AeroElectric-Archive.digest.vol-nq
December 11, 2016 - January 08, 2017
      At 11:09 AM 12/10/2016, you wrote:
      >On Sat, Dec 10, 2016 at 9:57 AM, user9253
      >There has been a recent discussion on VansAirforce questioning
      >whether or not the E-Bus should be fused.
           I've read it . . . and there are several pieces
         of spaghetti getting wrapped around unrelated axles.
         I'm updating Z-11 and working on the supporting narrative.
         Watch this space . . .
         In the mean time, please encourage participants
         in the VAF forum to bring the discussion to the
         AeroElectric-List.  Wayyyyy back when, there was a
         time that I tried to play electro-whizzy hop-scotch
         across a half dozen forums and it became totally
         unwieldy.
         If a Z-figure is being discussed, please bring the
         conversation here where analysis and resolution can
         be archived on the AEC-List and appropriate changes
         made to Z-figures and supporting documentation.
         Thanks!
Subject: Z-12 questions
Date: Dec 11, 2016
Building an RV-10 and working on wiring following Z-12 with 60 amp main alternator from B & C, and 30A backup alternator also from B&C. Planning on using the mythical 6-cyl P-Mags, but in the meantime will be setting up shower of sparks as I have that on hand. A couple of questions regarding switches. As I look at the endurance bus, I am trying to figure out what is an appropriate switch to use, I am looking at putting the GTN 650, a G3X display, flap motor, fuel pump, and landing lights on the endurance bus. While the 650 can be a large draw, that is only while transmitting, similar with the fuel pump and flap motor. Lights would only be for a few minutes on landing. But in total these could be a large draw for short periods of time, what is an appropriate switch to use for the endurance bus, typical toggle switches I see are rated at no more that 15 - 20 amps. I really don't want to use one of the pull switches. A similar question for an avionics bus, while I know this is not needed to protect the avionics, I have been advised it is a good idea so that there is minimal battery drain while starting the plane, after start you flip the avionics master to turn on the majority of the avionics. Some items like one display, and the engine sensors would be powered on with the main battery switch. It seems like this switch could be asked to handle a lot of amps, with radio, transponder, etc. What are your thoughts on an avionics bus for this reason, and also what is an appropriate switch to use? Bill Greenley Build an RV-10 in SW Michigan ________________________________________________________________________________
Date: Dec 10, 2016
Subject: Re: Z-12 questions
William, The EBus should be switched with a relay. The avionics switch is not a good idea as it introduces a single point of failure. I believe that you might be misunderstanding the EBus concept. It is designed to power only essential items such as in an electric ac one efis one com and maybe the pmags. The idea is that you can easily reduce the electrical load such that the available fuel is the only determining factor as to when you will need to land. Switching the master off reduces the load to the point that your standby alternator can power the remaining load till you arrive at your destination. You could then switch the master back on and hve your entire panel for the landing. Fuel pump and flaps are not required for cruise flight although they do draw any current when switched off, so they are not against the EBus concept. Hope this helps. I have an RV7 with Z12-8 from day one and it works perfectly as designed. My standby alternator is the B%C SD8. On Sat, Dec 10, 2016 at 9:09 PM, William Greenley wrote: > Building an RV-10 and working on wiring following Z-12 with 60 amp main > alternator from B & C, and 30A backup alternator also from B&C. Planning on > using the mythical 6-cyl P-Mags, but in the meantime will be setting up > shower of sparks as I have that on hand. A couple of questions regarding > switches. As I look at the endurance bus, I am trying to figure out what is > an appropriate switch to use, I am looking at putting the GTN 650, a G3X > display, flap motor, fuel pump, and landing lights on the endurance bus. > While the 650 can be a large draw, that is only while transmitting, simil ar > with the fuel pump and flap motor. Lights would only be for a few minutes > on landing. But in total these could be a large draw for short periods of > time, what is an appropriate switch to use for the endurance bus, typical > toggle switches I see are rated at no more that 15 =93 20 amps. I r eally > don=99t want to use one of the pull switches. > > > A similar question for an avionics bus, while I know this is not needed t o > protect the avionics, I have been advised it is a good idea so that there > is minimal battery drain while starting the plane, after start you flip t he > avionics master to turn on the majority of the avionics. Some items like > one display, and the engine sensors would be powered on with the main > battery switch. It seems like this switch could be asked to handle a lot of > amps, with radio, transponder, etc. What are your thoughts on an avionics > bus for this reason, and also what is an appropriate switch to use? > > Bill Greenley > > Build an RV-10 in SW Michigan > ________________________________________________________________________________
Date: Dec 11, 2016
My thinking on the ebus was that the radio has a very small draw when not in use, and the flaps, landing light and fuel pump have zero draw. Having them on the ebus would allow their use for landing in case of master contactor or switch failure, if not for that failure mode, the need for the ebus would be if both alternators fail. Wonder which is more likely. On Sun, Dec 11, 2016 at 1:33 AM, don van santen wrote: > William, > The EBus should be switched with a relay. The avionics switch is not a > good idea as it introduces a single point of failure. I believe that you > might be misunderstanding the EBus concept. It is designed to power only > essential items such as in an electric ac one efis one com and maybe the > pmags. The idea is that you can easily reduce the electrical load such th at > the available fuel is the only determining factor as to when you will nee d > to land. Switching the master off reduces the load to the point that your > standby alternator can power the remaining load till you arrive at your > destination. You could then switch the master back on and hve your entir e > panel for the landing. Fuel pump and flaps are not required for cruise > flight although they do draw any current when switched off, so they are n ot > against the EBus concept. Hope this helps. I have an RV7 with Z12-8 from > day one and it works perfectly as designed. My standby alternator is the > B%C SD8. > > On Sat, Dec 10, 2016 at 9:09 PM, William Greenley > wrote: > >> Building an RV-10 and working on wiring following Z-12 with 60 amp main >> alternator from B & C, and 30A backup alternator also from B&C. Planning on >> using the mythical 6-cyl P-Mags, but in the meantime will be setting up >> shower of sparks as I have that on hand. A couple of questions regarding >> switches. As I look at the endurance bus, I am trying to figure out what is >> an appropriate switch to use, I am looking at putting the GTN 650, a G3X >> display, flap motor, fuel pump, and landing lights on the endurance bus. >> While the 650 can be a large draw, that is only while transmitting, simi lar >> with the fuel pump and flap motor. Lights would only be for a few minute s >> on landing. But in total these could be a large draw for short periods o f >> time, what is an appropriate switch to use for the endurance bus, typica l >> toggle switches I see are rated at no more that 15 =93 20 amps. I really >> don=99t want to use one of the pull switches. >> >> >> >> A similar question for an avionics bus, while I know this is not needed >> to protect the avionics, I have been advised it is a good idea so that >> there is minimal battery drain while starting the plane, after start you >> flip the avionics master to turn on the majority of the avionics. Some >> items like one display, and the engine sensors would be powered on with the >> main battery switch. It seems like this switch could be asked to handle a >> lot of amps, with radio, transponder, etc. What are your thoughts on an >> avionics bus for this reason, and also what is an appropriate switch to use? >> >> Bill Greenley >> >> Build an RV-10 in SW Michigan >> > > ________________________________________________________________________________
Date: Dec 11, 2016
Minimizing battery drain during engine cranking is not a valid reason to have an avionics switch. Avionics use very little current compared to the starter motor. A better way to improve starter performance is to use larger wire size. An avionics master switch is an unnecessary failure point. Use an automotive relay located near the battery to power the E-bus. A small panel mounted switch can control the relay. Relays have the advantage of remote control and larger current carrying capacity. Search for relay part number 1432793-1. It is rated for 40 amps, costs less than $5, and has a built-in diode for arc suppression. The diode arrow should point towards positive or else it will self destruct. Here is a link to a circuit that you might consider: https://drive.google.com/file/d/0B7ZTG2VpCuDRSVNVa3JwUmFuMzQ/view?usp=sharing The E-Bus will not draw power from the main battery during engine cranking. The small brownout battery will prevent E-Bus voltage sagging during engine start. Thus avionics will not reboot. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=463838#463838 ________________________________________________________________________________
Date: Dec 11, 2016
At 07:54 AM 12/11/2016, you wrote: >My thinking on the ebus was that the radio has a very small draw >when not in use, and the flaps, landing light and fuel pump have >zero draw. Having them on the ebus would allow their use for landing >in case of master contactor or switch failure, if not for that >failure mode, the need for the ebus would be if both alternators >fail. Wonder which is more likely. Your throwing a lot of rocks into the electro-gearworks . . . First, the E-bus is an ENDURANCE bus originally intended to offer a simple, plan-B approach to MINIMIZING loads on limited energy resources for the en route phase of flight. The idea was that should the ONLY engine driven power source become unavailable, then it's entirely possible and practical to plan for continued, comfortable flight to airport of intended destination (or a similarly friendly one where repair resources are available). In other words, inoculate your system against the 'dark-n-stormy-night' syndrome. As originally proposed, the E-bus would let flyers continue with RUNNING LOADS as small as a few amps with a goal of reaching friendly concrete. Over the years, the E-bus has been badly mutated into a collection of band-aids that go to addressing very unlikely if none existent worries. Worries easily address by consulting gray-beards here on the List and deciding just what devices are must useful for meeting the ENDURANCE mode design goals. Z-12 was the next evolutionary step for replacing a pieces-of-@#$# generator on Bonanzas with an alternator having about 4-5x the output and 100x the service life. . . It was never being suggested as the elegant solution for a clean piece of paper design. I'm not suggesting that it's not going to perform as intended . . . in fact, it's a perfectly satisfactory alternative to the legacy architecture typical of a few hundred thousand spam cans (the vast majority of which will not be center stage in a dark-n-stormy-night story). Emacs! If you're well down the road with Z-12 then I would recommend ditching e-bus, and anything resembling an avionics bus. With a robust second alternator, you will not be energy deprived for the en route phase of flight. Just reduce loads till the alternator loaded light stops flashing. This holds ALL of the battery's contained energy in reserve for descent and approach to landing . . . turn on anything else you want to have (short of the air conditioner). Emacs! Loosing ONE properly selected, installed and maintained alternator is very unlikely. Loosing BOTH alternators is on a par with being hit by an incoming meteor. if Z-12 is good for hundreds of Beech, Piper and Mooney airplanes obsessed over by hoards of folk paid good salaries to WORRY about everything . . . then it's golden in your projct. Bob . . . ________________________________________________________________________________
Date: Dec 11, 2016
Subject: On other topics.
>Building an RV-10 and working on wiring >following Z-12 with 60 amp main alternator from >B & C, and 30A backup alternator also from B&C. >Planning on using the mythical 6-cyl P-Mags, but >in the meantime will be setting up shower of >sparks as I have that on hand. A couple of >questions regarding switches. As I look at the >endurance bus, I am trying to figure out what is >an appropriate switch to use, I am looking at >putting the GTN 650, a G3X display, flap motor, >fuel pump, and landing lights on the endurance >bus. While the 650 can be a large draw, that is >only while transmitting, similar with the fuel >pump and flap motor. Lights would only be for a >few minutes on landing. But in total these could >be a large draw for short periods of time, what >is an appropriate switch to use for the >endurance bus, typical toggle switches I see are >rated at no more that 15 ' 20 amps. I really >don=99t want to use one of the pull switches. See http://tinyurl.com/z22xf8q Laboratory performance ratings for switches are almost totally irrelevant in the single engine light aircraft that sees perhaps 100 flight cycles per year MAX. The Carling toggles offered by B&C and others are suited for any of the RV10's appliance loads. >A similar question for an avionics bus, while I >know this is not needed to protect the avionics, >I have been advised it is a good idea so that >there is minimal battery drain while starting >the plane, after start you flip the avionics >master to turn on the majority of the avionics. . . . old flyer's prophylactic having roots in a time when radios were fitted with vacuum tubes and electro-mechanical power supplies. Also a time when airplanes were cranked with rather soggy, flooded, lead- acid batteries. Emacs! The avionics master (like the Kettering spark system) is a feature we can appreciate for its value at the time . . . but happily discarded when that value diminishes and gets replaced by something better. See http://tinyurl.com/jn6gykz Emacs! Bob . . . ________________________________________________________________________________
Date: Dec 11, 2016
Subject: Audio Isolation Amplifier Boards
I've had some requests for the bare etched circuit board called out in the DIY amplifier project featured at http://tinyurl.com/hn28p2q Unfortunately, there is a minimum quantity for fabricating these. If I could sell three more boards at $25 each postage paid, I would be wiling to bring another batch of these in house. This was probably the most successful DIY project on the AeroElectric website. I think we sold about 80 of those boards over the years. I've placed an order for the boards based on requests received to date. The boards are ordered in lots of 6. From the 2 lots just ordered I'll have 4 residual boards available. Bob . . . ________________________________________________________________________________
Subject: Re: led trim display
Date: Dec 13, 2016
nuckolls.bob(at)aeroelect wrote: > At 07:18 AM 8/29/2013, you wrote: > > > > Hi Bob > > > > The Europa that I am building uses a Ray Allen for pitch trimming. I have read over the years that some folks have the same problem you are experiencing when transmitting. It seems that the greatest success is keeping the wire run as far from antenna and associated wires as you can. I installed 5 conductor twisted with shielding from ACS: > > > > http://www.europaowners.org/main.php?g2_itemId=30484 (http://www.europaowners.org/main.php?g2_itemId=30484) > > > > Ron Parigoris > > After pondering schematics for the trim indicator, > the reason for it's sensitivity to RF becomes > apparent. The design was never evaluated and > crafted for immunity to RF interference. There > are critical components missing from the design. > > I note further that voltage used to excite the > potentiometer in the actuator is the rudimentary > 1.2 volts supplied by the internal reference > regulator. An excerpt from the LM3914 specifications > states . . . > > [img]cid:.0[/img] > > > A higher reference voltage increases noise immunity > for the A/D conversion and less jitter or uncertainty > in the bar-to-bar transitions for the display. I would > have considered at least a 5v reference and probably > some higher value still by adding R1/R2 as described > above. > > Referring to the data sheet again we see that bias (or > input load) current at the signal pin (5) is 100nA or > less. > > [img]cid:.1[/img] > > This means that we could put a resistor in series with > pin (5) of say 10,000 ohms and exert less than 1 millivolt > of error in the signal voltage. At the same time we would > add say 1000pF capacitor from pin 5 to ground (pin 2). > > This mod alone might fix the RF sensitivity problem. As > a matter of good design practice I would bypass the power > input pin (3) to ground as well. > > The designers also missed a great opportunity to make > their product truly 'universal' by not exploiting the > expanded scale voltmeter example in the specifications. > > > [img]cid:.2[/img] > > Adding a few components and a couple of pots would > allow the indicator to be tailored to a specific installation > such that full down trim would illuminate the bottom led, > full up trim the top led . . . irrespective of the actuator's > as-installed stroke. > > I offered to help these guys with this product line at > OSH about 20 years ago but they weren't interested. They > also appear to have learned nothing new by way of feedback > from the field as to how their product has been performing. > > Getting back to the original query for driving two indicators > from one actuator pot, a study of the schematics and data > suggests that two indicators running in parallel on one pot > will not significantly 'load' the signal. Hence, you can wire > one indicator to the actuator per installation instructions. > Then wire the second indicator wire for wire in parallel > with the first but leave its potentiometer excitation voltage > wire (orange) floating. > > Bottom line is that this indicator would benefit greatly > from due diligence to rudimentary operating characteristics > and limitations. Adding the resistor and capacitor described > above may fix the RF sensitivity issue. The idea that an > installer should be burdened with careful positioning of > wires to mitigate design flaws is decidedly un-cool. > > > > Bob . . . Hi bob. I have this problem. When I press the PTT the ray Allen led flickers and dims. I've read your post above but don't really understand what is need to rectify the problem. In the simplest of language how would I go about to resolve the problem? Many thanks Frank Read this topic online here: http://forums.matronics.com/viewtopic.php?p=463890#463890 ________________________________________________________________________________
Subject: Trim position indicator
Date: Dec 13, 2016
I'm looking for some idea on how to implement a trim position sensor. Attached is a picture of the aileron trim mechanism. DC motor on the right drives a cogged belt with an idler pulley on the left. There is no limiter on the motor. It can run continuously. When it is unable to pull the bellcrank, the belt begins slipping. The mechanism works fine. I'm not looking for a new trim mechanism. But I would like to know where the system is positioned. I thought about a small magnet on the belt and then some type of sensor but I think that would be too coarse. So I'm wondering if anyone has any ideas on how to implement a sensor. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=463896#463896 Attachments: http://forums.matronics.com//files/fff_small_544.jpg ________________________________________________________________________________
Date: Dec 13, 2016
Subject: Re: Trim position indicator
Hi Don, I think you want one of these: https://www.aircraftspruce.com/catalog/elpages/racpos12sensor.php?clickkey=35250 [] At 03:48 PM 12/13/2016 Tuesday, you wrote: > >I'm looking for some idea on how to implement a trim position sensor. > >Attached is a picture of the aileron trim mechanism. > >DC motor on the right drives a cogged belt with an idler pulley on the left. There is no limiter on the motor. It can run continuously. When it is unable to pull the bellcrank, the belt begins slipping. > >The mechanism works fine. I'm not looking for a new trim mechanism. > >But I would like to know where the system is positioned. I thought about a small magnet on the belt and then some type of sensor but I think that would be too coarse. > >So I'm wondering if anyone has any ideas on how to implement a sensor. > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=463896#463896 > > >Attachments: > >http://forums.matronics.com//files/fff_small_544.jpg > Matt G Dralle | Matronics | 581 Jeannie Way | Livermore | CA | 94550 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Dec 13, 2016
how about a servo potentiometer geared to the idler pulley On Dec 13, 2016, at 19:30, Matt Dralle wrote: Hi Don, I think you want one of these: https://www.aircraftspruce.com/catalog/elpages/racpos12sensor.php?c lickkey=35250 At 03:48 PM 12/13/2016 Tuesday, you wrote: m> > > I'm looking for some idea on how to implement a trim position sensor. > > Attached is a picture of the aileron trim mechanism. > > DC motor on the right drives a cogged belt with an idler pulley on the lef t. There is no limiter on the motor. It can run continuously. When it is un able to pull the bellcrank, the belt begins slipping. > > The mechanism works fine. I'm not looking for a new trim mechanism. > > But I would like to know where the system is positioned. I thought about a small magnet on the belt and then some type of sensor but I think that woul d be too coarse. > > So I'm wondering if anyone has any ideas on how to implement a sensor. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=463896#463896 > > > > > Attachments: > > http://forums.matronics.com//files/fff_small_544.jpg > Matt G Dralle | Matronics | 581 Jeannie Way | Livermore | CA | 94550 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Dec 13, 2016
Hey Matt, I thought about that. But since this isn't a linear mechanism, I couldn't figure out how to implement that sensor. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=463899#463899 ________________________________________________________________________________
Date: Dec 13, 2016
> > >But I would like to know where the system is positioned. I thought >about a small magnet on the belt and then some type of sensor but I >think that would be too coarse. > >So I'm wondering if anyone has any ideas on how to implement a sensor. Emacs! There's a family of ten-turn potentiometers. You might be able to couple one of these to your idler pulley. See http://tinyurl.com/gunkre5 Bob . . . ________________________________________________________________________________
Date: Dec 13, 2016
Hi Don Johnston; Ray Allen makes a trim position sender that you could actuate by anchoring one end and fastening the other to the crank arm. It will not send a "stop" signal to the trim motor, so you will have to provide some other method of limiting the stroke of the trim motor. Cheers! Stu. ----- Original Message ----- From: "donjohnston" <don@velocity-xl.com> Sent: Tuesday, December 13, 2016 3:48:24 PM Subject: AeroElectric-List: Trim position indicator I'm looking for some idea on how to implement a trim position sensor. Attached is a picture of the aileron trim mechanism. DC motor on the right drives a cogged belt with an idler pulley on the left. There is no limiter on the motor. It can run continuously. When it is unable to pull the bellcrank, the belt begins slipping. The mechanism works fine. I'm not looking for a new trim mechanism. But I would like to know where the system is positioned. I thought about a small magnet on the belt and then some type of sensor but I think that would be too coarse. So I'm wondering if anyone has any ideas on how to implement a sensor. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=463896#463896 Attachments: http://forums.matronics.com//files/fff_small_544.jpg ________________________________________________________________________________
Subject: Re: Trim position sensor
Date: Dec 13, 2016
If you fastened a magnet to the belt, mount many magnetic reed switches side by side (glass touching glass) so that at least one switch will always be activated. 25 switches (part number 934-FLEX-14-20-25) cost about $10 total at Mouser. Reed switches are most easily activated when the magnet is parallel to the switch. In other words, the magnet north pole is near one end of the switch and the south pole is near the other end of the switch. A bar magnet should lay flat on the belt with its axis perpendicular to the length of the belt. Perhaps others can design a circuit to convert switch closure to panel display. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=463902#463902 ________________________________________________________________________________
Date: Dec 14, 2016
Your trim system is a "spring bias" system. The belt spring connection could be used to drive the device that Matt suggested. Thete are a few caveots. 1 the sensor has only 1 inch of travel. 2 you would need to find the "neutral point by trial and error 3 if the belt spring connection travels more than 1 inch total you would need to usr a bell crank to cot the input to the sensor to one inch total. 4 spring tensions must be equal with neutral trim (only in the air unless your elevator is fully balanced) Set up, double sided tape the sensor so that a rod connected to the belt spring connection and attached to the slide in the sensor pushes and pulls the sensor slide as the trim is moved up and down. If the indicator register bsckwsrda, swap the power and return wires on the sensor. Fly and move trim. If tbe center point is too far off mlve the sensor in or out to correct . Hope this helps. Btw this is similar to the aileron trim set up in an RV7 except it is driven by a servo with the motoon sensor built in. On Dec 13, 2016 17:51, "donjohnston" <don@velocity-xl.com> wrote: Hey Matt, I thought about that. But since this isn't a linear mechanism, I couldn't figure out how to implement that sensor. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=463899#463899 ________________________________________________________________________________
Subject: Stratux position data
Date: Dec 14, 2016
Hey Ya'll I'm looking into ditching my Garmin 510 and using only ForeFlight with the Stratux for navigation. Currently I'm feeding my 406 ELT position data from the Garmin but want to retain that ability with the IPad/ForeFlight/Stratux set up. Has anyone done this? Anyone know the exact pins on the Sratux to pull GPS position from to make the 406 ELT happy? I ordered the Stratux already built so I probably need to be spoon fed....... Paul Sent from my iPad ________________________________________________________________________________
Subject: Re: Stratux position data
Date: Dec 14, 2016
On 12/14/2016 9:17 AM, Paul J. Michel wrote: > > Hey Ya'll > I'm looking into ditching my Garmin 510 and using only ForeFlight with the Stratux for navigation. Currently I'm feeding my 406 ELT position data from the Garmin but want to retain that ability with the IPad/ForeFlight/Stratux set up. > Has anyone done this? Anyone know the exact pins on the Sratux to pull GPS position from to make the 406 ELT happy? I ordered the Stratux already built so I probably need to be spoon fed....... > Paul GPS pucks are pretty cheap; often under $20. Why not just add a dedicated GPS? ________________________________________________________________________________
Date: Dec 14, 2016
Bob is right. The ten LED trim position indicator detects the reference 1.2V FULL SCALE. At the LSB it can only read 0.12 V which is below the noise level in the environment. This is not hard to fix. 12V full scale would eliminate the problem. My approach to this was to make a trim wheel, which indicated the trim position with a little fiduciary line (like Cessna). I no longer make these but might do so in the future. The Trim Wheel is right at the top of my "I-had-this-part-in-my-old -airplane-and-need-another-for-my-new-airplane list." The "Trim Wheel" potentiometer also changed the voltage to my TSCMR, True Servo Controller for Mac and RAC. This can also be used separately with your own potentiometer, as well as a pushbutton-row assembly or what have you. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=463914#463914 Attachments: http://forums.matronics.com//files/servocontroller_macrac_213.pdf http://forums.matronics.com//files/trim_wheel_no1_146.jpg ________________________________________________________________________________
Date: Dec 15, 2016
At 06:51 PM 12/13/2016, you wrote: >how about a servo potentiometer geared to the idler pulley > >On Dec 13, 2016, at 19:30, Matt Dralle ><dralle(at)matronics.com> wrote: > > I've been mulling this over the past few days. Had to spend a lot of time on the road . . . good opportunity for sifting the seeds of ideas. That idler pulley seems the opportune location for tapping into trim system position data. With a little creating work on a small lathe, you could remount that pulley on a shaft supported by a bushing extending through the mounting surface. Is there room behind that bulkhead to mount a potentiometer? It seems likely that full stroke travel of the trim system will not produce more than 10 revolutions of the idler pulley. The pot would be rigged to produce 50% of full scale voltage with the trim system mechanically neutral. Simple electronics can offer electrical adjustment of the pot voltage should mechanical neutral be offset from aerodynamic neutral. If you had a voltage representing trim postion, where/how would you display it? Bob . . . ________________________________________________________________________________
Date: Dec 15, 2016
nuckolls.bob(at)aeroelect wrote: > At 06:51 PM 12/13/2016, you wrote: > > That idler pulley seems the opportune location for tapping into trim system position data. With a little creating work on a small lathe, you could remount that pulley on a shaft supported by a bushing extending through the mounting surface. Is there room behind that bulkhead to mount a potentiometer? > > Bob . . . Yes, that would be an elegant solution. There's plenty of room on the forward side of the bulkhead. However, I don't have access to a machine shop. :( The position data would be sent to the VPX. It has inputs that can handle the Ray Allen position sensors which then displays it on the GRT HXr EFIS. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=463960#463960 ________________________________________________________________________________
Subject: Re: AeroElectric-List Digest: 2 Msgs - 12/15/16
Date: Dec 16, 2016
I don't think you need a machine shop. Hardware store has bronze 'oillite' bearings in different shaft sizes, that can be epoxied into a bulkhead. Then some use of Aluminum angle to mount the pot. Bill Schertz -----Original Message----- From: AeroElectric-List Digest Server Sent: Friday, December 16, 2016 12:59 AM Subject: AeroElectric-List Digest: 2 Msgs - 12/15/16 * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete AeroElectric-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the AeroElectric-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 16-12-15&Archive=AeroElectric Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 16-12-15&Archive=AeroElectric =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- AeroElectric-List Digest Archive --- Total Messages Posted Thu 12/15/16: 2 ---------------------------------------------------------- Today's Message Index: ---------------------- 1. 09:50 AM - Re: Trim position indicator (Robert L. Nuckolls, III) 2. 07:00 PM - Re: Trim position indicator (donjohnston) ________________________________ Message 1 _____________________________________ From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Subject: Re: AeroElectric-List: Trim position indicator At 06:51 PM 12/13/2016, you wrote: >how about a servo potentiometer geared to the idler pulley > >On Dec 13, 2016, at 19:30, Matt Dralle ><dralle(at)matronics.com> wrote: > > I've been mulling this over the past few days. Had to spend a lot of time on the road . . . good opportunity for sifting the seeds of ideas. That idler pulley seems the opportune location for tapping into trim system position data. With a little creating work on a small lathe, you could remount that pulley on a shaft supported by a bushing extending through the mounting surface. Is there room behind that bulkhead to mount a potentiometer? It seems likely that full stroke travel of the trim system will not produce more than 10 revolutions of the idler pulley. The pot would be rigged to produce 50% of full scale voltage with the trim system mechanically neutral. Simple electronics can offer electrical adjustment of the pot voltage should mechanical neutral be offset from aerodynamic neutral. If you had a voltage representing trim postion, where/how would you display it? Bob . . . ________________________________ Message 2 _____________________________________ Subject: AeroElectric-List: Re: Trim position indicator From: "donjohnston" <don@velocity-xl.com> nuckolls.bob(at)aeroelect wrote: > At 06:51 PM 12/13/2016, you wrote: > > That idler pulley seems the opportune location for tapping into trim > system position data. With a little creating work on a small lathe, you could remount that pulley on a shaft supported by a bushing extending through the mounting surface. Is there room behind that bulkhead to mount a potentiometer? > > Bob . . . Yes, that would be an elegant solution. There's plenty of room on the forward side of the bulkhead. However, I don't have access to a machine shop. :( The position data would be sent to the VPX. It has inputs that can handle the Ray Allen position sensors which then displays it on the GRT HXr EFIS. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=463960#463960 ________________________________________________________________________________
Subject: Airport Courtesy Cars App Closing?
Date: Dec 16, 2016
IMPORTANT! If you are a user of the app version of Airport Courtesy Cars, please view it for an important message about the possible closure of the app, or view the page here: https://www.airportcourtesycars.com/app-status.html -------- Glenn Brasch RV-9A Flying Medevac Helicopter Pilot (Ret) Owner, "Airport Courtesy Cars" Smart Phone App and www.airportcourtesycars.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=463970#463970 ________________________________________________________________________________
Date: Dec 16, 2016
At 08:11 AM 12/16/2016, you wrote: > > >I don't think you need a machine shop. Hardware store has bronze >'oillite' bearings in different shaft sizes, that can be epoxied >into a bulkhead. Then some use of Aluminum angle to mount the pot. Agreed . . . 'jeeping' a pot onto the idler shaft is just a matter of noodling through the mechanical tinker-toya. Given that the sensor is a plain-jane potentiometer, you can probably connect it directly into the trim signal input of the EFIS assuming that it probably expects a signal bounded by zero and 5 volts. There may even be a 5v output from the EFIS that can be tapped to excite the pot. Does your idler pulley have a bearing built in or is it a pulley with set-screw or other fastener designed to mount directly to a shaft. Assuming the latter, can you acquire one that attaches to a shaft? Bob . . . ________________________________________________________________________________
Date: Dec 16, 2016
The Stratux is a wireless software package and does not offer "pins". More specifically, some of the Rasp Pi modules do have USB ports. You did not say which ELT you have or what the exact specs are it needs for GPS input. Many need RS232 serial, a 50 year obsolete protocol. That's not to say that you can't alter the software to use a USB port to output GPS strings. But then you would need an ELT that talks USB. -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464028#464028 ________________________________________________________________________________
Date: Dec 17, 2016
Subject: Re: Audio Isolation Amplifier Boards
At 10:47 PM 12/11/2016, you wrote: > > >I've had some requests for the bare etched circuit board called out >in the DIY amplifier project featured at http://tinyurl.com/hn28p2q All boards requested have been shipped and I'm out of boards. Bob . . . ________________________________________________________________________________
Date: Dec 17, 2016
At 05:48 PM 12/13/2016, you wrote: > >I'm looking for some idea on how to implement a trim position sensor. I'm going to Wichita today and may have a chance to meet with my counterpart in the mechanical side of our cooperative endeavors. I may have an idea for fabricating a potentiometer assembly on your idler shaft using ordinary hand tools . . . Gene will, no doubt, have some ideas to contribute . . . need to know if your idler pulley has a built in bearing to function as an idler or does it attach to a shaft that is carried through an external bearing. Bob . . . ________________________________________________________________________________
Date: Dec 17, 2016
Bob, The idler has an integrated bearing and is held in place with an AN bolt. Don Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464065#464065 ________________________________________________________________________________
Date: Dec 17, 2016
put a gears wheel on the shaft of a servo pot and bolt it to the bulkhead so the toothed belt is tangent to and drives the gear. On Dec 17, 2016, at 17:45, donjohnston <don@velocity-xl.com> wrote: Bob, The idler has an integrated bearing and is held in place with an AN bolt. Don Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464065#464065 ________________________________________________________________________________
Date: Dec 18, 2016
At 04:50 PM 12/17/2016, you wrote: > >put a gears wheel on the shaft of a servo pot and bolt it to the >bulkhead so the toothed belt is tangent to and drives the gear. That seems the simplest approach . . . what are the pitch and width of the cog-belt? Bob . . . ________________________________________________________________________________
Subject: Re: Airport Courtesy Cars App Closing?
Date: Dec 18, 2016
I am happy to report that thanks to donations, the site continues. View the donors or add your name by clicking here: https://www.airportcourtesycars.com/thank-you-donors-.html Thanks, Glenn -------- Glenn Brasch RV-9A Flying Medevac Helicopter Pilot (Ret) Owner, "Airport Courtesy Cars" Smart Phone App and www.airportcourtesycars.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464086#464086 ________________________________________________________________________________
Date: Dec 18, 2016
> put a gears wheel on the shaft of a servo pot and bolt it to the bulkhead so the toothed belt is tangent to and drives the gear. I like it! :D I can pick up another cogged pulley that has an ID which will fit over the shaft of a pot. Now I just need to figure out what type of pot. Since the VPX will accept an RAC trim position sensor, does anyone know what the spec's are for that? I'm assuming that it's basically a linear pot. -Don Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464159#464159 ________________________________________________________________________________
Date: Dec 18, 2016
Another builder informed me that the Ray Allen servo pot is 5K ohm. Unverified. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464161#464161 ________________________________________________________________________________
Date: Dec 18, 2016
Gents, FWIW, high quality gears, sprockets & chain drives are available from http://servolink.com In addition, the web page has facilities for drive design. Technical support is also available. Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop (75 hrs). Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com On Dec 18, 2016, at 4:21 PM, donjohnston <don@velocity-xl.com> wrote: <don@velocity-xl.com> > put a gears wheel on the shaft of a servo pot and bolt it to the bulkhead so the toothed belt is tangent to and drives the gear. I like it! :D I can pick up another cogged pulley that has an ID which will fit over the shaft of a pot. Now I just need to figure out what type of pot. Since the VPX will accept an RAC trim position sensor, does anyone know what the spec's are for that? I'm assuming that it's basically a linear pot. -Don Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464159#464159 ________________________________________________________________________________
Date: Dec 19, 2016
Install another bellcrank with its lower end attached to the outboard end of one of the springs. Connect a Ray Allen position sensor to the new bellcrank at a point that matches the travel requirements. Or drive the new bellcrank with a Ray Allen servo (with built-in sensor and limit switches). Replace the existing motor drive gear with an idler gear. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464177#464177 ________________________________________________________________________________
Date: Dec 19, 2016
At 06:58 PM 12/18/2016, you wrote: > >Another builder informed me that the Ray Allen servo pot is 5K ohm. >Unverified. The value of the pot is very non-critical . . . 1 to 10K would work . . . it's simply a voltage divider that is biased up with a 5v source from your EFIS system. You'll want a MULTI turn pot that will accept more rotation than what results from full-stroke motion of the cog-belt against the add-on pulley. Here's a likely candidate . . . http://tinyurl.com/gn4rs23 for a 10-turn device to which you can add the pulley and bracketry to make the installation. Bob . . . ________________________________________________________________________________
Date: Dec 22, 2016
Subject: IBBS battery with B and C alternators?
Still learning about alternators and have a question. Building an RV-10 with IO-540 engine. Have to mount on the engine BC460-H belt driven 60 amp alternator, and BC410-H accessory case mounted backup alternator. Thinking about failure scenarios. My understanding is that a master contactor or battery failure would take out both alternators as they need a battery online to help control the operation of the alternator. With the IBBS 6 AH battery having a charging line off of the main power bus, would that have any influence on this? Bill Greenley ________________________________________________________________________________
Subject: Re: IBBS battery with B and C alternators?
