AeroElectric-Archive.digest.vol-nh
July 06, 2016 - July 16, 2016
Date: Jul 06, 2016
Subject: Re: Dead battery
> >I have a regulator and alternator - my regulator is adjustable and >needed to be set to 14.5 to get a normal charge on my Odysseys. > >In general, 13.5 is fine for lead acid batteries. It has never been fine for any version of a lead-acid battery. In fact, low voltage warning systems are generally calibrated to come on at or below 13.5 volts. Batteries take on energy at 13.8 and above . . . 14.2 plus/minus 0.2 volts has been the lead-acid legacy setpoint for 70 years or more. B&C sets their regulators for 14.5 to 14.6 out the door. An alternator producing 13.5 will not charge a battery, but it will keep the battery from becoming discharged . . . assuming it was charged before flight. If the aircraft is stored with a charger/maintainer then the engine gets started by a 100% battery. If the alternator set-point is only 13.5, then the battery doesn't get replenished . . . until it gets connected to the charger while parked. Under THIS scenario, the battery is happy as a clam and will last a really long time. Assuming the battery is never supported externally for energy replenishment the 13.5v bus won't top off a battery that has just started the engine. At the same time, the 13.5v bus runs all the electro- whizzies just fine. Starting a well tuned engine only takes 3-5% of a battery's stored energy. So a topped off battery can be expected to take you flying for 5-10 times before you notice that it's getting 'weak'. Whacking it down over a long period of time without replenishment eventually produces the "dead battery" syndrome . . . storing a battery in a low state of charge is hard on its chemistry . . . no matter what kind of lead acid battery it is. We were presented with a 13.5v bus on a 182 a few days ago on a Canadian ship that was suffering the effects off high resistance joints and a poorly adjusted regulator. His "dead battery" symptoms were predictable . . . AGM . . . Flooded . . . it doesn't matter. The charging system needs attention to get the bus up . . . 14.5v is a good target. Bob . . . ________________________________________________________________________________
Date: Jul 06, 2016
At 12:44 PM 7/6/2016, you wrote: >Dead battery. >Discovered field wire broken - repaired. >Field wire is jumpered directly to the alternator output. No fuse, >cb, or switch. >The alternator appears to be internally regulated. then that is not a 'field' wire . . . it's a control line that the automotive ECM talks to for turning the alternator off and on. >I am seeing no more than 13.5 volts. >With no load at all on the field wire, is that what is keeping the >voltage down? If repairing the CONTROL line did not correct the problem, then the alternator is broke. Bob . . . ________________________________________________________________________________
Date: Jul 06, 2016
Sorry if I high-jacked the thread. My problem is a lycoming O-320 and it bothers me that there is no fuse, cb, or switch on the control wire going to the alternator. john On 7/6/2016 4:57 PM, Robert L. Nuckolls, III wrote: > At 12:44 PM 7/6/2016, you wrote: > >> Dead battery. > >> Discovered field wire broken - repaired. >> Field wire is jumpered directly to the alternator output. No fuse, >> cb, or switch. >> The alternator appears to be internally regulated. > > then that is not a 'field' wire . . . it's > a control line that the automotive ECM talks > to for turning the alternator off and on. > >> I am seeing no more than 13.5 volts. >> With no load at all on the field wire, is that what is keeping the >> voltage down? > > If repairing the CONTROL line did not correct > the problem, then the alternator is broke. > > Bob . . . > ________________________________________________________________________________
Date: Jul 06, 2016
At 08:19 PM 7/6/2016, you wrote: >Sorry if I high-jacked the thread. My problem is a lycoming O-320 >and it bothers me that there is no fuse, cb, or switch on the >control wire going to the alternator. This is an OBAM aircraft? Do you have an alternator on/off switch . . . either as a separate device -or- split rocker - etc? It is functionally sufficient to simply wire the control lead of an internally regulated alternator direcdtly to the b-lead or other always-hot source . . . this simply causes the alternator to come on line as soon as the engine starts. At the same time, you have no control over the alternator . . . if you turn the battery switch off, the alternator continues to provide output. If you experience an ov condition, there's no provisions for bringing the runaway alternator to heel. Bob . . . ________________________________________________________________________________
Date: Jul 07, 2016
Just to emphasize what Bob said, connecting the alternator control wire directly to the "B" terminal is not recommended. The master switch no longer has control over the electrical system. It is not a master switch in this case, but is a battery switch. Shutting off the master switch in flight only disconnects the battery, but does not shut off the electrical system. Everything will keep working. If the electrical system needs to be shut off in an emergency like smoke in the cockpit or a fuel leak or high voltage, the only way to accomplish that is to shut off the engine also. The master switch needs to be placarded, "Inoperative in flight". The solution is to run the alternator control wire to a panel mounted fused switch. Doing that will not only eliminate the above problems, but also allow the voltage regulator to monitor actual system voltage instead of alternator output voltage. They could be different if there is resistance in the alternator wiring. That resistance could result in lower system voltage even though the alternator is putting out 14+ volts. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457845#457845 ________________________________________________________________________________
Date: Jul 07, 2016
On Thu, Jul 7, 2016 at 7:24 AM, user9253 wrote: > > Just to emphasize what Bob said, connecting the alternator control wire > directly to the "B" terminal is not recommended. The master switch no > longer has control over the electrical system. It is not a master switch > in this case, but is a battery switch. Shutting off the master switch in > flight only disconnects the battery, but does not shut off the electrical > system. Everything will keep working. If the electrical system needs to > be shut off in an emergency like smoke in the cockpit or a fuel leak or > high voltage, the only way to accomplish that is to shut off the engine > also. The master switch needs to be placarded, "Inoperative in flight". > The solution is to run the alternator control wire to a panel mounted fused > switch. Doing that will not only eliminate the above problems, but also > allow the voltage regulator to monitor actual system voltage instead of > alternator output voltage. They could be different if there is resistance > in the alternator wiring. That resi! > stance could result in lower system voltage even though the alternator is > putting out 14+ volts. > > -------- > Joe Gores > > I think we need to be careful about which kind of alternator we're talking about. IIRC, the post was about an internally regulated ("one wire") alternator. Some older versions require the 'I' terminal to see system voltage for the alternator to start. Some of *that* subgroup will continue operation only with voltage on the 'I' terminal; some will not. But all of the internally regulated alts I've seen need some form of external overvoltage protection (typically a series contactor in the B lead circuit) which implies the ability to control the alt's ability to feed the system. If the contactor control is 'downstream' of the master switch, you get the one-operation shutdown of the system If the engine is electrically dependent, which is becoming more and more common, even with traditional a/c engines (automotive style ignition & injection), then something more complicated is needed, to be sure the engine electron source can be controlled independently from the airframe. Charlie ________________________________________________________________________________
Date: Jul 07, 2016
Thanks Bob and Joe. I will dive into the alternator wiring on this plane. I see a "page per system" in the future. john On 7/7/2016 5:24 AM, user9253 wrote: > > Just to emphasize what Bob said, connecting the alternator control wire directly to the "B" terminal is not recommended. The master switch no longer has control over the electrical system. It is not a master switch in this case, but is a battery switch. Shutting off the master switch in flight only disconnects the battery, but does not shut off the electrical system. Everything will keep working. If the electrical system needs to be shut off in an emergency like smoke in the cockpit or a fuel leak or high voltage, the only way to accomplish that is to shut off the engine also. The master switch needs to be placarded, "Inoperative in flight". The solution is to run the alternator control wire to a panel mounted fused switch. Doing that will not only eliminate the above problems, but also allow the voltage regulator to monitor actual system voltage instead of alternator output voltage. They could be different if there is resistance in the alternator wiring. That resi! > stance could result in lower system voltage even though the alternator is putting out 14+ volts. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=457845#457845 > > ________________________________________________________________________________
Date: Jul 07, 2016
But all of the internally regulated alts I've seen need some form of extern al overvoltage protection (typically a series contactor in the B lead circu it) which implies the ability to control the alt's ability to feed the syst em. If the contactor control is 'downstream' of the master switch, you get the one-operation shutdown of the system I seem to recall a couple of years ago, Bob N. was working on a system to safely shut down an internally regulated alternator, and a simple serie s contactor was not the answer. IIRC he never came up with a good recommendation for a circuit and procedure to do this. Am I correct or did I miss the final answer??? Roger ________________________________________________________________________________
Date: Jul 07, 2016
Subject: B-29 "Doc" nears first flight
There hes been a really ambitious project in Wichita to restore a B-28 to exhibition flight status. http://tinyurl.com/hozcsd3 "Doc" received an experimental airworthiness certificate May 16. Emacs! Negotiations are being conducted for use of McConnell AFB runways adjacent to the old Boeing facilities where Doc has been in rehab for the past 16 years. I think they're hoping to make it to OSH this year. Bob . . . ________________________________________________________________________________
Subject: Re: dielectric grease vs conductive grease: when and
where
Date: Jul 07, 2016
> dielectric grease vs conductive grease: when and where Summarizing some discussions Bob and I had some time ago, there is approximately zero need or use for grease in a properly constructed aircraft electrical system. There are very specialized exceptions (heatsinks of power semiconductors inside electronics, heat transfer compound on certain sparkplug threads) but the conductivity you're promoting is thermal, not electrical. Aircraft electrical connections have to be tight enough that they don't come apart, forcing a metal-to-metal connection of higher pressure than any grease will withstand. The grease only serves to prevent air and water from reaching metal parts that aren't in contact -- but if they are not in contact anyway the grease will not help. In cars, we have battery posts and terminals made of rough cast lead that won't support the kind of pressure that copper lugs will, so some amine grease (a variant of cosmoline, such as No-Ox-Id A-Special) is a good idea to help the battery terminal conform to the post and seal out the battery acid, but we hope you don't have that kind of terminal post in your plane. It's great for trailer and motorhome lights, truck battery posts, etc but we hope you don't have any iffy connections like that in your airplane. Conductive grease (containing metal dust) is used to solve one very specific problem in high current building power wiring and has no place in an airplane. If the surfaces are so rough that they need conductive grease to make contact, fix the surfaces instead. 'Dielectric grease' made with silicone oil came into use because it's available in a convenient tube and electronics techs have it already for heat sinks. But again, no reason in an airplane unless you need to make the surfaces slippery or exclude moisture. ________________________________________________________________________________
Subject: Re: B-29 "Doc" nears first flight
Date: Jul 07, 2016
Bob, That is great news. The crew of Doc has done a wonderful job of getting the plane back in the air. I truly hope they can get it to Oshkosh. Lyle On 7/7/2016 11:07 AM, Robert L. Nuckolls, III wrote: > > There hes been a really ambitious project in Wichita > to restore a B-28 to exhibition flight status. > > http://tinyurl.com/hozcsd3 > > "Doc" received an experimental airworthiness > certificate May 16. > > Emacs! > > Negotiations are being conducted for use of McConnell > AFB runways adjacent to the old Boeing facilities where > Doc has been in rehab for the past 16 years. I think > they're hoping to make it to OSH this year. > > > Bob . . . > /9j/4AAQSkZJRgABAQAAAQABAAD/2wBDAAEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEB AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQH/2wBDAQEBAQEBAQEBAQEBAQEB AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQH/wAAR CAGqAqsDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAA AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkK FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWG h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl 5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREA AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYk NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOE hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk 5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD+/iiiigBr8KevboMnqO2RXxF8fND8da94 t8VavoOj6wJvAPwK+M1x4D1q30i8vYh4+1K1+GWqeG5tEuotPkji1611PQbz7D9na+1EXMNy LOBzBcR19uuSFOCAeMEjI6jtkfzrN+22ojhLXVvGs8rWtu5mjXzLgO0KQIXYq1zuRl8jBk8x JFMeUdR5+Y4ejiKVKNeTSjWhKCV1eSlG+zXT9Lm1GcoS5ox5t07pW2vvZ7JP+mfmv43+BHxP 8OeDPjL4Zg8VfEbx7pk3wAggubafUPH3iKTx14y1jU/jZbzQ6Rb6nrOtvFrWnaLL4FsLuLSr mW/a2stCnkgjI07f3vwk+DugP8Evg94c8S6N400zRtJ+H+iW2q/DrWta8beHntvFjSX2pa9q GpQr4ihvYtRuNevtV1CAXtqLv+zri0hC2dnHb2Fp9ral4p8MabNHZ6r4k0HTprkBILa+1awt J7oSsIlEEU9zHKxMj+WoRXMkhCJ8xArjb3UdO10yT2FzHfaeks1lHNEsqRySadcS2k/kyts8 +KK4gliFxEXgnZGkhleIrX4V4953jeEeDpZrlGNlhsxxGbYbCYStTjCcqb+rYucvaQrQqU3B fV9U4TTdnZq7PVypSr1pRnTfLaTk2kkleKVnHVOz0d00lp1t4zbfB/w9c3vhu+8Van4i8WTe HfDtnpMEWseMPGkkBu9MtPDtiviCG3n8T3VtaaxNHoazXV6lu+oy3V/d3FzqlzdTXVze8xpP 7Pmj+G9c8AeIvCviPXtH1jwj4f8AEGk6/dTa/wCLtb/4TfUdY8LSeH9P1bWbfWPFV3aq3h7U Lm/8Q2NheQavE19f3KRS2M7Nfv8AQpiQkEr0ZXHJ+8udp69snjoe4oEaDOBjcwY8nkg7gevY 846V/E68ZvEuK14mrK3/AFDZfLXTvgetlfsm7Kzaf0bwdB6uC/FeXf1t207HwTpf7F+tWVz8 SRqHxWttY0L4g+F9O0F/CR8OTaH4a0zWNP8AFHgPxCniCTRLDX5tFlvmsfBQ04XkWlWuoP8A 2iivdNBC63Hpuv8A7PHiG08G+F/CXw38dQeB7Xwd8GPFHws0qHRbG60WAar4h0rwZbw+I7e4 0i+W7tGj1XwpearcSr9o1CC61dpoLl7hZZZ/qdo0L+YSA+zZnP8ADktjGcde+M+9KAinIIye M5z+YzjsPT617OE8f/EWhCnRnmtCqoLl9pUwmVupN6Wc74B+9dbX7X2M3gMM237PfXqlf3dU lJvp2SW91dnyv44/ZlsdQu/iEvwzh8IfDLQvGXw10bwNJ4Y8OLdaFoutX8Nz4/gvNc8QjQbO xglul0zxbYx2czWGq6g82niP7ZZj7PdJ5n8V/wBnPxFb+OviH47+E+m+D/D3hDxN8NvDvgvV PAFtZXNtJrCQ+PPButeKbmPSLLw7qemHUNV8O6HNpNpc2sceppIttOl/YiIyw/eZVSHyygOg jf3Qbvlzu4xvbkYPPXgYY4DPvJDMDkMPXaV6A46Ej9etel/xMpx9Qty1cJiJNrmhVwuW0YKN vijLD4PnclolFpQak27SimYyyjCySTUlbW8ZSu3pe75rtO3W9um9j80fgt+yR4i0S4z4ti0k +GPEvxTsPiBeeGkbxDOulaFpPgj466LpujyWd9YadBFqS6p8S/DN3LBG1nbH+ytSmlubq5tr Fb367+KHhr4i6H8cvB/x08CaX4V8fR2Xwx1r4U6r4U1rxBq3hOezTU/F/h7xhb+JbDUdD8Ee PklSNdCn02e2l03S5InubWePUpAv2dfcgqht4HzA5zk9cEdM46E1KpY8A4AwegPTp15717OE +lJxjTglXwWDlK+rhDDtWVrWvh4b21+T6GTyXDbRnUWnVzte+uvNbbb8VofFvxZ/Zn8f/Hv4 kXHjzxXe+ANBtP8AhRPij4f6P4cg8V+Jddj0nx1czeL28MeJ49f/AOER8L3MkNlP4gtLu5B0 8XVusVxDDb38SQ+b5Zaf8E+fFeofD2bTfHHxB8HeJviRqeq+D7K61mc63daZo/gfwBo/ijw3 4f0TR7ydIbi5a60L/hX8WqOuhaK32vw4Pt19rtwI9RvP0m3PnIDZyDnA6ggjjb7D/OaBJKGZ gTucqWO0clQVXjGBgEjjGe/Ne5S+ljmsZJ4vh6jKPanKd9Ld5QWj7vr5GMsig1aFeaXZN23T 3u7XVu/Tc8K+CvwL8YfCvwb+0dZWXifw4vjX4q/EL4j+LfBuq2sEttZaLc+ItKEXhiTUzNp8 pmj0zVne5uJLfTL6AxFvKguyTb180eFP+Cdeq+E/Enwn1/8A4WxYeKdO8KXXiaHxvpWqQ+IY bPxX4d8UGXSte0+e5m8Qa5HfLeeFLy+0d01O2CRrFHbwT26P9ptf0JS4mjd2XKtIx8wlQclj luq4HPPAA9OKmnvbicMJpN4Z1kI2xrl4/LKn5VB48qPgcHbyDls+7R+lvkUqT/tHhvNI1E0o LCKm4OLs25OeaUXe+yUWrNu62eP9gTTahUpyvr+8lNO9krK0Xp/w9j4IX/gn7qj6R8YI18a+ EYNf8R654g0/4M6jHHrE9t8M/hJq3xN0T4lad4Nt7V3jgtTYXY8WWW7T7W4aRddklXUxbXVx YQ+LeIv+Cb3xx8XeNdBbWfij4F1jwV4Y8efCvxHoUN4niKG9s/CfgbSX0i68M22h22iNpx87 TZbGxj1F9bkkgXSLbzv3mq3T236h6ppVhrdm2n6jG01q0wnaESSRfvQ7S7vMhaOT70jNtEgX nGMAAbllfz6PY2tjYP5dtb28FjFAVR9lpbxCGOPzJUeVisaIodnaRvvMzN81evgPpY8AucJ4 3IuIsNRVnWrww9OvOnFpXnGjHOKkqjvaPKoPR35VYxlkGKv7tTDu/Tnqb6W19lZ+ev8Ak/l/ xT+yj4t8V237RmkQ6z4Ni0L43eKfg74g0vU7mwnj8QaLB8PLXwXaa9p2r2EGkO1+l6PCLyaO q+JXgVNVlEkFh/pBu/BNR/4J5/ErUfAGr/BS48afDr/hX2rfEBvHp8cRaDct44iDaLbxReFX 8NpocEi2Gnatbpb2+sp8Ulkm0qztUbRLaKZ9Jt/0oXxLqpmaRmDIQiMpjh5UBuMrECPvk8DO MdqvL4luiDuti24LnDhcgBcH/j3OPur09Pqa+qofSj8I8WlKGK4io+VfIcVG2q1/d1KvfTfV GUsjxsXr7KW11Go+601jH8Lnwh42/YNfxLpps9O1vw1pmq6h+1Hb/HrXdWl0zUlOo6DY+LPi vren+HEuoZftEusWel/Ee006K5/0eATaZdyeZh4XH3p4CsPG+maXqkHjrXtM1/UX1y7n0670 2OK3gttFlgs4rHTZjDpmmA3UNzHdvLI0M0uy5izcSkLGgPE9xkFrYgqGC5kUcMQWx/o4zkqp 5zjtjJzIfFEzqyvCMMCrASLkqRg4Ig4yCenNevhvpH+E2s/7YzFJ25YyyfMFJNaap01207pr pa+TynGX0hHol766Ky12PkD4rfsyfF/Vvjlc/tAfA/4w6X8NPEmu+A7P4feIrDW/CFtraXsE d80x1dTqg1vTI7iA6f4Xkt7GDQrR5zoYV9UgW+uzN82fGv8AZE+J+lab+znZeBNastX+MU/7 QR+K/wAWfjHa/D1ZLHWPEA8Y6j4istR1vS7ez1vTdHsdGvvGt9FZ3LW1pp66dpV06aZa20h0 20/THX7yTX7VrW4aS0UZMU0LQMwZopYSdstu6nclxMhBHHDKQwBHk+ueBr/ULO7jg1zM0Nlc vp0ctlaMz3sNt5WnG7dbq1jkgiz5bIi2YeNx504kXzjx1/pEeFGIr8v9t4+nDdOeUZkrNNJJ clGb2fp1umV/Y+NUbuENbfb22eq5flvbsfI+qf8ABNO91C68N+PY/iVpF38WdJ8e+P8A4k61 rd74Wv7fSfE2r/FGx8JWfiS1McWvXen6LGjaJr11DeWPheeOdtcghttM0hdOt5V9w8FfsX2n gzxn8LvGGgeINF8PJ8N/A/jDwpYaZ4Z8Lf2VZnUfFFz8TJV1mytdP1Kx07TZbM/EHz5pI7GW 6vJdPlheeOPUDLbfYEfiWRAwaFGaRQZAjlEywIyu5JCGLbt48wgKE+VM7nytT1zUbhJBaSw2 EzxiJbvykuWjUklsRyssLcnPzISPWvQfj74QUKalU4jxTsot8uU5s302/wBmXz8+llZ4yynH O3LCCatrJprWz/lfTfTS6v5fGvwy/Yx8beD/ANoe2+OPjb43yeObbw/rHxS1Xw7ot/4auI7u 2j+Js+oKbSfVrrxHdC3XQNPvbfS7Itb6gl3Z2ixW8WkQlYUg8OfsJXUnhvw54P8AiP8AFK08 aeGPCHinXJ/D+iw+EX0kQ+DdWsPBmlxeFZtSsPElpqYu7fT/AAl9kk1i4uNQ1E/bhOtx9oid 5/rNb7xggjCeKLd1O4YOhWRIHJViVnXJ4wcAA7sgAACtzSNZ1a1tpItWvotXlkmY+fHaw6c2 x441eNkhM8RVmRn3qsbKXI3bQoE4X6QvhDUfK8+xcddHLKcz1Wm9qDadttPXyzeTZjFbU3bX 4ntZNfYS002fXpa6+DfA37BnjzRdE0fwT4w/aGj8YfD3wf4V+JOheDvCafDOy0o6br/xH8Lf EDw1deNRrtp4p/tu8m0+0+KXi2w/sG9vL6xvIZvkvbGYWa6X75YfsuwaRoXwS0jT/F7QXHwS 8O+MPD2n3r+FRexa6PGj6LJdTrpl54hltrOaxTR3RknbV5pPtE0sdxaNG/newePfE/in/hGr tPBuo+H/AA/4gnntYLbWPEWnNrumaelxMkE942mrrvhdL2e3hczQWp1aPznj8kRTPIFHkln8 Udf8KwWC+PfjZ8Mrq8tbn/iZzW3hSDw8NQX7JqEX2U2svjrW2tEiuLvTbj/R5DcBrBY5Jmhu rla6p+P3hHTqRi+IMVW503F0cnzecUrrSbWESjK1vdu7Ls9BxynMUnaML9VKV3stNItfjfS1 tSf9lz9mJP2adJ8eadL48/4S9vHPiKLWALXQn8G6NoIjtpoF0/SfDlp4i1bRbHBmYLJpFrpG 20hsrEQfZNPsY7bh/Cn7DXw38I2nhDTre4SSLwl8P/H3w8t3bTNWYzaV49k+Is+qStPc+LLm eKJE+JGqReXLJczSGCRYLyzWSAWXeeNPjsNK0q9ji8R+EPDl1qGk6hHp2p3N1aarKblbaRba 8tNKOoxGdreSZLiOCVZ4p2xbSCQtgeVaH+0J8XLvUtZ1DQvD1z470zWE08aPjwP4i8LaToL6 bBcR3dqNTv7Yfa1vLvzL2aTVL/ekrGxspIleFF7I+OvhVU5Zwz2vBppxlPLMxjZpppy5qCaS e+jaV9G1YxnlWYXXNST1V+Vr+7pstbK+m1/M9h1/9l/4deIv2fh+zbqC2s/hRmivLfMeo7oT H4ybxl5qQxa/DqgQ6i1xENutiNfNIA8gfZBmaX+zToN1dfDy/wDHfiDWPiL4o+F2otqWneI/ EE/iFzd3k+sabrFvKsNx4r1GBTaR6LplhOt0l9Gy2qB0aPfDJzHg7x1+0fqXxYtNZ8VpoOn/ AAqvPDklpceA7Tw9ZxarB4kW38+PWR4rfxFfau0XmRG2a1/sL+zJFJCTJOVkrvdR+J3xIufC vh6az8D2ln4jvZtRTXtOk1GK5uNCgiuZoLTULJnkhtp5RAYrpBNBqNu7yxCS3ePMcnoQ8avD OrFTfE9FKy3wWZX+y/8AoE89Xd69Opz1MqzCS9ykk9Fq/Tqot9Vbd7LzfMeEf2Nvgd4J8DfE f4deHfCem2mg/E/WPDeo+IEgXWJYdvhU6Td6JpzLca/cTxW9rqdnd6nBDY3mnwNeazeSy2s0 s1xJd+ufDT4ReFPhNomtaH4PtV0XTtd1ex1bUPswvYVOp6d4V8LeEIrxxc6ldsDJo3g/SbNW SeFfLWKMxvKJZ7j5d+HXxJ/aa0fwvpdh4u8Gr4h1TTzeyXeparDo+m6pq0b6je3kQmt/D7aZ pVotnbvFaxfZNKieWCBZZzNcSvM3NS+O/wBqrxF4j+Io1TQNMsPCN7YWI8H6NFolhaXmnG3u vBrSrF4iv9amTUxPdW/iO9kF/pe8/bZYbZooLOxCL/iNHhlJ3XE9C17WeCzJPdX1WDe721va z06ZrKs05VF4eU7dYygla91a7UtG0tV6X0v7F4O/Ys+A3w8utYl8N+Cba0j8QeGPEfgudH1D xTe2ll4P8R3lhc6noUdvqfiO+trCzmXT9LjdbKK1do9OjCTQxxhD6lofwO+Fnhuz8X6d4c8J 2OlWvjjw/pnhXxIuhahq8L3WjaINfGj211dW1/Dcwm2bxNrIimt5ba6/0mYm6lIjEPkPhHxV 8e9K8L+GtOv9P0e4vdN8JaFBqYmtdLh1GDUo9HsPtrzLb6ytoZTdLclooLEQK4VYkEYCSchr /wATv2tY9Vu7jT/Cnw2l0fTdb0r7HYPpc0mqato934hW21SOC7X4pxeVc2uhxrP5o0e4dZZP NNoflgER8a/C9ydN8UUY6aSngsyUdOXqsHJ9bJWd1p0Mnk+apuSwsr+UoeXn/Wncv+If2GPh Lr2ieD9LtdMsrS60T4z6B8T/ABX4iuYddbxR4yh0Lw7Po8OjQ+Ix4kfxHZKkSaAlvdwa2YLA eHlkhsvOjDV399+yX+zjfabY+H7/AOFPh690zw9rUuvafE66kdZk1/Vrq+1e+1KXxYupjxRq 17faje6hd3q6nqN0Pt10hxK1rbPHD+0tJ4t8dfB3xH8OPA89zoviTxy+kaJqOsWdrp2sXmge Er/WLaHxPqFtZavbf2Pc3MmjW95Y25uQ0lvLqEdxb289zBBHLyXwnj+Lnwy+EvgbwDc31l4k vPC9vcaL/bOq6TpljeXuj2eo6gmitf2uj6paadBdPozWEd01sls/mwSPJBazvNFHrPxl8L42 f+tmCb7RweaLtp/uC+/XVfNiyrNm1bCzvZX96CStZLd69O/zO/1D9lj9nnVIPB+lah8IPDAT wzYJY+Gry3tLrS5ND06G2soJdOg/s65tHgiu7Kwg0+S1NzJEkDtB+9jklSW/Z/AT4HyeOYvH OmfDzw3pvi/TriynMmkefZyadq1pFaQ2N9dpYXNrCuowaedPnSK500vJYfYpHlaFoSPmH4jw ftc+Mbmxt9L8Z6D4RsdF8Y2Gv2zaT4H8K6sbzRNH8UaFr9lp2pf234q1KUzta6DPYS3Vn/Z1 1IuoSTLZLcQ2yVheDfCP7TXgTxz4p17wt4o0aLwv41+IOg+OdX8Man4Q8OyHUZ9O8F+BfA93 aJqlx4rttXtbe6tPA1nIn2WO3uEulcwGWOQrPyT8b/DCP/NVYdrR3WAzVvp1eBV/nut+htSy jNYJ81KOuqSkrq/Lo3a+mvXtdn3R4/8AhB8M/izDY6X8S/A/hbxrDoN59qsF1qyiuLmwmuLO S3NxBdrGl7GZbZYoJ1MwjnURGTzDDERxXiT4D/AHUdF0TS/GXgL4aXnh/wALTMfCtlqfhvw/ aWHhqN7S1t4fD9lbsIbfcllpNtDLHIweWHT7dJLaRIQYuLt/F37Qi6prWrXK6FdQgRmz8OW2 j6dHBFmWO2lAu18QXWpSSR5FwFluDx54MbRqDB8ua54J/aq+L/hjX5PiL4n0K6ay8ftqXgHw Nb+B9D0zTdF8MR6fqzW2tXuo2fjaHXdX122N/Y6Pi+1uxspbeKaeXwq15Kbu1w/4jn4YTu48 U01y2v8A8J2btO70ty4CVttdlta7vaY5Jmjcm4U1e1rzeuut0oad/u6bfdF18GPgNZ6NpNnq Hwz+FkGh+FrsXdjv8O+HYrTSnuLi9/dWlrJZQ2mmvf3euXdufKnj+0vq9wrLK+oyxS2dE+A3 wK0dNU1DQPg98NfJ8Vy2mo6m+l+BvDUI1eJDd3di17La2Ei3xtnvjLFcOZCJBI6nM7tXyhcf Av4gHxX8Qr66+Jt/4u0DxvqnhrUZrbVPB3huzkjn8P2vw8ksmgm0CbQ7sSWmq+BbO8g8yBYZ JmaC8t9Qs2MFz1umeF/2jbTVpJF+OiQeF9IOnWXhjwUfhr4Di06DTYdHutPvLXV9burqXxDc 3kd3FY6laXJ1XSMTQ3dq9pfW1ykdlhLx58LabtPiVS5d+TK84b0aWi+oJvTZK+uiV2bRyDNZ WXLR10+OWt7L/n07rRW37en083wi+Elvro8Vy/DXwG3iq8vFvJ/FI8H+H21/+0heNqQ+1as9 mt+lyNRmm1ESm6ab7a01z5YmBkOBdaN8INO8c6xqjeHPh/pvjbQvDtrrviPxXN4c8I6X4i8N 6He2PiGw0W+1nW0jXWNJsEt9F8QNBc3lxaWbacl4kE0sK3scXmXgOX4waNrvjfxP4y+LTeKU 17VtW0rwb4dufCPgjStA8JaHe3h1DStJtF8P20HijVda0YH7DHdeI/EdzJd2UgGo6RLqAF/X n/jj4B6f8SdM+O9l418Q3FrfftDp4BtfFQ021to7bT9I+GtvYw6Vp+mLHeXOyHU1trwXlzLe i+8/UboW1ygt7KG05an0ifCelqs9xdVr/n3k2bO+1rc+Fhr0t/S1p8O5lH7NJ69JyejS/uLo /wCtL/Rmnan8DPi/crp9tqHwi+JeraMJbdrd7zwd4v1K3j0sm2uLiFYzq17aWsE2oSIZFEaw vfSW7hBduJO28L6p4Y8Z6XHrvha+8O+ItMZWs7DW9HudN1yGZrKa40zULq3WyN3p8EdpqWmS wQW9peSRJ5QtmayaA26/HXgH4Cab8NPDlvofg7WE0uCz0LTPDEU0UAvb670rRV0e0tnmXV9Y 1SFJrhdBsbidorSFhsIjEaPIZHfs/wD7Pul/sy+HvF3g74eeOteudB8UNaWo0/WLHQbubww4 uPE17qFzaz/2et9dPqWqeJdQ1GRNWluorcxQW1msNoDEfOr/AEm/CmlT5Vjs7kk2+anw/mVS LvbZql0tZq67m8eGswqe9zYeKb2lOopdFsqMl+P3H0fB8XPhLq/gbxb8SLLXPD3ibw78Pxdf 8JBq+hal4b1GOzaKws9Rvo7i+stVOn2wg0m8s57hNQvrdfsrO06x2rLJN2/g7xHoHjbwXovi rQmN34f160t9X068gmgkSXTL1Fm05IbrT7u4tVWG3ltLfyrO8ktcQsySSbjv+EvhR+x/8Lvg t4U8X+AfAmp+KrPwn8RdKutP8ZaZcarpt8s6fYdas5ZVvr/S7rUrM3mm6s1o32O+tlj+zJNA UuGlevbvBvwz0jwF4K0bwZ4a1rVtL8M+HjeR6TZl9K1OZF1HUr/WbmVru60+5upPPv8AVb2b bO8nliQJEY4Fhjj87/iazwtoxlTw8+JK9a6tGPD9elG3u8zVTFVaFK/ZOSk9opu5pT4WzFy/ iYTbf2la3T/pweifHD42eBfgD4b07xB4/jvNR0rVb++trRNETRoZbaW0tbi/vpHj1DVdHtrk BFYQxPcFWYFX+zozEfPfhr/goZ8EvEt54QsLHT/Flja/EDXR4b0rxFdz+FdM0W21KJdHlXVr y8svFUsL6bMfEOmS7rd58QhwIXjmjWb2xbPGialoDTz6jpmt6fcaTqYvPs8Ek1jeQXFtchHt YLGSORobqZA0BV1BDJhwHryDxJ+zt8IvHPhHwT4M8W+FpNY8M/De0ttN8F6b/bniSw/sWytI fD0FvB9t0vV7O/1HZF4Y0NPM1a7vpm+w7nkZrq8Nxl/xNbwM3+7y/iqqna3LlmWLt/z8zen3 6r/g9kOF8fH4qmEei/5eVt9N70E3rff02PpfVfit8P7dnmg8S6PrNstu90k+ga1o19ZgIssM 3lXcGpxLMyIk0cqEKiyuY2IK7xxWr/tG/CDR/EPgTwpca3ZNqvjhL290m3kv/C8jwS6Vf+Gt OnFzFc68bv7U914usTbfZoJ2CeepaJmgjmyfCfw38DeB9AtPDvhjRf7O0mxnmubSxOpaveGG aa6e9lf7Rf31zdSbrlmlCyzOg3bFURgJWhP4Q8MXl5HqFzp4N7bTLdwym8v12XEbI6OI1uli bY0afKyMhxhkIJB+axn0qMrnUrLCcMZrKHtZ+zqV61KlUnBSbhOpSpZzOnTnKNnKEPcjJuMX ZK+0OEuaXNKdDnk7ytOrbndua37tXV9Nkteh7Xqur6Fo1u09zf27yWNhc3E2nq9n/a97GkDq U08S3a3SuTFKF8mSIbgw3AhsfP8A4l+OWtXItbPwR4F8X28r3FuHl1O0aKLYWmNwJXSy1xlU gw4JU8D+AY3dekEAmWY4LspQsWPCOrqwwDjkSOM4yM5BBAIviVGRgMAsCDgk5HHr05A546e9 fM476T+bSVP+zMnnhtJe09tVw9XmXuciTxOKr2UW535LXunJu0bd9LhehTX7x05cyXLySqOy XxXuo9WravRLbS/lUHjz4z3V9Fu0yPSbcWk159p+03DO8sbWdslo8b+CraMPKt5NPt+0NgWz MInKB4rnhy7+Lsevxap4p19n0iBoIhpEdkjrfC4vY7iZmml0fTthW1tHtS6rO6C6DqybmD+k xSCHB4yjiSPJxtfbKjEHkHKTOMMCBnIGQCIVxGAIhtXLsedw/eeX5hy2T8wjTocDbxjJz8vi fpIeIdWTeFo4SkntKc8vbg9Pe5HSqRlyr3kmnF2s002dMeHsEmvd9fenr3+0dY3iydxiLTXi 6jkp14I/5dT7/nVWTxNqIUsJ2gBP+pV4zswccgxJjd977o+936nnywbAZgR9R/SmPGjKRj5T 0Pzc85HcenbFfN4/xw8UcxTVXP5RUlZ+wwuQ0tLb/u8JT13ej67noYfI8tWvs5NX/veWulS2 3XQfrUa+IoreHVZUvoIZ0uoreSQqI50V0SYGEo2USaRBn5fnPGcVjxeGPC9vIzR6HpPnS7fP mkijleYKrKis0qOSFjJQAnAB4FaCRRh1yuw/dDfOcklcL97HOM5PAx71aKSR5AXIUEqS8ajk c8EZxnqSfpivisdx3xhjpP67n+MqTkkpKcqcW0kuXXCUXS0t0k3310PWp4HBYeMYU6cEtWuZ a3la925S079OulrOpHY2VtxBp9lDGhIjEFtAgCdFClIV424HXkDJzUnmOZJAhZB8oPUr04OO mBzxjBBpHmlRgzghPUNGFyQQOdjE/UHB6gUiSg+Y5uV2tt4S3dymAwAYozZyM4O1Oh69vEWO xuIqKVfE1sVUld8scXiJSk2rv93KcIvrLb3bX0aOpQhBaQp62+zJ9tbKLu9evf71d5l+659C qcMc44+UA5OcD9OtRN9pYZxcjvn95xzjGcjP50SSrA4CsvlMMtLIfsyoB1ZvtBPC9ScqABye c1Qu/E/h7TlJv/EWg6cqEKz3uq6fCgLEhQWluYlBY5C/NyRgAmj2M6km6mXzq9/afXJdtvZq a+69rs1jLkStGn0s1Fppe7o48qd9ujtdX7FpN7rscuGQHJfOckkjIJyOPXtTgrPg7jgZB69x XmOqfHD4NaVKUvfix8OYpmby2ii8V6LdXauqqdptLXU7icMQw2qYQXYqqBmYA8zJ+0P4BuY7 n/hF08VeKpYHCLFoPw++JGo29zIXwB/aFj4Nv7SMGJWuEYSFHiAkUtGyufTpcO5vVjTqUcBO FKoozpR+s4CKUJpSglGti41oJRkrKtCFWK0nCM00bxcpJcsUm1e+y1te2ln1SSu210se5fZ2 Uljljj0bPb69KejKxI28rwTgdRx+fH86+X7747fFKckeGfgL4m1FSF2T6tfX/hxSwz5oaPXf C2nMgQ7QrO4EoLNGWCnEvwp+NPjrxd8QvF/gLx54Di8C3ulabomraTt1L+057uG/hs5NSBMV v9mnSxbV9KLzRSBd1xGpRPMKpriOG80jQqLFUYUU43pv61Rd5U3GclbB1astYRko+0Sheyvd XE41XZzcdly2eq2vdKO1tVbW/R9fpbyvMcEShAnUZ4bOfcdMeh61na59oTRdTNrqCWFytjdN bXzwQXK2U4gcxXTW1wfIuFt5NszQTnyZVQxy/IzVYkPzRscrvUEfu5IwwPRv3u7rnoMYwMjm pmij8ttzk7gRkYB3dFKnDDIwMAgjI+YEZB87AYueEr5DmtHEV6VOOPwydP2WHnWboYpOWlRy Vn7GVn7RO0o7a8pVpt0pRbupQlFK3Xla100Wv/B6n5qfse+N/i1D+1h+018MviJ8aNT8YWmj X1vrHgbw/rNtYWEH9neLr7VfGUEnhYPcy39lY+F/D+pafolzDo0Mmn/Z7mxh/wBGsPscZ+Hf +Fg/F39m34h/tB2Xhz4zy+GNC8JfHCfxHp3wk1ODS5pPiN4B1bXPiJDNpnhnUfFI1LWbrUb6 z+G2k+GdMWx0y+hRtUWew1i3u7m9t9S/bybStAsvFn/CZHQ/I8T6cL2xs9bkv9R23MN7FBZz olm8x0oyPYWMHmEWsjKYXeJYHZzXNa54a8N67q0et6zo8WpanYTwra3M11q8SyT2dzc3cLrF pl/YW8ki3FxLJHbiN2kE8isJkWFYf9QuH+JaOL4awmMlTxVSNfDYfFQShR5/Z1oQqKEk60Uq kVK04qUoqSajOS1f5hjMBUhU9nCpRhONtZSla/u/9O5dtdLarpt+XvwR/aH/AGs9c/ac0Oz+ IPj2Cz0Gz+Inh3w94l8FeKNUi0O91jQ9S8KeHbqGXwvYv4CtpLotPrd28ghOitdahbC1e/cF Z7X90kuoJI47jZcS291Ncs1lHltUjkeWWaCRkWXzZLIRrN5UzXKq0MtnIsAWRUg+XvGviv4b 6J4x8J6j4u1rQdK8RapfaZpfg2/vb+8sm1u/l1W208WWnWBvvss97YXuq2MccEiTPeXOo2kJ icSRRv7t/bscOl20yXNut1enfJcw3NtLOY4WcW95/Z22eSB5beRY2SWLytt5JIIUdIWg+ijm eHxCpunQxMEoRg/aQpRvJO7klGtP3feVm7O6emiOWEZ0k4VakKslLR07tWsrR1hB3vd7dVr2 6+6SORnYeUSWdsxbWj5JP7tlCgx55QhVBXBCqOKy5hjGeQmSPbcBn88d/SuWbXdRMamOFMtI ARGvmBAVztB+YEKejEknjk9+jhDyRKzuxL7gysgXaFJwRhVJ3Z564x705yTT5U03a3Mlps3r d+vbbdGkfeaSTs09Xaysl5t6+XVa9bQPKCSOcD6dh/n6dK9W+Fpz/bvzBv8AkGdMcf8AIQ9P WvMGt4uTu255PPf15PGeleofC6Ly/wC3OAM/2Z0Oen9of7TevtWuCv8AWad/7/8A6bl5Lr/X RZYuDWHqPT7H/pcfI9Zooor3zxQooooAZIMoRnHTuR3Hdefy/lX40+M/AH7fl1MsHgrU725H wp+Mniu68F2UvxCsIV8deF/EPjfxV4i0m68bS3viG2fxBbaDbaL4d0XTbHWLrSLqx0fxBqGn CwvEkvLjS/2WkYIjMzrGBjLuQFXJA5LcDJOBnuR3rjbrxz4MsNItNfvfFvhWy0C88+Ow1y68 R6VbaLfSQmT7QsGoS3KWEkkTW0/mLBNM0fk3O7b5UgrjxlJVVSTbXLUTXndxv/6SvTXua06s qd1FJ3d/O9unyPi2w/ZX8V2fiPU9R8ReKPHHjxfCHw3sk8C3fiP4peJb19b+IF1qXxTv9Qk1 y1hvdFtLy2sIb74dW2nTahaWEMDac5jaU201zL658IfDXinwj4DsNC8a4XxJHrfjTUruFdTn 1lLa013xv4i13R7RNQubm9mdLPRtS0+1S3F3PDZLELOB2ht4zXvN94y8IaabMaj4q8N2supi OPS1utb0u3e+eW8awjFis10hnee+YWCi1EjNcoIVLT/ul5vU7iOW/mliZZY5FhkSWNxJG8cl vE6bZQSG3KyyKQSGRlYEqRX8sfSscaHBmVRUm+biejo7/wDQuzaVraPdNq/zSPcySdSVSoml y8spXS6qUE+mt1LVdHt0vVqMSqWKAMWCK5GBwG37RkkDJKMOCQCOSAQaVWJJz0xnH4ivE/jD c6jdT+DvC+nazqehTeKNYt7OS70m/vbG5SGHWfD7THfp91Y3hzbyTxZguImCSyguqM2f4Gw1 OWIqcvS6T3b1t18+7va7dnY+oiuZpXSunq9lbX1emyW/c9pd1BG4MDjp8uR164JH5E/zphIU ZPQAkn0A5Oe/5c1863nwW8diTdonx28YaVblVPk3Saz4izLkrJKLjWPGM0iB1CIIF/dRsjSp iSWTOdP8Jfj7Ft+wftOXMIBHli5+E/hfUHXaPl3S3urTyMwbkuxZjwCSABXbVyakptzzHAU5 NpunVjU9pDRe7NqnJN9XZvy1uWoxbSUtdm7SWundJLq93bzPpoSI3Awfwb+ppdyjjAGO3zf4 18vr8O/2mbcjP7Ren6jjnFx8MPCliCOm0+TbXeN33icEg/KARzT08KftNW0oY/FjwxqUakEw TeHdJ01ZAQMgzW3hS7ePByAyKxOc8EYpRyOFuaOcZNB3tfEPE0oWaTaUoYWtLmvaycUrXbaa 5W/Za/FHbu+tr/Z+7brfZn06XVQCcAHp97vz2Oe1CsWxsIzx1yBg9K8DsrP9oW3ZBcXngLVF 2lS0niS/08scE+YVtvhfcBTxgxhio67iRiujGo/GC3jcTeGPA9265G6Px3rgxtU5OF+FfRiC Rx9K2hkmn/I84atfW+Ix3ktLZZ+f+dmqN9FKN7J7vq0u3e+jae3meukSAZ39PYfrhaZmXqHB A64A49Oqjr7fjXhUvj34pWYLy/DGO6C8lLTXdaZyD2AX4eJkjGT9RWdP8YfH1ou+4+CPiOcD K7dPvdcu5GOVGRE/gy2XaM5zu4GTjjnnrZLi5r3ajS88XiNtO1C/Vff5EKlJfyu/SLXkvtSX Tz6fN/QP77IyVIzzjrjv1xzT2GR79q+V1/aQ1u2lmTU/2ePjsAC3lNpPgm61FMqxB2yTJpbE 4BMZAJcbW+Qtw1/2p9PhBF98Ffj/AKXnnzNQ+H0FvtX++ftGuR/L0GScAkc9K4Y5BmXMqdOE a/NZtzrVavK1bS86KcU97J2+epSoy0srXtty21t53/A+pVVgzFsgA+x/hUds9T69qcwB27j3 3D6DHTAznkcHivmK1/aw+G6iM6rp/izQHYPvj8R2ug6NJCQzBFnjn8RnymkC5hBGZFKsOtdv p37Q/wAENQQTf8LV+HlkzKrG3v8Ax14Rt7hCxI2SRf225V1K/MhPGVHOeKq8O5zSsvq8Yp2u 6cnGa1XwtQjrt1XrsHspq7SbtqnbR2a3V0+u2n6HtKgDOOQen8jngelKS/QMAO2CeB6en5ce lec23xg+El6pNt8Ufh1OCduY/HPhtwDzkfutTcdj7jFbcHj7wPMq/ZvG3hC4VxuRofEmjyoy YBDK6Xb7lK4ZWGQykHODWFTLsbQh+9WOW21WV0tO9RefyIvLS6V7J7dXZdutrfh2t1RDt1cc epP9BS7JF9COp56fXOD+VZSa7o10AYdZ0i4Axzb6hZzgB84LFJMKG2nB53YOOlXY7q3lwY5o JemCksbkk8gAKT83fGe4rzp0403zTWJ5tL8+Ilza2SvbmT0V17z87MabtzJK3krW1Vuz39df kTFWPBII9Dnj6YAx+HvSNGCpwBvIYZ7MDn5WbG/acKDtIYAfKRgU4Ek5z8vYdwff/wDXTqmL otc3NOHS9WXtou/RRk4pPqnfRJpbsV5PS23Sy8raP+te2ycYYnOc8AEgAd+4OcZ7kDAxjnMX yYIO4g9mJYf+PEn9afvHof0/xpwIIz25/Sspyp1rR9vBaWX+zx627VNOy1tqxq/8lvR+ndL+ m/OzAuASoAyF2glsAcZ6Hjj0pduAdvXBwCzY3H159hg9RzjrSNuwTkYPOO+CeO39aiaQRqWJ wB16Z4BPfjoD3qJTfNGFPBTvolJU6Vm1b3rXbtK1/n5D5ZOybXyu300/BfMq32mwajZTWd6n nQSoweHzZYwCMlZI7iFkvIZUOGjmguI5YnAaJkYAjz28+GXw3uI5ItS8KaZqgmKtI+qwyazO JQwkZkudXku7hCz8F0lDvGqROTGqoOr1LV42ikiRyNy4JV0GQwII+Vs9+ueormlnt2OGZzn1 fPTn/nr/AIV3U4YynFOMMwop68uGo05QlZJJzf1vD2fZKM9N2r2dKLhbmjd3vstlbq7a/jv5 mBe/Cv4bzXqahfeGLbVJIbdo47fVLnUdVsbcPKJ3NrYaje3FpbndEqL5MUYEI8nHlfKOysor ewshDYWen6VayRtmy0u0SztFmE0xZ47eFBGnmB4zIwAdn8xhhtrVQZ4VaM4dkdgrAsemRkE7 z2bkZ70T+VIWWMNGI9vViAM4Y8B8cgd/Wu+lSxNWDU3WcbWl9Ygk7bSvatVSVvPpc2U4W1pR b13t1tvo1fa1+nzNBrpid++WGdFSCOW2WIEWyxqxy0wdhM0+/LqATCQhYZdTXa7faI2bbJFE 620ybjLJLIEby72aQtJLbJIFRACXEKKGLMAazzOqr5SuNy/7QJ9eQSSDg1CkjHcSNxQsMjvt YgHIH+zx1rWOHjFcq9n+Ouy/l9L+ru7Bz0/+fMXbyjfp15V879fRHRTXTPLKySyBWV8luWj8 6AW7LEMMuzagkVXDBZpJZBjfioA0spVftBVEiWNWMcTuShz86vBJEVIJJOzO/DDB5rJ84MAX kWLdkDcV+bHXqVyBkevXt3a7xqCRcrng5DL0J/36ylh0m7OGturvst/dXb5a7IxlVrqTVKjD kVrJ27Le0Xs276+d0aT3YZT5hZZVlfbLDJcK9xArOIY75zKHmPkiFZB03CQKdpBM25JPJlyv mIHd0eKNkM7RqQY3MbzrH5gHSVHCgEfPknmA4RsFiSM+nBBGOp71ZM8EihCDvxwQw4HbgODk 4Pb8TWscFZe2UKNZ6fu3TVS97X92aUdOr3T66kwq4qTt7KGn/A/uaLf0XkrmlCbyGOJ55w90 LeaGa5JaZgWknkgEbTozPHGxt32zI6iVWO1lC1D591vYG5Egdk8xZVUplQQ7xqkK7HkLM7BQ se5jtVFCqMzzPLPlurup5IycHHzdz/s4pRdW3KfZmLcjsTkn659KcaDm7fUaFtL3wdB9ul1/ V/lrzYv/AJ9Q/q39z+rvtpqPejf5eZDJvQCWILl1STJ89Zm8tzINwb9ych2+78u2b7UyvHJM y7025AjVxGBISGtwysqSKDvTJCeaSzghm3YYka33SRg5yWx1Kkdud2CM47YxSm5OwXBfa7t5 WXK+hI5PH8PQLnGT2qvY037rwFHtooLa2tlSaXW6u0ul1Zmbrw1vTjfZ7LW6vvHo/wAL+Zsp qZEhCyGPdLP5syxIJ5I2keSNiQpQyqQit8qoEaUKCdhEUV48bTL5zqvl4t3jjhjKtlw8cpii QyxECAjzRK/yNlvmIfBkvWXO+WPGRj/V8557gZxx61SfUrSOLyGu03gHJ82LPC7COZQ3XnH9 a2o4KVpewwMF8Kl7OMHdq9ub3Iedt+pLrQ0tTj8lF9tNvPodW2oXEssxjxETGwia3eaIB1QN HmMyiIfvgC8ix+bs4VwQMMR7m6jaGaPzGwGkJuLiDzJA2SzSWtzDK3VmDs3m5+UMEknSTjU1 rSo4y02p6fFhtp+03VokmCA24CSUnZ2B3AFgwx1qrJ4r8IwTRLdeI9AjVy4f7TrWn2UOfLLY ecXRaPDbduEO59qEANkN5XXm7rB1E1Z+7Tg2tVrFc0btOzSckr9VutY14qN1TWiT2j5eStrp Zf8ADd65SFpvN8hUe7mnhK2dozxNIRjUEjNq0CavGqKY5xGYkOVClDtp9izSRRFlimDgiVn3 ztGIpZXiW0kvGeZQ7sftHnMSwJVCEVAODk+IPw1tFHn+NfAMGc48/wAaaQOg7edcj7uDnH41 iyfF34T27u0nxO+GcarhtjeNPC52jaActJfKeTzz646VtDJMxb/c4PGSellKjTva6f8A0EO7 6W6ELFRX/LtaW6Ru9v7u/Xp8z1a4BKygq8LmTYrQLbxqkKkMjKVG4TttCynBRleTAywIqyXC s77FEUs900l5cEFp5IXkkbKbmlhWaNJAIiIlVSACSM58Vvf2hvgtZuyn4qfDpXDbGFp4x8Gz yHg5BR9YhITKglskhgo2/MSObu/2pPgtbdfFemajyRusde8LOp2jO4GLxEBtbOAexGBXo0OH uKJ017LBZgqd3b2b9nG94392Na2vVrXyVm21jaa0lTV+uketr9PT83fp9KyyK63hhUKJYxHb nLq4AjIbzSGx80juCV3Ew7VPIwK7zyRRQxFsMYYiy5doyUURMygk4BZCecHJJwM4r5If9r74 YrA32XT/ABpq5wcJp2k+GpWZsjEai38UuS55IHXg4psH7XnhuRQdP+F/xrvIlGC1n4Us54nk yNxDReIJBkIVJUdFweAa6Z8KcR8nPWy7GVIXjdYmtKFPV6NzXt3zb2Spu/8AMgWLpt2Safyt pZdPLT/M+vGu1Aj3B8IyklCyjjk8CRcgc8MpB9D3twzhYW+cgEhsFck8LjkKfxyR/WvjJP2t JZ5XFv8As+/tC3gz8jjwRL5R5wpZ472bahPDMA+ACQGIxWnbftE+NdXYLafAr4lWIYhU/t3T dRsFG4FlLFdAvcKqgK7YbD4XDdaKfCmaSXv0/qvW31zEO23WOHh8rr0sUsRHXS9t7Nf1/Xkf YyzeaElQlQ39/wD2WKnhSwHT+eetRySMWIDbW55OdpHGcYBOTwRkAdc46V8xQfEP4z6y0MWn fDm20slsLNqesarAY9rNuaWMfDS4VAWcFcu2UAbjO0WLpv2mtRYJYX/gTQSQWDz6tPdOsZCp 5JhufhSi7gzLIWL7vk29HYi5cMSjpPibh+lLadOticwdanJWvTquOAkvawleNT3pJyi7NrU5 Viv3krXtzS3+9f8ADbfNa/TaHzNoUMSuBnKgE8Z6kHnHH604CUKTHyACcggYA5P3tpwO4A+l fH978PP2rb8Fv+GgtA8PEhvlsPh34Y18DJD7g1/oekljH/q1UqA6/vGKt8lNsfgf8dLqVf8A hIP2n/FGpWeT59pY+F28JPMi4wi3fh/xTaTwk5bLxEM+RuJ2LjlqZLgaLj9c4jy6upX9msup 18Wo25ef231lYH2al7vs1D2vNapzOHLHn641nJXtfRWv0uvy012Pr+3k8+SSMyqXTHykONv3 twJ2YPQYwT05NWpobiBHlkUrDGjO7bkb5EBZiFVix+UZxgE9AM8V836d8B9KkHleKfFfxD8T 4VctP8Vfizp0JmAYvKttbeO2gbzDsYLgLCYx5f32xvf8M6/BdY2a58C2184UskmveIPE+usW C5zs1zVr9Zwx+aSORilwWcTBg7liGFyKk0nm06lrJwWBhFzvZcsZfXpcspL3b8tle+uw+Z9W 9fRfc/8AgfidTrvxZ+H/AIZVm1zX/sLKnmeWdK1q5cplAGBs9OuI+TIuAXDcnIGK851X9rP4 G6XGscvjGcyhgDGnhnxSzAMA6ncdHWPGx1PDkgHBGQQOwtPgz8I9KdIrP4XeC45SfMjuB4Y0 ptr/ADcjzLWTJXBHXHI4rstL8JeE7H5YPCnhi2CKUjaKztLXagZhtS0isVhi4wDsbLcyNlna uiVPhunq8uzT0VWk+qX/AD911+75G1GeqS7X8rJK3b+m9Twa1/bB+Fd/Mtto1j4v8SXGBJ5e l6PptoVjDLH5u7xFrWiR4LyRKoDFwZVLIFWUx7zfGLx3r8ckngP4ReNJSQI0uPFV/wDDJbLz x2aKw+KrXfkhVlEmINzSeWVDJuNe7KsNp+6jzbjIZQUWG0wnyhVYPtLkY2AQ/wCqUkEAbS6V 2uWj8w2yI+VLpcmRiM8naYYhkcAAP6nIPBuli8ipJLD5DWrtPSpis15NbrR4NYDE0mlpaX1j 3le8Y2Ox05TkpJ6Oy6tLRflfr+B8tXuoftpas7SaVpfwG8N6fLIxjj8Sf8JNdanAis5WKYaJ feIdO80/Ih+zvLCCsux1Uxs2hpvg/wDaSvzMviP4p+HtMGYTJH4IsdKjiLS+Z5yq3iH4dXU4 jjjGbYhxIJGczMwEZX6Te5iQGCQWt0Igqr5cytKFXaqhoxHlWUHDgyNtJI3N1NZ792ijZTMF kDbVkAUIB8uEOW3decBccevHVTzmrTkvqmT5Hg5JvlxE8pwWIrU9NbYj2VGr78b05NJOSm1K ybR0UsPOUoq7s/Xtf7umtvwPHx8IdauWU678XfipqGflMVv4k0rTYWj5BjZNG8LaRw/yh2Ui TGcSDJyyX4B+C5yW1S98aa8WOWGs+P8AxfNE5xlS1va6raW+6M5MZEI2kk8nbj10SyPMuScL g+vAyx7e349DwK1FYsqk+g7DNbviTN6f/L/Ko6fZpywr6J39nQq+mn6HV7B07X1Xz30t+C9O ljxe3/Z/+CdnIZD8L/Bd7dwhXWfV9ITW52kyJQ8tzqxvZpn3BBukkdhGBECI1VR6BpXh3wxo gVdG8OaJom4BnXR9Ls9PjLLGUUiK3jjiOELRgshZI8KhXAx0LqoleRsfNszn/ZUA98c4z2xV C/uIoniKINxBAAK/3gCe/YnJwcAE15c8Xi69SdaWNzJSq1J1JKhiq3sVKbU5exftoN0rt+zv CD5LPkj8MdIw+G99tdrbLzf5d/MsOIyvCKOP9s9/7rM0ffuv6187+OprDwh8bvhX4ht45Ipv Gml+KPCmqypHDKbm7m8QfCe30dpI22bIrW0sb2JZ13vAjhUjPmED6EicSR5ZeSSOT6dOwBr5 P/asS5023+DniOCRozo3xg8M3bNGCsgsYo7m9vYRIQUVJn0+B38z93uiQuQF59jIataWPVGv WxteFehXhGOLrTqwg40pT5oRnUqWlaLTaSai2r9HU425F1be/ZpWs/Vara3mj63LAja43Mqq sTbnYCMZ2cSOQrcEsVUAgqDkKAs+5Uh3SMEVcszhS2wAn59pVw2372Nj5xja33TUWWNnWLBO 2ONQeOoLg4Oc4+Uf4Vbb5U6AkHIBOFJByATg4B6H5T16GvmKrUKuV4ZK0aWIxFWyVo3hOrNa d7vTV9dhTj7qXV6W9Uk/x139PL8tfj3F8btZ/aC1bwhoPxa8U+GPCviLw1qur+DbTRL3Q7C0 0zWfD6fDIzvemTwtfX8Nre6Xq/iuQJGt4ZdRu7dpfssYGz4X/aG/ac+Odp4d+FGveEfHupeF /F9r8PdO8SeKYtRuLq08MeJPEukWNvearoug6T4Ze7trnWb/AFO7jWW58WWthoL6f/Zttb69 aRnWI3/oX1BIIpxepBFFemIRG8wslxGki27PHbyOoeOOVYUWQRNCHSNNysqhRwOuadFObdfs emSS6XDcG3cadZPcRQ/uReWkZ+y+Yryta2JRS5O+H/lm2TJ/enhTn8MZwXw/7aMpe0wfsbyl GV/YKKV073Vkklpa1rWPhM2y2rUxloTtzKPfd2drrTbdrTdJ2sfiJ8e/GGn3/iDxjr/jbxn8 QIfiJ4d8X/Bbxt+y14Xsb23k8JX2m6R4k8GXHjO01qzFtc2um3V54m8Ia8b1LnU9BGrWE2mI b+dQq2XOeHfin+1ZbfE+XVPFvxoXwdp+tWmla94U0bVL7VdZ0+XTtc8Jf2tdaPY6Fo+geL9A t10uPU9KllXXIYzbvaRHRtSup0uGuP3ok0TRhpcVybSzA06G5e0Weyt4Jo42mkkupILsM88U P32YIxjLpMrbA8rHa0mSGXTIDIlhfpYxGaytxJFNdJFczmPy1byHm2iKaN8F5F8qBdoCqpX9 Zy3OcPXo4ZxpNOdNfy3330trbrb8jypZTWwranKMm3z3abkk7JavXdPTv5nZ2Nlp62UMkaM8 sqRSuX5j3PCrEorAFULchdoIXjAPFabFTIkYRUHT5F2jJyeeSfyB61n6Wyy22zDK8SorCViZ AwjUEOWLOXBB37yWLfeJNXZIjGjyE8lQF4IK7Tg9fXdX0L9+HtFskvxaW/kcqlGNRU9btabJ aR5tvvt008gljiDbGJJwPuk4HGe4H9ea9L+Gfl/8TvYXP/INzvx/0/4xgfXP4V5SgZQZmJYE kd888Dk8dBXqfwwZm/tzdjj+zMYx3/tD0ArbBf7zS/7f/wDTcyMb/u1X/tz/ANOQPV6KKK94 8EKY5Gdp27mB2qSMuV5wATyB1PBwD260+onUEhsHeoIRiflVnG3kZycnAOVYDjGOaTSa1231 8uoHx5+294G8efED4Lpo3w98MXHjXVbXxjoOp6n4Otb/AE/Tj4h0eC01SzltpbnU7iOwEWm6 pe6Xrey4ttRDS6REIrSOcRahY/Jfx6+GX7RfxN8H+GdI8H/sx6T4X0S98I+NZW8H+FfHnw98 LXHhHxDrlroS6d9u1K6u7LSNbM9xdeIL2S2sNA0a6F1LK017bym4e7/Wa6vra1ktobuQxy3c pggUI7GSdbe4uG5jVkRWgtbiQFyvQKQrsqUtxf2enW015eTCG3RZGlkEc0io0KyPONkcbykZ jlYbVbIQhSCUDebiaeFryrU6sklOhCm2pR6VObS903dq69bo6YVqlNJRV00tNb3duz62S2vo +m/wh+z7+x9pvwlu/DN/4ms9P8S3Pw78BWXh/wAF6tqGi+HkuNLv7jx58a/Fmvz2zG61m50+ WeD4haRC76dNpySJZ28ks95J5sNl9RXKj7RKQNoDgbVI2KSgICYGCoUgKVJGBgHsNa++Jvgh /FNz8OG1oHxjJZPMdHGm6wAbeTTLnVFddQ+wf2YM2Ftcz7WvQ4aMxFRI0cbYkjKZ5lGBsfy1 HzZCKq7dxOQSRhsg/dKg4fco/ij6Ws8FQw3CGXUZKU6Cr1EuaN1FqpFScVfVtvt2u9z38hc5 Sqyadr72dt4trto9L+VvSMfc/Bv614P8RUM3xe+CUAJyl54xnwOu2DTrCYnB7KICSRyoyewr 3gfc/Bv614X4rDXPx8+FMGPl0/SPFN3IeAQ2p6RrFt1JO9QdPGxVAKHJcsrAD+RMn/3vF+dK 34M+lwqvGp5YSu1/4Jaf3q6+Z7m6kngdvb3p4UDHA474/WnxDemWxuyQcZ4/P2ppHUH3Brx5 rSL8t7en/B/Ezlvrvpe/kkPQZOfT+uaR/vH2/wD1/wBaAxXOMc+tITk5qnK9OyT3V36LX5CE qVXGOTjHHQ9KiprEgZHr/jWVOpKM30t69Pl532/GzAdRRSHOOOtZ+z8/0/z/AOB5gLRUYLMr Z25wcYzjp3zzQmfTg9T9P/11lKUoqyT1V2nfpbW39WAcM7j6Afhng/nzUckcLD99GkqE/cli Eq5OedpBAOMjJHQkd+ZqjkBClxyEBdxxnYoy2zOBvOPl3HGepArmjKs6kY0YqVVySgnfWV9L 21130/4JqkrXvbRJ7W6d0+v4mPP4Y8LXbGS88M+HbxiME3eiafOQAAMbprdiVwAcdBgelY1x 8O/h3ebvtHw/8EzqWyfO8LaFICQTjiSxboTkfXg1DbfEXwbda7qnhq31YvrujRRXGoWJ0/VF NvBNpsurRn7S1mtlM76fBNcAQXEm0BIn2znyqs2vjvwvdLcS2mp7hazy29y7WWoqI5opFimi w1qGdkkkVS0atE3JR2UZr6hR4kp0KU4RxdOno08Ph6s+13flkvxSvpYyfIm3rqrXbS09Nrfd +ryx8JPhLITv+FPw0cqTkt4I8MSNye//ABLcgnHU9ce1QTfBf4OyK4Pwo+GoO0jcngTwurjO cMjHSjtfPIbB2nBI4r0OK6W8gtrqEl4Z2AgYrtMhYkBArYZW3IVJkCJkZ3bSGL1nDiXZtlKO 8YjQMspkXpEDKUi3klVDFxFuOS4XJHTTxfEGIc23mE4YRRftJ4aqpSckptSXLZKLXL5pL0If K97fffsv0X4+Z5Jc/AH4QzSiWPwN4Ws2CgA2XhXw3CRgNyrJoxIJzk+uBWXJ+zr8LpXZhoMC AnI8rTfDsKjjHyxtoRK49z8x+YYBAr26BpJ1XAWViCwEeVBUPs+XzCmCDnO4joSMjFWCki4U RkEMishK7lMgLJk79pyAT8rNjgHB4oo5vxLieetho49ey91yo4atUbScbp2g4pbO667aDcox teUVsleS6+r+/qfP8v7NnwyZf3dpdwOCMPbxeHoZBhgcq40HI4yG9VJXjOahb9mv4fSKVN74 hiHrHc6ICO+eNC719CqsrMVQBmTaxUFRwxYDBYgE/I38XbnrzHPLLFFPI4HlwxtLI6hTtSNQ 7jBO4uFyQApU8DOcinLPuJor29SrmqUN74Ot05Xr7ummr7a3SFanPrF7W1Xddt07fcj50P7M /glGLjxL48tkU4Tytc0eFAv3QqKNA+VAMbUB+UYHOK4DXv2bPCV1IoTxz8RwkZlzjxJphABY gYB0RQAQDwM9BntX09fasbmKJbZXczGcxNsRVkEEsaMRvcMvlqSkodV3SkGEPFlhxsl/Bqsa zWDTMkCGS4E6IjKIwGudoAw3EkIhAJJIm38eWT6GBzbiScaONr1M1hHDqpG/1Osk/aufLduC a0qR69u9zZKmlbnj0+0tNOmv9eup83P+y34X2IsXj74kKGkQZHiXShty+CcjR1xgc/hVf/hl vw/K00LfEX4lhEI2t/wk+mc4bA66ZgcZ5HXt1r6fjuLGTTBdpODAbprRpNkwxKkTXchVDFv2 i2VlQlDm4wCvl5emOsQtonJkWNpB5rttJMc6yz2DxBQxHnW6eZIHUMhIVljfKDtWd8T06Tq0 s1xuEhzufLWwNWTqqo4y543q0dlppGV92+gpUsPUUnKaTirJXWuqfW/bp99j5Quv2YvClrb3 V7qnxQ+JdlZ2dvLcNcN4o01FjSzjeZ3YnS3KqIizsQo4jyM4IHkGseGf2ffD1toWreJP2jfH 2kQa/At9ZS3PjOBLa9hg1u60KVlf/hHXDRR3Vibd5JWVY5CwbEaZr7s8UaauraRrGhtIsc2o aNqdk/mM6xxRyWstncOZIo5WEga6j8oqkqbUmZ0JEQf8wo/2RPinrieENK+KKeFRofw9ht9P to9D1u8jm1TQb7xXq3i7xP8AaZEsnlklFvq8tpatA2kzqImSJWkWO9m+24Zr4bOIe0zriLFw qwtJU44WFOU5RmkoJ1a8+VySST5JWbvZqyPOrThBtU2m7WWut7Ky0b69k7/NnqOqeG/gW1xD pifH/wCId1/aFvpt/YpovjBLrU5bfUdIt9c0yW2Wx8N38ktvc6BNbXx8u2wlvNmRoSjxLhRr +zhd2ei3Ef7QHxhuYtVW+utNksZfEs8k5truGGW4Ah8BzySxW09zHG11shjZ5Y3SVVnTO58H f2YfF3w1+MujeO1u9Fk8DaFr+u6noMU+p3Vzf23h/XfAeqaJommzQQaTbXE72P8AbUMKtNcy 3X2eGOW91C+uVnefA+L37KfxD8YeEfgnpOm6T4X8Q3HgE+M21iDXNe1DT42j1bWNCvPtFtLp EmkG4Zxp8iFPMg8tJVAh8wl4fp8FQ4ZjiowlnGZ6Yet/0Cr/AJ+a/wAFK1v1OP29ful8npto 9emvk/I1ZvDvwGvNYbQF+N/xQtr432mWm19R1Gyt4tU1b7JFotpqWo3Xg+LTbWW7umsl09by 6tWMl3EI23TxEs8R+E/gD4R8SR+G9f8AjX8RIfFraPZ6sdFTXm1BbrSLtAIdQutQ07wle6fB HPIDcRpdXQkLC2Uqz3Fs8li1+Bvx+GpeL9B1Cw8Baf8AC7xd4j+GXiDx9fW2qX0viDSYPCGr aVfWdvo297wbtQuNCiQq1lqxZryYSXOnxGN7Pmvjr+zL8SvH/j/T9T8Bp4TTS9L8EeGPDume JdS1bUbfxRpMejWQg8lbKW1n8OXNleWrrma50PUNQ36tMQ1mYIhpsuhlEsVSweH4lzGjhMZR hWqRdPDS9lOlCnBLmTjFqesrSimnezYOq3rLWXV7Lyeu2nr8zR0TQP2fPEV544s9O+LXxNF5 8PdP1LX/ABo94+qWEeladpLTs0d3JqXgaxjjU20czlUuLyRYrR3S2aNDsuaron7O2jjwyb/4 ofEie08aWmm3/hW4sf7S1yG/0/VZLdLCBJtI8B38MMdwl3aLHFdGzbZd72gWMtja8Xfs5+Pt fvfiTp+na5ZwaX8QvFuhp4x/0uyXU18GLpnivSvE62LT+HbizttSnj1pJdMMQnZSqtI0JR4Z E+Hf7O/i3wYuh6bea/b6lo3w2+LN34j8JSPdWralD4Ls7nwWmnWV+1t4b0y2vNQtNN8IGWQN GJZbmaQPe3CyxR28VHgqcJYirxBmteMb0XTprDYd8iagp+0lSrpJJXa9naXRpIyjVkpXju9N b2SdtEuumlr9LK+l+DsdV/Zf1aLUtdtfiH49vdJ03T7m7v8AVDbaxHptsLYwwrK9xcfDkQ3D fap7Oy+zwStcXElwLSDEzbV9E8JeDf2cfGfhrUvFtn478TNoeg2f9r6pf3OzQ7KOKNNRntzH Brvgy1n1EtaaZqMky6eLmVzA7hIhcwRv4J4J/Yt+K3gS18ReRpHwxdNS0LWtDXxY/iPxjPqV w2sWtvENIurPNvpsVhqTqNEurq08ORahb2V29xa6hZ3qJqtt7j8Gf2W/EnhrwD8W/BnjQ6am n/EvSLSyg0fwhq0k2maG76b4zsdS1C2vtdsBraPdHxUb6VLy/wBcjS8nuFsrG3sbe2s1eMxu URoYiWX53m8q7w2CvBZhgJPm+uw0tDLr3Svo9bfM1ar0/fbXfVPrbez726+hxd9/wzRpelav quta14y0N9OTRodP0TWtH1KwuPFsfiLUm0XTNTh0G++G1pqt8Jb2RHd7ezvRG6YuJrYQSTL3 914R+AGh/D+++LuvWGpad4PtJQklzqun2rT288F/BZWcCWjeA01eRrnV4oYzFDpBeK0uZ9RY CxhmvV52/wD2bfGnxav7fWfjrf8AhbV7/TNS8BWWjWnhHUNX0yxvtE8P+Lk8Qa09+G0e0uRf alFM0cZhu7JMJGkEenPvmf234gfBPwL8U/BmifCq+lltPBaeKLXWte0KK+1O3vtQW2g1OVFG qCy1CeOCe7u9PDpZ6hZXIWFtkkK+YZcsbj4UZwUc3ziN+V4+VHDRqytJRcbNQs5Ri1q0k2r2 itFn7Sv3/p7de332duh4LDrf7Hs+rC0nudNja68JWHjdrmbSbSaOPSdVj8KTieIHwAivMlz4 x0WzuLdZzqFs93Il5ZwvBfJacZpPxH/Zn17Uo9N8NfDHRNein0jT9autQl8O28dzZ2+pTzwW oS2uvhrbz3cbrDPMrQHLyIY9iO65s/8ADCPhjUNWl8N6b4gvW8OeHta1GDwxpkOsMl5pelXQ 1Wa40i6ur7wkGuoxNDZSW0815e3oi0pVm1JnnuE1Dd8Pfsnax4K1u3v/AAp4j0ptD13QtCtL yG9v7yfUDpWk3d7NLNYB/CkMMZSz1mFf9LmNxJPJFthKR3DD2IyyGGWVcTjeIOIa9SP1arN4 inhsJQw9FfwVKc8NO7mpNXc6aTiopO7aznWrpxSs763u+jT6evz6dL8B4K/aF/ZY8QPJI/wi 8AWVq2kxara37aTpWpfaLZvFOneG5pZI4vhvbyabFazz3kkgvSryR6e20Rwala3Ke2+APFPw r8TeJHkf9nzwVo/wtnhvjpPxX1nQNF/4RnULmyk+yywywXvgvSYbW2l1SO803T7i61KK3kuI LSO2lvHurVZ8Sw/Yh+GngnQdK0OS91zTrK3sU8N63Pba2bxtc0a68XTeMlti1xoVzJBeJqza ewns7fSEFrpUcDSOZrt9RZr/AOzl4HsvC48P+IfiP4tt/g6b6a48P6Jbf2NJd2+rW+oXDy5v I/h1NrreTfX2sGQXupz2z+biEyQpa7OSOYcO4rDynluZZ844irTnWlzYapQq06c6cq0KDhgo 89WcI8sIxnJycklGV0nrCrXUJRlblknF2vopJLfu1tf/ACPVP2e/HXwW/aA8P+I9Z8N/CvwL oNxpesJYyaZb6LpM+p2EBso7qwv4pLnwpoVxBYXkl7cW8Sx2Bha40fcl2XjaGH6TsPB/hAW5 uLPwb4es0O5kNnpGk2kCFSyFo4lsFKfMCXIfJcs2RuxXzn4I8FfBH4D32vat4elu/D1nffD3 RfFviDT5ZvEOtW114TtptcudL8RwNc2+o30V75VtrkE2nxX8EhjFuW0YTMk1W/DX7XvwV8XW moXekeNZNQsNKt9Un1W6Xwt4otDbR6bpMury7Y7vRLaWUw2kLTyiCCXzIisUHmXJaMfCZlgs 4xeMqf2JLOKuHvdRxGCqapRjo+SlTtqpdL28t+7CyhThq9kt2uvbbTXV2fofS1vpmn2yE2mn WIYZXyo4rRNiFhnlI1GAQowAByPSuihvN9uI2uGtNq42xM4AxuAA2EDp83HevjL/AIbN/Z6t /DGteK5/F9+dI0LVG0jUroeFvE5Md29zZR2/l2y6ULmWKWHUtPbekZKvM29YxHIsfvulfE7w Rra+LU0vVLpo/Bc01lrU0mn3saWt0raqkQAktfNuol/sbUjM1rFIT5C+XnzYg/gYrIOIuam6 2UY6rOUpf7XHDYlQo6L922qMl77d7OafuNJO+nSsXQS95pu+mqu9vv8A+HXXX0KW+3J55mHy g4G5sdQD1bPcfj+VRrcecgkkkBj6feJA7jqT6+nevitv22Pg3q/h/wAGaz4Zg8Xa/beOE8UT aNbW2h29neyw+DLk/wDCR+aNa1jSLS2e3s4bi5thLckXIj2xFpmjgetov7anwi13xZqPgyCP xVbahpHg+Hxbcwz6HABFavrWl6I9lJcx6rdQy6ja3uqxx3CW5exZYJpbW+uEEZn9CjwVn2NV OWHyPG4eo4t+yq4fEqNJK3NJuWHg/fVlG6SdtLvQUsfQguZK+ysn3SfS/TX5P5/dIlUhPs5D Jld4U9U79AvBORgg59DVtbqSMfLDjjj7w7ccgDrX5u2P/BQX4eRy+DVm0bxNHYeLv+EXWC7/ ALCsmFkviaz0+/tbu8RfFLzpawW968lylpbX14gQJFbXEg2vP4l/bfMWkeKLjw/pULXulaR4 X1Own1TRp/7MtU8Ra1qOns2tJb+I1v5ls7bT3nmTSopnDA+R9sZ1gHSvDTiapbny6or3/wCX Fa2u91y6fl6kf2nT193bz6eTtr16aeZ+jkckk5l8wXSmRtw2alDHH8qxqNts8TSKDsIbLnc2 5hgMALT3CxwqhlUyL+7iSedHAlwQmTlFBBAGdyAAn5l6j8wLT4/ftI+JtK+G/jHwfB8Lbbw7 428Rap4a/tK7sNdS5t7/AEXRfHGvXyxWdxqF1JF5lj4SaG1mltbuF72ZElWK3lee25Dw3+1/ 8dpviDpWga1rHhy4sE8V+JNP8SQL4etEhstA8I+OLTw1rmpaZNbxw3sl1Dbyh7RJXumuPPaT +zy6LDD30fDPOKkFGriMrp+zioulUnFVabiox9nVjLExcakPhmnGLUotWT0LWYU3Z8r2Wt+9 rrb7+1up+tAvAGZFZ5oRvl3MXEqq4ItEUMpYQrJGCMR7VDSHMWC6wLdTwmYXDyNDEjyg3l4j u0jxCFtm8r5bG3kkRJDG/wDEnzh/Lr8evh5+0j8Tfi18HPjJceIPiBd+HvGfh7Qb74heFpdD 8M+E0tbjQ9X0K/1mw0+8XUfDHiK0ZbOTwdqUc0UqW179mv2Uald3D2sunt+J+tHwf8TLL4W+ KNX8Q3X7O174O8OeKfGtpqFr4bk1xNGvPiHDo2oztfeHtPs9aDtq0FvBFb6O0k62sqyqoYTS RVT8PHTk8NXzbLcNCvKMZ0oVMPfEJO328U3aHPb3VL423bS9xzLkVT2UL8yXM230WltNHq9P 1Z+x0d9BdR26qoeTcf3Vjcxx6i0MUcsaRgiOeW+QARSyG3ttlqkQEyqGR0ji1S31RYJbKWzE Cgqs9rNHcLcMBC0paSF1UG5SS3eMtnzBG7KZwp8n8PtF8LeMvGvxR0+3/Zu1IR/DzwvJ4kT4 RXHiQ6ZDbWsOs2hfxBZ6uNV06fxNcQSGy8QCzkvoJbuK6tNOxcizllNx+jv7FuneM9G+E93a eM9Ih0bV5NZd3tFubC6jOm2PhvwzFZpDJpmo6lCDFdXOrRky3HnuvlNI7qI3OXEPBVHhrAU6 2Bz/AAOKc1zTwEamGc1zuCk17LFOd7SbV6e67XLweMrzm/c0ej+Lyv8Acv61PqsyknYZev8A tHPr03e1SqzEbFJLYyTycjOR39Peqiyo8yjaN2QMfNjnPX5s9PQ+laDSLGhJADLtxt3EfN65 J5xj9favzxTlZ6PSz+d15b9fL77+xSX59N9lb7v8yjNayOF2ht4YHoOVwc556ZxznHPSp0hn jTBBHU4PHf8A3/8AOalN5EqxbSdzbc5U46DOPxI61BeXEwkRV27GXqR83XnvjjHpW0Zt002t U3vre9vT9dPx7oz5Uk9bO/5f5X0t12JRbNJyeSQCR8vXv1NW4olUAE9AMZx1788jiqMQnVBM SPI7n5d4c4B4x03HHc4NIrSO29OY2yVLYDYBA5Hr+Hb89aU7/Pz02vf5/puXGor9f1tZeq/4 bdGvE64dcjkHnI7qwqO4wsakc8qf0IqsjoEZizZ5HQdMY9OvJ/SlklX7PwGYAqOwzz16j+nP aob/AHj0avfu+z+5beu5tSf7xPs07fNOwySciNEwMN8uSTnkdvfmsm8jmV44IdwEwyXGRt2M G7MoOQCOv59DYV5biKORQg3M4wcggK5Q9yOq+p/pWi5QFVIy+3K9cYUZPcDscV0Uk9/n92nn 1fy3OvTWytd3M+BntWRH+ZScknP8R74LDtXj/wC0HoFzrvwn8ZXUETPPoela14ltY41jZnk0 rw1r7Qg73V1DNLGN0WJlJHlgHp7OZUL7NvI6nnOOv97HQ+lUdasE1XQde0mYuLfWtG1PSZDG ypKI7+zmtG8t2VlRtkjYdlcKwU7SMg9OErKji8POy92rBu70VpL8f8yKn8Ob0vbr5yjdLzY3 w3fnV/D2jai4Urc6XYTQsjF1kgmsbeeORWbJZHEpKngEcjqa3LbhgCdoKsCf7oJ+9noMda8P /Z88SJ4l+D3gK5QqZtN8K+F9FvdsTxJ9ssvC+iPNgO7b/nuT+8jIiYYCKMHPt8GW6rkMGQgH BIPBAywwcdCe/etM6ouhmuNg1b29BLa38eWHr6d21tbdak0V/s8ul9LbPSz081vt0+5t2u3b 8xljLHP8QGBxjBYYz7dqlfTLaaJFjRVzlmBSMfMyqCcFU44AB575J7S3FvJ9nURmOORWByxc qsRJ278ByXIaMfIGG4t/Dg1aMTxLCN8YEgFwxm3lprCIL9pNr5KYW5XzYfKW6EaEyfMCFfZ/ SHgXmDeQ5xlsFFyw+Iddq7cmqsYq7S2T9no7e9Z9j5rO6qVGN5bWttdu8b+Wu/8Al15y90qK SCRFUNkAYVYjwzLnsRxycd8UaDYw2E0iJGC0iEMNqAjDM/8ACnXJ5z/OrepXVlokJOpXC2Re W2sF8yO4nK6he3ENvaxn7HFcDyZ31HTY1f5hHJLM07RQxl18o8K/Fzwd4o8f/EDwJ4Z1Wa+8 S/D1NETxJb3GmX1ta6fc61bC4hAu7i1t472KcR3f2c2LTtEqRi7KMfm/oLLoYmlDLueDi6GH p0tYyu7VJSu73/n1XbqfP1qlOVKPNK1opKzS2S11v/wPWx7e1mItwHHmNlRtXjOcYAPGM8Dj FMnV8QRYzhpCfUbtmOM+344rfuLIR3CRyxXSkpHtw9qS0kjyLglXKhfk7Ywc84xire2/2KV1 nD20ipGUguGSSVTIWSNnaz8+ApI/ACzF1CsXVPlz+kTqVatGg5RaUVZuzSXuteiu1+Xkjyua m7qMrvpqn27a/f8A5GctvKEB+YDH0/8AZq9I+F0rSnXdyKgX+zMbTnOf7Qzn6Y4+tefTsXiR S373CuQgHlmM5KlS67txDJkNj+LjpXoHwuUqdeH/AGC8dPTUPT61rgv95pf9v/8ApuZOL/3K p5+z9fjhv5dtN/x9aooor3jwAqJwMk4B3BVZdqknk7MnrgMxKjpnOOSalqGV0Tc7sirEhkZn UqFU7ssJWIQYCksBkqAC2Aympkrxavy3W/b7w/E/Hn9tL9nX41fH74oeNfDGk6BpF3oF9o/h S68H+Jta0bVpNI0fS9Jg0aTUNHm1XTvBOpGPWZfEK+JLqGGK+vZv7M1SNHvIYHbTLb0/Sv2J /GJ/aI8eeJdW8QeFZP2fvE178OPFVt4BjbXL+/1Hxd4E0bTNL1KHX9PudOtdOGk+ILnWPiHL cp/wker2ckWsQx33h683hNJ+7rr4u/CmBddjf4m/D5JfDE7xeJIpfG3hu2m8OTpfWenSxa20 2oj+yJk1HUrCxeK/S3kF1qNnakeddwLJBP8AGH4Saf4XsPG958U/hza+C9XvJ7HSPGV5438M w+GtWvLaW/juLDTfEEuqJpd9eQSaZqMUtva3c0scmm3qtEGtJ1i8Svh6KlTp+3k3WqTcp2s4 xp0/aKKSVmnKKT02l6X6qc5xi0qalpa7dtVy+myu+13d3aPzZ+Hn7H37QC/Hj4XfGX41eIvh rrt98MLjxl/b+q6Fc6zDdeKpNa8Gzaf4eudK0mH4f+EtBhTRZLrSrG7uy6S3P9n3XmefNZQw 3H6JEEuWLjBLsEGCMb2XcG4O0HKLgbSoDfKTtGNf/HL4W6x4w0n4faL410HXfE2uaRPrNjaa Bf8A9sRNp23WlSebUNLivdKCyyeGNdjjE+oW0hewuIViaSMCTcU5V84BVmRgPZhsYkcZaPYx 6kZ2nBBA/gD6UOIhV4wwGXxqOpHCZXRrRlbX2mIftbSVkkoqo4p9Ur33S+nydSjSc5QinJu6 8/dd1a+r89lt1vGAdmMc4PH515dbQw3/AMZtYuNqStoPgjwgY5xiRbe41LVfihaXEe9TiGYr awrIj5YgxqFU8n1SvEfhzqketfEX4uXcLI8enyeHPDkjRszqt3o/iD4gS3ETlgCsyLqMJkQA qodCGbccfzvlNovM8RrzUcGqyj0k/ZVZtPS6V4Jd9X2Paoy5Y1EtuR0fO0+Wnf5J3Pc14HPH Pfj09aY2Nxx/ninBgQCwAJzxjPcj09qXKe35f/WrzqtOzcFKKjF2V1rbR7L/ACMou6Tdk3ur 31/pr7yKgkYI4Bxj3znOfyqQso6AH8P/AK3NJtUndkDPbjI7df8A61ZRXLe0oSukmrtdU730 8121v6Vp1/r+lchAYMRyRjqcgdvrT6m+T/Z/SlwvoPyFCozbvHk0e19Oluq+7vbpowr5A6kD 8aZJNDEu6WWONem6SRUXPpliB+tWSEYdsfQD+Y5r8+v+Cmolm/ZZ1TTbaa4t5NV8beDbTzrK 4+zXiLBc3mpkwuAS246eElTaQYmduCorvwWWvHYqGHWJw8IveS5ub7PR27/IHp96X3tI++or i3mx5M8MuVLjypUkyi7dzDYxyo3plug3rk/MMyB0YgK6knIADAklRuYAA9lIY+gOTxX5YfE3 wP4t+Jfxn+NHg7wLoGnrcj4V6D4bs9T0650q1vfB0+qeK/jHpcPibSnn1HTVi1jS5FsrhHsJ 7S4SWzsiZrYLbuup4u+Knxc8N+Afj5ol9aeH/G/gX4V674V8D6h4h1iW7bxHr03jrRPBHiKQ 3NxeeK79lGl3HxEsLGzaLRNRtBb2arJMji6+xfT1+AK79nHBY2ljKjg51KbnQoyinOFKny+2 qwTvVqU4vflV27LVF1ytt2209WuquvRdWfp8ATwASfQDNRNhgp81EQMGk3FdskS/6xCScAEH k9sV+ZHgj9rf4h6Xofg8RfDXwzL4OsvEXhz4aQmLU5n1ELH8CrL4gpqC+RO/79L7/iUMkeiC 3WxDfvklU4+r/gD448T/ABX+B9p4v8SfZdAuvEH/AAmr2eo6fdTTLYwr4r8V6fBc+bNqE11F BpVra2RgMtxaLHGgWKSGJE8rixnAmcZNGGLxyw+G9hKMqylXoYizq8roKEMJXrVZqSjVclTj Jrli3ZMlNSurtJtK/rv91lfy1bVj4G179n74keI/D2reDIfhjplp4m0q88Q+Km+Kd0viaz1S 9tJvDXhy6tNA066tvAzX2p3Wpr4N1HwhcwT63FFbWutWccCX4ubjShyFh+z1468VfCWb4YWP grxH4U8VHxVLqes+K/EnwunTRby3tNsstvZXFzazXPiO2nuBZLY6nqNrYSXotmvpIILi2jhk 9lvoPG/w1+EH7WGq+Gvjj8RfiD4P8N6D4W174ZePPEfjDVtX1KLxI2kv/wAJRosGuW2rwrNo 9tf2mhiCHR7XRDb3+qaxFNqGoXUki6f9R+D/AIt3PhH9k34c/F3xpDc6zfJ8NPhxrGtzC61C 8m1W/wDEsGg2Mt1PcQ22v6lJNNd6wL2UzLf3W8EXcobzbhPvsZnOOyPL8Fg8PhMrxixGJWBo YhwqUqlatOMfZR+rYuMcRhlOT5ebF0qMIb1HGLTM1TUubmnJWvayV+jv63W1vW1mfH3xJ/Y5 +JetaXp/w08E63YWln4Cl1bx23iDUdH1jw/4R8Q+PpiNW8Laj4Y8I6TY634b0Sfw9c+JPFVn Ja6PstpWu55H06VpWt7PgfA/7O3xq13xnefGPxXZX2n6bdftEWura/4J1XwVqEnj7VPD2o+N /C2pR3uleJb3RbHxDp2g6cdc1K4nXTLuw0iWDTNeEhW3udRUWPg3/wAFI/2mfHWs/DHUtU/Z r8E+KPhv8T9Q0OxtdV+FXjQ+LfEfg3T9e1nSrZ9f8b6N4ZvvHWtaFa2Gn3F/NHF4s8M+CxdS 2kyR3cRhnhFLUP8Agpf+0ZqXiH44T/DX9l/w14++HnwE8TeJtA8aeILTxXd2L2emeG9S12Gf Vp4LiMOVbRtIm1WYadp+pxJFDKqu4CEevgsPxRVweJjQyfK6yr0IyxFes44WrRc5+xjF0qsq L92pL2caip+zqJKopOElN8qqUrfxHdO21tE15Lol92mp7L8Tf2cR4b8FfEvUfhj8Ozo3jG2+ Lnw+vvDOpeGtJ1pNXXw/pOlfC3W76z0qSxspbu6sNQ1nStSsboRI9o9xc3ttciZY7izl+Nvi J4B/aG1PV5vGXiKx+J9mfEV34V0y+tW8O+KdRh0m38JaAnhtbk6Ne2mmaNKbyysBfzBrewNw 5db64unurm+b6Z8Xf8FRNWuz8KrT4H/B6w+K3iL4qabd6hpeiJ4l1bw/I76drvxD0S+tbS71 TwvawTyww+BDdoszQSyPdvFDDN5EbTe3fDD9sn4jyeGfiZ4z/aj+CKfs3+EvAvh9dY0vXNa8 WP4hj8RapDYa9qt3odvZWejJfrOul6HdX1vNa2941xDGRbwTtLAH48JiOK+E8FUovhbAYurj qtWOGlLFYKbrSi4RdOmoV5wb/duSnpFapz1ScyhTrWiq8ouLUrpJ7e7s49W11/BHzf4p8H/F S1T/AIWd8NvEvj1D8MvhJBOnhbTdE1XS9P8AGtzq2keK7DXLVNP0bUNV0dPENjogSfT7N9F1 eeLULnSbe3utG/0XV4PTvA3gq4X9qnwRqj6V4pg0qP4Eajq00mq3viaPTV8W2nxG8RWcE17b 3F5Pprai3h+C2tbaK4DySQNat9n2skw5jwb/AMFFvjFqnjr4faf8Tf2UfFXw08BfEPV0sNF8 dfafGOp2Hk3qWws77UbS18AkMt/cav4dtIUv5tI+yyam088kkaypb+g/DH9tHwv458O/GXxF qOlWWgaX8GrXWL2/vbvUNSniutP0Twn4K8Yyi5W40GxmiWWfxcLRYrVbtmNvE0MM1xM0UfPm FbiicMVRlkODjQi4qVahiMqrVKTq3jThOnCrOSqScJ/Z1S87lQ9jSVp15rzaWr03str/AC2P nX4y3fjv/hLfjnpNoPiN/wALPufGOjS/CLWdNn8SRaPpGhm6v77xFFpFpaXcUV1aT+D203Tt RksvD9/DBqC2ryurSpqh9r/Y4+GvjuwtfF/i/wCJGoXGqS6zLJpunw6lq3iOHU4Lwx6fqZn+ yXlraQGB2u5Ei8p2ZrhZ4xEqLk2P2WP27vCH7UviL4jaDomm2Wj6l8M7iW4tbaC61sXniDRN Q8Qaxo1jrFtHq/h7RmWwl0+z07U42sv7RiFvq1mplSF4Jrjvv2Uf2nNM/al0L4n+ILDQZNBX 4b/EvVPAVxbWN1qd1DPqej2cF7JOft2g6W0cji9WNxbJdQlI4tl2xGB1Z1nWdYPLcbgauTYf B1sNRyutVdWOEmnSxM8HClOLpRnFc7cVJc14tyTSs7XF0p/DWm77aLy8r9vwPlH4hfCG7TUf iRa+ALXxFpmoT+KvhZo/hm9u9b8ZRabDaar4m+Dtvq6MUvdYijtCL7XX1O5gtb2SDT/7SlZS sUsKeUHwx+0Pq9x4x+B3hbxB4ytvGUeu6XqN1JJrXjWLwtoGk+Ho9ckE2g67a6fe67e2fiyL W9M1PyX8O6BYRv5ESSalDBY3T/s7r2sWuh6HqfiDV5odO07T7G61bVLm7V0toLXSIZL6Se4l OAqRx2CMXYMyKqsqkqgr4q/Zx/bl8GftEfG34s/B7T9O0vSJ/h4NYi0XxDaX2qXV341sdI8S ro97dWVtd6DpqSW9kLe1kdrC/wBThihniwxgaOY3k3Eua1cvzCvT4ZwWaUsnwEcVjZKWGtGF F0aE4wjC05PmqRbhGMqm8lDlTa5sVCnFwcsTUhdXSiou+1ntpov19firW/iH8d7uy1Tx1o+m /FOTTPEz+GfB+s+GfJ8Qz32geK9Ti8Y6wniuwjFjdRQwWVvPeafqaWy6C6TQ6MsiyqbcaXmB vijcHVvDnh5vihrEniK88MwSXOs3vi/RL7w1C+oxW8tr4lsrC58RudPvoUu7u2uL67YpY3U8 kFssaNv9W8V/8FV9K8OaH4z1O2+Fmh6jeeFPj7/woqy0qPVtbuP7Z1m2s/E1xbzra2nhKaeL UHl0hLZY447i1X7f5a3e8os21bf8FJPFGhapfeGPi78B9Q+FnjeLwVr/AIv8KeGNYv8AxPDb eObPRdH8XavdiWKXwUkDfZP+EbNrbzyX5ktri4SdLedo4raf7qhmGfRpU8Tg+Csopc9KricL VliMM0oUVGca1RTrOm6abTqLlcYJWqpJq/A5UOaMXiJ3bS1Sur21Wlr3aaXddSPS/h943+F3 i/wT/wALq1zxD4r+D/iDRLbWb3wxonivxqvh7Rde1Lw7qY0yLV9XupvDkVtNFPpi3dxA8sap rGp2dnHaXBdL5vAo/CX7QHi67+IWt6HdeL4NH0TwpJqvhy31vVfGsOtaT4dm0hLrS/8AhGVi 0rVDqvia10+z05bWBtSsWu72OInxArSNeP7x8QP+Co/g/wAD/BjwD8Sn8JaNPrXjm/nhvPBc Os61LLpUcGr+NdJuLpp7HwpdTukN74O8ho7jT4DDJcCJ5CYYmn7f/h4V8Ok+KvxH8Fagvhyy 0D4VfD7RviR4k8Vpr95ct9m1jwt4Y8Y2WmXOmwaG0kSyaPrWqPDaQz39/wCVorQGyW5EtvHg sw42jKniJ8O5ZRrVsXjMswtKNPJqsK08NgIZjVqynSjNU4So1pKm6jinOCV23yg1RTssVU11 +GOvT+Xy/D5j/FPgwaVffFnx94S0bxPqOrWHgTwfa+BZ/wC1vFN41v4u8W3PjTwQ+pWYe91i 1la1mfQpdSeK2vp7O006GeC1e7SJG8T1Xw58RtR/Z+8S+D/iHo/jS7+JOgeMLLxZpOu2t94v Elz4W8VNoniFtLtLwW+h6tdzWOr+OdchltpLGeytYbC5gtbqK2sLTT7HsfDf/BRn4ky6r4f8 W+Pv2ada+HXwR8Ua5YaQPidqUPjXS9K037Tf2nhSS7ubbUPBNvLaR2/iu8sdNhnv4LK3lu7k vHOY0knSr47/AOChvxYuPi54m+FPwD/Z5uPjBb6LpeheK18WeE/GV/Zaxf6Pr3h7w7rqSNHb +Grg/ZoYvFWio6rNLIYprdpYYWWRYOD6txjjK8q0uGstrTxGCpY6dSjjssg8Jh8LHDYOpGca GKjh44h1ZU2sLFLEzhKVVUZRhVqIqSw1NQj7ec5X1bSSS6PRW0236FLVdLv/AAx8XvEUXj/w 58RPEvwR03xC2naR4ZsbrxWdL0W9i1C1/sjVJ7uTUdPgj0iz0C18TwLJLqcsTWl8JTbSRxtJ a+Z634B/aYfQvEfja017x/s0L4TeGv7E8GTReL11zU/DfiWLxhpljoFraCynabXfDFlcXNxq SiK9ulkltt+pBhFdweual+3l8UvEvwv0H4k/CL9nq68c3kD+JZfihoFjr+qxQfDOPw3falp9 xNqE7+G7SRora60PWojIYI0RbGcxO0ZWR+T0D/goX8b774P+JPj74p/Zxi0DwH4d0vw/4g0P WE8X3up6P4itvEotHiuZxbaPJe/6rUdAmMa2ouSmpwtOsQ+ZPXhieIqEJ34ZyijWjWp5ViIz xmArvD4vFz+rQpOlUxFRSxFOrGcZRjB3qQtT6ky9lzxSqySdpN2TtbldrNbO/Wz3XU/TvVz4 zuddgl0nS9LHhGXR9St9Tv59Wv7LxObn+zdYZLSz0628M3kbW1xdDTbeWZfFljKLSa8f7HN5 Qs7/APNvxL+zz40l8O/HjxxcG4l1DXLv4qT+HtAi8IXE2voF1fxq+lfYNWMUeq69PdQW+nNp 8Lw7bj7VZiKR1W3eX6L+Nv7Vlj8I/GXwv8K6HZeHPE7/ABE1+x0W51FtdCXenJdaZ431NpbO KyiuGleP/hD7a3KySBfJvrhmKhEB+PfiT/wVD8S+APA/jLxbZfDfRNUbw18Wr/wBf2b65rpF xptlffE+3F+Ra6bJP9omg8CxsYY4buFnvpAitshSX4/KaXGka1TPcNhMFicDVrwwLp18JlOH 5cZQnTxNSlHD1aVPGVIqjWpO8KUo3b1vGSWtTE06lNU/bSVrapdEknuv19O5wUXhSODxV8Pd S1H4a/Eb4ieFtMtfH9lrGmf8KV0/w5LFqOreEIdL0MwwaHquqW91FBrM1hfpqt3d2N/CLJpb S2mngjjeOy+E/wAUNF+KMyfEDwn4+8Qavq3hS7t7PWoPhzqPjSyt76/jfS9It9R8S+I4tM1D R/sMkR1ExWdtdtaKLWa2t5JL+aSD64+Kf/BQSLR/i58D/BXgPTtA8a+FfjJ8JPF3xFtNftNa 1S4trO60HwV4i8Y6Xp6Q2dq1pEt0mnaX5i6k9neQQXiSCKOREA+Xf2ev+Ci/7VH7Q0XgvxFa /CP4P6J4b8TeKoNEmlufiZpV7rNvBb6wmmahd2Ggah470TXru8WJbj7JFFo0jzbD9nS7jOG+ to5lxFBSr1OFsv5KkK9WrWqzow53Gs0k4VJRUIxjZWUY2jFJ7s5Pa0lZLESdv7sV27xXX8rn X2P7Pfxn8AaZbeJPC9pcav4g8eaT450ey07RvB1/4b1rwbdSfEPwx4mj1HxbfaJoWo6lqNnq Og6Fq+nWD6tbymG51SySxTybma4t+t+Hnw9+OH7NXifRLHWfD/if4u6PoUPiSTT73wJo3iCS C10zXdQ8CQ22gSFNBaMjT7X4cSStFPdzLGmtWnkxqstxLN5l8U/+CjHxu8P/ABk+Ivwl+HXw 0+FOpeIPh1Doza1pXjvxDJ4am8ay6jpugzzNoaeIPFPhGyvF0SfU7vUJ/wCzJ/F22yjtZ3kt I5Uvpu1/aC/b3+LHw+0T4DW8ngTwR8Ptd+MWg3d3req/E691XTdL0K5S08FpdW63+pa14HtG mtrzxbPczHUNdjkFvpVzMyLGt3eWecsRxfmEFlVTKsplg8+9hTgubLWoOFqtJSq0GpUoUeaK SlUpTqpte/yySOelJObxE7wtZcsdXJpb2vpbp0Poz9ov4XfGP4t+OvDqeFNR/wCEZ0fwHpum eN9GbU9P1C8hm8c6Jea9Da2luE0WeEXF1Za6h3yT3jrClwp0a5jKs3l9/wDsr/FTxBLqFn4n vNK1bwvqmjaZ4nm0F4deuIrT4jQnQ4fEF6NNOh29rZS+INU8ReOdfT7NJAXjaZjpKKXOleu/ sX/Hv4v/ABnsddHxU8HeGdLuNA1bUxb+JfB3iCLxD4X1qwsbDwrfwFWtNd8VWsV2lxrV/plw R4kuWhk0pWa0gMvkJ4x8Tv2i/jr8Zf2j/iB+zN+zpp3hPRl+EkZ1vx14zvRq+rX041Gw8N3O laSbK18bfDK2smfU9Z1SJHGqa8Tb6Vs+ywMXuh89Qz3OcJmP+q1LC5ZQhk1CWZVK8sNg1h4U 6LnzVKtSVF17J0pqEJVZc8oxSjJOz606bpwl7aSTa5rRWi927Wl9E7aLdJbaGx4F/Zf/AGgt E8beG/iRfePtHfUtPuNC+HevaBJZarJ/a3wxstXg17VNKS8utBG8PPG9lZ6PJpEUA+1XMo1y z3y20+hrX7FXjDWfBfhnw2PEnhKwfRNR8d3lxK+j3RjePxLpnhy201rVBYxSWQtLzRria5sY TFaan5mydpPtd4o+Jf2qP2vP22PhB8HvgjL8R/B+h/BnxT4h+NsHwv8AEOv6ne+JZrKX4eN4 X0hrn4kRJpHxFsriO5t9RXWb37LeeIb9BFaEHLhr6bsofjD470v9n79pLxr4V/a+0z41eLvA 3w4utU0e20OPxpFb6JqqaZ4quUkF8fi94leF5bVLe/MthfWMqNpThpjIqfZPo8PhOMcVQwuc TzXJ8Jgcfjo4LD+xpZfWhUlKliJJ3w9OdSneWGkrVVTteV7e6nFXE4ekvdqTe262do66LX1s tdPI+lPFP7DXxH+J8Olr4n8W+AJf+EX8A+GPhjoVvHp97qtrqVh4RlsbnT7/AFQDQtJSzvPs AuoxobW+vjTRbWXl6xdRxxvZew+Df2TPFXhbw78avBejfEmxg0j4qXt7p+np9m1L7Rofhac+ O7GPRJDNfXV3dXFpY+LNPtLKaG/t7mePSnlF3bSTJs/FLw1+1h8YtP8AA3wu+IfgP9qTW/jZ 8ePEdjaSeKf2ZoNQ+JOof2PZ3ej68urypBF8RtSnMfh24sbDUDdTWk8AeYxFY52juI/Zf2u/ gr8Yfh/8W/gta3f7Vvx00qz/AGhfiHdaXqnh+38ZeItOg8AG51fwbZW2l6HZQeKpkItbPxXe JFDPaW8aNpsCrFEkjQjtxuVcTurDAYjiTL8HOvRxOIwtGGXU5/WHg6mGp1JTrTw0lBP6zTcG qkab95e9paKOJozhrzSldvW/Rq2y9fn13P0T1b9hvV7DxronjP4T/FSLwgunT6g0GmT+FJte mTXNW0i08P6ndRvqfiPVEtzeaKmmwiNISGMQdIIpsXUs91+wJpN3ff2/4i8dQ6j4ima5k12/ j8P6hYajqeu6rc3WranLNDaeK7YR2Qn1GfyrcBYE+z25i0+0RIY7X87Pjl4a+IvwH+KPjT4K 23xn+KXjKw/4ZX8ca9Yax4r8V6xba1d6yfCH7QevN5UE2q+UZ7KS20iK3mSM3Cpb2bJJvjtx FwP/AAT78CaB4x8X+APE+u3H7Vut+K5/+E6tdb13UZ/GGofCyG/sbTxDYy6fZapf/CG40WRk ghhktQnxBvgL6Zo4fPl/0cefRfF7yqGYLPoVqNbB0sbQnSwOX4epXwjqVIu8amHp8k4ujUca XLGtNqK9m7xTqGKoyr+ycNLSbfvaNWt2vfy29Ufsb4d/Yv8Ahx4aurO8vNT0jUo9MsdPi1CL UbG8j0m40rR4rOM2EjXXiS9toYJbK1it/ns9qW0Uu7eiusnS+BP2XvgtDA1l4O1uC4FvYeHt PsLnwz4p8R3UNp/ZZuzpdq97YeNWmtxAGBSFfNNxDKY5lkikKv8Az6eOfiL43b4S/Bz4PTeL de8M+GvEn7XHjD4eeOvEcfiLUxfzeG9S+LnxX8PXek3jQ6hbWSqdJv794rfVY9Q07Zpao+nz W8UkY/ZPwz+y3+zD+zN8ePCHi/w58bbr4b6xq3h+5vIfg5ea/wCD/DunfEQ6Tp3jBH8QS6Fp WleHp9SWeHXriBrmbTdQaMaJEv2uRYJY4vMzutxNlVCjPFcR42GIx9OnPLKGHyV4z2jk6KqL FVMFl9enhVH2nuSrSoqWrV7StccRh3U5fZ6d/eT6W06dPwfQ+rvC3gj4HeD10P4T6VL4Sn17 QfEUvj620KbWILzxM+r3Gk3umSaxNpl/rGoa6ko8N30lhA0slzaiyFvNGsO9Hg8a+Knx2/Ys 8HXOt/Dz4nXPw+1Y6DrV/eXXhXU/Efgi3n0rxDqYvdW1ERWmpeK7XUEu7ybV746hZzwWYF5M ImglVYni/A7wx8e/DeqfHvQP27D4i1nVvHOn/FnwXpGp6XZ6Z4u1HwofhJD4Y8O+AfE+py+M 4NKvJLDQ9O+0avdarFdancaXDe2l6t7ZCOaQp+nv/BRD/hXnxR/ZR+E/x68G6F4L8/xL4n0v xfea94bsNHvpryKTwN4pvhBeajZ20GrXLtPp7faZrpvNjvLSVZ7aO5Cxxb0OEMZhMzyCOb4z NK1PiOVOGLxNCrRTwua4yjLFyg6cKvLCg1Tryi3CnGPKoLluonR9apJNRoxaj7qu5apWs352 6euzPffGX/BQz9k7w7pfh/XNU8PXXiS4vbHUPD3gm38Pw/DvWNRm0rT7PT47jQ7TzfF1pJfw 3GneI4LdtMhOoRfZbq48wNHekT+m/s0/tgfD79pvxhqGg+E/hJ8RfC80HhvVb2fxD4y8FeG9 CstQstOvNKim0J9V0TVdVuZFkudUt74WTvLb+XY3F28Pm28YPwN/wU/8OaLZ+K/2NvGmg+JL f4XaTY3sFzd+O9Mij0+DwkupeLPhhFPqlx/Z1zoV9D9ntLpELLe2Ehjdo3mVVkQfQ/7HHib4 SWHxWGmaD+3V4i/ai8Ya/ouradbeDtVuPFUmmWSRNper/wBo6W+s634ksG1HTodGAhWG888y azdrCiTF4ZfDzbhfA4nhxcQYDF5gq6eIp06dfEcs6dWhThOTs60bxleFnKPSWvQrC4ydSrKm 8NTUHye8pTv7za6vonfRWaP1atYREYLS2itoHRJIyHIbS1EYzFHGXheKDyIleGR47RXlusCY M7tKtyTzJiBbQtHlElmWR5JY/NvC4kuFd0crNb/ZgJYgiKFmjPmLnBhBkRYoWknllRriWWK6 jmW5tjdS/aFhlaUKWWNX8uAiOMeTGmAVKmkjuJlaRQpBYMo5YbcnA79Rn1H4V+Oz+sVaHtMV JTrRqJc1XH6uKnGKtT+s8mm1uVn01H2VCCcYJymk3e6auknbW3n/AMEiFqwYM0isoI/eAHAP +9xgjI79x61JLbBY3LTI27y9q7iSw6/KC3OBgnHbk1Yie5i/dmPdk7sHJzjkDhiOcY+lPuJH MavvUSZx9lw2E2/Ln7+OVG/hRjPfqSLb2VN6r/l5Dy0+Jb7fd2N6dWnouZrVd+tr6pdr267e hAtspESuhiCLu3upVTtCDaCSME9Rz0BPapZrcy7WiUyKAQWjUuAc9CVyM+xPtSRXTlwssJjO z76bpGK5UEbUVmCk8kn5QQAeSKknaFZFP2oxREZYtmMDHruKjGe5GOa1VOvJLkw9Scf56bjU jsr6Rcm2l0W19jb21NyXvbLfXW9t1Zf5aoIYXjjMcrFYiS2xwVAJYEZDY5z0H5VYMkCoiQor CMMCE2nbnBAOMkFucA9cHHSsW7vdFVWe51SGwjQhDPHdwwRuwO0PIxUr5kpyWLMCzY6nryM/ xc+E2kOY7/4k/DKzePcjLeeLfDVpdu0eC/nedqquZEGNwaIMpcEgdDvRoYiUlCnh8TKo1pB4 XEWeib95U+XSPM/iSurbm3NBJSjJuSXw7J3sr367t+WnW526zIwYOu3JH3iB2GeuP/rVZF3t j8qJd2AOV2kdQTyFJz7e9eL3H7RvwLtpZFj+I2jalcPGPLg8O3lx4od5CrLHDBF4c07VJJLq QlfLt4g9xI5AjiYgis+X9oDS508zwn4L8d+Lw2PKlHw2+J8MUi5/ekXU/gXyD5Q2kfP8xfav NejRyXNKz5lh1DR6Va2Hw/Vf9BFWm+vW35lU6ji+ZpPXVNpp7O+33f5M9qt3m86UCB2AKnIQ 7fmOeCI8cdD7irMYunYsw27SQMrzgg8f6sfjXyzefGf44Xt3JFoH7OmtvCChjnudfk0BnDog zJa6rodjNDtlLApKVYqPN4Rw9aUPiv8Aae1Ro0f4W+GvD8TnDy6hqdrrTQ5AdWYWvi/SmkAY CJ1UISxMm5F+QepHIpU4pVcfg6cuVc8LyqOEla8eelKVOfLK8eeEpQla8ZOLu+xYlO1462Xf ra+/R9O+h9GCGcS5aZVbg4bhjwB0I/zirUKmR/Ld1GwSRhmOFaW5kDoy+6bXHqM4UYzXzvde Efjz4mhNtrfjrw/4Rt5sK8nhrwvrcV9EEJ2tHc2/xZu1Bl3MX/0Y4CoD0y3LT/ss3+rTC58T /tIfHe6E/mMdN0vxlc6dpocMkZS2sb1td+zWrQr5cNo7yvBHKYmmlCsDy18swFCnUrVs1pyl GN4QoUas7zjZ2n7knFab/j0CdWU42hC7lZddNndW01V93+ZB+yeH00fHDwZhxF4R+M/iays4 SCqQacpi0qzjhhfMsVuF0N0hDsykKURmaOQn6+RdhKsXQ4YbVLLKMj7yYZHD/wBwqyndjDA4 I+KPgf4E0n4KfGXx54EsL7Wbq18dnT/FsF74hurebUb25N38Q1uCjWdjZRXG2HTLWeWaeMTv Lcu5I+VF+2Cqu6ujB2KBlGOGxIVHXtkYzntXTxXCk82p1qVbmhVw2XVYv2NZc0ZZfhlVTvBN ctXnjrba/mOjJ+z5Je7u7pdWlbytb5WeoTWkd9BcW8tykcM0ESOfNaO8XyZrZ0eWeOSO5Us0 IB/0klhIFZnUkN+GniN/i1rmt/HXRfgj4++KOreFPhbp/hv4j3ckuseLfEDXPijQrv40Wmt+ E/DM6614xkllvNN0/wAMMdDk1Sw0+EjSnk0CNr5biT90wAyrv3F1YgJEDlfvAg4EnGMZ+7lu e2Kx9MEdnd6nEln/AGYkuy5ja3eLT4b+6826WRLiIwgTyEGEySs4LLJtPQkfp3gRnFLA5vnV CUfaLGwpUoxm5RUfY/WJ80bKzcubW7tZKzvoeDnOFjUoq0pJK2yTvZwt0vbTfrbS6Wv4Y/F/ XLb9qR/2kvF2meFvinq+jeFrT4I+PPhpHrE/iRG07VfAGoL4q8d6VoA0DXdStF1DUrf4eaTK v2Oa68q/1CxnvbSx3yXN3yfxE8GfFLx54C8K638NH+LGkQ/Ev4H2OnzaAk/jmK+8J+L/AIae I/gJoV7JeXmlahqF3bXeqrpfj14Bbx6feaja3l5Pqlo0sd4tn/QZMZIvOhRHWaKIPPaRXcUC koHnhj2bWEiXK/JMF35jZlYpniiHvwy3cEt0LuZovJs4tQWKLSreG3kgu1QA/u/tkxtZJFVr fzJBvMc2N0f9hyzmLdNwwtFJqLl70/dbaul5Lo3d69D5bEYFunG1WatCK91LdN69duztfTvr +Hf7RHwO8WeDPhpBqXw4tfFvgjwFr/7LFl8YfG3h8an45ksJfiroOgeI7jWdK8UTXlxdW66z rGjeIYrLU9PvnEWpQ6FM+r+H7lNPtjDofsP/ALS/g74GeCvidpHiTwv4xn8V+IvFvhXxNZeE rOw0ywMul6/b23gPSrbw/Z3urWt3qIh1TwzrWs6h9k0GytoZbmURNe3hu51/c9LOx1uyjttQ iXUbNkme9huoV1K3vbe4it42i1CJ4pIpLO8i+0pMlwpjdDKsjFXYHk/DXwq+Gvg4TyeGfAng 7w6J5oprmTQvDXh+zk1N7MF7A3Uukadb+YLKeWdbVZ1kaBprh4Wj85zX3NDGLE4KMPZQjzJX cXJtWmpaX72ervu+x4aw3sasZKcpKN97Wd121tv+Fy94T8Qw+K/CnhnxMlhf6ePEOhafr66d q6C31DSYNTiFxFY6hGryiGeBJo0Zc7CZE2gBlz7l8OFKtrgJHB04ccf8/wDnsK81W3DxvCbZ QbsjaSqKILaIqYUVXUBUC2saqhZQofCoMKK9I+GyKh1sBSCf7OznGePt+OgH9a3wdNKvTld3 XMresJa+XU2xM3LC1E0tobX1/eU/19dT1GiiivZPFCuC+KOna/q/w3+IWl+FIoLnxPqXgbxX p/h22uJYIYJ9evdC1C20aGaW5kit4oZtRkt45ZLiWOFULNI6KGYd7Va6mitopLiZ/Lhhjeaa TYXCxQjzHLKoLthQ2AiOwJJUZxmZOKXvO17oabTTXRp/c7/mfld4u/ZI8X3HwA+DPg658Ha5 rWqWfxV1v4jfGDw74D8T+DrfxLcXvirw/wDFm81K48O6j491jS/Bxe18a+LPDIu7KLWIYY9B t9RGnLdXUJa40fiJ+yPEvw18Ew/Db4bfEgfEXTdb8UfEHQtZ1bxd8Mzqngf4l3Oqaj4h0G68 awS+Kz4N1Pw6PE2uz3+oWXhHSvFlwLHR7a1jRi89rq36V3ms6bZabHqtzdrFp0jRyJc+RcSF vtIPkKIEgaWMMjqSwQHduDqC7tWJrXjvwt4d0SPxLreq/ZdEupfLtLr7BqMoMqQ3U7gw2VnP e/NHaTyEy2wUGMqCzOgfy8RRwrd3WSqpXgm9dWlO1k94tvVpWv5J9Ea9VLSN1fezs3p7ujXr a3VO+h85+GPAHxI0z4la34z+JE/h3Vb28+Hfgbw3aavotxJHE9/ofib4wX2oWsVj9l0whYdL 8ZeHQZrixxLLcXAhdjAXr11cklR1A6H2wG/AMDg55HIJBGee8LfFbw38WrXWL/wxBqf2Hw94 juPDUl9qEEVmLy7Xw74Z8RyXUFqlxJMsMcXiCGwH2iNJWuLKaRV+ztDK3SIuGOTkgYz0zyM/ iTkknn3r/NP6Q86mJ8Tszp0pOr9Uo5bh7J3SX9n4as73t1qp6d1ax9fl0msPH2i5ZSVldNfa SVr9Gl17Weowg7T6EHnt+dfKX7PGu+H0vfjvd3Os6Vb3dx8fPHmnmOfUrO3eSKwns5YikM86 kqsmoT/vE++QVYHywD9XFgUCjOSxX2ySR+VfIHwU+C/gLX/C2teIdT03WY9Q8TeKdQ8UXT6f 438caX5l/wCILDSb26uJTpPiHT42mknbLSC3jOF2rFEmIx+VZJToTw2bTqTjGE8F7KMpXtKp 7GspQTtL3k2lazV2rvc9ajyqnUcm0nKLXKrt3nGy1to7K+qt8j62j1LTJwGgvrOdeQHhuoZU yDyu5JCuRnJGcjIzVgPG+NqswPQoyHOe6/OQT6ZBGfWvJ2+C3gSIhYpviBAijaFtvi/8XLVM nLnMdv45jRmOSTIwLEBULYRAEm+DvhtY1a1134m2zEP5bD4zfGKUROvC7opPH2yQI/JQ5jfa QxKkE4Thlsq1a+MpqNPllUaw9GSgpyjCLc52k05NK7V7vToZKMbK8mtN3ezatpZO606P19fX PlIyI5ACcKcAk5IxjBbJ5HbuKGUhiNpU/wB1uG6A9Ccj157c9K+afEvwg1vTtK1G90r4ufEP TGs9O1K6h83xR461fEtnavOr41DxzKpCqiKFdXV2+ZkJHPkvwe+HXxv8XfDzw94jv/2j/FMG qaj/AGsJjPoR1oK9prmpWMQaa78R2wnJtraJwGtI0jX90C5Xc/VUynLnQlVeOp0oxq06Lm6V OjFValJ1oUuelGcnKVOMqkYtcrjFtu6SYox3VSLV7bT8raNdrt+fqfdp4PP0xxx/Xt6mnjf0 z787c4+gH9K/PTWtY8W6H8QU+Fcv7a99pfj9lmlXQbj4DJq+YIdJttckB1R3vNF3DS721vA5 1AykObYYuVkgX0p/Af7RlrqFlpLftZxyanqOnX2rWVrJ8EfCKtNp2mz6ZbXlz5yyTW0YhuNX 06MwzTR3Ehut8MMscNw8XH/ZFChF1546EcO6c66qOpLkdGn7NVJt8jso+0he9mnJab2rlTW6 Xm7rt66edt3932CwRByCAPqMd/4sD868k+Mnwf8ACfxw8J23hHxXJqsWn2Wt2niC2l0i+hs7 lNQtLTULCMvJJa36tE1rql4pjNsVLMr7kZENfPMp+Oljqs+jXH7UOjXmpWvktcWNx8JdLtlA uEt5Igbm38O3kB3R3MBBR3wJMNtZGUbYi/aGiikaH4z+EboxRJPKZfCdrZbbd3ijSVvJ8C3O 4SPc2+EUNIm9cqo84x9lHKaUKrrxzLLqShQWI53OqkqUm0qjaw91FuL297R6aXJUZKyaei10 e/3H1hYaZa2Mkl3GkjX1xFHDeXjyBjeujNKZ3jjZbaKSSaSWUrbwW0eZWCwJGsaJhX/gPwnq lprVjfaQZrbxDf2WqazGb/UYheX2mw6TBZTiSG9jkt/Jh0PTE8q1eCGQ2u6aORp7hpfMLbTv 2i7cRCfVPAep7WiEgGsz2CsVx5hzF8MztLYw20EKJB5bPtIXSLfHu0Y+bp3w/uFLBQR421NR uIXCEN8Ks/O0iqD90HlioyR0Ty7M/azr0c/widBQU6dHFY2GI9nOEK9NwUMNGHK5KnP3px6N K4rKzu7N7LW7vu9V0X6dDXi+B3wuFutsPDBW3TXn8TIo1vxCca5Jor+HXvd51ZmO7R5ZLP7M WNoN32gW4ugJxZtfhX4E0/wTrHw7stEMHhHX7TX9P1TSjqWsyi5tvFM2rXGuxnUHvpdTtxez 63qcnmwXkLWv2nbaPbpDbrFjR6l8do2SKXwb4InQozieP4iXUaMS7bU8v/hWUbqwUZ+7sxgl t5Khp1r42Rht3w48MT5jnwsPxJQMjRsqhnMvgaBdpycFGkb1TPTkzChn2cQjTefKU4KM6ssR mGYRqr2ajGlOlUhSqyhKKnUXMpRaU3y3TaHSUIvVpLRq79Emlt/np8vBvE37GnhHwp8E/iP8 IfgDpWm+FB8S7fTrfWD4n8ReJdThEdhqdtcIbS6uD4gvLdUtJdZd9tpcyvcXMahTGkIg7/xF 4e+M3w3/AGYvDPgz4MWvh7W/i74I8FfDjwtpltqMqPol9JoEfh/Q/Ec8Nxq76JDIv9nWuqXN n9tNhO0SJIbOO5229ekXHif4vCY7PhDpTttZYpovibp5eImIA4jm8NwKzbmJG5wpzguoHFWT xd8WIkQTfBhXZvl81PiP4ejV5gz7isqWQnRmRHdgYljyWTc2QX7KmKzmvjYVcVSoZk6OZSzL 2mJjKpVr+zjh1GGIxdSEq7hOVJqULSUU+eLc3KKzajyyu7XT10u27ba676K+/dH899x+zF4p 1T4jfAXx9+y3+zV+0T8G/j5beLvB2p/tD6p8TtCsrD4UR6XHqHhO68UWHhW/8Za74wint7nx TpserRnTL2bUho9pdvZXsFur259N/Zo/4J13Xx08U/tU61+0TonxQ+HUWq/GzxB/wjVpp62f haw8W+F9R1nW9TudRjXxF4W1vVZ4J/tKRQ3enXWnqsU6KNswMqft8PGnxLiWa4b4EagIXX9x cxePfA7S3E+1jECj3sTqV2yCJpX2uBulMLELTYvG3xIBZj8BPEqCZ2lk+zeM/hlG6jG9Zbgr 4pg8ycnJaNHnRyhR5jG+4/cZjxRxfmODrYXA4GjhVm2Hw1OWMp4vGVKuFhgq1GsoPFuKr8lW VB0400p03CfI+SN7cdHAwknUm3yq+jas7WXfTpe9t+1j8TP2vP2XfBPh39pb4PeGLv4P/G3X v2XfCnw2LanqHws0DxJ4w8S2mu6hqPxdv3thfCPUZpD/AGpr8BmiaIiCG8tEyqsM53i/9m/w B8RP2ePit8Ov2Rvhn8etM8Q2Tad4q1rR/jh4a1jwjfa1ZaV4P+KWn6Xpnh6XWdOsLXUdUudT 8UtC1jZSJO0NzYtJPbnLP+0fiH4jeJFkEOpfs9eJNRufIkkjjm8R/CyQPZ21vd3rskk3iwrs ia3uWaCXyy5WQosm+NZuBtPiXrdhJNfWXwC8S6St4zpcXFhrfwst3mRZG2WtwbXxbDK5gVXj g4khYRyMZISYxLccz4sq4XLa0sDVq43IHUjg1XnVeGxDnJSdfl55uMWuZe7BNppvrZSoU6VR yhJO91ZO6V2m9vNWb1e3kfHdh+2T4+8Z+Jvgx4I+EfwN+Lb6l9qt9K+J2oePfhXq/hnSfCSv DosF/MdR1bxDo8A8qzsfFBtJbSLWYZNQsrSEpOJoobn84LL4e/G+T9nz46/Cjwr8OvE0Hj74 6fG7wx4T02HXvDmpWXh5vDF54M+DN1qGr6lrVzHDaaPY21x4Iv4ZtSFwxgktfK8lmlYj9wLH x7NYz/2lYfs4+ItLvN6TahfWWo/CGG5nluy0VrJNNB41imlBuZLkRtl3BnnaaOFHLSQR/EOK SWIw/s/+KreazuP7TVY7r4SN/pFvbNH5kcp8eRtHdtbHykmVcpHhPNGSq+1gM3zDDVMylguG 6dWnjKmGx9fEe1nWjOWDdWUa1FTUbUW6k007NuFmurzlhKdX4qnLrtfS2nW2n4n47/s6fA39 qv8AZa/aN+Gfi/4weBdBHw+8VfCzW/hbqF38NotX8bXUc3hvwn4HufD02tizlvW0qKV/BEUQ v7d7eG7v5pLZrcCdEtuz/wCCePxq8P8A7NHhb4z+FPi14J+M+ma74o+OPiPxVpw0j4T+Mdbt