AeroElectric-Archive.digest.vol-nx
May 21, 2017 - June 29, 2017
       senses, just with reversing the electrons movement on those
       2 wires. You also probably know that the motor doesnt
       stop at both ends if you dont release the switch, so
       the motor keeps turning even when the flaps reach full
       extension and full retraction. Now the question: which can
       be the reason for the current peak that the motor is
       reaching at full retraction? Any help welcomeThanksCarlos
Date: May 21, 2017
Subject: Re: Flaps system tripping the circuit breaker
On Sun, May 21, 2017 at 4:47 AM, Carlos Trigo wrote : > One of my aviator friends called me to help him solving a problem in his > RV-7 flaps system. > > He told me that occasionally, when he retracts the flaps, the > correspondent Circuit Breaker trips. But not always, so he resets the CB > and the flaps keep working normally. > > > I asked him to measure the current during the flaps movement, and he > measured 1 to 2 A when extending and when retracting, but he noticed that > after full retraction the current went to 7 A. > > That explains why the CB (5A) trips. > > > I think most of you know that the flaps system in an RV airplane is > powered by an electric motor with 2 wires, which make the flaps work in > both senses, just with reversing the electrons movement on those 2 wires. > You also probably know that the motor doesn=99t stop at both ends i f you > don=99t release the switch, so the motor keeps turning even when th e flaps > reach full extension and full retraction. > > > Now the question: which can be the reason for the current peak that the > motor is reaching at full retraction? > > > Any help welcome > > Thanks > > Carlos > > My 1st guess is that the flap linkage is slightly out of adjustment. If the flaps hit their stops before the motor reaches full retraction, it would still trying to pull instead of free-wheeling. My 2nd guess (after looking at the 10A flaps breaker in my RV-4, and looking at the specs for the motor that's inside the actuator) is that he's using the wrong breaker. Corollary to my 2nd guess is that he's holding the up button too long. :-) Charlie ________________________________________________________________________________
Date: May 21, 2017
Is there a functional limit switch in this system? If you hit the physical end of travel for the flap system and there's no limit switch, the motor will keep on pulling at maximum power. Current draw will be a lot higher and if it wasn't for the CB, you'd probably burn up the motor. On 5/21/2017 11:47 AM, Carlos Trigo wrote: > > One of my aviator friends called me to help him solving a problem in > his RV-7 flaps system. > > He told me that occasionally, when he retracts the flaps, the > correspondent Circuit Breaker trips. But not always, so he resets the > CB and the flaps keep working normally. > > I asked him to measure the current during the flaps movement, and he > measured 1 to 2 A when extending and when retracting, but he noticed > that after full retraction the current went to 7 A. > > That explains why the CB (5A) trips. > > I think most of you know that the flaps system in an RV airplane is > powered by an electric motor with 2 wires, which make the flaps work > in both senses, just with reversing the electrons movement on those 2 > wires. You also probably know that the motor doesnt stop at both ends > if you dont release the switch, so the motor keeps turning even when > the flaps reach full extension and full retraction. > > Now the question: which can be the reason for the current peak that > the motor is reaching at full retraction? > > Any help welcome > > Thanks > > Carlos > ________________________________________________________________________________
Subject: Re: IVO Prop current limiter
Date: May 21, 2017
Bob, When you get the new circuit up I would be very interested in purchasing. Have the Ivo mag prop which will be interfacing with a Viking Turbo 170HP. Should be interesting to see the performance. Merle -------- KC1DNJ General Radiotelephone Commercial SEL A&P Building scale P51 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=469481#469481 ________________________________________________________________________________
Date: May 21, 2017
At 06:14 AM 5/21/2017, you wrote: > >Due to the mostly vertical orientation of the motor, the grease in >the bearings will sometime migrate down onto the commutator/brush >area of the armature. This is a common issue. It requires removal >and disassembly of the motor to clean the grease off the armature >and re-grease the bearings. Contamination of the commutator can indeed manifest in mis-behavior of the motor but not over-current. Are these ball bearings? If so, they are most likely a metric standard. You might fix the problem with factory lubricated, sealed bearings. Bob . . . ________________________________________________________________________________
Date: May 21, 2017
> > >My 1st guess is that the flap linkage is >slightly out of adjustment. If the flaps hit >their stops before the motor reaches full >retraction, it would still trying to pull instead of free-wheeling. > >My 2nd guess (after looking at the 10A flaps >breaker in my RV-4, and looking at the specs for >the motor that's inside the actuator) is that he's using the wrong breaker. > >Corollary to my 2nd guess is that he's holding the up button too long. :-) =C2 > >Charlie Agreed. The spec sheet shows a motor resistance of 0.83 ohms. Add another few tenths of an ohm for wiring and we still have an inrush current potential on the order of 10 amps. So yes, the 5A breaker MIGHT be marginal . . . but I would expect it to operate on both extend or retract cycles . . . especially extend when the motor is pushing flaps into the slip-stream. So your first guess sounds like the right one . . . the flaps are hitting mechanical stops and stalling the motor . . . Well adjusted limit switches would be a sanitary solution. Bob . . . ________________________________________________________________________________
Date: May 21, 2017
Just an aside but this issue helps justify the decision to make the only CBs in my RV for the AP, the voltage regulator and flaps (none have tripped to date however). Everything else is protected by fuses that I don't intend to 'reset' in the air Bill "keeping the pilot as proficient as the plane is the perpetual challenge" Watson --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: May 22, 2017
First, the flap system in the RV's has a clutch for travel to both ends of travel, so the flap motor never actually goes into a stall condition. The motor current only goes up less than 2 amps over normal ground bases travel currents. Second, aerodynamic pressures on the flaps raise the flap motor current significantly. To the point That a 7 amp fuse or circuit breaker will definitely trip. And from my experiences in multiple RV's I Know that while flying, a trip can happen while extending or retracting the flaps. I strongly suggest that you need to increase the amp rating of your circuit protection to at least 10 amps. If you do that, your problems will go away.. All the planes listed below have had 10 Amp Circuit protections, and did not trip during flight.. Fred Stucklen N924RV 1395 Hrs Flying N926RV 875 Hrs Sold N925RV 2008 Hrs Sold One of my aviator friends called me to help him solving a problem in his RV-7 flaps system. He told me that occasionally, when he retracts the flaps, the correspondent Circuit Breaker trips. But not always, so he resets the CB and the flaps keep working normally. I asked him to measure the current during the flaps movement, and he measured 1 to 2 A when extending and when retracting, but he noticed that after full retraction the current went to 7 A. That explains why the CB (5A) trips. I think most of you know that the flaps system in an RV airplane is powered by an electric motor with 2 wires, which make the flaps work in both senses, just with reversing the electrons movement on those 2 wires. You also probably know that the motor doesn't stop at both ends if you don't release the switch, so the motor keeps turning even when the flaps reach full extension and full retraction. Now the question: which can be the reason for the current peak that the motor is reaching at full retraction? Any help welcome Thanks Carlos ________________________________________________________________________________
Date: May 22, 2017
At 07:28 AM 5/22/2017, you wrote: >First, the flap system in the RV=92s has a clutch >for travel to both ends of travel, so the flap motor never >actually goes into a stall condition. The motor >current only goes up less than 2 amps over normal >ground bases travel currents. I was wondering about that . . . I seemed to recall that the actuator was fitted with ball screws and end-of-travel clutches. But these are effective only if the ball nut reaches end of stroke on the screw before the flap mechanism bottoms out. > >Second, aerodynamic pressures on the flaps raise >the flap motor current significantly. To the point >That a 7 amp fuse or circuit breaker will >definitely trip. And from my experiences in multiple RV=92s I >Know that while flying, a trip can happen while >extending or retracting the flaps. > >I strongly suggest that you need to increase the >amp rating of your circuit protection to at least >10 amps. If you do that, your problems will go >away=85. All the planes listed below have had 10 Amp >Circuit protections, and did not trip during flight=85. > >Fred Stucklen >N924RV 1395 Hrs Flying >N926RV 875 Hrs Sold >N925RV 2008 Hrs Sold Thank you sir . . . good data! Bob . . . ________________________________________________________________________________
Date: May 23, 2017
Subject: Comparison of LED annunciator fixtures
A few days there was some discussion about some off-the-shelf, led annunciator fixtures offered on eBay: I ordered in some of these and found that they were reasonably bright, mechanically rugged with the only down-side being the lack of vibration support on the smash-em terminals at the back. http://tinyurl.com/lpgjdu3 Emacs! Somebody mentioned these: http://tinyurl.com/mw629ow Emacs! I ordered some samples which arrived yesterday. They're certainly good looking and mechanically rugged. They're biased up with a resistor spliced into the pigtails under heat shrink. As received, they're set up to consume less than 10mA at 12-14v. I'm pretty sure these lamps will easily handle 30 mA of excitation which gets you a bit more intensity. These may well be suited to your annunciation task. Consider replacing the existing series resistor with a 330 Ohm, 1/2 watt resistor. Bob . . . ________________________________________________________________________________
Date: May 25, 2017
I removed the LEDs from the circuit, and added new LEDs directly to the board. The behavior is the same as before -- with the engine off, the prop and circuit behaved normally. With the engine running, the prop current is shut down almost immediately, though a small bit of pitch change does occur prior to cut-off. -------- Doug Read this topic online here: http://forums.matronics.com/viewtopic.php?p=469605#469605 ________________________________________________________________________________
Date: May 27, 2017
At 05:36 PM 5/25/2017, you wrote: > >I removed the LEDs from the circuit, and added new LEDs directly to the board. > >The behavior is the same as before -- with the engine off, the prop >and circuit behaved normally. With the engine running, the prop >current is shut down almost immediately, though a small bit of pitch >change does occur prior to cut-off. > >-------- >Doug Need to pray over your observations . . . it would sure be nice to get some measurements . . . but I think I'll have an experiment that will help burrow down to root cause. Bob . . . ________________________________________________________________________________
Date: May 27, 2017
>> >> with the engine off, the prop and circuit behaved normally. With the engine running, the prop current is shut down almost immediately, though a small bit of pitch change does occur prior to cut-off. >> >> -------- >> Doug Could this have something to do with the higher system voltage when the engine is running? =94Daniel ________________________________________________________________________________
Subject: Firewall Forward Connections
Date: May 28, 2017
I am installing several sensors onto my engine (EGT, CHT, Fuel Pressure, Oil pressure and temperature, Manifold pressure, etc.) The CHT sensors came with a ring terminal that had a nut bonded to it. It was actually easy to crimp a ring terminal onto the other wire and screw the two together. The EGT sensor had regular ring terminals but provided screws, nuts and lock washers. All the other sensors have bear wires. As all of these sensors are in areas with high vibration (either directly on the engine, or on the fire wall) I was considering either using the above method of screwing the rings together, butt splicing, or AMP Mate and Locks. Screwing the rings together or using Mate and Locks would be easier, but I think the butt splice would provide a reliable connection. Is there another method that would provide both maintainability and reliable connections in high vibration areas? Neil Rosoff ________________________________________________________________________________
Date: May 28, 2017
Subject: Re: Firewall Forward Connections
At 10:24 PM 5/28/2017, you wrote: >I am installing several sensors onto my engine (EGT, CHT, Fuel >Pressure, Oil pressure and temperature, Manifold pressure, etc.) > >The CHT sensors came with a ring terminal that had a nut bonded to >it. It was actually easy to crimp a ring terminal onto the other >wire and screw the two together. The EGT sensor had regular ring >terminals but provided screws, nuts and lock washers. All the other >sensors have bear wires. > >As all of these sensors are in areas with high vibration (either >directly on the engine, or on the fire wall) I was considering >either using the above method of screwing the rings together, butt >splicing, or AMP Mate and Locks. Screwing the rings together or >using Mate and Locks would be easier, but I think the butt splice >would provide a reliable connection. Consider knife splices under heat-shrink. http://tinyurl.com/y8owslug Bob . . . ________________________________________________________________________________
Date: May 29, 2017
At 11:06 PM 5/27/2017, you wrote: >>>with the engine off, the prop and circuit behaved normally. With >>>the engine running, the prop current is shut down almost >>>immediately, though a small bit of pitch change does occur prior to cut-off. >>> >>>-------- >>>Doug > >Could this have something to do with the higher system voltage when >the engine is running? possibly . . . but I think not. The current limiter is configured to 'latch' into an OFF state approx 200 mS after a current limit on the order of 9A is achieved. The 'latch' is subject to premature triggering if subjected to noise which I suspect is coming from the ship's alternator. Emacs! Doug, Try tacking this combination of components onto your assembly. The experiment is to see if adding a smoothing capacitor to the circuit's power source will sufficiently attenuate the antagonistic energies. The 100 uF cap is the 'smoother' while the 10 ohm resistor mitigates inrush currents impressed on the circuit when the directional control switch closes . . . Bob . . . ________________________________________________________________________________
From: Peter Sokolowski <air.peter(at)googlemail.com>
Subject: Automatic header tank filling
Date: May 30, 2017
Hi, I am flying a Lancair 360 with wing tanks and the standard header tank. Rather thinking every 20 to 30 minutes to fill up the header tank again I would like to have an automatism filling the tank. I have a capacitive fuel gauge (output 0 to 5 V) and an independent emergency reminder looking up at the annunciator panel @ about 5 gallons. Rather re-inventing the wheel - is there a circuit diagram out there I can use for such a fuel filling mimic ? Thanks in advance, Peter LNC 360 MKII D-EPSO ________________________________________________________________________________
Date: May 30, 2017
Subject: Re: Automatic header tank filling
Hi, I am flying a Lancair 360 with wing tanks and the standard header tank. Rather thinking every 20 to 30 minutes to fill up the header tank again I would like to have an automatism filling the tank. I've done a couple of similar systems. Last one was for the Piaggio P-180. I have a capacitive fuel gauge (output 0 to 5 V) and an independent emergency reminder looking up at the annunciator panel @ about 5 gallons. The analog output makes the 'control' easy to do. The dragon to slay is failure mitigation. Any time you add a automatic feature to the airplane, it's wise to assume that it will fail at some point. What are the ways it can fail? How will you become aware of the failure? Is the failure pre-flight detectable? What are plans A, B, etc. for dealing with the failure(s)? You have a low level warning light . . . this should be totally independent of any other function. Suppose the transfer sticks ON and overfills the tank. What happens if the tank is over filled; what happens to excess fuel? Is there a practical way to add a high level warning? Rather re-inventing the wheel ' is there a circuit diagram out there I can use for such a fuel filling mimic ? You can watch the dc voltage from the fuel gage with a comparator that will, for example, turn the transfer ON at 3 volts or below and OFF at 4 volts or above . . . or what ever hysteresis values seem most practical. The existing low level warning backs up a failure to transfer, some kind of high level warning should back of a failure to stop transferring. Bob . . . ________________________________________________________________________________
Date: May 30, 2017
Will do Bob. Thanks! -------- Doug Read this topic online here: http://forums.matronics.com/viewtopic.php?p=469718#469718 ________________________________________________________________________________
From: "William Hunter" <billhuntersemail(at)gmail.com>
Subject: Dsub Connector Shell With Female Threaded
Date: May 30, 2017
Hi All, I have a couple of instances where I need to mate a male Dsub to a female Dsub end to end within the length of a wire bundle (example: connect the under panel wire harness to the wire harness of the control stick). I already have the male and female Dsub connectors wired up and they are connected end to end and I have the plastic shells (see below) however the metal screws of the one shell needs to screw into a threaded bore of the other connector so that the two connectors do not disconnect. Kinda like when you attach the Dsub connector to the back of a computer the plug slides into the receptacle and then the screws on the connector shell thread into the threaded bore of the computer case. How does one (me) do this on an end to end connector? .. Cheers!!! Bill Hunter ________________________________________________________________________________
Date: May 30, 2017
Subject: Re: Dsub Connector Shell With Female Threaded
multiple ways to to this 1 buy one connector with built in nuts (Stein has these) 2 remove screws and use zip ties to hold the connectors together. On May 30, 2017 19:56, "William Hunter" wrote: > Hi All, > > > I have a couple of instances where I need to mate a male Dsub to a female > Dsub end to end within the length of a wire bundle (example: connect the > under panel wire harness to the wire harness of the control stick). > > > I already have the male and female Dsub connectors wired up and they are > connected end to end and I have the plastic shells (see below) however the > metal screws of the one shell needs to screw into a threaded bore of the > other connector so that the two connectors do not disconnect. Kinda like > when you attach the Dsub connector to the back of a computer the plug > slides into the receptacle and then the screws on the connector shell > thread into the threaded bore of the computer case. > > > How does one (me) do this on an end to end connector? > > > [image: > http://www.steinair.com/wp-content/uploads/2016/03/SA-1030-BACKSHELL-DSUB15-L-DSC09853.jpg] > > > .. > > > Cheers!!! > > > Bill Hunter > > ________________________________________________________________________________
Date: May 30, 2017
I think you want something like this female screw kit: http://www.mouser.com/search/ProductDetail.aspx?qs=5KjJMQyy%252baNdw8WXW xtgeQ%3d%3d <http://www.mouser.com/search/ProductDetail.aspx?qs=5KjJMQyy%2baNdw8WXWx tgeQ==> It attaches to the contact portion before you install the back shell. Each one should contain a kit for one connector pair, and you can just use the provided male threaded hardware with the other one. Be careful to either tighten the female nuts adequately or use some Loctite to keep the nuts from falling out if you ever need to separate the two connectors. Here is a similar part from SteinAir http://www.steinair.com/product/dsub-nut-pack-4-40-thread-size/ <http://www.steinair.com/product/dsub-nut-pack-4-40-thread-size/> or you can also buy one with built in female lugs like this: http://www.steinair.com/product/9-pin-male-dsub-connector-with-4-40-lugs/ <http://www.steinair.com/product/9-pin-male-dsub-connector-with-4-40-lugs/ > These last ones are nice because you never have to worry about the lugs backing out when you take the connectors apart! > On May 30, 2017, at 9:49 PM, William Hunter wrote: > > Hi All, > > I have a couple of instances where I need to mate a male Dsub to a female Dsub end to end within the length of a wire bundle (example: connect the under panel wire harness to the wire harness of the control stick). > > I already have the male and female Dsub connectors wired up and they are connected end to end and I have the plastic shells (see below) however the metal screws of the one shell needs to screw into a threaded bore of the other connector so that the two connectors do not disconnect. Kinda like when you attach the Dsub connector to the back of a computer the plug slides into the receptacle and then the screws on the connector shell thread into the threaded bore of the computer case. > > How does one (me) do this on an end to end connector? > > > > > .. > > Cheers!!! > > Bill Hunter ________________________________________________________________________________
Date: May 30, 2017
Bill, I hate those screws. I have seen barrel connectors which are female on both ends, stuck between two D-sub shells. They require having a screwdriver on both ends, Pain-in-the-a**. I am planning to use a pair a zip ties in a X in the places where I have D-sub connectors in my plane. I would rather cut and replace the zip ties than mess around with the screws. I will be really interested to see if anyone has better ideas. -- Art Z. On Tue, May 30, 2017 at 9:49 PM, William Hunter wrote: > Hi All, > > > I have a couple of instances where I need to mate a male Dsub to a female > Dsub end to end within the length of a wire bundle (example: connect the > under panel wire harness to the wire harness of the control stick). > > > I already have the male and female Dsub connectors wired up and they are > connected end to end and I have the plastic shells (see below) however the > metal screws of the one shell needs to screw into a threaded bore of the > other connector so that the two connectors do not disconnect. Kinda like > when you attach the Dsub connector to the back of a computer the plug > slides into the receptacle and then the screws on the connector shell > thread into the threaded bore of the computer case. > > > How does one (me) do this on an end to end connector? > > > [image: > http://www.steinair.com/wp-content/uploads/2016/03/SA-1030-BACKSHELL-DSUB15-L-DSC09853.jpg] > > > .. > > > Cheers!!! > > > Bill Hunter > > -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Date: May 31, 2017
Thanks Bob for the answer. I agree with you that adding complexity/automatism adds possible failures to the ac. And yes, I am aware that it may fail and thinking about backups like my - already independent - low level warning light. In addition I already installed an aviation approved switch with which I can select manually between automatic and manual filling. Also there is a drain (standard for Lancair header tanks) in case you overfill - it just goes overboard. Would you mind sharing the schematic you already invented ? Thanks in advance, Peter LNC360 MK II D-EPSO Von: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] Im Auftrag von Robert L. Nuckolls, III Gesendet: Dienstag, 30. Mai 2017 20:04 An: aeroelectric-list(at)matronics.com Betreff: Re: AeroElectric-List: Automatic header tank filling Hi, I am flying a Lancair 360 with wing tanks and the standard header tank. Rather thinking every 20 to 30 minutes to fill up the header tank again I would like to have an automatism filling the tank. I've done a couple of similar systems. Last one was for the Piaggio P-180. I have a capacitive fuel gauge (output 0 to 5 V) and an independent emergency reminder looking up at the annunciator panel @ about 5 gallons. The analog output makes the 'control' easy to do. The dragon to slay is failure mitigation. Any time you add a automatic feature to the airplane, it's wise to assume that it will fail at some point. What are the ways it can fail? How will you become aware of the failure? Is the failure pre-flight detectable? What are plans A, B, etc. for dealing with the failure(s)? You have a low level warning light . . . this should be totally independent of any other function. Suppose the transfer sticks ON and overfills the tank. What happens if the tank is over filled; what happens to excess fuel? Is there a practical way to add a high level warning? Rather re-inventing the wheel - is there a circuit diagram out there I can use for such a fuel filling mimic ? You can watch the dc voltage from the fuel gage with a comparator that will, for example, turn the transfer ON at 3 volts or below and OFF at 4 volts or above . . . or what ever hysteresis values seem most practical. The existing low level warning backs up a failure to transfer, some kind of high level warning should back of a failure to stop transferring. Bob . . . ________________________________________________________________________________
Date: May 31, 2017
Google 'dsub latch'. There are several different options for joining dsubs in-line; screws, sliding latches, and spring bales. My favorite style: http://www.newark.com/cooper-interconnect/17-529/d-sub-spring-latch/dp/39F1 390?mckv=sPyr8IJjG_dc|pcrid|81605889141|plid||kword||match||slid||product |39F1390|&gross_price=true&CATCI=pla-164504983461&CAAGID 389674261& CMP=KNC-GUSA-GEN-SHOPPING-39F1390&CAGPSPN=pla&gclid=CjwKEAjw07nJBRDG_ tvshefHhWQSJABRcE-ZuxQrtf1Qi0xFg5ATYZXSW2anCtcB-ENzwuu27bdAVhoC_Jfw_wcB&CAW ELAID=120185550001138611 More positive security than screws, because it can't loosen with vibration. The same latch can be used on chassis mounted connectors, too, as long as the designer left enough room around the connector to add the springs. (Can you hear me, Advanced Flight Systems?) Charlie On Tue, May 30, 2017 at 10:43 PM, Art Zemon wrote: > Bill, > > I hate those screws. I have seen barrel connectors which are female on > both ends, stuck between two D-sub shells. They require having a > screwdriver on both ends, Pain-in-the-a**. > > I am planning to use a pair a zip ties in a X in the places where I have > D-sub connectors in my plane. I would rather cut and replace the zip ties > than mess around with the screws. > > I will be really interested to see if anyone has better ideas. > > -- Art Z. > > > On Tue, May 30, 2017 at 9:49 PM, William Hunter < > billhuntersemail(at)gmail.com> wrote: > >> Hi All, >> >> >> >> I have a couple of instances where I need to mate a male Dsub to a femal e >> Dsub end to end within the length of a wire bundle (example: connect the >> under panel wire harness to the wire harness of the control stick). >> >> >> >> I already have the male and female Dsub connectors wired up and they are >> connected end to end and I have the plastic shells (see below) however t he >> metal screws of the one shell needs to screw into a threaded bore of the >> other connector so that the two connectors do not disconnect. Kinda lik e >> when you attach the Dsub connector to the back of a computer the plug >> slides into the receptacle and then the screws on the connector shell >> thread into the threaded bore of the computer case. >> >> >> >> How does one (me) do this on an end to end connector? >> >> >> >> >> >> [image: >> http://www.steinair.com/wp-content/uploads/2016/03/SA-1030-BACKSHELL-DSU B15-L-DSC09853.jpg] >> >> >> >> .. >> >> >> >> Cheers!!! >> >> >> >> Bill Hunter >> >> >> >> >> >> >> >> >> > > > -- > https://CheerfulCurmudgeon.com/ > > *"If I am not for myself, who is for me? And if I am only for myself, wha t > am I? And if not now, when?" Hillel* > ________________________________________________________________________________
Date: May 31, 2017
On Tue, May 30, 2017 at 1:03 PM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > Hi, > > I am flying a Lancair 360 with wing tanks and the standard header tank. > Rather thinking every 20 to 30 minutes to fill up the header tank again I > would like to have an automatism filling the tank. > > I've done a couple of similar systems. Last > one was for the Piaggio P-180. > > I have a capacitive fuel gauge (output 0 to 5 V) and an independent > emergency reminder looking up at the annunciator panel @ about 5 gallons. > > The analog output makes the 'control' easy to do. > The dragon to slay is failure mitigation. > Any time you add a automatic feature to the > airplane, it's wise to assume that it will > fail at some point. > > What are the ways it can fail? How will you > become aware of the failure? Is the failure > pre-flight detectable? What are plans A, B, etc. > for dealing with the failure(s)? > > You have a low level warning light . . . this should > be totally independent of any other function. > Suppose the transfer sticks ON and overfills the > tank. What happens if the tank is over filled; > what happens to excess fuel? Is there a practical > way to add a high level warning? > > Rather re-inventing the wheel =93 is there a circuit diagram out th ere I can > use for such a fuel filling mimic ? > > You can watch the dc voltage from the > fuel gage with a comparator that will, > for example, turn the transfer ON at > 3 volts or below and OFF at 4 volts or > above . . . or what ever hysteresis values > seem most practical. > > The existing low level warning backs up > a failure to transfer, some kind of high > level warning should back of a failure to > stop transferring. > > > Bob . . . > "Suppose the transfer sticks ON and overfills the tank. What happens if the tank is over filled; what happens to excess fuel? Is there a practical way to add a high level warning?" The additional issue I never considered (but a research scientist friend who tests *everything*, did), was what happens to the *tank*. If you have a typical vent system using -4 (1/4" OD) tubing, when fuel hits the vent, the transfer pump can cause pressures in the tank to reach 10 psi. In case you don't know, more than about 2 psi will damage most a/c fuel tanks in planes like most of us fly. Dilemma: positive protection from overfilling that can't fail and prevent transfer. Secondary dilemma, when using auto-transfer: Especially if there's more than one aux tank, preventing the transfer pump from running (and destroying itself) when pumping from an empty tank. ________________________________________________________________________________
From: William Hunter <billhuntersemail(at)gmail.com>
Date: May 31, 2017
Thanks everyone for the advice... I came to the right place. Bill Hunter On May 31, 2017 5:40 AM, "Charlie England" wrote: > Google 'dsub latch'. There are several different options for joining dsubs > in-line; screws, sliding latches, and spring bales. My favorite style: > http://www.newark.com/cooper-interconnect/17-529/d-sub- > spring-latch/dp/39F1390?mckv=sPyr8IJjG_dc|pcrid|81605889141|plid||kword|| > match||slid||product|39F1390|&gross_price=true&CATCI=pla- > 164504983461&CAAGID 389674261&CMP=KNC-GUSA-GEN- > SHOPPING-39F1390&CAGPSPN=pla&gclid=CjwKEAjw07nJBRDG_tvshefHhWQSJABRcE- > ZuxQrtf1Qi0xFg5ATYZXSW2anCtcB-ENzwuu27bdAVhoC_Jfw_wcB& > CAWELAID=120185550001138611 > > More positive security than screws, because it can't loosen with > vibration. The same latch can be used on chassis mounted connectors, too, > as long as the designer left enough room around the connector to add the > springs. (Can you hear me, Advanced Flight Systems?) > > Charlie > > On Tue, May 30, 2017 at 10:43 PM, Art Zemon wrote: > >> Bill, >> >> I hate those screws. I have seen barrel connectors which are female on >> both ends, stuck between two D-sub shells. They require having a >> screwdriver on both ends, Pain-in-the-a**. >> >> I am planning to use a pair a zip ties in a X in the places where I have >> D-sub connectors in my plane. I would rather cut and replace the zip ties >> than mess around with the screws. >> >> I will be really interested to see if anyone has better ideas. >> >> -- Art Z. >> >> >> On Tue, May 30, 2017 at 9:49 PM, William Hunter < >> billhuntersemail(at)gmail.com> wrote: >> >>> Hi All, >>> >>> >>> >>> I have a couple of instances where I need to mate a male Dsub to a >>> female Dsub end to end within the length of a wire bundle (example: connect >>> the under panel wire harness to the wire harness of the control stick). >>> >>> >>> >>> I already have the male and female Dsub connectors wired up and they are >>> connected end to end and I have the plastic shells (see below) however the >>> metal screws of the one shell needs to screw into a threaded bore of the >>> other connector so that the two connectors do not disconnect. Kinda like >>> when you attach the Dsub connector to the back of a computer the plug >>> slides into the receptacle and then the screws on the connector shell >>> thread into the threaded bore of the computer case. >>> >>> >>> >>> How does one (me) do this on an end to end connector? >>> >>> >>> >>> >>> >>> [image: >>> http://www.steinair.com/wp-content/uploads/2016/03/SA-1030-BACKSHELL-DSUB15-L-DSC09853.jpg] >>> >>> >>> >>> .. >>> >>> >>> >>> Cheers!!! >>> >>> >>> >>> Bill Hunter >>> >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> -- >> https://CheerfulCurmudgeon.com/ >> >> *"If I am not for myself, who is for me? And if I am only for myself, >> what am I? And if not now, when?" Hillel* >> > > ________________________________________________________________________________
Subject: Can Westach Use 5VDC?
Date: May 31, 2017
I have two Westack capacitance fuel probes and I would like to power them from PIN 18 of the Dynon Skyview. That pin is a 5 VDC output and the only other item that this pin will power is a Grand Rapids CS-02 Hall Effect Sensor. Any experience would be most appreciated!!! .. Cheers!!! Bill Hunter ________________________________________________________________________________
Subject: Re: Can Westach Use 5VDC?
