AeroElectric-Archive.digest.vol-nv
March 27, 2017 - April 25, 2017
      30 amp circuit breaker and I placed it's 30 amp Potter and Brumfield
      W23-x1a1g-30 circuit breaker on the end of the row however I discovered
      that I have a slight space conflict to the point where the Potter and
      Brumfield circuit breaker will not fit in its hole.=C3=82
         I wouldn't bring this kind of
         high current feeder up to the panel.
         I'd use a current limiter at the battery
         contactor thus keeping all the fat-wires
         of the panel. If there's already a
         spot for a breaker marked 'landing gear',
         put a 5a breaker there to power the control
         system.
Subject: Re: Lightweight rechargeable battery backup unit
Date: Mar 27, 2017
Bob, Hesitate to display my ignorance but with the schematic you drew won't the ASX-1 draw power from the higher voltage source, the batteries, until they are depleted to below the E-bus voltage? Won't replacing the diodes and SP ST switch with a SPDT (even an on - off - on) with the center contact going to the ASX-1 solve the issue and provide the same functionality? Tom Kuffel --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Mar 27, 2017
Subject: Re: Klixon Circuit Breaker
At 11:13 AM 3/27/2017, you wrote: >Hi Bob, thanks (as always) for your advice!=C2 > >I already have two circuit breaker holes =C2 (one >labeled "gear control" and the other one labeled >"gear hydraulic" and therefore I was trying to >figure out some way to salvage this mess and >make it look like it it's supposed to be that way.=C2 > >So it looks like what I should do is simply >remove this 30 amp circuit breaker and cover up >its laser etched label with some sort of black >paint or happy face sticker or something to make >it look like it wasn't there.=C2 You could put a 5A breaker in there and use it to POWER the coil on the hydraulic pump contactor . . . >I know you stated "current limiter" =C2 in your >reply however is an automotive automatically >reseting inline circuit breaker sufficient for >airplane use or should it be a real slow blow >one shot for real current limiter? > >Bill Hunter I recommend the mini-ANL devices now available all over the 'net . . . and showing up in some auto parts stores. Here one example: http://tinyurl.com/k4x4bua Off the shelf holders for these fuses come in TWO varieties (1) uses 'set screws' to mash down on the fat-wires, ostensibly capturing them in the end of the fuse holder . . . AVOID THESE. (2) uses two threaded posts over which the fuse is dropped along with the terminals that bring fat-wires up to the fuse holder. Here's one example . . Emacs! Obviously, you could make something like this yourself. Get a piece of phenolic, delrin, lexan, etc, and cut out a base. Drill 10-32 fuse mounting holes (counter bore back side for electrical clearance to ground). A couple more 6-32 attach holes. The cover is more cosmetic than utilitarian. Bob . . . ________________________________________________________________________________
Date: Mar 27, 2017
unit At 11:16 AM 3/27/2017, you wrote: >Bob, > >Hesitate to display my ignorance but with the schematic you drew >won't the ASX-1 draw power from the higher voltage source, the >batteries, until they are depleted to below the E-bus >voltage? Won't replacing the diodes and SPST switch with a SPDT >(even an on - off - on) with the center contact going to the ASX-1 >solve the issue and provide the same functionality? > >Tom Kuffel Nothing ignorant about your observation my friend . . . good eye! Your suggestion eliminates the conflict you noted. Here's another alternative. The diodes prevent back-feeding of either source to the opposite source. The switch isolates the standby batteries. Preflight would be modified to close the sb battery switch first to see that the ASX-1 lights up. Then turn it back off for remainder of that flight op. Thanks for the catch! Emacs! Bob . . . ________________________________________________________________________________
Date: Mar 27, 2017
> > Obviously, you could make something like this yourself. > Get a piece of phenolic, delrin, lexan, etc, and cut > out a base. Drill 10-32 fuse mounting holes (counter bore > back side for electrical clearance to ground). A couple > more 6-32 attach holes. The cover is more cosmetic than > utilitarian . . . P.S. Dug around and found some pix I'd taken of an exemplar DIY Mini-ANL holder some years ago . . . http://tinyurl.com/mv2dq98 http://tinyurl.com/lvununh http://tinyurl.com/m2tj9ux http://tinyurl.com/mbmjoev Bob . . . ________________________________________________________________________________
Date: Mar 28, 2017
Subject: heater fan wiring
I am building a cabin heater (Rotax) and the fan draws 4.3 amps. I have read that on startup it can draw 12 amps. It is a permanent magnet type fan. It looks like a large computer fan on steroids. I have decided to use my "defrost" circuit, which was originally going to power a couple of small, low draw computer fans. I wired it with 20 AWG wire. I would like to use the existing wiring for the fan, but I might need to put in a 12 amp fuse, and am a little concerned that might be too much for the 20 AWG wire. The wire from the bus to the switch is about 18 inches and the wire from the switch to the fan is about 24 inches. I guess I have two questions: 1. What would be the largest fuse I could use and still be safe? 2. If I test it and it doesn't blow a 5 amp (or 7.5 amp) fuse, do you think it would be likely to continue working indefinitely? Thanks, Ken ________________________________________________________________________________
Subject: Re: heater fan wiring
Date: Mar 28, 2017
I would try a 7.5 amp fuse. I usually prefer fuses. But for a motor, a circuit breaker will not nuisance trip as easily. Some day the motor bearings will freeze up. If fused higher and the motor draws 12 amps continuously, the wire will then get hot enough to boil water. How hard is it to replace the wire? Sometimes it is easier to go ahead and do it the hard way to start with. When faced with a decision like this, I ask myself, what is best in the long run, not what is easiest right now. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=467764#467764 ________________________________________________________________________________
Date: Mar 28, 2017
On 3/28/2017 2:49 PM, Ken Ryan wrote: > I am building a cabin heater (Rotax) and the fan draws 4.3 amps. I > have read that on startup it can draw 12 amps. It is a permanent > magnet type fan. It looks like a large computer fan on steroids. > > I have decided to use my "defrost" circuit, which was originally going > to power a couple of small, low draw computer fans. I wired it with 20 > AWG wire. > > I would like to use the existing wiring for the fan, but I might need > to put in a 12 amp fuse, and am a little concerned that might be too > much for the 20 AWG wire. > > The wire from the bus to the switch is about 18 inches and the wire > from the switch to the fan is about 24 inches. > > I guess I have two questions: > > 1. What would be the largest fuse I could use and still be safe? > > 2. If I test it and it doesn't blow a 5 amp (or 7.5 amp) fuse, do you > think it would be likely to continue working indefinitely? > > Thanks, > > Ken Somebody on another forum recently posted a link to Cooper Bussman ATC format circuit breakers. The time-to-trip vs overload percentage looks a lot like traditional circuit breakers, instead of the near-instant trip of an ATC fuse. Might be worth a look. The longer time constant should allow for momentary startup loads. http://www.cooperindustries.com/content/dam/public/bussmann/Transportation/Resources/catalog_pages/BUS_Tns_227_ATC_CB.pdf http://www.cooperindustries.com/content/dam/public/bussmann/Transportation/Resources/catalog_pages/circuit-protection/bus-cbt-ds-series-22x-circuit-breakers.pdf That's a really sturdy looking fan box. :-) What's it weigh? Charlie ________________________________________________________________________________
Date: Mar 28, 2017
Charlie, it weighs 3 pounds 14 ounces, but that does not include hoses or fittings (or the additional fluid required). I estimate 5.5 pounds all told, 6 pounds maximum. The stuff that I will be removing (heater box, scat tubing, cables, etc. weighs about 3 pounds, so 2 or 3 pounds heavier the airplane will be. To me this is a no-brainer, as I look upon the typical method of scavenging off the exhaust as a kind of Sword of Damocles, always poised to kill you. Plus, I live in Alaska! Lots of cold weather flying, so a better heater is really appreciated. So anyway, I got my speed control this morning. I hooked it all up and tried to blow the 5 amp fuse. I was not successful. I am thinking that maybe the information that I read about 12 amp startup draw is bogus. As I said, this is a permanent magnet type motor, very similar to what I have seen on computers. Does this type of motor really have large startup loads? So now that I have tried and failed to blow the 5 amp fuse, unless this list implores me to rewire for safety, I will stick with the 20 AWG. I'm pretty sure Bob has said that there is no problem using a 7.5 amp fuse with 20 AWG, right? If I did blow the 5 amp, I would still have the 7.5 amp fuse option. Ken On Tue, Mar 28, 2017 at 1:57 PM, Charlie England wrote: > ceengland7(at)gmail.com> > > > On 3/28/2017 2:49 PM, Ken Ryan wrote: > >> I am building a cabin heater (Rotax) and the fan draws 4.3 amps. I have >> read that on startup it can draw 12 amps. It is a permanent magnet type >> fan. It looks like a large computer fan on steroids. >> >> I have decided to use my "defrost" circuit, which was originally going to >> power a couple of small, low draw computer fans. I wired it with 20 AWG >> wire. >> >> I would like to use the existing wiring for the fan, but I might need to >> put in a 12 amp fuse, and am a little concerned that might be too much for >> the 20 AWG wire. >> >> The wire from the bus to the switch is about 18 inches and the wire from >> the switch to the fan is about 24 inches. >> >> I guess I have two questions: >> >> 1. What would be the largest fuse I could use and still be safe? >> >> 2. If I test it and it doesn't blow a 5 amp (or 7.5 amp) fuse, do you >> think it would be likely to continue working indefinitely? >> >> Thanks, >> >> Ken >> > Somebody on another forum recently posted a link to Cooper Bussman ATC > format circuit breakers. The time-to-trip vs overload percentage looks a > lot like traditional circuit breakers, instead of the near-instant trip of > an ATC fuse. Might be worth a look. The longer time constant should allow > for momentary startup loads. > http://www.cooperindustries.com/content/dam/public/bussmann/ > Transportation/Resources/catalog_pages/BUS_Tns_227_ATC_CB.pdf > > http://www.cooperindustries.com/content/dam/public/bussmann/ > Transportation/Resources/catalog_pages/circuit- > protection/bus-cbt-ds-series-22x-circuit-breakers.pdf > > That's a really sturdy looking fan box. :-) What's it weigh? > > Charlie > > ________________________________________________________________________________
Date: Mar 28, 2017
That's a good point Joe. Update: I got it all hooked up (temporary) and it works great with a 5 amp fuse, so I think I will be okay. If necessary I will go to 7.5 amp, but I won't go higher than that. Do these type motors really have large startup current requirements? Would it make any difference that I am running it through a PWM speed control? Like I said, I am not blowing a 5 amp fuse. On Tue, Mar 28, 2017 at 1:12 PM, user9253 wrote: > > I would try a 7.5 amp fuse. I usually prefer fuses. But for a motor, > a circuit breaker will not nuisance trip as easily. Some day the motor > bearings will freeze up. If fused higher and the motor draws 12 amps > continuously, > the wire will then get hot enough to boil water. > How hard is it to replace the wire? Sometimes it is easier to go ahead > and do it the hard way to start with. When faced with a decision like > this, > I ask myself, what is best in the long run, not what is easiest right now. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=467764#467764 > > ________________________________________________________________________________
Date: Mar 28, 2017
Ken, Some fan speed controllers put out a steady DC for several milliseconds to start a motor, then change over to PWM. The motor might very well draw 12 amps to start, but only for a fraction of a second, too short of a time to heat up and blow a fuse. It looks like you have answered your own question by testing. As long as it works, it is good enough. Thanks for those links Charlie. I never knew ATC circuit breakers existed. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=467771#467771 ________________________________________________________________________________
Date: Mar 28, 2017
Does your speed control have a power on/off switch separate from the speed knob, or do you twist the speed knob from the "off" detent to the lowest speed setting, and up from there? If the former, then it's possible to start the fan in its highest draw setting (PWM at 100%). If the latter, it will always turn on at the lowest PWM value, so inrush should be well controlled (unless you slam the knob to max speed, I suppose). In either case, the speed control may have inrush limiting as part of its design. The best way to check this issue for sure is a DC clamp meter or series-connected ammeter with max-hold function. Eric > On Mar 28, 2017, at 3:39 PM, Ken Ryan wrote: > [SNIP] Do these type motors really have large startup current requirements? Would it make any difference that I am running it through a PWM speed control? Like I said, I am not blowing a 5 amp fuse. ________________________________________________________________________________
Date: Mar 28, 2017
This question is about USB charging ports and radio interference/noise. Ive check out a couple charging ports that plug into the cigarette lighter and they both produce noise when charging. Both purchased from pilot shops. Also tried a couple direct wire USB charging ports from marine/auto applications with the same result. Is there any way to filter or shield these devices to reduce or eliminate the radio noise. The noise cant be eliminated with squelch adjustment. Im using a hand held icom radio for the test, it doesnt see to make any difference if the radio is 12 to 36 away from the charging port. Thanks, Bernie > On Mar 28, 2017, at 4:01 PM, user9253 wrote: > > > Ken, Some fan speed controllers put out a steady DC for several milliseconds to start a motor, then change over to PWM. The motor might very well draw 12 amps to start, but only for a fraction of a second, too short of a time to heat up and blow a fuse. It looks like you have answered your own question by testing. As long as it works, it is good enough. > Thanks for those links Charlie. I never knew ATC circuit breakers existed. > > -------- > Joe Gores > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=467771#467771 > > > > > > > > > ________________________________________________________________________________
Date: Mar 28, 2017
I understand the desire for a good heater but running lean of peak minimizes the carbon monoxide > On Mar 28, 2017, at 6:32 PM, Ken Ryan wrote: > > Charlie, it weighs 3 pounds 14 ounces, but that does not include hoses or f ittings (or the additional fluid required). I estimate 5.5 pounds all told, 6 pounds maximum. The stuff that I will be removing (heater box, scat tubing, cables, etc. weighs about 3 pounds, so 2 or 3 pounds heavier the airplane w ill be. > > To me this is a no-brainer, as I look upon the typical method of scavengin g off the exhaust as a kind of Sword of Damocles, always poised to kill you. Plus, I live in Alaska! Lots of cold weather flying, so a better heater is r eally appreciated. > > So anyway, I got my speed control this morning. I hooked it all up and tri ed to blow the 5 amp fuse. I was not successful. > > I am thinking that maybe the information that I read about 12 amp startup d raw is bogus. As I said, this is a permanent magnet type motor, very similar to what I have seen on computers. Does this type of motor really have large startup loads? > > So now that I have tried and failed to blow the 5 amp fuse, unless this li st implores me to rewire for safety, I will stick with the 20 AWG. > > I'm pretty sure Bob has said that there is no problem using a 7.5 amp fuse with 20 AWG, right? If I did blow the 5 amp, I would still have the 7.5 amp fuse option. > > Ken > >> On Tue, Mar 28, 2017 at 1:57 PM, Charlie England w rote: l.com> >> >> >>> On 3/28/2017 2:49 PM, Ken Ryan wrote: >>> I am building a cabin heater (Rotax) and the fan draws 4.3 amps. I have r ead that on startup it can draw 12 amps. It is a permanent magnet type fan. I t looks like a large computer fan on steroids. >>> >>> I have decided to use my "defrost" circuit, which was originally going t o power a couple of small, low draw computer fans. I wired it with 20 AWG wi re. >>> >>> I would like to use the existing wiring for the fan, but I might need to put in a 12 amp fuse, and am a little concerned that might be too much for t he 20 AWG wire. >>> >>> The wire from the bus to the switch is about 18 inches and the wire from the switch to the fan is about 24 inches. >>> >>> I guess I have two questions: >>> >>> 1. What would be the largest fuse I could use and still be safe? >>> >>> 2. If I test it and it doesn't blow a 5 amp (or 7.5 amp) fuse, do you th ink it would be likely to continue working indefinitely? >>> >>> Thanks, >>> >>> Ken >> Somebody on another forum recently posted a link to Cooper Bussman ATC fo rmat circuit breakers. The time-to-trip vs overload percentage looks a lot l ike traditional circuit breakers, instead of the near-instant trip of an ATC fuse. Might be worth a look. The longer time constant should allow for mome ntary startup loads. >> http://www.cooperindustries.com/content/dam/public/bussmann/Transportatio n/Resources/catalog_pages/BUS_Tns_227_ATC_CB.pdf >> >> http://www.cooperindustries.com/content/dam/public/bussmann/Transportatio n/Resources/catalog_pages/circuit-protection/bus-cbt-ds-series-22x-circuit-b reakers.pdf >> >> That's a really sturdy looking fan box. :-) What's it weigh? >> >> Charlie >> ========================= >> - >> Electric-List" rel="noreferrer" target="_blank">http://www.matronics. com/Navigator?AeroElectric-List >> ========================= >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========================= >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ========================= >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contributio n >> ========================= > ________________________________________________________________________________
From: "Craig L. Reding" <clr(at)redingaviation.com>
Date: Mar 28, 2017
> On Mar 28, 2017, at 8:58 PM, Kent or Jackie Ashton wrote: > > I understand the desire for a good heater but running lean of peak minimizes the carbon monoxide > > On Mar 28, 2017, at 6:32 PM, Ken Ryan > wrote: > >> Charlie, it weighs 3 pounds 14 ounces, but that does not include hoses or fittings (or the additional fluid required). I estimate 5.5 pounds all told, 6 pounds maximum. The stuff that I will be removing (heater box, scat tubing, cables, etc. weighs about 3 pounds, so 2 or 3 pounds heavier the airplane will be. >> >> To me this is a no-brainer, as I look upon the typical method of scavenging off the exhaust as a kind of Sword of Damocles, always poised to kill you. Plus, I live in Alaska! Lots of cold weather flying, so a better heater is really appreciated. >> >> So anyway, I got my speed control this morning. I hooked it all up and tried to blow the 5 amp fuse. I was not successful. >> >> I am thinking that maybe the information that I read about 12 amp startup draw is bogus. As I said, this is a permanent magnet type motor, very similar to what I have seen on computers. Does this type of motor really have large startup loads? >> >> So now that I have tried and failed to blow the 5 amp fuse, unless this list implores me to rewire for safety, I will stick with the 20 AWG. >> >> I'm pretty sure Bob has said that there is no problem using a 7.5 amp fuse with 20 AWG, right? If I did blow the 5 amp, I would still have the 7.5 amp fuse option. >> >> Ken >> >> On Tue, Mar 28, 2017 at 1:57 PM, Charlie England > wrote: > >> >> >> On 3/28/2017 2:49 PM, Ken Ryan wrote: >> I am building a cabin heater (Rotax) and the fan draws 4.3 amps. I have read that on startup it can draw 12 amps. It is a permanent magnet type fan. It looks like a large computer fan on steroids. >> >> I have decided to use my "defrost" circuit, which was originally going to power a couple of small, low draw computer fans. I wired it with 20 AWG wire. >> >> I would like to use the existing wiring for the fan, but I might need to put in a 12 amp fuse, and am a little concerned that might be too much for the 20 AWG wire. >> >> The wire from the bus to the switch is about 18 inches and the wire from the switch to the fan is about 24 inches. >> >> I guess I have two questions: >> >> 1. What would be the largest fuse I could use and still be safe? >> >> 2. If I test it and it doesn't blow a 5 amp (or 7.5 amp) fuse, do you think it would be likely to continue working indefinitely? >> >> Thanks, >> >> Ken >> Somebody on another forum recently posted a link to Cooper Bussman ATC format circuit breakers. The time-to-trip vs overload percentage looks a lot like traditional circuit breakers, instead of the near-instant trip of an ATC fuse. Might be worth a look. The longer time constant should allow for momentary startup loads. >> http://www.cooperindustries.com/content/dam/public/bussmann/Transportation /Resources/catalog_pages/BUS_Tns_227_ATC_CB.pdf <http://www.cooperindustries.com/content/dam/public/bussmann/Transportatio n/Resources/catalog_pages/BUS_Tns_227_ATC_CB.pdf> >> >> http://www.cooperindustries.com/content/dam/public/bussmann/Transportation /Resources/catalog_pages/circuit-protection/bus-cbt-ds-series-22x-circuit- breakers.pdf <http://www.cooperindustries.com/content/dam/public/bussmann/Transportatio n/Resources/catalog_pages/circuit-protection/bus-cbt-ds-series-22x-circuit -breakers.pdf> >> >> That's a really sturdy looking fan box. :-) What's it weigh? >> >> Charlie >> ======================== =========== >> - >> Electric-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navig <http://www.matronics.com/Navig>ator?AeroElectric-List >> ======================== =========== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com <http://forums.matronics.com/> >> ======================== =========== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com <http://wiki.matronics.com/> >> ======================== =========== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contr <http://www.matronics.com/contr>ibution >> ======================== =========== >> >> >> >> ________________________________________________________________________________
Subject: Re: headset matching to radio
Date: Mar 28, 2017
I haven't picked up the plane yet, but I have a system I'm confident will work. On one side, an impedance matching transformer to convert the 8 ohm earphones for a receiver output expecting 300 ohms, and for the mike side, rather than working out an amplifier I bought a new replacement noise cancelling mike element from Aircraft Spruce. Wired to the appropriate connectors, I've verified they work, at least with the radio in a friend's Bonanza. Interestingly, they also work with the Icom handheld in my old plane... I guess the Icom is a lot more tolerant than the older radios. As for the "why", I use the earbuds because they fit under a leather flying helmet. The mike is on a flexible boom that clips to my shoulder harness, much more comfortable than than being clamped around my head or over my ears. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=467781#467781 ________________________________________________________________________________
Date: Mar 29, 2017
Thanks Charlie. If I ever start blowing fuses I will try these. Good to know that they exist. Sent from my Android. Sorry Steve. On Mar 28, 2017 2:10 PM, "Charlie England" wrote: > ceengland7(at)gmail.com> > > On 3/28/2017 2:49 PM, Ken Ryan wrote: > >> I am building a cabin heater (Rotax) and the fan draws 4.3 amps. I have >> read that on startup it can draw 12 amps. It is a permanent magnet type >> fan. It looks like a large computer fan on steroids. >> >> I have decided to use my "defrost" circuit, which was originally going to >> power a couple of small, low draw computer fans. I wired it with 20 AWG >> wire. >> >> I would like to use the existing wiring for the fan, but I might need to >> put in a 12 amp fuse, and am a little concerned that might be too much for >> the 20 AWG wire. >> >> The wire from the bus to the switch is about 18 inches and the wire from >> the switch to the fan is about 24 inches. >> >> I guess I have two questions: >> >> 1. What would be the largest fuse I could use and still be safe? >> >> 2. If I test it and it doesn't blow a 5 amp (or 7.5 amp) fuse, do you >> think it would be likely to continue working indefinitely? >> >> Thanks, >> >> Ken >> > Somebody on another forum recently posted a link to Cooper Bussman ATC > format circuit breakers. The time-to-trip vs overload percentage looks a > lot like traditional circuit breakers, instead of the near-instant trip of > an ATC fuse. Might be worth a look. The longer time constant should allow > for momentary startup loads. > http://www.cooperindustries.com/content/dam/public/bussmann/ > Transportation/Resources/catalog_pages/BUS_Tns_227_ATC_CB.pdf > > http://www.cooperindustries.com/content/dam/public/bussmann/ > Transportation/Resources/catalog_pages/circuit- > protection/bus-cbt-ds-series-22x-circuit-breakers.pdf > > That's a really sturdy looking fan box. :-) What's it weigh? > > Charlie > > ________________________________________________________________________________
From: Stephen Richards <stephencliverichards(at)gmail.com>
Date: Mar 29, 2017
QmVybmllICBOb3Qgc3VyZSB3aHkgeW91IGhhdmUgcHV0IGEgcXVlc3Rpb24gYWJvdXQgVVNCIGNo YXJnZXJzIHVuZGVyIHRoaXMgdGhyZWFkIGJ1dCBJIHVuZGVyc3RhbmQgQW5rZXIgcHJvZHVjdHMg YXJlIG5vaXNlIGZyZWUgSSBoYXZlIHVzZWQgYSBVU0IgcG93ZXIgZHJpdmUgMiBhbmQgY2FuIGhv bGQgYSBoYW5kIGhlbGQgcmFkaW8gbmVhciB0aGlzIHdpdGggbm8gcHJvYmxlbQ0KQ2xpdmUgDQoN Ci0tLS0tT3JpZ2luYWwgTWVzc2FnZS0tLS0tDQpGcm9tOiAiQmVybmllIFdpbGxpcyIgPGFyY3Rp Y2Fycm93QGdtYWlsLmNvbT4NClNlbnQ6IOKAjjI5L+KAjjAzL+KAjjIwMTcgMDI6MDkNClRvOiAi YWVyb2VsZWN0cmljLWxpc3RAbWF0cm9uaWNzLmNvbSIgPGFlcm9lbGVjdHJpYy1saXN0QG1hdHJv bmljcy5jb20+DQpTdWJqZWN0OiBSZTogQWVyb0VsZWN0cmljLUxpc3Q6IFJlOiBoZWF0ZXIgZmFu IHdpcmluZw0KDQotLT4gQWVyb0VsZWN0cmljLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6IEJlcm5p ZSBXaWxsaXMgPGFyY3RpY2Fycm93QGdtYWlsLmNvbT4NCg0KVGhpcyBxdWVzdGlvbiBpcyBhYm91 dCBVU0IgIGNoYXJnaW5nIHBvcnRzIGFuZCByYWRpbyBpbnRlcmZlcmVuY2Uvbm9pc2UuDQpJ4oCZ dmUgY2hlY2sgb3V0IGEgY291cGxlIGNoYXJnaW5nIHBvcnRzIHRoYXQgcGx1ZyBpbnRvIHRoZSBj aWdhcmV0dGUgbGlnaHRlciBhbmQgdGhleSBib3RoIHByb2R1Y2Ugbm9pc2Ugd2hlbiBjaGFyZ2lu Zy4gQm90aCBwdXJjaGFzZWQgZnJvbSBwaWxvdCBzaG9wcy4gIEFsc28gdHJpZWQgYSBjb3VwbGUg ZGlyZWN0IHdpcmUgVVNCIGNoYXJnaW5nIHBvcnRzIGZyb20gbWFyaW5lL2F1dG8gYXBwbGljYXRp b25zIHdpdGggdGhlIHNhbWUgcmVzdWx0LiAgSXMgdGhlcmUgYW55IHdheSB0byBmaWx0ZXIgb3Ig c2hpZWxkIHRoZXNlIGRldmljZXMgdG8gcmVkdWNlIG9yIGVsaW1pbmF0ZSB0aGUgcmFkaW8gbm9p c2UuICBUaGUgbm9pc2UgY2Fu4oCZdCBiZSBlbGltaW5hdGVkIHdpdGggc3F1ZWxjaCBhZGp1c3Rt ZW50LiAgSeKAmW0gdXNpbmcgYSBoYW5kIGhlbGQgaWNvbSByYWRpbyBmb3IgdGhlIHRlc3QsICBp dCBkb2VzbuKAmXQgc2VlIHRvIG1ha2UgYW55IGRpZmZlcmVuY2UgaWYgdGhlIHJhZGlvIGlzIDEy IHRvIDM2IOKAnCBhd2F5IGZyb20gdGhlIGNoYXJnaW5nIHBvcnQuDQoNClRoYW5rcywNCkJlcm5p ZQ0KPiBPbiBNYXIgMjgsIDIwMTcsIGF0IDQ6MDEgUE0sIHVzZXI5MjUzIDxmcmFuc2V3QGdtYWls LmNvbT4gd3JvdGU6DQo+IA0KPiAtLT4gQWVyb0VsZWN0cmljLUxpc3QgbWVzc2FnZSBwb3N0ZWQg Ynk6ICJ1c2VyOTI1MyIgPGZyYW5zZXdAZ21haWwuY29tPg0KPiANCj4gS2VuLCBTb21lIGZhbiBz cGVlZCBjb250cm9sbGVycyBwdXQgb3V0IGEgc3RlYWR5IERDIGZvciBzZXZlcmFsIG1pbGxpc2Vj b25kcyB0byBzdGFydCBhIG1vdG9yLCB0aGVuIGNoYW5nZSBvdmVyIHRvIFBXTS4gIFRoZSBtb3Rv ciBtaWdodCB2ZXJ5IHdlbGwgZHJhdyAxMiBhbXBzIHRvIHN0YXJ0LCBidXQgb25seSBmb3IgYSBm cmFjdGlvbiBvZiBhIHNlY29uZCwgdG9vIHNob3J0IG9mIGEgdGltZSB0byBoZWF0IHVwIGFuZCBi bG93IGEgZnVzZS4gIEl0IGxvb2tzIGxpa2UgeW91IGhhdmUgYW5zd2VyZWQgeW91ciBvd24gcXVl c3Rpb24gYnkgdGVzdGluZy4gIEFzIGxvbmcgYXMgaXQgd29ya3MsIGl0IGlzIGdvb2QgZW5vdWdo Lg0KPiAgVGhhbmtzIGZvciB0aG9zZSBsaW5rcyBDaGFybGllLiAgSSBuZXZlciBrbmV3IEFUQyBj aXJjdWl0IGJyZWFrZXJzIGV4aXN0ZWQuDQo+IA0KPiAtLS0tLS0tLQ0KPiBKb2UgR29yZXMNCj4g DQo+IA0KPiANCj4gDQo+IFJlYWQgdGhpcyB0b3BpYyBvbmxpbmUgaGVyZToNCj4gDQo+IGh0dHA6 Ly9mb3J1bXMubWF0cm9uaWNzLmNvbS92aWV3dG9waWMucGhwP3A9NDY3NzcxIzQ2Nzc3MQ0KPiAN Cj4gDQo+IA0KPiANCj4gDQo+IA0KPiANCj4gDQo+IA0KDQoNCl8tPT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQpfLT0gICAgICAgICAg LSBUaGUgQWVyb0VsZWN0cmljLUxpc3QgRW1haWwgRm9ydW0gLQ0KXy09IFVzZSB0aGUgTWF0cm9u aWNzIExpc3QgRmVhdHVyZXMgTmF2aWdhdG9yIHRvIGJyb3dzZQ0KXy09IHRoZSBtYW55IExpc3Qg dXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sDQpfLT0gQXJjaGl2ZSBTZWFy Y2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0LCBGQVEsDQpfLT0gUGhvdG9zaGFyZSwg YW5kIG11Y2ggbXVjaCBtb3JlOg0KXy09DQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3Mu Y29tL05hdmlnYXRvcj9BZXJvRWxlY3RyaWMtTGlzdA0KXy09DQpfLT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KXy09ICAgICAgICAg ICAgICAgLSBNQVRST05JQ1MgV0VCIEZPUlVNUyAtDQpfLT0gU2FtZSBncmVhdCBjb250ZW50IGFs c28gYXZhaWxhYmxlIHZpYSB0aGUgV2ViIEZvcnVtcyENCl8tPQ0KXy09ICAgLS0+IGh0dHA6Ly9m b3J1bXMubWF0cm9uaWNzLmNvbQ0KXy09DQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KXy09ICAgICAgICAgICAgICAtIE5FVyBN QVRST05JQ1MgTElTVCBXSUtJIC0NCl8tPSBBZGQgc29tZSBpbmZvIHRvIHRoZSBNYXRyb25pY3Mg RW1haWwgTGlzdCBXaWtpIQ0KXy09ICAgLS0+IGh0dHA6Ly93aWtpLm1hdHJvbmljcy5jb20NCl8t PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09DQpfLT0gICAgICAgICAgICAgLSBMaXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAtDQpfLT0g IFRoYW5rIHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQ0KXy09ICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgLU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLg0KXy09ICAgLS0+IGh0dHA6 Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24NCl8tPT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQoNCg0KDQo ________________________________________________________________________________
Date: Mar 29, 2017
Subject: Re: ASX-1 Supply
At 12:36 AM 3/28/2017, you wrote: > >Fail to understand why the SPDT solution isn't much better. It >eliminates two components, lets you test the battery supply anytime >and allows power to the ASX-1 to be shut off (presumably only for >maintenance). Or with a DPDT switch one could use the second pole >to take power from the 3a fuse and light a big LED warning if the >switch is in the battery position. Granted, there is a new single >point of failure but don't see how failure of the ASX-1 prevents >completion of the flight as planned. > >Tom Tom's comments planted seeds of a new idea which I massaged for several house on the "asphalt drafting board" yesterday driving to Wichita. I'll offer this configuration which I am considering as a new z-figure to the 'Connection . . . Emacs! This idea adds a warning light for standby battery switch position. This would reduce probability for inadvertent depletion of the battery. I've also added a fuse to the battery pack which is advised especially when the appliance teamed with design goals call for up-sizing the stand-by cells. Let's digest this configuration for awhile . . . Hat tip to Tom K! Bob . . . ________________________________________________________________________________
Date: Mar 29, 2017
Also, try SteinAir. They sell one that's supposed to be noise free. On 3/29/2017 2:57 PM, Stephen Richards wrote: > Bernie Not sure why you have put a question about USB chargers under > this thread but I understand Anker products are noise free I have used > a USB power drive 2 and can hold a hand held radio near this with no > problem > Clive > ------------------------------------------------------------------------ > From: Bernie Willis <mailto:arcticarrow(at)gmail.com> > Sent: 29/03/2017 02:09 > To: aeroelectric-list(at)matronics.com > > Subject: Re: AeroElectric-List: Re: heater fan wiring > > > > This question is about USB charging ports and radio interference/noise. > Ive check out a couple charging ports that plug into the cigarette > lighter and they both produce noise when charging. Both purchased from > pilot shops. Also tried a couple direct wire USB charging ports from > marine/auto applications with the same result. Is there any way to > filter or shield these devices to reduce or eliminate the radio > noise. The noise cant be eliminated with squelch adjustment. Im > using a hand held icom radio for the test, it doesnt see to make any > difference if the radio is 12 to 36 away from the charging port. > > Thanks, > Bernie > > On Mar 28, 2017, at 4:01 PM, user9253 wrote: > > > > > > Ken, Some fan speed controllers put out a steady DC for several > milliseconds to start a motor, then change over to PWM. The motor > might very well draw 12 amps to start, but only for a fraction of a > second, too short of a time to heat up and blow a fuse. It looks like > you have answered your own question by testing. As long as it works, > it is good enough. > > Thanks for those links Charlie. I never knew ATC circuit breakers > existed. > > > > -------- > > Joe Gores > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=467771#467771 > > > > > > > sp; - MATRONICS WEB F - NEW MATRONICS LIST WIKI - > _= p; &====== > > ________________________________________________________________________________
Date: Mar 29, 2017
+1 on the Anker "aux port" chargers. They also make great USB and Lightning cables, including 6-foot lengths. Jim Parker -------- Original Message -------- Subject: RE: AeroElectric-List: Re: heater fan wiring From: Stephen Richards <stephencliverichards(at)gmail.com> Date: Wed, March 29, 2017 2:57 pm Bernie Not sure why you have put a question about USB chargers under this thread but I understand Anker products are noise free I have used a USB power drive 2 and can hold a hand held radio near this with no problem Clive From: Bernie Willis Sent: 29/03/2017 02:09 Subject: Re: AeroElectric-List: Re: heater fan wiring This question is about USB charging ports and radio interference/noise. Ive check out a couple charging ports that plug into the cigarette lighter and they both produce noise when charging. Both purchased from pilot shops. Also tried a couple direct wire USB charging ports from marine/auto applications with the same result. Is there any way to filter or shield these devices to reduce or eliminate the radio noise. The noise cant be eliminated with squelch adjustment. Im using a hand held icom radio for the test, it doesnt see to make any difference if the radio is 12 to 36 away from the charging port. Thanks, Bernie > On Mar 28, 2017, at 4:01 PM, user9253 wrote: > > > Ken, Some fan speed controllers put out a steady DC for several milliseconds to start a motor, then change over to PWM. The motor might very well draw 12 amps to start, but only for a fraction of a second, too short of a time to heat up and blow a fuse. It looks like you have answered your own question by testing. As long as it works, it is good enough. > Thanks for those links Charlie. I never knew ATC circuit breakers existed. > > -------- > Joe Gores > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=467771#467771 > > > sp; - MATRONICS WEB F - NEW MATRONICS LIST WIKI - _= p; &====== ________________________________________________________________________________
Date: Mar 29, 2017
At 02:49 PM 3/28/2017, you wrote: >I am building a cabin heater (Rotax) and the fan draws 4.3 amps. I >have read that on startup it can draw 12 amps. This will be for milliseconds during spin-up . . . leave the 20AWG in place and go with 10A fuse . . . it's probably going to be fine. Bob . . . ________________________________________________________________________________
Date: Mar 29, 2017
At 04:12 PM 3/28/2017, you wrote: > >I would try a 7.5 amp fuse. I usually prefer fuses. But for a motor, > a circuit breaker will not nuisance trip as easily. Some day the motor > bearings will freeze up. If fused higher and the motor draws 12 > amps continuously, > the wire will then get hot enough to boil water. Actually, 20AWG is pretty 'cool' at 12A. See http://tinyurl.com/lk2tmhx If a 22AWG at 20A just barely passes 100C in free air . . . a 20AWG at 12A is pretty safe. A 10A fuse would be fine . . . Bob . . . ________________________________________________________________________________
Date: Mar 29, 2017
Great! Thanks. Sent from my Android. Sorry Steve. On Mar 29, 2017 4:35 PM, "Robert L. Nuckolls, III" < nuckolls.bob(at)aeroelectric.com> wrote: > At 04:12 PM 3/28/2017, you wrote: > > > I would try a 7.5 amp fuse. I usually prefer fuses. But for a motor, > a circuit breaker will not nuisance trip as easily. Some day the motor > bearings will freeze up. If fused higher and the motor draws 12 amps > continuously, > the wire will then get hot enough to boil water. > > > Actually, 20AWG is pretty 'cool' at 12A. See > > http://tinyurl.com/lk2tmhx > > If a 22AWG at 20A just barely passes 100C in free > air . . . a 20AWG at 12A is pretty safe. > > A 10A fuse would be fine . . . > > Bob . . . > ________________________________________________________________________________
Subject: Minimum GPS Antenna Cable Length
Date: Mar 30, 2017
I am installing an Appareo Stratus ESG transponder with internal GPS. It did not come with antenna cables. I purchased a 19 inch RG400 GPS antenna cable before reading the installation directions which state, "All wiring should have a cable loss of minimum 2 dB . . . .Using RG400 the minimum cable length is 10 feet". Will the GPS work satisfactorily with the short cable? If not, what is a cheap and easy way to increase the dB loss? What is the theory behind the requirement for at least 2 dB cable loss? -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=467824#467824 ________________________________________________________________________________
Date: Mar 30, 2017
Subject: Re: Minimum GPS Antenna Cable Length
I also installed an Appereo in my cozy I called the factory they said you need at least 10 foot of antenna cable so you have some resistance my antenna is 2 ft. From the stratus they told me to just roll up the extra so that is what I did . It. Works who am I to argue with success. Steve build on Sent from my iPad > On Mar 30, 2017, at 5:01 AM, user9253 wrote: > > > I am installing an Appareo Stratus ESG transponder with internal GPS. It did not come with antenna cables. I purchased a 19 inch RG400 GPS antenna cable before reading the installation directions which state, "All wiring should have a cable loss of minimum 2 dB . . . .Using RG400 the minimum cable length is 10 feet". > Will the GPS work satisfactorily with the short cable? If not, what is a cheap and easy way to increase the dB loss? What is the theory behind the requirement for at least 2 dB cable loss? > > -------- > Joe Gores > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=467824#467824 > > > > > > > > > > ____________________________________________________________ This Simple Step To Flawless Skin gundrymd.com http://thirdpartyoffers.juno.com/TGL3131/58dcf56de30bf756c6215st01duc ________________________________________________________________________________
Date: Mar 30, 2017
On Thu, Mar 30, 2017 at 6:01 AM, user9253 wrote: > > I am installing an Appareo Stratus ESG transponder with internal GPS. It > did not come with antenna cables. I purchased a 19 inch RG400 GPS antenna > cable before reading the installation directions which state, "All wiring > should have a cable loss of minimum 2 dB . . . .Using RG400 the minimum > cable length is 10 feet". > Will the GPS work satisfactorily with the short cable? If not, what is > a cheap and easy way to increase the dB loss? What is the theory behind > the requirement for at least 2 dB cable loss? > > -------- > Joe Gores > > The 1st thing that comes to mind is this. Most radio receivers have multiple gain stages (in addition to frequency down-conversions) to get weak RF signals up to a level that's useful. Each gain stage will typically have automatic gain control (AGC) that prevents the amplifier from being driven into distortion by a too-strong input signal. But there's a limit to the range of AGC. They've probably calculated the max possible output from the GPS puck (which probably has both the 1st frequency downconversion and gain), and the cable loss prevents overdriving the 1st gain stage in the box. When the GPS RF signal is weaker, the box's AGC circuit can ramp up gain to compensate. If you ever fly formation, you might hear the same overdrive effect in your comm radio. The wingman's radio might sound fine until they get within a half mile or so, but as they get closer, their audio sounds fuzzy & garbled. When they break formation & move a mile or two away, it clears up again. The bad audio is your radio's AGC being overwhelmed by too much RF or intermediate frequency signal level while the wingman's transmitter is too 'hot' for your receiver to compensate. Charlie ________________________________________________________________________________
Date: Mar 30, 2017