Date: Dec 22, 2016
Once up and running, an alternator will keep working even if the battery is disconnected. However, the the alternator output might be unstable without a battery. A contactor failure or battery open circuit failure will not take out an alternator, but the output voltage might fluctuate. Yes, a 6 amp hour will have a stabilizing affect. Exactly how much will need to be determined by testing. It is very rare for a battery to fail suddenly without warning, although my PC680 did suddenly develop an internal open circuit. The vast majority of small planes are flying without backup batteries or backup contactors. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464252#464252 ________________________________________________________________________________
Date: Dec 22, 2016
The IBBS will detect any failure of the main bus that results in a bus voltage falling below 11 volts, regardless of the cause. When this occurs, backup battery voltage will be provided to all of the connected equipment powered via the outputs of the ibbs. Bob Newman TCW Technologies, LLC 610-928-3420 > On Dec 22, 2016, at 10:34 AM, William Greenley wrote: > > Still learning about alternators and have a question. Building an RV-10 with IO-540 engine. Have to mount on the engine BC460-H belt driven 60 amp alternator, and BC410-H accessory case mounted backup alternator. Thinking about failure scenarios. My understanding is that a master contactor or battery failure would take out both alternators as they need a battery online to help control the operation of the alternator. With the IBBS 6 AH battery having a charging line off of the main power bus, would that have any influence on this? > Bill Greenley ________________________________________________________________________________
Date: Dec 22, 2016
I understand how the IBBS battery system works as a backup, and that is why I am buying. What I am trying to figure out is since alternators (at least most included B & C's) need the battery to be online to "buffer" the alternator output, does the IBBS battery charging line on the main bus offer any of this "buffer" capability so that an alterntor would keep running even if he main contactor were to fail. I am thinking it would not since the charge line is one way only, the IBBS battery would not put out any current unless their was a power failure. On Thu, Dec 22, 2016 at 8:34 PM, Tcwtech wrote: > > The IBBS will detect any failure of the main bus that results in a bus > voltage falling below 11 volts, regardless of the cause. When this > occurs, backup battery voltage will be provided to all of the connected > equipment powered via the outputs of the ibbs. > > Bob Newman > TCW Technologies, LLC > 610-928-3420 > > > On Dec 22, 2016, at 10:34 AM, William Greenley > wrote: > > > > Still learning about alternators and have a question. Building an RV-10 > with IO-540 engine. Have to mount on the engine BC460-H belt driven 60 amp > alternator, and BC410-H accessory case mounted backup alternator. Thinking > about failure scenarios. My understanding is that a master contactor or > battery failure would take out both alternators as they need a battery > online to help control the operation of the alternator. With the IBBS 6 AH > battery having a charging line off of the main power bus, would that have > any influence on this? > > Bill Greenley > > ________________________________________________________________________________
Date: Dec 23, 2016
I don't really understand what you mean by 'one way'? If the alternator and ibbs are both connected to the bus bar current will flow to the device with the lower potential, for the circuit to work they must also be grounded. If the master relay fails why won't everything keep working until you land? Why do you need a additional battery? Master relay failure is rare. Peter On 23 Dec 2016 02:11, "William Greenley" wrote: I understand how the IBBS battery system works as a backup, and that is why I am buying. What I am trying to figure out is since alternators (at least most included B & C's) need the battery to be online to "buffer" the alternator output, does the IBBS battery charging line on the main bus offer any of this "buffer" capability so that an alterntor would keep running even if he main contactor were to fail. I am thinking it would not since the charge line is one way only, the IBBS battery would not put out any current unless their was a power failure. On Thu, Dec 22, 2016 at 8:34 PM, Tcwtech wrote: > > The IBBS will detect any failure of the main bus that results in a bus > voltage falling below 11 volts, regardless of the cause. When this > occurs, backup battery voltage will be provided to all of the connected > equipment powered via the outputs of the ibbs. > > Bob Newman > TCW Technologies, LLC > 610-928-3420 > > > On Dec 22, 2016, at 10:34 AM, William Greenley > wrote: > > > > Still learning about alternators and have a question. Building an RV-10 > with IO-540 engine. Have to mount on the engine BC460-H belt driven 60 amp > alternator, and BC410-H accessory case mounted backup alternator. Thinking > about failure scenarios. My understanding is that a master contactor or > battery failure would take out both alternators as they need a battery > online to help control the operation of the alternator. With the IBBS 6 AH > battery having a charging line off of the main power bus, would that have > any influence on this? > > Bill Greenley > > > ===================================== > br> fts!) > r> > com" rel="noreferrer" target="_blank">www.aeroelectric.com > w.buildersbooks.com" rel="noreferrer" target="_blank">www. > buildersbooks.com > p.com" rel="noreferrer" target="_blank">www.homebuilthelp.com > e.com" rel="noreferrer" target="_blank">www.mypilotstore.com > " rel="noreferrer" target="_blank">www.mrrace.com > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > -Matt Dralle, List Admin. > =================================== > - > Electric-List" rel="noreferrer" target="_blank">http://www.matronics.com/ > Navigator?AeroElectric-List > =================================== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > =================================== > WIKI - > errer" target="_blank">http://wiki.matronics.com > =================================== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > =================================== > > ________________________________________________________________________________
Date: Dec 23, 2016
The charge/sense line will not provide any substantial buffering of the main bus. It is an input only and the ibbs battery is not "seen by" the main bu s. There is a series of input capacitors amounting to about 40 uF from our e mi filter that the voltage regulator of the alternator would see, but to the extent that this satisfies the control loop in the alternator/regulator sys tem we really can not comment. Bob Newman TCW Technologies, LLC 610-928-3420 > On Dec 22, 2016, at 8:58 PM, William Greenley wrote: > > I understand how the IBBS battery system works as a backup, and that is wh y I am buying. What I am trying to figure out is since alternators (at least most included B & C's) need the battery to be online to "buffer" the altern ator output, does the IBBS battery charging line on the main bus offer any o f this "buffer" capability so that an alterntor would keep running even if h e main contactor were to fail. I am thinking it would not since the charge l ine is one way only, the IBBS battery would not put out any current unless t heir was a power failure. > >> On Thu, Dec 22, 2016 at 8:34 PM, Tcwtech wrote: >> >> The IBBS will detect any failure of the main bus that results in a bus vo ltage falling below 11 volts, regardless of the cause. When this occurs, b ackup battery voltage will be provided to all of the connected equipment pow ered via the outputs of the ibbs. >> >> Bob Newman >> TCW Technologies, LLC >> 610-928-3420 >> >> > On Dec 22, 2016, at 10:34 AM, William Greenley wr ote: >> > >> > Still learning about alternators and have a question. Building an RV-10 with IO-540 engine. Have to mount on the engine BC460-H belt driven 60 amp a lternator, and BC410-H accessory case mounted backup alternator. Thinking ab out failure scenarios. My understanding is that a master contactor or batter y failure would take out both alternators as they need a battery online to h elp control the operation of the alternator. With the IBBS 6 AH battery havi ng a charging line off of the main power bus, would that have any influence o n this? >> > Bill Greenley >> >> >> ========================= ============ >> br> fts!) >> r> > com" rel="noreferrer" target="_blank">www.aeroelectric.com >> w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersboo ks.com >> p.com" rel="noreferrer" target="_blank">www.homebuilthelp.com >> e.com" rel="noreferrer" target="_blank">www.mypilotstore.com >> " rel="noreferrer" target="_blank">www.mrrace.com >> rel="noreferrer" target="_blank">http://www.matronics.com/contributio n >> -Matt Dralle, List Admin. >> ========================= >> - >> Electric-List" rel="noreferrer" target="_blank">http://www.matronics. com/Navigator?AeroElectric-List >> ========================= >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========================= >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ========================= >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contributio n >> ========================= >> >> >> > ________________________________________________________________________________
Date: Dec 23, 2016
Here is a circuit for those concerned about the master contactor failing. An automotive relay is connected in parallel with the master contactor. The relay is disabled during engine starting to prevent excessive current from flowing through the relay contacts. Prior to turning on the master contactor, the relay can be energized to be sure that it works. The relay must be shut off to start the engine. After engine start, the relay may be turned back on. If the alternator fails, the battery master contactor can be shut off to conserve energy. During cruise flight, the relay will only carry battery charging current. Aircraft load current will flow directly from the alternator to the main power bus, not through the relay. When playing with avionics in the hangar with the engine off, the relay can be turned on instead of master contactor. Notice that the arrows on arc-suppression diodes point towards positive. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464274#464274 Attachments: http://forums.matronics.com//files/contactor_bypass_462.pdf http://forums.matronics.com//files/contactor_bypass_143.jpg ________________________________________________________________________________
Date: Dec 23, 2016
If you're going to that much trouble why not just have two independently switched contactors? > On Dec 23, 2016, at 11:13 AM, user9253 wrote: > > > Here is a circuit for those concerned about the master contactor failing. An automotive relay is connected in parallel with the master contactor. The relay is disabled during engine starting to prevent excessive current from flowing through the relay contacts. Prior to turning on the master contactor, the relay can be energized to be sure that it works. The relay must be shut off to start the engine. After engine start, the relay may be turned back on. If the alternator fails, the battery master contactor can be shut off to conserve energy. > During cruise flight, the relay will only carry battery charging current. Aircraft load current will flow directly from the alternator to the main power bus, not through the relay. > When playing with avionics in the hangar with the engine off, the relay can be turned on instead of master contactor. Notice that the arrows on arc-suppression diodes point towards positive. > > -------- > Joe Gores > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=464274#464274 > > > > > Attachments: > > http://forums.matronics.com//files/contactor_bypass_462.pdf > http://forums.matronics.com//files/contactor_bypass_143.jpg > > > > > > ________________________________________________________________________________
Date: Dec 23, 2016
> If you're going to that much trouble why not just have two independently switched contactors? There is not much trouble, same number of components either way. The relay has the advantage of less current, less weight, less cost, and less space. I am not necessarily recommending this circuit. Just offering it for others who want redundancy. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464278#464278 ________________________________________________________________________________
Date: Dec 24, 2016
The only contactor failure I've had is when it welded itself shut, due to a short in the starter motor. It's quite unusual not being able to turn off the aircraft.. On 23Dec2016, at 7:12 PM, user9253 wrote: > If you're going to that much trouble why not just have two independently switched contactors? There is not much trouble, same number of components either way. The relay has the advantage of less current, less weight, less cost, and less space. I am not necessarily recommending this circuit. Just offering it for others who want redundancy. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464278#464278 ________________________________________________________________________________
Date: Dec 24, 2016
At 05:24 PM 12/23/2016, you wrote: > >The only contactor failure I've had is when it welded itself shut, >due to a short in the starter motor. It's quite unusual not being >able to turn off the aircraft.. > >On 23Dec2016, at 7:12 PM, user9253 wrote: > > > > If you're going to that much trouble why not just have two > independently switched contactors? > >There is not much trouble, same number of components either >way. The relay has the advantage of less current, less weight, less >cost, and less space. I am not necessarily recommending this >circuit. Just offering it for others who want redundancy. Contactor failure (or failure of the control wiring/swtich to a contactor is rare. Figure Z-13/8 was designed so that ENDURANCE mode flight was not only possible with the contactor deliberately opened to reduce en route energy demands. Have you done a load analysis of your proposed installation? Have you selected a system architecture? I'm betting that with a little pre-planning and adjustment of architecture, a Plan-B can be identified for every single- failure event but without adding a lot of weight, cost-of-ownership and system complexity. Electrical system failures as root or even contributing cause for a bad day in the cockpit are exceedingly rare. Most bad days in the cockpit arise from poor pilot preparedness for steering around the many inevitable pot-holes in their flying experience. I'll suggest a review of the Z-figures, accompanying notes and supporting narratives in the 'Connection would be useful. Particularly the chapter on system reliability (where 'system' includes prop-to-tailcone environs and all components in between). If you don't have a paper copy of the 'Connection, you can download a .pdf at http://www.aeroelectric.com/Book/AEC_R12A.pdf I've been out of pocket for the last few days . . .had a melt-down of my office computer. Just got a re-build up and running late yesterday. Leaving for Wichita today for Christmas celebrations. Be back on line late Sunday. In the mean time, let's see if we can figure out why Z-13/8 WILL NOT serve to PLAN for any real risks to the enjoyment of your airplane. Lets do failure mode effects analysis to your proposed system with a goal of keeping ANY and ALL single failures from creating an EMERGENCY . . . the goal is to upgrade a component because you're tired of replacing it . . . not because it damned near got you killed. FMEA is the easy, light, most economical way to craft an electrical system and mitigate any worries associated with flying it. Merry Christmas folks! See you in a few days. Bob . . . ________________________________________________________________________________
Date: Dec 24, 2016
In the event of an emergency landing or fire, it is necessary to turn off both switches. I suggest making that ergonomically easy to do in a single motion. Jeff Page Dream Aircraft Tundra #10 > Subject: AeroElectric-List: Re: IBBS battery with B and C alternators? > From: "user9253" <fransew(at)gmail.com> > > Here is a circuit for those concerned about the master contactor > failing. An automotive > relay is connected in parallel with the master contactor. The relay > is disabled during engine starting to prevent excessive current from flowing > through the relay contacts. Prior to turning on the master > contactor, the relay > can be energized to be sure that it works. The relay must be shut off to > start the engine. After engine start, the relay may be turned back > on. If the > alternator fails, the battery master contactor can be shut off to > conserve energy. > During cruise flight, the relay will only carry battery charging > current. Aircraft > load current will flow directly from the alternator to the main power bus, > not through the relay. > When playing with avionics in the hangar with the engine off, the > relay can be > turned on instead of master contactor. Notice that the arrows on > arc-suppression > diodes point towards positive. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=464274#464274 > > > Attachments: > > http://forums.matronics.com//files/contactor_bypass_462.pdf > http://forums.matronics.com//files/contactor_bypass_143.jpg ________________________________________________________________________________
Subject: EFII ignition and injection Z-13/8
Date: Dec 24, 2016
With EFII ignition and injection is Z-13/8 a good choice? I'm not sure the current draw of one pump, one ignition, and injectors; could be too much for the 8 amp alternator. Is Z-13/8 suitable for a 20 amp backup alternator or would that lead one to Z-12? I know I need to do a load analysis. Thanks for the LA-IFP accident report. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464299#464299 ________________________________________________________________________________
Date: Dec 24, 2016
Subject: 2016 List of Contributors
Dear Listers, The 2016 Matronics Email List and Forum Fund Raiser officially ended a couple of weeks ago and it's time that I published this year's List of Contributors. It is the people on this list that directly make these Email Lists and Forums possible! Their generous Contributions keep the servers and Internet connection up and running! You can still show your support this year and pick up a great gift at the same time. The Contribution Web Site is fast, easy, and secure: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I also want to thank Andy, Bob, George, and Jon for their generous support through the supply of many great gifts this year!! These guys have some excellent products and I encourage you to visit their respective web sites: Andy Gold - The Builder's Bookstore - http://www.buildersbooks.com Bob Nucklolls - AeroElectric - http://www.aeroelectric.com George Race - Race Consulting - http://www.mrrace.com Jon Croke - HomebuiltHELP - http://www.homebuilthelp.com And finally, I'm proud to present The 2016 Fund Raiser List of Contributors: http://www.matronics.com/loc/2016.html Thank you again to everyone that made a Contribution this year!! Matt Dralle Matronics Email List & Forum Administrator ________________________________________________________________________________
Subject: A couple of questions about Fuses
Date: Dec 26, 2016
Good morning 'letric Bob and all 'letric experts. I hope you had a Merry Christmas! In my fused power busses I decided to use LED blade fuses, those whose LED gets illuminated when the fuse trips. It happens that I have a couple of circuits which require a 1A fuse, but there are no 1A LED blade fuses. Therefore, in these circuits, either I use a normal (non-illuminated) 1A fuse, or I go for a 2A illuminated fuse. What happens if I decide for the latter? Do I get less protection? Is that particular device more prone to be fried? Now, for the second question, in a broader perspective: I have heard dozens of times that a fuse (or other protection device) is there to protect the wire and not the device at its end. However, the size (in A) of the fuse is determined by the device in use (you read in the installation manuals that "to protect this device, you should use a 3A fuse or circuit breaker"). I know that this depends on the power (W) that is used by the device when working, and that both the wire and the fuse must be sized accordingly. I also know that if we use a thinner wire, it will get very hot and eventually melt. But what about using an higher A or a lesser A fuse? What are the physics involved? Thanks Carlos ________________________________________________________________________________
Date: Dec 26, 2016
Subject: Re: A couple of questions about Fuses
Hi Carlos, Take a look at chapter 10, circuit protection, in *The AeroElectric Connection*. And here are a few articles: http://www.aeroelectric.com/articles.html#Circuit Protection In building my plane, I am following the advice to size the fuse for the wire, except in a couple of cases where I only need a couple of amps and did not feel like installing tiny wire. In those cases, I went ahead and used an undersized fuse, even though the wire is capable of carrying more current. Cheers, -- Art Z. On Mon, Dec 26, 2016 at 5:31 AM, Carlos Trigo wrote : > Good morning =98letric Bob and all =98letric experts. > > I hope you had a Merry Christmas! > > > In my fused power busses I decided to use LED blade fuses, those whose LE D > gets illuminated when the fuse trips. > > It happens that I have a couple of circuits which require a 1A fuse, but > there are no 1A LED blade fuses. Therefore, in these circuits, either I u se > a normal (non-illuminated) 1A fuse, or I go for a 2A illuminated fuse. > > What happens if I decide for the latter? Do I get less protection? Is tha t > particular device more prone to be fried? > > > Now, for the second question, in a broader perspective: I have heard > dozens of times that a fuse (or other protection device) is there to > protect the wire and not the device at its end. > > However, the size (in A) of the fuse is determined by the device in use > (you read in the installation manuals that =9Cto protect this devic e, you > should use a 3A fuse or circuit breaker=9D). > > I know that this depends on the power (W) that is used by the device when > working, and that both the wire and the fuse must be sized accordingly. I > also know that if we use a thinner wire, it will get very hot and > eventually melt. > > But what about using an higher A or a lesser A fuse? What are the physics > involved? > > > Thanks > > Carlos > -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Date: Dec 26, 2016
Charlie On Dec 26, 2016, 6:40 AM, at 6:40 AM, Carlos Trigo wrote: >Good morning 'letric Bob and all 'letric experts. > >I hope you had a Merry Christmas! > > > >In my fused power busses I decided to use LED blade fuses, those whose >LED >gets illuminated when the fuse trips. > >It happens that I have a couple of circuits which require a 1A fuse, >but >there are no 1A LED blade fuses. Therefore, in these circuits, either I >use >a normal (non-illuminated) 1A fuse, or I go for a 2A illuminated fuse. > >What happens if I decide for the latter? Do I get less protection? Is >that >particular device more prone to be fried? > > > >Now, for the second question, in a broader perspective: I have heard >dozens >of times that a fuse (or other protection device) is there to protect >the >wire and not the device at its end. > >However, the size (in A) of the fuse is determined by the device in use >(you >read in the installation manuals that "to protect this device, you >should >use a 3A fuse or circuit breaker"). > >I know that this depends on the power (W) that is used by the device >when >working, and that both the wire and the fuse must be sized accordingly. >I >also know that if we use a thinner wire, it will get very hot and >eventually >melt. > >But what about using an higher A or a lesser A fuse? What are the >physics >involved? > > > >Thanks > >Carlos ________________________________________________________________________________
Date: Dec 26, 2016
Fuses that glow when blown depend on the load to complete the circuit. If the load circuit happens to open up as a result of the malfunction, the fuse will not glow. While the above scenario is possible, it is not likely. If some electrical device does not work, check the glow-type fuse with a meter to be sure that it is not blown. Yes, the larger the fuse, the less protection there is. By protection, I am talking about protection against smoke in the cockpit. As far as protection for the electrical device, it doesn't matter if the fuse is 1 amp or 2 amps or 5 amps. If the device shorts out, it will be fried regardless of the fuse size. A lager fuse size will not make any electrical device more prone to fail. Many devices have internal fuses to protect against internal short circuits. 22 AWG wire can be protected by a 3 amp fuse. But if a device only requires one half amp, then a 1 amp fuse will offer more protection against smoke if the device ever shorts out. Bottom line is, you can use either a 1 amp or 2 amp fuse. A 1 amp will give more peace of mind. A 2 amp will work too. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464402#464402 ________________________________________________________________________________
Date: Dec 26, 2016
I would add that I have seen cases where the recommended small fuse popped after many years. Replacing the fuse with a handy slightly larger fuse also popped but this time it was accompanied by smoke from the transponder. Neither fuse put the wire at any risk and likely the smoke would have stopped by itself but I prefer to follow the manufacturers fuse recommendation. OTOH I don't worry about going up to the appropriate larger wire protection fuse in cases where it is convenient to put multiple items on the same fuse. Of larger concern to me are some of the very small gage cords that get plugged into 15 amp circuits in houses. Ken On 26/12/2016 9:35 AM, user9253 wrote: > > Fuses that glow when blown depend on the load to complete the circuit. If the load circuit happens to open up as a result of the malfunction, the fuse will not glow. While the above scenario is possible, it is not likely. If some electrical device does not work, check the glow-type fuse with a meter to be sure that it is not blown. > Yes, the larger the fuse, the less protection there is. By protection, I am talking about protection against smoke in the cockpit. As far as protection for the electrical device, it doesn't matter if the fuse is 1 amp or 2 amps or 5 amps. If the device shorts out, it will be fried regardless of the fuse size. A lager fuse size will not make any electrical device more prone to fail. Many devices have internal fuses to protect against internal short circuits. > 22 AWG wire can be protected by a 3 amp fuse. But if a device only requires one half amp, then a 1 amp fuse will offer more protection against smoke if the device ever shorts out. > Bottom line is, you can use either a 1 amp or 2 amp fuse. A 1 amp will give more peace of mind. A 2 amp will work too. > > -------- > Joe Gores > > ________________________________________________________________________________
Date: Dec 26, 2016
Subject: Securing Split PVC Conduit
Folks, I am using some split PVC conduit <http://www.hall-fast.com/consumables/electrical/cable-accessories/conduit-and-warning-tapes/pvc-split-conduit/> in my plane and two of the runs are pretty close to vertical, about 4 feet long. Sitting in my garage, with the wires not yet secured at the bottom, the conduit keeps trying to slide downward in the 2 inch square channels through which it runs. I think that I ought to secure it somehow and wonder if you have any ideas that will keep it in place. Maybe I can wrap a thin cable tie around it and get it to slip into a groove? Or maybe wrap it with silicone self-sealing tape and the put an AN742 clamp around it? Thanks, -- Art Z. -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Subject: Re: Securing Split PVC Conduit
Date: Dec 27, 2016
Is conduit necessary inside of a channel? -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464426#464426 ________________________________________________________________________________
Date: Dec 27, 2016
When there are sharp things sticking into the channel, yes On Tue, Dec 27, 2016 at 8:18 AM, user9253 wrote: > > Is conduit necessary inside of a channel? -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Date: Dec 27, 2016
A dab of RTV? Neal George Sent from my iPhone > On Dec 26, 2016, at 10:05 PM, Art Zemon wrote: > > Folks, > > I am using some split PVC conduit in my plane and two of the runs are pret ty close to vertical, about 4 feet long. Sitting in my garage, with the wire s not yet secured at the bottom, the conduit keeps trying to slide downward i n the 2 inch square channels through which it runs. I think that I ought to s ecure it somehow and wonder if you have any ideas that will keep it in place . > > Maybe I can wrap a thin cable tie around it and get it to slip into a groo ve? > > Or maybe wrap it with silicone self-sealing tape and the put an AN742 clam p around it? > > Thanks, > -- Art Z. > > -- > https://CheerfulCurmudgeon.com/ > > "If I am not for myself, who is for me? And if I am only for myself, what a m I? And if not now, when?" Hillel ________________________________________________________________________________
Date: Dec 27, 2016
Hi Art, You could probably use safety wire wrapped around the split loom and hang it using tape to hold the safety wire. Hal Benjamin RV4 Sent from my iPad > On Dec 26, 2016, at 10:05 PM, Art Zemon wrote: > > Folks, > > I am using some split PVC conduit in my plane and two of the runs are pret ty close to vertical, about 4 feet long. Sitting in my garage, with the wire s not yet secured at the bottom, the conduit keeps trying to slide downward i n the 2 inch square channels through which it runs. I think that I ought to s ecure it somehow and wonder if you have any ideas that will keep it in place . > > Maybe I can wrap a thin cable tie around it and get it to slip into a groo ve? > > Or maybe wrap it with silicone self-sealing tape and the put an AN742 clam p around it? > > Thanks, > -- Art Z. > > -- > https://CheerfulCurmudgeon.com/ > > "If I am not for myself, who is for me? And if I am only for myself, what a m I? And if not now, when?" Hillel ________________________________________________________________________________
From: Holger Selover-Stephan <holger-d(at)shadowbrush.com>
Date: Dec 27, 2016
I=99ve used lacing tape for that purpose in the past. So friendly to do-overs. Holger > On Dec 26, 2016, at 7:05 PM, Art Zemon wrote: > > Folks, > > I am using some split PVC conduit <http://www.hall-fast.com/consumables/electrical/cable-accessories/conduit -and-warning-tapes/pvc-split-conduit/> in my plane and two of the runs are pretty close to vertical, about 4 feet long. Sitting in my garage, with the wires not yet secured at the bottom, the conduit keeps trying to slide downward in the 2 inch square channels through which it runs. I think that I ought to secure it somehow and wonder if you have any ideas that will keep it in place. ________________________________________________________________________________
Date: Dec 27, 2016
In my fused power busses I decided to use LED blade fuses, those whose LED gets illuminated when the fuse trips. Are you anticipating replacement of fuses in flight? It happens that I have a couple of circuits which require a 1A fuse, but there are no 1A LED blade fuses. Therefore, in these circuits, either I use a normal (non-illuminated) 1A fuse, or I go for a 2A illuminated fuse. I used to sell 1 and 2A ATC fuses but never with failure annunciation. If your appliance is 'dead in the water', little lights on the fuses are of marginal convenience. What happens if I decide for the latter? Do I get less protection? Is that particular device more prone to be fried? "Less" and "more" are hard to quantify. What we do know is that legacy wire protection philosophy is based not upon wire size but the robustness of the insulation. You can purchase 22AWG wires with recommended maximum operating temperatures all over the map . . . generally no lower than 80C but some as high as 180-200C. In EVERY case, it is not the wire at-risk for failure due to effects of current flow . . . it's the INSULATION that drives the numbers on max recommended temperature rise. Wrestling with the consequences for choosing 1A vs 5A protection on a 22AWG wire is not particularly difficult. See http://tinyurl.com/zrmkoz6 That image demonstrates that loading a 22AWG wire at 20 amps does not produce a free-air temperature rise that places the Tefzel insulation at risk for failure. Now, for the second question, in a broader perspective: I have heard dozens of times that a fuse (or other protection device) is there to protect the wire and not the device at its end. Absolutely . . . However, the size (in A) of the fuse is determined by the device in use (you read in the installation manuals that "to protect this device, you should use a 3A fuse or circuit breaker"). People who write installation manuals are almost never system integrators. Frequently they are not talented writers either. The installation manuals should speak to continuous and intermittent current drain values. Intermittent values should also be quantified with a typical duration. It's up to the system integrator to supply a source of energy that is (1) not at risk for tripping its feeder protection. (2) sizing the wire such that its temperature rise does not exceed ratings for the proposed insulation. Allowances must be made for areas where the wire may traverse an elevated environmental temperature. Further consideration is made for loss of cooling the wire is bundled. (3) The final consideration evaluates potential for loss of appliance performance due to voltage drop when the run of wire is particularly long. Lear got bit in the cushy behind when they discovered an unacceptable loss of performance for a pitch trim system because motor current ran the length of the aircraft four times! While the wires were not over-heating, the voltage drop under certain conditions produced unsatisfactory trim performance. I got to design a solid state fleet retrofit trim controller. My boss was really happy with that one . . . got a big raise. He paid for my flying lessons accompanied by a generous flying budget from the rental fleet at United Beechcraft. I know that this depends on the power (W) that is used by the device when working, and that both the wire and the fuse must be sized accordingly. I also know that if we use a thinner wire, it will get very hot and eventually melt. But what about using an higher A or a lesser A fuse? What are the physics involved? The copper wire is never at-risk except conditions where ship's batteries can drive a hard-fault of hundreds if not thousands of amps. So in the photo example cited above, I COULD consider running a 20A appliance through a 22AWG feeder protected with a 30A fuse . . . as long as the feeder length wasn't so long that voltage drop becomes an issue. When selecting wires and protection, you're never wrong with the "legacy pairs" of 22AWG/5A, 20AWG/7A, 18AWG/10A, etc. etc. These are very conservative pairings. An installation manual should read something like, "Supply DC power at 11-15 volts with a continuous demand of X.X amps and a 10% duty cycle of Y.Y amps." After that, it's up to the system integrator to meet that requirement. I would never have attempted to qualify a product that begged for EXTERNAL overcurrent protection beyond that normally supplied with the recommended wire size. If you've got a 22AWG feeder to a device where 3A protection is suggested, 5A protection is not out of line. Bob . . . ________________________________________________________________________________
Subject: 5 Volt Converter Product Review
Date: Dec 28, 2016
I purchased a 5 volt converter on eBay (Item # 152124360516) and bench tested it. With an input of 13 VDC, I connected a load to the output that drew 4.6 amps. The input current was 2.15 amps. The output voltage was 5.1 to 5.15 volts depending on which meter that I used. That is within the USB standard of 4.75 to 5.25. I calculated the efficiency to be 85 percent. I could not detect any AC ripple using both a meter and a scope. The weight is 112 grams (4 oz), Dimensions are 59mm x 65mm x 22mm. The mounting holes are 54mm center to center. The seller exaggerated the efficiency, so the 10 amp output rating might be exaggerated too. Even so, this converter should be adequate for powering 2 or 3 devices. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464454#464454 ________________________________________________________________________________
Date: Dec 28, 2016
Subject: Re: 5 Volt Converter Product Review
I just installed one that is very similar. Running two devices my ipad will hold steady, but not charge. That's with a 5a fuse on the 12v supply, which might be a little conservative. On December 28, 2016 19:47:47 "user9253" wrote: > > I purchased a 5 volt converter on eBay (Item # 152124360516) and bench > tested it. > With an input of 13 VDC, I connected a load to the output that drew 4.6 > amps. The input current was 2.15 amps. The output voltage was 5.1 to 5.15 > volts depending on which meter that I used. That is within the USB > standard of 4.75 to 5.25. I calculated the efficiency to be 85 percent. I > could not detect any AC ripple using both a meter and a scope. The weight > is 112 grams (4 oz), Dimensions are 59mm x 65mm x 22mm. The mounting > holes are 54mm center to center. > The seller exaggerated the efficiency, so the 10 amp output rating might be > exaggerated too. Even so, this converter should be adequate for powering 2 > or 3 devices. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=464454#464454 > > ________________________________________________________________________________
Date: Dec 28, 2016
How many amps does it take to power a 10 inch IPad? Sent from my Android. Sorry Steve. On Dec 28, 2016 5:03 PM, "Jared Yates" wrote: > > > > I just installed one that is very similar. Running two devices my ipad > will hold steady, but not charge. That's with a 5a fuse on the 12v supply, > which might be a little conservative. > > > On December 28, 2016 19:47:47 "user9253" wrote: > >> >> I purchased a 5 volt converter on eBay (Item # 152124360516) and bench >> tested it. >> With an input of 13 VDC, I connected a load to the output that drew 4.6 >> amps. The input current was 2.15 amps. The output voltage was 5.1 to >> 5.15 volts depending on which meter that I used. That is within the USB >> standard of 4.75 to 5.25. I calculated the efficiency to be 85 percent. >> I could not detect any AC ripple using both a meter and a scope. The >> weight is 112 grams (4 oz), Dimensions are 59mm x 65mm x 22mm. The >> mounting holes are 54mm center to center. >> The seller exaggerated the efficiency, so the 10 amp output rating might >> be exaggerated too. Even so, this converter should be adequate for >> powering 2 or 3 devices. >> >> -------- >> Joe Gores >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=464454#464454 >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Dec 28, 2016
Read this post about charging an iPad: http://www.matronics.com/digest/aeroelectric-list/Digest.AeroElectric-List.2012-09-17.html#MESSAGE7 There must be voltage on USB pins 2 & 3 to signal the iPad to draw more charging current. Use a voltage divider with no resistor less than 10K ohm. Below is quote from the above mentioned post: > Here's what your USB receptacle needs to provide to properly quick-charge your iPad (for iPhones, reverse pins 2 and 3): > Pin 1 (+V): 5V (no less; ideally ~5.2V) > Pin 2 (D-): 2.00V > Pin 3 (D+): 2.75V > Pin 4: Ground -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464458#464458 ________________________________________________________________________________
Date: Dec 28, 2016
Good point, thanks! I believe those pins are shorted presently. On December 28, 2016 22:18:43 "user9253" wrote: > > Read this post about charging an iPad: > http://www.matronics.com/digest/aeroelectric-list/Digest.AeroElectric-List.2012-09-17.html#MESSAGE7 > There must be voltage on USB pins 2 & 3 to signal the iPad to draw more > charging current. Use a voltage divider with no resistor less than 10K > ohm. Below is quote from the above mentioned post: > >> Here's what your USB receptacle needs to provide to properly quick-charge >> your iPad (for iPhones, reverse pins 2 and 3): >> Pin 1 (+V): 5V (no less; ideally ~5.2V) >> Pin 2 (D-): 2.00V >> Pin 3 (D+): 2.75V >> Pin 4: Ground > > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=464458#464458 > > ________________________________________________________________________________
Date: Dec 29, 2016
In the four years since I wrote that, Apple has released a fourth charging s cheme for their 12-watt (5V, 2.4A) chargers that began shipping with the iPa d Air. If you configure your USB port as follows, it will rapid-charge all b ut the earliest Apple iDevices: Pin 1 (+V): 5.0V-5.2V Pin 2 (D-): 2.75V Pin 3 (D+): 2.75V Pin 4: Ground Note that Pins 2 and 3 are the same voltage, but they must *not* be shorted t ogether. Use two identical voltage dividers to provide the same voltage to b oth pins separately. For the voltage converter that Joe purchased (output = 5.1V), I would use a voltage divider comprised of 11.8k over 13.7k. Connect as follows: 5V --> 11.8k --> USB Pin 2 or 3 --> 13.7k --> Ground Suitable resistors: http://www.digikey.com/product-detail/en/yageo/MFR-25FBF52-11K8/11.8KXBK-ND/ 13232 -and- http://www.digikey.com/product-detail/en/yageo/MFR-25FBF52-13K7/13.7KXBK-ND/ 13244 One other note. Use heavier wire on the 5V output than the charging current would normally call for. Resistive voltage drop can easily cause the 5V ra il to fall below 5V over a modest wire length, which will change the D+ and D - voltages as well. Apple devices are picky -- it's important that +V, D+ a nd D- are correct. Eric > On Dec 28, 2016, at 8:11 PM, user9253 wrote: > Read this post about charging an iPad: > http://www.matronics.com/digest/aeroelectric-list/Digest.AeroElectric-List .2012-09-17.html#MESSAGE7 > There must be voltage on USB pins 2 & 3 to signal the iPad to draw more ch arging current. Use a voltage divider with no resistor less than 10K ohm. B elow is quote from the above mentioned post: > >> Here's what your USB receptacle needs to provide to properly quick-charge your iPad (for iPhones, reverse pins 2 and 3): >> Pin 1 (+V): 5V (no less; ideally ~5.2V) >> Pin 2 (D-): 2.00V >> Pin 3 (D+): 2.75V >> Pin 4: Ground ________________________________________________________________________________
Date: Dec 29, 2016
Subject: USB
Guys I have noticed some USB ports will charge a Samsung or other device and not an I-phone or other I-thingy. Is one available that wold do both or do I have a faulty port. Bobby analog guy in a digital world ________________________________________________________________________________
Date: Dec 29, 2016
QW0gSSBjb3JyZWN0IGluIGFzc3VtaW5nIHRoYXQgaWYgSSB3aXJlIGEgVVNCIHBvcnQgdGhpcyB3 YXkgZm9yIGFuIEFwcGxlIGRldmljZSwgdGhhdCBpdCB3aWxsIGJlIGNvbXBhcmFibGUgd2l0aCBh bGwgb3RoZXIgQW5kcm9pZCBkZXZpY2VzLgoKUm9nZXIKCgoKU2VudCBmcm9tOiBZT0dBIFRBQkxF VCAxMCBIRCsKCkVyaWMgUGFnZSA8ZWRwYXY4ckB5YWhvby5jb20+IHdyb3RlOgoKPkludGhlZm91 cnllYXJzc2luY2VJd3JvdGV0aGF0LEFwcGxlaGFzcmVsZWFzZWRhZm91cnRoY2hhcmdpbmdzY2hl bWVmb3J0aGVpcjEyLXdhdHQoNVYsMi40QSljaGFyZ2Vyc3RoYXRiZWdhbnNoaXBwaW5nd2l0aHRo ZWlQYWRBaXIuSWZ5b3Vjb25maWd1cmV5b3VyVVNCcG9ydGFzZm9sbG93cyxpdHdpbGxyYXBpZC1j aGFyZ2VhbGxidXR0aGVlYXJsaWVzdEFwcGxlaURldmljZXM6UGluMSgrVik6NS4wVi01LjJWUGlu MihELSk6Mi43NVZQaW4zKEQrKToyLjc1VlBpbjQ6R3JvdW5kTm90ZXRoYXRQaW5zMmFuZDNhcmV0 aGVzYW1ldm9sdGFnZSxidXR0aGV5bXVzdCpub3QqYmVzaG9ydGVkdG9nZXRoZXIuVXNldHdvaWRl bnRpY2Fsdm9sdGFnZWRpdmlkZXJzdG9wcm92aWRldGhlc2FtZXZvbHRhZ2V0b2JvdGhwaW5zc2Vw YXJhdGVseS5Gb3J0aGV2b2x0YWdlY29udmVydGVydGhhdEpvZXB1cmNoYXNlZChvdXRwdXQ9NS4x ViksSXdvdWxkdXNlYXZvbHRhZ2VkaXZpZGVyY29tcHJpc2Vkb2YxMS44a292ZXIxMy43ay5Db25u ZWN0YXNmb2xsb3dzOjVWLS0xMS44ay0tVVNCUGluMm9yMy0tMTMuN2stLUdyb3VuZFN1aXRhYmxl cmVzaXN0b3JzOmh0dHA6Ly93d3cuZGlnaWtleS5jb20vcHJvZHVjdC1kZXRhaWwvZW4veWFnZW8v TUZSLTI1RkJGNTItMTFLOC8xMS44S1hCSy1ORC8xMzIzMi1hbmQtaHR0cDovL3d3dy5kaWdpa2V5 LmNvbS9wcm9kdWN0LWRldGFpbC9lbi95YWdlby9NRlItMjVGQkY1Mi0xM0s3LzEzLjdLWEJLLU5E LzEzMjQ0T25lb3RoZXJub3RlLlVzZWhlYXZpZXJ3aXJlb250aGU1Vm91dHB1dHRoYW50aGVjaGFy Z2luZ2N1cnJlbnR3b3VsZG5vcm1hbGx5Y2FsbGZvci5SZXNpc3RpdmV2b2x0YWdlZHJvcGNhbmVh c2lseWNhdXNldGhlNVZyYWlsdG9mYWxsYmVsb3c1Vm92ZXJhbW9kZXN0d2lyZWxlbmd0aCx3aGlj aHdpbGxjaGFuZ2V0aGVEK2FuZEQtdm9sdGFnZXNhc3dlbGwuQXBwbGVkZXZpY2VzYXJlcGlja3kt LWl0J3NpbXBvcnRhbnR0aGF0K1YsRCthbmRELWFyZWNvcnJlY3QuRXJpY09uRGVjMjgsMjAxNixh dDg6MTFQTSx1c2VyOTI1M2ZyYW5zZXdAZ21haWwuY29td3JvdGU6UmVhZHRoaXNwb3N0YWJvdXRj aGFyZ2luZ2FuaVBhZDpodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vZGlnZXN0L2Flcm9lbGVjdHJp Yy1saXN0L0RpZ2VzdC5BZXJvRWxlY3RyaWMtTGlzdC4yMDEyLTA5LTE3Lmh0bWwjTUVTU0FHRTdU aGVyZW11c3RiZXZvbHRhZ2VvblVTQnBpbnMyM3Rvc2lnbmFsdGhlaVBhZHRvZHJhd21vcmVjaGFy Z2luZ2N1cnJlbnQuVXNlYXZvbHRhZ2VkaXZpZGVyd2l0aG5vcmVzaXN0b3JsZXNzdGhhbjEwS29o bS5CZWxvd2lzcXVvdGVmcm9tdGhlYWJvdmVtZW50aW9uZWRwb3N0OkhlcmUnc3doYXR5b3VyVVNC cmVjZXB0YWNsZW5lZWRzdG9wcm92aWRldG9wcm9wZXJseXF1aWNrLWNoYXJnZXlvdXJpUGFkKGZv cmlQaG9uZXMscmV2ZXJzZXBpbnMyYW5kMyk6UGluMSgrVik6NVYobm9sZXNzO2lkZWFsbHl+NS4y VilQaW4yKEQtKToyLjAwVlBpbjMoRCspOjIuNzVWUGluNDpHcm91bmQ ________________________________________________________________________________
Date: Dec 29, 2016
Subject: Re: USB
At 07:11 AM 12/29/2016, you wrote: Guys I have noticed some USB ports will charge a Samsung or other device and not an I-phone or other I-thingy. Is one available that wold do both or do I have a faulty port. There are USB ports . . . and then their are USB ports. The legacy USB port was conceived as a bi-directional, serial data port for SMALL accessories like thumb drives, mice, keyboards, etc. Power supplied from this port was offered at rather small rates . . . 100 to 500 milliamperes. Many computers were fitted with positive temperature coefficient current limiters (poly-fuses) to protect the computer from damage should the +5 volt USB power line become overloaded. Years later, new kids on the block (phones, tablets, etc.) found it useful to exploit that handy source of regulated voltage to charge internal batteries while in communication with a host computer . . . or even as a low-power charging source where leaving one's device on-charge overnight was no big deal. Simultaneously, demands on performance for USB ports evolved with ever higher transfer speeds. Accessories that exploited USB ports also evolved . . . there are electro-mechanical hard drives that will function solely on a 5 volt power supply while demanding less than 500mA. Then came the big kids. Tablets and larger smart phones that communicate with other devices via, you guessed it, USB ports. At he same time, their energy needs for both function and battery charging grew to 3 or 4 times that which the computer-based USB port could provide. This gave rise to proprietary chargers capable of 1 amp or more of 5v power. Problem was that if you configured your mini-super-pc to demand say 2A of battery recharge current, how do you keep it from overwhelming the 5v source on a legacy USB computer port? Instead of 'smart source ports' on computers, high-demand appliances evolved into 'smart-loads'. When the USB port was being used for only functional and/or battery charging power, then idle data lines could be used to tell the smart load how much power was available. Over the years, proprietary chargers lead the way to mostly accepted standards for tying idle data lines to each other or perhaps tying them to +5 or ground with certain size resistors. This little hat-dance in the source connector informed smart-loads as to how much energy was available. I have at least one device that annunciates "slow charging" behavior when plugged into a computer . . . with no such annunciation when being powered with a high-current source. The SHORT story in this thread tells us that it is insufficient to simply craft robustly powered, panel-mounted USB receptacles with an expectation of maximizing exploitation of that source. I've not taken time to study USB charging philosophies in detail but know that there is a lot of data on the techniques available on the 'net. It's a sure bet that any DIY power sources for your favorite cockpit companion may need a bit more information as to who much power is available. lacking such information will most certainly force the appliance into a 'slow charge' mode. Bob . . . --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Dec 29, 2016
I'm not sure what an Android device (a generic term for devices from many ma nufacturers) will make of an Apple charger. It won't do it any harm, but I d on't know if it will charge. Samsung, for example, uses a common (shorted) 1 .25V on both data pins. Someone mentioned that the data pins on his charger are shorted together. T hat defines a Dedicated Charging Port (and a Chinese standard). Most device s will accept this scheme, but will only draw 0.5A in accordance with the US B standard. That's why a device will hold steady under use but not add char ge. There are integrated circuits designed for this purpose that monitor a USB p ort and automatically configure the port to satisfy the device that's plugge d into it. They work fine, but they're a pain to use as they're all in tiny surface-mount packages. Eric > On Dec 29, 2016, at 7:11 AM, rnjcurtis wrote: > > Am I correct in assuming that if I wire a USB port this way for an Apple d evice, that it will be comparable with all other Android devices. > > Roger > > > > Sent from: YOGA TABLET 10 HD+ > > Eric Page wrote: > > In the four years since I wrote that, Apple has released a fourth charging scheme for their 12-watt (5V, 2.4A) chargers that began shipping with the i Pad Air. If you configure your USB port as follows, it will rapid-charge al l but the earliest Apple iDevices: > > Pin 1 (+V): 5.0V-5.2V > Pin 2 (D-): 2.75V > Pin 3 (D+): 2.75V > Pin 4: Ground > > Note that Pins 2 and 3 are the same voltage, but they must *not* be shorte d together. Use two identical voltage dividers to provide the same voltage t o both pins separately. > > For the voltage converter that Joe purchased (output = 5.1V), I would us e a voltage divider comprised of 11.8k over 13.7k. > > Connect as follows: 5V --> 11.8k --> USB Pin 2 or 3 --> 13.7k --> Ground > > Suitable resistors: > http://www.digikey.com/product-detail/en/yageo/MFR-25FBF52-11K8/11.8KXBK-N D/13232 > -and- > http://www.digikey.com/product-detail/en/yageo/MFR-25FBF52-13K7/13.7KXBK-N D/13244 > > One other note. Use heavier wire on the 5V output than the charging curre nt would normally call for. Resistive voltage drop can easily cause the 5V r ail to fall below 5V over a modest wire length, which will change the D+ and D- voltages as well. Apple devices are picky -- it's important that +V, D+ and D- are correct. > > Eric > > >> On Dec 28, 2016, at 8:11 PM, user9253 wrote: >> Read this post about charging an iPad: >> http://www.matronics.com/digest/aeroelectric-list/Digest.AeroElectric-Lis t.2012-09-17.html#MESSAGE7 >> There must be voltage on USB pins 2 & 3 to signal the iPad to draw more c harging current. Use a voltage divider with no resistor less than 10K ohm. Below is quote from the above mentioned post: >> >>> Here's what your USB receptacle needs to provide to properly quick-charg e your iPad (for iPhones, reverse pins 2 and 3): >>> Pin 1 (+V): 5V (no less; ideally ~5.2V) >>> Pin 2 (D-): 2.00V >>> Pin 3 (D+): 2.75V >>> Pin 4: Ground ________________________________________________________________________________
Date: Dec 29, 2016
Subject: Solder-sleeves with pigtails
Some time back, I had a fire-sale on solder-sleeves . . . Demand was more than I could supply. Ran out in about a week. For those who were left wishing, here's an offer at MPJA http://tinyurl.com/grp3z2c Bob . . . --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Dec 29, 2016
Some time back I wrote: >When selecting wires and protection, you're >never wrong with the "legacy pairs" of >22AWG/5A, 20AWG/7A, 18AWG/10A, etc. etc. >These are very conservative pairings. I thought of a quality unique to fuses that justifies a departure from the 'leggacy pairing' cited above. Fuses and Circuit breakers have one thing in common . . . they operated based on the HEATING effect of a current flowing in a component having some resistance . . . I.e. a voltage drop that liberates heat due to 'lost' energy. The similarity ends there. Circuit breakers have bi-metal components which are close cousins to thermostats. Heating produces a change in shape that causes some latching mechanism to release at a predictable temperature rise. On the other hand, the resistive current sensing component of a fuse is solid metal alloy designed to MELT when a certain temperature is reached. Conversion from a SOLID to a LIQUID calls for a phase change that exhibits a kind of plateau that cannot be exceeded until a unique quantum of heat has been delivered into the mass. In water, the heat removed in the change of phase from liquid to solid is called the 'heat of fusion' and if memory serves, is about 80 cal/gm for water. This means that you can have ice at 0C and water at 0C . . . but for every gram of ice at 0C you have to pump 80 cal of heat into it just to convert to liquid water. Every material, including the melting link in a fuse has a similar characteristic. This is important in the specification of fuses to a particular task. While a circuit breaker is a simplified 'thermostat' . . . capable of repeated operations with no change of calibration. On the other hand a fuse can, if you will, be 'hammered'. Let's say you have a 5A fuse loaded to 4A but subjected to an 8A transient measured in tens of milliseconds. On the bench you can subject the fuse to this stress many times with no failure. Such an event, say once per flight cycle in an airplane, may never produced a nuisance trip . . . or it may happen after tens or hundreds of flight hours. It doesn't happen very often, but ONE TIME may be too many for individuals who suffer the event. An excellent case in point . . . http://tinyurl.com/msfmldj Through a combination of events and poor design choices, fuses in the accident aircraft were subject to transient stresses that 'hammered' at the edge for heat-of-fusion on first one and then the second of two fuses . . . a failure that insured simultaneous failure of both ignition systems. The point to be pondered here illustrates the value of failure mode effects analysis in deducing risks associated with the failure of any single component. When unacceptable risks are identified, changes to selection components and system architecture will easily negate the risk. THE BEST prophylactics against risk for popping a 'hammered' fuse is to design the system such that loss of that system is no-big-deal. After all, there a dozens of OTHER reasons the fuse might open. Be prepared for ANY event. Based on what we know about the relative fragility of a 22AWG wire, a 5A, nuisance tripping fuse on a 22AWG feeder can be comfortably replaced with a 7A fuse. As a general rule, the engineering data on fuses suggests they not be continuously loaded to more than 75% of rating at 25C. http://tinyurl.com/zobgmdv If situated in an environment routinely hotter than 25C, perhaps de-rating to 50% is in order. This thinking supports the notion that a fuse under the cowl driving a 22AWG feeder loaded to 4A continuously might be 'protected' at 10A. It's not radical thinking . . . they do this in cars all the time. Bob . . . --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Subject: Re: USB
Date: Dec 30, 2016
At least in the Apple world, the resistor network which informs the device to be charged of the charger's capability and compatibility is actually in the charging cord. If I remember the tech specs, the amperage capacity is detected by voltage drop across the resistor. Bottom Line: If you want to charge an iPad or iPhone use a "genuine" Lightning cord. -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464480#464480 ________________________________________________________________________________
Date: Dec 30, 2016
Subject: USB
Thank you Bob and Eric for the explanations. Great information for an old geezer. bobby ________________________________________________________________________________
Date: Dec 30, 2016
Subject: Re: USB
On Fri, Dec 30, 2016 at 5:43 AM, rampil wrote: > > At least in the Apple world, the resistor network which informs the > device to be charged of the charger's capability and compatibility is > actually in the charging cord. If I remember the tech specs, the amperage > capacity is detected by voltage drop across the resistor. > Bottom Line: If you want to charge an iPad or iPhone use a "genuine" > Lightning cord. > > -------- > Ira N224XS > > > Or, simply stay away from that world.... ;-) ________________________________________________________________________________
Subject: USB
Date: Dec 30, 2016
