Jun 19, 2016
The strangest symptom is that twice the motor has cut out (and the bus volta ge was pulled down) mid-crank while the prop was already turning at a good s tarting speed. I think that suggests it's not a bad spot on the commutator, f or example. I can rule out mechanical seizure at the crank because when the motor cut, t he prop immediately bounced back off a compression stroke, and (I think) I c an rule out a starter jam because the engine has started and run since. I thought I was onto something with a possible fracture in the field winding but that won't explain things if the motor isn't shunt wound. > On Jun 19, 2016, at 09:29, Robert L. Nuckolls, III <nuckolls.bob@aeroelect ric.com> wrote: > > > I'm still not convinced you have a motor problem. The chattering relay po ints more to circuit / system and low voltage issues. > > neal Except that a contactor powered from the same battery that is being pulled down by what amounts to continuous stall current may well drop-out during closures only to re-close when the contacts break and stall-current goes away. 12v battery contactors drop at about 2v . . . and are not likely to be candidates for 'buzzing' but it's not impossible. A easy experiment would call for powering the starter contactor from a separate source . . . like another battery. It may well stop chattering. But the energies being circulated will be profound. I'm puzzled by the intermittent nature of the symptom. This implies a root cause that is transient or loose to rattle around. Having the starter motor come to rest on a bad pass in the armature windings could account for such behavior. It would sure be illuminating to put a data acquisition system on it to capture all the voltages/currents during the event. Bob . . . ________________________________________________________________________________
Date: Jun 19, 2016
I considered that, thought it unlikely since the motor was recently service d. I had a similar failure on my 99 Suburban. Turn the key; nothing. Smack the starter with a mallet, it would come to life... neal I'm puzzled by the intermittent nature of the symptom. This implies a root cause that is transient or loose to rattle around. Having the starter motor come to rest on a bad pass in the armature windings could account for such behavior. Bob . . . ________________________________________________________________________________
Date: Jun 19, 2016
Subject: Opinions on options
Architecture: Twin battery,alternator and buss system with an electrically dependent fuel system. Basically, two complete systems with a emergency cross-tie relay. There are three fuse blocks, one of which I can power via diodes from each system. Question: Opinions wanted on FEMA between just powering each boost pump system off of one of the alternators or using a dedicated, diode powered fuse block as an essential buss. I can see simplicity in the first option. The second has some elegance, but there is something of a single point failure there, as well. Scott ________________________________________________________________________________
Date: Jun 19, 2016
Subject: Re: Opinions on options
From: s64woody(at)aol.com Subject: AeroElectric-List: Opinions on options Architecture: Twin battery,alternator and buss system with an electrically dependent fuel system. Basically, two complete systems with a emergency cross-tie relay. There are three fuse blocks, one of which I can power via diodes from each system. Question: Opinions wanted on FEMA between just powering each boost pump system off of one of the alternators or using a dedicated, diode powered fuse block as an essential buss. I can see simplicity in the first option. The second has some elegance, but there is something of a single point failure there, as well. That may be much more electrical system than is necessary . . . but if you're already committed, run each pump from separate battery busses. Likelihood of loosing both busses during expenditure of one tank of fuel is vanishingly small. If any part of your engine support is electrically driven, run those items directly from battery busses as well. If you have bad smells in the cockpit, you want to make the entire electrical system "cold" without affecting engine operation. Bob . . . ________________________________________________________________________________
Date: Jun 19, 2016
This still suggests to me that a intermittent ground is shorting out the ar mature or field is shorting out . Clive -----Original Message----- From: "Alec Myers" <alec(at)alecmyers.com> Sent: =8E19/=8E06/=8E2016 14:51 Subject: Re: AeroElectric-List: Problem with starting The strangest symptom is that twice the motor has cut out (and the bus volt age was pulled down) mid-crank while the prop was already turning at a good starting speed. I think that suggests it's not a bad spot on the commutato r, for example. I can rule out mechanical seizure at the crank because when the motor cut, the prop immediately bounced back off a compression stroke, and (I think) I can rule out a starter jam because the engine has started and run since. I thought I was onto something with a possible fracture in the field windin g but that won't explain things if the motor isn't shunt wound. On Jun 19, 2016, at 09:29, Robert L. Nuckolls, III <nuckolls.bob@aeroelectr ic.com> wrote: I'm still not convinced you have a motor problem. The chattering relay poi nts more to circuit / system and low voltage issues. neal Except that a contactor powered from the same battery that is being pulled down by what amounts to continuous stall current may well drop-out during closures only to re-close when the contacts break and stall-current goes away. 12v battery contactors drop at about 2v . . . and are not likely to be candidates for 'buzzing' but it's not impossible. A easy experiment would call for powering the starter contactor from a separate source . . . like another battery. It may well stop chattering. But the energies being circulated will be profound. I'm puzzled by the intermittent nature of the symptom. This implies a root cause that is transient or loose to rattle around. Having the starter motor come to rest on a bad pass in the armature windings could account for such behavior. It would sure be illuminating to put a data acquisition system on it to capture all the voltages/currents during the event. Bob . . . ________________________________________________________________________________
Date: Jun 20, 2016
Subject: Re: Wrong email address - Re-send pls
Date: Jun 20, 2016
Hi Guys This daily email is getting annoying now Regards John Sent from my iPad ----x--O--x---- > On 20 Jun 2016, at 08:40 am, "Franz Fux" wrote: > > > I will no longer be checking franz(at)lastfrontierheli.com due to excessive > and uncontrollable spam. > > Please re-send your email to my new address: > > franz.fux(at)lastfrontierheli.com and make a note of it for the future. > > Apologies for the inconvenience, > > Franz Fux > Last Frontier Heliskiing - Go Beyond > www.lastfrontierheli.com > --- > > Head Office: PO Box 1237, Vernon, BC V1T 6N6, CANADA > > Tel: 250 558 7980 > Fax: 250 558 7981 > Reservations: 1-888-655-5566 > > > > ________________________________________________________________________________
Date: Jun 20, 2016
I had the same problem recently....the thrust washer on the starter was worn and this caused the end of the commutator to short out intermittently. Very frustrating as the starter bench tested fine... On 19 June 2016 at 19:28, Stephen Richards wrote: > This still suggests to me that a intermittent ground is shorting out the > armature or field is shorting out . > Clive > ------------------------------ > From: Alec Myers <alec(at)alecmyers.com> > Sent: =8E19/=8E06/=8E2016 14:51 > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Problem with starting > > The strangest symptom is that twice the motor has cut out (and the bus > voltage was pulled down) mid-crank while the prop was already turning at a > good starting speed. I think that suggests it's not a bad spot on the > commutator, for example. > > I can rule out mechanical seizure at the crank because when the motor cut , > the prop immediately bounced back off a compression stroke, and (I think) I > can rule out a starter jam because the engine has started and run since. > > I thought I was onto something with a possible fracture in the field > winding but that won't explain things if the motor isn't shunt wound. > > > On Jun 19, 2016, at 09:29, Robert L. Nuckolls, III < > nuckolls.bob(at)aeroelectric.com> wrote: > > > I'm still not convinced you have a motor problem. The chattering relay > points more to circuit / system and low voltage issues. > > neal > > > Except that a contactor powered from the same > battery that is being pulled down by what amounts > to continuous stall current may well drop-out > during closures only to re-close when the contacts > break and stall-current goes away. > > 12v battery contactors drop at about 2v . . . and > are not likely to be candidates for 'buzzing' but > it's not impossible. A easy experiment would call > for powering the starter contactor from a separate > source . . . like another battery. It may well > stop chattering. But the energies being circulated > will be profound. > > I'm puzzled by the intermittent nature of the > symptom. This implies a root cause that > is transient or loose to rattle around. Having > the starter motor come to rest on a bad pass > in the armature windings could account for such > behavior. > > It would sure be illuminating to put a data acquisition > system on it to capture all the voltages/currents > during the event. > > Bob . . . > -- Best... Bob Verwey ________________________________________________________________________________
Date: Jun 20, 2016
Subject: Parts
When asked about aircraft parts or test at an automotive parts store I tell them it is for "my very high clearance off road vehicle". ________________________________________________________________________________
Date: Jun 20, 2016
At 02:49 AM 6/20/2016, you wrote: > > >Hi Guys > >This daily email is getting annoying now I've emailed him to request that he UNsubscribe the old address from the List . . . Bob . . . ________________________________________________________________________________
Subject: Re: Parts
Date: Jun 20, 2016
The one I use is the part is for an airboat. Raymond Julian Kettle River, MN The things we admire in men, kindness and generosity, openness, honesty, understanding and feeling are the concomitants of failure in our system. And those traits we detest, sharpness, greed, acquisitiveness, meanness, egotism and self-interest are the traits of success. And while men admire the quality of the first they love the produce of the second. -John Steinbeck, novelist, Nobel laureate (1902-1968) On 06/20/2016 07:54 AM, BobbyPaulk(at)comcast.net wrote: > When asked about aircraft parts or test at an automotive parts store I > tell them it is for "my very high clearance off road vehicle". ________________________________________________________________________________
Subject: Dual batteries or dual alternators?
Date: Jun 20, 2016
Hello Bob Over on another popular forum, there was recently a discussion on whether it was preferable to have an electrical system with two batteries or with two alternators. Having previously read the Aeroelectric Connection and followed your forum here, my 2 cents worth would advocate for two alternators, as this provides unlimited duration backup; however, many disagreed. In particular, the owner of EFII (www.flyefii.com) said the following: "Electrical system complexity follows a progression: 1. One batt, one alternator 2. Two batts, one alternator 3. Two batts, two alternators One batt, two alternators is a problem. If you lose the batt, all you have left is half wave rectified AC power off the alternator - this means unhappy electronics. There needs to be a functioning battery in the system to absorb the pulses from the alternator." I feel pretty confident that if my battery successfully starts my engine that I am unlikely to "lose the battery" during a flight, and I also have some doubts about the need for a battery to absorb pulses from the alternator. Don't want to start any war of the experts here, but I would welcome your comment, and may repost your reply to the other forum as a followup, as many do respect your opinion. Best regards, Erich Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457320#457320 ________________________________________________________________________________
Subject: Re: Dual batteries or dual alternators?
Date: Jun 20, 2016
Are you referring to the Vans forums? > On Jun 20, 2016, at 17:55, erich weaver wrote: > > > Hello Bob > > Over on another popular forum, there was recently a discussion on whether it was preferable to have an electrical system with two batteries or with two alternators. Having previously read the Aeroelectric Connection and followed your forum here, my 2 cents worth would advocate for two alternators, as this provides unlimited duration backup; however, many disagreed. In particular, the owner of EFII (www.flyefii.com) said the following: > > "Electrical system complexity follows a progression: > 1. One batt, one alternator > 2. Two batts, one alternator > 3. Two batts, two alternators > > One batt, two alternators is a problem. If you lose the batt, all you have left is half wave rectified AC power off the alternator - this means unhappy electronics. There needs to be a functioning battery in the system to absorb the pulses from the alternator." > > I feel pretty confident that if my battery successfully starts my engine that I am unlikely to "lose the battery" during a flight, and I also have some doubts about the need for a battery to absorb pulses from the alternator. > > Don't want to start any war of the experts here, but I would welcome your comment, and may repost your reply to the other forum as a followup, as many do respect your opinion. > > Best regards, > > Erich > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=457320#457320 > > > > > > > > > > ________________________________________________________________________________
Subject: Re: Parts
Date: Jun 20, 2016
I like the ". . . very high clearance,. . . . " description. . . ------------------------------------------------------------------------- ------- ----- Original Message ----- From: BobbyPaulk(at)comcast.net To: aeroelectric-list Sent: Monday, June 20, 2016 5:54 AM Subject: AeroElectric-List: Parts When asked about aircraft parts or test at an automotive parts store I tell them it is for "my very high clearance off road vehicle". ________________________________________________________________________________
Date: Jun 20, 2016
Erich, I have a single battery dual alternator system wired like Bobs Z 13-8. I fly in Remote Alaska and have the Dual ECU EFII system. Twice now I have run into alternator trouble on a remote gravel bar 2 hours from civilization. Once was a bad primary alternator and the next time was a pulley that came off the primary alternator. In both cases, I didn't have use of the primary alternator. Had I not had a secondary alternator. On the vacuum pad, I would not have been able to depart because I wouldn't have safely had the battery longevity to fly to civilization. I would have had to have someone fly parts out. Since I had a secondary alternator, I switched off the primary, switched on the secondary, and flew home safely. I have no regrets and I am happy that I went with this architecture and Bob has been more than helpful and displays masterful knowledge. Hope this helps. Justin. > On Jun 20, 2016, at 17:55, erich weaver wrote: > > > Hello Bob > > Over on another popular forum, there was recently a discussion on whether it was preferable to have an electrical system with two batteries or with two alternators. Having previously read the Aeroelectric Connection and followed your forum here, my 2 cents worth would advocate for two alternators, as this provides unlimited duration backup; however, many disagreed. In particular, the owner of EFII (www.flyefii.com) said the following: > > "Electrical system complexity follows a progression: > 1. One batt, one alternator > 2. Two batts, one alternator > 3. Two batts, two alternators > > One batt, two alternators is a problem. If you lose the batt, all you have left is half wave rectified AC power off the alternator - this means unhappy electronics. There needs to be a functioning battery in the system to absorb the pulses from the alternator." > > I feel pretty confident that if my battery successfully starts my engine that I am unlikely to "lose the battery" during a flight, and I also have some doubts about the need for a battery to absorb pulses from the alternator. > > Don't want to start any war of the experts here, but I would welcome your comment, and may repost your reply to the other forum as a followup, as many do respect your opinion. > > Best regards, > > Erich > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=457320#457320 > > > > > > > > > > ________________________________________________________________________________
Date: Jun 20, 2016
All makes sense to me Justin; I followed the Z-13/8 architecture as well on my RV-7A. Yes, original post was on the VAF forum. Just a bit surprised by the response from EFII. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457325#457325 ________________________________________________________________________________
Date: Jun 20, 2016
Surprised indeed. I've never seen an alternator that normally put out "half wave rectified power" and I have seen automotive EFI systems run fine with a disconnected battery. There have been cases of some alternators going offline when overloaded to the point where the voltage drops way off but that isn't going to happen with a PM alternator. I'd want to suss out that scenario though with the alternator of choice if there are any heavy loads in the aircraft. I just used two tiny Dekka batteries that together weigh the same as the popular odysey battery and called it done. One has been in use for 10 years and the other 9 years now which for me makes the economics darn good compared to maintaining a single larger battery. Ken On 20/06/2016 7:06 PM, erich weaver wrote: > > All makes sense to me Justin; I followed the Z-13/8 architecture as well on my RV-7A. Yes, original post was on the VAF forum. Just a bit surprised by the response from EFII. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=457325#457325 > > ________________________________________________________________________________
Date: Jun 20, 2016
Can not argue with the order of complexity. As for which architecture is best, it is a matter of personal preference. A battery failing in flight is unlikely. Even if it did, how would you know it? What are the symptoms? If the pilot correctly identifies a battery failure, what is the correct action to take and why? I question the statement, "all you have left is half wave rectified AC power off the alternator". Most alternators put out rectified 3-phase full-wave current, not half wave DC. I agree with your statement, "I also have some doubts about the need for a battery to absorb pulses from the alternator." Our electrical guru has stated that avionics should be designed to handle anything an aircraft electrical system can throw at it. The ideal electrical system will keep critical equipment functioning even if a failure occurs and without requiring any action by the pilot, except to make a note to do repairs after landing. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457329#457329 ________________________________________________________________________________
Date: Jun 20, 2016
Progress.... I now have the motor on the test bench displaying its sometimes -run sometimes-short-circuit behaviour. And I have video of both. Given that I just had it overhauled, new brushes etc., I think I am going to cut my losses and get a replacement motor - same model, from Hartzel. On Jun 19, 2016, at 13:28, Stephen Richards wrote: This still suggests to me that a intermittent ground is shorting out the arm ature or field is shorting out . Clive From: Alec Myers Sent: =8E19/=8E06/=8E2016 14:51 Subject: Re: AeroElectric-List: Problem with starting The strangest symptom is that twice the motor has cut out (and the bus volta ge was pulled down) mid-crank while the prop was already turning at a good s tarting speed. I think that suggests it's not a bad spot on the commutator, f or example. I can rule out mechanical seizure at the crank because when the motor cut, t he prop immediately bounced back off a compression stroke, and (I think) I c an rule out a starter jam because the engine has started and run since. I thought I was onto something with a possible fracture in the field winding but that won't explain things if the motor isn't shunt wound. > On Jun 19, 2016, at 09:29, Robert L. Nuckolls, III <nuckolls.bob@aeroelect ric.com> wrote: > > > I'm still not convinced you have a motor problem. The chattering relay po ints more to circuit / system and low voltage issues. > > neal Except that a contactor powered from the same battery that is being pulled down by what amounts to continuous stall current may well drop-out during closures only to re-close when the contacts break and stall-current goes away. 12v battery contactors drop at about 2v . . . and are not likely to be candidates for 'buzzing' but it's not impossible. A easy experiment would call for powering the starter contactor from a separate source . . . like another battery. It may well stop chattering. But the energies being circulated will be profound. I'm puzzled by the intermittent nature of the symptom. This implies a root cause that is transient or loose to rattle around. Having the starter motor come to rest on a bad pass in the armature windings could account for such behavior. It would sure be illuminating to put a data acquisition system on it to capture all the voltages/currents during the event. Bob . . . ________________________________________________________________________________
Subject: OT: PCB coating removal
Date: Jun 20, 2016
Greetings, I'm working on a PCB that has a clear dip coating. Originally made in the 70s-80s. The coating will melt with a soldering iron, but I'm wondering if there is a better way to remove the coating. The component I'm working is a quartz crystal that is part of the tone generator on lineman's test handset. If any one is aware of a tutorial for identifying the value of the crystal, I'd sure appreciate a head's up. TIA -- Raymond Julian Kettle River, MN The things we admire in men, kindness and generosity, openness, honesty, understanding and feeling are the concomitants of failure in our system. And those traits we detest, sharpness, greed, acquisitiveness, meanness, egotism and self-interest are the traits of success. And while men admire the quality of the first they love the produce of the second. -John Steinbeck, novelist, Nobel laureate (1902-1968) ________________________________________________________________________________
Date: Jun 20, 2016
Robert at EFII wants you to use his bus manager. It's an additional $600-800 and can't handle 2 alternators. Its economically advantageous for him to recommend a system that works with his bus manager. I don't want to sound like I'm trash talking Robert here. I'm not. He has incredible customer service and is a stand up guy! Justin > On Jun 20, 2016, at 18:06, erich weaver wrote: > > > All makes sense to me Justin; I followed the Z-13/8 architecture as well on my RV-7A. Yes, original post was on the VAF forum. Just a bit surprised by the response from EFII. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=457325#457325 > > > > > > > > > > ________________________________________________________________________________
Date: Jun 20, 2016
If you want the EFII Bus Manager set up for two alternators, you can get it that way. It can indeed "handle two alternators." On Mon, Jun 20, 2016 at 5:18 PM, Justin Jones wrote: > jmjones2000(at)mindspring.com> > > Robert at EFII wants you to use his bus manager. It's an additional > $600-800 and can't handle 2 alternators. Its economically advantageous for > him to recommend a system that works with his bus manager. > > I don't want to sound like I'm trash talking Robert here. I'm not. He has > incredible customer service and is a stand up guy! > > Justin > > > On Jun 20, 2016, at 18:06, erich weaver wrote: > > > erich.weaver(at)aecom.com> > > > > All makes sense to me Justin; I followed the Z-13/8 architecture as > well on my RV-7A. Yes, original post was on the VAF forum. Just a bit > surprised by the response from EFII. > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=457325#457325 > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jun 20, 2016
Good to know. Thanks Ken. It doesn't show this on the manuals available onli ne > On Jun 20, 2016, at 20:33, Ken Ryan wrote: > > If you want the EFII Bus Manager set up for two alternators, you can get i t that way. It can indeed "handle two alternators." > >> On Mon, Jun 20, 2016 at 5:18 PM, Justin Jones wrote: ring.com> >> >> Robert at EFII wants you to use his bus manager. It's an additional $600- 800 and can't handle 2 alternators. Its economically advantageous for him to recommend a system that works with his bus manager. >> >> I don't want to sound like I'm trash talking Robert here. I'm not. He has incredible customer service and is a stand up guy! >> >> Justin >> >> > On Jun 20, 2016, at 18:06, erich weaver wrote: >> > ecom.com> >> > >> > All makes sense to me Justin; I followed the Z-13/8 architecture as we ll on my RV-7A. Yes, original post was on the VAF forum. Just a bit surpris ed by the response from EFII. >> > >> > >> > >> > >> > Read this topic online here: >> > >> > http://forums.matronics.com/viewtopic.php?p=457325#457325 >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> >> >> >> ========== >> - >> Electric-List" rel="noreferrer" target="_blank">http://www.matronics. com/Navigator?AeroElectric-List >> ========== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ========== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contributio n >> ========== > ________________________________________________________________________________
Date: Jun 20, 2016
I've got one that has never been used (that I am not using) if anybody is looking for a good price :) When I bought mine it was an either/or on the two alternator set up, but Robert said the next run would have a jumper so that it could be used either way (one alternator or two). I don't know if that has happened yet or not. On Mon, Jun 20, 2016 at 5:52 PM, Justin Jones wrote: > Good to know. Thanks Ken. It doesn't show this on the manuals available > online > > On Jun 20, 2016, at 20:33, Ken Ryan wrote: > > If you want the EFII Bus Manager set up for two alternators, you can get > it that way. It can indeed "handle two alternators." > > On Mon, Jun 20, 2016 at 5:18 PM, Justin Jones > wrote: > >> jmjones2000(at)mindspring.com> >> >> Robert at EFII wants you to use his bus manager. It's an additional >> $600-800 and can't handle 2 alternators. Its economically advantageous for >> him to recommend a system that works with his bus manager. >> >> I don't want to sound like I'm trash talking Robert here. I'm not. He has >> incredible customer service and is a stand up guy! >> >> Justin >> >> > On Jun 20, 2016, at 18:06, erich weaver wrote: >> > >> erich.weaver(at)aecom.com> >> > >> > All makes sense to me Justin; I followed the Z-13/8 architecture as >> well on my RV-7A. Yes, original post was on the VAF forum. Just a bit >> surprised by the response from EFII. >> > >> > >> > >> > >> > Read this topic online here: >> > >> > http://forums.matronics.com/viewtopic.php?p=457325#457325 >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> >> >> >> ========== >> - >> Electric-List" rel="noreferrer" target="_blank"> >> http://www.matronics.com/Navigator?AeroElectric-List >> ========== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ========== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> > ________________________________________________________________________________
Date: Jun 20, 2016
Robert may take yours and modify it for you. He is an awesome guy and I'm be yond satisfied with the EFII products and his customer service! > On Jun 20, 2016, at 21:03, Ken Ryan wrote: > > I've got one that has never been used (that I am not using) if anybody is l ooking for a good price :) When I bought mine it was an either/or on the two alternator set up, but Robert said the next run would have a jumper so that it could be used either way (one alternator or two). I don't know if that h as happened yet or not. > > >> On Mon, Jun 20, 2016 at 5:52 PM, Justin Jones wrote: >> Good to know. Thanks Ken. It doesn't show this on the manuals available o nline >> >>> On Jun 20, 2016, at 20:33, Ken Ryan wrote: >>> >>> If you want the EFII Bus Manager set up for two alternators, you can get it that way. It can indeed "handle two alternators." >>> >>>> On Mon, Jun 20, 2016 at 5:18 PM, Justin Jones wrote: spring.com> >>>> >>>> Robert at EFII wants you to use his bus manager. It's an additional $60 0-800 and can't handle 2 alternators. Its economically advantageous for him t o recommend a system that works with his bus manager. >>>> >>>> I don't want to sound like I'm trash talking Robert here. I'm not. He h as incredible customer service and is a stand up guy! >>>> >>>> Justin >>>> >>>> > On Jun 20, 2016, at 18:06, erich weaver wrot e: >>>> > @aecom.com> >>>> > >>>> > All makes sense to me Justin; I followed the Z-13/8 architecture as w ell on my RV-7A. Yes, original post was on the VAF forum. Just a bit surpri sed by the response from EFII. >>>> > >>>> > >>>> > >>>> > >>>> > Read this topic online here: >>>> > >>>> > http://forums.matronics.com/viewtopic.php?p=457325#457325 >>>> > >>>> > >>>> > >>>> > >>>> > >>>> > >>>> > >>>> > >>>> > >>>> > >>>> >>>> >>>> >>>> ========== >>>> - >>>> Electric-List" rel="noreferrer" target="_blank">http://www.matronic s.com/Navigator?AeroElectric-List >>>> ========== >>>> FORUMS - >>>> eferrer" target="_blank">http://forums.matronics.com >>>> ========== >>>> WIKI - >>>> errer" target="_blank">http://wiki.matronics.com >>>> ========== >>>> b Site - >>>> -Matt Dralle, List Admin. >>>> rel="noreferrer" target="_blank">http://www.matronics.com/contribut ion >>>> ========== > ________________________________________________________________________________
Date: Jun 20, 2016
At 06:06 PM 6/20/2016, you wrote: > > >All makes sense to me Justin; I followed the Z-13/8 architecture as >well on my RV-7A. Yes, original post was on the VAF forum. Just a >bit surprised by the response from EFII. . . . which was? Bob . . . ________________________________________________________________________________
Date: Jun 21, 2016