Date: Jun 01, 2017
From the specifications it doesn't appear you can use 5V to power these probes. They are specified 12/24V (28V max), with the output being 0-5V. You should power them from the main bus, or (if your Skyview installation manual lists it), to the +12V Auxiliary Output pin (pin 15 of the 37-pin connector). Not all SkyView systems appear to have that pin so double check. On 6/1/2017 1:33 AM, William Hunter wrote: > > I have two Westack capacitance fuel probes and I would like to power > them from PIN 18 of the Dynon Skyview. That pin is a 5 VDC output and > the only other item that this pin will power is a Grand Rapids CS-02 > Hall Effect Sensor. > > Any experience would be most appreciated!!! > > .. > > Cheers!!! > > Bill Hunter > ________________________________________________________________________________
Date: Jun 01, 2017
Easier link: https://tinyurl.com/y9mhl2j5 [Wink] ceengland7(at)gmail.com wrote: > My favorite style:http://www.newark.com/cooper-interconnect/17-529/d-sub-spring-latch/dp/39F1390?mckv=sPyr8IJjG_dc|pcrid|81605889141|plid||kword||match||slid||product|39F1390|&gross_price=true&CATCI=pla-164504983461&CAAGID 389674261&CMP=KNC-GUSA-GEN-SHOPPING-39F1390&CAGPSPN=pla&gclid=CjwKEAjw07nJBRDG_tvshefHhWQSJABRcE-ZuxQrtf1Qi0xFg5ATYZXSW2anCtcB-ENzwuu27bdAVhoC_Jfw_wcB&CAWELAID=120185550001138611 (http://www.newark.com/cooper-interconnect/17-529/d-sub-spring-latch/dp/39F1390?mckv=sPyr8IJjG_dc|pcrid|81605889141|plid||kword||match||slid||product|39F1390|&gross_price=true&CATCI=pla-164504983461&CAAGID 389674261&CMP=KNC-GUSA-GEN-SHOPPING-39F1390&CAGPSPN=pla&gclid=CjwKEAjw07nJBRDG_tvshefHhWQSJABRcE-ZuxQrtf1Qi0xFg5ATYZXSW2anCtcB-ENzwuu27bdAVhoC_Jfw_wcB&CAWELAID=120185550001138611) > Read this topic online here: http://forums.matronics.com/viewtopic.php?p=469769#469769 ________________________________________________________________________________
Date: Jun 01, 2017
Which buries the destination, so you don't know where you're going when you click it. :-0 On 6/1/2017 9:28 AM, donjohnston wrote: > > Easier link: > https://tinyurl.com/y9mhl2j5 > > [Wink] > > > ceengland7(at)gmail.com wrote: >> My favorite style:http://www.newark.com/cooper-interconnect/17-529/d-sub-spring-latch/dp/39F1390?mckv=sPyr8IJjG_dc|pcrid|81605889141|plid||kword||match||slid||product|39F1390|&gross_price=true&CATCI=pla-164504983461&CAAGID 389674261&CMP=KNC-GUSA-GEN-SHOPPING-39F1390&CAGPSPN=pla&gclid=CjwKEAjw07nJBRDG_tvshefHhWQSJABRcE-ZuxQrtf1Qi0xFg5ATYZXSW2anCtcB-ENzwuu27bdAVhoC_Jfw_wcB&CAWELAID=120185550001138611 (http://www.newark.com/cooper-interconnect/17-529/d-sub-spring-latch/dp/39F1390?mckv=sPyr8IJjG_dc|pcrid|81605889141|plid||kword||match||slid||product|39F1390|&gross_price=true&CATCI=pla-164504983461&CAAGID 389674261&CMP=KNC-GUSA-GEN-SHOPPING-39F1390&CAGPSPN=pla&gclid=CjwKEAjw07nJBRDG_tvshefHhWQSJABRcE-ZuxQrtf1Qi0xFg5ATYZXSW2anCtcB-ENzwuu27bdAVhoC_Jfw_wcB&CAWELAID=120185550001138611) >> > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jun 02, 2017
> >Also there is a drain (standard for Lancair >header tanks) in case you overfill ' it just goes overboard. > >Would you mind sharing the schematic you already invented ? > >Thanks in advance, > >Peter Actually, the systems I've already developed are not applicable to your task . . . but it's not difficult to sketch out a suitable alternative. I've got a deck project in Wichita that is soaking up some prime-time energies . . . but I'll get it posted Sunday. Bob . . . ________________________________________________________________________________
Date: Jun 03, 2017
Not really. I just made a clickable link from your URL. So the destination is newark.com. Trying to copy/paste that long URL with a phone or tablet is a pain. But hey, whatever stirs your grits. ceengland7(at)gmail.com wrote: > Which buries the destination, so you don't know where you're going when > you click it. > :-0 > > On 6/1/2017 9:28 AM, donjohnston wrote: > > > > > > > Easier link: > > https://tinyurl.com/y9mhl2j5 > > > > [Wink] > > > > > > ceengland7(at)gmail.com wrote: > > > My favorite style:http://www.newark.com/cooper-interconnect/17-529/d-sub-spring-latch/dp/39F1390?mckv=sPyr8IJjG_dc|pcrid|81605889141|plid||kword||match||slid||product|39F1390|&gross_price=true&CATCI=pla-164504983461&CAAGID 389674261&CMP=KNC-GUSA-GEN-SHOPPING-39F1390&CAGPSPN=pla&gclid=CjwKEAjw07nJBRDG_tvshefHhWQSJABRcE-ZuxQrtf1Qi0xFg5ATYZXSW2anCtcB-ENzwuu27bdAVhoC_Jfw_wcB&CAWELAID=120185550001138611 (http://www.newark.com/cooper-interconnect/17-529/d-sub-spring-latch/dp/39F1390?mckv=sPyr8IJjG_dc|pcrid|81605889141|plid||kword||match||slid||product|39F1390|&gross_price=true&CATCI=pla-164504983461&CAAGID 389674261&CMP=KNC-GUSA-GEN-SHOPPING-39F1390&CAGPSPN=pla&gclid=CjwKEAjw07nJBRDG_tvshefHhWQSJABRcE-ZuxQrtf1Qi0xFg5ATYZXSW2anCtcB-ENzwuu27bdAVhoC_Jfw_wcB&CAWELAID=120185550001138611) > > > > > > > > > > Read this topic online here: http://forums.matronics.com/viewtopic.php?p=469813#469813 ________________________________________________________________________________
Date: Jun 03, 2017
More to the point, you can win a free glass panel for your airplane by going here: http://bit.ly/2lHA1xP > On Jun 3, 2017, at 5:54 PM, donjohnston <don@velocity-xl.com> wrote: > <don@velocity-xl.com> > > Not really. I just made a clickable link from your URL. So the destination is newark.com. > > Trying to copy/paste that long URL with a phone or tablet is a pain. > > But hey, whatever stirs your grits. > > > > ceengland7(at)gmail.com wrote: >> Which buries the destination, so you don't know where you're going when >> you click it. >> :-0 >> >> On 6/1/2017 9:28 AM, donjohnston wrote: >> >>> >>> >>> Easier link: >>> https://tinyurl.com/y9mhl2j5 >>> >>> [Wink] >>> >>> >>> ceengland7(at)gmail.com wrote: >>>> My favorite style:http://www.newark.com/cooper-interconnect/17-529/d-sub-spring-latch/ dp/39F1390?mckv=sPyr8IJjG_dc|pcrid|81605889141|plid||kword||match||slid| |product|39F1390|&gross_price=true&CATCI=pla-164504983461&CAAGID 389674261&CMP=KNC-GUSA-GEN-SHOPPING-39F1390&CAGPSPN=pla&gclid=CjwKEA jw07nJBRDG_tvshefHhWQSJABRcE-ZuxQrtf1Qi0xFg5ATYZXSW2anCtcB-ENzwuu27bdAVhoC _Jfw_wcB&CAWELAID=120185550001138611 (http://www.newark.com/cooper-interconnect/17-529/d-sub-spring-latch/dp/39 F1390?mckv=sPyr8IJjG_dc|pcrid|81605889141|plid||kword||match||slid||prod uct|39F1390|&gross_price=true&CATCI=pla-164504983461&CAAGID 389674261&CMP=KNC-GUSA-GEN-SHOPPING-39F1390&CAGPSPN=pla&gclid=CjwKEA jw07nJBRDG_tvshefHhWQSJABRcE-ZuxQrtf1Qi0xFg5ATYZXSW2anCtcB-ENzwuu27bdAVhoC _Jfw_wcB&CAWELAID=120185550001138611) >>>> >>> >>> >>> >> > > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=469813#469813 > > > > > > > > > ________________________________________________________________________________
Date: Jun 03, 2017
I think his point is that the Tinyurl link obfuscates the destination that you'll reach when you click it. It might be benign, or it might not. Many people, myself included, will not click a link without knowing what's likely to be at the other end of the DNS rabbit hole. Tinyurl provides the option of using preview links that begin with preview.tinyurl.com. Those links take you to the tinyurl website where you can see the full un-shortened URL and decide whether you want to go further. Very handy for posting in forums like this one. Eric > On Jun 3, 2017, at 5:54 PM, donjohnston <don@velocity-xl.com> wrote: > > Not really. I just made a clickable link from your URL. So the destination is newark.com. ________________________________________________________________________________
Date: Jun 03, 2017
And since we know each other personally, and I know for sure that the post came directly from you, and I totally trust that any link I click on will not try to attack my computer..... I know what you did. The problem with those shortened links is that if you hover over them to see the destination, it only shows the short-link provider; not the actual destination site. So you don't know until you get there what site you're actually visiting. Not sure why you're having to copy/paste. All the phones/tablets I've used (both ios & android) allow you to just click on the hyperlink in the email client to open the page in the device's browser. Charlie On 6/3/2017 5:54 PM, donjohnston wrote: > > Not really. I just made a clickable link from your URL. So the destination is newark.com. > > Trying to copy/paste that long URL with a phone or tablet is a pain. > > But hey, whatever stirs your grits. > > > ceengland7(at)gmail.com wrote: >> Which buries the destination, so you don't know where you're going when >> you click it. >> :-0 >> >> On 6/1/2017 9:28 AM, donjohnston wrote: >> >>> >>> >>> Easier link: >>> https://tinyurl.com/y9mhl2j5 >>> >>> [Wink] >>> --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jun 03, 2017
Nor do I. My apologies if my attempt to help offended anyone or caused any problems. I shall show myself out now. ceengland7(at)gmail.com wrote: > Not sure why you're having to copy/paste. All the phones/tablets I've used (both ios & android) allow you to just click on the hyperlink in the email client to open the page in the device's browser. > > Charlie > Read this topic online here: http://forums.matronics.com/viewtopic.php?p=469817#469817 Attachments: http://forums.matronics.com//files/screen_grab_200.jpg ________________________________________________________________________________
Subject: no messages since May23
Date: Jun 04, 2017
Concurring with retasker - "this is just a test message" (read via the BBS forum interface): no messages received since May 23; same for Europa list and RotaxEngines list. ________________________________________________________________________________
Subject: Re: no messages since May23
Date: Jun 04, 2017
I'm seeing 29 messages since 23rd. Something is wrong on your end? On 6/4/2017 10:20 AM, Jan de Jong wrote: > > > Concurring with retasker - "this is just a test message" (read via the > BBS forum interface): no messages received since May 23; > same for Europa list and RotaxEngines list. ________________________________________________________________________________
Date: Jun 04, 2017
At 09:01 PM 6/2/2017, you wrote: >> >>Also there is a drain (standard for Lancair >>header tanks) in case you overfill ' it just goes overboard. >> >>Would you mind sharing the schematic you already invented ? >> >>Thanks in advance, >> >>Peter > > Here's a couple of approaches to a fuel transfer controller applicable to your project. http://tinyurl.com/yc4754vw The first page shows ship's wiring for power, switch, relay, pump and over-fill warning light. The second page illustrates a micro-controller based control module. Input signal voltage from the fuel gate is watched. The pump and warning light are activated based on numbers stored in the uC memory at the time software is loaded to the controller. This is the lowest parts count approach and very compact. All the electronics would fit into the backshell of a 15-pin d-sub connector. The third page illustrates an analog comparator approach to the same task. Potentiometers allow you to 'tune' the switch points for pump operation and illumination of the warning light. In both cases, the warning light can be left out if deemed unnecessary. Page 3 lends itself to a DIY approach. If fuel gage voltages are known, the uC approach would also work as a DIY project. We can supply the uC with the target voltages in situ. Those values are easily altered as experience dictates. Just order up another chip with revised calibration. The 'bad' chip isn't even worth returning . . . they're about 80 cents. Bob . . . ________________________________________________________________________________
Date: Jun 04, 2017
Same here. I've been subscribed to the digest emails and I haven't gotten anything for a week or two. Not certain of the exact date they stopped. I've unsubscribed and re-subscribed and no joy. Sent Matt an email yesterday but since its a weekend and this is not exactly an urgent matter i'm not expecting a response until later this week. Glad for the forums to get my daily electron fix. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=469821#469821 ________________________________________________________________________________
Date: Jun 04, 2017
On 6/4/2017 9:43 AM, rvtach wrote: > > Same here. I've been subscribed to the digest emails and I haven't gotten anything for a week or two. Not certain of the exact date they stopped. I've unsubscribed and re-subscribed and no joy. Sent Matt an email yesterday but since its a weekend and this is not exactly an urgent matter i'm not expecting a response until later this week. Glad for the forums to get my daily electron fix. > Have y'all checked your spam/junk folders? I just found your message, and several others related to not getting emails in my spam folder. --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jun 04, 2017
I did look in my other email folders and the Matronics emails are not there. I did get confirmation emails in my in-box when I unsubscribed and then re-subscribed. > On Jun 4, 2017, at 8:09 AM, Charlie England wrote: > > On 6/4/2017 9:43 AM, rvtach wrote: >> >> Same here. I've been subscribed to the digest emails and I haven't gotten anything for a week or two. Not certain of the exact date they stopped. I've unsubscribed and re-subscribed and no joy. Sent Matt an email yesterday but since its a weekend and this is not exactly an urgent matter i'm not expecting a response until later this week. Glad for the forums to get my daily electron fix. >> > Have y'all checked your spam/junk folders? I just found your message, and several others related to not getting emails in my spam folder. > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > ________________________________________________________________________________
Date: Jun 04, 2017
That surprises me. Even in my high wing aircraft the header tank vents back to a main tank in the wing Ken On 04/06/2017 9:21 AM, Robert L. Nuckolls, III wrote: > At 09:01 PM 6/2/2017, you wrote: >>> >>> Also there is a drain (standard for Lancair header tanks) in case >>> you overfill it just goes overboard. >>> >>> Would you mind sharing the schematic you already invented ? >>> >>> Thanks in advance, >>> >>> Peter >> > > Here's a couple of approaches to a fuel > transfer controller applicable to your > project. > > http://tinyurl.com/yc4754vw > > The first page shows ship's wiring for > power, switch, relay, pump and over-fill > warning light. > > The second page illustrates a micro-controller > based control module. Input signal voltage > from the fuel gate is watched. The pump and > warning light are activated based on numbers > stored in the uC memory at the time software > is loaded to the controller. This is the > lowest parts count approach and very compact. > All the electronics would fit into the backshell > of a 15-pin d-sub connector. > > The third page illustrates an analog comparator > approach to the same task. Potentiometers allow > you to 'tune' the switch points for pump operation > and illumination of the warning light. > > In both cases, the warning light can be left > out if deemed unnecessary. Page 3 lends itself > to a DIY approach. If fuel gage voltages are > known, the uC approach would also work as a DIY > project. We can supply the uC with the target > voltages in situ. Those values are easily altered > as experience dictates. Just order up another chip > with revised calibration. The 'bad' chip isn't even > worth returning . . . they're about 80 cents. > > > Bob . . . > ________________________________________________________________________________
Date: Jun 05, 2017
Thanks Bob, I will go first with the analog comparator approach - having the relevant voltages confirmed I will get the c ordered. BTW - what would be the price ? Looking on the schematic - at least to the comparator one - there is no hysteresis - right ? Iaw - the pump runs "all the time" the full limit is not reached. Will the c one have such a hysteresis in the SW ? Br Peter -----Ursprngliche Nachricht----- Von: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] Im Auftrag von C&K Gesendet: Sonntag, 4. Juni 2017 18:18 An: aeroelectric-list(at)matronics.com Betreff: Re: AW: AeroElectric-List: Automatic header tank filling That surprises me. Even in my high wing aircraft the header tank vents back to a main tank in the wing Ken On 04/06/2017 9:21 AM, Robert L. Nuckolls, III wrote: > At 09:01 PM 6/2/2017, you wrote: >>> >>> Also there is a drain (standard for Lancair header tanks) in case >>> you overfill it just goes overboard. >>> >>> Would you mind sharing the schematic you already invented ? >>> >>> Thanks in advance, >>> >>> Peter >> > > Here's a couple of approaches to a fuel > transfer controller applicable to your > project. > > http://tinyurl.com/yc4754vw > > The first page shows ship's wiring for > power, switch, relay, pump and over-fill > warning light. > > The second page illustrates a micro-controller > based control module. Input signal voltage > from the fuel gate is watched. The pump and > warning light are activated based on numbers > stored in the uC memory at the time software > is loaded to the controller. This is the > lowest parts count approach and very compact. > All the electronics would fit into the backshell > of a 15-pin d-sub connector. > > The third page illustrates an analog comparator > approach to the same task. Potentiometers allow > you to 'tune' the switch points for pump operation > and illumination of the warning light. > > In both cases, the warning light can be left > out if deemed unnecessary. Page 3 lends itself > to a DIY approach. If fuel gage voltages are > known, the uC approach would also work as a DIY > project. We can supply the uC with the target > voltages in situ. Those values are easily altered > as experience dictates. Just order up another chip > with revised calibration. The 'bad' chip isn't even > worth returning . . . they're about 80 cents. > > > Bob . . . > ________________________________________________________________________________
Subject: Re: AW: AW: Automatic header tank filling
From: "nuckollsr" <bob.nuckolls(at)aeroelectric.com>
Date: Jun 05, 2017
You can have the uC . . . need feedback on your success/problems. There is hysteresis on both comparators. Those values are not calculated . . . I can expand on that now that I know which way you want to go. It would help to know the target switching voltages . . . does your cap-fuel gage span 0-5 volts for empty-full? That uC version is compatible with my 'do-lots' board layout designed to fit into the d-sub back shell. http://www.aeroelectric.com/Catalog/AEC/9024/9024_FOOTPRINT.pdf So once you've deduce the voltages for fill and overfill, we'll be able to supply a ready-to-install control module . . . you can be the beta-test airframe. My office computer boot-drive went TU this morning. I'm scrambling around to be a new drive installed . . . old COA is illegible . . . will have to order a new one off eBay . . . at the same time, Nvidia ap on Dr. Dee's computer refuses to talk to the third monitor . . . #$%#$*!!! . . . ain't 'lectronics wunderful? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=469830#469830 ________________________________________________________________________________
Subject: Schematic Diagram Software
Date: Jun 05, 2017
I'm making some changes to the wiring in my Zenith 601HD, so need to update the schematic diagram, which is similar to those in the back of the Aeroelectric book. I have a .sch file, created in 2007, that contains the original schematic diagram. Unfortunately, after two changes of computers, the application that created that file has been lost. What's worse, I don't remember the name of that application. I've looked online for appropriate applications, and even tried a few of them (e.g., KiCAD, EAGLE), but none of them recognizes the file. Can anybody give me any pointers? Thanks very much. Bill ________________________________________________________________________________
Date: Jun 05, 2017
Subject: Re: Schematic Diagram Software
At 07:06 PM 6/5/2017, you wrote: > >I'm making some changes to the wiring in my Zenith 601HD, so need to >update the schematic diagram, which is similar to those in the back >of the Aeroelectric book. I have a .sch file, created in 2007, that >contains the original schematic diagram. Unfortunately, after two >changes of computers, the application that created that file has >been lost. What's worse, I don't remember the name of that application. > >I've looked online for appropriate applications, and even tried a >few of them (e.g., KiCAD, EAGLE), but none of them recognizes the file. > >Can anybody give me any pointers? Thanks very much. I think the .sch extension is unique to ExperessPCB software. https://www.expresspcb.com/free-cad-software/ Bob . . . ________________________________________________________________________________
Date: Jun 06, 2017
There's another schematic drawing program using .sch as extension. Abacom sPlan: http://www.abacom-online.de/uk/html/produkte.html On 6/6/2017 3:05 AM, Robert L. Nuckolls, III wrote: > At 07:06 PM 6/5/2017, you wrote: >> >> >> I'm making some changes to the wiring in my Zenith 601HD, so need to >> update the schematic diagram, which is similar to those in the back >> of the Aeroelectric book. I have a .sch file, created in 2007, that >> contains the original schematic diagram. Unfortunately, after two >> changes of computers, the application that created that file has been >> lost. What's worse, I don't remember the name of that application. >> >> I've looked online for appropriate applications, and even tried a few >> of them (e.g., KiCAD, EAGLE), but none of them recognizes the file. >> >> Can anybody give me any pointers? Thanks very much. > > I think the .sch extension is unique to > ExperessPCB software. > > > https://www.expresspcb.com/free-cad-software/ > > > > > Bob . . . > ________________________________________________________________________________
Date: Jun 07, 2017
Subject: SL-70 Install /Configuration issues -> Installation
Manual Working on an installation/configuration issue related to my SL-70. The latest Installation Manual I have is dated October 1999 and does not reference how to enable the EXTended mode or that it is available. It is available in the software in my SL-70 and I have been provided instructions to successfully enable the EXTended mode - but I would like to know if there are any other differences outlined in a later manual. Software currently in the SL-70 is MICR 015 and FPGA 1.1 from the set-up screen and offers the EXTended mode option in the configuration. Does anyone out there have a later version of the SL-70 Installation Manual? I want to make sure it is working properly while helping my ADSB equipment vendor! The SL-70 Installation Manual references the Altitude message only. I have the SL-70R manual dated September 2003 and there are enough differences that I am confident it does NOT fully apply to the SL-70! The SL-70R Installation Manual references the EXTended mode and "Mode" messages that are transmitted when the EXTended mode is enabled...hopefully, this info is also present in a later version of the SL-70 Installation Manual. Does anyone out there know how to 'capture' the RS-232 data as it is transmitted from the SL-70 in a readable format? I have a serial port on my computer connected to the TX pin from the SL-70 and set to 1200, 8, 1, N in HYPERTERM (old Windows software). It does capture the 'bursts' of data but the results are unintelligible on the software screen. The SL-70 Install Manual gives me a good idea about what I 'should' be seeing. Maybe I need special settings or special software! Any help or suggestions greatly appreciated! Thanks, Ralph Capen ________________________________________________________________________________
Date: Jun 07, 2017
Rob, It took awhile for me to get back to this thread but THANKS!!! For posterity sake, I tried the 5 VDC power source from Skyview and that did not work however the 12 VDC PIN 15 works great!!! Now I can check fuel by just firing up the Skyview (press and hold button #1) and do not need to have to connect the battery master!!! Thanks, Bill Hunter On Jun 1, 2017 2:19 AM, "Rob Turk" wrote: > From the specifications it doesn't appear you can use 5V to power these > probes. They are specified 12/24V (28V max), with the output being 0-5V. > You should power them from the main bus, or (if your Skyview installation > manual lists it), to the +12V Auxiliary Output pin (pin 15 of the 37-pin > connector). Not all SkyView systems appear to have that pin so double check. > > On 6/1/2017 1:33 AM, William Hunter wrote: > > I have two Westack capacitance fuel probes and I would like to power them > from PIN 18 of the Dynon Skyview. That pin is a 5 VDC output and the only > other item that this pin will power is a Grand Rapids CS-02 Hall Effect > Sensor. > > > Any experience would be most appreciated!!! > > .. > > > Cheers!!! > > > Bill Hunter > > ________________________________________________________________________________
Subject: Re: SL-70 Install /Configuration issues -> Installation
Manual
Date: Jun 07, 2017
First of all, I have to say I don't know anything about the SL-70. But I thought I'd just mention one possibility - if you see bursts of unintelligible data, that's often indicative of a non-matching baud rate. Do you know for sure that the SL-70 transmits its data at 1200 bps? That's actually a fairly slow rate... again, without knowing the specs of the SL-70, I'd expect higher - like maybe around 9600. If you're not sure of the baud rate, try higher rates and see if you find one that gives intelligible data. Dan > Does anyone out there know how to 'capture' the RS-232 data as it is transmitted from the SL-70 in a readable format? I have a serial port on my computer connected to the TX pin from the SL-70 and set to 1200, 8, 1, N in HYPERTERM (old Windows software). It does capture the 'bursts' of data but the results are unintelligible on the software screen. The SL-70 Install Manual gives me a good idea about what I 'should' be seeing. Maybe I need special settings or special software! > > Any help or suggestions greatly appreciated! > > Thanks, > Ralph Capen > > > > > --- Dan Charrois President, Syzygy Research & Technology Phone: 780-961-2213 ________________________________________________________________________________
Date: Jun 07, 2017
Finally got the plane out to run the engine. I modified the circuit, adding the 100 uF capacitor and the 10 Ohm resistor per Bob's instruction. Same behavior as before -- without engine running, the blades would change pitch fairly consistently, with an occasional premature cut-off at the extremes when trying to reverse the pitch; with the engine running, the pitch would change slightly, but the power would be cut off rapidly. I added my multi-meter in the loop to see what kind of current was flowing. Without the engine running, cut-off would occur, as before, at around 9 Amps. With the engine running, the meter indicated around 2 to 8 Amps before the circuit was shut down, with most readings around 2 to 5 or so Amps before cut-off. Not sure how reliable the meter readings are given the quick circuit shut-down. -------- Doug Read this topic online here: http://forums.matronics.com/viewtopic.php?p=469887#469887 ________________________________________________________________________________
Date: Jun 07, 2017
Manual Good question for verification Dan, The SL-70 manual specifies it as an acceptable rate. It is selected in the configuration of the SL-70. The primary receiving device (MX-20) can only use 1200 Baud - and it is receiving data properly and is displaying it without error messages. Verified - and I have tried other rates without success...with and without reconfiguration! -----Original Message----- >From: Dan Charrois <dan(at)syz.com> >Sent: Jun 7, 2017 3:56 PM >To: aeroelectric-list(at)matronics.com >Subject: Re: AeroElectric-List: SL-70 Install /Configuration issues -> Installation Manual > > >First of all, I have to say I don't know anything about the SL-70. But I thought I'd just mention one possibility - if you see bursts of unintelligible data, that's often indicative of a non-matching baud rate. Do you know for sure that the SL-70 transmits its data at 1200 bps? That's actually a fairly slow rate... again, without knowing the specs of the SL-70, I'd expect higher - like maybe around 9600. If you're not sure of the baud rate, try higher rates and see if you find one that gives intelligible data. > >Dan > >> Does anyone out there know how to 'capture' the RS-232 data as it is transmitted from the SL-70 in a readable format? I have a serial port on my computer connected to the TX pin from the SL-70 and set to 1200, 8, 1, N in HYPERTERM (old Windows software). It does capture the 'bursts' of data but the results are unintelligible on the software screen. The SL-70 Install Manual gives me a good idea about what I 'should' be seeing. Maybe I need special settings or special software! >> >> Any help or suggestions greatly appreciated! >> >> Thanks, >> Ralph Capen >> >> >> >> >> > >--- >Dan Charrois >President, Syzygy Research & Technology >Phone: 780-961-2213 > > ________________________________________________________________________________
Subject: klixon cb
Date: Jun 08, 2017
I notice that the top terminal on the klixon circuit breakers is marked "li ne." Does it matter on which terminal the bus or the LRU go? Thanks, Roger. ________________________________________________________________________________
Date: Jun 08, 2017
Subject: Re: klixon cb
At 03:19 PM 6/8/2017, you wrote: >I notice that the top terminal on the klixon circuit breakers is >marked "line." Does it matter on which terminal the bus or the LRU go? > No. Bob . . . ________________________________________________________________________________
Date: Jun 08, 2017
I just had an issue with recharging a flat aircraft battery by running the e ngine after a hand start. Not enough residual battery juice to close the mai n contactor, so no current flowing from the alternator to the battery. Come to think of it it might be a generator instead of an alternator because even without a power source for excitation the bus was powering the aircraf t radio. Still, no current going to the battery with the contactor resolutel y open. Is this a really obvious well known phenomenon that I've never really though t about before? On Jun 8, 2017, at 16:19, Roger Sherriff wrote: I notice that the top terminal on the klixon circuit breakers is marked "lin e." Does it matter on which terminal the bus or the LRU go? Thanks, Roger. ________________________________________________________________________________
Date: Jun 08, 2017
Subject: Re: IVO Prop current limiter
At 03:41 PM 6/7/2017, you wrote: > >Finally got the plane out to run the engine. I modified the >circuit, adding the 100 uF capacitor and the 10 Ohm resistor per >Bob's instruction. > >Same behavior as before -- without engine running, the blades would >change pitch fairly consistently, with an occasional premature >cut-off at the extremes when trying to reverse the pitch; with the >engine running, the pitch would change slightly, but the power would >be cut off rapidly. > >I added my multi-meter in the loop to see what kind of current was >flowing. Without the engine running, cut-off would occur, as >before, at around 9 Amps. > >With the engine running, the meter indicated around 2 to 8 Amps >before the circuit was shut down, with most readings around 2 to 5 >or so Amps before cut-off. Not sure how reliable the meter readings >are given the quick circuit shut-down. Well . . . fooey. This isn't going to be a 'problem' with your bus voltage. Circuits of this strip are inherently sensitive to dv/dt (fast rise noise) effects. Unfortunately, I didn't push this circuit through the DO160 examination . . . hmmmm . . . I think I was still at Raytheon/Beech. It's no doubt possible to tranquilize the little critter with the right test equipment but that's no longer in my bag of tricks. Let's go to plan B. In the time since that circuit was proposed, moving to a digital sensing, timing and reaction circuit makes a lot of sense. There's a LOT MORE separate between the bus and the parts that sift the fine sands of performance. I'm up to my eyeballs in a couple of programs now but I'll see if I can sketch out the diagram and get my super software guy to program a chip to try. Watch this space . . . Bob . . . ________________________________________________________________________________
Subject: Can Someone PLEASE Provide A Recommendation For A
Plunger Switch?!?!?
Date: Jun 08, 2017
Greetings, I have built a fiberglass air filter box that has an automatic alternate air door that I want to monitor with a micro switch and I was hoping someone could please give me a recommendation for a micro switch to purchase. The construction of this air filter box is of =BD inch Divinycell foam board encapsulated with two layers of fiberglass (see attached photo) and the alternate air door is a simple fiberglass flapper valve that is held shut by the spring action of the fiberglass valve and two magnets. The design goal is that the flapper valve will shut when the engine is not running and then after the engine is started the spring action and the magnets will hold the flapper valve shut. At times when the air filter becomes clogged (ice or debris) the engine vacuum will pull on the flapper door with enough suction force that the magnets will separate and the door will open into the air box and allow unfiltered air from the engine compartment to flow to the engine. The magnets are encapsulated in the fiberglass of the door and the air box walls so there is not fear of them falling into the engine. So=85getting back to the switch=85it needs to have the following attributes: -Plunger type switch that has a very light spring that forces the switch plunger to the extended position. -When the switch is pushed in the contacts need to be open and when the switch is allowed to extend the contacts need to close so my indicator light will illuminate. -The threaded shaft of the switch should be about =BD inch long. -Threaded shaft is made of plastic My goal is to install the switch from the outside so that the switch body is on the outside of the box and only the plunger assembly is inserted into the sidewall mounting hole just long enough so that the switch will be pressed in when the flapper valve is closed. If the threaded shaft is plastic then I can use epoxy to glue the switch threads into the sidewall of the air box and therefore it would not need a nut on the inside wall of the air box so there would be no worry about the nut falling into the engine intake. Here is a picture of a switch that could work=85I would not use the nuts and I would also prefer that the body and the plunger were made of plastic and I have no way of knowing how strong the spring is. If anyone has a suggestion as to the specific switch I should use I would be most grateful for the advice!!! .. Cheers!!! Bill Hunter ________________________________________________________________________________
Subject: Re: Can Someone PLEASE Provide A Recommendation For
A Plunger Switch?!?!?