Earlier today, someone said that to charge an Apple device, you had to use an Apple lightning coord. That is partially true, in that a cord sourced from Apple WILL work, but there are alternatives - and some are much better than Apple's own lightning cords. The "trick" is to purchase only "Apple MFi Certified" lightning cords. My personal choice for the supplier is Anker - sold through Amazon. They make MFi certified cords (complete with the unique authorization chip like Apple uses) that work beautifully with all Apple devices, are available in multiple lengths (1,3, 6, and 10 feet) and in several colors (red, white, blue, gold, space gray), all for very reasonable prices (much lower than Apple's own flimsy cables). I've never seen the "unapproved charging cable" notice when using an Anker cable. My favorite is the double-braided nylon-sheathed PowerLine+ cables. I use a "space gray" 6-ft version to charge my iPad Mini in flight, so that the cable 'disappears' when laid across my gray glareshield cover. I like the longer cable for this purpose, because my charging port (cigar lighter with an Anker 2-port USB adapter) is on the right side, but mounting the iPad there would interfere with entry/egress, so I have to mount it on the opposite side of the airplane. These double-braided nylon sheathed cables are very durable, far more flexible than standard cables, and they don't seem to tangle as much. They even come with a magnet-closed "cover" to keep the cord neat when not in use. I know it probably seems crazy to be this enthusiastic about such a trivial product, but after spending $20 on "genuine Apple" lightning cables, only to have the ends rip off, or the insulation covers develop holes that lead to kinks and shorts, finding a much-less-expensive alternative that not only works well, but is virtually indestructible just makes my day. I've given many of these cables as "stocking stuffer" gifts to my kids and family, and everyone just loves them. For those of you who use non-Apple devices, Anker also makes standard Micro USB and USB-C cables (with all the same options) for those devices (most Android phones and tablets). They also make a pretty nice 2-port USB adapter for you cigar lighter that will charge two 2.1A devices simultaneously (2 iPads, or 1 iPad and 1 iPhone, as I use). And, just for the record, I don't work for, or have any interest in Anker other than as a very satisfied customer. Jim Parker ________________________________________________________________________________
Date: Dec 30, 2016
Hi Neal and Art; Google "wire ties with mounting holes." Morris Products makes several types. Cheers! Stu. ----- Original Message ----- From: "Neal George" <neal.george(at)gmail.com> Sent: Tuesday, December 27, 2016 9:11:53 AM Subject: Re: AeroElectric-List: Securing Split PVC Conduit A dab of RTV? Neal George Sent from my iPhone On Dec 26, 2016, at 10:05 PM, Art Zemon < art(at)zemon.name > wrote: Folks, I am using some split PVC conduit in my plane and two of the runs are pretty close to vertical, about 4 feet long. Sitting in my garage, with the wires not yet secured at the bottom, the conduit keeps trying to slide downward in the 2 inch square channels through which it runs. I think that I ought to secure it somehow and wonder if you have any ideas that will keep it in place. Maybe I can wrap a thin cable tie around it and get it to slip into a groove? Or maybe wrap it with silicone self-sealing tape and the put an AN742 clamp around it? Thanks, -- Art Z. -- https://CheerfulCurmudgeon.com/ "If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel ________________________________________________________________________________
Date: Dec 30, 2016
Subject: Re: USB
There's no way a cord could know the capability of a plug adapter unless the adapter signals it in some way. The device in Apple's charging cords (and, as Jim pointed out, in MiFi Certified cords) is an integrated circuit used for authentication. It still looks for the signaling voltages on D+ and D-, which current Apple plug adapters provide. The plug adapters are still using simple resistor dividers to generate the 2.75V signals. Eric > On Dec 30, 2016, at 3:43 AM, rampil wrote: > At least in the Apple world, the resistor network which informs the device to be charged of the charger's capability and compatibility is actually in the charging cord. If I remember the tech specs, the amperage capacity is detected by voltage drop across the resistor. Bottom Line: If you want to charge an iPad or iPhone use a "genuine" Lightning cord. > > -------- > Ira N224XS ________________________________________________________________________________
Date: Dec 30, 2016
Subject: Re: USB
Is this contrary to Joe's advice about sensing voltage across the two USB data pins, or in addition to it? On Fri, Dec 30, 2016 at 6:43 AM, rampil wrote: > > At least in the Apple world, the resistor network which informs the > device to be charged of the charger's capability and compatibility is > actually in the charging cord. If I remember the tech specs, the amperage > capacity is detected by voltage drop across the resistor. > Bottom Line: If you want to charge an iPad or iPhone use a "genuine" > Lightning cord. > > -------- > Ira N224XS > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=464480#464480 > > ________________________________________________________________________________
Subject: Re: USB
Date: Dec 30, 2016
This is not correct. The charging resistor network is in the charger. However if you use a super-cheap charging cord, the wire gauge may not be large enough. When the iPhone (or whatever) detects the charger voltage drop below a certain voltage (maybe 4.8V?) it will back off until the voltage comes back up. So based on the resistance of the cable, the device may not be able to charge as quickly as it otherwise would. Both pieces have to be in place for an optimal charge time. > On Dec 30, 2016, at 5:43 AM, rampil wrote: > > At least in the Apple world, the resistor network which informs the > device to be charged of the charger's capability and compatibility is > actually in the charging cord ________________________________________________________________________________
Subject: Re: USB
Date: Dec 30, 2016
> On Dec 30, 2016, at 3:23 PM, Daniel Hooper wrote: > > This is not correct. The charging resistor network is in the charger. > This is not correct. The charging resistor network is in the cord, not the charger. You can take a charger that provides a USB powered port, plug a cord without the resistor network into it, and the Apple device will not charge. Use the same charger with a cord that does have the resistor network, and it will charge fine. The amp rating of the charger does have an effect on the rate of charge, but the resistor network is not in the charger, it is in the cord. -Dj ________________________________________________________________________________
Subject: Re: USB
Date: Dec 30, 2016
Maybe this is what you=99re talking about? http://appleinsider.com/articles/12/09/25/apples_lightning_port_dynamicall y_assigns_pins_to_allow_for_reversible_use <http://appleinsider.com/articles/12/09/25/apples_lightning_port_dynamical ly_assigns_pins_to_allow_for_reversible_use> It=99s a bad idea to use a non-MFI Lightning cable in any case, for this reason. But the D+/D- line bias network that tells the phone how fast it is allowed to charge is DEFINITELY located inside the charger. There are a decent number of standards between the various Apple configurations, newer USB standards, and a Chinese standard, so having an MFI cable for you phone and a Samsung charger is no guarantee of success. There are chips (ICs) made for chargers out there that can (somehow) sense which kind of device is attached and adjust its resistor network to allow the maximum charging for any type, but it is difficult to tell whether this chip was designed into the charger. > On Dec 30, 2016, at 3:09 PM, Dj Merrill wrote: > > > >> On Dec 30, 2016, at 3:23 PM, Daniel Hooper wrote: >> >> This is not correct. The charging resistor network is in the charger. >> > > This is not correct. The charging resistor network is in the cord, not the charger. > > You can take a charger that provides a USB powered port, plug a cord without the resistor network into it, and the Apple device will not charge. Use the same charger with a cord that does have the resistor network, and it will charge fine. > > The amp rating of the charger does have an effect on the rate of charge, but the resistor network is not in the charger, it is in the cord. > > -Dj > > > > > > ________________________________________________________________________________
Subject: Re: USB
Date: Dec 30, 2016
On 12/30/2016 4:47 PM, Daniel Hooper wrote: > But the D+/D- line bias network that tells the phone how fast it is > allowed to charge is DEFINITELY located inside the charger. If you buy a cable that is supposed to plug into a USB port, the resistor network is most definitely inside the cable, if for no other reason than your computer USB port (ie, the charger aka power source) is not customized for Apple devices. This is true for both the older style plugs (iphone 4s and earlier for example) and the new lightning connector for the later devices. In addition, the newer lightning connector has other circuitry built into it like the MFi authorization chip. You might be able to buy a charger that has the resistive network built into it, but from what I've seen it is common to put this inside the cable such that the cable can then be used with any charger that offers a USB port. Here is an example of a lightning cable that has it built in: https://www.amazon.com/Anker-PowerLine-Lightning-Certified-Charger/dp/B013JMBAMC/ Here is an example of an older iPhone 4s cable that has it built in: https://www.amazon.com/iPhone-JETech-3-Pack-Certified-Charging/dp/B015V7XB5C/ I haven't seen a charger that has the resistive network built into it, and didn't find one from a quick search on Amazon. Can you offer a link that has this in the charger itself, and not the cable? Thanks, -Dj -- Dj Merrill - N1JOV - EAA Chapter 87 Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Subject: Re: USB
Date: Dec 30, 2016
To make it even more confusing, there are differences in USB 1, 2, and DCP (Dedicated Charging Port) which also have different resistor networks across D+ and D-. However, Apple, in its infinite wisdom (sarcasm) didn't use the standards, thus causing one to have to buy special USB cables to be recognized as one that would actually charge the device, otherwise you get "Charging is not supported with this accessory" or similar message on the iPhone. That special resistor network built into the cables what we are referring to, if that helps to clarify things. -Dj -- Dj Merrill - N1JOV - EAA Chapter 87 Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Subject: Re: USB
Date: Dec 30, 2016
If you buy genuine Apple cables they do not have this built in =94 that is a special cable that potentially tells the iPhone that it can draw more current than the charger may be capable of. I suspect those items counterfeit MFI for that reason =94 highly nonstandard. It=99s possible that they have loosened the standards for accessory products, but in my experience they keep the leash pretty taut. The truth is that the resistor network is in EVERY charger that is intended for Apple devices, and some configuration or other (USB charging standard or Chinese charging standard) is present in nearly every other one. Some chargers, as I mentioned before, have a chip that can switch between the standards automatically. Here is the evidence in Ken Sherriff=99s Apple charger teardown: http://www.righto.com/2012/05/apple-iphone-charger-teardown-quality.html <http://www.righto.com/2012/05/apple-iphone-charger-teardown-quality.html> In the schematic he drew from examination, http://static.righto.com/files/charger-schematic.pdf <http://static.righto.com/files/charger-schematic.pdf> you can see the ID network there on page 2 of the schematic, R5, R6, R7, and R9. There are also many reference designs for USB chargers that include these or some similar configuration of resistors. > On Dec 30, 2016, at 4:47 PM, Dj Merrill wrote: > > > On 12/30/2016 4:47 PM, Daniel Hooper wrote: >> But the D+/D- line bias network that tells the phone how fast it is >> allowed to charge is DEFINITELY located inside the charger. > > > If you buy a cable that is supposed to plug into a USB port, the resistor network is most definitely inside the cable, if for no other reason than your computer USB port (ie, the charger aka power source) is not customized for Apple devices. This is true for both the older style plugs (iphone 4s and earlier for example) and the new lightning connector for the later devices. In addition, the newer lightning connector has other circuitry built into it like the MFi authorization chip. > > You might be able to buy a charger that has the resistive network built into it, but from what I've seen it is common to put this inside the cable such that the cable can then be used with any charger that offers a USB port. > > Here is an example of a lightning cable that has it built in: > https://www.amazon.com/Anker-PowerLine-Lightning-Certified-Charger/dp/B013 JMBAMC/ > > Here is an example of an older iPhone 4s cable that has it built in: > https://www.amazon.com/iPhone-JETech-3-Pack-Certified-Charging/dp/B015V7XB 5C/ > > I haven't seen a charger that has the resistive network built into it, and didn't find one from a quick search on Amazon. Can you offer a link that has this in the charger itself, and not the cable? > > Thanks, > > -Dj > > -- > Dj Merrill - N1JOV - EAA Chapter 87 > Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ > Glastar Flyer N866RH - http://deej.net/glastar/ > > > > ________________________________________________________________________________
Subject: Re: USB
Date: Dec 30, 2016
Read what this guy has to say about it. I haven=99t used his products, so I can=99t vouch for them, but I heard him give a talk at Oshkosh about USB charging and it was right on. These products you have here are what he calls a =9Ccheater cable=9D. He even has an =9Cintelligent charger=9D module that (I believe) has the smart resistor switching IC in it. http://www.commitlift.com/usbchargers.html <http://www.commitlift.com/usbchargers.html> Sidenote: =9CAdaptive Fast Charging=9D that he talks about is a whole different mess. > On Dec 30, 2016, at 4:47 PM, Dj Merrill wrote: > > > On 12/30/2016 4:47 PM, Daniel Hooper wrote: >> But the D+/D- line bias network that tells the phone how fast it is >> allowed to charge is DEFINITELY located inside the charger. > > > If you buy a cable that is supposed to plug into a USB port, the resistor network is most definitely inside the cable, if for no other reason than your computer USB port (ie, the charger aka power source) is not customized for Apple devices. This is true for both the older style plugs (iphone 4s and earlier for example) and the new lightning connector for the later devices. In addition, the newer lightning connector has other circuitry built into it like the MFi authorization chip. > > You might be able to buy a charger that has the resistive network built into it, but from what I've seen it is common to put this inside the cable such that the cable can then be used with any charger that offers a USB port. > > Here is an example of a lightning cable that has it built in: > https://www.amazon.com/Anker-PowerLine-Lightning-Certified-Charger/dp/B013 JMBAMC/ > > Here is an example of an older iPhone 4s cable that has it built in: > https://www.amazon.com/iPhone-JETech-3-Pack-Certified-Charging/dp/B015V7XB 5C/ > > I haven't seen a charger that has the resistive network built into it, and didn't find one from a quick search on Amazon. Can you offer a link that has this in the charger itself, and not the cable? > > Thanks, > > -Dj > > -- > Dj Merrill - N1JOV - EAA Chapter 87 > Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ > Glastar Flyer N866RH - http://deej.net/glastar/ > > > > ________________________________________________________________________________
Subject: Re: USB
Date: Dec 30, 2016
On 12/30/2016 6:11 PM, Daniel Hooper wrote: > If you buy genuine Apple cables they do not have this built in My curiosity was piqued so I conducted a couple of experiments. I took a genuine Apple cable that works with my Apple charger for an iPhone 4s, and plugged it into a Windows 7 PC USB port. It seems to work fine, and charges the iPhone 4s without displaying any error messages on the screen. I repeated the same test with an Apple lightning cable and Iphone SE with the same results. If there wasn't anything built into the cable, how did this work properly? Let's find out. This video gives a good explanation of how the Apple protocol works with regards to the resistive network used for the iPhone 4s: https://learn.adafruit.com/minty-boost/icharging?embeds=allow We know that the different USB ports (USB 1, 2, 3, etc) offer different power ratings (https://en.wikipedia.org/wiki/USB). The power rating is identified by using different resistances related to the two data pins, (D+ and D-). It would appear that the iPhone recognizes the standard USB identification resistances, and can therefore use a standard USB port to charge. In addition, Apple has another set of proprietary resistances that identify power ratings that are different than the USB standard, and they use these in their chargers. So, the answer to my question above is that it worked because in all of my test cases there were resistors across the data lines, both in the USB ports and the Apple charger. I stand corrected, and the only explanation is that the resistive network indeed exists within the charger, not the cable. The "cheater cables" you refer to were for using non-Apple chargers, whether wall chargers or the "cigarette lighter" variety that had no resistance across the data lines, and the resistors were added in the cable so the iPhone would work. I actually built one of these cables years ago, and made the incorrect conclusion that the resistive network identifier was in all the cables. -- Dj Merrill - N1JOV - EAA Chapter 87 Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Subject: Re: USB
Date: Dec 30, 2016
Thank you for taking the time to understand what is going on here. It=99s fairly complicated and the non-standard hardware that people use to get around all sorts of issues only makes it worse. For what it=99s worth, Apple has been using the line bias resistors since before there was a USB charging standard. There=99s one last point that you=99ve got a little wonky: > On Dec 30, 2016, at 6:28 PM, Dj Merrill wrote: > > It would appear that the iPhone recognizes the standard USB identification resistances Your test by plugging your phone into a computer doesn=99t tell you everything you want to know. Computer ports have a fully digital power-negotiation protocol that is built into the original USB 1.0 standard (up to 500mA). Because of this extra hardware, the computer port does not need charger ID resistors. There are SOME computers that have a type of dedicated charging port that can serve even when the computer is turned off, but this is not a typical setup. In some cases you may get a charging indication with a simple 5V power supply (no USB 2.0 communication, no ID resistors). BUT the phone will only draw around 500mA if it does anything. This is not enough current to keep the battery charged with the screen on, so the battery will slowly run down even though it is indicating a charge. What the ID resistors do is tell the phone =9Chey, go nuts! I=99 ve got 1A (or 2A or 2.1A) for you here!=9D, which will charge the phone with various levels of speed. The real struggle is getting the optimum charging rate out of your charger, no matter what device you have. That=99s the holy grail, and you have to spend a few bucks to get that functionality in a charger. (also assuming you aren=99t using a crappy cable) There=99s no great way to test for this function as a consumer and there=99s no real standard way for manufacturers to communicate that functionality effectively, since so many of the cheap ones lie about what they do. ________________________________________________________________________________
Date: Dec 30, 2016
Subject: Re: USB
This has all been really useful discussion, thank you! To take it from the theoretical to the actionable (I'm ready to get out my soldering iron), do we have a specific list of resistors and a schematic to get the appropriate volts on the data pins if we use something like the 5v power supply that Joe linked in the beginning of the discussion? It seems that there's no need for all of us to do the trial and error if we have the same volts coming in and the same device connected to the plug. On Fri, Dec 30, 2016 at 7:59 PM, Daniel Hooper wrote: > Thank you for taking the time to understand what is going on here. > > It=99s fairly complicated and the non-standard hardware that people use to > get around all sorts of issues only makes it worse. > > For what it=99s worth, Apple has been using the line bias resistors since > before there was a USB charging standard. > > There=99s one last point that you=99ve got a little wonky: > > On Dec 30, 2016, at 6:28 PM, Dj Merrill wrote: > > It would appear that the iPhone recognizes the standard USB identificatio n > resistances > > > Your test by plugging your phone into a computer doesn=99t tell you > everything you want to know. > > Computer ports have a fully digital power-negotiation protocol that is > built into the original USB 1.0 standard (up to 500mA). Because of this > extra hardware, the computer port does not need charger ID resistors. > > There are SOME computers that have a type of dedicated charging port that > can serve even when the computer is turned off, but this is not a typical > setup. > > > In some cases you may get a charging indication with a simple 5V power > supply (no USB 2.0 communication, no ID resistors). BUT the phone will on ly > draw around 500mA if it does anything. This is not enough current to keep > the battery charged with the screen on, so the battery will slowly run do wn > even though it is indicating a charge. > > What the ID resistors do is tell the phone =9Chey, go nuts! I =99ve got 1A (or > 2A or 2.1A) for you here!=9D, which will charge the phone with vari ous levels > of speed. > > The real struggle is getting the optimum charging rate out of your > charger, no matter what device you have. That=99s the holy grail, a nd you > have to spend a few bucks to get that functionality in a charger. (also > assuming you aren=99t using a crappy cable) > > There=99s no great way to test for this function as a consumer and there=99s > no real standard way for manufacturers to communicate that functionality > effectively, since so many of the cheap ones lie about what they do. > ________________________________________________________________________________
Date: Dec 30, 2016
Subject: Re: Audio Isolation Amplifier Boards
Bob, Just noticed this. Would this be a good way to connect an xm roady music receiver to my audio panel? Background, The roady has no volume control and is intended to plug into a cassette player using the supplied adapter. I wired it directly to my Garmin audio panel. It worked fine except The volume was lower than needed. I am changing to a PS Engineering PDA 360XR audio panel that has music input volume controls. I am not sure that the new install will have adequate volume. Any ideas on how to increase the volume? On Thu, Dec 8, 2016 at 1:00 PM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > I've had a number of folks express and interst in > acquiring the boards to the DIY audio Isolation > amplifier. > > Interested purchases can be made from our > website at: > > http://tinyurl.com/cgr42l5 > > Put your order details in the Commends/Special Rquests > box at the bottom of the form. The boards are $22 ea > plus first class postage of $2.25 > > I'll plan on ordering boards on Monday . . . > > > Assembly instructions for this project are available > at: > > http://tinyurl.com/ngoo6hc > > > [image: Emacs!] > > Perhaps the better term is 'unpopulated'. It looks > like this when you're done. > > [image: Emacs!] > > > Bob . . . <http://??.htm> > > No virus found in this message. > Checked by AVG - www.avg.com > 11/27/16 > > > Bob . . . > ________________________________________________________________________________
Date: Dec 30, 2016
Bob, Just noticed this. Would this be a good way to connect an xm roady music receiver to my audio panel? Background, The roady has no volume control and is intended to plug into a cassette player using the supplied adapter. I wired it directly to my Garmin audio panel. It worked fine except The volume was lower than needed. I am changing to a PS Engineering PDA 360XR audio panel that has music input volume controls. I am not sure that the new install will have adequate volume. Any ideas on how to increase the volume? On Fri, Dec 30, 2016 at 6:32 PM, don van santen wrote: > Bob, > Just noticed this. Would this be a good way to connect an xm roady music > receiver to my audio panel? > Background, The roady has no volume control and is intended to plug into a > cassette player using the supplied adapter. I wired it directly to my > Garmin audio panel. It worked fine except The volume was lower than needed. > I am changing to a PS Engineering PDA 360XR audio panel that has music > input volume controls. I am not sure that the new install will have > adequate volume. Any ideas on how to increase the volume? > > On Thu, Dec 8, 2016 at 1:00 PM, Robert L. Nuckolls, III < > nuckolls.bob(at)aeroelectric.com> wrote: > >> I've had a number of folks express and interst in >> acquiring the boards to the DIY audio Isolation >> amplifier. >> >> Interested purchases can be made from our >> website at: >> >> http://tinyurl.com/cgr42l5 >> >> Put your order details in the Commends/Special Rquests >> box at the bottom of the form. The boards are $22 ea >> plus first class postage of $2.25 >> >> I'll plan on ordering boards on Monday . . . >> >> >> Assembly instructions for this project are available >> at: >> >> http://tinyurl.com/ngoo6hc >> >> >> [image: Emacs!] >> >> Perhaps the better term is 'unpopulated'. It looks >> like this when you're done. >> >> [image: Emacs!] >> >> >> >> >> Bob . . . <http://??.htm> >> >> No virus found in this message. >> Checked by AVG - www.avg.com >> 11/27/16 >> >> >> >> >> Bob . . . >> > > ________________________________________________________________________________
Subject: Re: USB
Date: Dec 30, 2016
Jared, This thread was somehow split from the original post on this subject a few d ays ago. If you look at the original thread, here... http://forums.matronics.com/viewtopic.php?t=16765274 ...in the 6th message I described exactly the info you're looking for. Another option, if you have the ability to lay out and solder a circuit boar d using surface mount components, is to use an IC like the Texas Instruments TPS2513A or TPS2514A: http://www.ti.com/lit/ds/symlink/tps2514.pdf Eric > On Dec 30, 2016, at 5:34 PM, Jared Yates wrote: > This has all been really useful discussion, thank you! To take it from the theoretical to the actionable (I'm ready to get out my soldering iron), do w e have a specific list of resistors and a schematic to get the appropriate v olts on the data pins if we use something like the 5v power supply that Joe l inked in the beginning of the discussion? It seems that there's no need for a ll of us to do the trial and error if we have the same volts coming in and t he same device connected to the plug. ________________________________________________________________________________
Date: Dec 31, 2016
Eric, Please verify that the "D-" data pin has a positive voltage even though it is labeled with a minus sign. Also, I assume that computers do not have voltage on the data pins because that would interfere with data transfer. Is that correct or wrong? Thanks, Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464510#464510 ________________________________________________________________________________
Subject: Airport Cafe's Now Listed in ACC's
Date: Dec 31, 2016
I have just added over 50 airport cafs (and still growing) to current listings in the Airport Courtesy Cars website and app (just in case your courtesy car isnt available when you arrive!) These listings are highlighted in red so you can easily find them. If you have any additions or corrections, please email them directly to me at airportcars101(at)gmail.com. Thanks and Happy New Year! Glenn PS, Submit your ramp fee's experience also for inclusion in the website/app! -------- Glenn Brasch RV-9A Flying Medevac Helicopter Pilot (Ret) Owner, "Airport Courtesy Cars" Smart Phone App and www.airportcourtesycars.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464547#464547 ________________________________________________________________________________
Date: Dec 31, 2016
Yes, for charging adapters, both voltages are positive. The D+ and D- labels refer to their use in USB data communications. You're correct. A computer's USB port won't have a constant voltage on the data pins like a charger has, but the voltage will rise and fall at very high speed to send digital data. Apple computers probably have a chip in the USB data path that communicates with their Lightning cable authentication chip (speculation on my part). As I mentioned in another post, there are dedicated charging port chips that sense the attached device and configure the data pin voltages appropriately. Eric > On Dec 31, 2016, at 6:29 AM, user9253 wrote: > Eric, > Please verify that the "D-" data pin has a positive voltage even though it is labeled with a minus sign. > Also, I assume that computers do not have voltage on the data pins because that would interfere with data transfer. Is that correct or wrong? > Thanks, Joe > > -------- > Joe Gores ________________________________________________________________________________
Subject: Best dimensions for conduits
Date: Jan 01, 2017
Hi all, Best wishes for 2017. What could be the dimensions of the conduit for the (nav/strobe lights, magnetometer, etc.) wires in the wing of a a composite aircraft ? There is plenty of room in the empty leading edge, but obviously the passage is too large and some means of attaching the wires seems in order. Any opinions on a practical way to use this long empty passage for wires ? Thanks in advance for your input, -- Best regards, Gilles http://contrails.free.fr ________________________________________________________________________________
Date: Jan 01, 2017
Subject: Re: Securing Split PVC Conduit
Holger, I think this will work perfectly. Thank you! The lacing will slip into the grooves on the conduit. I can attach nylon cable tie anchors to the airplane and lace the conduit to the anchors. Cheers, -- Art Z. On Tue, Dec 27, 2016 at 5:04 PM, Holger Selover-Stephan < holger-d(at)shadowbrush.com> wrote: > I=99ve used lacing tape for that purpose in the past. So friendly t o > do-overs. > > Holger > > > On Dec 26, 2016, at 7:05 PM, Art Zemon wrote: > > Folks, > > I am using some split PVC conduit > <http://www.hall-fast.com/consumables/electrical/cable-accessories/condui t-and-warning-tapes/pvc-split-conduit/> > in my plane and two of the runs are pretty close to vertical, about 4 fee t > long. Sitting in my garage, with the wires not yet secured at the bottom, > the conduit keeps trying to slide downward in the 2 inch square channels > through which it runs. I think that I ought to secure it somehow and wond er > if you have any ideas that will keep it in place. > > -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Subject: Re: Best dimensions for conduits
Date: Jan 01, 2017
Looking at your wings, I think I'd put some 1/2 to 3/4 auto wire loom protector in the wings, with zip ties so the wire does not work itself out of the split in the loom protector. Leave a nylon string in the protector that you can later use to pull wires. Later on, you can push a stiff wire through the loom protector and use it to pull wires. The loom protector is lightweight but will protect them from abrasion. -Kent Cozy & Long-EZ builder > On Jan 1, 2017, at 1:44 PM, GTH wrote: > > > Hi all, > > Best wishes for 2017. > > What could be the dimensions of the conduit for the (nav/strobe lights, magnetometer, etc.) wires in the wing of a a composite aircraft ? > There is plenty of room in the empty leading edge, but obviously the passage is too large and some means of attaching the wires seems in order. > Any opinions on a practical way to use this long empty passage for wires ? > Thanks in advance for your input, > -- > Best regards, > Gilles > http://contrails.free.fr > > > ________________________________________________________________________________
Date: Jan 01, 2017
Virtually everyone complains of running out of wire path volume at some point, so 'go big'. For choices, the split loom stuff does work. I like this stuff: https://www.techflex.com/prod_ccp.asp and https://www.techflex.com/prod_f6w.asp Very light weight and very flexible. The unsplit stuff works like the old 'Chinese finger cuffs' we played with as kids; the 1" stuff will expand to close to 1 1/2" if you push it together (make it shorter). And it will shrink to about 1/2" if you stretch it. You could install the max size with enough length for max diameter, and when you know everything is in, just pull on the ends to tighten it up (if you feel it's needed; I don't). Only downside to the closed stuff is that you'll need a smooth, more or less ball shaped end on whatever you pull through it, to avoid snagging on the weave. Charlie On 1/1/2017 2:08 PM, Kent or Jackie Ashton wrote: > > Looking at your wings, I think I'd put some 1/2 to 3/4 auto wire loom protector in the wings, with zip ties so the wire does not work itself out of the split in the loom protector. Leave a nylon string in the protector that you can later use to pull wires. Later on, you can push a stiff wire through the loom protector and use it to pull wires. The loom protector is lightweight but will protect them from abrasion. > -Kent > Cozy & Long-EZ builder > >> On Jan 1, 2017, at 1:44 PM, GTH wrote: >> >> >> Hi all, >> >> Best wishes for 2017. >> >> What could be the dimensions of the conduit for the (nav/strobe lights, magnetometer, etc.) wires in the wing of a a composite aircraft ? >> There is plenty of room in the empty leading edge, but obviously the passage is too large and some means of attaching the wires seems in order. >> Any opinions on a practical way to use this long empty passage for wires ? >> Thanks in advance for your input, >> -- >> Best regards, >> Gilles >> http://contrails.free.fr >> ________________________________________________________________________________
Date: Jan 01, 2017
Try these for pulling wire thru conduit. http://www.techtoolsupply.com/ProductDetails.asp?ProductCode=85-901 On Sun, Jan 1, 2017 at 2:05 PM, Charlie England wrote: > ceengland7(at)gmail.com> > > Virtually everyone complains of running out of wire path volume at some > point, so 'go big'. > > For choices, the split loom stuff does work. I like this stuff: > https://www.techflex.com/prod_ccp.asp > and > https://www.techflex.com/prod_f6w.asp > > Very light weight and very flexible. The unsplit stuff works like the old > 'Chinese finger cuffs' we played with as kids; the 1" stuff will expand t o > close to 1 1/2" if you push it together (make it shorter). And it will > shrink to about 1/2" if you stretch it. You could install the max size wi th > enough length for max diameter, and when you know everything is in, just > pull on the ends to tighten it up (if you feel it's needed; I don't). > > Only downside to the closed stuff is that you'll need a smooth, more or > less ball shaped end on whatever you pull through it, to avoid snagging o n > the weave. > > Charlie > > On 1/1/2017 2:08 PM, Kent or Jackie Ashton wrote: > >> kjashton(at)vnet.net> >> >> Looking at your wings, I think I'd put some 1/2=9D to 3/4=9D auto wire loom >> protector in the wings, with zip ties so the wire does not work itself o ut >> of the split in the loom protector. Leave a nylon string in the protect or >> that you can later use to pull wires. Later on, you can push a stiff wi re >> through the loom protector and use it to pull wires. The loom protector is >> lightweight but will protect them from abrasion. >> -Kent >> Cozy & Long-EZ builder >> >> On Jan 1, 2017, at 1:44 PM, GTH wrote: >>> >>> >>> Hi all, >>> >>> Best wishes for 2017. >>> >>> What could be the dimensions of the conduit for the (nav/strobe lights, >>> magnetometer, etc.) wires in the wing of a a composite aircraft ? >>> There is plenty of room in the empty leading edge, but obviously the >>> passage is too large and some means of attaching the wires seems in ord er. >>> Any opinions on a practical way to use this long empty passage for wire s >>> ? >>> Thanks in advance for your input, >>> -- >>> Best regards, >>> Gilles >>> http://contrails.free.fr >>> >>> =========== =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Jan 01, 2017
Clean the aluminum with solvent prior to sticking on the cable tie mounts or else they will eventually fall off. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464595#464595 ________________________________________________________________________________
Date: Jan 01, 2017
I have not tried this but builders on another forum recommend using lawn sprinkler tubing available at home improvement stores. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464596#464596 ________________________________________________________________________________
Subject: Re: Z-13/8 and SD-8
Date: Jan 01, 2017
See Note 25 as well as Z-25. Makes the SD-8 work with no battery. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464601#464601 ________________________________________________________________________________
Subject: Re: EFII ignition and injection Z-13/8
Date: Jan 01, 2017
Some significant info from 2011: http://forums.matronics.com/viewtopic.php?t=83040&highlight=z12 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464602#464602 ________________________________________________________________________________
Date: Jan 02, 2017
It would be interesting to read about why the two diodes and resistor work and why the SD-8 will not work without them (unless a battery is connected). -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464605#464605 ________________________________________________________________________________
Date: Jan 02, 2017
I wouldn't. I'd use smooth conduit. Either regular plastic electrical conduit or, as Joe suggested, something like lightweight plumbing tubing. I'd suggest 3/4" or 1" if it'll fit. The corrugated stuff is good for wrapping around wires that are already in place but I find trying to feed wires through it later to be a pain. The reason for the larger pipe is not necessarily so you can cram more wires in but because the extra space also makes it easier to pull or replace wires later. --Rick On 1/1/2017 3:08 PM, Kent or Jackie Ashton wrote: > > Looking at your wings, I think I'd put some 1/2 to 3/4 auto wire loom protector in the wings, with zip ties so the wire does not work itself out of the split in the loom protector. Leave a nylon string in the protector that you can later use to pull wires. Later on, you can push a stiff wire through the loom protector and use it to pull wires. The loom protector is lightweight but will protect them from abrasion. > -Kent > Cozy & Long-EZ builder > >> On Jan 1, 2017, at 1:44 PM, GTH wrote: >> >> >> Hi all, >> >> Best wishes for 2017. >> >> What could be the dimensions of the conduit for the (nav/strobe lights, magnetometer, etc.) wires in the wing of a a composite aircraft ? >> There is plenty of room in the empty leading edge, but obviously the passage is too large and some means of attaching the wires seems in order. >> Any opinions on a practical way to use this long empty passage for wires ? >> Thanks in advance for your input, >> -- >> Best regards, >> Gilles >> http://contrails.free.fr ________________________________________________________________________________
Date: Jan 02, 2017
Leaving a "tied-off" line in the conduit to help pull a new wire through is a great idea. But remember that when you use that line to pull the next wire through, you need to also pull through another "spare" line to tie off, awaiting your inevitable "next" wire pull... Of course, I learned this the hard way... (Long story involving a lengthy conduit run from house to workshop, and a new welding circuit for the shop... Sigh.) Jim Parker ________________________________________________________________________________
Date: Jan 02, 2017
I found that the black 25mm OD HDPE sprinkler system tubing by Gardena (2718) is very lightweight. Fixing it inside a finished wing would be a problem. Wouldn't want it free to move. Jan de Jong On 1/2/2017 6:16 PM, Rick Beebe wrote: > > I wouldn't. I'd use smooth conduit. Either regular plastic electrical > conduit or, as Joe suggested, something like lightweight plumbing > tubing. I'd suggest 3/4" or 1" if it'll fit. The corrugated stuff is > good for wrapping around wires that are already in place but I find > trying to feed wires through it later to be a pain. The reason for the > larger pipe is not necessarily so you can cram more wires in but > because the extra space also makes it easier to pull or replace wires > later. > > --Rick > > On 1/1/2017 3:08 PM, Kent or Jackie Ashton wrote: >> >> >> Looking at your wings, I think I'd put some 1/2 to 3/4 auto wire >> loom protector in the wings, with zip ties so the wire does not work >> itself out of the split in the loom protector. Leave a nylon string >> in the protector that you can later use to pull wires. Later on, you >> can push a stiff wire through the loom protector and use it to pull >> wires. The loom protector is lightweight but will protect them from >> abrasion. >> -Kent >> Cozy & Long-EZ builder >> >>> On Jan 1, 2017, at 1:44 PM, GTH wrote: >>> >>> >>> Hi all, >>> >>> Best wishes for 2017. >>> >>> What could be the dimensions of the conduit for the (nav/strobe >>> lights, magnetometer, etc.) wires in the wing of a a composite >>> aircraft ? >>> There is plenty of room in the empty leading edge, but obviously the >>> passage is too large and some means of attaching the wires seems in >>> order. >>> Any opinions on a practical way to use this long empty passage for >>> wires ? >>> Thanks in advance for your input, >>> -- >>> Best regards, >>> Gilles >>> http://contrails.free.fr > > ________________________________________________________________________________
Date: Jan 02, 2017
If you have a solid conduit with no pull string, you can send one through by tying it around a wad of cotton balls and using either compressed air to blow it through or a shop vac to suck it through. This works best in conduit under a couple of inches in diameter, and where the conduit isn't already stuffed full of wires. It definitely won't work in a split loom. Another alternative is to disconnect a wire that's already installed and use it to pull through a replacement for itself along with the new wires (and a pull string for the future). Eric > On Jan 2, 2017, at 10:36 AM, wrote: > Leaving a "tied-off" line in the conduit to help pull a new wire through is a great idea. But remember that when you use that line to pull the next wire through, you need to also pull through another "spare" line to tie off, awaiting your inevitable "next" wire pull... > > Of course, I learned this the hard way... (Long story involving a lengthy conduit run from house to workshop, and a new welding circuit for the shop... Sigh.) > > Jim Parker ________________________________________________________________________________
Date: Jan 02, 2017
Extensive discussion from 2010. http://forums.matronics.com/viewtopic.php?p=288794 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464632#464632 ________________________________________________________________________________
Date: Jan 02, 2017
Extensive discussion from 2010. http://forums.matronics.com/viewtopic.php?p=288794 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464633#464633 ________________________________________________________________________________
Date: Jan 03, 2017
Subject: Re: Conduit implementation, was Best dimensions for
conduits I used non-split corrugated loom, secured with safety wire. Secure, permanent, flexible, adjustable, redoable, and easy. I used heavy duty synthetic cord, perhaps 1/16 dia and very flexible as a fish line. Scrap dowel with a dia about 3/4 of the ID of the conduit was made into toggles about 1 1/2" long and tied to the ends of lines just over twice the length of the conduit. I used a blow gun to send the line down the conduit, wondering just how far it would go before hanging up. It shot out the other end, across the shop, and bounced off the far wall. (That's when I installed the second toggle...) The length allows the line to do the job, be reset to the other original position, and pulled again, or used bidirectionally. Duct tape attaches the wire to the line and makes a smooth cone to avoid snags in the conduit. The toggles prevent the end of the line from disappearing into the conduit. Yes, the 4 pulling lines probably add 4, perhaps 5 oz. to my empty weight.... *SNIP* "Leaving a "tied-off" line in the conduit to help pull a new wire through is a great idea. But remember that when you use that line to pull the next wire through, you need to also pull through another "spare" line to tie off, awaiting your inevitable "next" wire pull..." ________________________________________________________________________________
for conduits
Date: Jan 03, 2017
/Le 03/01/2017 16:02, GLEN MATEJCEK a crit : / > / > > I used non-split corrugated loom, secured with safety wire. Secure, > permanent, flexible, adjustable, redoable, and easy./ > Hi all, Thank you everyone for the great suggestions. It is unusual to have to complain about having to large and too clean a passage in the wing. Now is the choice of a means for securing the conduit/loom inside the leading edge to prevent it from moving or flapping around. Best wishes for 2017, -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Date: Jan 03, 2017
At 08:00 AM 1/2/2017, you wrote: > >It would be interesting to read about why the two diodes and >resistor work and why the SD-8 will not work without them (unless a >battery is connected). > >-------- >Joe Gores > > Here's a close approximation of the Ducati product used by Rotax. This illustrates the general architecture of most rectifier/regulators over the past 20 years or so . . . Emacs! If you noodle through fuctionality of the circuit, you find a bridge rectifier consisting of two diodes with cathodes tied to the output terminal(s) . . . two silicon rectifiers with anodes connected to ground. Control electronics for the SCRs gets power through the "C" terminal. With no source of power at "C" and "B" . . . the control electronics are dark. With no control electronics, the SCRs are dormant. The AC output from a rotating dynamo is unavailable for use. Emacs! Adding a battery . . . even a badly discharged battery of under 10 volts will wake up the control electronics which in turn flogs the SCRs into action and the Dynamo/R-R system wakes up. Adding a couple of diodes external to the R-R along with a current limiting resistor creates the equivalent 'leaky SCRs' where rectification through the R-R is never zero. Small but never zero. In the absence of a load on the usual capacitor across the R-R output terminals, this small energy source will charge the capacitor to a voltage that will wake-up the control electronics and bring the system on line. This works only if there are no loads on the system's output that over-taxes the weak, wake-up source. Bob . . . --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jan 03, 2017
Extensive discussion from August 2014: http://forums.matronics.com/viewtopic.php?t=104794 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464663#464663 ________________________________________________________________________________
Date: Jan 03, 2017
I have concerns about EFII's Bus Manager and dual fuel pump wiring failure modes. I do not plan to use Bus Manager and I will have separate switches and wires for each fuel pump as well as the ECUs. I have learned that Z19 and Z07, dual battery single alternator, are intended for engines that do not allow dual alternators. Bob Nuckolls points us to Z12 or Z13/8 for Lycomings and others that can mount dual alternators. Robert Paisley reports system current draw: ====================== "jmjones2000(at)mindspring, PostPosted: Thu Aug 21, 2014 10:30 am Post subject: Z-19 Function, I just heard back from Robert, EFII power demands on the 12v system, ECUs draw about .1 amps ea, ignition coils draw about 2.3 amps ea at high rpm, one fuel pump draws a little under 5A." ====================== I wish EFII had better current draw info to share so I could compare to SD-8 output versus RPM. I can only assume from the above that "ECU" means injector ECU plus injectors and "ignition coils" means ignition electronics plus coils. I don't know if pump current varies with injector flow. What Robert Paisley emailed me is "the full system is a little under 10 amps at high rpm. About half of that is for the fuel pump." Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464666#464666 ________________________________________________________________________________
From: "William Hunter" <billhuntersemail(at)gmail.com>
Subject: EMI From Seat Heaters and Other Questions
Date: Jan 03, 2017
Hi AeroElectric Cyber Friends!!! I figured I would bounce these questions off of the folks on this forum. Over at the Velocity Aircraft Forum we have some questions with respect to EMI from 12 VDC supplemental cabin heat systems such as heated seats, heated blankets (such as an electric blanket that you plug into the cigarette lighter), and/or a 12 volt electric heating element heater. QUESTION 1: Would the heat blanket/seat system affect the magnetometer on the aircraft? The 12 VDC electric heater has a motor and an element so that certainly might cause issues. If so how far away would you consider it the reasonable distance from the magnetometer to the heated element in the blanket/seat? QUESTION 2: If the heated seat would cause EMI, is it possible to mitigate the EMI by "polarizing" the seat inserts (placing one element in one direction and the other in the opposite direction? This is the heated seat kit I bought for my aircraft: https://www.amazon.com/Water-Carbon-Premium-Heated-Seats/dp/B00AKEVNP2/ref=s r_1_10?ie=UTF8&qid=1483494619&sr=8-10&keywords=car%2Bheated%2Bseats&th=1 QUESTION 3: Would an electric seat/blanket cause radio noise? If so what can one do to mitigate the noise? QUESTION 4: How much heat would a small 12 VDC electric element heater system realistically put out? This is the one we have been discussing it is designed for a RV unit: <http://www.my12voltstore.com/12_Volt_Ducted_Heater_p/sd12-4000.htm> http://www.my12voltstore.com/12_Volt_Ducted_Heater_p/sd12-4000.htm Does anybody happen to have any experience with this particular unit and to see if it's worth the cost / weight penalty involved in hauling this thing around. I was thinking of installing this under the instrument panel and using it as a defroster by directing the "heated" air toward the windshield. We are in a "heated discussion" on how to add a heat source to the airplane. The only heat in the velocity airplane design is an oil cooler mounted in the nose and that air/oil heat exchanger is used for cabin heat.the problem being that outside air is blown through the oil cooler and into the cabin and naturally during cold months the OAT is significantly cold and therefore the heat increase is not very efficient plus the fact that our air cooled engines may not be producing that much oil temperature to begin with so we are dreaming of ways to supplement our interior heat. Any suggestions/feedback/experience would be greatly appreciated!!! THANKS!!! Bill Hunter ________________________________________________________________________________
Subject: SD-20/SD-60 Question
Date: Jan 03, 2017
Hi Again.On a Roll Tonight I guess!!! I am running a SD-60 and a LR3C-14 Voltage Regulator on one bus with its own battery and a SD-20 with its own LR3C-14 Voltage Regulator on the second bus with its own battery. The engine is a Lycoming IO-540. QUESTION 1: I intend to operate my two electrical systems isolated with a bus tie that will be used for engine start only and then untied afterwards. What happens if I forget to untie the two busses after engine start and both the SD-60 and the SD-20 are providing current to the combined system? Do they share the load equally on the combined system? What happens should the system load reach 50 AMPS? Does the SD-20 simply max out at 20 AMPS and then the SD-60 picks up the rest of the 30 AMPS? QUESTION 2: If I do remember to untie the busses.What happens to the single system when there is a temporary current spike on that isolated system? Example: Should the alternator be running at 90 percent of its capacity and then the electric landing gear hydraulic pump cycles and draws another 25-30 AMPS. Does the voltage regulator simply limit the alternator output to its max output of 60/20 AMPS and then the system draws down the battery during the short time the gear pump is active or does the voltage regulator deactivate the SD-60 requiring a reset? QUESTION 3: How much output does the SD-60 and the SD-20 really put out both at idle and at cruise RPM? I heard that the belt driven alternator will put out full production at low RPM however the SD-20 will only put out lower production at low RPM and only reach it's full rated production at max RPM? THANKS AGAIN ALL. OH.BTW.I wish you all a prosperous New Year!!! .. Cheers!!! Bill Hunter ________________________________________________________________________________
Subject: Re: SD-20/SD-60 Question
Date: Jan 03, 2017
Answer 1: The alternators do not share the load equally. The load will draw current from the source with the highest voltage. It depends on what voltage each regulator is set at. If the 60 amp is set at a higher voltage, it will provide all of the current. If the 20 amp is set at a higher voltage and the load is higher than 20 amps, the 20 amp alternator will put out its maximum current but will not be able to maintain the voltage because the load is too great. Once the voltage sags below the set point of the 60 amp alternator, then the 60 amp alternator will turn on and help the 20 amp alternator. The 20 amp alternator will still be putting out its maximum current which could cause it to get hot if not provided with cooling. There could be some instability where each alternator output varies up and down. Answer 2: Here again, the load will draw current from the source with the highest voltage. If the alternator voltage sags due to excessive current, when the alternator voltage sags to battery voltage, then part of the current will come from the battery and part from the alternator. A voltage regulator regulates voltage, not current. If the voltage sags, the regulator will increase alternator field current in an attempt to maintain the set point voltage. If the load is too great, the alternator output voltage will sag while its output current will be at maximum. Alternator output current is self limiting. It is only capable of so much. I have never heard of a voltage regulator deactivating and requiring a reset. Answer 3: I do not know. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464679#464679 ________________________________________________________________________________
Subject: Re: EMI From Seat Heaters and Other Questions
Date: Jan 03, 2017
> On Jan 3, 2017, at 6:20 PM, William Hunter wr ote: > QUESTION 4: How much heat would a small 12 VDC electric element heater sy stem realistically put out? This is the one we have been discussing it is de signed for a RV unit: http://www.my12voltstore.com/12_Volt_Ducted_Heater_p /sd12-4000.htm > At the risk of being pedantic, I'm not sure how one would answer this other t han to quote the product's specifications and explain the units. The description says this heater rated for 8,016 British Thermal Units (BTUs ). A BTU is the amount of energy it takes to heat one pound of water (about 16 fl oz, or two cups) by one degree Fahrenheit. So, the heat energy this thing puts out could heat a 4-ton tank of water (ap prox 960 US gal) by one deg F in one hour. Or, to use numbers that are a bi t more meaningful, heat about 96 gal of water by 10 deg F in one hour. Stil l not a very helpful comparison. The specs say it draws 480W (40A at 12V). It looks like the blower motor ac counts for 15W (1.25A) of that total, which leaves 465W (38.75A) for the hea ting elements. That's a decent amount of heat, but compare that figure agai nst a typical small domestic space heater that we're all familiar with: they 're commonly rated at 1,500W. The first three search results for "hair drye r" on Amazon are rated at 1,875W! Recommendations vary between 20 and 60 BTU/sq ft for heating a home, dependi ng on your climate region. If you assume a middle value of 40 BTU/sq ft, th en 8,000 BTU would be about right for a 200 sq ft room (in a home insulated t o code). Whether that kind of analysis translates to airplanes, or if 8,000 BTU is ad equate for a light plane cockpit flying through freezing air are interesting questions. How warm is warm enough? Eric ________________________________________________________________________________
Date: Jan 03, 2017
To what voltage should the SD-8's PMR1C-14 regulator be set for Z-13/8? I see for Z-12 the SD-60 and SD-20 (to use their old names) regulators are set at 14.2 and 13 volts respectively. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464681#464681 ________________________________________________________________________________
Date: Jan 03, 2017
1/2) Diagram Z-12 calls for: Two alternators and one battery. SD-60 alternator with LR-3 regulator. B and C presets this regulator to 14.2 volts. SD-20 alternator with SB-1 regulator, B and C presets this regulator to 13.0 volts. The SD-60 will carry all the load because it is set higher; but Z-12 has SD-20 switched off until needed. When SD-60 is inoperative Z-12 calls for: A panel light that will flash above 20 amps calling for you to shed load. This panel light and its associated current sensor are included with regulator SBK-14 versus the standard SB1B-14. I interpolate the SD-20 will make 20 amps at 1750 rpm. I think the battery will absorb most of the short-term hydraulic pump current. Also think about what engine RPM will be. But are you using Z-14? Z-14 calls for two two alternators at 14.2 volts. Ref its description in Appendix Z. 3) SD-20, ref page 2 here: http://www.bandc.aero/pdfs/quickfacts_bc410-h.pdf Runs at 1.3 times crank RPM. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464682#464682 ________________________________________________________________________________
Date: Jan 04, 2017