ZdGn07RtNhMd1YaRJDAZLyxvcLefO0ccMiTFPOr9Ybv4n3Gpq0ep/BDxpqAtI1nsbe51T4Xt LpglaGOR7dz49MaNJHKkLGGdWeF2Dcb464y48TeE7tZ72H9me833V4xhuZrL4OtnzBJKzNI3 i2S5nnYywyBbmFUG2RvtCyTSoenN8dm2e0qzznIeWeJwdDDV62Ef1eLpYbFPE4WUlGS5pRiq MHKSb9xJaJMinRjTk/eWm2vayV9Nuvz0Od/bovvGd3+yT8SPDPw40e/1n4h/EoWHwx8M6NZ6 TPfWxn8b30Gh3mr6mZV3adolnpU+o/2hrE0/kad5Pn/Z3dVL/kl8GvhN+2V+yl44/Z1+LPxR +H3hk+EPD3hXxp4FFx8N4tQ8Y+JYn8W+E7K8MviTR2v547VP7S8M2dubqygs0gup2g8l4ZQY P28HxMvm+zjWPgn411i0t50a2t7y/wDhUGguoCb2OTj4gTiGWMCd4rqGSWWPzlClTuRGah8W odSTyNW/Z/8AGGs6Zbs0lppGpX3wmurOwkVhCkkC3PjydJX8t5F8x4YpFDnGSzEebwjmeb8I 5bm2HwHDazOljp4v61zQhOeIhialGcaSnKdNuUI01apK8oq6jdMK1CnieXnqKPIrK7tdaP8A l/yfdaWP5ovH/wABvjTrHhzxtDpvw38cQnWf+ChtrriyReGtRa4bwVe2PjRL/XrWO4sbpfsS faNOZLySCSKF3jWUATBJf0J8E/szP8Cv2vk8IeOvC3j7x74P8ceHrfT/AIafEm00+8vtP8Lp 4g8E+M/C3ifSvE+o+GtK8I2Gmzr4g1GKeBtY8N6nJFp+rWdxBdvGfKt/1EPjFby2MMP7PetR tHqbarIzn4PlZL7ywr3GweMWAu5iQRegefahCIGYXEuNG6+I+p6lc2NzP8CfFt9qGnStJBf3 eo/Ce4vEDGORDbTXPjl5LN7cxsytDMplITcylVx9J/rJxPSwWDwiymnXwtLLM6yWvCk5xlDD 4ulRpLEptxjS54TqSU4e9N005x9xJ8EstpOUZKpqmnpK21rfZ8t+n4n4V/Dj9jP4m+L/ANqL 9onw54h8Fa5pvw18Har8SE+H+salHf6Xp2t2+s/E3QfF+n3Njq6WL3GrNPa+O9dwZBCgNldw +UW05JZeG+Dv7EH7QnxD/Zw/aN1e68FXmifE/wAX6Zp2meHNN8aLd+H9M8Qp4I8M/GbwNptt pcFpp7M2o6gy+E5As1zBFdJfTXSfY0k8qH+hI/EHxErXV1Y/AfxRb3lwu2addV+EttPeMZoX kkvLmDxo8sjkRov7w3BYQW4LgIgihi+IPiW3tRZ2HwJ8WaZbJIlxHb2fiP4ZR20dyvnNI0dt F4yhhiEtxczzu8agh3ZvLYuSuL4r4q+rtQyulhnOrS+qOE6svqjw6o+3r1nLllTnjsJSeCc6 PPKbqKE7U7tZvAJ1FJzf/gW+nb1ep+ZfxQ+MfxA/aE/Zxj/Zt8K/AT47aP8AF7xzq3hzTdWf xf8ADK48P+B/D62nxW0TxVFf6j4n/ti9tbGyk8IafPdCVW1KQapEbaW3iEkUcnzPoX/BPn4n +PPjJ4z8I6zY+LPCOv6B8K/h3pmn+K4Vtbbwdea5oHhD4R2Wt2lrrOpeEdftbsfP4ktIcWaL JNp48p0eLfN+4CeN9WtdRbUbT9nbWdPuZJoWjeDxL8Nhd+ZHFHCJP7RTxIt0zqMLDC7CKHBC OguJ2XQt/iN43j1Oa4j+AfiJr+aN3ku28a/Dy1u7mB2UxCe5g8RzSMqQiCP95K7t9njDKAFK 4YTibPMtq1auBy3D4WhmE62NxFKrXr1KUcdWqxqLEYely+zlRw8HUw06NTkjTqTlGHNCKlKa 2XL3akqj5W0m7vRKyetrb79npfQ+Kv2XvDesaT+xx42+D+qfC7xl4N+LXhf4ceNvCPiy01nS 7600XxP4l3fELTUuvBmoXmrX1trUWoXpW/tXsDb2s0Gs2ksVnHbywW9r5X4p+EfxR1P/AIJg 6z8PYvAvi248fT/DLwPpP/CInSt+ui5i0f4a213CNNs0a4V7aSy1MM8i+WJLC5+Z1tpwv6VS +LPiFPLO1t8CL1v7UnaWA/8ACZeAbKWNImkilMksGoO+oXEstzHIRfvEksgkea4DSO5bF43+ JsqGy/4UfJHDdGGGGCTxz4MgSVFcZgljs/PiWKBChWIu8K73SEEFy3izzviClWxOPngsNGti OJqPEGYe3xGIq0aWY4XMJY6o4uVOUqlKeJqVPq/tIqVOC05Ls6fquHq8qhVUmo7RfRct+n3v v6afkx4//wCCcfgr4TePP2bfGHwN8B/EG/utF+LmjHxXOdVu/ENromg6hoXxK0/U7+eOWJhb xxSXegKZp2cRSXyYRvPjWvCPGP7Mnx3udN+JtjY/CPxvdm7/AGsbTxNYkaTKRqXhSTxL8eby XWEZXjBhS21zRX3xrAAupRnYxKmP925PHvxZnYWo+C8UbW7xygjx54Ttx50jLFAJRa2LZmWW 5ikRx56KiwlpUkj8uGSTxj8WPIZ/+FO6Ygjjubi/d/iBoJ8trNij3MoXQZDLON80itCJZDul +fe4D+3huKeJsPl9LL6uDyrEYulj555DEv286lOriadDBzpc86SmnGOF9o4xVvfbUm20p/s1 TdlK77Jtdk9Ld7Lv6WdvwCu/2DP2lPhP+298P5vDXgu+8U/A0QfGK60PX9LddYk8Oad4q8Le PPDWj6TqV2mnaXcx6jcaYPCsEsN9BqM8Ulx532kTSytVj9jH9mKL4Q6F4Dn+L/7EP7TmtfF3 w344bXbTxV4ftbMaDbRw6xFf+HLiWGb4q+HdOddOnSP7fHPohEsMciBb2Vo9/wC9Efi740Sy Wj/8Ko0pZbDVbq1DzfEfSkmgkh+xBo2lg8NztIjEiPeJJQxMhcbGLOh8Y/GtZpI7z4a+G7R0 CXCbviJaFkgjeIrOos/BEqGFblGVk8wTuyuGt3gYPJ11eMOL8TRngsbV4N9msPXdXnxOZ1Kl NVanPFTU8scVJwqJtRbjsuZrU5/7Jkt1Lrez22t013d/0sfkB+0b8Gvjx8V/G/jtPi/+y34l +KHwq1i28O6p8DoPh/cR2njPwWwsfC8+u6R8V4Lf4n+GYre9itANFgjsF1tP7X0S5C3zW++/ vyx/Z9/bP8A/BX4LeDtc+FWj/Fjwrp76gnxB+HeiX9g/izRNMt/Cfwz0vTfsc1j4i8ByPcWu m2HjrQ9SjTxDfzpqV3ojCNmljvov2A/4SH43SQXl/wD8IZ4S+zK8MvnyeOkhX97I8aQOtv8A D+WeRXLlw7wt89ujSKjSBkoDUP2gJZpEsdB8GW13LcX8srf8Jq1w+bh7ULBif4cCFVllRi0c cgtyYQJcKI2PFT4ozunTweDpS4UoUqCwmJqV8P8AWaeKqujCyjQnHARerleTnKm1F+63dkyy 6NOElKTTfK4p/as9Xouid+m5+f3/AAT0/ZV+Kvwm+MHj74o+JPhvL8G/hxr2larZ6P4H1DUX v/Ellqi6Z8OLSTV9TNxq3jSKC0vpPDesS28P/CY3E7KLFk0qBLkJW549/Z4/aT+A/wC1t8Tf 2qf2ZfBvhr4h2Hx50+HS/iHoXiLWrVtSt10nR/CMegapZabquseArbT7eXVdN1d3ez8R35mt rmxZrJVkAi+7nuv2ippJQbLwXFa3F0bFLeXxpcSI99Fpy6lJFNj4aSbwdPglnPmB7by1CB2u glsaVxaftJPESNY8C2AuFcxxJqraklrDaTxQpEI7r4aQQsmxo1jRAFAw5AeCMHwcRic2nnGI zLFY/gepLM8Esrq4eU8f9VxlGlUrYlQxXNlN8RUbqv206sZtUUuXmcVE6I0YRpU4cyk046X7 ci2stNGv06H5DfG/9jT/AIKC/Gr4NeDpfHCfDvxL8X9B/aSsPi3ovhf+29A0PQvD3hj/AIRW djZ3lzpun6RDczx+J5I9OktZfEGqXX2O3kkXUWUG9l97l+F3/BRH4ifDv4p/Cz4g+B/gZ4Y8 LfEHwZ4m8KyN4d8RbbuW81Lwtq0GmG5uL/xZ4iurO3TXLvSlW4trTBinvhKsyQAQfbF9aftG Ca4Nz8V/Bmk+W7XUjJpbalMyI02Ios/DyNUjX96domjTcExGQ26PM1PSv2jbe+tNKvP2gfCO n3usyCHTBafDvS9QL3FuYneFJJvBVnG8zGW32zXstrGv2hIxP5dsSnpLN8dgac8khiuCqOHy +cMzjh8L9cp0ISnhpcs6dGOV06c2p41NSnThJSlzXvvX1ajNpOKd+llbz79u2/Y+INS/4Jxf FSy/Zj+D9n8OJvCHhz9rf4YW0Wl2Gtaz4nvb3wLPo7az42tdQt3hOia5ZXskvhHxXcGCeLSb dhfwIxnjaFxP9IftH/ssfGP9oC3/AGUNbu/EXgzTPEvwc8W6D4n8cTQalPYaRrVxbjwrJ4g0 zw6LjwzrDTQXN/4enWBdQOgzoiQ7NRtka4ZO2l0T4/33jSHwH/w19Zaf41XQ49Tj0iz+CmiP 9k04Zl+0tqC6fZaTLO8TtHJGl5JNsmB3yFTGvYQ/BH9pC5H+k/tUXrwTgF4rf4V+GoYrCST7 1zbxR61apvcNLNtgWDEhILBiHrx6nFOa1pYGtjc+y91MPWrVoVp0542UMLiuWdbAwq4mCqew jUhh3TwemGiqMGnenBG+HwcHKUIUuZRV3otL26tLS+27t3PJP2hP2JvGXxu/aB8MfGDT9f0X TNH0n4YeM/AmoaZe3Ws2V3dXHiTwp408OwXlrbp4L1VRHbP4kgleaXV7QJ9meQ2V0iGG6+lv 2Xvgtc/s/fCXRvhxq99Hqdxpus+MdSlvbeea8gktPEfivV9ft7dLo6RoqgW730UbLLZQXKvE yGa6iKzT8rpvwc+Ktwksur/tLeOL9flAitNM1PRd4+cMofS/GlubYf6skwhvNw4kA82Qtt2f wK1GSTdrfxd+KOrrIjq6Wvjv4l6Mq4k3RFYtP+I1vFuUIDJIAjyNI+8vty+ONzqrismwmXvO cYqWXQpU6NPA/wCyTq08JUniKdqlKtCVVVZVHB06ihGul7OqoRSkdMMDT5nNUb8vutqMfdvb To9fu/X56h/4J/8AwSHhn4ueGfHOtz3mh/E3xr4m8dKk3jF9PvtK1TXdY+I+rC40y4ttG0uC G8sYPiLqMcFrrB1bSo5FhF+t0lt50/BeAf2DP2WPAus+IfEniH4oz614nn0rVPD2hatr3xO8 GwXOh2GraR4i0DUhHp/h7Q/D2mzrLa+I7nM+o6bq8sUqGSDZ5IR/u21+BvgBwqaxN8QtYIVo ljvvjJ8YmjPmuN0rI3ju4jZyiohidSjK7qZQoIcl+AfwUiuA8vgqW5lkkId9R8bePNSAXfy2 y+1i7SQkvIzIwUO4UsxOGTtjxniaLqz/ANYuKfa1aeGVJRweBqUaMKTpKdL2c81ileMGm4rV tylZ3vf1OjFp+yd3bpG/S13187fhY8f+HngP9kH4V/s9X/7OGhePvDh+F+o2/iHTNQ0vUPiB HdarenxVqM+q6gDqKT22sRtJJciOE2qW/lRRqI1Zi00rNM0b9jKw+GEPwVGuWeo+A9I+0rFo dvr3im+kQXv9umYJqemSjWpY5k8QarGZXuyqG4jCSJJHbEe62/wH+DBdAfhf4VlYK08dxNDJ dr9pjLCKRortWMgQKq/vFYALgIy4zq2nwm+E9nK/kfDzwTHMY2SUx+FdIViyMvl5m+xh5FXB 3b8ZJUlXxlfLxPFrn9ccc74sq1a+MWMhKWPq01hq1NSp05YSlDMHDC2p1JxVOjaNOMnCEuV6 5vAPmUowfvO9rJJXs0n/AJffojzjXPiJ+zp4nsLHTNatPE/iHTtM8n7FbWHhv4hN5f2eWzng Al0i0tp5sS6fZyr5kzmRYTkskkoku6B8SPhfod0w8L/Dj4uCeaCWHFj8PPHshlSUo8sYbX1E CljHHlmZCpACOuXr2Oy8BeE4YzJZeFPDVttwVWHw/o64IX5esCDKg46HI49qv6VY2zReZZW9 rKR5mJ4LeO2lUAgMVLxwsNvHRwT2rxK2aYGnhquBWM4mxOHnUnKFPF5xi6VGMJQpxtTp0cVV jOTfN7XmhFJcii5c0lHuo4RQi5Je9ZbJdNtUnstb3v8Afp59H8aL3b5Gn/A/483ioSYJI/C3 hfSldHZnZzJ4o8Y6MsobkgQhnjxiVI98QfC1n4hfGq5TPhf4JeINP3K5ZvGl/wDDyFSzhjEz f2P8V5ikS5Q3JIRlAl2dFr3lLa8VMLNczOxGA9zIotQu7KIrTujCQYBKbQNgznIw26t5w0MU lw7SsQNkjybHOQuw7WkRlLHBV1CEHnIyK8inUyanBKOR0MTJNTjUxlWWKtJNNSkqsJOSTs2n ut+y7KTnrGV0vO9vLRX1+XY+Wbu9/be1C4jk0nSPgJ4etnjKH+228XahdxuC6tKD4c1HxJZh ODtVmaT5gWi4bbAmjftn3rrHqvxA+D1gMyPKnhzT9W3xsSWRI18Q+CLtwn3d/mgyZLlGKbDX 16kF0G+XcqgYwk7IvO7oilVOSecgfjUaW+24l88KAcESFmd8sNxDMoLnAO0ZYjHAwOB3Qzlp 2jk3C8m/+pNg79O+HX/A16q5rDDTbslJ/wDAstLef4vc+a5PhR8RtWjRvFvxP8QSlSGZtNsf AsFqZGXMiq83w1ilO7dMY13ZMeCfmBIozfs0eENXwde8UeLdQgOUlX7Z4dt90YILLmy8KWjD 7qcqyt8vDcnP01LJAH+zyz713b9rPduoCEofkaPbkBsAg5wSAcE0kzaVGhAkVY8EtiGf1GeN vPHvzn2rqXEGYQapUMPleDlZNUMJluGow1+3+7jCzlu2o3fmbRoNO0m1qnrfbTrr6731uj5a t/2O/wBnxpy134avdXuWaRvOuPEviiKWRTkq8q6dfadbCTbkuIolj3u21doUL6v4b+B/wy8K uf7C8LCyIWFSw1rxHdHFu5eDcLzV51+RmY8KC3RtwAFeqwRxCH7Va24uEUDEyrHH8r7MDEzL ICA6g/J1zgkZNcXrnxe+HHhrzRrWujT5YfMFyP7I1q62tFGJXANnplwrbEJJKcEkBdx6KWdc S1mqNDESo1J/DLD18RhKi5fefJOg+aN4xcXy2vFyi9G0dcYwprmc9lHr8vPTXW9js4EFvuto WMULAh4xhiyuG8wAyK75KscYYdRjHFXIorYYBkEZGQBM2wn/AMdxyCcfQ+lfI2qftw/sx6Ze G1f4gXl3fOqCO2svBvjMymSVQsKLJe6FY2wdyylS9wkY58yRK0NN/at8DeJNh8I+FPHvixXD NFNbWfhTS45VjXMrBfEHi/S5V8tWXIeFSxYbNxDFeujlXE2YWdejmuNu9eWSxyd+XZ4uvBv5 66+ZtCdJ295bX7fy2X5r+kfV8vmSEK0bPHwFeIBo2AAXKsSWPHBzxuzjjFV1EsAk5dBu4yIx hSdpG51Ccjjk8/wndivB2+KHxQ1KOM6P8FfEUMKruSXU/G/w/sdyEBQWg0/W9XEZDglgu/K/ PlnJSnT6v+0LqMLC18F+E9GEiqBdaj4/t7xoCxDqzWlv4A1GKXOfLYb22u29dwUOdp8LZzBf 7TXy7BU9PcxSq069NLltTrU6WGrQhWgrRqQhOcIzTjCTSUnrHEQTsqd7O10lrZqzv2dtX6Lu j3qKbaMpJufnAZrfHb0K9vfv60g82ZJo4dskqb5QqS2xKySF3+75m777Y2sCM8YNfJ2q+D/2 qb5iw+LXgrwhG2wf8S7QdP8AEksW0HLKLzwHpCv5pyxUyr5e0AFtx207H4K/HvUJhNr/AO1N rM6SNFJJbaD8P9P8OBlLYmiF/oXiDRrtlMWI43aKNlcm5VI5xk8VXJ8Hg0pYjOsvq+0ahKGB lUlKKXLJyqqthqKULJpWcnfolqaxq1Ja06N7Wd3FXS0S+0v0tcPipqUGgftV/AG6upikPiTT PFmgsd9sIjPpun6x9jgkWVorgMLvxHEiGyM0kjShJRtWMP8AX8KRxDaMl490YlQ5iAYeaqEN h+ZHX5jGBkgbwua+Gvir8E9P8G3/AMMvild+IPFPiLUPA/xI8GGW817xl46164Sy8UeP/Anh +7XT9P8AEXirWNNtUmhvL19RtoYlS4gaOH981va+X9vAk+a3mBZCyM2AQm1WhBIjVfLB2rjc ED5yRnqfRz/GZe8NkmLw2LeIpQwOJo4yoqcHGlWhjXTw9Ko3JNSnh4xnHSVk7pxehdO8leV4 vS6ejvor2201669mtpyFbckg3BmLEA4O4EkdCP7x4/pVON2t9Tl3MFFxYQxDOCGT7RP8oOOD h+vXB5PSrJXO1g6lm5z83ORkdVA6VS1jEEumy8gvIsZK9disjAHJGR8x6ZPX1r0/DfMMPguL MtgnGFPF1JwctLSl7Obto1q5SS+aWxhj4KeHtq3a69U4Lr6f8OaTeaXZmBeQskmCBkmLaynC hR8uwHA4O35gec5t2ouGdbhD8zo5zlMsiFEOQRyEdhgcHJJBIBGrNcJFM20NuCAjIXGCGB5L NjjI6H8OoyrqRpAz7cYbPBGeTgdMen4V/adXmWI9nGHK4SV4tWcVaN29bL+vn8vOMZQbWqi7 O19GuW6fXT9F5nQ2su+ykjHzAyF5MfxO0QVzntu9tqjsBVw3MskxaVs+aEEmVUbgm7Z90ADH fbgnvmsjQ54poZIyH3MYyCQMfMoXBIbOSTz1HHWtmVY0kxjJAHQcDqecnvnsD05xX6HlVeFT DRcZKSpL97JXtFN8seZ93KUV8zwMTTd3ZJvTZa206/LbUpTKIppJIhgSAbjyQxO3+9nH3F6Y 6e5z6T8Mowh1w/vMsdNzvAHT+0Pu4Vc9eevauDla38kBsBvlOSp9fUZ/livQPhqxb+2stux/ Z3YDGft/p1r38HOMqsOV31k9O3I++vX8fU4K8ZRwtW6t8P8A6cpnqNFFFeweOIc9sfjn+lfC n7cN78S7nw74Z8FeDPhcvxF8NeMoNeh8XXMPg/X/ABzfaFLo974Yv9AhTQtKS3sGs9avWlt7 +61PVLdrOytrrU7Ky1SbTW067+4dr5yAAcgMWPBjXJJGCRn5uDxnnsOBmihQM2IliZVUs2FD TOE2kljhmLqFDEZZlxkEVjVpKtCzbj57Wv31XW3WwU5tST5Gno7Pv223+Wup+U/wF/Zn8bXV x8CdN+Ifh2yX4d+EIfiJ8RdX8F63pOr22h23iLxT4i+MmmaL4ePgjXNAudDt7zStG8f6VqUT 3N9BfWKWRtrSC4tba2vr2zafAbxp8NdH+Atrqfwy0P4veGNIvvixYj4d/ZdWt9B8B6h8RviZ 4f8AGmgazdWtx4E8W6fFo+g6VZ6xo1xL/wAI/wCHZ9Ltb57aynvrae6kr9TPPiVlDSrG0zsk JH+skO1pmWNHDCViI5pP3aP+5RpB8iMy0bbWNNuru+sLfUtMurvTzAby1sruO4vNOknRnU6h bpI8loJTve2aeNI3jRix4GeCWBw9OE260XJe+m3G6UuVJW5n1Wm2rduh0+1qO37vRWvo9duy Vm++r1XbX4o/ZS+B2ufs9fBTRvh54lbw+NffX/E3iDV08LLef2FDJqN1bxWaWL3+l6Jey79N sLKW5e502BheS3EcTTQRxSv9HIxJPTAxtPfGF/rk8cVr6ldWl3cK9lPBcWpUCKa2mWeJ+gk2 TI8iPtcMrbWO1lZTgjAyzhZWHONo57dF6n1r/LTxdxP1rxI4sxcasWqGfPBbqWmDw9PCNaPR r6vZqzta2rTv9nhZSlhaKad5xUrtNWcpJ7Lysndu3yuZt9di00+9vCMi3sbq6xnH+phaX72R j7vXIx1yK4f4QQpb/DDwMFRQbjwj4UkmwAMzy6DpgkJwqkkHBJfLnuc1q+PrlLDwN4xu2O1b fwt4imJIyAI9IvZiSMjpsJ5I4qfwRaLp/g3wpYrE8C2vhnQoFgYlniMGlWsRRyzOdyCNU+Zi SynOSTn8+wi9hlNV3t7WpdLWy962730b7aJnoJWpa6pyT9XFq66WfpsnfW1jx/8Aam/aF0X9 mP4Pa18XtX0g+IY9M1HQdKs9ATUrTSp9WvNb1aDT/Kgu7pZl8y0s2vNSaOK3uZXgsJv3aRLL PDj/ALJX7SOn/tS/Bbwl8WIfDh8G6prUGoJrfgqfWINZvfDF3p3iTX/DbwXrpaafcQSzS+G7 i6QXdhaSqszRGNmhdz+XX7denftPftPftK2/wd+Bnw4l8SeAfhV4f0HxhezeMtKPhXwpqfix tE1q0vIIfGF3qejXd7cWuk/FHS5YtOtdS06FrmzuQVuDY3MN3rf8Ezbj4w/Cv9pf9p34M/HH wgvgfUdZs9F8a2VvY6be3Pha41m88Q3Wtvp/hzxWt7q0GpW9vD8UIlML6rqDoW2PfSNYzSP+ lU+Ecjq8AYrELHYePFLjQznDQWLpTlUyypWw9CWE+q+2Uo1Y+xxlbaUuVpezXNzGDqO9uRuz tezWl090mr2f53ezP2S+I1y1j4C8c3wXfJaeEvFFzEoJGTFo144XPDLkrglTx1Fcr4H0fU7T 4QjStLkEOtnQPFNtpIma4tdPi1S41HWZ7CedreJ7uMpPLE0kttD9pEIxCpcK50vjVPLH8Ivi d5Uphu5fA3iPT7Sa0RZ5ra51HS7zT7dzDNHcxuVnuUI3W1wvyuWikC7G8hfw18a/CXhm61bV fjza6FoOhadqWr6rqOs2XgTT9G0iwsxdXN3qmo6nf/CiGKzs7GJWvLqa6u0iigieR1MQCt8D kuXU6WU4hPFwhRq51ha8XXwPNGSjgq7nh/aSxME26ukftJLSLbOptOiklr7SOrbjtF6JpS62 e2tmmfHKeO/gt4c+G3xG8AfEX4X6346+Lr/FTxmvivRfDvhjwnrnjbX78/Fjx3r2na14fj10 N4n1HRrLw7IJ7fUtS0eSa38MX1okAFje/bF8e+K3jr4q/EnxrYftP+GfhzqFp4I+AHjrTvBu m6edX8Rxz33g74d6tq/xC8Va9cWOn+D7zSPsPirSP+EJhuWt/EenaXePoKw6lL9mtNJvoPtv w38Udc8WavFa+DP2uPgN4w16K1vpVtLXxl8PNQv5rPzrdbq5jsNF8IxPJFGVg86aO32Q/uiS okbf1dzfftGx6VpF/p3xY/Z3uNC1q402w0+91TUNTax1sX1tJMsel3ml+HUW6vdWs2tZbOG3 mVpYVeW2hiDBn/RcJmGGgqGNTqSlGjh8LDD4+SwVFTjSjDFU8H7ZS54ylyq0FLlUY62dyKr5 Iu/Wzau3rZXSVulopO2uui1PN/if8OPhv4j/AG5fgzHffDvwlqsL+CrrxFq8lx4Q0G+t9Tm0 /Rfilpunyag01lMt1dWNxbaQ9pLdb3t30zThBLG9raiP5S8EeAfCGofHz9qO7vIP2Sf7KPxO bTbPRvireaZpHivRLLw5q3jrQbbT/D9rLourW1tbBbS1GoWcUdvFDplpoyxqoijii+yrb4kf Gy98TWtjpvxq/Yx1PWZGh0+w0iHxzqU3iOWe6CtDawaXbOgmluXucW6mB3dbmPByUKedeNPC /jDX/E+rWfinVP2PLjxgZTJrNjffFDx1pfiGC5uUtb1Lm40i18YWEFmlzaQpMEexh3W89vLB Aod5FMBj62DpvC4jCzq+2yV8LKr7Ga5YznXrfXaFoy56C+uNTafJaE26ys+XmcbqyqpNW7PR NXWr8191+1/J9Rv/AA74n1v9pXXPi1oPh7xbr3gbxH4g8NeC/B3ibxHY6LHoPw90+78e3lt4 p8Ez+JfCfje8tNUF5Zx6XbahpOh6XokAgsHjZpYls1qfA+18D/tGal4ftfix4u8YeEPDPhb4 cC48IeGvF/j7SLi715df8X/G1PF+sa3/AMJLoUOn6zJpR8M6VLp97pmkWQ0u30+xTVJLv7Bb Sx/QfxT+HvxL8can4W1D4ueGv2bL/WNIhto/Csl545+IXhgPElx5zLZ20PjjQP7RMt0YGhlm huYiP3ZkTJQs+K3wZ8YfEePw7B8Xfhh8Etd0/wAMC7h0W7n8eeOfDa2tlq97Z3F5FFLYfEzw 8t3LdalAsKPdpP5UqxxJJCkjb+/GYzKswpzhUw6p1cVUwdSnVWNjg6VJ5bhqWXypUlKjONar iXSdaVpRlHmqLkmk5GdpRVlK9/Pazj59r636aPv8oa5N4jvtd8PfAnwbqHjH4k/D7w/8c/G5 8G6foHxEvrHWNa8N6Z4I+I8kFla3WleD/HGiSeH/AA5qkt5b2p0rwtLYQxaDa6elvplxay3V v23wh+HvxY8S/Cvxn8XdA+J+u+FF+HniqX4ieEfhHrnivxJrep6S/wAMNS+JsWv/AA5+Ik1l F4XEFr4m8QaTYx3VvpnhnSzb2dvc2l7pl7e2sM1fU3h7wZ428H6h4AvPD/wq+HNhc+DPDf8A YfgqSLxve3Ell4Uki11YIrGLV/ipNFrFpcf2vqU8WpX8epXEkF27JeZtoUttnSvAvjLTtT+K XiLSvgrpctz8cIFtviTd2XiuC6j8Q2NvaanpgjtVuPiq1tpFy9nrGoxZ0kaeBPK7MY2gi8vP Nc5o1cvw+WQwuDwVKhKLqYzE5zRnSrpRjD99TnhqMZV3Jc3svb83vVH9l3cXLdeTsteze3fR adt3ey8YsvjB4o8d/C6D4hz3mreFPFH7SWqafo/w+8F6LrOoXOieBNB+GPiyz8N+MNUvLp5d L1GXUtUguNe8QXb6Jo1tZiwg0m31SREhvNRfw/xbpnxB+GP7PXiP9pS0+PHxTvPGWmfFDxd4 Xi8I6j4y1tPBl1p2nfEjXfhrDbWVnHq0Oqoy6dpkXiGzVb6SBI4vktFgVZIvs+D4Y+I7C58D 3I+CF403wys/F2neEvI8S6VL9lsPiNBeWPiaG4R/ifi/eSO/vpo5J972KTq8EmY0ji8g0/8A ZN8JaT451L4hN+z745n1e71vXddmjl8deGU0+HXvFH2u41i+gg/4Wvay/ZLk6xqP2aCW6mW2 N4kZt43t1W28/L8VlK96o8ggnB1fZSxmG9xRcf8AhMu6sW513FpScede1sqMrLmJRlLvrbpe 60/q583eHfEHxI+IXxu8c6jqUP7ZMen/APC4NUtNI1H4dNr1/wDC3R7K28ea3pa2c5nIgttG 063sLa31P7LeQxQSaZrMQtoUjjjtNnVvid8WfDvxw03UPG/i34q2Vlc/EyKx8NeJvBeo+JdX /Z6fwze+L00+C08catq+teHotP1O8g1IW9slhPqGniLVfDMiQXSOLS99bvf2aPD+l+M9d8dR /DH43aHqfizxVqXirVYdL1z4W3ejXWpXetXWtXKodW8TarPDp9xeX1zPEtrqCyLbzMq3Eaxx CPhv+GcvCNj4mOtaR8IvjnbW9x4suPHes+ETrvwvm0S98Uw6jb65BeyTz+Mp/EkNlb6np9lJ Jb2XiW0tvsumIro6yXxu/TwuC4fr5hVxdeeRTp1JUpKMcdhlGKjCMfZJqtZ8lvZvTVxeieiw kq691J2W2j8m7aX7/j5Hnng79ob4h/GM6Z8K7nV9d8L/APCQX+u+N77xh4Y1PXLzXD4d8IeE 9a1C48H6IJNYsvMvtUv/AAyZ5Iprx7EWdzds9k8w85eS8S/tD/Evwrpl78OfAHjaPxHr+kfF LwjoWkXHjGDX4PGFodfg8bXSWXjG+0X4galetanUpdPt7WO20qy8rStPtgLW6nhgVPoGX4I+ GLXwppnhrw38I/jjodh4b8UJ418M+J9P1H4eajrmi+Lo7K504zRDVPFuueH72ybTL+/tza6n oOpxia7LAJLFbvBgaX+zp4RtNYl8TzfCL9oDXvGV/wCKPDHjjVfEd5N4Ja78Qa34TGo/2abq x0HXtO8O2ixnVntza6Zo+jxTLGonYTxyyP8ARP8A1RVSnDE4LLa9KDU6X1XHU5ThXirRbUOd uKg5p3tq1d3VjF0q1Nc872dldp76P9Lf8O0VbT9sz+39H+KHjrTrXyrTw38OfDtxJY6ne/aJ tE8ceI28c2h0rVdRg1hItOvYNROg2ht2tbfV5bxGi8sTyWUcVDw38W/GPxA/ZR+LN3dfE1Iv in8GG8Wa/PrnhXU9UudN8Yaf4f8ADel+L9NFlPJ4ubxEFln8Wad4Xu3e9uIFn0e4SBw5gtIu im+Avw90zxvrnjXQ/g18d9OuvGPi/QvH3i7Rprjwtd6Xq3ifw/4vufGtpMQvii/1KwTTtZun uvsOnaxYQzokNrcJc25kSTpvEXwy8O674w8d+Jpvgt8c7C++IXwp1v4VeI10WPwxLZ/2PrkE cE0qDUfFOpmyufJt7EG5iuGdGRDHZu0ziWJrh+vShXwOHwlPFqjh8bCpPFQUqfsKtaUcIqcv idWUbq7UndqMHbVe/vrp5Py/y1ucd4O+IPxL+FvgT9mj4l6l401/xtP8ZI21fWNCvLrX1l0m P/hXHinWJLeze48Rag4SHUtSsI5Xuo7hZo7KJmS3uGhMWXrvjX4w/DXwz8MP2gL/AOJZ8UW3 xO8U+DYdZ8BwSeKIdL0vwv4109/GtxY2DTeMr2OfXNMjsLrRmkurVdPlt72zL2USrJHN77p2 j6BZaD8ENC1H4N/tASab8ErC70/w+ltp/g8zzRJ4VufBNnLeBvEyXOoK+kXjy3M0cVnGL5oZ 0CW7pbv4po/7P3g7RdW0O6m+Gn7Qd9oPhHXbfxZ4O8LXP/CDDS9K8Qafc2MlhKbu01Gx8Q3i pZ6bY6d9l1TxHewS28Dyuj3zzXzZ4X6k6cMdVyrCSzGVSca1b60vZV6XNywptez5YuNK0XaU nzR1Seiylz2+Wlr91t+P438vJ/h3+2X8TJvDEnhjxjptoJtc8WeEm8IeLbXUdfMN0L7xx4J0 jUfD11Lqmob5bmTTE8ZzLDpd7OGhW1E9jJbrqoH65eGriS+8K+H7yU2/2m/8PaJfSghmw15Y Wd0wLMxkYgygFmySeSTnNfnvpXwh8Dw/DTR/hfcfBT43z+FfCvxE0T4r6Ddyz+GodTt/Gfh3 UrHUdNF1dDxhaQTaV5sEguLOaxLzxzMkc4kMDR/WGkfFfW9O07RdOg+DnxWSHT9Ki07zf7O8 GSZsbCK0tbFSzeOzuzFDbfvfKRpCu5my5DeBxXgcNmDoyyrAZdlcKdBxxFCpi4VE6spqXtIS nGi3zLR2jZW3vounCcnLLn3ut3srJ/Nfpex7yIxKGAS3diCCR2zngfK5xk56+nHrNa2X2ZJM RwBzna3TAKlT/wAsgeQSDgjg/hXz6nxc8cypGE+DXxCdIAsMe6y8HH9zGBsAMXxBwwx0ZjuO ck4xUzfF3xqzpL/wpv4ghofmUiz8Hg+Yp3RD958QdmGcIrbsDaTgg8j8/pcMYpqpNYvKoyUZ SUI4mhzyaSajFe2u5Nq0Uk3eySb0Opeytrb7/T/L7r9We/R2jfPLJJGAXb5dxAGSAMblxj0q CSHAJRVIO4gg5GOcHhO/Xj9a+c7744+PLGWSd/hN4vhCqjxQSL4Fa6eeYqJWMK/EhmCkPcNg 7AoXoMAHk9U+PvxPS2iGm/CDxXYxlg8EmtReCLdHV42cxxAfEozOwkYEK0Zby1GCSfm7cJwl nOId3Kh7Oya95baNa81mrL5303OOtXw9LZxXnzLXWz/z9U+h9TNsthJJcSQx4MTKkjALJ5bb myXKYCZBJCvjIzt4J+HP2/Pi3r/w5/Zk8e+KvAuo3Fn4msNX8Iw295pl9exNDbXXjHSNOuoR Po+oafqEe6BiHVLlI8MEkRkJWuofx78WvEccdxdfBzxdf3YVxcMF8GW+lI0LF7IQzw/EK3kL M0YF0HmcKyxqojDtv8a/aE8C/HD9oD4QeIPhNqnwy1bQtA1++0KZGg1HwbZSltB1TTtZhRb+ Txdr7qWk07EgWCTeYnjzECzV9NkvDFHLs4wFfG4zIlGhVhiqtDE4nDRreypzhGVOUZYmM17S /PFuG1mrrU8zF4h1aPNTa5ZX5dneza3S79NdUfC37Hni/wCK3xX8ZwprHiv9raxbWvANjqs+ pfFOx8SaL4MsJtSvfCyeZomrXXi7xAbhrFL9zo8j21q0nh+2uLvfbhTbV5t8F/2k/jZ8Uf2m fBn7NGtfGHw5o+l/Czx7qlrrnjDw54j8W6hqHxQs/DTX7RaPdvd+NrS3e/upfhVOJrK8i1qK 4/4TySFY7dp3lu/rzwf+zB+1nodrpmkS+IvHGt2ej+GotCs9J1Kb4Bo1rodjFpllp7iTSfCO kXktzBpVpZW0stxdyrI8zSlJZXWdOV0D/gm7B4XsvhdrHhr4Z+KNA8c/CPxbB438J+J28deG 7ue88RXX/CExa1NqWnal4i1PRLhdQtfB1rC9ifD+mRwtqN0LGKzne3bTv2NYvhHB4nNsRic5 4Xr4XMoPB4GhDF4C9BxVSjLMFy4+TxEKHtadaVNKnGafI69NNTPG9liqkPclKF2veat10TTt v+Xrr+aei/tC/H/xF498Rz+H/iL+0XrXxD8K/FHwHpnhfwl4ft/Guo/B+8s7jSPhnf6hPq8l l8SJ9cu0Sw8Ta9LqEunaJaRW99HCk8c0NteXF70Pxn+LX7SHiD9oi/8ACOtaj+0hfTR+BvAf iO48N/s8XPjwXmk69J4B+GMmuR+NtPu9Uv2stMv9W8QXjgyael59ra9N5Jc3LStN+x/7PvwP +LP7OjeKpfBXgPzR4u1S51nWrrXvEXhe/aKa50Xwr4ee1i8jxRpsFsi2nhHSbvyTFJchGubg TNHcJDH4d8XP2IviP8Tvi74y+P8APaXHg3xV4j020tNT1TS/FPg1dLa20/RPD+mW+6z1xPFV jbpFb+EbG5eWGRWZo7h5GMcjQx1hs24OxObrC4iHA/8AZ+Ay6VLD53VzHAzWHxL9rBU5Yd4q EKMq3tYxvPFtx9qrQk7J5VMJj8PHneIcVpbReXn6b9T8uf2yfi18WvhV4q/Yt8JRa7+1TJ4c 8afD/wAc33jPwT4R1LxKfjvraaP4Q8LSxRWNgup6fY6xf2svnvftquiShTbeJJFFszOIO6+C fx1+Mut/sgal8U9L8ceNE+Gl3+1R8JvD/hay8b+LfFV18UtLF54++Cmga9p2tzW+oxaBYaNq 8t14tj02DTpH85de0wXlrdNqGp28v6D6F+w34y1Dx/8ABT4wf2To/i/xf8Bb7W7jwPq2o+Mb GK1js/Fei6Xolzba7pfhu50S3vy1lYyTySJa2oiluZZLW6dIxDaJr3/BOO713X/FGu2fgjR9 Jk8Z6z4W8Qa54e07x/PLos2p+DH8GXGhanAdT1zVvEVpcpqHw98Km9tf7ZTTprG0u5TZIL2S V/ReccCYaVDLsbiOHajwmPwWIjmKxuES5fq6ny2+syi6UZ1Pdl7WzUU7a2WMsrzOqk44uV3Z pKCe9n/N2drdtt7H5DWn7WvxQ/Zn/bR+M3xp8b/FDXtU+EGv6X4a8CW/gzVvF3iGztfB+t+I fCGgeI9N1mS61fxVbeGIBdy+CdbtIFTTrC7uDr8fkSTMLs3Hk/ge3/aC0H9nH4y6B4v+K3jH xX4l179o/wADeIdLfUvHHjbRW0vw/wCKfAnxeso/D2n63qf/AAlN/Z2thf6QTb6jbaJLZQG6 a7XRZpoTaTfsT8Sf+CSVx8YdK8b+FPHXgjw5rWifEG+8B6vr2lQeP/EunS3V58N9LudK8KfY b3SLy1eI6dp2oXK6jFb37pcygNcl5I8HoPF//BNzXvFGmeKtA8R/D3wPY6H41g0e88SNYeNP He2SfSrfxrZWV1FcjV9QltbaKz8b+JjKYPlcSWsjoWt4d30n+uvh28JipUVkrzLF4ytGrjcL jcPJU8NgqyWB56cKskvbUqtVU25w5lGTTmou0RyfN6es606ilt7nw2315nv0v1TPmnxx8FPH nhL4AftQazJoviPwHqifA3xRZ6P4pf4vaz4u1u3uJ9X8Itaz2ukt8C/hbcW89vdLNPawWvi5 nV7BL2O4WS8aDTPnzwz8ffjP4Z+H/wCxh8AvjHJrMyskniX4bfFmy1DxXpieOdIj+DPjTxDr Oj+LF8U3t4G8R6ZZ+MfDdvatoOt6/a3svhzxFfXVvpMRsLa0+9fBf/BMKy8Danqt/oPhHwDI 2o+HtY8Ka5cp44+JOqbdA8RWq2msxG2gupJ4ibG4G29gtd9szIyyh8ivqC6/ZF8W+OfCvwt8 CanF8Hbjw98F/Pm+G9i3if4h2Go6Oz6Df+FLiSWRBDdapKui6neWNxFrIulia5NykSXUUM8P yFXiPh+nTxDq47BYx4vE5jKjWjUowWWv+z4yp1G41qkX7FwU25ukn1snd+lQwuJhKEZyb9+N 7q2nu7/ieB6l+xx8EtH/AG9/A/w6uPDjy+GfEXwD1v4hS2l7pPhISr4hsPjN4M0JtS+wSeFh p7o2n648Rvmge+VlaE3Ygco3wh/wU38Yal4p/bVPxP8Ahv4A+MHji7/Yi+HHg7VPhrd/CvRp /FnhS58Y6pa+Ifil4t0jxRqWgxPL4WnvtJv/AAzZWC6BNHqkj3Euoanb3Ns2nxTfvFH8D/jz feObP4p6r4y8BReONJ8O3Pg+212wGprGvh+81fT/ABFfaf8A2Rc+DJLGXfq+l2V5Bff2YbgL E9sLzyXe3Nrwf+zz8VvBFl4pstE+JVjoR8aXBvfEP9jLper2eo3UWi22hJI1xrPw51ltND6R ZWdgFhksY2lSacKJSbmvIwniJkkMyy3FV84jj6mUZPmOWYFYjFUKWFxbzHGwnjcUp804uWGy upmOXUYR9rzVKkJqcKkVSO+WAxUn+7qN+SV+29nf+ulz8Xv2cf2oPCev/wDBQP8AZ3/aQ+JU 9v4DtPiB+wn4e0fxpF4v1TTbW88M/EXTF1XQfFHhbWdY1/U9Mji1qz8S+EdTifQ9Wlj12zhC x6jEL+2uIl/pN8EfEnwZ8U/D9p4t8Fa1pviTQ7+a/ht7zQdS0rUreeKPVL7TZZluNJvtVs5F t7nS7i2j2XLqrB42aORZIl+M5v2G9E1+3Z/EfjrxRd3FxfXOoXy2Gp+GYomv76a4v7+5Xb4B iZDLqt9eFYAVSOCVFS3REUp674X/AGU9O8PWMOj6b8Tfifa6LFFHAkMDfDGZ0hV3LKsupfDO SdgBNPtZ3ZySuSVC18ZxtmnAWcRpVcNmuNy9qjRoUcLHL5ZiqWHoRUaFsSsXhuf920uX2UeX l1bvp1ZZQxuHrVqc7t+zi/haupNd0+z8v1+oYohHAf3XXOcKAeuP7vv+NW440EazM0EbABQs pCsV7E5APU49Mg183T/sreB9RR01Lxd8SNSRgVK6hdeCbYFMAlCdK8GWDhCVGSGEnA2tyc4v /DEnwGuy66tpviXVN7lmP9v6irtgAruOm29pGpVtzEAKfm5BUqK/MqmB4ZhQjP8At7McbK8U sMslqUG02lzKccfWfu2b5fZu+142uehh5VvZ1U7p88emmnL167a/8E+qP7f0iKVIrvUdItn3 qgklvLWBY2yBvaSWbMYQEM0mwlAN204AOBe+PfAEE+b3x34StjDuJEni3RU4VmDZ824jIAZS DnHvg14LF+w7+zNahP8Ai3d6wQqym88Y+MopZCp3AbI/EcALtn7oReCMAV1lh+y18CNPaP8A s3wI1sY2BH/FU+LJSGRQqH994jmBwBgg9epGeavD4fhRr97UzFbb4Gttppb2q1v5r8y71vPp 09PLy/PujsNT+O/wf0lJbybx54NuZIguVtfE3hee5bcABtdtaiZmxgAELhdqjOMnmZv2o/hB tX7Prb3ztlmjtb/wxdIVxyyhPEeSNzBVYjHzFTyRnt9O+GngrRF8nT9Kawt4JCYS+p38sYMm yR8PcXs7tukZ/vE4OVXAAFdU/h22EEH2G2LqoUtIk8kgMKqN2C0hHJxztz8vB656vrHCFJuP 9nY6pyXj7V5xKh7Tl93n9i8HUdHntzeydSbp8zg5ytc2j7a0d9l08l5X9bedt9fnm9/a18BR yCCz8E+NtZDbl3ad4f0a+BO7aAPK8QnJcDzFHVl+YcU3/hqzUL6Zbey+BHx01WVsbFj8LTWt uxAyfMaE6wyqmRvIjcnPRcc/TdrHdKhihCx2uQJGkwCABjq2W+6qjgHnpzW7FvihtkXAEc4c 9DgbnJOT16/l0rmxOP4bXJ9Vylz+Ln+t5n9Zt8PL7O+Gp8l/e5/i5rR25dbh7XW93tbT/gd3 b5dj5ftvjt8RtXHk2H7N3iOyaMBkuPFmpa74eyjhiQJYfhrrJklYIRIoEYQmIbpPMzH1lv4j /aJ1IEWfgb4NaRHKgQLrXj3xzqMiCX7rSJF8MtHVRGrASrk7mVwGQEEe43e4vJNH8xdk3YGR wu0YHXsc+9I/2qeElFXCqQVbapb5Og3EDJ6dQAeuK43muVwa5cnwceWzUnibqNrO7vRs0tW7 vXW/Q0vVdk+bW3R9bd0tm/8Ag9vBptK/aLu3An1j4CaJkbf9D0nxz4kAB6Ph9d8KZbI/1Xy5 3E+cNuHxrz4bfGvU5HfUfjNoOmrLsbyfC3gjxbpNpEyKq7bZ5/i1eAI4UPMPJBkmaVvl3YH0 G9tJBtyEXfnOXD4xxk7C+Bg/XqcVaht4jE7OxlBCEpEsxKktySfLUYyePnP0qv7cjV96jRyq +6tKk3pbXST11Xrq+qOulhHf/eU9NdY67f3tFp06/efK5/Z18a3jO2rftA/FKYsjsIdJ1jVr NVDEF38m51q/wi7mVfm+UMiljglqUX7LOnvuGo/FP4y62CRu3+JYPu4/1f7/AE7UOCMHng7f u9MfW8jWpMEZZFCKJBEzOzgpsUNsiLy4XO0k/ICQGO4rVX7dpKvNLcX+nwOiqQJ7kwHARuds rKSORz05rqo5/m1KN8PUq0Fdq2AwrrU73WqlDTm/mXS5u8NTTXNio8yS6x1Vk1pz9vlufO9j +zD8JbWJxq2m6n4jn2IXfxHY+GryWRmWDDXM9zoNw9zOuGY3BjiMsrvL5UW4pXpekfBb4RaS zS23wx8Ao0MdsI2vPBPhlZ3Cr5gMU0elxmZgyDewSPDGPAyQR0l9418F6cpbUPF/h6zRdqv9 p1awtERiSqr5t48MedylV/eNvx8pfrXIT/Hz4Kaa+28+LPwztclwovfH/hBJG8sguI44tcDl l3LvWRNwJQAZJFdrzXiXGw0q8TY+Lt/sWHy3FL2uqatUp0arSp29rpTmpRg07J8y2jQowtL2 8ZNW928W3ey25ns32f4s9J0/SdG0zc2j6PZaRG+d9vp+m2unWoJV0Z3itURWDK7lydu4FlJw xNaTiYqoV51j6/6PI8KdxxhZFA6cc5OORXiJ/aZ+ChUx2PxBsNYZjtCeGNO1fxYsjsQEhR/D Wl6wrTOTtECv5xO7amVJWQfH3w1dRA6X4U+MniKHIMUui/Bn4hyWkgHVkub3w1YoQgPzbpQS WUKGJxXJPK86xutXAY7B+Wae1oNfCve9vQovrtps+x10lR01W63a8l3vey/y8/bFEgaQrJE6 MqAB5Wkk+7824hFBIOQMD0B5pi3D5VPJZSeA4QhAAO7ds9B65A714qvxk167ha3034MfGGQq HMT3vhfQ9GtyHLhCRr/i3SrpCHYCUTxxlfnkVfJ2OeVPjT9oC7WY6P8ACmztJclbc6/eeHzG NxJzONI+Ity+BFkHYMibHHlgmtHkEoxhHEV8noWioznPNMKm3FRu3CUoqL01i2nG9r31Nli1 B8qoOUYuyavqk937rvfd6666u+v0TcQSvIrZjc8DEgYjjd9efSnWMRjuHDkZbsvCjLg4GewB wBjp6V8szW/7Y2tRyCPS/g5orP8Ac8261SSZdgC5Kx6lq6YckkZVjgDIXIBt6L4A/ahnYtrv xK8NaOrbTLD4U03TriSJjIfMhRtf+HWqxFIo8+U5lkLTAb5pIuvoYfh/LOSpN8U5VhpRjflw 2KweJnLbScY46DjG+0nu9NNl00sWqsXF03TUUm3qnd2Vtl3vvt5XPSv2iNOa8+CPxLRGImsP C1/4mt2IJKXHg8xeKoApALIxl0iNRIm14WxKjoyK6934S1KPXtE0zV4gR9pguwYgVkJNvqd5 BjcrPnd5S9c4zjHAr508e/sz6d4w8Ma5D4t+IfxA8T6hcaHrNrBZ3Evw9062E2oWMiSIBofw /wBEvDHPclS5aV5I0hQRGPMyybn7IeqSan8DfDl1NlpbKXxJp7iOLy/Lz4qvb4pL5mIyxhvP MO1vMMboEUtiuitLD0OF69KlntLEqVfltGnSfMpNpxvHEz31XW136OFO0r3erSWm97R2u1pv +vQ+l9zZCmAqOeSCOnY5Ucjt14zVLW4mubW3ZRtNtK0nAJJHlg7eOn3PXrWk7RSRISTg468Y 9Kr3IaW1mjjG5UjZyfrHIOv0HpXzeQ4r6jneV4nmS+q45JK9tHJQd3bR6X16rpcVaKnRk3HV aPdatxXe3V2+8rIGk+yzt0ImUgZP3dwGc+7D8KS5KBCuB16nGOoP6dB6c0tiUNmhUkupl9e7 HqMY6Z9KSZGdTkdfr6j057d6/wBAsFWWMaxe6r0VUTvf4oqS202em3ofIX5ZTp2veTlZu2kr K70662t06IsaOqQSrknEnltjgdWXjt/I10k5kWV2gjEgKpuB3ELjcB9xSOcnOSOg61y1pO8L wq2AAkYU4HUFQB19BzkV084Z03FS24HG0eh5zzx/9avt+F5KdLE05WtJK6vbacZLT1S9fQ83 Ew5ZX8/lay69dbehQffIxEke098A449Ny/5Feo/Dcsf7Z3NGf+QdjZnj/j+65J/D8a81aJvJ GYn6jGAeme/PWvR/hqzt/bW9lbH9nY29v+P/ADnge1faYWEY1YcunxP/AMka0f422PMxv+61 f+3P/TkNvPf5HqVFFFeoeAVfmBKu552ALgZAfeAuQcc7cZ3duwwT+Rfx8+Jur+IPjZ+0n8Jt C+JnxG0T4n2x+A/gv4IeF/D/AIn8XeHfD2m+KfFWkabrU/iG+l0fX9I8MPa6hf8AifT11Ua/ aarcR2fh+fyba9W4tdNl/XsZBxjooGfXqAN3HTByNp+8CMcg8Z4Z8CaF4Un8R3mlwyG78S6+ PEmpz3Edm0smpjwx4c8J+ZFLb2dtKwOi+F9JtxJcNcXAeFo/ONpHbWsHPiKc6iSi2l1tZdu/ 6PVrUuM3B3Vn5NJ9u68ltZ+Z+cXhj4U/tMSaH458ca78RfHGrfELwXo3w6+H3hzwcvxL16y8 NnxRpPgX4O2PjfxoWtvEsfha6n1O7u/iRlNZ8LT3d3c6n/a/2lL46fJB41+zcnjabQvih8Qd d/aG8Y6jqOpfBbXNE8URWH/CV61qXhzxjq9nBPp3jZbfX9Y0DRZr/wAGL4c8QQWEPh27LXr6 mywXllAFkl/a5g2Au1iVRWG/Owc7cFsE+byeij5Tj1JgkULE/wC73LJuXkbiQwfImXCgQryo G5sx46dK8zE5a1H2kas4QjTrOsua6koUnOF3K8tKlnaLV0rO60OulirLlnFN82jstrRVrcrV tG9nvt1Pkb9n/QtY8OfB/wAG6TrnjO48fapZjxAbrxZcvq8k+q/aPFOtXMG+TXT/AGq32G2n h0xftX3Vs1EH+jCGvY3LFSwyScKeeeMHOSeent19udLUnDXMo9AvUgn/AFaHn8en4VluiOgD FCM5ZXAcYwQCFJABzjk54yMZII/yN44qyxXFnEtWNZ1JYjNsfi5tOKU8ZPFVOerrGPLdTqfu 48tKKkkoK0bfZ0Z3oUm0l7qV9rJpX1Vtradjyr41akNP+GPjaPYZJr7wz4h0+NA+zy5brw7q vlsXKspAIGcbRzncMV6fbQpbwwQIoEcMUUShSQAkSBEAU9AABhc9ODXyr+15A+pfD/w1oCar q2jHxd8Q9E8LfbNImNvexLrmheJbEjaJY/NKeaJY4NziSSJPkOBhz/sz+J4xutv2kvjshAPN 34u1C5TcvJ3CO+tcqAcsuQc87gOK2w+W4XFZPltR45YJTxOauunRrVuejhp4WVGLtSqtezjO prT5ZTUve5mo8voSjH2NO8+Vvm6NptKF3ZJ2tfZvzV+v0xZ6Jo+n3Vzqdtp2mW+s3yhdQ1S1 0y0sr+/VVt4UF3cWsQkuES2s7K3VJpXGyytflAt4dlFPCfg99fm8Up4Z8NjxTNBHb3HiT+w9 OGvTQRCyVIpNY+x/2hLHH/Z2niON7nYgsbMLtFtDs+eoP2e/iJbIyp+0X8RpGDlv+Jnda5dc FVGCB4ttztH3kGeGJPOcDqbb4Y/FmzhWGH402kuE2CTVPBviW9mcrnBMifFa03OSfmcL8w2/ KDRiMBTli6McPxNgo4d0EqlGphM0jO/vpwk1GEoK/J7kOWmtXye828ZKKVlLmf8ANFKz+Ho4 rT5WTv0N/wCOFxH/AMKq8aNbuTJNb6VYlo1MbBr/AF3T7IhtwQFVFySTk7gXGU4J5f8AayuU sP2Y/j6yxRy+d8J/HWkwxykyQveav4evrC0WSKaGaJoTcXsPmySxtsTedjBFDecfGnwz8YrT wpY6dL8TfBmp/wBseMfAOnRRD4eeKYHc3HxE8H2ijY3xdvvtTFrtWZVRd2NoQlwR7BfaJ8Zo bK4j1jx/8HZbKRBasmsfDfxUtjcfbHS3hivpLr4tvC3nXE4t4YzC/mStbxKrOwU9WHwFHD5f lEqmOwFWEMylj6zo0cxpSmsJisRThpiasqMoypONF04U3KV1Nq95Fcz9ndN6JzSelmlBbW1s 43V9rvRq6Pza+Fv7MnjO2+FHwF+JqeFPgp8N7XQPAXh/xHf+J/BEjS+PfH9v408IWmnWWm+K odP+GPhNIoWm1638RakLvxb4ohXV9Ls1S2urjytVsc/WviNofiT4V/sTeAfBPinVG8UQ/Ev4 O6j4oiRdc0uNNN0rw54d0XWIry7mCQavEuoatbKbUSzpeqZpTGUXc36aG3+Oem6fZw2vir4H R2sMcMGnbvCfjDS4JIzCXS2tjH48u4zaR26O9rBApX7PbwONqRkLxmifCzx34W1K71jw34W/ Zf0fWLwmSfVNJ+H+saJqVw81x9qLvd2F+bq9f7VDHcIzzxlp/wB7nzCrr9ks5wNShiswrxwC hDH18dg8C6NXkbnWcpUU+d1Y06TlGLXtYNRSvN7nP+8qU5OU9eZK9l3jpZRWmvy9D8ifg5oG vX/wD8BfEa98H+HNMs/G3xt8L+HrH9olPHuv3PxD8FyHxlpmk28kvhG38KRanqdj/aWiSeH4 oLPxZ88OtW93cwQWEN60HUeGfg78Vfi94n/aXs/C3hqXx74gk8ReB9E8JfG3VvjD4h8Az6In hS813SNe1KXw/ZC91i4j8XWnh2TRUs5orh7QJbXlwRuaZP1efwP8UT4al8IxeGP2arjwoLqA L4ah0DxFpugR3v2231SKabTVg1TTVulvjHexMNPEq3DW18pM0a+azRfDfxc8FQ3Vj4U8Bfs8 6HLdBRdnw63ibSo7i5adr+GS6/s3wpbNeExT6lIBKsciTzzSo8im4MvsPijH4rA5jDD5Xk8M fHERwGBozpSjhfqsFhqrxddzxkcRB1Pa4igpLFUX+7hyxTTlOHSg2oq+vRSd7Jx0u32a19ND 48+Cuhv8ULn482H7Q3ivxR4i8R/A2xHgvTdRs/E/i/S7fSYtDk8YQ3vjjS7TwfrWhWt1canf 6NLPb215A+tQJpMEclzFHPClfPvwz1n41/Gnwl4G8Q6hrviP4r2nhj4f+ILvxt8PYvit4q+G njC+iu/GvxYj0DxVp+qaUml+FtdvYW0My2ml6t430eWCL4fQ2k9zaw+ILZX/AEA8d/BXxN8T fEeneI/Gfwd/Z81jUNF/0QyamuoX7ak4vmv2Ex1X4a6hPeaa07XLQk3MRc317mMPcSSHH+Jv 7PWqfE260S58R/Bj4QNceHrCSw0y40bxFcafLHp17qE15LYXE998Ddee6tTdyX009jbnToPs upXaNvl1Ca4TyJ5jg51sXhsdVwuISrYOeIoYWWDw2FoVo4ei+TDTqL64oSvzzf1qtzVHK89U kVaU6dNeydnLXdTd9LfFdLfp+G58NeBPEvxI+Ivx70HwN4ctPjT4+0Lw38G/EQvvAx+Ls3w/ 8QeGNX8P/FbxFoNxYz+J7f4nxLr8vg0TW/g+PUo/F17H4l0m3t9bZ/NL6db/ALN/DLSbrRfA nhawvdM13Q7qPR7U3eleJPEcvizV7OchpLu2vNffXPEjalcRzTsDfDV7pp1KMJvlEcfwN4q/ ZLi8SXOk3E/wl8LaA+geF9L8KwN4E8YL4bnfS9MnkkVBcv8As/6oZ576/uH1TVNkdrb3tzJN eC1gmy0n0P4Juvip8MvCeh+D9I+Fuj32l6JpkdhZ3Fz418R32pTJDmXfez23wl0y3aZ3mkyY rSMOf4VKMX8zjH6nnGHy3C5TQpqpSt7Km8fgadN1FTjFe3nOrTnOLhF6yrKXMlJy+KM3ho1n GTqu9tlyxi3ts42V+uzVrq12mvq7COwfc4IG1trMNwORyN6DOCQGOSOoIIFZGpXlvHDcQrIF cNHuZ4fP2HdH95ZVdZmwFXLMdgYBSRGtfOmrfGH4v6WkbH4LW052szC38TeJ2wN6qAf+Lbqe jZ57A1438Qf2mfij4W0m/wDEer/BGZdJ002K3PleIfEUQ/06a3t4Xea68Bw2yoLi+hhLSMu6 UKifOyLXxeX8HcUYx4X/AGXK71ay5/8AhVy1OVnC2qzWKT/w2bZq3GPe2lr/AJaLbf8Az6H1 Xql4bwtveXbHPG5hdmkgSARuDBDEzCKISpsy8cUbJt2gNuJrME1tcG6ZLRJ3nkHkuuyyltFd 2MkbTwqJbtJIn8uRZWCuiyKystxKp+TLD9oD4j3WnafqZ+CniNrbVobaezT+2debJvo/tFvA jf8ACDmOWSRGIiWIkyBSUBA4uwfHf4mRPIknwG8WQjDFxLfa+Ts2yBmMTeBot4wGBUugbBUu oyR7dPgfiSkqieEw0qtKUpOFPOsrVP2bk71NczcuZLo56tXcXcn2qT27W/BddV9/XofT5srm NHC7LOEZaGOOOGWCJsAF3tspDcsX3vmZGPKrnEUePzo/4KXfG74h/AH4JeHfFHwz8Z6j4F17 UvFk2mz+IbS1s7hFtYfCPiPULiUWE9nrEaQx6laWt+1tDYxkmBYYRJGPLb3m4+PnxL3G2b9n vxlgKrFvsmv/ACgnuD4W4GWGMgckevPxP+2V4P8Air+1R4S8KeEtI+F/i3wNqXhbxra+NbPV bzRPEer2N3e2Gj6lpdpa3Fja+H9Nna3WfVVnuIor+OW4jhdIrm0dg4+x4H4YxsuIMonnkMLQ yaOLTxNSrmuWOM6Eacr83sMZKvzc3KlyRin1i9WcWZ16s8NGOGko1I1YzlaEH7nJJS+KLWkn HbVWWurPHf2Yf2n/AIpyaz4t8c+K/wBpjUv2gfCfw90DW/E+ufDvS/htYeEtY1aBfB/jC+VN P1bX9J8NWCzWc2lQ60Y7jV7aK7XR2sX+a8WG47/4g/8ABVvwR8Svgr8afFH7O2jfEI3vgvwH e+L4/GN3YeGdC060vtH1fw3pdxosdprF/caxJfOusabcJJ/wjlxo0sdyyS3YljuRGyeH9trV fCvjnwtrHhDQrGXx34Yv/Ddnrfhn4T/FrQpvD66jpurWEmt3b3Xi/VWkEX9qJcxGKS2CpZXK NO3mCSD45+HH7Avxb+Efwr+LHwd8Ej4r6p8KvirYT/btH8b+GPExvtI8Tzah4EvrnULTTNI0 238OTWM1h4Bs7SGGbThqFxeateCS/WGSJE/T1wzwhiccsyzZYaGNo4jIZ4P6lnPscFWo08Zi pYurXoUcXOleSjRhKnJ0ouEE1SvOcp+HLE46OHcld1EnqoU99No8tna6+972Pvn4H/8ABRLT Pib8PvBng3XfD3xH8MfF3UPgv4b8dS+KtSHhDVdM8RuZfh3Nrt3YRaN4hmgsd1v4tsWjjvdL 0lriG7LCyt7q2ktoPFPDn7ffxB8N+LPghZavN41+LGm+Ovg0fGOt2Fha+BvDl/P4k/tL4cRJ KqapdabaQW8VvrOrQrJZavZRSTaygbS1isYrq2yNO/Z8+JWnax4C1gfDzxqsfgf4IaV8HLW2 j8E6/Cdljpfwd0+71mzb+zStq1/cfCeKc2sYQC31eZJXmeBZD554d/ZU/aL+H918E9Z+GUfi XR9X+DXwYtvg4x8TeD/HU9n4nXTpPAV1H4il/wCEfl8P3UV1LdeB7QgmacGK9vNoEixMvRhe FOBYYbPp18djnTxeIgsBBZ5glCgpzouqqLUPaKLlKfL7ac5KL0ldGFTE5hLkcbpcq2p092k3 vF+Vtj6D13/gpj4J+I2hfCf4mfBu/wDHdr4b1vU/FVhqngbV/Dehafe+I73wt4T+LesT6bql 5c3up6dpMd6/hrRriDUdPudQaBLSyZo/PkvbSLE0/wDbi+JfjjwV8OfEEp8W/C2LxF8XPHnh u11BIPAviy08QaRosPxl8rQgtpcWmoWdvop8HaSZLu90m0lnu7G2itTe2slxfN4p4O/Yb8b+ FvDXw08KWOh/ES8bwHf+OtevtSfwpq9r/bVz4w8GfFLwNFGBDo05hm0yH4hWF6VmeeSS20Ni s0Sywxwdr4Z/Zn+O+j6H4D8J+IPD8+qeEPhT8R/G3j3w9NL4O8Ywam6/EOD4o/a9N1S8vYL3 TGmtbr4iRpHe2NhpwA0p7SW2uZNQW4tOiXCvh9gsupYWGIxOIr0amGdalXzvD1p1cPUoSdaN OUFGrKs6qi4Pnkkue0LaqJYnMElNNxhFWn7lOzldNN6N7LZW/C59ev8A8FT/AIHW2ow3A+Hn xNj8A3XxNHwlh8fSWnhWLS4vFonWQwvoFt4mufFrafHossWtf2j/AGITJb77Lyv7SRbR6XiL /gpb4Ig1fxnpOh/CX4i6nongvxL4P8G+KvGg1HwZY6foWrfECz8Kv4bu4dIu/EH9varBHc+L 9PjvTY6bI1qYJJU84cJ+eFn+xV8ToNPsPBVzqnxOuvg3pnx7tPjPH4TfQvEFr4gu/FNlANJh 8OTXskF74VuPCo8KiTTb+6XwhHqP225tplt00520x/Xbb9jT4mP4a+J3haHSvFul2PxR+Kng j4j3MkkOvxx6bP4A0v4Swx6fqNunhCCFrHUj8M4AlxIZHH9qXYVQbZA/mUOAvD+lmGHeIqYt 060uejTrZ7h3ahel7Spjlg/Z1PbYW6mvYPDUpqTXsarjaMrF46Vk52VS0I3hTSvJpJ/DfT/L yP0U+Jtz8S/iL8HbTWfgjf6XZ+NfEOmeEdfsdY8V6tc6JaabpWpLp2o3ys9v4c8XmW4NvdLp ywro6q8lzNMJoI4Q8vxz+yp8R/2oNY8LfGa41u1tv2j4/D+rx+F/ht4vvfE+geCbTUtUt9S+ JWmaprEmg6v4bhn0Cw0/WfDmnaKsV3Y6jc3lpAmow2YiMttN3Xx60j4w+PP2eNA/Z40Tw3rf gd9F0zwBpV34x0O98UXF/qdn4KsbS3Ii0208N6KUTVr3TbW+k8zULiJI0MhiklMbw2v2R/Df 7Qf7PGmeIPAmuadqHjfQzpeleGvCHhy+1Xxtoun+DIbe41XzpbbSbzw5rVnHZzfbbQTjS7LR VKQxu8Z+0RJb8eHyrC5dw/meOvl+IxtDMqFLC4J5g+X+zHmeFpe3vDHxlKdTCzrKXNWc1yqS pxlaTjFKo3TjKUpSas3aybsl0sktdVb5lv8A4JfftD/ET4s/suap8QfjPrN7r/iOH4ka/pEr J/ZzTW2maZb6BMltGdM0zQrCRBFqBugVt0lZ5pYXdmRWfkvif+0V8el/bX+GPhO11eTwZ8C/ EFlrdto2kLq9hqc/iW80/wAH/FO/i1nU9MtfDUl5pAuL7w/cbLd9dvpIzo9i8i7L7Zb5fgP9 nn40fAz9n2/+DnhqO404ah8QLLx1PremXXivTbgm31zwNeXuiiCw8Nadm31fTvCp0gyOz+ad YvYpYJ4E8ifpPEvwE+MviTxv8KPjY2g2seofDjw3YaLZaHear4qupNXkl8LeLPDt3qmqMfAk c9kLtvGeo6koikumNxFaLLPObqeUc2Dy7JXnWMzGtVyWhh8a+TLcNWrYyu8JGKpQlBTWNqOq nOlOS9vOq1e3RIqpTxFKjClSk04q+0JW5lz6OSd/i6t2T9D81PjX+3h+0v8ACf8Aas1mY/GL xpaWkH7Tll8O734HvDob6QPhzD4w1C1e1sPFsNnq9ij6jofh3RIWt10+xvYj4mlEmrGfSLyW 7+0vjN8fv2rfBn/BRL9kPwF4019vAPws+KmveM00bwF4e8WWviW08a+HtEl1C7g13xVHaeEd Gi0q6msrzRI4dJm1DWJ7abT7g/bCSst1a1/9gr4meOvihqHxf1/ULrVNI8R/EHTvinb/AA91 /V9f1G00LWodQn1eKwjnvfAlzbQWqC+1KwumTRku44p4kWf91Ot39D/FX9nH42fGH47fAz48 +Ibfwfpmv/ASbXG8MaRZ+JPFs1hqK6ksck6T3N94AkvbSCQRpBbrp7xCUAo+4YA9LGR4TWH4 ZnhY5Bz4HJMZSzFU446rOrVq4LLk5uGIxNaCm50a8k6cUuaT0typTT+vqCdSbnBTjaPJRV9V Ztxgpf8Ak3TVWPX/ANr34nax4f8AD3wc8G+B9W1LQvEvxe+Pvwk8EnxHphSxbTtBv/EGoanr 8VxbYRJo9U0rwhfaJMLae3upYdURGuEtlnRvzV/ao/bq+LmteF/2mvhH8F/C9/pM/wCy/wCH 9Q8J+M/iNqPxCg8P3fibxU3w+8VQw39jo1t4T129ig/tnwn4rvXuJdWuXjEVjKsUj3wjtfv3 9p7wD8eviZ4Y8EX39i/DrT9d+F/xT+HnxQ0O9tdZ8Z3dxfv4Y1yaCTQJR/wh6XiJfW2t6mS1 ndxFE8tmjeM3CS/FXxM/4Jc+Lvjl4i8b/EHVPiHN4AvfjR4ejTx/4f8ACfinU9P0a7udW8O2 GmXMs9lceAvN1K8tYzqjPHrUt5ILrV9UjkmC3VwZfI4Do8KZfQyOpnmIwE1GpVWNUqFedOtj 8PSdepWqclOop0XRVH2cLun7aP2nzQKxtPG1nGlTbimlpaF9Gla8k9rKzuvkjqPhH8fPGXwv /a2/Zm+DXijxX4l1vQf2lvhVa+JrDTjdm+022u/D/hH4ha7fXdwt801xayX6nRUEdjLYJGdN hby32CNf1ct5riy8fa3p7TXEn2fSTdPEt1O0EKGx08yGGCVlhVvKdnDRBX82ViAGZ5a/PaD9 j34xSftAfBX4wSt8KB/wz54CtfAvgxZoPFMt5q1mul+LNBmv728bw/H9mvbrT9Vs3uo9KuIY ndWV98DxKfpnXvBP7RGq+Ko7h7r4V2YvbOD7XfQw+Obm0j+zswELSkWv72WK1hjKyzH5ZFTa VZMcHFeEyLNM8eY4THZVCWJy3GTlKNKtTg6kMxw9PCS+r+7RhKnhH7O0KUE0+acXNcy1wUcZ S/j3ny8qXwrZLT3LX6b7o+ivD+talq2tXksbSW2j6OZIYHeZVuGnffZzEG3ja5ZZbiC4l/fz uqIUVBggL0NrqdpqGoXulXILG1cpJHNbQtC9gs8lsbAshYlOHXzirSBWYhTuIPz1dH4/eC9E W7m1j4UR2tsYLO3ji0XxpvuXLtG07M/iSyjcHDy7kUk+cCepLR+FvDXx30rTrjU5PGfwuspb 9YzcPc+GfGO6LMAuCGdvG1mwKM8hO+Q8xsTghmHw+M4XozxMp0M1wMatRUJUXB14KMqd23yK apyunrzwktNndnqQxs3LlcVGCtzXje/q3d6eWu712PervwfA9vL/AGdcx2GoyRFTd2n2pYJo t+DDc2e+3tpd+1I5Glhm3RRxKxZVEacTq2j3vh2CO51RRaguYrbWdJEAmYyYebzrOGSwYC5w m4mScrIpJ++znyPWfEPx3jSKKDxh4Curee6tdNe+j8FeMZoFa7kz8s6fE7yyyNKiBC2fMO3B JGepT4ffGPW9KgbUvin4YtbZ4IbyaKHwF4peOPzihRE8/wCKyRhRLKmC6jPb5iCblktTLIQq ZpneCdGVdV6tT2FSfslNU6dSp7LDRcqnLThrRhTqKpblVOTlaRWqU5tOnFc11aznpJuNtG1t a6Xa1z1fS/EosCkOreZPFdKq2d9HHFcRu7GNEW4tZFidGCsZmbZOGV2jZmKgN2UciJC/mSLG XJ+0eXbRvFgY8oKMIY9oIZvJiUOz/OSQWr5H1D9nr4nWdhJ9k+NcvlytJPLbp4O8QWcAXyW5 tfL+Jc6mTblI90QCps+Yj5a5C1+EnxEFjLIf2gfiZDpiSgXuk6Zca5p19E5MWHjsz4wu7eEO GhuN0ysWRZpf4k2xVyPhXGQlVo8W4WEpJbZNnMUvfhP3YvLbQTnFNqKjfVSVpSvVPE18PZ8t 7d4p7W2v5Xtpc+8Yfs3khVaMIWMvm+RskeRiSQVRSdm1v4pMFlDGMNgjQtLqCPK3FwCg6bIC CAGP9xVJ+U9yfzr4qtv2ZNf1+1tdRuv2nf2gIhLBG0cGneNb2xW1hAIjtp2kvtQCXEZZvNgV VUEoyldpDaw/ZCt5Qsd5+0H+05cyMAFK/ElAZGICllEuizswYMoGCScjnkCvm8TluUYWpKLz 1Y2LnKp7eODxNCPNNqUoqlXwVOpFRellBU1tBKO3bSzGTvV9mlVklBvl3jFqyt8PXeybv6H2 VJEFOIpHkyO0a9Tx0llA/px9Kcg+xr9puIZynQOskcS/NgD91BcMCevzlN2CAcBRXyDb/sae C9wkuvil8ddciDAsNb+IGk6xEyjOY3Eng+JWjPBMZIBIUk8V0tv+yZ8JLSJVuF1TVVPzPNrT eGbqRnPy7XZ/DBDhSN6kkHezHb3KceH1T5qmNrTtaMVRp1Yz1tt/srjb1i30TRnHE1HKUadJ PmfM1ZWe2urdn2ta59Dz+L/D8Id7+8jHlbmXzba+cxsgJJbybGXdhQCR8+RwMniuG1D4y/Dj SpGS+10RhgzboNK11toDMpwE0tMkNgDkcVzFj+zd8GtPMezwF4F1I5QJJe+E/Ct7IGDbld3G iR5bJ2swwSFAGMV2UfwR+FNniSL4d/DtWQBgIfBXhtGyBjA26eCWwccYwPyqYPhhtOeIzJq6 suaSX4YNP+nt0pV8Tt7JdvhWluXrzP1vft5X4O9/ad+BNhHNHfeLJZjCyGSB/D3ivzE3Kki/ vE0aVH+Vg4xMeHCnaVIGFL+2Z8C4DHBZeJ77YilTFH4a8QDcoCDZvm0lDgkkZLd8ngZHt1r4 C8G2NjI1p4M8L2gfd5aW/h/SrRoizIrFEisSEyUZiVPzFtx5yK2rHw9pkEEf2PTrC1kCjPl2 1umEBJ2bYreJhltpHzY4+6SQR1KfB8UuWjntWS0blisFGnJq13C+XwqKD3jzzc7NKUnLU0VW s0rys9LpQirLS6+Hpqtb9Ls+do/2wvhZO4i07SvGOqbiFMVjpmlwRyk5wpfVNc0xl3KCykpg KBuKudldEn7QtxqxSLQ/g/8AFK8uJnCRQm9+EtpDkEhi09z8UkZQCQSRAx+b5Q2DX0FZ2xQ/ 8vNo4YbZI08pM4xuDZQ47Ag9COatlIZnkzFKxVCyBokVCVAONuZM8k8AjODyMGuerVyJWeEy HE4tK/tHXzOlT9n8PK7QxGFclJqV+Xma5el1fWE672qdk7Rp66q1vdeuvz6vc8Ni+IvxinUf 2d+zzrUyOFdG1v4k/DrTQ6YJBK6ZqviIo4BOUwVB2ASMGYxtufEv7RF1Huj+FHgXw6EVmBvv jLd3LcrkM8OmfCnU4mEQ5dC7hijKokUqW9wWSEMifZbR3AkBRYlSZQCOXGJC+Rg52x7R/ezw 6VVYkrZwBUBd0lsg3yrkldwkUKMZBJQgckg9K4/7Sy2Eko8O5TTaat9ZxOc1nFpxs28PnUKT Sdr80XD+ZWVjrhCtJWlPdau0FZaa7W67Hy3eaT+1VriyyW3iT4feFYSmwPZas/iZ4SB806x6 n8K9HEjZX/Ul1QhiTINoDYC/C79qO8SRrn9pS300yscpp/gLRJY0KSELHGUh07coCjLGOLJy ShJJP1nFJbtP5MdqYJmxtSOJEBypIIVQHPRs4Hr71emeWJEiZYkKE/MY2Mh3fMA2XTkA4xjg ZHQc+jHP8ZTS+r4PI6Wlk6GGo1Gtl/y+r1/Lo+5rRwtLS+Jk9Vf3rduvKttLLf7j5Gtfgh8Z 7t0Oq/tGeIbt4lBLWWgPpTuoKGQGTTvEtm+xzuJjJZMlW25jTb0dr8AbmWRjrnxI8ca5I+FK r4n8caQpQKw8vFh44Cjjad+3d8uD94mvpUT7vlErowTcRLH5SMo4OD57lmyQANoBBY5GMGu1 0udoZEK9ZC4UZPOcgjgDg81ouIs/qLki8PGF7pU8qy9q947Tp4R3u91zadfKqtHDQqqL5qmk fe9pUW/T3ZJad7a9U2eGD9nn4eNCLfU7PX9Wc4aSXVPHfxA1JGkyHyYL/wAV3cfyncU7RliU 2nrZ0/8AZt+BiyMj/CjwPfugXdNrWh2mvuxLZ3J/baX5gZ/+WxjYGfagmLiNNvrTaxalnTzY XeN3RmWaNvmjYo2fmz94HIJyCcHmlufEvhzS4FmvtY0uzLhmP2rUrG2x5YLvkzTIcqCC3Pyj k44rojmXE1ePsKFSTnNLlpwwtHDuXLabtVhSoyhaMW/4kea3K+ZNxe0KeGSuqburJN1KzXRO 6c7PRvddrJM5bTvhR8L/AA/LDHo/w1+HumbZo5kfTvBPhiy2yq4ZZNtvpiZZSTgnJwSOhIPf 21ra2SFLKOGwRCVS308Pp1soJGdtvYxw26ZHJAj6gcnapHml/wDHH4RaepGofE/4cWropkeG 68b+GIpWjGG/1U+qRlgy8KCVVs4yAc15jrf7Vfwg0y+EdhqsXidNikP4Ov8AwxrAcuJCxjMP iFQwiCgzHqishPUVz1cNxRVf76hVk+t6r7d1iV6fNeaOmEqSSSgvvlotF1e/fz/D6oiW6lRH ctKHPMu8KpAJUjaSrHaPlYlFLlS3zFsmujJG8gSNVZTtwjsCWJZdx+ULx1IJOQCOc8/I9l+1 xDc7U0L4D/HXX4Vkl8q4tPh4lxHKhnYLIL6z1q8SSJpMojrAAoGBvZMNs6f8d/iZq80n9l/s +ePtOaR2WNvEf9v6TbIXDuGuFt/Bt8VURnaNrnbPtj5X562hkOfVowdWOA5XGL5KuPy6M4pp PlnGeNVRSitGqi5001JJpo7FiIqKjaNkkvhvokl1T6K199N9dPqb7QYfklcFn4DRL5bruPGG RIz2P8Y6j04mhmnRWYCZgSxBMoyy7mK53SE5wRncScnnPNfPcXib4/6tG0dp8PfCGmNJuVZb /wAV+NYpY9uAS3l/DxSAScrhuQPyk/sv9om8KCbVvhLoqsFJSWx8c+IriMkKrRl21TwsJJI+ WMpji85sAwQZ3DZcLV3KH1zE5XgoctRqX1iniHWap35GsBiqs42+Pmmoxtpe+htRqQnzJRjs na3mumn37fN6e9vDcXKMwtvNDKyMog0/LbxhA0sk0ciB2YjcgYryzAcZ+Xf2YYT4X0nxh8Ob oPG/hrxbcEKj5hkTUPDPgvXEMflSTeWDLre1ozcSKzq7vtWQomlqvwd+L2uxN/aXxwl0a1TD TDwToPifQ9RK+ak220nuPiLfxrMHjWKB3hYRxvIuxiwx5X8JvDl98J/2qvGXw/n8Ua54xs/G Hw3Tx7b674jvZrnVHu1uvB3hhrJWeV4riK3tvCM7h0aWWO2aeMsscLondl2Ep0cozfLnjcnr TWFliMGvq+MdSM4Sg5yhJ1LSk00o+2c4KTuotJmc5clSy2corr1Ub66621T0XSzep93NGGjX ado4wMZxgH356U+IqvnQ7AwkhC7iQNpPmKTg53AbgcZGenvSkMYwFZc8cDJPPPGDk/lVeOR4 nBkjZQTjcQQpGQerADOAT16c18U1Gi6laEnOUHCunvy1b8ynZJJ3b1i1yu/w9H0WUoyg9V0j dx2ceqs9rd/N6lPS0EcVwHG4wOgwD94TDBPXC7Mk453e2auTvGqjCYDd+hzwegz79/8ACuQ1 Txh4Z8Kai8HiTxJoHh954o2ih13WdP0l5jMjW9sIo7+5tzIbi6eO2h2gmW4dIY8yMq0lj8QP AniSaXR9E8YeFNZ1yzjS5u9G0fxFo+para2j4K3Vzp1peTXkFu6y27rNLEsbCeJgxEibv7y4 MxmMxvDeRYiGFdZ1sows69fVKVZwtP3faQjHRK6hBRve22nxOJr0qONlTmuabSkm3L4G2kvd dmrrs357GvOzb1Kkr5bYwD12nIOe3T0Jrr7Brm9t8giPBcElg5HUjHyjOcYPTGe+K5CUhS+D uIZuBgkAHjcBjB6g+9dDps7vakxtt8tyD8xy29v9k9hnr2r9M4WnBe3hVajVe0LtbNPztaKv dv8AI4cVOU5Jr4PRa6RXVc2/pts9zTczRoyO/wBw7RgKdwBGG7Yzk8c4/GvQ/hvjOtYQIP8A iXdGLZ/4/wDrlRj9eteazzMhQEFwyqzuCSAxB+VieMggcE55FejfDN0b+2wgI2/2bndjPP2/ HT8etfeYNx9rBL+8krt7Qf4+uvQ8vG/7tV/7c/8ATkD1SiiivXPBCiuN8aa/rnhzQL3UdB8L 6t4v1TZPFp2laXP4ct5zd/Yrye3nupPEXiLwvp/9nG4gtraQR6kL7fcqwhECy3Fv538Dfi1q vxU0fxYde8L6n4P8T+BvFzeEPE2i6iNCZYr6bwt4Y8aWE+nT6B4o8W2Fzaz+HvF+jSvK2qiV L03Vu9rEIAXylWjGSg1JttLRJrW3ntquhSg3FyVrLTf0/wAz3Rvun/Peq9wdlvIe+xs9v4GP v0p5dvlCk5KBssF7nvjv9Biviz4Dftc6N8d/H/x0+HNrYXGn6j8KNX1K3tHn0o2cOr6JaeIP EOiHUIrlNb1cTTRx2OkSSpdW2iyvJqDvDZMqTxWPm55i44TK8xqyc17HAYms+WzdlRmmkm0n K6W9vXcdCPPXpqz/AIkY62tdtNPfrt3e1j26+usTs4K4cqSCR2RF9O+MdKpvdjaSQq/KPmJJ Gdw46Ac8n9OvNVtyyysshkcDAUybVflc8+TtThunHQDvkmtId0pgDEIRgDAPzLlurKx6A9c8 1/jdVjVxuaZlUcm69XGYzFxnUd17OpiZOMJ/FepapG8eWUFZpTkkm/06lQpOEaE4yThTi5St aNrRbSalzN3ld3SWjZ8u/tQ6o1zqf7P+jQFHNz8fPAupTqgLOLTTJZbS4cDHyoh1eMSPu3Iz INpySv1Dqeux6fp1/eSmP7PZ6XeajdI5ZJNlvaTXEqAhS4+SBlJSGRhyVQthT81/Eqws/EXx h+EOkGMTf2JaeJ/F00blo0jvNG1/4WLbXaP1d4V1a42wLhHEzb0JRNvonxW1f+x/hH8V9d+c /wBi+APiFd/aYI43uIjpPhTUbyN0E7IWbeN21cK3zDC5yfpq+FofVuG8NzYulCeDxNbE+xxF ejGTzangZ0WnRxFOTcFGftr8vK5RcPaXuu/EYejChTlFStGLlsrvZ6a2ulHutld2TZ+dej/8 FbvBGu6fL4h0b4N+Lta8PW9w1pdeKNGsfihqmiQzqsIMEl9YfB+5sUnWe5tbZ4Tc+ask8RYD zFQ/pX8LPiz4X+MHw+8LfE7wZqEF54Y8Y6UNV0y7tGnkWVEmltLm3kS/sbS9j8m8t7m2mM9h YzJLAylU4z/LL+zj8OfjFefsk3Op+Dviz4Z8IeDL7xTqP2nw/wCIPD2havqb38Ov6ZbyXC6t N8I/GOtiGaW1tJY4j4o8pFhkQW0ET+RJ+9H/AATl1PRb/wDYx+A8mk2a2FjF4Pu4DEq3LRS3 T+JddS+nh+13N7dKt1f293dR+a8IhWcJDFaxbLaH9I4/4G4U4dyutmeEx1J4lYyGEdFVMRWx UKnLTl788S5SkrSs5SrSm3dWsebhHGvWnaE+TpzWbtorWTlr13dunc9c+OniVk8YfA7w0pj/ AOJ/46sL3bgmZv8AhFvFPgfXcx/JgKgg3TbmX93nAY/LXnn7f2nXXjH9nbV/BVmzR6h458a/ DbwvatCInugbzxpo9xFPbR3BS2LW1xZrcv8AaCsLQ286SyRxsZI7nxn3XP7SH7Kun/etY7v4 pahdQn5VZ7Xw9pV3aOW4kJiuLASBEYKSgWQMjkH0X44fEv4OfDXwha+LPjVcWsHhbTfEWiTQ TXnh7U/EX2HXbeaW+0m8tbPStO1K6WaBrOaWKQRvGjmQSLiUBvgKdaGX/wCrMsVgMNmuHpRr YmeExEEqNaM8e3yu0Y883GduSfubtyuk369bDU1T91KMpRavK6dnstLt6q78tru1vyG8V/FD XPHPg34AfBrU40h0n9nPxXqPw88TX8aRafNqviPRPh/4+8I+Ezc3l9amwinj0bwr4pe5t9Dm v7W7uQ801xAttapcdn4f/ap+JsP7S2l/Hjxl4P1PQ/CvxF8Uw/s+eEdbvdA1XR/CN18Ir3x9 ZeMvBmt22v3/AIea1m1q607W9bu3v7u6t4ZNMtor25sbWOJpJPs/wV4m/Ye+MGg+KPGXg7SP D+o6Fba7Z+MfEWqP4K8T6C7eIdQvvEvh+DW5IE0fT9Subue81/xTZF44JWjTWLuR447e4eQe s+JfC/7OetfCjwbe69oHhyf4UeHP7E8T+GY7jSPEca6Sml+G2lsr3S4NMtU1uHULDw28S2jX Izhtk7S3cUYj+3xufcIV4TpUeC6HtIvEU7rD01SjUxsqbqxpuOKuqtOVG1K8Eo3ajKN3fxp4 WvGm4xrUYt2tec9PgdmvZuz0ts1o9tz8d/A/xJ+Lfgz4UeJ9fneK9+F3xk1KTwhZ69NpOnpL 4f8AiBqcuhaHZ20EtopnuBqVn4MXS7aHVdLt7Eah4kV1v2uIdPt5/p79kn4sxeDNc/aU1Lxd 4m03SH0Hwl+znb21trP2DT5oYbvQDZ31zbRmCGa+GoXMmmXkzLBexaet1DDH9niuI5D9DaH4 2/YQ174LXMej2+iX3wP8OeLNP102Vx4X+I6nR/Euja1o+rWmprDe6Ymu/a4tdlsGhm00zJKl 4tpdbtLk1aJOSNl+wH8XNW8Q3mkRR3E8+l+H4vEaaJP8dPBLahpWnWum2Hh6DW4NFm8P6frA tE0ywk03zVvJrT7NJcTPDe3NybmsZxHwrmWEzHCw4drZbPGVKa/tijSpUsZ9UoToV4UZU4Y3 2NOVSrTnCq6fvOjVlHnkvcWdPD17pynC3uvVvTZ63jZW38tH6e2fsp/Fi6m+GPwj8I+IrTWG 8WX3w08E67JcS+HtYs9Kk06Xw/4W0xpW1eHQU8N/2g+pSzv/AGZDq8N+LbddLposFW5T7ObV YwPvop6nJ6DPpt7jNeRG6+H/AIPFhpi6fpOhvo3hg/2StjoSxxWOh+HRbW6x232CxfybO1Mt oEtI0SSRYotsDeRGEwdB+Mnw88ZQXt34c16PVLdTLFG9tpXiOyNuba0+0XDXSavYWZfaoklT 7Ks26KPbtMxVH/Kc0w1DNMzrVcqy1YfCxVGnUVKhSrutOFGlFVp/WJVOScoxd4wkovWTV7s9 FU6a5eeUNN3q30TS/T56WPcpNYiiR5vOiIZh/EBj7q4+6T/D6fpXN6x4rtY4Vcy25y5AUOQc +WxB+4xxwewHIyemfDJ/ir4XvL6TR7HxDFPqIu5bZdOTTtdjmU2sDzXEkk9zp8Vj1ikdfKuz lGiVYw+9V5CXxvpWqXSW0OoTyI7T+WvkXaTebFNFbhZDJGIRDvkdXMf73HlmMgeZn0Ms4axF WpD2mHl7O+ilhMJFpWVtYx5lstYy69es1Xh18LTstVH4ndrRbJfNp7nqOp+LFuZdu6Mps28E 9CATz5Q7+tfNf7UniKKP4F+OH8yMKx8LR8542+KvDoxny+SPLxn613UNzLcnmRWk+ZcQBljU 7fkMhnAcnPP7ssMDkZOD83/tYX1z/wAKJ8Z21vFJdTfbfDsJjtvIR3ePxVpDurPezW8YEapl ijoGZBsL7iG+oyTJsNGpgaUIrm9tr+5p2TvHd2fZdHtoc01T5OZRaT3TSv0vvJr06W1Wu/uX ibxXN4Q+Dmrahpkqi+0D4aX17ayPF5yWuo6d4Tlu7Ge4iMMiyRxSwMzxSFYpVDLIcYx8BeCf 2vfidK/wl8MfE2XTvCfjGPXdHh1ee90iKzg8beCJP+EXtp/FtjbvaCw061vvsPjK68zSdQuY baMoUxFa2klz79N4u8UeJ/DGr+H9Z+G3iyfSL/w7e6Xqq6ZqXgW1luNHlsJdMvQjz/EKMxym ykZIJY0iuI3cspQlq8e8ffCXw3431HwZrOu/CL4hWV14K8LReGdL1rRvFPgvTL5dFuoJrC3S RLX4itFe3Vus1zJZXl5Zm6tbm8kuBIHCtD+kZHlWUYLEYlZvlv12njKnLhqlCnGc24U5SqKS lVw8Y0nZc6i5axk+VvV+PVlKo3KDUYu1r6NWSTvZNbp/fds8m8F/ts+PfEniXx0Y9c0aPwx4 j+FfjjXfAdtN4fW2uNI8beHfD0n2RHvbq0tZdVVpPC2sXw03UrOzSZL4Ro8sVvaNc2j+3D8X bH4BeIdPsZ9Gn+LulxaoNR1BtEhJk0LXbTxxquh6sdCFqNKhttK09PCsbTxXMkN0txFNfNBJ eOleseIPhl8ONU0LTNBsP2edd8HnTbi6ura+8Lt8MdF1Zbe7tNas9RspNYtPH1zqFxY39lq+ ow3OnXE8ljKJUcwrNFC6cbJ8KPhhZS6rPN8JviekviHwm3gq9dfEHgKVJtNg0zTtFkvIYH8e PbxavbW+nQC31NoBPFLcXkkK7bqdT7NTJuHvYQ9jw3SbjjPrHsMTh6Tw0qFLmp8sl7aq1QrO cakbQcvdi3GL0XA/rMOaSnBuS5Vdu26ld+69dLXWupP4M+OPxS8eeNvFUGq+JvH7WukeKLfR LCPwf8N9OvtMfTY9Y1MF9Rvl+GniRoSsADtI2pWTfZVMu5STc1+tFlfpDclpLlrqaGRJI7u4 RbaVXHklBNaxwwLtQMQMxRb0KMWOdzflDoPgu20TW9Y1fw1Y/tDeFhrWtTazeWGjeK/hMmnX Pkzz37kQXviLUJoYjBPNbPbRXESfZAkMSLLudvq6w+MWu3ty5s/hz48v4AC/nfbfh4moSPGI x5bi5+I1tYuobaAJIypjCBmJUgfL8b5NlmLrU6nC+WYLLsvaryxOEeGoxtNxoLDwptQxDVKL jWckqkOV1E4Rk7uPXl0rRccTGFTmd/cSa1srvmUXqvlfofYL6hFcSPvniZ5Hd2KkAFiSxIHO ASTgbj168UryQogYSqTuHy5GSSCfrxjHTvXx9cfHDxBaecZfhp4ytDbvJHNLNceAJJS8sytb oiWvxHntvOjiSSK5xCttnebcv+6kGv8A8Lt18KJJPhx4sldt4tlhuPBC27SYRoROJPiJHNvy SJShEWxl2HcGI+Cq8H5xJ4eMcLVWHVpuMVFRcrXTSsrxTta9rLotjqVbC00+empe8+XljB2X RatdOt/xPrmfyhZzTSMIk8ifdl1XICSAgO4IUsBgMVIB5wcEV+UP/BT347/tGfCn4KeHNY/Z k0HRfEfxBm+IWm6Ho2javDpOoRaxZHRtYn1eNYtQvtJj8yxsNPv77zYriI4s+rowSX6rvPjZ 4zvrWfS5/ht4oimt3E9y1lc+BED2YRXNsrz/ABHf5p3nVGYKjqHO24iC7l8b+JGhax8XbXw/ F4x+FXjW00zwvrJ8SeHhp2t/DvTnM1xomqeH2lu5LL4g3d1cy3Fjrkk0gncHz5ZZS6NmF/p+ FOHZZRxHgs3znAYbHUqNenVjSxkFWw0YRg4WxFKpTdNq0tPcqNPVa6rx8fWc8LVhh4RhKVSL jKUYqMbdHbnd+2j/AMvkLw7/AMFCr3xufi1qVt4q8K31x4S+CdnpNr4UsbeGS78E/HLVf+E3 nh0PUbSOxGvahewP4fXTTY34TSriTSpog0F69yJOf/aa/ba+OvwS+PPwb+H2i+P/AABqFt8N NC8P+Mv2g7bWdB8P2+q+Jbfxl478SS6PpulXSatBa+GDongnw9b310dAs/Fd7dxajHdXsGmz S2iS+uT/ALHHwh0rx54n8VeHf2f/ABV4V1jxr4n0Txx410jQ/EHgXT/Duu3miaz4u1KJ7zTY PHk0aC+uvGOt2t5ZWU1vZvYx21vEtosEbzdH46/ZZ0vxXe+MPG2v/s5zeL9f8XWdpD4o8T+M NW+H+r67b6fp+lQ+HdLsdEv5fiCbuwsrCygubqO2hJEOoX17ewfv7qQV+qKlwRWzmvmMOF/Z 0cZh6lGtDE4ek8NQjjYRov6unjKzjJRjKVOrywquS5pSTSZ4s4Y90sOlOldVIuUk5ax5o3s3 SvovTV/M/RLwtrWifHD4W+CfiNA1tqEPi3wj4V8Sk6ZNcajbQSavpVlfzQW8untZtLHYz6g9 g++HzY5Y3W5VJkeKJmg6XfzandxS6qLbX9PlkhkjaxhjFx9luvs8TfZZ5f3AlEFpIE86RlEw Uu2S9fLHwf1v4m/DrwHovwv+Ffw21NLDwzZXNjBba1rHha+j061OqPqLaZa3N58Q9/2LT1ub S002FY2Sys4o9PtXWyt4o09i07xP8bzqU+qN8KrMam6It5cNf+GSZbhGiErFV+IpjLNNBvaR VBdsuSSzE/j+IyjE4THZuqOHwc8vpuv9QpzlVliJwnUl9Xh7OVKUHShGUZP982rPljJ2T9b2 cZUYOaTrQSTlZWbfLfXfvZnv8Gn6tr9s8fiVfs7w3EBilhSKJZ40lhuHG1ZZFHlGJQxVskOc joK7BbewWGKw80tALS3hHzYObdI1HzAdcwc8nuMng18uy+Nf2lSqrbfDTw+kUnm4bUNQ0h3G 1F3mH7L8QpQDgEP5o6bPL5DEcpqXxY+PWil5NR8G+FY/s7BHgjMMzrI7Mv3h4vZWXLN0mIHY cCvl3w9xHjJ4PlwuEh7GUK16M6saS9rBTqQjbDxfNGpVcZLkS5oz5W9HJxqRSTqxlKVldpJ7 WS3e1rbeXVafan7qNmLOpibICKwJUE5PzKWc8Z+8M/iKhhtLRJDci4hLhiUWeaOIdyFw0sJI G/7xHJ4zxgfAV38Xf2nbvLad4a8B6eASxNyZZcLjGAreKNQXIYFuF5HGTkrXPXPxG/ahvNou v+EIjVi8SSWZurVQw2kgiC/RtysyfPsOVbAYgMF9XD+HGezhUlLEYbL6dSlSprEU62I9pTkl acFfDcqjUulZN6bpaGqxlCmlejVaTvZQpvXSzV520116/gvuvxzNaNpF0bia0W6W40kxRw3U bswGqWRJCLNNnEXmseDgKWIGKv6Dd6U+mWIN/aJMlrESklxEpDKMYKs8eDnGfT0r85rrXv2n r5raE/8ACA300l1bqxu7vWySofdtwL+OE4AAUlCVLFgQ6qyRm9/ajinn3yeArYROFENvf66i ohySAEvWB4RSMOcFj6nH0tLw/wATDBTof2hgqsvaTq0faSquEHVp0qTpX+rOShBRlUi0nJzk 01a7OKWaN14zpwfIraOMObS2yu107r8z9NTJE53RpHkHJkW4V0Y9S4GSNrDJGGIweCalaYyh U86OX5gfKUKpGM4fcHOeTjHT5h6c/m5aeIP2s5GhfTfEPgJLZQiPFO+pzclcKGNzazucIyhi snJGcs3J0T4x/a6067+zXOtfC0kRiUsLO/LxqzAB2eOwTcqkH5VEjZIOw4yvkVvDjH4emnPP MjnUslFRxGOlywdpOD5ssil76TsrrTfSz7lj4zsuRxvrrGGmqv1tfX/g6u/6D6jbW2oW62Wp Wpe1QhlKzSRHcMMDujOTzxjOKwdT8Jrq8tsJbua3tl5mjRIm+8wyDI53r+7Z1yPTdjIr5J0L Uv2qPEqsg8efDKF1QSGCLT9SRkwzqVLz+E7lWxsHSZyc/ePQV/EOtftN6SEtz8U/BLXl0zqi 2WiQuF4dF5vvh+ka/vThcE4GCRtzXHT4Nx0KkObPMipVLNwlVr4xRajy3Say2T0W6SVrpejl WoNWdOTnL4XGMLaWvf3lv0te+t7bn0FreiQ6Vq2h6PaTStY32taY7ho/MdcGW4kmEg5CobLB BwoAbJz19Q1K40u10prS+vjBYQQ2kRuVGJHbdAyxoPJm+YSLhtsbnajZ2jJHy7ovw/8A2mNb i0/UtY+KOjC5gml8iW30nwaWjCC4hUqJvhlOA+2ecBuq7gyMjAEOn+FH7QGvanNpev8Axk1S 30KF3nzo1j8N4b0yImIikk/wplZ086Qbo5wVEbMVUOkWx43JqdXlhjs/yKqsKlWqQhWxbc6d G05xpXy+m3OUYyULuCbesorVKmo04yahLnafs20uVTfK4tpt2Sdm2k2lqovY9e0TxjfWPmWu oRXU2jT3KpZXhtJIiWOI1UvDp7bgbTZKS6J1zuHIHcaloi36y38AuBcW0TZjWNnjuwq7shmV QCE3xnyTwUyRv4PiEvwl8Y2OjmbV/jV48g020bMKRaZ8J5ZDLFaly4KfCGWYEQR4B8xPmAIA b5hm+F/B3i7xLLPIPjt8Xv7JSVYInhuPh/YNIrQEy7ktvhzE4xcbkz5ceVBOGDMzcP1PBU/3 1DNMtjh9G4OriFOy5dbfV3G99dZLTW+yHTlWk17R05ddG9dtrxXnb+keuWGoXGmmea2hMrQS SR3tgwIljBdI2m5TzwonNuo2o6HdwxUlh6XY6jbXmnQzgwC0uYgSzXcSyW4cOGBD+W+V/ef6 yFf9WMjn5vmrXfgBe2lvdavafFr4zahqs4hLQy+NdPsrS7gmmi3rJbab4f0m2V0IFwHHkOzw rukk4ifntG+D+iWU2dZ+IvxyutJvYU+xRw/FnxdbK16xjaa3MGnajp6wQh5biFfLjiUIgZZd xEr6TybJM2wrxUcynGcW6c1RhTnBuFk3GU2pNtyvqo/iTUqyhU5Iwbjo9ErXdu9vv1/y+wk1 uys4XivrmO0XBJN3PCmFOTkkRQAKCRzkdQM1zmoePfCdju3+JfDESowDrP4n0WwcOSRkwXtw Z2HQeYgEJPyAb0fPmo+A/gSdlWXXvirqm44Y6h8bvjLMrDjCMp8aRDbxyNozgck1Kv7Nnwgl Ekl/oXiW8k8zG+9+J/xTv/MG1SGb7Z42nP3ixCgKqn5ggYsx+fpYThSnKVOtic4bhJqTp4bB ptxaXuv65BtXT3turrodtKdZQU4RipWsnNLZ2vdpS+Wn43v18vxp+GkcSpN8Q/A9m65G2bxZ oDAMAchj9pjBA4ZiCMA4yOtZcnx4+CltmSb4o+CHuACyrH4m0plLdx+6llH3if4unTjmsYfs 3/BNygXwFYzBWXb9r1TX7xmAIH7xrzVrhpCxwG8wtvHDZXitWx/Z6+Dybg3wz8EMqnrceH9M vGACkD5rq1uHPQZyTk/McsSa6PZ8GP3Y1+IHLrfD4O3TTTMr/huzX6xjV1o+mun/AJSIn/aP +EO1mj8c+Gr6dh/qrCe71GVjjACDTknEhAC5EcZIyFYbuTUH7Rfw8ZWa3u9SviDkRWPhPxxe ZUbvnBs/Ds5KZAUPyhLgZJwK6yw+Dfwe0t4zF8OfAy3GSAY/CeiKELngqV02IAgKDkZOT3PA 6+38BeA9PAktfBvhmEyJ5YMOiafGFD4cAIsCIACuQNpxjocnMvH8LULQWSYrF8loe1xGKxVK VXkaXtJwo5i4QlO3NKNNckHJpJJK1KFWXvSnT5pe87N2u7Nr4Nk35fhp4437SGkk40rwv49v SCQDa/Dv4lSAsPugf8UBMDuXLDDH5eeetczdftD/ABDjjMXhv9nD4i6wrYCfbV8SeHg7NnzF NxrXw6ggiCttAeQBWDEqflJH0jHpejWLYj03ToBnKi2sLW3K4yowYIIiCBxnJIAwDjrdt5Ss PJfI3fekkZev9zzCnTkfL1561azDhyUGv9VsNB6csv7UzmF2/wCeMMcoSSdrcyktXZK5UadV PSdNXt1l5f3X1a3u77I+RLr43/tNXnlRad+yFq0ccoeSK61H4v8AhS0GxdhwbW98N6fKWfJB BdWiIG9DvUFIPHP7Xd/ImPgD4P0MhlK3Gp+LtM1doixXbLts/G+ixyeRne8YQecVYL5asAv1 8ZlLIXZmIDgAtKwUkr9wMxEYIHzCPYGwNwOBhd8kx+YN5aZZcNs6HjdscMwx1BJ+mawhj8tp uTp5LlsI6+7Up/XErpaSeLjVcl3Um7rR3tZd1KnWa1nGzVnaUr205n8C17ba+h896Uv7TesW ry6xq3w68I3u8xpDD4BvNaYRf89vOT4uvbZwCArRnbuO4ErW2/hP45zW6m6+OvhyzJAJtdO+ Dtk0kT5G4LNdeNtUVlPLkGNmUMU3ggEe2tOGBbzYVdQQoMcm0jvkLEQep6nPTHaqRL4DS/Z/ LdpDHJEsglJ3ktu3rjGTgAjAHCgACphnEEk8Nl3D+He8ZRyDJHZ6dJ5ZJdO3z0N4YahzL36m 3d+W/vbO/wCK7M8V/wCFXfEzUYGOu/HHxLPGHBjjtvAHgPRYd7I3zCe80K+34VnCw+aWKsHJ by2Y4E37PFvqTk618R/G1+WAVmij+H9n+7H8IEPg9xngcjnj3r6XknmVFhum8yHG9DKWYCRR sUBYSOShY5aPoCCw4U0hsLDb5O3OOFkHYdMrnuc+3StY5/jJaRxGGpNfYw2WZZh6KtqmqdDC Uqabs+ZqHM3u2axpUYztrLZ3bbtt05nZL1X3XPmZv2L/AIOamzXGrXPinU5ZWZ5jda3bWpnl JLNK50+w0+MOXZ3xAkURJISMRhVGnpv7H37PWlyPs+H1xO5MX+kTeOPE4ZzGWIkKRazHGCSQ SAirxgAc19Fh7kMYh5S9Wjdt2BGeV4QnqvTKbufmOajFyilt15HK0ZUSKkLjaSCRy9rGGyFI G1mHBzjit1nGaTSvj3yNK6oQpYav5ctbDUqVansubkqx5oc0JXjJp9sKdJpbW0d5Xsvza8tH 66HHaL8Ifhx4dRE0TwwliFl85AfEOsXjrLkkOoudUlLkE5CbWBJA2npXf2ljBaRLDaqkIjyF Q+dI4zjJJknPBHqv0Iqm19CIpblyyRW8ckryCNR5axIZGcKg3NsClsBWY4wAxOK8x8SfG/4d eEWd9d8WRaYEaNZGfRPEd7KDMWWMf6Dot4nzMh+7woU5Izzm8fmdV2jmOPi1bWeZ49a3t/z+ e3poWoYdbyi7Pe701XV66eif6+wtciAAu6R7vlbcrGQgdNw3YXK8riNcjH3upiM7RyxrboXt 33GWcnJQqCUGCo+/wOn8XtXyNfftwfsz2j7ZviA94+8oY4/Bnjhpy6AAjdceHILfDH5Yz5mA Cm4qoYjQtP2s/htq+0+FtE+IeuGQEQ+Rp/hi0tJHdN8W6PWPE2lSgNEfNTci7RtV9sgMY2p5 DmuL/erASrOsva+3qU4VHW9p7zrOpNSqVHUb53Op7827zfM2wVXDXaVOejtdRjborp897PW1 1e260Z9cx3GASrEnpjbn0/2cj6Z/nUErO77iOnJOMc8cH8jnpjHavmaH4ufFTVIWl8NfCbV3 UlhFNrNz8P0QMgAk3pZ/EwPhWI2YiJPJOeDVE+Jv2rtSSaSx8F/DvTE/eNH/AGnc7pFRi4jW caf4s1CPzUChpfJzFncIiw2rXVR4Uzhz1wkaV4zipRoUWryg0lPmouyu03ypvyZ00alKnJvk layT0jd6q+8/617H1Sbq4ZlSKNXVgyyZIyG2nywOVxufjHOelfMnxA0hND/aR+DvjxkljTU7 Kf4bXUkh/wBGBvdD+JWv2kYb5itzJfQ2CqAgDI+wyqHK1jWuk/tj6hLHJc+Jvg/oNs8iEvps Osy3KjcJN2290DWIC0eURAUdG3Sb1kG1hynjrw38XtGf4aeLPiD8TIvEcOifGDwNLLpWn6Z4 Zgtw2pXc3hyOcSWnw90DUXVbXWZ45oU1hIiJnlFvK6gV6uT8OVYZvSq4jM8no4bD5biqOKw9 eko161WdOLp+yUMvlF+8lZzrU2m1a+6darSqTjyU5x96LbaWlnHa0pK29/l8vumGRpJGDjCA ZVgOv498Hj360MXLORIcqkj+SrQBp9hBEYRkeUE5K74/vGQADcvNbTJxd2tncIcrPFFMTt2l o5YHkXIP3ckocLgjGDxkG6ypmNwBu2jD4w+H2kjcMHkqCM8Agnqa+DqU42xuGw1416cIwcqr tTcou2ji5ytZPeCfe2p0StzyWqWjSstvO1tbrTXs+h+VP7aX7MKfGX45+D7++8Ba/wCItH8R fB/4heGLnVLG51K2t/Duv2vhnxqPDoJsri1Et9qOr6noi6fDelbKS7jt4pob63mu7WTzD4Mf sv698EYf2ffGnhf4SeKLPxj4N1/4ueCfiDJNc6pdXureCdWg8a23hPWb2yvJb7T9LSzfw74M tY5dD0pGvjrsEl9OpdjN+x2tYe4t5pXc+WY9rokXnx5mQboJHj3QPnBMkTxygKCrb0jIsTh/ s8axyBrieBJraKZVZ9kRgWZr2XyyJluUmW6wZp5GuFgkkEckbqP7Q8GeLMZi+EaOBoQTjktB 4bEyrQpe/UUY1G6ElGblTSqJJ1PZS391LV/HZthIrGwq1OSLlRptJN3+OVtLJd/+HVjAmQwu 0CW+5YkaISRM4icISgePe0xEbABkzNLhSMySffOjoXmfZ5gPkzIvBAbdgHp0I9D19eKrXU0L s6qWikUvE6pvCK4JBRdxc7FbhTknAHJ5yukO0MrwlmADRsMsz7t/mZ6lsY29gvvnt+s5S6lP Mo1a0venTdVRpt8vLOMaaUlaEW06kZNWaSUne9k/PxNLlUbONpbWvponrp5W69F6dfbykYSV c4z6r7joD0+tenfDQqTrgUdP7N7k9ft/r6dK8klneNgQFxtU/dBzuHJOcHrXq3wvbd/bhxjP 9m/j/wAhD3P9K/TsFRqRnQrNx5ZqTSTldp021dOKXVdX5Hh46olRnBp3fJrpbScXrrfVLt6n rFFFFeyeIfGn7ZvxI+NHgPwHpFp8C/AXi7xl4n8VahqumahqvhHS7/VZ/BunLo11EmtTWun+ FvFJkvY9QvbO5sIJk0dbp7CeM6vbbcNk/sr3et+Hfhj4K0uz+C3i7wlLr3i3xW/i+Xx2niLR /FcEttLpiWniXV4dV0bVtQ1Ke/0f7LoWlSapq9mDYeHNOs7a+FpFFb6d718SPj58IPg7dW1l 8SfHmh+FLy/tbnVbWyu3ur6+bS7WRorvW7yx0q2vbvS9DtpUEM2tajFa6TDN5kMl4JY2VIdX /aB+CWh6j4J0fU/ir4Gj1T4m3qaZ4J0+HxFpt/e+LrybWYvDVvBoiabNcC7R9dmXSHuIYxBH dx3MUkqSWV28My5V70ktOrSutejfmXGTWm6b2212+7yemz6HsZ3N8xby12KPLkPODhhI27+P LeWwOeQfnJ4PwnoX7MOv+FvCnwLvrXxHpeiePPhyviJvH2raNb6i6eONN8V+JtF8X+JdGuNR f+z7q7hnvtCs4AdV0x9uGEMVhAklpce//FP9oj4RfBO2lufiR4g1Tw9Y2sOn3N5qsXgrx7rm g6bFqUv2Kw/tXxH4e8M6zoWkvcTiKziTU762kkurrTrbYLnVdOS5lv8A4qfDXxRrGpeDND8a 6BrXibSNEtvEep6VpVw+pXOnaRqem6dfaXqFyti7x2yarZa1p97pKXEzPqFrOZrSC6jhneH4 DxLxn1XgjibFQk4unlcop35bOpXpU9+mlT9GdeAVT65hlFOzqxekZO+nZLXt5NmHGkgaZVcY QISWkZiwZSerBicYIOTwMY44FePP2wnO5wCOOcZQNn6bTt6dakS6MtxdmVss3kAkoVPEZHQK oHAHUcjn3NSRxHJO8JLygLhQVHBEQOS6EdM+nb8f8oK9N01KvCcKUq1ejSU51I0IRjWouped Vu1Ne6rt2V9e7P1lU6vPOLilejC9l7t3Gk3rZaXfZPutkfOGm3v2z9p/xQhilaLw98O9UskR lB2Ta4/wtvkMCgkKudLk84uVcuYyisN5X3nWtM0jxDpupeHNcsodW0XxBpN5o+uafcoJLa/s 9Stbiz1KCaMOC8V1bzvHIFaJmQ4yhwR8O2dz8WR+018dtR+Hej+GtV/sq18HaddjVBHIIoL/ AEHTLgGTd4t0MrIbnR5V4VvkV+I8Bn9evfEv7UsTBYvBvgnUGxkIkdvYk4bG0NP8QpgN2Cdx BC4wQc5r7vOMqr1sJlcKeOy6M6XD+V1E1mtC91gaMr/Gt+V30udC5WowdmuWzvLySVlyvSyb e3fVnLD/AIJ9/sTQlZ4P2afh/bSJISrJYX7Km6Joz5cLX6wgMrEMAqjczyYLklvqjStF0Dwz o2l+HvD+l2+kaFolkljpOj2KeRp2m2sKqIobGzR/IhVADgIiNuZjuJdifnCTxr+1WoxL8IPC rDIyyeItIQHgkcf8JdIQR0689cAVSvvHn7UsOWtvgh4cupFBKKnifTAzOEDKFI8TsuWb5RlW GccHkHHHriHMMPiMPXzyjLDzqUsXTpVuKrUYKcqVNJYeVR06duR6JWu+6uTSo0qTUrLdtcuq Wi1bvfa+11vbdlrxbFJf/tSfCiUDzbfwx4P1/U7gkFsDVtK8a2zGAqGUSXA0fywZniWUiJUO Q+OJ/a98P+KvG2r/AAS8D+Dden8Ka1c/Fbw7qcHjK204eJLbw8LHwx8R7oXVxpFwYbRY45oI fmluIoRPPAz/ADTknzTQ/iB+0NqPxr17UrL4M6JeX+geGvDejPaR+LtJJQQap8S4rZZANZVv MuJLi5iyA4Jh+UggmvZY/iv+1GptZn/ZqsZUMjQRPF450uIxnbNJJKInvZ5CViE6lZQynO8Y wgr38Zg8wy7McuxOFq8OYqeEoKi6Uc/wFOpyV6UZNuap1ZOMXKMnBws3FSbVk1FemqytKVkm rrS10rX3Wtm9uzR82/tBfDn4r6x4U8B/s5P4nHxc8QeKtV1XxX438Sapoz+FfDtz4c8C2sl3 b6bfxeG7DxXdJc3GveNfB1xp0Rt7K1MnhO4ke5MjxW8nxx4c8QeI/Cv/AAiHw6+M+iTP4W+E H7UWp+HL3SkEl14VsvCEv/CG6H4e1GFdZ0nwxFL4T0LTvh744tlvdWtre0fTdSQF2VtRjsv1 b/4Wd+0k9291e/s1WqQXEb25uX+IekQiOKNoS4cm4EaCa4tbb55I0IcJHEw80rJQ1L4q/tBN Bex6l+y7cTRalYG2vyvj2ziS2ttl0qvI8Vq+5NMW7vfOkjeESi8QzOnl25r18rznNcN9Sw88 Pw7P6niKrlUlxPgr4ivXaXtm3hXd0nCTTcptOeko3u/Nq4WDdnOy/wCAn1atr/VrX8u1vxr+ zt8Q9e+NK+DvhTpmta9Y/Azxm178WLHT9B1fwRqC2eiWl1BpaX1hd3+ka3qumzXekNHDqFqs 8F5pkUIliGnWUlfJvxH8K+GNO/Yb8F6nbeHNB0++vvifrr6zq2meEdCsNWOlTeNviXNAbu+t ILW7eze9OjQ28U15FaQRvbW1q/lC3tpvtqx+Kfxm8P2EulWf7L19b6RcrNBNbp8Q7a4imS8G LjdI+m3F6omANvmK7iKPtaNkY7Wzbv4r/FO4sjoUn7NGqW+mGRZ5YbbxhcXjJtZ5xgx6XNdM Y7qcIVWUnEjsy+XEwSqFfHU6sabeLxWXX96X+tdaUW2119hUi02lp5/fhUhKorQur2ta+1lo 0u1t9tfLT5u/al+JHh/x94u8Z33grWdH17TND/ZY+IXhS7v9DvNH1zTjrfijU5prSzkGmyXd ibs2/hqWZ7S5f7ZJBLD5MMkLzEfIXjPwHrvww16PR/H+t+DdL1LSvg58Udf8Lat4G8OaFoll rz6j4S+JEF5Ya/qdppXgm6a90ebS7Q28U8PisLZ6tBEo02G7eC5/Qe08b+JNA02/0PSP2bNf 0fTNZuJbq/tj4s1nUPtEpgazwLi50WWZUlt55I3W2liaLykfcjTIx5vX/iF4q186cPFX7OPi m7ltrXVbWMf2r4ktPsVnexMs6uLLw/EJDfBnjLSHzIEVXhMTHzG+2wWeVoqFGllM6NO3uSlm 7xftNryU3gqfKk/d5U5J6ttbPza+DqRac5SWl1uuqXf+tXe58i/s6+HLVNF8J+KdW8W/APVr a40XU746ZZ2HgUfE1JdV1K9mR9Q1GHwvB4haWNb0m/ebxBMZrdiZfOjk2V5XbeCtf02z/Zvl 8QQ+CvCGh694o0HWdM8XeGbOzi8R6jcyarpF3FoHivU08NeELySTUIdWnupRceK/ELNc6LM4 sbowi6tft6yXTNLv/wC3tN/Zg8awamsJiW6j1X4iX8YiuApkBjGhyW7KVkKo4UFU8slncl5O n1XxXdarpWlaNdfs/wDje/tvDF7b32k2wi8d26W91aJOtvcfaIfDMcly0O8osE080cvmOXik KAp11c3xcZwhUwcoUajSqSeJclyu124ewSkm7aXSd7eRzRoOnUjUc21Bp632TV7q7Vvl0u/P 6ukviWhdXe5KrKYpDMbyYhAXcI0pkdTksqhJCCwJypGB4B+03Jc6j8JLi1TzlF34g0iEKVaJ t0Uk92/neTl9oMD85dmcJuUAkpG3xn1/fJAPgl4+QyeUkWzSvGbsm5j5hUHwPJvJDZw27B6e g8g+OPxT1u+8H6ZZy/DXx9ZyN4mtE+zt4V8ZPIFi0nWJASzeCk3E7eWUKp2kgAHFfHZPk2Lp YlY6UH7OtUm6acZWi24PTpo1ZWStuehPER9j5Nd1votf0t+J9g+K/FNv4X8K654juZfsaaDo uo605+1xmZJNI025vYlh+1tDCP3cEjPFI0cDyLF56SqivH+bHgX4/wDxGl+CHx2stb+Jh1jx 3Da6b4t8HeJtPvdLvJvDmj+MjcWOm6EsAt7RorrQJvDuo3bKkU8af2kjW5heNmPv3xI1y++K 2gP4S1b4d/FLSNLGpJd6ld6X4P8AGM0t/p6WWpaZeWDNc+ALhLYXFtqUjpcWxW5jaHMW/wCb b5H8RvhL4a8aXK6ta/Df40+Ar20sJNJa007wv431tdRt5Jpv7Nv2Gs/Dy9kik0+4vLyUx2+2 K5UBLlQihq+myOjgKDq08yo4KvWxOIrxqVMRh6NSpgqcITnTm6lVSnH6xPlorWldTUU6l1F+ NJua5ovR30Xdv9P0+6j8Wb346fALUbzTG+NviLxPo/inwV4it9LF3psdhe6B4hXw/wCKNdst btY7671t7gW8vg37LD5Wo2hkuNSeLYEjlS7LHxd8YPhRonwK+IniL4qan420j4s3HhjTtS0X WLW206K0vtdXSNW/taO5vP7YtnuNKg/tXT5obK300ztqDzSXEBiWMa3iX4Zy+L9YvvEnjyb4 3eL/ABxqOgXPhfT/ABE3wz1PQbfw1p13DPBDe2OgaJ8LrS01a/tBcagkK6hLewzvqrma0l+x Wqw6Gn+A5ZIfC1h42tvjz47tPAtrHaeC7O6+GOtaANHmtX09Le7YeHPhHYX2pmWHS7FVi1Ke 4hCKS2+SbzD1R/s6hQWCVXBKqsXVxXtoYShUnGhFulSwV41FKlCEZpp8/LB07Kj7ycc4xc20 tUlfXW+sUtNbWX5PTZnzX8OPj58R7+/+FFnY/F34lal4w8WHQZtU8Oaz4d0ldH1Kx+z6Zd+J 7qUnxNrEq6bpmkz6/qNtfW3hVUlNmWuBokNv9u0/sfgN8Y/H3ju/8OXWsfE/4pXmsXEmruNE n0W3n8EXEljFfi0m1DUY/FMMUVoPKjF3P/wh12sFyjK0N2wMre5at4J8O6ro/wALdOT4d/GF NY+FGm6To/hDxLF4S8drfQWdhDoVld297bT/AA/fQLpNb0/Rhp93LcacZ7OK+u7nT7i0u1s7 i1yvCPhDxh4L8Lp4H0qb436n8NlGowXnhK9+FF3Zz3sWsGeTUoW8RP8ACuPWIBcTXcjQyW7o 0cjpFEx2mNtq2NyrHU1Q9hQw00lH6w8DSq1JXsrxxrjSlSs30btrLsYJzhJ2em9vu28tHe1j B8BfFL4jv8apdK17x/438M3tv4j8cQ3Ok+MdPh0b4eeLtFtxry6FbeCNZvdTK6nc6dp66Jrc EFj4Q09ZNMg1C5+2Nb2wm1Gp8MPiv8XY/iTa2ninx94w8N63qniR7Obw54006DRPDniHRbnX tIihXwrd6hN5mr3K3b6jYRG08LWElzY3ttIb9W8vToOnh+H08kel6RrvhT42eJvh7pGr3+v6 H4Gn8Jappyadql3BrVuiXXiPR/hdaeILy20tPEWrw2kM9zC8hNr9vmvZYC03KW3h29sdS0GP UPDHxn8SaD4J1FdR8D+H7rQWtIdI1SC405YI5b7R/hPZavqVpBZaJpNkYtTu5ZCm+ae8N1ce YN3LB08HKi8Bk05uCUZzp4Nzl8K5pOVJyba95u71bbberyp88pe829dLt6LTa/XR7H6baKkf 2+HR0G2KGOa/vJZJHWa5MaO8cDRZd2bd9kZUe4CmOFWKEAK3yD/wUa/al+If7Knwi8G+Nvhd pV74r1bVPHOneHNY8O6XPZte3Okv4b1m6iS0huvDXi8TT2F3a2c9zbJp1k0MFteSm+ZbYw3P b6N8ZvFnh2wDQ/CHxuiWomuZmfSvE6xxiNzP9rLy+DJAgjMcSZd3twV3SRsN6Hw342a54y+N p8B6xq/wn8WaTp3gfxTqviSx1Q2uti1v21Tw1r3hUPdzy6DptuiGPVyYlhEe64kjXy8Lx8Nk uQKXFWEx2a4PK6mSQlNV8LKeGpUsROal7Om4Spypzkk+de5O8adktW46YyVRYWUKV3Kbvdbp pWs7Ju2t7aWRy+mftt2us2/xi13StUtNV0fTPghovjfwjC174T1TV9O8X6+nxJvLfRru2a3v o7a8e18P6Oktt/aWphLq3eODR5VM091F8Tv2r/i98Bfjp8FfhsurRax4Us7LQPFPx7kibRbe ZNH8ceOfEXhzw1p0KXvhW/uYGh0/w1d31yt5rXgy2nt9RQQNeh5rlvlvwz+wt4l+HvjHxp4h +H3hT4reHdK+InxF0XxffeG7qwtNdkn0nTdU8WXx8H2+paj4e+2WtrqFt4phsDqD2ya7C2nx 3EVwZZbqNfVfF37E6fGvXviT8SPjr8B/ih4s+LHjyx0zRbbxZY+LP+EPsPCOg+FvDkeneE9L t/Cmj+Hjp+tzWWs3Gt+Iri6urhb26bXY7G+xplnpwr9LxOB4Gw9etU9jkdbL5YehGNFYzLuV qcZKUvglF/V9ZXUbx5t4XbfkYani6MaLqqXLKcbpqS93mje99Eur6WP3Z8LahovirwtoPi3S LGK30/xboumeKbOZba082S21m1t7qESy2jvBJI0UiOzQXEsLhQ0bOuGrs7y7treF/tKICgeS SIMkbqCrSNG6fJsdVOxkOArZHbNfm38EPEfxh+BHwo8GfDKP4D69rujfDvQINB0rX9R16LS7 yTRoLjydC0+6todJlheaw0q4sbOS8Cma9e2NxcBJ5ZlXuNS+MX7Q3jKRUj/Z11IaPBMxUxeL dNDurH7OymebSI2MeI7gLIkQyNrq5UKz/wA54vhWrHMcyqxhlzydY2vicNjPrdD2dGhUqr2F HncXTUVBxirVIq80lBN2PeU48lrdnp0229E7O3/APpfXPEepavp1/N4a83RLaziRHu5pjG0z zsgb7L5cE6SGBQ4l/wBIjK+cucZFTaToHhwaDZ6p4gjsdU1K8AlvNRvJvnkllZhh/Nn8vI2b QcITnhQc5+ar34sfHDStPmsE/Zqms4JI2wq/EPTrtrhncEZIs5niMbsMDKhww4wCTyf/AAsL 9ox7UyXv7Ol++k3DmW1iXxhpSNsd90OJksWmcDDtlkBPQ4AAr0qGRYp0ISof2dThJSnSSxmH XNTqScqc1ZLSrCSmmlrzc12mm+OTTm5act127K9l+q/A+t4bldUi+zeGtDgWErgan9gtlgeJ sxpLHLbWd6rAOzOCJgMRkh8jCwXfhGz0u2a/1e8TXriEtPBHFG3yM3lj7L5f2rYdsxVtxiZi DzENqqfnqz+N/wAbjbItp8B9Ai+woA0Vx49soJ02ZwJILvU4p9wMbfJ5e/kAjlScW9+KXx/v ZV8Qa78KNBtPs3yWNlceJNOtvOhiczoyv/bMM0iM92iCQRkMUOHJLBd8NkGcTrJPFZXRhreW Ix2HVK+lk/aSjFSfTW+9kEq9KMHdJ+rS3t99vm9H0PdtQ8LrbtpuqPa2lrcTalp8ccaRuAv+ l+UpldoYgoYxHpA+covzbjjSbw3aQS32ueRp1xcQbZL6CTgvHHG8rCHdFKjsVtAo3QQDLrls Fs/JXiD43/tC628fk/CnwvprW8ltPHKviKxvfLe0kadMwNr0byCWQiM4OED7sEKRXMyeN/2q tUeaSDwJoRTUQBIsQ01wIivk5Ut4k3ch+vByeOnH01HhfNJQX/Cpw3rbX69gNHo76V7aLpt1 OSGJpc3w2T7pd/NW+928z7fa58NRiCTRtTXRmeBblrdbiJVilKl/J8r+09iGJV8kIIkVeAI1 AAHJn4q3MD3DXdsmplYWRJpDYCSQsEZU5spfMVNzAIzsDjO0bRj4vurn9oOJvJu/DHhyyeQl 43mS1L+WW6kHxekbEbSGYKgJPCrwKLW4+PE9yrvp3hU2yj9yqWMN00t0CMRhbXxsswzGXYkj YAuDyykelguCsGr1cVjMsk/il++wvLe6bteq7q92mnqrdDN4uLb5UrJ6tO/X+tPJ+R9IyeJd Q1/VbmaCwltFd5JVW0VYHwcKAWsrS3LD5STkkck4OST1nhi4sdH1WS/uraHVljeMTGG5JeAp crM7NlWVMiJ+WZMEdQASPnCN/wBoK8iW3jj8IWYRVK20egedd4XsyzeP3cAD52Jt1O1h0GCf c/A+hfG9dNmsrTxR4FtZZViS/S78BX3nxg28cT+Yk3xStRGVYyBsRph0cfLt2rz5rgMlweGn TpY7KKNR2V/aYNuVnBf8/YuNrvq279GtdKM6tSpF07tRfvb9dtkv8mfV9lfQajHHf2Z82GSQ 7IZJvtpjERMb/vpGmMQ3Iz+Wg2Lv8zh5HrSjllS4Zkt5GLrjdEp2x4CnqqY5wU6LznuMV8jP 4U+PPheYTWXxJ8JwaPdXEUd5L/wrOOWKOS4RIJHjml+Idw+BHDDkBnQSbxlTlF77TPCPxmeK 3u7f43eHrRbyIS+fa/C3TJZImZS5EQufGF3EQxMkbeZbyEIWK7HCuv5lX4dw8ZPFyzfLnGTT ag8O5uN02oWxN5S/lS1b21tb2lOsoKMovVa3T2aV2umnX0vc7W88L6jrN/Nd63qouNJtN8kd ks11KiN5zyN5yhrSKMfZg0TbmkAXcCNoJrOTxw1pejQ/CWkJLb27osptJojayTTqLsfZzb2N 8ZMLIVkz5ZEyuoUgb65698A/GdLG8WX4/XFt50UuYYfhf4MRrrMMo2obprtl3biimMHBZepH Pn/hrQvHeiaW2lar+0L4q0IhpJJrNfAvw2gnm3s8iC0bUvBeovmRfKXcBdqJJGAUHbEnpUMq y+pQcf7TjZ7J0YN2Vnr/ALRr6vtvczckvv18j6T0PxRc6zqY0HU4rvSdU+yNPG0zDYiRFGHl K6WMpaSIygEQKPL3ncVBFUfEWmf2TPPcT2ZOn+IpJLKCKRJEi0qYoIpL6EyoYw5Z5rkmBrV8 sT5oPzjwLS/h3468S+IjqL/F/wCIj6PaW8ot9Xn0v4PWq3s0Y+yqqQSfDKzZVdLqSRdsTjEZ w7gFl7bUf2Y9B8RIiaz8V/ijfCOQ3cr/AGf4bW8aPMCZWDWfwztwV2uw/wBYwAXIwcmvJ/s/ KsBj2qme16VOahelTyWWLpq6+JVY5hTi3J7rlvG2rb2qM5uCcY3V2uvS2m1u/Xa/ZW9Z8ITX sKvoeq3kd7qCTBhcQOslv5cqNOoWRo4JiAqsrfuMBwwBIBNdnPf29gQLkGKNQVbLKvmEO6CV fMaPKMV+Vs8gDHcD4Vl/ZT+H91LJc+ItZ8d6pNYTW9nqkV/qvhq2VLC5MTxGQaN4T0tow0d3 OwaNjIfKX51O4Ht7P9ir9nCSGK8m8K6tfJLFC/2ibxhr0O/zIIyhIt7u3QZUhwVjUHd90DAD zjLeHcO4VoZtisTzON6NPI5YKT5tOb20cbWdlbWPJ713rojrpV6k48ko2XxX16WS6frsfUF1 4v8ADNuoZvEGjWvdhcarp8DR7VyTJuufl2/ebJwo5PFYl18Ufh5YxObvx94OjIUsS/inQ4yA Dg/6y/Tq3Hbnj2rxGx/Y+/ZxsJA8Xw3knAZdjP428ZhvlfeCuzxAq7iem6Nl4GUIyD3Oi/s8 fB/Ti0mn+DnsAjqwLeJPEl0AVRlUnzdWOcL8pHfO4815kIcPU480qmPd1/z6q/3bby/roaFu T4/fByzRlHjfwrcXOP3rQeJ/DEn3umzOtbiVjEf8Kc8Zx8zZLftMfCq0LsniCLUFIZfKsNT8 N3JB671A8QDK5BUEAZZgO9ehWfgPwppUKHTtN/dIWIH9o3pRd7Evjzrp5Ooz8ztyTtwMAdPY adZLGY00+GOKOIv5hvZj9wnA+a5wchmPGT8vHFaLEcO6L+yc2q2t+8jm1ekqlv8Al4qSwc1T UviVPnkoX5eZ2u37Go9U3Z6rfZ/Pz/D0v843v7VHw6hRp7bwt8RtXZQSDpOh6PfbiGBAUx+K MEuGLoMcp8w4rmx+1xZEo2lfBf4+amzkJHHF8P7WTc5JByItZvOFIGcKxAOcA8H6/gEIgkeG 1jIT0S9mAIAwCUuBnjpjr15q00gFnGIDg+aML9nuEJO5sjM7MMnjt9KcMyyei5LDZBVrX5ef +0ca8Xy2vy+x9vgP3V25Opy/Hywb+CJUKM76t9LXv/n+Wumh8lW37THjW+Wb+z/2c/jGS5hd G1fwpeaPGEw5/wBba6LqZd2H8JUhTtAY7yV3tO+KHxm8QBls/gdpunFcATeIfGfibSJITJtC TCOL4PX4bytweQNIoVkddxC7j9HLJOshaZJYwQNrFosPgAEhfJLDGRwSetNt5bh5XMRTYPvk x7mC7ucfOvIHT5Tz2PSr/tjAq/Lw3gISWsZShQkovpJweBipKLabi2uZJq6Wp306VS3/AAX5 fj5XdvvPn6ex/ai1hJJNOuvhZ4Ut9pUpJ4v1HWLkMBlpVi1D4MWoc/KQsZmVSHB3LgA8tP8A Dj9rLVJpJJPjr4M0K2YgxpYeEdC1eSNkAR1Fxc+EdJllR3Rm3NICofYE2oAfqQRh5mLbiAB8 zDaOVPXhen15oa1VmKtOBEDlcBMEnk/MSehz368e1bUuIMRy3+rZDov+ifwV+nn993p+dQo1 L7vz32sul7b7vfc+Tm+Dv7SVw4GpftU3bIMkLYfDfQ7LByMr9ostTsZShBYCM/I3yyFQyJt0 0+BPj99i678evFWrSsSC8CazpA8vPyqV07xfEAQcfOBuO0jPJr6efMCYUqIyQolcgDODtQZK gsVG71wDxiqn2ed54ZDNFjIxxHyAcHnzhj34+nrUf29mDu6bw1GOyhhMDDC0k9Lv2VKXKpP7 Ul8Ts2yvYz595Xt2emivfT9X2W54tH+z9YlIF1Pxt421KfyITI58b/EOCOVvLUhwkXjjZFzl hGibEJ2KdoBrRtf2fPhPJ5y6roeq6vJFsEj6p428d3Ks7ByzRR3fie5Vt6rtl4TcAisGB+X2 +NPnVnYYVduRjHA2jBBPHoefqetI6wiRnYEq5O8hiAMYx0Bxlc/l7VMuI815eWGJr0pOyVTD Rq06ySs24SpzjNXWklF/C5J6b9tOjZL2r/d2XNfTdK2stPitp6voeMr+z38BUePb8KvBFwWd Qk2paLZ65PE28AODqwu3dUJDrC0ojO0AhQARu23wi+D+kusdh8KPh9HKgIF7aeE9B06Y7hh/ 3VpppADAbWxMcg85wK7tjZ2jNLkquCwdpQgQhSu/fIhjUKSGLSAxrjLjbnNSTxX4a04F9Q8T aFZEEA/2h4j0G1wX5Xd5rQYJ5CjjJB6muWOa8QVpJwzPO9+lbHu2qXSstv8APujb2WAt/Ei3 dK7cdXppo9unlrpYvafpem6YoXTdHigRVVY0tLKO3jjUHeFjEC7QFbuFX5hu+8TWuv2yQZaR gmVzDLAhkILDhWZS42/xAEBsFW4JrzTUPjF8HdOlM998S/hVp8zHbLPffEjwtHK3lqpAa2bX 4NhRFDACJS6qGwd244d/+0b8BoXRl+Kngm/KgnzNJ1+11g5DdI7PSGvri4Z+qrCzFUPmkNGr EzDC5viqlT/ZszrVJylKVZ5Liq8qs2+aVSVZtutKpK8nUcm6jfNdt3LpVaUdI25U1GOzulZJ 372/rY97js+VnADKM5iS3S3lOCR8rwnfn2B5HXgVVvr9rZ0EaTou4Kwe9uB/CpIKOHXjnI/D oSK8Jf8AaR+F98pj0K88VeKbvrFb6P8ADP4o6jHKV5ZVl0vwZcISmVDhZsoWAcKcCud1L9ob xPbkDw18EfiDryliFafwZ8TNBQoFBjcyat4IWNPMkypDn90AZH+QE1a4Xzudek6mAxjg5N/7 Vgq+WwWi2qVYzjU0duTS2s72VjrjVpuztf8AJaLp1d77q/mfTFtfTSyPGhkXeoRcnKb28wIx ODwrFSSATjBweBXj/wC0tb7vgz481gAE+H7PTfEMEpd47qG78N6tpmu+dCibo1ZbezkWJ3l2 eawE0Yi3vXjsvxz/AGlNUvY47D9m26VAHaJ9V8W2EZiI8yXckLafosuPLjTzlnaQrhQDC4kE md431D9q7x/8P/F3h64+GfhvRNK8T+GPEWj3JW/0q+volu9KvrOSS03eMrZpLk8NbRG2kDSK E8qbdtPtZbkH1TNIRr4nhrDylKkvZ4vF5csQ7ypq0I1pQnKfSCSu5WS1sS60E00op3V7JPRW 68qb/Dr0SZ9NfB/VpNY+F3w51p5GlGo+BPCmoSuzK8jPe6JYTZkZPkMoaVhJhsBw4GcV6OJo 03HllUlPlwfu85HzdCOnPavm/wDZVvdSf4L+EfDviBETV/B51jwXqcESLG8M/hLxL4l8NbJ0 iadI5l/sBBKI55U84SASyAhj9G5J2x7BgRKVIJ5U5UE5J5wOmR9B38XPsOsDnWZU1p+8asvd 2t0Wltd9fnqdlFqpBPy9E9Vp0bffTr00t4Z+1Hq/ijRv2e/i9r/grULrRPFPh7wLrniXRdVt YFmuba68Nwf22Yo4mhnjzeQ2EtmS8M8aLcNJJBOitE/4y+C7v9pH48eMtMt9Q+LnxI8Ijxr8 DdP8W+GdPsL3xHYWr+KvBD/Bbw34o1VbbQ7vw3FqL6tH4h8TapHbQ211aWi6xcXEltFPBBcx /wBAmrwW97pl3YXKedDdWtxHLbgyBp4ih3wgwlZh5qgx5hdZfmPlsH2keO2PhzTYdat7lbVd PudEt9TttKvZLifyrSx1Ke0N3ZTR3VyYN8otrFUe9ZroG1YRENJcA/0F4BZxRw+HzzK5qMpV cNLGL3ktJRp0vhs+sVZ37bHzPEGDqVHHEQb5YQVN2T6TlK+j00l26WPEP2aP2gLL4kfCD4Mr 4ivQfHeu/Dzwjea1HfXmkrqM+sQeGPBw8SahPbwm1ujAus+JbZZp/sEOyeZknt7SR4IZPrWO 4ha9g2vvVigDRMrKMMwLMyuMKc7QeeUccbefLh4O8NabPY6hpFpNZzqLu0sooRqt8yLK+mzf ZCZ5rldlw9tZrLNPH5kBtIiJoRcTLOtpLqMdvaSoskSZlWaBoAUgKSswKzOgLmVZFd13P5fy /dDAV/ROGqqeYSnDang4W7K9bCx9PtbJaLqeHL+DBPV2X4af15aaH0C88QgjRSjOEQ/eUnIy DkZY8DivUfheSTrpOMH+zNvOTj/iYdePp3NfMOk3iwhbmVjIxVgVxtHIUfwRk4BBx+p9fpP4 R3a3Y18gAbP7Kzgk/e/tLHUDH3a/Vcuqc8MLr9nvv+5fTyseJj4WpVZduW3pzwS/P8+p7JRR RXtHhn88/wC3F8Qbr4jfGb4g3nhjXvB2gzfDrwBrvwn8R+HvGnhJ/EF148sJvFXjqU6X4UN9 4U8daPoF5ePoN3Y3fii31b4a68ZNS0jZrkdrZm50T2v9onV/gN4N+On7D3gmfwxpHhbW/D/j U6vLb3Wk61q+o+EtKh+JPh3xN4dW21yK48Ql113XIfEMq2+n6lqro128GrDS7KSER/rjqfgD wXrmsWfiPVvCHhbU/EOm+S1jrl/4b0jUdcsbe0umv7a1s9SurR76wlivpZLyE21wjw3ga4jb zvnGzceH9BuNQGq3WhaTc6pGYXN+9jay32+Hi2Iumg893tQEeJmcNaqVeHBwa4oYeo0r1NXp vdXdu2m6/Dc6ZVKVklF6LTyendLbW2n4H5If8FA/HHgT4teD/EHw2+HPxH1DUfiLNJ4OZvhK fCunaf4e8WWltcW/iWS+1PxPr3w+ivvMstHuLPWIdP8A+FjaRpv2nw/p6ppU2opJb6j2f7Nn h6/0b48/taQeKvDlvp3jm0m+HVkiWz6fcaVbeEbXR/EMXhXS9BubfULy6tLS38KQ+Ebe9srm 4hje4tLdWWU2CtB+oaaPo66k2sf2Tpa6iYFgbUTYWn9obAkcawtqBh+1MiwhY/KaXaEUIF2q K5DxoIA9sRCkr755pRHhZl8lIQqu6DzcEOQu5gECqFUgDb+O+O8fqnhVxhWlVlCVTD5VQg4z a1nn2WJ2tqrqUk/JK6selktRPHU6ajur3au046t3utXbdWtfzs/OkWLdlAjBsAuVJZsZAyWA Y4J2jcOAABxUTpGHJ2rksSx2jJXBABIGSAQuB7D0qQFioLSJKx5LoiRqcHskQCLgAKdo5Iye Sar3CMxDCTYOBjHoDznI6+n61/mIo1HTeHXvt+znFTaau4x5X70rJ2ktbqyejP02Cbcbzcbx Sb956rltokn07LZaI+XPgbbiT4qftAa45LHVPEWkWkkhYl5F0e78TaYqSAjcViS38qIMzKI1 AQKmFr6dnnghhnnuGREhSOeSfY7SxWxdjuAjVhvISTescbE9AMba+fvgNpjLbeONZ84O2ueN vGjAbCCkem/EDxtaKTKHImV0dGGFQRABMuCGr4T/AOCm3jjxZD4i/Z0+BHh7xDrHhnw98efE 0fhzxZLptzJZRXmmah46+G2mNZ332R7bUJI1s76+twLPU7KRkv5o1dN5Zv0evgJZrxxlmQYO rKKxtbAYV1rKP1ajFxVSMIygou1Jvkiqc7WS5ZfCa4nlg3KLfkrW2Sad97/nb7/0j0L4s/Dn xnrJ8P8AhjxHNe6mEkcWkul6zaSbYIEupXE91pkFmVWGVCN8xlOSig7QB2yCcGWQFgQ7RRSC RmLTxs8YDRyM0Ual42y0UcZ4yGAPP52eLf8AgnX+znouq+GNe+D1r4f/AGc/F2l3krC50O+8 Q3eq6jZXOk+I7C+sWt7vxlozXZv4r6C7e6uIriaO10aOCPMFvC1v+h0UcsUMUdxMZrg26L9p jzEplEaATTbCu+dywkMT7wXEwMjbSz+XnGU5XgauWPJs4xmd4eeCqf77SqUXCKdRxf73A4Dn as5J8s7baXSIwuIc4SjZNNLVr3re7fXTfrdNLtrp83fBp11H4kfHDUFVVubDU9K0dZUQROlx p2t/EGQlWALZR70MkoYAk5AG0k/Sby3YtC0QVvJZlHIXbO4IUKNygZSZd7DGUZ4yxUsh+Vf2 aWW51n9oPUGb5rn4weIEQltxSOC9vrgRh8gOqC7OMAY3FiAGFfBv7T3x2+KVh+2Nc/Cjw98d vFvwq8K2Xw58LatDY6L4W8M+I9Pu/EGo6rbwmaUavrnh+eKW8ttSWGZxc3TQx2SGG1m839x7 DyXFZ9xDmWFwdSPPhsuyvFt1H7OKUcpy+Lik5UtZTnrZvm1et7jr4mnhcPTrVIpqeIhT1i3q 4SlfRN2XI1d6I/Yqa8kS0mW6JlkCK00Zy8IzcRFFRGYIoAZTJtA3yIHZnYBjhatrM00Urm7/ ANGmSRIyVkUrayLIZklRExKGjaDesyzeZsw28Ag/n3+zr8TviTrvxd+IPgPxV431r4g6J4a8 HeDrqzvpdN0+wfUNR1rSdG1abUprHTTcixmZpbtZLdNW1CJpHdldQgC/POt/tRfGCbxb8QPA GgeKZV1bXfjJffD3wRqMw0aW18G2a6nr2ircPb/2DfSXktjc6n4bnfTJEcvHp2yW/RpVE/p4 HgTPMTN028KlGll1RPmjfmxdOrOpq8S3ePIvNX1ve5nVzHL5005RSdrv3Gtfd6uP5X0sfrZd apb7bhIvPkhiVVhEsVuWa7PlyRoScEJmQNyUQMMk55PGXmsus0m0yW7oheVo0jRoyHgjdd0b MWV5JR8oLjGD8oFfk54p+J3xh+Elv8QW1b9pbw38Tho/gHWNYOk2x8LaP4u0fVobe3vrS+Tw 7bW+qlre2tbaFheXGpW37rVhKbUpDCbuTRP2q9R8daF8FfD/AIR8VtH8QPEsH2zxbdXS+GZ2 1CODwTq+tPDcW9v/AGlckw3EUDhhptpue3WVwgG0etg+Cc5hb6k6uKw6b5qkK1GEY6xv7lap CTskvhWzVtzznmtFr3Yxt3UJK1rd0r6b9Pvdv0uubqWY20ryrIj2W4AoVaO6k2NEoCoi9BIJ GJdWIj3O4VdtRzNcT7rpmdiu07mLBl2twck5GOMHjrxX54fCtv2mfEHxZ8SeHdW+OVvqmgeD