Date: Jun 08, 2017
On 6/8/2017 9:22 PM, William Hunter wrote: > > Greetings, > > I have built a fiberglass air filter box that has an automatic > alternate air door that I want to monitor with a micro switch and I > was hoping someone could please give me a recommendation for a micro > switch to purchase. > > The construction of this air filter box is of inch Divinycell foam > board encapsulated with two layers of fiberglass (see attached photo) > and the alternate air door is a simple fiberglass flapper valve that > is held shut by the spring action of the fiberglass valve and two > magnets. > > The design goal is that the flapper valve will shut when the engine is > not running and then after the engine is started the spring action and > the magnets will hold the flapper valve shut. At times when the air > filter becomes clogged (ice or debris) the engine vacuum will pull on > the flapper door with enough suction force that the magnets will > separate and the door will open into the air box and allow unfiltered > air from the engine compartment to flow to the engine. The magnets > are encapsulated in the fiberglass of the door and the air box walls > so there is not fear of them falling into the engine. > > Sogetting back to the switchit needs to have the following attributes: > > -Plunger type switch that has a very light spring that forces the > switch plunger to the extended position. > > -When the switch is pushed in the contacts need to be open and when > the switch is allowed to extend the contacts need to close so my > indicator light will illuminate. > > -The threaded shaft of the switch should be about inch long. > > -Threaded shaft is made of plastic > > My goal is to install the switch from the outside so that the switch > body is on the outside of the box and only the plunger assembly is > inserted into the sidewall mounting hole just long enough so that the > switch will be pressed in when the flapper valve is closed. If the > threaded shaft is plastic then I can use epoxy to glue the switch > threads into the sidewall of the air box and therefore it would not > need a nut on the inside wall of the air box so there would be no > worry about the nut falling into the engine intake. > > Here is a picture of a switch that could workI would not use the nuts > and I would also prefer that the body and the plunger were made of > plastic and I have no way of knowing how strong the spring is. > > 1EN1-6 Honeywell Microswitch > > If anyone has a suggestion as to the specific switch I should use I > would be most grateful for the advice!!! > > .. > > Cheers!!! > > Bill Hunter > If you don't write restrictive requirements, you often get more useful ideas. :-) https://www.google.com/search?q=magnetic+prox+switch&oq=magnetic+prox+switch&aqs=chrome..69i57j0l5.6126j0j7&sourceid=chrome&ie=UTF-8 --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jun 08, 2017
On 6/8/2017 9:42 PM, Charlie England wrote: > On 6/8/2017 9:22 PM, William Hunter wrote: >> >> Greetings, >> >> I have built a fiberglass air filter box that has an automatic >> alternate air door that I want to monitor with a micro switch and I >> was hoping someone could please give me a recommendation for a micro >> switch to purchase. >> >> The construction of this air filter box is of inch Divinycell foam >> board encapsulated with two layers of fiberglass (see attached photo) >> and the alternate air door is a simple fiberglass flapper valve that >> is held shut by the spring action of the fiberglass valve and two >> magnets. >> >> The design goal is that the flapper valve will shut when the engine >> is not running and then after the engine is started the spring action >> and the magnets will hold the flapper valve shut. At times when the >> air filter becomes clogged (ice or debris) the engine vacuum will >> pull on the flapper door with enough suction force that the magnets >> will separate and the door will open into the air box and allow >> unfiltered air from the engine compartment to flow to the engine. >> The magnets are encapsulated in the fiberglass of the door and the >> air box walls so there is not fear of them falling into the engine. >> >> Sogetting back to the switchit needs to have the following attributes: >> >> -Plunger type switch that has a very light spring that forces the >> switch plunger to the extended position. >> >> -When the switch is pushed in the contacts need to be open and when >> the switch is allowed to extend the contacts need to close so my >> indicator light will illuminate. >> >> -The threaded shaft of the switch should be about inch long. >> >> -Threaded shaft is made of plastic >> >> My goal is to install the switch from the outside so that the switch >> body is on the outside of the box and only the plunger assembly is >> inserted into the sidewall mounting hole just long enough so that the >> switch will be pressed in when the flapper valve is closed. If the >> threaded shaft is plastic then I can use epoxy to glue the switch >> threads into the sidewall of the air box and therefore it would not >> need a nut on the inside wall of the air box so there would be no >> worry about the nut falling into the engine intake. >> >> Here is a picture of a switch that could workI would not use the >> nuts and I would also prefer that the body and the plunger were made >> of plastic and I have no way of knowing how strong the spring is. >> >> 1EN1-6 Honeywell Microswitch >> >> If anyone has a suggestion as to the specific switch I should use I >> would be most grateful for the advice!!! >> >> .. >> >> Cheers!!! >> >> Bill Hunter >> > If you don't write restrictive requirements, you often get more useful > ideas. :-) > > https://www.google.com/search?q=magnetic+prox+switch&oq=magnetic+prox+switch&aqs=chrome..69i57j0l5.6126j0j7&sourceid=chrome&ie=UTF-8 or more specifically, https://www.google.com/search?q=magnetic+prox+switch&oq=magnetic+prox+switch&aqs=chrome..69i57j0l5.6126j0j7&sourceid=chrome&ie=UTF-8#q=surface+mount+window+contact --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jun 08, 2017
At 07:33 PM 6/8/2017, you wrote: >I just had an issue with recharging a flat aircraft battery by >running the engine after a hand start. Not enough residual battery >juice to close the main contactor, so no current flowing from the >alternator to the battery. > >Come to think of it it might be a generator instead of an alternator >because even without a power source for excitation the bus was >powering the aircraft radio. Still, no current going to the battery >with the contactor resolutely open. > >Is this a really obvious well known phenomenon that I've never >really thought about before? Waaayyy back in the dark ages . . . but after Lucky Lindy, only generators were considered to be 'self exciting' but then only if the field was 'flashed' so as to possess some residual magnetism. Alternators too had some non-zero retentivity but generally too low to bring an alternator on line at ordinary speeds. There WERE notable exceptions. Alternators on the Bonanzas and Barons were expected to self excite at cruise rpms . . . and most did . . . but that's an interesting story for another time. Today's alternators, PARTICULARLY those that run nearly 10k rpm on the front of a Lycoming will come on line self excited if lightly loaded . . . and will run well. So your observation may not be a strange as you would think. Having said that, it's generally a poor idea to recharge a flat battery with the ship's alternator . . . use jumper cables to an automobile for a few minutes to stir up the battery's chemistry and avoid unpredictable perturbations of bus voltage during early phase of recharge . . . and know this is not very good for the battery's service life. Putting a regulated, 10A charger on it for an hour or so is much preferred. Bob . . . ________________________________________________________________________________
Date: Jun 09, 2017
For A Plunger Switch?!?!? > >So=85getting back to the switch=85it needs to have the following attributes: > >-Plunger type switch that has a very light >spring that forces the switch plunger to the extended position. >-When the switch is pushed in the contacts need >to be open and when the switch is allowed to >extend the contacts need to close so my indicator light will illuminate. >-The threaded shaft of the switch should be about =BD inch long. >-Threaded shaft is made of plastic > >My goal is to install the switch from the >outside so that the switch body is on the >outside of the box and only the plunger assembly >is inserted into the sidewall mounting hole just >long enough so that the switch will be pressed >in when the flapper valve is closed. If the >threaded shaft is plastic then I can use epoxy >to glue the switch threads into the sidewall of >the air box and therefore it would not need a >nut on the inside wall of the air box so there >would be no worry about the nut falling into the engine intake. > >Here is a picture of a switch that could work=85I >would not use the nuts and I would also prefer >that the body and the plunger were made >of plastic and I have no way of knowing how strong the spring is. Emacs! The switch you have illustrated is a Honeywell product used extensively in aviation for harsh environment limit switching . . . like landing gear. When disassembled, you find two basic switches inside a weathertight housing. There is a spring in the threaded barrel that gives this switch a VERY high operating force. Then, you will find that this product is expensive . . . in fact, I don't think they are catalog items. Examples I encountered at Raytheon/Beech were custom built to our specs for stroke, over-travel, force, and style of basic switch. If you want to go with a 'hard' switch, check out the range of options offered here: http://tinyurl.com/y7lnmvpu There are products adaptable to your task but you'll have to figure out mounting and actuator configurations. Charlie's suggestion for non-contact sensing is excellent too. A button magnet or metalic target bonded to the door and sensed by some form of proximity device. Some examples: http://tinyurl.com/yd3vzncr The later options are essentially zero-actuation-force, and usually very robust in crappy environments. Bob . . . ________________________________________________________________________________
From: "William Hunter" <billhuntersemail(at)gmail.com>
Date: Jun 09, 2017
THANKS for the feedback. A plastic plunger magnetic sensing switch would be great. The fiberglass air box base and the flapper valve each have a magnet installed so when the flapper is moved away from the air box base there will still be a magnet located directly next to the proximity switch so do you supposed that would affect the switch action? Whoa=85Digikey sure has a bunch of switches. I tried to use the filter function however I did not know what to select for the various filters. If I have to stick with a =93hard=94 snap action switch I assume the one I need will be a SP ST NC switch? The NC part I am unsure of=85If the flapper door is closed and pushing down on the plunger switch then I want the contacts to be open and then when the door opens the plunger will be extended so I want the contacts to be closed so I believe this is called a NC switch. Should I select =93MOM-OFF=94 or =93ON MOM=94in the filter? The Judco Manufacturing Inc. 40-4819-00 switch looks like it will work https://media.digikey.com/pdf/Data%20Sheets/Judco%20PDFs/40-4819-00.pdf How can one (me) determine how strong the spring is? .. THANKS AGAIN FOR YOUR HELP!!! Bill Hunter From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Friday, June 9, 2017 7:57 AM Subject: Re: AeroElectric-List: Can Someone PLEASE Provide A Recommendation For A Plunger Switch?!?!? So=85getting back to the switch=85it needs to have the following attributes: -Plunger type switch that has a very light spring that forces the switch plunger to the extended position. -When the switch is pushed in the contacts need to be open and when the switch is allowed to extend the contacts need to close so my indicator light will illuminate. -The threaded shaft of the switch should be about =BD inch long. -Threaded shaft is made of plastic My goal is to install the switch from the outside so that the switch body is on the outside of the box and only the plunger assembly is inserted into the sidewall mounting hole just long enough so that the switch will be pressed in when the flapper valve is closed. If the threaded shaft is plastic then I can use epoxy to glue the switch threads into the sidewall of the air box and therefore it would not need a nut on the inside wall of the air box so there would be no worry about the nut falling into the engine intake. Here is a picture of a switch that could work=85I would not use the nuts and I would also prefer that the body and the plunger were made of plastic and I have no way of knowing how strong the spring is. The switch you have illustrated is a Honeywell product used extensively in aviation for harsh environment limit switching . . . like landing gear. When disassembled, you find two basic switches inside a weathertight housing. There is a spring in the threaded barrel that gives this switch a VERY high operating force. Then, you will find that this product is expensive . . . in fact, I don't think they are catalog items. Examples I encountered at Raytheon/Beech were custom built to our specs for stroke, over-travel, force, and style of basic switch. If you want to go with a 'hard' switch, check out the range of options offered here: http://tinyurl.com/y7lnmvpu There are products adaptable to your task but you'll have to figure out mounting and actuator configurations. Charlie's suggestion for non-contact sensing is excellent too. A button magnet or metalic target bonded to the door and sensed by some form of proximity device. Some examples: http://tinyurl.com/yd3vzncr The later options are essentially zero-actuation-force, and usually very robust in crappy environments. Bob . . . ________________________________________________________________________________
Date: Jun 09, 2017
A Plunger Switch?!?!? Burglar alarm switches typically activate with around a 1/2" gap, max. Just order a SPDT surface mount window contact, glue the magnet to the door and mount the switch on the perimeter of the opening. The SPDT allows you to wire NO or NC; your choice. https://www.elvessupply.com/Honeywell-Sensors-7939-2WH-Surface-Mount-Contac t-Spdt-Wh_p_337005.html?gclid=CjwKEAjwjunJBRDzl6iCpoKS4G0SJACJAx-VG9UBele MqS-_LAKOkZ6xb8EjYY_HWPEU9mHkZIxe6BoC6BPw_wcB Something like that will many times more reliable than any snap action switch you can purchase. The last time I did burg alarm install work, my supplier offered a 5 for 1 replacement warranty against *anything* including lightning damage. The 'contacts' are in an inert gas filled, sealed glass chamber, and the mounting is more compact than any plunger you're likely to find. Google 'reed switch' to see what's inside. Just don't try to drive some 5 amp siren through it. :-) Charlie On Fri, Jun 9, 2017 at 12:57 PM, William Hunter wrote: > > > THANKS for the feedback. > > > A plastic plunger magnetic sensing switch would be great. The fiberglass > air box base and the flapper valve each have a magnet installed so when t he > flapper is moved away from the air box base there will still be a magnet > located directly next to the proximity switch so do you supposed that wou ld > affect the switch action? > > > WhoaDigikey sure has a bunch of switches. I tried to use the fi lter > function however I did not know what to select for the various filters. > > > If I have to stick with a =9Chard=9D snap action switch I ass ume the one I > need will be a SP ST NC switch? The NC part I am unsure ofIf th e flapper > door is closed and pushing down on the plunger switch then I want the > contacts to be open and then when the door opens the plunger will be > extended so I want the contacts to be closed so I believe this is called a > NC switch. Should I select =9CMOM-OFF=9D or =9CON MOM =9Din the filter? > > > The Judco Manufacturing Inc. 40-4819-00 switch looks like it will work > https://media.digikey.com/pdf/Data%20Sheets/Judco%20PDFs/40-4819-00.pdf > > > How can one (me) determine how strong the spring is? > > > .. > > > THANKS AGAIN FOR YOUR HELP!!! > > > Bill Hunter > > > *From:* owner-aeroelectric-list-server(at)matronics.com [mailto: > owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of *Robert L. > Nuckolls, III > *Sent:* Friday, June 9, 2017 7:57 AM > *To:* aeroelectric-list(at)matronics.com > *Subject:* Re: AeroElectric-List: Can Someone PLEASE Provide A > Recommendation For A Plunger Switch?!?!? > > > Sogetting back to the switchit needs to have the follow ing attributes: > > -Plunger type switch that has a very light spring that forces the switch > plunger to the extended position. > -When the switch is pushed in the contacts need to be open and when the > switch is allowed to extend the contacts need to close so my indicator > light will illuminate. > -The threaded shaft of the switch should be about =C2=BD inch long. > -Threaded shaft is made of plastic > > My goal is to install the switch from the outside so that the switch body > is on the outside of the box and only the plunger assembly is inserted in to > the sidewall mounting hole just long enough so that the switch will be > pressed in when the flapper valve is closed. If the threaded shaft is > plastic then I can use epoxy to glue the switch threads into the sidewall > of the air box and therefore it would not need a nut on the inside wall o f > the air box so there would be no worry about the nut falling into the > engine intake. > > Here is a picture of a switch that could workI would not use the nuts and > I would also prefer that the body and the plunger were made of plastic a nd > I have no way of knowing how strong the spring is. > > > [image: Emacs!] > > > The switch you have illustrated is a Honeywell product used extensively > in aviation for harsh environment limit switching . . . like landing > gear. > > When disassembled, you find two basic switches inside a weathertight > housing. There is a spring in the threaded barrel that gives this > switch a VERY high operating force. Then, you will find that > this product is expensive . . . in fact, I don't think they are > catalog items. Examples I encountered at Raytheon/Beech were > custom built to our specs for stroke, over-travel, force, > and style of basic switch. > > If you want to go with a 'hard' switch, check out the > range of options offered here: > > http://tinyurl.com/y7lnmvpu > > There are products adaptable to your task but you'll have > to figure out mounting and actuator configurations. > > Charlie's suggestion for non-contact sensing is excellent > too. A button magnet or metalic target bonded to the door > and sensed by some form of proximity device. Some > examples: > > http://tinyurl.com/yd3vzncr > > The later options are essentially zero-actuation-force, > and usually very robust in crappy environments. > > > Bob . . . > ________________________________________________________________________________
Date: Jun 09, 2017
From: Robert McCallum <robert.mccallum2(at)sympatico.ca>
A Plunger Switch?!?!? William; Why the insistence on a "plunger" style where you need to be concerned with spring pressure and possibly weather resistance?? Why not take the earlier replies suggestion of an inductive "PROXIMITY" switch which detects the closeness of a piece or ferrous metal and is generally sealed against all external environmental influence? (NOT switched by a magnet as someone suggested. Switches responding to magnets are usually "reed" switches) You then don't need to worry about how strong the "spring" is as there isn't one. Wh en the little piece of steel you embed in your fiberglass door is adjacent to the switch the switch is either "open" or "closed" depending upon whether you s elect a NO or NC switch. "Normal" by the way refers to the switches condition sit ting in space without activation, the switch "switches" to the opposite state wh en the ferrous target is close. Would make choice and installation a whole lot simpler. Just bring your door adjacent to the switch and, Bingo, it switche s. Alternatively move your door away from the switch and it switches the other way. No contact, moving parts, or forces involved. Bob McC > ---------- Original Message ---------- > From: William Hunter <billhuntersemail(at)gmail.com> > Date: June 9, 2017 at 1:57 PM > > > > > THANKS for the feedback. > > > > A plastic plunger magnetic sensing switch would be great. The fibergl ass > air box base and the flapper valve each have a magnet installed so when t he > flapper is moved away from the air box base there will still be a magnet > located directly next to the proximity switch so do you supposed that wou ld > affect the switch action? > > > > WhoaDigikey sure has a bunch of switches. I tried to use the filter > function however I did not know what to select for the various filters. > > > > If I have to stick with a =9Chard=9D snap action switch I assume the one I > need will be a SP ST NC switch? The NC part I am unsure ofIf the flapper door > is closed and pushing down on the plunger switch then I want the contacts to > be open and then when the door opens the plunger will be extended so I wa nt > the contacts to be closed so I believe this is called a NC switch. Should I > select =9CMOM-OFF=9D or =9CON MOM=9Din the filter ? > > > > The Judco Manufacturing Inc. 40-4819-00 switch looks like it will wor k > https://media.digikey.com/pdf/Data%20Sheets/Judco%20PDFs/40-4819-00.pdf > > > > How can one (me) determine how strong the spring is? > > > > .. > > > > THANKS AGAIN FOR YOUR HELP!!! > > > > Bill Hunter > > > > > > > > > > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. > Nuckolls, III > Sent: Friday, June 9, 2017 7:57 AM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Can Someone PLEASE Provide A > Recommendation For A Plunger Switch?!?!? > > > > > > > > > > Sogetting back to the switchit needs to have the following > > attributes: > > > > -Plunger type switch that has a very light spring that forces t he > > switch plunger to the extended position. > > -When the switch is pushed in the contacts need to be open and when > > the switch is allowed to extend the contacts need to close so my indica tor > > light will illuminate. > > -The threaded shaft of the switch should be about 1=81=842 i nch long. > > -Threaded shaft is made of plastic > > > > My goal is to install the switch from the outside so that the s witch > > body is on the outside of the box and only the plunger assembly is inse rted > > into the sidewall mounting hole just long enough so that the switch wil l be > > pressed in when the flapper valve is closed. If the threaded shaft is > > plastic then I can use epoxy to glue the switch threads into the sidewa ll of > > the air box and therefore it would not need a nut on the inside wall of the > > air box so there would be no worry about the nut falling into the engin e > > intake. > > > > Here is a picture of a switch that could workI would n ot use the > > nuts and I would also prefer that the body and the plunger were made of > > plastic and I have no way of knowing how strong the spring is. > > > > > > > > > > The switch you have illustrated is a Honeywell product used extensi vely > in aviation for harsh environment limit switching . . . like landin g > gear. > > When disassembled, you find two basic switches inside a weathertigh t > housing. There is a spring in the threaded barrel that gives this > switch a VERY high operating force. Then, you will find that > this product is expensive . . . in fact, I don't think they are > catalog items. Examples I encountered at Raytheon/Beech were > custom built to our specs for stroke, over-travel, force, > and style of basic switch. > > If you want to go with a 'hard' switch, check out the > range of options offered here: > > http://tinyurl.com/y7lnmvpu > > There are products adaptable to your task but you'll have > to figure out mounting and actuator configurations. > > Charlie's suggestion for non-contact sensing is excellent > too. A button magnet or metalic target bonded to the door > and sensed by some form of proximity device. Some > examples: > > http://tinyurl.com/yd3vzncr > > The later options are essentially zero-actuation-force, > and usually very robust in crappy environments. > > > > > > Bob . . . > ________________________________________________________________________________
Date: Jun 09, 2017
> Why the insistence on a "plunger" style where you need to be concerned with spring pressure and possibly weather resistance?? Why not take the earlier replies suggestion of an inductive "PROXIMITY" switch which detects the closeness of a piece or ferrous metal and is generally sealed against all external environmental influence? (NOT switched by a magnet as someone suggested. Switches responding to magnets are usually "reed" switches) I am not insisting on a plunger switchthe proximity switch sounds like a superior idealess moving parts to fall into the engine if the switch falls apart. If I install a proximity switch directly next to a magnet (meaning side by side) will it work? In other wordsmy flapper door has a magnet and so does the air box structure and the two magnets pulling toward each other is mostly what keeps the flapper door closed (these are really strong magnets). The only practical place to install a switch is side by side with the magnet that is installed in the air box structure so therefore the proximity switch will only be 1 inch away from the magnet installed in the structure of the air boxyes the magnet that is connected to the flapper door will move away with the flapper door and so will the ferrous metal =9Ctarget=9D that is installed next to the magnet in the flapper door however the proximity switch is still just one inch away from the magnet in the structure. Here is a switch that might work: http://www.ebay.co.uk/itm/SENSOR-PLASTIC-BARREL-M8-NO-Proximity-Sensors-S N36555-/381449156652?hash=item58d024382c:g:yKwAAOSwl9BWLjvd <http://www.ebay.co.uk/itm/SENSOR-PLASTIC-BARREL-M8-NO-Proximity-Sensors- SN36555-/381449156652?hash=item58d024382c:g:yKwAAOSwl9BWLjvd&_trksid= p2349526.m3874.l7936> &_trksid=p2349526.m3874.l7936 It says =9CNO=9D however would I not need a =9CNC=9D switch so that when the target is close to the proximity sensor the contacts are open and then when the target moves away the from the sensor (the Normal state of the sensor) the contacts will close? The window sensors are a great idea however I do not have enough room. AgainI GREATLY APPRECIATE YOUR HELP!!! .. Cheers!!! Bill Hunter From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert McCallum Sent: Friday, June 9, 2017 12:46 PM Subject: RE: AeroElectric-List: Can Someone PLEASE Provide A Recommendation For A Plunger Switch?!?!? William; Why the insistence on a "plunger" style where you need to be concerned with spring pressure and possibly weather resistance?? Why not take the earlier replies suggestion of an inductive "PROXIMITY" switch which detects the closeness of a piece or ferrous metal and is generally sealed against all external environmental influence? (NOT switched by a magnet as someone suggested. Switches responding to magnets are usually "reed" switches) You then don't need to worry about how strong the "spring" is as there isn't one. When the little piece of steel you embed in your fiberglass door is adjacent to the switch the switch is either "open" or "closed" depending upon whether you select a NO or NC switch. "Normal" by the way refers to the switches condition sitting in space without activation, the switch "switches" to the opposite state when the ferrous target is close. Would make choice and installation a whole lot simpler. Just bring your door adjacent to the switch and, Bingo, it switches. Alternatively move your door away from the switch and it switches the other way. No contact, moving parts, or forces involved. Bob McC ---------- Original Message ---------- From: William Hunter <billhuntersemail(at)gmail.com > Date: June 9, 2017 at 1:57 PM THANKS for the feedback. A plastic plunger magnetic sensing switch would be great. The fiberglass air box base and the flapper valve each have a magnet installed so when the flapper is moved away from the air box base there will still be a magnet located directly next to the proximity switch so do you supposed that would affect the switch action? WhoaDigikey sure has a bunch of switches. I tried to use the filter function however I did not know what to select for the various filters. If I have to stick with a =9Chard=9D snap action switch I assume the one I need will be a SP ST NC switch? The NC part I am unsure ofIf the flapper door is closed and pushing down on the plunger switch then I want the contacts to be open and then when the door opens the plunger will be extended so I want the contacts to be closed so I believe this is called a NC switch. Should I select =9CMOM-OFF=9D or =9CON MOM=9Din the filter? The Judco Manufacturing Inc. 40-4819-00 switch looks like it will work https://media.digikey.com/pdf/Data%20Sheets/Judco%20PDFs/40-4819-00.pdf How can one (me) determine how strong the spring is? .. THANKS AGAIN FOR YOUR HELP!!! Bill Hunter From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Friday, June 9, 2017 7:57 AM Subject: Re: AeroElectric-List: Can Someone PLEASE Provide A Recommendation For A Plunger Switch?!?!? Sogetting back to the switchit needs to have the following attributes: -Plunger type switch that has a very light spring that forces the switch plunger to the extended position. -When the switch is pushed in the contacts need to be open and when the switch is allowed to extend the contacts need to close so my indicator light will illuminate. -The threaded shaft of the switch should be about 1=81=842 inch long. -Threaded shaft is made of plastic My goal is to install the switch from the outside so that the switch body is on the outside of the box and only the plunger assembly is inserted into the sidewall mounting hole just long enough so that the switch will be pressed in when the flapper valve is closed. If the threaded shaft is plastic then I can use epoxy to glue the switch threads into the sidewall of the air box and therefore it would not need a nut on the inside wall of the air box so there would be no worry about the nut falling into the engine intake. Here is a picture of a switch that could workI would not use the nuts and I would also prefer that the body and the plunger were made of plastic and I have no way of knowing how strong the spring is. The switch you have illustrated is a Honeywell product used extensively in aviation for harsh environment limit switching . . . like landing gear. When disassembled, you find two basic switches inside a weathertight housing. There is a spring in the threaded barrel that gives this switch a VERY high operating force. Then, you will find that this product is expensive . . . in fact, I don't think they are catalog items. Examples I encountered at Raytheon/Beech were custom built to our specs for stroke, over-travel, force, and style of basic switch. If you want to go with a 'hard' switch, check out the range of options offered here: http://tinyurl.com/y7lnmvpu There are products adaptable to your task but you'll have to figure out mounting and actuator configurations. Charlie's suggestion for non-contact sensing is excellent too. A button magnet or metalic target bonded to the door and sensed by some form of proximity device. Some examples: http://tinyurl.com/yd3vzncr The later options are essentially zero-actuation-force, and usually very robust in crappy environments. Bob . . . ________________________________________________________________________________
Date: Jun 09, 2017
How about a =9CCapacitance Proximity Switch=9D https://www.amazon.com/Uxcell-Capacitance-Proximity-Sensor-Switch/dp/B005 42U3M4/ref=sr_1_12?ie=UTF8 &qid=1497072880&sr=8-12&keywords=proximity+switch If I understand this correctlyI would need to provide a 12 VDC power wire, a ground, and then the third wire would be the 12VDC signal wire to my EFIS input. It seems this gizmo will sense plastic being close of if it is moved away. I understand the concept of Normally Open with respect to a regular old push button switchwhen the button is not pushed then that is the =9Cnormal=9D condition (switch out in space with nothing touching it) however with respect to proximity switches is the normal condition when the target is close or away? .. Cheers!!! Bill Hunter From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Charlie England Sent: Friday, June 9, 2017 12:25 PM Subject: Re: AeroElectric-List: Can Someone PLEASE Provide A Recommendation For A Plunger Switch?!?!? Burglar alarm switches typically activate with around a 1/2" gap, max. Just order a SPDT surface mount window contact, glue the magnet to the door and mount the switch on the perimeter of the opening. The SPDT allows you to wire NO or NC; your choice. https://www.elvessupply.com/Honeywell-Sensors-7939-2WH-Surface-Mount-Cont act-Spdt-Wh_p_337005.html?gclid=CjwKEAjwjunJBRDzl6iCpoKS4G0SJACJAx-VG9U BeleMqS-_LAKOkZ6xb8EjYY_HWPEU9mHkZIxe6BoC6BPw_wcB Something like that will many times more reliable than any snap action switch you can purchase. The last time I did burg alarm install work, my supplier offered a 5 for 1 replacement warranty against *anything* including lightning damage. The 'contacts' are in an inert gas filled, sealed glass chamber, and the mounting is more compact than any plunger you're likely to find. Google 'reed switch' to see what's inside. Just don't try to drive some 5 amp siren through it. :-) Charlie On Fri, Jun 9, 2017 at 12:57 PM, William Hunter > wrote: THANKS for the feedback. A plastic plunger magnetic sensing switch would be great. The fiberglass air box base and the flapper valve each have a magnet installed so when the flapper is moved away from the air box base there will still be a magnet located directly next to the proximity switch so do you supposed that would affect the switch action? WhoaDigikey sure has a bunch of switches. I tried to use the filter function however I did not know what to select for the various filters. If I have to stick with a =9Chard=9D snap action switch I assume the one I need will be a SP ST NC switch? The NC part I am unsure ofIf the flapper door is closed and pushing down on the plunger switch then I want the contacts to be open and then when the door opens the plunger will be extended so I want the contacts to be closed so I believe this is called a NC switch. Should I select =9CMOM-OFF=9D or =9CON MOM=9Din the filter? The Judco Manufacturing Inc. 40-4819-00 switch looks like it will work https://media.digikey.com/pdf/Data%20Sheets/Judco%20PDFs/40-4819-00.pdf How can one (me) determine how strong the spring is? .. THANKS AGAIN FOR YOUR HELP!!! Bill Hunter From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com ] On Behalf Of Robert L. Nuckolls, III Sent: Friday, June 9, 2017 7:57 AM Subject: Re: AeroElectric-List: Can Someone PLEASE Provide A Recommendation For A Plunger Switch?!?!? Sogetting back to the switchit needs to have the following attributes: -Plunger type switch that has a very light spring that forces the switch plunger to the extended position. -When the switch is pushed in the contacts need to be open and when the switch is allowed to extend the contacts need to close so my indicator light will illuminate. -The threaded shaft of the switch should be about =C2=BD inch long. -Threaded shaft is made of plastic My goal is to install the switch from the outside so that the switch body is on the outside of the box and only the plunger assembly is inserted into the sidewall mounting hole just long enough so that the switch will be pressed in when the flapper valve is closed. If the threaded shaft is plastic then I can use epoxy to glue the switch threads into the sidewall of the air box and therefore it would not need a nut on the inside wall of the air box so there would be no worry about the nut falling into the engine intake. Here is a picture of a switch that could workI would not use the nuts and I would also prefer that the body and the plunger were made of plastic and I have no way of knowing how strong the spring is. The switch you have illustrated is a Honeywell product used extensively in aviation for harsh environment limit switching . . . like landing gear. When disassembled, you find two basic switches inside a weathertight housing. There is a spring in the threaded barrel that gives this switch a VERY high operating force. Then, you will find that this product is expensive . . . in fact, I don't think they are catalog items. Examples I encountered at Raytheon/Beech were custom built to our specs for stroke, over-travel, force, and style of basic switch. If you want to go with a 'hard' switch, check out the range of options offered here: http://tinyurl.com/y7lnmvpu There are products adaptable to your task but you'll have to figure out mounting and actuator configurations. Charlie's suggestion for non-contact sensing is excellent too. A button magnet or metalic target bonded to the door and sensed by some form of proximity device. Some examples: http://tinyurl.com/yd3vzncr The later options are essentially zero-actuation-force, and usually very robust in crappy environments. Bob . . . ________________________________________________________________________________
Date: Jun 09, 2017
YouTube answered my NC verses NO question: https://www.youtube.com/watch?v=0PtNGlj0u7g .. Cheers!!! Bill Hunter From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Charlie England Sent: Friday, June 9, 2017 12:25 PM Subject: Re: AeroElectric-List: Can Someone PLEASE Provide A Recommendation For A Plunger Switch?!?!? Burglar alarm switches typically activate with around a 1/2" gap, max. Just order a SPDT surface mount window contact, glue the magnet to the door and mount the switch on the perimeter of the opening. The SPDT allows you to wire NO or NC; your choice. https://www.elvessupply.com/Honeywell-Sensors-7939-2WH-Surface-Mount-Cont act-Spdt-Wh_p_337005.html?gclid=CjwKEAjwjunJBRDzl6iCpoKS4G0SJACJAx-VG9U BeleMqS-_LAKOkZ6xb8EjYY_HWPEU9mHkZIxe6BoC6BPw_wcB Something like that will many times more reliable than any snap action switch you can purchase. The last time I did burg alarm install work, my supplier offered a 5 for 1 replacement warranty against *anything* including lightning damage. The 'contacts' are in an inert gas filled, sealed glass chamber, and the mounting is more compact than any plunger you're likely to find. Google 'reed switch' to see what's inside. Just don't try to drive some 5 amp siren through it. :-) Charlie On Fri, Jun 9, 2017 at 12:57 PM, William Hunter > wrote: THANKS for the feedback. A plastic plunger magnetic sensing switch would be great. The fiberglass air box base and the flapper valve each have a magnet installed so when the flapper is moved away from the air box base there will still be a magnet located directly next to the proximity switch so do you supposed that would affect the switch action? WhoaDigikey sure has a bunch of switches. I tried to use the filter function however I did not know what to select for the various filters. If I have to stick with a =9Chard=9D snap action switch I assume the one I need will be a SP ST NC switch? The NC part I am unsure ofIf the flapper door is closed and pushing down on the plunger switch then I want the contacts to be open and then when the door opens the plunger will be extended so I want the contacts to be closed so I believe this is called a NC switch. Should I select =9CMOM-OFF=9D or =9CON MOM=9Din the filter? The Judco Manufacturing Inc. 40-4819-00 switch looks like it will work https://media.digikey.com/pdf/Data%20Sheets/Judco%20PDFs/40-4819-00.pdf How can one (me) determine how strong the spring is? .. THANKS AGAIN FOR YOUR HELP!!! Bill Hunter From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com ] On Behalf Of Robert L. Nuckolls, III Sent: Friday, June 9, 2017 7:57 AM Subject: Re: AeroElectric-List: Can Someone PLEASE Provide A Recommendation For A Plunger Switch?!?!? Sogetting back to the switchit needs to have the following attributes: -Plunger type switch that has a very light spring that forces the switch plunger to the extended position. -When the switch is pushed in the contacts need to be open and when the switch is allowed to extend the contacts need to close so my indicator light will illuminate. -The threaded shaft of the switch should be about =C2=BD inch long. -Threaded shaft is made of plastic My goal is to install the switch from the outside so that the switch body is on the outside of the box and only the plunger assembly is inserted into the sidewall mounting hole just long enough so that the switch will be pressed in when the flapper valve is closed. If the threaded shaft is plastic then I can use epoxy to glue the switch threads into the sidewall of the air box and therefore it would not need a nut on the inside wall of the air box so there would be no worry about the nut falling into the engine intake. Here is a picture of a switch that could workI would not use the nuts and I would also prefer that the body and the plunger were made of plastic and I have no way of knowing how strong the spring is. The switch you have illustrated is a Honeywell product used extensively in aviation for harsh environment limit switching . . . like landing gear. When disassembled, you find two basic switches inside a weathertight housing. There is a spring in the threaded barrel that gives this switch a VERY high operating force. Then, you will find that this product is expensive . . . in fact, I don't think they are catalog items. Examples I encountered at Raytheon/Beech were custom built to our specs for stroke, over-travel, force, and style of basic switch. If you want to go with a 'hard' switch, check out the range of options offered here: http://tinyurl.com/y7lnmvpu There are products adaptable to your task but you'll have to figure out mounting and actuator configurations. Charlie's suggestion for non-contact sensing is excellent too. A button magnet or metalic target bonded to the door and sensed by some form of proximity device. Some examples: http://tinyurl.com/yd3vzncr The later options are essentially zero-actuation-force, and usually very robust in crappy environments. Bob . . . ________________________________________________________________________________