IIRC each connector in the line adds about 1/2 db of cable loss. So in theory, 2 extra adapters in the cable would get you there. Don't know if that is exactly correct. So maybe with an extra foot, a union connector and 2 BNC connectors, or BNC to TNC adapters and you might have enough loss. BTW, BNC to TNC adapter is lot cheaper than just buying a crimp on TNC connector. On 3/30/2017 4:01 AM, user9253 wrote: > > I am installing an Appareo Stratus ESG transponder with internal GPS. It did not come with antenna cables. I purchased a 19 inch RG400 GPS antenna cable before reading the installation directions which state, "All wiring should have a cable loss of minimum 2 dB . . . .Using RG400 the minimum cable length is 10 feet". > Will the GPS work satisfactorily with the short cable? If not, what is a cheap and easy way to increase the dB loss? What is the theory behind the requirement for at least 2 dB cable loss? > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=467824#467824 > > ________________________________________________________________________________
Date: Mar 30, 2017
Subject: Garmin GPS antenna
> > The G3X Installation Manual says, in a "Note" on page 20-1, that "GA35, GA36 and GA37 antennas cannot be used with GDU 37X/4XX units". > > Does anybody know why? > > (I'm asking because I bought the pretty expensive GA35, as an excellent GPS antenna, before reading this "Note") > > Thanks > Carlos ________________________________________________________________________________
Date: Mar 30, 2017
Subject: Backup Power
I had a different thought on backup power for the EFIS I am installing in my day VFR plane. I figured the most likely scenario of having a problem with the EFIS is loss of power to it. I would like to at least have airspeed available while landing to troubleshoot the electrical problem, but why not just restore the whole EFIS? Also, I always have on board a couple freshly charged batteries for various purposes. One is running the Raspberry Pi Stratux system. Another is standby power (if needed for very long flights) for my Android tablet running Avare. So, why not put a round 2.1 mm jack for 12 volts on the panel routed the secondary power input on the EFIS and then keep one of these cables stored in the plane to go from 5 volts on the USB output of the battery to 12 volts for the EFIS: https://www.amazon.com/LANMU-Module-Converter-Barrel-Connector/dp/B01G3ERI6U Ron ________________________________________________________________________________
Date: Mar 31, 2017
At 06:01 AM 3/30/2017, you wrote: > >I am installing an Appareo Stratus ESG transponder with internal >GPS. It did not come with antenna cables. I purchased a 19 inch >RG400 GPS antenna cable before reading the installation directions >which state, "All wiring should have a cable loss of minimum 2 dB . >. . .Using RG400 the minimum cable length is 10 feet". > Will the GPS work satisfactorily with the short cable? If not, > what is a cheap and easy way to increase the dB loss? What is the > theory behind the requirement for at least 2 dB cable loss? I'm having trouble wrapping my head around this requirement. GPS satellite signals are exceedingly tiny . . . down in the atmospheric noise levels. The only reason our tiny wrist-watch, hand-held, and self-navigating drones work so well is because the 'smarts' in GPS receiver software is looking for specific patterns of data in the chaotic patternless noise. Routine variations in received GPS signals is all over the magnitude map spanning perhaps tens of db . . . a required 2 db 'addition of attenuation' simply doesn't make sense. The idea that a receiver's performance is predicated on a minimum of 2db of loss in the antenna system by making the cable longer is a real puzzle . . . usually, the instructions will say something like "limit cable losses to a MAXIMUM of 2db where a 10' run of RG-400 is the practical limit". I'm wondering if this manual wasn't originally crafted in Chinese and then translated by some academic instead of a systems engineer. One thing is for sure, if you install your system using only the needed length of coax, you can certainly ADD some later. I'm betting a dollar to a dozen doughnuts that it will not be necessary. Bob . . . ________________________________________________________________________________
Date: Mar 31, 2017
Garmin came out with the same requirement when the GNS-430W was approved. I believe they later reduced the minimum length to perhaps 6 ft. I suspect it has more to do with matching the output of the antenna pre-amplifier to the main receiver, and doesn't have a lot to do with signal strength at all. On 3/31/2017 7:16 AM, Robert L. Nuckolls, III wrote: > At 06:01 AM 3/30/2017, you wrote: >> >> I am installing an Appareo Stratus ESG transponder with internal GPS. >> It did not come with antenna cables. I purchased a 19 inch RG400 GPS >> antenna cable before reading the installation directions which state, >> "All wiring should have a cable loss of minimum 2 dB . . . .Using >> RG400 the minimum cable length is 10 feet". >> Will the GPS work satisfactorily with the short cable? If not, what >> is a cheap and easy way to increase the dB loss? What is the theory >> behind the requirement for at least 2 dB cable loss? > > I'm having trouble wrapping my head around this > requirement. GPS satellite signals are exceedingly > tiny . . . down in the atmospheric noise levels. > The only reason our tiny wrist-watch, hand-held, > and self-navigating drones work so well is because > the 'smarts' in GPS receiver software is looking for > specific patterns of data in the chaotic patternless > noise. > > Routine variations in received GPS signals > is all over the magnitude map spanning perhaps > tens of db . . . a required 2 db 'addition of > attenuation' simply doesn't make sense. > > The idea that a receiver's performance is > predicated on a minimum of 2db of loss in the > antenna system by making the cable longer is a > real puzzle . . . usually, the instructions will > say something like "limit cable losses to a MAXIMUM > of 2db where a 10' run of RG-400 is the practical > limit". > > I'm wondering if this manual wasn't originally crafted > in Chinese and then translated by some academic instead > of a systems engineer. > > One thing is for sure, if you install your system > using only the needed length of coax, you can certainly > ADD some later. I'm betting a dollar to a dozen doughnuts > that it will not be necessary. > > > Bob . . . > ________________________________________________________________________________
Date: Mar 31, 2017
This is not that unusual. My Garman GNS480 had the same requirement. Keep in mind that the antennas used are active antennas. Tim > On Mar 31, 2017, at 9:16 AM, Robert L. Nuckolls, III <nuckolls.bob@aeroele ctric.com> wrote: > > At 06:01 AM 3/30/2017, you wrote: >> >> I am installing an Appareo Stratus ESG transponder with internal GPS. It did not come with antenna cables. I purchased a 19 inch RG400 GPS antenna c able before reading the installation directions which state, "All wiring sho uld have a cable loss of minimum 2 dB . . . .Using RG400 the minimum cable l ength is 10 feet". >> Will the GPS work satisfactorily with the short cable? If not, what is a cheap and easy way to increase the dB loss? What is the theory behind th e requirement for at least 2 dB cable loss? > > I'm having trouble wrapping my head around this > requirement. GPS satellite signals are exceedingly > tiny . . . down in the atmospheric noise levels. > The only reason our tiny wrist-watch, hand-held, > and self-navigating drones work so well is because > the 'smarts' in GPS receiver software is looking for > specific patterns of data in the chaotic patternless > noise. > > Routine variations in received GPS signals > is all over the magnitude map spanning perhaps > tens of db . . . a required 2 db 'addition of > attenuation' simply doesn't make sense. > > The idea that a receiver's performance is > predicated on a minimum of 2db of loss in the > antenna system by making the cable longer is a > real puzzle . . . usually, the instructions will > say something like "limit cable losses to a MAXIMUM > of 2db where a 10' run of RG-400 is the practical > limit". > > I'm wondering if this manual wasn't originally crafted > in Chinese and then translated by some academic instead > of a systems engineer. > > One thing is for sure, if you install your system > using only the needed length of coax, you can certainly > ADD some later. I'm betting a dollar to a dozen doughnuts > that it will not be necessary. > > > Bob . . . ________________________________________________________________________________
Date: Mar 31, 2017
Bob, The first Garmin 430 install manuals stated nothing about the GPS antenna cable length. When the WAAS update was released Garmin stated that the GPS antenna had to be at least 13 feet long. It also stated that it was alright to "coil" the antenna. I know of two RV 10s with G 430s, o e with the 13 foot antenna cable and one with a 3 foot (roughly) anrenna cable. There is no detectable difference in performance. I have not checked the current G430 WAAS manual for cable length requirements. Don On Mar 31, 2017 7:26 AM, "Robert L. Nuckolls, III" < nuckolls.bob(at)aeroelectric.com> wrote: > At 06:01 AM 3/30/2017, you wrote: > > > I am installing an Appareo Stratus ESG transponder with internal GPS. It > did not come with antenna cables. I purchased a 19 inch RG400 GPS antenna > cable before reading the installation directions which state, "All wiring > should have a cable loss of minimum 2 dB . . . .Using RG400 the minimum > cable length is 10 feet". > Will the GPS work satisfactorily with the short cable? If not, what is > a cheap and easy way to increase the dB loss? What is the theory behind > the requirement for at least 2 dB cable loss? > > > I'm having trouble wrapping my head around this > requirement. GPS satellite signals are exceedingly > tiny . . . down in the atmospheric noise levels. > The only reason our tiny wrist-watch, hand-held, > and self-navigating drones work so well is because > the 'smarts' in GPS receiver software is looking for > specific patterns of data in the chaotic patternless > noise. > > Routine variations in received GPS signals > is all over the magnitude map spanning perhaps > tens of db . . . a required 2 db 'addition of > attenuation' simply doesn't make sense. > > The idea that a receiver's performance is > predicated on a minimum of 2db of loss in the > antenna system by making the cable longer is a > real puzzle . . . usually, the instructions will > say something like "limit cable losses to a MAXIMUM > of 2db where a 10' run of RG-400 is the practical > limit". > > I'm wondering if this manual wasn't originally crafted > in Chinese and then translated by some academic instead > of a systems engineer. > > One thing is for sure, if you install your system > using only the needed length of coax, you can certainly > ADD some later. I'm betting a dollar to a dozen doughnuts > that it will not be necessary. > > > Bob . . . > ________________________________________________________________________________
Date: Mar 31, 2017
My UPSAT 480 manual did mot list a cable length requirement. I used a 3 foot rg 400 csble and never had any issues with reception. On Mar 31, 2017 08:00, "Tim Olson" wrote: > This is not that unusual. My Garman GNS480 had the same requirement. > Keep in mind that the antennas used are active antennas. > Tim > > On Mar 31, 2017, at 9:16 AM, Robert L. Nuckolls, III < > nuckolls.bob(at)aeroelectric.com> wrote: > > At 06:01 AM 3/30/2017, you wrote: > > > I am installing an Appareo Stratus ESG transponder with internal GPS. It > did not come with antenna cables. I purchased a 19 inch RG400 GPS antenna > cable before reading the installation directions which state, "All wiring > should have a cable loss of minimum 2 dB . . . .Using RG400 the minimum > cable length is 10 feet". > Will the GPS work satisfactorily with the short cable? If not, what is > a cheap and easy way to increase the dB loss? What is the theory behind > the requirement for at least 2 dB cable loss? > > > I'm having trouble wrapping my head around this > requirement. GPS satellite signals are exceedingly > tiny . . . down in the atmospheric noise levels. > The only reason our tiny wrist-watch, hand-held, > and self-navigating drones work so well is because > the 'smarts' in GPS receiver software is looking for > specific patterns of data in the chaotic patternless > noise. > > Routine variations in received GPS signals > is all over the magnitude map spanning perhaps > tens of db . . . a required 2 db 'addition of > attenuation' simply doesn't make sense. > > The idea that a receiver's performance is > predicated on a minimum of 2db of loss in the > antenna system by making the cable longer is a > real puzzle . . . usually, the instructions will > say something like "limit cable losses to a MAXIMUM > of 2db where a 10' run of RG-400 is the practical > limit". > > I'm wondering if this manual wasn't originally crafted > in Chinese and then translated by some academic instead > of a systems engineer. > > One thing is for sure, if you install your system > using only the needed length of coax, you can certainly > ADD some later. I'm betting a dollar to a dozen doughnuts > that it will not be necessary. > > > Bob . . . > > ________________________________________________________________________________
Date: Mar 31, 2017
It seems that the minimum cable length is a requirement of the GPS receiver and not of the antenna. I agree with you Bob. I always thought that shorter cable length is better. I ordered 2 of 90 degree TNC adapters to increase the dB loss. eBay item number: 232142074744 Below is a quote from a separate unrelated company. Notice that they contradict themselves in the last sentence. http://utahscientific.com/support/protected/fb_contemp/GPS%20Installation%20V1_6.pdf > In the world of GPS; too much signal gain can be just as detrimental as too little, and RF noise, even if it is out of band, can severely disrupt the performance of your GPS application. > The Courtyard GPS receiver has a minimum input gain of 20dB and a maximum of 30dB. > The recommended antenna has a 26dB gain. > Recommended cable is RG58 and TNC connectors having a loss of 0.85dB per metre. > (RG174 has a loss of 1.2dB per meter.) > Maximum cable length is: (26dB-20dB)/0.85dBpermetre = 7.06 metres > Minimum cable length is: (30dB -26dB)/0.85dBpermetre = 4.70 meters > As a general rule, keep RF cable lengths as short as possible and use a good quality GPS antenna with the correct gain. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=467869#467869 ________________________________________________________________________________
Date: Mar 31, 2017
That is a fairly accurate statement correct. For others who have 'used' or 'seen' shorter cables work, indeed sometimes they do...but I lost count of the number of phone calls we've had from customers about antenna or GPS issues, only to find out they had a short little cable. Once extending the cable to the proper length most issues disappeared. Our recommendation is to keep it on the longer side - sometimes shorter than 10' will be ok, but something as short as 18" will almost certainly cause issues. Cheers, Stein -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Friday, March 31, 2017 9:38 AM Subject: Re: AeroElectric-List: Minimum GPS Antenna Cable Length --> Garmin came out with the same requirement when the GNS-430W was approved. I believe they later reduced the minimum length to perhaps 6 ft. I suspect it has more to do with matching the output of the antenna pre-amplifier to the main receiver, and doesn't have a lot to do with signal strength at all. On 3/31/2017 7:16 AM, Robert L. Nuckolls, III wrote: > At 06:01 AM 3/30/2017, you wrote: >> --> >> >> I am installing an Appareo Stratus ESG transponder with internal GPS. >> It did not come with antenna cables. I purchased a 19 inch RG400 GPS >> antenna cable before reading the installation directions which state, >> "All wiring should have a cable loss of minimum 2 dB . . . .Using >> RG400 the minimum cable length is 10 feet". >> Will the GPS work satisfactorily with the short cable? If not, >> what is a cheap and easy way to increase the dB loss? What is the >> theory behind the requirement for at least 2 dB cable loss? > > I'm having trouble wrapping my head around this > requirement. GPS satellite signals are exceedingly > tiny . . . down in the atmospheric noise levels. > The only reason our tiny wrist-watch, hand-held, > and self-navigating drones work so well is because > the 'smarts' in GPS receiver software is looking for > specific patterns of data in the chaotic patternless > noise. > > Routine variations in received GPS signals > is all over the magnitude map spanning perhaps > tens of db . . . a required 2 db 'addition of > attenuation' simply doesn't make sense. > > The idea that a receiver's performance is > predicated on a minimum of 2db of loss in the > antenna system by making the cable longer is a > real puzzle . . . usually, the instructions will > say something like "limit cable losses to a MAXIMUM > of 2db where a 10' run of RG-400 is the practical > limit". > > I'm wondering if this manual wasn't originally crafted > in Chinese and then translated by some academic instead > of a systems engineer. > > One thing is for sure, if you install your system > using only the needed length of coax, you can certainly > ADD some later. I'm betting a dollar to a dozen doughnuts > that it will not be necessary. > > > Bob . . . > ________________________________________________________________________________
Date: Mar 31, 2017
Below is a quote from Garmin: http://www.vansairforce.com/community/showpost.php?p=824265&postcount=3 > Once the antenna mounting position has been prepared, route the coax cable from the antenna to the 400W Series unit. Proper selection of coax cable and assembly of connectors is critical to GPS signal performance. The cable loss from the GPS antenna shall be between 1.5 dB and 6.5 dB in order to aintain proper rejection to interference signals. > The coaxial connectors and adapters, such as TNC to BNC, add additional loss to the cable and should be considered when computing the cable loss. A typical loss of 0.2 dB can be used for each connection. > NOTE: If RG-142B or RG-400 is used, 1.5 dB equates to a length of approximately 6.5 feet of cable with a connector on each end. RG-142B or RG-400 cable can be used as long as the length is less than 35 feet. Another website says, "Be kind to the 0.000 000 000 000 000 1 watt GPS signal at the Antenna !!" -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=467874#467874 ________________________________________________________________________________
Date: Mar 31, 2017
I think we may be losing sight of what signal we're actually talking about. It's extremely unlikely that the GPS antenna puck is sending raw, unamplified 1/5 GHZ RF to the receiver. Most GPS pucks send either decoded digital data (serial or USB), or amplified 1.5GHZ RF, or amplified and downconverted IF (intermediate frequency) to the receiver. If it's either of the 2nd two options, then the next stage (in the receiver) can be overdriven by a very strong signal from the puck. On 3/31/2017 10:57 AM, user9253 wrote: > > Below is a quote from Garmin: > http://www.vansairforce.com/community/showpost.php?p=824265&postcount=3 > >> Once the antenna mounting position has been prepared, route the coax cable from the antenna to the 400W Series unit. Proper selection of coax cable and assembly of connectors is critical to GPS signal performance. The cable loss from the GPS antenna shall be between 1.5 dB and 6.5 dB in order to aintain proper rejection to interference signals. >> The coaxial connectors and adapters, such as TNC to BNC, add additional loss to the cable and should be considered when computing the cable loss. A typical loss of 0.2 dB can be used for each connection. >> NOTE: If RG-142B or RG-400 is used, 1.5 dB equates to a length of approximately 6.5 feet of cable with a connector on each end. RG-142B or RG-400 cable can be used as long as the length is less than 35 feet. > Another website says, "Be kind to the 0.000 000 000 000 000 1 watt GPS signal at the Antenna !!" > > -------- > Joe Gores > ________________________________________________________________________________
Date: Mar 31, 2017
I will follow Stein's (and the Mfg's) recommendation and will use a 10 foot cable. They are the experts. It will be a lot easier to do it right the first time. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=467885#467885 ________________________________________________________________________________
From: William Hunter <billhuntersemail(at)gmail.com>
Date: Mar 31, 2017
Subject: Thermocouple Wires
Hi all , Are thermocouple units polarized? In other words does it matter when connecting up a thermocouple to a dynon EMS unit what wire goes in what pin? THANKS!!! ________________________________________________________________________________
Subject: Re: Thermocouple Wires
Date: Mar 31, 2017
>From the SkyView Installation Manual: > Polarity is important, so > ensure that you are routing the positive side (yellow for K-type; white for J-type) of the thermocouple to pin 27 or pin 36 on the 37-pin harness, and the negative side to pin 28 or pin 37 Note that the red wire from type J thermocouples is NOT positive, but is negative. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=467898#467898 ________________________________________________________________________________
Date: Apr 01, 2017
Thanks!!!! On Mar 31, 2017 7:03 PM, "user9253" wrote: > > >From the SkyView Installation Manual: > > Polarity is important, so > > ensure that you are routing the positive side (yellow for K-type; white > for J-type) of the thermocouple to pin 27 or pin 36 on the 37-pin harness, > and the negative side to pin 28 or pin 37 > > Note that the red wire from type J thermocouples is NOT positive, but is > negative. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=467898#467898 > > ________________________________________________________________________________
Date: Apr 01, 2017
Subject: Installing Mesh Sleeving
Folks, I am going to use some mesh sleeving to protect some coax in a couple of places. Do I need to do anything to the ends of the mesh sleeving after cutting it? Do I have to worry about it unraveling or anything? Thanks, -- Art Z. -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Date: Apr 01, 2017
I am going to use some mesh sleeving to protect some coax in a couple of pl aces. Do I need to do anything to the ends of the mesh sleeving after cutti ng it? Do I have to worry about it unraveling or anything? Art, A piece of shrink sleeving on each end works well. Roger ________________________________________________________________________________
Date: Apr 01, 2017
Subject: Re: Installing Mesh Sleeving
On Sat, Apr 1, 2017 at 12:58 PM, Art Zemon wrote: > Folks, > > I am going to use some mesh sleeving to protect some coax in a couple of > places. Do I need to do anything to the ends of the mesh sleeving after > cutting it? Do I have to worry about it unraveling or anything? > > Thanks, > -- Art Z.Brand/part # ? > > I'm using some TechFlex brand in two different varieties; one says it's > 'fray resistant' when cut with scissors and the other recommends hot knife > cutting to fuse the ends. (Both are better if the ends are melted slightly.) > > https://smile.amazon.com/gp/product/B00C1OMARY/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1 > > > https://smile.amazon.com/gp/product/B0008JHB0K/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1 > > The use instructions with your product should tell you if it's required, > but playing with a sample is the best way to know. > > Charlie > ________________________________________________________________________________
Date: Apr 01, 2017
I used heat shrink tubing Sent from my iPhone > On Apr 1, 2017, at 1:58 PM, Art Zemon wrote: > > Folks, > > I am going to use some mesh sleeving to protect some coax in a couple of p laces. Do I need to do anything to the ends of the mesh sleeving after cutti ng it? Do I have to worry about it unraveling or anything? > > Thanks, > -- Art Z. > > -- > https://CheerfulCurmudgeon.com/ > > "If I am not for myself, who is for me? And if I am only for myself, what a m I? And if not now, when?" Hillel ========================== ========================== ========================== -========================= ========================== -========================= ========================== ========================== ==================== ________________________________________________________________________________
Date: Apr 02, 2017
Thanks, Charlie and Roger. I don't know the exact model number. I bought 15 feet of the stuff from the local electronics supply emporium. I played a bit and found that a quick pass through the gas stove flame keeps the end from fraying and still allows the opening to expand/contract. Cheers, -- Art Z. -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Date: Apr 02, 2017
The way I do it is that I cut it with the mesh over a piece of pipe about the same diameter as the final size. This isn't critical, but it's way I do it. Then I use an old soldering iron to melt through the mesh. Won't unravel and it will still expand and contract. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=467954#467954 ________________________________________________________________________________
Date: Apr 03, 2017
Subject: Lithium Webinar
Because there is interest on this list I thought it might be appropriate to post that there is an upcoming EAA Webinar on the subject of lithium batteries: http://pages.eaa.org/WBN2017-05-31LithiumBatteriesExplained_LP-Registration.html Ken ________________________________________________________________________________
Subject: old B and C SD-8 Dynamo failure
Date: Apr 03, 2017
Well, after 27 years and 2300+ hours, my good old SD-8 dynamo finally gave me a problem. It was installed in my day/VFR RV4 in 1989 as the only charging source. It could produce up to 8.6 amps at high RPM and met my modest electrical load requirements (<4 amps in cruise) for all these years. Of course, I could expect my low voltage light to come on (at 12.5V) at low rpms depending on the loads. I didn't mind. It made for a nice reminder to turn off my boost pump as I exited the runway on landing. On a recent flight, I noticed that the low voltage light came on a little earlier than I expected on landing. At high RPM, the voltage was only going to 13.9 instead of the usual 14.1V. A quick run through my switchable loads showed they were pulling their expected currents. I have a switchable volt/amp gauge on my panel so I can look at one or the other but not both simultaneously. The amp readings are taken off my B lead and it takes several seconds for the amp reading to stabilize on my gauge after it's selected. I never saw an unexpectedly high amp reading on the gauge. Back at the hangar, a brief look at my B lead connections didn't reveal any problems. On the next flight, the low voltage light came on even sooner and the voltage only got to 13.7V. A more detailed inspection was made of the wiring, including micro-ohming some connections (using Bob's 100mA current clamp micro-ohmmeter design I've enjoyed using for several years). I thought I detected a little bit of a burnt electrical smell near the dynamo housing where the armature leads pass through a clip screwed into the rim of the housing. Using a cheap digital multimeter, I checked the resistance across the disconnected dynamo leads and got 5.6 ohms. Not sure what it's suppose to be. I flew the plane again and this time, I got a low voltage light in cruise and zero B lead amps when checked. I checked the resistance across the dynamo leads again with the same meter.. and got a reading of zero. My micro-ohm meter said it was about 700 milliohms. I bought a new SD-8 and am back in the air trouble free. Since removing the problem unit, I removed the clip that held the leads at the rim of the dynamo housing and slid the protective sheathing back. The lead wires look fine, including the half-inch of wire I can see inside the housing. The resistance across the leads remains 'zero' when checked with another cheap digital mulitmeter. I concluded that I had probably experienced a progressive short within the dynamo, probably in the windings themselves. This dynamo was from the 1980's and the exterior design has changed a lot since then. This includes a protected routing of the leads out of the dynamo housing with a better clamping system. The insides have probably changed as well. Lord knows the new unit is easier to install with much better access to the mounting nuts. I have no complaints about this SD-8 failure. I certainly got a reasonable service life out of this unit. I just thought I'd share my story as just one more data point, although I appreciate it's kinda ancient history. I'm planning on taking the dynamo apart (curiosity) and maybe salvaging the magnets. Bob, if you wanted to look at this dynamo for some reason, I'll be happy to mail it to you. I suspect you've got much better things to do than 'paleo-forensics' on this dated item. Mark ________________________________________________________________________________
Subject: Re: old B and C SD-8 Dynamo failure
Date: Apr 04, 2017
The saying, "Ring it out", when referring to electrical testing, got its beginnings when troubleshooters used a doorbell for testing electrical motors. There is not much difference in resistance between a good motor and one with a shorted winding. But there is a difference in the inductance. An experienced electrician could tell the difference in doorbell sound when connected in series with a shorted motor winding compared to a good winding. Modern doorbells are not suitable for this task. The doorbell must be of the old fashioned clanger and bell type. This information might be of use to you 27 years from now when your new SD-8 dynamo malfunctions. :-) -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468022#468022 ________________________________________________________________________________
Date: Apr 04, 2017
> >I have no complaints about this SD-8 failure. I certainly got a >reasonable service life out of this unit. I just thought I'd share my >story as just one more data point, although I appreciate it's kinda >ancient history. I'm planning on taking the dynamo apart (curiosity) >and maybe salvaging the magnets. Are the windings smoked? Do they smell bad? The DC resistance of this product is less than 0.25 ohms. So if you had a shorted turn or two, you could not resolve it with jelly-bean test equipment. The magnets are ferrites . . . rather brittle. You probably couldn't get them loose without breaking them up. >Bob, if you wanted to look at this dynamo for some reason, I'll be happy >to mail it to you. I suspect you've got much better things to do than >'paleo-forensics' on this dated item. > >Mark Actually, I would like to see it. I have a drive stand running that fits the SD8 and I'm equipped to test/inspect it in detail. Getting a close up look at a sample with this kind of service on it would be illuminating. Send the rectifier/regulator too. I'll get them checked out and repaired/replaced as needed. Bob . . . ________________________________________________________________________________
Date: Apr 04, 2017
Hi Mark; Hi All; I read this as an endorsement, not a complaint. Who gets 27 years of operation from a car, washing machine, or computer? It gives me great confidence in B & C products. Cheers! Stu. ----- Original Message ----- From: "Mark Todd" <motodd(at)frontier.com> Sent: Monday, April 3, 2017 10:32:48 PM Subject: AeroElectric-List: old B and C SD-8 Dynamo failure Well, after 27 years and 2300+ hours, my good old SD-8 dynamo finally gave me a problem. It was installed in my day/VFR RV4 in 1989 as the only charging source. It could produce up to 8.6 amps at high RPM and met my modest electrical load requirements (<4 amps in cruise) for all these years. Of course, I could expect my low voltage light to come on (at 12.5V) at low rpms depending on the loads. I didn't mind. It made for a nice reminder to turn off my boost pump as I exited the runway on landing. On a recent flight, I noticed that the low voltage light came on a little earlier than I expected on landing. At high RPM, the voltage was only going to 13.9 instead of the usual 14.1V. A quick run through my switchable loads showed they were pulling their expected currents. I have a switchable volt/amp gauge on my panel so I can look at one or the other but not both simultaneously. The amp readings are taken off my B lead and it takes several seconds for the amp reading to stabilize on my gauge after it's selected. I never saw an unexpectedly high amp reading on the gauge. Back at the hangar, a brief look at my B lead connections didn't reveal any problems. On the next flight, the low voltage light came on even sooner and the voltage only got to 13.7V. A more detailed inspection was made of the wiring, including micro-ohming some connections (using Bob's 100mA current clamp micro-ohmmeter design I've enjoyed using for several years). I thought I detected a little bit of a burnt electrical smell near the dynamo housing where the armature leads pass through a clip screwed into the rim of the housing. Using a cheap digital multimeter, I checked the resistance across the disconnected dynamo leads and got 5.6 ohms. Not sure what it's suppose to be. I flew the plane again and this time, I got a low voltage light in cruise and zero B lead amps when checked. I checked the resistance across the dynamo leads again with the same meter.. and got a reading of zero. My micro-ohm meter said it was about 700 milliohms. I bought a new SD-8 and am back in the air trouble free. Since removing the problem unit, I removed the clip that held the leads at the rim of the dynamo housing and slid the protective sheathing back. The lead wires look fine, including the half-inch of wire I can see inside the housing. The resistance across the leads remains 'zero' when checked with another cheap digital mulitmeter. I concluded that I had probably experienced a progressive short within the dynamo, probably in the windings themselves. This dynamo was from the 1980's and the exterior design has changed a lot since then. This includes a protected routing of the leads out of the dynamo housing with a better clamping system. The insides have probably changed as well. Lord knows the new unit is easier to install with much better access to the mounting nuts. I have no complaints about this SD-8 failure. I certainly got a reasonable service life out of this unit. I just thought I'd share my story as just one more data point, although I appreciate it's kinda ancient history. I'm planning on taking the dynamo apart (curiosity) and maybe salvaging the magnets. Bob, if you wanted to look at this dynamo for some reason, I'll be happy to mail it to you. I suspect you've got much better things to do than 'paleo-forensics' on this dated item. Mark ________________________________________________________________________________
Subject: MGL CHT probe
Date: Apr 04, 2017
I recently purchased the MGL 18mm spark plug CHT probes from Aircraft Spruce. The photo on both their website and MGL's shows a copper ring soldered to a K-type thermocouple wire, a pretty standard setup. What they sent me is pictured below. Since the bare wire ends connect directly to the RDAC brain box, I deduced that the other end- a 1/4 PIDG fast-on, crimped to the thermocouple wires- must just attach to the copper ring. The tab end of the copper ring is exactly 1/4 inch, so this makes sense. This seems like a pretty cheeseball setup. From what I know of K-type thermocouples (mostly from reading the 'Connection) that wires must be silver soldered to the probe and to each other. Or, am I mistaken and is this a reasonable setup? I am also reaching out to MGL about this, but I thought I'd ping this group for your thoughts as well. Thanks Jeff Point Milwaukee ________________________________________________________________________________
Date: Apr 04, 2017
Subject: K Type Thermocouple Wire Striping
Hi All, How does one (me) strip K Type Thermocouple Wires. The wire I bought from eBay Aircraft Supply has a metal shield and two wires inside that appear to be covered with some kind of a fabric type insulator. The metal shield can be stripped back with a pick, bandaids, and some bad words. The two inner wires insulation do not strip back with a mechanical wire stripper and if I use a razor blade the fabric insulation will simply unravel like a sweater thread. There has got to be a better way?!?!? Thanks, Bill Hunter On Apr 4, 2017 8:55 PM, "Jeff Point" wrote: I recently purchased the MGL 18mm spark plug CHT probes from Aircraft Spruce. The photo on both their website and MGL's shows a copper ring soldered to a K-type thermocouple wire, a pretty standard setup. What they sent me is pictured below. Since the bare wire ends connect directly to the RDAC brain box, I deduced that the other end- a 1/4 PIDG fast-on, crimped to the thermocouple wires- must just attach to the copper ring. The tab end of the copper ring is exactly 1/4 inch, so this makes sense. This seems like a pretty cheeseball setup. From what I know of K-type thermocouples (mostly from reading the 'Connection) that wires must be silver soldered to the probe and to each other. Or, am I mistaken and is this a reasonable setup? I am also reaching out to MGL about this, but I thought I'd ping this group for your thoughts as well. Thanks Jeff Point Milwaukee ________________________________________________________________________________
Subject: Re: MGL CHT probe
Date: Apr 05, 2017
> On Apr 4, 2017, at 11:42 PM, Jeff Point wrote: > > This seems like a pretty cheeseball setup. =46rom what I know of K-type thermocouples (mostly from reading the 'Connection) that wires must be silver soldered to the probe and to each other. Or, am I mistaken and is this a reasonable setup? What you have will probably work just fine but yes, the high dollar thermocouples usually silver-solder the wires to the copper ring and incorporate a support (pic), however they=99re amazingly expensive. Silver-soldering is a good skill to learn and does not take much more than a propane torch and the proper materials. Here are a couple I made as an experiment (2nd pic). They use copper sparkplug gaskets and a piece of stainless welding wire as the support. A =9Cresist=9D is a material applied to the parts that you don=99t want the solder to flow onto. Wite-out makes a pretty good resist. The tricky part is jigging the parts while you heat them. This place has all the supplies and there are many Youtube videos. https://contenti.com Time or money, take your choice. :-) -Kent ________________________________________________________________________________
Date: Apr 05, 2017
Subject: Re: Lithium Webinar
At 05:34 PM 4/3/2017, you wrote: >Because there is interest on this list I thought it might be >appropriate to post that there is an upcoming EAA Webinar on the >subject of lithium batteries: > ><http://pages.eaa.org/WBN2017-05-31LithiumBatteriesExplained_LP-Registration.html>http://pages.eaa.org/WBN2017-05-31LithiumBatteriesExplained_LP-Registration.html Thanks for the heads-up! I'll check it out . . . Bob . . . ________________________________________________________________________________
Date: Apr 05, 2017
> Are the windings smoked? Do they smell bad? I thought there was a burnt smell from the dynamo before I pulled it off the engine. Here at my bench, is smells fine. Now I wonder if that burnt smell was from something else in that 2300+ hour engine compartment. > > The DC resistance of this product is less than > 0.25 ohms. So if you had a shorted turn or two, > you could not resolve it with jelly-bean test > equipment. The magnets are ferrites . . . rather > brittle. You probably couldn't get them loose > without breaking them up. OK. > > >> Bob, if you wanted to look at this dynamo for some reason, I'll be happy >> to mail it to you. I suspect you've got much better things to do than >> 'paleo-forensics' on this dated item. >> >> Mark > Actually, I would like to see it. I have > a drive stand running that fits the SD8 > and I'm equipped to test/inspect it in > detail. Getting a close up look at a sample > with this kind of service on it would be > illuminating. > > Send the rectifier/regulator too. I'll > get them checked out and repaired/replaced > as needed. > > > Bob . . . I'll get the dynamo and regulator off to you within the next couple of days, using your PO Box 130 address unless you instruct otherwise. Thanks for looking at this. If it checks out OK, I guess it'll mean that I missed a faulty connection somewhere that got cleared up with the replacement. After all these years of flawless service, I can't decide whether I'm rooting for the dynamo or me! Mark ________________________________________________________________________________
Date: Apr 06, 2017
> > >I'll get the dynamo and regulator off to you within the next couple of >days, using your PO Box 130 address unless you instruct otherwise. > >Thanks for looking at this. If it checks out OK, I guess it'll mean >that I missed a faulty connection somewhere that got cleared up with the >replacement. After all these years of flawless service, I can't decide >whether I'm rooting for the dynamo or me! Thank YOU for making it available. It's a rare treat to get field returns on mature designs for evaluation. Products I designed at Electro-Mech were routinely serviced in house as E-M was the only FAA qualified overhaul and repair shop for those products . . . I was able to visit my former colleagues at E-M and look through the R/R records. In the OBAM aviation world it's more difficult to access such data. Bob . . . ________________________________________________________________________________
Date: Apr 06, 2017
Subject: Today's trivia dump . . .