At 04:55 PM 6/20/2016, you wrote: > > >Hello Bob > >Over on another popular forum, there was recently a discussion on >whether it was preferable to have an electrical system with two >batteries or with two alternators. Having previously read the >Aeroelectric Connection and followed your forum here, my 2 cents >worth would advocate for two alternators, as this provides unlimited >duration backup; however, many disagreed. In particular, the owner >of EFII (www.flyefii.com) said the following: > >"Electrical system complexity follows a progression: > 1. One batt, one alternator > 2. Two batts, one alternator > 3. Two batts, two alternators > >One batt, two alternators is a problem. If you lose the batt, all >you have left is half wave rectified AC power off the alternator - >this means unhappy electronics. There needs to be a functioning >battery in the system to absorb the pulses from the alternator." > >I feel pretty confident that if my battery successfully starts my >engine that I am unlikely to "lose the battery" during a flight, and >I also have some doubts about the need for a battery to absorb >pulses from the alternator. Okay, this is easy . . . A battery SHOULD be the most reliable source of energy in your airplane. Simple, no moving parts, easy to quantify for performance. Any time I've had a customer cite a battery 'failure', I've had to ask, "What was the last cap check you did . . . and how long ago?" Like tires, oil and even propellers . . . the battery is a commodity. It is subject to stresses of environment and circumstance. Yet unlike tires and props that get pre-flight check and oil that gets changed out every so many hours . . . batteries tend to be treated in airplanes like they do in our cars. Run 'em until they don't crank the engine any more. A battery that fails to get your engine started has been essentially USELESS as back-up energy source for a long time. Z-13/8 was crafted with the notion that the SD-8 alternator was NOT installed to back up DUAL failures of main alternator AND a battery . . . but simply to run 8A or LESS of endurance loads after a single failure of the main alternator. The idea was to hold all the battery's contained energies in RESERVE for descent and approach to landing. If one is crafting a plan-B, plan-C or any other plan assuming that alternators are there to back up a failed battery simply does not appreciate the need for KNOWING that your prop leading edges, alternator drive belt, tires, oil levels AND BATTERY are ready to deliver to mission requirements. A battery that fails cap check for minimum battery only endurance probably cranks the engine just fine. Getting the engine started is NOT a substitute for battery cap check. Z-13/8, when operated within its design goals, gives you as much mission reliability as any other architecture. The biggest advantage of Z-13/8 is savings in WEIGHT. A 3 pound alternator gives you unlimited endurance at e-bus loads of 10A or less thus holding the battery completely in reserve . . . which should allow you to arrive at the airport of intended destination with lights a-blazing and all the screens lit up in vivid colors. It's all about energy management and preventative maintenance. Bob . . . ________________________________________________________________________________
Date: Jun 21, 2016
At 06:44 PM 6/20/2016, you wrote: > >Surprised indeed. >I've never seen an alternator that normally put out "half wave >rectified power" and I have seen automotive EFI systems run fine >with a disconnected battery. The SD-8 is a single phase output with considerable 'trash' on the output . . . >There have been cases of some alternators going offline when >overloaded to the point where the voltage drops way off but that >isn't going to happen with a PM alternator. I'd want to suss out >that scenario though with the alternator of choice if there are any >heavy loads in the aircraft. I just used two tiny Dekka batteries >that together weigh the same as the popular odysey battery and >called it done. One has been in use for 10 years and the other 9 >years now which for me makes the economics darn good compared to >maintaining a single larger battery. What did your batteries do at the last cap check? Bob . . . ________________________________________________________________________________
Date: Jun 21, 2016
At 06:52 PM 6/20/2016, you wrote: > >Can not argue with the order of complexity. As for which >architecture is best, it is a matter of personal preference. How is parts count x weight x cost of ownership to achieve the highest practical system reliability a matter of 'personal preferences'? > A battery failing in flight is unlikely. Even if it did, how > would you know it? What are the symptoms? If the pilot correctly > identifies a battery failure, what is the correct action to take > and why? I question the statement, "all you have left is half wave > rectified AC power off the alternator". Most alternators put out > rectified 3-phase full-wave current, not half wave DC. I agree > with your statement, "I also have some doubts about the need for a > battery to absorb pulses from the alternator." Our electrical guru > has stated that avionics should be designed to handle anything an > aircraft electrical system can throw at it. > The ideal electrical system will keep critical equipment > functioning even if a failure occurs and without requiring any > action by the pilot, except to make a note to do repairs after landing. Exactly. Check out the DAS plots for SD-8 output under various combinations of load, battery and presence of a 'filter' capacitor at: http://www.aeroelectric.com/Pictures/Curves/Alternator_Performance/SD-8_Noise-Plots/SD-8_Noise_Data.pdf In particular, page 8 where an SD-8 is operated with a 47Kuf capacitor, NO battery, and 8.8A load while supporting a 14.5v bus. Note that ripple was 129 mv pk-pk and 38mv RMS. My question of any detractors of SD-8 operations would be, what is it about the quality of this output that is deleterious to your product? Bob . . . ________________________________________________________________________________
Date: Jun 21, 2016
At 09:25 PM 6/20/2016, you wrote: >Robert may take yours and modify it for you. He is an awesome guy >and I'm beyond satisfied with the EFII products and his customer service! I would be interested to know how system reliability is improved by any process that goes beyond running all engine dependent components directly from a battery bus . . . as a general rule, system reliability DOES NOT improve with increased in parts count or operational complexity. All too often, system integrators get wrapped around the "keep it powered up at all costs" axle while loosing sight of vulnerabilities of the electrically dependent device or system. The LA-IFP accident http://www.aeroelectric.com/Reference_Docs/Accidents/N811HB_Feb2008_LA-IVp/ is one such example. The guy was so worried about keeping BOTH ignition systems powered up that he lost sight of both single points of failure and loss of integrity due to poor architecture. Bob . . . ________________________________________________________________________________
Date: Jun 21, 2016
Subject: Re: Wrong email address - friggin autoreply
Date: Jun 21, 2016
This guy seems to have set up an auto-reply. The options to make this stop are to have the moderator manually remove him from the list, or to send a 500-page fax to the number listed below, requesting him to remove his auto-reply. On 6/21/2016 9:30 AM, Franz Fux wrote: > > I will no longer be checking franz(at)lastfrontierheli.com due to excessive > and uncontrollable spam. > > Please re-send your email to my new address: > > franz.fux(at)lastfrontierheli.com and make a note of it for the future. > > Apologies for the inconvenience, > > Franz Fux > Last Frontier Heliskiing - Go Beyond > www.lastfrontierheli.com > --- > > Head Office: PO Box 1237, Vernon, BC V1T 6N6, CANADA > > Tel: 250 558 7980 > Fax: 250 558 7981 > Reservations: 1-888-655-5566 > ________________________________________________________________________________
Date: Jun 21, 2016
At 02:53 AM 6/21/2016, you wrote: > >This guy seems to have set up an auto-reply. The options to make >this stop are to have the moderator manually remove him from the >list, or to send a 500-page fax to the number listed below, >requesting him to remove his auto-reply. I've asked Matt to remove his old address from the list server's recognized addresses Bob . . . ________________________________________________________________________________
Subject: do I need to change my capacitor
Date: Jun 21, 2016
When I built my plane I got a copy of Bob N Electrical manual and started following his advice on the way I should build my system. One of the first things I did was install the capacitor on the Jabiru electrical charging system. That was four years ago and hundred hours. I have had a couple of things happen to charging system. Burnt Molex plug, replace with block and terminals. This last incident was the voltage regulator went out, but it took couple of systems with it. I was flying with the Trio/MGL auto-pilot on and the circuit breaker popped. I waited a minute then pushed it back in and it popped again. I left it out for the rest of the flight. I observed that my voltage had dropped to 12.8, but it did not enter into my mind that I had loss voltage. Over the next couple of flights I started having starting problems after a flight. I finally figured out that my voltage regulator was bad. I replace it. Then started finding burnt resistors on the auto-pilot wiring, a burnt diode on the battery charging wire. It was still working correctly. Then Matt, at MGL found my mother board damaged. Today I read on the Europa List that I should check or replace my capacitor. Apparently there is only one check I can do. I'm wondering if I should just replace it for peace of mind as I'm planning on heading to KOSH in July. Rick Stockton N120EJ 3300L Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457354#457354 ________________________________________________________________________________
Date: Jun 21, 2016
Subject: Re: do I need to change my capacitor
Subject: AeroElectric-List: do I need to change my capacitor From: "AirEupora" <AirEupora(at)sbcglobal.net> When I built my plane I got a copy of Bob N Electrical manual and started following his advice on the way I should build my system. One of the first things I did was install the capacitor on the Jabiru electrical charging system. That was four years ago and hundred hours. I have had a couple of things happen to charging system. Burnt Molex plug, replace with block and terminals. These connectors would not have been my first choice for power wiring . . . I remember seeing the open-barrel, b-crimp pins from AMP, Inc back about 1968 when they were being incorporated into Cessna's production harnesses. They looked pretty cheesy to me . . . but they have stood the test of time. Having said that, they ARE very process and environment sensitive. They must be properly crimped and they have to be kept dry. It would have been interesting to inspect the carcass to see if we could deduce root cause. In any case, the 'upgrade' to terminal block was a safe bet. This last incident was the voltage regulator went out, but it took couple of systems with it. I was flying with the Trio/MGL auto-pilot on and the circuit breaker popped. I waited a minute then pushed it back in and it popped again. I left it out for the rest of the flight. I observed that my voltage had dropped to 12.8, but it did not enter into my mind that I had loss voltage. If you had a low volts warning system, it would have been flashing for anything below 13.5 volts. The battery cannot be charged with voltages that low. 14.2 to 14.6 is the target. Over the next couple of flights I started having starting problems after a flight. I finally figured out that my voltage regulator was bad. I replace it. Then started finding burnt resistors on the auto-pilot wiring, a burnt diode on the battery charging wire. It was still working correctly. Then Matt, at MGL found my mother board damaged. Where is this diode in the system? Did you pattern your system to a Z-figure? Today I read on the Europa List that I should check or replace my capacitor. Apparently there is only one check I can do. I'm wondering if I should just replace it for peace of mind as I'm planning on heading to KOSH in July. The capacitor is not a critical operational device. Unless you've suffered an extended over-voltage condition, the capacitor is probably fine. Do you have ov protection? What are your bus voltage readings with the new regulator? Can you share a copy of your architecture drawings with us? Did your autopilot repair guy offer a probable cause for what was discovered in the damage patterns? It's not clear to me that 'smoked' components are necessarily linked to regulator failure unless there was a sustained over-voltage condition prior to the failure that caused it to go belly-up. The constellation of failures you've cited may well be separate incidents with their own root causes. Bob . . . ________________________________________________________________________________
Date: Jun 21, 2016
Subject: battery question
I am installing a Rotax 914 which requires an electric fuel pump to run. My electrical system architecture will have the primary pump running directly off the integrated generator. The primary pump will be the ONLY load on the generator. The backup pump will run off the battery bus, connected to the external alternator. My question is, does it make any sense to include a battery in the generator/primary pump system? ________________________________________________________________________________
Date: Jun 21, 2016
Subject: Re: battery question
At 12:09 PM 6/21/2016, you wrote: >I am installing a Rotax 914 which requires an electric fuel pump to >run. My electrical system architecture will have the primary pump >running directly off the integrated generator. The primary pump will >be the ONLY load on the generator. The backup pump will run off the >battery bus, connected to the external alternator. My question is, >does it make any sense to include a battery in the generator/primary >pump system? What does your system architecture look like? Are you duplicating a system already flying or is this something original? Bob . . . ________________________________________________________________________________
Date: Jun 21, 2016
It was suggested to me by the Rotax dealer in Canada. Like I said, the integrated generator only runs the main fuel pump. There is a 22K capacitor specified. The external alternator powers the main bus and charges the battery. There has been some recent discussion suggesting a need for a battery in the system, but I was not planning one on the generator-fuel pump circuit. On Tue, Jun 21, 2016 at 10:44 AM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 12:09 PM 6/21/2016, you wrote: > > I am installing a Rotax 914 which requires an electric fuel pump to run. > My electrical system architecture will have the primary pump running > directly off the integrated generator. The primary pump will be the ONLY > load on the generator. The backup pump will run off the battery bus, > connected to the external alternator. My question is, does it make any > sense to include a battery in the generator/primary pump system? > > > What does your system architecture look like? > Are you duplicating a system already flying > or is this something original? > > > Bob . . . > ________________________________________________________________________________
Date: Jun 21, 2016
At 02:03 PM 6/21/2016, you wrote: >It was suggested to me by the Rotax dealer in Canada. Like I said, >the integrated generator only runs the main fuel pump. There is a >22K capacitor specified. The external alternator powers the main bus >and charges the battery. There has been some recent discussion >suggesting a need for a battery in the system, but I was not >planning one on the generator-fuel pump circuit. Giving well considered advice based on the information you've supplied is difficult if not fraught with risk. We're viewing your system through a 'knothole'. With that much generation ability, consider Figures Z-13/8 in the 'Connection. http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z13-8T.pdf Use your external alternator as the MAIN and the built in alternator as the STANDBY. Wire the main pump to the battery bus, the standby pump to the main bus. This architecture has been vetted by hundreds of builders over the past 20+ years and offers very high system reliability with no weight penalties over what the Rotax folks might offer. Rotax builds pretty good engines but their expertise in aircraft electrical systems is not well demonstrated. Bob . . . ________________________________________________________________________________
Date: Jun 21, 2016
Thanks Bob. I'll look at it. On Tue, Jun 21, 2016 at 12:36 PM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 02:03 PM 6/21/2016, you wrote: > > It was suggested to me by the Rotax dealer in Canada. Like I said, the > integrated generator only runs the main fuel pump. There is a 22K capacitor > specified. The external alternator powers the main bus and charges the > battery. There has been some recent discussion suggesting a need for a > battery in the system, but I was not planning one on the generator-fuel > pump circuit. > > > Giving well considered advice based on the information > you've supplied is difficult if not fraught with > risk. We're viewing your system through a 'knothole'. > > With that much generation ability, consider Figures Z-13/8 > in the 'Connection. > > http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z13-8T.pdf > > Use your external alternator as the MAIN and > the built in alternator as the STANDBY. Wire > the main pump to the battery bus, the standby > pump to the main bus. > > This architecture has been vetted by hundreds of > builders over the past 20+ years and offers > very high system reliability with no weight > penalties over what the Rotax folks might offer. > > Rotax builds pretty good engines but their > expertise in aircraft electrical systems is > not well demonstrated. > > > Bob . . . > ________________________________________________________________________________
Date: Jun 21, 2016
Am I correct in thinking that if I wanted to do away with the endurance bus I could eliminate the relay (1N4001) and the switch that energizes it? On Tue, Jun 21, 2016 at 12:48 PM, Ken Ryan wrote: > Thanks Bob. I'll look at it. > > On Tue, Jun 21, 2016 at 12:36 PM, Robert L. Nuckolls, III < > nuckolls.bob(at)aeroelectric.com> wrote: > >> At 02:03 PM 6/21/2016, you wrote: >> >> It was suggested to me by the Rotax dealer in Canada. Like I said, the >> integrated generator only runs the main fuel pump. There is a 22K capacitor >> specified. The external alternator powers the main bus and charges the >> battery. There has been some recent discussion suggesting a need for a >> battery in the system, but I was not planning one on the generator-fuel >> pump circuit. >> >> >> Giving well considered advice based on the information >> you've supplied is difficult if not fraught with >> risk. We're viewing your system through a 'knothole'. >> >> With that much generation ability, consider Figures Z-13/8 >> in the 'Connection. >> >> http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z13-8T.pdf >> >> Use your external alternator as the MAIN and >> the built in alternator as the STANDBY. Wire >> the main pump to the battery bus, the standby >> pump to the main bus. >> >> This architecture has been vetted by hundreds of >> builders over the past 20+ years and offers >> very high system reliability with no weight >> penalties over what the Rotax folks might offer. >> >> Rotax builds pretty good engines but their >> expertise in aircraft electrical systems is >> not well demonstrated. >> >> >> Bob . . . >> > > ________________________________________________________________________________
Date: Jun 21, 2016
At 04:08 PM 6/21/2016, you wrote: >Am I correct in thinking that if I wanted to do away with the >endurance bus I could eliminate the relay (1N4001) and the switch >that energizes it? The endurance bus would be loaded with only those goodies you would operate from the stand-by alternator . . . generally limited to 15-18 amps which is the internal alternator's rated output. Everything else goes on the Main bus. During loss of main alternator, you continue flight to airport of intended destination with the battery contactor OFF, E-bus alternate feed switch ON, S/B alternator switch ON. When airport is in sight, you now have all the battery's reserves available to close the battery contactor and operate all the goodies for descent and approach to landing. The e-bus is an integral component of the energy management philosophy on which Z-13/8 is based. The big advantage for you is that unlike an SD-8 s/b alternator mounted to the back of a Lycoming, YOUR s/b alternator is about twice that size. You have much larger e-bus options for the endurance mode of flight. Bob . . . ________________________________________________________________________________
Date: Jun 21, 2016
I already have the ability to turn each component on or off with its own switch. Separate ebus with its wiring and relay etc. seem superfluous. Sent from my Android. Sorry Steve. On Jun 21, 2016 13:27, "Robert L. Nuckolls, III" < nuckolls.bob(at)aeroelectric.com> wrote: > At 04:08 PM 6/21/2016, you wrote: > > Am I correct in thinking that if I wanted to do away with the endurance > bus I could eliminate the relay (1N4001) and the switch that energizes it? > > > The endurance bus would be loaded with > only those goodies you would operate from > the stand-by alternator . . . generally > limited to 15-18 amps which is the > internal alternator's rated output. > > Everything else goes on the Main bus. > During loss of main alternator, you continue > flight to airport of intended destination > with the battery contactor OFF, E-bus > alternate feed switch ON, S/B alternator > switch ON. > > When airport is in sight, you now have all > the battery's reserves available to close > the battery contactor and operate all the > goodies for descent and approach to landing. > > The e-bus is an integral component of the > energy management philosophy on which Z-13/8 > is based. The big advantage for you is that > unlike an SD-8 s/b alternator mounted to the > back of a Lycoming, YOUR s/b alternator is about > twice that size. You have much larger e-bus > options for the endurance mode of flight. > > > Bob . . . > ________________________________________________________________________________
Date: Jun 21, 2016
What advantage does an additional battery offer? email me at fransew at gmail -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457369#457369 ________________________________________________________________________________
Date: Jun 21, 2016
I'm not saying that a battery offers any advantages. I'm asking whether or not it is necessary to have a battery in the system. Another poster on this forum breached the idea (just a few days ago) that a battery might be necessary to "smooth" the output. I "think" that idea was debunked, but I'm never quite sure how to interpret some of the responses. In any event, that discussion was about a "failed" battery. I have not seen the idea of battery elimination discussed. I've been reviewing Z-13/8 and it seems to have some advantages but also seems to add unnecessary complications. On Tue, Jun 21, 2016 at 3:59 PM, user9253 wrote: > > What advantage does an additional battery offer? > email me at fransew at gmail > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=457369#457369 > > ________________________________________________________________________________
Date: Jun 21, 2016
At 04:34 PM 6/21/2016, you wrote: >I already have the ability to turn each >component on or off with its own >switch.=C2 Separate ebus with its wiring and relay etc. seem superfluous. The e-bus is NOT an avionics bus . . . it's a plan-b configuration tool for gathering a REDUCED electrical load onto an ENDURANCE bus. It's a way to do all of your plan-b authorship on the ground. When the LV warning light comes on, flip 3 switches and trundle on to airport of intended destination. It's also a dual-source bus that functions in the rare event of loss of battery contactor. It is powered up from the main bus through the normal feed diode . . . main bus up . . . e-bus is up. Have you done a load analysis to know what energy is needed to get into an optimized endurance mode? Bob . . . ________________________________________________________________________________
Date: Jun 21, 2016
I don't think it's a big deal to flip a couple of switches if the LV light comes on. I have done a load analysis, but I don't completely understand what you mean by "optimized endurance mode." The only thing necessary to keep the airplane in the air is one fuel pump, approximately 5 amps. This is a VFR only airplane, so nothing else is really necessary to get home safely. The EFIS is Dynon with their proprietary backup battery. If everything is turned on and working, the draw is about 25 amps (peak). With the system I already planned, the primary fuel pump is driven by the generator in an autonomous system. There isn't even a fuel pump switch in this system. The system consists of generator, regulator, capacitor, fuel pump, inline fuse, momentary contact switch to energize the generator, and the wiring to connect things together. The auxiliary fuel pump is switched off a battery bus (not really a bus, just a wire from the hot side of the battery relay) with an inline fuse. Everything else runs off the main bus, which is connected to the external alternator and battery. If the generator (or regulator) fails, the main fuel pump stops but there is still the battery and the alternator to power the auxiliary fuel pump and keep the engine running. If the alternator fails, the engine keeps running because the main fuel pump is not affected. The main bus becomes powered by the battery. Depending upon the situation load shedding might be desirable to preserve enough battery power to run the aux fuel pump for landing (normal takeoff and landings use both pumps). It seems the worst case scenario is the generator failure, as that takes out the main fuel pump and should the auxiliary pump fail, the airplane comes down. I don't really know what happens if the EarthX ETX36C lithium battery fails. Hopefully the airplane does not burn up in flight. On Tue, Jun 21, 2016 at 4:32 PM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 04:34 PM 6/21/2016, you wrote: > > I already have the ability to turn each component on or off with its own > switch.=C3=82 Separate ebus with its wiring and relay etc. seem superflu ous. > > > The e-bus is NOT an avionics bus . . . it's > a plan-b configuration tool for gathering > a REDUCED electrical load onto an ENDURANCE > bus. It's a way to do all of your plan-b > authorship on the ground. When the LV warning > light comes on, flip 3 switches and trundle > on to airport of intended destination. > > It's also a dual-source bus that functions > in the rare event of loss of battery contactor. > > It is powered up from the main bus through > the normal feed diode . . . main bus up . . . > e-bus is up. > > Have you done a load analysis to know > what energy is needed to get into an > optimized endurance mode? > > Bob . . . > ________________________________________________________________________________
Date: Jun 21, 2016
Maybe a little off topic, but if anyone is worried about the single battery i dea, I installed the EarthX set of jumper wires connecting directly to the b attery (pos and neg). They come to the instrument panel and terminate in a s ocket. It's the install kit that EarthX sells with their Lithium jump pack. W hole kit is less than 1lb. It will work to jumpstart the plane (ask how I kn ow) and it will extend battery life if you loose all alternators on your sys tem. The jump pack can't be recharged by plugging it in during flight. Only by pl ugging it in to the charger that comes with it. It also charges any usb devi ce. Justin > On Jun 21, 2016, at 18:32, Robert L. Nuckolls, III <nuckolls.bob@aeroelect ric.com> wrote: > > At 04:34 PM 6/21/2016, you wrote: > >> I already have the ability to turn each component on or off with its own s witch.=C3=82 Separate ebus with its wiring and relay etc. seem superfluous. > > The e-bus is NOT an avionics bus . . . it's > a plan-b configuration tool for gathering > a REDUCED electrical load onto an ENDURANCE > bus. It's a way to do all of your plan-b > authorship on the ground. When the LV warning > light comes on, flip 3 switches and trundle > on to airport of intended destination. > > It's also a dual-source bus that functions > in the rare event of loss of battery contactor. > > It is powered up from the main bus through > the normal feed diode . . . main bus up . . . > e-bus is up. > > Have you done a load analysis to know > what energy is needed to get into an > optimized endurance mode? > > Bob . . . ________________________________________________________________________________
Date: Jun 22, 2016
kenryan, Your electrical system sounds perfect to me. Why change a proven design by adding more weight, cost, time, and complexity? A backup to a backup is not needed unless someone can offer data showing that the primary fuel pump will perform better or last longer with a battery added to the system. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457376#457376 ________________________________________________________________________________
Date: Jun 22, 2016
Thanks Joe, that's what I'm thinking too. On Wed, Jun 22, 2016 at 3:23 AM, user9253 wrote: > > kenryan, Your electrical system sounds perfect to me. Why change a proven > design by adding more weight, cost, time, and complexity? A backup to a > backup is not needed unless someone can offer data showing that the primary > fuel pump will perform better or last longer with a battery added to the > system. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=457376#457376 > > ________________________________________________________________________________
Subject: Re: OT: PCB coating removal
Date: Jun 24, 2016
I don't recall a crystal in my old 1013A, but be that as it may, it seems odd that someone would use an xtal to generate audio tones unless they needed extraordinary frequency precision (an a lot of divider steps). You might try a bit of MEK on a corner of the board. it should not hurt the components, but might remove the PCB and component printing. The old potting compounds were pretty resistant to attack. -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457398#457398 ________________________________________________________________________________
Date: Jun 24, 2016
Thanks Ira, I'll give mek a try. The board is from an old telephone lineman's test hand set so it's generating 12 tones for dialing. Raymond Julian Kettle River, MN The things we admire in men, kindness and generosity, openness, honesty, understanding and feeling are the concomitants of failure in our system. And those traits we detest, sharpness, greed, acquisitiveness, meanness, egotism and self-interest are the traits of success. And while men admire the quality of the first they love the produce of the second. -John Steinbeck, novelist, Nobel laureate (1902-1968) On 06/24/2016 07:08 AM, rampil wrote: > > I don't recall a crystal in my old 1013A, but be that as it may, it seems odd > that someone would use an xtal to generate audio tones unless they needed > extraordinary frequency precision (an a lot of divider steps). > > You might try a bit of MEK on a corner of the board. it should not hurt the components, but might remove the PCB and component printing. The old > potting compounds were pretty resistant to attack. > > -------- > Ira N224XS > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=457398#457398 > > ________________________________________________________________________________
Date: Jun 24, 2016
At 10:27 AM 6/24/2016, you wrote: > >Thanks Ira, > >I'll give mek a try. The board is from an old telephone lineman's >test hand set so it's generating 12 tones for dialing. Brings back memories . . . the DTMF tone encoders of bygone times were indeed crystal controlled. Here is an exemplar component. http://tinyurl.com/hzxdjgw Very popular devices in the ham radio repeater communities 40 or so years ago. Bob . . . ________________________________________________________________________________
Date: Jun 25, 2016
Ah yes, the sweet simple days of in-band signaling and Cap'n Crunch ;) -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457421#457421 ________________________________________________________________________________
Subject: Master contactor temp?
Date: Jun 25, 2016
I was having the altimeter/transponder check done recently when I noticed the master contactor was hot. Too hot to touch for very long. Now I've never touched a master contactor before so I don't know what "normal" is (OAT was in the mid 90's). When I got back to the hangar, I turned on the master and checked it with my point-and-shoot thermometer. I was seeing around 120 after about 5 minutes. I think it was a bit hotter while at the shop but I'm positive. Once back at home, I pulled up the data sheet for the White-Rodgers 90-907 solenoid and the only reference I can find for temperature is "Temperature Range -40F to 122F" I don't know if that range is ambient or device. If it's device, then I'm right at the upper limit. Do I need to be worried? Time for a new master contactor? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457424#457424 ________________________________________________________________________________
Date: Jun 25, 2016
Subject: Re: Master contactor temp?