Date: Jun 12, 2017
Subject: Multiplexer or new antenna
Hello. =C2-I've added a new comm radio on my RV4. =C2-I currently have a Comant CI-122 bent whip. =C2-Space is limited on the belly of the RV4. =C2-Would it be OK to use a multiplexer and share the antenna or try to f ind a spot for another antenna? =C2-What multiplexer would you recommend? Thanks. Jeff Bertsch ________________________________________________________________________________
Date: Jun 12, 2017
Subject: Re: Multiplexer or new antenna
At 07:13 AM 6/12/2017, you wrote: >Hello. I've added a new comm radio on my RV4. I currently have a >Comant CI-122 bent whip. Space is limited on the belly of the >RV4. Would it be OK to use a multiplexer and share the antenna or >try to find a spot for another antenna? What multiplexer would you recommend? > Having two or more appliances share a single antenna is problematic . . . and as Heinlein noted, "There ain't no such thing as a free lunch". There are various ways that the energy being received or transmitted by an antenna may be split into multiple pathways . . . but the first effect is attenuation of said energy(ies). The second consideration is ability to isolate one pathway from another . . . a transmitter dumping thousands of milliwatts into the feedline is a severe performance risk (if not destructive) of other appliances where a pathway is conducting microwatts of energy. There ARE power dividers for driving up to two VOR and two glideslope receivers from a single VOR antenna . . . but the performance of ALL receivers downstream of the signal source is degraded . . . and, of course, NO transmitters are expected to share this system. The short answer to your question is no. Separate antennas go to maintaining both PERFORMANCE and REDUNDANCY of the two transceivers. Bob . . . ________________________________________________________________________________
Date: Jun 12, 2017
Find a place for second antenna. If there isn't room on belly, consider locations on top of fuselage, or.. I've had success locating a CI-122 on an inspection plate on underside of a wing. I'm not aware of any reasonable device that allow sharing a transmitting antenna with adequate protection from frying the receiver on the other radio. On 6/12/2017 5:13 AM, Jeff Bertsch wrote: > Hello. I've added a new comm radio on my RV4. I currently have a > Comant CI-122 bent whip. Space is limited on the belly of the RV4. > Would it be OK to use a multiplexer and share the antenna or try to > find a spot for another antenna? What multiplexer would you recommend? > > Thanks. > > Jeff Bertsch ________________________________________________________________________________
Subject: LYC HYIP 3000% ROI IN 24 Hours
Date: Jun 12, 2017
LYC HYIP 3000% ROI IN 24 Hours LycHyip.com is a short-term global investments offerring company, just launched in August 2016. We offer two types of plans for you to choose: 3000%-9000% of your deposit after 24 hours or 2000%-6000% of your deposit after 12 hours ! Payouts are sent 7 days a week, even on weekends! You don't need to go to banks or financial institutions to purchase the plans, cause we enable you to purchase it via Perfect Money payment system, online and instantly! Invest Here http://www.lychyip.com Proof of payment http://www.top10hyip.net/lychyip.html Read this topic online here: http://forums.matronics.com/viewtopic.php?p=469999#469999 ________________________________________________________________________________
Subject: Question about Z19RB and OVP/Beaker and size wire
Date: Jun 12, 2017
Hello all, I'am new on the forum, and I need some help to restart my plane please. ;) I started to change my electrical system on my plane. I had single battery, single old car ignition "Delco" type. I set now dual battery and two Leburg ignitions and an over-voltage protection (due to electrical dependance) and I have some question to finish it. My plane is an IBIS junqua RJ03 (wooden canard layout), looking to wire it with the Z19/RB. My main battery is 20ah (into the nose, so I will wire it with 2AWG to starter) and the aux. small battery 7ah., 30 inch. behind the main bat. but also in the forward part of the plane. Bus are quite close to the aux. battery. (30 inch. above) so I take the Z19AB wiring diagram. My problems are : I am not sure about the wires size and fuse/breaker to use, as Bob said it's a diagram and suggestion. And reading and reading again the chapter about wires size I keep not very confident to do my choice alone. 1) My cuve facet pumps (main and auxiliary, same model, have a consumption around 1,6amp/one apparently) are 20ft behind buses and switches. Same things for my ignitions. (It seems to be 0,4amp/each) may I use 14AWG for fuel pump and 16 awg for ignition ? (4 degrees Celsius only increase of temperature I calculate, I can take smaller wire not ? But up to what size to be safe, for my tezfel wire, ) 2)I have the OVP kit Bandc.aero and I have to set it close to the alternator o i can set it close to the switching panel ? (without changing the 5 amp breaker du to length of the wire ?) 3)I don't know how to wire my bandc-aero OVP kit. they sent me this diagram and did not succeeded to have another precision: http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z17K.pdf Problem is that I don't have a dynamo. I have a car alternator of 30A. Z19Rb don't show the relay and warning light that I have. Thanks in advance. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470004#470004 ________________________________________________________________________________
Date: Jun 12, 2017
Subject: Re: Question about Z19RB and OVP/Beaker and size
wire At 12:35 PM 6/12/2017, you wrote: > >Hello all, > >I'am new on the forum, and I need some help to restart my plane please. ;) > > I started to change my electrical system on my plane. I had single > battery, single old car ignition "Delco" type. >I set now dual battery and two Leburg ignitions and an over-voltage >protection (due to electrical dependance) and I have some question >to finish it. > >My plane is an IBIS junqua RJ03 (wooden canard layout), looking to >wire it with the Z19/RB. > >My main battery is 20ah (into the nose, so I will wire it with 2AWG >to starter) and the aux. small battery 7ah., 30 inch. behind the >main bat. but also in the forward part of the plane. >Bus are quite close to the aux. battery. (30 inch. above) so I take >the Z19AB wiring diagram. > >My problems are : > >I am not sure about the wires size and fuse/breaker to use, as Bob >said it's a diagram and suggestion. And reading and reading again >the chapter about wires size I keep not very confident to do my choice alone. > >1) My cuve facet pumps (main and auxiliary, same model, have a >consumption around 1,6amp/one apparently) are 20ft behind buses and switches. 20AWG wire is 10 milliohms per foot . . . 1.6A x 20 yields a voltage drop of 320 millivolts . . . FOR THE SUPPLY run. I presume the pump(s) are grounded to the same fat-wire that runs from main battery(-) to the crankcase. > > >Same things for my ignitions. (It seems to be 0,4amp/each) may I use >14AWG for fuel pump and 16 awg for ignition ? (4 degrees Celsius >only increase of temperature I calculate, I can take smaller wire >not ? But up to what size to be safe, for my tezfel wire, ) 20AWG here too would be quite sufficient. >2)I have the OVP kit Bandc.aero and I have to set it close to the >alternator o i can set it close to the switching panel ? (without >changing the 5 amp breaker du to length of the wire ?) Install up front close to breaker. >3)I don't know how to wire my bandc-aero OVP kit. they sent me this >diagram and did not succeeded to have another precision: > >http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z17K.pdf > >Problem is that I don't have a dynamo. I have a car alternator of 30A. > >Z19Rb don't show the relay and warning light that I have. Wire as shown in Z-19 . . . you don't need the relay. BE SURE THAT opening the control wire to your alternator actually opens the alternator's field supply. Unless this is true, your alternator may not be compatible with any form of external overvoltage management. Bob . . . ________________________________________________________________________________
Date: Jun 13, 2017
Thanks Kelly.Follow up question... I can put a second comm antenna about 3 feet from the existing antenna, but that will place it about 1 foot from th e transponder antenna.Would that be OK since the transponder is so much hig her freq? Jeff On Monday, June 12, 2017 8:47 AM, Kelly McMullen wrote: om> Find a place for second antenna. If there isn't room on belly, consider locations on top of fuselage, or.. I've had success locating a CI-122 on an inspection plate on underside of a wing. I'm not aware of any reasonable device that allow sharing a transmitting antenna with adequate protection from frying the receiver on the other radio. On 6/12/2017 5:13 AM, Jeff Bertsch wrote: > Hello.=C2- I've added a new comm radio on my RV4.=C2- I currently hav e a > Comant CI-122 bent whip.=C2- Space is limited on the belly of the RV4. >=C2- Would it be OK to use a multiplexer and share the antenna or try to > find a spot for another antenna?=C2- What multiplexer would you recomme nd? > > Thanks. > > Jeff Bertsch - S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Subject: RV-8 wiring diagram
Date: Jun 13, 2017
Current starting the wiring on the RV-8 I am building. Attached is the diagram for the main power and charging system. I would like a second opinion to make sure I have not made a mistake. Ignore the avionics bus that's planning for the future if I ever add that. The wiring from the circuit breakers is all sized properly. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470036#470036 Attachments: http://forums.matronics.com//files/n285ts_power_189.bmp ________________________________________________________________________________
Date: Jun 13, 2017
At 11:25 PM 6/12/2017, you wrote: >Thanks Kelly. >Follow up question... I can put a second comm antenna about 3 feet >from the existing antenna, but that will place it about 1 foot from >the transponder antenna. >Would that be OK since the transponder is so much higher freq? > >Jeff If it is a problem, the difficulty will manifest in misbehaviors by the comm radio. You may hear a burst of 'buzz' every time the reply light comes on. Baring that, proximity to the antenna should not be a problem. Bob . . . ________________________________________________________________________________
Date: Jun 13, 2017
I would rather see you get the separation by putting a com antenna under a wing. It may be okay, but what is backup plan if it doesn't work and you have a hole to patch in the fuselage? It is much easier to make an inspection plate mounting that can be discarded if you don't like the results. On 6/13/2017 5:09 AM, Robert L. Nuckolls, III wrote: > At 11:25 PM 6/12/2017, you wrote: >> Thanks Kelly. >> Follow up question... I can put a second comm antenna about 3 feet >> from the existing antenna, but that will place it about 1 foot from >> the transponder antenna. >> Would that be OK since the transponder is so much higher freq? >> >> Jeff > > If it is a problem, the difficulty will manifest in > misbehaviors by the comm radio. You may hear a burst > of 'buzz' every time the reply light comes on. Baring > that, proximity to the antenna should not be a problem. > > > Bob . . . > ________________________________________________________________________________
Subject: Re: RV-8 wiring diagram
Date: Jun 13, 2017
It seems that some of the feeders are larger than necessary and could be smaller by one or two wire sizes. Can the main power bus feeder be smaller? Can the E-Bus feeder be smaller? The E-Bus bridge diode only needs one wire feeding it, not two. If the E-Bus switch is inadvertently left on during engine start, the aux battery will help crank the engine and could trip its circuit breaker. That problem can be eliminated by connecting the output of the E-Bus relay to one of the inputs of the bridge diode. Having an engine start button on the control stick could be dangerous. Is it really necessary? An avionics switch is a single point of failure. Evidently it happened in Ron Simonton's RV. Read his post: http://www.vansairforce.com/community/showpost.php?p=1167360&postcount=7 -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470046#470046 ________________________________________________________________________________
Subject: MP100701 Open Collector To Ground Position Sensor
Date: Jun 13, 2017
Hi All, Sorry to keep bugging you all on this topic however this is a bit over my head and you are the smartest guys in the (cyber) room and I would greatly appreciate your comments/feedback/suggestions (again). Attached is a PDF data sheet of a sensor I think will work for my application. Could someone PLEASE look it over and tell me IF this sensor will work with my application? I like this particular sensor because it is the right dimensions (length and width) for my application (I have VERY LIMITED space) and this sensor is an open collector to ground that I need for the Dynon Skyview EMS=85plus it is only 15 bucks!!! The questions I have are: -The data sheet states =93Open Collector (NPN) output can be used with bipolar or cmos logic circuits with suitable pull up resistor=94. I do not know what this means. I want to have one of my Dynon Skyview EMS pins watch for ground on a wire. If the pin does not see ground then the display annunciation will be dark however when the pin sees a connection to ground then the EFIS display will annunciate an =93ICE=94 warning (it has to look for ground because I need to share this EFIS input pin with the Dynon AOA/Pitot tube heater system monitor wire. This monitor wire is open when the pitot heater system is working correctly however when the pitot heater system fails, the system connects this monitor wire to ground). -This sensor has three wires: Brown =93VCC=94, Blue =93ground=94, and Black =93output=94. I assume the Brown wire needs to have a 5 to 12 VDC power source and the Black wire would go to my EFIS pin? -I see where the =93pull up resistor=94 is supposed to be installed however I do not know what value resistor to use or if it is required. -If the sensor relies on the magnetic attraction of the target magnet and the target magnet moves away because it is mounted on the door however still attached to the air box structure is a second magnet that is located only =BD inch next to the sensor, will that second magnet effect the operation of the switch? -I want to use the Dynon Skyview PIN 18 as the power source for this sensor. PIN 18 is a 5 VDC power source that is output limited to 300 mA. I am already using that pin to power a McLagan Enterprises CS-6AB current sensor so I do not want to overtax the 300 mA output rating of the pin. Does anyone know what the current draw of the CS-6AB (it cannot be much) A recap on the project=85I built an air filter box out of fiberglass and it has a reed type valve alternate air that is made from fiberglass and is held closed by a fiberglass spring and two magnets (one on the door and one in the fiberglass air box structure). The design is such that should the big air filter become iced up the engine vacuum will pull against the door=92s spring and the two magnets and open the door (one magnet will ride away because it is mounted on the door while the second magnet will stay attached to the air box structure). I want to monitor the position of the door with the Dynon EFIS pin input. .. THANKS AGAIN and I am VERY GRATEFUL for the help!!! Bill Hunter ________________________________________________________________________________
Date: Jun 13, 2017
Subject: Re: MP100701 Open Collector To Ground Position Sensor
Attached is a PDF data sheet of a sensor I think will work for my application. Could someone PLEASE look it over and tell me IF this sensor will work with my application? I'm sure it will . . . I like this particular sensor because it is the right dimensions (length and width) for my application (I have VERY LIMITED space) and this sensor is an open collector to ground that I need for the Dynon Skyview EMS=85plus it is only 15 bucks!!! . . . ain't 'lectronics wunderful? The questions I have are: -The data sheet states =93Open Collector (NPN) output can be used with bipolar or cmos logic circuits with suitable pull up resistor=94. I do not know what this means. I want to have one of my Dynon Skyview EMS pins watch for ground on a wire. If the pin does not see ground then the display annunciation will be dark however when the pin sees a connection to ground then the EFIS display will annunciate an =93ICE=94 warning (it has to look for ground because I need to share this EFIS input pin with the Dynon AOA/Pitot tube heater system monitor wire. This monitor wire is open when the pitot heater system is working correctly however when the pitot heater system fails, the system connects this monitor wire to ground). If the Dynon will sense a dry switch, then some form of pull-up resistor is included within the Dynon's signal conditioning. This makes your open-collector sensor ideal to task . . . no additional electronics required. -This sensor has three wires: Brown =93VCC=94, Blue =93ground=94, and Black =93output=94. I assume the Brown wire needs to have a 5 to 12 VDC power source and the Black wire would go to my EFIS pin? That would be my interpretation as well. -I see where the =93pull up resistor=94 is supposed to be installed however I do not know what value resistor to use or if it is required. Not reqd. -If the sensor relies on the magnetic attraction of the target magnet and the target magnet moves away because it is mounted on the door however still attached to the air box structure is a second magnet that is located only =BD inch next to the sensor, will that second magnet effect the operation of the switch? Maybe . . . easy to check on the bench. No way to increase that separation? -I want to use the Dynon Skyview PIN 18 as the power source for this sensor. PIN 18 is a 5 VDC power source that is output limited to 300 mA. I am already using that pin to power a McLagan Enterprises CS-6AB current sensor so I do not want to overtax the 300 mA output rating of the pin. Does anyone know what the current draw of the CS-6AB (it cannot be much) . . . it seems unlikely that a 'sensor' would need more than a handful of milliamps. I think the risk is low. A recap on the project=85I built an air filter box out of fiberglass and it has a reed type valve alternate air that is made from fiberglass and is held closed by a fiberglass spring and two magnets (one on the door and one in the fiberglass air box structure). The design is such that should the big air filter become iced up the engine vacuum will pull against the door=92s spring and the two magnets and open the door (one magnet will ride away because it is mounted on the door while the second magnet will stay attached to the air box structure). I want to monitor the position of the door with the Dynon EFIS pin input. I think you're on the right track. Some fiddling with the proposed magnets on the bench should assuage concerns for untoward interactions. Bob . . . ________________________________________________________________________________
Date: Jun 13, 2017
On Tue, Jun 13, 2017 at 2:33 PM, William Hunter wrote: > Hi All, > > > Sorry to keep bugging you all on this topic however this is a bit over my > head and you are the smartest guys in the (cyber) room and I would greatl y > appreciate your comments/feedback/suggestions (again). > > > Attached is a PDF data sheet of a sensor I think will work for my > application. Could someone PLEASE look it over and tell me IF this senso r > will work with my application? > > > I like this particular sensor because it is the right dimensions (length > and width) for my application (I have VERY LIMITED space) and this sensor > is an open collector to ground that I need for the Dynon Skyview EMS plus > it is only 15 bucks!!! > > > The questions I have are: > > > -The data sheet states =9COpen Collector (NPN) output can be used w ith > bipolar or cmos logic circuits with suitable pull up resistor=9D. I do not > know what this means. I want to have one of my Dynon Skyview EMS pins > watch for ground on a wire. If the pin does not see ground then the > display annunciation will be dark however when the pin sees a connection to > ground then the EFIS display will annunciate an =9CICE=9D war ning (it has to > look for ground because I need to share this EFIS input pin with the Dyno n > AOA/Pitot tube heater system monitor wire. This monitor wire is open whe n > the pitot heater system is working correctly however when the pitot heate r > system fails, the system connects this monitor wire to ground). > > > -This sensor has three wires: Brown =9CVCC=9D, Blue =9C ground=9D, and Black > =9Coutput=9D. I assume the Brown wire needs to have a 5 to 1 2 VDC power source > and the Black wire would go to my EFIS pin? > > > -I see where the =9Cpull up resistor=9D is supposed to be ins talled however I > do not know what value resistor to use or if it is required. > > > -If the sensor relies on the magnetic attraction of the target magnet and > the target magnet moves away because it is mounted on the door however > still attached to the air box structure is a second magnet that is locate d > only =C2=BD inch next to the sensor, will that second magnet effect the > operation of the switch? > > > -I want to use the Dynon Skyview PIN 18 as the power source for this > sensor. PIN 18 is a 5 VDC power source that is output limited to 300 mA. > I am already using that pin to power a McLagan Enterprises CS-6AB current > sensor so I do not want to overtax the 300 mA output rating of the pin. > Does anyone know what the current draw of the CS-6AB (it cannot be much) > > > A recap on the projectI built an air filter box out of fiberglas s and it > has a reed type valve alternate air that is made from fiberglass and is > held closed by a fiberglass spring and two magnets (one on the door and o ne > in the fiberglass air box structure). The design is such that should the > big air filter become iced up the engine vacuum will pull against the > door=99s spring and the two magnets and open the door (one magnet w ill ride > away because it is mounted on the door while the second magnet will stay > attached to the air box structure). I want to monitor the position of th e > door with the Dynon EFIS pin input. > > .. > > > THANKS AGAIN and I am VERY GRATEFUL for the help!!! > > > Bill Hunter > > Bill, The pullup resistor is shown on that data sheet, in the schematic, which also shows all the wire connections to make it work. It should do what you want, but it's not that much smaller than many of the devices I sent earlier. It would save you (and us) a lot of time if you spell out all of your requirements, including size (dimensions) in your initial question. If you really need small, try this: http://www.mouser.com/ProductDetail/MEDER-electronic-Standex/KSK-1C90U-1015 /?qs=sGAEpiMZZMvFdY0L2HfHxsLmHWXxOk2BtXfBXWgtRX0%3d or use the google to search for 'form C reed switch'. No electronics, just a single pole, double throw magnetically activated switch (electrically, it looks just like a SPDT toggle switch). The one I linked is 'bare' and could be easily fit into a 3/8" diameter by 1" long space. Couple more thoughts. Do you really need two magnets? Have you checked whether the engine can actually overcome the magnets, if the inlet is blocked? (Many newer magnets are quite powerful.) If you use a long narrow magnet & just a piece of steel on the stationary side, you could probably use the same magnet to hold the door shut and activate the reed switch (mounted away from the steel, toward the other pole of the magnet). Charlie ________________________________________________________________________________
Date: Jun 13, 2017
The SkyView EMS has at least 9 general purpose inputs. If all of them are not already being used, then I suggest that the magnetic sensor be connected to its own discrete EMS input instead of sharing an input with the pitot heat sensor. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470075#470075 ________________________________________________________________________________
Date: Jun 13, 2017
Thanks Bob and Charlie!!! > Do you really need two magnets? Have you checked whether the engine can actually overcome the magnets, if the inlet is blocked? (Many newer magnets are quite powerful.) If you use a long narrow magnet & just a piece of steel on the stationary side, you could probably use the same magnet to hold the door shut and activate the reed switch (mounted away from the steel, toward the other pole of the magnet). This design is not exactly in BETA test at this point... perhaps more like Charlie minus testing and the plan has changed a bit (I'm sure that I am the only one in Aviation that has had design creep and concept validation issues). I really do not know how strong the magnets need to be... I know...the size of the flapper door... the size of the main filter... the engine is 540 CID...I know that I want the door to stay closed until the air filter gets blocked just a smidgen and then I want the flapper to pop fully open... the indicator light will help decide how large the magnets need to be. So... I just replaced my worn out electric sonic toothbrush and whilst conducting the R&R procedure the two brush heads whacked together on the counter top and got stuck together on the magnet ends and just like magic I had a "hey what if..." moment. These magnets are like really... REALLY small and if I place them on one corner of the door (one magnet on the door and one on the air box structure) then there will be about 2.5 inches of distance to the adjacent corner where the magic switch can be installed... then perhaps there will be enough distance to reduce any magnetic interference. I will buy this sensor and conduct some fiddling around and report back. Also... the original plan was to have the Dynon heater sensor on one EMS sensor pin and the flapper door gizmo on a different pin until I ran out of pins. Then you all suggested this fancy proximity sensor and I figured that I could combine both ice related contraptions on a single pin and since the Dynon sensor is a sink to ground I need a switch gizmo that will also sink to ground... Anyhoo.. THANKS AGAIN. It will be a couple of weeks before I can report back. Bill On Jun 13, 2017 6:31 PM, "Charlie England" wrote: > > > On Tue, Jun 13, 2017 at 2:33 PM, William Hunter < > billhuntersemail(at)gmail.com> wrote: > >> Hi All, >> >> >> >> Sorry to keep bugging you all on this topic however this is a bit over m y >> head and you are the smartest guys in the (cyber) room and I would great ly >> appreciate your comments/feedback/suggestions (again). >> >> >> >> Attached is a PDF data sheet of a sensor I think will work for my >> application. Could someone PLEASE look it over and tell me IF this sens or >> will work with my application? >> >> >> >> I like this particular sensor because it is the right dimensions (length >> and width) for my application (I have VERY LIMITED space) and this senso r >> is an open collector to ground that I need for the Dynon Skyview EMS plus >> it is only 15 bucks!!! >> >> >> >> >> >> The questions I have are: >> >> >> >> -The data sheet states =9COpen Collector (NPN) output can be used with >> bipolar or cmos logic circuits with suitable pull up resistor=9D. I do not >> know what this means. I want to have one of my Dynon Skyview EMS pins >> watch for ground on a wire. If the pin does not see ground then the >> display annunciation will be dark however when the pin sees a connection to >> ground then the EFIS display will annunciate an =9CICE=9D wa rning (it has to >> look for ground because I need to share this EFIS input pin with the Dyn on >> AOA/Pitot tube heater system monitor wire. This monitor wire is open wh en >> the pitot heater system is working correctly however when the pitot heat er >> system fails, the system connects this monitor wire to ground). >> >> >> >> -This sensor has three wires: Brown =9CVCC=9D, Blue =9Cground=9D, and Black >> =9Coutput=9D. I assume the Brown wire needs to have a 5 to 12 VDC power source >> and the Black wire would go to my EFIS pin? >> >> >> >> -I see where the =9Cpull up resistor=9D is supposed to be in stalled however I >> do not know what value resistor to use or if it is required. >> >> >> >> -If the sensor relies on the magnetic attraction of the target magnet an d >> the target magnet moves away because it is mounted on the door however >> still attached to the air box structure is a second magnet that is locat ed >> only =C2=BD inch next to the sensor, will that second magnet effect the >> operation of the switch? >> >> >> >> -I want to use the Dynon Skyview PIN 18 as the power source for this >> sensor. PIN 18 is a 5 VDC power source that is output limited to 300 mA . >> I am already using that pin to power a McLagan Enterprises CS-6AB curren t >> sensor so I do not want to overtax the 300 mA output rating of the pin. >> Does anyone know what the current draw of the CS-6AB (it cannot be much) >> >> >> >> A recap on the projectI built an air filter box out of fibergla ss and it >> has a reed type valve alternate air that is made from fiberglass and is >> held closed by a fiberglass spring and two magnets (one on the door and one >> in the fiberglass air box structure). The design is such that should th e >> big air filter become iced up the engine vacuum will pull against the >> door=99s spring and the two magnets and open the door (one magnet will ride >> away because it is mounted on the door while the second magnet will stay >> attached to the air box structure). I want to monitor the position of t he >> door with the Dynon EFIS pin input. >> >> .. >> >> >> >> THANKS AGAIN and I am VERY GRATEFUL for the help!!! >> >> >> >> Bill Hunter >> >> >> >> >> >> >> >> >> > Bill, > > The pullup resistor is shown on that data sheet, in the schematic, which > also shows all the wire connections to make it work. It should do what yo u > want, but it's not that much smaller than many of the devices I sent > earlier. It would save you (and us) a lot of time if you spell out all of > your requirements, including size (dimensions) in your initial question. > > If you really need small, try this: > http://www.mouser.com/ProductDetail/MEDER-electronic-Standex/KSK-1C90U- > 1015/?qs=sGAEpiMZZMvFdY0L2HfHxsLmHWXxOk2BtXfBXWgtRX0%3d > > or use the google to search for 'form C reed switch'. No electronics, jus t > a single pole, double throw magnetically activated switch (electrically, it > looks just like a SPDT toggle switch). The one I linked is 'bare' and cou ld > be easily fit into a 3/8" diameter by 1" long space. > > Couple more thoughts. Do you really need two magnets? Have you checked > whether the engine can actually overcome the magnets, if the inlet is > blocked? (Many newer magnets are quite powerful.) If you use a long narro w > magnet & just a piece of steel on the stationary side, you could probably > use the same magnet to hold the door shut and activate the reed switch > (mounted away from the steel, toward the other pole of the magnet). > > Charlie > ________________________________________________________________________________
Date: Jun 14, 2017
>d > >These magnets are like really... REALLY small and if I place them on >one corner of the door (one magnet on the door and one on the air >box structure) then there will be about 2.5 inches of distance to >the adjacent corner where the magic switch can be installed... then >perhaps there will be enough distance to reduce any magnetic >interference. I will buy this sensor and conduct some fiddling >around and report back. Ohhhh . . I thought the magnets were going to be CLOSE. 2.5" is like 'across the street'. If they were, say 0.5" apart, there MIGHT be valid interaction concerns to be resolved but 2.5" is plenty. I don't recall now which 60's Cessna used a similar alternate air door but the magnet holding it closed was a rather pedestrian cabinet door latch. Gravity would re-close the door. There were no annunciators on that system. The door magnet doesn't want/need to be very stout . . . pressure drop through a clean filter is, by design, as low as practical . . . measured in inches of water. You can calculate the force offered by such differentials and use it to test the release pressure of the finished assembly. Just remember that the total force is spread out over the door area and averages 1/2 the total applied to center of the door (class 2 lever). There is a boat load of magnet choices on eBay including disks with countersunk holes for screw mounting. http://tinyurl.com/ycoxy94d A spring-force gage can be crafted to check the door open calibration. I think I'd encase the mounted magnet in a layer of glass . . . while the risk is low, these things do break and the particles are akin to crushed carbide . . . not something friendly to engines. Bob . . . ________________________________________________________________________________
Date: Jun 14, 2017
Thanks for your comment i appreciate the feed back. Some of the feeders are bigger than they need to be but that's the wires I have. I see the downsides of having the start switch on the yoke but i do want it there. I have an enable switch which disarms the switch on the yoke. The enable switch also disconnects the e-bus during start. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470104#470104 ________________________________________________________________________________
Subject: Re: Question about Z19RB and OVP/Beaker and size wire
Date: Jun 14, 2017
Thank you Bob for your response. How could I check if my alternator is compatible with en external OVP before wiring it ? (it is not wired anymore) It was wired like the picture attached in this message. (drawn by constructeur) Thank you. Mickal Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470107#470107 Attachments: http://forums.matronics.com//files/capture_dcran_2017_06_14__171455_169.png http://forums.matronics.com//files/capture_dcran_2017_06_14__171448_651.png http://forums.matronics.com//files/capture_dcran_2017_06_14__170900_296.png http://forums.matronics.com//files/capture_dcran_2017_06_14__165206_149.png ________________________________________________________________________________
Date: Jun 14, 2017
OK, I overlooked the switch that isolates the E-Bus during engine start. Your wiring diagram looks OK to me. > The enable switch also disconnects the e-bus during start. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470114#470114 ________________________________________________________________________________
From: "William Hunter" <billhuntersemail(at)gmail.com>
Date: Jun 14, 2017
> I thought the magnets were going to be CLOSE. 2.5" is like 'across the street'. The flapper door is 4 inches long and 2.5 inches wide. Plan A (what is currently built) has a =BD inch diameter magnet mounted in the middle of the 2.5 inch door frame=85so not like across the street but in the same housing complex. These toothbrush magnets are very strong so perhaps I could install them on one corner and then the switch on the other corner. > I don't recall now which 60's Cessna used a similar alternate air door but the magnet holding it closed was a rather pedestrian cabinet door latch. Gravity would re-close the door. They stole my idea=85HOW RUDE!!! >There were no annunciators on that system. Sorta takes the fun out of it=85Well I suppose their engineering budget was a bit more than mine so they would not really need a monitoring circuit. I could teach my cute little EFIS girl to say =93MONITOR=94 when the door opens but I guess that might be too 2017=85a =93light=94 will do. .. Cheers!!! Bill Hunter From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Wednesday, June 14, 2017 6:08 AM Subject: Re: AeroElectric-List: MP100701 Open Collector To Ground Position Sensor d These magnets are like really... REALLY small and if I place them on one corner of the door (one magnet on the door and one on the air box structure) then there will be about 2.5 inches of distance to the adjacent corner where the magic switch can be installed... then perhaps there will be enough distance to reduce any magnetic interference. I will buy this sensor and conduct some fiddling around and report back. Ohhhh . . I thought the magnets were going to be CLOSE. 2.5" is like 'across the street'. If they were, say 0.5" apart, there MIGHT be valid interaction concerns to be resolved but 2.5" is plenty. I don't recall now which 60's Cessna used a similar alternate air door but the magnet holding it closed was a rather pedestrian cabinet door latch. Gravity would re-close the door. There were no annunciators on that system. The door magnet doesn't want/need to be very stout . . . pressure drop through a clean filter is, by design, as low as practical . . . measured in inches of water. You can calculate the force offered by such differentials and use it to test the release pressure of the finished assembly. Just remember that the total force is spread out over the door area and averages 1/2 the total applied to center of the door (class 2 lever). There is a boat load of magnet choices on eBay including disks with countersunk holes for screw mounting. http://tinyurl.com/ycoxy94d A spring-force gage can be crafted to check the door open calibration. I think I'd encase the mounted magnet in a layer of glass . . . while the risk is low, these things do break and the particles are akin to crushed carbide . . . not something friendly to engines. Bob . . . ________________________________________________________________________________
Date: Jun 15, 2017
Hi Joe Have you considerate to use EXP BUS, instead of discrete circuit breakers? I use them, they are very reliable. Advantages are it provide circuitry for the second battery, not so expensive and much less wiring. I'm not a representative :-) =F0=9F=98=84 I'm sorry if I throw you in another direction, but I think it's worth at least to give a thought. Regards Dilson Em 14 de jun de 2017 13:37, "user9253" escreveu: > > OK, I overlooked the switch that isolates the E-Bus during engine start. > Your wiring diagram looks OK to me. > > > The enable switch also disconnects the e-bus during start. > > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=470114#470114 > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Jun 15, 2017
wire At 10:17 AM 6/14/2017, you wrote: > >Thank you Bob for your response. > >How could I check if my alternator is compatible >with en external OVP before wiring it ? (it is not wired anymore) > >It was wired like the picture attached in this >message. (drawn by constructeur) > >Thank you. > >Micka=C3=ABl The last drawing is the 'magic' data. It shows that your alternator is externally regulated -AND- that the alternator control switch does indeed carry field excitation current. Here's an exemplar application of the crowbar ov module to your project. Emacs! Bob . . . ________________________________________________________________________________
Subject: com dual PWR/GND on two fuses?
