AeroElectric-Archive.digest.vol-no
September 21, 2016 - October 12, 2016
      > From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelect
      ric-list-server(at)matronics.com] On Behalf Of Art Zemon
      > Sent: Wednesday, September 21, 2016 6:34 PM
      > To: aeroelectric-list(at)matronics.com
      > Subject: AeroElectric-List: Problems Soldering DB-25 Connectors
      > Folks,
      > I am trying to solder 20 gauge wire into DB-25 connectors and having a tou
      gh time. The conductors just barely fit into the cups on the backs of the pi
      ns when everything is "dry," before tinning. After I tin either one, pin or w
      ire, I cannot get all of the conductors into the cup. I end up with somethin
      g like this:
      > I'm afraid that those are not acceptable. What do you think?
      > If they are not acceptable, what is the solution? Can I trim a few conduct
      ors away so that the remainder will slip into the cup? Or should I just give
       up and switch to crimp pins? Or what?
      > Thanks,
      >     -- Art Z.
      > http://CheerfulCurmudgeon.com/
      > "If I am not for myself, who is for me? And if I am only for myself, what a
      m I? And if not now, when?" Hillel
Subject: Re: New smartphone app for pilots
Date: Sep 21, 2016
Hi Bill, You are absolutely right. These apps don't run on Android yet. I am only a one man shop and that unfortunately requires setting priorities. I might, however, point out, in defense of my choice, that it is only quite recently that a single Samsung 7 series was released with the barometer hardware. So it's not quite a massive market yet. That being said, I do have a copy of the Xamarin cross-development system, and playing with it is in the queue. Stay tuned. -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460649#460649 ________________________________________________________________________________
Subject: Re: Problems Soldering DB-25 Connectors
Date: Sep 21, 2016
Be careful about dry joints, the solder should be bright and shiny all around the joint. If the wire is carrying just signal, clipping a strand or two should be fine (with adequate strain relief). Power carrying wire demand more careful consideration about potential resistive heating and voltage drop. What I see missing in your picture is heat shrink tubing on each wire pushed all the down to the connector's insulator block. I'll assume it is not there just to illustrate the solder joints clearly. -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460650#460650 ________________________________________________________________________________
Date: Sep 21, 2016
Rene' I also prefer the mil spec crimp pins. But when I solder the connectors I d o not tin first. I strip the wire to fit, hold in place and solder in place . It helps to have 4 hands. I will often clamp the connector down and hold the wire in place with one of those alligator clip stands the solder a wire at a time. or strip...crimp....insert John Snapp +1.303.810.0600 ( excuse the typos. This email was sent from a mobile device!) > On Sep 21, 2016, at 5:47 PM, Rene wrote: > > I prefer the crimp pins. Easier to create the connector and easier to tak e it apart or change wires. I have done way more of that then I would have e ver imagined when I build the plane. > > Rene' > 801-721-6080 > > From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelect ric-list-server(at)matronics.com] On Behalf Of Art Zemon > Sent: Wednesday, September 21, 2016 6:34 PM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Problems Soldering DB-25 Connectors > > Folks, > > I am trying to solder 20 gauge wire into DB-25 connectors and having a tou gh time. The conductors just barely fit into the cups on the backs of the pi ns when everything is "dry," before tinning. After I tin either one, pin or w ire, I cannot get all of the conductors into the cup. I end up with somethin g like this: > > > > I'm afraid that those are not acceptable. What do you think? > > If they are not acceptable, what is the solution? Can I trim a few conduct ors away so that the remainder will slip into the cup? Or should I just give up and switch to crimp pins? Or what? > > Thanks, > -- Art Z. > > -- > http://CheerfulCurmudgeon.com/ > > "If I am not for myself, who is for me? And if I am only for myself, what a m I? And if not now, when?" Hillel ________________________________________________________________________________
Date: Sep 22, 2016
Thanks Ira, more strength to your elbow, as the Vikings might have said. Bill On 22/09/2016 11:13 AM, rampil wrote: > > Hi Bill, > > You are absolutely right. These apps don't run on Android yet. > I am only a one man shop and that unfortunately requires setting > priorities. I might, however, point out, in defense of my choice, > that it is only quite recently that a single Samsung 7 series was released > with the barometer hardware. So it's not quite a massive > market yet. That being said, I do have a copy of the Xamarin cross-development system, and playing with it is in the queue. Stay tuned. > > -------- > Ira N224XS > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=460649#460649 > > ________________________________________________________________________________
Date: Sep 21, 2016
The solder will wick down into the connection if done right. On Wed, Sep 21, 2016 at 9:22 PM, john Snapp wrote: > Rene' > I also prefer the mil spec crimp pins. But when I solder the connectors I > do not tin first. I strip the wire to fit, hold in place and solder in > place. It helps to have 4 hands. I will often clamp the connector down > and hold the wire in place with one of those alligator clip stands the > solder a wire at a time. > > or > > strip...crimp....insert > > John Snapp > > +1.303.810.0600 > ( excuse the typos. This email was sent from a mobile device!) > > On Sep 21, 2016, at 5:47 PM, Rene wrote: > > I prefer the crimp pins. Easier to create the connector and easier to > take it apart or change wires. I have done way more of that then I would > have ever imagined when I build the plane. > > > Rene' > > 801-721-6080 > > > *From:* owner-aeroelectric-list-server(at)matronics.com [ > mailto:owner-aeroelectric-list-server(at)matronics.com > ] *On Behalf Of *Art Zemon > *Sent:* Wednesday, September 21, 2016 6:34 PM > *To:* aeroelectric-list(at)matronics.com > *Subject:* AeroElectric-List: Problems Soldering DB-25 Connectors > > > Folks, > > > I am trying to solder 20 gauge wire into DB-25 connectors and having a > tough time. The conductors just barely fit into the cups on the backs of > the pins when everything is "dry," before tinning. After I tin either one, > pin or wire, I cannot get all of the conductors into the cup. I end up with > something like this: > > > > > I'm afraid that those are not acceptable. What do you think? > > > If they are not acceptable, what is the solution? Can I trim a few > conductors away so that the remainder will slip into the cup? Or should I > just give up and switch to crimp pins? Or what? > > > Thanks, > > -- Art Z. > > > -- > > http://CheerfulCurmudgeon.com/ > > *"If I am not for myself, who is for me? And if I am only for myself, what > am I? And if not now, when?" Hillel* > > ________________________________________________________________________________
Date: Sep 21, 2016
Do you really need 20 gauge? 22 or even 24 will do for many avionics. If t he diagram calls for 20, I'd clip off a few strands. It won't change the wi re resistance measurably and if it did, the D-sub acts as a heat sink. BTW, i would rather solder than fiddle with crimp pins. I tin the cup, tin t he wire, then touch the side of the cup with the iron while gently pushing t he wire into the cup. It normally slips right in. You must hold your tongu e properly, of course. :-) -kent > On Sep 21, 2016, at 8:33 PM, Art Zemon wrote: > > Folks, > > I am trying to solder 20 gauge wire into DB-25 connectors and having a tou gh time. The conductors just barely fit into the cups on the backs of the pi ns when everything is "dry," before tinning. After I tin either one, pin or w ire, I cannot get all of the conductors into the cup. I end up with somethin g like this: > > > > I'm afraid that those are not acceptable. What do you think? > > If they are not acceptable, what is the solution? Can I trim a few conduct ors away so that the remainder will slip into the cup? Or should I just give up and switch to crimp pins? Or what? > > Thanks, > -- Art Z. > > -- > http://CheerfulCurmudgeon.com/ > > "If I am not for myself, who is for me? And if I am only for myself, what a m I? And if not now, when?" Hillel ________________________________________________________________________________
Date: Sep 21, 2016
On 9/21/2016 7:33 PM, Art Zemon wrote: > Folks, > > I am trying to solder 20 gauge wire into DB-25 connectors and having a > tough time. The conductors just barely fit into the cups on the backs > of the pins when everything is "dry," before tinning. After I tin > either one, pin or wire, I cannot get all of the conductors into the > cup. I end up with something like this: > > > I'm afraid that those are not acceptable. What do you think? > > If they are not acceptable, what is the solution? Can I trim a few > conductors away so that the remainder will slip into the cup? Or > should I just give up and switch to crimp pins? Or what? > > Thanks, > -- Art Z. > > -- > http://CheerfulCurmudgeon.com/ > > /"If I am not for myself, who is for me? And if I am only for myself, > what am I? And if not now, when?" Hillel/ Hi Art, For background, I went through several careers & a hobby or two with a soldering iron in my hand. When I started wiring my RV-7, I saw no need to spend the (relatively) big bucks on crimp style sub d's. After hours of work with a soldering iron, and a couple of minor revisions to the wiring, I threw in the towel & bought a batch of shells & machined pins. I've obviously got the skills to do everything with the iron, but crimped pins are *much* faster, and as others have mentioned, much easier to make revisions/corrections to the wiring. If you decide to stick with solder, I'd suggest tinning the wire, but not the terminal cup. Instead, try a dab of electronics grade flux paste in the cup before inserting the wire. Make sure you've got a hot iron with a clean & tinned tip. (Low heat and/or poor heat transfer can damage components before solder flows properly.) I like to mate the connector to a spare mate before starting the soldering process. That way, if the plastic insulating body gets a bit too hot, the 'mate' will keep the pins aligned. If you can keep the stripped area short enough, you shouldn't need shrink over the pins. Good luck, Charlie /9j/4AAQSkZJRgABAQAAAQABAAD/4QB+RXhpZgAASUkqAAgAAAACADEBAgAHAAAAJgAAAGmH BAABAAAALgAAAAAAAABHb29nbGUAAAMAAJAHAAQAAAAwMjIwAaADAAEAAAABAAAABaAEAAEA AABYAAAAAAAAAAIAAQACAAQAAABSOTgAAgAHAAQAAAAwMTAwAAAAAP/iC/hJQ0NfUFJPRklM RQABAQAAC+gAAAAAAgAAAG1udHJSR0IgWFlaIAfZAAMAGwAVACQAH2Fjc3AAAAAAAAAAAAAA AAAAAAAAAAAAAQAAAAAAAAAAAAD21gABAAAAANMtAAAAACn4Pd6v8lWueEL65MqDOQ0AAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEGRlc2MAAAFEAAAAeWJYWVoAAAHAAAAAFGJU UkMAAAHUAAAIDGRtZGQAAAngAAAAiGdYWVoAAApoAAAAFGdUUkMAAAHUAAAIDGx1bWkAAAp8 AAAAFG1lYXMAAAqQAAAAJGJrcHQAAAq0AAAAFHJYWVoAAArIAAAAFHJUUkMAAAHUAAAIDHRl Y2gAAArcAAAADHZ1ZWQAAAroAAAAh3d0cHQAAAtwAAAAFGNwcnQAAAuEAAAAN2NoYWQAAAu8 AAAALGRlc2MAAAAAAAAAH3NSR0IgSUVDNjE5NjYtMi0xIGJsYWNrIHNjYWxlZAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAABYWVogAAAAAAAAJKAAAA+EAAC2z2N1cnYAAAAAAAAEAAAA AAUACgAPABQAGQAeACMAKAAtADIANwA7AEAARQBKAE8AVABZAF4AYwBoAG0AcgB3AHwAgQCG AIsAkACVAJoAnwCkAKkArgCyALcAvADBAMYAywDQANUA2wDgAOUA6wDwAPYA+wEBAQcBDQET ARkBHwElASsBMgE4AT4BRQFMAVIBWQFgAWcBbgF1AXwBgwGLAZIBmgGhAakBsQG5AcEByQHR AdkB4QHpAfIB+gIDAgwCFAIdAiYCLwI4AkECSwJUAl0CZwJxAnoChAKOApgCogKsArYCwQLL AtUC4ALrAvUDAAMLAxYDIQMtAzgDQwNPA1oDZgNyA34DigOWA6IDrgO6A8cD0wPgA+wD+QQG BBMEIAQtBDsESARVBGMEcQR+BIwEmgSoBLYExATTBOEE8AT+BQ0FHAUrBToFSQVYBWcFdwWG BZYFpgW1BcUF1QXlBfYGBgYWBicGNwZIBlkGagZ7BowGnQavBsAG0QbjBvUHBwcZBysHPQdP B2EHdAeGB5kHrAe/B9IH5Qf4CAsIHwgyCEYIWghuCIIIlgiqCL4I0gjnCPsJEAklCToJTwlk CXkJjwmkCboJzwnlCfsKEQonCj0KVApqCoEKmAquCsUK3ArzCwsLIgs5C1ELaQuAC5gLsAvI C+EL+QwSDCoMQwxcDHUMjgynDMAM2QzzDQ0NJg1ADVoNdA2ODakNww3eDfgOEw4uDkkOZA5/ DpsOtg7SDu4PCQ8lD0EPXg96D5YPsw/PD+wQCRAmEEMQYRB+EJsQuRDXEPURExExEU8RbRGM EaoRyRHoEgcSJhJFEmQShBKjEsMS4xMDEyMTQxNjE4MTpBPFE+UUBhQnFEkUahSLFK0UzhTw FRIVNBVWFXgVmxW9FeAWAxYmFkkWbBaPFrIW1hb6Fx0XQRdlF4kXrhfSF/cYGxhAGGUYihiv GNUY+hkgGUUZaxmRGbcZ3RoEGioaURp3Gp4axRrsGxQbOxtjG4obshvaHAIcKhxSHHscoxzM HPUdHh1HHXAdmR3DHeweFh5AHmoelB6+HukfEx8+H2kflB+/H+ogFSBBIGwgmCDEIPAhHCFI IXUhoSHOIfsiJyJVIoIiryLdIwojOCNmI5QjwiPwJB8kTSR8JKsk2iUJJTglaCWXJccl9yYn Jlcmhya3JugnGCdJJ3onqyfcKA0oPyhxKKIo1CkGKTgpaymdKdAqAio1KmgqmyrPKwIrNitp K50r0SwFLDksbiyiLNctDC1BLXYtqy3hLhYuTC6CLrcu7i8kL1ovkS/HL/4wNTBsMKQw2zES MUoxgjG6MfIyKjJjMpsy1DMNM0YzfzO4M/E0KzRlNJ402DUTNU01hzXCNf02NzZyNq426Tck N2A3nDfXOBQ4UDiMOMg5BTlCOX85vDn5OjY6dDqyOu87LTtrO6o76DwnPGU8pDzjPSI9YT2h PeA+ID5gPqA+4D8hP2E/oj/iQCNAZECmQOdBKUFqQaxB7kIwQnJCtUL3QzpDfUPARANER0SK RM5FEkVVRZpF3kYiRmdGq0bwRzVHe0fASAVIS0iRSNdJHUljSalJ8Eo3Sn1KxEsMS1NLmkvi TCpMcky6TQJNSk2TTdxOJU5uTrdPAE9JT5NP3VAnUHFQu1EGUVBRm1HmUjFSfFLHUxNTX1Oq U/ZUQlSPVNtVKFV1VcJWD1ZcVqlW91dEV5JX4FgvWH1Yy1kaWWlZuFoHWlZaplr1W0VblVvl XDVchlzWXSddeF3JXhpebF69Xw9fYV+zYAVgV2CqYPxhT2GiYfViSWKcYvBjQ2OXY+tkQGSU ZOllPWWSZedmPWaSZuhnPWeTZ+loP2iWaOxpQ2maafFqSGqfavdrT2una/9sV2yvbQhtYG25 bhJua27Ebx5veG/RcCtwhnDgcTpxlXHwcktypnMBc11zuHQUdHB0zHUodYV14XY+dpt2+HdW d7N4EXhueMx5KnmJeed6RnqlewR7Y3vCfCF8gXzhfUF9oX4BfmJ+wn8jf4R/5YBHgKiBCoFr gc2CMIKSgvSDV4O6hB2EgITjhUeFq4YOhnKG14c7h5+IBIhpiM6JM4mZif6KZIrKizCLlov8 jGOMyo0xjZiN/45mjs6PNo+ekAaQbpDWkT+RqJIRknqS45NNk7aUIJSKlPSVX5XJljSWn5cK l3WX4JhMmLiZJJmQmfyaaJrVm0Kbr5wcnImc951kndKeQJ6unx2fi5/6oGmg2KFHobaiJqKW owajdqPmpFakx6U4pammGqaLpv2nbqfgqFKoxKk3qamqHKqPqwKrdavprFys0K1ErbiuLa6h rxavi7AAsHWw6rFgsdayS7LCszizrrQltJy1E7WKtgG2ebbwt2i34LhZuNG5SrnCuju6tbsu u6e8IbybvRW9j74KvoS+/796v/XAcMDswWfB48JfwtvDWMPUxFHEzsVLxcjGRsbDx0HHv8g9 yLzJOsm5yjjKt8s2y7bMNcy1zTXNtc42zrbPN8+40DnQutE80b7SP9LB00TTxtRJ1MvVTtXR 1lXW2Ndc1+DYZNjo2WzZ8dp22vvbgNwF3IrdEN2W3hzeot8p36/gNuC94UThzOJT4tvjY+Pr 5HPk/OWE5g3mlucf56noMui86Ubp0Opb6uXrcOv77IbtEe2c7ijutO9A78zwWPDl8XLx//KM 8xnzp/Q09ML1UPXe9m32+/eK+Bn4qPk4+cf6V/rn+3f8B/yY/Sn9uv5L/tz/bf//ZGVzYwAA AAAAAAAuSUVDIDYxOTY2LTItMSBEZWZhdWx0IFJHQiBDb2xvdXIgU3BhY2UgLSBzUkdCAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAFhZWiAAAAAAAABimQAAt4UAABjaWFlaIAAAAAAAAAAA AFAAAAAAAABtZWFzAAAAAAAAAAEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAJYWVogAAAAAAAA AxYAAAMzAAACpFhZWiAAAAAAAABvogAAOPUAAAOQc2lnIAAAAABDUlQgZGVzYwAAAAAAAAAt UmVmZXJlbmNlIFZpZXdpbmcgQ29uZGl0aW9uIGluIElFQyA2MTk2Ni0yLTEAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAFhZWiAAAAAAAAD21gABAAAAANMtdGV4dAAAAABDb3B5cmlnaHQg SW50ZXJuYXRpb25hbCBDb2xvciBDb25zb3J0aXVtLCAyMDA5AABzZjMyAAAAAAABDEQAAAXf ///zJgAAB5QAAP2P///7of///aIAAAPbAADAdf/bAIQACAYGEhIQEhISEhUVEhUSEBAVFRUV EBAVEBAVEBUVFRAQEBUYIhsVFiAXEBAdKx0gJSUoKCgVGy0xLSYwIicoJgEJCQkNCw0VDQ0V JhUVFSYmJiYmJiYmJiYmJiYmJiYmJiYmJiYmJiYmJiYmJiYmJiYmJiYmJiYmJiYmJiYmJiYm /8AAEQgDFQWLAwEiAAIRAQMRAf/EABwAAAEFAQEBAAAAAAAAAAAAAAMBAgQFBgAHCP/EAEwQ AAEDAgMGBAMGBAQEBAUDBQEAAhEDIQQSMQUGQVFhcSKBkaETscEHFDJC0fAVI1LhFmJy8SQz Q4JTkqKyF2NzwtIINPIlNUSTo//EABoBAAMBAQEBAAAAAAAAAAAAAAABAgMEBQb/xAAqEQEB AAICAgICAgICAgMAAAAAAQIRAxITIQQxQVEFIjJhFHEjMyRCgf/aAAwDAQACEQMRAD8A8hqC 6dTTHm6Viwz+3TxfSW0o7So7CitKyroElKmynSgqRyESjFBcEaLZhXBcuJRIezCmFPKY4qpB s0phSkppVSJNSJSmyrTSpspySEESF0pVyQNK5cUiRlSJYSJAqaSlKamVchuTimuTTTSmpUhV JcuK5ILIIiRKSkJTBhTSUpKaSmkhKaUpXBBECWEqQoBFwK5dCZOhclSQgETgUiWEByWUi6EB y5KkhAclSSlQClJKRcgFlcCuK5AKkXLkAoSBOTQgJWDZLgFYAKvwmpViwLowY5pWGcBYjzQ9 oMhwvNrR9UtMIOJbF+C1ZojiguKktpyVGqBZZNcQqjyRCUWYe4CYUR34PNY1rAguBSLgpUVd K5IEgUJU1KCgHSuSJQUKKSlBTAU5IxA5Ea5ABTgUjTGvhSG1VXNcpDHXAU5NeObr0TZn4B1/ RW2HflM66KrwYhjOwVmyy5L9vruOawi/q40vYAdNQszXqXJOtwrh1qcKhq8VpnRxzSurt1VZ ihYdpPqrOvUsfNVjqwIgws15/SurMsr3BH+UztKpK7gdFc4cfy29AF1cT57+Su9JBK4FDBTg 5dDx9CgpcyHmTTUT2WkplUjRT6GIuqVr1IpVkbK4tPQrK0o1ll8NXVxh6y0xyRYvqb0dtRVm HqeimNctpWdiY16M2qobSiB6pKe2qitqqubURW1UhpYNqJrqiiiskNVMaSHPQy5B+KmF6NjQ uZLmUfOnh6ZClyE5yRz0NzkA2q6yiuciVXqM4qbVQpcmuKRNcUlaMcUxK4oRKinDimrpXAqV HhdKalSBCUidCGSmZyUJkpQUEMCuLkLMkcUA8vQ3PTS5Dc5Bh1SoFV6lVCoVVZ1URX1FHe9E qFRHOWdUf8RNNRBLlY7I2JUxBsCGc+fZExt+hbIiUyXHK0Enpw7rXbH3Tk5q1zYgXiOREXV5 snYdPDtgjxcTa580/FbVAsBot5hIzttTBkpNtAA7Kmxe1ZsFDr4pzjcqOQnacwLUeXapMicG p4akvQWVdCJClYfCSbhEgt0DRw5N1Np0wApzMOAEGoy9lWmNy2ilDqOyo9SB3UGpJMlK1WMN qVSUMMlGa1OWbWQH4a4MRXBMqFJcAcUxPyriIQYRahvKI9yQgIVEY3TSjvbCCRKDDlNcyU7K UsoNHcxMcxGcOBTSEjALF2QIhKE5IBuagvR8iG5qQR3FCcxGfqmPQaO5MBUgtQi1II1QILwp jm2Ud4SsMBzVFc1THhR3qLFRGIQyEZ2iGVBglJlRCmJA+oLlIxGxAEyOKCxXm5OOaSGo4UZh RwsnQJKXMmkpEFTsya4rkhKpJhTE95QynoOKYUqRVINmOTCUQhNVaTswpqcU0plty5IlCQcu K5KAlTMXQnFIEgRInGUkJEaSuKUppKcKmkobkQppaqTTEiWEhTSVMlPlMQDSmkpxKYSmRCmJ UhTJxK4LkiCLK6VyRAcuXQuTJxSrkoKARLCRcgHJspQkIQCpZSQuQCQuTkiA5cuIXAIBUgK5 cgOXQuXIBVyQJU4SZs8XJU9ig4Maqa1dGDHNOo0bEyFArvJEdVPYwCkTNzooRAiStKiIhCj1 FIcgVFlk1xBcE5/4QE1xXVDYdljWsNXLguKk3LpXQuQZVySVyQLKVJK4lBlTgmpQUHDgulNS pKPBUjDyXNHHMAPVRmqXgf8AmM/1N+ajL6b8E3nHpVBtmdQCrFlyFDZqf3CmUhF+K5Py+un+ MWZd4IjVZ6s65nqFfYmoGsaeOiz2INyT39VeQwVmI16KlxFKCYV7iKt/JUuJ1UHn9IBZpJWi YfCFn6moHVXDKy6uN83/ACF9xKlKgtengrbbzDyU0uTS5ISgaKXJzXIcrmuQNLKhVVvh6t1n mFWeFq3CqIyjS4eraysKNVUmGerKi9b41lYsg9KHqMHp+ZaI0k/ETm1FFzJc6BpNFVIayifE SfEQNJfxUheo2dd8RA0kZ0oqqJ8RIaiey0lmqmuqqI6omF6nscgr3psoRelzJbVIIUxxSF6G XI2ZHoJcnvcguKm0zg9KCgylzqNhIBXZkHOlBTMUlDJXLoQCJwKbCa5yAXMuzIRK6UA5zkJx Ti5NJSMF5USoVKqKFWdGuiWjRK2qhwXOytBJOgAV9szd2tij4QW05u6It05rc4Ld/D4VgOrh xNzPmicf7K5MpsHcouipX7ht9Oq1Tq1Og2GNA6f3UPH7YLrNsFVOMmSSVf19FJak4vaLn9FD TiUgCGkmiAJzWp7WSpHw4QYAYnNpozWqdhcJxKqRGWWgcPg4upzWKS1oCG4KtMbls14Uao6O 6LWqwoLpKmnjEV9ylFOUcU+a4rOt4j/CSho4ouVDfTS0cCqNSNbzRAxMcIRpcCcENwRHNSRZ GlRHc1MIRHoYakoF5TcqK9qCSkYTghFqkvah5ZQYLmpMqM4JgSATgmOUlxkFRiEAJzkNxlGL U2yRo5YmPYjuCA8pACUNxRITS1IwiUx7LIpCY5IIjwo72qYQgvHBKnEJzUItUh+qC4LOqgRC TInFqRSYr2WQsikkJuVR2RcA2lFa5NLU4JDRy6U0rgU9g4lIXJHBNlVKmwpKYlJTCVcSWEia SuKuJpSmFOCaQqSSU0pYXfNIGQlCUpAkbkjinSkASMnBdC4hcjROSJUhRojQUpauASwqIIhI 4J5THBCaYQmOTyEwpkaUhK5xTEE4ppXSmkpk5IuXFBOK5IU4IBFxSkLkAi6EqQpk5KuC4IDi khKuhBuSEpUiAVcuXAIDlyVcgiELl0rkB0Lkq5AIUoXJCmCldC4LoRCqwwY8PmVLaFHoHwhS F04McllVj7uy1xUdJGsQLeyrsSW5vCCBAsTN+KssQR8MAG1vWL+8qprNurqIDVbrCjPUmsR8 lGqhY5NsQXhLV4dgkfqnVdfRY1oGuXLkjdKUJpShAcVy5cg3LkqRALKckaFyRuCeAmhOlCit VrsOiHVmg9/QhVTVe7tU5ryOAlZcn07fh475I31MKZhWzoJUOn81YYcRC5X1d+iY4zbSCqbF G6uMYJ4qmrmUUYxX1VU13XVq96p6h1RE8n0jPF1Np1lArFLTqrr4/p8z8+7zWjKo80bOq2nV UltSVo4EoOXEoQKI1ALK4LkoTIRpU/C1FXBSqb04mr+hWVlQrLPUKis6FVbY1nlF0yojB6rq VRHL1e0JZeuFRQxUS/ET2aWHrsyjNqJRURsaSsy4uQM67MjZaGzJrihZ00vRach2dd8RCLkw vU2noYvS51GzLviJbGkkvSZlHD0QFLYK4oZKem5UGGQmSjEIXFSZJRWlARWOQBgE6ExpTpTD ihOCKShkoAZCalcUPMgHlNK7N6KTgdn1K7oYIbxcdAmEAtc45WguceAWr2LuMIFXEG+op8I/ zBWGBw9HBEE+JxH4iJv+ih7U3ifUMMsL35hVIn7WWO27TptyUxcWtAAhZiviXPMuKEB5roTV MdBwuhEyp3w0tLCDEZtMJ4alhPQIAiZpTIU3DYKblGk5ZaPoYYalWAZZcyinEqtMLdmEIb3w JTn1YUQukpbPGAuaSZSBqMWIrcPxSaT0A2kSnfdQrD7tAlRXPRo9otSgQgQrBziUBzFOlxCc EGopdRij1GpLgTgmZEcBc0IXtCNNCe1TK7CghkpHKjZJTPhQpkQh1TZKqR5QqjLJ8JMik0a6 QNUiAo9R10A2oIQnjiiOumDRIwnBABupLghPSADihOajlCISMN1NCcpJuo72pAMphKc8JkoA Lgg1QjlAqlKhFLIQntUlwQaiiriM4JsIrkxQBykCe4JqxUcU1wC5ISgtEhcuC6Ey0QlcXJHJ sq4iuJTSuJTZVxFdK6U1dK0iKeCulMlKqS4pqc5MKVDikTpTSpUVIQlK5AIlhIuThOISFLmT SUyJC4JyakRChkojkIoBrkNzkrkxxTTSOKYUpTUJIkK5dCZEXLl0IDpSgJCnAIBpXJSuIQCB LC4LkBy6UqRMihIuXFAcVy6FyDKEhCWF0JAgTkkLimHQuhcuQCpF0LkEWUhXLkyclXApRr5p wVY0BYKXTMEFBDI1R2ASJ0sujBjksNo3axwESDPASOSpnuVttSrJDQIAAgfNVFRXUwB31Q6q KUB2qxya4hHVK83SxdNdqsa0JC5cFyRkK4JYTZQHFKkSoDly4JYQZQUi4LpSMoTgmyllBw8L S7o05qu5ZCs00rY7qYeGF8627CVjy309P+Om+WNVSN+inUWqDTGoU3DGFzR9PfoDGFVlWpEq yxhv3VTVNyg4rqvFVjwrGu6yrah1RGPNdRCxL4QW1EuNdwUVr11YfT5f5d3yLFj1Jp1FVsqK RSqLRyrSm9HY5V9OopVNyCSwU4IIKICmBQntQQU8OTSsMNUVlTqKmoOup1J6qVNi4o1EdtRV tKqpLaivaeqXnXfEUQ1UM1UbPSb8VPbWVe2qiiqjY0sRUlO+IoTaieKifYtJJemmoo5ekzJ7 GhS5JKHnSFyWxoTMuzoJKcCkBGuRmlRwURrkwOulMD0pKZOLkBxT3uUdzlNOFLkoehF6bnS2 aY1yKCobHp/xE9gdz0Nz0J1RDzII9zkNz/M8uKJh6D6jsjBJ48h3K0lDZNPD+JxzOjXg3sFU gQtmbBJh1Xwt5cT+it8RtVrBkpgCLW0Hfmq/E7Sc62g+ah5VWiFrVnPMuMlMhKAnBqZw0NTw 1PypYQowNXJUsJm4JYToR6GHzFBW6PwmFkyVcUqKTD0IClRCpz5ZboRYYUTEHKJU41oVJisS Xu6IoxmzS7MbooZySU6RUqnZQ10G1kJ7DdKYTRTJ0QEqviBEBVxYiPaQkQcNLoEKNnRa1Syj QkuFc8INQImRNcxJcR01ounuCbCShXRCjuT8/NCJugIzzdDLealPYmFqVVEbLdCqORajoUcq VEqDkgFSIsmFiSoBlQXOhHcVHISNxKA5HypjwkAShEohCa5qQALimuCI4JgQACENwRXtQykA ntQKjFILkCqUgAUF4RyhPU1URnhDyozmoZU0057UJzVKcEBywsMEhIEUtTMqQMTU4pYQDXIR Ri1Me1VEUElNKc4IcLbFnSrlxXBaRnaVcE2FwKaTimpQkhKm6FwXFIFJnJCFy4lBkhInSuBV JNSJ0JIQCLinBIWoAZCG5FKE4JEC8obk9xQyUJpCmylJTYVJcuK6FyCcklOhIAgEShcVwQbk sJJSoDoSJWrigiLkq5BOSQlXIDgEi4JUG4rmpEoQCrl0LkA1KlhdCZOCRKuQHQuhclKZGwnN 1HdNRKYuO6cKrdxn0CLQbJA6jRCJvZHwo8Te66cWOSVjvE8BoM21gn1VXWqSIiCCf9lNxtTx nnKhimTPYnkqpRHDZUZwR0EhYZNcTQBm8pQk5pv5EJqyrRy5ckSN0JE9NhIOSwkKWEwQFLKR IgywlXBdKA5OSALpSVD2Fb3dSifg9OpjqsJTC9G2IyKLOw/3XPzV7X8Vh/ba4pthSaIJkBRW survZeDo1GHNVLH8NIKyxe/nl1m6oMTUk9pVXU1J53VttHC/DeW5g7WCOSp61SB6j0KVVPav rtuoNRqkV8RclRn1rdU8Y5PkZelVtEqCCpG0HSQooXTjHzHPd50cOhSGPUJqKxypis6VRS6b 1VU3qXTqJhZtcjscq+nUUpjkyHm6JmQQ5OTJJY5Tab1WNKl03IJZ06ikB6r2PUljlUpDl6Qu TZXBMFzIjXoUJzQmSS2ontegNKeCgC5lxehkrpQBMy4uQ8yUFAOLkrXIbnIZejY0lZkoqKLn SiqjY0mNqJ3xVEFROD0bGhnPQnOSFyG5K0FJTCVyaUjEaUQuQGpwBJAAJJ0A1ThU8lT9nbId V8R8LOZ1I/yqXg9iZYfVubeHgO6mYraE2ZYc+XQLSYpSzWp0aeWmL+5PMqrrV3PuT5IMc0QB WHBqeGpzWIgajQIGJwToTUzIU1OTgxPQMDUQNTwxcQgyNarXBUoVdRpElX1ChATZZ5D0mpzl yDXrBrSUMZ7QMfifyhRG04uhfHzOLkb4krO10446iU02QnuTBV4LglsHAqYwCJBUSESmYT2H Vat1DqVCprSEythhqD5I2cV+UpQ1HzDRBeYKGkDeo8qU64QHsSOBlMKMGJjgkYM3Svppxamt MpGA56a2olc1NLEKiPUp36IbqakPCjlylUMKGXJ70MtSUC7VMcEcsQikYJCR9Nc4paZSAGVM qNUqrSi40QKgsgIrgmIzmoTikAnoZCK5yYRZIAPCBUUl4sgObKVABQiikIRKmqBeUPMn1AhQ pNbuahuapbmoTwpsEQntTJUhzboRb6qLDRykCIWppCg3JpCWVyJSsBe1BcpkINWmt8KwzR0h TsqSFtGVcAkhKkKCdK5cuCQcEoXBckospFy5AcUkJSuConJEsLoSIhSSnJhCQNcUF6MUJ5QE dxQiUZwQXJpppXLiuTQ4JYXLkApSBKmwgOK5cuAQCrilXIBAEuqRcEApXZV0LkB0JEq4IBIS QnFcgEhOaLpFyA5LK5cQmHBIlAXBAckSwkhBFSFKuQHAI2FjPdBARsJ+JVimrJoVjs5vjB4C 56KAFY7LeWuNpaRddWLChbVDCZYHAizgTM9QqtxU/aL2moSyY5H6KvqIyEDKATqj9UBY5NoY 3imFEKGVlVlCRclKRkSJSuQHBcUi5AKkhKkQboSgLguCQjkq4hchUScNTlwA1kBemYCllpsb xDQsDsChmrNjhdeh0r+RXNzPov4nH+tqWzWFIe0ZTa8IDRcFFqPtx9Fi9iq3EVADfsqyvB91 OxL505xyVbiCg1fXaFC+HCl1jKi1TAlXg4PlXUUmNfLlHKJXPiKEumPmOS7ypQU8FDJShNCT TepLKigtKkMcgLKnUUym5VdNyl06iYWDXIoUVr0drkwMEemVFa5HYUyTqRU6noq/DqfTVQhw EuROYEQBMgsiUNRi1JCZGQlCcGroQZIXLiU0uSDpXEppKaHIB2ZDLk4lMISDg5dmSBq7KgCN cjNco7UUFMCyuhICnIIxwTITyVLwWzS+7paz0LuyJNjaPhsM55ytF/Yd1osLhqdBvN5uXf8A 4jghh7WjIwQBy+pSVGrXHHSbSVsUXm1h800Bc1qK1qsjQxEZT5pzQnhGg7KlSFcE9G4pA1FD VPwuzi8iZjkq0m5SK9lE8lMbg3RMWWhpbPaBoAi5YVaZ+RlY4JQ2VP2lgIdmGh9kzC0hISsV 3SMLhBqdVPa1Ixqekzt2E5qq9p1xcDsrHGVwxpJVC92e6nKr48fyFQp3RUSi2E/KsW4lEACD qnFoQgucmBKpjRRnVE4vQ3BAjhVXF/VMLUyEKkI4pHFOCUMCFBhyQu4FKYCR6DK1qZUYhuqr hXMQUGE9yZmhPehkJHHP5oTnojigPSN1RRCLozk0hJUCcErzZOKG8oMEqO8I0LnMskaIWJhE KSWoTkjIaiE8yFzghuCQDcFHeFKdoo5HNIBliHCPCaQgIxah5YR3Ib0gBUFlGeVJquUR4Sph OahwiPKZCim0BpIL28FNdZRnBKhEexAeFNLVHc1RlDlRSEMqSWoLgslBEJE7KmEoBwK4hIE4 J45aTljsB9JByqaUF9NdOOW3NljpGSkpxakK0SYUkp5TYUh0rkoC5BkXJVyIRFyVdCZOSAJ0 pqAVMclKQqaAnIVQozkJ7UAEoRRihOTiKYSuSpITSSVy5cCgOldK5cgOXSuXBALCVNSkoBUg C4JSgOK5KCuQCLkoCQoBQEhXBdCA5LCRPCAbCWEsJCmCQlBSpEg5dCUBcEwSF0JxTSgnKTgR 4j2UeFOwVOGE8yR6LTBOSSxWGDs1xjkoNLqp1N8Bw5/RdMc9QMQblRSVJqlRipyPExxQXozk JyyybQIiyZKc4pqyqypJXFKkZEgXFcgFXLkkoMoK5ckQCyuCRKgOTwExOakqL7dekDVknQW6 reU1jt0aILnOPALatbdcfJfb6r+Ox68X/aVSXV3WTqTeSHjH2UO/8qrFc+MquqvU/EOk+V1W 4k3Qqq9+qi4k+E9lLcLyq/HuhpPkteOPL+blqVRkykSLpXQ+ayvssLiuSwmRQURrkIJQUjTa dW6l03KtY9SWVEzWlNyktcqylUUplRGwntcj0yoLXKRSejZWLSip1MqtpvU6g6VcqVhSCOAo 9J1kZrlSTkgSSkLkw6U0uTCUmZBnEpuZNzJhckBmtlSf4cT0Kbs14BudVdsp8eCeM2jK6Zyt SLDBFuB4FMlaLauGBpzx4LOgoyx0eOWzgEhTgJyjmQPdXu0tmNFOR+7Ik2dqgCIChA2TmlIC hyeD5nkh02Fxhon98SrihRbTHN3Pl0HJVIVpMLs4AZqlz/Ty7qRWxRNhppy9EF1UlPpsWkiX U6aMAla1PAVE4NTwEqVqoyJZSkIrWI0DMqPh8MXG3780fC4MuPT5q7pUQ0QFUjPLMzZ2ymtM n05qc8AaBBbWXGqqZX2eaifSElV9TEwm0sYZS2NLyvTBEQqU4fK7orSjWDhqhYhl0iR5Stuu LUHGVg1vdKrxm1ZtB+dwA0BQ8iRlYcVzrrDK7dOM0RpunlyGQnKVEfUTqbAdSguKcxqY0I5s FcEJ1VMLiUz0PViEAuC7IU1Cg3OhIXEohYhygwyngLouuckYL2pPhohCbnQAiEOUepdCyWQq AvCHlRimSkYbmwhEotRyA5qDNJQyFIptshuagBFqG5FdZAJSMN6C5Fe26TKkewYlCc1FdZDc +QkYJsgvKI5MypA0FCdYooKSqZSCNEobiiOQXlACqtuo5Ul7pUZ6mmBUF0OEVzrphKim0rgh uCOWppYihGLEFzVKITHtU0toDmoTmqc6mgOYsrFSohYhOClPCE9qlSPK6U9w9EwpA4FKmAJ6 vHLSMsdhVGIMKXCE9q6cctue46AcmkIhTSFSTISSnQmoMiWVy5MnJUkJ0ISSFxSpJQZEiUhI VIBJQ3oxCE4JAFwQXIxQSmmmFIlK6E0khcUq4lBEhcSuCRAKuCQhKEAqU6JE6UwaEsLoShIO hdC6eacAgGQuSkJCUAqRcEqDclBXJUBy5clQHLly5AIV0JSEgTJyUwkSoBIVhgmfyyeqgFWG FaQyOa0wZ5JDVZ4fENa0gtmR+7qA5gEXmRPY8kdx8MrqjCoDxCA5HqIJGqiqxCemVCiOCHUK xybRHekTnFNWdU5cuSgJGRIlKRAclCSFyAVcuCQoNxXBclQCpzUicElY+62u6WHimXczotTT 0BVFuvSiiO1+VzM/JX7XWXFn9vsfiY9eKRJY6Co+OOaT2U2m0ZbqBWdqO6TefasqjXuq/FaK bWdZQMRcFJV+leVWbVd4PMKzIVTtf5rbjeN8/L+tVK5cuXQ+eculKuQCJUkJUGe0o7HKMERp SOJ1N6lscq6m9SqT0GnscpdJyr6b1NolAT6JVjQKrqKn0SriasKbkcOUSm5GaVSRi5MJSSuC ZOJTSnJsIM1MKJlSIBjTCvNl48EgONlSFqVpggonpOU2121wA0ELMVhdWf3vM0SoVWgVrfbP H0DREuAHMFaLatf+VHGw81B2ZQADnO10CbjakmOqMZo7dqlqkYXBmobmGDU8+gUqnQAElDfi Zs3RTpUqZna2zB++qRslCpNUqmxXIVOpsUljU1rUUBXIk5KFzQlATMoCcGpGNR2NT0NuayFP w+Dm50RMNhYuVZyA1UzypWUw0QE2o5AqYuyiOxBKEaTDWAUarXJQXFDe9K1cxOzI2HbJUSVL w2qnZ2LSk21lLDLXUeipZIyo2ysRy1UGPfL+yuK+JaO6o8VrPNZ55NuPEAp1IrixcFk3PKaX JSVzQmZkJ8pz0iYDcE5hS1AmFvFMy1aiAiuCG6yZmucmwuBXEpKNemg3RAUw6pA14QnI74SO w4I1QYM2Q09zhogOKDNKa4IgbIXZIKDCdTTXItQoRCAHCYeiLF1HeIKRkcEJzAUZzpQZSAJC QQnucgOEpGbiGQgsYptQ+ESomeCkYDolCej1BxUaoUjJmQaiJCFVSALig1CiDWUyoUgjuKa5 PqILipphP1TE4lMUm1xamEKRCY5qCRnNTC1SC1NLUqER4QXhTH00B7VFglRHsQHNUxzUJ1NR YraE8IWVTHtUdwUKBlKCuK4lAPBSPCQFOWmGWkZYgOahwpJagvaunG7c9mgSEgCKUwlUkxKS ulcUFTU5dC4Jk6VxSkJEgRyanppSMNwQ3hFKG5qAjuCG4IrghOCSKHCbKeU1MjV0JSVwQRIX JUkIBSuhcAlCA5clAXEIDgUqQtXIBQE5IEsIBpCSE5IgECVIuQCwuC5OAQZF0rksIIqRcFyY LCRKFxQCALlyVAcFcFhsNbDTjZVACuqDiGtIWvGzzcKRGvorbD7Gq1KPxGDMc2UNAJd3jldV gcXG+tyvZvshwcF1SRAZBHEE3H1XdhPVt/Dlzy08Xq7PrAkGk8AGJymAep4KDUaQSDqDC+md /MKDgcTUcQAGucAABfr7r5oqGST1Pop5ccdbxPiy2A7VDq6opElAqarjydMCdqkSuSBZrcUi UpEgVIlhIEG6VyVcgEXJUsoMhXLl0IBUSmJhDCLSMHqlV4XVj0nY+HIoskGY/srmlRdYZSSe QnyWe2TvJTfDTLHQB0kcQtlgcBXc0OaJE6gmfkubx3LJ9Xh8jGcc1SHZlZok03AcyD7qnxFI glbEYHG1f5RnpNveyqzujjKj3MDPE2xmLecrovxcr9Jx+ZhP8soyT6Rv/ZVmLN4HZXW0tl16 bjTIc2oNWuAB52HYqgxTXg+IR3XPlw54322vycLPVALFQ7XN45LSUqzZAqEAG0lZna+Gcx8O gg6OFw4d1rhjp4vzuaWaivKROSK3kuXBcuhAdKUpClGiDKCuSLgkB2OUikVECkUkGsaRU6gV W0Cp1AIC3p6BTqRUGhcBT6SuJtS6bUUIVNFCoj10JU4JkaAuhOShqDMhNKdUBhdh2yboGzcq 4UpRnwE01lUTakfFysHRRX7T6IdUk66LsPRBMcArjNd0vwN7SotSq1tzc/VR6uPyCOCqquIL j+7JXI5E6pjC8xwUvD01GwdDSVa0WQnjDotOlZSGNTAEVoWsiTgEUJgCKEw4J7QkAUijQJTI lOlKtcLhQEynTACHVxXJMqmvrAKM/EEqGXpWvQWhCSUoTPiJuZTarQjnJhcmZk8NWdzMrApV FNp07IoZCi5ipjcWAouK2kSCBogPeo73qewmILnuJunySmlFY1S0hQnimEgSFyZiEAJrqoQk mRUcOc6UmYJcgTHBNR0JqVtSEyUzPDLINamiXQKhQZoCaSiNahv1SMjSmVDBT4XVKVkjB+In l9kINTs6ACWrsiM+naUElMygpxFpQQixZAR3XQpRiEEhIEJ4oNa6kQgvakaM4oT0abp5eEjR mtkIZapTzAUZzkjdWNlCepD3SgvCDAchmESoEwhSAXNQyEdxQXpGA4ITwi1GwhEpAAoDypFY QopcpphuMIOdFemQpNtUhCK5qbCCBIQ3NUgsTS1JKMWoVRqlOYhOCmhDe2EOoLW1UpzEFwUn KhPYguapj2ILgoq5UNwQy1SHNQnBQoxKCuypITBS5NcE4pVrhmyyxRyEMhSHILl0S7Y2aMIS JSkVIpJTgmpwTJy5LCUBBEXFqWEhCRhlqG4I6G4ICM4ILmqU8ID2pEA4JhCKQhwgjYXJxSQh JEieEhQDUsroTgEA1OK5LCARdCcuhAIF0JcqWEA1InwkIQDV0pbJIQCpQkCcCgy5U0hOlcmR qVclKARcEq4IBIXJyTKgjmCSrXLYdlXYUeMcY4K6+6vcRlaeehEea240Z/R2GplzgG6kgL6B +z7ZLKdMPDtWw5o4QCL+68b3ewtSlXY6pTNzYRmmdAvfMNh20sK934HOpuzGS2DHLgu/6w1+ 3DyI2+GV2AxQpHORTfyI00Xy0z6n5r6TqUPi7IrNov0p1CXg3LhMglfOAbxi0kecqM5rHS+E FhugVBco/FR6i4snXAHJAnJFmtwK6EpC4JAhCWVycEGaAkhOAXQgzQEsJ0JEA0pUqWEAgCWF yUBAGpi3yXtm4G0nnBmXcdTy/YXijQvZ/s0pThajY7eZK6OHGI5eXKY6leo/djTrUHfED2ut On5T/ZaPCsAqP/qIafITp6rOU6BGGw9Ti0tn1i60L6Z+PTeNC1zT0tIT5P0w48rbu1599q2A aHUaws45muiLgRBPP8RXl+8Dg2mwkWzCeo0+oXsH2qYQuoU3tH4XFp6SAR/7SvD98Hf8O0dj +/RLP3hi68crPyzW8FdjqgFM+GBI5dFVVa7iA0ulo0HLslchFcyrlv7NKROKakRFyUlJCA5O ASLkgWF0LkoKDc1SKZQAU9hQFhSKscO6wVTScrLDuSC8w+isKaqqD9FZUnK5STWIiCwoocri RAnIPxIT2vlMChPC5lIkW/RTKOAgS4phFa5BrMgToElbFNadVW4naGbRGyPqVSdElMnjokoi 0ob6iAkurzDRzVhiCKbQW8lUsskxuMJAHknstBVK5ce6NhmSbqHRuYGqu8HRgJYzdF9LCjTh TKaj0QpDSuiRA7U8FBBRGpgZqO0IDXI7Kg1lG4STRozdSHVgFEdtCBYKK/FE3hK5yDSa/ElC +IoReU8Aws7yK0l/ETg5RKbYR6b0vIBC9cBKUN4pyzuWwfTF1KpsUYNT2kpBMNUAKHVrngmO aSnNpoAd05lEkiVJp00400A34QCdkXOKQFUrbm0SdAmOZeFKo4qFHrVLyqOG5YTc6Y6pKQIU UodRy57jyQT1TXHSlzJq6EGO16jVGmUZrYTnvEJmjNfC5De66UOSBHPhIaia5iYgygroCcEw hIFL0wCUoSB0Jg17FzdEpKYSgEKEQitEoFR0GEGYSmSnvQSVNM2o3khEJ71xiEjCLyRBUR5U t0KNWakAwJTKieDCY5yDDbdDqWREGsZSAeqG9tkRohdU0SMF4lqilqkkoJcJSAZ/CR0Ve4Qp 7ioVXVTVQBybKV4SQoNvE0BEhIWoSGWprgikJkIKguahPapDhdMcxKkiFqE9qluahPhRYNoT 2qO9qm1GqO5qiqlRCENzVJc1Bcoq5Ud4QiFIchHRIzJXSuSJyghQnosppC2wyZZ4hQmEIrmp hK6JdsbDE8JITgqRShIAlhOYEE4BdCfC6EDYUJj2ojmprgkYDggPClOCA+6E1Fc1NLUdwQi1 IgoXImVOZRc78IJ7IAMJIRSyDGhShiRBJQE9wXZEwYQuhLCVzUAgTsq6E5rUjdlSFqKGpcko CPC5yKWJpagBwmlELUwhBOCeAmgJQmZSmwnlcmRqWEsLkA1LkTiVwQRsLgE9dKA6k4ghw1C2 GB28akuJa148gbLHN1R+B7QtML7RlPT2PdDaVanUa51I1gSACG5oPIeqt95d4MfiRVpMwdQN gtJax5Ib1RtyMIW0KDeJLXTprf6r1bZ+EDC+8kuk9J0XXc5jN37cmt3TwHYe2sfQwlem3C1H 0IeKjspIZaDcceaxm1tlfBhzTNBwFzwedV9V7KosAr0xBHxX5m9HgG45G68c2vs2gwYjDObm LXVIPZxgjloleSXf4azDTxio0ZXODgbxAIkKEQtBvThabPgmm0NDmmQOJnUrOucuTKtobCRK kUrcAulKkSDilXJUGQpYSAJ0IN0pE7KkhBkXJVyCIlC5KAgDMPzHzXvu4WHaKIDAfEwH/ugL wSk2Y6kD3Xu+4eHc0tYDqyL8Dw+i6uGObnvp6XhKZOGcw6tv7yFdVqxbSzxcNDiPmPmh0mgt 7x6ixUoQR0Ij9QozvtPCwH2i7xUjhhTZ43Oc10jRoE8ea8H3xr+Fre3pdbbatQ/Gq036sc5s HhDisHvmfFSHQpcnr+v6dUZV5QXFPqFDJWCnLlxCRAcuC5ckCrpXSuQZ0LkiUJGUJwKYulIJ dMqwwr7qqpuU6i5AXuHqK0ovVLh7aqZ8fkjZLYVY1TfvPJVjXE3Km0Y1VykmUqTydPopOQtC h1McRwQauKe4KtkkVtoEW1UN21HHifVC+AXfsprdnTPiuFN3QSlUJdJ4qbTp3QaGFIuVLpkE qsYVPrQ0W4qM25TcVVkxwSsdH7lWTsTUgKK508VLqbPrPuGW62UnB7Efq+Akew9lUgXSf2Vd NbCbS2MAdbcrhWlLDtHBaY3SaEymSLAx0CKxhKkfEPDRc1hVdkm/BhPCPToBFbRU7oRRTJRG 0SpApozaCkIfw0ooqWKKIKQCWhtBFJOLFL+GnCmp0e0QUkQU4UkU0VlJHUbRmpwapXwhwUpu GbEwnMS2g0wpDcK48EeWDQIn3wxpCrqW0SMpuntgpQ+8lEquBEo6gx1QBAdVlcaZKT4RR1Mh ehlyP8FDcnpUMBTHPnRIUgMIaQ8NSGpCR1YKOU1RNzCJUYuBTAEgYg4akm6eQmJm6q8prblP Q3EhBjVaAAlRjZSy+WqC+UA9xQ8ik0Ra6DXdGiQDJTQyUMPlHJgIMxoTHC6Vz0wvQHEppcng IREIBWvhMrMm6SUZplAQ3lMLbJ7m37JSUqewSFHqKSQhVWJBGLeKUkQnlyA9ySgXoeSUQsKa HQgOfThAcpbqkhRq0JAFyE8p+ZBqKTDcFFrFSnlBqsSNHModVkXRkGo5I0V6GEV5QlFU9DIT S1FhNIQg0JhCfC6EioTwhkI7moZCKlGcEKoxSHtQyFFCMWqLUZCnuaotRqmnKhOCA5qlvahO ChpKhvCG4KS9sIRU1aOUkIhCYQkDISJSlhVKVMeEGFJhMLVvhkwzgYCJSoucfC0k9BPmSnU6 JeQGiSSAvor7Mtz6NHDmo5jXPdaXNBi0mARpcLf6m65sr7fP9HZ1V9gxx9feyttl7nYqu/Ix nitYr3LebYtNpc9jWjMZsIjw/qEzcLZ/8wv5C55zaFxfH+XObO4z8DKXTCU/sLxmSTXpZoJy nOL8BICyOO3CxjD/AMvNDQ45TJg8AAvqtVWFwQFR9uBHeSujlzuP0nF8l1MG4EtymRqLyO4U QiV7j9qu6dDD4OpimZvjGs2XTq10gtjl+i8SLUcefaNEZyE5tlIc1Dc1akiOahlqluphWWyN 1MViyfgUXPA1IHHlOiJLfoqoRTlbjdnd341MEEtdJuOSg09ysTmcw0nNc12VzXDLBB0kr0nc 3dvEU4aKYJmNdJB4jusrlL6nsKFn2QVK7yTUEkyLOv3VliP/ANP9VrQW1ml0EkQYHmvZdn7K rUzmOQ2HhBPzhTMZtgUxdjyYmAJ91N5Os3kzs39V804v7JMRT1qN6gTbzgqDU+z4tBOfSTxO nFe0Y/bNKscrXEHQhwgyJtCpGN1ta49l5XP8/LD3HTx8W3hO19mfBc1szImeEKFC1e+NK4to B/7j+qzOVel8bl8nHMqjPHrdBhqdCcAnhw8lulI2XgHVqgptFzM9hqtBjN1K2UhlEgg6wYPR C3TtXbwk/uV7hgGtNZwJES2LiOP9lz8vL0sOPDsPuDj6haG4d3iIAtzOqDtHcLHUXuY+iZbE kXFxI+a+utmlpbIidDEfRQt4GjKXQJiJhPL5OOPH3Tq26fIZ3axMwWH/AMrvnolqbsVmtzOb ZeubSGZ3mbdJ4IW8VMNwzCAAQW+ffmvOz/k9ZzGT7dE4Lrbw80yCRxBgpwCstvNH3h0CNTa0 +I/2VfC9fDLtjL+2FmjYT8i4BEAVkEykToCewJTq1ItdlcCDYwbGDpZb7dPYzamHJmHySCOA 6rSM+yJ2JMmqC8gRa8AfmMrPyTt1J47lTSvfqH/6eKJo+LEPbXLploBZlt4S06nW88Vj8Z9j 1ei9kkObmMyHDM1p7RcK8spj90PMAlhb7GfZ5lqkWDbOH9V9RYQsvtzYhoHm2QJ+h6qZy426 lGlU1TMKyXtHMqK0K32FQzV6Y6gntr9F0YIy+n03u9gWvDJJDWUqREECXRx9CtfSp+JzuJA9 lj93sIMtUH8TfhRJ/wAvAei26vkrHCfljxj/AIW1XMOlVrPWLH2K8q3xc5m0KvWpUHcFx+hX pe+9FrK9KuLOiJ7G3zKwH2jNYX061M2L2a8ZbB85CL9bafl5NvMDmaOAJA6XNlSOWj3pbDhy zk+REqqo7HrVKXxWUyaebKTqQf8ASLwsdtJFeUilVNm1QHEts0SbOEDncBRQUQ3LoXJUgROh dCeKZJAAJPIXQZkJYUivgntGZzTExPCe6HAQA4SwnwmwgzYSJcwXFANTkkJ7UBLwTZe0dQvf 92MFUYyjVP4c7hPtfzJXiG7eGD6zb/hGaOcBfS+7mF+JgcoiWknz119V28XrHbk5l7sSq4l7 SdDInkU/Ze0256lF5AexxMExLTdP2TQhznHi1g5aT+qym++FNLE0MQzR8sf3AsfT5KNTPO4n x+o883urD+IVi2MrqjzPO6wG+jvGzsf381sN52ZcRPA39RP6rC721Zqt7D5FY8s1k3xvpnyE MhPcmLJbkiVIkbly5LCA4JUgSoNxSrgEsJHCLkVmHJVlhsCBBMdEjQ8Phi4hWlOiGohACaTd ICZ1JosUalSJKs2UYRCOajB1kNoA1Keys2VWyDqVDySGqVMe8PcABJ0RX4MNEmZ9kyV7ap1C 4VXTdEqVJ0T6eHm5S2ZWvJIE68uStqtBpHgMW4qNh2BoManipNNhOivGpqOzZIMS4q4w+Ca0 WAnsnUqUBSGK0CZCQi06aRjkVqZGgIgHBdCKwJkWnRUxtMAWQ2NRWhMtmtpIzaSVgRw1CdmM ZCcngJ7WJgLKlhFyrkA0UlwYERK1iehsyITgAi5VIpYJsSSjQ2gFPa1x7KzqGmBAAn3UW5T0 NhgAappfOin09mSJcfJSn02NboAYT0W1S+jAlMc5Svglx6Kc9gaBYJ6PaqZTKP8ACEXRatQB CqYhsdUaMI0TwFuai1MOZUxm0CBEIJfmMo0qIz6EKK5qm1ECvQI7KdNoHTwsiUx1OErXOGiR 1QlLSoG8rhUTZTsqFEcUNyeShPcmBGvXZgU1jkj3oBXjkup4YgSe/YJ1JydiMWIjigIdatCD TaTdNDSTClBwaISNHIhDdURargo4uYQZwKMKcXTjSAQ3PPkgEe5DLkj3pjJJQCEItJ8LqjkJ r7oBMQboMIrxJShiQRdCurOsiO5INTRIAuhRntujtCWpTi6RmZvCopKNVeopckZc6jvF05xv C50JGAbIdQ3RHOQiUjDATXmyc5yj1XypphvKDUKc4psqTRiEzKjPQsySnoxSIrwhkKWZhCSE 9IUyoZTCEQlMclSCcEBzVITHNU0kVwQnhSCEJ7VNNDeEBzVMqBBc3mpqpUOqxR3NUx4QHNUV cqM5qGQpFQIOVJQUJIRITUA1KGpYTg1VjdM84tN2qE122sD9DovpvYRjDUxNzJ/foF85br0z 8Tzj1v8ARfQ2zhai0H8LAT6BT8vl1x6/bks/sbvJS/lDug7pGHuHT6qZvAyaXmoe7Qh/r8iv P/jfXLlFZ/4tYUKLoqh4mqGuk8ivW+VlrHbLF5l9rFZ1TBkT4Q4kjsfCY8yvC4svbN86MUao cZLqHxOcQ6F4sxvh8lz/AAM+3b/trZoBzUJwUhwQsq9BJKWHzua0cSPSV9TfZ1shlDAsyi7i Xkxc8NfIr5v3eoZsQ3y+YP0X1LstmTC0W/5Gn1v9VlzcvjxtTZus7tvZ4bUqOIu9xd5aAq23 VpAA9l236c5PRG3a0d3XnfBytyu15z0v1HfSlxniFITXL0ObGXH2zjybfbdhmHdTr03uzvrS 8EiNPyiJUauIDo6+sK++0WpIpcmiT0LnCPkVQuF57r5v5uX3p3cM9PLd6m/zP+39Vm8Hs81K jKY1cYgamVqd62xVHUH52+SduFhQ7aFCRPjA5r1/4/L/AMWLPnj0xv2DYUYdpD6gxGVhdLg5 pdbMIgRx4qs2r9nFLDCnkbmLy4EPIOg7ar2/EVgLE3OnkshtyoHVG9LjuZv8lPyPla55hjWG OPrYW5W59BtNtV9JhdEDwg25mdStRjNh0XsgUmA6ghrW37gImxv+SztCnr0tTPH2hmzsR9Oi 74LnNqkWE2ngD0WZqYrFtrnD4nKc1I1AQTBA4AxzlejSsHvXW/8A6jQEaYeqJ55jb0yleXzc eEwv7a8f2wmPb/M7CP8A1FN3rMYRvdGxzZqTzv7oO9YnBs6u/ReBlf8A5GP/AG9Kf4vJdtUY LXciQfOD+qrmt5K72i2cw6qroUzMDXRfXfHu8ZHncs9rDY26+MxhIw2HfUA1cB4G93fTVWeG +z/GvLm/CIIMG2UT3K+jfsw2QMPs2iPzVM1V3dx09AFPpYIfGqlojxGw58StOblnHr/bF5Lu buXi6LHtLGGY1JB7aL1TYuzMTRa4ltMuIAAzGY7xCnbJfDsvf1V0ssMMeT+35FVOI238Ns1K bwQJOUZx5FYvbW9lCtVptDi3LIOYRBPP2W52g2SOxWb2/uXh3YXEObTBqvYX5nG7XWMtIFtF lOO8uVluuo+mI2mz+c48LkduBC883mpTReNc5zN6ESV6NiXSzNEeAfKFgNv/AIGd1wcWdnLr /bs6f12wDCtn9nuDFTFHMLNb7mwn1KydSnlc4civUvs22FkoMxLj+Ou2mf8AQDPzlfQYX1tw 5x6ruuScTiWzJb8MgHhp+q3K863OrTtHHttyE2m9vZegUGuDAHEZgIJGk87qrds5NMl9oQHw qJPCofSJM+i853jY2rgiWm4qMEciSBb1W13vxzquEh2XM1zTI46g/NYJ7y7B1Kf5zDm/6h1T sutQbD2bu/hqwrfHINRgbkGYCfDJt3Rq+zqdABtMQ1wzRqLHko+4W5A2gcQ6piHsNPK0BsHx OJue2R3qrLbOyK+DqNwtRwqMNNz6bwCCALZXTxmPVcPyuHPHG3f06OKy+mexVEVMzCInPB0k fDNl5KxsW5EjzlesVKuWq08nD04rzXa2H+HiazOGdxHYmyx+Fy3LcrTlw0hQlAXQnNavQYlD Vodzdntq4tjHkgEOggwZVFHABandHBVKeLoOe0taXNIJ0I7pZ45TG2QbeiO+zdtYfDL3QHCZ IdHYQOqPQ/8A09McSamIhuXwhjTOb/MSbAdBxWswm0qbajnF3EG19D0XoGGxTajczCC3mFHB y52f2mv/AMKvn3a/2E1aYa6m5rybFoLhEcb8VlnfZ25sZwBOk5uHRfUe1cY2nTJcY1+S8s2r j2VQ0MeCWzY2Pos+fkzx+oMJ7eXV90mU2k+EkCYLQQel1mt4dlCi+k5n4arS6OAIMEBej7VZ ztMrI7y0s2GbOtJwjs4ifcBc/Bz5ZZaydGXHqbZABEakKc1ejjNsa0G6LJxAsY0Ji1wbSvo7 cXFDI6ieeYHnOo+S8d+y6tSJeypxeDMCw0JB4Feq4DZvwsUMlYOYAHAmxibtK7Jj/XTl5Lut ltCqaLPiNEhsZhOrSYt6rO/aBjpwbHsgjOHcyIBt7+yn7xS+kcplsGQDI8/RUu2cbhq+zi0O DXtaIaCAS4GCCOMwVOGPXWVEv4eWbXxnxix8XAgjrELDbyYV7qrQ1jjbWLey2RpjOWmy0VLC M+FBYHSImLkdVy/I5Jjd10YR4k7Z9acvwzKXFbLrUxNSmWjqvUMdgWCYblj1Bi11SVqIqNc1 3EH5Lix+XjbrTfx3W3n8LiE4ti3KySF0ocEq6EWnQJQYeQ6AEnkASlLToQQeRBB9FsN0dnOe 5wYRPJwtw18itlj9w61YiaLMwtnaYt1gXUTOW9RXkdPDkqTTwXNest+wzGZMwqUZgEMzPzeZ LYVDjfs6xlFxDqZJHEXEcwSAqspSsgymAiF6u6m69UXcw9pA9oQ37EOQ+EtIuDMzGvBY3ORp FK5yLQoT0Ck4XZxLXOJs3Qcyue5UD84CV2JPBRS5KFPYj3VibFPoyYA1TKdOe6u9n4I6CM0c dfJVKVFwzRSBJMuMXQK2JLjdJiabmmHD0uCo2ZLLICNcpzHhQKcTzUhgUTMaT6REq0w1FV+C w5N+AV1AAXRhWeRQE8IUrviK+yRSiseoZrJ7KgKO40smOBR2KvpvUyi6VWOW02J1JqMAhMNk +VokZqKAo4enCqmSQCEsoAqJwegJDU4hBa5ObUTA7aRStsm/EKI3CucmRc4ThfmpVLANAkmU 2riQ3TRMAsIBuFNNdg5KtfXBMpc4QEp+PP5QgtJJuCUtGs0aqbhsU0G0FMBuq/0thBqNqPUr FViTICGKjuCoI42ceJSuwQA6pamcmZKGx7jxQqAOgJsQU3GNMozXh7RzSXEbEFBNSylVGiLq E4KWkCqExZCzKQLC6jOElJcMlFlI6mNUxxsko2rUTYsm5ZRAITMhFk2ndMfUlTcKxrRJ1PNB Iz7KPVdMJcS4lxjmUJrkGJSqhvBNrVJuguemNkmEjHo0y42RX0i266kcl0PG4gGIKCCq4koL qxKY+on0qcCUGLTpxqnuqgKO/EkobCEAWpVlAKkOpgiQo0oIZtURfVd8VRnFMLkjPqO1QrpI JTXVoSBHeFDq1pCR1Xmo9V/JTs4YSuYb3TWuTalVLai4lt1CqORKtZR3OStOQkprnQmOehuK natOquQc6cX6qO5yWxo8qNmT3OQXFTs9OemwkLk3Okb1MhBIRSE0oZBZUjgiBqYggSmIzwm5 EUAFJlRCxNhSWwHtQXKRVQXBLQ2jvagOCluCA8KbAhVAgvapb2IFQKbFyorggOapLwglRVwD gkhFKbCRmQntCQJQEJrTbsCHtHMj5wfmV7ru48ue8zZogdOC8N3WbNVvmV7huiRkeeZC5fmZ emFi42q2aXmPkoGwnD4vr8ip+1nRRd6Km3cJNWTwgLn+BlrmTlP6tkspvljRTa08f97+y1ZX lu++P+JiTSbowNae83HuvT+blrBnxzdUWOqmq3ESZ/4dxvcxwHzXkjDZet1qcVK7OeGeP/QV 5Iw29Vzfxt32v7bck0Y9CIRHJq9Vk0+4mFzYlvVzR7r6NfVBcGjQQPIBeC/Z1TmqHH8pLj5a e8L1fA4tzjUcDfwgd7yPkvL/AJLk1hqKwx3Vxt6pOWOqmbusgO8lQ4moS1uY+I3V/sA2PZY/ xquXHUXSFiKmUT5eZRVTbcxwZlB6u7ADVep8nLrgwxm6w2+dQOdVA4NpE/5SHut6KG0eId1A xOINSljXTqQfSQPmplN3ib/2/IL5T5GW8LXo4enmm+Lf5rex/wDcVZ/ZdSzbQpH+lzXeQIUX flkVW9BH/qd+quPsmZGJqVP6abj2svX+Flrhxv8AplzR7PXxmavI0a05eXX5KjxzpcrDCOD3 Bw/DlyifM/VVu0xD40XmY5XL5G6Nf1bLYx/lN8wrBVGwH/ywOgKt19Rw3eDjy+0XEVYj/UB9 fovNdu18+0GuBJbLqYP/AGGQFsNs48NJExq7vAIssB8QE4d0/wD+U4HsQR+i8b5PJrLTo4p+ UHap8fh4S33Ube4/8AOjvoVJ2k27v9Z9JUfeinOzp/z+1141v/nw/wC3fP8AF5PVM+yFg6U1 mgcx7myJUVlujgzVx9BkTme0EdJF19Zw3Th5H1Vg/wCRg6Yi7KNMf92UfUoGz60VL6uE+eqb vFioa2mLFxHoNQotPEhpaf7rzPlfJ3zSfpnjh62dgK5+8QLeNwPaStOsfsirmxJd/mPvK2C9 X4l3izyVuO/F5Jm2qgbgqxdMfAfp1YR9VJxzePkqjezHfDwThE5m/DM9RCXFLM87+B+nnOKt h55tb7rAbyCPgj/UV6DjmxhR2Z9F57vR/wBI/wCr6rxuK75tvQ/+rH45l55yCvZN0KLzsqm2 QAXuynkQSZXj+JEtPZetbOqvZhcFTBIaYce5GvuvfmV6vP5fVH3F2i6njiXXlzmFxkm9vovb nYlsEgyQCY426LzLYG7TX1CSXMIcHSLZjMyr/H1cuMbTDiGwNDBuDLT++KXDnblq/TK/TAnG Q6q0jM15c28+HxSCEWns3M2BoBf0QjSGd4Gge8d/EVPo1SylWJ/oMehXpyMTvsSs/Ft6iesO OvurH7RXA42kJkig4H/KS88PRVX2HT/xVQ6FwHnJKlb+PnHZhoaQb5i64v5HOY45f9Or43vJ 5ztIwJ45wPmsXvM0Gq2oPzt9wY/RbLbp8Dzye0e6zG2KOagI/IbdQbryvhZO3mnpngEWmzim ByKwr2sHFXrv2Q7n0q9V1SoMzad8puCTMT6L3ZmwcMCCKFKQIByNt7Lx37C67g6t/SWt8zc/ vuvZG4hznOEABouNS6dIPkt+XtvW/TC56ZXeenTpODGU23BNgBHSwV7urWBw4ABEG88eo9F5 1tR1V2JeA+QHQMx0E6Bej7s0IoNJEGI9z+qvlx1xyUsct1Z4t7Qw54y6GRM+SodpbBwlei4m k0EtOVwaGvBixBCkbbqua4QbEXBuLclMxDAWjhMeVtAsMcfU/wBpyzsrwLamFqUQWPbLbwTr pwWS2iM1N45tPrr9F6hvrhXGo5oIGRr3XHAySPReZuOnaPZcnyuPHHklxmndwZXLD2xrFbbC 2WK9enTIJBcA4DUgngoFSlD3DhJ9Fr/s2YP4hRJ0DgfQaFdfB79s+S6levVNwMJgqAfRLg8c y3xExYgDuj7PptpvBqfhMTxsrfemtIY0AETPoLImC2XUBZUqtZkLTIHjLQRbMCI5aSurfr24 d7aZmGpvpQ0DI5urYEjuvBN4sJ8DEPYHSA48bangvXt38TlqVsMDIHiYeQOtvReZ77bJqjEu ztg3dLdHNJ1Czwmu0tbY+1CKGYgzfh3V3uLuK/GfFqVK9SnkfkbE66zBKqcLUyt00lej/ZRj 8zcQw/1Bw/fmufc1dxv9Mnvfu7Wwzw17hUY5pLagblJy8HjnBWFfwXtH2qYnw0qf+p//AKSF 4xinRlt0Xi/ImOPJ/V3cW7h7YfaVLLWeP8xPqhswxKutpYb+bMagfsILaa7sc9yMbPYFDCDi pbqQEaXRabbfvReyfZVuZg6zHV6tMVXggAPAcwa3ynVVLtN9PPdymxWJ0aeJtNv7L2/YO02N fDnNiANddVN2puDhHkvp0W03/wCQBjTb+kWHkvNNrbPdRqkA2B/crh5p15fVOe3utKs1wlpB HS6ot5MUxouSDHK3qq/cEvNJxceXr0Wl2lgWVaZa8SLeVxou2S5Ysr6ryDapBu2L6hZ99KCe y9mxu42FqNiC0/1NIDvUhZXeD7OhSpOqUKj3ZQXObUId4eJaQ327rnvxssvcrXHOfTx7aZyn KLA3VO43V7txlgeIt3/dlRJzevaqQBFY0kwEjArbZ2FnxEdlcm02iYPDBrbi/NHwFEPxDGEk SCZHCF1Z0WiTyUnZmCqsrU6r6dQMuJNOoJ84hPklmN0UaTB7sNeXBznHzH1C1+z/ALJ8K6mH VHVM5B0NOBytkuqPA7QYKkkOg9I+a9N2FtKnUpgNNwNDqsfjcu/WRZTTyHbu4Bw5cWkENPIT HOw5LPV8I4CWwR0Xte9ezq1YEU6ZIiNQJ8p6ryzE7Mq0iW1KT2xOomfRa88z+8YrCy/aiNV7 bgwVNwmJc5vi1CiV2nUaJ+GkLm4+XKXVXlhNekx1RNNVDLk2V0XNl1ED5RQVHDkXgl2PQtHH tmJ9VdYRzdcw9VT4bAMcwEi54nhzW93Q3Zw7nZnNDoAIDgHA+RU8fyJ20nLFWUntIsR6oh7j 1XoOP3foVGEfDY0jQta1p9gvOtubvNYTlcu7LlkjLq41mjVw9Uw4pn9QKxuOpubo4xy6qqfU c0gybGdSua/Ju/ptOHc29HOJgoja4VPgMRmptM3In/dGhaY822dw0tRU6p7MSJuqlroTs6uc ibivaeKaSp1PaMWFlSYCkXGyh7ac9r/C4iwWsz1Np6+9NQ4uN5sgGmSqDY+1a5OTU9pWw/hO JyB1ibnLAke90Yc+OZXHSFToc0ytDVBx+MrsF23BjSCqjEbxuAIcz0Ty5cYeONq6qV1zKx4W WIxG8j7weeqh4Xep5qAOJAPIcVhflTbecFeoUMS/SUtbG1KfUFZP+LO1BseSa/azyIJ6qp8m DwNbS23NiEM4682WT+/uXDaLuar/AJB+FqcRigeIQPiQLFZv76TxVhQqyBdXjy7F49Jrq5Ra L5UQBEDlrKWnYp94TBWEJtUKI48kquQSpieC6jdD+FZBLoU7XpLe8AqLXrjgo9Uk8VHe/qpu auqwwuJE3UnG4kZbFUxrCNVFdiuqXkPxrFlfmhOxQVc7EBIx06lLyK6LBtaSpPxwFVvdA1QX 4jkn3HRYVcfKYyoHEKvD51XCrBsUdy6LB74KUYklQH4mdTJTWuTmQ6p0pzWodJqM56tFSaFS AWqG/VKyomPchJCVyRqXEOskZsqJVddELlFc2Sppw2o+U0Cy4iEwuUVcgVR3BDL0yrUugvel tWjnPQXvTkF7ktnojkIuTi5Be5LZ6I4oT3JSUJ6nZ6cTKGSlDoXJAwroXFImHqbkjgueuCTE wpqcQuCogiuARCEziggyhvCKQmEJJAcguUh4QHJUBOUeoFIeUB6gwHoFYKQ5BckqVGeyyCWq UQglqnStg5UwtR3NTIS0ewYXN1TyEgap0LWk3cqhtTsCvW91McAxwHGCF41sV/i04QtjsjHZ DyPXkuP5eFynpm9O2ztMCmBNyfXsqXd3aIFbU3OnmqTaG1AWiXG3mq2jjHi9NrpPGCPTkuD4 uOeOfbR3WnqW8O9VOhTJaQ6obNb9SvLGk5i993vJc48ybqvdiHVKkuMmY9DxVrXN2+RW3zeb K/5DixkTDSzVyOeHeP8A/m7+y8aA/F/qcP8A1Fe00o+80eRoOHclsLxiu2KlQcnvHoYWv8Tl u2f6HLAXBMnVPJTQvarB6PuHTDWvdxyj1J/2W+2RW8B5lzj6W+iwO6lWKL+4+S0uAxwaB0zD jxM/VeP/ACHttwxfbSxGXIeh+a0u7lfMB2XnO2tpyGReJB9dPkrjdDeDK5rXGx9r6KP4/KS+ 182O49NJXmO821S+q4yC3N8NvVgOvqtPvDvMxlJwYZc4FvYGxI6ry9z8zxyzD5rb+Q+RLOsY 8XH+Uqk3+VtAf6o8lJpv8Y7tQqDZ/iA/yvKWgYDOfgPVeFye8cnVPTFb9N/mn2/8yPuTWLKd VwtmIZ+qdv8AM/m9i4eWYoO7pihHN0len8O//HiOX7eybGd/LpN/yA+ajbbMVil2VJeDPBrY 5D9hD3gqAYiTyBXk4cmueQ7Gk3aqEi/9I+av1QbCeBlDbyDJ5cYKt8di20qb6jjDWNc4zyAl fW/Hy/8AG4s5/Z5rvRtGcU4N/JLf+7MZVEB/wzHcsaweriPoEPDYg1Hmo4yXOLvUz9UOhmNC prlZiWGP82eQfmvC5+SZcmv07OPHUTtsMF/9SbvHRB2ZP/zAPKD9FI2wyx/1pm3f/wC1H/6g /wDaV5nL65sP+43n08VxNo81r/snw2baVNx/IHuJ5AQVksYbgcp+a3f2T0v5laoeFMtB7mfo vqsb/Vycj1Pa+MLsQby0CR5zKj18RpBVIMRNV7ptJHpayZjceGlpBsF4fJ75muGP9Wy3fjOD zc2PdbRYbd5+ZwcPw2Mj991uV9D8T/Fx8k1VftasGszHQfPksBtneMYtoYyzWuqTp/SRr5rU 704xwhjY/CXHjzAC8w2W0Mq5Rp8N5PG5BWfPydMMrPz6PDHdiRi3zhhfg31BWE3rFqX/AHBb FzMuFA/zCOxcf0WQ3t/DT/1H5LyeD/2x3X6ZeiJqMHDMF7di8OHMoENszKLDQAf2C8Z2UAcR Sn8OdpPaV7bsmu41nNJ8M5mj5T0X1Hx8d4vM+RfbQ7u4/Kx1ap+EZmdYBt5I+IosxGNpPaMz RTbnjgcxjNHQrzbbm1arq/waYMFxENE8b2XsW7tIfAY8tio5gDifxHLIgnpCeWGrL+mMu4wO 19mspY6s1ohhDKgHIuaJ9wVmt49pinRfEybdgRAPrC2G+GIBxbgIsxjTzm5v6rAbz0S8ZAJL wB2PBdc+omtd9irg3CvceNR7j1EWIULeOpmr5gZaTVI7B2ivd3dm/cdluqVbOLYAuBpb3lZP EPz06DheWvJjgS7+y8L+Xy9yR2/Dx+6y23G/yn/6gfcrLVamoP7stdt5v8p4Ooj3KxlY/Jcv wr6dfKpQIsis4JtYeIpzD+i97i96cOb6A+yPAAYNziDL3Og9BZeljENpUw4m7uJ42WC3bxwp bPosa3KcmadLqxZtM1cOGPdcE5Z5zaV3Z47efvdRMBgHV6ziOLp9TqvS8PTyta3kAPQLzTd3 GvoVPFBcXwRzbzHqvS3VgG5ifDEz05rL5Nt1Pw14wcXghULZ0aZ79E7E4UOGsQq+htxtVzhT Phb+bmeya/bTXeAEgwSbcgsZhl6GVleZb+VstdzQZJpuHoDqvLmmfmFt95K2bE1L5ru4zYgi FhqdjbhZcPyc98mnfw46wUePADweYk+q3f2TbOLsSHFszYA8YvmHSyxlXCl9Sm0fmdlXtuz6 