LzQtR1qym8GeHreTVLSbxLrljqNlA1rpfn2Et1ZaHLEs63ivE1wDEY3hMrfoRJvjRVd/MljB O8/KW3NkDHOMDjvmujMMHPK5UaTxEpVJQcpxjOV6TUrct4+7drX3W09L2M3iY4hN8qaWmqfk 9L/1fX1ne4mhUxRvIqcDarFRgYCgBWUYUKoAxgBQBwBWXJf3du7Kssg3kgnexOeoJIYc/Mee cVpAkQrI6pyFIYscnI6HKY655yc49zirLGjogLKWLA5GCRwfQjPUenT3rzamJrShL99Vemic 5t207ytpror9/IhRTlHRb7WVne25LBPNGhuGYs6ksGY72XbwMFjkEHng+hrwr42315d/8IjZ oxAuPEkcr4IQuF8LeLZMO27JG6NWwwIyqnOQMe5tDIq7S2UOckg5A4zwcj/x4fhXzT8evEWm eFL3wXfatfW8MCa9HtT7TbRyFZ/DHjOKLK3U1ui8gkgOwyuFLHJHqZNKrVx9eLrVeSMMS4w9 pLljL2UGnGN7K17qyWt9dTDFKKTSirdElbfv0tpby30six+1N8V/EHwh+FM3iDwtqsel61f6 uNAW9ubFdRhtBc+G/Et7/aBglhnRjZXem20zZgu/MUupsLwMUT5R1b9pr4jW/g+z8RWXxoi8 R6VqevadoOo+IpPDMUF34eki1Lwyly0Fo/gLRGkWaDxJG6umk60Mq4EURj2S+p/HPx58I/i9 4V0Lw7J4ys9J/sjxtpvjC6mN5oV2bm00my1yyutNngg8V2DCOcayhd5pZLfFvtmgYupSt8QP G/wP8Yar4ImtNR0rRbfQPEKeIbmzjj8NNpGsR2+qaBq01rcW0HiS1sTKYdDaCCeeyuz5l1bs FiECZ+o4dxNLBzoPFZRSxlF4jG/W8TVqRc6mH+rYhYRtOupXhmTowXuN8qu4pXqLyMTCp7OM oWSd9tHe8Uuq6+vTQ858K/tP/FvWLnXtJ8PeMdE8cxX17oHhjwL4yvNAFilj4y8S694M0m2i 1eC50jwxdvpelJrmpX0kx8MXoDm3Cf2mIhZH0DxR8Yfj/wDA+ewv/iT4v0fxXY+KtK1jT7R9 P0+0kfQfF1u2kzK9sLLSvCcq6NE1xqsVu0/9r3KWtnp6mNZjM9z534m0z4R3viPxnJ4J8f6X 4B8MazpGnah4b8Lada6BFYeFPiHoc/hu90vxvpZtvGVrHNeRy+HIFfTYbeytb03N1HefaEmv FvcPT10fxFb6zH8Y/jA/xNNh4av9D8HiXQPDmiW3hm9vLeC3HiSFdK8X20er6hJBpWnTub+J rhZvtPl6i7Xd5c3nrUpZbVxdOvWymhRk6bVZwqQtaTjKn7vtqjvKKblZPbWz3419YdNKUXZN arrp3Te/6Lsa9t+2l8Qv+FA6Dfz39k/xh1W/8P6ZLcQaKsWlwvYN8P5/F8iRLdw6YqvZ6x4i /s+byprkyCHb5bRWZP6g2+o6xdQKCwYzOytsYRIrorFNqrIgUL5cb/Kv+s+f72SPyebwh8D2 m1O6t9fjha60Pw/plkiWGluNL1KxvNZk1nXIov8AhOBFcXfiC01KxsrxWSGWKPR7Z2urndGl v9sv+1B8LolWG3k1CGPzhN5ENzoLD/VlCu/+31fLECQnHH3cEc15XFNHLMSqcMnwdq7j7yhV 5EpN6bzprtfX52OvCNp2lFN3+0lK97dHfo/M9q1nXr3TbaQpc3KSQyGJwsshUyyTKZDjzQG+ ZZCG9z/eNc3osUt7exQmaR/Jt2upnMjBzJPNbKrFyMux8iUk8kHkklhXhuu/tJfDy+lgtYLb XZN80lxKwi0SRdscRCcrrrGQMZgwdtv3QfmLcT6J+0h8PrRrq4TSfFs32plJaw07RbkwpGWk VJSfEMYUfvyYzn5ir8DFeRRyvNqOCaqUa3NJJpyxFB2vyNWbqN2S072Wvd6cyu7xju7JRV90 rdfu8t9T6m1C0k1Gyu9PV5ENxbPbERSCJnSdgrKX5UhvNIIfKHA3AgV+WP8AwUX+Lv7RvwL8 GfCGz+BB07Vb3WviBqujal4d1waXcDWtHsfB2vao9pAb/UdC0oSabqkNvqYbUNStFaDTz9na 5vfIguPpu6/a08Ct4gkuhofjmOzSwdGs20/Row7CBm3q6+IOHJIKgDO5QQwPTyz4ifFn4Y/F nUPAWua54J+J9zH8PNc13WrCKLwzaana3v8Aamg6t4Pha0MPjDTreye2sdUzdXqwXMlzN5kM 2+a6kvK9jg+hiMuzahjM1w1XEYKjKVaWHqVaNSnUmocsW480r8vO7LRuy7NHn5gpyot00lZa 2su22qt119D5x0n9vzxx8QbL4pfEDwx4vu38Ht4H8IJ8JUh0d9NuNN8f+L4filreivqVrcPH P5Vppei+GheT3U13bJJiMSXri4aHs/2jf2ufj58N/wBpX4VeBtA+IKw+DfhRovgzxH+0dpk+ nR3N14sh+J/jbxNZ6EdIuGsUN+un+FvD9pDJDbzaC9rcRS5OoPKCfN/Df7Pv7OHgvxn4g8Ze CPhJ8WfDVr4v+KGk/F/xbofhzwLq1tZ6x4207Vde1X7bqkVt8UIbGG+u49fvrO7jjsBaTRJE tzYXUNpZw2vuEXg34APovxHbx7+z58QviN4o8c+f/anjHxb8ORP4muLF/Cum+FtO0/SdV1Hx bq+rxWnh+GwkvbVdK1PTIrO9vby4toba/mutQufpK+M4LnisO6WEq1Yywcqaw0vZxpU5YhKL mm8PGD5HGLu6kknvpdHkfV8VyU5uUuVTjpzLRKSb3et7bWufp7oHj2D4o+GfCa6Hc7bfxh4Y 8PeIvPMN3aakltfaNa64iN9pa4sYeTbIUWOeZYz5ImOGYe1W7roMF7H5aW0FkkvnI0cczKtv 5z+WfL8xHkCCTeyEh3BIkbdub8x/gF8a9N+FHgGx+H/hv4JfHy/0/QW1Oy8ORJ4NvbxNM8Pt qgutL061TUNd1a5az0nTmi0q1Vp5Ikt4o3iaJQsK+keJP2ntW1u9s9Gs/gT8d/JFwtxeWo8F zRhoZ1gBjlitpHeHK3ciFOI13sqnAWvxvMeH8xq4/H0YYeccnxGJr+ytj8Eoxp0msXRTisQr K6hFJ01/LpZ29ijVtRVNpXsl8LbvaN9fO17rr6n1v4fa/wDF07+INS2LaxTRwWtlFtgtXS3j zK8tlGZInZ53wWkbc4iQ7QFUn05I4mgQNFG0MIEccDIphQJ8o2REGNcZOMAdSepOfkPTP2mN ZthCLb9m/wCNRhikKGJvCt7AjoxL7RsspgAryyuxwTlueMbdO7/ak163invm/Zz+MENtGyoY 20K+Rd7Mics2lhQdzd+TjGATx5c8g4jrzU8NCMMPy04Uo/2xlNO0KcKdNJU6mNhKPwXScVdW cfdaTUKns4+9FNXbu1e6ck16/wBLqena5oemarr0OjaXbraut6s2rzWwFlK6SPbLJGJ41V5I wbubbGqso2IR9xc+N+Lkuf7cubIXVzJYQeakFvNcSyqqLd3aKsayFlQBIYBgbANi4wVGK/hT 46+NpLGS/i/Z3+Jsl5fut1LdzaZrEcro813J5LFfDkwI/eRruUjAgUhedq+R+P8A4q/EG11x L+T4JeLtIWeMzQQXiazBJDvvbhhKon8JKJEHnJGGICloW6EkV9PkWVZ9QxMIYuFFwcJRblmu U1ve0t7lPGVJOz6qLUW220tTycWpzftLWinZ20WtrK3U9p0/TLC2SOSa1a91GR2S3gd91uWJ IBnVpYInVI0kfa7uNwT5GICjauzrllbidmsNOtlQmGOzt7eOaNFQvtZ4reQkqq7h++f58HcT 0+dJPiz8S5rMyQfDHU9PTcouL+fUdWhLxeaFeIsPBRWEPmNAyTAnbjjewrCvfiN8QZh/ofgN 2uJMiaWTxFrM2SygBjG3gydQNxJIAUEDHI4H1s+HM0deE4wpqLSaSxuAS8/+X679UnsckZuP RP1V+36I9Wnv76/uEa4uXulbPlFyNyxsWYBchdoOQcDGOeldTpWlXTx2qweRbmS8SMOcbssw DeWwjlaOQrkCQbSFDLvAbDfOUeq/F+ZS8Xh7TraJIVZ5JNa1ZCpZXOCo8B7UIAAI8wbS2AOB u9J8PaD8d1sRr0Wm6DIkJnkgE3iLxBhZrVhJuXd8OpoQxELxg7WIDkkHBUmZ4KphMPKKxuCh Pkd4uTlKL5bNXjU5W09HZtaXRVKnKck4xVuZN7Jb7fnb7j6/8M+CNNswupT77jUJbSIubieS 5hDSBfMMcUkRRCVwAQBjGBUniXSNX025h1bQ5UtpElb+0bZJFS3uLNJGuWeWAxiOaXcjxljJ 5hRmQfKxavGNH1f9o7U9Lga3t/DMLBRBIB4g1OQwLC8saklfheCd/wBm24cR4L/eYr811NL/ AGn7lZEh1fwXZLOCszNPJcGWFgQ0B834YLhSHJ3BgTg8c5H5dPLq1bGSrVsywMIQbspuUoy5 1Z6SqS1uvLdaH0FGaVNJRjFxSTtGzeiett/TXqfSdimna/pm+SES6fKZEeOXzQiSLIYxIkLO 4SRGYMkiqWVssvNcfZyaj4f8Uy6LMY5dEuVnl0VHZrh1ZII7vyizMkkMaQXc+2MhUxFFGCfL jDfNFvoP7TujeIrPQYfG3hKwtNVbfFEsEUsAnlt5VEZ+0eAEcl2sjKRGSQTlY2O41n+MfA37 VOr3cGl2/wAaPDUF7azT3MZsfDel3s2mokccRt0VfCttO4khufKZ5fJISNvkboOjD8LSdSrV nm2AnRxFOpSinJuP72LinBOb5Ze8uVpaO1raCdWS8ktdbvbX+tD7nvRL5cxn28bjHuLS7F2y EBN5kKdOi4HA9K5TVrLwyofUda021uWVQ8Ev2SOaUrFsUjbIuxcSbQAFQEDccn5j8x6N8P8A 9q3XdPiubf8AaOs9P3QotxGvw58O6j5UnkRSFWaWwgyV85l+dYy3lkso3EJpN8F/2oJIpp9Q /af+0wrkuYvg/wCFRhVRdwRknhAP3f4kwR17nwp5XLB4+OEjjsI6blGLk5z1TUXe6qJbu2z0 87HRTnzx0inounXTTbfRW6b2SPZrrxQ9raY0LTDHp0RTAkttOihWMnbmOKK7jlEhkaIAlANh bdz06HwJqXiW+tbq61me3WG4hBsI982GDTXACypbtIMCNYlw7EYLDJJOPg7V/hp8edV1260e /wDj94sv9OtJXxHYeArWwgkngQhZduma5biOMCVsIHdC/l5QnayetaJ8AfjTei3Op/tDeMId Ot0iNraWdrrlu0KBlDIUt/E9gFxEhG3zHAc9jlz9LjcmyWlg6UcRxBluHxDSnKnPBZhXlGMu Sz9tQpVKbT191Tbjs7N3eDdSNRxS00aXS+j2vb87vrc+mvEVpJFr1t9nlV7LW7VrW4WV5Ss9 3BHNBbPOhRSxjkuLULI6uUWNSuBGBXR+GZAdPmsb+VmfTb65spliLNGvlFJbRVLgsQllNaqN gVFACbQysK+etQ+AE8WjzvqXxO+I+uSWUD3UbN4z+Itk0UgmaQBWt/iDMyE+TC27r+7HykE5 y/D/AMHPAv8AaljFrP8AwnmpPqOntd3c1x8WPisiXFzGHt1mkhbxqYzIEslQEHgKp+8DnzFl uR1MK41eIKGLSkmqeDweYU8Ro1qquKws6SinrKLXM1ta2rhKoqq0aVtFrbZedtrXe3c+wo0t j5e1lMUjKoH77zgrNj93kCNZMZ2FiFDYyQM1Vm1S0ti4muDBBHnerQEuwUkctbwuWPAB+bJO cZBJrxlf2d/grK7Rz+Dbm42zBd1/4w8aair5Zhuljv8AxDOkykD95HLvSZSUk3JwdUfs1fAh WDQfC3wesiqW8660tNRyQCcmO9eZCDg5UkqxbcQSAT89Vw3D1Oo4vH5jo9rdmrXX1C3Xp1PR pzm/srputm7aa97rfQ6q/wDH3g2xL/adWe3t8LujTT9QfYGXtssZG+YgscO33j0+6OWuPj98 JdHaSG98TTQQqroXGga1cMzABtnGkTdUZzu2KPlADjo1i1+C3watAPL+Fnw6lcBtjjwX4bVl JPUMLCQkr0HPfHGK2bP4Y/DK2dmi+HngazJTYrw+F9DtmwWBEe6KwjLLkA7NxBKglcgY6Y/6 sRhFOjxBOSjFe0p5hlcITa5bzhTngVUhGVrxjU9+KajL3rlRqVOaSs9HbZ+SXVeWn4dTyu4/ a+/Z7sVeKLxlqaSfMCG8NeJzEzqdvKJpO0jIPVPTAAHGU37anwEZCLXxLrGoSA5jhtvC+rwl mHobyysowR6tIoyRgnnH0ND4U8Lw4hg8OeG4A2ABHo2mQ9BtHKWgb5QMccgfU1txW+m2Keat jYLIM48pYUcEnghhErdvSsK+J4coSpulhc1alzczxmKwde9uS3J9VwtLltrzKpzc148lrSv1 J4iVvZRV1bmva/S27S77eW1z5Xj/AGw/hxqMoi03TPF+pOoYosel6XDlMZLA33iCzTBCk4Yh vl4UE4PUad+0C9+H/sX4Q/E/UiQA0kVx8J7e3DMBs8wX3xWsbjymLBj5SGQIcAK4IH0dDdGU B4lPyrhUDZCq55xgH+6P4fxHeoJ5i8jCBsAN53loHlKA5by/3aneRnYQ8Z3Yw6nkRVzDJZxX JhK7dla7Ti3dWU0qcW10dmtH0Kj9dbSduVtJ6rb3b/a7fp3Z85XvxJ+O2oyBfCnwSu445AEz r+p/D8MJRjJJ0/4uSsI9ofpls7cD71c++sftpajdz2mj+Afg3pgQRSLB4pvdUkmhR41d1mk8 PeM9RhZ3cs8QillRYmiEhSQOq/YlrbtPCWbeI8kYvS8bADrwxlG0nvuHbio7keVEIIHOQxyA 7XFsQW3/ACQSFoVIJOWWJSXySd2TUwzvCU7U45PgWndcyoYhvp19vb9LnWqW3vPp9rb4bevT bTuz4xl079u29QwXuo/sy6Kqyh1EcXxCmUkB02K39nau4kUMwUsRGQmWckjfatfA/wC19dAN qXxL8AWjA4A8K2lu0QXn5l/4SbwBdSCUnbuyfKIL4GdmPqxbGVSCIpJnZhuW1SSMhDyztFAF TAOAWI+XIUMAcVdjAzJGqhHTBxdxIobcpYDLiVscHJ2nkjitFn1Wl+6w2VZbGj8XNKlU505W 5l72K5ml0vDtZu4Kj/flpp8T626+en9NnzfbfDP4ytEh8QfGnxfHOygzJpR8B20CykBtsIh+ GsTCINv2hiWKhA5JFXpfg/rjQrLf/Gr4ryg/fUeJtPsxkgk+WNJ8IWeQVUg+aTsOPK2FnJ97 aMAsLreWYlkdYV8tVJyiRkvEDGq5VGCqCuCFHQVZYTbbPMuTdxTgkRRIrFAu3Hm4f5crIVHJ z83pW8c/r8rVKNCGI05IUMOqdTpzqFSup0l7t78zd4pqPvOJXsrpJzk1va76W26W+X3niS/A +1ltvOvfiL8XtQt/nBD/ABN8SW8ToCA0cqWMlhJ5bMQshjCylM7HDcmN/gB8M72JV1F/GurS 8bzffEbx/cq5XOCfO8QpkpklSRkE8V7zaLHKwRpAItw2wuQFyck8bsNuYA4IIJGO5q8sFvC8 h2LOCT+7iQKVyR0KNkhcc8Drz05zedZ1O3LPGLb4amWxvt/0716W+TsdFKhHv27b3S3a0fy/ M+fY/wBmP4HShWu/hfo+qLnIl1i4vtYkcg4ZpP7U1W63nHyEup3RgRnMfynrrP4JfBLT0CWP wi+HEEyFDGW8B+EnwUAUkzNpck4+RSMrICx+/nLE+nR/2WjFm8iIhm+SeVUuAd5JDh5CwyRl MucoVICjCi9/amlwKfOaCJAMGSW+CQDPyrvMjhAd2AgIOXKqCCQayqZnnNdqH1LF3Vk6yqOM qnw/vHKnVjBufLzNxjGLu+VJOx2UnGLStHSy2WqVtXprouj6dtDG0Xwj4W0p0bTfCnhjRVQu RJpGgaTp0iliC5V7K0jdS5A3FSN21c9BXSzRgW5EUhVRI6gIWQ7AZQoJCrnAAHXrXEy+PfBO nTyDV/FHh/ToY03s+qa5pWn2wyqsoaae9UJu+bDY5w2AcGuY1f8AaD+B+jwMsvxN+GZcSSoY 4viF4VMysgkZl8uTVEJYE7QpIO7AIGeOqFLO6ijyU8ctdVLFeUbJe0rbf4dWk7nRKSUUko7u 9krNJLfzPWTDChV40KyFWBcnLAMu07WyWG4MwfGAwODkZFaUZhihiVwWgEgzGyhk2sx3jYRj kFwRjkMRzk5+SdV/bG+FtgGi04654meVGEA8LnwzrJZ4m+VQIfEYJa4Vg1uFDGVFZgABzyif tkXlxsi0j9n39oHXFd1UOngfZbMCwEivPZz6iUWPIEjKjFcnIGACquS5pVcatTD1HKLT9pKt h5SVmnzKTm5K1r3TvfZalwtKLTS+G+y3sv8AgHU/AbVxafFb9ozwGJJBD4b8br4isrfDNFDD 4+13xp4un8qTd5YDPrcJMKxxGDPk5l8oufqwHmTlgDIypySQmflUcnCjnC8Aegr86vgT431r xB+1H8VtT1b4e+KPh8njDwjYX9rZ+KbS8024um0eHwrCFZbzT7Pzp7OCfOLfzfLivQZGUOpf 9DVzKmNjIbd2hEjFv34jC4mUcALJ94AFh/tGvS4jwMMNmXDeKk3NV8mw1So5vmVSVKhRTlPr OTdROTldyevrvg/4dvx3W6799tvXQsv+7BeUoY0VmZ3DMyIFJchlHmAKMsRHliOFDHAr8XvH Hxv/AGh4f2q/2mPgpd3llqnw7j0zwl4k8CRaLcNoXizQ9Kjt/BerXbWHiHT9W8NXUBvrrxXp 6X8WoXV1cT2PmW0ZQC6Fx+0aumEZ8BVddwLYBBderZGAOp9BX52ftYfBy21P4leDvihoGtTe DPFjReKdI1XVtMivWbxLoF3pfhO0h0rVBFq2nWN5HaP4e0C+tJbuyvpbaTTVS1kg824mn+x8 BsRhsJxeqOKl/v2XVMHGDu03VmlGys1dSas31s7Hk5/Cq8DU9ldLrZW1SXmvw+bPkrQP27Pj x8RdG+HWnfAjwz4Im1JPg/4c8f8AiW9+KGlXj3Ml3fWmnwRWumz2PjO9jub2S4JmvJdVilFx J5TzavOoda831T/gor+0n8RNR+G+gfBjwT8NtIn8d6N40dj4z0K5SG01zwgdX1K5WWSx8e6w 8Nne6NYWMULQR3ryXUrrI9ioEsPb3n7JXh7RtPtbLwl4h1nwP4hs9Qvry38V6FL4m02X+xr2 Cwim0AQ2Xi+xU6dHfaTpupQAzPBbNbhLa1gEkzS9Z4Z/Zf8Ahd4Tl8AT6dolguq/Di58S6p4 YvWu9auNt74nGzUPPa81e5+2rPFa29ps1SPVYrWNd1nBEWaN/wC3pTyNYirOhb2/s6MIK1ot 040ac7pUkre65b/Ek7HwMY4xwSi7yd0ru/VN7y10v17M8T1H9vz9p+x0Tw9qd6/wm8JaFp11 r3g/4geIm8LarqUMPxL8J+J/GHhfWbTS7Rb7xNqreHruXQbNrCa30ZleRxcSmzWS4WP+gX9j bxnrXjnwpqmuatPpN3He6T4P1GzvNLs7ixFyNRh1yeaSaC4jhdB8sQij8iIxjzAVwQa/GnWP gN4M8U6V4j0Ldrfh46p4h1PxffXek+IvF+nWkmr3+tmTU0j0nSvE+j2UyXV7c3F0iA29sYxF epYwSwwxQ/rZ+wl4X0XwV4Y8SeE/DOmNo/hvw9o/gLStE08LOIraytLXxFGscL3M9zM65Bci S4mZN4UyMMGvr8pq0qipqO6Ta0dlenrbRW0vfXyODEwxsaVV1bez93m2/nha3vN78t91vr1P vWiiivfPKPwf+GX7PPgGw8U/tdeK4/HXxQ1W0+A9vqX9h21/4r0ya0XWfDeo/EvUtSOpTt4X CGeePwt4fjvI9KisriOJXd55hLYrZZ/7Nnx8+Nn7Ovwn+GPwx8S+GfBupaBqvwm/aK+IdtcX 0GoDxFoT+BIPjD4viXWb6y8X6tZavY6/q2gQ2AeHSNCmstIhuLbzL6aNL2H9YNE/Zo+EmjaF 8Y9CstL1FdN+NmteLNb+Inma1qck91qni2zvbPWm0yQyf8S23MGpX32aO3U+S8qsC/lxhX+J P2XPgn4ruUuPEXhA6lLB4L1/4fRF/Efiy08rwx4vtvFFhrenounaxaKzanB4x123kvZfMvrN LmOSwuLSa2t5U8ijh8ZGKvU2Wi76r+7fX8u256Uq2GV17O60aurNaRWlp91fppptqfnn4X/a u+K9rZ/DeXxfZ+GPgP8ABDxt4W1v4iW/xmuPBnjnxB4Y1X4g+KPGfji9h8C/btA8VaDpnh+P U9FNz4ihTxBdyXl5d6ZHcl5ZPEWkRR/pv4rvg00kcskNw8KkSocrGjyW8TiZIHkla0EgDOkc rySBWIMjFGZvFLb9hD9mu08VaF4qh8G6rDfeGvDek+GNJ06Pxf4nfTLTT9D0CPwrplyBPqkl /cXcHh+KLSt91qM0U0Y+13FrJqRa9Pqvip1fWLpYvlnaW4a6Dg4wghWIKRuXhHIO089SSea/ nf6T+YYjA+Gv1CTTlnOeZXg5ScrShSo4zDYzmikoqUnKhZp6Wb1bR7PD0KNfM3ywtGGHbe9r 86bbd3b3dOZNe80rLc5ZHl27WMsgU482VZEc55+bzORjIUZx8oB6EVYVGbafvBuBkjGcE8En BIAP4ZNRO7pbL5hVt28syg84YAYHy4xwDx24zXJ69rH9n2FzMssMSwCGQyXEU8kaGS4ihyVt 1eVi3mhQAjKN244xkfwDDDyxOJxeGhzKUK6y+m6a9+UYONOFRKTt7SSpJ8vw3k1eyTP0OEXV UZr3G58qstNNE2rpX0u0rdlpY89/Z6kLfCPw5qMkYV9UTxLqgZuBKNX8U63qkciOw3SpIlys kcpLGSN1kJO/J8v/AGsP2U/Dv7Vngb+x9U8RX3gPxV4ehFz4J8V2Fjpuq6lpWtW+s6F4htbu CS4fTby0I1Dw5p0RkstX0mXbPLIl7HJEjx+b/BP9r/8AZ48OfBv4Y+HNe+IjWWq2ngnw3Y6r Da+EvG1wIL2TS4DciOdfDE8DqJJZGVomkTkBQyjFeoz/ALZ/7NMpjVfiC3TH7zwj48AyCD/B 4cJxxjjmv0PM3meE4glmeDwtaOOwubxxmGxUIU3Og8BilUhSjTk/YzpzioQl7SEnyw1T5pXq pGnO8KkpRTa96KUnpy9JNK/fdq7s01c+Tvhj/wAE6/Elz8V9E+MXx6+O/iT4rat4a0rUtJ0b wxe6MsWmobmxv9Otb6a58T+OPiPIJrS117XmRrdbQE3McSPAPtSX/wCn12ZrNpTby70Aggb7 1rbpaRwFbmQK8gUvGyRhVD/MDIyxupynzan7Yv7O4JW28fq3+54T8dbAeMg+f4dWTdtweMpg jBzuAypv2tfgj5kcsHjSGd/NVkj/AOEY8aK8rZ3JGhfRIYwzkBQZJI0BI3Oi5YY1aub55ief G04KGCjGhhsPHD4fDcsKsuVuf1WjSba520pSneyV7XHSoUKELRnKUWtLpX1cXrZ+VvdbW976 NYf7KF4y+FPiVqc2Q2r/ABX8S3duW3gXUN3p+iOssDtlp4iLkukillYENn5iTv6d8MtNsvi5 4w+McOvXM+peK9Ft9DudFntEksbK1t7DwzYM9ncrIk+8r4diugjh4xc3NxhWbYK+Y/2dfj58 LNA+Gem6dfeMXt7/AMyGVyNB1+aN7q+8O6FYLIGi0J1Cm6tySoRVVcNsKnbXrEf7Qnw1vYvO i8SidpgT539h+II1fY3lk7G0yMqFEez/AFaklSRnO4+9Uw2bUM4x+YYV+wq1KWAwU+WFOSVG lgMHT2nTlH3/AKvCTla6baTs3eJvDzhGjUiqkVOM7N2Sdmr6Nd++77nlfiL9mbxFp3xW+IHx U8JfGnV9Ak+It3ps1/oY0TUJI7ZdN06O0ht4LzT/ABjokjRRv5sw+1WbKRsSJVI82Tz+/wD2 L9O1Gz8QTQ/EXWbXxLP8WfEHxd0bXrHQorK4tdd1GKFreyIfUzfSWi39vb3q3EOq2N1vhGZo 5vLuY/oW4+NPgKXEh8RQsocjb/Y+vgjKsAf+QYOgXH3j16HqIk+MfgaR8p4hhAHrpGv5xnI/ 5hh5x1x+Fe1hMZn9OzWI960V/Bw+1PSC/ga8t2l5PU48VhcJUiuWHLotm31jfeV9bWf9M+Y9 c/YxvvFd9qfinxj8Sb698RTeH38O28Oj+GTplnaWjXCyCaIan4n8RTy3D2099C7wX8UR+17T GBDcw3PuFv8AByGPTfgxpqamyJ8KbWez3XGnwXE+rpN4OvfDQur2ZLqCOGQGZbnyoo53WSby WIEUsh6+f4p+FJJljfWoAjFA2NM1nPr1Fie3pTn+Ivgtwkdvr0QY7jLu03W8AgjbgnTD6tnG a2xOYZ1iatCNWToqpTlOUsPJ0VGUYzklyUoU4NPlSfNHZu5z/VsHTqqnBOavdylo9l2du2+q 76GN4J+Ey+CPGXjvxbba5Pq8njmbS7iayXTxpdtplvbar4o1ORUle8ujdsja6sJgKwSmONGW I7nCexuiOJRtYkKoVtpPqeuzt9RiuEHxF8IkwxrrsJ2OokA07WgWAKqQpbTgMnBAyVGSOQM4 tSfEXwnCp8rU8hgethqR6eubUHueleQ45pmHJOt++5FOKfJCLjFSdleEIubdk253kr6O1kEq VObfspUqSjZNSck22lrpGWn9anWJZTOC/wB6L5QqkqM4VFOQz54bd/AOR+NVllbzcCHgKUOF JxkpycLwPlzngd89K5VfiRoMiFU1WJQSSAdP1HoG4/5dG7Yp0Hj3w6mS2qxnjJxY6l0B5/5c wOn+etcsMLiZ+1hOjKm43tJtcllJayau0uukX001MpRdNSkqtGdr6RlO7vZae4k3dd0rHVSJ NIcKSwOQdpLAcD0bHqa8K8YmR/i78OdM3OVZL24lV7lJY0I8O+PVUvbjaIwdsZUSNuQuinJK 59Nk+IvhyX91BqSK5+UFrHUeCx97dh09j9K+c/EnjLTJf2gvBs8upp/Z1j4RupbiRbO7Di6Z fFlooVfsnmMmy6h+6u3JLE5VhXuZDh5vF4yvLSMVior2d5Ny9hS5W+fl3k0nq9r2OOo/aXb0 bt0vb5/f0fzPTPjn4n+Jug+EbnWfh1Jok8ujprmq6/DrdhqEsB0zTLG6uo7O1WHxZ4acPe+X ITPG2poiRD/QJDJGa+fbX4/fG7S9M8A6frGleHL7xt8ak0y++H9rZyana6Xolm0ei6hdT3tm /i7Vm1pbK21l7iVl13wcWh05fljMgMP0B468ReGvEXhPxZ4f0nWITq2t+HfEei28l5aatFBB LrGn3VpbyF49PZVCyywM7PDcbFUnyZPmVvn3xz4an1LSfg94k8K+IdD/AOFo/B7QFtdCj1SP W18OXsP9m6DZ3Nvfxx6C0l1FcWun61C0kc2mXCieB4ZoZdkkH0OTRprD4aOMwrbVXGyqxlVr RdWDo1lQpzUKiUY06rp104Wk5RSm3FtHj4ijNVGlUlypxaSS00i30b3vbXttqj1X4U/Gfx9J 8VNV+C/xN0nS7DxPYeEbrxpY6ppc96UvtPNxpVtY262v9qeI4GjN7dXcMzx68ZAbVmNrbqrv X1EsjDzyZc3NwIpJYwGwrSRs4AG4nJ8wZDOSCcNhsgfD/wAIraf/AITrXfjB8afEWgyfELUt Du/DMFt4Ut9eGhWvhmGPRWtGNo+hpJ9q+12F/LNK1/dSHz41WIR7Y4PpNfin4AgACa3hgFGR pmtlSij92w32Gcsu1jkDkkYXoPk82weJ9tTeDlUjpBzl7Wq+fnXNyNNySUHZJxSbW7umelQU VBKeq03S3su3z+/Y9HiWUzTFnlyrR7R8yoyrJIWIY5UgLzkHGMdcjOhNKBtCXEkR4G/zCoz8 x+98gyRx97/CvIJPit4IaRB/bimM7twbS9ZA4yRnbYB8g8jBxnGcjIq6PjB8OIIsv4gEZjyw 26Tr7f7Q66a+epP4Y9jxVMPmmk6adKolfmjObbeju+ZNK+itba+xolShLRJvbXRdH93XW34M XVL+VtU1sxNP5kCQRCQXJHmMZLRXdfkU5fy2f5XfKkncwG49ZptvPaWNpDvld2tLSVhJIJDv eEK6/IQFKmMBgxLHcMgYGfnPW/jP8L4JNXnk8T3ET3moBVkfRtZaMhJbhyFWPSHdQQo271zj 72GzXXL+0h8HtPNvFN44jZo4UDbfDnixiCu1eT/wjyKcmN/u56dgRXoY7D5p7GEH9a5pQpyu q1VXbUG9FNaXva0VvsjgjKMnJzfKuaVra7PTf5O//DnrV5pEd4haa3xI2FDCBZAMZCsw2MzB ScsN65UY3L1r89P22v2lp/2Nj8KfFOmeE5vGFj4/8Y6x4Z8TFbjVYZNDtdP8EavrVnfabpeg aNq+p3Pm6vZ2el3kf2e6jiW7+1vJbpHX1fJ+078DTIXl8dYQqQUHhnxfk8EY+Xw6TyMj74/C vlL49+M/g98W/HvwX1H/AITOwvvC/gjV/G2oeJtPu9K8cafdy2useDJ9F0X7I1n4aSSYQ6pJ ayyrHfW0qwqrTNOvnwt9LwHh8RHO8FHPMLKrksJSniKdXFYqnKrPkUILmpVYTjFX5ny1o+9F KzTsvLzT3qUZUJO0HacXZXell1ttfy9CxJ+3hcLH8WJNItfDevWPw90bQx8Or+bU9VvG8Zah q6/EpvD1pdTI6ruvYfA2nzQ/ZVtTMdXu3QwBIxXOfG/9tbxZ8O/jp8E/grL4W0XVvDviSDSr /wCNfiq7/t4n4XQeK/F2p6H4IjPlPcabFDrx0Q3E73U92qRXDS3a6fbBJ5Pzq+FP7OPww+FW u61p9l8SNIu/hrffHvwj8U7SJ/8AhOrnWZPDHhS88Sw6Tpyu3w50+RPK0DXLpXgnZdQnurhD Nqm6EGP07xV8I/2cvin4j+JPxK+M3j/Vb34v+M49Ki8Nal4Zi8SWHh62tPBfhiytPBsd1YL4 Fjjie18TRaldag0tvdtdW1wgkeSFY7aH9CeQcI4DM5c+DdbAww9ShgU8TjOf21anBU5yX1tc 3sql3GM6k4tpKcWm0eXRr11GkmlKKlG/dpSi329d79dD93YrGC+03w7408M+TqENzoekfZ4r FYooruxvdOFxFfwlWSaW2mS5t5YbhI3gmRo3SRgwYdX4A1WymutR1CUWcd9dyPbiFyhkj2X1 xEqiRgrsQIIQD8qngqAu3HwX8Ff2rfg58L/gn4J+Gvinx5Nqeu+DtItdDtriz8L+IpoRommy Na6PHNcR+HdJinuYtNSBLiVbJGklyzF2LNXdad+1z+zbJpGmw3nifxEuoGCF2Nv4b1fyvtDo Sdpk09hs3yLtyOnXODX41i8szKtVznC0oVo4OWJnHC1LJzpwjiYyg4p3T56cY03eT916a6nq RlSt7SbcdmoqyV9NL3+7v3P0ktomVSTtVYwxIWFmGXDAFyjkLkgBcgbiCASQcch4vg+32qaE io0l5JFdnbbsZsBp58iNmwVxEPmPO3n0r4u0b9uj4aWNx9h/tTW9TsPNjZWh8NOksZZS8okM 76eSGbb5exHwEbcVyN1uX9tj4R3vjCzuHi8UGGOxMYZdDiU5W3uF+6dW3HlzzgfpXztLgXia tOdeOUYjE0pRjKGIVSrH2ijGEfhjOMVy2cFZfZTd3qDxeHqwitVa/vJLuvPtp95+icDGCCG0 hsi6IqpmOIkquMZKpGQANx4wB79a85+KGiTXWiTyBfKMNpKwVvKU8TW78b3jOPlx8o/Xivle 4/b5+HTXUhstG8aSpuO3zNE0RflG0KTnxRGeTkH+lcX4o/bO03xTYXFjpvhrxYIHjkhfGm+F 4gZJHjc/Nc+LpJAdka5KjaBjA3FsLLeBuKKeZUa8sqr4amqnJKpUq1nCKqWjr709Wk7Jrd79 TnxOIofV3TUbvmhqrX03tqu7v/kdrc3M/lQhopN6uPlLMY2BMuQwxj7rEj5+WAGCSAUSV5Qq BI4GYAElljyTgDG5o8kZz1Pr718/v8Yri5ihNl4M8TTAM5JmPhJMlVmJ6eMYzxlcYxn35qA/ FjxC6h4vBGtAoeNz+FeMZxn/AIrMg8rX7DQ4dzZ05wnR5XRilG1Sp73KlveO66foeM3GT25V 5a9ujfa/X8EfY/hLwMNfu0gk1OR4QYRcxJAsyq4jmleE77ho2IMYXGx85GFOVB+lYtGtrS3F jb2+IDBJD5YhjgZWuJnLOUMarwsnUxgEYJbANfm54c/aJ+I3h9HNj8OmeWZlljkn/sCQuxiM au4HxDiRSwYllVFUE8KoAFdY37UvxsMCPP8ADywCCYbWaPQvvYIAxF8Qyc43dRtx1OcV+eZz wfxxiKsXDD4X2cpX1nVbSdmr/wCyvp69d3qerhcTRpxso8zsnqttlbR6aeXlY+zfDtlPYeJd c0oI6x3Cebbh5Y13lJUumEKjEblVnYtsGVUEkD5q9BuPs8QQuTEiZZmfCKAvJySgHAUknsAa /NNv2gvjXJrUWtReBtJjGyYEMulE4lgjh+5/wnL85Ts/HX2GPqPxk/aT1u8R77wt4US3iJK2 8SWCP80pJBb/AISmXOEJT/Xdecn79eZi/DTiKthqKxCw8JTu7xnVTjbkbtbDK99L8xSxtNe0 kl/Lo+y6Wv3ufdHjfXrS+hthpJiupdP1Czu5L62cyi1QLNDL508UarAkaXaO5aZNolQthX56 fwnpcFnpx1ZSLmfV4Ybm+uJxGY9kksko8q4I/fDz5oYzmaYgKAVBGU+A5fjN+0UNM1DRtP8A CHgWAahbPGGvhKx3ySRMSXt/F0oVMQqBhCwwcjnNb+hfFn9qSy0/T4F0/wCEVm0Ft5Ie4t/E Mvl5+bDfZ9UuQxKoVyqOoJHI+8OjFcC5zh8vpU1HDQjR5Kkq/PW5lGHK3Kzw7jaNuazt5rvd LFUq8ZqUXBqMrJat6Lu3bV6eh9seCdOGn3fiHTI42cG5+1xbIgxe1824txOiRBlMDBExMuYy SoBIK13EjN8j2rZg88LgNtWU4g3KqgpuI34ICtyRnrivzCtPjB+1IfiANGEvwet7278GT34m Nh4laLYmt21pncJJ9pWW5DbfIJK5OTjYfRrfxf8AtU+Ybabxj8GLQSOm4Q6X4qea3Tgx3EbS eHLmFgZA5ZX89tsTYhG5BJ4uP4FzmjSw9eWYZLB4iCqQniKuKi0lWjS2p5fNX5XzdUmvU6aG KpUVytXt39F5rT066rXU/QWC1jZZWmnGnhpd0kkaYlOUjIWQIwcRu21t7jYXVBkuyUkSW6vL b28i5DiI3EbIzl3LBdwjAYOW3FQzZJQ45BI+GPN/anstPGuXXxJ+Hken38kjD+yNKkee5cXM tnHK8eqeBWEcJFmBIqPDL50SMsYheTfysHxX+OUs0cHiX46xaZY/aJY9PurPwn4WlhilW58u /wAKvwov70payY8s3FvIXWNiv2jI3rC+HmOzCOLryzrIq1HCwUfaRxeYqpOtDSrRjCOWxp2p WSTbUnzJs1jj6TquKpxastW2nfS60eq7X/4b9BNSkj8q6tdrj7bFJG5KODGqQjcxBjAVQjl2 Mm1doJzjJrzudVtrBbsDKWOpz6cJyMIEK3M6gygYUEzgKqtsOVxy3PiiW/iLWYNJvLv9oXxf eweJNQvdG0prfw38PYPtV9brp9rd2sqyfBS3e3B/tDT445n8qImV3EyiORk8n8Q/DrwFr/iH xZ8P774q+PNW8eaPJY63qmkSWPhi1hjtJrLQZBdR39r8NbDTZAo1m2BgjvWm8yaT9yyRZWso 4fwyhKlUxeAp1fejF0a+Knb4UlL2lFJJu2yf+W7xVGLU3CN3ZWd0tbefl1ufosHt7dUuLjAV hHMrOMK4VQ5KsUIYAEcgnAPWnR6xpouXaW8tIooSyzeZcxIsRXzAyybyoQqcKysAVPBAPFfE XhH9lb9nf4kaDaeL/D114y8U6Rqf2oxTapqraU88lte3Wn3crW9vpOiTxp9ssLqAjEbGLZJF H8wkHDQ/Af8AYjm+IWq/DS68H6ze+LNJs01z7Hea98QI4pNJup/FEFvKl9p2u2tk08sngvXD cxO8RQQ25hCfaUB8qGTZPi8RXjQx9fFVMPKftaWHjCTXs03NR55U07KEmrtbXaR0UsYlZypQ UbrVOV9GrW6dF/lrc+/Z/GvgW13/AGjxT4Zs4lYRmS51vS7dVkaMShGaWaNQ5jPmBSQxT5gC Oa5u9+KnwqtN73fxK8BwJEWZd/i7w+CXQbgCv28lcKCScDb3IJ5/NvT9a/YXk8O+EvEHhX4X 654p1vxpBf3Hhjw5a6n8QrO/ubXTdW8R6fqF5dy658QvD2iWtnbf8IprjrHJryajLPHamK2m t5xHX058CdI/Zr+J9lrb+AvB+o6Dq2hTWem+L9G1DUfFSX+i373ms2A0+We48S69o13D9s0X UzaT6Nqmpf6LDA15eedLtftjw3klHBQzDEQ4jVKvVhySp4XAypRp1Ye1hUqueYQcY6cr5VJq Uo2TTbWkcZCUm4U4PV9XrqtLXvrf8u2vsUn7QPwgH7+T4neAJAn3Vj8W6NIzYOcBUvJXJO4c KhJ7A9qdx+0l8FxMUX4geF7gKodvszXNwyqFLMx8iGbhRyxx8owSRxnv4fhx4G0qWKOy0qRI Y8Fy+oanIfkBQfeu9xG1QOB154ryJf2g/gTL+0IP2ZrbUtQu/i/beGB4+k0xNI8QR2MPhxLU Sx3f9tTx2+jvqiTSW7JZq8kBtHQSo1yJgvLh8JwvUfPPLs8x1GnTjiatVU6NNUcLTc5Y2t+7 zSlzLDUqaq1lJPlg4Om5OU0qxGMcIRlK1HRqCir8+i+K/wDL0tbRu60ubdx+0p8LLeKKWz8R f2gzgCKLTdD8UXjSo6hxIq2OiXTOuwGRWVSpTc4O0EilbftK+Erk+bpum+K9QmJASO18AfEm 5DSHDIreR4Nc/M7IpyVzuXkZBrB8FftXfBb4hftDfET9mDQNY1Gf4l/D3TI9R8X2n9gazaWN jBbQaPPBHFrN7F/Z97dGLWLUXQsY5oDcJcC3lWBYml5b9p79rvw7+zDJ4Z0A+Hde8TeMfHEm tz6N4b0LT9Mu0Gm6CbKyvZ76+1/xX4U063Mmqa1o1hGketSzuJJZhFDBFLdj0cLgMtqYmjlt HhmvPHYrDvFYSnVxWLjCrhpVaqhVThjpTUXhqLqStHSrGUVeKUnjHEydONT2z5W1fSOya5mt OifU9DuP2iNTeRX0v4W/EDVZdrOqp4I+JFijeWCWBa58Csu1UR2dy4VQrbsVzuo/tAfFy4d/ 7G/Zn8c6tJ+6MZfV9U0dZI2jUhxZ6j4HWe3+QEgSSEzBfOQeXIoHyD4//wCCqukpd/C7w78G fB3jHxb4m+JHhrxv4ufTtb8O+E7P7Bo/w4vNc1DXLgXV78Q/Denwzjw74V8S31vbfa9Se6ms baFEhuLqK1uKniz/AIKIeMvG+l/A/QP2fPB0GvfF74kWnxKvNe8NeONHsdP0TSovhne6Xpfj 2KO/g8faXbR3Vt4rvLeO1+z63q9vexRySWEpswGk+jwPBuY16cow4Mwv7yrUpYarUzPOYxfs JujWq1+WtPkpLEU5xg6caknFwcoJuSRPMsJGSSrT7axjrt5/otl2PqJ/jb+1DqCZs/2QLs4w 0L3/AMUvDtqXVgTHIqXuk2bsDlD8p7sMgg7dOx+IP7Zd8EEX7P3hPQVaQRvDeePPDmqTKcgh 2W18YaUwDAgqjRBiHVgzAc/AvxO/4KCftM6t8G9K+O/7O3h/4fWvgSy8FlviXeeO9En/ALXt fidB4Vfxjq+l6DpcHi+683SF0Z4pdPlJnga5hube41A5t/NzviP+0J/wUu0H4S+HPit4Y034 NeDNH8K+A/Hniz4w67rVlYaktpL4c13xPNo9poul2es+J7y5L+HtKskZLPT5Ukv9YHn3kSRz PpXLPhPOcJWw9Kpw/gMunjajw2Do18Vjqk4Y28IRpYp1YVnCNWc4KPspVnZyfKno3DHUp2UZ tru7LZq+z8vu9Lv9LrKb9q7VGK32nfDnwwZmkd1TR7jU54XRiWiaWy+MVt9obzQ8Ms0caIzx O+1Qdq3B8MfjPqjMdS+NWjadIQCYLX4beMMoZR8yxT/8LkljAQBSrqrKWZW5C4OP+x18afF/ x/8A2Yvhl8V/HU9lN4t8VaVdnU5dM0+LTNM1C403Wb7TX1SxskeZrW01E2T31vDO9rcrFOgu NPsJt1nD9Roy28MLeQkUEgdrdlZ2eRd+5jKGmcKVLLjaqZyc7sAj5fHY3McvxtbBRoYGni8D OWHxkIUadWdCvB8suRVsO1OjK8YwnU5Z6tuEXFM9OkqdSHOq007RsrRa1ttfpv30d9Ej5cvP 2cPHd/N5lx+0V8QEbABTQJNY0SAqAOPIuPF+ptvIHzPvIbLYT5uM2X9lCaZvM1H49/Gm7nb/ AFiw+KHjOeSCfN+2kbTnO5icEcjqfsGEBgZlOBg469QCORgnHr+lQ7v3jNvAOSDw3PA6fL0/ I1yxz3O5ytF0Ev8AsAwH93T/AHW3V7bPTVHbTpx0XtZ30fwx0tb102tfTTc+Srb9kbwh5pl1 Hx38VtXLhd51PxLpV5HIQVDb4pvD0jkFR5TbnO6MFc4Ix2Om/sr/AAYhdBc6DZanOZEKte6P 4WnumVceZmeTw/IdpG6ScFR5o8wZUvuHvDW8s37yO3VmZm/e+YQWAJUfKZgoK4A/1a5xk5zk 6lu26MwXE0yggHbth25iUOAWSJnxuQAYOT3OMmuhZ7jpLlljHTnGymoYfCpKa0klFUkoqMk0 klZbJKyNoRhzP35OztstXok9NHsvx8zzK1+BPwd0hmXT/ht8OZpijbHPgfwtbXxaTGVW9/s1 FBwoCgRZ24Xnbmu30jwl4d0qLyrDwpommrFCqItpY6TbhBHkpGv2a0iXEZ+6FwARlQK6JZrd in2htkQYEuofcMEnOAGPcj7vbp62jDaAealtcujDekqPEN6EblfbJOhG4YbBjUjoVHSvMr5l jK0orEYrFYmEdYQpQo0nBuybbpOi2mlb3pSUW9Enqd0I09febtrayXWOvy0v/wAOUYrto7bb BbrDIMhltLiOzdgFjCGQbS0uDv2YA2Hf/e4fFeRyxOLiAGQrICbmZJZgpUgGOd4lEUgB/dSs rLE2GKMBiqOo39mmxpLmTMQcolzGdq8qDj7HCGOcANuYn5V29WJ5S6+JXhLQUluNY1qGwigj aaWW207WrhoowhfzNgsbndtCMxVUcnaAEJO0jxUpJJf2hdtKN6jtdrS9sQ/d1s9Hp0ub3pqL W7cWvvXdNPW+v4bM8/8AGUEWnfHL4JayGMa6zafE7w5JG0ZuSS/hrSNYtFa4twu+V7fwrJNE skQjeBJnjA8lTX0KisoERV/3Y2ZdxIW24XdwoC7sfdOSCDyc1+c37UX7TvwwfTfBGqaH4ve8 8Q+DvHUl7beZ4c16OP7BqHgzxXoF27pPo1tbTvt1SyCoWjdSXlQHY6n9D4boyCKQ9Jo45EbA +ZHwVcAHKghsgMAw7qOlfRcV4bHyybhXHuMXOngMyw9WPNLRUo5XSpO/JduSjNtPRPa+48F8 CTST6LW11brvptZq7f3liRfLieVSrtHhymRhtpDbOD1dQVUckkgBWJCn4M/4KF/E/VfhB8Hf DXxA0TSbTVzb+M9P0vVbfUZprW2srbWdJ1Jo5Ip4TFIXW+tbe2ZI1mUF9sqxsFZfvIqSJYl2 7piqJuzje4CKSRyBuIz1GO3WviT/AIKC/CrVviz+zR4p8I6RbQ3Gsrq3hG+09JL5bGHzdO8R 6VFeM88uY8fZJLkojr8zFSArhRXZ4f11l3iFwv7aMfYrPMDhZybkr4f21OTqNq3vatOK93S9 73MM3pTqYKtCErNJyVtLpcve99dNF+Z8z+IP2j/gh4X1I+H9Y8e6Zb3VpaJDqU0aanLBpUv2 i5spU1i+tdLu7DT3jksbt3bULq0Gy1upiBDbzSJzPhn9onwf48+LHjP4SWlrcpfeGLfw7Npt +iaxcWusW/irw9qOpqzzSeHLfSrWC0u9Gv7ITnVXhlmjuI38i4t5I3+VG+Dvxo8C6N8UtC8P eDNN8Wr8evAd5PfquuaPGugePdbtfEtnqN3dyX/iHwu9vpVuPEVmI49NHiNVC3LJb3BjiEvq ngD4MfGb4TfFLwh4hsdO0nW/D/iXw1ovh74j3o1PTZZrKXQ/E3xJl0SbT7eeXQp1iNt43thO 9nb3skkltceZAgijN5/oDDA5bGhOvFN1HFzhLXVyxUE7rntb2cpL/hrr8vpVsb7aVN04xhTc lzptva23LbV2WnQ7Rv2ndD8L/tNR/s46r4b1GJZfB6eNF8UQab4mvQZW07/jytpNP8L3ejyq gtpYNsOrSXKpHIxiEakD9VP+CfPxj8K/Fa7+Ntl4Qa6vNK8HX/g7TodbbTddtdN1iOa88eWK zaZfapoumafqSwS6JPFcto91qMVrKVjuXt2eAS/lj8W/hl8VLX4v+Efjp8M9E0rWdY8PaWPD Gt2F3qVnD5tjd6X4riIhs9T1DSrV5Ldta0EvNHqsLHyrjYtwFkE36B/8ErPCPxP+Hdr8cvh/ 43i0RfCfhu88Cz/DqXTLiO6v5dM8R6j8SvEWoDV7hPLaSeJNR0lIhJbQGM+fGDPtMp+ryV0F GEY/G4+7rv7ibe715f1ObHTxThJVHeDtzaL+aMltH+a3X/g/rjRRRX0J5B8DRftz/CO78EDx yPFNzpmn23irTPBFzZyzeB5PEB8S6ppF9q8ekzaXN4oitbeUQaXcxRp/aB1OW9W4t009Y7eS dt7xB+3P8IfDtr4VudQ0nx4YfFFhLfz29tpnhYT+E9OXxDqXh06j4yEvi+3Ph+xkl02+1SO7 LzwPo1rNfeYGimgj+XPh/wDslfFO4uvB/j3xT4aGk+Kdc/aQ8NfGjxjpLSeHpF8O6PpkltrK 2LXLa9PPqV5FqPiLxNbXF/HK92BpcUi6JE94Gn3/AI3/ALO3jrUv2n9d8dW3wd0L4seDPiXH 8Mn1nWvFF34K+zeBY/Cdu2gappFjo+v3U2qa5pt3ZW0GtXdjZW9qkl1qN3CpuJJ9y/OwxeLj F8yqK23MpdbdeltrX3210PaqU8JOpFQdNp81+SUHquXSyV3fXW+iWl7n0/pf7V/w/wBb+IWm /DPw3Y+MvF2r6t4N0v4hQ6h4dj0jUtF0zw9r2l2ms6bBqt1pfiO6u7aRbDUtMxcGzmtpbjUt MiiuJIL22uG7LxIT/a14AS80VxdOWPyyTMXRyuwbsYbCbcsAdowOFr4d8dfs7fEvxt8W/Dcu k+B9G+Deh+DdC0jT9M+KHw/j8O6Trdz4c0zwheaLaeEptP0vX7LXo9Nj1LV1tY4YZY9NhtND 0tI9MWCCO7X7N1Ubr10idhHHOyR30pMlzcpGVTznUeVKsk+1Z3DAtvIDAsM1/KP0psfLEZPw vg5TUnLM8ViJQUuaSjQw6cZuG6ipNpTeileN+aTR9Rwxh4QxVWpBcq9hy8zXuuTcbL+Vys78 urd+az5U0XKxmLdHlIyDhDnAIbHTcQPmGePrXzx+0vrcHhz4IeN9YkYxvaDw2sc0bxxSxyT+ L9AtyUkkZAu6KWSM/NlkdlxhjXvM92JIVAjMZ2uNjE7ly3f5F68kcDj16n46/bacT/s7+LdP V9k2o6n4VtoVBO6SSHxJpt+yLnauRDZSyHewXbG2MttB/kDKqftcxo2h7VYjFUJpRunUcowk +WSTu7uTbs9paaH29GhN4WUXzR9+T97S3vL3m7q2nXbW1z2v4e+DPCVr8NvAFhc+F9Alew8E eHIJTNounyu1xZ6JYQGSV7i3aZ33LJuM5Z2LHzMtmtK+8L+CZbiBbjwd4XljuLcmNJPD2jHD xiSWctmz5Dq0QwCQpUnaM5bRursWttDY2siA2yJGykmHbCIsDq0aEYK/KmR0+XFfhH4t/ah/ a3+If7SHxP8Ahn8GbLwjcaR4F1LU7C2u7iLxLdXFzLa+I/iNC8TTj4oeEdOs3Gj+ErZ32ROr NctjCJDbN+iZTkme8Q55ndLB16WDoYSrj8RiK2IxihSw+E56tX61XnN0oUcOqdKVR1pyjTUE 5c/Km1WInh8voqeI5JNpuKk4pvSPw817t3VrX79rfsZqnw78Bxwwy3PgjwNNKHEc5Xw1oWWB E7oGH9mqEIXyuABkANk7znyPxt4P+HGkaPrFyvgDwVDPYQahdpMPCnhzzBHbWl1OvlSS6eGS RQISkw+ZSoYMM5Pxz+x7+2D41+N8niTwX8WtE0jw58R/CE+onVdJ0641qdhpC23hLVdNv5G1 C71iJ5JYvF9tAUg1a4dYlibyoQs6RfSXxd1+SL4aeOryVozLb+A/F80K+azs08Hh+6aNV2s0 gclAMKN+7hfmGK+khk+ZcP53SynMsdi41qVKi6taGKrQw9XmrSUatGSqeznTlKLhGUJSi5xl FNuLRwOth8TQhVhVpwlUSapc8ean05XG8Wtn9lbt9Tj/AIdfDzwJZ/CLwVcXvgnwbcG2+Hnh O+vZZfC2hNNcTjw9ZPcFpprAyCaV4c72cMJXDjD5J+b/AAF8e/gB4x8AeMPG5+EHhW2v/BV8 sV14autB8CnUNVsXn8LW6Xtk8dqsq2sl14qt7LzmsSi3FpcxLK0ojRvrW3kceAoLK08l5E8F tYWtqs8SiS9tdA2WkIIkWMF7h4Iw4CxrwyuoG5fzYk/Zo8Wj4dfC/XNHsNR034g6L4k0Hw/4 w0+3bSoXl8AzfEzVda1W91C6hvLSaaS1tNTsbxLKXUL1JIbCycaZKwiaL7TLKdOrUzz6zmmI ouNek6SrY+pCVS2Ggvc9pVi2lJWajzK91u0jwcVOrScJQ5nepFNxu1Zq7bST00vd6b73P0m8 LeD/AIUeJfDfh/xLH8KvBdtF4n0DRvEUFlN4P8OMdPg1nT7XVILWS5TTx58yQXiRu/lRqzRO yZXBrbh+FfwxG55fhr4F254H/CJ6EnTB4I05e3SvIPhT8M9V8A6xeeJNS+K3inxPa6h4a0zT 4vBWqXl1No3hhjHpcitYWx1W+g862W1NnGbW0thDBPcJgIxUfQE2oK0ZRruFSGKkCdThipG3 IlwSMHgc9OmRn5DHYrFUcTONHG5jUppu0qeLxEotabOM5LVLvb1sejh+SpBOrUhTdldVJKOt ov7bXf8AJ7s8i8deHPgH8P8AwdrHjnxN4D+H1noPh0Rxapf3HhPwbZxeTNJCx1Rpr8Wthbww i8TT1WW7jhluYFVp45ZmCcNaal+y7c6d4C8Qw+CPh5e6R8S0vh4Tv4NA8CjTtRfTtMudUugN Rt7t7eV7a1sbtJ49LfUhDeRNby7Yo5LiPzn9vHSX8bfsyfEfwKbCXVrTxi/g/wAL31hZmK6u ZNP13xr4e0/VbSGwkhuknhi0qe71O4Sa1ns5YVuI7iPa0jr+V37Pvwn+LXwU+LPwi+BNnYeK 734W6domv+L/AIbatqlhqP2LSW1jwRP4o8R+H4Psd/H4d0yHStU+IlzoNlpsFpoN5dW2jRyx W12NN1QQ/a8IZBPP8qxNTF5xiqGLhWnTpUK2OqxrTp0qVLEVpQpzrwqSjSoupVquMGoUoznJ xjFtfN55m0sFi4rDUZ4inJLmlRUpxu9LOVOEopKyd7/ifsVa+Lv2P9T8f3Hw40/RPhLJ4nsx M8to1n8OvLuZbbWk0KXT9NSLUrjUb6YahLFEu/TreVlntw8STzLBVXR/HX7HHiPxte+CdN0j 4Q3esaIIpryytrP4aXEWoW91o0mtl4XtdTkv4o9PsLS6urqUWOERHd2FvG8y/jJ+yxH448M+ K9C8OyxeLPiL4j1bTPFn/C1PB3iXwH45ng+G1hY6l8KLHUvEmjavftc6LpWvz32o+ItL02Cb +1NUuk8PXF1Z22pWmmahs5HwX8Jbvxx8TvhBb+Ftc8Ua14D+Fdh8W7jX5rb4c+LNG1LTYPHH gvUs6frMuqyRx3lzPNplxdaTY2WgpdSQ30MBs7qTULO6u/pK3h3SoYibq57mdOjHLnUhKjiq /sqkp4jCwj70MWoOcqlRQjrKUpSUV70rHEs2rTpSqQw8JttOXtGk4uyVlem7XXV2u+l9v270 Dx9+x54q8Z+IPBGheGPhPd69oF1qttcWCwfDuSFjpd1BDdlZbO+u9RV7ZrkQtHLpwI8hjO0T sVXm/DPxo/Yi8a+JR4L8M2fwe1HxLH5n22ws1+Fd9eaZF9vstPF9f2Vjrd1fW1vBPf2oLTWq ROsyb2V2iR/zY/Zq8L6/rP7YfgvSNMXX9U+Hvw50T4nvfaw3w98XeFpdNnbVviHpy6Bq/ifX n/sK5urXU/F1jJ9htNKtri4WazmhsoooLi6P2D+zh4S8OTav8fP2oviJaPaWfjB/E2naB4b1 PS1v7LTPCPgjxF4q0S4t9G0WawvPEaya5pPgzw7fLaw6ZbJfBkWx0rUIn09bfxs34ewmTx5q eZZ3LEQyym1fE4yhy4uo6Lp0pVHWk6darCGIlGLXPKNKq4pqMrZU8zryUubC04xSfNKMkpRV 1dp+z3frc+kfh/49/Y/+JniFvDPgrSvhHres6ZH+9tLGy+Gl9ea5JNZahqyHT7PSNS1G6KW1 nZTRXDQxHZ9luJijLFKR73D8I/g/PKLp/hd4AWSWIBTL4P8ADzzRRNiQQCV7HeoRsghSozu4 G5gfyY/Y08XfDL49fGHQ/jJqXg9Pgz4n8FpqHh34b/Diy8FaroelWlje+G/Fseuaimp6r4T0 OC1uNUutV1O6LafBokfnJCt0uoTTebcfsw+rWbQxg3cWVjjR5BJ5jM6ABmd1yGZiMs+cMTnJ yK+T4syrMsmzTAZZLE5xRVfA4bGYv2+IxlX2Hta9eFX28ZziocsaSlN1HH3Wm9Hc9HC1o1rN tU/Oclo1Zu7fLpZ39EcOvwg+EouZ5G+GngElvLXJ8I6AQUVdoUqbHa3yqoJIJODuJLEnQX4U /CVFl/4tp4BYPhin/CIeHmjXblgsUZsTHAnby4VSPaAm3YqqOmXUNJQnGp2s7tjeqzRs0R7B wGcruzxu2/dPXBxZN9pZidRfWYZlYLuuIE528cswA57kgDuRXyjrZnKk1TxmZpQlaHs6+KpR kniFBuMI1GknC8m1o4803u2ehUp0fZxaq0pyV7uLg+q6KTvZabu1nbTbkV+EXwmXD/8ACsfh 60XIZX8GeHJFZTkMuJNOZcdwOgYbhhuajk+FHwljd3X4c+AFjKrti/4RHw6fKCoMgZsvlQHP looCRJtjjVUVVHY/2vpkUYifUrBCTnDXttwCScj94ATxxj6dabDqekBpi+pabsmQCNmvLXJK DY/BlyMMcAkDIGRkc1nCpms5OlHFZvJwqVGpLE4xpwhPli7qXwtO6abTW19DKMYWalOKS1u2 kuitq15/LX05AfCr4WIY3X4deAmQsm/b4P8ADvRmUBdwsCVJ3Y4IPPGa0JfhX8Mkl/dfDvwL aWxA8xm8J6CwweG+aSwAGSB/GMY9zWjba3o8CFTq2nSRuxOGu4MgIAQQvmknbkN93txgjIQ6 7oG9nl8R6W8WMGGXUbWMH5QPuyznrzj92c5OO9dz/tWMYxqYzNIOSVlPFYtXs0tFKevyv+V8 XCin/Hpf+Bx02397+rt9Dya58BfDuA3kSeAPCDxjXbqNGXw1opVovM1h1Kf6CwVDsRlCMVCh VU7MCvUE8HeBCXUeBvCUR+RV2eHdFhLL+8HzeXYIZADjBbdjJwRuOfPtT8T+HN1wIfEGi7Yd blMi/wBqWS+WpTV0Uf69ARucKNo9DgCu8bxZ4PWQveeKPD0QUlU83W9Mi3MjZkCCa4JfblMs gI5Xk5FdWYzzBxp1HXzBclOCu4Yl3aUFdyc7O+1927+pxwjTqcy54rV295WsmvNb977eZxeu fC7QTq63Fh4X8NQQRRxTARaBYl1eFXYtHIliSjhlVlZXUq4BBB5rvNJ8D+HI9Ot0i0DQ7a5M CTSXA0eyE7TO26V/NMAmVnM0u/DjcJGDZGBU3/CxfAcVs3/FW+FI3GcvJ4i0iMImfmYlrhBh Vy33xnGKot8TPh5h2m+IngiJdirHu8WaEoJ3JkfNqQ28KTzjPTnIrkljs5xCpqCx06FKLi1K GI96TcWpR3vonqrrUX1enTozjzxm5zTsnFuyWuzfX09Opk3XgDUWlS4hu9Mt4MSKqW2j29q+ /cjs3nW0ETkMnlgjf8xjRyCUQjCPhkQ38GmSqj3NzCI7drOBrRooS1y9wsSWphdGnjkkjnkh xJLFiOZ3iREXqJfiv8MBFFBJ8T/h7G8cG8o/jXw2rZZVTOG1YZGYyMjOSCM15b4t+Lfw6tdZ 0fUYviR4Ffy14EXjXw+hZBMEnPmLqblTHFIzhSpMmCiglsV25XWzSU6qxsMa6cYP2LlCvenP S048yunC/MmnF6KzTRzVqdONOEbxvdb8t76bryX9aadheeC49Ot5ruSO6jCSpHmKK7QkEIi+ Y5uI/NcgAvJIWkdvmZmb5q6LRvCGm3KreS2UzwzxJcLlbrzT5xExLSC4B3kE5YSN8xyDwDXG zfGH4Z6loJ2/E/wT5krQyGNfHnh15F2tHndGdQEi4PBLqvUf3hnotC+O/wAG7LRdPgf4ufDs SLaW0bBvHPh1nysRDbgmokhlJwVPO7IwCCKMbmGZVMDWoUpZlSnTrXjN0sUvaJOCvHVOSe9+ Z7X1uZLC0665ZVIx73aWmiW76fd3OltfCWhPMYUs7yIMyAO8l9Ise4YZsvqBOCBg8gZHrzXR QeFPDKXf2BTO91HaxzBo5rpWXcImcbU1XzOBI4ORj5ugwMc2v7RHwUQnb8WvAJiYxqzL4o0w tkNlgqLdlnwGUkKrYz9cc/p/7RvwXtfH8k3/AAsvwpLZPpm0Twal9p3ym3iyFS2WV3AKHLqr KACS2Oa8mFXiDFw5VDOqiVOEfaQxGOpRlyRhD3YKEkmmuV2m22m3vZNYShQXs3KM1G3vrlad 7SaTTknu1o3Zp7WsezL4K8MQ/u5QG/h/1twMHvydRBOc1MngrwpEVjVItkzEMjzTszZ2gkM+ oMwXB42kAYJABya5R/2kvgVK2W+IuhSnlv8AR7PVbvGMDI8ixl4PGCDyeBk0J+0Z8D5pLd4/ GS3LLMyH7L4W8W3OFHlkD9xoMxLcsfLB3YAO3DAnyZQ4rpwq0oYHP5O6nrWzKpH3Nea3sbNJ db6boUqVBRbUVLb7K8rp+vlrv5D/ABvbeENHtX03TNPRr6U2xiKXDOuHlMs2Y3u7hm/cRSZ/ dNjhsqBuHU6R4G8NtoGl6rd6ZaobvTI7mTzJLgFpjCkrMd8qRgk7ztQBfm6BQMfMfxC+N/w4 utYkfS9V1i5VobVI2i8DeO0Yv5bKwXPhxSOTtJxjBOTjNd+nx68Et4R8M2KJ4yvJ0sooJ1t/ hj8UbpQxgWMgSweDp4ZOSUDK7qSCATgivaxuW8R08swmJjTzN1KrpqpCNTF80eaKb5ko3Vut 1p11OOmsM5pKMXJdFGN76Jbef5vyPXm0HwWSVj0SMhCVYrAsgcjglHN2TggZUjGQQeK0LXw7 4PbaP+EeaVC67V+zsdrF1VnbF2xK7CykHIywOAQCPPk+PXgqGTyLPw/8QrkZKxrF8Jfi1lgu VT90nw8JQlVz5bAMvQgYqvL+0PZwnNl4E+JF2snybf8AhWPxYtnUKpld8S/D8EBRFgEoAxbh icA/PyyzieM0quGz+MJte/L+0VGza1vKFrLdO6Vnv0OunToWaUFv2i+17q2mvqehXth4Qsri CB/CLSrLcyxL+4IG2OC4kxgyN1KIcqc/LycE51E8LacpzHoeneaxGZGtxI5/4E9szfeO44PJ 56182+KPjx4gnvNAGm/CH4i3oe71C5kLeDPiJbuLc2Mwjk2T+BI2bLzxDbguoYMVABI6GD4+ fEFZStj+zp49uRnn7RZ+KLMqNwC8XPgKE88ZOMA8HGDXRjMrzjDYanOM8VKVa7lDEYutGUOR w+FVFLWXM+bSOqV7q1qhQo87bp2T5W246Pa2rW2vXY9uufB1qglf7BpkDxW73KMbCFyHj3KG 3SQKegICHKcA4JPFTQvD1ld2txPcx2LyQzXI3ixt1AKX89uuFTYmBGNmCB/eOX5rxPxH+0B8 Yo9D1S4i/Zx8RwKlnIrG51i9tUBYhRl5/DFuAzF1Crnc2cjI6cboX7Qvx203w9bSR/s23Zl1 CW5eD7X4pQ+ej311dB44BpMM1wTCwkKo26NSJXG1WFPBZTnOOpRjUcFFyUZyqYxzpQg3FSlV jKMYeyjFtz5nGPKpczSuRiHhqNnHkfw3s46arfl2TtrpbU9Y1Pw3pv8Aw0foFgIkltP+FP8A imSWMGUxmfTPHfg+FmKiZgMxagVEe4LtJDqfkI8J/bE+FFl4o8b/AAbGl654JsprFvE2Phv4 zuo9H8P/ABQSaTQJDZPdJb65Mv2BYZ1Q2vhPX2W+ktQI4JJTPD5tb/E79oaH40eGdYufgokG r6l4P8XWCabL4wsAD9s8V+Abq4txM1wCJoroQW7W7lXIcM8fGR7p4kf46/E2xTS/Gv7LHgHW bNfMNpa+JdT8IeIXeR5LeeeW0GqajJDL5Umn2Esi29uzSNaww+Ys8ETRfTYnC5rl1fKMfVzD LKOFwtH3aVLiGhlKq01jadNyhJOUVBTfK3GEoqTs3eyOdShV+GHMvJcySur3aXXy9L6nwVcW GmeJfHvgLwPa+EvBPh2fwl4u8V+CdR8N+O/EE1/8H7PUdP0D4keKriTSNc1zw1qSLYOupxNo emv4A0uO2vGMVlb2EEcErdt8aPhoEj/Zb8JeFLH4EX3iC18Y6voN6dAXQdf+HEb6v4m8MDTb uVx4DkshDCUUPaTeEUiuo5NcjZpUtZU1H63sPA3xOk0vTPCDfssfBFtE0+5mu9N8P3uieCLu zt7xY71ZryPRB4hhhW//ANI1CN9RgtIGWGWe3fLNMz6XhLwx8T7P7JpGgfDr9n/Q30uSy1SG LT/Dfhq8vrXULGVmtWMej/EyxeG7We+nmhnWCObzWYw4kZ2b6+rxJGnB16GIySpGlKVWkqnE 2DzSvKtWknXVTESpKfJFqPLTlFqnqt3rUMMnLmSaXbls1tfRWvf/ADPhbwjpWseCtRm1vxnp Gj6B408A/H/4Na94l8N+FtHstG0LTNM1PX/g8mjXPhy2ttE8IWslvqllY3b6pc3Pg7w3Be6l BqVhLLrKWk2oyUvFGufELQ/HvxC/ax0bwZ51pN8XfF+lSeIYdS1W28Vap4ONvd+CtP0FtPh8 I3fhwaPBrVvpWowyx65MhTT4NiG6CqP0dkk+KGu6rPZXvjD4GR65eLpU39lx+G473ULwWdzP NZ2L2SfGx7u/tlNo9yLZEJnjvrqC38qUySnxvxy2q6XL4qsPE37Q3wh8E302oWcN74ctrOPw 5PZ7YNJnQW+hXPxokvIA8lsrvE0Ep2iWckKhdMsl4nWGxMcbg6GEq4+vWp4nFwjXpezdCnVh UqqLjSkpJqKVuW0r2s7WJq0HdKT5Y3TvL3U2mra3Wr6K/ktUM/ZP/aN8CaJ4O8N/CS4k1Gz8 RW3jDxtotjZpHoDRQ2+vfFTxK9jbeTcazBqRiuIdT0l4pGsZJhEuLMSRyoZsj47/AAK1jxD+ 0d4o8U+F7X7H42s/hp4R8ReAvGVrp2o3CWev2Xi34z69q2jTT20UkN7Pr9nDYaNcWs9vqy+X ramTTJ47w2997hoHwN1rxHbxT6X+0zNdT6fDEbyLwpaX7XlnICY0a6vbP4i6gtnIHtZRFLPC mydZHGfIkStP/hlDxLP9pFz+058d7h47Wck6X4n1LR/tBlgnWWJI7rUNScSSBMQz7pY4PNDS RzrGwf5DGYvKco4kqcSYfMMDhK9eWMqYnBunQrJyxlKpTl7rrU78sq7lZ0np0VrnpwpVqtJU 1SqKFrKfJNxeq62s/vvq3d7H5q/sn6b8SPgr4e+Hf7Seu/DPx/qHhvS7HxP8M9c8G6ZoOvy+ LtHn1TxH4k1WLU4ItR0u2tDprxz2Lyx3N3pLn+05XTzEMZvvrj4H6x4x034qfHj9pWb4X+Mb bw18ab7wFpfhHwfLoeo2fiWzt9H03XNO1PxLrcX9kiwlgiutDt7m4ltLjVUtT4itklvUa4zd +3S/sd2Aulur39on9pXWUFq5P234mQypcsDKrwiC40SeVhHaiWTzv3kaCN8rhXUTw/sc/D9k Vb3x78adYiZZZGfU/F2j6jbut04muo8v4PeNlUv5FyN7BPL8m4VXBVeLH8QZBxBh5Vp4mmsR Gj/ZNetHJ6fso4WEo1KkqdNVlGq1VhTUZKcU4SbTWz6cPgMTGzhRrSW940pu7tHW6i1r87+j R9FePdW8QQ+AfF1x4ZtpLXxRJ4Q16fw7bySzDy9e/se6fSpWA0++lkNvqBt3a3GmXqSmHymt plleM/yZ+CPgN+2l8Pf2vvC3jS8i8MeG/jX46+APjzwJqPxM1TxN45fWNNi1u08f2OlazJqW u/B2O7mFjYaPo2mQWiwWHlR20dzaX63ECJN/Son7KfwMt7+COXSxqlyI/PEGrxeD70gYmzmK TwsjTxkxO8pjIH7syMVAzXW+HvgV+zeL2bTLDwP8M9cvIJiTDeaP8PtTmuIpbe1aQtp8ehJc RrapcC4hunZ4PNt44FUzzRbevgjinJOBYZ5Ohhaec4bNsDVwmYSq5PTw8aDxtOWHqOpFrGRh h1RhF1VJxhUi5qTiou85hl1TMYU4ym8NLDuVudOLqe1ULpKUoN8rhra9m1eyaPwW/Z2+Cvx7 +Cv7Ymja5rHjv4XaH4u8e+CfiTN8Tfiva38mpWniS/mXwV4gtbrxTrPiPwBpiXmuXl/dpDp1 nfyB9OaTXbHSrz7LY/Z9R0f2m/hv4/0y9+G3xQ+N/wAcNF/a9l8IXfiHSZtE8J6tP4T8R23g 6/l8MeIdQs7ceB5JWuLK/bwpeWkkl60Ci/1TTttzlFMf9CC/Bn4P2Wbex+HHgtYy7RtFaeE/ DUNpAkZdikMEWiFEeKUCFiJCCxmIRd+1Oosvhl8ObCV2g8J+ELM/ao7m3ey8LaNZ2/m7mKoL KOzaby4SkZdBMjTo8UUbxNbs7+tV8Vspxee4POquUSdbC4BKMaeXqisRhnTr5XDCOqsM3haW Hpw+uU5ctWDTjVjSgqiqEUsirRwypxqSqXsvdTb3Sb+N3a66+t7M/lJsfh54if4BfDjVfFmk WPxS8b+G7/4jWVudc+JPjqD4jeGvC/iXV9K0+201tdXQta8XHTWubnxRr0lpe3kFkdFu722h aTT7y9ig724+DMeg/s4fDOPQvDHgj4i+NtM8ZeMvF914M1Pxbr8Go+F7Hxz4k8bawLCz8Ww+ GvF/jCyl0608VWdjqZHh7SYdbNgovsRx2qx/1JnQfC0bNdnQdOgFuy7IhplmBdbggJMi2AWE RFj5vmI/nx4iQxEFzoQQaZLcQNFZ6dBHHDIsc0emBks42WLak0SBGvAwRYIhbvbC3Pzurouy iXjfgaVKVKPD2JVLCYpYuann0o08XRSnCOCcnlXK6NVVoV2mqkJTpRn7KWk48seF7zXPVSu1 8SSfR9Zr9ex/LbZ/s8eIbH9nz4ZfCjwx4pltby3/AGmPDfx1+Itjofh2bU9Bu/DVp4J0/wAN 6z8OIU+3pPfzXMrXUME9/peiWzWUahrC1e7nt4Pd/wDgoDpfx2/a+vvhro3wR1P4xfB/wP4P gu38d+D9e+EK+I9L8dXTeI9B8TaTLdWKaldWt9a2baDJbfY9TSS0lmkdGhkiM6P/AENfaonZ 4rcQxpLtiu41AKKCXWe5gtl8tolYMFaN/PbCQxtIxQbqQuriNhFFBbtD8kcsflMPORXaYBm8 0RgFppEw8bgAZwd1cdbxaxmMzTKszll0qk8sx2NxcXicXLG4hYnHPBtVqkqmFVSpyPCRk00n RST5rtM9OOQwoWhGopy0lZJSaul0U5dVpa9/wPyn/ZQ+Jnxw+DXwa8K/DLx18L/i/wDFDW/D EdzZWev2XwwbwTocehxMkei6dYaLpGk3NlZQabp6pbxCGACYu0jMXYyP9T2Pxk+MWqJ5+nfA DXrE3ZaR4/EV74g0A24aR0hCfZvhrqgn4Znm3LAIECFPOErbPsRZYDG0jLFAHAV7aIKojZSi 7sqCrE7FJIQfe68VRjaOVW+z3F3sQqWaKZrfcCGxuV4svgBgoGdoz/eFfE5nxJHMcwzHMHk+ AlVxeIqV68MVSoV6FSvVqc868/aYdQrOSkoqM4t05xjNTckkvRw+CdO1Nt8z2jazdkru1+iW qW2ux86Q+IP2mNWsnjsPCXw60IyCSJf7V+IfiFLhGbjzUt5fgXKJQPmKIZUWRiqkqDuHPXXg 39rvUg00Pjv4c+Gg75xBOdaKBcjb/p3wr04N5mQCTtKBQVDFiB9bPcBkKCB5I1Vt1xK+ZE6t kFolIKYBUgccY5FRGaJIMgpKSRiOSaMkg9ypGcgDPIHFcdHPJQkv+EHhtrfTKcvfWP8A1Dtf 09T0qWFa0b6dVbtbd6p91qz5Jb4M/tX3Y3v+0xoOmMyqzLY/D3w9doh2gHy7htM0+SX/AJ6f NHHtclAMKHLrP4BfHycFda/al16+ByJFtfB8emxMpQ7l86w8SWzR5k5RlQNjag2qcD7Cj1HE YMlrp0SsgVd8A8z5V2klzIoyfvA7BgY6gZLrWbe6xi4QiSRf9HimWQOAQx/dI7FvLHzfd+UL ngDImrxHm0JydKWDpU+ZuFClh6cadGN/dpU4QajCFNPljGEYxjGNoxSSS3hRpuVvaQunquaN 01a6+LSzvfr9+ny3a/s6a/mFdV+MvjjVFMg84Rap4ws1dNxwAtr46RU2rwSoBYnk5Oa6u2/Z r8FyLjV9V8Uay235zP8AED4kReY+SHeSBfGkkaNIvyvF8yqSyAsMk/Qdy7x3DRiIrGYwQy5A yQewHByMbjimGaK3QFEBlccnGSWI3ZJRMhtxHLHOSe+amXEmd1OXlx9TCtXbeDxFTATndK0Z zozj7SKvdRe0rtHdClRWkqtPZJJzjd6r+9b+nroeGL+zj8C0jaO4+H9tfSMAC97rXiO9DEcH zFvNZuBIHYFmVwwYnLbjzWlpv7P3wPsiPI+EXw/D5by5bnwppF4yO2Crs95aTs6owBCuxXA2 gBSRXraQqP3slxGXJBZPMjYoOvOJGIyWYc4+6fQ1a+0xAHfcRDaCxXzVOQMnAAY5JGeACT2B zUVc/wCIJLk/tnNakZe64POMXNT5rLllF1XzKV7OOqkm1qmbKjS3VSn0+1F7W8/w23t0Plf9 o74SeELv4GeM9E8M+DfCGk3cyeHTbT6R4U0ixuI1s/GOgPciCbS7CO8jEgaUMsLqoieSKQeU zIfdfhbqUWvfD7wXrIzIup+GPDmoKzOrv/p2iaddAvJGSrviUEsCQxJYHBzW5q0lje2U+nXD wJFKqgNI0YjYSXMF9hmlAhUkwqQrsCSOnmLivnH9kPW59T+HNzo0TrPH4R1tPCCMJXJSPSNC 0K0gQrI/lqxVHO23/wBGXGI8KRn2KtXEY3hTNHiq3sI5fUyylSdebglKvOqsTCMqkoqLpyo0 lVim3Hnippc0U8XUjCtywlGUeZaqSs72T2utuv6H1ZLGrSFsjIVsAkn5th2nBJGVbBHGQQCO aztVt0vNGvLOWNZBILct8uGOy8hk4dAJByATtYZxg5FW2RgHJOBjtz1GM4BJGDjr9enNLFKo 3g5bEarjaxyd0fXg9Ap+mMZ5FfIYCrUw2HynG+35sXTjSxM3Gf7ylL2jivaWk5wd46KXK9VZ X39SrBSw8rWmuROyV76Ld2Ter6rc+MY7ZoVYTz+a8EkkiLuZSlwwTzCfmBYsYIwyupB2DK9R VbeEt9k0S7jvCttUHaCGADFVYbWZj8p6sc1BcJqkes+KYL+yNqU13VHtMSpJ5tqLu4SOX5Hc KGx9zKsP7oGKbcEbUDyM24NsADEAhucj5sZOBk7c44zjj/RXKK8MZlGSYmFenUjXwtOpUnGp GcVzUHJuclJ7VUoNu3v+78TSPz+pUUZ16fsmruPvcrVrSi2/hT1Xnr9wjykAyRkIxVE3KFDB UVEXBAyG2xqrOMO4zvY733fbP7IDrIvxBcJGGb/hEy7Ikas+f+EmwHZFUsEHyxqxKxr8kYVR ivhh1kZdsa7iDwMhQeTnOSBnnOM5r7h/Y5iMcfxByQQR4Sxyp6HxP6E+vGcZ7V9Zkc2s1w0F LmjL220m1ZYaq1pqnt3bR42aRTwNaXLZp07XXetTXy0f5o+2KKKK/Qj5I4/w54p8O+KvDuhe JdGvkuNA8VaXputaHdTQ3enSanYazY29/p88EGqR2twVurK7gkVPKWRWkCMqurKL+oXMMZl2 yQIIreU3Eksm2O2hMTlJLpmcCBCfOKyOFRlU/MfLcL+HnxW+IPjlfEOu/B7RfiBc+Ez8LvAO g+Ffh1daV8QPib4FtdCv7C+8deF7DXhovw+8LXFh4lWP/hHdAki0/wAXX9yII9J+yCXyb++m m7z4hfFL4w+Efj3qn7Lmv+N9d1v4g/tO+HPht/wheuaJrVxp+geA7LS9X8X2HxCvbOQw6Vc6 XPc+C9KS9WHw/a6RLc6pbtLZzx61dzapJ40sbRlFpU101Sle/p0V/wAPM9eOX+znFupFb3Tk rWdvTo72019D9Nh448O32v6z4QtpdTfVNJ0y11W5vH0+ZdBkguJNIf8A4l+sCL7JenOrQhY4 pZHBW4BJ+zvt4e+ljklDg/dZyj/wsflwQeQeg7DvXwZoHiLWPhxeePLbxHrXjTxabf4pWvwE stSg8SamLq2vvCPwl8H+KNU1ma91HxBHqctpe6p4P8QQtA0lzcS3msx3stzNEZmH29ezMFja FTHEDHKgdg58l4xJsIYSfMAVBJJ3EH5j3/iz6TmMp1s54WwcbRc8Dj6qjqpfFW96z6e4r+jv sfoHDGFi6c5c3O5VOVNNcqShS0T3XxX02T+ZFJcJtd5nG4Y3bfu9Fxj3wR+NfH37Wk8Gr+EP D/hyFvMk1TxnYR+WPlYrbeHPFOpH95zsx9hBJCnIG3o2R9K6hqK26Sj5iBFG/JJ3EyODncGy cKBzngAdBgfF/wAbdc/tT4k/Dfw386ibUp9T2FUaA7PCHxEjDsm1AZNqhQ2SwAUYwOPwDhDK 3XzXLY1It0oVqbk+aEFyqnZ3nU9xataydrNdT7HG01RwlVN8qdOzctFFXjrrtZrS62dmfSV3 q0D7Z5ZlaSWO5+RQM5iaNMFRgjGAp56n1r+e34IfFk/BT9oH9pPxP8RPhb8cb668ZfEzxNff D9fCfwx1nXrTVbC31n4htG0jWaRoq3p8Q2At2lu42lhkMivFs8xv3Re+aQI88cql2FrGIxAA HbKPIBHJGq+a0Ikc4DMzbnJfcx4a88GeFvtiXE3hfw7cXiyPJHePoGjvcxzO+XlSeS3MySM/ zs6uGLfMSW5r9G4dxOGyTE5z7TCTl/aWRPB4m+Jw0tcTha1NJ8stHN1JKKd0+qfXwM5y+OJp YZLEReiWk4LeMP17P5aH50fsIfCL4iaZ438ffHX4oeGbzwhrnjm51DS7XRNUH9nX8ek2Xh74 daHby3OiBrlrN7i98H38sUj6hI01sIZxGsdwir9f/tFyWlp8MdetdpkHiGy8QaFGkbgtM2qa HrEYiR3kjSN5D8qyMwCHkkDJHui2SR7bZdtu7ZlVlt4dqr8wIHlvuBYqcgADk56nPzb+0wsk Xh7wHp73L7dZ+Iug6SVEK7DHcWGqW1wSBINqyNIrvtMbuSWL7gWr6OedYrO8+oVmqlGnUw3s MLT9tQ0WFVbFJRvKTslzybvttrcdPC4fDUKdJyi6lOMYN3Tbta+ys+l7adtzF1X9mb4DeD9E 1fxJ4gtNcstG0TS7vVtUurXV9XunFlY2s1xdSrCkU8kxESEhLWPc4YhBkrjxfTNP/Y91R0jn HjnRpZdP1PWlk1vTfGug2V3Y6Fa31/qL2NzrGmwR3DR2Gkai6ospMk1heRxndA6L9RftM6hJ a/AT4vT/AGh430nwR4isrrZDHHIiXNmbAXEKREw3IiYzSmKWSJ3WLYCDICPyH8NXN54y8QX1 l4a+KUvxTj0v4T/EyAaTc+DI/BkPh+afwr4xzq8V3qDqb+SF9bhtEskUrJJrzTtLElhNJF6+ T4zE4nBYurVxs8JWlj0uaWMwdFypxpy93mrOz1s7J3fLdK12eBicV7OorJSV1prfZavp8td9 Nz9BNS+G/wCytpXgbT/ipdTa7D4N1W7S00fVbjU9UeK+mE17pziC3tla6ZRLZ3P7xlWJVRSz BpIkfk9O8Hfsh63qkGg6fqGr3WoP45ufBHlJeeJt3/CR2VxYWV9ZZ+zYDRT6lYKW27QZlO0d D4xZ+O/CnxV+DPww/Zs8Kajdaj8QvDupNceKtJutLl03T9Dg8N2Hij/hJJzqU7R6bqPneJrz SYIU0u7uZbo3P24pHBBcKvl3hjxBpHww8Sab4t8fXb6TpVz+0f8AEjXre6FtNqTCAX/ww1O1 vJBpKXt75qW1rqEmxrZ5kKsAjTTJG/ZTU5P3s7d3s/7UyzfS1ru60a8vPUxqY18qfs3fpo3f a9rP+tPM+1PHPwh/Zu+G+pab4e16w8Zy61q5W6sNO8PnxD4g1KSBrbVJpbwWenWt1IIILTRd TeWQwNHEIAzr8wY8xNof7HFroia5bap4xkvLLWE0TUNFW38UXfijSNau49be3S/8NWmjy6pb G6sdC16dPOtHjW1UXDxxExPHyvjr9pb4Tv8AH/4c/FLU9Yu9S+H1p4L1DShM/h6/uTd65LH8 QbCOzi0i7s4rjzZRdmAXl1bw2qKzB7hIwHr5r+KbN/aPi344WuvzfDf4Z/Fr4i6Hqfg/ULbS IdWurHT/AA14b8d+Hrq+n8KabP5drJquo3tuNi+XdqNalu7gO8V8y8+V1sTzYGliMwxVCnVw rxU+XMsrvl9au6uHqe2dpqP7mCvC3M+dO7TRy4mtSrPl5G76aJ+Xdb77s+xbzQv2U9C0SXXt Y0L4reFrC2v9P0i2k8ReHvGunz6hr15aaneWFtp9tJp0kuoySw6XeM8dlHJtdIoyitcW6y9N 4N+HH7Meva2ngizsfHeia8lubzTvDPiiHxF4b1jU7WSDU7+W5sYdas7Y3UYXS7/bMkyWyPbe XIwYOD8Y+NPEl18VPh/4P8LeDfjhqHxE1a9+PPw4sLjUbrwCfDjeF21LRPFenJqRh1ue2i1e FLm4Sf7FBcfMYXUoiylz9c/CLwj4o8I/tA6tYfGPxY3jv4jXml+Hp/hl4qt9FsdNsIdAl0Tx fa6ppM1lp91b29hPaagmtTzT3emXb6hBqNrGtyyQiGzzxOZT/sbE4ulneKxOMqVVCSnjMHVd RUMZHD0vZxp0otRjTpwqtSbbUHJWhYwjRjeNNLlU7Sd9Nu2nd2/TU9vf9j/4Kahm3n0jxGsF yEvPtDeIZ/Mt7/YqeRMLd5QAtmrIQkEqeYykyk5YRR/sg/AR2S8fS/Eccwja5mKeI7iSWS4t zH9niSFHm2xMvmiZWSOUSCJVdCZFP0pHPcpFseRhLGzxzOscChp4pGimZdjD5S6sqHC/IFG1 VwopRw3ZS4mVtqW0Mt1P+7gB+zxZebZhuXIwVAKkn+IHmvha+eZ5WlVjWxeJUufD+zrtwnBt Rrcs0oKUpKmrp8u3tFpZo9ihh8FShapKN5JaNq720208/wBevzpqn7LnwK0oTXOqQ31lYWaI r3V54mu7NrYXREbbvtLwIQzzRbWeNwPMXnkCsjTP2Yf2ddeujFojT6nhXZjY+NFuXLIFMpZY 7tyGBkUyAIoQsBhRgV4R/wAFL/EPizw/4A8DaD4c1nxNo2oeKfiB4B0m5ttA8R3+gaj4p07U Pi/8H9LvNCTX9N1K0u9Jlv8AT9Q1PR1v31Cx8mHVmIvIYUd4fg74dfGnxX+zj+1DEmvWnxX8 PeEYvgXa+KJfAev/ABPvfijDres63rGmeHn8QW8/iDxn4qtbD7VOk15FayzWxsUsp0hs7d71 Wn+/y7JeKM54e/thZvnkp1FOnlmW1MLWgsVKCVm3UwMV7K/u3dSmu0lueDXx+Hw2LdNJeyut bS0Ta8lZaa3taz9D9g5f2RvgSgQHRNTeT5hJ53ibVCQVIAwLW7UDPfeOcDb/ABVWuP2SvgBb wy3V5od7Ba28clxc3EvibXligt4VMs00ri8IWOONWd2PRVJ7V8S2n7Znxi+GEuneKvjPodlr HhD4kfDvWvHHgvTPDWu6Ne6h4UhsYvCerQ6frc7+BPDc17eTaR4rtka6hu9VjgutNvIw0wng uZvI5/2+Pitd/D34oav4n8P3+u+Crv4N+JfFMeqaPrnhrRpfDBi8E+M9ZFg89r4c0TxPLdXR ttHtYb/Sobn7NIPtBaMC5VvIp8Icc4mlHEujOam5JzeIwdH3qc3SlF062JjVi4Sg4PmiuZx5 o3i03vVzTKHUk3Vak+W/LGbWkY7NUpLpd6vX8P06j/ZN+AN8sU9h4flv7R2KieDxXr7oXUuj qCupp91uD8vB71tj9kX4IpFao3hS/WJVlaPb4o1nkl0ZgC+q7zyTndjnocYr8w9c/bI+L/hL xbqfwp8DpFoVn4B+A+t/HXXPEWta1Y69LdWOj+M9Ss9R0uK31bwV4h1G6vbu2ms7e1kn1E2s CJhIYRErH03w/wDtffHr4zjwLoPw5vtO8KajY/D9fiH4q1/W59Eu7XxIqWvg1odIs9PHgG/b T01mXxFeXktzFDZR6YlrHbLYTCaOO0x/1T4yVWnCdOrTvNJuGLwEpPRuzUK85JXW/KldJNq9 jL+08qvH2VX3m/tqSVt7punDXbrtf1X3hB+yT8CzCko8I6msyb9hbxNrbId0aBsrFqzuQQSB hcjqcAEiI/sqfAyDM3/CHzy3CjKxyeJfFK55wPlXWIu3T5hke9YX7GHxp8VftB/Anwv8T/EE gF9r1ro+o+SkemwtFFrfgzwtr62b/wBmaTolr/ok+rzEXMdmHuS7I8cEMUMY+nmiut+bhCEI GHEoY9eDlSr9QR1H5Yr5rE4zPsFj8Zh67ryeCinJOrR091y1tNr7PS1u+p3Qhh60VOEk72tZ +XXSz29X6M+O7/8AZr+EUU/iCH/hDXXy5bO5RP8AhI/EfyrLICoy2uFiAl0OGJPqxIyfUrb9 mX4OpaW8qeEplaW0tbliPEXiJgPPiZsn/icMFwUJA9M/exx6BqlqkerzpJ8yaxbpEhOWKtYx 2MxLksXyREwBBB5wSQSD0Xh7UI77RyhknEtoqabJnLki0tYxu3NIgxumbbgs33iW5Fepicfn FXCwar4lc0KcuX2FZ6PkejULO2nWz363OeEaVNyu4p3d380/S2lv+Dt5B/woP4MQxgN4cQsh zk+I/EA287gx/wCJygAXqSRtA5PFaNr8E/g+iL5Phu3kJGOPEXiF8jk5/d657delb/iHR3s7 CTVINRu3tVeJZ1LTqwj3bJiFe8fjYAcINxydvzZzyEU1xrLwWXh++u7WS3jL3dw9xcxKVCKq hR5ruSZdw4C4GSeCBSpYfN8ThPaurjJ+zfKmqFRWTinrzUrt6pvbta5x1qqdWHs7NWd7Xdnd bvTovuOqj+D/AMMlAWHw15LsDhE1fxAyt90KxM2qytkk4OGC4A4zknF8RfC/wZaafHfW+hES 6fJHIdmpatLJ5TXduZyI2v2V8QGU9AVGWBBAI9YtWjjtrVDOJpI4ollnczh2kWNBJ8zRu7As A5Yt8xJJGRkpqclld201nGFkmuYJYkUCU5Z1IB/erHH8oIbLOuMZUlgBXnUFnNPE0pOePcIV acppUajvBTjKS0pdov7+zOqUKMqUuZpTUJNa68yXTR77fOx4dZ+CNFtbhPEGlaX5ttc2ywy2 8l1qDSiYhUlxEblHUB4VOfPIAzgEHA9E+HVvoBtZNNuLZbK8tpGSK3uri4gCoL67SKNS90zP tje3GXZmKkMzMSSc7QJ3tNRu9CvRMqQSXM0R2W80YRjE6KqicsuBI4AJwCCcDIqvq0K6dqke oNLdWkGpThI5LeGFDG5MDFtsF6rgKQ7gqqnIyAGIr2cVDH4uFovGwe+tGa3s+tG+muyfzOG8 I7tbL59rux9A2lnFH++tI1ji/eJcMPtEyMxjKwBWXz9pDSYbcyAkjqAcZesC00rWtG1u7jX7 Jb2vlXkhmVAJJ4dTjjGyWeBgS01v3Xr0POeFsb7xJo4aQ6nNq2mxHzWiR0t2BCnzPNS4AM+5 ypiDvII/KO3y9wzW1vxxoWu6ZLpd7Je2N8s8ZdpLNLlAIHB2hoJ1BBBIXGAMcjpXytfh7N51 qtWGEzGu5WftY4SvNTtGKspRo8rUWuV9LxaeqY5Tg4J3TXVX7NbX6dbX0ufUljfBiwjlV02g 5jMfQHAOXI4OTz+eK0Y57eImVP3qqSzOzozK54ZFEUiJgAggMC2SeSMY8P0L4neGX0nTXe8l tZ5rKKKYnTZJmExVVLM6QHedys+4dcnJyeelX4j+EbeGOGfX41mVDljol8qSFI0BaQQafIGb crEu6u7EjOcA18tmWVcR0nNwyrMai1TVTA4hRs1FNt8kFdbr3ld6WZrh/ZyupNJcje+unp12 a013OQ+K5K3MM8DSDzXsY0WUw+UWP2lBu25lHK5G1sbgM/KWB67SZZJPCXh2FSftaxxGVYQp AB83GBIGHRk7de+Ovh/xV+KPgOW0tJh4hhLQXNq8zpp3iCMqiJfsNqDR40YqWjbjBz8wyy1b 0v8AaG+D+kaB4aXUPF0MLmFI5Wk0HxZKxZWQnLW/h64Ziq5IOTxwDnivpK2VZrLh/ByeT4j2 l6bt9VrrXkhra91u9bp30OOlLDRxFueLs+ru/s7WV+q+f4fTtvK8bvchTbMkjASzLjzM8CQK TIh3b/4VVckYQDFXo7S3knEs0txJI8ci4wkcYVUf5gxhiG4KpGN56k7eMj5puv2rPgFbAmbx 6piT5ju8NeOZEKq33gh8MsdvAIBQNwPlBGKydS/be/Zs02xmuJPHzXTxIxjhg8K+O4nRmDAO XfwtEjJgsjRlmBMgJQgEj4yXCOcUaiqVOGMbh1OSn7X6liaKalZ8ylVvGz+JNaWs1od1V0Lf u5Jt9Frbbb3Vd79W+259Atd2t142trVZH+z6VY3glG6EFWktdMhTLZYtl9w7evQcdxNfWhhM 93d/ZyAzGaTy44yNpcgEoQT95jgfdHBxxX5z2f7cvwITUtb1C08QXks2olFtph4Z1uRkiSdW fBvNFQoHjjVSAiMdoBGAK07b9sb4LauUGpeOtcv7eFlh+yWHhXXLQOWKglytvpSNuTfENzOf n5KgZr05ZDjKv1WnKlXoxXPzRnUoJ3fJayV+W1re91trc5I1akZO0HKLs9E3bReel/uPsLxb rujXWhXmlaNfNd6vrTwaVaw+W8lrJJPJHKSbiOIIkyxQNhDLkAAmBtwY09H0CPw/pdlq+vXI h+xWMUDjcym3ubhoYCsK/ZYlmyodCHecKmXADAOPkqH9rH4O3firTLbR9K8Ty6bpLxamfL0e xSW51GJZQFDXmqwzgiO7hUGWdoAIh8hONvSeLv2nvDfi+zHhnwv4b8etfzXK314zW3hIpDaQ Bp4xAmpeMIIWJeaFCkctuypliH2CM+j/AKu4nCqHspSjFte0nOth4wgm480pzk4QhGC1c5tR jFXk0kNypyhKM42lKLjs73aST95eenbtZM2/EkcWj/Ef4K65eCRLnxNr3idbV5iqxyatrOvf Cm8srMIPKVGeSK4Owl9qggyMACPO/wBvvVPGvh7Rfhdc+C7pf7S03xDJqc0Fvb6dqMuoyWfi 34dXdtpthBdW8/2iW9jhuLJI4xDI9xd+Wl1BIsc1tifG74vXV/4g/ZxfSvhr4505tF+KWi27 m9uPhyft01ze+GzH9l8jx3f/AGXzDpnzM/lbMx5PyV6l8RPGD+NrXw3e+K/2efFF3F4c1WDW Ldbjxh4DMkstjrOi6qlqPsXjKIRxzXGj2ccm9poHSU+dDJF58Mv0eEp4qeL4IzPFU8JiaEYZ 9TrYWOY5fJ1q0aOaZfQgorFub/2dQxito5RupW/dmKXs4e702Wl9LLbQ/O7/AIXp8Qdc/aW+ G3xN8OR6i0Wg/DLTvhhf6VJoGnCFviDpfhbW77xpZXMTiS5S90/UZddSWCLV7WG3ex8pLEJE fN7HW/DnwX8E/CL4I/GrwB4stH+N+o+IPDmreIUTXItQbU/FN/BfeJtU0dPC19blLc/8JhpN vZC2trOwa3MYsHu4zcK0v0Fomj6ONcF54X/ZNuraZvGfiT4gQyXnxI8LW7Nq/iSx1qw1WXC+ IdSURyRa7ehbR8WCuTNBY20yW8kfOj9lfxPfaqniLT/gHZ6bDb6kniGy0S++LMWoeG9BvVuP t32jRtAk1K70K1mS686aOOy0HT4Io5Z7WELbzPFL+g1M1ymlDLoVHhsnpYOHPPnzLLqbrezh SpVaDhKrKpyzlJVKrUVadOlaUW+WXHGVSdSUuflWyV0tUlf5Na+q8z518O+BvgloXwb+KfjD UdU07S/jl4N8d2up+DLS+8Syx+Mb7V7PQvhrqHh23sfBH2l7DWIrm6MdqkB0B5rmGadnfi3u o/JvC2seLr+58U3epv8As96XquteK9L1/VL34seL/E/gzxVHLqfw18H3TsNKsvFeh6HBZXEk kQjX+yGuEupb+23obZYrb9JtY+BNnHf6rr17+zL4Lm8bTy21613e/FvUbqI39tY2dhpmojQn 0G68KtNaWdnZCORkSZ30+3mmAuLe2lrkp/2fn8W+KI2v/gN8KH1r+yLK51Z9V8WNNbXH2eyg srdZrWDwLd2JuLa0bTrWN4oJFEdmm2YYq8PnWBVTFvCYrDY2niYKtGtDHYTEyw9KTVNUI0KF T2zpJwdSEvZyjz1Jpza0jNWFacrKXNa0uW6e1vPo/S5S/Zw+Nfwp+HHxt/aY07xv408LaBBr 3iTwhqOgTHVopNO1u11N/FOszSaDdG6nmv7eSDXdOntXYu7Q3dviRy2W/VQasLgRXCSQuZoS LB4sMs1vLGfKkHzMGDJLuDdwc44r86L79lzX9Y1OC9T4R/AG11cxWzNczy2eqahHb2kNlbaW oku/hSsE8mjWcdpZwRSXaxTKkaGZYkLr6+3gr9rH7NJ9k+IXgXS47PZBZ7bHTbxbOCJlWPaJ Ph+rHbFiLYFbhASxzx+OcQ5bk1fHVMTDMuXESk24TjKME3y31dBd91N+up7mExVVU1Ss9Eo7 bWtbRP5/p3/Gv9qDxT4huv2lf2jPD39n/GHWvEXhb4f6V4r8AP8ADnw14EvdB0rW7HwH8Ppt Mn8T33iexUvpdrqN9ql5rESyTy+Rc6fFal3JtV+9v2Vf2yPAWh/s2fB4/FHxbdaj47u4dY8N a9ZaV4K8R6vqFtrvhbxVrnh2fR9di8GaDLomlanaNaJpk0du9pb3V5a372bzLbTzR+PfFn/g l38fPiz8UfFHxcvP2r7vwJe+LvCEPhDxZp3guz8XabFqWn21ra2Ecs03hrxP4ItoGu4tP0W0 uptP0qO+8iyhElzdL5qV678LP+CfXjH4c+C/D/hHw38XPBeoWehma41C91v4R6L4q1W+1uXU 77UtT1+51vxtLrOvNquqaxqGsapf6idTu9Qu729e4urieWKBx+i4zNfDnM+EcqwNfHYSWa4C OU08XTwHtadSFbA5fLCYmVTE16NfCLEVK0nOpHnUpO7jTUU7eRHCZhLEYiSp1eSeIrTg1KnZ xlJyTV3ezvs9T8z77w9oWmftV+DvDX7OPxssfGfjzTvGfxMi+O/iO7174fn4e6D4l1S21HRt H8H3d3rfhTw/qkWu22t6b45jbTvDem3Uqy6z4aju7ydLu1gt/Pv2N4PEHws/af8A2aLnTvDm o3fj3xJ4+1HwT8VPH1lqng/xBoWueEtc8JePLof2TpmmeI5Z7CS1tLLwZo0+oQeDdK+zXOk6 hLK8kc8uqah+jPh3/gjT4C8K+PLn4qaf8avFtl4s1vxYnxC1S9065+Kek2WseItZ1WbUW1nW 9N0/4zf2TrMt1qN1cTiLVNDuordi+LOGOZkHu3hL/gmX8N/Bvi23+JeleN/FMXiDT0kXTNTt tT+IWn2GkTC3W3fV9H0WH4rz6XpepRWq3Nn9u0/RLTUpRcXh+1bby4kuPpq/G3h+svp5ZWzH EYqjUyCpl+FnXy3Na2MrZhH6y6VOWIoZZHC141niKVOgqFNN1FU99ppRUcqx/wBZhO86NNOL nKcoWavHaz6Wbej376H6XR6hbwRxyy3NsjiGBZFuri2juEzEoiE9ukqPCxjHy74oxKuJI/MQ 7zBceLvDFqA2pa/oVtn7vnanbwfdyTlpLhUULzlnYIuCWYAE14DpXwD8MwGCTxN8QPidrMVx FG7XDfFD4y6bJfi1gaCWQrpvxDkeDFxNaSW8bMoW2jaMeSGe3Nm7+EfwQggvBqd14zuJbdFb zNR+JXxmvot1wl3st4Yn8XXyyO7Wc7ATxQW7KNssqB9rfz9W4fyvGYib9tnMalKlTUYU8kze fNRqY2boTio5TNyVSrU+rqz1nBwSUk7fWUYUaNOC+vUuZWckqkLtrlvts9L2792em3fxT+Gd qZYLz4g+CLdQgcpN4q0ONtpGSf8AkIZwdowc1z7fHX4LWqsi/FX4d2sqO6Oz+MNCZjtdhgxn UJiOB18pRg5zyDXjXiLSv2LfC92LbWrGCC/8mWT7JrF98X9dubqAQq6osjRa1ZQlRJIVDXq5 DxlirxqsXGeIPE37A3gm00XXPEmj+DtN0zxELx9JnuvBHjnxDJenTfKtr9Wibw1fywNBcXsI L3QiM+Q8RkEeU9GHCNepUrUY5fxa5Uox9nClw9nNCVaXJD2kUsTk2rpTcqckrWcGnsyquKpe 1X76F7r7S30b8v8Ag37u/wBE3P7R/wAFEXyI/ij4TvZDkkxXwu4l4KEhtOiZ8lsbCcxlSTnJ TNVP2lPg5aW7wReN9MnuHyUFnp2v3YJPCj93p7jcfm49jnocfJOrftHf8E6/BnhG08f6sfBV p4V/4SBfD8msR/BTxHceZqEOmf20LE6bD4Nl1BvP06Ke6+0vZiAeSLeSfznSI+n/AAF+NX7E n7R9vql38GNC8G+IY9Ov1sbiST4aaroMulXUdjJqExdfEPhTSjeR3djby+QIWnS2lgmYLBNO rT9f+q2GoUq+Jr5LxtikqsHDFOhClRlh8L71d2qZRCXLSjJc8m0ktjT61FVbQmp+7DVXt9m2 3Zf5eZ63/wANHfDGSbNvqGr3pKDe2n+C/G95vfALsnk6NIrLuwSUGwAgjAIqwP2h/BLKostL +Jd0ACJPsnwu8b4xnCfNeaBEG3fNsMTHvvx8lem2XgXwHbwo1l4O8KQq67onh8OaTCxikAZT kWauMptBBw2AARWwNA0GxiV10XSY9xCqItNs06BmBIWED5cDGemTjAJz4VHHcP0pVqawGP8A bfWJ1YUsTUouboOMIQk4QoQnJc8KmqXxRbaSTOuEK1epBpNJrSXrFvdvr53sn0PEJ/jnpcjL JYfD74y3hXaQ8Xwx8Qqd6tlQGuYbeBCCD80xWIYzIwUE1K3xo1G6hU23wQ+O2oOcfvR4O0Sy jbGckHUfFemKMA8BlUtuwoYg49yFraQj7JHBFE0oLq0caoM8nBKhTzsI64+Y54JzbiD26BPN dVHG1WbGexwGx0FavMcpekcsrP0i/Jbcl/6vfVnT9Vr/AM8tt215f15W1sfO83xO+KVwwGk/ AL4khTt8s6svw4tiMqozIg+KsUiYk7NGpMQ3AHIJy7vxf+1XcukWnfCrwvZCQgJH4g1jwwqA bw26aPSvidPenZGMfuFbbOo8weSHNfTf2go7SiSQhsYG5+iDHc45wO1KhLOLlh5jpnaGOWAc EHDHIH3iT+nNVUzmUIRVHIsglTUbU5V1VVeULR5ZV7ZnTXtmrOolTp++5e5C7itMPTak0/iV 072u2tHr/XmrnyleP+2/dTFdO0n4A6OjoBnU77X5dhAIcsbLWdU4fgrtDEAHIU4BqQ+GP25b 2Tzbrxr8AdKCENt0qz8XyOuG2lEfU/B+o28oRUyjpJJG74YSSQsCfswbntnk8kFhu5YoTwfU g/T2zT7GSEK4mLsdrfLlyqHc2VHzYwMhRgAYHAA4ripcQZgqklRyvI8I2rOWHpYmo5q6tGSh mNWyW+sVq927nbCnzSemqS/FrT89l00Pl23+HP7RGpQsviT4sWyvhFVdD0vw0kbBwDOGbUPh c74DBfJKsDtz5hJxVk/s4arqr48QfELxXeLIpSdLb/hCofMhClfLUR/D2CTcY2df3ZVySNp3 YNfTDXMaSIgeYl2IB3PtTGMgqXOR9AfpWgS0aGRpmYgFg8YKlcZAbqhO0jJX+Lpg1vU4hzz3 XGllsEmm6n1XG+5t793i/s2Ur7HoU6DsrLT/AIK/4Pmm+90fJjfsZ/CaecXOp3Xi++eY75Li 81/SLONZoIzbyEx2ul6fICWfywvkkAqCVTOW5v8AZF8FWXwy1r44/DuwiltLbTfiAPE9jBcz S3E0ml6pd63odjd/aJ0Rpkmj8KlBhAhaJ5ASZCF+01R7hk3ss0AVmZXRVJMhVs8AnLSAs5zy wyc5zXgej21pov7SOv6fBHsg8WfCTQtXURz3MZuNR8L+PPEsF79oI3sXuE8bWO2SSRI5Nkvm I5QMndl2cZjnWUcQZZWzjB4pupHEyjSjVTcVUlNPWcklzQ7N2SW45UqVOom3HdNJfK2+u2l9 NX00PoaEP5rIUOCww2CeAgY8g49eoNPVFSWU/wATcYOeeQfbnHP/ANaqitOmxgzBsMWTdkp1 Ay7cvvHTAO3GOKcZWG13ySS2Rnk9QOR7V8TzqrSoyUlNToQpXj8L9nUlUtrrp1d2um53JKb5 YtNezXw3eqdra26Lv5o+a/iDbmDxG2IyBdWtzctyTkvfz88ngEE8Dp2rzV0DEsrAgKoGT6Mx Pb39a9p+MFoyXujXsIEYkaaBynyO0Zl80RuQQWRQT8pyuScdTXjUtu0ZdWbGWBXaTjG1MgYI xzk445JPUmv7i8NMcsbwdl0k0/ZRlh21feFWej81Z36aN+nwOYR9liqkZO15dbfyp/dt5mZi Qzsqsp5OAcY6eoH17/Wvt39jh2Y/EdGRl8s+EQMjHX/hKOnJJxgZzXxSwRDwcN/eAOfQ5bOT 37mvtz9j1g3/AAsQhNp/4pEk5BLZ/wCEn5P/ANf1r9Y4elfNsIu3t/uWGqniZprl+IdltS7X 1r0vPb07n2tRRRX6WfHHgmu/Db4ba5rMfiDxX4A8GeJ9Y06WNLPV9Z8KaDqmp6WILqa9gm02 /wBSsbu6sZYLoz3MskU6bLh7WZNkiu796mg6RNcQXs2nWMl/ZRTWsGrXcFq2r2dtMkpkjiv2 tWmSGUXdzGqI8EYWWZWWUSSbvy08Nf8ABRbwoyeGtbvvBPjPRvhx4u8fWHgCXxrqnhSKPTJv E+siwu4YrNbXxld6qllc6FLdasNQfRXtIre2UGSO5ItJ97w3/wAFKvh54n+Kvg3wT4Tgn17w L4t8R6b4W0/VYrTRH8Rrqd4LLz7q50WPxtB4gs9Ji1PVrWCLULjwkIpYbDWbiL7TaadPdD5m nKnLLHOy+uKFSTl191tq8PgVopJNQ83tc9yo+aEWm1O+7b11WqitE+3dO1+h+iHiyG00/QNR WKx04pLPaXMgEUSi7fzrW1F3IyxAXN86QxrKzICYo2cTERLCfnbUdTVV3HeT8wZWcY3bRgg5 4HBwpUnBA3cHdw2nftGeLfif4y8f+HtH8D6lp3wr8J+LfEfg+58dapp1hYw33ijwlfWtpdWN lKfFt7ezo0zrGsjeHLRJGtbr5oQg3y6pdQvGx88Aln5OApBVs4JXHHH0r+IfpCxljvEDL6al z0ct4fw0aMI2SpV8TiMd9Zu4pOTnFwVqjkoNe5GO7/T+D8NKjlFStNL2ksbJRbbbUVQwzWjV tG3313eitl+IdRaRZm3DfJEkbhSQESNlbzNvmMTlZHyCVH7snfhiE+A/ixpOteMv2gPBWhaF 4kHhu9i8LtfrqRsbvUysFvaeMbaQfZbPXNFmHnmYR+YL1UQcMJSwSvtK+bMczg+aJrd4cxje AFWQO7bQNqKsxJc/KojcnARjXyFZiS9/a0QRo8i6J8IJg7IhKxTyeIpAiyMAQWe11WKVFYru jmilAKlWb4zg6lLBTq46KSqYWMqkJOMZqPK6cU+Sop056SaSnFq/mfQZvGNSlRoyV4V7QqRu 4ucGr8qcWpR1itYOLXR6sut8Nfi55dtn4zRDfKsK58J+Jj5bhinm/wDJUBnlS+0bDzjfn5jW f4Z/FOAYb4zI0mPlB8K+IhyOD1+Jxbr1wO1fSVxGUCqRtK3MLANwdpWRmJHcAlckcLkAnkVh 3kmHwySGRt20BG4JJABA9G6+2euK9qGeZjUxGIl7TD2qRpRmvqGX6xocypJf7Lpy80tU05J3 nzNK3lSwNCUYKdOTUEuX95VsrJW1U1fZb7vc8Mi+HPxYmEcE3xlgYyyNgHwp4kLqFjdw25/i gcrmMrs8sDLbvM4Knwn43+BPiQt98KdPuvijb6wb3x7paW0J8Ma9GLGdZrWFLho5PiHqH2kL 9qAMcaWTtnaLiPfivuayiuoWNzIqF0LbXLKFVWVY9rfMi7ssxAPzYIPTAr5++IjvqHxL+F2n yJtey1GbVpkBVJYja6n4KxJtZ2OAt6WCumxtyk8YB+gyHMcXXzOjWqzoznCniVhHHCYOKpVn hqntJclPDwjNOg5w5ZxlFcykoqa5ly4/Dwo+wlCNlVV5XlN31Wj5pPoltbp5EWq/Djx/ZafP q+ufHrSLDS0ZJLmfV9B1q0so7V5od6Xb3nxQFu8JE6x5knhjLSbSvzANm6R4G8S3R87wl+0D oUsK5Vr3wppGoT6VA4aPfNd3GmfFEIscLtB56lkMc32aQyZCIc79rltKufAWm+Fta+xx6f4k 8V/D3SJ4b2W8tzPp0vxQ8C22tRm6s5UNu66bcMHlEkckDMsiNGcNXyV45T4e/An45za18FbW 3lgt/hVqkOq6Po2oX/jOK/8AEWrR6zaaBpcMl3qeozjVta8Qf8IJpkGlxataTSi+tzHBCl+b mXryr+3cZgY16eJhGNd4ipBxwGXyXNQxE8O+dTwnLCF4SvOOq0VrNo8XFVsvw1f38PKopU7K KnU0k3F81/ap9Grd3qrn2M/gLxcl5e3KfHzQjqcLImrXcGj6nGytINiXmoXQ+J73CTXDKI43 ueXe7ljEjl8vzcWlS372tp/w0t4Mv7u4PkWthZRtdXQS9MEazJF/wtR5DPLJHHDujhxJII1B ZgqV8x/s3WV0vxd14ePPBnjLQbz49eHNd8VX1r4p8P6t4dsb/X9E1nRPEdlpfh+8Is482Gk6 5q9zd2kOoahIYrBDNdu0TtdaXwz+HPw7N7+154sg8OKo+Gs3iGx8M3q6rrZi0ifwlN4/1Jhd JJq7RX7W/l6NK4nF2ZVgcMgWV/P9KrSzPBzqYepi4yrQwmAxSrxwGVvDOWMpudSk6n1aNpUO VQkvZ3Umk27XOOpi6FS3ssJOK0tbmeja6uba0+a7n0JBpct9dR2lj+1D4TvL+e6jFnpdq7Sa zdyiJTstLKH4qTTTKyLIRHEjtKVddyBmZN/W/h74zs9KmvPEPx1isNKdLUR3Wtabqun2lqsk kJjjhnvviK9tbvduIDJGrEXTorqVKIp+Kf2OvBT6UPhpa6j4D+Hn9n2mraveSa9beONRfxLB LHqWrzwLFoj/ABHUSbLgRIFbwrLvtm80tIp8+vqv44R+FfFPxa+GXhD4kC2sPhwtt471W1W7 1E6HDqeuaVovhy0022i1o30EjTW0GrazcJZLfWzXUFvPMwulsyo5sW85y7Mf7PWIoYig2pYq pTwWCc5Kn+9f1JrCJ15VeSNKnSlKnB1JWsrtvnpqm48zjdrXqu3n6X/pGtY+Frq50iTWbT9p TTn0OyuMzarGskmlSTw2wuo4r2/i+Jps5WNmJblC8kTrbNczLG0UzNHY0Xwxq/iK4lt/Dv7S GmeI57RoYbuTQ47q/nsmnWSe3VBY/E29eyE0ZkabzWJlgjlkRdqsB8DfHvSvCFhfeMPDvwbb RtV8H+IvFXhTS9SiGrX2raV/wsC9m+LFjLoA1n7bJdR6h/Zc1istnb6lJDBbSRXZkSS4inm/ Qz4F+A/EHhe28RXfibwBpHgnWJ76EabHomo61qZvLeLTDHHLPBqHibxMIpEubmeELi13QyCV o3CpMrzGlXwOBnmuJzOhTVWvRWEw0cDlkMSozpqjUlicK8LTpUZQbaio86lHlrP94+ZZ0n7W reWvs01HRRtez+yl173evQq3/wAP9atbTUtQ1f8AaVGhabpd8unanq+oz3em6Paaky2riwlv bn4gpbxX7fa4Flt7iaG4a4aX91ym7Gs/DF3deHk8V2f7S11caFCJr2DUnu5Y7J0sGvCTczxf ES6szG4s7h3hS9w0cMx+0IInI+VviLb6b4htfG2kjW/D+n+Lx+0d4z1HT7Px/fz+GfA2o2th o2taJd2d14hij09YNXiaLUr22sP7f0+aZ9NGUlib7Fdec3tv4B1fwnqVhHcaV4F8ezfEnTbv Xk1fVL1/hPrviRJvHsWlWnh3xhDd+KIjp91LeTT3Lz+J7EwWlzeNPd2cmnyx6f1YfLsdiMNl tf8At7D1aGKajGh/ZuSxnRjVhGbU5xwKnpyRim6knG1k1d356lf95U57y9ndxe1rtdmk7ba9 j334o/su+CP2m/A8UWs/tP8AiG50HTdWsBaarpmoaRPq2ja2niDw7qNnNb3l14t1+z0q+bU9 G0N9LliJu2uY0kiAuEtDFxPw8/4J4fC74beJLxT8cfGnjvxXrPh4n7Z8QP8AhHdf1u58OS3m mNBZ2T/arfUrjS4LnRob2yPmPYRqbkpB5irOmZY6tLDofiy413TvDWj63D8TvghJ8Rtc8I6r LrvgOHRLXxx4JuNFubXX38QeJbO1utP0s6hJrsb3kBtA1rNPAscsUr9d4r+KfhLw9+0VpnxM 07VItf8AC3gr4E6Loj654daDXLJNYv8AXEthpjy2s/2eXUEsfEkNzPZmSKeCCVLh4gifNE8R n9LEUsAs9rUcJQqKVLkw+X06dOV1qnGhG61vZ3VlqtDKdHBVoOdXCuU7L3uerFJ2V9I1UrfI 5/4Yf8E9fhR8M9S8baro/wC0L438YynQrzwXqZ8T3XhvXdN8DaF5pTUrXQntb6zbw9G7aDar qcdw8dmZNDthPZE6fGLe54c/4J5fDPw54cvdCm/aD+Iniqx+IukWnhjR38Rar4f1pF0G/tJt Ij03SGd4oYrW5svETRvaWsOo2c6TwxrbPC5juOE+HUmu/Dmz+NGh/Ejwd4o8EP8AFH4SeIPE EDeIrbTYIfEPj+fSkvfElrocljqt3KsUPiDx3qqrp7pHJ5N1Zx2iypatt5+SD4j/AA11P4Pf CLWLG4uNUhivtW+Es9jYR39pf6VpWkaND4f0vUNXhhg099Y0x/CdlcXVtdJA102p2iC4v/tq W1t7lVcRTlWqPiZVMHamqTpYbKYtvkg5u0MJFN+05ovV3ababuzlhDL1FRlg3freVV7tNO7q drdeiXp6zqH7IPwA1j4k6zb33x11qLxd468D3Pwt1V7G/wDBVvqr+GdZMepS2Txzahc6mC/k RXH2K5kvtPuLfypmsv3qvD8u/HL9kDwUdd8KeD/An7R3hHT7P4cR6j4Vhs/FF1pMPiW6KJ4b sxZalcaN4iji1LSbq70Sc6r4aTSNI/tNW0mP+0LSXT3a6+xfhKv7Pdr8A/C+h312L7xC+vXW ox+FrXVdSm8bR+LLLxVe6hoGoN4VtruLV4LWytLDSdTvHvNNTSDoMU9/cRyiZZZfOvh14m8U afrviCz0/wCIX7P2g6Hf/EHxVANG+Ivi+bQvGcNm3j3xGq2r2CXVpFBqcsE8z21vcje0Mlk8 yhzMa4crzjNMrxOIziGY4qtHLadWnWw2JwWWunjYNxTxNFzhK7UorlUHSVpXtYyxGHwNZU4w wzi1Ui3JTqxdkmraVPh1Wn+R9QfCz9kO4+GPw88J+BbD41fEaaDRtH0vT1lsL57IXMukaFpG mPfLFDdBLZLuPTom2CK4aKJChuJlVdno8P7PV3OqPN8Z/iqYxFLNPu8RSoEijMqDY7PIsjmR U3I6xKkbSS72aIRS/ScU8ESs8ZuiBJaNcM626JA0E4kk8tnEeQQSIWcyoWVfMYLuJ/Lj4veI v2hYf24vgTpeo+JfDVp8ILjVtMm8MeGbWwsTrWo3UHgn4jXcmqajcXOiTaqgj8SWeuRrbwax aq1lYWT/ANnPDJNPc/E5TmGecSZhnM54mh7aOWYjMMVVngsqgqqwdOcqlBRhh+WM507K1OMH qmpRep7KeGwGHjJxurbc83bRP7U/1+7c+pte/Z0UWFncRfGP4mvdRvJPbxS+JxGWhJFu5eRY 5ZEVo7iKVHSJ1kAUHarqwyrb9nvTbC+eC6+MvxJgg1Wzi1qxe48UQRCSK5mkQ2yrIiI10qNA bhIWlWLdCC8olQr+U/xH8bfFbwt+0v4o8WeT4nvviBP8bvGHh7w/Lb6T4L1DwO/gGTwx8UZZ rOP7DEurLqv2LQPAEr/2lMuowX2naxby+Vi/tn6D/grPo3xP1vRfgJp/w01SbQ/FfhXxb4l8 bS2wtdFuZ9a8J+H7TQoJrK0t9Z0bXI5lm1K406OCJY9N1aZ5Agvol8xa+yw3DudVsVlGX1cy y9yzvB5hj8G/ZW9hh8vyrEYy0+TL7Jyr4GtSi17VOb5FNRScfCxGbYenSlN0Z773ls5JL/l5 a1ra9rH6h6x+zBZT6ha6YfjJ8QoLK9ZIWsL3xTFFfzzGO4ma3aw+zGHbPDEXDHzm8n96YJFG Kvv+zD4P0KxDS/EP4lW8IjMTzNrel2guJbe4igkWGZtOCSoJpHZWK7mjVWZI3Yqv4RzftMa3 8Wv20PAH7Y3hzxLY2PwltfDHinRdGj13TNP0Twzc674G+FfxH1l9a1iS9hfXItNt9U0a6sLm 4tvFtpZyPY/ZhZRymeaT6Y+H/wC2J+018c/itrngW0u/hz4oi1/wp4m8V/CqLRfDWsabZ+Ro HifwRDqE0Wsai1hb65psnh3XLl7W8srvXrW52Wt5FfiGe2nvbq8I8ZUcPl8fr2BqYfF5PgM1 r14U5QWHp42jTqwpy5MtjHnhGcVJSutfiluYUs2wc6HtKdFwknFSbcne6TulKpJLR9F5eZ+k un/Bbwddam+nvr/xPWOOV4Ib7Uda0toJ0huI4PMinOjbdkiypNHGgcFPMfzCMZ6S6+AXwnst QsNL1Tx9q1prOouyWGja14o8NQXd242iFl0+40hbqeJpGXZJDFIVZGZUdkCt8u/s8/tWR/tU avJB4Tm0zUfDngL4a6Jc+OLSPT57bUtD+Pd9cqniLwvd/ZtR1BtP/sewsoY77R9SltptJnuI ft8im4javDP2vtH+B2vftUeEtHvPEdhdftH6lJ8LtUj1PWfGWgaDoPw50HTfEqT6al9FNqWj aSLjxDomjeJp1g1DS/Fd3MZtO+yDTZbyxVvLrcN5os2xOVRrvC4+nChinClB4ihhcNGKlUqV Z1KNSq4VU05t06jgoP2f97epmFNU4VHByu1JxTs5JWUlpJavbTysfoBqvwL+DceqroaeLbaH xhHAs7aPPrXhYahdWQEh+2W1sNLTVJ7d4Ssyzm0ERjikO4ogar0Pwi+Ceow2el3U8cmvXMSv Lot3P4SuL+x3COKS+ltJNKW8FuJLu0dpWtYvkvLYNJumiaT8X/jPpXhbT9P8f+MNA1TQfEP7 WOifGWz8I+EtDs/Eun32saz4Ksvhzo1uNQ0PwZbaha2euaFd+ETqXiG08Rx6bItzZtJfxXgh ijt4vpHU/h3448Jft86R44fWJPEXjLxr4X1nxBLbanHp50nTru0179n+90a30+00LQNEvIn8 rUbS3lttUn1CSf7M/lvI6TTzdmI4dzDDvB0a2dZe54ylKsmliYuKpqV4xX9mxvB+z96TXNG8 rNcqSwnmNFR9q8LNwSTaTns7WWk/NX1b+4/R7wR8O/2e7vVW8FahdeEG8Y21zHs0Oe88ENqk i3dodShA0qfTW1R1ks42ljAt1EiKzpmJTJXu9v8As9/B77Qpm8D+HZEhjVHuJfDHheSFm8pd pa5fRgMneAAUyWwAeQa/l0/ZQ13XtN/aq+BWpfE7wX4Yu/iZfePtaa0TR5/EkPjXwkE8IWFg 1/418Jt4psdM0awvtGFndeG7qbw/PBf2Flqt/N5ptnkH9ZfhnXotbsLG4W5je4CG3vbVlWJ0 ltYzCRvwLZFUJARm6DuCDg7wD8nxfkWdcPPCzp5g8U8yy6GMoSwc8RKjRlNQukp4ek2o66yg 1Ju+t7rbCYrD46EZU6UqSbklGUpXTjLkb+OXxO8ldvey7Hldp+z38GtO8Q3WmXngDwctteyi axuJPCfhUrG0k0MgtxFLo0UbbBqATdDKCRb8RLvxH1d3+zR8HLm7imbwJ4TgManMVt4V8LQq GYuSxB0OQs2eA5CFggGARkdjr2lXOp2Mbu8Yu7bdeWUhkSONpBCzRxZ2tG8m4wL5JG/KOpOV fO7oPiey13TWuhdWy3FgsNjqCySRQNBdrEm9ZI2mPl5mldAG25dWRV3KRXwOKq5vGjh68MTX qudGj9Yv7VpOcIKpzJ0+WLm+a1kuV6q1kehCNFS9nb3nFu/NJrSza36p7Wv+vi/i34F/DDwr 4fnvNM8G+FLn7M0LMs/hjw8Vdbmf7O4Jt9Njxt81WBORxgg5GOl0P4Z/DvVPD/hZG+H/AIKj ZrNrlmHhXQ5OUlhTZg2APzebkMTxtxg547nxpLYSeDtaje8tEdIYJJFe7gRlRL+1beymTcE+ 6NxG3J696peDdT0uPTvDSvqumpGunSpve/tVTP2qzwN5lAzgMfoGPauihmub/wCr9VV4V6uJ pV70WpVYctNewSThFRjKy9prKMnrrJ2VuOGHw8at5Rvq3fnmvylt3Wtnp2L9h8H/AIZQn7Qv gfwkj7wwVfDvh9QGwDhQNJUgAvgDJI9TU+u+E/BtpBDpOn+FfDUF7qV1a2xMWiaVHJDbtKbq SULBapKwxaYK7VT5tzN8uD0tx4h8L6XBcXFzr2ixoivcl31ewEYI5wWa5QDLBQFJByQM5Irk 9H8W+Dr/AFtfEur+KPDljHDbyW0ENzrum2dwJgnlLK1rJd+YYRHNO5lZvLAjZzxGa8R1c6xU PrFaeZOglrFrHON7R2ah8PRWk12sjohTow5nJddLyku2nxa9FrpuehaNoOm6ba2tnHY2FtDF ZQR+Zb2cEBeRUjZlAVEQAOZcrlmGOQDuNReKdfi8P2kcFvaWUs+rrJHamMKshJidEf5Crhi8 sWBGJiGPBJChuc1X4p/CvR0DXnxF8EDfM0kMQ8WaA0r+buk2rGL9HZkjnDOvVAGLZ2kn571f 44eB2umlbx58P1nhz/Zi3Pi3w5b7AZJWheRX1qLK744QWkJX5XBHDV2ZNk2Z4zGwxFeriJ5e qkFKlNYqm1BxfMvaKlCpq1G79rdW3V2iJ15Uv4VnGdrq0ZWs1bWSb2l31e70PoFpY/BuhPcy Spfa3ezFUi+0K1zC9w32WFljZI7tokjtEl2hkJaRtjBcGtLw1ZmPHiO+Nzd6lrMIP2byvLSG N2aQq7TNczsFiigC87d6AkBdgTxbwl8QfhBZ3kPijxR8WPhjJrq+bGtvD8RPCYiSBCsVuzw2 +qwgNlGY5nyyuhKkMoHok3x8+BUhkk/4W38PUYkCRR4v0KSBFyAqrJFezFsFVAIlkyc5JAOO LG/2lDD/AFeVHFzqSXJXsq95037s0rpKN481muR635la6qinWV6lNy7v4dEot/Day6+R5T+1 tcubf9n68NpLI0H7SPgG2kmmBk8mC7TUJXdW2AqqGy3FWkRH4JKbN1Uf2t/ivceDvhD4s1LQ LnUbHUY10a2M2nl520601LxJ4b0y8ulhstW0idLpLG+vriKM3lvFLshaWdYWmFedftcfF/4T +K/BHgiPwl420nXdQ8P/ABW8JeIprTQZJ9auo7aw0jxYs169tp9tfSNaQzvaxSyFUhWS5to2 dWuIg8Hjbxn8JPiZ8HPFvgbTfHVva+JNbt4HsL3+xfGdxFbX1rq1rf2X2ltN8Ja3AUB0qMst vp15ujkKyL5vmeR9Zwvga1Olw1i8bCsqWCzKo6MpKmnhoVXi4ylOnzxhUVp6quql+Zb30yxV oRap6bW1v/6U31Pnn4K6Pf8Ax40vxLpmh/Fn4q2fia78PWt1Fq/irQ5rbwvpVzb6r4Nv78aR NafEXWdQmne2urrTrRlksZJbS8vJJvLjElrc85o/xg+LHxF+Ffxp+IA8eTaLH4C8Ka5odr4R 8L+I/Es95BcabpHi/TtZ8Tsw1eBdPh1PU/AH9taC0dgjvaeI0kur+W4h+0XmrHJ8SdE0IeG9 Q+LEt1o0eiaR4esLPwl8LPH15qQg0ltLnsrzztX+A/kzh4dJK3DxSzPJHIk8VokJe4h9Z1/4 O/AwadJceD7D4yeH11fwPJ4H8bXkPwy+MFz/AG7o2n6JpPh62u4/7a+GetQafPZ2Ok3f2O4t YtGSZL559QtbiRYhY/fY2tRwmPq1Vifr6qZhPE4Oo8vyudOlSk6vtcPKlKmozUHOjZOnVjZX lJNRUvOpQlJc8vibabem1ui0/BdD5Pj8Z/EB9N8U2fw38W/G/W/AVn8P9e8QeJtT+LF7rT3t pqGj6X4z1Wwj0yTQdZvdGFvLcaNBHcHUJbeeNxA0MhfZ5XkNx4+eS18SeIPFfh39pDxpLb6B 4Buopfhhr5XR7KC48H/DixktJDqXh7xA1tctql5f6lPGtyqGPU7MsGuJZp7n9XtV8deE/Ffg DxJ4Gm8D/Hi7h8c6Nf6Lb/2f8KfFtpIdNuxdWeqOk+p6DAEMSPeyLcLFcrGUkHzPGsQl+D/h zwF8J5hf+HPhR+0jqGpXXhnTPDt+mp+CLg2LwWVh4cgjaMTR6LMJBB4d0xleOQeZmRzERJJ5 euHzzLKjeKjlspTxONivZVMPl2DU6SVFzhfDV4xjCSuoqlK6lzNKL946aVKUZqonok1d3d72 73St3Pm/Wrv4tfs5fC34Z/HzRPE83xBv/i74L8GeBfEFtqWu+JYNJ0DWNS8F6ZqGheLNP1a0 +3zalbW0PhnVX1OG9NhdajJeR3NnqenrDcpJ+mPwo+H0Xws8CaV4Xj1e+1htLstNuNX1PVp1 knv9Ss9J06xnu0Cwwn7PdzaUJxDcySTo0sm+9mZ8x/MMXgzwPN8NdN+E8PwE/aHl8FaVq11q 2kW8+naJayrJNc+IXsYYNRn8XWt7eWcFv4l1C3beZ7mNBaC9uDdqJZvZf+Fm+P5I7SCL4JfE VpYwIHSW28FRxyW6LEsQSVviLGrsuJ2cxyAgGMtw6bvzXO8RjM1hj4RwmGp/V8wlQjVvg4S+ r1aUXSXuS15a0oU3Jty0u5PW/p0ZQi05Wvpq/RW0v52emup8deLvjX48tP2uP2nPhBD4qu7V vDP7O2reOvDGnQ69rNtLp13D4P8AAc1ne6dpi6oCH/tq+u3Z9Ps9OlBuLq6i1H7WkkN1+an7 RP7VX7TOhfBr9l/xR8PvFOp6l8Rbr9pP4jeDvEWj654w8fwWvim10j4qeLNI8O6Or6JqF1ru y+t/DtjY3FrfW+tRolyI7GwmSGG2f7l/aP8A2Z/j/wDE34r6l8dfhr4c8YeA/iT4j8GJ8N/F E9/q/wAJDoWpeEb7TdQ0TUbE6Vq9z4zngmvLWfSEXUdJNrPFLZlori3f7Ylx5tN+wR471f4d fBLwPdeB5Y9V+FPxWX4y6nq03jbw0J9d8c3PifxB4u1e4EVnrk0XkS+IfFGsyWel/wBh+HbW S1mhhgDw26sv6Tw1Hh3A4LDPMMLl1LErJsuoYmE4Kdb+0MDhqGGxGI5HF0JyxFRVKicpWnfm 5InkYmOKnWqyw1WcE6k5aNveV9E1JJWttZJqystF86z/ALa3iD4v+CP2vPEvg/xp4l0R7j4U eGfHel+GG8ZXq6z8PdeF98W/F+u+DLq30vXpjoes+H9N03S9Jl0+3t7O9sby38u8jhgjtvK/ Tb9r/wAXalqP/BMP49eP9G1iXSNd0b4Z+Ldf0+WO7ng122HhjxPPePJb/ZL6O8QMlhPkwahb /wCjNKxuIRv2/JV9/wAE5NZ0rxX8a9cs/A3hvwYP2jdE8ReHPiNo8nxEuJdL1K016L4g2819 p39q+Itd1rRJ4z8TdeSGGDU4rhmg06CPS7q8geG+5iL/AIJk+M9JttQ0HxT4t8ONoeseFPEP hnWNI8QeOtB0oyaP4ls9SsdQeKex8M6RqKk2t7cvbz2t6ZFnDLGkrReSKzilwbj1keMyTF4S jhcp4nyrMIYfFUZRqwyjCYnD1sVgp+yhivapRpzm6tapOraryusopJGHjjYQqRrYifNUUVG6 Vrq97e6t7rbe+2h+dV38dvil8KfFP7J37XWh614z16Pw7+zJ4Vn8S+CoNR8RRW3i+TxJ8F/g V8PH1aO5s9YkWC/0vW9U/te4vr8a0zNfahZFobvUvtScR8I9D8X+NLj9r3x/rvxD8V3mm/tL /An4hfEjwPYm91Oa38HWm/xDrVpbaXbXmq3kD3MkHxf06Ga50i88qdNC0+OJo0SCWX9o9M/4 J+6h4f8ACXhCS91f4KaV4T8FeB7n4ceH9Z174j+J7bSE8Larq3g3ULWxvtahjWykuZp/h74a AupLmG9N9ZGzjdlvL+CSPwn+x94N0LTtB0XQfij+z8IPCXwul+EtrbWXxcvtUjtfAE8Gg2lz ZzT+RdzCN08M6ZHJqV9NHrUS26OskT3F00n6VT414Vhg81jg6fD2JnicNl+CwmK9njHLDYfB 5jTzPFUV7PByg6lSVTF8tWSnWi6kKcatOnCHs+L+y8wlUVSOIkrtPWT3uns47afcj5Y+Onwd +EPijwR+xP8AtBaz4T8Naxd+LPilDoPjG71PSfDF62sWA/aF8BfDu0t9b1e70W7lv7O20zUJ ILS11S8uoSrT6fEsNvK0de5ftp/DLwX4C8efsI694Jf9njwHoV/4R+OGk6dH8UfDOlR/D62T UvBvwz1mBPJ0nUvClmL0x6TfLZLBcgSXN286R7UmWT7Jl/ZrHg3wt4Q+Dfij45eD9E8F6Fda j4o8IeG4PFPh221EXOh63B8Rr3UrO817wIur6pb6V4k0201zUvNuryytrKCe2nUWPm2tO+Kv wz+D/ifwx4Kf45/tNQXfha1eez8DzReIvAFlb3Fzp9lHptzFo03hz4a2t7q40uxsksNWku2v Y7S4RfNkFxMssn5xgOKKMswo47DVJ0sNgszzrEyjCGKrOpgcVm2Mr4TD/wC0U5KboYavQoub lzt0m3VnJOcvbll8vZRqOq/aOz5uaS/8lta606W6H5O/tY6R4b1H4IfCzWn8YfBrxrJ8L/2q fAXjvVYf2ftKsNN8ODTLbwj4ou7i01+A+KPGLT6PO3h2ZHkuZ9JtzYSWiOxO94/ojxH4z8L/ ABb/AOCk/wCyd4u/Zm0hNN8KaFoOrWHxkvPh9pmnReE3tRY+PLjRE1DUfAF7eaa2sx6dNrYX /hKTDHEJ9OjtIjA13JJ93eCf2Kv2ZNa0GW88F/Erx14i8Jaq9m8t7onjDwBqsE0P2NpbR3u4 PCkn2YR6ZqLSzwNJDeql7ayGA5Vo+K0P4Z/sF2uuQ+HE+KWsaheanqOlac2pJqmq3vha51a8 liWGxi8caV4T/wCEIFy9reaTbC1XX1uY9QurexmjS+u4IJubF8QZHUwGIwlOrm8qmAeMwnJS w8p0MVQx0KcasqlWVdVIPDxg+WUYxnN1HeT5Vbow2FxdKrBznzUkk9k9bxbvLkT3v1/U/UO2 ntLe3WeTU4ARHGfKv7mKK4IkWMjzmaVszAN852Dc6sQF6CO88V+FrGUx3viTQFKhVVDq+nDM joj7WWW6QqF+6xAZgT93nFfmZP4R/YRh8Qaxoen+HfjH471Tw3qd5o+oz+E/CHxh8S6Oby0C tcRQ6z4d0FNJuzbx3ULmSzvGhdZYpIzLHJGz0ZdN/Ydg8S+KPB/h34H/ABn8Xa14Hk0+TxW/ h7wz8ZdZXSLjU7R9R0z7ZJZ65DBbsYvtkckMtvFIJ7O4hMbPbT4/KqnC9DEV3KlVzzENU4qN OhluG+s1sLUqN0YR9rKlCMaFacqrq+1hUqRhKMp1NKb+jeZU6FLkptqfLBJ6PZxT3bWyfTRO /Q/SGf4j/Du2jMl18QfBC7lDLIvinQy0Y3+WBIJNQj2ndhhh+UcHrwecu/jf8JLMSLL8SfA0 pjdU2Dxh4ZWQsQpYtG2rttVSXAbLE7VyqliE+Dbvxz+yZoXhSH4geEPgt8VPGPgRmSGfxXoG m+Mb7SdL1abV10CHS9UuL7xxpLWN29/c2BEVxFt+z6ha3BmEMybfQfDnxC+CNvc+Borz4ZeO vC138QtMnv8AQrPUIL+KafR5Ydf1fTbhhN4z1JImvNM8OyXUeZZTJCokVVEwYdUOD8K4KMaf FTxEkqMaf1HKuaOIh7s24/2h/NTno017y91aJa/2l+75uZuVlrZa3Sfe2i8rXXlc+kLn9o74 NQXLxw+NNGvkjEzNJaa74VlhfyGjUiB08QsJQ5ZgxIj2OuzD5JXJuv2r/hba73ij1zVNi/LD ov8AwjupTT7mKZhRfEMW8RAieUgHbbBpeAMV4n8NPjzqHjOPRdS0T4V39p4L8SWcU+janeX3 huK/azW7trNFfTR8VL3V4rlo555ZIJtJaYSwCNUR2jt58zW/2vV8R6R8OPD3ws8LWuu/FH4q Wc82gaHqdheJpVuLPTdB1m7u9Snj8YWi2EC6be6zNBI9/cRTTaWY0WQROt10UOE8NWnODw+Y v2VH2tSlW+qQrq0eZwqRjjfcqppqcVJWmmk3YdPGXSlF2lJKTlZWu1F3s7rV9Nk/LRexL+2D 4aWCQW/w3+Ld5dJKY3tbbw5YTRnMCyxeVKmttJI0kj28RQ2qbWlYq0jIiTUP+Gv72X7V/Zv7 PXxtvXtYvOkVvC80XmxGMvmA26XpkZiAqqyorbgd4J2nKX44fF3wr8Gfih4w+LHgCHw1458G 6Nqt3p9/b6aZvB2uXM66HaeGLOwu7TxXqMF/Pe6nrUOmuiXdlGdQsrqzeaKWFln474R/tFfE 34+fD690jwbdeEPD/wAa9DtrLUvEWj+JdNvdPtNP0bWU8QDw1f21tDPrqyW0tiPDd9NOzTqk F7C0p33Pk15+CyLDYmjWzbD5JVq5fhJeyxMMbiq1CMHVVOlSrQngsZWqS9lVrU5zhOcYKMXd S1T3hjqtPml7RtuKStGDtqu667W+e9z1+0/aU+I19KkWm/s1/EIJO0cc9zrMOu6ZbWjsThJZ 4PB2pCPAOPnVSZSkYUbt407D4t/HrVLhILD4J6TpIlheX7Rr3jTxlDYxqkhidLh4fhRGAXIB VOjqQCwLfL8L/CP4w/tu+K9H/aO1bXfiB4Agm+DOq/EbQ5dH0rw3YRXV3ceG9A16XQ72GC88 H3Et5E2tWW7zHvNOjuYbOWOS1wJEfZ/Ze+L2t/E7UvA+teJvjL4x8VXOqa1fLJoNj8MUtdAu ZLF7yzthda7pXwX060sIES3Wa6kfxdZeWxxLJGXWE/U4jhejgaGNrwyLLcdSyipgqWKq0Mzz yTksXlsczhi3CbpQ9lCHLTlZRjzSS5JX5h0c2xV+WdXTS16dJbtJbQXdb30PvO01f9pTUGk8 jRPg7o+8bx5utePdWCDdny9qeHtC3HjG/KY3f6vj5vIfGCfE/wAL/GP4P+JPiTqngi6i1NtQ 8K6ePCFn4h02KF77xT4Fv2+1XevarerdTFbaQCzgS3JVUlJYFhH9m6ZLFCXkSWKNgilxIxBR XOVLhvu7sjbnGcjGc18sftjWM39gfC3xQ0Ty/wDCKfFTQtVkaBWdYdPSy1LUbq5miA+aBP7J iLzM8ccYwvmL5pI+ZyfPISzaeGwmUZVhI42lKniE51/fShKW8qc3DVv+G4vXe1j25xqTwsK0 pc1SVm5e6usbe6ko7ennrv8AYdqzuIzLueRY3WSRVKRuC05TKs0rAoDgbpGyegSpyjOeMKqF iMgnOTj/AGRx/WmwXpmDEhUhn2iLjBbyyfMxlmJwwGcFsd8Cp5QgjDBiSTnA5+nAGR1718Ri aP1fMcZhqlKhSoYadb6vSw9SrUp04ctqf7yqo1ZSu3fmclayblc9OhF0o039qUYq71umo30l dLW6slp3PKvi/avLo2n3KHJtJ55mUITuxaySbdwPyf6vGSDjdnHHPzzeyiSeEbk+eIuCz8Aq zgqTzniMHOP4sEYGT9U+ObJ9Q8OXyoVLQWtzMQzhCqiwvBuOQeMjvxwfQ18M6t460jwudF0/ U31I3viK8XT9MfT9F1LVbXzDe2ltL9tutOs7q309M6lEI5b14EkPmmMyeRKF/pzwIx9avw1X wleXtqmHxNarCkowjJQniKyT9yMJO3NFu99Nb7I+R4gowhXp1FaMnJc025WvaKWj02stF1R1 zBd64w7OGOyMh+QzrjOMn5E342cA45A3H7U/Y3kVn+JUYWVTEfB4YyIFDZ/4SjGwhiSBjnIG