I think I've written about a project to repeat the experiment I did on AA alkaline cells 14 years ago . . . http://tinyurl.com/mhztc2b I've been keeping a constellation of AA-cell products in the super-duper-battery-runner-downer for several weeks and at first blush at most of the data, the original deductions about alkaline cell quality vs. costs and advertising hype haven't changed. There are a couple interesting things I've discovered that I'll share with the List. There's a line of alkaline cells purported to be enhanced with lithium. A noteworthy example is the Energizer 'Advanced Lithium' brand. These are not lithium-ion cells . . . they still present the expected 1.6 volt/cell open circuit potential as their rudimentary cousins but unlike MOST 'enhanced formulas' these do indeed offer improved performance in the same envelope. The energy traces below show a generic pair of alkaline AA cells that have delivered ~1.4 Watt-Hrs of energy . . . about the same numbers as the first experiment in 2002. Then we have a trio of traces that have delivered 3.6 Watt-Hrs of energy or about 2.5 times that of the non-lithium cell. There are three additional traces of interest . . . they too are generated by the discharge test of some advanced lithium cells. The general shape of the curves are the same as for the first three described above . . . but they averaged a 15% lower value of delivered energy and the output voltage is 'ragged' or unstable. Emacs! This is caused by tiny amounts of resistance introduced by the connections to the test equipment that can arise when the cells are connected with the spring-loaded holders common to 99.999% of all cylindrical cell powered products. Emacs! These resistance values are small . . . and generally have little effect on appliance performance for applications with smaller current demands. The tests I'm conducting use a 300 mA constant current discharge rate. At this rate . . . and anything higher . . . there is a potential for battery holder resistance to degrade system performance. This fact is part of the foundation for why I explored and ultimately recommended the 9v alkaline cells in a standby battery application a few days ago. The very low current demand in the application under discussion did not exclude the 9V cell. Obviously, the AA cell offers a larger energy bucket for such tasks . . . but getting a firm electrical grip on the cell's electrical energy is a bit more problematic. My energy studies are being conducted with cells having SOLDERED leads eliminating the holder issues . . . indeed, one could build up disposable cell arrays using similar techniques. But they need to be done with care lest the cells be damaged by soldering heat. It would be really cool to use tab-welders common the Ni-Mh and Li-Ion arrays. The AA alkaline cell has a really small (+) terminal . . . more difficult to weld on. I have some alkaline D-cell arrays for video cameras that were welded . . . but the AA-cell is more problematic. I may do an article on the techniques I use for soldering to AA-cell . . . it's not difficult. It seems that the past few weeks discoveries in my AA-cell testing offer another choice for DIY standby battery construction. As soon as I've squashed all the energy out of the current constellation of test articles, I'll do some testing on the effects of soldered leads. Watch this space . . . Bob . . . ________________________________________________________________________________
Subject: Re: Today's trivia dump . . .
Date: Apr 06, 2017
Good to see some quantified info on the advanced li alkalines. While I've soldered a number of tabs on alkaline batteries it seems that DIY tab welders are somewhat common for building battery packs. In the crudest form, just two handheld copper wire "electrodes" fed by a lead acid battery. More advanced units are AC powered using a few volts from a couple of secondary turns on an old transformer and timed current pulses. Two pulses of 50 ms or so each from what I've learned so far. Ken ________________________________________________________________________________
Date: Apr 06, 2017
--- MIME Errors - No Plain-Text Section Found --- A message with no text/plain MIME section was received. The entire body of the message was removed. Please resend the email using Plain Text formatting. HOTMAIL is notorious for only including an HTML section in their client's default configuration. If you're using HOTMAIL, please see your email application's settings and switch to a default mail option that uses "Plain Text". --- MIME Errors No Plain-Text Section Found --- ________________________________________________________________________________
Date: Apr 06, 2017
For anyone interested in this project, search YouTube for "MOT spot welder" and you'll find a number of videos on the subject of using a microwave oven transformer (MOT) to build a spot welder. Eric > On Apr 6, 2017, at 11:10 AM, C&K wrote: > While I've soldered a number of tabs on alkaline batteries it seems that DIY tab welders are somewhat common for building battery packs. In the crudest form, just two handheld copper wire "electrodes" fed by a lead acid battery. More advanced units are AC powered using a few volts from a couple of secondary turns on an old transformer and timed current pulses. Two pulses of 50 ms or so each from what I've learned so far. ________________________________________________________________________________
From: Stuart Hutchison <stuart(at)stuarthutchison.com.au>
Date: Apr 07, 2017
At around 3200mAh, the energy density of typical Lithium primary (non-rechargeable) cells - which are not the same as Li-Ion secondary (rechargeable) technology - is only about 15% more than a typical quality Alkaline cell (about 2800mAh). The reason for the claims of 5-7 times longer lasting in high-energy devices is the C-rate. In other words, Lithium cells can deliver their stored potential at a higher rate of current without increasing internal resistance and getting hot. Energy can neither be created nor destroyed, so when Alkaline cells used in high-energy devices get hot, the heat represents a =98loss=99 or waste of stored energy from the cell itself. So, it is not that Lithium cells have 5-7 times more stored energy density (commensurate with the price difference), but Lithium cells can deliver much more of their energy without the wasting it as heat. Putting Lithium batteries in a very low drain wall-mounted clock would be pointless, but in my Infra-Red Night Vision hunting scope they are excellent value for money. V/R Stu > On 7 Apr 2017, at 04:10, wrote: > > Bob, > > Thanks for this update. I had been really wondering if those Energizer "Advanced Lithium" batteries were worth the extra cost. I just did a lookup on Amazon to find the current pricing for the AA cells =93 seems to be around $1.27 each (cheapest I could find). By comparison, the Kirkland brand alkaline cells from CostCo run about $0.25 per cell. Even if the "Lithium" cells last 3 times longer, they still cost 5 times as much! Looks like your old advice from 2002 still rings true: "Buy cheap and change often!" > > By the way, I recently went on a lengthy cross-country trip in my '65 Champion 7ECA (pre-dates the "Citabria" name...) only to have the PTT wiring under the stick the short out. That gave me a "hot mike" until I shut off the aircraft radio. I switched over to my SP-400, which had an alkaline battery pack installed that had already been used for 4+ hours last year at OSH (listening to the Sunday arrivals). That pack lasted another 4+ hours of "normal" use in the cockpit before the SP-400 would no longer transmit. I keep a spare battery pack loaded and ready to go (the only reason I didn't put new batteries in the 1st pack), so I switched to the new pack to complete the flight. The "new" batteries show a "full" charge on the SP-400 battery meter after about an hour of use in flight. > > By the way, with the SP-400 connected to a dedicated coax and external VHF comm antenna and a headset adapter, I was able to talk to both enroute ATC and our local tower from 15 miles away pretty clearly, with only a bit of "scratchiness" at 20 miles (still understandable to them, though). Reception-only range was well over 30 miles. > > Jim Parker > > > -------- Original Message -------- > Subject: AeroElectric-List: Today's trivia dump . . . > From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com > > Date: Thu, April 06, 2017 11:29 am > To: aeroelectric-list(at)matronics.com > > I think I've written about a project to repeat the > experiment I did on AA alkaline cells 14 years ago . . . > > http://tinyurl.com/mhztc2b > > I've been keeping a constellation of AA-cell products > in the super-duper-battery-runner-downer for several > weeks and at first blush at most of the data, the > original deductions about alkaline cell quality vs. > costs and advertising hype haven't changed. > > There are a couple interesting things I've discovered > that I'll share with the List. > > There's a line of alkaline cells purported to be > enhanced with lithium. A noteworthy example is > the Energizer 'Advanced Lithium' brand. These > are not lithium-ion cells . . . they still present > the expected 1.6 volt/cell open circuit potential > as their rudimentary cousins but unlike MOST 'enhanced > formulas' these do indeed offer improved performance in the > same envelope. > > The energy traces below show a generic pair of alkaline > AA cells that have delivered ~1.4 Watt-Hrs of energy . . . > about the same numbers as the first experiment in 2002. > > Then we have a trio of traces that have delivered 3.6 > Watt-Hrs of energy or about 2.5 times that of the > non-lithium cell. > > There are three additional traces of interest . . . they > too are generated by the discharge test of some advanced > lithium cells. The general shape of the curves are the > same as for the first three described above . . . but they > averaged a 15% lower value of delivered energy and the output > voltage is 'ragged' or unstable. > > > <13684fd9.jpg> > > This is caused by tiny amounts of resistance introduced > by the connections to the test equipment that can arise when > the cells are connected with the spring-loaded holders > common to 99.999% of all cylindrical cell powered products. > > <13685027.jpg> > > These resistance values are small . . . and generally have > little effect on appliance performance for applications > with smaller current demands. The tests I'm conducting use > a 300 mA constant current discharge rate. At this rate . . . > and anything higher . . . there is a potential for battery > holder resistance to degrade system performance. > > This fact is part of the foundation for why I explored > and ultimately recommended the 9v alkaline cells in a standby > battery application a few days ago. The very low current > demand in the application under discussion did not exclude > the 9V cell. > > Obviously, the AA cell offers a larger energy bucket for > such tasks . . . but getting a firm electrical grip on > the cell's electrical energy is a bit more problematic. > > My energy studies are being conducted with cells having > SOLDERED leads eliminating the holder issues . . . > indeed, one could build up disposable cell arrays using > similar techniques. But they need to be done with care > lest the cells be damaged by soldering heat. > > It would be really cool to use tab-welders common the Ni-Mh > and Li-Ion arrays. The AA alkaline cell has a really small > (+) terminal . . . more difficult to weld on. I have some > alkaline D-cell arrays for video cameras that were welded . . . > but the AA-cell is more problematic. > > I may do an article on the techniques I use for soldering > to AA-cell . . . it's not difficult. > > It seems that the past few weeks discoveries in my AA-cell > testing offer another choice for DIY standby battery > construction. As soon as I've squashed all the energy > out of the current constellation of test articles, I'll > do some testing on the effects of soldered leads. > > Watch this space . . . > > Bob . . . ________________________________________________________________________________
Date: Apr 06, 2017
At 04:31 PM 4/6/2017, you wrote: >At around 3200mAh, the energy density of typical >Lithium primary (non-rechargeable) cells - which >are not the same as Li-Ion secondary >(rechargeable) technology - is only about 15% >more than a typical quality Alkaline cell (about >2800mAh). The reason for the claims of 5-7 >times longer lasting in high-energy devices is >the C-rate. In other words, Lithium cells can >deliver their stored potential at a higher rate >of current without increasing internal >resistance and getting hot. Energy can neither >be created nor destroyed, so when Alkaline cells >used in high-energy devices get hot, the heat >represents a =98loss=99 or waste of stored >energy from the cell itself. So, it is not that >Lithium cells have 5-7 times more stored energy >density (commensurate with the price >difference), but Lithium cells can deliver much >more of their energy without the wasting it as >heat. Putting Lithium batteries in a very low >drain wall-mounted clock would be pointless, but >in my Infra-Red Night Vision hunting scope they are excellent value for money. > >V/R Stu I have encountered AA cells offered with creative advertising hyperbole . . . and found them to be short on snort. However, the cells I posted about earlier today were discharged on an well instrumented, 300 mA constant current load. So irrespective of the cell's c-rate, I was comparing the various offerings under identical test conditions. I'll do some more detailed comparisons of these cells and get some internal resistance measurements at various points along their discharge profiles. Bob . . . ________________________________________________________________________________
Date: Apr 06, 2017
At 04:11 PM 4/6/2017, you wrote: > >For anyone interested in this project, search YouTube for "MOT spot >welder" and you'll find a number of videos on the subject of using a >microwave oven transformer (MOT) to build a spot welder. I've seen those . . . while economical in terms of purchased materials, they're kinda labor intensive. I'm toying with the notion of trying one of these. http://tinyurl.com/knl5wrf Bob . . . ________________________________________________________________________________
Date: Apr 06, 2017
Indeed; plus the dangers inherent in a mains-powered project. I hadn't yet seen the eBay item you linked. The Chinese manufacturers never cease to amaze with their ability to crank out high-dollar items at bargain basement prices. This got me thinking about a simple way to accomplish this with stuff we might have on hand at the bench or could get cheap-and-quick. With the idea that lead-acid batteries are ubiquitous, safe and able to provide ample current to weld the tiny spots needed to secure battery tabs, here's what I came up with: http://preview.tinyurl.com/knz5te2 ...using a solenoid like this: http://preview.tinyurl.com/n88f7tl This could probably be lashed together in half an hour, for a few dollars in parts. Thoughts? Eric Robert L. Nuckolls, III wrote: > > I've seen those . . . while economical in terms of purchased materials, they're kinda labor intensive. I'm toying with the notion of trying one of these. > > http://tinyurl.com/knl5wrf > > Bob . . . Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468112#468112 ________________________________________________________________________________
Date: Apr 07, 2017
At 01:09 AM 4/7/2017, you wrote: > >Indeed; plus the dangers inherent in a mains-powered project. > >I hadn't yet seen the eBay item you linked. The Chinese >manufacturers never cease to amaze with their ability to crank out >high-dollar items at bargain basement prices. > >This got me thinking about a simple way to accomplish this with >stuff we might have on hand at the bench or could get >cheap-and-quick. With the idea that lead-acid batteries are >ubiquitous, safe and able to provide ample current to weld the tiny >spots needed to secure battery tabs, here's what I came up with: > >http://preview.tinyurl.com/knz5te2 This is almost exactly what I crafted to replace the failed pulse controller on a friend's spot welder some years ago. This was an AC welder so I could use a photo coupled triac to control primary supply current. The only questions that come to mind immediately about the battery+contactor configuration is the ability to control pulse current as well . . . some high current resistors (i've used coils of steel clothesline wire). Also, you may want to craft your solenoid driver to withstand the inductive kick inherent in the solenoid's windings. Adding a diode causes a large contactor increase in drop-out-delay which MIGHT affect your selection of optimum current x time . . . or not. But the thing is worth pursuing . . . we could do an Eric's Shop Notes page on the website to assist others in repeating a useful experiment. Bob . . . ________________________________________________________________________________
Date: Apr 07, 2017
At 01:10 PM 4/6/2017, you wrote: >Bob, > >Thanks for this update. I had been really >wondering if those Energizer "Advanced Lithium" >batteries were worth the extra cost. I just did >a lookup on Amazon to find the current pricing >for the AA cells ' seems to be around $1.27 each >(cheapest I ccould find). By comparison, the >Kirkland brand alkaline cells from CostCo run >about $0.25 per cell. Even if the "Lithium" >cells last 3 times longer, they still cost 5 >times as much! Looks like your old advice from >2002 still rings true: "Buy cheap and change often!" Agreed . . . but with this 'special case'. As a primary cell standby battery, cost of ownership has to include a significant $time$ expense. It occurs to me that a welded (or carefully soldered) array of these more robust cells might well offer an attractive option for keeping these nifty little panel appliances running in situations where our preventative maintenance and/or less than artfully conducted FMEA does trigger a black-panel- syndrome. 'Standby' batteries have been an intuitively seductive idea since the first panel mounted electro-whizzy was installed on an airplane. As we've discussed on the List many times over the years, bad days in the cockpit are rarely based on loss of electrical power . . . and when they do include total electrical failure, we have generally deduced root cause to be something OTHER than deficient hardware. System architecture and/or pilot ignorance plays a major role in virtually every dark-n-stormy night story published in the popular aviation rags. The alkaline AA cell is a demonstrably robust and predictable source of energy. In the very first edition of the 'Connection, I suggested DIY arrays of alkaline D-cells as a potential back-up source. In the 25+ years since, energy requirements for some useful appliances are so low that the lowly 9v transistor radio battery becomes a EMF to consider . . . with attractive cost, weight, volume and performance ratios. This exploration into a world of flight forced into Plan-C operations SHOULD be more academic than practical . . . but it sounds like fun. Bob . . . ________________________________________________________________________________
Date: Apr 07, 2017
Hi Bob; Hi All; This is good work that you do. Much preferable to trusting manufacturer's hype. Cheers! Stu. ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Sent: Thursday, April 6, 2017 9:29:08 AM Subject: AeroElectric-List: Today's trivia dump . . . I think I've written about a project to repeat the experiment I did on AA alkaline cells 14 years ago . . . http://tinyurl.com/mhztc2b I've been keeping a constellation of AA-cell products in the super-duper-battery-runner-downer for several weeks and at first blush at most of the data, the original deductions about alkaline cell quality vs. costs and advertising hype haven't changed. There are a couple interesting things I've discovered that I'll share with the List. There's a line of alkaline cells purported to be enhanced with lithium. A noteworthy example is the Energizer 'Advanced Lithium' brand. These are not lithium-ion cells . . . they still present the expected 1.6 volt/cell open circuit potential as their rudimentary cousins but unlike MOST 'enhanced formulas' these do indeed offer improved performance in the same envelope. The energy traces below show a generic pair of alkaline AA cells that have delivered ~1.4 Watt-Hrs of energy . . . about the same numbers as the first experiment in 2002. Then we have a trio of traces that have delivered 3.6 Watt-Hrs of energy or about 2.5 times that of the non-lithium cell. There are three additional traces of interest . . . they too are generated by the discharge test of some advanced lithium cells. The general shape of the curves are the same as for the first three described above . . . but they averaged a 15% lower value of delivered energy and the output voltage is 'ragged' or unstable. This is caused by tiny amounts of resistance introduced by the connections to the test equipment that can arise when the cells are connected with the spring-loaded holders common to 99.999% of all cylindrical cell powered products. These resistance values are small . . . and generally have little effect on appliance performance for applications with smaller current demands. The tests I'm conducting use a 300 mA constant current discharge rate. At this rate . . . and anything higher . . . there is a potential for battery holder resistance to degrade system performance. This fact is part of the foundation for why I explored and ultimately recommended the 9v alkaline cells in a standby battery application a few days ago. The very low current demand in the application under discussion did not exclude the 9V cell. Obviously, the AA cell offers a larger energy bucket for such tasks . . . but getting a firm electrical grip on the cell's electrical energy is a bit more problematic. My energy studies are being conducted with cells having SOLDERED leads eliminating the holder issues . . . indeed, one could build up disposable cell arrays using similar techniques. But they need to be done with care lest the cells be damaged by soldering heat. It would be really cool to use tab-welders common the Ni-Mh and Li-Ion arrays. The AA alkaline cell has a really small (+) terminal . . . more difficult to weld on. I have some alkaline D-cell arrays for video cameras that were welded . . . but the AA-cell is more problematic. I may do an article on the techniques I use for soldering to AA-cell . . . it's not difficult. It seems that the past few weeks discoveries in my AA-cell testing offer another choice for DIY standby battery construction. As soon as I've squashed all the energy out of the current constellation of test articles, I'll do some testing on the effects of soldered leads. Watch this space . . . Bob . . . ________________________________________________________________________________
Date: Apr 07, 2017
Good catch; there's not much point in having 50mS pulses if the relay takes 1/3 of that again to release. I've added a 200V Zener across the coil to allow its stored energy to dissipate faster. I changed the MOSFET to an Infineon IPA65R650CEXKSA1 that's Vds=650V rated, and I've annotated a minimum Vds=500V for substitution. Updated schematic: http://preview.tinyurl.com/knz5te2 WRT pulse current, I suppose you could use a power resistor or DIY facsimile -or- get fancy with a beefy MOSFET gated by a pot-controlled op-amp sensing a shunt. Based on the results shown in the various YouTube videos on this subject, my gut says current control isn't really necessary for the limited purpose of welding tabs onto cells. I think my first go at this would be to just control heat with pulse width. More R would be easy to add if found necessary. Let me know if I can put this together and send it to you to try. I don't have a need for it at the moment and my ability to measure how it works is limited (most of my equipment is in storage), but I do have the time to build it if you can get some use from it or if you think it will add to our collective tool box. Is there anything else you would suggest changing? Eric Robert L. Nuckolls, III wrote: > At 01:09 AM 4/7/2017, you wrote: > This is almost exactly what I crafted to replace the failed pulse controller on a friend's spot welder some years ago. This was an AC welder so I could use a photo coupled triac to control primary supply current. The only questions that come to mind immediately about the battery+contactor configuration is the ability to control pulse current as well . . . some high current resistors (i've used coils of steel clothesline wire). Also, you may want to craft your solenoid driver to withstand the inductive kick inherent in the solenoid's windings. Adding a diode causes a large contactor increase in drop-out-delay which MIGHT affect your selection of optimum current x time . . . or not. > > But the thing is worth pursuing . . . we could do an Eric's Shop Notes page on the website to assist others in repeating a useful experiment. > > Bob . . . Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468133#468133 ________________________________________________________________________________
Date: Apr 07, 2017
>WRT pulse current, I suppose you could use a power resistor or DIY >facsimile -or- get fancy with a beefy MOSFET gated by a >pot-controlled op-amp sensing a shunt. Based on the results shown >in the various YouTube videos on this subject, my gut says current >control isn't really necessary for the limited purpose of welding >tabs onto cells. I think my first go at this would be to just >control heat with pulse width. More R would be easy to add if found necessary. Remember that total heat = K x T x I(SQUARED) . . . while there will be some current limiting offered by wiring and contactor resistance, the 'weld current' available from a healthy battery can exceed many hundreds of amps. I would sure build in some sort of limiting. It occurs to me that incandescent lamps in parallel might offer an interesting current profile. Inrush tapering over tens of milliseconds will come asymptotic to the running current about 100 mS later. So an array of 10, 55w lamps (4A running) would settle out at 40a but deliver a pretty good start up jolt . . . Just a thought. In any case, an open coil of clothesline wire can be a pretty rugged, adjustable limiter. Used the stuff in a motor inrush controller for the a/c compressor motor on King Airs wayyyyy back when . . . Bob . . . ________________________________________________________________________________
Date: Apr 08, 2017
Subject: Splices
I am redoing my panel after replacing my failed Subaru with a Lycoming and I would like to do some cleanup in wire routing. Would using some knife splices on some 16 and 18 wires to get some wire bundles untangled do any harm? Thanks, Ron Burnett RV-6A May you have the Lord's blessings today! Sent from my iPad ________________________________________________________________________________
Date: Apr 08, 2017
Subject: Re: Splices
At 09:06 PM 4/8/2017, you wrote: > >I am redoing my panel after replacing my failed Subaru with a >Lycoming and I would like to do some cleanup in wire routing. Would >using some knife splices on some 16 and 18 wires to get some wire >bundles untangled do any harm? Generally, no . . . but why knife splices as opposed to butt splices? Bob . . . ________________________________________________________________________________
Date: Apr 08, 2017
Ron, You could also solder the wires together, with is easy and reliable. See the photos at the bottom of this post on my blog . Cheers, -- Art Z. On Sat, Apr 8, 2017 at 9:06 PM, Ron Burnett wrote: > ronburnett(at)charter.net> > > I am redoing my panel after replacing my failed Subaru with a Lycoming and > I would like to do some cleanup in wire routing. Would using some knife > splices on some 16 and 18 wires to get some wire bundles untangled do any > harm? -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Date: Apr 08, 2017
Bob, My panel isn't easily assessable except from underneath, thru 2 access panel s I cut and installed between the windscreen and firewall. Was thinking knif e in case I needed to get in there again, but I like your plan better. Thanks, what little I know is from attending your course twice and this lis t. Thanks for all you do for all of us. Ron Burnett May you have the Lord's blessings today! Sent from my iPad > On Apr 8, 2017, at 9:21 PM, Robert L. Nuckolls, III <nuckolls.bob@aeroelec tric.com> wrote: > > At 09:06 PM 4/8/2017, you wrote: net> >> >> I am redoing my panel after replacing my failed Subaru with a Lycoming an d I would like to do some cleanup in wire routing. Would using some knife s plices on some 16 and 18 wires to get some wire bundles untangled do any har m? > > Generally, no . . . but why knife splices as opposed > to butt splices? > > > Bob . . . ________________________________________________________________________________
Date: Apr 08, 2017
Art, Thanks but I prefer crimping as those are skills I am sharper at. Ron Burnett May you have the Lord's blessings today! Sent from my iPad > On Apr 8, 2017, at 9:35 PM, Art Zemon wrote: > > Ron, > > You could also solder the wires together, with is easy and reliable. See t he photos at the bottom of this post on my blog. > > Cheers, > -- Art Z. > >> On Sat, Apr 8, 2017 at 9:06 PM, Ron Burnett wrot e: net> >> >> I am redoing my panel after replacing my failed Subaru with a Lycoming an d I would like to do some cleanup in wire routing. Would using some knife s plices on some 16 and 18 wires to get some wire bundles untangled do any har m? > > > -- > https://CheerfulCurmudgeon.com/ > > "If I am not for myself, who is for me? And if I am only for myself, what a m I? And if not now, when?" Hillel ________________________________________________________________________________
Subject: Endurance bus switch
Date: Apr 09, 2017
Hi Bob, I=99m building an RV-7 and tackling the wiring, thank you for sharing the invaluable knowledge in your book. I=99ve been grappling with whether or not to wire the endurance bus directly through the switch or use a relay. The switch is rated at 20 amps but the bus could conceivably see up to 24 amps if everything on the bus was on and drawing its maximum, eg radio transmitting, transponder transponding and GPS charging for example. Regards, John. John Keen 0412 141 833 15 Scott St Scone NSW Australia 2337 ________________________________________________________________________________
Subject: Re: Endurance bus switch
Date: Apr 09, 2017
The deciding factor is not ampacity because either a relay or a switch will work. Even if a switch is operated above its rating, it will not immediately self destruct. For example, if a 20 amp switch carries 24 amps, it might only last 50,000 cycles instead of its 100,000 cycle life expectancy. It could still outlive the life of the aircraft. The important consideration is remote control. Locating a relay close to the battery allows power to be shut off close to the source. A small switch and small wires can be used to control the relay. A government accident investigator once made the comment that the chances of a post crash fire were greatly reduced if the battery had departed the aircraft. Shutting off electrical power close to the source should also reduce the chances of fire following a forced landing. The downside of a relay is that there is one more item to fail. If you do not install it, it can not fail. I vote for using a relay. Your preference may vary. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468173#468173 ________________________________________________________________________________
From: "William Hunter" <billhuntersemail(at)gmail.com>
Subject: Is there M39029/63-3XX For 18 AWG Wire?!?!?