DsPSoPpgBzbA6ToIPuvQ+PP6ufnuvTTb10vhZDwMjndS9lYup8Fpa4PaIlp1HrwVJvFtCpXd Tp1QKYEkESZPIz2VrutiGAmkSJgdiRK299fbjv8ApbU8VSZixmaGueyA6wDjOk9gqj7RcDmp 06gMOBLe4N49fmhfaCzLSY8Wc02I4dFVbd2l8bDUiHEutPWBF+sqZj9ZtcKw9ekADz5La/ZG wfzjxzEfv0WPxtitl9mlMfDe6NXari7zVroyM+02ufjNbaBTd+/mvKMebhb3fKuXYl4mQA4D posBtM/h7Lw+Tk7cj0OL/CKvaAkA91ABU/FOkQoLV28d9IyiThaJdYL6E+zNopYWdcxuvAsN De9l71uaS3DsA4gepKXLydcdsrHoIfIleYb1Yb+cSP6oPqvS6A8ICwW9f/NPeVw3kuWWOQw/ LT7n0wMOI5/Qfqr9wkEKg3QfNCOR+n9loF7PH/hGOX2aNFTb1Y0U8LU5lpb6q5c6ASvON+No l1JzfOeiz5OTrNKxnt5PtaHNJ6n5rOlq0FU+EeSpnMguHVc/HltvkXDUJMBaI0sjY6KHsilc 20AU/Eu4Ltxmoxt20n2c4Jr8WC5ocBBEiYiV7XiqTXMc1wBaRoQCPReRfZfaoTFv916zXfIh cnNz9JRrdYfbGxqbRLWgX4CFYbp04eOxRdsi3mibvMhw7rm+Jncrurz+mqQcRhWP/E0O7gFG SOXrZfTBgt4fs6bVJfRdkPLgvMcfsypQqGnU1HETcc19FZoC8S31rA4s91z8mtNuO2s09NlF xYgoIcsDEAUuhQc6GjU2HdQ2OWk3TpB2KZPAg+xTlDS4L7MX/DBdiSHETlDAQJvEyuweCr4J 8ZswBA4wQvSZWc2oc0nqVn8rLDDGevZYbtVrt5ar/DpNrK72dsGkWB1Roe438V46ALJYYeNo 4yvQ8KfA3sFr8XLsnOaZrbO4OHrAljfhug/hsD5LzzbG4D6YlpzdIk+oXtyG5gOoXVySVOOV jwTZ0tblIIIkXspudbHfPZFNpztEGJssU5ywvpW9iyla9BbUShycpVfbJqwOqhbereMHp7cF L2U4R2urb/CNXEAVA9jGkWkOc4jnGnuunW8LEz1ltkNj7VDa4m1wPOf7r26g8FoPMBeObU3K rUaguCJkOFpV/gt6KtFgY68ACdV5cuXx8/bfLGZTcXm9B5AfsFeWbQqCTxMmOy15xD8VUuYa TGq2OB3SwzGiaTXO4kgEnzK2xy8l9IxnR4HiKd7KpxIyvHde1bf3Cph2ZnhBmwix9FjcTuLi HO/l0XPA1dp80eK706cebHSLhaktH7lPLk04J9LwvaWkcDZDc5PLHLD1VSyiGohmoh5k0uU9 l6SqTrqUarhoVBw7ocjV6nstO1k3GeUWuzsW+o4M/wB9Y9Vvqe5bMk/EfmIm8QDyIhec7s4s NrscbjNH917i0zdafH5rvVc2fp5JtbDPouIPDn9FSfxYDhdbvfZ7ZNxwnvBsfZecU8BUqktp 03VDf8IJ91fNz2eovj1+T6u3o09FDp7bzOgxf2Q8bsSvT/5lJzJ4OBVLBa+wWN5M/wAurHHG /TUuxIUCtWlAa8whPcq738rmIrqvVCL0HMmOcp7K6juqpwLtZKhOqK4wzMzUryaLKaQ3VncS hmrCtWbJc8w315dVqcF9m7XU8znOc43nRo8ourw5Jl62xy5ccftgzXsk+MVo9pbm1KdgZ17f JUf8OeJlaW6KcuOX0jfGKm4SrfxKG+g4XlRRiS13EiUscjtjTtqcErioVKsCBCPTN12Y3cY0 ZtyiCmk0ulqVLK0hPN0xwTHG6PhwDqkEJ9kzNyTsQYJUCpVg2WeS4fXqIHxghVqyiuesrk0h 7imvIhCLkI1FFyXoUu5ILqiY+oglyWz0c+qgly5xQyU9no8vTXFMJSSkCLpXSmkpkUFOhNCU BCXqLlwcmlcCiMjkspq4qk0iFURAmOQRhK4hOKa5JIFQoD1Jeor0qAXlBKI5CKkwihOCMhwk YRamZUVwTU9HsAhI9qMWpuVFg2jOCGjOCYWrOw9rnYLJqNnqPZbXD7Da8Bz3ENJAMAE5ZvCx uwf+YOC9Nwr/AOX0Dm/NTYnKr3djcmjJqvzPaD4A+AP9RA1UvfGm1rGtYxrbOJLQGmNIt5rQ 7HqzSb0t5QqTe5s8PyEdpOvsnzSTCSOeX28nbSAqGJIkgc/P3VxiqUBp0loKr/h/zi3kXK+2 tQIZRJ4sn/1leH8+eo6uGuoCa2F/+nB7515BtylkxVdvKo/5yvWsET8WieRA9157vPhx99xE i4qv6fmV/wAZeud/6PlZYtT6dBxIsrP4A5J7aWkL3Lmwafd5hbQJn8zSfMH9FYNcQTlOqZsD D56VRp0t9VZYXd2o9+QPaPDmBM+i5OTj8i8c+qpxWdwA5cf1UjZtJwuDLhOmkLfbvbhsLc9c l0mzRYQOJOvoo+9NOkwgUWBuSmQYAGaDFzx7pT4045s7y9vTH1Kjnva1wIuOESJ99EggVDOg P1S0Hl1Rp5FoHaf7pu0mFtRwnRxB9V5nzfuRpxLLAuGfHRoaNYjrrHyQab7MMXys+X9kzYBl 2IB44aqPMMcU6gP5NM8clP0gLks1jWrP7/tBc0/5nDylQdjtHwWXA1PKbqfv3TiqRwDjHaf7 quwlAnCteCfC5wPY6fRd/wAL/wBOmfJ9vT9g7QBLOoaZ5RwQN7ce0VxJEZB9Vldi7XDRDjof RN25jm1agLSTaLAkn9yuK/Dz8ssn0uZY/lqt0d5Mjw0/hLrk/lEazyS7570feiMNQP8ALzD4 jtM5Dvw/6Vi8NhKroAaWtP5jInoOZVhs0AVA0C4N558F6kxzw47u+mGXW5ekpgDXEDRpiOyl YX/9pizGlZjv37oNen/Md1dKkYVn/DY1o11HlH6leF33na6PwftqoC09wUHazwdmlvVrkPaL iWNPMD5KJtSt/wAGW8Yb8phHNj/5cf8As8fp5TizxW/+zY5aFZx4uA8spWBxTbkLa7l1i2gR qM6+lxv9XPnF0cQGucOTnfP+6gbTxhtBvy6IG0HlrzbjKqsZiyTbsBGq4PBbntvjZ1brcfec MqBjz4TZs/Je0CuMmebRK+VsAahqDKDIve0L1vZeOrVKLWPqH4bRLoN3a2d0Xp/Hmc9SOPm1 sm8m2M5qOYSC45W/6QYWfwjIxDR/kI9QiY4+PWbm/SbQnUh/xNPq23ZeR83mvfpv6a8WPrYW IH/Ds7j5lYveq7WT/U75LcYpkUG/6j8ysVvKLNP+Y/JHB/7MW1+lRu5QDsUxpX0HhNn4WhXY wvzP+A0yCD4gSCY5eFeT/ZdsVmIxwzOA+H48vF0DTtdepP2GGPxOIfqxzgx0xbJbwxzMd5X1 PHvHGarzOb3kmbk0GZ8S7JFT4upAs0zGUrRit/PNMaBoeeQJJH0WR+z7FPNOrVqHwuIbPUTr 5K229tptJr6tEtdUa0BwnVs8OZC0yvX7ZKXeTAsfj2tNg4Uw7hrYFV2N3fZh68OcHEtzMBvB mL21sqneHaeIp1qVWp4qr4flA0bwAjon7Y2396qNrRlcGZMtxAmb9ZJUZ/Jkx9CY20zf3egi gKA0cIIn3VHsjEfyabosA5se4VLvEx7qjS4z4fRWuw2ThHn+l3tC+e+Xnubtepw4dYr9t1c7 Kjo/KfUSsLUNvRbnGN/l1Bza75LD1hp2V/Bvqr5FbiR4vIIuDoZ6jGc3gJmJ/F5BTd3mTiqQ /wAw/wB17/Bfpwcj2jGV4YKQ4NDQeyhPxzmCB+qbtjElrmdnHvwVDjtpFzZBvpGi7cstObj4 rl7/AA1e7m1GtqPdVOYRI1kdvOFr6O89MU6jXZi1zfBFzcH2mF5DRxT6gDA05pAkfVbXZ7A1 oaRYDjwKPue2eXqrfB7ZbSp5QDmNyeS5m0RQZUxDjIykRb1VRs/CGs90HKBe+pExZVG+uGqt honJEW0PcJcuXXHZYzd0pm1WvLqrTIcXGNIJ4LM1BDiP3qtVRwOTDscI8TiD7/osti7VHD/M vmvJ35bXs446wiLRrZa1FxNmvE+q9/2jTpmhRdSeHNJmOI6jzlfOeMuOxPmvYvs23hY/Cmm+ k45Yh8ZsvHXhwXufGy9aef8AKn5TdtVy4NnhpzCPs6k4VaLmkCXQCTx6oG0WZnHropzcPBoA nRwJvwF12VxtNvthy7C34RKxlDZFQ4X4jajMoJOW4Ig8F6Fva5owrp0sP36LKVKbfuI4XdKj C7wa4xiMRTc9rWtBLnGBC3GwsG7CYcjQxLh1heaUdoPFUAOgNeACLcYW9xO8kUHNdDiRE8V4 nPydJY65jcqze235qmbiWuJ83H+yx21Py+i1uOPgpu5tI9z+iye2LBp6lePjd57ejjNY6VVY KNYKRUdqoWZepx/THJLw0uewcz9V9CbqOkUmgflDvZfPeznfzW9Cvd/s+qFz3EmwGUeUrl+b dYJ09IZovOt8av8ANI5FeiMK843ug1XdzPkubHKaxTh91p9x3zRd3H1WpJWP3Df4Hjt+/dbB e7w3eEY5faHiqv8AKcehXlG8lYOpk9x5QVo9vbfyUiwG4JGvrZYavVL6DjPP9Fw8+Wq144yM 2CiV2+NGH4QleJf3Kfx/dVmssJTytnmo9d0+6mvdDLqte6V6PJdRjHqv2bU4pacT+/Zbj4hl YvcTENbQbPH5yVqjWk2XgfLya4YoO1DdStg/iHf6Ku2jU8QU7ZBuO60+DfcVyz01Sa4pybUN l7eX05UDa9XLRcQYMLwfauJzVnE3ufWV7JvTiMtEkHh/ZeGYmrLz1J+a4c8m/FEjHXg9lECk Yt3yCjZlGzGZ+q1e5YnEA8o/fsVkGOWx3IqRVJ/0/M/qlaHruKd4VVYloyoeNxlrGyjVa/gK 8r5educi+PH0zr3uFS39S9H2f/ymf6QvPKbZf5z7r0HZk/DE9Y7SvW+Cy5UtNTkMvC7eRixO /VexHReeVHLX77YsOfA1v5jWVii9c9rWQQPRKZUTOiMejGnY1OwzrxGi9L2Q4GhTjlHuvI9l 1C0r07dyt/JE/u5XRM9YsrPadtSk11M5lgdt4YAEha7aGMJdHDTus7tRkjqvA+X8i580n6dX FNYq3dtp+IBzcPZeorzvYNOKg7g+69FXq/CY8v2ZVZISsAAslckaV02yZs2T372ax1IPgBwO trjkV5PX1svTt+9p+DID3/fkvL6z1lzZ9nVwfQDnJGlNJuuBXO6kvCslwC2+6+6DK73Pq3pt I8EkZnRxjgsJhq0O9V6buTtCA6ZynL5dfZb4Wac3N6aKrunhDpRa0jQtsQmY3PSp5WusBY8Y 5K1djG2g6qu2oZb6rl+d8nHHrjPtjjLft5RtfHvfUOYkyfVeobmNZ91blAFzMCJPMryzadP+ Z5/Ven7jj/hvP6BacF7ZQ8/pZbd2c2tRLXNlYrEfZzm/CADzP1AXo7xZc1ductyjPHKz6eO7 V+zqvSYXgtcBwEyB2hYjEUi03C+lsQRkdOkFeC71horPDf6nG2n7ghLPrrX5dfx87l9sy96i 1KhRKp1UdxXNa7YUK72eTBjkqKVe7JuD0WPLdRHJ9NHuvhquIrhjLNGrokARf6eq9cZgXUqM Zs0C9lkPs4eGh4gCSJ62P6L0Ks4ZTPIpfFsu7fw83m93TznbNVxJB7qi/g3xHRe/AGPM2Wm2 nTBeT5JmzmAPHoqy5t3Qxx1B9k7iUi2Xt89T8rJm1vs0oOEsGU8x9VvMP+ERyCKQu3ix/rtF yrw3Gbovp2Hkq84CqzVhA4nh6r3UbOYXEkA94UXbOzWOpHwjSIXRxZfg+7xHMmFysNqYUMeQ Oah02RquhcuwQAnCpC55hBLklI+Idcquq6ypldQKpWebTEx2iiVX3kIj3ILlz1rIEaiE9y4l McpW5zkNKXIZcgyEppckcmlAKSkTZSEpinSuTZSlNFOXSmhPTTXqBTU6E1KMzkiQrmmyqJpq QhKQlKEmQmkJ6G4oSFUcoz0d6juKmmjuQiivQipM1xTITiUjgnoB1AuhSKOGzETp04qXjNnh obl8+a0mNRc1XlTC1ThhCnswRR1pd4qXUjOiaMOTwhXowiUYbmo8ZeQDZlAh0+UL0LCVwGkc 4hY/C0b26LUbJolzhI4j9+qm4JvJt6du6SWk30bHaNVG3oZ+ExqCOxtBVxs4AMaOIY0Eco6K v3jbmDWjXxfJLlx3iiV5ccPFZ865iPIlXO2f+RSP+Uj0P91Er0SKhcQdeStNsYacMy4ka+5C 8P5+GVkkn5dPFlpnDW/BeIIWW3jE4ysebitJiGHKIF5HzVDtzDE4h7jYnxEaxMH6qvhcdxv0 vky2pSErWKT8HoiNw+khepqufbV7rNAZUPNg+q1mxr1mO/yN9ln90sAagqXgBjj3ytJj3Wg3 YYSW9iB7pYz2LXoFKoCyRwH0XnG8wIkaZ2n1k/SF6NhqMNvxELDb1UCXAcpPY/sLTln5TKyO DoxUZ3bPqm7xty1qn+tyn4el429wo+9FI/HeOZLl4nzJ/fF18V9K7Y2KyvdHGlWB/wD9ZS4e uclIZjGVgjoo+y6RNUgf+HV/9hUjBsmnSJ/obPdReOWLuSHvThXPrGLxz/VTN3MHGHqNI0cS QeWUT8kLbYvPOD81c7o0S6nXsTLHkd8jj+i6vj49MNMs8tomzd3KLnODy/iW5SG9uBlepbub r0cNTacgNX8ReQC4E8Gk6WWI3ZguDjrDQOh/cr1XgvX4v8XPlXnG9T2/zIsWPeABaZJ4LE7E bNZvcArT710jL28c1/oqHY1L+awf5h815/P7xyaYfa02rQyvE8QCO37CXZQkYof/ACS7zAUv e5kOB/8Al+hzH9FV7AxWX44P5qdT/wBv+6+cxx3lXb+EF2Na6nTE3yN9eKJjaY+4VHEj8QEe qoqF2jzSV3ONgbcj8yvRy+NeSyz8Mu+mKxLfFpda3c9v8ioOIc0/NV1TBtcCNSDY8T0Wn3Rw uXM2LkF3cR+q9PrZiyyyCrRJL2GZ1IKPgcPLszKcgXkMJg9StdsSgS7MWgtzAGQCvUKVJrRD Who5AAD0C6uHjlm6yyzv08b/AIMWvaHtbSe5hqtMRnHDTqkfjXtLaLQ1uUAOiPHOpK2O81L/ AInO4aU4YTpYEkLB05NQuOrip5+a442YekybvtJ2oyHt5ZRp5oGHP8+l/pj3VhtmjHwzzZPu VBwZ/wCIpDzXy2d3nXoYz+p+Kf8Ay2A8HVD/AOo/qsVvIfCP9Z+RVzjsa7O5p0D3x5uVJtg5 mgefYr0uDC9pSuWogbr7TqUa/wDLMPeCydLHhPkvU9s71FmEp4ICXuAa954jPMg85XlGycOR iKTjwdP0+q3ePwTXOzE3DhA/7p+a9jD5PTKSuLkw7e3qO4uyTSwozi7nOMaiJ5J28u5zMQya cU6gMyLB/RwHzUjdXaIfRbTP4mjyIk8eequMZjW0mlzjb5nku282OXvfph1eLbfbXp1GitJ+ G0MBPLhfU6oex6Ye546SPQz8lO3o2ka9R7nwBYADpoe8FQd2zNSOh+RXkfyPNMcbcHRw4KLb +HJeSOXyVpu4z/gq/MH6Jd4KJDyALT7I+7zg3DYnlJ/9v914eXNc+N360zmKPheOhj0WJrtu VvKw/FPEH5LC4pt/Vep8O/aMwBs7OM1x2Wg3LwWTEiWh0hwBIBixiOXFVuEdIjkrnYFQjEMJ 6j2Xs8XL1rj5Mdxc7exTiWzwdCon1Mh1mfmVusRs+jUJbUsbmxhZh2zywwWgibHWQvUuPbVj m4+XrjcUjZDsrmkg+KL9uELSY7GSQ0CLXOipKeAqtLZpnMbtHPsrbE7NrnxVKTqeUDUET1C0 nphldrjZOFa7D5g9weXECLcR/dB3vqNbTbTmX2B7RElOONrHL8KkXAfiIExbpoqHawOYueSX Hnw6QvG/kvnY4y4S+3V8bhtvahVqR+4sdwFU/VYrazIqujut4CHYGmJ/6pB9FhduiKzh3C8T 4d3lXpZfTP490R3Xo32U7Rc34rJGVwbb5n5LGbPpNc5wcARGhutVuqxravgaAY4W48l9Bw80 wefzY9o9bbsV5ioWZ6cyYubccuqk4vZlN9agGjK0kTAiYvEdYQcNjarMO7I4EETHG5vB4alQ DULvhup52PGlyRPZdt+Q4rjpZ/aFjWtp06YPicbjk0DWFjtq47LhA0Ge19f91cY7dR1cmrVr guFovpHC3dVDdiUy0w50dTZZ+Xc1FY32yezsKXychMXUnE1iZHAc+itsFhslQtB0nTiCFVYu mQ53Un5r5n53LZnY9Xgx9bHr/wDJo/6I85Kyu3B4B/qWoxX/AO1pdP8A8isvtz8De6w4PeUd N+lI9/1UElSnvUTKV7HH9OfJP2U0mqABK9u+zzGAF4Njx58R9AvFtiVHNqtjjI9l6NuptHJW IJAzfP8Acrj+djvCiPb8PXBCwG8haarpP5itLsHF58/RYDeSrFV8HjC8rj5LfX6Vjj7eh7n1 KRp+CA6BPOy0sx814ruvt74FUE3bMeRXpO1t6aLcO5weC5zSA0ayRFxwX0Hw/kY5Yavqxhy8 dlea714lrq7g0yL/ADVZhnTh39z8p+iBtCbv4nXzUnY1LNQeP8x+RXB8nmmefpvjjqMVm17k eUo1Js1ByF1Ce+HkdfqpeGf4pXb8b7Z8idjatlBafolxVW8IDaniHcLq5ctssY9O3fqwxkaW /futlQrWWC2VXGRvKSB6rT4fEyNV4fy3Vxwu1cZDgf35q+3feHZXc4WL2zVM9CJUzc/bQa8M cYuQOvJa/EurD5cdx6moW06sNA5n6KYCs3vTjwwAcdfWy9vKzrtwSbrEb5bZ8LmyZ0915vUd cT5q727j/iVDyuD/AOb+yzuJq3815uWe668cdRZ4p1x2UfMn4h8+gQgVSaICtZum+CT1+iyG Zajdd9j3P1SyJr6uLMxwR61XwW5Kpc+6WtiSGFeT8if3dGE9H4HEy+/OP7r0jZTppheM0Mfl qzPHyher7uY4PZbuvV+FlJdOfmx9bXiocfjsod5q7rPhpPIFefbxbRyh08QZvou/mrDGbZDb eOzVSOF/LqqcvQH4sue485Pum/EXFcnRMdQfOiMcowentcqlKxc4KrB7r1DYr4otC8iwtWHt J0kT2XpeBxY+GL6AR6Kss9RnlimYl3iVdjHJDir6qLjcSvnuW759uvGaxWmx2+IT+4W0Cwux K8kdiFuWmy9/4NcnLPbn6KE/Ew0lTH6HsVn9p1Ypukwt+ae9s48+3yxRL7acRyM6eyyT3Kz3 gxU1Bzv5qmc5c+VdvHNQhcuDkwldmUbbJdG7gt3sR4YBB4TC8+pOuFttmVQKbbyb+QWsy1jW HLNtvg3kgKdi2Sy6h7Pp+Fh7K2qUpaV89y53m5bZ/wDVP08j2q3+Y7v9V6LuO4HDno76Bee7 fbFRw6rd7gP/AJD+jh8l7vxL7iOT6a0poKeoteqGhd3NdarCM7vXtosaWtMW9bHVeJbQxpc5 xPP5rc74Y2XuBPT6rznEPkz/AGXPctu7481AahURzkapdAIUuyEzK/2A6WlZ3NqrvYT7gdT7 rHm+k5/T1Dcavln98TdbfE4uRCx+6WCysniYPa9x6rTVAuWZzHC159m8lPimyT5qLhzDgrPE ssqmm7xW5rPgy7VWX09CwZ8DewR1G2ef5Teykr6Di/wjloY1UDbWKDacc1OqOgrKbyY2xE6C e+v6JY3WRPOds1pqH93VU96k4ypL3dyoVSpK7ZfTeEL06iJQCnMKFExbBwVVWKn133VZXcs8 14otUpjXLqjkFz4XPW8MrKM5FqOlR6hUrhZQyUsppKA4pjilLk1AcCkKWEhTKkK5NSymiiNU ylQsLKHT1HdaTD4M5R4eCaa1udMzJC5NckzPLkrXJkrmqoVPS5U0hKU2ZnFMqJxKDUckDHlR XFGc9RnlTQHUchp7impGaWp+Ho5nAdUnFWOzWeMditcMdozy1EkYSNOC44Zx1VmxiPToBdcx cWWdU7cIn/ChXBww4Jv3VHUu9VPweiX4KuadDopNHAT+5U2SCZbQNn7NDrk5RbuStPgMAGaO 9YlNw2zhGn91IdgoXNnfa13hMc4uDGf813HpzJ5IW8FL4bqcvcXuBm/ERp0Q9jV20MziAXG0 ngOiq9ubVNeoHRAaIb6mST+9FOtnsjXG6gY7EgjLrHog1KruBXfFGTKWjvdLLh3+DmekZxJA 6EKv2xhs1YuixaFb03AaqNjYc6RpACnHg1dneRUN2WcpdYRFkynhi4idFZuokhcygRwWt409 2h2LUFIOAEktcI5S2JPqrvdOGubz8QWa2a6HXn8LvlZXu7mJioJ5lZdNVUrfLEb01G/FPaD3 vK20rz/eSnFZ885HY/sozx7TR2qbCjxNPJzR7om89Bpqm17Ge4H6IFB/iHkp+3qXjY7+poXn c/xZc5a2wz1FBs3DhlWf8lT3Yfqh7Mw5OVg5gXtYXVphsMPitm4ggDST1UVjMpNtHFXOCKvI h7UwpLyHAW04ytHuRTgPHNjx2sf7KrxVKYPRWew6haCGmDc+0K7w3r6Rcwd2aZ+LHIuPpK9T w58Dey852HDXHmSV6NQcC1scgurjmppnvbzve/CljnOv4qkTwAgEfVZrZV67Ryc32P8Adbfe 2uzOZuQAC06ExHqsxs6oxjpc2ZII6QfkuTm47qrxqy32o2bAN269Q4z7FZfD0g2r3pP48cpH 1C1m82PNSmwWuCbcOiybsMC4AifCfYLx+P4efa38OvyTTOYVhcS0TaZi6sWbFP3epVkyCAO1 5n0VjhGBrbCCTf8ARWdGnNCoznfzv+q7c8csdSM7dsNRZF1p906RdVNuEdhB/VVdSgBK0u6V L+YBESD3jmu24/1Y2rfd5/4m8Mxn9+S9LC892LhJruA0DiPIL0JdHDPSKw29pJrEf5BCxtBs vHT9F6NvHhCXtc1s+Ag+/wCq89ccr4Ii4P8AuuP5E1tWN9pm3Lhnb2VRTtWpRqp20K8hk9Qo YI+Ph+WYExyBXzmeN7XT0Mb6ZzaNaKtQf53fPRRfhg6q72rs4F9d7Zn47gJj8J1kc5VVVwha JId5i0c17fBL0npzZ5ewfgNbBFoj1lbHF4PK2m+Z+JeDwj9lYjPca6jWRxXpm08P/Jw7SL+G Ox6+ZRyy9sU7aLcjxA9L+5HzV/tnAl9N2XkTB5/sKk3PpFjnA9rXvMrUbQfFJ5H9JXZjhLx3 9sr9vF9v0i0meMeU/wCyNuZQBqt/7h34R7o+2GZs06gn1FkPdfE/DrN0ib+a8r50t4cpG/Ff bt56HjqDk79VUYDEhmFrzxcG+Z/2VtvXjQar4EyZ/ss9RaXYWqR/4tP0vK8r42FuEmTrt9K7 E4gk/vks07Dgkz1Wlr0NeapqrLmy97486sM8kbC0QNVZbIb/ADmdx80OlRkKZs+kfiMtxt3k H6Lqzy1GTe4h9KwqDiIIiQrXCbkU674FR0CCYiWjoVD2hhWZWPi5i3AiZ0W+3YqUy12UeI3P 6fJdPxPmZ3CYubk4pvaJtLdqhSpZ2hxcwANlxOlrysXtjeGpUbFobqef7heobXdFFy8Z2xUj MBzutObnzn1RjxxdbqbRc1r+oPn3CzG8NaS46Ez5EyrfdQkhw6E/NUO8FgZ5/Ur5Tn3l8jde jxTUJSd/wDP/AKxHsf0WQ2syak8/3K0YxMYIMGvxZ+aocTJ1XofGw1laWdV+FYQ6eHFaXdl8 V45j9VSUWeJXWwh/xDO8eoXfyX+tYN7hahY7JmIa4x2W2w+7NJzGuZVeHRNy0j0hYnGUiHNg cVvd3ZNPS+UG/wAlPB8nKTTDkwik2pRfTaWFwI4EWMjmFgcZiHyAHWOvBeibbpmSHWOqwGNb qeRW2Xyb+GePHCbKPj8lHx7IefMqVskTU8kDb1OHnz+a8D5l3yvS4fUAxI/4Zn+orMbbd/LA 4ytg1v8AwQd1cPNY7adw3lN/Va/GntdrO1RCu24NkN8N4CrsVhhmtobgclah/hb0AC9njc2V 2Ls7CsFZmUc/krLGsdSqNdw1BE+YlQtn1IqtPVbTFUgWDMAQf1jVYc3+Un7Ey0uN095GtDiS LgA/RZ3b+MmqTIgzp8vdX27e4eGxBJdVqtH9DHMaPUtJWhxv2XYIMc5ucFoJhzy5pjWQb+6y x/jsbe0yV5pPw8kGOAEAeasthuNR8HQaJdq4KnTMU2wIFv33Xbtj+ap5eKcWF0JydlntylZV +yahFKpHP/7SrzbtOR5FU+xh/Lq85+i8rDK5N79MDiHeM/6rrmV4KXaTf5j/APU75lRGOXuc XphmmGsmtfLm91HBRKYOZvQg+62yrNv9nv8AAO0q4w+OgKuwLIpttwAUp+BLvwn1XFycfdtx 5yfYG1toA/vgqGjtFzHhzdQZGqtcTsCq43eMvS6LgdhtaZJzXmfolhxWNby4xudk77uFEZxc W/cLP7c2y6sXGeCg1raJ5oy1VzctwxYTVu4yeMHiPe6p8a6HAK8x7fGf3ZZ/ab4d7LLiy2tY vqzfoEzOq1mLtdE+9rsjOpoetXu2+yxIxYWo3WxA49UsiaarUg6pKtfwFRsYCVCqvOUgyLci uHl4rldxvx5TSqx9aCY4XW0+z/ehrXhjzqD6fVefVGOe/KwEumOXqStFsvYBpQ5/4tbEEArb iwuPs+S461Xsu0trsbTMGSQvIN59p5g4DiTHrxVhi9oGMoP91kNqEknuVryfIv0www0i0XIw cojHck9tVRhdtKk5k5tVRMycHraVKxoVPEPIrY4fG+AQsHSq3Wnw1bwhTnfRaX2GryZXbRdb ylVtCrJTNpYq0Lxrjvk26J9LjdjHeLLaZHovT6J8I7BfPmB2p8OqHTxHmAeK9z2Fj21aLXA8 F7Xw85jlpy8+P5T8Q6GO7LAbw7ShpHPnwW52jUimea8d3r2oDMnn68F281jLDHbObQqgvnzU MlBFeUpcuOuzGaEJTS5MzJAVKkim64Wi2XiB4RPEfNZdj1ZbNqfzG8pCWd1hU5R7fs78AVkX 2PZU+yan8tvb6qyqnwlfN/G5bMsp+0Zz28s3nfNY91tvs+d/JeOrfksHvSYqnuth9m1cFlQc fCfT/dfR/Cy9xPLj/VvAsPtLbkFwJ599VuAV4tvXiMtR8HiY9TYr1eXHtj/058JuqTeDH5nk nS57lZeq6UTE15JPFRnPXE9DjmoHUKEXJ1VyChtKQq32C7xRzJ+VlTkKx2K7+Z5LLlm8Syvp 7jsCqBTHM39/7q6+JKx2za8Mb0sr+jXleXzXWOnJJ7Exh1VC2p4lcY93hJ6LNit4442T+KMo 9P2S6aTVNVZsI/yvMqzX0nD/AIRx37Q8S+56LAb0Yu8TwJPbktRtfHFpd6LyzePaUk34/sJa /seM2p69XxOi90ALgREobqq659N9HvqJBVhAzJC5MyYp0mVX1gpxdZV2JddRkvFFeVGqIrnI DyuetoYSmPcucUNzlKzXFNlcm5kApXJMybKZOXLoSEplTikCQOT8oTSlYSmCQOZW4wtHKxoi YCy2waUunU/IFb1lGwsnIjJHhIQiALsiGdprWp4an5bJE0WmkpjnJzyhPQQbihuKdmQXFTQa 9yi1ESo5RiVFNzkgTVwciA8aq52YNeypgOKsNk4kF5HRdHHXPyNFTCNSddRqT7IzHLqlcliY Uwrg9JKZJNK6sMKFX0XKxw3ArLOqxXOFiEWsbIGHKdWNlxZX21kQMQeCr6rYU6qbqFX1W2Ca ipqe4IcrZJC1PZSCblR6SCPbQUyhgpKZSVlgws86cP8A4cI/VD+BlIhWQ0UTEO1XPv20WGN3 mytDaYvAGY34cAsnj8Q+o7M5xJ/dlKrKI9bY4laitsZ4olbGOeRm4CycQkyKrxypmVNp4gg5 hqEzNJJPEk+qKWhEpUgl44fao7wSFM2XSLDmdeRAjgpNFg8lZUsO2AVnlNHvao2eSx8kWkr0 LZb5osPT6lZWrREaIOJ2lUDMgcQ3SBayWKgd6XNdWdlINxpwtzWbpA5mjqPmrB1L/dAFGD8l p49wu2lzvBggKdItPPNoYPCPdUtOgA5p6Eeq6pmJuUxrSssfjaV5SUcEXTlHE9Fc0NmljHku aRGnGY0KrA8jQwnmq8gtvB1Ty+PsvIpKtDLIdEyfSVb7DqAvgGDlyph2fNz+ql7P2bkOYG+t 1Nw1NH22tNh1stVwB4kec6r0FhkA9AvNqFMsqZwBxJ7rebOxgfRa8wLQeAEW1Tx9HtXbxY0s gcCNeWq88xGHLvHmE5ova3CFrt6NqUnlrWuktzXGk2tPqsc95/DzM9uyMuKZfZdtDY+iBSpk zre3uPZRcPl+JTcWnwn/AMw5K9xOJpuw7Gz4gRM8uhUHaWLYcgpiA0XtbNxhcvF8Wbu4u83p CxtUZnuiMzy+O5m6azaDhTcAzM3S4nKh1XAm6cKhAjhyXXOGYz0z8lV+O2dnpscYBFoAvC2L PhVhTYXEOawQeZjRZirVJgR0Cvm4P4YaSb2JWefHKru1+7eBc0mTIt6/v5K+xdEvY5oME2nX iqHdjETmB46Dn+7rRkwrxxkmht5dtXY9UOeIsJvfvKzuFoRUF+MdFstr7Qe97gDqS2dJ7qkG y3Mc1zspbmExJi/KFx83xu2N0vDPVUu38M74mlrdTpogYRzvuOJb8OWlzfFeW2/WFpN4mNfW caREQIi1wqllVzKFWkR/zIk8oC4uP4OXWenReaaZ/D7PqZAIzOJgAa6f2UHamz6lNjM7C0nN MgiOhV+zMIixEEJ20sY4iHXBtfRejh8eRleTbO4KkC2/orLZ1D+azuPnoh4emLgCOynUacFp GuYfNGeHoTNq9oOH8qNADI87LX7qRw/pusnhmsL2Z/wlejbN2fSpjNTGojWbKfi46Tldg7xM Jw7o/wB7LxrbM6EQZv3XuG0aAfSe0mBEzyi/0Xkm8mGh9nZl0cmO0y6Luc0zUj+k+8W9lRbf pSCf830K1u5DSPiCD+E+t4+aodsYfWR+Zw7XK+b5uLK/Iru48vTMfCihMW+JrzVbXatcaB+4 vAvDxbt+ys45hhd/xsb7TnUKgySrXZTCKrHRoVHw9HxK72dhpqMA1zDoNQPquzPH+tY7a/FX II5gr0HYTP5TSeUe5/sqXbWzMuHY6QcuUEjjPEK+2G6aDOghY/Gw9yVOVQN48GCM3Ox9F5lt DDi8G0kf2Xrm22TRd++BXlmPpGHDzWvLhqon2hbAp/zhyv8Ar9E7eiiG1HEaGR26I+7WE/nt FypO+WELHxzAPrK8T5M3yuzjvpmPvcYIt4tf8wstVJLVpcv8ip/qHuD+ioqtPwldfxsNFnkq n0r+ylsZKX4StKWBkcBbrK9PBjah4Vvjb3HzW/riaLe31WQw2E8QHUXW0pshscNFjzY3tBtb 7mMJdYwdR5n+xWr3hrPay5lpBkC1+vRZrdR4a/rp04/2Wo25TNSmWji03WuGO2drx/bTg50t /wA0eZQ92m/zb8wibRoZXlp1B9BKJsmnFQHrPdY/Ix/rWvHVzvCIZPQ+qod3TLao/wBJ84Mq 924+afqPb+yyWyMQ5r3hps4H1Xi8M+3VfpQ7Tw4L3f6iZ7lV7aQ4hWuLBLnTrN1F+Evb4/pz 5VGIHJK1sXhS/hJzaM91rUbbvYVMvpidTHzK0+zN3hUeAXOAJvB4dLKg3YJFIAgiBx5yT9V6 Du8299LfVZcc9oyqbS3PwoEFjnHm5759AQPZZzbuyadJxDBHLzC34WH24+SZ1k/VdmX0hia7 IMKS0eHyTMULotM+HyXk/Lnp08bJbT/GfIfNZzabbrR7W/GeapsThnOIi/QKfjxpldKl7UfA 4Rr6rGPdka4xmtY9VJdgjxt3CD92M6r0IytLtDZnwahpl2aNDEWPNXm7rZtxJ9gqZ1Ak5iSS tDunT/mX529P7qOW+hK0zHQb/JWuFxjAIyg/9s/RTMFhQXCVv9m02tpgNA6wAL9U+KY5eqyt eZV8gM5YOtxl+iq8djToBC9S3iwzHMBcBmvBtMQvKNqWPT+61zwmM9DG7qExxJVbtSnx4K5w NKZ6Kt2y2F43Jf76dcZt7olQziD/AHU6sPCVVE+Irq4YLR24opwxztVHATg1dHVG0yljzI7w tdhHnICsRSZf0WrwNU5e6jODawGKAKHi8ZKhVSotWYtquW8HvbbHKI+KrXtotjuLvn8HwPdb QE8hNoWIdhHOufa6sMJhAPRadLCyuNeqbW3xDmQDwP8AuvLdsYkuJnnP6K4w7PD7Ko2rSiUe a/VTjjIp2konxIUXEPgKJ8VbY3atrN1SeKTOVVmqU4Yg6K9Da1bUKsMFW8TXdQs4MQeausO7 w26LPOetDb2zYuMaaY6wrxz/AAGF5Vu/tmBBJ1C3tDabTSBn9V81eLLj5r+js2wO97/5vqVb fZptICuWf1Aj0E//AGqi3urgvJCoNm7SdRqCo0wQfbkvW4uS4WZRWWO8dPpOpUDQSSvB98qw NR8f1H5K6qb9uqCxPOPosftd5cJPGT2kyvWx+b2mrNOfj4+tZwvTSmTc9ykc5Tjduo16GSue 9CLlapTy5TNluioq34ilbNqQ9RnPRZV6tgcVIb2BPQq+w+J0WLwOKgDqrWhtCCvN5sNxhGjx lbw/RZLEY3LU8581Pxm07H9VlsdiASevz5qeGdVae2boYzPR6jXuZ/stCF4xuRvaKLsjzYwL /voFvcVvhTynKYK9jg+TJOtcvJxXan3vxUZr8T5mSvH9p4wueb8fdazeTbYeTC86xWJJqE8J XR3lrXi4tTdXNHEiOqFUrKtpYuE81+ZW8zO4p7XSlLwq348aFN+N1T7DqnVKqhVXzqkdUJCj Oqwi5KkNe5Ae9LUegPcsa0ji5Nd0SEphcpUc4oZS5khQCFKEyV0pkdKaSnAJpTJwKI1CRqLJ Kaa1m7eHkzHD9IW3bRss3u7Q+nnC2NGlDQqjLJRhqVoT00oZ7KU2UjihlBEeUGo5Oe5Ae5Kg 1zkCq+E9z+ag1sXdRaBVFqVg3VBfUdqFVYjEmbqaaxrY0GwCCcVCp31j1lD+IeJQF03axm0K wwe0xMlonoI81k2m6mYavHZXjlpjlNvQMPi5b4Wku9vJSKeKA/FIPZYdu3HgWdbzHyRGbacT dx/fVazlZXB6Bh8WDPi9VIo1c8kEWnjGiwlHarOZ7KUNrMjU+yryp8bcUaw8lPwuKE2K88p7 UHOB0j6K1w228sADhEkH5KMuTZzjeiUMUEV+IEarE4fbeY+2kKcNocJXPa1mC5fV1URz1WVM eW3ny5pXbVYdZHa60w5NIywSn1E0PVd/FKXMp7sdTiQ5bzkjPrVjmT2vCqxtBnM+yLTx7P6o 7p94Vxq8ovVhhqioMPig64cPWPmrHD4ocx7LLPOU8cV4aii4l/BAONHBDdiQeqylX1MqlRHu TqtdRn1F0Y5RFh2ZKHIBelD1ptCQCj0QogcjU3JWjSxoBWVN1lT0XqxY+y5860kErvVZiSpl SooFeolgdAe5BLk970ErqjOlzLgUgXBMhApNI9FGY5SaSVCdRaDwVlSpiFW0Hqex9lz5rxdW YFX13EjKCQFNrPsq6o6FOKqgvpKO6mFKeUArqxnpnQPgJpoqSCiNATSgiipFPCgogCkU0qHU dn8gFN/h5MSZHdPwg1VrTiFyZ1rirGE0yC2xBlSNq7yve3I0Zf6jxPQdEmMCp8SITwuzQa1d x8kL7w7mjOKE4BdExiLQi4aoJfKM4rgxPrC2hVaaj16BcAFa02BGZRCVxHZS4XZszw7o9LDk OE8D7q6p4YKTRwQJ6LLPSpkhvr/hPEfNegbr40vpZTwuOxWW/hYhFwFR1B4c3TiOY5LLHU+m m24x7v5VT/S75LyLa5uR1PzWx2jvW9wLWMA5nWeyyeKlxkhdEm4m0fdTEOY94BI8M+f7CibW cS588XHTmlw9Q0zI10TalfNqFy5fE3n3Xjy6CwjP+Hqs/wA0/vyKzxwy0tJ8NIjVQ34T98le HxuuxeXakZQhytMDQJqN7+yIzAXUynhyCCBoVplxzWk+RrMftEupU2E6AT5K22PthlNmV2ms /wBllPjOEHU9lYYKi2vUaHHIDroPILDH4+GP0dzq2xm2/ilzWuDRFhbxd1l8SyqWFzqTsskZ g0x6q82/sSnRyvpk3JBBIPCxCqG7w1GUnUhdpnW8BbTix/PtPZB2Zi20qrXjsTPBSN68eKwt eB+v6qqoCXCeaLtKmBcLi5PhY3Ps1x5WbNA5Hdx8rT7qtfRK0radjHGPNQnYX0WuHx5BeVR/ djIVhSp2Uw4ZPZQldE4tIuYVOnMdwtS2DR0vMSqfC4YTBV1TbaOCy5OLfsd11ulgc1STwuRz j9hbrFUA5pBHA/JZDdWoGvAPGy2OIqBrHE6AE+yrDHQ28a3hwobUdHUehUHZzvGAVc7cqB1S Y1n1Vbhoa8HssefiuUul4Z6WG3qMUhGpHzCzGyKDS8tdbwzPULX47aAyAQqHCn+Y49CPVebj 8LKRv5fTMYvD5ajhM3Q6dC6tsRs5xcZ9klPZw6r0ePhsjLLkitOET6eEvKtDs08ClOAeB8oV 5cSe7UbvDNTk8J9rL0PYOGGVef7sDwev1Xo2wP8AlrDin99C3a2WO3jw13R39VsVnN6KHhzd APn+gXZnPSXnNcXujN0SYsDMuoi0LyflTbfjrKbYHjd2VVTrxfirrbVHxnkqUsU8EsjTKuxG KLjp8roEo5orvgrukY7BGq0W7A/mAdfoVUUsGCdYWh3ewwFQR+7Qs+Sf1OVusG6CPRbbZ7fA sKxhDh5Lc7KnJfyS4ZtGSt286RPIELy/a7fH5H5kr1PeGl4T1B/fuvLdqSXeULp5JqFj9mbM pk6KHt+kR++KuNg0zm/dgoe9lMgnvI9l4PL/AO12S+mKeJBUR+HUxxuuIXocP0nKoPwCiMwy lZoTc66GOwjh4Wn2LSzMVA18lazYA8J8vqs8/o9rrY+wKNV4FWbkaWstq37OsABHwjPPO+fn HsszsZsPB6wvRWYjwTrZacWdn4RlXmu3t0qNGfhtA5E3NuaybqEFei7wvJDvP5rz3EE5itOb +0Vx5e0zDM8Kpdta+yvtmskGVU7wMv8AvqvHv+ddMY/ECyiNCtXU0M4eF3cScqrgxL8NT3UQ UE0it0dgckK9wFGWqnNM/wC6v9ituR6eiz5PodiOzMMhWdDbz4ygOMWs0mOhgKXRYM4zBewb AFJtBpYGNtcgCSeZPFZ4fHw5b/dN5ri8JxdZzj4munqCPmoBoXvK9k3wwVN7JgZtJFrnj7Ly 2s3xeZC2y+Nhxz+qsOa5HYTD+IfuUTatDwW/dkejqEfadLwE9D8lwcnrKN9sG8KFUeVYV6d1 BdSXZxFckYm6RyP8NL8JdGk90aVJwjfF6LhTRKWo5pZT0O7ZYSp4f3oi57oezqcjyj0VgzZD nXntrdcmOHb0Vz0gV6jo81W1aZJ/ei2uH3BxL2Z3EU28Abk+UWVTjt3X0jDvULSfF/JTniko YYgzxHFTamJcBr7I7MJCj4tsAqenVpjeymx9eZhUFc3Vzihqqev+JbcddH1iFJXZkZqcQuuO fsimoU01CpXw0w0lQ7wA4i0IfxFKNEIZoJDtEd1SyEXKScOmnDJH3iNmTSVIOG4obqJQczCl OlNcEiSuxSEiUOSOTG3SkKQrgUy2dlUrBslwUVqtNk0/Fbp/cJpr0HYmHgD39StQzQKl2PQ8 M9T81omsstMYyrLuKaU0uSOcpZuJQ3FcXoL3pUEcUF5SlyjEklZ5ZaCPiX8FFqEt1HZTnU79 VAxNJxJBk8QRNlG9jaHiMQSCRwgRfrdVrjN/7K1bSB6FObsV5EktjheDHop2XZTtbzQixWVb Aua4iCQOV/cJjcLJuCBzRstoBppMqssThmAgMJ6kmZKbTw2Z0Ex3T2SAWLgYVjVweUdPko4w 97J7ATX8UoqSiCn0XNZfROUHMfFx8k8Yyo4yEx9OTZSmQ0Jg+jtB9wTHW8+ylt288DU9Yj9F XtZnN7I7aIpuAu7ppPRKwJ3+Inf73PyTm7ccePsFWYqs0aU4d8lClTo2lo4kESSAfmldjW87 rMuPNcHlGxqNI3HBF+O06Ousy2seRT3YuNE91Omqp4lwFj/ZHp7ZI1cT0WP++O4kx0K4Yoib lTRp6CNrCLuA6KXhtsht81+HFeaffXFKNouFpjskenpVfeJxmSCTxUXEbxZg1sAASeOpWDbt Axx/fFc3HHiVUtibjK3lLbnAifVEdt9ugCw1LaJPD0lE++q/JUdG4o7aBN/mpbNstkAEgcZh YD+It0uFIp46n/X7JeSl0eiUtrMB1+nzVhR2kHae5XlzdpAfmt0UmltwAdPT6KLltUxek1tq NBI4gcjCjuxYI1WE/js8h5/2S/xSfzJ456FxbM1hzCT4oWJO04NiE5u2XgzPoYW05kXBsjVS ioFjhvE7iPdJ/ijUGfmrnKi4tuxSGvWJo72X8Qt2hWVHeNrmg3B8vki8o6tfSqqcyusZR3iH T0VpR2y0i5ErHLOVpIuatVQqtRAGPB4j1ChVNps4n2TxzgsSnPTHOUdlcP8Aw37JCSF045xl cRw9Ea5Qw/mnteq7xOkoBSKZUJj0WlUupyyhyLrDK0ZUEKioVeKntr2XJyVpIdjbKmxBU+vW lVlerdVx0VFeU0UpEynEgoBK68WdIQkCUFMKohIRW6BABRGuU0J9B6sMKQq2k1T8MFz5rkWm dQsQ9FJUWvzWeK0F77qNUqdER7lHqrqwZ5BkpE4JpC0SdZOptlBRmFAS6NIKfRoAqBQcrLDO WOdVIlswQhBqYWNLKcw2UbEPhYTL2pV4oEm5J5SdOyrX0CrGvV4qI6tK6cE1CNIpHAkI9QoY K01E7R/hlN+7qSUoKNEiChyRWYY8lKa5SaAuimgsokKYym7krKlTB4KZ93byWOVVELZOIyvG cRf0W62jiWGg85hdtr6rGVaIUOqDpJjuVMVtWY7UqFTbcKyrUVFdSWvXaeyRiKHgmeSiU6bQ bIkGE34RROOQrmbUEoXwAj/BKT4JVdU7CqMEWS4e9iifdyiswp4KcoqVLwbQ0WWs2DtYt8J/ CspTouHBTsFULTcWt81zZY+9tJXpTXA3CyO8W22k5AJi3cq9wm1aRYPEBFoOqw28WU1DBtJP un9nao8TVkplOoh1NVzQpy4JRORB2i2TpZVVTDch6q9rBRX0U8eCRXlVRw/Rd93Vp8BNNBX4 090JtPkrrd9gFWXcv1UVmGCtMGACFnycPaaOZtTTZLmxpxW6wjIY0dF5vhsSWnVb/ZGMFSmD xFiseLDpfat7F2nQD6Th0leT7Yw8P9l6htvHfDpmNTPovMNqYnM4zxM2W+U7J3qpW7NHxO9f ZA3sZ4Tx1Q9lV4J5aoe2cRm9l4+Xw7ebbox5PTC1KV00U1bVaEkoBoFejhwdYnLPaCKKL93C kignCir8aOyKyhBFv3zWo2LS8JVRTpLS7CpQ0zznyWXLhqDstdm2cO69DwtI5Bb9lYTBjxDl I+a9HZoOwT4sdlWG3hoxPX2lefY1viPf2XrW82HBbPQ/p9V5jtHCnMb9VtyY+hhdU/YrZBVd vBRIA6z6hW+xG3P74IO8TAROsFeHlL5a65kwh1SF6JUomTyTfgL0OPCoyobSlLUenRRvhreY s+w2DoNjxD2Vtsym2bC2qqWOKt9jNlyjlx1iJVvVw4sYutBsnGPa2AYHL9FWt1ErSYDBBzZj gFlxIzZ/buMJBmZ9lhaj/HbqtzvFgy2eUT/b3WCrGHHkuvKbxPjulhhaniHdW+OIy+vpCoMM 7TurTFOJYeS8nnmso6pWLxI8R7qI9qm4z8R7lAyrq4iqKQkyKUKK4011JRA1Go07p/wlIo0o iynL6PbV7Cp+Hr/crX7MYJaY4rL7BHhJ7LUYB1x3XNh9ozb44oFn+YiFit4HajjP0KvWAlqo Nsmxnqu/D3HJ+WTzXKr8appN1CxrvquTk+3o8LO4kcOBVNXb4leV9YVM9t08HTlf6uYxE+Gn MCIAuvG+nDlfYORNyoy6FRbALUwhGLE0sgpAFwTSUZzU0tQrYDkMo8JjmpDYWVBqUFJIXNHR OHMtKxzYK5TMXR4qCqay7LC6EkrgUGcwK/2BRl0x0+d1QtK127VHQ/u8JlW/2VTt5q8YyyrN ntgK4botMWVYZxQ3uXEoTistoLnQS5K53BMc0xKVoDqvUrB0Ig81COoCv8EwBo7D6/2XPmav xeHgjre3fRWezMAXNmDY8tRCPh8B8R3hi3Hl0WrwGBDWNvzkeWqUvpnkxeLwGcAhoY0HgA0u PdR/8PEtD2FsAmWk311B0hbnF7PplsNbJkRJsJmTA8rpWYNlNsG5iAOA6xxS2l503BgH8IEa 5hYlAbs4uc4AAmZJAMRyK9CqbJpEg1Jc4xERAHWytNnbFosl0Ak88pt6KsYW3k+I2ZTLpY2G gDM6BapylIN38pGYsc53iBuYB4m1l6y/Y7TewaCXQGi/bmVWY/Y7JzkR4bBtyTyhOzRbeYVt jCSMxfyyi5ProkGwnAw4cMwIiAOttVvamxwGjK2CY8R8JE8ELGbNPgYDa9xq46ERx0UbVtg8 Rs9waG/DLc1wYiW/1AnVDZhWjKJMDpE+a9MbRIDpaDkAZBg5SeiJ/DKTmgOojMRMxHstJC28 u+6tEuGnHigu2ZUDQ4ghpu3qOq9HxGwczgGCna8aQmbT2E802nJJBAt9AqG3nuHwZFwJ90x1 N2YnKZveFtMTsENY5zszHCIbI8V9YSUtj0yxoeIfckiZPfkEhthDRk8/XXuhOoG9tFt8ZsGG gUvECdNfMqvqbvPbcATN7x6yke2Za08kppjkr6rs14EmnbmIPoUE4TwjwkdeaR7UwZPD1BCa aIVvUpWIuO178ro1bYhaGZi2XND4vYdTzRsKb7qImfJAOF5LRVcMSA0BodwOgjuoFTCPaYdE 8wRBRuBX1sC5kTxE2ugNwxOgVvWpu8Mxpzld8A2ym54ckbCqbTcPypzMGT+KwVgC5kyB3v7L m5naAngmNoNWtlENB5KIXFaJmGDR4rTPHXyUd1BuYQIF5QNqQFE+MQrV2CpONwR20QKmyQD4 XA3gJBBNcp33k8TZT6mwXAEFwnoZQ2bFe4wwSf3qjRoPxv8AdL95I4lH/hxk5wQRIta47qP9 ydE+aNDYtbE3F549kVu0iBwsq91E8uE9wFBrVibRZVMNjcWVXa09uaTD7Vyzxn2VS91oARKF Im6vUkR9tVh8ayPENbzY+Se7HsAsTPCyzwJ8l0lZU+rR/wAcLtBEeSkU9tkG4b3kLLMKa917 qequrbN23ms4gdR/ulG1GcXesrEOMJfilHUabNu1onK70KVu2KnByxgrFFZjCNCn7hXFsG7Y fz9YKlt228D8RN9P0WKZtNwPVSKe1yTcI7ZJuDZu28T+4+SLT3hIsbrJs2yNI87Qnv2qzj7S l3yLo31DeGdDHpEqyp7dmOPPgvKP4mPyu8gi094C3QOnqptp9XqtXbDI1v8AJQKu1m9PULBs 3hB19/7JTtRrryPkqxysK4tyNoscYBungHgR6rEMxJJsSErsa8fnPqt8eWs7i2snik+MFjP4 rV/qTxtyoOXt+ivyl1bH4qI111h27ZfMz6QFY0d5DF2/vuUrynMW3o1YsVOw1UA305rCs3mn VoH77QpdHb17HLPos8uWKmLdOqhRKmJAWfbts/1AjmVx2u3mFOOc2rSwqVEE1JUP+JM/qCE/ aDJuV048kZZYppeEgKDnESCD5pBUstJnEaH1R2NUA1Cj0nz/AGk+ydzGk+mrHDFUrK0GDZTK NdYZ5bXIvWPUfEFCZibaoNWtPFYz7VpGqhRXI1Woozqq6sKzpHlCSl6bmW20lSwm5k5rkEIx SqZUUKRSSyNYUHKc10qvoFTWrnyq4HWcoLnqXWKg1GyjEUN70CoURzUF4XREV2dJnTHJkqkj B6JTco4KZ95aDdAWtMhTaLAqmm7krKiVlnVYrBjRwSVaIhNa5JUqWWO/bRGe4jQqDVpzMm6l 1XqM961wickR+E6oP3dSalVDJW2kI5w6acMpSbKYR/uSRuD6qfScjSjQ2rxgkenhCNFOpqbQ AWWaor20T1Wl2FtQM8J0KhwECqAsLjte1tvDtVjmZfPrposBXN1eVxKhPw4W2HGm5IOFMFLt Ag3CkHDIZwxKfhm9jup3U0gpq2OBTDglXjLuqvgpRh1afcE8bNPEI8Y7K2lQV3gHQEJmzzwE KTSwrhos8sFTJMw9WHfvVek4F802E8WrzKjhXgzHVeg7Nx7PhNvBAuOKxmOquVTb040g5eER +v0Xn+Lq5j7rWbz4wPeYWRqNlazDae3smEdBJQ8fUmxRcM290LFNlY3407b008ilfSQfgKxN Fd8Nazi0V5EAYdd8FWAop3wgn4y7IDKSudj0odPBRmUVa4RsLLk49zQmaxaPEFv93mfygeKw VMrbbt4sFmXr6Lnx4uqu2wt6sC00y4C+p6jkvH8dhYcTC9h3lxAyGOcexXl+Mp5nLpmO4mXV VWDpjM3lK0uMoMyWtw9Qqb4IU59fwrg5/i5ZZSxvjyMftOhDyBoCoYpq+xlKTKjCgt+Pg0Ly K0U04UlZ/dkrcKtvGXkVjaR5I7aOis24JccLzSy4xM1vsGlMea1WBo+IKg2G3Lc9QOy02GdL hC4ZjZkdu2jpYcltgsxt6gQCD5L0DCU4Y3sD6hZzevDDLPQntZd/HPTCzVeVVqkE81AxVWQV Y45niJ7qqrNWHJh7dXHyaVVYyVWPbdWlZmqg1BdRjjpteT0RgSkIlOkUUUl0SMLUMjon/CUz 4ae2kq0navhdklWvwQmvpiEaG1WaaYWKa+mhGkkqVCLE0sUw00wsQe0dlCTfRXD8NT+GHNAa 8ANe3UO/zNJuqxzk19cpwg9qUpEjSyoFbYnEGD2hU5cqaYXRyRJKVNrsWl7rd7t0Y9j6f7rD 4VsuC9C3fZYEc0FWzwAsFagKBgmqyAWuLKvO3PQHFc+pKG56wSXMkfUtHmh5kxzkqYtIDMtH hGSANLLPYVwvzWm2ZRc4C3WekrHRr3C4VgALZtE9VPmHdwfcQhtojKMvAwf7J+Xw9hKyzy0z sSNn0vH4rRzT8UGucSAD/Mtb8tlFoVjDyecDr1+SLg6/wyMwmx9wQsbkNJ+JogOaPDe4MjTq pRptMNaZineI/Fx+aoBWHHXrdTcJjQHtOnQRcJzLR6TGsLfDBMCT0CEKIdJ4iD26BDxG04e8 gG8jsDzQsJXAvOq0me02JGM2T+EPJJMOsNAOCRmx/wALsvhaTF/Fa8QjfxolxEAwJB+kIlHa JyjM2CfF3HZG0o2GwAio7KDLi68a8AZ4oX3CH/zHS7KPCDa4sp33gOaQLGQR1iVzsUA4uLRm ho7RxT7K0gYvZjQ9hAywxs5RdxLiTPkkxggljQToYAkx1U92JnPU1EBo7lPwrgxuYQXGA4HV HYaUZ3fzySZeZIEElo62shYbd95cyWtIILibnKxpuT6LXUq7GOeTxaeOg10QMNi4aCQY+G8f M/oq7Fpm6Owxnc+QGNdlaB+aTYkcApOF3UHxHF7Q5pnjMEmYuFY4PE3DXCGwI78JRn45zM7T Yl0jkGnkeavHlk+03D9KDa27FPMKbD+LxNEyGnSLjVVlHc17Q5zmtfBsIJy9iLBbTAFnxZ4g TcypAxYDiDa7nCOJhVeTCp6ZPOhum90H8IDpDYJM84ISN3Jqvd8RxgyQJBkgcI4Bb6i34lVr nHxBvhHC3FTHYfjY30kBT3wV1yeS1dgVnOcTS/DIkCAAPZVz923RMSdQG+OBzJC9lxTT+BsA lzv/ACngob9lUwWhoEWBNgZ435JXrfqj3Hi79kvE2MCRofqjjZ8tEUyYuXZfmV6xtDddpeQD MgOAtGab8EmG3bcA5oAbm46lRMfetj28qOyGGM5sIJBm45WCi4nZGV2ZtmEwLG3dex1d2GOp PaZLgYDrDxWtICgHdOBmIbGkGRPlxWnjqbXlLtnOILGjNMdweEID9iPZExJ4CZb3lepv3TLH Nexp8RsLROvkg4rdR7oqVSWgEtiBMTOvqn0yLs8rrYTKQBdxmZsB5oH3Qg31+XmvVMNuW2oS 7N4RIBIE+qkHdFoblYGuEgOmM0/5baJdKfd5EaLjxE91cbMFVrahawOP4bXItqF6G3dam1tR uRkwRmInKeipqG6jwGlhBm0XE8JCf0OzBVMPUac0XNr8/NQ67nBwBABkTyW52ru7VZZwObQc QDy7rKbQDmOOdpaYH4hGtpRNss+fHH7oG3ttUvhsZSY34gEEgD8PG4WUDmz+G3nZTa2BcJef FPER6KVgdivcMxpuym4K1jn/AORL9VAp4PNIAJGpiLDuruphaIptytEwB/c9VY4HYVWmHE03 Q6wtoO6l09iz4Swk6wQbd0V1cd/LOvwMNzkeGQI+qQ7Pa67SIPAmFrqW7jqgEgtboHfl7Hkh N3bfRM/jF7ATHRwU9WvZlXbKMEhwBGg1ntZAobPqSHBoMHyWtwOyHmqDBjWAJgcZRdpU3moA GDK0ScosbmJ66J9R2Y7aOCq5g97YzWEAx8lGp7Pc42E9uC1e1GPeG69Qq9tAtu0dD/dRbD7K KphH3hpifNJUwbmiXNI7haBlRxBOUkaTBj1SGtzbPdG4fZnaFIE+K3JNr08piZGojgr2pTa5 0uAF9BA9YVlQwtODLW3toJHY6p+h2ZGkwu0ErpKvG4SHEtMXUc4Mh2Ym8ylqDsq2tKbKs34d 7jaD7Jf4S7iLo6jasDZT6IuJPdWz9hENLi6D6qrbSMp9RsapiS13heYRBtR/H5KEad7eiOHE CC0jrr6o0Wolt2s4dR2TRtEngoxq2sm08K90lolHUaiS7Epja8GyCcORrZI1wR1LSa3Hu5FE p7Xcobqw4BCaJNkrhKFzT22Qbz7Qj/4iB1BHp8lTNpjiU37u0n8Xnol44a4/irTxPoAiNxc6 HzVJjMAWRDpHuFGzObf6pzDRaaJ2PcNSis2o7n2glZoh8SdEwYlw0VfQ6t07a7sgBPi5jkn4 Lb1RhkGTyn9VhTi3cU9mNc24M90bHR6FV3hc8yWweh1R8FvBlMkH5rz6ltR37CcNouzTM9rK afV6n/Gmuggx7gorNttm8ekLzCnteOcd7ozdtDn6lR7HV6PU2tSnWPNEZXoOE53A9wfovOht FutvIynffQeMK5bEXFvmVaRMfE84n6Ja+Vv/AFGkHQ/2WDc82M/X3TXY5x1cVpOSpuDcfGHO yNTaToQvP3bQd/VPoi0drubMGE/JU9G/FSEelVWCbt55sXfvyU2lvE4an6IvKOlbmnXHNSxX WGpbxcz6QpdPbs8ZHkFnc1TBrKtXqolSoqYbaH7hNfttmhTxzFxWr6yEXqodtpqUbUYeJC3x 5IzuK0LkkqCMcw6FO++t5/RX5IXVNCH8K6ina1MGJ9Lp9PalM8/32T7l1WVEKxpVFUU64IBG mql08QDxWeWUVItmPSPcobaqV1Yeay2t1R6ivKc+ogPqLbCppC1MzJrqyHmW0qBnPStchBIX pkmNqIrCoTHqSw2RaEtrlMoqtY9TaT1jlVSJuZBqFJmQqj1EVTXNlDe0QhvqwgOqSt8ainuK ZnlBcV0rRI2dJnQSSuylMJVM3Rw5QmuRMyQWNBimNYFX4dysaazyVDwAhPdGiI5Rar1nr2oC szMbqNVwIRy5cHrfFFVhwcITsKrOq5RHK9J2guwaT7kBwU4PTpRobQfuFk1uDVyxoXZAjR7V LcCeqPSwhHFWzAplGkFnlie1RTolXGy8Y6nI9EYUBySmkI0WV4z2i7W2gXiCL/uyyVdpnqtb Wws8FX1MCJutceMuzNkIrtFdfw7ouds9gEkXTvDsd2Vey6G2itBUwOYmGlDOzTyT8Q8isp4U JTRVoNmFNOzn8keI+6ExsJrqclT27OebwlGz38WlRlxHMxMIICtMLXgqDSwrhwPopLaThchc +XCvu9I2ZXLqYJVLvY8hvkpWztotZTAPLX+yzu8O1M4P7sjDCwXJiMa2Sq59GVZ1goTwtPFs 5mrX4UKM7CNVo5qCaSPFFd1cKHJL8JThTXfDR4x3Q/hJQxSTTSfDR0HYBzUwhSXBMLVFhyob 6aZlUtwQnNUWKmSI5qDUEKW4KNVCiqlQ3KLUcpbwolQoVEXEiyqajrq2xBtKqHi5Tio6U5rk wOTgqXMk/Z7JeO69M2FT8A5yvONk0wXep9tV6nsanp2904fZp8G2ynhRcMNFMhb4xFeTOqSm 50M1EB9QcCuUJD3IZcozq3VMLkqFvs0S7utpgXQyOOnksZsyoNOMLUYaoRBPGPRY1TQ03Wjv 6wm53AwSPL6qBTxLgZsiMbILuV+t1hkzqwo1BMO/zf8AtMe8IFTFQRKBUxJgG0wAq+viYk68 Ss9EtX4xhBvwMjqo+Hr2nQ6qqdiSdBbiitqGBb5p6CezHOEiTrxUrN/LzTF4Pv8Aoq2hQc4x Bi6JimObDSbOhwjlJF1eMSmse6zpJBHD6oVbGkEAagEa6Xn6qEaxEgam0dVWim8tc/UAwSq0 F9S2k42zXnn9VIbtctJDnW56kHoqGlhAaefMNdPI/ooTqzjMHjp+qWhtp37YbLGgnKbu7jQq S7FtOXIZki5sQOayLKR4+UXRiC0AwQjQ212L2m0AnVwcBPMRoFzN4gKZaZgtIHSeqx7XE89e KJiXmcvAGLcUtHtqqO2Gw0l09DdSm4+RJ8Q1adbcljKT+EOM6ZRJTsLtJ4MAEgWA6o0e2wq4 8vcXgAEmbWgckSliHFkmfxEW4dVlxtPNr4Y8vVOO1TEBxgEHukNtSKzS0EOh7XRB4hNbjT+Y 21ErPmu4OsQQTIUp+La+AXZec/IJHtocRi/C14OjfaUbZm0R4piBz5wshhsYQ+HGxEDlKk1M S6kTaWngiE15xQqFuY5S0G44prcc4XDhI6wsaduwZb2ynT1T8PtMPIaeJOl4J0TtJuaeMOWL G+YnmSmVNpAgRwKylXEvpRDgW6m8wORR8PtqmzPMEumPS10eSpsaJ2LzODSfww7kpVPHBzXZ h4XTlmD0WVp7XaKeV8HN+b8zOx5KZRxYNJzQQ4QQIN/LknObIuq7puaW5AAInzTKeCbnFoEG TPHgqI44ECJmw81Mr434dmPJBaDfnxBSvLacxW1XD0/wgQTx/uh09ksmcx8NoH6qvw2MLhNp jQ8+6JRxTiSWmOYmZU96fUDbmxQaTiyXGxF9DosKNgtcSSXmBJHXiLiwXomJ2gYAAg2F4T2l jw4EQ4C0cTHHpK0x5tfbj5/jTkrz/A/Z6XOzvphrHeJrZMjlw4q7qbouMOc3KBEBh5aEiAVp MNjiRkMZu8W7KW3HtdDAYdpe09iqvyafH8PDBRYbBvFskGDNtRwKHQ2XVJcAAMwuY0HULRYX GBzsrrEGO8KS6sCTGsEeXVTee10ddMDiNnPbFPrqBYjsi4XZniPhkRFuMdFs6ZaDLu0lSPh0 3XEHzTnNSuLy/wDh7mkuDIF7aEX5ITNiyDHfxW8uy9SrbPY+CWgxpxUHEbMpOvlFrWtCLy2l p5RW2MCDEB39IEA/qoT9h1ALNPWQbL2fDbEp5QHNBuTcA/NQK+7zSSZIk3EwI5Qs+9N5J/CK mhFuxQ6eygCSWmDwvM817JU2LT+G6BBAsDxKis2fTYBNIaagRfsnMqHlNHYb/wALQPEbaQAV Exm776Ryk3iYEfOV6ycDOYtaQSZFvko+C2EQ576jZPAK+9Tt5L/DM2lilo7Eh3izOGnSPRep Yvd1ompEZjcNFweqjt2blEBvqLpzMbeYVNkNbUIEtZqP0lO+6EHwuM8on5L1J+x2EEOjxCNB ZRcFsh2Hd4f5gImYGbtpor8g28sqteTfhYiFJwOwn1DYwO2q32L2UXuL30wJOkEfJGweAc3/ AKXYhXhyS32Lk8w2pstzHEOZ53gjnop2zsGxwa1zZFgvRxgS4wWHhqJTXbKY0kGnE8QPrC6M ev7Tc6wuM3KpvkgZfb20VIdgVKRLTmi8Wt5ler/dmDn5lE/w+yoJJPzHyW0xxv5T3rxx+x3f mNjxIMKS3YDQ2Tdes4bZTLtMHhp8lQ7X3RsTSdHNpKnLCT6VOR5m/YZMw70gptHZDuIM/JbQ bn4jhB62+iKNhV6YhzAetyfksdaX2YmvsV4HhM99VDGAeDqAts/YtU3gx6FVtXZTmu/C7zFl J9lB9zqmwh3modam9v4mEeS2mHwZdxymJ0XNwrnGMzT1QOzGfeiW5eHugLcYrYozD4jWuHAt /UhGbuzSiWZY5QPmnIfd5+6kmwt3X3Za4aehj5KGd2HRGX5/ojqczZANIRqGFe+comOoCt37 HLXEGQfOPkhMouYSBwPJTYrsrH0Ht/E0hIGq2qtc7UHvwUM4V06T2BUntFzkJRWKkfAIMER3 SHCko0NmjGOGiT706UV2zXxIb6XSNocwQeoIVFuFGJS/GlDqUihOtxQPSSK0cU5tfqogC4FT YqaTRiCNEZu0nD/ZVoqJwep0rUXDNsnif33T/wCKTf3VPCbKWh1i4/iBSff7qq+NaEx1RPSf GuxtLqfVI/a9vxR3vKoH11GfVkrTFnli0LtoExeykUccOHsso2u7mpNCu7WVdpdG5wu1i24N u/zVhR23MyY7QsGzEmNUVuOKwuVPxvRcPtwaadzqju2t1v0XnDNqH92Ulm1T+yp3T8beja4/ YKT+LNPJYb+LnmnDaU6+yqZ2FeNtjtJnNMO028x52WPG0JTTjeZWk5UXjbZmNaePuFIbXb/U sK3HWsfZEbjyeKrzJ8bbnEjmpFHECFhhtEgWNkdm2CPzJ+YujciuFJp1+qwlPbN7FTm7ZNr+ gU3kPrW0FcJlSoswzbPVE/jCUzPquqj0AvVX/FeJCZ/EweK2x5Ii4rPOnAqp/iA5rm7SHOFr OWJ61bh4TzUVc3GNT24odFc5InSaHKSxVwxARmYkIuYkWdKqp1CrZUbMQOan0a9lnclaWbqi j1EMVkypV6pSw9FKHVZyTPipXVrLfGosBKYVz6iHnVpPyJJSZ04EFMHsenNchFwRKaVCfQYp 1GlZQaTlPoOU001tMQhOEKUwIVZqUNFdVUV7VMDE11Na4oqPTAUltNvJRXNRaRVxI7gIUOrT HJSygVKZVEA1gR6LBOiFlRqLSSg1xToiNB6BN/hrCdE4WT6LrqcgfT2UwaD5I52U2NL+Sk0i pAK58rVxmsbgIBA8uiqRsJzruPotji2WUTD6q8da2GXdugImfLT5ql2hsIsJj009F6m6mFmt tUxHUKsNZFt5tUwsKI+ir/FtuVWVAlljpcqv+EkyKQ9DhRpWwSxNIUhwQ3BRT2jlqG5qkliG WqLFSozmoTwpRYgvCzqohuCjVFMqBQ61llWmKDUKiOKk1SqvEVdQk1gVeoq9xujVnShAJw3B qJTanMZKkUqaqGtdh0JdbmJ7H/ZeobLoaczB8l59sJvi7/ovStmaDyVQLyg2ykwh0NEZbQnh tSrZRi5NzSn8VhMSuWjDKcykT2Rsik0mIuKe4uynQ8HvK3DaudrJGjQJ6ArBUHRVAkRErcbM ObsM0+YJhc2TWfSz+AIMEQAuLIA8Uy3hw7yjYKiDTJPZRs7g/LAMCI4X6rKxNNeGgC9zw5I4 oUTmFTNJbaANY5qvqYgZ56R5qc/8DjIHh1JAg9OZUpQKlPJIgxNuvmrXD4QFrCTlJ4cx2VO+ s52p04HgYVpTqtNMPM5g9nU5IMx6JyEmMphhcbmcwgXiSitp0gz4jgXOMNa06RBv6hK2sw1H BmaNRI6Cfqh4oOADpmAABE6k3ngqJBNHxy9sEnMCNBe0IOHpAioBpmLo5q5wj2uvUEtA068F BpU4dVIEEOJjS0mQgjQxpZAbEkaKtq0GGoREBtjpJV9TyloMa2jqqoVBnfLYgkW01QBKOzWw KhcGtzZQ0zm0mUuAa+SXwGmbakT09FFdVLrcJkDqniq4G/AjzSNYt2E6q92SAwDMTYGzZMBA Oy5cYBLWNDiYuZ5o+0MbI/l+EmGFokWg381Kftv4GHNMDxvaAXH5z0IVST2FaWCKceETIdoS DZRtqYIU3kNNpBkHUxcz3RXVyaLXTN8kRwuZCm4xrTRZ4W5wJJ4vMc+Sk1SMES8BwuYPOZ5q NUpw97YgtJEDgrBle+Y880cJBn0S1BmDjl8biDI5XsRx1SsCEGkNa7gTl7FI/BuLgbc7mPop RpEtLTIaCHcNeEJ7IbEXEXlTo1e+s6csXFh+oKc3aDzDTfXW0QrTwG5aCRBFp0S7WrtqFnw6 bYuYa0AzBnRGgqC+4tzCk4eW+Ia681IoYekRMnSTPA9LJtNomKclsceB5SnojKmN/FOp1tqo xqwOc37I9amS3wxI1B/VNywAOhKXUGUKlgdQpmFxmQyPTRAwlF0FzQTGsaeZT6lI/wBJnjAl LqEs7VdwEIn39xAkzoSoFUQwGD6JuHw5cXQYIbP9kria7fjGBpF/WLoTtoQBGaTaeSqRLoad T80apVI8Gka9wpuIXVfagORsmAZJ0II07olLa5a8umRpI+qzzDBJN0gqEaTBPdLQ00mL2sDB LYqcLat4AlD++zBMKjfi3yM14Fp1A5Sn/ebtka3S0TU0qoN8+us6hPbtQtlrX3/foswKjYJJ 7I7Hgs0GYRewsloaaWpjxUptYSRU5mwNzxS16oaReLXjisuK5g/L6pX42WQ4SQQJ6JaLTUYL aZkAOIbKmffWzlJuTrwKxj6n4XCYBAtpJ4Iv3gtP4oPCSnqlWyOJLI4358OiLU2myCQfJY47 fc0AETHcqxZtBhpguIzTJBsfRVC0vKW1WuIgxNr81KewmYvxAWOftKmHSL9NVPo7ZzNdlMHk efRMaaHAEkuB4RHvKe2o0nKQCZKz2B2vlc7Na2t4R6eOpufOaD7FPZdWgqYadLKFicKMwDvK Bqo9bEvFw4xwhH+/ggTrE+aB1DOz2cpCks2awN76dEMbSbFwZ6aKcyswgQbaoHVW/wAIIGoI RxgWxMCIT/vZDrwWz2hSgRzHZPZXFQ1cMWkls/NS6+y5YOdpVjUpRcaC6ZVvBmyrsnop8Vsc Fv4p8klLCfCBm7VbfEaRDlLDBHROW/sdGR+4ZgSB1skp7Oe4XpuI7e61tGixslvFGaZWuO/2 OjLjd93CAORt9EDG7BAbmLoPHiFrKrJBUOps5rxBJ9U/7fsaZGvsOp+TK4dgFBfsmqDlc0Gf 6gFvKGy8v5ieUxZLX2Ux8ZpPnCWsi0wLsA9pyuaIItaxHSyiDd9uaQw92x7yvRK2wKbouRHI /qlobDYwyHOPeE9ZDrXnWO3YlhLWwbXn5hV9HYBMjKe94XqWM2SXXa6OiBR2ZVaNGlLeQ1Xm NTZJbxt5ymnZrSILnT04L0atu86ofEI7EfohVN0gBYe9/kjeQ08qq7NqAkGSOaiYjYrnXgR0 v6L1j+B5dWedv0QMRu5IzMAPS3yhG8j28wfsZrWA305cVAds9w1aQNQTI+i9Rp7DceHlB+aH itmuFi13pKqbHZ5ZWwB0cLfvio9LZRkCQRPL5r1YbGzas9WlEOwcujARyA+hCrtJ9jswDtkH JY35EKsrM4ObPkV6PiMA24yZT2MqF/hfOZM+enlZF5MRt5ydnMNyxw7E/WUWjsmgfxAz6ell vq27eTQSOgPuoGJ2ISLU46m3ujvD2yNTY1DgSPIFRauwGXIf6gBa5+7x0Fjx0I8iEMbtO/MT HS6O0HZhzsq8BwPYaI9Td6BOf1WvG7mUyHeRB/RDr7MqHwo7RXdiKuAe08xra9kMN5j6LX1t iVWj8Do53hQnbCcTy7h/6IuUPuzLsPyQnUytG/YzgYgHtP1hAxuEdTaczYtrrB7ol2PJpl66 jcVNxLbrsNhsxEW7/RafSO+wqNE6qU2lAVpS2XaZTvugFgSpta45KxKpdTC3/sm/dlm1mUR1 2VH+AeS74LuSNH3gIXByIaBCHkR1PtHfEKX4xTQxdKND0J8Yp/3o80AJYRoagwxRTxiOqjEL sqE9YnNxhCI3aBH5iq2VyB1i5p7T4lHG1j+ys8AUoJlLSerRDavMmU4bSCoVxqHUILo0JxvV d97PNZz72eae3GFPdHjaQY0/1J/313GPVZsY0p/33oqmVTeONS3aRjUDtJR6e0Vkfv3eUSnj Ov0T70vG2bdq/vRS6W2fJYQY9yOMceMpXKjo3rNrz+ZPO1uvqsKNpnQH1H1Uinjj5JdqVwbA 7V7IjdoBY04k6pBjewWk5bEXBsjj0041Y8Y8c/mnjaHVXOepvG1zcXKIzELJN2h/mThtHqVc 5y8dbKnilIp4kLFM2qR+ZS2bY6hV5k9G1pVQplLEgLG0tq2Upm1evujywdG0bi+qd8eVkmbR n8yPS2j1unOWDq0pqJHVVQnag5pv8THNb48kRcV8HBO+IFQjaQStx61mcRcavmVQU5z1RM2i iDanVPvCuNWLnCVJw9UBUTseiUscOafaDTU0qwKl0wsvS2gP3xVnh9pDmptg00FJykNVLRx3 UKxoY0cSssoekis2yrGfiHdT6uIEKtqVRKeEuhVw51lmNtOsrM4yyo9oPLlpx49aVZfFtuqq orjFNuVV1WIyXihOamEKQ4IRWSgyAhuCJKY4qaoxyG5PL0JxWdOGFCenlyC8rLJciNVKg4hy m1nAXVJtHGCDFlnWuMRMTiLqpq1ZTqtY6oLQk1kIQnBiKGorKSqG6iyLojUkoLqqqHppdjO8 XaPkV6Zswry7d83B7L1HZfBViVaGgbI8oFEWR4W0S+d2VI4ovxVNbuzWuYFhN59klPd3Eu0p EjpP6LPVc/eAU6ohd8bkUersKu23w3DuEEbGr6mk70MJZS6Lvj+xcJU8S22x8WbDnPnKxv3d zGNLmkeIi/HoPVaXY1TxHoAFx5fbqxu5uNjSH8kwbDL530VVXqG+WZVnQMUSOJPyVW+ncws8 ioTafMojqpMTwSBpNgFJo4LxAvBaMjnDrrf2U6TaFVu0u4kyf7IuHqeGeo+qHVpQYBkHmkeM rY5x80y2usNixrxvp1EQp1dwFMtFQkQLQO+sLNCvAsL/ALurTZlcOPjMWICZHU6/OQLE2Uin gA52IcXOlpkaQTeZUqi45XMB8LmhruoQ/ilvxmusC0iY5DVMkMsA46OEcZQhhSM88SSLz68l 1GvAi1jM63RDmmo4QZc50W0Jn6pGBQpMaSSCSPRDpUy8wOMkzwClUXkhwBEu1/3UP4vicDAL bW4oCRIHPh6XUHG1C46G3Q6TqpjMRl1/pj31T3417aZ/pcyJ6A2CDAbhgaQg21PfKSPkoryc oBnSeNhyVrUw7fhsLSAIbIGmmqjVBo62gB8uKNBFcAMovBEolA5iQ0uADSbcual7TLXBhENi B5Eap1GiAXgO1pEB3MwmaFhcadACbX/uorsQc08CplKl8JjiSCSB/sFDxLi6LAC8Rym09VGg WoS694sDrHmm05a8FhIInTgi0a0MycDE9SFxoMiQ45p06J6BtN5MpuEqkSdASbeaE4w4ETEq b4XRzPzQD8zTmIHmo+FqjMQ69rJxplj4J1UdjJfY8RfhCAsTjiyzbNIAI590Wtjj+UAG0qK8 AudyBgdY4pmMpODRBF40v5Hkg0uliy8ZSO/UclJrY2myofgtlscRoYgg81n6byCSPNXOAexr CC0E63+YQDXhrm8iLg/RdTo0ywF5OYXN9ROiiUsWQTpedUGs8yOSmhpBsygQCC4SOY9QUzGY dtA5AZBgyec3HyVS2v4RHaDf0SGqXWJ0/dlNC0xOGLhmgWFjzCZgcAasyIDBrwnkSorajsgG awm0/JTcNtNzaZpg2cZd15BToinZ7SJcbDlZLR2E+qCacGLi40UJ1YiWk2+aPs7FPaSGkAdT HkEaBn3Sq3VkXi9kJjSSfQgqa/aDqhvYKG/FhrjA17o0CszsaHAR4o5hxF0fFsfUh0AGI6J5 2gX0/hHQeITwd0KPhXuDJcR26IkJVsaWmCPNGqDMB9VpaOBGJEtLQWAA9bcuCrMfs9rbNdeL i1u4S0FJjC2Q5vhdxHA9YT8LinEz+yp2HwOQyS1w00XP2eC4ljonQaDsnoCMIeImDxCDRc5k ixKjsovBMg5ugn5In3ZzoyknigJ9La9Roh4HNGbiTVHDzsqp9F8EPBjnGhRaFE5fxRH/AKkB LZVc069FKfWqNAAeYnyVc3Dh+jjIXFtQSDPTsq6hYuqEukmeanYTGgHxXbz/AKVnKWKqNl2o 5FFpYxhBBBBPD6paJpf4wGghrwQTaeA5LsNtRpcA50acVlvgBxt7ojmj8LtRxGieg1e0MTkI gAtOjuXQhPwu3gRlMA6DhKyVHEzLcylvgsnUyiBqqeNgxlty/RFfi4EgRxWPo4t4/CT5mSlq 4l0Ak+Sfsm1p7SYbGx6o4qDgsO3GBwXUsfUYZExymyO+Qbj702YlHWL/AIt8Qfhv6HyUvA7U DXeImDa5V481n2NNTK6FQv2iAZa71lBpbSeXHxAdOBWk5v2NNGE5VNHHVPzAEdFKpY0O015F V5oWkspsSgjFCYNvknVK2W/BF5caNChgXfDHIegTGVwRIXfFVzkxGjywck0UQnhyWVcuNLRn whyHohvwreUdrI4XJ3DGjSMcE0/iAPe6HW2awiA0D5KauS8OIUjN3xMkx2/SEp3cpzoD3A/R XS5HihaUtfdmi4fhAPMWUQ7pgfhf6ifdaVcjxQaZZ26/MNcolfdMxMDtf9FtFyV4oNPOqm7k asd5SPoozt23umIjkSQfkvTk34Y5D0Cnwlp5NU3UJ1JB8oPmRKyG8ezXMb4geURZfQz8O12r QfILD75bvlzZpi3H1TnFpzfKtwx7R8+N2aTcCZ7LW7B3MDhmLZPMkwFoKG5NQuFwZMwAbecL 0vZW7RY1smCL6T7J5Y1zfE5M+T3+Hk9bdZ40bHUNJ+l03/CD9cjo55I9l7fW2O135iOwA9ky nsFjTIcfOCPRKcb0vbw2ru0RaDPVv6KI/deodGuj/SYXvmJ2RP4QPkgHYjyNWpXjv4G68H/w 89v4hA6hc7Y4HCF7VX3bDj4qcjmCDPkoeK3XZHhbHlKnrYcteMnZ7T4SLHiACpVPdjDu0zz3 F/Zens3LpkyWvB6NEJa+6QaPwuA8wfZE9HuvLa+6rBNj5kGfZCZscR/yp7AFei1d2nO0dAH9 UyoX8AqtP4QTwN/0VdoN1gK2xJvBZ3aQFAxexi0zMjp9V6ZV2U/8zZHqq/EbDZ/Q6e5+SVsP tXmr9mu/pJ5IQwDv6XehXoTdgGbNd5T7ymu2dwLHHyU7V3rADZ7uSa/BkarffwKdGOSf4ZPX sf8AZI+7CtwhjRN+6OHArbv2GW6x6n5KNW2YTpCY7s7SwU6oVfDAaBaRuw6pvAHc/RAq7GeP yk34fqmfZmTSB1CY7CGJGi0B2Y4aj5FBdgzx0QfZQFq6VdN2aHFWVHdmnEuk+acmx3ZQJZWt fsCnwaB1iT6qK7dueIhO46HeVS4fqivJVj/CcnXryUerQKk9q3PB4o9LFEcUYYE68O6V9COA S0DPvU8/Vc18lDdSStYfJA0lOq2UZ1eDqhvBQX0zySGkluLM/wBkUYgnmotFl1Kd7JjThXKV uNjh0URxSNkpFqLWnjzwPupTNoOF5+SogERjEy6tGzaw6+ikt2vI19Fk3PPNI2oRoUF0bJu0 eRXHaB7rK08Q7jdFGMKqWl0aYbSI4wldtTzWWdXOsoYxR/dlczsT441rdqfuQijaf7BWPOMK QY0p+WpvG2Y2ny90Zu0TzHksP9+PVFZtCDxR5qPG31LaXZSmbX/zLz+ntIBShtQ9vRV56Xje h0ts8J85+im0dtxxXmrNr2/RSKO2OMlH/IpeN6n/AB4qG/bNzx7rCfxojigv2veZhXj8lN43 pFHao4lNxOPC85btzqPUpKu3jFvXVaT5JeJrcZjWz6qqrYpqzdTaxIglQ3bRPElF59nOJp34 gILsQFl3bRI4/JBO0idY9FN5VeNp31wguxAWbO0OSBV2pyPqovIfjaYYlBfjhxWWqbRJ4gKL U2gY1Km5qmDVVNpNCra+2I9/JZyri3HkgmseJUbaTFaVtqEzcwq2rVk6lBCUBLbWQpKc0JGh FyoVoRrUrnwm5kF704ei1XoIMpC5MlUGq3bN56x7L1PZnBeU7sOuJ0/tZepbKdaOIAVYpyaS ibKRmUbDlSlvEscNotc02HZXGAxLIHhseXBYPC7Q6/JX+A2owam374JzKPP6vRtluwzWyac2 uXDPfpKs3uw/ww7I3UCIaCe/NYPDbdYALi370RMbvOwNkEF0iLSAozy1B036Z37XsVTfXw1O mIygl1g381hCotlMOYczb3UPeTaPx8ZmNsrcscyDP/3K32NR8cng0nzDf1XmW7u3o4YzHHUa KjVMFvR/y1UcU5Umg289He4UkUfABES5pFuhGvmhGSEylHBT8Jh3VHAS0DKRLpPhnQeqkjZ4 kSXC091b4DYghzvEGtbIMcZ4qmNrH4nDljnCZyuInnCY29NxImHM62JutJiMAT8Qm8l3Cxnj 0QKGy4aTc/hEAGM0yJMdEi2zjfxcbc+StsFgy/MGxYSOGY8gpGJ2YC/QyTlI4gqzpbKeG08r YbcW1nmU5D2qG1zAANxr07oOLxJcXAmRAJ/fJaGhhcgc3KHFxkyCAW8bkKK/Dw+qxrRBZx1D cosnobUdGoJcOBEJ34ajxMCXAdijUdnAT4xYE35Aad7KLVB+I7laPMKT2c5uVrgHTxSOa2Iv PDqZsSjYYS0t5zJjhPBEwbMoqCASHR4hOnBBg7QpCGlvFrrcr2hDpP8AAAeSsdo4dwDDADXt eW6aC+g01UNlEw2RAiSRy7o0Z+IqtNGbyMoHTuouJdLG2iCb85UutUBFQNHhjwzqe6j5JpwW 3sZn2QD64inLryGtA46apjaGXLcjwyRy7KRjbOaOAaECvVkt/wDpuHlcopgYZxJdbMBe/ETH 1QyNYFpt06KTgBOYgWymO2v0QHU5BAN8wHGD1SBQ1sGSc0SOU8iE3EDK7IRfKDI4SNLIuLwj qTfGB4hIIMweRCXByWEu1+iBtDc5sFv5j00TqfAcQIRKmGBzOBOeLciBqE6m0OieGt4KDDxG Ec2mKkyC4tjiNSD2sm4FjXgi8yOisMVi/AGt0BAH91AAgzEGJJFp6oMSvhzTYHAyM0WM+qR4 JYzmXSeQCjueSI/LMotXEWbGhsRySBzsK5uZ8At5j6ohE8UlF3gc0cWm3VNa0ZspMQJKYFwr G5vE0GAQgiiWmJkLi3KdZvqnvq8xBSpJNMtFnD99Ej6QEkGQUrqpDQSAQowxBzCR4VOgEHHM pYeQPZPxNIESALckwv4wloE+DmBMmyVlF0RK6i8idbqbgW5iZjKOfMo0ESk6Hx0Ck4ijmNuA TMZRaHy22luqbTpON2m/KUaABkWPl/upNLEaMJtE9ikLXmzvyz1TKUEI0Bm1i2WsMXkm3iTK uIJ1Pi+aZQaAbylxT2GLQReefRToJ2He4CCnPqckJ1UFszeAo1Oq03IKYXOBxJbmMzZNw+JD JtrqFW0QC4kGBwm0pvxnTDvVGiWg2ncC/cqRi8VnbBA/uqljcxCksa4Ez5J6AIOUyPMK4wO0 hLQQCBrKoRize3ROp1JFk4Ftj306mYU5HGOSDswNH4gMw58k3BjMHXuPJRHEtJEpknZWh8tE Spr6n+UHuFnfiOHNWHxiRdIk3EbGNVhfTDQW8rEnlyUCjQqQQW6ajipjMW9jZbBHHig0toHN MRzTAjMICJEg8Vz8AXcdOCKzE3tZNbtCHHMAe1kBFZssycpnpy7IZw9QE5QT0/spbq5BzQi0 cc1x5JaCr+DUBnQ8kSltJ4PiZCtsTRh0zI4IFVruIBHrCNA1uOaRKJQqtdpqo8D8zbcwEv3Q OByOg9U9BKpbTLHEat+XZdUxxzZhxUKjhXj8XupLNnvIkQeiWgT+OPDovHJTaW3SeI+aiMwI dZ8tPWyh1NkxpdLQWzdtQ6R6Kdh94MxIIhZlmzzP4SudRcDAkHqEBo6+3MuhRaO8Q4yVn6NN 4MvaSO0pK2HvLLdEboax22YAj0/uns20D+X3WSo4hzBDxIRRtIDQFV3yn5DZN2gORhSWVQdC sF/GDMXHz9EVu1v8xHsrx5soNN1KVZGlvA5oHiDh6FG/xDNwIVz5FGmoXLPU9vOGrZCls29T PP2Vz5M/JaWy5QW7Tpn8y5+O5J/8iBOXKLTxgOtlIbUB0IVTmxoOQq9HN+9USV0q/JE5YzKa oVHDho0E9EZNlOTmcoxwmM1HLly5Ubly5cgacuXLkBy5cuS6gw0W8gmPwrTqJRlyXWBG/h9P +ke6U4Gn/SPQKQuS6QIFXY1I/lHyUJ+7LD+yrxcl44GYq7p8iAo7tz/2CteuR44GJqbmgjRx PWCFEfucSfwD2PzC9BXSl44Hnj9zLW8J81XYndIgeIZuwK9UlcQn0Dxmru07UU46n9ED/DM6 g69V7S7DsOrGnyCC/ZtI6sHkISvGHk1DdtgMgCeoI91Ir7HMWaB6L0mvslmU5WiVWU9lPqcA BzP6KscNJee/4fbxKjYvYbgBlaf17r07/DZFxln99F38Eqf5fX+yWUHt48/YNc/l80P/AAq7 V7o7XXsL9h1DYlQqu6Tjx+ZU9TmVjyCtsot6qNU2ef6ZXreI3TcBESOyrv8ADBB/CY6AhZ5Y 1cyeWHZTz+U903+GFv7lepP2GDbIfr7pv+FQdGOnt87KfZ9nl42eTo26kM3ckS4x2XotTdF7 fFlj2UR+xiNWlA7MA/ZTW8z1KA/CLb4jZIdoy/ndQau77+X090bHZiX4Iyh/dD1Wwdsh39J8 rof8CJOhHsjauzKtwbk40StPU2G5uoPqFHdgCOHsjY7M6cOeSaaJ5LSfw9x4H0TTss8R++wT 2Ns78JJCvXbPHBCfgh3Rs9qR0rgrZ2z7Tp8kwbPP7CNjarcDCHBVydnnl7JPuB5XRsKoMKJT pqwGC6XXHCuCZIDhCbKlvpIJo6o2DGN4omYpRTslaE4R8nmfVcXnmmlya5xT0HPqkaFDdiz/ ALIZklMcxM9DHFIT65TC1Dc1B6JUrID66R6A5A0f946pnxkJwTJQYxqIb3Jq6EHowrgnELh2 SPRAlXBLCDhzEcFMYE4lC5COKjvKK4qO9ycM0lNBXFIVcTWl3c/U+0L1TZbrT5ei8r3ddp0j 53XqOySIVRNafDaSpWZRMKVKhbRLw9mJ5BSqDyffyUFtkdj4XPM2Vw2vMOTxci4nE02NJdeA YGpJhUwrQJ4/NAPiJss+Tk9HjhoHCUyahd1Jv3Wy2Rz8lnKFDtK0OBqBoElczbfpoKfDutHg arXOJP4QIaDosrhtoMBEnQzHPorpm87GtDcogDgBr2unGOXtpaWHFR7J0a2bceQWlbSGWOBt 2CwezN5xJcQOfJXDN8WnWPUKto00H3Bl7arquCHwyxsNmLxxBm/oqCrveyLH5obN7AeI/fkj ZLB+xs1S+U2BJI1KsXUC1rWgTAc3pfiqbB7xNJe4utYR/eFY0tuUyRNp7pwh8Ps0NBvJLC28 