OK+FI/EOkzPJZx39pLqEM4mFrFPEb4RtbR7lksWkFyjoJmaVGtkaMAltoUivrr9hTxNoGr65 8cNC03VdKvNZ8MzfD6LxBpthcSS3WkvqUXjKfTlv4JnaW3+2QQSzWpYL50aO67lANf0Vw7Kr /bWDTozhC2ITk07f7rXau23u7L+mfL5pOl/Z1dKalNqla0lr+/pNtLrt22P0Pooor9RPjT+d 79mH9iv4ueL/AIcfCWD4veO/DNz8OdAv9B+Kmm+EYNN+1arqXiefQvAyW1hqcmlW+kQxm00K x1DTLfVLjxFrEEVzquoNFpcKSyX197j8B/8Agn94j+D19Z393rnwe8ReHtC1WK+8PeMG8B2k Xj+2vL1JYTM0954V1DV7eTTNdmtm08r41vkWxi8yD7Bvk08fo8L3w9p9lJLdOLErbT7QRY2s 0qRxRtPe6d5kqYWbEXzAyDfFbb5n2LjZk1nTgz+RcWVzcwwyvFLZyQRrNEYnaW5uNk1xI0Fo izGGVX2wy210zMAjhPkH/vWKpwTVPknCGiS5pwUY3XZyb17a9D6GpTvUpRp9Zq13orOPl3/q x8raT8NNS+FHhLX9Hu9cg13/AIST4meL/HV1d2kE9nHLd+MtX1LXI/Ot53djLBaSw28jJtiM ka+VBGqjblyqZ0CN93k4JyDkYPTB6GvSfiPqi397bRxSvLGkNsXmiImtXJ+2SSTPcLMQ7Rzy /YiTGu141hZt67T5tLcOECCMSAnGY8huhG7ID+vHHUjn1/hfxSxbxPHObSk23Sn9SjzXbToS kpJX2ipyfL0ad+un7FkNCayenTVuZ1ud6pqzpUVvbrZ6bo528AhlS3U4jaK5jbGcfPCSeDkk Yk9fWvmHwpZG6/aH+JGsQMI003Q7Lw00hyHMg0jwHq5RVByYtl4Dkg/OD83QD6iu4o5o5/ME sUkMaSRruUNiZjG3mBkDEAQ5GNuFJySK8I+FVt9t174uarjC3HxT1SyVwuSU0fwh4L0MgSYY FTJpLM6hyBLvBVGUoniZJKVHK81nUXu2VCyd37SqqdSCVvsuEW229JdNbG2PUp18JBPSE4uV 9dOW19rvdadj1BwWnKzyFhuH95uPlB7gjj3+lVJLNpJVmyGAPUk9S2RwT3LDtxXQkMWk2xp+ 7OBuQnOM4zjGc7QTjGarP8kagKpBAOAef4cZIXrx6VyYbFYf21TDRr0/bqMXyNvRSV103/Ib ja1+u/4fjuVGsGa1d2Xy4mcKXJBQEMhGVRy+4kAZEZGMZbGRXyF4v1jUbb41af8A2T4S1Txt NoWj6xNqC2mpaHpccMLXngC6t3jl13VdPZg8cDQDyInljKbjHjYW+w7syxgyAHCwKQgZiSTc bM42rkck9uRnPGK+XPBuotd/tNfG12t2I0vw/wCE7NVgyWE+q6J4fuWESkMFkMmnP5aAo7ty QzKSvv8ADOM5MXUrVJOUMNhqtZKneco1JwlRa5bJJ8jlqrt6J6Wa8rM1Kp9Xa0jFdXrvd6df z9LoxviFBqvxW0rTtP8AFX7Pfia5i0y/gukmXx/4MtnjuotR0bUoJop9M8a6ZeRyJf6TazLK jl1ZVP3fMRuK034daVpf2a2i/Zk1e91N9V07W5tZ1P4heGNU1W4bSL+y1CxtJNR1Xxpf38sF ld6Np+owrNe+RG9lHFHatsRZex+NPxP8aat8QvCHwG8CXthoN74z8P6he6r41kk1Z7jQrHSB qWoRT6Zb6NqlhNeape23hzV7aKa5vdOhiubixmVp41uoB8xfEr40/FL4J6h4i+BWr+NJtWU6 J4c8V2Hxa1u88RWmuaPB4i8YeHdAu9O1V7rxRgw2dtPq00CQ6zYpLa3FnHIY4zc+b9RlFTGP LcPhqNelGNSjiasKSxUqNR4epipSqqfLB8n76qk4vmvdSs9l83mEsPTrRmo875VFpwUuzurp ro1ptdr1+s9Wn8T3l54a1W5+AGsjUvBDajJ4f1M+PPBaSaVb63Y/2Xdx24t/Ee945bGWCxlg mimibbHcKA9tFKuPaaJq/h7SvGGk2P7NV5BYfE+fVtR8ZBPiH4RVfFr67bTW2qtcA69NNZvf Q31x5jQPZYF78gjaEFPjH/hoHxn4Ljvrvw/8Wb74o6fL4Lk1PxI32vVWtfCmoDxN4BtNN/sr UbL4h+IoI59Vl1/VrdYL+00ueSwsr5ILm5a3uY5er+D3j/VdT0bXPElx8UvilquoeH/hrP4q vtG8Q6dc6boF1eWdrbX72TXL/EnX57mF5o7i1uTNY20rWU/mHa++F+7E5bXeHqUpYj/YnRw0 +RZhUlUlXkk8TScuVctOjU5Y024tVIttRglZ8McZBfDTattypLdLoo7NLy/z9k8M/C268D6x pOp+H/2fdf0y50m48y3t5PjHDeQ7pTKXzY3fi+/0tg/nFiZo5DwSVDEV1vjnQ/EfxIW1tPE3 7PK6lJo1wb7SLofErQ7HU9Klubf7Ld/Z7rTbmwnhF7byCK6SHUXimSNBMkhC7fgr4K/Gzxp4 j1z4Zi2+LfxK8S/ETXfE1jbaj4B1671Wfwgvhsa7dW2sa1LbR/EDVtcW207w5aXOpPqE+iT2 EN/DMl0IrFJLtPojxT+1Bqdl8d30B9S0WPwt8PLr/hG/EsNp4iuDN4j1vxH4LfU1ltoDew6d CnhXW/D2q6bdR38d3dxveogFldrcxttXp4mhnWHwn1rBVq2GpyqYHESxLk8I8DSqYuFSzg3X k3Rs489JtNJy2RjRr4dxaXPd7Xg0tUuvr6Lql1PWLX4TNa6dY6Pa/soaUkUfiSy8ezGX4k+H WmuvEthAbWDWrq6a6nuZ7tFubjLzXE4LzzSNBLI7O3sv/CYfGG6IY/A+3NxNazmF/wDha2ix FHjW4UzOY9JA3Isa7fvtiJQCCQB8j/Ef4dfEPVfjDoHh60+O3xK0rTvFGjeKfFlzZ2Wt65b/ ANh6fpnijwzY29vp0MWviCOKKDxXcxMZLeKA/wBn2KI8CRSJJ5l8T/iP8VfCWveMvDfhPxHr HiHV9G8c+FLPQ01bUvEdyNUEeh/DTxTqelPHpuptdTm/ttdutOt0s4f3U0yPcWl5G0kdxyzo Sx+JlUxCwGY1K0XiK9XEShJVZU3TppxpVqdX2Xsk401FTlzqPOnG/KlTrUaEpuak1JXuo325 Va3Xe27sfUWv/DTVPGdpd6Pq37MPhrUHvdfu/FUkzfE7TLS8Ov3bXP8Aaupf2na6fBf/AGm7 mvNUMzC6RJo7yaMx+WwSqsvwdabw9F4Su/2WPAcmk2cpv0+2/E6GXUYb9RfeXqNxqKeHLvUr nU7UarfG3un1a5mUzytHdROUr5Rvf2sPFGkeI77xVOhubrw78HtHt9b8F3d/qMmk2Pja28e6 N4S8Ri7ifVUks57a5n1Bobe706LVlDW0l9LDJNPaJ051m5+GPxD8HR6l8efH+o+KvEup+FZ/ FXhjX9dkm8BKPEQ0DX5dO8LaPP4xtNRsJLdNVTTLNdRTU/8AQ5bpWgYOEl6IYXMKdWnhMHgs sl7emp0VGdJOnFKLTglRSUlHonHS/axipYecqkoptyXu80LK7aa6tJbvq915L6RtvhjqWneG 9Z8Jwfs2+Brfw/4idZddsL74rT6hNrM0XkCyur28uPCd9efaNOktrdrArfloPstsYZbYqvlV dI+EI0fS20i2/Zk+GFxp1zcvc3tvffE+7n+1k7BDa3j3XgPUJJlt/s1jPbBpp4IY7SzgiEPk JHDa+JnijxLF+1Z+z/4PstZmtdCvdB8c6xr+mWd9f2+kasU0HXJLL+07WK7+x3LWsmhh4Xvb Ofym2tEysuY/nr9qD4oeKfCXxh8RaXpWuapY6JZfB/Q9ZktrTVtRttPi1O7+Itpp5vBBbXtt aGQ2txFZR3TJBcNbmKEyGMLC/HThmmaVMFhIZfhn/aGGeLw9fkpWdDnlTc6kvZpws4Tbu+ib NZVaVOk1KL+UV5L5XPrfxL4S8c+Po9LufE3wS+GmryWZv4NOnv8A4kXU8kEd9LbpdW0SD4ao tvA50+zjuAjFJ/slu5RtilUv/CfjjXdd8MazdfBj4TXur+ElC+GNQvvH9211pDXO2Lbp8/8A wqid7WJxbwrKB/AvEb4Kt+f3jv4y+P8AUPgB8IvB+j+JdRt/H+krLD8Qdat9a1pdTa28H2t5 4bne4e11P+2oL3XXuotXtptbd4y9s8rxzEKyTNpmv/Ef4P8A7TPjXVviL8QNG1H4efEP4qaf 4abQfFV7p8McWm2ukX1jb301z9tnWGGdo4jHYT2KpBLcLDHG8qsKxGRZrlcY0sUp0aE5yoUJ UaCr3k4+2nJxjVhypNuzu7rornFSq0a0nCELSVr3iku+j27X9fU+0rf4J6hoviCPX7D4J/BP SdXgLSrc2/jfWZjFI9i1i0sQb4RiLzGsm8psQJmPeu4sxLZc/wCzhe6vfX3iC4+DfwDlu76+ l1X7dJqszzHUlnmkku0c/CJJfthuWkmuJ2ihMl1ul8ycsJ28j+KmiWXwP+Bl54b0r4oeK5fE HxC8S23huz8QeKvF8La5os2oq+qXGp6VJbf2Vex2dtpHhK6t4jFcM6XVxqEkjm18yOLKa203 4yfsqx39/wCOPFY1z4P+EPHf2jXfDPia3W71vUfCsfiTRLTUNfupl1W8lh1MeFf7Qcvd288j yyvFcALmPOGHzuFHCY2tPDYjLo4uplP1fEZfTqKdCmpOeJrU51pRU1OlCCi4ybVST9oldS0m qafK4pSXvK0VumrXene/yPsaS1/aMmVo7eP4ZyxuWDrD4juA3mcFY3S4+EVvHJghclpGQAsQ SeG8h8WfBD4y+J/iJ4K+IWu6j8N28S+C7uJdBkGo6kZbcvpviKwjjhgtvh5a6VArL4o1QtcS Q3EyCeU7GdozF8teNdBf4Ezfs2XnhfxB421a58UWnifxX4gi8Q6ybz7TqXh/wv4N1RLeCPTr bSpH0iaea4F3HevdTpayTuJw5ct2Vt8PXsfgdaftGzeO/EGr/ECz8V6NcwTQ66bjS9US08Y6 d4VHhaN2jfWrjTtR0uKQXOkprri4v57mXYbeRrKujKctWHqqpgcNgYRzGpi8pu8iw1N1MfKl hFiKelX3sP7HHYNKq/dm51IuFqbvw1Je1tDEN+z6ac9r2W3y0t5I6O1/Yz+IK/F3Wvilqeve CNWutS1TUNXi8Oat4k8aalpGla9qtjeWV/qttY33hi90C3muoL/WSgsNDhSBdUmhiWAfMNH4 u/s+/Enx/rHhbX/F/jDwFfXHh62vtMg26ZdThdP1S60691CBGTwjpYWO+fR7fbIbeWeL7Llf s/mskvydonxF8aeBvEnxg+I/iPXppPB3xSm8JaKbW71PVY4Ph54gsjNq0LE31/FpdhY6qfD+ v6YYvtFtei6udNtk+1YvTXq3inQb/wAUeGNE8V3lrH8UtI0b4DeGdJutLsdXmvPE3gbUbPT9 Z1K819LWXQPFltFrOp20i29ndSTeHZ21Dw9NHLLPGofT/qcLT4pwuOwtXE4nCRq5dg8RleW1 IYCnOhGjVjiqk6UaixCVKahjq1J0oxtytRvytxOSpTw1al7PkTd0k3BO6vFrRt/ZXXb7zH8O /wDBN638H+H9K+G63Xw/h8H6Lp3ieTTLEaHeX9lJ/wAJZY+JtG1mNoryGW8aOWz8Va+Z/tcs wKeatrEsrWbx9V8Pv2EvFXw31Ww8WfCb4ieDbTxR4b03VtC0ORdD1aBNB0XWLq0i1HQrZtXs dStNO0qWHTbSOKPSrK7ST+x9Mha2s4Qklp6P4s1LRtf/AGWY4Be3+sRatr3hWO21rWhanV7u wl+MWjabe2Nxi81NZBIV1Cy8uO9nhOmsfOhbE9o3Nxal8PfgB4n+FHjnw2hsF1LwVrkPjvS1 n0TTNLuvK0nwhY2FxNDYR6aJ7hdZ1AXMbaxLJ+9urmaFkupAkro8QcX4qiqLx/sa9HkyelhJ 4G2ErxwUVRjCrD617KXs1BxipU5KMY2jZWtzzwWEhGnBJRb1a5Ek3or2T6apW2Vzz/8AZS/Y Z8cfsu6N8V9Rt/jd4T0fWvG/xL1j4hePIfDngO61Cz0/WNbtYp9Q0j7VqdvAdW0yK70fU1t5 rHTLC0litvMXQLD7Ylu/LeMP2bvAXjn4q2/xD8Q/EjSdb8dibSFvvGd/4A1WPWRa6DaQPp9o 6QXJhubXTLFp3sYy5RJr682wRyySy3PUfstx32peN/GHhXxrY+NdEtPixoVz8SZ7P4lWM1hp uoavNq9lp2o+HfD1pq0hi1LSY4vGHlWSvDd3PkTzxToFuNs+FJ4a8IWHwe/aK1ey8J6Mmt23 iW0s9MuZNH0sPp6ReB/hzMtvqGpRWUd3ZWN/Jql3H5VvFiWK4uwEkaeXfpgMdmVPNsxnjczp Vc1qUMvw8cVg6UsurVcPmCrUqcakKVWrKqoOlaNCVblqNtJ07tjxFOhGNHli5ckoykuVJOMe Vv8AK1vx79PpX7LPwr1fx0PHVt8W/C8njnS7LamvXnwf1N7mxW10+PwpDOsUhmsrq4g8OTxe GlvHga9axcgyeUm4+1+HPg2/xD8byeKtG+Or63420Cxhjg16f4fXdhqOm2EkmjrPFbT3WpwR ukd34e0FFjUjf/ZNm67EQ14DZpfP8Eklh8OfCHRrhvh74F36j4GjmTxxNu1Dwa8qXt6unWjq LiUmbVYD5u6ZQ7SOzFl9Cv8ASPBek6h+yp/wrmHw9H4tv28IL4otvDdppNvevph/4QFrs6uN Cb+05pXvJrYwf2jELeN5bhZfNlkjc8eb4XOKdSnVxGZY+nLDxrYfBz568o06bhKpUg/9p92M 41alpWspTs4trXrw1SlVioSpR5NFZxT091Ky5fXd9NT0nSf+CfOjR+LR8T7LxHoMHxFVY4of GX/CGrpmqLNb2VxpVvLHeabrlzNE8emXJ03zFtlfyFRCzId0Xaal8LvH3hQXWmD40+K7HWrQ RXUs1k+tLps9vcNDH5yLF4mVWebzUP77T0myoLhGUEfWklzqI0iUWFnPFqX2K+Omy6nazmO2 vkFw1tJNFC8c7pHP5Uw8ie3mHHlurhXP5E/DXRPiZpH/AAUg+OmjeI/idD4j1vXfg+fGunW9 5da/JpXhWz1fV/hgLHRdN0u/168u7O30vSxLYlYJ7eL7bfXssKQW07WZ+LyvPM6zieNweKx2 GrPK8JKGDWNTxEv7PoVaNGXsq1WUpTjSqVIUrLl8opaGGP8AYYOKnhouN7NRjFQs7Jy26N3u lbufb/hjw1458RT3tnb/ABv8XX17ZSGK+tZZ/ElvFbTSXM0Ijh366trE8TxPB5tiNo2mSN9p Vm0rvwLL4L8T2miav8RPGFlc63Eb+fRbLX/Gc51NGe9iSd7iHxMlil1FPDM5eW6hkJiRhMf3 RH47fsi2XjLw7+098FvAsWnakkut+DPE0HjzxppusarrGi+O9X8OfEv4GaGPElht8P6GyWOo /wDCQ6/qqy6zqXim5ePUh/p//H7PqOf/AMFI28afCf8Abt8C/tKJ4l1DVNF/Zm+EGgfE3XfC 0Uuqw2fiPTrrx18aRq+n3CDURaSw2OmaBPPa/bLmwgLSMt1PBbl5Yvtp8KQqcR0OHqePwNPC 5zkSzXB1JYKEbuhh4VkuVVvd53Xp295XWtnY8ieZyo0PrVT2qXNGC5YuTbm7Waum9tX/AJH7 WQ2XgbxeNd8Lad47+I93q/kvLeW1xr/jxFgszbafhHubjxwsUiRvdWl+I4JJNzsI9ocTGP0H w78ENMttM0+Vte8c3tvZwRElfGPjKE4VjI6CB/Hiovm+U4yrNygLYL1/Lv8AspeM/iX8Dtb+ L3j7xX4oh0nxl8QfhnJCLV5tf8/w/c+JfHnwr+FWkvpR1LXPDmqm7u4tDtpLCXzoZE1TVttt HqCpHY3P1t+zp+1r+1H8RtS/a88EeGtcur27/Z60D4f+Pba9vZviJNrGuaLf+DfHHiHVbXUp bDxdqMsUEl7/AGXBayx28Fpb2ggW5a7lFvJXnZ5wDneCnOGAzHLsRh4RjQm4UYRi8VUmqcYW Vdpv95Sbk7Kz6Wd7o5tSqpSarJu3xQf913fa+9lonrufurqnwl0DxBNP4f0pPFj3LXX2edrr 4j+PTGxguRJNZMk/ip40Z4raaJpIXaLdOpWVxGGHkF/qP7Ow8cp8NH8SainjNbYXI8NQ6r8X b0zQy2Ml9GDrl59k01GuLaVTtN+fKDrGxU+YkfLf8E7vFvxB/aJ8KfF34yeKfE0mm+Etb8fp a/D6I6rrer2U3gzU9N/tyx1e11fUb1NNSP8AszxZp808+iLd6U1vawXEMz27wNX5r+JpPgN4 o/aEuvgr8Jrvw/4dtfh1NfeLdD+JGuX3g2++JPxT+KVz8Hr5tC8F+DovDUWkR6jpFynjfRdL jjs9Y1PxENS8Ia8tnp1wLe0trfxMhyrO1m+Z8NZnj8ypVsnw1DEZl7GdaphsJTxFHD1qXNJY qKXPSxNKUIxvpKzsom+LxM58jp89rR0u49E7+dvXd9D9NPhr/wAM3/En4ua98KdGiuvEXj3R /wC03fQtbl8cx2FimgZs9YEOq6hdXOnSyWzS28LMnN0w8yGSZV82vavCHgH9k3UvGvjbwT/w ieia14k+Hmmxa94zW80zxPeWlho0mra1pL2trc6v8s1yt/4a1oBtKjkaOJUkhmIuVVvyc/Zy vfCeu/F39l/wB4V0q10/46+Dvin+1sPjB/Z1vpsHj9NFkX4urBqXi+005X8YS6bqupv4Wu9O i8UR2FpFFqGlSpfajcR6cb32r4Y/szTfDP4+/t0fC/4fXWu30Xin9kZdXivNVtHu9R1TxFd+ NPjr4emt5n0TT9OXUNUuFGly3BW0mvrieclhiW3irPiDIcTSxCwEc/zvCTng62LwkVicZg1O g/YuNWfs8Y1yzSTpXvf37JXKpYqoqd3Fvltzcz110Vm07+bsvQ+xPgT8Xv8Agnx+0L46n+Gf ww8HeHdd8YQWOoalJBqHw61nTLW4tNMtLHULqWC71nS7e1RIre+tohFI0EjzpOY4XU+bL9of 8KD+AqW7Qx/CD4bRvtYb28J6TPseCdI5PPEumsG3FnClDcfOVOAAJF/nY/4Jw+PvFOh/Hn4U aTp/h2fUvt3gvx5pviGPVPBOo6VrPgSa6vPFd3YWMF/B4n1f7PpN5LF4d1VrK+0zR3mufF91 PD5jS2Nxqv8ARJ4W1CTVPFtxH4j+1peafBLJY2skTSWqvfQpJOII764EscgtgjK0KAqhmjcS RuJV+F4xyHG5FmNTFUs+zbG4aGEp4uNFZnjZwqwc6kI0qtOWIlDkqTp8lROMl7OTbjJOz9TB Zip05QUWpSi43aaS5opN7dL67WXRHNad8Pvg5oF/Paa78HPhuEvT5Wnz2/hDw1KFHneUN6R6 LHIgAKvhi3TGd1Saj8GfBNreR3Hhbw54D0kp5K3NtH4WsYEaSSTyo3jCaRNCNiPJK+1IySxG Hckj2XxDpVhfaYYpQ4ia6SKK4Pkm4t0uLe6VpAzRlV8tUjdCrIA4YnI2lfGtXsPE+h+DfE+n +H7qx1nUn8M+KR4Zlv7rUBPNrmp6HfWNpFdJZRXVw0MGoCze3TT2a8jZpJYg88kUSfIYPOKk 8JDGxx1Z0ZY6jQeFq42tCmqlST0j8cXFWfNJUv5kxVE5W2e1/uXXuuvn52Pmb4cfFnw54v8A jt48+FF/4O077Z4Mk8Q2mi3SWOkRWGrL4UvtL8N6hPbra6XaT2jrqDa/HEmojMlrYiRZWFzZ RjxO/wD2yfHlvD4B1bUtF8Of8Il8RvEVloFr4V0TWFl1vSLO+vFtHa+ubr4XaDZ3ki2vnrc2 8XiBkkvbpFS9mijOpR1x+yp4m+GLeHfjrpPxOvtS+L3/AAkHiPXdf8CeJNb1CLwID8RJ/GN9 ruj2FvbWQ8TrJoep+KnuLFb2M4XS5GvIVuAZly7n9lzQLLwl8LrnwjqngLQ/i94K8RX2seId WubGysrXWbaXW5dYjttQvtMtYPE5lubq10Wa3vr5njgt0vJVs7yR7R4P2TDw4dxlajiuacaO GwdLDTdNuqlmDjS+tulWtBxjKcHzTjBe1Si29Ejkm5JKFNNyWt+nvcul+nW/oaPw5/aL+I/x D+ImmH/hYfhDwNo+neLtG8N2vhO60zUb3U5LO6s9H1HUDbXOg/CefTI01WfWrqIJca5BIu+R ppYI3VF+jP2sPjF8SPh/ofw/g8H/ABGt/B0nifV9KsJ/GQ0SDUoomi8N+Nr65jGhzeHNRmuL a9fwxDbxXLw2l1HJIjPbQwxM8vlfw/8Ah/efDLX9fn064/ZUvrK/1/Stft9Y8deIpbXxhp/k 6JpWlTWdndQeGjE8tvLpUl7ZTJPb+Wuo2sbRK0bT3Ht3xi0b4XfF7Q/hzb678WPghpl94Y1y y1rWtP8A+En8O6hpU0sPg7xj4fntreO8u4ZntY9T8SJcQTXcEDCW0CvElwRXkcQ08uwnEmXU sBh6OIyTDU8PLEwqQpwpxlOvP21WGEcakOanR5W5r3p2UOaPLc76MJyp8ri1Kyer6aa3/A8H 8Iftj+NLP4X/ABgh8ReI7nxXrfgqJ/CPgn4haZY6fp1lr3i3XtP+IN1pt3BoM3h3SbjQreyv PC0Fu8moabNGjWgkjjMEn+kcf45/a08b+IPgfpOu6P461jwPrHhfxrF8PfiN4lstH0y9uLbW bXUfhdp+q3Wm29vYWcl9D5+u6tHC1lHYGRLosrwrsEHu3x98K/s6/GDR/hT4SsPjD8DvBfgX wN8RtJ8ba54b0nxF4Gt7TxPY6abmKXTHsYdSTRzb6jaaprTSNeabdQs2qMzLLFPdi58a1n4X /s46T4m1PUfh18YPh74X8K+Ide8I+IdY8NWUvgSVW8Q+EPGdx4rN9p50LxFoGmwN4iSbStFl mutMvr64t9KgX7VIIbaOHOlT4drurOWS4de0xyxGJprL8P7OnR9nHD4SNR+ySbxFdUq9Nct3 OaclduRUqFa65bbp7+lvPu9LdjlPhB4/+MXx3j+I+g+Bf2gfGniTwNo3g/Wdesviff6NF4Y1 fT/EegHwzqNxo0eivrC+JzDFb3bmO7XVpNOla8ZTaFo2C/VH7Gfhnx/fWOteLfF/xT8S/EO4 0+88V6HcWut3OqCCOTQvH+vaTHqqw3etXllJOtr4bEEIWzNwsFzIhufnuPtHAy+L/gbpXxpu PjhoHirVrO01fwjeeEfEPw/0e08IXOk6xNPpk9lD4giSy8VaZFLqcX2TQba4uL6zvmaw0uSx RkzZy2PV/C747fCr4ZJ4mtbLSfi14kTxRr2u+IYzY+EvDn2Oyk8TeJfEHipbKGWHxjKEs7aT xK9h9qWGRo1skcW0zMUXp4jp47F5ZiMHlGXPDScsvnSnHA0njZqlh5QxNOlKMqU6VFVpQvy1 HFqKXK91rhabp8zqcrbk3o+a1+Xy6a6fccb4Z0vx5+0748+PV1ffE7xf4Y/4Vn418Q+A/A2n aLqer2umwvYar4nl0/XNQg0LX/B9rfTNINKEdtrWn67Mn9lIs9+I7iSvj3wr8VPiZ8V/HXwp uPGDfET4k21x4W17QNW0Lwz46j8D3Gu69bap8QtW0zVJxa+JvA2mPFp+mS6ZYzm5vle4SwhV 47pYYo196+K154e+JHiq/wDGHw/039sf4Yapq9re2nimw8BeCrHTdN8TT3d7qt62o6ouieJd PuNTuUXW9WSDUdRe6cJJ55gIW5jueq+HreDPh/f/AA1vvCPwB/aWuJvhzeatFokl94J0qCXV ZNdh8XrcprNzpmio90bc+NL5rZ7RbRok07S0kil+yTPddGCqrK6eKmsOpSxGCpRjhK+VU4vD cv1j+0sR7R1ZqUJUJ4WNOfJTlKVGqumjlQdatBytywa69+Ru60Stbz6vrY+4fDPw50Hx18Hv D/gHxP4Z1vStMktbO/l0TV/El3qurWs1veXN9HYalq2l+J7xtQmspZwouR4j1CFxEpSRl2xr +WXgn4Z6VZ/Bz9sW/wBPXUR4q+GHxM+Juj2Oo3Oua5NdQaFo/hbxHNpWmWVzcaxdCK2TUdEm nSNvN8uRUkkMgYZ/RWz/AGmPGhuz5X7NPxoiikeVRNfeH9WtmkEIkSY2wXQ5Vk2zhUmkEnRk LIjyhE8v8PSaxYW3xNtdK/Z68XS2fxbl1i58ZWusm6VHuNbj1GO5itrO2+GjRTOsWtajHNLq r3zyiSKKSLaJzc/MZY8/y/DZvS9tiI0K1TBYvL3Rc4QlF5lQni42jV/dp4FVFPT3rSg4tNo7 atOnGMFCeqtvo0nyt9XdW8/J+Xyf8bdR+Nvij4gfsxeLPGXh3w5oXhnW4PjD4X05tE8dS6xf aofElhaeCmTU7aLwR4YKW0OsajbwxPcXV5LFbT3tzbpbCGNbt914SuvEulfAzQLPVfA1l4s8 PeJP2itL0PQviTolz4t8HeJbay8aahZ62WM/g7x5Y6PqHhqHTrQabdXfha5n1JLi5S11KwzO bv7OksfGF5ofhjRZvgHpKWXgq+k1XRpNc1XVG1C2nudattaknkL/AAkENskGoadHcRPaJbvs USNKsyrMlC+8B+J/F1ldaFrX7P8A8KbnRb3U5/EFqNfbUNRsn1Oa7vby7vbYXfwp+yR391Nq t/NPcRw3FxP9pujLOXkmlm+lXEk4YRUoxaf1zFufssVPDxjg8Ri69ejzyhSahelUoqMLSST6 W5Tnr05VORU56RtdPTs9FfX19TB/ZO1+w8SeEPjl8O/DPhNPAGueDte1XQ5bPS/EN5r/AIdn 1660y70O1uvC2pX9pot7ommW95oUkVnYRaJodla2K6dPFZ2soltLLwX4F+O/2cfht+z3FoXx p8F6bqfxE8LeKZby+0eDw0moa7qOs3PiPSdZ8MNp/iizhj02CeW0uPDMEd7LrtodP+xhJtq2 qpJ9o+C9C+Jnw50JtC8G/D34IeE9Nu55Le4i0ebxBbOJVs7KzXUb/wDsrwfoEDXcEEMatfvb FlKNiJEKxpBeeCfiB4h8R2PiK/8ABX7N19r6xtbWXiLUNE1vWtUV7OGV7dzqU2mwXr3Fq9x5 VsIbuM2ka2zIWI8s8tatRo4rNcPTx+Jw2Fx1XDVYwr57iaGIj7GMuam6SpSdP2/tfftJ3UYc 6npbtnWiqMaUG+ayu3or6dfTr9/n+YV542udH+LvxLl8P/Ha5/Z+8NeItQ0Xx54b8Hy/DlvH t3Fo/jLwD4A1q2jn1exi1NoLmdtSme5ha+lSCTTpEU7LqHPeeGfAXxd+Jn7QHx/l+Cfx7X4f 6d4p8HeCvFFrrTeHrp4vGUsHhDR7WYX+nSQNc6BcJrWu3c0T+RcI0d3dy4iCRRS/oNF4D+Ie qa60txF+y/qGs2ULm5jufCOuavfJFAv9npZSCTWILovZxSwqsMgiW0t4liClYkLppcXjaW+g 0/Svjf8As8aVfRy21gNO0PS9Wtr3y0dLUWEdtbfE+Oae0kkSBTbCGBUk+yxeXIzIy9lTOZ0s RUxODzR1q31SlRjSq5xiMTSUKTb9lLDVKcYVFTTlVjO6XO+ZRUo3fPRw/tZWk05t3Tbutk9W /v8AQ+V/hpoLRfsM/Fr4SWPhq88P+MPAh1jUvE2l6jrq6xNLr8N7p/xJ0O8tNfOpanFdrNoC aDDGz6lElpdWr201sIos3HTeIPDXiK9+G37Jvje2sUk1nRfDXhjSdTjnurOS9Tyfh38StOnU 3FxI1rLCtxewbFhM2FKlAoVjH9Gz+CPibeXs2nar+0L4Zt9fnsre7m0Oz0bxBHrV3ZW0l9NH OLW5+KxvbiCOCyupVke0MUUUF2yuUjkZOD8VeD7vwzpMni7xL+2DrGgaLBdnSZGs/Esnhq0T W1u57WXRYZb/AOIs1pDd2ZiufOs2ma7VbGZGtovKk8vzcHmGP+trGwzDDVK04vEU6PvNKvJw c07tpLmc/e5bu/nY73ChGCg371kl7v8Ah0e369WVP2Vf2ZE0bw1pGseJNa8Upq+iap4qhtND bxR4nutAsItM+IGsDShb2Nv43k0QWlxp2mafIluuibYbeWS1ubcubmGf51+GH7OHxs8Iap4Q +MGmeH9P1DUfgZ8R/HNk3g2TxFo0N34v8ET6J4T0bTLTQNUu57zRdHisbSbxLcR6fqi2TOrx 2skyGeKS2+k/B/wJsPiToba5oH7XXxl16zvtOFw76P8AEuG8S1aZZoWVhZalqsUHlTQXNvvN w5MkD5VHEkMfWt+xtod3NHcal8bP2htX2wQ/JffECzuY1XMryxzmfw9ceYl0G2SLiMSbSG3b sL5i4goYTM8VisTDBOWNq1ZVebKKNWTVWo5y5pyk3J++uaTScnd6O9uylg5OEPZ2fuRa1s2m o2Vn2/rs/Ivin4V/aa/aGs/E2hnRF+Fvws8Ry+CvD8/hnVfF/h3WNYs00bxp4N8U+INf8rwt HPCkN1pljq9raRWXiqPU/tYikWK1MyyxVNG/Zh8RfBDxh4G8Z/CPxrBcalNDovh/4u2+pan4 qtDrXhLSm8MP8p1mTxZZ3c1jZ6LcWFpb2tvZXCwXrRwahHF5kcn0Npv7HHwxhSFLzXfiBrO2 Us7a3q3h/UfOTllt5/N8KjzLVHAlSE4CzAODkV1Vt+yv8Hbdyo8Px3hzGjHUNL8LXI/dZQbf +KcTAI+Vsk5UKvGK6YcW5LhcPPLsPVw+Dwdf2rxCocO0V9YVWnGlaUYV6a/dNQqRcuf3oqyh JcxvDL682rqNlZ6y6eXn59L+p4l4R8IaF4F8T/tK3+p+ItDtfC/xo1TxHfadDb2viWYafPqk /jprm4v7aHRZJJY5oPEuiQiOErt+x3GLeEcyfJHwr8N+NfgjpWgaRbfGb4UaT4e0vU31KS50 7wNrlxrM1neai8mo2VpJL8IpbyKe8UXcELvrtukbMjCa0Qho/wBX1+AHwhsfsckfw68ESCJA hjl8H+GGimSJFVEuEXR18xY97MgyArszADJzox/C34axki28A+DLMeU0Kmz8K6BbmHexkM0H l6ePLnVmLrIPusN2Cea3w/GdGg8a8Pm1bGUc2jhMBj8Di8rlKi8DhsFTwirU5VMXUhGu4UKV NJUeaEajam1T5Z9dTK6jUXTUbpp/EkujWtr6enyaPDdJ/ay+C+laZa2up+M7zV9XttN0+LV5 4vBmrRx3VwIYA0qNNp8IYeYwYfuoydpJUEgHzP49ftP/AAn8ffD3xLpOhzeIbq4tdI12/slf w/FBFHd22h6rbWrCa6v7aSPMl9EFAR4oVDPsJLAfd1l4P8LW8MKW/h7QkWK3htww0jTgzpCi RoZClugZyIwzngFyxCjOBf1HQdN1DTdV01bS1iGpadeWbm3toE2W9zbzQSiJRG4DKJl2ZDoM KGRuAflKeY5FHPsNOlldWEOeVK6xjj7/AC8mywqdr3S1tq29D1fY4t4OFOKjzxSv+8220u1Z 9v8APryfwd8WweOvh94b8XN501tqr60baabEcsS2WsahpcqywRrEpLTWTBCFb5SrEjrXq4eF uETcAO4xxxg8mvjb9iy8ZvgppWi3gaS88Na1r2kSySMWlzd6jP4jRnEpMqMYdeRAGWLdGiME KkSP9logESlByQDyO3PoPevmuJKSoZhj5woOgqlWVOEJV3Xk5KUZSk5KFO0ZQdkuWyatex20 pt04uT1haEkm2uZKLbVujutrJ66dXi6lDFeWGrW7EJ9os7m1UEMwDNDcx4+XHA80c5HQ8ivx u/amHiDwxpPh3XtG1aWytvDHijwxLqTQSyRyNb6h4z8EROsSkStKzwTXMewqVYyFHaNHLr+z LwiZ1SXKnz3xsIUMGKD5gysSCc49ea+LfiJ4Z0ka9daLqdpZ39pcDTZzDqtrbXVm7hbZ0+1Q XEPlSRxzWsMsfyZjlUSBiyrt/Yvo/Zr9W4lxmAqNuEssqV4Qu3D3HSU21a3Neqn30bvfQ+d4 qw862Ffsmk/3dru1vfprR+f62el7/kf8NPifP4P+N8Np40v/ABH4p1H4jeItcv8Aw14jsvE+ uz2OlaNqvge88W6d4X1DwTqU2naDZzaTY6BqNu2r6el7JLObVklIvLr7L+5f/BPPwDbeGviX +1X4vt8Z8e3Pwbmk/fXUp3aBpXjqyGRcXMqoM3bbfKt7QMPvLJhSvyN/wqz4eWXiCbxZbeEv DVnrlqptY9Z0zw9oaaq6tAloY7S6jsYLxrQWcptVjW/UJaxGIh4oyjfpN+xsUVPiHCmCIz4T ZWSYSxGOZvFEsXlgRRhAEYA4Lqx+6QAM/wBk5Pjo1c3wtKMILmeI1Vr+7hqstuVdn1PgcVhJ UsBWnUlecVSaV76urSi9b+b6a/l9uUUUV9+fOH8kf7Rl5L4j8b+Ffhz4ym07xTbeFvh9ofge 68ctImgWXhW+h1fXNC1nxdd6Zpt7BbXvmx2kOry6bLqp02wi0trcTiO+NzXvHjPxL4D+DGtf GDw3ZanJdQW/7Pb6X8KFsbDWtXTxlq2u6b8b/wC0v7Om0601n7XcWXiHxFBprwm5lgjmtkSR I1NyF+r/AB1+xV8N9R8T6vr+oeJfGNto/i/UbmTxXpdw/g7UWn1GfUNRvb/T9Ev7zwHq2v6D 4d+y6xf28Fjo2vaX5Ra3mhVL22gvI/UtS+EPw2u5LGbWPh34V1G48O2U9rHqF3o2m6hLptnP Nd6isFjcX4mvpbVp766maC5FwI7q4uzDHHFKpbwpV6MauKqWu1NO6fknvt2flt5H0VDD1J1a O7bnH56xV9Vp2utvRnkn7LEVyfgB8LbvWIp7XVNR0C8vLu1urS4tru2XXde1jxMPPjKwpbTx NfpaGxntYbqKIBriGOYOF98k3o7JFKFZecFUb5QBgktwcZHTk5pmm6Zpmn29raaXDb2Gk28Y t7CwtIEtLeCMKXjMVtbwRwQhU3RhECIqjAiHDUglt5JHfc3ORkhsnnGOn+zz24r/ADr47xkM bxzxA0tIZ1j6Wln8NVu7d30en5Lr+45LRdDAUYy3ajL5OnTXby/A5vV72eC01K7Zlcwadfyy OQqjZbWMk8LFR0zIZFIAJIQEjBGfKPgdNPJ4a1i7SME6t8QviTqjuWVVZx4z1rT0KhioVPs9 nGADtyQWwS2T6H8RydN8FeNNSgkKi08M6xOp6kFdMnGdu0ZwwPGeleb/AAKZ0+GOiXrNhr+6 8S6grKFJaXUvFmr3rs6upCh1mkYgfMrELuIzlYdwp5LmvtLKCxeF5rtJJfV293otbW/A58VF zxdGC3lJLW+jst/n3PWptdsbETDVLuz00OVWOS+uY7NJmmR5Y0gkuWjjncxEOUhZ3TOJArcV g/234Vu71La013R5t0rxKltrNhcytIrE+WkccryPLgLiNQXYkAKxIB/IH/grj8YtZ+GWmfs6 2dl478YeB9K8R/Fu60vxRf8AgvV9a0rWrrR47TTVa3Fzp0y5WCwvLuS3QRsEuEt32l0wYP2V vFv7MfxI+K/h23+Gnxw/ac8U+IrHUW1Kx0Xxp418XS+GdVf+ydX1GEarZanaxW91G9vpV5M8 MzwIZYrZWAJCj7TBcJ1qvDtTPY4nF+y9lm0lBYeoqVsHTjKyqqlyNK9m+fSz2e/z1TPIfXnl +nPzqHo7L+937xdtdz9n5VsoHl8+SRRDGolVkdXRXdNm5RGXUlpIyFK7irq+NhBr4n8C/Eb4 Y6L8Yv2jbzxV4r0vRr6+8TeG9PtIbq4ljWePRIfEumyRrtiKiWOOKxEisVkLSsVDYcj7ImWX UImZo3klu4x50nmCKUvFOAq4imSEqIoI+SjMcY3ZAC/Kvw2+HHgXxFb+JfFmveD/AA1qmo+J fG3jmVrnVdE0y+urj+yPHvizTIA0klrPJFItusEQdpwxRVJlQrx4vDqpYSjj5V6ldUrRw9JY KvQjWS9z4lVpVUrup2jonpa5vmL9n7Om73irNNW10d1/X+ZwvxRufht4s8d+Evi/4H+N2ieF PHHhHS9Y0qwXUfD7eKdDv49Xhu7aRdU0yS+0C6SSK11vVY4YbXVLCc3FzAzs5t0gfhp/CXwU 1jX4/Hfir4+WXiTx+2u+FtR1LWNP8LXOhWD6H4W1jQNSttFh8Nw3N95KSHQLVrnV/tlxOPtN xsVFRIo+c+Ifjmw8JfEy08LD4ffCrTNIM1601pqPgm3n1LWrO21DUrdLvQ5dGe4023uvKsRJ u1xtKbzTbERhVkSLm7L4lG/s7fW9O8DfA6w0PTLqz0zxDPqfw833l1rlzqtuBp9h9jtb64fT 7jQtW0jm4MES6gt4XmiRIy/6bhsvxUcvwuJpY7MXhnSlhKcKuZ5fKqp1JKsnKnDBxkklCS5t k3a13p8tiKsFiH7Racit2v7uqu9Xa59EfGDW/gt8TPhhrHgCD4v2fhWHUbjQ5LjX4/D+p61N bLpmpQajb40ydLUOLo2/2dG85QsMzTETFEcc5a63ZP4K1/wdrv7Teg69out+CNY8GtHpnwcv 9LudNj1TSYtLnuHv49a1SKa4jtAyrHJFAgkHnMQvynxDQ/jr4RvNb1XRNa+HHwxhmPiWGxtZ rf4eWL2N7pFrpfiye6ljjae4KfZLux8PwW/2mztbny7iXZFIv2mWBmj/ABS1bxX4E+KeueHf B/wpstQ8Ma7dat4cST4d+H7e1vPCmpaP4ivPDJ1GA2N1HPPPPocw1CGQ20wjVEkAVxtivlGY wwrqSxeOcZar/bcFbeK6YWz7f1Yj2tDR2Wq7ry7td316bHsPibTPgvrXh3wZpmm/FG70HxD4 B1gX+geI08K63q/2eOWXxHLeW91o01mlnd289r4t1iFQ8gu4riS3uY7gxwx2h4TxH8H/ANmb xL4HvNAvfGesP4y1rVLzWdU+I9roXjATXOoXHiK41q5a38Hi2k0iJLmG7n0/yYd4tIUNyf36 lhr3PiDWvCGr+MdE8UeGvhnc6j4f8JL4gsWtfA/h+WKfUJ9S0O1sobhotKtEmhaK/lWWJooo 8bC82V58i0T44eINU8Q2drF4a8BO8t5rbyabB4A8KQW8Nnpv2yznkgd7WNkeK9l09Agu281J 5n8twm6LowWTVa1VZlN5k2pUqX++4O9sVUjhU/8AdGtqz1ut/kYV3SoySemia2vrbe1lpe59 jr4/+HD+NPC/jq88b3l/rXhrwRqngGCOLwnr8drexX+q+GNYn1GRbfR3Edyt34egU2sbGOOO 8IZlHlF/Io/DHwdfxdpnjK38a+KJZ7DxnH4yjhfwb4lNv9sTRfBugR2jTJ4fhV40XwZbXSlF 3vNeS25RvLTzLnwX8QT674G8Z+OPGXh3wjc/2P4Wh1+ygtPCHhe2tLW/utHvdXKvbWVjBO0U n9nuk3lXDyrFBDHDOHO9vKPF3xL+IXgnw/ouo6hpvgOSbx1Y6n/wj9jpfg7w40OmXejalNpd xKRcafaeS8801rdQGe61GMzxu7rbxZgfmjltdZhiFQr5hShhqkcNNPHYO7dWlHEpr/ZbWtHs vnczlKFRQSS21tra78tdrfgvI66++F3wE1Hxf8UPEl7rnjK5T4qsh17w5F4c8WrA9wL/AMJa y+qWF3B4eOoWn2i+8JWdzJbySPbRma7to1jjaCKKSTwr4I1K48Hnxl8VvHnirw58N77Sta8H 6RB8LdU0M2t5oJszp8Wparpvg6S51gWtpaHTsxpaLdKZrp0lnMTRbeteL/Enhv8AZlk+Kk2m aL/wljzaJbR3j+FvBUs8Rv8AVdLgnjht4rFLBY/s8l0sbyO0ogc73ac4rzn4lfGzVfAGifC+ 2vY9Ci1e+1NLzxrBfeDfDM3/ABTKmzvJoIW0TTIrRr640zUrRo2tZJJEYSKLi3mMgl0hiHGp WjWxeKapTeFl7bMMDGm1dp87dCNofu7brW29yGoUnG9tPw26v+rbbs9T+Ki+EPiB8RPBfxP0 fxr498H+JPB2h6hpFmdJ+G+uanaXaai+qwSyTW3iHwTqCmSC01K5RTCPLJl3MPNiBXhPFvw8 +GvjS4u9a8X+IfiTrOq6n4Os/B2p6nD4G8QaYL2Kz8XQeK4rg2lj4HS2tro3FpCkq28cUJjV tqpv8sdj4X+OnhrVv2grr4ciHw/JoWq2tlaeFoj4UZFi1Kw8Kar4j8SyTXDWv2lImiudIa2M 8citPHPHEioC8nm+ufFvx5afETXtJsbywFla+MvFWm6Vp914S8DSeF5vD2kT6xp9vJGo0VvE J1SK/wBPZDPfPF5scEjvuWSHzfLy/JKuGo4LCYWjSeKw1GioQ/tHCycaM68l9UcVBSU5ttKN k2prTWJNacZw89/nZb/p3+bNG2+DXwXk1bxzrUNt8WReeMG0681Wf/hFfGTQQ3Wh2N9pyWkM beAgsH2lr+4ecyOWhktNibF8wV2uk6D4E0TwH8QvAFlofxQudN+KXiHxF4m1+ZfCvjAXtlea /b6bHexWpPgKWOBUSwUw+egCvv3RMFKHzXWviJ8WdB8GfC+6k1rxFZ6v488TeEbXUEGjfCeb 7TaaxaXlxq8dhs0ia2iN1c3lpLG2pSM8ReNI2hjF4lR3HxK+OGn6vPY3+r3MGoabD8P9OmFl pXgH+x01jWfFGp6FqKeIs6eb+ZruWOG1ml8OI9sqhpIWSPa49HE4HM8TJUa7w9OFCFWsovE0 5OLVBws5xfK3F72Staz1uclOUaMPa9W3+DSXlezV13Xoe+ahrmh6h8SNG+KMvgn4n6jrehaH P4f0zSl8PeLLaxSG5TV45L+dY/h0t1PcTR65f6XFbCWNM3Vvcxo00MZflLPRdBiv/jRPD8N/ irAnxzsY7LxVZyaN4tRLGA6XrOlTtphuPAAuYmli1+8mYySPskMXl7Iwq15t4F8f/GnxB8Pb 3xhdeLdaS+v5Tpml3a2HgKDRftk2t6bpENvY21vozaxDqcge4Wzu9RjXT7XUXS8e6to4baeG pH8V/itrWo6B4PsvG3jBta0i41eDxOIE8IW2pm4k1ixgs0udUm09La7s1jluktxZ3EkkMAtl lCSRkLyrgzE4nDUqcqmFrKWFwOOo03iaScK2OwyxCnC696SjKcVFe81Ju8rXM54uLan3fK99 Ho3f7vzPaPFcMPizxJ8Mdf1H4MfEua4+FVjrGj6DZhfE1lHNZ+IdMtNB1GG+3+Bo57h5bC0j jhkiKyCbcYSJmGPL/DHwr0jw54j0bUNL+Cnxamt9B1bTNc0fwzLrF/Jpn9pWN7bXNvO1yvw9 XXLrZeq941uNY8qVla1EYiAjGdpXxx+J1h4wvvAeveL9fe08Y/FLTPC/g/WB/Zlxrmn2ml+L tPh8TwXGomNvsZbQdR0tLOeK0uXF5PfS2zQzKkq3rf4ifEbRvg5p2u6R488f658RdW1+7ns5 dRvtBdYtB8OjUfEF7FbtJbabYWokg8I3tvLmQX08N3e20UiLeRvFzvKaEKOXOlh8GnXlh602 sZRbqV8fXWHi6yT/AHV1hIpOVvdu1s0kpwmk/T9NOv8Al5WOx8UeEZfFeg/EDwfqf7M3xFuN I+JGu2Oq+JIF8W6tp88t7pmt33ifT/sDv4QS4sYoryS4M0LNM5iEcMzq4xJyvir4Zvr0ljfS fsx/ErTltvCNj4NL2fxOtrOPVNC09rybT1vX1vwNqCzXDi+vibjRv7Ma4WWQxKohi8nr7fxf 4l8Rjw94ri+IPxSg1K++HP8AbutaRF4lW00xPF1ldfDvw7qf2azikaCOCC41rxOdsF2beeaW K6SSfbCTwt942+NR8Na54a1Hx14gXU9M+HOo/F221T+1kM0Ph25sJLDSLCC6gjZla1uNN1K4 Swa1Vrd5BIl/mZowSwlaEKmNpYzBPl/dzwTxVJwc/aLDuvQ5Zc0uVKNNvnkuejNWXLyqEoK+ 9r6L0t+fy2fU9G8axeP/AB54FvvhpefsreIrTQ5BZzGyh+LGnSXca2OtweILeWK/OhxmSFtY WJnJMojLSLLIbaKSBPnLTvDXh/wgdY0dvgL9i1m4W303WLDWvj7oUN5KumXAkWGCFrex8qSC SGCW6ESTuFRQ3lI0m/0P4U/ED4r/ABF1QeAfBvjG5urd7jd4w8ff8JF4wmvtP0NH0681ez8M 3vjO+vdZt9UWwutNjtmbw29nDLdXstpcxXX+kx/XJ/Zr+Hl3Yw3UttrfiLxQVEup674i8YeK Lu81O7lYC/vZbhNQtxBLcSszkafb6fEybImgWFFhXupVKfDyng80xWLhhc6wiqRy/BqDxUnj JUas8diak4Tp0cPLklFSnS96Uo2m9SK2GdePt43tR0fa717O9/VdfJHkes638VPiePCWuyfs zmY+C3mufDJtfi9obIZLn+xbwqzKkAuo5jpWlbZZUlQCMlCBPKGwtS034zy+HfE3gey/Z0s7 HQfHL/aPFKz/ABQ0a7e6mNnp+mqRdHVbZrVbex0izZVspLcFmLzF2Y7oIJPjn4Y8Qat4J+Gm vxSW1nbWesIniPUBqX9m2Vze6rpNhp9jd36S3Bjjj0mMOs32mQ+Qkst5K7tu9q+BXxa1/wAU 3Os+BfipbabZ/ErSNTskmtNMsSunXOla3p5vtOeC9sry+tfPNvbXaS+ZNatHIkYZWDCQ5Yzh vGxy+tmOTUsNjsNh4YbHeyoOVbGLBz9pOpj6uEoN1VKhGjKc52jSpWi5qzsRhcRQkvZTWr9x XaWr0T87N+fl3PnDw78B/EfgyCXVrT9nHRbdprOOxuLm8+LL3KXrztZXL/uovG0X2clreIo8 QWMi32gnzznqPhN8KviX4DurnxH4P+EXhHQ/7SgkhElz4nu9QSK1XUTdGaWXUviW8RJmhW6d vJt1ALIFSEbB718QPjR4E0TWvE/hy+1TVkTwLFYXXi22hsbtrO2Fw+k2FjaWDIqy3NzG/iPw 5JcSQ5hYm+b7XLsdHxvFXxJ1vTf2ZdS8Xlv7B8R6t4Jvrjw8tlEojtrzUvCniPU9N3CG5vUh lieDTZGke5kVJfNJlkyWHHTxGeLK6NLEYKnGjjsbSwdGpi8JjI2niZUKcXd1YL4Z2sr37M1q ckNYK22mz6W/Us2Pjz4/XGv2eg2mi/DfT7WTzGE76fe35M32aS5DCRfihDGyo8UalVYBtxj3 CRGrOg+CfjkfGC9+OjT/AA/s/iVr3hOPwTqUp0PXLqwTw3ay2dxDImlp8ZRb/aZ59GsC0kYW RFlc42bs5X7P2qatrfgL4a+Idenmu9ZurvxINUv7qQSXNwtp4i1K2hQvFI4ZItOSCJQDnBZe ucfWXh6GXVdevb2QF7FRLZ2cfmMqhoIrXJ8rfkHIuTvYjOemSM+Rn+HqZDjcdhMDLARq4Ryy zMOaTi518PKFOth8JF1YylzVaDqVFJTl7SE7KNnFTGEa6UZpNf8A22+t+9/NWZ8ofAT9iu+/ Z88T+J/GHwx1zwf4b1fxwbmDxBPqHg/xZ4gt4YG1ybVbyG0h1L40yx27XmoyvetJJ5zWfkC0 UCIuh6X4xfs/WXiK81DxN8Y/in8OLWXW/CNz4X1W8vPBPiTQAPDlodbnkt4La2+NEP2l2uPF eqxNqNjCGhNzFI5aKCFE9o+I3xj0b4Wx6xq3iK6u7fSNLgvrOC3is5dRl1LX4rNr6309Y45H Aa9Gn6qJrueWwgMxUvqFuswkPyZ8QE8b+LE8MeF/i9cyap8VvifGieDdD0fUp7Hwn4b8JXU2 n3XiFJINPubHSv7ctdPu9fEc+pN4kXzNI0MWk9w0RN31ZDgM9zvF0sfj8Vh8FgvYUqX1uTlT tSpQ5KdPCSqSlCUKCjyYq7qcilTbcL3eVepgadNYaSvecXpZfC10+d1oep3X7Emm+NbXVpL7 4j+HL7S/Efhi68OXkmn+BPEVubnS4tSTUDb25HxXnliiXU7FGkvkQsJY5bUXKAmJbnw3/Yfb whonivw38OviuvhE69os/hHV7yH4fT+JH/smddQskube21vxjfi3nsfMMyAyS+fJJslDooUf RmrfEDSvg/4FtNS1/SZEkufE+ieDdIt7D7TqEVy3i7WrOytgiT61GLby76/vJ555JbQRx20h WO4MiRXnXaV42vLCK0vrXSEtI9Zit71ZQqNK8V2EvI1lA1aXawS6BYYYBgRvbGW8DFZtxhgq GIq08DOOWVsXJZfXnRxP+0VKfs5wxHOpRpyg1TjrBbwfySo4ScU4JPbqtX7u+/d9devn5r8I /wBl3xN8HPBPg/4V+DPjxrFr4a8P6bpmhW7T+BfCF1ceRYaHpPhoT3r363c8tzJpukWgnW3m tozIjNDFDLIznN0/9ivw5oWu6Z4ltfiT4nt/EGjzxQ6fdroujGW2jVnu4pQt1b3WkywefO8f kXFhNc+c/nNd/ZlFqPqDw9eeI9SuVa6tLGGAyb450EYnUtG8iEstxM27esW47W+83J5I4sap 4mv59VtbzVHt7u0tZb4eWyqggt7W3kUho4pgXMrHK8EqMZA6/H4XibiqriMXJ5lQ/tCtFtu8 26y9y6aVS9TksotQs4qOuqbe9WlTairXXKlvfZJ+m9+nQ8utf2UbOw8R6x4oi+J3jZdb8Rym TW72PSfBwjuAN0kU3kzeHLi0XeRGWjsI7cq8m47Y43iPNeIPhEmi+IGj1L4m+PLlb2Geea8t 9O8CWs2IL1hBD5P/AAgl/EsZFxeyl/IWQOVV3KqiN9SeB9W1DUbT/ib3JuIYnlt45wB5shhn vYgWIUOfltlGWRchegzXP+N3s4PEFhPNp8N+uoafKkcMsausZe9V8hXmgCEiUISHcgcDgZrO nxJxBWxlahis1spYadKE6Ek7TfL7WE5Sc4pQcVGMbKUPeU3K6tlUo04wiktJLXbpy9Lebd+/ 4eOaZ+zL4C1u7g1uHxz45uXuC8cjGfwmJokiR7YoWTwfbwFEKJOI/sS3LOynz2gIQ4/iL9jv wReG6n0/XfGdxqUVz5sTXV3oLC5ErGO4zFFoenouVbzl2FdgjCYYFi3sumaf4u8NCDVIkg/s o3Co1j50MoDyOInYQtIgGTGW4n6sTjkgezaO/wBqXT7+9hWMXSF5EjCgqzQSEDajuMblHAdw M5z6RPifPcBjcHXp5jiMWpUoJxlOLuqM5VXG8Yq10rauyTbsjbCYeMKdSSWvJJ6d+WNt1r33 vc/P/Xv2aPhufhj4+1uW08V22ueGvBHie9hEusRJDPqWm+H7i7twYpdIVGje7il3GKR4Sny7 iNrFNJ/Z3+BNt8LdQ8c6xZ6vqDWOheJNWuTJ4hvrMTtpbapF9mDWkCpA0tvZ20KkWkrqzrMI pjIFf63+MlzZ6N8NvG1pPbwJca14M8VxwJZwBUcT6DfRA3BHlKDvkAJJfAJOCK8A+Hf/ABUP wOuPDupxtqXiDxR4a8W6b4a0y3bydNkmvb7xLpx/tMzSW1uJzOFlinklkSJIrZiwaIxD3cDm 2aZnklPG1cRWpYaOd0HCSxVCPNGU6sa7vKEk+SUqn+Hld7u5E4SstH89NdNvXfXtofDPhW3/ AGf7/Wor3WvhB4j8N2GqXeuab4S8S654y8Z2/hrW10i81K0MEeoXHh/SdOS4u00PxBfwXE+s RwzGye2tIZ/NtDJ0/wAIdM+FXiwahf6l+zBrOleEU8Pa3rD+OJfjHr+ordw6bqcEF1c/8I3Z aVYamm2CS+u4tNhVb6aOzNpD59w4nrqbb4JfF3xn4Z8GfB3WvAUHhjR/C3j7xvr2pePrjXPD TywaIb74lPoumaJcaV4l8R6whuLvxFokfkS+D4I4rF9Rjnu7d1HmdD8H/gz8WvCmnzeHP+FX a7a6hFo+safJrup/E7+2vCszarqpu7G7Phe4+Lmp6ULBoZUurmyXwNFC1slxYy6VKk8lhcfZ Y/GZDjsBiKf+s9bC4mGL9kqazXKqbdOnKShPknQlO0opvm2dm46ChSrv3opct7Xs/Le3+f3H l/wy+I/wg1nwv4t8Y337NSaJZeF9LvvFXhi5tviz4z8RWWujSdO1a41a11i9023EHhp7S68O fZ44tWWzurqC9iu7WC4hktZbjqpvitretWaaz8D/ANlXTPGPhu00Dw7qPiTxLe/F/UND0jTP FnibTdF8R3vgSO68SXelW1xcaTpfivw/fx3dtcXE1zEzRsokS+jteS0f9lf9ox9QGiN4Q8L/ AA+0Cfwt460DxfpXhvxreSeHPFOqeI/CWvWPhpovD9/4m8U6bYpYXOp6VHdzadpfh4PcTz6j crqV1CL2L0XTf2bv2pvh/wCHB4Q8G6d4L1/wF4g0/wAP33iTw/f+Mdd0fUNP+IGmaNoOiSXt tqPhvV/Bl1/ZK+HvCGiRIkWr35kur2ZZLc2oEem+PiqmQ4evUhW4leMqypQgsPUzLLa0ailL dUqNKnUctLRcZWV3dPZaw+tN8qjr/wBvdLX/AA6vut3vo+G/2rvCEHxA8UeANb8AaP4Is4vB 3hvWvB0+o+J/EM8upeI9e0DQNWHw6le6ggig1AX3iJ9Nsbi9lg1C+h0O4u4bWVRfNba3jT9s W98HXn7PcMHg3w9Pp/xZ0/TNd+Jt9c6vqYj+H+hXUXhy50+/gWLab2K0uNQ8SygFzNdjRlik RRIu/I8C/sP6oLDVpPiy+n6zr154B0iLw74os/Emp3+sWvxE0zQLKx0zXLfVr3TxqKDR5zOL W9v45Zf3VpLLDdNHuGz4O/YRvfEOlXsHx9vH1nUfD3gHw54E8Fy+HfGuv6PFp5tLLxDp9xqN xH4bttDt7iea+v8AS5ba6u7e5eJrHeLK1iVo7njqf6jJqvjc0xlaDalVhgquEn9fiqaw1J0r 0anMstr8lSs43UPqtTntytLX2WNf2W+trNvp5272/wCAr+keK/ih+0No/wAb/B/gLSP+Feab 4f8AGShrLUr3wnqWralBb2Gg+I9f1G3MkPxKsrWWa5m8I6jBDJLZWjW8FwgSC6mihkveG1T9 p/4salr3h34ceHrXwjaeNte+JfizwV4g1+fSrvULLSdG8O+PLrwNH4gsvDza7YxfaXjvdL1d 7KfxDfLHIkliyyiZ57f3Hwp8GvHLwfBvxD8QfEFvrHjT4d63r114l1+2vVZ9S07VdK+JWg6X ZKy6HZ/a0tx450YvGLaxCCzZzNMbYx3fD6v+yJfXHiHxT4x0bxNdaF4lvvGVx4w+H+q22roP 7Pvb3UdZ1zV7XUIZvC+oRDTtS8TXOg6jc2b2935q6ai+aixtDc+Rhs14OqTq/WFS5sJUqYah mE61GE8VBSSw+IblPlftqSc60oRjH2krRUU0jWOCryipNWlJKT0e7SbVmr7v+meDfFH9rP8A aD+FutXfhHV/DnhHxJ4k0LxXpNt5djpV1pj+NfCN14ytPDiXttp9vr+vNo2oatBpniSe1t4b y8u4bie2tk06Z7WEX/vvwn/aZT4l/Fz4h6Nod9pmteEPDPgjUPE/h42Vvcw3FzHpen+Fft0N 281rFeQY1fVNYXddQxSCEWzRwSW7W80s+i/spXesTal4w+K3iEeLfiDqHjHwn4g/tg3NlLY6 XaeHfFdp4tt9A0y0Xwjp1vbaVeazc61a3Vj9hnjuNNv0s3vIIgJbft/hx+yn8Ovhh8XvFHxC 8ELqWk6J4j8OHwvqXhh9Ve502KO9i8Nx3qWmmzafIsDXo0e1kl26o9m7XN3JJAs1zNs2x+ac FSy3HUKNGj/alXLsbh8Ti6MPrdGtVWHtSpUXRq3jGbq2hzufPJyUdUzeng60G7p62S0fRq+6 /padmfO+v/EH4023gT4i/tGeH/iHplrJoHjPxBodl8OLjwn4bn0ax0bTvidq/wALbD+1PEF1 cQawbuSy0+y1i3lllsjcXclxALe5tyrQfIM37U/xblj8b+KB4k8VafrZ8btpXg/RLHwPo2o+ Ek07UF1/UdDsNd1o/Du9ayRruzjtLy81bxPos0OmQSXd3PYkvqFfqH4l/ZF8OeJNR8T6NB42 8baV8NvGuqvrfib4e6X4jSw0ae7S7m16OaJB4an1DT2/4S+7l12a30rXoLS5vLmV7iKe3itb eDobT9kv4Madp3i/RrXwyt/ZeMbzOoWmoXk0sGlxrBrFr9u8OXSR2+p6LrMEWtXEVpf2t0Jr ZFgkhljuIFkN4XiLg7CZdChUw/8AtEJ4avFfUqylQgqODpOMr1U4e2q06qhdK7qre6QVcBXk 42bs3HZPvF9v63R5X+0b4x8XFvgv8OjdQeGPD3xl8U3+g/EPxQljbXd3omn2fiLwTZ6Pb2p1 A3Gm6dc699uutGt5rq3Z1mvY7mKOWWOAV8cftY6TrvwG8L/8IH4K+IV94r8PeOdNv/EMun3u neE21vwbP4L8T+A47W9+32OlBL3T/Fb/ABC1W6QalpccdnA2mW1pcTybbmf9Tr/4JeCvFPgy PwP4jfxH4kTRmmk0/wASaxrk8vjbS9VutRh1zTr+08WQ/Z9Ssb3TtTtdLuNNvNMmiltI7K0j kdxbhB57H+x18HZIdabxYPHvj2+1rS7XSUuvGvj/AMReKZtL0jTdT0e5vbDTJtVvy+kLd3+j eGfMl0rZcaha6HbRajcuqyJczgOMslwVSjXxWWValOObY/F1aSjeWLw2IxuJr4WhSTl77weH q0cJNR0jKhJPVWOj+zq3fpbboreXp/TPyJ+J3grxNofwU8N6s/wV8X+A7TV/i74GhfRvEXjv Rtbfxpotz4T8V3JjtNUTw1oh8PQX0W60TU2tp1UzPcQuPsksY7TxNoXxL+FOjfCu70L4W6v8 LNeu9T+Lklp4avfEGl/EF9QvdS8PeFtA8P30dwlnvBudVkltYNOQqXnh33BNvKmP2Z8V/Cj4 e+NvDmi+EfGWk/2tofhW40670e0a6vt9vf6LYXGmacz3W9bm4FjZ3N1GjzyvIxvJJDJLI7sm x4o+GnhPxXqGmXPirQNM1S98LXNldaLK5ufL0uV7621AtBGsiRkSXNpbzTq8Ugk2BSGHy1tS 8QMCqWDhGGbzlRx1WvVq4L2bw9alOpQcZxcqVVtyjCSk+dq60slpcMqrOz133s7dLdPU/Kj4 eeHv2edH8H+FPi9438Xtofxvmv8AxGfGMVhriXHiRfGF7rfinStf0K6+HEOn61dWdtDaPdag J7Tw/BHbw2ttJ9ueBpZrvhP2YdN8O+HNY0J9Rn+CuiNpXii/sLmTWvEmrQ+LLlbDx9cxyGfS pPjVZJZajcJZfajB/wAIoo857dYLHySbe6/Uw/sy/AmfxfceKz8N/D934meW81B2mF/NYT3G oLLDe6g/hq6uj4Na7mF7dB799HXVJS7Xc88l9LNcS2R+zF8Bk1mTV7L4V+DzqtxfPrqyNb3w uWuLm6GpS3d4puVsVu5bu4inK2WIN8kwKqoQDfEcd5XisPm2Fnhs/qPGwouhBqjZ+wrUsRK7 +rOy5aTd1du3Tc66eVV1JSV0/NaarvbTrr16HwT+1B4J12+/a2+HPjnwRPef8JtafC7Vbzwt CtlbX+l69P4bsfiFfXPhmWC5MKW76zbi60db1763uIpdajuLFZrmxhhfxb4Z3fiaLxNp3xQ+ KfhjUtH8MeEvi98StF8baLBpWrq2geKtV0zxzcvrE1xYRX2szWN1qfiq0021itLC40nGrWUs eoyCPc37ZXXg/wAHapqdj4kl8O6Zd61pCNY6Fq09jajVdNiuzJHd2VhdoiPaxXgvZ45GWRDi 8nYTRE748+X4eeCLi112yuvBfhl9P1nU/wC0dWjk0fT7myvNd26eJ7rWbW6juBf6o/2KIzaj 9mu3lmjt5DePtd1zyvj/AANHD4PCU8prz5KDj7tSnLEpc61lFdm9f3aS00W5pDJsRUqdd9dH dWtv7r7/AObPz/8AgX4g0Gz/AGiv2hfiD4Mi1RvhbrGh6df3PiOPRtf1DStc1VEsru+GjSTa YdRki+3W/i8TSWJv7aKSJIkaNTp8c36P6esktsMuTGEjZGwg/dsg8pWXAYsNvONrDcN6qMA8 9pPgjwRoFnNpHhnwr4Z0rSnjlg1HT9J0Ox03T7iB3mZkW2gtLZTGftF78uxGzcyswLyM1dGs yQrHAFMLggCOMYjZRsXDctkIFbaCQB2zmvgs7zWjmE6M6NOpRnNKcqVVr21OUlTfs6iVrVIy 92a5Yq97pbL2sNhZUVCE73ppQfk48qfTTZ6W0L+0mNVYhQG5YAHHUnjJzwff86eZXWPEShsD aCTjIAIDEHAGcA446+1U3mbcEz1xkDPv746VL+9ZDsAGB3IzwCB3/lXltRaSl8UdXd+i/O/n 2Z6bSUY2W+uvolbp23vtsXEkZo1DdedwxjHyrj65ORgHjHPUUv2cBs4J5GfmHK8buh44B96q QyO0cgONy7ee4Jz3z6jmrcPm+am8naeCM57n6n/PpR7aNNNrotO+nbW/qapNLV/n2S/zf9WL UbLyiLyBzkkcD3bA7+tLbh452KqDiF1GWXks6bx16LtTB77jg8GpSIv4AQ/O4jI4z27cnH/1 qkgWIs7OWBjUsSCwzkgsDgHP3BxwKzlV9lOni9LwUa22l5Wl363XXXTa7Z1R0pPrtsvTQ+XP gda2/hnxx8Z/BtoStnB4l8I6zZGYkztDqngHRIpZMvnchu9GuolDNvXynO1UaNn+q7cjCr5m WAyBtHOck9sd+1fJb3Q8L/tOahpERMUfjDwt4YvDGoMizXGj6Z43jlkdgVERWC3tlG4NvEYA xivqK2nY7SDg7fQf56V63FtNzp5fiVe+KyanmEu7dSeJp363sqCW/wA76LOjFyw85bL27v2+ Ck3vpt6+ZoSAeamTzHggj1Dck9R2HH5V+VX/AAUW+LXj74Sap4Zt/hdBpV74w8Z6bPHpGnan aC/bUZNH1LQorq1tbZrq0G6XT9TvomleaMQM8VwokMJR/wBTXdvNYk9EMh+m45HH8q/N39uL 9nrUvjP8SPgn4tj1TVdJ8P8AgS18XNq97ouv/wBi6jDNrB0ePS5IIfsl213i+06NZPkIigaX KsJTj6jwYx1DAeIWRyxj5cLjctzSnWbcUrRwk6lPWTUV+8oQWqfpfbyOJIVHlFedJXnFUGt7 O+JoJ7at8rk0k9l2Vj5Xvv2j9X0r9lM/F+6Glab8QtCfTNE8Q6OIZrmCy8VweKLHwv4pge3C TCCSK7n1LbYFLjyY/LuILie0MFy/6F/8EhfjP4j+Kfg/4p6L8QrXT7b4q+BLX4cWvxCbToJt OiuNQ1i5+I39mXH9jM11a6Ss+m6THcR21pqepKfOYyTIyqp/JDx7+xh8VvEGmeKPhZ4W8Q6t efBTxb4iXxfqd5deNY7XxnF4jl+x6pqot9Uewtrq3sbrxTYC8a0ihlhZL25KlFlZYP2s/wCC a/7P/gT4Nar8ffEnhG78XX2qfEg/C1/Elz4q8U6n4iadvCdv47s9Kms4b5zBpzzQ6tdPefY0 j+2MYGuEV4EVf9AcjqZLXxmGqYOonXSqOnHnpybvh58+kVeyptv8+p+WYpYtYWr7VWp2g37s le86dt9Pit+S7v8AVCiiivuDxD+cXwn+2D4o8DfDj4eeH4/DXjn40+LY/hZoPi3xxqGmXjXa aXZwaDpNlqI1XULez1/UbbU9U1O31Gc2t9ZadbW4guJ47xp5LqKLlvE/7aPifxJ8Rv2cofhf 4J1y48IfFGTxBJqdo9xZrdXceg69daRe2s0Gm+HvEKQz28el3dyi6dqkTC3ube5nNvLK5jhu fhN8avh9rmoWPwms7TXtG8d+DdJ8G+Jr3WLDTpZvDI0q712G11eyU+JdIa4aG18TXkosZ4bl Ge1AnuJjIqxa2kfsueIfhf4v/Z6l+HVyNU0v4df8JPZ6ouqw2LyoniTXdWvry7hmfxDZNbst h4huQqyW+sRFrCJ41iZ5oT5mMVLD18TjpKDozw2KkkkuW8KMEvdty3TWjWz89D6OhOqsTQ0l bnjpv9pLa6v56ffqfoTY3dxd6RaXt7bSWNzd21pdNpcrOLjS3uYYZpba4LxW800sMsksbNcQ RP8AvFGxPLjjWNoIgoZY4hkluEUZxkk8Dk5Oc+59aVGujbQi6WNpxHDDLIrxkLcLCjzxqsLm NyswlG5CUCcDcV3mC4v0jjCbDkfKT85/hPOBGenpnmv8zs+qxxWf8QV4bVM1x9RSSs/exVR3 b11to9dtD94yx81DD3X/ADCUtH/27uuuvX/gnkPxuuZo/hf8QxHNLEsvhe6tcpI6bHule3yp VhgkTrkKVY8AclTTPg5YpH8KPANmHKj/AIRXS5nYPJH5k86rdSs5V90jyNK0sm9mLyEysCwD Vz/x5vw3w41u0UGNdTOjWkjMrZzd+JNIsgihkXDESALyCWccjg13fw6shbeB/B1vHGStr4Z0 EbGcBmK6PaRNLnIKgu5GzDBTxkkZHrzvHh7CqKXNU5OZqMW5Ne0s5JpqTS/mu0tN9vGpXnj6 ybb9521ejThazWqt/Wlz8n/+Cgfw6+JHjH4x/CTxJonw/vviDovgHxNdeKRpsmk6zqVpLLZp 8PL6GJEtPDPiCyVpTp19YL9pjkh2tJH5UiCaBfd/2cfH/wAQfEPj6zsPEX7Ldl8MtNaaOH/h Jl02fTZLSH+ztZYuso+EfhURxq0cNrsXV4k23zxbgrmK5/Rk3dyblYnDGJmBR8IRG7MmSdkY LqC7HaWBwuN2earTXbNKoeERt5u8uXLEkOG6ABQCykHjox54GPqafFdeORf2bHKsNGLpSg6y zOtzPnspyWF+sqlee04+y95bpnmf2KnmHt7R+O/M2730V72v16/8PQupZYoftcwiZ2ADjz2u ud5jVmeeJdjbFVQgXG3DA5dhXinwPtyfhd4bm+eU3Y8RakYy0hH/ABOfEurapIxG5hvla53T SKuJJGZxkMM+l+O72S00nUNSWICIiySQ8iNZjd28YJZ95yY1RdgGMnd1znjfhB5ll8LPAWy3 aMS+F9MWQyMXx9st0uC+MKR5JLKV48zOcpjFeJQdelwzVrcqcpZvBOdoRbThg7JqyVn221vb U7MTBSrVItX5ZWvvfRWte9/Lqji9b/Zy8Aaxqt7e6lb3E0M89zfS6dLea+2nSzyzz3KSTWP/ AAkUdhI6XAidWezba8EBQL5UQjybz9nT4ZzXyXEmkiS1aC3/ALRsIb7XYdL1SaC/SW0k1HTo NdTTbxo5otNRjeWlwWjsrYP5iwQxL9LXc8JilZU3vLFEud5AUxyM5O3aCwbzCMbhtxnJrgvF 2qjw94S8Q+J4NMm1W80PSNZ1mLR7S31KaXUX0bR7zVIrJZbNLx45byWzS3IjtpZraGQXzwS2 8bh98HnuPcqmHhVrwf1yhGMYLDyTcqVlB/WJRpwTbV5RakmtLJyOCvhcMoSqYnDSrQSdo0Yv n50rpvllB8qipJpu13G62a+Lv2rNc/Z8/ZZ+EumfFnx58JR400Lwl4os9G07QtEvjpd+bzxj FqcDC0urnULeKOC3USyz2++QPHbII4IxGDD7/JoPwIfS/Cuqarp3gvwjL488HeHbJdO1G903 wzc3mh3dvNcWkd9Zw39lHdW1m2s3kEt8kdxJ5lxcReayqi1+RX7YX7Slh+198MPCXwJ8EeF7 1fipc/Gi+j8U/DzR49evvEeg6F4D0H4pLPrOrPqvh7T7XSdNe80jw9jUL77JaXE/iLS7Czur qfUdPW9/O39uXXJfGXiv446n4f8AhFrWnfEbwP4d1D4b+GdZ1DR/iNres+I44NS+MFxazaVo FvH4e0Ww0qHXdP0y6Ot6joviDTLi61W1sv7aW0tbi0vf1rKuEszzPL6UcXm0crzH22Jq1FVx uXVIfUXKlLAS5I1a9NSlS53JeyUotpTu9Y/GY7OMDgqjjDKsbK2z9nJ/ytb1/PZv7z+nvx14 R+CmqeKz4g8c3HhbT9fms7NSNf8AEK6NZXWlaaxu4RqkT6xZ2upKsthNJEb/AEq7UfZLUGfb p8AtvGvjr4n+D/wx+GPh/wAT2Xw0074p+Fv+Eon07SNP8I6v59gt1qn9tXeoXVnqVkt/FHai 9tb7db2waKaSMh47c2axxfj98Vfh5J8Zv2xNE8CfEHwprfiD4beGP2W/Hniu41Sxj1LR7e48 U2lp8U7ax06fUNMiil822tfEMd+LOzulkuvJt4XibzJd3FW3wu1u1/Zs+H3w30jwn4jtvCut ftI/E6xtbH+zNUnuNJ8K+Fde/aWvNB1B725ia68m88rQ4op9RkR7xNVheOSdmBaJcJVaalS/ t3EOEZrDPDxr4WOHoUINTTWJjUVarXhOUpxtKrN+41NpKyrZzSndfUK7219ktFZWtep3s7Ls f0ReHV+Dvw6t7fw5d3+i6K/iPRrDTx4U8VeM5oZxpxQ2AsYdO8Qa1ezsmZX01ore1iEjwvA5 LxiNa+qeG/2dPhvqVnZalH4A8N32tXFo2n6T4i17T4b95LCeFtPvrCPX9Ve7hsY9SuzKDp0Y gN3b3srRy3DS7/53NO8I+HvFXxF/aBl/a3+DHxF1z4tP+0/cRfAbSfCWm/EPw7Lqfw103XfH zeFvEkF14W8NeL/DklhL4l1p7a6n8SxGcteaVJcTW1hFMupdb+1R8PdW8U/tBfGrQfiF4c8b WV14v+H3w08I/CZbT4YfELxJNrGm6vpfijS9Sh8P6x4OtItDGq2/i3WNViuJ/EtvqsVgZtOe 50+DTLaR9QywnB3t8dBYriOvCGLw1anKUZYKKrVKEoyoVKXLKM+enDDwp1ZTjTfs1Wk/aPWU UM1qOXsqWElCE5JylUpwunolyuTlLq72srvyP6Q/ES+ENb8I2+nahpGg654XkttMv7QnU1k0 WR0aKCzmjaKF7SfzLfE9pLvfdazQGP8AdiIj8l/gF/wUd+EH7Qus/tdXWo/AfVvAlx8G/Cmt zeLL/wAXanocqeOdE0CPxPo9xaWN9PZWUiWVzYeFkljmuQ0cNjd2WQY0DH6o+D3g7xN8Nv2M /hR4DXTddudc8MfDvwhY29hqGkyWniWG1t9Rtba3hu9HFoJXurPTStvew/2dHcxyRXFxcxW7 wXCRfzheK/gT8cfDF38AdN+G3wR8dT6d+1yLTRv2hZ7vwX4xvodC8K63P4M03xJqMjzyWjeC dVtIvHniKS1F9PYKgjvpBpNzFpTvpmvB3B/DmYUuKqHEOcqjVpY/6plNdYuo1KvQr4hV68Y4 erapTxEVGXNWhNQcY+zhBTlfgz3M8dhlRp0cPze0cU5RhTurru0mvht9x+8X/BOX9pj4b/to /CnUvH3h/wCA0fwhs/hl4vu9B0XRdXvbLW71rrUoI9V1G+stQi0TSJdMS5MkcNwkSXTSJhnY IREfpD9q3x14G+BfwF8R/FHWfh5ofizTNF1jSWj0LzNPsiNW8SeLI7C5vhql3pd8I5jJq1/c Tbrdmma6mXCNKXHxH+x5f+I/2e/CXxKt7z4XePZrPxh8Z/C2m6bav4Z8YKbLTr7w38MfD2oa qq23hnVr2eytrnXr+8murqSC1jOm3kf2mG3tLuS077/gqvpfjrxv+wv4u0r4feAvFvjbXtZ1 D4YXyeGPDOhavqutGJPF+jXs6Gws9Ju9Qt20+zhimvftFqjQ7HSeK3kkCJ5ueZRlz48jRwdW GX5HUzrA1KeJjmWIqUcBgadahKtia0vrNfFVWoxqTVDlxN2uVU9bHbg6+Jr4FOVKKqcu3LTv tFrp1111877mb+0D+078NP2X/hl+yx4+8PfBzQL/AFT9oH4j/CrwAmkaTqejqfDN3460GbXI L86nf+H9RmW30m6iEEw0vStMuBLIjQmH7NDCfp7Xv2jf2aNJ8cXHw21zxP4KTxJ4q1OPSdU0 q91PwF5txqVrrF7bWlre6Ze+I4724aHWhdpp9u9ksj3/AJ0KW8VxvQfjl+0z/wAEzvCXgaP9 iHxh8GvBXxY1zx3Z/Fj4Xa94/KJqHiVdC07S7fw5qV1De6ZZ6PFDpFhcagkbX13dB5tOOnpa faLd5LoTeMeKfhx+2J8T/Efi1fEnwO+KPgy28KftTeHtT0fwl4R+HmrP4V8XfC+2+MvgjVX8 Z+IfEviTRvF2oT3GnaDoWtarbp4V8WeFhOukRGfSLxdStLe7+jwPDPDWcYeNbL+I5U8Qlm1T F4utiZ0nVWHr4ulSccPiqqSi6dGMqKp4de1k4OpG02zxfruLw9SUJ4KpUcZJ3UYuMtndXlFW t5b6H9Ah8T/sm+H9J13XYtB+HMGiwXml+Ftankt/A9rYfb9a1Dw8YNGvr9tVkghub2LU9Jki 06ZlnnS6tJoYXNxbmTyD9ov47fAf4dfCnxpeeFfAngzxRq/gj4d+I/HGk+FrTTPAmoQWWlT+ C5/GNne2kc8OuNaw3X2jR9tz/YjWd79vS5eaaMwR3n5q/tZfsoftFeL/ANpjxp8M/Bnw/wBd uv2adf0DSPjPd+LdM8OyanM3xo+Hvgexm8G+GbTxBJrzi30658T/AA+8Cy3Glz2Vxc3V7cXN s1+NO1AWMWV4M/Yt/aOH7Lf7TPirxJ8NfG9/8cfi34P1vwHovgiPRrS1lfwh4A8M/F74deC9 R0vT7KeVzca94atfhpfXz6lLI0+oa5DLaLZw3FxbDhocOcPYeOW5tW4sqY6FKGHlOg61ahVr 1adNU40J0cOqap0uWUpTdH3aMoKFJqmTLMsdiV7OngHS5WpuU6dKzSSVk7zu3zJ26pPVao/X /V/2qf2efhpoHwwHjceEdM8SeN/COg+Lbq0s7zwH9o0q4ezsLnUtf1K01TUdBfSUsLo3N4bq zso7eL+xrxi9oun/ALru779pP9nrQtc8b6IV8OadP4E8B6p8RdRsTq/hIXlr4R0q3tJtXvYr W51eOdt32q6jjub82unrJJ5cmpWwRNn4wfG/9mD9pSLx54yOnfD34n+NPDPxM+EHhLwFDZ+F T4J0zT4Ba638VYdT0vV9Wu/C3iq5sZzpXjvTg893e+HZLaHMqztO0s1k/wDac/Zks9J+N/wG 8E+FdXjn8YfF638OfAv4veFpr/SNX8QRfCLxJ4p+I3jHxTraaTZazZ32htDpWiaIqa3bwRQ2 loPOWU3N3k4Yzgjh3EYjL54PP4Thi5ZlOrCGKxyoYangIYGpTxEpSSrUPYyxNWcadaNJSs3G M1zW0hmGY0Ur4aL9IULaO+7inb1P39+GHi34cfFXwPoHxC8J6TZt4a8SWMl/Z/aYdJuVvrC5 vZlt5w1jeajp0kN7PZrqQFvdT2zt9nlSWZoo5F3fEFktp4c8VT2lpanUG8I63aaV5djbzG3u TYzvpbRwtA6Sx2s6v5dqIXifzdgjYEoeO+EvgLT/AIX/AA1+Hfw00OyuBoPgLwZ4c8LaZC0s 8s8lpoWjWumwyS3M0t5IXkEXnsWmlwXMfmONrj0UwvJFHbyRO5e4i3I0FwzRw7WSSVfIaIsY t6gZ3Al+UbK4/IsRJYPNq+EwuMxtehhqsFh5zjh5061Cji3XlOPs6tSpKM8RGtb2kVUlT5ee MU+SPuuHNhlFwSqTUalrLTm5ZNX6Wvolddtz5L/YYtvDsfwD8NXNjZ2Dawt34nbVbho7bTtU ml/4Sy4jU3lnatc+T5emHTwkryb3t4bYlUjZHH2LcXdhHaTXV/LZafYxyxC7vbu6jggRQZYL aO5nmEUaRtKYkgeSXMjrCipukAX41+K3w48PfCGbV/ix8PvEmqeD/FN1Da6XpeiGxi8TQeK9 XvLSPTbLw7a6RqtnqGtG81qSwsolk0+QPbR2ct2iRwfa5T86fFvw58bvi38Gm1z4zeJLrwb4 biuNLuPD3hrRfBekRatr2oXOqLap9tM8us64Li2060n1qWytNJ0poTNcrdwpbWnlw/pMOF8L xjmOX8Q0s8w2W5bVxNDLMbPMHmsMXDFKnPEV44LA0MDi1WoU6d4xjRXsYzjyxgtGefLGVcNT tRhGSirTvGDTk0uW/Mne6va1/wADzz4tfGCP4s/FLXta8JXeowaN4e8/w9app2s7bSfVdH8R a7djVPt2gzlLzTJLXU7EW9vdmeGWMPNJbgOnm+DQ+IvE+oa34p+OS6lff8JD4Q06zk0G8v7a M6pDe6Xpl+bTUbW6dJ4I0tLu6RrcmG4T7RYzKQjhsfXv7PX7BUulaTb3PxJ8Saraz3VlpM1p o1nY6VavZ3ZtrOSd9Se21bV7mU2jlrWe3H9lEksT5UmzZ9k/C/8AZQ8C+DfAmpeCNd1LVPFM WuPfWt9qF3dQ6XNe2WorJA2nR2ujzRLbRwJcS/v0kF3Ibp3+0IiQCH9yxXiV4ZeH2DeQYGri M2xmCwdHLI1IZRjatLG4PFwn9egq2Ip03LnhOMKtStGHsG19RqfHKPh0sqzHH1K+MSjCEYyq RipxinyRW0YpWd49r317t/mBf6l408beE/B/w4s7JfE2o+OYYvjn8RdY1BXv01XUvF6a1qv2 XXSmiatdlbN9S8LC2gmlt9HglsNKNhptoE08DqvFPxi8X/HbxQPhVrJ07wD4D+Bklh4k8XG3 v7TU7DW7CG1sI/7Htgvh7wm9vdS6NJrzaXbahq0MN/D9pdjbJbGeD7L8D/sxW/wq8VeN9Y0b SL6/8LXGt6nFZaJ9peK5axuU0WKzSLWJtSv52gtTYwOGl057mfyWWW5AkcnxTxL+yPr+pT3O saJqU0Ot+JfiF/wk/iSymsrAx6lbafqXiAaRp7Jea9btaW0VjrBs5ZdOktb24WRLh5I5wHXh p8b+GuZ4ijhatLBN4ehDMMDjZRzmnGnjcXzYfE06mGhGNGU8JhWpxjOjUjGoozpe8lNUsLjq W6lJ7P3lLa2ju9b+W+p33h/9oOw13wt411m+8Hy/DvTvANhZXum+Hr59Ps7+GLWWv/lFlLp+ kR2L6jqtjO1qGa5W+a7QxsJGaCsXxF+2Na6v4G0zwN8NLXWvDnxC1X7JqUerQ3ekz3UcUMtx c6jLGkJvNSjh1Oys2nDW9skMaXZgUfZczSepQfsufDvxHqF7r3xi/wCEn8UeJ/EWqabeaxfS Xy+HdPnl8Ow6dBo/kWnhuwtoIUtbTT9JE6Q3rNLNCZLghbmSGvpbwh8KvhP4Tm0m98NaZaWV 3o9k2n6ddyazr11LFZNBJA1tcw3usy29wSk0haUW0MvmlGVkjQxN+dZ1nvhLg8ynWq5TxBnF d5rH2VfCUqzweKqKlWjXxVRYvOMFipRr4iM6r/2TmXtLezglyx7KOHzCqk4VKNNO9oz5E1rb V+zlvum3tq2fn18ZPjd4EHxC+F2v+JbCbxlpfgrV9T1abQdNn0vUJV8SeHNW8GmymvIBfQQ2 0ksena3bxXV2s84+1zFrOYyXQTN1vxV4t8S+B/Hvj+8tfEGqeK9aiuNRi1C1snH/AAh3gyRv 7Xl8IwatZQxPprf2fq/ijS7mS007TDcQXcaXDtbhIbD9TdA+EfgHRNR1PWNN8O3ceo6+lwdV uX1TWHWa3kufOW4S2mnZIkdXWY28ASch1jWRSrZ+R/jn8TvhDpnw48eeDdF+LGgznxHpscOs 6ZYxjWNO0eM6nHBqOmXniS0W60+yfTbNLtWlvNVtZ5EiSfOZYnk6OHuLMhxeOyrK+H+GMw+t 4Cpk1GtWxVWg8IsPJxp5hFwr5vXpSVWnSmpOrQWLkrOgnVujnxeW4mjGWIxNWjOGitTkpTvJ JK1oRa7t3Vt0fJXhr4SfFPx7qPwFl8TfEXWvDOlah45k0Xwj4Ht4dXt9R8LSWFr8Qddm8ULD bXfhy5n864tfE6JMULw/2qkq32LWOG3+3fGH7KvxJ0XTrK6j/aR+It3azMCLNz4tkMEcdtvE Ecs3xDuGUKpaFAgiCqqgKoRUXB1Q6D/w1t+z14W0O8sdTh0DSdY8VyiO9W6lggl8OfGTSDcy vb3CILQXmqwWwYl8XU8cZJ3BF+/PFFqmv6dbaW8iQCBpnR4VaYDzYmTBTzdxC+b183LbTjGf l8jxG8Sc9y/F5HgaFPBZdhatKrj6mWLJsvq0PejWoqLrYzLZ42DboL3aDcVo/ilNlZXgKVWn K9SSs39qa6R8/v6Xt3O28N6YdF8O6RafbZ9QksLHTbSWe6aZrm5mtrW0t2ublJ7m8cXMzL50 3mzTy+ZnfNK6+YfK/F2lPN4/gtru8lhs9UsILGUia4jQF4bh1Dss0GVdoFVkEilg20hgSreh 2d2sUNuiOEKxRCUGNyDKsYDEAjKDcB8m5iOhc9ao6ra2OpyW9xqDFpre4jnSVZPsyKYYplj3 qwKbR5jEksueM9Dn+Z8BisT/AGjWxE6KUq1apUXLFJRVWpz2hzRjKMfeso8sbJK8V09zFU4c lOMbXUIxuvdb5Uld212/N+TOI0671rw1NqXh8pNLpyyhtFuIEZY1jWaS5dw7229mkiuyrOtz cliXLOQ2T6DfaXd3l1pOpfazutwiuwMnm7PMguCm9SPlypO1jjdyapT+ItEsrYQXep6fGsG2 OIteRO64IG0rE5JO3AJZePY5rnp/HVy6yroemPeIu/ZcTNNaWwTDCJjNeWkEOCAjkGbIjJZs IrMOjF0cTi60vZ0XFKrBScUo2jUacpXSW9rt3+93ZnRoR5HzWd7WTd+17dumyW6Xc9ZOpQPH MSMxxkl4XlAJCxq5kUZOAA2AflG4Hkda4zUvG+HksNB0+6u7q3crcSxujC2VSMsGhjvZFDOW h+dYQc4Jz8leXanrUt/brLfXsWo3ySxvBpekwpF5qRFvLDago1O2wZDI0ihUkClVzHt3traS NY1mJY9Ti/sfSo4UKW8AhN86ghYlnu7priNiHRJWMOnW5bdtwqCtYZR9XlWrTmpewqU5Uk5u XNBTp81ou6acea9/1JbakoRXutpWS06K11r3/pGZr8F62h+LdFsp49f1i+8P6w91qjoLyy02 0uLS8tGszGY9RWKUXTNcHEFqxiQruAGxcb9ka1sx8FPDc0gN5c3F14gljvHZpZY/L8Q6vDhJ XlkdeItuI2UHGCM5r0y8t7Cx8PazZWqmOO40+43lJHaSQ/YbqHMjTideVYZ8lYBuJIAGAvg3 7HurXH/CkvDyF4lB1LXIkUIP3CnX9Rc7txJkLtMzjJTaCByAK9HEVPacOZzCm/ZwjmGAcIxv CMealHm5UmlHmbbfKtW292FOm3VSaTV1o9ez9Oh9l28hTzWBljjDGNlDuqySDYS7AMFZjgZZ sudoyTgUovApO23U/OkudkZJkj3bJCfLJ3pvYK+Sy7mwRk1zQ1Qh2jeWMquSeAAz8DdkDIzk jbk49TUp1wqQsaIQOjl8g4742jv2yc9q+Olhp8tNttt0qUnJttybhHXq21qru71u9j2VCMIq Lhe6TaUU9bJ+X3fedHc3c7dAHB3HkI2WdUjY8xtyyIiN/eVFU8AAMiZ0Q3EyIRjyQhVRmMkO FwYwu0SZfGCNwz15GEt9GEiUMHaRiM7gNg3gZI24bgk44xj3rT82B4lSSVScAhMhSR1zkDsS w/CuedOcZe1s5TVlzbzXzbeitpro+25pTUOZWjFOz+zbovlt5u3zuTm4hmfe69QEUkghFwFA HICqqooCjACqAAAoqE3EshZImZUYneV+62c/f2jB4HJYknPPuJFvUgYChTweSR04O4c++D16 VZdAihYBvyPmI529AMj6Z49qceaSipbJNQW3Lzu8lG1klJtuVvibb6u/RZdlr5IsW0a7M+c3 zO0zR722NKq+UJCvmbTJ5Sqm/bu2ALnAp01xNEy+QZ980kcRaJfMI2rsjeVs5SKMYHmjc0S4 CLg4qtEihwgUsxByckDnnpgjjjvk06a3d1KyyGC1kfybpg0Ic2j7lnCeaHZ38sErHCjTsR+7 BIIPFVdKnCpUqNKVJ1Icqp8ylHnjyQUVFr3Y/baTsvifXKp7q5lp3XzXb/gq4GaSZ3urbfbr F+5JSWS4jkmywDBnCpjMqYXaeCDjkCoQ5WGd5JLtZFgMX+lwCzu7RFkS4wtss8gbzMEJvliL i5OTtAD/AIg33iP4z/tw/tL/ABc+EN58XLz4H/D74I6vqng3QbTwd4H8FajrWsOfEPxNi0/V dS1P4k6Trskbwf8ACAeGoHjt7FLOSM6kZpEln8+187/bNk+Pvwg/YahsPH/xlbxl4m0z9pP4 W6dfeKPCXgf4fw+L5vA/iHXNFGp6ZH4P8PQeOtP/ALWWDVNVh00W/hWfW7tZdJkttPupLi1b UP1PBeHOZVsy4fwOLzLB4bF5jRyqs8rjRqzjDDYrH16NKusdh8vq4d1Jyp1YVKdbGJxVGEuX knzHmVM3p0IzjUT15VG0b7ead1vq9eltbn9C0WoQIqCa7jTzINPXc8kTTqy2W5DJayOsatLG GYN5pZU3FS6u5qLMk0tvIYphlYJEt2eWNr6Cdiwt02jKpP5QTESyrlhsVyoB/A7/AIJ2ab4f j+M3gvxpd6H+0nAt/wDD/VLu58afFLwXqHgv4e3B1PQ7Rklk1K+/Z5+HOlW9zfu6x6Pap4sh Zm3Q/ZdTn+79iftP/wDBT/8AZ6+GXw51K4+EXxj+EvxG+J+pXdx4C0fw9B4z0yQWni/+wvEb 6Msb28MtjdmTxDFaWP2W4nFtIJUMl+sMgdvKx/A2bUs9p5XldCeZYqrVkq+KrVKEMNRjUxFT C+zcIz9pOFKnTdS6ws3DmjOLUlePdRzjDPBuo07xjJr3G3dJPXb/AIO7P0qubqzkea6kvLe6 sbJJZ7t90EUGnoLcM5uzFI0ISVIlkP2po0t0H2iIM0j5p2/iHQdZtJk0LV9Iv5rEqNSj0nU7 O/lhjE7W9nHdx2krtZLCEMKFgvmyR7WBcEr/ADX/APBOO9h+K3wd/bJ/Zu+MX7RXhW38Sa14 q8L6e3jbQ2+HOn3lzoWs/DnSNZ1K40jRoLvVdAvobfSrCbR7ya0vL2SzMN9dSTWd8ix2vYfs S+EdR/ZO/b68X+BdUGv+Gfgn428B+IdF+EnjfxOdJ1nTf2hb/wAKWPhHXde8S+HL3RtGt5dD TSLi51jWbnTYb6e0nh1mG3t5mttKRZvosw8K8xy2nnuCePwk884ew8cxwFDDrMKmHxWEqUsP iatq+JwFOl+5njFT/e8s5yptxco3k+XD8QUsXCmuWUbuKfucujs+mvW66621sf0XxQNGhA3D eokDM0kgK3QO+OKSTLGEeQhMa7YiGjYRgmp44HLBn2sQSASuSMjDYJXIyMA46gYPSqYn2JEC 8TblRxDFJG628IGIHXa0spS4zKgWWR5IRaDzGZpgxtJexYEa4JOf4ueSeMbPQV+Xxd05QqRq QbTjUjGNNSjayfs4xgobNcvJFq12lc+qhKMoxlC9nFfJ6X3116+j67lxayZJYK6ttIUqWGMf KMFSDtAAHHAAx0FESB9yyIhBO8gquGfLEuflGXyzENyRubBGTl7SM+PmXGBgY5HHTqCcHj9a ge9aEkfZy2FKg+YBu6cgBDjGMdT9apOd9HK6ut3dX0et+qdn5b6GkNJLfaz1fbtqirN+8Kyk bpFdUDn5mCsyKybuoV1ZlZehVmBBBINtWuNihS4wAARuG0KAoAwvACgKMfw4HTioo1+TcxC5 dSAccFWUdcjOcD+VaUUqKmWkT/PA6E1dNOLUldS6Sjo7Oz3Wu6/rQ6E2tm16aFKJLlwwLnDI V5ByQeCD8vzD2JIxgdKSysHC3ElxIJdkgYCQuzDdkHbvPHOCcY6e1WWnRzu7A8EN1wcdNuRj HeqySwvKYxIF3luvOMBjnGAT+Y6VbSvdpOV93q79dRxfvd7vW/Xrf79b9+u4PCPNDCTAG3jc e3J/ix04xWlbXEYYggsoCrg4I4IBPJPXBz9TmqMqRoNok3E45CkdeOnPT65JqxAh8oMh3kHp tI4Bb368Y6ZoOuGzdutvwRZj8t3yAF2NlgQPmB6AjoQNp+8D16dadLOJZlVB5eSgyuBx35Xa cEHB59jVfZKXJYGJQASGXO/JbPJIxjHUDHPtT4wPM3R8sOc5yOBnkcZA4zgg+9S4pp6La2y7 G8Fd20106dbW8/673tZjBDyBXUnn5iBkYbHU7jzSpbPIoVpUBberN0J80IFBxgts2uQCeN52 4y1SwyP84aIEkD5gWUfez0yevA5NVHhcrlmMeHVw20EYUN8uD3Gcls9O3euGr8FGnu48qavd WXLo77q2yelkvI35XGLi/JLfy8tL+b8kfJvxgdtJ/aZ/Z010kGLW4vFGjXbIQpcQWstnbR3E rDZKnma4RDGSGBeRFBaRQfsG3jDxswUDLuVwMEKZXKgEDoFwMDjAx0r5k/aN0SGGz8F+OUMi y+BvFng+6h3HMAt9T+IXg+21QztwFUWKSESNFL5WDIoBXn6J8M6mmp6JpGoxFZYb3SdO1BTG wZGW9tYZlVHCjKp5+A+35wmdq7uPpM9msVkOGxMLuOHjTwbezioWm4K32f3l1Fe77z0u2Yxm qadHrJupa2mvLFPXS75beWjVkbGwPIXzkMuwA54BbO0jJGBnBHT2rzP4oaX5/h83BlMC2UVw fktllYJNcWQciVpImgjjCu8wUlJYy6y/JuB9V2IgHOCSCR6ex59e/GMdOa8b/aA13VtC+EPx B1rRVifUtG8Katq1rDJGJllk02IXrI6FlzGY4HEmMtsJKYcA15HD9edHO+HK1KXLUhj8PFSu l7s5qEoNv7LjJqSeju092Z49/wCx1uWKl7qsmrq6lG1lLR2tvbpfqr/OskSGISCf5YAh+WJH aSPiFZkUyBVRzKu5QfLD72DPISW+1v2OFXPxHcW8cZc+Eh58agrcxxnxQkJWfy0M0cUQVYyc qiEKmFxn+ea4+LPx68fePtU0TQPiNbeFYbbwFoPi7SdHsPBXhbVLp9Rm/wCEc03WEa91uGcy 2cc+r63iBo0nhlsolWd443Ev69f8ElZ/G+v+C/iF4/8AHHjq58X3/jvQ/hNq32IaD4b0LSfD 95FbeOV1KDR4tFsYNQlguppollTW9Q1SWBrKMWs0YkuPN/0i4Zy/lzbL8ZKUIv6lFqnCVk3U wUk3yRSjdc17vW3TY/JsyxUpUMbRcGrygvhSS5a9OW9tNkul3ofr1RRRX6ifLn4+2k8sDyZc w3CY+VnlPnbT/GY3dCTIuDkp949jkb1vIJZYZy0aTB1CJIZyxkd/LIUxl08ooI+GkB3GUkYI z+LXhvxx8a73wN8avitqfxo8WXFuviPxP4V8AaRBc3FvZ+HVuNH1TxHp99C1ve2+napPo6Ra Zax/aNPuLnynBF5FBdSQT+xfCnSfjro/7QPw98J6r8aPHfibRbzRLDxD4x0q/wD7YktLpI9R +Igi06e2udWvharqNh4etIRCPsdvMzrP5E8k1xJN8bnWJceGcZVlJxlhsmzPH83M7zdLDVaz orrHmUFH2l3y35lTlaz+voYiFXH4KksOl7erFKXMny3lTV7Kmk9+rXyP1oeAsVgcxx7YY7yR 4t48szKo3ZKlmZzMqsNsn385+UsuHcLGjsodZeSBvQNzx6xL1JxnHStMzwRWn2WF5UvklHlm Q7JIrTYC6GPzZHUQT77P7pCmMoXQjyFz4zcLuaQmXgkkg+ucnKn6V/m1Ocni8TVld/Wsbibp t+7/AMvnq789722j3u9l+60KfslQjFXVPC04O2nM1peyvb0123bPnP49SGew8N6KvlhNZ8Ye DbWRFQIGiTxz4MaRC+3CBklk7NncQcZr2rSbddP0rTrKMNbpZ6fpunqUbIPl6dazhOC2Rs53 bFGVA46H5z+N88lz8Zf2eNIi3Kt94g1jUHjzkBNHufDuoDcoG8nNg7Iw2qrYLEqrY+i7xWEn BOS25gM54DxjPfOFQ44GMdep+qryVPLcqoqSTlBVVJ3SVuaPJbV683xJ9NtT56hRnLFYmSfI 43fV2vKHo++vbd6E8czqsi4EkkeQrMASPvkckr1wufoKYZLeVS7AtJxt4OM8E56etTIwWNSi 7WwM+uRnvyeT7U9rZ5EOycSIuMpywOMEjALDkADn0rzOShCXO1Rc+srK+6td8l10tqdTp1Et Ju666rs9r9U/L/LxP476zLpPwy1+4SUwNFNozqUXJHma1YQkjGTyGIOSOM+2ei8E2Daf4G8I WjS4gi8M6AIkDFgP+JTbsRkRg87z6Dk5PevMP2rNRii+D+u2VrFJDcTXugBNhADMNZtp2OAd xbyYmBwhOFyTtBI9r021kttN0uOJkV7GzsbYkAhisFvHGNoKkjHkLjdz0yc5z9Gqs55JRwjn DkxeOqYlVOeXuKhQpS5FBQ97m9jbm5o2U78srWfmyjJVp3973r72vtrbbXTXtrsWWlt1ChwT x6E9Me/TisDxBqul6TpWrahqkttb6DZWV1NqBmtbi6jCS2jWk7XVnBBcteWs1vcG1urUQXCT Wski/Z3fDDahZI45mlG5yxORjJJGOpx3OeneuV8UaDonjLR9T8J+KdGs/EXhPXNNNtrug6lC LjTtTsLi6W2ubW8gZGSS3eM5mViFKK24dTXmYdQqVacZxqTjiMTQqVHhferUYwcYSnGM5UVU 929k6lPWSTa3KxVWtTw0p4flhUinfmXOpxjBtwSduW7StL3mrNWbd18naN4j/Yk8O+NNQ8Z6 X4Q+Hlh8QNQfUF1LxVpXwy1XT9Z1Ga+dZdUSbU7Xw/Z3CxTPEPOMLW73JhiEzTq0nmdxZeDv 2a/iH4rvxH4A+H/ifxPd2FvqmrTXnghU1KTRtR1K8+zyajealpVpZXitqEupO5Sa61X7RcXM sjtDOHb8k/gV+yv+zn40/wCClX7XHg3UPgN8NNR8GeBvCGmr4e8MJ4X07UrC1vtX/wCFezT3 0FmtjCkd5F5GpLJK73U4/tC+Cyxq9wJvG/ih+0f8RPAXiL9tXX/hL4g0fwbdeCbVvB/g3VvD mj+D7K6sNV0i+/aHvbPQGurPw7If+JbJpHhu5Sznm1O6ikRJGsFzvvf2b/UrD5rj5YbJsw4m xOcLKsBjakcZSWEwiwua0VVwFKEqGdY6o/q9GlWTk6EY1HZxjBXt8DLP5ezdfGYSkv38qXLy 05rSSV3KcY+V48u1tT+hp/hv8M49Wur+28C+E4/EE9hJpD6w+gae1+NEvohBeaTJeG3eR9Pu o55xNanzI3W4kBGSQs//AArTwCtnaafD4H8ItZWs0lxY6fD4f0qO3s9TmFw19fWkL2kUMFzq DXWqXF5dKRPNJeXWWQXc8Un86njP4g/t26L+1IPgeP2yNXXTvEHwD8UfEOY6d4Y0KGy8MS6F a+LL0atpdrHaQXKX7HwfHbwz29xocP2zV3D3Ifzmvtjw3+1B+1h4j+Bvw4+Fj/H/AMRWHxK8 c/G74rfDyy+Nt9o+gf2uNF+FfiT456o5k0prESaj/bujfD7RNNjlGuNe2FpCrtfXsE16l3y1 PD3iHmXs+KMvl9Xp/WalF4nM+XDzjfmxmNoKg6coxjFRnRjKpZUtKrvaLWf4Nb4GT23hR8vP r+r7af0Dav4H+GseoN4rv/BHha51rS4JntfEd34d0u/vo0tJzqWp3hvLq2n1QSwXaaZfWaxh Ak017LDbi4llB4TxR8Q/gDe+JPhvqmt6bpWpeJ/Gd5JpHgnV9Q8DWd9dRXdnq8Ol2SWF1Po0 kugtb63fh4bhRZ+XdudQDjZ9oH4ZfHLxt+0N4K0D9rr4L+JP2nvEXjWHwp+z34q+JWi+MY7l by48JalaWXxd8KPo+oS3moy6lpdqi6La6o/n67NZu9lM02jCezN5L8qSfDj4jaB8Q/8Aglt8 E4PjPrQ1nxb4y+NetWni/VtNln16w0+28e6feXljpcGpa5f6vYyRQaDqJubvR9dsntLbVYNS JDwKg9Wh4a5hOjTzDE8Q0ZSp1fq2Ghga+OrYdPE4Sr7bEYdVY4RUoKHtamKjGlGSp+3s61rV OTG8SYVxVKllrjJ6qt7SnTlFK10oQoy5m97ucfRn9bxksppUtdhllS2CWtuysL0pDKUlaCTK afHZiVbkrbyzRsCGkW3DmJjUfwx4bR7eOTQPDwXQpnNjKdGsgljDbSjK6esVoHstvkW5eC0i t7WeS3ieWKVre1aP+erxv42/aw8P/Bn9rTwn4J/aA8Z6n42+Dn7SlzpHg3x5/amrfa7Twu9v 8LIrzwrLAi69NFbWcvjXXBCt9c6yzILedls5ZYI9N+pP2Bfi38Xv2nPjH8afjVqfxD1nUfgR Lo3gKw+E3h+8126/sWC/0cS+GfGt9ZTaLbxeG55dU8QeCdSu4Gs9Q1mWOG/nV2sJjfW0vy2Y +GOeZTgM4xGIznLZ4LKFl2Jq4zDrFUp1qWdrE1soq4TEeyVWnLGUMFip0pSUHi43nU9g6ajL XB5rgsRGFKvhVVqysoSlKF1JpW3g3pbvd6n2f8dv2vP2Y/2ZNS0Xw18YdRudB1fxHaN4i0Sw 0fwVqWvWd2LW8hshdSy2enXkVtcJc2dmirJLBkQxSYwpavTvgt8evg3+0h4HPjP4ealqGveF U1C+0u7iuvD82mKl7pctqJobjSvENlHDKtu99Y+W8EUsQcwtbttgkMf5oftCW3gTWv8Agqx+ zp/wnF54Uh03wb8LtavUHjaLRL2Nx4i8LfFeFkivtfmMsO+40y0S5V5HQxvZqiv8kNL8DL3w vp3/AAUO/aN8feDte8MeHvgbonh1vC2txaXdaTpvgPUPiCvh/wCDX27XYb+wlHhc6m7XVlo0 6SXEOom4sZYpUEqCJjHcL4enkeFxlL+0KlXMcppZ46lWbnRw9J1sRQllNSjKvyYjENYV1IV3 KnCSxEIShDkcpRHG2xXsY0eSCaWktF8O0VBJfgk1v0X7A67q2laHpt9rmsRWn2TRbS6uY9lk bq6hS2t5LuE2yvG6wyta2RZXt5IJIZFjSGS3GVX81NL/AOCwv7D2vWyXema94xltZ9V0bRbr UB8NtWt7K3vda1Gy0/RIL2OVY9UuorrUdQjgmkS0v0himaSZolNxIftj4v6/pl/8EfiVrVjq Gn/2fcfCzxhqtpqB1KCaK8tpPCGpXVrd6fcBpYJbnU4GF/ayW9xtuAxliupUxO38tOpfDf8A av8ABfwE/Zd03xf8V7Cf9kP4iaF8OtG+NnhnTPAGlWd/4X8G6xbfCnRrHRrrVf8AhG9JkNiY Nfs9L1TWrv4h+CL3T9N0/UNUt31C8QWUvZwhwrkmcUMZXxjrUa2HkqOEhSqvDQqKthJSqxnV p3liJxnL3aM6cY0qiShUbSZhmeZVcNiZwpUYzhFU+W9oq8qUJO7UZaczd301P7BIZbK6TzrS YSQJdg72gAMsUcCsjXEM1uI5w2oGK1ZZonJgCgoIkWVfNPEvxy8HeCfH3hj4eazF4x/4SPxd cDT9LudGt9Jk021F7c+G4/Lnku9TtzZ2Er+JNIk8qysJXijtZESKMW8cM388v/BQr4z+HrXx 98VPAPw71y48N+MfA3w08I+IPDlxB8Y/EHh/QdCtbzxD4eAufBfhrSb690/VvFD6v4olks4p dG0p9Uv7vUrCTWoAqG56/wAC+MfHWr+Jv2XbvXfFviTVntP2R9R13xGbrXtWVtY15dN/ZcuL TUtQKzYk1Awy6yDJdiSQtqF62Zd8zt6GE8J5qeEq4/N8PhsPiY1MPhIzw1XDYjCzouCjWqV6 VWs8ROrCM3Us6cpybnKd1aXKs/kqcfaYCMVde9Ccbt2+H+FCy3e7tpo91/R8slmkn2FtrXO5 yImEzRpLACzMkh+YLI0JWVi5fy41MRSUh28bvPgh8GNR+MWkfFrU/Denat8W4LZYtJ8QX1z4 iuFsbO20u+02KLT7OWZdKsitoLxHmS0juSt1fFZi10Q387/wl8G6n4Q8EfsDeNodf8YXHxT8 R+IPB19rPiHVPHnjzU7nxJPPo/wKk1Wxj0/Wta1G0mN0+u+JfKtINNWEXGvkJBbsYmiXSdQ8 X/ED4j3Q8UfEyOw+Od1+0J8HpvDDah4w1G4+M03hnR7T4R350jT/AApM2na4+g6s1lr9pcS2 d3c2r6Zeak81teQte2DceF8O5U8RKUOLMLT/ALSy3HrFU6cMXTo1JulGm3OjGooSVWDUasJa TjHlk5R2ylnlGT/3Odu3NDy/u/f8+zP6ihq2l2iTyGfaLVjbXCJBKyQypKYHih3xFzEk0bxo dzExqpLN1Mj6lFcaedShnijsbSK5vr25MMsdytnawwz3CxGKIynMMnmFFAZpETaQy4P8xvxv 8D/FnQvj/wDED4C6j4s8cz6T+1GfAviXfaSeJ7FfC83ws+Hen+PPE8v2WG9gvmn8ReLfE1o+ rT6PqOj7NSZhq3237WLV/wBgfhJ4WvP2lCL7xJ/aen/BX4dTWfhTw54Eun1N7fxQdJNtMviU vp8+kW95o9/4TubTRtPF1f6/bqk+oGFwlzPNfcEvDihg8Nl2d1eIqGGymlHGVa+NpYat7OeF U8Rl0KGHtiIOrinmtOovYVfYUIRqQksRKblCPVh82+tVtMNye6o2dVNaRSvpSWul7Wt2bOL+ M/7SPgO4+Mnw+mhv9S8W+CPDgttc1LQIdGlY22vQ6X4yttN1trbxENJhvBYXuo6I8SLd3Bhu DDdw2TyWjzQeJfG79q/W/E+s6Bo2kT2+gaPcXt5deC9P8R6DbS6JGljo8SajqGr6do02vLcT vBPcCwiubW7jgudY8+K0tZIjNp37KaV4F8B+F7JY/DXgnw5oTTOzQjQtLs7OJYjIsl1FNDa2 1vHJJc/ZJFJdJGbdb5b5EEfM+Ofg/wDDL4mW1injvwV4e8UW2lzPcW9vrehWd6tjNcRLbbkW RwI3McaRbm2llRVA7D2OHvE3gPI6uSyzPg7N8VgsmoVarxONzDB08fiKkuSm81p5NKlisJQr 12703/bM6kKVSpF1nqp54rKcbVU50aqjGpJScOWT5WrWStJX00WittY+T/hv8bfh14G00eIf GXxZ8XfELxBrWkEfY7rTtSfSbTUmgsL6ddG0638KeEdPtYGvWkitZLsPKttLHBNIsEYEP0F8 MvjX4Y+L+o+KbHwvp/iGwbwbPo322TXLXTLGTzdds57q0Nn/AGTq1/DPHjTnWUzxRyRSN8uV YOnh/wAefgV8EvCvw/1rxb4c8EaT4N8U+EtA1nUvDvibwfbzeF9Vs7zRNE1LU7FLebQtT0hr 28TUbSw1DTbS7lnjNzYl12FWZvj/AOAHxp8Zw+DdG0bQtSPh+9F3qXij40/FfxJfW/k2v2S/ vZNG07W7jUNL1KJdUvfB3hi18O6PBrGsaCsY1bRJbFnNys1e6+E8t8Qck4m4h4chjKGIwmLo UovH4SjlVHCUKNOvLFww8cuxmaJU1ThBtxVH2kk5TpxbucUMzrYJ0MJWk6K9pTpzabcakZSj zKS92ys3d+9a70ldX/ZwW84RTMHeGcB5A8iuskhJw5Tf1+ReSoOVrNvNK0+5lgja1kR4X8wX dhNJaTCVvLJ3Mk8IYIxJA8pl3xhhnq/ypJ+2b8GdD8A6P4p1bxXBqk9ndSaDqB0zVvB17f3l 1p13qWjXGupZS+JrW2h0/UbyyaeGdZE/dXkCgFpmSrd7+2t8DLS/urNNX1HUBb3NrbpcaLN4 N1i3ke4iZw4d/GEGDuUqX+dzKJVB+Vi35G+C+McHOPJkNbGezxGIhCrSpQ/f1fYa4iFaVqip KlyVFFw5pqLvyuba9j63haiv7elfTTV62W7a+7Q+krzQdTijja1nt9Qtw8rtBqojuJ4TthVj BKbRGUz7fnzctgQxgeWBhsp5LC1TytR026t5lPzyafP5cZJJI2quojAYA5xEvQcCvm/4ffHD T/ih8erG88PeO7638Knw7b6c/gTW9Q0y1utT1mDTPHFzNdW9hY61qiPkS6PMRGTI/wBgjMkQ UozfbKhLhYrWe3nR3mZhqJtVFpHbGGS4is5HDRpM0TFIw8o3s6xngqgXzc3hj+Fa+HwWPqwq Yqph446U5udZ4OGIlGpUlQhVUOWrCrPkVCFSnTSlJxraJTUcNCspVlUai1pOm3Z8tk7K8bWc Xez3ve2h8ofGn4p+KPDuneHtD8D+KtRtte8Z+Ih4T0W4vUWRtNXUI5rO2urm4e2MSCzvZ9NY uI9RKxoSLO5CMhTSv2dvAL+FNV8IzeCfBGqxa5ZtZ6rqF/po1LV9Unv7RbG6vp9c1Wzk1WC+ lKG8MtnNZwpeSvcpCsssyn4D+MX7SerT/tCa7qkvgLWPF3gL4e6zdWXhTQ7bTtOvdN1TVra4 8ONd+ING1KPRrmOe9tr7w1qduqh7+SOfxBNEbq3eF47n0G6/aM1z9oHwd42174c6NefCjwt4 HttRt/HevatfQf8ACSWy2ls+r6tFp9haaR9ksb+HSLS4sjNL4s0G7hvNQBee2+xQXEn7rX8P +K8n4f4bx2D+o5XUzPDYfNs0zejhZUYYb2kMLi8DPG4yhGGKrP8A2it7WHspR5lOKnJNyPnK uJoqrOE5VKiipLkk1y6WfNZylqt9vuNT9kbwH4wh+JWu/ETU9e1HxxfeG47zwjomqeJ9ZfUt XtdGu9O8KarLaIZLfTYvJi1XXNYkiZnEqJeyoA6ECv00fV/GUkieXBawMVB+YwN1Ef8A08zd Cc9SPr0r8ZvDXiD44eAPC+gfFrSdIufAnwRg8a6B4e/4Vm9jPHq2pPr3iHTvDmo3lzrupeD4 Z2Fxqmo3V2IX1S7MdpYRGCWGSKOCz++bH9o74Rv4j8F+CNQvLe18TeINA8O30yXPiTSGh0a4 13T/AAndG0vhcazFexXEkvia1khjOnwkxWV2LeOOOOONzxS4Vz3P88wOY4enlmefV62KymP9 l4e7wlXAYR5liqWJdejRUXSwtf28lT9r7ko23ZWCxlGLdNRau78ylfflv0j27va3mfTE2t+N oATc39jbquSWjhjLBRwWJS3kywOORnnketY914puPLcal4jvJk4AhsVmgkLkgAs4sbb92ULh lE3LFDt4JGjeWXhHRtOn1nxBqvhvTdOtozJca14g1C00/SbeABA80uo3832VIgZlJnlZAWlh LMC6EecWPx9+AFnrlvoGjePvA9xI+yeC+sfFvhKfTpbifEf2ezvo/EM0324BhujgiWRVWXaf vbvw+llssTUnWy7LHj/ZPmrRwqhamly3lLmjFRjotnJ2aXLsj1va06ji5VXG1lrHmvs9ffjv ff7zq45ft0kJsbNr8zK0hbVZpJlYBQQ+1r0AOfm/gHQdMV5xo/xWF58XNU+DOsXF/p2r2nhj TvF2n/2ZAltp2oabc+JtW8KtHNd208r7murOHFvLaWhWCTzPMBzFF7n/AGvZarbJqOmahZXt leKk0F3YSWmqSSROMowukZiyOQRvS5ZWC7csFAGhJpWjw3MesTaPYPqVwjWcl3FaW6am9uJE ugZJFiSVozPJJLgykfaGLbi3zDCjmmEovMKc8sjOpGi4TjCrF1aVXaHLB0Ixk0+bmvUp8tlb nvprHlrtRpVnH2Xxe58XNa203azi73v28h1lHYWsgS1soIxG+P3yNPKruFb5ZZZJm2kMpA8z AYtgA5rrU+1NHGyqFV1G3ayqgGMjKBhxgYAKnB5wOtY0MLvbwrEpjZwzox3FkUSyJhsgncXV iOT8pXkfdHSabakBVnk3OF4JLDDfNnGSp5XjpXyVedapHBVo1LwjhcR9ZoyclWnL2FZxbgrw dpcj96d7xutUr91Ok0rcqnf7V0rXS95rlet79fu3K9yrTWV9EwyzWEuMnj5oZV5OT3NfO37I dvIvwst7M8fY9b1JFUMML5t3Jc8EcHJkz25OD0r65g0uGSUlWP7yPY33zksw54l/2uleDfso 6OY/BHiK2RQE0vxteWpco4Obrw54au8j7xUA3oBDuT1IwGAqIYuDyTOKLhVi5YnA1L2i7cqp U+W3Om/j5r9LWt1WKvTrL3LtNNe93s7Xs/T/AIY9llsXG52Y/O+0Hf0P3sYx/sn1pkdjKfkD EtwPv+p4wSO2fT869KXQ7OKFHlSO4lYu+zDEjzHc7jmQnIBIPyY+brzWlDoMU0QuFtkVipYZ jfPBOOQOuVB6f/X+djmlBunTnTqJxVSk/gbXsOSClbmWtS7drpxSteR6cZOaTty6JNb2aSvr p+R5XJbPE8gVjiFQ4+bOCVL8ZHfFNWW4ZPM8w/LmMc44B9uc8nmvVrnwspicfuyJVIxskOSM D+9zz6fSqtv4bEMflBYCAxPMb5yTnGGDcd+vXtWEczw8qCrzpTjfn92XLa8I3V53v7z00j7u +uzuLUXfZf8ADea/X0PN11DUIyGEuUjO5gecopywIzzkDpnmtK21eeLJkwwcqR8gbGeAPvjH LCuz/wCEZQmRzFbkIGfaI3JOMnA+Uc4GBVVPDCz/ADJEqYYH7kuckg8YPXjH5VUsZhnKjeVO EKlKVRyhLmlCyTUeXlind9VJWu2lfQv2it21W1vLz0v2136lCyvGaZNyjo2TtHOAf9rP6dqv XM8TqqyK0gMy7VBK7G+cByN6KwXJ+VvMU5+aNu12Tw+iPhpm8wEAxrAzqMjIAZpwxyCCcxjB OACACbEWgIgWSVcIhVw7xyW4yMsAHVuTgE7ScHBY5215lTHYGOIpKXPW9rTv7N0KSjVU3FxS k60uVwS5eflk5K/uxu0CnFpprRrR3u91r91/y8j8uv2gf2EvjDo/xeuvjt+xv47sPhl4t8U2 GpXnjHSPHGvLc+FvF3iK81bxPfWuq3mhJ4H8XQssMHjbXiGN5pzx3DWJW3c2iPXlGpf8E2/j J4q/ZW8V/Dbx98cNe+IHx58WfEvQ/iXZ+LPFfj281Lw54ftfBd54Sm8OppKJ8ObKxsLq1ufA VqZrMeFb61u4dX1tbqeU6tcCD9ubXS4WbcjxfORj/SpyCSDznJzkN6H9atHTI2kCIf3eR8nl 8Zxk9HP419zhvFXP8thhcP7fD1K+Ejh40sbi8FTrYt0sNVnVo4eOInWnWjToVKlScf3nKpVn aEXdy4HlWHrObnUT5lG16SfLbe156p6drW662/H/AOC/7Lv7cPgyXwX4f8bfG74a674G8L6J BpV/4Y06CzW9vbGw0CXTdFaaeL4NaHHdzQXzaVqN1I2rQs0scsqK4MltJ7Frv/BMH9hfxAgu Zv2dPCUE0WrQ+LEvbV72xnt9ZQXcgv1mtdSW4hu42m82O5tALqF0L29wkgXd+kSaKzTJuYGM K4RdjgLkL6EDt/hVr+y7Tc6CFQ7BkWQKWMbZIDhSwDFSQwUkBsYJHWvIq+IucVseswo5pXwO PhOpKdbLq1XAwnTnG8oTp4epC8vem/aOUtXfl0NYZZh4UnS5k1ZpvkSuny6Wu9LaW9ezPx58 Af8ABKH4M+APGHxy17QbbUvDkPxW0zQNF0Cz8J+ONf0668I3tv4I1Lwde6roN4dOgvdOvLyT WIr6a61DVtdYSW2+0t7aGNLCfV+FX/BPG88F/F/wn4++JHxX+JPxS0L4QaR4z0P4P+FfGXxA PiSDwsnjODTtG8QyTRP4P0We9kfTtPgt4Lq+8QX9zAqRiMur3AP63Q6VkMHjkukHJHlyQ5GC cfumfHTOe+OmM1VOkxPLL/oU8UeVAVbRpVBHDEXDujvuYFiCBsJKDKqCe5eKnEmJxWOks9U1 jcshhqmMxNfEYqu8OqeGh9XUqjUtY04uU/ae9KLbppy0uhlmEpxhGEYxcbO6hG+ltenlZ3/K xxZhghtlLl3ukhgglVrewjjSOOOUwBXtreGVyJDchXeR3kXJui7LbMufa7RKZHUEBlxxkYCn gDPqea9El0+FfKBhldVIfEvm26Arj5gySSZcA4ClQMEksNoBoX/2QXMbbraHYo4e+cdT1G7H r/nNfL4fH4WcIyoxhGMldqErwVSVuZRj7OFldK0Ukltd7ntKpGmowhD3VFW1t0V+nX7/ALjk 5Jo23GNmVtxHcKMHBAHPToP501opFQSSneH5XJB4Gd3GBgnj610QNmd++9sSCzMABagjLZAM wZZJCATlm5f7zc1U8zS/3hkvLS3WPGBPeqQ+QxOwSygKE24YLkHcucYFdqxFKSXLJOTtaOmt 7Xd7uyiruWj0Wl2rGsK0bptWtvqr/p38jJnOYNwJULuJxwcBgSRj0GaIHR4xglsj+L1yPX/O anm1/QYQudS0kICGfN9ZRfJuG7Mgk3R/Ln5wQUzuGCM1Sl8YeEUJD+JNBtU7q/iS0I68f626 Tqf5etbx9spRtSi4ySl7R1JJRg7WqSTp6UmmnGSvNqUbwjdpdMalOe0v8+nn5r/hiykTnOTh T0AP5569Tk96cLaAMSNwkGdpyeDzkdOhGR3rn7z4heAbXC/8Jn4Tt0dsS3E/iHRVjZQBnJlv WUBAzZ+YfKpJIGcYA+L3woglKT/E/wCHmyMsFR/Fvha2jKjcvMy6nvULtUthWDABW+VjXowy jNK8Yyw+FdWUpVZOClJP2NNr3qb9m+eq4t3pPkhGVo+2km5R0i4ppuVlunbf5XPR1hkKkqoc g8FiD6f3jng1oWqvEo3KnzHJHUDLEnAz7+/tXi13+0D8GrRzD/ws3wAZOCDY+O/DD2g3AkeY F1eFDjGZN0Lfw53cYwrn9qP4P2eUPxD8J3jWbNLstfFHg+4CYzKGTdrQI3cBWKrk+1TRyjNs RKMaWArczpwqNTtFKNWbpUrOPO3J1U1Ui4xUKX7yMqkl7I6oVaTi+WfM1ZtWSsnZJ7vr3s/y PoS5eVp0UgKhGCFAGRubIOMnpjH1pwMcTFk/hBZuP4QMtx0Py/j6V8saj+2D8GrGF5YNSvdY uXDTiTRtU8N6lIpkZQFdR4nXyS/zsgTIlXzBgCPnCb9tn4bBA1v4R+ImpHqE03SNAuEkbJAX dD4j5cHAOEZlJTGTjHsQ4O4i5VOtgfZw5/Y3jOVR+3a5krOnTXseSNRurze0UlCPsHGcpw0w +Kw8naVRxd07WTvtputXp6du/wBnLcIUBUfeAP3cZ/WphG0iYbkEnpgdQM9vQ/4d6+Kx+2ro U4EGn/Bf4yXgf5lZPD1sVKqN279zf3ORyw4JGR19Gzftdaxdgm2/Z5+NNyEHlq76Fdoi43bV LQ2dwONwJBycNnB4z574Pz/mq1qmBnToU6k4uavKSp83LSqcjUY81Rbw50obKc7XNq2NhGfK oXvbefpvo9bNWXl0d0vb/wBoSwN/8F/iGiKpnsvDl1qts5IUxXOjzQ6xbSqxBIaK4sY5VGOW QAEE5E3wF1C+v/g58N764fzbifwpp9vNI2Mu+nKLElstyc2/3s/PjdgZwPnLxT8f/iD4u8Ke INAi/Z6+Idrbazoer6a91qdrrC29uLuynhaWaNfCUqsibsj96pJC4ZGww9I/ZM1y/u/h3b6P qFrJp95oF9rdnPpE4CzWO/xV4rWKFo5La2uofLitkGJ7eJiCvy45Pbj8nxOXcHToY1unisTj 1iY0nFv2dGrHD0E1JyTnyujKekIXb5bK3Mc05OtjKc4JxiqUE1zX1527rRJvVfPe2y+s5FLO Oo7nBHqc1geJvDmm+JtF1fw7q9uLqy17TL3SLmAuVSS11C3ktLqNmH3Q8UpAYq208gZ4O3BI QCApBUBSOpBHbkZ69SRmrEjSYiIcg/vgQCSGJUAZ6dPoc5x9fz2E6tD6hVoVHCtTrxqxnHmv TdCv0tJP34wfvacjkrKXLr2VN403BSi07620Svd6ST1Wq00v6nxZpv7Kfwl0HxZPr+l+GCuu WukS6B5v2+QxtpJvY7swMh8tGCXWwoSQVWNAFwgNfZv7IPw58KfC/QvEnhPwlpX9k6bptv4a toYfPafNqj+Ibi0j8x5HJEKXcgA2pgMF+bbkYCK63N2GsjOZJpXJ8sndkod3+qbP3eo7d+1e 6fBjfjxHvQqcaP1BGf8AkKZxkDp3471/fXhdxDis0x/C2IrV6k1mWEr03h5VJSVF4fJ8RX5n Nv8AeuThZL2VPl3u7WPzTiPC06NHGTVuaTg7cqXK3iKTeq30utLHuNFFFf0ofBH4Pr8F/A1l 4eHg21sIbvRJ79dWlsk0/SbdJZRYnSmvJrVtOe0la5tGEVxM1qJJQkcbP5a+XXpmleDtCj8U v4pTTbNtZntNMsjeNZ2JljttLl1aS0WO5EAulKPqt8cG4KLv/dxxlpWl/PPVv28NAufhtqnj z4e6np8s+l+K7Twjex6xpTRNDpV1oOtazBciOTU4rYkvpu1pTd+cpR1a18tvMH2r8HPi14P+ KMmrw+EvElhrtzoctvBq1vBBdWN3ZSXdpeX1sHstRt7O8ZJ7SJpopY7eSJxHKFkLRyKn5dx/ WqYHgPPcQoSToZVjMNUcouKpLEUalG03a0XJSdk7X6X6fc5NCjVzDLU6kXUhUTlTUouUVzQ1 lG/NHZO7t62Z70XZPtKqEBdgw2jAx+5Dx8N/q3dWuHTPzXLPMTuJFSNIkahQRuIHU98Z7AcA nHXp3qlOk6xARKW3N8xYYAOWJBLBACMDjOecdc1Xu2AUPlt5U5wpYAhR6KRjPU5/Gv8APt8r qU3dKM8XValdcr56EbWeqd5Oy7vRan7ZUryoy0j7nsY2m0+Vt6OPNazd7db2ta9z5X+IEE2o /tQ/BONCr/2JonirUJkV0+SLUNF1yKFpFd/kDyaVMI2UFmZGyBtUt9NT21xg3RCjzcgR5XAK yNGhD+ZjDQxK7LtBLszZAIQfIvivxbr2k/Hy4u7DwR4n8YHTfBnhyzJ8PWOn3AsDqB8dIYbl r3XNGiSWZdQaePzncCMblIIVH7a4+MXjTTrKSeT4PfECyt4rqMSXWp2/gi0tEWS3jAjM03xD iCyNM6BFcgsD8uQVr7fFZdUnRymhBRjio4VS9lX9xpOSanUTcZQg001LRO6s7NHzWHxklUxU uRpNe63e0m5R2dnfTTroe9xST7T9pSOIAHBQgZ5P+2/RQDnt+lPS1f5pIt3GT8s0ewHk44I7 HGM9MV4M/wAWPiHd7TH8G/HkyGEXB8mz8ISsLfZGROyxfEB3WIo6MJCoQh1IOGXOdJ8U/irG ggtPgt4liSUhVeZPCoGSVVGy/wASiQuMFnKbVGWYgBiJjw/i6nx1cqj64mmklpunW+evZ+ZX 1yrJ2jSnJ6KyjKXbsr6fNN3tqUf2jbUX/h3QtOaYrPqXim0tYrZcF5/I0HxHqR2bjsO2Oykc qwICxMwO4KB7tOqxxxDzFimCkyrIpOWiVVWNSGj2SNk5JaQhgfk4Ir5C8a6n8c/FuveD5W+F d/baV4f1ebVpRJc+E4pTcP4Z8VaKroI/Hd088R/t6NNsZADq7sR5Lq3R33xa+MFr5tjc/D6C 0uZJZ7t4b3UfBkTuhd5IwqJ8Rd7xGO9jMjwhggkiDSo8kfme5/ZrWDwOHp43IqlShUxKqQjj 8PKdPmwzSdSEcQ3DmbUVzct2kl2fk1cXXhWnz0Zw97TmhOP8vddu2lru1j6RmnaMqqqjIVyz Ny2R7ggdhng9TzzxlXF2JyiXLwwLJE6NtcKfm85RFIGdsxPkM0bABsg5Gcn56k8aftAzxlf+ FUwxuqqxDTaCCEY/KT/xcBsH5HBU/OMYK5K5qXXiz9ouPzlt/hvoaQqV2tdXWlq6sVQ4fb46 C5LnKhQSUI4JzXHQyONSOG58bkjqQd4xebYXDypzcklN+0qVXondQtFtO/Mkmm54+SjSfsnK MqijJpSas4S3aTttb9FexU+G/wCzR4H+Gfxp+L3xu0DUtV/4Sr4vizGurcSaILCyFjPE8L6J 9g06z1S3MsaGK4a+1G/3xyyIvlh8V4lrH/BPn4LeIj43juJdYjt/HPjFvG/iCGO28HGG711v +EiWZmjl8OMtxFcp4lv1uWvVu7udVgVrvAnE/per/E74+aekseqeFvAWni3Ebyf2hqenwLGs hiWNnK+N8rvE8QUthCZUGdzpm7J4i/acjEZj8IeAISxXIe8V8s4OxRs8Vy/MSrfLndx05Gfq 6OH4mw1RSo51kcq7o4bDOvPO8HCj9Uy6DpYCmqim05Rp1Jp+9vbljHZ+XVqYbEU6VCpl2Ikv rE5SlGnUaSvG8n+6aUdHZrR/iVtf/ZJ+GPiD4yar8bL6ylXxvq3w81L4Y3V9Ha+GCg8K6rp9 1Y3VnHcTaNLrAGLyW4jgk1WTTfte2aSwkG5G5LxH+w/8Gda+Gtr8Mbmxm/siz8Tan4rsNQt7 LwfHr1jq+s61r+u6pNa3kvh6e0g+1XPiXVLeaSGxjuprKZobi4mkluJpuxPiH9qWXzD/AMIp 8O4WCsCZJrjClVDkMF8SSEHZ8+CPufNjBBNM6x+1bIAYNG+FwYlhtkfUTwCemzVmwBtPzMdr ZXazbhnnhUzfCqMI8QYOvCD9pThHFYeSo0rq1KlyVpXqRkpSUW27Sj7uqvg8PlUk5RymbS6r CYhro9bO23n27speCP2Kfgx4M+H/AI08A2OlG40z4iLKni6/1Gx8HT6xq63ei32i3Qvrm38O 21vqKzW+p380q6laXolurqeR9yTTRSV/BP7D3wG8B6z4F1vTNEiGofDXU9T1bwbPc6N4N36P PrRRtXi0+W18MW0+nW+omPbfppUtg94ssoupJd+RsC8/azuQuLP4RwuVyVebUkdQ2MHY98zZ ySANrFirBQxVhRcH9q+dhFNL8IoJIeimTVCcELKHbZ5wEfBzIxVPlcbsxybLljs7jzU5cUyo VMQ1OtKjKjVWLo2UI0aiVZWlFShC8X7tOMm4Oza5pUMuqXdHATpqPx8tGpBX0a5uZT6emnTq cd8d/g34x0XwR47t/wBnfwlomr+Lfid4wg1zxPHrH9gWWmS/a72w1TVdRkjGr+CVuruOTwvo GnWz6hrVzdi0WJSt2ttbeR6h+y/8HE/Z7+APwl+Clpa2FxN8P/B+l6TqetRQ6Rpd5rGov5mo agdStdPurqEtFf6heRL/AKZdK4V5BPKZXduaLftV3EDaY2sfCG3tLiXzZFc6mYZbmACMNDJH ZT3Uj+XboDHBuQCKWRkVElccpruv/H7wg+nyeKfiN8JNBu/EWpWekWSxQalcNqGsXiFrGxW3 Hhi+mhmkQt5e6KCLcXErlvKFb4mpXzPAf6vYnHYHEYWrXw2YVasofvY4jKqNfB4OnCt9cdFT dHNMarSouU1zyhGKjJLClQwdOtTqxpyThJNLzWn8u1t/Q9M+KX7LfwU+M3iK28Q/E7wP4c8V arBYx6bHca34a8I+IpPsKsxNsZtb0DV7jyZMmOWBZ1ieP5TGBye3sPgb8LNL+HEXwl0zwX4b sPAUDWsieHbHQ/DNhpjPaS289s76RFpEej7ontbYRn+zA0a20CoVaCNl8pXTP2nPJkn/AOFh fDsSRo8mBFbxKsaKxaRjc+EkVUVUdmdnVFCMWIArPl8R/GbSbrT7PVfjP4KtdU1INHaWVhDo F1JcyxwXk8yWy/8ACD3QkEcem6g7ne21LSXLblOfPq4TNMRgYwp8Q1ZuhUp1FgKdGE254WSq U52VeU43fLBQ5L3Wkk3prUlRU1UVGTfXRu1nG20f66a6n0rD4X0WPw8vhcWFmvh6LR/+EfXS 4o9Pnsl0f7H/AGelibKCA2UVtDYqbSC1a1W2FuWhSDyVMdNbwD4QufC//CHyeG9BuvDLW8Fn NpNzoulzWE1nbpaR29vNYSWn2B4IEs4DFA9oY4inyIoCBPENMk+Lmp2+nXMvx20+0k1u3trz TrG4tvAWl6hdw3aRSQ+Vper/AA1h1LzGS6tf3BtxPG91BHNGsk0SnoNG0Px3qF01nF+0Ha3t 44WSXT9On+GFzqcccizl2Ninw1e4R41guXdZIv3Itp2nVUhkI8yvldWhzP2+GhCjOGJrOvTc fY1JwhJ1FN4iEXVvK8abSfwxbluyU8NXd5Unzacy+0uVJLRRTV0k7/cdvcfAb4U3+pw6lffD vwNeXi6dJpCXd14U8Kz3UenTS3M0lrHcz6a8qQmW5nfyA3kFppWMRaR2b0LTvhx4J0xbMWfg 7w1GdO0+PTbOaPQdGWW305I7VBp0EsNknlWJSyska1hCQbbK0Xy8W0QXx7VvD+q6VcWdrrP7 Q2o6dfXksMNpZ30vwlsLm7kneZYEt4Lz4YwSTNKYpRH5YYMYpcE+XJty7XwppfiDWbjQz+0F qGq67Gqm90mx1f4PTX9oHaCCH7XZ2fgD7RZeetxAIftKQmcPvh3gMw5pxc/ZZlWzWsqGHg6c cTVy6c1U9o4y5pRWLppQTuo1faODbUbNtEShRgrUqK5rptT0XL16Lsvxuuh9BWfgrwvC+k/Z vBvh6G10B0l0hItG0pYtFlhSARz6THHaINOuFSzslWS0WN0FjZY4toQtj/hEfDzeJJ/EMug6 UdYOlyRWmoPptg1/FhBbhYL42xuo5WjE0IKyL/o8skWwo5LfJep+FvgdoGo/2X4i+Pz6fqbS zxyWN54p+G1rfh7Z2iukNtL4ShZXjlSSORDGGV0kjUCRdo4u70L9nqXVYYrr4p3eoeGbjQH1 8+IF8VeBDaqYdVuNFOGs9Ot7l4Yrq2e3eSLTpYBcb4muvNR446oZZRq1qU1mlZ04U3GNRZJX dN0qjXNNT/tLk5UldyvZK7dkc7rU46SWFi7LR1Un07yem/r823heO/2LhovxD+MH7SLfEjxl 418Z+MdPOj+F/BmovaXWn/D3StW8V+C5NUsfDDSXl5qemRXWmeFtKhuYrVtKtruCxTzbaSKG 1htvpv8AZH8WeHNf+EOgxaPc2LXug6bomg63pkIOdF1Cz8MaAtxZyWRht5oXilEluigFENrJ CryMp8vyLT/g5+y/qsM2oQeOZ9TsrywTUhNB4u0lxPZ2l1Y6c94Db2UQEUF7qFlaTBSrJcXU KNHw+zxTxN+zD+yhPfS2fwr+JFr4b8QXlrc65rUM3jeHULa8jEzxQXjXWoaN4jsLRkvbmRJb BbqxvY42WSaxWHZIfuPbUs8yV8L54swo4h4ijLBZ5hsqxGIjltGg6FZUcbgnUjz0MZh8Py4e f13BWr4uPK6yjGFTzY0aODm6sKtOTlJz5Yyjo5Wbtyu7SvZPy7pn6szXsYaKJpwoiIIkluUi uHB3kxKku2WNZA7IHKMgBLEMpIqndalpcCyO+qWNn5hjWZGvbdmygG0SlJIy7ZG5iy/fOcKa /IT4WfAXwd488SWVlp3jvwP48tIgbm90+11zxHa61daTFc28F9NbwweHdBSW1ie7Nr9rtmWN JmaJ7gT28xi+jtQ+D37EnhTXIvCfiBdEtvFSKINYsJPFnxGlXTr9rBNVitdTubPUzY6VcXdi Z7qwgvbi3e/itrn7Es5tpwvxeccI4DKsdUwmW5hi8c6mDjj6io5RPD1XJzhBRq0Vi8ZOmnzJ tSblCTUHJtNv0Keaz3fJBQ0UZyac9ndJ2bSsldXs+vQ+wPiLpHgDxp4Y1Xw9q/ibSjp+t6Te 2txLJeaVvtn1DT76xk8mC+8xSiwXkzDdGyOyKhfCurfnL8Nv2MPhz4d8KajoPjH406LBHbQa tF4bsLCbwlpFoJdbs7uCe81Kwm8Ra5Hc6iuoSWr2t7E2keRFZ6cZkmFql0ei+Dfgf4B/EXw7 8R/GGp/Cz7HoXgXWNY03R2k1D4maff6pDpFj/aiT29lJ4yuJr2OSzNuUJSzneaUQyQRMygYX gnxb+y54h8QLJrfw31zQdMn0Xw3qEGqT6Z8XIrSyvNY8R+NPDZbVbyLxFqlrpNq03h3Tk83V hawmOeWa3mkPnfZfrOHs34t4PwmZ5Zkua5hRjOpgY1pVsFUqYjD4lfWPYRcadShGGJrSqy9l TqRcpzpxUINpp+bjqWFx79tWir07VdGlF8iT1k17sXb3mtl16Hr1v+zf+yk3wmj+FPiHxh4G vLD+1Breqaxd6p8NJtS1XW2uxdzLfNPY3dtNAsjboorhbi4ja0tS15I8K5+mNO8a/Anw3pdl oOjeMfhlptrplra2ca6b4k8IacGhsoPJtyq2sscCsqszL5asqSOzIqglT8n2PjX9lPSZL3Sr 7T1vr3+39XGn2PhqP4l61cf8I9BNdQWGpzi11C6XbM1qFkYP5n+kW8hto4pQ6+7eLtC+A/w2 0fTvEOt6RfW9v4hmtLLwjb2M3inUb7xBrV3ZSX1vptjp8V5JdPPPNGLeGOdbYedNDBJIryKR wZ9n3FmY4rB4TNc54jxLxNfEYj2FR06EK1Stg/ZSpwlPA1HCUFTVX2T9pNRVpSSkmihSwKgn HC0Juy1VdO+iu1aOv9anpsvxZ+DD3cF3cfEH4bG/hUiO4HiHw/daj5bblGb2K8eRVAMildoz blowFXLnzv4qfFD4feIvBWs+HvDPxk8E+HdU1SfT5V1uHXLGW8s1tNTtJ5obSS21/RXhS4gs VilBveRPcgh/NEa+bX3x3+APh24tNK1LTPFmgX0yxnWrDWtI1fSdQ8PWl5cPbwX17Z6vqEFz 9n1C082a1ktIdUBWCR3jhIVH5vxR+0J4VjgsH+Fvgfxhrnh6XXV0GbxdPoVy+hXN+ug32vXM FpfXXiKw8+UxxWRQW9icAyoVXy52i8/D8NZvB4CpDBZrOrOvSoU62Jo1KmFgqV4KE+TC0Xaf s+eU3Wjzu8oRjGajHdV6FOlKMZ0aUdbUFVg3F79Xze8/fXur4ut039B+Efin8DPB/hLQfCWl fEXwubDwpodhpNsVuraAQpZWkcV3PFbW8McUNzdXMTXN01suJrrfMVdnBHzL8VvBP7O/xI8U NrsPxgtfCOn69oeraF4o03QtLjk07xHp+pLrBgvNStYLa2/tC9Da/qHkSX0WoIJGjk8gATrP 5VD+0740l8YaAhu5dK8GaXqfhmz1XU00DT2hvRqCadPdwRtOt/qEReOy1p43e208qIm2ycRY +v1/aG0a28P6x4gfwN4603Q57ay1Tw9rV/pOl22jatY38hezupdWuPFB03TI7mCSxZBrt3oj Kb2BXWN3ZY/pZ0eJeGM6xeNwP9rVJ5nOviKuMpyWGpYeWKnKriMBh6ssFiIR5XV9lGVSVWdP lg506run5kVl1anO6jCrzJ83OvWTSkldfM+VLP4L/A+/cWvxB/aY8beObS0s75bTQNT0bWtR 