Date: Jun 16, 2017
Hello, most avionics do have PWR and GND on two pins. My SL30 had even one used for the NAV part (3A fused) and one for the COM part (5A fused). I have to replace it with a new 8.33, but just going for a COM right now, that one has as well 2 pins each tied together, PWR onto a 10A fuse (8W COM). Is there any disadvantage, if I use the existing cabling with the 2x GND/PWR on extra fuses? Should I use 2x10A fuses (for a 8W com I found the 10A a bit high). Thanks for your advice Cheers Werner ________________________________________________________________________________
Date: Jun 16, 2017
Subject: Re: com dual PWR/GND on two fuses?
Hi Werner You may use the same cabling, connected to only one 10A fuse. After installation, just measure the current when transmitting, and then you could use a 7.5A fuse instead of the 10A. Cheers Carlos Enviado do meu iPhone No dia 16/06/2017, s 22:20, Werner Schneider escreveu: > > Hello, > > most avionics do have PWR and GND on two pins. My SL30 had even one used for the NAV part (3A fused) and one for the COM part (5A fused). > > I have to replace it with a new 8.33, but just going for a COM right now, that one has as well 2 pins each tied together, PWR onto a 10A fuse (8W COM). > > Is there any disadvantage, if I use the existing cabling with the 2x GND/PWR on extra fuses? Should I use 2x10A fuses (for a 8W com I found the 10A a bit high). > > Thanks for your advice > > Cheers Werner > > > ________________________________________________________________________________
Date: Jun 16, 2017
I have my SL-30 (14V) on 5 amp breaker for Com and 3 amp for Nav. Actual use, from what I gleaned from the manual is about 3 amp on transmit for the Com side. On 6/16/2017 2:20 PM, Werner Schneider wrote: > > Hello, > > most avionics do have PWR and GND on two pins. My SL30 had even one used > for the NAV part (3A fused) and one for the COM part (5A fused). > > I have to replace it with a new 8.33, but just going for a COM right > now, that one has as well 2 pins each tied together, PWR onto a 10A fuse > (8W COM). > > Is there any disadvantage, if I use the existing cabling with the 2x > GND/PWR on extra fuses? Should I use 2x10A fuses (for a 8W com I found > the 10A a bit high). > > Thanks for your advice > > Cheers Werner > > > ________________________________________________________________________________
Date: Jun 17, 2017
The ampacity of a single USB pin is about 5 amps. Many avionics use dual USB pins for power to divide the current so that USB pins do not get warm. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470188#470188 ________________________________________________________________________________
Date: Jun 17, 2017
Many thanks ! Mickal Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470189#470189 ________________________________________________________________________________
Subject: G4 stick grip wiring
Date: Jun 17, 2017
Hi all, A group of buddies asked me to devise the wiring of a pair of Ray Allen G 405 stick grips, but they can't remember whether they came with any documentation, and no wiring information is available on Ray Allen's website. Of course my buddies are in a hurry and would like to have schematics completed over the weekend... I sent an email to Ray Allen but they'll probably won't answer before Monday or Tuesday. Does any of you gentlemen and ladies happen to have any information as to the color code etc. of those particular stick grips ? Thanks in advance for your inputs, -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Date: Jun 17, 2017
Subject: Re: G4 stick grip wiring
Gilles, I have attached a copy of what I received with my G407 grips, which also includes the G405. Ed Godfrey On 6/17/2017 8:28 AM, GTH wrote: > > Hi all, > > A group of buddies asked me to devise the wiring of a pair of Ray > Allen G 405 stick grips, but they can't remember whether they came > with any documentation, and no wiring information is available on Ray > Allen's website. > > Of course my buddies are in a hurry and would like to have schematics > completed over the weekend... > > I sent an email to Ray Allen but they'll probably won't answer before > Monday or Tuesday. > > Does any of you gentlemen and ladies happen to have any information as > to the color code etc. of those particular stick grips ? > > Thanks in advance for your inputs, > ________________________________________________________________________________
Date: Jun 17, 2017
/Le 17/06/2017 15:44, Ed Godfrey a crit : / > /Gilles, > I have attached a copy of what I received with my G407 grips, > which also includes the G405. / Ed, This is exactly what I was looking for. Thanks a lot ! -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Date: Jun 19, 2017
Hi Gilles, aircraftspruce most of the time has documentation to what they sell: http://www.aircraftspruce.com/catalog/pdf/G207instruct.pdf I know not before the weekend bust I was abstinent on emails :) Cheers Werner On 17.06.2017 15:28, GTH wrote: > > Hi all, > > A group of buddies asked me to devise the wiring of a pair of Ray Allen > G 405 stick grips, but they can't remember whether they came with any > documentation, and no wiring information is available on Ray Allen's > website. ________________________________________________________________________________
Date: Jun 19, 2017
/Le 19/06/2017 09:56, Werner Schneider a crit : / > / > Hi Gilles, > aircraftspruce most of the time has documentation to what they sell: > > http://www.aircraftspruce.com/catalog/pdf/G207instruct.pdf > / Hi Werner, Thanks for responding. Unfortunately the Series 4 stick grip document remains unpublished to date. Thanks to the great guys on the 'List, I got the documentation within hours, and was able to deliver the schematics on time ! Thank you everyone ! -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Subject: Re: Onex antenna location
Date: Jun 19, 2017
The gear legs will affect the radio transmissions and reception. Exactly how much can only be determined by testing. You can install the antenna then go fly and try it out. You might be satisfied with it. Or maybe not. An option is to mount the com antenna on top of the airplane. Theoretically the airplane will block the signal from reaching the ground. But in practice, top mounted antennas work fine. The same might be true for an antenna mounted between the gear legs. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470234#470234 ________________________________________________________________________________
Date: Jun 19, 2017
From: Robert McCallum <robert.mccallum2(at)sympatico.ca>
Always bear in mind that the fuses are sized to protect the wire and what is connected at the other end (in this case your radio) has no influence on the fuse size used. As long as the wires are adequate for the 10 Amps then 10 Amp fuses are fine and certainly if the existing wiring will supply the new device's requirements then they may be reused/re-purposed. Bob McC > > ---------- Original Message ---------- > From: Werner Schneider <glastar(at)gmx.net> > Date: June 16, 2017 at 5:20 PM > > > > > Hello, > > most avionics do have PWR and GND on two pins. My SL30 had even one used > for the NAV part (3A fused) and one for the COM part (5A fused). > > I have to replace it with a new 8.33, but just going for a COM right > now, that one has as well 2 pins each tied together, PWR onto a 10A fuse > (8W COM). > > Is there any disadvantage, if I use the existing cabling with the 2x > GND/PWR on extra fuses? Should I use 2x10A fuses (for a 8W com I found > the 10A a bit high). > > Thanks for your advice > > Cheers Werner > > > > ________________________________________________________________________________
Date: Jun 19, 2017
I have a bent whip on my RV4 between the gear legs just aft of the firewall. I haven't had any problem communicating once airborne, but on the ground at certain airports I have a heck of a time getting hold of the tower. I'm building a full IFR RV-7A, and plan to put one antennae on the bottom of the plane, and the secondary radio antennae on the top in order to switch to whichever radio works best per the situation... Tom -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of user9253 Sent: Monday, June 19, 2017 12:10 PM Subject: AeroElectric-List: Re: Onex antenna location The gear legs will affect the radio transmissions and reception. Exactly how much can only be determined by testing. You can install the antenna then go fly and try it out. You might be satisfied with it. Or maybe not. An option is to mount the com antenna on top of the airplane. Theoretically the airplane will block the signal from reaching the ground. But in practice, top mounted antennas work fine. The same might be true for an antenna mounted between the gear legs. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470234#470234 ________________________________________________________________________________
Date: Jun 19, 2017
I had the same problem on my RV-10. I moved one antenna to the top, problem solved. Rene' 801-721-6080 -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Tom Chapman Sent: Monday, June 19, 2017 12:19 PM Subject: RE: AeroElectric-List: Re: Onex antenna location I have a bent whip on my RV4 between the gear legs just aft of the firewall. I haven't had any problem communicating once airborne, but on the ground at certain airports I have a heck of a time getting hold of the tower. I'm building a full IFR RV-7A, and plan to put one antennae on the bottom of the plane, and the secondary radio antennae on the top in order to switch to whichever radio works best per the situation... Tom -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of user9253 Sent: Monday, June 19, 2017 12:10 PM Subject: AeroElectric-List: Re: Onex antenna location The gear legs will affect the radio transmissions and reception. Exactly how much can only be determined by testing. You can install the antenna then go fly and try it out. You might be satisfied with it. Or maybe not. An option is to mount the com antenna on top of the airplane. Theoretically the airplane will block the signal from reaching the ground. But in practice, top mounted antennas work fine. The same might be true for an antenna mounted between the gear legs. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470234#470234 ________________________________________________________________________________
Date: Jun 19, 2017
Hi Bob You are right that the fuse is there to protect the wire, but the size (in A) of the fuse is a function of the current which is drawn by what is connected at the other end of the wire, isn=99t it? Otherwise you could put a 1A fuse to protect a #24 wire with a pitot heater at the end, and you would never see that heater working when you wanted it. With due respect Carlos De: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] Em nome de Robert McCallum Enviada: Monday, June 19, 2017 6:35 PM Para: aeroelectric-list Assunto: Re: AeroElectric-List: com dual PWR/GND on two fuses? Always bear in mind that the fuses are sized to protect the wire and what is connected at the other end (in this case your radio) has no influence on the fuse size used. As long as the wires are adequate for the 10 Amps then 10 Amp fuses are fine and certainly if the existing wiring will supply the new device's requirements then they may be reused/re-purposed. Bob McC ---------- Original Message ---------- From: Werner Schneider <glastar(at)gmx.net <mailto:glastar(at)gmx.net> > Date: June 16, 2017 at 5:20 PM > Hello, most avionics do have PWR and GND on two pins. My SL30 had even one used for the NAV part (3A fused) and one for the COM part (5A fused). I have to replace it with a new 8.33, but just going for a COM right now, that one has as well 2 pins each tied together, PWR onto a 10A fuse (8W COM). Is there any disadvantage, if I use the existing cabling with the 2x GND/PWR on extra fuses? Should I use 2x10A fuses (for a 8W com I found the 10A a bit high). Thanks for your advice Cheers W-======================== ========= > ________________________________________________________________________________
Date: Jun 19, 2017
Not Bob, However, the wire has to be sized at a minimum to carry the anticipated load, so you would not have the situation you describe. On the other hand, it is common that relatively small loads, say 1 amp are carried on 18-22 gauge wire, and would be fused for what the wire can carry, usually more than what the load is. Another common occurrence is that wires for lighting on a plane were sized for an incandescent load, but the lamps have all been replaced with LEDs that draw 1/5th the amount. The circuit breakers would not change, because the wiring did not change. On 6/19/2017 2:38 PM, Carlos Trigo wrote: > Hi Bob > > You are right that the fuse is there to protect the wire, but the size > (in A) of the fuse is a function of the current which is drawn by what > is connected at the other end of the wire, isnt it? > > Otherwise you could put a 1A fuse to protect a #24 wire with a pitot > heater at the end, and you would never see that heater working when you > wanted it. > > With due respect > > Carlos > > *De:*owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] *Em nome de > *Robert McCallum > *Enviada:* Monday, June 19, 2017 6:35 PM > *Para:* aeroelectric-list > *Assunto:* Re: AeroElectric-List: com dual PWR/GND on two fuses? > > Always bear in mind that the fuses are sized to protect the wire and > what is connected at the other end (in this case your radio) has no > influence on the fuse size used. > > As long as the wires are adequate for the 10 Amps then 10 Amp fuses are > fine and certainly if the existing wiring will supply the new device's > requirements then they may be reused/re-purposed. > > Bob McC > > ---------- Original Message ---------- > From: Werner Schneider <glastar(at)gmx.net <mailto:glastar(at)gmx.net>> > Date: June 16, 2017 at 5:20 PM > > > > > > Hello, > > most avionics do have PWR and GND on two pins. My SL30 had even one > used > for the NAV part (3A fused) and one for the COM part (5A fused). > > I have to replace it with a new 8.33, but just going for a COM right > now, that one has as well 2 pins each tied together, PWR onto a 10A > fuse > (8W COM). > > Is there any disadvantage, if I use the existing cabling with the 2x > GND/PWR on extra fuses? Should I use 2x10A fuses (for a 8W com I found > the 10A a bit high). > > Thanks for your advice > > Cheers W-================================= > > > > ________________________________________________________________________________
Date: Jun 20, 2017
Ok after reading again through the AeroElectric Connection about wires and fuses I come to following conclusion. According the Icom Manual we use 2x AWG20, together they are fine for a 10A fuse, as I remain with my original SL-30 setup (2 wires with a fuse each) I could go for 7.5A each, considering the power of the unit I might stay with 2x 5 A out of convienence but will first check how much power the Icom draws when transmitting, I bet it will be below 5 :). If I would go for a dual cable crimped into a single fuse, I would rather prefer a 7.5A fuse, so when one wire breaks it will still be adequate, however taking into account the relative short wire a 10A might be fine. Thanks for your ideas. Cheers Werner On 19.06.2017 19:35, Robert McCallum wrote: > > Always bear in mind that the fuses are sized to protect the wire and > what is connected at the other end (in this case your radio) has no > influence on the fuse size used. > > As long as the wires are adequate for the 10 Amps then 10 Amp fuses > are fine and certainly if the existing wiring will supply the new > device's requirements then they may be reused/re-purposed. > > Bob McC > > ________________________________________________________________________________
Date: Jun 20, 2017
Some avionics use two pins for positive power and two pins for negative power. The reason for using two pins is not for redundancy. The reason is that if only one D-Sub pin carried all of the current, it would be overloaded. The problem of using two fuses is that if one fuse blows, then all of the current will flow through one D-Sub pin and overload it. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470261#470261 ________________________________________________________________________________
Date: Jun 20, 2017
Correct. However the assumption must be made that the wire installed is ade quate for the intended task. My point was that if you've installed a 14ga wire yo u protect it with the appropriate fuse for that wire, and not necessarily dow nsize the fuse because the device you're powering draws only 1 amp. Once adequacy of both wire and fuse is established then the fuse size chosen becomes a funct ion of the wire and not the connected load. Respectfully Bob McC > ---------- Original Message ---------- > From: Carlos Trigo <trigo(at)mail.telepac.pt> > Date: June 19, 2017 at 5:38 PM > > > Hi Bob > > > > You are right that the fuse is there to protect the wire, but the siz e (in > A) of the fuse is a function of the current which is drawn by what is > connected at the other end of the wire, isn=99t it? > > > > Otherwise you could put a 1A fuse to protect a #24 wire with a pitot > heater at the end, and you would never see that heater working when you w anted > it. > > > > With due respect > > Carlos > > > > De: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] Em nome de Robert > McCallum > Enviada: Monday, June 19, 2017 6:35 PM > Para: aeroelectric-list > Assunto: Re: AeroElectric-List: com dual PWR/GND on two fuses? > > > > Always bear in mind that the fuses are sized to protect the wire and what > is connected at the other end (in this case your radio) has no influence on > the fuse size used. > > As long as the wires are adequate for the 10 Amps then 10 Amp fuses a re > fine and certainly if the existing wiring will supply the new device's > requirements then they may be reused/re-purposed. > > Bob McC > > > > > > ---------- Original Message ---------- > > From: Werner Schneider <glastar(at)gmx.net <mailto:glastar(at)gmx.net > > > > Date: June 16, 2017 at 5:20 PM > > > > > > > > > > > Hello, > > > > most avionics do have PWR and GND on two pins. My SL30 had even one > > used > > for the NAV part (3A fused) and one for the COM part (5A fused) . > > > > I have to replace it with a new 8.33, but just going for a COM right > > now, that one has as well 2 pins each tied together, PWR onto a 10A > > fuse > > (8W COM). > > > > Is there any disadvantage, if I use the existing cabling with t he 2x > > GND/PWR on extra fuses? Should I use 2x10A fuses (for a 8W com I > > found > > the 10A a bit high). > > > > Thanks for your advice > > > > Cheers W-================== =============== > > > > > > > > > > ________________________________________________________________________________
Date: Jun 20, 2017
Thanks Joe for that warning, that is why I fuse for 5A only I still wonder the Icom uses a 10 A fuse for a 8W com and the SL30 was using a 5A for a 12 W COM. I believe the d-subs are rated 5A and if you break one cable it would be the same issue at the pin side. At the end I will see what it draws (the KX-125 I had at the begin on Xmit was drawing 3.8A) and leave another 30% as margin. it is just convenient to leave it as it is. Cheers Werner On 20.06.2017 14:49, user9253 wrote: > > Some avionics use two pins for positive power and two pins for negative power. The reason for using two pins is not for redundancy. The reason is that if only one D-Sub pin carried all of the current, it would be overloaded. The problem of using two fuses is that if one fuse blows, then all of the current will flow through one D-Sub pin and overload it. > ________________________________________________________________________________
Subject: Tosten grip wiring with car-relay for trim
Date: Jun 20, 2017
Hello, I want to wire my new grip tosten with my basic 12v electrical actuating as trim (up/down) pulling a spring. I bought a double car relay to do some test to find the good wiring diagram but before that I prefer asking in this forum how can I wire it if anybody know the response ? Before I was a double pole switch, wire by the previous owner. I had a problem with the previous wiring, when i actuated my trim, my compas begin to turn completely. The motor/switch were not close to the compas. I have tested to set the motor very close to the compas to do a test. Without all the wire juste motor and a small battery. And in this case it don't turn ! I don't understand why. I find this documentation to do my wire. Thank you in advance. Mickal Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470273#470273 Attachments: http://forums.matronics.com//files/capture_dcran_2017_06_20__170003_154.png http://forums.matronics.com//files/capture_dcran_2017_06_20__165117_106.png ________________________________________________________________________________
Date: Jun 20, 2017
It would be dumb to put a 20A breaker on a 2A load, regardless of what wire y ou used. On Jun 20, 2017, at 09:23, Robert McCallum w rote: Correct. However the assumption must be made that the wire installed is adeq uate for the intended task. My point was that if you've installed a 14ga wir e you protect it with the appropriate fuse for that wire, and not necessaril y downsize the fuse because the device you're powering draws only 1 amp. Onc e adequacy of both wire and fuse is established then the fuse size chosen be comes a function of the wire and not the connected load. Respectfully Bob McC > ---------- Original Message ---------- > From: Carlos Trigo <trigo(at)mail.telepac.pt> > Date: June 19, 2017 at 5:38 PM > > Hi Bob > > > > You are right that the fuse is there to protect the wire, but the size (in A) of the fuse is a function of the current which is drawn by what is conne cted at the other end of the wire, isn=99t it? > > > > Otherwise you could put a 1A fuse to protect a #24 wire with a pitot heate r at the end, and you would never see that heater working when you wanted it . > > > > With due respect > > Carlos > > > > De: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectri c-list-server(at)matronics.com] Em nome de Robert McCallum > Enviada: Monday, June 19, 2017 6:35 PM > Para: aeroelectric-list > Assunto: Re: AeroElectric-List: com dual PWR/GND on two fuses? > > > > Always bear in mind that the fuses are sized to protect the wire and what i s connected at the other end (in this case your radio) has no influence on t he fuse size used. > > As long as the wires are adequate for the 10 Amps then 10 Amp fuses are fi ne and certainly if the existing wiring will supply the new device's require ments then they may be reused/re-purposed. > > Bob McC > > ---------- Original Message ---------- > From: Werner Schneider <glastar(at)gmx.net> > Date: June 16, 2017 at 5:20 PM > > > > > Hello, > > most avionics do have PWR and GND on two pins. My SL30 had even one used > for the NAV part (3A fused) and one for the COM part (5A fused). > > I have to replace it with a new 8.33, but just going for a COM right > now, that one has as well 2 pins each tied together, PWR onto a 10A fuse > (8W COM). > > Is there any disadvantage, if I use the existing cabling with the 2x > GND/PWR on extra fuses? Should I use 2x10A fuses (for a 8W com I found > the 10A a bit high). > > Thanks for your advice > > Cheers W-====================== =========== > > > > > ________________________________________________________________________________
Date: Jun 20, 2017
Unless, of course, you have a limited number of fuse locations, and therefore, multiple non-critical 2A loads on one circuit that has wiring sized to accept a 20A fuse. The fuse protects the wire. (There's a period at the end of that sentence...) :-) On 6/20/2017 11:13 AM, Alec Myers wrote: > It would be dumb to put a 20A breaker on a 2A load, regardless of what > wire you used. > > On Jun 20, 2017, at 09:23, Robert McCallum > > > wrote: > > Correct. However the assumption must be made that the wire installed > is adequate for the intended task. My point was that if you've > installed a 14ga wire you protect it with the appropriate fuse for > that wire, and not necessarily downsize the fuse because the device > you're powering draws only 1 amp. Once adequacy of both wire and fuse > is established then the fuse size chosen becomes a function of the > wire and not the connected load. > > Respectfully > > Bob McC > > >> ---------- Original Message ---------- >> From: Carlos Trigo <trigo(at)mail.telepac.pt >> > >> Date: June 19, 2017 at 5:38 PM >> >> Hi Bob >> >> You are right that the fuse is there to protect the wire, but the >> size (in A) of the fuse is a function of the current which is drawn >> by what is connected at the other end of the wire, isnt it? >> >> Otherwise you could put a 1A fuse to protect a #24 wire with a pitot >> heater at the end, and you would never see that heater working when >> you wanted it. >> >> With due respect >> >> Carlos >> >> *De:* owner-aeroelectric-list-server(at)matronics.com >> >> [mailto:owner-aeroelectric-list-server(at)matronics.com] *Em nome de >> *Robert McCallum >> *Enviada:* Monday, June 19, 2017 6:35 PM >> *Para:* aeroelectric-list > > >> *Assunto:* Re: AeroElectric-List: com dual PWR/GND on two fuses? >> >> Always bear in mind that the fuses are sized to protect the wire and >> what is connected at the other end (in this case your radio) has no >> influence on the fuse size used. >> >> As long as the wires are adequate for the 10 Amps then 10 Amp fuses >> are fine and certainly if the existing wiring will supply the new >> device's requirements then they may be reused/re-purposed. >> >> Bob McC >> >> ---------- Original Message ---------- >> From: Werner Schneider <glastar(at)gmx.net <mailto:glastar(at)gmx.net>> >> Date: June 16, 2017 at 5:20 PM >> >> >> > >> >> Hello, >> >> most avionics do have PWR and GND on two pins. My SL30 had even >> one used >> for the NAV part (3A fused) and one for the COM part (5A fused). >> >> I have to replace it with a new 8.33, but just going for a COM right >> now, that one has as well 2 pins each tied together, PWR onto a >> 10A fuse >> (8W COM). >> >> Is there any disadvantage, if I use the existing cabling with the 2x >> GND/PWR on extra fuses? Should I use 2x10A fuses (for a 8W com I >> found >> the 10A a bit high). >> >> Thanks for your advice >> >> Cheers W-================================= >> >> > >> > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jun 20, 2017
It's not an absolute requirement that, for the fuse to do its job and protec t the wire, it has exactly to match the listed maximum current capacity of t he wire. A fuse can protect the wire just as well (and some who live on the e dge might say even better) if the fuse is chosen to be appropriate to the lo ad. However you want to punctuate it. On Jun 20, 2017, at 16:15, Charlie England wrote: Unless, of course, you have a limited number of fuse locations, and therefor e, multiple non-critical 2A loads on one circuit that has wiring sized to ac cept a 20A fuse. The fuse protects the wire. (There's a period at the end of that sentence... ) :-) > On 6/20/2017 11:13 AM, Alec Myers wrote: > It would be dumb to put a 20A breaker on a 2A load, regardless of what wir e you used. > > On Jun 20, 2017, at 09:23, Robert McCallum wrote: > > Correct. However the assumption must be made that the wire installed is ad equate for the intended task. My point was that if you've installed a 14ga w ire you protect it with the appropriate fuse for that wire, and not necessar ily downsize the fuse because the device you're powering draws only 1 amp. O nce adequacy of both wire and fuse is established then the fuse size chosen b ecomes a function of the wire and not the connected load. > Respectfully > Bob McC > >> ---------- Original Message ---------- >> From: Carlos Trigo <trigo(at)mail.telepac.pt> >> Date: June 19, 2017 at 5:38 PM >> >> Hi Bob >> >> >> >> You are right that the fuse is there to protect the wire, but the size (i n A) of the fuse is a function of the current which is drawn by what is conn ected at the other end of the wire, isn=99t it? >> >> >> >> Otherwise you could put a 1A fuse to protect a #24 wire with a pitot heat er at the end, and you would never see that heater working when you wanted i t. >> >> >> >> With due respect >> >> Carlos >> >> >> >> De: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectr ic-list-server(at)matronics.com] Em nome de Robert McCallum >> Enviada: Monday, June 19, 2017 6:35 PM >> Para: aeroelectric-list >> Assunto: Re: AeroElectric-List: com dual PWR/GND on two fuses? >> >> >> >> Always bear in mind that the fuses are sized to protect the wire and what is connected at the other end (in this case your radio) has no influence on the fuse size used. >> >> As long as the wires are adequate for the 10 Amps then 10 Amp fuses are f ine and certainly if the existing wiring will supply the new device's requir ements then they may be reused/re-purposed. >> >> Bob McC >> >> ---------- Original Message ---------- >> From: Werner Schneider <glastar(at)gmx.net> >> Date: June 16, 2017 at 5:20 PM >> >> t> >> >> Hello, >> >> most avionics do have PWR and GND on two pins. My SL30 had even one used >> for the NAV part (3A fused) and one for the COM part (5A fused). >> >> I have to replace it with a new 8.33, but just going for a COM right >> now, that one has as well 2 pins each tied together, PWR onto a 10A fuse >> (8W COM). >> >> Is there any disadvantage, if I use the existing cabling with the 2x >> GND/PWR on extra fuses? Should I use 2x10A fuses (for a 8W com I found >> the 10A a bit high). >> >> Thanks for your advice >> >> Cheers W-====================== =========== >> >> > >> > > > Virus-free. www.avast.com ________________________________________________________________________________
Date: Jun 20, 2017
Subject: Re: Tosten grip wiring with car-relay for trim
At 10:01 AM 6/20/2017, you wrote: > >Hello, > >I want to wire my new grip tosten with my basic 12v electrical >actuating as trim (up/down) pulling a spring. > >I bought a double car relay to do some test to find the good wiring >diagram but before that I prefer asking in this forum how can I wire >it if anybody know the response ? > >Before I was a double pole switch, wire by the previous owner. > >I had a problem with the previous wiring, when i actuated my trim, >my compas begin to turn completely. The motor/switch were not close >to the compas. > >I have tested to set the motor very close to the compas to do a >test. Without all the wire juste motor and a small battery. And in >this case it don't turn ! I don't understand why. It's difficult to diagnose the underlying physics for your observations without first- hand observation and diagnosis. I can tell you that incidences of wiring interfering with the compass is rare. Suggest you get the new trim system installed using the drawing cited below as guidance. Then see if the compass is still getting trashed . . . it will be easier to figure out why it IS having problems than to figure out why it is NOT having problems. >I find this documentation to do my wire. I think this wiring diagram is what you're needing. http://tinyurl.com/y7mwhg4t Bob . . . ________________________________________________________________________________
From: "John Ciolino" <JohnCiolino(at)carolina.rr.com>
Subject: Fuselink vs. blade fuse
Date: Jun 21, 2017
All, I am confused over the difference between using a fuselink and a blade fuse. Bob's Z-11 diagram shows a fuselink on the wire between the buss bar and the master switch. The rest of the electrical circuits are protected by blade fuses, why not use a blade fuse here? From Bob's write up on circuit protection in the AeroElectric Connection a fuselink is just another form of circuit protection. Why not just use a blade fuse everywhere? John Ciolino Bearhawk Patrol builder ________________________________________________________________________________
Subject: Re: Fuselink vs. blade fuse
Date: Jun 21, 2017
That fuselink is part of the crowbar over-voltage circuit. Since the crowbar circuit is more likely (than any other circuit) to nuisance trip its over current device, a circuit breaker is used to make it easier to reset. In many aircraft the circuit breaker might be located quite some distance from the main power bus. That long wire needs to be protected on the source end; thus a fuselink. Why not use a fuse? Because a fuse is fast blowing. A fuse, even a much larger fuse, will blow quicker than a smaller circuit breaker in series with it. I see no reason why the circuit breaker needs to be mounted on the down steam side of the master switch. Connect the circuit breaker directly to and close to the main power bus. Then no fuselink is needed. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470318#470318 ________________________________________________________________________________
Date: Jun 21, 2017
To avoid compass interference, do not run a single wire anywhere near the compass. Run the positive and negative wires together in a twisted pair. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470319#470319 ________________________________________________________________________________
Date: Jun 21, 2017
>I see no reason why the circuit breaker needs to be mounted on the >down steam side of the master switch. Connect the circuit breaker >directly to and close to the main power bus. Then no fuselink is needed. Not so much 'down stream' as 'adjacent to' that switch. Emacs! Fuse blocks are generally mounted out of sight, out of mind. The necessity for a single breaker to be part of the mix calls for extending the bus to the switch location . . . hence protection more robust than fuses, less robust than breakers, i.e. fusible link. Bob . . . ________________________________________________________________________________
Date: Jun 21, 2017
Subject: Re: Fuselink vs. blade fuse (CORRECTION)
>I see no reason why the circuit breaker needs to be mounted on the >down steam side of the master switch. Connect the circuit breaker >directly to and close to the main power bus. Then no fuselink is needed. Not so much 'down stream' as 'adjacent to' that switch. Emacs! Fuse blocks are generally mounted out of sight, out of mind. The necessity for a single breaker to be part of the mix calls for extending the bus to the switch location . . . hence protection more robust than BOTH fuses and breakers, i.e. fusible link. Bob . . . ________________________________________________________________________________
Date: Jun 21, 2017
Subject: Future of flight . . .
http://tinyurl.com/ybztoq3g Bob . . . ________________________________________________________________________________
Subject: Does Anyone Recognize This AMP 12 Pin Connector?