Date: Apr 09, 2017
Hi All, I am rewiring my airplane and am therefore making wire runs to the Lightspeed Plasma III ignition systems. The Plasma ignition systems input connector uses DSub 15 plugs so I have utilized the M39029/63-368 crimp on connectors for all of the 20-24 AWG wires that push into the connector however I have according to the directions used an 18 AWG positive wire and an 18 AWG negative wire for the power and ground. To make this phase of the project more dramatic, the Plasma input connector has two positive pins and two negative pins on its connector so I need to figure out to go from my single 18 AWG positive wire and divide it up into two wires that will each fit into its respective M39029/63-368 ORANGE-BLUE-GRAY crimp on connector. Is there a M39029/63-3XX crimp on connector that is designed for 18 to 20 AWG wire? If not, I could cut off a couple of strands of the 18 AWG wire to get it to fit into the 20 AWG connector barrel however that is not very elegant because the remaining strand(s) will kinda poke out of the wire insulation however a needle nose pliers could fix that. Then the next obstacle to Plasma Bliss is dealing with dividing out the single wire and making it two wires. I am considering peeling off a 1 inch section of the insulation of the single wire about 3 inches away from the wire end and then once that section of wire is exposed, place a second wire with the insulation stripped off the end onto the exposed conductor and solder the second wire to the first and then cover the junction with heat shrink. To expose the first wire 3 inches up from the end could be possible to do by using my wire stripper to make the two cuts by just squeezing the handle only about =BC of the way to have it cut all the way around the insulation and move the insulation about 1/16 of an inch and then exacto off the remaining center section. My soldering skills have much to be desired however if I use a =93second hands=94 type contraption to hold the two wires together and then use a clean soldering iron tip and some flux I could do a respectable job. I would think that=85IF=85there was an easier way someone here would have found/invented it by now. Also, in the past someone told me that a crimp on butt end connector creates a more secure and durable wire splice than if the two ends were soldered together. Is that true? Perhaps with my soldering skills that would certainly be the case however for people with decent soldering skills I am interested in the actual answer. Any feedback on this idea/proper suggestions/well wishes would be most appreciated!!! .. THANKS!!! Bill Hunter ________________________________________________________________________________
Subject: Re: Is there M39029/63-3XX For 18 AWG
Wire?!?!?
Date: Apr 09, 2017
Bill, First, there is no need for 18ga wire in providing the power. 20Ga is plenty. So just skip that. Be aware that Klaus does not recommend anyone ever cut the connector off and reconnect it their self. Other than not wanting someone to screw up such a critical part of their ignition system, I don't know what his motivation is. But be aware that he may not be as interested to help once someone cuts that off. Anyway, there's no reason to go 18ga, so just skip that and then things get easier, and you can run 2 long 20Ga wires to the power source, or join them into something thicker with your choice in splice if you wish, further away from the connector. Tim On 4/9/2017 9:00 AM, William Hunter wrote: > Hi All, > > > I am rewiring my airplane and am therefore making wire runs to the > Lightspeed Plasma III ignition systems. > > > The Plasma ignition systems input connector uses DSub 15 plugs so I have > utilized the M39029/63-368 crimp on connectors for all of the 20-24 AWG > wires that push into the connector however I have according to the > directions used an 18 AWG positive wire and an 18 AWG negative wire for > the power and ground. To make this phase of the project more dramatic, > the Plasma input connector has two positive pins and two negative pins > on its connector so I need to figure out to go from my single 18 AWG > positive wire and divide it up into two wires that will each fit into > its respective M39029/63-368 ORANGE-BLUE-GRAY crimp on connector. > > > Is there a M39029/63-3XX crimp on connector that is designed for 18 to > 20 AWG wire? > > > If not, I could cut off a couple of strands of the 18 AWG wire to get it > to fit into the 20 AWG connector barrel however that is not very elegant > because the remaining strand(s) will kinda poke out of the wire > insulation however a needle nose pliers could fix that. > > > Then the next obstacle to Plasma Bliss is dealing with dividing out the > single wire and making it two wires. > > > I am considering peeling off a 1 inch section of the insulation of the > single wire about 3 inches away from the wire end and then once that > section of wire is exposed, place a second wire with the insulation > stripped off the end onto the exposed conductor and solder the second > wire to the first and then cover the junction with heat shrink. > > > To expose the first wire 3 inches up from the end could be possible to > do by using my wire stripper to make the two cuts by just squeezing the > handle only about of the way to have it cut all the way around the > insulation and move the insulation about 1/16 of an inch and then exacto > off the remaining center section. > > > My soldering skills have much to be desired however if I use a second > hands type contraption to hold the two wires together and then use a > clean soldering iron tip and some flux I could do a respectable job. > > > I would think thatIFthere was an easier way someone here would have > found/invented it by now. > > > Also, in the past someone told me that a crimp on butt end connector > creates a more secure and durable wire splice than if the two ends were > soldered together. Is that true? Perhaps with my soldering skills that > would certainly be the case however for people with decent soldering > skills I am interested in the actual answer. > > > Any feedback on this idea/proper suggestions/well wishes would be most > appreciated!!! > > .. > > > THANKS!!! > > > Bill Hunter > > ________________________________________________________________________________
Subject: Re: Is there M39029/63-3XX For 18 AWG Wire?!?!?
Date: Apr 09, 2017
> Also, in the past someone told me that a crimp on butt end connector creates a more secure and durable wire splice than if the two ends were soldered together. Is that true? No, the two methods are equal. Some might argue that soldering is better. The disadvantage of soldering is that solder wicks into the wire and makes it stiff which could lead to breaking if subject to vibration. But good support and a couple of layers of heat shrink will prevent that. Crimped wires also need support. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468179#468179 ________________________________________________________________________________
Date: Apr 09, 2017
At 05:01 AM 4/9/2017, you wrote: >Hi Bob, > >I=99m building an RV-7 and tackling the wiring, >thank you for sharing the invaluable knowledge in your book. >I=99ve been grappling with whether or not to >wire the endurance bus directly through the >switch or use a relay. The switch is rated at 20 >amps but the bus could conceivably see up to 24 >amps if everything on the bus was on and drawing >its maximum, eg radio transmitting, transponder >transponding and GPS charging for example. The switch 'rating' is largely irrelevant. The number is an engineer's guide to service life under tens of thousands of cycles at full load. Your switch won't see 1000 cycles in its lifetime and never under full load. Tell us about this 'endurance' bus . . . what are your design goals for battery only operations and what electro-whizzies are fed from this bus? Bob . . . ________________________________________________________________________________
Date: Apr 09, 2017
At 09:38 AM 4/9/2017, you wrote: > > > > Also, in the past someone told me that a > crimp on butt end connector creates a more > secure and durable wire splice than if the two > ends were soldered together.=EF=BD Is that true? no >No, the two methods are equal. Some might argue >that soldering is better. The disadvantage of >soldering is that solder wicks into the wire and >makes it stiff which could lead to breaking if subject to vibration. also not true > But good support and a couple of layers of > heat shrink will prevent that. Crimped wires also need support. EXACTLY. risks from stress risers on strands of wire rise at the TRANSITION from strands (flexible) to solid (inflexible). That solid thingy happens whether you solder or mash. Hence the PIDG design which provides the SAME support to crimped wires as that which is recommended for soldered wires as well. http://tinyurl.com/mz89on7 Bob . . . ________________________________________________________________________________
Date: Apr 09, 2017
On 4/9/2017 9:00 AM, William Hunter wrote: > > Hi All, > > I am rewiring my airplane and am therefore making wire runs to the > Lightspeed Plasma III ignition systems. > > The Plasma ignition systems input connector uses DSub 15 plugs so I > have utilized the M39029/63-368 crimp on connectors for all of the > 20-24 AWG wires that push into the connector however I have according > to the directions used an 18 AWG positive wire and an 18 AWG negative > wire for the power and ground. To make this phase of the project more > dramatic, the Plasma input connector has two positive pins and two > negative pins on its connector so I need to figure out to go from my > single 18 AWG positive wire and divide it up into two wires that will > each fit into its respective M39029/63-368 ORANGE-BLUE-GRAY crimp on > connector. > > Is there a M39029/63-3XX crimp on connector that is designed for 18 to > 20 AWG wire? > > If not, I could cut off a couple of strands of the 18 AWG wire to get > it to fit into the 20 AWG connector barrel however that is not very > elegant because the remaining strand(s) will kinda poke out of the > wire insulation however a needle nose pliers could fix that. > > Then the next obstacle to Plasma Bliss is dealing with dividing out > the single wire and making it two wires. > > I am considering peeling off a 1 inch section of the insulation of the > single wire about 3 inches away from the wire end and then once that > section of wire is exposed, place a second wire with the insulation > stripped off the end onto the exposed conductor and solder the second > wire to the first and then cover the junction with heat shrink. > > To expose the first wire 3 inches up from the end could be possible to > do by using my wire stripper to make the two cuts by just squeezing > the handle only about of the way to have it cut all the way around > the insulation and move the insulation about 1/16 of an inch and then > exacto off the remaining center section. > > My soldering skills have much to be desired however if I use a second > hands type contraption to hold the two wires together and then use a > clean soldering iron tip and some flux I could do a respectable job. > > I would think thatIFthere was an easier way someone here would have > found/invented it by now. > > Also, in the past someone told me that a crimp on butt end connector > creates a more secure and durable wire splice than if the two ends > were soldered together. Is that true? Perhaps with my soldering > skills that would certainly be the case however for people with decent > soldering skills I am interested in the actual answer. > > Any feedback on this idea/proper suggestions/well wishes would be most > appreciated!!! > > .. > > THANKS!!! > > Bill Hunter > I think there's a drawing in 'the Book' showing how to feed a bigger power wire into a pair (or more) of the standard pins in a subD. It's basically what you're describing: a pair of ~6" long 20 ga pigtails brought together & attached to the larger wire. Soldering works great, but if you're not confident in your skills, a crimp style butt splice is fine, too. Solder + heat shrink is cheaper, less bulky, and properly done, has no more risk of poor connection or breakage from stress risers. Crimps are more expensive, but much faster and can be achieved by 'unskilled labor'. You can split the insulation & splice in another conductor as you describe, but if the primary is 18 ga or larger, you still have the issue of fitting it into the 20 ga pin. Snipping strands works, and if you keep the insulation butted against the end of the pin, there's little danger of a short, but the whole process is a lot more painful and risky than just using 2 20 ga pigtails. Charlie ________________________________________________________________________________
Date: Apr 09, 2017
Bill, Bob has extensive advice on how to use multiple pins in a connector for power. I documented his advice and included photos of my work (5 pins in parallel) in my blog post Wiring Harness Installed . -- Art Z. -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Date: Apr 09, 2017
At 09:00 AM 4/9/2017, you wrote: >Hi All, > >I am rewiring my airplane and am therefore making wire runs to the >Lightspeed Plasma III ignition systems. > >The Plasma ignition systems input connector uses DSub 15 plugs so I >have utilized the M39029/63-368 crimp on connectors for all of the >20-24 AWG wires that push into the connector however I have >according to the directions used an 18 AWG positive wire and an 18 >AWG negative wire for the power and ground. To make this phase of >the project more dramatic, the Plasma input connector has two >positive pins and two negative pins on its connector so I need to >figure out to go from my single 18 AWG positive wire and divide it >up into two wires that will each fit into its respective >M39029/63-368 ORANGE-BLUE-GRAY crimp on connector. > >Is there a M39029/63-3XX crimp on connector that is designed for 18 >to 20 AWG wire? Those pins WILL accept a 20AWG wire. Run two pairs of 20AWG, one for power the other for ground. Let each wire enjoy its own d-sub pin; bring them together at the source and ground connections. The LightSpeed 6-cyl ignition system draws about 2.5A at 2700 rpm . . . the 4-cyl is about 2/3 that amount. The system would perform happily with a single 22AWG feeder for power and ground. A pair of 20AWG for each feeder is still . . . shall we say? . . . exceedingly robust. A bit of trivia on this topic, you CAN buy pins for d-subs that will accept larger wires. The crimps are OUTSIDE the pin cavity in the connector with a longer stem extending into the connector cavity. They are expensive and not easy to find and used ONLY when the LENGTH of the wire run offers an unacceptable voltage drop within the connector pin's normal rated current. I've only seen such pins in the wild once in my lifetime . . . and if memory serves, they were soldered onto the wires. The crimped mil-spec pins are rated at 7A under benign environments . . . I generally never run them at more than 5 . . . especially when paralleling for high current applications. http://tinyurl.com/mzauc8b I used this technique on a super-sonic target for the Navy and the process was repeated on some power distribution components in the B4000 Horizon. Oh yeah, if you need the too-large wire to compensate for voltage drop, then it's perfectly acceptable to prune the strands on an 18AWG to get them into the 20AWG pin. But I'm betting a dollar to a dozen donuts that the OBAM aircraft owner will NEVER encounter such a situation. It's also a certainty that the LightSpeed system secures no performance enhancements with the pudgy supply wires. Bob . . . ________________________________________________________________________________
Date: Apr 09, 2017
Hi All, This advice is most helpful.THANKS!!! Yes I know the Plasma instructions said to not fool with the input connectors however I dinked up the cable so I had to.Grrr. Since the ignition system is somewhat important I decided to go with the MIL spec connector pins. I imagine that solder-on DSub connectors would be the best way to go however with my soldering skills and lack of patients the crimp on pins seemed to be the the way to go. I was very careful with each crimp and did a pull test and they did not fall off. The Eclipse crimper tool is really good and makes professional crimps even with me using it. The airplane in question is a Velocity (plastic pusher) and I am running two Plasma units each connected to the battery terminals of their respective independent electrical system. Electrical system 1 has the battery in the nose so its electrical path is from the battery POS terminal to the CB, to the expensive MIL spec switch mounted on the panel, to the POS D-Sub pins on the ignition module mounted way back on the cold side (front) of the firewall and then from the ignition module NEG pins all the way forward to the NEG terminal of the battery up in the nose. Electrical system 2 has the battery under the rear seat so its electrical path is from the battery POS terminal forward to the CB, to the expensive MIL spec switch mounted on the panel, and then back to the POS D-Sub pins on the ignition module mounted way back on the cold side (front) of the firewall and then from the ignition module NEG pins forward to the NEG terminal of the battery mounted under the rear seat. With these long distances I felt that 18 AWG wire was a good idea. THANKS AGAIN!!! .. Cheers!!! Bill Hunter From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Sunday, April 9, 2017 9:14 AM Subject: Re: AeroElectric-List: Is there M39029/63-3XX For 18 AWG Wire?!?!? At 09:00 AM 4/9/2017, you wrote: Hi All, I am rewiring my airplane and am therefore making wire runs to the Lightspeed Plasma III ignition systems. The Plasma ignition systems input connector uses DSub 15 plugs so I have utilized the M39029/63-368 crimp on connectors for all of the 20-24 AWG wires that push into the connector however I have according to the directions used an 18 AWG positive wire and an 18 AWG negative wire for the power and ground. To make this phase of the project more dramatic, the Plasma input connector has two positive pins and two negative pins on its connector so I need to figure out to go from my single 18 AWG positive wire and divide it up into two wires that will each fit into its respective M39029/63-368 ORANGE-BLUE-GRAY crimp on connector. Is there a M39029/63-3XX crimp on connector that is designed for 18 to 20 AWG wire? Those pins WILL accept a 20AWG wire. Run two pairs of 20AWG, one for power the other for ground. Let each wire enjoy its own d-sub pin; bring them together at the source and ground connections. The LightSpeed 6-cyl ignition system draws about 2.5A at 2700 rpm . . . the 4-cyl is about 2/3 that amount. The system would perform happily with a single 22AWG feeder for power and ground. A pair of 20AWG for each feeder is still . . . shall we say? . . . exceedingly robust. A bit of trivia on this topic, you CAN buy pins for d-subs that will accept larger wires. The crimps are OUTSIDE the pin cavity in the connector with a longer stem extending into the connector cavity. They are expensive and not easy to find and used ONLY when the LENGTH of the wire run offers an unacceptable voltage drop within the connector pin's normal rated current. I've only seen such pins in the wild once in my lifetime . . . and if memory serves, they were soldered onto the wires. The crimped mil-spec pins are rated at 7A under benign environments . . . I generally never run them at more than 5 . . . especially when paralleling for high current applications. http://tinyurl.com/mzauc8b I used this technique on a super-sonic target for the Navy and the process was repeated on some power distribution components in the B4000 Horizon. Oh yeah, if you need the too-large wire to compensate for voltage drop, then it's perfectly acceptable to prune the strands on an 18AWG to get them into the 20AWG pin. But I'm betting a dollar to a dozen donuts that the OBAM aircraft owner will NEVER encounter such a situation. It's also a certainty that the LightSpeed system secures no performance enhancements with the pudgy supply wires. Bob . . . ________________________________________________________________________________
Date: Apr 09, 2017
> >Electrical system 2 has the battery under the rear seat so its >electrical path is from the battery POS terminal forward to the CB, >to the expensive MIL spec switch mounted on the panel, and then back >to the POS D-Sub pins on the ignition module mounted way back on the >cold side (front) of the firewall and then from the ignition module >NEG pins forward to the NEG terminal of the battery mounted under >the rear seat. > >With these long distances I felt that 18 AWG wire was a good idea. Not very quantified . . . Resistance of 22AWG wire = 0.016 ohms/foot = 16mv drop per amp per foot of wire 20AWG wire = 0.010 ohms/foot = 10mv drop per amp per foot of wire 18AWG wire = 0.006 ohms/foot = 6mv drop per amp per foot of wire Assume 20foot round trip from battery(+) to battery (-) and 2 amps of appliance draw. 22AWG drops 0.640 volts 20AWG drops 0.400 volts 18AWG drops 0.240 volts Assuming your power pathways totaled 20 feet and you indeed require 2A of supply power, voltage variations presented over the range of wire sizes explored above are trivial. Further, LightSpeed's passion for hooking things right to the battery is without president in certified general aviation. The only folks I know of that do this routinely are the kids with 1000 Watt boom boxes in their vehicles. In fact, driving BOTH systems through a common source configuration violates the common sense for in the analysis and mitigation of failure modes. Bob . . . ________________________________________________________________________________
From: William Hunter <billhuntersemail(at)gmail.com>
Date: Apr 09, 2017
Bob, just curious... how comfortable are you with using the M39029/63-3 crimp on pins for the ignition system D-Sub connector as opposed to the solder on type? Thanks again, Bill Hunter On Apr 9, 2017 1:42 PM, "Robert L. Nuckolls, III" < nuckolls.bob(at)aeroelectric.com> wrote: > > Electrical system 2 has the battery under the rear seat so its electrical > path is from the battery POS terminal forward to the CB, to the expensive > MIL spec switch mounted on the panel, and then back to the POS D-Sub pins > on the ignition module mounted way back on the cold side (front) of the > firewall and then from the ignition module NEG pins forward to the NEG > terminal of the battery mounted under the rear seat. > > With these long distances I felt that 18 AWG wire was a good idea. > > > Not very quantified . . . > > Resistance of 22AWG wire = 0.016 ohms/foot = 16mv drop per amp per foot > of wire > 20AWG wire = 0.010 ohms/foot = 10mv drop per amp per foot > of wire > 18AWG wire = 0.006 ohms/foot = 6mv drop per amp per foot > of wire > > Assume 20foot round trip from battery(+) to battery (-) and > 2 amps of appliance draw. > > 22AWG drops 0.640 volts > 20AWG drops 0.400 volts > 18AWG drops 0.240 volts > > Assuming your power pathways totaled 20 feet and > you indeed require 2A of supply power, voltage > variations presented over the range of wire > sizes explored above are trivial. > > Further, LightSpeed's passion for hooking > things right to the battery is without president > in certified general aviation. The only folks > I know of that do this routinely are the kids > with 1000 Watt boom boxes in their vehicles. > > In fact, driving BOTH systems through a common source > configuration violates the common sense for in the > analysis and mitigation of failure modes. > > <#m_-4996803437017520622_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> > > Bob . . . > ________________________________________________________________________________
Date: Apr 09, 2017
At 01:55 PM 4/9/2017, you wrote: >Bob, just curious... how comfortable are you >with using the=C2 M39029/63-3 crimp on pins for >the ignition system D-Sub connector as opposed to the solder on type? No difference. Properly installed wires passing though quality connectors are generally considered to have failure rates less than one per billion flight hours. I've read failure rate studies on dozens of systems having high orders of system criticality as demonstrated by detailed studies of component failure rates for the resistors, transistors, capacitors and all manner of electro-jelly-beans. Then they run even the simplest software through rigorous certification and configuration control protocols. After all the bureaucratic thrashing dies down you can ask: "Does this appliance have and critical power or signal pathways that pass through connectors?" "Of course," they say. "But failure rates for those assemblies are insignificant in the grand scheme of things." For YOUR personal failure analysis consider that you have TWO ignition systems. The engine runs very happily on ONE system. If one system fails, you probably won't notice it in flight but you will at next pre-flight. Next consider the probability that BOTH systems will go T.U. on any single tank full of gas. You can have terrible failure rates for each system and still fly with confidence . . . like we've been doing with dual magnetos for over 100 years. If it were my airplane, one system would run from the battery bus, the other would run from the e-bus. Wire with single 20AWG feeders and stay away from hooking anything directly to the battery(ies). It's far too easy to get wrapped around 'reliability axles' and loose track of the real risk factors. That's what happened with N811HB about ten years ago http://tinyurl.com/msfmldj KISS Bob . . . ________________________________________________________________________________
Date: Apr 09, 2017
> On Apr 7, 2017, at 5:08 PM, Robert L. Nuckolls, III wrote: > I would sure build in some sort of limiting. You mentioned 40A. Would that be our target for max current in a system like this? Would we want adjustability, and if so, through what range? I have zero PIC time with a spot welder, hence the questions... Eric ________________________________________________________________________________
Date: Apr 09, 2017
Very good and comforting information Bob. As always I am very grateful for your advice!!! Thanks, Bill Hunter On Apr 9, 2017 7:59 PM, "Robert L. Nuckolls, III" < nuckolls.bob(at)aeroelectric.com> wrote: > At 01:55 PM 4/9/2017, you wrote: > > Bob, just curious... how comfortable are you with using the=C3=82 M39029 /63-3 > crimp on pins for the ignition system D-Sub connector as opposed to the > solder on type? > > > No difference. Properly installed wires > passing though quality connectors are > generally considered to have failure > rates less than one per billion flight > hours. > > I've read failure rate studies on dozens > of systems having high orders of system > criticality as demonstrated by detailed > studies of component failure rates for the > resistors, transistors, capacitors and > all manner of electro-jelly-beans. Then > they run even the simplest software > through rigorous certification and configuration > control protocols. > > After all the bureaucratic thrashing dies > down you can ask: "Does this appliance have > and critical power or signal pathways that > pass through connectors?" "Of course," they > say. "But failure rates for those assemblies > are insignificant in the grand scheme of things." > > For YOUR personal failure analysis consider > that you have TWO ignition systems. The engine > runs very happily on ONE system. If one system > fails, you probably won't notice it in flight > but you will at next pre-flight. Next consider > the probability that BOTH systems will go > T.U. on any single tank full of gas. > > You can have terrible failure rates for each > system and still fly with confidence . . . like > we've been doing with dual magnetos for over > 100 years. > > If it were my airplane, one system would run > from the battery bus, the other would run > from the e-bus. Wire with single 20AWG feeders > and stay away from hooking anything directly > to the battery(ies). > > It's far too easy to get wrapped around 'reliability > axles' and loose track of the real risk factors. > That's what happened with N811HB about ten years > ago http://tinyurl.com/msfmldj > > KISS > > > Bob . . . > ________________________________________________________________________________
Date: Apr 10, 2017
Thanks Bob, My design goal for battery only operations is to be able to focus on flying the aeroplane easily to a safe landing at the nearest airfield. As the plane has conventional dual mags and a carb with engine driven fuel pump, and a traditional panel with vacuum AH and DG, I imagine wanting electrical help mainly for navigating and communicating (day VFR). This is my list for the endurance bus, the numbers with a ? are current draw that I=99ve guesstimated until I have the correct value: - Panel floodlights x2 (in case day VFR runs out) = 0.15 - Van=99s Voltmeter = 1? - Van=99s fuel gauges x2 = 1.5? - Dual USB outlet (charges iPad = 0.85 and GPS = 0.5) - Transponder Garmin 330ES = 4 - Comm radio (has built-in intercom) Garmin GTR200 = 7.5 - Boost pump = 0.8 Total = 16.3 Better - I had some very round and generous numbers previously giving me the 24! And I=99ve taken off the hour meter. This leaves out the alternator; starting system; nav, landing and interior lights; engine instruments; turn coordinator, flaps and trim; hour meter... Cheers, John. > On 10 Apr 2017, at 01:05, Robert L. Nuckolls, III wrote: > > At 05:01 AM 4/9/2017, you wrote: >> Hi Bob, >> >> I=C3=A2=C2=C2=99m building an RV-7 and tackling the wiring, thank you for sharing the invaluable knowledge in your book. >> I=C3=A2=C2=C2=99ve been grappling with whether or not to wire the endurance bus directly through the switch or use a relay. The switch is rated at 20 amps but the bus could conceivably see up to 24 amps if everything on the bus was on and drawing its maximum, eg radio transmitting, transponder transponding and GPS charging for example. > > The switch 'rating' is largely irrelevant. The > number is an engineer's guide to service life > under tens of thousands of cycles at full load. > > Your switch won't see 1000 cycles in its lifetime > and never under full load. > > Tell us about this 'endurance' bus . . . what > are your design goals for battery only operations > and what electro-whizzies are fed from this bus? > > > > Bob . . . > ________________________________________________________________________________
Date: Apr 10, 2017
The current draw estimates are way too high. The voltmeter and fuel gauges combined are probably less than one amp. The Transponder is 3 amps. The GTR 200 is probably less than 1 amp except when transmitting. I guesstimate less than 8 amps total. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468231#468231 ________________________________________________________________________________
Date: Apr 10, 2017
Subject: Circuit protection for backup alternator
Bob, I am building an RV10 and installing a B&C 410H backup alternator. I have installed an ANL circuit protection next to the battery behind the baggage compartment, to protect the #6 wire that I have going forward, along the lines of your Z-13/8 schematic. But I was concerned about the output of the alternator going aft. I have a contactor on the firewall for the output of the alternator and I was considering installing a fusible link between the alternator and the contactor for protection. Are there any issues that you might see with a setup like this? Thanks. Ed Godfrey ________________________________________________________________________________
Date: Apr 10, 2017
Subject: Re: Circuit protection for backup alternator
At 11:29 AM 4/10/2017, you wrote: > >Bob, > I am building an RV10 and installing a B&C 410H backup > alternator. I have installed an ANL circuit protection next to the > battery behind the baggage compartment, to protect the #6 wire that > I have going forward, along the lines of your Z-13/8 schematic. But > I was concerned about the output of the alternator going aft. I > have a contactor on the firewall for the output of the alternator > and I was considering installing a fusible link between the > alternator and the contactor for protection. Are there any issues > that you might see with a setup like this? Thanks. No . . . the alternator is incapable of delivering current needed to put the b-lead at risk. Bob . . . ________________________________________________________________________________
Date: Apr 10, 2017
At 09:43 AM 4/10/2017, you wrote: > >The current draw estimates are way too high. >The voltmeter and fuel gauges combined are probably less than one amp. >The Transponder is 3 amps. >The GTR 200 is probably less than 1 amp except when transmitting. >I guesstimate less than 8 amps total. Generally agree . . . transponder energy draw is under 1A except for very short bursts while replying . . . so I'll suggest your e-bus loads are smaller yet probably 5A or less. A simple toggle switch and 10A fuse protection for your e-bus alternate feed will be entirely adequate. Bob . . . ________________________________________________________________________________
From: "H. Ivan Haecker" <hivanhaecker(at)gmail.com>
Date: Apr 10, 2017
Subject: Voltmeter
Is there a best place to wire a voltmeter to my electrical system? Should I be most interested in the voltage at the main bus? And if so, can I piggy back the voltmeter to an existing breaker (such as other electric engine gauges) or does the voltmeter need it's own separate protection. Hope my question isn't too naive. Ivan Haecker (rewiring my ancient rv-4) ________________________________________________________________________________
Date: Apr 10, 2017
IMHO you are getting things backwards. You do not need protection for the heavy wire from the battery to the firewall/starter solenoid. However, that cable should be #4 minimum, and better #2. Use the ANL to protect the B lead from the alternator to the main bus, with the ammeter shunt either right above or below it on the firewall. Your #6 (or #8) is appropriate for that B lead. Kelly RV-10 40866, flying On 4/10/2017 9:29 AM, Ed Godfrey wrote: > > > Bob, > I am building an RV10 and installing a B&C 410H backup alternator. I > have installed an ANL circuit protection next to the battery behind the > baggage compartment, to protect the #6 wire that I have going forward, > along the lines of your Z-13/8 schematic. But I was concerned about the > output of the alternator going aft. I have a contactor on the firewall > for the output of the alternator and I was considering installing a > fusible link between the alternator and the contactor for protection. > Are there any issues that you might see with a setup like this? Thanks. > > Ed Godfrey > > ________________________________________________________________________________
Date: Apr 11, 2017