At 07:17 AM 6/25/2016, you wrote: <don@velocity-xl.com> > >I was having the altimeter/transponder check >done recently when I noticed the master >contactor was hot. Too hot to touch for very >long. Now I've never touched a master contactor >before so I don't know what "normal" is (OAT was in the mid 90's). > >When I got back to the hangar, I turned on the >master and checked it with my point-and-shoot >thermometer. I was seeing around 120 after >about 5 minutes. I think it was a bit hotter >while at the shop but I'm positive. > >Once back at home, I pulled up the data sheet >for the White-Rodgers 90-907 solenoid and the >only reference I can find for temperature is >"Temperature Range =93=93 -40=C2=B0F to 122=C2=B0F" > >I don't know if that range is ambient or device. >If it's device, then I'm right at the upper limit. > >Do I need to be worried? Time for a new master contactor? No . . . all is right with the universe . . . See: http://www.aeroelectric.com/Pictures/Contactors/Battery_Contactor_Temps_1.jp g http://www.aeroelectric.com/Pictures/Contactors/Battery_Contactor_Temps_2.jp g "too hot to touch" does not automatically translate into un-desired performance. These contactors dissipate about 8w at stable temps . . . which generates and expected temperature rise of about 100F. Bob . . . ________________________________________________________________________________
From: "Bob McCallum" <robert.mccallum2(at)sympatico.ca>
Date: Jun 25, 2016
Contactors draw about 1 amp, so at 14 volts that's 14 watts of heat which needs to be dissipated. If you think about a 15 watt conventional light bulb being continuously illuminated then trying to hold onto that (which you're unlikely to be able to) you'll understand how hot the contactor can become. In short what you have sounds "normal". You're only 30 or so above ambient which isn't particularly "hot". The quoted figures of -40 to 122 F would be referring to "ambient". Bob McC > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list- > server(at)matronics.com] On Behalf Of donjohnston > Sent: Saturday, June 25, 2016 8:18 AM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Master contactor temp? > > > I was having the altimeter/transponder check done recently when I noticed the master > contactor was hot. Too hot to touch for very long. Now I've never touched a master > contactor before so I don't know what "normal" is (OAT was in the mid 90's). > > When I got back to the hangar, I turned on the master and checked it with my point- > and-shoot thermometer. I was seeing around 120 after about 5 minutes. I think it was a > bit hotter while at the shop but I'm positive. > > Once back at home, I pulled up the data sheet for the White-Rodgers 90-907 solenoid > and the only reference I can find for temperature is "Temperature Range -40F > to 122F" > > I don't know if that range is ambient or device. If it's device, then I'm right at the upper > limit. > > Do I need to be worried? Time for a new master contactor? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=457424#457424 > > > > > > > > _- > ===================================================== > ===== > _- > ===================================================== > ===== > _- > ===================================================== > ===== > _- > ===================================================== > ===== > _- > ===================================================== > ===== > ________________________________________________________________________________
Date: Jun 25, 2016
At 300A continuous and 500A inrush for 1 second, this solid state battery master relay has done me quite well for over 100 hours. No moving parts means no arcing and no wearing out of contacts. It allows current to flow both ways and works flawlessly as wired into Bob's 13/8 diagram. The original application was for the medical package on an ambulance. https://www.waytekwire.com/item/44407/Data-Panel-33034-Solid-State-Battery-Disconnect/ Justin. > On Jun 25, 2016, at 07:17, donjohnston <don@velocity-xl.com> wrote: > > > I was having the altimeter/transponder check done recently when I noticed the master contactor was hot. Too hot to touch for very long. Now I've never touched a master contactor before so I don't know what "normal" is (OAT was in the mid 90's). > > When I got back to the hangar, I turned on the master and checked it with my point-and-shoot thermometer. I was seeing around 120 after about 5 minutes. I think it was a bit hotter while at the shop but I'm positive. > > Once back at home, I pulled up the data sheet for the White-Rodgers 90-907 solenoid and the only reference I can find for temperature is "Temperature Range -40F to 122F" > > I don't know if that range is ambient or device. If it's device, then I'm right at the upper limit. > > Do I need to be worried? Time for a new master contactor? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=457424#457424 > > > > > > > > > > ________________________________________________________________________________
Date: Jun 25, 2016
The MGL provides for the low voltage readings, but I did not catch it. I was flying around with the battery voltage being shown. With the new voltage regulator I'm showing 13.8v to 14.4v volts during flight. If I turn on landing lights it will drop to about 13.4v. Yes, I pattern the diode to the Jabiru figure, but did not install the over protection. I'm now planning on doing that when I return from KOSH. Trio Avionics only told me that the mother boards were burnt. The same for MGL. I'll see if I can find a architecture drawings. Most of mine are hand drawn as I could never find a computer drawing program that I could use effectively. Thanks for the help. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457428#457428 ________________________________________________________________________________
Date: Jun 25, 2016
Might be great for contactor temps, but I'm pretty sure that the purchase would burn a hole in my backside.... On 6/25/2016 8:45 AM, Justin Jones wrote: > > At 300A continuous and 500A inrush for 1 second, this solid state battery master relay has done me quite well for over 100 hours. No moving parts means no arcing and no wearing out of contacts. It allows current to flow both ways and works flawlessly as wired into Bob's 13/8 diagram. > > The original application was for the medical package on an ambulance. > > https://www.waytekwire.com/item/44407/Data-Panel-33034-Solid-State-Battery-Disconnect/ > > Justin. > >> On Jun 25, 2016, at 07:17, donjohnston <don@velocity-xl.com> wrote: >> >> >> I was having the altimeter/transponder check done recently when I noticed the master contactor was hot. Too hot to touch for very long. Now I've never touched a master contactor before so I don't know what "normal" is (OAT was in the mid 90's). >> >> When I got back to the hangar, I turned on the master and checked it with my point-and-shoot thermometer. I was seeing around 120 after about 5 minutes. I think it was a bit hotter while at the shop but I'm positive. >> >> Once back at home, I pulled up the data sheet for the White-Rodgers 90-907 solenoid and the only reference I can find for temperature is "Temperature Range -40F to 122F" >> >> I don't know if that range is ambient or device. If it's device, then I'm right at the upper limit. >> >> Do I need to be worried? Time for a new master contactor? >> ________________________________________________________________________________
Date: Jun 25, 2016
From: Henador Titzoff <henador_titzoff(at)yahoo.com>
I wonder if this device can be used as a starter solenoid?=C2- The 300A c ontinuous looks pretty good, and it has fins to dissipate heat.=C2- Max c urrent would only flow for 2-10 seconds at a time, which means it will take a heat breather before the next attempt.=C2- Our starters never use more than 300A that I know of. The data sheet says it has internal diode protection for inductive loads, b ut there is a 150 msec turn off time.=C2- How different is this turn off time from our accepted mechanical solenoids? That burning a hole in the back pocket stuff may be cheap compared to a fai lure of a mechanical device far away from home. =C2-Henador Titzoff From: Justin Jones <jmjones2000(at)mindspring.com> To: aeroelectric-list(at)matronics.com Sent: Saturday, June 25, 2016 9:45 AM Subject: Re: AeroElectric-List: Master contactor temp? ng.com> At 300A continuous and 500A inrush for 1 second, this solid state battery m aster relay has done me quite well for over 100 hours. No moving parts mean s no arcing and no wearing out of contacts. It allows current to flow both ways and works flawlessly as wired into Bob's 13/8 diagram. The original application was for the medical package on an ambulance. https://www.waytekwire.com/item/44407/Data-Panel-33034-Solid-State-Battery- Disconnect/ Justin. > On Jun 25, 2016, at 07:17, donjohnston <don@velocity-xl.com> wrote: > om> > > I was having the altimeter/transponder check done recently when I noticed the master contactor was hot.=C2- Too hot to touch for very long.=C2- Now I've never touched a master contactor before so I don't know what "norm al" is (OAT was in the mid 90's). > > When I got back to the hangar, I turned on the master and checked it with my point-and-shoot thermometer.=C2- I was seeing around 120 after about 5 minutes. I think it was a bit hotter while at the shop but I'm positive. > > Once back at home, I pulled up the data sheet for the White-Rodgers 90-90 7 solenoid and the only reference I can find for temperature is "Temperatur e Range =93=93 -40=C2=B0F to 122=C2=B0F" > > I don't know if that range is ambient or device. If it's device, then I'm right at the upper limit. > > Do I need to be worried?=C2- Time for a new master contactor? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=457424#457424 > > > > > > > > > > - S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Jun 25, 2016
They are $160. That's slightly more expensive than a good quality continuous duty relay like Skytec, but you only make the purchase one time. Cheap when talking about aircraft parts. > On Jun 25, 2016, at 09:32, Charlie England wrote: > > > Might be great for contactor temps, but I'm pretty sure that the purchase would burn a hole in my backside.... > >> On 6/25/2016 8:45 AM, Justin Jones wrote: >> >> At 300A continuous and 500A inrush for 1 second, this solid state battery master relay has done me quite well for over 100 hours. No moving parts means no arcing and no wearing out of contacts. It allows current to flow both ways and works flawlessly as wired into Bob's 13/8 diagram. >> >> The original application was for the medical package on an ambulance. >> >> https://www.waytekwire.com/item/44407/Data-Panel-33034-Solid-State-Battery-Disconnect/ >> >> Justin. >> >>> On Jun 25, 2016, at 07:17, donjohnston <don@velocity-xl.com> wrote: >>> >>> >>> I was having the altimeter/transponder check done recently when I noticed the master contactor was hot. Too hot to touch for very long. Now I've never touched a master contactor before so I don't know what "normal" is (OAT was in the mid 90's). >>> >>> When I got back to the hangar, I turned on the master and checked it with my point-and-shoot thermometer. I was seeing around 120 after about 5 minutes. I think it was a bit hotter while at the shop but I'm positive. >>> >>> Once back at home, I pulled up the data sheet for the White-Rodgers 90-907 solenoid and the only reference I can find for temperature is "Temperature Range -40F to 122F" >>> >>> I don't know if that range is ambient or device. If it's device, then I'm right at the upper limit. >>> >>> Do I need to be worried? Time for a new master contactor? > > > > > ________________________________________________________________________________
Date: Jun 25, 2016
Nice. And 125mAmp continuous for the control circuit is about 12% of the standard contactor isn't it? On 6/25/2016 9:45 AM, Justin Jones wrote: > > At 300A continuous and 500A inrush for 1 second, this solid state battery master relay has done me quite well for over 100 hours. No moving parts means no arcing and no wearing out of contacts. It allows current to flow both ways and works flawlessly as wired into Bob's 13/8 diagram. > > The original application was for the medical package on an ambulance. > > https://www.waytekwire.com/item/44407/Data-Panel-33034-Solid-State-Battery-Disconnect/ > > Justin. > >> On Jun 25, 2016, at 07:17, donjohnston <don@velocity-xl.com> wrote: >> >> >> I was having the altimeter/transponder check done recently when I noticed the master contactor was hot. Too hot to touch for very long. Now I've never touched a master contactor before so I don't know what "normal" is (OAT was in the mid 90's). >> >> When I got back to the hangar, I turned on the master and checked it with my point-and-shoot thermometer. I was seeing around 120 after about 5 minutes. I think it was a bit hotter while at the shop but I'm positive. >> >> Once back at home, I pulled up the data sheet for the White-Rodgers 90-907 solenoid and the only reference I can find for temperature is "Temperature Range -40F to 122F" >> >> I don't know if that range is ambient or device. If it's device, then I'm right at the upper limit. >> >> Do I need to be worried? Time for a new master contactor? >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=457424#457424 >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Jun 25, 2016
I am not sure if it would work for a starter relay or not. One behavior I no ticed is when I leave my LED instrument lights on and shut the battery off ( this solid state relay) the LEDs will dim down while shutting off (like dimm ing them with a pwm). If I shut the LEDs off with their switch, they turn of f instantly. Odd, but it doesn't seem to have any ill effects. Justin > On Jun 25, 2016, at 10:40, Henador Titzoff wro te: > > I wonder if this device can be used as a starter solenoid? The 300A conti nuous looks pretty good, and it has fins to dissipate heat. Max current wou ld only flow for 2-10 seconds at a time, which means it will take a heat bre ather before the next attempt. Our starters never use more than 300A that I know of. > > The data sheet says it has internal diode protection for inductive loads, b ut there is a 150 msec turn off time. How different is this turn off time f rom our accepted mechanical solenoids? > > That burning a hole in the back pocket stuff may be cheap compared to a fa ilure of a mechanical device far away from home. > > Henador Titzoff > > > From: Justin Jones <jmjones2000(at)mindspring.com> > To: aeroelectric-list(at)matronics.com > Sent: Saturday, June 25, 2016 9:45 AM > Subject: Re: AeroElectric-List: Master contactor temp? > ing.com> > > At 300A continuous and 500A inrush for 1 second, this solid state battery m aster relay has done me quite well for over 100 hours. No moving parts means no arcing and no wearing out of contacts. It allows current to flow both wa ys and works flawlessly as wired into Bob's 13/8 diagram. > > The original application was for the medical package on an ambulance. > > https://www.waytekwire.com/item/44407/Data-Panel-33034-Solid-State-Battery -Disconnect/ > > Justin. > > > On Jun 25, 2016, at 07:17, donjohnston <don@velocity-xl.com> wrote: > > com> > > > > I was having the altimeter/transponder check done recently when I notice d the master contactor was hot. Too hot to touch for very long. Now I've n ever touched a master contactor before so I don't know what "normal" is (OAT was in the mid 90's). > > > > When I got back to the hangar, I turned on the master and checked it wit h my point-and-shoot thermometer. I was seeing around 120 after about 5 min utes. I think it was a bit hotter while at the shop but I'm positive. > > > > Once back at home, I pulled up the data sheet for the White-Rodgers 90-9 07 solenoid and the only reference I can find for temperature is "Temperatur e Range =93=93 -40=C2=B0F to 122=C2=B0F" > > > > I don't know if that range is ambient or device. If it's device, then I' m right at the upper limit. > > > > Do I need to be worried? Time for a new master contactor? > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=457424#457424 > > > > > > > &ga href="http://www.matronics.com/Navigator?AeroElectric-List" target= "_tp://forums.matronics.com/" target="_blank">http://forums.matronics.comh ttp://wiki.matronics.comp; -Matt Dralle, Li====== === > > > > > ________________________________________________________________________________
Date: Jun 25, 2016
One of the problems with solid state devices is they will bleed current whe n "OFF."=C2- The manufacturer of this device does not state the bleed cur rent on the datasheet.=C2- They only state the max and max inrush current s as well as the max voltage drop at 150A. The bleeding of current was never a factor when incandescent lights were us ed, because they required higher magnitudes of current relative to LEDs and went totally dim at milliamps of current.=C2- LED lights, on the other h and, are relatively efficient and use tens of milliamps of current when ope rating.=C2- When "OFF," they still shine dimly at tens or hundreds of mic roamps.=C2- Perhaps you can contact the relay manufacturer and ask when w hat the current bleed spec is.=C2- Their leaving it off may be an indicat ion of a problem. This bleed is one good reason not to go with such a relay for both master a nd starter unless you maintain your battery very well.=C2- In cars, we fi re them up and charge them daily.=C2- In airplanes, it could be months be fore they get fired up and charged.=C2- Leaving a charger on an airplane battery while it's installed is pretty easy, but then there are more and mo re owners going to lithium ion batteries, which could pose more risk. NOTE: check out the split lock washer on the power connector bolts.=C2- This is not a good way to lock those nuts in vibrating equipment. Henador Titzoff From: Justin Jones <jmjones2000(at)mindspring.com> To: aeroelectric-list(at)matronics.com Sent: Saturday, June 25, 2016 12:04 PM Subject: Re: AeroElectric-List: Master contactor temp? I am not sure if it would work for a starter relay or not. One behavior I n oticed is when I leave my LED instrument lights on and shut the battery off (this solid state relay) the LEDs will dim down while shutting off (like d imming them with a pwm). If I shut the LEDs off with their switch, they tur n off instantly. Odd, but it doesn't seem to have any ill effects.=C2- Justin On Jun 25, 2016, at 10:40, Henador Titzoff wrot e: I wonder if this device can be used as a starter solenoid?=C2- The 300A c ontinuous looks pretty good, and it has fins to dissipate heat.=C2- Max c urrent would only flow for 2-10 seconds at a time, which means it will take a heat breather before the next attempt.=C2- Our starters never use more than 300A that I know of. The data sheet says it has internal diode protection for inductive loads, b ut there is a 150 msec turn off time.=C2- How different is this turn off time from our accepted mechanical solenoids? That burning a hole in the back pocket stuff may be cheap compared to a fai lure of a mechanical device far away from home. =C2-Henador Titzoff From: Justin Jones <jmjones2000(at)mindspring.com> To: aeroelectric-list(at)matronics.com Sent: Saturday, June 25, 2016 9:45 AM Subject: Re: AeroElectric-List: Master contactor temp? ng.com> At 300A continuous and 500A inrush for 1 second, this solid state battery m aster relay has done me quite well for over 100 hours. No moving parts mean s no arcing and no wearing out of contacts. It allows current to flow both ways and works flawlessly as wired into Bob's 13/8 diagram. The original application was for the medical package on an ambulance. https://www.waytekwire.com/item/44407/Data-Panel-33034-Solid-State-Battery- Disconnect/ Justin. > On Jun 25, 2016, at 07:17, donjohnston <don@velocity-xl.com> wrote: > om> > > I was having the altimeter/transponder check done recently when I noticed the master contactor was hot.=C2- Too hot to touch for very long.=C2- Now I've never touched a master contactor before so I don't know what "norm al" is (OAT was in the mid 90's). > > When I got back to the hangar, I turned on the master and checked it with my point-and-shoot thermometer.=C2- I was seeing around 120 after about 5 minutes. I think it was a bit hotter while at the shop but I'm positive. > > Once back at home, I pulled up the data sheet for the White-Rodgers 90-90 7 solenoid and the only reference I can find for temperature is "Temperatur e Range =93=93 -40=C2=B0F to 122=C2=B0F" > > I don't know if that range is ambient or device. If it's device, then I'm right at the upper limit. > > Do I need to be worried?=C2- Time for a new master contactor? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=457424#457424 > > > &ga href="http://www.matronics.com/Navigator?AeroElectric-List" target= "_tp://forums.matronics.com/" target="_blank">http://forums.matronics.com http://wiki.matronics.comp; =C2- =C2- =C2- =C2- =C2- =C2- =C2 - =C2- -Matt Dralle, Li========= ________________________________________________________________________________
Date: Jun 25, 2016
The bleed off hasn't been an issue. I have let it sit for 9 weeks before and no noted battery degradation (PC680). I also have a turn coordinator on the battery bus that spins down and behaves normally when the master is shut of f. Overall, I am extremely pleased with the performance. Justin > On Jun 25, 2016, at 11:54, Henador Titzoff wro te: > > One of the problems with solid state devices is they will bleed current wh en "OFF." The manufacturer of this device does not state the bleed current o n the datasheet. They only state the max and max inrush currents as well as the max voltage drop at 150A. > > The bleeding of current was never a factor when incandescent lights were u sed, because they required higher magnitudes of current relative to LEDs and went totally dim at milliamps of current. LED lights, on the other hand, a re relatively efficient and use tens of milliamps of current when operating. When "OFF," they still shine dimly at tens or hundreds of microamps. Perh aps you can contact the relay manufacturer and ask when what the current ble ed spec is. Their leaving it off may be an indication of a problem. > > This bleed is one good reason not to go with such a relay for both master a nd starter unless you maintain your battery very well. In cars, we fire the m up and charge them daily. In airplanes, it could be months before they ge t fired up and charged. Leaving a charger on an airplane battery while it's installed is pretty easy, but then there are more and more owners going to l ithium ion batteries, which could pose more risk. > NOTE: check out the split lock washer on the power connector bolts. This i s not a good way to lock those nuts in vibrating equipment. > > Henador Titzoff > > > From: Justin Jones <jmjones2000(at)mindspring.com> > To: aeroelectric-list(at)matronics.com > Sent: Saturday, June 25, 2016 12:04 PM > Subject: Re: AeroElectric-List: Master contactor temp? > > I am not sure if it would work for a starter relay or not. One behavior I n oticed is when I leave my LED instrument lights on and shut the battery off ( this solid state relay) the LEDs will dim down while shutting off (like dimm ing them with a pwm). If I shut the LEDs off with their switch, they turn of f instantly. Odd, but it doesn't seem to have any ill effects. > > Justin > >> On Jun 25, 2016, at 10:40, Henador Titzoff wr ote: >> >> I wonder if this device can be used as a starter solenoid? The 300A cont inuous looks pretty good, and it has fins to dissipate heat. Max current wo uld only flow for 2-10 seconds at a time, which means it will take a heat br eather before the next attempt. Our starters never use more than 300A that I know of. >> >> The data sheet says it has internal diode protection for inductive loads, but there is a 150 msec turn off time. How different is this turn off time from our accepted mechanical solenoids? >> >> That burning a hole in the back pocket stuff may be cheap compared to a f ailure of a mechanical device far away from home. >> >> Henador Titzoff >> >> >> From: Justin Jones <jmjones2000(at)mindspring.com> >> To: aeroelectric-list(at)matronics.com >> Sent: Saturday, June 25, 2016 9:45 AM >> Subject: Re: AeroElectric-List: Master contactor temp? >> ring.com> >> >> At 300A continuous and 500A inrush for 1 second, this solid state battery master relay has done me quite well for over 100 hours. No moving parts mea ns no arcing and no wearing out of contacts. It allows current to flow both w ays and works flawlessly as wired into Bob's 13/8 diagram. >> >> The original application was for the medical package on an ambulance. >> >> https://www.waytekwire.com/item/44407/Data-Panel-33034-Solid-State-Batter y-Disconnect/ >> >> Justin. >> >> > On Jun 25, 2016, at 07:17, donjohnston <don@velocity-xl.com> wrote: >> > .com> >> > >> > I was having the altimeter/transponder check done recently when I notic ed the master contactor was hot. Too hot to touch for very long. Now I've n ever touched a master contactor before so I don't know what "normal" is (OAT was in the mid 90's). >> > >> > When I got back to the hangar, I turned on the master and checked it wi th my point-and-shoot thermometer. I was seeing around 120 after about 5 mi nutes. I think it was a bit hotter while at the shop but I'm positive. >> > >> > Once back at home, I pulled up the data sheet for the White-Rodgers 90- 907 solenoid and the only reference I can find for temperature is "Temperatu re Range =93=93 -40=C2=B0F to 122=C2=B0F" >> > >> > I don't know if that range is ambient or device. If it's device, then I 'm right at the upper limit. >> > >> > Do I need to be worried? Time for a new master contactor? >> > >> > >> > >> > >> > Read this topic online here: >> > >> > http://forums.matronics.com/viewtopic.php?p=457424#457424 >> > >> > >> > >> &ga href="http://www.matronics.com/Navigator?AeroElectric-List" target= "_tp://forums.matronics.com/" target="_blank">http://forums.matronics.comh ttp://wiki.matronics.comp; -Matt Dralle, Li====== === > > ________________________________________________________________________________
Date: Jun 25, 2016
> Most of mine are hand drawn as I could never find a computer drawing program that I could use effectively. Try a free program called ExpressSCH. It is very easy to learn and use. The program is intended for designing printed circuit boards. The company makes their money by selling PCBs. The program has two parts, the schematic part and the PCB layout part. Just the schematic part needs to be used to make a schematic of your aircraft electrical system. Designs can be printed. I use a another free program called CutePDF Writer to emulate a printer. It will save an ExpressSCH design as a PDF file that can be shared and zoomed in on without blurring. http://www.cutepdf.com/Products/CutePDF/writer.asp -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457438#457438 ________________________________________________________________________________
Date: Jun 26, 2016
"Ambient" refers to the contactor temperature. But keep in mind that "ambient" doesn't refer to the temperature someplace outside, but AT and ON the contactor can. The Type 70 would not specified to use at many airports and inside the cowls of many airplane based on these numbers. 122 deg F is not very hot. It was hatter than that in Phoenix a couple days ago, and Death Valley that would be a nice day. Furthermore the type to is G-position sensitive, vibration sensitive, not liquid proof and has many undesireable characterists compared to other solutions. As for my choice? I go with the Flaming River Battery Switch, or any of the several electronic contactor offerings, unless your mission doesn't take you far from home. Factoid: No NASCAR vehicle uses a type-70 contactor. Factoid: Very old Type-70's were made from far better stuff. Please, can we do better than "hot to the touch" -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457449#457449 ________________________________________________________________________________
Date: Jun 26, 2016
"Ambient" refers to the contactor temperature This is not true! The Ambient temperature is the temperature of the air in the general vicinity of the subject device, not the temperature of the device itself. Roger ________________________________________________________________________________
Date: Jun 26, 2016
ambient ambnt/ /adjective/ 1. *1*. of or relating to the immediate surroundings of something. "the liquid is stored at below ambient temperature" Please, Eric; we can do better with our definitions. ;-) On 6/26/2016 10:03 AM, Eric M. Jones wrote: > > "Ambient" refers to the contactor temperature. But keep in mind that "ambient" doesn't refer to the temperature someplace outside, but AT and ON the contactor can. > > The Type 70 would not specified to use at many airports and inside the cowls of many airplane based on these numbers. 122 deg F is not very hot. It was hatter than that in Phoenix a couple days ago, and Death Valley that would be a nice day. > > Furthermore the type to is G-position sensitive, vibration sensitive, not liquid proof and has many undesireable characterists compared to other solutions. > > As for my choice? I go with the Flaming River Battery Switch, or any of the several electronic contactor offerings, unless your mission doesn't take you far from home. > > Factoid: No NASCAR vehicle uses a type-70 contactor. > Factoid: Very old Type-70's were made from far better stuff. > > Please, can we do better than "hot to the touch" > > -------- > Eric M. Jones > www.PerihelionDesign.com > 113 Brentwood Drive > Southbridge, MA 01550 > (508) 764-2072 > emjones(at)charter.net > ________________________________________________________________________________
Date: Jun 26, 2016
At 11:04 AM 6/25/2016, you wrote: >I am not sure if it would work for a starter relay or not. One >behavior I noticed is when I leave my LED instrument lights on and >shut the battery off (this solid state relay) the LEDs will dim down >while shutting off (like dimming them with a pwm). If I shut the >LEDs off with their switch, they turn off instantly. Odd, but it >doesn't seem to have any ill effects. The solid state 'contactor' is a array of field effect transistors controlled by a variable voltage applied to their 'gates'. When used as a 'switch', on wants them to be either 'on hard' or 'off hard' like the behavior of contacts in relays and switches . . . but depending on the circuitry that drives the gates, the transition time between ON and OFF states may not be quite as fast as for metallic contacts. With solid state contactors, there is a much longer intervale to achieve the same current flow as an open sent of contacts and it's most observable when controlling devices that with activity at every low currents . . . like an LED. In a dark room, an LED can produce visible light with tens of micro-amps of current flow. Hence, what you've observed is an ordinary circumstance that does not speak ill of the contactor's performance. Airplanes with higher levels of constant-on loads will drag the bus down faster during contactor shut-down make the behavior more like metallic contactors but there's seldom a reason to make this a design goal. Bob . . . ________________________________________________________________________________
Date: Jun 26, 2016
At 10:56 AM 6/25/2016, you wrote: > > >They are $160. That's slightly more expensive than a good quality >continuous duty relay like Skytec, but you only make the purchase >one time. Cheap when talking about aircraft parts. What place do the legacy metallic contactors hold in the hierarchy of cost-of-ownership issues. Where to they stand on the list of risk drivers? At every airplane factory I've worked at, there were periodic meetings to identify, discuss and mount mitigation programs for hardware problems in the field. The vast majority posed little if any increase in risk . . . only cost of ownership and loss of company image with the customer. I have never seen a metallic contactor on the top-ten list . . . one of them made it to the 'gee, should we do something about this?' list. http://www.aeroelectric.com/Pictures/Failures/6041_Contactor_Failure.jpg The answer was, "No, while perhaps spectacular there was nothing beyond a cost-of-ownership issue for less than a dozen aircraft in a fleet of hundreds over ten years. None of the failures were even in-warranty. So what's the return on investment? How often do you anticipate needing to replace el-cheapo whisky- barrel/automotive contactors? The legacy contactors of choice have a rich field history . . . yes . . . they DO wear out or get damaged . . . but they're easy to replace at little cost of ownership. Further, if you've crafted a failure tolerant system, failure of the $low$ contactor poses no increase in risk. Further, besides the extra acquisition costs, what's the weight, real-estate and volume penalties for going all solid state? Sometimes, the most practical way to drive a nail is with a hammer. Bob . . . ________________________________________________________________________________
Date: Jun 26, 2016
Good to know Bob. Thank you for sharing your knowledge. I am really happy wi th the choice to go with contactor Justin. > On Jun 26, 2016, at 11:21, Robert L. Nuckolls, III <nuckolls.bob@aeroelect ric.com> wrote: > > At 11:04 AM 6/25/2016, you wrote: >> I am not sure if it would work for a starter relay or not. One behavior I noticed is when I leave my LED instrument lights on and shut the battery of f (this solid state relay) the LEDs will dim down while shutting off (like d imming them with a pwm). If I shut the LEDs off with their switch, they turn off instantly. Odd, but it doesn't seem to have any ill effects. > > The solid state 'contactor' is a array > of field effect transistors controlled > by a variable voltage applied to their > 'gates'. When used as a 'switch', on wants > them to be either 'on hard' or 'off hard' > like the behavior of contacts in relays > and switches . . . but depending on the > circuitry that drives the gates, the > transition time between ON and OFF states > may not be quite as fast as for metallic > contacts. > > With solid state contactors, there is a much > longer intervale to achieve the same current > flow as an open sent of contacts and it's > most observable when controlling devices that > with activity at every low currents . . . like > an LED. In a dark room, an LED can produce > visible light with tens of micro-amps of current > flow. > > Hence, what you've observed is an ordinary > circumstance that does not speak ill of the > contactor's performance. Airplanes with higher > levels of constant-on loads will drag the > bus down faster during contactor shut-down > make the behavior more like metallic contactors > but there's seldom a reason to make this a > design goal. > > > Bob . . . ________________________________________________________________________________