05Lqe2uks7wWmo23iK3a8s5b64ubSaKKKSCd4pFaNkkM3oHgj4bfsn+BPCmveGn8U3viiPxR JdyXsniHwNc6ld2ED3HiCSzbSnTwWYrWTTrLxC9jYPLHc/ZLaC0gSNUjkiepJ+29b3niPRtW h02RfAWm6Lrmra5cTabYNdxalpOkeJ7qzto5bbxRKkomvodEXZbSSKUuJElmgK3HkfQPwL/a S8N/G7VfEOlw291p17pGlaZrVostrb2sV3p2vk3EJiuU1nV7aacwyac32MyQ3sbTSRNE0sN1 Hb+tm/FPG+CwnJVp5pgcNOlSq4ings7oUacoRrKVGtCnWyTEzxLdaEL1qdSnTUYaR/dz5nTw uDbThUjOSs7RlGT6dI3f9bnzB4X+Dv7M2h61DrNzrfxD8U2dnqEU8Wi+IPB+qaxoAt0kfY0l gfho0cllIsiPDDG0YDWMLLJJtQJ9Kar4q/Z81jTLnS7jwfE9ldFLZIYvhD4lmSS3mZBJIkR8 BSxKUuJJh80bKHjLsvzZrznxR+1N4ns/GWueF/C3gW4vray8Y6n4CgvbjTYENz4isdaOj2rO 914zsiIpLi90uQzfYreJ/Of/AEdNrwJzN5+3HqETeDo7XS9DWHVTp93rdpc2MtzqCR33izUf CkjW+m6d4suNVjgS1FlcfbzavpkTCcPffacWJ462P4+zKNGvXr5nOnTpU68IU83w+BSi1Bqo 6NfKsXU5pJpyq+0VOUmnGnFSUS5ew0jeK6P3o99b7W9Ld+jPOvGXwp8FRapdeIPhF4q+MXgH UZruUGw0DwB46tNFltJlWOWO3sND8I+FpEhR0luYVN7MiNcSMUkLM79L4D/am/aX8KSHSPFP 7PniTx3othZW0Mfi7SrDxpo15b21u0dsW1GC9sPGlzcTzWlpNqclwjWcZlZkMJkBL/QvgH9o n/hNfHug+DYdPhtdbnk1rV9Utxp13brp/hiPSr+80fVJ5LnVrkW9vqUd/wCGGti6yXE39qwK 8MLPN5HLfHj4rfEnwH8Yri+8HPpWp+H9G+C2jeJfElp4hsoTdQ6ZpvinxlNqM3h9bOTSZ73z LK0jjhea4urcyJAPPiecvNVfPsyzpU+Hs+yDAZvVVGpXw9XPcdU+vYaEVTbeFzGlRwmEhTxH s4c7nl1W6pxUJK7ZnKHI4PDVornv7RJxe1lBbqzV5au97+t9vRv2q/EGvzr9j+BnxGglaNy0 Mmk+OoY42jYIA97c/De0tZWIaKUlShEbeTjdG8g9P0n9oj4hxxKNP/Z28c6ncrG7yIW8QxDy llEYkEsngQpFu81Dud33f6tRucFfA/DH7WXjPxb8WtN0DStDeT4W6j4l0/wlI3/CG6/DrUGq X/h201KbUptYmuW0OKztprxVcG9e5jhTc2lyqrTP7z8ffH3xK8PX/wAI/D3ws1DwTo2p+ME8 Zi61Tx7PFaWDWvhix0a48iOeW5WGC5Z7h1Vfsbm5SPdGwVTK3wmcZDXjXweVVckeWxx1OpWp U5ZhDE0oulCpUVq39n4aKpr2LTTjdQTk5dT0KE+RKU6tJyi+ZJzSk7KLWnM7vsuuu51Fr+0d 8a4AZLP9k3xlfqYhcIreJ7i2DE4ZAJJvAuwDCqCuNw80MdoUhvPvhh8Q/wBpP4caV4whm/ZS 12fTNa8XLr0uo3vxO8P6VaafDB4W8JaSsE0kuhyQR+dc6RKRJPLbsWuEVYGHlyXHlGm/ts+N 4fAp16CLw3oGoSXPw4ls7bWNKktBqx8R6P45vL680q2u9dnm1CyM+h6XHBNbSMp84R24uGmk aPi9d/a3/aHv/Ctpc+Of+EWufCPj+PxTFHoen+HJbW60pPh7ZWWrXM17K09pd2SahfXlrcQt Jq199qhtpY4ksV+SfxXwLjYYXMlWw+Eo0Z1sGoVauMpwpzblQ0jOUFGT0ekXrZ2IljG6iai2 rrVXsrJX1/zt+R96W37QH7U81nBdW37HflWr24mtL69+MPhSKwntGnMVtMdUn0yzsXN5EUuY IxOkjpLGUSRQHfq9M+Mv7Y2p263lh+ybpkVrLbLeQzD4ueEdRhMDKHhV3try1WMzI3mCZ/LU BJAYshin5wr+0b8W/Htqvwo8VeI9Gt/ht4w8MeELXR/D9jZeGSqwaR4d8MeLtIU6tYLqWvaf fxL4deS5TWtTSLbFLZTRi8urOOTsNB/aX+P/AMMvD1p4I8V+PgI7Twb8IZ/h7qOmeFPCsl5p 9vqnw4t9Z1OzE994Vs9NEwutY0IWs/iixmtIG03bd3wtvt0l/wAs/DLGR51DKclxVWcoyovE Rr169aM7yn7OVHF0FVhBcjXJRfKpe9JuSZs8de21rRvZq17LS+uuib+a8j70X4s/tfNrlp4d n+AHgXTdWnhiu7bT7r4leErjU3tZnuwboaYvjC1vLmJf7Pu3TykQyrBKiNmJmN+Dxz+2Bqt7 qFrp/wAJ/hm1zpV+2n6sia7o1/Jp94tlbXy6fe28HxNhlsL02V/p16VuWDC3uoCYALuFx+WG k/tC/FfxL8RPCPirxP8AGOw8LeIfB+g/ELS7fXrmy+GqDX5tA8Haz418L2FxPaeF9c8ITuNc 8SHRYYdLTSdQ1L+0YtJxdayLWZO6t/jh8ap/CvjBYtQl0mf4hfFrSdd8YeNW0XwxpsGo2Q+D /hD7HqkF54mtl8L2Frrt54a8M3Fs9rpdtHcx3ccdils161umk/D/ABFJ1adDLeE6TpKN51ad dw1f7ynZZtTXPypJLmunvF7BHFyerXLH+Zt2vpZbb389fm7/AKVXWu/tX6dp9xqWreH/AIR+ H7O0tnuNTvtT0oC00+KOCS4uZPPb4z2kcotIoZ5nMUjF44Wddo5q5p1j+1LrGlQ6pFrXwqit dSt7a+09rXwFrN9DcWt9FFPbol9bfHkW6yCOWPbI6p9pEsflW8ZIVtX4L6p43+J/7Hklx42N vrni3XPh9490WXU9Et4Y7DWfss3i7w5o17pz6aiaZe+dpdrpx8/SIHtLyaY3NrBLFNFX5xeD /EnjHwfovgxf2fvF2s+OtE0v4YeFfiX8Xobzw9pOoweEPFvh7RdS8R+NNFvryPwhobaXdato vhaTS7TQ5r2a7S+tEggm0m5u1vJ/l8Fk0Me8dgaWT8M0cfhsTDD+1q4TFxp3qzUYu0s2h7rT 921RqSatujX200lJxlZ9bOzSa17fq+u9n+iB+HX7TmoRStd/EbwRors+2OKz+G3ie8BVI1bc r2nx62wl/wB6WD9Cm458xBUUXwd/aFvhdQ/8L60K1eFINwsPAfimOXM0MhlikVPjvI0OxxgJ IMhh8wLKawf2Y/FXjbx9+yb4x+J2uRapPrPjKL4k6vpel2GjWlvqz22haE/hG1h0vRDasW1O 51PwtcR2dpfyXSXbXCykLDPbpB8h/sx3Pi7w9+0k2q6boXiG30/xlJ4nsvHcOpeGdT/tHTNZ j+JHg+HRR4ikWxXStBv7ixl8VXFjaWN3FFfWsV7cm0mXTC1n5rwFfD4biCrUqZEsZwziK2E+ qUqFVuU8JVWHq06cP7VlV5adSLhZOTj7qlK+p280nCEoxk04xbsnLRpO6stbd9uu2/t3jm21 3wL408K/D3Xv2tb0+K/E/kPa6VYeBviKkthby372Hn3s1p8SdXsxGZ7W/VHubrTUP9nXOCUy 8fpS/s5fEe71CKG5/ar8UJeNAZZ7C0GswXVtEjOFn8l/iZcS3FuVEZkuYohBCZiZJF+yTg+E ftkfATVdT+NjeO/BfgfxDq/iOf4Z2tzp+t6ZZ67q1udU0LXfiN4hubG3t7ZLnTZL6WHVj5Fl NaSPdyajaW9qDI8WzwKD9lb4j6d8FNQ8deCfhx43H7QOreMPFvg27nvtPuPMuvCmu/CjW9Hj 8nQruFNFt9Bee50q0l8Ry6dbyQasl1anU1K+Q33GBo4TE5dk+Lnn2QZdiMRSr1cXQjGCqU5K VHlhXhUziM6Uoq7jGavaTdkkmcUquIjKNqU2m3q4Tto11S89/Vrz+8tO/Zg8Ra3dXyp+1j8S L2S1uJba7i0vUNUuv7NuIJp7dxcyQeL7tE+0S2kwFu3kvayq1rNJNPC+6of2YbHT9Vh0nXf2 rvi5p2rXu42WmzePI7DUL1PtMVtFJZ2NzfSXUpu7mV7e1hjjlleeGSGIzyI6p83/APBPb4X/ ABR8DfFbVk8ZeFdZ8MW9z8OtT0/x7JdeFPGGi6Q/jDTdc8OJAF1/xZodno+p3Ut+mvzMfAur 6hoc00lzJAq6V/Y+30n9o/8AZc1Dxj8Tvij470/wBqfiDxJovgT4f+JvhvrWmXWriJfEug+I P2gNZu9Hs7V7y20zV9aS/wBU8FXaaTd2l/FItxbxlxb3U0Vx8rXxuJoZ7HDRz7Llgq9SNGGN jhWqVpv2cp06v9qOi3BvmvdxUl710dtKrUcXzRlF8t7WtZ280nrpZ3evZvXo/Ev7Onw/8L2O v6h4u/at+KVs3hbRrrXfE2m3HxP0m61HTNItbK61H7VJp0KXmomOXT7Se6jENjcySRwO8UUm 3aL/AIE/ZV+GnxI8KaX4z8I/Hr4zeKfDGuWxvNMv7PxlZQw3EQuZrWZmkvtADwtb3kE9q0dx awSyyxOyKojYV8b6v+yv8RJm0nwfdfBvx5qXxZu/E/iUX3xGW3k/4QVvB/iTwv4I0mVb/W7T UbbwtZzpoVh4t0TbFotrqNvdi0lkD3Nxp9/J+lf7O/gXxdov7Ptv8JNR0PUvB2seFLnU9Hhe 9hVILuK2+IHiC8iurK9vP7Ui1C1vNPtob21uo7ZUntL6CdFVJozF63EUa+T5VgqGB44rY2vU zepQqxoLCVatPAwnjYfW5wo4ico0FKGHUq0kqPNUhFzvOF86VaqrN05Jcqd7Ndu68tO+q6nh un/AL9mPVYdWNn+0pr+rw6RqX9mX04+JXgyePTZ3S5MRvGbSWVw62l063CNDb3C29wYpAI3K 1NU+B37Jnhiwk1DxT8c9Q0sR3xsJ4NW8ceC/NhuYE0q6u7be/h3dLNDpuuaRqMsccJNva6lZ SzL5cyO3zz8KP2afjJpHh3xz4f8AF/w0+IGo3Gm/AXxT4AstP1H/AIRW00K+8V3Fjpdlp8Wg 3+k3mj6lqdrPJpOoQQ6hJfy6d9jlt5rmRbi5tpqo/Cz9kD9oP4Tf8Kiu/E3w7t/H1x8JNV+J 8+urofiHRp7rxta/ETRbKwsjpyQ654QtFk0iGc2V0kx8GMItNMtsus3LG5vuvG0oYXHzw68Q qfs/ckpyxeW01eUYtpJ4hq61T9567o6HXq2TVOT9IN30VrW7tpPXft1+gpfhx+xRBqVhp938 W9Nu7nUdFt9Z063n1/wbfLd6feM8unX8moR+F5LKNLvSwt6FnaKZJpVt3CTusLb0Pwy/Ynk8 R6r4UXxP4Vm1jR5p7O4jni8Hxw3d9BcR2kttFqE3hNdNM9tdv9ju0jvLpopy6y+SYJkHyV8Q P2M/jl481vx1qt78LPE1povxLMeq23gzQPE/w6ttM0ZbXV9IOk2Ov33iPxRda1Z6xFo3hizv tUg0/wAW6nZ/2vcQQQTG1lurG3ll/wCCf3xem1K08N6z4QvNV0O18ZXGsWWvt4v8G2uiadYa vrd9qV/cwLb6hpniea+09NUjSOC90S8t3+xah5UOoD7DLd+gsJlnsFVx/iTRdC9KU6dPNMmh Vl71NxcHOpUvyz5ZSSptuMZJcrfNHL6xXlePs5pN3u4ySVrPTS3TVa736nU6v4r/AGWV8YTa J4B8J/D3xb4cs7HwjqNz4uvdN8Ow2UH9s63rVlrMKLP4PsYb1NH0/Rmu/PtLtkkubhrFl+02 kkUvsfhvVv2J9Y8RWXhmPT/hzHqU9mqzarP4R0abw9HrS6Yur3Oif2g/gu30db1NNEl6lu/i A3CxBR5UrkBvAJf2LP2oNQX4e+GNQ8I+Df7C+HngD4meHB4iHimzWa/vvF48da9oaWgh1NvM gsfEXiO2tb2a/wBD0xkikmCi+toY7qvcNO/Y2+Ky/s0ar8LriLQIvF8vxQ0Txxp0aa/EbJbO LwB4Z8PanJNem0kh3HU4Nbjjt9jFlNvPCxt2hatK2Y8LRjRpYbjfGV3B3c6WZ5TUs9ff5aeH k5c1/wCCpRlDmUXVlyty6KVWpvaSfS6fl+N7WX+djufBeu/sh+MvFcXhbw14Q+Hst3qMd1Lp T3fw7tBZ6raafqmm6NdXejahdeCtK0u+it77V9Piknsb26jnN5BNC3kMZT8w/tqXtz8Jfid4 E0Pwp4J8AeH9Bu9AsdSTUdY8HC10jU9efxNfWNxoEmtWWp+HdB0pIYbTRbWW41OaWMDX7dnx CEjmr+EP+F42fxq/Z/8AhHbeFL+88KfAjxzN4QkudP8AB3ieK9s/AJ+Ingi3tdU1nWtb02x0 i9srXw7oVm51TTRDcToy30Ud5FJNcx/a/wC2r8F/jd8VPDNlp/wen0K8tl0m/h1bwjrt1a2V tq99PqOk3FjJNfT6eNQt4oktZJZRZ+I9LGbMKY5PMZLjDB4qhkfF+STxObUcVlWaZbmGIq1s Xm+Btg6UqGFqYXEVHCjSjGtivauXJUlBOVN8jlytLtVeclGDvF2S1XlFX10tbz6/f434o8b+ IdB+Nvwe8MaN8FfB4+E3i/xLo/hvWviPp7aSdITWtVtvFc0eiafFp8f2K+1Brmw0hW2S3qzb 57AxJdoHter/AGvNZ1fwdb/Bzwd4LuNL8Iy/FDx9J4V1LW10y8WSwsZJbPSIktYdI1Xw+UuR /bn22AXt68IaxwtuQXlh9J8C/swa14K/Z/8Ag58H59XtL7WPhX8TNF+Ir6suoiSN7fTviRq/ iy4W0lXQbBLueLTNXnjigutEtbd7hGhe6Yok0mZ8Ufgb8TfjJ4u8S2nia5sNP8JeDrnw14u+ DOtx32nWV03jHT/Dqxyf25HDp+pS3Vq+szSXBtptKSJ4bYiFliIhn+Pw/EWQZnhsqxWJoYTD OjfD1KMOavOvNXlSrzvVpunOlVqxqThyyUqdJJODlzx0w6dP2snUT54xi1pde8nsm3q+ve5+ ctz8b/ip8WvHul/B8avL4G1zwTefEDw3q1/pF14givdY1vwFok2p28c1s2v2KRfbdV8MS2Nx anUNRZYNTuIobwykTT5OnfH/AOI/xe8X6544s/EF/o8Xwt+GGofEi38LaNqHiOLQ/Ew8Ia9D DdWmtWk2rw/aNN1O31m7sbt4YmkimtLWdjcQ2s1pL9vaH+wTrOn2mq/EG88VWS/H/U/F+ueP ofEun6yG8MpqfixdKm8QwJpt74L+w7JJR4jFqh0ia0hj1GyMd8RFvsdeH/gnd4L0/wAH2VnY +Idb07X3sNW8J+JtdOv2TQah4F1+41l9a0VFvfCNxZQXVzb6skcV/baXY3cDRqsOpRShjN+g z4z4IhglGpSwlaEE4T9nRk/9pScXjnJYmcVShFVaDp20qVo3rpx9nPhjTm6sKnO4pTjurLRx fW29vn+ffRfHqTw/+y94d+OF9o1rNcv4Y8Iane6NBcXiwG88Q6hp2lXNul7Fa3tzbJaXF/JL GJ7ad5VgMLMDunX5U8W/to/Hbwb4es7jxV8FtAtde8X+GYfGXgaI+IJzaXuhT2M7zPLLDdX6 XCafeXehLPuvtHm8vU0ZrOASrNH+iOk/CHwB4P8AhN4Y+F1/OR4X0TSNH0QS3WteVcajY6Oq S2Mjag4so3mNzDZTtLbxWcc6FwsZjdYz8y6V+yX8B9PkvJ/Fnj281y0l8MyeEPD4v/GGgWUe jaEzb2tt+laFoMjyLEtoGudTk1GeNYCZHVmkaX89yLGcJYzM8wqYvLcX/Zv1rEzpL6rVUK1K pUqOhTpVJQcJzhGyagpS1vyxurezKUqk4ySbjvdJvTTVPW/5b6XPoH4bah4y1jwFaXnjtbGy 8SXqatHd2Ojs0Omqsd7e29v5NtJrOvO26yW2kkP9pSr57StiMZgi8F+Btxcaf8aP2ivDUi/8 e2p+HdVskcOJni1OXV9Sun2hjEY0fVoAjIqMEkj8ze7Fh9g+Eo/D1xoUFp4V1Oz1jSbPzYHk s9Qt9RWOR7y5vHia4tWYLIrXDSsszKdjII92CB4NZeH4/DH7UVzfNHJBb+PPBWvySSO7TCaf w5B8OkhWJQpaAol3cFlAcSqCxx5YNfPZbi8PNYvKsPRqUKVJ4ut7KtTlQrSqUML7aVSNKdpO Hs6Sk5JNJRl0iz0qVSMIq7jzJu6btLTl1tu1vrZ+ujPoGPckIymCqKPun7yp0OP1pUffsJxw /PXGMr6/Tnn+VaxsrhsxiFj5YO45UZx8pYNuCkHHGOO+MVVFu6YYI2zcMng4IIzx16EY457Z wa+ceJpOvi+SrSlCi4RoyjUi4zlKlCUoxabTak5QajrdNPVM7KeIpVFdzhzdUpq+q63bd9vm /kaOkQ3FxfrFbruAjduFzyEBbjegxluv05NezeA9Nm0/+1fNiaITfYdm5VG4R/bM42k9N469 MivOPCUsdvqQLnarRTYyRn5kQ9MgjkE9OnvXuGkEETkEEHyiMEH/AJ6fl+Nf2L9H7EPHY7hh 80ZSwEMdGtCElKVGUsmxdOKrLem5OTSUlFtpJLVn5vxTWqOVam4tQkotSaavatF6NpJpcq1W /pvs0UUV/ah8Kfw7aR4TsfEXwQ+GfhzQfB0tpf3fxs8FweP7Ky8LQLcXkFx4RjsLtNcisIxd /Y7aabVIpmvo4ED3tyrxxSl1r9bv2e/Aun+Gvjf8cbnRtGtdG0M2/wALbbTZ9L0/+ztMvJYf DXiWXVriKG2SHTpbgf2nHZXMqSXE+IYUnljCQRReu6fDAHPlRQl2EeSI03EKTtBIAJwWbb6F jjqa9Z8MrO0LyukwJuiCQW+YLHHgk4JJBbA9ABivxLxnzZYTw84gpyatjqVGGmt3KVrWUXb4 nq7fgfovDGXxlnkanSyavfo49nfotrWtqbMyzOjhMeQHKo2MM8gbJY4Q4yu4jEjnAHGOmZeM beAu8e/APbPRGY/eU9cD68V0Tn5mUREM5yXYc7h1JyqkkquMls9vasy6RozOzsJk82MeVIQy ABJNy7SxABxtYY55GK/gz2jnChGN1y4im7/9u0nt93XReVz9dxtvYNLXlcV6WcfyR86+B2F9 8VPi7qgwBBbeAbGGKWGOYefZeH9Vv28hnLIqyDU4FZEQMZAxdHDJu+W/22Pitci2074OaP4t 1Pwb4h8QT6L4hvtd0iazt30zToIdfuFt5orbUdL1FPtT6NYQuwltIW+0whmmDeXP9Q/BjUjr Wp/ErWgkSwX/AIq0myEiBpVSOy8FeHFinViVdXe6up4QXUDdbjZnDGupg+HHgqLxz4h8cGVL 7xTrGnppF67Lpj3dlYxNpDx2lvP9il1GFXXTLW8aGS4ki23kzeSPMSRf1CWPprPIV69J16OD ymjKrTUpRc1FYaNlKFpfbT0e3kfISpTr0q1GnP2c6ilGE/5Xda9vkfBek/tKfEjxV4R8NDwD fW+jXfhz4QDxV4r1rVbvTLltZbSfD/hUy6ZLnw1q6xXV1dXN+8pnmQBrWUSRSlXW36bwz+1D 4o1XxBF4F1TRbiHxV4q13QLjwwr3dkv2fw3qOs7Lh1txoFteSxR6fYamWmtrK4i2RswvIljk lg+lPD/7Lfw58LyeMptMjvVPjDT9W02/N3D4ftrIWGrS3M99b2SDRrRZGhkmSFIJJ7lXSM7r d8HZxHhH4LX7/Em7+JfjLSbbTb/wvbL4W+G9lpelWUTan4bsB4njt9RN6LvV7i1F5beJI0Vb eLTbbZA6pE6vKlv9G8fw3jcBVdDASp4lwtyuvi00311mktnp8tTz6OV5hTmv+FCP309L28+/ lqvmc/8AtN/FnxL4P0bTrHwNrltofiTUrnTpYJ7ePSNc1WzsWOtm6aHw9qlhcxahFP8A2YYn eVoUt0nku43M1osc354+LPi18RviHY6RqsPjTVvDut3Ph6O0vblJYbdf7R1TStJjtpri2sUs LfSlkk0+S8lFrbbrElo7OKdEaQ/qZ8Rfgr8O/i1q1rqV3dPe3ekJBa2muaEdEe4BhivnbTJ7 q403UpyVh1q6uWSO5gQRtbjyRiR58eT9nL4RLp8mknRLVdPSzjsIbiHSfDrygW9q1miJbRaA 7WqQxl0jZ4xDEIo1UhCobbhvOuH8BhY0sXksqteEeSrUf1ifPNPVtq6enW723OXF5dj61WpD 64nyu9/3dnpG1ldLo+p+dsf7X/xgn8TajeWdz4s/4R3S9Y17wxcabdaBoa2N3/ZazRx+If7f GlXNzAkaanbXyWYR4ZDpkUUt75eoTT29Pxh8efjj4S8CxaxrHxV1S/1+50nVvFsejaRoHh28 1GLT9HfX7NI7q2uLaxk/suWbw7JLdaq9lLFZi6Vfs10bf5/0Ei/Z8+EdnfS64nhzR3lZp/ON 7o/hm6jim1JZra9nfZosMscjRXe55JHBkaKPzHcRstLrvwf+GHiZrCTXvDmh3s1hEI7aSfQ9 Dv0NiJr13sZZp9KuVOnCa/vbuW0WWKI3DPIQskkjP6mIznhmvThPD5I4TVaMneOIbcIxkpat Jbta7+drnDLLsdb2UsXFKL5vsW2S736+W/oflxZfFP4i+J/t3jrWPFGqavDrfhj4f+R4W1J4 oLF7/XPDelard3qiG3mtIDaNo909xDZ6Q0aXl5FEBEiebXrN78cfif4d0KXxlefEKfxKnivQ fE82keGI7fRrO58JSWtnoeq6Rdh4bW5N9c6YNaudPnMlnaNJIsBnmmLxRW33vb/Cf4d6ZcW1 5Z+EPDZNtb21vZ3H9g6F5a2lrYrp0MFvHFpySxQW1sYrWKKOXy4IYo4VRYlVFxLf4efCjw42 t6p/wjHgq1s9VN1LrV8dD8O6fbsgM1xMt7K1iFmS4imuppzcu4dLcs4IVzT/ALfyeUI01k8t NNqtna3l0t+WolhMZT/5jLaK+sOyv1v6nz18GvFnxO0X40T+BvHvxC1HxrpNz4GuteW71Sxt NEtF1OfVrDTbWDbF9pPnrbxSwxKt0BMbvAt9/wA7elftTaz4z0z4c6bb+A/Et54O8R6x4q0+ yttf08Bmgsf7O1fWJ4lwoNxDPb6elu7gKyO8bAlWbPrWpeBvCXiKKC6urDSo7q2vdLuft1ha aWlxLb6RqtrqltaPevb3JFlJqNvCskZcxrKA6hJlDDrzpGlfZLdNQsbaeytUH2Fb6Sw1G2t+ BEs8EK25WFhE5tmeMR4NyYyV3GJ/nsbVwaxVOpPCzp8sovkoqrOL1T1cbq/r0Oz2GIo03D6w te3Lo9FZPXqtN7vzaPyqvPix8YbXxjqOkad4z8QBfCnjaz8LLJrur3mnNq1jYapq9rd3H2M2 mrpeSaiLGxNst3LdSkrexC9UPcNec1F8VvilceEtH1bSvjNrutan4q07xXY6kkeqefd6Jcx/ atE0J18q8vnikaWU6hH5MelysEUxm6kCyr+qus6N4B1PUJ9IvLPwvbeKtR0HU1s74WmkT6/c 6aJ4LWXU7O4EJuoIYdRvrabzmmkijvbiB2fzDvav8PfhP4T+GvhS18NWdnY3McUl01zf3un6 WNS1WW+vbiSKG7ktreMSzWy3KW1kZUlaOJ4FVCo2v9PT4jyinChSqZDCdZUpcspOpzTppq7k v5edxT5L1b2aXIpHmU8ux06kpLFKNJtObfJ8VlbW99k9LfkrfnDd+I/GWg6DfLr3xl8U23iD SPBfgnUtMhfX9Rjvry+8Q2fgvVNS1OKyuvENm8+f+Ej8QWLM8N1GsVvK8X2dYI7exx9Xv9X8 YJ8P9U8SeM9X1D4gn4kG51HwpqOp3if8I++leIb7T9LMeipqSxW5uLOPTWiuD4X0yRIpBsFy LySSf9c4tF8PPPZ3kmj6KLy2BsbSa5sbCe6EMUE4Wxhl8qOaJIoWlka3UhUdJ2MabmVEhPg+ OW91Tf4aFy7MdQuVu9FEkBiMnmCe6GWRGMTORK/Ig3AsIiw5afFGHoV6lRcOc3I26cU371O6 Wjf2bOOlX/aduqqGk8nqXUoY1WVnLVXW3nbW/TfR9T8mNE+KvjjWPBfhQR+NPFt5c2Phi+fx rfR39wLhRqvjbxtZvLe/Zr1nSTTvC9naXUZvZbHbarE6SWsJ+3t0A1LRZfEvgzXLS68Y6/o9 nbWyzX2oalqq2cmvy+E9Vi1RdN1pfEmr7Wa5vLy4lsYZLZILiXUrcWkYiaSb9RbfU/BVnbPe xXHhFLe7b/Q7iK60a3ttSkjIt5VjmEhjujDKy2+I3YxTExt8zBBynjr4s+APhxoc2u+Irzw7 bJZvY3djp631rFdXcGqNHZo8MFta6hdSae011eXIkgsmgluYGuPOVS5OceKqlKu6tPhv2XtN Fr0k0763XRa+VraGUsqq2/32Pr7vZW2b/wCArH5g2WseKLiws7S8ufiJe/EeO4+HUHhI2t54 gX+yrebw5eKbldPg1SIzWT3a+D5tULaLcxNcx24n+1SXKPe++/DHw3r/AIf+JHwF1PzPFF0/ iGDWNQ8Ys2qeJZ5opJvCltJBYeIrO6u5reFDfXmoxRx3TRRxXE2oGC2MsTI/2lY/EzwJLG0+ r614Y8Ok3t5bWzaxq2n6dLKLC+ubIzW7aj9hciNYYpgqK2yOaAq5jCSSdNP8Qfh9ZalYaDe+ MPAsGqX9y8dnpUmraTBrF4szx21p9ms3v2up7i7uY5bZjHbOzSRshiUqRWGa51iK+ExNKWRq MsXFPmbVrQUEt+1klqr266k0cI6U3GVZTkuVOV/JPS2isnZdX01Pgn4/trifF/xBaappPi3X Li88AaQvw7u9BbWU0fSvFMmsWUVjLAtg9lbSaxavHr91OLe0v706bdSK6y26yQw+j/sj/D/U dOl8W+K/FunXCeLdY+wRPqPiKHUJL5W0/VNahKIdYj4kVLbTT+6gjfZbQCTgLn3f4sfFK7+G Xh2y1SDw7P4iuvt8Nzdackeo2tvpulwQapd3urXuqQ6fqFklnbQaVIohlFsXvLq2RJnnaC1u uk8M/EPRvEXgjRvH2p3dnoWk6jpQ1i5N1ehLWzVo5LieMyXMdq7Q2cdvcgztAqyRRmVAsbLu 8d46rLhtxWAjFyxVPBKMYwqPm9l7VR5bSVuWm3zNWTSV7tI0pUJSxFRTqJRVN21688F0fZvv 5nwfd/CaPxP4p8Z6r4k8H3Wr3t18aNPGj3t7a6uLmy8OL8QNNvNVjtAsaq+mz6VdXa30UTrZ S2Xnx3TmzeTHgVt8J/HNna2p1Hwb4nl0aHwBJaxW+n+H9cuZ9NvJPiRPcgx6W9nZWmtLBHLN q02jajeW9nfRSyLdoLYecf101b4ofDfwrDOdd8d+GdI+wy/6TBNqVvNcyyXc8ensotbaZrmZ 450CSeVBM0ZYvMEjUtVHUfjr8Iba+0+Kf4k+FI73Wzarp0djqkV7aXbT30mm2cg1Gwe4sbC3 utStDpEt/e3CWcdyzWU0qTTxR11YPiHMcFSwVOeTzqwq2wyf1anpeUI20ovVqXdd09Wziq4S g561Y9n1008+2ttdz849O8F/FHwl4YsrmHwP4i8Rr4y8N614e8PafpHh/V9P1Xw+tt4x8K+I 4tQ1vw/p+hT2uinV9H8N3JW0sri+Tz7rKXNzAkt29aP4GfE/UtXuNG8O+Gr7wrqlx4IuYdX1 6/sfEc1hfPe3Udokun6nc6FLcabq/wBoS4vDpmnRWixQiC4ivi8Uaw/ofeftJ/BO0m1LTrv4 iaZJq2k3tvaGz0zR/EOuzyahLFdvNYWTaPp98NRkitYL66nk01rlJYNOub0iO2glaP1rR9Z0 bxNo9jqnhy9t9W07UIbS/tZYkeBG821S4hjjW5WFn2QXluxgEazKJ0BWMttPVLinNMu+s4l5 dGhTqygq0a6pTleDpwpJXjNwVlBJJJK9rKztH1ClOz9omlZLXTZea/y1Pgf9k/4Ra94W8ft4 zvPCdx4Q0+y8O6t4dWxvpfEdtczTSX2m6y9xBp+pabaWDWE0DTQtc+Z50dzBcyJCxgMlP8d/ AXx14l+JfxP02LRdKntPiV4p0LxZpnxBuTrkl74T0/w/ousyjTnuU8OTNF/ay+I7PRbNbTxF aWzWGmtGFkiWHT1+tvFXx1+GfhvxhdaHq/iArJbraDUNWi03XbnQ9LmlsYdRtbO61y00e80L T7y5jNksNpd6vFdTSanZxRQGfULOKaz4P+KHh/x7Br+oeEZdTuNM0+6NvHq1zo3iK20S+kTU 73T7ptGvtQ0jSbG+cXmnXa3T6ZeagrSK8jlUZXfxcRmed4jEPO1gXQeJjDA6ypNTVTlrQnBN 6R5aSVlGP6FLCYePxyUmtrJ6aLtvfzPM/gX8Ldc8K/C3xh4R1KC2fV/Emra/fWtxFY3M8cFv qfh3SdMtxcx3lnDOoiuY5HeWKKQFSVUlwVrx7wV+zR47XwH410rWk8M2WreItE8GaVpFxINW lkjj8MeNPF3iK/MKXXh2ylhmng10W9vFYK7zTiNrmeJJIjH6J8N/2tPC2o+DbDVPG1i/hfVH 0fTNY0mwvLbxFp3/AAlEd9pUNxNBoS6l4fMusQyXEEENtYaU2pXUv2uAKJ2mhMvnnxP/AGxN e0n+ztG8O+BLu11a60bx3H4hg1XTvF1nqXhXUNJ8ORa5olxPby6No1xb2+oWd/bXbTTCKOa0 VvIvYmjleHtqVeK8Vi69XDYeCqZvmWHxVGUnhuXny2pBxb5mlyqWITfMlHXVSRlUhRUJRVuV xcXrbRqztd3a/wCG6XOJvP2M/ij9ma30rWPB8Oq3YKWfiA3PiHRtX0qNrtr17MjT/DdzPqit axTQSRXl/GqfbHl8s/2Za+b9WfE/4OeLPHPg34c6fYeJtNj8R/D2+0rXIG1aCdrSbVdE04W7 XAKQ3j2EU+pRxzpO2nXS/ZpTK9qzKLaTK/Zy+O7fFODSfD2u6ZeaP4p/4RYapdRSvq6rfW9v Jpy/2tZR6npkfm2movdefA0Wo35ETMRc3QjmmHT/ALRemeLZfh1qPiXwZ461PwjqPhnR/Evi iZ7FdThOow6Lot1dW+nT3lhr2hPLbtJDGZ3jknDOBJHBGQuOXMc24iqZxk+EzKOEo1qVSc5V oxwzUXOnOhzfu4uLvKLT1a/MqOEhHDqVPWyT69VHz7ad9PU+Xdc/ZD+KnjDW18TeKfHPg3Wd V1n+zNN1+5fTbiWC00zTLlorL7G0ejW9vflre8ujOZbTRmt3RU+03YRJofW4/wBlzxLpvweX wBofjPSLDXLf4hz+NNN1hNOuWtI7R9In8PPp6ac7zJk2r3EsbqksAi2skaSASx+M+H/iR40+ F3j74JWPjDx54z8d6T430z4gazqdpaaT4+8S3gg0W31/T9OtE07RbzxfPcQpqGni9aOfT5WV WuZoYoEje8TpfDPxt8ZeI/GIvtMub2PT7v4peOtIs9K8RT69oUa6TpWk+KksIr3SfENzotzp M1vHp1r5dnqVpaGN4Y1htIjJbIn1inxjUvQwlahXwWFrzxNOvGWDjJqlJ06i5ZctRezqTnD3 lrypq6aPNSopJ1YXnd3d30vb4dNl/XSU/sT6k1tHaz+OdNuI21Hw5fXS22j3yxvJpdje20hY xanEV837bMRwqDc+9SwUi637J3xU1fRLzw9qnx4a40HQUtLHQvDtv4enm0A2OlSRva2+sQJr Fpb6hAsen2EcdrqtlrMG22IYstxcCTn/ANmvVPFFt46lTxv8Q/iRD4p8TeHm1PVvBfxMk8Wz aTca3BrGhK0HgW7106ZptxZStrLQwSafc+JlGnanpOy9mtyJ9R9T+IfhbXPjd8XtX8GQ/En4 hfDXQ/h54T027so/CPie6019Y1bX9W+IFr9vvbdntbeWw09vAuiyWM1talYo5dSY6p5aRSWP g1M84gnj6WHr472Dw9R4mo3h6eKjJTdOcoKnTo1ruai0mo+7vo9Tqjh8Moe19n2jrzbyXTe2 2lzjLL9hGysfDUOk3XjjS7+a9uNW+3zReEmsknstT0bVNHigi0i3182qw2N1Na6rKYjCtw9n MJQrzSzt618A/wBnG2+CuqeI7+41aPxAdV0fTdHsbiHwbb+HbeytdEJhtYrW7h1W+F7eG2S1 ij+SG5MlnPO91JM8sj/DPjlvFniv46WXh+78W/E74jaUngewuBN8I/F2oDw7NdJr8xa5ltLK 1+JNhJNp9vcSxanN9uDmJIopHsQu1+A8Yx6vYfEj4s2Gs6P8cdc03wr4K8Bf2RBY+KtR/wCK NST4caTdTanrkQ8B62lm4FvHcXUi2/hoySwXkrvG2Ra+ri3nOeU6ODr8TUqcnhKFWM3kzSjR jiJP2X+4RV7xl1Uve2MaXsqU+aNPTTZPurebsrJeqZ+lf/DPWjR67qury6lcXN5qXjtvHhlG nXsTWepz65aavISE11kV2nsIssqRW+Y8C2EYaM+UX/7Evg8eI9L1H+1Tbwadp1npMkg07V0C Wqa7JrsERkHilEgkbWJ7ZkYsJpNyQGZoJ/srePeNPgtaXfi79kubxN4o8YT3nxDiih8cC31q z1LTr4Gz8I3YuLeSK11OHVILvUtc1b7Obi91lJE8qWOafz2uLnC8Z6Nqs3h7UfCtjo+peOLo /tJ+GbCy8Fz6naWmo6ra3fwa8P3r2Ek2o213Zx6a13dz3f2ebSjbSXJEhYzOXfDCwzOnJSp5 /OsqmGxFGKlhKUU1RrRp7ToJpWpaXSstLWRL9m23ybu/32fz3/rp9bfCv4O3fh742eOfGV1o 9jb6fbeDtB8F+GZI7rWZNS1u10yw8L6VcaxHBdWMFrGTD4UhluobS+1dlGqhrjUJHh8289J+ JfwR8J/FHxNBrtxrb2F1pvh+DwjqlvZajq6R6t4c/tDUbyfwtqdppniLTLSe3mkmnQre2t1O VknjK+W7xt8E/Ey18bfDvwf4cHh/whrPw58STeAvFtunhmz1KMGykh+Inwla4jS48PW2iQyS m0lubpni8pWS8uMK+6bf9Iw6T8C/gV4a8K/Efw94607SdeHwnlm/svSLnSrKPxpPpNhoWutq GsroFgL7VtTjvIre3klleS5ZdcmEaia4y/BjKOdfXcDmP9o3boU8HThHDYdqrzRjGXPUVJ+y UG73lKmpaq7tZXTUNf3fbo/+B3+enfT2aP4O/DjRvGI8fWSWPhLTtI1Gz1eXw+ms6ppmhWus Q6ba6NHqlzYLq9roU0ctnJbB7m+0na1yUiaCWSKG7aj8U/DPgH4oa58OtT1v4i+D4PDngG48 W3F9aWvjIaHqMsnirToLSwjtdW0DV9KvbW3hngMk6SX8cNyiwRCCRSFj/Pv9myPXbG/1r4Pf EbwT4jtvD/xD8F+Ltaji+IGj6raWl94qsIorjT7ax0nxHo8Fhe3UemeCnvob1lmlSOyv0hlR rMiC3478G+HfCPwDu9b8NeBPBtxrlp8YdZ0u6iutN8P6dYz6fZ+J/ippUNtqN00dkn2eGOG1 lignvlh/tC0shDGHjggG9LK8yo4qNLMs9VSrSVOhg6saNHEL6tXmqKneNOooSnKpWpvmtOMb S0VmaqNN7097K+ul7dvK/rofp1pv7PX7N3j6PSBY6V4Q8Q2vgux0bTI7fw9rt3qNlDY6Ssv9 mG6sNJ1+Kxa6sYzdppt7fxXF75N/fQpdxQyTLcepH4P/ALOlzoYg1TRPAF94a8KPrz6ncTa4 sttpcGs6bZTaulzdSahssY7nTktmn+03kKvbsrHy4iHfy39km7SaPxdaXnhf4TeEZ47nQxFB 8Mp/CjSXyOt9EZNZXw3rut4lDoEU3YtiW4CnivzR1LxBqXhjwp8f/glJFPHb/tFT6dbWYhF0 8ovfCvgzw4fFVvpSWfm6YZm8N/2G+s/2iVNxYXNtA3nwxpEnw0MszTOsxx2U/wCttSjhcLOU qE54SilUScZVJSvRUk6Dc4w523JRXIndMuSpqD5ad9vxt1f9fPb9mPBfwJ/Za1nWYNc8L+FP Al3c2ek29tp09lqSaxpNnp8NhZWlldwwprN1p0VzJo89taC7Sy+0G2vPKF/NFclpzx1B+x1Y 2XhqfxnpvwtkHiPTbfS9LXUNa8NwajZabpOm6XpFpcA3WuW01vbadpbabDYyWdwRHZG0ZZoB 5Bb89v2NPF3gv4Talb6F488RaH4OspPhPYaLpF54s1Cz0OyvofD194O8PQCG9v2ttNe6Mng/ VLdrGOdZhNp180MQhtyq874W0vw14a0fTPGY8eeDvA/iLXvhBpFleaL8YdIjh8IfEPw9pvhX wtBZx6PqGseIvh5p18Z9Os9G/tGyOseJi9r4ikQ2VrDbzBsK3D2Lw2cctfizH4xYfL6EcLWo yw9CFSKUIp+zvTaly253KN23dt2ZjDkcb+zd7vu09UlbsvRddbH6FeJ9J/YC8G67beEfEfhP 4L22o2si3sGjXU3gcajcXGqQWu2WxOp6/batdSSR21kJl8tVMMEUC+ZCAK9z8UWf7L/hL4Y6 X4p8W+EvhhY/DTWo/DkdjJqWmeDLfTZvM0q1i8NAX+p3Nrp5nt9F0qxsYEt9SmZ7eyXypJ0M hP576Ddnx/4r/wCCb3xTf4Wx+B0l8b/HfTdZ8Px+Hp4U0i1m17QvDlg155ujaXc29tqEkt1e Qpc6fHC8lzdOjtFLJMfqr/gpXo91f/sxyrpLHTxpnxC8K3v2m00+e8OmWbQarYJcC0sZ7S4j hlk1CHTwIni8trxd5MbNG3w1KhVr5rleCjneZRWKx0I4qdWtSdNRcqamnySvdptJxt5eXYlD 2L/dbW6Ppyt/O6t27nrtr+0b+zf4A+GHhrVdG8ReDtB8AR38Hg/RNC0LXPBVjZWl5ejWpLbT YbKLxDa6Wkl+dA1eaKGK4kvLqQTyrFKxvHjzPh9YfA/43/C/4had8HPCGk/DS18V2c/hPxBq egeFvDegairanpTB/to8F6pby3En9naveWbvLqtteBbu7jSQI5Z/xM8f6RrU2qeM59B8Yax4 18O6P8bPgz41P7Q9n4Y8TLaStpXhv4i3d5qNor6ne6gYfDlzqOoW7S23ie5uIW8KqI5oJJIh bftv+yRr/hnUND8c2Ph79oTWv2g5rbX7K7u9e1zTfFdnJoS6naywWelW3/CTalqcphuW066v B9mvBGryYlhVmWSbbOuGoZHgMXmeGzvEVcVVx9J1kqj/AOXc4ex1c5RTb5ErW1adiqeIhUtS dPp220v5a9uqvpqcz8K/2o/2a49d8PfBb4a2F1ougz3T6ToV9Zz+F5/AKalrU0urS6DHqcXi +9aTWNVv9Sm8uwjtbi8nu75IYkKyxgb3jT4/fAD4VWniDxHF4ZtbnXLTx0/hPUbHwjoPgifx ZrXi9LjxVJYobc61Y3d5c3N54c1VLCaeV9We5vLfyLIy3V0IPjbRbzT/AAz8A/ir+y/Fp3i2 6+KPiD4peFbrwj4WTwP4w1C4OnXw+E2tr4jj1XTvD8nhpLXRLqx1jVX1I6rpttpsmlSC6ubS 8tZbg+J2nwr8ZadZ/E/wl42+GfxUvrPw344+Cerab4z8I6Xq2n+JvBkt34J+IupeKvG2jXK+ FPGdxPDoWo6hFf6g2gR2t1LrNto002rpfG2WZUOHstq4eGMxeNxH1zMnSx+PpfXcNGOIjj6a xdZzVHERlGXt3HmjJRqxekoxaaVKpXjZRjorR6LlStZLvpbo7+p+h/iX9uj4I6PpPgvWk0Hx z4s1Lxhq+u+HNF8NeG9M8Ka54w07WdDs/Cl1rOi3ul/8JitzaXltb+MNPjmsrSS4u4WttTFz a26wwtdekfDb9qb4b/Ep/Cdn4e07xPpl74r17VPDtpY6lb6HaT6Zq2l6DrfieSz1aCw8QXkt tLdaRoj31vGkU93Nbahp8r24srhp0/LLTvhb8c/ih4p8BWGl3vxttvCvgb4t6ppfhD48X/hb 4haJ8Qbjwv4rv/Behz+Kb+98QtpWuWKXHhvSLPWb7UFg0yykk13XlvTEkN9Fb/aOpfAW2/Zf 8NfCnXPDVx8Wfjdq2m/tAWvivxt4g1PS9W8dePLjSdV+HPivwfLqWoP4S8Nap4ivbDRLSPw7 p9vI9nqH2WCGztneO0jt0tsMVw/kWDwUqFTFOGNx+Gr14p4uvL2NanFRw1ONq8qf7ypKSlZp JJOfupSThUqte9GyWysmnt2V09Fe/wDmfUPxf+OHw++BMfhSbxtFcxJ478R3nh+1nshotrFb 3MOg6z4tnvtWl1TVdJWOwVdHGnvcxG5lm1rU9LSeJWu/OTV1n43+D9A8W+L/AAvrq6loU/gz 4ey/EybUdVGlWGna74c0/Utc07UpPD819qtu982nvpUM8900cNlDBrGmPPd25ulDfFnxT8F+ Of2zfG2h6Bb6L4p+Efgfwh4X8Yzx+J/Gfwx8bWh12/1vWfhxLbacLPxkfhuWuTLoGr3cbQw3 jrbW7PJEiywXU/m/xG+EHxW+NfwC+Dnhrxj8MPEKeMfgT8cfDXhGJpLHff8Ain4c+HfBdpYa 14qZ9ajuXTRfEmq6dYm8gsb7U9OuJre3LSakbeKZPMnkOT4TLMpnjsep4ivWrPGKOIrOWEpw rz+ryiqdV3c4xozfs7v3nzq/MdKlJ7X2Tei7dfutd72PdLf9u3Wda1KDTPDH7N3xe1y9/sXT 9a1GzFveQXllBqus+JdHgtbmPTdE1i5hvJIPC19fW8ciwrcW89l5cirJNLBr6z+2r4gsfGae AdC/Zz+JWveJbPwjpXi/xFp0MmoLqGjW2p6R4Pv4tPWytfDWqalc3unzeM7XTdUe/t9IFtNZ 3LFppJUgPkX7XXwt1HVf2m9D8eyfCn4i/EbwtP8ADXw5pEl14GiP2TTLzRtV8fy3NlqLw+Cv GzzvcnXNNlmjNpYg2TNH+9Dvc23RW+o/Ej4Y+LPhf8Tvh7+zZ418Q2Wp/C/xf4F13wv9rbSL /Rmtbv4VR+FbrU2j8F294LmfTfB2sOv2vQLaFjcTfZ3s0kihu/pJZLkbwcvYKjiG8PXqwlPN K6dfGwxMKOEw85yxieHhisDzYuaUqdOFSKhLlqNRIhKTte+yS0WytZW2b1v+Xl9o+AfjD4f+ JHw0HxF8OJdzJ/YQ1DUNBnvLSbWdH1c6BZ67P4W1VbK6vxZ63aC+js57OcR3MV0k4a1TaPM+ Z/h9+3p4M8dfFb4ffC6Xwbqvhyb4l+GI9d0TxHe61pL6RFfHXPiRoK6PdMUtHkvZLrwDbR24 tHuZZJPEOnQLbLKqi79A/ZB+GHi34feAfiK/j3S10XWfiz8V/FfxXu/DM0mn3EPh+Pxzovhw 3mgK1nqF/DNa6XdWtxp6R3Is7qRYHM1nEjKK+Ovhp+xt47Mfgfw34w0m/wBO0yLwh4o8Lat4 r87w9JrvhG8h1X4heKvCfiGyhOp3l495ba/4ws5tO+xxh7e40yO4tby0uy09n89l+WcKUJ5x /aGIqVcLCNCngJRxVap70o1vatSVaWIklN0/enJp68r5UzXmkuiutnZJra2i+Wlrbed/018C +N7rx74e13WdK02xhvNE8efELwKNOvtdlWyuLjwB481zwZPqUmp2ukXU1r/alvoraxFajS7i S3a7j0955o1Oov8AIngn4/ftCeJvG/x48IXvgHwhZTfAjS9DvdcguPHepXL6sfEGi6hr2mN4 aWX4J293qCrp2k3Cyz6l/Z5mnvNPZFnjuWng9f8A2T/hV4v+DXw98YeCPGF5c6m0HxU8d6no GvX01sdV1/wtqOo2b6Drl+0Or6wUvNTtVaa8WeS3uVnaRLiys5d0VaPgr4O6l4a/aK+N/wAU JWSbQfi14e8G2VzZta2aJBe+EvD2jaFboZU1CWa+F1CNVe4N1pkKo42JLskxcc9B5JlWKx+H jhqeLwdWjh6mGxFSrjZzpOVX3oKnKUoyvBcvvxaXNeKjJJpOb5XpfaystLON3e3Xr6K54HB+ 3J4fv/BHwP8AEukPoeraj8UvEWreH9T8O2Xi3w9PqujzW/jvTfCGmm7s7XTrkuL2LUP7Rgjj tdPknt43VftDYnDfhv8AFX4w+PfHGtapefGn4QeGPC1t41+IHhyz+HWqa94Xj8YwWPhrVdZ0 jTTcWp8D2d+mBYQ3zI+oTutvGWluLrDs+j8OP2Q7bwf+zf4Z8Av4T8IxfE3wv458MeJrDxev hfwxD4gWDRvjBonjuZn1SDUpJVZ9GsLjSZHt/EEUx0tY7ZYXZUtZszw78Pfj18LNc8ZxeEPg N8MPGi614z17xnaeNtVi8JWWv3E/iwWt9q0Ms7eMYtQZIb6a/tI3maGeW2K+cJQWln+mw8uE 5ZNWngqEcPi5Rm5U6v1ic5u2qpufNGHM7NWtZ3t1CFSSX32dk7J8r0srWTSWu7SenX6h+NWv eH/hb8N/iP8AEyw0fRrHxXY+DvFeqaRqcFrpUGr69rml+HdT1fS9MW/urV5Zpbu7022Fptj1 OVvJhdNPnEYhr540D9pjW/GXwe8KeNtHjk07xFoXjXwJ8OfiTZS3OmXdxBr+s698NtB1m8nQ aYyW1pDceKdXYQ3un6NcMLO7T7NYyKBa+w/tM/Ba/wDj74J8G+CnvJNKsY/H/h/XPGcUMdle yT+HV0jXNK1nTJ0u7+ztriGW21qRWSWHU0n8tR/Zt1EzrXjnib9i7T9G1O4svhBep4R8GeNL Tw1N430K20bRLWzm1rwJruoeJ/DutHT9JvvCNtd6nqN9qENpq11eaTqd0LbSrBo7mweBHTyc ojw1icAp5pjZ/wBp05KnVo1KeZN0crh7sKM50oqhUhGhFwtgJSx/KrSbrcl9IqTa9/lTu1d3 Ss1o3LRXb91aJ200sfEvgD9o343v4etPiH4p/aUsNV8Xad8TfDnh2X4BnRPAlpr3iPT9Un8N 6auiQyRRQa2DqdprkmuxRR+DbiZ4/mgEiGK9T37wjrn7QP7VXxI+Kdl4b+LupfA7TfhFbeAJ 7HQ7bRbLXo73WfF/huS7uLPWhFb+FHig0rVfDWoC6j1WLXRaf2lPZW+mwQRz2831DN+yj4Zb wV8SvC1vqBg1Pxh4u07xt4X8VWWg6baeI/BHiDQfDngix0W40i/DtNC9vqngsX7XVrNo12IN XvLW2urOYrqUuZpP7M/jPwrfWvi/wR8Ujo/j7UfC9h4a8e6lr3hi91uw8ato+n6Jp2i67rFt pHjzwnqd54k0+HRH+zarq3iTXBbpruvxW0FsmosY/WfEPCLw8MLl2GhlznWlh6eLeExWLpxo U4QlCrUpVaFar7KUm1Hkise5a1v3HKa+9a6qLm01sttG76adl0T89D4x/aR+JPxL+HvxP8Ge F/iN8bPFnhBbj4R2V7ex/DnyW0251WyfxpH4g1N0fW/hnt8mWwsmguRAGe0iUzJpqwrBIsfx 5+LXiD9hLTvFtz8QL/w1438VfGK08HaD4v1i5s7O8XTLfUxqkzXkr2USyWsv9j6xpMiRLfMb QHfM0STWMH2R4B/Y78PeCPEnw98W3fjPxT4q1PwRp/iGLV18VxWGpDxXeeJ/CZ8M6i17fSRh obUOZ9Qitrh9Vdrm7n8+7mE7SPJo37GPg3QvFWianF4gv9R8BaF4wj8b2Pwwv9J0mXwlFrcP hOfw1HJHYBV0aJWupZNYkkg0JLxr24uMXSPK9wNv9YuHZ0I4f6xT9jQaq1sRHKXHC1qdFqnW oqlLArMlKtUUp83Koqzbajy3TnJac6vul0bTvZaJJro+nXrb4Y+Kf7QSeIvgV+z54g1HxV4z 1Wbw34o1f4f/ABbtPh1rLS+IvFWp6R4e8ZaDpevRpoHiDw1cQ6Ze694CfX18650t5LW+hJS8 Injl7rUPhtB8WfgF488WeG7b42fDm/8ABekeJ7mCDxvq3xF0fWNTez8FyalFdWrR+Ob6VoBM sCJLIZ0S6WchSwYzfYvir9j74ceJvGl542sbjUPCNzfS2txPpfhbTtC0zTDcWeiroUErJDpa u8kNq160MjuWjbUL5I2EdzKr/UepWkWr6Zf6XfQyG01Gyu9MnVUEjNaXtu9vMXV4pY3DROwZ ZIzGxwJEKnafMzHi7J6eHoYPLaU6bxOJ+u05/VZ2hRbVSNP38O0vdmou7UtNdWy4Va0EuWe2 klpZeWqtvpZaLoz56/Zc8P8AhnT/AIR6HqPhxri5tdeu9bvJ7m71rVNdkkltNZ1LSgDeanqm qvhFstoSKdI1GFKB1Jqb4rW1tpHxJ+DPicxIkf2nx/4evJFURs6al4Yh1C3WSZiItgfwyhVH KyMyoYyVSQH0n4X/AA90n4U+BdD8A6NcXF3puhnUza3N1FbQ3Ezapq9/rE5aO0ihgUxzag8a mOMEpGpclyxrzH9qRZLL4bWevxBi3hzxTpuqFhlWjjvLLVfDxJkX97Grvrkas0QLO5RGHls5 HxlHNJYriOpjad1DF1K+HhB01T5freGlg+Xl9nB71XZuKvzX5uppTxE3XV5OTa+9WcUrLto9 V9nufQyW0QXlV3FNuSMFjgc9cnJOT1z3qg2mx7Cu1TzkjYe+MHrnjGfwrTjZZI4HjbejIjKw +YMrKpVsjrkEH3zUrA7lwD15wD7Yz/8AXr5Gca2Hr16FtaeKtZNO1tezWq830RKrzpybUmnd b9XdW3TstXto9zAjsXtpxPGxTClQVVh1G04JOM+3oM16r4PupLkah5hYhBabQxzgN9pzjgf3 R69q4zarEK6hh3VgCOnHBFegeGoFiS6ZUCGQW5YDbj5fPwBtA4Ge5Ptiv64+izmk6nFksHO6 554t2f8AcyzGy7f3PLp3s/E4grOthbz+Jcq+6pT/AE183c6eiiiv9Cz4o/D2xs79J0kjCKrO gw4O7l1YZ+QjgcHnOfXrXvmgW039n4n3b3uZQDHs2bQsIG7cu7Od3TI6V4/pgnn8thjAeI8l R/dPp7+le06ZO8dqyEfc3yAAg43buRx1zH69q/l/6QVadHg/CYeTXLjMwVGoktZUaShOKT05 XzSXM92rI/XuD1GrjFW1crenb/gfJvqaaWccrmPMgKD5ixQKSAOQQpbHzDHA5z2rmNQhgt0v 55fMCJJNPwybnjUTyZTopwmASxUAlcnkmt+O6kBEgLDfuzyATyecgf7IGPbNeeeM7+4sPDmq 3kjNmHStXYbWBYtHZzSIfu44ERAyDnPPv/IGV03iKutnSfJON93OLjF2eunJFe78+x+gYxT+ rSlFr+Kovd2vGDfls/8AJaI8A/ZVEknwy1DWLZHWLV/Emp3N35kUm+e306x0+ytWgKo1upFx a3kchWUK2wBiHDAfMniH4o/FK/8AjH4/8F/C250LT9S1L4iXmlzahq1gJSNK0bwJpl9e24eZ dQt0lXVNDtojMNOZiY5ollQPkfU37KltLpnwI8MzXuJQJvE816ovryISxnxFq8MW5IY3QkBM HaM7VBOScC7ZeEPhBp3jO48T2ei2MPiXUtU1nU5rwSeIRPJqt+L6C+Z5iJIt5sBNEZREsbRq I0RCy4/S8jzHCUc3xuJr5dPHuhlyh9WcYVIVmvqS5PZ1JxpzTUZO0tLq/mfN4vDyjGlTpT9n Ku1GdRtpRunJyi0rxem62Ts9bW/PrS/2nPj/AKLok2qeJfFfhW/m1/4fa7r2ixQ6Hp8UOm6v YW+lS6LfamF07TZIdOmttV+0ThprtJIm8xEVVXdBa/tA/HG68Sv8NtH8feEta1TWPEFloEXi zSdM0e80y2t21c6fr9v9vOipp7XVvo8V1dW0yaJeQ7tRtJ/MljeOO3+pvih8APhz480ePwx4 IsdG8P6pp19pemX1w83iWKJPBjaPeaXeeHLZoxkPcrHomZIvJbdpe83ociWXpfDXws+BGi6z BpugeFtGh1/w/df2vM6WOqf2k11OJLea7fVLuR/NnYaFdPIW1Ccs8crDL3G+5+uwmf8ADcI0 a8OHZTqTtLF044TAqEKS5P38Ye1SSs5zcdtLO6PCnleOVR2x8rXTt7So3bTyaXlbVH5vWP7Q fxC0PS0js/EOnaZoU0z6jNe6ZB4Tl8VPeMx0/MumeIGuoG05hBDCWsdHMwMcMwlVBfS11E/x 8+JWsBdetPiB4bW5h8Q6DpGj+CF03TItangMOpW8st7pV1oh1aIavPomn3FlI2p2w8nWYiY7 I3NtDZ/UOsaV+x/L4xtfBF54U8OjxHb2wmh0qHQfE1vDMjWl1qHlS3tpZRWTItnPNf8AlzSy xGWKMbRdrD5eL4vv/wBkjwT46XTdb0Lw5onje41vSbeNrXwnrt4kl1BHafY0itrLTG0KwngF zpvl3tu6SK5kfzd0l29dmGz3AYiMJR4dlT9rT9u1DBYPmUPh5IQ9qo6ON5tyVoNuN2kjmeEx tOrO2MvrpKUpt2tG97rrp56+aPk3XfjB8cdLvPB/iPUfE8F3/wAJtp/xCvLSxbw9o8QttN07 wjaax4ccxLoFhcQyC/12cyCW6u/PFokDbzHKtyt/r3xm0LxfewSeLp9QfRNB0HxHLbvovh1p rvX5/G2g6HaWqra+FLIyWb6XqFn51vEbe6U+fdJMqIHP138SPFv7M3gXUtC0Lx3a6LBqFvDL p3h2zl8IavqS6fbXk8Wg3NrZz2OmXsFvHKEhs33SQhooo23CMB1qfEL4u/sy/DzWmPjRbCDX NU0OymEp8IaxfyvZJrJk02+kms9Mu43WDVNEjhSzkIkWS2iuWQRBGYr55DDww06eQU/ZVavN UjUoUIKVNNJwwlSEnKo/53V9ny1Lxi5Rs3MsFXnLmeMadraTnbp5Py+7Tqj470f41fGG7+IP 9oQ3iWniCPVL3T3s7uy8JLbDT7bSNWtLqVdJjefxHCvnWGlOt3eW0NuGnTLot9aRyt8U2fjV /BF7Fq2r6rqH/CdfB/xLr/iK3TTdJaK21CbSLBbaTTf7N0CC6ijf+3NfjS2kkvXKxW+5DIiN L9Ran8X/ANkzwva+GfiRd6LoRXxlHfR6Lrdt8P7iS+1R4Io11YzQSaTHLZmOSILJJcpG90yb 494csfQ9O+IvwK1v4cah8R7a003UPAfh/RtR0ue7l8DQpcWmmWOhW2u3+jjTbm0W6uLaLRha yqFEsUzl7dMSBw/VDPsL7SNalkCpUeX3qWJo0LSbSXuzhOrKyb00WyutXbF5VUlq8bNPTapN eq0X9X0MPx1oEdl8Cn0bwvqU2oW2o61oHh+G/gMF3KbXVvHWnPqsgc2C26C3gmvVM0loTCY8 +XJtV2+QrGw1Dw/4y8S+CPFlz4ksPhHHP4RkvvEDaIj/APEyfwjqeqqkWsWmgSobaTxNd3Fv uW2wpW2s2kjZisv6Bv8AEj4RQ+GPBN3Fbx/8Ib478W2HhnwnEukXrWz+JJ9Q1MWxnspbZbmz C6loWoP9rmhEaMkcm/ZKhrj/ABx8Wf2fdAm8caL4s0mCaPwjN4Vl8Txv4UOpW9wdbtUl0NYw 0TNcmMXsEnmbAbby2iwqsRXn4LMa9FQksnniI15VZQeLwmGrTo0XS92bnOrJ89GSlVkruMox 1fvSOrE0KdRJxq1E0kv4kkr7enml+R84/AXwxqUnxd0vVvGEHiG307TtC8VzfDTULrTPsUU+ nt4n+G9z4fF4YNLhUiWC1hndtSjgeVUmxIwhulhoftR2HxL1r40WkNnYafHpWi+HfCLeCnvd G8T3F1/bN5rGsT65LpE+i6ffWV5cwSRaQ8tv4heW2tWW2f7MtncXDT/QSftLfByytL+51Dwl rmjXnhmLTobPTP7E0Q6hBpOoR6tJZR6dd6TqtxYrHLL4Znt47afULbZPZQyz/Z4Wgnf0/wAJ eNNA+JV6dRvfhzq+mTaKI0SfxQPCmpXyvMt3LBNZT6Z4g1x4lWW3RZkNxblVWJ0Wcl449sU8 W8bSzGvk9SjSwUI0pwpRhySqYj2dWlUgnJKN4NX1jZykleNm+ehRm4TpSrzSlZq05JqySeq/ S/fofAGn6D8YIPiKuqW/h7xTLor+EdEtrDUJtAtVs5PiJDomjW3iY3UIsYtVg0uS3t/E7WMs lrb2LXLackTL50ELY3jD4cahJ4b8Kf8ACrvBHj+zlu7/AENfirfeI/D2rPptxDHp00OsQeH7 eK0utYnktb59chujplhJ5ckUUVtIzTWC3P3h4v8A2iPhd4I8Pf29qejamI7f4ha34De0tNMt ZJl1LRh4giur8kzpALaWTQ7uOF43e5Mc0CuqRtKsWfc/tH+ArPxDqHgmy8HatfXVrr1xodq6 W2jadYX2qz6hPbPDbj7W0kIW/eS3uru7htwZd1zC1zFK01exhcfiKlSnVWRucakoujzUKMYO pa6lV99uWl7u0m279WcMcPyOtGri61OFmud1pvkV1r1emlrrW/3/AJ/XXwb+KFxF4bh1Dwp4 m/4Rh4vEv2WJPDmtwzW+o31uLLybaCTRk1i1N1fwaX9mn8Qxpp32yWWZrlNFjumt+p1X4C6t qHg2+8Nav8J/iDrfxDvdQ0Cfwpq8Vldf2RB4JtfDOg7dNv5dKv7OyXVrW9stcjnE2nyzrIUh ku2YRJH9oSftF6tEviv+2vgnq2mWPw/iR/EM1z4w8Kag1g11pEWv2K6fbWct19vlukurVRIs kAtrmZDJIiQM8foui/HDQL7Ufh0lv4e1GK68b6JaavYSSXkROm2d54e1nWfs07/MVlQ6bPC6 WgaFXnAilaDdnLM8/wA2oXliOHcA6dK3KuV0Xpra9ODv9/z0RMcDhKlv+Fir0Xxyv0t8vvt6 6nxh4R+AnjC/1H4mX/ijwHrJuW8J/EyPw/JN9psTPqOqa1Fc20NjHHdW0d9IPs1ukaFbhPlQ SeYZi8nl3gaDTdP8S6H4I13SF1f4iXHx503UrDVbLU7Wax0nS9P8XeC5xFf2ljrdncQXFpLo uu3ExuvD9xGyvGv2iRbe5isv0Q+Nfx80z4Qav4SsJNGv/ELeLdRlsJ0sL5bQeGdNjGkNqesz yX8IOpLv1S2uXsLEm7uXVgMugNeF+IPFXhbQ/iB8RvFHg34JeGNXm+GA1PXNf1+4vdH0bU5b 2zvvF8t7caXHcaDqU0t7FBo9zfrJLPbLczXMFuZQwlljwy7PsVnlCc62RQpx9jUjglh0vZRn ByhLmqykqtRSnTu3KHuy5orSzfPWpQwtR06NepiOXkftXOT501GWl/5ebleyXL03PeP2iNC8 a6/4c1bwPo3hA+Kvh94n0ebTb2CxkW28V2XiWW01S50y8eW+1jRrRfD1nqVnoU1/Nbpe3Ail uI1inAmign8O+C4/D/7N2n+BviFPbaQlv8PNa0W/Et2wTSNLk0zUYLeC4nsYppWudP0O4gju ZYYr3dNbTyK94+ySfyCX9qbxTdyarr+keHEv/BHhG6sn1vUNR1qystW1PcNJF3a6foo8Naks bxpr1oIvM1i0t7oWdx5stubgh/Vvg78VrT9oGTx9Yan4YVfD+m2+hqlnqc9lMH07XLXWLe+h aOzsoSAYrQo8Zml3I4WJkwc+HDAZ7hMBB47DQw+Hp5gsfVlCpVUnaE6UY2cEuVqrqurS1tY2 pRVS755KpbV87SavG+2zva/profDOm/s0/Fzxdovw/8AiRqXhyfVteuF17XPEmhWN9pmmarJ B468OeHo9K+zWGptpdlBCmr3WuPqCSalBPDZWlxHayXF3Dbwvu3P7Mvx4guNB0CHw9YSeHNM j0OSxls9Y0hLfTbuz8dxeJ9ROqy6pcQ6o4GmjVZo/ssdzFvutNTKqt0bf6J8K/Hzx78QI/D/ AII+G/h2x0zxPrOmQ3EmtXupaPYaR4c0YaaL3w5afZl8M3b3TyNpfiSygWw07/QpZLSS4lig eKW13vHnxs+IHw3+Een6v4u0O3/4TuTxRBBqFpZ6zp08b+FLc3+ta5fpfW/h8ac00XhTSNYi jtFtIr6eaGOCG5jlmhlHuRzbiGl9Uw9aGT0JxqwxeDw2JjVdT2MZQSrTmqE3KKnCXu3to9b3 tyV8HQbvOrWvo3y1Z3e36Hkeufs4/Eq5+HlnpVp4W0XxBqsfjKfXtYsE8QRQ3kekeZ4ygtbz TZzq2k6U0qT+INGjvIrm6f8AcXMxt4jPESn1R8CNK+JPhi3t/B/jOGwvLLR/Bfhq4h1nSRHN /wAT6NH0vVNLkkRbVZFtYtNtboImlq3+lhlu5Q4t4Pkr4s/tUatoVn4M1fSPiJb/AA30PxD4 JtvEktzqHht9de/+2WfgC4XSETT/AAlr16kkN74hku3uZls7eVbM9WeCGP6U+E/xZ8R+NfFG i2Opxx6fb6h8DvA/ji5jh+wW7z634h1C/huJRLpGk2kkglS3ZT5k0FupjVksoWbcPPzOnmuY UsTh8RWyKcMVGOOqNvESnHlxPKo05vBtwip4ZpRjpytrS7sUnhklHmrabt1W7pWV93+K+48y 8ffAb406/q/irwXoo8GW/wAJ/GOq6V4t1LUdSvdTTxNFqegeH9CitbWDyLK4EEE2veD9HEkb aXP5mnzXZW8hkmjNv9R/C/wFd+C/hj4f8G6zeBptItpoZzaSxyRQfatVvNSgk0+Wawt5pFuY po2m/tCByisyxJC4Uj4Vn/aE8Zax8epvBUvxzk8Lwp4u8KaPY+Ax4Cg1T+1rXUPD3hjUZbM+ J7bREawj1i61S+jaWW7Z7E5k3KhiSP1j9snVvjV4a+EOn+Lfht8UpPBV3pN1pFpqIi8O6NqU 2unUm061hVbnULe48lbEw3s2+eJGkSYRIBhQPFzCvj7ZXluLzDA06bjhcXho4V1X7kaEqdPm lUpU3dQlJSik1J6t6HT7ChKMpQdV2dpXqN9rWd9L66P1OE0z9lL4za/pGj2/jzVvBS6t8OtA 0rRvhtd+GL3V00611HS7Upbaj4lfUPDcjXltFc6fpMmbaJhJAt6ZLJi8S1r+Kf2VPjJ49N74 q8Z+K/AsHxL8RS+IrHxLJpd3q9p4Sm0bUfCeh+DdDTTIp/B099bXNtp9pqUt/JctGrXk8EkD 3UYNtB0EejfHJvEs3wvf49asl/P8LJvG3/CTw+HrUGO9a/Xw8tn9hW9hlLwTM2oLdC9ETlzD 9nVlEteCfB/xx8cU8O/BjxP4s+NHiXxjL478c3Wn6jbajp1nZRw6Xofi7SNLltriOC7vbadL 23vrhV+z20cieWvmszMkkft4SWdRoYONHNsJz4enUjhW6MpNTx7gqjm3C8mpUqXs39i0rXuc 3ssHrz+0bs9qjVn96+/qu1kfVvhr9nPxz4Pfw9rnhnxXokXivQ/hdoHw1Ek1011psf8AZV5Y XV9eWizeE2SZbiKzljinumZilw4+wW8oje3+j/FujyeI/BXjLwbd3hiHi/wzq/hR50aCNYl1 bR7/AEfUJosW090GE12siTLY3ka43RwOrwwy/AP7QfjT4jJ8eNG8L6X4z+I2leF7z4Y6Trw0 3wFe2Ol7tVN/q1rJcyb/ABl4IlMksUObljeMrqIF8u4Zf3P2b4HtfE03wx0630+9vdQ8Sx+F 2fTtT8W3Mc+tR6jc2txLbXmr3D3XiuCecXjWskzf2vrOUjXLyjfEPnc4wuMoTy3MMxxlCrUx 3sqGGaormpt4qcVKd4pte1lN3vJtdHY7KNWjTpqklLkslrK7srbtu+isuvzsZ1t8GrOy8c/D Pxw2qzR6h8MdF8WaTaxPqFgtpOfEMPiCY/bLZ9NW6mdR4iP2OSOexiM+1JBcpDKrYw/Zy8J6 z4lute1LUNTvjq3i7XvFl/bWWp24d7/W7TVDJDbMmlR2ypbtqCt9kN6biOKF2d5thMnwlF+0 d4x8FfsxX/hjxj491fV/jV47n8fWvh7x9LHNM+j23h+30C9fUvNXT7gKbDStTnSwhiiiuXvb JwDb+bb3p+/P2W/Ed94r+APw01y/1m98Ta0dBQaz4kkElvdazq9pcXGmX94wuWtZ1uJnUs5k RI2gVgsrsVjbozCnxJw7hMTmtDHOrhZYqtl/sI1a6p1alWpUq15wpWhTox9tQqWVN7SbcU27 c8qeElNxlGVlbrbdL9X2fq7HNeBfgV4P+H/ijQLrxT46vtUbw/p0uk/DfRda1zwrp6wPFqPh +4trK0isvD/hnVNVMP8AZOi2Fx/aN5f3LHyvLeSS6kupNP41/Bn4b+N/Fmiarrnjk+EPEt3o SaLp8f8Awkfh7S7jV9LkvdQdLS00zX9I1WS5aBtW1GGGa2tknaS/Ec008kMBtvGNF8Gr8U9d +PXivxp4/wDFNvJ4T17xTa+EpLHVvFtrB8MB4f1jxdoseqWWn6D4h0W01GSaLwvpetTWtrZz sbnTDDJLd3Nw93d8J4Gs4fjJ4K/aD+IXxC8Wa9q/if4bah480nwHrkWteK9Kh8MaZ4a0bUdd 0rUNNsdA1HR7ZZGvbgzoZdJl1F1s7WC+le3htYLeMPhsdPEV8VHHulisFLBU8dL2S/5f8/Kq bvzSjH2VRVFNw54uKaauolatQp0vZqN4XjpondWtrf8AFbddD1nW/wBlv4AeHdftILfxpL4L 1zT7KDQYvDcvjfQLbVJ7K5vJfEe/+zPFen3+oyPfT3TLBNG8atsiWNY4Vnmb0Lwv4Z+Afwf1 jxdeX/jzRLHV/Hnhjw/o2swa9410aKfVNP0nQbezsVaBZNPht5ZNNu7fzZtKMAmF0s8BAaKQ fDOh3d78UZfi147+I+o6u3jjRPhZ4k1/StRXX9aV9IvPDkOixaLfQ22hXGm6SblCZII5EtpJ WF35d4HtzM6Yfwq0fxR8T/HPiqO/8HWnxTl0n4beDNRs/wDhKvG9zoQ0iCPwt4btzqtqPsGq peXWoItpLLDN5U42AzyvLJNj38RkOaxdSNTPMTB4NUliKlGrVhKadWCpRoP3ZcrqzjzqTprk lKyb0fMsThlr7Nvp03tHu/X0vrbp+jth8K/hX4f0T4da/Z6hNH4b+FKWniXw3rGo6yq2FrZ2 1n4feGWe+EcNreafb2Ph3TJ3uLuQBopZJWu5RMTFn6Nd/s8ywah49sfHPh6+sdH8TWfjfUNc i8URT6bDrGk6Zo/hiOS7ntpBZW2nppsen2j20jW1w2oyRTMRBcLJJn/tCedpHwv0DRo7NtE8 IXGr/DjRfF9rY3rRJYeG7nx74H0nVNKhew2ajfWWoaPPf6LeRWT2ryaezoUmS4aEfFn7T+i+ G/CPxfn8CfCzTovCuh6t8NfDOq+Ivh7Yy3dn4RIuPiBHaXF3f2pa40qebU5LDQobq4sdLurz yJ0jkSWGG8WvDyfL8TmWKwmBeY42jGpPGU1VjUlBwviajqNzjOUnzScpRdm0mtLqx0VHSSg4 QS5lF2cU90r6+t/lt3P0Y0DxF8Fvi94kbVvDOvaL4u1jw5ZXUE58Naxd3kljZa+1m0haCG6e 2mWWTQbWLzQsxiMMuxgHkevm/wAL+E/2KdD1XxNH4f8AEVhJfXVhdwa+f+Eo8Q3iQRQ3Mq33 2uUTPa2tv50ubl4GSeMIrW5jj3l/T/2aPh5qfhbQodSuPBXgrwTNrXh3wtcWF/4LfT7zUPEF sdPuJ2k1Qp4d8LmBjBd21663d1eSG4nnQFpUaWX4v+A/w88Q6l8Ofjb4iuPD/gq602Gz+JVv Bq1wtlJ4jEtnoWjX0LF5PDRuY40gu3ufl1qQi/kc7Hk/0ujB4Op7TOcC8dnFeOV1fZwcsXUl Gdq1WmpxvWdnL2d4tqLV7WV7ClONOMXyRvK9/dj05bffd6b/AJH25c/HH9mfxXNZ3dv41068 uvC9pqniTTrqI68NPsrfTtL1q31iWWaKAx3KRaJqOuPIjNP5Zl3q0cttGIINE8T/ALJ/xM0n VvB114k0zU9G1OWHxTqNidS8TaSbmSO/nu5Lyxnlex1C9gOr62s7rpUl1FAk8Pni3tDGr/m9 8OrCdfg1q11dah8NZ4X+HfxHVLXSfCvkeLp50fxE00LatJ8O9HQW82nx3EcxfxWV/s9xbCCV gtiPXLa7+GPibwZ+z34V+Gdvo+n/ABQg8L3svjW707QrrQbk6PZ+HdPGo2+paqNPs7bWWXXZ NCRhFcXjvcRG7hd4Fnmb0YcNSjUkp5hmtONPMJQ9tHFVPdWHpUcSpNc/vUVLX2L9xvnfKryZ g8VulCG2nuryv/w9u3z/AEF/Z88d/sj/AA9h8W6n8I7q+02EaMni3xTqS2XxCvNPk0TQla4u NTjvvFcU+nNbsl2s9tDp0wu7mBJZkgMETNXrvwx+MP7M3jjxBo3hjRdVubjxDrmpTyaVZX+n eMdAn1OWazFrqUuijXoNLivR/Zejrbag2JrezFoGg+zXksssv5UfA/XNOHwi8XabqvxR8B6h c6l+zpqumad4Q0T4YXWia7FrD+GbG3ifUPE1l4A0e1v4baScaZO154huo7q8uE1Bo5o4mvoo NLuPF3wP1j4ZfFb4o6xZapbxeBviVefCi78G+HtB0WS38UW8PjvQbq38QLo9roc8rzeIL7wo NLutVsPEljZxyzSJ/ZtumoeZ83mPA+DVfE4innGcUK+JafLQxEqLnG0Od0vZ1IunGajzVIxd p3lzX5rkrFzSsow111gns11/p9tEfsdrviT9mXxRo3jRNYvdP1TQvhR4q1Pwt4utrfUPFEV1 4f1fTtat7Ka08y0vbdbuW31jxXp9vfzpcXVpHe393aRSKbWKC2+mLbSfBPxH8PeEtZMH9u6K 9np2veH5zd3tkkFlPawS6VfwfZbmxmmhnsGhmAvjc5Xy2eNWZw34HaBofxd8OW8njTxxpNnZ /DT9pfR7zWpk0/xRb6pd6n418beLD8ZdK8Ra5o0WnWH2W8m8JeELXS717O72299b28IWWF5W b9R/2LP2m/hP8W/BHgf4beEPE11qPjXwF8LvCsHizS5/Dmr6bBClpZ6PoriLUrrT7exvTBdC O2UwSuWSUyq2wO5/MuL+HcTw7llXPcHneZYl0cVhcPRo18TVqVYRrQr/AFmEry5ZxhUhRVFc 7UEpqK1s+zD1ITp+/CPNdp2jFJL3dl960W3ex1mkfth/AHULjTFt18bnRrLXbHQR42/4QLxl H4F0jWtautNWyt73xHNZi2ia5vNY0my3XAmijv7uK3bywWrr7P8Aaj8AeLtR1XQvDHg74v8A jbTrDXdQ8P3viHwx8LvFmp+FJNW0iMXt1bQ+Ire2is5nWNYJ0NvLtInggkCXBmgj/I/w78CP jNoljr/jnUPG0F5+zx8N/jF4L1z4qfAq0WFNV1DRtOt/hJrf9oaP4ueW2v78repL4gn09tX0 qVf7Il0uFLyPUI4Zn+APjl4J+H3xB8d3A/aF+J/w18NX3xL8S+KPDPwm0bwHf+IdNj8MeKfD 1je6HNc63F42trb+1YYL9XulubW5uFGnLG1/IZY1T0sfwpwxUw+JzLLcVm8JRhgqlClUzGqq tPF4mvOMq3Opyl7KlH2cpQUldxkmmnrP1qaqezhGHLZ2Tgn2t079H66H606n+1j8N9J1fxP4 f03wz8WPEmj+A9V1HRvGfirwt8NfEet+DfD11p91e22s/bdcjhWW4TQ7vTNfstWudNgvbXTr vQ9Xtbp1njsUueysP2kvhpruifGTxRp+p6tcaf8AAafxLa/EQrpD+dAfCNtqd9qr6RaqGn1K 3SHS9QktJkEQuNgDMFDbPzE+KHxH8Q/CfwZ4q+Dyat4g8AeNvEXxA+IHiLw94ntfBvgHxlYf HTT/AB/4h8c+MtB0LXBfeIXudGNzafEPwxb6s3jWGW0iub6/t3N5ZWtxLJvvL4h/Zw8H/Hzw B8WvCuo6z4u/ao8B3tx4KfwtJ4Sm0/VPGvi7T/G3h/W9N16WTWtGi0qSPU/EnhyS6vzbvpVx bahJ9kbFjdRLjT4SoZxhsTQwuMzKDxcsI8PCtmOIqRlUwU6U8XVtepaLjQrrlSfNdp2u2ONa UZcyjC6vZ8q6rrp5/Pufp34L+MHgbx94k13wh4duby41Tw/bM98kto8VgIpLXRrvzLe9WWQX ChfENishRyEkNzFgPbkVyKftMfCiH41ar8AZtU1C18daLFo/2mWfTZV8OS6jrUPh2XRNCtta WR0k1vUovE1sbCxeGMzJp+sl5d2nsX+HPAviLxd+y98cNcT4o+C/E3iQa/4AEwuvBl74GeCT UNQ1jQ7aye6ttQ8V+HTB5Nj4bmguJraGchPszJHcSySiPzHXf2W/2l/iV4k8Y/tSeDvE2m+F Z9a+JVt8WPC/hXU7jSB4x1Lw14AvvFC+EvC03iPTzqOm6dPeaRa6DbCC61NtJtpHsBqT3jaS J4PPr8F5VQxucyrYuv8AVKOV8+Ax/t6jk8znWoe0oybjZ00nUUIJ+4rRUUkzo9tJpO0bta+6 vLVb6vq/w7/fkX7Xtrc+Pf8AhX1x8DPj3putwQJqOoS6v4e+HtvYWeiLNrm/WvOtviXLcS6f FF4a124xbWl1fNHYkLZySSwRS49h+2v4C8YxeFNN+F3hL4gePfG/jbw/qvjDSvBum6Ho0WoW HhrRNZ8T+G77WNc1LV/Fmg+FLG1XVvClxbRW0fiifVLmXU9Hit7OSa+8mDsNX8CeJNW/aB8O ePrfwuyeD/EPwtsdJ1LWG1XSUOnajJbfE+a40+60ldQF9fSFPFulQNdW1tJbFrtmW52W87Qf F3wL/Z2+Mn7Puu+AvjTqXgg+I38L+BvEnws8U/DrQvFPhmPXLfR9a8W+KfGdp4k0fUNZ1uy8 KXVump6noVrc2K6rpesD7TfzLJLbQSWt7pPIOHMTgPayWKpZ7SwOEq0cJjcZUrU8Tj8TWxcJ 8jkqk6NKp9Xw0IRhG9KXPOC5psh1ZpJrlUeto6NKz6K2n6+Z9P6j+3V8F/Db+F9J8cf8JR4R 8T6lreqeGPF2i6j4ckupvh1rulaXruo+V4si0LUdcdLHW/8AhHruLQNR8OzeKLCdrvTRf3Vi uoW8xpfFP9tbwV4EttetNK0nVr/XNO8S6R4M0m9v08OWvhKfUPEEfjWLQdavvEOo+NNC0qz8 HS3fg65luNc1DU9OB0xpL6ASW1rqVxpniGkfsoeKviR8ern47/Eb4c6Vp/w+8beNoNY1D4Z6 r4i0rW9X0nw3B8M/iD4fstZ1n+ydQfw8L/VfFLeC9aa08Papq97btrsyXV00dhq8kvI+EP2Q v2gvDWp/Fuy8ZeFvA3xr8G6hrXgqbwvYeL/EOkR3Ou+GfClx8V4pbTTH1jRPEl14f8USaV4m 06G3nvr/AEtY5PEcp/4SvzNPvJolR4X4PqVcNOriJVcX/Z1HEYrBVMVUdD28sVXw1WKbpuTj QdNuMXDlUaUZX5rxQq1XSyS95J2j6W00etnv0Z+ifwX+Jup/EbwrqOteIdBTQ9X0TU7ixaWw udI1Tw5fwNawXaXek6v4e8T+L9N1NLSKcw6jHbas11aX0MtrLZpJ5aS+U+N/2j/FkMV7p/w9 8Hv4o8Ua9431LwJ8NNPvbO0s7bxBf+Cn8UH4kXt1cah4u8O239l6KvgvVo7G4W9s7rzrjSIL mzknu5Y4n/s1fDjxn4Wvfiol94J8QfCf4e63/wAI1F4H+G/iL4jj4nXelatb6Pq8Hi/WIdbX xL4nbTLXWbi60C5FlDqgDy2U8n2OCRpJLjxOz0Dx1qfizxh4K8Cx6befFD9nj4ueJvHmnWmq X8VhZ6j4Z+Otx8UNVmtrHW7nTtVtre5TSfGuh6jdR6hbXbA2E1hbGzkOBz0OHsn/ALexGElV wMMrU6DhTpYivS56c8LRqVKs7YdRnWjVlOnSqtc8KL9krRvfeDenN879Nra/JXt7unkTfFv9 qn9ob4MfDXQr7xx8MfCPhr4h618TvDfgRNTv4xP8J7iw8QaB4gmOtW+uWnxKnubBLPXPD1zc Xa6zqFnfaf4antLy90QSTmeLkfEv7YHx58N+F/Alxfal+ypfa94+8Y694esPFfh/xLquufCH RrLQZPApEnifxNYeO7iTS71ZPFF+H8q6uk80aakttEomW47/AONnwi/aD/ah0yLTfF/gLw/4 B8L+HfF3hLWdG8Ban4v8PeKJ9S1HR7fxxBq/iyXWdC0y0W3t9Q07xDo2jR6Nd6jdlH0+6uv7 PUTGeb1T4jfsg/D3xHZ/Dnw94N8FeCNF8HeEvHdp4j1fw1Lpxisr+xvvEXgS98Rx21ukU0Uk t7pHhe4hmS4eFZ3MESkZL0qOF4RwtDK1jMDRnicTXxEav1WhQeF9jGph1TjCFRUuVxU5qVoJ XcXrYbnLm92ySUbrVvVLfXrpq7b6HGfD/wDaq8c654B8ZaprGkeFPGfib4feJzY67qPwbsdS 8SfD7xDok8HheG3Xwbrtz4juINS1my1Lxhpn9s2V7qenXVpFpeu4ssWcIu/ujQdX03xDo2k6 9ptwtzpWt6ZYazpV0oaNbmw1W1ivrWZY5QsqRzwTxSqsqLIqlRwdwPxTF8OdP/Zh1D4t619k 8M6R+zRqyW3iaPw3plg1xqeleOdf1bwHo1zF9nbS73V20ye90661KG3tdb/sSxW+toLbRrX7 IrQ+3/s/R+KtO+FXw+07xLb2EFnY/Dj4dx6TeQ6o+p3V47eFbJ9Vgu4Tpdu9oNNuPKs7dze6 gl5EpmiNrGqxNyZxhcpjB4rKaNSp7KfIsI6dCUJwm4Q5ZU1LkkqSm6sVtCcYzWsEV8Ub6Xbj Z632i77aPTVbW+Z7mIXX5cx7AQwVWJ+6Qwzn5id4zgHBGB6ipP3hR1UKZA4aLcH28hd/mbcH IzKE2/w+Xuy241mT63ptsG+0XaoApYkW9wQFAyTmOAtx7An0BrCuPHvhW1YibWVTB7WWqsRk kAZWwPp2NfLUcNiKMpVaWDxk1O941OSoofC7QjKpyw20UbJIOSWmi7rSWuyd9PJX+Z2bphVK qu8yKXZi3zRgN23YDgbcfKFzuz2poT5GEQw55JYNzIcZJyNoBx8wAGBnaAcV5tc/GH4d2ZaO 68SeW6feB0jXpCCy7xzHpbg/KQepx04PFYcv7Qnwit1Yy+MQioNzZ8P+KD3x1j0N26jsDn0x mul0cVVnGtLLq8f3aipwhSjJPlV6iaqJqrJ6yqL35S95tyVxKE9bN7p7Sfby7Wt2+R7K8ZGG YBm3Kd3PybSGAQDAI3KG+cNyzDO3aFazPg+XkMc5LLwc8noD/F6dq8AuP2qfgPbBjcePQgXG f+KZ8av1GR9zw23bPTP61jyftjfs5RErJ8RkUqSCB4R8ek5HUHb4Ux29SPeonhMRNTksNXw1 OMIJSioU3KV0nUvGfN7ZxspVdJyilFuysDhUdvi3vfW62tuvS+2zv1PpYL5QQKNjfKCCeGC7 cn5iTkAnGMc4yKT94SwLAx7SQTt3bz8pB2gLtKFh65Ocjgj5cf8AbV/ZqP3fiTuKZOP+EM8e MTnjAMnhZcZ2nocHuRVeT9tb9nfAEPjK+neQhE8nwp4oTLudq4WfR4EyGwMOVUnGWC5IylhM ROKnFYhybUUou3NLlUFGVpaqTs5L7U7Sd2y1RqO8rNu60u79O6tZW83fY+rVT5QrH5T94Ljk AkpgkE5HGcHk56imqSjZ+QNsIwGGC7EbuGOduUXb0PXIr5ci/bB+DUqj7JqOv6gx6LF4fuLf jkls3L26gYB4znjp0zLJ+1b8OjInkaZ4vnLKrBIdK0bBLMcHfda7bkEnAxjAyCSDuAP7Fz5e yhTy/Ec9Kyg3ZySSimk+dtRsvhul5W0L9lKV/i13/DW3d2V3byPpxkAUqpGxQxAYgtjG4n5e PvZP0xXmXxh0GTxR8Ote0SCIzS3Y0hhEJPLaQW2taZckowyw2CLcTgDHB5IrjbD9obRdVeKK x8CePbj7RKtujqPA8QLyNsAKz+N4eAW5JwMDgnpWxB8XTqE1xY2nwn8f6lNamSKaKS6+GcMT iOYLkG4+IgQqGi3AbScqvHcaQybOMPi8PiquGjRlDEUMRKFbnTvQqU6kOWMYyXs3Km1yqVna S0uONOdOaqcsm1bZrbR9Wlq77vdvRXu+68BX/wDaPgfwZqZO4aj4W8Pahuwqjbd6RZXG8hSU AbzCQI2deDtJABPYKRIQ6kFSQR68HB4+oI/CvLPhBpXivSfh74a0fxZYNpWpaTpejaZHp8t5 p19Na2NhommWotJ59KlurEzW08c8Egt72/iLozw3tzCySt6io8sBQNoB6DB+Xr06Dkt7+p6Y 8HGc6zDFVKlOlGDmqjcXJ/vJKmtE4xTi+aStfRO/QJtOXe7vdd9HutPy+/UcTh8/56V0PgvV 3vdX8U6W1tLEmjnRfLnZEEVwmoW93cjynE8ryGJUVJt8UIWQ4TzF+Yc4xySf89K67wfbRx3G s3axqj3n9nLI4xuk+yR3UCliCc7RkLkDAOK/fPov4zk8UcDhG1bEUs0qRVkm5QyfM52vfZRU tO/lt4+cxTwVWT3ioWd+rrUlbz91yfyv0O5ooor/AEyPjT+NH4K+GfG2o2vxq17UfjH8TdRT wB4i8U6DpNjP4i1eS0uE0mOW8icifVLoRJKLGKEpbCMCJztXAWv2w+DWl3ekfDPQ7K+u5L2W 2bV/NmleWSXEutahOqs02GG1JV2hgPlII4INfAHwj+BXjfw74F+IOga2limueN/GesapavFf JJDNZaxo62Ubq6WqxQu15I52mJwiFTyvy1+oenWY0zSotP8AOWZITMu9WDsVkmNxhmEcQ3Bp mHCKAgTOTuY/yD9I7MqFXA5BlkHL27r1pzi4WjzKGHSfNfvOPSyVz9f4GoVab9pVStZpWkn9 p9kno/L8tW3N1ErRrGuH8mMdVGcA5+7z0Gf85rxP4660mnfC7x5OkeGm8J6+iKXCFpY/C2q7 ACCCxZgcKMsc8c5r2a4+zeajFipCqpO9FAAVucyEKCTgckA9AM4r5o/aO8PeLvFfgCXR/Bem DUNYmN4lzY3MltEXt5dC1G0QW7vcRRmSSeeBATNgGVTlVyR/NWTU0p5TyNJwUnXTaT3nFcq+ 07tbaWV2fcY+pOOHlCK3rOeiXVRjpo7bf5dzodFsB4G+FUsMYDroOleJr4mRfJEq+ZfX7jCi IICrtGScA4yTjJr8dNf0LxV4/wDiTaP4Q1FNJ8Rf2n8SPHemz2w1F3WK4+I/xK8M3FnK+mSr fBJLHVLi6Elu21v3SOzQu+77v8SfHX4mWElz4K1/wp4Q0/VdUsTph0PVNd8NafqkqaoJlRoL F/iRb6lIlxFeL5csMEoyjGMfI+eH8M3XxEtdZkl8G/DXwlN4msLK4s7pU8U6ff3tvY392mt3 Xm6YvxOnMMc1xqkFxHcXFjGqQXcEQlR5IYz+1cN4LMsorYrN44XCy5nKWGlWxUaNNwck17Wr KlONGPLa8pRkk9LbW+JzLGOv7GhCTg1KKk2tlazatvbR2ut+lyp+zH45h1Pw38WPjVd2o0uL XtQvfE97pl46xzWDaTrXj2e408TyyRqWiNpPFmaVDGIkDqm1wnxf4c8VeP8Awv8AEJfGd34T 1/TNU+J1t48kS41ddajt7m8u/DOuTaHbWdxJYWFxNFBrPi9vsqi41CXzb2E2aLdTE3f2boeo /FW/8P3+m6B8OPAWp+Hrv+0oNYisPEMuot591dalHq/2i4s/iRPLbiK+m1mCQwTRLDIWjQZh j8rlLT4p+PvH91p+k6LpHwr1+60ybGn2Nnr8r3NldRiO4thafZfHCLeRQPpsU0v2p70m3tGY +YJH873sJCnha+LxeF/syc8f78qNTOsPTjSg3OUsJNypycYJVPZKo4xuoXUdLLhqUl7N/wC0 VOay+z2s/wCbXr3tZs838Fah8C7L9m/wnZarpSa5r99repiaPS7TwfL8Rzerr2vzRR3S3Jub 1Y49Es0m3tHLN/YxtUWJLRhPHe8MeKvgvonwz8QDxtY6PqvjvVdW8c2XiDSIX8KS+LL+9n8R +Mjp1k1pq6trFxefYngsdEW9jmmWKa3hgt3imRB2dh4C+L+ieKZvGOk/DT4dWOuzwGyXV28Q a/LHOGtoYZIltrzx1PY+Z9lt/LytouEgZx++LyPA3hv45L4qvvFNt4Q+FaeIr2R3uboeINVk eQpNauS1ofF8llHAsttbfa3SGMxyLEkbokkqveKg5zf1arRjR5/bRUcfST5nZckZ8jtBOKd7 Pni5R0+IwXslSjF1pOaVpNrd31+12+7oebeBNe8EeF9L+P6fESK0XxS2ra+PDum6idIbVdS0 W5TW7LTbbRoNca11GSaK9a+zHYxXFoHkiEC+cZlbwXwz4E+KOl+K7+00a5sLTXvBfwJ8VatI NY8P+IryW8EHirVNUfSUmtdU0q8sr26s9Tim0/dbz7JxBMbeeKdWT6h1fxb8TZvF+maVrGsf BSHxP9p8mCzl1DxKghu5buWFbOa4t7ltNhlW+hmg8q5uRKZMJlhJDu1T8RvjFpWmax4mj8Wf BRbKwuf7I1G90mfXNahjvfsdjqv2aRbKLU9yQWEtrqVxPbAxQRJtnnUrcQHso4ivCnF0p0Ku Ij+9lT9vCrByi0oqlFa0IpNKUv3ilN87S5uVc0qUZOzrz5Vq+WN29LdJJpNXvsr+unlfwr8Z +F/BGtfDTxP4va7tpJPC3xRk14zPp9s1v4u1DxL4Y/tKFF1S5tmgWe/udck06O9un1N9Nic3 BlmS8J5Pwn4Q8efEDU/EWj+GNIsNL0nxn8WfEfxQe08S2Ws22mnw0lxplrb2066fZ3NtO+pW 3iwxS3BtZbB7fTJwklxH+7X2ofEj4kao9ix8f/CIyazEt2tzFD4ie0y9st8BeyxaLMml5QlY EvvsbzTL9nj82YMlb3jLx98f/hvdaTH4r8b+EtNfWGXTNMudK8I+IdZtrxBIFi0zzbTwLqKx yyndJbQusWpzxh2VnCELpKvicU/rFeCo4qOkaUpKvQaVlf4aSWmqWuvUzjQot29vVVuvs3fp /e+fz6218M0HwF4z13S/CnwJ16C6sNS8NeMNY1Wx8Q2mnaqdIS8bwL4n8RaPcxR3ojuIprbV NchiMkKxSrNbM1rMlwUaue0PRfGnhPxZ4+8VeKvCmqeILXwH4n8H+HNRSDRtVuLrxJaWHhXx n4HsNbt49St3jnVZrXS7syz3TxQQX+yGRnlt1f6+8Q618e/BuweK/i/4E0m6x9vjhtdNguLl WEVwsLx2DfD+5vpDcR2ktvF/o0kM07xwQn7VJGtUofHfjO50u38Ra9+0HoVppWsXkOmMYNI0 SLUZb62t9TItRpk/wte+jlV9GuZUjFqJhZ2txNcqoVmWKeKqVqU6rq0qyq+xjVi8OqSp1I1o yxGJi3VlzOrh0qHsuVWS51UblyrSpTjTfvVYvbVST7ef3/PueN/tDfEiX4xeCGGg+APGenab pnjTw8154l0/S2uvFWo2kukeN/taollEbcRWlvJbX8fm6vPEuo34EoRHjup/pb9mDUtOuofF cGn3vxh1DfqdiPtXxYhghltWfS5QY9J8jUNQ2WzKpeU+YhN48ZKEHJ43WvH+v6dLLpviP48a v5Fjqn9nGTTvB+iSadp04a4gkS+1Nvg/9ntkVLWQk3V2JfIt5LgKY455RND4v0i50zxBr95+ 0D4rhsdFt9Ovo55PD/gmw/tOxup7izEul22o/CSC61EC/sL7Tt9vEI4722lilYKhevLxGGqy yyth4xp0qCrqrHlh7Zzd3NSlZx5dW1y66W7CoSgq8ZOcnBJr3Upa6WvZ7uz6nmHiv4G+KvEP xL+M15cW2pvoaajcP4bljtNRuEub/VdU8K+Ibq6jL6Y1myIuta/ZBrCR5sQHzJXH20HsfBfw r8Y2+n/s+nUtF1ldU0z7drviu4/sjVAsGp6z4m8Na9NCZJ7NbhPszT38W7UjFcH7OXbBExXo YT4U1/WLHwyfjL8RNS13V/DGnfEGHT4NI+H8Zfw1q8du1jetKvwyt4o3LXtvut/NEqBwrhmD Cq3izwx8MdD0vwxquoeK/iv4mtfHjG40KHQYfh/Pd3kUqW8klxKj+GtJitTnUrWAiWWONLi4 ClAiM6PAYyVbBxy2pOdGPKqarQwE686fKormhRVSDqNW+D2i0bd1azWIoRnKVSKVSm9JQqP2 fMm1pKXvcttNV00Ol1H4XeI9a+Hv7R2mDSb6K68YX/g+z0eynsb5D9hg0bw1Z6lciH+zpJJg MXzZtYZYR9mxcMNswj5L4ZfszSeB/iT8L/EOnQ3tvHp/w+gtdfuby3a0hg1a50bWYL2CKaDR IVjjNzNaCFL2eO5KPiVDIYw2Fonh/wDZO8SabBruofEXxZp4uFkiuYPEF9pWlana26XNxZwx y2MHh5fJe9kWVbRZFeW5E0DRYMiVoav8Jv2Qbfw/c65L4ovNb0cXcFoyx+LIluZby4EF3BbS xQx6a8dzHZSw30katCI4eJQZRJDVwrYnBRlSpZjmNSNkl/whVaV9Er/7zUtp6+pjCFGCssFh +2uKXld/w+r6/wDDu147/Zq1/wCJvi/4t+L9d+IV14T/ALVtb3TfCmkWkt68U0Vrp8mjIly1 49nmKddH0y42abFOpW8kAQhbfzF+HP7NOj6zrvjDxl8YtR0iK/l1jTJrDTrG9tZLG+tDqWrX t0b+38U+H1muw1zqO2WGGcRSxKY5J0kfzQ+D4U/sSahLb2Md7JJefaILNY5vEviaNry/Zjbp b2EiTpbairzK8aNpz3G4GD95ulUyWNF+En7EeveIdN8K6Fpw1bVNSYSQw/298RjaztIk7iJt Rg1GKytHVLGeR0vLq1ZFMRLYkUVUM/z6ng3gfrGMVKnV/wBn5svqQk4VKiqVOeTd4vnlK173 VhqjGVWdSUaVKm+W0IVVNRcUo72Td3722l2rPc6zwx8Fvh0/xB8Q/EjxprXgK6vbnUbK+0e0 M+hSPZtpmg+GtNsJmbVrN5YBHqOl3dwZrWYmNZt0JWcygV/AF14r+GXjj4iPpOrfAm88KeMP F0d7HqV9451Kz12x0ebWNe1ARfZbbw6dNR7O11qWFVXU5LUGxteYo3YReE+HND/ZxvPGEts/ gXRrTwholy0V2ZfFHjVvFAiOi22oM0OmW/j26url5b/U47eyii0xp7h3hijhlDq8tm41r9my 112++zfCvUptMtdbh07R2kf4ipq2oxxTTxBvsUvje3lCu1ogRp7KzkcS2rKmJmNc8MBmuYVK tWvhq2Zxq1VGph7TUo4SS5p1VGFOpJSjUdOKjype/L39EnnUdGnK7qJQ0inGzbbs0rKXk9em x2HhrwZffDO+8F+KPBnxe+C194g8O+G00DW9I8ReI5otFvpRotxolreLNpV6l6V0+bWNX1BY 7u0LM9rZpHJavLczRZUvwp8JeLNWsr74tftA+FvEuj2vhXVNLFrpuvaZPef2ncz61FHfxXHi XX9YtUtrfSNWv7cx/ZftDXJEazxWssynudB8RfsnwWNnqeoeEddkEBkmbVtItfiQ+h6bfraW zvpV7e3usLFFqE1w1taWdtI0gnnvLOFZWecMPRbyf4Z6n8NtT8TeAPA2pad4ii8UaN4P0yz8 XDxPYxx+KtU1HQWsv7UtpPELNFbLY6vZX6zLMkIjSOSaOWPzopnLHZrha69plOa1KuHtTw+K gsRTmsN7rdD2X1Spom5Pmc2/e20MfZUa12qjd1qu+292t/zT7nzRpHg/SvAcs83hf4wfB3X9 EtbPWfD2k6Z40trbX7/R9A1DxBpmraVNbW+neNdKtLW9htdDsdPvLi2SCynguG+zWsMbwxJ1 PhWDSfhZrWl6h4E+OHgKQR+AvC/hHV/+EisbbU5Jk8O3d9ONQ0iTR/iVoP2WC4+1NujuvtYj ZLdg5ycbum6x471PVtA0S08OeBv7UvNV8UaZ4mEk/iVLa3i8K/2pY3OoQz/2+0cWnrrdlp9i 92C6yXWq6bBHHGLwCPLsf2hZ7PXjqfi/R9KtPAOnaumiAQ6frUWrhJrz7RDdRRvrfmS2EWja dff6SS0jXLIuyZs+V6M6eLrrmippyoKlKMszhCahKpKu04vD3UlOtNNNJp39FMaFOL1UtO0X 5fhp+fcf4X8S6b4M8V3uq6J8X/CtzoGq61Y6/d6ND4at7y5KQaXomhXtpa3tp8XbCytZ5Y9D F5FJLpV6IHm8yWOdW2x+gfHL4o/DD4tfDZvAd74m1fSlnv8AS7+TU7CHw9dM02my+awNlN4r URpKzsu5rqZlJ5JLGqOh/HjXPFn7OXjz4rraeGo/GWha9HpGlwW/nTWQjlu/CunyWklnba9q Ec93NZa7fTxSC78kNLbq0qTp9mritM/a58QPq2lRapbWFz4ZtPAVkoR9Pt4PP8YJb+CYNdtI JI9ctLuW10rVj4ntWj8xZIWt7RJnmCuz+RHKpZpWpVXlVfMamXRpYWM45nJeyp04vkinDBzT 5vi1110urFzrRoxUIKdpq79x7qyv1d7Lr0T72PTJfjH8Nm8e3njWG58V3V5P4Il8EmC3tdBu 7do4dZk1b+1xcJ4hSVLu4lutn2Y+aqpGr/aZWb5fnaSL4fWnw78C+BtI1b422V14L1fXNY0j xLp+gaI+qG61TXdJ1uYPDa+JbKSNbY6YkEL2t/BII5ppWb5ArfYPw9/aJXx/qnhrSNP8Pamd Q1jRNJ8QmGbSvscNl4aurjT7WXWXeTXGZbS2n1KBEfddOq+aZopSsZbyLSP2wPEHhnRtUsfE diup61f3cbeHJdM0i0vYGgSO0W6XXYNP1uC4swkzym0K2lu8sQaUvNGm9V9XzCnekuHcRR9n GlapLMqlSNL2d26kovL488YX5nFyipJNOUd1jH2M37ynzX920G9b6X12va/3WseEX62d7rtn 4oh8ZftRt4psfDsWgya3pfhmL7Tdaal/NcJBLdJ48k1HKi4hV4mv3twII8QgBdv1f4G/aRj8 F+GNK0e98CfHXxVeaZbrbR61qmgqNT1K7ilnk+0zNNqt9KVldlVNtzNJ5SwfOTgDqx8Z9X1b wr8I/Gj3lv4P03xP4n1XTvEF5qFna2drB9j8PfEUI4fUn1ZLOC81PQ9LW2ZpmuJDLHGY4ftD ovjo/a28UeHJbCDVY9M1bSpb/wAWz2uqxaUt7NqFpbeI1bSLbRP7D1W3hvN+k3YhtriayaG9 NtaTC9nMz3N5y4rL8ZnVOhh54SkpYaNOnBSr2jBUK/1iEk/ZxTbqtpp7J6voW3Tp/EprbaD8 u17/APD9TP0PxF4Asvh1q/w+f9nT4y+IrLVF1Xyta1P4b6LqmsaQdYhhttQfTmNp5NkUt7WG aB13efcRt54RIEZn+AfHer+APFuh6j4c+D/x0i8HaH4Bk8G2PhXVPCN1Z6fNcHXJ9UfxIbOx ji0uK9lMj2n7m1aTZvzdOSUrmNX/AGx/ij4s0G40yO38NaJd6raa4j6nfaWtnaSWdjYx3MVp p1xc63fWj6ukkV+q200EnmT6lpELK4uo1T1i/wD2mvEXw+0zwPo5tdJe9vvg54M8YC4nsjLc 6rq2q3FvYagloqaza2kqvGl9fi2trSIRw2088cghhMNceNyzNv3lGrTwSbqqVajPMKSjWVvc m5OmvYy5JK8Up7tu17CjKlL94lU5Xom4SvdWT082pedvLbyPxjoGmeOvFWpeJbn4HftDaTJq 15bal4g06ws7e20jVltreG2WO5hk8BztPFcW4uGdb1rsbb66Ad0kfzOl8X6F/wAJ94j0/Wrn 9nL4kaF5NlDbX+l6ZB/Zvh7xHDb3V5f58QQyfC+8/tJp2uriFjMsiOkoTbmV2PG+Lf2gfj7c 2nhWG5l8N6NY3/i3Q724j0/Q2kRtC1NLu7SxuX1AapPbzLpt5AswjeK6inS4X7UXjye70DVJ tb/Z/v5fG5uLXw/c/Emyh8TzXNjPam30GfUPhgbtpBptu9zbadBFNest3GgvFT7UzzyfZ0MP sVsBjMPh1jMRmeFjT58PClCjKlWnRm2lBtRrRdVU3bW0E0ns3pPNSdS3LUl/25Ly3+W6S+8s +J/Ct5478ar47u/2dfFcd0+m2sE9gdRlTRZk0ub91cXcEvwbvJAheCGHe9zKDcxwhfLJRI4f E3w6vfFmpxa1ffARNGuxpuj6LEr+KpdOguLTSdG0zQ9Ot1ab4EXMskz2GjWjfZ1YxKTKIEEK xInG3fxc+JvwqMnhv4S6VqFx8K7PVbfVPDWv+IvCtzcy6lNc2MD63pMF68Ni12YtVXWrpI1s kuYlsrjN6bO2aIY+q/GT43eO7fQNRtnl8XX+m+IG8TzaNoXgu7eHRNW8O309no2iXTxaNaOT qEc11bXMLapeySXOnTiLUrLy2afsjl+a4mGH9hm+EpYXBx/2SVWrQjUtOPLUVSEqsXrTnKKb k2m72drilVox3o1bf9ept9PLffr0ufW1vdfFCfwqngOf4P8Agu60ObSV8NzaV4g8b+IZoprS Oxh09C+mv8HGs7y4t40jlkZraGITQQMLaJY1Uc94S+FnjXwPpWoaZZ/Br4Q2MOoahafb9R8R +KdWtr6e6e80S4srU3MXwStFmsvtOnaS8NtMHkN1A0kTeZHbeX8nXHxU/ao1nU/C3jYy6/da p4X0zxXY6NdWvw7tDDFPdeHBCtrdQf8ACJ+ROLR7yKWOQZ3mdt812ipHH3Hh74kftIeMNX8E 6R40PiCfwhH4q8JavZPY/DtreHWdUsvGditxHqd7b+ExcWNtDpR1kvIkuiW6vptoXuxJK/27 yMZw9UwDpVf+EpUZ888TUo4ylWqwTbleEFK83JWla8febW6uFCpCcrONT4lZSg1peOjvt/n9 59y6Zqn7RcUNtpNt4I+DdtYadHFFZOnjDx1LbxWiwuIY7Xy/h3aQhdnkr+6SKLaNqpgLVTS/ DXx+0m1u9O0zwf8As4Wlnqk8s81rC3jR7drieNYJd8Fv4bsonUxGKPLo7sgKMdu0D37SXupt P02K7hXebOB0s5leKWFWgVwCsbI6EIyZW4kLgEAjzA2N+e5kuZoJdgdhglpAU2kurFgEZVzn nBBXjhcZr8xxea1sLi8THDYLATSnUXPWgqjqqEv3MmtPZ80buau7XS1tc9ylhadSHNJduXTf RXT1VradNdduvxfpH7Pvj/TZTc6b8Ov2TNOuTFf2xvF8I60t49vd6fPb3sZMGi2cjo9lNPGF 88RsFCTI0O8V3fg/4RfGDwrczXugeH/2ZNMuL62eG8e0+H/iiVr2B7iO5RZBZajpD3ASVI5v 3ssiKw8wJuVWP1BaC8aYklRGS6AoFICyweS4yQTkiSTk5wSCDwBXSQwQpCxCq07RxIDI0gHy FQeEZR91ecA84xjmsMVxTi4OapYTAW9pKMZfVlGTpKEXGp8TcZubcWtWklK7vZN5fQvd+XfX Zd/vfmfMelfAz4taRPc3umWf7L2h3/2ASGfS/hF4lt7q7be0u6aW38Y2MzsJokcMWkPmHdkP g16dN8Kf2gtTSzsrrxh8E0s0JMcMPwv8bTC1JuPOYR+Z8TkiBeWJJvlhiO5iTuYCQ+6afL5R hCNCrJbR2u0+aQ6fuwC+cnflcZQovLfLnBX0HS1aCKIbIyd7HdmQn7zdPmA4z3FfK5lxTmko 8qrUufTlquhG9FWjeMY396+zbcbb2aH/AGfhuz/Hy/vev9bfOkfwS/aBure2S5+Mfw0itLaF IINIi+GfjUW1vHECIpUik+MflIyh2T5LWNQGIUjJU6dp+z78dtPhaW2+OnhPTFnH/MJ+HXjG BsZd8fu/jHbghSxZBk4Y596+srG5UxhZHAHl4wQAAAykAEDPBHcn3rWikMsi7VRYkK7TlskA qDuyzDjB6Yr5JcX5vSnWp4hYPEYaXK3TqYeLcqsX/FbT0ck2+WzSel3uT9ShB3ivc7ve+jfy 2XS/5/IsX7Pvx1eN4pv2kobeNuGGn+DPGCNt5JPz/GRVDE9CVIwTXz38YJvGPwb1nRfCd58b /iN4u8U6xbQ6zHpPgfwdqh1mTSbga7bm5mMvxpl1F9MgutEmM0a6TLbC6NrIb1ZFaNP1QgEn zb8ZPAHTjBz/AD4z3r4M/a2+FPxC+JHijShonw8ufFPhuz8M6YLLXvDOs6HZeL9G8Wwax4gN wj2PiXxVpmiz6AfDt/c2ss02halcfb9XiEEyvAJdP9XhfiLMMwzOc8fLAUL4avKnRap4enOd JRlQhLESklBSqXTvCWjvZpNHNVw8Ityive0T8+j3b6enV7I+Zk8eeM7zxbH4T0L4oftU+LZ7 NPD0mp6x4Y8OarqGl2EPi2x03VrVr+Cz+K989oNLju3sdSiuLtV+22F9HHMixnZqfBxviD8Y fEjaJpfxN/a10vR01bU9Pl8XeII9b0nSbZF064uopI7q38X63aiOSK2j2q17EN19bRruWZZT U8CfsqfFUfE7xB8RPi/8HtS8T+O9X1Pwfqlv4u0XxZ4TtvDq+INIiQSas2lWXjrQbtdOtJYL A3Uf9gyI4tpvJs5BNELn2T9j/wDZnn+EmraXqPiP4M3PhXxFaXRa58Uf8JjZa1H5/wDwjtxp 15cmz074i65aIrXE90I430GI5vty26pCgtP0DOsXlscNP6jmeHo4qFOhLCONei4051ZUVj6V 3VtySpzxHLO3vXsorS2Ps3o7f5rRforfh118S8U+IdY8PeKdU03UPit+1tN4N0DxJ4e8Max4 +0zVrqHQ7fXtd0vQNX062jnm8StpTCN/EmjW91Hda1ZXhkafyLZytr9qy9P1PxL4gXxT4gtP Gv7Ydx4U8LReINWfxM/jW/tdN1XSPCl7eWepXoSK01TTTbSLYSzup157VY1YT3sYLNF3j/sL a3/ZQ+JkmgaZd/H1fF15fw6f/wAJVPFoMWgXPgK78A22opZtNa2p1WwFyl7ZpNfPYPeW9tJq Nte2hu9Pn9S/Zr/Zl1nwTqfiU+M/hLonh2+8WaH4p03xP42tPF+o6jqGvp4h8TJqGpRjT7bx 5q+k2Fzdwzvewy2HhPSrW3ktBDvhVxbXWeMxPDtTKaEcLmODrYm2FdXBV8VQpUlNUbV6/wBY dWd6jqaOHslfmcubSzpU5NK1lsld26J9fJ/eeN/GPS9O+G2oRaLa/Gr9pzx1qVzp/g27sbjS viTBb6es3xD8WXXgzRtJiuI4dZuLOa0v7Jrp1ht7tjDd2sdrbTzEh+D8S3n/AAjS6Fbal4u/ aGk17VvDms+LzZn457dP03wzoDeLXvNRvJbj4dR3t9qDy+Eb20tY/senae/22wt5dXgaGUv6 FafsZfGm2+F1jpHiLS/BvjbxVd+PbTxH4u0ifxDe2ejajoWk3/w91jStMjuNHXwreRTw6rpX i6cDT7+znmMlhDc6jJbNHHFv6r+whefEDVbW+8Z+EPCmg6N4c+DniHw14L0DQ/F3ipDpXxKP ivxN4i8NavNNe6lrl3dWok8Q3E1yuoazfaa3miB9IYRRrUvNOG8BjqbqZhRxuHxMK0K9eGJp UqsUo040aagqtZpUpTqzhPmV3Ul7q5U21Sm1fT+tfy7XPH4dU0bVrfw3qWhXP7UvimTUdCut cv8ASYPibaXF3qMVq+i6bP8A8Irodn4H1VvEaWuo61DdaleTX+nLpllbtdPFcz3SwW/V/DDw 5oHxc8X+IfDlj4t+JGnWPhnxnd+Db1/Efx3soPHF7LpeqQ2N1qGmeEIfhbfwtD5N8hjspvEa sdXkGmSXUSKL6b1n4h/s0/tD+K/A/gDwFBf/AA/utN8G+HdA0bw/qMmpXlvrHgmXw/4e0bRL g20iaRHpmpvr1vZXllePrem+JYUiYzaami3bQzrq/s8/sy/Fb4SeN/EV7rfh/wCGt9pGseOb 7xAfEtrr/iu48TPYX2r6XM8f2P7dpnh5JPsunvfiMaH5iahIIjKbFls4+Sea5NLLMfSpYig8 RKC+pS+vUoyjUhio1/bN2a5p4ZLDOm07cntOZufIqVKSabtuvtLo1f8AP8ep558QPht4b8F/ FaL4dWUvj3W7CG38KarqMt98TLDTPGHiSLxHe3lotj8OPB8Xwz1WHxQnh8aRLeavDPr1golv blQbXLTNx0fwu8KeOPH2m+FvAXg/xRF4u11/HVpc6l448f6b4dnsNH8CalZ6dqqSvo3we8S6 naapLqVto9pfWUnnWsUolguZ4p47WM/ZX7QPwM+JvxX8YaY2kXPgk+EdNm8J3ekajrF7rdl4 s8H6jpfiCz1rWL3w5Fp+nTaFqP219N06Z4/F1j4mtla3aKztrJJJkk88uP2cP2gvA9/4O8Rf CDxj4Dj8W6RafErTNa1TxtPdXEE9n438T6F4ia6sbXTfBq2bXVxNo4F4ZLKCC0NwIbO2QOGg rB8VYD+z6axGLrfXv7MrUarjioSh9beJpSpWmoq8HQi7za+J8rV9XtKOnu2Ta0b07Wuv5tbP one93Y+ddBuPhP4w1jSfDvhG08PaBIPDUOu+Iovi58R/DXh25k1uS6srG78MeGIdM+H2qN4n 2NKVR76LQLuWQBJdMiN2VtvZfjN4Z+DfwX8dfBPw5qvw7n12z+L3iDWNHur+zbwrbab4VTS7 nwzp76mbW58HyRXSKniCO/uDJc2IjOnuTKo2yp1Wk/ssfEb4X+JdM1v4Q6n4FkW+8M6LZeNm 8eaprs97qfimyv57u/1PR4tK0SzsorfUA+Yoz9jt/OVli0+ziU5+k/ip8DtG+LXifwZq/iS5 vZdJ8M6P450i7sLO+jsXul8Z6GdGknRl0+SVri2C201oRf2lvHPApuYLyBpoJsMfxLldXNsu lQxGK/s/DU4upJ1E5+0l7OVS0eW8mnBbPa+1gguWNpNc2t7avpZd79b+ne6+Cdb/AOFaanrb aHpvwc+Ftj4Um8Ra9ocXjv4lxaBP4N1L/hGrnXrNLeeO38F2umprd/NoCX8JXX77a3nILR3I uII9P+Ivwd0jxv8AGnwn4n/Z78B6ZZ/DnwTp3iDwxq8Fl4W1LRfEWsXXhq11268KG51DwboE StdXl19m06LT0nurm0029Mll5tvhfpOP9lnxX4M8DHwb8LfGS2Vpca/4kup9L8XXOn3WmDR9 Z8Y694rtmS9sfBM2sf2xa+fodiVF42n/AGe1u1cXU7fb7ilJ+wf8NNT8HeJ/Bmv3/iW90/WT 4YvLO6g1y3g1G31fwv4b8R+Hre481PD9rYmKVfEl5MyNaXUcjx2z+VAiSQT9NXiTh9YPFQni 8fLnm5RjySktZ00tE+jSf49i4yV01d29fK9+nrv+J7f4R+D/AMHdY0tLq8+CXgSxlguZovs2 s/D3wsZ5N5X99bGXRo2aKRSkLN5Y3PC0eWEYr56+I2s/DD4anxJ40vfgh8EL7wB4Y8ej4Yya fF4B8PQeLbzUP+Ecg1xtTj1uaIaLb6ZaalO+kNoLaVNOpsnvTqsU7HTLf7usre8gaZbi7+2Q m5Z4DIIBJBbNaW0Ygj+y29qrK14l1KzTiaUecQswjWKKLxbxV+z/AOFvGmr3g8S32uaj4Kv/ ABA3jC78DC+sbPRn8XPor6E2s/2hY6TbeMo3NpI8hsY/Fq6ULh9408RhYl+JyrO8LRxNd4qr ifq8pN0+X3mk3Fx5opK1le7v16jbf2tV+mlldO+uvnfRPRX+Hte+KVxo+laNY6J+zR8I/Efi 3xFH4G1Y2Hhv4Yyap/wimk+OfDA8ThNUsbSNdT1PUdCbWtE0s3WfDttqV3aalMIdLN/aW9j7 df6p4Us4/hj4m0Xwv8FLmy1tfDFtD4Yt/h1pq+KNdv8AVrzRbbXbqF7TxRLFoFr4f0zXLDWN 6ad4wmthb6mbxobe1hu7n1nT/wBmHwlayxam3iLxePENnP4fOka6l74ea70m08HWb6T4Vt7S 1bwv/YtwlnpUGjpO2qaTqM91PpNtJczzGfVDqM+mfsy+EtG8a+EvHOk+JfGunat4S0220uOG K78M3FhrMMEN/bTzavDf+FbucXGo22pXdveHSLnR4Y0dX0+CwnRZR6lXifJlh61KlWxzndxp /u5pJJpK71W29/W+xpzJ2vvb3rbO6Sf+e3TQ8t+IPxR8FaT4j1LQPhv4d+FuuWXgv4dat8Vt c1bTLHSfEFrqdroH9rfaPBITQbnT4rfU9UnXSDDcXlxcR24vLd30u8eS1V/P/Dv7QepPoXh7 4u33hLwVonhTxN4s8P8AgqXw3a6LcR6/pGm6jNrUOt6oL+bVrPTYJ7L/AIQyeXSbZrD7PBHq UEd3cN9jeS7+xvGnwP8Ah/47vbTUNZstQiurdLe0nk0/U7qAajpEMt1LNol4k7XKJY3rXk32 m509bHWUBUWeq2m3J52y/Zw+GOma5pus2VhqscWi3mm6jpOitrF1JpVjqWjvbSadfpI+7Wbi a3e3lPkXur3NjN9uuhPaShLIWfK+KMljlsqGIo4rGV5TvCM5Sowp25PeU1SqJt2cbW0Tv3JU klpe7Vm29d031e7XR6bLQ+afi3+0LrS/E7QP+EA0Wa58AeD9C0/XPE/iW0iu73RJ5tf1TXdP t9PvU0W/h0WWCODw9ayWL6hq9q4bWfNSGVFjiueZ8CfG7xt4v+LKfCzU77UfDutfEDwnrF1e y6fBq40Twa0FhdxWsnhQ3HiS2u4r+/g8PWf2W4lsLMxeI/Ed60aXiLEl/wDa/jv4I+B/iVre l694nttSlvNLFlG0dlqUlpbala6bqbaxp1nfoqvKsNnfyXM0cmnTafdzC7miu7m4ijtUtuat /wBlX4KW2qa1rUfhq+bUdc0o6Lczv4h10iDTi1hKILWJb9YVK3WnQXayzpcTGZpY2drVltkM LxHwysudKrlVd4lylLTE1HFpr3btYay16WfqWqr5VHySu7PtrrvZ7X/4bzb4Z/HebQrrxd4A 8Y2/irXbrwH4hu/Dlvq8Vo9zruqJHqviZba/1ufVNdkkZJtP062a3ZIVDCWIR/uBGa+adI/a p8efFPxp4s8Pu7eDNJ1fX/AXhrSJrC41nT7vw/4f1bVfiRZSateMddNtBrxtruwbUJ7aK3sn l0K1LBo7WFYf0l8C/C3wb8N7e9h8KadPaPqIt1v57nUL29muks5Lp7RWFzO8EQtheTRobaGB pE2m4aaRd5t6r8PPCGtf2qdU0UXX9txwQ6of7Q1WH7TFbf2t5K/6NfxeQE/tzVMtb+Uzfafm Y+Tb+V5eEz/KaWNlWr5RP6vd2UcVJy1TSulhk3q+5MZJO9tdNttLW0+Xy0PzuufHnii4vfHW kt4+157L4O6K+o+EdXs9e1Hz/iRqmp+Hb3xcYNSnOrSQ6iujazHZ6FDHpjz3EVuHgLQ3bRBN z4F+OPF3iLWtM8ca1rWrnxFresWmi3PhVL3UzGNMt/CXjoC9vLW7v5r6Yyjwxod+Hkj+zi4v RMA26zdPs6P4HfC2Ox8OaYvhcCy8JXVzeaBCdb8Rn7Dc3eoRapcSGT+1zLdb76GKcJePcRpt 8pFWFmjPVW/gPwnZ+IIPFNppCw69a2i2MF+L/VXCWyWFvpaobWW+ks2K2FtFbh2ty5wZWJnY y11V+Jskq4fFqjg61B1IyjSg5zlebStLmdKNtkrNaWve17XOrdPljq7q+mibV03vZ630d77b HWsNwxkdew4/Dnp6U0AKcc/MeP8AP40oXGeTz16c/p39vwoKjqSePp/QV+YVasHT5nS5K/tI yc1U5koqd22uVXvGytpo77qzzik3r28/L+v6Q/BwD2P/ANf/AArtvCJJW+9vsv8A7c1w5k+X AI4PHXP+ea7LwaxP9o57fY/1+1V+5fRtxUZeN3B8ISbValxDF6Wu4cK51Ut6Jwbv/T83OItZ biG+nsf/AE/S/HW3yfkdvRRRX+q58OfjDpEUf2q0QfMVlQwCQEtFMJLcQwbiX5jIPzhmiySd x6n2d5GlyQix+ZgmJSpEZ4TBIVFLMED5TIwygncGA/NL9mvxf8Tvid8VviXJqOvaXY+CPh14 kvvDMGn2sPiDUdX1qWy8SFjcyyz6/BpEIk0iyEG1LOZvtNyWx9mxE36UraxRQqgniSC3Vl2q VWUFmaVhKMhFcmUFRgfumjJBJBP8P/SIduIcqw72o4SrXiuvvfVtW9Vb3H+bP3fgin7XCObS fLFvpf8AiP8Ar16FOdIySrFS/ACMpYEg854K8DJyc9OD0rlbuSaITXDTmfy3kAJt4I8RLvOV YMz/AHY0AyqsBjHIIrcvrtRHMkZXYhVQ24bmAkUZG1sck9R2rkLi4Dl0HzLzuJYHgjt1HQnr 1r8GwUJU3GtBtOhU9mkm2npGps7Xu5/kfTVpU5U6tKVuZVJJPXZcvba716tfNNfnf4s8HeI9 a+L3xB+LF9/Yt74b8BQ+Fnax1WOC/wBcuGs/DEd9ImkC4065t7YT3N1DEHm1CzKzI8zLsjjZ /HtL8dfEX4YePtX+JV14cubnRvH9pfP4dsbTxVYrM0V7qES6TbXVjLbtp+mpa+HfCzufIMiR yQQWyh5Z5Liv1Xls7QxPDFEgjvXEU48uMxXESiNd1wFULLtDyoN4dQqKvHzAZV/p1g0DCSyt ZIrMR2aI1rC4ECssitAGXamJpSvACBDIANzZr9TwfF9elhaGFxNGnVwklGNaPJJOULJW5oTj Japaxad9mkj5atksqtR1kmknzfEkumr1v+vm73Pgv9n268aeB4viZ4B8XaU0Gs6Poa6rDe2n iNdZgv7nUzq+takIXmgt5bd3uddtG3z7UMm9YhHDGAPJ9E+GPjj4W/DZPFt3f6NC12vh3UL3 VPD+m6Xp3iPQtMuJNGg1uW21C1trO9u7mLTdSvCDa6nbXE5juEt5Y5rpXf8AUDyLWZnUrGt2 8ISVvJjEl1EURVhlcsZZBs8pNrB1xwFICiqU9vHcxvLIIzaeQsJgliV4Nq7zt8tn8rGJUG08 fKoxwM3T4kw86yn/AGTGNOvrirTrpUUkrOH+0vlvzS25tUu1zGrlMuRO0r2s/eXW3b+tj8pN Ol+OOpXFyknjHxdLoWn6J9r0Uv4l+z3t9qDa1bWk5mjg1pnjlihvtVCzXuoXCNaWkUSFGa0t 4NjwV4e+Mlt4w0y5m8Q+JNUtX8UeFIriHUPFcskDaPJdF9eE0NxrF6skV/LFbu0IhkleHKBU +eBv0tmtrd5LidI4UEsCQqkdvGFAWaGQ4Abu0ZJAJGSTjOactufNEdusayOkT7hDt2lERVOU bIwZc57Y45r3Y8WzcIKnRwVCHKlGjLDzqSpx0Si5ucnJqybfM7u2pzRySDSu2nZNrnW7to/v vp6Jn5jT+B9d1z492dxd2c+YvHXnCBBo76fdaFB4lvrx9UuLv+1rW9t7r7Kl9cJYxaVdTmS1 t4jdK9zutvQh4AuNC+FXxB8OHwQZrjxLr16NNmttX067vNN/tLwfoujRal5epanbW7BL2zmt X2apHexQXJmhhaNNrfeSGziSTyWQSs/zzmKIXG/IB2SLMGwSWySc/O/HJyyWMlJIDksQCQY8 pt+UlgN2S4HQ4wCBzxWD4lxV4u2FceZXVLDShNLS95Sfw91u3y220uGT04ttXl7u3OmtWvyt 369T8udE+BfxFGiy+F/sVrp2oeIE0C90nxG+p2M8ejaXodjdyXkF1DFcS3kF3qA1HSrOaDTE vbd7mOeSa9nt7aK6uPqKf4VePvEWteD7Lx/r2neL7Dw9qc3iL7fJZWljGl3bXegQ6ZbfY7SK 2nmlWGLXZtkizaeVujFcMz+QK+o4oUj8rYGlIG1vNjH7tyjHEZBbauFdcEAkBPQitEZG5SYx JyAxGD6dzuyGOeD696WJ4jxFamo0UlNLVqFne6el3bZNdrMcMphf4X/4Et+/XbT716HxV8Xf D/ibxB8YUgs9Ph1mJ/CGgz6Tol1c2EcV/qGleKItWu7Rbu+Oy3e80qx1S2Wa8EdszTm0mZbe YufL9b/Zi+MviGW21ex1XQPD9s2u6lrC+AbldPvE0KW6TV7W3nS9ggn0e4uIrfUbweXbMYlj 1afDiW3CN+ijW9rIIr9oI/Oggkt47ho4zchWeckCQruAHnvgLIB2xyc3YruOO3QpG0jAKAQF 3HGQ5bGT970J9+aqhxTmtPD8v1LAJaL+Gm7+6tX9ZS3W9rXXmjKrkmDqOzrTV/77T3VulnbW y/p/CeofA74m3x0/TL7w7pGq6df+dr/irVn8QWUDN4lufstvJ5tn5K3N3p1hBJq9ylvBKthd HUpov7JhkSNnuaT+z74qvPBfiTSNf07w1a38mhaZ4f0CCK8/tW2Ih13xFrl3qMt0+n2T2oST xGqW8JguJmudPkcPbxyQSV9xC7nlUkRKmB8wO/5hjkcDknPORg1VH2iSQA7UBxkEv79iAD05 rWpxNmNahGNTD4eCa2pU1aSuld/vZ66WTura73uDyOjRS9i5ST1k3Lms1ayV0npptp1Plm0+ E994X8Y+FfGCW2kXMfh/4MeF/h1qENrHFHqN/q2mSWazmCaeOOL7DHHDHIjzXEZdbUKELsit Zb4JXfifQ/g1Z6pe/ZIPBOnltUgtNU1iynFzNP4fkjitbjSLyyeS3t4NPvopoxci3klNrIkM 2yOWD6rSEsrQyKjocMHKFhyFbHzcHByPYjHUVb8xYwkXlqUUBRgAc8YOOnTPb+tebDiHGYZu dKlTjVT9xypqUVLRO6crd1sr/JN5PL0/cqNxhKybur201ul26rXZXPiD4g/skf25LqreCpfD Gg2815pFzptndWdzHbtFZHSJLmG7lhS+khxcWeo3Fqq295HLNeBZDao8kqchefsZeL7lTb/8 Jxodno9xoVgk+jrY6hJZReMYbq0a78QqyMrSRyaRby6PblbeN/LeEtZ28YYxfokZEVlYc98A jqP5ev61XM7ySttUhQW9SMgn046nrXVHizOmueUcL019hT8v7y29CP7GwWn76S2+3LrZ/wAv 69vl8Gzfsg+MDbWk9r4+0DTr7R9Uh1Dw5dW3hpZp7a3tpLqVYtQLtbreXMkq6VMbu9k1WaCS 2uESWRLm4e57L4f/ALKut+DfHHhfxjc+NdMurfQIrXzdNttCfT/tdzFb38M7zPbXbxXonN3A oa/glIETlkAlfP2O8kzodwUKgwpBbByCSeeARt7e9PQziPcw3DjaPnO7gYHPXJI6etYV+KM5 rK3+ywT0uqFNW2TfxN3VtNweSYX/AJ+y5dPt6bLXWP8AXRLS/wARaT+yHr9lea40fxC0Saw1 ON5kkk+HulQa1FqUdlp0FleHWkv59WENldafa3H2GPU1tbiKDyJYik0sb2bP9jljGjal8R/t 2ri4nun1JfD19ZlLt7qWaxaC3t/ESxL9iikWCSRRCZ5IEnaOR5WaP7dZp4Yi3kABjt4DjGT/ ALg7ioYkeQhvuuWyyjPALccYBxjB59RisaHFOeYJyqUcdTpznF03ahSneMnGT91xkldwWtr6 JXs2nH9iZfN8s6k9EpW9o9WrLXS2zv3PlrT/ANj7RdNhayfxhcXWgtG95eaBLp+rx2eoarFA WXUGkHim4KNDcW2mXUKNEFeSwiR0hVmcewL8IdJvfBvifwva61NE3iLxHZeKrfVY4tTtrvSN Z0uy8O2FrPZxQaqj/aoofD0LwSwajYxK9xlwsiSyzevqksysjMVBjb5m3bRhGPOezYx2696W Nf8ARltY2jR3k4kzhhlif4cH079K46/FHElWXO8xjrr/ALrhr3Vl/wA+fNael/K45NlsNqk9 Lbzl0tv7vmuy11PJtA+B+geG4dOlknur++g0rVrC61R59UTUr6XXdW0rXdVvpZJdeuHW5vdT 02KeZzeySsssyi5SN5ba4ybj9nD4b3Oq2F/c6Jp+oWVpptjaXOjXtvd3Wk6jqNjcyzHV5LK6 1SaxlnuIp5rU/atOMrW08kUsjQu8Fe+xWyKoEgaZgoDEYILDAZhuRj8xyRk5x1JxTHe3j4Eb JuPcoOmQDwq8jcc/SvNhn+bxruM6rbktXypXbs7qz072totuxDwlBOyjdLRO7279v68zxbTv gf8ADnw/4T1TwJp3h3SrXw9rOr22rXlpbW08VvJNBJpFwAbP7VgyS3Gi2gN0t1FIq4Uo0SMk vKal+zL8I7yztbG08L6day2c+pTxXAfVoznVr3+0b5XSHVTkNc4CAvKigZiW3T91X0vHb713 K6sVyeeT8vPJGe+B07/hTlHkN5kkKyAjG1RyD6jch/GijnebUK1b2OJq0o1JKT9nKnG7SST9 5NtpPdaejOerhcO5RTjrrbV6q6/rpueIfDr4M6J4I8X33iO1bTZ7KDwRYeCdE0uK0ureaw0y z1Oa+uFS+eSZ9t7FFo9vFA4JgbTWmN3GZD51yH9nf4RtHqgk8H6NONRFsPtLLqMtxYeQpj22 V3Pdre2Bm2gytpj2xk3ZlMjA17U93CqYS32M3y8BB2PPCg9T+OOvFQRRt5b7W2FyuM5A4PJ4 x6Hp37+kQz3NJVarqYzEtcr5k6lKTa6pRUW27aWV77K7dwhhsMrS5Vo01q+lu3bS666LTrxV 38Lfh5eeB7DwHP4c0y50XS71bmxtLg37G3ljNy5ube7LyX0Eztd3SyTJd+fOtzcicsl3cK2b H8Dfg2qaQr+A/DRGjRtBYw3OnyXdrbQ+ZbtB5UcxmRpIorOBJ5ZLfzZ5A7vJO0kry+ni1Zox +/jDd+vrk5O7OaiCoAUkucbDggEdRkFRukHTkDjPqK4qeeZjGtUlSxWKW9vcj1ae3stH3e+m vQt4bDVL3jfbq+tn8tX11PNU+BnwWe3SzT4b+ElijvY7uyW40qO4W2w9nJfIpkWZsajHaLbS rkxqoVyGDOo629+EXwp1OLS73WPh74R1CbRLeDSdKebTIbp7LQ7SG4t7LSLZ57WM2llbNdTT Q2cIe2hLkRjc7Mva6elqqSiNmnMgIJPl/uiFfbtwX+8Sc/d+6MZqSEPAJ2aMyxGV8IckDcVx wVK8Hvjv0qJ5rjsT79TGVPayvzcyipe6+SN4qKXwpW0V1Y2jgsKqSXIra9XffS337dNGedy/ DL4d6h5Xn+DPCt1DBcWs0Mdx4c0spCbdHjt2twYH2JaxEwKu2L5CgSNlXCbkPgDwZNod34cb wx4cl0W9kia90qfQdNbSrmTNv5skuntDLbTnba25UywqSYIAApjUr0peWEEBU6Yxlu3boOv6 1A0zpumJUNggICQTjJzyQcEuR0PCmlLHZnOmqcsVOcOaMuVuP2bNPVdN+r2su/NLD4ek3OMU 5bWbfVpad7f8N3OZ1DwF4JvNHbSJfDOg/YIXuPs9v/YlgsNi11Z3Nu15p0EaKlpcRvfTuGt2 tJnkluT5sYuZJXzfC3w58JeF7cWfhrRPDelZnlubu8k8P2MlxeyS3txeySXDyW2oXBuftN5c S27GeUKryjzrb93C3VsGmRppCyrlQYxnc3zKg4Y4PJDEYPAzViAuqlY12ZAG58jgEgfdA6Zz 1/Ktnj8fOmqbxs6SSjpFpWtbsnf+nqONGlUt+6Xlp6dn30vt5mcdD8LWirZ2fhzQreyLNIYI NH08IjSBI5jGGtYzvlghihnIMYeKOMbpMbFistG0a2SKGHS9JVbY+baWtvp1rbpYyGbeJ7eZ LeMpteSWchAjebLIQpb521TBIskW8owyMsA3IB5IJzkHrnPTrVoiIyFY1IbaCThcbcgEZUA8 HB9MZrOpi8YoOM8fVqaJe81Z6X1tFX7dehnUoYVNckWpaX8mraba628rW1sWbGKRp2kMiykQ qkcGDEYwgjjAF0qmQjYucEAYAU9BW1aweZFJlVMgxtHBP3TyDwB82B7delZkRVI12YMm3k5A PUenzdD+WRWjbzy24JXad4A5LAduBgj24rxKl25NtzcrN3dr6eW1/wAfRm9OPLFb2fTp0/S2 i0V9jU06aEbYRGZJCzFjgDBOCBluMhdrZBxzjOQRXQYUKD5QVlAOG2kDOAc43A5B/unk/iOd hN0kTuohLNJu3DzN+AqqQCBnHy+uM1p2tyww0sfzIOTk4ycqclhnuMVwVoKUJvrySat3Sdnv +BpFXlFPq0vxO1sLUvtlVITjYTwOB8rd0AHfoCfau7sFaVVwANrHIGMDqeOF7DPTrxXnumXD Pu3fKoC4yTxnHYnGQPyruNOuEjUqr78PkHcOeMnoxzjke3NfIZjTnZp6+astUo239P6e3R7H pbbz6u138reXp0Ovt4JBhsbkK4IyBjoc4z6gDjnn0zW/bRMQNjjaQDnkcZ5688nPbtx1rAsZ jLEoIIXLNuz16YHORjkd+tdHamPPU4AXuuBz/wDrr5PEU9Xe99L+Xb7vTr5GNeHLBdNdr6dP 67fma29fX+f+FLtcsjoQMffIALOpVv3ZLAYAYrJkE8rjHJNAx2xj2pw3ds/hn+lctKUk/dlO L705cs9187b3+6+h5rd3fQAkmwAtIpReMzSOeRllEjN5m0kDk44C4XgAMMe3fwRvLFiu1CxP 3juRtxL5xuOG7nFTFWJySPpzj8qNx/iTP4f4g10y5JRXtamIb02qSVtrJWVt1oultk95SXb8 Ldn+i/LoRCEFzLw0hG1ZNilljGGEe8sHYeaDIARgMR6ZqTa2NpAOcqTkqyq33iCoJ3HggBhy PvggUowTuyFHpnHTt9DjP+c1JWtKMLKyurJJyrTu1pbmSqJ3ateyWr0SFe27a7JJPTbs/uIg jcnPzHjrtzj+PcpJzkk9M5HXnIeY1IIbBywb+I4wANwbG4OMZUgDBxhgeaXI9R+Ypa0io3kv ZQqfDrKpNtXS6+2W6ezdttFe4aJLV6+S8l/L6W/4YYsaDcM4DEDoQcDPzFgdzljgkscjJ5PO W7MDkeYTgAcR4Y53SEqf93B5cc4HXMtFbpyS0w0Era2nN6NdnWeqTbV09baW0SvG/wAT/q3l otNSuEk4ySD0++XXGSScthjuU7fucEdcYNOKElT0wSGyquCu1sgbjlQzhHO0ZJVQRjJDmLZw AcD0zzSAsDyGP51xxnSi0vZVdVspz8vPtZa72T3bK6av5r9NH/XboxoixJHB3EqXRHwV/wBW y7mbaEJYrjBG4/KO8hD5ypwuP9WQAGbsS4yVwcHgEjbkAnipKK2SgrcrlTV0+WTbd9Orvo0+ lk9Lrstezl21VulvW3R/8OMXcB8y9MkAOWIJ6gFgOBk4ORlf4QSVAA+Tlvlx8qHnY3HIbqec n27U+itJOKpuXNfbS++sbeWl7+tr62alN8yTXf8ALXy7bd9NHYZtODtAXOeDjjjjpkcHLYBx k+pNABxyOc/NnGG4HzYGcZOOoB49OS+isoVYrol6eaXZW6Ipq6Wuqtr929vT7+wgAwOCPbJ4 9sAkY9hxjilpMj1H50uR1zx61nPl1fLbmbad/T+tu3ypbL+vzCm7VPb9T/jSFwDxz+NOyMAn AyM8msW4S3d7a9fL/gALgDoAKKYzKCowDnPPHGMU0tklPkwQQQeRgjnIyMjnkcZ6UlOK0ilv ZL7u/rb7ujAfuUd/0P8AhTDKo9x0PXr6Yx/9amFVXB+Tj/nnGAf/AEM/5zTCcHcFlYYxgLwM c56nk5/Ss6sq/wDz7Vrdktrb2fTXYaTe39bf5of9Tj3/AP1ZoyDyOR/n1pnIB27pD/dU5b8M Buxz06Cot7ISDHISTkB3II4PQGM+vtxz7V59Wqo/xVOMrJpRoYqorbJ82HhKCd7q0veSV2kn Eai3f8uvTo2umvb7yXIYZDYxznB6c/Soi67dwclcgHhhySAODz1PpSMzngwuWwXUAEtt7YG3 JGemMAmqxlDMhyyMA58pnCMRtJYsmCSFUFweAo+Y8dPHxFaDhJU/bSm7KywWYd47J07fDe+v 3Gyi/nba8fLt8l027E7SIgLMcAAEnBPBIA6AnqRXc+Cv+Yn8xb/jy654/wCPv1rztLiNnCRm KVyzALHKskzld28bFXJ2FW3AElQhyBg49B8EHJ1VSrKV+xZDe/2v2HTvX7R9GCVV+OvAqlGo ov8A1mvzYXF043XBvED+OrBQjq/tP3tEndxR52dQayzFXVmlQdrrZ4iitVe/VfijvaKKK/14 PgD8G/2ffg/oHwuuPGk2k3moXD+MtdufFGqfb5Idwu7t43MEYRUCK5ebARY2BBwi7QB9LXrt cov2mJg6xkbGJBA8x2BBQIMHg85Oc84OB893fiy/8MPbGK3NyLjyp7llWN2+zwklmi8y8tQq NuYqhG8nG5FwK6+4+JcGn6NrGua/FcxWuhWUt/q1xBbwyxwWcMc0zSRwpdyXExjhjZ3jhjeR iCI0dyFP8NeM3D/EOc8WVcTg8uxlenDDUIU1PEV5xpxdCinGMXVnGEXKMnJKybd7NvT944fz DLMBgeSNVwk7q8G431ejamnu72/4B2dwi4ZlTJQgIhLdAducggkYJPfnvWUYoFViz+SXzleW 5+bIGdx7+vevIrX47eF9a8KTePdFlvrjwql9dacb59NML/arPVH0ieP7FPNFekC9Qqr+RsZC JQcZx803/wDwUR+AMB2yXPilnSeWBgvhWQgvE7RyMpN8vyqyEZJDNuBCkZI+Fw3AHGc5ONDh zG1IycZN0KdKpBTdOmrOVacZqdlFySTjZpp3PVqZvkMIOriMfChOTvyz1clpad25X5rtXutU fbstvAYZIlkZo3BDKOAcAHGdu4c+jCsMStazmOKEuix+WOTwm4MBnB/iA5PJz1xxX553n/BU 39mE+J/+EKttT8YnxQbNLz+zI/Bd0iNFNb3l1EVvJbtLEM1tp91IVa6UgoFOHdFKt/wUm+Ag MknneLW8udrOd38KttiuY13ywME1MOzxEbGkiWSBmBMcrph696Hhpx1UpqD4dzd80UlCVKio NXTV2qraXou55T4oyK9oZqlFOzjHld1pooyag9ejtpruj77miR5i+14ssWIEiHGCOPnQn39f rUJe2VWKAZzuz5mfmPfBGP0xX5w6r/wUv+CccUM8L+Jws6Syru8KybkhjVN0jgax/CXUlVLu c/KpIOMK7/4KX/COK2+0xW3iE25tVunm/wCEWGyOJ1LRtIja+JiWUH5Yo5CD1Ar3aXhdx1Lk