Thanks Joe, Bob! Cheers, John Keen > On 11 Apr 2017, at 2:40 am, Robert L. Nuckolls, III <nuckolls.bob@aeroelec tric.com> wrote: > > At 09:43 AM 4/10/2017, you wrote: >> >> The current draw estimates are way too high. >> The voltmeter and fuel gauges combined are probably less than one amp. >> The Transponder is 3 amps. >> The GTR 200 is probably less than 1 amp except when transmitting. >> I guesstimate less than 8 amps total. > > Generally agree . . . transponder energy draw > is under 1A except for very short bursts while > replying . . . so I'll suggest your e-bus loads > are smaller yet probably 5A or less. > > A simple toggle switch and 10A fuse protection > for your e-bus alternate feed will be entirely > adequate. > > Bob . . . ________________________________________________________________________________
Date: Apr 10, 2017
Subject: Re: Voltmeter
At 02:05 PM 4/10/2017, you wrote: >Is there a best place to wire a voltmeter to my electrical system? >Should I be most interested in the voltage at the main bus? generally, yes > And if so, can I piggy back the voltmeter to an existing breaker > (such as other electric engine gauges) or does the voltmeter need > it's own separate protection. Hope my question isn't too naive. Not at all. Tie it to any handy 5A breaker on the main bus and wire it with 22AWG. Alternatively you could simply drive the voltmeter through its own 3A fuse in an in-line fuseholder . . . easy to tuck behind the panel. Here's a guy who will sell you 5 holders with small wire (18awg) more appropriate to this task and 3A fuses to go with them for $10. You'll have some holders/fuses left over but you can't go down to Smiley Jack's Parts Emporium and buy one holder and fuse after you figure in time and mileage. Bob . . . ________________________________________________________________________________
Date: Apr 10, 2017
>>I have a contactor on the firewall for the output of the alternator >>and I was considering installing a fusible link between the >>alternator and the contactor for protection. Are there any issues >>that you might see with a setup like this? Thanks. You probably don't need that long #6 feeder . . . you can feed the alternator's output into the system at the starter contactor on the firewall. A miniANL on a fuseblock or a MAXI-blade in an in-line fuse holder could be pressed into protection of this circuit and eliminate the long wire run. Bob . . . ________________________________________________________________________________
Subject: Interesting thread on overvoltage event
Date: Apr 10, 2017
There's an ongoing thread over at the VAF (RV-x) forum about an overvoltage event. Very few of those guys seem to be subscribed here, and most are quite.... let's say, limited, in electrical knowledge. This case involves an alternator overvoltage event with (apparently) an internally regulated alternator in a plane with no automatic overvoltage protection. Where it gets interesting is that he was running an EarthX 12V lithium iron battery. The suspicion is that the battery's protection circuit protected the battery by disconnecting it, and even though most of the avionics were capable of handling overvoltage events in a 28V system, the sudden loss of the battery load allowed the alternator voltage to go high enough to trash almost everything in the plane. Talk about your load dump event..... Just something to explore, for anyone considering a lithium chemistry battery. Will manual shutdown of the alternator be fast enough? Will even automated OV shutdown be fast enough? Charlie ________________________________________________________________________________
Date: Apr 10, 2017
Bob, Following the Z-13/8, I am connecting up the backup alternator to the hot side of the battery contactor. With the distance that the power is traveling, I calculated that the #6 wire would be the best choice. Did I choose wrong? Ed On 4/10/2017 4:04 PM, Robert L. Nuckolls, III wrote: >>> I have a contactor on the firewall for the output of the alternator >>> and I was considering installing a fusible link between the >>> alternator and the contactor for protection. Are there any issues >>> that you might see with a setup like this? Thanks. > > You probably don't need that long #6 feeder . . . > you can feed the alternator's output into > the system at the starter contactor on the > firewall. A miniANL on a fuseblock or a > MAXI-blade in an in-line fuse holder could > be pressed into protection of this circuit > and eliminate the long wire run. > > Bob . . . > ________________________________________________________________________________
Date: Apr 10, 2017
I have been flying my RV-10 with a 2 battery/2 alternator/2 bus Z-14 for 5+ years. Just for reference purposes my configuration includes: * Both batteries and battery contactors are installed behind baggage compartment * 2 AWG wire used to to all contactors including a run forward of the firewall for the starter contactor and the main alternator * 8 AWG wire used for runs to 2 fuse blocks on cockpit sidewalls and for run from SD20 alternator and it's battery contactor in the rear * ANL current limiters installed on firewall close to alternators for both B leads * (there is no protection on runs from battery contactors in rear to fuse blocks and starter in the front) I wouldn't do it any differently if I did it again. On 4/10/2017 12:29 PM, Ed Godfrey wrote: > > > Bob, > I am building an RV10 and installing a B&C 410H backup alternator. > I have installed an ANL circuit protection next to the battery behind > the baggage compartment, to protect the #6 wire that I have going > forward, along the lines of your Z-13/8 schematic. But I was concerned > about the output of the alternator going aft. I have a contactor on > the firewall for the output of the alternator and I was considering > installing a fusible link between the alternator and the contactor for > protection. Are there any issues that you might see with a setup like > this? Thanks. > > Ed Godfrey > > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Subject: Re: Interesting thread on overvoltage event
Date: Apr 10, 2017
Here is a link to the VAF thread that Charlie mentioned. http://www.vansairforce.com/community/showthread.php?p=1164359#post1164359 It seems that the pilot was unable to shut down the alternator with either the field switch or master switch. Anyone who installs a Lithium battery should read the Dynon Support post #7 in that thread. Without aircraft electrical system over-voltage protection, a Lithium battery could disconnect itself from the electrical system to protect itself against an over-voltage event. Without a lead-acid battery to mitigate over-voltage, very expensive avionics are at the mercy of a runaway alternator. Post number 17 by Dynon Support is also interesting. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468273#468273 ________________________________________________________________________________
Date: Apr 10, 2017
Minor correction; the owner said he didn't turn off the master until everything had died. He *might* have saved some stuff if he'd turned the master off sooner. On Mon, Apr 10, 2017 at 6:47 PM, user9253 wrote: > > Here is a link to the VAF thread that Charlie mentioned. > http://www.vansairforce.com/community/showthread.php?p=1164359#post1164359 > It seems that the pilot was unable to shut down the alternator with either > the field switch or master switch. > Anyone who installs a Lithium battery should read the Dynon Support post > #7 in that thread. Without aircraft electrical system over-voltage > protection, a Lithium battery could disconnect itself from the electrical > system to protect itself against an over-voltage event. Without a > lead-acid battery to mitigate over-voltage, very expensive avionics are at > the mercy of a runaway alternator. > Post number 17 by Dynon Support is also interesting. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=468273#468273 > > ________________________________________________________________________________
Date: Apr 10, 2017
Normally, I would agree. However, the RV-10 requires the main battery behind the baggage compartment for W&B, so it does require one long heavy lead from the battery to the firewall. IMHO it should be no less than #4, and really should be #2 for good starter performance, given the over 10 ft run from battery to starter. Ground is handled through the aluminum airframe for the battery. Very conventional with master relay at the battery and starter relay on firewall near where the battery heavy lead comes through. Vans publishes a basic wiring diagram that is very conventional for a VFR aircraft, that gives a good starting point for wire sizes and physical locations. It is easy to modify to meet goals for endurance bus, redundancy, etc. On 4/10/2017 2:04 PM, Robert L. Nuckolls, III wrote: >>> I have a contactor on the firewall for the output of the alternator >>> and I was considering installing a fusible link between the >>> alternator and the contactor for protection. Are there any issues >>> that you might see with a setup like this? Thanks. > > You probably don't need that long #6 feeder . . . > you can feed the alternator's output into > the system at the starter contactor on the > firewall. A miniANL on a fuseblock or a > MAXI-blade in an in-line fuse holder could > be pressed into protection of this circuit > and eliminate the long wire run. > > Bob . . . > ________________________________________________________________________________
Date: Apr 10, 2017
At 05:39 PM 4/10/2017, you wrote: >Bob, > Following the Z-13/8, I am connecting up the backup alternator > to the hot side of the battery contactor. With the distance that > the power is traveling, I calculated that the #6 wire would be the > best choice. Did I choose wrong? How about Z12 instead? Tie both alternators to the bus structure at the hot side of the starter contactor. Just use the smaller alternator like a stand-by device like hundreds of TC aircraft. Which regulator are you using on the small alternator? Z-13/8 was crafted specifically for minimizing loads on the diminutive SD-8 alternator with bypassing the battery contactor. The extra snort available from the larger wound field makes this a moot point . . . Z12 would simplify your wiring. Bob . . . ________________________________________________________________________________
Date: Apr 10, 2017
At 06:47 PM 4/10/2017, you wrote: > >Here is a link to the VAF thread that Charlie mentioned. >http://www.vansairforce.com/community/showthread.php?p=1164359#post1164359 >It seems that the pilot was unable to shut down the alternator with >either the field switch or master switch. >Anyone who installs a Lithium battery should read the Dynon Support >post #7 in that thread. Without aircraft electrical system >over-voltage protection, a Lithium battery could disconnect itself >from the electrical system to protect itself against an over-voltage >event. Without a lead-acid battery to mitigate over-voltage, very >expensive avionics are at the mercy of a runaway alternator. >Post number 17 by Dynon Support is also interesting. The assertions made in this posting are largely correct. The stock internally regulated alternator has failure modes for ov conditions that cannot be controlled from the outside. With no battery on line to grunt the excess energy, bus voltages of 100-200 volts are easily realized. I had conversation with folks about this very topic last week . . . the event chronicled on the RV forum may have triggered the queries. The battery has always been a CRITICAL component of the overvoltage mitigation dynamic. The auto-disconnect feature in EarthX batteries is understandable from the battery safety perspective . . . but it may upset the apple cart when it fails to perform legacy duties expected of lead-acid batteries. Bob . . . ________________________________________________________________________________
Date: Apr 10, 2017
Bob, I am using the SB1B-14 regulator. Ed On 4/10/2017 7:26 PM, Robert L. Nuckolls, III wrote: > At 05:39 PM 4/10/2017, you wrote: >> Bob, >> Following the Z-13/8, I am connecting up the backup alternator to >> the hot side of the battery contactor. With the distance that the >> power is traveling, I calculated that the #6 wire would be the best >> choice. Did I choose wrong? > > How about Z12 instead? Tie both alternators to > the bus structure at the hot side of the starter > contactor. > > Just use the smaller alternator like a stand-by > device like hundreds of TC aircraft. Which > regulator are you using on the small alternator? > > Z-13/8 was crafted specifically for minimizing loads > on the diminutive SD-8 alternator with bypassing > the battery contactor. The extra snort > available from the larger wound field makes this > a moot point . . . Z12 would simplify your wiring. > > > Bob . . . > ________________________________________________________________________________
Date: Apr 11, 2017
Regarding the overvoltage event with an earthX battery. Apparently the fried system did not have an overvoltage module installed. Would the B&C overvoltage module have made this a non event? Paul On Mon, Apr 10, 2017 at 8:53 PM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 06:47 PM 4/10/2017, you wrote: > > > Here is a link to the VAF thread that Charlie mentioned. > http://www.vansairforce.com/community/showthread.php?p=1164359#post1164359 > It seems that the pilot was unable to shut down the alternator with either > the field switch or master switch. > Anyone who installs a Lithium battery should read the Dynon Support post > #7 in that thread. Without aircraft electrical system over-voltage > protection, a Lithium battery could disconnect itself from the electrical > system to protect itself against an over-voltage event. Without a > lead-acid battery to mitigate over-voltage, very expensive avionics are at > the mercy of a runaway alternator. > Post number 17 by Dynon Support is also interesting. > > > The assertions made in this posting are largely > correct. The stock internally regulated alternator > has failure modes for ov conditions that cannot > be controlled from the outside. > > With no battery on line to grunt the excess energy, > bus voltages of 100-200 volts are easily realized. > I had conversation with folks about this > very topic last week . . . the event chronicled > on the RV forum may have triggered the queries. > > The battery has always been a CRITICAL component > of the overvoltage mitigation dynamic. The > auto-disconnect feature in EarthX batteries is > understandable from the battery safety > perspective . . . but it may upset the apple cart > when it fails to perform legacy duties expected > of lead-acid batteries. > > > Bob . . . > ________________________________________________________________________________
Date: Apr 11, 2017
At 08:33 PM 4/10/2017, you wrote: >Bob, > I am using the SB1B-14 regulator. Okay . . . I'd recommend a Z-12 with endurance bus. Much simpler in terms of wire and not significantly less robust. Bob . . . ________________________________________________________________________________
Date: Apr 11, 2017
Bob, Thanks for the insight. I will review the Z12 ans see if I want to make the changes. Also, thank you to those others who offered up advice. Ed On 4/11/2017 10:27 AM, Robert L. Nuckolls, III wrote: > At 08:33 PM 4/10/2017, you wrote: >> Bob, >> I am using the SB1B-14 regulator. > > Okay . . . I'd recommend a Z-12 with > endurance bus. Much simpler in terms > of wire and not significantly less > robust. > > > Bob . . . > ________________________________________________________________________________
Date: Apr 11, 2017
Paul, the Alternator causing the issue was an internal regulated one, the B&C OVM is for external regulated and yes it would tehre avoid such things. Cheers Werner On 11.04.2017 17:18, Paul Eckenroth wrote: > Regarding the overvoltage event with an earthX battery. Apparently the > fried system did not have an overvoltage module installed. Would the > B&C overvoltage module have made this a non event? > > Paul > ________________________________________________________________________________
Date: Apr 11, 2017
At 10:18 AM 4/11/2017, you wrote: >Regarding the overvoltage event with an earthX >battery.=C2 Apparently the fried system did not >have an overvoltage module installed.=C2 Would >the B&C overvoltage module have made this a non event? Yes . . . sorta . . . The B&C Crowbar OV module deliberately opens the alternator's field supply breaker when an ov event is detected. The problem with STOCK automotive alternators is difficulty of accessing the field supply power path. The alternator must be disassembled and modified for such service. This is what B&C has routinely accomplished on all their IR alternators since day-one. Over the years, there have been numerous articles in the OBAM aviation journals describing techniques for modifying various brands of IR alternator to external regulator service. Early Plane Power products were modified to to ADD the crowbar OV module right on the back of the stock alternator housing . . . current offerings have the module built in . . . http://tinyurl.com/lnypyeq Running an internally regulated alternator with no ov protection is a relatively low risk decision . . . but the risk is NOT ZERO. Further, the stock alternators do not permit the system integrator to offer absolute on/off control of alternator output by crew under all circumstances. Bob . . . ________________________________________________________________________________
Date: Apr 11, 2017
Subject: Trivia for the Day: Y2M Series Connectors
There's a relatively new kid on the block in the community of robust connectors. I've been seeing offers for several years but didn't have time/inclination to explore them. A few weeks ago, I ordered a Y2M-5TK, 5-pin 'military' connector for a hands-on, look-see . . . Emacs! This connector has lots of cousins offered all over the 'net. An exemplar constellation of offerings can be found here. http://tinyurl.com/mt78ajg The prices are VERY attractive. The quality is excellent. The only down-side is that you need to hone your soldering skills. I'd have no problem with using these connectors in application on our airplanes. Note: The backshell on the cable end has a fine LEFT HAND THREAD. Further, you need to have the connector halves mated thus securing the cable innards for tightening the backshell. The fine thread is a little fussy getting it started . . . easy to cross thread. Bob . . . ________________________________________________________________________________
Subject: Re: Trivia for the Day: Y2M Series Connectors
Date: Apr 11, 2017
Bob, thank you for the report. Jan de Jong ________________________________________________________________________________
Subject: Starter engaged warning light
Date: Apr 11, 2017
Bob and fellow listers, My starter solenoid (B&C) is not the type with a post for a starter engaged warning light. It seems to me that I could simply run a wire from the starter side of the solenoid to a warning lamp with no issues. Once energized, the starter would draw it's large current and the lamp it's very small current. Is it that simple of am I missing something? Thanks Jeff Point Milwaukee ________________________________________________________________________________
Subject: Re: Starter engaged warning light
Date: Apr 11, 2017
Hey Jeff, I'm not 100% sure on this but I think I've seen a cutaway photo showing that the "I" terminal on the other type of solenoid is actually connected internally to the same basic spot as the big terminal is. So I would think it would work just fine. I can't think of any real reason not to do it, as long as the main terminal is secure and has enough exposed threads with an added ring terminal there, and I bet it will fit fine. I did put the starter engaged light on my -14, but I have the regular Van's solenoid. Mine is like the second one on page 6. http://verticalpower.com/_documents/_pdf/contactor_wiring.pdf I'm guessing that the reason they even added the terminal is for simplicity in wiring those smaller wire ends to the solenoid without needing a large ring terminal. Tim Up NorthWest of you On 4/11/2017 10:27 PM, Jeff Point wrote: > > Bob and fellow listers, > > My starter solenoid (B&C) is not the type with a post for a starter > engaged warning light. It seems to me that I could simply run a wire > from the starter side of the solenoid to a warning lamp with no > issues. Once energized, the starter would draw it's large current and > the lamp it's very small current. Is it that simple of am I missing > something? > > Thanks > > Jeff Point > Milwaukee ________________________________________________________________________________
Subject: Re: Digital Industrial Scales Outlets
Date: Apr 11, 2017
i always buy products from Amazon such as body weight scale Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468321#468321 ________________________________________________________________________________
Date: Apr 12, 2017
At 11:21 PM 4/11/2017, you wrote: > >Hey Jeff, > >I'm not 100% sure on this but I think I've seen a cutaway photo >showing that the >"I" terminal on the other type of solenoid is actually connected >internally to the same >basic spot as the big terminal is. So I would think it would work just fine. Correct . . . >I'm guessing that the reason they even added the terminal is for >simplicity in wiring those smaller wire ends to the solenoid without needing >a large ring terminal. Actually, the "I" terminal is a holdover from the early days of the transition from 6 to 12 volt cars. It was deduced that the original 6v Kettering type ignition coil could be retained if one simply added a resistor in series with the coil . . . the added source resistance REDUCES coil charging time and you got better performance at higher RPM. A further benefit was realized by adding the "I" for ignition terminal to the starter contactor. This was used to bypass the coil resistor increased spark energy at low RPM of engine cranking. You can see the full disclosure of the 3-terminal starter contactors here: Emacs! All three 'floating' terminals of the power path through the contactor get connected together simultaneously with the motion of "B" against "A" as suggested by the schematic below. http://www.aeroelectric.com/Pictures/Contactors/Starter_Contact Fully floating contacts were necessary to achieve design goals for the automotive world . . . and they're handy for our purposes 60 years later to drive a light bulb . . . but the same goal can be achieved by attaching driving the light directly from the starter motor's power input terminal. Don't forget to fuse the wire at the starter end if driving a lamp . . . or you could put the LED's current limiting resistor in series with the wire at the starter end and eliminate the fuse . . . the resistor will protect the shorted wire. > Bob . . . ________________________________________________________________________________
Date: Apr 12, 2017
Subject: [OT] DecalPRO
Not strictly electrical but I'll be somebody here has some experience... I am thinking about using the DecalPRO <http://www.pulsarprofx.com/decalpro/Vertical/1_MENU/1a_Home/Aircraft/Aircraft.html> system for my instrument panel. Do you have any experience with it? -- Art Z. -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Subject: Re: [OT] DecalPRO
Date: Apr 12, 2017
Art, I used that system on my panel. It takes some practice to get good results, but it does work. I did the panel 8 years ago and it's held up well. Jim On 4/12/2017 8:47 AM, Art Zemon wrote: > Not strictly electrical but I'll be somebody here has some experience... > > I am thinking about using the DecalPRO > <http://www.pulsarprofx.com/decalpro/Vertical/1_MENU/1a_Home/Aircraft/Aircraft.html> > system for my instrument panel. Do you have any experience with it? > > -- Art Z. > > -- > https://CheerfulCurmudgeon.com/ > > /"If I am not for myself, who is for me? And if I am only for myself, > what am I? And if not now, when?" Hillel/ > !DSPAM:729,58ee3381247391849433127! ________________________________________________________________________________
Date: Apr 12, 2017
Greetings Art. I have the Decal Pro system and it is great, although somewhat complicated. You print out your labels using a Laser printer (cannon, I think is not allowed) You then take your label sheet and using a heat/plastic laminatior-- has to be the type they recommend, and I believe sell-- make several passes of your label sheet with a few types of transfer foil and paper. You then soak the labels that you have created to remove them from the carrier paper, dry them and using a special fabric adhesive (available at fabric stores) spray the back of your labels and apply them to their home burnishing them in. I put them on my leather instrument panel and I think that they came out well. There is a steep learning curve. Somewhere in the technique there is a heat gun (hair dryer is not acceptable) (the labels on my panel were black.\ My next step is to do my switch labels (in white) which requires yet an additional step or two. I have postponed that for a year or two, but will get back to that soon. Look at the videos on the website, although the actual technique is slightly different... they will tell you. Great product, difficult to use steep learning curve . Rich In a message dated 4/12/2017 8:51:27 A.M. Central Daylight Time, art(at)zemon.name writes: Not strictly electrical but I'll be somebody here has some experience... I am thinking about using the _DecalPRO_ (http://www.pulsarprofx.com/decalpro/Vertical/1_MENU/1a_Home/Aircraft/Aircraft.html) system for my instrument panel. Do you have any experience with it? -- Art Z. -- _https://CheerfulCurmudgeon.com/_ (https://cheerfulcurmudgeon.com/) "If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel ________________________________________________________________________________
Date: Apr 12, 2017
Subject: RS-232 GPS Input
Folks, I am considering an ARTEX ELT 345 which requires a GPS signal to its "Built-in GPS Navigational Interface (NMEA 0183 or RS 232)." If I understand how to do this correctly from a Garmin GNS-430W, I just take the RS-232 signal and a ground and run them to the ELT. Right? The last time I did any RS-232 wiring was between DEC VAX computers and VT-100 terminals in the 1980s. Is there anything that I should know with regards to wiring these more modern devices? Thanks, -- Art Z. -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Date: Apr 12, 2017
Subject: Re: RS-232 GPS Input
Art, You're pretty much on the money...couple of tricks with the 430W: The 430W has multiple output ports - if you have one set to "Aviation", you can simply fork that output signal wire. Make sure that output port on the 430W is set to the correct output type ("Aviation") to match the ARTEX - the default 9600 baud rate should take care of it. Wiring a different port from the 430W is a PITB unless your panel has real good access. Configure your new port for "Aviation" and you should be good to go. I just did this to add ADSB and learned the difference between ports and protocols output from the 430W - I needed "ADS-B OUT+" (wasn't in the original manual - found out while troubleshooting with vendor) and had it connected to the "Aviation" port. I needed to run a separate wire just for this! Good Luck, Ralph -----Original Message----- From: Art Zemon Sent: Apr 12, 2017 2:54 PM Subject: AeroElectric-List: RS-232 GPS Input Folks, I am considering an ARTEX ELT 345 which requires a GPS signal to its "Built-in GPS Navigational Interface (NMEA 0183 or RS 232)." If I understand how to do this correctly from a Garmin GNS-430W, I just take the RS-232 signal and a ground and run them to the ELT. Right? The last time I did any RS-232 wiring was between DEC VAX computers and VT-100 terminals in the 1980s. Is there anything that I should know with regards to wiring these more modern devices? Thanks, -- Art Z. -- https://CheerfulCurmudgeon.com/ "If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel ________________________________________________________________________________
Date: Apr 12, 2017
Another option is to go to ebay for a $20 gps puck with serial output, & have an independent source. On Wed, Apr 12, 2017 at 2:19 PM, Ralph E. Capen wrote: > recapen(at)earthlink.net> > > Art, > You're pretty much on the money...couple of tricks with the 430W: > The 430W has multiple output ports - if you have one set to "Aviation", > you can simply fork that output signal wire. > Make sure that output port on the 430W is set to the correct output type > ("Aviation") to match the ARTEX - the default 9600 baud rate should take > care of it. > Wiring a different port from the 430W is a PITB unless your panel has real > good access. Configure your new port for "Aviation" and you should be good > to go. > > I just did this to add ADSB and learned the difference between ports and > protocols output from the 430W - I needed "ADS-B OUT+" (wasn't in the > original manual - found out while troubleshooting with vendor) and had it > connected to the "Aviation" port. I needed to run a separate wire just for > this! > > Good Luck, > Ralph > > -----Original Message----- > > From: Art Zemon > > Sent: Apr 12, 2017 2:54 PM > > To: aeroelectric-list(at)matronics.com > > Subject: AeroElectric-List: RS-232 GPS Input > > > Folks, > I am considering an ARTEX ELT 345 which requires a GPS signal to its > "Built-in GPS Navigational Interface (NMEA 0183 or RS 232)." If I > understand how to do this correctly from a Garmin GNS-430W, I just take the > RS-232 signal and a ground and run them to the ELT. Right? > The last time I did any RS-232 wiring was between DEC VAX computers and > VT-100 terminals in the 1980s. Is there anything that I should know with > regards to wiring these more modern devices? > Thanks, -- Art Z. > > -- > https://CheerfulCurmudgeon.com/ > > "If I am not for myself, who is for me? And if I am only for myself, what > am I? And if not now, when?" Hillel > > ________________________________________________________________________________
Date: Apr 12, 2017
Another option is to go to ebay for a $20 gps puck with serial output, & have an independent source. Charlie, The 2020 rules for ADS-B out require an approved WAAS GPS source. I do not know of ant "puck" GPS that meets this requirement. If you know of one please let me know. On Wed, Apr 12, 2017 at 12:33 PM, Charlie England wrote: > Another option is to go to ebay for a $20 gps puck with serial output, & > have an independent source. > > On Wed, Apr 12, 2017 at 2:19 PM, Ralph E. Capen > wrote: > >> recapen(at)earthlink.net> >> >> Art, >> You're pretty much on the money...couple of tricks with the 430W: >> The 430W has multiple output ports - if you have one set to "Aviation", >> you can simply fork that output signal wire. >> Make sure that output port on the 430W is set to the correct output type >> ("Aviation") to match the ARTEX - the default 9600 baud rate should take >> care of it. >> Wiring a different port from the 430W is a PITB unless your panel has >> real good access. Configure your new port for "Aviation" and you should be >> good to go. >> >> I just did this to add ADSB and learned the difference between ports and >> protocols output from the 430W - I needed "ADS-B OUT+" (wasn't in the >> original manual - found out while troubleshooting with vendor) and had it >> connected to the "Aviation" port. I needed to run a separate wire just for >> this! >> >> Good Luck, >> Ralph >> >> -----Original Message----- >> >> From: Art Zemon >> >> Sent: Apr 12, 2017 2:54 PM >> >> To: aeroelectric-list(at)matronics.com >> >> Subject: AeroElectric-List: RS-232 GPS Input >> >> >> >> Folks, >> I am considering an ARTEX ELT 345 which requires a GPS signal to its >> "Built-in GPS Navigational Interface (NMEA 0183 or RS 232)." If I >> understand how to do this correctly from a Garmin GNS-430W, I just take the >> RS-232 signal and a ground and run them to the ELT. Right? >> The last time I did any RS-232 wiring was between DEC VAX computers and >> VT-100 terminals in the 1980s. Is there anything that I should know with >> regards to wiring these more modern devices? >> Thanks, -- Art Z. >> >> -- >> https://CheerfulCurmudgeon.com/ >> >> "If I am not for myself, who is for me? And if I am only for myself, what >> am I? And if not now, when?" Hillel >> >> ________________________________________________________________________________
Date: Apr 12, 2017
1. He was using the GPS for ELT, not ADS-B. Does not need to meet any approval. 2. The Dynon 2020 GPS puck meets the requirement, but it isn't cheap, at $590. May not work with other brands. On 4/12/2017 1:01 PM, don van santen wrote: > Another option is to go to ebay for a $20 gps puck with serial output, & > have an independent source. > > Charlie, > The 2020 rules for ADS-B out require an approved WAAS GPS source. I do > not know of ant "puck" GPS that meets this requirement. If you know of > one please let me know. > > On Wed, Apr 12, 2017 at 12:33 PM, Charlie England > wrote: > > Another option is to go to ebay for a $20 gps puck with serial > output, & have an independent source. > > On Wed, Apr 12, 2017 at 2:19 PM, Ralph E. Capen > > wrote: > > > > > Art, > You're pretty much on the money...couple of tricks with the 430W: > The 430W has multiple output ports - if you have one set to > "Aviation", you can simply fork that output signal wire. > Make sure that output port on the 430W is set to the correct > output type ("Aviation") to match the ARTEX - the default 9600 > baud rate should take care of it. > Wiring a different port from the 430W is a PITB unless your > panel has real good access. Configure your new port for > "Aviation" and you should be good to go. > > I just did this to add ADSB and learned the difference between > ports and protocols output from the 430W - I needed "ADS-B OUT+" > (wasn't in the original manual - found out while troubleshooting > with vendor) and had it connected to the "Aviation" port. I > needed to run a separate wire just for this! > > Good Luck, > Ralph > > -----Original Message----- > > From: Art Zemon > > Sent: Apr 12, 2017 2:54 PM > > To: aeroelectric-list(at)matronics.com > > > Subject: AeroElectric-List: RS-232 GPS Input > > > Folks, > I am considering an ARTEX ELT 345 which requires a GPS signal to > its "Built-in GPS Navigational Interface (NMEA 0183 or RS 232)." > If I understand how to do this correctly from a Garmin GNS-430W, > I just take the RS-232 signal and a ground and run them to the > ELT. Right? > The last time I did any RS-232 wiring was between DEC VAX > computers and VT-100 terminals in the 1980s. Is there anything > that I should know with regards to wiring these more modern devices? > Thanks, -- Art Z. > > -- > https://CheerfulCurmudgeon.com/ > > "If I am not for myself, who is for me? And if I am only for > myself, what am I? And if not now, when?" Hillel > > ________________________________________________________________________________
Subject: Is a battery contactor really needed?