Date: Jun 26, 2016
There could also be something else on the bus that has a smoothing capacitor at its front end which is providing enough charge back to the bus to hold t he LEDs up briefly when the master is shut off. On Jun 26, 2016, at 12:52, Justin Jones wrote: Good to know Bob. Thank you for sharing your knowledge. I am really happy wi th the choice to go with contactor Justin. > On Jun 26, 2016, at 11:21, Robert L. Nuckolls, III <nuckolls.bob@aeroelect ric.com> wrote: > > At 11:04 AM 6/25/2016, you wrote: >> I am not sure if it would work for a starter relay or not. One behavior I noticed is when I leave my LED instrument lights on and shut the battery of f (this solid state relay) the LEDs will dim down while shutting off (like d imming them with a pwm). If I shut the LEDs off with their switch, they turn off instantly. Odd, but it doesn't seem to have any ill effects. > > The solid state 'contactor' is a array > of field effect transistors controlled > by a variable voltage applied to their > 'gates'. When used as a 'switch', on wants > them to be either 'on hard' or 'off hard' > like the behavior of contacts in relays > and switches . . . but depending on the > circuitry that drives the gates, the > transition time between ON and OFF states > may not be quite as fast as for metallic > contacts. > > With solid state contactors, there is a much > longer intervale to achieve the same current > flow as an open sent of contacts and it's > most observable when controlling devices that > with activity at every low currents . . . like > an LED. In a dark room, an LED can produce > visible light with tens of micro-amps of current > flow. > > Hence, what you've observed is an ordinary > circumstance that does not speak ill of the > contactor's performance. Airplanes with higher > levels of constant-on loads will drag the > bus down faster during contactor shut-down > make the behavior more like metallic contactors > but there's seldom a reason to make this a > design goal. > > > Bob . . . ________________________________________________________________________________
Date: Jun 26, 2016
Some object to my use of the term "ambient" as representative of the device temperature. You would be right for solid devices, but the type 70 is a part in a hollow housing. To make this more clear. If the "surrounding temperature" (perhaps under the cowl) is 130 deg F. What is the temperature of the can when the power is off? 130 deg F. If the can is 120 deg F and the surrounding temperature is 0 degrees. What is the temperature inside the can? It depends on the rate of heat removal, but it's more than 120 deg F for sure, and a device rated for 122 deg F would be in trouble. I know this is a more complicated issue. See my attachment on this subject that was slated to have been published in ECN but can't be sure it ever was. But don't get sidetracked. The type 70 isn't a reasonable device for GA aircraft. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457458#457458 Attachments: http://forums.matronics.com//files/hot_potato_121.pdf ________________________________________________________________________________
Date: Jun 26, 2016
Subject: Re: do I need to change my capacitor
At 09:26 AM 6/25/2016, you wrote: > >The MGL provides for the low voltage readings, but I did not catch >it. I was flying around with the battery voltage being shown. >With the new voltage regulator I'm showing 13.8v to 14.4v volts >during flight. If I turn on landing lights it will drop to about 13.4v. >Yes, I pattern the diode to the Jabiru figure, but did not install >the over protection. I'm now planning on doing that when I return from KOSH. >Trio Avionics only told me that the mother boards were burnt. The >same for MGL. >I'll see if I can find a architecture drawings. Most of mine are >hand drawn as I could never find a computer drawing program that I >could use effectively. Unless you're already proficient in CAD drawing systems, the FAST and very effective way to document your airplane goes something like this. Build a page-per-system wire book in a 3-ring binder using #2 pencil and 'pink pearl' eraser. Neat doesn't count at this stage. Just get all the data down on paper so you don't have to 'go back an look' to refresh your memory of things you did perhaps years ago. Every time you make a change, record it. But keep EACH page simple. Bus, breaker/fuse, wire, switch, wire, connector, gizmo, wire, ground. This litany might describe a landing light. Obviously, some will be more complex but in terms of the WHOLE airplane, each page is simple. Download this document and check out the wirebook pages in the back . . . http://tinyurl.com/zlco6ke These are examples of page-per-system drawings that illustrate the technique for illustrating wire segments, how and where they are terminated and how to list all of the components and materials that go into crafting that one system. Make the same kinds of drawings for your airplane filling in details as you go along. The 3-ring binder on the shop-bench is all the tooling you need. When the airplane is all done and depending on how legible your first-pass work is, you may choose to redraw the work . . . use a straight edge and gel pen. You can even draw your final document on top of your draft document using the draft data as a guide. When the final document is complete and totally dry, use the pink pearl to remove the pencil lines and smudges. It takes less practice to go this route than to search out, install and learn to use any kind of CAD program. If you're going to do this stuff for a living, having a CAD program may be useful. If this but one of a very few numbers of airplanes you're going to build, paper, pencil, eraser and pen are excellent, time proven alternatives to RECORD your work. The NEXT person to own your airplane will thank you for it. Bob . . . ________________________________________________________________________________
Date: Jun 26, 2016
Sent from Mail for Windows 10 From: Roger ________________________________________________________________________________
Date: Jun 26, 2016
At 10:03 AM 6/26/2016, you wrote: > >"Ambient" refers to the contactor temperature. But keep in mind that >"ambient" doesn't refer to the temperature someplace outside, but AT >and ON the contactor can. No . . . ambient means SURROUNDING conditions . . . >Furthermore the type to is G-position sensitive Yes . . . more G's than it takes to pull the wings off your airplane . . . as is every other metallic contactor. > vibration sensitive Non-quantified . . . how many g's at what frequency? Levels SMALLER than those found anywhere on a light aircraft? I've never analyzed a Type 70 failure that I could attribute to a vibration stress . . . LOTS of failures attributable to dripping water . . . a few failures due to manufacturing defect . . . and none that posed high-risk scenario. > not liquid proof Show me ONE contactor used on any TC light aircraft that is liquid proof . . . > and has many undesireable characterists Many implies more than one . . . I'd settle for just two . . . > . . . compared to other solutions. > >As for my choice? I go with the Flaming River Battery Switch, or any >of the several electronic contactor offerings, unless your mission >doesn't take you far from home. Can you cite any instance in the literature where a contactor failure "far from home" figured in elevation of risk to airframe or people in it? If so, what were the circumstances that promoted that failure? >Factoid: No NASCAR vehicle uses a type-70 contactor. For what reason(s) . . . can you cite conditions on these vehicles that are analogous to conditions on our airplanes? >Factoid: Very old Type-70's were made from far better stuff. Really? I've done some teardowns several variations of 70 series contactors. See pictures of inspected articles here: http://tinyurl.com/kcc26jt . . . they may be useful in explaining how the materials illustrated in picture A of a failure are 'better' than those in picture B. How did they contribute to the failure? One failure in a 'modern' 70 series contactor had nothing to do with selection of materials and lots to do with failure to solder a joint on the production line . . . http://tinyurl.com/zs42jpj >Please, can we do better than "hot to the touch" I will suggest that 'hot to touch' is more definitive to stress boundaries than several of your assertions above. "Too hot to touch" at least says somewhere more than ~130 degrees. I like "sizzle-spit" as being greater than 212 degrees. "Sticking your tongue to the flag pole" says a whole lot colder than 32 degrees. But 'sensitive to vibration' offers no bounded image. Bob . . . ________________________________________________________________________________
Date: Jun 26, 2016
Eric M. Jones wrote: > Please, can we do better than "hot to the touch" We can, and I did. If you will read my post you will see that I checked it with a thermometer and was seeing ~120F. Or do you require an exact temperature? Or do you need some digits to the right of the decimal point? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457462#457462 ________________________________________________________________________________
Date: Jun 26, 2016
> >If the can is 120 deg F and the surrounding temperature is 0 >degrees. What is the temperature inside the can? It depends on the >rate of heat removal, but it's more than 120 deg F for sure, and a >device rated for 122 deg F would be in trouble. Exactly . . . If you take any 70 series device apart you will find a collection of materials. Threaded, copper terminal studs upon which stationary contacts are formed. A washer-like movable contact mounted to the end of an iron armature that moves freely within the cylindrical 'bore' of a coil core. The core has evolved a lot over the years. But suffice it to say, that whether the solenoid wires are (1) simply wound on a tube and captured between disks of phenolic, (2) embedded in a solidly potted assembly or (3) wound on a complex molding that forms the tube, end confines, terminals and mates with contours of the shell . . . ALL materials used must first hold components in their intended positions while withstand expected internal operating temperatures. I used to work in a facility that specialized in the design and manufacture of numerous electronic and motor driven components . . . including the actual motors. I can tell you that ALL materials used in the manufacture of a brushed DC motor including insulated magnet wire, insulating varnishes, paper and molded plastic insulators and components were RATED to perform as advertised while enduring "Class H" thermal conditions. http://www.marathonelectric.com/generators/docs/manuals/thermal-life.pdf Of course, these are INTERNAL conditions which are expected to be hotter than external conditions. 122F is 50C . . . a rather benign condition for many qualification levels in aircraft. 70C ambients for black boxes are not uncommon. At the same time, I can tell you that 100C ambients for most electronic assemblies not dissipating a lot of power is no big deal. An engineer I've worked with for years will often throw his brass-board assemblies into the lab oven at 100C just to make sure he didn't overlook an unusually vulnerable part in the design. I trust this little dissertation goes to an understanding that 'proper' temperatures for operation with limits of design goals can be all over the map. Certainly your cylinder heads will 'sizzle spit' under perfectly normal conditions. The contactor illustrated in http://www.marathonelectric.com/generators/docs/manuals/thermal-life.pdf demonstrates a temperature rise of ~50C with no air flow over the device. Were we to operate this contactor in its RATED 122F environment (70C) then we might expect the contactor surface to go up to 120C . . . which will sizzle-spit. I can tell you that we didn't build a single motor that could not be operated with surface temperatures in sizzle-spit range . . . VERY much too hot to touch. Hence I can assert confidently that while the observed surface temperature for an operating 70 series contactor is unfriendly the touch, the device is NOT being unduly stressed internally. The 122F limit to operating environment suggests something less than class-H ratings for stuff inside . . . at the same time, it poses no practical operating limits on how we use the contactor. Bob . . . ________________________________________________________________________________
Date: Jun 26, 2016
Is there any evidence it's actually a limiting temperature? >>and the only reference I can find for temperature is "Temperature Range =93=93 -40=C2=B0F to 122=C2=B0F" The normal operating temperature for a device is given as the temperature ra nge within which the given electrical specification is met. There's no expec tation the the device can't or won't work, or shouldn't be used outside that temperature range, merely that you are somewhat on your own with respect to its characteristics. > On Jun 26, 2016, at 21:37, Robert L. Nuckolls, III <nuckolls.bob@aeroelect ric.com> wrote: > > > If the can is 120 deg F and the surrounding temperature is 0 degrees. What is the temperature inside the can? It depends on the rate of heat removal, b ut it's more than 120 deg F for sure, and a device rated for 122 deg F would be in trouble. Exactly . . . If you take any 70 series device apart you will find a collection of materials. Threaded, copper terminal studs upon which stationary contacts are formed. A washer-like movable contact mounted to the end of an iron armature that moves freely within the cylindrical 'bore' of a coil core. The core has evolved a lot over the years. But suffice it to say, that whether the solenoid wires are (1) simply wound on a tube and captured between disks of phenolic, (2) embedded in a solidly potted assembly or (3) wound on a complex molding that forms the tube, end confines, terminals and mates with contours of the shell . . . ALL materials used must first hold components in their intended positions while withstand expected internal operating temperatures. I used to work in a facility that specialized in the design and manufacture of numerous electronic and motor driven components . . . including the actual motors. I can tell you that ALL materials used in the manufacture of a brushed DC motor including insulated magnet wire, insulating varnishes, paper and molded plastic insulators and components were RATED to perform as advertised while enduring "Class H" thermal conditions. http://www.marathonelectric.com/generators/docs/manuals/thermal-life.pdf Of course, these are INTERNAL conditions which are expected to be hotter than external conditions. 122F is 50C . . . a rather benign condition for many qualification levels in aircraft. 70C ambients for black boxes are not uncommon. At the same time, I can tell you that 100C ambients for most electronic assemblies not dissipating a lot of power is no big deal. An engineer I've worked with for years will often throw his brass-board assemblies into the lab oven at 100C just to make sure he didn't overlook an unusually vulnerable part in the design. I trust this little dissertation goes to an understanding that 'proper' temperatures for operation with limits of design goals can be all over the map. Certainly your cylinder heads will 'sizzle spit' under perfectly normal conditions. The contactor illustrated in http://www.marathonelectric.com/generators/docs/manuals/thermal-life.pdf demonstrates a temperature rise of ~50C with no air flow over the device. Were we to operate this contactor in its RATED 122F environment (70C) then we might expect the contactor surface to go up to 120C . . . which will sizzle-spit. I can tell you that we didn't build a single motor that could not be operated with surface temperatures in sizzle-spit range . . . VERY much too hot to touch. Hence I can assert confidently that while the observed surface temperature for an operating 70 series contactor is unfriendly the touch, the device is NOT being unduly stressed internally. The 122F limit to operating environment suggests something less than class-H ratings for stuff inside . . . at the same time, it poses no practical operating limits on how we use the contactor. Bob . . . ________________________________________________________________________________
Date: Jun 26, 2016
At 09:42 PM 6/26/2016, you wrote: >Is there any evidence it's actually a limiting temperature? > > >>and the only reference I can find for > temperature is "Temperature Range '' -40=C2=B0F to 1o 122=C2=B0F" > >The normal operating temperature for a device is >given as the temperature range within which the >given electrical specification is met. There's >no expectation the the device can't or won't >work, or shouldn't be used outside that >temperature range, merely that you are somewhat >on your own with respect to its characteristics. Temperature ratings are a bit 'squishy' . . . like contact ratings for current and voltage. Most ratings are bounded by calculated or laboratory demonstrations of service life. The 70 series contactor isn't going to burst into flames if operated in a 150F environment. At the same time, it would probably not demonstrate rated life limits either. Then again, we don't even begin to stress the service life of any switch or contactor in a GA single engine airplane! The 122F/50C recommended limit probably assumes still air . . . sitting out on a bench. Add a little moving air and internal temperatures will fall like a stone . . . which translates to a boost in recommended limit to ambient air temperature. I may have the data in my archives somewhere that describes temperature conditions under the cowl on a single engine airplane. We were setting up a cooling test on a new alternator installation and had 8 thermocouple channels open on the DAS. We scattered some extra thermocouples around and discovered that in-flight temperatures are really rather benign . . . the hottest spikes occurred during cool-down after engine shutdown when air flow dropped and heat stored on the engine mass warmed things up under the cowl. Of course, the thermocouples only gave us total temperature of the air at various locations. To assess cooling effects of air movement, we would have to repeat the experiment by mounting the thermocouples onto power resistors and then plotting differences between static air and in-flight conditions with stirred air over components that were dissipating heat. The constellation of variables can be all over the map when it comes to in-situ thermal management of components in the airplane . . . hence, making a decision to buy brand X contactor rated at 50F versus brand Y rated at 70C could very well be a poor cost of ownership decision. As our ol' buddy Lord Kelvin used to say, "Until you've measured the thing . . . your knowledge of the science is of a meager and unsatisfactory kind." Bob . . . ________________________________________________________________________________
Subject: Re: Dual batteries or dual alternators?
Date: Jun 27, 2016
Hi Bob and everyone else, Here is our take on the Bus Manager: We wanted a simple one box solution to provide the management necessary for a two battery setup to support electronically dependent engines. The creation of a protected "Essential Bus" being the primary goal. The Essential Bus is the protected power source for the engine electronics. We also wanted some other items such as: Battery charge isolation, ability to start the engine off of either battery (or both), and automatic management of a dual electric fuel pump module. The Bus Manager is simply the solution for the above requirement. It does not require pilot intervention to supply current from either battery to the Essential Bus. It also does not require pilot intervention to engage the backup electric fuel pump. In addition, there is a third level of redundancy via the Emergency Power switch. There is a Main Bus output powered by the primary battery to power non-flight critical systems. The Bus Manager also supports one or two alternator operation. Most two seat airplanes can use two Odyssey PC625 batteries for the system. Two of these batteries together are similar in size and weight to one Concord (RG-25) aircraft battery. The failure mode the we have seen most in small aircraft is simply a loose wire somewhere. If the loose wire happens to be a battery cable or primary bus supply wire, this can spell trouble for the engine electronics. Having multiple paths for electricity to reach critical equipment is the simple solution to this issue. An architecture that allows the backup process to occur without pilot intervention means that the engine never skips a beat if one supply source goes down - this is a big deal and provides a big comfort level. I have witnessed an entire panel go black and the Bus Manager protect the engine without power interruption. Anyhow, those are the goals of the Bus Manager. It is a simple one-box solution to a semi complicated problem. In most experimentals, the Bus Manager can provide the the power distribution for the entire plane. It really makes power system setup a simple task. And simple means reliable. Robert Paisley EFII Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457483#457483 ________________________________________________________________________________
Subject: New smartphone app for pilots
Date: Jun 27, 2016
Greetings All, While being grounded for the past many months with a cracked engine block, I have been amusing myself by writing software. Since there is a preponderance of hardware geeks on the AeroElectric list, I thought you guys might be interested this app from a long time list member/contributor. Allow me to introduce avAltimeter Not many many people are aware that in the iPhone 6 and later, Apple has incorporated a Bosch barometer chip. I recently released to the App Store a unique app which emulates an analog flight altimeter with a number of "smart" features including a Kollsman window for setting the current pressure, calculation of Density Altitude, true airspeed and takeoff performance. The App also provides a warning for supplemental oxygen consistent with US FARs. Obviously avAltimeter is not FAA TSO approved and so I provide it for entertainment only. At present it can only be run on iPhone 6 and later, and not iPads or iPods. I understand the new Samsung Galaxy S7 now has a barometer chip as well and I plan to transfer the code to Android soon. My software web site is http://www.aviametrix.com or search for "avAltimeter" on the Apple App Store! Thanks for your attention! Cheers, -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457490#457490 ________________________________________________________________________________
Subject: Re: New smartphone app for pilots
Date: Jun 27, 2016
Ira, Just downloaded your app. Very nice. Looking forward to trying it out if I can ever get this inner ear problem cleared up. Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop (75 hrs). Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com On Jun 27, 2016, at 5:04 PM, rampil wrote: Greetings All, While being grounded for the past many months with a cracked engine block, I have been amusing myself by writing software. Since there is a preponderance of hardware geeks on the AeroElectric list, I thought you guys might be interested this app from a long time list member/contributor. Allow me to introduce avAltimeter Not many many people are aware that in the iPhone 6 and later, Apple has incorporated a Bosch barometer chip. I recently released to the App Store a unique app which emulates an analog flight altimeter with a number of "smart" features including a Kollsman window for setting the current pressure, calculation of Density Altitude, true airspeed and takeoff performance. The App also provides a warning for supplemental oxygen consistent with US FARs. Obviously avAltimeter is not FAA TSO approved and so I provide it for entertainment only. At present it can only be run on iPhone 6 and later, and not iPads or iPods. I understand the new Samsung Galaxy S7 now has a barometer chip as well and I plan to transfer the code to Android soon. My software web site is http://www.aviametrix.com or search for "avAltimeter" on the Apple App Store! Thanks for your attention! Cheers, -------- Ira N224XS ________________________________________________________________________________
From: Stuart Hutchison <stuart(at)stuarthutchison.com.au>
Date: Jun 28, 2016
G'day Ira, thank you for developing the avAltimeter app, very handy! One suggested improvement in many parts of the world (including here in Australia) metric is needed for Celsius, but we still use Feet for altimetry (if not, literally tens of thousands of altimeters would need to be replaced), so a combination of Metric for Celsius and Imperial for Altimeter/DA in Feet would be handy when you next update the app. Cheers, Stu > On 28 Jun 2016, at 09:26, Robert Borger wrote: > > > Ira, > > Just downloaded your app. Very nice. Looking forward to trying it out if I can ever get this inner ear problem cleared up. > > Blue skies & tailwinds, > Bob Borger > Europa XS Tri, Rotax 914, Airmaster C/S Prop (75 hrs). > Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP > 3705 Lynchburg Dr. > Corinth, TX 76208-5331 > Cel: 817-992-1117 > rlborger(at)mac.com > > On Jun 27, 2016, at 5:04 PM, rampil wrote: > > > Greetings All, > > While being grounded for the past many months with a cracked engine block, > I have been amusing myself by writing software. Since there is a > preponderance of hardware geeks on the AeroElectric list, I thought you > guys might be interested this app from a long time list member/contributor. > > Allow me to introduce avAltimeter > > Not many many people are aware that in the iPhone 6 and later, Apple > has incorporated a Bosch barometer chip. I recently released to the > App Store a unique app which emulates an analog flight altimeter with > a number of "smart" features including a Kollsman window for setting > the current pressure, calculation of Density Altitude, true airspeed and > takeoff performance. The App also provides a warning for supplemental > oxygen consistent with US FARs. > > Obviously avAltimeter is not FAA TSO approved and so I provide it for > entertainment only. At present it can only be run on iPhone 6 and later, > and not iPads or iPods. I understand the new Samsung Galaxy S7 now > has a barometer chip as well and I plan to transfer the code to Android > soon. > > My software web site is http://www.aviametrix.com > or search for "avAltimeter" on the Apple App Store! > > Thanks for your attention! > > Cheers, > > -------- > Ira N224XS > > > > > ________________________________________________________________________________
Date: Jun 28, 2016
Nice one Ira, We in South Africa also have the same system as the Aussies, so we would welcome the upgrade! On 28 June 2016 at 00:04, rampil wrote: > > Greetings All, > > While being grounded for the past many months with a cracked engine block, > I have been amusing myself by writing software. Since there is a > preponderance of hardware geeks on the AeroElectric list, I thought you > guys might be interested this app from a long time list member/contributor. > > Allow me to introduce avAltimeter > > Not many many people are aware that in the iPhone 6 and later, Apple > has incorporated a Bosch barometer chip. I recently released to the > App Store a unique app which emulates an analog flight altimeter with > a number of "smart" features including a Kollsman window for setting > the current pressure, calculation of Density Altitude, true airspeed and > takeoff performance. The App also provides a warning for supplemental > oxygen consistent with US FARs. > > Obviously avAltimeter is not FAA TSO approved and so I provide it for > entertainment only. At present it can only be run on iPhone 6 and later, > and not iPads or iPods. I understand the new Samsung Galaxy S7 now > has a barometer chip as well and I plan to transfer the code to Android > soon. > > My software web site is http://www.aviametrix.com > or search for "avAltimeter" on the Apple App Store! > > Thanks for your attention! > > Cheers, > > -------- > Ira N224XS > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=457490#457490 > > -- Best... Bob Verwey ________________________________________________________________________________
From: Stephen Richards <stephencliverichards(at)gmail.com>
Date: Jun 28, 2016
Ira The Uk & rest of EASA land uses hectopascal Europe new name for ( Millibar ) & feet. So a upgrade would be useful -----Original Message----- From: "Bob Verwey" <bob.verwey(at)gmail.com> Sent: =8E28/=8E06/=8E2016 07:53 Subject: Re: AeroElectric-List: New smartphone app for pilots Nice one Ira, We in South Africa also have the same system as the Aussies, so we would we lcome the upgrade! On 28 June 2016 at 00:04, rampil wrote: Greetings All, While being grounded for the past many months with a cracked engine block, I have been amusing myself by writing software. Since there is a preponderance of hardware geeks on the AeroElectric list, I thought you guys might be interested this app from a long time list member/contributor. Allow me to introduce avAltimeter Not many many people are aware that in the iPhone 6 and later, Apple has incorporated a Bosch barometer chip. I recently released to the App Store a unique app which emulates an analog flight altimeter with a number of "smart" features including a Kollsman window for setting the current pressure, calculation of Density Altitude, true airspeed and takeoff performance. The App also provides a warning for supplemental oxygen consistent with US FARs. Obviously avAltimeter is not FAA TSO approved and so I provide it for entertainment only. At present it can only be run on iPhone 6 and later, and not iPads or iPods. I understand the new Samsung Galaxy S7 now has a barometer chip as well and I plan to transfer the code to Android soon. My software web site is http://www.aviametrix.com or search for "avAltimeter" on the Apple App Store! Thanks for your attention! Cheers, -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457490#457490 - Electric-List" rel="noreferrer" target="_blank">http://www.matronics.co m/Navigator?AeroElectric-List FORUMS - eferrer" target="_blank">http://forums.matronics.com WIKI - errer" target="_blank">http://wiki.matronics.com b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution -- Best... Bob Verwey ________________________________________________________________________________
Date: Jun 28, 2016
Hi All! Several of you have made the excellent point that in many more places than I realized, the pressure setting is done in metric, but the output required is in feet! I modified the Setting Page to accommodate that requirement this morning. I want to test it for a few days and then I will send it to Apple for App Store review. It should be available by the weekend if Apple keeps up the recent improvement in review time. At the risk of spamming, I will post a very brief note here when the improved version is available. Many Thanks for the thoughtful comments! Cheers Ira -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457501#457501 ________________________________________________________________________________
Date: Jun 28, 2016
Subject: Z-13/8 Questions
Hi Bob, I'm building a Long-EZ and have a couple of questions on the Z-13/8 architecture. 1. In AEC 12th Ed. Chapter 11-3 you discuss "panel space conservation" and that in the Z diagrams there's an example that shows "avionics master switch controls essential bus connection to main bus, selects an emergency mode essential bus feed directly from battery . . . " I couldn't find any examples of that, but it did make me consider combining the AUX ALT and E-BUS ALT FEED switches into one switch using a 2-10 ON-ON-ON switch. Is there a specific reason that I'm missing that would preclude me from doing so? My thought is that it would refine my focus if my main alternator goes haywire, requiring me then to only concern myself with two actual switches versus three. Plus, there's the added bonus of weight savings and panel space. 2. I found a forum exchange where you discussed keeping feeds off the battery bus no greater than 7A (if fused). Otherwise, the feed should have a pilot controlled disconnect (relay) in local proximity to the bus. Apparently, I missed taking this into account as I designed my electrical system, and am now backtracking a bit to correct it. I wanted to clarify this information since in many of the Z diagrams in the back of the AEC you show a 10A fuel pump being fed off the battery bus. I also wanted to confirm this because I have a couple items requiring 10A feeds that I would like to keep on the battery bus. The first is a fuel pump, which I can throw in a relay no problem. The other feed, however, is for the nose gear actuator. On the gear actuator, the manufacturer's schematic shows the feed coming off the battery bus to a panel mounted 10A circuit breaker (required by manufacturer). I'm a bit stuck on how to design this, especially since there's no included information as to whether the gear actuator feed should be connected off the battery bus at a fused fast-on tab or off the threaded fuseblock post? I'm trying to keep my electrical system as safe, simple and elegant as possible, so I would greatly appreciate your feedback on this. Regards, Wade Parton (building) Long-EZ N916WP ________________________________________________________________________________
Date: Jun 28, 2016
Subject: Re: Z-13/8 Questions