eybW2Sxz3OIOY0wyRa3A9wprK7SAZsfJKyqCTB0sVr6NisNsIkPsJDZvxN7eyptpYV/xXzGj NOWVenNpCSQNdVSbQ2CH1M7Yba/U9lnlAweHJDZAuTkb0PX0QKmZtWo2oYfOYxpmK1b92CTc nmInXnAVTW2FVzuc5kkudcg2HRQW1RWxRc4SbZHt6NkcEMbRNNmXWQW3vAIgqxfsOpwaSMxb aNQJPYQop2eYPhmQYJ9oQe0JmM8OUC5tKO2r4GttYmTxjkmVcOC4ASIAtyPMKY3Zw+Eal84e 1pE2IIMmPRNUQ8biA5oHHgenJRwYiRM6dtLKZisDOUhpzAX5Ec1EqUHyByE3+iVN1Oq5sxbh 2BCG3Fw7SeKMaDsrrTlgu0sLXHqgVacQUjPq187g68DQHmm/HMEnQGDHCU2poDBTy4hrhwcB I6BIHveLQeInspop05FrTI7dSqVrDrfURIKP8YyeCNhMxbY00Jn14JjjII5iFBrOJM/rCK2o SjZuLSB0Suoy1sanVCBzGO6OfwiNbBI0zBYHNJa4hwBmdJ1shnDuz+LUASU7CPcJE8CUmHqk gzqVRHVWBxDWzM9Ex+Dfa0wDPeU9wAgjXinPxDmt8JufkkD6GHL6TmzoQblQsRRcDB4QVIp4 x0R+5Qqz5jmghHUnPaMky2Sf9MIPx3CxHLzB0KsBh3UmU35x4p0JkdxCQvzm5kR6BI0UVrdV M2VJJIiwkzx8lDrwNDITsPU0AtJ149kiSMTJdMW6fNOwgGaRPI8E6m0ioCdFJq08zpaQFRBV asuypMRRawCRcngnVqLrcTzCj/CqPdDuHPRAPxFA2LL9ChVGG0hTWUnAiY1R8VRbkMkh82EW LehS0aqB4Fc0hsyJBVhgaYId0IA4oeMpk+HLB1kaJ9Qg0b66TKk1K4aQB3QjgnAxIvfyTH4b xZZS0Fjh6ua6kGsdFW0WvborChh3PPL6qpAaaDSIIlPota0Rl80ldjmOy2/VLQqteINjKeiD xD7+H/dRqhzX4qwfSyugwf0TquHAggWPslolW+SOasMPiGmz29Eyph79Cboz8PACegdiMPlM 0zLTqNYVe6oZsAFPbiA1pHFRWC8lLRHgEjSydh8IA6STHyU9mUt1CHUpGLJaCBVxBY8tmW8D 0TmDiELLJUqjUaNPRII1Su4OlTGbRbl4g9k9+Ha68Qg1MHbmEyObjLHiOvBdTrEXHdDoUeZU r7uRoQmBqmOMBCpbWcLRCCcO7hfoo1dh4pHtaux2fUBc3GsHQ+qraT+B05pxYpo2txtFh5Jt TaDSNFR/d5drCniiA3VItiDGnySDFnkgGmuYITLawwtZrjBb6wR7qRV2c0HM0AcwNFHzU4kE goP3t5sPVJW0vE0mvF2ieeh9VCGyx0PdFzniUF+IcDIKBs+ngwbFs+yA/CgEgSp9HHAwbA9g iVMQ3zT0WwcO60QnOoTpr5IjBOiXRMbQyYsbFPoY9zTHDsprnti8EotCkHDgkaNUxTrELqeP IOqmHDDjCDUwrRNggF/ibuBnsiN2zHEqIzCDgYSP2dF5JVBP/jE6T5hEpbVI1t6qvpMGh9U9 7o0MjsES0LultNpGoRW41p0N1nG4gJada8gqu+QX330g30UluKaeIWedjHckE4hx4JzkyhtW HBLKytKu8aEon8QeOKrz0NNK5Z5m1H8SEYbV4EwqnPf0NLtcqlu1Y1MqW3aDef1Vznn5LSWu QW4pp4pwxDTxCucuN/IEXJM45pVXeBy5cuT7QOXLlyeycuXLkBy5cuTDly5cgOXLlyQcuXLk aBZSLlyAQtHILsg5BKuRoAVcE12qCdlUzw+SmrlNwlCsqbBpnhHkolTddh4+llfLlPjgZr/C DOLh6Ih3VpgWA8/0WhXIvFDY7F7qg6Mn0A9FC/ws8flA8lvlynxB53U3fd/T5gE/IKM7dlxP 4T6OXp0pEeIPLKu5r/6PW3zVfW3YDTcX6TC9jIB1CBUwNN2rR6IvGNvH3buzoLdRMIL92Xaj 5R9F69X2W0iAAov+Hm8SfZY5Y09vJKm77+YHqVH/AILGpnsF7A/dikeJ9lXYzdoAQ1p8rpda e3ltTYw4ST7fJRKmy3AXHlC9RZu+R+IFo6on+H2a376fRE2e3kb9lk/l+YUepsqNLeq9Uq7B BMBru8f2TTu0I/DI5GD8lRbeTOwMWIRGbLlb/E7ugTA66adlEbsk9e0BVE3Ji3bG5KDXwBGo svSXYEgSWecKtq7Pnh9VpoTJ58aE6JHUFtKmw+MH0Q37DbH9ilo+7FGgeRQauFI4LeDZDQOf RQ8bs1usQjQ7ME/DFBqYchabE4Ua8Pkq6phXHh5pLlUTmpvw1d/w0x+kJv8ACzxkd0HtTfDK SFdOwITPuSFT2psieGKzOD6Qu+6qLk1mCt+GnCkpxpphYl2V1R8qY5GyoVQKpT0CSo70aoo7 lcRkaSkKUlIqQ0e7pvH7uF6lsaYHYLynd8Sf3ovV9kNIAHZOBp8NopXmo2GUpbwnhYTgtW/c W8NqR1JB9kAbh1j+F7T9Fws+zNyjU3wrl24mLzQA33H0UHEbuYthI+ETBiReeym4n2hKdUKQ doxaFWvwVdn4qLx5H5IDnOmMpB5G3zUdKO0WZ2kZ5Jgx/UqrdW5/T5oZrjml1qV/h9rOFpt6 qTU21lABu4310CyzMQlFS5JKCaittQtLbi4mOXmjYfa5MwT6j2Kx/wAQTKLTqckybzDbWJad Q0EEuJ48lZ4feUB4JIgc4Xm/3ggRciRKYNpOHT3TGnrn+MSTYiOAB/QKdhd6rRmuTwkfReN0 MeTxhTKG1CDM3H70RstPYhvSWsjNF5seHVJS3uJ49ok/IBeN1drOJkmT6I1PbDrR2gSL9krT 09wob0FxAkSeZ+kKcN5WZspggRJNp5xZeHs204HxG41EgT2hS6O8xEzPT/L0kIGnttTbVKWg EaOdYdIsB3KEx1A3tccf0Xj7N6Og9TPpCM7eMmIsNDZB6epvwVGoSbGIHAeV0Snsln4Rlg3I HTsvNcJvGCQxrwJkmZEeqsKO8TQ7K157yDPa2ico09IZu/TgTJgAWMBUG3N1wHA0xDTfnB5d lDp78Q2ARA55f90CpvkXn8fIZY16qrYNLjA7EcKNdpH4mwYm5jTyVM7drK8U7kkW6hWo3xgB sCTxgkI+F3ma5wkN7/ql6Cg2jsd9NuSLHmCPQ8VGfsV/hAguMtIW0xG8NAxmE62gG/SUlPaW Hac4EOOnQo1DYmnspz6bgWmWh3A2LVWjBuMAtOnAFepmpT+GI1ecxjWXakoNXCU5zAhpgBot 7yjrA8xxGz/C3X8UExaOpTG4Mgxr2XqtTd+m6nl0ObMSPl2Uaru6LC3cWPmIR0N5y/CAwMpH CdPdGw2EcA5v4idOa9HqbtUixrCJvmJ0JsbWUJu6oAeZAucnlojoNsGcG6CBIfcEFVbWuFo0 K9KxGwSCKj+QBg6ngSs5i9gEkkaknr6hTcQztWqTciNNPmmVJB7q7/gL9DTNuVvmiYndshoN 8xuJOoS1QoaNQzBF7o7HDj3Vhh9k/iBJBi06So1TZz5aAIPUWjjdGiOq1A6nE8QfLog02jhZ TKtC2XLHC0HzQGYAjU9uUo6gE0nA2KRuEfqRClMw1UmMpdHIj11QQ92aMpR1pH1a5nVFogFs l0FQxeeeil0IAgpaBpe6YzEoxrvtMxzjRNxLB4Y1S08WWsc2dT0sIQBH1jYE8UevWMAmC0W6 qp+LJR3Osg0/A1gJB/CTPYozsdcCbWBPIKppVNb2TpvdUFvjabmuaYlpEAjmohpSZSYes/TN IHAn5JahdqEApepNKckXB4KvfUKssLWkX/3TJD8ZMTJ63UjD4f8AFJhwKjV65+JyjQ80+hi4 dLrjimQz6bgQSZ81J+8mILfNJXfSqAZCQ4cOaE1xFjojQOq1QR1QsK+LGYTquEGoKbTw7ouj RFqtEotOoLWBHH9VLdjG5Q1zQbXsouZo00T0SU/Y77OpwRyFrdOaFWpvDJLSOBlNoVSwyCY5 DgpVXFmoInkDKNBWU2wZUxwaSCBfnCZXokKM3E5bwpuJJ9UmU0vcbIeJxIdGXlcdU2hinN/E 0o0A2tINxZLUxAGilvqgpjqQKkFw2IEdeadWdmTRSA0TS8pA1wEJ9LKBdRfiGdFMDgbFOQDV qDSJaQCopJHVPfStaUxtlXUifGBsbFHZQ4prqYI0Q21CLApaCT8MFMILdEPOQniqlcTHcJao Yowb3RfjFCKJiAH07yERhmyWnrdK5omQnYSVhwRxUlzCeN1DZVsjMedVJw6myPxI7GibGEKt WzCEFuDPBGjTnuXCpZBAcLOaR3CblMpaCfRpB1wUfNGig0p0RbhMbPfUHFo90ORyUgCQq6u+ JCBtLbkPJd93bwEKoNRwMhSqb3uF0GnCkQhuYeSBmeOSkUsYSIKQObT5ppc0asnsCUr66eKl kAymGkyApp2exw1hQWvGZSBiI0TNGq7HeNPEOdh7IbMFUB5K3w+N5pMVUm4TCtNN41updDDt d09U6jVE3Uk1m8ggIdfDluhlMp486X9VJfUBUJ+HEygJbMc5FdtJw4IFKlZI6mjYHbtg8WqT T2m081WmiDqg/db8U+1/YX4xbdZStxTTxHyVE7DkCwUZwdMQ5VOTKBqw4JVm8OXA6+qntxTx xCuc1C1XKtO0ICYMcTxT8/8AolquUBmO5orcc1VOefkkpcgDFtTzWCvy4gRchiuE8FOZygq5 cuV7Dly5cgOXLlyA5cuXJm5cuXIJy5cuQHLly5AcuXLkjcuXLkaDiE34Y5BOXJdYCZQhPwjS jLkukJAdslh1JUc7BbwP0+St1yXSBQO3dn8REcroNbdsRAA91pVyOhMYd2unzQa27Z5Qtykc 0EQUuoeZYjZAabC/74Klx2yJ1015r1utsqm7hdV+I3eaRz9AossDxjE7KI/L/dRxsv8Ay+xC 9TxGxmtOirsTgheR2RJsWvOquzhyUOtglscVhoJVPiGhXoplWXfgShHC9FoHtUV7NVnndO3h inNDog1aMK1eFCrBc9rrkVj2BAe1TKjVHeEtjSM5qiVWqc5RXrTGpsQ3qO8qRVCivW+LDM0l NK5JKtm0u7guPL5r1nZH1Xk+7us8cwHkvV9jGQP9SA0+GClAKPQ0UhbY/QUjakcAe6QO16qy q7Jplo8Tmk+gCqKuAk/jMTH7C4erm2kU8dEa2+cQpFHHifEbXUOnsp5s14Mf1C3sm1mVAcga 15FjlkieRPBOY0tpnxGvqNyt8IBzEiZnujVKdOfFTbrwa2fVV1NtfhQP/a76EIb8Y5p8THA8 iCVfuEtK+Awjw3+SwS5oMsAmXQfZFO52znuy5IM3IytVHSx7S6XEgCYBBHVSKeNDrh7Z6mFN 7D0Dtn7N8M6mfg1cjw7K0fl0Jlwi5MBZSv8AZjiWkgPpuhoebxYmImNVucNiyHAPggGfCZ9f VdtTa0uLQ5wEAeFpJN5uVGWNio8mxG6eLaZ+A4tkgEEHQxoL8FFfsvENJBovBHQ/VenuxJAa GPM5SNYvmJv6qdRxr8xIcS4hg11N5+iz3pTxz4VUGMj/AEOvVIarmzIIGht817dhauUlz2Am 5ktETB4qDTqUyaoqUmukeGQPCehR2DxcYm/9oT837C9kp7KwwpS+i0mSLgT6gBU3+GcGWN8L s7n5SASMrb3BKOwebh5hPp1j/db3G7jYbNlZVqD/AFQY6yBdRKu4HhJZXa6OBBEnlojYY4O4 onxCr/F7jYprsoaHOAGYB0weWirau7eKbrRfExIFp5SnJaW0VlROa4DieybWwdRhh7HtP+kk eoUdz4N7eRT60dk0Yox+qdTxZFwYPRV3xF2fhNxw4paPstnY9wb+Mz5H3UjD7ZdTaYALiIk3 VKO6UoPa6Ztt5vPqVJw+8D2nUe5kLOh6UOSPbWN3lJT27z3H1MLIF6VpEzCNh6BT3tlwJce0 jXhopjN5XuIe4wJyjhbqOK85c4RI/ulOIJiXGyNm9j/xacg/pA53t0hSaO9+RrSTGa7eo5xK 8ZpYgkg5oA4Ea+XFFftao5wJNhYcIHQBHY3tmF3wJmTPW1h2Vph962O5ZQNZEk+S8Dp7Wc0H KO8HVTm7wEANIPORHyTmQe7P3lpFpkHLccCFE2dtei92gsNSvFsXvJIDGTAuTcT2UrC7dA1J zEZePuYIT7DT3enj6JNo5aKTiaDKjYdBHA8R2K8Sw+8eUjxWHJ037QrT/FwbBDifzGRlv3Tm RaenM2MxrTAzE81HxW74e1rbCDJ/ssXT35ysknxG8TOXoU/Cb7F9QS4WEjXXtxVdoWmxfu1R gnKLCwGblylRWbBcGuMNA1DYmVU1d9ObgPP6BXOH3rZkaSQSRM3/AEVSwqJh93mmCRl7SJ6E JWbs0zZzQIcYI1IJ4qVh9v0nMDiYlTKOOpu0eO0ifRaaxpMXtHdPLW8EunxAdORUQbBl8EQN baDuvQzVZIuJIMduN0opsMwG31iPdLxwnnmI3ecBnAJH75KA7Y7nAlsg9dCvVWsAEAQBZCp4 ZgmAL9Al4obyUbFc2MxN+QNvZEr7Me0SJLTaYXqrsIwiC0R2QMRsmm9obAAHKPdLxDbymlgX tHMdLn0SPpngJ9LDsvU27BpTJEnvHyUc7vta8uYBBOhAtzvEpXio28zFJ1o4qa1jhwMc+Xkt 3V3bZ4oaBN7Wg9Cg0N2BludeBv8AJHjo2w9dpJ8LgVMwwLQOaucVuq5rvBJbqi093HROWZ6/ RTcLAzzarS8tdwKbWoDNbQ+y0DtgNz/hIdF9fVCxWwS2IkDqCfSyWgz5peIFpEclZ/ciWZgb 8kT+FwfxfIKNj2vZBbMaHWPZMqiZjcEwjCo7LBMqIak8FMwdHMCJ0QRtF5IIXAJuXJId6paL SZI0SJLw9Tj1UhzgfENeXNRMsDl3TfgkCZnomEl2Ka4QbJDhmSIdIt+4UQOg6J7mcQgk84IC 7T5JKmIy6jVAZjXNsU5+IDtUqDHt5IjBMAlPyACQZ9kBzJUaNKfSLRe4S4d10AUT/VKLRfBg o0Qj3ZiinBh7dL80BtVoJR6FZxBjSVUAbMOQLoD8MT0U4VJSFyokJlE6Jr8BV1gHsVMcE9pK QVbS6bgojBJ4qxeBxEKR9zES13kUGgsoRdOJBsQER9JwEkel02lTzI0EAYa6I/CuaJhThQIK MTwRoKtrzH4fOEdjJtMItaiYsg06TiVOlCHZztc4nsuAe2xI7qQ8lRzRJOqfUHurkDifdCFQ nop2Hlo0lNc5h/EPolcSMw7jNlKqOfF2eYIKgfFDdFMpV5CcxIIVykq0Gv119EyuboVJ8FFx MrWZUVmL6FKWSVMo7ODxrBU6CudXk2BTgVIq4M0zzHNAq1UaMrqTtQnsq8DZLhq0qUWAi6eg FTYDxUp1AR1VcKWU2KlU8Q3rKWj240SkfZPGMB4pajQRYo0AGtnROdTTWOgqRqEaCIXI9KUr KUFSnaWQCUcQRwQ8RmNwF3xCj03SkFbTxLgYKlMrkp2JoA3i6DTBT0EgvRqeU6iVHawpQCg0 pzKfKEB7BwTS5I3VAJ8IHiE00YUpjWjgnSOSQRqaLCI1pSOYdUiR3DyRKNYjqj0h0RKlMJEj urJGVynEDilYEwe3GkahIdoHkudQJTG0YT7U0lmKkJ33lQatkSjUKffL9hKGManjEN5qvrFQ a1XKq8mRtCHjmllZhu0HDiinGE8VU5shpo1yzoxzuqLT2mRqn56NL1cqpm1TyCkN2k1XOeDS auUZmNaUT7w3mr82JaFXJgrDmngpzkxv5GnLly5XuBy5cuTDly5cgnLly5AcuXLkBy5cuQHL ly5TYFfjsMCCVncXSC02ONlldoVfqsfqprPbUoi6zFdt1oNoPJVFVSuelYT2gupqLWClPKjV Vhllt3ccV9cqHUVi9qhVmrN0q6qNVEeptUKK9AR6ijuClOCBUC0xKq+vqorgpdcKI9dGDmzB JXApCUoWjJoN33+L98QV6tsN0NHYH0svH9j1Yd3j2Xq2wq/oB7ElM23w50U3Kq7BlTw5aYhH xe0aeXKDcx5eajZAW6iZB+f6rIfG6p4xJ4ntc2WXVneNpXMqAFsWP71TaNWpTByt9lRMxjho 4+pUqntOoNTPdPSLhV/httObJyjNY8RppbzUUYsNcHOu5xJM3B/sqt20yTJaFx2oCIcz6p6L x1eYnH0nasaLCbCY9FHccKQ2GjWSYAMQbT3hVZx1OOIQT8N35j8kdU3CrOtgsO69NwBJvezW 8gjnYwjNTqEdrz5Kk+6tJ8NSydRpVJs4EDmYT6lqrLHbKqA/DL2GQ15Oh42JjohO2TXa2W06 dzlEEkl3IAcU11SoJJgktLbco/un4PHYgOaZMNuJIIngovHKPaDXo1KVqlF+YCXBpMxzghQa e0GzLhWb3BPuAtJjt7yTJY0uy5HEg31/VV79uMLcpYCT7Dkp8UPdQHbSpER8UzOjg4R3Uqji BYitTdFwJIPyU3DY+jV8LqIIzDg2dIiSE/aWzMG6m7M0scIy2gST0ACm8MHdHbUmTAcbmxHo jUXeAkgiRpr8kEbih12VyLAkcukLqu5GIbHw6rjx0MnsFPhHdIpYhriTJzEyZkXWg2S1wJk+ C+sLF18HtCkRmaT0IdJA5yF2K21iskGjI4jKTZXjh1TbtrK9fV2RsAxEB3mhOfSfBdSYbXBa NZ1CxFPeR7AQ6k8eo9lKbvXSiCCDrrdp6SEf2Go1WH2fh4zDD05zOiWiDe0i6q8buxhKz87q WR5Bn4ZgTzAjRVzd5WOb/wA830Bi3dWeH2yCBFSnYanXqs8u1OQCp9mOGLKZbVeHZS5xJaYH Dgq/aH2ZiPBiS50XDmxB52WnbteRl8BBbls4aTKNQxpu8tsDzBJUGwbvstxIDYqMMiby311U Kv8AZ/jW5yGsc1tzBMkcwIXqI2y2JhwAEQRoo9TbbXB7QScwgdOaV1+i9vIam7WMaAXYd4BJ 0E+yhPwNVv4qVQDj/Lfbzhe+UdoCHOLhYaSo9fFHUkOkDWEvQ3XgXxRz9ZTmv/ei95w2ysNU BNShTdfkBfyUDam4uEeXVHUywGwDDkkgWEp3H1tXZ4rnlPa+F6qfs8wZAlr22jwmT5yqzaX2 Z0wf5NdzWwLOAJnjKzV2YAVUpqlbB/2YV8peytTIA/NLSTygBRan2c44RDWum8Akf+4Jyb+h 3Z5jhrHDXinU6t1YVd0MY0T93qawIAPpCrauza7DlfSqAjUZTbuYVdbPwfeHnEcrdV3xJMlx lQzIsQR3BSfE5+9vSUvZ9ljVxY1lOp1zrPuq0RrKdnRsbW9DHuHVSqu3agFrC2hWfDynB5S2 NtY3eMEWcWkc9CfSyLT3rLCCHGY8WoHkVkc8JM0qu5bb/D74kX+JciBEkR5hX2zt7IpOeXxU uGAwA8gcvqvJ2VBoRZSHVM0CfC3QI7k9Rfv44tixebm5t6qfg9/i1rWiDpJNvmF438a+qMzG xqT81XcPc6X2gUy4NIA9THmFNqb7URpc9/7LwFm0nAyI+SLQ2hUF+OvGyqclD6Hw28tF8Xue QJEqZV2vRbYvE+Z+S+fMPtwi5NxoOGbgkZvHVJlzj6qvLQ+hm7SpGPHr0P6KQyqDoQfNfP7N 5Q0SHuDupP8AurnAbw1mgP8Aigzwn25p+Uae1SuXj3+NKnxJzCOOU/2V5R35qO0cOHD+yfmg 09FXLz+n9oUOhwHUWn2VhhN/abvxAASALkW8wn5MaNNRWwFNxlzRPoh/wql/SFWt3vw5tJUh u8dAtzZrdteyfbGkSru5SJkSOgiExu7VMCJPsiUt4qTvwyR8laNqgiQbJ6xpaZvF7pNI8Jm9 +Fuh4JtLdWBAMe603xBzHqnI6Ylpj6+wqg8P4vL5FRXbIqtMZVulyXSDTBVtjvABLTHSbeyH /Do0MdCvQCE11Fp1aPQI6E8/OEPHTmgYjZxEFrpHJejuotIgtEdggnZ1I/kHoleMPO6jDlH9 0MNceNl6I7ZNI/kA7WHooR3cZmJGh4cvZT4zYevTqASHFEZUJbc3W2/w5TiOHl81Cq7qN/L7 n+yXjpM0yynYSu2I5q1G7BHIqLV3dfqBHb9AjpognOAQKj+M2Rqmz3tsQSOxQBgDoZjzS0Nu Zj26H1TqeLAUR+zHDQz3S/dDGh9Cl1AmMxnLTij4HaEiDbgq99B3km0olGjaahUzNIm6jupF juiqxUcNEyri6nEoNcfHBPVRqh8UyqgYl2aVZ/E4pgV2LIUhlQESCqyq4FBDj+Uo0a8YA4G6 X4MKppZ2m5UyliHAzqE4SyouIEdVDrQSpwxMttCq3v8AEUAn3a8ypFHVBfVICGyoSUaJZvpB V9WneyIcWRqEytWAunoH0azm6hSBiTwldhnscOveE+3JRcQFUruIvMJhoMcNSEYVeEIYw5Js jRm/Dy6J7anNSThTl4HzUcDmEaBCWpDBTH028AkDUaMVtBh6FEFONDbqorX3RxiAjqBJSfEI Qm1TKI5pKOoEbieYT21wo2XmhnDDUEpaNbsbKmNoiOCpqdQgQiDHOHBKwJbzBhCOqiPxJKLQ qnVASQTwCb95GhEHsiNxg4rnYtp4I0ZfhtPFCyQUpaOBQ3NIvBRoDQkBQmYqOHsn1awNwlok xr7JlWsoLa0KTTc0m6egQYopzapKMQBwQ31Ql1IBzSSjMpkJrK10cPU2HDk0hcTCTMkA3sK5 qN8QLnPagAuokoX3IHqpecJQ4BVDAGy26m6T7mwcFK+IEJ5TVEGrRCD906KwyonwwjSlS/Dn QBBOEdxKvHEKM9spaCqgjQlOdi41KsHYcRZQauzWm5lTYNGNx/JSqe0SFDOBA0lNNI9UhpdU 9pypQxKzzCbKQ2oU+1LS9biEQVAVUMdIRmK5zWDos5SqA3FAIn31q1x+R+03FLXKIMc1HbVB VzmlLQi5JKVazOUtOXLlyonLly5KhGxtKR2WQ2jTie5WzxL4aVi9sV72XPl9lWb2hYeSz+JM K6xzifRZ/Fmyirw+0V71HeU5xumysK7uOAPCiVAptQqFiXKW6uqNUSoVMqFRHtRBQoQKgR3I LuS0iNoNZQawVhVCgVQujBlyI7gulcuhbMEzZ74eCvVN3HGG87BeU4H8X75r1Hd11h++aA9A wZViAqzA8ByCsQrxDz2F0LilBUN+rgU4GU2UrSmWimoV0pCmwmWiucntS/DlIBFk0XEhcUZt ZCc3kmAJl1PNR3MqQ3aLwIBQGhDKC6xI/iB4taZ6Si4c0hJdT99PJQSuLjCVReNZCsywaYvw RcQ1z4BeCAQYPTRZ4C86coUprtJU3JN4mjq5nFpzQQ2LcTH5lJwO0qlIyXEwNAJnvKocO5WD ZU3JFw0tcdvM+qWy0jLLp5k6iIUd+8xDm+AEDgQIN9CFHbmjigPpTeEpyRPVa4jb9J7odQaO zQ2e6ZiBg308xogAkAwACBNyoFMCcxaCVAxezwTZxAmeyfeDqtBulgK7gWlzGAjMcwBg8uCF tD7PcO3M6nXLaY/DmcCdOYhVvwyxpa0yCeOqc0Va0NzAMGg0HWwCO0pdS4bcGo6D94lsTYwR POQm4zdLG0iGsqAiM0Zjcc4hXDa1ZmnAAWi8DqhjbFeS9wJAEAOkwJ4J9ZS9qarhcexoOYu4 QA4R3kQm/wATxlMZ6lIQPDccDx0urzB7xvzOzHwxYqc7e1xcM1NjmAaEAfOVPjh+2TfvO389 M+Ui/aESnvJhyYc17bc5PcBaU7w4V85qDRP+UfOEjqGz6rTmZkfGVpAFusQleODaDg95qXha KjgBrI1HVXjt7GVG5czDB8My3hrKpXbn4Qw5rwCbHgf7KezcbCuY6m6rlJuDAlpGkHql4/Wo NpmD214tAYuYPyCPX2uHvkscNJi9hxgLKU/s8qnxNrxBI8U29kHEbqY6kHOFUONgIOvYQo8A 22X8XpyQWnKTIJaR6jgplHbdNo/GL6C684GE2loAXc4JTsHUxhdD2mW30kE8p4pThso9PXWY ijlb4ri5nn1VdiKjTUcYB6kA+68zxO81UVS2pQMixMGHDnpZEp74022h46S4geyuyjT0tmAo ES6nTd3a3Xuko7s4OqSH4an+EgnK3XoYWBw++tM61D2IBhWeE3wZEtq8dCNfZLtYfVa7Y+zL A5Ww1zZMWcZ8ln8Z9lGHJPwq9QHkb+8K4dvS94znI4DQSQR1unUN6JN2a8WkOWeeW/wfVkq3 2R1CCadds8nA+hVQ/wCznGNE5WuvwPD0Xqw3iZEOa6/T9EJ+3GEgNMAXIuFlTeQ4nc/Ft/6L j2gqG/YuIbrQqAf6Hn6L3Rm0Kbh+IH9ElR4MgaKRdvn59MgwQQeRBBTS6Br6r6BGApOHia3z Eyo9fdrCvcAaLHHsE/RbrwYAwjUHR+nNe04vcPDOkMZl7R6Kixv2cUODnNPQz9EVUry8m54J Q8jivQh9l8gltU+cfRQK32cVxo8HyP6JbNis+vdOZUhaeruHihcNa48pM/JV1XdrEtJBoukc ohG6ELDuaT457i94tKYcW4HW027IrtmV7j4VS2vhKiupkah3mEbG0ihtBzZ6pWbQcDP6qM0L gwo7DacMe7Un1EpWYvmb+Sghn7unliOw2nt2jUm7pHAcuquNnbYrHwZpJ0vEDqIWZbKdSqua 6QSqmULbTDbFSiSNDz5jupx3/qgZcwI6A/MLG18S90ZjMfVDzKu423+A33cXRMdyT6eFXjd9 HsuHHtIsvJhUjREOJP74pzMPWqP2iOzCTbrHzV9R3z/MS0tIm2o9BdeC/ejxuPfyRfvZ4Ot1 VTMnubN/WOdDWjzn6BTae+VPiB6kfReBU8e4Xm6kt2q6OJ6jRV5A97bvZROlzyBn6KdR27Rd HjAPI6r59w23CDP1+atGbwMNzY/5TE+RTnKb3tmIadHD1+ifnHMeoXimE3qdBDXDsf8AZKd4 62odZVOUae1roXj1DfirSF58v91Op7/Psc3zP0VeQtPU1y87w+/zyY7aiFZN33I/Ewe/yCfk g02JCT4Y5D0CqMFvHTeJJA81IO26Q1d6An5J9oNJJwVP+kLvuLP6Qh0drUnmA8SpPxm/1D1C PQ0iVNk0zw+X6KK/d5nA+wVs14OhB7GU5PULSlbsADiElbYDXWIHf9hXa5LrD0zLt2SLiD0Q 6mxnR+Ez2WqXI6Biv4c4G7SgOw0OtK3iY6i06tB8gl0DGZeaR9EjRbE4Rn9I9Ez7hT/phHUM bTLuZj0RHMIvqtTW2Sx3RA/gg/q9kriTNuq8ISELRO2Q7gWn2USrs1zeB9JU6JVASnnCNOp9 1Jds1x0keSjOw9QahLRhijl4o1LEQbplSi/UhAh3I+hRoLI1xrZd97VYZ5ELqbjKRLluIaRe ya4g8VBTNEGmUqYzao9UNCqxU4qQysCEGsm0qbgJAQ6mz2cIHqoGeNET74VRCPoRxnsm/GKM wyEx9FPROY4lOLEoaRwTmFTYNg5epT2tR8gXGFNLYGREYV1k9jAkNhVkENPBTxlT2MCrStoY DxqCpNGrwKOWKK+jCVgSi+yhuYuFQhFaZU6BrWFFFSLJR0Q3sKejFLiUNz0yISAIB4qJ5emN pAopocipsBheUajWA1Q2pTQdwCjRiVcRNkylQJKYcDUPADzT6dKo3gPVHUJYpwhvYJQPvbuK Ix3NVIcFa1EaAhtISvNk1CGEJ4UOpUSMro0qCuCVrkhKc1qDPACBUcj/AAilNGUWBFBkowYC nigAnsaAs6AvuDT+4XGg0cEbOlDZQEQhBqvU2qxCGG5paNWVGOJtKE55FldfBtZQ34Makp6C CxxKssPUI4rqNEcAiOoo0B2YtSW1FVsbBR/iABP3E2LEOTlWDGFGbjRxK1x5tfaLE1co7cU3 mlOKatPNKnQG0XW8ljtpkSVpMbiRe6zmNaCsrlsaZXFu1CosQtFj6cA91msU6JRavCe0R6G4 pS6U1658q78J6Ae66jVT0spD1Hq8VO2qvcguCkPCiuKqJoLygO1R3FBJWkZ2oldV9VWNQKBU at8GeaNlTYTyE0rZikYT8Q7helbuP+Y9F5jQ1Xoe7lWzff1TD0/BH5jyVs1UuztIVw11leIe fFiSE8pYWTrCStTyEgCZOCcwBJCWmFURRQmvalATgqTYY0QmubdFhNhBGQhwjOEJjQmTgEKr oikIVQpUle8wVZUqQLA6b3Va8eJT6DpaB1WOVOrTCt0VpSp6KrwjldYRkwo+2GaT93so+JaA DPKVatpmFV427jJsAsLjds5Vb8YfVRjjRysm4lpAdFwD7KBUqQ396pbq0s4tsmbclJZXbHhM 9lR7QbDmgG2QEkcyTZQ/iAGQSnLRpqHYiE91Z2U3VDRx7hfUaJzsSTEdlczpaX1J0DQegRjW pwZYFljtEjnyngn/AMRESCTzWs5C6tGx1Im7AR6LsVQoOLcsscBFtD3CzjtpQf2Ev8RHE/qq 8g6rwYETIqeqNjKDyARUkjvcclnxi+vqkdjjP4j6p909Wic/ENpwLtkEmTr05KbSx1YAl8iG kN4gmNSso3ajhbOUc7bIEF5PYCE+xdV0zeCsym0lsOJN4BhXGx9sOFJzvxEGfEAbngse/bZE AQbaEKbh94MrYLNdcv1VzItVpqu3qeXPVoC9phpHZIK2BOGcalFoc/M1pgF0xYxy0WexG36b 25HMOXUoNbFUHQCSCLAXEeSrtC0scPsfAVAPD4tDFr+yStubgiCQ5zHaC/Hsq/D4RkktqEDv xRMTh3ufma8RAtPEcU/Q0bivs8bIyVyJFx162QX/AGf123ZWvwvKm4P4rqgDnaGSQeHL5K5p ipncXOJtDdbI6437ibbGTqbA2iwnK+Y4ST8wgintOY+Dm05FbUV6rAQHT3Eo+D285rsxizeX FPx4I7ZMB/GK7XEVMK6QSJDXCCFYYDbgc4NIfTdyJK1GK3ogg+EkkyIiB1lMO82HNzTbpGjZ +SjxYKmdQ/4mWtJLpAE3Nwh7J2+6oS5j5jUGysnY/B1BldTgniB84+qlYbZeAM5RkPEtlt1O Xxsb9KmegRvSWHxlonT9wjN3kY+AYmbQY+YSP3PwtWJquInmq3GfZhSGZ1Os8DhcWPkFlfi6 V5Ghwe36ZdBBEAydR5RqpTNq0TOveFgaO42J/C3Ei5jxTPS8I2M3Tx7H5GPa6ACHcD7LO/Hv 4VM43dCqx1w7qlpvBJIieOi84OA2oyQaYcOYj2UzZ5xjTnq0HtaNXQ6I0R/x8h2jd/d2OM5R 5CEB27GHqHxU2+YlYjFbyVGVDla8t4EAwe9kf/HbmxOYG2oH1UZcOUP01OI3FwrhHw2+Qj3V HjPszw5Ph8NgLH3EoVP7QwTd4A5ED6BWH+NKbhOZvkVHiy/Qqjr/AGVgfgqntYqK37M639fq JW2wu81M6/qrfD7epFouicf7Tp5ZU+y7Ej8Lg49bKoxG6OKZrSnXTgvcP4xRJs6/kpGHxVNz otMSneIR87YjYOIGtFw+R9FGfsyq0XpPHLwuHpa6+j8dTZqA0+6ltosc0AhpsOAMWU+JT5ai 5BBB5EGfRcBz8l9JYrdzDVDLqTSezf0VNiNwMI7/AKTRyhT10Tx7Z+zKbm5nG/kPRQsdSGY5 QvY632Z0HfhOXtKqsT9kQIJbVIPUmB5Ky28lDE8OtC32I+yvENmHh0cNLcxzVTU3AxbT+EG3 Ak/RTuntl2tCUuI4q6r7p4xgk0DHqfQKvfsusPxUank1x+iWz2hOrFPbiniDJtw4JCzoR3BT CAOaez2m1NqucIOi779EZVChcWJ9gsf4qRcEyifxZ7tXDt/sqh7U1piU+4XtHbdVgIa6x5zb srHC7yvFiT66+gWUFUovxyn3NrKe87mPBExrwHyU12973a5gehEfJYoYy10n30jRHcPQsHvS RcG/ofVWOH39eDBLu8ryt2JJCSjinNNlXc3sg+0B+mveP0Vvgd9Q4w4Dz4leIMxrpBkqc3a7 p1TmdD3F+9tIa/P+yJR3qou4x5yvCsTtVxM5jCazbjwLOV+QafQlLbNF2j1MbWadHD1C8Cwe 8Lhx7zBn2U5u9Lho4+tvkq8hae5Arl47ht86jR+L9+QVlhPtAqRcg9+XmE/KNPUFy89o7/lz hJA9P0VyzfNlpE+v6J+SDTUrlQ0t66J1t7/OFKbvFQP547hV2haWiQtB1CiM2tROlQKSyu06 OB7EJ7g074Tf6R6BIcOz+kegRFyPRAuwjCIyhRnbHpngp65GoNKY7BE2Nk12wev79FdrkuoU NLYEG8e5Ta+xYuBPZaBcl0DIHDOBjKUotqD6Fa5IWg6gI6hlaboKltpq8OHb/SPQLjh28vSy OpKcNakFNo0Vq7BNPNAOyxwcfQJdS0gvKY5oOqsDs3/N7Ibtlng5T0TZUA0kwqybgCNRKE7A HlZHQvauBRWVDzU1uz+YKR2zx1R1OVGLzzQ/jHiVIdhTwKE2he4S0sP4so4JR6eGbGkJjqJ8 kgRuJ6Inxwmtw4Oqa7C8kaBxg6IjWBRfgEcE8NcOiWgNUbCa2qgvqFI16NBKCkUqqi03okI0 acK4Q6lVRyUmdGgc54PBMcVwSOCegaKiMo/FEpsS0crnNSMooxaEobCelyhPowgklSM907LK Oqkf4rk8PKdUpwozyjqaU10pTTKHhnDmjPcouBmCmitMKODJhS24cRdR1LaFWrFcyoeaXEUE CYRo09ibUA5qP8YxCHkJTCW14SuqoDKJTa7oCWgcbpXMEKufjCFFrbROiKSdUcgZyoTcap9G uIUFTDWco9XGEcYUsuVbjWgp6LSNiMd1+qh1MWSuqUtVCxFk5CqFtHFXyjT6wsxiat1Z4ytr 5qlfJ4WTqsDM6UlCIunSsMndg52ihVVKcVEqlJoh1HKJUJUl7VEqFXizzoLnITk5xTCVrGNo VRQa2qnOUKqFtgVRSmFOXLZmdR+q3u7rrN8/RYKkVtd36lh2n2KCerYA/RXTNAs/sx1h5K8a bK8SrEZbooYntauhZu2huoofwlKalfS4ppqM1qWE8hcAmkMBOC4hJKey0cFxFkwuSEo2WjSV wC7VIjZWCAKPWCO1MqIpaVtTVTcOLCFFey6mYEWPqs7DsWeEYr/As0VNgKevdaPZ9E+kJacn LdJZaVR7QEB5PI+y0+JoWMLObQFy09QpsYYVmMhmZsbp7NnveDwbBPMkDiAkZSJdEwBJPlwC tqrnUsht4mGOxEEehWVxbyqH4TQ1xcPylom2vEKE/AtaGkOF+EdFf/D+IwssMzm+I/kHFAGA b8XKS1zWtdcXBI0UmqKeGJ0CG3w6zPJWDaD2uLrZdTB0HZcyg17xmcQNZEE+/BAV+Nw8DkZn 1S06FgOfRGqtzVCSeMKZQwpJMH8PMxZXAra2HAiPVRcThXc+OXzV5WwgAkTf0SV3jIWxMkO8 /wBlUFSzCw0giXWg3t1TquHLW5rGBeNVP+6Hw8y0+UE/RK3BPJygCXWBNh68EwrsLhnPvF4J g2sErW6GRBnuCOamNPgg6gxbpM35WKjYUAmNBc9ucJgyrcT5KP8AHOk359Ve1GMAaAZaReYs 6VDq4EahMkSk6LnhfuifGc+HmxJKR+sAQBw5o1MEwP3dA0R+J4T0XUp5/wB0WvSAc0ECxv1C MaTJ/DlnvHkqlpaJQxDmy7MQQF1LeCpxcZ0vcFJiaep4QB3/AHZRDSaYEfSOqO1TcVxht4Kx mYMXPZOZvC7iweyrsHhwHZblrjB9VNxuzgaogwDDDxykTc+yO9LqMdqU3HxU556IwxeG1yR1 gRZV209hVKckVGOAAceBAJ5KHVw9RrLiW2vqBPVOchdWlbUovJc10dtPILvgg/hqmeyojgah bMtyAF1jcgCTCDhKYy5yfFNlflLq07aBn/m+6M74wECoI7m6xteuQZa4gze/FHpYmofznkO6 flLq2ezqtdry4mQGwAeJSfxOqCZzfp0CzlXG1abg1r3GQNefFP8A4xU0gSNSjyDo0mF3iqse CSSOo0Vk/fs5fwC5gyDGWNCsX/F6jfxNHolG2zxYIR5S6NTQ3ppn/pg9gP0XYjbmGeYqUgDp MA26rPUdsU/6B7BEdiqL5c5vcn6qpyjo01PC4B4h1Nt9DYe6jYjdDAugttygxH6rNvqU3Tld 6SimXAQ+COfEJ+Sfouq6G5+HkAVHX5P+il1dwYvTruA4CdFljTqhwOcaa2spJ2jiRo/6o7Y3 8Hqrhm5OKnwVxbmCUKnsXaDHESx3fgOirKG8uIYSTOkD/Yq0O89YgEgg9YMpXqfstVuNBg0o 7TfsmjaOMbZ1N47TomO3urD8pPkEahvkQfG0R+9VNmNLtSjeWuzVr/8Ay/2UzCb7k6jv/tlT sNvdSqFzXNb6f2Qqu08LJ/lt9B8oWWXDKfkWNHfRs6D9+Sns3xoxeQo1DFYJzLtaJ6Qg1Nk4 F5tA6Awl/wAf9U/Isae89JyNT23RdqY8vrCrTuzh8pLXEeYso9LdRp/6p84PuErwUu0aZuMp OgSL6BP+DT5D0WarbnVBBZVEj+qR7hCq7LxTNYPUEkfRLw1W4v6+wqD9abY42Cr6+42FfrSb 6AKua7FCMoM9CI91NbtfFMHjpmOgDvkFneKz8HLEWp9mmDdMsjtA+iq8T9kdAghrnDkZ0V6N 6njWmfQ/oiDfFvFvz+cKen+lemKd9j5/8Ux019FW4v7KazTDKto/M0uPsvVmby0SiDblEn8S LxwtPE8V9nOMZo0PHMCJ7AlVz9zMYP8AoP8AZfRTMZTd+YIgLDy9kvFL+TfMWI2LXZOek9sa 2n3ChOZAv7gr6rfh2EQWg9wCodbYVB2tJvoEeG/sPmBtQD/YhPDuS+lv8M4X/wAFh7tafoqT aH2bYOoZawN7WHoEeKm8Bc7ula9ezYj7H8OfwOLT6/MKDU+xocK7vQfJT0y/QeUl1tUML0fE fZDXF2VWnoWmfayp8R9m+NYYyNPWSPoi9p9wbZWnUjmnivdW1fc/Gt/6Dj1FwoGI2LiGfiov HH8Lj9Eux7Mdi7CE0451+R53QHtP5gR3aR80zOOafYbS6WPeOJjlYKbR2o7mqkEc06IR3C8G 0+q7+MP5/JUaVyczDSYfeIgQ7n0+SsKG+Bbo70sPksRCWFXcPSR9oB/r9CPrCl0PtHdP4j5y J+a8slEBT7h7Rh/tAJ1+X9lLbv8Aji0f+peIsqxon/fDw1905yE96wW/FB9neHqrMbw0P64X zwzEu1zH99EUbVePzfRV5aH0TT2vROjwpDMSw6OafML54obeeDc+8e4Vgd6SIgmekkeqryh7 4CuXhVHfeo3ip9H7Rav9Z9f7JzlD2ZcvLMP9odXmD5T7wrLDfaIZ8Qaek+9gr8kGnoK5ZKnv 0w/k9/7KS3fSjxBHmCnM4NNIuVTh95KD7h3qFIbtiif+oPdPtC0nLkCnjWO0eCjB06I3Boq6 Fy5P0NEyjkkLByTlyNQaDOHbySOw7SirkusCP9zb1Sfc+qkrkdS0jnDcihPwpKmrkdRpUuwD uU+aX7i7l7q1XI6jSsbs8o7MABxUxcl1NW4iidAoQpOm8q/SFgOoR1CsbTACXKrD4TeSQ0Aj qFYWmUQAqcMMOaU0AjqFU8rgSrP7qFxwo5pdTlQmtTwUY4P/ADLhg+qOqtgOumjCqcMOE9jI T6jsh08AEX7mOakwuT6jsjDCgcyjZU9clcC7IdUjioddw4K3c0HUJnwG8gpvGrspg1EFWFa/ AbyQn4Fp5o8Z9kA4pRK1WVcDZrORPcp/3FnBoCPGO7L1WSoNbBu7LZfw1nX2/RIdmN6+ynxD swZaQVJoVrrTYvY/IAj3VS/ZDwSQ0+ajLio2Q1hCjilmKc6g4ahPorPpYEathhCpMbR4LR4h U2NRomUr0gCZvdVuKeNArjHNVJWbdKrxV7zdNBTqgSBY12cf0YVFrqa/RQavFJqg1XKE96lV FDqFaRjmEkIXFdCuMg3BQainVAoNcQtcAjOTCnkpFvGbqYWr3dfp0EfMrKgLSbt6+c+x/sgP Wtj1JA6ytA02WW2HV8I9j3WnY6wVYprMwmnojEJmRQ7SAIgclYYTU00x7UMhSISOYgkctTHN RQkegkeEhKemPQeiwmpZSFMWHym1G2lcucUI0gO1UzCH9F3wBBJmYMd0mHUmv8GJIjotZgKU A8ys3stsR2JWtwzZa09Ak8/nOxDjl72WTx7SC/mDPktZX4LO7Upg5+sgLO1lgyFWpDieZ9lb 0Htc3NNwA0DgPJRHUWxf/ZOwjRBAPXuUVts58tBE6/VCwWHGc5jLG3IFi62iPWpOJy20uf0R ceGtylkACkxhAsXkEy48+6zo2i4wNyxTkNcMpnUAm4VPWZDsvAAK7xlDIGOzNOfxBrfyjqVX voy8g/0g+6lSLh6EuaPZWFbBZfFMSLRx6GUXA0G03F+YWaRB4yCPqq/Etc05Xd2mZF+RVQGu qumNU6lVN4BPOBMQh4ikQYm8A9pUtuK8OQaGJ620VjZTiS/K2QPyybRKWi158AIkvFybN6qO SzMCRabjmlpkFxLbEkkduATBlVpa4iZN2yLaiD80/D4MNdz8Lh2kaobaJzDNxMTy6lI6u5pi Sdetkwa63h15I7XQECi4lwgX4K0r0aIawDMHHxOkggf6YVGhxJ11sjMwVRnig97ac4QajWzZ 0xqpmLx5Ay3ggeQQSPVLXGXXPP6qwZjRkayAYEEnnzCqWi08ApQqQARxn0TArHCKjTcFpjuB wULA0cwji494HVSJJObQQQP7ImEqBp0M8R05oTU/B0abQ4QDBHrFzfyTH4Z4qZSGkxn1sQRI +SBTqtzSDH7905lUuqFxPIf9o0Roqdths5HREtyujQ91AqUX/DMfmcwdABrb0UvFV/ERq1CD yWuMxAgD6qCVjnOaCGmJse2hhNbTzANHZHY2XEnkj0MNqRyMoAGDpBuYOFzzAItpCLh8ODDi cpnMBoNdQjigMpLueutk+tTDy1ptlENI4idCkD69FzajXVIygZvDcmbqJWpt+ISwy05Seki4 hWVakPhF0yQHADhpCqKgJaCLFo7SOqYExtQgGLgkDtyCtcDTaYpua2BfuI5qrOHe1gLh4XEO nkRpKssJJEu/NYdQFUh7Cq7PZDoEG/kq92BcGyL8+oVvXLmtLeZBvyHI+aBVBED/ALkUbVZp lrQYsVH+Gc34j0Vniwfh25m3dSsDso5QXNzFwEGQMp5Qp9jcU7nvGrj87J+Hrl2aSTYxHRWO J2YIuCHAkdLG4ITcM0Upy3B0nVqPY3FdTxzj14Ke3H1IAgaSpDoA0ub8LqM5jmmS0+h06c09 0ekVu2XA3HyUqntpjrOYP35KJi6LC4EA68j7qwGDoO1bBiDltdVLRqC4fF0SDYW4aJ7MRQJ/ YVKcKWutp15KVhqIa4WB4q+yOq3LqRMZ4806jQbmkPnoSSqSphS57nCwJS1cO5tjM8DePVPy Dq0ppOAOWp5SVI+K+LuPkVjKnxhNj3vC5m0agH4iI7fUI8kLq3+D23VY/UkToeSJjN7arzkD IvMjj0Xnrds1QZm3b6wjv26+RYTrxsjyQXCtw3b1RsZmmOYEqTS32BgFutv3ayxLd7SDBbMC 5gRKYN4GPdJZB4wI+iPJEeOvQTvJROoHz+YUluOwxF8no1edP2lRPTySMxdMxB9U5nD8dejO weEeLQO1vkolbYdD8ryOxn5rH0C0kw+PVOq4hzdH++qreNHWxsKO7ANxVcD5If8Ah/EA2rT6 n6LOYXeKq0242F+Cmu3jrAg6jiLH6JdMKW8o0NOnjGaeIIp2jiW/iYfQKnpb4OGrf36Io32H FtuyPDiryWJ1XeOq0wabvREw+9f9bSPUfRV3+MaZN2+39lZ4TbeHqENtJ5gfUKb8efijy38x KZvRS6/vuplPbNIj8SifwzDOv8Nh/fJV+I3ew7rtOU/5Xfqp8Oc+qrzT9NAzaVM6PCOys12h BWUwm7DQf+a+Ohj6JlfYdZh/l1ZHXXzRcM4qcmNa/wCGOQTH4Vh1aPQLHCnjWnQHsdfYJ1La eMab0XHt/sp638xW40dXYNB34qbT5BVlfcPBOuaI8rJjd6XNtUpPDv8ASR/uns3xpzDgR6/o oyxx/MNFd9muAP8A0veFS4n7IsPJyFwHLMTHqthS3kon80KS3bNI6OUdeMPN8R9kA/6dUj/V ePIKoxP2TYn8r2u7y1ez08ax2jgjB4OhROLHL6oeDVfsvx7RORjv9LwT6Krr7m41hvhn9xBC +jlyL8efsPmCrsmu27qFTl+FyjupkatcP+136L6iOGZ/Q30CG7Z1I602/wDlCn/j39h8tufy P0SNK+k6+6ODfd1Bh7tB9FXY/wCzrBVBakGnm0QpvDnA8CJPFCLV7S77IsPwqPH0VXi/sdgH 4VY9AfrZTcM5+A8rAK6CvQKn2UYkaPafIqDW+zTGtOjSOkpf2n4DIMcntcrnEbl4xmtEnsq+ rsqs3Wk8f9pPyR2oDGKISjGO4W81xwtQascO4IUcDv6FV3CZ/FXhd/FXqHITcso8hrFu13DU mO6Mzbbxo7yKqXMTgIT7k0mH3pqN4+5EegVgzfJ/MzzkfIhYohIHFHY3o1Hf6q0fj9TCsMJ9 oNQ6ukdwZ9l5XmRGVep91UzD2nC7/SYMH99FZ0t9aR/E2P32Xg4xMFGG0TwVeSh76ze2gdSR 5KZS29QdpUHnK+eaeNM6qQzbDxx9P1VeWjT6FZtKkdHt9UcVm/1D1C+em7wu5nzP9lMw+89Q G5jzJ9k5yjT3xcvFKO+dRujvePZTaG/1QavPqT8gq8o09eXLzajv+/i4ex+YVjR385iev+yq ckLTcLllae/FLi0/vyUpm+GHPE/NV2g00C5VLN5MOfzx3Uhm16J0f7H9EdoNJy5BbimHRw9Y RQ8HQhPY0VcuXJk5cuXINy5cuQHLly5AcuXLkBy5cuQHLly5AcuXLkBy5cuQHLly5AcuK5cm AKuCY7UKuxGyLHL5K4XJdYNsbi8ORw7qnxVAr0Svhw4XF1ndo7PibKLgqPPNoYeFnq1OCttt bDQJHCVksY2/ssMsFxU1GiUIC6PVKYFzZTTs4r6Me1QaxVkWqHVapbKeuFEqBWGIZdQaoVSs skYhLCdlXQtIxoLmqNVZKnFqjVWrTEKxzUgCNVbdMaxbSpsI1iutjOyu7lVgpq12cy4jmhL0 7Yj7R2jrb+y1YKx2wXWB5QtY0WV4pqqLEhCNlTcqTtMhMRsq7IhIK6ERwTCEEG5qC4KSQo7w gBlBKkEITgkoIJ0rnNTAUbBVy5102UbTospaIuE1rJ48CiU2RHdTsq0Wz9AOkLW7PfLOyx+z 7uWu2afCe6dedz/Y1QTfhdZ7abob1+pWhe9ZzaZ4DXVcty9ssWVxNLxubOjp8ot80bDMDbFJ i6MVBzLZ7oQe4eIi2aOi03tqt6bWuYXOJbB0icwGkKD92c9jX8XWA0jVHoA1DmNmwRyvCj1S 5pibC45JGjsaM3jJgWtqEoeM06jTyCbVxLXa2Nz3QnuDYaNbT5qKYtTxXi3BLUq5g1rogacP dCD5cGgkCfEYmB06oFd4NhwzDqb6qpQHXMuP77IoABBvwRMBh8xOZ0eGfddi8MGaODgY8pn9 FewbhsI9xe4AZWQSXGBBdEAcbkJaOL1Gmp0A9+Sc6vlb8NrjD7uE2JniFGr1JBGh0np+4RsJ AqeEnt7z+iDTLi8ZfxGw7dSUL44DYFz+il7NwpeHEEgjtAlVKYFEnP1ko1WtJM8z5JjZzRFx LSi1sJ4Zgz9ZVAEVQ0QDr2SGrm4/rC02xdjUhSzOyvcb3gx0AR2bMpxLqbZv+UBBbZQOh2Xg LT/UOBTXVpcGjQAjsZV9jNjUM4/ECRPhdACg4Xd1zqhvFMepvoXaSkW1e2qeBsFIZXIIdxU6 ruq8POQ/yyREulw5jQKLjtmvouDHwbZpBmR3VQbSafwj+ORMmRqDFo81XhxGpSu0ngm5uiZU Nz5IkmJBUtzweFlCzDTj1U2mznrEqNJOxjWFgyzmHqnYRx0bqQZlRzJMhSm1gKmZo4aHndIG vxEsIFp+iJRplzc3ca8kOALQDaTcx2QKVQDjYpGsKdZppgEkEH3lFrUKTmtdJ+JmHYsHTmoH xm6a+RT3YhthEcidVcgW2LqE06bWtESZI4gyYPmUtd7czLxlAtwmOCimpdhBtYkdVOGzg9j3 SAZ8PeJKog6DAQ6S0tmxPDzUXEXdAM2tHDomHBuAIbJtmPGwudNYS4Vnjb2mVNLYjcKJg68j xVwGA0y4W5cpVNiwZibqdQxBFOOAvB4qS2jmS4GxgXvqVExWHIBMeSX4hCJUqSAOxKcLafRw uUQQHaeSJ8LN4XMsI6R2TMPj8zhLeU8FPxuOIe3SHECRwvoVR7Axuxg0h7Wy35HnCDSpNzZs oB6ad4VvW2lTbLbGxA4yCNCqqm+W2NroG0fF7LY45iIJv4bD0StwzGjSRxm58iimtIA5Jwrg EaaTcSlae0LI0cI4pHGRGv0VkyrTc8FwBjskqYRg/CIkmEi2h4TAucSCYbwi/uhYvZuWQXgi CbgSrBgyGEz4Je6df0SPamII8MTaExmzs1wQDyPFX1Wm2Ii/a6rxhXcPZPR7Z3GbLc12libx cAp1HZ9tYJ5q9xdA2BkoDtmPNgwg8DYeso0e1I7Cy2+skdExrIVu2mQ2HC83npxRjQYQPAD1 /VLRqqjScR+KAhVA5t5JCvMdTZPgGUxccJ4QolLBlwRdhUPrP1B+aL/FKzNZjnchWVXZ7ogR PeFH+5VDbLbnZLdHp1LeJ/ECe0Irtvc2KONmvcJyG3GJiOydQwBcLxEcVU5Mi6xKp7QYQCf9 lLp4ukYMqlOzzzM+qjuwxaYgq5zWF0jbs2lYAVY4KRSa+JbUv3KwcJW16rfwu+sLSc8/Sbxt 5T2riGn8U9E87w1xqD7LDO2nVbq5PbvG8cJ8/wCyqc2NLx1vMNvVUB8Tbdf7LQbJ3oY8w6x+ Xey8tw+8RcYLQpbNqiZLYPQqu+NPrY9d/jVHTOPdBxFXDvFw0+Q+a8u/irDxTvvbTo+PPVE0 PbcYnB4Zw0A7WVfT3apPcAHuE8Zn2Ky+Z3Cp7qRhcTVaZD/33Tsxv4Etbn/BtMNAbVqhw4yI P/bCrauysVRJyVM/qLddU3CbwV8sZhPOAfdK7bdSZcZ8lnOPE7nZ9HF20ss5QR0IBUR23sbT E1KLoH71VtR3oaBDte0JTvLSOv79keLGp8uX6VNLfsj8TSOh/QhTKW/tMi/6IFfH4Z7pIae4 Bv6KzoUMJUZ4mUyJjQa9ws7wX8VU5f3HUt9KR1IVjR3iou/Mq6tuhg3aUwP9LlDfuHQ/KXAx rmNvKFPi5J+VeTFpW7WpH8wUhuLYdHfvzWGrbhVB/wAvEEd7oTN08a3Su3vcfRHXkh98XoYd 1SrzuoNo0tW/EHMO9zKJh94sc3XDPIHIF3pCqb/MOWX6b8pj6DTq0HuAsSzft4/HRc2NZa4e 8KTT+0Kl+YQn1g209TZ9J2rAfIKFV3Ywzpmky/8AlafoodDfTDu4wrBu36B0ePdK4Y/o1TW+ z7BO1pAdoH0VfV+yjAky0Pb2ctVT2xRNg8KU3EsOjh6qPDhTedYj7H6JnJVc3lN1RY37KcQ0 +F4dyt84Xs4XJ+HAng1X7OMW3gD2B/8AxUGtuRjGz/Lzex94X0QkSvDj+CfMtbYeIb+Ki8cL Nn5KM/CVBrSqD/sd+i+oDSafyj0CE7A0zqweizvBfwb5cd5+YKUAcV9KYndrDPnNSZ6BVVX7 P8IdKbW9Q0Sp8ORvBQkcV7ZU+yvCHSQgO+yTCn87x2hLxZDbxkJcy9Rxf2PD/pVz/wBwBhV1 b7IMSB4azHHkRE+fBK45QMCKibn7rS4z7P8AHUo/lh3+lwPoq6puvjG3OHdHcKd6NBbiyNE/ 76Qu/g2I/wDAqf8Ald+iDWwVZv46Tm9wbd05QknaLo1ITqe03/1H1j5KsLua4FV2C8btVw0J nuR8kentx41J9Sfms7mXByfY2uobzOHGPM/RWmG3tePzD1+kLz7MkNYz1TmQeos30f8A1kdi P0U6jvzUH5pHM/7LyL7yeJKIzGnmeiruHs1Hfs2kg+QVlQ31adQPIrwpuOM6qTT2qQNU5yDT 3qnvXSOtvdEG9FA2k+hXgo20/n9UZm2nACTf0VeQ+se9jb1LmfRFZtekdD7FeFUdvGRPteVc Ud4iGwXA+X6J9y6x7IzGsOjgjAryCjvJx9wf7KfS3tP9Xv8A2T7n0eorl5yze8jR3z/RT6W+ fM36g39gn3hdK265ZAb4/v8AYRmb3t4x7hOZweOtSuWeZvZTUhm8lI8R6p9i6VcrlCp7WpH8 wUplUHQhPZap65cuQTly5cgnLly5M3IdWkHCCiJEjYfbmFADh7cl57tCjr5lembdEguHn7rz 7arNeSnKNIzNRI1qdWfcpWFcnJHTxEqCyh1lYO0USoxYOlVVac+6g1WK1rU4UV9NEZ5IBCGW KY6mguF1pGFRyo9RtlKeozwrgQX05XBiM5q4rWFTA1TMK66iFydSfcd/ZUh6Tu/U08lsmVLa rz3d6pfX/YrdMqWFlcTS5V0I2Vd8NN17AyJQLIuVDhBBuYh5QpWWyCQkAnNQixSS1Cc1AALU FzFJc1CIU00Z4Q8qk1WqO4QlswiUhXHVLnS2NFD0YDRR2m6mOfICIirfZrocO61uzT4fMrH7 NPiatnsltinyXUed8j7EJVXjWDODGrfkSrp9K1upVRizOWOEriuW2OLKVWTVAP4QQfLiFBfW LgRwzmOwNlZbQpZYj8Tmk21mYhVOcg5C2Dx6HqtMW0WdFzQxt+EkdUj3B7crdRpwtxuoYokX iZmEfCvzEANjqqBlOm3K4PiQPCREzwvxQKuGdZ51MD0HJGxdINcM3AygVsUXOJi2gUUz/vZD SzKCJmTYgoQxDGse0iXOu0x+E9040y5rnSABe+vkotRocf8AS3+91O1B5/CI14ppJypaJBEl OrU+SqUBGnDQ68k27IT3GTzKeHmQ2bC3TVDxAhxHl36hPYOw9PM4Am0iVZ1cdkEMADvw2tIB mTzKrKae5t2Aak+WsJyh1HEvzOMmSZ81Op1yNTqbhAILCWQJBN/7pWiTHHVaShO+9OERYaCF PxG2HtgOBkgFUbh4STNiOJj0Ud9cudeTFhronaWl7Q2jnzOcROWBEJMNtMtYGc+J69VQ1ncI 6otBkCdESlprcNtN4ImIHoYS7bqCu0PY2HMkuA1LT/SqCjiHacvlzU6hjAI1nmFoR+D2cwua Xs8A8RBtmhXP36hlLfhDp0jgLKsdtIdZXYZ0umNTATJJbUoOImiP30RHbHo1AajJbAMg6GP6 YTJaQAHN1PdPc21ne6ekqyvsxuXOx0CLg39ELDbKs50gngBKvBsvM0SSANdFCZQqU5PC8W4c FPUIGFwHxHGbBvDn0UbaDWh8MaGgWMDirY5m6yCZPKVV126k66o6qiFcC6Wmyblc+TE6I2GY DIMx0TkMXDVIDp7joVP+9Q0QVDpVGtEEKQynTLZm8ExxTTQzinDQkdbaJtKtlPX6Jjb2UqtQ bxJFonr2SsIwvk+UrqdYOe1pJAmCVHpVL3T8/iU9UiV6kPcAZaDY9FzMUJumfdSXiJgxPTqk xGDLHiAS297e6NBLZiW+am1sYx7BIGaZt0Va2kWicpM+aaWi5g2EnUeyAmNeJk6e6AcZE8J+ SgPxkkDTunVXBzgEGm/ezI9Sm1MR4pmyHVplovHJR8shKkucMG5S4GST6KxGKAa1rhcXlZvA VDmA6wrfEOzWGqRJYqF0w2RwKHTxOUnmojMU5nhKRjsxMpw1kcVMSEdlcSBEFVrTBtdGdVEw RCZpVQjiOMcE9lRmXW891FqYgxA9wptD4eSXgAgcALeyAQ7PY4ZoBnnZAfsmmctoveEYVJgj Q6RZHw2HzPaw1A0E8bk9AkqAjZNFzjmB0gHl+qAzYpp3a7MOuqmbVw1Sg8guDqb/AMJGojge qiYSq8u6dEUVDxWBzmdHD3QWscLRNj8lZGoM0lDfTGayRbRNl0XtacwIE8Ux1IAum+vy5K1w 9W8EeqJi6NJ+nhcgrVFhcLLp/fdWDtntc0kC4k91Lw+HyCAn/HIkEJ6Lsw+Mw7c1tR0UjB4H NxEcVeupDMTAv0CkYLAuY6YGU8ot1IRo+7OfwNzzFMZjPkD34KDWoQS17IcLGQtxWplrw6mO eYcD17qjxuZ78zhew04dVOj7sx9yIIPDhY+5hPFF03Fua2b8K1zCDY8P7quOz3AcwjR9lG/C lHfs+Wi9+l1cHZpdAnz0joifwgga/vujdHZnmsIsbI2d4FirluBAuQD3ufJEOCadAn2yLcUN Pa9Rp5j0hS/43UAT8RhA10EJfuoI6J9qfpG/xCeLT7ItDbbHG4jqVDxOzctxMT+wgNwZA0/f ZOZ2DrF58ek7iJ81MpERZ0eay5wTuDT3hLRpObdazmLq142k9otUJ9P90altyqDYysZWqv5l Dbj3p+VPR6UzeaqBcfvspFLe7+oLzYbacPy+5T27bP8ASn3Lo9MG9LTwt2Wgwu06bx4XDTQ2 Xj1HbzRqL9LI7NvMnUjsUdorGWPWcTUpEeLKe8FUlfZmEefFTaesLF09pg/nP76qXSxMkQ4p 7hXbWs3PwZ/6QPYm3oVCxm4VAj+W57POVXUMY9ujz2kpXbYqjiUek7yO/wDh+eGJcP8AtlCO 5uMa4ZMQHDm4FvsplLeCqOZ9FNw28xH4mpaipnl+VednbTpyQWPHRxB9CFHftjHs/FRcY1gj 10WvZt+kdTCf/GKX9XyS6tO7GUt/KrbPpPHdpPyU+n9olPi35rVtq0nf0nuB9Ux2yMO45jSp k/6WpdT3tQUd/qDuPzUunvfROjh7q1q7JoOs6jTPC7GGPZUWO3FwrgS1uQ8cpI9kumV/It0t WbfpHiplHHMdo4LDf/D2PwVn8dYMIT9zsbT/AOVVDuNyAjrlBMnogeOY9QnQvOG4Dag/ID2c z5FGG09o0h4sO+OJBafkmp6DC6F5vW37qtEupvHdse8KMz7QTqZHmpt/0HqJCY6k06gLB4bf 5h1d6/pCt6W+lI8Qp+/wbS/CHIeyj1tmUnfiYPRQqO8NM8QptPalM8fl9FXSfolNjNx8LUma bb9Aqur9luEPA+Rj5LatrtP5gnZhzCXig288q/ZHhvyuc3sT81CrfY4w/hrOHcz9F6jI5roS 8UPbxyt9jtYHw12HuHD6qsxf2UY1twWu7Fe7QuS8UG3zjitxscz/AKJIvcXVXV2PiGmDQqf+ Un5L6iITHUwdQCl4j2+WXUHNPia4HkWkIRMHT6fNfUdXZlJ34qbT5BVuL3PwtTWk0dgB7peI bfNshOaeq99rfZpgj+QA+igu+yfCkzJ7CE5x0dnifxCNE5uLI7/NevV/sdoH8LyPf2hRj9jT P/HM/wCn9IT8Q7PLBieSkNxx4ytvjfshrt/BUa4eYPoVQYjcLGMJ8GaE/DVTJU/xB3D9Udm0 Y1/fmmVtjYllnUXeQP6KK6m8WyOnsVNwsPutm7WdzHoErNrEaFUrg4atITPiFLrT7tCNqu/q Uijtczqsy2uUdlfqj2fZr6O2Xc/orOjvA4cT7wsGK5Rm4yE/Z9no+H3vqDR1v3zVzhN9wfxD 019F5GdodSiN2lm1P0TmVK6r3PDbyUX/AJoPVWdPENdo4HsV4CNqRxPqUanvJUbcO7XNlcyL pK98XLw6lvxWH5rKY37Qag4/v0VdoXi/29kLgNVAxe1WNFiCfkvJqu/zjqT8/oqbGb5Odx5R HHueCXY/Hpv9r7XbeDbVYbaeOBBVFit4HGRaORM/IBVdbaWbUqbRpYVq4lPoVgbKidjE0bQ7 +uqwzm23HdNQagUZ7lTDaJj9U04/rCy6t+8WNYqNUUI41BqYzkn1TllEh6juegVMVKjvxCfV lakudzUZxQn4hBdU5KpiWzy5DfUQy9MLlrE2nhycCEIFOa+FSW23e4evoFv8PV8I7LzfYFa7 eX6r0DCVxkb5/NOFVyGzqnkJ0LiFTpBc1NyI7mJMiAAQm5E9wTm6IAD0LKpEJpakEVzEEtUx wQXMSNDqBBe1SHtQSoqohvQyFIeEF7VJua5TGAwoDNQrQNgJ4oyT9nfiB6LcbLbZYfZo8TVv thQOE810ZcffF5vyPsWobHsVU42lA629FpMRhGDnJNr2Cq8bgHBrqhgjRo48lw5fHyxc+NYn GeGrJvlkDsTNlU4hrXVCW3LrnmOiutrUH5iC0gkSeg5rO03OpuBg/M+icxs/DaXafSfYNNgA b8edkFtUhrjMadz1StY4uLnam8cvJQ2fiM6ShY4rZi0OE3iSkfSIcQW8bciEgoWBJ1Mj1hWm duUtImNCR7hTTVQANQg2bF+ScGMAqGR4hAjmAn1YGnmgYlpNNgaPCx2Y+YIv6rM0BjfCWzeZ U44WKOckl05Ty0JkehUXDtDn3swQTwnsj4vFS59Jl2y4N7XAPeE4Fa6xMJlUOBGYQYkTxbzC n/DAtFxrKBia5e/MeAy+QTMJlRGfV0Okad0BgzEn0XF/Ao2C/FvPmepU+lABceQAULJmsNTZ Hx1IMbSAcS7xZ7zBmxA4K8aDqj5GqEwQgNfdGabrSUkhjOk2PyQ2HgeQTmk8ERjmyJGnLimY lKuRaTBsuc/kmQDoVxadBrKuFpKbjrRAtZOwtZw0J7fog7R/KA0DKAS4cZ4H0TcKefIj1Cad Jhqw42uNQeac0FpY50EOdMTe3NQC8zfWAD5JXYgmOghOUuq0rYwycpsept0TjiHNjxm/CZVT nGXqlpXI8lcHVrDtCm9jRVbLhadC3qFD2zgWMZ4XZgYM6FvQ+yqKlSTdIyvmBaSYMIExOxFA CkHAyS4COl7+ybQcG3PFAxTxmgGw9+hXVqhIA4AQP7oVo57Y+aeSXQIvwQQ5SGDxeEzaba6I TYl0KEQeK44cud+JDOJMGdU6nUIIKSKMzCMm8zonDChpkCQi1yWhpOh5cOhRqd3NaDry7cUJ DdUjjdFrlwALSe31UGphnh7mkHM10Rx9E99R4e0OBBEWNpCNEm4XFm8j/dSH12kyQJFrgacl FwWHFRz4dlsTB4HlKj0pJgg2MFKw1nRw1F7hnpC55WPooe1tjUmOLqTrEyGngOIBVhQxzW1G logNabcJhVNaqXOnqoCuqMzEnqkow03/AN1NoUS9x6e6dWe0sy5b5swI1bHCUiRdnUBmzSbO kBS8QyTZR6ThJPspj3giW2NkaCP8Jx4wRwKJTxLmnxAf2T21OeqOMIHC5VyA81mggx6XQX1g ZlNxWzyAC13cfooWIfLBzn5WQoetXNoNlIdjCWweIhVVSpCmUKrXNg6qKD24kgQDZMO0HhzT Ohn0THU0pozHBIxa+Pe4X0JmOSn4LHkNmFW1qTm/qi4YSIlAS2bQvDgBJ1hdUdBlQaswQbkI Qx5yXvwSJbMrjVS6LWm5Ings5hKswOEqzdTaGk/7pks3ti4PfsimoOMALM/fHN0ci0dqXGcA i2qeysWVaAYlSPjkBt7Qoe0cfTe4QIcDqLBw6prsTYAJpT21r2UTFEl0omHr80tS90BCLiQd Y0VhRbliDPdBcJYR1CAGHmke0wGagHOVLdgTE5rKAWaEcFNbVIbrbVA2E7CyIJv0SYXChrzP knnEAXlSTUaQCCEBXY0ZjlIB6wm4LAhp6aohq3UuliAdP7oVKjYrDNLdJ6Ku+5ytAHBQ6rhM BGhtVsogWi6BiMBxhWr8OSZCa+mdIRo9qJ+HEWCj/A6LRvwQ1Q3YZo4I0e2cds0EyCo9XB8g tK6i3VDZg2uNieyNHKyj8KRqEL4B4NJWtdgWnULvuI4QnqnMmP8AhEmxIT2PqCTey0FbZ8Fc MFaSEe4rcU1Pa9UWk+aU7deDJv6qwbssPNz+qiY7d4tuHSOR4eaXalqDYfex2l/09lYf4pHE hZpuyp439VztlO0n6J96Okar/FDOYUyjtqk4a/P9Fh/4Q7l5o52YQLG6qcg6RuW7UZwcVZbP 3gLHTmkcRPDsvKHfEBtKfTxtUfsq/IOunulPeymRp7/2UPFbwufZkR3XjzNq1G8B7o9Hb7wZ mT6JzkhZTb1ehtmo03gqyo7wt/MF5G3el3GR6I9Headb+g+idy2jrY9qo45jhIcPkjCq08R6 heS4fecAC/uZ9FIG8gP5vZKVUr1E0mn8o9AoGK3ew1T8dBh8o+SxdDew6Bzvb6qwob1E3n3V aHZa1tx8E7/oNb/pkeqhv+znB3y52no8/IqQzetvGFIbvTTP+6NH2UdT7OQJ+HiHjkD9SChM 3ExI0xQHKzneoJWnpbxUj08wp9HGsf8Ahd62+aNK2xFTdnH0xLarKnbM0+hsgtbtLhRJ7kD5 r0QuA4pG1AdCgPM620ccz8eHqeXiHqAm0t9ajPxseB1aQPUheoIFbB03fiY09wCpuOwxWH+0 BhFzfj+4Uxu+zD+Yei0J2Jh4/wCTT/8AK1Q626ODdrQaDzEtPsVneP8A2ewMNvbTdxHkp7du 0uao3/Z3Qmz3tHKZ+ZQqn2fgf8uu/wD7jI9AEdMp+Q1FPalM/mRvvjP6gsP/AIHxLbtrg9II 91ExOxsdSuBmHQz8gnJkHoza7TxT15m2pjhrRcU/+PYln4qTh/2n5gJ+yekwuhee0t8HjUO9 1Y4bfQcfeAl20GxSFoPALPM3tpniFOo7epu4j1/VOZhMr4NrhBH0VPX3VouMloA4xx7lW7do sPFEbimHitJkWlA7cnDH8o9lAxW4FCCQ0LZZxzCQvHEhPsWnmlX7NGvPhjvoB3sp9H7JsJHj c9x4xDb9FvhHBdCmyVW3nlf7IsNrTfUaOUyPVUu0PswLB/LcTY6ySvXYXFqrGyfgrt8+4jcn FN0bPnf0uov+FsZFqDj5EBfRXwhyHoE5Tlqnjb+XzTW2biGfipPj/SVDqBw1aR3BC+nq2Ha8 Q9ocOREqIzYmHH/Rp+bQfmp6tJm+aMxPA+hQS/y9l9N1thYdwvSYOoa0R7LK477NqdQmC1o4 QAD8k5x4/sd3gzn6oD6p5r24/YxQOtZw7AH5qJW+xGmScuId0kD6KbgO7xN7kLMvVNqfY1WY D8N4qDkJBWQxG4mKZ+Q2nqfZHip92Xc9CKsMTseqw3YZGtj9VFOHeNWnupvFRMwZKfnTekeq 4nqouCu5QUN5KLI4JjwjqfYBzkMuUgsshFvFLQ2CSU2VIFPmmFqehsBcQiZU0hUDVwSkJQEB oNhOuPX3W7o4qw8/mvNtl1odHl6rZsrWHZMnpkJriuzJYVukyEhCLaENxSIFyQJ8JHBI3ZZQ 3BOaVzkABwTMqIUkICHVpqNUarB7VFq04U2KlQHNQHhTi1RagWagApzXnKoZCl0BITiM1tgD 4h5Fb7ZEAHusDguHcLb4F1o5Fd3H9PO+SuMdUktjqVEq1jxNhFuFuiM4THZQKjtVhc/7aciX Rx4vnAdIAggacj0VTtTDYZ9R7ngD/ltEWy88scU+pVAaTyE+6z218T4S48wPUarW2a9tMFbt fJTdUaxxIzeEm5IEyJjRU7cRBhPxL8/lKdh8MIEnv35Lz8vtuknDyykSRJzW4gTqfVdtDM1t MS3xSYEyAP6pCbnLaut2giOXVdVh0GTMASfM/VRTAM5zpGqHWxJLXN5xMWsEWvTl7abXXJDc 3AcyVHrs+HUeyZynLPPnAU9TMrUYAHGFGw4ynMdRMKyweGbUqtDpAkDkYHIq321sAUaT6rXS GuAg8G3v7LScV69gz0TOkyoGOow4w6RAnhB5I7WFxHUpHUzPS6z0oCiQQdbXRKbGkEu5aTF+ aNUgAdR9Uw4SwdMiRI5DukEehVykuHCYXBrnAuJkm6kigar4aALEDh2SYOkXAiRYEz15JwK/ MiscZj9wh1Kca68eiLh5Hfn0V40li1ngzaTAA5mRxUaoYS1cY4gNJsOHCUySfERYkj0WkoPk xKlNaWBpdIOsHiIkEeqG6m4CmSPxAkdYRdq7QNUszflEAzM2Av5AKwCa+q77wOyjRCQt4o2S Q2tdSaFMOzZjAAN+R4KtIgDndOZV99USmmUxI8k6g+Cmh0eiSk2/n7LSUJGLqiAJ80NswToe WiRrh8RtpAcPSb+ytN59qNquaWNAhmQgQOOseioKf4l7oxElRGNJI5KQ10yRoDCCEIvZNouI dMxZI2sAUprZrfuEEPTrOvy0KsfjghttBfqobagEwLJaeIAPRCMouMQ7KxnJ0mDwhdsnFsD3 FwiGn1IVdWxmZwi4GtvkpVas1xJ4wB3ASZ6No44l5cTJ5/IlOr4ovIJ14KIx8AjnKQOtccEH pNpM/GDYnyKZRJB7WQaAupDjEDmUAUn3UrCbPL3ASBrr0BKjMc34gnQD3hXeCpC54xr0KWiq mxb/AIWtiB79FSPxTnGQFuMXsUYl1JlhJJJ0IDQTyTXbn5XFsg2JEgEO5XhHUmMw1QZoOnFS 6dPxW5q7fu4eLI56iPZQK2A+G7t1S0D3PgwQDFk4Un2mROltUuBILjImB+ytNsuhm424cVQZ +nsoPcZJsJsob9iuzG0tmQdJ8lsaWG/mVS0SOijYPHZSQWzc2I6oErF4zCkG4I6i4URzHAyJ iNQvV8G2hWOV1MTE6R6QqLeDdcUv5tL8H52m8XsR0U2LYfDYuLFWDqwIn5KFtDDFr7DW6jmo R0WdJfVmAM1v17IdKkC2Z6eyrKmMLtZ9NEylinDhx6hAWDZBvdcGgcE9ta1wPRAr4kEWEc5k JAw040SZXcZTmVCVIIJ4pEr3meKeynYIjsLe+kotWkDEc7pB1Ole91KpU4Oia1qIw+JOVNh1 QgGykUqoIPYqvxDodPBOp1jKotJWHeTICf8AEkFT6NJjackQbmf1VYHSmDTUcNCi06hI1SfA cGzEiFBbWM2QaR8YQZSUq1olJkm6YGRMo0Eh1YRqo9LFkFDhSm4ARObrCDcMaU5uKM3UGpYp hrpmvm4omyY/ECbqgpY1wdqVKqvBuUzWLsWJjgpNUCJCpqQaR+K/f6ImcjilIEx9MHij0KIA nVVFSqbXVth6oyAFXICESUjqSFmAOqYcQZ6KoYNV1ypZgs0PJR3jirXAVQWIsNQs2fLuI7JN obOcGyCTGoN/NXeIddRK75souKooMPhOasBhGxpPqpVLZwIJFvNHpYLqo0NoBwIIUR2BLVeH DwiN2fOpRouzOVcMCOqrK2AJ7LV4jBxaPdC+5Dl+iOo7Mn9yB6e6Adnwf2Fs6eGHL2SYnBAi 4+SOtHZjfuSYKHCPYrSOwffyQThUao2pfuFpAQjRI4kLRtw3JMq7NcdAn7G2czvEXPopFPGv B1P76KccG6YgyOhCZWwSfaww/wCM1P6k5u3XDUz5KOcKR27FCfh+BCPJRpZ09vnt++Sl0N5n NjxHyVCKPIJDhO6fkGmu/wAUuOrrf9v6I9HetzfzHz4+6w5pO/pQ3MeOaucsGnp2H36cCPFI 6kW+StKW/o4gFeMCq7/dL8Zw0KPJDe8U986RCkM3npHt3Xg1LaDxx+Skjbjmj/8AiR8k+8D3 xu26R4wj09oU3aOC+fxvGdVJo70OFw6PdHaB74a7f6guGIb/AFBeIs3wf/XPqFKpb4O/q9x8 kbge0ApHUwdQD5AryrDb6Hnfz/RT2b4E/mjn/YlAegPwNM6safIIR2VQ/wDCZ/5W/osfht8o 4yPM/RWmE3uDjcfT9E5CWrt3cMf+k3ykfIpo3bw//h/+p/6pKG8VJ3FWDMUw6Pb6hPrYaqrb sUz+B7m9JzDylBdu2/8ALWPmP7q7OLYPzBKzEtJgFP2FD/AcR/4zfQp42RiB/wBRhP8A3foV oFyQZupSxTOGb/Rf6Skdtau0S6m8Dq3+y0yQpaJlTvUeXsjUd6AdVoKmGY7VjT5BRn7Hon/p tHUCEWBDZvGzjp++Cls2xRP5lEqbsUT/AFeo/RBdujS4PePNp+iWjXTMUw6OHqigrO/4UjSq 6eoH0QK2xMU38FQEdSR7EKoGpJjVI14OhCw1fBYwWLS7tf5IVOriaf8A03DylGg38LoWNbvP Wb+JhHef0SjfM/0+yNBsVFxWFY7VoJWeZvfPCE9u3wUS6TRK27lJxJyi/QKE/cjDumWA97q1 obUaeKmU8c0qu7O7YzE/Zjh36sb2CrT9k1M2aAxvOCT8l6WKrTxRfNK3Y3k8qq/YpRIP8xxP CwWRxf2TYgOd4hbSeXkvoQPHNBqQdQpulzOx8v43cTE09QPLxe1lUP3dxEkfCcewI9l9T1tm U3GS26j19lUyLW/fZZ5WNsctvlWrs6q0+Km4HjYqPUou/pK+pqm7dFwPhHWwKhVNw6L/AMjS OzRHslj7O5yPl8g6QZTQLL6UqfZhhpvSaT1H6Kox32S0SZDY7SPQq+qPNHgOUJAF7n/8EWuv mIHIAKFjPsXcPwOP/cAPcJaV5I8jwboeDyWtoVfCJN4Vlivsyq075pjhf9E5m7VcADJp3T0c zlehhqdCJlshuKHYahlsogXBIgi1McivKYQkYaROISIBC1NDUZJlQSM5qA+mpzqajOpmUqJV dUZCjParKo1RatPVZVpKgEXhSsM2yFlupOHZc9pRE5Vb4JgkLU7PfB8lkMNV4K7wWIIXXhl6 cfPjuNbmsoNVibh8XI6pzqkqOvvbz9WK6s2GmeYHqVU44j8MSATNp4R9Vd1riOoWbr1jmcOZ KOS/hthGdAifOEahVaQ6SQQCRbjPNT8RhhGmqg1aNgB5rksbIza0vc6SJKUYkSddUTFUIpiG kuc4ZSOIEgwON1EqeAta9pDhcjl0KRpL8WGunj+qg1nFz51vKjYisS/5DkptMtAEnxfqqkNY bMZmqSTef2Fo9r4mcO+dSMpBWYwDiKg7gqVtZxLRf8/tBXXPXGm/aqw+HdLTw+cFAfJJ4STb TiiYh+g04KSKLGtkk5xJM8eQXJZtavqvk8gnVaogNB1AnukHbqm1myc3FTcQLg6ZAls5iSB0 CbSpFrrcLn1hK2qY1iE/BMc9+VsFzrXOUc7lKYhHfD6jiZA4fquqRw/3SVnEEgiCCQeOhIXU qJOkaTfknoE+EpIdMtNgbjp2Ues1zcpMZXGxHRPYRBPHgqgGxNR0Mpx+EzPQ8EB49kw1Cn1K Jm4jwg97KiJSdx+aaSdAlP4YTC7SPNMEykomHw4J1vbrxTwYCPQpsIcZIIEjkTyQDcRYxyMe 6d8UQhNuJPG6a2Lq5THpugyBPTimUi0uLokao2CdF+OoI4JuJaAJHE3HI84VbI1zwHEgW4BA +KQCBxK5rpIhdi6cEEceCAZMCUfDOtn6x+whYhsADpPmhh3CdE9kl1a5XOqqIj06ctJnRGyq ZOSOMiVJZimjj/ZVbXmefTokc+UFpd5m2IN/3Yrmv4FUwrW1up7q1gR0n0QLFnQT3mSOYuq6 niC4tAPTupbiW1ANdL9eKE1YupQb3VzsthbLtQQLKjdUnTVWtLG5eFoTZVotmOH3lsf0H1I/ srfaZIAcOCzWy8SDXpnnI9la7fecpIPMEdP2FQ2nbMrveDmgt+fRQN49hMqMzjwuaJsNRyKF uvji4Flov3BWjqRF9DZI3mdLAfDdd0h1p/VbDA4XKBFrfRZ/bLGtrZQIhaii8ZR2STVZs/EF orcxf3Kj7MxYzyeZ5DVOwDv+b5/VZvFSTAdEEkeqQj09rm5Q6BpPPhwS1S0sOaC0gz1CwWG2 rWZTy5pA9fdSKe3XFpa79+UIabUOOotzkCYDnAKPW2cAJBvrBvKtXskjqSVPx9BrqUAAFZ5R NZyoAdAAellDqCT0CmVWkWhNw7g1pB1lQEWI4/7q6wmIz0SHNB1Fx6Hoqh1MEzKXD4vKXC8a eaANTwoAPmmtb1RX1g4JrqUtkTySBjiOaAQQpuCwocTPBD2jSyGxmeHLuloKyqXAkynYeu4C 6c4E6pGyE9BLZWkE8Ai0gE7Dv8BHM6eSBTpOaVRVMdUdEaolMghGwVnAxx+iTGNDfELSfUpp Pbiy0RPBVnElNq1AePuuplVIYzAntaHGJAKE8iNboFMcVWgtmYHmlqYbK2QZHuhYesjNeiw1 TVZLio7qauq2EDrtMH2Kr6tIjVSaJkTaolS6dVmhCK0U+ATNU03QdVKzpz8MDdK1gQCGTdED iRBUvD0QiVac6CSnAFSwvh1KNSw/GV1GtaEZotZWYTijYEwLnUKA6rdOGIOmiDTjWaXfiQcQ 4KFUoEpc8apUJbMbAiFIw2JB6KsCn0qDS3r0MKKVqU6qJXHGgBVjmQdZUsVGnihNoX3sk3V1 haTSBIVM9jeCfTxJFpVQL77q0oVTAA2/uoVPEu5ooxxm6cNHGy7/AKKHXwWX/ZXH3zzQzXa6 R80+oVDGclPw2GJ1aitot4KTSfBR1G0PF7Hc6/w57RKqq+yzpk04W91tPvoDdFHdiWk6D0CX U9skMEBZzYUU7NaTET7e62GNy5Qqmm0AzCXU9qo7HI0b/wCqUHEbPeACQPUFakM6arn4ZpEE WS6l2Y5uz5TcRs+Pw/qtoNmsiwg+qi1dnOmwCVxHZh37OJ0j0KjVNjO4QPn6L0yls4Zb5dOS q8dso6tFlOjmTz92yTw/RM/hx5epW1+4niEF+D6eiFbYyps+EA4ONFtqmAt+A94KhHBA9fJB 7ZR2GI/smNa4LR1sABoCoVbBHumar+OQl+9u6+qPVw0ahM+F0S7G5m1Hi8/p6KTR247n+npC h1KfRAcyFU5NFpdf4jIOpHofopDd5nDRxhZr4LjwSfdz1CrzUaapm9TgfxFWeH3wI1dbzPuv PvgkJQHDj6pzmo09cwP2iFusEciTbtxVoPtHYdAPdeJfFd0RBXfzjyVTkn5D3Wjvy08LKdS3 sYeQ84XgtLFPEXJKnN284XgjurmUpae80NvU3cQVOp41h4rwGhvQZGp9B9VaUd8nDQxzNv7p 6xpae4rl5Bht/Kg/MfNXuH+0E/mylLp+jehJVhf/AIgDkPb6ojN+wenp9E+lDarlmcLviw2d HlwVvT21RcPxhTcbAmvptOoB7gFAfs6kRBpsj/S1KzH03aPHqjCq3mPUJaJV1N2sOdGZe1lH dupT4Egd5Vy/EtHFFBm4QFGN1qf9bvZI/dyPwvP/AHf2V6uQFCNi1Ro8e6a7B4gcZ81oFyE2 Mu99dpuw+6adoVBq0+hWqSFo5JaLTM09qO4g+6edo8xC0Pwm/wBI9AuNJv8ASPQKekVpnmbR BVnh8Q0qRW2fTd+WO1kMbKYNJ9U8cJCsFLhzTW1BzQXbM5PKZ/CT/X7K0dVgCkcojcE8aPB7 ymup1RyPmkeqbXwjXG4CjnZ7OSc51X+gpvxqn/hu9ClpU9MdUchIhSAJPTdCaU8uQy5IGFcn AprkgYQkKdCUMQAwiQkStQRpCHUZKlllkF4RSQKjVDrBWFRqA6jIWdh7VzmXR2HXqCE6oxMp vhLQpaLirrDG3oqmmxWOGdoFrgyzXNJ6kyodFklTgxaOLLH2aTqs9tKiWlrubiPKFf1rKDiw C0A859lnlFxQYmpDbG/7so4JH4tdUaqfHPDl2Q3vNQuJ/C1pJOk8oWFUPiMUCWcmtgW4n9lU +0K4cSeMqUx5eWsH4iQBPXmVHxGDALhMwY81JqxtK+ZNdTMi6m1Gwx3dvoo4mZCcNabIpTUY Jvngj/LlEX9VO27SDKedrjOaIUbY7SDn5FO204lpB/rB8iui3/x6Tr2o6cz1153R8ZXL35nD UR5hBoyFP+B8RrWNsc0z05LnkUh54B7phMwOZgJ2Io5XOadWmECCCnoGvP6KTgDlkzw8wojx Hnf3RKRTBatSTMf36lObULfELFCLbrqk+0pASpiM8Dl80hEWQQU91eTJSAtOxBn98lY7UIJz cS0W4crKpbVvZT6r8zG9G+pmUyDDQb/ueaFXaJGXQ2PdPq4YsLAXNOZue35b/hPVMBBICYIA uA4BHpYU5mgDMSQANJuiYYQXSIIc5pHIgxCAR1IgXFlHzSYU3Eu8JUdhAiycAz6mSWxwUb4v i8kd75mT5oXxBNkwTE1s2WwBHLjaLpmcT2T3YUukt1taQNUB1EtdldrrqD7hPZHVzPi42Hkm 1WtLQfzc+idCa1iNhzaGYGXRxCssdspoFH4Bc9zmjO25h0aKPRwxcP8ANw69FP2ayuahLGnM y5tp1KqUtq+tTdTIzsLeAnvyTWNDmudPYc0/G411Q+LUzEiPRRzWysjSeiDhICNSdwUZhkIt GnxlMJWhB4j5qbg3kkkqBUfIV1syj4C6ReBH77IZ5CUr3HBTKdYuMRMRP91HpEXGnFTNmYgM c+dHR+/dDKrTZOIBr0f9cHpAUvexxDjBMEe8H9EL7w0GkANXyDABFj+qj70VDm6G3aRqqoii 2FtJ7aljF/W69IbtTO3W8AkcivJMBVEkaEG3lwWkwG0DM8z+wkvS13iA+I13EgFWm7lTO108 o+c/NUO16ecgk/haFN3drABwnoP1QixN2fSyuqjUX8xJQcNu9Try4OLTeRw1Og15Imy3+J9+ B+aFsXE/zHAOvJ/3SKH4jc+oPwVAehkeioK2zX0z/MY8GdeB6yvRmvqDgHDmDCM5rXtgiWkQ Qfkho82GMAe0cvNXlWHtFuEqj27ssUargNAQ5v8ApN4noj4fFnLbRTUVGxjJd81U4qkdRora riADfioD6gyki6zsCofprdGo0pam/CDtdUdjIESlozaBe09JHVXQYXWam4CnIVzhqACJAdh9 nww9h/us3jsG5z7TrEcytnQuQ2ein4XZzGVZIBkCJAs5azEMC/YzzAIh0cZCnUtyHvEteAeU n9Fuds0WuZw+JbJwMz8lAw2Dr0xmieJAIJT0emRr7qYii3MQHNGsHMQOahNPOYK9Vw+Ja9oN ri4+dlgNuUWiq4NHhmR0nl5pXEqfSoCLKPtGiSMp43VrsqiHMEou0MESWBsT/dEiGUO7T+AP qbprdkvaCINuhW3pYw0qkOA0/cK5oY6k+wieoCrSo8rq4YgXHzSUTGi9Xr7PovHiY09bBZja e7rC8fDgDiEBnsJ4rqxZhG8VLdsLKJB+aUYUhpPABBbUmJqZHEfNVmIx+YRqj7VcTULRzVxs /ddtQN8UW6TKVhxl2xrBTaro0XoY3IbH4zPOAqbau576fiAztGpbqO7UtK0zFOsTxR8NVh10 N+G4gGyA9pmyDXrKrDojNxDQqOgL3UrKnAmOg6IPxiF1GsAurPkqpQLhGtdJSVqLdQpezqgA uBpyQ69AE2MDl1Rs9o7tEF1PNpqj1sI6LFRmBzdUDYjMK4CD7ILpHFF+O48UKnJMFSin4avB h3qiVhm0SVcORwUzA0cwSJHYLXK5mqLisPF9ECEgluqxxVnhNmse2cx7j9Fmq7jFkuFxz26G 2nZOU1tim/DJEyPRQjWuhuqOdcqXhqA46rXYAGJdaCpba7kCthiLhJTxEapgTEYkwhUdoW69 U41mlQ6rQSkEt+0JsUWlUHNVnwCeCI2yQaEV5AjsguxB0MhAwWKCumOYQND3SCLRDwJgwife wj1Koiyr6tK8pEk/fArTBhkGQDN7qkpMClUQBxUZHEqvSp8GtHkFWu2fJJAnsranhGm6dUpA