Date: Apr 12, 2017
There seem to be a lot of advantages to not disconnecting the alternator from the battery, so I'm wondering if the battery contactor is really necessary? The things I can see as advantages are that it provides an extra layer of protection from accidental starter engagement, and provides a big switch that can be used to disconnect the battery from everything. I'm curious if there are other advantages that I'm not seeing. Thanks! -------- Mickey Coggins http://www.rv8.ch/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468348#468348 ________________________________________________________________________________
Date: Apr 12, 2017
This is for an ELT, not ADS-B. > On Apr 12, 2017, at 3:01 PM, don van santen wrote : > > Another option is to go to ebay for a $20 gps puck with serial output, & h ave an independent source. > > Charlie, > The 2020 rules for ADS-B out require an approved WAAS GPS source. I do not know of ant "puck" GPS that meets this requirement. If you know of one plea se let me know. > >> On Wed, Apr 12, 2017 at 12:33 PM, Charlie England w rote: >> Another option is to go to ebay for a $20 gps puck with serial output, & h ave an independent source. >> >>> On Wed, Apr 12, 2017 at 2:19 PM, Ralph E. Capen w rote: link.net> >>> >>> Art, >>> You're pretty much on the money...couple of tricks with the 430W: >>> The 430W has multiple output ports - if you have one set to "Aviation", y ou can simply fork that output signal wire. >>> Make sure that output port on the 430W is set to the correct output type ("Aviation") to match the ARTEX - the default 9600 baud rate should take ca re of it. >>> Wiring a different port from the 430W is a PITB unless your panel has re al good access. Configure your new port for "Aviation" and you should be go od to go. >>> >>> I just did this to add ADSB and learned the difference between ports and protocols output from the 430W - I needed "ADS-B OUT+" (wasn't in the origi nal manual - found out while troubleshooting with vendor) and had it connect ed to the "Aviation" port. I needed to run a separate wire just for this! >>> >>> Good Luck, >>> Ralph >>> >>> -----Original Message----- >>> >>> From: Art Zemon >>> >>> Sent: Apr 12, 2017 2:54 PM >>> >>> To: aeroelectric-list(at)matronics.com >>> >>> Subject: AeroElectric-List: RS-232 GPS Input >>> >>> >>> >>> Folks, >>> I am considering an ARTEX ELT 345 which requires a GPS signal to its "Bu ilt-in GPS Navigational Interface (NMEA 0183 or RS 232)." If I understand ho w to do this correctly from a Garmin GNS-430W, I just take the RS-232 signal and a ground and run them to the ELT. Right? >>> The last time I did any RS-232 wiring was between DEC VAX computers and V T-100 terminals in the 1980s. Is there anything that I should know with rega rds to wiring these more modern devices? >>> Thanks, -- Art Z. >>> >>> -- >>> https://CheerfulCurmudgeon.com/ >>> >>> "If I am not for myself, who is for me? And if I am only for myself, wha t am I? And if not now, when?" Hillel > ________________________________________________________________________________
Date: Apr 12, 2017
The new Dynon GPS antenna/device is approved it may only talk to dynon, however. Rich In a message dated 4/12/2017 3:44:16 P.M. Central Daylight Time, Tim(at)MyRV10.com writes: This is for an ELT, not ADS-B. On Apr 12, 2017, at 3:01 PM, don van santen <_donvansanten(at)gmail.com_ (mailto:donvansanten(at)gmail.com) > wrote: Another option is to go to ebay for a $20 gps puck with serial output, & have an independent source. Charlie, The 2020 rules for ADS-B out require an approved WAAS GPS source. I do not know of ant "puck" GPS that meets this requirement. If you know of one please let me know. On Wed, Apr 12, 2017 at 12:33 PM, Charlie England <_ceengland7(at)gmail.com_ (mailto:ceengland7(at)gmail.com) > wrote: Another option is to go to ebay for a $20 gps puck with serial output, & have an independent source. On Wed, Apr 12, 2017 at 2:19 PM, Ralph E. Capen <_recapen(at)earthlink.net_ (mailto:recapen(at)earthlink.net) > wrote: --> AeroElectric-List message posted by: "Ralph E. Capen" <_recapen(at)earthlink.net_ (mailto:recapen(at)earthlink.net) > Art, You're pretty much on the money...couple of tricks with the 430W: The 430W has multiple output ports - if you have one set to "Aviation", you can simply fork that output signal wire. Make sure that output port on the 430W is set to the correct output type ("Aviation") to match the ARTEX - the default 9600 baud rate should take care of it. Wiring a different port from the 430W is a PITB unless your panel has real good access. Configure your new port for "Aviation" and you should be good to go. I just did this to add ADSB and learned the difference between ports and protocols output from the 430W - I needed "ADS-B OUT+" (wasn't in the original manual - found out while troubleshooting with vendor) and had it connected to the "Aviation" port. I needed to run a separate wire just for this! Good Luck, Ralph -----Original Message----- From: Art Zemon Sent: Apr 12, 2017 2:54 PM (mailto:aeroelectric-list(at)matronics.com) Subject: AeroElectric-List: RS-232 GPS Input Folks, I am considering an ARTEX ELT 345 which requires a GPS signal to its "Built-in GPS Navigational Interface (NMEA 0183 or RS 232)." If I understand how to do this correctly from a Garmin GNS-430W, I just take the RS-232 signal and a ground and run them to the ELT. Right? The last time I did any RS-232 wiring was between DEC VAX computers and VT-100 terminals in the 1980s. Is there anything that I should know with regards to wiring these more modern devices? Thanks, -- Art Z. -- _https://CheerfulCurmudgeon.comh_ (https://cheerfulcurmudgeon.com/) "If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel ________________________________________________________________________________
Date: Apr 12, 2017
Sorry. I guess I need to get my eyes checked. DDon On Wed, Apr 12, 2017 at 1:38 PM, Tim Olson wrote: > This is for an ELT, not ADS-B. > > > On Apr 12, 2017, at 3:01 PM, don van santen > wrote: > > Another option is to go to ebay for a $20 gps puck with serial output, & > have an independent source. > > Charlie, > The 2020 rules for ADS-B out require an approved WAAS GPS source. I do not > know of ant "puck" GPS that meets this requirement. If you know of one > please let me know. > > On Wed, Apr 12, 2017 at 12:33 PM, Charlie England > wrote: > >> Another option is to go to ebay for a $20 gps puck with serial output, & >> have an independent source. >> >> On Wed, Apr 12, 2017 at 2:19 PM, Ralph E. Capen >> wrote: >> >>> recapen(at)earthlink.net> >>> >>> Art, >>> You're pretty much on the money...couple of tricks with the 430W: >>> The 430W has multiple output ports - if you have one set to "Aviation", >>> you can simply fork that output signal wire. >>> Make sure that output port on the 430W is set to the correct output type >>> ("Aviation") to match the ARTEX - the default 9600 baud rate should take >>> care of it. >>> Wiring a different port from the 430W is a PITB unless your panel has >>> real good access. Configure your new port for "Aviation" and you should be >>> good to go. >>> >>> I just did this to add ADSB and learned the difference between ports and >>> protocols output from the 430W - I needed "ADS-B OUT+" (wasn't in the >>> original manual - found out while troubleshooting with vendor) and had it >>> connected to the "Aviation" port. I needed to run a separate wire just for >>> this! >>> >>> Good Luck, >>> Ralph >>> >>> -----Original Message----- >>> >>> From: Art Zemon >>> >>> Sent: Apr 12, 2017 2:54 PM >>> >>> To: aeroelectric-list(at)matronics.com >>> >>> Subject: AeroElectric-List: RS-232 GPS Input >>> >>> >>> >>> Folks, >>> I am considering an ARTEX ELT 345 which requires a GPS signal to its >>> "Built-in GPS Navigational Interface (NMEA 0183 or RS 232)." If I >>> understand how to do this correctly from a Garmin GNS-430W, I just take the >>> RS-232 signal and a ground and run them to the ELT. Right? >>> The last time I did any RS-232 wiring was between DEC VAX computers and >>> VT-100 terminals in the 1980s. Is there anything that I should know with >>> regards to wiring these more modern devices? >>> Thanks, -- Art Z. >>> >>> -- >>> https://CheerfulCurmudgeon.com/ >>> >>> "If I am not for myself, who is for me? And if I am only for myself, >>> what am I? And if not now, when?" Hillel >>> >>> > ________________________________________________________________________________
Date: Apr 12, 2017
Ralph, Thanks for confirming. I do intend to feed both the ADS-B and the ELT from the 430W. I read of lots of people just splitting the signal to feed two devices, which seems odd to me but then this is one-way communication so I guess it ought to work. And I will check my ADS-B documentation carefully to be sure that I get the right signal from the 430W. So... just a single twisted pair for these RS-232 devices? I don't need any of the other pins besides + and - ??? Should I shield it and, if so, where do I ground the shield? -- Art Z. On Wed, Apr 12, 2017 at 2:19 PM, Ralph E. Capen wrote: > recapen(at)earthlink.net> > > Art, > You're pretty much on the money...couple of tricks with the 430W: > The 430W has multiple output ports - if you have one set to "Aviation", > you can simply fork that output signal wire. > Make sure that output port on the 430W is set to the correct output type > ("Aviation") to match the ARTEX - the default 9600 baud rate should take > care of it. > Wiring a different port from the 430W is a PITB unless your panel has real > good access. Configure your new port for "Aviation" and you should be good > to go. > > I just did this to add ADSB and learned the difference between ports and > protocols output from the 430W - I needed "ADS-B OUT+" (wasn't in the > original manual - found out while troubleshooting with vendor) and had it > connected to the "Aviation" port. I needed to run a separate wire just for > this! > > Good Luck, > Ralph > > -----Original Message----- > > From: Art Zemon > > Sent: Apr 12, 2017 2:54 PM > > To: aeroelectric-list(at)matronics.com > > Subject: AeroElectric-List: RS-232 GPS Input > > > Folks, > I am considering an ARTEX ELT 345 which requires a GPS signal to its > "Built-in GPS Navigational Interface (NMEA 0183 or RS 232)." If I > understand how to do this correctly from a Garmin GNS-430W, I just take the > RS-232 signal and a ground and run them to the ELT. Right? > The last time I did any RS-232 wiring was between DEC VAX computers and > VT-100 terminals in the 1980s. Is there anything that I should know with > regards to wiring these more modern devices? > Thanks, -- Art Z. > -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Date: Apr 12, 2017
Thanks Bob (and others) for the detailed explanation confirming what I thought. Protecting this run of 22ga wire seems like a perfect job for a fusible link, and since I have some 26ga left over from the Ray Allen servos, I will make one. The panel LED has a resistor built in so that option is not available. Jeff On 4/12/17 4:25 AM, Robert L. Nuckolls, III wrote: ________________________________________________________________________________
Date: Apr 12, 2017
Art, I may not have been clear enough... >From my reading of the ARTEX ELT manual, it needs "Aviation" from the 430W. It looks like you can use a single pin shielded wire (grounded at the 430W end) for the TX (at the 430W end) to the RX (at the ARTEX end - pin 9). If you have something else that already uses "Aviation", you can do a take-off from that port/wire - otherwise, see the next paragraph. Depending on the ADSB box, it will most likely need "ADS-B OUT+" from the 430W - mine did. This required me to use a different port on the 430W for the ADSB box. I used a single pin shielded wire (grounded at the 430W end) for the TX (at the 430W end) to the RX (at the ADSB end) for mine. It was a different port! I have already 'wasted' the troubleshooting hours figuring out why it wasn't working (install manual didn't call out "ADS-B OUT+" - I had to get that from tech support after I had already wired it the other way. I've got a picture of the 430W config if you want it - let me know and I'll send it direct! Hope this clears the mud I stirred up! Ralph -----Original Message----- From: Art Zemon Sent: Apr 12, 2017 6:10 PM Subject: Re: AeroElectric-List: RS-232 GPS Input Ralph, Thanks for confirming. I do intend to feed both the ADS-B and the ELT from the 430W. I read of lots of people just splitting the signal to feed two devices, which seems odd to me but then this is one-way communication so I guess it ought to work. And I will check my ADS-B documentation carefully to be sure that I get the right signal from the 430W. So... just a single twisted pair for these RS-232 devices? I don't need any of the other pins besides + and - ???Should I shield it and, if so, where do I ground the shield? -- Art Z. On Wed, Apr 12, 2017 at 2:19 PM, Ralph E. Capen wrote: Art, You're pretty much on the money...couple of tricks with the 430W: The 430W has multiple output ports - if you have one set to "Aviation", you can simply fork that output signal wire. Make sure that output port on the 430W is set to the correct output type ("Aviation") to match the ARTEX - the default 9600 baud rate should take care of it. Wiring a different port from the 430W is a PITB unless your panel has real good access. Configure your new port for "Aviation" and you should be good to go. I just did this to add ADSB and learned the difference between ports and protocols output from the 430W - I needed "ADS-B OUT+" (wasn't in the original manual - found out while troubleshooting with vendor) and had it connected to the "Aviation" port. I needed to run a separate wire just for this! Good Luck, Ralph -----Original Message----- From: Art Zemon Sent: Apr 12, 2017 2:54 PM Subject: AeroElectric-List: RS-232 GPS Input Folks, I am considering an ARTEX ELT 345 which requires a GPS signal to its "Built-in GPS Navigational Interface (NMEA 0183 or RS 232)." If I understand how to do this correctly from a Garmin GNS-430W, I just take the RS-232 signal and a ground and run them to the ELT. Right? The last time I did any RS-232 wiring was between DEC VAX computers and VT-100 terminals in the 1980s. Is there anything that I should know with regards to wiring these more modern devices? Thanks, -- Art Z. -- https://CheerfulCurmudgeon.com/ "If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel ________________________________________________________________________________
Subject: Re: Is a battery contactor really needed?
Date: Apr 12, 2017
In case of an immanent forced landing or smoke in the cockpit, it is advisable to shut off electrical power as close to the source as possible. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468357#468357 ________________________________________________________________________________
Date: Apr 12, 2017
Subject: Re: old B and C SD-8 Dynamo failure
>>Bob, if you wanted to look at this dynamo for some reason, I'll be happy >>to mail it to you. I suspect you've got much better things to do than >>'paleo-forensics' on this dated item. >> >>Mark > > Actually, I would like to see it. I have > a drive stand running that fits the SD8 > and I'm equipped to test/inspect it in > detail. Getting a close up look at a sample > with this kind of service on it would be > illuminating. > > Send the rectifier/regulator too. I'll > get them checked out and repaired/replaced > as needed. Got Mark's SD8 and R/R from the post office today. Ran the SD8. As I would have predicted, it runs just fine. The construction of these machines doesn't have much of a wear-out mode. The bearings are VERY lightly loaded. There are no brushes or slip rings. The stationary windings might be a some risk for aging were they operated at temperatures that pushed the insulation limits on the magnet wire. The numbers on Mr. Todd's SD8 track very closely with those from a new, current protection unit. I've got some wiring details to fiddle with before I can add the R/R to the bench setup . . . perhaps tomorrow. Watch this space . . . Bob . . . ________________________________________________________________________________
Date: Apr 12, 2017
That clears it up. Thank you, Ralph. When I get to actually making wires, I'll be back in touch if I am confused. -- Art Z. On Wed, Apr 12, 2017 at 5:55 PM, Ralph E. Capen wrote: > recapen(at)earthlink.net> > > > Art, > > I may not have been clear enough... > > >From my reading of the ARTEX ELT manual, it needs "Aviation" from the > 430W. It looks like you can use a single pin shielded wire (grounded at > the 430W end) for the TX (at the 430W end) to the RX (at the ARTEX end - > pin 9). If you have something else that already uses "Aviation", you can > do a take-off from that port/wire - otherwise, see the next paragraph. > > Depending on the ADSB box, it will most likely need "ADS-B OUT+" from the > 430W - mine did. This required me to use a different port on the 430W for > the ADSB box. I used a single pin shielded wire (grounded at the 430W end) > for the TX (at the 430W end) to the RX (at the ADSB end) for mine. It was > a different port! > > I have already 'wasted' the troubleshooting hours figuring out why it > wasn't working (install manual didn't call out "ADS-B OUT+" - I had to get > that from tech support after I had already wired it the other way. > > I've got a picture of the 430W config if you want it - let me know and > I'll send it direct! > > Hope this clears the mud I stirred up! > > Ralph > > > -----Original Message----- > > From: Art Zemon > > Sent: Apr 12, 2017 6:10 PM > > To: aeroelectric-list(at)matronics.com > > Subject: Re: AeroElectric-List: RS-232 GPS Input > > > Ralph, > Thanks for confirming. I do intend to feed both the ADS-B and the ELT from > the 430W. I read of lots of people just splitting the signal to feed two > devices, which seems odd to me but then this is one-way communication so I > guess it ought to work. And I will check my ADS-B documentation carefully > to be sure that I get the right signal from the 430W. > So... just a single twisted pair for these RS-232 devices? I don't need > any of the other pins besides + and - ???Should I shield it and, if so, > where do I ground the shield? > -- Art Z. > > On Wed, Apr 12, 2017 at 2:19 PM, Ralph E. Capen > wrote: > recapen(at)earthlink.net> > > > Art, > > You're pretty much on the money...couple of tricks with the 430W: > > The 430W has multiple output ports - if you have one set to "Aviation", > you can simply fork that output signal wire. > > Make sure that output port on the 430W is set to the correct output type > ("Aviation") to match the ARTEX - the default 9600 baud rate should take > care of it. > > Wiring a different port from the 430W is a PITB unless your panel has real > good access. Configure your new port for "Aviation" and you should be good > to go. > > > I just did this to add ADSB and learned the difference between ports and > protocols output from the 430W - I needed "ADS-B OUT+" (wasn't in the > original manual - found out while troubleshooting with vendor) and had it > connected to the "Aviation" port. I needed to run a separate wire just for > this! > > > Good Luck, > > Ralph > > > -----Original Message----- > > > From: Art Zemon > > > Sent: Apr 12, 2017 2:54 PM > > > To: aeroelectric-list(at)matronics.com > > > Subject: AeroElectric-List: RS-232 GPS Input > > > Folks, > > I am considering an ARTEX ELT 345 which requires a GPS signal to its > "Built-in GPS Navigational Interface (NMEA 0183 or RS 232)." If I > understand how to do this correctly from a Garmin GNS-430W, I just take the > RS-232 signal and a ground and run them to the ELT. Right? > > The last time I did any RS-232 wiring was between DEC VAX computers and > VT-100 terminals in the 1980s. Is there anything that I should know with > regards to wiring these more modern devices? > > Thanks, -- Art Z. -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Date: Apr 12, 2017
Happy to help! -----Original Message----- From: Art Zemon Sent: Apr 12, 2017 7:19 PM Subject: Re: AeroElectric-List: RS-232 GPS Input That clears it up. Thank you, Ralph. When I get to actually making wires, I'll be back in touch if I am confused. -- Art Z. On Wed, Apr 12, 2017 at 5:55 PM, Ralph E. Capen wrote: Art, I may not have been clear enough... >From my reading of the ARTEX ELT manual, it needs "Aviation" from the 430W. It looks like you can use a single pin shielded wire (grounded at the 430W end) for the TX (at the 430W end) to the RX (at the ARTEX end - pin 9). If you have something else that already uses "Aviation", you can do a take-off from that port/wire - otherwise, see the next paragraph. Depending on the ADSB box, it will most likely need "ADS-B OUT+" from the 430W - mine did. This required me to use a different port on the 430W for the ADSB box. I used a single pin shielded wire (grounded at the 430W end) for the TX (at the 430W end) to the RX (at the ADSB end) for mine. It was a different port! I have already 'wasted' the troubleshooting hours figuring out why it wasn't working (install manual didn't call out "ADS-B OUT+" - I had to get that from tech support after I had already wired it the other way. I've got a picture of the 430W config if you want it - let me know and I'll send it direct! Hope this clears the mud I stirred up! Ralph -----Original Message----- From: Art Zemon Sent: Apr 12, 2017 6:10 PM Subject: Re: AeroElectric-List: RS-232 GPS Input Ralph, Thanks for confirming. I do intend to feed both the ADS-B and the ELT from the 430W. I read of lots of people just splitting the signal to feed two devices, which seems odd to me but then this is one-way communication so I guess it ought to work. And I will check my ADS-B documentation carefully to be sure that I get the right signal from the 430W. So... just a single twisted pair for these RS-232 devices? I don't need any of the other pins besides + and - ???Should I shield it and, if so, where do I ground the shield? -- Art Z. On Wed, Apr 12, 2017 at 2:19 PM, Ralph E. Capen wrote: Art, You're pretty much on the money...couple of tricks with the 430W: The 430W has multiple output ports - if you have one set to "Aviation", you can simply fork that output signal wire. Make sure that output port on the 430W is set to the correct output type ("Aviation") to match the ARTEX - the default 9600 baud rate should take care of it. Wiring a different port from the 430W is a PITB unless your panel has real good access. Configure your new port for "Aviation" and you should be good to go. I just did this to add ADSB and learned the difference between ports and protocols output from the 430W - I needed "ADS-B OUT+" (wasn't in the original manual - found out while troubleshooting with vendor) and had it connected to the "Aviation" port. I needed to run a separate wire just for this! Good Luck, Ralph -----Original Message----- From: Art Zemon Sent: Apr 12, 2017 2:54 PM Subject: AeroElectric-List: RS-232 GPS Input Folks, I am considering an ARTEX ELT 345 which requires a GPS signal to its "Built-in GPS Navigational Interface (NMEA 0183 or RS 232)." If I understand how to do this correctly from a Garmin GNS-430W, I just take the RS-232 signal and a ground and run them to the ELT. Right? The last time I did any RS-232 wiring was between DEC VAX computers and VT-100 terminals in the 1980s. Is there anything that I should know with regards to wiring these more modern devices? Thanks, -- Art Z. -- https://CheerfulCurmudgeon.com/ "If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel ________________________________________________________________________________
Date: Apr 12, 2017
It might be worth mentioning that the electrons have to get back home, even if it's only signal data. If you float the shield on one end, then the return path is the airframe. *If* it's a metal airplane, and both of the devices are grounded to the airframe. So that idea may work fine in an aluminum or steel tube a/c, but in a Velocity/Lancair/etc, not so much. And even in a metal a/c, it *could* leave the signal vulnerable to noise on the ground side of the circuit. There's a lot of myth & metaphysics parading as universal truth around shields and grounding. (Pardon the pun...) Charlie On 4/12/2017 6:19 PM, Art Zemon wrote: > That clears it up. Thank you, Ralph. When I get to actually making > wires, I'll be back in touch if I am confused. > > -- Art Z. > > > On Wed, Apr 12, 2017 at 5:55 PM, Ralph E. Capen > wrote: > > > > > > Art, > > I may not have been clear enough... > > >From my reading of the ARTEX ELT manual, it needs "Aviation" from > the 430W. It looks like you can use a single pin shielded wire > (grounded at the 430W end) for the TX (at the 430W end) to the RX > (at the ARTEX end - pin 9). If you have something else that > already uses "Aviation", you can do a take-off from that port/wire > - otherwise, see the next paragraph. > > Depending on the ADSB box, it will most likely need "ADS-B OUT+" > from the 430W - mine did. This required me to use a different > port on the 430W for the ADSB box. I used a single pin shielded > wire (grounded at the 430W end) for the TX (at the 430W end) to > the RX (at the ADSB end) for mine. It was a different port! > > I have already 'wasted' the troubleshooting hours figuring out why > it wasn't working (install manual didn't call out "ADS-B OUT+" - I > had to get that from tech support after I had already wired it the > other way. > > I've got a picture of the 430W config if you want it - let me know > and I'll send it direct! > > Hope this clears the mud I stirred up! > > Ralph > > > -----Original Message----- > > From: Art Zemon > > Sent: Apr 12, 2017 6:10 PM > > To: aeroelectric-list(at)matronics.com > > > Subject: Re: AeroElectric-List: RS-232 GPS Input > > > Ralph, > Thanks for confirming. I do intend to feed both the ADS-B and the > ELT from the 430W. I read of lots of people just splitting the > signal to feed two devices, which seems odd to me but then this is > one-way communication so I guess it ought to work. And I will > check my ADS-B documentation carefully to be sure that I get the > right signal from the 430W. > So... just a single twisted pair for these RS-232 devices? I don't > need any of the other pins besides + and - ???Should I shield it > and, if so, where do I ground the shield? > -- Art Z. > > On Wed, Apr 12, 2017 at 2:19 PM, Ralph E. Capen > > wrote: > > > > > Art, > > You're pretty much on the money...couple of tricks with the 430W: > > The 430W has multiple output ports - if you have one set to > "Aviation", you can simply fork that output signal wire. > > Make sure that output port on the 430W is set to the correct > output type ("Aviation") to match the ARTEX - the default 9600 > baud rate should take care of it. > > Wiring a different port from the 430W is a PITB unless your panel > has real good access. Configure your new port for "Aviation" and > you should be good to go. > > > I just did this to add ADSB and learned the difference between > ports and protocols output from the 430W - I needed "ADS-B OUT+" > (wasn't in the original manual - found out while troubleshooting > with vendor) and had it connected to the "Aviation" port. I > needed to run a separate wire just for this! > > > Good Luck, > > Ralph > > > -----Original Message----- > > > From: Art Zemon > > > Sent: Apr 12, 2017 2:54 PM > > > To: aeroelectric-list(at)matronics.com > > > > Subject: AeroElectric-List: RS-232 GPS Input > > > Folks, > > I am considering an ARTEX ELT 345 which requires a GPS signal to > its "Built-in GPS Navigational Interface (NMEA 0183 or RS 232)." > If I understand how to do this correctly from a Garmin GNS-430W, I > just take the RS-232 signal and a ground and run them to the ELT. > Right? > > The last time I did any RS-232 wiring was between DEC VAX > computers and VT-100 terminals in the 1980s. Is there anything > that I should know with regards to wiring these more modern devices? > > Thanks, -- Art Z. > > > -- > https://CheerfulCurmudgeon.com/ > > /"If I am not for myself, who is for me? And if I am only for myself, > what am I? And if not now, when?" Hillel/ --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Apr 12, 2017
Good point - I was only considering a metal frame! If bonding is a part of the builder scenario, the return path becomes an actual requirement - which can be satisfied in a number of ways! The documents for the ARTEX make a similar consideration as well..... -----Original Message----- From: Charlie England Sent: Apr 12, 2017 8:07 PM Subject: Re: AeroElectric-List: RS-232 GPS Input It might be worth mentioning that the electrons have to get back home, even if it's only signal data. If you float the shield on one end, then the return path is the airframe. *If* it's a metal airplane, and both of the devices are grounded to the airframe. So that idea may work fine in an aluminum or steel tube a/c, but in a Velocity/Lancair/etc, not so much. And even in a metal a/c, it *could* leave the signal vulnerable to noise on the ground side of the circuit. There's a lot of myth & metaphysics parading as universal truth around shields and grounding. (Pardon the pun...) Charlie On 4/12/2017 6:19 PM, Art Zemon wrote: That clears it up. Thank you, Ralph. When I get to actually making wires, I'll be back in touch if I am confused. -- Art Z. On Wed, Apr 12, 2017 at 5:55 PM, Ralph E. Capen wrote: "Ralph E. Capen" Art, I may not have been clear enough... >From my reading of the ARTEX ELT manual, it needs "Aviation" from the 430W. It looks like you can use a single pin shielded wire (grounded at the 430W end) for the TX (at the 430W end) to the RX (at the ARTEX end - pin 9). If you have something else that already uses "Aviation", you can do a take-off from that port/wire - otherwise, see the next paragraph. Depending on the ADSB box, it will most likely need "ADS-B OUT+" from the 430W - mine did. This required me to use a different port on the 430W for the ADSB box. I used a single pin shielded wire (grounded at the 430W end) for the TX (at the 430W end) to the RX (at the ADSB end) for mine. It was a different port! I have already 'wasted' the troubleshooting hours figuring out why it wasn't working (install manual didn't call out "ADS-B OUT+" - I had to get that from tech support after I had already wired it the other way. I've got a picture of the 430W config if you want it - let me know and I'll send it direct! Hope this clears the mud I stirred up! Ralph -----Original Message----- From: Art Zemon Sent: Apr 12, 2017 6:10 PM To: aeroelectric-list(at)matronics.com Subject: Re: AeroElectric-List: RS-232 GPS Input Ralph, Thanks for confirming. I do intend to feed both the ADS-B and the ELT from the 430W. I read of lots of people just splitting the signal to feed two devices, which seems odd to me but then this is one-way communication so I guess it ought to work. And I will check my ADS-B documentation carefully to be sure that I get the right signal from the 430W. So... just a single twisted pair for these RS-232 devices? I don't need any of the other pins besides + and - ???Should I shield it and, if so, where do I ground the shield? -- Art Z. On Wed, Apr 12, 2017 at 2:19 PM, Ralph E. Capen wrote: Capen" Art, You're pretty much on the money...couple of tricks with the 430W: The 430W has multiple output ports - if you have one set to "Aviation", you can simply fork that output signal wire. Make sure that output port on the 430W is set to the correct output type ("Aviation") to match the ARTEX - the default 9600 baud rate should take care of it. Wiring a different port from the 430W is a PITB unless your panel has real good access. Configure your new port for "Aviation" and you should be good to go. I just did this to add ADSB and learned the difference between ports and protocols output from the 430W - I needed "ADS-B OUT+" (wasn't in the original manual - found out while troubleshooting with vendor) and had it connected to the "Aviation" port. I needed to run a separate wire just for this! Good Luck, Ralph -----Original Message----- From: Art Zemon Sent: Apr 12, 2017 2:54 PM To: aeroelectric-list(at)matronics.com Subject: AeroElectric-List: RS-232 GPS Input Folks, I am considering an ARTEX ELT 345 which requires a GPS signal to its "Built-in GPS Navigational Interface (NMEA 0183 or RS 232)." If I understand how to do this correctly from a Garmin GNS-430W, I just take the RS-232 signal and a ground and run them to the ELT. Right? The last time I did any RS-232 wiring was between DEC VAX computers and VT-100 terminals in the 1980s. Is there anything that I should know with regards to wiring these more modern devices? Thanks, -- Art Z. -- https://CheerfulCurmudgeon.com/ "If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel This email has been checked for viruses by Avast antivirus software. www.avast.com ________________________________________________________________________________
Subject: ICE Disruptor?
Date: Apr 12, 2017
Electromotive vehicle range limitations may have just become a non-issue. http://www.truth-out.org/buzzflash/commentary/seaweed-could-revolutionize-how-we-power-our-devices Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468367#468367 ________________________________________________________________________________
Subject: Re: Interesting thread on overvoltage event
Date: Apr 13, 2017
Rotax, LiFePO4 and OVP LiFePO4 batteries do not have a voltage limiting effect in OV situations as lead acid batteries do. In Rotax systems with builtin 20A PM alternator the capacitor on the output of the R/R can give a little time for OVP to operate. Some ruminations. With the standard 22mF, 25V capacitor there is 9V room above 16V. DO160-capable devices can take 40V for 100ms, 24V above 16V. Say the alternator is capable of an excess 14A or 14,000mC/s. The bus voltage will climb at 14,000/22 = 636V/s = 0.64V/ms. The 9V room to 25V is consumed in 9/0.64 = 14ms. With a 22mF, 40V capacitor there would be 24/0.64 = 37.5ms available until the DO160 limit is reached. If a 47mF/40V capacitor were installed the bus voltage would climb at 0.30V/ms and it would take 24/0.30 = 80ms for the DO160 limit to be reached. At 1500 RPM (idle) the ripple frequency is 10 x 1500 / 60 = 250Hz (there are 10 coils I believe), the ripple period is 4ms (each of these consists of 2 ripples, not quite identical (different rectifiers)). Shorter periods at higher RPM. A fast OVP would sample several ripple periods before deciding on an OV condition. Relay release time (10ms or so (diode/zener question)) would be added. In total 20 or 30ms may be enough. All in all limiting the potential voltage excursion with LiFePO4 using fast OVP and a somewhat oversized R/R capacitor seems doable for the small engine users among us. Don't know who supply fast OVP though. Don't know if nuisance tripping can be avoided. Jan de Jong ________________________________________________________________________________
Date: Apr 13, 2017
At 03:35 PM 4/12/2017, you wrote: > >There seem to be a lot of advantages to not disconnecting the >alternator from the battery, so I'm wondering if the battery >contactor is really necessary? > >The things I can see as advantages are that it provides an extra >layer of protection from accidental starter engagement, and provides >a big switch that can be used to disconnect the battery from everything. > >I'm curious if there are other advantages that I'm not seeing. There is a legacy train of thought that goes back nearly 100 years . . . when on short final to the rocks, it's a good idea to suppress risk to the smallest values. Hence, the POH for most if not all TC aircraft calls for shutting off the fuel and killing the electrical system. Getting the electrical system stone-cold calls for independent, positive control over power sources like alternators, generators and . . . you guessed it . . . batteries. Of course, the contactor is also a hedge against a stuck starter contactor . . . Don't know what 'advantages' might be secured with permanent pathways between alternators and batteries. Bob . . . ________________________________________________________________________________
Date: Apr 13, 2017
nuckolls.bob(at)aeroelect wrote: > At 03:35 PM 4/12/2017, you wrote: > Don't know what 'advantages' might be secured > with permanent pathways between alternators > and batteries. Thanks for the feedback gents, looks like the off field landing scenario slipped my mind when thinking about this. The "advantages" I was thinking of were one less component, and the possible avoidance of a load dump if the alternator is pumping hard and the battery is disconnected. Avoiding issues with a load dump are pretty easy by following the recommended designs in the 'connection. Thanks for the tips! -------- Mickey Coggins http://www.rv8.ch/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468379#468379 ________________________________________________________________________________
Date: Apr 14, 2017
Hello Mickey I suppose everything is ok with you and your family, and you are flying your RV-8 in beautiful Switzerland Cheers Carlos Enviado do meu iPhone No dia 14/04/2017, s 05:26, rv8ch escreveu: > > > nuckolls.bob(at)aeroelect wrote: >> At 03:35 PM 4/12/2017, you wrote: >> Don't know what 'advantages' might be secured >> with permanent pathways between alternators >> and batteries. > Thanks for the feedback gents, looks like the off field landing scenario slipped my mind when thinking about this. The "advantages" I was thinking of were one less component, and the possible avoidance of a load dump if the alternator is pumping hard and the battery is disconnected. Avoiding issues with a load dump are pretty easy by following the recommended designs in the 'connection. Thanks for the tips! > > -------- > Mickey Coggins > http://www.rv8.ch/ > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=468379#468379 > > > > > > > > > ________________________________________________________________________________
Date: Apr 14, 2017