Someone has their units mixed up here. BTU is a measure of energy. Heaters a re measured in BTU/hour. (Like the difference between joules and watts). 480 W is 1638BTU/h, and 8000BTU/h is 2344W so the two figures given don't seem t o agree. The former seems more reasonable than the latter for this unit. On Jan 3, 2017, at 23:50, Eric Page wrote: > On Jan 3, 2017, at 6:20 PM, William Hunter wr ote: > QUESTION 4: How much heat would a small 12 VDC electric element heater sy stem realistically put out? This is the one we have been discussing it is de signed for a RV unit: http://www.my12voltstore.com/12_Volt_Ducted_Heater_p /sd12-4000.htm > At the risk of being pedantic, I'm not sure how one would answer this other t han to quote the product's specifications and explain the units. The description says this heater rated for 8,016 British Thermal Units (BTUs ). A BTU is the amount of energy it takes to heat one pound of water (about 16 fl oz, or two cups) by one degree Fahrenheit. So, the heat energy this thing puts out could heat a 4-ton tank of water (ap prox 960 US gal) by one deg F in one hour. Or, to use numbers that are a bi t more meaningful, heat about 96 gal of water by 10 deg F in one hour. Stil l not a very helpful comparison. The specs say it draws 480W (40A at 12V). It looks like the blower motor ac counts for 15W (1.25A) of that total, which leaves 465W (38.75A) for the hea ting elements. That's a decent amount of heat, but compare that figure agai nst a typical small domestic space heater that we're all familiar with: they 're commonly rated at 1,500W. The first three search results for "hair drye r" on Amazon are rated at 1,875W! Recommendations vary between 20 and 60 BTU/sq ft for heating a home, dependi ng on your climate region. If you assume a middle value of 40 BTU/sq ft, th en 8,000 BTU would be about right for a 200 sq ft room (in a home insulated t o code). Whether that kind of analysis translates to airplanes, or if 8,000 BTU is ad equate for a light plane cockpit flying through freezing air are interesting questions. How warm is warm enough? Eric ________________________________________________________________________________
Date: Jan 04, 2017
One might also point out that trying to heat a space from a 12v supply is li ke filling a swimming pool from a garden hose. Don't expect too much - there 's a reason that where the aviation community can't use exhaust muff heating systems (cabin twins, for instance) they don't try electric, they use Janit rol heaters. On Jan 3, 2017, at 23:50, Eric Page wrote: > On Jan 3, 2017, at 6:20 PM, William Hunter wr ote: > QUESTION 4: How much heat would a small 12 VDC electric element heater sy stem realistically put out? This is the one we have been discussing it is de signed for a RV unit: http://www.my12voltstore.com/12_Volt_Ducted_Heater_p /sd12-4000.htm > At the risk of being pedantic, I'm not sure how one would answer this other t han to quote the product's specifications and explain the units. The description says this heater rated for 8,016 British Thermal Units (BTUs ). A BTU is the amount of energy it takes to heat one pound of water (about 16 fl oz, or two cups) by one degree Fahrenheit. So, the heat energy this thing puts out could heat a 4-ton tank of water (ap prox 960 US gal) by one deg F in one hour. Or, to use numbers that are a bi t more meaningful, heat about 96 gal of water by 10 deg F in one hour. Stil l not a very helpful comparison. The specs say it draws 480W (40A at 12V). It looks like the blower motor ac counts for 15W (1.25A) of that total, which leaves 465W (38.75A) for the hea ting elements. That's a decent amount of heat, but compare that figure agai nst a typical small domestic space heater that we're all familiar with: they 're commonly rated at 1,500W. The first three search results for "hair drye r" on Amazon are rated at 1,875W! Recommendations vary between 20 and 60 BTU/sq ft for heating a home, dependi ng on your climate region. If you assume a middle value of 40 BTU/sq ft, th en 8,000 BTU would be about right for a 200 sq ft room (in a home insulated t o code). Whether that kind of analysis translates to airplanes, or if 8,000 BTU is ad equate for a light plane cockpit flying through freezing air are interesting questions. How warm is warm enough? Eric ________________________________________________________________________________
Date: Jan 04, 2017
Last post for now, I promise: the Janitrol approved for installation in a (4 seat) Cessna 170 is 25000BTU/h which is 7.3kW. Compare 500w... On Jan 4, 2017, at 07:41, Alec Myers wrote: One might also point out that trying to heat a space from a 12v supply is li ke filling a swimming pool from a garden hose. Don't expect too much - there 's a reason that where the aviation community can't use exhaust muff heating systems (cabin twins, for instance) they don't try electric, they use Janit rol heaters. On Jan 3, 2017, at 23:50, Eric Page wrote: > On Jan 3, 2017, at 6:20 PM, William Hunter wr ote: > QUESTION 4: How much heat would a small 12 VDC electric element heater sy stem realistically put out? This is the one we have been discussing it is de signed for a RV unit: http://www.my12voltstore.com/12_Volt_Ducted_Heater_p /sd12-4000.htm > At the risk of being pedantic, I'm not sure how one would answer this other t han to quote the product's specifications and explain the units. The description says this heater rated for 8,016 British Thermal Units (BTUs ). A BTU is the amount of energy it takes to heat one pound of water (about 16 fl oz, or two cups) by one degree Fahrenheit. So, the heat energy this thing puts out could heat a 4-ton tank of water (ap prox 960 US gal) by one deg F in one hour. Or, to use numbers that are a bi t more meaningful, heat about 96 gal of water by 10 deg F in one hour. Stil l not a very helpful comparison. The specs say it draws 480W (40A at 12V). It looks like the blower motor ac counts for 15W (1.25A) of that total, which leaves 465W (38.75A) for the hea ting elements. That's a decent amount of heat, but compare that figure agai nst a typical small domestic space heater that we're all familiar with: they 're commonly rated at 1,500W. The first three search results for "hair drye r" on Amazon are rated at 1,875W! Recommendations vary between 20 and 60 BTU/sq ft for heating a home, dependi ng on your climate region. If you assume a middle value of 40 BTU/sq ft, th en 8,000 BTU would be about right for a 200 sq ft room (in a home insulated t o code). Whether that kind of analysis translates to airplanes, or if 8,000 BTU is ad equate for a light plane cockpit flying through freezing air are interesting questions. How warm is warm enough? Eric ________________________________________________________________________________
Date: Jan 04, 2017
Bob, thanks for that explanation. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464694#464694 ________________________________________________________________________________
Date: Jan 04, 2017
On 1/3/2017 9:55 PM, William Hunter wrote: > > I am running a SD-60 and a LR3C-14 Voltage Regulator on one bus with > its own battery and a SD-20 with its own LR3C-14 Voltage Regulator on > the second bus with its own battery. The engine is a Lycoming IO-540. > I have been operating an RV10 with a Z-14, LR3Cs, an SD40 and SD20, all on an IO-540. A Z-14 is what you are describing. > > QUESTION 1: I intend to operate my two electrical systems isolated > with a bus tie that will be used for engine start only and then untied > afterwards. What happens if I forget to untie the two busses after > engine start and both the SD-60 and the SD-20 are providing current to > the combined system? Do they share the load equally on the combined > system? What happens should the system load reach 50 AMPS? Does the > SD-20 simply max out at 20 AMPS and then the SD-60 picks up the rest > of the 30 AMPS? > Operationally, the idea is to use the systems tied for the start, then untie them for flight. I've run them both ways, 50:50, over 800 hours. No problems either way but I can't tell you exactly what was charging what, when, due a voltage measurement problem (see way below). A big reason you run them split is so you can detect any problems. I recently 'lost' the SD-40 in IMC - low voltage light came on and bus voltage dropped to battery levels on the one bus. Nothing popped or anything so I simply cross-tied the buses and turned off the Alt/Batt switch on the SD-40 side. The SD-20 kept the voltage at an acceptable, constant level until the flight was completed. (the problem on the SD-40 bus turned out to a degraded connection somewhere in the LR3-switch-bus circuit that detects field voltage. Executing B&C LR3 troubleshooting procedure identified the problem. All connections were physically reset and problem resolved) > > QUESTION 2: If I do remember to untie the bussesWhat happens to the > single system when there is a temporary current spike on that isolated > system? Example: Should the alternator be running at 90 percent of > its capacity and then the electric landing gear hydraulic pump cycles > and draws another 25-30 AMPS. Does the voltage regulator simply limit > the alternator output to its max output of 60/20 AMPS and then the > system draws down the battery during the short time the gear pump is > active or does the voltage regulator deactivate the SD-60 requiring a > reset? > Just like a single bus/alt/batt, it draws on the battery but you won't even notice. > > QUESTION 3: How much output does the SD-60 and the SD-20 really put > out both at idle and at cruise RPM? I heard that the belt driven > alternator will put out full production at low RPM however the SD-20 > will only put out lower production at low RPM and only reach its full > rated production at max RPM? > Yes, the SD-20 will put out considerably less than 20amps at idle. Doesn't really matter in my experience Voltage Measurement: I created a problem with how I measured bus voltages. I have a GRT panel with (3) EFISs and (1) EIS. I took one voltage measurement from the EIS and the other from the EFIS, and then displayed the 2 voltages on the EFIS. This was easy since the EFISs were on 1 bus and the EIS on the other. In both cases I was getting the voltage level of the feeds for each system. However the EFISs represent a significant load and the voltage there was about .6 volts less than bus voltage. On the other hand, the EIS is a very low, constant load device and the voltage there more or less was equal to bus voltage. Many problems resulted from this. The solution is to get your 2 bus measurements from places that match bus voltages. Load Balancing: Distinguish between constant loads and temporary loads. My understanding is that you generally balance for constant loads (Powered on panel devices, strobes, running lights) and rely on your excess capacity and battery for the others (gear, landing lights, radio transmit, engine start). I got a bit fancy and started with too many constant loads on the SD-20. Though the SD-20 will run everything on both buses in daytime cruise and keep the battery fully charged. Charging voltage levels: If you are using AGM batteries (PC680s here) be careful about low bus voltages. 14.2 is a good minimum and you should see at least 14 on both buses at shutdown. Anything less means that your battery is being stored at less than full charge and that will shorten its life. Any shutdown voltage level of 13.x is going to cost you extra battery money in my experience. Bill "wishing for FIKI" Watson --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jan 04, 2017
I am running a SD-60 and a LR3C-14 Voltage Regulator on one bus with its own battery and a SD-20 with its own LR3C-14 Voltage Regulator on the second bus with its own battery. The engine is a Lycoming IO-540. Okay, Figure Z-14 . . . QUESTION 1: I intend to operate my two electrical systems isolated with a bus tie that will be used for engine start only and then untied afterwards. What happens if I forget to untie the two busses after engine start and both the SD-60 and the SD-20 are providing current to the combined system? Do they share the load equally on the combined system? What happens should the system load reach 50 AMPS? Does the SD-20 simply max out at 20 AMPS and then the SD-60 picks up the rest of the 30 AMPS? Not necessarily. Both regulators should be set for optimal BATTERY maintenance (14.2 to 14.6 volts). It's practically impossible to set them to the same voltage. Hence, while paralleled, the alternator with the slightly higher setting will 'hog' the load until such time as it maxes out, bus voltage falls until the alternator with the lower set-point picks up the difference. QUESTION 2: If I do remember to untie the busses . . . How would this happen? If wired per the published drawing, the crossfeed contactor is automatically closed when a SPRING LOADED switch is moved to START position. This gets you two batteries for cranking while illuminating a CROSSFEED WARN light. When the engine starts, the switch is released, the contactor opens, the light goes out. Nothing to 'forget'. Emacs! What happens to the single system when there is a temporary current spike on that isolated system? Example: Should the alternator be running at 90 percent of its capacity and then the electric landing gear hydraulic pump cycles and draws another 25-30 AMPS. Does the voltage regulator simply limit the alternator output to its max output of 60/20 AMPS and then the system draws down the battery during the short time the gear pump is active or does the voltage regulator deactivate the SD-60 requiring a reset? Not sure what the concern is here. First, how do you expect to normally load either alternator so heavily? Both sides should be designed to achieve 25% or so of headroom on the alternator for battery charging. But even if the inrush current from a pump motor exceeds an alternator's rated capacity, the bus voltage sags, the battery picks up the difference, and all returns to normal after the event . . . which is generally over in tens of milliseconds. No big deal. QUESTION 3: How much output does the SD-60 and the SD-20 really put out both at idle and at cruise RPM? I heard that the belt driven alternator will put out full production at low RPM however the SD-20 will only put out lower production at low RPM and only reach it's full rated production at max RPM? Generally true. Don't go by what you HEAR . . . go get the specs from the folks who design, manufacture, sell and support the systems. Generally speaking, B&C belt driven alternators DO run fast . . . unlike alternators deliberately slowed by installation of larger pulleys (to save bearings), the B&C alternators (and most others) produce a substantial fraction of rated output at taxi speeds. The SD-20 is mechanically crippled by installation on a drive pad with a max rpm on the order of 4K . . . LESS than minimum speed for full output from the 40A core from which the SD-20 is manufactured. Have offered that, it behooves every builder to KNOW what the in flight running loads are on ANY alternators. To KNOW what headroom is available to recharge the companion battery. To KNOW what energy levels are stored in any combination of batteries. Figure Z-14 offers a tall fire-wall against failures but it does not negate the value of discovering and understanding EVERYTHING there is to know about how all the pieces fit together along with the effect any single failure might have on in-flight systems operations. Bob . . . --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Subject: Conduit and adding wires
Date: Jan 04, 2017
One other technique for adding a wire to an existing conduit if you don't have the embedded string is to take a length of 1/4" polyethylene tubing, run it down the existing conduit (may have to occasionally turn it) it is stiff enough to allow you to install it, then run the wire into the tube, fasten the far end and pull the tube back out. The slippery nature of the tubing makes pushing the wire through easy,. Bill Schertz ________________________________________________________________________________
Subject: Rotax 912iS questions
Date: Jan 04, 2017
Hi all, Presently considering the wiring of a Rotax 912iS in a friend's composite project. The engine features a digital fuel injection with high pressure fuel pumps, digital control "lanes", backup power circuit, dual alternator with control box etc. The Rotax Installation manual calls for a certain number of panel switches : Pump A and B switches (permanent) : 10 A each Lane A & B switches (permanent) : 7.5 A each Engine Control Unit start power switch (momentary) : 20 A Backup battery switch (permanent) : 20 A QUESTION : is it advisable to bring such heavy current carrying wires to the panel, or would it be preferable to use relays to control the system ? Any input appreciated, Thanks in advance, -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Subject: Re: Rotax 912iS questions
Date: Jan 04, 2017
On 1/4/2017 1:21 PM, GTH wrote: > > Hi all, > > Presently considering the wiring of a Rotax 912iS in a friend's > composite project. > > The engine features a digital fuel injection with high pressure fuel > pumps, digital control "lanes", backup power circuit, dual alternator > with control box etc. > > The Rotax Installation manual calls for a certain number of panel > switches : > > Pump A and B switches (permanent) : 10 A each > > Lane A & B switches (permanent) : 7.5 A each > > Engine Control Unit start power switch (momentary) : 20 A > > Backup battery switch (permanent) : 20 A > > QUESTION : is it advisable to bring such heavy current carrying wires > to the panel, or would it be preferable to use relays to control the > system ? > > Any input appreciated, > > Thanks in advance, > > > -- > Best regards, > Gilles > http://contrails.free.fr > http://lapierre.skunkworks.free.fr For me, the decisions were based both on overall weight, and complexity/reliability (yes, I know they aren't necessarily the same thing, but can be related). How much weight (length has a big influence) will using the heavier gauge wire add, vs the added weight of the relay? How much reliability will you sacrifice by adding a relay and all the extra terminations required? Even 20 A is not that big a deal for the proper switch. Going bigger than that, a relay starts to look more attractive, especially since the automotive world now makes fairly light weight, high current relays available for very reasonable prices. Charlie ________________________________________________________________________________
Date: Jan 04, 2017
1/4/2017 Hello Bill Hunter, I could not find enough space under the engine cowling to put a heat muff on the exhaust system of my KIS TR-1 airplane powered by a Continental Motors IO-240 B9B engine. I initially tried to use an recreational vehicle heater similar to your: http://www.my12voltstore.com/12_Volt_Ducted_Heater_p/sd12-4000.htm It generated about as much heat as waving a lighted cigarette around in the cockpit. Also it generated noise on the radio. Totally useless. My solution was electrically heated clothing like the motorcyclists and the snowmobile riders use. My brand was Gerbings bought several years ago which has worked great. That company=99s recent history is shaky so shop around before you buy. OC ============= From: "William Hunter" <billhuntersemail(at)gmail.com> Subject: AeroElectric-List: EMI From Seat Heaters and Other Questions Hi AeroElectric Cyber Friends!!! I figured I would bounce these questions off of the folks on this forum. Over at the Velocity Aircraft Forum we have some questions with respect to EMI from 12 VDC supplemental cabin heat systems such as heated seats, heated blankets (such as an electric blanket that you plug into the cigarette lighter), and/or a 12 volt electric heating element heater. QUESTION 1: Would the heat blanket/seat system affect the magnetometer on the aircraft? The 12 VDC electric heater has a motor and an element so that certainly might cause issues. If so how far away would you consider it the reasonable distance from the magnetometer to the heated element in the blanket/seat? QUESTION 2: If the heated seat would cause EMI, is it possible to mitigate the EMI by "polarizing" the seat inserts (placing one element in one direction and the other in the opposite direction? This is the heated seat kit I bought for my aircraft: https://www.amazon.com/Water-Carbon-Premium-Heated-Seats/dp/B00AKEVNP2/re f=s r_1_10?ie=UTF8&qid=1483494619&sr=8-10&keywords=car%2Bheated%2Bsea ts&th=1 QUESTION 3: Would an electric seat/blanket cause radio noise? If so what can one do to mitigate the noise? QUESTION 4: How much heat would a small 12 VDC electric element heater system realistically put out? This is the one we have been discussing it is designed for a RV unit: <http://www.my12voltstore.com/12_Volt_Ducted_Heater_p/sd12-4000.htm> http://www.my12voltstore.com/12_Volt_Ducted_Heater_p/sd12-4000.htm Does anybody happen to have any experience with this particular unit and to see if it's worth the cost / weight penalty involved in hauling this thing around. I was thinking of installing this under the instrument panel and using it as a defroster by directing the "heated" air toward the windshield. We are in a "heated discussion" on how to add a heat source to the airplane. The only heat in the velocity airplane design is an oil cooler mounted in the nose and that air/oil heat exchanger is used for cabin heat.the problem being that outside air is blown through the oil cooler and into the cabin and naturally during cold months the OAT is significantly cold and therefore the heat increase is not very efficient plus the fact that our air cooled engines may not be producing that much oil temperature to begin with so we are dreaming of ways to supplement our interior heat. Any suggestions/feedback/experience would be greatly appreciated!!! THANKS!!! Bill Hunter ________________________________________________________________________________
Date: Jan 04, 2017
Joe and Bob, I am VERY GRATEFUL for your help on this!!! >Okay, Figure Z-14 . . . Yes exactly.I stole that idea from the best source I could find. I did not go with the auto bus tie option however. >Both sides should be designed to achieve 25% or so of headroom on the alternator for battery charging. Can you all PLEASE check my homework on the current draw of the proposed equipment on each system? Naturally not all of these items will be running at the same time so it is hard to try to figure out what the actual steady state load will be. EXAMPLE: On hot days I will need the turbo intercooler electric fans but no pitot heat nor heated seats and vice versa. Communications radios on receive mode draw very little however when transmitting they draw 3 AMPS for only that time. I will be running two Dynon SV-1000s and each will be powered by its onside independent electrical system. Red System Loads (SD-20): The left system with the SD-20 is called "RED" (because there is a red light on the left wingtip). CB NAME AMP ITEM ON RED (PILOT SIDE) BUS BAR VOLT REG SENSE 2 LR3C-14 Voltage Regulator BUS VOLTAGE SENSE VOLT REG FIELD 5 VOLTAGE REGULATOR FIELD EFIS 5 Pilot side EFIS system SV-D1000 10" SKYVIEW DISPLAY 3.5amp SV-GPS-250 GPS MODULE 0.10amp SV-BAT-320 1.00 amp (only when at max charge) SV-ADAHRS-200 0.15amp USB WiFi ADAPTER 0.10amp SV-ARINC-429 0.10amp SV-KNOB-PANEL 0.07 amp SV-AP-PANEL 0.05 amp SV-EMS220 0.11amp SV COM 5 SV-COM-425 0.2amp continuous in RCV mode 3 amp only during XMT SV-AP SERVO 5 SV-AP SERVO Pitch servo 2 amps only when moving at MAX torque Roll servo 2 amps only when moving at MAX torque SV-AP POWER 3 SV-AP UNIT AP control box less than 3 amps TAXI LIGHT 5 TAXI LIGHT IN NOSE ENG FAN 2 ELECTRIC TURBO INTERCOOLER COOLING FANS ACCY FEED This CB powers the accessory power for the relays only. There are two engine cooling fans mounted below the turbocharger intercooler and there are two relays (one for each fan) attached to the battery box and each relay needs a 12V signal for accessory on and then it also needs a ground signal to close the relay contacts that power the fans. The ground signal is provided by switched ground. When the relay closes the fans get their power feed directly from the GREEN battery output through a 30 AMP inline fuse. The Intercooler fans provide supplemental ground and climb cooling to the intercooler and engine and therefore this system is not required for flight GREEN BUS SD-60 The right system with the SD-60 is called "GREEN" (you get the idea). CB NAME AMP ITEM ON MAIN BUS BAR VOLT REG SENSE 2 LR3C-14 Voltage Regulator BUS VOLTAGE SENSE VOLT REG FIELD 5 VOLTAGE REGULATOR FIELD EFIS 5 (All these items are powered from the #2 Skyview) SV-D1000 10" SKYVIEW DISPLAY 3.5amp SV-GPS-250 GPS MODULE 0.10amp SV-BAT-320 1.00 amp SV-ADAHRS-200 0.15amp SV-ARINC-429 0.10amp SV-KNOB-PANEL 0.07 amp SV-AP-PANEL 0.05 amp SV-EMS220 0.11amp USB WiFi ADAPTER 0.10amp FUEL PUMP 10 ELECTRIC FUEL PUMP PITOT 10 10.0amp max @ max heat START 5 STARTER SOLENOID GEAR CONTROL 5 Gear Controller circuitry 18 AWH wire GEAR HYD 30 Electro-Hydraulic pump for retractable gear actuation STROBE 10 WHELEN HDACF 01-0770028-05 LAND LIGHT 10 HID Landing Light plus two LED landing lights MISC LTS 5 INTERIOR LEDS AND OTHER LED MISC LIGHTS USB 10 USB CHARGER AND CIGARETTE LIGHTER SOCKET FUEL QTY 2 PRINCETON CAPACITANCE PROBES (two probes total) NAV 5 INCANDESCENT LIGHTS HEATED SEATS 10 FOUR SEATS IN THE AIRPLANE WILL BE HEATED. THIS CB IS FOR THE ACCESSORY CONTROL ONLY. THE SEAT HEATERS HAVE THEIR OWN 10 AMP MINI CB THAT IS CONNECTED TO THE GREEN BUS BAR. AVIONICS BUS YELLOW: The Avionics bus will be normally powered by the GREEN Bus through a dedicated Honeywell LT-001 ON/OFF switch. During abnormal operations after manual load shedding the Avionics Bus can be powered by the RED Bus through a dedicated Honeywell LT-001 ON/OFF switch. CB NAME AMP ITEM ON AVIONICS BUS BAR GARMIN COM 10 GARMIN GNS650 Comm Connector .45A continuous 5.66A Max when transmitting GARMIN NAV 7.5 GARMIN GNS650 Nav Connector .6A continuous 1.16A Max Main Connector 1.6A continuous 2.8A Max AUDIO 3 SL-15 0.350amp typ 1.5amp max XPNDR 5 SV-XPNDR-261 0.4amp ADS-B 5 SV-ADSB-470 0.2amp THANKS AGAIN!!! .. Cheers!!! Bill Hunter Mobile 408-464-1902 From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Wednesday, January 4, 2017 10:15 AM Subject: Re: AeroElectric-List: SD-20/SD-60 Question I am running a SD-60 and a LR3C-14 Voltage Regulator on one bus with its own battery and a SD-20 with its own LR3C-14 Voltage Regulator on the second bus with its own battery. The engine is a Lycoming IO-540. Okay, Figure Z-14 . . . QUESTION 1: I intend to operate my two electrical systems isolated with a bus tie that will be used for engine start only and then untied afterwards. What happens if I forget to untie the two busses after engine start and both the SD-60 and the SD-20 are providing current to the combined system? Do they share the load equally on the combined system? What happens should the system load reach 50 AMPS? Does the SD-20 simply max out at 20 AMPS and then the SD-60 picks up the rest of the 30 AMPS? Not necessarily. Both regulators should be set for optimal BATTERY maintenance (14.2 to 14.6 volts). It's practically impossible to set them to the same voltage. Hence, while paralleled, the alternator with the slightly higher setting will 'hog' the load until such time as it maxes out, bus voltage falls until the alternator with the lower set-point picks up the difference. QUESTION 2: If I do remember to untie the busses . . . How would this happen? If wired per the published drawing, the crossfeed contactor is automatically closed when a SPRING LOADED switch is moved to START position. This gets you two batteries for cranking while illuminating a CROSSFEED WARN light. When the engine starts, the switch is released, the contactor opens, the light goes out. Nothing to 'forget'. What happens to the single system when there is a temporary current spike on that isolated system? Example: Should the alternator be running at 90 percent of its capacity and then the electric landing gear hydraulic pump cycles and draws another 25-30 AMPS. Does the voltage regulator simply limit the alternator output to its max output of 60/20 AMPS and then the system draws down the battery during the short time the gear pump is active or does the voltage regulator deactivate the SD-60 requiring a reset? Not sure what the concern is here. First, how do you expect to normally load either alternator so heavily? Both sides should be designed to achieve 25% or so of headroom on the alternator for battery charging. But even if the inrush current from a pump motor exceeds an alternator's rated capacity, the bus voltage sags, the battery picks up the difference, and all returns to normal after the event . . . which is generally over in tens of milliseconds. No big deal. QUESTION 3: How much output does the SD-60 and the SD-20 really put out both at idle and at cruise RPM? I heard that the belt driven alternator will put out full production at low RPM however the SD-20 will only put out lower production at low RPM and only reach it's full rated production at max RPM? Generally true. Don't go by what you HEAR . . . go get the specs from the folks who design, manufacture, sell and support the systems. Generally speaking, B&C belt driven alternators DO run fast . . . unlike alternators deliberately slowed by installation of larger pulleys (to save bearings), the B&C alternators (and most others) produce a substantial fraction of rated output at taxi speeds. The SD-20 is mechanically crippled by installation on a drive pad with a max rpm on the order of 4K . . . LESS than minimum speed for full output from the 40A core from which the SD-20 is manufactured. Have offered that, it behooves every builder to KNOW what the in flight running loads are on ANY alternators. To KNOW what headroom is available to recharge the companion battery. To KNOW what energy levels are stored in any combination of batteries. Figure Z-14 offers a tall fire-wall against failures but it does not negate the value of discovering and understanding EVERYTHING there is to know about how all the pieces fit together along with the effect any single failure might have on in-flight systems operations. Bob . . . _____ This email has been checked for viruses by Avast antivirus software. www.avast.com ________________________________________________________________________________
Date: Jan 04, 2017
Thanks All for your time in contributing to this subject. I certainly came to the right place. DANGand I thought that a =9CBTU=9D was a form of currency changing because I see BTU on my utility bill and my currency changes from my account to the utility company account. .. Cheers!!! Bill Hunter From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Alec Myers Sent: Wednesday, January 4, 2017 4:31 AM Subject: Re: AeroElectric-List: EMI From Seat Heaters and Other Questions Someone has their units mixed up here. BTU is a measure of energy. Heaters are measured in BTU/hour. (Like the difference between joules and watts). 480W is 1638BTU/h, and 8000BTU/h is 2344W so the two figures given don't seem to agree. The former seems more reasonable than the latter for this unit. On Jan 3, 2017, at 23:50, Eric Page > wrote: On Jan 3, 2017, at 6:20 PM, William Hunter > wrote: QUESTION 4: How much heat would a small 12 VDC electric element heater system realistically put out? This is the one we have been discussing it is designed for a RV unit: http://www.my12voltstore.com/12_Volt_Ducted_Heater_p/sd12-4000.htm At the risk of being pedantic, I'm not sure how one would answer this other than to quote the product's specifications and explain the units. The description says this heater rated for 8,016 British Thermal Units (BTUs). A BTU is the amount of energy it takes to heat one pound of water (about 16 fl oz, or two cups) by one degree Fahrenheit. So, the heat energy this thing puts out could heat a 4-ton tank of water (approx 960 US gal) by one deg F in one hour. Or, to use numbers that are a bit more meaningful, heat about 96 gal of water by 10 deg F in one hour. Still not a very helpful comparison. The specs say it draws 480W (40A at 12V). It looks like the blower motor accounts for 15W (1.25A) of that total, which leaves 465W (38.75A) for the heating elements. That's a decent amount of heat, but compare that figure against a typical small domestic space heater that we're all familiar with: they're commonly rated at 1,500W. The first three search results for "hair dryer" on Amazon are rated at 1,875W! Recommendations vary between 20 and 60 BTU/sq ft for heating a home, depending on your climate region. If you assume a middle value of 40 BTU/sq ft, then 8,000 BTU would be about right for a 200 sq ft room (in a home insulated to code). Whether that kind of analysis translates to airplanes, or if 8,000 BTU is adequate for a light plane cockpit flying through freezing air are interesting questions. How warm is warm enough? Eric ________________________________________________________________________________
Date: Jan 04, 2017
Well....That's kinda comparing apples to kumquats. Ever driven a late model car with seat heaters? Hop in on a freezing cold day, crank the engine, and with the seat heaters on, your body will be warm before the engine coolant has gone up 2 degrees. All the heat goes directly to your body core. As an analogy, consider the radiant heaters used in a lot of workshops. As long as they are pointed at the worker, the worker stays reasonably warm even though the shop's air temp stays cold. I suspect that twins had Janitrol heaters long before heated seats were invented, or even a possibility (many generators from that era could barely keep up with the electrical demands of the instrument panel). And the current crop of cabin twins have them because those that can afford them expect them to offer all the comforts of home; hang the expense and inefficiency. Charlie On 1/4/2017 6:41 AM, Alec Myers wrote: > One might also point out that trying to heat a space from a 12v supply > is like filling a swimming pool from a garden hose. Don't expect too > much - there's a reason that where the aviation community can't use > exhaust muff heating systems (cabin twins, for instance) they don't > try electric, they use Janitrol heaters. > > On Jan 3, 2017, at 23:50, Eric Page > wrote: > > On Jan 3, 2017, at 6:20 PM, William Hunter > wrote: >> >> QUESTION 4: How much heat would asmall 12 VDC electric element >> heater system realistically put out? This is the one we have been >> discussing it is designed for a RV unit: >> http://www.my12voltstore.com/12_Volt_Ducted_Heater_p/sd12-4000.htm >> > > At the risk of being pedantic, I'm not sure how one would answer this > other than to quote the product's specifications and explain the units. > > The description says this heater rated for 8,016 British Thermal Units > (BTUs). A BTU is the amount of energy it takes to heat one pound of > water (about 16 fl oz, or two cups) by one degree Fahrenheit. > > So, the heat energy this thing puts out could heat a 4-ton tank of > water (approx 960 US gal) by one deg F in one hour. Or, to use > numbers that are a bit more meaningful, heat about 96 gal of water by > 10 deg F in one hour. Still not a very helpful comparison. > > The specs say it draws 480W (40A at 12V). It looks like the blower > motor accounts for 15W (1.25A) of that total, which leaves 465W > (38.75A) for the heating elements. That's a decent amount of heat, > but compare that figure against a typical small domestic space heater > that we're all familiar with: they're commonly rated at 1,500W. The > first three search results for "hair dryer" on Amazon are rated at 1,875W! > > Recommendations vary between 20 and 60 BTU/sq ft for heating a home, > depending on your climate region. If you assume a middle value of 40 > BTU/sq ft, then 8,000 BTU would be about right for a 200 sq ft room > (in a home insulated to code). > > Whether that kind of analysis translates to airplanes, or if 8,000 BTU > is adequate for a light plane cockpit flying through freezing air are > interesting questions. How warm is warm enough? > > Eric ________________________________________________________________________________
Date: Jan 04, 2017
> >I suspect that twins had Janitrol heaters long before heated seats >were invented, or even a possibility (many generators from that era >could barely keep up with the electrical demands of the instrument >panel). And the current crop of cabin twins have them because those >that can afford them expect them to offer all the comforts of home; >hang the expense and inefficiency. Janitrol and Southwind . . . both legacy icons in cabin comfort in the air and especially on the ground. I picked up an old Southwind heater at a garage sale some years back and was fascinated by the technology. MUCH simpler than the gas fired heater in my VW van. Dug up the patents on a few models . . . very slick. Used engine vacuum to 'suck' fuel, provide 'draft' and dispose of exhaust gasses. Glo plug for ignition. Really slick. Combustion fuel/air pathway totally closed. These were popular before my time but relatives spoke highly of them. McCollum's name appears on dozens of Southwind patents of that era . . . he was a prolific inventor/developer. My mentor (Ken Razak) and I puzzled over the practicality of adapting a similar technology to compact cabin heaters for the Ez series aircraft . . . using a venturi to produce operating vacuum. It appeared doable but not without a great deal of R&D . . . and the market was limited. All light twins use gas heaters 'cause you just can't get exhaust-muff heated air in from the wings. Further if the airplane is pressurized, the cabin air side of a gas heater lends itself to becoming part of the pressure vessel. Persons interested in reviewing this piece of automotive history are welcome to download the data package at: http://tinyurl.com/jy6potv Bob . . . --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jan 05, 2017
From: Buckaroo Banzai <ornerycuss2001(at)yahoo.com>
Have you considered a door in the fresh air inlet to the air-oil cooler and an alternate air path to recycle cabin air through the air-oil cooler? -------------------------------------------- On Wed, 1/4/17, William Hunter wrote: Subject: RE: AeroElectric-List: EMI From Seat Heaters and Other Questions To: aeroelectric-list(at)matronics.com Date: Wednesday, January 4, 2017, 3:31 PM #yiv3929019256 #yiv3929019256 -- _filtered #yiv3929019256 {panose-1:2 4 5 3 5 4 6 3 2 4;} _filtered #yiv3929019256 {font-family:Calibri;panose-1:2 15 5 2 2 2 4 3 2 4;} #yiv3929019256 #yiv3929019256 p.yiv3929019256MsoNormal, #yiv3929019256 li.yiv3929019256MsoNormal, #yiv3929019256 div.yiv3929019256MsoNormal {margin:0in;margin-bottom:.0001pt;font-size:11.0pt;} #yiv3929019256 a:link, #yiv3929019256 span.yiv3929019256MsoHyperlink {color:#0563C1;text-decoration:underline;} #yiv3929019256 a:visited, #yiv3929019256 span.yiv3929019256MsoHyperlinkFollowed {color:#954F72;text-decoration:underline;} #yiv3929019256 span.yiv3929019256EmailStyle17 {color:windowtext;font-weight:normal;font-style:normal;} #yiv3929019256 span.yiv3929019256EmailStyle18 {color:black;font-weight:normal;font-style:normal;} #yiv3929019256 .yiv3929019256MsoChpDefault {font-size:10.0pt;} _filtered #yiv3929019256 {margin:1.0in 1.0in 1.0in 1.0in;} #yiv3929019256 div.yiv3929019256WordSection1 {} #yiv3929019256 Thanks All for your time in contributing to this subject. I certainly came to the right place. DANGand I thought that a BTU was a form of currency changing because I see BTU on my utility bill and my currency changes from my account to the utility company account... Cheers!!! Bill Hunter From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Alec Myers Sent: Wednesday, January 4, 2017 4:31 AM To: aeroelectric-list(at)matronics.com Subject: Re: AeroElectric-List: EMI From Seat Heaters and Other Questions Someone has their units mixed up here. BTU is a measure of energy. Heaters are measured in BTU/hour. (Like the difference between joules and watts). 480W is 1638BTU/h, and 8000BTU/h is 2344W so the two figures given don't seem to agree. The former seems more reasonable than the latter for this unit. On Jan 3, 2017, at 23:50, Eric Page wrote:On Jan 3, 2017, at 6:20 PM, William Hunter wrote:QUESTION 4: How much heat would a small 12 VDC electric element heater system realistically put out? This is the one we have been discussing it is designed for a RV unit: http://www.my12voltstore.com/12_Volt_Ducted_Heater_p/sd12-4000.htm At the risk of being pedantic, I'm not sure how one would answer this other than to quote the product's specifications and explain the units. The description says this heater rated for 8,016 British Thermal Units (BTUs). A BTU is the amount of energy it takes to heat one pound of water (about 16 fl oz, or two cups) by one degree Fahrenheit. So, the heat energy this thing puts out could heat a 4-ton tank of water (approx 960 US gal) by one deg F in one hour. Or, to use numbers that are a bit more meaningful, heat about 96 gal of water by 10 deg F in one hour. Still not a very helpful comparison. The specs say it draws 480W (40A at 12V). It looks like the blower motor accounts for 15W (1.25A) of that total, which leaves 465W (38.75A) for the heating elements. That's a decent amount of heat, but compare that figure against a typical small domestic space heater that we're all familiar with: they're commonly rated at 1,500W. The first three search results for "hair dryer" on Amazon are rated at 1,875W! Recommendations vary between 20 and 60 BTU/sq ft for heating a home, depending on your climate region. If you assume a middle value of 40 BTU/sq ft, then 8,000 BTU would be about right for a 200 sq ft room (in a home insulated to code). Whether that kind of analysis translates to airplanes, or if 8,000 BTU is adequate for a light plane cockpit flying through freezing air are interesting questions. How warm is warm enough? Eric ________________________________________________________________________________
Date: Jan 05, 2017
/Le 04/01/2017 20:49, Charlie England a crit : / > / > > Even 20 A is not that big a deal for the proper switch. Going bigger > than that, a relay starts to look more attractive, especially since > the automotive world now makes fairly light weight, high current > relays available for very reasonable prices. > / Charlie and all, Thank you to everyone who responded, on the list and in PM ! Actually my concern is the high amperage in the fuel pumps and the digital lanes wires. All those electrons flowing to and from the panel just to keep the engine running, considering the avionics in the vicinity... Maybe relays or contactors for the 20 amp circuits... Those injection engines are a bit complicated to manage : 5 switches to fumble with in addition to the regular master and starter switches just to start the engine. Lots of thinking to simplify the task of the pilot and avoid forgetting something or manoeuvring the switches in the wrong sequence... Thank you for your attention, and please keep giving advices, this is a great help ! -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Date: Jan 05, 2017
From: "Raven Aero Service" <ravenas(at)ksbroadband.net>
Subject: audio jacks for King KY 197
Hello, I am trying to install a King KY 197 radio in an aircraft.=C2- I have the installation instructions.=C2- The diagrams for making the connection ha rness show that shielded single-conductor cables should be used to connect the audio jacks to the radio, and that the shield for each cable should be connected to the "barrel" of the associated=C2-jack on one end and to a p articular radio terminal on the other end.=C2- It seems logical to me tha t it would also be required to insulate the jack barrel from the panel it i s mounted in, but I can find no instructions for this.=C2- Can anyone tel l me if this is required? Thank you Jon Hornbostel ________________________________________________________________________________
Date: Jan 05, 2017
At 04:25 AM 1/5/2017, you wrote: >Le 04/01/2017 =C3 20:49, Charlie England a =C3=A9crit=C2 : >> >> >>Even 20 A is not that big a deal for the proper >>switch. Going bigger than that, a relay starts >>to look more attractive, especially since the >>automotive world now makes fairly light weight, >>high current relays available for very reasonable prices. > >Charlie and all, > >Thank you to everyone who responded, on the list and in PM ! >Actually my concern is the high amperage in the >fuel pumps and the digital lanes wires. All >those electrons flowing to and from the panel >just to keep the engine running, considering the avionics in the vicinity. =2E. >Maybe relays or contactors for the 20 amp circuits... >Those injection engines are a bit complicated to >manage : 5 switches to fumble with in addition >to the regular master and starter switches just to start the engine. >Lots of thinking to simplify the task of the >pilot and avoid forgetting something or >manoeuvring the switches in the wrong sequence... Is there a down-loadable copy of the installation manual for your system? The REAL concerns have little to do with switch ratings, wire sizes or breakers/fuses. The elegant solution considers failure modes (including risk of pilot error) . . . this is a system integration issue . . . a skill seldom demonstrated by folks who manufacture and market airplane parts. After FMEA is done, you NEED to know the ENERGY requirements for each accessory and anticipate the combinations in which those accessories are needed after loss of a single accessory for any reason. This is called LOAD ANALYSIS and it sets the sizes of alternators, batteries, circuit protection, wires, and yes . . . switches. Switches are last on the list of concerns. Many individuals in the OBAM aviation community get wrapped around the axles of AC vs. DC ratings, slow vs. fast break mechanisms, etc. etc. The underlying motivation being "nothing is too good for my airplane . . . and after all . . . it IS an airplane . . . everybody knows that things breaking on airplanes comes with risks for spiraling out of the sky trailing smoke." The realities are not nearly so exciting. See http://tinyurl.com/jfr8zzu The bottom line demonstrates that IF your FMEA is artfully conducted and IF your energy budgets are KNOWN and MAINTAINED, likelihood of an electrically induced bad day in the cockpit is vanishingly low. Let's pray over the manufacture's data a bit to see if there's enough data to move your deliberations forward with confidence. Bob . . . --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jan 05, 2017
Subject: Re: audio jacks for King KY 197
At 07:48 AM 1/5/2017, you wrote: >Hello, > >I am trying to install a King KY 197 radio in an aircraft. I have >the installation instructions. The diagrams for making the >connection harness show that shielded single-conductor cables should >be used to connect the audio jacks to the radio, and that the shield >for each cable should be connected to the "barrel" of the associated >jack on one end and to a particular radio terminal on the other >end. It seems logical to me that it would also be required to >insulate the jack barrel from the panel it is mounted in, but I can >find no instructions for this. Can anyone tell me if this is required? Absolutely recommended. There are lots of installations not insulated with no perceived problems . . . but it's easy to do from the get-go . . . See http://tinyurl.com/hngj22o http://tinyurl.com/z9wr629 Bob . . . --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jan 05, 2017
Bob, The 912iS installation manual (along with all other manuals for all Rotax engines) is available at: http://www.rotax-owner.com/en/support-topmenu/engine-manuals <http://www.rotax-owner.com/en/support-topmenu/engine-manuals> Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop (75 hrs). Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com On Jan 5, 2017, at 12:11 PM, Robert L. Nuckolls, III wrote: At 04:25 AM 1/5/2017, you wrote: > Le 04/01/2017 =C3=83 20:49, Charlie England a =C3=83=C2=A9crit=C3=82 : >> >> >> Even 20 A is not that big a deal for the proper switch. Going bigger than that, a relay starts to look more attractive, especially since the automotive world now makes fairly light weight, high current relays available for very reasonable prices. > > Charlie and all, > > Thank you to everyone who responded, on the list and in PM ! > Actually my concern is the high amperage in the fuel pumps and the digital lanes wires. All those electrons flowing to and from the panel just to keep the engine running, considering the avionics in the vicinity... > Maybe relays or contactors for the 20 amp circuits... > Those injection engines are a bit complicated to manage : 5 switches to fumble with in addition to the regular master and starter switches just to start the engine. > Lots of thinking to simplify the task of the pilot and avoid forgetting something or manoeuvring the switches in the wrong sequence... Is there a down-loadable copy of the installation manual for your system? The REAL concerns have little to do with switch ratings, wire sizes or breakers/fuses. The elegant solution considers failure modes (including risk of pilot error) . . . this is a system integration issue . . . a skill seldom demonstrated by folks who manufacture and market airplane parts. After FMEA is done, you NEED to know the ENERGY requirements for each accessory and anticipate the combinations in which those accessories are needed after loss of a single accessory for any reason. This is called LOAD ANALYSIS and it sets the sizes of alternators, batteries, circuit protection, wires, and yes . . . switches. Switches are last on the list of concerns. Many individuals in the OBAM aviation community get wrapped around the axles of AC vs. DC ratings, slow vs. fast break mechanisms, etc. etc. The underlying motivation being "nothing is too good for my airplane . . . and after all . . . it IS an airplane . . . everybody knows that things breaking on airplanes comes with risks for spiraling out of the sky trailing smoke." The realities are not nearly so exciting. See http://tinyurl.com/jfr8zzu <http://tinyurl.com/jfr8zzu> The bottom line demonstrates that IF your FMEA is artfully conducted and IF your energy budgets are KNOWN and MAINTAINED, likelihood of an electrically induced bad day in the cockpit is vanishingly low. Let's pray over the manufacture's data a bit to see if there's enough data to move your deliberations forward with confidence. Bob . . . This email has been checked for viruses by Avast antivirus software. www.avast.com ________________________________________________________________________________
Date: Jan 05, 2017
At 12:38 PM 1/5/2017, you wrote: >Bob, > >The 912iS installation manual (along with all other manuals for all >Rotax engines) is available at: > ><http://www.rotax-owner.com/en/support-topmenu/engine-manuals>http://www.rotax-owner.com/en/support-topmenu/engine-manuals Thanks! Bob . . . --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jan 05, 2017
Le 05/01/2017 19:11, Robert L. Nuckolls, III a crit : > > The elegant solution considers failure modes (including > risk of pilot error) . . . this is a system integration > issue . . . a skill seldom demonstrated by folks who > manufacture and market airplane parts. > > After FMEA is done, you NEED to know the ENERGY > requirements for each accessory and anticipate the > combinations in which those accessories are needed > after loss of a single accessory for any reason. > > This is called LOAD ANALYSIS and it sets the sizes > of alternators, batteries, circuit protection, wires, > and yes . . . switches. Switches are last on the list > of concerns. Hi Bob, Thank you for responding. I tried to follow this approach of system integration, and after some hard thinking we had a 2-day meeting with my partners playing the "what if" game and establishing the corresponding load analysis. Thanks Bob B for the link. I would also suggest downloading the Operator's Manual to have a look at the starting and holding point sequences. Seems akin to rigging a nuclear sub for dive... Many opportunities to forget something or doing the wrong manoeuver. I have some ideas for combining some functions and rendering pilot error less likely, though it implies more complexity than the rudimentary circuit proposed by Rotax (with some errors in their schematics). I would add that the Aeroelectric community is a tremendous help. Peer review and critique of ideas or architectures are invaluable. Please Bob and everyone, keep up the good job ! And BTW our two battery, Rotax 914 four-seater is still going strong after 12 years ! Thank you, -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Subject: Re: Trim position indicator
Date: Jan 05, 2017
I'm making some progress on this. The VPX guys say use a 10K linear pot. I've determined that with the appropriate timing gear that I'll be getting 3/4 of a revolution total. Which means I don't need a multi-turn pot. And I just happen to have a 10k pot in the drawer (Alpha 813 B10K). And it's got a 1.75" shaft (which is very important since that bulkhead is rather thick). But I can't tell if it's linear or audio taper. At 50% of travel, I'm getting about 6K ohms. IIRC, if it's an audio taper 10k pot, at 50% of travel, I would be seeing about 3k. Does anyone know if this particular pot is linear or audio taper? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464739#464739 ________________________________________________________________________________
Date: Jan 05, 2017
Most audio pots aren't really logarithmic, they're a two or three straight line approximation. The 25% and 75% travel resistances should enable a better determination, but the B in the code usually means linear taper. I'd most definitely use a dedicated servo pot, cheap panel pots wear horribly and lose contact; not much of a deal if your old amp volume knob goes a bit crackly, but probably not helpful in your application. On Jan 5, 2017, at 19:08, donjohnston <don@velocity-xl.com> wrote: I'm making some progress on this. The VPX guys say use a 10K linear pot. I've determined that with the appropriate timing gear that I'll be getting 3/4 of a revolution total. Which means I don't need a multi-turn pot. And I just happen to have a 10k pot in the drawer (Alpha 813 B10K). And it's got a 1.75" shaft (which is very important since that bulkhead is rather thick). But I can't tell if it's linear or audio taper. At 50% of travel, I'm getting about 6K ohms. IIRC, if it's an audio taper 10k pot, at 50% of travel, I would be seeing about 3k. Does anyone know if this particular pot is linear or audio taper? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464739#464739 ________________________________________________________________________________
Subject: e will be out a minimum of three weeks. That leaves
the Argo
From: "blueberryjerry" <blueberryjerry0822(at)hotmail.com>
Date: Jan 05, 2017
KAPOLEI, Hawaii - Tom Pernice Jr. Wholesale NFL Jerseys China (http://www.chinajerseysnfls.com/) . birdied his final four holes for a 12-under 60 and a four-stroke lead Friday in the Champions Tours Hawaii Championship.Thats awesome to shoot 12-under 60, Pernice said. I just want to have another good day tomorrow.Pernice finished a stroke off the tour record of 59 set by Kevin Sutherland last month in the Dicks Sporting Goods Open in Endicott, New York.Davis Love III opened with a 69 in his Champions Tour debut. The 20-time PGA Tour winner turned 50 in April.Pernice played his final nine holes a the front nine at Kapolei Golf Club a in 7-under 29, also birdieing Nos. 1, 2 and 4. He had five birdies on his opening nine.On the last four holes, he hit wedge to 6 feet on the par-4 sixth, a lob wedge to 10 feet on the par-5 seventh, chipped in from 25 feet on the par-3 eighth, and hit a lob wedge to a foot on the par-4 ninth.I hit the ball really good in the pro-am yesterday and hit good shots on the range this week and had good practice sessions, Pernice said. The greens are really good. I putted well today.The 55-year-old Pernice tied the tour record for birdies with 12. Walter Morgan set the mark in the 2002 AT&T Canada Senior Open, Fred Couples matched it at the 2011 AT&T Championship and Sutherland accomplished the feat in his 59.A two-time winner on the PGA Tour winner, Pernice won the Principal Charity Classic in June in Iowa for his third Champions Tour title.Michael Allen was second after a 64. Hes fighting a cold.I got sick Tuesday night. Its not fun, Allen said. I putted well and, basically with a cold, I played one shot at a time. I rolled the ball beautifully today.Joey Sindelar and Scott Dunlap shot 65, and Jay Haas, Vijay Singh, Paul Goydos, Jim Carter and Mike Goodes followed at 66.Guy Boros and Skip Kendall also made their tour debuts. They shot 69.Bernhard Langer, the tour leader with five victories, skipped the tournament to play in a European Senior Tour event in Germany. Cheap! Jerseys USA (http://www.chinajerseysnfls.com/) . This week they discuss the Philadelphia 76ers, Gregg Popovich, Royal and Ancient Golf Club and Bill Belichick. China Jerseys Authentic (http://www.chinajerseysnfls.com/) .5 million. The 25-year-old Varlamov is thriving under first-year coach and Hall of Fame goaltender Patrick Roy, posting a 26-9-5 record with a 2. http://www.chinajerseysnfls.com/ (http://www.chinajerseysnfls.com/) . City has reached new heights under manager Manuel Pellegrini as they transition from big spending/immediate impact to perennial contender. Yaya Toures seeming discontent Tuesday may complicate that, as does the little issue of Financial Fair Play.TORONTO -- The Flyin Hawaiian will be grounded for this week, and probably longer. Toronto receiver Chad Owens will miss the Argonauts game in Ottawa on Friday with a left foot injury, and the team believes he will be out a minimum of three weeks. That leaves the Argos with very little veteran depth at receiver. Slotback Andre Durie is out with a broken clavicle and wide receiver Jason Barnes is sidelined with a knee injury. Owens was wearing a walking boot for the second straight day when he arrived at Tuesdays practice.dddddddddddd The good news for the Argos is that the injury will only require treatment and rest and Owens will not have to undergo surgery. In other injury-related news, receiver Jason Barnes could not get an MRI Monday but will have one Tuesday. Head coach Scott Milanovich said he expects Barnes to miss this weekends game. Cheap NFL Jerseys (http://www.cheapjerseysstitchedshop.com/) Wholesale Jerseys (http://www.wholesalejerseyssafestore.com/) Wholesale NFL Jerseys (http://www.wholesalechinastitchedjerseys.com/) Jerseys From China (http://www.wholesalenflcheapjerseyschina.us.com/) Wholesale NFL Jerseys (http://www.chinanflonlinejerseys.com/) Cheap NFL Jerseys (http://www.cheapsoccerjerseyschinaonline.com/) Cheap Jerseys (http://www.cheapnbajerseyschinastore.com/) ' ' ' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464748#464748 ________________________________________________________________________________
Subject: MALABO, Equatorial Guinea - Both the Ivory Coast and
Camero
Date: Jan 05, 2017