Cyk9qWphnAQQVUuwdzYytHUxsGCE1oDuycG2Vq4KbFQ6uz4Wrr4doOiE7D57AJnMmIxOElRB hDyW1xexOWvDiqr+Fvk+D3AQuZMzVpdFGdhui1o2bGrR80x+zxqjR9mapYTojDBg2hWj8HyC lUMIOI80dT2zOIwAHBAdguhWvq4EQolTBE6BPqXZmPuSk0cDord+zz0RKWGIIkJdT2qqmGA4 KLiaNlqX4SeHsoeI2dHBP2NsbWwuvL1QPhEcfdaWvhROii1MJy+am2qiqbIUluJI4lOqYcjg oVSeSXammDaJ5z3CPT2u4a/r9FVBpRmtnVHejS3p7Z5m/opdPbbuHncfRUDKcmO/ySOpQl5L D6tXR3gcDYn98irGnvO+1z6lYelUVjhnmU78mwdG2p7debz8irPC71PYIn99ljKIMI4S/wCX R426pb5v439P0Ulm+44j2/QLz7MmPrnmtMfkS/gri9H/AMbNOkJ9De1ua5sfP5BeWuxh0v7I LtpuGhW05ManxWvbKW8dM8R6/wBlMo7UY7j9V4H/AB5wOvyCkUt5yIgx6foq3jU3iyj38PB4 hOXgw30e38xUyl9oFT+sp9J+y1Xtq4LyJm/9SJ19R9Eanv8AmRf0kouM/Zar1dcvP6H2it43 VhS3/pHW3ql1ptguWWpb70iYOnY+yt8Jt6jUFngHki42BZLkD79T/rCX75T/AKwpDzoJua6c EElJ6RSUxdKQpAoSOSSuSDkQNTQnNQRrmrgxK9Oa6yRGkoTnJarkIII3LdI9qKAkqNkIsCvq ssohap7mKLVZCjQPpvVhhHyYVQHKbhKl5CvFnnGkoPhSziAqShiRHVSG4oLTbnuPtKrulRsQ LDzXfehoo1eTYFRlS6qephHOcGga3J4C51UXG4fLIBkce6vHtyjKNeJVTWpmVjV6VrXQSewT i4ZdeKdicN9FHNI8lICyyehOnO6mkDM6AAJsOQQqTDwBTnkjUEJBKa8iBMWS7T/CDrmAHYtO ihl/fzsrZlMVaDqM+Oc7DIHi4tHktfuEoaLZ7aqYytlBy8Y16f7qJUBE2IjwkGxniCiNiLyD HdTo0ylssvHxnuA8TbcTY39gq7G4XJWdexPxGjoToptOuXQ3kQmY5wcGu4h7m+XBARqBp5iX i15HKRySUME0uJzeEX5TyCXEwSCdYOna0oVN0cbFALiqbRU8AgZROv4ud1EqOVn93Dgb6cVC qYaNTKVAMWnySNYivfbRLSZoTp80gGWKTSfNuibTpT7+SkUqIBPEER2TCJXJnW6a1SXUTJn1 UfLBQE/BNu5xdGSmXt6vvaVFp1iTJuT4j1PM9Ud5IAHD5prKMnuEEX4k2TNCkNIpYsT6ph0i D5J9HCywuBuOCAaZF4skJI09OaZJLWnW/wA1GrHxSjCtopAosNVmeSzUxrp+qCVwElGa0paj gHuy3ZmOWf6ZtKaahOnzQSVRPEcFqNiVGim+q4nO8lkaS3SFlMPhqjvCIEkalWmMDqJYwkGA HaKolI29h2/eKWVghtMAjSTJKra1FrWuFRsg3beYPUpH41znyVKp4pj3gVGTFh+oCelRS1mB 34bdNJRKVA5Rz4qZt2gGVGgNLbA8v3oUCnUmyZ7PdSloEXVjs55Dcp4SVGw9Ih19IPqpOG0c T0CGeVHfUEyLFWFCPCTr+7qtyeGesKdTccoshmsKsOdTIOjm/NH2tQD33NsmnW8H5KHQF2/6 goO8OK/mkAlsgTw5iE6J9su2oRUdzmP7q7wNYyIN5AveZWbL4JHX6q22LUmo2eBJPkLKNraT auLOYAXgRPbgpuxangPn81U1H5viP1A1KkbKr+GB1T2S5wNQNdUk8PZZx2P+GXOB4mCOU2V1 hjLyIMlpHzus1tLCOaSw6TIPMcEWk12y96CWNB5RN+as8JvBleW6g34691iMBULGgQD++Sr6 m0HGoTMCbd0tm122scKzs2WCPCeIMclCbQdlJZOnDgo9El1PMeJWo2LhZABA0jl5pprEsw1a oTAMDmD84XfAcwXB8wvR9mUxQqPY+AHeJp4G/NHxWyqNUyHAHW0H2R1N5aJ1IXEhei4jdMG7 anqP0VbjNznXIDT0n+yXUMzsmvBI1CvKeJEKkx2y3Uaki3MC/opVJ8t6o0FnUqgQ4Hj6IuG2 547ukSDPLtCz1YlQi8gphsqm1s1UvJm4jhYLVO2rTDC7NoJI+i8fONcDrZS24mq9hA0NjwgI lDTO22HVpbOUnTvxUfF+IuKgbIwDhDjMfv1VjijDT1TJabJb4B6ouM/5jO4QNnTHkFZVcCXP Yeo8oQSu3nZADuIn3KrNk7VgQ4SJWt2xsf4wAn14rPM3Lf8A1R5z9Ez0tKeMpc/dNqVmAyHf VUO0NiVqV9QOI09VVsxLpSKt1ReHjmm4rC+B8aZT8lD2TVlgVwG2PYoJ57gsMX1XE8L9lpMJ mYWht1E2dRPx3iNcx+qNicQadQHkR5hM41VFtUCTlPTl0lGpYlrpGjhq06hdhsS2o0OabfJQ NsHLlePxAnzHVPTRTbxbBbmzsAAOoFhPZYyphYcZsvRa+1czfwza/dZnaGCBGYa691NK1n6e CvJ06Irw1oU7CvElp9FGx+zj+JsxxHLspCFmT6bhIQa1EiITQnsLlsBPLgqjDuMqVTqgmIS2 axqHwghCoukwqypXc0xf6KVhqxkSjZJ9SkG3hRw5sold5uobXyltKwe0EIQpuZ2Q3VoCEcdw KAdVlyTJATM0p9OmSjQCzJfgBPfheKYDGqchpFPDDmiBhCBRxN1OdXlXAi/HIN0mJAIBSVRJ UtjBlVbCqZhwTe6uKOzWZZge6C5oGiG3FkWQDsU1rdFAqQVMfe6G6mNUBCpmFJpY9zT0UUiF xekrS6pY7mpD3zxWbkzxUltdw4qaNLYNgqRS7qnZjJUg1zCktJdfGZPzFFwe2w6zifkqunTz OvdTXbPbEwJ6KKGq2e6kRMC44wUuOq0gDGXkYWPaHN0JCBXxp4mUBY4uXmWiyDSY5qZhdpCO alffWnojYSaLpsUrsECZBKXC0gdfKEzHg07tJ53S2EPG4AATJjiqaqIUtm0s1ncVJ+E0haYh RtN7qSI4I9TZc6WS0sFk4yr0e0ao1NYjYqpyS4CjmIlOAhb09lKw+BOuU/27K7oUG2UrMIVa G1FVYNIVLjaE6LS4gAyeKpcQLlFhbUB2W52gQKuy3DW3utIyoAApjabXDQLK4q7sHVoRwVXX oidFt9p4NovHksrXpXIGnBLqJmpzRunRZSHsgpopSssm2N2ZSCSopLMOUOrThQtGYFZ4QaBQ WCFY4I38ioymxtb0W2RyEyg2yPlUTEdkd6jVSj1Co1QrWY6Pe0aqbKBVU6ooNYLSNuOe1Pij 9VBdiDzUzF6HoqsrSV03AWpiTGqiv2g8fmK6qVCrOutJk5s8EobVdPPqj/xx/ElVBKQkp9mX VdU9tGZyj3J91MG8TuNuskewWcpulEDE5km4NQzeMj+xcpeH3qcDYx3WQYDxKeLcU+5dG5bv W/8Arj99FJbvi8CM7Vgs6fnT7Do99chZUUhNcortgbkx7kpKZKDKxEamwnhIq4pZgJpKa50o LRWulNq1QE0uhR3mTKQ0I4pU0i6WUFogenAygEo9PRBB1goVdS6xUWoihCJTqVWDZI4KM8wk NbXDcVCLTq3kqlbiEZldPbLLFcMr3PL5pxfeVW08QIT2151SqNJzjN5Q3tCE2snmop6kE5kp jWzw0UmiboxaJR1JHYRTGbj6qFVcHHop+Ip3hDp4XUgcD8ktFpFrAOyzwEWUam4teC2dbIho kXuiMZcd04NE2pRc54eOLS89HDX1hVWcm6ua1YtkdC0dioBwwyk/msRyjtzSoBoP8Q5yFKax uR+caOce0GFGom4U3KHZmm2eRPKXSgKd7Y4zx8kLKrLGbOLG+K5kAEaEKCcO5ID0KsNI53QR xnmn06RPsm4ikQdLaylQa4jX2SUACYThTlGp4a0jnCRjU6YkAcbIc/OP36JXWNinBqCMDpQ6 jQ4p9WjeUzMQmEoVPwjoB6cUragzcwn7MpEtqPLJAaR26jylV2aCY8uyZVYVKzXZQ1uWBB69 U7HtDaAgXLtePn0ugYQS4AcTHmVaYui5vxA8D8AbHAzee4KZKUuMR5ITaRFzrwHSUQi8cUY1 AYzcOKABTF4KJVN4HIJ9WzCeZgH9E3kUEjEJ1GjmJA4KQaEzCmbBwoe97XOiBbvwlMjNj4ea zA7QOv6qz3xot+8NDdAwcecnVV1AOYXSYc2x/fkor8xJc6ZI48uicIJ9IgZkXBVIqNnifol1 gC5UjDV8huqUNt1hfTDy6XNMEH+mbEcygbKwgf8AiIHhJHfkpOJrB9MnLqR+whuaAIFigB0s RADO+vG6kUarHZBNs0uHSD9YQKdG8nUI9DCNmbyhlkvKlCkWhjbHUJg5BRGEzPEBSGYu8xdC E5lP+YzgJv6KFvFgHB7HH8JB1tZWOzMU34rC4T4hwmy1G84ovo5XkSLtjUGEUR4hiMCQ4wbX M+avNhbMqOu0cNeHH3V/S2NTMuuRxEgqxw4yUy1ojWDoo0rbP1wWUntJuQSRzjh7Lt33SOsK Dt15MXk+8pdkYlwdAtqUt6D0Td3K5zi9t2ixI4HhCLjN1cNXJcHEGZsZg9BwCzNHbdVnK+pH Lsis2q4Xgk8tAqllKpOI3DqA+CqI6yDKg4fdHKT8UAnv81PpbedBuQVFq7dkQTJ/fJHojqmE gAAWEK3+8Npw7QCLrPja2WAYS4vaGZoA19kbDRVdssqOh4kcDZQ2YFrnS2qR2hZxmMuGusfb 1U2nVAIuq7DTQsoVm/gr+RB/ukq1sW3VzSqujUDicr4PdS61Z+WA+bdEbIj8O6of5h+QUWrg gzRdTxbhqiVamYINFxbWuEGxVLiKIarqpRlyosbJfl4ygB4XDZ3QNFqsBs7KL9ucBQcDh8jR IglWfx4HVASa2JaxkKsFPPqf7KJiqpJiboVLFFuqVoarDMyAdleUMY2G/uFk6WNBAM8FztoF pSlDZ4jFNZqew5oNDGOdfLbv+5WDxe3akgkGBbgfVXO7u8IccrjqrlG2sBDwRqNCD8isBvBs v4VU/wBLrt9dJ6LW4naQY9saEXnio+8TQ+lHmPMcE6FHsfF5W37LUYHFB3y7rIYJvBTaeJyf NSWlrisGKdZrxoTBHJJtfZBqtluom3MdFJww+O2SbW636ItOu6icrxLPyuHyIVHIymDxdWg4 WI5gg+hCssNtYVKnj0n2V8/4VUGQD3sfIrP7U3cygvpuPb9ChVaf4LHN0BB6BZ7aeFAcQBaJ Ci4Da7mtyExBRq20QblKpZvEYQh0jVK/aAAh2v0R8XjhN9FXY6tTew/1DSNfNQcBrw67dFCb VvBU3ZFRrpbIJ1hC2xsZzR8SndvEcuyShhpIUc14KrqWIdAM+SLVMgFTaaXW2g2biUtHHCbQ qKpVunUaolBtW/GAjnZRadcSoNKrAlCdikJ6rbF4gRIuq99VDNWV2WUx1SqVcJGYwtOqgmxT HXVQ+q8btAFM+PzVdSpQiZ0xpY1aoEI+GrAjoqOvUJU7BDwynsrE8vEo4qWsqzjqp9DENAiU 9lotWqVCc4ypWIfyVWcTBRsSJLyQEuHqWIRTiBllVvx4Nk9npLqaIDXXulpYtuhXPCNhKaLJ 9lDpPvGiI5nVSZzqXJS6DeCjYUEmOHM8EaoxzSbg+qmkksbeys6YtdZtu0iNQpjNouIsopJm KqCYlR6eCDuZVfXc6ZR8HQe7Q9kgn0tnsAP6oDqAn+5RW4V7bkowYIukA8NiC3jZS21muuSb cyq3EMI0USoXaglEmw1Zpsy8LjkP0VI+oJgKDTxTtJKl0qJ1W2MCYxhgFVuIzZ4Ux2KLBrZQ 3YsEyVpAudk4BhALhPG/NWWIDQIss1RxpFh9VJY551lOGkvrckz7yUgbzS0wAqJGrOcq6s1X FdwhV1RklFSjUqJVhQo8yiU8AQJlJUJaoK1B2nSgHzKx2LFzyWrxz3HjwWexlPippSqF7USm FO+GCkdQEdVjk6MaE1yBiKg01SVQVFeFnpqbxVjgdfZQqTFY4ZiWhV9hB4UZ4QMKbIzitMcW aJVCi1FMqBRnBOxrihVAoNcqwrBQK4SdHH9qLGt1Va5WuN4qocVUd2vQdRQKuqsKuir6qqOb OAFyaSkKamwo9B10V1ZQ8yY6rKYT/vATHYzooBcuzIGk040pwxhUDMnApDT6fqITii1CgQtG 5hCTKiwhuKRlJSFyRNKAVdKSU15SI15TWiyVI9IEL03PKG4p1NqAcQnUXnVNckZqmktYyZUW FKcEKEEhVWXUWuyVYvZZQqgUnFcHIja6Y+nqmEIFiUMSEYYhVi6U0XBctxZ0sijEKibUKeap 5pxFxaCliR5o4xAJWdZiCiNxKekdWia4cU4GyoBjSjN2ieaVhaWriEP4YURuPnWEZuJBU3Ea EqYeUJ2FtCIcQOvunfHlKw9If3UAGExrL3U4vlI4iFI0jOqSMrrj5dQoj6USNRzU9kSkAQWl U3COyuIOgJ72SP4TporKtTnRRzhzGqmjSC5OzQEU0ChPpnkkWjAYIlTA8cFELU+mPRMkt7wW j98FDxDf0UijVE+qhvq80yGGJcxpaCRIv5hRaUJ+eUSnQB0N0zEw5AcSdI906rXLrSY1uUI0 obcjUoc9UEfl4oFV5Rcp1TA26Al4nGTRbTLRbxdnEqM2qNCBPNOrGbnko41QE7DuuRzFvdS9 n4rISYmYBUGiborH35XTKwWrXl5nU3n6J1Z+YC4sPZRTT8YzWB5ppjgmNFo1cr56e6biX5nT xIhObQJnoLp1jHRB6SsNi2hoa4Wjvfmg55MIbASYCLhqgDxI058E5Ql4Jpc4sDS6xJgEwBxQ Q8g2Nk+hjHUnVHt4tIAPU39pUatjM0uMAkkwOZQzuO011Y+SLRxoGvJQcOZDpPZMqmEVn1XW GxfiaRwIPotCdo03OcagJaRE8R2WJwtUz2CnvrGII1EyJjzKi0tLGliAzNkdYm3bqkxmOc8A AxAJnryWbFV2o04rjiY4o2cxEzySSE9j2wYs4XBn2KjOrckjRN5hQvSxwuPcDcz0PJGxW07t 5i37CrMKyZ6Lq1Mg37oKxZMxTzxRA9v5h/ZRWtgSnvbMc1W06EqlvA217ImHxI/qBVbUdllD w9Qakc0HItMU2XAjklpEjqq/EA6CxTaAqNInRA0thV8k4MfYh8dCYQH1Gx1UX4hJS2NLentQ aP7SrWmWECHarP7MwoqPykx1UrFUDRqBvAEEHmFWORWLfEwLg2j3UPY+EbUxLcwm8lW3x6T6 Alo1MEa+al7vYSKodHB1/JapM208MbpaT5dlW7OqNqujqFb7w4EucbQ08db81Q09kOpkPZUH uEE1A3fpvOmnXj2Kzm2tiOomR4mn1Cn4XbtSn+K/S3zhLtDeRj2FpaZIPJRlDUeHIgEFS8Pi mh7Q4TPsqduIaP78Vc7IosqPaSlIFrjsJTe2WkAxPC/cLGVm/DrAttc6aei0218C+kcwk0zr 06LK42pLgRp/dPQXuIxRcATeytqmKLmM/wBIWTw+ILy1vX9hbPEYH+W06ENB6aKyV2HYdUHH OsU6lXhDxNIumOKRrLdfGQ65gEgR9Stk+mHCCJC8x2dsx8kh3i/Q8Vp9n7wFvgfrMX4J7VKv nbMpkEBsdQTZQyx9PwuMtMwfoQpuH2gx41Czu3dueINEQ12v70VCom18HBzCIMT3VSRyV08m pTJ4WKp2NN1OSER9EnVVuPot5weitq1e8AKnxzCe91C4q6Ti1wc0wRxV2duF9JzHWMRwHmFn 6ocDGiEx7tPopVpcnCZmy2x9lBe94s5v1RcFjyLHorOpTBCkM/UCYykSbKxq4cB3RSaGAHNB xEo03QmindXNTBANnNPtChDCA8VWjRw5K3E8JRqWDbNzb5+anVMIwt0B66FMKmqJQM8G6tPg ctEKthJ4JmHha024J7wlo7PewyWWjUEGPJFcRF0FTKUKW14iylU8JSNKYkjjx81T1xkJi97I LSQ43XU3wVAOIKLTeXINaVqxyqqFQzoplWQOaFSrAoI+o/wp2Ge283TazTHRQ3NM+HVBVMdh czvCY7qSyiRqh4Og4XMQi1qxDkyI+hxQapKM6tGqPTqtPEICvZiC063tKl1NpF0G/CVFxLQ4 hEow3RSCtwbnHSytWbKIHAKLSxQjqnfxkwGlIJQwnNPa/IhU68hAqkygll99BtonfDVVT1Cn txEKdAtZhjRDwVMOJzCR9VMp4hpGqY9zRonCdjKDYkAdlDbiot9FY4fx6o1TBDUT1lawKt1I uHTVR2YNp1F1c/dCLIdTCxfirhhYXCNF1NJACjBTaUEJwK2vUUXMVYYmiF2Foibp7TahglSs PhuJU91FqAbJWpEfUgKpxLiVYPqCFFLwVFpKyowwbKnxbdQtTWaC0rNYwXUWhVGihPfCkVHq BWcpbYAVqnJQ3ao/FBqCFFdEGpuCksKrw/RTqTlIq8wjrKZwVfgX/orAmFrihGquUdwUiobq O4J2NMUWsVBrBTq0qDUCnTfj+1FjBqVUOKt8cz9VUON03o63iHUcoFUKa8qDWcnHLyIxKSVz kkqnOa5BlGcgHVBlXJAuKAVPsmNTwEG+oSExye5yE660amOKYETKmlBmOSFKueUgYSmlc5ya EidKRycQmlIAwiNdCaQuGqAdVBB7pjNUr73SM1TTT3NQS1SK5+SjlMg3hRKlNTHINUQlYFdW bCjuapbmzqgvYpUjOppmVSHMTC1MAhPATgxEITiKHCROTvh8VSA5Ts64hcgjc6X4p5ppC4sQ NCNxB5+6L99KhwngJaGk1u0D+4/RPOP6lVsJzSjqSzGLBRW4oc1TueuFRTcAuxiAkdUVMKxG hSnEuU3AlxC6AqtmNIRW40KeoTgwckJ+HB0QxjgntxQRoaKMOAotfBzpYqaysOC74t7o0XVW NwTuJXU6ZbdWRcCmGP7IHVXVbhRvNXf3RpHVRK+zhAuQZ/dkJ0hMqkJ7al06pgHgwfVFfgfC Pogkd9SbfomB10SthQ02mI94UcaoGllRZqQdIslzRHdQ21oHVd94cL+xQWmrxlZr8MXQJsDa 4jiFmpUnC7TDWxbso+MPiECARI9UxBG4ggRzXB4CHSIgykDgkadRrNDXZhrxGqBhTNS6FVcC nYdggkaoIuLdDoGiHUokZZ4iey6qwzKc4p7I5juqX7zaDdBCaBdLZWLbZ5bIvwKtsFi4zAgO Y6GkHkAf7KgpMgE8modN9plBaSJgv/1R5KNUpk6XUpjuaKKQYQ7pKNBVCm4mLBSfur8hcBpq OnMIeJcC4kWRKWJMaqdB2CubHv2RsU4gkE9jwI7qK5oBzBJUeCB3lBWJox4gNOsRKnU6gAWe m/RT2Y0RCSdJuOILQUNg8A9EFrgUyo/LbhdMx2Olw7qe7iCqT4yd8Yk3KAlu1K6jTlyDVdEX TBiy3TzSoWFKkWvDuRmUlXFPcbkmJjp2QTtIm0JKdQFJNW+G2rDQ0harY22soYCLEkeU6rBF wOqn4XGxlaOHFa45JsenVdrsktjMOPEfJVOKx9Cfwx0FvOIWabtLxTeen6IGKxJc6Vp2JqXf BeI5qo2ps+kGyCNCdeSqhWcIgwhY+oSweIzdK2CK6veFZbFr5XdQfcqicHI9DM26iU3s2Ce2 pTBsQdR15LP7T3KY5xdTgTqDp5LNbH3hexrgLGR6dFe1N6iOJ9lpLsFwG7wp68+F1I2xj2tZ HGIVPW3nmyqMbiy/j0TIT415CscHUzKjpVospWFxhDuiWg0+zWtFaDoeCJvDsQlpfTHeNR26 KrZiCXB3EELV4Hacg5uCrRvOorsuM0IdDD1qlSTMkyeS9LdRw7iTAnj+VCqUaLQSIS0W1QKZ ZSIOoCpGvlXGOxTTICoq1PKpyICoYdHdBrMngn8QSlr140ULirqATBQa1RukIuKpk3CgUxz1 S0s0U5NtFcNcHMF7wouHyg8EWo5g0gdk+pK/Egtdcz1Uunjv3KkjDNe2+h06qtrYQNNuaNHF kK+ZsJmaAoMFEpsPFVpWjKtdDw+JdJEmE+uxRwCEqels2qQj0q8GVDY8ECVIzt5pFpJrY6BY KJVeCFDdmLja3BSg20FMaLQrRbgnPaHcQozhCLQQNIz8LBsiUaJaZCPVC6jUjVAHaS6x7JX7 OaAHCQQb3kHy4JaThKmMGYH9yhNQK4JbAQ6WFMJ2LrFuoUc4xxCCWzW2AUfE4abkqLQq1J0R KrnngeyCOcwFvqomSDYlSmUHxojU8KDqnoKwhwvBjsjNr8wVf02NgCAVXYig0n93RoKx1Y6B S9m0xmzONwREwR1kI/8ADW6ifJArYcjQFK4ha1yAbR5JjwCFBp5nRz07d1b4XZJeLmE5iQOF pctFJxNK3VTqWysvFFq7PLhAF+fLun1JmA4hyucNTBAKJ/hh+rXj0d84Xfwuow3i3X5KdBa4 eg1Ff4bKLQaQLlBxs6ytMQJVqTCM3DAtmVWMJATm44i0wFQFxVIKIx5B6IoxAMgoFYcUGdUq hPoVZVPVN9VYYJvEpVNi2GihVW3spIqWQiVmkP7mSEE4QqYcRaE1rpSJCrUyAqHHsWuq05E+ qzm02fMpBlsQY81DqSp9ciU0OCTbBW06d03E0FYmCUPEUZ9FFjaKlrYUqkVxop9JqWlrPBCw PVWRcoODhTlpiVgLkIlHeEB5VnEesLKurKwqlV9QJNeP7UmN1VNVEHorvHBUtZql6uH+INTR VlVWLzZQKoTjm5YjOTCiOCYAm5TUFyO8IBTBCulLCaUGcE8BNCIGpB9NubJS5QiQhlbNSSmP CI1q6pqkAYTXJ5CYQkA4SwnQmuKQNcmlLKCXJBxSFcuIhAHoPgGRqD8lHFkRNdqqRTqn6IOq OShJkEQmVG2RoTCEaNCyIZbqpb2ID2qbBtCc1DIUtzUIsQNgtaiPalDf3ZHYxOFUVrE4tSxC dCaAcqQhFLU0oAJalhELVwCACWpQiOakDEAJzUgYjZUmVBBmEwBGyymFt00mATZJiKZA6/RH YLyjVoeL6gQglZmhDNREcEIhKwyZrpBXM6ptQJkKdBKOOdxJ/fZEG1oAsq5zkGoTZKw4txtY HUFGbtJnNZt70zOoU1zcWODgnjET1WNOJjQpW413Bx9UFY2YxB4glOfiLSdNFkGbUcLBx+Z9 SpZ266ACJCVLq0tOqDcLiAdQFRs2uIRKe3G8f1Ul1Wj8M1x5JjsEJso9DbNM2B76/opjMWCC JF/JVBoB2DPSFKxNKWgcZSNqDv7otR9lSLFZXp5dFHDjyVo4TqLIfwRP7Cmkg/GOhUihXDey M/Dgpv3exCBQfvCfSOYwDdRvgEIlKk4GUEM92WxCfhY/Eolcum/Hik+IQLI0SzZWaJnjZdh6 MhVJqeqn4M2zA24pyEmNok6Lq7DEzpw5IZxQBnirMVKBwzswGZx8L+LSOE8k9BRxxXB0Jf33 TIN7aX8lBil0gIRCHmuiVnRpqjREywjYExUbMQbXv7IBrTZK18EFExC7xdNkh1OBwcIieoUa q2yD8YarjXDh5qtFogpE8UV1CAoxKe+rwRoaPwxb8QZhIEcdElei3MS3Q3S0KeplcWFTcSIK cX906my4I4LgfCiU4CXVNSW0iSj0MI/NwCiVMwgg2RKW0CCOITkJYUsLULkN7XB0HUKZRrGx a6QR6KLjanE6qk6CqOcbJn3d6RlYi4RW44wgw/uz+SZ8It1Cm0sQSh16jgJIkdwgB0wFJFME BRWXUtthqrgSP4c0jW6G/BQNU5mLgaplTHCIVQaR3U4ui06BdokfVGqk4XHta3RMFpF4IBCs 6e0HBQqWOa50KRVN7KiWOHx4M5gEmMxbSIHLRRaTQQo9SpB6pVOjK2M5KO6rOqbVImU5z25V nlFSI+IiFGAKY+vdGZXEWUyK0Qiyh16N5Ck1a55ILahPBaTFaHUamOZKlYhkqKLIsCz2fVtl 8x0QcZTg34oGAxTWvv5d1O2nXaRbokERrVznqOx5Umjg8wmbzopWjVblcaRB5hLXoHNY3T2Y twF0gVrCYXVKR1B+iNTrSkNRIgRWIGiQ4sylNW6fSAIjgmATUJKnYGjJsJhH2bhqZJkAkzry H9KlMqsYfCPD6+6AFisGALCCoJA5qbisbJMaFRW0M2iAa2pCl4euVEdh3NR6DT80JoOLcSm0 RHdSvhlM+DCCOouurPD0pGl1X06KucDTDRzEK8YVEFIwq7EEyYVwzFNiNEdjaZ5LTSVRgMDn udOUwpL9ksF495T6+Kaw29EAbRDjH79UHILhsKCVOZsumdR7rO1sWQ6yl0NqONuPFIaaNmAp gRlEeRTHOazSw6KCK5I1UCu4k3KC0uP4g0mPnZT8NjWAZp/RY7E4UxIkeaAzEuaIkwlaWm5r bdYBEqrxO1g82HBZr73ms4ieCa15nwyeynY001LFg902vXJsqvC0Hk3B+Ss6dIgeIJygImEp ogpldhUzA1AIuns0Zmyibgwm4jAOA5q5qY5gF9fRVVbHSbJhRPokGSrHC1LJ3wwdVLw1EGEq K4BR6r4Vm7CDgqbG0yJU6ZhOxkItHFhVb2poU2Beuxgiyo9pVJSmeaHWIIukGUxj7/JRmvVl jqevRVRF0q3wSadS6lRKrc6O2qpWdVbCCNUQuXAJVeKwwTrKyYbKpw7oVjScES6VYK9qiPCm OKiVVrLskOqFBraKfWCg1wlWuH2p8YJCpKyv8UJaVS1aai16nFf6q+qVCqhWGIbCgVERlyxG cEwNRSExW4zXKOQpJKjuEJg1IU4FcUA0FGbohpcqQfUbkgaihq4tW69hEIZKkOFlHdqkAnJY RMqQqTCJQnorkFxSMyUIBEDU2EBzQnPF1zAuebwjRUjkwpxSEJxIg0QpRZQXJk4psJURrUyR nBCq0zqpjmodVtkWDaEWITmKVlTHMU6G0TKngJ7mpExTatLimZFIamxCCCLUzKjFqYWpgEtT WhHNNIG8EgHlTosiFqZCCMTCE94uuy2QVDyri1EypfhymkGFzXQnwmEII3FUgRm7SPqq8qxL lFexIIbk0hHcLoLgkYTmShFqkAIbmpU0OqFHKsK1OyiOYs6qIZCbCM5iZlUmaCuLkpCaQkZ4 rQoGLxHIx7KQ+VT4wahCae3Fn+9kdu0SPzO9lTSnZlcS0mH249unuT9FY0d5qg/f6ysZ8RGp 1imNN5h95j+Ycf3KsqG3GG0LzynUVzg6sfubJC4tszGA6JTVKqdnVPkFo8I3mrmO2d9IPxAn isrtmEYdWg9012xqZ0EdQSn409lU8sdYpPugAjgp53fPB3qhO2PWGkHzU3GjcQH7PnQplGg5 tlLqCo2xYesX+iC3Exq0juIS0ESs10/vVMeXQ1sWBzAde/mp/wARp0UjCPa0+ISOPH5IGlaC 4C8qTgMaAXB+kR3UwtaZjTgoowLZRog69NmaWacP0QqwOvFSauCJENA9V33J8Q4EA6WmEaCL hyOKlva1/CD3UOphXNJH4hz0T8OCRbXqmRRTKa5plJXwlQXI9DKiCoZglBrGi50/splauZug U8RAT6eM5wQkB6NQ8Foti4Wm9w+I4wc2kDRp1Kz+DxYBJjmpuF2oxrpLeBvy7BBaPx+GFN8B 4c03B4joVENTRRzWaTrabSnvbEEFA6rA4logFDc9s2Vea5JulLkDqt8zgOij18Q4xyUc1iQL ykFQpjqm0q1lKwlZuaDyt2VSa0p1F8JFcV22CDlXNfIgqFQqw0p1N6cieqeyiIsV2IokeyA6 pEQn1sW7yWmh1CydUmUJ0yEEMIT0Wkt4BAkJ+CotmDonC8Don0qcGUyolTDAGWqZhaxv5KP8 SykYXijRCVK8GwUKrVkqwfh5EqBEOTLRHsEX1QKsAaqbiQqjEosVIFUpaQUbDtgLg2QFKo01 Ol6Ar280Om7gj12EhCoYdwOlkA5zLKH8C6uGU7FVr2HMlRFRiacEhdTJdqUuLqEuNuiJSo8p lRVBOYRoU1uJfBU6nh81in09ngalSavpVXOcJ7KZ92KcaAa6/wDupFY8kEDSoRN0lRIx17o9 Sg2dfRIIjGc0TLyRCxHpUwEBXsY7MjUplGqCT4VHuDcFMCVmxdHwOIABUKq6UTDUJJQFjiMY 2FHoV5MaJlXAjLrdVwqFpkFA0vWNJVrhtmNc3xE+Ufos5RxTipuHxb2nknE2L/DbutzfiMA6 Hj2Kta2wmAHLItaCsyzHvBnMfVWI22XNvqOv0V4osqK3Cw6Co1VxFgjnFkmQgvu6VY0A7DF1 yTKZTpQ5WrntyqGGSdUlw2rh5KJR2a4mwRX0YOqPR2lk1CQdUwdVgEgRwgz6qpxGLOZXj9r5 mwOapMTQzGQEbJLwzHPbxNpTqeABN5Psi7PqBgbfTXqj18aDoopIbtltnWPL6qfgGMpmePNR XYmygVnmdSkTWfHb+ii164lVVLFGLz0RW1cyCS6leU1mFLhYwUV4bknkq520spsUwJXaRMlV rnQUZ+0pKiVahKezHGMIRMNtOHaj9VWOmE6jhiSIvwTJrqWODuiFi25hZJg8FDRPBSXMCqIZ uvRI1UYvhX+JYHCFSVcKQeiLiEd1dRarzyVgaAhRq1JRYGbxVUk9VCKvsVhJuoFTDiJWda4q 4hPaU4tuisapaGtYjMangJIQcEaEem+6GwJSFGTee03PKE8JKbrLnIxyTYjVyob2qbUUeotN rwU+KbZVVcevJW+MCratOST3+al6PDfSkxJMqE9WmLZKrKgRC5foByYQiPQyFo4zHFAcpJbZ RnpkGQuKWFxQZU/MhSnCUifVhTXJ6G4rczHOQwxEISJGY9MKe5DJSMF6EUchDhJRpEIMItRy Y0IB2HPiS1meInmmMajJpoJTYRUN5Qkrj4UEo9E2PZChMGwiBIAnhqaSFDIRcqTKgkYtQ3NU t7UFzUqAC1CLVIhNLUgBCRGc1Ma1ADcE51KLohauTADgmQpBCG4IAZQynuTcqkyOFk1PyppT KuK5pRKRjVMqNgmNJTS5zOKARCLmQiEEE9DngjEJkJBGrUog81GcFbOALSCq2rSjVIApClKZ Kkwqp0QnU5UlzbShwlVREfTUZ7IViWqM+koqoiQkKKQmkJAB7VWbQoEjMLRqrsU1GrUpTkKs quBUnHYfKbaG6iyqSUOR2lAlFYUjiVTcrLB1FV0zdTsGbwpU1ez6wBE9FqMDVnXXRYnBVbha bZ1db8VY8ka6joOylNCrcJVNlY0yt2A7QnQmNKMwpaBpp9EN+BY7VoUoJ4apuJqapu/SdeAD 0UGtuyfyPjvdagNSZFPQ5WLfsWu3Qh3aUE4WsDJYfmtwaXJIaAIuAl1N5/8Ae3A3lp6gqY3a lotC2D8Cw/lCBV2DRdq2/NLqGWGNBOgThVZyEq3r7oNuWmBymFXv3XqD8LxHWT/9qmwIz6o4 f7pRh2RMBMdsTEN4A+o+iY6lWbqw/vojQ0DiNnA3ZY8uCrhQeDBBHcaq0GJc0/hcP+1yb9/H H3RoKwucDCOwSCpLxTdx900YZvA+4UhWHVS6VfS6I/AD+pBfgTwSM41uSEcTGqU4dzR+EqOK JJuCO6AmNxKI3FqHUpEHmOaA6qns1v8AG4qRhnglU1F8hSGvhGw0Ajqi0oVDSxE/vRSaeIjQ pykuxh+MovwVTU8ZHFSG4880dyqzFI8k6nTkxCrhtDqptPEiPxX5peQtLBtEDVTKGHaQqint RuhF9JRzihwlaY5yl1HrUstklOqQortpA2untqSJWksLqnUapUfEA5pTKWJjgpHxhzTHVGeX crKFiZIsFaurgKL9+bPLqlRMVSahA4pcPjHTeVLqVGvQjQHNRtXVLZixF0h2goBalFHkjYuK YMfwMITqg5qDVonXVDDHcjHYqbS0e+gXFSsLSAmdZ1UNr4UgtdEwY7KQkh4lOqNnRR2KS2sB xSFQDQfOn6KVToEiCpAqhK2sEiQhgXOKWrhHBWFHFXgJ1V0wUBTnDuRW0HRqrFolEdgTCC2q qYIKe6iXcFL+7QbprjBsmNnM3fJF3eSi4jBGmZnorA7UIhAq1s4M8LoEVVSuTZB+DzRKghxT ToksSm8BFdiTwlQ22N1o9n5IuP7dU4VU33ojWQubiCDMKdtIsHdVgE6KhFpTxwH7lGOLzcFT FpEFSKVTgqlCRUxB5odPEkHVNdSKZ93J1Rsk6tjyQFHdVJQjhSAhiQlsl1h6YASVK4CqBVdw TjWcdUBYfHzaGEYNVXSrQpJxllNKrPDYXOYU2ls4DU6W5e6oaO1MpViceXX5pJa7A0mBmWAB qAbqs2jhqcEtABvpZVbMa9os49lX4vabiLwgh2vcTA4rsRsarlmW+9u6iYXaBBur/C7SzAiy ZqGlgXTcqU6kAFKxeJH+yrauLVSAo1Vzs/DgX4/VZx+I5d1a4LHEW6J6KtO1QMc4hSsNXtdQ 9qYkGw/ZVyM1W3FXhNriQkZEqS29k1Kl5SG6nVcFeyr6wyqbiEbFNtZU2JerGvXKqK5lY5TT TFCm6O0oJCNSKzaHgrpTS5BNZM4n0ncE9xUak9GJWeToxHplPhCoo5CnEZI1QKJVCm1FEqrT ZRWYoaqseFa4r/dVjyh28N9KrFC6rKrlaYrUqqcqjXP6BchwjOCYGrSOKkiyg1dVcVGeDrCq HpgMpITiU1IEhPXNXFIafViYQiQmFbgiE5EcgkqTNchwiFIQkYZCG+yMSg4j8XkEKAJXQn5U 4NThOpNskaE8JYTTQqjUN7UUm6YQgjGJA26KwXT3a6JkFCVoTy1c0JkQBIQiBLlQlHcEEhHq IYYkAzTSEKQ4IZCRo5ahlqMQudTsEA1lOTrCT4cEjkngQuLggAOCY9GcLIbmoCM4Lk5wSAKT NcIQyEV4TcqASURl7ITU8JpsBqNgwuIUpgB1QKzYKZAOCHlRniyCUiMcUrqeZp5gGE1wXAwk Fc5qYQpdenxCiuClUDL1z28VzrJwAIISNHm6ZURXNhCcEqcRqrEyEfIhuZCkzAm1GoqQhMVT Y/CyCePJUDmxZbKtRWc2phiDMaz7JpV4RGFDCewJURIpm6mUqkKCzVSaZUrXWEdy7rQ7OraL J4Z3BXuFqJ4XScpuNvgK3srrDPWW2bU9x79Vo8LU4dAuyXccuU0sWI7FGpuR2lCRwntQwntQ YoCQLsydCRmwlypQnBIzQE97ISkJ5Fk9BwEodbDhEZYp1S6NBEFKyQ0lLZSlCc2DCNBFODad WhRq2xKTtWA+X91aBidl5o6hmau6FIzFu1lHq7liPA8g+s+q1wYucErhAwNbdnEN0cCFEqbM rtuWi3KZPsvSywFCfQi+qm8YeYur1G603+QlC+/DjI7ghel1MIDwHoFEq7JpkXaEvGe2BbXa TdIcPTdwC2L91qB/KfIwodbchty1zm+du+inpQoqFCmAggCdLeisqu6VQfhqT34+yhP2BiW8 AfX9EutMCphBq0x01XMpEhOfhqzRem7yuhtxBbOZrh3BCWiI5pBghK2twSffWnl3RadFr9HX UXEBCsitrHRLV2fl6oNRkJaIVuJI1RqO0FWVZKLRw5hEgWH8Q8lOobUIbGqoX0r3UyjVbEEe a03SWb9qpg2oeXuqt1UHRBrWOqO1ORoG48HjdCdigqhthqopxIBU3Kq0v/vAnXyUilUnissc TyT2Yo6pdjalr7qRaLFZRuNPNSP4gY5I2VaDLyKlUGHKso3HuGhUrD7acLGPJG02NGMOSZyy iV8TDYLTKhbO22SDJHQ/qpL9stH4sp7TPyVJu0YCeELhRUxu0qL/AO655ZzT0naOaXBAdRcO qlhwnVGpuBOqfWltDwrSDdWDmptWlxXF8JdS7BOfBR24+0aIAAJhTauymRYkduCWhsKq5uWZ UZ1RqbUwZiJSU8LdPVBtYiEGk/VXL8M2NFTuaAbJaVKE+k0nxKzpbHa4CBB/fBVlcI+FxpYI vHySVanYnYzWAEE2v3UIsI/siv2oTaUjcTIREh1cE55kR1FwU5uDDTx87qZhXgotZgOhVHEG pSmyjfALTYKanhiZoolNYxxOllYjDIvwOQQnaDUZZRfhyQrWphzHRQ6VG6A77uIUZ1IgwrRg 4QudRHEILapZSkqS/CWupgYOATjRlKlaqBhSDPBSKZhGfSKX4SCEpV1HxFCRICKKSL8YNF0B SsBlTaEi/kuqVASiNcEQOqsLggjAEn8Kk064lWFCsFpIAcPs219fVW+E2W3U3UdtZovKkUtp AK5IjLabUaIVFtBil4jHg6FVuJqyFSJDaAUlj4UWkCiPSkUk/GCC+lOqhPrQisxVlpqBBxtJ qz2KYrnaFayz9aqsuSTTXAF6YKie82QmrkrQcGQhZUWmbJ7UKhaLEQLgFwCzyb4JVFGKDSKM 4qYeURnFR3qS5Q3KkoGJ4+aq6g4K0riyrKovIVuzgVmKZxVUQrjE8VUxdXG3J9Blq6ky6KQl pMvKuOK/ZMV+FU9XVW2NdZVD0wYAucxcUsKabmooYhMF1ICkPqQoUrly3EDKRy5cpphuKa5c uSMObprhxXLkzcF0LlycI0lEfw7LlytNCcEoFly5IjUVjVy5MjiE2Fy5CC5UxxXLkwDCWFy5 SCEJhC5cgGOS6rlyAC5NIXLkA9gsguK5cgwoQyuXKTMcuXLkjNIun02SuXIIhsnYgS2Vy5Uh DYh1RBXLkgaUJ65ckA3GECqFy5Kmju1SrlykzXiyC4LlyRwIhCcVy5I3QuyrlyAR7VVY6lNj xXLk0s7VpwY801mq5ckBQjsK5cprSJtEq2wlQ27rlyQrSYKqQSFp8C+R2XLl1cf05s1tQcpD XXXLloySWCye1cuQYgTwVy5IOTly5IzgjNC5cnAR7bpq5cghaLktRt1y5MGFqO5oLFy5M0cJ CFy5MFCe1cuTBuS6Z8NcuQQeW6l02yCuXICO/DDVAZTBXLktGR2GbyUapgWH8o9B9Vy5LRIO I2FQdqwe3qo53UoxIkdiuXKbjAqsVsUNPhe4ehVNj6Lm/mny/uuXLKyGq6uJLZNjHkpVLHnk NFy5SYr8XPBL8S2i5cgGMamVG3XLlNAVQGNSobzYlcuUqjqLdFNrvhlly5I0D4pRTVIC5ckT m4ooz6pgLlyZEbiHAaotLFO5rlycKpr6sgI1OuWiy5criEqjjnIn34g/3XLlpimrfCYxzvCT oi1Kt1y5Ukod0VthX5miVy5CaJVpgBRqbRcLlyZOq6IVPBsOovzXLlnkqJP3Fqrdp7Pa38JI FrLlyzWq3U4StHVcuSNc7MZr5I2NbELlycMLD0wWk8oSubdcuTKhfFIMSpuFxB5ae65cmkdz 8wKh0m3XLkBNw9MZlYvwbS0nRcuTJS1KdyF1PVcuU0jqjFDLOq5ckA6jiBqoVV0lcuTMGdE1 9UrlyAdRqGyP94IIC5cqCS3EHRTsPcLlycIoYjNoArlyuJyS6dMRCq8YYJ81y5bRKmrVipFN 9ly5RTQNoFZ2s6CuXLPk+muCOahKJTcuXLlbDZk9pXLkBKanSuXKcmuA1FyMVy5RGuQLwolR cuWsQhYkWVU9slcuVOvh+lZi7Aqse665cqjXk+jgi8PVcuVxw/lW4l0lQiuXJVQaVcuSM4FG bouXKTj/2Q= ________________________________________________________________________________
Subject: Re: Problems Soldering DB-25 Connectors
Date: Sep 21, 2016
-------- Forwarded Message -------- Subject: Re: AeroElectric-List: Problems Soldering DB-25 Connectors Date: Wed, 21 Sep 2016 21:21:24 -0500 From: Charlie England <ceengland7(at)gmail.com> On 9/21/2016 7:33 PM, Art Zemon wrote: > Folks, > > I am trying to solder 20 gauge wire into DB-25 connectors and having a > tough time. The conductors just barely fit into the cups on the backs > of the pins when everything is "dry," before tinning. After I tin > either one, pin or wire, I cannot get all of the conductors into the > cup. I end up with something like this: > > I'm afraid that those are not acceptable. What do you think? > > If they are not acceptable, what is the solution? Can I trim a few > conductors away so that the remainder will slip into the cup? Or > should I just give up and switch to crimp pins? Or what? > > Thanks, > -- Art Z. > > -- > http://CheerfulCurmudgeon.com/ > > /"If I am not for myself, who is for me? And if I am only for myself, > what am I? And if not now, when?" Hillel/ Hi Art, For background, I went through several careers & a hobby or two with a soldering iron in my hand. When I started wiring my RV-7, I saw no need to spend the (relatively) big bucks on crimp style sub d's. After hours of work with a soldering iron, and a couple of minor revisions to the wiring, I threw in the towel & bought a batch of shells & machined pins. I've obviously got the skills to do everything with the iron, but crimped pins are *much* faster, and as others have mentioned, much easier to make revisions/corrections to the wiring. If you decide to stick with solder, I'd suggest tinning the wire, but not the terminal cup. Instead, try a dab of electronics grade flux paste in the cup before inserting the wire. Make sure you've got a hot iron with a clean & tinned tip. (Low heat and/or poor heat transfer can damage components before solder flows properly.) I like to mate the connector to a spare mate before starting the soldering process. That way, if the plastic insulating body gets a bit too hot, the 'mate' will keep the pins aligned. If you can keep the stripped area short enough, you shouldn't need shrink over the pins. Good luck, Charlie ________________________________________________________________________________
Date: Sep 21, 2016
YES On Wednesday, September 21, 2016, Charlie England wrote: > On 9/21/2016 7:33 PM, Art Zemon wrote: > > Folks...... > > Or should I just give up and switch to crimp pins? Or what? > > Thanks, > -- Art Z. > > -- > http://CheerfulCurmudgeon.com/ > > *"If I am not for myself, who is for me? And if I am only for myself, what > am I? And if not now, when?" Hillel* > > ________________________________________________________________________________
Date: Sep 22, 2016
You and everyone else who hasn't spent a lot of time practicing soldering th em. Two choices. Keep trying until you get it right or my favorite: Get rid of the solder connectors and order some crimp ones. Sebastien > On Sep 21, 2016, at 20:33, Art Zemon wrote: > > Folks, > > I am trying to solder 20 gauge wire into DB-25 connectors and having a tou gh time. The conductors just barely fit into the cups on the backs of the pi ns when everything is "dry," before tinning. After I tin either one, pin or w ire, I cannot get all of the conductors into the cup. I end up with somethin g like this: > > > > I'm afraid that those are not acceptable. What do you think? > > If they are not acceptable, what is the solution? Can I trim a few conduct ors away so that the remainder will slip into the cup? Or should I just give up and switch to crimp pins? Or what? > > Thanks, > -- Art Z. > > -- > http://CheerfulCurmudgeon.com/ > > "If I am not for myself, who is for me? And if I am only for myself, what a m I? And if not now, when?" Hillel ________________________________________________________________________________
Date: Sep 22, 2016
To tin the wire, I first clamp the stripped wire into my padded vise. After applying solder, I immediately wipe the tinned end to remove any excess solder. I use an old washcloth. Reapply heat, pinch the rag between thumb and finger around the wire and pull straight off the conductor. This should result in no stray strands and minimum solder. -------- Jerry King Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460661#460661 ________________________________________________________________________________
Date: Sep 22, 2016
Subject: Re: New smartphone app for pilots
What? In 2012 there was a single Nexus model with a barometer. According to gsmarena.com it's now included in 132 Android phone models, including the S5 and S6. But we've also got dozens of free altimeter apps in the play store, so don't feel bad about leaving us Android folks hanging. On Wed, Sep 21, 2016, 7:25 PM rampil wrote: > > Hi Bill, > > You are absolutely right. These apps don't run on Android yet. > I am only a one man shop and that unfortunately requires setting > priorities. I might, however, point out, in defense of my choice, > that it is only quite recently that a single Samsung 7 series was released > with the barometer hardware. So it's not quite a massive > market yet. That being said, I do have a copy of the Xamarin > cross-development system, and playing with it is in the queue. Stay tuned. > > -------- > Ira N224XS > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=460649#460649 > > ________________________________________________________________________________
Date: Sep 22, 2016
At 07:33 PM 9/21/2016, you wrote: >Folks, > >I am trying to solder 20 gauge wire into DB-25 connectors and having >a tough time. The conductors just barely fit into the cups on the >backs of the pins when everything is "dry," before tinning. After I >tin either one, pin or wire, I cannot get all of the conductors into >the cup. I end up with something like this: Then don't 'tin' them first. In my Shop Note for dealing with solder-cup d-subs, I suggest tinning before dropping it into pre-filled cups. With 22AWG, the fits are not so tight and the process works well. When the stranding is tight, as with 20AWG, it's better to dry fit then solder. Bob . . . ________________________________________________________________________________
Date: Sep 22, 2016
At 08:22 PM 9/21/2016, you wrote: > >Be careful about dry joints, the solder should be bright and shiny all around >the joint. . . . which is easy to achieve with 63/37 solder featuring quality flux. > If the wire is carrying just signal, clipping a strand or two should >be fine . . . I've attached 18 AWG wires to solder-cups by trimming back excess strands. This was a system with long runs of wire where voltage drop was an issue. There are companies that make special adapters to put too-large wires into 20AWG solder-cups but trimming the strands is more compact and works good too. > (with adequate strain relief). The backshell is were wire-support takes place. Heat shrink is more of a hedge against pin-to-pin shorts by conductive contaminants . . . a thing that just doesn't happen in a clean work environment. >Power carrying wire demand more careful consideration >about potential resistive heating and voltage drop. Sort of . . . but pin-to-socket interface within the connector is the driving concern about path resistance. 20AWG wire is 10 milliohms per FOOT, 22AWG is 16 mOhms/Ft. A single pin-to-socket interface on a d-sub can present 3 millioms of resistance over a millimeter. Variability in resistance between pin-to-socket interface within a connector gives rise to the prohibition for paralleling pins to increase current handling of any one path. I designed and qualified a paralleled d-sub pin process at Beech that was used in both targets and production aircraft. This involved EXTENDING each pin in a paralleled array with say 12" of 22AWG wire before the pin-paths were joined in parallel. This ADDS 16 milliohms resistance to each 1-3 milliohm pin-to-socket variability. This 'ballasting' resistance forces the sharing of current across an array of paralleled pins. The short answer is that concerns for heating due to current flow reside in the pins . . . not the wires. Bob . . . ________________________________________________________________________________
Date: Sep 22, 2016
Subject: Speaking of solder . . .
We've had many discussions on the List over the years concerning soldering materials, tools and techniques. I own perhaps a dozen tools intended to effectively heat solder and the target work piece(s). I use solders of several types for both electronic and mechanical joining. For about the last 15 years, Metcal solder stations have been my favorite tools for joining everything from specks of electronic fly-dung on etched circuit boards to installing terminals on 4AWG wire. Metcal stuff has been readily available on eBay and I've pretty well outfitted the tool boxes of myself and relatives with these tools. I had recently had occasion to enhance a product development partner's tool compliment and decided to try a prominently promoted product line I saw on eBay. http://tinyurl.com/zddlb2t I bought one for the project . . . and a few months later, added another to my drive-stand bench. These have proven VERY capable. Good temperature control, good energy concentration at the tip, reasonably priced tips in range of sizes and shapes. I've found them to be a good value and more readily available than the older Metcal system products at similar prices. I think Hakko may be the Metcal of the Pacific Rim. They have a broad range of products and are widely represented. I can recommend them as an alternative to Metcal. Bob . . . ________________________________________________________________________________
Date: Sep 22, 2016
At 07:33 PM 9/21/2016, you wrote: >Folks, > >I am trying to solder 20 gauge wire into DB-25 connectors and having >a tough time. The conductors just barely fit into the cups on the >backs of the pins when everything is "dry," before tinning. After I >tin either one, pin or wire, I cannot get all of the conductors into >the cup. I end up with something like this: Art, if you do not have 63/37 solder of known pedigree, drop me your mailing address and I'll send you enough to do a handful of d-dsub jobs . . . having a good solder is 75% of the task, good iron is 20% thus making your probability of success in mastering the last 5% more of a sure thing. Bob . . . ________________________________________________________________________________
Date: Sep 22, 2016
So much for my Android "guru" Just out of curiosity, any of those play store apps have a kollsman window for altimeter setting and density altitude and performance computations? -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460669#460669 ________________________________________________________________________________
Date: Sep 23, 2016
Folks, Thank you for all of your advice. Last night, I did some more experimenting and achieved much better results. My solder-sucker doesn't completely clean out the old solder from the cups so I will try some solder wick tomorrow (no time tonight). I got most of the solder out, trimmed a few conductors from the wire, and was able to neatly and securing solder 20 AWG wires to pins. It was quick and I have connections that look safe and secure. In case you are curious, unless the solder wick works miracles, I will discard the DB-25 connectors that I have "messed up" and start from scratch. I am not driven by any irrational *need* to salvage these things. What I thought would be a simple assembly process has turned into a great learning exercise. I'll let you know how things go later this weekend. Cheers, -- Art Z. -- http://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Date: Sep 23, 2016
Art: Please send pictures so us newbies can compare thanks for sharing!! E > On Sep 23, 2016, at 7:22 AM, Art Zemon wrote: > > Folks, > > Thank you for all of your advice. Last night, I did some more experimenting and achieved much better results. My solder-sucker doesn't completely clean out the old solder from the cups so I will try some solder wick tomorrow (no time tonight). I got most of the solder out, trimmed a few conductors from the wire, and was able to neatly and securing solder 20 AWG wires to pins. It was quick and I have connections that look safe and secure. > > In case you are curious, unless the solder wick works miracles, I will discard the DB-25 connectors that I have "messed up" and start from scratch. I am not driven by any irrational need to salvage these things. What I thought would be a simple assembly process has turned into a great learning exercise. > > I'll let you know how things go later this weekend. > > Cheers, > -- Art Z. > > -- > http://CheerfulCurmudgeon.com/ > > "If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel ________________________________________________________________________________
Date: Sep 23, 2016
At 07:22 AM 9/23/2016, you wrote: >Folks, > >Thank you for all of your advice. Last night, I >did some more experimenting and achieved much better results. Yes . . . the learning curve is rather steep but it DOES take some practice . . . > My solder-sucker doesn't completely clean out > the old solder from the cups so I will try some > solder wick tomorrow (no time tonight). I have solder-sukers . . . VERY SELDOM used except to open a plated through hole in a circuit board. Really most effective when powered by vacuum pump pulling on a heated tip attached to the end of a soldering iron. > I got most of the solder out, trimmed a few > conductors from the wire, and was able to > neatly and securing solder 20 AWG wires to > pins. It was quick and I have connections that look safe and secure. Good for you. Solder wick can be VERY effective but there are some pot-holes. The wicking needs to be FINE and impregnated with a good dry flus. There are many good ones and many more poor ones. >In case you are curious, unless the solder wick >works miracles, I will discard the DB-25 >connectors that I have "messed up" and start >from scratch. I am not driven by any irrational need=C2 to salvage these things. Try heating a solder cup then rapping the connector on the workbench to shake out the molten solder. I would hold the connector in a pair of pliers by the end-tab, heat the solder cup then 'whack' the piers on the bench with solder cup facing down. You'll find it is quite clean. >What I thought would be a simple assembly >process has turned into a great learning exercise. My 'lifetime supply' of Chemtronics wick is holding up well so I'm out of school on current offerings. I'll order some samples of current offerings on 'solder wick' off eBay. It's a whole new bunch of players since I ordered any. Bob . . . ________________________________________________________________________________
Subject: Current Status of third class medical reform
Date: Sep 24, 2016
Hi All, I'm switching hats here for a moment to my other pastime as a Senior AME to bring you a brief update on the POBR2 reforms. I enclose an article by Jim Frasier, the Federal Air Surgeon. I had several personal chats with Dr. Frasier at the CAMA meeting last week and this article tracks closely what he told me. I will only add that the expectation is that the NPR and public comment process will probably exceed the one year mandate (and Inhofe knew this going in), but the new FAA regs once published in the Federal Register will supersede the "no enforcement" clause. There is a lot in the air so to speak, that will not be settled until the major insurance carriers and underwriters publish for guidance both for aircraft hull insurance and for medical malpractice. I know the EAA says everything will work out, but as the law is currently written with the exact wording of the physician attestation at the end of the checklist, none of the docs I know will be covered by insurance for signing it and fully expect to be a litigation target as soon as there is a mishap. Oddly enough some senators attempted to add liability protection for non-AMEs to the bill, but the committee rejected that amendment. So as it stands, in section 7, AME, DARs and DPE as shielded from civil actions, but not non-AME MDs. Further, according to the FAA legal guys, doing the checklist medical exam (instead of an FAA 3rd Class), is not considered being a representative of the FAA, so it will not be covered by section 7. Catch 22. I'm just laying out the situation as it exists this week. I will not response to ad-homineum attacks. -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460695#460695 Attachments: http://forums.matronics.com//files/faafas201602abridged_723.pdf ________________________________________________________________________________
Date: Sep 24, 2016
I'm switching hats here for a moment to my other pastime as a Senior AME to bring you a brief update on the POBR2 reforms. I enclose an article by Jim Frasier, the Federal Air Surgeon. I had several personal chats with Dr. Frasier at the CAMA meeting last week and this article tracks closely what he told me. I will only add that the expectation is th at the NPR and public comment process will probably exceed the one year mandate (and Inhofe knew this going in), but the new FAA regs once published in the Federal Register will supersede the "no enforcement" claus e. There is a lot in the air so to speak, that will not be settled until the m ajor insurance carriers and underwriters publish for guidance both for aircraft hull insurance and for medical malpractice. I know the EAA says everything will work out, but as the law is currently written with the exact wording o f the physician attestation at the end of the checklist, none of the docs I k now will be covered by insurance for signing it and fully expect to be a litiga tion target as soon as there is a mishap. Oddly enough some senators attempted to add liability protection for non-AMEs to the bill, but the committee rej ected that amendment. So as it stands, in section 7, AME, DARs and DPE as shielde d from civil actions, but not non-AME MDs. Further, according to the FAA legal guys, doing the checklist medical exam (instead of an FAA 3rd Class), is not considered being a representative of the FAA, so it will not be covered by section 7. Catch 22. I'm just laying out the situation as it exists this week. I will not respon se to ad-homineum attacks. Thanks for the update, IRA!! It seemed that this had gone into a =9C Black Hole=9D and would not be seen again until a couple of thousand pages of regs had been written, had you not come forward with your update. Even if you can=99t show much progress, I and probably many more on this list are interested in any tidbits of information that you can dole ou t. Please fill us in whenever you receive an update. Roger ________________________________________________________________________________
Subject: Re: Current Status of third class medical reform
Date: Sep 24, 2016
>From what I heard, the refs are mostly done and hew very close to the law congress wrote. After all, 70 senators and 200 some odd congressmen signed it. It has to wind its way through layers of review at DOT etc before opening for public comment. -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460697#460697 ________________________________________________________________________________
Date: Sep 24, 2016
On Fri, Sep 23, 2016 at 9:29 AM, Efraim Otero wrote: > Art: > Please send pictures so us newbies can compare thanks for sharin g!! > Efraim, Your wish is my command :-) Desoldering went well. Bob's suggestion to melt the solder and then wack the pliers-holding-the-connector on the workbench did the trick much better than the solder wick. I ended up with nice clean cups like this: I stripped the wire to the length that would fit into the pin. Here is a photo showing the scale (I am not going to solder this wire into the pin on the end). I set the wire into the pin and it stayed nicely in position all by itself, making the soldering super easy. Here is a photo with the red wire already soldered and the black wire set in place, ready to be soldered. With both soldered, I have connections that please me very much. They are mechanically solid, which gives me confidence that these will last the life of my airplane. (They actually look better in real life than in this photo, which has some terrible reflections.) Reinforcing my confidence in these connections, they were very quick. Since the wire set neatly and securely into the cups, total time to strip the wire, set it into the cup, and apply solder was well under 60 seconds. Previously, I had been fighting the wire and fighting with clamps to get everything to stay in position so that I could solder; it was taking me 5-10 minutes per pin with lots of do-overs. Hat tip again to all of you who helped me. Thank you! -- Art Z. -- http://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Date: Sep 24, 2016
On Sat, Sep 24, 2016 at 2:46 PM, Art Zemon wrote: > On Fri, Sep 23, 2016 at 9:29 AM, Efraim Otero > wrote: > >> Art: >> Please send pictures so us newbies can compare thanks for shari ng!! >> > > > Efraim, > > Your wish is my command :-) > One more photo. I disassembled and reassembled the first connector that I did (more than a week ago). I am much happier with this iteration: These wires are for the pitot tube heater. It draws 12 amps so I am using three pins each for power, plus one pin for the status lamp. These three 20 AWG pigtails join to 12 AWG wire which runs the length of the wing. Cheers, -- Art Z. -- http://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Date: Sep 25, 2016