At 01:11 PM 6/28/2016, you wrote: >Hi Bob, > >I'm building a Long-EZ and have a couple of >questions on the Z-13/8 architecture. > >1.=C2 In AEC 12th Ed. Chapter 11-3 you discuss >"panel space conservation" and that in the Z >diagrams there's an example that shows "avionics >master switch controls essential (ENDURANCE) bus >connection to main bus, selects an emergency >(PLAN-B . . . we don't have emergencies) mode >essential bus feed directly from battery . . . " >=C2 I couldn't find any examples of that, but it >did make me consider combining the AUX ALT and >E-BUS ALT FEED switches into one switch using a 2-10 ON-ON-ON switch. Not recommended. It's prudent not to generate signle points of failure for the e-bus feeds. >=C2 Is there a specific reason that I'm missing >that would preclude me from doing so?=C2 My >thought is that it would refine my focus if my >main alternator goes haywire, requiring me then >to only concern myself with two actual switches >versus three.=C2 Plus, there's the added bonus of >weight savings and panel space. That 'avionics switch' was illustrated to placate builders deeply steeped in legacy hangar lore. The original need for an avionics switch was il-conceived. The REAL need for any such switch evaporated a few years later with the incorporation of DO160 design goals and even less significant with the drop in avionics power draw paired with more robust cranking performance of batteries. None of the z-figures illustrates or suggests an avionics master switch. >2.=C2 I found a forum exchange where you >discussed keeping feeds off the battery bus no >greater than 7A (if fused). Otherwise, the feed >should have a pilot controlled disconnect >(relay) in local proximity to the bus. >Apparently, I missed taking this into account as >I designed my electrical system, and am now backtracking a bit to correct it. What's on your e-bus? Remember, this is an ENDURANCE bus . . . crafted and loaded such that during loss of main alternator, energy stored in the ship's battery is held in RESERVE for descent and approach to landing. So if you've got an SD-8 aux alternator, e-bus loading goals are on the order of 8A or less. This is done by operating only those items necessary for the EN ROUTE phase of flight. The e-bus first appeared on LongEz aircraft before Z-13/8. Back then, the design goal was to reduce EnRoute loads to some value assuring arrival at airport of intended destination battery-only. Often these loads added up to less than 2 amps. Panel lite, nav receiver, transponder. With Z-13/8, the nature of e-bus ops changed dramatically. Now you have an en route budget on the order of 8A while holding the battery in reserve. Shoot for 8A or less and don't worry about the relay. > I wanted to clarify this information since in > many of the Z diagrams in the back of the AEC > you show a 10A fuel pump being fed off the battery bus. I don't show a fuel pump that DRAWS 10A, I show a fuel pump that is POWERED through a feeder protected at 10A. >=C2 I also wanted to confirm this because I have >a couple items requiring 10A feeds that I would >like to keep on the battery bus.=C2 The first is >a fuel pump, which I can throw in a relay no problem. What is the current draw for this pump? >=C2 The other feed, however, is for the nose gear >actuator.=C2 On the gear actuator, the >manufacturer's schematic shows the feed coming >off the battery bus to a panel mounted 10A >circuit breaker (required by manufacturer). That is an intermittent load . . . lasting only seconds. So like your starter that draws a LOT of current, it only uses a few percent of the battery's stored energy to get the fires lit off. >=C2 I'm a bit stuck on how to design this, >especially since there's no included information >as to whether the gear actuator feed should be >connected off the battery bus at a fused fast-on >tab or off the threaded fuseblock post? Your nose gear actuator could draw lots of current but it's only for a few seconds so the ENERGY required is minimal. Wire it to a fast-on location at the battery bus fuse block. Shucks, you can wire the nose gear up with 12AWG driven by a 20 A fuse if there's any concern for nuisance tripping the fuse. I would do some testing on the ground to put a rough measure on the motor's inrush characteristics. What kind of information do you have on the motor used in the gear assembly? Does it have a lable with a manufacturer's name and part number? >=C2 I'm trying to keep my electrical system as >safe, simple and elegant as possible, so I would >greatly appreciate your feedback on this. No problem, it's what we do here. If you're putting Z-13/8 in an Ez, then tie all your alternator feeds to the system at the HOT size of the starter contactor which should be on the firewall. What size wires are you running aft for starter feed and ground? Make us a list of all your fuses, what they feed and which bus drives them. Bob . . . ________________________________________________________________________________
Date: Jun 28, 2016
Subject: Bendix King KY97A Tuning Problem
My Bendix King KY97A VHF Transceiver inner tuner knob skips tuning adjustments. It is like a gear with some worn or missing teeth. It tunes properly for a while and then skips repeatedly for a while. The radio works fine in all other regards. Has anyone ever experienced this or looked inside to see if there is an obvious issue? I may open the case when I get a chance. TIA --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jun 28, 2016
Subject: Remove KY97A Replace With SL40
As noted in another post, my Bendix King KY97A VHF transceiver has a tuning problem. I have on hand a working Garmin SL40 VHF transceiver with tray. If I can't fix the KY97A, I plan to pull the tray and put in the SL40 tray. Then I plan to make a converter cable to go from the current input cable to attach to the SL40. The KY97A has a flat connector with 1-15 on the bottom and A-S on the top. It is a very simple installation. The SL40 has a 15 pin D connector. Does anyone have any experience or comments on making such a converter cable? I already have plans to change out the panel next year to a totally different system. I'd like to use the SL40 radio on hand for the interim and minimize the rewiring until I do the full makeover. Comments? Suggestions? TIA --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jun 28, 2016
Bob, Roger on NOT combining the AUX ALT and E-BUS ALT FEED switches into one switch. It does make me curious though what would happen if either of those switches becomes in-op, since there would still be no way to revert to the SD-8 backup ALT, correct? > > What's on your e-bus? This is what I currently have on my E-BUS: E-Bus Relay/SD-8 Relay/VReg/OV 0.3A ElectroAir Electronic Ignition System Coil 0.8A Electronic Ignition System Controller 0.8A EFIS GRT HXr - PFD 1.5A EFIS GRT Mini-X MFD 0.3A Engine Mgt System Module - GRT 0.2A TruTrak ADI 0.5A Trig TT22 Transponder Mode S 0.4A Trig TY91 Radio - COM1 0.2A Radenna SkyRadar-DX ADSB Receiver 0.4A Fuel Computer 0.4A MGL RTC-2 Clock 0.1A USB Hub 0.4A Nose Gear Auto Gear Extension 0.1A Nav Lights 0.4A TRIO Autopilot Control Head 0.5A Trio A/P Servos (~2A transient) Total nominal draw on E-BUS/SD-8: 7.9 amps (not including transient loads). Also, The numbers above either came out of the manuals or from discussions with the manufacturers. I do currently have an S704-1 Relay wired into place between the battery bus and E-Bus. > What is the current draw for this pump? Just under 5A according to the folks at EFII. According to them, a 16AWG wire fused at 10A from the battery bus to the panel switch, then 16AWG to the pump sitting just forward of the firewall would work fine. > > What kind of information do you > have on the motor used in the gear assembly? > Does it have a lable with a manufacturer's name > and part number? The nose gear actuator is under a cover right now that is difficult to get to, but from my build pictures I found that on the motor cover it states: > Thomson Saginaw Ball Screw Company, Inc., Performance Pak And from looking at the manufacturer's website, it looks as if this is the Electrak 10 series motor. The nose gear actuator motor is actually part of the EZNoseLift electric nose gear system. The purpose for the 10A CB is that in a fiberglass plane like the Long-EZ it offers some protection if the up-travel microswitch fails and the nose gear continues to travel up into the nose wheel well. After some minor crushing the 10A CB is designed to pop and thus save the rest of nose from any further damage. I checked with the manufacturer and he recommended running a 16-AWG wire from the battery bus to the 10CB on the panel. > What size wires are you > running aft for starter feed and ground? Planning on using the Super-4-CCA copper clad aluminum. This was recommended to me by a number of EZ drivers that are currently using it and are quite happy with it. I'll work on compiling that list of fuses, feeds and busses. Thanks Bob! -Wade -------- Airdog Wade Parton Building Long-EZ 916WP www.longezpush.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457516#457516 ________________________________________________________________________________
Date: Jun 28, 2016
Subject: Re: Remove KY97A Replace With SL40
> I'd like to use the SL40 radio on hand for the >interim and minimize the rewiring until I do the full makeover. >Comments? Suggestions? Can probably be done. I have the connectors and pin-outs. It would be useful to know which pins are populated in the KY97 connector. Don't need functionality, just the location. I can sketch the wiring and send you connectors. Bob . . . ________________________________________________________________________________
Date: Jun 28, 2016
At 06:17 PM 6/28/2016, you wrote: > >Bob, > >Roger on NOT combining the AUX ALT and E-BUS ALT FEED switches into >one switch. It does make me curious though what would happen if >either of those switches becomes in-op, since there would still be >no way to revert to the SD-8 backup ALT, correct? Not at all. Recall that the Plan-B for inop main alternator is . . . Ebus Alt Feed Switch . . . closed. Aux alternator Switch . . . ON Main alternator/battery contactor switch . . . . OPEN This series of actions supports the e-bus DIRECTLY from the battery, supports the battery with 8A of engine driven energy, relieves the system of parasitic battery contactor loads and potentially parasitic alternator field loads. The main bus goes dark. This DOES not preclude the pilot from re-closing the battery contactor to bring the main bus back up . . . which brings the e-bus up as well through the normal feed diode. But keep in mind that ONE failure is rare, in the interval defined by fuel aboard for engine endurance. DUAL failures are exceedingly rare. Hence, there are NO single failures of Z-13/8 that put the pilot in an uncomfortable condition. Bob . . . ________________________________________________________________________________
Date: Jun 28, 2016
Subject: KX155 alternative
Now that Bendix King have stopped making parts for this radio, especially the display, any advice concerning maintenance options or replacements? One of mine was rehab'd so it works well but the other is starting to miss segments. Haven't pulled it yet to try burnishing the zebra contacts. I just love obsolescence. Jim Baker 405 426 5377 ________________________________________________________________________________
Subject: Re: KX155 alternative
Date: Jun 28, 2016
If it's 12v, and it has a glideslope receiver, and you decide to part it out, let me know... On Jun 28, 2016, at 21:56, Jim Baker wrote: Now that Bendix King have stopped making parts for this radio, especially the display, any advice concerning maintenance options or replacements? One of mine was rehab'd so it works well but the other is starting to miss segments. Haven't pulled it yet to try burnishing the zebra contacts. I just love obsolescence. Jim Baker 405 426 5377 ________________________________________________________________________________
Date: Jun 28, 2016
> >This is what I currently have on my E-BUS: >E-Bus Relay/SD-8 Relay/VReg/OV 0.3A >ElectroAir Electronic Ignition System Coil 0.8A >Electronic Ignition System Controller 0.8A >EFIS GRT HXr - PFD 1.5A >EFIS GRT Mini-X MFD 0.3A >Engine Mgt System Module - GRT 0.2A >TruTrak ADI 0.5A >Trig TT22 Transponder Mode S 0.4A >Trig TY91 Radio - COM1 0.2A >Radenna SkyRadar-DX ADSB Receiver 0.4A >Fuel Computer 0.4A >MGL RTC-2 Clock 0.1A >USB Hub 0.4A >Nose Gear Auto Gear Extension 0.1A >Nav Lights 0.4A >TRIO Autopilot Control Head 0.5A > Trio A/P Servos (~2A transient) > >Total nominal draw on E-BUS/SD-8: 7.9 amps (not including transient loads). Okay, looks like the SD8 is good >Also, The numbers above either came out of the manuals or from >discussions with the manufacturers. > >I do currently have an S704-1 Relay wired into place between the >battery bus and E-Bus. that could go away . . . > > What is the current draw for this pump? > >Just under 5A according to the folks at EFII. According to them, a >16AWG wire fused at 10A from the battery bus to the panel switch, >then 16AWG to the pump sitting just forward of the firewall would work fine. Is this a back up pump or does it run all the time? > > Thomson Saginaw Ball Screw Company, Inc., Performance Pak > And from looking at the manufacturer's website, it looks as if > this is the Electrak 10 series motor. The nose gear actuator motor > is actually part of the EZNoseLift electric nose gear system. The > purpose for the 10A CB is that in a fiberglass plane like the > Long-EZ it offers some protection if the up-travel microswitch > fails and the nose gear continues to travel up into the nose wheel > well. After some minor crushing the 10A CB is designed to pop and > thus save the rest of nose from any further damage. I checked with > the manufacturer and he recommended running a 16-AWG wire from the > battery bus to the 10CB on the panel. Hmmmm . . . IVO Props do a similar thing to manage the stalled motor condition . . . not very sanitary. If these are ball-screw actuators, theres is potential for large forces on the screw as a product of both stall torque and dynamic torque when bringing the rotating armature mass to an abrupt halt. Have there been instances of limit switch failure? > > What size wires are you > > running aft for starter feed and ground? > >Planning on using the Super-4-CCA copper clad aluminum. This was >recommended to me by a number of EZ drivers that are currently using >it and are quite happy with it. > >I'll work on compiling that list of fuses, feeds and busses. Looking forward to it . . . Bob . . . ________________________________________________________________________________
Date: Jun 28, 2016
Bob, I'm glad I asked the question! > Not at all. Recall that the Plan-B for inop main > alternator is . . . > > Ebus Alt Feed Switch . . . closed. > > Aux alternator Switch . . . ON > > Main alternator/battery contactor switch . . . . OPEN For some reason I had this process exactly reversed... some vital info to know right there! Also good to know on the relay between the battery bus and E-bus: I'll remove it. > > Is this a back up pump or does it run all the time? It's a back up pump to the engine driven fuel pump. It's only on during takeoffs and landings, and as a backup if the mechanical fuel pump croaks. > > Have there been instances of limit switch failure? I haven't heard of any limit switch failures, and I've been working this project for over 5 years. I did get into the manual and here's the warning, which shows that a failure of the micro-switch is protected more by the mechanical configuration of the actuator, in conjunction with a CB, than any crunching of fiberglass. Forgive my earlier dramatic paraphrasing on how this thing works: "Warning: The actuator is capable of 3000 lbs. of straight line lifting force that will cause damage and injury even when protected by the slip clutch and the circuit breaker. In case of micro switch failure or misadjustment, the over travel in the up position is about .15 at the actuator. The internal rubber shock cushion will absorb this and the actuator will reach its mechanical limit and pop the breaker. This feature will protect the aircraft structure from damage." Thanks again Bob! Regards, -Wade -------- Airdog Wade Parton Building Long-EZ 916WP www.longezpush.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457522#457522 ________________________________________________________________________________
Date: Jun 29, 2016
Hi Bob Isn't 'closed' - 'ON' --- (and of course 'open' being 'OFF') You used both 'styles' or am I wrong John Sent from my iPad ----x--O--x---- > On 29 Jun 2016, at 02:09 am, "Robert L. Nuckolls, III" <nuckolls.bob@aeroe lectric.com> wrote: > > At 06:17 PM 6/28/2016, you wrote: >> >> Bob, >> >> Roger on NOT combining the AUX ALT and E-BUS ALT FEED switches into one s witch. It does make me curious though what would happen if either of those s witches becomes in-op, since there would still be no way to revert to the SD -8 backup ALT, correct? > > Not at all. Recall that the Plan-B for inop main > alternator is . . . > > Ebus Alt Feed Switch . . . closed. > > Aux alternator Switch . . . ON > > Main alternator/battery contactor switch . . . . OPEN > > This series of actions supports the e-bus > DIRECTLY from the battery, supports the battery > with 8A of engine driven energy, relieves the > system of parasitic battery contactor loads and > potentially parasitic alternator field loads. > The main bus goes dark. > > This DOES not preclude the pilot from re-closing > the battery contactor to bring the main bus back > up . . . which brings the e-bus up as well through > the normal feed diode. > > But keep in mind that ONE failure is rare, > in the interval defined by fuel aboard for engine > endurance. DUAL failures are exceedingly rare. > > Hence, there are NO single failures of Z-13/8 > that put the pilot in an uncomfortable condition. > > > > > > > Bob . . . ________________________________________________________________________________
Date: Jun 29, 2016
At 01:36 AM 6/29/2016, you wrote: >Hi Bob > >Isn't 'closed' - 'ON' --- (and of course 'open' being 'OFF') > >You used both 'styles' or am I wrong yes open/off closed/on Bob . . . ________________________________________________________________________________
Subject: Hypothetical Battery Contactor Failure
Date: Jun 29, 2016
While flying, suppose that there is failure in the battery contactor coil circuit and that the alternator continues to function. Will the pilot notice any symptoms prior to engine shutdown? If so, what are they? Thanks. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457526#457526 ________________________________________________________________________________
Date: Jun 29, 2016
I thought King is making an LED replacement but it's pricey! Sent from my iPhone > On Jun 28, 2016, at 6:56 PM, Jim Baker wrote: > > > Now that Bendix King have stopped making parts for this radio, especially the display, any advice concerning maintenance options or replacements? One of mine was rehab'd so it works well but the other is starting to miss segments. Haven't pulled it yet to try burnishing the zebra contacts. > > I just love obsolescence. > > Jim Baker > 405 426 5377 > > > > ________________________________________________________________________________
Subject: Re: Hypothetical Battery Contactor Failure
Date: Jun 29, 2016
Hmmm. . . . Interesting scenario. . . . First thought is. . . if one is good at watching steam gauge detail, the amp/current meter should drop 1-2 amps because the support charge going to the battery is cut off. Maybe some audio noise may increase in headsets, etc., since the battery, acting as a huge filter capacitor, is not able to do its secondary job being cut off via the open contactor. . . . Dave ----- Original Message ----- From: "user9253" <fransew(at)gmail.com> Sent: Wednesday, June 29, 2016 7:14 AM Subject: AeroElectric-List: Hypothetical Battery Contactor Failure > > While flying, suppose that there is failure in the battery contactor coil > circuit and that the alternator continues to function. Will the pilot > notice any symptoms prior to engine shutdown? If so, what are they? > Thanks. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=457526#457526 > > > ________________________________________________________________________________
Date: Jun 29, 2016
Hi Jim, You probably have already found this. . . the 155 display is easy to get to and change. Just remember to set the control knobs at some "known" position before you pull them off. Once the front panel is removed, the display slides out of it's large contact holder. Cleaning the contacts may help, but, being a high voltage gas display, the problem of missing segments is usually permanent. That display is expensive and a bugger to find. I would check with large avionics shops and if they have some new old inventory, they might sell you a new display. I like the -155. It is a same to send it to the grave yard. Dave _______________________________________________________________________________- ----- Original Message -----
Sent: Tuesday, June 28, 2016 7:36 PM
> > If it's 12v, and it has a glideslope receiver, and you decide to part it > out, let me know... > > On Jun 28, 2016, at 21:56, Jim Baker wrote: > > > Now that Bendix King have stopped making parts for this radio, especially > the display, any advice concerning maintenance options or replacements? > One of mine was rehab'd so it works well but the other is starting to miss > segments. Haven't pulled it yet to try burnishing the zebra contacts. > > I just love obsolescence. > > Jim Baker > 405 426 5377 > > > ________________________________________________________________________________
Date: Jun 29, 2016
QXQgJDIuNWsgYSBwb3AsIEknbGwgcGFzcy4gCgpKaW0gQmFrZXIKNDA1LjQyNi41Mzc3CgotLS0t LU9yaWdpbmFsIE1lc3NhZ2UtLS0tLQpGcm9tOiBQYXVsIE1pbGxuZXIgPG1pbGxuZXJAbWUuY29t PgpUbzogYWVyb2VsZWN0cmljLWxpc3RAbWF0cm9uaWNzLmNvbQpTZW50OiBXZWQsIDI5IEp1biAy MDE2IDEyOjE5ClN1YmplY3Q6IFJlOiBBZXJvRWxlY3RyaWMtTGlzdDogS1gxNTUgYWx0ZXJuYXRp dmUKCi0tPiBBZXJvRWxlY3RyaWMtTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogUGF1bCBNaWxsbmVy IDxtaWxsbmVyQG1lLmNvbT4KCkkgdGhvdWdodCBLaW5nIGlzIG1ha2luZyBhbiBMRUQgcmVwbGFj ZW1lbnQgYnV0IGl0J3MgcHJpY2V5IQoKU2VudCBmcm9tIG15IGlQaG9uZQoKPiBPbiBKdW4gMjgs IDIwMTYsIGF0IDY6NTYgUE0sIEppbSBCYWtlciA8amltYmFrZXJAbnBhY2MubmV0PiB3cm90ZToK PiAKPiAtLT4gQWVyb0VsZWN0cmljLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6IEppbSBCYWtlciA8 amltYmFrZXJAbnBhY2MubmV0Pgo+IAo+IE5vdyB0aGF0IEJlbmRpeCBLaW5nIGhhdmUgc3RvcHBl ZCBtYWtpbmcgcGFydHMgZm9yIHRoaXMgcmFkaW8sIGVzcGVjaWFsbHkgdGhlIGRpc3BsYXksIGFu eSBhZHZpY2UgY29uY2VybmluZyBtYWludGVuYW5jZSBvcHRpb25zIG9yIHJlcGxhY2VtZW50cz8g T25lIG9mIG1pbmUgd2FzIHJlaGFiJ2Qgc28gaXQgd29ya3Mgd2VsbCBidXQgdGhlIG90aGVyIGlz IHN0YXJ0aW5nIHRvIG1pc3Mgc2VnbWVudHMuIEhhdmVuJ3QgcHVsbGVkIGl0IHlldCB0byB0cnkg YnVybmlzaGluZyB0aGUgemVicmEgY29udGFjdHMuCj4gCj4gSSBqdXN0IGxvdmUgb2Jzb2xlc2Nl bmNlLgo+IAo+IEppbSBCYWtlcgo+IDQwNSA0MjYgNTM3Nwo+IAo+IAo+IAo+IAoKCl8tPT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cl8t PSAgICAgICAgICAtIFRoZSBBZXJvRWxlY3RyaWMtTGlzdCBFbWFpbCBGb3J1bSAtCl8tPSBVc2Ug dGhlIE1hdHJvbmljcyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UKXy09IHRoZSBt YW55IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sCl8tPSBBcmNo aXZlIFNlYXJjaCAmIERvd25sb2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwKXy09IFBob3Rv c2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZToKXy09Cl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJv bmljcy5jb20vTmF2aWdhdG9yP0Flcm9FbGVjdHJpYy1MaXN0Cl8tPQpfLT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT0gICAgICAg ICAgICAgICAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0KXy09IFNhbWUgZ3JlYXQgY29udGVudCBh bHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhCl8tPQpfLT0gICAtLT4gaHR0cDovL2Zv cnVtcy5tYXRyb25pY3MuY29tCl8tPQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT0gICAgICAgICAgICAgIC0gTkVXIE1BVFJP TklDUyBMSVNUIFdJS0kgLQpfLT0gQWRkIHNvbWUgaW5mbyB0byB0aGUgTWF0cm9uaWNzIEVtYWls IExpc3QgV2lraSEKXy09ICAgLS0+IGh0dHA6Ly93aWtpLm1hdHJvbmljcy5jb20KXy09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KXy09 ICAgICAgICAgICAgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUgLQpfLT0gIFRoYW5rIHlv dSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQpfLT0gICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uCl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJv bmljcy5jb20vY29udHJpYnV0aW9uCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09CgoKCgo ________________________________________________________________________________
Date: Jun 29, 2016
Qm90aCBhcmUgMTJ2IGFuZCBHUy4uLi4uYnV0IG5vdCBwYXJ0aW5nIHRoZW0gYW55dGltZSBzb29u Li4uLi5JJ20gYSBjaGVhcCBiYXN0YXJkLgoKOyApCgpKaW0gQmFrZXIKNDA1LjQyNi41Mzc3Cgot LS0tLU9yaWdpbmFsIE1lc3NhZ2UtLS0tLQpGcm9tOiBBbGVjIE15ZXJzIDxhbGVjQGFsZWNteWVy cy5jb20+ClRvOiBhZXJvZWxlY3RyaWMtbGlzdEBtYXRyb25pY3MuY29tClNlbnQ6IFR1ZSwgMjgg SnVuIDIwMTYgMjI6MzYKU3ViamVjdDogUmU6IEFlcm9FbGVjdHJpYy1MaXN0OiBLWDE1NSBhbHRl cm5hdGl2ZQoKLS0+IEFlcm9FbGVjdHJpYy1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiBBbGVjIE15 ZXJzIDxhbGVjQGFsZWNteWVycy5jb20+CgpJZiBpdCdzIDEydiwgYW5kIGl0IGhhcyBhIGdsaWRl c2xvcGUgcmVjZWl2ZXIsIGFuZCB5b3UgZGVjaWRlIHRvIHBhcnQgaXQgb3V0LCBsZXQgbWUga25v dy4uLgoKT24gSnVuIDI4LCAyMDE2LCBhdCAyMTo1NiwgSmltIEJha2VyIDxqaW1iYWtlckBucGFj Yy5uZXQ+IHdyb3RlOgoKLS0+IEFlcm9FbGVjdHJpYy1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiBK aW0gQmFrZXIgPGppbWJha2VyQG5wYWNjLm5ldD4KCk5vdyB0aGF0IEJlbmRpeCBLaW5nIGhhdmUg c3RvcHBlZCBtYWtpbmcgcGFydHMgZm9yIHRoaXMgcmFkaW8sIGVzcGVjaWFsbHkgdGhlIGRpc3Bs YXksIGFueSBhZHZpY2UgY29uY2VybmluZyBtYWludGVuYW5jZSBvcHRpb25zIG9yIHJlcGxhY2Vt ZW50cz8gT25lIG9mIG1pbmUgd2FzIHJlaGFiJ2Qgc28gaXQgd29ya3Mgd2VsbCBidXQgdGhlIG90 aGVyIGlzIHN0YXJ0aW5nIHRvIG1pc3Mgc2VnbWVudHMuIEhhdmVuJ3QgcHVsbGVkIGl0IHlldCB0 byB0cnkgYnVybmlzaGluZyB0aGUgemVicmEgY29udGFjdHMuCgpJIGp1c3QgbG92ZSBvYnNvbGVz Y2VuY2UuCgpKaW0gQmFrZXIKNDA1IDQyNiA1Mzc3CgoKCgoKCgpfLT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT0gICAgICAgICAg LSBUaGUgQWVyb0VsZWN0cmljLUxpc3QgRW1haWwgRm9ydW0gLQpfLT0gVXNlIHRoZSBNYXRyb25p Y3MgTGlzdCBGZWF0dXJlcyBOYXZpZ2F0b3IgdG8gYnJvd3NlCl8tPSB0aGUgbWFueSBMaXN0IHV0 aWxpdGllcyBzdWNoIGFzIExpc3QgVW4vU3Vic2NyaXB0aW9uLApfLT0gQXJjaGl2ZSBTZWFyY2gg JiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0LCBGQVEsCl8tPSBQaG90b3NoYXJlLCBhbmQg bXVjaCBtdWNoIG1vcmU6Cl8tPQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05h dmlnYXRvcj9BZXJvRWxlY3RyaWMtTGlzdApfLT0KXy09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KXy09ICAgICAgICAgICAgICAgLSBN QVRST05JQ1MgV0VCIEZPUlVNUyAtCl8tPSBTYW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFi bGUgdmlhIHRoZSBXZWIgRm9ydW1zIQpfLT0KXy09ICAgLS0+IGh0dHA6Ly9mb3J1bXMubWF0cm9u aWNzLmNvbQpfLT0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT0KXy09ICAgICAgICAgICAgICAtIE5FVyBNQVRST05JQ1MgTElTVCBX SUtJIC0KXy09IEFkZCBzb21lIGluZm8gdG8gdGhlIE1hdHJvbmljcyBFbWFpbCBMaXN0IFdpa2kh Cl8tPSAgIC0tPiBodHRwOi8vd2lraS5tYXRyb25pY3MuY29tCl8tPT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cl8tPSAgICAgICAgICAg ICAtIExpc3QgQ29udHJpYnV0aW9uIFdlYiBTaXRlIC0KXy09ICBUaGFuayB5b3UgZm9yIHlvdXIg Z2VuZXJvdXMgc3VwcG9ydCEKXy09ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgLU1hdHQg RHJhbGxlLCBMaXN0IEFkbWluLgpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2Nv bnRyaWJ1dGlvbgpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PQoKCgoK ________________________________________________________________________________
Date: Jun 29, 2016
in that case... sometimes you can encourage a missing segment to work again by warm-soaking the unit (i.e. leaving radio in the on state) for an extend ed period of time. On Jun 29, 2016, at 19:27, jimbaker(at)npacc.net wrote: Both are 12v and GS.....but not parting them anytime soon.....I'm a cheap ba stard. ; ) Jim Baker 405.426.5377 -----Original Message----- From: Alec Myers <alec(at)alecmyers.com> Sent: Tue, 28 Jun 2016 22:36 Subject: Re: AeroElectric-List: KX155 alternative If it's 12v, and it has a glideslope receiver, and you decide to part it out , let me know... On Jun 28, 2016, at 21:56, Jim Baker wrote: Now that Bendix King have stopped making parts for this radio, especially th e display, any advice concerning maintenance options or replacements? One of mine was rehab'd so it works well but the other is starting to miss segment s. Haven't pulled it yet to try burnishing the zebra contacts. I just love obsolescence. Jim Baker 405 426 5377 ========================== ======== ========================== ======== ========================== ======== ========================== ======== ========================== ======== ________________________________________________________________________________
Date: Jun 30, 2016
Interesting timing for this thread. Just last Friday my 155 was acting up f or the first time. Some digits will go blank, but the radio woks fine. The i ssue goes away if I turn the radio off then back on again. That happened ab out half a dozen times in about two hour flight. It was hot summer day here in Texas so I thought maybe it was the heat, but reading this post sounds l ike it's a chronicle problem with this radio ? Does this sound like the disp lay is dying or is it the pins cleaning symptoms? Any recommendations for a c ourse of action? Any good repair shop you can recommend that can recondition the radio for a reasonable charge ? Thanks, Saad Sent from my iPad > On Jun 29, 2016, at 6:27 PM, jimbaker(at)npacc.net wrote: > > Both are 12v and GS.....but not parting them anytime soon.....I'm a cheap b astard. > > ; ) > > Jim Baker > 405.426.5377 > > -----Original Message----- > From: Alec Myers <alec(at)alecmyers.com> > To: aeroelectric-list(at)matronics.com > Sent: Tue, 28 Jun 2016 22:36 > Subject: Re: AeroElectric-List: KX155 alternative > > > If it's 12v, and it has a glideslope receiver, and you decide to part it o ut, let me know... > > On Jun 28, 2016, at 21:56, Jim Baker wrote: > > > Now that Bendix King have stopped making parts for this radio, especially t he display, any advice concerning maintenance options or replacements? One o f mine was rehab'd so it works well but the other is starting to miss segmen ts. Haven't pulled it yet to try burnishing the zebra contacts. > > I just love obsolescence. > > Jim Baker > 405 426 5377 > > > > > > > ========================== ========== ========================== ========== ========================== ========== ========================== ========== ========================== ========== > > > > ________________________________________________________________________________
Date: Jun 30, 2016
On a simple aircraft such as my Cessna 172K, the voltage regulator "S" terminal is supplied with power through the battery contactor. If no power is present at the voltage regulator, the alternator field SHOULD not be energized rendering the alternator inoperative. The first noticeable indication after battery voltage bleeds down is that my VHF radio display (KX-155) goes blank. In order to alert me to take necessary steps to conserve battery power after an alternator failure, I installed a "13V Idiot Light" from Perihelion Design, which I highly recommend. Only $50 and legally installed without paperwork using Velcro and powered through cigar lighter. In addition, I added a Westach 6-16 VDC voltmeter to give me a REAL indication instead of the near worthless ammeter. -------- Jerry King Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457550#457550 ________________________________________________________________________________
Date: Jun 30, 2016
Once an engine is running above idle, the battery no longer supplies electrical power to the aircraft. The alternator does. Many alternators will continue to operate if the battery is then disconnected. The electrical current needed to power the alternator field comes from the alternator output, whether the battery is connected or not. There may be some alternators that will not continue to run without a battery connected. Even for alternators that do continue to operate without a battery, the alternator could stop working if a very large electrical load is turned on which causes the system voltage to momentarily drop. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457555#457555 ________________________________________________________________________________
Subject: Re: Bendix King KY97A Tuning Problem
Date: Jun 30, 2016
I am sure you know this already BUT... Before you tear it apart, make sure the problem is not just a loose knob set screw -------- Jerry King Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457561#457561 ________________________________________________________________________________
Date: Jun 30, 2016
At 08:13 AM 6/30/2016, you wrote: > >Once an engine is running above idle, the battery no longer supplies >electrical power to the aircraft. The alternator does. Many >alternators will continue to operate if the battery is then >disconnected. The electrical current needed to power the alternator >field comes from the alternator output, whether the battery is >connected or not. There may be some alternators that will not >continue to run without a battery connected. Even for alternators >that do continue to operate without a battery, the alternator could >stop working if a very large electrical load is turned on which >causes the system voltage to momentarily drop. WWWaaaayyyy back when, it was generally assumed that running the aircraft sans battery was not a good thing to do. Before alternators, generator and battery switches were separate and generators would self-excite. Given that batteries are NOT good filters of power generation noise, it didn't matter if the battery was on-line or not. The earliest alternators on Cessnas (and indeed all other S.E. TC aircraft) were automotive derivatives. I was not privy to any investigative tests at Cessna but the corporate policy was that their airplanes should not be operated sans battery. Hence, the split rocker switch was birthed. Apparently, Beech experience was different. While many if not most of the smaller S.E. aircraft did the same battery-first-then-alternator switching protocol. Re: B-23 Sundowner panel excerpt below . . . Emacs! The Bonanza and Barons were different. The first regulator design I qualified for Beech was about 1978 and their procurement specification stated that no feature of the regulator's circuitry 'shall prevent the alternator from coming up self-excited above xxxx rpm". This was the first time I'd encountered an alternator EXPECTED to come up all by itself. The Bonanza and Barons had totally independent battery and alternator switches. Operation sans battery was not prohibited and in fact the system was designed to allow it. I've got a new electro-mechanical test bench under fabrication and will be doing some work on PM Dynamo rectifier/regulators. The same facility will allow me to explore and quantify the present state of the art in production alternators. In the mean time, as long as you don't hit the alternator with a really BIG load (which few system are capable of doing anyhow), the modern alternator runs self-excited and benefits immeasurably from battery presence with respect to noise. More details to follow. So the answer to the opening question on this thread is: "Loss of the battery contactor in flight will not produce a behavior likely to be noticed in the air." Bob . . . ________________________________________________________________________________
Date: Jun 30, 2016