MALABO, Equatorial Guinea - Both the Ivory Coast and Cameroon came into the day as big favourites at the African Cup of Nations, and both finished it happy just to avoid losing. Darren Woodson Jersey (http://www.footballcowboysshop.us/cowboys-darren-woodson-super-bowl-jersey-authentic/) .The Ivorians got a late equalizer from Seydou Doumbia shortly after Gervinho was sent off with a straight red card to earn a 1-1 draw with Guinea on Tuesday at Malabo Stadium.A short time later at the same venue, it was Cameroon that needed a late goal from Ambroise Oyongo to hold on for a 1-1 draw against Mali.We bounced back. Its a good point for us, said Ivory Coast captain Yaya Toure, who recently won his fourth African player of the year award. We have a couple of games coming, and I hope we will do well in them.The draws leave all four teams in Group D with one point. On Saturday, Ivory Coast will take on Mali and Cameroon will face Guinea.Gervinho had been Ivory Coasts best player, or least the one with the best chances, until a scuffle with Baissama Sankoh during an off-the-ball incident earned him a straight red in the 57th minute.With 10 men it was very hard, said Ivory Coast coach Herve Renard, who led Zambia to the African Cup title in 2012. I think the players did very well in the different organization (after the sending off).Doumbia, who came on in the 66th as the tactics changed, scored from in front of goal in the 72nd after a pass from Wilfried Bony. Toure was the one who started the play.Guinea had taken the lead in the 36th when Ibrahima Traore crossed to Mohamed Yattara.Traore then had a chance to double the lead in the 61st but his shot hit the crossbar.Were not happy, because we know we could win this game, Traore said. Were going to keep working hard. At the end we will win and we will qualify, because as I said we are not afraid of anyone.In the second match, Oyongo latched onto to a long pass from Raoul Loe in the 84th and beat Mali goalkeeper Soumaila Diakite in a fast-paced game that h! ad sever al missed chances at both ends.Sambou Yatabare had given Mali a surprising lead in the 71st, controling the ball with his chest and scoring from a tight angle after a free kick on the other side of the field.The manner we played this match, especially the second half, it was the manner to win the game, Cameroon coach Volker Finke said. The goal of Mali was a matter of concentration. The players were not concentrated.Cameroon, which conceded only one goal in qualifying, had chances earlier in the game but lacked quality finishing.One of the more entertaining moments came in the 57th minute when Cameroon forward Edgar Salli bounced the ball several times on his head to evade defenders but was eventually brought down just outside the box. Michael Irvin Super Bowl Jersey (http://www.footballcowboysshop.us/cowboys-michael-irvin-super-bowl-jersey-authentic/) . -- Kevin Harvick pulled away on a restart with 47 laps to go and ended Chase Elliotts two-race winning streak in NASCARs Nationwide Series with a dominating victory early Saturday at Richmond International Raceway. Tyron Smith Super Bowl Jersey (http://www.footballcowboysshop.us/cowboys-tyron-smith-super-bowl-jersey-authentic/) . Louis, MO (SportsNetwork. http://www.footballcowboysshop.us/cowboys-jay-novacek-super-bowl-jersey-authentic/ (http://www.footballcowboysshop.us/cowboys-jay-novacek-super-bowl-jersey-authentic/) . "I wouldnt read anything into what happened Saturday at Torrey Pines," Woods said Tuesday after an 18-hole exhibition for past winners of the Dubai Desert Classic.New York, NY (SportsNetwork.com) - Despite missing 25 games, reigning MVP Kevin Durant was selected to the All-Star Game Thursday as a reserve, while Kings center DeMarcus Cousins and Trail Blazers point guard Damian Lillard were among the players snubbed. Durant, who was named MVP of the 2012 All-Star Game and will be appearing in it for the sixth straight time, has only played in 21 of Oklahoma Citys 46 games while dealing with foot and toe injuries. There are plenty of fami! liar fac es among the Western Conference reserves, including Durants teammate Russell Westbrook, Rockets MVP candidate and NBA scoring leader James Harden and Clippers point guard Chris Paul. Warriors sharpshooter Klay Thompson will be making his first appearance. Spurs big man and future Hall of Famer Tim Duncan will be making his 15th appearance in the All-Star Game, tying him with Kevin Garnett and Shaquille ONeal for third-most all-time. Portland power forward LaMarcus Aldridge, who has put off thumb surgery, rounds out the West roster. Harden is expected to move into the starting lineup in place of injured Lakers star Kobe Bryant, who is sidelined for the rest of the season after undergoing shoulder surgery. Lillard, Cousins and Grizzlies guard Mike Conley are among the potential replacemeents on the roster. Cowboys Super Bowl Jerseys (http://www.footballcowboysshop.us/). There were few, if any, surprises among the Eastern Conference reserves, with the conference-leading Hawks placing three players in the game for the first time since 1980. Point guard Jeff Teague made his first All-Star game, forward Paul Millsap his second and center Al Horford will represent the East for the third time. Miami will be well-represented as well, with veterans Dwyane Wade and Chris Bosh earning their 11th and 10th consecutive trips, respectively. Clevelands Kyrie Irving and Chicagos Jimmy Butler round out the roster. Irving, the reigning All-Star Game MVP, will play in the game for a third consecutive year, while Butler is set to make his first appearance. The Western Conference starters as voted by fans were Bryant, Golden States Stephen Curry, New Orleans Anthony Davis, Memphis Marc Gasol and Blake Griffin of the Los Angeles Clippers. New Yorks Carmelo Anthony, Chicagos Pau Gasol, Clevelands LeBron James, Torontos Kyle Lowry and Washingtons John Wall were voted as starters for the Eastern Conference. Atlantas Mike Budenholzer and his staff will coach the East, while first-year Golden State coach Steve Kerr and his staff wil! l lead t he West. The game will be held at Madison Square Garden on Sunday, Feb. 15. Cheap NFL Jerseys (http://www.cheapjerseysstitchedshop.com/) Wholesale Jerseys (http://www.wholesalejerseyssafestore.com/) Wholesale NFL Jerseys (http://www.wholesalechinastitchedjerseys.com/) Jerseys From China (http://www.wholesalenflcheapjerseyschina.us.com/) Wholesale NFL Jerseys (http://www.chinanflonlinejerseys.com/) Cheap NFL Jerseys (http://www.cheapsoccerjerseyschinaonline.com/) Cheap Jerseys (http://www.cheapnbajerseyschinastore.com/) ' ' ' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464749#464749 ________________________________________________________________________________
Subject: ey members of the new ownership. The Cougars relocated
from
Date: Jan 05, 2017
Henrik Stenson remained on course to wrap up the Race to Dubai crown as Rory McIlroy endured a torrid opening day of the DP World Tour Championship in Dubai. Cheap Jerseys Wholesale (http://www.cheapjerseyswholesalenfl.us/) . Leaderboard DP World Tour Championship Stenson failed to make much happen on the greens at the Jumeirah Golf Estates as he ground out 16 pars, one birdie and a bogey in a workmanlike 72, while Lee Westwood set the early pace on six under after a superb 66. Lee Westwood leads the way after opening with a 66 Danny Willett, Stensons main threat in the race to be crowned European No 1, opened with an erratic 71 to edge one ahead of the Swede, but defending champion McIlroy is tied for 55th in the elite 60-player field following a 75 - his worst score in 29 rounds over the Earth Course. Westwood, still rattled after being denied a debut in next weeks World Cup of Golf, provided an excellent riposte as he played some of his best golf of the season on one of his favourite courses. Danny Willett and Henrik Stenson on the first tee The 43-year-old picked up an early birdie at the 583-yard second and added three in four holes around the turn before dropping his only shot of the day at the 12th.But the 2009 champion bounced back with birdies at the next two holes, and his assured putting earned him another at the 17th which took him into the outright lead ahead of Nicolas Colsaerts and Julien Quesne, who birdied four of the last five holes to vault up the leaderboard. Westwood carded seven birdies to hit the front on six under Sergio Garcia is a stroke further adrift after a bad mistake at the 16th cost him the outright lead having stormed to six under with three birdies in four holes from the eighth before he made only the second eagle of the first round at the 14th. Six months half price Upgrade to Sky Sports to watch Man Utd v Arsenal on Saturday and get the first six months half price But the Spaniard dumped his approach to the tricky 16th green into the water and ran up a double-bogey six! which d ropped him into a tie for fourth along with Joost Luiten and Francesco Molinari, while Victor Dubuisson slipped from five under to two under with bogeys at each of the final three holes. Live European Tour Golf November 18, 2016, 8:00am Live on Get Sky Sports Get a Sky Sports pass The four contenders for the overall Race to Dubai title all had their struggles on day one, none more so than McIlroy as he bogeyed three of the first six holes and dropped another shot after driving into the desert scrub at the 10th. Rory McIlroy fired his worst score in 29 rounds in the event He finally got a birdie putt to drop at the 14th and followed it with another at 15, but he undid that recovery work by blocking his second to 16 and finding the edge of the hazard, from where he needed two attempts to splash onto the green.McIlroy did at least finish on a positive note with a birdie at the last, but his very slim chances of retaining his European No 1 title effectively ended after 10 holes. Race to Dubai leader Henrik Stenson struggled to make much happen at the DP World Tour Championship, making just one birdie in a level-par 72 Stenson remains the man to beat despite being far from his best, and he admitted afterwards that average was a fair assessment of his opening 72 in which he parred the final 11 holes.Willett, who trails the Open champion by close to 300,000 points in the standings, got on a nice run after he hit back from an early bogey with three birdies in four holes before a tough back-nine 37 left him five behind Westwood. Danny Willett offset four birdies with three bogeys And the in-form Alex Noren, third in the Race to Dubai, put together a similar grafting round to Stenson, making two birdies and one bogey in a solid 71.Upgrade to Sky Sports now to watch Man Utd v Arsenal this Saturday and get the first six months half price! Also See: Race to Dubai contenders Dubai leaderboard Golf live on Sky Sports 4 European Tour Schedule Wholesale Authentic NFL Jerseys (http://www.cheapjerseyswholesalenfl.us/) . Se! ager had another triple, a home run and a double in a rare feat not seen in more than 40 years, leading Felix Hernandez and the Seattle Mariners past the New York Yankees 10-2. "It was a weird play," Seager said of the triple in the fourth inning. NFL Authentic Jerseys China (http://www.cheapjerseyswholesalenfl.us/) .The South African had three birdies on the front nine and another four after the turn at Leopard Creek Country Club to move to 16-under 128 overall.Grace, who won all four of his European Tour titles in 2012, dropped his only shot of the competition on the par-3 fifth. http://www.cheapjerseyswholesalenfl.us/ (http://www.cheapjerseyswholesalenfl.us/) . Ferrer, the two-time defending champion in Buenos Aires, is aiming to win his 21st ATP tournament. Ferrer will next face fellow Spaniard Nicolas Almagro, the fourth seed, who defeated Jeremy Chardy of France 7-6 (7), 6-3 in another quarterfinal match.CALGARY -- The Western Hockey League board of governors approved the sales of Prince George Cougars and Regina Pats on Wednesday. The board voted unanimously to approve the transfer of the Cougars ownership from Rick Brodsky to EDGEPRO Sports and Entertainment Ltd., and the Pats from Russ and Diane Parker to Queen City Sports and Entertainment Group Ltd. The new Prince George ownership group is led by local businessman Greg Pocock along with partners Ernest Ouellet, Raymond Fortier, and John Pateman. Former Cougars and current NHL defencemen Dan Hamhuis and Eric Brewer are also key members of the new ownership. The Cougars relocated from Victoria twenty years ago. Brodsky has been the only owner of the franchise since it beegan operations in Prince George in 1994. Cheap Jerseys Free Shipping (http://www.cheapjerseyswholesalenfl.us/). The new ownership group in Regina is headed by local businessman Anthony Marquart. His group will take over from the Parkers, who have owned and operated the Pats for the past 19 seasons. "The WHL is fortunate to have attracted two very high calibre ownership groups who are fu! lly comm itted to whatever is necessary to take the Prince George Cougars and the Regina Pats franchises to a new level," WHL Commissioner Ron Robison said in a statement. "We are confident that fans will enthusiastically embrace the local ownership groups and bring long-term stability to these WHL markets." Both sales are expected to close prior to the end of May. Cheap NFL Jerseys (http://www.cheapjerseysstitchedshop.com/) Wholesale Jerseys (http://www.wholesalejerseyssafestore.com/) Wholesale NFL Jerseys (http://www.wholesalechinastitchedjerseys.com/) Jerseys From China (http://www.wholesalenflcheapjerseyschina.us.com/) Wholesale NFL Jerseys (http://www.chinanflonlinejerseys.com/) Cheap NFL Jerseys (http://www.cheapsoccerjerseyschinaonline.com/) Cheap Jerseys (http://www.cheapnbajerseyschinastore.com/) ' ' ' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464750#464750 ________________________________________________________________________________
Subject: our shoulder, its four-to-six weeks or whatever and
you know
Date: Jan 05, 2017
TURIN, Italy -- Ten-man Benfica returned to the Europa League final following a 0-0 draw at tournament-favourite Juventus on Thursday, advancing on 2-1 aggregate. NFL Wholesale Jerseys (http://www.nflwholesalejerseyslife.com/) . Juventus created numerous chances but either couldnt find the target or was denied by Benfica goalkeeper Jan Oblak, who had a standout performance. Even when Benfica was reduced to 10 men in the 67th minute as Argentine midfielder Enzo Perez picked up his second yellow card for a foul on Arturo Vidal, Jorge Jesus squad maintained its composure. "Were a squad that tries to defend to perfection, and we more than deserved to advance," Benfica defender Guilherme Siqueira said. Its the third time Benfica has reached the final, having been runner-up in 1983 and last year, when the Portuguese side was beaten by Chelsea. In the May 14 final back in Turin, Benfica will face Sevilla, which scored in added time of a 3-1 loss at Valencia to advance on the away goal rule. With Diego Maradona watching from the tribune, Juventus controlled for long periods and came close to scoring the lone goal it needed. Andrea Pirlo shot high eight minutes in and a bicycle-kick attempt from Carlos Tevez also went high in the 24th. In the 43rd, a header from defender Leonardo Bonucci went just wide following a free kick from Pirlo, and Tevez couldnt quite reach it at the far post. In first-half added time, Paul Pogba inspired another chance for Juventus, leading to a header from Vidal that beat Oblak, but defender Luisao cleared the danger off the line. A downpour accompanied by hail greeted the squads at the start of the second half, and Benfica came close with a shot from Rodrigo that sailed over the bar in the 50th. Pirlo found the target with a splendid free kick in the 62nd but Oblak made a leaping save in the top right corner. Juventus substitute Pablo Osvaldo thought he scored in the 81st but was ruled offside. There was a brief skirmish between the benches in the final minutes, resulting in red cards ! for Juve ntus forward Mirko Vucinic, who did not play, and Benfica forward Lazar Markovic, who had just exited and will now miss the final. Benfica actually ended with nine men, as defender Ezequiel Garay was carried off on a stretcher following a collision, and all three substitutions were used. The referee let the match continue for eight minutes of added time but even that wasnt enough for Juventus, which can console itself by clinching its third successive Serie A title with a win over Atalanta on Monday. Jerseys NFL Wholesale (http://www.nflwholesalejerseyslife.com/) .com) - Novak Djokovic captured a mens Open Era-record fifth Australian Open title on Sunday by defeating rival Andy Murray in the final in Melbourne. Wholesale China Jerseys (http://www.nflwholesalejerseyslife.com/) . The Nevada Athletic Commission voted unanimously in Las Vegas to quit granting therapeutic use exemptions for fighters undergoing the so-called TRT. http://www.nflwholesalejerseyslife.com/ (http://www.nflwholesalejerseyslife.com/) .ca Fantasy Editor Scott Cullen, NFL Editor Ben Fisher, and Isaac Owusu discuss three hot fantasy football topics.Montreal Alouettes quarterback Anthony Calvillo said Wednesday he is symptom-free after suffering a concussion in mid-August and fully expects to play again this season. The 41-year-old pivot is eligible to come off the nine-game injured list in time to face the Toronto Argonauts in the last game of the regular season. Ive been adding to my workload week in and week out and I know Ill be coming off the nine-game (injured list) going into Week 18 and thats my goal right now is to get ready to play for that game," said Calvillo. Calvillo suffered the concussion in a game against the Saskatchewan Roughriders on August 17 when his head hit the turf at Mosaic Stadium.dddddddddddd He is also recovering from a partially torn rotator cuff. "The toughest part is theres no timeline on cussions. When you pull a hamstring or hurt your shoulder, its four-to-six weeks or whatever and you know thats a goal,! " added Calvillo. "With a concussion, its what your body tells you." The Alouettes are currently in third place in the East Division and could clinch a playoff spot with a win against the Winnipeg Blue Bombers on Thanksgiving Day. Cheap NFL Jerseys (http://www.cheapjerseysstitchedshop.com/) Wholesale Jerseys (http://www.wholesalejerseyssafestore.com/) Wholesale NFL Jerseys (http://www.wholesalechinastitchedjerseys.com/) Jerseys From China (http://www.wholesalenflcheapjerseyschina.us.com/) Wholesale NFL Jerseys (http://www.chinanflonlinejerseys.com/) Cheap NFL Jerseys (http://www.cheapsoccerjerseyschinaonline.com/) Cheap Jerseys (http://www.cheapnbajerseyschinastore.com/) ' ' ' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464751#464751 ________________________________________________________________________________
Subject: er started in net for Lethbridge (12-44-5), but was
pulled a
Date: Jan 05, 2017
MIAMI -- As soon as Chris Young connected on a deep fly ball to left field in the ninth inning, the New York Mets thought they had tied the game on a sacrifice fly. http://www.officialpackersteamgears.com/kyler-fackrell-jersey/ (http://www.officialpackersteamgears.com/kyler-fackrell-jersey/) . But they misjudged the strength of Marcell Ozunas arm. Ozuna threw out Kirk Nieuwenhuis at the plate to end the game to help the Miami Marlins beat the Mets 3-2 on Friday night. "Its pretty surprising. Hats off to Ozuna," Nieuwenhuis said. "He made a great throw. Theres no other way to put it." Even Ozuna thought the Mets had tied the game. "I didnt think I had a chance to get him out, but I was going to throw it no matter what," Ozuna said. Ozuna also threw out David Wright to end the eighth after the Mets cut the deficit to 3-2. "I cant remember seeing a game decided by two great throws from a left fielder and two great tags from the catcher to end the game," Marlins manager Mike Redmond said. "Thats pretty amazing." Henderson Alvarez (4-3) pitched 6 1-3 scoreless innings, allowing seven hits without a walk, and struck out five. In his past six starts, he is 2-0 with a 0.68 ERA, which leads the majors since May 22. "It was a good start for myself. All my pitches were working. Now its about keeping going forward," Alvarez said. Steve Cishek allowed a double to Nieuwenhuis to open the ninth, but earned his 17th save in 18 chances when Ozunas throw landed in catcher Jarrod Saltalamacchias glove for his fourth assist of the season. "He started at the Clevelander, so I didnt think he had a shot, but he started running in," Saltalamacchia said. "Once he got closer I knew he had a chance, but thats a tough throw, big moment like that. You tend to do too much. He made a perfect throw." Mets starter Daisuke Matsuzaka (3-1) allowed one run and six hits in 5 1-3 innings. He struck out four. "I felt good today, and just going off our last time off of Alvarez, I knew it was going to be a close game -- a one or two-run game --! so I kn ew I couldnt give up too many runs," Matsuzaka said. "One run ended up making a difference." Adeiny Hechavarria drove in two runs, and Saltalamacchia hit two doubles for the Marlins, who won their major league-best 17th one-run game of the season despite going 1 for 11 with runners in scoring position. "It was nice to win that one," Redmond said. "We needed to win that one." Six of the eight games between these clubs this season have been decided by one run New York had a two-game winning streak snapped. With the Mets trailing 3-0 in the eighth, Wright hit an RBI single off Kevin Gregg. Two batters later, with Mike Dunn pitching, pinch-hitter Eric Campbell singled to left field to make it 3-2. Wright was thrown out at the plate as he tried to score on the hit. "I got thrown out by about 10 feet, so it wasnt a real close play," Wright said, "but at the same time we kind of thought that he was blocking (the plate) and apparently they thought he wasnt." Mets manager Terry Collins challenged the play, taking up the argument that Wright was blocked from getting to the plate. "When you saw replays, his foot had pretty much that whole side blocked," Collins said. "The over-the-top view, I dont know. You dont ever get an explanation. All they say is the play stands. "You dont ever get an explanation or why they ruled it, and the umpires are as confused as anybody." Rafael Furcal led off of the game for the Marlins with a triple off the right-field fence and scored on a groundout by Hechavarria. It was Furcals first extra-base hit of the season in 30 at-bats and first leadoff triple since June 11, 2010, against the Angels when he played for the Dodgers. "I knew that was the only run I could give up the rest of my outing," Matsuzaka said. After Jake Marisnick stole second base in the seventh, he swiped third with Wright not in position to cover the bag. He then scored when catcher Anthony Reckers throw to third went into left field. "It surprised them a little bit that he took off there with a left-hand hitter," R! edmond s aid. "He was being aggressive and took advantage of a bad throw. That was a huge run for us." The Marlins extended their lead to 3-0 later in the inning when Wright attempted to bare-hand a grounder hit by Hechavarria, but the ball bounced past him, allowing Justin Bour to score. Wright was originally charged with an error, but it was later changed to a hit. NOTES: Mets SS Ruben Tejada took a base hit away from Casey McGehee in the eighth inning when he made a diving stop to his left, spun on the ground, and threw to first from his knees. ... Wright has a 10-game hitting streak at Marlins Park. ... Miami will send RHP Tom Koehler (5-5, 3.84) to the mound on Saturday. New York will counter with RHP Jacob deGrom (0-4, 4.39). http://www.officialpackersteamgears.com/jacob-schum-jersey/ (http://www.officialpackersteamgears.com/jacob-schum-jersey/) . With a win tonight, Buehrle will match Yankees ace Masahiro Tanaka for the most wins in the majors with 11. Buehrle is 10-4 with a 2.32 earned run average, but has lost his last three starts, including a 7-3 setback at Yankee Stadium last Wednesday. http://www.officialpackersteamgears.com/ray-nitschke-jersey/ (http://www.officialpackersteamgears.com/ray-nitschke-jersey/) .Y. -- The Detroit Red Wings had just enough time to salvage a point. http://www.officialpackersteamgears.com/sam-shields-jersey/ (http://www.officialpackersteamgears.com/sam-shields-jersey/) . The team said they will announce a corresponding roster move prior to their series opener on Tuesday night in Kansas City.MOOSE JAW, Sask. - Logan Nelson and Jack Walker scored shootout goals and Patrik Polivka made 31 saves through overtime to lift the Victoria Royals over the Moose Jaw Warriors 4-3 in Western Hockey League action on Monday. Joe Hicketts had a goal and an assist, and Austin Carroll and Axel Blomqvist also scored in regulation for Victoria (41-16-4). Travis Brown picked up two assists. Jesse Forsberg scored one goal and assisted on another for Moose Jaw (15-34-9), while Jack Rodewald and Ta! nner Ebe rle rounded out the Warriors offence. Brayden Point chipped in with assists on all three goals. Moose Jaw goalie Zach Sawchenko stopped 29 of 32 shots in defeat. --- PATS 4 WHEAT KINGS 0 REGINA Dyson Stevenson scored two goals and helped on another, and Daniel Wapple made 23 saves as the Pats blanked the Wheat Kings. Morgan Klimchuk had a goal and an assist and Carter Hansen also scored for Regina (31-22-6). Jordan Papirny stopped 35 of 39 shots for Brandon (28-24-8), which is winless in its last six games. The Pats were 1 for 8 on the power play while the Wheat Kings failed to score on five opportunities with the man advantage. --- RAIDERS 3 BRONCOS 1 SWIFT CURRENT, Sask. Nick McBride made 31 saves and the Raiders scored two power-play goals to edge the Broncos. Graeme Craig and Leon Draisaitl scored with the man advantage and Collin Valcourt added an even-strength goal for Prince Albert (27-28-4). Draisaitl also picked up an assist for a two-point game. Julius Honka scored the lone goal for Swift Current (29-23-88), on a power play in the third period. http://www.officialpackersteamgears.com/jc-tretter-jersey/ (http://www.officialpackersteamgears.com/jc-tretter-jersey/). Eetu Laurikainen made 24 saves in the losing effort. --- OIL KINGS 12 HURRICANES 0 EDMONTON Mitchell Moroz scored two goals and assisted on three mote, and Tristan Jarry stopped 25 shots as the Oil Kings dominated the Hurricanes. Henrik Samuelsson had two goals and two assists, Brett Pollock and Curtis Lazar had two goals and one assist apiece, Reid Petryk scored once and assisted on four goals, Edgars Kulda had a goal and an assist, and Ashton Sautner and Mads Eller also scored for Edmonton (41-14-2). Teagan Sacher started in net for Lethbridge (12-44-5), but was pulled after giving up six goals on 20 shots through just under 31 minutes. Jonny Hogue stopped 27 of 33 shots in relief. The Oil Kings outshot the Hurricanes 53-25 and were 6 for 11 on the power play. Lethbridge racked up 58 penalty minutes on 19 infractions. ---! HITMEN 7 REBELS 1 CALGARY Brady Brassart scored a hat trick, and Adam Tambellini had a goal and three assists as the Hitmen toppled the Rebels for their seventh straight win. Joe Mahon scored twice, Greg Chase had a goal and two assists, and Travis Sanheim contributed with five helpers for Calgary (39-15-6), who was 4 for 8 with the man advantage. Mack Shields made 39 saves. Adam Musil scored the lone goal for Red Deer (28-28-4), which has dropped its last two. Patrik Bartosak started in net for the Rebels but left the game after giving up six goals on 39 shots through 56:44. Taz Burman stopped 2 of 3 shots in relief. Cheap NFL Jerseys (http://www.cheapjerseysstitchedshop.com/) Wholesale Jerseys (http://www.wholesalejerseyssafestore.com/) Wholesale NFL Jerseys (http://www.wholesalechinastitchedjerseys.com/) Jerseys From China (http://www.wholesalenflcheapjerseyschina.us.com/) Wholesale NFL Jerseys (http://www.chinanflonlinejerseys.com/) Cheap NFL Jerseys (http://www.cheapsoccerjerseyschinaonline.com/) Cheap Jerseys (http://www.cheapnbajerseyschinastore.com/) ' ' ' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464752#464752 ________________________________________________________________________________
Subject: en activated from the disabled list. Blackwood, 28,
has miss
Date: Jan 05, 2017
Eden Prarie, MN (SportsNetwork. Wholesale Ravens Jerseys (http://www.cheapravensjerseysauthentic.com/) .com) - The Minnesota Vikings waived running back Ben Tate on Tuesday. Tate was waived by the Browns in mid-November and quickly picked up by the RB- needy Vikings. He only played three games for Minnesota and gained 38 yards on 13 carries. The Auburn product signed with the Browns as a free agent in March after spending his first three seasons with Houston. He started six games and rushed for 333 yards with a 3.1-yard average and four touchdowns with the Browns. Tate, 26, ran for 771 yards with four touchdowns and caught 34 passes for 140 yards in 14 games last season and has accumulated 2,363 rushing yards and 14 touchdowns in 51 NFL games. Cheap Ravens Jerseys (http://www.cheapravensjerseysauthentic.com/) .Steamboat Ski Resort contends Steamboat Springs, Colorado has long been known as Ski Town, U.S.A., and claims in a new lawsuit that Salt Lake tourism officials violated their trademark when they rolled out the Ski City marketing campaign last month. Wholesale Ray Lewis Jersey (http://www.cheapravensjerseysauthentic.com/) .C. -- Panthers wide receiver Steve Smith has been ruled out for Sundays game against the Atlanta Falcons. http://www.cheapravensjerseysauthentic.com/ (http://www.cheapravensjerseysauthentic.com/) . -- Peyton Manning is the only player in this Super Bowl who has won the big game.Winnipeg Goldeyes manager Rick Forney announced today that veteran outfielder Ray Sadler has been traded to the Kansas City T-Bones to complete a previous trade between the two clubs and veteran infielder Jake Blackwood has been activated from the disabled list. Blackwood, 28, has missed the last 15 games with an ankle injury. Hes hitting .263 this season with two home runs and 21 RBI in 33 games. Sadler, 33, hit .277 with 21 home runs and 81 RBI in 109 games with the Goldeyes during the last two seasons since being acquired from the Kansas City T-Bones last July. Baltimore Ravens Jerseys China (http://www.! cheaprav ensjerseysauthentic.com/). . With Blackwood coming off the DL, the Goldeyes needed to move a veteran or LS-5 player off their roster. The Goldeyes now have 21 players on their active roster, including 11 pitchers and 10 position players. Winnipeg finishes a three-game series with the Sioux City Explorers Thursday night at Shaw Park. Cheap NFL Jerseys (http://www.cheapjerseysstitchedshop.com/) Wholesale Jerseys (http://www.wholesalejerseyssafestore.com/) Wholesale NFL Jerseys (http://www.wholesalechinastitchedjerseys.com/) Jerseys From China (http://www.wholesalenflcheapjerseyschina.us.com/) Wholesale NFL Jerseys (http://www.chinanflonlinejerseys.com/) Cheap NFL Jerseys (http://www.cheapsoccerjerseyschinaonline.com/) Cheap Jerseys (http://www.cheapnbajerseyschinastore.com/) ' ' ' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464753#464753 ________________________________________________________________________________
Subject: Holly Bradshaw, training in USAAPRIL 12-17: Siob
Date: Jan 05, 2017
SHENZHEN, China - Defending champion Li Na and Peng Shuai advanced Friday to set up an all-Chinese final at the Shenzhen Open. Kansas City Chiefs Jerseys China (http://www.cheapchiefsjerseysauthentic.com/) . Top-seeded Li defeated Germanys Annika Beck 6-1, 6-3, while fifth-seeded Peng advanced in a walkover when American Vania King withdrew with a right thigh injury. "Itll be a tough match tomorrow," Li said. "Were quite familiar with each other and have improved a lot over the last year. But no matter what, Im quite looking forward to the final." Li was leading 6-1, 5-0 Friday when Beck came back to reel off three straight games, but the former French Open champion regrouped to close out the match. King said she began feeling pain in her leg during her win over second-seeded Sara Errani in the second round and pulled out to rest before the Australian Open, which begins on Jan. 13. "It was a really difficult decision for me to pull out because I hate losing and not competing," King said. "But I just have to look out for my health." Saturdays final will be just the second in WTA history featuring two Chinese players. Li lost the first when she retired against Zheng Jie at Oeiras in 2006. Li has a 5-1 record against Peng, including a 4-0 mark at tournaments in China. Cheap Derrick Thomas Stitched Jersey (http://www.cheapchiefsjerseysauthentic.com/) . Ryan Getzlaf certainly got them started in the second. Getzlaf scored the first two goals in the second, and Teemu Selanne scored the go-ahead goal late in the period as the Anaheim Ducks beat the Nashville Predators 4-3 Thursday night. Wholesale Chiefs Jerseys China (http://www.cheapchiefsjerseysauthentic.com/) . Blown save in the ninth inning? No problem. http://www.cheapchiefsjerseysauthentic.com/ (http://www.cheapchiefsjerseysauthentic.com/) . The Laval Rouge et Or defensive back/kick-returner gained the invitation following his showing Sunday at an NFL regional combine in Baltimore.Sam Oldham impressed at the British Championships, but it was mixed fortun! es for Q uillan Isidore and Savannah Marshall as the Sky Academy Sports Scholars continued their fight to be at Rio. Oldham wasnt able to hit the heights of his all-around glory at the English Championships in March, but the 23-year-old still looked in good form in Liverpool at the weekend with a third spot in the floor and high bar disciplines. He was also fourth overall.Injuries have hampered Oldhams progress at times since the London Olympics, but the Nottingham stars health and mentality look sharp with Rio qualification reaching its climax.Oldham said: The British Championships was a job well done. I had a great weekend in Liverpool and I was really happy to have hit nine for nine routines over the two days of competition.Im really looking forward to getting back in the gym and working towards the next competition. The road to Rio continues.BMX star Quillan Isidore may have suffered a miserable World Cup in Manchester last year with crashes in all three races, but he was a steady performer at the weekend at his home venue. Quillan Isidore performed in front of his home fans at the weekend Manchester welcomed the UCI BMX Supercross World Cup for a fourth consecutive year and while GB team-mate Liam Phillips grabbed the headlines with a fourth successive titlle, the 19-year-old Isidore showed signs of a rising composure under pressure.ddddddddddddIsidore said: Overall it was a positive weekend for me. Although my day ended in the 1/8ths, I performed at the best of my ability and delivered what I was capable of at this moment in time.Ive got a more positive head on my shoulders when it comes to racing now so Im pleased with how I dealt with the home crowd pressures and enjoyed myself. Savannah Marshall will be desperate to bounce back at the World Championships in May There was disappointment for boxer Savannah Marshall who surprisingly lost her opening fight at the European qualifying tournament in Samsun, Turkey on Monday.The 24-year-old from Hartlepool lost to Erika Guerrier of France and she must now hope t! o take h er final qualification chance at the World Championships in May in Kazakhstan.WHATS COMING UP FOR OUR SCHOLARS...MARCH 19 - May 2: Holly Bradshaw, training in USAAPRIL 12-17: Siobhan-Marie OConnor, British Championships in GlasgowAPRIL: Olivia Breen, training camp in TenerifeMAY 22-30: Sam Oldham, European Championships in Switzerland Also See: About the Scholarship Meet the athletes Blogs Videos Galleries Cheap NFL Jerseys (http://www.cheapjerseysstitchedshop.com/) Wholesale Jerseys (http://www.wholesalejerseyssafestore.com/) Wholesale NFL Jerseys (http://www.wholesalechinastitchedjerseys.com/) Jerseys From China (http://www.wholesalenflcheapjerseyschina.us.com/) Wholesale NFL Jerseys (http://www.chinanflonlinejerseys.com/) Cheap NFL Jerseys (http://www.cheapsoccerjerseyschinaonline.com/) Cheap Jerseys (http://www.cheapnbajerseyschinastore.com/) ' ' ' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464754#464754 ________________________________________________________________________________
Subject: ation wwere released earlier this month and the 14
Date: Jan 05, 2017
Stitched AAron Donald Jersey (http://www.cheaplosangelesramsjerseysauthentic.com/) . Week 2s biggest games include Florida facing Miami and Notre Dame travelling to the Big House to conclude their rivalry against Michigan in primetime on TSN2 and TSN 1050. Cheap Rams Jerseys Authentic (http://www.cheaplosangelesramsjerseysauthentic.com/) . Hes the same player he always was, only now his efforts are being rewarded. The rookie manager has made a habit of heaping praise on others when things are going well, and accepting criticism when they arent. But in the case of Hurtado, its what the coach is NOT saying that may be the secret to a superb run of form. http://www.cheaplosangelesramsjerseysauthentic.com/ (http://www.cheaplosangelesramsjerseysauthentic.com/) . Jimmy Howard made 44 saves and Henrik Zetterberg scored two goals, leading the Detroit Red Wings to a 5-1 victory over the Dallas Stars on Saturday night.(SportsNetwork. Rams Jerseys China (http://www.cheaplosangelesramsjerseysauthentic.com/) .com) - Richie Incognito has reportedly been admitted to a psychiatric care unit in Arizona. According to TMZ Sports, the offensive lineman at the center of the Miami Dolphins bullying scandal checked into a facility on Thursday night. Incognito was suspended by the Dolphins last November and didnt play the rest of the season after fellow offensive lineman Jonathan Martin left the team before a Week 9 game against Cincinnati and later claimed he had been bullied and harassed by teammates. The results of an investigation wwere released earlier this month and the 144- page report from Ted Wells concluded that the harassment was a contributing factor in Martins decision to leave the team, but added that it was not intended to drive him away or cause lasting emotional injury. Cheap Eric Dickerson Jersey (http://www.cheaplosangelesramsjerseysauthentic.com/). Incognito had strong words for Wells via Twitter after the report was issued, then apologized to Wells, Dolphins owner Stephen Ross and Martin a few days later. ! Earlier this week it was reported by TMZ Sports that Incognito smashed his own Ferrari with a baseball bat. Cheap NFL Jerseys (http://www.cheapjerseysstitchedshop.com/) Wholesale Jerseys (http://www.wholesalejerseyssafestore.com/) Wholesale NFL Jerseys (http://www.wholesalechinastitchedjerseys.com/) Jerseys From China (http://www.wholesalenflcheapjerseyschina.us.com/) Wholesale NFL Jerseys (http://www.chinanflonlinejerseys.com/) Cheap NFL Jerseys (http://www.cheapsoccerjerseyschinaonline.com/) Cheap Jerseys (http://www.cheapnbajerseyschinastore.com/) ' ' ' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464755#464755 ________________________________________________________________________________
Date: Jan 05, 2017
alec(at)alecmyers.com wrote: > I'd most definitely use a dedicated servo pot What's a "servo pot"? This will provide a visual indication of the trim position. Something that I haven't had before. So if it stops indicating, it's absolutely not a problem. If it stops rotating, that would be annoying, but not insurmountable. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464756#464756 ________________________________________________________________________________
Date: Jan 05, 2017
Something like this: http://www.mouser.com/ds/2/414/8140-18711.pdf I had got it in mind that it was part of a feedback mechanism to sense and c ontrol the trim position. But if it's just a visual indicator... I don't know the system you're interfacing to but if I were designing someth ing I'd still use a 10 turn device as it means you don't have to worry about the angular position of the pot in its mount. I'd run the output of the div ider to the analog input of a $1 PIC mounted adjacent and have a simple cali bration procedure to setup the two endpoint voltages. The PIC can output any analog or digital signal you want. On Jan 5, 2017, at 19:59, donjohnston <don@velocity-xl.com> wrote: alec(at)alecmyers.com wrote: > I'd most definitely use a dedicated servo pot What's a "servo pot"? This will provide a visual indication of the trim position. Something that I haven't had before. So if it stops indicating, it's absolutely not a probl em. If it stops rotating, that would be annoying, but not insurmountable. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464756#464756 ========================== ======== ========================== ======== ========================== ======== ========================== ======== ========================== ======== ________________________________________________________________________________
Date: Jan 05, 2017
This will be connected to a VPX. Once connected there's a calibration procedure to set the start and stop positions of the trim system. There's no way to get more than one rotation on the pulley. 1/2 - 3/4 turn is what I'm going to be looking at. So a one turn pot will provide more than enough motion. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464761#464761 ________________________________________________________________________________
Date: Jan 06, 2017
Subject: Re: Rotax 912iS questions
At 02:22 PM 1/5/2017, you wrote: >At 12:38 PM 1/5/2017, you wrote: >>Bob, >> >>The 912iS installation manual (along with all other manuals for all >>Rotax engines) is available at: >> >><http://www.rotax-owner.com/en/support-topmenu/engine-manuals>http://www.rotax-owner.com/en/support-topmenu/engine-manuals >> > > Thanks! Oh . . . fooey. For all the skills, time and effort Rotax put into the rest of this product, the wiring diagrams are . . . well . . . My teachers held that a schematic should be all revealing. The architecture, functionality of each conductor, pin connection and component should just 'jump off the page' at you. This philosophy was practiced in every job I've ever held. I'm disappointed to find that the published drawings in the installation manual do not lend themselves well in this regard. It would take too much time and perhaps consultation for me to achieve a functional understanding of the Rotax system at the engineer/integrator level. So, getting back to the original questions on switches . . . ANYTHING B&C sells in the way of switches is entirely adequate to the task. Some of the 12AWG wire called out is 'overkill' but not harmful. I wish I could be more helpful but getting conversant with the designer's intent using only these drawings is like looking for a black cat in a coal mine with a candle. Bob . . . --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Subject: RV8 Elec schematic.
Date: Jan 06, 2017
Hello All, Sharpen your knives. I am the novice of novices and have strayed well out o f my expertise and comfort zone and attempted to design an electrical syste m for my RV8. I have read the electrical bible (thank you Mr. Nuckolls) and used a combination of figure Z-10/8 and Z-11 as a guide. Attached schemati cs are a representation of my understanding. I'd prefer not to have a hot battery bus or add a second alternator. Althou gh IFR capable, it will be flown VFR or VMC most of the time. The system wi ll run off a plane power 60A alt with built in OV and Voltage regulation. E ngine is using 2 PMAG's and mechanical fuel injection. Main battery will pr obably go in the forward baggage compartment and the emergency battery loca tion is yet tbd. Probably aft. Some consumers on the busses will use breake rs and some will use fuses. The philosophy is to power the essential and emergency busses using the eme rgency battery during start. Primarily to get the avionics setup without th e engine running and then protecting against a voltage drop during start. A fter start it will remain online and all busses are powered by the alternat or while charging both batt's. Max 75% ALT load in cruise. Alternator fail- red light - (open emergency buss tie manually. I would lik e this to happen automatically but don't have the brainpower to design that yet, maybe later) will leave all busses powered by the main battery. All e quipment on the main buss is switchable effectively leaving the essential b uss powered by the main battery and emergency buss powered by the emergency battery. Following low volt on the main battery (2,5hrs health depending) the emergency battery powers emergency buss only. Max draw 1,5A so good fo r at least 3 hours (health depending) from start of alternator failure. Could I please ask for your expert advice and commentary on my design? Don' t be polite, there are lives on the line.. [cid:c88e7748-abd5-4055-b5ee-c64311dd7d38] Thank you in advance. Regards, Roger. p.s. I apologise if the schematic symbology details are not 100% correct. S till have to master the software. ________________________________________________________________________________
Date: Jan 07, 2017
Le 06/01/2017 17:19, Robert L. Nuckolls, III a crit > Oh . . . fooey. For all the skills, time and > effort Rotax put into the rest of this product, > the wiring diagrams are . . . well . . . ;-))) They were not good at making diagrams back in the 914 days, but it seems they didn't improve since then... I'll try to re-draw a simplified version of their proposed architecture to help clarify some of my future questions. > > > So, getting back to the original questions > on switches . . . ANYTHING B&C sells in the > way of switches is entirely adequate to > the task. So can we consider there is no problem bringing the two permanent 10 amp pump wires and the two 7.5 amp "lane" wires to the panel ? Thank you for your help, no doubt I'll have many more wiring questions about this very peculiar engine. -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Subject: Re: RV8 Elec schematic.
Date: Jan 06, 2017
The wire between the battery contactor and the main bus does not have to be so big. The diode in that wire will drop the voltage and it will get hot since it will carry the full aircraft electrical load. Depending on where the voltage regulator senses voltage, field or "B" lead, the battery could be charged at a higher voltage than intended. The emergency battery might not charge because the charging voltage will be dropped by the 3 diodes in series, the one in the main feeder, the one in the bridge rectifier, and the one connected to the top of the emergency bus. If the diode in main feeder is eliminated, and if the main bus tie is inadvertently closed, the emergency battery will help crank the engine. That is not desired because heavy current will flow in small wires and the emergency battery voltage will momentarily drop. One of the purposes of the E-Bus switch in Bob N's circuits is to be able to shut off the master contactor to conserve energy while still powering essential loads. If your alternator fails, the master contactor must remain energized to utilize main battery stored energy. It is hard to beat Bob's well proven designs. Attached is a circuit to consider. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464804#464804 Attachments: http://forums.matronics.com//files/brownout_prevention_166.jpg http://forums.matronics.com//files/brownout_prevention_2_571.pdf ________________________________________________________________________________
Date: Jan 06, 2017
> So can we consider there is no problem bringing the two permanent 10 amp pump wires and the two 7.5 amp "lane" wires to the panel ? > Designing an aircraft is full of compromises. Running always hot wires to the instrument panel makes the engine circuits more reliable and simpler. On the other hand, if one of those wires starts smoking or if a forced landing is imminent, they can not be disconnect from the battery. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464805#464805 ________________________________________________________________________________
Subject: ll and rolled into the end zone for a 21-7 lead. Th
Date: Jan 06, 2017
Scotland assistant manager Mark McGhee says he would be amazed if Gordon Strachan quit as national coach. Lucas Jersey (http://www.psgsoccershop.com/c-9-lucas-paris-saint-germain-fc-jersey.aspx) . The Motherwell manager gave an impassioned defence of their performance as a Scotland management team amid debate over Strachans future following last weeks 3-0 defeat by England.Speaking ahead of Saturdays visit of Partick Thistle, the former Millwall and Wolves boss said: In the week leading up to the game I know his appetite was full. It showed in the performance, that he got his message across and the boys responded and played very, very well. He is entitled to go into the next games and see if we can improve on the results and Id be amazed if he doesnt. Action from Englands 3-0 win over Scotland at Wembley McGhee has deliberately avoided media reaction to the Wembley defeat, which left Scotland fifth in their World Cup qualifying section with four points from four matches, and has not spoken at length to Strachan since the match.But he reiterated he felt the teams attitude and approach was spot-on and described their start to the game as excellent, enough to convince him that they can revive results next year, which starts with the visit of Slovenia on March 26.We have our views and everyone is entitled to their opinion, of course they are, thats the business we are in, McGhee said. Scotland began the campaign with a 5-1 victory in Malta But, as far as I am concerned, I am looking forward to the next games, in particular I cannot wait for the game in June. I want to get the other games, of course I do, and I want to do well but I want to be here when we play England at Hampden. Highlights of Englands clash with Scotland at Wembley in their 2018 World Cup qualifier Whatever else anyone says, we will just keep doing it until someone else takes the keys off us and we cant do it.Scotland took seven points from their first four matches in their Euro 2016 campaign from arguably a tougher run of fixtures, against! Germany , Georgia, Poland and the Republic of Ireland. But McGhee bristled at the suggestion that there were no signs of progress. Shaun Maloney scores the only goal of game as Scotland beat Republic of Ireland at Celtic Park In some ways our results and overall performance in the last campaign is better than it is in this campaign, he said.However, you have to be honest, you have to look at the players we have available, look at the opposition. Dont judge it as the same thing, things evolve. Circumstances in each game are different.You cant be blind where you dont take account of any other circumstance other than the result. Thats not fair. Last time we had a great result and performance against Ireland. Six months half price Upgrade to Sky Sports to watch Man Utd v Arsenal on Saturday and get the first six months half price We have not had one of those big results and performances yet. But thats what we are working towards. We were close to it at Wembley in some ways and thats what we will take into the next game, that we want that big performance.I feel if we go into that game and it was to be abject then there are clearly questions that need to be asked. But I feel so far that Gordon has done just about as well as we could be expected to do. And McGhees sentiments were echoed by Scotland captain Darren Fletcher who insists the players are keen for the former Celtic and Middlesbrough boss to remain in charge of the national side. Darren Fletcher (R) says players right behind Strachan He said: Friday was one of the most frustrating games I ever played in. We took the game to England at Wembley and were so unlucky.Gordon Strachan takes all the flak and deflects it from the players which is the sign of a great manager. The players want him to remain as manager. Upgrade to Sky Sports now to watch Ireland v New Zealand and Man Utd v Arsenal this Saturday and get the first six months half price! Also See: Scotland latest Scotland fixtures Scotland stats Table Live on Sky David Luiz Jersey (http://www.psgsoccershop.! com/c-26 -david-luiz-paris-saint-germain-fc-jersey.aspx) . Mired in an offensive slump, Lowry - the NBAs leader in taking charges this season - did what he has learned to do best, standing his ground and drawing a crucial offensive foul on the Cavaliers all-star point guard. Fast forward 30 seconds to the Cavs next possession, with the home team still trailing by three, Spencer Hawes - one of the leagues best passing big men - threw an interception, intended for Tyler Zeller and picked off by DeMar DeRozan. Marco Verratti Paris Saint-Germain Jersey (http://www.psgsoccershop.com/c-8-marco-verratti-paris-saint-germain-fc-jersey.aspx) . Curlings version of the Ryder Cup will introduce a new format beginning with the 2015 event, set for Jan. 8 to 11 in Calgary, as itll be Team Canada taking on Team Europe this season and in the 2017 event, while itll be Team Canada against Team World (including the U. http://www.psgsoccershop.com/c-7-marquinhos-paris-saint-germain-fc-jersey.aspx (http://www.psgsoccershop.com/c-7-marquinhos-paris-saint-germain-fc-jersey.aspx) . Off-Season Game Plan looks at what the Blue Jackets may do to build upon last seasons success to return to the playoffs again next year.BALTIMORE -- John Harbaugh listed all the good things the Baltimore Ravens did in their third preseason game. "Very pleased about most everything about the game," he said. "I like the way we played, I liked how we played." Then he stated the obvious. "I just didnt like the four returns for touchdowns," the coach concluded. Ted Ginn Jr. took a punt 74 yards for a touchdown, and the Carolina Panthers defence scored three times in a 34-27 victory over the reigning Super Bowl champions Thursday night. Drayton Florence ran an interception 71 yards into the end zone, Thomas Davis scored on a 2-yard fumble return and linebacker Luke Kuechly picked off another of Joe Flaccos passes late in the second quarter to set up a 54-yard field goal by Graham Gano for a 24-7 lead. "I was able to read the quarterback and make a play on it," Kuechl! y said. Carolina (2-1) had only 67 yards in offence before halftime, yet reeled off 24 straight points after Baltimore (2-1) scored on its first possession. Late in the third quarter, D.J. Moore intercepted a pass by Tyrod Taylor and ran 31 yards for a touchdown to make it 34-17. After collecting four turnovers against the Ravens, the Panthers have 10 in three games. "Turnovers are great. Its paying off big-time," said Kuechly, the AP Defensive Rookie of the Year in 2012. "Weve had quite a few turnovers in each game and thats huge for us. Defensive coaches have done a good job of stressing it." Flacco, the Super Bowl MVP, played into the third quarter and went 18 for 24 for 169 yards and a touchdown. In three preseason games, he has two TD passes and three interceptions. Although he produced 10 points in the third quarter, Flacco was far from satisfied with the performance of the first-team offence. "We obviously turned the ball over, and you lose more games than you win in this league when you do that," he said. "With what we did tonight, were not going to win a lot of football games." The Ravens finished with 27 first downs compared to 14 for Carolina, outgained the Panthers 357-173 and had an 11 1/2-minute edge in time of possession. "Its one thing to always remember: When you score (three) touchdowns on defence and on special teams, the offence doesnt get back out there," Carolina coach Ron Rivera said. Hatem Ben Arfa Paris Saint-Germain Jersey (http://www.psgsoccershop.com/c-20-hatem-ben-arfa-paris-saint-germain-fc-jersey.aspx). "The opportunities are limited. Having said that, 3.7 yards an average offensive play is not good enough, not in this league." Theyll win plenty with a 4-0 edge in turnovers, though. "Tonight was one of those games that we did a lot of good things, but we had some miscommunication and turned the ball over too much," Flacco said. Panthers quarterback Cam Newton completed 10 of 19 passes for 99 yards. Carolina lost backup receiver Kealoha Pilares in the first quarter because of a knee! injury. He will have an MRI on Friday. "Theres a little concern, but well keep our fingers crossed," Rivera said. Guard Amini Silatolu left in the second quarter with a strained hamstring and running back Kenjon Barner rolled his ankle. Baltimores opening drive was a display of precision. Flacco went 5 for 5 for 45 yards, connecting with three receivers during a nine-play, 69-yard march that ended with a 1-yard touchdown run by Ray Rice. "We opened the game the way we want to play and know how we can play," Ravens offensive co-ordinator Jim Caldwell said at halftime. "We were crisp, we were fast and we were in rhythm." The next time, though, Flacco missed on three straight passes to set up a punt. Ginn eluded the first wave of tacklers, broke up the middle and held the ball aloft at around the 20 with punter Sam Koch in futile pursuit. That enabled the Panthers to get out of the first quarter in a tie at 7 despite making only one first down and 38 yards on nine plays. Early in the second quarter, Flacco was attempting to convert a third-and-10 when Florence intercepted the pass and took it down the right sideline for a touchdown. After the kickoff, Bernard Pierce fumbled when hit by Kuechly. Davis pounced on the ball and rolled into the end zone for a 21-7 lead. Three turnovers and poor punt coverage offset all the positives for the defending champions. "When you turn it over and give up a special teams touchdown, you get in a big hole," Harbaugh said. "We have to protect the ball better." Cheap NFL Jerseys (http://www.cheapjerseysstitchedshop.com/) Wholesale Jerseys (http://www.wholesalejerseyssafestore.com/) Wholesale NFL Jerseys (http://www.wholesalechinastitchedjerseys.com/) Jerseys From China (http://www.wholesalenflcheapjerseyschina.us.com/) Wholesale NFL Jerseys (http://www.chinanflonlinejerseys.com/) Cheap NFL Jerseys (http://www.cheapsoccerjerseyschinaonline.com/) Cheap Jerseys (http://www.cheapnbajerseyschinastore.com/) ' ' ' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464808#464808 ________________________________________________________________________________
Subject: nutes.Pliskova added the Korea win to her first WTA
tittle s
From: "blueberryjerry" <blueberryjerry0822(at)hotmail.com>
Date: Jan 06, 2017