h/q3mSVTl9ouk0rNKa9quazb0ffzZ5mI4ryeN3HMa7Wm1OhbW3Tm0fkl+R+lUKlmKrE7RZyX DfKH2r8udp5xjjPfpU5zb+dI20kwyRguR8se0ZGFZcnCL2zxxyTn8mbP/gqv8INUtTNora1c QNIxaeTwnqNsqFNqOrp/b1vIfm2AFYnJLrltqts5/Xf+Cq/gPS0Qz2d9GkpmXM3hjUpiixKv zMIfFUgxIreYoUP8g2uqSfu69ql4NeIlaq3TyCuqcn7ntKdNztZL3pOnOTdt2pyeu93pyVeN eGKcI+1zerCokueP1XBO0u1+fmem19XfyR+u8dushB8xVQn51CMcg89TIWHpxj861BBbCJvL j3hOVIdwMghuhO7hjzlj+XA/EGf/AIK3+H7K6ubSXQ76z+zz29s0tz4WM0LTXN29jCqfZfG1 zNgzqquzRIoEiPnaJDHleIP+CvNro0o02LRJRrMscE0NgfC0refHcTm3RklXxwlkgLjaVluY mBRmK4KlvVp+BXiZUuqXD9eq1FPkUFGyvFc140k7XaVm7a7aJnDPxB4VjFNZ1KPvJXnhsJBN Wva8HdvumrdXqrH7olWIRgViZAduBuIBwCMM5HTuR9MZqJU3sTM6v2BKMvf/AGHXH49M1/Pb Yf8ABaDUdX8Q+I/DUHhWSzvvCsOmzanLdeFIPs7jVYYprVLaS3+I128rBJAZd8EKoVIV243L rX/BZC+0fU7DSbuHTba71O9j06yz4N1OWKa8muBbRQ74PFMhj3SEfvJlSJV5ZxyKql4C+Kik 7cMYpdLpyXZL7Gvp+qFDxE4V3/tyN73/AIOH8t/lda/PbX+hcfY5AJWnjmiUnasUNwMPggEF ZHcnJOcgrz0HBpY9obNuWjRd+DJDKA3mNuOwyhCcMDkgtjj7oIz/ADn63/wWH8ZeH9Z1Wwvb DQ9NstL0J9dnz4MuJ2S0j8tZbhDbeLLouY3Z3MQQyssT7EdjGsnBXn/BbfxaNAuPE1tf6KPD yahb6faagPAN6fPubiTUUFulrLrZvlZG0u/DyTW0MH+jMVlcS2xl92P0avFiS5f7Jw3LvZVM TbpslgrdO36W4n4lcF6Nf2qtVb/ZcD5Wt/t/9Lq0f05hJCJC+4gK2H2EKh67zjggdTkhcDsK VraxAVppgx6Hbu+7kd1LAdT7/wBP5er3/gtT8UNP0fTNbvNd0C10nWb+fS7GX/hAbiaS4voL Wxu3szAmoTvHI9tqNu0ctwiWRbzEknUqQ3U6r/wVS/aSsoLW5Nx4fFjqFxo9na3y+DdEaBbn XteXwzpayQtqv21VuNcYWjOto6wj/SZjHagTVrH6NfinBKNTCUMO/sxdXFJSWmqX1J27WVt+ u5EvFLg+l7qqZx72tlQwXl1/tDr+Pmkf0xGW2hgxFPbiJGCRpJMiud37x2cPIrj52cLlUG0L jOdzTMLbDLIyLIu3nzRIJMqSZFWMjhPl+ZWZPnAbkrX8ot7/AMFN/wDgoNd/Ha2+Guj2PgW6 0aTwRB4tJfwt4NS5mt7tWktrhLq58RwkFhc2X7iSCOVIiyuqurAev/Ar9tL/AIKVfHDTby4t f+EO0yfSb3UNPmkudG8AWjH7H4h1jQZonEGq6wkrpLo4KSqMFVaRZP3uwuf0bfEaEHUxEcBR pU0pVK1eeJ9lTjonKbWW1JcqbS0jJ6rTcheJfCldqnSeayqzaUI1cPgvZ3drc9sdJ8ttvdk9 Nt2f0nJ9nacKHUrkZkG4bflz0Jx27+v0q6yW0LEmYFGUEKY5ACzAEkMDzyCcj5eoAAwK/m7+ IP7V3/BRDwRrtro2r6pY2VjPqvhzQr/xRY6d8MZtD0bVfFmp6Vo+hQX8C3J8Szfa7/WtKgef SPD2qQWwvRLcyRQwXclvyHi79q3/AIKC6Zrmr+Fo/G154i1zQ9G0bxBd2PhCH4e2LyaRrUOj XNjcWt14pHhywLJD4i0x7qCS4gmQNKkUcjQsp3o/Ru4xrw5v7b4dinrb6zmCVtHssltpe/bs edV49yiNS3Li0m1pGhhkt7PT6xbe6P6cEiRoyDtdcGTawcblTPyKEkRzuD4JUlumME1duYlh iCLMJSiIUCqImZ3YRxxorly7I6KyqoZmZgjBsgH+a/xB8av27tQ0vwS3gD41a34k1Dxf4Vj8 fWkemTeE9PePwa2m+Hb5tRlPijw7oFtE7L4u8PkWHmT6gJJ3U2qrbXJXtv2ZY/28fi58MNI8 Z+J/2ovGN3c6heWV0I7bXdA065gtNT0Dw5qdnaSC2+HaQrc295ezmUw3c0MZOIbmVfmbof0Z OJ3C8uIchjJ7xjVxjitbLV5MpO61d+raBeIeVxqyp/2LmOKjFx/fwqOlGpdRelOnmNOnHkb5 XywV3FtrVt/0MvcxMsSPKjLIwDgyxI8ZLPhimA5GAp+6Ad33qRGsoZHlF3bq+VDCWaMJtXOw hfMjfdtUFv3jBskhVBAH87EPiH9snT/iR4a0nxv8Z/H2ieBvGt3L4e0HUYvGNhNrMevJ4f1j XUlu/wCyLTUhb2JXw3rMKyLYzS+alsrwiOYTjc8FQftX/Evxv4kstE+OnxLuvAHhfxFc+Hbj Wf8AhPm03WJLvTddu/D2rz3McljC1xZR3uheIDp7QaXHcvZRWck9sbiYo3n1vo157h7TxPEe RU4N8im62Mg+ZrmUeaGTxlqoybT0dr2bVzSPHWX1ZNYfI8Xh52u54ipKpGUbxvFKeOrJScmp J8t7KSUldp/0HzazpaRvBLqmmyQttWSR7u3hKkuEQBfPBPzgc8gE4Y4rOh1Xw4JVSbVdKQI4 wz61YRDkAhsPIDxuOMsQcdOtfiJ8Yvhf+0d4b8Oy3vhT43fE2/mtbJr291K9+JmofYLWCC6t GkNzAbHT72aWa1W8Np9ksbnZdGIztBHyKvwY8O6t8X/hhp3xNj+N/wAcVtp/7eikgvPiX4ls ZHm0a+vrUA2ljDcR/MIYxG32rDnDSGMZ2zD6OuYSS/4yrId/+grMu6u1/wAJXT/h9i/9c6b/ AOZa36xhrp0/eO6P3TPi/wAD2rSxy+NPDNkPlT95r+kGaJ0I3jEl0Qd7bid0RADDYQME4T/E X4bTXARvH3g7T8AALJ4j0lhd3KORDAxmvkKpd75RL5LRsnkL5csO4l/5pPEuufEmz07V/iXf eOfiQfhV4N+Ifjrwb4jvG+Ivid/EWojSPGPinwBok2nWcPiAGbZ4h8PIb+e7WweW0kW6ityZ JI4vaZPBFrcaN+0Rq8Pi/wCKd3efBrQNa1nRbeX4meMlM+o6Va+OLlEuAdbhhvkMvhmySFZr izT99diSWNLjfF00/o3KU4ufFlLmdk3GLlFO1/dbwSk43uk2k2t1c5J8Z1U3bL5pWVlaKVrr tU2tpfXVn72p8U/hPZfu5Pij8Pi/lNvhPifRvtU298F7eFdWMht1h+/IsFwgkinXz0YFIc+4 +OfwWtgxf4m/D2MRMVlafxroUKxOrCJEaOS+SQNcBml2s5ZWjwuEytfzYeLfg1451v476XpP w68ZfEDz5PgfqniGaz174teOY/CsNxpPiXxMbmWOzj1xrz+15LLT7aJZ/s8kDWs80IuopSFh 9T8G/Cnwl4zX4IL4g1Dx63iKfxJ8V/DPxDgtfiL43tdI1HVvBCeLfD8csVvD4gMWo2g1Dw7J d2k9+k1wSYrx47a7lmVPWX0aMumoyxHEVavKyUZYaHKktLqf7ujdt2aupabtao5Z8a1rq+Ej B2054UpN7Xs5uTWvRW+drn72n9or4FB0j/4Wx8N7nZhWEXi/SIU3RkK+6Rr+ZZGfcvywvHxl kBDAhtz+0p8AAGE3xa8ARQKAcDxRp9xNLsPmMuIZd1uXyscbyRMoJMoEio61/OboXw0XxfJ4 X8HeFpNY0rxH4k8Q+MNeu9Vv/GXiqW3i8IaE3w60tI7SW71nWjbajLf+N/tMVmumvY7LMs62 3lLBffd3gv8AZA8HaJ8N/EV78R2vdQ8XaXp+tzprsPizxLNpiRxWd1dWVzNZWa2ySixSWPzV j0cyy+QB5V2yqZN6X0achi4yecY5a6yjBXt7vXmTW27fz3NFxXWcHOFKDlCLkqbp01CTik1F 2i/dlZJ6PfbofpBP+1b+zfbLIH+LPw7hkguSxjfxZayzvZum2OSUpKqJmaVPlEEci7VRxy5b H/4bV/ZXKJPbfGn4d3VpJNGhuU8QGcCAeYss/k26LLa7tjOWug8bEEwqsYKn8CvhJ4c+Gvi/ 9re3+G9pd3Hj3wdqfh/xnBd2t+dVsreDxT4W1LXbTUbKwuJbPw1qptNLn8NzRW8t8tzDcgSu l1diS1dJvFn7Pja34V+A2kfDvSPDPhnU/iN4s1/T/HGpXM12s03hOy8U23h6dNBaS31m20vW 7OHWYf7NmisYIWkRp7uSZ40D91P6OHDkWv8Ahcx93a+mt9P+nndLTbyOSfGuZfZwGFi+toxT 6f8ATtab39U+h++8H7bn7K8SmOX44eBo5E8xfJbUpS1zbiMSyXMgFiGimiWSZIoV8rctrBK0 Ewn/AH2dd/t+fsqWkUnk/GLwLNao5EgXWbmK4e4WUxeUs0umyxJviWO9aM2jyBWZVdY8FPyT 0b9jDwX47+J3jDSba4u9O0T4cQeD4bRrW+tLWfXdV8Q2Opa1dN4g3+Hb0X9gw/snSEitodM8 uxgvY2haSU39xynw7/Y78G+LPjp8btN8VxRr4O+GniPTtI0rQNJuorSyu5v+FYfCW4uL7UFj 0T7ZdSTa54z1u9zFe2UZlFk/2NI4GSXvo/Ro4InFTxOMzqrWbbnVpQioS1Sjyv69TtaKjGXu R95Pdq75Z8bZvzNfV4pfyxhTcUmo7OUb66363bT0Wv7CX/8AwUG/ZRR2VPjB4LkYi+eFzqGo 7Lv7HKkMnlWg0gXNuqSOkbCaeZkLqrMzENXFRf8ABTv9hu8s7/WNP/aH+G2o2GlXNxa3lxba tqT2kN1AI2eyuruPSWijmtxPC7xhkmAnj38SxY/Ef4f/AAV+E2vfGP4Wah4S8C+MtS+HHxZs vEE8OreNNd0vUdE1q2vvGnw2gN/4Y0SbxLda34ThlXWtYkgifw/4cu4LKe2hNpDNbx28Pmng j/gnv+znqP7P3xh8Qro/jVptI+Nt94eiEHj7xDo0C2P9r/Dq2ltms9DvtMgvplttUnWW/wBR S5vblHijmu7lYVRN5fRr4Dpx5li+I46pJ04U5NXstefMkrd+3a6ZlDjHPK0+SjSpRm02nUo4 eUEla91KjUV3pZ8rtrqj+hl/+Clv7H1xJbxaV8XfB2oW0ksUja1Y3HiK4jhieQ2syiBNBnju Bbu3myCNhKMHcUjjc1z99/wU5/ZQ87ULeH4o+FNSWyNxAjQ3muRyGRNyLcXVqnhmS4tYy0TZ SUxIQ5IkACtXyX4o/Y9/ZU+Dvwo8XXt38LbCPwr4W8K6/qN3q1s1zqPi5HuftDj7DqNzdJcm 4FxdxxWLtJELSTyZBNAkAnj/AD/+Hn7OPwdm+N/w7vdP+F91p/w3+MvhjxTcGLxV4o1zXtQ1 u3bxf8KbPR9XSyl8Z+JLfwzdJpHiLW5ZW0eHRLiI6xEkdqr2wt7Ap/Rs8Ppu8sbxG9f+gfDe W98y8/XsXLijitL3XhF10w+HS6bWwd/krdumv7KaX/wVc/ZF1+we48OfEnwprghSzitTps3i tJJDOR5DyQXHhW4lheeMq5eWNIY1VyUTyZiOav8A/gsf+xzZwa4LXx94Yvr3w1a3d5qsNvf+ LGuY7S00uPWp52gj8DTtdiKzubdmg06F5/KIkALRXAPw/wDsOfsVfsxWPw88SXenfC2w1O5h 8cTWt7P4n1rxN4mvE/s7QtDks7ewn8Ra1qZsrYz3N1mxsZbTSw8jH7NGjyFvIfHf7F37Mnh7 4mftdW2l/CvR4de0v9nnxpr3h+KTUfEEmnWVzF8OPBsa3yaMdV/4ReO6TN6qXH9l/bGMn7yR o5ZN2/8AxLz4VrSeC4rlJaOXPK0mrJySWfKKUr3soxsm7JGNXiLjRxUo08vTdmmsHg+Z6Lf/ AIT3e7s29dW9e36c6F/wWH/Zc8RR2l14X8ReHPEU93p1vqP9n6Xq/iaXUrdLiK3fF3pq+CJd RhDLPLJIs1nay2ckAguQruUKn/gsP+zfNqEuk/2p4cl1KIbV03T/ABZql5qUdyZ3tvLurC38 CXd3byCdBBLYTRQXiz4hLRy5VvzW+Fv7JHwI8GeBP2J/F3h/4WaHBrnxDu/GOmeOr/7RezSe Jw/w28feJJYNUiudREKWuleINDtW0VNOS0WytraC0iVrItHXjHwo/Y/0rxbqsmqDw78MtFu7 P48tqup6rK3iRvEeqM9zp1xP4UnvI9O1m3/4Rh5PMubXR7drKxjvpL2V7iNJLcnaj9Hnwlaq c+W8USfu8vPWrRa3vbkz/W/W+v3nLDiTjiMmpywlrq18Phrba/8AMBbt+uh+0Opf8FdPgrok ct1qujWloLNIWuLy41TxdY6SEuLmKC3ZGuPAEhVZbi4gs2gOpzXD3DSzJJFCVggoTf8ABab9 nrTNNt9cv4PDttoF1NJax6y/jzUbewnvUkmjaztzN8PZXE0M9vdwtbGaa4X7JOZCfImI8g/a g/ZM+Bz/AAqvn0zwJ4U0HVbbXfDuqaampJqradqt3ouox6xFomuSaVHqd/PpOo/2e32vTY5r fTbqJEjuZYZZZmf4dfwb8DPEnw++HHheP4JfArTdSl8YeM9E1zU/Efg7xBe+Dhq/hm58aRXU 2naZY3WuXon1C70bUJLS+l8OF2iluHunsJ7whuWp9Hvwlg3zZZxHy219pisWoJWS99xz9yjB R1k4ptJOy0NXxNxo3Hllg7tq1sNhVrdNP/cLb73v26M/ViH/AILW/BWHTrDU5/D+hQWOpTix s7qXx1qsVhc6i8FtcQ2aXsvw9EJnkhm8zyhMj+SRL8qguHaV/wAF0vgDcJpi2Vh4HuG1u4Nr octv8VJZhqFwbn7DciK3XwM8rvZTOhiiLxG8nJt4zIflX8UfAvwN+DnjPwh8H4Lvw4NT024/ bZsPD1wIbm/s7SXRDpngpIdNS0aW0H/CPtBfXgayktVuRHLHGYF2tGv3H41/Yl/Ze8L+Df25 tW0L4HeC9K1P4WaP4M8SfDhrGC6K+B57r4d6XqepTeFFur+SPRGvdS0+51SeOyNvv1Wa41EF Lu5ac8c/o9eDUlrlmPl5Sx+aS7dHnDvfrsaf6zcd/wA2D/8ACfDf/MHn+fZn6D33/Bcj4X+F vJttX8JeE7O4khhltLW++Js1lcajaToXh1GOxk8CfbhBcrFLNFLH/o+yIoCxVnbun/4LLaNZ 6MdePwl0250oQTaob2Dx3qkNrNo1uk1zHeW12/gK6hmS7sBHdeZCJiu7ckW3MVfhtY/Az4Oz 678P9V+I1p4T0TTvEf7P/wAKdf0zUvE+h3XixpW1Dwd4YNyIo7fwv42u7K/udci8Qu0rWsA8 gXubtY9QVb39zf2dv2Jv2b/EnwF8D2134NtfGlrceA2sl1jVtR1rGsowlsrOU28g0lkge0Ro Jkn0mwfy1iU26/PXm1fo4eDE5OSyGdSNkr1Mzzum9ElZxpZvypLo73et9hPiPi6S/fyo8/aF KjGNtLOywsVe2+n5NnCfDn/gvV4R+JfgnTvHeg/CLQ4NIv76PTHF58SdViNvfvr8mhW8O3Uf hxo94xvbg20cYezVS8qiKQhvMrqb/wD4Lo+A9Ila11PwB4OsZ7e+Nlf+b8VJVWyka0e8iFx/ xRLrbu6NbKI5pQx8+Jgcyxqfzg+AH7Pn7OR/Y5v/AApD4GsbT4q/Df45fCv/AISqKzGoWVwu jeIfjR8NPENham9tJovDuoLceG5dY82O1l3Jb3TWdw32yTYvrXiL9ib4Ha/8AP2nvEo+Eemz +NbL4v8AhGTw/qNxqlybqLQNQ8IfAW4NvYSya09vZO6a3qc09u7WkOJ9Q2AzTxrcYf8AEung pS96XDzS0V6eaZ7z9H9rOIrXrd/J2sQ8/wCJuio9Lfu6Pl3w1/XXvvqj7S0X/gt34e8SXGqW eh/C/wAL3U+kxR3NyT8UJiDZbXE96iP4KtA9vDJ5QLwyzLtmi+fEiO8eg/8ABbrQvE2oJpel fC/QvtVxLPBpQuPGetxDxALeGS5lm0r7V4IsUuoxaotxus5buPy7iEq7B4/N+a2/YW+HB8Ve GtE8C/Dex0e/8Z/suajHHPp+rRWYbx9f+FvgdFaT6lLdXrg3aa/rOuTRX0cN1ZxF76WSfy5r b7TxH7LH7Mn7E/i34g/CXQ9ds/jnd/EbwPbx6TqmlrrXh3S/B2ma3a+F7iHxE+snRFsbrW7S 5uNK1C3sp7KfVpydOjaTyYbhJbzkq+A/glT0fDmJklprmGbyVtO+dtK63v8A8PKz7ia+iorv +6pJbJaL6t+LStv0ufoUP+CsHiItsT4NaBKp+5Oni/VCpOOf3S6EzcEMpG8E4yCARXCePP8A gr98SfCvhvxH4h0z4G+Eb+PQdE1nVvs9x4m1uHdHpmnXF9vln+xr8m63KOEgJxJuCnZhvof9 nb9kP9mz46+AYfHSfDTxV4atZdc1XRBb6l4qubXUDPpkcNw1xFb6L4p8R6alrJFK0aFrlbh5 45DLbRxsksve/GP/AIJufs8XXwi+J0Xhzwtrdxr7/DnxxBo1tf8Ai/VFt7nXn8NanHpUNwxl igktbi+CrMl7Mto0L/6VtUEq4+AXhI+SVPguhKnJRlByzLPOecZJOMpxjmrinKNnKzaTbSb0 v3f2tn3s4SnUppyjFytGKtJpNrSgurfy6aHwL4y/4LT/ABH8DeGtD8Ua58E/Ahs9V1rwxpc4 g8QeJWFuPE/iHwz4etnhitItSutQYXXiJDELWELKYkDGOORpY9uw/wCC1ur32l6vqB+FvhSz n0Ke2g1LTLy98Z217Eby50e3t5fJu9ItbnypDrunENHaToRIf3yASNb+g/E7/gmd4K179mn4 QXumeBr+/wDHMR/Z9vfFWn6j4q0qe2h1O08dfCfUfE7Il9O+kvLaRR61PE1jcywyz21uLV7h ltQ/h/7SH/BMK7sfj/8AHW1+Ffgi/l+H03wP8N6l4KMnjjRtPW8+Idr4q+HbXi6hYyX+mShk 0qw1fyLi5sYbJmt7BWvC4QH0n4C+EcYRUOB8GpNNzazHOrvayb/tO+mttfubZyyzbiB2arJf +ALt0VKx1Nn/AMFqvEGreJpvC2i/DLwhqmo2OnWGqazHZDx3ctodtqmmWep6dHfvFYtbiS9S +iS2Z5oXdYZ/9HaQSC27Pxb/AMFa/ib4a0+O8s/gr4W8QXk1zNaRaTZ6l4mhuA6QNLHdyzxW 9+Fs2lVbZ0a3h2vIrm9XARvlb4mf8E5fGul+GvCJ+DHwr8S+GvjprfhL4eQ6t43PxB8DxeC9 WvbPwHoNx4us/F1ld+L7271aKxljvtN8OSw+FbxrPVIo5rS6j0uaXUZ/rz9sj/gl14kfwD8N b74GP4rn1ew16O6+Ldlp3j7QNE1HUtBXRWm1fS9G1TWLHRWs/tV1DdRWtxout6PqVrO9rcWm qWJjF3Bk/Azwng7PgvDRStdrM88skrXdlmmtk9nv10uaxzPPOVv2tNtJ292GrS0/5c73/wCD c8s03/gtX4rvtBXVZfh78OLS5i8V6T4S1CxmvfFiPYavrWo+HLTS9PnlmlhBu9Tj8T6RJaoI EU/2haLuZnLjnZP+C3nxNvfF/i/wd4a+CXgzW9S8CHS38UtHP43SHTbfXLaO40pzdNbJYTPc PLHCiWd7euB5nnJG8b+XyPgH/gj/APFWb4dfGGPxB4Jk8O+LH+Lfwb8Y/DrQLr4k6Brgk0/R tW+GbeItS8SalPqHitTqMB8IX9zpdvD4gEJtLTSYvI+0PNbV7x8Af+CQ3ifRfjD8efEXxCs7 Sx8PeNvDvwhn8P3dt4r0a8a+1/SPDNvF4tttVtrTw/e3Mdla6vcXosVeARSSwWU0EssMQlLj 4J+CqmnLhnBtXV743Nn+eY6W+9Hn/wBscUWa9pCyW3LCz2/6cf8ABvv3ORf/AILV+Jhqvw50 lfC/wrK/EzwwviPQr4f8Jg6O0tz4atodFikXUfsj6tcDxPZzW0N09neSCKVl0eaITmz871n/ AILifGuRvDWl+Dvgz8MvEvi3xnea1Y+H9Dh1HxRaWcw0SDTbi6uBf3N6bU5t7y/dJLnU7S2+ 0aa1vGLiZZ7esXUv+CHXxvmuPjAmn3ujqvhNtRv/ANmi6m8fWEFz4Zls38WDQrSFrTwlGLLT 7cWPw+key1OJoDJYRmRX+yyqm7e/8EXPjv4U8G/CLxj4DHh6++Jnw9i8eXGpaFq3jTR5tNnG t6zJBZqby48MWk1zKugTXt1ayQeJLVoL5YIbqY28UVmvTLwY8E4NNcJ5dUVlrPEZlK7stG5Y 9vTRa+hDzbipySjUtF2vZRWvXah3srvut0UPHP8AwW9+P3gL4Rax8Rr74L/Du+8V+F/E1t4R 8SfD1bjxMgsNRuJrVnkbVLO4vJnkhtNRsLmJ7aO4sbq0mimidlmFwMHVP+Cx37clj41+HegS fAn4T2lj4wic6rBNqE327SIlvvB1rPex3L+KBETZx69dP9lntN87NCygrbyh+71D/gjL8d/i L8C/G0fiu+8JaN8SviD42tvEd3p1v40UaHYw2L+HLKF2kh8I63HBqH9meHFt5/s15fxSyvI/ nMbh5V9S+Nf/AASa+Ot8ngTX/h5f+Bj4j8NXUy6k2t+JmVJLG7i0q9mtnlHhAyTE3uh2iRGC 5jZLaNlMwco65z8KPBKK5FwXlDemjnjWnbl3vjX5vVW+7W4Y3iuVp/WnbtzaO66r2Olr9tD5 ouf+CyP7aun6p8S5rn4S/DGbwZ8NvEfhDTdZ8QKs6XiaR4j0TwrqmpalHax65LKx0Ya5eSiO 303U2uVtNhCM22PS8Qf8Fnv2kbay1zUPDnhX4fapLY+FvC/iTR7CXQtYMeqWOvv4TV7iRlub a48yFfENyxEUkIDWeHsof3qp7vqH/BIP42Xui/FvTEvvCRT4mWdm1rFN4wZBb3dh4fg0NzeC DwoIiW/s60ltJZxqslvJiWOS12JFD5hbf8EXf2hbGe1l+1eEpbaL4e6F4Nmtx46Vo5LvR73S pluhG/heMNF9m0qKNZmdZC4VfssaYZJ/4hJ4Lpcy4Lyaz10njbdNv9r8vzvoafX+Kr/x/ndW /wDTJy3hn/grv+1u2o3KeP8AQfhzodld+DJvG+if2Z4bunmubezt9EvLrTSV1bWmZY4PENlF JI8EN4Jo12w72mgj4Hwf/wAFkv2v9a1bwRZmH4f+Kbf4gaVca1/xTvw51axXwXLJobatpeg6 nfnUdbtbiS/vXj0qC41EaPcSNBMUiaaVVt/pK7/4JKfHac+EGuNN0C5bw/4VfwteyL420921 C2urfwxFfq4utPCzLM3h1QrMlp8rAGIK5EXm3hH/AIJSftR+A9QtIYtC8C2fhbRUs7Sxm0/W /Bb+IGsrBJ7Ozlvb2XQUle/hgFlJHLbzRo12108+6N9pl+Fng1HX/UzIJRsmlOOJemjWrrtt rq2279XrdfX+Kv8An++ut10/7g/11PM/Cv8AwVq/bW1zwB4h1m/8TfDaz+JUOg67eWfwug+G 1rZ6xpU9hKiWWpFNQ1m5v9WtZLCMao1qlogmF6IY7hRasG9h+CX/AAUy/af8baZPD4g+Jfg7 VvFNlpuh6hregaZ8N9I0XUdBu72K5kvtLvLOY307RxztHYi4MMTO1qlxE4W7Ct53B/wS7/aG s/F+oeNtQtNLOrf2BfaNp8ml+IPAVnBuubEwW8mo2UHh+ytb7ZLLMsovFvIXtltkkt5vs8SR 3fhz+wD8XPhn4i8XeLdR0trvxF4sgt7TUp4vEng+OwhNg8nkNaadpVto1nbv5KwedKLaZ5ZY 3lYmWaeSfnn4aeD8bfVuDOF4S2m6uFlV5lpolV9sk76t2i33ew45hxFzWxOIqKL+D2c3BuWm j5acNN+r+W5oeB/+CkP7ZvxD8TfEG4g+I3hzQdG8AeNtZ8MxaHB8OPCN2dXttHu7x2e8vdQt F1CGa/tVgsrWWzEcUdzG8yC+fzLZfM/B/wDwU+/bd8Y3el6rb+KoLy1uvFFjo2paPafCrw6d ItdHkitY9Uu31geGxPaXNhazy61JLcamYViiEDW3lyow6rVP2PPGGh63d61oCax4Tj1jUBq/ ibTtF8ReHEstdvzfy3V/dXcVzb6jMZ7hLmWBpbe7tHaMxgOjxrMvM2f7N7+GdWhvdIfXfDun tdR3l34c0nW9LXR7i5FuttvFvNBdTgXqWtpFfINQijuIftETqIp5Ek7MD4ceEyu58F8GTle0 HLK6E2pWTi0p0HF6rRSvF7NWuOpmObx5f9pxS13VaouzWt153X67RWv7cP7ZnjLxf8WrHU/j Bp9po/hbUNGj8P6Novw1+HiX9rFqVzOv+majf6Pq7XRe3tFnjMljAWSSUqPlRo+Cm/bt/ay0 zwP8NdVt/iJY6pceJ/GfhbSfFr3Hg3wAq2em6ppENzq6RrZ6DbJBcI7SHcqtJGMCONQMH1HS /hJpGja14n1jT9LnXWfEk1iNcEt5bzwXP9niZbSQ20rtZwzQI2xGtFRSss+4MWUjiNN+AngK 1trvSEs9YvrWHV/7fh0+78QandW2k6tbRva2zaf9qulNtZxxtJCbSGR4Ujht/KjXDs/U/Djw 5dr8G8Ju9t+Hcofbf/Y+n+fYazbNle2Lxff+PU/+S2/z3Gaj+0x+0Np2mfF69l+Iz3l34Kuv D15pqXXgzwVEsNlcaLo2obJUtfD9sZVuL3+0QJJDJJGAAAI0RW4zwf8AtLfGH4neLdSi8ffE W20XTNL8L+GNY8PPH4f8G6RHe3Oq6Jow1plu7/RnS7+zT3CKIYsGP7QTs2Rgx+zz/D3w3qcP iR59JMsPiZLS28SrHdzpHeQwWyWFrGySXIO6G2/492QHy5mMjMMDbyms/BfwBfWWmWy+HpbI 6TB9jtrjTNX1TSLyWxSO3t4IL670zUrae9Vbe1tf3c7yRrNErooKgjWlwH4c4f8Adf6m8JWk 1U04cye12ox1/wBk6qPy26WMamY5rUkn9ex0NFG0MVWgt92lNK7btfeyS6I+Wfjh+0z8UdE8 Zrd+DruDUW0XVbObV9f1KbwnpcE9pJquvyXem2Wlarodo17DIdHhvUvtKmvZdkotopWMkbSe i6h8U/E9v8QfGM8XiKGLX7nwRpN94StLmDQjLPqJsvG1hc2dpbf2fAdRNx/Z9qvlsHkglusq SrRLXqOsfB/4Y61dRz6n4S06+aONYSJjdSJNHFJI9p9pjkn2XF6pnvfPuJVfeLjb5zhnAs3f gPwY+tadrV94csf7d0oRC0vmjLXNvbJLLO0f7uRre6j2z3JjgvUuYkeabbHGJpC6xHA/hzSh KrDgzhJyim4/8Y3k/knf/ZLaJv03YQx2cc0V/aWYbr/mMxKVtP8Ap5e1rr9O/wBT/sG6r431 fx38MfGGq+NPh94SYweN4PEmm3mqeEL3xRrN2uneK7WV7jwq/jCz8RaVMdSazuEWw8OW9vHp WkxTtFLa3l1qs39PHgy3ihvNfkhEoWaSw/1oIBEYvFXbujQ9Cc9e3Tv+ZX7D/wCz18CNW+GX gn4o/wDCufDzeNnfXLa48QSWkom+1SC6tLicacZG0fdc6dM0U8i6eS9xcXFwEWZzOP1O8Pwe S18+MCUwFfu5wpnwTtA6hgQCSQDggHIr4vh/IuGcL4i5JicpyXKcurUJZq4SwGXYPBuKnlGY UZJPDUqdk4TlHzi7Pex9O8TiZ5ZUhXxFatKSpfxa06jdqlF688nfVX/E6Siiiv6IPGP4sfhr qmm+DfCPxq+NXjqfxZ40uX8f+JdG8M2SeJNfgew0+TTL7xZHp9kX1xdPsLVpLOCKRNOspPIP 2Ty0lgjiiXl/CjXc2o/F/TmsbHTfDcfwi1K+u/C/hrxXq/iXS4rj/hEvik8Ul5d3WmaFJ9ou bnT7W5ljuLXalukG1riNREf1Ng+FHgGTwxqfhOfSZYfD+rtNPfWsmpaoDNc3Onyaa0cF19rj uYybKa4jVUmfBKyY8xQ5reFPgv8ACzwPpuo2XhfQ2srLWbaaz1WzudY1y+NxBNFeWjRvPPqA mtImt9RutrxNDIDI8gnxHF5OeXypunVniP3lSdFU/aTSbi483vK9278yaV18OrelvoauFnUp 8kJOnZ3dm2nt5x+/XXQ/Hf4i6Xqsn7Pfwh8AfDXVLbw1beLfE974h8Y6nFr2o6RpN1vm+J2o S+G9Rv8ATIb+4tNQt9R0nwxfzRxNbPLc6XFHPAqTSPN+Uvjb9kX9oLwv4e01T49B8KeMfihp tg1v4Yn8Xa5pPhzw5qtz4tmv7X7fc6ZpkZsGtbsNNKjaejPYuC6LGJo/60Lr9n/4SXPh+68M T+G1XQ9R1SfXrqz/ALc8ReVLfXl017K8V6utC5jBum80RC8ZF2NEIwh2ppf8Kb+F8Pgm08BQ aEj+GLGG4httHfV9fBt1uVvgT/an9rLeTblv7sDfdOQJwcgwoV97KuJsRlcKtLDuNSE8Q6is +Wz5KVO2ile6pp3ul0tZa/PZ3wpgc59lVxk6vtaVGNBOLetOM5TWnOteac1q7tNa6H8uvwZ/ 4J+a/N8XfiHb+Bbjww2habZeAbUx6NB4i1DQ4NRudP8AFN1egy21lc21hLNb3dmZoI490jbJ 5E3TCRvP/wBo79inxVceIPG2l6zrXgjRbrwRBoJb7ZqGv2mtX1ldtoZhh0HTZNHs5bZzceKh cvqNveQXU2lWerW7O9lcT2sn9XPhfwT4M+H0F1pvgzT7TT4bsoblE1LU9RcSATHdGNQ1S+kB MV1IdoLLliQPlATA134SfD7xTrreJ9c0RLjXvs8dr9sGsavbSm2hQxI5sLfU4bcAh5Iy/wBk Ay33twUj1P8AXvOXVg1TtFNOSlUlKL0WjXs0n37XufP0fD/IadOpCUKlVyjy3lJaO8fstu+i 226n8snjr/gnp4w0fQPhv4x1b4xeAfE2p6foWgweIfBut2V3HqWq2mr+H9C1iTTtINydUuYN XnttDTTHuLbTNP1Bru/hnS5MpPm/V3x3/wCCfGveFPhklze+LNFvf+Eju9LsmE3hW++x6Dae Ktd8K6BPqGuWV1dS2N5Z+HYtWl1e7XUIfISDTrsmSzy9zH++N98HfAN7qdnrlx4fDatavG9t eDVdaV2eL7IYma2XVFtjg2VocG3AbZyCHcP1et+H9P8AE2ny6VqkP26yuozDJCs0tniN2jcr 58M0TDmNCG3g/JjPzGnW42zupOMoVKNLl6KmpX2t1j27HRS4H4ahHllgYVdd24RvqtLOnL0u r7I/m/8A2QP+Catrb+MfHFm3xV8LeKLTTp7s2eueH/Ds+naLcedongKV7HTbbRPEI0yP7PLe 3Ulz9nYM92l480XmmSWr3h39gf4BRfHj49WPxsfQdUgtNT8PL4Mm8XaZdMl67Wl21+dFfXvG VmftDxnSkEmnyXkyq0GHiBiEv9E+h+CdJ8MWy2mk6e9nAXlRkN9LeY80+e8m+WaVss8aJjdt XHABJzXufAnhW+uLTUr/AE8TXtrfxfZ7g6hewGB0kOy5EEd2kUzR/ZIG8t42jfGGUhyDzPif Oa9WrVeI5XJ8z5VLVuyWilZdtV+Z6sOGcmhSp0aWAwEadOKUIzwOGqzUVradTki5/wCJpdNE z8ErP9g/4Jf8Ip+0p4ni8AG6vfCXi6PWNPiI8VzNKfDfiS91u5gsbVvEctqvnQWgjSPyJIU3 R+bGIUArrvCP7Hnwi8dfCnTPi5qfwo0mx1/4hfGvwDYQabrWgXyeItE0TSvFfgzQbjfIblJF 0+dvCd9eGytoLaxni1OR7iQyTXjS/u6NNsI7dlSBWhcFZ4UmlJIwqgtJ5rtF1PZfuH3Ikt9J 06OGG1VHUZPlhHlk2uZHkcowL+YjReYCcsquzKGDoEExzjNcXButjG4X92EouSUkkuZOVTVp OS0Sa5nrtfejw5lEJOTy/LmuVrTAYaN9U9Hyvtt+J+Wn7N/7JPwfg+L/AMdnuPht4Ts47SDw dp1pevp1zazyfY4LqzEtvzEIj5FoYpYIblxKk/mTvJJCu/4b+KHgyw8beNL7T3+FFv4Xi0b9 oOPwbaeDrD4b6RqV1qHhKw1bW4LXx9q+pnStE1m10u5W5bSzdyWmsQGSG5uD4guLqMxH+kuy tbGF0EdxDZSLujE7sZMDDbxLHLMER2KABSIyCSACRgYraXpZuHuBGYZA6r55lmYPIryOzeWz hQsLMHOBtPmhS2AKcMRjFJXxELf9eV5dfaaevquxvHJMmb/5FmA0drrCYb7/AOF/Vj8mPij8 G/C2p+Nfi7JY/C/SEtdT03wRpdtpS+HhdzMk2ufCyO6nnQ6eWuINq3bSBvOCxqBlVjHlekeL PDfhj4SWv7OviO5+HUNx4Y0XRNT0W803w74Q062l07Vr3wPZQW13qEggs4jbxTW2rWQ/tC5D x3eoRRRQGZ2EX6VtpqZaONWWCBfNQlslmXDEZJDHLOegPTAFMGkQyjzhHK8knDKCw2bCVGQP 7wXPboSMjNZ1bU3aM67ut1iJq23a99PPf1063lsKausTiJa/8/Zrtp8b9fO19z89LXw54a+K Pxn+F3irTfhtc6D4f0Pwh4s1Rf7V8KW9vt1K/wDFfwq1GDULVrVXtJmNlZnyria6jb/RnMKi JppB4P8AHvTvG/iD4g+OvCd14e8brFe6x8KovCNlouna1YeErPSjP4cu9b1DWrzSE0z+0Hgv 49XvNS0+90fWbO306ztPP1FLbU7200z9lU02UIEW2lKOAGzu6MMYzkYJGeadHorRnC20iBuC SxbHGM53Y745qlSjZOc6tRtXXtKkpuKVrq8m3rvpb8jGeChJp81eSjZWdaduj87emt1fe1j8 6fg/8NtZ0n496f4juLK/02DT/wBn7wl4RttVTTL+KFNQstO8HG9lWWQW1qbK5mh1KGDdK0rv LEWt4nJSDvf2YdRk/wCEUv8A4fav4K8TeG9R8JX+sw3Gp61Z3qafrUmteK/E15Bd6JHqAt3u xbwSpJOzRw7zdQncyTCQ/bj6NbrEy3F4waRtsdiklssxYkSF0XbJcMu1ZHJ2sow3zALgaR8O xNNFJcSXDBJFkuJGMQSGB2WRnxHGvzJGARksSFbKE5A2lhqUqUuZXvG3K3e60et9H93ctUoQ jyqnW1sk/rEvJW5XDVdLJpK9z8XvHfgP4neNPGOt6Dq3hPxtreoXPjn4V6z4d8SxT+NX8G+E vCej6l4L1PX9IOmWenxaFf6hrc2geKVN5d2CTG81bTreW/CadbPY/QPhn4UeKdCvPizqq6QV udZ07wfp+gJY6fqKa3Jaab4d+DunX8JcadFctEupeHNemmgt7i8SFo2SUrJBcJbfpXa6NaPG 1xEtwUV4SEl3K64kxNPhkhcrGg3kGMriE84ZjUjWsMLSNH8xZioJY/MNwOcZ4JC56Yxx15r0 YYXDxwiUYxTsv5b3slbSz+7W5xVcHKUuZc620U5aOyfRLfvbvr2/IzwF8LfiT8A5/DOqaZ4C Tx0fEnwd0f4fS6ZoUev203gHxJo3h7wHplnqd/bR+EdVjXR7O60zVUms7iLTVRbe3imsJWV4 7H6f+AXwp8Y+D/gba+EvEQt18VvpaG5vLe31D7CNZuvCOg6W13Fa3enWBg26tYSzQeTp8Jix D5EMU0KxR/ZDPZ6ZLp0M15Z2lxfTBYo7i6gjuJZFliAW1glnDTsGuEDCOKTa7wowBlRX1oY7 RVIF9HNHLPIPMlUROhURmUqgaIyGNGWQqEPOFxztrgw+Ap1V71atBK9lGpOMFr0ipJK/W27u /TNU4wm251E9LxU5O2i2d0tdXtp5n4sfCP8AZL+Nun6v8JbjxbYeHdQ8VfDTxxqHifU/iNqm r+M9Zv8AxRDceHfF2mabpljb654HSBorT/hLtNs3SbUJLYR6FfsttLM5hPudn+zr8Q9a+NUf jaLwr4W+G0eg+IXvvGfizw3feIob34tW8mvaNfWlhqmn2ngnwppMcdrpui6hBdxvq2sRR3V4 YzFMrz3NfpaILdXJglQFRnMSSzB8YJV/3koRTwrNlNoAOQTkyOJViWUIgAEswCXEKqZLdsIS khkkUybmZ0ZvvEhVVQEXp9gsPNujWqKTjZzlUlNOLabXLzJJtpa30V0lrdTKjCs7TlWqRWqi 6s1azsnd812k3FadfJI/Nz9p39lX4kfF/wCIXw78YaF4p8Mv4Z8K6Dr2k6v4E8Z2V6mja5J4 sE2n2OriOLSfEOn3U3h55odaYXmlM63GkacYru3d0vbDs/2e/wBnfVv2d/2av+FYa1relazd eHrPx/fS3nh/SH03Tpv7b/tvU4ILZX+zz28yC/TfbKix30waOQmO8levuSXT/KkCpas0IMls 85nG1YI/kGSCFBlSRlzwcsCh3AU2KyiljZJPJict5MkEUpPmJJsAIle4lVfmkQnHQJyVBYiZ fW5X5cY46dIN2+6qt/8AhvJfUqO/sqttNPbNbWv9jW/+Z+MPwt/Zd+MHxV0fxNpmufErT4Pg 9rnxd+JXiKXwf4g0m8srqW2074g/FSHSLCDW4LddTt4odZ1S21gTWWsxRrb2NrpQgnsLzZb+ 5fFr9hf4oeMNU+KGl/D/AOONl8PfAnxP8MX+m+JdCg8N3eq3cV29z4yt9Rjk1F9Sh1C3a70f xpDZyWNlqWmrbS6Ms8aefOlxafpdBZJpccvkRsgV2+SSTKOssryPIsrcNmRw3yOVHmbQAoAF sQr5kaLjZHi8VpcySfuioiCLC8GxXDOfPlSaJWQBlOcGJ0Yz154qVleXKtWkru3N116vezbs S6NF6ONTTT+LLTb+7pt/Wlvza8dfsReN9V8eQ+OfAfxdh8Ga5D4Jm8AXH2bwzdXNpe6HqV9q l5qBDDWBaRTytq6IHTS2vU+xK0epQhlSH1nwn+y9H4T074To/iKC7174bnxrqWq64umXaDxX rnjQ3ia7dLJLqsrWU0Wo63qE86Mt2HcywrFZjCxfXXh3xj4O8ax3+oeD9d0zxBptveCym1XT p2v4HuI7bT5ri1K2xiCSW0N5DcvtyzoghBDzqyeV3f7R/wAEdN8QfETwxfePtKg1L4UT6DD4 x0+O21e+l0a88WjztJhu7Gy06S+he/Uz3EYju71Y/LdZRAgCK1Sha03GburNx2Wl9Ly/RfiE aVKKaUbt7OcuZq1k7XXVb2tq7nynqf7D95Y6HokPgj4l3XgzxfoGteINWtfF2l+HNQ1K6l0n VLTwyl1o0tjP4rt4pbRtT8NaNqaXtzJcmaS2MP2eFTO1z9JWfwIlb4Xaz8M/F3iGXxsuuaPr +jeIdS1G31CW61PTfEKXluYSk2qXV6yixum06JU1G3aNrYyWssUzHy/dbS7ja2S/s5zewlE+ zNDLbxRNZSRiaKQeZBLII40SM+RIxu2Wcb5tyEtol40wpnWUEBEeSWG2W7juWaCaBVdVYnbv hVoXEkckgkYsDGgxnhqcle0NnePJF30Xu3vfXbRPd3WjE4apxcY2adnBOLemjTaTT6rrex8M /Cz9irwv8MfG2heOrnXNW1K08HaVq3h7w/4alfxVZRad4Y1KTUm0/RtOsbjxjd6cLbS59cml GpmxN9I6XVmHSEk16Nafsw+EdMs/h1AXtQfhzeahqGlSIdWthJd6jrNjr109vCur7LcSX1ij tC7XUKMUWOJIk8o/UVvBBJOsMl0tlFdB0S9EbXMNikJYrYs4fyJZM2vMkrrL+9Hy8JuyUvYr mOURyQw3ckSylJLiJC1vIhMkcJmMccRjL26bphPIvyl1JEu7GODou16UFstYRfbukvnfv5Wq 0uscO/XDQ1Vlpvt19Xfc+ZPHf7M2heKfG1r4ztta1HQ9Qli0u11qz0O+8SW9v4gh0OZ57KK/ TS/Euk2kzwW13NBAZtOuJFExBYrtrpvDfwN8KeD77X7/AEyyjjvPFps7vWJvsV1eX11e2Wl+ HNBW6vZL7UriWZ/sHhHTLaRi67XhjDiSZZZpvXPF/jbSPDmgaz4ts7e61OytJtJSztNNhv8A Urh4b6/sNInCJp2m6hdzeRc3FzdXMosHW3tQXlFvbwSXtfOc37TtnJq3jvTtJ8Ga3rOoeDbH w/O+nada+I7vUro+IdM8CeIXUada+Ebm9MtpD45T7RHbw3D26WsjXUVo0V3HZ6LDYaLcHRpy t9rlhronb4Xtfu9g5ox0bhFrpFRgl6RWi7vu9epj+E/2Ovhl4V1/R9Zg03fceFpDc+E7fUZP ER07QbH+0tP1WOw0KyvvEd/p9qqNp2jRhLawij22EIx5X7t+usv2fvhxp/hDxZ4AsvD1rbaB 411S91LX7FrC508Nrd0LIXV6rQ6pLeCQvYWBWa3utPcPaJthiKkn0Xw78bfhv4q8S6h4ItvF 2gjxx4b07Rr/AF7w1PfZ1rRW1+zsb+GwurIxaezyKbu2hjVIjc/LEkqCeV93TQeI/CGoXBsb DxT4cv8AUnjbbptjrGn3F5DcskpMLwRXs0zTwNC5lBjjXEL5hjVZK6IYXCWu6ENf5VGL6K3M o39VbV9iGqc7xqyjOD15U1B3WqfN723XT5o88h+DXh2LwbL4Bubez1Xw3qMOoWl/Yaqb3U4r 2DUPtMlza3c2pXd9eGCYOYwpunC5URIgIA5Hwt+y78JvB2qW+teHvBOgafqWjI8ljqMD6nOz IL211KTRNKiurqa3s0W8sbOE29mFTzNMtkNsogSGL27/AITb4etdmOHxb4QttRuHjtLbSH8U aVPfFJBG8IhjOoRyyXFxdgC3je3kaVpUhjil8yMHUOr6Utzp9n9vtY766aSaG1mvLdbq4g8+ 3D3FtCwjaW3Zry0Z5UjljjN3ZqZFE8fmjwmG0tCS/wC4j6W8vv8AXSxlLC4OWqjJJdfbJ9t3 yr+n9/jvg34GfDn4fXer6p4K8O6Ho1/4g1Maprb6fJdqdY1XfM895LbvcTwC9uPts4kEMSkG WMZYJF5dnWvgH8PfFOut4w1fwr4d1PxPc6fPoU2pTW0st3daVJZXVq+l3ioyx3EEkU7qYZoZ t0RiHQRiPuda8e/Dvw3d2mgeIfGnhHw9qOsrbR2Ojav4m0mw1jVAbn7NbLbaTeXsOp3lwt2T C6WEEZ8/MTwRlSlN1n4q/Drw94ktvBuv/EXwdYeLb6S2+zeHdQ8RaHYa9dvqELx2b2mmSXCX MoljBa3VLaUXDxOilmJVSVNRSsoNWtrTjfRLd6t+v36lqnBJJVJ2Sskqr2VvP+r+hm2Pww8P adYaFYJouix6f4UM0vhuybSoEs/Dk81vc6bqElirIyW73cWoXds5EalkuZUO1nxXPf8ACifh u3iBvFx+H/g//hJRMLtNWOg2jXpuY71tTW5a6NqHe+a/f7T5rI0pmDSGYkkV1OufGn4PeCpr ez8XfFDwN4euo2kljsdQ8TaRFrF1JdxJeRmbSvtT34hWyvUukmhsYIjBNazPIY54jLbu/i18 PLKw0HU5/F3hiHTvE9/aad4avU8Q6c9vretX8MVxYWNgQ8xnmv4J4JoIkIJQptbMmTklGbvK jQny7KdCnU37cytHZX7pa2SInTopxcuea109q12Vnvprfp16DtZ8C6B4q0xtD8S6FY+J9EFw l3NpGtael5ZzPbAzW0k2nTi5tneO7MZivZA8yEpAv7tUSoP+FWfDRdDtNF1LwB4TvfDFnIjW XhWTQdOttO051+0HzIIUt9tuPOmeUzRwo8kk21x/pMhrzvwD+0NpH/Cq77x38WPEngXwpZ22 vT6Bb/2RrlhdadJe3gsILTS7S4t9U8QS6pq+o29/eltLsZJtRjs5Hvo7eCGye5Ttp/2i/gnp vhTRPFt58Q9DtfDviKaXSdLn26hdXF5fWD3Ql0+y022s21e8Mf8AZGoXN75ViZbI6aHnuILc TR3UVHQen1PCptaSjQpRafSUXGmmpJ6prVaNO9rTajKUUoTT5o2ftW7O61Xuq+vy2aO+0jwL 4U02BYovC+iQxWmox3sEVhodjDGuroiLHdWkcUMCRzosAVbiIJMF8hRHhECd3aaHpcSXyzaN YyDUCkepRwWUM0d+PKFvBHMrRRrf7I2VPKuECoCY1DBiT4XL+1f+zpo/hPTvFmrfFnwlbaJr muReELNBc3d7eah4+uNNj1JvBsOnWFrJrM2um0ljA0+2sIrrzZ0gEQupoIV9p0n4neDfE3hP UPiPot/Bqug6Da+I9WNzPZ61oazNo+kh9TsXttVgtNQg22+nR/vDaSS4u1mgSVHgVuScaaTf KvwV7Wvra/f5dEdPIv5p/wDgbOzt/A3hPVYbCLV/DXhnU7OyhU2ljqmhaXKliUSaK3IWa1mF tJbW1zJZx2ijyoopSyMpYJXtnhqysbLS9NtLK2061tbZFtbdIZxaJFH5zAJZ20MPlRKuz5Eh aMDEeNufl/In4gftza38Ff2c9Z+OniPRG8V3+u/G3xlpPhbw7HouvyaPpXw8tvGPinwd4Qkk u/Cfh6/1CeZdI8JW051PVriCS7m1NVurZJZrJpfTpf23ZPDH7Qb6Lq+q3t34C1r4aT+LfB3h O28BeJj4n1TV9OtfhNOtg0Vl4Vv/ABVAL2TxbqNt9rvdGtbXT5r+xiuLeaabToz5tdw5v91w tRWXv1MNSqzelrOcoN2XSN9L/JHI+kpfNt/jc/Wa10DSIpp7yKz0qO5vJYYr+C2s7W3a9EKL Fby3M0CRyYtYZS0WYX2rGwDKGZh21rDY2cC2zQ20lqwRZNP84rbvvjS5W4aIgpKY3EcPmvFv Lxj5wUVa+I9K/bU+EV38MdG+JHgh9R8fWF9c6va2mjeCvD3j3XwW0HV7eHVxfto/g3X9W0/y bXUH1B1vLexZrO1mubZ5LUPcQeG/tDf8FC7fwT8EvD/xc+F/g+bxRDrHjg+Ddf0m78MfEXUr PwlqkJ8Wy6vpupwWHhzTtctNdsL/AEKxt59N1NrO4t01VLmSzFvJaluKcnFt0cNgqUuk4YSj e2l17sYtJ9Xf5CcJNfG1569/U/VnyVUrJGluF8w2KK9zIFa3LGOSEuYn227G2jV1UMu0R5U7 FWtGxitZJfMgWKCZ2/dPcXDiW3OGb5GbzHcYbavKZcHgFia+d/E3jzVrz9n3xL8UI73Vfh5r knw217xbKL7w3canrPhwL4X1bV7m8n0TVNFtpBNplxBa3k9pqfh7NzN5MMdjDbvJZz/Oevft xx+FPGPwl+Hvg/wjqXxg8UeL/BXhfx1rmseHpNTtpfDVv4n+32qapf6TpfgfWbKaS5HhnxDq U1h9p0x7SLS50ksLKFoZZI9pVbvKnh5O/XCU/Lq7/wBdLon2cv8An7L8fL+9/Vz9KY9TnLzQ xNdQi4gRbWG5ytwbyW6gt/OlDNLI0nkeZGh3zOYFRFCoAselDfMPKBuoopldIJkneMCa4gby WiQOCWmlkRyqeWsnLDGdwrjs3EqLIkaNCts8YlV1MEBWeSYW0hD7pJJpcbHE0ZDXUUYRygWT 88P2if25fHPwG8V63YP8DtS1DwJ4bljXV/iHqfiK50a1GmQaLZavql/olhJ4NuP7QTTYP7UP k2T6/JINNtyGke6VLqfquGneUo4hSleUlDEzpwUpatQpxi4windRgtIq0VsjRxTSTctkm1Jq 7SSb369vP5n6kReIYYzFKEkMl3b+fFEkq7nmETy3ErKCMtKjRgFUfBjJG3Ga6GHWIjILcFGM tzsVop0KiM2ofajKobzBIpkwoU4yd/UV+N3jL9qmL4d/Evxf4tP9qeIbG3+EI+JdjoyJFZ6L JpGl23xa1+yubSa28EXuuahFqEWmstt5Gr3Eyrp9o32S7e5mj1D3L9mH9qb4jfHzQ9X8X+LP hLJ8NvBb22s3Om65d3t/dnWk0KbR7O4ilsr3StHv7GJ7oa1B9oNnAJTogt7VpLi+gmcWEwqv dYp/9zlRf+29TNUILrL5yv2/y/F+Vv0sg1SCOWUqly2GEUswYyWzGPcmFZpTGksTRmKbaiuZ vMErM4Ytag1Ozn3swj8uOQKBc+RCzjkn7MQZDNLtA2DcjEsDvXOa/Ibwb+2x8WviF8aPGPhD w18B7XUvgh4J8T+JvB1/8TLfXNSlS8u/DNxrmgC5j0x7G11C3QeMfC2o6FdpGb+CG6kiVrxY vs7XnjkP/BUX4yS6lJ44n+B2hr8B5fiW/wAOv+Fjx63qS77G0nGrr4khtW06W9EA8G3r66YT o8ts26KMX5mRrV854XDRacVib3VubFTkk01unG0l3Wl9uprCKh3a7N6f1p/Wt/3sUw7ZMtBx JGZpmlEvmQy+XGd88g3qWVZYFG4jgBXByEpy39nDHM5uILaKN2hSSe5RYgnnYDbJG8pE/dIi MCTL5kbkhmwfxN+Mv/BRD9orwP4r+Msngn4I+E/Evw2+B48Dan8Rdfl1S/tb1rPxPomk6yws xNemWBrW0eeNpdN0nxN9wPLBbygxNe+Ev7afxt+NHiHwH4e+J/wx0HwZ8OP2hPCPiHxV8LtV 0vUHuNYkXwX/AGDr32OeUyXX2w3Wk3huM6honhieOGBysF1Ksix4zo1JO6qwX/cFf/Jr/g3L vH+V/f8A8D+rvyt+0Gl6tp2r2sN7YXdhq9rK0Vxa3llfQ3drIZo0lRreS382DzVjeGVBCxzH cxsrKjIX0ROpSSbLjewSOM4jlmkUKFV2Vi7gu6KoJkO0lQmDtb+Yv9lD9uz9or4IfC34cHxF 8LvDTfA+0+MPhf4J3viy5e6XWbCG18O+Fi/iO9k068vGSG18I6XealdKfC9vYLd5Z9VhIi05 /rn4if8ABSD4s/D747eEfBN03wau/D2veLfCuhXnhnSbyLVvEujaZ4kbw1pr6vearpHjHW2h u7i71q/vbLT7vQrOQ6fo0LCGW3vxqLqVOvCLkqsZLa3sktdOvM9/TvZBeNrcrv35v0t/kfuC kvyqSEMhAzC0pLof4htKk/Lgj7qnrkDkVI8gjbIVWb7p2yEtjAx5g29ePlLZOM4IyQfxm/ZU +MPx78VftvfHHQPEev8Ahy4+HGoS6r4vsdOg8LWFtq9lomoeDvhfL4ZjtNTt9aN5cJCl7pq3 E95pN1cXQku2mt7Esn9nem/tKftG/tMeG/2iPBXwT+D9t4K0zRvF+m+I9Qg8SeIPDv8Abd2l 3p938I9OtUtLW88WeHbaX7Tf/EbU71PMkKiLT7W3KyxyPcjglWqzl7FRhCT1VVQUnFx95+7Z L3lHl1kmua+trOdbqzaXVXdn6rbfXb8j9URLsBUKuCC3zSsCDjp91iBxngjrnHqxpcgN8oHp 9oc888/dH0r+fH4W/tzftl+LPCfhv4u+OLrwNo3gvR/jD4b+GPjfwlZ+CrFjq1j4l8Q/DnR7 rXz4kTxDdahoc+k6d8RrO7htLXSbiC4OiR+bIRqFybZf2k/+Cg3xd+G2q6/4h8AfFjR/G3h7 SNc0jSdT+Gdt8Ipbvwl4dttS0G3voY9c+Ken2M7weIbKe+0O8l0y48QafdO2p2VtNo0C3CRy ZVMTWivZ88HZfFyJfgpXVtPtP8hqy89vzV/1X6H9BBkBwQwwc/dYODggYycf/WPHaoPOjaQo Ayvk4YsVUYznJDcZwQODkkCvwXP7Sv7YnxE+I/7XFloHxm0fwR4a+Bnhi58eeAtC0n4V+CNb u/Edo2gajrkej6xqfiBr67Gm30ttaH7dBbWd9DFfRhbhdo3+d/GL9t79qjxt42+H+g/DIa54 f/tP4MeEviKuk+C/AOleM59f8beLm8YXM6XNxrXgrxI6ado58IaPcw2Olf2Ybu0uNSEt2PNt 7ix4KuAqyXtHWd6i52uTT3rS0vU0Svppt8maqqkl7rdlb4rfglovLzP6LiEKlCYiT6ykkn6Y J6cVWdbVsI9uGKkgl0VkJHynaWJyD64GR1HOK/D74c/tU/tO33xS+BafF2LTvhnZeNPhf8SR 4n8PXmmeG7a0svE+i/8AC8tT8PbL2+t5dT0uS90nwdoF/wD6dqD6a4kkZoyt4kFeaXv7Xfxz 0nUtR+I2n+L7HxD4V+HHx017w18QLO00Pwld6anw3vvHfjfUp9Qv9X0rSJbvTItK8N/Dh7FN UsjK1xDd3eoSM11DAW4Pqbu1KcYpbOVNSu9FZJyVtX3d9AlVvb3drbu/T079dbn773Vlpe1m a3sVG08fY7Rt3J5bcF45/wBrv+PNzaT4Rmjll1DSdEli8tw4udO00JsCEEu7jCqBuySCAMmv 5lvHfxl/aQ8XfD/w7Lc3E+veAv2ivihr8t3GumeDfDOnT+ENWuvhZqvhmwsvFV/pAh0/Trw+ K5obfX7yS2nvYZlAuknjWSD2Oy8IfFXxB+zB4P8Ahh8VddS20HUP2p/Aug6i+gTeBdQ1RvBn iifRtP1KzkvdAk1m0tGubrX9XRbs2ceowJLaxQvC8lncM3gUlriqSf8A2Dx02vr7Va+fq+wp SdV7WsvX8bJ9395+xmmeKPhx4q+LXij4Vf8ACs7Sxj8O6Pb6r/wm11pmljwzfIbbQpUsbSdI VRp3OrpGuZiWfTrnCkg7fTNN8F/B/Xbq5s7TQ/AGpzWsKXU2n2lloUsljayySRJ9pW03zKFe OSBnuIlUsjDeXDKPxw8cfBmT4Z/EHwr8JfBFxr8fgzxP8I9ZsPDst9Fp9/c7tEvPgh4ru51v ZbGJppprldR3Q3L26xxTusSObVFHz14L8KQfBHw/+zR8QPhLf6rZeIPjLYRfDn4l6le2sGsm f+0LL4Sa1FawaXqFg0OkXMF7q2u3FrJaWkKv589vcS3C2lrHaxSwMZtf7ds/5O9l/wA/0rpX 7q1uiRnZ/wAr+5/5H7ynwl+y3qeuxaEtp8H7rXJSkUekWdz4W/tJ2khM8YWztb1L1yYQZxiA t5CM65jBNb97+zR8CLyEySfDjwim/ZIbv7CQjKxUqQy3CIVcFApDYPGM5r+Zb9hnTfAz/tGf APxH4wPhzwFeeAfFeoNqWraz4guF1fxdqd3Zatf+HIr3TrvX7Kx0dtLubjSNOsY9L8PxLq0N 9C959qnYzH+n/wAH/G74W/E7UfG/h7wT4s0XxbrHgOextfGGl6Xc3DSabPfXl1b2AnufIigV Wk069CC2kuQ5hZXkBXdJw5lhamFnHkrOunCLc1FwUbyceXSdRaJJ7q9/S/RSpKcLyTvzNduk bX+96/0vkC8+Ff7G2u+I7zwTpsvwsfxbaTXqJoNprmjHU49Qgv10lY7zT7PxSdTjWPU5o7J4 5bGfZcFoDbtcEQv8qaH8LvgTZeEPEXiP4t3fgXwtqFjr1xptr9g1Cyjt1sv7I8Mt5jveax4H hRxNrILA2czYlBNz88SV+efxZ1TxXL+0BFqGjfDtfh7rvgf9qq8lttB0jw14/wDE+p+JvDB8 ayz3nje/utZ1vWrSDSZ7zw/pdmkmlaVZ2P2h55Le5aKT7Mn0z47+AOta1ffFTRr/AMH+K9c0 Hwt8XPgzrdqkOj6xC2u6dra/B4ay6y6eiXEdvpLeHbl5ZrVpXjFvctKY40rxsVT5KLrzxvLo v3bjvzOMXq6q2vfSN3bYqFFc8Uldapt2aem9vXTXTX0P1q+Ak/gDwX8HLHXfAt8NY8DCS+u7 PU9NngmsHkuNaj0iRY7mLXNZ08sJ0AOzU5Ad23ashKnT/Yl/a58K/tY6F401fw1ot1ocvhO6 0yz1O1utS0jUGD3er+MdJgVf7K2rCEbwrctieGFmEigKXjlNcH4V+Cnj5/C/w/07wX8U9Y+H vw9h8G+Fw/w4l+Hmja9D/aS+HYXupZfFXiEDxHFOt60cr2jXipG9gbfygk0yVw3/AATZ8OeK PAnjL9q34d6/4S1jw7ZeEvGnh7+wdR1XTdTsU8Qafr/iT4r65FcWc18jWt5Hb2d5YM0ljd3Q VLuFrgwvKkdHBmGwcOIcNVdWFbEP606cmoqUG8JX5uX3pttwlNOzT5XrodteHLg6n/bi22tO np/w3kfqxRRRX7aeOfxYv+1L8X1v/hh4NPj7wZL4j8V29v4u1++fw/rh0y00i3m8NaVcaTpL DQkkj1Ga+167mt47nT7uw+z2sRm1KJl8i6+9LD4xeE28Y2vgC814z+LZTax3Wn22lalHBO99 FPd2YhumsINPAexWPPmyxqkySCTBYM/gviX4Z+H5PixLa6b4U0xZNE+BesjS5hpS26WPiNfE tpHbT2rW8MzT3UTWUDWplAuHEblYUO/f8NfAT4f397deD7bxL4u1C48Y6V4im1H7DJ4ehtbq K6WWK80+6vr+PWbXV2jmttPshHLd6ZOqW9k0EMc1qjhtaUsPKPKoOK2T5Wr38nH+l16nup4p aPmj/SXf0/BH6z618ePhp4e8USeCtY8QXFrr1uzvLZHRdVu4ILcQyzJE9xFp9xa+eoQM32Z3 i5wshLODxfwe/aT8BfGfVvGul+Hr6+Fz4Tm1iCeym0e7sH8zRNd1Hw6x86VriCaN7mwctsuI y4ljlVYl3JD4N8HPEPw90nW/FPgjxl4IHiv4hzfEz4h38t/c6LpV1eXOnyX19d6bMZr2U6wb CPRI7eG3lWzNs/7kRgxSfaK6n9k+Xw9a6Z440KHSW0rxHaeKvGdxqEj6VZWk7Wl98RPG93bi SYTrftBNDd2U8LT26Ryw+XNHlPJLZ/VIKTlFpK97OS301s9b232WlvMTlW+Gad2rpuLej6X1 XS35HRfFz49+D/hjpeuw3utR2/i+Hw5qWr6TEmh6ldWjzx2c/wBhMssFikZDTQbXWWZSAOXR cEWvgp8ZbTxv4Y8G3fiTUEl8Q+KtKv8AV4Fs9NuLZJtMXUNUFoI5Fj2QMsNizvHcTCQiNgWL PGjfGnxh1vT/AA7cfHrw94l8G6v4x8Y+LtB8PWvg+/ttBt76aBbnw0mlxvZx3BF15dhfyT3l 1/ZttceWkE0rZmVlXnfAuuXXwi8afBTxV4j8LeJn0K1+Buk2ssWl6VLE9trWqPr7S2MhvDp1 tb6jE8tzNdWpuVuEiZsRbCVXaLp2dO6cm7Npp2d1s9lp/V3pyVHNTSSlZvXR2Wi17Xvb+rH6 E+Kf2gfhx4U0e21vV/EV1aadd+IT4bsWfStdupJNStpNUtryALaWc08YS60m5WGeV0gaNVYu d0ZHn4+PK3HieLV7bXrWL4cW/hc+KtTjOl6pHr8VibPxFqYaGOK1MDLHZ6fYkwq73G6O7RWZ ngJ+RLD4bSeO9F/Z1Ov+BtTk+2/FK58e3emaroN7LLocbeO5Lu1XXrV4YxZ3NvYa+Y7trhDA GS73tMhErek/FzwHrHiC++O39m6Fcm2svhppnhXSzbWF8j3NzqGq/FHSry20uKytSk4t7O+s HvIIpjNFZ3MW6NVliMr9lD+bt1S7X6addPQOWX8r+5n1D4H/AGnvhX448UweC9G1/UbrxNca XdalFbXGja1b2L21rKWlmiuJ4BGpWFWTbOyzNIJQimIxE5EH7XHwTvPFEHgu21vWZtbl1b+x oEbw5fJa3F8dQh0xXiuHtowp+13ESiW5WFMSvIU2hivj3xC8EWfg/wCNHgC5tvD1tp/hvQPC 9xdanqNnaS6d4fE1+fHFhHbz6pHBHapK9zqunt5dyy77jyY1QyG3dvCP2blns/F/gSD4oWXi O502/tLCH4bRal4bi0HRNOvL3X/Dkv8Aoeq/bdPbV5JBLpzki1vpWSKeZVJYi47aFOnGlL34 3dnq43eq876PttdlqctktrK2rd9O3y/A+lv2u/jxe/CrSPCPh7w5rOoaNrvjnVNJsrjULSzi uLm0s5fF3hLTNXm0+e5ElrbXMWl6lqn2Ez2t1H9oMRlikQbG4rw/8YPHNr4m8YafdfEK+k0T RNT8LaLpF1qdnDcXwvtb1D4dytCxs9DYO1yfEmo2Mc8tukUUFztlkjESzr9DftD+E7/X/id+ z+dN0CfU9L0zxMbvXb2DT7nU7Kx0+y13wrf2qX9wlrPFaRutle7WuZYY3G9maVUcL89eIfhh 4uvrvxlqV5ompPb6l8ZPhnevG+k6mrHQtD0/4U3uo6rKBZpHFZ6e2gag73kbGC2ksvMmu7cx Tm3xoS5YRSd2qlmtHZPVNq+ie9/MbnNLVNWVno/lp+nW57F4j/bG+C/w8B0/xbfeJ77U9Hh0 y38Q3VloBubL+09QsILpXO6WyuJPMkklVWsrYRLJ5nmqIvKc8FqH7Wmh+D/jJ4503xVd+ILz wnp/wv8ACfjGz0uy0iwnfTbPVvFXxIt9U1SVXurXdfNpvhrT7cRW81ywNsQkL71c/Hl3LHon xD+J2ueNdC8SeJ/gva+KBZat4d0+3vBpGrahZS6xo+iTy6ot1ZWsz6XrC3kws575lW7aYESX dlGK+39B8G67qr/tVeK7Xw1ewzeLPBN5ofhBl0+/guNW0eU/FDUtOsrFbax8nVNOjfWbExCz +3qXv4xGrpcxed6EnanFq3M1f56evR/Ixp1ajl8M/J2l5fjr/Vzd8X/tWWWlfFb4R+E/DWm6 lrHhjx7fRx6lqMunWsc4tHsvHURFkLnXtKlhki1vw3pyXAutMuFbTzftbiWeS1aP1zwn+038 O/FHxE1v4caXo/il9T8PTrZ61fJpulW+mWd6dPu75IPOudd+2Tl/sV7bmS006aH7RC2ZVtpI Z5PmjR/BPjrwD4g+AniOPwXq+rWfhqw1vRNT03TLLW5LzS7nxBqnxYtk1S6t30Z4rOC0t/El jPcS3LwutpOkyHE0HmXfDfhnxZrP7Rya/wCBfh74o+Ed/JeeI7z4i+M7v/hJ9P8ACvj+1l0C 4tNCVmXTYtEvtUgv5ob4vPaRTW93Lqf2e9uZpriW9inL2kbzaTW26elrbu935f5o64VJyXvK Ts+sZLTTq7fefUPx/wD2jvBP7OVn4Km8cWviK7n+IOsf8I54Vg8Oabp+oefrflRNFFfm+1PS o7S1d7m2TzzNx5jbiiqzL5d4p/bEtPDAWyk8EeJbvV9G0KTxT4409LPw3I+iaFNd6wunSWk0 njy0srq8udP8PazemCzvNTEYS1SYwXEpta7T4zfD7V/H/wATfghrNtpcE+heDNT1LV9cfU7G 4cC6XxB4FurWaNYbC8tY5Us7DVjCbq6tVYPMAPLSWRPnn4zfCND8cfFni3VPg6/xd0vx9ofg 7T45Uk8SwppEWg6fqOj3+mapc6bomsW91YXi3qXSrJIBEkl7G1oA7y3ChUlzPfRpXs+qXbS1 2tO/Tq88T7ZOPs72tdpaXd1bqltr3NjR/jvL49/aO+EWqaNqfiSy+HXij4Pz+Lbnw7cmO2Mu pGfxtpDi5sYL68hW6tL21gjcxXklu32ASwXVxGY2n9A0H9qfXrvx7H4F8W+B7/QX8UWVxc+C Z7NNKuBrDQ3ug6ebK+lTx9rS2kkp8U6SbY3NpYQBDcm4uojDsfxdP2d/HC/Fvw14s8DQ2nwx 8M6d8FdN8N6boOn22s28fh7V5tdl1a6srfUotLsirw2N9Pp8zMtvfXBE32i1jSaQDmPgh+zf 400j4ieEfGviLw7pGgnRNBj0rWbySTxDqfiPxPrMOseDJLzW9W1TWvDek3t2b6bwxqWpodR1 HUJHXWIgWEcRkPbCd4pN3Tt3vpba69L6HHbFafH5ary6X9PU6f4Kftb/ABUg+FnxN+JXxa0p G0/SfFGnaB4SjsbTTppJ7/W9O8OaFpOk3NpZeJ2C2934y1/T47qeW4tUisdSmuDeRLBK9r2f hX9uGxtrrxBp3xS8PnQtR03w/a+NdPj0LSJLq3l8M6vqnhzSdJjuHXxXq5Osfadcna8hUw2q Q22+OdnCpc+cf8MveM9Q+D/jj4T+IrPw5rCw+MfDXjXwxd3Nrql7pmqXOj6l4J8USafqWm3P h9UkiGp+C7a2jVjr9szXJklsFCTWd12Gjfsu3nir4Zaz4M1Xwf8ADz4eXd7pmlaZFrGgaMYb yebStY8NatNdyi18J+DruC21NtOvFe3gvZoopBAmJ4wwt7VeafIlK3TR26LyWnl8lZkSeIW7 n2117dt+mnocRH8XfjX8RPjh+z7a+M9Gs/COh69aan4t0UeGtQltYtS0678V/CCTS7PXbaPx dr4kuBoniG3NzC1sIYrqTUooLsQuI5/Qf2vfHn7Svh/4k/AXRfgLP4N03QNe1q6tfFcfiv7U l3qOrPr3hi1t7S2GnXBtzpD28/kX32mNLk293ci3k83YYn+AfgR8dLnx78NvHXxI8aaDeaH4 E8JT+HLXwpaWt5NcfbH1L4dO2sBpfDugpFcva+Arl41njnn8zXGC3SiOee79e+Pvwe8XfEXU fAnivwnrmk6Zr3wz1AXds2q2k2+/kudY0KXzNJ+z2WoxviLS7k3Ektm22OW3ch1B8rSVR0qc HG99dFd7yT233en4kKnVmuZxk21duz9P8keM/Er9oz4+23iLxZpfwh0bwFd6L8NPDi+JvHWp +JNOuFudQt7G0tNb1rTPDgOuWzzXZ0PXdBa0+32GmWxuodSjOpKUtzP9WfCb4jX/AMQvg9oX xG1C3Fteal4TutXu7OzgihhttX0kXVpq0EltPeX0f2OTU7S4ZEtr2582JQVmQMq18q+Of2XP i3deP/Gl94H+JGheG/BHj7QrPQ/FmhRaXc30spns9D03Wr6x1J7GW4uHvdC0Sx00wW95ohQm 4VbiJo5Jrz6i8O+DLb4cfBG58GWE26bwp4DvbM6jFJdK9zfyaRqN5d31va3NxcObm91B5r2S 0luSI7hzAkrRjcDnlKnGVndtJ3u9OVPbTy3GqNW+kWvVpfi2l8tz8/fCX7Uf7WtzpPwO+Lfi i6+GUfwh8d694K0nxXpNnpF4/iaWD4gXvgbSNAvtFtTPNbwompePtMkuv7Q1aS4gtrGdpLO5 eFYr/S8N/tEftSa1oXxZ+LbXfgVPhj8N1vdG0nTl0e2j1/WPFknhfwjdaSmqQAyebpJ1/wAY wrcy22q6ROlnZRGMq8LSXmB+zN+y78Z9U8G/s5aj8QPjOdc+Gvgvw34R8VX3wxv/AAm1tPqt 9/wiXhm+8N6bqF59qt7rTD4R8QeHfD+p2sTvfwve2dxAbKAG4+3fZ/hv9mrT9K+DXxB+EHiD XLPWV8cXOqPcarBFfxxW0uoaPolnZXMWNTivXaxm0m2kMltd2bK6sEYPGxlj2kluu3dbW/4F u2hXsa/Z/wDgcf8A5I8BsPip+09oM3wO8TeNPFHhzVdC+PVrqqx+GtP07TXbwlcy+C7z4jaE bdpNLsJILZtI0W7s5DNr3iydGngt5dsjyX0GD4E/al+J3xLsvhd4c8P+IrD/AITC2+Ks3hT4 p3C6QtjHJ4Y8KQ+AbDxVDpFzdQvFIZNU8XSvZSLGLmdQkhWJYNsntfwn/Zc8Y+C/FOhXfxC+ KVz8UfCnw60e/sPg94Qv9M1Gy03wA1/a2+hrdWGtPrN9cPcxeDpb3QXNxaXk0sd3dRtcAl7i T0vwH+zR4L+Hfxb8b/FPSHhXU/GenvDNZpLq9zZabqs/ibUfEd3rFhbX+t3Wk2t5e3F1aRX8 2m6TptxfRaTpMd5NPbWGnW1jF33f3+n/AAPu8jFxktGn9zPhP4U/Fv4g6x4U+H3w98G6xpfg nxH8TfjVPod/rnhLQNG0ZLHw1YeBNa8Vai2mJcaVfaZBrN2fBkdnJeX3h/UWksJprVJIme2n s/kbxbeeO/hv4q/4KHarLqWneKvFtj40/Zz0lNc8SaR4e1Mamsy+IkmuNShg0TSba5v47G3i haVtPgt0nSV7WIgxyn9a4/2PfDtl8P8ATvC2h+JptG8TeHfGUHjLw94+0201e01zSb8wNpdx FpwtfFUV7C0uj6lqdi1zHrACRXk5FruAcZNt+wt4Bfwx4/sNe1u98Qap8TdW8Max4z1zVdQ8 X3Wq6xqXha61mWC9uba88aXMjzXV1q0lzugvrQJEuZBcqUjjFJp6Xd9Nm+3b7vQlwlzJ+8rL bWzvZrSx4pq3iP4y+L/EvxosrD4oaz4O8L/Dn4b2+reHrPwvcWmj3Mviq2v/AIjQzyXiL4f1 GG40gadpGiRQ2Ya1ilkhkFzbusdsYvHfGP7RXxA8Tf2bZ6z8SPHfh7Urz4V3N94LtvhrNp+i nU/G+peKfipotpNrEmqW0tuFjvfD/g6C0Ms1rZW0SX88hVp55T+oun/A/wAI2F146uIrW3ST x9pEuka4outVihuLJ5NadUyNQZUlDa7qId7OGznZZUJnYR262/wx8WPgLeeGfiJqkfh/4W3/ AIz0Kf4faD4f8Cah4b1HxtoR8FatHqPjzUNVuJ7nw5peo/bBe6p4rs7wzXWoz3dhDaTeREsR igI6jSb1dtbJavqktL67fgEoN2dno09uzT108j6/+CcvjOz/AGfPAlz4t17XdZ8UXXh6z1HV tS17UrfUdWmv9S1E3IkvruxCWj3UVjPHaTfYSbQSK4hMsZE7/ndrt38YbXwP+y94rsPjf8Uo NY+Lfjq10bxpO/iLTZLa90S/16C3l03TdPk8PzWOirBatHaQ3Wm21pqASGOWS+muWnuZv0d+ AvgrxJoHwg8K+HfH9/f3upQR6rczw6jc6vqV3ZWOoeINR1XRNDlvddNpq048PaXd2OjRy3Sx SSx6YknkxB/KToLv4H/DOTSvAmizeGtJl0r4bXdvqvg3ToRdSpo+owSQXiva/wCmRyKVuogU edrvJwTCMmOlGtKVvcav3jLyt/l8uxVm9k2fFOu3njDwV4B/aZ8PaZ4y8Yapp/g/xL8Erjw9 ea5r8us6toMPim/8JHW9Ntb+/wASz2GrSrct9nvBfC3k1C+MUtpFKgi+XviT4q8XeF/Cfx18 ZaBr2t6D4gTw38GJ5Nc0y/8Asmqi61bwp+zol7PJcW8mV+12940Ei2uEMUqI0agTEfsNq3wt +Huqp4iivfCunXI8YzaBeeJUuI5mh1CfwxPbvoT3I88iR9PawtpoNqW4RkjLCXG441z8APg3 q2mazp2qeAvCt9aeIYdMs9Yt7mBnW/ttDj0OHSUuozJl47GDwzocNt8w2Lp1ouSI/m1T05nv u/yt922u9t3vzVMNKc3K7V7aWfRJdvJH5wfAvwR4asP2qPjz8QtYvvEkmof8K8+G/i03L+I9 duFvbu38J+E9XvjHp/2trNw90qeXaX8MVmiEWsCw2Zkjrw7wj40+Js/7TH7KfiLQJofCvw6+ Jd3qWpPpbeJvGuoa/wCKtL1DR4b/AEi78QWWqeKPE+hwTPba7ZiaK1nsHiuJNUbyE8nTpR+z mofAv4Tan4lh8U3vgfw9N4l00W1vp+uNY+TeLBaJp0VnFLPDMhv7e3i0TSI1W8W4Ty7GAMpD OGw9A/Zw+BPg/XIfEfhz4W+B9G17Sb77dpOs2uj20V9pd1dM9tNdaZcMHe0DQkpJDbGGCKEY QbXYDNVJc3L73fTTVNN7L01/TeY4ZxfxO+1tU9beXZH5b/s5/DbVvFP7Hnin4wXvizxl4g+L Wiazr2raZ4r1/wAdeJpDbjwZqOjazYWq2ltdQWJg8nS/slxA1jsu7O7vreSQSXPmp7l+xj8R PFXx/wDib478X+INWuNQ0D4V+DfCvgTRoFv9Y0+2l8ciPS9D8bz3en/bne9jXxh8KtbSx1Fx bh7OeaeMSJqm6P77ufAGg6R8P/FXgTwBpmieEIdY0nXLDTYdMsobPRbbUdc0xrI6lc2VrH5U 6rLMrXLNbTPsgDqGkgiVeb+Bnwgt/hH4JtPD8c2g/wBtXWo+JdX8Q6hplsLK11PUdY8Xa94j ubuXfGsklxPda/dTxu9vFlpruSHyo32Npzy6xfbr5WX9eXY0VB9G+n6eX3fLufnz+1Tp2p+G fjd4b+K8d/4a8XaDoc+mW/jDwr4rfxPdaxpOnr421FNPvvh9FYWujaTp+trNr9/NrM1x4lht 7lPDvh+OCO4js/s9/wCEyeHPF/jX4s/EG98ffEHw7pXi+y8aeEG0bVrxPEd94z0fSbLwj8M5 7KLwxrNl4R8R6XpNvc6xPqCC2a8tyZNR1iW5igi1CS4l/aPWPhP8NNc13TfE+q+BvBuoeILB 2lsdd1Pw/pWqavazyytPE8V3fW0k9tG13M8t4Y5iEWWeYx3DZik0NX8B/DzxBqkHiDVPBPhX UdZtLbz7bWdX0bTbzVbN9PFxJamK5ubaeZ5rZwZbVHnQRhw6MmxMuMnJ2enrddls/wA/QFRf 8zellbotP+D8rL0/On4cfCjwr4+/aR1uy8fafD8Q5dG+FPhf+z5vEc89/ZT6hF4U+G2n3Gst YzJY2j3t7ZxTSS3M+mwTGa4llWCCWaQDhfgx4X8U+KPjnafAnxo0N3pXwW8YXXxI8NpJdh7W HQ38X+HPB3w6huLiLzJdRlsLbwT4wF7Y3FgiLHeQvLNO155MH686fo+h2oF/baZpf2240+C3 lntLW2trma1t/skNvbXkttGJILeGGGAW0SmaNltoUCoqqyaFrpmlxXtzqSWFrHqV1Cgu9Rj0 21jvLwLNNO6NcJiWW2W4mkngUv5ay3EzpFE0jGS5cqtZq/XVeX9ah7D+e/k1ddFd637L87H4 neFdMg0LwB8OfE3jqBb74K+CP2hI9U8X6RqznXbS4vbj4d65pmlXuq6IXu7vxBY2ev8AiDw9 c/Yit2IprO3u1sZRp6keifGrWfhH4z074OeM/BTXfhr4QeHNe8dpqcvh7wv4ds7Fdd16xv7G wltfCniDQdVT7I2saf4rjiuYtCh1CyF4rLJDaahemT9bD4f0OaOSzl0XRJtNupI/Ps5dPsja yyo0MplmszbNbSwrHbqokcH/AElEXywUWUSLo/hsWy6THoOkQ2FtNIxtIrO0WxlG+ZoljtEh S3tvKaUyCSFCxfcp4nkauNLmqQ3s5R16JNrr0XzXcaoxTTTlo0910+R+MV/8O/2To/g+uq6j 4m+JWs2sfxwk8c+F9cKWq2mh/GBfC4ubTULLRB4Z0+zh0FYxa3n9nTeHLrTxFawWhsxEj2L/ AHn+yfqnjn4k/sl+KY/GVlotlqviCL4paNpP9g2Gk6Jaz+doLWNjdyR6QoitriXU5PsN2/lx RmysoJRbCWS6urv7JTw/oy2K2LaRpC2odJltnhijt4pWhMKRh/s+5Q0atGhCDKRMVjypA6O0 a3RwLOCOwiiZi0KNuBRk3BNhCqstw/nRxjrIzoA5IVUeIoxs2pRem6ktFZXtZ2em2iNLLt/W n+SPyZ+LPge88df8E8PFHg7T9Gj1LxR4D+MXiDw3qbTXNrbjdofxh1YPDaalcXcUjgW2rWlz 5kUltFKrzoQJTLbyfSPgnw7oPxC/aB+DnxUtPB2nXOhal8Mb+G3k1vT9FSfSwuq/AW3VBY2s 8zkyL4euHuIi9/ZyG0iBjKvDG31voXhHw/4XvPFd1oVmbeXxdrdx4j1uCLzxDPrGp2+jm9vZ bR7u5tmnl/s21E8scFuDcBmKCTe830Xon2ZLW0VYIYY2giMUUREUSyXu24Ozy1jCQIxYTLGu zcyHyjhQPOappWbi9XdNrpb9RqF9ot+ib2t/kv6Z+Dum+Fvjr8J/Cfg3w5ptk3hb4O2vxG8c P8UY/A954S0/xyula54c+Ftvo1r4U1CS6t47KO81efUYtSitLi0b7Jf6pI7CW7Eje02Pwg8c eKf2FfiR4e8KaDqdzqt1+1L4i+I3haLxZr2hXPiPUfB+sSWFtb3Oqav/AGxd6YL6VtXuLy6t 5NQtrsSxzfMUZLe4/bGx+zvJkok1nM5kgivJm+0RzQxgJJPG/wBoyy3MUcsDNPIdsceAm1UH Tm7RFMbiSWJbSJxBG5MYuPMiQSwzBg6MluTCYI0WMIHfqWB4qqg7uKTd+ny6LfR7+vyTitNL Wt38v0SPH9X1O5+MH7J+sz6RpF1Yah46+DPjSy0vTbuWxsdQOpa34Y1XTrLT9SurTVb+xjgF zIsJji1S40+CLywJPJhj8v8AMb4r/Cn4g6JpHwaHgbwB4w8O/tDSfCz4faP4H+IHg/xv4b0X w5NfwSJa3lh8SIrr4g2z69o+nxX+tzW0H/CLavGIfE2tpAs8t89vB+3VrKka2ZjkVy9xCYFV xHHabnZpHDIW2OZCjKVRSNrkMhGG31jhkwkEdssYsrFSssmxbSRnuArLKElaJ2IRLoL5R8uK MOZgQic5cYN2srLa7/4P9eZ8hfC79oLxP4u/aF8ffBqXT9Im8KeCPD8F6fEUVnd20k+t3Ome Btbt7O4V9ZV7tkPjCHMo8LQwCCGKFr55LZjL+ef7X37O37WXxH+Lvxxgj0eX4i/D74i6M2jf CDRbj4jQ6B4b8F3V74L0rQ9T1C90K18W+DJU+16vcxyQte2ninZaRamzWcLXrw6h+1Nj4d8P 6XJqGqaBoGn6XLevGb5rTTra3kupTHYWTxXV9EhmuXms7WzhMk4aWO2ighRWitYAdkXNpEFk mhjeRTbzR27bHSEWkZR4WEnEsblowryQ/LGu3y9shSgVndq17X28j8kviF+yL8bfEOreBJrT StGNmf2R7j4beJFn8RWKxzeLm+HXxN0mJFgaSUXOmwat4msZLe8mSVoFee5jQSREt94/s3fD TWfBvwL8MfD7xrbWCa9HZeKo9XGlXCvaS2up+LNdvYolu4EiYFtOuIGZrdI5IplBSQTJvr3Z ZvMkZWjZooby8e2uJIUskhtYlieKO2EAdJLZ0j2Rv5iIVcqEK5DOnv0yhQ70uZZGhWN1b5fs c0DYI+8iPFLK+3KgK2RlWITaW7S9S4wcr6S8tP8AgH5V6F8G/wBr/wCEPxR+Jnhv4f6f8LYf gb8QfiH4s8UaZrmvX8l54h0C01fXfF3j6e1me0aLVmudc8X+KGMSTaX4gig0yyliurzTp0t5 7z54b9i39q+9sNT+Aeh3Hw4vPgMnxaufHFzrc2vXcHifT/DkcMngu70uymbS7UxK3g2S1u47 eHw5Jcf2hbxt/aA8pbA/uRqttFq8No02R5V3bbAskhkUW+m31m7rFG0SkMdm5iw2CTBJZyGm ljhEk0a2xhR4Le6L3Ekl/vuZWuxLPIt7uFjKgWMyyW7SNFvwDgAvnU1SellrfottSVFtpNNX aWz6/I+DfGP7LHinxBZ/tc6dp+qeHjpfx78JeD9G8LR3WoahG39seHPB17odzNqsa6A0NjGL +XTvs8/l3jvFAZSkfloC/wAFfs1+M/Cui/sipdar4eS7/Zu0Hxl4e8Uzrd3E8TJ4z8HyaFp0 elbPD4fVIUns7ZJmmismt0SORFlAYD7d0fxNpmu2AvdDv7bVrSeVbU3On3NrfW9rNDPlhdT2 stxFDv8AOBQFizBWyowK1ba+dZJgZWZ48wtHLsaCKFpA8j7JC6FZJobcws0KnDqUZN2ySLq1 76d+n37dUdX1V/zd+3T+tD8N7H/gnr+0rY2tn8OPEvxP8O33wJtvjQnxj1jR7DXVbxBBHNHB oSaJZXM/w2tnl0X/AIQ6y1e1On3E898L0Wkn9rZkmduu8V/sDeK9Y+NEWu6V4h8PN4X1bxZ4 I8XpqWq3UF/8RoL7wnD4ajuLGz8Ral4D1G8sNDEnhGykt9Kt9Yjgcaj4gbEMmrzA/qnr/wAX /h94Li1Ntb8a+FLEaNCdT1GyufEPh+xns9PnXUC1rqiXd9A9rI39gX0UP2sFGez1IJJGbW73 dzp3iHSb2GK/t5odSt2W5miuLT7HcWx+xK7zWUuoQysYpLhojCiL5pDTqpT5ypxlUu3TVpWX M1G7fTor/ikvPU56lNwny6vRPbo/Q+R/CX7MPxN8C/tB6T8avBXi6ztPDNx8PdE8IfEHRLvU IJLzVr7TPB2meHl1C0gXwmskRnv/AA/4NvZZrTXrAzfZrySSyQXF1aTfRXjr4L6B46+LngX4 qXGrajbX/wAPE1NLK2s702txcf2xqngHV7dNUjfSLiG6hVPANqnlWmp2yQLKYUTZIhs/Wre7 sblLa+DJHHNCFm0YiFkuI23SJIbnzBK32d/JjYfZcLNZtGXG045r4hfFHwt8LNJTWvFusSaV pUd09p50TaTZwpLPa3GqLbpqGoarpImS1tLO4jnDyI0ckQPklI2ePhq2UZTaV015WvJK3luk vVLqTGLlJR2vfe/RXZ4Lpv7D/gnTPhX4w+GYvdXHh7xb440Lx89zaa3GNR0fU/D0/gSdF0u6 l0KNbKC4m+H+lS3US2d5NN5t4Y7mCSeH7L4b4m/4Jj/DjxfJr2j3HjDx1ZeCPFN9pmueJNE0 zxJpFodU8Q6Vo2jaLDq1zqD+BJ9feeePw/pE13D/AGx9gluoDOlnENqL+jOna0b+yhv4VM9t NHLOlwDH5cSQzT2+LgxK8JllntZYrZXkcSuI4g6NlY3pPNMjm2Nw0lzO4UxW6SKHA814gFYg yLHGWZFUEKCxAAJrxq3Pz3UJOLtryuzXS3ql/Wy09i07XV/K36tM+dvB/wCyh8NPCviL4q+K bZtcnvfjB4Wg8F+JEudVjnspdMs9LGhH+z7P+zYUsbie2iVppJBJAZmcxQQwEQjlde/Yb+Gt /wD8INN4a134ieBte+H3hzTvBeneKfB/jJtF1ufS9HgSzgi1e5bTL2HUpIrafU47aQ2ISGTW dUkijga6Dx/V/wDaqQLI2ojzpbaJliUGON4plXI/d/uwsj+WpUEFmKluTuJ8E+An7Ufh3433 HxQj07SdS8OP8LfHFx4H1ptUudLdb68sp7mFtSjW2kURW8ktvLt+2BZsqQx3IQsOpibWTaSS 76RVrdVayXXe3TUyas2uza+4p+I/2QPhd408L+G/DWvX/jW51Two97d6T43i8Y6rB47HnnxM JrC78TrF9qu9MurHxTq+jXFjNCYH0q6+zAK0Ucy3vA/7FfwC8HeB/GXgGHwnLqeifEm0uF8a HX9Z1PXL/WGKeJLW91AXt67vZanMvjTXWN1YLas73xkYBoIdnpnjj4w+Evh34NvfFvijW44d Gtta0iwkvnvtJsbQS6neWFjbW4vrzUrS1E1zczrbRQmUSTTzxwxBpXVTwM37QcE/i34eaLof hrXNc0Dx5o8ut2XifThaXujWlrLc+CRbwXd/bx3cLTTReLJGAhvXjf8AsfUiryeQHj5qvt42 5lJu/Kkk7uUUna2rbV7vS9tXuCTk7L/hjobv9ln4Gal8ONB+FM/gPTo/B/hjTdJ0zwxDZzXd jq2gWOixaHDpMuka9ZzQavp+owx+GtHEmqW95HqcxsLd5rt3jRl1PCf7MPwh8KeHoPDNv4cv dZ0y38U2HjCF/FPibxH4lvote0yfTrrTb1LrVtUuHH9n3Ol2VxaIQRDLD8uUd1bfsfiX4Mvr +PRrLx14R1LXI98T6TYeJtFutUieFJS8MlhBdNdpJEba7LI0IZfs9xuA8mTatp8avhg2rWOh P8TvALa1qMscNjox8aeGv7Vv5Jt5iis9P/tH7ZdSSCKUxxwxOziOQqDsbHkVqmJvyqNTs7Rn pe2r2S7Nvt3O6lCCVk156q7en4Hb3/wp8B69qug67qXhjS7rVfDFlf2GiX8qyvc2FnqlvYWl 9bxM8jL5dxb6VYRurArttYdoBRcchf8A7O3wYOiaXoqfDnw5Hp3hy4e/8OxpZoieHdTW0tbS HUdHlV/tWn39pBptgtvc2pEkAtLdoj5kYI9Pi1KJ1UwzoVdY3QJMjeZHInmRsm1iGR4yJUZc ho8OpKnNeH+Ov2nPg58NfFWjeE/GPjnwlo+t606w29rqXirwlp11E7akNNVJrXVdXs7zK3az x+WkT4khnjA81HURT9vFqMHOc22lGCc5NpWlG0bybj1Vrp3uJwXa34dv0/O5+eug/wDBLnXN J8Z6JGPFehH4Y6T4h0rxHNqcUmhH4ty3Vk+nXsiDxm/wpj1prWDVNHso4rca/CTocl9pYZrW 4FmP0P8Agh+zj8PPgYfFtz4V067k1XxteQXfibXb28jvdV8QHTtR1u6sm1O9NvYTMbd9cl2L EkIOyJXDJCN3P/Ev9rr4G/Cu+l0zxh4w0eDVoo7CZtNj8TeErS+nt9RnhtoZP7N1DxJp0j26 CUyTytEyC2SeVfM2bGwfiF+2V8Ivhv8ADzwV8UbvXYtc0bxxJND4Q07w5qnhG4vZ1CNLqG0N r1vZ3p02OIw34tJr82lwHEjRspc5Yuti69JRjGfvSsnyyd7NNpa6tLXTsaU7L3bpPte2vu6/ p/w7Par74O/CC/8AEk3ie7+GXgO912WFRJrE/hPRZdXmuft9xqEkhvJrLc3m3kxumeSQObpj L8pLselm8OeG/OvmXQtOjn1L7M+of6BZEXb26rDZzXIMbpPJZxxIbUyBxbPEkkKpKWZvzv8A +CeX7R3jD4/eGvjVqHizxRN4hj8L/FbVNK8N32o3emPLZeHTYWk9hpMDafaRokzKxmSE3Fwx ZGKXUoXfXQ61+398MtI+KWk/Cm88HePdHl16ew0uz8V6t/YcPh+x1PU7dZo5Wu77XRKZbc3m mK0MZEhuJrSMKvnwu/xuaYXH1JqClUfIk500/eiuWEouUVdro9Vtrs9e+FOFuZuO+j5o31t8 +y6WsffMW63gigtBGbO03RQ26h0jjliZ7fYR+6eNUiztjtmjtlIURoE3Keg8H2mmQ3mu3VvY Wlvq969g2tX0NnawXGomJbtdPN3cwIs14bW2ZoonuWkeNWYBiXct+Rmu/tu6D8EtK+LPinxv 4l8T/EbRtF+Kmo6dpenWh8NQS6PpuswaDNpNlaPca/LE9lYJfSNDLJJEZor/AMyNAGjD/od+ yt8WU+NPgGHx6nhbxH4RGu2dhqEeleJrdLfUI7Wa91u3sWITCPHNaWcV3DIiCOW1urWVGkSQ OengmhiaHF2Uqp7RU5PHp8yaTayzGNJXttppZ6q/mVjIxWBrNNXfs9E1/wA/ad9v6230Pp+i iiv6JPnD8zpP2NPiiSgj1v4fAR2QshK2peIhcMg7PIvhflTgMRwC+W2Vn2f7EHxEgYSNqnw5 gmiP7iaxvtcil24JzLIfCYbeHd1UoQBEQOpOf1BooO+WZYqcuZuF/KC6W/yPzCH7EnxFW5mu V1j4febcDE87ahrv2hx8hy0o8J7mJMUYJdmyox1C4rRfsTfFVfMY6z8NIZJz/pElrqPiON5e WA3ufCm6T5WJ+fPze1fqNRSsr362t8hyzPFSSTcNEkvcWy26n5bQ/sP/ABQEsMk2vfD6Qi4D TsdU8Qu/2YeSDFCX8JdSBOdjny90hPR3rRP7E/xH85z/AMJB4Ja2MuUjk1XXW8uDyQAkaf8A CKeWhFwCwUfIEZiPnNfpxRURpxhJyV7y31/rqZvHV3o3H/wH08/L8Wfmb/wxd8TDarC/iPwW 8sLzNbyNrHiBvLE8kkr4Y+FdyHeYSNgH3OclVNOi/Yy+Jgt5YZdY+HrGZIhKw1DXyZXjyxaQ t4Wy+XOSWBJyx4Jr9MKK0F9dr2teNv8ACj8tvFf7DHxB8X6dfaXq2r/D26s7+a1lmgnv9bnh BtDA8RWK58I3MW4SW6Nlo3wSxUqxBXwX4ef8EnNe+HWuLrun+IvB2rzpZ/Zra11/V7y/sdGd byxvYZ9Bgg+HFi+nTwvZIkUscwMaKiquQHT9w6KDOGJqwnKpFrmk7t29Pu2PzPg/Y2+Kcbbp Nb+HjkDCH+0vETEfKw/i8LjHJB4qnL+xX8UrlWiudb+HckM1sbe4j/tLxE6vvnJchZPCrK26 2PlkuDkkoVMZr9PKKqE5Qd47+ly3jK8t3Hp9ldD8QIf+CSXm+OtR8X6ldeAJotQvdQ1GWxin 8yF7vUEm82WS2uPhsVZhLcTSq7XLyh5Gdndnfd9D2n7F3xSijCT678P5FdYoZYhqfiJ4BbIr Bo4438KgdHdVRgY9mFIHOf04orb61WsldWXlvrfX+upSx+Ijs4fOKf8AX9eR+Z6fsbfFQSBp Nd+H7DuBqfiMn8N3hfH61YP7HHxLJB/trwECM8jUtfHXH/Ur+1fpRRSeIqNp3Wnl6ab7aDeY Yh21horfD0+/+rn5nTfsafFKThNf8BAHIIbVfEQ4OeOPC5Heq7fsW/FJnRhr/gDCjnOqeIs9 SeP+KV96/TmiqWLrJWTjp/dJeNrvdx0/un5mN+xh8TmTb/bvgLdxk/2p4gxx6H/hFs9qhf8A Yt+KLMhGvfD/AAvUHVPEX+znAHhXGeDX6c0U1jK6ad46f3R/XsRa14/+Ary/r5+lvzP/AOGN PihvVv7c8AYH/UT8Q57/APUr1O/7HPxOZAo1zwDkEZzqfiHHAP8A1K/rX6U0VoswxK2cP/AE Q8XWejcf/AT8zJ/2MvijIQV17wCuM5/4mniIZyB6eFj6GoX/AGLvim23/if+AOMf8xXxFwcg nH/FK+3FfpzRR/aGJve8L/4F5efkVHG14pJONl/dXe/9evpb8yF/Yw+KYJzr3gDkdtU8RcdO n/FLe351K37GnxVeLyzr/gFDFBdJbtHqviNS8lwyuPtJ/wCEXJZFZABsAZVJGGOCP0yoq1mm LWnNDT+4v8/6uKeMrTSUnGyakvdS1St/n9/ofmPN+xl8VmSOOHXfh3GoJRh/afiRQsEflm2S ML4WwNh80FSNiqV8sAlqYv7F3xWH3tf+Hx47ar4kPf38K1+ndFQ8xxMt3De/wL/Mh4io1Ztf cj8zP+GMvimQB/b/AIBAAHTVfEXYf9it0z0/Cov+GMPipuJOv+APukD/AImviPrnv/xS3T1r 9OKKX1/Ed4f+Ar+v+HflZOvUdtVptofmVH+xj8U0BB1/wCec5/tXxFnt/wBSsPTj3pJP2MPi m541/wAA9e+q+IvoP+ZWP41+m1FNZjiVonD/AMAQOvUdtVptofmSP2Mfin31/wAA/hqviP8A r4WqB/2LPiqxBHiD4fjBU/8AIV8RjoQT08K+g496/T2ikswxCaacNGmvd7W8/L8X5Wl1ZtNO 1mmtu5+Ykv7F3xVdVA8QeAAVCg51XxHjgHpjwqT3oX9iz4phlJ1/wAQuP+Yr4jzxjPXwr7cV +ndFW8zxT3cP/AF/n/V2KNSUdrdtuh+Ys37FvxSkOU1/wCOCDu1XxEB7dPCp49agX9in4rKc nxB8Pj1/5iviTv2/5FTpX6g0VDx+Ibu3D/wBFe2n5fcfl8/7FXxYZlP/AAkPw/wCD/yFvEue MdP+KVxnjio5v2J/ivKsg/4SH4fZZQq51bxJgAMSc/8AFKHHB7Z5r9RaKccxxMXdOF/8C/r/ AIf0Ic23zdf6Z+W//DEnxX4/4qH4fZxjP9reJPUnj/ik/wDPNJ/wxH8WP+hh+H3/AINvEn/z J1+pNFW80xbVm4f+ALy8/L8fSz55eX3f1/Tflb8tm/Yl+LRI/wCKi+HuAAOdX8S5x7f8UpTo /wBiT4rKrK3iLwACVcDZq/iTDb0KFZM+E+UIY5HfC9RkV+o9FTLMsVJpycG0kl7iW1v8hRk4 u6tfzVz8hvGn7E/7TY0OCH4beIPgRba6NTSS4uPFeq/ECGzfTFivVaNZtB8KfbGujJNbEI4+ zlY3JO5Y89/D+xf8V4xEH8QfD87IRG2NW8SH5hs5GfCw+X5T1wenFfp1RWbxtduTvG8rX93t t1HOcp25rabWVu3+R+ZQ/Yy+KihQPEHgHhCuf7V8R9SzHjHhbpgj8c1LZ/sZfE6O4D3WveA3 hO7cseqeIGc5VtvEnhYIcMVJyegJHOK/TCiqWYYhRlFOFpJxfuLZqz69f1IPxn+D37B/7U/h vVvibP8AE7x58JNa0rxB4uvNV8DwaF4o+Iuoz6ZoT3N+9la6tF4g8HwW1lex21zCkkOkGazR 1dYpDGFLer+IP2PfjsNDuYvCfiL4WLr0rWbRy69q3jFdOjFvqMEzhX03wx9tTdZfaQAoObpo gdsRkNfqDRWf1uty8t42/wAK8v8AID8crj9hD9pvUPiR4Z8WX3xB+Gi6BZeFrew1/RLTxX8Q BDJ4hSw1C2nvdL02bwe9k9qZri2Mdxe3KXxiWYugcRq31Dp/7M/xJskRP7b8HMEMIX/iZa8c Rxbhgf8AEhQBtpUAABeD0AFfdlFcz1bfc1hWnTXLG1r31V97f5fi/K3xrH+z98QEeJv7Y8K7 UYMw/tDWsnnJwP7FAPHriustvg34zhiSNtR8ONhRvIvNVOXwB8udLHy4A6jOc19PUU02ndET nKbvJ3fol0S/Q+YNX+EnxElgtItH1PwnEYZA0ovb3XEjkQJ93FrppLAvnKsACh9Sak1b4Z/F W48n+zrr4ew4it0m8+fxHHveKbe+3yLBtylCwXfyScEAEmvpuipaurMftJKPKrJena3+R83y fDH4iSJJdDUPCMWpRwBbNIrrXEsEuI51mhmlX+zzcKwAZXkiYOBtCgcmvDvBf7Jnjvwh8Ufi z8VIte8MXes/E7TNLWezutU1ifTLbV9MsookZbdfDdtdQ2M10srTs+o6hcyQsrDy5Cwr9AaK ErJJbJJfcKM3Ha3X8T4w0r4UftESeEPEq+ItS+D58d/ZZovBp0e88cf8InFK1oUiOvm+046w kYumO7+yvmFuqbQZARU3w8+Ev7QB0lv+Fu658MrjXBLeeV/wgup+NZtKFuwiSzV/+Em037YH KPefalX5MvF5XDSg/ZNFKUFK176bfh/ka/WatrXX3en9fP0t+eHxM+Dn7Zt5qMkfwr139new 0Jby3a3bxdqfxVtdYNlFp3lOkx8OaW9n50uoM80ioPJeJIZDidSKn8JfB39sL/hO7+88e6j+ zdJ4AudD+wW9j4Xu/ig+v2epS6wJZtTtrbWdM/sW3uotFLQ2l4jNcJerHG6G0BNfoRRT5Vbl 6NNffuS603vbvsfjnZfsc/tpeBfhbY+CfhL4h/Zk8KakfEmpavqccWrfFfQvD4gurnwu1vPY J4Z8MWdx/an2bTtZFzJcWmzzTpQSVozdGPp/iX+zN+3n4k+H3ws0Dwd8QfgHo3ivSY9Tl+J2 uXPiv4y6d/aN75EEekDwvqWl6DPqV3ayyvfS6yPEEMcrstm9sdwmB/WWioVOKpqkr8iSjvrZ eZSxFRaJr7vT/I/Hb4qfsE/H/wCI+jeO9KOtfA+2uPFPwwTw5aaw2o+NYdZfxrJaeNba51HV dQPg6+dtHjfxFZXVndxx3GrJdPq08kBLQrPy/wATf2HP26NQk8JWXwo+MHwp8N6B4V0C4T7H qPxA+MGjvrPiafxFretmXW7fw34Sey1HSVin0azEmy31AW8d/b4KpaSn9saKmlQp0akqsE+e UVF3d1ZeRLqzcnLS7ST07fqfEHhT4IfH3Tfg34b0LX/E/gC6+LtlouiWuvaxZa140n8KzanZ raQalLp+oXukx+J5Lae3glMD3kKXEs0hNwqo7AfE3h39gL9svS/hz410vWPjV4I8R+OfFegz C3TXfiP8VNY8F6R4pGm+IILW50xbrwbHrGn6ab3WIjcTJHc6ibSJvL/fIol/biioqYSjUU1J SftGnK0raqSmrdtUhOpJtS0ur207qz/4HY/DT4v/APBP79t/4leMvEOuad8b/h94b0RfC2kJ 4O0vSPiV8XdHWHxnYLrU1zd65ZQeDL+0j0a4u4vCWZ9Lm/tWWCHWfMCSx6YRc+Bn/BP/APbQ +F3xG8FfErxD8b/BfijV7bQdR0jx1Yah8Svitrej3TXGmatp9iPD9rfeDNPuZ7e08vwy8Y1i /UwGDUmhibytPQft/RTlhqUoxi07Rtazs9Nrtb7LchyblzPe9z8dPGP7DX7VviX4L2/ge3+J vw6tfGlv8WtZ8aJqo8afEiDSR4W1DXPifqFrowvk8Iz6sJ7Wy8VeFrSPThaLp0C6XeQR3Tw2 WnPcZng3/gm58WNNtP2kdI8UeLvAM+jfGfx2/ifRbfSNf8SSvBpzeIdU1g2+vxah4FjtYrlo bmyiaK0i1WAutyn2goIpW/Z6is5YDDzU01O048kvfa92zX32e4m7tt7vVn8/cv8AwSf+Peq/ DX4m/C3X/FfwWvPC/inU9G1zwtp6a74zuLbTdW0y+8AXbT31re/DmTTrMbvDmvzQyadp9xc/ abyykM0ZuL1oPVfEP/BNv42W/g39nnw78O/FHwp8M3nwe8M6hpGtXMet+LdGj1a/vpPBt559 tNofgVZb6BNQ8PahMJLuDTJlW6ik8p5552g/a+ilLAYeVaNdqftIVpV01N29pKCpttbW5UrL vqB+IFt/wSv8aeHvDPwVv/B+r/DLTfir8PdX8Iaz4q8SPf6rZ2mvXVre+A/+EyZNY0v4eQeI 9U+3adofipdLOpPZSXN3rEY1WVYNQ1HyU8P/APBLPxzonw08S2Q1P4UP8XLv4q+FvGvhrxaL zWGg03QNBTwCJ7CTXh8PYvE1neu3hrWvItbBGsmW9t993Cbm78j9wKKUsuw0pTk1O9R3l778 tu2xUZOLut7p6+TujwjwF8NPFPhrwD4N8P6zqOkXniLRPDmhaZrN9a3eo3Fldahp2mR2d5Na XN1YQX09vJMrtDJdQQzvGVMsaOSlfm7+2h/wT/8A2jP2jtZvYvBPjL4TeG/C9zoepFn1PxD4 60fxDf8AiS/uvESpHq7aR4M1zTrrw9Z6dqsBs0Ia/t7681sjfBcJ5n7M0VhgsmwWAxEcTh41 FVjVrVk51HKPPXu6nutWtq7LoavEVJbuP/gK6aI/HSw/4J2/FW58cWvi3xVrfwr1ph8NNZ8E 3txPqXiPUdUa81W3+J9iJoJdR8EMWs4LLxno4jklufNjmtb8fZJIYLVLqP4b/wDBPb41eBvH Xwy1648QfCXUPD3w+1b4uTxaZNq3iy7kGl+P5tZfSYrOyfwVaWIubNLyxW+jWayt7fypxbG9 CQlv2Poq4ZVg4ey5Y1P3LlKHvt6yTi799G/vMnNuSk7XVvw2Pzc/Ze/Y/wDib8DPF/7Qupa3 f/DKXw38V/GmoeIfDFp4ZuvED6hp1hc6pr1xbrrEF34Z0iwtNQSw1O1icafJqMKzwukc7Qxx tJ8l/En/AIJk/tG/Ezx8fHOufEj4dy3GmeIPCF/4dtm8YeOngtdM0KXw9c6nHcQ3ngG/eC7u 7nTtRaJLG7jt50eyNw8MjTsn7r0Vyx4ey2OLxWMUa3t8XCEKz9q+Vxp04U48sbWi+SnFN9Xd 7sv20+6+7+ux+Evjn/gl18cvFXh7x9pFr40+F0Nx4puvDN7p7T+I/F8dvHc6Rpvgexv5L8x/ D64dGmfw7qjQPBFcSSLPZGZ4jJcJB+x3wq8H6x4K8KaPo2uSaRJqNloPh/TLp9Fe6exa50qw +y3D27XlraTm3d8NA0kSSMpJeOM/LXplFTh+HMsw2Lw2NpQrKvhZ1Z0XKq5RUq1Cph580Wve Xs6s0lfSTT6DlXqSg6ba5Xa+mujTWvqkFFFFe8Yn/9k ________________________________________________________________________________
Date: Jul 07, 2016
Subject: Re: dielectric grease vs conductive grease: when and
where
Thanks everyone for the comments. How about grease for the specific purpose of mitigating corrosion, for example on grounds? Also what about on D-sub connections? Sent from my Android. Sorry Steve. On Jul 7, 2016 8:38 AM, "David Josephson" wrote: > dlj04(at)josephson.com> > > dielectric grease vs conductive grease: when and where >> > Summarizing some discussions Bob and I had some time ago, there is > approximately zero need or use for grease in a properly constructed > aircraft electrical system. There are very specialized exceptions > (heatsinks of power semiconductors inside electronics, heat transfer > compound on certain sparkplug threads) but the conductivity you're > promoting is thermal, not electrical. Aircraft electrical connections have > to be tight enough that they don't come apart, forcing a metal-to-metal > connection of higher pressure than any grease will withstand. The grease > only serves to prevent air and water from reaching metal parts that aren't > in contact -- but if they are not in contact anyway the grease will not > help. > > In cars, we have battery posts and terminals made of rough cast lead that > won't support the kind of pressure that copper lugs will, so some amine > grease (a variant of cosmoline, such as No-Ox-Id A-Special) is a good idea > to help the battery terminal conform to the post and seal out the battery > acid, but we hope you don't have that kind of terminal post in your plane. > It's great for trailer and motorhome lights, truck battery posts, etc but > we hope you don't have any iffy connections like that in your airplane. > > Conductive grease (containing metal dust) is used to solve one very > specific problem in high current building power wiring and has no place in > an airplane. If the surfaces are so rough that they need conductive grease > to make contact, fix the surfaces instead. > > 'Dielectric grease' made with silicone oil came into use because it's > available in a convenient tube and electronics techs have it already for > heat sinks. But again, no reason in an airplane unless you need to make the > surfaces slippery or exclude moisture. > > ________________________________________________________________________________
Date: Jul 07, 2016
Subject: Re: Dead battery
At 10:48 AM 7/7/2016, you wrote: > > >But all of the internally regulated alts I've >seen need some form of external overvoltage >protection (typically a series contactor in the >B lead circuit) which implies the ability to >control the alt's ability to feed the system. If >the contactor control is 'downstream' of the >master switch, you get the one-operation shutdown of the system > > I seem to recall a couple of years ago, Bob N. was working on a system > to safely shut down an internally regulated > alternator, and a simple series > contactor was not the answer.=C2 > > IIRC he never came up with a good recommendation for a circuit and > procedure to do this.=C2 Am I correct or did I miss the final answer??? Yes, that idea was predicated on a bit of kerfuffle over some Van's alternators that eppeared to have gone belly up after having been switched on/off using the Figure Z-24 ov manager. To the best of my knowledge there was no failure analysis conducted on the damaged units. The general consensus amongst the best-guessers was that the alternators were switched under load . . . perhaps at rpms more than idle and the subsequent load-dump (automotive parlance load-dump) zapped the alternators. Nobody knew the pedigree of Van's offerings. Further, my visit to MPCA overhaul operations in San Diego/Tijuana demonstrated that a righteous/capable overhauler produces parts immune to such events (see chapter on alternators in the 'Connection). The more sophisticated controller was not pursued as probably unnecessary. Even if the alternator is not so capably remanufactured, turning it on/off under load and running faster than idle is simply not necessary. Hence, Z-24 has not be replaced or updated. Bob . . . ________________________________________________________________________________
Date: Jul 07, 2016
Subject: Cheap-n-Dirty In-Line ATC
Needed to add a fuse to a device with limited space and very low current requirements. Wound up adding this ATC3 fuse to the gizmo using fast-ons and heat shrink. While not as robust as a legacy fuse-holder, the manner in which terminals are retained in the ATC fuse doesn't raise much concern for over stressing them with direct support of 22AWG wire. Emacs! Bob . . . ________________________________________________________________________________
Date: Jul 07, 2016
A quick test reveals that you are absolutely right. The master switch is "Inoperative in flight" as long as the engine is running. I am considering running the control wire through a panel mounted pullable breaker as a temporary solution. On 7/7/2016 5:24 AM, user9253 wrote: > > Just to emphasize what Bob said, connecting the alternator control wire directly to the "B" terminal is not recommended. The master switch no longer has control over the electrical system. It is not a master switch in this case, but is a battery switch. Shutting off the master switch in flight only disconnects the battery, but does not shut off the electrical system. Everything will keep working. If the electrical system needs to be shut off in an emergency like smoke in the cockpit or a fuel leak or high voltage, the only way to accomplish that is to shut off the engine also. The master switch needs to be placarded, "Inoperative in flight". The solution is to run the alternator control wire to a panel mounted fused switch. Doing that will not only eliminate the above problems, but also allow the voltage regulator to monitor actual system voltage instead of alternator output voltage. They could be different if there is resistance in the alternator wiring. That resi! > stance could result in lower system voltage even though the alternator is putting out 14+ volts. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=457845#457845 > > ________________________________________________________________________________
Date: Jul 07, 2016
Roger So you saying that the Plane-power alternators (as fitted to many RVs) need e xternal over voltage protection http://www.plane-power.com/pdf/internally%20regulated%20experimental%20alter nator%20information.pdf John Sent from my iPad ----x--O--x---- > On 7 Jul 2016, at 04:48 pm, Roger wrote: > > > > > But all of the internally regulated alts I've seen need some form of exter nal overvoltage protection (typically a series contactor in the B lead circu it) which implies the ability to control the alt's ability to feed the syste m. If the contactor control is 'downstream' of the master switch, you get th e one-operation shutdown of the system > > I seem to recall a couple of years ago, Bob N. was working on a system > to safely shut down an internally regulated alternator, and a s imple series > contactor was not the answer. > > IIRC he never came up with a good recommendation for a circuit a nd > procedure to do this. Am I correct or did I miss the final ans wer??? > > Roger ========================== ========================== ========================== -========================= ========================== -========================= ========================== ========================== ==================== ________________________________________________________________________________
Date: Jul 07, 2016
John, Which alternator style are you using? If it's internally regulated, let us know what happens after you install the switch in the 'I' lead. Some alternators won't start without 12V on the 'I' lead, but will continue to operate after breaking the 'I' lead connection. Regardless, you still need positive control over the alternator if it has a regulator 'failed hot' overvoltage type of failure, and opening the 'I' lead is unlikely to offer positive protection. (Shorted components in the internal regulator can keep the alternator 'hot' no matter what you do to control terminals.) Charlie On 7/7/2016 1:21 PM, John Morgensen wrote: > > > A quick test reveals that you are absolutely right. The master switch > is "Inoperative in flight" as long as the engine is running. > > I am considering running the control wire through a panel mounted > pullable breaker as a temporary solution. > > > On 7/7/2016 5:24 AM, user9253 wrote: >> >> Just to emphasize what Bob said, connecting the alternator control >> wire directly to the "B" terminal is not recommended. The master >> switch no longer has control over the electrical system. It is not a >> master switch in this case, but is a battery switch. Shutting off >> the master switch in flight only disconnects the battery, but does >> not shut off the electrical system. Everything will keep working. >> If the electrical system needs to be shut off in an emergency like >> smoke in the cockpit or a fuel leak or high voltage, the only way to >> accomplish that is to shut off the engine also. The master switch >> needs to be placarded, "Inoperative in flight". The solution is to >> run the alternator control wire to a panel mounted fused switch. >> Doing that will not only eliminate the above problems, but also allow >> the voltage regulator to monitor actual system voltage instead of >> alternator output voltage. They could be different if there is >> resistance in the alternator wiring. That re! > si! >> stance could result in lower system voltage even though the >> alternator is putting out 14+ volts. >> >> -------- >> Joe Gores ________________________________________________________________________________
Date: Jul 07, 2016
On 7/7/2016 12:21 PM, Robert L. Nuckolls, III wrote: > At 10:48 AM 7/7/2016, you wrote: >> >> >> >> But all of the internally regulated alts I've seen need some form of >> external overvoltage protection (typically a series contactor in the >> B lead circuit) which implies the ability to control the alt's >> ability to feed the system. If the contactor control is 'downstream' >> of the master switch, you get the one-operation shutdown of the system >> >> I seem to recall a couple of years ago, Bob N. was working on a system >> to safely shut down an internally regulated alternator, and a >> simple series >> contactor was not the answer. >> >> IIRC he never came up with a good recommendation for a circuit and >> procedure to do this. Am I correct or did I miss the final answer??? > > Yes, that idea was predicated on a bit of kerfuffle > over some Van's alternators that eppeared to have > gone belly up after having been switched on/off > using the Figure Z-24 ov manager. > > To the best of my knowledge there was no failure > analysis conducted on the damaged units. The > general consensus amongst the best-guessers > was that the alternators were switched under > load . . . perhaps at rpms more than idle and > the subsequent load-dump (automotive parlance > load-dump) zapped the alternators. > > Nobody knew the pedigree of Van's offerings. > Further, my visit to MPCA overhaul operations > in San Diego/Tijuana demonstrated that a > righteous/capable overhauler produces parts > immune to such events (see chapter on alternators > in the 'Connection). > > The more sophisticated controller was not > pursued as probably unnecessary. Even if > the alternator is not so capably remanufactured, > turning it on/off under load and running faster > than idle is simply not necessary. Hence, Z-24 > has not be replaced or updated. > > > Bob . . . > Bob, My memory of those events is a bit different. At one time, there was a circuit in the book to provide overvoltage protection for 'one wire' (internally regulated) alternators. It used your overvoltage 'crowbar' module, but the crowbar was applied to the CB-protected power going to the coil of a contactor, which could open the B lead from the alternator. As I remember it, numerous people running Van's small IR alternator (I think it was a Honda product; ~35amps) had alternator failures when they intentionally triggered the OV module with the alternator producing power (the infamous 'load dump'). Others were manually cycling the control to the contactor (thinking in legacy 'split master switch' a/c terms instead of 'new' automotive terms) while the alternator was under load, also resulting in alternator failure. FWIW, I actually had an alternator failure in an RV-4 using that old alternator, that apparently happened on the same flight that I cycled my master switch, working on a different electrical issue. I can't swear to cause & effect, but they were coincidental. Again, as I remember it, you decided to pull the design to avoid the failure mode induced by misuse of the design. I hated to see it removed from the book, because I thought it was an elegant way to control inexpensive, readily available (any auto parts store), light weight alternators. I always thought that education would have been better than deletion. :-) I still have a copy of the original circuit page from the book; I'm implementing it (twice) for my dual alternator equipped Mazda rotary on an RV-7. Charlie ________________________________________________________________________________
Date: Jul 07, 2016
I'm not Roger, but I'm quoted in that message, so... I suppose I should have been more specific. I was referring to 'off the shelf' internally regulated automotive alternators, being installed, unmodified, in an aircraft. I think Roger's question would be at least partially answered by my response to Bob (sent a few minutes ago). Charlie On 7/7/2016 2:41 PM, John Tipton wrote: > Roger > > So you saying that the Plane-power alternators (as fitted to many RVs) > need external over voltage protection > > http://www.plane-power.com/pdf/internally%20regulated%20experimental%20alternator%20information.pdf > > John > > Sent from my iPad > > ----x--O--x---- > > On 7 Jul 2016, at 04:48 pm, Roger > wrote: > >> But all of the internally regulated alts I've seen need some form of >> external overvoltage protection (typically a series contactor in the >> B lead circuit) which implies the ability to control the alt's >> ability to feed the system. If the contactor control is 'downstream' >> of the master switch, you get the one-operation shutdown of the system >> >> I seem to recall a couple of years ago, Bob N. was working >> on a system >> >> to safely shut down an internally regulated alternator, >> and a simple series >> >> contactor was not the answer. >> >> IIRC he never came up with a good recommendation for a >> circuit and >> >> procedure to do this. Am I correct or did I miss the >> final answer??? >> >> Roger >> >> =================================== >> st">http://www.matronics.com/Navigator?AeroElectric-List >> =================================== cs.com >> =================================== om >> =================================== matronics.com/contribution >> ================================== ________________________________________________________________________________
Date: Jul 08, 2016
Subject: Re: Cheap-n-Dirty In-Line ATC
That is a really frugal solution, fraught with simplicity and lightness! On 7 July 2016 at 20:09, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > Needed to add a fuse to a device with limited > space and very low current requirements. Wound > up adding this ATC3 fuse to the gizmo using fast-ons > and heat shrink. While not as robust as a legacy > fuse-holder, the manner in which terminals are > retained in the ATC fuse doesn't raise much concern > for over stressing them with direct support > of 22AWG wire. > > > [image: Emacs!] > > Bob . . . > -- Best... Bob Verwey ________________________________________________________________________________