Thanks for the knowledgeable answer. Once your new test bench is up and running, it would be interesting to verify or disprove this statement quoted from the Rotax 912 Installation Manual, > Never sever connection between terminal C and B of regulator (e.g. by removal of a fuse) while the engine is running. Overvoltage and regulator damage can occur. I find that statement hard to believe. When voltage is removed from Rotax regulator terminal C, its DC output should shut off, not increase. Of course the AC voltage would increase due to lack of load, but not anymore than if all electrical loads were shut off. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457567#457567 ________________________________________________________________________________
Date: Jun 30, 2016
At 04:20 PM 6/30/2016, you wrote: > >Thanks for the knowledgeable answer. Once your new test bench is up >and running, it would be interesting to verify or disprove this >statement quoted from the Rotax 912 Installation Manual, > > > Never sever connection between terminal C and B of regulator > (e.g. by removal of a fuse) while the engine is running. > Overvoltage and regulator damage can occur. If we had a VERIFIED copy of the schematic for the Ducatti R/R, the validity of that statement could be confirmed or debunked. I have seen THIS schematic offered from various sources over the years http://tinyurl.com/zfkte7c A simply analysis of this drawing demonstrates that "C" is both the voltage regulation sense lead -AND- power source for the low-level regulating circuity. Simple analysis of this schematic shows that disconnection of the C terminal causes the R/R to shut down . . . which is consistent with a legacy design philosophy for voltage regulators of all stripe. >I find that statement hard to believe. When voltage is removed from >Rotax regulator terminal C, its DC output should shut off, not >increase. Of course the AC voltage would increase due to lack of >load, but not anymore than if all electrical loads were shut off. This is an enduring problem with anecdotal data gleaned from the catacombs of hangar-lore. Open circuit voltage from the PM dynamo windings may indeed be the voltage referred to by the original assertions. Further, THAT voltage generated by the engine running cruise rpm just might be hazardous to the R/R . . . but without the benefit of original designers documentation, we might as well be discussing Slobovian politics over a pitcher of beer. In the TC world, we write specs, do test plans, carry out experiments in the lab and airplanes on the ground and airborne. Then we write test reports which form the foundation for design decisions or remedial actions to correct a deficiency. Without that report (assuming one was ever produced) the real meaning of the ideas floating around on forums and hangars are at risk for (1) being mis- interpreted and (2) being morphed with the telling and re-telling into an entirely new significance. If the FAA ever extends it's grip deeper into OBAM aviation, a very strong excused is bound to include our poor utilization of computing and communications tools to keep (1) and (2) in check. So I'm with you my friend. I think the assertion about the Rotax R/R is at best an idea that suffered too many re-tellings by individuals with little or no understanding. Bob . . . ________________________________________________________________________________
From: "William Hunter" <billhuntersemail(at)gmail.com>
Subject: Composite Aircraft and Lightning Strikes
Date: Jun 30, 2016
Hi All, There is a discussion brewing on the Velocity Owners Builders Association about composite aircraft and lightning strikes. What sparked (sorry) this discussion was a question about static wicks and if they could be useful on composite aircraft and now there is some good bantering going on about lightning strikes and composite aircraft...so...naturally I thought since there is some really sharp electrical folks on this forum I would ask you all for your feedback on the subject and I will certainly give you credit for your feedback and suggestions (of course I could not try to pass this knowledge off as being my own because that cat is already out of the bag and they would never believe it came from me). Anyhoo...here are some questions (if you think up others please feel free to add): -Would static wicks be beneficial to add to a composite aircraft? -If adding static wicks to a composite airplane, where should they be added? -Should control surfaces be bonded to the aircraft structure if static wicks are used (and even if static wicks are not used)? -Should all of the metal components of the aircraft be bonded together and if so what technique should be employed to do so? -Does anyone know of any lightning strike incidents to composite aircraft and if so what damage to the aircraft structure/components have occurred? -What causes lightning to be attracted to airplanes and/or why does lightning hit airplanes (yes, I can understand why lightning hits trees/buildings/other items that are connected to earth but an airplane is not connected to earth...if it had just taken off I could see the static in the wake leading to ground however an airplane in cruise flight is another story)? -Are composite aircraft more or less likely to be hit by lightning than metal airplanes? -Are there any techniques or design considerations that would mitigate the chance of lightning strikes on the composite aircraft and/or the damage being done should the aircraft be hit? -On production composite aircraft, what if any equipment/design considerations have been required by the FAA to be employed in reducing the chances of and/or in mitigating the effect of a lightning strike? -Some guys are discussing using Carbon Fiber or mesh being installed under the surfaces of the airplane to transfer the energy of a lightning strike so if a mesh of some sort is indeed used, will it help or hurt in reducing the chances of and/or in mitigating the effect of a lightning strike (if the mesh is not robust enough to conduct the extreme electrical current by a lightning strike could it make the problem worse (as a lightning rod on a house has a too small conductor then the lightning rod attracts the lightning and then once the lightning does actually hit the rod the conductor to ground melts and now the house structure becomes the conduit to ground)? Please dream up other thoughts in the area of lightning strikes and I will certainly forward them on. We appreciate your help in making the design of the Velocity aircraft more safe during this time of year!!! .. Cheers!!! Bill Hunter ________________________________________________________________________________
Date: Jun 30, 2016
On 6/30/2016 4:20 PM, user9253 wrote: > > Thanks for the knowledgeable answer. Once your new test bench is up and running, it would be interesting to verify or disprove this statement quoted from the Rotax 912 Installation Manual, > >> Never sever connection between terminal C and B of regulator (e.g. by removal of a fuse) while the engine is running. Overvoltage and regulator damage can occur. > I find that statement hard to believe. When voltage is removed from Rotax regulator terminal C, its DC output should shut off, not increase. Of course the AC voltage would increase due to lack of load, but not anymore than if all electrical loads were shut off. > > -------- > Joe Gores > I don't know squat about Rotax stuff or their manual, but... If it's a PM style alternator, and the regulator is a shunt style regulator, and breaking that C-B connection removes the shunt load, then I can see how the regulator might be damaged. If the regulator sensing/control semiconductors are still connected to the alternator output but the shunt *isn't*, then the alternator could well be able to create a high enough voltage to exceed the max voltage ratings of the devices. Having the shunt *in* the circuit would ensure that the voltage never got that high. Charlie ________________________________________________________________________________
Date: Jun 30, 2016
Subject: Re: Composite Aircraft and Lightning Strikes
> >Anyhoo...here are some questions (if you think up others please feel free to >add): > >-Would static wicks be beneficial to add to a composite aircraft? Depends. A 'static wick' is intended to REDUCE coronal resistance between CONDUCTIVE parts of the airframe and the surrounding atmosphere. Without static wicks, electro static potentials in the millions of volts can build up in various places on the airframe. The existance of high levels of static build up can manifest in (1) visible light (St. Elmo's Fire on prop tips, around window frames, sharp trailing edges), (2) radio noise that can totally cripple some systems and sometimes (3) excessive erosion. The purpose of a static wick is to ENCOURAGE dissipation of electro-static energies at LOW levels . . . levels too low to produce the deleterious effects cited. -If adding static wicks to a composite airplane, where should they be added? EXCELLENT question. Figuring out were to put them nn a metal airplane is not a simple task . . . an insulated airplne is whole different ball game. I've seen airplanes perched on insulating jacks and excited with bunches of volts while a technician walks around the outside probing potential leak-off points on the airframe with a very long test probe. This is a good start on figuring out where potentially >-Should control surfaces be bonded to the aircraft structure if static wicks >are used (and even if static wicks are not used)? > >-Should all of the metal components of the aircraft be bonded together and >if so what technique should be employed to do so? Can't think of a single reason to do such things. I think Burt Rutan may have uttered such an opinion WAaaayyyy back when about control surfaces on the Ez series aircraft . . . But I'm at a lost to imagine, much less demonstrate how the action would benefit anything. >-Does anyone know of any lightning strike incidents to composite aircraft >and if so what damage to the aircraft structure/components have occurred? One of our very own suffered just such an event http://tinyurl.com/hre2hkz >-What causes lightning to be attracted to airplanes and/or why does >lightning hit airplanes (yes, I can understand why lightning hits >trees/buildings/other items that are connected to earth but an airplane is >not connected to earth...if it had just taken off I could see the static in >the wake leading to ground however an airplane in cruise flight is another >story)? > >-Are composite aircraft more or less likely to be hit by lightning than >metal airplanes? Intuitively one might think so . . . but the airplane is only a triggering influence in what was going to be a strike whether the airplane was there or not. All images of airplanes being struck show the airplane in the middle of a strike that extends from one area of the storm (usually cloud) to another area or the ground. >-Are there any techniques or design considerations that would mitigate the >chance of lightning strikes on the composite aircraft and/or the damage >being done should the aircraft be hit? Yeah, it's called staying the @#$@ away from areas for which no practical invincability can be demonstrated. This included lightning, ice, high winds, hail, etc. >-On production composite aircraft, what if any equipment/design >considerations have been required by the FAA to be employed in reducing the >chances of and/or in mitigating the effect of a lightning strike? It's exaclty the OPPOSITE. We cannot nor do we attempt to avoid being struck. We must ASSUME we WILL be struck and design for measured and predicted stresses. >-Some guys are discussing using Carbon Fiber or mesh being installed under >the surfaces of the airplane to transfer the energy of a lightning strike so >if a mesh of some sort is indeed used, will it help or hurt in reducing the >chances of and/or in mitigating the effect of a lightning strike (if the >mesh is not robust enough to conduct the extreme electrical current by a >lightning strike could it make the problem worse (as a lightning rod on a >house has a too small conductor then the lightning rod attracts the >lightning and then once the lightning does actually hit the rod the >conductor to ground melts and now the house structure becomes the conduit to >ground)? Check with the Lancair and Glasair forums. These folks would come a close as anyone to knowing what was tried and either succeeded or failed to produce the desired mitigation of effects. There is a wealth of discussion on . . . http://tinyurl.com/zeay3x5 . . . this is NOT a trivial task. >Please dream up other thoughts in the area of lightning strikes and I will >certainly forward them on. > >We appreciate your help in making the design of the Velocity aircraft more >safe during this time of year!!! History is rife with examples of work done to make aircraft resistant to the effects of lightning strike. Lancair, Glassair and contemporaries wrestled with it. At Beech, we stayed with metal wings but the fuselage structures have large, flat conductive straps that run longitudinaly7 in the fuselage. These 'fixes' are tested in direct effects of lightning laboratories to show that people, structure and systems within the airplane remain intact after events that are ASSUMED WILL HAPPEN. The simple answer to the question is: "Yes, you CAN do things to airplanes of any stripe to reduce risk due to lightning strike . . . but it's not a simple task. A task deeply intertwined with issues of structural integrity, weight, aerodynamics . . . and cost. In flight school, we were well advised to stay away from ice and convective activity. Risks to body and airframe go up exponentially . . . while costs for mitigation of those risks are breathtaking. Adding any feature intended to mitigate environmental risk brings some human factor's issues with it. More that one pilot with boots, prop-deice and a windshield heater patch was willing to 'press on just a little further' . . . with more than simply disappointing outcome. The same effect could beset a pilot flying an airplane with lightning mitigation enhancements . . . enhancements that did not benefit from a through checkout in the lightning lab by folks who have been there, done that. Bob . . . ________________________________________________________________________________
Date: Jun 30, 2016
>If it's a PM style alternator, and the regulator is a shunt style >regulator, and breaking that C-B connection removes the shunt load, >then I can see how the regulator might be damaged. If the regulator >sensing/control semiconductors are still connected to the alternator >output but the shunt *isn't*, then the alternator could well be able >to create a high enough voltage to exceed the max voltage ratings of >the devices. Nobody has built a shunt style regulator in a very long time. A few small systems on motor bikes and snowmobiles popularized the simple design but the B&C regulators have never been shunt . . . the alleged schematic of the Ducatti R/R is also a series regulator. They are manufactured as a spares item but better regulators are so easy to design, there's no reason to stay with shunt style. >Having the shunt *in* the circuit would ensure that the voltage >never got that high. but it WOULD drive internal energy dissipation to the max and, give the demonstrably poor thermal management of many designs, could toast the device. But I'm pretty sure nobody builds/offers that control philosophy to on the product we're using. Bob . . . ________________________________________________________________________________
Date: Jun 30, 2016
The Rotax (Ducati) rectifier/regulator is a switching-power-supply type of regulator that turns on for part of the dynamo AC cycle. There is no shunt. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457572#457572 ________________________________________________________________________________
Date: Jun 30, 2016
Date: Jul 01, 2016
Before getting really wound up about lightning protection first understand the risk and then figure the mitigation. Look at the accident statistics- how many light aircraft have been struck by lightning and not survived? The answer is very, very few - in the US and in Europe. For whatever reason. Thunderstorms kill many people but lightning does not. My conclusion is that airframe lightning protection is not worthwhile. Thunderstorm protection is difficult so I avoid them. Peter On 1 Jul 2016 04:50, "William Hunter" wrote: > billhuntersemail(at)gmail.com> > > Hi All, > > There is a discussion brewing on the Velocity Owners Builders Association > about composite aircraft and lightning strikes. > > What sparked (sorry) this discussion was a question about static wicks and > if they could be useful on composite aircraft and now there is some good > bantering going on about lightning strikes and composite > aircraft...so...naturally I thought since there is some really sharp > electrical folks on this forum I would ask you all for your feedback on the > subject and I will certainly give you credit for your feedback and > suggestions (of course I could not try to pass this knowledge off as being > my own because that cat is already out of the bag and they would never > believe it came from me). > > Anyhoo...here are some questions (if you think up others please feel free > to > add): > > -Would static wicks be beneficial to add to a composite aircraft? > > -If adding static wicks to a composite airplane, where should they be > added? > > -Should control surfaces be bonded to the aircraft structure if static > wicks > are used (and even if static wicks are not used)? > > -Should all of the metal components of the aircraft be bonded together and > if so what technique should be employed to do so? > > -Does anyone know of any lightning strike incidents to composite aircraft > and if so what damage to the aircraft structure/components have occurred? > > -What causes lightning to be attracted to airplanes and/or why does > lightning hit airplanes (yes, I can understand why lightning hits > trees/buildings/other items that are connected to earth but an airplane is > not connected to earth...if it had just taken off I could see the static in > the wake leading to ground however an airplane in cruise flight is another > story)? > > -Are composite aircraft more or less likely to be hit by lightning than > metal airplanes? > > -Are there any techniques or design considerations that would mitigate the > chance of lightning strikes on the composite aircraft and/or the damage > being done should the aircraft be hit? > > -On production composite aircraft, what if any equipment/design > considerations have been required by the FAA to be employed in reducing the > chances of and/or in mitigating the effect of a lightning strike? > > -Some guys are discussing using Carbon Fiber or mesh being installed under > the surfaces of the airplane to transfer the energy of a lightning strike > so > if a mesh of some sort is indeed used, will it help or hurt in reducing the > chances of and/or in mitigating the effect of a lightning strike (if the > mesh is not robust enough to conduct the extreme electrical current by a > lightning strike could it make the problem worse (as a lightning rod on a > house has a too small conductor then the lightning rod attracts the > lightning and then once the lightning does actually hit the rod the > conductor to ground melts and now the house structure becomes the conduit > to > ground)? > > Please dream up other thoughts in the area of lightning strikes and I will > certainly forward them on. > > We appreciate your help in making the design of the Velocity aircraft more > safe during this time of year!!! > > .. > > Cheers!!! > > Bill Hunter > > ________________________________________________________________________________
Date: Jul 01, 2016
There is a very narrative report from a glider in the UK, which was hit by lightning and disintegrated, in the same report a helicopter with carbon fiber blades is described as well. http://www.pas.rochester.edu/~cline/ASK%20lightning%20strike/ASK%20accident%20report.htm For my feeling stay away from possible lightning ;) Cheers Werner On 01.07.2016 01:37, William Hunter wrote: > > Hi All, > > There is a discussion brewing on the Velocity Owners Builders Association > about composite aircraft and lightning strikes. > > ........ > > -Does anyone know of any lightning strike incidents to composite aircraft > and if so what damage to the aircraft structure/components have occurred? > > - ________________________________________________________________________________
Date: Jul 01, 2016
Read the AAIB report, aircraft was in good VMC. The energy of the strike meant that no protection would have made any difference. The control rods melted - nothing much could be done about that... On 1 Jul 2016 8:30 a.m., "Werner Schneider" wrote: > > > > There is a very narrative report from a glider in the UK, which was hit by > lightning and disintegrated, in the same report a helicopter with carbon > fiber blades is described as well. > > > http://www.pas.rochester.edu/~cline/ASK%20lightning%20strike/ASK%20accident%20report.htm > > For my feeling stay away from possible lightning ;) > > Cheers Werner > > > On 01.07.2016 01:37, William Hunter wrote: > >> billhuntersemail(at)gmail.com> >> >> Hi All, >> >> There is a discussion brewing on the Velocity Owners Builders Association >> about composite aircraft and lightning strikes. >> >> ........ >> >> -Does anyone know of any lightning strike incidents to composite aircraft >> and if so what damage to the aircraft structure/components have occurred? >> >> - >> > > ________________________________________________________________________________
Date: Jul 01, 2016
I did check the knob and it is securely on the shaft, but thanks for the reminder. When one turns the knob, there is a distinctive aural and tactical click. Sometimes the display updates and sometimes it doesn't. The display always indicates the true frequency, so this may be a mechanical issue. I've moved the knob enough that I'm confident it is not a dirty wiper. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457582#457582 ________________________________________________________________________________
Date: Jul 01, 2016
I searched for a KY97A Maintenance / Overhaul manual (not install manual) availability on the web that might help you out. I found this manual preview for KY 96/97 that enables you to view all pages (scroll down to view each page) and also has a magnifier to view detail. This requires some WORK, but the entire manual appears to be viewable along with parts list. http://www.manualslib.com/manual/835245/Bendixking-Ky-96a.html? -------- Jerry King Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457583#457583 ________________________________________________________________________________
Date: Jul 01, 2016
No argument on those points, but if the contents of the document are artifacts from 'the bad old days'..... On Thu, Jun 30, 2016 at 9:11 PM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > If it's a PM style alternator, and the regulator is a shunt style > regulator, and breaking that C-B connection removes the shunt load, then I > can see how the regulator might be damaged. If the regulator > sensing/control semiconductors are still connected to the alternator output > but the shunt *isn't*, then the alternator could well be able to create a > high enough voltage to exceed the max voltage ratings of the devices. > > > Nobody has built a shunt style regulator in > a very long time. A few small systems on motor > bikes and snowmobiles popularized the simple > design but the B&C regulators have never been > shunt . . . the alleged schematic of the Ducatti > R/R is also a series regulator. > > They are manufactured as a spares item but better > regulators are so easy to design, there's no reason > to stay with shunt style. > > Having the shunt *in* the circuit would ensure that the voltage never got > that high. > > > but it WOULD drive internal energy dissipation > to the max and, give the demonstrably poor > thermal management of many designs, could > toast the device. But I'm pretty sure > nobody builds/offers that control philosophy to > on the product we're using. > > > Bob . . . > ________________________________________________________________________________
Date: Jul 01, 2016
On 6/30/2016 9:04 PM, Robert L. Nuckolls, III wrote: > the problem worse (as a lightning rod on a > > >> -Are there any techniques or design considerations that would >> mitigate the >> chance of lightning strikes on the composite aircraft and/or the damage >> being done should the aircraft be hit? > > Yeah, it's called staying the @#$@ away from > areas for which no practical invincability can > be demonstrated. This included lightning, ice, > high winds, hail, etc. > > > Bob . . . > ROTFLMAO ________________________________________________________________________________
Date: Jul 01, 2016
On Fri, Jul 1, 2016 at 6:27 AM, jnmeade wrote: > > > > I did check the knob and it is securely on the shaft, but thanks for the > reminder. When one turns the knob, there is a distinctive aural and > tactical click. Sometimes the display updates and sometimes it doesn't. > The display always indicates the true frequency, so this may be a > mechanical issue. I've moved the knob enough that I'm confident it is not > a dirty wiper. > > As someone who was an electronics tech back in another life (in the epoch when that radio was probably designed), I can tell you that you might be over-confident. :-) Some corrosion issues on switch contacts or controls just cannot be wiped away by switch action. Or even contact cleaner, in some cases. ________________________________________________________________________________
Date: Jul 01, 2016
At 01:35 AM 7/1/2016, you wrote: >Before getting really wound up about lightning protection first >understand the risk and then figure the mitigation. Look at the >accident statistics- how many light aircraft have been struck by >lightning and not survived? The answer is very, very few - in the US >and in Europe. For whatever reason. Thunderstorms kill many people >but lightning does not. My conclusion is that airframe lightning >protection is not worthwhile. Thunderstorm protection is difficult >so I avoid them. Excellent point . . . Similarly, few engines stop cold because of mechanical or electrical failure. The majority of 'engine trouble' on airplanes is fuel exhaustion. The moral of the story is that the pilot is the weakest link in the chain of risk for operating an airplane. Static wicks (also a topic of this thread) are another matter. They go to a more mundane issue . . . radio noise and miscellaneous damage to systems. The windshields in many high performance airplanes are vulnerable to the high voltage discharge often observed around the edges of a window frame. When that window is fitted with embedded heater wires, replacement can be VERY expensive. I thing the price tag on a GP180 window was around $20K in 1980 dollars. There have been many experiments with aircraft finishes and shapes conducted to understand how static electricity can be better managed on high performance aircraft. Not all static wicks are the same. Walk around the ramp and check out the variations you'll find. I recall John Cooper, head cheese of our EMC lab building a fixture to survey static wick performance. Various samples being tested might vary as much as 3:1 with respect to their 'conductivity'. Once you identify a 'good' wick design, then finding the 'right' place to install them was another grand experiment. And this was on all metal aircraft. Airplanes of glass and plastic are another matter. Imagine how you might modify a glass rod (used to demonstrate static electricity phenomenon in physics class) to dampen if not eliminate it's ability to stand up the hairs on your cat. Further, your successful technique cannot materially change structural characteristics, it must be durable, and it cannot add too much cost. If anyone discovers some literature describing successful application of static wicks to plastic/glass/carbon aircraft . . . I'd REALLY like to read it. Bob . . . ________________________________________________________________________________
Date: Jul 01, 2016
[quote="nuckolls.bob(at)aeroelect"]At 08:13 AM 6/30/2016, you wrote: > > In the mean time, as long > as you don't hit the alternator with a really BIG load > (which few system are capable of doing anyhow), the > modern alternator runs self-excited and benefits immeasurably > from battery presence with respect to noise. Just to clarify, did you really mean "benefits immeasurably"? I think maybe the opposite. Immeasurable: Too large, extensive or extreme to measure. regards, Erich Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457589#457589 ________________________________________________________________________________
Date: Jul 01, 2016
From: William Hunter <billhuntersemail(at)gmail.com>
Hi All, THANK YOU FOR YOUR HELP!!! Very good information and I will be passing the information on to the VOBA Forum. Bill Hunter +1 408-464-1902 On Jul 1, 2016 7:14 AM, "Robert L. Nuckolls, III" < nuckolls.bob(at)aeroelectric.com> wrote: > At 01:35 AM 7/1/2016, you wrote: > > Before getting really wound up about lightning protection first understand > the risk and then figure the mitigation. Look at the accident statistics- > how many light aircraft have been struck by lightning and not survived? The > answer is very, very few - in the US and in Europe. For whatever reason. > Thunderstorms kill many people but lightning does not. My conclusion is > that airframe lightning protection is not worthwhile. Thunderstorm > protection is difficult so I avoid them. > > > Excellent point . . . Similarly, few engines > stop cold because of mechanical or electrical > failure. The majority of 'engine trouble' on > airplanes is fuel exhaustion. The moral of the > story is that the pilot is the weakest link in > the chain of risk for operating an airplane. > > Static wicks (also a topic of this thread) > are another matter. They go to a more mundane > issue . . . radio noise and miscellaneous damage > to systems. > > The windshields in many high performance airplanes > are vulnerable to the high voltage discharge > often observed around the edges of a window > frame. When that window is fitted with embedded > heater wires, replacement can be VERY expensive. > I thing the price tag on a GP180 window was around > $20K in 1980 dollars. > > There have been many experiments with aircraft > finishes and shapes conducted to understand how > static electricity can be better managed on > high performance aircraft. > > Not all static wicks are the same. Walk around > the ramp and check out the variations you'll find. > I recall John Cooper, head cheese of our EMC lab > building a fixture to survey static wick performance. > Various samples being tested might vary as much as > 3:1 with respect to their 'conductivity'. > > Once you identify a 'good' wick design, then finding > the 'right' place to install them was another > grand experiment. And this was on all metal > aircraft. Airplanes of glass and plastic are > another matter. Imagine how you might modify > a glass rod (used to demonstrate static electricity > phenomenon in physics class) to dampen if not > eliminate it's ability to stand up the hairs > on your cat. > > Further, your successful technique cannot materially > change structural characteristics, it must be > durable, and it cannot add too much cost. > > If anyone discovers some literature > describing successful application of static wicks > to plastic/glass/carbon aircraft . . . I'd REALLY > like to read it. > > > Bob . . . > ________________________________________________________________________________
Date: Jul 01, 2016
"Benefits immeasurably" can be interpreted two ways: Benefits are so small that they can not be measured. Benefits are so greats that no scale exists to measure them. Judging by his ending statement, I assume that he meant the benefits are very small. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457594#457594 ________________________________________________________________________________
Subject: Re: New smartphone app for pilots
Date: Jul 01, 2016
Hi All, Just a very quick note to let you know that the revised version of avAltimeter is now available from the Apple App Store. The new revision allows QNH entry in millibars and Altitude reading in Feet Also, I caught and squashed a nasty little bug which might have caused crashing. Cheers -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457596#457596 ________________________________________________________________________________
Date: Jul 01, 2016
Ira, Just updated. Nice app, easy to use and it provides useful information. Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop (75 hrs). Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com > On Jul 1, 2016, at 12:56 PM, rampil wrote: > > > Hi All, > > Just a very quick note to let you know that the revised version of avAltimeter > is now available from the Apple App Store. > > The new revision allows QNH entry in millibars and Altitude reading in Feet > > Also, I caught and squashed a nasty little bug which might have caused crashing. > > Cheers > > -------- > Ira N224XS ________________________________________________________________________________
Date: Jul 01, 2016
Strange: can't find it --- Sent from my iPad ----x--O--x---- > On 1 Jul 2016, at 07:28 pm, Robert Borger wrote: > > Ira, > > Just updated. Nice app, easy to use and it provides useful information. > > Blue skies & tailwinds, > Bob Borger > Europa XS Tri, Rotax 914, Airmaster C/S Prop (75 hrs). > Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP > 3705 Lynchburg Dr. > Corinth, TX 76208-5331 > Cel: 817-992-1117 > rlborger(at)mac.com > >> On Jul 1, 2016, at 12:56 PM, rampil wrote: >> >> >> Hi All, >> >> Just a very quick note to let you know that the revised version of avAlti meter >> is now available from the Apple App Store. >> >> The new revision allows QNH entry in millibars and Altitude reading in Fe et >> >> Also, I caught and squashed a nasty little bug which might have caused cr ashing. >> >> Cheers >> >> -------- >> Ira N224XS ========================== ========================== ========================== -========================= ========================== -========================= ========================== ========================== ==================== ________________________________________________________________________________
Date: Jul 01, 2016
Hi John! If you searched for it via your iPad, it probably will not be visible. None of the iPads extent to this point have the Baro chip, so I selected iPhone only. The app actually runs on an iPad or older iPhone, but when it fails to detect the Bosch chip, it sets a pressure of zero. Not much I can do about it, sorry. If you were searching from your phone, it is conceivable that the latest version 1.0.4 did not make it to Apple's Server farms across the pond yet. Please let me know if you still have issues. Ira -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457606#457606 ________________________________________________________________________________