Imagine a playoff that includes Arizona facing TCU in one semifinal and Mississippi State meeting Georgia Tech in the other. Cheap Los Angeles Rams Jerseys (http://www.wholesalechinastitchedjerseys.com/Nike-NFL-Jerseys-ak-11_Los-Angeles-Rams-Jersey-ua-12/) . Is it a long shot? Sure. But its not quite as far-fetched as it may have seemed before this season of surprises began. No. 3 Mississippi State, No. 9 TCU, No. 10 Arizona and No. 22 Georgia Tech are all unbeaten after starting the season unranked. The list of undefeated teams that opened the season outside the Top 25 also includes Marshall, which remains unranked despite winning its first five games by an average margin of 31.8 points. Its way too early, but I thought before the season when everybody started lining teams up for the four-team playoff, I said, you know, theres so much that can happen in the regular season in college football, Arizona coach Rich Rodriguez said. All the polls are nice for the fans, but theyre going to be presumptuous. Lets wait and see what happens because I think the Power 5 conferences have so much more parity than theyve ever had that theres so much more thats still going to happen over these next six or seven weeks. Heres a look at these five unbeaten teams that started the season unranked. -- ARIZONA (5-0, 2-0 Pac-12) How they got here: Arizona is 5-0 for the first time since 1998 with a young offensive backfield featuring redshirt freshman quarterback Anu Solomon and true freshman running back Nick Wilson. Linebacker Scooby Wright leads a defence that has eight sacks over its last two games. In its last two games, Arizona edged California 49-45 on a Hail Mary and pulled off a 31-24 stunner at No. 12 Oregon, which was ranked second at the time. Potential roadblocks: Arizona has a tough home test with Southern California on Saturday and has three more games with ranked teams: Nov. 1 at No. 18 UCLA, Nov. 22 at No. 24 Utah and Nov. 28 at home against No. 20 Arizona State. If the Wildcats stay unbeaten through the regula! r season , theyd still have to survive the Pac-12 championship game. -- GEORGIA TECH (5-0, 2-0 ACC) How they got here: The Yellow Jackets have found an ideal quarterback for Paul Johnsons triple-option attack in Justin Thomas, who has rushed for 470 yards while also throwing seven touchdown passes with only one interception. Georgia Tech beat Georgia Southern 42-38 on a touchdown with 23 seconds left and erased a 10-point deficit in a 27-24 triumph over Virginia Tech. Id say theyre resilient, Johnson said. Nothing much seems to affect them. We get behind and nothing changes. They dont panic. Potential roadblocks: Georgia Tech hosts defending ACC Coastal Division champion Duke on Saturday and closes the regular season with a Nov. 15 home game against Clemson and a Nov. 29 trip to No. 13 Georgia. The Yellow Jackets avoid No. 1 Florida State in the regular season but could face the Seminoles in the ACC championship game if both get that far. -- MARSHALL (5-0, 1-0 Conference USA) How they got here: Marshalls the one team on the list that isnt really a surprise. Before the season, Marshall was touted as a team that could go unbeaten thanks to star quarterback Rakeem Cato and a tissue-soft schedule. Cato directs an offence that leads all FBS teams with 595.6 yards per game. Cato has done a tremendous job, Marshall coach Doc Holliday said. He is extremely unselfish and could care less about his stats. What he cares about is winning the football game. Potential roadblocks: Marshall has a potentially tricky home game Saturday with Middle Tennessee, which beat the Thundering Herd 51-49 last season. The only other remaining opponent that currently owns a winning record is UAB, which hosts the Herd on Nov. 22. Marshall also could end up in the Conference USA championship game. -- MISSISSIPPI STATE (5-0, 2-0 SEC) How they got here: Quarterback Dak Prescott has emerged as a Heisman Trophy candidate while leading Mississippi State to its highest ranking ever. The Bulldogs have gained at least 500 yards in each of their games th! is seaso n, though their brutal schedule gives them little time to celebrate. The difference between a pat on the back and a kick in the rear end is about six inches, Mississippi State coach Dan Mullen said. We have to make sure we keep in the high-end of those six inches right there because if not, it will turn to the second. Potential roadblocks: Mississippi State hosts No. 2 Auburn on Saturday. The Bulldogs also have two upcoming road games against Top 25 teams: Nov. 15 at No. 7 Alabama and Nov. 29 at No. 3 Ole Miss. If the Bulldogs get through that grind unscathed, theyd still need to play the SEC championship game. -- TCU (4-0, 1-0 Big 12) How they got here: The Horned Frogs already have matched their win total from last season, when they finished 4-8. TCUs offence is averaging 516.2 yards per game, 171.4 more than last season. That represents the best statistical improvement of any FBS offence this season. We are good enough to win the Big 12, TCU linebacker Paul Dawson said after a 37-33 victory over No. 11 Oklahoma, which was ranked fourth at the time. Potential roadblocks: TCU visits No. 5 Baylor on Saturday and hosts No. 16 Oklahoma State on Oct. 18 and No. 17 Kansas State on Nov. 8. Cheap Chicago Blackhawks Jerseys (http://www.wholesalechinastitchedjerseys.com/NHL-Jerseys-lw-50_Chicago-Blackhawks-Jersey-kp-60/) . They have watched it from afar. And now they have seen it for themselves. Wholesale China Jerseys (http://www.wholesalechinastitchedjerseys.com/) .The Hamilton Tiger-Cat defensive back always has the required receipt. But he also walks around with a tangle of metal screws, rods and plates after breaking his neck in 2006 playing high school football in Louisiana. http://www.wholesalechinastitchedjerseys.com/MLB-Jerseys-oy-15_San-Diego-Padres-Jersey-nu-41/ (http://www.wholesalechinastitchedjerseys.com/MLB-Jerseys-oy-15_San-Diego-Padres-Jersey-nu-41/) . Scheffler told The Associated Press on Wednesday he made the choice because he had three concussions over the past four years.SEOUL, South Korea ! - Second -seeded Karolina Pliskova of the Czech Republic defeated fifth-seeded Varvara Lepchenko of the United States, 6-3, 6-7 (5), 6-2 on Sunday to win the Korea Open.Pliskova stormed out to a 4-0 lead in the third set at Olympic Park Tennis Center and held on for the second WTA title of her career in a match that lasted 2 hours, 11 minutes.Pliskova added the Korea win to her first WTA tittle she won in Kuala Lumpur last year. Cheap Nike NFL Jerseys (http://www.wholesalechinastitchedjerseys.com/Nike-NFL-Jerseys-ak-11/). She was playing in her fourth WTA final this year. She lost the first three in Pattaya City, Nurnberg and Hong Kong.Lepchenko beat top-seeded Agnieszka Radwanska in the quarterfinals but couldnt build on the momentum in Sundays final.The doubles final saw Lara Arruabarrena and Irina-Camelia Begu beat Mona Barthel and Mandy Minella, 6-3, 6-3. Cheap NFL Jerseys (http://www.cheapjerseysstitchedshop.com/) Wholesale Jerseys (http://www.wholesalejerseyssafestore.com/) Wholesale NFL Jerseys (http://www.wholesalechinastitchedjerseys.com/) Jerseys From China (http://www.wholesalenflcheapjerseyschina.us.com/) Wholesale NFL Jerseys (http://www.chinanflonlinejerseys.com/) Cheap NFL Jerseys (http://www.cheapsoccerjerseyschinaonline.com/) Cheap Jerseys (http://www.cheapnbajerseyschinastore.com/) ' ' ' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464809#464809 ________________________________________________________________________________
Subject: ave agreed to a four-year deal with free agent fullback
Erik
Date: Jan 06, 2017
ST. Cheap Jerseys From China (http://www.cheapjerseysstitchedshop.com/) . PETERSBURG, Fla. -- Jake Odorizzi won his third consecutive start, James Loney had two RBIs and the Tampa Bay Rays beat the Milwaukee Brewers 2-1 on Monday night. Odorizzi (7-8) allowed one run and three hits in seven innings to beat the team that took him 32nd overall in the 2008 draft. Tampa Bay took a 2-1 lead in the sixth when Loney drove in two with a two-out, bases-loaded single off Kyle Lohse (11-5), who gave up two runs and four hits over six innings. The Rays had won nine in a row before a 3-2 loss Sunday to Boston. The winning streak was the second longest in team history. Mark Reynolds put the Brewers ahead 1-0 with his 18th homer of the season in the third. After Brad Boxberger struck out the side in the eighth, Jake McGee got the three outs for his 12th save in 13 chances. Lohse benefited from a key defensive play in the fifth when Reynolds, the first baseman, ran down Logan Forsythes bloop hit that went into foul territory. Reynolds threw the ball to shortstop Jean Segura, who then made a relay throw to get Forsythe at third. Lohse was coming off a pair of victories in which he had allowed two runs in 13 2-3 innings. The right-hander dropped to 5-4 in 12 games against the Rays. Tampa Bay right fielder Kevin Kiermaier made nice catches on balls by Khris Davis and Reynolds during the fifth. Ben Zobrist went 1 for 3 with a sixth-inning walk and has reached base in 11 of his last 16 plate appearances. This is just the third series between the teams and the first at Tampa Bay since June 2005. The Rays have won five of seven against the Brewers. TRAINERS ROOM Brewers: Second baseman Scooter Gennett was back in the starting lineup for the first time since hurting his right quadriceps last Tuesday. Rays: Catcher Ryan Hanigan, out with a strained left oblique, could return this weekend. ON DECK Brewers: Right-hander Matt Garza (7-7), the 2008 ALCS MVP with the Rays, will start Tuesday nights game. "Hes not afraid, man," Rays m! anager J oe Maddon said. Rays: Right-hander Alex Cobb (6-6) will oppose Garza. NFL Jerseys China (http://www.cheapjerseysstitchedshop.com/) . -- The Detroit Lions made it crystal clear to Golden Tate that he was their top target in free agency. Cheap Jerseys Stitched (http://www.cheapjerseysstitchedshop.com/) . Sizemore, who turned 29 on Jan. 4, has been limited to six games over the past two seasons because of an injured left knee that twice required surgery. He originally got hurt on Feb. 25, 2012, during a fielding drill in Oaklands first full-squad spring training workout and had surgery that March 21 to repair a torn anterior cruciate ligament. http://www.cheapjerseysstitchedshop.com/ (http://www.cheapjerseysstitchedshop.com/) . - The New Orleans Saints have re-signed receiver Joseph Morgan for one year and have agreed to a four-year deal with free agent fullback Erik Lorig.DETROIT -- Pittsburgh Penguins defenceman Deryk Engelland has been ejected from a game against the Detroit Red Wings because of an illegal hit to the head. Engelland landed his right shoulder high on Detroit forward Justin Abdelkader late in the first period Saturday night. After Abdelkader struggled to get up and had to be helped off the ice, Engelland was called for a match penalty. Bostonn Bruins forward Shawn Thornton was suspended earlier in the day for 15 games by the NHL for punching and injuring Pittsburgh defenceman Brooks Orpik. Cheap Authentic Jerseys (http://www.cheapjerseysstitchedshop.com/). Thornton went after Orpik during a stoppage in play Dec. 7, knocking him down to the ice and punching him twice. Orpik sustained a concussion and was taken off the ice on a stretcher and hasnt played since that game. Cheap NFL Jerseys (http://www.cheapjerseysstitchedshop.com/) Wholesale Jerseys (http://www.wholesalejerseyssafestore.com/) Wholesale NFL Jerseys (http://www.wholesalechinastitchedjerseys.com/) Jerseys From China (http://www.wholesalenflcheapjerseyschina.us.com/) Wholesale NFL Jerseys (http://www.chinanflonlinejerseys.com/) C! heap NFL Jerseys (http://www.cheapsoccerjerseyschinaonline.com/) Cheap Jerseys (http://www.cheapnbajerseyschinastore.com/) ' ' ' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464810#464810 ________________________________________________________________________________
Subject: ove to within one leg of victory. Lewis ended Michael
van Ge
Date: Jan 06, 2017
Draw Sheet Date ET A B C D E Nov 10 9:30am MB 4 vs NT 6 NB 9 vs BC 1 NO 7 vs NL 4 ON 9 vs NU 1 Nov 10 3:00pm SK 9 vs NU 2 NT 3 vs AB 4 YT 10 vs NB 1 PE 3 vs NS 6 QC 3 vs BC 8 Nov 10 7:30pm AB 8 vs YT 4 NO 3 vs NS 7 MB 5 vs QC 8 NL 4 vs SK 6 PE 5 vs ON 8 Nov 11 9:30am NU 2 vs PE 9 SK 7 vs NS 4 BC 8 vs AB 4 NB 2 vs NT 4 Nov 11 2:00pm NS 4 vs ON 6 YT 5 vs QC 9 NL 3 vs PE 9 SK 4 vs NO 3 AB 5 vs MB 8 Nov 11 6:30pm YT 9 vs BC 6 NL 1 vs ON 9 NB 3 vs MB 6 NT 6 vs QC 3 NU 1 vs NO 9 Nov 12 9:30am PE 7 vs SK 6 QC 7 vs AB 3 MB 10 vs YT 3 NS 5 vs NL 3 Nov 12 2:00pm QC 6 vs NB 3 BC 3 vs MB 7 ON 6 vs NO 5 NU 5 vs NL 9 NT 10 vs YT 4 Nov 12 6:30pm NO 8 vs PE 5 NS 8 vs NU 3 BC 9 vs NT 7 AB 5 vs NB 4 ON 6 vs SK 5 Nov 13 9:30am QC 3 vs SK 8 PE 3 vs NB 6 MB 6 vs NS 3 Nov 13 2:00pm NT 8 vs ON 7 NL 2 vs AB 5 YT 13 vs NU 2 BC 3 vs NO 7 Nov 13 6:30pm MB 3 vs NO 5 BC 6 vs NS 4 QC 1 vs ON 11 AB 7 vs PE 6 NT 3 vs SK 6 Nov 14 9:30am AB 6 vs NU 3 PE 3 vs YT 8 NB 8 vs NL 2 Nov 14 2:00pm BC 4 vs SK 6 NU 3 vs NB 9 NT 6 vs NS 4 QC 2 vs NO 7 MB 4 vs ON 6 Nov 14 6:30pm QC 7 vs NS 6 NT 6 vs NO 2 MB 5 vs SK 8 BC 8 vs ON 3 YT 7 vs NL 2 Nov 15 9:30am SK 7 vs BC 4 ON 3 vs NT 7 Nov 15 2:30pm FINAL SK 7 vs NT 4 BRONZE BC 2 vs ON 9 Julian Draxler Jersey (http://www.germanyfcsoccershop.com/c-28-julian-draxler-germany-jersey.aspx) . Cornet won six straight games to rally from a 2-0 deficit and take the first set. The 25th-ranked Frenchwoman broke back twice in the second set before Bacsinszky saved a match point at 5-4. Marco Reus Germany Jersey (http://www.germanyfcsoccershop.com/c-13-marco-reus-germany-jersey.aspx) .com) - Former FBI director Robert Mueller said his investigation found no evidence that the NFL saw the elevator video of Ray Rice striking his then-fiancee before the tape was released in September. http://www.germanyfcsoccershop.com/c-3-manuel-neuer-germany-jersey.aspx (http://www.germanyfcsoccershop.com/c-3-manuel-neuer-germany-jersey.aspx) . The injury will keep the Finnish forward out of the Olympics. The 29-year-old has 20 goals ! and 41 p oints in 56 games this season, his first with Tampa Bay.Peter Wright came from behind to defeat Adrian Lewis 6-5 in the final of the Players Championship One on Saturday. Mario Gotze Jersey (http://www.germanyfcsoccershop.com/c-21-mario-gotze-germany-jersey.aspx) . Wright, the current world number five, came from 5-3 down against Lewis to claim his first title of 2016.The 46 year-old Scotsman bounced back from last weeks disappointing loss in the final of the UK Open to claim the 10,000 first prize on offer in Barnsley. Wright, otherwise known as Snakebite, recorded notable victories over Ian White and Joe Cullen in the competitions earlier rounds, whilst Lewis run to the final included impressive wins against the top two players in the world - Michael van Gerwen and Gary Anderson.After sharing the opening four legs, Lewis took out 91 and a brace of 14-dart finishes to open up a 5-3 lead and move to within one leg of victory. Lewis ended Michael van Gerwens run of 27 straight victories in the competitions quarter-finals However, Wright hit back to take leg nine and went on to land two 180s in a 12-darter to level the game at five all. Matthias Ginter Jersey (http://www.germanyfcsoccershop.com/c-8-matthias-ginter-germany-jersey.aspx). . The Scot then held his nerve to take out 81 for a 12-dart winning leg in the decider. Both players are set to return for the Players Championship Two which will also be held at the Barnsley Metrodome this Sunday. Also See: Sky Bets darts odds On Sky TV Schedule/Results Features Get Sky Sports Cheap NFL Jerseys (http://www.cheapjerseysstitchedshop.com/) Wholesale Jerseys (http://www.wholesalejerseyssafestore.com/) Wholesale NFL Jerseys (http://www.wholesalechinastitchedjerseys.com/) Jerseys From China (http://www.wholesalenflcheapjerseyschina.us.com/) Wholesale NFL Jerseys (http://www.chinanflonlinejerseys.com/) Cheap NFL Jerseys (http://www.cheapsoccerjerseyschinaonline.com/) Cheap Jerseys (http://www.cheapnbajerseyschinastore.com/) ' ' ' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464811#464811 ________________________________________________________________________________
Subject: t a fumble and threw an interception. Vincent Jackson
also l
Date: Jan 06, 2017
PHOENIX - Missy Elliott is going to Work It at the Super Bowl with Katy Perry. Davide Calabria Jersey (http://www.acmilansoccershop.com/c-22-davide-calabria-ac-milan-fc-jersey.aspx) .A person familiar with the plans for Sundays halftime show told The Associated Press on Thursday that Grammy winner Elliott is slated to make a surprise appearance during Perrys performance.The person spoke to the AP on condition of anonymity because Elliotts participation had not been announced by the NFL.Elliott was featured on a remix of Perrys song Last Friday Night (T.G.I.F.) in 2011.During a news conference Thursday, Perry hinted at Elliotts involvement in the Super Bowl act, which also will feature Lenny Kravitz.Perry said the halftime show will include an old school female singer but did not say who that would be.When you hear the first ring of the chord, Perry promised, I think jaws will drop and faces will melt.Elliott is a multiplatinum rapper, singer and producer whose Grammy Awards from the early 2000s include Best Rap Solo Performance for Get Ur Freak On, and Best Female Rap Solo Performance for Work It and Scream a.k.a. Itchin.Other Super Bowl halftime shows have included unannounced performances, including by singer Usher and former Guns N Roses guitarist Slash in 2011.___Follow Howard Fendrich on Twitter at http://twitter.com/HowardFendrich___Online:AP NFL website: www.pro32.ap.org and AP NFL Twitter feed: http://twitter.com/AP_NFL Ignazio Abate Jersey (http://www.acmilansoccershop.com/c-15-ignazio-abate-ac-milan-fc-jersey.aspx) . Mike Vecchione tied it at 2 with 4:01 left in the first, Saskatoon native Eli Lichtenwald gave the Dutchman the lead 57 seconds later, and Daniel Ciampini capped the spree with 2:57 to go. Manuel Locatelli Jersey (http://www.acmilansoccershop.com/c-20-manuel-locatelli-ac-milan-fc-jersey.aspx) .com) - Graeme McDowell opened up with a first- round, 5-under 67 on Thursday and he holds a 2-shot lead at the WGC - HSBC Champions. http://www.acmilansoccershop.com/c-16-gabriel-paletta-! ac-milan -fc-jersey.aspx (http://www.acmilansoccershop.com/c-16-gabriel-paletta-ac-milan-fc-jersey.aspx) . The stress, the waiting, the whispers about whether he doped during his stellar cycling career, all of it ended when - after nearly two years - federal prosecutors closed an investigation of him last week without bringing any charges.ATLANTA - Brian Hoyer shook off three interceptions, leading the Cleveland Browns down the field in the final minute to set up Billy Cundiffs 37-yard field goal as time expired for a 26-24 victory over the Atlanta Falcons on Sunday.Taking advantage of the last of Hoyers picks, the Falcons drove for Matt Bryants 53-yard field goal with 44 seconds remaining to seize the lead.But Hoyer completed four straight passes, the last of them to the Falcons 19, and spiked the ball with 5 seconds left. Cundiff trotted on and made his fourth field goal of the game for the Browns (7-4).Atlanta (4-7), coming in improbably tied for first in the woeful NFC South, dropped to 0-7 against teams outside the division.Isaiah Crowell scored a pair of touchdowns for the Browns, who also were bolstered by the return of Josh Gordon. He had eight catches for 120 yards.PATRIOTS 34, LIONS 9FOXBOROUGH, Mass. (AP) Tom Brady threw for 349 yards and two touchdowns in a pass-heavy offence against the NFLs stingiest rushing defence and the New England Patriots stretched their winning streak to seven games with a victory over the Detroit Lions.The Patriots led 24-6 at halftime as Brady repeatedly found wide-open receivers while the Lions struggled on offence. For the second straight game, Detroit failed to score a touchdown.New England (9-2) routed a division leader for the third consecutive game, following wins over Denver and Indianapolis. Detroit (7-4) lost for the second straight week against a conference leader after falling to Arizona 14-6 last Sunday.LeGarrette Blount rushed for 78 yards and two touchdowns three days after signing with New England after being cut by Pittsburgh. In the win over the Colts, ! the Patr iots stuck with the running game as Jonas Gray rushed 37 times for 201 yards and four touchdowns. After being sent home from Fridays practice for reporting late, he didnt play at all on Sunday.PACKERS 24, VIKINGS 21MINNEAPOLIS (AP) Eddie Lacy rushed for 125 yards on 25 carries, both season highs to help Aaron Rodgers and the Green Bay Packers hang on against the Minnesota Vikings.Lacy scored twice, on a run in the first quarter and a catch in the fourth. Then, he rumbled through the line for two first downs to drain the clock after the Vikings (4-7) cut the lead to three with 3:23 remaining.Rodgers threw two touchdown passes and again avoided a turnover for the Packers (8-3), who stayed out of a potential trap against a struggling team with a game next week against surging New England. They also moved past Detroit into sole possession of first place in the NFC North when the Lions lost to the Patriots.Charles Johnson and Greg Jennings caught touchdown passes from Teddy Bridgewater, who finished 21 for 37 for 210 yards and an interception.EAGLES 43, TITANS 24PHILADELPHIA (AP) Josh Huff returned the opening kickoff 107 yards, LeSean McCoy ran for 130 yards and the Philadelphia Eagles beat the Tennessee Titans.Huffs return was the longest in franchise history and the 10th non-offensive touchdown for Philadelphia this season.Mark Sanchez threw for 307 yards and one touchdown in his third start for the iinjured Nick Foles. Juraj Kucka Jersey (http://www.acmilansoccershop.com/c-30-juraj-kucka-ac-milan-fc-jersey.aspx). He has 300 yards passing in three straight games, tying a team record.Now, the Eagles (8-3) can shift their focus to the Dallas Cowboys (7-3) for a first-place showdown on Thanksgiving. The top two teams in the NFC East will play twice in 18 days, starting with Thursdays game at Dallas.Rookie Zach Mettenberger had 345 yards passing and two TDs and Delanie Walker had 155 yards receiving for the Titans (2-9).BENGALS 22, TEXANS 13HOUSTON (AP) Andy Dalton threw for 233 yards and a touchdo! wn and A .J. Green had 121 yards receiving on a career-high 12 receptions to give the Cincinnati Bengals a win over the Houston Texans.The Bengals (7-3-1) led throughout, but Houston (5-6) cut the lead to three points late in the third quarter before Cincinnati tacked on two field goals in the fourth quarter to secure the win.Rookie Jeremy Hill scored on a 2-yard touchdown run early in the third quarter after an interception by Ryan Mallett for Cincinnatis only touchdown of the second half.Mallett struggled in his second career start, finishing with 189 yards passing and often overthrowing open receivers. Houstons only touchdown came on a 60-yard interception return by Johnathan Joseph in the third quarter.Rookie Alfred Blue ran for 46 yards filling in for the injured Arian Foster for the second straight game.COLTS 23, JAGUARS 3INDIANAPOLIS (AP) T.Y. Hilton celebrated the birth of his first child with a 73-yard TD catch, spurring a second-half turnaround that allowed Indianapolis to pull away from Jacksonville.Andrew Luck was 21 of 32 for 253 yards with one score, but his streak of consecutive 300-yard games ended at eight one short of Drew Brees NFL record.The Colts (7-4) have won 11 straight against AFC South foes. Jacksonville (1-10) has lost four straight overall and five straight to Indy.Hilton promised to score a touchdown for his new daughter, but it sure wasnt easy. Luck was sacked five times, fumbled three times and lost two of those in the first half.But Indy still led 6-3 at the half and 13-3 after Trent Richardsons 1-yard TD run in the third quarter. Hiltons long catch made it 20-3. Adam Vinatieris third field goal capped the scoring.BEARS 21, BUCCANEERS 13CHICAGO (AP) Matt Forte rushed for two touchdowns in the third quarter, and the Chicago Bears beat Lovie Smith and the Tampa Bay Buccaneers.Jay Cutler threw a 2-yard TD pass to Alshon Jeffery as the Bears (5-6) scored 21 straight points to erase a 10-0 halftime deficit. Forte had a 13-yard run that put Chicago ahead to stay, and then add! ed a 1-y ard plunge that made it 21-10.Smith coached the Bears to three playoff appearances and a trip to the 2007 Super Bowl during his successful nine-year run in Chicago. He was hired by Tampa Bay (2-9) in January.Tampa Bay had three turnovers in the third. Josh McCown, who played for the Bears the previous three seasons, lost a fumble and threw an interception. Vincent Jackson also lost a fumble at the end of a 24-yard reception that would have resulted in a first-and-goal.___AP NFL websites: http://www.pro32.ap.org and http://www.twitter.com/AP_NFL Cheap NFL Jerseys (http://www.cheapjerseysstitchedshop.com/) Wholesale Jerseys (http://www.wholesalejerseyssafestore.com/) Wholesale NFL Jerseys (http://www.wholesalechinastitchedjerseys.com/) Jerseys From China (http://www.wholesalenflcheapjerseyschina.us.com/) Wholesale NFL Jerseys (http://www.chinanflonlinejerseys.com/) Cheap NFL Jerseys (http://www.cheapsoccerjerseyschinaonline.com/) Cheap Jerseys (http://www.cheapnbajerseyschinastore.com/) ' ' ' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464812#464812 ________________________________________________________________________________
Subject: n Davies and slotted it into the bottom left corner
past a d
Date: Jan 06, 2017
BERLIN - Cristiano Ronaldo became the European Championships all-time top scorer by giving Portugal a 1-0 victory over Armenia, while Germany could only beat Gibraltar 4-0 as its World Cup victory hangover continued on Friday. http://www.chinajerseysnfl.net/ (http://www.chinajerseysnfl.net/) .Portugal captain Ronaldo broke the deadlock in the 72nd minute to take his tally across Euro finals and qualifying to 23 goals. Denmarks Jon Dahl Tomasson and Turkeys Hakan Sukur had previously scored 22 goals each.Germany was looking for a high score against Gibraltar, a territory of just 30,000 people which is playing its first qualifying tournament and had already lost 7-0 to both Ireland and Poland in Group D.However, there were whistles from some fans at full-time after watching the World Cup holders labour against a defensively set-up side made up mostly of amateurs.Convincing in Brazil during the summer, Germany had been held to a 1-1 draw by Ireland and beaten 2-0 by Poland in its two previous Euro 2016 qualifiers. It also lost 4-2 to Argentina in a friendly repeat of the World Cup final in September.Elsewhere, Greece slumped to a shock 1-0 defeat at home to the Faroe Islands and Denmark came from behind to beat Serbia 3-1. There were qualifying wins for Poland, Scotland, Romania and Hungary.In London, Teofilo Teo Gutierrez headed in a late goal as Colombia came from behind to beat the United States 2-1 in a friendly.Heres a roundup of action from Fridays Euro 2016 qualifying games:GROUP IRonaldos winner against Armenia meant Portugal stayed one point behind group leader Denmark. The Real Madrid star struck from close range following a goalmouth scramble.Nicklas Bendtner scored twice as Denmark came from a goal down to beat Serbia 3-1 in Belgrade. The match was played in an empty Partizan stadium because of incidents in a qualifier between Serbia and Albania last month. Serbia was penalized by UEFA for pitch skirmishes involving players and fans over an Albanian flag that was flown above the stadium by a dro! ne.Serbi a winger Zoran Tosic opened the scoring with a low strike from 12 yards (meters) in the fourth minute.But Bendtner equalized from close range in the 60th before centerback Simon Kjaer gave the visitors the lead two minutes later by heading in a free kick from Christian Eriksen. Bendtner made it 3-1 in the 85th.Serbia coach Dick Advocaat was quoted by UEFAs website: This is our first terrible match since I became the manager. If someone should be blamed then its me. And, yes, I will think about resigning.France, which has already qualified as the host of Euro 2016, drew 1-1 with Albania in Rennes.Albania defender Mergim Mavraj stunned the hosts with a header in the 40th. But France substitute Antoine Griezmann salvaged a draw by cutting inside to fire into the bottom corner in the 73rd.GROUP DThomas Mueller scored twice as Germany got its Euro 2016 qualifying campaign back on track with an unconvincing 4-0 win over Gibraltar.Mueller opened the scoring in the 12th minute and claimed his second 17 minutes later. Mario Goetze made it 3-0 in the 38th, before an own goal from Yogan Santos completed the scoring in the 67th.Germany coach Joachim Loew said beforehand he wanted a result to reflect his sides status as the World Cup winners and he started with a very attacking line-up and just three defenders.The home side dominated the game but found it hard to penetrate the visitors stubborn defending, especially in the second half.Liam Walker almost scored for Gibraltar with an audacious effort from the sideline just before the interval, only to be denied by a great save from Manuel Neuer.Germany remains three points behind Group D leader Poland, which won 4-0 in Georgia thanks to second half goals from Kamil Glik, Grzegorz Krychowiak, Sebastian Mila and Arkadiusz Milik.Shaun Maloneys 75th-minute strike was enough for Scotland to beat Ireland 1-0 in Glasgow, moving the Scots level on points with Ireland and Germany.GROUP FGreece continued its disastrous run in qualifying with a humiliating 1-0 defeat to the Faroe! Islands , while Northern Ireland surrendered its lead in Group F to Romania.The result in Greece is almost certain to prompt the dismissal of coach Claudio Ranieri, who hasnt won a game since taking over in the summer and has now lost three straight at home.Greek Football Association president Giorgos Sarris has called an emergency board meeting and said he took full responsibility for the most unfortunate selection of this coach. Sarris pledged to make changes so that the national team never again has such a shameful evening.The Faroe Islanders, winning only their third European qualifier in 19 years, celebrated after the four minutes of injury time were up. Several of them in tears as they were clapped by Greek fans at Karaiskaki Stadium in Piraeus.The remote archipelago of 50,000 inhabitants is ranked 187th among 208 nations in FIFA, while Greece is ranked 18th.Joan Edmundsson scored in the 61st minute, firing in a ball that fell favourably in front of Greece goalkeeper Orestis Karnezis.In Bucharest, Romania looked rejuvenated under coach Anghel Iordanescu, returning for his third spell at the national team, fighting hard to beat Northern Ireland 2-0. Paul Papp scored twice in six minutes in the second half, finally beating goalkeeper Roy Carroll who had been key to his countrys opening run of three wins.There was a late winner at Budapests Groupama Arena, where Hungarys Zoltan Gera scored in the 84th minute to beat Finland 1-0 and claim third place. www.chinajerseysnfl.net (http://www.chinajerseysnfl.net/) . -- Each time the Utah Jazz threatened Memphis lead, the Grizzlies responded with defensive stops. chinajerseysnfl (http://www.chinajerseysnfl.net/) . In the calls, Hernandez discussed the murder of Odin Lloyd, including his "belief about his criminal liability" and the "extent of his control over persons charged as accessories," according to the request filed Thursday in Fall River Superior Court. http://www.chinajerseysnfl.net/ (http://www.chinajerseysnfl.net/) . Perhaps as important, shes sending a mes! sage to 17-year-old gold medal favourite Sara Takanashi of Japan. Iraschko-Stolz relegated Takanashi, who has 10 World Cup victories this season, to second place in two of three training jumps Saturday.Manchester, England (SportsNetwork.com) - Wayne Rooney and Juan Mata netted first-half goals on Sunday as Manchester United rolled to a 3-0 victory over fierce rivals Liverpool at Old Trafford, handing the club its sixth consecutive win in league play. With only 30 miles separating the cities of Manchester and Liverpool, the clubs are heated foes and are the two most successful clubs in English football. But they came into Sunday?s tilt on opposite ends of the form book as United began the day in third place, while Liverpool started things in ninth position. The visitors had the better of the play for the opening few minutes as Raheem Sterling got in behind the United defense after 12 minutes, but his weak strike was easily handled by United goalkeeper David de Gea. Less than a minute later, however, the home side opened the scoring when Antonio Valencia got free down the right flank and cut it back to an on- rushing Rooney, who blasted it low into the right corner, leaving Liverpool goalkeeper Brad Jones with no chance for a save. The Red Devils then doubled their advantage five minutes before the break when a cross came into the area from the left wing and Robin van Persie got a flick on it and the ball came to Mata, who nodded it home at the back post for the 2-0 lead. But the goal was not without some controversy as Van Persie?s flicked pass appeared to leave Mata in an offside position as Red Devils went into the intermission with the two-goal lead. Looking for an offensive spark, Liverpoool manager Brendan Rodgers sent Mario Balotelli onto the pitch at the start of the second half and the Italy international created a bevy of quality scoring chances.dddddddddddd But each time, De Gea came up with an answer, finishing with an impressive eight saves on the day. United added a third goal in the 71st minute when! Mata st epped in front of a poor clearance on the edge of the penalty area and slid the ball to an open Van Persie, who snapped it home as the Liverpool back line raised arms in unison, pleading for an offside call which never came. The Red Devils rolled the rest of the way for their sixth straight win in league play to improve to 31 points, while Liverpool drops into tenth place in the Premier League on 21 points from 16 matches. Also in the Premier League on Sunday, Christian Eriksens 89th-minute strike propelled Tottenham-Hotspur to a 2-1 win ovwe Swansea City at the Liberty Stadium. Spurs got off to a flying start, taking the lead thanks to a brilliant header from Harry Kane after just four minutes. Swansea drew level three minutes into the second half with an excellent strike from Wilfried Bony, but Spurs grabbed the winning goal right at the death as Eriksen collected a well-placed pass from Ben Davies and slotted it into the bottom left corner past a diving Gerhard Tremmel. The result lifts Spurs into seventh place in the Premier League with 24 points, just four behind West Ham United for the final Champions League place, while the Swans drop to ninth place on 22 points. Cheap NFL Jerseys (http://www.cheapjerseysstitchedshop.com/) Wholesale Jerseys (http://www.wholesalejerseyssafestore.com/) Wholesale NFL Jerseys (http://www.wholesalechinastitchedjerseys.com/) Jerseys From China (http://www.wholesalenflcheapjerseyschina.us.com/) Wholesale NFL Jerseys (http://www.chinanflonlinejerseys.com/) Cheap NFL Jerseys (http://www.cheapsoccerjerseyschinaonline.com/) Cheap Jerseys (http://www.cheapnbajerseyschinastore.com/) ' ' ' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464813#464813 ________________________________________________________________________________
Subject: BOSTON -- The suddenly high-scoring Boston Bruins are
showi
Date: Jan 06, 2017
BOSTON -- The suddenly high-scoring Boston Bruins are showing no mercy, even for the departed goalie who led them to the Stanley Cup. Gonzalo Higuain Jersey (http://www.argentinasoccerauthentic.com/Gonzalo-Higuain-Copa-America-Jersey/) . Milan Lucic scored twice and the Bruins spoiled Tim Thomas first game in Boston as a visitor with a 6-2 win over the Florida Panthers on Tuesday night. "I think I mightve enjoyed myself watching the State of the Union more," said Thomas, not a big fan of President Barack Obama, who delivered the speech at the same time as the Bruins were beating the Panthers for the sixth straight time. "No, probably not." In 2011, Thomas didnt accompany his teammates to the White House for the ceremony with Obama marking their championship that year. Boston scored six goals for the third straight game, following road wins of 6-1 and 6-3. The Atlantic Division leaders improved to 5-0-1 in their last six games. Why all that scoring for a team known for its defence? "Weve been able to get out of our zone cleanly and establish the rush," Lucic said. They kept going to the very end, with Carl Soderberg charging into the crease where an angry Thomas swung his stick, hitting Soderberg in the helmet with 4 seconds left. "With less than a minute left in the game and theyre up by four goals," Thomas said, "I took exception to that." Soderberg proclaimed his innocence. "I was just going for the rebound," he said. "We cant stop playing." Even if the opposing goalie was Thomas, who won the Conn Smythe Trophy as playoff MVP with the Bruins in 2011. He spent one more season with them, took last season off and then joined the Panthers. "Tims always going to be a part of this organization for what hes done," Boston coach Claude Julien said, "but we just have to look at him as the opposing goalie." Zdeno Chara, Reilly Smith, Shawn Thornton and David Krejci also scored for Boston, which led 4-0 until Brad Boyes connected for Florida with 2:33 left in the second period. Dmitry Kulikov added a power-play go! al for t he Panthers 4 minutes into the third. "All four lines are putting the puck in the net," Krejci said. "Thats good to see." Fans applauded lightly when Thomas was introduced as the starting goalie. But after Thornton made it 5-2 just more than 8 minutes into the third period, they derisively chanted, "Thomas! Thomas!" "I didnt really hear it too much," Thomas said. "There were really not a lot of feelings." Thomas played against the Bruins for the first time on Oct. 17 in Bostons 3-2 win at Florida. He travelled with the Panthers to Boston but did not play Nov. 7 in the Bruins 4-1 victory. For the second consecutive game, the Bruins were the early aggressors, outshooting the Panthers 19-8 in the first period. On Monday night, Boston took 18 of the first 20 shots in a 6-3 win over the New York Islanders. Lucic gave the Bruins a 1-0 lead at 7:41 of the first period on a rebound after Thomas stopped Jarome Iginlas shot from the right circle. Lucic was initially credited with the second goal less than 8 minutes later when Charas 45-foot shot from the right appeared to hit him before bouncing over Thomas and trickling into the net. The scoring was changed when it was determined that the puck hit Thomas glove, not Lucic. But that didnt stop a few spectators from throwing hats on the ice early in the second, thinking Lucic had completed a hat trick when he scored his 15th of the season on a short backhand. Smith made it 4-0 with his team-leading 18th goal at 14:54 of the second on a pass across the slot from Soderberg. He beat Thomas to the open side of the net. "That wasnt (Thomas) best game," Panthers coach Peter Horachek said, "but I dont think there were a lot of solid efforts by many of the players." After Boyes ruined Tuukka Rasks bid for his fourth shutout in 13 decisions, Kulikov made it 4-2. His goal ended an 0-for-43 power-play drought for the Panthers over their previous 13 games and the first two periods Tuesday. Rask finished with 28 saves. NOTES: Sean Bergenheims assist on Kulikovs goal was his 150t! h NHL po int. It came in his 100th game with the Panthers. ... Bruins forward Chris Kelly played for the first time since missing 22 games with a broken leg. ... Boston is 12-2 in its last 14 home games. Lionel Messi Argentina Jersey (http://www.argentinasoccerauthentic.com/Lionel-Messi-Copa-America-Jersey/) . His Brazilian opponents said he produced miracles. There is no doubt that Mexico goalkeeper Guillermo Ochoa was the one responsible for spoiling Brazils hopes of another World Cup victory at its home tournament. Mariano Andujar Jersey (http://www.argentinasoccerauthentic.com/Mariano-Andujar-Copa-America-Jersey/) . Brassard and Coyotes defenceman Derek Morris were battling for position in the crease when a nudge from Morris sent Brassard on top of Smith late in the third period. http://www.argentinasoccerauthentic.com/Lionel-Messi-Copa-America-Jersey/ (http://www.argentinasoccerauthentic.com/Lionel-Messi-Copa-America-Jersey/) . Teams one through twenty competing in Englands top flight are each fatally flawed. A wide-open, highly competitive and mistake-filled season has followed.The Toronto Maple Leafs signed restricted free agent defenceman Jake Gardiner to a five-year contract on Tuesday. The deal is worth $20.25 million with an average annual value of $4.05 million per season. The 24-year-old defenceman scored 10 goals and 11 assists in 80 games with the Maple Leafs in 2013-14. He is coming off the final year of a three-year entry-level deal he signed prior to the 2011-12 season worth an average annual value of $1.117 million including performance bonuses. Gardiner wwas drafted in the first round (17th overall) of the 2008 NHL Draft by the Anaheim Ducks. Enzo Perez Jersey (http://www.argentinasoccerauthentic.com/Enzo-Perez-Copa-America-Jersey/). . He was acquired by the Leafs, along with Joffrey Lupul, in exchange for Francois Beauchemin. In 167 career games, Gardiner has scored 17 goals and added 48 assists. He won a gold medal as a member of the American team at the 2010 World Junior Hockey Championsh! ip and w as also named a member of the NHLs All-Rookie Team in 2011-12. Gardiner: New deal, working with Carlyle Cheap NFL Jerseys (http://www.cheapjerseysstitchedshop.com/) Wholesale Jerseys (http://www.wholesalejerseyssafestore.com/) Wholesale NFL Jerseys (http://www.wholesalechinastitchedjerseys.com/) Jerseys From China (http://www.wholesalenflcheapjerseyschina.us.com/) Wholesale NFL Jerseys (http://www.chinanflonlinejerseys.com/) Cheap NFL Jerseys (http://www.cheapsoccerjerseyschinaonline.com/) Cheap Jerseys (http://www.cheapnbajerseyschinastore.com/) ' ' ' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464814#464814 ________________________________________________________________________________
Subject: At this point, it doesnt sound like Luke Richardson
has any
Date: Jan 06, 2017
At this point, it doesnt sound like Luke Richardson has any interest in becoming an assistant coach in the NHL. There have been several Ottawa fans wondering if Richardson - currently the head coach of the clubs AHL affiliate in Binghamton - would be able to help the Senators with their defensive issues as an assistant coach down the road. But speaking to him on TSN 1200 Tuesday, it sounds like the 44-year-old is waiting for the right opportunity to become a head coach in the NHL. Richardson had spent three years as an assistant in Ottawa, but in the spring of 2012 he had a conversation with general manager Bryan Murray about his coaching future. So when the Binghamton job opened up after Kurt Kleinendorst stepped aside, he knew that was the career path he wanted to pursue. "It was great getting the experience those first few years kind of being the part-time guy, the upstairs guy and the practice guy with the Senators. But when I had that chance to become a head coach I told Bryan, Thats what I want to be. I want to be a head coach. Its not that I think Im better than anyone else or better than an assistant coachs job, I just feel more comfortable in that role and I like it," Richardson said on Tuesday. Richardson says he currently has no aspirations to leave his post in Binghamton, where he has guided the club to a first-place position in the AHLs East Division. "Im really happy to be here. And I take a lot of pride trying to help these young players in the organization. So my answer is that Im happy to be here and Im signed for another year," added Richardson. Of course, things could change if an NHL head coaching job opened up in the summer. A couple of teams - like Buffalo and Florida - are currently working with interim head coaches and have made no guarantees about who will be behind their bench next season. Add in the usual number of post-season coaching changes and there could be several opportunities for Richardson to consider in the summer. But he was quick to point out the Binghamton job off! ers him the unique luxury of being close to his daughter who is wrapping up her sophomore year at university down the road in Ithica, New York. "It really works well for my family with our daughter Morgan an hour away at Cornell and we get to see her a lot. Its very unusual to be able to do that in the geography of the hockey world. We are fortunate to have that so right now, my answer is that Im going to stay in the AHL." HOUSTON - Outfielder Colby Rasmus has agreed to an $8 million, one-year contract with the Houston Astros.The deal was announced Tuesday, a day after Houston dealt last years starting centre fielder, Dexter Fowler, to the Chicago Cubs.The 28-year-old Rasmus started 80 games in centre field for the Toronto Blue Jays last season and has played both right and left field in hiss six-year big league career.dddddddddddd He batted .225 with 18 homers and 40 RBIs last season after hitting 22 home runs with 66 RBIs in 2013.A first-round pick by the St. Louis in the 2005 amateur draft, Rasmus hit 23 homers in 2010 with the Cardinals and 2012 with Toronto.Catcher Carlos Corporan was designated for assignment to make room on the roster. Cheap NFL Jerseys (http://www.cheapjerseysstitchedshop.com/) Wholesale Jerseys (http://www.wholesalejerseyssafestore.com/) Wholesale NFL Jerseys (http://www.wholesalechinastitchedjerseys.com/) Jerseys From China (http://www.wholesalenflcheapjerseyschina.us.com/) Wholesale NFL Jerseys (http://www.chinanflonlinejerseys.com/) Cheap NFL Jerseys (http://www.cheapsoccerjerseyschinaonline.com/) Cheap Jerseys (http://www.cheapnbajerseyschinastore.com/) ' ' ' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464815#464815 ________________________________________________________________________________
Subject: s in February and dressed for six games. He was dr
Date: Jan 06, 2017
ANN ARBOR, Mich. Cheap Jerseys Fans (http://www.cheapjerseysfans.co/) . -- Nik Stauskas and Glenn Robinson III are skipping their last two seasons at Michigan to enter the NBA draft and chase a dream theyve had since they were kids. Stauskas, who is from Mississauga, Ontario, set his sights on joining in the worlds best basketball league when he started playing the game in an organized way at the age of 7. "From that point on, I pretty much committed myself to doing whatever it took to get to this point," he said. "I dont think many Canadian kids had that same dream. I think most of them were trying to go to the NHL, but I think the rise of Canadian basketball has been unbelievable. You see a lot of kids now making that jump from Canada and Im glad to be a part of that group." Robinson, meanwhile, might have looked at the league a little earlier because his father -- nicknamed "Big Dog" -- was the No. 1 overall pick in the 1994 NBA draft. "My dad has been through this whole process, so that was definitely a big help," he said. "He stayed an extra year in college when he thought he wasnt ready." Robinson, who is from St. John, Ind., said the NBAs undergraduate advisory committee informed him he would be a first-round pick if he entered the draft and he chose to make the leap Monday night. Stauskas wouldnt say what he was told, but he obviously liked the feedback. "I heard from the advisory board in the middle of last week, a couple days after that I really decided," he said. "The information I got from them was kind of what I wanted to hear." Mitch McGary has not announced his future plans. "Mitch is still gathering information," coach John Beilein said. "He has all the way until the 27th to make a decision, so hes looking at all the possibilities right now." McGary was not made available for interviews after his teammates had a news conference. He turned down a chance to enter the draft last year as a likely first-round pick and ended up having back surgery last season, putting his standing as an NBA pro! spect in doubt. The Wolverines lost Trey Burke and Tim Hardaway to the NBA last year as underclassmen, but retooled well enough to win the Big Ten title and advance to an NCAA tournament regional final. Stauskas said hes confident Michigan is strong enough to keep winning next season. "I think were leaving this program in great hands," Stauskas said as he looked toward his former teammates, who gathered to show their support for him and Robinson at their news conference. The 6-foot-6 shooting guard became one of the nations most well-rounded offensive players, averaging 17.5 points and improving defensively and earning Big Ten player of the year honours last season. The 6-6 Robinson came on strong toward the end of the season and finished with a 13.1 point average. The pressure will now be on improving guard Caris LeVert to have another big season for Michigan next season. Derrick Walton and Zak Irvin -- who both had their share of impressive moments as freshmen -- will also have a chance to take on more leadership. The Wolverines also will lose fifth-year senior Jordan Morgan, and Jon Horford is transferring. Early departures have become the norm at Michigan now that the program has become a Big Ten power again. After going without a regular-season conference title since 1986, the Wolverines tied for first in 2012 and went on to reach the NCAA finals. Thanks in part to Stauskas and Robinson, Michigan won a school-record 59 games over the last two seasons and lost just 17 times. Cheap NFL Jerseys Authentic (http://www.cheapjerseysfans.co/) . The fact that he was willing to do the deal the way we wanted it to be done showed that he wanted me to be a part of something great," Lowry said, noting that Ujiri willingness to sign off on the proposal that both Lowry and his agent presented to the GM was the final straw that convinced him to return. Cheap NFL Jerseys (http://www.cheapjerseysfans.co/) . The No. 5 Aztecs held Burton, the Mountain Wests leading scorer, to 11 points, 10 below his average, in beating the W! olf Pack 73-58 on Saturday night. http://www.cheapjerseysfans.co/ (http://www.cheapjerseysfans.co/) .Impact president Joey Saputo confirmed Thursday that he is part of a group of investors whose offer to buy the 105-year-old Italian club was accepted by the teams board of directors.The Edmonton Eskimos added depth the offensive line on Tuesday, acquiring lineman Steve Myddelton from the Hamilton Tiger-Cats. The Eskimos traded a conditional pick in the 2015 CFL Canadian Draft and a fourth round pick in the 2016 CFL Canadian Draft in return. Myddelton, a six-year CFL veteeran spent four seasons with the Calgary Stampeders before being traded to the B. NFL Fans Cheap Jerseys (http://www.cheapjerseysfans.co/). C. Lions in 2013. He was signed as free agent by the Tiger-Cats in February and dressed for six games. He was drafted in the fourth round (30th overall) of the 2009 CFL Canadian Draft. Cheap NFL Jerseys (http://www.cheapjerseysstitchedshop.com/) Wholesale Jerseys (http://www.wholesalejerseyssafestore.com/) Wholesale NFL Jerseys (http://www.wholesalechinastitchedjerseys.com/) Jerseys From China (http://www.wholesalenflcheapjerseyschina.us.com/) Wholesale NFL Jerseys (http://www.chinanflonlinejerseys.com/) Cheap NFL Jerseys (http://www.cheapsoccerjerseyschinaonline.com/) Cheap Jerseys (http://www.cheapnbajerseyschinastore.com/) ' ' ' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464816#464816 ________________________________________________________________________________
Subject: an early converted try to backrower Juan Ma
Date: Jan 06, 2017
MINNEAPOLIS -- Joe Mauer hit a two-run double that just missed reaching the seats and Kevin Correia pitched a smooth six innings to help the Minnesota Twins beat the Chicago White Sox for the third straight game, 4-3 on Saturday. Wholesale China Jerseys (http://www.cnjerseystousacheap.com/) . Glen Perkins pitched another tenuous ninth inning but got his 19th save in 22 tries after giving up two runs to blow one the night before. Adam Eaton led off with a triple and scored on Gordon Beckhams sacrifice fly. Pinch-hitter Paul Konerko then smacked a single up the middle, but Perkins struck out Jose Abreu and Adam Dunn to end it and punctuated the final swing and miss with a big pump of his left arm. With the Twins trailing 2-1, Mauers drive in the fifth inning soared over left fielder Alejandro De Aza and landed about halfway up the wall. Kendrys Morales hit the next pitch for an RBI single against Andre Rienzo (4-5), who lost his fifth straight start. Correia (4-8) gave up five runs or more in five of his first 12 starts, sliding toward replacement in the rotation, but the 33-year-old right-hander has pitched superbly in three turns since. In 18 innings, Correia has allowed a total of two earned runs and walked only four. He surrendered his share of sharp drives on this picture-perfect first-day-of-summer afternoon, but the defence behind him didnt do him any favours. Centre fielder Sam Fuld tried to dive for a two-out sinking liner by Conor Gillaspie in the first inning, but the ball skipped in front of and past him for a triple and Abreu followed with an RBI single. Then third baseman Eduardo Escobar bungled a routine ground ball by letting it slide between his legs to start the second inning. The White Sox only needed a single, a walk and a two-out hit-by-pitch to produce the unearned run. Correias 3-1 bases-loaded fastball bounced off Beckhams elbow and hit catcher Kurt Suzuki in the throat, but he was all right to stay in the game. Escobar committed a second error on a similar play the next inning, but! Correia escaped trouble with a double-play groundball by Dayan Viciedo. The Brazilian-born Rienzo, who debuted for the White Sox last summer, was 4-0 after his first six starts following the rotator cuff injury that knocked Felipe Paulino out of action. Rienzo has struggled badly since, though, by finishing the fifth inning in only two of his last five turns. His ERA during the losing streak is 8.87. The Twins hit three straight two-out singles in the second inning to load the bases, and Fuld walked to force in the first run. Then Rienzo hit Brian Dozier with a pitch to put two runners on for Mauer in the fifth inning, setting the struggling six-time All-Star and three-time batting champion up for just his fourth multi-RBI game this season. Two of those have been in this series. The White Sox have hung around the pack in the American League Central all year, never losing or winning more than four games in a row, but this has been a rough start to an 11-game road trip. They fell a season-high five games under .500 and back into last place. The Twins took a five-game losing streak into this series. Their starters have a 2.41 ERA over the last 11 games. NOTES: Mauer has 18 of his 20 RBIs this season at Target Field. ... Gillaspie went 2 for 4 to raise his average to .340, but he doesnt have enough at-bats to qualify yet for the league batting lead. In his last 30 games, Gillaspie is batting .366. ... Twins RF Oswaldo Arcia is hitless in his last 27 at-bats. ... The White Sox will send John Danks (6-5, 3.97) to the mound for the series finale Sunday, and Phil Hughes (7-3, 3.09 ERA) will pitch for the Twins. Danks has a 5.70 ERA in six road starts this season. Hughes gave up three HRs in his last home start, the only time a team has taken him deep in his last eight turns. ... White Sox manager Robin Ventura successfully challenged a call in the third inning, when Brian Dozier originally led off with a double. Replays showed Beckhams tag grazed Doziers foot before it landed on the base. Cheap Jerseys USA (http://www.! cnjersey stousacheap.com/) . Switzerland faces Belgium or Kazakhstan in the quarterfinals in April. Serbia dropped into the World Group playoffs in September. A confident Chiudinelli and Lammer defeated veteran doubles player Zimonjic and young Krajinovic 7-6 (3), 3-6, 7-6 (2), 6-2. Wholesale NFL Jerseys Jerseys (http://www.cnjerseystousacheap.com/) . With their coach gone, they finally played offence the way he would have wanted. Amare Stoudemire made all seven shots in the first half, Anthony passed and shot well, and the Knicks shook off the surprising departure of their coach to rout the Portland Trail Blazers 121-79 on Wednesday night, snapping a six-game losing streak. http://www.cnjerseystousacheap.com/ (http://www.cnjerseystousacheap.com/) . Argentina, who have yet to beat New Zealand in 17 meetings, rocked the All Blacks with an early converted try to backrower Juan Manuel Leguizamon and led 7-0 after five minutes. But Smiths double in the 23rd and 26th minutes - when Argentina was reduced to 14 men by the sin-binning of hooker Eusebio Guinazu - turned the tide of the match and set up New Zealands third straight Championship win.BROOKLYN, Mich. - Kevin Harvick posted the fastest qualifying speed in NASCARs top series since 1987, winning the pole at Michigan International Speedway on Friday at 204.557 mph. Harvicks pole-winning speed was the fastest since Bill Elliott set the record of 212.809 mph at Talladega Superspeedway in April 1987, but drivers have routinely broken 200 mph at Michigan since the track was repaved before the 2012 season. Marcos Ambrose had a speed of 203. MLB Jerseys China (http://www.cnjerseystousacheap.com/). 241 in 2012, the first time anyone won a pole at over 200 mph since Elliott did it before horsepower-sapping restrictor plates were introduced at Talladega and Daytona. Last August, Joey Logano pushed the track record to 203.949. Harvick was even faster in winning his third pole of the year and ninth of his career. Points leader Jeff Gordon was second, and Dale Earnhardt Jr. w! as third . Cheap NFL Jerseys (http://www.cheapjerseysstitchedshop.com/) Wholesale Jerseys (http://www.wholesalejerseyssafestore.com/) Wholesale NFL Jerseys (http://www.wholesalechinastitchedjerseys.com/) Jerseys From China (http://www.wholesalenflcheapjerseyschina.us.com/) Wholesale NFL Jerseys (http://www.chinanflonlinejerseys.com/) Cheap NFL Jerseys (http://www.cheapsoccerjerseyschinaonline.com/) Cheap Jerseys (http://www.cheapnbajerseyschinastore.com/) ' ' ' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464817#464817 ________________________________________________________________________________
Subject: hab asssignment with Triple-A Louisville.