> > >[] > > >Reinforcing my confidence in these connections, they were very >quick. Since the wire set neatly and securely into the cups, total >time to strip the wire, set it into the cup, and apply solder was >well under 60 seconds. Previously, I had been fighting the wire and >fighting with clamps to get everything to stay in position so that I >could solder; it was taking me 5-10 minutes per pin with lots of do-overs. > >Hat tip again to all of you who helped me. Thank you! You're gaining on it! My only impression now is that I would strive for better wetting/flow in the finished joints. Your iron temp may to too low. It could be a solder issue too. You said 60/40 . . . normally that alloy is quite satisfactory. Used it the first few decades of my solder slinging career. But I've had some 63/37 of some brands that did not behave optimally. What brand of solder are you using? I'll send you some solder Monday. What kind of iron are you using? Bob . . . ________________________________________________________________________________
Date: Sep 25, 2016
At 05:44 PM 9/24/2016, you wrote: >On Sat, Sep 24, 2016 at 2:46 PM, Art Zemon ><art(at)zemon.name> wrote: >On Fri, Sep 23, 2016 at 9:29 AM, Efraim Otero ><efraim.otero(at)gmail.com> wrote: >Art: >Please send pictures so us newbies can compare=85 thanks for sharing!! > > >Efraim, > >Your wish is my command :-) > > >One more photo. I disassembled and reassembled >the first connector that I did (more than a week >ago). I am much happier with this iteration: > >[] > > >These wires are for the pitot tube heater. It >draws 12 amps so I am using three pins each for >power, plus one pin for the status lamp. These >three 20 AWG pigtails join to 12 AWG wire which runs the length of the wing. These joints look good. I would use 22AWG "ballast resistor" pigtails. Here you are actually using the wire as a resistor . . . the larger the better from the standpoint of sharing loads across an array of pins. Also, be aware that the legacy heated pitot tubes have a strong temperature coefficient. A typical pitot heater for a Beechejt is 1.5 ohms at 0C . . . a time when the tube is likely to be turned on. 28V/1.5 ohms is 18A start up current. When the heater gets to 100C (typical high altitude condition) it goes to 2.2 ohms for 12.7A running current. 14v probes behave similarly at about 2x the current. What kind of probe are we talking about? If you've lots of unused pins in this connector, it wouldn't hurt to use 5 or 6 pins per path and I'd certainly drop to 22AWG ballast wires. Another thing to consider for the solder-cup connector is the form of the female pins in the connector . . . not quite as robust and uniform their crimp style cousins . . . so extra pins if available wouldn't hurt a thing. The work we did at Beech was entirely with crimped pins. I'm not suggesting that your design goals cannot be met with this connector, just that I have no experience with the parallel pins in the commercial connectors so if there are unused pins in the connector, bringing them into harness with the three already in service is not a bad thing to consider. The extra wire is a 'sense' wire? What does it do for you? Bob . . . ________________________________________________________________________________
Date: Sep 25, 2016
On Sun, Sep 25, 2016 at 3:43 AM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > > > [image: []] > > > Reinforcing my confidence in these connections, they were very quick. > Since the wire set neatly and securely into the cups, total time to strip > the wire, set it into the cup, and apply solder was well under 60 seconds. > Previously, I had been fighting the wire and fighting with clamps to get > everything to stay in position so that I could solder; it was taking me > 5-10 minutes per pin with lots of do-overs. > > Hat tip again to all of you who helped me. Thank you! > > > You're gaining on it! My only impression now is that > I would strive for better wetting/flow in the > finished joints. Your iron temp may to too low. > > It could be a solder issue too. You said 60/40 . . . > normally that alloy is quite satisfactory. Used it > the first few decades of my solder slinging career. > But I've had some 63/37 of some brands that did > not behave optimally. What brand of solder are you > using? > > I'll send you some solder Monday. What kind of > iron are you using? > Bob, I am using a Weller WES51. I have been setting it at 650 when butt splicing wires and bumped up to 700 degrees for the DB-25 pins. I can certainly try something hotter. I was worried about damaging the connector. I have two tips for the iron, the one that came with it and an extra narrow tip that I also bought. I find that extra narrow tip easier to control when working on the DB-25 pins but it doesn't transfer heat as well. I am using Kester 60/40 solder. Cheers, -- Art Z. -- http://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Date: Sep 25, 2016
On Sun, Sep 25, 2016 at 4:07 AM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 05:44 PM 9/24/2016, you wrote: > > > On Sat, Sep 24, 2016 at 2:46 PM, Art Zemon wrote: > > On Fri, Sep 23, 2016 at 9:29 AM, Efraim Otero > wrote: > Art: > Please send pictures so us newbies can compare thanks for sharin g!! > > > Efraim, > > Your wish is my command :-) > > > One more photo. I disassembled and reassembled the first connector that I > did (more than a week ago). I am much happier with this iteration: > > [image: []] > > These wires are for the pitot tube heater. It draws 12 amps so I am using > three pins each for power, plus one pin for the status lamp. These three 20 > AWG pigtails join to 12 AWG wire which runs the length of the wing. > These joints look good. I would use 22AWG "ballast > resistor" pigtails. Here you are actually using > the wire as a resistor . . . the larger the better > from the standpoint of sharing loads across an > array of pins. Also, be aware that the legacy > heated pitot tubes have a strong temperature > coefficient. A typical pitot heater for a Beechejt > is 1.5 ohms at 0C . . . a time when the tube is > likely to be turned on. 28V/1.5 ohms is 18A start > up current. When the heater gets to 100C (typical > high altitude condition) it goes to 2.2 ohms > for 12.7A running current. 14v probes behave similarly > at about 2x the current. > > What kind of probe are we talking about? > > If you've lots of unused pins in this connector, > it wouldn't hurt to use 5 or 6 pins per path > and I'd certainly drop to 22AWG ballast wires. > Another thing to consider for the solder-cup > connector is the form of the female pins in > the connector . . . not quite as robust and > uniform their crimp style cousins . . . so > extra pins if available wouldn't hurt a thing. > > The work we did at Beech was entirely with > crimped pins. I'm not suggesting that your > design goals cannot be met with this connector, > just that I have no experience with the parallel > pins in the commercial connectors so if there > are unused pins in the connector, bringing > them into harness with the three already in > service is not a bad thing to consider. > > The extra wire is a 'sense' wire? What does > it do for you? > Bob, I'm glad that those connections look better. The other ones that you criticized were my first two. I'll go back and rework them. I am planning a Dynon heated pitot tube. Here is my wiring diagram, including the warning lamp: =8B pitot.pdf =8B Dynon says that that lamp will illuminate if the heater fails. I have plenty of spare pins in the connector. See my connector "diagram" =8B wing root connectors.pdf =8B Dynon says 11-12 A for the heater so I planned on 3 pins @ 5 A per pin. I'll have to buy some more 22 AWG wire if I am going to switch the ballast wires. Do you see any reason why I cannot buy 22 AWG wire locally (which won't be tefzel insulated) instead of mail ordering a small amount of tefzel wire? I can't think of any reason to prefer one insulation material over another for this application. Cheers, -- Art Z. -- http://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Date: Sep 25, 2016
> >Bob, > >I am using a Weller WES51. I have been setting >it at 650 when butt splicing wires and bumped up >to 700 degrees for the DB-25 pins. I can >certainly try something hotter. I was worried about damaging the connector.=C2 700 is fine >I have two tips for the iron, the one that came >with it and an extra narrow tip that I also >bought. I find that extra narrow tip easier to >control when working on the DB-25 pins but it doesn't transfer heat as well. > >I am using Kester 60/40 solder.=C2 Okay . . . you're 95% of the way there. All that's left is to refine your technique. Bob . . . ________________________________________________________________________________
Date: Sep 25, 2016
>I'll have to buy some more 22 AWG wire if I am going to switch the >ballast wires. Do you see any reason why I cannot buy 22 AWG wire >locally (which won't be tefzel insulated) instead of mail ordering a >small amount of tefzel wire? I can't think of any reason to prefer >one insulation material over another for this application. I've packaged up enough 22AWG tefzel for this task. You may have it Tues, Wed for sure. I'd not kept track of Dynon's product line. Looks like their pitot tube is electronically controlled using a technique I proposed to Beech upteen years ago you duty cycle switch power to the heater (except that the OFF current is regulated to some very low value and accurately known). You measure voltage across the heater during off-time and you can deduce the heater's present temperature. I did a bunch of studies on pitot tubes used on the Beechjet during an analysis of loss of airspeed events. Turns out that these things are really easy to regulate by this methodology. I'm guessing that Dynon has exploited the smart controller's software to include soft-start during warm-up. Hence, extra-robust wiring for inrush mitigation is not necessary. But better ballasting of the pins . . . and adding some to the mix is not a bad idea. Bob . . . ________________________________________________________________________________
Date: Sep 26, 2016
Subject: solder splices
hi all, i know solder connections are generally frowned on, especially in engine compartment but my take on a solder splice in the middle of a 6'' run with the wire bundled with 6 others is that it is totally satisfactory. am i wrong that solder is ok if you pick your application sites? bob noffs ________________________________________________________________________________
Date: Sep 26, 2016
=C2-i know solder connections are generally frowned on, especially in eng ine compartment but my take on a solder splice in the middle of a 6'' run w ith the wire bundled with 6 others is that it is totally satisfactory. am i wrong that solder is ok if you pick your application sites? I was never aware that solder connections were frowned upon! In fact my be lief is that a well executed solder connection, with good mechanical connec tion, good solder flow, and a double insulation with heat shrink, is in fac t more reliable than any other connection, over the long term. Just my hum ble opinion! Roger ________________________________________________________________________________
Date: Sep 26, 2016
Thanks!! I got a lot to learn!! > On Sep 24, 2016, at 5:44 PM, Art Zemon wrote: > > > > On Sat, Sep 24, 2016 at 2:46 PM, Art Zemon > wrote: > On Fri, Sep 23, 2016 at 9:29 AM, Efraim Otero > wrote: > Art: > Please send pictures so us newbies can compare thanks for sharing!! > > > Efraim, > > Your wish is my command :-) > > > One more photo. I disassembled and reassembled the first connector that I did (more than a week ago). I am much happier with this iteration: > > > > These wires are for the pitot tube heater. It draws 12 amps so I am using three pins each for power, plus one pin for the status lamp. These three 20 AWG pigtails join to 12 AWG wire which runs the length of the wing. > > Cheers, > -- Art Z. > > > > -- > http://CheerfulCurmudgeon.com/ > > "If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel ________________________________________________________________________________
Date: Sep 26, 2016
I found a good old method here: https://www.youtube.com/watch?v=_GLeCt_u3U8 2016-09-22 2:33 GMT+02:00 Art Zemon : > Folks, > > I am trying to solder 20 gauge wire into DB-25 connectors and having a > tough time. The conductors just barely fit into the cups on the backs of > the pins when everything is "dry," before tinning. After I tin either one, > pin or wire, I cannot get all of the conductors into the cup. I end up with > something like this: > > > I'm afraid that those are not acceptable. What do you think? > > If they are not acceptable, what is the solution? Can I trim a few > conductors away so that the remainder will slip into the cup? Or should I > just give up and switch to crimp pins? Or what? > > Thanks, > -- Art Z. > > -- > http://CheerfulCurmudgeon.com/ > > *"If I am not for myself, who is for me? And if I am only for myself, what > am I? And if not now, when?" Hillel* > ________________________________________________________________________________
Subject: Running Multiple Devices from One Serial Port Output
Date: Sep 26, 2016
I am trying to hook my altitude encoder to my transponder and GPS. I have the TX and RX going to the right places but am wondering what I have to do with the grounds. Here are the connections. Serial Port 1 TX Encoder to Serial Port 1 RX Transponder Serial Port 1 GND Encoder to Serial Port 1 GND Transponder Serial Port 1 TX Encoder to Serial Port 2 RX GPS Serial Port 2 TX GPS to Serial Port 2 RX MX-20 Multifunctional Display Serial Port 2 GND GPS to Serial Port 2 GND MX-20 Multifunctional Display Will this work or do the different serial grounds screw things up? Ross Mickey RV-6A N9PT From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Roger Sent: Monday, September 26, 2016 8:18 AM Subject: RE: AeroElectric-List: solder splices i know solder connections are generally frowned on, especially in engine compartment but my take on a solder splice in the middle of a 6'' run with the wire bundled with 6 others is that it is totally satisfactory. am i wrong that solder is ok if you pick your application sites? I was never aware that solder connections were frowned upon! In fact my belief is that a well executed solder connection, with good mechanical connection, good solder flow, and a double insulation with heat shrink, is in fact more reliable than any other connection, over the long term. Just my humble opinion! Roger ________________________________________________________________________________
Date: Sep 26, 2016
I may be wrong, but do serial ports have a port ground? I have a GRT system and each serial port has an in and out..but no separate ground. In this case the serial out would be one wire going to wherever you want..to its serial in. Rene' 801-721-6080 From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ross Home Sent: Monday, September 26, 2016 4:45 PM Subject: AeroElectric-List: Running Multiple Devices from One Serial Port Output I am trying to hook my altitude encoder to my transponder and GPS. I have the TX and RX going to the right places but am wondering what I have to do with the grounds. Here are the connections. Serial Port 1 TX Encoder to Serial Port 1 RX Transponder Serial Port 1 GND Encoder to Serial Port 1 GND Transponder Serial Port 1 TX Encoder to Serial Port 2 RX GPS Serial Port 2 TX GPS to Serial Port 2 RX MX-20 Multifunctional Display Serial Port 2 GND GPS to Serial Port 2 GND MX-20 Multifunctional Display Will this work or do the different serial grounds screw things up? Ross Mickey RV-6A N9PT From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Roger Sent: Monday, September 26, 2016 8:18 AM Subject: RE: AeroElectric-List: solder splices i know solder connections are generally frowned on, especially in engine compartment but my take on a solder splice in the middle of a 6'' run with the wire bundled with 6 others is that it is totally satisfactory. am i wrong that solder is ok if you pick your application sites? I was never aware that solder connections were frowned upon! In fact my belief is that a well executed solder connection, with good mechanical connection, good solder flow, and a double insulation with heat shrink, is in fact more reliable than any other connection, over the long term. Just my humble opinion! Roger ________________________________________________________________________________
Date: Sep 26, 2016
Subject: Connecting Shielded Cable to DB-25
Folks, I need to connect a shielded cable to my DB-25 connector and I need some advice about how to physically construct this. Here is the wiring diagram =8B strobe position lights.pdf =8B I am concerned with the construction of wires LIGHTS-1-C and LIGHTS-1-D at the wing root. Specifically, the center conductor of the cable is to be connected to a pin in the DB-25. The shield is to be connected to a local ground. This connector (when operating) will be inside the tubular spar of my Bede BD-4C, so the whole assembly will be well shielded; I'm not worried about how many unshielded inches I have near the DB-25. This is what I think will work: Strip the outer insulation of the shielded cable back several inches, so that I can separate the shield from the center conductor outside the DB-25 housing. Solder a sufficient amount of wire to the shield so that I can work with it and attach it to the local ground. Run the center conductor to the DB-25 and connect it to a pin just like any other wire. Your thoughts? Thank you, -- Art Z. -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Subject: Re: Connecting Shielded Cable to DB-25
Date: Sep 26, 2016
On 9/26/2016 9:05 PM, Art Zemon wrote: > Folks, > > I need to connect a shielded cable to my DB-25 connector and I need > some advice about how to physically construct this. Here is the wiring > diagram > > strobe position lights.pdf > > > I am concerned with the construction of wires LIGHTS-1-C and > LIGHTS-1-D at the wing root. Specifically, the center conductor of the > cable is to be connected to a pin in the DB-25. The shield is to be > connected to a local ground. This connector (when operating) will be > inside the tubular spar of my Bede BD-4C, so the whole assembly will > be well shielded; I'm not worried about how many unshielded inches I > have near the DB-25. > > This is what I think will work: Strip the outer insulation of the > shielded cable back several inches, so that I can separate the shield > from the center conductor outside the DB-25 housing. Solder a > sufficient amount of wire to the shield so that I can work with it and > attach it to the local ground. Run the center conductor to the DB-25 > and connect it to a pin just like any other wire. > > Your thoughts? > > Thank you, > -- Art Z. > > -- > https://CheerfulCurmudgeon.com/ > > /"If I am not for myself, who is for me? And if I am only for myself, > what am I? And if not now, when?" Hillel/ Art, I believe Bob has a 'cookbook' page showing that technique for handling shields at sub-d connectors. You should be fine. ________________________________________________________________________________
Date: Sep 27, 2016
I would connect the shield to ground at the wing tip end Art, not at the win g root end. Sebastien > On Sep 27, 2016, at 03:05, Art Zemon wrote: > > Folks, > > I need to connect a shielded cable to my DB-25 connector and I need some a dvice about how to physically construct this. Here is the wiring diagram > =8B > strobe position lights.pdf > =8B > I am concerned with the construction of wires LIGHTS-1-C and LIGHTS-1-D at the wing root. Specifically, the center conductor of the cable is to be con nected to a pin in the DB-25. The shield is to be connected to a local groun d. This connector (when operating) will be inside the tubular spar of my Bed e BD-4C, so the whole assembly will be well shielded; I'm not worried about h ow many unshielded inches I have near the DB-25. > > This is what I think will work: Strip the outer insulation of the shielded cable back several inches, so that I can separate the shield from the cente r conductor outside the DB-25 housing. Solder a sufficient amount of wire to the shield so that I can work with it and attach it to the local ground. Ru n the center conductor to the DB-25 and connect it to a pin just like any ot her wire. > > Your thoughts? > > Thank you, > -- Art Z. > > -- > https://CheerfulCurmudgeon.com/ > > "If I am not for myself, who is for me? And if I am only for myself, what a m I? And if not now, when?" Hillel ________________________________________________________________________________
Date: Sep 27, 2016
Whoops, disregard last message, I see you are talking about the wire from th e cabin. Any reason you can't just ground it at the switch? Sebastien > On Sep 27, 2016, at 03:05, Art Zemon wrote: > > Folks, > > I need to connect a shielded cable to my DB-25 connector and I need some a dvice about how to physically construct this. Here is the wiring diagram > =8B > strobe position lights.pdf > =8B > I am concerned with the construction of wires LIGHTS-1-C and LIGHTS-1-D at the wing root. Specifically, the center conductor of the cable is to be con nected to a pin in the DB-25. The shield is to be connected to a local groun d. This connector (when operating) will be inside the tubular spar of my Bed e BD-4C, so the whole assembly will be well shielded; I'm not worried about h ow many unshielded inches I have near the DB-25. > > This is what I think will work: Strip the outer insulation of the shielded cable back several inches, so that I can separate the shield from the cente r conductor outside the DB-25 housing. Solder a sufficient amount of wire to the shield so that I can work with it and attach it to the local ground. Ru n the center conductor to the DB-25 and connect it to a pin just like any ot her wire. > > Your thoughts? > > Thank you, > -- Art Z. > > -- > https://CheerfulCurmudgeon.com/ > > "If I am not for myself, who is for me? And if I am only for myself, what a m I? And if not now, when?" Hillel ________________________________________________________________________________
Date: Sep 27, 2016
On Mon, Sep 26, 2016 at 9:32 PM, Charlie England wrote: > On 9/26/2016 9:05 PM, Art Zemon wrote: > > Folks, > > I need to connect a shielded cable to my DB-25 connector and I need some > advice about how to physically construct this.... > > Art, > > I believe Bob has a 'cookbook' page showing that technique for handling > shields at sub-d connectors. You should be fine. > I found it: Shield Termination Techniques <http://www.aeroelectric.com/articles/pigtail/pigtail.html> I can adapt that nicely. Thank you, Charlie. -- Art Z. -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Date: Sep 27, 2016
Subject: Re: solder splices
i agree that the joint if undisturbed can't be beat. i was questioning if movement would become a factor in the condition i described. bob noffs On Mon, Sep 26, 2016 at 10:17 AM, Roger wrote: > > > i know solder connections are generally frowned on, especially in engine > compartment but my take on a solder splice in the middle of a 6'' run with > the wire bundled with 6 others is that it is totally satisfactory. am i > wrong that solder is ok if you pick your application sites? > > > *I was never aware that solder connections were frowned upon! In fact my > belief is that a well executed solder connection, with good mechanical > connection, good solder flow, and a double insulation with heat shrink, is > in fact more reliable than any other connection, over the long term. Just > my humble opinion!* > > > *Roger* > > ________________________________________________________________________________
Date: Sep 27, 2016
At 07:07 AM 9/26/2016, you wrote: >hi all, >=C2 i know solder connections are generally >frowned on, especially in engine compartment but >my take on a solder splice in the middle of a >6'' run with the wire bundled with 6 others is >that it is totally satisfactory. am i wrong that >solder is ok if you pick your application sites? >=C2 bob noffs I don't know why it wouldn't be just fine ANYWHERE the materials, talents and tools are likely to produce a serviceable joining . . . irrespective of location. Soldering was 'frowned upon' on the 1960's production lines at Cessna because soldering irons burned people and melted carpets. At Boeing, I had to have a fireman come out and give me a permit to plug in an iron . . . just to make sure I wasn't working the task close to flammables. It's process sensitive (meaning you gotta have the moves). But an artfully crafted solder joint is no more/less risky to meeting design goals than a crimped connection. Bob . . . ________________________________________________________________________________
Date: Sep 27, 2016
ok, away we go. i like my soldered joints more than any crimped joint cuz i made them. bob On Tue, Sep 27, 2016 at 7:36 AM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 07:07 AM 9/26/2016, you wrote: > > hi all, > =C3=82 i know solder connections are generally frowned on, especially in engine > compartment but my take on a solder splice in the middle of a 6'' run wit h > the wire bundled with 6 others is that it is totally satisfactory. am i > wrong that solder is ok if you pick your application sites? > =C3=82 bob noffs > > > I don't know why it wouldn't be just fine ANYWHERE > the materials, talents and tools are likely to > produce a serviceable joining . . . irrespective > of location. > > Soldering was 'frowned upon' on the 1960's > production lines at Cessna because soldering irons > burned people and melted carpets. At Boeing, I had > to have a fireman come out and give me a permit > to plug in an iron . . . just to make sure I wasn't > working the task close to flammables. It's process > sensitive (meaning you gotta have the moves). > But an artfully crafted solder joint is no > more/less risky to meeting design goals than > a crimped connection. > > > Bob . . . > ________________________________________________________________________________
Date: Sep 28, 2016
At 06:55 PM 9/27/2016, you wrote: >ok, away we go. i like my soldered joints more than any crimped >joint cuz i made them. Understand. See http://tinyurl.com/dgg2nb if you haven't already. Bob . . . ________________________________________________________________________________
From: Christopher Cee Stone <rv8iator(at)gmail.com>
Date: Sep 28, 2016
The stress riser that occurs at the interface between wire strands and solder filled wire strands if not mechanically supported is a candidate for fatigue failure due to vibration induced flexing. This is true of field splices and soldiered pin/wire connection. Good mechanical support/strain relief is imperative to prevent fatigue failure of the connection/soldier joint. A good crimped connection does see a stress riser at the crimp/wire interface... BUT the transition is not as sharp as with soldier wicked into wire strands. Crimped pins the wire are generally supported upstream from the crimp thus creating a mechanical support for the connection. Chris Stone On Tue, Sep 27, 2016 at 5:36 AM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 07:07 AM 9/26/2016, you wrote: > > hi all, > =C3=82 i know solder connections are generally frowned on, especially in engine > compartment but my take on a solder splice in the middle of a 6'' run wit h > the wire bundled with 6 others is that it is totally satisfactory. am i > wrong that solder is ok if you pick your application sites? > =C3=82 bob noffs > > > I don't know why it wouldn't be just fine ANYWHERE > the materials, talents and tools are likely to > produce a serviceable joining . . . irrespective > of location. > > Soldering was 'frowned upon' on the 1960's > production lines at Cessna because soldering irons > burned people and melted carpets. At Boeing, I had > to have a fireman come out and give me a permit > to plug in an iron . . . just to make sure I wasn't > working the task close to flammables. It's process > sensitive (meaning you gotta have the moves). > But an artfully crafted solder joint is no > more/less risky to meeting design goals than > a crimped connection. > > > Bob . . . > ________________________________________________________________________________
Date: Sep 28, 2016
Subject: Solder splices/connections
The stress riser that occurs at the interface between wire strands and solder filled wire strands if not mechanically supported is a candidate for fatigue failure due to vibration induced flexing of the wire This is true of field splices and soldiered pin/wire connection. Good mechanical support/strain relief is imperative to prevent fatigue failure of the connection/soldier joint. A good crimped connection does see a stress riser at the crimp/wire interface... BUT the transition is not as sharp as with soldier wicked into wire strands. With crimped pins the wire is generally supported upstream from the crimp thus creating a mechanical support for the connection. This can be true for soldered joints as well... AS LONG as no solder has wicked up the wire strands beyond the point of mechanical support. The finer the wire strands (as in very flexible type conductors) the greater the likelihood that solder will wick further up the strands potentially going beyond the insulation. Studies done here where I have been a test engineer on medical electronic equipment have demonstrated the fragility of soldered wire connections. All pins are crimped and strain relieved by connection of the wire outer sheath to the connector body and by the cable outer sheath to the connector shell. Chris Stone ________________________________________________________________________________
Date: Sep 29, 2016
Subject: Re: Solder splices/connections
At 04:29 PM 9/28/2016, you wrote: >The stress riser that occurs at the interface between wire strands >and solder filled wire strands if not mechanically supported is a >candidate for fatigue failure due to vibration induced flexing of the wire > >This is true of field splices and soldiered pin/wire connection. > >Good mechanical support/strain relief is imperative to prevent >fatigue failure of the connection/soldier joint. Yes, stresses due to flexing of any material is a function of thickness/diameter of object and the magnitude of the bending . . . which under vibration gives rise to cyclical tension/compression forces on the material. A second of 1" copper rod flexed through x-degrees will fail in a tiny fraction of the same cycles impressed on a 0.020" strand of copper. This is why welding cable is made from a bizillion strands of copper 'cat hair' as are braided copper bonding straps . . . http://tinyurl.com/jxsf55j . . . are unlikely to fail under flexure stresses over lifetime of the installation. Whether or not a solder-solidification of strands presents a more/less severe stress riser point than a crimp- solidification is kinda splitting hairs. When used in a situation that imposes cyclical forces on the joint, there is significant risk of failure at the transition from solid to strands in BOTH technologies. This fact of physics gave rise to the double crimped, 'pre insulated' terminals of all stripe but most famously, PIDG style terminals offered by many suppliers for the last 70 or so years. http://tinyurl.com/zkmh7kj When the joining is effected with solder, folks in-the-know strive to achieve two goals. Join the wires and support the insulation just outside the junction. http://tinyurl.com/ju4gvvg Arguments favoring one process over the other have no solid foundation in risk reduction. It's not difficult to apply either process in a manner that will exceed the service life of the airplane. You can mess up a potentially good crimped installation too. http://tinyurl.com/hekmvyz This terminal was observed on an accident aircraft where, amongst many other shorfalls, some terminals were not properly installed. Understand the physics, acquire the tools and PRACTICE. Bob . . . ________________________________________________________________________________
Subject: Strobe Grounding
Date: Sep 30, 2016
I have installed a Whelen HDACF Power Supply in my composite aircraft and the instructions make no mention of grounding the shield in the cables to the strobes. Should I ground the shield and if yes should it be one or both ends. Thanks Mike ________________________________________________________________________________
Date: Sep 30, 2016
Subject: Re: Strobe Grounding
Mike, The instructions for the AeroLEDS Pulsar show the shield connected to local ground at both ends. -- Art Z. On Thu, Sep 29, 2016 at 10:48 PM, wrote: > > > I have installed a Whelen HDACF Power Supply in my composite aircraft and > the instructions make no mention of grounding the shield in the cables to > the strobes. > > Should I ground the shield and if yes should it be one or both ends. > > Thanks > > Mike -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Date: Sep 30, 2016
This should be the subject of a discussion hopefully with input from Aerole ds. I installed Aeroleds Pulsars. I had major loud static noise during the fi rst flights. In phone discussions with Aeroleds, I was instructed to disconnect the outb oard shield grounds and insulate that end shield from any structure near th e Aeroleds light. This greatly reduced my static noise. I still have a low level Aeroleds strobe sound ( But not at a level objecti onable to me), but, I still have a significant static noise ( primarily on the ground during taxiing) but still occasionally in the air. This winter I intend to try and trace all the Aeroleds wiring and find an intermittent ground location or connection The Aeroleds schematic shows grounding the shield at both ends ( in my inte rpretation). I can only offer, be very careful in the Aeroleds wiring and grounding. You will not enjoy Aeroleds static noise! I would suggest Aeroleds should provide some additional guidance for their product as the installation schematic is not clear. I do like the Aeroleds products and hope this gets some clarification. On Sep 30, 2016, at 4:54 AM, Art Zemon > wrote: Mike, The instructions for the AeroLEDS Pulsar show the shield connected to local ground at both ends. -- Art Z. On Thu, Sep 29, 2016 at 10:48 PM, > wrote: ion499.com> I have installed a Whelen HDACF Power Supply in my composite aircraft and t he instructions make no mention of grounding the shield in the cables to th e strobes. Should I ground the shield and if yes should it be one or both ends. Thanks Mike -- https://CheerfulCurmudgeon.com/ "If I am not for myself, who is for me? And if I am only for myself, what a m I? And if not now, when?" Hillel ________________________________________________________________________________
Date: Sep 30, 2016
Mike, See "Interconnecting Cable" and Fig 3, on page 2 of this document: http://www.whelen.com/install/136/13603.pdf Eric > On Sep 29, 2016, at 8:48 PM, mike(at)vision499.com wrote: > I have installed a Whelen HDACF Power Supply in my composite aircraft and the instructions make no mention of grounding the shield in the cables to the strobes. > > Should I ground the shield and if yes should it be one or both ends. > > Thanks > > Mike ________________________________________________________________________________
Date: Sep 30, 2016
> >I installed Aeroleds Pulsars. I had major loud static noise >during the first flights. The word 'static' conjures up a mental picture of radio noise on an AM radio tuned off-station with thunder storms in the area. Or perhaps the noise heard near a high voltage transmission line where one or more insulators are failing. "Static" normally describes random, short duration impulses . . . no regularity reminiscent of a tone or musical note. Can you be a bit more descriptive? Also, did you conduct any investigative operations to determine whether the noise was coming in through antenna, power supply or system signal leads (See chapter 16 in the 'Connection'. >In phone discussions with Aeroleds, I was instructed to disconnect >the outboard shield grounds and insulate that end shield from any >structure near the Aeroleds light. This greatly reduced my static noise. This is a disturbing revelation. The AEROLED website speaks to STC and TSO qualification of products. These assertions argue with any narrative suggesting that treatment of shields had a profound effect on an objectionable emission of noise. >I still have a low level Aeroleds strobe sound ( But not at a level >objectionable to me), but, I still have a significant static noise ( >primarily on the ground during taxiing) but still occasionally in >the air. This winter I intend to try and trace all the Aeroleds >wiring and find an intermittent ground location or connection Please go through the diagnostic exercises described in the 'Connection. Also, it would be VERY helpful if you could post a .wav or .mp3 recording of the sounds you hear. The qualification processes for dozens of products and systems I've shepherded through DO-160/MIL-STD-461 qualification would not have allowed a program to move forward with EMC deficiencies that you've described. >The Aeroleds schematic shows grounding the shield at both ends ( in >my interpretation). I can only offer, be very careful in the >Aeroleds wiring and grounding. You will not enjoy Aeroleds static noise! > >I would suggest Aeroleds should provide some additional guidance for >their product as the installation schematic is not clear. > >I do like the Aeroleds products and hope this gets some clarification. Precisely. Shielding of wires is intended to break ELECTROSTATIC coupling between a potentially antagonistic signal (high voltage, fast rise) and a potential victim wire carrying low level data. The de-coupling process is guaranteed only to ward off exchange of unfriendly energy between conductors in adjacent wire bundles. Any time the existence or treatment of shields has an effect on RADIATED noise (stuff that comes in through the antennas), there is a SERIOUS problem with that product's design and qualification. I think it unlikely that you have any small-signal data or audio lines bundled with shielded wires in the strobe system; hence this thread suggests value in a more detailed investigation. Bob . . . ________________________________________________________________________________
Date: Oct 01, 2016
Subject: Re: AEC 9005
At 04:45 PM 10/1/2016, you wrote: >Thanks Bob! What kind of product do you use for the coating? >I can think of some other projects that can benefit from that. The 'in-crowd' uses a mil-spec polyurethane coating specifically crafted for etched circuit boards. In the 'po-boy' world, a clear poly by Krylon, Deft, et. als. will suffice. You can get it at any hardware or big-box store. Here's one example. http://tinyurl.com/gpsdkh4 It doesn't need to be this specific product. Any of the clear poly's are fine. You need to mask off connectors. Getting that stuff into a d-sub is . . . well . . . you get the picture. I clean a board of solder-flux and other guck with the spray from a can of carburetor/ air intake cleaner (a close cousin to lacquer thinner). Walmart sells a can of it for a couple of bucks . . . I buy this stuff by the case for a host of cleaning tasks. http://tinyurl.com/h8ppujv Walmart may have the polyurethane too . . . Bob . . . ________________________________________________________________________________
Date: Oct 01, 2016
Bob, I like your input about using the carburetor cleaner, but I have acquired an allergy to that product. I have found a product from CRC Industries that I like very well, but have not yet used it on circuit boards for cleaning. Here is a link to the product, and all our local auto parts stores stock it. http://www.crcindustries.com/ei/product_detail.aspx?id=05018 What would be your take on using it instead of carburetor cleaner for that purpose? Thanks, Harry ________________________________________________________________________________
Date: Oct 01, 2016
At 06:46 PM 10/1/2016, you wrote: >Bob, > > >I like your input about using the carburetor cleaner, but I have >acquired an allergy to that product. I have found a product from >CRC Industries that I like very well, but have not yet used it on >circuit boards for cleaning. Here is a link to the product, and all >our local auto parts stores stock it. > > ><http://www.crcindustries.com/ei/product_detail.aspx?id=05018>http://www.crcindustries.com/ei/product_detail.aspx?id=05018 > > >What would be your take on using it instead of carburetor cleaner >for that purpose? High order probability of success. When cleaning a newly assembled board, products of assembly (flux mostly) needs to be removed before coating. Depending on type of flux, it MIGHT just come off with water. I used to assemble my products with a water soluble flux and run finished boards through he dishwasher. But without knowing the specifics of what ever solder flux you have (or perhaps other contaminants acquired with service/age like Mr. Yates board), a more universal solvent can be considered. 91% isopropyl alcohol from Walmart is often sufficient but it doesn't come in a handy spray can. Mild solvents like paint thinner/toluene/naptha work but again, not so handily packaged. The carb cleaner has proven suitable to my tasks for decades. I flush generously and immediately blow dry with an air hose. The biggest risk for solvent selection is picking something too aggressive . . . MEK comes to mind. Does a NICE job of getting flux off. Also removes paint stripes from resistors and melts some of the lesser- robust plastic parts. An on-purpose board cleaner . . . especially from the likes of CRC is very likely a well proven product. Bob . . . ________________________________________________________________________________
Subject: Poisonous Battery Vapors?
Date: Oct 04, 2016
Can lead acid batteries give off Hydrogen sulfide? If so, is it safe to have batteries located within an aircraft cabin? A mother and daughter might have been killed by battery vapors. http://www.orlandosentinel.com/news/breaking-news/os-latifa-lincoln-dead-hydrogen-sulfide-20161004-story.html -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460949#460949 ________________________________________________________________________________
Date: Oct 05, 2016
Subject: Re: Poisonous Battery Vapors?