Date: Jul 01, 2016
Right, and many believe that a battery DOES provide great benefit with respect to buffering electrical noise, so thought it would be important to clarify That Bob does not believe that to be the case. Thanks E Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457616#457616 ________________________________________________________________________________
Date: Jul 02, 2016
At 10:48 AM 7/1/2016, you wrote: > > >[quote="nuckolls.bob(at)aeroelect"]At 08:13 AM 6/30/2016, you wrote: > > > > > In the mean time, as long > > as you don't hit the alternator with a really BIG load > > (which few system are capable of doing anyhow), the > > modern alternator runs self-excited and benefits immeasurably > > from battery presence with respect to noise. > > >Just to clarify, did you really mean "benefits immeasurably"? I >think maybe the opposite. > >Immeasurable: Too large, extensive or extreme to measure. I've been thinking that word described an unquantifiable entity; impossible to express in terms of quantity for any reason. In fact, I've learned that it refers not to generally unknowable numbers but only to nebulously large numbers. I can go to bed tonight knowing something I did not know this morning . . . it's a good day. Thanks for the heads-up! Bob . . . ________________________________________________________________________________
Date: Jul 02, 2016
At 04:53 PM 7/1/2016, you wrote: > > >Right, and many believe that a battery DOES provide great benefit >with respect to buffering electrical noise, so thought it would be >important to clarify That Bob does not believe that to be the case. It's easily demonstrated. I've made numerous measurements on vehicles and on the bench that show how the fully charged battery becomes chemically 'disconnected' from its charging source. I.e. its influence on minor wiggles (noise) is diminished to insignificance. Yes, during alternator runaway the battery becomes the major 'load' that prevents an predictable rise in bus voltage to 100 volts or more. An during high-inrush events, the alternator's momentary overload or slow dynamics in voltage regulation will also be mitigated by the battery's ability to dump energy back into the system during the transient. But for the itty-bitty wiggles we call noise . . . excursions in hundreds of millivolts over a broad range of frequencies, the battery offers no significant 'filtering' of these events. The new test bench taking shape in my shop is fitted with a large bonding surface (copper clad top), lots of 120 vac outlets, and a 2hp variable speed drive. The bench is a shrine to Lord Kelvin. We will endeavor to discover all the operating characteristics of various components down to every measurable detail with particular emphasis regulation stability and efficiency. I'll repeat the experiments that speak to the battery's filtering qualities. The cool thing is that we can document and publish significant findings. Bob . . . ________________________________________________________________________________
Subject: Switch wiring
Date: Jul 02, 2016
Guys This switch is model LT-2561-601-012 from Carling Technologies, which is a DPDT switch w ith illuminated lever tip. I know that the 2 sets of 3 contacts on each side are the DPDT contacts, so n o doubt about their wiring. Now about the other 2 middle contacts, which are for the tip illumination, h ow are they wired? Thanks Carlos ________________________________________________________________________________
Date: Jul 02, 2016
Guys The switch in the attached images is model LT-2561-601-012 from Carling Technologies, which is a DPDT switch with illuminated lever tip. I know that the 2 sets of contacts on each side are the DPDT contacts, so n o doubt about their wiring. Now about the other 2 middle contacts, which are for the LED tip illumination, how are they wired? Thanks Carlos --- Este e-mail foi verificado em termos de v=C3=ADrus pelo software antiv=C3 =ADrus Avast. https://www.avast.com/antivirus ________________________________________________________________________________
Subject: Re: Switch wiring
Date: Jul 02, 2016
Carlos there are some pictures on google for boats: https://www.fpmarine.com/Articles.asp?ID=245 On 02.07.2016 16:46, Carlos Trigo wrote: > > is model LT-2561-601-012 from Carling Technologies, which is a DPDT switch with illuminated lever tip. > ________________________________________________________________________________
Date: Jul 02, 2016
Carlos, The Carling datasheet for this switch... http://www.mouser.com/ds/2/65/LT-Series_Details___COS-275734.pdf ...is curiously silent on terminal connections. I can only conceive of one way to connect it: as you said, the terminals down each side are the switch contacts, with the center terminal common in each circuit. +12V is connected to the common terminals and switched to the terminals on the corners. My guess is that +12V is also switched to the lamp internally, and the upper and lower middle terminals would be connected to ground for illumination in each toggle position. You would only ground the side you want to light up, or both if you want illumination in both ON positions. This would allow you to control the switch illumination by grounding it through another switch elsewhere; say, a limit switch. If the switch were used to control flaps, for example, the toggle would be lit while flaps are moving, and extinguish when they reach the limit switch, breaking the bulb's ground path. You may find that the lamp operates from only one of the +12V common terminals but not the other, or that each toggle position illuminates from a different common terminal. This would be done to maintain separation between the two SPDT circuits that make up the DPDT switch. A quick bench test would confirm or refute my hypothesis. If you don't have a bench power supply handy, a 9V battery should suffice to light the toggle's bulb. Or even an ohmmeter set to test continuity should work through an incandescent bulb. Eric > On Jul 2, 2016, at 7:46 AM, Carlos Trigo wrote: > Guys > > This switch > > > > > is model LT-2561-601-012 from Carling Technologies, which is a DPDT switch with illuminated lever tip. > > I know that the 2 sets of 3 contacts on each side are the DPDT contacts, so no doubt about their wiring. Now about the other 2 middle contacts, which are for the tip illumination, how are they wired? > > Thanks > Carlos ________________________________________________________________________________
Date: Jul 02, 2016
You could try emailing team2(at)carlingtech.com for advice. The two extra terminals could power the lamp independent of the switch mechanism. Then it would be up to the installer to add jumper wires. The spec sheet says, Independent lamp is Standard, dependent lamp is available. Other than having an internal lamp, the switch could operate exactly like any other DPDT switch. For switching higher voltages, a separate 12 volt supply would be needed for the lamp. The lamp might be located in a fixed position and shines through fiber optics in the actuator lever. This is all guessing on my part. I like Eric's ohmmeter or 9 volt battery suggestion. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457650#457650 ________________________________________________________________________________
Date: Jul 02, 2016
At 10:34 AM 7/2/2016, you wrote: >Guys > >The switch in the attached images is model LT-2561-601-012 from Carling >Technologies, which is a DPDT switch with illuminated lever tip. >I know that the 2 sets of contacts on each side are the DPDT contacts, so no >doubt about their wiring. >Now about the other 2 middle contacts, which are for the LED tip >illumination, how are they wired? Here's the carling data sheet on that series of switches. http://tinyurl.com/jda6zop Looking at an exerpt we see Emacs! Your LT2561 is two pole, three position on-off-on with .25" quick connects, satin chrome handle, red display in all three positions and a 12 volt incandescent lamp (so you don't have to worry about polarity). Bob . . . ________________________________________________________________________________
Date: Jul 02, 2016
Subject: z-13/8 questions
Regarding drawing Z-13/8 ... 1. Why is there a 30 amp inline fuse on the 14 gauge wire coming from the 8 amp dynamo? 2. Why doesn't the 4AWG cable connect to the battery side of the battery contactor? Thanks, Ken Ryan ________________________________________________________________________________
Subject: Re: Z-13/8 Questions
Date: Jul 02, 2016
If the over-voltage module shorts out, it is desired that the 2 amp circuit breaker trip before the fuse blows. A larger size fuse will take longer to blow. There is a 4 awg wire connected to the battery side of the battery contactor. I do not understand the question. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457664#457664 ________________________________________________________________________________
Date: Jul 02, 2016
Thanks Joe. I was thinking 30 amps was too high for 14 gauge but I now see that it's not. The other question is why not run the big cable to the starter from the battery side of the contactor? That way the engine could be started in the event of battery contactor failure. Is it because cutting current to that wire when the contactor is turned off is considered more important than being able to start the engine if the contactor fails? That would make sense I guess for forced landings, etc. But not for getting maximum voltage to the starter. The reason I ask is because the Rotax 914 installation manual shows the starter wire going to the battery side of the battery contactor. And it does seem like it would make sense to maximize voltage getting to the starter. On Sat, Jul 2, 2016 at 6:14 PM, user9253 wrote: > > If the over-voltage module shorts out, it is desired that the 2 amp > circuit breaker trip before the fuse blows. A larger size fuse will take > longer to blow. > > There is a 4 awg wire connected to the battery side of the battery > contactor. I do not understand the question. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=457664#457664 > > ________________________________________________________________________________
Subject: Non-Working Radio Help Needed
Date: Jul 02, 2016
Hi All, Can you all please help a cyber friend with a second King radio that is no longer working. It was working fine and now all of a sudden it is no longer working. He has two radios however they are not identical radios so he cannot swap them to see if the problem follows. Here is his latest report: ---------------------------COPY----------------------- I tried a few things and here are what I found. The antenna is confirmed to be working. The radio doesn't work on either receiving or transmitting. However, when I pushed the push-to-talk, the 'T' on the radio display did show up so it tried to transmit. When I used a handheld to detect the transmission, the handheld didn't receive anything when the radio tried to transmit. (The same handheld can be heard when I switched to the working radio. Besides the handheld's indicator light turned to green when the working radio was transmitting.) In the headset, I can hear "static noise" from the radio when the volume was turned up. When I pulled the volume button out for "pull to test", the static noise is loud. I removed the radio from the panel. The connectors looked clean but I cleaned the connectors using rubbing alcohol anyway which didn't help. The model is Bendix/King KX-155 (P/N 069-1024-42). What else I can try? .. Cheers!!! Bill Hunter ________________________________________________________________________________
Date: Jul 03, 2016
Well, I had to ask exactly because the Carling documents don't have any info rmation about the contacts, not even a wiring schematic, as it is usual. Thanks Werner, Eric and Bob; Now I know that the middle contacts are very si mply the 2 lamp contacts. Nice! It is already wired... Carlos Enviado do meu iPhone No dia 02/07/2016, =C3-s 20:57, Robert L. Nuckolls, III <nuckolls.bob@aero electric.com> escreveu: > At 10:34 AM 7/2/2016, you wrote: >> Guys >> >> The switch in the attached images is model LT-2561-601-012 from Carling >> Technologies, which is a DPDT switch with illuminated lever tip. >> I know that the 2 sets of contacts on each side are the DPDT contacts, so no >> doubt about their wiring. >> Now about the other 2 middle contacts, which are for the LED tip >> illumination, how are they wired? > > Here's the carling data sheet on that series > of switches. > > http://tinyurl.com/jda6zop > > Looking at an exerpt we see > > > > Your LT2561 is two pole, three position on-off-on > with .25" quick connects, satin chrome handle, > red display in all three positions and a 12 volt > incandescent lamp (so you don't have to worry about > polarity). > > > > > Bob . . . ________________________________________________________________________________
Subject: Re: Non-Working Radio Help Needed
Date: Jul 03, 2016
It sure sounds like an antenna problem. If the antenna has been confirmed good, maybe the problem is the interface between the antenna and radio. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457670#457670 ________________________________________________________________________________
Date: Jul 03, 2016
A 30 amp fuse is normally too high for protecting a #14 wire. There are two purposes for circuit protection, overload and short circuits. Since a PM dynamo is self current limiting, overload protection does not need to the provided. But short circuit protection does. The battery and the rest of the electrical system needs to be protected against the PM dynamo circuit shorting out. A 30 amp fuse will definitely blow when a 14 awg wire shorts out. The event will happen so quickly that the tefzel insulation will not get hot enough to be damaged. B and C provides a schematic that is wired as you suggested. In fact, there is no battery contactor at all. http://www.bandc.aero/pdfs/420-506_REVB.pdf Most aircraft are wired with the battery contactor and starter contactor in series. One advantage is being able to shut off the battery contactor if the starter contactor gets stuck closed. I understand Rotax's reasoning. There is more than one way to wire an airplane. Like other design considerations, compromises need to be made. The advantage of one feature causes a disadvantage someplace else. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457672#457672 ________________________________________________________________________________
Date: Jul 03, 2016
Thanks Joe, especially for the explanation regarding overload and short circuit. I never clearly understood that before. Here's another question: With the Rotax the rotary keyed ignition switch is not allowed. Independent toggles for the ignitions are clearly specified. Given that, what would be the options for inserting a keyed switch to prevent unauthorized starting? The only thing I have come up with is to put it in series with the battery contactor (given that the starter cable is connected to the output side of that contactor). If I moved the starter cable to the battery side of the contactor, where might I use a keyed switch? Ken On Sun, Jul 3, 2016 at 4:38 AM, user9253 wrote: > > A 30 amp fuse is normally too high for protecting a #14 wire. There are > two purposes for circuit protection, overload and short circuits. Since a > PM dynamo is self current limiting, overload protection does not need to > the provided. But short circuit protection does. The battery and the rest > of the electrical system needs to be protected against the PM dynamo > circuit shorting out. A 30 amp fuse will definitely blow when a 14 awg > wire shorts out. The event will happen so quickly that the tefzel > insulation will not get hot enough to be damaged. > B and C provides a schematic that is wired as you suggested. In fact, > there is no battery contactor at all. > http://www.bandc.aero/pdfs/420-506_REVB.pdf > Most aircraft are wired with the battery contactor and starter contactor > in series. One advantage is being able to shut off the battery contactor > if the starter contactor gets stuck closed. I understand Rotax's > reasoning. There is more than one way to wire an airplane. Like other > design considerations, compromises need to be made. The advantage of one > feature causes a disadvantage someplace else. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=457672#457672 > > ________________________________________________________________________________
Date: Jul 03, 2016
Ken, assuming that you are installing a starter contactor, how about wiring it as shown in Z13/8? Battery, Battery Contactor, Starter Contactor, Starter Replace the push button switch in Z13/8 with a momentary key switch like Mouser part number 611-Y208122A203NQ Ignore the Mouser Switch Function description. The C&K data sheet shows that the DPDT that can be wired to function as desired. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457674#457674 ________________________________________________________________________________
Date: Jul 03, 2016
If your starter contactor does not have an internal diode, install an exterior one with the arrow pointing towards positive. The banded end of a diode is the end of the diode that the arrow points towards. A diode will protect the start switch from arcing. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457676#457676 ________________________________________________________________________________
Date: Jul 03, 2016
/Le 03/07/2016 17:17, Ken Ryan a crit : / > / > / > /With the Rotax the rotary keyed ignition switch is not allowed. > Independent toggles for the ignitions are clearly specified. > / Hi Ken and all, Didn't know about that. Maybe it concerns the latest engines. Or maybe it is in the new installation documents, but as Rotax didn't change the engines already flying, I would not lose sleep on the keyswitch vs separate switches problem. Hundreds of airplanes have been flying for years with a standard ignition keyswitch for their Rotax without the slightest issue. I'd even state that the Rotax circuit wiring suggestions are to be taken with a grain of salt, especially concerning the 914. -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Date: Jul 03, 2016
Thanks Joe, good idea. On Sun, Jul 3, 2016 at 8:20 AM, user9253 wrote: > > Ken, assuming that you are installing a starter contactor, how about > wiring it as shown in Z13/8? > Battery, Battery Contactor, Starter Contactor, Starter > Replace the push button switch in Z13/8 with a momentary key switch like > Mouser part number 611-Y208122A203NQ > Ignore the Mouser Switch Function description. The C&K data sheet shows > that the DPDT that can be wired to function as desired. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=457674#457674 > > ________________________________________________________________________________
Date: Jul 03, 2016
Thanks Gilles. As I tend to be biased towards the manufacturer when it comes to guidance, I am referring heavily to the Rotax 914 installation instructions. Can you tell me specifically which areas that you feel are suspect? If you could do that it would help me to evaluate their "suggestions" against my installation. On Sun, Jul 3, 2016 at 10:53 AM, GTH wrote: > > *Le 03/07/2016 =C3- 17:17, Ken Ryan a =C3=A9crit : * > > > *With the Rotax the rotary keyed ignition switch is not allowed. > Independent toggles for the ignitions are clearly specified. * > > > Hi Ken and all, > > Didn't know about that. > Maybe it concerns the latest engines. Or maybe it is in the new > installation documents, but as Rotax didn't change the engines already > flying, I would not lose sleep on the keyswitch vs separate switches > problem. > Hundreds of airplanes have been flying for years with a standard ignition > keyswitch for their Rotax without the slightest issue. > I'd even state that the Rotax circuit wiring suggestions are to be taken > with a grain of salt, especially concerning the 914. > > > -- > Best regards, > Gilles > http://contrails.free.fr > http://lapierre.skunkworks.free.fr > ________________________________________________________________________________
Date: Jul 03, 2016
I agree with Gilles. What difference does it make if both ignition switches and start switch are within one housing or are independent switches? Unless you consider the switch handle being a common point of failure. Advantage of individual switches are less cost and easier to replace and troubleshoot. > I'd even state that the Rotax circuit wiring suggestions are to be taken with a grain of salt Agree, how about the warning not to run the engine with regulator terminal C not connected or the regulator will self destruct? -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457690#457690 ________________________________________________________________________________
Subject: Re: Hypothetical Battery Contactor Failure
Date: Jul 03, 2016
Bob, Don't tuck that piece of knowledge away just yet. I believe you usage was correct. The following is from my correspondence with my sister. Her qualifications include a B.A. in English, an M.A. in Library Science and a career as a technical writer, copy writer, college instructor teaching creative writing. ----------------------------------------------------------------------- First off, "immeasurably" is the adverbial form of the adjective "immeasurable," so the difference is how they are used in relation to the other parts of the sentence rather than in their fundamental meanings. Cutting to the chase, we begin with the OED definition of "immeasurable" (adjective) which is given as "Not measurable; that cannot be measured; immense." This takes us to the definition of "immeasurably" (adverb) which is given as "To an immeasurable extent or degree; beyond measure; immensely, vastly." ---------------------------------------------------------------------------- The essence of the terms in question is to describe things that can't be measured. This includes things which are too small to be measured as well as too large to be measured. The terms are also used to describe things which are too large to be measured. From a usage stand point I again refer to my sister's correspondence. ---------------------------------------------------------------------------- ... the phrase "benefits immeasurably" (which indeed uses the correct form, an adverb modifying the verb 'benefits')... ------------------------------------------------------------------------------ Bottom line the words "benefits immeasurably" convey the idea correctly and are used properly from a sentence construction stand point. Hope this information is useful. Raymond Julian Kettle River, MN The things we admire in men, kindness and generosity, openness, honesty, understanding and feeling are the concomitants of failure in our system. And those traits we detest, sharpness, greed, acquisitiveness, meanness, egotism and self-interest are the traits of success. And while men admire the quality of the first they love the produce of the second. -John Steinbeck, novelist, Nobel laureate (1902-1968) On 07/02/2016 08:31 AM, Robert L. Nuckolls, III wrote: > At 10:48 AM 7/1/2016, you wrote: >> >> >> [quote="nuckolls.bob(at)aeroelect"]At 08:13 AM 6/30/2016, you wrote: >> >> > >> > In the mean time, as long >> > as you don't hit the alternator with a really BIG load >> > (which few system are capable of doing anyhow), the >> > modern alternator runs self-excited and benefits immeasurably >> > from battery presence with respect to noise. >> >> >> Just to clarify, did you really mean "benefits immeasurably"? I think >> maybe the opposite. >> >> Immeasurable: Too large, extensive or extreme to measure. > > I've been thinking that word described an unquantifiable > entity; impossible to express in terms of quantity for any reason. > In fact, I've learned that it refers not to generally unknowable > numbers but only to nebulously large numbers. > > I can go to bed tonight knowing something I did not > know this morning . . . it's a good day. Thanks for > the heads-up! > > > Bob . . . > ________________________________________________________________________________
Subject: Re: RV6-List: Official RV6-List Usage Guidelines
Date: Jul 04, 2016
Dear Mat, I have been on the RV list, RV-6 list and Aeroelectric list for about 16 years. I sold my RV-6A in 2008 and have monitored those lists ever since. I consider all your lists a great service to the aviation community and especially to the home building community. They were a great help to me while building my RV-6A and even enjoyed them, even after selling my airplane. I would like to discontinue my subscriptions. I have long since lost my login and pass words. So, I have been unable to unsubscribe on your website. Over the years, I have received e-mailings to two different addresses: rhdudley1(at)bellsouth.net and rhdudley331(at)cfl.rr.com. Please unsuscribe me form all Matronix lists. Thank you in advance. Yours truly, Richard H Dudley ________________________________________________________________________________
Date: Jul 04, 2016
/Le 03/07/2016 21:30, Ken Ryan a crit : / > /Thanks Gilles. As I tend to be biased towards the manufacturer when > it comes to guidance, I am referring heavily to the Rotax 914 > installation instructions. Can you tell me specifically which areas > that you feel are suspect? If you could do that it would help me to > evaluate their "suggestions" against my installation./ / /Hi Ken and all, It took me some time to download and peruse the latest 914 Installation Manual (February 2015). Concerning the ignition switches, it seems there has been no changes since the 1996 version that was current when we wired our project. The manual just mentions "Type : two separate, suitable on-off switches" (page 114 newer edition) The Rotax 914 relies on two electrical pumps to keep running. Rotax suggests to feed the main pump from the voltage rectifier/regulator, and the aux pump from the main bus. If the regulator fails - not a rare occurence - you are left with only the aux pump and the battery to stay aloft. I feel a critical pump should run direct from a battery bus. -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Date: Jul 04, 2016
Thanks Giles. Does that mean that you would run both pumps from the same battery bus, or just the main pump? I thought about putting them both on the battery bus but that would violate the clearly stated requirement that "...the fuel pumps are connected on two completely independent power supplies." On airplane that you are familiar with that have both generator and alternator, do they both feed the same battery? Rotax in British Columbia steered me away from trying to combine the outputs, even though that is what is shown on the installation manual drawing. The way I have things drawn now I have the main pump wired to the integrated generator (as shown in the 914 installation manual) but I have the auxiliary pump wired to a battery bus. The auxiliary pump should run continuously as long as the external alternator is working. If both alternator and generator were to quit, then it would be battery only on the auxiliary pump. My current drawing is different from the Rotax 914 installation manual in that I don't have the integrated generator connected to the main bus (except through a momentary contact switch for exciting it into action). So the only thing the generator and regulator are doing is powering that one pump. I also plan on mounting the regulator on the cabin side of the firewall, where it is cooler. I am thinking that given the low load and cooler environment, the regulator might be more reliable. All comments are appreciated. My starting/charging/fuel pump wiring is still all on paper only at this point, so I can still make changes. Ken On Mon, Jul 4, 2016 at 4:55 AM, GTH wrote: > > *Le 03/07/2016 =C3- 21:30, Ken Ryan a =C3=A9crit : * > > *Thanks Gilles. As I tend to be biased towards the manufacturer when it > comes to guidance, I am referring heavily to the Rotax 914 installation > instructions. Can you tell me specifically which areas that you feel are > suspect? If you could do that it would help me to evaluate their > "suggestions" against my installation.* > > > Hi Ken and all, > > It took me some time to download and peruse the latest 914 Installation > Manual (February 2015). > > Concerning the ignition switches, it seems there has been no changes sinc e > the 1996 version that was current when we wired our project. The manual > just mentions > "Type : two separate, suitable on-off switches" (page 114 newer edition) > > The Rotax 914 relies on two electrical pumps to keep running. > Rotax suggests to feed the main pump from the voltage rectifier/regulator , > and the aux pump from the main bus. > If the regulator fails - not a rare occurence - you are left with only > the aux pump and the battery to stay aloft. > I feel a critical pump should run direct from a battery bus. > -- > Best regards, > Gilles > http://contrails.free.fr > http://lapierre.skunkworks.free.fr > ________________________________________________________________________________
From: Stephen Richards <stephencliverichards(at)gmail.com>
Date: Jul 04, 2016
I understood Rotax recommended separate switches so you could turn the engi ne on the starter with ignition off to check oil pressure after a oil chang e. We have fitted a keyed ignition switch as we were given one and a start pushbutton, Not ready to run engine yet. Clive -----Original Message----- From: "GTH" <gilles.thesee(at)free.fr> Sent: =8E03/=8E07/=8E2016 20:25 Subject: Re: AeroElectric-List: Re: Z-13/8 Questions Le 03/07/2016 =C3- 17:17, Ken Ryan a =C3=A9crit : With the Rotax the rotary keyed ignition switch is not allowed. Independent toggles for the ignitions are clearly specified. Hi Ken and all, Didn't know about that. Maybe it concerns the latest engines. Or maybe it is in the new installatio n documents, but as Rotax didn't change the engines already flying, I would not lose sleep on the keyswitch vs separate switches problem. Hundreds of airplanes have been flying for years with a standard ignition k eyswitch for their Rotax without the slightest issue. I'd even state that the Rotax circuit wiring suggestions are to be taken wi th a grain of salt, especially concerning the 914. -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Date: Jul 04, 2016
Thanks for that info Stephen. Makes sense to me. On Mon, Jul 4, 2016 at 8:30 AM, Stephen Richards < stephencliverichards(at)gmail.com> wrote: > I understood Rotax recommended separate switches so you could turn the > engine on the starter with ignition off to check oil pressure after a oil > change. We have fitted a keyed ignition switch as we were given one and a > start pushbutton, Not ready to run engine yet. > Clive > ------------------------------ > From: GTH <gilles.thesee(at)free.fr> > Sent: =8E03/=8E07/=8E2016 20:25 > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Re: Z-13/8 Questions > > > *Le 03/07/2016 =C3- 17:17, Ken Ryan a =C3=A9crit : * > > > *With the Rotax the rotary keyed ignition switch is not allowed. > Independent toggles for the ignitions are clearly specified. * > > > Hi Ken and all, > > Didn't know about that. > Maybe it concerns the latest engines. Or maybe it is in the new > installation documents, but as Rotax didn't change the engines already > flying, I would not lose sleep on the keyswitch vs separate switches > problem. > Hundreds of airplanes have been flying for years with a standard ignition > keyswitch for their Rotax without the slightest issue. > I'd even state that the Rotax circuit wiring suggestions are to be taken > with a grain of salt, especially concerning the 914. > > > -- > Best regards, > Gilles > http://contrails.free.fr > http://lapierre.skunkworks.free.fr > ________________________________________________________________________________
Date: Jul 04, 2016
At 07:55 AM 7/4/2016, you wrote: >Le 03/07/2016 =C3 21:30, Ken Ryan a =C3=A9crit=C2 : >>Thanks Gilles. As I tend to be biased towards >>the manufacturer when it comes to guidance, I >>am referring heavily to the Rotax 914 >>installation instructions. Can you tell me >>specifically which areas that you feel are >>suspect? If you could do that it would help me >>to evaluate their "suggestions" against my installation. > >Hi Ken and all, > >It took me some time to download and peruse the >latest 914 Installation Manual (February 2015). > >Concerning the ignition switches, it seems there >has been no changes since the 1996 version that >was current when we wired our project. The manual just mentions >"Type : two separate, suitable on-off switches" (page 114 newer edition) > >The Rotax 914 relies on two electrical pumps to keep running. >Rotax suggests to feed the main pump from the >voltage rectifier/regulator, and the aux pump from the main bus. >If the regulator fails - not a rare occurence >-=C2 you are left with only the aux pump and the battery to stay aloft. >I feel a critical pump should run direct from a battery bus. How is one 'critical' and the other not? The magic in having two pumps and separate power sources is that the likelihood of dual failures in any given tank of fuel is vanishingly small. If the engine runs per published performance specs on either pump, then there are no 'critical' pumps, just one pump backing up another pump. How would you ever get down to one, battery operated pump? Wasn't his airplane going to get an external alternator in addition to the stock, 912/914 PM alternator-rectifier/regulator? Bob . . . ________________________________________________________________________________
Date: Jul 04, 2016
> >If the regulator fails - not a rare occurence The failure driver for the Rotax/Ducatti R/R has root cause in thermal considerations . . . where the ship attempts to use full rated output from the power source. What kind of fuel pump are we talking about? How much current does it draw? Certainly nothing approaching the 18A capability of the power source. It seems that the rather strange recommendation for dedicating the stock Alternator-R/R to simple powering of the fuel pump is a hedge . . . with loads limited to a fraction of the system's advertised output capabilities, the regulator should last a very long time. Bob . . . ________________________________________________________________________________
Date: Jul 04, 2016