Date: Jun 21, 2017
Hi All, I need to rearrange the wires on this AMP 12 pin connector and my hope is to simply pop out the terminal ends and leave the wires still connected and just move them to the proper pin locations and pop them back in (I might have to re-bend the metal retainer tabs). The questions are: Does anyone know what terminal connector this is? How does one (me) unseat the terminal ends from the connector and what tool should be used? .. THANKS!!! Bill Hunter ________________________________________________________________________________
Date: Jun 21, 2017
Subject: Re: Future of flight . . .
Yes, the electric airplane... Eventually, we will have viable electric airplanes. The model airplane folks have largely gone to electric power... On Wed, Jun 21, 2017 at 11:57 AM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > http://tinyurl.com/ybztoq3g > > Bob . . . > ________________________________________________________________________________
Subject: Re: Does Anyone Recognize This AMP 12 Pin Connector?
Date: Jun 21, 2017
On 6/21/2017 12:02 PM, William Hunter wrote: > > Hi All, > > I need to rearrange the wires on this AMP 12 pin connector and my hope > is to simply pop out the terminal ends and leave the wires still > connected and just move them to the proper pin locations and pop them > back in (I might have to re-bend the metal retainer tabs). > > The questions are: > > Does anyone know what terminal connector this is? > > How does one (me) unseat the terminal ends from the connector and what > tool should be used? > > .. > > THANKS!!! > > Bill Hunter > It *looks* like what most would call a 'molex' style connector. If the pins are made like typical molex pins, there are 'barbs' on the pins, instead of in the connector body, as you see with dSub style connectors. The release tool would be inserted on the pin end to release the pin, instead of the wire end. Back before I learned to avoid molex's like the plague, I used to retract the barbs using a very small jeweler's screwdriver (too cheap to buy the proper tool). If it's really like a molex, here's a search for pin removal technique: https://www.google.com/search?q=molex+connector+pin+removal&oq=molex+connector+pin&aqs=chrome.5.0j69i57j0l4.10241j0j7&sourceid=chrome&ie=UTF-8 Since yours is an AMP brand connector, it may be made completely differently from the molex products. Here's a search for AMP pin removal: https://www.google.com/search?q=amp+connector+pin+removal&oq=amp+connector+pin+removal&aqs=chrome..69i57.171741j0j9&sourceid=chrome&ie=UTF-8 Charlie --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jun 21, 2017
At 12:02 PM 6/21/2017, you wrote: >Hi All, > >I need to rearrange the wires on this AMP 12 pin connector and my >hope is to simply pop out the terminal ends and leave the wires >still connected and just move them to the proper pin locations and >pop them back in (I might have to re-bend the metal retainer tabs). > >The questions are: > >Does anyone know what terminal connector this is? >How does one (me) unseat the terminal ends from the connector and >what tool should be used?\ What does the other end look like? TE Connectivity (AMP) offers a series of mate_n_lock connectors which all use the same pins If you look over this array of pins http://tinyurl.com/y8r989bn you will find that the 'business end' of pins and sockets are uniform while the wire ends are available in a range of sizes. I believe they all extract with the same tool. It would really help to see the other side of the connector. Bob . . . ________________________________________________________________________________
Date: Jun 21, 2017
It would really help to see the other side of the connector. I 'think' this is the tool you'll need TE CONNECTIVITY 305183 or one very similar. exact p/n to be determined. Bob . . . ________________________________________________________________________________
From: William Hunter <billhuntersemail(at)gmail.com>
Date: Jun 21, 2017
Thanks for the information... I knew I could count on you. I will report back Thanks, Bill Hunter On Jun 21, 2017 11:21 AM, "Robert L. Nuckolls, III" < nuckolls.bob(at)aeroelectric.com> wrote: > > It would really help to see the other > side of the connector. > > I 'think' this is the tool you'll need > > [image: TE CONNECTIVITY 305183] > > or one very similar. exact p/n to be > determined. > > > Bob . . . > ________________________________________________________________________________
Subject: RE: Future of flight...
Date: Jun 21, 2017
"Viable" for certain missions, sure. For an FBO renting airplanes for local flights, training flights, and $100 hamburger runs, we're almost there already. But "viable" for extended cross-country flights? That will take a while. It's not the airplane end that will be the slow part, it will be the charging infrastructure. Look how long it is taking to get the charging infrastructure built up for electric vehicles using the highway system, then imagine the economics involved in setting up "fast chargers" (2-4 hours for a full charge) at all the GA airports across the nation. And that's IF all the electric airplane vendors standardize on a charger type / plug / etc. I wish it were not true, because I would LOVE to have an electric car (but can't afford a Tesla), and there is no "fast-charge" station in between Dallas and Austin that would allow me to drive a Chevy Bolt (which would be my preferred "inexpensive" electric vehicle) from my home and my kids' place in Austin. Even with a 200+ mile range, I would need a charge before I got to their house... I suspect we'll experience similar stuff with electric planes for many, many years. Jim Parker ________________________________________________________________________________
Date: Jun 21, 2017
Subject: NiB - Dynon Skyview Touch 10" SV-D1000T For Sale...
I have a brand new in box Skyview Touch 10" screen for sale. Dynon web site price is $3905. I'll let this one go for the first $3500. I can accept Visa/MC for a 5% fee. Check's okay too, but it will have to clear before shipping. I'll send pictures of the actual unit upon request. I will ship it anywhere for the cost of required shipping (UPS/FedEx/USPS). I was going to use this unit in my RV-4 project, but decided to go with an HDX instead. Best Regards, Matt G Dralle | Matronics | 581 Jeannie Way | Livermore | CA | 94550 925-963-1130 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Jun 21, 2017
Why would you choose to buy a Cole powered car with gas near $2.00 / gal. headed toward $1.00 for the next several years. Tesla will require a few more billions of our tax dollars to stay afloat. Look what has happened to the solar plants. T. Boone Pickens gave up on wind power after spending millions of his own money. Tim -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of jim(at)poogiebearranch.com Sent: Wednesday, June 21, 2017 12:12 PM Subject: AeroElectric-List: RE: Future of flight... "Viable" for certain missions, sure. For an FBO renting airplanes for local flights, training flights, and $100 hamburger runs, we're almost there already. But "viable" for extended cross-country flights? That will take a while. It's not the airplane end that will be the slow part, it will be the charging infrastructure. Look how long it is taking to get the charging infrastructure built up for electric vehicles using the highway system, then imagine the economics involved in setting up "fast chargers" (2-4 hours for a full charge) at all the GA airports across the nation. And that's IF all the electric airplane vendors standardize on a charger type / plug / etc. I wish it were not true, because I would LOVE to have an electric car (but can't afford a Tesla), and there is no "fast-charge" station in between Dallas and Austin that would allow me to drive a Chevy Bolt (which would be my preferred "inexpensive" electric vehicle) from my home and my kids' place in Austin. Even with a 200+ mile range, I would need a charge before I got to their house... I suspect we'll experience similar stuff with electric planes for many, many years. Jim Parker ________________________________________________________________________________
Subject: Re: RE: Future of flight...
Date: Jun 21, 2017
My 2 electric cars are powered by solar panels on my roof, not by coal. I choose it because it's still less expensive than gasoline, doesn't fund terrorist countries and doesn't pollute the atmosphere. Plus they're fun to drive. When I drive regular cars now, I despise the noise and vibration. I'm excited about the explorations of electric aviation. Of course battery technology is still too heavy and limited to allow for anything beyond short flights right now (although battery capacity is increasing quite dramatically) however I think we could see some very cool hybrid applications. Designs can be innovative. Using electric motors to drive props and ducted fans can be far more efficient than using gear boxes or long odd drive shafts. Engines or turbines running generators can run at their most efficient speed instead of what's most efficient for the prop. Small battery banks can provide a buffer, allow "silent" taxiing and give emergency power in case the generator quits. I also think it could be ideal for helicopters since a large part of their maintenance and wear items are gearbox related. There are some really interesting developments going on in electric mult-rotor designs--full size drones essentially. And Tesla seems to be doing fine without any of our tax dollars. --Rick On 6/21/2017 4:22 PM, Tim Yoder wrote: > > Why would you choose to buy a Cole powered car with gas near $2.00 / gal. > headed toward $1.00 for the next several years. Tesla will require a few > more billions of our tax dollars to stay afloat. Look what has happened to > the solar plants. T. Boone Pickens gave up on wind power after spending > millions of his own money. > > Tim > > -----Original Message----- > > > "Viable" for certain missions, sure. For an FBO renting airplanes for local > flights, training flights, and $100 hamburger runs, we're almost there > already. But "viable" for extended cross-country flights? That will take a > while. It's not the airplane end that will be the slow part, it will be the > charging infrastructure. > > Look how long it is taking to get the charging infrastructure built up for > electric vehicles using the highway system, then imagine the economics > involved in setting up "fast chargers" (2-4 hours for a full > charge) at all the GA airports across the nation. And that's IF all the > electric airplane vendors standardize on a charger type / plug / etc. ________________________________________________________________________________
Date: Jun 21, 2017
Cole who? And why would he want to power my car? As to T. Boone, it might be worthwhile to expand your news sources a bit, to get a better picture. If you want to see a real tax dollar, and lobbied-government-forced-consumer dollar boondoggle, google 'Kemper County coal power plant'. Current (pardon the pun) construction spending total (and it's not over yet) that is roughly five Hundred BILLION dollars *over budget* at >$700Billion, and they have conceded that they can never burn coal there economically so they have shifted to natural gas. The rate payers in that plant's service area were forced to pre-fund a huge percentage of that cost, until the Public Service Commission was forced to realize that the consumers it was supposed to serve were being ripped off. Do the math. A significant percentage of their customer base could have had 30KW (gross overkill) solar systems *complete with battery storage & generator backup*, for the money wasted on that plant. I'm always amazed that people closely tied to tech (airplanes and what powers them) don't believe in how quickly tech advances.... Charlie On 6/21/2017 6:22 PM, Tim Yoder wrote: > > Why would you choose to buy a Cole powered car with gas near $2.00 / gal. > headed toward $1.00 for the next several years. Tesla will require a few > more billions of our tax dollars to stay afloat. Look what has happened to > the solar plants. T. Boone Pickens gave up on wind power after spending > millions of his own money. > > Tim > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of > jim(at)poogiebearranch.com > Sent: Wednesday, June 21, 2017 12:12 PM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: RE: Future of flight... > > > "Viable" for certain missions, sure. For an FBO renting airplanes for local > flights, training flights, and $100 hamburger runs, we're almost there > already. But "viable" for extended cross-country flights? That will take a > while. It's not the airplane end that will be the slow part, it will be the > charging infrastructure. > > Look how long it is taking to get the charging infrastructure built up for > electric vehicles using the highway system, then imagine the economics > involved in setting up "fast chargers" (2-4 hours for a full > charge) at all the GA airports across the nation. And that's IF all the > electric airplane vendors standardize on a charger type / plug / etc. > > I wish it were not true, because I would LOVE to have an electric car (but > can't afford a Tesla), and there is no "fast-charge" station in between > Dallas and Austin that would allow me to drive a Chevy Bolt (which would be > my preferred "inexpensive" electric vehicle) from my home and my kids' place > in Austin. Even with a 200+ mile range, I would need a charge before I got > to their house... > > I suspect we'll experience similar stuff with electric planes for many, many > years. > > Jim Parker --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jun 21, 2017
Well said. It's interesting...you have 2 electrics. I have 2 electrics. Another RV buddy of mine has 2 electrics. My opinion is, if more people would just try one and buy one, they'd soon see why they are so nice to have. We wouldn't buy 2 if they weren't making us happy. My second one I just got as a 3 year lease return and when purchased with 22k miles on it, was a better deal all the way around than any comparable used car with a gas engine. And, mine is usually powered by the local hydro dam... Other times it's powered by a nuke plant not too far away. Too bad more people don't embrace nuke....it's really the best choice for mass populations. Tim > On Jun 21, 2017, at 7:16 PM, Rick Beebe wrote: > > > My 2 electric cars are powered by solar panels on my roof, not by coal. I choose it because it's still less expensive than gasoline, doesn't fund terrorist countries and doesn't pollute the atmosphere. Plus they're fun to drive. When I drive regular cars now, I despise the noise and vibration. > > I'm excited about the explorations of electric aviation. Of course battery technology is still too heavy and limited to allow for anything beyond short flights right now (although battery capacity is increasing quite dramatically) however I think we could see some very cool hybrid applications. Designs can be innovative. Using electric motors to drive props and ducted fans can be far more efficient than using gear boxes or long odd drive shafts. Engines or turbines running generators can run at their most efficient speed instead of what's most efficient for the prop. Small battery banks can provide a buffer, allow "silent" taxiing and give emergency power in case the generator quits. > > I also think it could be ideal for helicopters since a large part of their maintenance and wear items are gearbox related. There are some really interesting developments going on in electric mult-rotor designs--full size drones essentially. > > And Tesla seems to be doing fine without any of our tax dollars. > > --Rick > > > >> On 6/21/2017 4:22 PM, Tim Yoder wrote: >> Why would you choose to buy a Cole powered car with gas near $2.00 / gal. >> headed toward $1.00 for the next several years. Tesla will require a few >> more billions of our tax dollars to stay afloat. Look what has happened to >> the solar plants. T. Boone Pickens gave up on wind power after spending >> millions of his own money. >> Tim >> -----Original Message----- >> "Viable" for certain missions, sure. For an FBO renting airplanes for local >> flights, training flights, and $100 hamburger runs, we're almost there >> already. But "viable" for extended cross-country flights? That will take a >> while. It's not the airplane end that will be the slow part, it will be the >> charging infrastructure. >> Look how long it is taking to get the charging infrastructure built up for >> electric vehicles using the highway system, then imagine the economics >> involved in setting up "fast chargers" (2-4 hours for a full >> charge) at all the GA airports across the nation. And that's IF all the >> electric airplane vendors standardize on a charger type / plug / etc. > > > ________________________________________________________________________________
Date: Jun 21, 2017
Flight schools will be the very last adopters of electric airplanes if ever. Flight schools only make money by keeping their aircraft in the air every hour of every sunny weekend day, to make up for all the down time. You can refuel an empty gas powered 172 in two minutes while the next pilot is performing a preflight inspection and get it earning money with essentially no gaps. Lets see what the equivalent electricity requirements are. Lets say we burned 15 gallons in our 172 in our 90 minute flight, and we need to achieve a five minute recharge. The energy density of gasoline is 45MJ/litre, which is 171MJ/gallon 15 gallons of gasoline has 2.6GJ of energy. 2.5GJ serviced in 5 minutes is about 8.7 MW. An 8.7MW draw is 800 amps from a dedicated 11,000kV distribution substation. That is an entirely absurdly large amount of power to have to provide to an airport: the infrastructure doesnt exist, would have to be built, and paid for. So lets bundle together stunningly efficient airplanes, that fly with 50% of the power required at present. Lets lengthen the charge time to an hour, throw in multiple battery packs that we can quick change, whatever else you like. By the time you have more than two airplanes on the ramp the cost of the electrical infrastructure to recharge them is beyond belief. Now lets price the cost of electricity with equivalent energy content to a gallon of 100LL: 171 MJ is 47.5kWh, I dont know what the industrial price for electricity is but the retail price is 12 US cents per kWh, so that gallon equivalent of energy is costing you $5.70 anyway. Not a lot of savings there. Youre welcome to power your electric airplane from solar panels on your roof, and it might work if you only want to fly a couple of hours a week. Thats not going to cut it for anyone who uses an airplane for anything serious. > On Jun 21, 2017, at 8:16 PM, Rick Beebe wrote: > > > My 2 electric cars are powered by solar panels on my roof, not by coal. I choose it because it's still less expensive than gasoline, doesn't fund terrorist countries and doesn't pollute the atmosphere. Plus they're fun to drive. When I drive regular cars now, I despise the noise and vibration. > > I'm excited about the explorations of electric aviation. Of course battery technology is still too heavy and limited to allow for anything beyond short flights right now (although battery capacity is increasing quite dramatically) however I think we could see some very cool hybrid applications. Designs can be innovative. Using electric motors to drive props and ducted fans can be far more efficient than using gear boxes or long odd drive shafts. Engines or turbines running generators can run at their most efficient speed instead of what's most efficient for the prop. Small battery banks can provide a buffer, allow "silent" taxiing and give emergency power in case the generator quits. > > I also think it could be ideal for helicopters since a large part of their maintenance and wear items are gearbox related. There are some really interesting developments going on in electric mult-rotor designs--full size drones essentially. > > And Tesla seems to be doing fine without any of our tax dollars. > > --Rick > > > > On 6/21/2017 4:22 PM, Tim Yoder wrote: >> Why would you choose to buy a Cole powered car with gas near $2.00 / gal. >> headed toward $1.00 for the next several years. Tesla will require a few >> more billions of our tax dollars to stay afloat. Look what has happened to >> the solar plants. T. Boone Pickens gave up on wind power after spending >> millions of his own money. >> Tim >> -----Original Message----- >> "Viable" for certain missions, sure. For an FBO renting airplanes for local >> flights, training flights, and $100 hamburger runs, we're almost there >> already. But "viable" for extended cross-country flights? That will take a >> while. It's not the airplane end that will be the slow part, it will be the >> charging infrastructure. >> Look how long it is taking to get the charging infrastructure built up for >> electric vehicles using the highway system, then imagine the economics >> involved in setting up "fast chargers" (2-4 hours for a full >> charge) at all the GA airports across the nation. And that's IF all the >> electric airplane vendors standardize on a charger type / plug / etc. > > > ________________________________________________________________________________
Date: Jun 21, 2017
Slight correction, total cost is now looking at just over 7 billion, not 700 billion. It was supposed to be a model for environmental technology to create a clean coal power plant. On Wed, Jun 21, 2017 at 8:33 PM, Charlie England wrote: > ceengland7(at)gmail.com> > > Cole who? And why would he want to power my car? As to T. Boone, it might > be worthwhile to expand your news sources a bit, to get a better picture. > > If you want to see a real tax dollar, and lobbied-government-forced-consumer > dollar boondoggle, google 'Kemper County coal power plant'. Current (pardon > the pun) construction spending total (and it's not over yet) that is > roughly five Hundred BILLION dollars *over budget* at >$700Billion, and > they have conceded that they can never burn coal there economically so they > have shifted to natural gas. The rate payers in that plant's service area > were forced to pre-fund a huge percentage of that cost, until the Public > Service Commission was forced to realize that the consumers it was supposed > to serve were being ripped off. > > Do the math. A significant percentage of their customer base could have > had 30KW (gross overkill) solar systems *complete with battery storage & > generator backup*, for the money wasted on that plant. > > I'm always amazed that people closely tied to tech (airplanes and what > powers them) don't believe in how quickly tech advances.... > > Charlie > > On 6/21/2017 6:22 PM, Tim Yoder wrote: > >> ftyoder(at)yoderbuilt.com> >> >> Why would you choose to buy a Cole powered car with gas near $2.00 / gal. >> headed toward $1.00 for the next several years. Tesla will require a few >> more billions of our tax dollars to stay afloat. Look what has happened to >> the solar plants. T. Boone Pickens gave up on wind power after spending >> millions of his own money. >> >> Tim >> >> -----Original Message----- >> From: owner-aeroelectric-list-server(at)matronics.com >> [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of >> jim(at)poogiebearranch.com >> Sent: Wednesday, June 21, 2017 12:12 PM >> To: aeroelectric-list(at)matronics.com >> Subject: AeroElectric-List: RE: Future of flight... >> >> >> "Viable" for certain missions, sure. For an FBO renting airplanes for >> local >> flights, training flights, and $100 hamburger runs, we're almost there >> already. But "viable" for extended cross-country flights? That will take a >> while. It's not the airplane end that will be the slow part, it will be >> the >> charging infrastructure. >> >> Look how long it is taking to get the charging infrastructure built up for >> electric vehicles using the highway system, then imagine the economics >> involved in setting up "fast chargers" (2-4 hours for a full >> charge) at all the GA airports across the nation. And that's IF all the >> electric airplane vendors standardize on a charger type / plug / etc. >> >> I wish it were not true, because I would LOVE to have an electric car (but >> can't afford a Tesla), and there is no "fast-charge" station in between >> Dallas and Austin that would allow me to drive a Chevy Bolt (which would >> be >> my preferred "inexpensive" electric vehicle) from my home and my kids' >> place >> in Austin. Even with a 200+ mile range, I would need a charge before I got >> to their house... >> >> I suspect we'll experience similar stuff with electric planes for many, >> many >> years. >> >> Jim Parker >> > > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > ________________________________________________________________________________
Date: Jun 21, 2017
Well for starters, you conveniently leave out the percentage of the gasoline's energy that actually propels the plane. I won't go any farther; doesn't seem to be any point. Charlie On 6/21/2017 8:07 PM, Alec Myers wrote: > > Flight schools will be the very last adopters of electric airplanes if ever. Flight schools only make money by keeping their aircraft in the air every hour of every sunny weekend day, to make up for all the down time. You can refuel an empty gas powered 172 in two minutes while the next pilot is performing a preflight inspection and get it earning money with essentially no gaps. > > Lets see what the equivalent electricity requirements are. Lets say we burned 15 gallons in our 172 in our 90 minute flight, and we need to achieve a five minute recharge. > > The energy density of gasoline is 45MJ/litre, which is 171MJ/gallon > 15 gallons of gasoline has 2.6GJ of energy. > 2.5GJ serviced in 5 minutes is about 8.7 MW. > An 8.7MW draw is 800 amps from a dedicated 11,000kV distribution substation. > That is an entirely absurdly large amount of power to have to provide to an airport: the infrastructure doesnt exist, would have to be built, and paid for. > > So lets bundle together stunningly efficient airplanes, that fly with 50% of the power required at present. Lets lengthen the charge time to an hour, throw in multiple battery packs that we can quick change, whatever else you like. By the time you have more than two airplanes on the ramp the cost of the electrical infrastructure to recharge them is beyond belief. > > Now lets price the cost of electricity with equivalent energy content to a gallon of 100LL: > 171 MJ is 47.5kWh, I dont know what the industrial price for electricity is but the retail price is 12 US cents per kWh, so that gallon equivalent of energy is costing you $5.70 anyway. Not a lot of savings there. > > Youre welcome to power your electric airplane from solar panels on your roof, and it might work if you only want to fly a couple of hours a week. Thats not going to cut it for anyone who uses an airplane for anything serious. > > >> On Jun 21, 2017, at 8:16 PM, Rick Beebe wrote: >> >> >> My 2 electric cars are powered by solar panels on my roof, not by coal. I choose it because it's still less expensive than gasoline, doesn't fund terrorist countries and doesn't pollute the atmosphere. Plus they're fun to drive. When I drive regular cars now, I despise the noise and vibration. >> >> I'm excited about the explorations of electric aviation. Of course battery technology is still too heavy and limited to allow for anything beyond short flights right now (although battery capacity is increasing quite dramatically) however I think we could see some very cool hybrid applications. Designs can be innovative. Using electric motors to drive props and ducted fans can be far more efficient than using gear boxes or long odd drive shafts. Engines or turbines running generators can run at their most efficient speed instead of what's most efficient for the prop. Small battery banks can provide a buffer, allow "silent" taxiing and give emergency power in case the generator quits. >> >> I also think it could be ideal for helicopters since a large part of their maintenance and wear items are gearbox related. There are some really interesting developments going on in electric mult-rotor designs--full size drones essentially. >> >> And Tesla seems to be doing fine without any of our tax dollars. >> >> --Rick >> >> >> >> On 6/21/2017 4:22 PM, Tim Yoder wrote: >>> Why would you choose to buy a Cole powered car with gas near $2.00 / gal. >>> headed toward $1.00 for the next several years. Tesla will require a few >>> more billions of our tax dollars to stay afloat. Look what has happened to >>> the solar plants. T. Boone Pickens gave up on wind power after spending >>> millions of his own money. >>> Tim >>> -----Original Message----- >>> "Viable" for certain missions, sure. For an FBO renting airplanes for local >>> flights, training flights, and $100 hamburger runs, we're almost there >>> already. But "viable" for extended cross-country flights? That will take a >>> while. It's not the airplane end that will be the slow part, it will be the >>> charging infrastructure. >>> Look how long it is taking to get the charging infrastructure built up for >>> electric vehicles using the highway system, then imagine the economics >>> involved in setting up "fast chargers" (2-4 hours for a full >>> charge) at all the GA airports across the nation. And that's IF all the >>> electric airplane vendors standardize on a charger type / plug / etc. >> >> > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jun 21, 2017
it's about 30%. Do you think the percentage of energy you can get out of a battery into useful propulsion is much better? On Jun 21, 2017, at 21:28, Charlie England wrote: Well for starters, you conveniently leave out the percentage of the gasoline's energy that actually propels the plane. I won't go any farther; doesn't seem to be any point. Charlie > On 6/21/2017 8:07 PM, Alec Myers wrote: > > Flight schools will be the very last adopters of electric airplanes if ever. Flight schools only make money by keeping their aircraft in the air every hour of every sunny weekend day, to make up for all the down time. You can refuel an empty gas powered 172 in two minutes while the next pilot is performing a preflight inspection and get it earning money with essentially no gaps. > > Lets see what the equivalent electricity requirements are. Lets say we burned 15 gallons in our 172 in our 90 minute flight, and we need to achieve a five minute recharge. > > The energy density of gasoline is 45MJ/litre, which is 171MJ/gallon > 15 gallons of gasoline has 2.6GJ of energy. > 2.5GJ serviced in 5 minutes is about 8.7 MW. > An 8.7MW draw is 800 amps from a dedicated 11,000kV distribution substation. > That is an entirely absurdly large amount of power to have to provide to an airport: the infrastructure doesnt exist, would have to be built, and paid for. > > So lets bundle together stunningly efficient airplanes, that fly with 50% of the power required at present. Lets lengthen the charge time to an hour, throw in multiple battery packs that we can quick change, whatever else you like. By the time you have more than two airplanes on the ramp the cost of the electrical infrastructure to recharge them is beyond belief. > > Now lets price the cost of electricity with equivalent energy content to a gallon of 100LL: > 171 MJ is 47.5kWh, I dont know what the industrial price for electricity is but the retail price is 12 US cents per kWh, so that gallon equivalent of energy is costing you $5.70 anyway. Not a lot of savings there. > > Youre welcome to power your electric airplane from solar panels on your roof, and it might work if you only want to fly a couple of hours a week. Thats not going to cut it for anyone who uses an airplane for anything serious. > > > > > >> On Jun 21, 2017, at 8:16 PM, Rick Beebe wrote: >> >> >> My 2 electric cars are powered by solar panels on my roof, not by coal. I choose it because it's still less expensive than gasoline, doesn't fund terrorist countries and doesn't pollute the atmosphere. Plus they're fun to drive. When I drive regular cars now, I despise the noise and vibration. >> >> I'm excited about the explorations of electric aviation. Of course battery technology is still too heavy and limited to allow for anything beyond short flights right now (although battery capacity is increasing quite dramatically) however I think we could see some very cool hybrid applications. Designs can be innovative. Using electric motors to drive props and ducted fans can be far more efficient than using gear boxes or long odd drive shafts. Engines or turbines running generators can run at their most efficient speed instead of what's most efficient for the prop. Small battery banks can provide a buffer, allow "silent" taxiing and give emergency power in case the generator quits. >> >> I also think it could be ideal for helicopters since a large part of their maintenance and wear items are gearbox related. There are some really interesting developments going on in electric mult-rotor designs--full size drones essentially. >> >> And Tesla seems to be doing fine without any of our tax dollars. >> >> --Rick >> >> >> >>> On 6/21/2017 4:22 PM, Tim Yoder wrote: >>> Why would you choose to buy a Cole powered car with gas near $2.00 / gal. >>> headed toward $1.00 for the next several years. Tesla will require a few >>> more billions of our tax dollars to stay afloat. Look what has happened to >>> the solar plants. T. Boone Pickens gave up on wind power after spending >>> millions of his own money. >>> Tim >>> -----Original Message----- >>> "Viable" for certain missions, sure. For an FBO renting airplanes for local >>> flights, training flights, and $100 hamburger runs, we're almost there >>> already. But "viable" for extended cross-country flights? That will take a >>> while. It's not the airplane end that will be the slow part, it will be the >>> charging infrastructure. >>> Look how long it is taking to get the charging infrastructure built up for >>> electric vehicles using the highway system, then imagine the economics >>> involved in setting up "fast chargers" (2-4 hours for a full >>> charge) at all the GA airports across the nation. And that's IF all the >>> electric airplane vendors standardize on a charger type / plug / etc. >> >> > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jun 21, 2017