At 09:20 PM 10/4/2016, you wrote: > >Can lead acid batteries give off Hydrogen sulfide? If so, is it >safe to have batteries located within an aircraft cabin? A mother >and daughter might have been killed by battery vapors. >http://www.orlandosentinel.com/news/breaking-news/os-latifa-lincoln-dead-hydrogen-sulfide-20161004-story.html > >-------- It would be interesting to see the final report on any analysis generated by the hypothesis. A term search for "hydrogen sulfide" on batteryuniversity.com yielded three hits. http://tinyurl.com/hv6n6bt . . . it seems 'possible' that products of battery distress could include h2s . . . Our machines are usually fitted with ov protection. The quantity of liquid in the AGM battery is very limited. I suspect that demonstrations designed to produce H2S from a SVLA battery would be rather bizarre . . . unlikely to ever happen in vehicles . . . even less in airplanes. Bob . . . ________________________________________________________________________________
Date: Oct 05, 2016
Subject: rotax generator without battery
I am designing my electrical system for the Rotax 914 which requires two electrical fuel pumps. My plan is to run the main pump (and nothing else) off the generator, and the auxiliary pump off the bus, which will be connected to a battery and the external 40 amp alternator. According to the Rotax 914 Installation Manual, the minimum idle rpm is 1400, and at 1400 engine rpm the generator produces only 2a/13.5v (+/- 5%). The pumps are Walbro GSL395. Is there any danger that this might be setting up a problem that would damage either the regulator-rectifier or the fuel pump? Also, what would be the best way to insure that the auxiliary pump (if activated) would automatically stop in the event of a crash? ________________________________________________________________________________
Date: Oct 05, 2016
Subject: Re: rotax generator without battery
At 02:54 PM 10/5/2016, you wrote: >I am designing my electrical system for the Rotax 914 which requires >two electrical fuel pumps. My plan is to run the main pump (and >nothing else) off the generator, and the auxiliary pump off the bus, >which will be connected to a battery and the external 40 amp alternator. > >According to the Rotax 914 Installation Manual, the minimum idle rpm >is 1400, and at 1400 engine rpm the generator produces only 2a/13.5v >(+/- 5%). The pumps are Walbro GSL395. > >Is there any danger that this might be setting up a problem that >would damage either the regulator-rectifier or the fuel pump? No >Also, what would be the best way to insure that the auxiliary pump >(if activated) would automatically stop in the event of a crash? This is usually managed with the master switch . . . Bob . . . ________________________________________________________________________________
Date: Oct 05, 2016
Bob, Below is a quote from http://batteryuniversity.com/learn/article/health_concerns that you referenced. The danger of hydrogen sulfide is that the sense of smell acclimates to the gas and can not smell it anymore. That explains why the woman in the news article did not stop driving before she was incapacitated. > Over-charging a lead acid battery can produce hydrogen sulfide. The gas is colorless, very poisonous, flammable and has the odor of rotten eggs. Hydrogen sulfide also occurs naturally during the breakdown of organic matter in swamps and sewers; it is present in volcanic gases, natural gas and some well waters. Being heavier than air, the gas accumulates at the bottom of poorly ventilated spaces. Although noticeable at first, the sense of smell deadens the sensation with time and potential victims may be unaware of its presence. > As a simple guideline, hydrogen sulfide becomes harmful to human life if the odor is noticeable. Turn off the charger, vent the facility and stay outside until the odor disappears. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460981#460981 ________________________________________________________________________________
Date: Oct 05, 2016
Thanks Bob. What would the effect be on the pump if it was getting less than ideal amps/volts? Would it simply lower the performance of the pump? Regarding automatic shut off of the pump, the master switch is hardly "automatic." The scenario would be one of a crash with injuries. We would want the electric fuel pump to shut down when the engine shuts down so that it does not continue to pump fuel, possibly into a ruptured fuel system. Ken On Wed, Oct 5, 2016 at 1:05 PM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 02:54 PM 10/5/2016, you wrote: > > I am designing my electrical system for the Rotax 914 which requires two > electrical fuel pumps. My plan is to run the main pump (and nothing else) > off the generator, and the auxiliary pump off the bus, which will be > connected to a battery and the external 40 amp alternator. > > According to the Rotax 914 Installation Manual, the minimum idle rpm is > 1400, and at 1400 engine rpm the generator produces only 2a/13.5v (+/- 5%). > The pumps are Walbro GSL395. > > Is there any danger that this might be setting up a problem that would > damage either the regulator-rectifier or the fuel pump? > > > No > > Also, what would be the best way to insure that the auxiliary pump (if > activated) would automatically stop in the event of a crash? > > > This is usually managed with the master switch . . . > > Bob . . . > ________________________________________________________________________________
Date: Oct 05, 2016
There are about a zillion certified aircraft out there with electric fuel pu mps that are engaged and energised specifically for takeoff and landing. So y ou may be trying to solve a problem that isn't judged to arise very often; p articularly if you factor in the small but real possibility of whatever auto matic fuel pump shutoff mechanism you design engaging at the wrong moment (s hortly after takeoff, say) and causing the very accident you are hoping to a void. For an expectedly rough landing in the event of a forced approach onto rough terrain, the fuel and electrical systems should all be purged and isolated w ell in advance of touchdown, as Bob suggests, by use of the master switch an d fuel shutoff. > On Oct 5, 2016, at 5:48 PM, Ken Ryan wrote: > > Thanks Bob. > > What would the effect be on the pump if it was getting less than ideal amp s/volts? Would it simply lower the performance of the pump? > > Regarding automatic shut off of the pump, the master switch is hardly "aut omatic." The scenario would be one of a crash with injuries. We would want t he electric fuel pump to shut down when the engine shuts down so that it doe s not continue to pump fuel, possibly into a ruptured fuel system. > > Ken > > >> On Wed, Oct 5, 2016 at 1:05 PM, Robert L. Nuckolls, III <nuckolls.bob@aer oelectric.com> wrote: >> At 02:54 PM 10/5/2016, you wrote: >>> I am designing my electrical system for the Rotax 914 which requires two electrical fuel pumps. My plan is to run the main pump (and nothing else) o ff the generator, and the auxiliary pump off the bus, which will be connecte d to a battery and the external 40 amp alternator. >>> >>> According to the Rotax 914 Installation Manual, the minimum idle rpm is 1 400, and at 1400 engine rpm the generator produces only 2a/13.5v (+/- 5%). T he pumps are Walbro GSL395. >>> >>> Is there any danger that this might be setting up a problem that would d amage either the regulator-rectifier or the fuel pump? >> >> No >> >>> Also, what would be the best way to insure that the auxiliary pump (if a ctivated) would automatically stop in the event of a crash? >> >> This is usually managed with the master switch . . . >> >> Bob . . . >> > ________________________________________________________________________________
Date: Oct 05, 2016
That may be true, but the Rotax 912iS and the UL Power engines do shut off fuel pumps when the engine stops as do all modern automobiles. Again, I am not concerned with a forced landing where there is time to prepare. I am concerned with a crash, such as flipping the aircraft due to soft or rough terrain, or a million other things that could conceivably happen (and do happen). In such an instance, I would prefer not to have a high pressure fuel pump doing its job. On Wed, Oct 5, 2016 at 2:35 PM, Alec Myers wrote: > There are about a zillion certified aircraft out there with electric fuel > pumps that are engaged and energised specifically for takeoff and landing. > So you may be trying to solve a problem that isn't judged to arise very > often; particularly if you factor in the small but real possibility of > whatever automatic fuel pump shutoff mechanism you design engaging at the > wrong moment (shortly after takeoff, say) and causing the very accident you > are hoping to avoid. > > For an expectedly rough landing in the event of a forced approach onto > rough terrain, the fuel and electrical systems should all be purged and > isolated well in advance of touchdown, as Bob suggests, by use of the > master switch and fuel shutoff. > > > On Oct 5, 2016, at 5:48 PM, Ken Ryan wrote: > > Thanks Bob. > > What would the effect be on the pump if it was getting less than ideal > amps/volts? Would it simply lower the performance of the pump? > > Regarding automatic shut off of the pump, the master switch is hardly > "automatic." The scenario would be one of a crash with injuries. We would > want the electric fuel pump to shut down when the engine shuts down so that > it does not continue to pump fuel, possibly into a ruptured fuel system. > > Ken > > > On Wed, Oct 5, 2016 at 1:05 PM, Robert L. Nuckolls, III < > nuckolls.bob(at)aeroelectric.com> wrote: > >> At 02:54 PM 10/5/2016, you wrote: >> >> I am designing my electrical system for the Rotax 914 which requires two >> electrical fuel pumps. My plan is to run the main pump (and nothing else) >> off the generator, and the auxiliary pump off the bus, which will be >> connected to a battery and the external 40 amp alternator. >> >> According to the Rotax 914 Installation Manual, the minimum idle rpm is >> 1400, and at 1400 engine rpm the generator produces only 2a/13.5v (+/- 5%). >> The pumps are Walbro GSL395. >> >> Is there any danger that this might be setting up a problem that would >> damage either the regulator-rectifier or the fuel pump? >> >> >> No >> >> Also, what would be the best way to insure that the auxiliary pump (if >> activated) would automatically stop in the event of a crash? >> >> >> This is usually managed with the master switch . . . >> >> Bob . . . >> > > ________________________________________________________________________________
Date: Oct 05, 2016
Perhaps more practice at landing...? > On Oct 5, 2016, at 6:56 PM, Ken Ryan wrote: > > That may be true, but the Rotax 912iS and the UL Power engines do shut off fuel pumps when the engine stops as do all modern automobiles. Again, I am n ot concerned with a forced landing where there is time to prepare. I am conc erned with a crash, such as flipping the aircraft due to soft or rough terra in, or a million other things that could conceivably happen (and do happen). In such an instance, I would prefer not to have a high pressure fuel pump d oing its job. > > >> On Wed, Oct 5, 2016 at 2:35 PM, Alec Myers wrote: >> There are about a zillion certified aircraft out there with electric fuel pumps that are engaged and energised specifically for takeoff and landing. S o you may be trying to solve a problem that isn't judged to arise very often ; particularly if you factor in the small but real possibility of whatever a utomatic fuel pump shutoff mechanism you design engaging at the wrong moment (shortly after takeoff, say) and causing the very accident you are hoping t o avoid. >> >> For an expectedly rough landing in the event of a forced approach onto ro ugh terrain, the fuel and electrical systems should all be purged and isolat ed well in advance of touchdown, as Bob suggests, by use of the master switc h and fuel shutoff. >> >> >> >>> On Oct 5, 2016, at 5:48 PM, Ken Ryan wrote: >>> >>> Thanks Bob. >>> >>> What would the effect be on the pump if it was getting less than ideal a mps/volts? Would it simply lower the performance of the pump? >>> >>> Regarding automatic shut off of the pump, the master switch is hardly "a utomatic." The scenario would be one of a crash with injuries. We would want the electric fuel pump to shut down when the engine shuts down so that it d oes not continue to pump fuel, possibly into a ruptured fuel system. >>> >>> Ken >>> >>> >>>> On Wed, Oct 5, 2016 at 1:05 PM, Robert L. Nuckolls, III <nuckolls.bob@a eroelectric.com> wrote: >>>> At 02:54 PM 10/5/2016, you wrote: >>>>> I am designing my electrical system for the Rotax 914 which requires t wo electrical fuel pumps. My plan is to run the main pump (and nothing else) off the generator, and the auxiliary pump off the bus, which will be connec ted to a battery and the external 40 amp alternator. >>>>> >>>>> According to the Rotax 914 Installation Manual, the minimum idle rpm i s 1400, and at 1400 engine rpm the generator produces only 2a/13.5v (+/- 5%) . The pumps are Walbro GSL395. >>>>> >>>>> Is there any danger that this might be setting up a problem that would damage either the regulator-rectifier or the fuel pump? >>>> >>>> No >>>> >>>>> Also, what would be the best way to insure that the auxiliary pump (if activated) would automatically stop in the event of a crash? >>>> >>>> This is usually managed with the master switch . . . >>>> >>>> Bob . . . >>>> >>> > ________________________________________________________________________________
Date: Oct 05, 2016
How about putting an oil pressure switch in series with the electric fuel pump? And maybe a momentary push button switch in parallel with the oil pressure switch to allow for checking pump operation with the engine not running. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460989#460989 ________________________________________________________________________________
Date: Oct 05, 2016
Joe, how would I accomplish the engine start? The primary fuel pump needs the generator and the auxiliary needs oil pressure. Is that what the push button is for? Sent from my Android. Sorry Steve. On Oct 5, 2016 4:50 PM, "user9253" wrote: How about putting an oil pressure switch in series with the electric fuel pump? And maybe a momentary push button switch in parallel with the oil pressure switch to allow for checking pump operation with the engine not running. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460989#460989 ________________________________________________________________________________
Date: Oct 05, 2016
We had this happen one time on a drive into Mexico for winter duck hunting. We drove in friends old Suburban as it was pretty much bullet proof in the Baja outback conditions. I the way down, at night, I got the distinct smell of "burning french fries. . .". That is how my nose translated the problem Turned out the regulator had failed and the battery was being charged way beyond its design max limits. Very hot and fluids coming out the vent caps, etc. It was the smell that tipped us off. Never dawned on us that the nasty discharge would be dangerous other than eating up a battery box steel. I don't recall the details now, but, we did a work around such that the battery was not being charged for the remainder of the trip. Small Mexican city got us running again as they had parts and pieces. ----- Original Message ----- From: "user9253" <fransew(at)gmail.com> Sent: Wednesday, October 05, 2016 2:43 PM Subject: AeroElectric-List: Re: Poisonous Battery Vapors? > > Bob, > Below is a quote from > http://batteryuniversity.com/learn/article/health_concerns that you > referenced. > The danger of hydrogen sulfide is that the sense of smell acclimates to > the gas and can not smell it anymore. That explains why the woman in the > news article did not stop driving before she was incapacitated. > >> Over-charging a lead acid battery can produce hydrogen sulfide. The gas >> is colorless, very poisonous, flammable and has the odor of rotten eggs. >> Hydrogen sulfide also occurs naturally during the breakdown of organic >> matter in swamps and sewers; it is present in volcanic gases, natural gas >> and some well waters. Being heavier than air, the gas accumulates at the >> bottom of poorly ventilated spaces. Although noticeable at first, the >> sense of smell deadens the sensation with time and potential victims may >> be unaware of its presence. >> As a simple guideline, hydrogen sulfide becomes harmful to human life if >> the odor is noticeable. Turn off the charger, vent the facility and stay >> outside until the odor disappears. > > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=460981#460981 > > > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Oct 05, 2016
Hi Ken; Are the crankshaft and alternator pulleys the same size, or is the alternator a spline drive unit? Otherwise, the alternator usually runs faster than the engine. Cheers! Stu. ----- Original Message ----- From: "Ken Ryan" <keninalaska(at)gmail.com> Sent: Wednesday, October 5, 2016 12:54:16 PM Subject: AeroElectric-List: rotax generator without battery I am designing my electrical system for the Rotax 914 which requires two electrical fuel pumps. My plan is to run the main pump (and nothing else) off the generator, and the auxiliary pump off the bus, which will be connected to a battery and the external 40 amp alternator. According to the Rotax 914 Installation Manual, the minimum idle rpm is 1400, and at 1400 engine rpm the generator produces only 2a/13.5v (+/- 5%). The pumps are Walbro GSL395. Is there any danger that this might be setting up a problem that would damage either the regulator-rectifier or the fuel pump? Also, what would be the best way to insure that the auxiliary pump (if activated) would automatically stop in the event of a crash? ________________________________________________________________________________
Date: Oct 06, 2016
Le 06/10/2016 02:42, user9253 a crit : > > How about putting an oil pressure switch in series with the electric fuel pump? And maybe a momentary push button switch in parallel with the oil pressure switch to allow for checking pump operation with the engine not running. > Hi all, Just a few thoughts he Rotax 914 uses two electric fuel pumps. If no fuel is pumped into the carbs, the engine stops. Some builders wire the main fuel pump with a pilot operated switch, which opens the door to unexpected pilot induced engine shutoffs. Those things happen. Wiring the main pump in series with an oil pressure switch is making the engine dependent on this switch for continued operation. No problem for checking pump operation : the pumps are clearly audible from the cockpit. Please note that we are talking about a Rotax engine here, the PM alternator rotor is keyed on the crankshaft at the rear of the engine. In our project, we wired the main fuel pump direct from an auxiliary contact on the ignition keyswitch. The fuel pump runs any time the ignition is "on". FWIW -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Date: Oct 06, 2016
If your aux alternator is running off the spline takeoff in the back of the gearbox, it is never turning at engine RPM and so will never produce its max rated output of "40" amps. I don't see why you are planning to just throw away the 15-16 amps from the engine's alternator. -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460998#460998 ________________________________________________________________________________
Date: Oct 06, 2016
Yes, I suggested a momentary push button switch to bypass the oil pressure switch. A guarded maintained switch could be used instead. Another option is to automatically energize the fuel pump whenever the starter is energized. > Joe, how would I accomplish the engine start? The primary fuel pump needs the generator and the auxiliary needs oil pressure. Is that what the push button is for? -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461000#461000 ________________________________________________________________________________
Date: Oct 06, 2016
At 04:48 PM 10/5/2016, you wrote: >Thanks Bob.=C2 > >What would the effect be on the pump if it was >getting less than ideal amps/volts? Would it >simply lower the performance of the pump?=C2 If you're talking about and electric, "thump-thump" pump, you just about cannot hurt these with any sort of electrical abuse short of severe over voltage. Pioneered by Bendix in the 60's, the motor that drives the pump is simply a solenoid (originally energized through a set of contacts no unlike a switch relay) that compresses a spring which in turn forces fuel out of the pump. As the fuel flowed out under spring force, a pair of check valves allowed fuel to be sucked in behind the piston. When it reached end of travel, contacts would close, solenoid would pull the piston back thus re-compressing the spring. Modern versions are all solid state. In the example you see here http://tinyurl.com/hxwckfr Figure 10 shows our old friend the 555 timer used to periodically compress the spring with a string of short pulses . . . energy applied irrespective of flow rate through the pump. This configuration offers an exceedingly simple, robust design with very long service life (the contacts would wear out on the original Bendix design and were not repairable). >Regarding automatic shut off of the pump, the >master switch is hardly "automatic." The >scenario would be one of a crash with injuries. >We would want the electric fuel pump to shut >down when the engine shuts down so that it does >not continue to pump fuel, possibly into a ruptured fuel system. Electric fuel pumps have been used on aircraft in various forms almost since day-one. The POWER source for that device along with all other electrically driven components offers a potential ignition source for spilled fuel. Hence the legacy requirement for crew accessible control of all electrical sources in the form of alternator/generator and battery switches. The idea is that a pilot generally knows when an off-field landing is imminent and will shut off those energy sources before the crash. This 'new' push by Rotax to dedicate the built-in PM alternator to running just one fuel pump is a puzzlement . . . In he past, this 18A alternator powered entire airplanes . . . thousands of them. Now see a suggestion that this capable source be partitioned off to run one of the smallest energy-demands in airplane . . . a thump-thump pump. Adding a 40A external alternator to the 912/914 engine offers a great opportunity to craft a Z-13/8 style system in the airplane . . . except it's a Z-13/18 with about twice the stand-by power of the original Z-13/8. This two-layered electrical system is about as robust with respect to failure modes as you can get. One pump would run from the battery bus, the second from the e-bus . . . or main bus . . . it wouldn't much matter with that large a stand- by energy source. This thing Rotax recommends for dedicating an 18A alternator to running just one pump is, in my not so humble opinion, just silly. Bob . . . ________________________________________________________________________________
Date: Oct 06, 2016
At 05:56 PM 10/5/2016, you wrote: >That may be true, but the Rotax 912iS and the UL Power engines do >shut off fuel pumps when the engine stops as do all modern >automobiles. Again, I am not concerned with a forced landing where >there is time to prepare. I am concerned with a crash, such as >flipping the aircraft due to soft or rough terrain, or a million >other things that could conceivably happen (and do happen). In such >an instance, I would prefer not to have a high pressure fuel pump >doing its job. You say "high-pressure" . . . is this no longer the solenoid driven spring style pump I described earlier? Is the 912/914 now fuel-injected? In any case, you can achieve the automatic shut off in the same way that cars have for decades. My truck uses an oil pressure switch to keep the pump running with a bypass relay energized by the starter switch to get fuel pressure while cranking. Your 'bypass' could be a simple diode off the starter engagement line that feeds power directly to the pump while cranking. Bob . . . ________________________________________________________________________________
Date: Oct 06, 2016
The Rotax 912 (with carburetor) has an engine driven fuel pump, so the engine is not electrically dependent. The Rotax 914iS fuel injected engine is electrically dependent with two high pressure fuel pumps. It seems that the Rotax engineers (and lawyers) do not trust aircraft electrical systems to be fail safe. Thus they have dedicated the flywheel dynamo to powering only a fuel pump. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461007#461007 ________________________________________________________________________________
Date: Oct 06, 2016
/Le 06/10/2016 14:53, Robert L. Nuckolls, III a crit : / > / > If you're talking about and electric, > "thump-thump" pump,/ Hi Bob and all, Just to say that the Rotax 914 pumps are the rotary vane type from Pierburg, like some German cars. http://contrails.free.fr/engine_pierburg_en.php FWIW, -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Date: Oct 06, 2016
I wondered if the battery was located in the passenger compartment so I looked it up. https://www.youtube.com/watch?v=d6ZTeFT137Y#t=26.879952 Yes, and it takes three boys and a monkey to swap one. Amazing. When I saw this I was glad I didn't own one. But I still doubt the Cause Of Death pronouncement. Cars usually have enough ventilation to avoid the buildup of noxious vapors. Aircrafts probably do even more. Recently around here a guy died because he was drunk and sleeping in his car, which went up to a zillion degrees in the sun. So I'd look for some COD that is more plausible. "Wisdom is being aware of the obvious." -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461010#461010 ________________________________________________________________________________
Date: Oct 06, 2016
Bob, the 914 engine is not fuel injected, but it is turbocharged and there is a fuel pressure regulator that maintains a constant fuel pressure over air pressure produced by the turbo. From what I can tell, it works the same as injection in that a lot of fuel is pumped to the regulator, but most of that is returned to the tank. I have no idea what a thump-thump pump is, but I believe the Rotax pumps are the same type as used in fuel injected automobiles. Ira, the 40 amp aux is belt driven. On Thu, Oct 6, 2016 at 5:59 AM, GTH wrote: > > *Le 06/10/2016 =C3- 14:53, Robert L. Nuckolls, III a =C3=A9crit : * > > > * If you're talking about and electric, "thump-thump" pump,* > > > Hi Bob and all, > > Just to say that the Rotax 914 pumps are the rotary vane type from > Pierburg, like some German cars. > > http://contrails.free.fr/engine_pierburg_en.php > > FWIW, > -- > Best regards, > Gilles > http://contrails.free.fr > http://lapierre.skunkworks.free.fr > ________________________________________________________________________________
Date: Oct 06, 2016
At 08:59 AM 10/6/2016, you wrote: >Le 06/10/2016 =E0 14:53, Robert L. Nuckolls, III a =E9crit : >> >> If you're talking about and electric, >> "thump-thump" pump, > >Hi Bob and all, > >Just to say that the Rotax 914 pumps are the >rotary vane type from Pierburg, like some German cars. > ><http://contrails.free.fr/engine_pierburg_en.php>http://contrails.free.fr/e ngine_pierburg_en.php Thanks. Okay, on the order of 30psi max. Do we know what the cracking pressure is for the fuel return line? The specs call for not more than 4.3A which would be at static pressure rating. This will be reduced in approximate proportion to the fuel control system pressure relief settings. It would be a valuable knowledge-nugget to contribute to the library if someone made a real-time measurement of fuel pump current in this system, The Rotax 912 (with carburetor) has an engine driven fuel pump, so the engine is not electrically dependent. The Rotax 914iS fuel injected engine is electrically dependent with two high pressure fuel pumps. It seems that the Rotax engineers (and lawyers) do not trust aircraft electrical systems to be fail safe. Thus they have dedicated the flywheel dynamo to powering only a fuel pump. Hmmmm . . . I wonder from whence their discomforts are derived? A study of the aviation accident reports shows that loss of electrical power is almost never a contributing factor in loss of engine . . . and it's an easy task to craft a failure tolerant system that insures sources of energy vital to engine operation. Z-13/8 evolved out of decades of experience and observation of aircraft operations in both TC and OBAM aviation venues. I would really appreciate it if anyone associated with Rotax or any other institution could show by considered FMEA how any aircraft fitted with Z-13/x is likely to suffer engine failure due to any single failure within the system. Some cultures find comfort in staffing committees of individuals paid to worry. All too often, work product of such committees fails the common sense approach to failure effects analysis. I observe that common sense is inversely proportional to the bureaucratization of the institution. My last stint in TC aviation offered me an inside observation of the merger of Beech/Hawker/Cessna into one big Textron operation. The very FIRST field failure problem I was asked to assist with had a STONE simple, two week solution made possible by the merger of the two inventories of qualified products . . . a foaming at the mouth field failure on one brand was easily mittigated by replacement of a decades old, field proven part from the other brand. The last meeting I attended before my consulting contract ran out left me with a feeling of satisfaction of having identified a short path to an elegant solution. To my dismay, nearly a year later I was told that there were 'problems' with the solution having nothing to do with form, fit, function and everything to do with differences of opinion from a parade of bureaucrats with 'worries' and regulatory barriers . . . I shudder to think of dozens of customers with million dollar airplanes; the foam around their mouths getting dried out, crusty and flaking off. I don't know they get an airplane built anymore. Walter, Clyde, Olive Ann, Hedrick, et. als. would be horrified to see what we've done to their airplane companies. My gut feeling is that Rotax is/has become similarly afflicted with bureaucratic worriers lacking foundation in physics and practical experience. This is a disease that is horribly taxing on one's ability to offer good value with un-impeachable confidence. In some instances it is terminal. In any case, I'm still unconvinced that the dedication of a rather capable energy source to the operation of a single, low energy task for which a back-up already exists is a solution seriously lacking elegance. Bob . . . ________________________________________________________________________________
Date: Oct 06, 2016
Poor engineering, those Porsche guys... CT -----Mensagem original----- De: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] Em nome de Eric M. Jones Enviada: Thursday, October 6, 2016 3:03 PM Para: aeroelectric-list(at)matronics.com Assunto: AeroElectric-List: Re: Poisonous Battery Vapors? --> I wondered if the battery was located in the passenger compartment so I looked it up. https://www.youtube.com/watch?v=d6ZTeFT137Y#t=26.879952 Yes, and it takes three boys and a monkey to swap one. Amazing. When I saw this I was glad I didn't own one. But I still doubt the Cause Of Death pronouncement. Cars usually have enough ventilation to avoid the buildup of noxious vapors. Aircrafts probably do even more. Recently around here a guy died because he was drunk and sleeping in his car, which went up to a zillion degrees in the sun. So I'd look for some COD that is more plausible. "Wisdom is being aware of the obvious." -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461010#461010 ________________________________________________________________________________
Date: Oct 06, 2016
At 10:39 AM 10/6/2016, you wrote: >Bob, the 914 engine is not fuel injected, but it is turbocharged and >there is a fuel pressure regulator that maintains a constant fuel >pressure over air pressure produced by the turbo. Do you know what the pressure setting is? Bob . . . ________________________________________________________________________________
Date: Oct 06, 2016
/Le 06/10/2016 22:42, Robert L. Nuckolls, III a crit :// / > /At 10:39 AM 10/6/2016, you wrote: > / >> /Bob, the 914 engine is not fuel injected, but it is turbocharged and >> there is a fuel pressure regulator that maintains a constant fuel >> pressure over air pressure produced by the turbo./ > / > //// Do you know what the pressure setting is?// > / Airbox pressure + 0.25 bar (+- 0.10 bar) -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Date: Oct 06, 2016
Per this document <http://www.rotax-owner.com/en/support-topmenu/technical-information/rotax- technical-articles/17-understanding-the-rotax-914/file> : The fuel regulator is mounted on the airbox and plays a critical role in maintaining fuel pressure to a minimum 0.15 BAR (2.18 PSI or 4.45=9D) above airbox boost pressure. The regulator is calibrated at the factory and normally no adjustments are required. In the event that the fuel pressure gets too low, due to a maladjustment or malfunction of the fuel regulator, the engine would experience fuel starvation due to the higher airbox pressure sensed in the carburetor float bowls not allowing the fuel supply to enter. A high fuel pressure can result from regulator maladjustment, malfunction or restriction in return line. A properly adjusted fuel regulator will maintain fuel pressure above airbox pressure within the following parameters: Maximum fuel pressure is 0.35 BAR (5.08 PSI or 10.36=9D) above airbox pressure Minimum fuel pressure is 0.15 BAR (2.18 PSI or 4.45=9D) above airbox pressure Normal fuel pressure is 0.25 BAR (3.63 PSI or 7.41=9D) above airbox p ressure On Thu, Oct 6, 2016 at 12:42 PM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 10:39 AM 10/6/2016, you wrote: > > Bob, the 914 engine is not fuel injected, but it is turbocharged and ther e > is a fuel pressure regulator that maintains a constant fuel pressure over > air pressure produced by the turbo. > > > Do you know what the pressure setting is? > > > Bob . . . > ________________________________________________________________________________
Date: Oct 06, 2016
I found this Pressure Switch which seems to be a viable way (combined with a relay) of automatically turning off the auxiliary fuel pump when the engine stops turning. On Thu, Oct 6, 2016 at 12:58 PM, GTH wrote: > *Le 06/10/2016 =C3- 22:42, Robert L. Nuckolls, III a =C3=A9crit :* > > > *At 10:39 AM 10/6/2016, you wrote: * > > *Bob, the 914 engine is not fuel injected, but it is turbocharged and > there is a fuel pressure regulator that maintains a constant fuel pressur e > over air pressure produced by the turbo.* > > > * Do you know what the pressure setting is?* > > > Airbox pressure + 0.25 bar (+- 0.10 bar) > > > -- > Best regards, > Gilles > http://contrails.free.fr > http://lapierre.skunkworks.free.fr > ________________________________________________________________________________
Date: Oct 07, 2016
/Le 07/10/2016 02:09, Ken Ryan a crit : / > /I found this Pressure Switch > which seems to be a > viable way (combined with a relay) of automatically turning off the > auxiliary fuel pump when the engine stops turning./ Your call. You'll make your engine operation dependent on a switch and a relay. "On a switch and a prayer" ;-) -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Date: Oct 07, 2016
Hi Ken; Advice from an old electro-mechanical engineer (now 76) and new pilot (@ 70 ): Keep the pilot in charge of turning things off. Cheers! Stu. ----- Original Message ----- From: "GTH" <gilles.thesee(at)free.fr> Sent: Friday, October 7, 2016 12:17:19 AM Subject: Re: AeroElectric-List: rotax generator without battery Le 07/10/2016 =C3- 02:09, Ken Ryan a =C3=A9crit : I found this Pressure Switch which seems to be a viable way (combined with a relay) of automatically turning off the auxiliary fuel pump when the engi ne stops turning. Your call. You'll make your engine operation dependent on a switch and a re lay. "On a switch and a prayer" ;-) -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Date: Oct 07, 2016
Q: how does the engine get it's fuel for start-up, the engine being off ie: n o oil pressure Sent from my iPad ----x--O--x---- > On 7 Oct 2016, at 02:51 pm, ashleysc(at)broadstripe.net wrote: > > Hi Ken; > Advice from an old electro-mechanical engineer (now 76) and new pilot (@ 7 0): Keep the pilot in charge of turning things off. > Cheers! Stu. > > From: "GTH" <gilles.thesee(at)free.fr> > To: aeroelectric-list(at)matronics.com > Sent: Friday, October 7, 2016 12:17:19 AM > Subject: Re: AeroElectric-List: rotax generator without battery > > Le 07/10/2016 =C3- 02:09, Ken Ryan a =C3=A9crit : > I found this Pressure Switch which seems to be a viable way (combined with a relay) of automatically turning off the auxiliary fuel pump when the engi ne stops turning. > > Your call. You'll make your engine operation dependent on a switch and a r elay. > "On a switch and a prayer" ;-) > -- > Best regards, > Gilles > http://contrails.free.fr > http://lapierre.skunkworks.free.fr > ________________________________________________________________________________
Date: Oct 07, 2016
Subject: Skyview Screens and Z13/8
I'm considering installation of a Dynon Skyview system with two 7" screens, and wondering how to best power them. I've got plenty of room on the ebus from a load analysis standpoint, but is it better to put one screen on the main bus in case the ebus were to short? Is there any issue with having a half volt difference powering the two screens? How has everyone else been doing it? ________________________________________________________________________________
Date: Oct 07, 2016
I think maybe some of you are not factoring in that this is on the auxiliary fuel pump only. So for a failure of the switch or relay to have any effect on the flight, the main fuel pump would have already had to fail. The primary fuel pump stops automatically when the engine stops turning because it is powered off the generator. As far as startup, I think the way the pressure switch works is that it is a single pole, double throw. So there are three terminals: Comm, L1, and L2. Without pressure, Comm is connected to L2. With pressure, Comm is connected to L1. The Comm goes to the fuel pump relay. L1 goes to a fuel pump switch. L2 goes to the starter side of the starter relay. So at startup, because the pressure switch without pressure is connected Comm-L2 only, closing the fuel pump switch would do nothing. But when cranking power is put to the starter, current would flow to the relay through the Comm-L2 connection. Then, when the engine starts and current is removed from the starter circuit, power continues to flow the fuel pump relay because now with 7lbs of oil pressure Comm is connected to L1 (and the switch has been turned on). On Fri, Oct 7, 2016 at 7:30 AM, John Tipton wrote: > Q: how does the engine get it's fuel for start-up, the engine being off > ie: no oil pressure > > Sent from my iPad > > ----x--O--x---- > > On 7 Oct 2016, at 02:51 pm, ashleysc(at)broadstripe.net wrote: > > Hi Ken; > Advice from an old electro-mechanical engineer (now 76) and new pilot (@ > 70): Keep the pilot in charge of turning things off. > Cheers! Stu. > > ------------------------------ > *From: *"GTH" <gilles.thesee(at)free.fr> > *To: *aeroelectric-list(at)matronics.com > *Sent: *Friday, October 7, 2016 12:17:19 AM > *Subject: *Re: AeroElectric-List: rotax generator without battery > > > *Le 07/10/2016 =C3- 02:09, Ken Ryan a =C3=A9crit : * > > *I found this Pressure Switch > which seems to be a viabl e > way (combined with a relay) of automatically turning off the auxiliary fu el > pump when the engine stops turning.* > > > Your call. You'll make your engine operation dependent on a switch and a > relay. > "On a switch and a prayer" ;-) > -- > Best regards, > Gilles > http://contrails.free.fr > http://lapierre.skunkworks.free.fr > > ________________________________________________________________________________
Date: Oct 07, 2016
Subject: Re: Skyview Screens and Z13/8
My understanding is you only put what you need to safely conclude the flight on the ebus so primary EFIS only. I would also highly recommend you put both screens on the pilot side so that if one fails, the other one is in front of you, not the passenger. On Fri, Oct 7, 2016 at 9:17 AM, Jared Yates wrote: > I'm considering installation of a Dynon Skyview system with two 7" > screens, and wondering how to best power them. I've got plenty of room on > the ebus from a load analysis standpoint, but is it better to put one > screen on the main bus in case the ebus were to short? Is there any issue > with having a half volt difference powering the two screens? How has > everyone else been doing it? > ________________________________________________________________________________
Date: Oct 07, 2016
In that case why do you need the backup pump energised at all, absent a main fuel pump failure? Many (most?) TC aircraft with fuel injection or low-wing tanks have an elect ric backup pump but it's either on only for takeoff and landing and switchin g tanks (Piper, Grumman) or only used for priming and in the event of engine storage due to main pump failure (Cessna) I'm not familiar with the proposed system so If the backup pump is permanent ly energised what alerts the pilot to a failure of the engine-driven pump? > On Oct 7, 2016, at 12:27 PM, Ken Ryan wrote: > > I think maybe some of you are not factoring in that this is on the auxilia ry fuel pump only. So for a failure of the switch or relay to have any effec t on the flight, the main fuel pump would have already had to fail. The prim ary fuel pump stops automatically when the engine stops turning because it i s powered off the generator. > > As far as startup, I think the way the pressure switch works is that it is a single pole, double throw. So there are three terminals: Comm, L1, and L2 . Without pressure, Comm is connected to L2. With pressure, Comm is connecte d to L1. > > The Comm goes to the fuel pump relay. > L1 goes to a fuel pump switch. > L2 goes to the starter side of the starter relay. > > So at startup, because the pressure switch without pressure is connected C omm-L2 only, closing the fuel pump switch would do nothing. But when crankin g power is put to the starter, current would flow to the relay through the C omm-L2 connection. Then, when the engine starts and current is removed from t he starter circuit, power continues to flow the fuel pump relay because now w ith 7lbs of oil pressure Comm is connected to L1 (and the switch has been tu rned on). > > > >> On Fri, Oct 7, 2016 at 7:30 AM, John Tipton wr ote: >> Q: how does the engine get it's fuel for start-up, the engine being off i e: no oil pressure >> >> Sent from my iPad >> >> ----x--O--x---- >> >>> On 7 Oct 2016, at 02:51 pm, ashleysc(at)broadstripe.net wrote: >>> >>> Hi Ken; >>> Advice from an old electro-mechanical engineer (now 76) and new pilot (@ 70): Keep the pilot in charge of turning things off. >>> Cheers! Stu. >>> >>> From: "GTH" <gilles.thesee(at)free.fr> >>> To: aeroelectric-list(at)matronics.com >>> Sent: Friday, October 7, 2016 12:17:19 AM >>> Subject: Re: AeroElectric-List: rotax generator without battery >>> >>> Le 07/10/2016 =C3- 02:09, Ken Ryan a =C3=A9crit : >>> I found this Pressure Switch which seems to be a viable way (combined wi th a relay) of automatically turning off the auxiliary fuel pump when the en gine stops turning. >>> >>> Your call. You'll make your engine operation dependent on a switch and a relay. >>> "On a switch and a prayer" ;-) >>> -- >>> Best regards, >>> Gilles >>> http://contrails.free.fr >>> http://lapierre.skunkworks.free.fr >>> > ________________________________________________________________________________
Date: Oct 07, 2016
Rotax operating procedures for 914 call for running both electric fuel pumps for takeoff and landings. On Fri, Oct 7, 2016 at 10:59 AM, Alec Myers wrote: > In that case why do you need the backup pump energised at all, absent a > main fuel pump failure? > > Many (most?) TC aircraft with fuel injection or low-wing tanks have an > electric backup pump but it's either on only for takeoff and landing and > switching tanks (Piper, Grumman) or only used for priming and in the even t > of engine storage due to main pump failure (Cessna) > > I'm not familiar with the proposed system so If the backup pump is > permanently energised what alerts the pilot to a failure of the > engine-driven pump? > > > On Oct 7, 2016, at 12:27 PM, Ken Ryan wrote: > > I think maybe some of you are not factoring in that this is on the > auxiliary fuel pump only. So for a failure of the switch or relay to have > any effect on the flight, the main fuel pump would have already had to > fail. The primary fuel pump stops automatically when the engine stops > turning because it is powered off the generator. > > As far as startup, I think the way the pressure switch works is that it i s > a single pole, double throw. So there are three terminals: Comm, L1, and > L2. Without pressure, Comm is connected to L2. With pressure, Comm is > connected to L1. > > The Comm goes to the fuel pump relay. > L1 goes to a fuel pump switch. > L2 goes to the starter side of the starter relay. > > So at startup, because the pressure switch without pressure is connected > Comm-L2 only, closing the fuel pump switch would do nothing. But when > cranking power is put to the starter, current would flow to the relay > through the Comm-L2 connection. Then, when the engine starts and current is > removed from the starter circuit, power continues to flow the fuel pump > relay because now with 7lbs of oil pressure Comm is connected to L1 (and > the switch has been turned on). > > > On Fri, Oct 7, 2016 at 7:30 AM, John Tipton > wrote: > >> Q: how does the engine get it's fuel for start-up, the engine being off >> ie: no oil pressure >> >> Sent from my iPad >> >> ----x--O--x---- >> >> On 7 Oct 2016, at 02:51 pm, ashleysc(at)broadstripe.net wrote: >> >> Hi Ken; >> Advice from an old electro-mechanical engineer (now 76) and new pilot (@ >> 70): Keep the pilot in charge of turning things off. >> Cheers! Stu. >> >> ------------------------------ >> *From: *"GTH" <gilles.thesee(at)free.fr> >> *To: *aeroelectric-list(at)matronics.com >> *Sent: *Friday, October 7, 2016 12:17:19 AM >> *Subject: *Re: AeroElectric-List: rotax generator without battery >> >> >> *Le 07/10/2016 =C3- 02:09, Ken Ryan a =C3=A9crit : * >> >> *I found this Pressure Switch >> which seems to be a viab le >> way (combined with a relay) of automatically turning off the auxiliary f uel >> pump when the engine stops turning.* >> >> >> Your call. You'll make your engine operation dependent on a switch and a >> relay. >> "On a switch and a prayer" ;-) >> -- >> Best regards, >> Gilles >> http://contrails.free.fr >> http://lapierre.skunkworks.free.fr >> >> > ________________________________________________________________________________
Date: Oct 07, 2016
That's very reasonable; why not just have an on-off switch for the backup pu mp? Switch it on on the ground to test, on for takeoff and landing and off t he rest of the time. Is there a benefit to having it run full time in parallel with the main pum p? how do you tell if the main pump has failed if the backup is already runn ing? On Oct 7, 2016, at 15:19, Ken Ryan wrote: Rotax operating procedures for 914 call for running both electric fuel pumps for takeoff and landings. > On Fri, Oct 7, 2016 at 10:59 AM, Alec Myers wrote: > In that case why do you need the backup pump energised at all, absent a ma in fuel pump failure? > > Many (most?) TC aircraft with fuel injection or low-wing tanks have an ele ctric backup pump but it's either on only for takeoff and landing and switch ing tanks (Piper, Grumman) or only used for priming and in the event of engi ne storage due to main pump failure (Cessna) > > I'm not familiar with the proposed system so If the backup pump is permane ntly energised what alerts the pilot to a failure of the engine-driven pump? > > >> On Oct 7, 2016, at 12:27 PM, Ken Ryan wrote: >> >> I think maybe some of you are not factoring in that this is on the auxili ary fuel pump only. So for a failure of the switch or relay to have any effe ct on the flight, the main fuel pump would have already had to fail. The pri mary fuel pump stops automatically when the engine stops turning because it i s powered off the generator. >> >> As far as startup, I think the way the pressure switch works is that it i s a single pole, double throw. So there are three terminals: Comm, L1, and L 2. Without pressure, Comm is connected to L2. With pressure, Comm is connect ed to L1. >> >> The Comm goes to the fuel pump relay. >> L1 goes to a fuel pump switch. >> L2 goes to the starter side of the starter relay. >> >> So at startup, because the pressure switch without pressure is connected C omm-L2 only, closing the fuel pump switch would do nothing. But when crankin g power is put to the starter, current would flow to the relay through the C omm-L2 connection. Then, when the engine starts and current is removed from t he starter circuit, power continues to flow the fuel pump relay because now w ith 7lbs of oil pressure Comm is connected to L1 (and the switch has been tu rned on). >> >> >> >>> On Fri, Oct 7, 2016 at 7:30 AM, John Tipton w rote: >>> Q: how does the engine get it's fuel for start-up, the engine being off i e: no oil pressure >>> >>> Sent from my iPad >>> >>> ----x--O--x---- >>> >>>> On 7 Oct 2016, at 02:51 pm, ashleysc(at)broadstripe.net wrote: >>>> >>>> Hi Ken; >>>> Advice from an old electro-mechanical engineer (now 76) and new pilot ( @ 70): Keep the pilot in charge of turning things off. >>>> Cheers! Stu. >>>> >>>> From: "GTH" <gilles.thesee(at)free.fr> >>>> To: aeroelectric-list(at)matronics.com >>>> Sent: Friday, October 7, 2016 12:17:19 AM >>>> Subject: Re: AeroElectric-List: rotax generator without battery >>>> >>>> Le 07/10/2016 =C3- 02:09, Ken Ryan a =C3=A9crit : >>>> I found this Pressure Switch which seems to be a viable way (combined w ith a relay) of automatically turning off the auxiliary fuel pump when the e ngine stops turning. >>>> >>>> Your call. You'll make your engine operation dependent on a switch and a relay. >>>> "On a switch and a prayer" ;-) >>>> -- >>>> Best regards, >>>> Gilles >>>> http://contrails.free.fr >>>> http://lapierre.skunkworks.free.fr >>>> >> ________________________________________________________________________________
Date: Oct 07, 2016
Alec, I'm not sure where you got the idea that the auxiliary pump would be running all the time. It would indeed be used only for takeoffs and landings, via a toggle switch. But inserting the pressure switch and the relay would insure that in the event of a crash, such as on takeoff or landing, the auxiliary pump would automatically shut down when the engine ceases to turn (because the oil pressure would drop). Ken On Fri, Oct 7, 2016 at 11:59 AM, Alec Myers wrote: > That's very reasonable; why not just have an on-off switch for the backup > pump? Switch it on on the ground to test, on for takeoff and landing and > off the rest of the time. > > Is there a benefit to having it run full time in parallel with the main > pump? how do you tell if the main pump has failed if the backup is alread y > running? > > > On Oct 7, 2016, at 15:19, Ken Ryan wrote: > > Rotax operating procedures for 914 call for running both electric fuel > pumps for takeoff and landings. > > On Fri, Oct 7, 2016 at 10:59 AM, Alec Myers wrote: > >> In that case why do you need the backup pump energised at all, absent a >> main fuel pump failure? >> >> Many (most?) TC aircraft with fuel injection or low-wing tanks have an >> electric backup pump but it's either on only for takeoff and landing and >> switching tanks (Piper, Grumman) or only used for priming and in the eve nt >> of engine storage due to main pump failure (Cessna) >> >> I'm not familiar with the proposed system so If the backup pump is >> permanently energised what alerts the pilot to a failure of the >> engine-driven pump? >> >> >> On Oct 7, 2016, at 12:27 PM, Ken Ryan wrote: >> >> I think maybe some of you are not factoring in that this is on the >> auxiliary fuel pump only. So for a failure of the switch or relay to hav e >> any effect on the flight, the main fuel pump would have already had to >> fail. The primary fuel pump stops automatically when the engine stops >> turning because it is powered off the generator. >> >> As far as startup, I think the way the pressure switch works is that it >> is a single pole, double throw. So there are three terminals: Comm, L1, and >> L2. Without pressure, Comm is connected to L2. With pressure, Comm is >> connected to L1. >> >> The Comm goes to the fuel pump relay. >> L1 goes to a fuel pump switch. >> L2 goes to the starter side of the starter relay. >> >> So at startup, because the pressure switch without pressure is connected >> Comm-L2 only, closing the fuel pump switch would do nothing. But when >> cranking power is put to the starter, current would flow to the relay >> through the Comm-L2 connection. Then, when the engine starts and current is >> removed from the starter circuit, power continues to flow the fuel pump >> relay because now with 7lbs of oil pressure Comm is connected to L1 (and >> the switch has been turned on). >> >> >> >> On Fri, Oct 7, 2016 at 7:30 AM, John Tipton >> wrote: >> >>> Q: how does the engine get it's fuel for start-up, the engine being off >>> ie: no oil pressure >>> >>> Sent from my iPad >>> >>> ----x--O--x---- >>> >>> On 7 Oct 2016, at 02:51 pm, ashleysc(at)broadstripe.net wrote: >>> >>> Hi Ken; >>> Advice from an old electro-mechanical engineer (now 76) and new pilot ( @ >>> 70): Keep the pilot in charge of turning things off. >>> Cheers! Stu. >>> >>> ------------------------------ >>> *From: *"GTH" <gilles.thesee(at)free.fr> >>> *To: *aeroelectric-list(at)matronics.com >>> *Sent: *Friday, October 7, 2016 12:17:19 AM >>> *Subject: *Re: AeroElectric-List: rotax generator without battery >>> >>> >>> *Le 07/10/2016 =C3- 02:09, Ken Ryan a =C3=A9crit : * >>> >>> *I found this Pressure Switch >>> which seems to be a via ble >>> way (combined with a relay) of automatically turning off the auxiliary fuel >>> pump when the engine stops turning.* >>> >>> >>> Your call. You'll make your engine operation dependent on a switch and a >>> relay. >>> "On a switch and a prayer" ;-) >>> -- >>> Best regards, >>> Gilles >>> http://contrails.free.fr >>> http://lapierre.skunkworks.free.fr >>> >>> >> > ________________________________________________________________________________
Date: Oct 07, 2016
It really comes down to probability, modified by your personal risk tolerance. What are the odds of actually needing the auto-off function of the aux pump (remember that in t/o-landing modes the other pump will be running, too; what auto-protects that one?), vs the likelihood of needing the backup pump (primary failure) and risking any one of the various wires, connectors, pressure switch, pressure *line*, etc causing loss of the pump? Or actually *causing* a problem (pressure line or pressure switch opening an oil exit path comes to mind...). In the 'simple' scenario, the aux pump switch mounted next to the primary pump switch allows one swipe to get both, if a crash is imminent. But if the auto feature makes you more comfortable, go for it. Charlie On Fri, Oct 7, 2016 at 3:14 PM, Ken Ryan wrote: > Alec, > > I'm not sure where you got the idea that the auxiliary pump would be > running all the time. It would indeed be used only for takeoffs and > landings, via a toggle switch. But inserting the pressure switch and the > relay would insure that in the event of a crash, such as on takeoff or > landing, the auxiliary pump would automatically shut down when the engine > ceases to turn (because the oil pressure would drop). > > Ken > > > On Fri, Oct 7, 2016 at 11:59 AM, Alec Myers wrote: > >> That's very reasonable; why not just have an on-off switch for the backu p >> pump? Switch it on on the ground to test, on for takeoff and landing and >> off the rest of the time. >> >> Is there a benefit to having it run full time in parallel with the main >> pump? how do you tell if the main pump has failed if the backup is alrea dy >> running? >> >> >> >> On Oct 7, 2016, at 15:19, Ken Ryan wrote: >> >> Rotax operating procedures for 914 call for running both electric fuel >> pumps for takeoff and landings. >> >> On Fri, Oct 7, 2016 at 10:59 AM, Alec Myers wrote: >> >>> In that case why do you need the backup pump energised at all, absent a >>> main fuel pump failure? >>> >>> Many (most?) TC aircraft with fuel injection or low-wing tanks have an >>> electric backup pump but it's either on only for takeoff and landing an d >>> switching tanks (Piper, Grumman) or only used for priming and in the ev ent >>> of engine storage due to main pump failure (Cessna) >>> >>> I'm not familiar with the proposed system so If the backup pump is >>> permanently energised what alerts the pilot to a failure of the >>> engine-driven pump? >>> >>> >>> On Oct 7, 2016, at 12:27 PM, Ken Ryan wrote: >>> >>> I think maybe some of you are not factoring in that this is on the >>> auxiliary fuel pump only. So for a failure of the switch or relay to ha ve >>> any effect on the flight, the main fuel pump would have already had to >>> fail. The primary fuel pump stops automatically when the engine stops >>> turning because it is powered off the generator. >>> >>> As far as startup, I think the way the pressure switch works is that it >>> is a single pole, double throw. So there are three terminals: Comm, L1, and >>> L2. Without pressure, Comm is connected to L2. With pressure, Comm is >>> connected to L1. >>> >>> The Comm goes to the fuel pump relay. >>> L1 goes to a fuel pump switch. >>> L2 goes to the starter side of the starter relay. >>> >>> So at startup, because the pressure switch without pressure is connecte d >>> Comm-L2 only, closing the fuel pump switch would do nothing. But when >>> cranking power is put to the starter, current would flow to the relay >>> through the Comm-L2 connection. Then, when the engine starts and curren t is >>> removed from the starter circuit, power continues to flow the fuel pump >>> relay because now with 7lbs of oil pressure Comm is connected to L1 (an d >>> the switch has been turned on). >>> >>> >>> >>> On Fri, Oct 7, 2016 at 7:30 AM, John Tipton >>> wrote: >>> >>>> Q: how does the engine get it's fuel for start-up, the engine being of f >>>> ie: no oil pressure >>>> >>>> Sent from my iPad >>>> >>>> ----x--O--x---- >>>> >>>> On 7 Oct 2016, at 02:51 pm, ashleysc(at)broadstripe.net wrote: >>>> >>>> Hi Ken; >>>> Advice from an old electro-mechanical engineer (now 76) and new pilot >>>> (@ 70): Keep the pilot in charge of turning things off. >>>> Cheers! Stu. >>>> >>>> ------------------------------ >>>> *From: *"GTH" <gilles.thesee(at)free.fr> >>>> *To: *aeroelectric-list(at)matronics.com >>>> *Sent: *Friday, October 7, 2016 12:17:19 AM >>>> *Subject: *Re: AeroElectric-List: rotax generator without battery >>>> >>>> >>>> *Le 07/10/2016 =C3- 02:09, Ken Ryan a =C3=A9crit : * >>>> >>>> *I found this Pressure Switch >>>> which seems to be a vi able >>>> way (combined with a relay) of automatically turning off the auxiliary fuel >>>> pump when the engine stops turning.* >>>> >>>> >>>> Your call. You'll make your engine operation dependent on a switch and >>>> a relay. >>>> "On a switch and a prayer" ;-) >>>> -- >>>> Best regards, >>>> Gilles >>>> http://contrails.free.fr >>>> http://lapierre.skunkworks.free.fr >>>> >>>> >>> >> > ________________________________________________________________________________
Date: Oct 07, 2016
Charlie, The primary pump is powered by the integrated generator, so it already has auto shut off. What are the odds? Well, in off airport operations here in Alaska the odds are probably higher than high altitude ops over midwest farm fields from one 6,000 foot paved runways to the next. I know more than one guy who has flipped his airplane, and they all say the same thing: it happened in an instant with no warning. Fortunately, they all walked away. Ken On Fri, Oct 7, 2016 at 1:41 PM, Charlie England wrote: > It really comes down to probability, modified by your personal risk > tolerance. What are the odds of actually needing the auto-off function of > the aux pump (remember that in t/o-landing modes the other pump will be > running, too; what auto-protects that one?), vs the likelihood of needing > the backup pump (primary failure) and risking any one of the various wire s, > connectors, pressure switch, pressure *line*, etc causing loss of the pum p? > Or actually *causing* a problem (pressure line or pressure switch opening > an oil exit path comes to mind...). > > In the 'simple' scenario, the aux pump switch mounted next to the primary > pump switch allows one swipe to get both, if a crash is imminent. > > But if the auto feature makes you more comfortable, go for it. > > Charlie > > On Fri, Oct 7, 2016 at 3:14 PM, Ken Ryan wrote: > >> Alec, >> >> I'm not sure where you got the idea that the auxiliary pump would be >> running all the time. It would indeed be used only for takeoffs and >> landings, via a toggle switch. But inserting the pressure switch and the >> relay would insure that in the event of a crash, such as on takeoff or >> landing, the auxiliary pump would automatically shut down when the engin e >> ceases to turn (because the oil pressure would drop). >> >> Ken >> >> >> On Fri, Oct 7, 2016 at 11:59 AM, Alec Myers wrote: >> >>> That's very reasonable; why not just have an on-off switch for the >>> backup pump? Switch it on on the ground to test, on for takeoff and lan ding >>> and off the rest of the time. >>> >>> Is there a benefit to having it run full time in parallel with the mai n >>> pump? how do you tell if the main pump has failed if the backup is alre ady >>> running? >>> >>> >>> >>> On Oct 7, 2016, at 15:19, Ken Ryan wrote: >>> >>> Rotax operating procedures for 914 call for running both electric fuel >>> pumps for takeoff and landings. >>> >>> On Fri, Oct 7, 2016 at 10:59 AM, Alec Myers wrote: >>> >>>> In that case why do you need the backup pump energised at all, absent a >>>> main fuel pump failure? >>>> >>>> Many (most?) TC aircraft with fuel injection or low-wing tanks have an >>>> electric backup pump but it's either on only for takeoff and landing a nd >>>> switching tanks (Piper, Grumman) or only used for priming and in the e vent >>>> of engine storage due to main pump failure (Cessna) >>>> >>>> I'm not familiar with the proposed system so If the backup pump is >>>> permanently energised what alerts the pilot to a failure of the >>>> engine-driven pump? >>>> >>>> >>>> On Oct 7, 2016, at 12:27 PM, Ken Ryan wrote: >>>> >>>> I think maybe some of you are not factoring in that this is on the >>>> auxiliary fuel pump only. So for a failure of the switch or relay to h ave >>>> any effect on the flight, the main fuel pump would have already had to >>>> fail. The primary fuel pump stops automatically when the engine stops >>>> turning because it is powered off the generator. >>>> >>>> As far as startup, I think the way the pressure switch works is that i t >>>> is a single pole, double throw. So there are three terminals: Comm, L1 , and >>>> L2. Without pressure, Comm is connected to L2. With pressure, Comm is >>>> connected to L1. >>>> >>>> The Comm goes to the fuel pump relay. >>>> L1 goes to a fuel pump switch. >>>> L2 goes to the starter side of the starter relay. >>>> >>>> So at startup, because the pressure switch without pressure is >>>> connected Comm-L2 only, closing the fuel pump switch would do nothing. But >>>> when cranking power is put to the starter, current would flow to the r elay >>>> through the Comm-L2 connection. Then, when the engine starts and curre nt is >>>> removed from the starter circuit, power continues to flow the fuel pum p >>>> relay because now with 7lbs of oil pressure Comm is connected to L1 (a nd >>>> the switch has been turned on). >>>> >>>> >>>> >>>> On Fri, Oct 7, 2016 at 7:30 AM, John Tipton >>>> wrote: >>>> >>>>> Q: how does the engine get it's fuel for start-up, the engine being >>>>> off ie: no oil pressure >>>>> >>>>> Sent from my iPad >>>>> >>>>> ----x--O--x---- >>>>> >>>>> On 7 Oct 2016, at 02:51 pm, ashleysc(at)broadstripe.net wrote: >>>>> >>>>> Hi Ken; >>>>> Advice from an old electro-mechanical engineer (now 76) and new pilot >>>>> (@ 70): Keep the pilot in charge of turning things off. >>>>> Cheers! Stu. >>>>> >>>>> ------------------------------ >>>>> *From: *"GTH" <gilles.thesee(at)free.fr> >>>>> *To: *aeroelectric-list(at)matronics.com >>>>> *Sent: *Friday, October 7, 2016 12:17:19 AM >>>>> *Subject: *Re: AeroElectric-List: rotax generator without battery >>>>> >>>>> >>>>> *Le 07/10/2016 =C3- 02:09, Ken Ryan a =C3=A9crit : * >>>>> >>>>> *I found this Pressure Switch >>>>> which seems to be a v iable >>>>> way (combined with a relay) of automatically turning off the auxiliar y fuel >>>>> pump when the engine stops turning.* >>>>> >>>>> >>>>> Your call. You'll make your engine operation dependent on a switch an d >>>>> a relay. >>>>> "On a switch and a prayer" ;-) >>>>> -- >>>>> Best regards, >>>>> Gilles >>>>> http://contrails.free.fr >>>>> http://lapierre.skunkworks.free.fr >>>>> >>>>> >>>> >>> >> > ________________________________________________________________________________
Date: Oct 07, 2016
Subject: Re: rotax generator without battery
Rotax's advice to energize the backup pump for landing is based on limiting t heir own liability rather than improving your overall safety. Even if it's g enuinely based on a concern for your safety then a pound to a penny the risk analysis on which they based that advice (if they did one) assumes 6000' ta rmac strips and essentially no risk of inverting the aircraft with adequate p ilot skill rather than rough bush operations. Have you considered overriding their advice and leaving the pump off for lan ding? On Oct 7, 2016, at 17:58, Ken Ryan wrote: Charlie, The primary pump is powered by the integrated generator, so it already has a uto shut off. What are the odds? Well, in off airport operations here in Alaska the odds a re probably higher than high altitude ops over midwest farm fields from one 6 ,000 foot paved runways to the next. I know more than one guy who has flippe d his airplane, and they all say the same thing: it happened in an instant w ith no warning. Fortunately, they all walked away. Ken > On Fri, Oct 7, 2016 at 1:41 PM, Charlie England wro te: > It really comes down to probability, modified by your personal risk tolera nce. What are the odds of actually needing the auto-off function of the aux p ump (remember that in t/o-landing modes the other pump will be running, too; what auto-protects that one?), vs the likelihood of needing the backup pump (primary failure) and risking any one of the various wires, connectors, pre ssure switch, pressure *line*, etc causing loss of the pump? Or actually *ca using* a problem (pressure line or pressure switch opening an oil exit path c omes to mind...). > > In the 'simple' scenario, the aux pump switch mounted next to the primary p ump switch allows one swipe to get both, if a crash is imminent. > > But if the auto feature makes you more comfortable, go for it. > > Charlie > >> On Fri, Oct 7, 2016 at 3:14 PM, Ken Ryan wrote: >> Alec, >> >> I'm not sure where you got the idea that the auxiliary pump would be runn ing all the time. It would indeed be used only for takeoffs and landings, vi a a toggle switch. But inserting the pressure switch and the relay would ins ure that in the event of a crash, such as on takeoff or landing, the auxilia ry pump would automatically shut down when the engine ceases to turn (becaus e the oil pressure would drop). >> >> Ken >> >> >>> On Fri, Oct 7, 2016 at 11:59 AM, Alec Myers wrote: >>> That's very reasonable; why not just have an on-off switch for the backu p pump? Switch it on on the ground to test, on for takeoff and landing and o ff the rest of the time. >>> >>> Is there a benefit to having it run full time in parallel with the main pump? how do you tell if the main pump has failed if the backup is already r unning? >>> >>> >>> >>> On Oct 7, 2016, at 15:19, Ken Ryan wrote: >>> >>> Rotax operating procedures for 914 call for running both electric fuel p umps for takeoff and landings. >>> >>>> On Fri, Oct 7, 2016 at 10:59 AM, Alec Myers wrote: >>>> In that case why do you need the backup pump energised at all, absent a main fuel pump failure? >>>> >>>> Many (most?) TC aircraft with fuel injection or low-wing tanks have an e lectric backup pump but it's either on only for takeoff and landing and swit ching tanks (Piper, Grumman) or only used for priming and in the event of en gine storage due to main pump failure (Cessna) >>>> >>>> I'm not familiar with the proposed system so If the backup pump is perm anently energised what alerts the pilot to a failure of the engine-driven pu mp? >>>> >>>> >>>>> On Oct 7, 2016, at 12:27 PM, Ken Ryan wrote: >>>>> >>>>> I think maybe some of you are not factoring in that this is on the aux iliary fuel pump only. So for a failure of the switch or relay to have any e ffect on the flight, the main fuel pump would have already had to fail. The p rimary fuel pump stops automatically when the engine stops turning because i t is powered off the generator. >>>>> >>>>> As far as startup, I think the way the pressure switch works is that i t is a single pole, double throw. So there are three terminals: Comm, L1, an d L2. Without pressure, Comm is connected to L2. With pressure, Comm is conn ected to L1. >>>>> >>>>> The Comm goes to the fuel pump relay. >>>>> L1 goes to a fuel pump switch. >>>>> L2 goes to the starter side of the starter relay. >>>>> >>>>> So at startup, because the pressure switch without pressure is connect ed Comm-L2 only, closing the fuel pump switch would do nothing. But when cra nking power is put to the starter, current would flow to the relay through t he Comm-L2 connection. Then, when the engine starts and current is removed f rom the starter circuit, power continues to flow the fuel pump relay because now with 7lbs of oil pressure Comm is connected to L1 (and the switch has b een turned on). >>>>> >>>>> >>>>> >>>>>> On Fri, Oct 7, 2016 at 7:30 AM, John Tipton wrote: >>>>>> Q: how does the engine get it's fuel for start-up, the engine being o ff ie: no oil pressure >>>>>> >>>>>> Sent from my iPad >>>>>> >>>>>> ----x--O--x---- >>>>>> >>>>>>> On 7 Oct 2016, at 02:51 pm, ashleysc(at)broadstripe.net wrote: >>>>>>> >>>>>>> Hi Ken; >>>>>>> Advice from an old electro-mechanical engineer (now 76) and new pilo t (@ 70): Keep the pilot in charge of turning things off. >>>>>>> Cheers! Stu. >>>>>>> >>>>>>> From: "GTH" <gilles.thesee(at)free.fr> >>>>>>> To: aeroelectric-list(at)matronics.com >>>>>>> Sent: Friday, October 7, 2016 12:17:19 AM >>>>>>> Subject: Re: AeroElectric-List: rotax generator without battery >>>>>>> >>>>>>> Le 07/10/2016 =C3- 02:09, Ken Ryan a =C3=A9crit : >>>>>>> I found this Pressure Switch which seems to be a viable way (combine d with a relay) of automatically turning off the auxiliary fuel pump when th e engine stops turning. >>>>>>> >>>>>>> Your call. You'll make your engine operation dependent on a switch a nd a relay. >>>>>>> "On a switch and a prayer" ;-) >>>>>>> -- >>>>>>> Best regards, >>>>>>> Gilles >>>>>>> http://contrails.free.fr >>>>>>> http://lapierre.skunkworks.free.fr >>>>>>> >>>>> >>> >> > ________________________________________________________________________________
Date: Oct 07, 2016