Date: Jan 06, 2017
SANTA CLARA, Calif. Per Mertesacker Arsenal Jersey UK (http://www.arsenalfcteamshop.net/per-mertesacker-arsenal-jersey-uk/) . - An extra week to heal has proved beneficial for San Francisco tight end Vernon Davis, who says he can play without thinking again. And thats a good thing. Coming off an injury, it always lingers and its in your mind when youre playing, Davis said Thursday. I feel healthy enough to go out, get going, not thinking, just reacting. Hampered by ankle and back problems most of the season, Davis hopes to add to his 14 catches for 142 yards in the 49ers rematch with the visiting St. Louis Rams on Sunday. An All-Pro player last year after catching 13 touchdown passes, Davis has been limited to a pair of touchdown receptions, both in the first quarter of the 49ers season-opening victory over the Dallas Cowboys. Youre always going to have trials and face adversity, Davis said. You can grow from it if you deal with it the right way. San Francisco offensive co-ordinator Greg Roman expects bigger things ahead for Davis, the franchise leader among tight ends with 55 touchdowns. I think hes back to form, and you know, hes been playing through some things, Roman said. Hes gutted his way through it and I think hes got a very focused glare when it comes to what he wants to accomplish from here on out. Regaining his proficiency as a deep threat is one of those things he wants to accomplish. For the most part I feel like I can do a lot of things well, Davis said. The bye week was a great opportunity to work on things and to try to get healthy. His presence would give Colin Kaepernick, who threw for season highs of 343 yards and three touchdowns in the 49ers win over the Rams three weeks ago, another weapon in the passing game. Ill do whatever it takes to win, Davis said. Ill block for Frank Gore, Ill be the decoy down field, whatever it takes. As far as dealing with adversity, Davis only needs to look down a few lockers to see how running back Marcus Lattimore has been dealing with it for two years.! Lattimo re, who turned 23 on Wednesday, is two years removed from a devastating knee injury and made his practice debut this week, getting individual attention from former 49ers fullback Tom Rathman, among others. It was great to see him out there, Roman said. He worked with coach Rathman after practice and got with some of the defensive players and got some contact work, which was really good. The 49ers have 21 days to decide whether to put him on the active roster. NOTES: WR Stevie Johnson, a San Francisco native, said the Giants winning the World Series puts pressure on us to make it a San Francisco thing. Hopefully, the Warriors can take the NBA. Johnson said the San Jose Sharks Logan Couture once told him that the difference in the playoffs was how people reacted to each other. Thats what we want here and it could be a special year. Santi Cazorla Jersey UK (http://www.arsenalfcteamshop.net/santi-cazorla-arsenal-jersey-uk/) . Anything less than gold for either nation is considered a disappointment. Yet for Switzerland, advancing to the semifinal might be a victory in itself. Santi Cazorla Arsenal Jersey UK (http://www.arsenalfcteamshop.net/santi-cazorla-arsenal-jersey-uk/) . Dillon Brooks scored 26 points on 9-17 shooting for Canada while pulling down six rebounds and picking up six steals. Teammate Chris Egi had 20 points, 14 rebounds and four blocks. http://www.arsenalfcteamshop.net/ (http://www.arsenalfcteamshop.net/) . In question is whether 26-year-old Matt Frattin will be on it. A a?mediocrea? training camp, as Carlyle put it earlier this week, has Frattin lingering nervously on the bubble at the end of the exhibition season, pushed out of a likely job by Brandon Kozun, the small, but feisty winger determined to make the NHL for the first time.OAKLAND, Calif. -- The Cincinnati Reds have placed second baseman Brandon Phillips on the paternity list, and he will miss the teams two-game series in Oakland before rejoining the club Friday at Texas. Phillips returned to Cincinnati as the club made a b! rief sto p in the Bay Area. The Reds reinstated outfielder Chris Heisey from the 15-day disabled list Tuesday after a six-game rehab asssignment with Triple-A Louisville. Calum Chambers Jersey UK (http://www.arsenalfcteamshop.net/calum-chambers-arsenal-jersey-uk/). . He had been on the DL since April 29 with an injured right hamstring. Heisey was in the lineup batting sixth as the designated hitter against the As. The Reds also recalled infielder Henry Rodriguez from Louisville for his second stint with Cincinnati this season, and optioned outfielder Donald Lutz to Double-A Pensacola. Cheap NFL Jerseys (http://www.cheapjerseysstitchedshop.com/) Wholesale Jerseys (http://www.wholesalejerseyssafestore.com/) Wholesale NFL Jerseys (http://www.wholesalechinastitchedjerseys.com/) Jerseys From China (http://www.wholesalenflcheapjerseyschina.us.com/) Wholesale NFL Jerseys (http://www.chinanflonlinejerseys.com/) Cheap NFL Jerseys (http://www.cheapsoccerjerseyschinaonline.com/) Cheap Jerseys (http://www.cheapnbajerseyschinastore.com/) ' ' ' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464818#464818 ________________________________________________________________________________
Subject: with former St. Louis Rams safety Darian Stewart on
a one-y
From: "blueberryjerry" <blueberryjerry0822(at)hotmail.com>
Date: Jan 06, 2017
BOSTON -- The Fourth of July game between the Boston Red Sox and Baltimore Orioles was postponed because of the impending storm. Marcelo Brazil Jersey (http://www.officialbrazilonline.com/world-cup-marcelo-football-jersey/) . The game will be made up on Saturday as part of a day-night doubleheader. The Red Sox made the announcement more than three hours before the first pitch. Hurricane Arthur was expected to sweep through the area on Friday afternoon and deliver heavy rain and flash flooding. The forecast for Saturday was clear. Bernard Jersey (http://www.officialbrazilonline.com/world-cup-bernard-football-jersey/) . Last year, Islanders forward Colin Mcdonald released a "Do It For Colin" campaign to promote his teammate and friend John Tavares for the EA sports honour:The most popular sports voting video ever has to go to Chris Bosh who showcased his comedic abilities in his effort to get fans to vote him into the 2008 All Star Game:You can vote for TJ and other star players for the NHL 15 cover vote here. Gil Jersey (http://www.officialbrazilonline.com/world-cup-gil-football-jersey/) . The deals were announced on Friday. Beckham will receive $4.175 million in base salary, while De Aza will receive $4.25 million. Beckham hit .267 with five home runs and 24 RBIs over 103 games last season, his fifth with the White Sox. http://www.officialbrazilonline.com/world-cup-fabinho-football-jersey/ (http://www.officialbrazilonline.com/world-cup-fabinho-football-jersey/) . Malone will become an unrestricted free-agent and as per the collective bargaining agreement, the Lightning will be responsible for two-thirds of the remainder of his contract over twice the length of the rest of the deal.OWINGS MILLS, Md. -- The Baltimore Ravens have agreed to terms with former St. Louis Rams safety Darian Stewart on a one-year contract Friday. The 25-year old Stewart signed with the Rams as an undrafted free agent in 2010 and spent the last four seasons with the Rams. He started 13 games in 2011 under current Baltimore seconda! ry coach Steve Spagnuolo, who was St. Fernandinho Brazil Jersey (http://www.officialbrazilonline.com/world-cup-fernandinho-football-jersey/). Louis head coach from 2009-11. Stewart had 84 tackles, three sacks, two forced fumbles and an interception in 2011. He had 36 tackles last season while making six starts. Cheap NFL Jerseys (http://www.cheapjerseysstitchedshop.com/) Wholesale Jerseys (http://www.wholesalejerseyssafestore.com/) Wholesale NFL Jerseys (http://www.wholesalechinastitchedjerseys.com/) Jerseys From China (http://www.wholesalenflcheapjerseyschina.us.com/) Wholesale NFL Jerseys (http://www.chinanflonlinejerseys.com/) Cheap NFL Jerseys (http://www.cheapsoccerjerseyschinaonline.com/) Cheap Jerseys (http://www.cheapnbajerseyschinastore.com/) ' ' ' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464819#464819 ________________________________________________________________________________
Subject: s for Sundays game before 12:30 p.m. for the start
of the ce
Date: Jan 06, 2017
The Ottawa SenatorsThe Sens had a golden opportunity to win the cup in 2007. nfl jerseys china (http://www.cheapnfljerseyschinastore.com/) . After beating the Pittsburgh Penguins, New Jersey Devils and Buffalo Sabres all in five games, the Senators would square off in the Cup Final against the Anaheim Ducks. It was a great time for the city of Ottawa as it was their first time being in the Cup final since 1927. Dany Heatley, Jason Spezza and Daniel Alfredsson carried the Sens throughout the playoffs, along with the goaltending of Ray Emery.The Sens could not handle the Ducks in the Cup final though, who had forwards like Corey Perry, Ryan Getzlaf and Teemu Selanne. The Ducks also had a solid shutdown line, a lethal defence duo of Chris Pronger and Scott Niedermayer, and a world class goalie in Jean-Sebastien Giguere. The Sens would lose to the Ducks in five games which would conclude their best run at the cup since the Habs won in 1993.Watch a tribute to their run here.Toronto Maple LeafsYes, the Toronto Maple Leafs have had a solid playoff run since the Habs won in 1993, and it almost got them in the Cup Final. The year was 2002 and the Leafs defeated the Islanders and the Senators in the opening rounds. They would play the Conference Final against a team that they matched up pretty well against, the Carolina Hurricanes. The Leafs had an incredible goaltender in Curtis Joseph, and classic players like Mats Sundin, Gary Roberts and Darcy Tucker. Sundin and Tucker actually missed most of the first two rounds with injuries, so when they returned in the Eastern Conference Final, most Toronto fans were predicting their team would finally play for the Cup for the first time since 1967.The Leafs seemed to run out of gas and couldnt handle the Hurricanes, who got great goaltending from Arturs Irbe, and tons of production out of forwards like Rod BrindAmour, Erik Cole, and Jeff ONeill. The Leafs would lose in dramatic fashion at home in Game 6 in overtime. Sundin tied the game with the goalie pulled before the e! ventual season-ending goal by the Hurricanes. Check out Sundins game-tying goal which would highlight the Leafs 2002 run.So fans, who in the East has the best shot at being the next Canadian team to win a cup? Tweet us @BarDown cheap jerseys (http://www.cheapnfljerseyschinastore.com/) . Cammalleri suffered a concussion in the Flames 2-1 loss to the Pittsburgh Penguins on Saturday. The 31-year-old forward did not travel with the team to Carolina. jerseys from china (http://www.cheapnfljerseyschinastore.com/) . -- Craig Anderson has quite a record against his former team, the Florida Panthers. http://www.cheapnfljerseyschinastore.com/ (http://www.cheapnfljerseyschinastore.com/) .C. - Canadian ice dancing, it seems, is in good hands.NEW YORK -- Ivan Nova thought discovering he was tipping pitches in his start against Boston last week made the difference. Manager Joe Girardi simply attributed this outing to better control. No matter the reason, Novas stellar September start kept the New York Yankees in the AL wild-card chase. The right-hander pitched a six-hitter for his second career shutout, Eduardo Nunez hit a two-run homer and the Yankees beat the San Francisco Giants 6-0 Saturday. "We need to win games, and its no time to pitch the way that I pitched the time before," Nova said. Nova watched video between starts with pitching coach Larry Rothschild after giving up five runs -- four earned -- against the Red Sox. Nova thought he saw himself giving away some pitches, so he adjusted the way he held his glove, and he also worked on better curveball command. The adjustments made for a 108-pitch gem. A day before New York honours retiring closer Mariano Rivera in a pregame ceremony, Nova (9-5) gave the Yankees bullpen a rest with his third complete game, all this year. He struck out seven and walked one in winning for the first time in four starts following poor efforts against AL East rivals Boston and Baltimore. "I think he has a lot more confidence in his stuff," Girardi said. Brendan Ryan made several impressive ! plays at shortstop, Alfonso Soriano connected for the second straight day and Robinson Cano had an RBI single in a three-run third against Ryan Vogelsong (3-6), helping New York win for just the third time in eight games. New York (82-73) remained three games behind Cleveland (85-70) and 2 1-2 back of Texas (84-70) for the second AL wild card but moved ahead of Baltimore and Kansas City (both 81-73). The Yankees have seven games remaining, including three against wild-card leading Tampa Bay (85-69). "If we played like we played last night and today we feel like we can win every game," Soriano said. Soriano connected on the first pitch thrown by reliever Guillermo Moscoso leading off the sixth, giving him 17 homers and 50 RBIs with the Yankees in 52 games. He had 17 homers and 51 RBIs in 93 games for the Chicago Cubs. The Giants gave the many orange and black-clad fans in attendance little to cheer. They only had two baserunners reach second -- one the result of Soriano losing Brandon Belts flyball to left field in the sun for a double. Belt and Pablo Sandoval each had twwo hits for the Giants, who never put two runners on in the same inning. wholesale nfl jerseys (http://www.cheapnfljerseyschinastore.com/). San Francisco lost for the eighth time in nine interleague road games this season. With a .458 winning percentage (71-84), the Giants are on track for the third-worst winning percentage for a defending World Series champion, trailing only the 1998 Florida Marlins (.333) and the 1991 Cincinnati Reds (.457), according to STATS. After Vogelsong retired six straight to start the game, the bottom three in the Yankees lineup reached opening the third. Mark Reynolds blooped a single over third base and went to third on a hit-and-run single by Ryan, who entered with a .197 average. Chris Stewart walked on four pitches to load the bases for Ichiro Suzuki. "It was upsetting for me from a mental standpoint. I didnt have a good mental game," Vogelsong said. "On the hit and run, I knew they were going to send the runner t! here and the cutter away but it ran up a bit. If that ball is where I want it to be its a groundball." Suzukis sacrifice fly put the Yankees ahead, Alex Rodriguez drove in another run with a spinning grounder to the left of second base that shortstop Brandon Crawford gloved with a nifty grab, and Cano tacked on a run when he sliced a single the opposite way through a huge hole between shortstop and third base. Nunez connected in the fourth on the first pitch he saw from Vogelsong for his second homer this season. Vogelsong was lifted after five innings. He allowed five runs and five hits in losing for the fourth time in five starts. Sandoval, the Giants third baseman, was lifted for defence before the start of the bottom of the eighth because his back tightened up. He is day to day. NOTES: Nova pitched a three-hit shutout against Baltimore on Aug. 31. ... Girardi said that while C Austin Romine (concussion) was cleared to play, he may not return this season because he still feels dizzy after working out. ... Giants manager Bruce Bochy visited Monument Park. ... Giants 2B Joaquin Arias will miss several games with a pulled left hamstring. Arias was injured Friday night in the seventh inning. ... The Yankees are urging fans to be in their seats for Sundays game before 12:30 p.m. for the start of the ceremony honouring Rivera. .... Giants RHP Yusmeiro Petit (4-0) faces LHP Andy Pettitte (10-10), who will be making his final regular-season start at Yankee Stadium. Cheap NFL Jerseys (http://www.cheapjerseysstitchedshop.com/) Wholesale Jerseys (http://www.wholesalejerseyssafestore.com/) Wholesale NFL Jerseys (http://www.wholesalechinastitchedjerseys.com/) Jerseys From China (http://www.wholesalenflcheapjerseyschina.us.com/) Wholesale NFL Jerseys (http://www.chinanflonlinejerseys.com/) Cheap NFL Jerseys (http://www.cheapsoccerjerseyschinaonline.com/) Cheap Jerseys (http://www.cheapnbajerseyschinastore.com/) ' ' ' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464820#464820 ________________________________________________________________________________
Subject: ew Schiestel answered for the Bulldogs (32-34-7). The
IceCap
Date: Jan 06, 2017
MADRID, Spain -- Barcelona defender Dani Alves has received an outpouring of support for his response to a racist taunt during a game, while Villarreal issued a lifetime ban to the season-ticket holder who threw a banana at him. China Jerseys (http://www.wholesalenflcheapjerseyschina.us.com/) . Alves, who is black, was about to take a corner in Sundays 3-2 win at Villarreals El Madrigal Stadium when a banana landed on the pitch in front of him. The Brazil international picked it up, peeled it and ate some of it before throwing the rest aside. "Villarreal deeply regrets and condemns the incident that happened," Villarreal said in a statement on Monday. "The club has already identified the (culprit) and has decided to withdraw his season tickets, permanently." After the match, Alves said humour was the best way to combat racism in sport. That sentiment has led fellow football players, officials and even political figures from around the globe to respond with solidarity by picturing themselves eating a banana. Barcelona teammate Neymar posted a photo of himself on Instagram holding a peeled banana alongside his son, who was holding a doll that resembled a banana. Fellow Brazil teammates Hulk and Fred also lent support via their social media accounts. Argentina striker Sergio Aguero and Brazil womens striker Marta both posed for photos while biting into bananas, while former Brazil international Roberto Carlos also posted an internet photo of himself with the fruit. "We have suffered this in Spain for some time," Alves said Sunday. "You have to take it with a dose of humour. We arent going to change things easily. If you dont give it importance, they dont achieve their objective." Brazilian President Dilma Rousseff, who has been actively condemning racist acts in Brazilian football, also expressed her support to Alves, while Italian Prime Minister Matteo Renzi and Italy national team coach Cesare Prandelli also shared a banana in a photograph. "The player had a daring and strong response to racism in sport,"! Roussef f wrote on her official Twitter account. "Confronted by something that unfortunately has become too common in stadiums, Alves had attitude." Rousseff praised Neymar for getting behind his teammate and reiterated that Brazil will "raise the flag against racial discrimination" during the World Cup. FIFA President Sepp Blatter also commented on Twitter, saying that "what (Alves) tolerated last night is an outrage." He added that there "will be zero tolerance" at the World Cup. The match referee on Sunday included the 75th-minute incident in his match report, so Villarreal could face a fine. "Our club would like to express its firm commitment to promoting respect, equality, sportsmanship and fair play both on and off the field and our absolute rejection of any act that is contrary to these principles, such as violence, discrimination, racism and xenophobia," Villarreal added in its statement. Alves has often been subjected to racist taunts and called fighting racism "a lost war" in January 2013 after segments of Real Madrids fans abused him with monkey chants during a match. Madrid defender Marcelo, who is also Brazilian, was also recently greeted with monkey chants by a section of Atletico Madrid fans this season. Former Barcelona striker Samuel Etoo was convinced not to walk off at Zaragoza in 2006 after fans berated the Cameroon striker with racist chants. Two years earlier, Spain fans at Madrids Santiago Bernabeu Stadium infamously greeted Englands black players with monkey chants during an international friendly match. Jerseys From China (http://www.wholesalenflcheapjerseyschina.us.com/) . Dallas (2-0-1) sits atop the Western Conference with an MLS-best seven points. Castillo opened the scoring in the 71st minute off a Mauro Diaz set piece, and Watson outran defender Tony Lochhead on a long ball and then juked goalkeeper Ian Kennedy for the eventual game-winner in the 78th minute. Jerseys China (http://www.wholesalenflcheapjerseyschina.us.com/) .J. -- Pitcher Carl Pavano is retiring after 14 major leagu! e season s. http://www.wholesalenflcheapjerseyschina.us.com/ (http://www.wholesalenflcheapjerseyschina.us.com/) . Perez, 35, posted a 1-2 record with a 3.69 earned-run average in 19 relief appearances last season. His season ended Aug. 9 due to a torn ligament in his left elbow. Perez joins infielder Andy LaRoche and catcher Mike Nickeas with minor-league agreements for 2014 that include invitations to attend spring training. ST. JOHNS, N.L. -- Devan Dubnyk stopped all four shots he faced in the shootout and made 25 saves in regulation as the Hamilton Bulldogs edged the St. Johns IceCaps 4-3 in American Hockey League action Wednesday. The goalie played with an aggressive style in the shootout, coming out to cut the angles down early, and set the tone by poke-checking the puck away from IceCaps forward Jerome Samson on the first attempt of the night. "Its the way I play," Dubnyk said. "Some guys are different. For me, I like to get out and I feel I can move side-to-side well enough that if I get out and really give them absolutely nothing to shoot at then Ill be patient and force them to try and go around me." Dubnyk said that although the Bulldogs are virtually eliminated from the playoff race, the team still looks forward to winning games at this point in the season. "We talked about continuing the fight," he said. "We did a good job pushing to the end and we scored a huge goal in the third period. We were really close last night but we had a few letdowns that cost us towards the end of the game so it was really important to come out and do that tonight." IceCaps defenseman Jordan Hill notched two assists on the night. "Its nice to help out offensively, but I know thats not my game," Hill said. "I just try to move the puck to the forwards and let them do the work." Hill said St. Johns expected this sort of push back from Hamilton after beating them Tuesday night. &quuot;Theyre a good team," he said.dddddddddddd "Obviously its late in the season and were trying to get every point we can here, scratching and clawi! ng towar ds the playoffs. We didnt get the job done tonight." The IceCaps guaranteed themselves a playoff spot after winning Tuesdays game. Andrighetto scored the shootout winner on a quick forehand-to-backhand move before slipping the puck in behind IceCaps netminder Tyler Beskorowany. Gabriel Dumont also scored in the shootout for the Bulldogs. John Albert, Kyle MacKinnon and Adam Lowry scored in regulation for the St. Johns IceCaps (43-22-7). Greg Pateryn, Mike Blunden and Drew Schiestel answered for the Bulldogs (32-34-7). The IceCaps scored first, 1:59 into the game, when Albert ripped a wrist shot from the left faceoff dot to score high glove side. The Bulldogs equalized on a Pateryn slapshot, through a sprawled-out Beskorowany on the powerplay at the 13:41 mark of the first period. MacKinnon gave the IceCaps a 2-1 lead when he surprised the Bulldogs and ripped a quick wristshot high glove with 4:25 left in the first. Lowry backhanded home a rebound on the doorstep for St. Johns at the 17:39 mark of the second period to make it a 3-1 game. Seventeen seconds later, Schiestl pulled the Bulldogs within one from the slot with a wrist shot high glove. Blunden tipped home a puck while going to the net at the 12:54 mark of the third period, to tie the game. Beskorowany made 37 saves, and saved two of four shots in the shootout. Cheap NFL Jerseys (http://www.cheapjerseysstitchedshop.com/) Wholesale Jerseys (http://www.wholesalejerseyssafestore.com/) Wholesale NFL Jerseys (http://www.wholesalechinastitchedjerseys.com/) Jerseys From China (http://www.wholesalenflcheapjerseyschina.us.com/) Wholesale NFL Jerseys (http://www.chinanflonlinejerseys.com/) Cheap NFL Jerseys (http://www.cheapsoccerjerseyschinaonline.com/) Cheap Jerseys (http://www.cheapnbajerseyschinastore.com/) ' ' ' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464821#464821 ________________________________________________________________________________
Subject: from behind (Fedor Tyutin, CBJ)March 20, 20
Date: Jan 06, 2017
Morocco was thrown out of the 2015 African Cup of Nations and dumped as the host Tuesday after refusing to commit to the scheduled dates early next year because of fears over Ebola. Matthias Ginter Jersey (http://www.dortmundfcshop.com/c-19-matthias-ginter-fc-borussia-dortmund-jersey.aspx) .The tournament in January and February will now have a new host country only two months before kickoff, the Confederation of African Football said after an emergency meeting at its Cairo headquarters.CAF didnt announce the replacement host, but said it had received some applications.These applications are currently under review, and the executive committee will finalize the selection of the successful national association shortly, the African football body said in a statement.It didnt name any of the candidates.South Africa, Egypt, Sudan and Ghana have all already indicated they are unwilling to replace Morocco, partly because of Ebola. Nigeria, Angola and Gabon have also been mentioned as possible stand-in hosts.The decisions by CAF were taken at a meeting that was forced by Moroccos refusal to hold the tournament on the planned dates of Jan. 17-Feb. 8 because of the threat of the spread of Ebola. The disease has killed about 5,000 people in West Africa, and Morocco wanted the 16-team soccer event postponed until 2016 because of fears the deadly virus would arrive with supporters and other travellers.CAF repeatedly refused Moroccos request to postpone the African Cup, the bodys main money-earning tournament, and gave the country until Saturday to commit to the planned dates. Morocco declined again.The Royal Moroccan Football Federation reiterated its refusal to hold the competition on the dates indicated, CAF said Tuesday. Therefore having firmly and unanimously notified ... its decision to keep the competition on the dates indicated, the executive committee confirmed that the Africa Cup of Nations 2015 will not take place in Morocco.CAFs executive committee also decided that the national team of Morocco is automatic! ally dis qualified because of its refusal to host. CAF will decide on further punishments for Morocco for breaching its contract as host, it said.CAF must now decide on a new host nation, one which will have little time to prepare. The decision on the new host would be made shortly, CAF said, but it didnt give a solid timeframe.It also will have to re-schedule the final draw for the tournament, and the ongoing qualifying competition might be affected if a country currently playing in the qualifiers is given an automatic place in the final tournament as the new host.After Morocco indicated last month that it wanted a postponement, CAF approached seven countries to act as possible short-notice hosts, according to South Africa, one of the nations on the list.No country has publicly said yet that it wants to host the tournament in Moroccos place.Although Guinea is the only one of the three West African countries worst-affected by Ebola to still have a good chance of qualifying for the final tournament, there was nothing stopping fans from the other Ebola countries from travelling, Moroccan authorities said. They warned of the dangers of supporters from football-mad West Africa mixing with large groups of other fans at stadiums.Morocco said it wouldnt stand down over its position because of advice from its health authorities, which took precedence over sports.Moroccan authorities were criticized by some sections of their own media over their decision, which could result in a ban from future editions of the African Cup.While harping on the risk of Ebola, Moroccos position is strongly contradicted by Royal Air Marocs 15 flights a week to countries affected by Ebola, an editorial in the French-language Moroccan daily Les Echos said. There are not less than 1,500 people transported from these countries to Morocco every week, without a single case detected.The paper predicted severe penalties and a negative political impact for Morocco.Morocco is also scheduled to host FIFAs Club World Cup next month, featuring Champions L! eague wi nner Real Madrid. The country said it was willing to continue with its hosting duties for that tournament because it didnt expect many supporters to travel to it from Ebola-affected regions.The two African teams playing in the Club World Cup are from Morocco and Algeria.___Associated Press writer Paul Schemm contributed to this report.___Gerald Imray is on Twitter at www.twitter.com/GeraldImrayAP Ousmane Dembele Jersey (http://www.dortmundfcshop.com/c-8-ousmane-dembele-fc-borussia-dortmund-jersey.aspx) .One day after winning her record 63rd World Cup race, Vonn posted to her Facebook account Tuesday that she was happy Woods surprised her by coming to the race, and that she felt terrible that his tooth got knocked out. Adrian Ramos Dortmund Jersey (http://www.dortmundfcshop.com/c-13-adrian-ramos-fc-borussia-dortmund-jersey.aspx) .Gasol had 16 points and 13 rebounds, and the Bulls beat the winless Orlando Magic 98-90 on Tuesday night.Jimmy Butler led the Bulls with 21 points and Taj Gibson added 16 for Chicago, which finally pulled away in the final minutes of a game that was tied after three quarters. http://www.dortmundfcshop.com/c-14-christian-pulisic-fc-borussia-dortmund-jersey.aspx (http://www.dortmundfcshop.com/c-14-christian-pulisic-fc-borussia-dortmund-jersey.aspx) . In the days leading up to the draft, TSN.ca and TSN Radio basketball analyst Duane Watson looks at some of the names that will be headlining the event. Tonight, Michigans Nik Stauskas of Mississauga, Ontario.Minnesota Wild forward Matt Cooke has been suspended seven games for kneeing Colorado Avalanche defenceman Tyson Barrie during Game 3 of their series on Monday. If the suspension is not fully served in this years playoffs, it will continue on next season. The Avalanche have a 2-1 series lead on the Wild with Game 4 on Thursday. Cooke has 48 hours to appeal the decision, first to NHL commissioner Gary Bettman then if Bettman upholds six games or more, he then has seven days to file an appeal to a neutral arbitrator. The incident oc! curred i n the second period when Cooke and Barrie were involved in a knee-on-knee collision. The suspension is the sixth of Cookes career. After the incident he was assessed a two-minute minor for kneeing. Coach Patrick Roy said after the Wilds 1-0 overtime win thaat Barrie has a medial collateral ligament injury in his left knee and will need four to six weeks to recover. Hendrik Bonmann Dortmund Jersey (http://www.dortmundfcshop.com/c-25-hendrik-bonmann-fc-borussia-dortmund-jersey.aspx). The offer of an in-person hearing gave the NHL the right to suspend Cooke for five games or more. Barrie was one of Colorados best offensive blueliners, with 13 goals and 25 assists in the regular season. Matt Cookes Suspension History: Feb. 19, 2004: 2 games - Spearing (Matt Johnson, MIN)Jan. 20, 2009: 2 games - Illegal check to head (Scott Walker, CAR)Nov. 28, 2009: 2 games - Illegal check to head (Artem Anisimov, NYR)Feb. 8, 2011: 4 games - Hit from behind (Fedor Tyutin, CBJ)March 20, 2011: 17 games (10 regular season and first round of playoffs) - Elbow to the head (Ryan McDonagh, NYR)April 23, 2014: 7 games - Kneeing (Tyson Barrie, COL) Cheap NFL Jerseys (http://www.cheapjerseysstitchedshop.com/) Wholesale Jerseys (http://www.wholesalejerseyssafestore.com/) Wholesale NFL Jerseys (http://www.wholesalechinastitchedjerseys.com/) Jerseys From China (http://www.wholesalenflcheapjerseyschina.us.com/) Wholesale NFL Jerseys (http://www.chinanflonlinejerseys.com/) Cheap NFL Jerseys (http://www.cheapsoccerjerseyschinaonline.com/) Cheap Jerseys (http://www.cheapnbajerseyschinastore.com/) ' ' ' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464822#464822 ________________________________________________________________________________
Subject: Author: Blueberry
Date: Jan 07, 2017
Dear Mr Dralle Is anything being done about the non relevant emails emanating from 'Blueberry' Regards: John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464823#464823 ________________________________________________________________________________
Subject: Re: Author: Blueberry
Date: Jan 07, 2017
It seems part of the Matronics subscriber list has been leaked or harvested a number of years ago, and this results in spam every now and then. I'm not getting any spam from Blueberry so it's not coming through the Matronics site itself. But I do get spam from other sources. As I use a unique email address for Matronics, I can tell that that address has been leaked or harvested at some point. Our addresses are now in spammer databases and there's very little you can do about it. Matt can't help, Bob can't help. All you can do is use unique email addresses per subscription, and if the spam level becomes annoying for that address, just toss that email address and use a new one. I have my own domain, so it's just a matter of setting up a new alias. Rob On 1/7/2017 9:34 AM, JOHN TIPTON wrote: > > Dear Mr Dralle > > Is anything being done about the non relevant emails emanating from 'Blueberry' > > Regards: John > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=464823#464823 > > ________________________________________________________________________________
Date: Jan 07, 2017
Beg to differ, Rob. It's very recent - i've only been a subscriber for a month or two and I'm getting them. And it's 99% certain it's all coming directly through the list server judging by the headers and signature. No spammer would bother spoofing all that information. On Jan 7, 2017, at 04:22, Rob Turk wrote: It seems part of the Matronics subscriber list has been leaked or harvested a number of years ago, and this results in spam every now and then. I'm not getting any spam from Blueberry so it's not coming through the Matronics site itself. But I do get spam from other sources. As I use a unique email address for Matronics, I can tell that that address has been leaked or harvested at some point. Our addresses are now in spammer databases and there's very little you can do about it. Matt can't help, Bob can't help. All you can do is use unique email addresses per subscription, and if the spam level becomes annoying for that address, just toss that email address and use a new one. I have my own domain, so it's just a matter of setting up a new alias. Rob > On 1/7/2017 9:34 AM, JOHN TIPTON wrote: > > Dear Mr Dralle > > Is anything being done about the non relevant emails emanating from 'Blueberry' > > Regards: John > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=464823#464823 > > > > > > > > > > ________________________________________________________________________________
Date: Jan 07, 2017
In fact here's the archived spam on the list server website, as proof it's c oming brought the server: http://forums.matronics.com/viewtopic.php?p=464821#464821 On Jan 7, 2017, at 06:45, Alec Myers wrote: Beg to differ, Rob. It's very recent - i've only been a subscriber for a mon th or two and I'm getting them. And it's 99% certain it's all coming directly through the list server judgin g by the headers and signature. No spammer would bother spoofing all that in formation. On Jan 7, 2017, at 04:22, Rob Turk wrote: It seems part of the Matronics subscriber list has been leaked or harvested a number of years ago, and this results in spam every now and then. I'm not g etting any spam from Blueberry so it's not coming through the Matronics site itself. But I do get spam from other sources. As I use a unique email addre ss for Matronics, I can tell that that address has been leaked or harvested a t some point. Our addresses are now in spammer databases and there's very li ttle you can do about it. Matt can't help, Bob can't help. All you can do is use unique email addresses per subscription, and if the sp am level becomes annoying for that address, just toss that email address and use a new one. I have my own domain, so it's just a matter of setting up a n ew alias. Rob > On 1/7/2017 9:34 AM, JOHN TIPTON wrote: ld.com> > > Dear Mr Dralle > > Is anything being done about the non relevant emails emanating from 'Blueb erry' > > Regards: John > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=464823#464823 > > > > > > > > > > ========================== ======== ========================== ======== ========================== ======== ========================== ======== ========================== ======== ________________________________________________________________________________
Date: Jan 07, 2017
I guess my provider filters it as spam then, as I have zero entries for Blueberry anywhere in my mails. On 1/7/2017 12:48 PM, Alec Myers wrote: > In fact here's the archived spam on the list server website, as proof > it's coming brought the server: > http://forums.matronics.com/viewtopic.php?p=464821#464821 > > On Jan 7, 2017, at 06:45, Alec Myers > wrote: > > Beg to differ, Rob. It's very recent - i've only been a subscriber for > a month or two and I'm getting them. > > And it's 99% certain it's all coming directly through the list server > judging by the headers and signature. No spammer would bother spoofing > all that information. > > ________________________________________________________________________________
Date: Jan 07, 2017
Subject: Re: Rotax 912iS questions
>> So, getting back to the original questions >> on switches . . . ANYTHING B&C sells in the >> way of switches is entirely adequate to >> the task. > >So can we consider there is no problem bringing the two permanent 10 >amp pump wires and the two 7.5 amp "lane" wires to the panel ? Sure . . . I wouldn't add relays to the system to keep panel currents low. This just drives up parts count and offers little if any benefit. Bob . . . --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jan 07, 2017
Hi Rob Are you saying that when you view they 'aeroelectric list forum' you do not s ee the posts from 'blueberryjerry' either John Sent from my iPad ----x--O--x---- > On 7 Jan 2017, at 01:04 pm, Rob Turk wrote: > > I guess my provider filters it as spam then, as I have zero entries for Bl ueberry anywhere in my mails. > >> On 1/7/2017 12:48 PM, Alec Myers wrote: >> In fact here's the archived spam on the list server website, as proof it' s coming brought the server: >> http://forums.matronics.com/viewtopic.php?p=464821#464821 >> >> On Jan 7, 2017, at 06:45, Alec Myers wrote: >> >> Beg to differ, Rob. It's very recent - i've only been a subscriber for a m onth or two and I'm getting them. >> >> And it's 99% certain it's all coming directly through the list server jud ging by the headers and signature. No spammer would bother spoofing all that information. > ________________________________________________________________________________
Date: Jan 07, 2017
Same question about the courtesy car app spam. Sebastien > On Jan 7, 2017, at 00:34, JOHN TIPTON wrote: > > > Dear Mr Dralle > > Is anything being done about the non relevant emails emanating from 'Blueberry' > > Regards: John > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=464823#464823 > > > > > > > > > ________________________________________________________________________________
Date: Jan 07, 2017
I've been receiving those too, with Aeroelectric headers... -----Original Message----- From: JOHN TIPTON Sent: Saturday, January 07, 2017 3:34 AM Subject: AeroElectric-List: Author: Blueberry Dear Mr Dralle Is anything being done about the non relevant emails emanating from 'Blueberry' Regards: John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464823#464823 ________________________________________________________________________________
Date: Jan 07, 2017
Hi John, I never visit the forum online, I receive the emails in my inbox. No trace of any blueberry or related sender there. Rob On 1/7/2017 3:26 PM, John Tipton wrote: > Hi Rob > > Are you saying that when you view they 'aeroelectric list forum' you > do not see the posts from 'blueberryjerry' either > > John > > Sent from my iPad > > ----x--O--x---- > > On 7 Jan 2017, at 01:04 pm, Rob Turk > wrote: > >> I guess my provider filters it as spam then, as I have zero entries >> for Blueberry anywhere in my mails. >> >> On 1/7/2017 12:48 PM, Alec Myers wrote: >>> In fact here's the archived spam on the list server website, as >>> proof it's coming brought the server: >>> http://forums.matronics.com/viewtopic.php?p=464821#464821 >>> >>> On Jan 7, 2017, at 06:45, Alec Myers >> > wrote: >>> >>> Beg to differ, Rob. It's very recent - i've only been a subscriber >>> for a month or two and I'm getting them. >>> >>> And it's 99% certain it's all coming directly through the list >>> server judging by the headers and signature. No spammer would bother >>> spoofing all that information. >>> >>> >>> >> ________________________________________________________________________________
Date: Jan 07, 2017
/Le 07/01/2017 14:49, Robert L. Nuckolls, III a crit :// / >> / >> So can we consider there is no problem bringing the two permanent 10 >> amp pump wires and the two 7.5 amp "lane" wires to the panel ? >> / > / > Sure . . . I wouldn't add relays to the > system to keep panel currents low. This > just drives up parts count and offers > little if any benefit./ Bob and all, Thank you. Attached is a drawing of how I understand the Rotax schematics. Hope it'll get through. At least it helps me better understand the starting sequence (5 switches in addition to the master switches and start button). Please feel free to comment and point me to errors. Thanks for everything, -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Date: Jan 07, 2017
So you think 'blueberryjerry' is a member, however if this was moderated more efficiently this would have been picked up sooner, i don't think the fund raising/charity thing has anything to do with it Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464850#464850 ________________________________________________________________________________
Date: Jan 07, 2017
On Sat, Jan 7, 2017 at 2:47 PM, JOHN TIPTON wrote: > jmtipton(at)btopenworld.com> > > So you think 'blueberryjerry' is a member, however if this was moderated > more efficiently this would have been picked up sooner, i don't think the > fund raising/charity thing has anything to do with it > I'll assume you're referring to my recent post, though I can't tell for sure since I get the list via email and if you don't quote at least part of the post you're responding to, none of us on the email server can tell who you're responding to. My point is that if all you do is suck from the teat, you've no right to complain about what the cow eats. (In case you've never been outside the city limits, that's where milk actually comes from.) The fund raiser isn't a charity. It's intended to help Matt cover his expenses running this, and a lot of other lists/forums. In case you haven't noticed, there's no advertising in these lists or the forums; not even for the products that Matt produces and sells. If you think about it, a handful of spam emails is noteworthy only because of its rarity here. Kinda like the news media focusing on every a/c crash, when thousands of car crashes happen every day. You can't post here without being a member. I can testify to that, because I've accidentally tried to post from one of my other email addresses in the past, and I just tested it again a few minutes ago. See below for the response from Matt's server. Charlie quote: Matronics Email Lists 3:05 PM (7 minutes ago) Reply to me >------------------- >--- >--- "Poster: xxxxxxxxxxxx(my other email address) >--- "Subject: test from non member address" >--- >--- Your message was not posted to the AeroElectric-List because the >--- poster is not a member of any Email List on the Matronics Email >--- System. >--- >--- Note that this check can be triggered in some cases where your >--- your message's From: address isn't an *exact* match to the email >--- address that is subscribed. An example of this might be where >--- you are subscribed to a List as: >--- >--- "joe(at)internet.com" >--- >--- but your email message's From: line shows your address as: >--- >--- "joe(at)email.internet.com" >--- >--- While these may be functionally the same email address, there is >--- no way for the receiving email system to determine that they are >--- in fact actually the same address. >--- >--- To ressolve this issue, please either change your email >--- applications's configuration so that your From: line matches the >--- email address you have subscribed as, or go to the Subscription >--- Web Site and unsubscribe your old email address an subscribe >--- your actual email address. >--- >--- The Matronics Email List Subscription Web Page can be found at: >--- >--- http://www.matronics.com/subscribe >--- >--- >--- Your message contained the following headers: >--- >--- > From: xxxxxxxxxxxxxx >--- > Date: Sat, 7 Jan 2017 15:05:41 -0600 >--- > Subject: test from non member address >--- > To: aeroelectric-list(at)matronics.com >--- >------------------- unquote ________________________________________________________________________________
Subject: Return of the Rotax 912/914 PM alternator
Date: Jan 07, 2017
Hi all, From time to time someone raises the Rotax 912/914 alternator subject. Maybe some here will remember that many moons ago we conducted an in-depth study of the Rotax alternator and voltage regulator electrical and thermal performance : http://contrails.free.fr/elec_ducati_en.php Two days ago I paid a visit to the electricity lab where we performed our tests 13 years ago and gess what, there lay "my" alternator, among other DC machines, dynamos and motors. The alternator is now back in my garage again, ready for any additional (static) tests... -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Date: Jan 07, 2017
So: 'blueberryjerry' is a member, but no-one can suspend/block his posts Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464853#464853 ________________________________________________________________________________
Date: Jan 07, 2017
On 1/7/2017 3:32 PM, JOHN TIPTON wrote: > > So: 'blueberryjerry' is a member, but no-one can suspend/block his posts > Sure. You can. Just mark his emails as spam in your email client. ________________________________________________________________________________
Date: Jan 08, 2017
/Le 07/01/2017 20:29, GTH a crit : / > / > Please feel free to comment and point me to errors./ Hi all, Sorry, I just found a mistake : the starter contactor was misplaced ;-( Here is a more correct version. -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Date: Jan 07, 2017
Hey guys, I don't know the details, but these messages are being posted on the forum. Not sure if they are being posted from a hijacked email address or they're being posted through email. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464857#464857 Attachments: http://forums.matronics.com//files/matronics_871.jpg ________________________________________________________________________________
Date: Jan 07, 2017
Hey guys, These messages are appearing on the forum as well. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464858#464858 Attachments: http://forums.matronics.com//files/matronics_118.jpg ________________________________________________________________________________
Date: Jan 07, 2017
Please, just let it go. If you must tell someone; tell Matt, to be sure he's seen it. The rest of us know that posts to the email list go to the forum, and also that posts to the forum go to the list. We've gotten more spam from legit list members the last couple of days, than from the spammer. :-) Charlie On 1/7/2017 9:17 PM, donjohnston wrote: > > Hey guys, > > These messages are appearing on the forum as well. > > ________________________________________________________________________________
Subject: Relay failure modes
Date: Jan 08, 2017
Hi all, Is there such a thing as a typical, or most likely relay failure mode ? For instance "failure to operate when the coil is energized", "uncommanded contact opening", etc. ? We are speaking of "ordinary" relays. Let's say we have a load permanently connected to the normally closed contacts, and the relay is occasionally energized to open the circuit. Is failure likeliness on the same order as that of the contacts of a switch, for instance ? Or does such a relay significantly impair the circuit reliability vs an ordinary switch ? Thanks in advance for any facts or opinions, -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Date: Jan 08, 2017
Hello Charlie >From the way you are bashing John and other people who are complaining about the spam, it seems you are defending the spammer himself. They are just asking for Matt to take care of this spam, we all recognise the utility of this list and Matt's work. Like you recommend to others, just let it go. Hit the delete key not only when you receive the spam but also when you receive the complaints about the spam. End of rant! Let's talk about Electrics Cheers Carlos Enviado do meu iPhone No dia 08/01/2017, s 03:42, Charlie England escreveu: > > Please, just let it go. > > If you must tell someone; tell Matt, to be sure he's seen it. The rest of us know that posts to the email list go to the forum, and also that posts to the forum go to the list. > > We've gotten more spam from legit list members the last couple of days, than from the spammer. :-) > > Charlie > >> On 1/7/2017 9:17 PM, donjohnston wrote: >> >> Hey guys, >> >> These messages are appearing on the forum as well. >> >> > > > > ________________________________________________________________________________
Date: Jan 08, 2017
Subject: Hot alternator
Good morning guys I am still doing the electrical installation of my bird, and sometimes I turn on the Master Switch to check if everything is working well with the last installed critter. This time, after finishing the wiring of an electronic Carbon Monoxide detector, I turned On the Master (together with the Main Alt field) to check if the CO alarm 2-colour Led would lit as advertised, first a blinking green and after 2 minutes the steady green. All went well, except that I forgot to turn Off the Master (and Alt field), and they kept On for perhaps 15 or 20 minutes, while I was working on the Engine baffles... Then, I noticed that the Main Alternator was really hot to the touch, which reminded me to turn Off the Master switch. Long story to ask the question: is this normal? If the Master switch (and the Alt field switch) is On for some time, even with the engine Off, the Alt gets that hot? Why? Carlos P.S. - perhaps you'll need some more information about my electric system architecture... ________________________________________________________________________________
Subject: Re: Hot alternator
Date: Jan 08, 2017
It is normal for an older internally regulated 40 amp nippondenso. They aren't "smart enough" to sense rotation so they draw a couple of amps into the field coil when stopped and get noticeably warm. Ken On 08/01/2017 6:08 AM, Carlos Trigo wrote: > > Good morning guys > > I am still doing the electrical installation of my bird, and sometimes I turn on the Master Switch to check if everything is working well with the last installed critter. > > This time, after finishing the wiring of an electronic Carbon Monoxide detector, I turned On the Master (together with the Main Alt field) to check if the CO alarm 2-colour Led would lit as advertised, first a blinking green and after 2 minutes the steady green. > All went well, except that I forgot to turn Off the Master (and Alt field), and they kept On for perhaps 15 or 20 minutes, while I was working on the Engine baffles... > > Then, I noticed that the Main Alternator was really hot to the touch, which reminded me to turn Off the Master switch. > > Long story to ask the question: is this normal? If the Master switch (and the Alt field switch) is On for some time, even with the engine Off, the Alt gets that hot? > > Why? > > Carlos > > P.S. - perhaps you'll need some more information about my electric system architecture... > > ________________________________________________________________________________
Date: Jan 08, 2017
[quote="ceengland7(at)gmail.com"]Please, just let it go. If you must tell someone; tell Matt, to be sure he's seen it. The rest of us know that posts to the email list go to the forum, and also that posts to the forum go to the list. We've gotten more spam from legit list members the last couple of days, than from the spammer. :-) Charlie On 1/7/2017 9:17 PM, donjohnston wrote: [quote] Hey dude, I was just trying to help. I saw all this talk about email and figured I would mention that it was also on the forum. Sorry if my attempt to help bothered you. I won't make that mistake again. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464865#464865 ________________________________________________________________________________
Subject: Re: Relay failure modes
Date: Jan 08, 2017
My experience: Most common relay failure mode by far is failure to "set" - whether by mechanical or electrical failure inside the relay, the contacts fail to open or close as designed when current is applied to the coil. Often begins manifesting itself as intermittent operation (sometimes works, sometimes not). Second to that is not an actual relay failure, but a failure in the installation. The result is the same (failure of the relay to actuate), but the cause is usually a wiring or mechanical fault introduced by the person that installed it. Bad soldering, incorrectly terminated wires, insufficient ground, not securing plug-in type relays, etc. Also often begins with intermittent operation. Third and low in percentage of failures would be failure of the relay to "reset" after the coil current was removed (stuck "on"). Can't say as I've ever seen a relay actuate without input to the coil. Whenever I've run across a relay that's actuating when it's not supposed to be, it's always been a fault in the controlling circuit. I suppose it's possible under high g or heavy vibration to mechanically move the contacts. Chuck On Jan 8, 2017, at 4:03 AM, GTH wrote: Hi all, Is there such a thing as a typical, or most likely relay failure mode ? For instance "failure to operate when the coil is energized", "uncommanded contact opening", etc. ? We are speaking of "ordinary" relays. Let's say we have a load permanently connected to the normally closed contacts, and the relay is occasionally energized to open the circuit. Is failure likeliness on the same order as that of the contacts of a switch, for instance ? Or does such a relay significantly impair the circuit reliability vs an ordinary switch ? Thanks in advance for any facts or opinions, -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Date: Jan 08, 2017
Please, just let it go. If you must tell someone; tell Matt, to be sure he's seen it. - - - - - Well, I guess that brings us full circle: if you see the original post it was addressed only to 'Matt' (but silence) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464868#464868 ________________________________________________________________________________
Date: Jan 08, 2017
Ken Mine is also internally regulated but is an all new PlanePower 60A CT Enviado do meu iPhone No dia 08/01/2017, s 12:37, C&K escreveu: > > It is normal for an older internally regulated 40 amp nippondenso. They aren't "smart enough" to sense rotation so they draw a couple of amps into the field coil when stopped and get noticeably warm. > Ken > >> On 08/01/2017 6:08 AM, Carlos Trigo wrote: >> >> Good morning guys >> >> I am still doing the electrical installation of my bird, and sometimes I turn on the Master Switch to check if everything is working well with the last installed critter. >> >> This time, after finishing the wiring of an electronic Carbon Monoxide detector, I turned On the Master (together with the Main Alt field) to check if the CO alarm 2-colour Led would lit as advertised, first a blinking green and after 2 minutes the steady green. >> All went well, except that I forgot to turn Off the Master (and Alt field), and they kept On for perhaps 15 or 20 minutes, while I was working on the Engine baffles... >> >> Then, I noticed that the Main Alternator was really hot to the touch, which reminded me to turn Off the Master switch. >> >> Long story to ask the question: is this normal? If the Master switch (and the Alt field switch) is On for some time, even with the engine Off, the Alt gets that hot? >> >> Why? >> >> Carlos >> >> P.S. - perhaps you'll need some more information about my electric system architecture... >> >> >> >> >> >> >> >> > > > > ________________________________________________________________________________
Date: Jan 08, 2017
My PlanePower has been hot enough to leave a blister. After some cursing, I got in the habit of pulling the field breaker if I have the battery on for any length of time. The regulator is trying in vain to raise the output voltage. I assume it runs as much current as it can through the field, but of course it gets no results. --Dave On Sun, Jan 8, 2017 at 5:57 AM, Carlos Trigo wrote: > trigo(at)mail.telepac.pt> > > Ken > > Mine is also internally regulated but is an all new PlanePower 60A > > CT > > Enviado do meu iPhone > > No dia 08/01/2017, =C3-s 12:37, C&K escreveu: > > > > > It is normal for an older internally regulated 40 amp nippondenso. They > aren't "smart enough" to sense rotation so they draw a couple of amps int o > the field coil when stopped and get noticeably warm. > > Ken > > > >> On 08/01/2017 6:08 AM, Carlos Trigo wrote: > trigo(at)mail.telepac.pt> > >> > >> Good morning guys > >> > >> I am still doing the electrical installation of my bird, and sometimes > I turn on the Master Switch to check if everything is working well with t he > last installed critter. > >> > >> This time, after finishing the wiring of an electronic Carbon Monoxide > detector, I turned On the Master (together with the Main Alt field) to > check if the CO alarm 2-colour Led would lit as advertised, first a > blinking green and after 2 minutes the steady green. > >> All went well, except that I forgot to turn Off the Master (and Alt > field), and they kept On for perhaps 15 or 20 minutes, while I was workin g > on the Engine baffles... > >> > >> Then, I noticed that the Main Alternator was really hot to the touch, > which reminded me to turn Off the Master switch. > >> > >> Long story to ask the question: is this normal? If the Master switch > (and the Alt field switch) is On for some time, even with the engine Off, > the Alt gets that hot? > >> > >> Why? > >> > >> Carlos > >> > >> P.S. - perhaps you'll need some more information about my electric > system architecture... > >> > >> > >> > >> > >> > >> > >> > >> > > > > > > > > > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Jan 08, 2017
And there's no cooling airflow (does it have a shaft mounted fan? That's not turning) > On Jan 8, 2017, at 9:36 AM, David Saylor wrote: > > My PlanePower has been hot enough to leave a blister. After some cursing , I got in the habit of pulling the field breaker if I have the battery on f or any length of time. > > The regulator is trying in vain to raise the output voltage. I assume it r uns as much current as it can through the field, but of course it gets no re sults. > > --Dave > >> On Sun, Jan 8, 2017 at 5:57 AM, Carlos Trigo wrot e: .pt> >> >> Ken >> >> Mine is also internally regulated but is an all new PlanePower 60A >> >> CT >> >> Enviado do meu iPhone >> >> No dia 08/01/2017, =C3-s 12:37, C&K escreveu: >> >> > >> > It is normal for an older internally regulated 40 amp nippondenso. They aren't "smart enough" to sense rotation so they draw a couple of amps into t he field coil when stopped and get noticeably warm. >> > Ken >> > >> >> On 08/01/2017 6:08 AM, Carlos Trigo wrote: pac.pt> >> >> >> >> Good morning guys >> >> >> >> I am still doing the electrical installation of my bird, and sometimes I turn on the Master Switch to check if everything is working well with the last installed critter. >> >> >> >> This time, after finishing the wiring of an electronic Carbon Monoxide detector, I turned On the Master (together with the Main Alt field) to chec k if the CO alarm 2-colour Led would lit as advertised, first a blinking gre en and after 2 minutes the steady green. >> >> All went well, except that I forgot to turn Off the Master (and Alt fi eld), and they kept On for perhaps 15 or 20 minutes, while I was working on t he Engine baffles... >> >> >> >> Then, I noticed that the Main Alternator was really hot to the touch, w hich reminded me to turn Off the Master switch. >> >> >> >> Long story to ask the question: is this normal? If the Master switch ( and the Alt field switch) is On for some time, even with the engine Off, the Alt gets that hot? >> >> >> >> Why? >> >> >> >> Carlos >> >> >> >> P.S. - perhaps you'll need some more information about my electric sys tem architecture... >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> > >> > >> > >> > >> >> >> ========================= >> - >> Electric-List" rel="noreferrer" target="_blank">http://www.matronics. com/Navigator?AeroElectric-List >> ========================= >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========================= >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ========================= >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contributio n >> ========================= >> >> >> > ________________________________________________________________________________
Date: Jan 08, 2017
It takes a lot more magnetic force to pull a relay armature in than it does to hold it in the pulled position. In fact, just residual magnetism in the coil core could be enough to hold the armature pulled in, even after the coil has been de-energized. To prevent that, a thin layer of non-magnetic material is bonded to the armature. If that thin layer wears away or falls out, the relay could remain in the pulled-in position after the coil has been de-energized. At work many years ago, a machine operator complained that a 5 HP, 3 phase, 480 volt motor started up all by itself after he had previously shut it off. Another electrician verified the operators observation, but could not find the problem. He asked me to help. It turns out that the motor did not actually stop running. But it appeared that it did because the run-indicator light went out when the operator pressed the stop button. I measured the coil voltage of the 3 phase contactor and it was zero. So the contactor never pulled in all by itself for no reason, it just never dropped out. Replacing the contactor fixed the problem. Examining the contactor back in the shop, it repeatedly stuck closed when manually pulled in. I do not know if was residual magnetism or atmospheric pressure (like a suction cup) that held the large area mating surfaces together. The mating surfaces were slightly oily. This was a highly unusual failure. I only saw it happen that one time. So yes, it is possible for relays to get stuck in the closed position. But it is not very common. If I wanted to use relays in my airplane, I would not let fear of relay failure deter me. A relay is less likely to fail than the fuel system is. If the relay controls a critical circuit, then have a backup plan. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464873#464873 ________________________________________________________________________________
Date: Jan 08, 2017
Gilles, Often the failure of a relay can be traced to a design choice. On a single pole relay the most common failure modes (in no special order); Open coil (won't pick) Shorted coil (blows fuses) Welded contact (fails to break) Contact fails to make (dirt) Mechanical binding Relays are generally used to drive loads greater than the rating of the switch piloting the relay or when multiple signals (poles) are needed. Comparing equally rated switches and relays, one disadvantage of a relay is that it adds one more step to the process, a power failure in the coil circuit and it won't pick. Other than that, It doesn't matter if you use a switch or a relay, it's more important that the device you choose meets the requirements of the circuit. A properly selected relay or switch will likely last then life of the design, trouble free. When choosing a contact, bigger isn't better. As an extreme example, don't use a contactor in a telecom circuit. Also, not all loads are equal, when driving an inductive load, mange the kickback and de-rate, when driving lamps, cold filament can be 10 times rated lamp current. Mike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464874#464874 ________________________________________________________________________________
Date: Jan 08, 2017
Vern Little has lots of relays in his plane. Below is a link to his electrical schematic. http://www.vx-aviation.com/sprocket/photos/panel_elec/schematics/Rocket_electrical-C1.sch -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464875#464875 ________________________________________________________________________________
Subject: RV8 Elec schematic.