Let's not forget that a solar powered airplane has already flown around the world. On Wed, Jun 21, 2017 at 9:42 AM, John B wrote: > Yes, the electric airplane... > Eventually, we will have viable electric airplanes. The model airplane > folks have largely gone to electric power... > > On Wed, Jun 21, 2017 at 11:57 AM, Robert L. Nuckolls, III < > nuckolls.bob(at)aeroelectric.com> wrote: > >> http://tinyurl.com/ybztoq3g >> >> Bob . . . >> > > ________________________________________________________________________________
Date: Jun 21, 2017
oops. You're right. I guess it just seems like 700 billion, after watching that fiasco for so long. To return the favor; slight correction to your evaluation; it was *marketed* as a model for environmental technology to create a clean coal power plant. Talk about alternate facts.... On 6/21/2017 8:19 PM, William Greenley wrote: > Slight correction, total cost is now looking at just over 7 billion, > not 700 billion. It was supposed to be a model for environmental > technology to create a clean coal power plant. > > On Wed, Jun 21, 2017 at 8:33 PM, Charlie England > wrote: > > > > > Cole who? And why would he want to power my car? As to T. Boone, > it might be worthwhile to expand your news sources a bit, to get a > better picture. > > If you want to see a real tax dollar, and > lobbied-government-forced-consumer dollar boondoggle, google > 'Kemper County coal power plant'. Current (pardon the pun) > construction spending total (and it's not over yet) that is > roughly five Hundred BILLION dollars *over budget* at > >$700Billion, and they have conceded that they can never burn coal > there economically so they have shifted to natural gas. The rate > payers in that plant's service area were forced to pre-fund a huge > percentage of that cost, until the Public Service Commission was > forced to realize that the consumers it was supposed to serve were > being ripped off. > > Do the math. A significant percentage of their customer base could > have had 30KW (gross overkill) solar systems *complete with > battery storage & generator backup*, for the money wasted on that > plant. > > I'm always amazed that people closely tied to tech (airplanes and > what powers them) don't believe in how quickly tech advances.... > > Charlie > > On 6/21/2017 6:22 PM, Tim Yoder wrote: > > > > > Why would you choose to buy a Cole powered car with gas near > $2.00 / gal. > headed toward $1.00 for the next several years. Tesla will > require a few > more billions of our tax dollars to stay afloat. Look what has > happened to > the solar plants. T. Boone Pickens gave up on wind power after > spending > millions of his own money. > > Tim > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > > [mailto:owner-aeroelectric-list-server(at)matronics.com > ] On > Behalf Of > jim(at)poogiebearranch.com > Sent: Wednesday, June 21, 2017 12:12 PM > To: aeroelectric-list(at)matronics.com > > Subject: AeroElectric-List: RE: Future of flight... > > > > > "Viable" for certain missions, sure. For an FBO renting > airplanes for local > flights, training flights, and $100 hamburger runs, we're > almost there > already. But "viable" for extended cross-country flights? That > will take a > while. It's not the airplane end that will be the slow part, > it will be the > charging infrastructure. > > Look how long it is taking to get the charging infrastructure > built up for > electric vehicles using the highway system, then imagine the > economics > involved in setting up "fast chargers" (2-4 hours for a full > charge) at all the GA airports across the nation. And that's > IF all the > electric airplane vendors standardize on a charger type / plug > / etc. > > I wish it were not true, because I would LOVE to have an > electric car (but > can't afford a Tesla), and there is no "fast-charge" station > in between > Dallas and Austin that would allow me to drive a Chevy Bolt > (which would be > my preferred "inexpensive" electric vehicle) from my home and > my kids' place > in Austin. Even with a 200+ mile range, I would need a charge > before I got > to their house... > > I suspect we'll experience similar stuff with electric planes > for many, many > years. > > Jim Parker > > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > > =================================== > - > Electric-List" rel="noreferrer" > target="_blank">http://www.matronics.com/Navigator?AeroElectric-List > =================================== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > =================================== > WIKI - > errer" target="_blank">http://wiki.matronics.com > =================================== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > =================================== > > ________________________________________________________________________________
From: Christopher Cee Stone <rv8iator(at)gmail.com>
Date: Jun 22, 2017
The photo is of an AMP Mate'n'lock connector. There are three or four sizes of Mate'n'lock connectors based on pin size (diameter). The contact removal tool is a sleeve and plunger tool. The sleeve compresses the retainer tangs into flush with the contact body and the plunger pushes them out of the housing. On Wed, Jun 21, 2017 at 10:02 AM, William Hunter wrote: > Hi All, > > > I need to rearrange the wires on this AMP 12 pin connector and my hope is > to simply pop out the terminal ends and leave the wires still connected and > just move them to the proper pin locations and pop them back in (I might > have to re-bend the metal retainer tabs). > > > The questions are: > > > Does anyone know what terminal connector this is? > > > How does one (me) unseat the terminal ends from the connector and what > tool should be used? > > > .. > > > THANKS!!! > > > Bill Hunter > > ________________________________________________________________________________
Date: Jun 22, 2017
That is exactly it. THANK YOU SO MUCH for the help. Bill Hunter On Jun 22, 2017 5:51 AM, "Christopher Cee Stone" wrote: > The photo is of an AMP Mate'n'lock connector. There are three or four > sizes of Mate'n'lock connectors based on pin size (diameter). > > The contact removal tool is a sleeve and plunger tool. The sleeve > compresses the retainer tangs into flush with the contact body and the > plunger pushes them out of the housing. > > > On Wed, Jun 21, 2017 at 10:02 AM, William Hunter < > billhuntersemail(at)gmail.com> wrote: > >> Hi All, >> >> >> >> I need to rearrange the wires on this AMP 12 pin connector and my hope is >> to simply pop out the terminal ends and leave the wires still connected and >> just move them to the proper pin locations and pop them back in (I might >> have to re-bend the metal retainer tabs). >> >> >> >> The questions are: >> >> >> >> Does anyone know what terminal connector this is? >> >> >> >> How does one (me) unseat the terminal ends from the connector and what >> tool should be used? >> >> >> >> .. >> >> >> >> THANKS!!! >> >> >> >> Bill Hunter >> >> >> > > ________________________________________________________________________________
Date: Jun 22, 2017
Hello, Thank you I will do it, it's true that before wire was twist only 3 inch. and the other wire for the trim/switch trim/bus were not. For the wiring I find a wiring diagram for a car relay, but time to actuate relay is very slow for trim fonction. Any idea to improve ? (special relay ? or other things ? ) Mickal ;) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470374#470374 Attachments: http://forums.matronics.com//files/capture_dcran_2017_06_22__170547_630.png ________________________________________________________________________________
Subject: RE: Future of Flight
Date: Jun 22, 2017
<< Why would you choose to buy a Cole powered car with gas near $2.00 / gal. headed toward $1.00 for the next several years. >> In part, because I already have a wind generator that supplies about 1/2 of my electricity, and if I do get an electric car, I will add a solar system that will provide the rest. At that point, I would only be concerned about recharging on the road... But I also believe your "headed towards $1.00" gas outlook is a bit optimistic. << Flight schools will be the very last adopters of electric airplanes if ever. Flight schools only make money by keeping their aircraft in the air every hour of every sunny weekend day, to make up for all the down time. You can refuel an empty gas powered 172 in two minutes while the next pilot is performing a preflight inspection and get it earning money with essentially no gaps. >> You are making the assumption that the batteries in that airplane cannot be swapped out in an equivalent amount of time. Some of the more practical designs for electric-powered airplanes have swappable battery packs that can be recharges over time - no need to draw massive amounts of electricity over a 5-minute period. You've got a full 24 hours to recharge that battery pack. That changes the power draw required to recharge that battery to about 30KW (if I did my math correctly). And as someone else pointed out, our Lycosaurus engines are <30% efficient at converting gas to power (though some more modern designs may be up to 45% efficient). By contrast, an electric motor running at 75% rated power is generally 90% efficient. So you'll need about 35% of the energy using an electric motor that you would if you used an ICE. So your 30KW draw comes down even further, towards the 10KW range. And you're completely ignoring the economics of no longer having to maintain that internal combustion engine, the fuel pumps, lines, and tanks, etc. Even at current battery prices, Siemens and AirBus have determined that it would be less expensive to purchase and maintain spare batteries than service and maintain gas-powered engines. Don't get me wrong - I don't think this is going to happen tomorrow, and I'm not selling my gas-powered airplane any time soon, but it WILL happen in most of our lifetimes, and perhaps even within the next few years. The airplanes may not look like what we're used to seeing, but multi-rotor type aircraft are on the (very near) horizon! Jim Parker ________________________________________________________________________________
Date: Jun 22, 2017
An aspect of electric aircraft which is worth considering is the risk of fire following an accident. I know of a case where an electric aircraft got into a spin at low altitude and crashed. The post crash fire consumed everything and little was left of the pilot. Fortunately he died on impact. Batteries are a fire hazard. We have seen that with Tesla cars that burn. Fortunately nobody has been hurt so far, as far as I know. We have also seen the batteries of laptops and of Samsung Galaxies catch fire. I understand that such events are caused by a rupture within the battery which results in a short circuit, and the energy thus released causes a conflagration. I wonder how much it would cost to insure an electric aircraft that uses lithium-ion or similar batteries. The possibilities of a crash causing a major conflagration have to be kept in mind. It is obvious that electric motors are far more efficient than internal combustion engines. However, generating electricity is very inefficient. One also has to take the energy cost of transmission of all that electric power into consideration. Of course refining oil and distributing fuel also consumes energy. It is my impression that, if one takes the global view, there is no huge difference between the efficiencies of internal combustion and electric aircraft. Given the cost of creating an electric power grid that serves all airfields and the fire hazard of current batteries in my opinion the internal combustion engine is the power source of the foreseeable future. But not necessarily the spark ignition engine. I think that diesel engines are the future of aircraft propulsion for a few decades at least. They are heavier but provide power and torque at lower engine speeds and are more efficient energy wise. Besides I understand that diesel and jet fuel are less of a fire risk than gasoline. Current diesel engines for aircraft are converted automotive units and may not be optimal, but once they start making dedicated aircraft diesel engines I expect to see improvements. I myself have flown diesel powered Robin DR400's. I would be reluctant to set foot in an electric aircraft, at least one based on present technology. George Nielsen On 22-Jun-17 9:01, AeroElectric-List Digest Server wrote: > * > From: John B <jbsoar(at)gmail.com> > Subject: Re: AeroElectric-List: Future of flight . . . > > Yes, the electric airplane... > Eventually, we will have viable electric airplanes. The model airplane > folks have largely gone to electric power... > > On Wed, Jun 21, 2017 at 11:57 AM, Robert L. Nuckolls, III < > nuckolls.bob(at)aeroelectric.com> wrote: > >> http://tinyurl.com/ybztoq3g >> >> Bob . . . >> > ________________________________________________________________________________
Date: Jun 22, 2017
On 6/22/2017 10:50 AM, George Nielsen wrote: > > > An aspect of electric aircraft which is worth considering is the risk of > fire following an accident. I know of a case where an electric aircraft > got into a spin at low altitude and crashed. The post crash fire > consumed everything and little was left of the pilot. Fortunately he > died on impact. Different battery chemistries have different risk of fire. As do different liquid aviation fuels. Car fires are so common (175,000 resulting in 445 deaths and $1.2 billion in damage in 2015 alone) that they barely make the news. Electric vehicle fires get sensationalized because they're so rare. As electric aircraft get commercialized, I believe that's a risk that's easily mitigated. > It is obvious that electric motors are far more efficient than internal > combustion engines. However, generating electricity is very inefficient. > One also has to take the energy cost of transmission of all that > electric power into consideration. Of course refining oil and > distributing fuel also consumes energy. It is my impression that, if one > takes the global view, there is no huge difference between the > efficiencies of internal combustion and electric aircraft. Generating electricity isn't all that inefficient especially compared to "generating" fuel. In fact refining fuel takes huge amounts of electricity and heat. Several analysis have said it takes roughly 6kWh of energy to refine one gallon of gasoline, or enough to drive an electric car 20 miles. This article is a fairly unbiased analysis of a lot of that research: https://greentransportation.info/energy-transportation/gasoline-costs-6kwh.html > Given the cost of creating an electric power grid that serves all > airfields and the fire hazard of current batteries in my opinion the > internal combustion engine is the power source of the foreseeable > future. I think it will be for a while, as well, but only because of the need to go distances and/or recharge very quickly. Both of which are coming faster than I suspect we imagine. --Rick ________________________________________________________________________________
Date: Jun 23, 2017
Thank you bob, I haven't see the response before and I answered in other topic. I will try it and I will come back to tell if it run better or not. (if it run well also to tell what it was bad if it can help anyone.) I find relay a bit slow for the motor trim operation, we haven't another solution to wire it with another system ? (transistor ? I don't know well what is it, I just read that on internet) Thank you ! Mickal Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470400#470400 ________________________________________________________________________________
Subject: Re: Question about Z19RB and OVP/Beaker and size wire
Date: Jun 23, 2017
Hello again, Just to ask a question about this OVP wiring. I have a filter with it (b&c complet OVP system) for the relay I didn't put it to wire it like the diagram, but the filter have to be add or not in my system ? What is his fonction ? Mickal Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470403#470403 ________________________________________________________________________________
Date: Jun 23, 2017
Le 23/06/2017 14:26, Achille a crit : > > Thank you bob, > > I haven't see the response before and I answered in other topic. > > I will try it and I will come back to tell if it run better or not. (if it run well also to tell what it was bad if it can help anyone.) > > I find relay a bit slow for the motor trim operation, we haven't another solution to wire it with another system ? (transistor ? I don't know well what is it, I just read that on internet) > Achille, Just in case you happen to be happier posting in French, do not hesitate to mail me personal in French. Could you explain what you find so slow in relay operation, especially considering that most trims are slow operating ? N'hsite pas discuter en franais ! Best regards, -- Amicalement, Gilles http://contrails.free.fr ________________________________________________________________________________
Date: Jun 23, 2017
Le 23/06/2017 14:26, Achille a crit : > I find relay a bit slow for the motor trim operation, we haven't another solution to wire it with another system ? (transistor ? I don't know well what is it, I just read that on internet) > Achille, Just in case you happen to be happier posting in French, do not hesitate to mail me personal in French. Could you explain what you find so slow in relay operation, especially considering that most trims are slow operating ? N'hsite pas discuter en franais ! Best regards, -- Amicalement, Gilles http://contrails.free.fr ________________________________________________________________________________
Date: Jun 23, 2017
wire At 09:11 AM 6/23/2017, you wrote: > >Hello again, > >Just to ask a question about this OVP wiring. > >I have a filter with it (b&c complet OVP system) for the relay I >didn't put it to wire it like the diagram, but the filter have to be >add or not in my system ? > >What is his fonction ? The OVP system was configured for use with a permanent magnet alternator. The filter is only used with these machines. Your internally regulated alternator only needs the OV protection module. Bob . . . ________________________________________________________________________________
Date: Jun 23, 2017
At 07:26 AM 6/23/2017, you wrote: > >Thank you bob, > >I haven't see the response before and I answered in other topic. > >I will try it and I will come back to tell if it run better or not. >(if it run well also to tell what it was bad if it can help anyone.) > >I find relay a bit slow for the motor trim operation, we haven't >another solution to wire it with another system ? (transistor ? I >don't know well what is it, I just read that on internet) What do you mean my "slow"? Running speed of the motor? Response delay to pilot input? Virtually every trim system I've worked on over the past 40+ years is controlled by relays. They're smaller and perhaps a little bit faster than the suggested automotive relays . . . but the difference would be described as a few milliseconds. The relays can be replaced with transistors but let's see if it's really necessary. Bob . . . ________________________________________________________________________________
Subject: Re: Tosten grip wiring with car-relay for trim
Date: Jun 23, 2017
Yes in respons to pilot input. Little input didn't run the motor, a bit large input pass through the value desired. (no possible to adjust it precisely) but maybe it's not the fault of the relay. More in the trim system made with a spring, which can increase the imprecision, taking into account your response. If all system are made with this kind of relay or close to, I will think about all system before looking on the electrical part so. (photo not very important helpful but a least we can see the motor) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470425#470425 Attachments: http://forums.matronics.com//files/capture_dcran_2017_06_23__235723_187.png ________________________________________________________________________________
Date: Jun 23, 2017
If I understand correctly, it is difficult to adjust the desired trim position because pressing the switch either does not run the motor long enough or else it runs too long and overshoots. More precise control can be achieved by using a lower voltage to run the motor. But the motor may fail to start if operated with a lower voltage. The solution may be to operate the motor with a PWM (pulse width modulated) voltage. The type of relay used has little affect on the trim speed or travel. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470431#470431 ________________________________________________________________________________
Date: Jun 24, 2017
Have you tried something like Safety Trim? http://www.tcwtech.com/Safety-Trim%20Page.htm Peter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Achille Sent: 23 June 2017 22:58 Subject: AeroElectric-List: Re: Tosten grip wiring with car-relay for trim Yes in respons to pilot input. Little input didn't run the motor, a bit large input pass through the value desired. (no possible to adjust it precisely) but maybe it's not the fault of the relay. More in the trim system made with a spring, which can increase the imprecision, taking into account your response. If all system are made with this kind of relay or close to, I will think about all system before looking on the electrical part so. (photo not very important helpful but a least we can see the motor) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470425#470425 Attachments: http://forums.matronics.com//files/capture_dcran_2017_06_23__235723_187.png ________________________________________________________________________________
Date: Jun 24, 2017
<< Have you tried something like Safety Trim? http://www.tcwtech.com/Safety-Trim%20Page.htm >> Or look at the June 2013 issue of Kitplanes for a do it yourself controller with all the features and then some of the $400 TCW unit for less than $50 in parts. Or email me directly for a copy of the article, schematics, photos, etc. Tom Kuffel --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
From: "David A. Leonard" <dave(at)evergreengeo.com>
Date: Jun 24, 2017
Subject: Re: Kx 170 b radio, ki211c indicator no power to ki
211c pin a Hi guys, been away from flying a while, and airplane mode and N77FE is a bit pissed off at beong ignored. Cant get my cdi to power up. I tried both my kx 170b and michel mx 170 in the tray. I pulled the cdi and the connector was loose, so fixed that. Probed for power. Pin c on ki 211 is supposed to be 13.75 v input, no power there w nav radio on. I do get gs energize power at pin p when tuned to gs freq. Pin 26 is power out from tray, probed from there to connector end of cdi connector pin c and wire is connected. Continuity is solid. Does the tray connector jumper power to the cdi, or does the radio switch it? Im kinda baffled. Page 2-13 shows what i think I have. Thanks, Dave Leonard Super viking N77FE https://www.google.com/url?sa=t&source=web&rct=j&url=http:// www.aeroelectric.com/Installation_Data/Bendix-King/KX175B_IM.pdf&ved 0ahUKEwiSucHOuNfUAhWp64MKHfcCBQ0QFggdMAA&usg=AFQjCNEMWUD78gQVdc- xgRjp70uLbwJ1bA ________________________________________________________________________________
Date: Jun 25, 2017
to ki 211c pin a At 04:56 PM 6/24/2017, you wrote: >Hi guys, been away from flying a while, and >airplane mode and N77FE is a bit pissed off at beong ignored. > >Cant get my cdi to power up. > >I tried both my kx 170b and michel mx 170 in the >tray. =C2 =C2 I pulled the cdi and the connector >was loose, so fixed that.=C2 Probed for power. >=C2 Pin c on ki 211 is supposed to be 13.75 v >input, no power there w nav radio on. =C2 I do >get gs energize power at pin p when tuned to gs freq. =C2 =C2 > >=C2 Pin 26 is power out from tray, probed from >there to connector end of cdi connector pin c >and wire is connected. Continuity is solid. > >Does the tray connector jumper power to the cdi, >or does the radio switch it?=C2 Im kinda baffled. =C2 > >Page 2-13 shows what i think I have. =C2 > >Thanks, Dave Leonard Super viking N77FE > >http://www.ae roelectric.com/Installation_Data/Bendix-King/KX175B_IM.pdf&ved=0ahUKEwiSuc HOuNfUAhWp64MKHfcCBQ0QFggdMAA&usg=AFQjCNEMWUD78gQVdc-xgRjp70uLbwJ1bA>https ://www.google.com/url?sa=t&source=web&rct=j&url=http://www.aeroelect ric.com/Installation_Data/Bendix-King/KX175B_IM.pdf&ved=0ahUKEwiSucHOuNfUA hWp64MKHfcCBQ0QFggdMAA&usg=AFQjCNEMWUD78gQVdc-xgRjp70uLbwJ1bA The label "NAV SWITCHED 13.75VDC" says that this is indeed a power output pin controlled by the nav receiver's power switch. There is a Note 7 associated with this path: Emacs! . . . which tells us that this ouput is limited to 300 ma. Probing this pathway with the voltmeter should show bus voltage with the nav radio ON. This power comes from the radio and is switched internally to the radio. If the power is missing on TWO radios, then it seems likely that the disconnect is somewhere in the ship's wiring. Bob . . . ________________________________________________________________________________
Date: Jun 25, 2017
to ki 211c pin a Thanks Bob, that is where I was heading. But it seems odd that the wire pins to tray buzz on the ohmeter. Must be doing something wrong. Virus-free. www.avast.com <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> On Sun, Jun 25, 2017 at 7:30 AM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 04:56 PM 6/24/2017, you wrote: > > Hi guys, been away from flying a while, and airplane mode and N77FE is a > bit pissed off at beong ignored. > > Cant get my cdi to power up. > > I tried both my kx 170b and michel mx 170 in the tray. =C3=82 =C3=82 I p ulled the > cdi and the connector was loose, so fixed that.=C3=82 Probed for power. =C3=82 Pin > c on ki 211 is supposed to be 13.75 v input, no power there w nav radio o n. > =C3=82 I do get gs energize power at pin p when tuned to gs freq. =C3=82 =C3=82 > > =C3=82 Pin 26 is power out from tray, probed from there to connector end of cdi > connector pin c and wire is connected. Continuity is solid. > > Does the tray connector jumper power to the cdi, or does the radio switch > it?=C3=82 Im kinda baffled. =C3=82 > > Page 2-13 shows what i think I have. =C3=82 > > Thanks, Dave Leonard Super viking N77FE > > https://www.google.com/url?sa=t&source=web&rct=j&url=http:// > www.aeroelectric.com/Installation_Data/Bendix-King/KX175B_IM.pdf&ved > 0ahUKEwiSucHOuNfUAhWp64MKHfcCBQ0QFggdMAA&usg=AFQjCNEMWUD78gQVdc- > xgRjp70uLbwJ1bA > > > The label "NAV SWITCHED 13.75VDC" says that this is > indeed a power output pin controlled by the nav receiver's > power switch. There is a Note 7 associated with this > path: > > > [image: Emacs!] > . . . which tells us that this ouput is limited > to 300 ma. > > Probing this pathway with the voltmeter should show > bus voltage with the nav radio ON. This power > comes from the radio and is switched internally > to the radio. If the power is missing on TWO > radios, then it seems likely that the disconnect > is somewhere in the ship's wiring. > > > Bob . . . > ________________________________________________________________________________
Date: Jun 25, 2017
to ki 211c pin a At 11:16 AM 6/25/2017, you wrote: >Thanks Bob, that is where I was heading.=C2 But >it seems odd that the wire pins to tray buzz on >the ohmeter.=C2 Must be doing something wrong. =C2 =C2 Connectors captive to a slide-in tray can be problematic. You may be wrestling with a pin engagement issue . . . and if one path is coming up short, then there may be more. Bob . . . ________________________________________________________________________________
Date: Jun 25, 2017
Subject: David Clarke / SoftComm system for sale
A further reduction in inventory dictates that I give up one of my two-station head-set/intercomm systems. I have the following to offer first to members of the List: DC H10-30 headset (mono) with new gel pads installed DC H10-13x headset (stereo with active noise reduction) with new gel pads installed. SoftComm ACT-2T two station, portable intercomm (one of my favorites). Control Yoke press to talk cable. Offer includes a zippered carry-bag (not shown) that holds one head-set, intercom and cordage. Cordage and general appearance is very good. New batteries installed. ANR box modified for more robust battery configuration (no spring-loaded holders). Will ship with two extra, alkaline battery sets. See at: http://tinyurl.com/yapnz577 Asking $300 for the system. If no takers over the next few days, I'll split the offer into component parts. Email me directly please. Bob . . . ________________________________________________________________________________
From: "William Hunter" <billhuntersemail(at)gmail.com>
Subject: Enclosure For Batt Contactor and Bus Tie
Date: Jun 25, 2017
Hi All, I am installing a bus tie contactor and a battery contactor in an "enclosure" under the rear seat of a composite airplane and I am concerned about the heat produced by these two devices. This enclosure is a "box" of sorts that is constructed with foam core composite material (good insulation properties) and the space is kinda small (about 20" X 10" X 4") and it will not have any airflow whatsoever so I am wondering how hot these two units could get when energized in this enclosed location. I do not intend to have the bus tie closed during flight so when airborne only the battery contactor will be energized however during ground operations I do intend on having both the bus tie and the battery tie closed for maintenance purposes. I have already had them both humming however I have not yet closed the lid to this box. If need be I could construct some kind of cooling air scoop however I would prefer to keep the box fully enclosed.IF.there would not be a fire hazard. THANKS for your feedback and advice. .. Cheers!!! Bill Hunter ________________________________________________________________________________
Subject: Did I Fry My Optima Battery?!?!?
Date: Jun 25, 2017
So.I left my battery charger connected to an Optima battery overnight on the 10 Amp charge position. In the immortal words of Homer Simpson "!!!DOH!!!" The Optima battery can be installed in any position other than upside down and my battery was installed on its side. Well in the morning, I noticed that clear liquid was leaking out of the two small gray ports so I assume that these ports are some kind of vent to release the internal pressure in the instance where some DumbBass left the charger plugged in all night and the battery overheated. I felt the battery was not hot nor even warm however the liquid was definitely dripping out a fair amount. I thought that these things were supposed to be "spill proof" because they are "gel filled". In the past I noticed that when in the battery charger is in the 10 amp position the battery charger only puts out a voltage of about 13.0 volts so I would not have thought that it could cook a battery. How can one (me) determine if the fluid/gel level of an Optima battery is still adequate? I can weigh it and/or I can get it tested at the auto parts store? THANKS for your suggestions/experience/feed back!!! .. Cheers!!! Bill Hunter ________________________________________________________________________________
Date: Jun 25, 2017
Subject: SOLD David Clarke / SoftComm system for sale SOLD
At 03:44 PM 6/25/2017, you wrote: >A further reduction in inventory dictates that >I give up one of my two-station head-set/intercomm >systems. The audio system has sold. Thanks to all who inquired! Bob . . . ________________________________________________________________________________
Date: Jun 25, 2017
Subject: Re: Did I Fry My Optima Battery?!?!?