Alec, Yes I have indeed considered that! On Fri, Oct 7, 2016 at 3:30 PM, Alec Myers wrote: > Rotax's advice to energize the backup pump for landing is based on > limiting their own liability rather than improving your overall safety. > Even if it's genuinely based on a concern for your safety then a pound to a > penny the risk analysis on which they based that advice (if they did one) > assumes 6000' tarmac strips and essentially no risk of inverting the > aircraft with adequate pilot skill rather than rough bush operations. > > Have you considered overriding their advice and leaving the pump off for > landing? > > On Oct 7, 2016, at 17:58, Ken Ryan wrote: > > Charlie, > > The primary pump is powered by the integrated generator, so it already ha s > auto shut off. > > What are the odds? Well, in off airport operations here in Alaska the odd s > are probably higher than high altitude ops over midwest farm fields from > one 6,000 foot paved runways to the next. I know more than one guy who ha s > flipped his airplane, and they all say the same thing: it happened in an > instant with no warning. Fortunately, they all walked away. > > Ken > > On Fri, Oct 7, 2016 at 1:41 PM, Charlie England > wrote: > >> It really comes down to probability, modified by your personal risk >> tolerance. What are the odds of actually needing the auto-off function o f >> the aux pump (remember that in t/o-landing modes the other pump will be >> running, too; what auto-protects that one?), vs the likelihood of needin g >> the backup pump (primary failure) and risking any one of the various wir es, >> connectors, pressure switch, pressure *line*, etc causing loss of the pu mp? >> Or actually *causing* a problem (pressure line or pressure switch openin g >> an oil exit path comes to mind...). >> >> In the 'simple' scenario, the aux pump switch mounted next to the primar y >> pump switch allows one swipe to get both, if a crash is imminent. >> >> But if the auto feature makes you more comfortable, go for it. >> >> Charlie >> >> On Fri, Oct 7, 2016 at 3:14 PM, Ken Ryan wrote: >> >>> Alec, >>> >>> I'm not sure where you got the idea that the auxiliary pump would be >>> running all the time. It would indeed be used only for takeoffs and >>> landings, via a toggle switch. But inserting the pressure switch and th e >>> relay would insure that in the event of a crash, such as on takeoff or >>> landing, the auxiliary pump would automatically shut down when the engi ne >>> ceases to turn (because the oil pressure would drop). >>> >>> Ken >>> >>> >>> On Fri, Oct 7, 2016 at 11:59 AM, Alec Myers wrote: >>> >>>> That's very reasonable; why not just have an on-off switch for the >>>> backup pump? Switch it on on the ground to test, on for takeoff and la nding >>>> and off the rest of the time. >>>> >>>> Is there a benefit to having it run full time in parallel with the >>>> main pump? how do you tell if the main pump has failed if the backup i s >>>> already running? >>>> >>>> >>>> >>>> On Oct 7, 2016, at 15:19, Ken Ryan wrote: >>>> >>>> Rotax operating procedures for 914 call for running both electric fuel >>>> pumps for takeoff and landings. >>>> >>>> On Fri, Oct 7, 2016 at 10:59 AM, Alec Myers wrote : >>>> >>>>> In that case why do you need the backup pump energised at all, absent >>>>> a main fuel pump failure? >>>>> >>>>> Many (most?) TC aircraft with fuel injection or low-wing tanks have a n >>>>> electric backup pump but it's either on only for takeoff and landing and >>>>> switching tanks (Piper, Grumman) or only used for priming and in the event >>>>> of engine storage due to main pump failure (Cessna) >>>>> >>>>> I'm not familiar with the proposed system so If the backup pump is >>>>> permanently energised what alerts the pilot to a failure of the >>>>> engine-driven pump? >>>>> >>>>> >>>>> On Oct 7, 2016, at 12:27 PM, Ken Ryan wrote: >>>>> >>>>> I think maybe some of you are not factoring in that this is on the >>>>> auxiliary fuel pump only. So for a failure of the switch or relay to have >>>>> any effect on the flight, the main fuel pump would have already had t o >>>>> fail. The primary fuel pump stops automatically when the engine stops >>>>> turning because it is powered off the generator. >>>>> >>>>> As far as startup, I think the way the pressure switch works is that >>>>> it is a single pole, double throw. So there are three terminals: Comm , L1, >>>>> and L2. Without pressure, Comm is connected to L2. With pressure, Com m is >>>>> connected to L1. >>>>> >>>>> The Comm goes to the fuel pump relay. >>>>> L1 goes to a fuel pump switch. >>>>> L2 goes to the starter side of the starter relay. >>>>> >>>>> So at startup, because the pressure switch without pressure is >>>>> connected Comm-L2 only, closing the fuel pump switch would do nothing . But >>>>> when cranking power is put to the starter, current would flow to the relay >>>>> through the Comm-L2 connection. Then, when the engine starts and curr ent is >>>>> removed from the starter circuit, power continues to flow the fuel pu mp >>>>> relay because now with 7lbs of oil pressure Comm is connected to L1 ( and >>>>> the switch has been turned on). >>>>> >>>>> >>>>> >>>>> On Fri, Oct 7, 2016 at 7:30 AM, John Tipton >>>>> wrote: >>>>> >>>>>> Q: how does the engine get it's fuel for start-up, the engine being >>>>>> off ie: no oil pressure >>>>>> >>>>>> Sent from my iPad >>>>>> >>>>>> ----x--O--x---- >>>>>> >>>>>> On 7 Oct 2016, at 02:51 pm, ashleysc(at)broadstripe.net wrote: >>>>>> >>>>>> Hi Ken; >>>>>> Advice from an old electro-mechanical engineer (now 76) and new pilo t >>>>>> (@ 70): Keep the pilot in charge of turning things off. >>>>>> Cheers! Stu. >>>>>> >>>>>> ------------------------------ >>>>>> *From: *"GTH" <gilles.thesee(at)free.fr> >>>>>> *To: *aeroelectric-list(at)matronics.com >>>>>> *Sent: *Friday, October 7, 2016 12:17:19 AM >>>>>> *Subject: *Re: AeroElectric-List: rotax generator without battery >>>>>> >>>>>> >>>>>> *Le 07/10/2016 =C3- 02:09, Ken Ryan a =C3=A9crit : * >>>>>> >>>>>> *I found this Pressure Switch >>>>>> which seems to be a viable >>>>>> way (combined with a relay) of automatically turning off the auxilia ry fuel >>>>>> pump when the engine stops turning.* >>>>>> >>>>>> >>>>>> Your call. You'll make your engine operation dependent on a switch >>>>>> and a relay. >>>>>> "On a switch and a prayer" ;-) >>>>>> -- >>>>>> Best regards, >>>>>> Gilles >>>>>> http://contrails.free.fr >>>>>> http://lapierre.skunkworks.free.fr >>>>>> >>>>>> >>>>> >>>> >>> >> > ________________________________________________________________________________
Date: Oct 07, 2016
I agree with Ken's analysis. Several scenarios where the auto shutoff would be a benefit: Snag a wheel and invert on t/o or landing; Challenging cross wind landing goes bad; Failure to clear and obstacle on t/o or landing; Bird strike; Deer strike; Encounter with extraterrestrial beings; and the ever popular item with insurance companies -Act of God-. If it were my aircraft, I'd put in an 'engine not in operation' detection system of some sort. Oil pressure switches have a long history of reliable operation in the field. The only issue I see is verifying the system is functioning properly during preflight/startup. Raymond Julian Kettle River, MN The things we admire in men, kindness and generosity, openness, honesty, understanding and feeling are the concomitants of failure in our system. And those traits we detest, sharpness, greed, acquisitiveness, meanness, egotism and self-interest are the traits of success. And while men admire the quality of the first they love the produce of the second. -John Steinbeck, novelist, Nobel laureate (1902-1968) On 10/07/2016 04:58 PM, Ken Ryan wrote: > Charlie, > > The primary pump is powered by the integrated generator, so it already > has auto shut off. > > What are the odds? Well, in off airport operations here in Alaska the > odds are probably higher than high altitude ops over midwest farm fields > from one 6,000 foot paved runways to the next. I know more than one guy > who has flipped his airplane, and they all say the same thing: it > happened in an instant with no warning. Fortunately, they all walked away. > > Ken > > On Fri, Oct 7, 2016 at 1:41 PM, Charlie England > wrote: > > It really comes down to probability, modified by your personal risk > tolerance. What are the odds of actually needing the auto-off > function of the aux pump (remember that in t/o-landing modes the > other pump will be running, too; what auto-protects that one?), vs > the likelihood of needing the backup pump (primary failure) and > risking any one of the various wires, connectors, pressure switch, > pressure *line*, etc causing loss of the pump? Or actually *causing* > a problem (pressure line or pressure switch opening an oil exit path > comes to mind...). > > In the 'simple' scenario, the aux pump switch mounted next to the > primary pump switch allows one swipe to get both, if a crash is > imminent. > > But if the auto feature makes you more comfortable, go for it. > > Charlie > > On Fri, Oct 7, 2016 at 3:14 PM, Ken Ryan > wrote: > > Alec, > > I'm not sure where you got the idea that the auxiliary pump > would be running all the time. It would indeed be used only for > takeoffs and landings, via a toggle switch. But inserting the > pressure switch and the relay would insure that in the event of > a crash, such as on takeoff or landing, the auxiliary pump would > automatically shut down when the engine ceases to turn (because > the oil pressure would drop). > > Ken > > > On Fri, Oct 7, 2016 at 11:59 AM, Alec Myers > wrote: > > That's very reasonable; why not just have an on-off switch > for the backup pump? Switch it on on the ground to test, on > for takeoff and landing and off the rest of the time. > > Is there a benefit to having it run full time in parallel > with the main pump? how do you tell if the main pump has > failed if the backup is already running? > > > On Oct 7, 2016, at 15:19, Ken Ryan > wrote: > > Rotax operating procedures for 914 call for running both > electric fuel pumps for takeoff and landings. > > On Fri, Oct 7, 2016 at 10:59 AM, Alec Myers > > wrote: > > In that case why do you need the backup pump energised > at all, absent a main fuel pump failure? > > Many (most?) TC aircraft with fuel injection or low-wing > tanks have an electric backup pump but it's either on > only for takeoff and landing and switching tanks (Piper, > Grumman) or only used for priming and in the event of > engine storage due to main pump failure (Cessna) > > I'm not familiar with the proposed system so If the > backup pump is permanently energised what alerts the > pilot to a failure of the engine-driven pump? > > > On Oct 7, 2016, at 12:27 PM, Ken Ryan > > > wrote: > >> I think maybe some of you are not factoring in that >> this is on the auxiliary fuel pump only. So for a >> failure of the switch or relay to have any effect on >> the flight, the main fuel pump would have already had >> to fail. The primary fuel pump stops automatically >> when the engine stops turning because it is powered >> off the generator. >> >> As far as startup, I think the way the pressure switch >> works is that it is a single pole, double throw. So >> there are three terminals: Comm, L1, and L2. Without >> pressure, Comm is connected to L2. With pressure, Comm >> is connected to L1. >> >> The Comm goes to the fuel pump relay. >> L1 goes to a fuel pump switch. >> L2 goes to the starter side of the starter relay. >> >> So at startup, because the pressure switch without >> pressure is connected Comm-L2 only, closing the fuel >> pump switch would do nothing. But when cranking power >> is put to the starter, current would flow to the relay >> through the Comm-L2 connection. Then, when the engine >> starts and current is removed from the starter >> circuit, power continues to flow the fuel pump relay >> because now with 7lbs of oil pressure Comm is >> connected to L1 (and the switch has been turned on). >> >> >> >> On Fri, Oct 7, 2016 at 7:30 AM, John Tipton >> > > wrote: >> >> Q: how does the engine get it's fuel for start-up, >> the engine being off ie: no oil pressure >> >> Sent from my iPad >> >> ----x--O--x---- >> >> On 7 Oct 2016, at 02:51 pm, >> ashleysc(at)broadstripe.net >> wrote: >> >>> Hi Ken; >>> Advice from an old electro-mechanical engineer >>> (now 76) and new pilot (@ 70): Keep the pilot in >>> charge of turning things off. >>> Cheers! Stu. >>> >>> ------------------------------------------------------------------------ >>> *From: *"GTH" <gilles.thesee(at)free.fr >>> > >>> *To: *aeroelectric-list(at)matronics.com >>> >>> *Sent: *Friday, October 7, 2016 12:17:19 AM >>> *Subject: *Re: AeroElectric-List: rotax generator >>> without battery >>> >>> /Le 07/10/2016 02:09, Ken Ryan a crit : >>> / >>> >>> /I found this Pressure Switch >>> which >>> seems to be a viable way (combined with a >>> relay) of automatically turning off the >>> auxiliary fuel pump when the engine stops >>> turning./ >>> >>> >>> Your call. You'll make your engine operation >>> dependent on a switch and a relay. >>> "On a switch and a prayer" ;-) >>> -- >>> Best regards, >>> Gilles >>> http://contrails.free.fr >>> http://lapierre.skunkworks.free.fr >>> <http://lapierre.skunkworks.free.fr> >>> >> > > ________________________________________________________________________________
Date: Oct 07, 2016
At 02:17 AM 10/7/2016, you wrote: >Le 07/10/2016 =C3 02:09, Ken Ryan a =C3=A9crit=C2 : >>I found this=C2 >>Pressure >>Switch=C2 which seems to be a viable way >>(combined with a relay) of automatically >>turning off the auxiliary fuel pump when the engine stops turning. > >Your call. You'll make your engine operation >dependent on a switch and a relay. >"On a switch and a prayer" ;-) How so? If there are TWO pumps with independent power paths, then the holy grail of FMEA has been achieved. "No single failure" of the electrically driven fuel delivery system will disable the engine. In conducting an FMEA you assume that EVERY part . . . crimped terminals, threaded fasteners, circuit breaker, switch, relay, etc. etc. WILL fail. Then configure a system whereby that failure does not put the airplane at risk. See chapter 17 of the 'Connection. Bob . . . ________________________________________________________________________________
Date: Oct 07, 2016
Raymond, I don't see a problem verifying that the system is functioning properly. Startup procedure would be: 1. Flip auxiliary fuel pump switch on (nothing happens) 2. Engage starter (simultaneously sends power to the aux pump) 3. Oil pressure rises, engine starts 4. Starter is disengaged 5. Engine continues to run At this point the auxiliary fuel system has been checked. All that remains is to power up the main fuel pump and then turn off the aux pump. If the engine continues to run, the main fuel pump check out. Incidentally, it turns out that no relay is necessary. The pressure switch is adequately rated for the pump current. Ken On Fri, Oct 7, 2016 at 4:30 PM, rayj wrote: > > I agree with Ken's analysis. Several scenarios where the auto shutoff > would be a benefit: Snag a wheel and invert on t/o or landing; Challengi ng > cross wind landing goes bad; Failure to clear and obstacle on t/o or > landing; Bird strike; Deer strike; Encounter with extraterrestrial > beings; and the ever popular item with insurance companies -Act of God-. > > If it were my aircraft, I'd put in an 'engine not in operation' detection > system of some sort. Oil pressure switches have a long history of reliab le > operation in the field. The only issue I see is verifying the system is > functioning properly during preflight/startup. > > Raymond Julian > Kettle River, MN > > The things we admire in men, kindness and generosity, openness, honesty, > understanding and feeling are the concomitants of failure in our system. > And those traits we detest, sharpness, greed, acquisitiveness, meanness, > egotism and self-interest are the traits of success. And while men admire > the quality of the first they love the produce of the second. -John > Steinbeck, novelist, Nobel laureate (1902-1968) > > On 10/07/2016 04:58 PM, Ken Ryan wrote: > >> Charlie, >> >> The primary pump is powered by the integrated generator, so it already >> has auto shut off. >> >> What are the odds? Well, in off airport operations here in Alaska the >> odds are probably higher than high altitude ops over midwest farm fields >> from one 6,000 foot paved runways to the next. I know more than one guy >> who has flipped his airplane, and they all say the same thing: it >> happened in an instant with no warning. Fortunately, they all walked awa y. >> >> Ken >> >> On Fri, Oct 7, 2016 at 1:41 PM, Charlie England > > wrote: >> >> It really comes down to probability, modified by your personal risk >> tolerance. What are the odds of actually needing the auto-off >> function of the aux pump (remember that in t/o-landing modes the >> other pump will be running, too; what auto-protects that one?), vs >> the likelihood of needing the backup pump (primary failure) and >> risking any one of the various wires, connectors, pressure switch, >> pressure *line*, etc causing loss of the pump? Or actually *causing* >> a problem (pressure line or pressure switch opening an oil exit path >> comes to mind...). >> >> In the 'simple' scenario, the aux pump switch mounted next to the >> primary pump switch allows one swipe to get both, if a crash is >> imminent. >> >> But if the auto feature makes you more comfortable, go for it. >> >> Charlie >> >> On Fri, Oct 7, 2016 at 3:14 PM, Ken Ryan > > wrote: >> >> Alec, >> >> I'm not sure where you got the idea that the auxiliary pump >> would be running all the time. It would indeed be used only for >> takeoffs and landings, via a toggle switch. But inserting the >> pressure switch and the relay would insure that in the event of >> a crash, such as on takeoff or landing, the auxiliary pump would >> automatically shut down when the engine ceases to turn (because >> the oil pressure would drop). >> >> Ken >> >> >> On Fri, Oct 7, 2016 at 11:59 AM, Alec Myers > > wrote: >> >> That's very reasonable; why not just have an on-off switch >> for the backup pump? Switch it on on the ground to test, on >> for takeoff and landing and off the rest of the time. >> >> Is there a benefit to having it run full time in parallel >> with the main pump? how do you tell if the main pump has >> failed if the backup is already running? >> >> >> >> On Oct 7, 2016, at 15:19, Ken Ryan > > wrote: >> >> Rotax operating procedures for 914 call for running both >> electric fuel pumps for takeoff and landings. >> >> On Fri, Oct 7, 2016 at 10:59 AM, Alec Myers >> > wrote: >> >> In that case why do you need the backup pump energised >> at all, absent a main fuel pump failure? >> >> Many (most?) TC aircraft with fuel injection or low-wing >> tanks have an electric backup pump but it's either on >> only for takeoff and landing and switching tanks (Piper, >> Grumman) or only used for priming and in the event of >> engine storage due to main pump failure (Cessna) >> >> I'm not familiar with the proposed system so If the >> backup pump is permanently energised what alerts the >> pilot to a failure of the engine-driven pump? >> >> >> On Oct 7, 2016, at 12:27 PM, Ken Ryan >> > >> wrote: >> >> I think maybe some of you are not factoring in that >>> this is on the auxiliary fuel pump only. So for a >>> failure of the switch or relay to have any effect on >>> the flight, the main fuel pump would have already had >>> to fail. The primary fuel pump stops automatically >>> when the engine stops turning because it is powered >>> off the generator. >>> >>> As far as startup, I think the way the pressure switch >>> works is that it is a single pole, double throw. So >>> there are three terminals: Comm, L1, and L2. Without >>> pressure, Comm is connected to L2. With pressure, Comm >>> is connected to L1. >>> >>> The Comm goes to the fuel pump relay. >>> L1 goes to a fuel pump switch. >>> L2 goes to the starter side of the starter relay. >>> >>> So at startup, because the pressure switch without >>> pressure is connected Comm-L2 only, closing the fuel >>> pump switch would do nothing. But when cranking power >>> is put to the starter, current would flow to the relay >>> through the Comm-L2 connection. Then, when the engine >>> starts and current is removed from the starter >>> circuit, power continues to flow the fuel pump relay >>> because now with 7lbs of oil pressure Comm is >>> connected to L1 (and the switch has been turned on). >>> >>> >>> >>> On Fri, Oct 7, 2016 at 7:30 AM, John Tipton >>> >> > wrote: >>> >>> Q: how does the engine get it's fuel for start-up, >>> the engine being off ie: no oil pressure >>> >>> Sent from my iPad >>> >>> ----x--O--x---- >>> >>> On 7 Oct 2016, at 02:51 pm, >>> ashleysc(at)broadstripe.net >>> wrote: >>> >>> Hi Ken; >>>> Advice from an old electro-mechanical engineer >>>> (now 76) and new pilot (@ 70): Keep the pilot in >>>> charge of turning things off. >>>> Cheers! Stu. >>>> >>>> ------------------------------ >>>> ------------------------------------------ >>>> *From: *"GTH" <gilles.thesee(at)free.fr >>>> > >>>> *To: *aeroelectric-list(at)matronics.com >>>> >>>> *Sent: *Friday, October 7, 2016 12:17:19 AM >>>> *Subject: *Re: AeroElectric-List: rotax generator >>>> without battery >>>> >>>> /Le 07/10/2016 =C3- 02:09, Ken Ryan a =C3=A9crit : >>>> / >>>> >>>> /I found this Pressure Switch >>>> >>>> which >>>> seems to be a viable way (combined with a >>>> relay) of automatically turning off the >>>> auxiliary fuel pump when the engine stops >>>> turning./ >>>> >>>> >>>> Your call. You'll make your engine operation >>>> dependent on a switch and a relay. >>>> "On a switch and a prayer" ;-) >>>> -- >>>> Best regards, >>>> Gilles >>>> http://contrails.free.fr >>>> http://lapierre.skunkworks.free.fr >>>> <http://lapierre.skunkworks.free.fr> >>>> >>>> >>> >> >> >> >> =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Oct 08, 2016
I didn't catch that the primary pump was switchable. I made the mistake of assuming that it was wired direct to the engine driven power supply (a la a mechanical pump). Sounds foolish now that I see it in print. As long as the battery can crank the engine long enough to pressurize the oil system sufficiently, is should work. Or, you could start with the primary, and immediately switch to aux pump for ground operations, then both on takeoff. I'm sure with a little T&E it can be worked out. Raymond Julian Kettle River, MN The things we admire in men, kindness and generosity, openness, honesty, understanding and feeling are the concomitants of failure in our system. And those traits we detest, sharpness, greed, acquisitiveness, meanness, egotism and self-interest are the traits of success. And while men admire the quality of the first they love the produce of the second. -John Steinbeck, novelist, Nobel laureate (1902-1968) On 10/07/2016 11:44 PM, Ken Ryan wrote: > Raymond, > > I don't see a problem verifying that the system is functioning properly. > Startup procedure would be: > > 1. Flip auxiliary fuel pump switch on (nothing happens) > 2. Engage starter (simultaneously sends power to the aux pump) > 3. Oil pressure rises, engine starts > 4. Starter is disengaged > 5. Engine continues to run > > At this point the auxiliary fuel system has been checked. All that > remains is to power up the main fuel pump and then turn off the aux > pump. If the engine continues to run, the main fuel pump check out. > > Incidentally, it turns out that no relay is necessary. The pressure > switch is adequately rated for the pump current. > > Ken > > > On Fri, Oct 7, 2016 at 4:30 PM, rayj > wrote: > > > > > I agree with Ken's analysis. Several scenarios where the auto > shutoff would be a benefit: Snag a wheel and invert on t/o or > landing; Challenging cross wind landing goes bad; Failure to clear > and obstacle on t/o or landing; Bird strike; Deer strike; > Encounter with extraterrestrial beings; and the ever popular item > with insurance companies -Act of God-. > > If it were my aircraft, I'd put in an 'engine not in operation' > detection system of some sort. Oil pressure switches have a long > history of reliable operation in the field. The only issue I see is > verifying the system is functioning properly during preflight/startup. > > Raymond Julian > Kettle River, MN > > The things we admire in men, kindness and generosity, openness, > honesty, understanding and feeling are the concomitants of failure > in our system. And those traits we detest, sharpness, greed, > acquisitiveness, meanness, egotism and self-interest are the traits > of success. And while men admire the quality of the first they love > the produce of the second. -John Steinbeck, novelist, Nobel laureate > (1902-1968) > > On 10/07/2016 04:58 PM, Ken Ryan wrote: > > Charlie, > > The primary pump is powered by the integrated generator, so it > already > has auto shut off. > > What are the odds? Well, in off airport operations here in > Alaska the > odds are probably higher than high altitude ops over midwest > farm fields > from one 6,000 foot paved runways to the next. I know more than > one guy > who has flipped his airplane, and they all say the same thing: it > happened in an instant with no warning. Fortunately, they all > walked away. > > Ken > > On Fri, Oct 7, 2016 at 1:41 PM, Charlie England > > >> wrote: > > It really comes down to probability, modified by your > personal risk > tolerance. What are the odds of actually needing the auto-off > function of the aux pump (remember that in t/o-landing modes the > other pump will be running, too; what auto-protects that > one?), vs > the likelihood of needing the backup pump (primary failure) and > risking any one of the various wires, connectors, pressure > switch, > pressure *line*, etc causing loss of the pump? Or actually > *causing* > a problem (pressure line or pressure switch opening an oil > exit path > comes to mind...). > > In the 'simple' scenario, the aux pump switch mounted next > to the > primary pump switch allows one swipe to get both, if a crash is > imminent. > > But if the auto feature makes you more comfortable, go for it. > > Charlie > > On Fri, Oct 7, 2016 at 3:14 PM, Ken Ryan > > >> wrote: > > Alec, > > I'm not sure where you got the idea that the auxiliary pump > would be running all the time. It would indeed be used > only for > takeoffs and landings, via a toggle switch. But > inserting the > pressure switch and the relay would insure that in the > event of > a crash, such as on takeoff or landing, the auxiliary > pump would > automatically shut down when the engine ceases to turn > (because > the oil pressure would drop). > > Ken > > > On Fri, Oct 7, 2016 at 11:59 AM, Alec Myers > > >> > wrote: > > That's very reasonable; why not just have an on-off > switch > for the backup pump? Switch it on on the ground to > test, on > for takeoff and landing and off the rest of the time. > > Is there a benefit to having it run full time in > parallel > with the main pump? how do you tell if the main pump has > failed if the backup is already running? > > > On Oct 7, 2016, at 15:19, Ken Ryan > > >> wrote: > > Rotax operating procedures for 914 call for running both > electric fuel pumps for takeoff and landings. > > On Fri, Oct 7, 2016 at 10:59 AM, Alec Myers > > >> wrote: > > In that case why do you need the backup pump > energised > at all, absent a main fuel pump failure? > > Many (most?) TC aircraft with fuel injection or > low-wing > tanks have an electric backup pump but it's > either on > only for takeoff and landing and switching tanks > (Piper, > Grumman) or only used for priming and in the > event of > engine storage due to main pump failure (Cessna) > > I'm not familiar with the proposed system so If the > backup pump is permanently energised what alerts the > pilot to a failure of the engine-driven pump? > > > On Oct 7, 2016, at 12:27 PM, Ken Ryan > >> > wrote: > > I think maybe some of you are not factoring > in that > this is on the auxiliary fuel pump only. So > for a > failure of the switch or relay to have any > effect on > the flight, the main fuel pump would have > already had > to fail. The primary fuel pump stops > automatically > when the engine stops turning because it is > powered > off the generator. > > As far as startup, I think the way the > pressure switch > works is that it is a single pole, double > throw. So > there are three terminals: Comm, L1, and L2. > Without > pressure, Comm is connected to L2. With > pressure, Comm > is connected to L1. > > The Comm goes to the fuel pump relay. > L1 goes to a fuel pump switch. > L2 goes to the starter side of the starter > relay. > > So at startup, because the pressure switch > without > pressure is connected Comm-L2 only, closing > the fuel > pump switch would do nothing. But when > cranking power > is put to the starter, current would flow to > the relay > through the Comm-L2 connection. Then, when > the engine > starts and current is removed from the starter > circuit, power continues to flow the fuel > pump relay > because now with 7lbs of oil pressure Comm is > connected to L1 (and the switch has been > turned on). > > > On Fri, Oct 7, 2016 at 7:30 AM, John Tipton > > >> wrote: > > Q: how does the engine get it's fuel for > start-up, > the engine being off ie: no oil pressure > > Sent from my iPad > > ----x--O--x---- > > On 7 Oct 2016, at 02:51 pm, > ashleysc(at)broadstripe.net > > > wrote: > > Hi Ken; > Advice from an old > electro-mechanical engineer > (now 76) and new pilot (@ 70): Keep > the pilot in > charge of turning things off. > Cheers! Stu. > > > ------------------------------------------------------------------------ > *From: *"GTH" <gilles.thesee(at)free.fr > > >> > *To: > *aeroelectric-list(at)matronics.com > > > > > *Sent: *Friday, October 7, 2016 > 12:17:19 AM > *Subject: *Re: AeroElectric-List: > rotax generator > without battery > > /Le 07/10/2016 02:09, Ken Ryan a > crit : > / > > /I found this Pressure Switch > > > which > seems to be a viable way > (combined with a > relay) of automatically turning > off the > auxiliary fuel pump when the > engine stops > turning./ > > > Your call. You'll make your engine > operation > dependent on a switch and a relay. > "On a switch and a prayer" ;-) > -- > Best regards, > Gilles > http://contrails.free.fr > http://lapierre.skunkworks.free.fr > <http://lapierre.skunkworks.free.fr> > <http://lapierre.skunkworks.free.fr > <http://lapierre.skunkworks.free.fr>> > > > =================================== > - > Electric-List" rel="noreferrer" > target="_blank">http://www.matronics.com/Navigator?AeroElectric-List > =================================== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > =================================== > WIKI - > errer" target="_blank">http://wiki.matronics.com > =================================== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > =================================== > > ________________________________________________________________________________
Subject: Re: Skyview Screens and Z13/8
Date: Oct 08, 2016
I have two 7" screens and both have the Dynon backup batteries ... plenty of time to divert in an emergency with one running and the other off if necess ary to extend endurance. 7" uses less power than the 10" too. Kind Regards, Stu Sent from my iPhone > On 8 Oct. 2016, at 00:41, Sebastien wrote: > > My understanding is you only put what you need to safely conclude the flig ht on the ebus so primary EFIS only. > > I would also highly recommend you put both screens on the pilot side so th at if one fails, the other one is in front of you, not the passenger. > >> On Fri, Oct 7, 2016 at 9:17 AM, Jared Yates wrote: >> I'm considering installation of a Dynon Skyview system with two 7" screen s, and wondering how to best power them. I've got plenty of room on the ebus from a load analysis standpoint, but is it better to put one screen on the m ain bus in case the ebus were to short? Is there any issue with having a hal f volt difference powering the two screens? How has everyone else been doing it? > ________________________________________________________________________________
Subject: Loom mounting
Date: Oct 08, 2016
I have to install loom in the wing rib lightning holes. Any recommendations on how to adhere it to the edge of the hole? The loom runs the length of the wing perpendicular to the ribs. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461093#461093 ________________________________________________________________________________
Subject: Re: Loom mounting
Date: Oct 09, 2016
This is how I mounted mine (not an RV-10) I then used an adel clamp and mounted it to the angle. > On Oct 9, 2016, at 00:41, whodja wrote: > > > I have to install loom in the wing rib lightning holes. Any recommendation s on how to adhere it to the edge of the hole? The loom runs the length of t he wing perpendicular to the ribs. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=461093#461093 > > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > > ________________________________________________________________________________
Date: Oct 08, 2016
Subject: battery contactor vs starter contactor wiring
Reviewing 13/8 I notice that the battery contactor jumps power from the big terminal and then switches the coil ground, but the starter contactor switches coil positive. Why do it differently on one than the other? Ken ________________________________________________________________________________
From: Stephen Richards <stephencliverichards(at)gmail.com>
Date: Oct 08, 2016
I would say for safety if starter solenoid was switched on negative side an y grounding fault would energies solenoid with positive switching a ground would blow fuse a connection to another positive less likely. With battery solenoid if switched positive it would require a fused positiv e supply from battery to switch to solenoid, any ground fault would blow fu se and de energise solenoid, with negative switching any ground fault will retain solenoid, if on switched side it would energise solenoid but this s hould not cause any danger unless you happened to have crashed. Clive -----Original Message----- From: "Ken Ryan" <keninalaska(at)gmail.com> Sent: =8E08/=8E10/=8E2016 19:13 Subject: AeroElectric-List: battery contactor vs starter contactor wiring Reviewing 13/8 I notice that the battery contactor jumps power from the big terminal and then switches the coil ground, but the starter contactor swit ches coil positive. Why do it differently on one than the other? Ken ________________________________________________________________________________
Subject: Wiring install 327/navwork/encoder
Date: Oct 08, 2016
Loose pin in the 327 connector or something fried my 327. Now I am paranoid about putting in a new one. Questions??? on the 327 pin 13 and 25 are the same ground? 13 shows power and 25 shows signal ground? Arent they the same thing? Do both need to be grounded? navworx wants to be connected to 13, so is that tied into the pin or just grounded at same location? navworx also wants altitude ground to pin 13 or 25, again tied into pin or just grounded at same location? Thanks Keith Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461102#461102 ________________________________________________________________________________
Subject: Re: Wiring install 327/navwork/encoder
Date: Oct 08, 2016
I think I figured it out after talking to some folks. But more important. If the navworx wants to connect on the garmin 327 ground pin 13, where would you tie that in? Awful hard to get 2 wires into a small dsub pin. Splice after the connector? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461104#461104 ________________________________________________________________________________
Date: Oct 08, 2016
I'm sure they are both at the same ground potential, but I would put any wires carrying higher current on that Pin 13 since that's the power ground. For a signal ground like the RS232 running to NavWorX, it won't matter which ground you attach it to. In fact, not that I'd recommend this, but, if all of your avionics are grounded to the same ground point, it is fairly likely that most of the RS232 signals would talk even if you left the signal ground wires off, simply due to the fact that most of the systems will have the signal ground tied to the same ground potential as the power ground. But again, I'm not recommending that, just saying that in theory it would probably work without it. The signal isn't carrying much current so either pin will be OK for the signal ground in your case. That doesn't mean the pins are the same, so when connecting the system power and ground, use the pins that are specified for that purpose. Tim On 10/8/2016 2:02 PM, class4sanger wrote: > > Loose pin in the 327 connector or something fried my 327. Now I am paranoid about putting in a new one. Questions??? on the 327 pin 13 and 25 are the same ground? 13 shows power and 25 shows signal ground? Arent they the same thing? Do both need to be grounded? navworx wants to be connected to 13, so is that tied into the pin or just grounded at same location? navworx also wants altitude ground to pin 13 or 25, again tied into pin or just grounded at same location? > > Thanks > Keith > ________________________________________________________________________________
Date: Oct 09, 2016
Subject: Thermostatic switch/relay
Guys I installed a couple of cooling fans in my RV-10 dashboard, actually copying other builders idea, to extract heated air from the back of the avionics, which is blown in the inside face of the windshield, thus also serving as a windshield defrost system. I am planning to use a 3 position switch, off, on, and automatic, in which this last position is to be connected to a thermostatic switch/relay that will turn on the coolers only when the temperature behind the avionics reaches a preset or an adjustable temperature. Will somebody please point me to such a thermostatic switch/relay, and a source for it. Thanks Carlos ________________________________________________________________________________
Subject: Re: Thermostatic switch/relay
Date: Oct 08, 2016
On 10/8/2016 6:26 PM, Carlos Trigo wrote: > > Guys > > I installed a couple of cooling fans in my RV-10 dashboard, actually copying other builders idea, to extract heated air from the back of the avionics, which is blown in the inside face of the windshield, thus also serving as a windshield defrost system. > > I am planning to use a 3 position switch, off, on, and automatic, in which this last position is to be connected to a thermostatic switch/relay that will turn on the coolers only when the temperature behind the avionics reaches a preset or an adjustable temperature. > > Will somebody please point me to such a thermostatic switch/relay, and a source for it. > > Thanks > Carlos I googled '12 volt thermostat'. https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=12%20volt%20thermostat The 1st one I checked says it will do both heating & cooling: https://www.amazon.com/12V-Digital-Temperature-Controller-Thermostat/dp/B00C4TEEF2 Web site for it: http://www.thermomart.com/index.php?route=product/product&product_id=149 Does that help, as a starting point? Charlie ________________________________________________________________________________
Date: Oct 08, 2016
https://www.amazon.com/RioRand-Thermostat-Temperature-Controller-Waterproof/dp/B00KCCX0EE https://www.amazon.com/12V-Digital-Temperature-Controller-Thermostat/dp/B00C4TEEF2 Make your own electronic temperature controller: http://ww1.microchip.com/downloads/en/DeviceDoc/21448D.pdf It will not hurt anything to leave the fans running continuously. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461109#461109 ________________________________________________________________________________
Date: Oct 09, 2016
Another option from McMaster;http://www.mcmaster.com/#thermostats/=14irk9r Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461114#461114 ________________________________________________________________________________
Date: Oct 10, 2016
That's what I did - just have it on all the time. Simplicity On 10/8/2016 9:28 PM, user9253 wrote: > > It will not hurt anything to leave the fans running continuously. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=461109#461109 > > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Oct 10, 2016
Well, it can be, but I am too sensitive to noise ... Regards Carlos -----Mensagem original----- De: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] Em nome de Bill Watson Enviada: Monday, October 10, 2016 6:15 PM Para: aeroelectric-list(at)matronics.com Assunto: Re: AeroElectric-List: Re: Thermostatic switch/relay --> That's what I did - just have it on all the time. Simplicity On 10/8/2016 9:28 PM, user9253 wrote: > --> > > It will not hurt anything to leave the fans running continuously. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=461109#461109 > > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Oct 10, 2016
Say what? Is there supposed to be a winking emotie after that statement? If not, you might need to consider another hobby. :-) Seriously, the big fan will hide the noise of any number of cooling fans you might install in/behind the panel. Charlie On 10/10/2016 12:31 PM, Carlos Trigo wrote: > > Well, it can be, but I am too sensitive to noise ... > > Regards > Carlos > > -----Mensagem original----- > De: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] Em nome de Bill Watson > Enviada: Monday, October 10, 2016 6:15 PM > Para: aeroelectric-list(at)matronics.com > Assunto: Re: AeroElectric-List: Re: Thermostatic switch/relay > > --> > > That's what I did - just have it on all the time. Simplicity > > On 10/8/2016 9:28 PM, user9253 wrote: >> --> >> >> It will not hurt anything to leave the fans running continuously. >> >> -------- >> Joe Gores >> ________________________________________________________________________________
Date: Oct 10, 2016
Hello Charlie Yes, a friend of mine who happens to be a doctor (ear nose & throat) tells me that I probably have a higher sensibility to some frequencies ... And I don't like that noise when the big fan is not swinging. Carlos -----Mensagem original----- De: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] Em nome de Charlie England Enviada: Monday, October 10, 2016 6:50 PM Para: aeroelectric-list(at)matronics.com Assunto: Re: AeroElectric-List: Re: Thermostatic switch/relay --> Say what? Is there supposed to be a winking emotie after that statement? If not, you might need to consider another hobby. :-) Seriously, the big fan will hide the noise of any number of cooling fans you might install in/behind the panel. Charlie On 10/10/2016 12:31 PM, Carlos Trigo wrote: > --> > > Well, it can be, but I am too sensitive to noise ... > > Regards > Carlos > > -----Mensagem original----- > De: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] Em nome de Bill > Watson > Enviada: Monday, October 10, 2016 6:15 PM > Para: aeroelectric-list(at)matronics.com > Assunto: Re: AeroElectric-List: Re: Thermostatic switch/relay > > --> > > That's what I did - just have it on all the time. Simplicity > > On 10/8/2016 9:28 PM, user9253 wrote: >> --> >> >> It will not hurt anything to leave the fans running continuously. >> >> -------- >> Joe Gores >> ________________________________________________________________________________
Date: Oct 10, 2016
Wait... you're flying an AIRPLANE and you're worried about the noise in the cockpit from a fan???? Have you considered a glider? -- Art Z. (only half kidding) On Mon, Oct 10, 2016 at 12:31 PM, Carlos Trigo wrote: > trigo(at)mail.telepac.pt> > > Well, it can be, but I am too sensitive to noise ... -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Date: Oct 10, 2016
Yes Art I also fly gliders, and must confess that glider flying is indeed the supreme flying experience! No kidding Carlos P.S. =93 I must add that I=99m still puzzled why we don=99t care to reduce noise inside airplanes like the car builders have already done it De: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] Em nome de Art Zemon Enviada: 10 de outubro de 2016 19:17 Para: aeroelectric-list(at)matronics.com Assunto: Re: AeroElectric-List: Re: Thermostatic switch/relay Wait... you're flying an AIRPLANE and you're worried about the noise in the cockpit from a fan???? Have you considered a glider? -- Art Z. (only half kidding) On Mon, Oct 10, 2016 at 12:31 PM, Carlos Trigo > wrote: > Well, it can be, but I am too sensitive to noise ... -- https://CheerfulCurmudgeon.com/ "If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel ________________________________________________________________________________
Subject: Re: Thermostatic switch/relay - Garmin 430W/530W
Date: Oct 10, 2016
Fans for the Garmin Navigators. . . Both the 430 and 530 run "hot", at least from my point of view. This is normal says Garmin and I was wondering if any of you guys have installed rear fans to assist in shedding some of the heat. And, how you did the mounting,etc. I think using the small computer type fans can be installed to run full time when the panel is operating. They seem to do this in computers and last for years. It is the mounting of the fan that I think is a problem. Ideas. . . David ------------------------------------------------------------------------- ----- Original Message ----- From: "Charlie England" <ceengland7(at)gmail.com> Sent: Saturday, October 08, 2016 6:07 PM Subject: Re: AeroElectric-List: Thermostatic switch/relay > > > On 10/8/2016 6:26 PM, Carlos Trigo wrote: >> >> >> Guys >> >> I installed a couple of cooling fans in my RV-10 dashboard, actually >> copying other builders idea, to extract heated air from the back of the >> avionics, which is blown in the inside face of the windshield, thus also >> serving as a windshield defrost system. >> >> I am planning to use a 3 position switch, off, on, and automatic, in >> which this last position is to be connected to a thermostatic >> switch/relay that will turn on the coolers only when the temperature >> behind the avionics reaches a preset or an adjustable temperature. >> >> Will somebody please point me to such a thermostatic switch/relay, and a >> source for it. >> >> Thanks >> Carlos > I googled '12 volt thermostat'. > https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=12%20volt%20thermostat > > The 1st one I checked says it will do both heating & cooling: > https://www.amazon.com/12V-Digital-Temperature-Controller-Thermostat/dp/B00C4TEEF2 > Web site for it: > http://www.thermomart.com/index.php?route=product/product&product_id=149 > > Does that help, as a starting point? > > Charlie > > > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Oct 10, 2016
I don't think that we don't care; it's just much more difficult to achieve in an a/c. For perspective, several years ago one of the European auto mfgrs was looking at using active noise cancelling in the cabin of their cars. Their initial efforts at a (very complex, multi sensor, multi transducer) system seemed to work ok, and by their numbers, they would have been able to remove close to 100 lbs of sound reduction material from the car by using the system. This was on a car that sells for far north of $50K, and development costs would be spread over hundreds of thousands of units. Now, if I try the passive noise reduction approach in my 1000 lb plane, I've added 10% to the empty weight, and I haven't yet added the additional 60-80 lbs of muffler/exhaust system that the car carries. Just not practical, unless you can afford a jet, and the weight it can carry. Even then, you're not likely to come close to a premium car in noise level. On Mon, Oct 10, 2016 at 1:41 PM, Carlos Trigo wrote : > Yes Art > > > I also fly gliders, and must confess that glider flying is indeed the > supreme flying experience! > > > No kidding > > Carlos > > > P.S. =93 I must add that I=99m still puzzled why we don =99t care to reduce noise > inside airplanes like the car builders have already done it > > > *De:* owner-aeroelectric-list-server(at)matronics.com [mailto: > owner-aeroelectric-list-server(at)matronics.com] *Em nome de *Art Zemon > *Enviada:* 10 de outubro de 2016 19:17 > *Para:* aeroelectric-list(at)matronics.com > *Assunto:* Re: AeroElectric-List: Re: Thermostatic switch/relay > > > Wait... you're flying an AIRPLANE and you're worried about the noise in > the cockpit from a fan???? Have you considered a glider? > > > -- Art Z. (only half kidding) > > > On Mon, Oct 10, 2016 at 12:31 PM, Carlos Trigo > wrote: > > trigo(at)mail.telepac.pt> > > Well, it can be, but I am too sensitive to noise ... > > > -- > > https://CheerfulCurmudgeon.com/ > > *"If I am not for myself, who is for me? And if I am only for myself, wha t > am I? And if not now, when?" Hillel* > ________________________________________________________________________________
Date: Oct 10, 2016
I agree on the supreme experience but there's nothing quiet about it. Whether slogging around in a drafty 2-33 or zooming about in a modern 18m racer with the speed-to-fly audio constantly sounding off, it's noisy ;-) Bill "who still gets airsick from the sound of a vario" Watson On 10/10/2016 2:41 PM, Carlos Trigo wrote: > > Yes Art > > I also fly gliders, and must confess that glider flying is indeed the > supreme flying experience! > > No kidding > > Carlos > > P.S. I must add that Im still puzzled why we dont care to reduce > noise inside airplanes like the car builders have already done it > > *De:*owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] *Em nome de *Art > Zemon > *Enviada:* 10 de outubro de 2016 19:17 > *Para:* aeroelectric-list(at)matronics.com > *Assunto:* Re: AeroElectric-List: Re: Thermostatic switch/relay > > Wait... you're flying an AIRPLANE and you're worried about the noise > in the cockpit from a fan???? Have you considered a glider? > > -- Art Z. (only half kidding) > > On Mon, Oct 10, 2016 at 12:31 PM, Carlos Trigo > wrote: > > > > > Well, it can be, but I am too sensitive to noise ... > > > -- > > https://CheerfulCurmudgeon.com/ > > /"If I am not for myself, who is for me? And if I am only for myself, > what am I? And if not now, when?" Hillel/ > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Oct 10, 2016
Mounting fans in my BD-4 was very easy. First I glued coarse plastic mesh to the exhaust sides of the fans and wired them to the avionics fuse block (no individual switch for the fans). To install cut two round holes in the dash, put a lip around the edges, and attach with machine screws. Sebastien > On Oct 10, 2016, at 14:46, David Lloyd wrote: > > > Fans for the Garmin Navigators. . . > Both the 430 and 530 run "hot", at least from my point of view. This is normal says Garmin and I was wondering if any of you guys have installed rear fans to assist in shedding some of the heat. > And, how you did the mounting,etc. > I think using the small computer type fans can be installed to run full time when the panel is operating. They seem to do this in computers and last for years. It is the mounting of the fan that I think is a problem. > Ideas. . . > David > > ------------------------------------------------------------------------- > > > ----- Original Message ----- From: "Charlie England" <ceengland7(at)gmail.com> > To: > Sent: Saturday, October 08, 2016 6:07 PM > Subject: Re: AeroElectric-List: Thermostatic switch/relay > > >> >>> On 10/8/2016 6:26 PM, Carlos Trigo wrote: >>> >>> Guys >>> >>> I installed a couple of cooling fans in my RV-10 dashboard, actually copying other builders idea, to extract heated air from the back of the avionics, which is blown in the inside face of the windshield, thus also serving as a windshield defrost system. >>> >>> I am planning to use a 3 position switch, off, on, and automatic, in which this last position is to be connected to a thermostatic switch/relay that will turn on the coolers only when the temperature behind the avionics reaches a preset or an adjustable temperature. >>> >>> Will somebody please point me to such a thermostatic switch/relay, and a source for it. >>> >>> Thanks >>> Carlos >> I googled '12 volt thermostat'. >> https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=12%20volt%20thermostat >> >> The 1st one I checked says it will do both heating & cooling: >> https://www.amazon.com/12V-Digital-Temperature-Controller-Thermostat/dp/B00C4TEEF2 >> Web site for it: >> http://www.thermomart.com/index.php?route=product/product&product_id=149 >> >> Does that help, as a starting point? >> >> Charlie > > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > > > > ________________________________________________________________________________
Date: Oct 10, 2016
How about a dab of pro-seal at each end rib? Subject: AeroElectric-List: Loom mounting From: "whodja" <whodja(at)gmail.com> I have to install loom in the wing rib lightning holes. Any recommendations on how to adhere it to the edge of the hole? The loom runs the length of the wing perpendicular to the ribs. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461093#461093 ________________________________________________________________________________
Date: Oct 10, 2016
. . . .Neat idea. . . .!! ____________________________________________________ ----- Original Message ----- From: "Sebastien" <cluros(at)gmail.com> Sent: Monday, October 10, 2016 1:32 PM Subject: Re: AeroElectric-List: Thermostatic switch/relay - Garmin 430W/530W > > Mounting fans in my BD-4 was very easy. First I glued coarse plastic mesh > to the exhaust sides of the fans and wired them to the avionics fuse block > (no individual switch for the fans). To install cut two round holes in the > dash, put a lip around the edges, and attach with machine screws. > > Sebastien > >> On Oct 10, 2016, at 14:46, David Lloyd wrote: >> >> >> >> Fans for the Garmin Navigators. . . >> Both the 430 and 530 run "hot", at least from my point of view. This is >> normal says Garmin and I was wondering if any of you guys have installed >> rear fans to assist in shedding some of the heat. >> And, how you did the mounting,etc. >> I think using the small computer type fans can be installed to run full >> time when the panel is operating. They seem to do this in computers and >> last for years. It is the mounting of the fan that I think is a problem. >> Ideas. . . >> David >> >> ------------------------------------------------------------------------- >> >> >> ----- Original Message ----- From: "Charlie England" >> >> To: >> Sent: Saturday, October 08, 2016 6:07 PM >> Subject: Re: AeroElectric-List: Thermostatic switch/relay >> >> >>> >>> >>>> On 10/8/2016 6:26 PM, Carlos Trigo wrote: >>>> >>>> >>>> Guys >>>> >>>> I installed a couple of cooling fans in my RV-10 dashboard, actually >>>> copying other builders idea, to extract heated air from the back of the >>>> avionics, which is blown in the inside face of the windshield, thus >>>> also serving as a windshield defrost system. >>>> >>>> I am planning to use a 3 position switch, off, on, and automatic, in >>>> which this last position is to be connected to a thermostatic >>>> switch/relay that will turn on the coolers only when the temperature >>>> behind the avionics reaches a preset or an adjustable temperature. >>>> >>>> Will somebody please point me to such a thermostatic switch/relay, and >>>> a source for it. >>>> >>>> Thanks >>>> Carlos >>> I googled '12 volt thermostat'. >>> https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=12%20volt%20thermostat >>> >>> The 1st one I checked says it will do both heating & cooling: >>> https://www.amazon.com/12V-Digital-Temperature-Controller-Thermostat/dp/B00C4TEEF2 >>> Web site for it: >>> http://www.thermomart.com/index.php?route=product/product&product_id=149 >>> >>> Does that help, as a starting point? >>> >>> Charlie >> >> >> --- >> This email has been checked for viruses by Avast antivirus software. >> https://www.avast.com/antivirus >> >> >> >> >> > > > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Oct 10, 2016
Google "suspension clamp". I used the ones from Oatey with 1/2 cpvc pipe. john On 10/10/2016 1:34 PM, MLE wrote: > How about a dab of pro-seal at each end rib? > > > Subject: AeroElectric-List: Loom mounting > From: "whodja" <whodja(at)gmail.com <mailto:whodja(at)gmail.com>> > > > I have to install loom in the wing rib lightning holes. Any > recommendations on > how to adhere it to the edge of the hole? The loom runs the length of > the wing > perpendicular to the ribs. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=461093#461093 > <http://forums.matronics.com/viewtopic.php?p=461093#461093> ________________________________________________________________________________
Date: Oct 10, 2016
/Le 10/10/2016 20:46, David Lloyd a crit : / > > / / > Fans for the Garmin Navigators. . . > This is normal says Garmin and I was wondering if any of you guys have > installed rear fans to assist in shedding some of the heat. > / David and all, We got a 400. No cooling fan. > / It is the mounting of the fan that I think is a problem. > Ideas. . . / We did indeed install an "defogging fan". Some info here http://contrails.free.fr/cellule_defog_en.php Defogging is efficient, but a bit slow. No problem for us, as the windscreens gathers fog only on the ground and clears as soon as we're airborne. No noise audible with headsets on. Hope this helps. -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Date: Oct 10, 2016
/Le 10/10/2016 22:56, John Morgensen a crit : / > // > > / I used the ones from Oatey with 1/2 cpvc pipe./ > Hi all, We did use an electrical PVC pipe. -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Subject: Anyone have a B&C LR3b Voltage Regulator handy?
Date: Oct 10, 2016
I have 2 LR3bs installed on the firewall of my RV10 and need help. The voltage output regulator screw is under a plastic cap on the unit. I need the diameter of that brass screw's head. The problem is that I need to adjust the voltage on one of the units but I can't get a screwdriver on the head of this tiny screw because of where the units are located. My solution is to fashion a screw driver with a piece of brass tubing slightly larger than the screw to help guide the screw into the slot. My guess is that the screw's head is about 1/8" in diameter but that is only a guess. Plus/minus 1/32" would do the trick. Thanks in advance! Bill Watson --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Oct 10, 2016
Subject: Re: Anyone have a B&C LR3b Voltage Regulator handy?
I have one out I can check this evening. On Mon, Oct 10, 2016 at 5:58 PM, Bill Watson wrote: > Mauledriver(at)nc.rr.com> > > I have 2 LR3bs installed on the firewall of my RV10 and need help. The > voltage output regulator screw is under a plastic cap on the unit. I need > the diameter of that brass screw's head. > > The problem is that I need to adjust the voltage on one of the units but I > can't get a screwdriver on the head of this tiny screw because of where the > units are located. My solution is to fashion a screw driver with a piece > of brass tubing slightly larger than the screw to help guide the screw into > the slot. > > My guess is that the screw's head is about 1/8" in diameter but that is > only a guess. Plus/minus 1/32" would do the trick. Thanks in advance! > > Bill Watson > > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > ________________________________________________________________________________
Date: Oct 10, 2016
Instead of buying a speed controller or thermostat, buy a fan that comes with a speed selector switch. Let the buyer beware when it comes to manufacturer's claims of quiet. Larger diameter and slower speed usually results in less noise. A 120 mm fan will be quieter than an 80 mm fan. Compare the RPM and Db ratings. Computer fans are designed to operate at 12 volts. They might run faster and make more noise at 14 volts. The voltage can be dropped with a resistor or diodes. The Antec TrueQuiet 120mm LED fan has two speeds and silicone mounting grommets. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461155#461155 ________________________________________________________________________________
Date: Oct 10, 2016
Hi Carlos; One word: weight. Cheers! Stu. ----- Original Message ----- From: "Carlos Trigo" <trigo(at)mail.telepac.pt> Sent: Monday, October 10, 2016 11:41:50 AM Subject: RE: AeroElectric-List: Re: Thermostatic switch/relay Yes Art I also fly gliders, and must confess that glider flying is indeed the supre me flying experience! No kidding Carlos P.S. =93 I must add that I=99m still puzzled why we don =99t care to reduce noise inside airplanes like the car builders have alrea dy done it De: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric -list-server(at)matronics.com] Em nome de Art Zemon Enviada: 10 de outubro de 2016 19:17 Para: aeroelectric-list(at)matronics.com Assunto: Re: AeroElectric-List: Re: Thermostatic switch/relay Wait... you're flying an AIRPLANE and you're worried about the noise in the cockpit from a fan???? Have you considered a glider? -- Art Z. (only half kidding) On Mon, Oct 10, 2016 at 12:31 PM, Carlos Trigo < trigo(at)mail.telepac.pt > wr ote: c.pt > Well, it can be, but I am too sensitive to noise ... -- https://CheerfulCurmudgeon.com/ "If I am not for myself, who is for me? And if I am only for myself, what a m I? And if not now, when?" Hillel ________________________________________________________________________________
Date: Oct 11, 2016
Subject: Re: battery contactor vs starter contactor wiring
I haven't seen any responses to this. Did I ask a dumb question? Reviewing 13/8 I notice that the battery contactor jumps power from the big terminal and then switches the coil ground, but the starter contactor switches coil positive. Why do it differently on one than the other? On Sat, Oct 8, 2016 at 9:44 AM, Ken Ryan wrote: > Reviewing 13/8 I notice that the battery contactor jumps power from the > big terminal and then switches the coil ground, but the starter contactor > switches coil positive. Why do it differently on one than the other? > > Ken > > ________________________________________________________________________________
Date: Oct 11, 2016
The difference is the fuse. In both of them, grounding the coil circuits actuates the solenoids but there is no fuse on the battery contactor circuit. If you visualize the starter contactor wired the same way as the battery contactor, you would have to bring the output side of the actuating coil back to the cockpit to the starter switch and thence through a single dedicated fuse. Wiring it the way it is allows you to use a fuse or CB in the fuse panel. Just a guess. -Kent > On Oct 11, 2016, at 2:15 PM, Ken Ryan wrote: > > I haven't seen any responses to this. Did I ask a dumb question? > > > Reviewing 13/8 I notice that the battery contactor jumps power from the big terminal and then switches the coil ground, but the starter contactor switches coil positive. Why do it differently on one than the other? > > > On Sat, Oct 8, 2016 at 9:44 AM, Ken Ryan wrote: > Reviewing 13/8 I notice that the battery contactor jumps power from the big terminal and then switches the coil ground, but the starter contactor switches coil positive. Why do it differently on one than the other? > > Ken > > ________________________________________________________________________________
Subject: Documentation error?
Date: Oct 11, 2016
I just added a lighting dimmer to my Icom A200. I didn't wire the dimmer circuit initially, and it was really annoying to be completely black on a dark night! Anyway, I found this document on the aeroelectric.com site: http://www.aeroelectric.com/Installation_Data/Icom/Icom_A200-210_Wiring_D.pdf At the top of page 2 there is a representation of the connector at the back of the tray labeled "Wire Entry view of Connector" that shows pins A and 1 on the left side of the connector. The issue is from the wire side of the connector pins A and 1 are on the RIGHT side of the connector (the symbol is labeled backwards). The Icom installation document has the same connector representation and it is labeled "Front view" which may confuse someone. This "front view" refers to the front of the radio, not the front of the plane! If you take the radio out, sit in the pilot seat and look down the tray, A and 1 are indeed on the left side! So I think either the symbol is labeled backwards or it should read "Radio View Of The Connector". Just to be clear, I added the power line from my dimmer to pin B. Laying on my back under the instrument panel (wire entry view of the connector) I added that wire to the top row, second from the RIGHT. And by the way the dimmer circuit works great, so I'm pretty confident that I got the right pin! Sorry if this is nit-picky, but I don't want someone to blindly follow this document and get things wired backwards! (not that I have ever done that myself!). The document seems to be seven years old, so maybe I'm the only one confused! This document claims to be for both the A200 and the A210. I can only speak for the A200. I hope this helps! Paul A. Fisher RV-7A N18PF ________________________________________________________________________________
Date: Oct 11, 2016
SUlSQywgdGhlIG1zdHIgdGVjaG5pcXVlIHNhdmVzIGEgcmV0dXJuIHdpcmUgKGxvY2FsIGduZCBm b3Igc3dpdGNoIG9uIHRoZSAnZ3JvdW5kJyBzaWRlIG9mIHRoZSBjb2lsKS4KClRoZSBzdGFydCBj b250YWN0b3IgdHlwaWNhbGx5IGhhcyBvbmUgc2lkZSBvZiB0aGUgY29pbCBncm91bmRlZCBpbnNp ZGUgKDJuZCBzbWFsbCB0ZXJtaW5hbCBnb2VzIGhpZ2ggd2hlbiBzdGFydCBpcyBhY3RpdmF0ZWQp ICwgc28gcmVxdWlyZXMgc3dpdGNoaW5nIHRoZSBob3Qgc2lkZS4KCkNhbid0IHN3ZWFyIHRvIGl0 LCBidXQgdGhlcmUgbWF5IGJlIGEgd3JpdGV1cCBhYm91dCBpdCBpbiAndGhlIGJvb2snLgoKQ2hh cmxpZQoKCgotLS0tLS0tLSBPcmlnaW5hbCBtZXNzYWdlIC0tLS0tLS0tCkZyb206IEtlbnQgb3Ig SmFja2llIEFzaHRvbgpEYXRlOjEwLzExLzIwMTYgMzozMCBQTSAoR01ULTA2OjAwKQpUbzogYWVy b2VsZWN0cmljLWxpc3RAbWF0cm9uaWNzLmNvbQpTdWJqZWN0OiBSZTogQWVyb0VsZWN0cmljLUxp c3Q6IGJhdHRlcnkgY29udGFjdG9yIHZzIHN0YXJ0ZXIgY29udGFjdG9yIHdpcmluZwoKLS0+IEFl cm9FbGVjdHJpYy1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiBLZW50IG9yIEphY2tpZSBBc2h0b24g PGtqYXNodG9uQHZuZXQubmV0PgoKVGhlIGRpZmZlcmVuY2UgaXMgdGhlIGZ1c2UuICBJbiBib3Ro IG9mIHRoZW0sIGdyb3VuZGluZyB0aGUgY29pbCBjaXJjdWl0cyBhY3R1YXRlcyB0aGUgc29sZW5v aWRzIGJ1dCB0aGVyZSBpcyBubyBmdXNlIG9uIHRoZSBiYXR0ZXJ5IGNvbnRhY3RvciBjaXJjdWl0 LiAgSWYgeW91IHZpc3VhbGl6ZSB0aGUgc3RhcnRlciBjb250YWN0b3Igd2lyZWQgdGhlIHNhbWUg d2F5IGFzIHRoZSBiYXR0ZXJ5IGNvbnRhY3RvciwgeW91IHdvdWxkIGhhdmUgdG8gYnJpbmcgdGhl IG91dHB1dCBzaWRlIG9mIHRoZSBhY3R1YXRpbmcgY29pbCBiYWNrIHRvIHRoZSBjb2NrcGl0IHRv IHRoZSBzdGFydGVyIHN3aXRjaCBhbmQgdGhlbmNlIHRocm91Z2ggYSBzaW5nbGUgZGVkaWNhdGVk IGZ1c2UuIFdpcmluZyBpdCB0aGUgd2F5IGl0IGlzIGFsbG93cyB5b3UgdG8gdXNlIGEgZnVzZSBv ciBDQiBpbiB0aGUgZnVzZSBwYW5lbC4gIAoKSnVzdCBhIGd1ZXNzLgotS2VudAo+IE9uIE9jdCAx MSwgMjAxNiwgYXQgMjoxNSBQTSwgS2VuIFJ5YW4gPGtlbmluYWxhc2thQGdtYWlsLmNvbT4gd3Jv dGU6Cj4gCj4gSSBoYXZlbid0IHNlZW4gYW55IHJlc3BvbnNlcyB0byB0aGlzLiBEaWQgSSBhc2sg YSBkdW1iIHF1ZXN0aW9uPwo+IAo+IDxzbmlwPgo+IFJldmlld2luZyAxMy84IEkgbm90aWNlIHRo YXQgdGhlIGJhdHRlcnkgY29udGFjdG9yIGp1bXBzIHBvd2VyIGZyb20gdGhlIGJpZyB0ZXJtaW5h bCBhbmQgdGhlbiBzd2l0Y2hlcyB0aGUgY29pbCBncm91bmQsIGJ1dCB0aGUgc3RhcnRlciBjb250 YWN0b3Igc3dpdGNoZXMgY29pbCBwb3NpdGl2ZS4gV2h5IGRvIGl0IGRpZmZlcmVudGx5IG9uIG9u ZSB0aGFuIHRoZSBvdGhlcj8KPiA8c25pcD4KPiAKPiBPbiBTYXQsIE9jdCA4LCAyMDE2IGF0IDk6 NDQgQU0sIEtlbiBSeWFuIDxrZW5pbmFsYXNrYUBnbWFpbC5jb20+IHdyb3RlOgo+IFJldmlld2lu ZyAxMy84IEkgbm90aWNlIHRoYXQgdGhlIGJhdHRlcnkgY29udGFjdG9yIGp1bXBzIHBvd2VyIGZy b20gdGhlIGJpZyB0ZXJtaW5hbCBhbmQgdGhlbiBzd2l0Y2hlcyB0aGUgY29pbCBncm91bmQsIGJ1 dCB0aGUgc3RhcnRlciBjb250YWN0b3Igc3dpdGNoZXMgY29pbCBwb3NpdGl2ZS4gV2h5IGRvIGl0 IGRpZmZlcmVudGx5IG9uIG9uZSB0aGFuIHRoZSBvdGhlcj8KPiAKPiBLZW4KPiAKPiAKCgoKXy09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT0KXy09ICAgICAgICAgIC0gVGhlIEFlcm9FbGVjdHJpYy1MaXN0IEVtYWlsIEZvcnVtIC0KXy09 IFVzZSB0aGUgTWF0cm9uaWNzIExpc3QgRmVhdHVyZXMgTmF2aWdhdG9yIHRvIGJyb3dzZQpfLT0g dGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMgc3VjaCBhcyBMaXN0IFVuL1N1YnNjcmlwdGlvbiwKXy09 IEFyY2hpdmUgU2VhcmNoICYgRG93bmxvYWQsIDctRGF5IEJyb3dzZSwgQ2hhdCwgRkFRLApfLT0g UGhvdG9zaGFyZSwgYW5kIG11Y2ggbXVjaCBtb3JlOgpfLT0KXy09ICAgLS0+IGh0dHA6Ly93d3cu bWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/QWVyb0VsZWN0cmljLUxpc3QKXy09Cl8tPT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cl8tPSAg ICAgICAgICAgICAgIC0gTUFUUk9OSUNTIFdFQiBGT1JVTVMgLQpfLT0gU2FtZSBncmVhdCBjb250 ZW50IGFsc28gYXZhaWxhYmxlIHZpYSB0aGUgV2ViIEZvcnVtcyEKXy09Cl8tPSAgIC0tPiBodHRw Oi8vZm9ydW1zLm1hdHJvbmljcy5jb20KXy09Cl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cl8tPSAgICAgICAgICAgICAgLSBORVcg TUFUUk9OSUNTIExJU1QgV0lLSSAtCl8tPSBBZGQgc29tZSBpbmZvIHRvIHRoZSBNYXRyb25pY3Mg RW1haWwgTGlzdCBXaWtpIQpfLT0gICAtLT4gaHR0cDovL3dpa2kubWF0cm9uaWNzLmNvbQpfLT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PQpfLT0gICAgICAgICAgICAgLSBMaXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAtCl8tPSAgVGhh bmsgeW91IGZvciB5b3VyIGdlbmVyb3VzIHN1cHBvcnQhCl8tPSAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgIC1NYXR0IERyYWxsZSwgTGlzdCBBZG1pbi4KXy09ICAgLS0+IGh0dHA6Ly93d3cu bWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KCgoK ________________________________________________________________________________
Date: Oct 11, 2016
Ken I did send this resending Clive -----Original Message----- From: "Stephen Richards" <stephencliverichards(at)gmail.com> Sent: =8E11/=8E10/=8E2016 22:07 Subject: RE: AeroElectric-List: battery contactor vs starter contactor wiri ng From: Stephen Richards Sent: =8E08/=8E10/=8E2016 20:01 Subject: RE: AeroElectric-List: battery contactor vs starter contactor wiri ng I would say for safety if starter solenoid was switched on negative side an y grounding fault would energies solenoid with positive switching a ground would blow fuse a connection to another positive less likely. With battery solenoid if switched positive it would require a fused positiv e supply from battery to switch to solenoid, any ground fault would blow fu se and de energise solenoid, with negative switching any ground fault will retain solenoid, if on switched side it would energise solenoid but this s hould not cause any danger unless you happened to have crashed. Clive From: Ken Ryan Sent: =8E08/=8E10/=8E2016 19:13 Subject: AeroElectric-List: battery contactor vs starter contactor wiring Reviewing 13/8 I notice that the battery contactor jumps power from the big terminal and then switches the coil ground, but the starter contactor swit ches coil positive. Why do it differently on one than the other? Ken ________________________________________________________________________________
Date: Oct 11, 2016
>> In both of them, grounding the coil circuits actuates the solenoids but there is no fuse on the battery contactor circuit. If you visualize the starter contactor wired the same way as the battery contactor, you would have to bring the output side of the actuating coil back to the cockpit to the starter switch and thence through a single dedicated fuse. Not so! The battery contractor coil is hard tied to the battery on one end. The other end of the coil is grounded through the master switch. No fuse. The starter contractor coil is tied to ground on one end... The other end gets power via the mag/starter switch, typically via some breaker. On my Cessna it's the electric fuel pump breaker. Paul ________________________________________________________________________________
Date: Oct 11, 2016
I have several such tools. Usually made from a screwdriver with an 1/8" blade and a short piece of .125" i.d. tubing glued over the end. An exemplar drawing calls the adjuster out at just under 0.100" . . . >My guess is that the screw's head=C2 is about >1/8" in diameter but that is only a >guess.=C2 Plus/minus 1/32" would do the trick. Thanks in advance! Emacs! Bob . . . ________________________________________________________________________________
Date: Oct 11, 2016
At 01:15 PM 10/11/2016, you wrote: >I haven't seen any responses to this. Did I ask a dumb question? > > >Reviewing 13/8 I notice that the battery contactor jumps power from >the big terminal and then switches the coil ground, but the starter >contactor switches coil positive. Why do it differently on one than the other? so you don't have to protect the control wire. Bob . . . ________________________________________________________________________________
Date: Oct 11, 2016
At 03:30 PM 10/11/2016, you wrote: > > >The difference is the fuse. In both of them, grounding the coil >circuits actuates the solenoids but there is no fuse on the battery >contactor circuit. If you visualize the starter contactor wired the >same way as the battery contactor, you would have to bring the >output side of the actuating coil back to the cockpit to the starter >switch and thence through a single dedicated fuse. Wiring it the >way it is allows you to use a fuse or CB in the fuse panel. > >Just a guess. Actually . . . a fact Bob . . . ________________________________________________________________________________
Subject: Can One Oil Temp Resistance Bulb Run Two Instruments?
Date: Oct 11, 2016
If wired in parallel, can one oil temperature resistance bulb supply oil temperature information to two separate instruments? I can't fathom why it wouldn't if all it basically is is a resistor... The specifics are a Rochester bulb (MS28034-1) installed in the oil tank and wired in parallel to two separate 14v instruments in two open cockpits. Thanks, Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461198#461198 ________________________________________________________________________________
Date: Oct 12, 2016
Subject: Re: Documentation error?
At 03:39 PM 10/11/2016, you wrote: > >I just added a lighting dimmer to my Icom A200. I didn't wire the >dimmer circuit initially, and it was really annoying to be >completely black on a dark night! Anyway, I found this document on >the aeroelectric.com site: > >http://www.aeroelectric.com/Installation_Data/Icom/Icom_A200-210_Wiring_D.pdf > >At the top of page 2 there is a representation of the connector at >the back of the tray labeled "Wire Entry view of Connector" that >shows pins A and 1 on the left side of the connector. The issue is >from the wire side of the connector pins A and 1 are on the RIGHT >side of the connector (the symbol is labeled backwards). The Icom >installation document has the same connector representation and it >is labeled "Front view" which may confuse someone. This "front >view" refers to the front of the radio, not the front of the plane! I believe you're right. I've updated the Icom installation data to include service, installation and operating manuals. http://www.aeroelectric.com/Installation_Data/Icom/ I also reviewed the Molex philosophy for marking wire locations in the connectors . . . http://aeroelectric.com/Mfgr_Data/Connectors/Molex_Waldom/A200slash210.pdf and all the documents agree with your observations. I'll go dig out that drawing and correct it . . . as soon as I get a really big hole in the side of my house plugged with a new patio door. Thanks for the heads-up!!! Bob . . . ________________________________________________________________________________
Date: Oct 12, 2016
Subject: Re: Can One Oil Temp Resistance Bulb Run Two Instruments?