Date: Jan 08, 2017
Not many comments, haven't spent very long looking, sorry if I haven't understood how some stuff works. 4 AWG is a little large from Battery relay to main bus, could be smaller. Could add circuit protection into starter button feed. Size of fuses/breakers seems odd. Suggest standardise by wire size, for example, 22g = 5A, 20g = 7.5A, 18g = 10A, 16g = 15A Do you really need 14g for the pitot? Pmags need 5A fuses/breakers, I think. GTR225 probably takes > 1A on transmit? Do you need a relay on the emerg batt feed? A switch could handle the likely currents. I would include an aux socket in the cockpit. You do not show a trim motor? A voltmeter on the main bus would be useful. Why ground the starter relay to the engine? If it is mounted on the firewall just use that. Load analysis is a little high - 78A continuous is too high for a 60A alternator, battery will be flat very quickly. But too many loads are included. Do not include momentary loads, for example, flaps, radio transmit, trim. Also relay loads not included (main relay often ~ 1A)? Spreadsheet for loads often easier. Joe has raised a few issues I was going to mention. Peter From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Roger Sherriff Sent: 06 January 2017 22:46 Subject: AeroElectric-List: RV8 Elec schematic. Hello All, Sharpen your knives. I am the novice of novices and have strayed well out of my expertise and comfort zone and attempted to design an electrical system for my RV8. I have read the electrical bible (thank you Mr. Nuckolls) and used a combination of figure Z-10/8 and Z-11 as a guide. Attached schematics are a representation of my understanding. I'd prefer not to have a hot battery bus or add a second alternator. Although IFR capable, it will be flown VFR or VMC most of the time. The system will run off a plane power 60A alt with built in OV and Voltage regulation. Engine is using 2 PMAG's and mechanical fuel injection. Main battery will probably go in the forward baggage compartment and the emergency battery location is yet tbd. Probably aft. Some consumers on the busses will use breakers and some will use fuses. The philosophy is to power the essential and emergency busses using the emergency battery during start. Primarily to get the avionics setup without the engine running and then protecting against a voltage drop during start. After start it will remain online and all busses are powered by the alternator while charging both batt's. Max 75% ALT load in cruise. Alternator fail- red light - (open emergency buss tie manually. I would like this to happen automatically but don't have the brainpower to design that yet, maybe later) will leave all busses powered by the main battery. All equipment on the main buss is switchable effectively leaving the essential buss powered by the main battery and emergency buss powered by the emergency battery. Following low volt on the main battery (2,5hrs health depending) the emergency battery powers emergency buss only. Max draw 1,5A so good for at least 3 hours (health depending) from start of alternator failure. Could I please ask for your expert advice and commentary on my design? Don't be polite, there are lives on the line.. Thank you in advance. Regards, Roger. p.s. I apologise if the schematic symbology details are not 100% correct. Still have to master the software. ________________________________________________________________________________
Date: Jan 08, 2017
What is an sch file? What app can open these? Peter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of user9253 Sent: 08 January 2017 16:02 Subject: AeroElectric-List: Re: Relay failure modes Vern Little has lots of relays in his plane. Below is a link to his electrical schematic. http://www.vx-aviation.com/sprocket/photos/panel_elec/schematics/Rocket_elec trical-C1.sch -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464875#464875 ________________________________________________________________________________
Date: Jan 08, 2017
Can open with ExpressSCH, free at expresspcb.com On Sun, Jan 8, 2017 at 6:20 PM, Peter Pengilly wrote: > Peter(at)sportingaero.com> > > What is an sch file? What app can open these? > > Peter > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of > user9253 > Sent: 08 January 2017 16:02 > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Re: Relay failure modes > > > Vern Little has lots of relays in his plane. Below is a link to his > electrical schematic. > > http://www.vx-aviation.com/sprocket/photos/panel_elec/ > schematics/Rocket_elec > trical-C1.sch > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=464875#464875 > > ________________________________________________________________________________
Date: Jan 08, 2017
Peter the software comes from Express PCB, *https://www .expresspcb.com/* *I've used it to do all my elementary drawings.* *Rick* *#40956* *Southampton, ont* On Sun, Jan 8, 2017 at 6:20 PM, Peter Pengilly wrote: > Peter(at)sportingaero.com> > > What is an sch file? What app can open these? > > Peter > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of > user9253 > Sent: 08 January 2017 16:02 > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Re: Relay failure modes > > > Vern Little has lots of relays in his plane. Below is a link to his > electrical schematic. > > http://www.vx-aviation.com/sprocket/photos/panel_elec/ > schematics/Rocket_elec > trical-C1.sch > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=464875#464875 > > ________________________________________________________________________________
Date: Jan 08, 2017
The Express.sch program is similar to Excel in that there can be more than one tab. After opening Vern Little's schematic, click on the various tabs at the bottom of the page. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464882#464882 ________________________________________________________________________________
Date: Jan 08, 2017
Has anyone used this on an iPad? On Jan 8, 2017 5:49 PM, "user9253" wrote: > > The Express.sch program is similar to Excel in that there can be more than > one tab. After opening Vern Little's schematic, click on the various tabs > at the bottom of the page. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=464882#464882 > > ________________________________________________________________________________
Date: Jan 08, 2017
At 04:03 AM 1/8/2017, you wrote: > >Hi all, > >Is there such a thing as a typical, or most likely relay failure mode ? > >For instance "failure to operate when the coil is energized", >"uncommanded contact opening", etc. ? We are speaking of "ordinary" relays. > >Let's say we have a load permanently connected to the normally >closed contacts, and the relay is occasionally energized to open the >circuit. Is failure likeliness on the same order as that of the >contacts of a switch, for instance ? Or does such a relay >significantly impair the circuit reliability vs an ordinary switch ? > >Thanks in advance for any facts or opinions, Relay failures are rare . . . as are switch failures. Relays are simply remotely operated switches having manual actuators replaced with electro-magnetic actuators. If one does measurement/analysis of contact performance and the effects of environmental stress for manual switches vs. electro-mechanical relays, they are virtually identical. Contacts are made from the same materials. They 'bounce' on closure. Contact erosion and tendency to 'stick' as a byproduct of metal-transfer in the electric arc are the same. The only failures I had occasion to study on TC aircraft had foundation in poor application of the relay to intended task. I worked one relay failure program on a bizjet that took several years of sand-sifting to identify root cause. The relays were being used in a very benign environment (pressurized cabin) and well within their electrical . . . but were known to 'stick'. Single sticks would disable a trim system. Double sticks would produce a trim runaway. Yet, all the 'failed' relays showed minimal wear and tear . . . and would test normally in a production test fixture. Relays are, as a class of product, no more prone to failure than their remote cousins on the panel. I have operated three vehicles to a cumulative total of more than 400K miles. All three machines have a dozen or more relays scattered about various systems. I've experienced a range of mechanical failures due to end of life wear out . . . but haven't replaced a single relay. Relays, like switches, have design lifetimes in the tens of thousands of operations at rated loads. Few relays in light aircraft see more than a few hundred cycles per year . . . and none are stressed to their maximum rated loads. We've studied some contactor failures due to manufacturing error . . . a few more due to electrical abuse (starter contactors down stream of a soggy battery). But for the most part, kept a cap-checked and charge battery installed and even that risk drops dramatically. Others were subject to moisture ingress due to location and poor choice of installation orientation. You are probably more likely to lose a relay's functionality due to a bad crimp on a mating terminal than from failure within the relay. The vast majority of failures I've investigated on heavier iron had simply reached the end of their service life . . . they were worn out. Bob . . . ________________________________________________________________________________
Date: Jan 08, 2017
> > >Then, I noticed that the Main Alternator was really hot to the >touch, which reminded me to turn Off the Master switch. > >Long story to ask the question: is this normal? If the Master switch >(and the Alt field switch) is On for some time, even with the engine >Off, the Alt gets that hot? Yes . . . this is quite normal. while the alternator is not rotating, battery-only bus voltage is so low that the regulator is full-fielding the alternator. Depending on the altenator, this can be as much as 3.5 amps at 12 volts for 42 watts of heat being generated inside with no place to go. This is why ALL of my architecture drawings show either a three position DC power master for OFF/BATT/ALT+BATT -or- a two-pole OFF/ON with a PULLABLE breaker associated with the crowbar ov protection system. It is a design goal to have independent control over the alternator during battery only operations. The non rotating alternator not only gets hot, it consumes energy from teh battery that would otherwise be available for ground test operations -or- battery only operations while airborne. Bob . . . ________________________________________________________________________________
Date: Jan 08, 2017
At 07:57 AM 1/8/2017, you wrote: > >Ken > >Mine is also internally regulated but is an all new PlanePower 60A Many, if not MOST internally regulated alternators are fitted with a stator phase sense connection to the regulator chip. Emacs! This signal tells the regulator whether or not the alternator is rotating so as to prevent full-fielding of the alternator is a quiescent state. No such provisions are available for most externally regulated alternators. Waaay back when, automotive alternators had a "AUX" teerminal that power the field control relay inside the regulator. This too effected field current shutdown while not rotating. Future regulators from our drafting table will be micro-controller based and will feature a full field limit timer that will prevent such events during ground testing or alternator failure while airborne. In the mean time, a pullable field breaker Emacs! . . . or three position DC PWR MASTER are recommended. Emacs! Bob . . . ________________________________________________________________________________
Subject: e defending champions. Keeping the game clos
From: "blueberryjerry" <blueberryjerry0822(at)hotmail.com>
Date: Jan 08, 2017
WINNIPEG - The Winnipeg Jets could be getting three key players back for Saturdays game against the Carolina Hurricanes. Eder Jersey (http://www.soccerportugalproshop.com/c-15-eder-portugal-jersey.aspx) . Coach Paul Maurice says he expects forwards Dustin Byfuglien and Jim Slater and defenceman Zach Bogosian to skate in the morning and hes fairly optimistic they will be able to dress for the game. All three missed Wednesdays game against the Colorado Avalanche, but the Jets still pulled a 5-4 overtime win out of the hat. Slater skated Friday and is also a new father, as his appropriately-named daughter Win was born Wednesday. Maurice says hed be making decisions about who plays after the morning skate. But the coach says goaltender Ondrej Pavelec isnt ready to return, although he may be able to play when the Jets face Dallas on Monday. Fabio Coentrao Portugal Jersey (http://www.soccerportugalproshop.com/c-3-fabio-coentrao-portugal-jersey.aspx) .com) - Willie Cauley-Stein and Karl-Anthony Towns each scored 12 points in the top-ranked Kentucky Wildcats 70-55 victory over the Alabama Crimson Tide. Eduardo Jersey (http://www.soccerportugalproshop.com/c-27-eduardo-portugal-jersey.aspx) . Granlund scored 2:04 into the first period. Max Reinhart, on his first NHL shift of the season, neatly stripped the puck from Zack Smith at the Senators blue-line. As he moved in, his attempted shot deflected into the slot where Granlund buried a shot past Craig Anderson. http://www.soccerportugalproshop.com/c-1-blank-portugal-jersey.aspx (http://www.soccerportugalproshop.com/c-1-blank-portugal-jersey.aspx) .ca presents its latest weekly power rankings for the 2013-14 Barclays Premier League season.Being long shots is nothing new for the Carolina Panthers. Carolina, 10.5-point underdogs to the Seattle Seahawks on Saturday, were ruled out of playoffs before December by most fans and media members. Yet, the Panthers reeled off four straight wins in December after a six-game losing skid and squeaked into the playoffs as NFC Sout! h champi ons. The Panthers season rarely lacked drama; a 37-37 tie against the Cincinnati Bengals proved key in their playoff berth and a car crash that forced quarterback Cam Newton to miss a crucial game in December. In a surprising turn of events, the Panthers entered their Wild Card matchup against the 11-5 - yet, heavily banged-up - Arizona Cardinals as six-point favourites. The Panthers covered the spread with a 27-16 victory and held the Cardinals to a post-season record 78 yards. However, the Panthers turned the ball over three times against the Cardinals, a stat line they will need to avoid against the much stronger Seattle Seahawks. Newton, who returned in Week 16 after missing one week with two back fractures due to the accident, threw one interception and lost a fumble against the Cardinals. Those things cant happen, Newton said after his first career playoff win, especially in playoff football. We cant expect to win when we have three turnovers. The 2011 first-overall pick struggled in many during the regular season, including against the Seahawks in Week 8, but has thrown seven touchdowns to two interceptions in his last four games. Newton has also rushed for 232 yards on 37 carries in that span an average of over six yards per carry. Newtons may need to put his legs on display once again against a Seahawks defence known for their ability to play the pass. With All-Pros Richard Sherman and Earl Thomas likely to be locked on Newtons top targets, wide receiver Kelvin Benjamin and tight end Greg Olsen, Newton may be forced to make plays on his known for the Panthers to have a chance. Benjamin and Olsen tied for the Panthers lead with 1,008 receiving yards, but will face a tough test against the Seahawks Legion of Boom secondary. The entire Carolina receiving core had a quiet day against the Panthers, but nine players made a catch in the win. Little used receiver Philly Brown and second-string tight end Ed Dickson each chipped in gains of 20 yards and running back Fozzy Whittaker s! cored a touchdown oon a 39-yard screen pass. Anthony Lopes Jersey (http://www.soccerportugalproshop.com/c-18-anthony-lopes-portugal-jersey.aspx). Though Browns status remains unclear for Saturday due to a shoulder injury, the Panthers will again need depth players to step up against a top defence. Though the Seahawks secondary attracts most of the attention, the teams stingy front seven make running the football also extremely difficult. Running back Jonathan Stewart has played a key role in the Panthers current win streak, and was one of the NFLs hottest back to close the season. In their matchup earlier this season, Stewart was able to gain 79 yards against the NFLs third-ranked run defence. He will look to better that mark in Seattle this time around. As a team, the Panthers gained 188 yards on the ground against the Cardinals in Wild Card weekend, a number unlikely to be reached this week. The Seahawks gave up more than 160 rushing yards twice this season, in losses to the Dallas Cowboys and Kansas City Chiefs. Coming off their historic performance, the Panthers will not have the benefit of matching up against a third string quarterback this week. Instead, the unit will take on the leagues top dual-threat quarterback this season in Russell Wilson. In their first matchup, Wilson threw for 199 yards with a touchdown and interception while rushing for 35 yards. Their success against Wilson and star running back Marshawn Lynch (14, 62 carries) will be something the improving group will hope to emulate. With their win over the Cardinals, the Panther became the sixth team to win a playoff game after finishing the regular season at .500 or worse and win a playoff game. Unfortunately for the Panthers, all five teams in that category before them have lost in the divisional round including the 2010 Seattle Seahawks. But recent history is not on the side of the Seahawks either. Coming Super Bowl wins, no defending champion has won a playoff game since the 2005 New England Patriots. That win came in t! he same playoffs as the Panthers and Seahawks only other playoff meeting. The Seahawks won that game 34-14 and this week will mark the first road playoff game the Panthers have played since. In their return to road postseason action and Seattle the Panthers are 10.5-underdogs to the defending champions. Keeping the game close will be of the utmost importance for the Panthers as they hope to keep their unlikely run towards to the Super Bowl alive. Cheap NFL Jerseys (http://www.cheapjerseysstitchedshop.com/) Wholesale Jerseys (http://www.wholesalejerseyssafestore.com/) Wholesale NFL Jerseys (http://www.wholesalechinastitchedjerseys.com/) Jerseys From China (http://www.wholesalenflcheapjerseyschina.us.com/) Wholesale NFL Jerseys (http://www.chinanflonlinejerseys.com/) Cheap NFL Jerseys (http://www.cheapsoccerjerseyschinaonline.com/) Cheap Jerseys (http://www.cheapnbajerseyschinastore.com/) ' ' ' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464888#464888 ________________________________________________________________________________
Subject: London, England (SportsNetwork.
Date: Jan 08, 2017
London, England (SportsNetwork. Chelsea Jersey (http://www.chelseafcsoccershop.com/) .com) - Liverpool will go in search of a rebound performance on Sunday when Brendan Rodgers men face Chelsea at Stamford Bridge. The Reds have been exceptional this season, leaning heavily on the attacking prowess of Luis Suarez, who leads the Premiership with 19 goals scored, and Daniel Sturridge, who has nine tallies. But the holiday period of fixtures was always sure to test the clubs top four credentials as they suffered a 2-1 defeat to Manchester City at the Etihad Stadium on Boxing Day. The Reds outplayed City for large portions of Thursdays match and opened the scoring when Philippe Coutinho found the back of the net from a tight angle in the 24th minute. City responded with an equalizer seven minutes later when Vincent Kompany outmuscled Martin Skrtel on a corner kick and nodded the ball down into the bottom right corner, past the outstretched arm of Liverpool goalkeeper Simon Mignolet. The winner came for City in first-half stoppage time when Alvaro Negredo slipped through on goal and hit one with the outside of his boot that Mignolet misplayed and it rolled into the net. Despite the loss, Rodgers praised his teams effort as they gave City their toughest test on home soil this season. "I was very proud of the players, I thought they were absolutely outstanding," Rodgers said. "They really took the game to a team that is a top, top side full of top European players. "Were disappointed not to have won the game, never mind losing the game. We showed great confidence and belief, scored a wonderful goal and could have had a few more. We have things to learn from the goals we conceded, which were disappointing. "I am very proud of the team. I was here at the Bayern Munich game when Bayern were outstanding, but apart from that every other team Manchester City have played here - really good sides as well - theyve scored a hatful of goals against. "Everybody walking away from the stadium would feel we at least deserved a! point f rom tonight - and were disappointed we havent won." Chelsea is coming a 1-0 Boxing Day victory over Swansea City as an Eden Hazard goal in the 28th minute was enough to allow the Blues to extend their unbeaten streak in league play to three matches. Jose Mourinhos strike force of Fernando Torres, Demba Ba, Willian and Samuel Etoo have struggled to score consistently, something that is beginning to wear on the Portuguese manager. "They kill me," Mourinho said. "Every game Im tired in the end. "At halftime we all should be relaxed with a comfortable result and we werent and the first thing that happens in the second half was probably the biggest chance of the game. "You dont score, you finish feeling you are going to concede. But the boys, they worked hard defensively and in the last part they looked comfortable in their control of the game." Also in the Premiership on Sunday, Everton will shoot for a bounce-back effort against Southampton at Goodison Park after suffering a shock 1-0 defeat to Sunderland on Thursday, while Newcastle United hopes to build on their best performance of the season -- a 5-1 destruction of nine-man Stoke City -- when they host Arsenal at St. James Park. In Sundays final fixture, Tottenham goes for a second win under manager Tim Sherwood when the club hosts Stoke City at White Hart Lane. On Saturday, West Ham United welcomes West Bromwich Albion to Upton Park following a 3-1 loss to Arsenal, while Aston Villa battles Swansea City at Villa Park. Hull City hosts relegation-battling Fulham at the KC Stadium, Manchester City faces Crystal Palace at the Etihad Stadium, Norwich City welcomes defending champions Manchester United to Carrow Road and Saturdays lunchtime fixture sees Cardiff City host Sunderland at the Cardiff City Stadium. John Terry Jersey (http://www.chelseafcsoccershop.com/c-20-john-terry-chelsea-fc-jersey.aspx) . Among the teams moves was trading one of the teams two third round picks, no. 83 overall, to the Chicago Blackhawks for Brandon Bollig, a six-foot-two, 223-p! ound lef t-winger who had seven goals, seven assists, and 92 penalty minutes in 82 games last season. Thibaut Courtois Chelsea Jersey (http://www.chelseafcsoccershop.com/c-11-thibaut-courtois-chelsea-fc-jersey.aspx) . -- Having already fallen behind because of the NFL lockout, Blaine Gabbert couldnt afford a lengthy holdout. http://www.chelseafcsoccershop.com/c-10-john-obi-mikel-chelsea-fc-jersey.aspx (http://www.chelseafcsoccershop.com/c-10-john-obi-mikel-chelsea-fc-jersey.aspx) . Murray, the defending champion and No. 3 seed, claimed his first match win at Queens in 2005 and went on to win the Wimbledon warmup three times. But he failed to take advantage of eight set points after leading the first-set tiebreaker 6-2, and Stepanek survived to convert with his second set point.KANSAS CITY, Mo. -- Struggling Billy Butler found himself in a strange place, on the bench and out of the Kansas City Royals starting lineup. But Butler was needed late on Friday night and he delivered a pinch two-run homer with two outs in the eighth inning to send the Royals over the Cleveland Indians 6-4 for their fourth straight win. Carlos Santana homered twice for the Indians, who have lost five of six. Butler connected against John Axford, sending a drive over the Royals bullpen in left field. Butler was hitting just .200 in his previous 20 games with three extra-base hits and two RBIs. "As of late, the production definitely is not there," said Butler, who entered this season with a career .298 average. "Over my career, its there, but this game is about what youve done for me lately. If he (manager Ned Yost) thinks a guy matching up differently is better for the team, thats what hes got to do. Hes got a job to do putting the lineup out there. "Its just my job to prove I belong in there. Ive been in the league a long time. If you give up and get put in a situation like that, you dont compete. Im not going to give up." The Royals won a game of matchup moves. After Salvador Perez singled with one out in the eighth off Carlos Carrasco (3! -4), Nic k Hagadone entered and got the second out. Butler batted for Raul Ibanez and homered on Axfords second pitch. "It does give you a shot of confidence," Butler said. "Ive got a lot of confidence with a bat in my hand anyway. It definitely helps. Hopefully, I build off that." Axford gave up the winning hit to Nori Aoki in the 14th inning in a 2-1 loss on Thursday. "Its obviously tough after the last two nights," Axford said. "It was just a bad pitch. I let it stay out over the plate. It was supposed to be away and it ended up in the seats." Earlier in the game, the 42-year-old Ibanez drove in a run -- beccoming the oldest Royals player to hit a triple. Thibaut Courtois Jersey (http://www.chelseafcsoccershop.com/c-11-thibaut-courtois-chelsea-fc-jersey.aspx). Ibanez scored on the play when second baseman Jason Kipnis made a wild relay throw. Kelvin Herrera (2-2) pitched a scoreless eighth, and Aaron Crow worked around a leadoff double in the ninth to earn his second save in four chances. Royals closer Greg Holland, who had pitched in the three previous games, was unavailable. Perez, who had three hits, and Mike Moustakas had back-to-back home runs to open the second. It was the second time this season Perez and Moustakas hit consecutive homers, having also done it April 23 at Cleveland. "We like hitting in the hot air," Perez said. Royals rookie Yordano Ventura, tagged for six runs and nine hits in 4 1/3 innings in his previous start at Boston, left after 6 1/3 innings. He gave up three earned runs and struck out seven. Santana hit a solo homer in the fourth and a two-run shot in the sixth. "The first home run to Santana, Ace threw a pretty good pitch, a sinker down and away," Perez said. "The second one was in the middle in and up." Indians right-hander Josh Tomlin, who was 1-5 in his previous seven starts, was pulled after 5 1/3 innings. "I thought when he made mistakes with his fastball they made him pay," Indians manager Terry Francona said. "But he always competes every time and keeps you in the game." N! OTES: RH P Jeremy Guthrie, a first-round pick of the Indians in the 2002 draft, will start Saturday against Cleveland. RHP Zack McAllister will start for the Indians. ... Cleveland RHP Justin Masterson, a 2013 All-Star who is on the disabled list with right knee inflammation, made his second rehab start Friday with Triple-A Columbus. He allowed five runs, four hits and six walks in 6 2/3 innings against Norfolk. . Butlers shot was the 75th pinch-homer in franchise history and the first since Justin Maxwell on Aug. 3, 2013. Cheap NFL Jerseys (http://www.cheapjerseysstitchedshop.com/) Wholesale Jerseys (http://www.wholesalejerseyssafestore.com/) Wholesale NFL Jerseys (http://www.wholesalechinastitchedjerseys.com/) Jerseys From China (http://www.wholesalenflcheapjerseyschina.us.com/) Wholesale NFL Jerseys (http://www.chinanflonlinejerseys.com/) Cheap NFL Jerseys (http://www.cheapsoccerjerseyschinaonline.com/) Cheap Jerseys (http://www.cheapnbajerseyschinastore.com/) ' ' ' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464889#464889 ________________________________________________________________________________
Subject: alls location, but said its premature to sug
Date: Jan 08, 2017
Sunrise, FL (SportsNetwork. Mateo Kovacic Jersey (http://www.realmadridfcproshop.com/authentic-mateo-kovacic-real-madrid-jersey/) .com) - P.A. Parenteau netted the lone marker in the shootout and Montreal overcame some late Florida heroics to post a 2-1 victory on Tuesday. Brendan Gallagher tallied in regulation for the Canadiens, who have won four in a row and tied idle Tampa Bay atop the Atlantic Division. Dustin Tokarski managed to stop 36 shots over the games first 65 minutes and all three chances in the breakaway rounds. This year hes been a rock, Gallagher said of Tokarski. Hes been very consistent when hes been in net, Nick Bjugstad provided the lone offense for the Panthers, who dropped the second game in their last six. Roberto Luongo took the loss despite 33 stops. You feel fortunate to get the one (point), but I thought we played well enough to win the hockey game, Panthers head coach Gerard Gallant said. Tokarski was 1:49 from a shutout when an defensive breakdown cost his club. Bjugstad was left alone up the middle to accept an Aaron Ekblad pass and score with a fluttering shot inside the right post. Hayes nearly ended the game inside of 10 seconds left in overtime, but his shot from the left side zipped through the crease without even touching iron. Price had accidentally sent a blind, backhanded clear up that side expecting one of his teammates. After Alex Galchenyuk and David Desharnais failed on their shots, Parenteau managed to sneak a wrister off the tip of Luongos glove to start the third round. Jonathan Huberdeaus final opportunity was deflected away by Tokarskis shoulder to end the contest. After several close calls by both teams for almost two-thirds of regulation, Gallagher finally netted the games first goal with 66 seconds in the middle period. He fired from the right wing, and the puck sailed between a Panthers defenders legs and squeezed through Luongos pads. Game Notes The Panthers have participated in a shootout in five of their last eight games ... Florida has recorded at l! east one point in 10 of its last 11 home contests (7-1-3) ... Montreal upped its defensive streak to eight straight games allowing two goals or fewer. Casemiro Jersey (http://www.realmadridfcproshop.com/authentic-casemiro-real-madrid-jersey/) . Blatter also told reporters Saturday after meeting with Qatars emir that the decision to award the tournament to the desert nation is "not reversible." There have been calls to move the tournament because of Qatars intense heat. Danilo Real Madrid Jersey (http://www.realmadridfcproshop.com/authentic-danilo-real-madrid-jersey/) . Last year, Islanders forward Colin Mcdonald released a "Do It For Colin" campaign to promote his teammate and friend John Tavares for the EA sports honour:The most popular sports voting video ever has to go to Chris Bosh who showcased his comedic abilities in his effort to get fans to vote him into the 2008 All Star Game:You can vote for TJ and other star players for the NHL 15 cover vote here. http://www.realmadridfcproshop.com/authentic-alvaro-morata-real-madrid-jersey/ (http://www.realmadridfcproshop.com/authentic-alvaro-morata-real-madrid-jersey/) . LOUIS -- The St. BUFFALO, N.Y. -- Dont rule out Niagara Falls as a potential future home of the Buffalo Bills. Several officials told The Associated Press that a newly formed Bills stadium task force of public and private leaders seeking to bolster the teams long-term viability is considering sites that would put it closer to the teams burgeoning Ontario fan base. "Were looking at Niagara County," Lt. Gov. Robert Duffy told the AP this week. "Were open to looking at a number of venues." Niagara Falls Mayor Paul Dyster confirmed Niagara County was discussed as an option during the inaugural meeting last week of the newly formed New Stadium Working Group committee. Duffy made clear "that all options should be on the table," Dyster said, adding that includes Niagara County and even Batavia, about halfway between Buffalo and Rochester. That goes beyond the groups initial directive, which was first limi! ted to s eeking potential stadium sites in Erie County, where Buffalo is located. Another idea is having the Bills relocate their headquarters to the University at Buffalo campus in the Erie County town of Amherst, where a new practice facility would be built and shared with the schools football team. That proposal would satisfy a long-term need for a Mid-American Conference program seeking to broaden its profile. Though not a member of the working group, New York state Sen. Tim Kennedy told the AP he is aware of the preliminary discussions tying the Bills and the school. A person familiar with the discussions confirmed the Bills/UB plan has been raised. That person wasnt authorized to publicly discuss the subjects raised in the private meeting and spoke to the AP on condition of anonymity. Duffy and Dyster are among 20 members of the stadium group, which was established to make recommendations on whether the Bills require a new facility or should continue playing at Ralph Wilson Stadium, their 41-year-old home in Orchard Park. The group was formed as part of a 10-year, $271-million lease agreement the team reached with the state and Erie County in December 2012. The groups role in helping determine the Bills future took on more significance after Ralph Wilson, the teams owner and founder, died on March 25. Wilsons widow, Mary Wilson, is now overseeing the team until the franchise is sold, which raises the possibility of the Bills relocating under a new owner. The Bills are essentially locked into playing at their current home through the 2019 season, because the lease features a $400 million penalty in the event the team broke it. In 2020, the Bills have a one-time opportunity to opt out of the lease ffor about $28 million. Raphael Varane Jersey (http://www.realmadridfcproshop.com/authentic-raphael-varane-real-madrid-jersey/). Toronto and Los Angeles are regarded potential suitors. The new owner will have final say on any stadium proposal. Its incumbent upon the working group, which includes U.S. Sen. Charles Sc! humer, t o present a framework of viable options that provide the best chance of keeping the team in western New York. "We have many very good tools to help that happen," Schumer told the AP. "I think there is a view that us showing early interest and the potential of a new home for the Bills is very helpful, because we want to show an owner that we want to do what it take to keep the Bills in Buffalo." Ralph Wilson Stadium is currently undergoing $130 million in upgrades. The work includes structural upgrades and adding fan amenities to bring the facility up to modern-day NFL standards. The Bills presence has been regarded as key in helping an economically hard-hit region maintain a national identity. As the NFLs only New York-based franchise, the team generates about $20 million in direct annual tax revenue for the state. Niagara Falls is 30 minutes closer by car than Orchard Park to a growing southern Ontario fan base. The Bills estimate Canadians make up about 18 per cent of their season-ticket base. Kennedy favours the proposal of linking the Bills and the university but is against a stadium site outside of Erie County. "The Buffalo Bills were born in Buffalo and should stay in Buffalo," Kennedy said. "At least in Erie County. If were talking about a new stadium Id like to see it built in Buffalo proper." Kennedy said a new stadium with a dome or a retractable roof could be part of a larger development, including a new convention centre. The new facility would boost efforts to re-energize downtown Buffalo, he said, and could even make the city a contender for hosting the Super Bowl, he said. Former Erie County Executive Joel Giambra said the southern Ontario market is critical to the Bills future. Giambra said Wilson discussed with him the possibility of the team playing home games in St. Catharines, Ontario, while maintaining its headquarters in New York. "They were aggressively trying to figure out how to tap that Canadian marketplace because of the economics," Giambra said. Dyster is aware of discussions ! regardin g the advantages of Niagara Falls location, but said its premature to suggest what recommendations might emerge. "The critical thing here is that we all have to come together as a region to make certain that we keep the Bills here," Dyster said. "If we lose the Bills, were all losers." Cheap NFL Jerseys (http://www.cheapjerseysstitchedshop.com/) Wholesale Jerseys (http://www.wholesalejerseyssafestore.com/) Wholesale NFL Jerseys (http://www.wholesalechinastitchedjerseys.com/) Jerseys From China (http://www.wholesalenflcheapjerseyschina.us.com/) Wholesale NFL Jerseys (http://www.chinanflonlinejerseys.com/) Cheap NFL Jerseys (http://www.cheapsoccerjerseyschinaonline.com/) Cheap Jerseys (http://www.cheapnbajerseyschinastore.com/) ' ' ' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464890#464890 ________________________________________________________________________________
Subject: es and Cameron Yarwood scored once. Drummondville (0-1)
got
Date: Jan 08, 2017
Happy birthday to Stephen Ames. Alvaro Morata Spain Jersey (http://www.soccerspainonline.com/Alvaro-Morata-UEFA-European-Spain-Jersey/) . And this is not just any birthday. Today, the Calgarian turns the big Five-Oh. So is the four-time winner on the PGA Tour happy about his big day? "Hell no. Its 50! Who wants to get there?" Ames chuckled in mock protest. "Actually, Im OK with it - its just a number." But its a big number, one that makes him eligible for the Champions Tour, that career mulligan circuit for the older set. He will make his official debut as an Old Guy on May 22 at the Senior PGA Championship, one of that tours five majors. "I look at it as being fortunate," Ames said, "because I have another place to play. Someone referred to it the other day as the back nine of my career. For me, it means I have 15 more years of golf and having fun with it and not having to worry about a job or a pay cheque coming in. Im pretty much set - its nice." Ames is ready to compete on the Champions Tour and thinks he can play well. Compared to many of the older guys, hes in great shape. His back problems that troubled him years ago havent been an issue for some time and in preparation for his move to the 50-and-over tour, hes lost 11 pounds. "Ive been working out hard," he said, "doing some hard cardio. Its not about weights for me, its cardio and all of a sudden the weight started dropping off. I was a size 35 pant and now Im slipping into 32s." Ames, who is being inducted into the Canadian Golf Hall of Fame later this year, has also been working hard on his game, adding some distance to his drives and concentrating on his scoring clubs. Those will come in handy on a tour where the courses are 7,000 yards as opposed to the 7,500 hes been playing. "I expect to play well," he stated. "The only difference is that instead of hitting 3-irons into greens, Ill be hitting 9-irons." After years of working with Sean Foley, Ames parted ways with the guy he brought to the PGA Tour last year. The two remain friendly but Ame! s found it hard to get time on Foleys busy schedule. So hes been seeing Calgary swing coach Paul Horton, and is happy with the new relationship. "The changes Im making, Im understanding them and Im starting to hit it further, which is a bit scary," he said. "The hard thing were struggling with right now is keeping it on the golf course. Thats just because Im not quite secure with it yet. But overall, Im definitely seeing the difference. Im not as short as the numbers are saying right now." In addition to less mileage on the scorecard, Ames is also looking forward to the more relaxed atmosphere on the Champions Tour, which he says will fit his personality. Its definitely a fan-friendly circuit and the out-going Ames believes hell enjoy that part of it, something thats been missing from the current PGA Tour. "Im going to get to be me a little more," he said. "The guys out here [on the PGA Tour] as so serious and stern-faced and there are no smiles... Im still enjoying it out here but its tougher and so thats why Im really looking forward to the Champions Tour." Ames will spend this year going back and forth between the two tours, playing 20 on the PGA Tour and filling in the rest of the season on the Champions Tour. For the first time in his career, hell also get a home game, teeing it up in the Shaw Charity Classic, the stop in Calgary. Sleeping in his own bed while playing a tournament is something hes never done, but hes looking forward to helping the tournament become even more successful than its maiden run last year. As he did on the PGA Tour, Ames will take to the Champions Tour in his own way. On the course, he should be a contender with that silky smooth swing of his. Off it, he will be the same guy too -- he never worries much about what others think and hes not afraid to say whats on his mind. Thats refreshing. Stephen Ames leads a stress-free life and thats a good way to be. http://www.soccerspainonline.com/Thiago-Alcantara-UEFA-European-Spain-Jersey/ (http://www.soccerspainonline.com/Thiago-Alcantara-! UEFA-Eur opean-Spain-Jersey/) . Patty Mills scored 15 points, Tim Duncan had 10 points and 11 rebounds in limited minutes, and San Antonio trailed for only 11 seconds late in the first quarter of a 103-90 victory over Portland on Wednesday night. http://www.soccerspainonline.com/Paco-Alcacer-UEFA-European-Spain-Jersey/ (http://www.soccerspainonline.com/Paco-Alcacer-UEFA-European-Spain-Jersey/) . -- Marty Havlat scored three goals for the first time in nearly nine years, and the San Jose Sharks prevented Colorado from clinching the Central Division title with a 5-1 victory over the Avalanche on Friday night. http://www.soccerspainonline.com/Santi-Cazorla-UEFA-European-Spain-Jersey/ (http://www.soccerspainonline.com/Santi-Cazorla-UEFA-European-Spain-Jersey/) . -- During a players meeting following the All-Star break, Jermaine ONeal promised his teammates to play the rest of the regular season like he would never play again -- because he very well might not.BOISBRIAND, Que. -- Vladimir Tkachev scored his second goal of the game 16:58 into overtime as the Moncton Wildcats took Game 2 against the host Blainville-Boisbriand Armada 6-5 on Friday in Quebec Major Junior Hockey League playoff action. Ivan Barbashev had a goal and three assists for the Wildcats (1-1), who evened their Round 1 matchup at a game apiece, Christopher Caissy scored once and set up two more and Conor Garland and Christophe Lalonde each had a goal and an assist. Nikita Jevpalovs had a hat trick for the Armada (1-1) while Ryan Tesink and Marcus Hinds each scored once. Monctons Alex Dubeau made 41 saves for the win as Blainville-Boisbriands Etienne Marcoux gave up six goals on 26 shots in defeat. --- MOOSEHEADS 6 ISLANDERS 3 HALIFAX -- Danny Moynihan scored twice and Jonathan Drouin and Luca Ciampini each added a goal and two assists as the Mooseheads doubled up Charlottetown for a 1-0 first-round series lead. Nikolaj Ehlers and Andrew Schewfelt had a goal and an assist apiece for Halifax. Anthony Cortese, Alexandre Goulet and Daniel Sprong each had! a goal and an assist for the Islanders (0-1). Zachary Fucale made 15 saves for the Mooseheads while Charlottetowns Mason McDonald stopped 45-of-51 shots in defeat. --- HUSKIES 5 REMPARTS 4 (OT) QUEBEC CITY -- Ryan Penny scored 4:11 into overtime and Jeremy Lauzon scored twice in regulation as Rouyn-Noranda slipped past the Remparts to take Game 1 of its Round 1 matchup. Mathieu Lemay had a goal and an assist for the Huskies (1-0) and Jason Fuchs scored the other. Adam Chapman had a pair of goals for Quebec (0-1), Cody Donaghey and Nick Sorensen each scored once and Olivier Archambault tacked on three assists. Rouyn-Norandas Alexandre Belanger made 29 saves for the win as Francois Brassard stopped 30-of-35 shots for the Remparts. --- DRAKKAR 5 CATARACTES 1 BAIE-COMEAU, Que. -- Philippe Cadorette made 27 saves and Robbie Graham scored twice as the Drakkar toppled Shawingan in Game 1 of their first-round tilt. Jeremy Gregoire, Denis Gorbunov and Charles Hudon also scored for Baie-Comeau (1-0) while Valentin Zykov and Alec Jon Banville each chipped in with two assists. Shawinigans Alexis DAoust snapped Cadorettes shutout bid with less than five minutes to play in the third period. Marvin Cupper turned away 33-of-38 shots for the Cataractes (0-1). Gerard Pique Spain Jersey (http://www.soccerspainonline.com/Gerard-Pique-UEFA-European-Spain-Jersey/). --- FOREURS 4 TITAN 1 VAL-DOR, Que. -- Anthony Richard scored late in the first period and then again in the third as the Foreurs took Game 1 in their Round 1 clash against Acadie-Bathurst. Guillaume Gelinas had a goal and assist for Val-dOr (1-0) and Samuel Henley added the other. Aaron Kerr scored the lone goal for the Titan (0-1). Antoine Bibeau made 15 saves for the Foreurs. Acadie-Bathursts Jacon Brennan stopped 38-of-42 shots in defeat. --- OCEANIC 5 SAGUENEENS 3 RIMOUSKI, Que. -- Sebastien Sylvestre scored twice and Philippe Desrosiers only had to make 13 saves as the Oceanic were victorious in Game 1 of their opening round meeting with Chicoutimi. Jimmy Oligny, Sa! muel Mor in and William Couture also scored for Rimouski (1-0) and Alexis Loiseau chipped in with two assists. Janne Puhakka, William Gignac and Domenic Beauchemin scored for the Sagueneens (0-1) while Julio Billia kicked out 36-of-40 shots in a losing cause. Chicoutimis Simon Tremblay was ejected in the second period after receiving a major for checking from behind. --- TIGRES 4 VOLTIGEURS 3 DRUMMONDVILLE, Que. -- Francois Tremblay made 33 saves and Julien Leducs goal 27 seconds into the third period stood up as the winner as Victoriaville edged the Voltigeurs for a 1-0 series lead in Round 1 action. Jonathan Diaby and Yan Pavel Laplante each had a goal and an assist for the Tigres and Cameron Yarwood scored once. Drummondville (0-1) got goals from Matthew Boudens, William Carriere and Olivier Caouette. Louis-Philip Guindon gave up four goals on 18 shots for the Voltigeurs. --- OLYMPIQUES 7 SCREAMING EAGLES 2 GATINEAU, Que. -- Simon Tardif-Richard had three goals and two assists and Martin Reway added two goals and two assists as the Olympiques hammered Cape Breton in Game 1 of their first-round bout. Vaclav Karabacek scored once and set up two more for Gatineau (1-0), Emile Poirier had a single goal and Jean-Simon Deslauriers had three assists. Timothe Simard and Clark Bishop scored for the Screaming Eagles (0-1). Robert Steeves made 18 saves for the Olympiques. Cape Bretons Alex Bureau gave up five goals on 23 shots in 46 minutes of action before Zachary Fortin took over. Fortin stopped 4-of-6 shots in relief. Cheap NFL Jerseys (http://www.cheapjerseysstitchedshop.com/) Wholesale Jerseys (http://www.wholesalejerseyssafestore.com/) Wholesale NFL Jerseys (http://www.wholesalechinastitchedjerseys.com/) Jerseys From China (http://www.wholesalenflcheapjerseyschina.us.com/) Wholesale NFL Jerseys (http://www.chinanflonlinejerseys.com/) Cheap NFL Jerseys (http://www.cheapsoccerjerseyschinaonline.com/) Cheap Jerseys (http://www.cheapnbajerseyschinastore.com/) ' ' ' Read this topic online here:
December 11, 2016 - January 08, 2017
AeroElectric-Archive.digest.vol-nq