Eric says his works in about 200ms: http://www.periheliondesign.com/lovm.htm Mickey Coggins On 13 April 2017 at 16:32, Jan de Jong wrote: > jan_de_jong(at)casema.nl> > > Rotax, LiFePO4 and OVP > > LiFePO4 batteries do not have a voltage limiting effect in OV situations > as lead acid batteries do. > In Rotax systems with builtin 20A PM alternator the capacitor on the > output of the R/R can give a little time for OVP to operate. > Some ruminations. > > With the standard 22mF, 25V capacitor there is 9V room above 16V. > DO160-capable devices can take 40V for 100ms, 24V above 16V. > Say the alternator is capable of an excess 14A or 14,000mC/s. > The bus voltage will climb at 14,000/22 = 636V/s = 0.64V/ms. > The 9V room to 25V is consumed in 9/0.64 = 14ms. > With a 22mF, 40V capacitor there would be 24/0.64 = 37.5ms available until > the DO160 limit is reached. > If a 47mF/40V capacitor were installed the bus voltage would climb at > 0.30V/ms and it would take 24/0.30 = 80ms for the DO160 limit to be reached. > > At 1500 RPM (idle) the ripple frequency is 10 x 1500 / 60 = 250Hz (there > are 10 coils I believe), the ripple period is 4ms (each of these consists > of 2 ripples, not quite identical (different rectifiers)). Shorter periods > at higher RPM. > A fast OVP would sample several ripple periods before deciding on an OV > condition. > Relay release time (10ms or so (diode/zener question)) would be added. > In total 20 or 30ms may be enough. > > All in all limiting the potential voltage excursion with LiFePO4 using > fast OVP and a somewhat oversized R/R capacitor seems doable for the small > engine users among us. > Don't know who supply fast OVP though. > Don't know if nuisance tripping can be avoided. > > Jan de Jong > > ________________________________________________________________________________
Date: Apr 15, 2017
In a PM generator like the Rotax, frequency is not a function of the number of coils in the stator, it's a function of the number of magnets in the rotor divided by two. Divided by two because the magnets are installed in the rotor with the poles alternating. Just look at the flux lines of one circuit. Two magnets in series inducing a field through the laminated stator of two coils. The two coils are connected in series with one of the coils "crossed" so the magnetic effect is additive. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468412#468412 ________________________________________________________________________________
Date: Apr 15, 2017
Subject: Re: Audio Isolation Amplifier Boards
At 10:47 PM 12/11/2016, you wrote: > > >I've had some requests for the bare etched circuit board called out >in the DIY amplifier >project featured at http://tinyurl.com/hn28p2q Also for the >lvwarn/aux battery manager >project at http://tinyurl.com/6mvso29 I ordered a second batch of audio and lv/abmm boards. There are 4 audio boards and 1 lv/abmm board left . . . Email me directly if intereseted. Bob . . . ________________________________________________________________________________
From: "William Hunter" <billhuntersemail(at)gmail.com>
Subject: FW: ADS-B and Transponder Antenna Radiation Concerns
Date: Apr 15, 2017
Hi All, I am building a radio rack/shelf in a Velocity (fiberglass pusher) and I am thinking of getting creative in the installation location of the ADS-B and/or transponder antenna location so as to reduce antennae farms under the airplane and the resultant drag. I was considering mounting the transponder and/or ADS-B antenna upside down under my newly built radio shelf that will be installed on top of the =9Ccanard=9D in the =9Ccanard doghouse=9D. In the Velocity pusher design, the =9Ccanard=9D is the front wing of the airplane and the =9Cdoghouse=9D is the space above the canard center section and it is essentially a large faring that streamlines the airplane nose and fuselage to the canard. The design is such that the canard mounts to the airplane in front of the windshield and it is installed pretty much directly above the pilot/copilot foot well (above the rudder pedals). See attached picture of partially built radio shelf and this view is as if you were looking down from the windshield to the top of the canard center section (doghouse) and directly below this radio shelf would be the pilot/copilot foot well and rudder pedals. I could drill a hole in the aluminum shelf and install the antenna (antennae) sticking straight down below the aluminum sheet metal and that would require drilling a vertical hole straight down through the canard skin and foam (making sure to avoid drilling through the canard spar). That area of the canard is not considered to be a structural component because the canard has a main spar and this is just a fiberglass skin/foam core/skin sandwich construction. The antenna would pretty much be completely inside the fuselage envelope and surrounded by foam and fiberglass and the aluminum shelf would act as the ground plane. My electrical concerns are: -Is having a high frequency transponder antenna mounted 24 inches above my feet a good idea? -The ADS-B antenna is a dual band receive only antenna so if I just went with the ADS-B antenna mounted above my feet there would not be a concern of irradiating my feet however the other concern would be the interference of the metal rudder pedals and the metal control linkage below the antenna interfering with its signal. Would that make the ADS-B reception less sensitive? Just some thoughts to ponder for the transponder. THANKS!!! Bill Hunter ________________________________________________________________________________
Subject: Re: ADS-B and Transponder Antenna Radiation Concerns
Date: Apr 15, 2017
> Is having a high frequency transponder antenna mounted 24 inches above my feet a good idea? I do not know, but probably is a bad idea. > Would that make the ADS-B reception less sensitive? Yes, but probably not significantly. I would install the receiving antenna wherever you want, then try it out. You can always move it if necessary. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468431#468431 ________________________________________________________________________________
Subject: Re: FW: ADS-B and Transponder Antenna Radiation Concerns
Date: Apr 15, 2017
> On Apr 15, 2017, at 11:14 AM, William Hunter wrote: > > > I was considering mounting the transponder and/or ADS-B antenna upside down under my newly built radio shelf that will be installed on top of the canard in the canard doghouse. > The transponder antenna must have line-of-sight to the radar station with no engines, avionics or people (bags of water) in between. When departing a radar station at say 5000 AGL and 25 NM, the look angle from the airplane to the station is only about 2 degrees down so the antenna almost has to go on the bottom of the airplane. Even fiberglass builders who mount them in the nose have problems keeping radar contact on departure. A 2 degree angle of attack and 1 degree climb angle puts the passengers between the antenna and the radar station. It is fine to mount the antenna under your seat or under your feet. The transmit pulse is so brief that it has negligible effect. My ground plane in under the seat and the antenna sticks out the bottom of the airplane. -Kent ________________________________________________________________________________
Date: Apr 15, 2017
Subject: Matronics Internet Connectivity Upgrades April 17-18
2017 Dear Matronics Email List an/or Forum User, The Matronics Internet connectivity will be upgraded on April 17 through April 18, 2017. During the upgrade connections to the Matronics and AeroElectric web servers may be unavailable. Additionally, Matronics Email List email will not be redistributed. Internet Connectivity bandwidth will be significantly increased by a factor of 7X for downloads and 50X for uploads, which represents a significant increase in performance. Reliability should also increase in terms. I will send out a follow up message when the upgrade has been completed. Best Regards, Matt Dralle Matronics Email List and Forum Admin. Matt G Dralle | Matronics | 581 Jeannie Way | Livermore | CA | 94550 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
From: William Hunter <billhuntersemail(at)gmail.com>
Date: Apr 16, 2017
Subject: Red Crimp On Terminal Ring For 5/16 Stud
Hi and Happy Easter!!! I am struggling to find a crimp on terminal ring that will work with 20 AWG wire and a 5/16 stud. The Google keeps showing results for 8 AWG wire. Does anyone have a part number to share? Thanks, Bill Hunter ________________________________________________________________________________
Date: Apr 16, 2017
Subject: Re: Red Crimp On Terminal Ring For 5/16 Stud
Bilk That will be SA-044 from SteinAir Carlos Enviado do meu iPhone No dia 16/04/2017, =C3-s 16:56, William Hunter escreveu: > Hi and Happy Easter!!! > > I am struggling to find a crimp on terminal ring that will work with 20 AW G wire and a 5/16 stud. The Google keeps showing results for 8 AWG wire. > > Does anyone have a part number to share? > > Thanks, > > Bill Hunter ________________________________________________________________________________
Date: Apr 16, 2017
Sta-Kon RA18-516 -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468531#468531 ________________________________________________________________________________
Date: Apr 16, 2017
Joe, I knew I could count on you!!! I guess I figured out why I could not find them on The Google...all of the results I found were for around 85 bucks because they only sell them in 100 pc boxes!!! .. Cheers!!! Bill Hunter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of user9253 Sent: Sunday, April 16, 2017 9:48 AM Subject: AeroElectric-List: Re: Red Crimp On Terminal Ring For 5/16 Stud Sta-Kon RA18-516 -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468531#468531 ________________________________________________________________________________
Date: Apr 16, 2017
Amazon Aircraft Supply had a different manufacturer for only 15 bucks!!! https://www.amazon.com/Terminal-Connectors-Plus-Parts-House/dp/B00N9RYQDI/re f=sr_1_fkmr0_1?ie=UTF8&qid=1492363881&sr=8-1-fkmr0&keywords=22-16+AWG+5%2F16 %22+Stud+Nylon+Insulated+Double+Crimp+Ring+Terminal .. Cheers!!! Bill Hunter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of user9253 Sent: Sunday, April 16, 2017 9:48 AM Subject: AeroElectric-List: Re: Red Crimp On Terminal Ring For 5/16 Stud Sta-Kon RA18-516 -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468531#468531 ________________________________________________________________________________
Date: Apr 16, 2017
Bill, Just a data point, but that link is for a product with a vinyl insulator, and it's unlikely to be configured as PIDG (where the crimp grabs both the wire and a small portion of the insulation). I'm not saying that it's a deal breaker; I've used a few of those in my build & I'm not afraid the plane will fall out of the sky because of them. Just wanted to note that you're not comparing apples to apples. (The 'real' PIDG terminals are grossly overpriced, in my not so humble opinion. An order of magnitude price increase to go from vinyl to nylon and a slightly longer metal barrel is a real stretch.) A tip for finding products when a google search doesn't instantly find what you want: If you look on ebay & find something that's similar from one of the web stores that list there, try clicking on the store's direct link, then search within that store. You can often find what you're looking for that way. Bigger ebay sellers rarely list every product they sell as a separate listing on ebay, but you can still purchase through ebay by looking within the store's listings. Charlie On 4/16/2017 12:33 PM, William Hunter wrote: > > Amazon Aircraft Supply had a different manufacturer for only 15 bucks!!! > > https://www.amazon.com/Terminal-Connectors-Plus-Parts-House/dp/B00N9RYQDI/re > f=sr_1_fkmr0_1?ie=UTF8&qid=1492363881&sr=8-1-fkmr0&keywords=22-16+AWG+5%2F16 > %22+Stud+Nylon+Insulated+Double+Crimp+Ring+Terminal > > > .. > > Cheers!!! > > Bill Hunter > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of user9253 > Sent: Sunday, April 16, 2017 9:48 AM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Re: Red Crimp On Terminal Ring For 5/16 Stud > > > Sta-Kon RA18-516 > > -------- > Joe Gores > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Apr 16, 2017
I would recommend using only AMP or TE PIDG terminals. They are available from Steinair, Allied Electronics, Mouser and digikey for as little as 37 cents each in lots of 1. Just my opinion, the junk stuff does not provide insulation support or good material so they tend to fail fairly quickly. On Apr 16, 2017 12:56, "Charlie England" wrote: > ceengland7(at)gmail.com> > > Bill, > > Just a data point, but that link is for a product with a vinyl insulator, > and it's unlikely to be configured as PIDG (where the crimp grabs both the > wire and a small portion of the insulation). I'm not saying that it's a > deal breaker; I've used a few of those in my build & I'm not afraid the > plane will fall out of the sky because of them. Just wanted to note that > you're not comparing apples to apples. (The 'real' PIDG terminals are > grossly overpriced, in my not so humble opinion. An order of magnitude > price increase to go from vinyl to nylon and a slightly longer metal barrel > is a real stretch.) > > A tip for finding products when a google search doesn't instantly find > what you want: If you look on ebay & find something that's similar from one > of the web stores that list there, try clicking on the store's direct link, > then search within that store. You can often find what you're looking for > that way. Bigger ebay sellers rarely list every product they sell as a > separate listing on ebay, but you can still purchase through ebay by > looking within the store's listings. > > Charlie > > On 4/16/2017 12:33 PM, William Hunter wrote: > >> billhuntersemail(at)gmail.com> >> >> Amazon Aircraft Supply had a different manufacturer for only 15 bucks!!! >> >> https://www.amazon.com/Terminal-Connectors-Plus-Parts-House/ >> dp/B00N9RYQDI/re >> f=sr_1_fkmr0_1?ie=UTF8&qid=1492363881&sr=8-1-fkmr0&keywords >> 22-16+AWG+5%2F16 >> %22+Stud+Nylon+Insulated+Double+Crimp+Ring+Terminal >> >> >> .. >> >> Cheers!!! >> >> Bill Hunter >> >> >> >> >> >> -----Original Message----- >> From: owner-aeroelectric-list-server(at)matronics.com >> [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of >> user9253 >> Sent: Sunday, April 16, 2017 9:48 AM >> To: aeroelectric-list(at)matronics.com >> Subject: AeroElectric-List: Re: Red Crimp On Terminal Ring For 5/16 Stud >> >> >> Sta-Kon RA18-516 >> >> -------- >> Joe Gores >> >> > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > ________________________________________________________________________________
Subject: Off Topic: Amazon tip for the charitable among us
Date: Apr 16, 2017
The recent link to an Amazon-listed product made me thing about this; a heads-up if you have charitable tendencies. Amazon has a feature called 'smile' (just add 'smile.' between the slashes and the word 'amazon' in the url.) If you sign up for it, your prices stay the same, but Amazon will donate some small % of your purchase price to the charity of your choosing, from a pretty large list of charities & worthy causes. St Jude's Children's Hospital gets ours, but you get to pick where yours goes. Just thought I'd mention the option, which only costs you a few minutes to activate but can add up to quite a boost for your favorite cause. Now, back to your regularly scheduled programming... Charlie --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Apr 16, 2017
Good informationTHANKS!!! .. Cheers!!! Bill Hunter From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of don van santen Sent: Sunday, April 16, 2017 1:20 PM Subject: Re: AeroElectric-List: Re: Red Crimp On Terminal Ring For 5/16 Stud I would recommend using only AMP or TE PIDG terminals. They are available from Steinair, Allied Electronics, Mouser and digikey for as little as 37 cents each in lots of 1. Just my opinion, the junk stuff does not provide insulation support or good material so they tend to fail fairly quickly. On Apr 16, 2017 12:56, "Charlie England" > wrote: > Bill, Just a data point, but that link is for a product with a vinyl insulator, and it's unlikely to be configured as PIDG (where the crimp grabs both the wire and a small portion of the insulation). I'm not saying that it's a deal breaker; I've used a few of those in my build & I'm not afraid the plane will fall out of the sky because of them. Just wanted to note that you're not comparing apples to apples. (The 'real' PIDG terminals are grossly overpriced, in my not so humble opinion. An order of magnitude price increase to go from vinyl to nylon and a slightly longer metal barrel is a real stretch.) A tip for finding products when a google search doesn't instantly find what you want: If you look on ebay & find something that's similar from one of the web stores that list there, try clicking on the store's direct link, then search within that store. You can often find what you're looking for that way. Bigger ebay sellers rarely list every product they sell as a separate listing on ebay, but you can still purchase through ebay by looking within the store's listings. Charlie On 4/16/2017 12:33 PM, William Hunter wrote: > Amazon Aircraft Supply had a different manufacturer for only 15 bucks!!! https://www.amazon.com/Terminal-Connectors-Plus-Parts-House/dp/B00N9RYQDI /re f=sr_1_fkmr0_1?ie=UTF8&qid=1492363881&sr=8-1-fkmr0&keywords=22- 16+AWG+5%2F16 %22+Stud+Nylon+Insulated+Double+Crimp+Ring+Terminal .. Cheers!!! Bill Hunter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com ] On Behalf Of user9253 Sent: Sunday, April 16, 2017 9:48 AM Subject: AeroElectric-List: Re: Red Crimp On Terminal Ring For 5/16 Stud > Sta-Kon RA18-516 -------- Joe Gores --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus - Electric-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List FORUMS - eferrer" target="_blank">http://forums.matronics.com WIKI - errer" target="_blank">http://wiki.matronics.com b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Apr 16, 2017
At 12:18 PM 4/16/2017, you wrote: > > >Joe, > >I knew I could count on you!!! > >I guess I figured out why I could not find them on The Google...all of the >results I found were for around 85 bucks because they only sell them in 100 >pc boxes!!! How many do you need? Perhaps I can simply mail you some . . . ship me an address . . . Bob . . . ________________________________________________________________________________
Date: Apr 16, 2017
THANKS Bob.That is very kind of you!!! I need to buy some more stuff from Stein so I will just get some from him next week. .. Cheers!!! Bill Hunter From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Sunday, April 16, 2017 2:24 PM Subject: RE: AeroElectric-List: Re: Red Crimp On Terminal Ring For 5/16 Stud At 12:18 PM 4/16/2017, you wrote: > Joe, I knew I could count on you!!! I guess I figured out why I could not find them on The Google...all of the results I found were for around 85 bucks because they only sell them in 100 pc boxes!!! How many do you need? Perhaps I can simply mail you some . . . ship me an address . . . Bob . . . ________________________________________________________________________________
Date: Apr 16, 2017
Subject: Re: Off Topic: Amazon tip for the charitable among
us Even the Soaring Society of America is on their list of organizations. Rick Girard On Sun, Apr 16, 2017 at 3:40 PM, Charlie England wrote: > ceengland7(at)gmail.com> > > The recent link to an Amazon-listed product made me thing about this; a > heads-up if you have charitable tendencies. Amazon has a feature called > 'smile' (just add 'smile.' between the slashes and the word 'amazon' in t he > url.) If you sign up for it, your prices stay the same, but Amazon will > donate some small % of your purchase price to the charity of your choosin g, > from a pretty large list of charities & worthy causes. > > St Jude's Children's Hospital gets ours, but you get to pick where yours > goes. > > Just thought I'd mention the option, which only costs you a few minutes t o > activate but can add up to quite a boost for your favorite cause. > > Now, back to your regularly scheduled programming... > > Charlie > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > =========== =========== =========== =========== =========== > > -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Date: Apr 17, 2017
Got Mark's SD-8 and original stock R/R running on the bench. The R/R seems to be fine too. I initially used a LiFePO4 battery (ETX36) in the test setup and observed some unexpected behaviors. Got a small lead-acid from the store a few minutes ago and put it on a maintainer. Will resume the experiment when the battery tops off . . . Bob . . . ________________________________________________________________________________
Date: Apr 17, 2017
>Bob, if you wanted to look at this dynamo for some reason, I'll be happy >to mail it to you. I suspect you've got much better things to do than >'paleo-forensics' on this dated item. I've finished some preliminary operations on the as received SD8 and companion R/R. They seem to function pretty much as designed. 2800 RPM produces 3+ amps at 14.4v 3300 RPM produces 4+ amps at 14.3v 3800 RPM produces 8+ amps at 14.1v At the final load setting, current in the SD8 windings was 10.5 A(rms) I can return this hardware if you'd like to have it around for spares. At the same time, it would be interesting/useful to add it to the constellation of test tools I'm building around a 2HP drive-stand with and AND20000 spline pad on it. Emacs! As an interesting aside, test data were taken without a battery on line . . . this prevented pollution of current values dialed into the dynamic load bank. I was able to 'tickle' the dynamo-r/r into operation with a momentary application of battery power. On one fire-up/shut-down cycle, the capacitor was still charged to about 3 volts and the system came on-line with only a small fraction of start up excitation offered by the ship's battery. Bob . . . ________________________________________________________________________________
us
Date: Apr 17, 2017
If you go into "Accounts & Lists" and "Your Amazon Smile" you can choose your charity. I typed "Aviation" into the search box and got 861 results. Amazon claims there are almost a million charities in the system so if you can think of one, they're probably there. --Rick On 4/17/2017 12:02 AM, Richard Girard wrote: > Even the Soaring Society of America is on their list of organizations. > > Rick Girard > > On Sun, Apr 16, 2017 at 3:40 PM, Charlie England > wrote: > > > > > The recent link to an Amazon-listed product made me thing about > this; a heads-up if you have charitable tendencies. Amazon has a > feature called 'smile' (just add 'smile.' between the slashes and > the word 'amazon' in the url.) If you sign up for it, your prices > stay the same, but Amazon will donate some small % of your purchase > price to the charity of your choosing, from a pretty large list of > charities & worthy causes. ________________________________________________________________________________
Date: Apr 18, 2017
> > I can return this hardware if you'd like to > have it around for spares. At the same time, > it would be interesting/useful to add it to > the constellation of test tools I'm > building around a 2HP drive-stand with > and AND20000 spline pad on it. Bob, I'm happy to contribute them to the cause. BTW, I never had a big cap or OVP module until I installed the new dynamo and regulator. After just a couple of flights with the replacement hardware, I've had no indication of a return of the problem. To be at ease, I'll just have to go fly some more! Mark ________________________________________________________________________________
From: "nuckollsr" <bob.nuckolls(at)aeroelectric.com>
Date: Apr 20, 2017
After the server upgrade at matronics, I'm still wrestling with some email issues . . . but these too will pass . . . In the mean time, I subjected a fully charged ETX36 lithium battery to a 40v, 15A constant current source. Didn't take time to record and plot the data but my suspicions were correct, these batteries WILL grunt some level of over-charge current. In this experiment, it took several seconds for battery voltage to rise above 16.0 volts. Risks to accessories in an airplane fitted with a PM (read small) alternator and legacy ov protection (16.2v) are small. Indeed, if the system loads are a significant fraction of the alternators maximum output, one might well never trip a legacy ov protection system. We're in the late stages of bringing a new suite of OV protection devices easily calibrated-to-task. A 16.2v trip point was derived from a series of bench tests on various ov scenarios . . . for airplanes with 60A or larger alternators. Trip dynamics is generally based on a simple RC integrator calibrated to trip in 50 mS after a step up from 14.4 to 20.0 volts. This generally produced a trip response tolerant of the Mil-Std-704 envelope for NORMAL bus excursions while minimizing nuisance trips. The next generation of ov discriminators will be software based and easily tailored to the target system. It's a certainty that trip point can be lowered for systems with PM alternators. In any case, this experiment confirms the idea that legacy ov protection is still okay, even with lithium paired with small alternators. Electronics internal tot he ETX battery allowed 'overcharge' energy to be grunted by the battery. However, we can and will do better. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468639#468639 ________________________________________________________________________________
Subject: Antenna cable
Date: Apr 21, 2017
SXMgaXQgb2sgdG8gZXh0ZW5kIHRoZSBsZW5ndGggb2YgYSBhbnRlbm5hIGNhYmxlIGJ5IG1ha2lu ZyBhIHNob3J0IHBpZ3RhaWwgc2F5IGZpdmUgZmVldCB3aXRoIGNvbm5lY3RvcnMgb24gZWFjaCBl bmQgdG8gZ28gYmV0d2VlbiBhIFZIRiBhbmQgdGhlIGV4aXN0aW5nIGNhYmxlIHRoYXQgaXMgdG8g c2hvcnQ/DQoNCkNodWNrDQoNCg0K ________________________________________________________________________________
Subject: Re: Antenna cable
Date: Apr 21, 2017
You will have a small signal loss from the connectors, but otherwise fine. It is fairly common to build an 18-24" coax from the radio tray to make future changes and servicing easier. AFAIK only GPS has constraints about allowable dB loss between antenna and receiver. Kelly On 4/21/2017 6:24 AM, Charles Plumery wrote: > Is it ok to extend the length of a antenna cable by making a short > pigtail say five feet with connectors on each end to go between a VHF > and the existing cable that is to short? > > Chuck > > ________________________________________________________________________________
Date: Apr 21, 2017
At 08:24 AM 4/21/2017, you wrote: >Is it ok to extend the length of a antenna cable by making a short >pigtail say five feet with connectors on each end to go between a >VHF and the existing cable that is to short? Yes Bob . . . ________________________________________________________________________________
Date: Apr 21, 2017
VGhhbmtzIE1yLiBOLg0KDQpTZW50IGZyb20gbXkgaVBhZCwNCkNodWNrDQrigJxBIG5hdGlvbiBj YW4gc3Vydml2ZSBpdHMgZm9vbHMsIGFuZCBldmVuIHRoZSBhbWJpdGlvdXMuIEJ1dCBpdCBjYW5u b3Qgc3Vydml2ZSB0cmVhc29uIGZyb20gd2l0aGluLiBBbiBlbmVteSBhdCB0aGUgZ2F0ZXMgaXMg bGVzcyBmb3JtaWRhYmxlLCBmb3IgaGUgaXMga25vd24gYW5kIGNhcnJpZXMgaGlzIGJhbm5lciBv cGVubHkuIEJ1dCB0aGUgdHJhaXRvciBtb3ZlcyBhbW9uZ3N0IHRob3NlIHdpdGhpbiB0aGUgZ2F0 ZSBmcmVlbHksIGhpcyBzbHkgd2hpc3BlcnMgcnVzdGxpbmcgdGhyb3VnaCBhbGwgdGhlIGFsbGV5 cywgaGVhcmQgaW4gdGhlIHZlcnkgaGFsbHMgb2YgZ292ZXJubWVudCBpdHNlbGYuIEZvciB0aGUg dHJhaXRvciBhcHBlYXJzIG5vdCBhIHRyYWl0b3I7IGhlIHNwZWFrcyBpbiBhY2NlbnRzIGZhbWls aWFyIHRvIGhpcyB2aWN0aW1zLCBhbmQgaGUgd2VhcnMgdGhlaXIgZmFjZSBhbmQgdGhlaXIgYXJn dW1lbnRzLCBoZSBhcHBlYWxzIHRvIHRoZSBiYXNlbmVzcyB0aGF0IGxpZXMgZGVlcCBpbiB0aGUg aGVhcnRzIG9mIGFsbCBtZW4uIEhlIHJvdHMgdGhlIHNvdWwgb2YgYSBuYXRpb24sIGhlIHdvcmtz IHNlY3JldGx5IGFuZCB1bmtub3duIGluIHRoZSBuaWdodCB0byB1bmRlcm1pbmUgdGhlIHBpbGxh cnMgb2YgdGhlIGNpdHksIGhlIGluZmVjdHMgdGhlIGJvZHkgcG9saXRpYyBzbyB0aGF0IGl0IGNh biBubyBsb25nZXIgcmVzaXN0LiBBIG11cmRlcmVyIGlzIGxlc3MgdG8gZmVhci7igJ0NCk1UIENp Y2Vybw0KDQoNCk9uIEFwciAyMSwgMjAxNywgYXQgMToyMyBQTSwgUm9iZXJ0IEwuIE51Y2tvbGxz LCBJSUkgPG51Y2tvbGxzLmJvYkBhZXJvZWxlY3RyaWMuY29tPG1haWx0bzpudWNrb2xscy5ib2JA YWVyb2VsZWN0cmljLmNvbT4+IHdyb3RlOg0KDQpBdCAwODoyNCBBTSA0LzIxLzIwMTcsIHlvdSB3 cm90ZToNCklzIGl0IG9rIHRvIGV4dGVuZCB0aGUgbGVuZ3RoIG9mIGEgYW50ZW5uYSBjYWJsZSBi eSBtYWtpbmcgYSBzaG9ydCBwaWd0YWlsIHNheSBmaXZlIGZlZXQgd2l0aCBjb25uZWN0b3JzIG9u IGVhY2ggZW5kIHRvIGdvIGJldHdlZW4gYSBWSEYgYW5kIHRoZSBleGlzdGluZyBjYWJsZSB0aGF0 IGlzIHRvIHNob3J0Pw0KDQogIFllcw0KDQoNCg0KICBCb2IgLiAuIC4NCg= ________________________________________________________________________________
Date: Apr 21, 2017
VGhhbmsgeW91IEtlbGxleS4NCg0KU2VudCBmcm9tIG15IGlQYWQsDQpDaHVjaw0K4oCcQSBuYXRp b24gY2FuIHN1cnZpdmUgaXRzIGZvb2xzLCBhbmQgZXZlbiB0aGUgYW1iaXRpb3VzLiBCdXQgaXQg Y2Fubm90IHN1cnZpdmUgdHJlYXNvbiBmcm9tIHdpdGhpbi4gQW4gZW5lbXkgYXQgdGhlIGdhdGVz IGlzIGxlc3MgZm9ybWlkYWJsZSwgZm9yIGhlIGlzIGtub3duIGFuZCBjYXJyaWVzIGhpcyBiYW5u ZXIgb3Blbmx5LiBCdXQgdGhlIHRyYWl0b3IgbW92ZXMgYW1vbmdzdCB0aG9zZSB3aXRoaW4gdGhl IGdhdGUgZnJlZWx5LCBoaXMgc2x5IHdoaXNwZXJzIHJ1c3RsaW5nIHRocm91Z2ggYWxsIHRoZSBh bGxleXMsIGhlYXJkIGluIHRoZSB2ZXJ5IGhhbGxzIG9mIGdvdmVybm1lbnQgaXRzZWxmLiBGb3Ig dGhlIHRyYWl0b3IgYXBwZWFycyBub3QgYSB0cmFpdG9yOyBoZSBzcGVha3MgaW4gYWNjZW50cyBm YW1pbGlhciB0byBoaXMgdmljdGltcywgYW5kIGhlIHdlYXJzIHRoZWlyIGZhY2UgYW5kIHRoZWly IGFyZ3VtZW50cywgaGUgYXBwZWFscyB0byB0aGUgYmFzZW5lc3MgdGhhdCBsaWVzIGRlZXAgaW4g dGhlIGhlYXJ0cyBvZiBhbGwgbWVuLiBIZSByb3RzIHRoZSBzb3VsIG9mIGEgbmF0aW9uLCBoZSB3 b3JrcyBzZWNyZXRseSBhbmQgdW5rbm93biBpbiB0aGUgbmlnaHQgdG8gdW5kZXJtaW5lIHRoZSBw aWxsYXJzIG9mIHRoZSBjaXR5LCBoZSBpbmZlY3RzIHRoZSBib2R5IHBvbGl0aWMgc28gdGhhdCBp dCBjYW4gbm8gbG9uZ2VyIHJlc2lzdC4gQSBtdXJkZXJlciBpcyBsZXNzIHRvIGZlYXIu4oCdDQpN VCBDaWNlcm8NCg0KDQpPbiBBcHIgMjEsIDIwMTcsIGF0IDk6NDggQU0sIEtlbGx5IE1jTXVsbGVu IDxrZWxseW1AYXZpYXRpbmcuY29tPG1haWx0bzprZWxseW1AYXZpYXRpbmcuY29tPj4gd3JvdGU6 DQoNCi0tPiBBZXJvRWxlY3RyaWMtTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogS2VsbHkgTWNNdWxs ZW4gPGtlbGx5bUBhdmlhdGluZy5jb208bWFpbHRvOmtlbGx5bUBhdmlhdGluZy5jb20+Pg0KDQpZ b3Ugd2lsbCBoYXZlIGEgc21hbGwgc2lnbmFsIGxvc3MgZnJvbSB0aGUgY29ubmVjdG9ycywgYnV0 IG90aGVyd2lzZSBmaW5lLiBJdCBpcyBmYWlybHkgY29tbW9uIHRvIGJ1aWxkIGFuIDE4LTI0IiBj b2F4IGZyb20gdGhlIHJhZGlvIHRyYXkgdG8gbWFrZSBmdXR1cmUgY2hhbmdlcyBhbmQgc2Vydmlj aW5nIGVhc2llci4gQUZBSUsgb25seSBHUFMgaGFzIGNvbnN0cmFpbnRzIGFib3V0IGFsbG93YWJs ZSBkQiBsb3NzIGJldHdlZW4gYW50ZW5uYSBhbmQgcmVjZWl2ZXIuDQpLZWxseQ0KDQpPbiA0LzIx LzIwMTcgNjoyNCBBTSwgQ2hhcmxlcyBQbHVtZXJ5IHdyb3RlOg0KSXMgaXQgb2sgdG8gZXh0ZW5k IHRoZSBsZW5ndGggb2YgYSBhbnRlbm5hIGNhYmxlIGJ5IG1ha2luZyBhIHNob3J0IHBpZ3RhaWwg c2F5IGZpdmUgZmVldCB3aXRoIGNvbm5lY3RvcnMgb24gZWFjaCBlbmQgdG8gZ28gYmV0d2VlbiBh IFZIRiBhbmQgdGhlIGV4aXN0aW5nIGNhYmxlIHRoYXQgaXMgdG8gc2hvcnQ/DQpDaHVjaw0KXy09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT0NCl8tPSAgICAgICAgICAtIFRoZSBBZXJvRWxlY3RyaWMtTGlzdCBFbWFpbCBGb3J1bSAtDQpf LT0gVXNlIHRoZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJlcyBOYXZpZ2F0b3IgdG8gYnJvd3NlDQpf LT0gdGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMgc3VjaCBhcyBMaXN0IFVuL1N1YnNjcmlwdGlvbiwN Cl8tPSBBcmNoaXZlIFNlYXJjaCAmIERvd25sb2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwN Cl8tPSBQaG90b3NoYXJlLCBhbmQgbXVjaCBtdWNoIG1vcmU6DQpfLT0NCl8tPSAgIC0tPiBodHRw Oi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP0Flcm9FbGVjdHJpYy1MaXN0DQpfLT0NCl8t PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09DQpfLT0gICAgICAgICAgICAgICAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0NCl8tPSBTYW1l IGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFibGUgdmlhIHRoZSBXZWIgRm9ydW1zIQ0KXy09DQpf LT0gICAtLT4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tDQpfLT0NCl8tPT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQpfLT0gICAg ICAgICAgICAgIC0gTkVXIE1BVFJPTklDUyBMSVNUIFdJS0kgLQ0KXy09IEFkZCBzb21lIGluZm8g dG8gdGhlIE1hdHJvbmljcyBFbWFpbCBMaXN0IFdpa2khDQpfLT0gICAtLT4gaHR0cDovL3dpa2ku bWF0cm9uaWNzLmNvbQ0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT0NCl8tPSAgICAgICAgICAgICAtIExpc3QgQ29udHJpYnV0aW9u IFdlYiBTaXRlIC0NCl8tPSAgVGhhbmsgeW91IGZvciB5b3VyIGdlbmVyb3VzIHN1cHBvcnQhDQpf LT0gICAgICAgICAgICAgICAgICAgICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4u DQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbg0KXy09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0N Cg0KDQoNCg= ________________________________________________________________________________
Date: Apr 22, 2017
At 12:27 PM 4/20/2017, you wrote: > > >After the server upgrade at matronics, I'm still wrestling with some >email issues . . . but these too will pass . . . Got 2 out of 3 email channels 'unclogged' . . . we're back in the saddle on the AeroElectric-List. I'm working on a couple of new regulator designs. There's a need for data describing performance studies and system integration questions that bubbled up with the advent of LiFePo4 batteries. The plan is to fit the drive stand with a 12-bit, 8 channel data acquisition system that will let us go measure things . . . things that that both suppliers and users of products offered to OBAM aviation should know. Need to get the regulators into production first but we'll add everything but the kitchen sink to the test stand after that. Got all the hardware in boxes waiting for software to be installed on the hosting computers. Bob . . . ________________________________________________________________________________
Date: Apr 23, 2017
Subject: 1.5DB???
Hi, I am installing a GTN-650 in my Velocity and the antenna location is only 2.0 feet from the unit itself. The Garmin instruction manual states that the cable loss needs to be between 1.5 and 6.5 DB. The manual also states that the calculated loss of a 6.5 foot cable with two BNC ends is 1.5 DB. I assume that this means that I need to run a 6.5 foot cable for my short run? If so, what is the minimum radius of the bends I would need to make in the cable to coil it up? Thanks for your kind help!!! Bill Hunter ________________________________________________________________________________
Date: Apr 23, 2017
Subject: Re: 1.5DB???
Bill, Yes, you need a minimum of 6.5 feet of cable length. The GPS antenna is an active antenna, having a pre-amplifier built into it that's powered by a bias voltage applied on the antenna center conductor (power comes from the GTN). The 1.5 dB of loss is to keep the receiver in the GPS unit from being over-driven and thus degrading the signal. The minimum 1-time bend radius from the RG400 spec is 1" - and the FAA spec from AC 43.13-1 is 10 times the diameter of the cable (which would make it just under a 2" radius). Both of these are a bit tight in my mind, and I would suggest a 3" radius (6" dia) or larger loop. That'll give about 19" of length per loop, which means three loops would get you what you need (or there about). Chuck ---- William Hunter wrote: > Hi, > > I am installing a GTN-650 in my Velocity and the antenna location is only > 2.0 feet from the unit itself. The Garmin instruction manual states that > the cable loss needs to be between 1.5 and 6.5 DB. The manual also states > that the calculated loss of a 6.5 foot cable with two BNC ends is 1.5 DB. > > I assume that this means that I need to run a 6.5 foot cable for my short > run? > > If so, what is the minimum radius of the bends I would need to make in the > cable to coil it up? > > > Thanks for your kind help!!! > > Bill Hunter ________________________________________________________________________________
Date: Apr 23, 2017
In order to meet the minimum cable length requirement, I purchased a 10 foot RG400 cable with TNC connections from eBay for $12 with free shipping. Item number: 131817000902 -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468711#468711 ________________________________________________________________________________
Date: Apr 24, 2017
Well I came to the right place for advice. Thanks for the item number as I will visit eBay Aircraft Supply this afternoon in order one Thanks again, Bill Hunter On Apr 23, 2017 16:59, "user9253" wrote: > > In order to meet the minimum cable length requirement, I purchased a 10 > foot RG400 cable with TNC connections from eBay for $12 with free shipping. > Item number: 131817000902 > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=468711#468711 > > ________________________________________________________________________________
Date: Apr 24, 2017
cbirdsall6(at)cox.net wrote: > Bill, > > Yes, you need a minimum of 6.5 feet of cable length. The GPS antenna is an active antenna, having a pre-amplifier built into it that's powered by a bias voltage applied on the antenna center conductor (power comes from the GTN). The 1.5 dB of loss is to keep the receiver in the GPS unit from being over-driven and thus degrading the signal. What's the long term impact from an antenna lead that's too short? I have a GTN625 which has been operating for about 18 months with a 1.5' antenna lead. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468748#468748 ________________________________________________________________________________
Date: Apr 24, 2017
Read Stein's post is this thread: http://forum.matronics.com/viewtopic.php?p=467885&sid=0551c7cee028f1697ba54f038595af00 I think that if it works, do not worry about it. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468750#468750 ________________________________________________________________________________
Date: Apr 25, 2017
One point that is not clear for me about the internal/external VR discussion. I apologize in advance if this has been clarified somewhere else and I just missed it. I don't understand why or how an external voltage regulator can safely cut the field using the crowbar method and an internal regulator cannot. If I look at the wiring diagrams there does not seem to be a difference. Is it just that the external VR is more robust? Thanks for any clarity you can provide. -------- Mickey Coggins http://www.rv8.ch/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468755#468755 ________________________________________________________________________________
From: MICK MULLER bigpond <mmul6471(at)bigpond.net.au>
Subject: TSU'd Usb charger??
Date: Apr 25, 2017
Hello Electrical Gurus. I recently got an email from Aircraft Spruce advertising Appeareo stratus dual power usb charging port which was TSOd. I am aware that TSO defines technical standards to which each device must conform. But I am wondering just what is in a TSOd version of a USB charger port versus a non TSOd one. Especially given the price quoted on the Spruce website is $399.95. For that money, I would want it gold plated at least. Mick building an RV9A. ________________________________________________________________________________
Date: Apr 25, 2017
Subject: Re: TSU'd Usb charger??