> >I would like to discontinue my subscriptions. I have long since >lost my login and pass words. So, I have been unable to unsubscribe >on your website. Over the years, I have received e-mailings to >two different addresses: rhdudley1(at)bellsouth.net and >rhdudley331(at)cfl.rr.com. >Please unsuscribe me form all Matronix lists. You don't need a password to subscribe/unsubscribe the email lists . . . only for browser access to the forums. Go to http://matrontics.com/subscribe and you'll be offered a page that will let you modify your emailed list subscriptions. After dropping from the lists, you'll get one last email asking you to confirm the decision. Good luck! Bob . . . ________________________________________________________________________________
Date: Jul 04, 2016
Thanks, Bob!!! RH Dudley On 7/4/2016 5:17 PM, Robert L. Nuckolls, III wrote: >> >> I would like to discontinue my subscriptions. I have long since >> lost my login and pass words. So, I have been unable to unsubscribe >> on your website. Over the years, I have received e-mailings to >> two different addresses: rhdudley1(at)bellsouth.net and >> rhdudley331(at)cfl.rr.com. >> Please unsuscribe me form all Matronix lists. > > You don't need a password to subscribe/unsubscribe > the email lists . . . only for browser access to > the forums. > > Go to http://matrontics.com/subscribe > <http://matrontics.com/subscribe> and you'll > be offered a page that will let you modify your > emailed list subscriptions. After dropping from > the lists, you'll get one last email asking > you to confirm the decision. > > Good luck! > > > Bob . . . > ________________________________________________________________________________
Date: Jul 04, 2016
Thanks for those comments Bob. Your reasoning makes sense to me. Sent from my Android. Sorry Steve. On Jul 4, 2016 1:23 PM, "Robert L. Nuckolls, III" < nuckolls.bob(at)aeroelectric.com> wrote: > > If the regulator fails - not a rare occurence > > > The failure driver for the Rotax/Ducatti R/R > has root cause in thermal considerations . . . > where the ship attempts to use full rated output > from the power source. > > What kind of fuel pump are we talking about? > How much current does it draw? Certainly nothing > approaching the 18A capability of the power > source. > > It seems that the rather strange recommendation > for dedicating the stock Alternator-R/R to simple > powering of the fuel pump is a hedge . . . with > loads limited to a fraction of the system's > advertised output capabilities, the regulator > should last a very long time. > > > Bob . . . > ________________________________________________________________________________
Date: Jul 05, 2016
/Le 04/07/2016 17:52, Ken Ryan a crit : / > /Thanks Giles. Does that mean that you would run both pumps from the > same battery bus, or just the main pump? I thought about putting them > both on the battery bus but that would violate the clearly stated > requirement that "...the fuel pumps are connected on two completely > independent power supplies." / On our airplane the main pump runs from the main battery bus any time the ignition switch is on. The aux pump runs from a dedicated aux battery fed through a battery management module. > /On airplane that you are familiar with that have both generator and > alternator, do they both feed the same battery?/ I'm aware of only one other Rotax aircraft with two alternators, but I don't know how they wired their machine. -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Date: Jul 05, 2016
Le 04/07/2016 18:30, Stephen Richards a crit : > I understood Rotax recommended separate switches so you could turn the > engine on the starter with ignition off to check oil pressure after a > oil change. We have fitted a keyed ignition switch as we were given > one and a start pushbutton, Not ready to run engine yet. I'll bet the two separate ignition switches are for the magneto checks before each flight. Rotax doesn't give recommadations for the starter switch, which may or may not be combined with an ignition keyswitch. It's up to the homebuilder. There are different ways of priming the oil circuit, but no problem for oil pressure if you perform the oil changes as recommended. Unless you drain the oil lines, but then the procedure is in in the maintenance manual, separate starter switch or not. -- A+ Gilles ________________________________________________________________________________
Date: Jul 05, 2016
/Le 04/07/2016 23:10, Robert L. Nuckolls, III a crit : / > / > If the engine runs > per published performance specs on either > pump, then there are no 'critical' pumps, > just one pump backing up another pump. > / Hi Bob, Of course. I'd say that for us the "critical" one is the pump that we think should run anytime the ignition is on. And the backup the one that is pilot operated. I saw so many voltage regulator failures around that I would not like to depend on the regulator to keep the engine running > > /How would you ever get down to one, battery > operated pump? Wasn't his airplane going to > get an external alternator in addition to > the stock, 912/914 PM alternator-rectifier/regulator?/ The point was "why do you say some of Rotax suggestions are to be taken with a grain of salt ?", not any suggestion as to how Ken should or shouldn't wire his airplane. -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Date: Jul 04, 2016
Gilles, I hear you loud and clear on depending on the regulator to keep the engine running. At this point, I am considering that to the the weakest point in my proposed design. But, I am not convinced that there is a significant probability of regulator failure, given that my plan is to run only the pump (approx 5 amps) off the generator. That would mean that the regulator is only being stressed to less than 1/3 capacity. Also, given that I plan to install the regulator on the cabin side of the firewall, that would further mitigate heat issues. Like Bob, I'm thinking this should significantly lower the probability of regulator failure. My question for you, and for the group, is this: what is the normal (if there is a normal) mode of failure for these regulators? Do they just suddenly stop working, or is there typically some warning of failure? As always, thanks. It's amazing how many things there are to consider. Ken On Mon, Jul 4, 2016 at 2:41 PM, GTH wrote: > > *Le 04/07/2016 =C3- 23:10, Robert L. Nuckolls, III a =C3=A9crit : * > > > * If the engine runs per published performance specs on either pump , > then there are no 'critical' pumps, just one pump backing up another > pump. * > > > Hi Bob, > > Of course. > I'd say that for us the "critical" one is the pump that we think should > run anytime the ignition is on. > And the backup the one that is pilot operated. > I saw so many voltage regulator failures around that I would not like to > depend on the regulator to keep the engine running > > > * How would you ever get down to one, battery operated pump? Wasn't his > airplane going to get an external alternator in addition to the stock , > 912/914 PM alternator-rectifier/regulator?* > > > The point was "why do you say some of Rotax suggestions are to be taken > with a grain of salt ?", not any suggestion as to how Ken should or > shouldn't wire his airplane. > > > -- > Best regards, > Gilles > http://contrails.free.fr > http://lapierre.skunkworks.free.fr > ________________________________________________________________________________
Date: Jul 05, 2016
Mike Miller has done autopsies on several failed Ducati regulators and he attributes the failures to poor manufacturing and vibration, not from heat. Some RV-12 owners have reported a gradual failure where they get low voltage alarms at RPMs where they used to have normal voltage. Each regulator could fail differently. Some builders are reluctant to mount the regulator inside of the passenger compartment because they do not want to breath smoke if the regulator does fail in that location. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457742#457742 ________________________________________________________________________________
Date: Jul 05, 2016
/Le 05/07/2016 13:37, user9253 a crit : / > Mike Miller has done autopsies on several failed > Ducati regulators and he attributes the failures to poor manufacturing > and vibration, not from heat. Some RV-12 owners have reported a > gradual failure where they get low voltage alarms at RPMs where they > used to have normal voltage. Each regulator could fail differently. > Some builders are reluctant to mount the regulator inside of the > passenger compartment because they do not want to breath smoke if the > regulator does fail in that location. / Hi all, In the past years we performed some study of the Rotax alternator and regulator. My buddy Jerome Delamarre studied the functionning of the switching regulator, and conducted some thermal analysis of the unit. It seems there is definitely a thermal issue with the regulator. I published some data here http://contrails.free.fr/elec_ducati_en.php The rest of the study will be published some day in an indefinite future ;-) Re the smoke, the components are potted inside a metal case, and the failed regulators I saw showed no external trace of failure. So the possibility of smoke seems to be remote. For instance, about 500 Dyn'Aero MCRs have the regulator inside the cabin, and although the cases of regulator failures are not infrequent, I never heard of a smoking unit. What *can* be happen though, is a capacitor bursting, very disturbing for the crew they told me. Bottom line, after some thorough analysis of the Ducati regulator and a Schicke, we elected to install a Schicke GR4. Worked flawlessly since the beginning. FWIW -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Date: Jul 05, 2016
Thanks Joe, all good points. On Tue, Jul 5, 2016 at 3:37 AM, user9253 wrote: > > Mike Miller has done autopsies on several failed Ducati regulators and he > attributes the failures to poor manufacturing and vibration, not from > heat. Some RV-12 owners have reported a gradual failure where they get low > voltage alarms at RPMs where they used to have normal voltage. Each > regulator could fail differently. > Some builders are reluctant to mount the regulator inside of the > passenger compartment because they do not want to breath smoke if the > regulator does fail in that location. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=457742#457742 > > ________________________________________________________________________________
Date: Jul 05, 2016
Thanks for the input. Reading the information you linked to, it looks like your conclusion was that if the regulator is making full power (240 watts) then in order for the operating temperature to remain safe, the ambient temperature must be no greater than MINUS 59 C (-74F). Meanwhile, Rotax says that ambient temperature must not exceed PLUS 90 C (+194F). That's quite a discrepancy, -74F vs +194F. Please, tell me I have mis-interpreted your paper. On Tue, Jul 5, 2016 at 4:24 AM, GTH wrote: > > *Le 05/07/2016 =C3- 13:37, user9253 a =C3=A9crit : * > > > Mike Miller has done autopsies on several failed Ducati regulators and he attributes the failures to poor manufacturing and vibration, not from heat . Some RV-12 owners have reported a gradual failure where they get low vol tage alarms at RPMs where they used to have normal voltage. Each regulator could fail differently. > Some builders are reluctant to mount the regulator inside of the passen ger compartment because they do not want to breath smoke if the regulator d oes fail in that location. > * > > Hi all, > > In the past years we performed some study of the Rotax alternator and > regulator. > My buddy Jerome Delamarre studied the functionning of the switching > regulator, and conducted some thermal analysis of the unit. It seems ther e > is definitely a thermal issue with the regulator. > I published some data here > http://contrails.free.fr/elec_ducati_en.php > The rest of the study will be published some day in an indefinite future > ;-) > > Re the smoke, the components are potted inside a metal case, and the > failed regulators I saw showed no external trace of failure. So the > possibility of smoke seems to be remote. > For instance, about 500 Dyn'Aero MCRs have the regulator inside the cabin , > and although the cases of regulator failures are not infrequent, I never > heard of a smoking unit. > What *can* be happen though, is a capacitor bursting, very disturbing for > the crew they told me. > > Bottom line, after some thorough analysis of the Ducati regulator and a > Schicke, we elected to install a Schicke GR4. Worked flawlessly since the > beginning. > FWIW > > -- > Best regards, > Gilles > http://contrails.free.fr > http://lapierre.skunkworks.free.fr > ________________________________________________________________________________
Date: Jul 05, 2016
The ambient temperature can be greater if the air is moving. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457750#457750 ________________________________________________________________________________
Date: Jul 05, 2016
So I guess if it's in the high pressure area of the engine compartment, it should be good in flight, but maybe not so much during taxi and cool down? Maybe a timer like this: https://www.youtube.com/watch?v=CJG2f2ZjPxQ&t=0s could be connected to a computer fan such that the fan always runs when the master switch is on, and continues to run for a period of time (10 minutes?) after the master switch is turned off. Alternatively, it could be set to come on only after the master switch is turned off. The regulator on a UL engine that I installed on a Zenith had two features for dissipating heat: 1) it was mounted to aluminum engine shrouding using a heat conducting gel to facilitate heat transfer from the regulator body to the aluminum engine shroud and 2) it was blasted by cooling air through a dedicated 1 inch scat hose. On Tue, Jul 5, 2016 at 7:39 AM, user9253 wrote: > > The ambient temperature can be greater if the air is moving. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=457750#457750 > > ________________________________________________________________________________
Date: Jul 05, 2016
At 06:37 AM 7/5/2016, you wrote: > >Mike Miller has done autopsies on several failed Ducati regulators >and he attributes the failures to poor manufacturing and vibration, vibration in a potted assembly? > not from heat. Has he published a teardown report? > Some RV-12 owners have reported a gradual failure where they get > low voltage alarms at RPMs where they used to have normal > voltage. Each regulator could fail differently. Color me skeptical . . . these regulators have been in production for decades. There must have been thousands sold. Over that period of time and numbers of examples, I find it curious that a constellation of failure modes would emerge. At the debut of the 912/914 series engines on this side of the pond . . . a SINGLE phase PM dynamo in the 18-20A class was really pushing the state of the art. The control devices capable of handling that much current would normally have been mounted directly to metallic heatsinks with fins. To my knowledge, production examples still expect the potting compound to bring BTUs to the outside world. Why Rotax continues to sell/recommend this device is curious considering the fact that there are much more robust/modern devices available. The OBAM aviation community has been slicing/dicing this sad piece of technology for too long. It has been thermally challenged since day-one. I cannot argue against 'constellations' of other failure modes . . . but debating a broader spectrum of issues seems a waste of $time$. It's like worrying about whether or not the a/c and stereo are working in a car with 3 flat tires. >Some builders are reluctant to mount the regulator inside of the >passenger compartment because they do not want to breath smoke >if the regulator does fail in that location. Has one EVER 'smoked'? Has a 'smoked' R/R every been preserved for examination? Our ranks are rife with anecdotal information on a product with a very long service history . . . and and continues to be offered by a company with a lot of 'skin in the game'. Why jepoardize consumer relations on a product costing $thousands$ by sticking with a demonstrably marginal accessory that probably costs them less than $50? I've observed some pretty strange marketing decisions by big-name manufacturers. To be sure, there are really powerful cultural forces in company behaviors. I could tell you some interesting stories about the intractability of several supposed European 'project partners.' So just maybe, the Rotax decision to stay with Ducatti has nothing to do with science and economics. Emacs! My advice to Rotax customers. Pitch the Ducatti R/R right out of the box . . . or put it up on eBay. There's a bunch of ultralights flying the 912 that can probably make good use of an R/R that should probably be rated at 10A. The Silent-Hektick electronics cavity volume is a fraction of that in the Ducatti. Square- inches of fin area for heat dissipation is much greater. Further, the thing is RATED at 47A . . . so de-rating to run it on an 18A Rotax dynamo seems a rational decision that goes toward longevity and serviceability. There are probably other devices out there with equal or better performance than the Ducatti. There will come a time when incandescent landing lights will be a thing of the past along with carburetors, VOR receivers and E6B computers. It's time for the Ducatti R/R to be retired as the best Rotax could offer at introduction . . . but long since surpassed by better ideas. Bob . . . ________________________________________________________________________________
Date: Jul 05, 2016
/Le 05/07/2016 17:23, Ken Ryan a crit : / > /Thanks for the input. Reading the information you linked to, it looks > like your conclusion was that if the regulator is making full power > (240 watts) then in order for the operating temperature to remain > safe, the ambient temperature must be no greater than MINUS 59 C > (-74F). Meanwhile, Rotax says that ambient temperature must not exceed > PLUS 90 C (+194F). That's quite a discrepancy, -74F vs +194F. Please, > tell me I have mis-interpreted your paper./ Hi Ken, You correctly read the info on my webpage. We got the regulator thermal characteristics actually measured in a lab. Concerning what Rotax says, well unless they publish their own results, I'd stick with the grain of salt ;-) Especially when you consider the failures around as soon as people draw much current from their alternator & regulator. Besides they are not wrong : temperatures no greater than 90 C doesn't mean that 70 or 80 C are safe... -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Date: Jul 05, 2016
/Le 05/07/2016 18:18, Ken Ryan a crit : / > / > / > / two features for dissipating heat: 1) it was mounted to aluminum > engine shrouding using a heat conducting gel to facilitate heat > transfer from the regulator body to the aluminum engine shroud and 2) > it was blasted by cooling air through a dedicated 1 inch scat hose./ Add to that a safe and cool place with no exhaust, turbo, engine block radiating or convecting heat at the regulator (i.e. not in the engine comparment ;-), and everything will be well. -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Date: Jul 05, 2016
I am not taking sides here, just reporting Mike Miller's postings. Joe G. > My motivation for the analyses was based on the abysmal failure rate, with no good data available on a cause. I cant make any broad claims as to the cause of the failures, only claims based on a sample of one unit. I think the electrical design is fine, simple and safe for the use in a VFR aircraft, Im not so sure about the mechanical design/assembly. I first thought the failures were based on the stress of thermal cycles. After the analysis I think its simply vibration. I base this on the review of the fretted solder joints you can see in the pictures. The main failure on mine (and Im guessing yours too) is a broken lead on the SCR (the SCR is the power switch that controls the regulator output.) The likely cause of the failure is the movement between SCRs bolted to the case (required as a heat sink) and floating PCB in the epoxy jel. Your post questioned the SCR installation with the bent over leads to attach to the PCB. This is not uncommon, for a component requiring a heat sink. I would be confident your regulator is fixed by re-soldering the SCR leads. I would touch up all three pins, on both SCRs, also inspect all the other solder connections for fretting. I dont think you need to remove the PCB from the case, unless an SCR lead is broken at the component (like mine was.) I use several epoxy potting compounds here at work, so for me repotting was a non issue. I did use a harder epoxy to reduce the gel effect. I suggest you not remove the board from the case, and after you are finished, cover the bottom with high temp RTV. There are no heat issues on the bottom of the regulator. All you want to do is seal it up, Just my opinion. > > Oh, the reason you found two layers of epoxy, its part of the manufacturing process. The regulator is filled with epoxy, placed in a vacuum chamber to remove the air bubbles, after curing its topped off again. > > I asked LEAF about the two failed regulators I returned under warrantee. They said they just trash them, Rotax doesnt want them back. They also told me, Rotax will not give me anymore credits for failed regulators, because the problem is the aircraft/aircraft design, not the regulator. I sent Vans a feedback form for the failures, not to blame Vans for the problem, I just thought they would have more pull with Rotax to get it fixed. With that said, I think Rotax knows there is a problem, I say this based on the cost of the regulator. $160.00 may be a lot of money, but its cheap as Rotax prices go. Im guessing Ducati sells it for about $50 to Rotax, but it goes through Kodiak, in the Bahamas, then a distributor (LEAF/Lockwood,) each tacking on freight and markup, before we see it. " See http://www.vansairforce.com/community/showpost.php?p=1092091&postcount=23 for pictures -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457760#457760 ________________________________________________________________________________
Subject: EXPBUS Circuit Failure
Date: Jul 05, 2016
I found several conversations on this site relating to the Expbus system, and Electronic Circuit Breakers. I wanted to relate my recent experience. I have two Expbus systems in my Rutan Defiant. They have operated flawlessly for 16 years, or about 870 hours on the airplane. Recently one circuit, with two devices on it, started shutting down intermittently, but with no indication of a short on the indicator board. I found the problem the other day, by pulling the two devices (terra nav and Gemini backup efis) and checking voltage at each connector. Both read normal 12+ volts. I then plugged in the Gemini, checked voltage at the nav connector, now it was 3.4 volts. I plugged in the nav radio, pulled out the Gemini, and IT was now showing about 3.4 volts. Apparently the one circuit/breaker was dropping out with any sort of load on it. Not sure why, but I have fixed it by wiring an inline fuse to the devices, and disconnecting from the output on the EXPBUS. -------- Harry Manvel Defiant N2HM PTK / Pontiac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457761#457761 ________________________________________________________________________________
Subject: Dead battery
Date: Jul 05, 2016
From: Dennis Wright > Trying to figure out if I have an issue with my electrical system in my sonex or just bad luck. Have had multiple battery failures. Here's the situation. Battery is an odyssey pc625. , 12 volt. Engine is an Aerovee 2180. First flight was in December 2015. Battery at that time was about 2.5 years old. During the time before first flight had to charge batter several times due to minimal use. After about 5 hrs of flying started experiencing a dead battery. Would charge, fly, and next day battery would be dead again. Figured it was due to age and fact that battery had sat uncharged for prolonged periods. Replaced battery. After about 15 hrs flying time (about 3 months) on new battery, went dead. Tried to charge but would not hold a charge. Had battery tested and showed that it had a bad cell. Replaced battery. After about 25 hrs (about 3 months), another dead battery and will not hold a charge Each time everything is working perfect one day and dead the next. Not blo! > wing any fuses, no smoking wires, system voltage is showing 13.5 volts when I'm flying. Have not checked to see if there is a load on the battery when the battery solenoid is open but do not have anything connected on the battery side of the solenoid so unless the solenoid is bad, shouldn't have any load when off. Would appreciate any thoughts on what the problem might be or where to start to figure it out. > > From: Dennis Wright > > > ________________________________________________________________________________
Subject: Re: Dead battery
Date: Jul 05, 2016
On 7/5/2016 10:37 PM, Dennis Wright wrote: > > > From: Dennis Wright > >> Trying to figure out if I have an issue with my electrical system in my sonex or just bad luck. Have had multiple battery failures. Here's the situation. Battery is an odyssey pc625. , 12 volt. Engine is an Aerovee 2180. First flight was in December 2015. Battery at that time was about 2.5 years old. During the time before first flight had to charge batter several times due to minimal use. After about 5 hrs of flying started experiencing a dead battery. Would charge, fly, and next day battery would be dead again. Figured it was due to age and fact that battery had sat uncharged for prolonged periods. Replaced battery. After about 15 hrs flying time (about 3 months) on new battery, went dead. Tried to charge but would not hold a charge. Had battery tested and showed that it had a bad cell. Replaced battery. After about 25 hrs (about 3 months), another dead battery and will not hold a charge Each time everything is working perfect one day and dead the next. Not b! > lo! >> wing any fuses, no smoking wires, system voltage is showing 13.5 volts when I'm flying. Have not checked to see if there is a load on the battery when the battery solenoid is open but do not have anything connected on the battery side of the solenoid so unless the solenoid is bad, shouldn't have any load when off. Would appreciate any thoughts on what the problem might be or where to start to figure it out. >> >> From: Dennis Wright >> >> 13.5v won't charge the battery. ________________________________________________________________________________
Date: Jul 06, 2016
Agree, charging voltage should be more like 14.2 to 14.5 v, especially for an Odessey type battery. On 6 Jul 2016 05:07, "Charlie England" wrote: > ceengland7(at)gmail.com> > > On 7/5/2016 10:37 PM, Dennis Wright wrote: > >> wright.dennis(at)icloud.com> >> >> >> >> From: Dennis Wright >> >> Trying to figure out if I have an issue with my electrical system in my >>> sonex or just bad luck. Have had multiple battery failures. Here's the >>> situation. Battery is an odyssey pc625. , 12 volt. Engine is an Aerovee >>> 2180. First flight was in December 2015. Battery at that time was about >>> 2.5 years old. During the time before first flight had to charge batter >>> several times due to minimal use. After about 5 hrs of flying started >>> experiencing a dead battery. Would charge, fly, and next day battery would >>> be dead again. Figured it was due to age and fact that battery had sat >>> uncharged for prolonged periods. Replaced battery. After about 15 hrs >>> flying time (about 3 months) on new battery, went dead. Tried to charge >>> but would not hold a charge. Had battery tested and showed that it had a >>> bad cell. Replaced battery. After about 25 hrs (about 3 months), another >>> dead battery and will not hold a charge Each time everything is working >>> perfect one day and dead the next. Not ! >>> >> b! > >> lo! >> >>> wing any fuses, no smoking wires, system voltage is showing 13.5 volts >>> when I'm flying. Have not checked to see if there is a load on the battery >>> when the battery solenoid is open but do not have anything connected on the >>> battery side of the solenoid so unless the solenoid is bad, shouldn't have >>> any load when off. Would appreciate any thoughts on what the problem might >>> be or where to start to figure it out. >>> >>> From: Dennis Wright >>> >>> >>> 13.5v won't charge the battery. > > ________________________________________________________________________________
Date: Jul 06, 2016
And I can confirm, that if your system charging voltage is 13.5, you will kill your battery in amazing short order. You have to get it up to 14.5 or so. In the mean time, charge it on a proper charger (for AGM Batts) between flights. Bill "killer of at least 3" Watson On 7/6/2016 1:53 AM, Peter Pengilly wrote: > > Agree, charging voltage should be more like 14.2 to 14.5 v, especially > for an Odessey type battery. > > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jul 06, 2016
Subject: Re: EXPBUS Circuit Failure
> Apparently the one circuit/breaker was dropping out with any sort > of load on it. Not sure why, but I have fixed it by wiring an > inline fuse to the devices, and disconnecting from the output on the EXPBUS. I don't know what the failure modes are for the polyfuses . . . we looked at them on two separate occasions at Beech and just couldn't figure out how to integrate them into system wiring . . . Had the idea progressed any further, we proably would have done some endurance/halt testing on the devices to see if their weaknesses would present . . . but given the service life demonstrated on your airplane, I'm not sure we could have 'turned that rock over' as a part of preliminary design studies. Those polyfuses are widely available parts. If you choose to identify and replace the one that went belly up, I can help you find a replacement. Bob . . . ________________________________________________________________________________
Date: Jul 06, 2016
Subject: dielectric grease vs conductive grease: when and where
When and where should electrical connections receive grease? What type of grease should be used? --Thanks. ________________________________________________________________________________
Date: Jul 06, 2016
Just to add one more datapoint, I'd been running on a charging voltage of 13 .2 to 13.4 for three years+ on a Comcorde sealed gel battery - and while it h as been sluggish starts for the past three Canadian winters I don't see any e vidence that it's damaged, certainly not dead. On Jul 6, 2016, at 11:15, Bill Watson wrote: And I can confirm, that if your system charging voltage is 13.5, you will ki ll your battery in amazing short order. You have to get it up to 14.5 or so. In the mean time, charge it on a prope r charger (for AGM Batts) between flights. Bill "killer of at least 3" Watson > On 7/6/2016 1:53 AM, Peter Pengilly wrote: > Agree, charging voltage should be more like 14.2 to 14.5 v, especially for an Odessey type battery. > This email has been checked for viruses by Avast antivirus software. www.avast.com ________________________________________________________________________________
Subject: Re: dielectric grease vs conductive grease: when and
where
Date: Jul 06, 2016
Everything you ever wanted to know about grease and electrical connections: http://www.w8ji.com/dielectric_grease_vs_conductive_grease.htm I have never used conductive grease on electrical connections. I use dielectric grease on connections exposed to moisture. Dielectric grease does NOT increase resistance in a connection because it gets squeezed out from between electrical terminals. That squeezed out grease prevents air and dirt and water from entering. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457798#457798 ________________________________________________________________________________
Date: Jul 06, 2016
and where At 11:20 AM 7/6/2016, you wrote: >When and where should electrical connections receive grease? What >type of grease should be used? --Thanks. If the connections are subject to water drip/splash. Dow Corning DC4 is my favorite. http://tinyurl.com/hbty5z2 http://tinyurl.com/heqjw25 it's a silicone based grease that doesn't attack rubbers and plastics. There are, no doubt, others. We also used DC4 to 'pot' coax connectors on towers before wrapping with Scotch 33 tape. Bob . . . ________________________________________________________________________________
Date: Jul 06, 2016
I have a similar problem with an RV4 that I purchased. Dead battery. Discovered field wire broken - repaired. Field wire is jumpered directly to the alternator output. No fuse, cb, or switch. The alternator appears to be internally regulated. I am seeing no more than 13.5 volts. With no load at all on the field wire, is that what is keeping the voltage down? john On 7/6/2016 8:15 AM, Bill Watson wrote: > And I can confirm, that if your system charging voltage is 13.5, you > will kill your battery in amazing short order. > > You have to get it up to 14.5 or so. In the mean time, charge it on a > proper charger (for AGM Batts) between flights. > > Bill "killer of at least 3" Watson > > On 7/6/2016 1:53 AM, Peter Pengilly wrote: >> >> Agree, charging voltage should be more like 14.2 to 14.5 v, >> especially for an Odessey type battery. >> >> > > > ------------------------------------------------------------------------ > Avast logo > > > > This email has been checked for viruses by Avast antivirus software. > www.avast.com > > > ________________________________________________________________________________
Date: Jul 06, 2016
On 7/6/2016 1:44 PM, John Morgensen wrote: > > I have a similar problem with an RV4 that I purchased. > > Dead battery. > Discovered field wire broken - repaired. > Field wire is jumpered directly to the alternator output. No fuse, cb, > or switch. > The alternator appears to be internally regulated. > > I am seeing no more than 13.5 volts. > > With no load at all on the field wire, is that what is keeping the > voltage down? Well, charging at 13.5 will kill an Odyssey AGM battery. I have a regulator and alternator - my regulator is adjustable and needed to be set to 14.5 to get a normal charge on my Odysseys. In general, 13.5 is fine for lead acid batteries. I'm doing this from memory and experience but the place to look is the spec sheets. --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jul 06, 2016
JohnInReno, A bad connection could be causing low voltage. Check both ends of the wire from the alternator "B" terminal. Pull hard on the terminals to make sure they are solid with no corrosion. Also check the engine ground wire. The engine mount should NOT be part of the ground circuit. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457815#457815 ________________________________________________________________________________
June 17, 2016 - July 06, 2016
AeroElectric-Archive.digest.vol-ng