At 10:03 PM 10/11/2016, you wrote: > >If wired in parallel, can one oil temperature resistance bulb supply >oil temperature information to two separate instruments? I can't >fathom why it wouldn't if all it basically is is a resistor... The >specifics are a Rochester bulb (MS28034-1) installed in the oil tank >and wired in parallel to two separate 14v instruments in two open cockpits. > >Thanks, >Dan Probably not. One thermocouple can be read by multiple instruments . . . but the calibration of legacy technologies used by Rochester and others depends on COMBINED resistance of the sensor and components built into the gage. Paralleling two gages would upset the calibration. Bob . . . ________________________________________________________________________________
Date: Oct 12, 2016
Thanks as always Bob! Going at it now. Bill W On 10/11/2016 9:11 PM, Robert L. Nuckolls, III wrote: > I have several such tools. Usually made > from a screwdriver with an 1/8" blade and > a short piece of .125" i.d. tubing glued > over the end. > > An exemplar drawing calls the adjuster > out at just under 0.100" . . . > > >> My guess is that the screw's head is about 1/8" in diameter but >> that is only a guess. Plus/minus 1/32" would do the trick. >> Thanks in advance! >> > > > Emacs! > > Bob . . . > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus /9j/4AAQSkZJRgABAQAAAQABAAD/2wBDAAEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEB AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQH/2wBDAQEBAQEBAQEBAQEBAQEB AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQH/wAAR CAE4ARwDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAA AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkK FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWG h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl 5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREA AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYk NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOE hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk 5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD+/iiiigAorzDXvjD4E8N6teaJq2pXMGo2 DxpcxJpt/OiNLDHcIFlhgeN8xSo2VY4JKnBBAyP+F+/DL/oMXn/gn1P/AORqdn2f3MV13X3o 9morxn/hfvwy/wCgxef+CfU//kaj/hfvwy/6DF5/4J9T/wDkaiz7P7mF13X3o9morxn/AIX7 8Mv+gxef+CfU/wD5Go/4X78Mv+gxef8Agn1P/wCRqLPs/uYXXdfej2aivGf+F+/DL/oMXn/g n1P/AORqP+F+/DL/AKDF5/4J9T/+RqLPs/uYXXdfej2aivGf+F+/DL/oMXn/AIJ9T/8Akaj/ AIX78Mv+gxef+CfU/wD5Gos+z+5hdd196PZqK8Z/4X78Mv8AoMXn/gn1P/5Go/4X78Mv+gxe f+CfU/8A5Gos+z+5hdd196PZqK8Z/wCF+/DL/oMXn/gn1P8A+RqP+F+/DL/oMXn/AIJ9T/8A kaiz7P7mF13X3o9morxn/hfvwy/6DF5/4J9T/wDkaj/hfvwy/wCgxef+CfU//kaiz7P7mF13 X3o9morxn/hfvwy/6DF5/wCCfU//AJGo/wCF+/DL/oMXn/gn1P8A+RqLPs/uYXXdfej2aivG f+F+/DL/AKDF5/4J9T/+RqP+F+/DL/oMXn/gn1P/AORqLPs/uYXXdfej2aivGf8Ahfvwy/6D F5/4J9T/APkaj/hfvwy/6DF5/wCCfU//AJGos+z+5hdd196PZqK8Z/4X78Mv+gxef+CfU/8A 5Go/4X78Mv8AoMXn/gn1P/5Gos+z+5hdd196PZqK8Z/4X78Mv+gxef8Agn1P/wCRqP8Ahfvw y/6DF5/4J9T/APkaiz7P7mF13X3o9morxn/hfvwy/wCgxef+CfU//kaj/hfvwy/6DF5/4J9T /wDkaiz7P7mF13X3o9morxn/AIX78Mv+gxef+CfU/wD5Go/4X78Mv+gxef8Agn1P/wCRqLPs /uYXXdfej2aivGf+F+/DL/oMXn/gn1P/AORqP+F+/DL/AKDF5/4J9T/+RqLPs/uYXXdfej2a isLw54j0nxXpMGt6JO9xp9w88cUskEtu7PbyvBKDFOiSLtkRgCVAYDIyDW7SGFFFFAH50fGn /kp3iv8A6+bD/wBNGn15XIxWN2HVUZh9QpIr1T40/wDJTvFf/XzYf+mjT68skUsjqMZZGUZ6 ZIIGevFOv7T6tW9lf2vsKns+XSXtPZvk5X35rW8zHTn125tfS+p/Gro//BbD9vjT/wBlT4rf tkal8bf2DL6H4U/Hq/8AhS37Kfi/wfr/AIc+L3jzQLLxJ4b01tZ8FX2j/FmLVL3U30/XpbwR t4Yext9L0TxFrUj3S6YLGT9pvCP/AAW5/Y/8ReNNa+G+p6L8cvD/AIv+H2nWmrfHC5k+EniH U/AfwK0b/hCD411bxV8S/Hun+bo+g+EdK8ufw9/aVwqatfa+sVnaaA6y+Ynn/wDwTZ/4I1fC f9l/4deJY/2pvg3+yv8AHP433Px68a/FHwj8UIfh1pfjnV/D3hnVn0O78J6VB4l+IHgbSfEF jqfh/U7DUdQhgsoXsdNvLtbrTbxrh5HSxoX/AASh8X67cf8ABX7QPiV8QvCemeDf+Cj3iLT9 Q+H2qeCDrmp+Jvh9ZadpXiaKxu/GGl6rpHh3T7m5sdZ1XSr19E0bXNQstVsLa/sJtVsftCy0 nPE4fAOEYQxeIp8NYbM6MJLllLO8Pl/DtGeSzxUpxqTlmWNxOb4vGzrRlHCPA1sPgKtGFWNa G9dYatj6k4TnhsNPiXG4B1I6wjkmJzHNpUMzhhIwlCFPK8FhsHTwfspKpjFjqNTHUqjoujU9 z+CH/BYT9jr42+M9L8Fib4v/AAel8Y+CPFHxO+Enib4+/CPxR8KPBfxx+GfgrSLnX/FPj34S +Jtcjex8ReHtG0OxvtYuf7Q/sXVZNMsru/tdMntLeSZfhv4lf8FwbP4ifHD9gzwj+yd4T+JF p8Kv2if2nYvhf4n+JHxn+AfjLwp4K+LPw1TU9I0bUvEfwD8Z6tdafYarJper3F5p2ptdww6z plxJbi+8Owp+8GFoX/BH/wDa4+O+o/sx+EP22/il+zjpvwd/Y5/Zx+Kv7Pfws/4Zqg+Jlx8Q viPbfEv4Wv8AB1fFHxGl8faP4f0Twtc6P4VtdF1aTSfC0utWGpa7aajbsLXTdTRbLA+HP/BK H/govav/AME7Phj8U/ip+x1qXwI/4J3fHPTvG/g7VvBS/F6x+LHxH8DWWtG5gfxNZav4Ok8K aR4o0vRYYtNsdD0jUH0q/lu5LjV/FM9zp8V1f9E42xOH9jL2lOnmuVzoe1/d08ZldDibFRxO KzGTjfC162TYbK54nKXRUatHMMelUpXnHKOGtKqsDi3GEViZ5Nmsaih78sJnNXIYvBYXL9f9 sw8czrYlUsy570K2Gw0XGcUq2M/SnRP+CvH7IXiD4GfBf9obT7j4l/8ACvPjz+0Xbfsu+BHn 8ErFrR+KV3qF/psMes6YNYYad4fNzp1yW1dLm5Kx+W32Uliq81qP/Baf9iTTvihceAGvPjJe +D7X4sf8KFn/AGjNN+DXjC9/ZoX44mc2sXwpT4sxW/2GbxRPcLIIriDTpfDRtIpdYfX00NRq Z/Kjwr/wRQ/4KCeHPAHwD/Zom+L37IV9+zX+zl+3Np37V3hTXIZPjDZfGbxno0fiS51G60vx Nbv4NvfB2hapZaXdX5sNG0e51G0vtR1RI7vxXaWujJJq315+zT/wTt/4KT/shM37OX7Pn7Tn 7O3gT9j2X9pXWvjZcfE9vBOt+Kv2r7jwB4muIb/xD8H5fCPjfwh4o+DL/wBpPbwaYPiB/ba+ IbUxnXLW3hR/+EaV4flrVcP7SToUa0KTXNG0ozlg+DY4pYttuWChQxGN4uxFCpCni6lX+z8N TWFxE6MMDmvTjfZ0nmEcMva+wr4iOHnzXU8OsdxhLC1KEbJYutUwmD4PoVKLnh4XzLHTnWws VLF5f7f/AMEzf+CnHj39uT4z/th/C7xx8EvFvw8sPgT8X/Fnhn4f68/wu8a+E7G38GaHrC6V ZeFvjDqviTxBrdloPx2AngvNS8FWtvozLZ2uq3UOnRx2EwT5l1H9rr/gqj8dP+CgP7eP7Mn7 JHiv9kjQfDH7Iv8AwrrUPD+i/HPwB47vLrxlD468G2OswaLc+J/BviGKe2m/tdNQja+awtEh t7izQs3lTTH7F/YV/Yo/aQ/ZI/at/bl8Z674w+CPiv8AZu/at+M/jT9oDw9HpMPju2+N/h7x 14o1q3u7LQdZtby0j8Bx+EtN0e/12yup7G/1PWNQ1K10nUYn0+1u7zS7P5Z8RfsEf8FQfhR+ 3L+27+1J+x38Tv2JdB8PfthDwDp7SfHG1+NOveOvA2n+B/CFhoNrquh6X4T8PWvhGHxBFqR1 O+ii1u68W6Ncwppq3FnF/pcL8kPaSlkdScK8VPgvErGQp1KanDib6nldPD/WY1bUI14Y6njP fqqeGq01PE1IxpYh0o61nFQzuNGVDmXFuHlgJVITdN8PPH46pXVGVNOs6Esvnh7why4ilUcM PFurQVR8P+zn/wAFpfFXx8s/2JZfGl74W+CPj/x38bv2gvgV+0R8KdM+GmsfEHTvF3jL4HeG vA3iXUl+HnjRvHVnL8MtOk0fxbZ6pCPEFn44lmvL+fw+t9PDo6eItU+hvD3/AAcCfsI+Jovh 7e6Z4b/ask0b4tHxBpXww8Qx/szfELUNE+Inj7w7ew6ddfCnwLd6NBqb+MviHPeXml26ab4Z g1bRrC41jTLXXdd0i6uGgj+cvBv/AAQr8dfCKT9gYeA/jF4O8ZX/AOzz8Vv2lvjT+0Z418cQ +IfD2u/E3x98fvCXg3w6l74J0TSdK8VWkNppK+ErOxuIte16wlks7aLUhLc317c2lvV+EP8A wRf/AGjPh98Kv+CTHgTV/iR8FLvVP2Bv2j/iX8ZPird6dq3jqSw8V+HvGnxMsPGmm6b8Pnuf AdrcX2s22m2j219F4jt/DVil8ypBfXEGbgdmE5q3s6eMnRoOWbZZh8VUw1OapRhj/Y4XO8xw jxDqVVl+X1VXx+X4WpFRjTVCPs4UpV6FblxLp06NGrhI16reCz6tCjiZw9vBYPE8Q47h/B4p UVGDxmOw9LJstxdZSqVn9bk5V5VKNGpR+9NG/wCC0H7Fet/BGL4yWtx8Yo9auPjNdfs62f7P j/CLxLcftK33x3srS2v7r4WWPwo077ddXXiW3s7uB7iaHVH0K1unGkXWswa5jTDmal/wW1/Y k0jwJ4W8aX5+OEOreIfjdd/s4at8J/8AhS3ix/jZ4D+N1ppiamfh540+F6IfEkGu3ayR6fpq eHrfxHb6nrBl0mwnuL6zvobX83PHv/BBv46eJ5fih4/tfiB8A9X+Ja/8FDfil+2F8KPB3jG+ +Kn/AAqvxZ8PPibBo9tqPw7+K+s+EdH8OeOvCXiFf7C0y7TWfAg8Qx2TW9zaW11Ib9NQ0/v9 C/4ItfHEat+zP8Qbpf2QPhr49+Hn7dfgH9p/4saD8Gv+F2R+Fr74dfD5TFovhjRvFXxDTxb4 s+InxARLzV5H13xNY+AdLlS7gtGRfs8l7cZ4NyxCovExWCeIr8Lxqxi/arA0sfLhB53NOXL7 aOChj+LlOLc6lCWV4KMmo0/aZxpi1DD+0WHf1v2MeInCT9z63LBz4pjlEFyc3sniqeC4Xqwm 4xhVeZYyC9o5JZZ9w2P/AAW4/YluPhL4r+J+p/8AC7PDGu+DPjho/wCzhrnwK8TfCDX9M/aA g+M3iKPVp/D/AII/4V2J7gRajrFvoOuPbveaxawW11pN7pGpy2GuxppcnG/Ef/gqp4U8R6x+ y1a/DLX/ABx8DNW8fftieGf2a/ip8MPj7+zV4ti+IR1fVDZyS+CDBP4o8Paf4MutQgmmFl8R 9Ku/H/hq2mjuLd7S5ubO5ih+cPih/wAEfv2ifFHir9vrxVpOqfsgePdM/am/ak+G/wAcfCfw x+O3hPxZ4t8Iar4K8K6R430bX/DPi7xDp/hGPxb8IfG9zD4tjk0Lx/8ACafXtbsLddW01Ly0 TVPtcHlPw7/4IhftZaJJ+z6/iT40fCqw8F/CH9vLwb+0vovwC0r4mfHfx/8ADj4JfBrwms0M 3w4+C/jX4leHbvxtrfiHWop45b7+37Dwho/2vTrS5W+NxPczicJOpVeEq1qMaUnPg7FVKE6j jTpTr1uDqnEGEqzcXzU8PLG8TRm/Z4ulOhlzp4ijh44anHP5xiVKGLhh5yq8seKMNSqqKdSs qdDieOS4inBOPJKqsNw+ovmw0418Z7XD1q8sRUWSfpbbf8Fo/wBiO6+J1v4FTUvi4ngS8+K/ /Ch7D9pub4QeLY/2Wr/40/azYj4bWnxjNv8A2ZJrbXCSMupNYJ4VawifWR4h/sUDUW4vxd/w XX/Yi8EeKvGugeIdI/aLt9A+F/xy1L9n34rfFS1+BfiXUPhB8MfHWn6ncaRbv4y+IVjcT6Na adrV9Z36aLbac2p+Jby3sbi/fw5BYGC5m+FrH/gin+1/D8H9D/YCuvjL+zfJ+wJ4f/ali/aD tfiBFpvxMX9rO68OQ65P4mX4fT6ANNT4XwX0uoXdzp7+MrfxZ9qjhMepJpbRK3h9uv8AiD/w Ri/aI8Wfshf8FFf2e9N+I3wVt/FX7X37cI/ab+HerX2r+Oh4f8OeCV8c+HfE66L4zuYfAc+p 23ir+z9HuLcwaJpmuaUbuWJf7YMLSTJWFd1ls66lKMvqbxkZR9hUq06+K4GpYtzgpVfqVTCP NONfZ0+eu54TIsHWfPz+3xvRWp0XiMZSpVFTp+2xMMPWu6saNOnS4wlhKkW4w+tfWaeX8KVK 3NGl7DFZviKHKknQwX6D+KP+Cvv7Jnhn4x+PPhFDpfx38X23wn8e6H8L/i38W/APwV8V+Mfg 38L/AB/4jkmi0jw34w8V6Ms+qW81xNaX8Mmp6X4d1XQrSXT7tLvVYGEHn/qSrK6q6kMrKGVg chlYZBBHBBBBB7iv5kP2kP8AgjP+1n8Wfj/4l+JPw48X/sofCrWtY+Ivg/xP4R/a4+HN18av gp+1b8N/B1okP/CY+EdS8GfCfStN+FPxt1e/jt7XTNO8c/EHxFp/iK80+G7k1OaC51GD+yP6 aLSGS2tLW3luJLuWC3hhlu5gomupIo1R7iUIFQSTMpkkCAKGYhQBgVpQinl1CpWkvryrzpV4 2cVOMcHgKjq06erhTWMq4yjFTs4+y9lSqZhRowzTHcM5VPrdowSw08LCqkrydGs69aKpTqO3 POWHVGbcIvZ1K1LAVav1CjYoooqTUKKKKACiiigAooooAKKKKACiiigD9AvgF/yTLR/+vzWP /Tnc17NXjPwC/wCSZaP/ANfmsf8Apzua9mrCW79X+ZvHZei/IKKKKQz4y/ak+N/7En7MNlZe O/2rvil8MPhJH4su5bbR7rx34rm0vVfE93YQW6XSeH9Atrx9Y1z+zrd7X+0G0fS7qPT45rd7 1oBPEz938KrT9mL45+AtA+KPwa1XwL8UPh14pt5bnw/418DeKn8SeHNVS2uJbO8jttU0vVrm 2N1YX0FxYalZO6Xmm6hbXNhfQW95bzQR/jr+3B4W8ffAf/gr7+zp+3j4+/Z7+NP7SP7L+lfs qeMPgfZS/BL4Wax8cfEXwI+L994n1vWG8XXvw48PQ6lr1jpvivw7qaeHf+Ev0zTAWbULjTLm c/ZLe3ufhfxKn7QF0/7Lfi27/YY/bH/YC/4J8+N/Hf7WXi34o/Av9h24+NNj8e9W8e33hfTr L4F/Ez44eCvgJoXhj4m/DdvGWtWCvZeCYIbzwtpusWFleeKtRnstQ0/bzUsS3hHXnCc6jeZu dOmnSWAnl2YY7D4bBYp1l+/x2d4DBUsdk9Kg6dXFV8xy7B08PUwtXEZrhN69CMMQqdOceSNP ASUpJVJ4763l1DF4irg4UneFHKcZXeCzGdXnpUIYLHYirXo4iOEy/Ff1a/8ACmfhl/0Kdp/4 Gap/8nUf8KZ+GX/Qp2n/AIGap/8AJ1fxUaZ8MP8Agsr8SPAmo/8AC+Nf/wCCl2jeKPAH/BKD x/8AET4cW3w88bftG+EX8RftMeHfj34lT4MaD49h+HN7a6T40/aBuPhNf6NN4g8F6mb34jax b2lhdeK7CfWLC5aGLx78Nf8AgrR4TOreCfAHiD/gqvN4e+Inw9/4Jr+M/FPiG28U/tXa54k0 n4l+NbC0m/amTw74vla81LwfPpF7q+rH4keE9GurDSPC32WysvEei2dpoWl2th3+xm8bQwSl BTxWaUssoVZScaMJYjM+Jsuo18VJJyw9KC4Tx+IxbUav1aONyaCdb69OeG5as6dGhiq7bnHB YTEYuqqUed1o4TCcNYussFZr6zGquJ8FHAzfsvrUcFmdTlovCwhW/tc/4Uz8Mv8AoU7T/wAD NU/+TqP+FM/DL/oU7T/wM1T/AOTq/kK074If8FI/hb+0Edb+HviH/gpfrei/Dz/gsj4K+Enw 8tPHfxB/as+IHw3u/wBhfU11nU/EfiLxJpniS+1fQvGfwfl1A6fZ6/8AFbxBFrGmQ2MMMEvi OOeWaW48tsl/4KxjwtoY8Hp/wU+X9tZPDn/BQp/24pPE8n7QZ/Z9l0KXwZ41X9npf2fFvJT8 KG8WR3f9ht8Bf+GdIx4nTXt40xvsC6QqcKxKlg44yMalpYSji1RmuStyYnJMkzyi+W8v3OEw +d0KOd1tP7Kr4bExjTxkacXLseFlHESw8p0lbFrC+1jJSp3hmPEWW1W5JK061fhuosspq/8A aE8xyqDnhfrLlT/tH/4Uz8Mv+hTtP/AzVP8A5Or4Z8T/ALZv/BK3wR8UtZ+Cnjb9pj9nXwX8 U/DviCfwpr/g3xh8UbXwtqWieI7ZxHNo+qza9q+n2FherIViWO6vIhLK8cUReSWNW/ML/gl1 4A/bk+FH7Yv7NKfFTV/26fFHwq+Mf/BLjwx8Qv2h7n9pjxN8e/iB4K8MftfS/EdYtQ0WXUPi nNf6R8OPiVaeFrGC2fwItxpmtQaHc3Es+klLk3NfCfxk8D/FXRvFv/BeD4F+IP8Agnb+2B8d PEn7bPxpto/2XvF3hz9lzxlrvwh/tiHT/EekaN8Rbj4xa1pVj4T8LaV4Y1vW9K8S2Xiix1Ge 226ZJIl7AqNKvRjVWweIlShD67Onl3EOIhhcM5KvjswyHivD8MLLsHW5asIvMIxx2Z4CtUoS dfBUsNVlRowqVXSwwip4qnTnOX1OnUzDIsPPFYjl9jgsBnPDlXP3mGKpJwk1gJPCZfjKMK0V SxUq0FWnKFNT/q48GXv7KXxE+IHxK+FfgbWfBfin4i/B3/hFv+FoeD9G17ULzWvA48b6ZNrP hFtfto74/Y18Q6Vbz6hpTFmW6tYnlQ7RXq//AApn4Zf9Cnaf+Bmqf/J1fxaaT8CP+CuPgv4m eEP2bfEfiX/golb/AAx8O/tB/wDBJ34Q+JPE3wb8WftK6P8AD7S/g/Zfs7+KvC37T1z8PfHf gy4g8Paf8O9G8SLpkPxJ8YeHLuDw9B4ks9D1vxNdQ6uNPmXrvhr8JP8AgrB8OPHHwu8U/DfW /wDgo1q3jfTf29v2zfgvo9n8afGH7SnjL4Vj9mfw74Asm/Z1134i+H/iBPqHgqX4aap4z1W/ n0v4peJ7M6Zrtyhe18QTDQtNGmXiHToNunOeJox9jGFbDxjUniXU/wBUKXtaVCM2qcamJ4xw Cp0VXxHLh8vzqq69SWXwhisoKcpOE1To1PYYWu4VnKnSw7xGVZ5mcqFXESheboR4cx1GtVeG oezxGLynDyo3xM61L+x3/hTPwy/6FO0/8DNU/wDk6j/hTPwy/wChTtP/AAM1T/5Or+G/StM/ 4LBp+z58WdS8H+MP+Coq/HNv2bNUtvjX4Nufh3+2C13P8ZV+NfhqTT9T+G/j7xz4+ltrL4lR 6XKV021/ZI8IXXhDVPg8lyutJpMP9szv9A/GP4Vf8FE/hl8Qfjv8LPC/xF/4Kqx/s/PdfsE/ ETTvGbaH+1d+0dpupeJNS+G+rXfx/wDDXifxh4V+KfgD9onSfhNfeMdSa5+OMf7NHiHxR8Q/ C11YadpsPgeOG1sX0OLtTVN1KKbdCEayq82DnKpisypSrU8SoWq4JYTKcRj8PiqVOcsTTr5f RjQhWxfLS0UU6daqo1F7F4luhKk44zkw9Hh6Spyw126eNlieIcPhJYWc4wpywGZVniXRwylU /q81W5/ZX0T4u+FvgJq+q+D9P+Mvjbwtq/jfwl8N7nW9Sj8U+IPCWgzS2+s+INM043u6403T J4JYru4VsQuhDDlc+p/8KZ+GX/Qp2n/gZqn/AMnV/FhpOo/8Ft9T8G+C4vhP4X/4KE+F9c03 9kr9sHS9M/4WH4q+PPijw7r3iWL4hNP4O8R2Nz8S/Cfg/wAQ6N4yv/A9z4hh/Z30H47wax8c dLWz8PjS/EF7HL4cgs5fiPZf8FMNR8F/Fmw/Y7l/4K2ab8A7/wAFfsS6fqdz8Urv9q+0+P8A aftFzeMtLg+Pl58JrjxnJL8X7LwNF4al8SyfFW48Mqnwuj1+NZUX+wYvDIqqEZV62Cw8E4VM ZPBU4zr3w6orMs6z7L8NWx1J888vw+Gw+T4eGMnUnXqQzLMstwsqND661hIqyhRpY7ETcfZ4 J4y8af751ll2W8P4qvDCVIWjja+Iq5zWq4OnShCE8DleZVo1a31HnxP9pX/Cmfhl/wBCnaf+ Bmqf/J1H/Cmfhl/0Kdp/4Gap/wDJ1fxzfHH4af8ABQ34d/EX9pX4Q6H47/4Kfxfs5/Dj9sQ6 l8E9b1bw5+2h8b/AXjjwHrfwivbhtE+IXxi+C/xS8Mftc/8ACpbPxZZwr4Z8Q/Bqw+LPhfT/ ABxPv+IGm2t5eWN5qf8ATL/wSy1T43av+wV+zveftF+FvjX4O+L6+GNWtPFWiftFeKLjxj8Z EFj4q16z0a/8a69qPhbwb4guLzVtCh03U7G18W6BB4w03Srqx07xTfazrdre6zfmG5cVg62M hN04045JUhRqpQrzpZzk1DNouUFKUadXCyqywdehzTqxnRdacadKdLmMRfDVsNRlFSderm9B yptSVOrlOaY3LW2kuaVDERwX1qnibRoRjiMJRU51aqS+tP8AhTPwy/6FO0/8DNU/+TqP+FM/ DL/oU7T/AMDNU/8Ak6vT6KV33f8AX/DL7h2XZf1/wy+48w/4Uz8Mv+hTtP8AwM1T/wCTqP8A hTPwy/6FO0/8DNU/+Tq9Poou+7/r/hl9wWXZf1/wy+48w/4Uz8Mv+hTtP/AzVP8A5Oo/4Uz8 Mv8AoU7T/wADNU/+Tq9Poou+7/r/AIZfcFl2X9f8MvuPMP8AhTPwy/6FO0/8DNU/+TqP+FM/ DL/oU7T/AMDNU/8Ak6vT6KLvu/6/4ZfcFl2X9f8ADL7jzD/hTPwy/wChTtP/AAM1T/5Oo/4U z8Mv+hTtP/AzVP8A5Or0+ii77v8Ar/hl9wWXZf1/wy+48w/4Uz8Mv+hTtP8AwM1T/wCTqP8A hTPwy/6FO0/8DNU/+Tq9Poou+7/r/hl9wWXZf1/wy+48w/4Uz8Mv+hTtP/AzVP8A5Oo/4Uz8 Mv8AoU7T/wADNU/+Tq9Poou+7/r/AIZfcFl2X9f8MvuPMP8AhTPwy/6FO0/8DNU/+TqP+FM/ DL/oU7T/AMDNU/8Ak6vT6KLvu/6/4ZfcFl2X9f8ADL7jJ0TQtJ8N6dFpOiWaWGnQPK8VtG80 io88jSysHnklkO+R2Y5cgE4AAwK1qKKQwooooAKKKKACiiigAooooAKKKKACiiigAooooAKK KKACivkfxr+3b+yh8PfCOseOfFPxcsoPDeg/FPxz8FtSudI8LeOvFOop8SPhjZarqfxI0K08 P+FfC+teIdTtPAGk6Frms+M/EumaVeeFfDOiaLq2s6zrdlpem3t3B03xd/a+/Zu+BPhvwH4v +KPxV0XQPDHxMtZNT8E65Yaf4g8WafrHhy20yy1rUvG0k/g7SPEA0j4daFo+paZq3ib4ka2N N8B+F9N1LTr7xD4i0y1vrSWZQlGpGE6bU4VHhFTnBqUZvMKEMVgFCSupPG4WpTxOEUW/rNCp CtR56coydOMo1PZSjKNX/av3bTVT/Ya08Njfcfvf7HiKc6GK0/2etCdKtyTi4r6SoryPwv8A tAfAbxx8QfEXwl8F/G34R+L/AIqeELe6u/Fnwz8L/Enwb4g+IPhe1sbmzs7258ReDNJ1q78R 6Jb2d3qOn2t1NqWm20dvc31nBMyS3UCv65Ts+WE7e5Ujz05fZqQbcVOEtpRcoyjzRbV4tXum QpRbklJNwajNJpuMnGM1GSWsW4SjJJ2bjKMtmmyiiigYUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAV83ftN+PdT+HXhn4aa5YeI4/C1le/H34LeHv Euq3FxZ2ll/wiWu+NtPsfElpqN3fj7Na6fd6ZJNFeXDvCYYC7rPERvH0jXxv+234R8KePfh5 8LvBfjrwx4e8aeDvE/7Sv7P2jeJPCfizRdN8R+GvEOkXvxE0uK90rXNC1i2vNL1bTbuJjFdW N/a3FrcRkpLE6kiga3XqvzMaf/gpb+wHH8UvA/wUsv2ufgZ4j+J/xF1SfRfCfhTwX450vx3c XWpW1rd3s9tqmoeDJNd0fwwI7eyunM/ijUdGty8XkrKZ3jjf6p/4Wd8Nv+iheB//AArNB/8A lhX59r/wRj/4JgW/xc8PfHHSv2OPhP4f+IPhnWRrmnS+HrPVtF8Gy3Zsrqwkh1H4XWOqxfDD UrGWC8lMlneeDpYvPSG4QJPErj6x/wCGPv2Sf+jW/wBnT/wyXw0/+ZmjXr/X9O4aab+ei38t f6+enqf/AAs74bf9FC8D/wDhWaD/APLCp9T8Z/D9fCmq+JNZ8V+Dl8D28Ulrrev6nruiDwpB BcNHZTW2q6rdXX9kRRTvdw2kkN3OqStcxwMrGZUbyX/hj79kn/o1v9nT/wAMl8NP/mZrwz9r Ofw5+z78EfAPww+Cvgj4cfDxvjz+0f8ABH4HaRZaV8PPB48H6FcfFHx9pEXjDxY/gl9Cm8J6 trlh4I0XxDeaKNa0i7sJfEdtocupw3dtbtbSpqNSph8O0pSx2MwOW0YSS5amJzPGUMvwtKfN 7qhVxOJpU5ynaEYycptRTYczpwrV1JwjhMNisfWqJtOlh8BhquNxNZct5t0cPQq1VGmpVZuC jSjOpKMX+IPj/wCF0vw/+FN9F+zxq/wU8K+KPDP7ZX/BQG/+G/hLwR48/Za1bwppPwD/AGm/ AXjDwR4c1C3+Hev/ALQ/wL8L6Zo2qrceHYtCvNP8c2msfDe5Nvq2r/DfxX4dXXNCPQ/G7w9q 5+AfwI+F/g3VfBPxG8QfDD/gnN+0N/wTq1+RP2iP2ZtI0q48efGX4Ofs76R4d+OGlXfiX41a dJefCPT9e8D+JvDniS/uLWw+ItveaOk1l4A1DRriy1Sf9Yf269E1H4K/D3w14q+AXgn9ki18 Y+JPF/hv4W+Dfhz8U/2W7j4k3fxV+KnxG17TNA8A+H9I8ReD/jH8Hk8A6NYvJq2ueOdfvvD/ AI8OleEdN1bxJBpyJ4fn0/VPmD4k/GzxX8Ev2gfiL4S+MH7NPwK8K/BjRvDfinT/AIK+Ko/2 T9Ok079oX4m+A/2VZPjx4u0TQPibcftBxap4KjXxBovjq00Gx1D9njxP4c1XRfBWo6APiini +4iCccZ0MNl+N9t7WrhsLlWGy7F1azlKpLC8L8I1uHXRjiKbUXjcVkfEVZTwsKkcRPGcQ0MZ h8Nhp8lSh20lXlmeBxOGjTp4tYrM81w9KnywpRqZ9xHRzavVq0aiSWHw+ZZfSqU8U0qSy/h/ FUMRisRh8Hi6b4v9inVrb4KftP30Nr48tPhd8F5NL/aIvvjlffEL9tb4PfFz4TfGf4m+JfiJ 4Cv/AIMfET4GeCtN+Iz6r8Nbm98N2fxA1bxZa3Xw38C3enWOsad4R8V6n491nStM8RJ+9Op+ MvCGiG1XWfFXhvSGvbdbuyGp65plgbu1c4S5tRd3URuLdjws0W+Nj0Y1/OH8MPjh4x8J+Grn xF8T9N+E/wASrHwN4k/4JpfEvxlcN+z18F/DEur/AA8/4KBWMfgDxn8NreHw14PtPJ0n4T+P /EGm+OPhzq1jHF42udM0u18M+OPEvjGCbUL+9/oN8cfAz4JfE6706/8AiV8HfhZ8Qr7SLH+z NJvfHHw+8JeLLvS9N81pv7P0651/SNQmsrHzneX7JbPFB5rNJ5e9iT7WKhiIQVDEezdTKcXi sixElyqpLG4SGFzTEwqKmo0HHCrO6OBo/VIU8FSpYWOFwcHhsNSqVPFwksNOKrYXndDHUaOZ U3q4QpYp1KNKnzVP9odapRwlPH1Fip1cVKlj8PWxFV1q1SnS2/8AhZ3w2/6KF4H/APCs0H/5 YUf8LO+G3/RQvA//AIVmg/8Aywryz/hj79kn/o1v9nT/AMMl8NP/AJmaP+GPv2Sf+jW/2dP/ AAyXw0/+ZmuI7dPP7v8Ag+v9PTx34H/8FPP+CfH7RsVmfhD+198C/EWoahfDTbHw3q/jfT/A vjW71BiwWzg8B/EA+FvGclwSpAiXQSxJXj503fQX7NfirX/Hf7OnwB8b+KtRbV/FHjL4KfCv xV4k1Z4LS1fVNf8AEPgXQtX1jUWtrCC1sbdr3Uby4uWgs7a3tITKY7eCGFUjX4z+C/8AwRn/ AOCXvwEd7jwF+xb8F77UJorVJtV+JWiXfxk1FprQxyR3lvP8W7/xqumXjzxrcyTaRHp+Z/nR UAVV+q/2PQB+yT+y2AAAP2c/giAAMAAfDPwyAABwAB0FAO3S/wAz6MooooEFFFFABRRRQAUU UUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABXyx+1f/AMgH4J/9nT/s6f8AqyNKr6nr 5Y/av/5APwT/AOzp/wBnT/1ZGlUDjuvVfmfU9FFFAgrwX9o74GWv7QHw7s/CC+IX8H+I/DXj /wCGvxV8A+Mk0lNePhbx98KfHGieOvDGpz6JJf6Uur6Zc3minRte0tdU0yXUvD+q6rY2+pWE 9xFeQe9UULSdKotJ0MRh8VRmtJUsThK9PE4avB7xqUMRSpVqUlrCpCMlqkD1jUg7OFWlVoVY NJxqUa9OdGvRqRd1OlWo1J0qtOScKlOcoTTjJp+Fa1+zl8MPE3ibwL4u8T2/i3xNrXw0+Lmv fHHwK/iL4g+OtbsfDPxC8Q+D9c8B3N5pWmal4gubC10DTvDPiXXrLw94Njtx4R8OT6pd6hou i2WoSfahwtx+xH+zXe/GrVPj9f8AgXVNR+IGsatrPiS/tdS+IHxF1H4dv4v8R/DiL4P+IPG0 PwjvfFc/wttPGes/C6FPAuo+J7XwhDq9xoD3ULXP2i/v7i5+r6Knkg4Om4RdN0amHlBxThLD 1aOGw9WjKLXLKlVoYLB0qlOScZ08JhYyTWHpclOc2+Zzk5e77zk+ZctbFYiNpXurV8djaqs9 KmMxUt8RWc/z8tf+CcPwF8LeG/DHgj4aR+IPB3gyD40fBP4tfETT9d8VePPijrvxD039nO2t Z/gv8NF8V/Ebxrr+r+FPA3gXX/DngO80nRNNN3o1toXhe78PWej2cniTUdZi/QOiitHObjOM pzkqmIni588pTcsRPC4LAyquU3KV3hMuwVC1+VQw8LJScnKOWN4NRjH2dCOGgopQjGjHEYrF qKjFKN/rGNxNRzadSXtFCUnCnSjAoor5I1H4SftZ3GoX1xp/7X+jabYT3l1NY6c37N/hC9aw s5Z3e2smvJPGkUl21rCyQG6kjje4MZldEZyokZ9b18y/sp6nZaL+xt+zbrGoymDT9J/Zl+Du p384jkmMNlYfCzw7dXUoihSSaUxwRO4jiR5HI2ojMQD+NX7HX/BPz/guP8J7/Uz8ZP8AgrX4 YuPDM+qLqlp4avfhZP8AtTXt1CbozPpV54s+MVt8PvFGg2ZtybV49C1y6VD89vKmxHb9afgQ HX/gn58GlkcSSL+xz8OxJIE8sSOPgpo4dxHubYGbLBNzbQcbjjJBtW6p+l/8j6p8LeJdG8Z+ GPDnjDw7dNfeH/Feg6R4l0K9e3uLRrzRtd0+31TTLprW8igu7ZriyuoJjb3UENxCXMc8Ucqs g3a/mY+Kv/BPv/gsD8df2bfgvL+zp/wVpl8AaLefDX4e6poPw9Hwsg+Ap8OaFd+DNHl03QX+ MvwWOuePfEC6XayRWf2rU9EWW8Nst1KUmmlB/YTwV8Af2udF8K+EtL139t7WbzVNJ8P6Dp+s OvwQ+FeqpdahYabaW2oMusalpsOqais9zFMRqd/FFqF4G+1XUaXEkigC3mn9/l5ef4H3HX50 /B/xT8WJf+Cl37YHgXxl8Sb3xN8P9H/Zq/ZT8WfDnwLZ2eo6J4W8CR+J/Hv7S+nau8Wjz+It csdU8Xa0vhvTm8S+NooNIu9dtrHRdMOmWWmaBpdrD9DftQfEIeBPA3hfTrDxz4y8BeL/AInf FP4d/CnwFqfw/wDDHgfxh4tvPFPjDXooza2Gh/EaC48Iy6ZYeH7LXvEniy/1FDPpHg/Qdf1T S47rVbSysrn8uv2xJNH+AHiWWz+Mvxu+LfxX1L4kfDhPFHxh1rw5+yL+w54xj8MfAD4P+O/D lnF46+NFz418C+HtS174b/Dfxt8TrXV9F8OeH7bx94p0291DxFr/AIW8Ezva6tdqUWpYihKF qjliMdl0YJ3UsSsoeLrU2neMJYPB4nD5niK0lFYXARq4ipUpYf2006qvg8bQkuSdWjlWLp1H eMqVGjxFgJxq2Xvzp46eAxeU4aEeZYrH1Y4anGrXjGmeKeLP2i/jW3iT4p+Av2lf2sfGMHgf xnrfiz4zfCi5/ZJ+Ifw58cy+LvhF8Pf2yNK+GGm/su+CZ/gX8FPgX8bfhf8AG74h/wBu+Cvg vYa3a/tM/GbUbzUW+IC6jd+GfEGg6oln+0H7F3hf4zeDP2Xvg74b/aC1bVdY+LWn+G7h/E8v iDxHc+M/EmmW9/rWqal4Z8L+KPGl7PdXvjPxR4O8JXeheE/EnjC9vL+88Ua5ot/rt3qWp3N/ LqF1+Keu+Av2d9U1D9rq/wDFkfjC/wDhd8O7j4peLPj38f8AVf8AgnZ/wT/8SfB34tfEH9ne fSdd8d6PqWsWHwt1rxb4n+JHhnXPFNwfDF58TvB3h+38WeJLDxZ/wgHiDX7zRtWmj+0f2Hfj j4M8Df8ACKfCafUfjB4O0m/+KHij9nPRfgn45+Bf7LHwb8O/BD4vaN8PYP2gLTwtf2n7NMre FYLr4n/DPWp/Gng+Tw3qvirw5ft9vsdauPD/AIynj0m6Mv1yyhh0nWxFbC4HNHiIe99cwOIr 1MFgcbKc1GvVc/rOX5dTqSdShipxw+YYTCZbis8x6zOcdrmGIxfMqWFli8ywlOjrCjhcRg6F LGZlhaMYOeGjDCuli8XieRxqYKMnl2LxOKo5TgYYL9e6KKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAr43/bt+L+qfAz4DWfj7w38OfBHxR8bTfG39nD4f/Dzw58RtUvND8HWPj/4 v/Hr4efCTwl4t1nWdM8PeKdX0u38G6v43t/Epu9G0O+1Zf7MMdgqXEiSL9kV+dH/AAVD/wCT cfh3/wBnv/8ABOf/ANbw/Z4oGtWvVB/b/wDwVt/6JR/wTo/8SD/aX/8AoZaP7f8A+Ctv/RKP +CdH/iQf7S//ANDLX6L0Uvm/w/y/q78rHyX4/wCf9Xflb86P7f8A+Ctv/RKP+CdH/iQf7S// ANDLR/b/APwVt/6JR/wTo/8AEg/2l/8A6GWv0Xoo+b/D/L+rvysfJfj/AJ/1d+Vvzo/t/wD4 K2/9Eo/4J0f+JB/tL/8A0MtH9v8A/BW3/olH/BOj/wASD/aX/wDoZa/Reij5v8P8v6u/Kx8l +P8An/V35W/Oj+3/APgrb/0Sj/gnR/4kH+0v/wDQy0f2/wD8Fbf+iUf8E6P/ABIP9pf/AOhl r9F6KPm/w/y/q78rHyX4/wCf9Xflb86P7f8A+Ctv/RKP+CdH/iQf7S//ANDLR/b/APwVt/6J R/wTo/8AEg/2l/8A6GWv0Xoo+b/D/L+rvysfJfj/AJ/1d+Vvyv8Aif8AF/8A4KofCb4afEP4 qeJ/hN/wT0fw18M/A3i34geIU0/4+/tK3F+2h+DNA1DxHqy2Nu/7NMKT3jWGm3AtoXliWWYo jSIGLDg/B3/BUr9m7xD+zL4V19/2eP23/h78N9c+BOh6u83hX9gT9rHWPhr4H8Eal8P7W9aT w3450b4LReCdV8D+GtBnLaP4r0qaPwtfaDZW+r2MiaTLEw+5f26P+TJf2xf+zWP2g/8A1Uvi 6vlL4U/8oQ/ht/2ir8Hf+sj6dRr3+/5drefzfyGknbzdtH6evc/QX4Iw+Fbb4L/CG38C63P4 l8EQfC/wBD4O8R3NvLZ3Ov8AhWLwppKeHtbuLSa3tJrWfVdIWzvpbeW0tZYJJ2ikt4WUxr6f Xzp+x9/yaT+y3/2bp8Ev/VaeGa+i6ZJ8UftifD/xd4g8Qfsg/FDwno+ueJo/gD+1d4T8e+Lf DOgWs+pX954K8afD34l/AzX9eg0e2P2nUpPAy/Fm28aXaWqT3cGgaJrs1raXkypbS/Mf7aX7 Fn7RH7Umqza9oEXwS8I3vxK/Z++Mf7IvxZsNY+JHj7VIPC/wl8f/ABc8CeL9C+KHgHUrL4O2 jeL/AB9B4S8G6gmqfDPX9I8D6DZeI/FUNpbfFLV9M8KjUfE/650UUl7KVKa96pRx+Ox1OUtW lmOTUMhxmEaVk8NWy6GKp7fWKc8xxVWlXp1YYOeFupOdSUZczg44PAYJOGjUMsznGcQYGqm7 tV6GbYqni1JNQm8FhaNSnKg8XSxX8/Wr/wDBID4j6n4w/aq07Rte+EfgHwL8dfCv7bdq/wAR fDuteM734nfFzWv2r9f8NeMvAWg/G/wR/wAIVofh2w8I/s8eJrLxJ/wjF5pvxF8fahrVtrMl 5pOk+A7jVfEFpqPr+j/sjfH+28e/DXVviLoXhKLxv8Wv+Chfhr9sH4qS/CbxD4o8W/DL4SeB vgb+zZpvwu8PaDF498V+C/h5rXiHXfHGteFPCVo9pP4L0AXEfinxDa21tdab4YvNVv8A9pqK eGbwqy9Um7ZZg8qwOD5/edOhk2d4PiDBLs5/2nl2Aq15tOVenhlTlb2uIlVyrRjXpYijKKjT xNXOq1SMFyvnz/K6uUZklL45Qnha1SVCnUlOGGq8nsYxo0qVGBRRRSKCiiigAooooAKKKKAC iiigAooooAKKKKACiiigAr86P+Cof/JuPw7/AOz3/wDgnP8A+t4fs8V+i9fnR/wVD/5Nx+Hf /Z7/APwTn/8AW8P2eKBx3XqvzP0XorgNb+LHws8Nanc6L4j+JXgDQNZsvJ+2aTrfjLw7pWp2 n2iCK6g+02F9qMF1B59tNDcQ+bEnmQSxSpujkRjz95+0J8A9OSKTUPjh8ILGOaZLaGS8+Jfg u2SW4kDNHbxNNrSLJNIqOyRKTIwRiqkKcAj1+ivK/wDhevwR/wCix/Cv/wAOF4R/+W9H/C9f gj/0WP4V/wDhwvCP/wAt6APVKK8r/wCF6/BH/osfwr/8OF4R/wDlvR/wvX4I/wDRY/hX/wCH C8I//LegD1SivILX9oT4BXzXC2Xxw+EF41pM1tdLa/EvwXcNbXCEh4LgQ605hmUghopNrqQQ VGKt/wDC9fgj/wBFj+Ff/hwvCP8A8t6APVKK8r/4Xr8Ef+ix/Cv/AMOF4R/+W9VIv2hPgFPd XFjB8cPhBNe2YRruzi+JfguS6tVkAaM3FumtGaASKwZDKihgQVyCKAMT9qmxtNU/Zg/aP0zU IEurDUfgL8YLG9tpM+Xc2l38PfEVvcwSbSrbJoZHjfawO1jgg81+dn7Kf/BM39jbxn+yD+zb deJfh94+1JfFn7Nvwdn8Qaef2jf2lrPQ9QGu/DDw7JqtmfD1h8X7XQrXSrsXU8H9jWWnW+kw Wkn2G3sobNUgX7v+OvxC8A+M/wBnX9oy18H+OPCHiu5svgX8VZ7y38NeJdF12e0gk8Da/HHN cxaXe3UkETyfIkkqojP8qsW4rhP2Xfiz8K/h1+yP+yJpPxB+Jnw/8Cardfsu/Ai8tdM8ZeM/ DnhjULm0Hwz8NWxuoLLW9Ssbma2FzBPbmeONohPDLEW8yN1AVrZWvu9v+3bH1/4b8O6J4P8A DugeEvDOm22jeG/C2i6V4d8P6PZqy2mlaJoljBpmk6baq7O621jYWtvawKzuwiiUMzHJPIfF v4peH/g14HuvH3iez1i/0ez1/wAD+HJbbQbeyutTa+8feOfDngDR5Uh1DUNLtTa22s+J7C51 N2vFmh0yG8mtYLy6jhsrjmf+Gmv2bv8Ao4P4If8Ah1/Af/y/r8SP+Dgm5+Ff7TH/AATl8TeH fhZ8cfAev/ETwN8Zfgf468K+GPAPxK8N6j4j8SXN347sfhpqVnDZ6DrU2oyWelaF8RtV8VX8 6xNBp1t4dfVLl4IbFriEez6iSu1vuv0/zX3n9E1FeD/BXxr8CrTwx4J+EHwt+LvgDxw3gXwT oPhnR9N0X4h+G/FviWbQPB+j6fodvf30Wnavf6jdulra2zX9/Kj7p5fMnl3y5b3igQUUUUAF FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAV8d/t0fB24+PHwKsvh1pPxU8L/AAb8 XP8AGr9nTxx8PfGvjPwvN428Nj4i/CX46/D/AOLHgrw7qvhK08W+BL7xBa+LNe8E2fh2XTtO 8WaLqDx6k8lndedEsb/YlfLH7V//ACAfgn/2dP8As6f+rI0qga3Xqj5d/Zm/YC+DdpfftGeI P2ndI/ZX/a6+P3xA/aG1Xx78TvGsf7NvhXSLXwLq2ufCn4Rw6N8M7HRfHnib4x+J9IsbDwjY eHfGtvZ6h41uBIvjo39vZW0F5HJcfHP/AAVh/ZB/ZM8L/DCW58Nfsvfs7eHbiD9m39vvX4Z9 C+Cfw10maHXfCf7JHj3XvCutRS2Hhm3ePVvDOuW1trXh/UkYXmjatbwajp01teRRzL+tH7Pn /JWv26P+zp/CP/rEv7HVfEH/AAV9/wCSVXP/AGav/wAFG/8A1jL4iUW6fnqNXUlr/L+KX/A9 bH2//wAML/sS/wDRnf7LH/iPnwl/+ZGj/hhf9iX/AKM7/ZY/8R8+Ev8A8yNfU9FArvu/6/4Z fcfLH/DC/wCxL/0Z3+yx/wCI+fCX/wCZGj/hhf8AYl/6M7/ZY/8AEfPhL/8AMjX1PRQF33f9 f8MvuPwi/YH/AGOP2RNZ8T6tFq/7K/7OGqxXH7H37JHiiePUvgd8Mb5J/EviD4uftt6fr3iK ZLrwvKsmu63YeG/Dtlq+ruG1DUrTQdFtry4mh0uxSD9Nv+GF/wBiX/ozv9lj/wAR8+Ev/wAy NfLH/BPX/ka9Q/7Mh/Yx/wDV0ft61+p1A23fd7L8kfLH/DC/7Ev/AEZ3+yx/4j58Jf8A5ka/ Mn4D/scfsiXn7WVlY3f7K/7OF1ZXw/4KUre2dx8DvhjPa3i+C/2kf2Q9H8HC6t5fC7Q3A8J6 Rr+u6X4ZEyONB07WtWsdL+y22o3kU37u1+WP7P3/ACd7pH/eU/8A9ai/YtoFd9395mfHj/gm teXPxCtfiL+xNrP7NH7JWoa5+z78Zf2cPijo8n7LEPibRfGvgz4u638PNdbW7a2+GfxS+Bhs fFnhifwEbXR9R13/AISu0itNc1COGxt/Mm+0Q/tq+Nvid/wTy/YTX4r+DPFnwV8Q+E/2V/gd 8MPAtzovxR+BHivxv4h8feINOvvC3wv0K7s/E2iftAeALXwhpes32qaPJd6fcaB4sudOc315 /at8siW0X6z1+HX/AAcMeCvh78QP+CbnjPw18TP2irX9nHw3N8QPCGpQ6peaSdYg+J+uaJp3 ibWND+ERhGsaMLVtf1Gxh8SJeNJerG3hERHT5vP82Aeztv0BO7intdfofemmfD39qbWtN07W dJ+N37Gmo6Vq1jaanpmoWn7FPxJmtb7T7+3jurK8tpk/bhKy29zbSxzwyKSrxurA4Ir5I/b1 +Nn7SH7CP7MXjT9pXxX8R/2OfFGm+ENf+HGhr4ZH7H3xH0G71qTx38RvC3gm6XTb6X9tLUle +0bSte1LxOll9jb7fBoc9q89lHK99bff/wCyJpXhvQf2Vf2bvD/g74jWfxf8JeHPgZ8K/Dnh j4q6fpkujWXxH8P+H/BOi6No/je30qfUdWlsE8T6fZW+sfZm1O/8trsgXUy4c/GP/BZf9l34 fftXfsTat4M+JU/xCi8N+DPi38GPiLcJ8NZZRr0lpZ+O9N8G+JJ7iztfD/iW/wBR07SPBXjb xR4gNtp+mtdW+p6RpmqbpYNPntLoBatLzS29P6/4dn2l8MvBHx40LxGmp/EL4ifs9eKPDTad cxrp/wAMv2bfGXwu8RveT+S1ndJ4r1v9pf4rWB06NVl+06ePCrS3u+FotSsxCwm+ha+H/hr+ 13+yj4W8M+APhh4c+Jvi/WIvDmheFfAehXfiH4dfF271vVI9I0+w8PaXc65rFx8PrK3udUvl t4JdT1OdbSGa7lnupRBGzBPcvir+0d8FPgjqGlaV8U/Hth4Q1DXLObUNKtrzT9cvWvLO3nFt NOjaTpd/GipORGVmeNyeVUrzQL/gf8D+upnftEftE+GP2cfDHhXXNc8J+PfiDrvj/wAeaR8M /h98Pfhlpmhan418a+NNZ0zW9dh0jSB4q8R+DvClitr4f8NeIddv9R8S+KtB0u30/SLlReSX 0tnZ3XzH8NP+Co37NHxd+Inwn8CeArT4maxpnxhh+Htn4c+JT+FNOsPAGl+Nvin8KPE3xs8D fDTxH9u8RW/jey8Zax8OfB/iDWpZrDwTqng7SLmyXRda8W6drV1aWE3if7U/7bvh3x7oV/4D +Efjf4J6v4D1Y6HaeNJ/EPxj/aa+B3xD8V+GNVsfF9t4q0bwF49+DHwxk8Q/CDxN4a1iD4f6 1pXi9NS8Y2vjHQ7vxj4TvvD3heRLHXL78t/2dfhp4b+E/wAef2cfiN40/aI/Zw1u6+EjfAY6 j8YfC8vxW0Xxp4Y+G/wq/Zz8Y/B7xR+zP4M+Gdl8BNC8I634B8W+MvEqeNT431DxF4Wvb1rr VdX1DwVZeILHRI6WCvUr1o4nSj/amVU6NSypcuBrQrUc2jOEm5zeESp5jRxsLU2o1MPHD4zF UcJlmfXikoUZujrXhkuY4iME3UjVzOE6dTLKaqQjOKddTp4atg+WLjGUpSxdH22JxfD/APWf RXz54S/aO+Evxh8N/EG6+Dvjyy8Vah4M8Oz6hqUllp2r2raVNe2GrSaPM661pdlFP50+lXbI ka3Cg2zCdFVkD/zA/szf8FRv21Pifpv/AATd+HfiL4uy3fxEufiB41n/AGwteHhTwNBdePPC PxP8B2PxQ/Zj0yeytfDUdh4ei1PwR4kn1F7vw1baJcX03giZJ2mjuruMYLEQliKuFhGUq9JZ dJ00kuelmOIxeHVWMpNQ5cK8JOpiYylGq6c4fVqeInzwhq8NUWFWMbiqHPi4Tk3rTeEwTxl5 xtflxDdPC0JRUovFVqMKrpU5+1X9gNFfx8W3/BTr9t7w7J8ONR8S/Ge5vfB/xZ/ZW/4J1WGl 6pL4S8B295o/7TPxp1Twh8QPGWpRTW/hSOCRPiv8J/DnxstbrTJ1GmaNc6HaSeGbPTLqSJ4v 7B69CvhqmHniKdRx9phcxzLLK0E23CvluJdCctUl7PE03RxmGd1OWFxNCdWFKpKVKPHTqxqx hOKahUoYXE0pSsvaUsVhqdZSjG/NajWlWwVSUoqLxWExKoyq0Y061QooornNAooooAKKKKAC iiigAooooAKKKKACvlj9q/8A5APwT/7On/Z0/wDVkaVX1PXyx+1f/wAgH4J/9nT/ALOn/qyN KoHHdeq/Mh+Alxb2nxT/AG7rq6nhtrW2/ah8K3Fzc3EqQ29vbw/sRfseSTTzzSMscUMUatJL LIypGiszMFBI/OL/AIKf/Fj4e/F74b3Ol/BPxHD8e9Xj+CX7b3w0vdD/AGfLHVfj3r+i+Nfi f+y3448E+A9H8SaF8HrHxtq/hiPxD4s1Cx0C31bxDZaZotrqN3bw6hqNp5qMfTW8NaV8Yf23 fjL+z74/t11b4Oa98ZfiX8avGngq8Cv4d+J3iT4Rfsi/8EwvCPgjwR4409w9v4n8B2p+NHiH xxrHgvUVGneIfEHhDwhPqMGqaLpGtaZP4n4T8GarrHw0/wCCoHjP4ieOtJb4t/sg/tHfEvxP +zz8Z9K8OjwfB8BLXwB+yz8FPid4b8PeA9HfV/EU3hb4SW17f6hY+P8A4cQ63d+GfiJoGseM rbxbaagfF2seaUU62IxGHXuvD5TiM2lN/DKnhs0yTKpUYpa+0dTO6NVNpR9nRqK7k0k6r9jS oV3eUa2ZYXLIxW8auIy3NsyhUl3pqlk9em0ry9pVpWTjzNfvLFNFOpeGWOZFkmhLxOsiiW3l eCeIshIEkE8ckMyE7o5Y3jcK6Mokr+Zb4T/tU/H79kz/AILP+I/2W9S+E/jLXv2Zf+ChOi/D f9ovwj4e0mG51jU/gN8YviL4CvpviZ4iM8jJp9h4a17xv8Nvidq/xF8OXE9o8FpoOq/ELQGl vdI17RfFn9NNH9f1+foJq1vNX+8K8u1z44/BTwx4ysPh14l+MHwt8PfEHVWhXTPAmufEDwnp PjLUmuFie3Ww8MX+r2+t3jTpNC8It7GQyrLEybhIhPDftbeO/Enw0/Zt+MXjXwhqi+H/ABJo /g29TS/FUlvbXkPgqbVZ7bRpfHtzaXsU9ndWvgO21Gbxjd295b3NrNbaJLHcW1zCzwSfk78R /wBkXwlY/tgfDP4GfBXW/FfjCx3/AAe8bfG/4WarNrt/8FvB/wAA9Lf4o2nxe8UftR22p+JN S8J/tMfGn9sHWNWk0Lw1qHxW8JeJPiJpl74X1Pxvp+u6VYaLPqVwQ9/E4LD7fW8XTwzmk5ew hOM51cVOC1lh8FShUxmOlF81DAUMViYxqyoKjUU/cw2NxG7wmEq4mNPROvUg4QpYaM5NRhWx dWpDDYRSv7bGVcPhlaVeLX05/wAE7Y9Yk8V+Nzf+D/iH4YTwh+zR+y98JdZl8dfDXx/8PYJP H/gX4q/tl6z4t0PQbjxz4b8PQeLIdE0vxx4RvbrW/CsmteH3h1/Tjb6rM0xVf1Qr5D/ZHN14 ej/aE+DcGraprng39n/9oC7+Gfwz1DXNSu9b1e38B658G/gz8Z7Lwrda5fT3N5q1n8Odc+LO v/DTw/PeXN1qNp4X8HaJpWr3d5q+n393N9dOxRHZUaRlVmEaFA8hAJCIZHjjDORtUySIgJG5 1XJAN/ovyR5v4++M3wf+FMulwfFH4r/DX4bT65KIdEh8feOvC/g6XWJmk8pYdLj8Q6ppz6hK 0v7sR2gmcyfIBu4r85f2fNWJ/a41u9m0HxvYaD4D0X/goL4j8QeM9W+HvjvR/h4+ifGD48fs o+OPhpqPhz4j6r4cs/AfjW38XeEfCHibxBp3/CGeItfdNO0W9mvEtTGqt8E/tGeDNP1D9iTw V+1FpXxJ+IEP7Vfxc/ZQ+J/7UXjbTvht8R9H+HnxE8XeIvEfw48N+Jo/HnivXLz4g+APGPiT 9mD9iW68V/2NB+z1omneP9D1Dw7rOkaJqPwt8V+Jru4l1P8AVD9lyy0j4b/HXxn8Kvhxd20n wi8Z/s7fBT9o6y8L6Jpp0Pwn4C8fePPEXxE8L+KdW8I+GHtrP/hBvCvxqt/Cun+LLLwNp9np +j6Z4x8KfEXxFHptrrPi7XXnKN61KvVWioVqNOUfibhiJ46lRqXjdJTq5ZjYpv8AdT9m6VGt VxmFzbCZY6sfYywkZXf1uli5w0acJYKWA9rGV1yvmp5lhKkFCcqsYyc8RRw9GrgK2P8AY/8A htz9lD/oufgj/wACr3/5Cr8jP+C6fxS/Zr/ad/4Jg/tI/Dvwf8SfA/i/4gaZaeB/HXgHS457 hr5dd8IePvDeoanNpXnWscQ1Obwa3inTbbdIgf8AtB4tw8yv6Gq+PP8AgoH/AMmV/tKf9ks8 Qf8AoMNAla69V1815ev9LXk/g5+0l+x18GfhD8K/g/oHx58G3GhfCj4b+B/hros9xdXhnm0n wL4Y0vwvp0sxFiAZZLPS4XkIAG9mwBX174D+IPgv4n+Hbfxb4A8Raf4p8N3VxdWtvrGlvJJa S3FjMbe7hRpY4n3wTK0cgKABgcEjmuyooEFfD3j3x94s1P8A4KB/s9fBa11/XNB8DaP+zr8e Pj1rul6beXWnaf4+8UaZ4t+Fvwq8L6Trb208S61o/hLTfHvinxBPoN0k9gNev/Cmt3ELXuk6 VNb+t/Cn9qb4M/GyHxrffDnVPHGqaF4AuPEFrr/jDW/g38ZvBHgG7n8Ka3rPhzxIng/4heOv AHhvwP8AEQaJrfh7WLDUpPh/4g8Tx2slk0krrBLbyy/mT4r/AOCgX7IPxi8UfDH4rzfCn9p/ Uvip4R0bU9M+HHwn0zwX8O4fFnxy+AP7THwj8ZeP7nXbnSNe8cSeEbz4MeLfBPwO1f4if2d4 r8YfD/4i6Z4i+F+kaRfeHLTV9Sh8JeJs1VVKrQxcnTlhcNRr18Qqk3Sw9SGZZZm2XZRUqYnl nCnTjmsqWY0p2k50cox1anGdPB4mVLX2U6lPE4dRnCtOUaSnGCqVaDwONwGLzOl7CUoKcquX qpllVVZU6eHqZthPa1KdSvho1cT4zfGn4yab/wAFA7ibS/iV8QtJ0vwH+19+xX+zn4d+F+ne Kr+2+G3iX4UfHn4IfEHxl8U9U8Q/DqP/AIkfifX59dLaxY+MtTsbzxF4Xh+HFrb+G9Z0TTB4 lt9SraX8S/22bvwb+3H4Q8JftAeD7v48WP8AwUz+HPwa+H3ivX9Z8IfCDwhonw61z4Y/s3+K da+Hnwu0r4z2H7SGh+GNTu/DOseKbTRNKtPCPxb1rUvFmp6t4t03wTrGp3txpsf6b/Cv4bfs i/EfR/gb+1H8OvhJ8IJ2T4S+CZ/gf8Uj8OPDOl+K/C/wq1fwwZfBmk+GtZvNIg13wtpNp4Z8 SXmn6fo9vPZDSbLWtX0uGG3i1LUYLj0TxR+zv8A/GmheOPDXjL4MfC7xT4c+JPi2x+IHxB0T xF4G8N6zpXjLx1pVjoenaX408R2WoadcW+reKtLsPDHh2103xDdxy6tp8OhaQtpdw/2fa+Va w9TLZ4vD13VdSlWxcJRr2w9Sg45zwRjJUKkZKvClCpDhfPq+NowiqMcXxRj8LGnOg8RiMTi6 9PG08JiaDpqFTDYCXtKf7+nXccn4vwjxMbOj7RqpxDkiw85O9Shw7g8TN06iw+Hw/wCa37On 7R3ij4nfFD9im9uvEfxO8U+Ev2p/2aP2n/B/xQ8N/EXWvDeoXOm/Eb9mr4heE9MbxpAPhz4T +HHw4H2y78S/EXwVeeLvAnw88DWvjvQ5/h5qd7pNrLpVhaWf1j4R/wCCcP7FPgPVtL13wj8C dF0TWdGT4PRafqdv4n8ey3kUfwC8AeJPhd8I0mnu/Fdw96PB3gPxb4g8PwC9Nx/a0d+t9r/9 q6pZWF9a/C/gH9tf9hrTfiJ4X8ffDH4O/HC18WeDfhl4R+An7KnwQ8IeAfhj4d0Hx38M/i18 RvH8EHiH9nPwhZ+LtE8N+GbDxbrH7O/iOLxI/wAUvEfw01DR/CHwm026HhbQ7C+W68R/rl8E PjJ4F/aF+Enw++NnwzvrzUPAvxL8M6f4p8OT6lp1zpGqR2d8hEljq2lXarc6Zq+mXcdxpuq2 EwZ7PUbS5t98gjEjVGNLEYRVqdOE4QxeJjiZxoxjCFd57nWb5VRnJzqSdfA4XGQnToVZzrZP WlVy6Lg8KpScva0K08LXnU9rLCYZSjOpKU62HeXZZhqlSVPlhFYfESwlGlCuoQoZxDB08zpq ftJKn843n/BNz9ifUPCml+CL74FaTdeGNEf4AyaRps/iz4hSNpsv7LtvqNn8CZrO/bxcdSgn 8B2mr6paRTpeCXxDa391b+LH16GVkP174S8KaP4J0K28OaCdYbTLS51S7hbXvEviTxfqhm1j Vb3Wb3z9f8W6trmvXUQvtQuRZW11qU1tpdiLbSdLis9KsbKyt+koqpVJzdWU5zlKviKuMryl JydbF16dClXxVVtt1MRWpYXDU6ted6tSnh6EJycaVNRlQguS0Yr2dGnh6dopezoUp1qlKhCy 92jTqYjETp042hCdetKMVKrNyKKKKgoKKKKACiiigAooooAK+LP2tP2jfjR+z3dfDiX4e/Bj 4WfFvTfiV458F/C3w9o/iD4+eLPhl8Sdd+InjHWLqEaP4S8Iab+zv8T/AA3rOkeHvCVhq3j7 xFr+t/EHwmmmeGvDnie6nsFi0mGfUPT/AIqfFP4oeC/GHhvwv4M+GfgPxjF4rtZo9Am8TfHH Sfhvruua/YW2panrOh6B4XvvBviC9119I0GwGt3dzp91K8di13NPZ29vYS3Mn53eJPGfjDUv jno/xO+JN98LNe8WfsaXXxb8f6z4I8Q/tnfAnQ9I+D+lfG3w9ZaBpmp/E7R9I+B+iat4a0rw N4LTW9F+HvibxfdWGq3GleLPEVz4h1/xNLdW89rKkliMNzu1GlUWLxSbioVsHhJU6uMwspLm rUZYjDOpGniqcPZ4SajiK8vZw9jXrlk6VZQjzValOWHw7V26OLxFOpDBYiUdIVaUcXGjTqUG /a4iFSVKgozbxGH9P/4J/wD7dfiv9sbxZ8TJ9W1X4Gaf4Ttv+Ep1TwB8OvDf/CxtK+OHhnw3 4Y+Lvjj4YWes+M18VWkvgv4k+HPFFr4VtNXn8ZfDy50G18CeK7u7+Guv6BqOqWv9uH9Rq/Bj 9nLwzpH7OfxO8GfErwl/wrPxbJ8WPAfjvwZ+y74Q8V/tx/AmTwvZfC7xf8S9T+OnjrQvgQPC vwK8NeIPiXpE3izU4dQn1zWNe+ImqaT4a0fQ9Oi1WC1tru51D9dfBfxF+I/jj4Rn4gaR4C+H 934k1i1g1XwLoekfGe28SeA/GPh/UINOvNH163+Kfh/wNqFtDpurWV3c3dnc6d4W1yCWGC1l hmmhv1mt7pxksHglUi1iqNCWHx6s37PFU8Xi4UadWezxLwVPDvExbk4YpYikq+L9i8ZXzm/9 rxjjKLw1atCvgGmvfws8HhHUlTjZNUFjZYmGHlywdSgqNadOhOrLD0vcq+WP2r/+QD8E/wDs 6f8AZ0/9WRpVfLX7af7Qf/BSb4S/s0/Eb4hfAL9kP4U+NPi34dn8DP4S8K+H/ix49+NWq642 pfEXwjo+uWMPw20L4K/DnVNet38N6hrDahd23jbw+vhrTkuvFVzdyWuiT2tx8ofDj9ob/gqV 8XNI+ANr+29+wf8AC/8AZ50O6/aU/Z+1Gf4g+F/j7pWoX5lPxB0p9M0q2+C9tD8QNdtry4nI h1KTXviJoo0yFDcRwahLJ9iiV+n6P89jSK1T03XVeT/U+79E+C2jfGX4hftkxyeIvEvgLxv4 G/bE8JeLfhl8UPBE+mW/jL4eeLT+wf8Asm6DLq2kJrmma54c1mw1PQtZ1bQfEXhbxXoWveFf Euiald6frGj3P+jTW21pH7G3ijXdQ1WD41/F/wAOeNPAniHxhp3j/wAc/D34W/Azwj8DtK+N vjDRo9At9I1z9obWdP13xn4j+J8kFr4X8O2eraVp2p+C/Dvi3S9C0nw14w0TXvBltN4ZufmH 4k/GP9un4V/Ej9t3/hjj9jfwX+1Fd3/7RvhmW51HxL+0T4c+Ec3hfX4/2Lf2QVit7nwh4k8O RReKtIeySC4Fzpnj7R9RkuppLIafGkKXk9D9gX9qn/grL8bvB/xS1T9qj9hv4U/Cfxf4Y+JD +GfD3h7VPH/j/wCDNvc+HYPDujXh1LSBqngb442vjywn1O7vkHi/Q/FNppDyxyaXDpiTafNc TidpNq6k4OnJq6bpynTqSpt9YSqUqVRwu4udKnJrmhFokm1FOzSlCpFNrSpGnOnGok9pxhVq wU1aShUqRTUZyT/S39ov4RXPxp+Fmr+F9C1eDwv8QdGv9G8efCPxrPDLPH4I+LngbUYfEfw+ 8S3UFuVub3Q4NfsbbT/GGiwSRDxT4I1HxL4Tu3Ona7eRvf8AgF8XbX44/Cnwx8Ql0efwvrl2 NU0Dx34JvbhLnUvh98TPB+rX3hT4k/D7VLiNI47m/wDBfjbR9c8PS38Ea2erR2EWr6a02m39 nPL1nw/1T4g6voH2v4l+DvDXgbxL9tuYjofhXxxe/ELSv7PQRG0vP+Egv/BXgKc3NwzTCax/ sEJbCNCt7c+aRF8vXxH7O/7VdrqyhbP4QftkX9ro2tYCx2HhL9qzwl4XEHhvWJTuCWtp8efh R4X/AOET1C6mMFhb+PPhD4C0yziufE3xUuXugk+w9d0LRfFGiaz4a8SaVp+veHvEWlahoWva Hq9nBqGlazourWk1hqmlanYXSS219p+o2NxPZ3tncRyQXNtNLDMjxuyn80tR/wCCbFlH480b xf4c+IPw2e/8MRaHY+CPih8UP2VPgv8AGf8Aav8AhlonhZNng/R/h9+0142t5NXlXwOjvD4O 1v4p+Cvir4p0+NLaXV9e16/W9vr/APUKihaTp1FpOlNVKU1pOnUScVOnJawmlKSUotSSk1ez YPWM4PWFSDp1IPWNSDabhOL0lFuKbi002lpoedfCr4W+Evg34J07wJ4Mgv10uzu9Y1fUNT1r UbnWvEfifxP4m1e98ReLPGHirXb1nvdc8U+LPEep6nr+v6rcsGu9Sv7hoore2EFtD6LRRQB+ cXxW/wCCeug+NNWU+Ftf+FcngRPGGu/ELSfhN+0J+zX8Ov2m/Afw08feLdTu9a8ZeNPgeviu /wDDHif4X6z4r1m9uNb1PTk8SeIvBdprMs99ofhHSVvdRt736v8Agt8D9J+D1t4m1K48S+I/ iJ8RviBqGnav8R/ij4yGjp4l8W3ukabHpOh6dBp/h7S9E8N+FPBvhbTUex8JeCPC2j6X4f0R LrVNUe3vvE/iLxR4h1326ihaJxWkXN1HFaJ1JRjBzaWjm4QhFyfvOMIxbtFJNtyab1cYezi3 q4w5nPkT3UOdynyrTmlKVrttlfHv/BQFXb9iv9pbYkkhT4UeJJWWKN5XEcMKTSuEjVnYRxI8 j7VO1FZjwDX2FRQCdmn2dz5o0n9s39k3XdV03Q9F/aN+DWqaxrOoWelaTplj8QPDlzfajqWo 3MdpYWFnbRX7S3F1eXU0VvbwRq0ks0iRopZgK9W+JfxV+HXwc8NHxj8UPGOh+BvDAv7XSv7c 8Q3QtNPGo3yzNZ2hlIOZrgW8xjTgsIn5GK9Br4d/ZV8feLfif8a/27Nc8R+INck0z4e/tE6N 8BfA3gu7u7pNC8KeGPh98HPhz4rn1ex0Nrg2cWseN/FXxL8R65qWurBHf6zocfhWymnfT9F0 yK3Uf3tSvQgpSqUcuxGZTinyt4XD43LMuqcknKK9q8Vm+CjGPNF8sqlTmSpsU2qdOnVk7Rq4 yhgafXmxNbDY7Gxg7JuMfqmW42pzuLjz0oUm1KrFn5K/su/ETwF+zp8WPiD8SPC/j/8A4J8f C+y8XeBNJ+HGp+DPhF8Y/ijH4H+Ifi6T4u+PfGmo/tO+PNC8SfDR9ek8a6H4R8S6Zo9p4Luf GniHXfE8tz4g8OXnxZ0DQNL8KX0Hlg8eeLL6b9ojX9f+PP7FE8X7U2kfDrQPjf8ADzQv22P2 stD16/1vwx4R+JEXiTx58Fv2koPAf/C1fgl4HvvHWv8AgeLw9+zdJaePPhpofw10zxpomkya HdeL9b07Xftj9mpP2mdRs/2yPFvwx/ak8ZfE74eaX8MNR8LeHv2gfjH4e8T+LfAPjz9qXwv4 2+KGrfFXx78APhVdfE2xPhP4Q+B/C154a+EWm2Xgfxrofwz1fxx4Sm1vQNM1+Pw/rV94l+Nf iL+0p+0R/wAMzfsqeM7f41fFrSPE/wAPv+CUfwY/a20nVtJ8eavp8/xb/aA1b4ofAfwdfv8A FFDJKfixYX2jazqGjX/g/wAXf27oOqXfxFudSudHl8SL4e1TT8MNh6WPw1LLpJxpVMLhKDVR tVKWX5jQ404kxEqU6aUlh8Rh+E80x2AjD2UqlDMchVGGVLA5fTyTfE154LFYjHKzqPG1KkJ0 ZcsJZhleJ4JyfDO7kpUcVhMZxFk+Bx0nKVTDV8tz2lWljvrWYRzr3n9oPx38GPiV/wAE6/hj +yRa/tWfA3X/AIoaF8N/hn4D8X+LvDHxg8S/AfwR/aPg3w3plhqutWXh/wCH3hVLbxH4dn1D SxFpnga80rw3oUPn2etxWmnT6PZ6UPvPQP2+f2cvCvwp8F6ZpHxp+DepeNLOPwrpWtaJ4t/a E8T+JV0zTbjVLK08U6o/xX13wJrXifxzrHh/RJb/AFfTP7a8N6ZN4u1OzttHvtT8OwXz6xZe z/tf/tSa3+y14I8A+L9J+Cnjb4wP41+LXwj+GNzZeFNU8JaRF4fPxP8AiZ4M+HsVzfXPifXt HmuNWlk8Ws3hjTLOzmsdV1exWw8Qaz4S0ueTXbb1/wCLvjbxH4W+AfxP+I3h3Rr2z8W+HPhB 418baF4f1SKyn1K18R6R4L1PXdM0bUYLC51TT5r2DU7eCyvIrK71GyknWRLa5vICksmmZ4/m wmfZzilOrRWPxeIzJUG8POeJwmCo5ji8LQVOdCSjUwmNpNV6c1UpLERjhsZh5RThll+CjOrk uV4e0HUwWGwuA9o24LD4jFTwWHr1XyT9nKFehUXslCCfs3Ophqq1l/J/4P8Agp4d8FWqeINB /al/ZO8L/Ebwh4h+D3iax8WeAf2i/EekeKfi38WfA/j/AOPWr+Nv2ndZ1zxt+y/8RfB/w8+J fi/wF8abjwhceDtW+F3xh8M6jp934m0W/wBRt4bDwbrmnfvv/wAExNR+CHw3/Zk+DP7KXgD4 8eA/jN49+EHw4ku/GVz4P1q61hZ77UfEU+reJ9Xtri/sNLv7vR4vFHiprGz1K807TLq9iltL mfS9OluGsrf8Z7P4kfHXV/h58WPCmm/tYftJ+Lb7wb+y58CP2p/Cvw58KfG/SLD44/FL4t/F r9krxL4l8dX/AIa+Iviv4p/DrxPY/CL4NeNj4S+PvjL4Q+EbjxZ4cTSdQtPDOjfDW68L6rpf grV/eLP9pv8Aal8XQ+LY/Gv7TWpa74D+N/wZ+LC/sveOv2f/ABx8GrTQdA+IvwT/AGTvh38Z NS8R/E7wPo3wD0344eAr3UPFcfivxlDZeIP2gEeKz1HSvh58Rvgnomi6taPqmteSymPEmAru EI5I3m2aVYK9GVTDUcVh69PCSjGm05YjC4/DYLD1MNhcHOjhMNg8qlQo4SeV5ZNOSzavkuZU 37/EDhgsIpe5OMKk8FVw0sVTjGouWhhMbh8ViqlKtXrUamKxdbGfWK9dY3Gf0kUV5F+z98Rb /wCMHwH+CvxZ1XS20PVPif8ACb4dfEHUtGZGjOlX/jLwho/iK804I7O6rZ3GoyW6B2Ztkali TmvXa3xeGq4LFYnB1uX22ExFbDVeV80fa0KkqVTllZc0eeDs7K6s7HPhMTTxmFw2LoqSpYrD 0cTSU0ozVOvTjVgppOSUuWS5kpNJ3Sb3Ciiiuc6AooooAKKKKACiiigD82Piz4ptPA//AAUd +Gfi/wCIMWrSeBPD37Cvx+1XwCNG8OeJvGWrnxhZfGH4LyfFNPD3hLwlpeu+Ite8RN4KPgg2 2neG9E1TxBd6auqRWlrJb/aUf8f7z4V65p/xnin+Kn7NPx58b2Xwr+K3/BQDxb8ZvE2h/s7/ ABa8U6Bfv8dP25vgD8U/2Q/iBPD4X1D4caj+0H4F8Er4V0D4veMPAHwx8Za7r+l+Afh3r2k6 hocdzYS6I39Ruo+GvDmr6poGuatoGi6prXhO6vr7wtrGo6VY3uqeGr3VNMutF1O80DULmCW7 0a61HRr290m+uNOmtprvTLu6sLh5LW4lifaqcNF4apldWL5qmV0M9o053nCdSWeZxmOayqe1 pTp4ihPBrHqhh54etSrQnhqGKpVaNanS9lpVqe1jiYtWjicdlOPlF8s4055TkccipwpUqkZU ZQrUpYnG1Y4ilXpSx1anUlSnTpVKWJ/j9+H/AMCvj1FNfaXqnwJ+MEniz4v+O/2c9Q+BfjSL 4GfE/R/DFtqvw8/4K2fGb9ob40/En7BrnhaTUP2WfBviH4deJ9E+KPh7wT8V9V03XLLwTe6P of8Ab3jTU9LuNRuP3/8A+CZ76i/7NuvYl87wSn7S/wC11D8HZAHEJ+DMH7S/xRh+Ha2BYKja KmixqnhtrZVsT4cXSRYD7GICf0BdEkR45EWSORWR0dQyOjAqyOrAqyspIZSCCCQQQaytA8P6 D4T0PSfDPhbRNI8NeG9A0+00jQvD2gabZaNoei6VYQpbWOmaTpOnQ21hpun2VvHHBaWVnbw2 1tCiRQxIiqo2oTVDCvCRinTjVx9WDaik55lUymdWr7GnGlQo4ijHJaFOnPD0qdGUMfmMKeHw tJ0aSjEP6xiMTiZKMKmKx2Dx1VxUpTUsHl+Oy5YdVqs6tepha0MbDE1YV6tWtLGYWniq1evW q1JrXr5Y/av/AOQD8E/+zp/2dP8A1ZGlV9T1SvtN07U1tk1KwstQSzvbTUrRL61gu1tdRsJl uLG/tlnjkEF7ZXCrPaXUQWe2mVZYZEcBhmCdmn2dz5l/Z8/5K1+3R/2dP4R/9Yl/Y6r6nqla 6bp1jPqV1Y2FlZ3Os3sepaxcWtrBbz6rqMWnWGjxX+pTQxpJfXsek6Vpelx3V00s6adpthYr ILazt4o7tAN3+5L7lYK8o+OHwl0f45fCrxh8L9Z1C+0MeI7G2l0PxTpAiOu+B/GegalZeJPA XxC8NtPmGPxP8PvG2kaB408NTTK8EOu6Fp8k8ckKvG3q9FAj59/Zn+LWs/Fz4Yw3fjbT7LQv i54C13V/hZ8cPDGn+eLLw98WvBLQWfib+yUulS7bwn4rtp9K+IXw7vbuOO41n4beMfB+vNGi 6oqj6Cr5bvfhz4x8EftTaT8V/AGkf2l4C+NvhZ/A37Qelw32nWK6B4q+H2j6nrHwg+NMNpfX dob+afS01z4L+OYtIt9U8S65Bq3wWunhg8MfDXVLi32/iN+1t+zV8I/FF14K+Jnxo8CeCvFl lbWd5daBr2rLaajBa6hAtzZTyQGNisdzbussRz8yMDQHofRNeC+O/wBpf4SfDn4p+Efgr4gv fHWofE3xvo0PiTRfDPgT4N/GX4omz8MzeIbbwovijxbrHwy8A+LtA8A+F01+6h0+48SeO9U8 OaJat5txdX8NpbXFxF5t/wAPA/2K/wDo5T4Wf+FAv/xmvyF/au+Ivwu/aU+L3gX4gWHjn9gj wbr/AId1P4baf4e+P8/xs+JOoftA/BHRfhf+0mnxEv8AWfh5JD8K4/C2sL8UPhVZ/wBmXPhG 0/4QO90HxL4h8QeF/E/j74geBrhXiKXvY/LKM1bCYjGqlj6qtGdDCSoV17enUn+5hOninhpS Vb3Z0PbRjyz5akHNcuDxtWP+8UqEHhINOUald16LlGpShevOl9UWKlegnONZUElUlOFCt+2X wF/an+Dn7S+tfG/Sfg54hTxfZfAT4nx/CLxf4p0y40jUfCWreMV8FeFPG2ow+Eta0jVdSj1m x0O38XWnh/WLqaLT3tvE+l63psUFxBZR31z9DxzQytKkUsUjQSeTOsciu0MvlpL5UoUkxyeV JHJscK3lyI+NrqT+Qn7OX7Rv7L3wm+Lv7a/jvxN+098DbjRv2h/2gfD3xR8Cw6P4uvLjULPw 5pXwC+D3wxuYPEcVzo9lDp2qv4i8B61NDb2FzqtudLl0+6a8juJ5rO28X/Ym+M/wD+BHxd/a i8b+P/2h/hvBo/x1+IcXxC0NZf2s/iZ8YzpBh8D/AA28C/2Jqmg+NfC+k6dfazIvgK41sfED z49at9L1Ow8BRaedE0G0vZnQtU+pQqP2cpcNZdj8VVd+X+25YHKZ4/LlBqMaTeKxGZzjepL2 KwP1a1WrVo+0daKh9ZlTbqRhm1bC0IW96WXPEY2OHxcpK7qONKlg41HCnGFSWK9vahSjKMf0 l/aQ/bb+Ef7L3ijwv4V8faP8QdbuNa0GXxv4p1PwP4dsNc0j4VfDO38Z+E/h7c/E74jzXuua PeWnhG38YeNtA0l4fCtj4s8VPG+p6vD4Zl0PQdd1PTq37PP7cvwh/aV+IXif4c+CdD+I2g6l pHhzVPHPhLWPG3h7StI0D4sfDvRPiP4l+Eus+P8A4dz6b4i1vVG8Pad4/wDCupaHLbeN9J8F eJbiG40jXbHw/d+HdY07Vrj8e/21fF/w9/ae8eeKtf8AC/7QX7JPhrSPij8FPEP7J/jWTxB8 bfFs+o+HPhXH8efAvxS8P/Fvw9Zab8HpbbXPGOq+G9H8YaZqPwyvr7RtN0TXrzwy0XxD1vTl 1Wa39f8A2ZPj14K8M/tW/Ef9or48/tL/ALKemf8ACX/BzT/hZrFp8OvjZ8VviXY+M9d8MfET Vtb8H+MPCHhj4u+GvtP7N/hKz8FXrW+u/CbwB458SeE/EXjjXdX8RalbS6lo+n+IdXnB3qxy 2Vf3PrEOIamOUkqbw/sHmM8ihGLcZ0nXw2HySdRzhialXE5vjsFKjRnhsRX4fnFqUFj1QXM6 NbIqeCaan9YhVnlsM6lJLm5/ZVsRncISX1elDC5VgcVTnWji6H9sfvhXgNr+zP8ACeH4h/Ef 4i3uhjXbv4n+Lfhl8R9d8M+IbfSNY8I6d8U/hPo0Phzwt8UvDum3elPfaR47bw/pnhbSb/Vk 1SW3MPgvwzdadY6bqUGpX2qY/wC1D+0APgT+yX8bf2mvCWm6Z45T4ZfBXxd8XfDml3F/PZaR 4qh0DwtdeJdLtpNStobi4trDVooYR9rgt5ZI4JhKkTsAp+Lof+ChPxQ8M/Gbwt+z78Svhj4A t/H+r/Gz9mfwdda/4P8AFHiK+8KXvwr/AGlfh18YvGGi+LrC01nRNP1LS/FnhzxD8FvFXhTU vD15ealp9zbCx8QwaoiX39l2pBxlXpwVo1Z4nKsDTlK0VLEZtmdDC5fRVR6Jyx9KhXk21HD/ AFeOMm4Rw/tKbrKVHCzr1VbDSw2bYirJNNLC5PhsNXzKc0nzRhGjj8Nh+V2eLljI4KnGtKvO lL71+G37Mv7PHwdTXYvhT8E/hl8OofE+nzaT4hg8HeDdD8PwazpdzPPc3GnajBptnbxXNlcX F1cTzW0iGKWWeV5EZnYlur/swfs3+ILD4V6Xr/wF+D2uab8DINNtfgzY6z8OfCWqWvwrtdGG jjSbX4fw32kzx+E7bTG8PeH5rGDRVs4rW50DRLqFEuNI0+W2+ZP+Cf8A+3PcftrW3x9m1LwN aeApPhd8V5NJ8DQWurTauPHfwO8UaZHrHwj+LDzS29sts/jrT7fWpJdPtkmtLGXTHhhu7oZl PkXxp/4KL+OPhP8AtQ+M/g1beCfhVrXhPwX8Yv2RfhANJvvHuq6L8Z/G1z+1SkNs/iD4feGR o+oaVr6fDK5u4tc8R6M8lqbnwjY63qkmsaU2mgXEVK0cLHBVKkpUvbvKpYWykqlKtiU6uWU5 RiufDYijVzCpT9nUVOpgMTiMTTrrDz+s8pK7WNnL3lhaeZVMVK6lzUaMEsxqxd2q9Kth8HCo 5Qc1jcPRoOl7ePsE/wBGfid8D/g98aYdIt/i18NPBfxGg8PyXk2iReMNA0/XY9Kl1BbdL6Sw W/hmFs92lpbLO0YUyLBEGyEGN7Uvhv8AD/WdP8HaTq/gvwzqmmfD3U9J1rwLp+oaLYXln4R1 fQdMu9G0XU/D1vcQSRaVf6VpN9e6dYXVmsU1rZ3U8ELpHK6n+fK2/wCC6/jSP+xodZ+AfhjT 28WfsY/Bf9pPwrqUfinWJtIu/iJ8UfiQfDl98KLuRrFJohp3gbT/ABN4z0bUkH2jWB4Z1WCS 2tI7dmr9Kf2Uf2zfiZ+0V8YPiD4I1r4YfDrwf4c8G3nxT0nWtFs/izBe/HT4Sa74A+JR8FeD tK+NXwe17QvDniLTbb41+E47j4neB/FHhWDWPCVnosCaVJrWtJqOj69qO8sPKFeWClCMazlm WKnR91KNTIcdicHia1a7UKdWni8JNYKpVcJYl1MJPByqPG4P25WvR9tKrdfVpYHBVHrOyzvB 0cZh6FPlv7WnXw2IUsTGlzU6XLiI4nkdCuoe3S/sKfsUz+Fx4Jm/ZI/Ztk8Hr4ku/GA8MN8F Ph0dB/4Si/0ceHL7Xf7L/wCEd+xnUrzw2F8N3VyYS9x4cVNAl36Qi2Yg8efsPfsv+OLL4mNb fB/wH8PvF/xc8C6t8NPG3xT+GXgrwX4P+K194I8QaTpnh3xDoFt46tfDk+r2VvrnhjRtM8M6 hNC/2s6Lp2l29tcW02jaLcad8YeMv27v2mPhj4k/akv/ABl8Nfgxq/ww/Y08efBKz+NWpeD9 V8eP4tufhT8UPDvhbxl4x+Inhqx1SCPTYX+E/g7xLc+Jtd03UJrj+19O8M6uLGS3lmtgvhfj T/gr/wDFDQNH1v4k6Z8LPgzafC5vgP43/am+GVr49+IviLwj42+MXwW0f43XXwu+G9h4PVdA 1KyT4jfGrwrZxfELwFoR06/S4TxH4W8Ozxi6vLy+tcaThiZ0KUGpSxtKdKMJRa58P/YscYoV VKP8HEZJSrLDQleOLoZdmGDw8atTLcXQo6yVanasnO9LE4X2VSE/eWIxOZxo0atGXMnGVPNM RhpV694rB4jH4HEYmdF47DVKv7y6TpWm6DpWmaHo1lbaZo+jafZaVpWm2caw2mn6bp1tHZ2N lawrhYra0tYYoII1AWOKNVHAFaFVrK4a7s7S6e3mtHubaC4e0uAq3Fq00SSNbzhSyiaEsY5Q rModWAJGDVmtqjm6lR1ZOdRzk6kpS55Sm5NzlKd5c7lK7crvmbvd3ucmHdF0KLw8YxoOlTdC MIezjGi4RdKMabjH2cVDlUYcseRWjyq1goooqDUKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigAr4f/aa8e+K7P8AaM/YR+DWha/rnhfw98VPi58SvE/jnUNCvbrS5/EOi/Bb4O+K PG2kfD+81K0mgmTSvEni2fw/rGs6ajFdf0XwpqWiXqTaPfapbzfcFePfFn4H+CvjJd/DLUfF X9qW2qfCX4hWvxG8Ialo09lBcpqP/CPeIfB2v6Dqaahp2p2mo+FfGngrxZ4l8I+K9Iltle80 fWJprC80zWLTTNVsZfMpUZQScqeKwlWLlJxjTdLFUaqrStGblGg4e2lTUJ+1UHT5Jc/K3aMo YiEpOMauExtFqMFOU/bYStSVGLcoezddz9iq8ZxnhnP6xTanSiz8Jv2n/jf8dLb9qD4xXejf tQ+M/wBnyPSf2sU/ZH0u+1DV31v4SfDD4E+IP+Cafin9oLWvjTq/wh1HVdE8J654i8E/FN4v ievjzUprDXLXTfDdt4Uk8U2nhJtR066+d/iB8Tv2pfC3w48TTQfHP9pzwJ8GH/Z+/b9/bG/Z M1zx18SfG2mfG3xBbfs9/DP9myw+DF18VNa8VarqPjjXvBvjD4ieIvir8WNF+DHxJ1TWLa78 GeN/Ceg+MfDken6VYeFNE/ouvv2NP2SNTuI7zUv2ZfgPf3sXw3Hweivrz4U+Cbi/i+FY0Kbw sPh5Hey6K90nhAeGbi48ODQVmGnjQbi40gQf2fNLbvBJ+xZ+yHP4e0jwld/syfAnUfC+geJx 400Pw/qnwt8G6rpGj+LPsNtph8Q6bYajpF1bWWqvp1laWMt3bxxyS2ltBbyl4okUKjTdCFWn CtPmeXwwFLE8i9pGosto4P8AtJUZVJwpY/DZxho8Y4OdGqrZrmGbZdip4mFXBZtgul4mnPEZ diJ4WnKnhKirYnCc6dPEuNXE1JYWdR0msRhMVgcUuHsUsbh8TVWXZdluMw06M/reX4jzL9oL 9rzxZ+z58J/2fvHf/CivHPxZ1X4weN/gf4C1yw8H6h4Q0SDwpqfxW8S+DPC832pvFniHRbif WpbvxRcf8Ito1vaHTtR1DTJbHxFr/hKydNVr3D9ojx94q8BfsyfHH4oeENOurPxt4N+BfxJ8 d+GdK1CCzur2z8UeH/AWs6/o9jfW1tLqWn3Fza6raW8F1Bbz39lNLHJHFNdQMrv0PxO+BXwa +NK6Knxa+GHgj4jJ4bN+dAXxh4e07XV0c6oLMaj/AGcL+CYWv20afYi58rb5otIA+fKXHR6z 8OPAHiK18I2Ov+C/DGtWXgHU7XWvBFpquiaff23hTV7LQtU8MWepaBBdQSxaXe23h3WtX0SC 4tFilj0vU76yVhb3MqNOZQljsDnOHov6liMxxuPlga9GUv8AhLy7G4ajh6OGpcnsXUq5dWhi MZRqNRqV5YiGGlXoRwyxFbny1rA18nqVr42jl+BwdPG0qy5nmWPwmKxFapiK06rrONPH4eWF
September 21, 2016 - October 12, 2016
AeroElectric-Archive.digest.vol-no