What is included for the price is FAA permission to hardwire it to a type-certificates aircraft without invalidating the certificate of airworthiness. If you have such an airplane and want legally to install a USB charger that's worth 10x any amount of gold plating. > On Apr 25, 2017, at 5:45 AM, MICK MULLER bigpond wrote: > > > Hello Electrical Gurus. > I recently got an email from Aircraft Spruce advertising Appeareo stratus dual power usb charging port which was TSOd. > I am aware that TSO defines technical standards to which each device must conform. > But I am wondering just what is in a TSOd version of a USB charger port versus a non TSOd one. > Especially given the price quoted on the Spruce website is $399.95. > For that money, I would want it gold plated at least. > Mick building an RV9A. > > > ________________________________________________________________________________
Date: Apr 25, 2017
The Appareo Stratus ESG already has two of 5 VDC outputs. All you have to do is buy the USB ports from eBay for about $2 and connect the wires. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468759#468759 ________________________________________________________________________________
Date: Apr 25, 2017
The internally regulated alternator gets its field power from within the alternator. There is no easy way for the pilot or for an over-voltage protection module to interrupt that power. The externally regulated alternator gets its field power from a panel mounted fuse or circuit breaker or switch. It is much easier to interrupt the external field power source. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468760#468760 ________________________________________________________________________________
Date: Apr 25, 2017
On Tue, Apr 25, 2017 at 4:45 AM, rv8ch wrote: > > One point that is not clear for me about the internal/external VR > discussion. I apologize in advance if this has been clarified somewhere > else and I just missed it. > > I don't understand why or how an external voltage regulator can safely cut > the field using the crowbar method and an internal regulator cannot. If I > look at the wiring diagrams there does not seem to be a difference. Is it > just that the external VR is more robust? > > Thanks for any clarity you can provide. > > -------- > Mickey Coggins > http://www.rv8.ch/ > > > With an external regulator, the crowbar shorts the field winding to ground, tripping the field circuit breaker (typically 5 amp rating). One cycle on the breaker; no damage done. You can achieve the exact same thing with an internally regulated alternator, but you must open up the alternator, find the field lead from the internal regulator to the field winding, and bring it outside the alternator to a field CB, then back to the winding. It can be done, if you know what you're doing. But it *is* a significant 'invasion' into a very well thought-out and tested (by auto engineers) system, so there's risk of doing it wrong, or just upsetting the design. It could be as simple as: the act of re-routing the field wire could make it more vulnerable to vibration induced failure. (Just one example.) The simpler method is to add an external contactor in series with the B-lead, and feed its coil through that 5A breaker. Then the OV module would short the coil circuit to ground, tripping the breaker and opening the contactor. That's the technique used on the permanent magnet alternators, that have no field winding. Bob no longer includes that method in the book. If memory serves, there were issues many years ago where some were 'testing' the OV feature (or their 'traditionally wired' split master switch) while in flight (with the alternator loaded), and by 'dumping' the load, the perfectly good alternator could fry its internal regulator because the regulator couldn't respond quickly enough to keep the sharp rise in voltage from damaging internal semiconductors. In the immortal words of the Hee Haw TV show doctor, 'If it hurts when you do that, don't do that.' The only reason to operate that contactor is if the alternator has already failed. Charlie ________________________________________________________________________________
Date: Apr 25, 2017
user9253 wrote: > The internally regulated alternator gets its field power from within the alternator. There is no easy way for the pilot or for an over-voltage protection module to interrupt that power. > The externally regulated alternator gets its field power from a panel mounted fuse or circuit breaker or switch. It is much easier to interrupt the external field power source. Yes, this is what I thought as well, but looking at the Z diagrams for how to wire an external VR, it looks like control of the F is only done by the VR, so I'm struggling to see a difference between and Internal and and External VR. -------- Mickey Coggins http://www.rv8.ch/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468761#468761 Attachments: http://forums.matronics.com//files/voltage_regulator_113.png ________________________________________________________________________________
Date: Apr 25, 2017
Aero Folks, And if you happen to need one in your Experimental OBAM aircraft where the TSO isn=99t necessary there=99s a nice unit available for $75 from: http://commitlift.com Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop (75 hrs). Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com > On Apr 25, 2017, at 4:45 AM, MICK MULLER bigpond wrote: > > > Hello Electrical Gurus. > I recently got an email from Aircraft Spruce advertising Appeareo stratus dual power usb charging port which was TSO=99d. > I am aware that TSO defines technical standards to which each device must conform. > But I am wondering just what is in a TSO=99d version of a USB charger port versus a non TSO=99d one. > Especially given the price quoted on the Spruce website is $399.95. > For that money, I would want it gold plated at least. > Mick building an RV9A. > > > ________________________________________________________________________________
Date: Apr 25, 2017
Mickey I suspect that something about the diagram you are looking at is misleading you. Recall that the voltage sense wire (or any of the small wires) going into an internal vr alternator do not normally supply the field. The internal vr alternators that I'm familiar with will continue to output power if all the small wires are disconnected. As mentioned, there is no external connection or wire between the internal vr and the field winding unless you modify the stock alternator. Ken On 25/04/2017 8:19 AM, rv8ch wrote: > > > user9253 wrote: >> The internally regulated alternator gets its field power from within the alternator. There is no easy way for the pilot or for an over-voltage protection module to interrupt that power. >> The externally regulated alternator gets its field power from a panel mounted fuse or circuit breaker or switch. It is much easier to interrupt the external field power source. > Yes, this is what I thought as well, but looking at the Z diagrams for how to wire an external VR, it looks like control of the F is only done by the VR, so I'm struggling to see a difference between and Internal and and External VR. > > -------- > Mickey Coggins > http://www.rv8.ch/ > > ________________________________________________________________________________
Date: Apr 25, 2017
At 04:45 AM 4/25/2017, you wrote: > >One point that is not clear for me about the internal/external VR >discussion. I apologize in advance if this has been clarified >somewhere else and I just missed it. > >I don't understand why or how an external voltage regulator can >safely cut the field using the crowbar method and an internal >regulator cannot. If I look at the wiring diagrams there does not >seem to be a difference. Is it just that the external VR is more robust? > >Thanks for any clarity you can provide. The externally regulated alternator has NO electronics inside . . . just a rudimentary alternator. Emacs! Interrupting the 'field input' line offers total control over alternator output. The internally regulated alternator has solid state devices that control alternator output. There is no field power input connection, only a 'control' connection that talks to the electronics. Emacs! There are failure modes INTERNAL to the alternator that can cause an over voltage condition . . . a condition not controllable from outside. Hence, the legacy preference for externally regulated alternators that allow a system integrator to include over voltage protection in some form. It doesn't have to be the 'crowbar' style . . . there are several satisfactory approaches. The crowbar ov module offers the simplest and most robust configuration but it's not intended to displace any other demonstrably functioning ov management system. Bob . . . ________________________________________________________________________________
Date: Apr 25, 2017
At 04:45 AM 4/25/2017, you wrote: >MULLER bigpond > >Hello Electrical Gurus. >I recently got an email from Aircraft Spruce >advertising Appeareo stratus dual power usb charging port which was TSO=99d. >I am aware that TSO defines technical standards >to which each device must conform. >But I am wondering just what is in a TSO=99d >version of a USB charger port versus a non TSO=99d one. >Especially given the price quoted on the Spruce website is $399.95. >For that money, I would want it gold plated at least or perhaps platinum plated . . . Try any usb power port product you like. It's an experimental airplane . . . this means you can try things that may be discarded for one reason or another later. Risks for incorporation of jelly-bean usb power products include noise in radios and/or perhaps simple lack of robustness for the aviation environment. Just be aware of the potential risks and explore them under comfortable, low risk flying conditions. If you plan to run some appliance that is extraordinarily useful/necessary for comfortable conduct of your flight, consider building your own usb power port. It's just a 5v power source. A linear regulator generates no noise and is only a little larger/heavier. But yeah, give me a break. . . . 'TSO' in this case is a license to extort . . . Bob . . . ________________________________________________________________________________
Date: Apr 25, 2017
>Yes, this is what I thought as well, but looking at the Z diagrams >for how to wire an external VR, it looks like control of the F is >only done by the VR, so I'm struggling to see a difference between >and Internal and and External VR. But the crowbar ov module in turn controls power to the external regulator. Opening the field power source to the regulator will also shut down the alternator. That 'control' lead into an IR alternator cannot be guaranteed to offer absolute control under all failure modes. Bob . . . ________________________________________________________________________________
Date: Apr 25, 2017
>>But yeah, give me a break. . . . 'TSO' in this case is a license to extort . . . Bob, I think that's a little harsh. If you own a TC aircraft - which can be anything up to a multi-million dollar business jet, remember, and you want a USB socket, you need something TSO'd. You yourself probably know better than anyone the cost of pushing the paperwork through on that, versus the number of units likely to be sold. If there's any "extortion" going on it's by the FAA and the ICAO - it seems unfair to single out this product for criticism. ________________________________________________________________________________
Date: Apr 25, 2017
I've been thinking about the alternator setup for my RV-10 lately. I think OV protection is necessary, but also would like to have a high capacity alt (60-70amp) so I can run some seat heaters (I know, blame the wife). The best thing I had found so far was the externally regulated Honda alt that puts out 45amps. Also have found the write-up for hacking up an IR alternator to bring out the field wire, but not very fond of that idea as it complicates (at best) field maintenance. This is the first I've seen of the Perihelion design module. At first glance it seems like it may allow me to run a bigger IR altenator but still have effective OV protection. Jan's comments though make it sound like a 200ms trip time might not work. Bob what kind of new setup are you testing? Very interested to hear what you have going on. -Josh On Fri, Apr 14, 2017 at 3:09 PM, Mickey Coggins wrote: > Eric says his works in about 200ms: http://www.periheliondesign. > com/lovm.htm > > Mickey Coggins > > On 13 April 2017 at 16:32, Jan de Jong wrote: > >> With a 22mF, 40V capacitor there would be 24/0.64 = 37.5ms available >> until the DO160 limit is reached. >> If a 47mF/40V capacitor were installed the bus voltage would climb at >> 0.30V/ms and it would take 24/0.30 = 80ms for the DO160 limit to be reached. >> >> >> >> > ________________________________________________________________________________
Date: Apr 25, 2017
On 4/25/2017 8:35 AM, Alec Myers wrote: > > >>> But yeah, give me a break. . . . 'TSO' in > this case is a license to extort . . . > > > Bob, I think that's a little harsh. If you own a TC aircraft - which can be anything up to a multi-million dollar business jet, remember, and you want a USB socket, you need something TSO'd. You yourself probably know better than anyone the cost of pushing the paperwork through on that, versus the number of units likely to be sold. > > If there's any "extortion" going on it's by the FAA and the ICAO - it seems unfair to single out this product for criticism. > People seem to almost always blame regulations on the regulator (government). It's rarely that simple a case. Example from one of my past lives: One aspect of my former business was installing and maintaining security systems (burglar/fire alarms). At the time, there were 2 or 3 big companies in my area, and me (much smaller, but I was probably the only one who would service 'orphaned' systems). As fear of crime heated up, demand went up and new players appeared on the supply side. One day I got a call from one of the big companies, inviting me to help form a new local organization of alarm companies *so that we could lobby the legislature for regulations requiring any new companies to be 'certified' and licensed. *Got to protect those consumers from those inexperienced, incompetent new companies, right? Existing**companies would be grandfathered in, of course... For an example closer to home, look at the most common a/c carburetor. Do some historical research, tracking the dates of ownership changes (remembering that typically, big money changes hands) of the carb design, and overlay the dates of the series of AD's on the float. Correlation? Causation? You decide. We get the government we lobby for. Or we get the government that someone else lobbies for, while we do nothing. Charlie * * --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Apr 25, 2017
Subject: Re: Interesting thread on overvoltage event
Because I am installing the optional 40 amp Rotax alternator (internally regulated Denso) this discussion is very interesting to me. From what I am reading, it sounds like the only way to shut it down would be to interrupt the output (B wire) with a switch or pull breaker. If that is the case, what is the purpose of the IG wire, which runs from the bus, through the master switch, to the alternator? Thanks, Ken On Tue, Apr 25, 2017 at 4:04 AM, user9253 wrote: > > The internally regulated alternator gets its field power from within the > alternator. There is no easy way for the pilot or for an over-voltage > protection module to interrupt that power. > The externally regulated alternator gets its field power from a panel > mounted fuse or circuit breaker or switch. It is much easier to interrupt > the external field power source. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=468760#468760 > > ________________________________________________________________________________
Date: Apr 25, 2017
Some of these USB chargers out there are utter crap though! I=92ve now racked up a handful of reported instances where people (temporarily) wire in some sort of 5V converter for their flight computers or other electronics and end up with =91terrible screeching=92 on the radio. For a guy flying around in a mid-6-figure airplane, a $400 USB jack is a no-brainer. For the rest of us, be careful what you buy. That $12 USB charger from Walmart may not be very good. > On Apr 25, 2017, at 9:52 AM, Charlie England wrote: > > On 4/25/2017 8:35 AM, Alec Myers wrote: >> >> >>>> But yeah, give me a break. . . . 'TSO' in >> this case is a license to extort . . . >> >> >> >> Bob, I think that's a little harsh. If you own a TC aircraft - which can be anything up to a multi-million dollar business jet, remember, and you want a USB socket, you need something TSO'd. You yourself probably know better than anyone the cost of pushing the paperwork through on that, versus the number of units likely to be sold. >> >> If there's any "extortion" going on it's by the FAA and the ICAO - it seems unfair to single out this product for criticism. >> > People seem to almost always blame regulations on the regulator (government). It's rarely that simple a case. > > Example from one of my past lives: > One aspect of my former business was installing and maintaining security systems (burglar/fire alarms). At the time, there were 2 or 3 big companies in my area, and me (much smaller, but I was probably the only one who would service 'orphaned' systems). As fear of crime heated up, demand went up and new players appeared on the supply side. One day I got a call from one of the big companies, inviting me to help form a new local organization of alarm companies so that we could lobby the legislature for regulations requiring any new companies to be 'certified' and licensed. Got to protect those consumers from those inexperienced, incompetent new companies, right? Existing companies would be grandfathered in, of course... > > For an example closer to home, look at the most common a/c carburetor. Do some historical research, tracking the dates of ownership changes (remembering that typically, big money changes hands) of the carb design, and overlay the dates of the series of AD's on the float. Correlation? Causation? You decide. > > We get the government we lobby for. Or we get the government that someone else lobbies for, while we do nothing. > > Charlie > > > > > > > > > > > > > > > Virus-free. www.avast.com ________________________________________________________________________________
Date: Apr 25, 2017
Bob Could you right up the details on building our own Quiet USB charger? Thanks Bernie Willis Sent from my iPhone > On Apr 25, 2017, at 7:07 AM, Daniel Hooper wrote: > > Some of these USB chargers out there are utter crap though! > > I=99ve now racked up a handful of reported instances where people (t emporarily) wire in some sort of 5V converter for their flight computers or o ther electronics and end up with =98terrible screeching=99 on th e radio. > > For a guy flying around in a mid-6-figure airplane, a $400 USB jack is a n o-brainer. For the rest of us, be careful what you buy. That $12 USB charger from Walmart may not be very good. > >> On Apr 25, 2017, at 9:52 AM, Charlie England wrote : >> >> On 4/25/2017 8:35 AM, Alec Myers wrote: >>> >>> >>>>> But yeah, give me a break. . . . 'TSO' in >>> this case is a license to extort . . . >>> >>> >>> >>> Bob, I think that's a little harsh. If you own a TC aircraft - which can be anything up to a multi-million dollar business jet, remember, and you wa nt a USB socket, you need something TSO'd. You yourself probably know better than anyone the cost of pushing the paperwork through on that, versus the n umber of units likely to be sold. >>> >>> If there's any "extortion" going on it's by the FAA and the ICAO - it se ems unfair to single out this product for criticism. >>> >> People seem to almost always blame regulations on the regulator (governme nt). It's rarely that simple a case. >> >> Example from one of my past lives: >> One aspect of my former business was installing and maintaining security s ystems (burglar/fire alarms). At the time, there were 2 or 3 big companies i n my area, and me (much smaller, but I was probably the only one who would s ervice 'orphaned' systems). As fear of crime heated up, demand went up and n ew players appeared on the supply side. One day I got a call from one of the big companies, inviting me to help form a new local organization of alarm c ompanies so that we could lobby the legislature for regulations requiring an y new companies to be 'certified' and licensed. Got to protect those consum ers from those inexperienced, incompetent new companies, right? Existing com panies would be grandfathered in, of course... >> >> For an example closer to home, look at the most common a/c carburetor. Do some historical research, tracking the dates of ownership changes (remember ing that typically, big money changes hands) of the carb design, and overlay the dates of the series of AD's on the float. Correlation? Causation? You d ecide. >> >> We get the government we lobby for. Or we get the government that someone else lobbies for, while we do nothing. >> >> Charlie >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> Virus-free. www.avast.com > ________________________________________________________________________________
Date: Apr 25, 2017
I did all the background research necessary to do a fully-protected and whisper-quiet (and probably TSO-able) one a while back, but then Commit Lift and a few others came along and it wasn=99t really worth it anymore. My chip-level design was going to be a minimum of $100 a unit to sell anyway, and it=99s hard to compete when people don=99t understand the difference between your $100 product and a $10 product. Just my 0.02.. : / > On Apr 25, 2017, at 11:30 AM, Bernie wrote: > > Bob > Could you right up the details on building our own Quiet USB charger? > > Thanks > Bernie Willis > > Sent from my iPhone > > On Apr 25, 2017, at 7:07 AM, Daniel Hooper > wrote: > >> Some of these USB chargers out there are utter crap though! >> >> I=99ve now racked up a handful of reported instances where people (temporarily) wire in some sort of 5V converter for their flight computers or other electronics and end up with =98terrible screeching=99 on the radio. >> >> For a guy flying around in a mid-6-figure airplane, a $400 USB jack is a no-brainer. For the rest of us, be careful what you buy. That $12 USB charger from Walmart may not be very good. >> >>> On Apr 25, 2017, at 9:52 AM, Charlie England > wrote: >>> >>> On 4/25/2017 8:35 AM, Alec Myers wrote: >>>> >>>> >>>>>> But yeah, give me a break. . . . 'TSO' in >>>> this case is a license to extort . . . >>>> >>>> >>>> >>>> Bob, I think that's a little harsh. If you own a TC aircraft - which can be anything up to a multi-million dollar business jet, remember, and you want a USB socket, you need something TSO'd. You yourself probably know better than anyone the cost of pushing the paperwork through on that, versus the number of units likely to be sold. >>>> >>>> If there's any "extortion" going on it's by the FAA and the ICAO - it seems unfair to single out this product for criticism. >>>> >>> People seem to almost always blame regulations on the regulator (government). It's rarely that simple a case. >>> >>> Example from one of my past lives: >>> One aspect of my former business was installing and maintaining security systems (burglar/fire alarms). At the time, there were 2 or 3 big companies in my area, and me (much smaller, but I was probably the only one who would service 'orphaned' systems). As fear of crime heated up, demand went up and new players appeared on the supply side. One day I got a call from one of the big companies, inviting me to help form a new local organization of alarm companies so that we could lobby the legislature for regulations requiring any new companies to be 'certified' and licensed. Got to protect those consumers from those inexperienced, incompetent new companies, right? Existing companies would be grandfathered in, of course... >>> >>> For an example closer to home, look at the most common a/c carburetor. Do some historical research, tracking the dates of ownership changes (remembering that typically, big money changes hands) of the carb design, and overlay the dates of the series of AD's on the float. Correlation? Causation? You decide. >>> >>> We get the government we lobby for. Or we get the government that someone else lobbies for, while we do nothing. >>> >>> Charlie >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> Virus-free. www.avast.com ________________________________________________________________________________
Date: Apr 25, 2017
Bob, Found Committ Lift. Thanks, Bernie > On Apr 25, 2017, at 9:00 AM, Daniel Hooper wrote: > > I did all the background research necessary to do a fully-protected and whisper-quiet (and probably TSO-able) one a while back, but then Commit Lift and a few others came along and it wasn=99t really worth it anymore. > > My chip-level design was going to be a minimum of $100 a unit to sell anyway, and it=99s hard to compete when people don=99t understand the difference between your $100 product and a $10 product. > > Just my 0.02.. : / > >> On Apr 25, 2017, at 11:30 AM, Bernie > wrote: >> >> Bob >> Could you right up the details on building our own Quiet USB charger? >> >> Thanks >> Bernie Willis >> >> Sent from my iPhone >> >> On Apr 25, 2017, at 7:07 AM, Daniel Hooper > wrote: >> >>> Some of these USB chargers out there are utter crap though! >>> >>> I=99ve now racked up a handful of reported instances where people (temporarily) wire in some sort of 5V converter for their flight computers or other electronics and end up with =98terrible screeching=99 on the radio. >>> >>> For a guy flying around in a mid-6-figure airplane, a $400 USB jack is a no-brainer. For the rest of us, be careful what you buy. That $12 USB charger from Walmart may not be very good. >>> >>>> On Apr 25, 2017, at 9:52 AM, Charlie England > wrote: >>>> >>>> On 4/25/2017 8:35 AM, Alec Myers wrote: >>>>> >>>>> >>>>>>> But yeah, give me a break. . . . 'TSO' in >>>>> this case is a license to extort . . . >>>>> >>>>> >>>>> >>>>> Bob, I think that's a little harsh. If you own a TC aircraft - which can be anything up to a multi-million dollar business jet, remember, and you want a USB socket, you need something TSO'd. You yourself probably know better than anyone the cost of pushing the paperwork through on that, versus the number of units likely to be sold. >>>>> >>>>> If there's any "extortion" going on it's by the FAA and the ICAO - it seems unfair to single out this product for criticism. >>>>> >>>> People seem to almost always blame regulations on the regulator (government). It's rarely that simple a case. >>>> >>>> Example from one of my past lives: >>>> One aspect of my former business was installing and maintaining security systems (burglar/fire alarms). At the time, there were 2 or 3 big companies in my area, and me (much smaller, but I was probably the only one who would service 'orphaned' systems). As fear of crime heated up, demand went up and new players appeared on the supply side. One day I got a call from one of the big companies, inviting me to help form a new local organization of alarm companies so that we could lobby the legislature for regulations requiring any new companies to be 'certified' and licensed. Got to protect those consumers from those inexperienced, incompetent new companies, right? Existing companies would be grandfathered in, of course... >>>> >>>> For an example closer to home, look at the most common a/c carburetor. Do some historical research, tracking the dates of ownership changes (remembering that typically, big money changes hands) of the carb design, and overlay the dates of the series of AD's on the float. Correlation? Causation? You decide. >>>> >>>> We get the government we lobby for. Or we get the government that someone else lobbies for, while we do nothing. >>>> >>>> Charlie >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> Virus-free. www.avast.com > ________________________________________________________________________________
Date: Apr 25, 2017
Just for clarity=99s sake, I am not Bob. =94Daniel > On Apr 25, 2017, at 12:26 PM, Bernie Willis wrote: > > Bob, > > Found Committ Lift. > > Thanks, > Bernie >> On Apr 25, 2017, at 9:00 AM, Daniel Hooper > wrote: >> >> I did all the background research necessary to do a fully-protected and whisper-quiet (and probably TSO-able) one a while back, but then Commit Lift and a few others came along and it wasn=99t really worth it anymore. >> >> My chip-level design was going to be a minimum of $100 a unit to sell anyway, and it=99s hard to compete when people don=99t understand the difference between your $100 product and a $10 product. >> >> Just my 0.02.. : / >> >>> On Apr 25, 2017, at 11:30 AM, Bernie > wrote: >>> >>> Bob >>> Could you right up the details on building our own Quiet USB charger? >>> >>> Thanks >>> Bernie Willis >>> >>> Sent from my iPhone >>> >>> On Apr 25, 2017, at 7:07 AM, Daniel Hooper > wrote: >>> >>>> Some of these USB chargers out there are utter crap though! >>>> >>>> I=99ve now racked up a handful of reported instances where people (temporarily) wire in some sort of 5V converter for their flight computers or other electronics and end up with =98terrible screeching=99 on the radio. >>>> >>>> For a guy flying around in a mid-6-figure airplane, a $400 USB jack is a no-brainer. For the rest of us, be careful what you buy. That $12 USB charger from Walmart may not be very good. >>>> >>>>> On Apr 25, 2017, at 9:52 AM, Charlie England > wrote: >>>>> >>>>> On 4/25/2017 8:35 AM, Alec Myers wrote: >>>>>> >>>>>> >>>>>>>> But yeah, give me a break. . . . 'TSO' in >>>>>> this case is a license to extort . . . >>>>>> >>>>>> >>>>>> >>>>>> Bob, I think that's a little harsh. If you own a TC aircraft - which can be anything up to a multi-million dollar business jet, remember, and you want a USB socket, you need something TSO'd. You yourself probably know better than anyone the cost of pushing the paperwork through on that, versus the number of units likely to be sold. >>>>>> >>>>>> If there's any "extortion" going on it's by the FAA and the ICAO - it seems unfair to single out this product for criticism. >>>>>> >>>>> People seem to almost always blame regulations on the regulator (government). It's rarely that simple a case. >>>>> >>>>> Example from one of my past lives: >>>>> One aspect of my former business was installing and maintaining security systems (burglar/fire alarms). At the time, there were 2 or 3 big companies in my area, and me (much smaller, but I was probably the only one who would service 'orphaned' systems). As fear of crime heated up, demand went up and new players appeared on the supply side. One day I got a call from one of the big companies, inviting me to help form a new local organization of alarm companies so that we could lobby the legislature for regulations requiring any new companies to be 'certified' and licensed. Got to protect those consumers from those inexperienced, incompetent new companies, right? Existing companies would be grandfathered in, of course... >>>>> >>>>> For an example closer to home, look at the most common a/c carburetor. Do some historical research, tracking the dates of ownership changes (remembering that typically, big money changes hands) of the carb design, and overlay the dates of the series of AD's on the float. Correlation? Causation? You decide. >>>>> >>>>> We get the government we lobby for. Or we get the government that someone else lobbies for, while we do nothing. >>>>> >>>>> Charlie >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> Virus-free. www.avast.com >> > ________________________________________________________________________________
Date: Apr 25, 2017
My experience was virtually identical to Daniel's. I spent several months and a several $hundred$ on prototypes of a ground-up design to get a charger that worked well and -- with some guidance from our mentor here -- was electrically quiet. Then I sat down and figured out what I would have to charge for it to make it worth my trouble. When I considered what would be involved (form an LLC; get panels of PCBs fabricated and robotically assembled; stock shipping supplies; build a website; set up payment acceptance; handle federal, state and local tax reporting; traipse to the post office to fulfill orders; deal with tech support requests; handle the inevitable returns -- and after all that, make a reasonable profit), in the end, it just didn't make any sense. For an existing company with engineers on staff, an established supply chain and a dealer network, it's feasible; for an electronics and aviation hobbyist, not so much. Eric > On Apr 25, 2017, at 10:00 AM, Daniel Hooper wrote: > I did all the background research necessary to do a fully-protected and whisper-quiet (and probably TSO-able) one a while back, but then Commit Lift and a few others came along and it wasnt really worth it anymore. > > My chip-level design was going to be a minimum of $100 a unit to sell anyway, and its hard to compete when people dont understand the difference between your $100 product and a $10 product. > > Just my 0.02.. : / ________________________________________________________________________________
Date: Apr 25, 2017
Thanks, Daniel Bernie > On Apr 25, 2017, at 9:54 AM, Daniel Hooper wrote: > > Just for clarity=99s sake, I am not Bob. > > =94Daniel > >> On Apr 25, 2017, at 12:26 PM, Bernie Willis > wrote: >> >> Bob, >> >> Found Committ Lift. >> >> Thanks, >> Bernie >>> On Apr 25, 2017, at 9:00 AM, Daniel Hooper > wrote: >>> >>> I did all the background research necessary to do a fully-protected and whisper-quiet (and probably TSO-able) one a while back, but then Commit Lift and a few others came along and it wasn=99t really worth it anymore. >>> >>> My chip-level design was going to be a minimum of $100 a unit to sell anyway, and it=99s hard to compete when people don=99t understand the difference between your $100 product and a $10 product. >>> >>> Just my 0.02.. : / >>> >>>> On Apr 25, 2017, at 11:30 AM, Bernie > wrote: >>>> >>>> Bob >>>> Could you right up the details on building our own Quiet USB charger? >>>> >>>> Thanks >>>> Bernie Willis >>>> >>>> Sent from my iPhone >>>> >>>> On Apr 25, 2017, at 7:07 AM, Daniel Hooper > wrote: >>>> >>>>> Some of these USB chargers out there are utter crap though! >>>>> >>>>> I=99ve now racked up a handful of reported instances where people (temporarily) wire in some sort of 5V converter for their flight computers or other electronics and end up with =98terrible screeching=99 on the radio. >>>>> >>>>> For a guy flying around in a mid-6-figure airplane, a $400 USB jack is a no-brainer. For the rest of us, be careful what you buy. That $12 USB charger from Walmart may not be very good. >>>>> >>>>>> On Apr 25, 2017, at 9:52 AM, Charlie England > wrote: >>>>>> >>>>>> On 4/25/2017 8:35 AM, Alec Myers wrote: >>>>>>> >>>>>>> >>>>>>>>> But yeah, give me a break. . . . 'TSO' in >>>>>>> this case is a license to extort . . . >>>>>>> >>>>>>> >>>>>>> >>>>>>> Bob, I think that's a little harsh. If you own a TC aircraft - which can be anything up to a multi-million dollar business jet, remember, and you want a USB socket, you need something TSO'd. You yourself probably know better than anyone the cost of pushing the paperwork through on that, versus the number of units likely to be sold. >>>>>>> >>>>>>> If there's any "extortion" going on it's by the FAA and the ICAO - it seems unfair to single out this product for criticism. >>>>>>> >>>>>> People seem to almost always blame regulations on the regulator (government). It's rarely that simple a case. >>>>>> >>>>>> Example from one of my past lives: >>>>>> One aspect of my former business was installing and maintaining security systems (burglar/fire alarms). At the time, there were 2 or 3 big companies in my area, and me (much smaller, but I was probably the only one who would service 'orphaned' systems). As fear of crime heated up, demand went up and new players appeared on the supply side. One day I got a call from one of the big companies, inviting me to help form a new local organization of alarm companies so that we could lobby the legislature for regulations requiring any new companies to be 'certified' and licensed. Got to protect those consumers from those inexperienced, incompetent new companies, right? Existing companies would be grandfathered in, of course... >>>>>> >>>>>> For an example closer to home, look at the most common a/c carburetor. Do some historical research, tracking the dates of ownership changes (remembering that typically, big money changes hands) of the carb design, and overlay the dates of the series of AD's on the float. Correlation? Causation? You decide. >>>>>> >>>>>> We get the government we lobby for. Or we get the government that someone else lobbies for, while we do nothing. >>>>>> >>>>>> Charlie >>>>>> >>>>>> >>>>>> >>>>>> >>>>>> >>>>>> >>>>>> >>>>>> >>>>>> >>>>>> >>>>>> >>>>>> >>>>>> >>>>>> >>>>>> Virus-free. www.avast.com >>> >> > ________________________________________________________________________________
Date: Apr 25, 2017
At 09:52 AM 4/25/2017, you wrote: >On 4/25/2017 8:35 AM, Alec Myers wrote: >> >> >> >> >>>> >>>>But yeah, give me a break. . . . 'TSO' in >> >> this case is a license to extort . . . >> >> >> >>Bob, I think that's a little harsh. If you own a TC aircraft - >>which can be anything up to a multi-million dollar business jet, >>remember, and you want a USB socket, you need something TSO'd. You >>yourself probably know better than anyone the cost of pushing the >>paperwork through on that, versus the number of units likely to be sold. >> >>If there's any "extortion" going on it's by the FAA and the ICAO - >>it seems unfair to single out this product for criticism. You are right of course . . . I wasn't clear. It's the primary reason I have departed the TC aircraft scene professionally. Back about 1980, I proposed, prototyped, submitted samples, reworked to customer desires, did a production drawing package, built qual test articles, wrote the test plan, did all but EMC testing in our labs, wrote the test report, got it bought off by FAA, wrote the acceptance test procedure and coordinated with the production line to put a new, all electronic stall and gear warning horn on the Bonanza and Baron lines at Beech. Did it all by myself in about 90 days start to finish. To get that SAME exact product on an airplane today would probably command a 'team' of a half dozen specialists and take 6 months to a year to wind it's way through the ISO9000 policies and procedures mine-field. I had similar successes with a constant speed pitch trim system for the Lears and a sprinkling of other devices at Cessna, Lear and Beech. My last exertions in TC aircraft were expended about two years ago. The goal was to convince Beech DERs that we could take the guts out of a Cessna regulator (made by Lamar) and put them inside the housing for a Beech regulator (also built by Lamar). The Beech regulator had been a pain the the arse for about 30 years. The Cessna regulator had a flawless field history for about 20 years. Since both Beech and Cessna were now the same company, you'd think it was a no-brainer . . . BOTH products were qualified and had been in production for decades. Fortunately, my consulting contract ran out about three weeks into this 'simple fix' . . . and I did not have to hang around and watch the various 'teams' turn a little problem into a huge one . . . that took about a year to get resolved. In the mean time, Bonanza and Baron owners were suffering the consequences of 'our' inadequacies. So yes Alec, you're point is well taken . . . to which I will add the idea that (1) nobody sets out to build a marginal product and (2) the path to perfection is paved with spontaneous order, the collegial cooperation of all interested parties to do the best we know how to do today and improve on it tomorrow. Improvements that are now burdened with tons of regulatory mill stones. Thanks for calling me out on it! Bob . . . ________________________________________________________________________________
Date: Apr 25, 2017
March 27, 2017 - April 25, 2017
AeroElectric-Archive.digest.vol-nv