At 05:39 PM 6/25/2017, you wrote: >So=85I left my battery charger connected to an >Optima battery overnight on the 10 Amp charge >position. In the immortal words of Homer Simpson =93!!!DOH!!!=94 > >The Optima battery can be installed in any >position other than upside down and my battery >was installed on its side. Well in the morning, >I noticed that clear liquid was leaking out of >the two small gray ports so I assume that these >ports are some kind of vent to release the >internal pressure in the instance where some >DumbBass left the charger plugged in all night and the battery overheated. > >I felt the battery was not hot nor even warm >however the liquid was definitely dripping out a fair amount. > >I thought that these things were supposed to be >=93spill proof=94 because they are =93gel filled=94. In >the past I noticed that when in the battery >charger is in the 10 amp position the battery >charger only puts out a voltage of about 13.0 >volts so I would not have thought that it could cook a battery. The 13.0 volt observation seems valid . . . and certainly not enough snort to cook an SVLA battery. Yet, here we are. I would do a cranking load test on it first. Go to a battery store and have them load it DOWN and HOLD at 9 volts for 15 seconds. At the end of 15 seconds, note the current. A new battery of that genre would probably dump 400-600A. This test will normally consume less than 10% of a battery's snort. Follow up with a cap check. Hook a 55W head lamp to the battery and see how long it runs before the voltage drops below 11.0 volts. Again, for a battery of that ilk, 8 to 10 hours is healthy. After the first test, put it on a known-good charger/maintainer and repeat the test. Now, even if it still performs electrically, I wouldn't recommend using it for anything other than ground ops. It's obviously compromised. Optimas are jelly-roll cells with a rich heritage in AGM development and marketing. I'm a bit surprised that this thing leaked 'juice'. Hmmm . . . found these tid-bits on the 'net http://tinyurl.com/ya7lnv5u http://tinyurl.com/yaxbbaxl http://tinyurl.com/ydbpvo5z http://tinyurl.com/y76kk7q9 Seems your experience is not unheard of . . . What is the brand and model number of your battery charger? I have found, disappointingly, that even the masters of battery chargers stub their toe from time to time. I have a 'beefy' automotive charger by Schumacher I bought at Walmart a few years ago. http://tinyurl.com/y7yrzlyk I was evaluating a battery for Hawker-Beech that was purported to be a new, 'carbon foam' device. The sample I was working with was a 100A.h. group 31 truck battery. Needed something much larger than my usual stable of battery charger-maintainers. This thing was supposed to output charging profiles tailored to flooded, gel and AGM batteries. Got to watch the behavior during a dozen or more recharge cycles on the test battery. Frankly, the behaviors in each mode did not match conventional wisdom. I've still got the charger. Used it on the truck a few weeks ago to mitigate a dome-light-discharge event. But in spite of the claims in literature, I would not use this charger for anything but utility recoveries . . . it's not a 'maintainer' in spite of its apparent used of software. It would be interesting to test your charger with instrumentation to see if it might be responsible for your battery's 'accident'. Bob . . . ________________________________________________________________________________
Date: Jun 26, 2017
> Yet, here we are. Yup.THANKS Bob for the words of encouragement. I betcha if I would have had the battery sitting straight up that the "gel" would not have leaked out. .. Cheers!!! Bill Hunter From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Sunday, June 25, 2017 7:36 PM Subject: Re: AeroElectric-List: Did I Fry My Optima Battery?!?!? At 05:39 PM 6/25/2017, you wrote: So.I left my battery charger connected to an Optima battery overnight on the 10 Amp charge position. In the immortal words of Homer Simpson "!!!DOH!!!" The Optima battery can be installed in any position other than upside down and my battery was installed on its side. Well in the morning, I noticed that clear liquid was leaking out of the two small gray ports so I assume that these ports are some kind of vent to release the internal pressure in the instance where some DumbBass left the charger plugged in all night and the battery overheated. I felt the battery was not hot nor even warm however the liquid was definitely dripping out a fair amount. I thought that these things were supposed to be "spill proof" because they are "gel filled". In the past I noticed that when in the battery charger is in the 10 amp position the battery charger only puts out a voltage of about 13.0 volts so I would not have thought that it could cook a battery. The 13.0 volt observation seems valid . . . and certainly not enough snort to cook an SVLA battery. Yet, here we are. I would do a cranking load test on it first. Go to a battery store and have them load it DOWN and HOLD at 9 volts for 15 seconds. At the end of 15 seconds, note the current. A new battery of that genre would probably dump 400-600A. This test will normally consume less than 10% of a battery's snort. Follow up with a cap check. Hook a 55W head lamp to the battery and see how long it runs before the voltage drops below 11.0 volts. Again, for a battery of that ilk, 8 to 10 hours is healthy. After the first test, put it on a known-good charger/maintainer and repeat the test. Now, even if it still performs electrically, I wouldn't recommend using it for anything other than ground ops. It's obviously compromised. Optimas are jelly-roll cells with a rich heritage in AGM development and marketing. I'm a bit surprised that this thing leaked 'juice'. Hmmm . . . found these tid-bits on the 'net http://tinyurl.com/ya7lnv5u http://tinyurl.com/yaxbbaxl http://tinyurl.com/ydbpvo5z http://tinyurl.com/y76kk7q9 Seems your experience is not unheard of . . . What is the brand and model number of your battery charger? I have found, disappointingly, that even the masters of battery chargers stub their toe from time to time. I have a 'beefy' automotive charger by Schumacher I bought at Walmart a few years ago. http://tinyurl.com/y7yrzlyk I was evaluating a battery for Hawker-Beech that was purported to be a new, 'carbon foam' device. The sample I was working with was a 100A.h. group 31 truck battery. Needed something much larger than my usual stable of battery charger-maintainers. This thing was supposed to output charging profiles tailored to flooded, gel and AGM batteries. Got to watch the behavior during a dozen or more recharge cycles on the test battery. Frankly, the behaviors in each mode did not match conventional wisdom. I've still got the charger. Used it on the truck a few weeks ago to mitigate a dome-light-discharge event. But in spite of the claims in literature, I would not use this charger for anything but utility recoveries . . . it's not a 'maintainer' in spite of its apparent used of software. It would be interesting to test your charger with instrumentation to see if it might be responsible for your battery's 'accident'. Bob . . . ________________________________________________________________________________
Date: Jun 26, 2017
At 10:03 AM 6/26/2017, you wrote: > > Yet, here we are. > >Yup=85THANKS Bob for the words of encouragement. > >I betcha if I would have had the battery sitting >straight up that the =93gel=94 would not have leaked out. >.. > Maybe . . . but I've been getting search hits on Optima leaks that do not correlate with laying the battery down. Optima may well be suffering from acquisition creep and often profound if not terminal degradation of value for a product or service. Three patents on jelly-roll cells are found at http://tinyurl.com/y7p26p9l One of these dates to 1943, 73 years ago. Roots of the Optima cells take a genealogic side track when Gates Rubber adapts the idea to the AGM technology with their work Circa 1975. At this time, the contained liquid in the cells was reduced to less than saturation of the glass mat separators. At this time, the cells were, like other SBLA/AGM products, supposed to be 'leak proof'. Drive a nail into them and no liquid comes out. Gates got out of the battery business and their product lines got scattered to the market. Hawker Enersys was interested in the smaller, 2.5 a.h. cells, Optima took on the larger cells. I see that Enersys has expanded their Cyclon jelly-roll line to include the larger, 25 a.h. cells. http://tinyurl.com/yd9z6x89 The Optima line may well have spun off directly from Gates . . . their operations spooled up in Aurora Co, a short distance from the Gats facilities in Colorado. I understand they are owned by Johnson Controls (who also used to do Gel Cells . . . maybe still does) and the factory is moved to Mexico . . . not necessarily a bad thing but it does give rise to questions about why these products have become 'leakers'. B&C offered the Gates 25 a.h. cells . . . I think it was their first venture into AGM technolgy. They had been offering Sonnenschein GELS for some time previous to Gates AGM. I put an array of these cells into the PAT-1 prototype about 1980. Unfortunately, the airplane was lost with three souls aboard during a demonstration flight for NASA. The Gates 25 a.h. cells proved problematic in aircraft . . . the negative terminals were prone to cracking inside the battery . . . the newer Enersys cells are, no doubt, more robust. In any case, leaking from the Optima products is mystifying and surprising. I'll see if I can find out more about it. In the mean time, it's sure bet that your existing battery is not flight worthy. Why did you choose so hefty a battery? Bob . . . ________________________________________________________________________________
Date: Jun 26, 2017
Subject: Solder for Thermocouple splices
Can anyone suggest a specific silver solder product for use in soldering thermocouple wire spices? Ron ________________________________________________________________________________
Date: Jun 26, 2017
From: Robert McCallum <robert.mccallum2(at)sympatico.ca>
Subject: Re: Solder for Thermocouple splices
"Easy-flo 45" from Handy and Harman works well. Bob McC > ---------- Original Message ---------- > From: RWhitt1245(at)aol.com > Date: June 26, 2017 at 12:44 PM > > Can anyone suggest a specific silver solder product for use in soldering > thermocouple wire spices? > > Ron > ________________________________________________________________________________
Date: Jun 27, 2017
Subject: Archer Antenna in RV4
Does anyone have experience installing an Archer Comm antenna in an RV4 wingtip?I'm considering the Archer Model 1A and have concerns that it will fit properly. ARCHER SPORT AIRCRAFT COM ANTENNA MODEL 1A | | | | | | | | | | | ARCHER SPORT AIRCRAFT COM ANTENNA MODEL 1A ARCHER SPORT AIRCRAFT COM ANTENNA MODEL 1A These antennas have been designed by Bob Archer from Torrance, CA uti... | | | | Thanks. Jeff Bertsch ________________________________________________________________________________
From: Stuart Hutchison <stuart(at)stuarthutchison.com.au>
Subject: Re: Archer Antenna in RV4
Date: Jun 28, 2017
I bought one each side for the wing tips of my Rocket Jeff, then learned that only one was practical. In the end, neither was used due to building tip tanks, so both are available for sale. Usually US$100+ each I believe, but I will part with one or other for US$60 each plus shipping. Cheers, Stu > On 27 Jun 2017, at 23:36, Jeff Bertsch wrote: > > Does anyone have experience installing an Archer Comm antenna in an RV4 wingtip? > I'm considering the Archer Model 1A and have concerns that it will fit properly. > > ARCHER SPORT AIRCRAFT COM ANTENNA MODEL 1A <http://www.aircraftspruce.com/catalog/avpages/archer_antenna1.php> > > > > ARCHER SPORT AIRCRAFT COM ANTENNA MODEL 1A > ARCHER SPORT AIRCRAFT COM ANTENNA MODEL 1A These antennas have been designed by Bob Archer from Torrance, CA uti... > <http://www.aircraftspruce.com/catalog/avpages/archer_antenna1.php> > > Thanks. > > Jeff Bertsch ________________________________________________________________________________
Subject: Re: IVO Prop current limiter
Date: Jun 27, 2017
With Bob's prompting to move on to Plan B, I put together an Arduino-based IVOProp "controller." I bought an Arduino clone, a relay module, and a current sensing module, and wrote a program to monitor the prop current. When the current goes above 9 Amps for a sufficiently long time, the program opens the relay and shuts off the current. The red and green LEDS are triggered to indicate the current flowing and not flowing to the prop. The program leaves the relay open and the red LED on for a few seconds so the pilot gets the message that a limit was reached. I just ran the engine and put the prop through its paces, and the system seems to work well. There might be additional tweaking to the code needed, but I think it's pretty close to good. I'll be happy to share the code and links to the components if anyone is interested. -------- Doug Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470523#470523 ________________________________________________________________________________
Date: Jun 27, 2017
Subject: Master contactor catch diode failure
What would be the root cause of this charred diode and wiring? https://i.imgur.com/e3FcBgf.jpg https://i.imgur.com/Sl9foF6.jpg This is in a friend's RV-9A and the diode was wired (properly) across the master contactor's coil. The wire runs to the master switch (split-rocker type) where a ground is applied. Both the contactor and the diode were supplied by Van's Aircraft. http://vansaircraft.com/cgi-bin/store.cgi?ident=1498576754-172-723&browse=electrical&product=master-sw http://vansaircraft.com/cgi-bin/store.cgi?ident=1498576754-172-723&browse=electrical&product=diodes This incident happened the instant the master power was turned on. Could the diode have failed in a shorted condition, vaporizing itself and the wire when the switch applied a ground? After replacing the diode and wiring, operation seems normal. -- Joe ________________________________________________________________________________
Date: Jun 27, 2017
Subject: Re: Master contactor catch diode failure
The most obvious answer is that the original diode was installed backwards. Maybe the supplied "packaged" assembly from Vans was incorrectly assembled under the heat shrink causing full battery voltage and hence current to forward bias the diode leading to its action as a fuse. The new assemblies shown in your photos leave no possible clue as to the direction the encapsulated diode is oriented. The external red band is fine and dandy, but if the diode under the shrink was accidentally reversed there is no way to know without "testing". I would suggest your "test" proved conclusively it was incorrect. Bob McC > > ---------- Original Message ---------- > From: Joe Dubner <jdubner(at)yahoo.com> > Date: June 27, 2017 at 2:55 PM > > > > What would be the root cause of this charred diode and wiring? > > https://i.imgur.com/e3FcBgf.jpg > https://i.imgur.com/Sl9foF6.jpg > > This is in a friend's RV-9A and the diode was wired (properly) across the > master > contactor's coil. The wire runs to the master switch (split-rocker type) > where > a ground is applied. Both the contactor and the diode were supplied by > Van's > Aircraft. > > > http://vansaircraft.com/cgi-bin/store.cgi?ident=1498576754-172-723&browse=electrical&product=master-sw > > http://vansaircraft.com/cgi-bin/store.cgi?ident=1498576754-172-723&browse=electrical&product=diodes > > This incident happened the instant the master power was turned on. Could > the > diode have failed in a shorted condition, vaporizing itself and the wire > when > the switch applied a ground? > > After replacing the diode and wiring, operation seems normal. > > -- > Joe > > > > ________________________________________________________________________________
Subject: Noisy radio system
Date: Jun 27, 2017
OK, here goes. Let me start this by saying I have tried pretty much every trick in the boo k to solve this issue and yes the unit is wired to a high standard with sep arate earth to battery, RG400 antenna cable etc etc etc. I have a Trig radio installed in a Fairchild F24 with 145hp Warner engine. It is constantly breaking squelch even with the internal squelch wound righ t up. I have improved it by a huge amount but it is still pretty bad and at high RPM makes the radio essentially useless. It is an unshielded ignition harness so this is a good portion of the probl em but I wondered if anyone may have any other ideas. Oh, by the way, the n oise is coming in via the antenna as it goes away when the antenna is disco nnected. Things that have improved considerably were, taking a ferrite ring and loop ing the antenna cable through it 4 times. more doesn't help and less doesn' t help. Also changed to automotive plugs and resistor caps (5kOhm) which he lped. I get the impression that if I up the resistance a little further by going to resistor plugs or leads that we may solve the problem but I'm concerned about loading the windings in the mag to much and burning them out, would r unning 5kOhm resistor plugs or resistance leads load the mags too much? I will get a reduction in spark quality which may be unacceptable and cause fouling but what do you guys think, worth a shot. Last parting shot. The owner did the antenna install and it is an internal antenna surrounded by the steel tube fuselage and this probably isn't helpi ng. Worth trying an external antenna, although difficult to do at this stag e with a finished aeroplane (fabric), I may be able to fit to one of the wi ng route fairings to get a halfway decent ground plane. Cheers, Ryan ________________________________________________________________________________
Date: Jun 27, 2017
Bob McC wrote: > The most obvious answer is that the original diode was installed backwards. That was my initial thought too but the aircraft had 29 hours TTSN with that configuration. The RV-9A owner told me this incident happened on the first master switch actuation after battery replacement due to a totally discharged battery. There was a battery charger involved but the owner assured me it was always connected properly. And the master contactor actuated, at least momentarily, because the Dynon EFIS turned on (and continued to run on its internal battery). Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470527#470527 ________________________________________________________________________________
Date: Jun 27, 2017
> Does anyone have experience installing an Archer Comm antenna in an RV4 wingtip? > I'm considering the Archer Model 1A and have concerns that it will fit properly. Jeff, I have the Archer NAVantenna mounted in my RV-8A's wingtip, which I believe is similar if not identical to that of the RV-4. So taking your question literally, I would say it will fit OK. However . . . you didn't ask but I advise against it because of the performance hit of the mostly horizontally-oriented antenna while VHF com requires vertical polarization. When I ran out of space for vertically-polarized antennas on the bottom of my '8A, I mounted one on the bottom of a wing. The ground plane is larger and there's plenty of separation for multiple antennas. -- Joe -------- RV-8A Independence, OR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470531#470531 ________________________________________________________________________________
Date: Jun 27, 2017
I would agree. I have one Archer Nav antenna in each wing tip to serve 2 navcoms. Performance is okay. While my -10 has big enough wing tips to do a vertical com, I wouldn't. A friend put one in -7 wingtip and it was good for maybe 20 miles until he had the plane painted with a metallic paint. Performance dropped to under 10 miles, so he abandoned and put antenna on a convenient wing inspection plate. On 6/27/2017 2:40 PM, jdubner wrote: > > >> Does anyone have experience installing an Archer Comm antenna in an RV4 wingtip? >> I'm considering the Archer Model 1A and have concerns that it will fit properly. > > Jeff, I have the Archer NAVantenna mounted in my RV-8A's wingtip, which I believe is similar if not identical to that of the RV-4. So taking your question literally, I would say it will fit OK. > > However . . . you didn't ask but I advise against it because of the performance hit of the mostly horizontally-oriented antenna while VHF com requires vertical polarization. > > When I ran out of space for vertically-polarized antennas on the bottom of my '8A, I mounted one on the bottom of a wing. The ground plane is larger and there's plenty of separation for multiple antennas. > > -- > Joe > > -------- > RV-8A > Independence, OR > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=470531#470531 > > > > > > > > > ________________________________________________________________________________
Date: Jun 28, 2017
At 02:52 PM 6/27/2017, you wrote: >The most obvious answer is that the original diode was installed >backwards. Maybe the supplied "packaged" assembly from Vans was >incorrectly assembled under the heat shrink causing full battery >voltage and hence current to forward bias the diode leading to its >action as a fuse. The new assemblies shown in your photos leave no >possible clue as to the direction the encapsulated diode is >oriented. The external red band is fine and dandy, but if the diode >under the shrink was accidentally reversed there is no way to know >without "testing". I would suggest your "test" proved conclusively >it was incorrect. Agreed . . . with one other possibility . . . I have encountered plastic diodes that were incorrectly marked. Band on the wrong end. It's rare but I think I've seen it a couple of times. Further, they were a one-of event, not a 'batch' problem. I'm not sure this is possible but it's certainly low probability given modern manufacturing and grading techniques for diodes. But these days, there are diodes and then there are DIODES. Without knowing the critter's pedigree, we'll never know. In any case, replacing the diode is the permanent fix. Bob . . . ________________________________________________________________________________
Date: Jun 28, 2017
At 01:37 PM 6/27/2017, you wrote: > >With Bob's prompting to move on to Plan B, I put together an >Arduino-based IVOProp "controller." > >I bought an Arduino clone, a relay module, and a current sensing >module, and wrote a program to monitor the prop current. When the >current goes above 9 Amps for a sufficiently long time, the program >opens the relay and shuts off the current. The red and green LEDS >are triggered to indicate the current flowing and not flowing to the >prop. The program leaves the relay open and the red LED on for a >few seconds so the pilot gets the message that a limit was reached. > >I just ran the engine and put the prop through its paces, and the >system seems to work well. There might be additional tweaking to >the code needed, but I think it's pretty close to good. GOOD for YOU! >I'll be happy to share the code and links to the components if >anyone is interested. Yes, I'd be interested in seeing your work. Bob . . . ________________________________________________________________________________
Subject: Re: Noisy radio system
Date: Jun 28, 2017
Someone may correct me if wrong, but adding resistance to a circuit decreases the current. Therefore adding resistance will decrease the load on magnetos. An external antenna is a good idea. The ground plane does not necessarily have to be sheet metal. A ground plane can be made using 6 or 8 radials of copper tape or wire that are glued to the fabric. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470545#470545 ________________________________________________________________________________
Date: Jun 28, 2017
I would also like to take a look at your setup. I am planning on using an IVO mag prop with in flight adj. Was hoping to do just what you have already done. Way ahead of me!!!! Merle > I'll be happy to share the code and links to the components if anyone is interested. hmmm, seems I screwed up the quoting somehow.. -------- KC1DNJ General Radiotelephone Commercial SEL A&P Building scale P51 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470546#470546 ________________________________________________________________________________
From: William Hunter <billhuntersemail(at)gmail.com>
Date: Jun 28, 2017
How does one (me) check a diode when it is installed on the contactor? I assume that you want to have the master switch off and use DC resistance. Does it matter what polarity to connect the leads? Thanks, Bill Hunter At 02:52 PM 6/27/2017, you wrote: The most obvious answer is that the original diode was installed backwards. Maybe the supplied "packaged" assembly from Vans was incorrectly assembled under the heat shrink causing full battery voltage and hence current to forward bias the diode leading to its action as a fuse. The new assemblies shown in your photos leave no possible clue as to the direction the encapsulated diode is oriented. The external red band is fine and dandy, but if the diode under the shrink was accidentally reversed there is no way to know without "testing". I would suggest your "test" proved conclusively it was incorrect. Agreed . . . with one other possibility . . . I have encountered plastic diodes that were incorrectly marked. Band on the wrong end. It's rare but I think I've seen it a couple of times. Further, they were a one-of event, not a 'batch' problem. I'm not sure this is possible but it's certainly low probability given modern manufacturing and grading techniques for diodes. But these days, there are diodes and then there are DIODES. Without knowing the critter's pedigree, we'll never know. In any case, replacing the diode is the permanent fix. Bob . . . ________________________________________________________________________________
Date: Jun 28, 2017
At 09:20 AM 6/28/2017, you wrote: >How does one (me) check a diode when it is installed on the contactor? Just unhook one end (the small terminal) and use your ohmmeter function to test continuity through the diode. One configuration will show SOME value of resistance, reversing the leads will show infinite resistance. >I assume that you want to have the master switch off and use DC >resistance. Does it matter what polarity to connect the leads? You test BOTH ways . . . looking for basically NO conduction one way (off scale high resistance) and some value of resistance the other way . . . the exact value unimportant as it will vary from one ohmmeter to another. Bob . . . ________________________________________________________________________________
Date: Jun 28, 2017
At 04:16 PM 6/27/2017, you wrote: > > >Bob McC wrote: > > The most obvious answer is that the original diode was installed backwards. > >That was my initial thought too but the aircraft had 29 hours TTSN >with that configuration. > >The RV-9A owner told me this incident happened on the first master >switch actuation after battery replacement due to a totally >discharged battery. THIS IS NOT GOOD . . . If the diode WAS good and fried after battery replacement, then the battery was hooked up BACKWARDS . . . This fries the catch diode and potentially, lots of other stuff. Years ago, I used to recommend adding a fuse in series with the battery master contactor wire that runs off to the master switch. When paired with a catch diode on the contactor the diode shorts out reversed voltage to the contactor preventing closure while the fuse blows preventing wire damage . . . and perhaps damage to the diode as well. But it sounds like this event went on long enough to open the diode, close the contactor and to put battery energy onto the ship's bus . . . Bob . . . ________________________________________________________________________________
Date: Jun 28, 2017
Thanks, Also, how warm do contactors get when they are energized? I have two contactors mounted in a well underneath the backseat of my airplane. This well is about three inches deep 20 inches wide and 12 inches long and it's completely sealed with no cooling air and since it is constructed of foam core fiberglass It is Well insulated and therefore none of the heat can get conducted out of the airplane. I felt them and the contactors do get warm but the question is how warm can they get and do they need any cooling air? Inflight only one contactor will be energized however on the ground during maintenance I will have both contactors energized. THANKS AGAIN FOR YOUR HELP Bill Hunter On Jun 28, 2017 12:44 PM, "Robert L. Nuckolls, III" < nuckolls.bob(at)aeroelectric.com> wrote: > At 09:20 AM 6/28/2017, you wrote: > > How does one (me) check a diode when it is installed on the contactor? > > > Just unhook one end (the small terminal) and use > your ohmmeter function to test continuity through > the diode. One configuration will show SOME value > of resistance, reversing the leads will show > infinite resistance. > > > I assume that you want to have the master switch off and use DC > resistance. Does it matter what polarity to connect the leads? > > > You test BOTH ways . . . looking for basically > NO conduction one way (off scale high resistance) > and some value of resistance the other way . . . > the exact value unimportant as it will vary > from one ohmmeter to another. > > Bob . . . > ________________________________________________________________________________
Date: Jun 28, 2017
I'll get the info posted next week. -------- Doug Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470559#470559 ________________________________________________________________________________
Date: Jun 28, 2017
At 02:50 PM 6/28/2017, you wrote: >Thanks, > >Also, how warm do contactors get when they are energized? Too hot to touch but not hot enough to 'sizzle spit' http://tinyurl.com/mpcgp3t http://tinyurl.com/k6bwdqo >I have two contactors mounted in a well >underneath the backseat of my airplane.=C2 This >well is about three inches deep 20 inches wide >and 12 inches long and it's completely sealed >with no cooling air and since it is constructed >of foam core fiberglass It is Well insulated and >therefore none of the heat can get conducted out of the airplane. > >I felt them and the contactors do get warm but >the question is how warm can they get and do >they need any cooling air? Inflight only one >contactor will be energized however on the >ground during maintenance I will have both contactors energized. > >THANKS AGAIN FOR YOUR HELP Materials used in construction of these devices is rated for operating at temperatures well in excess of 100C . . . but of course, hotter than you would want to touch. Bob . . . ________________________________________________________________________________
Date: Jun 28, 2017
At 03:00 PM 6/28/2017, you wrote: > >I'll get the info posted next week. This might be another opportunity for an open source project. Once you've finely tuned the code, we can poke it into chips for mounting on a dedicated ecb . . . have you considered solid-state switching as opposed to relay? Bob . . . ________________________________________________________________________________
Date: Jun 28, 2017
Thanks Bob!!! The next time I have them humming for two hours at room temperature I will lick them to see if spit sizzles. Thanks again, Bill Hunter On Jun 28, 2017 1:15 PM, "Robert L. Nuckolls, III" < nuckolls.bob(at)aeroelectric.com> wrote: > At 02:50 PM 6/28/2017, you wrote: > > Thanks, > > Also, how warm do contactors get when they are energized? > > > Too hot to touch but not hot enough to 'sizzle spit' > > http://tinyurl.com/mpcgp3t > > http://tinyurl.com/k6bwdqo > > > I have two contactors mounted in a well underneath the backseat of my > airplane.=C3=82 This well is about three inches deep 20 inches wide and 12 > inches long and it's completely sealed with no cooling air and since it i s > constructed of foam core fiberglass It is Well insulated and therefore no ne > of the heat can get conducted out of the airplane. > > I felt them and the contactors do get warm but the question is how warm > can they get and do they need any cooling air? Inflight only one contacto r > will be energized however on the ground during maintenance I will have bo th > contactors energized. > > THANKS AGAIN FOR YOUR HELP > > > Materials used in construction of these devices > is rated for operating at temperatures well in > excess of 100C . . . but of course, hotter than > you would want to touch. > > > Bob . . . > ________________________________________________________________________________
Date: Jun 28, 2017
Do be aware that the temp it will get a *lot* hotter in your sealed up insulated box than it will sitting on your kitchen counter. I wouldn't do what you're talking about, because I wouldn't want to melt my aircraft in that area. Component life might be a secondary issue, in this case (pardon the pun). On 6/28/2017 3:48 PM, William Hunter wrote: > > Thanks Bob!!! > > The next time I have them humming for two hours at room temperature I > will lick them to see if spit sizzles. > > Thanks again, > > Bill Hunter > > On Jun 28, 2017 1:15 PM, "Robert L. Nuckolls, III" > > > wrote: > > At 02:50 PM 6/28/2017, you wrote: > >> Thanks, >> >> Also, how warm do contactors get when they are energized? > > Too hot to touch but not hot enough to 'sizzle spit' > > http://tinyurl.com/mpcgp3t > > http://tinyurl.com/k6bwdqo > > > <http://tinyurl.com/k6bwdqo> >> I have two contactors mounted in a well underneath the backseat >> of my airplane. This well is about three inches deep 20 inches >> wide and 12 inches long and it's completely sealed with no >> cooling air and since it is constructed of foam core fiberglass >> It is Well insulated and therefore none of the heat can get >> conducted out of the airplane. >> >> I felt them and the contactors do get warm but the question is >> how warm can they get and do they need any cooling air? Inflight >> only one contactor will be energized however on the ground during >> maintenance I will have both contactors energized. >> >> THANKS AGAIN FOR YOUR HELP > > Materials used in construction of these devices > is rated for operating at temperatures well in > excess of 100C . . . but of course, hotter than > you would want to touch. > > > Bob . . . > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jun 28, 2017
I agree with Charlie. The heat given off by a fire (caused by hot contactors) will be a whole lot hotter than the heat given off by contactors exposed to circulating air. What is the purpose of an insulated box? At what temperature will the diode start conducting in the reverse direction? Nobody knows how hot it will get inside of the box because it depends on several factors: size of box, how well it is sealed, insulating properties of the box, ambient air temperature, wattage of the contactor, length of time contactor is energized. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470566#470566 ________________________________________________________________________________
Date: Jun 28, 2017
I appreciate everyone's opinions and suggestions!!! The airplane is a Velocity (pusher) so it is constructed of fiberglass foam sandwich panels and I was trying to move as much of the heavy electrical cables aft closer to the engine so I placed these components under the rear bench seat. The rear seat "pedestal" (support structure) is a fiberglass box integral with the fuselage also constructed with fiberglass foam sandwich panels that equate to an "enclosed box". I thought that this was an "elegant solution" to utilize this empty space as an electrical equipment box however I didn't really think about the BTU output of these contactors. I guess I could cut some vent openings into the pedestal and that would introduce some cabin ambient air into the box (four feet away from the heater floor vents) however this would not be forced air ventilation but still much better than an enclosed, sealed, and very insulated box. Thanks, Bill Hunter On Jun 28, 2017 5:37 PM, "user9253" wrote: > > I agree with Charlie. The heat given off by a fire (caused by hot > contactors) will be a whole lot hotter than the heat given off by > contactors exposed to circulating air. What is the purpose of an insulated > box? > At what temperature will the diode start conducting in the reverse > direction? Nobody knows how hot it will get inside of the box because it > depends on several factors: size of box, how well it is sealed, insulating > properties of the box, ambient air temperature, wattage of the contactor, > length of time contactor is energized. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=470566#470566 > > ________________________________________________________________________________
Date: Jun 28, 2017
I would put the battery contactor as close to the battery as possible and the starter contactor on thd engine side of the firewall. This is how the RV 10 is done, battery in rear battery contactor inches away and starter contactor on the front of the firewall. I realize that your are building a pusher but this will work fine. This also keeps the heay generating contactors out in the open and seperated from each other. On Jun 28, 2017 18:37, "William Hunter" wrote: > I appreciate everyone's opinions and suggestions!!! > > The airplane is a Velocity (pusher) so it is constructed of fiberglass > foam sandwich panels and I was trying to move as much of the heavy > electrical cables aft closer to the engine so I placed these components > under the rear bench seat. The rear seat "pedestal" (support structure) is > a fiberglass box integral with the fuselage also constructed with > fiberglass foam sandwich panels that equate to an "enclosed box". > > I thought that this was an "elegant solution" to utilize this empty space > as an electrical equipment box however I didn't really think about the BTU > output of these contactors. > > I guess I could cut some vent openings into the pedestal and that would > introduce some cabin ambient air into the box (four feet away from the > heater floor vents) however this would not be forced air ventilation but > still much better than an enclosed, sealed, and very insulated box. > > Thanks, > > Bill Hunter > On Jun 28, 2017 5:37 PM, "user9253" wrote: > >> >> I agree with Charlie. The heat given off by a fire (caused by hot >> contactors) will be a whole lot hotter than the heat given off by >> contactors exposed to circulating air. What is the purpose of an insulated >> box? >> At what temperature will the diode start conducting in the reverse >> direction? Nobody knows how hot it will get inside of the box because it >> depends on several factors: size of box, how well it is sealed, insulating >> properties of the box, ambient air temperature, wattage of the contactor, >> length of time contactor is energized. >> >> -------- >> Joe Gores >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=470566#470566 >> >> >> >> >> >> >> =================================== >> - >> Electric-List" rel="noreferrer" target="_blank">http://www.matronics.com/ >> Navigator?AeroElectric-List >> =================================== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> =================================== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> =================================== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >> =================================== >> >> >> >> ________________________________________________________________________________
Date: Jun 29, 2017
At 09:36 PM 6/28/2017, you wrote: >I would put the battery contactor as close to the battery as >possible and the starter contactor on thd engine side of the >firewall. This is how the RV 10 is done, battery in rear battery >contactor inches away and starter contactor on the front of the >firewall. I realize that your are building a pusher but this will >work fine. This also keeps the heay generating contactors out in the >open and seperated from each other. I like that . . . Starter contactors on firewall become a tie-point for the altenrator's b-lead to tie into the fat-wire system. Battery contactors are generally only inches away from Battery(+). Bob . . . ________________________________________________________________________________
Date: Jun 29, 2017
I am using your Z-14 dual alternator and dual battery design with the batte ries under the pilot and copilot seats, battery contactor within 6 inches o f battery.=C2- The crossover contactor and starter contactor on firewall with 2 inch crossover connection to starter contactor.=C2- Alternator B-l eads connect to crossover input=C2-and starter input=C2-lead.=C2- Ove rvoltage connections just before connection to contactors.=C2- Any issues you can foresee? Bob Reed From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> To: aeroelectric-list(at)matronics.com Sent: Thursday, June 29, 2017 6:48 AM Subject: Re: AeroElectric-List: Re: Master contactor catch diode failure At 09:36 PM 6/28/2017, you wrote: I would put the batterycontactor as close to the battery as possible and th e starter contactoron thd engine side of the firewall. This is how the RV 1 0 is done,battery in rear battery contactor inches away and starter contact or onthe front of the firewall. I realize that your are building a pusher b utthis will work fine. This also keeps the heay generating contactors outin the open and seperated from each other. =C2- I like that . . . =C2- Starter contactors on firewall become atie-point =C2- for the altenrator's b-lead to tie into the fat-wire =C2- system. Battery contactors are generally only =C2- inches away from Battery(+). =C2- Bob . . . ________________________________________________________________________________
Date: Jun 29, 2017
At 08:56 AM 6/29/2017, you wrote: >I am using your Z-14 dual alternator and dual battery design with >the batteries under the pilot and copilot seats, battery contactor >within 6 inches of battery. Okay > The crossover contactor and starter contactor on firewall with 2 > inch crossover connection to starter contactor. Okay >Alternator B-leads connect to crossover input and starter input lead. Okay
May 21, 2017 - June 29, 2017
AeroElectric-Archive.digest.vol-nx