Subject: Re: do I need to change my capacitor
Date: Jul 08, 2016
On another internet forum the question was posed - "Why do you need a capacitor on the Rotax charging system?" A reply was posted by another member: "In our charging systems, the stator produces AC output which goes to the regulator/rectifier. The ouput of that is DC plus an AC voltage on top of it. A capacitor is often used to filter out higher frequency AC ripple on the rectified DC supply. It helps keep the electronics happy and audio quiet." I'm curious if this is an accurate statement, or not. -------- John Evens Thorp T-18 N71JE (built & flying) Kitfox SS7 N27JE (building) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457943#457943 ________________________________________________________________________________
Date: Jul 08, 2016
CgotLS0tLS0tLSBPcmlnaW5hbCBtZXNzYWdlIC0tLS0tLS0tCkZyb206IGpyZXZlbnMKRGF0ZTow Ny8wOC8yMDE2IDI6NDQgUE0gKEdNVC0wNjowMCkKVG86IGFlcm9lbGVjdHJpYy1saXN0QG1hdHJv bmljcy5jb20KU3ViamVjdDogQWVyb0VsZWN0cmljLUxpc3Q6IFJlOiBkbyBJIG5lZWQgdG8gY2hh bmdlIG15IGNhcGFjaXRvcgoKLS0+IEFlcm9FbGVjdHJpYy1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5 OiAianJldmVucyIgPGpyZXZlbnNAY29tY2FzdC5uZXQ+CgpPbiBhbm90aGVyIGludGVybmV0IGZv cnVtIHRoZSBxdWVzdGlvbiB3YXMgcG9zZWQgLSAiV2h5IGRvIHlvdSBuZWVkIGEgY2FwYWNpdG9y IG9uIHRoZSBSb3RheCBjaGFyZ2luZyBzeXN0ZW0/IiAgQSByZXBseSB3YXMgcG9zdGVkIGJ5IGFu b3RoZXIgbWVtYmVyOgoKIkluIG91ciBjaGFyZ2luZyBzeXN0ZW1zLCB0aGUgc3RhdG9yIHByb2R1 Y2VzIEFDIG91dHB1dCB3aGljaCBnb2VzIHRvIHRoZSByZWd1bGF0b3IvcmVjdGlmaWVyLiBUaGUg b3VwdXQgb2YgdGhhdCBpcyBEQyBwbHVzIGFuIEFDIHZvbHRhZ2Ugb24gdG9wIG9mIGl0LiBBIGNh cGFjaXRvciBpcyBvZnRlbiB1c2VkIHRvIGZpbHRlciBvdXQgaGlnaGVyIGZyZXF1ZW5jeSBBQyBy aXBwbGUgb24gdGhlIHJlY3RpZmllZCBEQyBzdXBwbHkuIEl0IGhlbHBzIGtlZXAgdGhlIGVsZWN0 cm9uaWNzIGhhcHB5IGFuZCBhdWRpbyBxdWlldC4iIAoKSSdtIGN1cmlvdXMgaWYgdGhpcyBpcyBh biBhY2N1cmF0ZSBzdGF0ZW1lbnQsIG9yIG5vdC4KCi0tLS0tLS0tCkpvaG4gRXZlbnMKVGhvcnAg VC0xOCBONzFKRSAoYnVpbHQgJmFtcDsgZmx5aW5nKQpLaXRmb3ggU1M3IE4yN0pFIChidWlsZGlu ZykKCk5vdCBleGFjdGx5IGFjY3VyYXRlLiBUaGVyZSdzIG5vIEFDIG9uIHRoZSBvdXRwdXQgb2Yg dGhlIHJlY3RpZmllci4gVGhlcmUgaXMgYSByaXBwbGUgb2YgdmFyeWluZyBEQyB2b2x0YWdlLCB3 aGljaCBpcyB3aGF0IHRoZSBmaWx0ZXIgY2FwYWNpdG9yIGlzIHN1cHBvc2VkIHRvIHNtb290aC4g V2l0aCB0aGUgY3VycmVudCBjcm9wIG9mIHN3aXRjaGluZyBzdHlsZSByZWd1bGF0b3JzLCB0aGVy ZSAqc2hvdWxkKiBiZSBsaXR0bGUgdG8gbm8gcmlwcGxlLCBidXQgdGhlcmUgbWlnaHQgYmUgc29t ZSBoaWdoZXIgZnJlcXVlbmN5IG5vaXNlIGZyb20gdGhlIHN3aXRjaGVyLgoKTmVlZGVkPyBPbmx5 IHlvdSBjYW4ga25vdyBmb3Igc3VyZS4KCgoKCgoKCgoKCl8tPT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cl8tPSAgICAgICAgICAtIFRo ZSBBZXJvRWxlY3RyaWMtTGlzdCBFbWFpbCBGb3J1bSAtCl8tPSBVc2UgdGhlIE1hdHJvbmljcyBM aXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UKXy09IHRoZSBtYW55IExpc3QgdXRpbGl0 aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sCl8tPSBBcmNoaXZlIFNlYXJjaCAmIERv d25sb2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwKXy09IFBob3Rvc2hhcmUsIGFuZCBtdWNo IG11Y2ggbW9yZToKXy09Cl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdh dG9yP0Flcm9FbGVjdHJpYy1MaXN0Cl8tPQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT0gICAgICAgICAgICAgICAtIE1BVFJP TklDUyBXRUIgRk9SVU1TIC0KXy09IFNhbWUgZ3JlYXQgY29udGVudCBhbHNvIGF2YWlsYWJsZSB2 aWEgdGhlIFdlYiBGb3J1bXMhCl8tPQpfLT0gICAtLT4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3Mu Y29tCl8tPQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PQpfLT0gICAgICAgICAgICAgIC0gTkVXIE1BVFJPTklDUyBMSVNUIFdJS0kg LQpfLT0gQWRkIHNvbWUgaW5mbyB0byB0aGUgTWF0cm9uaWNzIEVtYWlsIExpc3QgV2lraSEKXy09 ICAgLS0+IGh0dHA6Ly93aWtpLm1hdHJvbmljcy5jb20KXy09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KXy09ICAgICAgICAgICAgIC0g TGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUgLQpfLT0gIFRoYW5rIHlvdSBmb3IgeW91ciBnZW5l cm91cyBzdXBwb3J0IQpfLT0gICAgICAgICAgICAgICAgICAgICAgICAgICAgICAtTWF0dCBEcmFs bGUsIExpc3QgQWRtaW4uCl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJp YnV0aW9uCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09CgoKCg= ________________________________________________________________________________
Date: Jul 08, 2016
At 02:44 PM 7/8/2016, you wrote: > >On another internet forum the question was posed - "Why do you need >a capacitor on the Rotax charging system?" A reply was posted by >another member: > >"In our charging systems, the stator produces AC output which goes >to the regulator/rectifier. The ouput of that is DC plus an AC >voltage on top of it. A capacitor is often used to filter out higher >frequency AC ripple on the rectified DC supply. It helps keep the >electronics happy and audio quiet." > >I'm curious if this is an accurate statement, or not. This statement and similar ones have been around for a long time. They have a 'ring of truth' about them. Everybody knows that capacitors are a hedge against noise. It's also common knowledge that the higher the noise frequency, the 'better' a capacitor works. This is a simplistic statement that is un- quantified (how high is high?) and just how does ripple on the bus figure into 'quiet audio systems'. I did some simple demonstrations with an SD-8 on B&C's bench about 20 years ago wherein I MEASURED the effects upon ripple voltage for both the battery and the legacy recommendation for a 'filter' capacitor. I was unable to support the notion that the capacitor was a useful addition to the system. It doesn't hurt anything but I'm unable to demonstrated that it helps anything either. The test-bench under construction will explore next generation options for PM dynamo rectifier/ regulators. It will also be instrumented adequately to explore answers to the capacitor question in more detail with a test report with measured data. But based on what I observed 20 years ago and since, I'm not a big proponent of adding fat caps to the bus. I may be wrong. If so, the REAL answer will be in somebody else's test report wherein it is demonstrated that some problem was mitigated by addition of a capacitor. But for now, my inclination is to suggest that the capacitor is equally effective in warding off meteor strikes. To the question in your subject line, what makes you think the capacitor is bad? Without evaluation on appropriate instruments, it's a rather enigmatic device. Of course, if it's all puffed up, leaking gooey stuff or smelling bad . . . well . . . yeah. The puppy has gone TU. Bob . . . ________________________________________________________________________________
Subject: Current Sensor basic question
Date: Jul 09, 2016
I'm using the 50a hall effect sensor which came with my Grand Rapids EIS 6000. But the current numbers don't jibe with the VPX. It's not a huge difference, but enough that I don't like it. I've talked with GRT and verified the offset and scale factor configuration but it's still not right. While searching to see if anyone else was having this issue I ran across an aftermarket sensor. High accuracy current sensor http://www.crazedpilot.com/high-accuracy-current-sensor-for-5v-input-7-30v-supply-engine-monitor-systems-dynon-mgl-grand-rapids-garmin-and-more-ems-efis-systems/ Interestingly, it looks just like the GRT sensor. I contacted them to make sure it would work with the EIS6000 and if it came with the offset and scale factor values that needed to be configured on the EIS. They said yes and that the correct values were based on the wire size being used. There is nothing in the GRT documentation about the wire size having an effect on the offset and scale factor settings. Is it true that the size of the wire effects the reading of a hall effect sensor? Don Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457996#457996 ________________________________________________________________________________
Subject: Re: Current Sensor basic question
Date: Jul 09, 2016
I can believe that wire size affects that sensor but not the hollow round 60 amp sensor that GRT sold me several years ago. The wonderful thing about the GRT sensor is that you can adjust the offset and scale for almost any sensor. IMO the values from GRT are simply a recommended starting value and all of my sensors benefited from some tweaking when I calibrated them. Ken On 09/07/2016 3:34 PM, donjohnston wrote: > > I'm using the 50a hall effect sensor which came with my Grand Rapids EIS 6000. But the current numbers don't jibe with the VPX. It's not a huge difference, but enough that I don't like it. > > I've talked with GRT and verified the offset and scale factor configuration but it's still not right. > > While searching to see if anyone else was having this issue I ran across an aftermarket sensor. > > High accuracy current sensor > http://www.crazedpilot.com/high-accuracy-current-sensor-for-5v-input-7-30v-supply-engine-monitor-systems-dynon-mgl-grand-rapids-garmin-and-more-ems-efis-systems/ > > Interestingly, it looks just like the GRT sensor. > > I contacted them to make sure it would work with the EIS6000 and if it came with the offset and scale factor values that needed to be configured on the EIS. They said yes and that the correct values were based on the wire size being used. There is nothing in the GRT documentation about the wire size having an effect on the offset and scale factor settings. > > Is it true that the size of the wire effects the reading of a hall effect sensor? > > Don > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=457996#457996 > > ________________________________________________________________________________
Date: Jul 09, 2016
If it's a Hall Effect sensor the wire size doesn't matter. Magnetic field is what the Hall Effect device is measuring. What dictates the magnetic field strength is Ampere-Turns. I assume you have the wire only passing through the sensor once (one turn). A smaller wire will have more voltage drop across it for any given current flow than a larger one, but won't change the current measurement. Look at your installation. If the wire and the sensor is laying tightly with other wires, the field may be effected. This should be a very localized effect so if you have about 1/2" from other wires carrying current you should be OK. Bill Putney - WB6RFW Chief Engineer KPTZ - Port Townsend, WA PP-SEL/A&P-IA "...you know me to be a very smart man. Don't you think if I were wrong, I'd know it?" -Sheldon Cooper On 7/9/16 12:34 PM, donjohnston wrote: > > I'm using the 50a hall effect sensor which came with my Grand Rapids EIS 6000. But the current numbers don't jibe with the VPX. It's not a huge difference, but enough that I don't like it. > > I've talked with GRT and verified the offset and scale factor configuration but it's still not right. > > While searching to see if anyone else was having this issue I ran across an aftermarket sensor. > > High accuracy current sensor > http://www.crazedpilot.com/high-accuracy-current-sensor-for-5v-input-7-30v-supply-engine-monitor-systems-dynon-mgl-grand-rapids-garmin-and-more-ems-efis-systems/ > > Interestingly, it looks just like the GRT sensor. > > I contacted them to make sure it would work with the EIS6000 and if it came with the offset and scale factor values that needed to be configured on the EIS. They said yes and that the correct values were based on the wire size being used. There is nothing in the GRT documentation about the wire size having an effect on the offset and scale factor settings. > > Is it true that the size of the wire effects the reading of a hall effect sensor? > > Don > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=457996#457996 > > ________________________________________________________________________________
Date: Jul 09, 2016
In general that is 100% correct, but this sensor doesnt appear to have a split ring to concentrate the magnetic field into a Hall sensor. When youre not collecting the whole field, geometry has a large effect on field strength. Im curious how this sensor works or if they expect some sort of calibration step after installation. > On Jul 9, 2016, at 3:29 PM, Bill Putney wrote: > > > If it's a Hall Effect sensor the wire size doesn't matter. Magnetic field is what the Hall Effect device is measuring. What dictates the magnetic field strength is Ampere-Turns. I assume you have the wire only passing through the sensor once (one turn). > > A smaller wire will have more voltage drop across it for any given current flow than a larger one, but won't change the current measurement. > > Look at your installation. If the wire and the sensor is laying tightly with other wires, the field may be effected. This should be a very localized effect so if you have about 1/2" from other wires carrying current you should be OK. > > Bill Putney - WB6RFW > Chief Engineer > KPTZ - Port Townsend, WA > > PP-SEL/A&P-IA > > "...you know me to be a very smart man. Don't you think if I were wrong, I'd know it?" -Sheldon Cooper > > On 7/9/16 12:34 PM, donjohnston wrote: >> >> I'm using the 50a hall effect sensor which came with my Grand Rapids EIS 6000. But the current numbers don't jibe with the VPX. It's not a huge difference, but enough that I don't like it. >> I've talked with GRT and verified the offset and scale factor configuration but it's still not right. >> While searching to see if anyone else was having this issue I ran across an aftermarket sensor. >> High accuracy current sensor >> http://www.crazedpilot.com/high-accuracy-current-sensor-for-5v-input-7-30v-supply-engine-monitor-systems-dynon-mgl-grand-rapids-garmin-and-more-ems-efis-systems/ >> >> Interestingly, it looks just like the GRT sensor. >> I contacted them to make sure it would work with the EIS6000 and if it came with the offset and scale factor values that needed to be configured on the EIS. They said yes and that the correct values were based on the wire size being used. There is nothing in the GRT documentation about the wire size having an effect on the offset and scale factor settings. >> Is it true that the size of the wire effects the reading of a hall effect sensor? >> Don >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=457996#457996 >> >> >> >> >> >> >> >> >> >> > > > > > ________________________________________________________________________________
Date: Jul 09, 2016
It appears from the photograph that it's sensing the magnetic field at only one or two points; The field decays in strength with distance away from the conductor, and measured at the surface surface a larger conductor has a smaller field than a small conductor carrying the same current (because of the 1/r rule) so I would expect the size of the conductor to make a difference. If the current sensor were a transformer (which effectively integrates the field strength around a closed loop surrounding the conductor) then no, the size of the conductor wouldn't make a difference; but this doesn't appear to be such a thing. Of course a transformer wouldn't be able to detect a DC current so you'd have to be doing something very smart like integrating the transformer output which would be expensive, and probably inaccurate. If it's a Hall Effect sensor the wire size doesn't matter. Magnetic field is what the Hall Effect device is measuring. What dictates the magnetic field strength is Ampere-Turns. I assume you have the wire only passing through the sensor once (one turn). A smaller wire will have more voltage drop across it for any given current flow than a larger one, but won't change the current measurement. Look at your installation. If the wire and the sensor is laying tightly with other wires, the field may be effected. This should be a very localized effect so if you have about 1/2" from other wires carrying current you should be OK. Bill Putney - WB6RFW Chief Engineer KPTZ - Port Townsend, WA PP-SEL/A&P-IA "...you know me to be a very smart man. Don't you think if I were wrong, I'd know it?" -Sheldon Cooper On 7/9/16 12:34 PM, donjohnston wrote: > > I'm using the 50a hall effect sensor which came with my Grand Rapids EIS 6000. But the current numbers don't jibe with the VPX. It's not a huge difference, but enough that I don't like it. > I've talked with GRT and verified the offset and scale factor configuration but it's still not right. > While searching to see if anyone else was having this issue I ran across an aftermarket sensor. > High accuracy current sensor > http://www.crazedpilot.com/high-accuracy-current-sensor-for-5v-input-7-30v-supply-engine-monitor-systems-dynon-mgl-grand-rapids-garmin-and-more-ems-efis-systems/ > > Interestingly, it looks just like the GRT sensor. > I contacted them to make sure it would work with the EIS6000 and if it came with the offset and scale factor values that needed to be configured on the EIS. They said yes and that the correct values were based on the wire size being used. There is nothing in the GRT documentation about the wire size having an effect on the offset and scale factor settings. > Is it true that the size of the wire effects the reading of a hall effect sensor? > Don > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=457996#457996 > > > > > > > > > > ________________________________________________________________________________
Date: Jul 09, 2016
Bill I certainly agree for what I'd call a common hall effect transformer with the sensor in a gap of a magnetic torus and the wire through the center hole but the pic that came up when I clicked on Don's link just appeared to be hall sensors strapped directly on both the sides of the wire. I would expect such an arrangement to be affected by wire diameter? Ken On 09/07/2016 4:29 PM, Bill Putney wrote: > > If it's a Hall Effect sensor the wire size doesn't matter. Magnetic > field is what the Hall Effect device is measuring. What dictates the > magnetic field strength is Ampere-Turns. I assume you have the wire > only passing through the sensor once (one turn). > > A smaller wire will have more voltage drop across it for any given > current flow than a larger one, but won't change the current measurement. > > Look at your installation. If the wire and the sensor is laying > tightly with other wires, the field may be effected. This should be a > very localized effect so if you have about 1/2" from other wires > carrying current you should be OK. > > Bill Putney - WB6RFW > Chief Engineer > KPTZ - Port Townsend, WA > > PP-SEL/A&P-IA > > "...you know me to be a very smart man. Don't you think if I were > wrong, I'd know it?" -Sheldon Cooper > > On 7/9/16 12:34 PM, donjohnston wrote: >> <don@velocity-xl.com> >> >> I'm using the 50a hall effect sensor which came with my Grand Rapids >> EIS 6000. But the current numbers don't jibe with the VPX. It's not >> a huge difference, but enough that I don't like it. >> I've talked with GRT and verified the offset and scale factor >> configuration but it's still not right. >> While searching to see if anyone else was having this issue I ran >> across an aftermarket sensor. >> High accuracy current sensor >> http://www.crazedpilot.com/high-accuracy-current-sensor-for-5v-input-7-30v-supply-engine-monitor-systems-dynon-mgl-grand-rapids-garmin-and-more-ems-efis-systems/ >> >> >> Interestingly, it looks just like the GRT sensor. >> I contacted them to make sure it would work with the EIS6000 and if >> it came with the offset and scale factor values that needed to be >> configured on the EIS. They said yes and that the correct values were >> based on the wire size being used. There is nothing in the GRT >> documentation about the wire size having an effect on the offset and >> scale factor settings. >> Is it true that the size of the wire effects the reading of a hall >> effect sensor? >> Don >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=457996#457996 >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Jul 09, 2016
Can you elaborate on the tweaking process? For example did you adjust the scale factor or offset? Which direction did you change for what effect? yellowduckduo(at)gmail.co wrote: > I can believe that wire size affects that sensor but not the hollow > round 60 amp sensor that GRT sold me several years ago. > The wonderful thing about the GRT sensor is that you can adjust the > offset and scale for almost any sensor. IMO the values from GRT are > simply a recommended starting value and all of my sensors benefited from > some tweaking when I calibrated them. > Ken > > On 09/07/2016 3:34 PM, donjohnston wrote: > Read this topic online here: http://forums.matronics.com/viewtopic.php?p=458012#458012 ________________________________________________________________________________
Date: Jul 09, 2016
Only one pass through the sensor. No other wires within about 4-6". billp(at)wwpc.com wrote: > If it's a Hall Effect sensor the wire size doesn't matter. Magnetic > field is what the Hall Effect device is measuring. What dictates the > magnetic field strength is Ampere-Turns. I assume you have the wire only > passing through the sensor once (one turn). > > A smaller wire will have more voltage drop across it for any given > current flow than a larger one, but won't change the current measurement. > > Look at your installation. If the wire and the sensor is laying tightly > with other wires, the field may be effected. This should be a very > localized effect so if you have about 1/2" from other wires carrying > current you should be OK. > > On 7/9/16 12:34 PM, donjohnston wrote: > Read this topic online here: http://forums.matronics.com/viewtopic.php?p=458013#458013 ________________________________________________________________________________
Date: Jul 09, 2016
> >High accuracy current sensor >http://www.crazedpilot.com/high-accuracy-current-sensor-for-5v-input-7-30v-supply-engine-monitor-systems-dynon-mgl-grand-rapids-garmin-and-more-ems-efis-systems/ > This is obviously not a 'cored' sensor. Because there is no control over the concentration of flux in the measured wire, there is similarly no physical filtering of external magnetic fields normally afforded by the use of a gapped core. Hence, the need for two sensors on opposite sides of the wire. Magnetic lines of force will be equal/opposite in the two sensors where the sum of the two will represent a field proportional to flux surrounding the wire. Flux from outside the sensor pair will affect each sensor approximately the same and since they're wired for adding opposing fields, non-opposing fields tend to cancel each other. As long as the instrumentation system has adequate accommodation of scale factor and offset, then this 'coreless' approach seems reasonable. I use a closed loop, gapped core sensors in my instrumentation packages. One of my favorites is this critter http://tinyurl.com/zxsdyj4 [] [] Emacs! It's core function is a plus-minus 6A sensor but easy to 'jeep' into fractional multiples and sub multiples of 6A. Of course, it's designed to mount on an ECB but I've converted dozens of them to remotely installed sensors at the end of pendant cables. These are gapped-core, closed-loop sensors with great linearity and calibration numbers. They too could probably be adapted to the popular displays. The price sure is right. Bob . . . ________________________________________________________________________________
Subject: Re: Z-13/8 Questions
Date: Jul 09, 2016
Bob Here are the details of about a dozen Rotax regulator failures. Draw your own conclusion(s). First some background. There are several versions of the Rotax 912/Ducati regulator. Older versions include Rotax PN 965-345/Ducati 383475, I believe this is the version examined on the http://contrails.free.fr/elec_ducati_en.php website. This was replaced by Rotax PN 965-347/Ducati 343620. This version was manufactured until late 2009 and was replaced by the current version, Rotax PN 965-349/Ducati 362001. I believe this change was driven by component obsolescence, the button case diode was no longer produced. My findings show there are two failure modes, depending on the version of the regulator. The older pre 2010 regulators fail from the inability to adequately transfer heat from the diode assembly to the case. This causes the diodes to unsolder themselves from the assembly. Both diodes show signs of unsoldering, but, If look closely, the inboard diode always shows more heat damage then the outboard diode. This asymmetrical failure is likely caused by the asymmetrical geometry of the enclosure/heat sink. This is the only failure I have seen in this version regulator. This includes regulators with melted supply terminals (G pin,) the solder connections on these diodes show the same failure mode. I have not seen any component fail out of spec in any regulator examined. Here a schematic/assy for this version https://drive.google.com/open?id=0ByPxADyU-DwPdTQ3NWp5LW9iOHc Typical failure mode https://drive.google.com/open?id=0ByPxADyU-DwPTnlXcUVEQTdfcVU Current production since 2010 uses a different diode package. This resolved the internal heatsinking issue of the older regulator versions. Unfortunately, at this time they changed to gel type potting compound. All the examined failures of this version are likely caused by vibration. This failure is unique to the regulators with the new gel potting compound, this failure mode is nonexistent on the older version regulators. Here a schematic/assy for this version https://drive.google.com/open?id=0ByPxADyU-DwPWTBBcGlUeENTcHc Here are some failure photos https://drive.google.com/open?id=0ByPxADyU-DwPYm1rYUVsbUJyQ3M Heat is often the cause of failure in electronics, but these regulators fail from poor mechanical design and poor material choices, long before heat would kill them. nuckolls.bob(at)aeroelect wrote: > At 06:37 AM 7/5/2016, you wrote: > > > > > Mike Miller has done autopsies on several failed Ducati regulators and he attributes the failures to poor manufacturing and vibration, > > vibration in a potted assembly? > > > > not from heat. > > Has he published a teardown report? > > > > Some RV-12 owners have reported a gradual failure where they get low voltage alarms at RPMs where they used to have normal voltage. Each regulator could fail differently. > > Color me skeptical . . . these regulators have > been in production for decades. There must have > been thousands sold. Over that period of time > and numbers of examples, I find it curious that > a constellation of failure modes would emerge. > > ..... > > Bob . . . Read this topic online here: http://forums.matronics.com/viewtopic.php?p=458023#458023 ________________________________________________________________________________
Date: Jul 09, 2016
Don The formula is in Section 7.1.5 "Transfer Function" in my GRT manual. From a quick refresher it seems that increasing the Aux Scale Factor increases your reading by MULTIPLYING all sensor outputs by a larger scale factor. Increases or decreases each reading by a similar percentage so to speak. Changing the offset simply adds (or subtracts) the same value to all readings. For example you could change this by some value that adds say 5 amps to all indications. It would then add 5 amps to the indication even when no current is flowing, and 5 amps to all readings. Tweak this by an even number such as -2 or +2. Changing it by an odd number such as 1 or 3 reverses the direction for example from adding to subtracting. If you describe what you are seeing on the display and what it actually should be at one point preferably somewhere near a normal cruising current and also with zero current flowing (such as with no wire or a disconnected wire in the sensor) we can make a suggestion as to what tweaking might help. There is an interaction in that we get the multiplier correct and then use the offset to make it read zero when no current is flowing. Sometimes it takes a couple of tries. The suggested values from GRT for my sensor were Aux Scale Factor = 93 and Aux Offset = 177 so you probably have those set as a starting point if it is the same sensor and you are setting it for +/- 50 amps. Increasing the Aux Scale Factor to 94 would slightly raise all displayed readings especially the highest readings. If it then reads above zero with no current flowing you'd try tweaking the Aux Offset to maybe 175 to lower the zero current display a bit. Ken On 09/07/2016 5:11 PM, donjohnston wrote: > > Can you elaborate on the tweaking process? For example did you adjust the scale factor or offset? Which direction did you change for what effect? > > > yellowduckduo(at)gmail.co wrote: >> I can believe that wire size affects that sensor but not the hollow >> round 60 amp sensor that GRT sold me several years ago. >> The wonderful thing about the GRT sensor is that you can adjust the >> offset and scale for almost any sensor. IMO the values from GRT are >> simply a recommended starting value and all of my sensors benefited from >> some tweaking when I calibrated them. >> Ken >> >> On 09/07/2016 3:34 PM, donjohnston wrote: >> > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=458012#458012 > > > . > ________________________________________________________________________________
Date: Jul 09, 2016
FWIW, I spent a lot of years doing electronics repair, first on consumer products and then industrial products. The post-2010 failure pics all look like what electronics techs call 'cold solder joints'. Either bad prep (dirty contacts or leads), or inadequate heat when soldering. I've seen joint failures on circuit boards from TV sets that never move after installation to industrial equipment valued at 6-7 figures. Every time I dealt with it, cleaning the lead either mechanically (scraping) or by using a good electronics grade flux during the re-soldering process, cured the problem. I have no reason to doubt your word that the components can move if embedded in 'soft' potting compound, but.... in my opinion, a properly soldered joint on a pc board pad like that would not fail due to vibration. The pad/trace would peal up from the substrate, or the lead would break, before the solder joint to the lead would fail. Properly executed solder joints are much stronger than most people think. Charlie On 7/9/2016 6:24 PM, MMiller wrote: > > Bob > Here are the details of about a dozen Rotax regulator failures. Draw your own conclusion(s). > > First some background. There are several versions of the Rotax 912/Ducati regulator. Older versions include Rotax PN 965-345/Ducati 383475, I believe this is the version examined on the http://contrails.free.fr/elec_ducati_en.php website. This was replaced by Rotax PN 965-347/Ducati 343620. This version was manufactured until late 2009 and was replaced by the current version, Rotax PN 965-349/Ducati 362001. I believe this change was driven by component obsolescence, the button case diode was no longer produced. My findings show there are two failure modes, depending on the version of the regulator. > > The older pre 2010 regulators fail from the inability to adequately transfer heat from the diode assembly to the case. This causes the diodes to unsolder themselves from the assembly. Both diodes show signs of unsoldering, but, If look closely, the inboard diode always shows more heat damage then the outboard diode. This asymmetrical failure is likely caused by the asymmetrical geometry of the enclosure/heat sink. This is the only failure I have seen in this version regulator. This includes regulators with melted supply terminals (G pin,) the solder connections on these diodes show the same failure mode. I have not seen any component fail out of spec in any regulator examined. > Here a schematic/assy for this version > https://drive.google.com/open?id=0ByPxADyU-DwPdTQ3NWp5LW9iOHc > Typical failure mode > https://drive.google.com/open?id=0ByPxADyU-DwPTnlXcUVEQTdfcVU > > Current production since 2010 uses a different diode package. This resolved the internal heatsinking issue of the older regulator versions. Unfortunately, at this time they changed to gel type potting compound. All the examined failures of this version are likely caused by vibration. This failure is unique to the regulators with the new gel potting compound, this failure mode is nonexistent on the older version regulators. > Here a schematic/assy for this version > https://drive.google.com/open?id=0ByPxADyU-DwPWTBBcGlUeENTcHc > Here are some failure photos > https://drive.google.com/open?id=0ByPxADyU-DwPYm1rYUVsbUJyQ3M > > Heat is often the cause of failure in electronics, but these regulators fail from poor mechanical design and poor material choices, long before heat would kill them. > > > nuckolls.bob(at)aeroelect wrote: >> At 06:37 AM 7/5/2016, you wrote: >> >>> >>> Mike Miller has done autopsies on several failed Ducati regulators and he attributes the failures to poor manufacturing and vibration, >> vibration in a potted assembly? >> >> >>> not from heat. >> Has he published a teardown report? >> >> >>> Some RV-12 owners have reported a gradual failure where they get low voltage alarms at RPMs where they used to have normal voltage. Each regulator could fail differently. >> Color me skeptical . . . these regulators have >> been in production for decades. There must have >> been thousands sold. Over that period of time >> and numbers of examples, I find it curious that >> a constellation of failure modes would emerge. >> >> ..... >> >> Bob . . . > ________________________________________________________________________________
Date: Jul 10, 2016
Charlie, Yes I agree with you, that was my first thought also. But the more I looked at these, the more my option evolved. I lean towards vibration on this version for several reasons; 1). Sample 1of the post 2010 version photos had many failed solder joints but the ultimate failure was lead stress that sheared the gate pin at the body of the SCR. The same logic would suggest " how can this happen in a potted device." 2). This failure mode is nonexistent on the older versions without the gel type potting compound. 3). These don't fail out of the box, they run about 125 hours before failure...on average for these samples. ceengland7(at)gmail.com wrote: > > ...The post-2010 failure pics all look like what electronics techs call 'cold solder joints'. ... > ... > I have no reason to doubt your word that the components can move if > embedded in 'soft' potting compound, but.... in my opinion, a properly > soldered joint on a pc board pad like that would not fail due to > vibration. The pad/trace would peal up from the substrate, or the lead > would break, before the solder joint to the lead would fail. Properly > executed solder joints are much stronger than most people think. > > Charlie > > > > > Read this topic online here: http://forums.matronics.com/viewtopic.php?p=458033#458033 ________________________________________________________________________________
Subject: Electric Fuel Pressure Gauge
Date: Jul 10, 2016
How does an electric fuel pressure gauge work? Specifically, what power supply must be provided? What amperage? I am installing a Holly brand fuel pressure gauge on the fuel pressure regulator servicing the Bing 94 carburetor on my Rotec R2800 radial engine. The installation will be temporary during the Phase 1 flight test period. My idea is to power the gauge via the 12V accessory (cigarette lighter) outlet. Should this be an adequate power supply? Thanks. Ed Leineweber ________________________________________________________________________________
Date: Jul 10, 2016
Subject: Re: Electric Fuel Pressure Gauge
On Sun, Jul 10, 2016 at 6:24 AM, Ed Leineweber wrote: > How does an electric fuel pressure gauge work? Specifically, what power > supply must be provided? What amperage? > > > I am installing a Holly brand fuel pressure gauge on the fuel pressure > regulator servicing the Bing 94 carburetor on my Rotec R2800 radial > engine. The installation will be temporary during the Phase 1 flight test > period. My idea is to power the gauge via the 12V accessory (cigarette > lighter) outlet. Should this be an adequate power supply? > > > Thanks. > > > Ed Leineweber > What does the installation guide for the gauge say? If it's a typical off-the-shelf gauge that's sold for installation in cars, then 12V supply would be likely. Current consumption should be insignificant; milliamps rather than amps. Older 'can type' sensors work by pressure moving a diaphragm, which moves the 'wiper' of what amounts to a volume control, varying the voltage to the meter. Newer solid state sensors with 3 wires use a 'strain gauge' in the case. A lot of the solid state sensors expect to be supplied with 5V, but a dedicated gauge would likely supply the reduced voltage to the sensor. Charlie ________________________________________________________________________________
Date: Jul 10, 2016
At 07:46 AM 7/10/2016, you wrote: >On Sun, Jul 10, 2016 at 6:24 AM, Ed Leineweber ><edleine61(at)gmail.com> wrote: > >How does an electric fuel pressure gauge >work?=C2 Specifically, what power supply must be provided? What amperage? > >=C2 > >I am installing a Holly brand fuel pressure >gauge on the fuel pressure regulator servicing >the Bing 94 carburetor on my Rotec R2800 radial >engine.=C2 The installation will be temporary >during the Phase 1 flight test period.=C2 My idea >is to power the gauge via the 12V accessory >(cigarette lighter) outlet. Should this be an adequate power supply? I believe the vast majority of OEM and after market automotive instruments are of the 'moving magnet' variety. A magnet is mounted to a shaft such that it lies within the effects of two stationary, electromagnets. Energizing electromagnet 1 moves a pointer to one end of the scale, energizing EM2 moves it toward the other end of the scale. Emacs! The position of the pointer is the vector sum of the fields generated by the two electromagnets. Hence, the pointer depicts some ratio of the two energizing currents. The cool thing about this technique is simplicity of manufacture. The pointer doesn't need to have return springs. The magnet can be immersed in a damping fluid that causes it to integrate small fluctuations in the measured current thus giving a steady reading when the signal (like fuel sloshing in a tank) is wiggly. The positioning forces are large meaning that the pointer shaft need not be supported on low-friction bearings . . . often simply stuck through a hole in sheet metal or plastic. http://tinyurl.com/zlsovbe I've just installed a new 'sender' in my truck to replace one that blew a gasket and was leaking oil under 40psi pressure! The sender's specs call for a resistance of 10-180 ohms resistance over a 0 to 150 psi stimulus. http://tinyurl.com/jqh4umt This means that the instrument reading this variable resistance is designed to indicate 0 psi when current thru 10 ohms is impressed on the left-most coil and allowing the pointer to move toward the right-most coil as the resistance goes up to 180 ohms with increasing pressure. My new sender isn't the stock GMC part, so the instrument that came with the sender will have to be installed also. The instructions with this, and most after-market instruments will show three terminals on the back . . . one of which goes to 14v bus, one to ground, the other to the 'sender' which is grounded through its fitting to engine's crankcase. These two-coil instruments are generally limited to a small stroke scale . . . on the order of 90 degrees maximum and their accuracy is generally on the order of 5 to 10 percent of reading. Multi coil insturments can offer longer arcs . . . like speedometers. Further, when driven by software in ECUs, they can be much more accurate . . . perhaps 1-2 percent. In the case of the oil pressure instrument, the 'sender' (transducer) and instrument must be matched to each other. They consume very lo currents from the bus . . . on the order of 50 milliamps. Bob . . . ________________________________________________________________________________
Date: Jul 10, 2016
Subject: Short DB-9 shell?
Folks, Is there such a thing as a short DB-9 shell? The wire from this box is shoved up against the spar, as you can see in this photo https://goo.gl/photos/4K1n8VVHZKYNhioj6 If so, where would I get one? If not, what would you think of installing the connector without the shell but putting a cushion clamp near the box to provide strain relief? Thanks, -- Art Z. -- http://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Subject: Re: Short DB-9 shell?
Date: Jul 10, 2016
Maybe something like this will work for you, a side-entry DB9 backshell: Mouser Part #: 706-165X10439XE Manufacturer Part #: 165X10439XE > On Jul 10, 2016, at 10:35 AM, Art Zemon wrote: > > Folks, > > Is there such a thing as a short DB-9 shell? The wire from this box is shoved up against the spar, as you can see in this photo https://goo.gl/photos/4K1n8VVHZKYNhioj6 > > If so, where would I get one? > > If not, what would you think of installing the connector without the shell but putting a cushion clamp near the box to provide strain relief? > > Thanks, > -- Art Z. > > -- > http://CheerfulCurmudgeon.com/ > > "If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel ________________________________________________________________________________
Date: Jul 10, 2016
He is a link to Digi-Key's in-stock inventory of DB-9 backshells: http://tinyurl.com/jzxpt6z If you see one that looks short enough, just click the PDF icon in the left c olumn to view the datasheet, which should contain a drawing with dimensions. Eric > On Jul 10, 2016, at 11:35 AM, Art Zemon wrote: > Folks, > > Is there such a thing as a short DB-9 shell? The wire from this box is sho ved up against the spar, as you can see in this photo https://goo.gl/photos/ 4K1n8VVHZKYNhioj6 > > If so, where would I get one? > > If not, what would you think of installing the connector without the shell but putting a cushion clamp near the box to provide strain relief? > > Thanks, > -- Art Z. > > -- > http://CheerfulCurmudgeon.com/ > > "If I am not for myself, who is for me? And if I am only for myself, what a m I? And if not now, when?" Hillel ________________________________________________________________________________
Date: Jul 10, 2016
Digikey has a lot of 90 exit DB9 shells. Shield and non-shielded, plastic and metal, one piece and two piece. http://www.digikey.com/product-detail/en/norcomp-inc/981-009-130R121/981-09RCE-ND/1632178 Bill Putney - WB6RFW Chief Engineer KPTZ - Port Townsend, WA PP-SEL/A&P-IA "...you know me to be a very smart man. Don't you think if I were wrong, I'd know it?" -Sheldon Cooper On 7/10/16 8:35 AM, Art Zemon wrote: > Folks, > > Is there such a thing as a short DB-9 shell? The wire from this box is > shoved up against the spar, as you can see in this photo > https://goo.gl/photos/4K1n8VVHZKYNhioj6 > > If so, where would I get one? > > If not, what would you think of installing the connector without the > shell but putting a cushion clamp near the box to provide strain relief? > > Thanks, > -- Art Z. > > -- > http://CheerfulCurmudgeon.com/ > > /"If I am not for myself, who is for me? And if I am only for myself, > what am I? And if not now, when?" Hillel/ ________________________________________________________________________________
Date: Jul 10, 2016
Excellent! Thank you Daniel and Bill. Now that I know what it's called and where to shop, I can buy something that will work. -- Art Z. On Sun, Jul 10, 2016 at 11:34 AM, Bill Putney wrote: > Digikey has a lot of 90=C2=B0 exit DB9 shells. Shield and non-shielded, p lastic > and metal, one piece and two piece. > > > <http://www.digikey.com/product-detail/en/norcomp-inc/981-009-130R121/981 -09RCE-ND/1632178> > http://www.digikey.com/product-detail/en/norcomp-inc/981-009-130R121/981- 09RCE-ND/1632178 > > Bill Putney - WB6RFW > Chief Engineer > KPTZ - Port Townsend, WA > > PP-SEL/A&P-IA > > "...you know me to be a very smart man. Don't you think if I were wrong, I'd know it?" -Sheldon Cooper > > > On 7/10/16 8:35 AM, Art Zemon wrote: > > Folks, > > Is there such a thing as a short DB-9 shell? The wire from this box is > shoved up against the spar, as you can see in this photo > https://goo.gl/photos/4K1n8VVHZKYNhioj6 > > If so, where would I get one? > > If not, what would you think of installing the connector without the shel l > but putting a cushion clamp near the box to provide strain relief? > > Thanks, > -- Art Z. > > -- > http://CheerfulCurmudgeon.com/ > > *"If I am not for myself, who is for me? And if I am only for myself, wha t > am I? And if not now, when?" Hillel* > > -- http://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Date: Jul 10, 2016
Subject: Silent-Hektik Regulator
Okay, so I've decided I will take Bob's advice and not use the Ducati regulator and instead use the Silent-Hektik. I have a German connection that should be able to get one for me. There are (at least) two questions that I need answered to complete my wiring diagram for starting/charging/fuel pumps. 1. Does the Silent-Hektik need to be disconnected from the battery when the engine is not running, like the Ducati does (to keep from running down the battery). 2. Is there a prohibition (again, like the Ducati) against disconnecting the sensing wire from the bus while the engine is running? I have not been able to find any specific information on this regulator, other than its amp rating and its dimensions. Any help would be appreciated. Ken Ryan ________________________________________________________________________________
Date: Jul 10, 2016
Thanks for the help. It turns out to have been a grounding issue. The information in your post lead me to the answer. Thanks again. Ed Leineweber From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Sunday, July 10, 2016 10:16 AM Subject: Re: AeroElectric-List: Electric Fuel Pressure Gauge At 07:46 AM 7/10/2016, you wrote: On Sun, Jul 10, 2016 at 6:24 AM, Ed Leineweber > wrote: How does an electric fuel pressure gauge work?=C2 Specifically, what power supply must be provided? What amperage? =C2 I am installing a Holly brand fuel pressure gauge on the fuel pressure regulator servicing the Bing 94 carburetor on my Rotec R2800 radial engine.=C2 The installation will be temporary during the Phase 1 flight test period.=C2 My idea is to power the gauge via the 12V accessory (cigarette lighter) outlet. Should this be an adequate power supply? I believe the vast majority of OEM and after market automotive instruments are of the 'moving magnet' variety. A magnet is mounted to a shaft such that it lies within the effects of two stationary, electromagnets. Energizing electromagnet 1 moves a pointer to one end of the scale, energizing EM2 moves it toward the other end of the scale. The position of the pointer is the vector sum of the fields generated by the two electromagnets. Hence, the pointer depicts some ratio of the two energizing currents. The cool thing about this technique is simplicity of manufacture. The pointer doesn't need to have return springs. The magnet can be immersed in a damping fluid that causes it to integrate small fluctuations in the measured current thus giving a steady reading when the signal (like fuel sloshing in a tank) is wiggly. The positioning forces are large meaning that the pointer shaft need not be supported on low-friction bearings . . . often simply stuck through a hole in sheet metal or plastic. http://tinyurl.com/zlsovbe I've just installed a new 'sender' in my truck to replace one that blew a gasket and was leaking oil under 40psi pressure! The sender's specs call for a resistance of 10-180 ohms resistance over a 0 to 150 psi stimulus. http://tinyurl.com/jqh4umt This means that the instrument reading this variable resistance is designed to indicate 0 psi when current thru 10 ohms is impressed on the left-most coil and allowing the pointer to move toward the right-most coil as the resistance goes up to 180 ohms with increasing pressure. My new sender isn't the stock GMC part, so the instrument that came with the sender will have to be installed also. The instructions with this, and most after-market instruments will show three terminals on the back . . . one of which goes to 14v bus, one to ground, the other to the 'sender' which is grounded through its fitting to engine's crankcase. These two-coil instruments are generally limited to a small stroke scale . . . on the order of 90 degrees maximum and their accuracy is generally on the order of 5 to 10 percent of reading. Multi coil insturments can offer longer arcs . . . like speedometers. Further, when driven by software in ECUs, they can be much more accurate . . . perhaps 1-2 percent. In the case of the oil pressure instrument, the 'sender' (transducer) and instrument must be matched to each other. They consume very lo currents from the bus . . . on the order of 50 milliamps. Bob . . . ________________________________________________________________________________
Subject: Re: Silent-Hektik Regulator
Date: Jul 11, 2016
Here is a link for the Silent-Hektik wiring diagram: http://www.silent-hektik.de/E_R4112.pdf I assume that the "Kondens" is a condenser, aka capacitor; and that the "anlasser" is the starter. 1. Even though the diagram shows the regulator connected directly to the battery, I would connect it to the load side of the battery contactor instead. The electrons will not know the difference unless the master switch is shut off. 2. Even though the Rotax manual warns against disconnecting the sensing wire from the bus while the engine is running, that precaution is highly debatable. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=458063#458063 ________________________________________________________________________________
Date: Jul 11, 2016
Thanks for the link Joe! I wish these companies would pay a little money to a professional translator. Even Rotax, with all the money they must be making, cannot break loose with enough cash to pay a professional translator. So struggling through the language barrier, I find myself wondering what in the world this means: "A safety fuse between alternator-regulator and battery plus leads to a total failure in the case of insulate contact." Are they simply stating the obvious, that if the fuse blows you will lose the generator current? Or are they cautioning against putting a fuse in the battery plus lead because it could lead to total failure of the regulator? No fuses or breakers are shown in their drawing. With regards to Rotax's advice not to disconnect the sensing wire when the engine is running, I "think" these instructions state the same thing: "only connect or disconnect the cable from the ignitions system when the ignition system is turned off." Do you agree that is what the above sentence is saying? They also say "operating without battery or without cooling causes failure." Really? The Ducati regulator does not require a battery. Then, specific to Rotax 912 installation they say "the max length of the plus and minus cables is 50cm (20 inches) with *NO* (emphasis is theirs) fuses, switches or shunts." Another point of interest is that only the R wire goes to the capacitor. Every Rotax diagram that I have seen has at least the R and B+ going to the capacitor. Most also use the capacitor as a junction for R B+ and C. Any help figuring out exactly how to incorporate this regulator will be appreciated. FYI I have abandoned the idea of running the main pump directly off the regulator. The road I am following now is a variation on Bob's Z-13/8, Z-16, Rotax installation diagram, and all the good ideas I have gotten from this list. Basically, the 40 amp alternator will be primary and the 20 amp generator will be auxiliary, as in Z-13/8. I have it drawn out in rough and I think it works, but this new regulator info has me scratching my head, and before I post my drawing for review I need to actually understand the installation requirements for the Silent-Hektik. Ken On Mon, Jul 11, 2016 at 5:56 AM, user9253 wrote: > > Here is a link for the Silent-Hektik wiring diagram: > http://www.silent-hektik.de/E_R4112.pdf > I assume that the "Kondens" is a condenser, aka capacitor; and that the > "anlasser" is the starter. > 1. Even though the diagram shows the regulator connected directly to the > battery, I would connect it to the load side of the battery contactor > instead. The electrons will not know the difference unless the master > switch is shut off. > 2. Even though the Rotax manual warns against disconnecting the sensing > wire from the bus while the engine is running, that precaution is highly > debatable. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=458063#458063 > > ________________________________________________________________________________
Date: Jul 11, 2016
Le 11/07/2016 17:45, Ken Ryan a crit : > The Ducati regulator does not require a battery. Ken and all, It's been a long time since I designed our project circuits, but I had the impression thant this regulator actually does need a battery to operate. Back in 2003 when we conducted multiple tests with the Ducati regulator, we found that it needs some voltage to come to life, so we concluded that it was safer not to operate our electrically dependent aircraft without a correctly charged set of batteries. At the time we kept this 'List updated with our findings. Concerning the Silent Hektik, it seems it can be a direct swap with the Rotax/Ducati altenator, and can be wired liked suggested on fig Z16. FWIW -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Date: Jul 11, 2016
As an experiment, I connected a wire from the load side of the battery contactor to terminal "C" of the Ducati regulator. I went flying. At cruise speed, I turned off the master switch which disconnected the battery from the electrical system. As expected, nothing changed. Everything electrical kept right on working. Shutting off the master switch had no affect, except for an intermittent high voltage alarm. When the alarm sounded on the D-180, I was reluctant to increase the RPM, not wanting to destroy any avionics. Back on the ground, I downloaded the Dynon D-180 data to my computer to analyze. The maximum voltage of 14.7 occurred at about 5200 RPM. The voltage fluctuated between 13.25 and 14.7 So once enabled, the Ducati regulator will remain enabled by its own output voltage. The Ducati does not need a battery to continue operating. However, a connected battery will have a stabilizing affect on system voltage. Without a battery, the system voltage varied plus or minus 3/4 of a volt or 1.5 volts total. Based on this experiment, the Rotax charging system needs a battery for stability. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=458077#458077 ________________________________________________________________________________
Date: Jul 11, 2016
> Based on this experiment, the Rotax charging system needs a > battery for stability. Good data! Thanks for sharing Bob . . . ________________________________________________________________________________
Subject: Vertical Power VP-200
Date: Jul 12, 2016
Anyone know of any service available for a VP-200? Ours has a second problem before our first flight. When the company was sold all support for the VP-200 disappeared...can't even get a schematic, etc. Dee 804-677-4849 -------- DeWitt (Dee) Whittington Richmond, VA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=458111#458111 ________________________________________________________________________________
Subject: Re: Vertical Power VP-200
Date: Jul 12, 2016
Dee, Punch in VP200 and see lots of info on it. Larry On Jul 12, 2016, at 10:16 AM, hilltopkid wrote: > > Anyone know of any service available for a VP-200? Ours has a second problem before our first flight. When the company was sold all support for the VP-200 disappeared...can't even get a schematic, etc. > > Dee > 804-677-4849 > > -------- > DeWitt (Dee) Whittington > Richmond, VA > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=458111#458111 > > > > > > > > > > > ____________________________________________________________ Affordable Wireless Plans Set up is easy. Get online in minutes. Starting at only $9.95 per month! www.netzero.net?refcd=nzmem0216 ________________________________________________________________________________
Date: Jul 12, 2016
Contact the new owner "Astronics", I had to send in my CU for repair and they were very responsive ands it's been working great since I got it back. Astronics Ballard Technology The new home of Vertical Power products 11400 Airport Road Everett, WA 98204 Phone: 425.328.1658 Skype: VerticalPower Fax: 425.339.0915 Email: info(at)verticalpower.com Matt Dralle At 07:16 AM 7/12/2016 Tuesday, you wrote: > >Anyone know of any service available for a VP-200? Ours has a second problem before our first flight. When the company was sold all support for the VP-200 disappeared...can't even get a schematic, etc. > >Dee >804-677-4849 > >-------- >DeWitt (Dee) Whittington >Richmond, VA > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=458111#458111 - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 210+ Hours TTSN - Version 2.0 Now Flying! RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 300+ Hours - Full Flyer Mode! Matt's Livermore Airport Live ATC Stream! Check out the live ATC stream directly from my hangar at the Livermore Airport. Includes both Tower and Ground transmissions. Archives too! For entertainment purposes only. http://klvk.matronics.com ________________________________________________________________________________
Subject: Question OV Crowbar connection in Z16 figure
Date: Jul 13, 2016
I am in the designing stage for a new electrical system for my Rotax 912S powered Europa and am using Z16 as the basis. By now I have a pretty thorough understanding of the philosophy of Z16, but one question keeps popping up in my mind: Why is the positive side of the crowbar OV module connected to the 'downstream side' of the master switch? In my reasoning I believe it to be more robust to connect the positive side of the OV module to the downstream side of the 5A C/B. This would take the master switch and the wire between C/B and master switch out as potential points of failure during an O/V situation: Master Bus -> Fuselink > 18AWG wire > to C/B Then run 2 circuits from this C/B: (1) --> to OV Module (2) --> 22AWG wire > to Master Switch I know this would be a small amount of additional protection for situation that is likely to be very rare, but it's a very minor and easy change to Z16 so why not make this minor change? So basically what I would like to know: is there any reason why I should not connect it like this? -------- Marcel Zwakenberg XS TG || 912ULS || PH-SBR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=458125#458125 ________________________________________________________________________________
Date: Jul 13, 2016
Subject: Re: Question OV Crowbar connection in Z16 figure
At 09:10 AM 7/13/2016, you wrote: > >I am in the designing stage for a new electrical system for my Rotax >912S powered Europa and am using Z16 as the basis. By now I have a >pretty thorough understanding of the philosophy of Z16, but one >question keeps popping up in my mind: > >Why is the positive side of the crowbar OV module connected to the >'downstream side' of the master switch? > >In my reasoning I believe it to be more robust to connect the >positive side of the OV module to the downstream side of the 5A C/B. >This would take the master switch and the wire between C/B and >master switch out as potential points of failure during an O/V situation: You can do that . . . it makes no significant difference. Bob . . . ________________________________________________________________________________
From: "William Hunter" <billhuntersemail(at)gmail.com>
Subject: Optima Prius Battery For TIO-540
Date: Jul 13, 2016
Greetings, I am building a Dual Battery/Dual Alternator electrical system for a single Engine Velocity. The engine is a TIO-540 (turbo) and I notate this because the engine only has 7.3 to one compression pistons so therefore the starter motor will not have to fight against the usual 8.3 to 1 compression. One battery will be mounted in the nose and one battery will be mounted under the back seat. Optima sells a 12V Prius battery that they advertise as "38 AH / CCA of 450 amps / MCA of 575 amps" and this battery is only 26 LBS. http://www.optimabatteries.com/en-us/shop/yellowtop/optima-batteries-ds46b24 r-yellowtop-prius-auxiliary-battery/ Concord has a "Platinum Series" replacement battery for a Aztec and this airplane has an IO-540 (with normal compression pistons) and the top of the line Concord battery advertises Rated Capacity C1 = 1 hr. rate in ampere hours 33.00 Cold Cranking Amps 440.0 and it is 33 pounds. Even though my airplane will have two batteries I still want to be able to start my 6 banger engine with a single battery. Does the collective wisdom on this forum believe that a singular Prius battery will be sufficient for the starting of my engine? .. THANKS!!! Bill Hunter ________________________________________________________________________________
Subject: Lay Flat Battery Contactor and Starter Relay
Date: Jul 13, 2016
I vaguely remember one of Bob's majestic musings that articulately dispelled the long time myth mandating that battery contactors and starter relays must be installed vertically against a wall and not installed flat on a floorboard. My proposed installation of mounting them on a wall is not going to work and I want to mount them under the back seat against the floorboards. Can someone please confirm that my recollection described above is indeed accurate and I was not just dreaming Bob's majestic words?!?!? .. Cheers!!! Bill Hunter ________________________________________________________________________________
Subject: Re: Lay Flat Battery Contactor and Starter Relay
Date: Jul 13, 2016
Don't know about the general battery contractor, but I have heard that the s tarter solenoid should not be mounted upright since in the open position the disconnection is created by a spring and in a hard landing (which we never d o) momentum will cause the contactor to close momentarily and possibly do da mage to the starter ring on the flywheel or the gear on the starter motor. My starter contactor's mounting flange is such that it demands to be mounted in a horizontal orientation unless I Mage an angle bracket No worry about the general contactor as it will be closed (against the sprin g) when landing Rich Sent from my iPhone > On Jul 13, 2016, at 7:02 PM, William Hunter w rote: > > I vaguely remember one of Bob=99s majestic musings that articulately dispelled the long time myth mandating that battery contactors and starter r elays must be installed vertically against a wall and not installed flat on a floorboard. My proposed installation of mounting them on a wall is not goi ng to work and I want to mount them under the back seat against the floorboa rds. > > Can someone please confirm that my recollection described above is indeed a ccurate and I was not just dreaming Bob=99s majestic words?!?!? > > .. > > Cheers!!! > > Bill Hunter ________________________________________________________________________________
Date: Jul 13, 2016
Date: Jul 14, 2016
Subject: Re: Optima Prius Battery For TIO-540
On Wed, Jul 13, 2016 at 6:54 PM, William Hunter wrote: > Greetings, > > > I am building a Dual Battery/Dual Alternator electrical system for a > single Engine Velocity. The engine is a TIO-540 (turbo) and I notate thi s > because the engine only has 7.3 to one compression pistons so therefore t he > starter motor will not have to fight against the usual 8.3 to 1 > compression. One battery will be mounted in the nose and one battery wil l > be mounted under the back seat. > > > Optima sells a 12V Prius battery that they advertise as =9C38 AH / CCA of > 450 amps / MCA of 575 amps=9D and this battery is only 26 LBS. > > > http://www.optimabatteries.com/en-us/shop/yellowtop/optima-batteries-ds46 b24r-yellowtop-prius-auxiliary-battery/ > > > Concord has a =9CPlatinum Series=9D replacement battery for a Aztec and this > airplane has an IO-540 (with normal compression pistons) and the top of t he > line Concord battery advertises Rated Capacity C1 = 1 hr. rate in amper e > hours 33.00 Cold Cranking Amps 440.0 and it is 33 pounds. > > > Even though my airplane will have two batteries I still want to be able t o > start my 6 banger engine with a single battery. > > > Does the collective wisdom on this forum believe that a singular Prius > battery will be sufficient for the starting of my engine? > > .. > > > THANKS!!! > > > Bill Hunter > > Bill, For perspective, I looked up a Gill flooded cell battery (old style with liquid acid & fill caps) designed many decades ago to crank 'big sixes'. It's also 35AH, but only 250 CCA. http://www.aircraftspruce.com/catalog/elpages/gillg35.php Pretty sure the Optima will crank your 6cyl engine. :-) Most of the AGM (starved electrolyte) batteries have significantly higher CCA than flooded cell batteries with the same 20 hour rating (the '35AH' number, in your case). For example, a lot of us with 4 cyl engines use 'no name' 18AH to 22AH AGM batteries to replace the certified 25AH flooded cell batteries originally used with these engines. Even with significantly lower total energy (~20AH vs 25AH), the AGM battery will spin the engine almost fast enough to taxi the plane. :-) Reason is, the AGM can deliver more *power*, short term, than a flooded cell battery. Only downside is that if forced to fly on battery power alone, it will run down faster than the 25AH battery. In your case, both batteries have the same AH rating, so should have the same alternator-out endurance. Charlie ________________________________________________________________________________
Date: Jul 14, 2016
On Wed, Jul 13, 2016 at 7:02 PM, William Hunter wrote: > I vaguely remember one of Bob=99s majestic musings that articulatel y > dispelled the long time myth mandating that battery contactors and starte r > relays must be installed vertically against a wall and not installed flat > on a floorboard. My proposed installation of mounting them on a wall is > not going to work and I want to mount them under the back seat against th e > floorboards. > > > Can someone please confirm that my recollection described above is indeed > accurate and I was not just dreaming Bob=99s majestic words?!?!? > > > .. > > > Cheers!!! > > > Bill Hunter > IIRC, one dispelled myth was the idea that if you mounted them upside down, pulling Gs in the plane could open them. The only issue I could see with 'side mounting' would be asymmetrical wear of the guide that the metal 'slug' moves in. Of course, you can always just make a right angle bracket & mount it on the floor, if you want to keep conventional orientation. Charlie ________________________________________________________________________________
Date: Jul 14, 2016
From: William Hunter <billhuntersemail(at)gmail.com>
Thanks Charlie for validating my thought process!!! Greatly appreciated!!! Bill Hunter On Jul 14, 2016 06:25, "Charlie England" wrote: > > > On Wed, Jul 13, 2016 at 6:54 PM, William Hunter < > billhuntersemail(at)gmail.com> wrote: > >> Greetings, >> >> >> >> I am building a Dual Battery/Dual Alternator electrical system for a >> single Engine Velocity. The engine is a TIO-540 (turbo) and I notate th is >> because the engine only has 7.3 to one compression pistons so therefore the >> starter motor will not have to fight against the usual 8.3 to 1 >> compression. One battery will be mounted in the nose and one battery wi ll >> be mounted under the back seat. >> >> >> >> Optima sells a 12V Prius battery that they advertise as =9C38 AH / CCA of >> 450 amps / MCA of 575 amps=9D and this battery is only 26 LBS. >> >> >> >> >> http://www.optimabatteries.com/en-us/shop/yellowtop/optima-batteries-ds4 6b24r-yellowtop-prius-auxiliary-battery/ >> >> >> >> Concord has a =9CPlatinum Series=9D replacement battery for a Aztec and this >> airplane has an IO-540 (with normal compression pistons) and the top of the >> line Concord battery advertises Rated Capacity C1 = 1 hr. rate in ampe re >> hours 33.00 Cold Cranking Amps 440.0 and it is 33 pounds. >> >> >> >> Even though my airplane will have two batteries I still want to be able >> to start my 6 banger engine with a single battery. >> >> >> >> Does the collective wisdom on this forum believe that a singular Prius >> battery will be sufficient for the starting of my engine? >> >> .. >> >> >> >> THANKS!!! >> >> >> >> Bill Hunter >> >> Bill, > > For perspective, I looked up a Gill flooded cell battery (old style with > liquid acid & fill caps) designed many decades ago to crank 'big sixes'. > It's also 35AH, but only 250 CCA. > http://www.aircraftspruce.com/catalog/elpages/gillg35.php > > Pretty sure the Optima will crank your 6cyl engine. :-) Most of the AGM > (starved electrolyte) batteries have significantly higher CCA than floode d > cell batteries with the same 20 hour rating (the '35AH' number, in your > case). For example, a lot of us with 4 cyl engines use 'no name' 18AH to > 22AH AGM batteries to replace the certified 25AH flooded cell batteries > originally used with these engines. Even with significantly lower total > energy (~20AH vs 25AH), the AGM battery will spin the engine almost fast > enough to taxi the plane. :-) Reason is, the AGM can deliver more *power* , > short term, than a flooded cell battery. Only downside is that if forced to > fly on battery power alone, it will run down faster than the 25AH battery . > In your case, both batteries have the same AH rating, so should have the > same alternator-out endurance. > > Charlie > ________________________________________________________________________________
Date: Jul 14, 2016
Hmmmmmm thanks for the info and I will look today to see if I can mount these little buggers on brackets Bill Hunter +1 408-464-1902 On Jul 14, 2016 6:45 AM, "Charlie England" wrote: > > > On Wed, Jul 13, 2016 at 7:02 PM, William Hunter < > billhuntersemail(at)gmail.com> wrote: > >> I vaguely remember one of Bob=99s majestic musings that articulate ly >> dispelled the long time myth mandating that battery contactors and start er >> relays must be installed vertically against a wall and not installed fla t >> on a floorboard. My proposed installation of mounting them on a wall is >> not going to work and I want to mount them under the back seat against t he >> floorboards. >> >> >> >> Can someone please confirm that my recollection described above is indee d >> accurate and I was not just dreaming Bob=99s majestic words?!?!? >> >> >> >> .. >> >> >> >> Cheers!!! >> >> >> >> Bill Hunter >> > IIRC, one dispelled myth was the idea that if you mounted them upside > down, pulling Gs in the plane could open them. > > The only issue I could see with 'side mounting' would be asymmetrical wea r > of the guide that the metal 'slug' moves in. Of course, you can always ju st > make a right angle bracket & mount it on the floor, if you want to keep > conventional orientation. > > Charlie > ________________________________________________________________________________
Date: Jul 14, 2016
Subject: Contactor orientation
I've heard a boat load of narratives and anecdotes concerning contactor orientation in aircraft. Most of the 'advice' goes to the 'whisky barrel' style contactors from White-Rogers and Cole-Hersey. The first time I recall such a story was a OSH back about 1990 . . . an airshow performer showed up at the B&C booth to buy a new starter and contactor. Seems his contactor was stuck and the starter gears chewed up. He hypothesized that g-loads during his show teased the contactor closed followed by a welding of contacts and an engaged starter. In years since, many more tidbits of sage advice on contactor orientation have appeared throughout the OBAM aviation industry. I have yet to put my hands on any failure of hardware that supports any notion of risk due to airframe induced g-loads. The tear-downs I've conducted fall into three primary categories: (1) Wear out. Contactor has been in service a long time. Contacts are worn. No other evidence of stress such as moisture, broken parts, mis-installation. I.e. the thing went to end of service life. (2) Moisture ingress: contacts, springs, plunger, case badly rusted. See: http://tinyurl.com/p2x7fbl (3) Installation/Manufacturing error: Failure to solder coil wires to terminals, main terminals twisted out of alignment during torque-down of terminal nuts, bit of debris between contacts, exposed to gross external moisture, etc. If you think about it, the plunger in a starter contactor mounted on fire wall moves PARALLED to fuselage axis. Mounted terminals up, it takes NEGATIVE g's to close contact. A whisky-barrel battery contactor is already CLOSED any time aircraft is in motion. A transient cross-feed contactor closure presents no potential hazard. In 40+ years of working with these devices, I have yet to see any evidence that supports the widely circulated fears for 'correct' contactor orientation in airplanes. By the way, I've see hundreds of installations of contactors in TC aircraft for ALL orientations . . . I've never heard of it being any kind of 'problem'. If I were going to posit a bit of advice for orientation it would be to mount the whisky barrel contactor CAP DOWN after first PUNCHING a very small hole in the center of the cap. This is for draining moisture that MIGHT get inside if the contactor experiences long periods of condensing moisture and/or splash. Don't drill the hole . . . you may drop a chip into the interior. Having a drain hole can be the bane of your contactor's existence. See photo series at http://tinyurl.com/p2x7fbl Note in particular what appears to be a factory provided drain hole in pictures 10 and 11. At the same time, severity and range of rust on the interior parts along with rust patters on both sides of the cap suggest that this contactor was installed DRAIN up. Short answer: I have yet to identify a justification for recommending a contactor installation orientation with a goal of reducing risk to system due to operational g-loads. Bob . . . ________________________________________________________________________________
Date: Jul 14, 2016
Thanks Bob for confirming! -------- Marcel Zwakenberg XS TG || 912ULS || PH-SBR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=458185#458185 ________________________________________________________________________________
Date: Jul 14, 2016
Subject: Re: Contactor orientation
I am a little confused about your statement, " If you think about it, the plunger in a starter contactor mounted on fire wall moves PARALLED to fuselage axis..". Although the device moves parallel to the fuselage, that is really a non-issue. even with severe aerobatics. It is when a hard landing occurs that the spring which keeps the contacting mechanism open can be compressed and contact made. The contact mechanism I think a thick washer) and its associated armature have mass. When the aircraft hits the ground it stops its downward movement but momentum makes the contact mechanism and armature continue on its downward movement compressing the spring. Added to that, the aircraft rebounds and not only does the contact mechanism continue to move downward, the shell of the solenoid, being connected to the firewall is now moving upward increasing the possibility that the contactor will contact, until the energy contained in the spring overcomes the closing movement of the contactor---or the contactor actually makes contact, at which the spring disengages it. Actually, if you look at ACS starter solenoid (contactor) you will see that the terminals are on the top of the "can", the lower part is the electromagnet which pulls the armature (connected to the actual contact device) downward to complete the circuit. It has to be held up (open) by a compression spring. The pilot will never notice that this happens save for the possibility of damaged gears which will probably be blamed on something else. Rich In a message dated 7/14/2016 11:13:32 A.M. Pacific Daylight Time, nuckolls.bob(at)aeroelectric.com writes: I've heard a boat load of narratives and anecdotes concerning contactor orientation in aircraft. Most of the 'advice' goes to the 'whisky barrel' style contactors from White-Rogers and Cole-Hersey. The first time I recall such a story was a OSH back about 1990 . . . an airshow performer showed up at the B&C booth to buy a new starter and contactor. Seems his contactor was stuck and the starter gears chewed up. He hypothesized that g-loads during his show teased the contactor closed followed by a welding of contacts and an engaged starter. In years since, many more tidbits of sage advice on contactor orientation have appeared throughout the OBAM aviation industry. I have yet to put my hands on any failure of hardware that supports any notion of risk due to airframe induced g-loads. The tear-downs I've conducted fall into three primary categories: (1) Wear out. Contactor has been in service a long time. Contacts are worn. No other evidence of stress such as moisture, broken parts, mis-installation. I.e. the thing went to end of service life. (2) Moisture ingress: contacts, springs, plunger, case badly rusted. See: http://tinyurl.com/p2x7fbl (3) Installation/Manufacturing error: Failure to solder coil wires to terminals, main terminals twisted out of alignment during torque-down of terminal nuts, bit of debris between contacts, exposed to gross external moisture, etc. If you think about it, the plunger in a starter contactor mounted on fire wall moves PARALLED to fuselage axis. Mounted terminals up, it takes NEGATIVE g's to close contact. A whisky-barrel battery contactor is already CLOSED any time aircraft is in motion. A transient cross-feed contactor closure presents no potential hazard. In 40+ years of working with these devices, I have yet to see any evidence that supports the widely circulated fears for 'correct' contactor orientation in airplanes. By the way, I've see hundreds of installations of contactors in TC aircraft for ALL orientations . . . I've never heard of it being any kind of 'problem'. If I were going to posit a bit of advice for orientation it would be to mount the whisky barrel contactor CAP DOWN after first PUNCHING a very small hole in the center of the cap. This is for draining moisture that MIGHT get inside if the contactor experiences long periods of condensing moisture and/or splash. Don't drill the hole . . . you may drop a chip into the interior. Having a drain hole can be the bane of your contactor's existence. See photo series at http://tinyurl.com/p2x7fbl Note in particular what appears to be a factory provided drain hole in pictures 10 and 11. At the same time, severity and range of rust on the interior parts along with rust patters on both sides of the cap suggest that this contactor was installed DRAIN up. Short answer: I have yet to identify a justification for recommending a contactor installation orientation with a goal of reducing risk to system due to operational g-loads. Bob . . . ________________________________________________________________________________
Date: Jul 14, 2016
Subject: Speaking of 'drain holes' . . .
While I was working at Cessna, back in the dark ages, the single engine cowls were modified to mount onto brackets riveted to the firewall. These brackets were fitted with rubber shock mounts with Dzuse sockets. The idea was to 'float' the cowl off the fuselage structure for reduction of engine noise in the cabin. Emacs! Prior to the floating cowl, a contiguous cowl mounting flange extended forward off the firewall. After the floating cowl upgrade, fielded aircraft began experiencing contactor failures due to moisture ingress. It seems that an airplane getting a cooling rain on a warm day experienced water splash on cowl mounted equipment. A whisky barrel contactor's temperature was dropped by the cool water, internal pressure went down and liquid water was literally sucked inside. The same water had to get back out through successive atmospheric 'breathing' which could take days of cycles. In the mean time, the 100% humidity inside the contactor wreaked havoc with the devices innards. The first attempt to 'fix' the problem involved manual application of epoxy around all the obvious ingress gaps in the enclosure. Not sure what the effectiveness of this fix was but it was not total . . . Any of the tiniest holes still provided a moisture entry point while further restricting egress through atmospheric breathing. Had a similar problem I wrestled with on an amateur radio repeater on the 1200' platform at KTVH, Hutchinson, KS. A brand new Motorola Micor repeater would go off the air every time it rained and stayed off for hours until it dried out. We set out to 'seal' the cabinet but attempts to close it only made things worse . . . the more we 'sealed' the longer it took to dry out. Recalling my observations years earlier at Cessna, we opened the cabinet up. Installed baffled ducts for air inlet and mounted fans to maintain a good positive airflow. The repeater might still go off the air during a really big frog strangler . . . but would be back on minutes after the rain ceased. Moral of the story: Unless your enclosure is HERMETICALLY sealed, then any attempts improve moisture control with goo, glue, gaskets, etc may prove ineffectual if not antagonistic. In the case of the whisky barrel contactor 'drain' hole, I suggest it is more of a VENT hole. It prevents atmospheric cooling inside from reducing pressure and drawing the moisture inside in the first place. That contactor mounted vent hole up was a contactor waiting to be trashed. Mounted vent hole down, it would probably have died of old age having ingested NO liquid water over its lifetime . . . and if it did . . . it would not have risen high enough to wet the innards. It would have been readily ejected during subsequent atmospheric breathings. Bob . . . ________________________________________________________________________________
Date: Jul 14, 2016
> > >Even though my airplane will have two batteries I still want to be >able to start my 6 banger engine with a single battery. > >Does the collective wisdom on this forum believe that a singular >Prius battery will be sufficient for the starting of my engine? Many moons ago, B&C did some testing on one of their SMALLER SVLA batteries for cranking a high performance engine on an aerobatic aircraft. As I recall, they performed 5 or 6, 10-blade cranking events before the starter performance began to noticeably flag. Cranking performance has more do to with LOOP RESISTANCE in the wiring path and CONDITION of the battery than with gross battery size. Fitting your airplane with such beastly batteries in a quest for starting performance seems a bit counter-intuitive . . . it is, after all, an airplane. Any increase in empty weight should equate to some highly desired performance gain. Keep in mind that getting your engine started generally uses only a few percent of total stored energy. Just as B&C demonstrated years ago, having an energetic little SVLA battery wired to the starter with low loss wiring and controls proved very adequate to the starting task. If you're planning dual alternator, dual battery with a split bus (Z-14) then battery integrity is very low on the system reliability totem pole. I would go for two of the smallest practical batteries mounted as close to the engine as practical so that their energy is not wasted getting it piped around the airplane. Why the desire to start on one battery? Do you not plan to maintain your batteries with the same due diligence as you would tires, oil changes, fuel in tanks, spark plugs, prop nicks, brake fluid level, etc. etc? With that much engine driven power there is little performance gain to be secured by carrying around a lot of lead. If it were my airplane, I would use two of the smallest practical batteries located as described above. A pair of 18A.h. batteries should be fine. Plan on both batteries for cranking and the either (1) cap check the batteries every 100 hrs or annual with a goal of discarding at 80% of new capacity -OR- (2) put a new battery in the main battery slot every year and move the year-old main battery to the aux battery slot. That way, you have one battery always less than a year old, no battery more than two years old and no need to cap check. The only reason to worry about getting started on one battery is because you don't have the foggiest notion of the condition of either battery. Batteries, PROPERLY MAINTAINED, are the most reliable source of energy in your airplane. Carrying around two, oversized batteries is not a good substitute for knowing their condition. Bob . . . ________________________________________________________________________________
Subject: Can Someone PLEASE Double Check My Homework?!?!?!
Date: Jul 14, 2016
I am building a dual bus ala'Bob and I am hopeful someone would PLEASE double check my homework. Attached is a picture of what I want to do. Do I have the cables connected to the correct side of the ties? THANKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! .. Cheers!!! Bill Hunter ________________________________________________________________________________
Date: Jul 14, 2016
THANKS Bob for your help and thoughts on this!!! Yes.I read your book (multiple times) and yes maintain the batteries and will swap them out every two years whether they need it or not. I bought a flying Velocity and it came with two batteries mounted in the nose. The larger battery is a 54 pound Optima Red Top and the small battery is a 26 pound Power Sonic 26 Ampere Hour 12260 NB. As per your book I am moving one battery to the firewall (closer to the starter) and leaving the other battery in the nose (weight and balance reasons). I am switching the Power Sonic out for a 26 pound Optima Yellow Top AGM Group Size: JIS 46B24R (Prius Battery) and next year the huge Optima Red Top will most likely go with your recommended battery and go with the annual switch program. .. Cheers!!! Bill Hunter From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Thursday, July 14, 2016 12:17 PM Subject: Re: AeroElectric-List: Optima Prius Battery For TIO-540 Even though my airplane will have two batteries I still want to be able to start my 6 banger engine with a single battery. Does the collective wisdom on this forum believe that a singular Prius battery will be sufficient for the starting of my engine? Many moons ago, B&C did some testing on one of their SMALLER SVLA batteries for cranking a high performance engine on an aerobatic aircraft. As I recall, they performed 5 or 6, 10-blade cranking events before the starter performance began to noticeably flag. Cranking performance has more do to with LOOP RESISTANCE in the wiring path and CONDITION of the battery than with gross battery size. Fitting your airplane with such beastly batteries in a quest for starting performance seems a bit counter-intuitive . . . it is, after all, an airplane. Any increase in empty weight should equate to some highly desired performance gain. Keep in mind that getting your engine started generally uses only a few percent of total stored energy. Just as B&C demonstrated years ago, having an energetic little SVLA battery wired to the starter with low loss wiring and controls proved very adequate to the starting task. If you're planning dual alternator, dual battery with a split bus (Z-14) then battery integrity is very low on the system reliability totem pole. I would go for two of the smallest practical batteries mounted as close to the engine as practical so that their energy is not wasted getting it piped around the airplane. Why the desire to start on one battery? Do you not plan to maintain your batteries with the same due diligence as you would tires, oil changes, fuel in tanks, spark plugs, prop nicks, brake fluid level, etc. etc? With that much engine driven power there is little performance gain to be secured by carrying around a lot of lead. If it were my airplane, I would use two of the smallest practical batteries located as described above. A pair of 18A.h. batteries should be fine. Plan on both batteries for cranking and the either (1) cap check the batteries every 100 hrs or annual with a goal of discarding at 80% of new capacity -OR- (2) put a new battery in the main battery slot every year and move the year-old main battery to the aux battery slot. That way, you have one battery always less than a year old, no battery more than two years old and no need to cap check. The only reason to worry about getting started on one battery is because you don't have the foggiest notion of the condition of either battery. Batteries, PROPERLY MAINTAINED, are the most reliable source of energy in your airplane. Carrying around two, oversized batteries is not a good substitute for knowing their condition. Bob . . . ________________________________________________________________________________
Subject: Re: Can Someone PLEASE Double Check My Homework?!?!?!
Date: Jul 14, 2016
Do the banded ends of the diodes connect to the positive side of the coils? If so, OK. I can not tell from the picture. The lower right contactor looks like it has an extra diode that connects the two fat terminals together. Is that what it is, a diode? If so, it is in parallel with the contactor and will be destroyed by high current. A schematic would be easier for me to understand than the picture. If the mounting surface vibrates, flexible cables are better than a bus bar. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=458197#458197 ________________________________________________________________________________
Date: Jul 14, 2016
>At 01:37 PM 7/14/2016, you wrote: >I am a little confused about your statement, > >" If you think about it, the plunger in a starter >contactor mounted on fire wall moves PARALLED to >fuselage axis..". > >Although the device moves parallel to the fuselage, that is >really a non-issue. even with severe aerobatics. It is when a hard >landing occurs that the spring which keeps the contacting mechanism >open can be compressed and contact made. Okay, the plunger mass moves along the longitudinal axis of the aircraft. All the flight dynamics plots I've observed speak to really big loads along Z-axis, this is the one that breaks the wings off. What is the forcing function that accelerates the fuselage along the X-axis with any degree of robustness in a 'hard' landing? > The contact mechanism I think a thick washer) Not exactly . . . Emacs! > and its associated armature have mass. Yes, but even less than the legacy whisky-barrel contactor . . . Emacs! > When the aircraft hits the ground it stops its downward movement > but momentum makes the contact mechanism and armature continue on > its downward movement compressing the spring. Actually, aircraft Z-axis acceleration is at 90 degrees to the contractor's stroke axis. > Added to that, the aircraft rebounds and not only does the contact > mechanism continue to move downward, the shell of the solenoid, > being connected to the firewall is now moving upward increasing > the possibility that the contactor will contact, until the energy > contained in the spring overcomes the closing movement of the > contactor---or the contactor actually makes contact, at which the > spring disengages it. Assuming contactor closure CAN be achieved with airframe g-loads . . . what do you suppose the duration of closure might be? What is the delay between first application of power to a starter until the pinion gear is extended and gears make contact? Assuming they do make 'contact' what is the behavior of starter's parts? Contactor closure times are at best measured in tens of millisonde. Time from first energization of starter to gear tooth engagement is many tens of milliseconds . . . perhaps as much as 200. When the ring gear tries to drive the starter pinion, the output shaft will spin ahead of motor velocity due to the starter's built in over-run clutch. > > >Actually, if you look at ACS starter solenoid (contactor) you will >see that the terminals are on the top of the "can", the lower part >is the electromagnet which pulls the armature (connected to the >actual contact device) downward to complete the circuit. It has to >be held up (open) by a compression spring. If you study the disassembly photos of an exemplar contactor at . . . http://tinyurl.com/o5turon Energizing this style of contactor LIFTS the armature and pushes a very light moving contact up against the inside of the dome which mounts the contact studs. The return spring resides between the stationary contacts. > >The pilot will never notice that this happens save for the >possibility of damaged gears which will probably be blamed >on something else. You're right. The pilot who bought a new starter and contactor at OSH was unaware that his starter had probably been engaged for the duration of his performance . . . not because of some transient g-loading but more likely from contact welding promoted by low battery voltage. G-loading to contactor mounted on the fire wall isn't even on the right axis for moving the contactor's inner workings. Even if the contactor were mounted upside down . . . maintained a Z-axis g-load induced contact for an interval needed to get the pinion gears extended is problematic. Bob . . . ________________________________________________________________________________
Date: Jul 14, 2016
Thanks for your kind reply! The top-left contactor is a BNC S701-1 and the bottom-right contactor is a BNC S701-2. I believe the design of the S70 1-1 battery contactor is such that you're supposed to connect the battery positive to the left hand Pole and the electricity flows from left to right. The diode is as delivered and the silver band is to the left Pole. The bottom-right contactor is supposed to be a bus tie... the idea for the system is when the bus tie switch is off (not grounded) then the left-hand electrical system is powering the left bus independently and the right-hand electrical system is powering the right-hand bus independently. When the bus tie switch is turned on (ground introduced) then that bus tie contactor acts as the connection between the left hand system and the right hand system. I do not intend to have the bus tie to automatically close with the starter switch so the question I have is... what Pole do I connect the bus tie switch grounding wire to? THANKS!!! Bill Hunter +1 408-464-1902 On Jul 14, 2016 15:50, "user9253" wrote: > > Do the banded ends of the diodes connect to the positive side of the > coils? If so, OK. I can not tell from the picture. > The lower right contactor looks like it has an extra diode that connects > the two fat terminals together. Is that what it is, a diode? If so, it is > in parallel with the contactor and will be destroyed by high current. A > schematic would be easier for me to understand than the picture. > If the mounting surface vibrates, flexible cables are better than a bus > bar. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=458197#458197 > > ________________________________________________________________________________
Date: Jul 14, 2016
Not sure if I can find it again but Cessna Pilots Assn had an article on contactors and orientation about a year ago. One of the interesting quirks was the mention of a mislabeled contactor that was routinely installed incorrectly at the factory resulting in several instances of starter engagement many years after the install. I'll see if I can find it again. Jim Baker 405 426 5377 ________________________________________________________________________________
Date: Jul 14, 2016
Also... since the starter relay is powered by a 12-volt source it I ASS-U-ME it does not matter what side of the relay is the power side and what side goes to the starter motor... is this correct? Bill Hunter Bill Hunter +1 408-464-1902 On Jul 14, 2016 6:33 PM, "William Hunter" wrote: > Thanks for your kind reply! > > The top-left contactor is a BNC S701-1 and the bottom-right contactor is a > BNC S701-2. > > I believe the design of the S70 1-1 battery contactor is such that you're > supposed to connect the battery positive to the left hand Pole and the > electricity flows from left to right. The diode is as delivered and the > silver band is to the left Pole. > > The bottom-right contactor is supposed to be a bus tie... the idea for the > system is when the bus tie switch is off (not grounded) then the left-hand > electrical system is powering the left bus independently and the right-hand > electrical system is powering the right-hand bus independently. > > When the bus tie switch is turned on (ground introduced) then that bus tie > contactor acts as the connection between the left hand system and the right > hand system. > > I do not intend to have the bus tie to automatically close with the > starter switch so the question I have is... what Pole do I connect the bus > tie switch grounding wire to? > > THANKS!!! > > Bill Hunter > +1 408-464-1902 > > On Jul 14, 2016 15:50, "user9253" wrote: > >> >> Do the banded ends of the diodes connect to the positive side of the >> coils? If so, OK. I can not tell from the picture. >> The lower right contactor looks like it has an extra diode that >> connects the two fat terminals together. Is that what it is, a diode? If >> so, it is in parallel with the contactor and will be destroyed by high >> current. A schematic would be easier for me to understand than the picture. >> If the mounting surface vibrates, flexible cables are better than a bus >> bar. >> >> -------- >> Joe Gores >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=458197#458197 >> >> >> >> >> >> >> >> >> >> >> ________________________________________________________________________________
Date: Jul 14, 2016
At 08:50 PM 7/14/2016, you wrote: > >Not sure if I can find it again but Cessna Pilots Assn had an >article on contactors and orientation about a year ago. One of the >interesting quirks was the mention of a mislabeled contactor that >was routinely installed incorrectly at the factory resulting in >several instances of starter engagement many years after the >install. I'll see if I can find it again. Super! I've got good G2 at Cessna . . . it will be interesting to see which parts were involved. Bob . . . ________________________________________________________________________________
Date: Jul 14, 2016
At 05:20 PM 7/14/2016, you wrote: > >Do the banded ends of the diodes connect to the positive side of the >coils? If so, OK. I can not tell from the picture. The S701-1 and -2 contactors START with the same, 4-terminal, off-the-shelf device. When used as a S702-2, bus tie contactor the schematic looks like this excerpt from Z-14. TWO diodes provide power to energize the contactor from either bus . . . this insures that you can get the cold bus connected to the hot one no matter which is which. The THIRD diode is the legacy coil suppression device. Emacs! A photo of the as-aSsembled product from B&C looks like this: Emacs! The S701-1 contactor is for more rudimentary tasks like battery contactors. Here you only need the coil suppression diode and the schematic looks like this: Emacs! And the finished product looks like this Emacs! Bob . . . ________________________________________________________________________________
Date: Jul 15, 2016
Jim Baker, the CPA contactor article you are looking for appeared in the April 2015 issue of their magazine. -------- Jerry King Read this topic online here: http://forums.matronics.com/viewtopic.php?p=458217#458217 ________________________________________________________________________________
Date: Jul 15, 2016
> what Pole do I connect the bus tie switch grounding wire to? The small right terminal that only has one diode connected to it. Notice that the banded end of the diode does NOT connect to the small right terminal. Also notice that in the picture that Bob posted, http://www.bandc.aero/pdfs/S701-2_Wiring.pdf that there are 3 diodes and each banded end is connected to the small left terminal. Bill, your picture is not very clear, but it looks like one of the 3 diodes is missing and is replaced with a plain jumper wire. If so, something bad will happen. > it does not matter what side of the relay is the power side and what side goes to the starter motor... is this correct? Correct -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=458218#458218 ________________________________________________________________________________
Date: Jul 15, 2016
>Notice that the banded end of the diode does NOT connect to the small right terminal. Also notice that in the picture that Bob posted... that there are 3 diodes and each banded end is connected to the small left terminal. Bill, your picture is not very clear, but it looks like one of the 3 diodes is missing and is replaced with a plain jumper wire. Sorry. Bad photo. Using a smartphone camera if the flash is on then some items get washed out and if the flash is off then some items are not visible. Then when I compress the photo it makes it worse. Thanks for the confirmation and yes my bus tie contactor does indeed have 3 diodes as delivered. Thanks to all of your help on this forum... when I flip the switch on my electrical system for the first time... it will not have any of the smoke escape from the wires! Bill Hunter On Jul 15, 2016 7:18 AM, "user9253" wrote: > > > > what Pole do I connect the bus tie switch grounding wire to? > The small right terminal that only has one diode connected to it. Notice > that the banded end of the diode does NOT connect to the small right > terminal. > Also notice that in the picture that Bob posted, > http://www.bandc.aero/pdfs/S701-2_Wiring.pdf > that there are 3 diodes and each banded end is connected to the small left > terminal. Bill, your picture is not very clear, but it looks like one of > the 3 diodes is missing and is replaced with a plain jumper wire. If so, > something bad will happen. > > > it does not matter what side of the relay is the power side and what > side goes to the starter motor... is this correct? > Correct > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=458218#458218 > > ________________________________________________________________________________
Date: Jul 15, 2016
VGhhbmtzISBNYWtlcyBpdCBlYXN5IG5vdy4KCkppbSBCYWtlcgo0MDUgNDI2IDUzNzcKCi0tLS0t T3JpZ2luYWwgTWVzc2FnZS0tLS0tCkZyb206IHJhY2VyamVycnkgPGdua2luZzJAdmVyaXpvbi5u ZXQ+ClRvOiBhZXJvZWxlY3RyaWMtbGlzdEBtYXRyb25pY3MuY29tClNlbnQ6IEZyaSwgMTUgSnVs IDIwMTYgODowMApTdWJqZWN0OiBBZXJvRWxlY3RyaWMtTGlzdDogUmU6IENvbnRhY3RvciBvcmll bnRhdGlvbgoKLS0+IEFlcm9FbGVjdHJpYy1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiAicmFjZXJq ZXJyeSIgPGdua2luZzJAdmVyaXpvbi5uZXQ+CgpKaW0gQmFrZXIsIHRoZSBDUEEgIGNvbnRhY3Rv ciBhcnRpY2xlIHlvdSBhcmUgbG9va2luZyBmb3IgYXBwZWFyZWQgaW4gdGhlIEFwcmlsIDIwMTUg aXNzdWUgb2YgdGhlaXIgbWFnYXppbmUuCgotLS0tLS0tLQpKZXJyeSBLaW5nCgoKCgpSZWFkIHRo aXMgdG9waWMgb25saW5lIGhlcmU6CgpodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20vdmlld3Rv cGljLnBocD9wPTQ1ODIxNyM0NTgyMTcKCgoKCgoKCl8tPT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cl8tPSAgICAgICAgICAtIFRoZSBB ZXJvRWxlY3RyaWMtTGlzdCBFbWFpbCBGb3J1bSAtCl8tPSBVc2UgdGhlIE1hdHJvbmljcyBMaXN0 IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UKXy09IHRoZSBtYW55IExpc3QgdXRpbGl0aWVz IHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sCl8tPSBBcmNoaXZlIFNlYXJjaCAmIERvd25s b2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwKXy09IFBob3Rvc2hhcmUsIGFuZCBtdWNoIG11 Y2ggbW9yZToKXy09Cl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9y P0Flcm9FbGVjdHJpYy1MaXN0Cl8tPQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT0gICAgICAgICAgICAgICAtIE1BVFJPTklD UyBXRUIgRk9SVU1TIC0KXy09IFNhbWUgZ3JlYXQgY29udGVudCBhbHNvIGF2YWlsYWJsZSB2aWEg dGhlIFdlYiBGb3J1bXMhCl8tPQpfLT0gICAtLT4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29t Cl8tPQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PQpfLT0gICAgICAgICAgICAgIC0gTkVXIE1BVFJPTklDUyBMSVNUIFdJS0kgLQpf LT0gQWRkIHNvbWUgaW5mbyB0byB0aGUgTWF0cm9uaWNzIEVtYWlsIExpc3QgV2lraSEKXy09ICAg LS0+IGh0dHA6Ly93aWtpLm1hdHJvbmljcy5jb20KXy09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KXy09ICAgICAgICAgICAgIC0gTGlz dCBDb250cmlidXRpb24gV2ViIFNpdGUgLQpfLT0gIFRoYW5rIHlvdSBmb3IgeW91ciBnZW5lcm91 cyBzdXBwb3J0IQpfLT0gICAgICAgICAgICAgICAgICAgICAgICAgICAgICAtTWF0dCBEcmFsbGUs IExpc3QgQWRtaW4uCl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0 aW9uCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09CgoKCgo ________________________________________________________________________________
Subject: Transponder antenna
Date: Jul 15, 2016
I'm at that point where I need to install a transponder antenna on the bottom of my fiberglass fuselage. Research shows differing opinions on several issues. -Location, For a number of reasons I am limited to the area below the pilot/ copilot seats. Some say thats too close to your body. Some say it doesn't matter. I have read that the radiation pattern from the antenna is horizontal and in the shape of a donut. If this is true then under seat would seem to be a good location. Also, since I need to add a ground plane, would this serve to reflect any radiation? -Ground plane, I have room for up to a 16" square ground plane. I am unsure as to the size and shape. I have read that if it's round it has to be a certain size, But don't know what that size is. It seems that size doesn't matter as much if its square or octagonal. Also, should I make ground plane as large as I have room for? The antenna is just the standard post and ball from B&C. Would appreciate any feedback, Steve -------- Steve Read this topic online here: http://forums.matronics.com/viewtopic.php?p=458221#458221 ________________________________________________________________________________
Date: Jul 15, 2016
Subject: Re: Transponder antenna
At 11:09 AM 7/15/2016, you wrote: > >I'm at that point where I need to install a transponder antenna on >the bottom of my fiberglass fuselage. Research shows differing >opinions on several issues. > -Location, For a number of reasons I am limited to the area below > the pilot/ copilot seats. Some say thats too close to your body. > Some say it doesn't matter. It doesn't . . . there are no biological hazards associated with proximity to the transponder antenna. > I have read that the radiation pattern from the antenna is > horizontal and in the shape of a donut. Sort of . . . it's 'half a donut' . . . Emacs! If this is true then under seat would seem to be a good location. Also, since I need to add a ground plane, would this serve to reflect any radiation? The ground plane is essential to antenna performance. It it isn't provided by 'very large' surface areas like the skin of a metal aircraft, . . . > -Ground plane, I have room for up to a 16" square ground > plane. I am unsure as to the size and shape. I have read that if > it's round it has to be a certain size, But don't know what that > size is. It seems that size doesn't matter as much if its square > or octagonal. Also, should I make ground plane as large as I have room for? The RADIUS of a minimal ground plane is equal to the seated height of the associated antenna. For a transpoder, this is 5.3" in diameter. > The antenna is just the standard post and ball from B&C. > Would appreciate any feedback, Steve That would be my choice. See chapter 13 of http://tinyurl.com/pt97pha Bob . . . ________________________________________________________________________________
Date: Jul 15, 2016
Subject: breaker as switch for aux alternator?
For a two alternator (alternator + generator) one battery system similar to Z-13/8 where the generator is the auxiliary and is wired for over voltage so the relay cuts the current TO the regulator (as in Z-16), would it be acceptable to just use the 5 amp panel breaker as the on-off switch for the auxiliary generator, rather than using a toggle switch? In this case the C wire from the regulator would go directly to the main bus (the master switch would be used for the main alternator field wire and battery contactor). I can't see why a push-pull breaker would not be adequate for activating and deactivating the auxiliary generator. Normal use would be once on startup to check that the auxiliary charging system is functional, and then only in the event of a failure of the primary charging system during flight. ________________________________________________________________________________
Date: Jul 15, 2016
Well, that made it easy. Thanks! Jim Baker 405 426 5377 -----Original Message----- From: racerjerry <gnking2(at)verizon.net> Sent: Fri, 15 Jul 2016 8:00 Subject: AeroElectric-List: Re: Contactor orientation Jim Baker, the CPA contactor article you are looking for appeared in the April 2015 issue of their magazine. -------- Jerry King Read this topic online here: http://forums.matronics.com/viewtopic.php?p=458217#458217 ________________________________________________________________________________
Date: Jul 15, 2016
The maths to figure the size of the ground plane are quite straight forward when you know that speed of light = frequency x wavelength. For a transponder 3 x 10^8 m/s = 1090 x 10^6 x wavelength Wavelength = 3/10.9 = 0.275m (or 10.84") Most antennas we use are 1/4 wave dipoles, the ground plane should be tuned to the antenna, so the radius should 69mm, diameter 138mm (5.42"). Peter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Steve Kelly Sent: 15 July 2016 17:10 Subject: AeroElectric-List: Transponder antenna --> I'm at that point where I need to install a transponder antenna on the bottom of my fiberglass fuselage. Research shows differing opinions on several issues. -Location, For a number of reasons I am limited to the area below the pilot/ copilot seats. Some say thats too close to your body. Some say it doesn't matter. I have read that the radiation pattern from the antenna is horizontal and in the shape of a donut. If this is true then under seat would seem to be a good location. Also, since I need to add a ground plane, would this serve to reflect any radiation? -Ground plane, I have room for up to a 16" square ground plane. I am unsure as to the size and shape. I have read that if it's round it has to be a certain size, But don't know what that size is. It seems that size doesn't matter as much if its square or octagonal. Also, should I make ground plane as large as I have room for? The antenna is just the standard post and ball from B&C. Would appreciate any feedback, Steve -------- Steve Read this topic online here: http://forums.matronics.com/viewtopic.php?p=458221#458221 ________________________________________________________________________________
Date: Jul 15, 2016
Thank you. Those are the answers I was looking for. Steve -------- Steve Read this topic online here: http://forums.matronics.com/viewtopic.php?p=458227#458227 ________________________________________________________________________________
Subject: Re: breaker as switch for aux alternator?
Date: Jul 16, 2016
Your plan sounds OK to me. Just keep in mind that if the "C" terminal is wired directly to the main bus, then shutting off the master switch will NOT shut off the Aux generator. The master switch will only disconnect the battery from the electrical system. The generator, once enabled, will continue to power the aircraft. So in an emergency, not only does the master need to be shut off, but also the aux generator breaker needs to be pulled off. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=458231#458231 ________________________________________________________________________________
Date: Jul 16, 2016
You might want to also look at the rated lifetime operations of the pull-able breaker vs a plain switch or a 'circuit breaker switch'. It's unlikely any of us would ever wear any of them out in a homebuilt, but those ratings are at least some indication of expected life. Most breakers aren't designed for multiple actuations during every use of the 'appliance' they protect, so their number of rated operations is typically lower than a switch. Sometimes by a lot. FWIW... On Sat, Jul 16, 2016 at 7:21 AM, user9253 wrote: > > Your plan sounds OK to me. Just keep in mind that if the "C" terminal is > wired directly to the main bus, then shutting off the master switch will > NOT shut off the Aux generator. The master switch will only disconnect the > battery from the electrical system. The generator, once enabled, will > continue to power the aircraft. So in an emergency, not only does the > master need to be shut off, but also the aux generator breaker needs to be > pulled off. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=458231#458231 > > ________________________________________________________________________________
Date: Jul 16, 2016
Take this with a grain of salt... I was told that because there are two frequencies involved with the transponder that a ground plane of two different sizes is best. So following that logic, I created an octagon shaped ground plane. I may have misinterpreted the RST document, but it works fine. http://www.velocity-xl.com/blog/2013/11/07/13-99-transponder-antenna-ground-plane/ Steve Kelly wrote: > -Ground plane, I have room for up to a 16" square ground plane. I am unsure as to the size and shape. I have read that if it's round it has to be a certain size, But don't know what that size is. It seems that size doesn't matter as much if its square or octagonal. Also, should I make ground plane as large as I have room for? > The antenna is just the standard post and ball from B&C. > Would appreciate any feedback, Steve Read this topic online here: http://forums.matronics.com/viewtopic.php?p=458238#458238 ________________________________________________________________________________
Date: Jul 16, 2016
Thanks Joe. I guess it's not ideal but in that respect I think it's the same as Z-13/8. I hope to have a completed diagram to post pretty soon. Ken On Sat, Jul 16, 2016 at 4:21 AM, user9253 wrote: > > Your plan sounds OK to me. Just keep in mind that if the "C" terminal is > wired directly to the main bus, then shutting off the master switch will > NOT shut off the Aux generator. The master switch will only disconnect the > battery from the electrical system. The generator, once enabled, will > continue to power the aircraft. So in an emergency, not only does the > master need to be shut off, but also the aux generator breaker needs to be > pulled off. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=458231#458231 > > ________________________________________________________________________________
Date: Jul 16, 2016
At 10:15 AM 7/16/2016, you wrote: > >Take this with a grain of salt... > >I was told that because there are two frequencies involved with the >transponder that a ground plane of two different sizes is best. So >following that logic, I created an octagon shaped ground plane. I >may have misinterpreted the RST document, but it works fine. > >http://www.velocity-xl.com/blog/2013/11/07/13-99-transponder-antenna-ground-plane/ This is REALLY fine hair-splitting. The signals using the transponder antenna are not that far apart. Even if you had access to a %million$ antenna test range and equipment, you would be hard pressed to detect and quantify any improvement in performance for having crafted an 'optimized' ground plane . . . after all, the real magic in broader bandwidth performance has more to do with the shape of the antenna as opposed to its ground plane. There are much more expensive transponder antennas out there that do offer wider band width . . . but if you bought one and installed it, you wouldn't observe any difference in system performance. I've offered similar arguments about going with $higher$ batteries to save weight by asking just how much the expense will shorten your take-off run, increase your rate of climb, increase your service ceiling? One might calculate the differences . . . John Q. OBAM airplane pilot would be hard pressed to fly two otherwise identical airplanes and tell us which one has the super-cool battery installed. Tony Levere was once known to run stripes of Scotch Tape over the lines of rivet heads on the skins of his p-38 race plane . . . with a notion of getting a few more knots out of the machine . . . intuitively one can 'see' how this might be useful but the difference would be hard to go measure. Tony did wins lots of races with his pride and joy . . . but was Scotch Tape really the tipping force . . . or did more powerful influences make the difference? We'll nver know. Bob . . . ________________________________________________________________________________
Date: Jul 16, 2016
At 08:15 AM 7/16/2016, you wrote: >You might want to also look at the rated lifetime operations of the >pull-able breaker vs a plain switch or a 'circuit breaker switch'. >It's unlikely any of us would ever wear any of them out in a >homebuilt, but those ratings are at least some indication of >expected life. Most breakers aren't designed for multiple actuations >during every use of the 'appliance' they protect, so their number of >rated operations is typically lower than a switch. Sometimes by a lot. While switches are generally rated in the tens of thousands of operations, our favorite little breakers are only rated in mere thousands. You're not going to wear it out in the life time of your airplane . . . and even if you did . . . it should be operated once per flight-cycle in pre-flight . . . you'll detect the failure for an easily replaced component. Bob . . . ________________________________________________________________________________
Date: Jul 16, 2016
Hi All; The rated life of the Tyco W31-X2M1G, which is a toggle switch/circuit brea ker available from 1 to 50 amps is stated to be equal or greater than 10,00 0 mechanical cycles, or 6,000 cycles at 100% rated load. The push pull type is similar. Enough for my limited life-span. Cheers!=C2-=C2- Stu. ----- Original Message ----- From: "Charlie England" <ceengland7(at)gmail.com> Sent: Saturday, July 16, 2016 6:15:54 AM Subject: Re: AeroElectric-List: Re: breaker as switch for aux alternator? You might want to also look at the rated lifetime operations of the pull-ab le breaker vs a plain switch or a 'circuit breaker switch'. It's unlikely a ny of us would ever wear any of them out in a homebuilt, but those ratings are at least some indication of expected life. Most breakers aren't designe d for multiple actuations during every use of the 'appliance' they protect, so their number of rated operations is typically lower than a switch. Some times by a lot. FWIW... =C2- On Sat, Jul 16, 2016 at 7:21 AM, user9253 < fransew(at)gmail.com > wrote: Your plan sounds OK to me.=C2- Just keep in mind that if the "C" terminal is wired directly to the main bus, then shutting off the master switch wil l NOT shut off the Aux generator.=C2- The master switch will only disconn ect the battery from the electrical system.=C2- The generator, once enabl ed, will continue to power the aircraft.=C2- So in an emergency, not only does the master need to be shut off, but also the aux generator breaker ne eds to be pulled off. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=458231#458231 =========== - Electric-List" rel="noreferrer" target="_blank">http://www.matronics.co m/Navigator?AeroElectric-List =========== FORUMS - eferrer" target="_blank">http://forums.matronics.com =========== WIKI - errer" target="_blank">http://wiki.matronics.com =========== b Site - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution =========== ________________________________________________________________________________
Date: Jul 16, 2016
Hi All; I'll pose this as a philosophical point, as I am no expert: It would seem, considering no ground plane is required on a metal aircraft, that the only consideration is how small can they be made and still function adequately. In other words, there is no "too big," only "too small." If this is correct so far, it would behoove us to err to the large side. Cheers!=C2-=C2- Stu. ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Sent: Saturday, July 16, 2016 9:47:11 AM Subject: Re: AeroElectric-List: Re: Transponder antenna At 10:15 AM 7/16/2016, you wrote: > Take this with a grain of salt... I was told that because there are two frequencies involved with the transpo nder that a ground plane of two different sizes is best.=C2- So following that logic, I created an octagon shaped ground plane. I may have misinterp reted the RST document, but it works fine. http://www.velocity-xl.com/blog/2013/11/07/13-99-transponder-antenna-ground -plane/ =C2-=C2- This is REALLY fine hair-splitting.=C2- The signals using =C2-=C2- the transponder antenna are not that far apart. Even =C2-=C2- if you had access to a %million$ antenna test range =C2-=C2- and equipment, you would be hard pressed to detect =C2-=C2- and quantify any improvement in performance for having =C2-=C2- crafted an 'optimized' ground plane . . . after all, =C2-=C2- the real magic in broader bandwidth performance =C2-=C2- has more to do with the shape of the antenna as opposed =C2-=C2- to its ground plane. =C2-=C2- There are much more expensive transponder antennas =C2-=C2- out there that do offer wider band width . . . but =C2-=C2- if you bought one and installed it, you wouldn't =C2-=C2- observe any difference in system performance. I've =C2-=C2- offered similar arguments about going with $higher$ =C2-=C2- batteries to save weight by asking just how much =C2-=C2- the expense will shorten your take-off run, increase =C2-=C2- your rate of climb, increase your service ceiling? =C2-=C2- One might calculate the differences . . . John Q. =C2-=C2- OBAM airplane pilot would be hard pressed to fly =C2-=C2- two otherwise identical airplanes and tell us =C2-=C2- which one has the super-cool battery installed. =C2-=C2- Tony Levere was once known to run stripes of Scotch =C2-=C2- Tape over the lines of rivet heads on the skins of =C2-=C2- his p-38 race plane . . . with a notion of getting =C2-=C2- a few more knots out of the machine . . . intuitively =C2-=C2- one can 'see' how this might be useful but the =C2-=C2- difference would be hard to go measure. Tony did wins lots =C2-=C2- of races with his pride and joy . . . but was Scotch Tape =C2-=C2- really the tipping force . . . or did more powerful =C2-=C2- influences make the difference? We'll nver know. =C2- Bob . . . ________________________________________________________________________________
Date: Jul 16, 2016
At 11:52 AM 7/16/2016, you wrote: >Hi All; >The rated life of the Tyco W31-X2M1G, which is a toggle >switch/circuit breaker available from 1 to 50 amps is stated to be >equal or greater than 10,000 mechanical cycles, or 6,000 cycles at >100% rated load. The push pull type is similar. Enough for my >limited life-span. >Cheers! Stu. These devices were problematic in the Barons and Bonanzas. Furhter, their i(squared)T constant is larger than the legacy, miniature breaker. If you want to use a breaker upstream of crowbar ov protection, please consider the miniature, push-pull breakers. Bob . . . ________________________________________________________________________________
Date: Jul 16, 2016
At 12:05 PM 7/16/2016, you wrote: >Hi All; >I'll pose this as a philosophical point, as I am no expert: It would >seem, considering no ground plane is required on a metal aircraft A ground plane IS required . . . but the airplane IS the ground plane. >, that the only consideration is how small can they be made and >still function adequately. In other words, there is no "too big," >only "too small." If this is correct so far, it would behoove us to >err to the large side. The resonant ground plane on a composite aircraft is the electrical equivalent of an infinite number of 'antennas' surrounding the base of the radiating element. Hence, the minimal ground plane is 'tuned' to the operating frequency. Either fabricate a tuned ground plane or go with metal many times larger than the tuned ground plane. Erring to the 'large' side by smaller factors is counter productive. Bob . . . ________________________________________________________________________________
Date: Jul 16, 2016
The belly of a Boeing id a rather large ground plane. The Dynon Installation Manual was extremely specific about the size of the ground plane being a minimum size and then increments above that... but the increments above the minimum were not defined Bill Hunter On Jul 16, 2016 10:11 AM, wrote: > Hi All; > I'll pose this as a philosophical point, as I am no expert: It would seem, > considering no ground plane is required on a metal aircraft, that the only > consideration is how small can they be made and still function adequately. > In other words, there is no "too big," only "too small." If this is correct > so far, it would behoove us to err to the large side. > Cheers! Stu. > > ------------------------------ > *From: *"Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> > *To: *aeroelectric-list(at)matronics.com > *Sent: *Saturday, July 16, 2016 9:47:11 AM > *Subject: *Re: AeroElectric-List: Re: Transponder antenna > > At 10:15 AM 7/16/2016, you wrote: > > don@velocity-xl.com> > > Take this with a grain of salt... > > I was told that because there are two frequencies involved with the > transponder that a ground plane of two different sizes is best. So > following that logic, I created an octagon shaped ground plane. I may have > misinterpreted the RST document, but it works fine. > > > http://www.velocity-xl.com/blog/2013/11/07/13-99-transponder-antenna-ground-plane/ > > > This is REALLY fine hair-splitting. The signals using > the transponder antenna are not that far apart. Even > if you had access to a %million$ antenna test range > and equipment, you would be hard pressed to detect > and quantify any improvement in performance for having > crafted an 'optimized' ground plane . . . after all, > the real magic in broader bandwidth performance > has more to do with the shape of the antenna as opposed > to its ground plane. > > There are much more expensive transponder antennas > out there that do offer wider band width . . . but > if you bought one and installed it, you wouldn't > observe any difference in system performance. I've > offered similar arguments about going with $higher$ > batteries to save weight by asking just how much > the expense will shorten your take-off run, increase > your rate of climb, increase your service ceiling? > One might calculate the differences . . . John Q. > OBAM airplane pilot would be hard pressed to fly > two otherwise identical airplanes and tell us > which one has the super-cool battery installed. > > > Tony Levere was once known to run stripes of Scotch > Tape over the lines of rivet heads on the skins of > his p-38 race plane . . . with a notion of getting > a few more knots out of the machine . . . intuitively > one can 'see' how this might be useful but the > difference would be hard to go measure. Tony did wins lots > of races with his pride and joy . . . but was Scotch Tape > really the tipping force . . . or did more powerful > influences make the difference? We'll nver know. > > Bob . . . > > ________________________________________________________________________________
Date: Jul 16, 2016
I was hoping to use Klixon 2TC series because I have some in the shop. Here's a link: http://www.sensata.com/klixon/circuit-breaker-aircraft-2tc.htm They are endurance rated: 2500 cycles: 120VAC, 400 Hz inductive 5000 cycles: 120VAC, 400 Hz resistive 2500 cycles: 30VDC inductive 5000 cycles: 30VDC resistive 10,000 cycles: Mechanical, no load What I have on hand is 4 amp. I think I already asked if it would be okay to substitute 4 amp for 5 amp and got the "okay." Just out of curiosity, which of the above would be closest to this application (connecting and disconnecting the generator and regulator)? Does it make any difference how this breaker is wired (which terminal is upstream)? One of the terminals seems to be designated "Line." Ken On Sat, Jul 16, 2016 at 9:16 AM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 11:52 AM 7/16/2016, you wrote: > > Hi All; > The rated life of the Tyco W31-X2M1G, which is a toggle switch/circuit > breaker available from 1 to 50 amps is stated to be equal or greater than > 10,000 mechanical cycles, or 6,000 cycles at 100% rated load. The push pull > type is similar. Enough for my limited life-span. > Cheers! Stu. > > > These devices were problematic in the Barons and Bonanzas. > Furhter, their i(squared)T constant is larger than the > legacy, miniature breaker. If you want to use a breaker > upstream of crowbar ov protection, please consider the > miniature, push-pull breakers. > > Bob . . . > ________________________________________________________________________________
Subject: Re: Battery weight
Date: Jul 16, 2016
On 7/16/2016 6:47 PM, Robert L. Nuckolls, III wrote: > ...I've > offered similar arguments about going with $higher$ > batteries to save weight by asking just how much > the expense will shorten your take-off run, increase > your rate of climb, increase your service ceiling? On my plane I went from an Oddyssey PC680 to an AeroAkku LFP450D. The combined weight savings of the lighter battery and mounting materials is 5kg, which equates to 7 liters more fuel at MTOW, which equates to 25 minutes extra range. I do appreciate having that headroom. Rob ________________________________________________________________________________
Date: Jul 16, 2016
Hi Bob; How far back in time is your experience with these devices in Barons and Bo nanzas? In other words, has there possibly been time for improvement? I kno w of many in use without complaints. Cheers!=C2-=C2- Stu. ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Sent: Saturday, July 16, 2016 10:16:18 AM Subject: Re: AeroElectric-List: Re: breaker as switch for aux =C2- altern ator? At 11:52 AM 7/16/2016, you wrote: Hi All; The rated life of the Tyco W31-X2M1G, which is a toggle switch/circuit brea ker available from 1 to 50 amps is stated to be equal or greater than 10,00 0 mechanical cycles, or 6,000 cycles at 100% rated load. The push pull type is similar. Enough for my limited life-span. Cheers!=C2-=C2- Stu. =C2- These devices were problematic in the Barons and Bonanzas. =C2- Furhter, their i(squared)T constant is larger than the =C2- legacy, miniature breaker. If you want to use a breaker =C2- upstream of crowbar ov protection, please consider the =C2- miniature, push-pull breakers. =C2- Bob . . . ________________________________________________________________________________
Date: Jul 16, 2016
Hi Bob; Possibly I should have said no additional ground plane is required. I expec t most understood what I meant. For those who didn't, I offer my apologies. Concerning the second portion of your comment, I appreciate the distinction you have made. Either use a tuned ground plane, or one much larger.
July 06, 2016 - July 16, 2016
AeroElectric-Archive.digest.vol-nh
